Kolb-Archive.digest.vol-la
January 20, 2011 - February 10, 2011
      Don't accept your dog's admiration as conclusive evidence that you are wonderful.
      Ann Landers
      http://forums.matronics.com/viewtopic.php?p=327656#327656
Subject: Re: MkIII Xtra V speeds
Date: Jan 20, 2011
> Mike=2C > > Using Pat's numbers you can come up with pretty accurate stall speed esti mates at different flying weights by using the fact that a change in stall speed varies with the square root of the change in weight. > Thom Riddle Thanks Thom!! You are correct=2C and I hadn't taken that into account=2C yet. Also=2C thanks to Pat for the V speed numbers. They do coincide with what I was expecting. Mike Welch ________________________________________________________________________________
Date: Jan 20, 2011
Subject: RE: Kolb-List Digest: 5 Msgs - 01/19/11
The FAA put out a bulletin stating that all small aircraft should have a Manuvering speed recorded in the plane's information manuel??? Anyone have any (manuvering airspeed thoughts) input for the MarkIIIX with 100 hp engine? Thanks, Bob Green MKIIIX project, N830PB GPAS VW Conversion ________________________________________ From: Mike Welch <mdnanwelch7(at)hotmail.com> Subject: Kolb-List: MkIII Xtra V speeds Kolb guys=2C and especially Travis=2C I am in the process of rounding up information for my Operator Limitations manual for my plane. Could I get a few of you Xtra owners to post your "V" speeds below in the list I have provided. Also=2C Travis=2C would you be kind enough to post the factory recommended speeds for these catagories=2C please? 1) Vso--(stall speed=2C or min. flight speed in 'landing' configuration {fl aps down})_________________ 2) Vs--(min. controllable airspeed in steady state flight {flaps up}_______ _____________ 3) Vfe--(maximun 'flap extended' stall speed)______________________________ ______ 4) Vno--(max speed for 'normal' operations)________________________________ _ 5) Vne--(never exceed speed)_____________________________________________ The Kolb factory states that the MkIII Xtra has a 35 mph stall speed=2C a nd 26 mph stall speed with flaps extended. Is this pretty close to what you Xtra own ers are experiencing? You response is appeciated. Thanks!!! Mike Welch MkIII ________________________________________________________________________________
Date: Jan 20, 2011
Subject: Re: RE: Kolb-List Digest: 5 Msgs - 01/19/11
Bob, Mine's a IIIC, but I use 60 as Va. That puts me in the white arc so I can drop the flaps a notch if I want to slow down any more. Rick Girard On Thu, Jan 20, 2011 at 10:23 AM, Bob Green wrote: > > The FAA put out a bulletin stating that all small aircraft should have a > Manuvering speed recorded in the plane's information manuel??? > Anyone have any (manuvering airspeed thoughts) input for the MarkIIIX with > 100 hp engine? > > Thanks, > Bob Green > MKIIIX project, N830PB > GPAS VW Conversion > > > ________________________________________ > From: Mike Welch <mdnanwelch7(at)hotmail.com> > Subject: Kolb-List: MkIII Xtra V speeds > > > Kolb guys=2C and especially Travis=2C > > I am in the process of rounding up information for my > Operator Limitations manual for my plane. Could I get a few > of you Xtra owners to post your "V" speeds below in the list I > have provided. > > Also=2C Travis=2C would you be kind enough to post the factory > recommended speeds for these catagories=2C please? > > 1) Vso--(stall speed=2C or min. flight speed in 'landing' configuration {fl > aps down})_________________ > 2) Vs--(min. controllable airspeed in steady state flight {flaps up}_______ > _____________ > 3) Vfe--(maximun 'flap extended' stall speed)______________________________ > ______ > 4) Vno--(max speed for 'normal' operations)________________________________ > _ > 5) Vne--(never exceed speed)_____________________________________________ > > The Kolb factory states that the MkIII Xtra has a 35 mph stall speed=2C a > nd 26 mph > stall speed with flaps extended. Is this pretty close to what you Xtra own > ers are > experiencing? > > You response is appeciated. Thanks!!! > > Mike Welch > MkIII > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Subject: MkIIIX V speeds
Date: Jan 20, 2011
>Bob=2C Mine's a IIIC=2C but I use 60 as Va. That puts me in the white arc so I can drop the flaps a notch if I want to slow down any more. >Rick Girard Rick=2C 60 mph is what I was thinking=2C too=2C for the maneuvering speed. I'll add that to my growing list of 'V' speeds to go into my Operator/Aircraft Limitation Ma nual. Thanks=2C Mike Welch ________________________________________________________________________________
Subject: Re: Monument Valley 2011
Date: Jan 20, 2011
