Kolb-Archive.digest.vol-kz
December 29, 2010 - January 20, 2011
Date: Dec 29, 2010
Subject: Re: power loss
Ted, Sounds like you have most of the bases covered already. I hope you don't find any metal transfer when you look at the exhaust side of the piston. All I can think to add is carb ice or a split in the carb connector. Good luck. Rick Girard On Wed, Dec 29, 2010 at 5:35 AM, Ted Cowan wrote: > > hello all, hope you had a great holiday season so far. got a question for > someone smarter than I. I know and understand rotax engines but this is > more for a hirth 3503. Friend has one that ran great and then after several > times just taxiing, started acting up. first it would just stop and then > get where it required the enrichers to be on. it will not go past 3000 rpm > which should be more at 6000. I picked up the carb needles and it would run > without the enrichers being on, idle also. helped but not cure. we are > going to put the old larger main jets in and see. it feels as though the > prop is pitched too high, dead throttle the last quarter. if it were a > rotax, I would suspect stuck rings. checked plugs which were black soot and > wet, no carbon build up. it ran great in the air before then but I suspect > he might have overheated it on the ground taxiing. gauges did not work well > so I really dont know. got to pull the exhaust and see what I see and of > course, do a comp test today. any more ideas? dont want to tear this piece > of work down. if it were up to me to send it somewhere, it would be to the > dump. my good friend cannot afford a new engine or another engine or to > rebuild this on. I love my little 912 even with the rum rum. all ideas > welcome even off list. by the way, I get about the same rpm and speed that > the jabiru SS does. we should fly together and see one day. ted cowan, > slingshot, 912ul, rum rum. > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Subject: Re: Christmas Day flight
Date: Dec 29, 2010
Hi Eddie, Great pics. Nice looking plane. I like the red struts. They really pick out the line. Mine is red/white also but not as neat as yours. The weather has broken down here in the south. Roads are clear and all snow is gone. Floods to look forward to now I suppose. Not forgetting the fact that we shall probably get the tailend of the snow now falling in American East Coast in about a week. Cheers and have a good New Year Pat By the way did you read my `Parlez-vous franglais` letter in Microlight Flying?. Caused a few chuckles on my field. ________________________________________________________________________________
Subject: Re: 912 Tach Malfunction
Date: Dec 29, 2010
From: "Kirby, Dennis Civ USAF AFMC AFNWC/EN" <Dennis.Kirby(at)kirtland.af.mil>
<< The tach needle was jumping around erratically on my Mark-3 >> Kolb Friends - Here's a quick update on my erratic tach situation: It turned out to be a simple matter of corrosion on the tach terminals. Easy fix - I just pulled off each of the three electrical terminals on the back of the tachometer, then re-attached them to achieve positive contact again. On close inspection of the terminal posts, I could see a slight surface coating of corrosion - probably leftover from my salt flats landing in 2006. (ugh) Flew the airplane, and the tach worked just fine. Am glad I did not have to open up to instrument to investigate the innards. My thanks to Dana, Rick G, Mike W, Boyd and Cap'n Ron for your various ideas and thoughts. It's what makes this List so valuable. Dennis K. New Mexico ________________________________________________________________________________
Date: Dec 29, 2010
Subject: Re: Sonex or GP VW
George I don't think the direct drive Generac option is a good choice for at least two reasons. First, it doesn't sound like you will be happy with the performance if it will even fly. Another reason is the ability of that engine to accept a direct drive prop. My experience with the VW conversion indicates that there was a long and checkered development process in getting a reliable engine. The first concern is a prop hub attachment. Does anyone make a prop hub for direct attachment to the Generac? Next is how will the Generac handle the gyroscopic and harmonic loads of a direct drive prop? VWs had to change to forged crankshafts with a hardened key way and a custom deep drilled and taped prop mounting bolt hole to handle the harmonic loads and then they require only wood props. Also this is with a engine that has fairly even firing pulses. The Generac has two cylinders in a V configuration. This is not a good choice for driving a prop. I know Valley had to develop a custom one way slipping redrive to handle the Generac's nasty harmonics. To handle the gyroscopic loads most VW engines now use a custom main bearing machined into the prop end of the engine case. It is four or five times the surface area of the original. Oh yes and one final issue is the thrust loading on the crank. Besides that no big deal go for it. Again as always worth what you paid for it. Rick Neilsen 1st Redrive VW powered MKIIIC On Wed, Dec 29, 2010 at 5:15 AM, George Bearden wrote: > > > Direct drive Kolbs do not do well and have never performed well on any > model Kolb. > > I hear you, but would like a few more details. I have been following this > thread because I have a Kolb FS-1. I read about the Kolb powered by the > Generac, and the struggles Mr. young had. He said his plane (FSII) weighed > in at 435 dry and empty. I *think* mine will come in between 280-300# with > Generac (if I go that way). I have been considering trying out the Generac > direct-drive on there. > > > When compared to an engine with a reduction drive, there is a marked > performance increase with reduction drives. > > I understand that this will cost me performance. I am just wondering how > much. I can/probably will get a PSRU, but want to look at direct-drive > before giving up on it. Would any of you care to throw out some guesses as > to how it would perform? I weigh a lil more than 210# but getting lighter > as > we speak. > > > As a direct drive Kolbster,I could not agree with you more. > > G.Aman > > Mr. Aman! What kind of setup do you have? > > > Faith is believing what you know ain't so - Mark Twain > > Mark Twain had a lot of things right, but a man such as himself isn't > qualified to speak on 'faith'. He doesn't know diddly about it. But I > respect your right to quote him, and would fight to the death to protect my > right to needle you about it a lil bit. :-) > > "Faith is taking the first step even when you don't see the whole > staircase". > - Martin Luther King, Jr. > > And I would add, "particularly when you know who built it" > > GeoB > > ________________________________________________________________________________
Date: Dec 29, 2010
George, Had a FS2 with 503 which of course is redrive equipped.I now fly a MK3C jab iru 2200a direct drive w/Sensenich wood prop.It is slower than a redrive mk 3 912ul although both are 80 hp.I love this engine but it makes a lot of no ise.My most desired setup would be Jabiru w/PSRU which Jabiru could do beca use the case is CNC milled from billet stock,they could put attach surfaces on the case easily IMHO. G.Aman MK-3-C Jabiru 2200A Sensenich 600hrs -----Original Message----- From: George Bearden <gab16(at)sbcglobal.net> Sent: Wed, Dec 29, 2010 5:23 am Subject: Kolb-List: Re: Sonex or GP VW > Direct drive Kolbs do not do well and have never performed well on any model Kolb. I hear you, but would like a few more details. I have been following this thread because I have a Kolb FS-1. I read about the Kolb powered by the Generac, and the struggles Mr. young had. He said his plane (FSII) weighed in at 435 dry and empty. I *think* mine will come in between 280-300# with Generac (if I go that way). I have been considering trying out the Generac direct-drive on there. > When compared to an engine with a reduction drive, there is a marked performance increase with reduction drives. I understand that this will cost me performance. I am just wondering how much. I can/probably will get a PSRU, but want to look at direct-drive before giving up on it. Would any of you care to throw out some guesses as to how it would perform? I weigh a lil more than 210# but getting lighter a s we speak. > As a direct drive Kolbster,I could not agree with you more. > G.Aman Mr. Aman! What kind of setup do you have? > Faith is believing what you know ain't so - Mark Twain Mark Twain had a lot of things right, but a man such as himself isn't qualified to speak on 'faith'. He doesn't know diddly about it. But I respect your right to quote him, and would fight to the death to protect my right to needle you about it a lil bit. :-) "Faith is taking the first step even when you don't see the whole staircase". - Martin Luther King, Jr. And I would add, "particularly when you know who built it" GeoB ________________________________________________________________________________
Date: Dec 29, 2010
Ted, Check exhaust system. -----Original Message----- From: Ted Cowan <tc1917(at)bellsouth.net> Sent: Wed, Dec 29, 2010 6:39 am Subject: Kolb-List: power loss hello all, hope you had a great holiday season so far. got a question for someone smarter than I. I know and understand rotax engines but this is more for a hirth 3503. Friend has one that ran great and then after severa l times just taxiing, started acting up. first it would just stop and then get where it required the enrichers to be on. it will not go past 3000 rpm which should be more at 6000. I picked up the carb needles and it would ru n without the enrichers being on, idle also. helped but not cure. we are going to put the old larger main jets in and see. it feels as though the prop is pitched too high, dead throttle the last quarter. if it were a rotax, I would suspect stuck rings. checked plugs which were black soot an d wet, no carbon build up. it ran great in the air before then but I suspect he might have overheated it on the ground taxiing. gauges did not work wel l so I really dont know. got to pull the exhaust and see what I see and of course, do a comp test today. any more ideas? dont want to tear this piec e of work down. if it were up to me to send it somewhere, it would be to the dump. my good friend cannot afford a new engine or another engine or to rebuild this on. I love my little 912 even with the rum rum. all ideas welcome even off list. by the way, I get about the same rpm and speed that the jabiru SS does. we should fly together and see one day. ted cowan, slingshot, 912ul, rum rum. ________________________________________________________________________________
Subject: Re: to Kolb/Jabiru guys...
Date: Dec 29, 2010
HI Guys, I got my Jabiru 2200 started yesterday for the first time since I purchased it- 3 years ago!. YEAH.. But, I had fuel going from the carb clear line into the air filter and then dripping out onto the plane , so the engine run was short. Can someone confirm that this line is the overflow from the bowl as the schematics I have don't show it. I believe that this is just like the issue Chris had where the float needle valve is not functioning correctly and overflowing the float bowl. I have the Bing 94/40, standard for engine # 902. I think that sitting around for three years may have gummed up the float needle valve, and will take it apart and clean it and also check for wear like chris suggested. I'll look for a pink tip. Any other advise?? while I'm doing this. The solenode issue was solved and once started the Jab ran smoothly at idle power. I did not get to run it up due to the fuel drip issue. One step closer to flight! Frank D M3X , 0hrs, Jab 2200 started! Fuel dripping. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=324930#324930 ________________________________________________________________________________
Date: Dec 29, 2010
Frank, That line is a bowl vent.It insures that the atmospheric pressure on the fu el in the bowl is the same as the pressure of the air at the carb air inlet .If fuel comes out of that line, the the seal at needle and seat is faulty. A microscopic fiber can cause the problem.Keep a good filter between fuel t ank and carb and a soft tipped needle if you still have a brass one. G.Aman -----Original Message----- From: Frankd <frankd(at)foundrynet.com> Sent: Wed, Dec 29, 2010 1:08 pm Subject: Kolb-List: Re: to Kolb/Jabiru guys... HI Guys, I got my Jabiru 2200 started yesterday for the first time since I purchased it- 3 years ago!. YEAH.. But, I had fuel going from the carb clear line into the air filter and then dripping out onto the plane , so the engine run was short. Can someone confirm that this line is the overflow from the bowl as the schematics I have don't show it. I believe that this is just like the issue Chris had where the float needle valve is not functioning correctly and overflowing the float bowl. I have the Bing 94/40, standard for engine # 902. I think that sitting arou nd for three years may have gummed up the float needle valve, and will take it apart and clean it and also check for wear like chris suggested. I'll look for a pink tip. Any other advise?? while I'm doing this. The solenode issue was solved and once started the Jab ran smoothly at idle power. I did not get to run it up due to the fuel drip issue. One step closer to flight! Frank D M3X , 0hrs, Jab 2200 started! Fuel dripping. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=324930#324930 ________________________________________________________________________________
Date: Dec 29, 2010
One of the Generac's attractions for me is that it's designed from the start as an industrial, run all day at rated power, almost any kind of load type of engine. While the power pulses are uneven & may give a reduction drive fits, the engine & in particular the crank should handle almost anything short of a serious resonance issue. VW & other auto engines were never designed to take side loads on the end of the crank, but the Generac crank has a pulley mounted to it in many applications (exception would be direct drive generators). I could be wrong, but I would think that a wood prop on a direct drive Generac would present less load than the crank sees while driving 4 feet of steel blades through ant hills, small logs, etc with the load transferred to the crank through a cantilevered pulley. FWIW, Charlie On 12/29/2010 10:06 AM, Rick Neilsen wrote: > George > I don't think the direct drive Generac option is a good choice for at > least two reasons. First, it doesn't sound like you will be happy with > the performance if it will even fly. > Another reason is the ability of that engine to accept a direct drive > prop. My experience with the VW conversion indicates that there was a > long and checkered development process in getting a reliable engine. > The first concern is a prop hub attachment. Does anyone make a prop > hub for direct attachment to the Generac? > Next is how will the Generac handle the gyroscopic and harmonic loads > of a direct drive prop? VWs had to change to forged crankshafts with a > hardened key way and a custom deep drilled and taped prop mounting > bolt hole to handle the harmonic loads and then they require only wood > props. Also this is with a engine that has fairly even firing pulses. > The Generac has two cylinders in a V configuration. This is not a good > choice for driving a prop. I know Valley had to develop a custom one > way slipping redrive to handle the Generac's nasty harmonics. To > handle the gyroscopic loads most VW engines now use a custom main > bearing machined into the prop end of the engine case. It is four or > five times the surface area of the original. Oh yes and one final > issue is the thrust loading on the crank. > Besides that no big deal go for it. > Again as always worth what you paid for it. > Rick Neilsen > 1st Redrive VW powered MKIIIC > > On Wed, Dec 29, 2010 at 5:15 AM, George Bearden > wrote: > > > > > > Direct drive Kolbs do not do well and have never performed well > on any > model Kolb. > > I hear you, but would like a few more details. I have been > following this > thread because I have a Kolb FS-1. I read about the Kolb powered > by the > Generac, and the struggles Mr. young had. He said his plane (FSII) > weighed > in at 435 dry and empty. I *think* mine will come in between > 280-300# with > Generac (if I go that way). I have been considering trying out the > Generac > direct-drive on there. > > > When compared to an engine with a reduction drive, there is a marked > performance increase with reduction drives. > > I understand that this will cost me performance. I am just > wondering how > much. I can/probably will get a PSRU, but want to look at direct-drive > before giving up on it. Would any of you care to throw out some > guesses as > to how it would perform? I weigh a lil more than 210# but getting > lighter as > we speak. > > > As a direct drive Kolbster,I could not agree with you more. > > G.Aman > > Mr. Aman! What kind of setup do you have? > > > Faith is believing what you know ain't so - Mark Twain > > Mark Twain had a lot of things right, but a man such as himself isn't > qualified to speak on 'faith'. He doesn't know diddly about it. But I > respect your right to quote him, and would fight to the death to > protect my > right to needle you about it a lil bit. :-) > > "Faith is taking the first step even when you don't see the whole > staircase". > - Martin Luther King, Jr. > > And I would add, "particularly when you know who built it" > ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 12 Msgs - 12/29/10
Date: Dec 30, 2010
loss of power and squirting gas on the block on hirth 3503. replaced main jets to original larger jets, checked comp pressure, 150 psi each cylinder, changed spark plugs and removed badly stretched cht ring. engine ran good, right to max rpm. dont know for sure which one did it but it is done. I suspect the compression was being lost on front cyl. to the extent that it was being dragged and could not produce enough power after 3000 rpm. anyway, you can put those results in your mind next time you have a problem and think you lost the rings or whatever in your kolb. I know my old 447 had ice once and I thought I messed up a piston but it was just carb ice. hit the carb enricher and it bucked and coughed but cleared it. buddy said it sounded like hell from the ground but I think he was talking about my heart! anyway, thanks for listening. things might not be what they seem sometimes. ted cowan, SS 912UL zoom zoom ________________________________________________________________________________
Date: Dec 30, 2010
Hi Everyone, I got her going yesterday with the new float needle valve and she seems to run good....taxiing out I thought it stumbled for a second and returned to the hangar to run it up again,but all sounded good, so up I went. I ended up taking the carb off to install the new needle and will remove if it has to be done again later on ( hopefully not) ! The pink one is the old one...black tip is the new......the video was part of the test flight yesterday... Happy new year to all and have a safe weekend ! http://www.youtube.com/watch?v=r5fLA9byUdQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=324999#324999 Attachments: http://forums.matronics.com//files/takeoff_1_982x654_130.jpg http://forums.matronics.com//files/img_1610_1024x768_438.jpg ________________________________________________________________________________
Date: Dec 30, 2010
Happy new year to all and have a safe weekend ! http://www.youtube.com/watch?v=r5fLA9byUdQ Morning Folks: Glad you got your engine problem corrected. The Jabiru sounded good. Don't you have a two blade prop? I like the sound of a two blade prop. People used to tell me my Firestar with 447 and wooden two blade prop sounded almost like a "real airplane." You were getting a little frisky on the throttle during taxi after landing. ;-) You are flying out of Houghton Lake State? Landed there in 2003, on the way to Gaylord, home of my Army helicopter Instructor Pilot who soloed me in 1968. Then on to St Ignace to meet John Williamson and fly up to Sault Saint Marie and west along the south shore of Lake Superior. Eventually, we wound up at Scott Trask's in Iron Mountain, MI, where we met Rick Neilsen and Bill (has a FS), before we all flew down to Oshkosh. If I remember correctly, Houghton was grass. Longing to get some decent weather and get back on the cross country trail again soon. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 30, 2010
Charlie/All Ok.... Lets just assume for a moment that the Generac will handle the harmonic, gyroscopic, and thrust loads. The engine is designed as a industrial engine which is a good thing except for weight and power. Valley Engineering souped up the Generac engine, lightened it a bit, added their reduction drive and put it on Jimmy Young's Kolb FS. Jimmy even had to opportunity to fly the plane with the engine installed and choose the best prop by flying a selection of props. With all that it was found to be inadequate for Jimmy. Imagine now that a stock Generac with a dirict drive prop is installed on what George feels is a much lighter FS. Lets also assume that George will get the prop selection perfect and will get conservatively as much as 80% of the thrust of a reduction drive Generec. Jimmy or anyone how well would the plane fly? I'm not a engineer and I could be way off base. I was only able to get maybe 60-70% of the reduction drive thrust from my direct drive VW engine. I can't find the rated RPM for the 32-33 HP Generac. Lower RPMs closer to 2000-2200 RPM would make for a better direct drive engine. RPMs in the 3200-3600 range like a VW make much better reduction drive engines. Again worth what you paid for it. Rick Neilsen Redrive VW Powered MKIIIC On Wed, Dec 29, 2010 at 10:33 PM, Charlie England wrote: > One of the Generac's attractions for me is that it's designed from the > start as an industrial, run all day at rated power, almost any kind of load > type of engine. While the power pulses are uneven & may give a reduction > drive fits, the engine & in particular the crank should handle almost > anything short of a serious resonance issue. VW & other auto engines were > never designed to take side loads on the end of the crank, but the Generac > crank has a pulley mounted to it in many applications (exception would be > direct drive generators). > > I could be wrong, but I would think that a wood prop on a direct drive > Generac would present less load than the crank sees while driving 4 feet of > steel blades through ant hills, small logs, etc with the load transferred to > the crank through a cantilevered pulley. > > FWIW, > > Charlie > > On 12/29/2010 10:06 AM, Rick Neilsen wrote: > > George > > I don't think the direct drive Generac option is a good choice for at least > two reasons. First, it doesn't sound like you will be happy with the > performance if it will even fly. > > ________________________________________________________________________________
Date: Dec 30, 2010
Date: Thu, 30 Dec 2010 11:32:51 -0500 From: Rick Neilsen <neilsenrm(at)gmail.com> Charlie/All > .............. Lets also assume that George will get the prop selection perfect and will get conservatively as much as 80% of the thrust of a reduction drive Generec. Jimmy or anyone how well would the plane fly? ............... > Rick/All Propeller selection can be a pain too. On the FireFly with the MZ34 mounted, I have run two different IVO propellers. Both have been cut to about the same radius. Med pitch 50" prop @ 14.0 deg - 5,500 rpm -> 23.0 hp @ 55 mphi Low pitch 54" prop @ 8.25 deg - 5,800 rpm -> 24.8 hp @ 40 mphi Low pitch 52" prop @ 8.25 deg - 6,000 rpm -> 26.0 hp @ 40 mphi This indicates to me that the low pitch IVO is not a very efficient propeller for the MZ34/FireFly combination. It is beating the air like crazy, but it is not passing enough air through the propeller arc to produce thrust at speed. I have cut the medium pitch IVO down to the limit, and with it set to minimum pitch, I can not get the engine up to speed. Called Compact Engines and they do not offer a larger ratio than 2.34 to 1. Called a propeller fellow and he said he could make a propeller that would do the job for $700+. Thought about it some more and decided to re-work the propeller hub and sheave combination to get a 2.60 to one reduction. I figure this ratio may do the trick. If not, I will go back to the propeller carvers. As it flew very well with the medium IVO, I could have left it the way it was, but there is something about leaving the last four horses in the barn. Should receive the new sheave next week. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Dec 30, 2010
> Valley Engineering souped up the Generac engine,lightened it a bit, added their reduction driveand put it on Jimmy Young's Kolb FS. Jimmyeven had to opportunity to fly the plane with the engine installed and choose the best prop by flying a selection of props. With all that it was found to be inadequate for Jimmy. Imagine now that a stock Generac with a dirict drive prop is installed on what George feels is a much lighter FS. Lets also assume that George will get the prop selection perfect and will get conservatively as much as 80% of the thrust of a reduction drive Generec. Jimmy or anyone how well would the plane fly? George/Rick/All; Here's the way I see it. The Generac (Valley Engineering's version) needs to turn 3600 rpm to develop what was supposedly 38-40 hp. It didn't have enough power to safely fly my FS after 112 hrs of test flying with 4 different props. With the adjustable 72" 3 blade IVO, I pitched it so I was turning over 3800 rpm S&L flight and it was still a dog. It was ok on cool, still, stable early morning air, but heck I fly all the time in all kinds of air and it could not safely cut it at mid-day taking off with a crosswind and 95 degree humid air. It may fly someone else's plane that is much lighter or in a tractor config, but not my 435 lb dry & empty FS, and @ 750 lbs full fuel/me/& 20 lbs of baggage. I now have the 60 hp @ 6200 rpm HKS. Based on that, I should get 50% better performance with it over the Generac. It's more like 90% to 100% better. I'm not so sure the Generac ever developed 40 hp for me. Valley puts it on their tractor-pull 254 lb backyard flyer and apparently it works well for that plane. Tractor-pull aircraft are more efficient than our pusher-type Kolbs. They know more about the Generac & how to adapt it to aircraft than anyone around. I've done all the experimenting I care to do with aircraft engines and plan to stick only to a proven design from here on out. More power is more better, time tested proven designs trump what-ifs and how-abouts. Hoping you're going to make it over those trees on take off is not my idea of fun. I scraped the left side gear off my FS 2 years ago because I could not get enough climb taking off in a 90 deg. crosswind blowing over the hangars on a hot day. I aborted the take-off and made a perfect landing. As others have said before on this List, the only problem was I was 15 ft over the runway when I made it. Pilot error was the cause, not the engine, but it was a contributing factor. Do what you wish, but to go Generac-powered direct drive & a 56" prop in a FS could only be a worse scenario than what I tried, & I would highly discourage anyone from attempting it. -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325045#325045 ________________________________________________________________________________
Subject: Direct drive Generac
Date: Dec 30, 2010
I have been working on the direct drive Generac for over a year now...on and off. taking off the flywheel and installing a lighter part(made from the hub of the old flywheel) to hold the magnets/counterweight leaving the coils in place. Hub is mounted on the PTO end. May get it running in the next month or 2,trying to get the timing down. Engine will be installed on the Ultrastar which has the old Cuyuna....courtesy of Ted Cowan. ________________________________________________________________________________
Date: Dec 30, 2010
Jack, you give rpm at different speeds (level flight I presume). Did you measure the full throttle rate of climb at Vy for each prop? For ma y of us, that would be more meaningful than cruise performance. Rate of climb also directly proportional to power changes. -Dana At 02:27 PM 12/30/2010, Jack B. Hart wrote: >Propeller selection can be a pain too. On the FireFly with the MZ34 >mounted, I have run two different IVO propellers. Both have been cut to >about the same radius. > > Med pitch 50" prop @ 14.0 deg - 5,500 rpm -> 23.0 hp @ 55 mphi > Low pitch 54" prop @ 8.25 deg - 5,800 rpm -> 24.8 hp @ 40 mphi > Low pitch 52" prop @ 8.25 deg - 6,000 rpm -> 26.0 hp @ 40 mphi > >This indicates to me that the low pitch IVO is not a very efficient >propeller... -- HAL 9000: Dave. Put down those Windows disks, Dave. DAVE! ________________________________________________________________________________
Date: Dec 30, 2010
Subject: Re: Direct drive Generac
At 03:53 PM 12/30/2010, mark.shimei wrote: > >I have been working on the direct drive Generac.. > Engine will be installed on the Ultrastar which has the old > Cuyuna....courtesy of Ted Cowan. I'm looking forward to hearing about your results. I have the Cuyuna on my US now, but my friend complains it's too loud so he's giving me a fresh rebuilt 447 (he replaced it with a HKS on his GT400) while will probably go on my plane this winter. I'm looking forward to a significant takeoff and climb improvement... -Dana -- Illegal aliens have always been a problem in the United States. Ask any Indian. ________________________________________________________________________________
Date: Dec 30, 2010
Hi Rick, Most industrial engines have a design rpm of 3600 (works for 60hz generator). A friend has built up a direct drive 992cc Generac & IIRC, the all up weight is a little under 80 lbs. That would mean about the same pwr/wt ratio as a traditional 4 stroke a/c engine. I wholeheartedly agree that 32-36hp is woefully inadequate for a 700+ lb, very high drag airframe, reduction drive or not. A long, paved strip might make it doable, but not much fun. I'd also agree that prop rpm lower than 3200-3600 would be much better for a high drag, low speed airframe, but I don't see any need to go as low as 2200rpm unless there's room to swing a 6.5-7 foot diameter prop, like the Valley guys are doing on their psru engines. Regular a/c engines swing 72"-74" diameter props at 2700 rpm with excellent efficiency. For efficiency, tip speed is tip speed (determined by diameter & rpm+minor addition for airspeed), & the variable for higher/lower hp is blade area. A lighter, lower drag airframe is a different story. The Europeans are flying several different designs with decent performance on 20+ hp industrial engines that aren't any lighter than the 36hp Generac. I think that you're absolutely correct in the context of underpowering particular airframes, but don't see a valid reason for a general dismissal of the industrial engines. Congrats on your successful VW install. Having had my share of grief with a direct drive VW, I'm glad to see VW's running successfully with reduction drives. Charlie On 12/30/2010 10:32 AM, Rick Neilsen wrote: > Charlie/All > Ok.... Lets just assume for a moment that the Generac will handle the > harmonic, gyroscopic, and thrust loads. The engine is designed as a > industrial engine which is a good thing except for weight and power. > Valley Engineering souped up the Generac engine, lightened it a bit, > added their reduction drive and put it on Jimmy Young's Kolb FS. > Jimmy even had to opportunity to fly the plane with the engine > installed and choose the best prop by flying a selection of props. > With all that it was found to be inadequate for Jimmy. Imagine now > that a stock Generac with a dirict drive prop is installed on what > George feels is a much lighter FS. Lets also assume that George will > get the prop selection perfect and will get conservatively as much as > 80% of the thrust of a reduction drive Generec. Jimmy or anyone how > well would the plane fly? > I'm not a engineer and I could be way off base. I was only able to get > maybe 60-70% of the reduction drive thrust from my direct drive VW engine. > I can't find the rated RPM for the 32-33 HP Generac. Lower RPMs > closer to 2000-2200 RPM would make for a better direct drive engine. > RPMs in the 3200-3600 range like a VW make much better reduction drive > engines. > Again worth what you paid for it. > Rick Neilsen > Redrive VW Powered MKIIIC > > On Wed, Dec 29, 2010 at 10:33 PM, Charlie England > > wrote: > > One of the Generac's attractions for me is that it's designed from > the start as an industrial, run all day at rated power, almost > any kind of load type of engine. While the power pulses are uneven > & may give a reduction drive fits, the engine & in particular the > crank should handle almost anything short of a serious resonance > issue. VW & other auto engines were never designed to take side > loads on the end of the crank, but the Generac crank has a pulley > mounted to it in many applications (exception would be direct > drive generators). > > I could be wrong, but I would think that a wood prop on a direct > drive Generac would present less load than the crank sees while > driving 4 feet of steel blades through ant hills, small logs, etc > with the load transferred to the crank through a cantilevered pulley. > > FWIW, > > Charlie > > On 12/29/2010 10:06 AM, Rick Neilsen wrote: >> George >> I don't think the direct drive Generac option is a good choice >> for at least two reasons. First, it doesn't sound like you will >> be happy with the performance if it will even fly. > > ________________________________________________________________________________
Date: Dec 30, 2010
Date: Thu, 30 Dec 2010 17:14:20 -0500 From: Dana Hague <d-m-hague(at)comcast.net> > Jack, you give rpm at different speeds (level flight I presume). Did you measure the full throttle rate of climb at Vy for each prop? For many of us, that would be more meaningful than cruise performance. Rate of climb also directly proportional to power changes. > Dana, An amended data table follows: Climb Rate of Speed Climb Med pitch 50" @ 14.0 deg - 5,500 rpm -> 23.0 hp @ 55 mphi 45 mphi 300 fpm Low pitch 54" @ 8.25 deg - 5,800 rpm -> 24.8 hp @ 40 mphi 40 mphi ??? Low pitch 52" @ 8.25 deg - 6,000 rpm -> 26.0 hp @ 40 mphi 40 mphi ??? The low pitch propeller flights were very short and the engine speed did not vary until the FireFly was once again over the runway. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Dec 31, 2010
Subject: Re: Photos For New Web Site
Hello Kolb Gang and Travis, - It has been a very long time since I wrote to the group here. I have really missed you all, and want to thank you for-being so dedicated to the spor t we all love. - Here is a photo of-my family's-beloved FireStar 2, factory built back i n 2001 or so. I am sure that Travis offered-much to the construction for the original owner (now deceased)-Jesse Saxon and his lovely wife Mary Li b-who both-loved Kolb aircraft so very-much. - For now-this beautiful bird-rests gently in her trailer. NMS503 is her official-FAA name, but to my wife and I, we have named her "Izzy" in hono r of our recently deceased infant-daughter Isabella who was called back t o God on December 1 2010, 19 days after she was born. We do not know why Go d took her so soon, all we know is that His will shall be done, and someday we will fully understand. But for now, we know we have a Saint in Heaven t o intercede for us and to pray for us. - Happy New Year and blessings of happiness to all. - Michael and Pin Schnabel --- On Tue, 12/21/10, John Hauck wrote: From: John Hauck <jhauck(at)elmore.rr.com> Subject: Re: Kolb-List: Photos For New Web Site Date: Tuesday, December 21, 2010, 9:15 AM ---We are building a new web site and would like to ask all the membe rs here to submit a good picture of your Kolb aircraft Travis Kolb CO. Travis/Gang: Thanks for the new web site.- I always enjoy looking at everyone's Kolbs. Maybe you all could put a photo of the pilot/builder with the photo of his airplane also. Thanks for being there when we need you all.- Hopefully, Kolb folks will realize the importance of supporting Kolb Aircraft now and in the future. Life would be very difficult without you all providing kits, parts, technical support, and your friendship. Merry Christmas and Happy New Year from hauck's holler, alabama. john h mkIII - Miss P'fer Titus, Alabama =0A=0A=0A ________________________________________________________________________________
Date: Dec 31, 2010
My wife noticed a mistake-I made in-my last message-and insisted-I correct it... - Our FireStar 2 is not NMS503, but actually N503MS. Her nickname is still Iz zy. Thanks to all, and hoping everyone has a wonderful New Year! - Mike and Pin Schnabel --- On Fri, 12/31/10, Mike Schnabel wrote: From: Mike Schnabel <tnfirestar2(at)yahoo.com> Subject: Re: Kolb-List: Photos For New Web Site Date: Friday, December 31, 2010, 1:01 PM Hello Kolb Gang and Travis, - It has been a very long time since I wrote to the group here. I have really missed you all, and want to thank you for-being so dedicated to the spor t we all love. - Here is a photo of-my family's-beloved FireStar 2, factory built back i n 2001 or so. I am sure that Travis offered-much to the construction for the original owner (now deceased)-Jesse Saxon and his lovely wife Mary Li b-who both-loved Kolb aircraft so very-much. - For now-this beautiful bird-rests gently in her trailer. NMS503 is her official-FAA name, but to my wife and I, we have named her "Izzy" in hono r of our recently deceased infant-daughter Isabella who was called back t o God on December 1 2010, 19 days after she was born. We do not know why Go d took her so soon, all we know is that His will shall be done, and someday we will fully understand. But for now, we know we have a Saint in Heaven t o intercede for us and to pray for us. - Happy New Year and blessings of happiness to all. - Michael and Pin Schnabel --- On Tue, 12/21/10, John Hauck wrote: From: John Hauck <jhauck(at)elmore.rr.com> Subject: Re: Kolb-List: Photos For New Web Site Date: Tuesday, December 21, 2010, 9:15 AM ---We are building a new web site and would like to ask all the membe rs here to submit a good picture of your Kolb aircraft Travis Kolb CO. Travis/Gang: Thanks for the new web site.- I always enjoy looking at everyone's Kolbs. Maybe you all could put a photo of the pilot/builder with the photo of his airplane also. Thanks for being there when we need you all.- Hopefully, Kolb folks will realize the importance of supporting Kolb Aircraft now and in the future. Life would be very difficult without you all providing kits, parts, technical support, and your friendship. Merry Christmas and Happy New Year from hauck's holler, alabama. john h mkIII - Miss P'fer Titus, Alabama =0A=0A=0A ________________________________________________________________________________
Date: Jan 01, 2011
Hi, Folks, Is the new "Kolb Company" website viewable yet? I'm looking forward to seeing everyone's airplanes. Happy New Year from S. Florida. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325184#325184 Attachments: http://forums.matronics.com//files/dandd_kolb_152.jpg ________________________________________________________________________________
Date: Jan 01, 2011
Subject: Big motor, big problem?
Has anyone thought of trying to install an O-200 Conti on an M3X. with my modified rail Mount I could paste one there, the oil tank will not be in the way. However it's a big sucker, and heavy, but,,, about the same weight as the DBL cam 16 valve 1.3 litr zuki I have sitting there now. I think it was Williams that had a Hirth on his M3X he went over to a 912 later on. Still not clear why he did not stay with the Hirth. the specs look mighty good on it. I see some of them Conti O-200 pretty affordable. ________________________________________________________________________________
Subject: Re: Big motor, big problem?
Date: Jan 01, 2011
I think it was Williams that had a Hirth on his M3X he went over to a 912 later on. Still not clear why he did not stay with the Hirth. the specs look mighty good on it. ****************************** John Williamson never flew with a Hirth or any other two stroke on his Kolbra. Jabiru Verner 912UL 912ULS john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 01, 2011
yes that's right I remember the Verner and the vibration, I also now remember the jabi, that was over heating iirc. So who had the big Hirth on his ride? As I am told its not the memory, its that I have too many things on my mind as some chick once told me who of course I forgot her name and who she was. Laughing.... ________________________________________________________________________________
Date: Jan 01, 2011
Subject: New Year's day flying
Today was a strange one. Weird, weather, careless damage, and almost a forced landing. A week after the Christmas blizzard, forecast was for upper 40s and light & variable. All the snow melted or blew off our grass strip, looked like a good day, everybody was there. The strip was here, but I had to dig out the snow behind my trailer to get the plane out. Then the first hitch, maneuvering the plane around a snowdrift I got careless and let a tree branch slice a foot long rip in the elevator fabric. AAAARGH! I'll fix it properly, of course, but some ripstop tape takes care of it for the moment. Not as bad as my buddy's Firestar; the storm blew his canvas shed down and sliced his wing pretty good... duct tape fixed him up for the moment, too. Started out a beautiful flight. Temperature inversion, snow nearly everywhere, upper 40s on the ground but 65 at 2000! This is a rare winter treat. Engine hesitated a bit going from mid to full throttle, but top rpm and temps OK. Flew out across the river, but my engine didn't want to hold cruise rpm... would fall off or increase. Then the rpm dropped to around 3500, which isn't enough to maintain altitude. Kept jockeying the throttle but it just wouldn't "catch". Tried a shot of prime but that nearly killed it. I kept circling over a couple of short farm fields, deciding between the one near the road with horses, or the empty one farther out. I was down to about 500', setting up for landing, when the rpm finally came back up, and I was able to climb to 2500', high enough to make it back home, keeping a potential landing site in reach, though it continued to run fine at full throttle. Back on the ground, the same problem was intermittent. CHT OK and EGT on the low side. Running at 4000, it was hesitant to speed up, so I killed it and pulled the plugs... looked OK. Fiddled with it until it happened again, full throttle and it sagged until it quit. Pulled the rear plug and this time it was black. My guess is it's flooding, perhaps a bad float needle, this is supported by fuel dripping from the carb onto my leg as I was pulling the plugs. Took the carb off and brought it home, though I haven't opened it up yet. Time to order a needle and gasket set, I guess... -Dana -- If one synchronized swimmer drowns, do the rest have to drown too? ________________________________________________________________________________
Subject: Re: New Year's day flying
Date: Jan 01, 2011
Dana, It must be the season...My Jabiru did the same thing 2 weeks ago and forced me down in a golf course...Changed the needle and all is well again... Glad yours stayed running.... chris ambrose M3X/Jab N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325258#325258 ________________________________________________________________________________
Subject: What Should be Max Pilot Size in a FS2?
Date: Jan 01, 2011
Hello all! I've been studying this neat little flying machine for about 6 weeks now and I'm about ready to buy one. I'm 6'1" tall, 270 lbs. Called Kolb several times and spoke with Travis (His responsiveness and having someone actually pick up the phone is another reason I'm choosing Kolb) and even spoke to him about putting a big guy like myself in a FS2. He said "no problem, lot's of big pilots fly them". Unfortunately I have not been able to locate any big pilots to talk with about this. Performed the W&B with full and empty fuel and I still end up within weight limits and within CG limits. Are there any big pilots like myself that can give me advise and first hand experience? My first task I plan to do is remove the 2nd seat and replace that little front seat with something more accommodating. -------- Jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325266#325266 ________________________________________________________________________________
Date: Jan 01, 2011
Subject: Happy Kolb New Year
While the rest of the country is snowed under, flooding, or hitchhiking to Oz, Kansas is under a range fire warning even with below freezing temperatures. Go figure. By three o'clock the thermometer finally made it up to freezing and I rolled Zulu Delta out of the hangar and fueled up. Took a long time to get the 582 up to temp even with part of the radiator blocked off, but the needle of the coolant temp gauge finally crawled up into the green arc and we were off. In the cold dry air I was getting 1000 feet per minute so I throttled back and cruise climbed once I hit 500 feet, stayed low and tried to make shallow power on approaches to keep the engine warm. I had on enough to stay nice and warm, but I didn't like throttling up on a touch and go with the temp needle down around 120 so I made one of each flap setting, did a lap around the Duchy and called it a day. Not a bad week for winter. I got in an hour on Thursday to close out 2010 flying in shirtsleeve weather into a beautiful sunset. Two days later it's a clear blue sky thanks to a polar air mass that brought temps down to single digits for New Years Eve. Got the year off to a good start, though. Rick Girard -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Subject: Key West Tach...anyone want one...0 to 4000rpm
Date: Jan 01, 2011
Hello Kolb / Jabiru flyers, I just pulled a Key West Tachometer P/N: ED-9704B out of the panel of Kolbra #1. Looks fine but don't know anything about it. I will not be running a Jabiru and so will need a Tac with a higher top end. Contact me off list, if you want it. Thanks, Nick Cassara Building wings for Kolbra #1 Please don't archive ________________________________________________________________________________
Subject: Re: What Should be Max Pilot Size in a FS2?
Date: Jan 02, 2011
Since it's good to haul two people, it will do fine with one big one. And here's one way to improve the seat. This was done when N582EF was still a 2-seater, if you don't have a passenger, the seat would not need to be narrowed. And if you left off the back rest (my preference) it would have been even easier. http://www.bcchapel.org/pages/0003/FSII%20seat%20page.html Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325281#325281 ________________________________________________________________________________
Subject: Re: Key West Tach...anyone want one...0 to 4000rpm
Date: Jan 02, 2011
Nick where did the Jabire engine go that was attached to that Tac? Ellery Batchelder Jr. -----Original Message----- From: Nick Cassara <nickc(at)mtaonline.net> Sent: Sun, Jan 2, 2011 1:38 am Subject: Kolb-List: Key West Tach...anyone want one...0 to 4000rpm Hello Kolb / Jabiru flyers, I just pulled a Key West Tachometer P/N: ED-9704B out of the panel of Kol bra #1. Looks fine but don=99t know anything about it. I will not be running a Jabiru and so will need a Tac with a higher top end. Contact me off list, if you want it. Thanks, Nick Cassara Building wings for Kolbra #1 Please don=99t archive ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jan 02, 2011
Has anyone thought of trying to install an O-200 Conti on an M3X. with my modified rail Mount I could paste one there, the oil tank will not be in the way. However it's a big sucker, and heavy, but,,, about the same weight as the DBL cam 16 valve 1.3 litr zuki I have sitting there now. I think it was Williams that had a Hirth on his M3X he went over to a 912 later on. Still not clear why he did not stay with the Hirth. the specs look mighty good on it. I see some of them Conti O-200 pretty affordable. >>>>>>>>>>>>>>>>>>>>>>>>> according to larry borne,,, that was going to be his original plan,,,, when people told him it was too heavy he started on the vw with psru. then the chain in the psur exploded he caned the vw idea, once again considered the o 200. i think he mentioned a B model, to be in a pusher configuration. then he sold everything. to my knowledge that is the only mention of o 200 i iknow of. boyd young mkiii utah ________________________________________________________________________________
Date: Jan 02, 2011
Ron Early on I wanted too put a Lycoming or Continental on my MKIIIC. I was told by Kolb that it was too heavy so I never really went any further with it. My VW is a bit heavy but with with some effort I was able to keep the empty weight of my MKIIIC just below 600 Lbs. The two major concerns with engine selection is thrust and weight. After that you need to address cost, fuel consumption, reliability, physical size, vibration and a host of other things. I really don't have a clue what a "0-200 or a 1.3 zuki" weigh. I do know at almost 600 lbs empty weight I very quickly hit gross weight limits in my airplane with two passengers. If you put a heavy engine on a Kolb you could end up with a single passenger airplane. The factory has and to my knowledge still recommends 1000 Lbs gross weight limit. I have done some modifications and set my gross weight limit at 1050. Some have gone even higher and have made extensive modifications to get a higher limit. Bottom line anything over the factory limits and you are the test pilot and a mistake in this area can be something you can't live with. Again worth what you paid for it. Rick Neilsen Redrive VW powered MKIIIC On Sun, Jan 2, 2011 at 10:18 AM, b young wrote: > > Has anyone thought of trying to install an O-200 Conti on an M3X. with my > modified rail Mount I could paste one there, the oil tank will not be in the > way. However it's a big sucker, and heavy, but,,, about the same weight as > the DBL cam 16 valve 1.3 litr zuki I have sitting there now. > I think it was Williams that had a Hirth on his M3X he went over to a 912 > later on. Still not clear why he did not stay with the Hirth. the specs look > mighty good on it. > > I see some of them Conti O-200 pretty affordable. > > >>>>>>>>>>>>>>>>>>>>>>>>> > > according to larry borne,,, that was going to be his original plan,,,, > when people told him it was too heavy he started on the vw with psru. then > the chain in the psur exploded he caned the vw idea, once again considered > the o 200. i think he mentioned a B model, to be in a pusher > configuration. then he sold everything. to my knowledge that is the only > mention of o 200 i iknow of. > > boyd young mkiii utah > > * > > * > > ________________________________________________________________________________
Date: Jan 02, 2011
Travis, Do you have a web site yet? G.Aman -----Original Message----- From: kolbaircraft <customersupport(at)tnkolbaircraft.com> Sent: Tue, Dec 21, 2010 9:36 am Subject: Kolb-List: Photos For New Web Site raft.com> Hey Everyone We are building a new web site and would like to ask all the members here to submit a good picture of your Kolb aircraft Please email your picture to morgantechnical(at)yahoo.com Thanks to everyone on this awesome list and Merry Christmas to each and eve ryone of you. Kind Regards Travis Kolb CO. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=324011#324011 ________________________________________________________________________________
Date: Jan 02, 2011
I have thought about it since my first pondering about which motor. I think I mentioned it back in 2001 thereabouts. Since I have changed the mount to my rail design that problem of how to accommodate the oil tank has gone away. I need some free time to maybe go and buy one. I have no problems with aircraft engines ( I am A&P) so it should be a straight job of getting it running. The only thing I am troubling about is a bad mount design for the O-200. I have a friend with a Vereze that has an O200 so I need to look at it some more to see if I want to do it. I may just stay with the Suzuki as I am 90% there; just fed up with the complexity of the installation. ________________________________________________________________________________
Date: Jan 02, 2011
> From: "Jimmy Young" <jdy100(at)comcast.net> > Here's the way I see it. The Generac (Valley Engineering's version) needs > to turn 3600 rpm to develop what was supposedly 38-40 hp. Thanks for your comments Jimmy. I am thinking you may be right on, but I lack the aircraft experience to even guess. I have not heard that VE hopped up the Generac engine. I would really like to know what mods they performed for you to get the performance that you did get (if any mods at all). I originally bought the Generac before I had my Kolb. It isn't the end of the world if I don't use the Generac on there. I have a new 503 DCDI in the garage. My experience is in engine building and modifications. I have enjoyed pleasing results, some surprisingly good, but am NOT saying I am anybody's idea of a professional. My interest is/was in seeing how close to a good aircraft engine I could convert the Generac into. With the torque peak at +/- 2200 rpm I feel that there remains considerable power and torque potential remaining untouched here. I have no idea what I will decide to do- but so far I have been investigating high-torque cams, with my desktop Dyno. More to go on that. I kinda anticipate doing some manifold and head work. Not sure the carb yet. I may lower compression some, may mod/replace the ignition. I think 36 degrees is too much advance for my taste. The gasoline flywheel has a more reasonable advance. Mine is a propane model. Jimmy, suppose I had your exact engine, PSRU and a good prop match on my lighter FS1. Do you have any wild guess what the performance might be then? You think VE folks could give experienced feedback on that? GeoB ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Date: Jan 03, 2011
Hi George. Love the sound of the VE Generac! I have quite a few trouble hours behind Rotax 2 strokes (well over 400 hours) but only a few in a Kolb (Firestar XKP)and I'm wondering if there seems to be issues with the two? Are there still a lot of folks using the 503 on the Kolb or for some reason is everyone searching for something else for a given reason? I've been away from the 2 stroke scene for a goodly number of years, so things may have changed. Last 2 stroke I had was a 618. A wonderful engine. Any info you can share with me on the 503 and Kolb Firestar would be much appreciated. Gene N71RB Kolb XKP with 503 ________________________________________________________________________________
Date: Jan 03, 2011
Should have read "trouble FREE hours" Gene -------------------------------------------------- From: "Gene & Tammy" <zharvey(at)bentoncountycable.net> Sent: Monday, January 03, 2011 12:42 AM Subject: Re: Kolb-List: Re: Sonex or GP VW > > > Hi George. > Love the sound of the VE Generac! I have quite a few trouble hours behind > Rotax 2 strokes (well over 400 hours) but only a few in a Kolb (Firestar > XKP)and I'm wondering if there seems to be issues with the two? Are there > still a lot of folks using the 503 on the Kolb or for some reason is > everyone searching for something else for a given reason? I've been away > from the 2 stroke scene for a goodly number of years, so things may have > changed. Last 2 stroke I had was a 618. A wonderful engine. Any info > you can share with me on the 503 and Kolb Firestar would be much > appreciated. > Gene > N71RB Kolb XKP with 503 > > > ________________________________________________________________________________
Subject: Kolb SS pic's
Date: Jan 03, 2011
> I thought I would show some pictures of my Slingshot. Without even searching, I found a 2.58 HKS gearbox on Ebay, and with a low bid, won it. I looked it over, and everything seems good, and complete. I think I'll wait for warmer days to do any more experimenting, and for now just play with it as is. I'll be flying down to Texas (commercial) next week to visit family and friends, and hope to have time to meet a few fellow Kolbers, and visit a few airparks as well. > > Tom McCarthy > > N514TM Zenith 601HD > N441TM Kolb Firestar > N863GB Kolb Slingshot Seem's that I have a problem sending pictures as a attachment. I'll try again later ________________________________________________________________________________
Subject: Re: Kolb SS pic's
Date: Jan 03, 2011
Looking forward to your photos From: McCarthy Tom Sent: Monday, January 03, 2011 7:45 AM Subject: Kolb-List: Kolb SS pic's I thought I would show some pictures of my Slingshot. Without even searching, I found a 2.58 HKS gearbox on Ebay, and with a low bid, won it. I looked it over, and everything seems good, and complete. I think I'll wait for warmer days to do any more experimenting, and for now just play with it as is. I'll be flying down to Texas (commercial) next week to visit family and friends, and hope to have time to meet a few fellow Kolbers, and visit a few airparks as well. Tom McCarthy N514TM Zenith 601HD N441TM Kolb Firestar N863GB Kolb Slingshot Seem's that I have a problem sending pictures as a attachment. I'll try again later ________________________________________________________________________________
Date: Jan 03, 2011
http://kolbsport.com/ -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Faith is believing what you know ain't so - Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325429#325429 ________________________________________________________________________________
Date: Jan 03, 2011
> I have not heard that VE hopped up the Generac engine. I would really like > to know what mods they performed for you to get the performance that you did > get (if any mods at all). GeoB, The only mods that mine had were an Empi carb, a custom intake manifold, and a custom exhaust. Your best bet would be to call Larry @ VE & discuss the engine with him regarding what they have done since then. They are very much a customer-service oriented family biz and are great to deal with. > suppose I had your exact engine, PSRU and a good prop match on my > lighter FS1. Do you have any wild guess what the performance might be then? > You think VE folks could give experienced feedback on that? I would guess a sustainable climb rate of 300-450 fpm. My cruise was the same as with the 503. What did not work for me was very poor & even negative climb rates in hot summer air while trying to overcome the sinks & downdrafts. On nice cool mornings it flew decent, but in mid-day summer air there just wasn't enough power to safely fly the plane IMO. If I had only a choice between a 503 & a Generac on a FS, I'd take the 503 hands down. Good luck with your project - -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325459#325459 ________________________________________________________________________________
Date: Jan 03, 2011
http://kolbsport.com/ Dennis T/Gang: Close...but you don't get a prize. That is the web site of The New Kolb Aircraft Company that is no longer in existence. We are still waiting on Kolb Aircraft Company to publish their "new" web page. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 03, 2011
At 02:33 PM 1/3/2011, John Hauck wrote: >That is the web site of The New Kolb Aircraft Company that is no longer in >existence. > >We are still waiting on Kolb Aircraft Company to publish their "new" web >page. John, I must've missed something. Why the name change? Did the company ownership change again? -Dana -- Be wary of strong drink. It can make you shoot at tax collectors-- and miss. ________________________________________________________________________________
Date: Jan 03, 2011
John, I must've missed something. Why the name change? Did the company ownership change again? -Dana Bruce Chesnut sold The New Kolb Aircraft Company to Brian Milburn (Milborn)(Milborne)(sp), who in turn changed the name to Kolb Aircraft Company, as it was in the beginning. Brian's (Bryan)(sp) desire is to go back to the Homer Kolb roots. Emphasize Homer's designs and not the fancy LSA type aircraft that most of us could not afford even if we liked that kind of airplane. Kolb Aircraft is a very small company and needs everyones help to stay in business. It is to our advantage to support them. Kolb is our only source of parts. Parts that are no longer available can be fabricated at Kolb Aircraft. Kolb Aircraft is a very valuable resource for us all. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Looking for FS2 Close To VA
Date: Jan 04, 2011
Looking for an "OK" FS2 close to VA that has an "N" number that is priced reasonable. Please let me know if you have one or know of someone who does. -------- Jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325608#325608 ________________________________________________________________________________
Subject: Re: Looking for FS2 Close To VA
Date: Jan 04, 2011
Did the Florida FS fall through? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325616#325616 ________________________________________________________________________________
Date: Jan 04, 2011
The shipper now wants $1,200 to ship it 950 miles.- I may reconsider by t his weekend.- There are 3 at Beaverdam Airpark (VA33) where I plan to kee p mine and the owner of the field is contacting them to see if any want to sell.- I'm finding out there are actually a lot of Firestars in VA.- If I get the one from FL I plan to recover and repower it (I guess you can sa y a full restoration) with an HKS-700E if I can afford it.- There is one for sale on Barnstormers now for about $5k.- It will be a project. - On a side note, the red prototype Serial# 1 Slingshot that you see in all t he Kolb advertisements and YouTube videos is for sale here in VA.- I spok e to the guy and he's letting it go for a very good price.- I'm afraid I would kill myself in that thing.- He's the same size as I am and he has a 50+ mile stall speed in it.- He hits the numbers at about-65 and slowl y idles back.- Needs all of 1000 - 1200 feet. - I've been here several times and it's real fun.- Only problem is I have t o cross 14 miles of the Chesapeake Bay to get there.- I'll feel much bett er doing it with an HKS.- I know many say don't fly over anything you can 't land on but if that was the case I would just stick with my car.- And besides, water is softer then trees or mountains and I can swim. - http://www.campbellfieldairport.com/ - Scroll down and check out the firestar.- I hope I'm still doing this at t hat age. --- On Tue, 1/4/11, 209GS wrote: From: 209GS <guebbing(at)aol.com> Subject: Kolb-List: Re: Looking for FS2 Close To VA Date: Tuesday, January 4, 2011, 9:03 PM Did the Florida FS fall through? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325616#325616 le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Jan 04, 2011
From: "Jeff Gerlach" <jeff_gerlach(at)yahoo.com> On a side note, the red prototype Serial# 1 Slingshot that you see in all the Kolb advertisements and YouTube videos is for sale here in VA. He's the same size as I am and he has a 50+ mile stall speed in it. He hits the numbers at about 65 and slowly idles back. Needs all of 1000 - 1200 feet. ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Jeff G/Gang: My perception of the Slingshots are a little different from yours. If that is the original Slingshot from Old Kolb Co, I flew it when it was brand new at Oshkosh. May have been 1996. Not sure. would have to look in my log book. It stalled at 43 mph clean and 38 mph with full flaperons, indicated airspeed. The following Sun and Fun I flew a gentleman with a very large commercial video camera in the same SS. Don't know what the stall speeds were, but if they had been unusually high, I think I would have remembered it. I was flying during the in cockpit shots south of Lakeland through the scrub oaks, palmetto palms, and cow pastures, that are on Youtube. Bruce Chesnut, owner of The New Kolb Aircraft Company, had a red SS with a 912ULS. It flew like the old original SS but with more get up and go. The original was powered with a 582 Rotax. The SS and Firefly share the same dimension wings (length, width, cord, and airfoil). Flaperon dimensions are different. Please correct me if I am wrong. The 22' wing span flies much the same as the 27' and 30' wings, with the exception of a much quicker roll rate. I like flying both the SS and the FF. They are quick, nimble little hot rods. Be fun to fly a 912ULS powered SS to Alaska, if I could find a place to stow my gear. Your friend is burning up too much runway. The SS lands much shorter than 1000-1200 feet. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 04, 2011
I had originally planned on the HKS for my Firestar, and had the engine ordered but due to an unfortunate glitch, didn't have enough money to go ahead with the purchase. Ended up going with the 503 with hopes of eventually getting the HKS sometime in the future. I think it would be a good combo together and like the idea of a 4 stroker in the back when I'm over the mountains. Gerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325628#325628 ________________________________________________________________________________
Date: Jan 04, 2011
Subject: the Kolberee begins
Kolbers and all, I finally got the Kolb in the shop! Changes are in store for her. New cage and an HKS motor. Already took a hacksaw to the cage, hack is a good name for that saw. Traumatic experience. Cutting up my baby. First up was the motor mount upgrade. Thanks Frank for the heads up. Next up were the Rudder pedals, moved them back 4", added a battery mount in front for a 12 1/2 Lb battery. WWAAAA Balance rules. However, I pulled out 17 Lb of steel plate. And so it is. The Biggest challenge I see next is rigging old wings to a new cage. I know there are flyers that have faced this task. Any Hints / Suggestions ? I'm going to put a pointy thing on the back of the cage, are there any HKS's w/4" extension out there that could give me a number? Cage to prop. I'm making strut fairings, steel legs, moving gas to the rear seat, and locking storage. Huge electrical system, battery and start and whatnot. Looks like a happy new year coming up! Busy anyway. Live long and prosper!! Bob Dresden Colorado Rockies ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 6 Msgs - 01/04/11
Date: Jan 05, 2011
I am going to agree with Mr. Hauck on this SS thing. My little SlingShot 912ul breaks clean at 48. Power on and it is just a little low bump and low power dives slowly for maybe fifty feet until it gets up speed again. I take off in about three hundred feet and can land easily in five hundred. I usually only use up about three fifty. Mine weights in at five hundred pounds which is somewhat heavy I think. By the way, I have finally almost eliminated my rum rum from the sound. I have been working on the after muffler for a year or so now and it is working great. It has been a tedious and expensive chase. It now sounds like an airplane, not a train. Hope everyone had a great holiday. Ted Cowan, SS 912 UL zoom zoom. ________________________________________________________________________________
Subject: Re: Looking for FS2 Close To VALooking for FS2 Close To
VA
Date: Jan 05, 2011
On a side note, the red prototype Serial# 1 Slingshot that you see in all t he Kolb advertisements and YouTube videos is for sale here in VA.- I spok e to the guy and he's letting it go for a very good price.- I'm afraid I would kill myself in that thing.- He's the same size as I am and he has a 50+ mile stall speed in it.- He hits the numbers at about-65 and slowl y idles back.- Needs all of 1000 - 1200 feet. WOW--That is a lot of runway for a Sling shot. One thing I learn over and over when reading posts is that too many people use "indicated" rather than actual airspeeds. In the original Kolb info, it lists 41 as the stall, my SS is around 44 clean "actual". I have not tried landing as short as I can, but I think it lands as short or shorter than my Firestar will. The only real difference in performance is take off distance with the HKS is longer, and the sink rate is much higher power off. Now that you mentioned that there is a SS for sale, I bet it will show interest. If I already did not own one, I would be interested. > Tom McCarthy > 61C Fort Atkinson, WI > N514TM Zenith 601HD > N441TM Kolb Firestar > N863GB Kolb Slingshot ________________________________________________________________________________
Date: Jan 05, 2011
I agree with John H on the Slingshot. Mine is a good bit heavier than one equipped with a 582 and its stall speed clean was 45 mph but about the same 38 with full flaperons. And it does not take 1000' to land or take-off. That was before I added home-made VGs to the wings. Now, without flaps, I run out of elevator travel at 42 mph without it reaching stall AOA. With half flaps, it now stalls at 35. I've never tested stall speed with full flaps after adding the VGs but suspect it may be a couple mph less. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325646#325646 ________________________________________________________________________________
Date: Jan 05, 2011
From: william sullivan <williamtsullivan(at)att.net>
Subject: Winter damage
- I thought I did enought to store the Firestar for the winter.- Wrong. - I have it folded on a trailer, tarped, and out in the middle of the yar d so the trees won't drop branches on it.- The high winds from the blizza rd caused the tarp rope to chafe a small hole in the middle of a wing.- M ore work for spring. - ------------------------- ---------------------- Bill Sul livan ------------------------- ---------------------- Windsor Locks, Ct. ------------------------- ---------------------- FS 447 ________________________________________________________________________________
Subject: Re: the Kolberee begins
Date: Jan 05, 2011
Experi-Mental Bob , ...All in good humor ! -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Faith is believing what you know ain't so - Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325670#325670 Attachments: http://forums.matronics.com//files/cid_bcfec44202f7433386faac8bf7fae5d3thate_125.jpg ________________________________________________________________________________
VA
Date: Jan 05, 2011
One thing I learn over and over when reading posts is that too many people use "indicated" rather than actual airspeeds. > Tom McCarthy Tom M/Gang: I use IAS because that is the only airspeed instrument I have. Where do you get your "acutal" airspeed? Just curious. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 05, 2011
I've never tested stall speed with full flaps after adding the VGs but suspect it may be a couple mph less. -------- Thom Riddle Thom R/Gang: Why haven't you tested full flaperon stall? john h mkIII Titus, Alabama ________________________________________________________________________________
From: "cristalclear13" <cristalclearwaters(at)gmail.com>
Date: Jan 05, 2011
JeffG wrote: > The shipper now wants $1,200 to ship it 950 miles. > http://www.campbellfieldairport.com/ (http://www.campbellfieldairport.com/) > > Scroll down and check out the firestar. I hope I'm still doing this at that age. > It cost me nearly a thousand to go pick up my Mark II a little closer than that distance when I bought it (between renting the truck and gas, lodging, etc.). I love that airport and the activities they do...and that Piper dog is the cutest!! I wish our airport would have more participants. Maybe if we found human bones on our airport it might peek people's interest. :D -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325700#325700 ________________________________________________________________________________
Subject: Re: Winter damage
Date: Jan 05, 2011
williamtsullivan(at)att.n wrote: > I thought I did enought to store the Firestar for the winter. Wrong. I have it folded on a trailer, tarped, and out in the middle of the yard so the trees won't drop branches on it. The high winds from the blizzard caused the tarp rope to chafe a small hole in the middle of a wing. More work for spring. > > Bill Sullivan > Windsor Locks, Ct. > FS 447 > Seems like there is always something! [Rolling Eyes] Sometimes I just wish I could fly whenever I wanted to (but then again having something to work on can be fun too). [Wink] But more flying and less working is BEST! -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325706#325706 ________________________________________________________________________________
Subject: Bing 54 jets - cleaning?