Anyone interested in Monument Valley 2011? Looking at the calendar, 19-22 May 2011 (Thu thru Sun), looks like our normal time frame to have the 2011 Kolb Unplanned/Unorganized Monument Valley Flyin. john h ++++++++++++++++++++++++++++++ Hi Kolbers: Since I sent the above post to the Kolb List yesterday, I have decided not to try and fly to Monument Valley this year. For those of us that fly in, there is a lot of walking and standing around involved in camping and living during the event. After getting entirely honest with myself, I do not think I am going to be capable of having fun and enjoy camping and walking around the area for four days. Being entirely dependent on hitching rides, calling the shuttle van, etc., would take away a lot of the fun of attending the flyin. I will not know for sure if I can be comfortable camping until I fly to Sun and Fun 30 Mar. If I discover I can not be comfortable and enjoy the show, I can get back in the mkIII and be home the same day. I have flown to every MV flyin since the original in 2003, through 2008. Last year I missed because of my accident. Those that did make last year's flyin said I was a lot more comfortable in the Rehab Hospital than I would have been trying to camp at Gouldings. I think I would have rather eaten and slept in sand. Last year we had zero Kolb aircraft show for the flyin. By all means, do not cancel the MV Flyin. If you have a couple Kolbs in attendance, you can have a lot of fun. I will miss it, as I miss many of those regular attendees, and close friends that are no longer with us. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 21, 2011
Subject: RE: Kolb-List Digest: 6 Msgs - 01/20/11
Thanks to all that responded concerning the maneuvering speed for the MKIIIX. Rick Neilsen... what do you use since you are the pioneer for VW conversions? Craig Spoke??? Will look forward to seeing the complete V speed lists. Thanks again. John H. I would I would like to go to MV but will be busy with work obligations in May. Any plans for a Nauga Fly-in in the fall? Bob Green MKIII X project N830PB ________________________________________________________________________________
Subject: Re: RE: Kolb-List Digest: 6 Msgs - 01/20/11
Date: Jan 21, 2011
John H. I would I would like to go to MV but will be busy with work obligations in May. Any plans for a Nauga Fly-in in the fall? Bob Green Nauga belongs to John Bickham, who has not indicated any plans for a future flyin. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 6 Msgs - 01/20/11
Date: Jan 22, 2011
Heck we'll throw something together. We're in the process of juggling work shift teams. Need to know where I land before I can schedule something. Anytime someone wants to just visit, we'll do our best to feed, water, and bed em. Been pretty busy. Grandkids are time consuming, but a blast! -------- Thanks too much, John Bickham Mark III-C w/ 912UL St. Francisville, LA I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327934#327934 ________________________________________________________________________________
Subject: Future Nauga Field Fly Around
Date: Jan 22, 2011
Anytime someone wants to just visit, we'll do our best to feed, water, and bed em. John Bickham John B/Gents: I need some training flights to help me get back into cross country shape again. Soon as the weather starts getting a little more agreeable I'll be on my way to Star Hill, LA, with a stop over at the late Paul Petty's father-in-law, Charley Harris. Both John B and Charley H have nice grass strips and wives that can cook as good as my mama could. Today would have been a good day to fly, but the temps stayed in the 40's and that was too cool for me. Soon as it warms up enough to work on my airplane under the shade tree, I need to replace Lord Mounts and update some wiring. Travis Brown has a lot of stiff Lord Mounts at Kolb Aircraft. Lord mounts do wear out and they are hard to come by because most dealers do not want to sell less than 100 each. Looking forward to the next Nauga Fly Around at Star Hill, LA. The local folks down there know how to cook, tell stories and even make Yankees feel at home. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: aileron gap seal advice request
Date: Jan 22, 2011
Kolb Folks, I need to replace my deteriorated clear-tape gap seals with PolyFiber tape. Need to know if when using Poly tape if you only do one side, & if so, top or bottom. I'm assuming top? I removed my seals today and went for a flight-gap seals off, noticed my Kob pulls more to the right than she used to. Also noticed in turbulence I need to apply quite a bit more stick pressure to level the wings, so it's obvious the gap seals help in control authority. Stall speed is the same, cruise speed is the same, but she just doesn't have the easy finger-tip control she had before. Ready for suggestions, -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327942#327942 ________________________________________________________________________________
Date: Jan 23, 2011
Subject: Re: aileron gap seal advice request