Date: Jan 05, 2011
I know it is not recommended to clean the idle and main jets, but was wondering if anyone has ever done it after they were gummed up and used them again (and lived to tell about it)? :D -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325709#325709 ________________________________________________________________________________
Subject: Re: Bing 54 jets - cleaning?
Date: Jan 05, 2011
cristalclear13 wrote: > I know it is not recommended to clean the idle and main jets, = = = snip= = Cristal: Do you have a source for that recommendation? I could understand that you would not want to use anything (tool/chemical/process) that would change (enlarge) the orifice(s), but don't know why cleaning otherwise wouldn't be OK. -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325712#325712 ________________________________________________________________________________
Date: Jan 05, 2011
Cristal, Why wouldn't you clean them? As long as you don't use something that changes the jet size, no problemo. I used a small sewing needle to clean out the idle passages and the jets in the Bing 54's on my 582 last year after they gummed up during a protracted rebuild of the airplane. Soak in carb cleaner, work out the softened gum with the needle, repeat until clean. After the carbs were balanced they work as good as they ever have. Rick Girard On Wed, Jan 5, 2011 at 3:17 PM, cristalclear13 wrote: > cristalclearwaters(at)gmail.com> > > I know it is not recommended to clean the idle and main jets, but was > wondering if anyone has ever done it after they were gummed up and used them > again (and lived to tell about it)? :D > > -------- > Cristal Waters > Kolb Mark II Twinstar > Rotax 503 DCSI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=325709#325709 > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Jan 05, 2011
Hi,=0A=0AIf I thought I might damage the jet---( I don't think anything use d with =0Areasonable care would hurt them)--=0AI would use a jewlers ultras onic cleaner, they are cheap and you can clean =0Ajewlery with them later. (multitask).=0AFrank=0A=0A-=0A=0A=0A=0A________________________________ =0AFrom: cristalclear13 <cristalclearwaters(at)gmail.com>=0ATo: kolb-list@matr onics.com=0ASent: Wed, January 5, 2011 3:17:16 PM=0ASubject: Kolb-List: Bin " =0A=0AI know it is not recommended to clean the idle and main jets, but was wondering =0Aif anyone has ever done it af ter they were gummed up and used them again (and =0Alived to tell about it) ? :D=0A=0A--------=0ACristal Waters=0AKolb Mark II Twinstar=0ARotax 503 DCS I=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.c -======================== - - - - - - - - - - - - - -Matt Dralle, List Admi ==== ________________________________________________________________________________
Date: Jan 05, 2011
- Somebody recently suggested using a copper wire, obtained from strippin g some stranded wire (like a piece of 14 gauge automotive wire).- Soft en ough not to scratch the ports. - ------------------------- ---------------- Bill Sullivan ------------------------- ---------------- Windsor Locks, Ct. ------------------------- -----------------FS 447 --- On Wed, 1/5/11, cristalclear13 wrote: I know it is not recommended to clean the idle and main jets, but was wonde ring if anyone has ever done it after they were gummed up and used them aga in (and lived to tell about it)? :D -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325709#325709 le, List Admin. ________________________________________________________________________________
Date: Jan 05, 2011
I know it is not recommended to clean the idle and main jets, but was wondering if anyone has ever done it after they were gummed up and used them again (and lived to tell about it)? :D -------- Cristal Waters Hi Cristal W/Gang: I was always taught to use a piece of copper wire to clean carb jets. Copper is softer than brass. Scrap multistrand copper wiring is a good source for the right size. Don't use anything that would scratch and enlarge the jet. Along with some carb cleaner and a good air hose. Becareful with the air hose though. It will launch a jet into never never land. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 05, 2011
rickofudall wrote: > Cristal, Why wouldn't you clean them? As long as you don't use something that changes the jet size, no problemo. I used a small sewing needle to clean out the idle passages and the jets in the Bing 54's on my 582 last year after they gummed up during a protracted rebuild of the airplane. Soak in carb cleaner, work out the softened gum with the needle, repeat until clean. After the carbs were balanced they work as good as they ever have. > > Rick Girard > I was getting my information from http://www.ultralightnews.ca/bing/bingjetchart.html under the sections titled Bing Main Jets and Bing Idler Jets. It says: ... jets on the Bing carb are replaceable. It is recommended that they be replaced if they are found to be plugged. This can happen when the carb is left with fuel in it for long periods of time. The fuel turns to sludge which plugs the jet. In this situation it is NOT recommended that the jet be cleaned and reused. But on another page it talks about cleaning them with solution and air compressor. http://www.ultralightnews.com/enginetroublshooting/techtips/techtips2.htm -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325722#325722 ________________________________________________________________________________
Date: Jan 05, 2011
he must be in phase one test flying .......LOL Ellery Batchelder Jr. -----Original Message----- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Wed, Jan 5, 2011 1:10 pm Subject: Re: Kolb-List: Re: Looking for FS2 Close To VA I've never tested stall speed with full flaps after adding the VGs but uspect it may be a couple mph less. -------- hom Riddle hom R/Gang: Why haven't you tested full flaperon stall? john h kIII itus, Alabama ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jan 05, 2011
Listers, Compressed air cleans the important parts of your carb. -----Original Message----- From: cristalclear13 <cristalclearwaters(at)gmail.com> Sent: Wed, Jan 5, 2011 5:42 pm Subject: Kolb-List: Re: Bing 54 jets - cleaning? .com> rickofudall wrote: > Cristal, Why wouldn't you clean them? As long as you don't use something that changes the jet size, no problemo. I used a small sewing needle to clean ou t the idle passages and the jets in the Bing 54's on my 582 last year after they gummed up during a protracted rebuild of the airplane. Soak in carb cleaner , work out the softened gum with the needle, repeat until clean. After the ca rbs were balanced they work as good as they ever have. > > Rick Girard > I was getting my information from http://www.ultralightnews.ca/bing/bingjetchart.html under the sections titled Bing Main Jets and Bing Idler Jets. It says: ... jets on the Bing carb are replaceable. It is recommended that they be replaced if they are found to be plugged. This can happen when the carb is left with fuel in it for long periods of time. The fuel turns to sludge which pl ugs the jet. In this situation it is NOT recommended that the jet be cleaned an d reused. But on another page it talks about cleaning them with solution and air compressor. http://www.ultralightnews.com/enginetroublshooting/techtips/techtips2.htm -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325722#325722 ________________________________________________________________________________
Date: Jan 05, 2011
Bob Dresden wrote: > > 'm going to put a pointy thing on the back of the cage, are there any HKS's w/4" extension out there that could give me a number? Cage to prop. > Whatever you put on the back of the cage, think in terms of the prop making it flex a lot. As in - a lot. Extra finishing tape, tie it to something solid, etc. or the prop pulses will cause paint cracks. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325731#325731 ________________________________________________________________________________
Date: Jan 05, 2011
John Hauck wrote: > Becareful with the air > hose though. It will launch a jet into never never land. > > john h > mkIII > Titus, Alabama That might be kind of funny (if the part didn't cost so much)! :D I could tell people I'm flying jets now. :D -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325737#325737 ________________________________________________________________________________
Date: Jan 05, 2011
VA Not sure if I mentioned this or not but he weighs about 280lbs and lands on asphalt in Blacksburg VA.- The stall listed in the specs is based on a s tandard issue FAA pilot of 170 lbs. --- On Wed, 1/5/11, McCarthy Tom wrote: From: McCarthy Tom <mccarthy(at)jefnet.com> Subject: Re: Kolb-List: Re: Looking for FS2 Close To VALooking for FS2 Clos e To VA Date: Wednesday, January 5, 2011, 7:13 AM On a side note, the red prototype Serial# 1 Slingshot that you see in all t he Kolb advertisements and YouTube videos is for sale here in VA.- I spok e to the guy and he's letting it go for a very good price.- I'm afraid I- would kill myself in that thing.- He's the same size as I am and he has a 50+ mile stall speed in it.- He hits the numbers at about-65 and slowl y idles back.- Needs all of 1000 - 1200 feet. WOW--That is a lot of runway for a Sling shot. -One thing I learn over an d over when reading posts is that too many people use "indicated" rather th an actual airspeeds. In the original Kolb info, it lists 41 as the stall, my SS is around 44 cle an "actual". I have not tried landing as short as I can, but I think it lan ds as short or shorter than my Firestar will. The only real difference in p erformance is take off distance with the HKS is longer, and the sink rate i s much higher power off. Now that you mentioned that there is a SS for sale, I bet it will show inte rest. -If I already did not own one, I would be interested. Tom McCarthy 61C Fort Atkinson, WI N514TM Zenith 601HD N441TM Kolb Firestar N863GB Kolb Slingshot =0A=0A=0A ________________________________________________________________________________
Date: Jan 05, 2011
Whatever you put on the back of the cage, think in terms of the prop making it flex a lot. As in - a lot. Extra finishing tape, tie it to something solid, etc. or the prop pulses will cause paint cracks. Richard Pike Richard P/Gang: I had a fabric faring on the rear of my mkIII fuselage for the first 100 hours. Then it disentegrated. Replaced it with a .025" aluminum faring and it is still trucking after 3,000 hours. Had a fabric faring on the FS and never had a problem. Lots of difference between the drumming from a 447 and a 582. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 05, 2011
Cristal, To avoid that problem next time, empty your carb bowls if its going to sit idle any length of time. It only takes a couple of minutes to do, and saves alot of time and effort cleaning up later. (talking from experience):) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325744#325744 ________________________________________________________________________________
Date: Jan 05, 2011
> > > Whatever you put on the back of the cage, think in terms of the prop making >it flex a lot. As in - a lot. Extra finishing tape, tie it to something >solid, etc. or the prop pulses will cause paint cracks. > If you use light foam to fabricate the desired shape, you can cover it with almost anything and it will take the propeller battering. This can be seen at: http://jackbhart.com/firefly/firefly93.html It flew 186 air hours and I took it off after mounting the MZ 34. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jan 05, 2011
209GS wrote: > Cristal, > > To avoid that problem next time, empty your carb bowls if its going to sit idle any length of time. It only takes a couple of minutes to do, and saves alot of time and effort cleaning up later. (talking from experience):) Hi Gerard, Welcome to the Kolb list. I've been out of commission for almost a year having a baby (she came too early which caused me to not get my plane ready for long storage like I should have). Did you know you can place your information in your signature line of your profile so that we can always know who 209GS is and what he flies (or plans to fly)? :) -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Sept 2007 Private Pilot Aug 2008 ELSA Repairman for N193Y April 2008 Rotax 2 stroke maintenance April 2009 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325750#325750 ________________________________________________________________________________
Date: Jan 06, 2011
"Why haven't you tested full flaperon stall? john h" I did not test the full flaperon stall speed because the half flaperon stall speed is slow enough(35)... same stall speed as my last Firestar with no flaps. I usually land with 1/2 flaperons in 3-point and make the first turn-off (which is 550' from the numbers) on our paved runway. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325777#325777 Attachments: http://forums.matronics.com//files/k9g0_600.jpg ________________________________________________________________________________
Date: Jan 06, 2011
Subject: axair for sale
- only $3,500- a real deal- needs N# and motor--- only 60 hrs s ince new in 2004- =0Amal=0A-Malcolm Brubaker =0AMichigan Sport=0APilot Repair =0ALSRM-A, PPC, WS=0A(989)513-3022 =0A=0A=0A=0A=0A__________________ ______________=0AFrom: John Hauck <jhauck(at)elmore.rr.com>=0ATo: kolb-list@ma tronics.com=0ASent: Wed, January 5, 2011 1:00:24 PM=0ASubject: Re: Kolb-Lis t: Re: Looking for FS2 Close To VALooking for FS2 Close To =0AVA=0A=0A--> K olb-List message posted by: "John Hauck" =0A=0A=0A- One thing I learn over and over when reading posts is that too many people =0Ause "indicated" rather than actual airspeeds.=0A=0A> Tom McCarthy=0A=0A Tom M/Gang:=0A=0AI use IAS because that is the only airspeed instrument I h ave.=0A=0AWhere do you get your "acutal" airspeed?=0A=0AJust curious.=0A=0A ====0A=0A=0A ________________________________________________________________________________
Date: Jan 06, 2011
Subject: Special Airworthiness Information Bulletin for VW Engines
I just got this from the latest EAA News Letter. It's a Special Airworthiness Information Bulletin that recommends you retorque VW Heads. http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgSAIB.nsf/dc7bd4f27e5f1 07486257221005f069d/4a6335de983cb8b68625734c006353bc/$FILE/CE-07-43.pdf I don't know if this has been posted before, it was based on an accident in 2006. I use the Great Plains engine manual as the operating guide for my engine and they recommend you retorque the heads every year as part of the annual inspection. I had the exact thing happen as described in the bulleti n on a old VW camper bus years back so I know from personal experience that the head bolts can loosen with age (or maybe the studs stretch?) so I retorque my heads every year. I asked my VW expert that built my engine a while back and he didn't recommend you retorque the heads. He said that mos t people like to see bolts or nuts turn when they retorque, they cause more problems than they solve. I just bring the torque wrench up to the rated torque and stop. Most of the time the head bolts don't turn but some times they do. I have also had the oil pump nuts turn a bit when checking things. It=92s not a bad idea to check as many other engine bolts as you can easily get to every year also. Just don't over torque anything. Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Subject: Re: Special Airworthiness Information Bulletin for VW Engines
Date: Jan 06, 2011
just bring the torque wrench up to the rated torque and stop. Most of the time the head bolts don't turn but some times they do. Rick Neilsen Rick N/Folks: I thought you had to back off a nut or bolt, especially one that has been torqued for a while, then retorque to get an accurate reading??? If you try to torque without backing off, you may be working against seizure/friction caused by age??? john h Titus, Alabama ________________________________________________________________________________
Date: Jan 06, 2011
I did not test the full flaperon stall speed because the half flaperon stall speed is slow enough(35)... same stall speed as my last Firestar with no flaps. I usually land with 1/2 flaperons in 3-point and make the first turn-off (which is 550' from the numbers) on our paved runway. -------- Thom Riddle Thom R/Folks: Probably not going to be much difference, if any, between half and full flaperons. Flaperons don't do a whole lot on the SS or FF, compared to the flaps on the MKIII. However, if it was me, I'd want to explore and become proficient flying my airplane in all configurations to insure I was familiar with what to expect when and if I had to. I am so rusty now, 3 short flights last month, since I had my accident last May. Be glad to get some decent weather and time to go do some serious flying and learn how to fly my mkIII again. Times a flying. Three months to Sun and Fun. Just looked at the Sun and Fun web site. Surprise! Sun and Fun is 29 Mar - 3 Apr this year. Less than three months to go. Better get my plane washed before then. If I don't, it will be a record for length of time between washings. john h Titus, Alabama ________________________________________________________________________________
Date: Jan 06, 2011
Hi Cristal/Guys, I like your thoughts about JET flying... I'd log it if it happens:) On the topic, I just took apart my Bing 94/40 on my Jabiru 2200 due to fuel overflow during start after sitting for three years. Chris Ambrose had an issue with the float needle and I found I had the same "Pink" needle , which was recommended to be changed to the "Black" tipped one which has a stronger spring to facilitate a better seal. (Info for the Jab guys) I have one on order and my engine # is 902. I had a friend who worked as a car maintenance manager and he brought along Pipe cleaners and used those to clean out the overflow conduit and fuel intake couduit. Worked great on these bigger bores. He also suggested standard car Carb cleaner in a can. We did not touch the jets but I'd not hesitate to clean those gently and using fine copper wire for the smaller bores is now in my bag of tricks for the future. Just adding my 2 cents. frankD MX3, 0 Hrs Started engine. Learning about Carbs. Holister, Ca Trying to get to airworthy state. PS, Congrats on your baby. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325804#325804 ________________________________________________________________________________
Date: Jan 06, 2011
Rick there even a more serious AD out on the VW engine. I was notified from Great Planes that the wrist pin keepers may be the wrong part and therefore to small. When the engine heats up the pistons allow the keepers to fall out and scar the cylinder walls, a real bummer. He sent me a new set and I pulled the cylinders off to check and sure enough, mine had the wrong keepers installed. I called Steve, of Great Planes, and thanked him for possibly saving my engine and life. This AD note covered about a five year time period but don't remember the exact dates. Anyone that has buildt up one of these engines from them should call and find out if there engine might be at risk. -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325860#325860 ________________________________________________________________________________
Date: Jan 06, 2011
Subject: Re: FS2 for sale
I=C2-have a nice fs2 for sale its=C2-near Valley Forge=C2- PA=C2- =0A$6,500=C2-its realy in very nice shape and has quite a bit of history behind it.=0Aplease contact me off list=C2-=C2- call anytime=C2- for a link to some pics=C2-=C2-=C2- mal =0AMalcolm Brubaker =0A=0AMichiga n Sport=0APilot Repair =0ALSRM-A, PPC, WS=0A(989)513-3022 =0A=0A=0A=0A=0A__ ______________________________=0AFrom: Thom Riddle <riddletr(at)gmail.com>=0AT o: kolb-list(at)matronics.com=0ASent: Thu, January 6, 2011 8:28:46 AM=0ASubjec t: Kolb-List: Re: Looking for FS2 Close To VA=0A=0A--> Kolb-List message po sted by: "Thom Riddle" =0A=0A"Why haven't you tested fu ll flaperon stall? =0A=0Ajohn h"=0A=0AI did not test the full flaperon stal l speed because the half flaperon stall =0Aspeed is slow enough(35)... same stall speed as my last Firestar with no flaps. =0A=0A=0AI usually land wit h 1/2 flaperons in 3-point and make the first turn-off (which =0Ais 550' fr om the numbers) on our paved runway.=0A=0A--------=0AThom Riddle=0ABuffalo, NY (9G0)=0AKolb Slingshot SS-021=0AJabiru 2200A #1574=0ATennessee Prop 64x 32=0A=0A=0A=9CEveryone is entitled to his own opinion, but not his ow n facts.=9D=0ADaniel Patrick Moynihan=0A=0A=0A=0A=0ARead this topic o nline here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=325777#32577 7=0A=0A=0A=0A=0AAttachments: =0A=0Ahttp://forums.matronics.com//files/k9g0_ =C2- =C2- =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. =======0A=0A=0A ________________________________________________________________________________
Date: Jan 06, 2011
> I know it is not recommended to clean the idle and main jets even with the fine copper strand, be careful. > but was wondering if anyone has ever done it after they were gummed up Sometimes the motorcycle jets I work on are too blame small for carb cleaner to do much. Plus idle jets seem to be the ones that plug up first, being the smallest. I use a propane torch on them, holding them lightly but firmly with needle-nose vide-grips. After getting them very hot I can usually blow out a small amount of ash and have a clean idle jet. GeoB ________________________________________________________________________________
Date: Jan 07, 2011
Rick and John, I know this is about VW engines but... Jabiru specifies a head torque CHECK (not re-torque) after first 5 hours, 10 hours and 25 hours. Afterwards at 100 hour or annual. The purpose of the CHECK is to determine if there has been any loosening. Jabiru says NOT to loosen the head bolts and re-torque them, unless they are loose at proper torque setting. If loose, no need to loosen them, just torque up to spec. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325883#325883 ________________________________________________________________________________
Date: Jan 07, 2011
Jabiru specifies a head torque CHECK (not re-torque) after first 5 hours, 10 hours and 25 hours. Afterwards at 100 hour or annual. The purpose of the CHECK is to determine if there has been any loosening. Jabiru says NOT to loosen the head bolts and re-torque them, unless they are loose at proper torque setting. If loose, no need to loosen them, just torque up to spec. -------- Thom Riddle Glad we don't have to go through that drill with the 912 series engines. However, I did have a cylinder head loosen and leak on my first 912UL, a 1993 model. My other two engines, 912ULS, have not had that problem. Don't know of anyone else that experienced a loose head back then. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 07, 2011
...I did have a cylinder head loosen and leak on my first 912UL... On the two Jabiru 2200 engines I have maintenance experience with, so far the head bolt torque checks I have performed have not found any loosening. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325889#325889 ________________________________________________________________________________
Date: Jan 07, 2011
Rick My engine builder installed those teflon plugs instead of the wrist pin keepers. I have heard good and bad about the plugs but at least I don't have to work about my batch of keepers being too small. Rick Neilsen Redrive VW Powered MKIIIC On Thu, Jan 6, 2011 at 7:13 PM, Rick Lewis wrote: > > Rick there even a more serious AD out on the VW engine. I was notified > from Great Planes that the wrist pin keepers may be the wrong part and > therefore to small. When the engine heats up the pistons allow the keepers > to fall out and scar the cylinder walls, a real bummer. He sent me a new > set and I pulled the cylinders off to check and sure enough, mine had the > wrong keepers installed. I called Steve, of Great Planes, and thanked him > for possibly saving my engine and life. This AD note covered about a five > year time period but don't remember the exact dates. Anyone that has buildt > up one of these engines from them should call and find out if there engine > might be at risk. > > -------- > Rick Lewis > > (VW Watercooled Engine) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=325860#325860 > > ________________________________________________________________________________
Date: Jan 07, 2011
John makes a real good point. Should we be backing off a bit and then retorqe? My concern is that VW heads are assembled without any head gaskets. The last thing I would want to do is allow the cylinders to move within the head some and cause a leak that didn't before. Maybe only back off enough to get the nut or bolt to move? Another concern is a nut under a valve cover might become lubricated and be over torqued as a result (seems like torque specks are normally defined as dry unless specified as lubricated). Any thoughts out there???? Rick Neilsen Redrive VW Powered MKIIIC On Thu, Jan 6, 2011 at 9:49 AM, John Hauck wrote: > > > just bring the torque wrench up to the rated > torque and stop. Most of the time the head bolts don't turn but some times > they do. > > Rick Neilsen > > > Rick N/Folks: > > I thought you had to back off a nut or bolt, especially one that has been > torqued for a while, then retorque to get an accurate reading??? > > If you try to torque without backing off, you may be working against > seizure/friction caused by age??? > > john h > Titus, Alabama > > ________________________________________________________________________________
Date: Jan 07, 2011
I have been using an Ultrasonic cleaner for years, they are good for anything including the fuel injectors on my Beech. It works good. Instead of water you can fill it up with Kerosine or any potion that you want and they will do their magic. Strongly recommended as something that works. Besides once you remove your Kerosine you can put water and clean anything else that you want that fits there. I did a quick search and found a unit on amazon for about 36 bucks. Well, worth it. ------ http://www.amazon.com/Haier-HU335W-Ultrasonic-Cleaner/dp/B0000BVGNJ ------ I couldn't find the model I have but the above is pretty close in size to mine. It does not take long for the gizmo to get the shmutz out, if you look carefully you will see a little cloud come out when it first comes on vibrating. The injectors on an IO-360 are a bit bigger than the carb ones so they have more crap in them, I get a bigger visual effect than the Carb jets I would guess. Ron @ FHU ======================= ============ > I know it is not recommended to clean the idle and main jets even with the fine copper strand, be careful. > but was wondering if anyone has ever done it after they were gummed up Sometimes the motorcycle jets I work on are too blame small for carb cleaner to do much. Plus idle jets seem to be the ones that plug up first, being the smallest. I use a propane torch on them, holding them lightly but firmly with needle-nose vide-grips. After getting them very hot I can usually blow out a small amount of ash and have a clean idle jet. GeoB I have been cleaning the injectors on my Beech for a few years using a sonic cleaner. I did a quick G-search and here is a cheap one from Amazon --- -- kugelair.com ________________________________________________________________________________
Date: Jan 08, 2011
Thanks for the info and link -------- Firestar II 503 b-box Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326006#326006 ________________________________________________________________________________
Date: Jan 08, 2011
> I have been using an Ultrasonic cleaner for years A wonderful idea. One would have thought *I* would have come up with it. :-) I used to use one to clean my pen points when I was a draftsman long years ago. GeoB ________________________________________________________________________________
Date: Jan 08, 2011
> My engine builder installed those teflon plugs Can't you use both together? I have had engines mysteriously lose keepers. Totally ruins the cylinder reeeel fast. GeoB ________________________________________________________________________________
Subject: RE: Special Airworthiness Information Bulletin for VW Engines
Date: Jan 08, 2011
> John makes a real good point. Should we be backing off a bit and then retorqe? It worries me too to not retorque. The VW engine likes to be torqued properly. Some folks on assembly do the final torque of the heads AND the block at the same time. My engines have held together a purdy good without this though. GeoB ________________________________________________________________________________
Subject: Re: RE: Special Airworthiness Information Bulletin for VW Engines
Date: Jan 08, 2011
The VW engine likes to be torqued properly. Some folks on assembly do the final torque of the heads AND the block at the same time. My engines have held together a purdy good without this though. GeoB GeoB/Folks: Were those engines used in an aircraft application? john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Inflight emergencies/ Just curious
Date: Jan 08, 2011
Anyone ever saved his Kolb with an in-flight repair ? -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Faith is believing what you know ain't so - Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326024#326024 Attachments: http://forums.matronics.com//files/lolcaption_funny_fail_pics_climbing_out_of_a_plane_in_mid_air_pilot_flying_lol_113.jpg ________________________________________________________________________________
Date: Jan 08, 2011
While it is possible to damage jets I have found it easier to use wire to clean jets without damaging them then I have been able to clean my own rear with just toilet paper. [Laughing] For those that don't want to clean your dirty jet, send them to me, I will pay postage -------- Dale Whelan 503 powered Firestar II Projection, A simple and interesting Psychological concept Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326028#326028 ________________________________________________________________________________
Date: Jan 08, 2011
"Some folks" aren't very bright. You torque the case while rotating the crank to make sure a main bearing hasn't jumped off it's locating dowel pin. Piston drag will mask the symptom until damage is done. Good way to ruin parts without even running the engine. Rick Girard On Sat, Jan 8, 2011 at 11:14 AM, George Bearden wrote: > > > John makes a real good point. Should we be backing off a bit and then > retorqe? > > It worries me too to not retorque. The VW engine likes to be torqued > properly. Some folks on assembly do the final torque of the heads AND the > block at the same time. My engines have held together a purdy good without > this though. > > GeoB > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Subject: throttle cable splitter failure
Date: Jan 08, 2011
Kolb List, Yesterday afternoon I took my Firestar out of the hangar for a good cleaning and had plans for a short flight. After a good pre-flight check I took off to the south. I was full throttle and about 400' agl when the engine went to idle. By the time I determined my throttle cable had broken, a 180 turn to the field was not an option so I picked an opening in a field straight ahead and landed. After a walk to the highway and a couple of calls, I had some help show up. We got the plane out by folding her up and setting the tail on the truckbed for the ride back to the airport. I discovered the main throttle cable had not broken, but the soldered ferrule on the end of the main cable inside the splitter had failed. After seeing how the cable splitter works, (I had never opened one up before this) I am interested if anyone else on the Kolb list has ever had this happen? It's something you will not catch on a pre-flight. -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326058#326058 Attachments: http://forums.matronics.com//files/photo_0045_181.jpeg ________________________________________________________________________________
Date: Jan 08, 2011
Subject: Re: throttle cable splitter failure
Jimmy, I take it that the ferrule slipped right off the cable. Was the ferrule soldered, swedged, or molded? If it was soldered, can you tell if it's a cold solder joint? Do you know who supplied them? Rick Girard On Sat, Jan 8, 2011 at 6:15 PM, Jimmy Young wrote: > > Kolb List, > > Yesterday afternoon I took my Firestar out of the hangar for a good > cleaning and had plans for a short flight. After a good pre-flight check I > took off to the south. I was full throttle and about 400' agl when the > engine went to idle. By the time I determined my throttle cable had broken, > a 180 turn to the field was not an option so I picked an opening in a field > straight ahead and landed. > > After a walk to the highway and a couple of calls, I had some help show up. > We got the plane out by folding her up and setting the tail on the truckbed > for the ride back to the airport. > > I discovered the main throttle cable had not broken, but the soldered > ferrule on the end of the main cable inside the splitter had failed. > > After seeing how the cable splitter works, (I had never opened one up > before this) I am interested if anyone else on the Kolb list has ever had > this happen? It's something you will not catch on a pre-flight. > > -------- > Jimmy Young > Missouri City, TX > Kolb FS II/HKS 700 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=326058#326058 > > > Attachments: > > http://forums.matronics.com//files/photo_0045_181.jpeg > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Subject: Kolb/Jabiru carb overflow
Date: Jan 08, 2011
Hi guys, looking for suggestions here about the 94/40 Bing Carb on the Jabiru 2200 engine. I have started my engine but am getting fuel overflow at idle. I switched out the float needle valve as recommended with the black tipped one and cleaned out everything I could around the needle valve area. It still overflows at idle. Any ideas on how to fix this and what the issue may be? My thoughts are:- a/ the floats are getting stuck somehow in the bowl. b/ The needle valve seat still has some microscopic fibers or something I can't see. c/ There is a blockage of vents causing an air pocket and the floats are not fully lifting (one would think the overflow vent would stop this) Any ideas and suggestions for a fix are welcome Thanks Frankd M3X Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326078#326078 ________________________________________________________________________________
Date: Jan 08, 2011
Subject: Re: Kolb/Jabiru carb overflow
Frank, have you checked to make sure the float arm is parallel to the base of the carburetor body when the needle valve is seated? If it is past parallel, i.e. the ends of the arms are closer to the body than the pivot the fuel level will be too high and let fuel overflow. Have you checked the fuel pressure? Are you running a boost pump? Is it the correct model that limits fuel pressure to less than 4 psi? Assuming you have a boost pump, remove the float bowl and see if you can shut off the fuel flow by pushing lightly on the needle, then try the same by pushing on the float arms you could have something keeping the float arms from swinging freely. I looked at the picture of the pink tipped needle that you posted and it appears by the marks on it that it is seated properly, but all it takes is one imperfection to make it leak. Get a magnifying glass and look the brass seat over carefully. If in doubt replace it. Rick Girard On Sat, Jan 8, 2011 at 10:29 PM, Frankd wrote: > > Hi guys, > looking for suggestions here about the 94/40 Bing Carb on the Jabiru 2200 > engine. > > I have started my engine but am getting fuel overflow at idle. I switched > out the float needle valve as recommended with the black > tipped one and cleaned out everything I could around the needle valve area. > > It still overflows at idle. > Any ideas on how to fix this and what the issue may be? > > My thoughts are:- a/ the floats are getting stuck somehow in the bowl. > b/ The needle valve seat still has some microscopic fibers or something I > can't see. > c/ There is a blockage of vents causing an air pocket and the floats are > not fully lifting (one would think the overflow vent would stop this) > > Any ideas and suggestions for a fix are welcome > Thanks > Frankd > > M3X > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=326078#326078 > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Jan 09, 2011
Rick's recommendations are good ones and hitting on the most probable causes. However, the Jabiru installation manual states that the acceptable maximum fuel pressure is only 3 psi. >From Jabiru Installation manual: 4.4 Pressure to Carburettor (above ambient) Maximum 20 kPa (3 psi) Minimum 5 kPa (0.75 psi) and 11.3 Mechanical Fuel Pump The mechanical fuel pump is mounted on the engine crankcase and is camshaft driven. It is designed to supply fuel at the pressure described in the following paragraph. If fitted, the electrical boost pump must also fulfill the fuel input criteria for the carburettor, given below. 11.4 Carburettor A Bing constant depression type 94/40 is used. This carburettor has a minimum delivery pressure of 5 kPa (0.75 Psi) and a maximum pressure of 20 kPa (3 psi). To confirm that the fuel system is capable of delivering this pressure a fuel flow test must be performed. To check pressure, insert a T piece between the mechanical pump and the carby. Test boost pump with engine off, then mechanical fuel pump with engine on, then combine with electrical boost pump as well, before first flight. A method for performing a fuel flow test is available from Jabiru if required. A drip deflector to deflect overflowing fuel from the exhaust system is supplied as standard equipment on the engine. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326089#326089 ________________________________________________________________________________
Date: Jan 09, 2011
If you make up your own cables, you can easily guarantee that the cables will not pull out of the swedge. There is a countersunk end on the swedge, push the cable through so that the countersunk end is at the cable end. Push about 3/32" of cable through and then rat tail it severely with a small tool, and then pull it back in as far as it will go, it should be physically impossible to pull it through. If that is the case, then solder it. The attached pictures ought to give you the idea. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326090#326090 Attachments: http://forums.matronics.com//files/solderswage1_147.jpg http://forums.matronics.com//files/solderswage2_192.jpg http://forums.matronics.com//files/solderswage3_187.jpg http://forums.matronics.com//files/solderswage4_155.jpg ________________________________________________________________________________
Date: Jan 09, 2011
At 12:18 AM 1/9/2011, Richard Girard wrote: >...but all it takes is one imperfection to make it leak. Get a magnifying >glass and look the brass seat over carefully. If in doubt replace it. How often should one replace the float needle/seat? Or put another way, how often do they fail? Not the same engine or carb, (mine is a Cuyuna with Mikuni carb), but I had what appears to be the same thing, engine flooding while running, after it had been running fine all year. Happened once before, a few years back, and although the needle/seat didn't look bad then, I replaced it and the problem didn't happen again (until now). This time it almost put me down in a farm field. I haven't taken the carb apart yet,but I've ordered a Viton tipped needle (the old one was steel). -Dana -- Society is like a stew. If you don't keep it stirred up, you get a lot of scum on top. ________________________________________________________________________________
Date: Jan 09, 2011
Fuel venting causes: 1. float arms not adjusted properly. Fuel level to high in the bowl. (number one cause and an easy fix) 2. rough running engine or poor engine mounts causing the engine to shake so the floats can't properly control the level. 3. boost pump in series and running all the time and has too much fuel pressure to the carb. (not always a problem, but needs to be ruled out) 4. carb not mounted straight. Tilted to one side or the other too much. 5. debris around the carb needle and not effectively controlling fuel flow. Go after number 1 first and make sure your carb is not tilted. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326096#326096 ________________________________________________________________________________
Date: Jan 09, 2011
Hi guys, thanks for the suggestions. I do have an electric pump mounted at the bottom level of the tanks and it is a Facet (P/N4015) 4.5Max PSI , but I did not have it on while I get this condition. I now see that Aircraft spruce have a lower PSI pump (!). I have checked that the carb is not tilting side to side and one thing that came to mind is that it does tilt front to back due to the angle of the whole airframe so I can adjust the floats to close sooner. The overflow holes are towards the rear of the bowl. Engine Vibration appears normal, actually quite smooth so this is not a concern. I will double check the fuel pressure from the mechanical pump if adjusting the floats to close sooner does not work. I will also test both pumps operating in sequence to see if this causes a problem. Replacing the brass insert is on the list if none of the above works. Lots to do, thanks again for the pointers. FrankD Soon to be fixed M3X Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326108#326108 ________________________________________________________________________________
Date: Jan 09, 2011
thanks for the suggestions. FrankD Frank D/Folks: Correct float bowl level is critical to proper carb operation, as is the fuel float bowl static port and the static port in the intake lip of the carb. Float level to high, engine runs rich. Float level to low, engine runs lean. Set the level per your engine manufacturer's specs. Correct length and location of the float bowl chamber static port tubing is also very important. The engine manufacturer or Bing should be able to provide that information. That little port and tube are not vents, but static ports. The front and float bowl chamber static ports should read the same static pressure in order to operate correctly. The configuration of the Bing carbs on the 912 series engines, the way they are delivered new is the correct set up, per the Rotax folks. However, I discovered that configuration of accessories and location can affect airflow and the proper static pressure. To preclude this I run my float bowl chamber static port tube to the inside of my carb air filter covers. This has proven to work well on my airplane. What works for N101AB, may not work for you. john h mkIII Titus, Alabama - Already up to 30F from a low of 24 last night. Forecast is snow and cold for the next week. Ugh!!! ________________________________________________________________________________
Date: Jan 09, 2011
List, I think my problem was I did not have my throttle stop positioned properly. At full throttle I still had about 3/8" to go to get to the throttle stop, so I've probably been flying around for the past year & a half over-stressing the cable. I'll take car of that. Rick, The ferrule was soldered. The only kind of soldering I know of is hot, don't know what cold soldered is. Guess I should learn though. Rev. Pike, thanks for the photos and tip. I'll do that as well. Frank Goodnight suggested I set the throttle cable at the carbs to go to full throttle upon any cable failure and explained how to do it, probably will do that too. Thanks for the help- -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326123#326123 ________________________________________________________________________________
Date: Jan 09, 2011
Jimmy, A cold solder joint is a defective one. Instead of bright and shiny, the solder looks dull and leaden. Rick On Sun, Jan 9, 2011 at 12:38 PM, Jimmy Young wrote: > > List, > > I think my problem was I did not have my throttle stop positioned properly. > At full throttle I still had about 3/8" to go to get to the throttle stop, > so I've probably been flying around for the past year & a half > over-stressing the cable. I'll take car of that. > > Rick, The ferrule was soldered. The only kind of soldering I know of is > hot, don't know what cold soldered is. Guess I should learn though. > > Rev. Pike, thanks for the photos and tip. I'll do that as well. > > Frank Goodnight suggested I set the throttle cable at the carbs to go to > full throttle upon any cable failure and explained how to do it, probably > will do that too. > > Thanks for the help- > > -------- > Jimmy Young > Missouri City, TX > Kolb FS II/HKS 700 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=326123#326123 > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Jan 09, 2011
Frank, I had this issue as well.it would happen occasionally,and I dropped the bow l removed the needle and flushed the seat using the aux pump.It would be OK for a while ,then flood again,even after the new needle.When it happened, I could shut off the fuel run the engine till it leaned out which let the f loat drop and the needle pull off the seat, then open the fuel valve and it flushed the trash off the needle and seat and it would run fine for a few days.Some microscopic fuzz can do it. Starting at the tanks,new paper element filter,new lines all the way throu gh the gascolater,aux pump to the engine driven pump and to the carb, which IS tilted 20 degrees to even up the exhaust temps.No more problems even id le all the time. G.Aman MK-3C Jabiru 2200a 600hrs -----Original Message----- From: Frankd <frankd(at)foundrynet.com> Sent: Sat, Jan 8, 2011 11:32 pm Subject: Kolb-List: Kolb/Jabiru carb overflow Hi guys, looking for suggestions here about the 94/40 Bing Carb on the Jabiru 2200 engine. I have started my engine but am getting fuel overflow at idle. I switched out the float needle valve as recommended with the black tipped one and cleaned out everything I could around the needle valve area. It still overflows at idle. Any ideas on how to fix this and what the issue may be? My thoughts are:- a/ the floats are getting stuck somehow in the bowl. b/ The needle valve seat still has some microscopic fibers or something I c an't see. c/ There is a blockage of vents causing an air pocket and the floats are no t fully lifting (one would think the overflow vent would stop this) Any ideas and suggestions for a fix are welcome Thanks Frankd M3X Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326078#326078 ________________________________________________________________________________
Date: Jan 09, 2011
Without trying to refute what some of our learned colleagues have said about soldering cable ends....... For another view, here is the contents of a post April 2006: George Alexander wrote: > MAY BE A DUPLICATE RESPONSE... but anyway > Although nico sleeves weren't involved, from a personal experience, I would like to support what Ted said about heating the cable. > > In my case, the throttle cable was heated and solder applied to keep it from slipping through the connector to the throttle lever. The good news is that it snapped, on the ground, as part of my regular preflight. (Open the throttle to full and close it listening for the infamous "click" of the slides as they return home. They certainly clicked this time when the cable let go and they went home in a hurry!) > > On examination, there was noticeable discoloration from the point that was soldered, back about 1". The general consensus, of those that examined it, was that the break was caused by the effect on the cable of the heat application. (The failure may have been accelerated by the humid conditions here in FL.) The cable actually rusted through. Miffed that I didn't see the rust before it broke. Some of the discoloration/rust protruded from the connector enough to be seen. Conceptually a good idea, with not so good results. tc1917(at)hughes.net wrote: > I would like to add something to the 'solder the end of the cable to keep it > from slipping through the nico' discussion. > > If you heat a steel/SS cable even to solder it, it seems to lose its ability to flex and will become brittle and break upon bending. -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326148#326148 ________________________________________________________________________________
Date: Jan 09, 2011
After seeing how the cable splitter works, (I had never opened one up before this) I am interested if anyone else on the Kolb list has ever had this happen? It's something you will not catch on a pre-flight. -------- the best prevention for this happening is to have a throtle quadrant stop,, adjusted so the cable can't be over tight when pulled to idle for the 912's or WOT on the 2 strokes. boyd young mkiii ________________________________________________________________________________
Date: Jan 09, 2011
Hi George,=0AI believe- accepted procedure is to dip the cable in molten solder rather than =0Aheating the cable.=0AThat way the cable never gets ov er 300 degrees or whatever temp the solder is. I =0Adon't think the cable =0A=0Ais affected when it's done this way.I have also had a cable corode un till it =0Abroke ( I live near salt water & =0A=0Athe salty air got it) , n ot visable on even a good preflight only wa-to check is =0Ato desolder th e cable and remove=0Ait from the housing and resolder afterwards---I do it -2 times a year, takes less =0Athan an hour, worth it to me.=0AFor-what its worth.=0AFrank Goodnight-=0A=0A=0A=0A=0A____________________________ ____=0AFrom: George Alexander <gtalexander(at)att.net>=0ATo: kolb-list@matroni cs.com=0ASent: Sun, January 9, 2011 4:28:14 PM=0ASubject: Kolb-List: Re: th Alexander" =0A=0AWithout trying to refute what some o f our learned colleagues have said about =0Asoldering cable ends.......=0A =0AFor another view, here is the contents of a post April 2006:=0A=0AGeorge Alexander wrote:=0A=0A> MAY BE A DUPLICATE RESPONSE... but anyway =0A> Alt hough nico sleeves weren't involved, from a personal experience, I would =0A>like to support what Ted said about heating the cable. =0A>=0A> =0A> In my case, the throttle cable was heated and solder applied to keep it from =0A>slipping through the connector to the throttle lever. The good news is that it =0A>snapped, on the ground, as part of my regular preflight. (Open the throttle to =0A>full and close it listening for the infamous "click" of the slides as they =0A>return home. They certainly clicked this time when the cable let go and they =0A>went home in a hurry!) =0A>=0A> =0A> On exami nation, there was noticeable discoloration from the point that was =0A>sold ered, back about 1". The general consensus, of those that examined it, was =0A>that the break was caused by the effect on the cable of the heat applic ation. =0A>(The failure may have been accelerated by the humid conditions h ere in FL.) The =0A>cable actually rusted through. Miffed that I didn't see the rust before it =0A>broke. Some of the discoloration/rust protruded fro m the connector enough to be =0A>seen. Conceptually a good idea, with not s o good results. =0A>=0A=0A=0Atc1917(at)hughes.net wrote: =0A=0A> I would li ke to add something to the 'solder the end of the cable to keep it =0A> fro m slipping through the nico' discussion. =0A>- =0A> If you heat a steel/S S cable even to solder it, it seems to lose its ability to =0A>flex and wil l become brittle and break upon bending.=0A=0A=0A--------=0AGeorge Alexande r=0AFS II R503- N709FS=0Ahttp://www.oh2fly.net=0A=0A=0A=0A=0ARead this to pic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=326148# ==================== ________________________________________________________________________________
Date: Jan 09, 2011
Hi Jabbers.. As you all know I had the problem with the float needle too and after replacing the needle had the same problem...after 3 successful forced landings in 3 weeks,we finally fixed it today...I'm not so sure it was even the float needle to start with...today I got a fuel pressure reading and it was putting out 7 lbs of pressure ! Disconnected the mechanical pump and ran it on the electric pump that was putting out 2-3.2 lbs and it ran perfect ! I removed the mechanical pump,placed an extra .030 gasket between the pump and the engine and the fuel pressure went from 7 lbs to 3.2 and stayed right there and ran great... Why it started pumping so much more gas I have no idea... chris ambrose M3X/jabiru A-2200 N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326153#326153 ________________________________________________________________________________
Date: Jan 09, 2011
> "Some folks" aren't very bright. You have passed judgment already? > You torque the case while rotating the crank to make sure a main bearing hasn't jumped off it's locating dowel pin. If "some folks" are fairly resourceful and careful, might they not have anticipated this need and provided for it? > Piston drag will mask the symptom until damage is done. Unless someone has anticipated the problem and provided for it. These VW engines were not used in aircraft applications. > Good way to ruin parts without even running the engine. I bought an expensive Pontiac someone had rebuilt and locked up this way. When it wouldn't turn over after engine installation they let it sit for a coupla years then sold it to me for a fraction of its value. WITH an engine full of new parts. :-) Ran good after reassembly. GeoB ________________________________________________________________________________
Date: Jan 09, 2011
George, Build four or five VW engines and report back. Rick On Sun, Jan 9, 2011 at 8:11 PM, George Bearden wrote: > > > "Some folks" aren't very bright. > > You have passed judgment already? > > > You torque the case while rotating the crank to make sure a main bearing > hasn't jumped off it's locating dowel pin. > > If "some folks" are fairly resourceful and careful, might they not have > anticipated this need and provided for it? > > > Piston drag will mask the symptom until damage is done. > > Unless someone has anticipated the problem and provided for it. > > These VW engines were not used in aircraft applications. > > > Good way to ruin parts without even running the engine. > > I bought an expensive Pontiac someone had rebuilt and locked up this way. > When it wouldn't turn over after engine installation they let it sit for a > coupla years then sold it to me for a fraction of its value. WITH an engine > full of new parts. :-) > > Ran good after reassembly. > > GeoB > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Jan 09, 2011
Subject: Interesting video
If you remember when one of the boys from the A/V dept brought the projector to class and set it up to run, you'll love this. Rick Girard -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Jan 10, 2011
Chris, Very glad to hear you found the actual problem. It IS a mystery as to why it changed over time. A couple questions: 1- Had you done any fuel pump maintenance before this happened? What is the total gasket thickness now? 2- Are your electric and mechanical fuel pumps in series or parallel? 3- Do you normally run the electric during all phases of flight? FWIW, my electric pump is plumbed in parallel with the mechanical and I use the electric to fill the float bowl before starting and during approach and take-off. I know the Facet is a 100% duty cycle pump which could be run full time but it is an old habit of mine not to use it except as stated. Also, I've never removed my fuel pump so don't know how much gasket is there and I don't have a fuel pressure gage installed so don't know what it is producing. I think I'll ckeck it out during next condition inspection. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326229#326229 ________________________________________________________________________________
Date: Jan 10, 2011
Subject: Re: Interesting video
Did I miss something here? At 09:25 PM 1/9/2011, you wrote: >If you remember when one of the boys from the A/V dept brought the >projector to class and set it up to run, you'll love this. > >Rick Girard > >-- >Zulu Delta >Kolb Mk IIIC >582 Gray head >4.00 C gearbox >3 blade WD >Thanks, Homer GBYM > >It is not bigotry to be certain we are right; but it is bigotry to >be unable to imagine how we might possibly have gone wrong. > - G.K. Chesterton > > ________________________________________________________________________________
Date: Jan 10, 2011
No, but I did. http://www.youtube.com/watch?v=ftq8jTQ8ANE <http://www.youtube.com/watch?v=ftq8jTQ8ANE>Rick On Sun, Jan 9, 2011 at 9:25 PM, Richard Girard wrote: > If you remember when one of the boys from the A/V dept brought the > projector to class and set it up to run, you'll love this. > > Rick Girard > > -- > Zulu Delta > Kolb Mk IIIC > 582 Gray head > 4.00 C gearbox > 3 blade WD > Thanks, Homer GBYM > > It is not bigotry to be certain we are right; but it is bigotry to be > unable to imagine how we might possibly have gone wrong. > - G.K. Chesterton > > > * > > * > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Subject: 912S engine start
Date: Jan 10, 2011
Started my engine for the first time yesterday. It had been sitting in the basement for about a year but started immediately and sounded great. Have to do some throttle adjustments and prop pitch changes. I had about 5700 rpm and still had some throttle to go. I used 10 degree angle on a 70" three blade warp prop. Will try 12 degrees and see how that works. Rex Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326253#326253 ________________________________________________________________________________
Subject: Re: 912S engine start
Date: Jan 10, 2011
Started my engine for the first time yesterday. It had been sitting in the basement for about a year but started immediately and sounded great. Have to do some throttle adjustments and prop pitch changes. I had about 5700 rpm and still had some throttle to go. I used 10 degree angle on a 70" three blade warp prop. Will try 12 degrees and see how that works. Rex Rex R/Gang: I prop for 5400 static WOT. That gives me 5500 WOT straight and level with my MKIII. john h mkIII 912ULS 71" Warp Drive 3 Blade Fast Taper Titus, Alabama - Freezing rain. Woke up to 32F. Now 33F. Think I'll stay inside today. ________________________________________________________________________________
Subject: 912ULS and IVO prop for sale
Date: Jan 10, 2011
For anyone who's interested=2C I have a 2007 912s for sale with 330 hrs. so ft start=2C slipper clutch=2C etc. runs perfectly. lots of new stuff instal led. 100 hrs on 68inch IVO$13=2C999Daniel Myersh20maule(at)hotmail.com407 920 7700 ________________________________________________________________________________
Date: Jan 10, 2011
Thanks John. Do you remember what angle you used? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326268#326268 ________________________________________________________________________________
Date: Jan 10, 2011
Rick, Thanks for that video post. My Firestar does not have the aerodynamic wing strut fiberglass shell installed. This will be one of the first things I do before I fly it. Thanks Dennis Good [Idea] ! -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Faith is believing what you know ain't so - Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326275#326275 ________________________________________________________________________________
Date: Jan 10, 2011
John The manual for the SportCruiser says that Rotax 912 ULS should be operated normal cruise at 4,800-5,300 but with 100LL 5,000-5,300. I assume this is to deal with the high lead content of 100LL. Interesting. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Jan 10, 2011 at 11:55 AM, John Hauck wrote: > > > Started my engine for the first time yesterday. It had been sitting in > the > basement for about a year but started immediately and sounded great. Have > to do some throttle adjustments and prop pitch changes. I had about 5700 > rpm and still had some throttle to go. I used 10 degree angle on a 70" > three blade warp prop. Will try 12 degrees and see how that works. > > Rex > > > Rex R/Gang: > > I prop for 5400 static WOT. > > That gives me 5500 WOT straight and level with my MKIII. > > john h > mkIII > 912ULS > 71" Warp Drive 3 Blade Fast Taper > Titus, Alabama - Freezing rain. Woke up to 32F. Now 33F. Think I'll stay > inside today. > > ________________________________________________________________________________
Date: Jan 10, 2011
The manual for the SportCruiser says that Rotax 912 ULS should be operated normal cruise at 4,800-5,300 but with 100LL 5,000-5,300. I assume this is to deal with the high lead content of 100LL. Interesting. Rick Neilsen Rick N/Folks: Yes, I'd think it had to do with lots of lead. john h mkIII Titus, AL ________________________________________________________________________________
Date: Jan 10, 2011
From: "Kirby, Dennis Civ USAF AFMC AFNWC/EN" <Dennis.Kirby(at)kirtland.af.mil>
<< Push about 3/32" of cable through and then rat tail it severely with a small tool ... then solder it. >> Jimmy - The exact thing happened to me a few years ago, on my Mark-3. Throttle cable slipped thru the ferrule. Fortunately for me, on the 912, the carbs spring to full throttle if the cable lets go. This gave me the fortunate opportunity to fly back to my airport, enter the pattern, and shut down the engine on downwind, making for and easy deadstick pattern and landing. Richard Pike shared the same advice with me (above) at the time , on fixing the cable/ferrule interface. It's an excellent solution - guaranteed not to ever pull thru again. That's how I fixed it on my Kolb. Glad to hear you exercised excellent judgment, and made a safe landing without damage to you or your Firestar. Dennis Kirby Mark-III, 912ul, Sandia Park, NM ________________________________________________________________________________
Date: Jan 10, 2011
> George, Build four or five VW engines and report back. Reporting as requested sir. Been there, done that. Some I built as hot-rods, some as mpg champs, once as a wedding gift, always with care. GeoB ________________________________________________________________________________
Date: Jan 10, 2011
Thanks John. Do you remember what angle you used? ********************************** Not for sure. 12 to 12.5 sounds pretty good. Each engine and prop will have its own setting. Main thing when you get it dialed in close is to insure all three blades are set the same, even if it was over or under 5500 WOT straight and level flight, by just a little bit. I doubt most of our tachs are all that accurate anyhow. I usually do a prop tach check when I adjust my prop to insure my engine tach is close. john h mkIII Titus, AL ________________________________________________________________________________
Date: Jan 10, 2011
Richard , I am amazed at how much difference there is , I built my-KXP wi th =0Astreamlined wing struts but didnt realize how munch difference it mad !-Thanks =0Afor that link and I think there is more to learn on that sam e Youtube page-Chris =0ADavis=0AKXP 503 492 hrs=0AGlider Pilot=0ADisabled from crash building Firefly =0A=0A=0A=0A=0A_______________________________ _=0AFrom: Richard Girard <aslsa.rng(at)gmail.com>=0ATo: kolb-list(at)matronics.co m=0ASent: Mon, January 10, 2011 11:35:05 AM=0ASubject: Re: Kolb-List: Inter esting video=0A=0ANo, but I did. =0A=0Ahttp://www.youtube.com/watch?v=ftq 8jTQ8ANE=0A=0ARick=0A=0A=0AOn Sun, Jan 9, 2011 at 9:25 PM, Richard Girard < aslsa.rng(at)gmail.com> wrote:=0A=0AIf you remember when one of the boys from the A/V dept brought the projector to =0Aclass and set it up to run, you'll love this. =0A=0A>=0A>=0A>Rick Girard=0A>=0A>-- =0A>=0A>Zulu Delta=0A>Kolb Mk IIIC=0A>582 Gray head=0A>4.00 C gearbox=0A>3 blade WD=0A>Thanks, Homer GBYM=0A>=0A>=0A>It is not bigotry to be certain we are right; but it is big otry to be unable to =0A>imagine how we might possibly have gone wrong.=0A> ---G.K. Chesterton=0A>=0A>=0A>=0A> get="_blank">http://www.matroni cs.com/Navigator?Kolb-List =0A>tp://forums.matronics.com _blank">http://w ww.matronics.com/contribution =0A>=0A=0A=0A-- =0A=0AZulu Delta=0AKolb Mk IIIC=0A582 Gray head=0A4.00 C gearbox=0A3 blade WD=0AThanks, Homer GBYM=0A =0AIt is not bigotry to be certain we are right; but it is bigotry to be un able to =0Aimagine how we might possibly have gone wrong.=0A---G.K. Che =0A=0A=0A=0A ________________________________________________________________________________
Date: Jan 10, 2011
I'll try 12 degrees and see what happens. I have an E.I.S. and also a tach guage. They were within about 25 rpm of each other as best I could see so I'm comfortable that it's a good reading. The Rotax manual that I have ok's a max. continuous speed of 5500 rpm but 5 minutes only at 5800 rpm. Rex Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326316#326316 ________________________________________________________________________________
Date: Jan 10, 2011
Ok...Chapter 14....I thought I had the problem solved ,then I flew it today...stayed over the airport for about 10 minutes and it seemed to run fine...headed out over the lake,throttled down to loose some altitude and it started all over again...I headed back to the airport and it sounded like it was going to quit again...I kept the throttle wide open and luckily it started to clear out and kept running....land ... Called Pete at Jabiru ,told him about spacing the pump out .030 and it seemed to be ok....his thought now was the spring in the pump needed replacing...I removed the spring...took about 7/16 off the spring put it back on the plane with a fuel pressure Gage and at idle I had 1.7 and it went to almost 3lbs wide open....when I GET THE NEW SPRING ,i WILL PUT IT IN AND TAKE ANOTHER pressure reading.... stay tuned... chris ambrose M3X/jabiru N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326322#326322 ________________________________________________________________________________
Date: Jan 10, 2011
Richard , I am amazed at how much difference there is , I built my KXP with streamlined wing struts but didnt realize how munch difference it mad ! Chris Davis Chris D/Gang: 1987, I was flying my brand new FS without brakes and with standard round lift struts out of Gantt IAP, all 600 feet of it. I finally saved up enough money to buy 4130 streamlined tubing for new lift struts. Brother Jim welded them up for me, I got them prepped, painted, and installed. On my first test flight I was amazed at how stable and solid the FS felt. The round aluminum struts were constantly dancing in flight. On my first landing I had to go around. I ran out of airstrip. With no brakes to slow me down, and a hefty increase in glide and reduction in drag, I had to rethink my landings. Was time for brakes. ;-( By Spring 1988, I had brakes and longer heat treated 4130 gear legs, 35.5" long. I chose that length because Lindberg Heat Treating in Orlando, FL, could only go 36". By being able to get the nose higher during landing and roll out I was able to use the bottom of the wing to help slow me down, plus my new Hegar Brakes. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 10, 2011
The Rotax manual that I have ok's a max. continuous speed of 5500 rpm but 5 minutes only at 5800 rpm. Rex Rex/Gang: That is why we pitch for 5500 straight and level WOT with a fixed pitch or ground adjustable prop. If we pitch for 5800 we have terrific climb and poor cruise. Pitch for 5500 and we get the best climb and cruise combo. 5800 could be used for 5 min if you had an inflight adjustable prop, which would be a nice toy, but not really necessary to have fun and fly where you want to. I have never had a problem being pitched for 5500. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 10, 2011
From: william sullivan <williamtsullivan(at)att.net>
- John- Very interesting info about your Firestar.- I have a set of ste el (!) streamlined struts, almost 10 pounds for the pair.- I intended to swap them out for round aluminum to cut some weight.- Once they are off, I will probably put them up for grabs.- Your comment about your 600 foot field got my attention.- My spot for a field at my place in Vt. is about 600 to 700 feet long.- It's on top of a small hill, with the ground being lower at both ends.- The prevailing wind is aligned with the runway.- I was wondering about the necessity of brakes, and now I know.- I wonder if Richard Pike still has the old FS brakes he mentioned.- - ------------------------- ------------------------- ------- Bill Sullivan ------------------------- ------------------------- ------- Windsor Locks, Ct. ------------------------- ------------------------- ------- FS 447 ________________________________________________________________________________
Date: Jan 10, 2011
Subject: Re: Interesting video -> Drag Reduction
Date: Mon, 10 Jan 2011 11:34:24 -0800 (PST) From: chris davis <capedavis(at)yahoo.com> > Richard , I am amazed at how much difference there is , I built my KXP with streamlined wing struts but didnt realize how munch difference it mad ! Thanks for that link and I think there is more to learn on that same Youtube page > Chris, If you are interested in drag reduction, see: http://jackbhart.com/firefly/pdrag.html And everything under "Drag Reduction" on the following: http://jackbhart.com/firefly/fireflyindex.html Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jan 10, 2011
John- Very interesting info about your Firestar. I have a set of steel (!) streamlined struts, almost 10 pounds for the pair. I intended to swap them out for round aluminum to cut some weight. Once they are off, I will probably put them up for grabs. Bill Sullivan Windsor Locks, CT. FS 447 Bill S/Gang: I think the reduction in drag, absence of vibration, and good solid feel of the steel streamlined struts will far outweigh the difference in weight, which probably will not be that much. Definitely not progressing going round aluminum. john h mkIIUI Titus, Alabama ________________________________________________________________________________
Subject: FW: Type certificate for KOLB MARK II TWINSTAR/ Rotax 582
Date: Jan 10, 2011
Hallo Everybody! Can somebody send me a type certificate by copy for my KOLB MARK II TWINSTAR/with Rotax 582/? It would be the best in english language, or in others. Please to help for a " poor" kolb pilot!!!!!!!!!!!!!!!!!!! Thank's. Zolt=E1n Tibor KOLB Twinstar/R582 zetebete@t-online.hu ________________________________________________________________________________
Date: Jan 10, 2011
Ok...Chapter 14....I thought I had the problem solved ,then I flew it today...stayed over the airport for about 10 minutes and it seemed to run fine...headed out over the lake,throttled down to loose some altitude and it started all over again...I headed back to the airport and it sounded like it was going to quit again...I kept the throttle wide open and luckily it started to clear out and kept running....land ... Called Pete at Jabiru ,told him about spacing the pump out .030 and it seemed to be ok....his thought now was the spring in the pump needed replacing...I removed the spring...took about 7/16 off the spring put it back on the plane with a fuel pressure Gage and at idle I had 1.7 and it went to almost 3lbs wide open....when I GET THE NEW SPRING ,I WILL PUT IT IN AND TAKE ANOTHER pressure reading.... stay tuned... chris ambrose >>>>>>>>>>>>>>> seems that springs loose tension after time.... I am puzzled on how you would get an increase of pressure.... is there any chance at a reduced power setting there is a vibration that is putting enough bubbles in the float bowl that the float wont sense the correct level? boyd young mkiii ________________________________________________________________________________
Date: Jan 10, 2011
OK.. Our theory on the spring is this....as the spring gets rusty from condensation it gets more brittle and harder thusly,making more pressure as it pushes the fuel into the carb...cutting it off,making it shorter also made the spring weaker and reducing the pressure...you think ???When I get the new spring ,I am going to rust proof it just for the heck of it then re-install it and take another pressure reading.... chris ambrose Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326355#326355 ________________________________________________________________________________
Date: Jan 10, 2011
Contrary view...Wow there are thousands of those engines in service, lots with very high hours, and yours is the first to suffer "rusty fuel pump spring hardness"? I am unaware of the metallurgy that leads to increased elastic modulus from rusted steel surface damage. Maybe something hangs up on the spring movement or a diaphragm movement......I think I would look again for maybe a vacuum or vent leak in the induction systems that develops with temperature differential. Best of luck.. Bob ---- ces308 wrote: > > OK.. > > Our theory on the spring is this....as the spring gets rusty from condensation it gets more brittle and harder thusly,making more pressure as it pushes the fuel into the carb...cutting it off,making it shorter also made the spring weaker and reducing the pressure...you think ???When I get the new spring ,I am going to rust proof it just for the heck of it then re-install it and take another pressure reading.... > > chris ambrose > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=326355#326355 > > > > > > > > > > ________________________________________________________________________________
Date: Jan 10, 2011
Subject: Re: FW: Type certificate for KOLB MARK II TWINSTAR/ Rotax
582 Kolbs (in the US at least) don't have type certificates, which are only for factory produced aircraft. Kolbs here are certificated in the Experimental category, with only an airworthiness certificate. -Dana At 04:08 PM 1/10/2011, zetebete wrote: > >Can somebody send me a type certificate by copy for my KOLB MARK II >TWINSTAR/with Rotax 582/? > >It would be the best in english language, or in others. -- But, Officer, a broadsword is hardly a concealed weapon! ________________________________________________________________________________
Date: Jan 10, 2011
Subject: 3 in egt needed
yes i need a 3 in egt-gage-- please reply off list ell send cash fast mal=0A-Malcolm Brubaker =0AMichigan Sport=0APilot Repair =0ALSRM-A, PPC, WS=0A(989)513-3022 =0A=0A=0A=0A=0A________________________________=0AFrom: daniel myers =0ATo: kolb-list(at)matronics.com=0ASent: Mon, January 10, 2011 11:55:04 AM=0ASubject: Kolb-List: 912ULS and IVO prop for sale=0A=0A=0AFor anyone who's interested, I have a 2007 912s for sale with 330 hrs. soft =0Astart, slipper clutch, etc. runs perfectly. lots of n ew stuff installed. 100 hrs =0Aon 68inch IVO =0A=0A$13,999=0ADaniel Myers =0A=0A=0A=0A ________________________________________________________________________________
Date: Jan 10, 2011
Subject: Firestar winter flying video
Friends, I recently uploaded a video, made years ago, to YouTube. It was my first attempt at video and isn't that great or sharp but it does give an idea of how flying is done up north in winter. http://www.youtube.com/watch?v=-a834qGn-OU Enjoy, I hope. Jon L Minnesota ________________________________________________________________________________
From: "Larry Cottrell" <lcottrell1020(at)hughes.net>
Subject: Re: Firestar winter flying video
Date: Jan 10, 2011
Very nice Jon. Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ________________________________________________________________________________
Date: Jan 10, 2011
Very nice Jon. Larry Even the sun looks cold up there in the Far North. Very nice flying and video. Be glad when the weather straightens itself out down here in the sunny south and I can go fly a little. john h mkIII Titus, AL ________________________________________________________________________________
Date: Jan 10, 2011
Thanks Jon from Minnesota ...." Hi Mom !" :) Very enjoyable footage. -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Faith is believing what you know ain't so - Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326443#326443 ________________________________________________________________________________
Date: Jan 11, 2011
Jon, Great video! Here in Buffalo, we get a good bit more snow than you but it does not get as cold as it does there in MN, compliments of the Lakes Eire and Ontario. Unfortunately, our winter flying conditions are generally poor because of the nearly constant low overcast and high winter winds, also compliments of being downwind from the Lakes. In the past week we have had unusually nice conditions, colder than normal but some sunshine and rather low winds but my Slingshot is moth-balled for the winter. If climate change continues on its current trajectory, I might not moth-ball it next winter. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326467#326467 ________________________________________________________________________________
Date: Jan 11, 2011
- Nice video, but it raises a couple of questions.- What about the tail wheel?- Does it sink in and drag, or do you have a short ski hooked to i t?- How do you cross the bare spots on the pavement?- Get into the hang er?- Just curious. - ------------------------- -------------------- Bill Sullivan ------------------------- -------------------- Windsor Locks, Ct. ------------------------- -------------------- FS 447 ________________________________________________________________________________
Date: Jan 11, 2011
[quote="williamtsullivan(at)att.n"] I was wondering about the necessity of brakes, and now I know. I wonder if Richard Pike still has the old FS brakes he mentioned. Bill Sullivan Windsor Locks, Ct. FS 447 [quote] Sitting in the hangar, give me a call, 423-323-9441 or richard (at) bcchapel.org Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326484#326484 ________________________________________________________________________________
582
Date: Jan 11, 2011
Hallo Dana Thank You very-very much, for your urgent reply! I understand, you wrote me.So I must tell, I need an airworthiness certificata of KOLB MARK II.TWINSTAR/R582. Would You be so kinde to help me to receive a copy. It's my problem, my KOLB is forbided by the aviation authority.Namely, my KOLB is the one single KOLB plane in Hungary, and so the authority does'n know this type. Regards Tibi From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Dana Hague Sent: Monday, January 10, 2011 11:53 PM Subject: Re: Kolb-List: FW: Type certificate for KOLB MARK II TWINSTAR/ Rotax 582 Kolbs (in the US at least) don't have type certificates, which are only for factory produced aircraft. Kolbs here are certificated in the Experimental category, with only an airworthiness certificate. -Dana At 04:08 PM 1/10/2011, zetebete wrote: Can somebody send me a type certificate by copy for my KOLB MARK II TWINSTAR/with Rotax 582/? It would be the best in english language, or in others. -- But, Officer, a broadsword is hardly a concealed weapon! ________________________________________________________________________________
582
Date: Jan 11, 2011
Personally=2C if "I" had an airworthiness certificate=2C I'd send him a c opy. What he does with it is up to him. Mike Welch From: zetebete@t-online.hu Subject: RE: Kolb-List: FW: Type certificate for KOLB MARK II TWINSTAR/ Rot ax 582 Date: Tue=2C 11 Jan 2011 21:00:11 +0100 Hallo Dana Thank You very-very much=2C for your urgent reply! I understand=2C you wrote me.So I must tell=2C I need an airworthiness cer tificata of KOLB MARK II.TWINSTAR/R582. Would You be so kinde to help me to receive a copy. It=92s my problem=2C my KOLB is forbided by the aviation authority.Namely =2C my KOLB is the one single KOLB plane in Hungary=2C and so the authority does=92n know this type. Regards Tibi From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@m atronics.com] On Behalf Of Dana Hague Sent: Monday=2C January 10=2C 2011 11:53 PM Subject: Re: Kolb-List: FW: Type certificate for KOLB MARK II TWINSTAR/ Rot ax 582 Kolbs (in the US at least) don't have type certificates=2C which are only f or factory produced aircraft. Kolbs here are certificated in the Experime ntal category=2C with only an airworthiness certificate. -Dana At 04:08 PM 1/10/2011=2C zetebete wrote: Can somebody send me a type certificate by copy for my KOLB MARK II TWINSTA R/with Rotax 582/? It would be the best in english language=2C or in others. -- But=2C Officer=2C a broadsword is hardly a concealed weapon! http://www.ma tronics.com/Navigator?Kolb-Listhttp://forums.matronics.comhttp://www.matron ics.com/contribution ________________________________________________________________________________
Date: Jan 11, 2011
Subject: Re: FW: Type certificate for KOLB MARK II TWINSTAR/ Rotax 582
Tibi Maybe some one in England or one of the other countries that requires one can send you what they have. If you really have a MKII there may not be any type certificates anywhere. If you have a MKIII maybe a certificate from a country that requires one can send you what they have. How about it out there? Again most of us are in the United States and we aren't required to have on e so none of us have one to send you. Rick Neilsen Redrive VW Powered MKIIIC On Tue, Jan 11, 2011 at 3:08 PM, Mike Welch wrote : > Personally, if "*I*" had an airworthiness certificate, I'd send him a > copy. > > What he does with it is up to him. > > Mike Welch > > ------------------------------ > From: zetebete@t-online.hu > > To: kolb-list(at)matronics.com > Subject: RE: Kolb-List: FW: Type certificate for KOLB MARK II TWINSTAR/ > Rotax 582 > Date: Tue, 11 Jan 2011 21:00:11 +0100 > > > Hallo Dana > > > Thank You very-very much, for your urgent reply! > > I understand, you wrote me.So I must tell, I need an airworthiness > certificata of KOLB MARK II.TWINSTAR/R582. > > Would You be so kinde to help me to receive a copy. > > It=92s my problem, my KOLB is forbided by the aviation authority.Namely, my > KOLB is the one single KOLB plane in Hungary, and so the authority does =92n > know this type. > > Regards > > Tibi > > > *From:* owner-kolb-list-server(at)matronics.com [mailto: > owner-kolb-list-server(at)matronics.com] *On Behalf Of *Dana Hague > *Sent:* Monday, January 10, 2011 11:53 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: FW: Type certificate for KOLB MARK II TWINSTAR/ > Rotax 582 > > > Kolbs (in the US at least) don't have type certificates, which are only f or > factory produced aircraft. Kolbs here are certificated in the Experimen tal > category, with only an airworthiness certificate. > > -Dana > > At 04:08 PM 1/10/2011, zetebete wrote: > > > Can somebody send me a type certificate by copy for my KOLB MARK II > TWINSTAR/with Rotax 582/? > > It would be the best in english language, or in others. > > > -- > > But, Officer, a broadsword is hardly a concealed weapon! > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?Kolb-List* > > ** > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > * > > arget=_blank>http://www.matronics.com/Navigator?Kolb-List > ttp://forums.matronics.com > =_blank>http://www.matronics.com/contribution > * > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Jan 11, 2011
582 At 03:00 PM 1/11/2011, zetebete wrote: >I understand, you wrote me.So I must tell, I need an airworthiness >certificata of KOLB MARK II.TWINSTAR/R582. > >Would You be so kinde to help me to receive a copy. > >It s my problem, my KOLB is forbided by the aviation authority.Namely, my >KOLB is the one single KOLB plane in Hungary, and so the authority does n >know this type. I can't help you; my Kolb doesn't have an airworthiness certificate (it's not required) and it's not a Twinstar anyway. In the US, every Kolb is amateur built, so each one is (legally) different. The manufacturer is not "Kolb", but whoever actually builds the plane. The design itself is not certificated. Did you build it yourself, or did you buy it from outside of the country? If the latter, the seller should have something, no? -Dana -- Question Authority and the authorities will question you! ________________________________________________________________________________
Date: Jan 11, 2011
582 I agree with Mike W, I would send him my certificate scanned or otherwise if I had one. I guess the G-robots there need something to show them that this type of craft is Really really certificated in the big world outside of their domain. and if it comes from Uncle Sam its good, its even better for the Euro mentality if it would be a UK certificate. ________________________________________________________________________________
Subject: Air foil for cable...
Date: Jan 11, 2011
Kolber's, A year or two ago someone posted drag values for parts of a Kolb, if I remember right. I was amazed at the drag values for the cables on the tail. One of you, with a lot more skill than me, can probable come up with an airfoil for a cable! Winter is not over yet, what do you think? Thanks as all ways for all your knowledge! Nick Cassara Palmer, Alaska Kolbra #1 ________________________________________________________________________________
Date: Jan 12, 2011
Subject: Re: Air foil for cable...
> I was amazed at the drag values for the cables on the tail. I would like to see the drag values too. I have been thinking about this issue- now, I am not any kind of aircraft guru, completely new to aircraft- so I am just 'seeding' the discussion with an idea. Have you ever used Shoo-goo? Great stuff. Much stronger and tougher than silicone seal, yet comes in a squeeze tube. I wish the feller in the lab coat in the video had demonstrated the drag of a tube faired on only one side, because that is what I am thinking- run a bead of shoo-goo down a cable, shape it into a 'V' between your fingers somehow. A Kolber posted pics somewhere showing aluminum v-shaped fairings he had a sheet metal shop brake for him. They were rivited to the sides, forming a trailing edge streamlined shape. Don't know how effective they are (he had no test data either) but it gave me the idea on the cable streamlining. ________________________________________________________________________________
Date: Jan 12, 2011
With all the current excitement about cutting drag it occurs to me that most of the examples shown have been for much higher speeds that the ones we generally fly at. I forget the maths now but doesn`t drag increase at the square of the speed or something like that? Streamling lift struts etc might be worth it, and it looks nice, but is it worth it for cables at speeds of 50 to 70? WW1 biplanes used tear drop shaped cables certainly but they were operating at around 100mph and few of us reach that and live to tell the tale. Just a thought Pat ________________________________________________________________________________
Date: Jan 12, 2011
All the thoughts expressed here are right on target, but dont forget the common simple/basic cause of carb flooding which is HEAVY FLOAT. With metal floats - a leak/pinhole or with composite floats - soggy/porous. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326654#326654 ________________________________________________________________________________
582
Date: Jan 12, 2011
If the person requireing a C of A for a Kolb will contact me I am happy to e-mail or fax a copy of the Permit to Fly issued by the CAA in the UK. It is valid until Mar 15th which may or may not be of significance. If it will help I can supply a copy of the Form completed by my Inspector last March. Authority likes to have a form even if they do not understand what it is for. Pat Ladd ________________________________________________________________________________
Date: Jan 12, 2011
From: "elleryweld(at)aol.com" <elleryweld(at)aol.com>
-----Original Message----- Date: Wednesday, January 12, 2011 2:36:20 am From: "Nick Cassara" <nickc(at)mtaonline.net> Subject: Kolb-List: Air foil for cable... Kolber's, would it reduce drag if you was to fold a peice of vinal tape in half over the cable to give it at least a 3/4 inch trailing edge reduce drag? A year or tw o ago someone posted drag values for parts of a Kolb, if I remember right. I was amazed at the drag values for the cables on the tail. One of you, with a lot more skill than me, can probable come up with an airfoil for a cable! Winter is not over yet, what do you think? Thanks as all ways for all your knowledge! Nick Cassara Palmer, Alaska Kolbra #1 ________________________________________________________________________________
Date: Jan 12, 2011
would it reduce drag on a cable if you was to fold a peice of vinal tape in half to leave a 3/4 inch trailing edge? let the testing begin -----Original Message----- Date: Wednesday, January 12, 2011 2:36:20 am From: "Nick Cassara" <nickc(at)mtaonline.net> Subject: Kolb-List: Air foil for cable... Kolber's, A year or two ago someone posted drag values for parts of a Kolb, if I remember right. I was amazed at the drag values for the cables on the tail. One of you, with a lot more skill than me, can probable come up with an airfoil for a cable! Winter is not over yet, what do you think? Thanks as all ways for all your knowledge! Nick Cassara Palmer, Alaska Kolbra #1 ________________________________________________________________________________
Date: Jan 12, 2011
At 02:26 AM 1/12/2011, Nick Cassara wrote: >One of you, with a lot more skill than me, can probable come up with an >airfoil for a cable! Streamlined wires have long been used in aircraft. There are a couple of companies that still make them today. They're solid wire, rolled to the streamline shape, then threads have to be formed at the ends... they're special order, of course, made to the specific length you need... and expensive. Years ago, in U-control (control line) model airplane racing (these models can go 200+ mph, on 60' cables of around .015 diameter), somebody figured out that the lines were 80% or more of the drag, and came up with what was termed "funny lines"... basically a streamlined enclosure to hold the two lines close together, one behind the other. The original was a thin wall tube slipped over the front wire, and a bit of tap wrapped around and stuck to itself forming a tab in back, forming a crude airfoil shape. The rear wire ran through the gap in the tape immediately behind the tube. Later, molded plastic shapes were used. IIRC, they cleaned up in the speed events at the Nationals that year... and funny lines were promptly banned immediately afterwards. -Dana -- Beam me up, Scotty, it ate my phaser. ________________________________________________________________________________
Date: Jan 12, 2011
This is overexposed, but you get the idea: OD 5/16" X 5/32" X 35", ID 1/8" X 1/4". Got it at the local RC hobby shop, thinwall aluminum, weight 1/2 oz. Ought to be able to slip a tail brace wire through it during cable assembly, Goop it to an end fitting to keep it from pivoting. Use 2 pieces, each one attached at an end fitting, leave the middle of the wire uncovered so you could still fold the tail? Maybe squeeze it thinner so that it has less cross section? Food for thought... Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326673#326673 Attachments: http://forums.matronics.com//files/sl_125.jpg ________________________________________________________________________________
Date: Jan 12, 2011
Regarding drag; this is an interesting video that has been circulating on other groups. http://www.youtube.com/watch?v=ftq8jTQ8ANE On Wed, Jan 12, 2011 at 2:53 AM, George Bearden wrote: > > > I was amazed at the drag values for the cables on the tail. > > I would like to see the drag values too. > > I have been thinking about this issue- now, I am not any kind of aircraft > guru, completely new to aircraft- so I am just 'seeding' the discussion with > an idea. > > Have you ever used Shoo-goo? Great stuff. Much stronger and tougher than > silicone seal, yet comes in a squeeze tube. > > I wish the feller in the lab coat in the video had demonstrated the drag of > a tube faired on only one side, because that is what I am thinking- run a > bead of shoo-goo down a cable, shape it into a 'V' between your fingers > somehow. > > A Kolber posted pics somewhere showing aluminum v-shaped fairings he had a > sheet metal shop brake for him. They were rivited to the sides, forming a > trailing edge streamlined shape. Don't know how effective they are (he had > no test data either) but it gave me the idea on the cable streamlining. > > ________________________________________________________________________________
Date: Jan 12, 2011
The experiment we saw on the video and many others are explained in the book "Shape and Flow, the Fluid Dynamics of Drag" by Ascher H. Shapiro, published by Doubleday Anchor. It's out of print but I got a copy via the internet. Rex Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326709#326709 ________________________________________________________________________________
Date: Jan 12, 2011
The experiment we saw on the video and many others are explained in the book "Shape and Flow, the Fluid Dynamics of Drag" by Ascher H. Shapiro, published by Doubleday Anchor. It's out of print but I got a copy via the internet. Rex Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326710#326710 ________________________________________________________________________________
Date: Jan 12, 2011
> would it reduce drag on a cable if you was to fold a peice of vinal tape in half to leave a 3/4 inch trailing edge? let the testing begin >Ellery Ellery=2C Yes=2C I bet it would....a lot. What about this idea? I have a roll of heavy thickness aluminum tape=2C the kind air conditioning installers use (that's who I go it from!!). It has a protective tape on it. What if we cut the tape to length=2C then bent it lengthwise=2C down the middle? Then we pulled off the protective tape. Next=2C carefully (!!) stick a len gth of nylon string exactly down the center on the crease-line (this to hold the a luminum tape back a bit from the blunt edge=2C sort of trying to maintain the airfo il shape). Now=2C with the cable good & tight=2C try to accurately adhere the tape o nto one edge of cable. Once you have the orientation accurate=2C begin pinching th e two sides of the tape. It may take a couple of practice runs=2C but I bet a guy could make a rea lly good looking aluminum tape cable airfoils. Mike Welch ________________________________________________________________________________
Date: Jan 12, 2011
It may take a couple of practice runs, but I bet a guy could make a really good looking aluminum tape cable airfoils. Mike Welch How much drag reduction to you expect to receive from streamlining 8 to 10 feet of 3/32" cable? Doubt you or your Kolb would ever notice the difference. The following does not pertain to cable air foils, but it does have something to do with reducing drag and improving air flow to the prop on a MKIII. The first modification we made to my MKIII fuselage was replace the 7/16" or 1/2" round 4130 tubes with streamlined 4130 tubes at the rear of the fuselage that brace the lower side of the rear engine mount. Don't know how much good that did, but was bound to make some improvement removing that drag and air turbulence right before it was fed into the cleanest part of the prop arch. Another thing we did that reduced drag was the main landing gear legs. Only 18" of .125" gear leg are exposed to the air stream. Permanently enclosing the upper rear of the fuselage also reduced drag, as did the keel faring on the bottom of the fuselage. The keel faring also cleaned up air going to the prop. Still the quickest MKIII until someone comes along that can out run me, side by side. Last race I had was at the Kolb Homecoming a couple years back with Steven Green and his MKIII powered with a 912ULS. I beat hands down. ;-) If only I could have out run John Williamson and his 912ULS powered Kolbra. John was 10 mph quicker than Miss P'fer. Skinny Kolbs are faster than fat ones. john h mkIII Titus, Alabama ________________________________________________________________________________
582
Date: Jan 12, 2011
For Mr. Pat Ladd Hy Pat, Many thank four your offer. It would be very good, if you can send me a copy of your Kolb certificate. I don't know, it's accetable or not for the aviation authority.In any case- it' more,thann nothing. I'm awaiting the copy to my address.: zetebete@t-online.hu Many-many thank's for your help! By Zolt=E1n Tibi From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Pat Ladd Sent: Wednesday, January 12, 2011 12:26 PM Subject: Re: Kolb-List: FW: Type certificate for KOLB MARK II TWINSTAR/ Rotax 582 If the person requireing a C of A for a Kolb will contact me I am happy to e-mail or fax a copy of the Permit to Fly issued by the CAA in the UK. It is valid until Mar 15th which may or may not be of significance. If it will help I can supply a copy of the Form completed by my Inspector last March. Authority likes to have a form even if they do not understand what it is for. Pat Ladd ________________________________________________________________________________
Subject: Type certificate for KOLB MARK II TWINSTAR
Date: Jan 12, 2011
Pat=2C John Brown=2C or any of our other British friends with Kolbs=2C I was looking through all my original Kolb paperwork to see if I had anyt hing that could help out our buddy Tibi=2C and came across a statement in the Kolb sales br ochure bragging how safe=2C wonderful etc.=2C the MkIII is. In this Kolb Aircraft Company letter=2C it brags about how the MkIII has been CERTIFIED (note the magic word certifed!!) to the "rigorous BCAR-s standard" in the U .K. Wow!! Now=2C I don't exactly know what that means=2C but it sure sounds officia l to me. The fact of the matter is=2C Tibi is probably being forced to come up wit h some kind of dumbass useless paperwork for some lard-ass desk jockey. (oops=2C my an ti-government feelings just slipped out) Question for you helpful British blokes=3B can one of you really nice gu ys dig up one of those "certified BCAR-s standards" for this chap? It would probably be especiall y helpful if it had the word 'KOLB MkIII' on the form=2C I'd bet. How about help ing this lad out?? Mike Welch MkIII=2C but no certified paperwork=2C not yet=2C at least. From: zetebete@t-online.hu Subject: RE: Kolb-List: FW: Type certificate for KOLB MARK II TWINSTAR/ Rot ax 582 Date: Wed=2C 12 Jan 2011 21:36:53 +0100 For Mr. Pat Ladd Hy Pat=2C Many thank four your offer. It would be very good=2C if you can send me a copy of your Kolb certificate . I don=92t know=2C it=92s accetable or not for the aviation authority.In any case- it=92 more=2Cthann nothing. I=92m awaiting the copy to my address.: zetebete@t-online.hu Many-many thank=92s for your help! By Zolt=E1n Tibi From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@m atronics.com] On Behalf Of Pat Ladd Sent: Wednesday=2C January 12=2C 2011 12:26 PM Subject: Re: Kolb-List: FW: Type certificate for KOLB MARK II TWINSTAR/ Rot ax 582 If the person requireing a C of A for a Kolb will contact me I am happy to e-mail or fax a copy of the Permit to Fly issued by the CAA in the UK. It i s valid until Mar 15th which may or may not be of significance. If it will help I can supply a copy of the Form completed by my Inspector l ast March. Authority likes to have a form even if they do not understand what it is fo r. Pat Ladd http://www.matronics.com/Navigator?Kolb-Listhttp://forums.matroni cs.comhttp://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 12, 2011
Subject: zenair floats plans.
several years aho i sold a set of plans for the zenair floats to a-Kolber =0A-can anyone rember buying a set?-- i lost my copy and need anothe r- mal=0A-Malcolm Brubaker =0AMichigan Sport=0APilot Repair =0ALSRM-A, PPC, WS=0A(989)513-3022 =0A=0A=0A=0A=0A________________________________=0AF rom: "elleryweld(at)aol.com" =0ATo: kolb-list(at)matronics.co m=0ASent: Wed, January 12, 2011 7:43:44 AM=0ASubject: RE: Kolb-List: Air fo =0A=0Awould it reduce drag on a cable if you was to fol d a peice of vinal tape in half =0Ato leave a 3/4 inch trailing edge?- le t the testing begin =0A=0A-----Original Message-----=0ADate: Wednesday, Jan uary 12, 2011 2:36:20 am=0ATo: <kolb-list(at)matronics.com>=0AFrom: "Nick Cass ara" =0ASubject: Kolb-List: Air foil for cable...=0A =0AKolber's,=0A=0A=0A=0AA year or two ago someone posted drag values for pa rts of a Kolb, if I=0Aremember right. I was amazed at the drag values for t he cables on the tail.=0A=0A=0A=0AOne of you, with a lot more skill than me , can probable come up with an=0Aairfoil for a cable! =0A=0A=0A=0AWinter is not over yet, what do you think?=0A=0A=0A=0AThanks as all ways for all you r knowledge!=0A=0A=0A=0ANick Cassara=0A=0APalmer, Alaska=0A=0A=0A=0AKolbra ======================0A=0A=0A ________________________________________________________________________________
Subject: Re: Type certificate for KOLB MARK II TWINSTAR
Date: Jan 12, 2011
Subject: Kolb-List: Type certificate for KOLB MARK II TWINSTAR I was looking through all my original Kolb paperwork to see if I had anything that could help out our buddy Tibi, and came across a statement in the Kolb sales brochure bragging how safe, wonderful etc., the MkIII is. Mike Welch MkIII, but no certified paperwork, not yet, at least. He has a MKII, not a MKIII. john h MKII Titus, Alabama ________________________________________________________________________________
Date: Jan 12, 2011
Yeah=2C uh huh=2C a simple keystroke. > He has a MKII=2C not a MKIII. > > john h > MKII > Titus=2C Alabama ________________________________________________________________________________
Date: Jan 12, 2011
-----Original Message----- Date: Wednesday, January 12, 2011 5:53:36 pm From: "Malcolm Brubaker" <brubakermal(at)yahoo.com> Subject: Kolb-List: zenair floats plans. several years aho i sold a set of plans for the zenair floats to aKolber can anyone rember buying a set? i lost my copy and need another mal Malcolm Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS (989)513-3022 malcolm i am the one that got the plans for the floats from you i will see about getting a copy made up i will let you know when i have that done i think i remember where i last had them ________________________________ From: "elleryweld(at)aol.com" <elleryweld(at)aol.com> Sent: Wed, January 12, 2011 7:43:44 AM Subject: RE: Kolb-List: Air foil for cable... would it reduce drag on a cable if you was to fold a peice of vinal tape in half to leave a 3/4 inch trailing edge? let the testing begin -----Original Message----- Date: Wednesday, January 12, 2011 2:36:20 am From: "Nick Cassara" <nickc(at)mtaonline.net> Subject: Kolb-List: Air foil for cable... Kolber's, A year or two ago someone posted drag values for parts of a Kolb, if I remember right. I was amazed at the drag values for the cables on the tail. ________________________________________________________________________________
Subject: Re: Kolb/Jabiru carb overflow
Date: Jan 12, 2011
Hi Jabbernuts ! Did anyone here know there are 2 different springs?? The silver one is the one we are supposed to have ..it puts out 2-3 lbs....the gold spring puts out 7 lbs....and some of the engines "got out" with the gold springs.....Imagine that.....Mine was to rusted to see what color ( seee picture) even after we cleaned it up... chris ambrose M3X/Jabiru N327cs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326776#326776 ________________________________________________________________________________
Date: Jan 12, 2011
sorry...forgot the pictures... chris ambrose Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326777#326777 Attachments: http://forums.matronics.com//files/img_1640_831.jpg http://forums.matronics.com//files/img_1639_193.jpg http://forums.matronics.com//files/img_1638_138.jpg ________________________________________________________________________________
Date: Jan 12, 2011
- Chris- looks like condensation from somewhere. - ------------------------- ----------------- Bill Sullivan ------------------------- ----------------- Windsor Locks, Ct. ------------------------- ----------------- FS 447 --- On Wed, 1/12/11, ces308 wrote: From: ces308 <ces308(at)ldaco.com> Subject: Kolb-List: Re: Kolb/Jabiru carb overflow Date: Wednesday, January 12, 2011, 8:21 PM sorry...forgot the pictures... chris ambrose Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326777#326777 Attachments: http://forums.matronics.com//files/img_1640_831.jpg http://forums.matronics.com//files/img_1639_193.jpg http://forums.matronics.com//files/img_1638_138.jpg le, List Admin. ________________________________________________________________________________
Date: Jan 12, 2011
Subject: Re: zenair floats plans.
i thot that was you elery i may hve a set of of 950 for sale did you ever b uild =0Aa set?--- would like to build the amphibs if i sell my streai ght- set- mal=0A-Malcolm Brubaker =0AMichigan Sport=0APilot Repair =0ALSRM-A, PPC, WS=0A(989)513-3022 =0A=0A=0A=0A=0A_________________________ _______=0AFrom: "elleryweld(at)aol.com" <elleryweld(at)aol.com>=0ATo: kolb-list@m atronics.com=0ASent: Wed, January 12, 2011 7:04:50 PM=0ASubject: RE: Kolb-L (at)aol.com" =0A=0A=0A-----Original Message-----=0ADate: W ednesday, January 12, 2011 5:53:36 pm=0ATo: kolb-list(at)matronics.com=0AFrom: "Malcolm Brubaker" =0ASubject: Kolb-List: zenair fl oats plans.=0A=0Aseveral years aho i sold a set of plans for the zenair flo ats to a-Kolber =0A-can anyone rember buying a set?-- i lost my cop y and need another- mal=0A-Malcolm Brubaker =0AMichigan Sport=0APilot R epair =0ALSRM-A, PPC, WS=0A(989)513-3022 =0A=0Amalcolm i am the one that go t the plans for the floats from you i will see about =0Agetting a copy made up i will let you know when i have that done i think i =0Aremember where i last had them=0A=0A=0A________________________________=0AFrom: "elleryweld (at)aol.com" =0ATo: kolb-list(at)matronics.com=0ASent: Wed, J anuary 12, 2011 7:43:44 AM=0ASubject: RE: Kolb-List: Air foil for cable... .com>=0A=0Awould it reduce drag on a cable if you was to fold a peice of vi nal tape in half =0A=0Ato leave a 3/4 inch trailing edge?- let the testin g begin =0A=0A-----Original Message-----=0ADate: Wednesday, January 12, 201 1 2:36:20 am=0ATo: <kolb-list(at)matronics.com>=0AFrom: "Nick Cassara" <nickc@ mtaonline.net>=0ASubject: Kolb-List: Air foil for cable...=0A=0AKolber's, =0A=0A=0A=0AA year or two ago someone posted drag values for parts of a Kol b, if I=0Aremember right. I was amazed at the drag values for the cables on ==================0A=0A=0A ________________________________________________________________________________
Date: Jan 12, 2011
"Wow..."got out"....we used to call that an "escapement " in the DoD universe. Sounds like you are very close to getting back to a highly reliable powerplant! " This really has been a very reliable engine and other than this,I could be happier with this engine ! It should be all better next week....then look out for the new videos !!! lol chris ambrose M3X/jabiru A-2200 N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326809#326809 Attachments: http://forums.matronics.com//files/img_1635_185.jpg ________________________________________________________________________________
Date: Jan 13, 2011
He has a MKII, not a MKIII.>> Hi John, If all he is tryng to do is establish the fact that the Kolb is an established aircraft it probably wont make much difference. I am willing to send him a copy of my Permit to Fly and of the form which my Inspector filled out last March if it will help the guy out. Pat ________________________________________________________________________________
Date: Jan 13, 2011
Chris, Thanks for the update about two different springs. That was news to me and very much worth knowing. I've not taken my fuel pump apart but will next condition inspection just to see what is what. I hope you will post this information on the JabiruEngines Yahoo group since that seems to be the busiest of the Jabiru lists. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326847#326847 ________________________________________________________________________________
Date: Jan 13, 2011
Subject: Video producers please school me.
Hi all, I really enjoy watching the various videos that are posted. It is interesting to see the scenery and terrain that fellow Kolbers fly over. I would also like to learn to post videos of some of my local flights. What video cameras and mounts are you guys using to make these videos? My computer skills are limited and I need something very user friendly and not real expensive. If you feel this topic this isn`t worthy of the list, please e-mail me off list at donaho1(at)verizon.net Lanny N598LF ________________________________________________________________________________
Date: Jan 13, 2011
If all he is tryng to do is establish the fact that the Kolb is an established aircraft it probably wont make much difference. Pat No problem here. Didn't know if Mike W had caught that, or if it would make any difference. john h - 17F (no flying today) mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 13, 2011
Chris=2C In viewing the photos of the inside of your fuel pump=2C it appears to me that you have a significant amount of water getting into your fuel system. Either by condensation=2C fuel container transfer=2C or something =2C it looks like an issue you should address. I don't recall seeing anywhere how many hours you have on your engine=2C but it can't be a tremendous amount. I'm just wondering how an area that is supposed to have zero (!!) moisture=2C is somehow getting so much. Maybe I'm not seeing the photos clearly=2C but that's what I see. In my opinion=2C if your fuel system is well designed=2C and you don't ha ve any "obvious" culprits=2C at the very least I'd consider using a 'water separat or' style funnel. I'm not a fuel expert=2C or anything like that=2C but it jus t seems to me there is something you need to fix!! I'm curious......do you fill up your fuel tank(s) in your plane EVERY tim e you park it? According to what I heard once=2C you are supposed to fill u p your tanks after you fly the plane. Full tanks have very little room for a ir to deposit moisture on the inside walls of your fuel tank. Do you have a 'well placed' moisture trap?? I mean=2C one that does a gr eat job of letting ALL the water settle into it=2C and allows for easy and thor ough drainage. I think this is something you REALLY need to be confident of!! Let's keep the off-airport landings to a minimum! Mike Welch ________________________________________________________________________________
Date: Jan 13, 2011
In viewing the photos of the inside of your fuel pump, it appears to me that you have a significant amount of water getting into your fuel system. Mike Welch Mike W/Gang: The corrosion seems to be on the crank case side of the pump, not the fuel side. The engine oil is probably not getting hot enough to cook off condensation, which collects where ever it can find a home, e.g., the cavity in the fuel pump and many other places inside the engine. I do not know about the Jabiru, but 912 engine oil must get at least 190F, during a flight, to be hot enough to burn off condensation. An easy check is remove the oil tank cap, after a flight, to see if there is a milky substance covering the bottom of the cap. If it is, it isn't running hot enough. For me, that much corrosion in the fuel pump would be cause to wonder about the rest of the engine. Chris has been flying in some very cold weather this year. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 13, 2011
From: Mike Welch <mdnanwelch7(at)hotmail.com> Date: Thu, 13 Jan 2011 06:26:37 -0800 > In viewing the photos of the inside of your fuel pump, it appears to me that you have a significant amount of water getting into your fuel system. Either by condensation, fuel container transfer, or something, it looks like an issue you should address. > Mike, Every engine has combustion blow-by from the combustion chamber that passes the rings and piston and on into the crankcase. And, since a high percentage of the combustion products is water vapor, it is not surprising to find it accumulating and condensing on things inside the crankcase. In most cases, if you can keep the crankcase and the parts in side it at or above 180 degrees F, most of the moisture will not condense inside the case and will blow on out the vent as vapor. Fortunately for us two strokers this is not much of problem as the crankcase is constantly purged with fresh air, fuel, and lubricant. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jan 13, 2011
Mike and John,hello, The fuel pump is on the side of the engine,right in the slipstream and hangs upside down and tilted...it looks like oil for lubrication comes from just enough clearance around the push-rod to drip on the pump actuator and then a small ,about an 1/8 " hole at the bottom for an oil return to the crank case...there is a cavity above that where the return spring is that has no air going through it or oil getting to it,so with the slipstream of cold air going over the hot/warm pump case it has to be making some moisture there....I don't think it's a lot ,but enough to collect on the spring and the bottom of the diaphragm.I have never seen moisture in the oil fill tube or the dipstick...Oil temps in the winter...at 16* is 160-185...I have never found any water in my fuel system... I'll get a picture of where the pump goes on so you can see what I'm talking about... chris ambrose M3X/Jabiru A-2200 172. hrs TT N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326879#326879 ________________________________________________________________________________
Date: Jan 13, 2011
Subject: Freeze point
- Something just occurred to me.- John has 17 degrees, and we have 20 d egrees up in Ct.- Do any of you Kolbers with liquid cooled engines (espec ially down south) bother to check the freeze point on your coolant?- Ever ybody talks about engine running temps, but not frozen engines. - ------------------------- ------------------------- -- Bill Sullivan ------------------------- ------------------------- -- Windsor Locks, Ct. ------------------------- ------------------------- -- FS 447 - ------------------------- --------- ________________________________________________________________________________
Subject: Re: Freeze point
Date: Jan 13, 2011
Something just occurred to me. John has 17 degrees, and we have 20 degrees up in Ct. Do any of you Kolbers with liquid cooled engines (especially down south) bother to check the freeze point on your coolant? Everybody talks about engine running temps, but not frozen engines. Bill Sullivan I do that when I replace the antifreeze, normally 50/50 with distilled water. Change it out about once every year or two. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 13, 2011
> The corrosion seems to be on the crank case side of the pump=2C not the f uel > side. > Chris has been flying in some very cold weather this year. > > john h > mkIII > Titus=2C Alabama John=2C guys=2C Thanks for the clarification. You can see I'm no Jabiru fuel pump expert . One thing I do know=2C tho=2C is that simply reaching 180-190 degrees F isn 't all there is to moisture in your crankcase. Once you've achieved a steady-state warm engine=2C let's say 190 F=2C you have to maintain that temperature long enough to do some good. How long? Well =2C that depends on a lot of factors=2C like engine design=2C ventilation=2C et c. The condensation is going to take a while to be able to 'escape' through a breather cap or v ent=2C or whatever. Just getting the engine to 190F and shutting it off=2C isn't going to eliminate moisture. In fact=2C it'll make it worse=2C because it is the co oling down effect that causes condensation. Seeing as how the moisture is a product of Chris's crankcase (and not his fuel delivery system)=2C then this would possibly be a characteristic of his fly ing conditions=2C or flying habits=2C wouldn't it? Possibly due to the cold=2C northern cli mate=2C or the duration of his flights=2C or maybe even the wrong thermostat for his conditions=2C clearly something needs to be remedied. Without a doubt=2C Chris needs to make his flights a lot longer=2C or cer tainly long enough to achieve a dryer moisture level inside his engine's crankcase..... 'cause what he has at the present is causing some risky landings!! Simple question=2C Chris=3B How long would you say your typical flight is? 15 minutes? 30?? Also=2C can you get a higher temp rated thermostat? This might help a lot. Mike Welch ________________________________________________________________________________
Date: Jan 13, 2011
Attached is a photo of the Jabiru 2200 fuel pump from the Installation Manual. You can't see it in this photo but the fuel line FROM the pump to the carb is behind the supply line with the fire sleeve to the pump. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326888#326888 Attachments: http://forums.matronics.com//files/jab2200_fuel_pump_997.jpg ________________________________________________________________________________
Date: Jan 13, 2011
Thanks for the clarification. You can see I'm no Jabiru fuel pump expert. One thing I do know, tho, is that simply reaching 180-190 degrees F isn't all there is to moisture in your crankcase. Mike Welch Mike W/Folks: I went back and looked at the new Owners Manual, 912 series engines: - Eng Oil Temp operating range 190 to 230F (This temp is read at the outlet end of the oil pump, but before it goes back through the engine. This is oil fresh from the oil cooler.) - The manual also states eng oil temp should attain at least 212F some time during flight each day. It does not explain if this is 212F at the eng oil temp sender on the aft end of the oil pump, or oil temp when blow by gases push the oil out the crankcase on its way to the oil tank after it has been heated inside the engine. My experience has worked out well using the old spec which was attain 190F during the flight. No time at or above that temp specified. If I comply with this, I have a nice clean oil tank cap on the inside. If I don't get the eng oil to 190F (indicated), I'll have the tale tell milky looking oil residue inside the cap. My experience has also been that condensation converts to steam well below the boiling point of 212F. I also know there is 3 to 5 psi crankcase pressure constantly purging the crankcase of steam/contaminents, pushing oil out of the crankcase and back to the oil tank. The condensation does not have to be boiled out of the crankcase. About the only way one could get the engine oil temp to 190F on the ground (912) would be bypass the eng oil cooler and tape up the radiator. Difficult to get 120F, as required, prior to going full throttle, especially when it is cold. Don't think it is the cooling down that causes condensation in the 912 engines, but the by product of combustion. There is a lot of water in the air, especially here in the SE. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 13, 2011
Attached is a photo of the Jabiru 2200 fuel pump from the Installation Manual. You can't see it in this photo but the fuel line FROM the pump to the carb is behind the supply line with the fire sleeve to the pump. -------- Thom Riddle Thom R/Folks: The way the pump is mounted, inverted and canted, seems to be a built in situation to trap condensation. The 912 eng driven fuel pump is a "run of the mill" Pierburg pump, about the same as used on the old Opels. It is a throwaway pump that can not be disassembled. It is mounted on the gearbox and driven off a lobe on the prop shaft. Maybe this location reduces the amount of condensation it is exposed to, maybe not. ;-) john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 13, 2011
My Jabiru engine has its fuel pump located as shown in the photo I posted. I have an oil breather "catch can" that I empty after each flight by opening the petcock in the catch can drain line. It always drains out several drops of muddy/wet looking oil/water muck. This air/oil separator must be catching most, if not all, of the moisture in the oil system because the oil dip stick never shows any signs of this excrement or condensation, nor is there any when I change the oil. On my pusher configuration, with the engine hanging out in the breeze, and me living in the north with mild summers, it does not need an oil cooler and therefore does not have one installed. I rarely if ever fly in winter so the oil temps always manage to get up to the 170F minimum (at return line to engine) specified by Jabiru, as long as I don't baby the engine during climb. I doubt seriously, that the oil temp would get up to minimum in this weather without closing down some of the air scoop, but I could be wrong, since the CHTs get up to normal in cold weather. 18F currently (Thursday 1PM) and still snowing... almost continuously since Tuesday around noon. Beautiful to behold, if you are dressed properly. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326895#326895 ________________________________________________________________________________
Date: Jan 13, 2011
Folks the fact is and unless he has already told them in writing, they would not be able to tell Kolb Firestar from a Kolb Sputnik to a Kolb M3X. all he has to do is show the G-Robots a piece of paper and say here is the certificate for this airplane and he be done. They do their inspection certify it and off he goes flying a Kolb and opening a whole new market. . Everybody is happy there in Hungaria. :-) I can imagine when the next kolb shows up and providing they wonder why both of these have the same model and look different, well by then it has been inspected and certified. G-Robots don't mess with stuff they already certify, the next guy may have to do some contortions but Zoltan will be certified in his now M3 under *its* Hungarian model designation in Hungary. Lol That's the way it works. Zolta say nothing to those G-Robots just give them the paper show them your airplane and keep quite. ________________________________________________________________________________
Date: Jan 13, 2011
the crankcase is probably doing ok... if the fuel pump is out in the open like the fuel pump on the 912,,, it will have a lot more cooling air around it,,, and even if the crankcase is 200 deg c the fuel pump may stay 160 or so.. remember there is very little movement of oil or gases inside the fuel pump.. it is sepperated from the case with a gasket. all which limit the heat saturation into the pump. boyd <<<<<<<<<<<<<<<<<< Seeing as how the moisture is a product of Chris's crankcase (and not his fuel delivery system), then this would possibly be a characteristic of his flying conditions, or flying habits, wouldn't it? Possibly due to the cold, northern climate, or the duration of his flights, or maybe even the wrong thermostat for his conditions, clearly something needs to be remedied. Without a doubt, Chris needs to make his flights a lot longer, or certainly long enough to achieve a dryer moisture level inside his engine's crankcase.....'cause what he has at the present is causing some risky landings!! Simple question, Chris; How long would you say your typical flight is? 15 minutes? 30?? Also, can you get a higher temp rated thermostat? This might help a lot. Mike Welch ________________________________________________________________________________
Date: Jan 13, 2011
Mike, Jabiru engines are entirely air-cooled therefore there is no thermostat to change. I always climb hard after take-off to get the temps up, even climb higher than I really want to go, if necessary for just this purpose. The air/oil separator also does a good job of getting rid of most of the moisture. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326930#326930 ________________________________________________________________________________
Date: Jan 13, 2011
> Jabiru engines are entirely air-cooled therefore there is no thermostat t o change. > -------- > Thom Riddle Thom & Chris=2C and all other Jabiru drivers=2C I forgot the air-cooled part.......doh!! In that case=2C the the an swer is simple!! You guys need to fly your planes more!! Evidently the old adage=3B TIME SPENT FLYING IS NOT DEDUCTED FROM ONE'S LIFE!! =2C has a corollary=3B TIME SPENT FLYING YOUR JABIRU ENGINE IS GOOD FOR IT=2C IN FACT=2C THE MORE THE BETTER! : ) Mike Welch ________________________________________________________________________________
Subject: Rocky Mountain Lodge Airstrip
Date: Jan 13, 2011
Hi Folks: July 1, 2000, I crashed on landing at the airstrip across the Alaska Highway from the Rocky Mountain Lodge, on Muncho Lake, British Columbia, just south of the Yukon Territory Border. The strip was rocky and rougher than I anticipated. I was about 25 lbs less than max gross weight for my MKIII, 1,200 lbs. Soon after touch down the left gear leg/axle socket failed, which triggered a chain reaction of damaging both main landing gear, left wing and aileron. I was 2,470 miles from home with an airplane that was not repairable in the field. Tonight, while looking for a video of a Zenith CH-701 with turboprop engine, I discovered this video of a Twin Otter that crashed in Northern British Columbia. As I watched the video I felt like I was familiar with the location of that strip. By the time the Twin Otter crashed on takeoff, I knew it was the same strip I had crashed on, landing to the south. The Twin Otter is taking off to the north. At the beginning of the clip you can see fuel drums on the ground on the other side of the airstrip. That is where I ended up after ground looping, barely missing a full fuel drum, over into the edge of the bush. The airstrip has been extensively upgraded since I was there. Where the cameraman was located is on the two track that crosses the airstrip. It used to be two deep ruts. Those ruts are what initially took out the left main gear. http://www.youtube.com/watch?v=e0DEb0M6wt4&feature=related I flew over the Lodge and airstrip the next year, 2001, on my way to a successful flight to Point Barrow, Alaska, my intended destination the year before. Nope, had no desire to land there then, but would have no problem landing there now. We upgraded the main gear, welding the axle socket to the gear leg before having them heat treated. Bother Jim wanted to make the gear this way initially, but I talked him out of it because it was easier to line up the main gear when building. My bad. ;-( john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: turbine 701
Date: Jan 13, 2011
John, These are several videos of the turbine 701 PCKing Turbine Zenith 701 Scott Ehni (Texas) scratch built a Zenith 701 with a 90 hp Garrett JFS 100-13A Turboshaft in the nose. He's going to put another one in a Zenith 601. Don't look for one of these on every homebuilt any time soon. This one burns 12 gph at cruise. http://www.zenithair.com/misc/turbine-power.html Video of the second flight. Listen to the engine sound as he lands. http://www.zenith.aero/video/second-flight-turbine-powered Tab down to Scott's build pictures. He does nice work. He runs a fabrication company, which explains the jigs and fixtures. He owns a lot of Clecos. http://www.zenith.aero/profile/ScottEhni ----- Original Message ----- From: John Hauck To: kolb-list(at)matronics.com Sent: Thursday, January 13, 2011 9:11 PM Subject: Kolb-List: Rocky Mountain Lodge Airstrip Hi Folks: July 1, 2000, I crashed on landing at the airstrip across the Alaska Highway from the Rocky Mountain Lodge, on Muncho Lake, British Columbia, just south of the Yukon Territory Border. The strip was rocky and rougher than I anticipated. I was about 25 lbs less than max gross weight for my MKIII, 1,200 lbs. Soon after touch down the left gear leg/axle socket failed, which triggered a chain reaction of damaging both main landing gear, left wing and aileron. I was 2,470 miles from home with an airplane that was not repairable in the field. Tonight, while looking for a video of a Zenith CH-701 with turboprop engine, I discovered this video of a Twin Otter that crashed in Northern British Columbia. As I watched the video I felt like I was familiar with the location of that strip. By the time the Twin Otter crashed on takeoff, I knew it was the same strip I had crashed on, landing to the south. The Twin Otter is taking off to the north. At the beginning of the clip you can see fuel drums on the ground on the other side of the airstrip. That is where I ended up after ground looping, barely missing a full fuel drum, over into the edge of the bush. The airstrip has been extensively upgraded since I was there. Where the cameraman was located is on the two track that crosses the airstrip. It used to be two deep ruts. Those ruts are what initially took out the left main gear. http://www.youtube.com/watch?v=e0DEb0M6wt4&feature=related I flew over the Lodge and airstrip the next year, 2001, on my way to a successful flight to Point Barrow, Alaska, my intended destination the year before. Nope, had no desire to land there then, but would have no problem landing there now. We upgraded the main gear, welding the axle socket to the gear leg before having them heat treated. Bother Jim wanted to make the gear this way initially, but I talked him out of it because it was easier to line up the main gear when building. My bad. ;-( john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 13, 2011
These are several videos of the turbine 701 PCKing I'm sorry. I wasn't looking for info on that airplane. Mentioned I was looking for a video from EAA when I discovered the Twin Otter crash at Muncho Lake, BC, and the airstrip I crashed on 10 years ago. Thanks any how. Don't think I could feed a 12 gph engine. ;-) john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 14, 2011
Hallo all, but mostly Ron, Pat, Mike and John! I think all you are in a big misunderstanding. Now I try to explain you, why I asked your help some days before. My KOLB have had a permit of my instructor four years befor, but it is too few for our authority. The hungarien aviation low doesn't know the "ultralight experimental" category. ((becouse, it is an old low - still from the socialist system)) Forthere, tehere is no separetly rul for this category.The experimental planes is managed by the same rule, like a big plane./forinstance Jumbo 747/ The rule is rule!Must keep, but we know it is wrong.The handmade producing is als=C3=B3 very complicate, like other office work. forinstanc an interesting affair.:Peter Bessenyei(he is a hungarian No. 1 pilot) who have made the RED BULL AIR RACE world chanpionship up - and he have won it more times.He obtained a hungarian produced CORVUS type, wonderfool race plane - and now listen!!! The plane is registered in the USA - becouse he could not register here, at home.( You will see him to fly-and I hope to win- this year on the RBAR.) The aviation authority is too difficult and the low is not "up-to-date.It is the estate of the socialist system too. Our contry is a very small one.Here must keep the rules. Maybe,it will be a new up-to-date aviation low in this year, and the problems "fly" away. I want to calm down everybody, I don't want to cheating, to steal,to falsify, to make a new type hungarian kolb, I don't need any new kolb part,and I haven' got a long dark-grey trenchcoat, and so on...................................! And Mike, mustn't close your door, nobady knoks there. I had got a complete plane set and weight and ballance report four years before, from an american kolbers and he didn't mention closed door, and now, there is no other kolb in Hungary. I passed 66 and I want ONLY FLY by my KOLB.And I am very grateful to Mr KOLB, that he gave so good plane for the people. And now I very ask everybody, don't send me a n y t h i n g N E V E R !!!!! So, I thank you very-very much for everything!!!!Your correspondences were very instructive. Finally, You can see the single hungarian kolb and me - without dark view. Excuse me my poor english!! Thank you. Hi for all. Zolt=C3=A1n Tibi >From Hungary KOLB TWINSTAR MARK II/R582/ -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Ron @ KFHU Sent: Thursday, January 13, 2011 9:22 PM Subject: Re: Kolb-List: Type certificate for KOLB MARK II TWINSTAR Folks the fact is and unless he has already told them in writing, they would not be able to tell Kolb Firestar from a Kolb Sputnik to a Kolb M3X. all he has to do is show the G-Robots a piece of paper and say here is the certificate for this airplane and he be done. They do their inspection certify it and off he goes flying a Kolb and opening a whole new market. . Everybody is happy there in Hungaria. :-) I can imagine when the next kolb shows up and providing they wonder why both of these have the same model and look different, well by then it has been inspected and certified. G-Robots don't mess with stuff they already certify, the next guy may have to do some contortions but Zoltan will be certified in his now M3 under *its* Hungarian model designation in Hungary. Lol That's the way it works. Zolta say nothing to those G-Robots just give them the paper show them your airplane and keep quite. ________________________________________________________________________________
Subject: Re: Kolb Firestar II for sale in Florida.
Date: Jan 14, 2011
Still for sale! New barnstormers ad: http://www.barnstormers.com/classified_504706_KOLB+FIRESTAR+II.html Price - 6800 airplane, 700 trailer. Price is negotiable! Need to sell! Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327040#327040 ________________________________________________________________________________
Date: Jan 14, 2011
In the uk we too do not have airworthiness certificate as we operate on a permit to fly. I have a mk 111 and could let him have a copy of that if it will do. Better for him or his own governing body to contact the Light aircraft association for details of the standards that we operate under maybe ? ________________________________________________________________________________
Date: Jan 14, 2011
So, I thank you very-very much for everything!!!!Your correspondences were very instructive. Finally, You can see the single hungarian kolb and me - without dark view. Excuse me my poor english!! Thank you. Hi for all. Zolt=C3=A1n Tibi >From Hungary KOLB TWINSTAR MARK II/R582/ I would never look at you and your plane with a dark view... and your English is far better than my Hungarian. boyd young mkiii ________________________________________________________________________________
Date: Jan 14, 2011
$2000 firm on the price they are prety nice floats i lost all my pics onthe =0Acomputer so no build pics but i could take some of them they are wraped in =0A=0Aphome and suran hanging in my hanger-- they are 12 ft long- 950 displacement w =0Aone rutter no rigging =0A=0A-Malcolm Brubaker =0AM ichigan Sport=0APilot Repair =0ALSRM-A, PPC, WS=0A(989)513-3022 =0A=0A=0A =0A=0A________________________________=0AFrom: "elleryweld(at)aol.com" <ellery weld(at)aol.com>=0ATo: kolb-list(at)matronics.com=0ASent: Wed, January 12, 2011 7 :04:50 PM=0ASubject: RE: Kolb-List: zenair floats plans.=0A=0A--> Kolb-List message posted by: "elleryweld(at)aol.com" =0A=0A=0A----- Original Message-----=0ADate: Wednesday, January 12, 2011 5:53:36 pm=0ATo: kolb-list(at)matronics.com=0AFrom: "Malcolm Brubaker" <brubakermal(at)yahoo.com> =0ASubject: Kolb-List: zenair floats plans.=0A=0Aseveral years aho i sold a set of plans for the zenair floats to a-Kolber =0A-can anyone rember b uying a set?-- i lost my copy and need another- mal=0A-Malcolm Brub aker =0AMichigan Sport=0APilot Repair =0ALSRM-A, PPC, WS=0A(989)513-3022 =0A=0Amalcolm i am the one that got the plans for the floats from you i wil l see about =0Agetting a copy made up i will let you know when i have that done i think i =0Aremember where i last had them=0A=0A=0A__________________ ______________=0AFrom: "elleryweld(at)aol.com" <elleryweld(at)aol.com>=0ATo: kolb -list(at)matronics.com=0ASent: Wed, January 12, 2011 7:43:44 AM=0ASubject: RE: leryweld(at)aol.com" =0A=0Awould it reduce drag on a cable if you was to fold a peice of vinal tape in half =0A=0Ato leave a 3/4 inch trailing edge?- let the testing begin =0A=0A-----Original Message----- =0ADate: Wednesday, January 12, 2011 2:36:20 am=0ATo: <kolb-list@matronics. com>=0AFrom: "Nick Cassara" <nickc(at)mtaonline.net>=0ASubject: Kolb-List: Air foil for cable...=0A=0AKolber's,=0A=0A=0A=0AA year or two ago someone post ed drag values for parts of a Kolb, if I=0Aremember right. I was amazed at ====0A=0A=0A ________________________________________________________________________________
Date: Jan 14, 2011
Hi Zoltan I can assure you that I and the rest here on this list only meant the best and were trying to be helpful. We use humor a lot but none of that humor in any way is intended to disparage you, Its just our way of not being too serious or dark. In any event we all know more about your situation and I wish you the best of luck. I for one was not aware from your initial message that you had your craft already registered or the whole story. Thus were the comments. ________________________________________________________________________________
Date: Jan 14, 2011
Hello all.. Here is an update on the fuel pump delema...last Saturday we eliminated the mechanical pump all together and flew it on just the electric pump at 2- lbs of pressure and flew it for 20 minutes and all was fine...ok..then it was suggested we cut some of the spring off and that would lower the pressure...we did and it did...ran it for about 6 minutes and all was good...I talked to Jim from Jabiru in CA ,told him what we did and he said if it worked to leave it alone,try it,if it works ,fly it....ok...I tested it and it was fine...then I flew it...it was good for just over 6 minutes,then it started flooding out again...it did keep running allbeit not very good and I made a safy landing...when I got to the hangar I placed the pressure guage back on and it went right to 7+ lbs...why?? Here is what I think happened...Saturday we cut off the spring ,started it up and the pressure went to 2-3 lbs...It only ran for a few minutes... Today,after Jim said if it works ,check it and fly it.... I checked it,ran it for 6 minutes and it seemed ok...it got to about 3.2 # and seemed to be steady ... then I flew it for just over 6 minutes and then it started flooding again... What I think is happening is when we cut it off it just took longer for the fuel to build up pressure and once everything was full of gas,the spring was still working and although it wasn't going up as far, when it did push up,it was still pushing at 7# psi...we only shortened the spring...not relieve any tension......do you see what I mean??? does it make any sense??? I hope so...cause I'm going nutts !!!! LOL Frank is sending me his NEW silver spring which is supposed to be 2-3 lbs...if that does not work I will put a regulator on and set it to 2-3 lbs.. Again..Thank you Frank ! chris ambrose M3X/Jabiru A-2200 172.0hrs N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327077#327077 ________________________________________________________________________________
Date: Jan 15, 2011
ARE YOUR TANKS VENTING CORRECTLY? ________________________________________________________________________________
Date: Jan 15, 2011
Is there supposed to be a fuel return line or something like that, that may be plugged up? I am trying to remember from the Mikuni iirc on the Cuyana I flew last year. But it had a pulse pump and very little pressure I guess. Why is yours flooding is not making any sense. It may not be flooding at all. and in fact it may be too lean. I would check and make sure there are no cracks in the fuel lines. I had to put down the Pterodactyl on my maiden flight next to a MacDonald restaurant because of a crack in the fuel primer pump nipple. It displayed the symptoms of too rich, poor throttle response and chocking at full throttle, and it progressively got worse till I could not maintain altitude. Check all of your lines for cracks anything from the fuel tank to the Carb. ________________________________________________________________________________
Date: Jan 15, 2011
I hope so...cause I'm going nutts !!!! LOL chris ambrose Chris A/Folks: If it was mine, I would have already replaced the fuel pump with a new serviceable pump. Not worth the chance of getting hurt and/or ruining your airplane being a test pilot. How much does a new pump cost? Of course, as I age I am not nearly as bold as I used to be. ;-) john h mkIII hauck's holler Titus, Alabama ________________________________________________________________________________
Date: Jan 15, 2011
My Grosse weight is 1250 I would probably sink them Ellery Batchelder Jr. -----Original Message----- From: Malcolm Brubaker <brubakermal(at)yahoo.com> Sent: Fri, Jan 14, 2011 7:46 pm Subject: Re: Kolb-List: zenair floats plans. $2000 firm on the price they are prety nice floats i lost all my pics onth e computer so no build pics but i could take some of them they are wraped in phome and suran hanging in my hanger they are 12 ft long 950 displaceme nt w one rutter no rigging Malcolm Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS (989)513-3022 From: "elleryweld(at)aol.com" <elleryweld(at)aol.com> Sent: Wed, January 12, 2011 7:04:50 PM Subject: RE: Kolb-List: zenair floats plans. -----Original Message----- Date: Wednesday, January 12, 2011 5:53:36 pm From: "Malcolm Brubaker" <brubakermal(at)yahoo.com> Subject: Kolb-List: zenair floats plans. several years aho i sold a set of plans for the zenair floats to a Kolber can anyone rember buying a set? i lost my copy and need another mal Malcolm Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS (989)513-3022 malcolm i am the one that got the plans for the floats from you i will see about getting a copy made up i will let you know when i have that done i think i remember where i last had them ________________________________ From: "elleryweld(at)aol.com" <elleryweld(at)aol.com> Sent: Wed, January 12, 2011 7:43:44 AM Subject: RE: Kolb-List: Air foil for cable... would it reduce drag on a cable if you was to fold a peice of vinal tape in half to leave a 3/4 inch trailing edge? let the testing begin -----Original Message----- Date: Wednesday, January 12, 2011 2:36:20 am From: "Nick Cassara" <nickc(at)mtaonline.net> Subject: Kolb-List: Air foil for cable... Kolber's, A year or two ago someone posted drag values for parts of a Kolb, if I remember right. I was amazed at the drag values for the cables on the p; -Matt Drall=========== ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jan 15, 2011
> >Hello all.. ...........................> > >What I think is happening is when we cut it off it just took longer for the fuel to build up pressure and once everything was full of gas,the spring was still working and although it wasn't going up as far, when it did push up,it was still pushing at 7# psi...we only shortened the spring...not relieve any tension......do you see what I mean??? does it make any sense??? I hope so...cause I'm going nutts !!!! LOL > Chris, The force (F) exerted by the fuel pump spring is equal to the change in spring length (L) times the spring constant (K). Or F = L x K. L is predetermined by the cam lobe in the engine. The spring constant is determined by type of material and diameter of the spring wire. So you are correct when you do not see any change due to cutting the spring. You did not change the pump stroke or the wire spring constant. The only way to reduce pump stroke (L) is to add gasket material to the point that the cam follower does not remain in contact with the cam. The only other option is to replace the spring with one that is the same physical size but wound from smaller diameter wire thereby reducing the spring constant (K). If your new silver spring does not do the job, and pressure remains too high, purchase a new spring that is close to the same length and outside diameter, but with smaller diameter wire. Springs can be purchased over the web and in some cases from your local hardware store. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jan 15, 2011
Hi , never having seen your fuel pump or the spring that controls the presu re , =0Ai'd like to hazzard=0Aa guess. Hopefully if I' wrong some of the mo re knoweledgabe folks on- the the =0Alist can correct=0Ame before any dam age is done.-I have always thought that if a spring was made =0Ashorter ( cut ) that=0Awould make-the spring-stiffer ---easy to check, just cut a n old spring and see =0Awhat happens---.=0ALooks to me like that would rais e the fuel presure, could be you need a longer =0A(stretched ?)sprnig=0Aor one with thiner wire.=0AFrank Goodnight-=0A=0A=0A=0A=0A=0A=0A____________ ____________________=0AFrom: Jack B. Hart <jbhart(at)onlyinternet.net>=0ATo: k olb-list(at)matronics.com=0ASent: Sat, January 15, 2011 9:08:06 AM=0ASubject: Re: Kolb-List: Re: Kolb/Jabiru carb overflow=0A=0A--> Kolb-List message pos ted by: "Jack B. Hart" =0A=0AAt 10:25 PM 1/14/11 - .com>=0A>=0A>Hello all..=0A...........................>=0A> =0A>What I thin k is happening is when we cut it off it just took longer for the =0Afuel to build up pressure and once everything was full of gas,the spring was =0Ast ill working and although it wasn't going up as far, when it did push up,it =0Awas still pushing at 7# psi...we only shortened the spring...not relieve any =0Atension......do you see what I mean???- does it make any sense??? - I hope =0Aso...cause I'm going nutts !!!!- LOL=0A>=0A=0AChris,=0A=0AT he force (F) exerted by the fuel pump spring is equal to the change in =0As pring length (L) times the spring constant (K).- Or F = L x K.- L is =0Apredetermined by the cam lobe in the engine.- The spring constant is =0Adetermined by type of material and diameter of the spring wire.=0A=0ASo you are correct when you do not see any change due to cutting the spring. =0AYou did not change the pump stroke or the wire spring constant.- The o nly =0Away to reduce pump stroke (L) is to add gasket material to the point that =0Athe cam follower does not remain in contact with the cam.- The o nly other =0Aoption is to replace the spring with one that is the same phys ical size but =0Awound from smaller diameter wire thereby reducing the spri ng constant (K).=0A=0AIf your new silver spring does not do the job, and pr essure remains too =0Ahigh, purchase a new spring that is close to the same length and outside =0Adiameter, but with smaller diameter wire.- Springs can be purchased over the =0Aweb and in some cases from your local hardwar - - - - - - - - - - - - - - - -Matt Dralle, L ======= ________________________________________________________________________________
Date: Jan 15, 2011
ces308 wrote: > > Frank is sending me his NEW silver spring which is supposed to be 2-3 lbs...if that does not work I will put a regulator on and set it to 2-3 lbs.. > Again..Thank you Frank ! > > chris ambrose > M3X/Jabiru A-2200 172.0hrs > N327CS Hello Chris, Be careful that the fuel pressure regulator you use does not restrict flow. I put one of those round silver types with a dial on my airplane and at extended high power settings it would not allow enough fuel to flow. It caused an engine out on my first flight in my MKIII. Regards Jason Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327117#327117 ________________________________________________________________________________
Date: Jan 15, 2011
As one who has had experience with those "round silver" regulators....... They are not all created equal. The one from NAPA will work. Others can be junk even though they appear similar. I recommend simply using the lowest pressure output facet from AC spruce with no regulator. Why? because if the diaphragm in the regulator fails, it fails closed. BB MKIII, suzuki On 15, Jan 2011, at 1:11 PM, Jason Omelchuck wrote: > > > ces308 wrote: >> >> Frank is sending me his NEW silver spring which is supposed to be 2-3 lbs...if that does not work I will put a regulator on and set it to 2-3 lbs.. >> Again..Thank you Frank ! >> >> chris ambrose >> M3X/Jabiru A-2200 172.0hrs >> N327CS > > > Hello Chris, > > Be careful that the fuel pressure regulator you use does not restrict flow. I put one of those round silver types with a dial on my airplane and at extended high power settings it would not allow enough fuel to flow. It caused an engine out on my first flight in my MKIII. > > Regards > Jason > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327117#327117 > > > > > > > > > > ________________________________________________________________________________
Subject: Pitot static port location
Date: Jan 15, 2011
Guys, I'm VERY close to being able to permanently install my front instrument panel/console. I have already installed the overhead panel. Next will be the task of hooking up the various sending units, loose wires, etc., the stuff you can't do until the panel gets installed into the plane. As far as all the wires between the two panels is concerned, this is simply a matter of plugging together two DB15 plugs. As many of you may recall, I recently installed my airspeed indicator pitot (under the front edge of the nosecone). Yesterday, I made the static pitot fitting (for the unpressurized static source) Here's my question; Do any of you have a recommended place on the nosecone for the static pitot fitting? Or is it okay to locate it ANYWHERE on the side of the nosecone? The inlet hole for the static air is a drilled hole about .025 dia. (It is TINY!!!!!, just slightly larger around than a pin) Here is a second question! To make sure that the exterior fitting doesn't get either higher or lower pressure than static, would it be a good idea to drill an EXTRA hole into one of the interior static line "T's? (the static line supplies air to 3 instruments) By drilling an extra hole into an interior T, I would be allowing for BOTH static air inside and outside of the cabin. I know you are not supposed to rely ONLY on inside static air, because it is possible that the inside cabin MAY have slightly higher or lower static air, due to cabin design. Anyone have some training on the pitot system, and at this point, the static part of it? Thanks for any advice, Mike Welch MkIII ________________________________________________________________________________
Subject: Re: Pitot static port location
Date: Jan 15, 2011
Anyone have some training on the pitot system, and at this point, the static part of it? Thanks for any advice, Mike Welch Mike W/Gang: I have no training on the the pitot/static system, only practical experience that works for me. If I was going to use a system similar to yours, I would use a static port on each side of the nose cone, combine these two ports into a T fitting, then into your instruments. By doing this, you eliminate the pressurization or vacuum of a single port when the aircraft is not quite in yaw trim, one side or the other. Once flying, the static ports can be calibrated by taking a tiny bit of material off the aft side of each static port, if they are pressurizing, or off the forward side of the hole if it is creating a vacuum. The reason I settled on this system for my Firestar is because I tried it single first, then found it to be a more workable solution with two ports. BTW: I used 1/16" ID ports. john h mkIII hauck's holler Titus, Alabama ________________________________________________________________________________
Date: Jan 15, 2011
> If I was going to use a system similar to yours=2C I would use a static p ort > on each side of the nose cone=2C combine these two ports into a T fitting =2C > then into your instruments. By doing this=2C you eliminate the pressuriza tion > or vacuum of a single port when the aircraft is not quite in yaw trim=2C one > side or the other. > > Once flying=2C the static ports can be calibrated by taking a tiny bit of > material off the aft side of each static port=2C if they are pressurizing =2C or > off the forward side of the hole if it is creating a vacuum. > > The reason I settled on this system for my Firestar is because I tried it > single first=2C then found it to be a more workable solution with two por ts. > > BTW: I used 1/16" ID ports. > > john h > mkIII > hauck's holler > Titus=2C Alabama John=2C I clearly see the logic in the "each side" of the fuselage idea. It seem s as though if one side were being slightly pressurized=2C for the most part=2C the opposite side would equally 'depressurized'. I need to get another 'T'. What about the interior hole through one of the 'T's'=2C which would incl ude the inside of the cabin into the static system? A small hole into one of the ' T's' (in the static source) would then be giving you three locations of "suppose dly" unpressurized air=3B left side fuselage=2C right side fuselage=2C interior fuselage. Is this unnecessary=2C would it help any? Opinions??? I did a quick check of A/C Spruce=2C and this is vitually identical to wh at I made=2C except that my circular flat part is MUCH thinner than theirs=3B http://www.aircraftspruce.com/catalog/inpages/alumstaticports.php Also=2C from the looks of it in the photo=2C my drilled hole appears to b e the exact same size as in the photo. I'm trying to keep the inlet hole as small as p ossible=2C to reduce any "ram air" affect. I'll do some more research on the inlet hole size. Thanks for the pointers.....especially the 'each side of the fuselage' pa rt. Mike Welch ________________________________________________________________________________
Date: Jan 15, 2011
I recommend simply using the lowest pressure output facet from AC spruce with no regulator. Why? because if the diaphragm in the regulator fails, it fails closed. BB MKIII, suzuki >>>>>>>>>>>>>>>>> I don't have any experience with this regulator. But all the regulators I've been familiar with, when they fail, they fail open. From my experience all regulators are all open until the outlet pressure reaches the set point, then the outlet pressure presses against the diaphragm working against the spring pressure to close them. as the gas is burned off,, the pressure on the diafram drops and the valve opens to let more gas through till the set point is reached and it is again off.... a continual small use through the carbs (the engine is running) will set up a small flow through the regulator to keep up with the rate of burn. if the top of the diafram is vented,, and the diafram leaks the device will leak. i have rarely seen a regulator stick shutt. it is normaly caused by something jaming or sticking in the valve. Boyd young mkiii using the lowest setting faucett pump in serries with the engine driven pump on a 912 ________________________________________________________________________________
Date: Jan 15, 2011
Here's my question; Do any of you have a recommended place on the nosecone for the static pitot fitting? Or is it okay to locate it ANYWHERE on the side of the nosecone? The inlet hole for the static air is a drilled hole about .025 dia. (It is TINY!!!!!, just slightly larger around than a pin) >>>>>>>>>>>>>> sorry about the drawing... this is what i did. boyd young mkiii ________________________________________________________________________________
Date: Jan 15, 2011
Hi Boyd=2C Thanks for the drawing=2C your drawing is plenty good enough for us to get the idea of what you have. But=2C I would prefer to use those flush-mount type of static ports like I previously showed the link of=3B the ones that look like this=3B http://www.aircraftspruce.com/catalog/inpages/alumstaticports.php From what I've been researching=2C I think John has me headed in the right direction=2C namely a port on each side of the fuselage. I'm afraid that if I had a port on the underside of the Xtra nosecone it would definitely be getting slightly pressurized air with the flush mounted type ports. I still not sure about the interior vent hole through one of the "T's"=2C though. >From what I've been reading=2C it may not be all that necessary=2C especially if a guy went with two side ports! I did find that a Cessna 150 uses a .040" static hole (the guy said 1mm =2C which is .040") Cessna also has only one outside port=2C too. Some of them have an inside port=2C which I guess you can open by way of a knob or something=2C if you thought the outside was plugged=2C iced over=2C or w hatever. Thanks for the input=2C guys. I think I have enough good information to go ahead and finish the static line installation. Mike Welch MkIII ________________________________________________________________________________
Date: Jan 15, 2011
at grose you would.mine atre best suted for a singleseat or firestar-- --- -i =0Ahave a set of aeroset floats for $5,000=0A-Malcolm Brub aker =0AMichigan Sport=0APilot Repair =0ALSRM-A, PPC, WS=0A(989)513-3022 =0A=0A=0A=0A=0A________________________________=0AFrom: Ellery Batchelder J r =0ATo: kolb-list(at)matronics.com=0ASent: Sat, January 1 5, 2011 9:56:18 AM=0ASubject: Re: Kolb-List: zenair floats plans.=0A=0AMy G rosse weight is 1250 I would probably sink them =0A=0A=0AEllery Batchelder Jr.=0A=0A=0A-----Original Message-----=0AFrom: Malcolm Brubaker <brubakerma l(at)yahoo.com>=0ATo: kolb-list(at)matronics.com=0ASent: Fri, Jan 14, 2011 7:46 p m=0ASubject: Re: Kolb-List: zenair floats plans.=0A=0A=0A$2000 firm on the price they are prety nice floats i lost all my pics onthe =0Acomputer so no build pics but i could take some of them they are wraped in =0A=0Aphome an d suran hanging in my hanger-- they are 12 ft long- 950 displacement w =0Aone rutter no rigging =0A=0A-Malcolm Brubaker =0AMichigan Sport=0APi lot Repair =0ALSRM-A, PPC, WS=0A(989)513-3022 =0A=0A=0A=0A=0A______________ __________________=0AFrom: "elleryweld(at)aol.com" <elleryweld(at)aol.com>=0ATo: kolb-list(at)matronics.com=0ASent: Wed, January 12, 2011 7:04:50 PM=0ASubject: "elleryweld(at)aol.com" =0A=0A=0A-----Original Message---- -=0ADate: Wednesday, January 12, 2011 5:53:36 pm=0ATo: kolb-list@matronics. com=0AFrom: "Malcolm Brubaker" <brubakermal(at)yahoo.com>=0ASubject: Kolb-List : zenair floats plans.=0A=0Aseveral years aho i sold a set of plans for the zenair floats to a-Kolber =0A-can anyone rember buying a set?-- i lost my copy and need another- mal=0A-Malcolm Brubaker =0AMichigan Spor t=0APilot Repair =0ALSRM-A, PPC, WS=0A(989)513-3022 =0A=0Amalcolm i am the one that got the plans for the floats from you i will see about =0Agetting a copy made up i will let you know when i have that done i think i =0Aremem ber where i last had them=0A=0A=0A________________________________=0AFrom: "elleryweld(at)aol.com" =0ATo: kolb-list(at)matronics.com=0AS ent: Wed, January 12, 2011 7:43:44 AM=0ASubject: RE: Kolb-List: Air foil fo ryweld(at)aol.com>=0A=0Awould it reduce drag on a cable if you was to fold a p eice of vinal tape in half =0A=0Ato leave a 3/4 inch trailing edge?- let the testing begin =0A=0A-----Original Message-----=0ADate: Wednesday, Janua ry 12, 2011 2:36:20 am=0ATo: <kolb-list(at)matronics.com>=0AFrom: "Nick Cassar a" =0ASubject: Kolb-List: Air foil for cable...=0A=0AK olber's,=0A=0A=0A=0AA year or two ago someone posted drag values for parts of a Kolb, if I=0Aremember right. I was amazed at the drag values for the c ables on the p; - - - - =0A- - - - - - -Matt Drall= ============0A=0A=0A=0A=0A=0A ======= ==== =0Arget=_blank>http://www.matronics.com/Navigator?Kolb-List ============0A tp://forums.matronics.com ==== ======= =0A_blank>http://www.matronics.com/contribution== ======================= =0A =0A=0A=0A ________________________________________________________________________________
Date: Jan 15, 2011
Mike, I'd recommend you do either static ports or just vent them into the cockpit, not both, for the simple reason I think you'll play heck trying to tune the system if you have both. Yes, some Cessnas have an alternate static source valve with a knob on the panel to actuate it, for those that don't, student pilots are taught that should ice fowl the static ports the solution is to break the glass face of the VSI and vent the system that way. Rick Girard On Sat, Jan 15, 2011 at 3:41 PM, Mike Welch wrote: > Hi Boyd, > > Thanks for the drawing, your drawing is plenty good enough > for us to get the idea of what you have. > > But, I would prefer to use those flush-mount type of static ports like > I previously showed the link of; the ones that look like this; > > http://www.aircraftspruce.com/catalog/inpages/alumstaticports.php > > From what I've been researching, I think John has me headed in > the right direction, namely a port on each side of the fuselage. > I'm afraid that if I had a port on the underside of the Xtra nosecone > it would definitely be getting slightly pressurized air with the flush > mounted type ports. > > I still not sure about the interior vent hole through one of the "T's", > though. > >From what I've been reading, it may not be all that necessary, > especially if a guy went with two side ports! > > I did find that a Cessna 150 uses a .040" static hole (the guy said 1mm, > which is .040") Cessna also has only one outside port, too. Some > of them have an inside port, which I guess you can open by way of a knob > or something, if you thought the outside was plugged, iced over, or > whatever. > > Thanks for the input, guys. I think I have enough good information to go > ahead and finish the static line installation. > > Mike Welch > MkIII > > > * > > * > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Subject: Re: Kolb/Jabiru carb overflow
Date: Jan 15, 2011
Chris, Any possibility of high crankcase pressure pulsing the fuel pump diaphram? Is the vent system open to atmospheric pressure? I just think the spring failing is a stretch. Thanks G.Aman -----Original Message----- From: ces308 <ces308(at)ldaco.com> Sent: Thu, Jan 13, 2011 10:53 am Subject: Kolb-List: Re: Kolb/Jabiru carb overflow Mike and John,hello, The fuel pump is on the side of the engine,right in the slipstream and hang s upside down and tilted...it looks like oil for lubrication comes from just enough clearance around the push-rod to drip on the pump actuator and then a small ,about an 1/8 " hole at the bottom for an oil return to the crank case...there is a cavity above that where the return spring is that has no air going through it or oil getting to it,so with the slipstream of cold air go ing over the hot/warm pump case it has to be making some moisture there....I do n't think it's a lot ,but enough to collect on the spring and the bottom of the diaphragm.I have never seen moisture in the oil fill tube or the dipstick.. .Oil temps in the winter...at 16* is 160-185...I have never found any water in m y fuel system... I'll get a picture of where the pump goes on so you can see what I'm talkin g about... chris ambrose M3X/Jabiru A-2200 172. hrs TT N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326879#326879 ________________________________________________________________________________
Date: Jan 15, 2011
>Mike=2C I'd recommend you do either static ports or just vent them into th e cockpit=2C not both=2C for the simple reason I think you'll play heck >tr ying to tune the system if you have both. >>Rick Girard Hi Rick=2C I'd say at this point I agree with you and John=2C I ought to go with jus t the two side ports. I'm just thinking out-loud here........ At the risk of over-thinking this I was just wondering=2C since the main objective of the 'static' source is simply that=2C "static" =2C what we wa nt is absolutely uncharged=2C unpressurized air. I definitely see the logic in J ohn's suggestion of the two side ports=2C but just the fact that the air is rushi ng past a nosecone has GOT to have some kind of slight pressurization=2C whether it be positive or negative=2C however slight it may be. When I try to wrap my mind around the objective of getting an "ambient" static air source=2C I can't picture how having both (two side port fitting s and an inside hole in a fitting 'T') would do anything but create an even bette r balance to having zero pressure. I'm not arguing with you=2C I just don't see it intuitively. You might b e absolutely correct. It was my intention all along to try out the whole airspeed indicator(s) system in the car. Since my entire panel is somewhat portable at this point=2C an d I do have the entire pitot system 100% built=2C hoses=2C tubes=2C fittings and all=2C I could set the entire arrangement on the seat of my truck=2C and go buzzing down the highw ay. I could try a couple of pitot designs and try to get a feel for what might work best in my situation. I think the thing I'm trying to get a good handle on is if the airspeed i ndicator is going to be 'reasonably' accurate on my first time out. I don't expect it to be gnat's ass perfect=2C but then I'd rather it wasn't off by 25 mph=2C either . Maybe taking it for a spin down the highway will give me a little indication of it's app roximate accuracy. (BTW=2C I do realize that when flight testing the plane=2C the important point is to know what the airspeed indicator says for certain flight functions (like stall speed=2C for instance)=2C and learn those readings=2C regardless of how acc urate they are. In other words=2C if the ASI says stall happens at 37 mph=2C then nev er try to fly less than 37 mph.....period!!! Hey=2C thanks for the help=2C guys. I'm going to try to get some 'down t he highway' readings. I'll let you know what I come up with. I also include various s tatic pitot source designs. More later....... Mike Welch ________________________________________________________________________________
Date: Jan 15, 2011
When I try to wrap my mind around the objective of getting an "ambient" static air source, I can't picture how having both (two side port fittings and an inside hole in a fitting 'T') would do anything but create an even better balance to having zero pressure. Mike Welch Mike W/Gang: That is why I said you can fine tune the static ports after you fly the airplane by taking a little material off the fore or aft side of the port, depending on whether the ASI is reading high or low, pressure or vacuum. There are also other ways to fine tune the static system. Use your imagination. You are looking for one static source that will read the same air pressure as the pitot tube is flying in. Testing your ASI in your truck will do nothing for the installation in your airplane. If you take a static source inside the cockpit of a MKIII or FS, it will be low pressure. It is the nature of the nose pod flying through the air. What I shared with you is a proven system that worked well for me. john h mkIII hauck's holler Titus, Alabama ________________________________________________________________________________
Date: Jan 15, 2011
Nice drawing of a vulture with whiskers . . . just kidding . . . On Sat, Jan 15, 2011 at 1:05 PM, b young wrote: > > Here's my question; Do any of you have a recommended place on the > nosecone for the static pitot fitting? Or is it okay to locate it ANYWHERE > on the side of the nosecone? The inlet hole for the static air is a drilled > hole about .025 dia. (It is TINY!!!!!, just slightly larger around than a > pin) > > > >>>>>>>>>>>>>> > > sorry about the drawing... this is what i did. > boyd young > mkiii > > ________________________________________________________________________________
Date: Jan 15, 2011
Gary, The vent is good...today while waiting for the spring from Frank, I went to the hardware store and bought a spring of the same diameter,but had less tension than the gold spring Pete sent me and it seems to work fine...I will run it wide open tomorrow,but it looks good so far ! 1.5 lbs at idle and 2 at 1400 rpm's. I wish I would have taken a fuel pressure reading at my condition inspection...I also have a fuel pressure sensor coming from GR Tech to keep checking the pressure...Now I will have something to go by... chris ambrose M3X/Jab N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327164#327164 ________________________________________________________________________________
Date: Jan 15, 2011
Jab guys... Also did any of you know about this?? Got this from Lynn Matteson... With all this talk about the float needle, let's remember that there are black-tipped needles (the rubber end is black) and needles with silver, gold, and *black* springs, (or at least a silver, gold, or black colored spring end, which is a code for the strength of the spring within the needle) and make sure you know which one you're referring to. Lynn Matteson Kitfox IV Speedster, taildragger Jabiru 2200, #2062 Sensenich 62"x 55.5 Wood (winter) until the Prince prop arrives Electroair direct-fire ignition system Rotec TBI-40 injection Status: flying...1078+ hrs (since 3-27-2006) As Rosann Rosanna Danna always said," It just goes to show you...It's always something ! " lol And you thought this was a simple engine ! lol chris ambrose Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327169#327169 ________________________________________________________________________________
Date: Jan 15, 2011
John=2C Okay!! I got the message! I'll proceed as you suggested. Two side ports=2C 1/16" fitting holes=2C adjust as needed. Got it. Thanks=2C Mike W ________________________________________________________________________________
Date: Jan 16, 2011
Mike, Strongly endorse Hauck's suggestions for a static system of two side ports connected by a T. It has been a well proven industry standard for many years. To expand slightly: Put the ports as far aft on the nose cone as reasonable. You want the air at the port to be going parallel to the surface, not accelerating around a curve. << Once flying, the static ports can be calibrated by taking a tiny bit of material off the aft side of each static port, if they are pressurizing, or off the forward side of the hole if it is creating a vacuum. >> There is a simpler way of determining which way to trim the ports than airspeed error. Go to a long, level runway and make a takeoff keeping the aircraft planted on the runway as long as possible. Just before liftoff note any change in *altitude*. If the altimeter goes up you have a vacuum, if it goes down you have static pressurization. This maneuver does take some practice and should be repeated several times to be sure of correct indication. Instead of removing material you can add wedges on the other side: front side if static is high, back side if static is low. You can also buy static ports with a wedge built in. Much more professional looking than balsa wedges glued on. These you rotate to get most accurate readings. Tom Kuffel ________________________________________________________________________________
Subject: Re: zenair floats plans.
Date: Jan 16, 2011
straight floats ? if I had the money I would be interested might be in th e spring Ellery Batchelder Jr. -----Original Message----- From: Malcolm Brubaker <brubakermal(at)yahoo.com> Sent: Sat, Jan 15, 2011 6:33 pm Subject: Re: Kolb-List: zenair floats plans. at grose you would.mine atre best suted for a singleseat or firestar i have a set of aeroset floats for $5,000 Malcolm Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS (989)513-3022 From: Ellery Batchelder Jr <elleryweld(at)aol.com> Sent: Sat, January 15, 2011 9:56:18 AM Subject: Re: Kolb-List: zenair floats plans. My Grosse weight is 1250 I would probably sink them Ellery Batchelder Jr. -----Original Message----- From: Malcolm Brubaker <brubakermal(at)yahoo.com> Sent: Fri, Jan 14, 2011 7:46 pm Subject: Re: Kolb-List: zenair floats plans. $2000 firm on the price they are prety nice floats i lost all my pics onth e computer so no build pics but i could take some of them they are wraped in phome and suran hanging in my hanger they are 12 ft long 950 displaceme nt w one rutter no rigging Malcolm Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS (989)513-3022 From: "elleryweld(at)aol.com" <elleryweld(at)aol.com> Sent: Wed, January 12, 2011 7:04:50 PM Subject: RE: Kolb-List: zenair floats plans. -----Original Message----- Date: Wednesday, January 12, 2011 5:53:36 pm From: "Malcolm Brubaker" <brubakermal(at)yahoo.com> Subject: Kolb-List: zenair floats plans. several years aho i sold a set of plans for the zenair floats to a Kolber can anyone rember buying a set? i lost my copy and need another mal Malcolm Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS (989)513-3022 malcolm i am the one that got the plans for the floats from you i will see about getting a copy made up i will let you know when i have that done i think i remember where i last had them ________________________________ From: "elleryweld(at)aol.com" <elleryweld(at)aol.com> Sent: Wed, January 12, 2011 7:43:44 AM Subject: RE: Kolb-List: Air foil for cable... would it reduce drag on a cable if you was to fold a peice of vinal tape in half to leave a 3/4 inch trailing edge? let the testing begin -----Original Message----- Date: Wednesday, January 12, 2011 2:36:20 am From: "Nick Cassara" <nickc(at)mtaonline.net> Subject: Kolb-List: Air foil for cable... Kolber's, A year or two ago someone posted drag values for parts of a Kolb, if I remember right. I was amazed at the drag values for the cables on the p; -Matt Drall=========== ======================== =========== get=_blank>http://www.matronics.com/Navigator?Kolb-List===== ======================== ====== p://forums.matronics.com ======================== blank>http://www.matronics.com/contribution========== ======================== = ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jan 16, 2011
Chris, The spring internal to the float valve in the Bing Carb that Lynn is talking about has nothing to do with the fuel pressure being too high. The spring internal to the float valve performs a single function, to dampen/absorb the vibrations that occur in the float system on a running engine. So, different internal float valve springs perform that function slightly differently but have no effect on the fuel pressure nor the pressure between the float valve tip and the seat/orifice, nor the ability to resist the pressure applied by the fuel pump while the engine is running. Bottom line is that this internal float valve spring can be ignored in thinking about your current high pressure situation. Having a float valve with a tip in good condition is important and you've already tended to that. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327181#327181 ________________________________________________________________________________
Date: Jan 16, 2011
Boyd's drawing looks like what I am using. One is the pitot, the other is static port, both are out away from the airframe in clean air, seems to make life simpler. Worked right the first time, needed no tuning. Your results may vary... Details here: http://www.bcchapel.org/pages/0003/pg7.htm Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327182#327182 ________________________________________________________________________________
Date: Jan 16, 2011
> Boyd's drawing looks like what I am using. > Richard Pike > MKIII N420P (420ldPoops) Bro. Richard=2C Although I do agree Boyd's and your suggestion of the static inlet works well out on an extended tube=2C I would prefer to go with the type of fitting that mounts on the surface of the fuselage. But=2C thanks for your input!! At this point=2C I concede I know when I'm given good advice. John H was generous enough to offer what says worked well for him. Although I did agree=2C I was curious if a slight (unnecessary) modification would b e better. He=2C Rick G=2C and Ted K didn't think so!! (probably others=2C t oo) That's good enough for me!! I appreciate everyone's input=2C and value the advice I have been given. I think I'll go with the two=2C side fuselage=2C surface mount ports=2C no inside cabin venting=2C and 1/16" vent holes. Thanks=2C guys. Mike Welch ________________________________________________________________________________
Date: Jan 16, 2011
Mike, I'm coming into this discussion late, sounds like you already have a plan, but I'll add my two cents: Putting ports on both sides helps to cancel out any variation as the aircraft yaws. On the bottom wouldn't be good as it'd change as AOA changes. Inside the cockpit is a bad place because the air inside is nearly always _not_ at static pressure. I built a concentric pitot/static tube, with the inner tube for the pitot and the outer one (sealed at front and back) with four holes spaced around the center for static air. Mounted on the nose such a system will give very good undisturbed static air. -Dana -- Congress shall make no law....What part of NO didn't you understand? ________________________________________________________________________________
Date: Jan 17, 2011
I have had good success in changing the pressure seen by the static ports using a dab of RTV either fore or aft of the port. My current Slingshot setup has the dural pitot/static tubes mounted below the nose cone with an extender for the pitot mounted flexibly and going out about six inches forward of the nose. My static tube has a Tee in side the cockpit so it is sensing both the pressure outside the at the static port and under the panel. With this setup, it reads TAS on the ASI at about 2,000' - 2,500' density altitude. Speaking of density altitude, I calculated it this morning and here at KBUF, the DA at 7 AM was -3,675'. Coldest yet this winter here at 1 degree.... but clear skies for a change and low winds. About -4F at my house. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327273#327273 ________________________________________________________________________________
Date: Jan 17, 2011
> Speaking of density altitude=2C I calculated it this morning and here at KBUF=2C the DA at 7 AM was -3=2C675'. > > -------- > Thom Riddle > Buffalo=2C NY (9G0) > Kolb Slingshot SS-021 > Jabiru 2200A #1574 > Tennessee Prop 64x32 Hi Thom=2C Thanks for the pitot info. -3=2C675' density altitude?? I think even Capt Nemo would have trouble f lying at that level!! (think about it=2C it'll come to you) BTW=2C thanks for the pitot comments=2C everyone=2C but I think I'll pro ceed with what I mentioned previously (2 side ports=2C etc=2C etc.) If that design n eeds some adjustment=2C then I'll work on it later. Cheers!! Mike Welch ________________________________________________________________________________
Subject: Flying the Tallapoosa
Date: Jan 17, 2011
Hi Folks: I sent some posts to the Kolb List earlier, each with a photo attached. That was three hours ago. Still no posts. If I resend, the old posts will arrive. ***************************************************** Hi Folks: Got to fly a little yesterday, in addition to washing Miss P'fer for the first time in 9 months. She is 50 lbs lighter now. Was a beautiful Sunday afternoon, just a little wind out of the NW. I flew the Tallapoosa River, not far from Wetumpka Airport. My son, Mike, was going to be running the river in his jon boat. Found Mike and his buddy on a short, rough sand bar. Too short and rough, I chose a gravel bar up stream about a half mile. Now that I have the first gravel bar out of the way, the next one will be a lot more fun and not nearly as intimidating as this one was. That was my first off field landing since the first part of last year. I have only logged 3 hours air time since 10 May 2010. Does my mkIII fly any better clean? Couldn't really tell any difference. john h mkIII - 3,012.8 hours (airframe) 912ULS - 444.3 hours (engine) hauck's holler Titus, Alabama -------- John Hauck MKIII/912ULS hauck's holler, alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327349#327349 Attachments: http://forums.matronics.com//files/picture044_1_151.jpg http://forums.matronics.com//files/picture042_2_971.jpg http://forums.matronics.com//files/picture038_2_192.jpg http://forums.matronics.com//files/picture037_1_112.jpg ________________________________________________________________________________
Date: Jan 17, 2011
Subject: Re: Flying the Tallapoosa
Nice pics John, makes me wish I was down south ,23 degrees for a high here today 65 in O'brien looks like it finally warmed up where you are ? Chris Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly ----- Original Message ---- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Mon, January 17, 2011 7:23:36 PM Subject: Kolb-List: Flying the Tallapoosa Hi Folks: I sent some posts to the Kolb List earlier, each with a photo attached. That was three hours ago. Still no posts. If I resend, the old posts will arrive. ***************************************************** Hi Folks: Got to fly a little yesterday, in addition to washing Miss P'fer for the first time in 9 months. She is 50 lbs lighter now. Was a beautiful Sunday afternoon, just a little wind out of the NW. I flew the Tallapoosa River, not far from Wetumpka Airport. My son, Mike, was going to be running the river in his jon boat. Found Mike and his buddy on a short, rough sand bar. Too short and rough, I chose a gravel bar up stream about a half mile. Now that I have the first gravel bar out of the way, the next one will be a lot more fun and not nearly as intimidating as this one was. That was my first off field landing since the first part of last year. I have only logged 3 hours air time since 10 May 2010. Does my mkIII fly any better clean? Couldn't really tell any difference. john h mkIII - 3,012.8 hours (airframe) 912ULS - 444.3 hours (engine) hauck's holler Titus, Alabama -------- John Hauck MKIII/912ULS hauck's holler, alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327349#327349 Attachments: http://forums.matronics.com//files/picture044_1_151.jpg http://forums.matronics.com//files/picture042_2_971.jpg http://forums.matronics.com//files/picture038_2_192.jpg http://forums.matronics.com//files/picture037_1_112.jpg ________________________________________________________________________________
Date: Jan 17, 2011
Looks great John Glad to see you back in the saddle again posting all the great pics of all your flying adventures But I have to ask where did you ditch the 50 lbs I hope it wasn't just the grime you washed off your airplane Cold weather is really biting us here in Maine now so I probably wont be flying for a while -15 degrees this morning Ellery Batchelder Jr. -----Original Message----- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Mon, Jan 17, 2011 7:23 pm Subject: Kolb-List: Flying the Tallapoosa Hi Folks: I sent some posts to the Kolb List earlier, each with a photo attached. That as three hours ago. Still no posts. If I resend, the old posts will arrive. ***************************************************** Hi Folks: Got to fly a little yesterday, in addition to washing Miss P'fer for the irst time in 9 months. She is 50 lbs lighter now. Was a beautiful Sunday afternoon, just a little wind out of the NW. I fle w he Tallapoosa River, not far from Wetumpka Airport. My son, Mike, was oing to be running the river in his jon boat. Found Mike and his buddy on short, rough sand bar. Too short and rough, I chose a gravel bar up tream about a half mile. Now that I have the first gravel bar out of the ay, the next one will be a lot more fun and not nearly as intimidating as his one was. hat was my first off field landing since the first part of last year. I ave only logged 3 hours air time since 10 May 2010. Does my mkIII fly any better clean? Couldn't really tell any difference. john h kIII - 3,012.8 hours (airframe) 12ULS - 444.3 hours (engine) auck's holler itus, Alabama -------- ohn Hauck KIII/912ULS auck's holler, alabama ead this topic online here: http://forums.matronics.com/viewtopic.php?p=327349#327349 ttachments: http://forums.matronics.com//files/picture044_1_151.jpg ttp://forums.matronics.com//files/picture042_2_971.jpg ttp://forums.matronics.com//files/picture038_2_192.jpg ttp://forums.matronics.com//files/picture037_1_112.jpg -======================== ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jan 17, 2011
Looks great John Glad to see you back in the saddle again posting all the great pics of all your flying adventures But I have to ask where did you ditch the 50 lbs I hope it wasn't just the grime you washed off your airplane Ellery Batchelder Jr. Ellery B/Chris D/Gang: Weather got better here for a few days. Supposed to start raining tonight and get cold again here. Glad I was able to get out and do some flying while it was nice. Washed 50 lbs of crud off the mkIII after sitting in the hanger on the farm for 9 months. Last time I washed her was just before Sun and Fun 2010. Got word it was in the 50's at Larry Cottrell's Rock House. Looks like warmer days are coming for Alabama. ;-) john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 17, 2011
Gary and Thom.... I think you hit the nail on the head with crank case pressure....I thought it was ok,then I got thinking last night ( I work nights so I had 12 hrs to think about it ) and I got looking at the videos I made and the dates I made them,then went to the weather channel and matched up outside temps for the days it flew and the days it quit and the days it ran good the temps were 32+ and the days it quit temps were 10 - 18 *.With a closer look today I believe the vent tube was freezing up blocking off the venting of the case,The original catch cup I had was loose fitting and starting to come apart so this summer I made a new one with fittings in the top and a screw on cap for security and it worked great in warmer temps ,but maybe not so good in the winter months.I will try to run it tomorrow and will let you know how it goes...It all makes sense now and why after everything we did it all came back to the same thing ! Thanks Thom and Gary ! I would not have considered this Knowing how simple the system is...from now on I check this first, fuel pressure will now be monitored all the time now.... and I should have known this too! I will let you know for sure tomorrow! ps...this is the picture of the catch can...i removed the Brillo pad that was getting deteriorated and replaced it with paper toweling to soak up any moisture and oil...I am back using A Brillo coarse mesh pad again and I think I'm going to use larger diameter tubing too..when I took it apart you could see where the toweling was right up against the in-coming and out going openings... chris ambrose M3X/Jabiru N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327369#327369 Attachments: http://forums.matronics.com//files/img_1291_214.jpg ________________________________________________________________________________
Date: Jan 17, 2011
ps...this is the picture of the catch can chris ambrose M3X/Jabiru Chris A/Gang: Is it mandatory to use a large catch can? or can you configure the breather hose to dump overboard? Does the engine blow that much oil through the breather? or is the catch can also the air/oil seperator? john h mkIII titus, alabama ________________________________________________________________________________
Date: Jan 17, 2011
John, It's more of an air/oil separator...this is where the moisture gets out of the engine and without it it would make an annoying mess on the tail...the one I had on last year had the Brillo pad in it and was not as tight as this one is...maybe I made it too good ! chris ambrose Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327372#327372 ________________________________________________________________________________
Date: Jan 17, 2011
It's more of an air/oil separator...this is where the moisture gets out of the engine and without it it would make an annoying mess on the tail...the one I had on last year had the Brillo pad in it and was not as tight as this one is...maybe I made it too good ! chris ambrose Chris A: Does Jabiru provide an air/oil seperator? or do you have to provide one of your own design? john h mkIII Titus, AL ________________________________________________________________________________
Date: Jan 17, 2011
John, make your own... chris ambrose Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327374#327374 ________________________________________________________________________________
Date: Jan 17, 2011
Chris I have installed and flown two of the same Jabiru engines you have the 2200 I didnt get a big mess out of them and I would run that tube dow n through the tail boom and out to the end of the rudder it if was making that kind of a mess on the tail or I am willing to make you an aluminum Can just for that crank case vent if you would like with a petcock in the bottom of it so you can drain it on pre flights Ellery Batchelder Jr. -----Original Message----- From: ces308 <ces308(at)ldaco.com> Sent: Mon, Jan 17, 2011 11:22 pm Subject: Kolb-List: Re: Kolb/Jabiru carb overflow John, make your own... chris ambrose ead this topic online here: http://forums.matronics.com/viewtopic.php?p=327374#327374 ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jan 18, 2011
Nice to see you in the air again, John. Looks as though you have some good weather as well. Pat ________________________________________________________________________________
Date: Jan 18, 2011
Chris, An old Lycosaurus trick is to put a slit in the breather tube so that if there is any obstruction in the end of the tube the pressure will push the slit open and allow the engine to vent. Rick Girard On Mon, Jan 17, 2011 at 9:28 PM, ces308 wrote: > > Gary and Thom.... > > I think you hit the nail on the head with crank case pressure....I thought > it was ok,then I got thinking last night ( I work nights so I had 12 hrs to > think about it ) and I got looking at the videos I made and the dates I made > them,then went to the weather channel and matched up outside temps for the > days it flew and the days it quit and the days it ran good the temps were > 32+ and the days it quit temps were 10 - 18 *.With a closer look today I > believe the vent tube was freezing up blocking off the venting of the > case,The original catch cup I had was loose fitting and starting to come > apart so this summer I made a new one with fittings in the top and a screw > on cap for security and it worked great in warmer temps ,but maybe not so > good in the winter months.I will try to run it tomorrow and will let you > know how it goes...It all makes sense now and why after everything we did it > all came back to the same thing ! > > Thanks Thom and Gary ! I would not have considered this Knowing how simple > the system is...from now on I check this first, fuel pressure will now be > monitored all the time now.... and I should have known this too! > I will let you know for sure tomorrow! > > ps...this is the picture of the catch can...i removed the Brillo pad that > was getting deteriorated and replaced it with paper toweling to soak up any > moisture and oil...I am back using A Brillo coarse mesh pad again and I > think I'm going to use larger diameter tubing too..when I took it apart you > could see where the toweling was right up against the in-coming and out > going openings... > > chris ambrose > M3X/Jabiru > N327CS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327369#327369 > > > Attachments: > > http://forums.matronics.com//files/img_1291_214.jpg > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Jan 18, 2011
Man, Too bad we can't scrub the weight off our little tummy's!!! Good to see you ya with the Kolb grin again. You oughta come visit when it warms a bit. -------- Thanks too much, John Bickham Mark III-C w/ 912UL St. Francisville, LA I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327401#327401 ________________________________________________________________________________
Date: Jan 18, 2011
John, The oil fill tube,dip stick guide,crankcase vent are one and the same.About 3/4 in ID with the base of the tube not far enough above the oil level.The later model engines have a deeper oil pan,but it really should have a wind age tray like we used in VWs .I have built a separator mounted on top of th e engine with 5 vanes in it that cause the vent gases to make sharp turns w hen leaving the case that SEEMS to help,and have used a PCV valve to try to hold a negative pressure in the case, but the venting system needs a redes ign IMHO.If I still have it at the 2000hr TBO,I would try to modify it.It i s such a sweet engine in other respects. G.Aman MK-3C Jabiru 2200a 600hrs PS welcome back! ! -----Original Message----- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Mon, Jan 17, 2011 10:51 pm Subject: Re: Kolb-List: Re: Kolb/Jabiru carb overflow ps...this is the picture of the catch can chris ambrose M3X/Jabiru Chris A/Gang: Is it mandatory to use a large catch can? or can you configure the breathe r hose to dump overboard? Does the engine blow that much oil through the breather? or is the catch can also the air/oil seperator? john h mkIII titus, alabama ________________________________________________________________________________
Date: Jan 18, 2011
Chris, Glad you found the culprit! My rather small air/oil separator has one inlet and two outlets. The top outlet goes via flex hose directly overboard. The bottom outlet goes to a petcock and from there it also goes overboard. After every flight, I drain the several drops of the muck that collects in the bottom using the petcock. As long as I never let the separator fill up (drain after every flight), no oil or muck comes out of the upper outlet and the tail stays nice and clean. I add no more than a 1/2 pint or so of oil between 50 hour changes, so most of what comes out of the separator is oily water. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327409#327409 ________________________________________________________________________________
Date: Jan 18, 2011
Nice to see you in the air again, John. Looks as though you have some good weather as well. Pat Thanks, Patrick: Good to be back up again. Now I have to learn how to fly. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 18, 2011
If I still have it at the 2000hr TBO,I would try to modify it.It is such a sweet engine in other respects. G.Aman MK-3C Jabiru 2200a 600hrs PS welcome back! ! Gary A/Gang: Thanks for that info. I have a better understanding of what the Jabiru folks problem is now. Is the Jabiru Factory doing anything to help with this problem? Hopefully, you all can come up with a good solution. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 18, 2011
ps...this is the picture of the catch can...i removed the Brillo pad that was getting deteriorated and replaced it with paper toweling to soak up any moisture and oil...I am back using A Brillo coarse mesh pad again and I think I'm going to use larger diameter tubing too..when I took it apart you could see where the toweling was right up against the in-coming and out going openings... chris ambrose M3X/Jabiru N327CS >>>>>>>>>>>>>>> if there was someway that you could put some insulation around the seperator / tubing, it would keep it warm enough it could not ice over. just thinking outloud here, i have seen some foam tape that would keep things a bit warmer. as to paper or corse mesh pad... when working with pnumataic thermostats and controls,, one of the best filter housings ive seen used a roll of toilet paper as a filter element. it worked as a filter dryer. and cheap to replace. boyd young mkiii ________________________________________________________________________________
Subject: Birds of a Feather
Date: Jan 18, 2011
Birds of a Feather -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Faith is believing what you know ain't so - Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327484#327484 Attachments: http://forums.matronics.com//files/aerodynamics_101_843.jpg ________________________________________________________________________________
Subject: MkIII Xtra V speeds
Date: Jan 19, 2011
Kolb guys=2C and especially Travis=2C I am in the process of rounding up information for my Operator Limitations manual for my plane. Could I get a few of you Xtra owners to post your "V" speeds below in the list I have provided. Also=2C Travis=2C would you be kind enough to post the factory recommended speeds for these catagories=2C please? 1) Vso--(stall speed=2C or min. flight speed in 'landing' configuration {fl aps down})_________________ 2) Vs--(min. controllable airspeed in steady state flight {flaps up}_______ _____________ 3) Vfe--(maximun 'flap extended' stall speed)______________________________ ______ 4) Vno--(max speed for 'normal' operations)________________________________ _ 5) Vne--(never exceed speed)_____________________________________________ The Kolb factory states that the MkIII Xtra has a 35 mph stall speed=2C a nd 26 mph stall speed with flaps extended. Is this pretty close to what you Xtra own ers are experiencing? You response is appeciated. Thanks!!! Mike Welch MkIII ________________________________________________________________________________
Subject: Re: MkIII Xtra V speeds
Date: Jan 19, 2011
Hi Mike Stats are. Mk3xtra with Jab 2200. MAUV 943 lbs Stall flaps up.engine off 35mph Flaps down. 5mph less Cruise happily 50 to 80. I usually use around 70 to 75mph Ticketed at Vne 95mph Ticketed. Flaps down 60mph Min pilot weight with no ballast. 170 lbs. I usually take off single stage flap/climb out around 50mph. Land . Flaps down, engine idle around 50. bleed the speed over the hedge. Cheers Pat ________________________________________________________________________________
Subject: Monument Valley 2011
Date: Jan 19, 2011
Hi Kolbers: Anyone interested in Monument Valley 2011? Mothers Day is 8 May. Memorial Day is 30 May. Looking at the calendar, 19-22 May 2011 (Thu thru Sun), looks like our normal time frame to have the 2011 Kolb Unplanned/Unorganized Monument Valley Flyin. For an alternate date we can use 12-15 May. Usually, we arrive on Thu and depart Sun morning, giving us two full days, Fri and Sat at Gouldings. We encourage everyone to attend whether flying, driving, hitch hiking, or whatever. Let me know what you all think. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 19, 2011
Subject: Re: Monument Valley 2011
Hi John,=0AAlways interested in M.V. and Kolbers. Hope to see you and other s there. It's =0Acold in ARK.=0AFrank Goodnight=0A=0A=0A=0A=0A_____________ ___________________=0AFrom: John Hauck <jhauck(at)elmore.rr.com>=0ATo: kolb-li st(at)matronics.com=0ASent: Wed, January 19, 2011 4:08:23 PM=0ASubject: Kolb-L " =0A=0AHi Kolbers:=0A=0AAnyone interested in Monumen t Valley 2011?=0A=0AMothers Day is 8 May.=0A=0AMemorial Day is 30 May.=0A =0ALooking at the calendar, 19-22 May 2011 (Thu thru Sun), looks like our =0Anormal time frame to have the 2011 Kolb Unplanned/Unorganized Monument =0AValley Flyin.=0A=0AFor an alternate date we can use 12-15 May.=0A=0AUsua lly, we arrive on Thu and depart Sun morning, giving us two full days, =0AF ri and Sat at Gouldings.=0A=0AWe encourage everyone to attend whether flyin g, driving, hitch hiking, or =0Awhatever.=0A=0ALet me know what you all thi -======================== - - - - - - - - - - - - - -Matt Dralle, List Admi ==== ________________________________________________________________________________
Date: Jan 20, 2011
Mike, Using Pat's numbers you can come up with pretty accurate stall speed estimates at different flying weights by using the fact that a change in stall speed varies with the square root of the change in weight. Baseline Flying weight of 943 lbs Stall speeds 35 and 30 Examples: If flying 10% heavier, 1.1 x 943 = 1,037 lbs... Stall speeds should be 1.1^.5 = 1.049 ==>> 36.7 and 31.5 If flying 15% lighter, .85 x 943 = 802 lbs... Stall speeds should be .85^.5 = .922 ==>> 32.3 and 27.7 Vfe and Vne don't vary with flying weight. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32
December 29, 2010 - January 20, 2011
Kolb-Archive.digest.vol-kz