Hi Jim,=0A=0AI Know your plane is prettier than mine -----but---- the best thing I have found =0Afor gap seals , after useing=0Aboth pollyfiber and th e clear (book repair tape from- Kolb ) is two strips of =0A2in, gorrilla tape one with=0Athe sticky side up and and the other one sticky-side down . Easy to put on and =0AEasy to take off should you=0Aneed -to make a rep air, plus it lasts a long time,I also-use a strip of it for =0Aleading ed ge protection.=0AStay warn and dry. It's been a little cool here in Ark.=0A Frank=0A-=0A=0A=0A=0A=0A________________________________=0AFrom: Jimmy Yo ung =0ATo: kolb-list(at)matronics.com=0ASent: Sat, January 22, 2011 6:01:54 PM=0ASubject: Kolb-List: aileron gap seal advice request =0A=0AKolb Folks,=0A=0AI need to replace my deteriorated clear-tape gap sea ls with PolyFiber tape. =0A=0ANeed to know if when using Poly tape if you o nly do one side, & if so, top or =0Abottom. I'm assuming top? =0A=0A=0AI re moved my seals today and went for a flight-gap seals off, noticed- my Kob =0Apulls more to the right than she used to. Also noticed in turbulence I need to =0Aapply quite a bit more stick pressure to level the wings, so it' s obvious the =0Agap seals help in control authority. Stall speed is the sa me, cruise speed is =0Athe same, but she just doesn't have the easy finger- tip control she had before.=0A=0AReady for suggestions,=0A=0A--------=0AJim my Young=0AMissouri City, TX=0AKolb FS II/HKS 700=0A=0A=0A=0A=0ARead this t opic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=327942 ==================== ________________________________________________________________________________
Date: Jan 23, 2011
Hey Jimmy, This is what I did and got good results for +10 years now. Early on I noticed a lot of cracking in the gap seals of various Kolbs using the recommended method. I think that 2" tapes were the standard. This method kinda produced a hard crease, like an upside down "V". I used a 3" tape that is folded back and doubled for about 6 inches on the ends for strength. The 3" tape produces more of a roll than a hard crease that is less prone to cracking, IMHO. After over 10 years, just starting to see a little cracking in gap seals on inboard flap in. I use them flaps a lot at Nauga!! Simply my experience and opinion. -------- Thanks too much, John Bickham Mark III-C w/ 912UL St. Francisville, LA I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327996#327996 ________________________________________________________________________________
Subject: GSC hub for sale
Date: Jan 23, 2011
GSC 2 blade hub,vg condition $100 shipped lower 48 ________________________________________________________________________________
Date: Jan 23, 2011
> I Know your plane is prettier than mine Frank, I've never seen your Kolb so I can't comment on that. Maybe one day we can meet somewhar & check each other's Firestar out. Back to the finishing tape method for a gap seal, I'd like to see a pic of someone's Kolb done that way if anyone has a photo handy. I was looking it over today and it seems one layer over the top laid down with the flaperons in the down position would do the trick. What I need to know is, do I need one on the bottom as well? If it's just for looks only, I'll go on top. If it has much, if any, effectiveness to add one on the bottom, then I'll do that as well. -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328139#328139 ________________________________________________________________________________
Date: Jan 24, 2011
What I need to know is, do I need one on the bottom as well? If it's just for looks only, I'll go on top>> Hi Jimmy, It definitely is not `for looks only` it is for efficiency. The tape should go from the top surface of the wing to the underside of the aileron. On the other hand I have seen gliders, who REALLY worry about things like that and fit ailerons/elevaters/rudder to much tighter tolerances than a Kolb, use a tape to connect both TOP surfaces. Might be worth talking to a glider pilot who is current about it. My gliding experience is many years out of date. Cheers Pat ________________________________________________________________________________
Date: Jan 24, 2011
What I need to know is, do I need one on the bottom as well? If it's just for looks only, I'll go on top>> Hi Jimmy, It definitely is not `for looks only` it is for efficiency. The tape should go from the top surface of the wing to the underside of the aileron. Cheers Pat >>>>>>>>>>>>>>>>> i did mine the way pat describes... but i used book binding tape, found an exact match,,, used 2 inch wide tape, overlalped sticky side to stick side 1 inch,,, leaving 1 inch sticky to attach to the top of wind and 1 inch sticky to attach to bottom of aileron. i guess you could do it with polly fiber,,, but not 100 % sure how to keep a straight line when gluing the inside line on the strip. maybe you could use some type of silicone tape. boyd young mkiii utah ________________________________________________________________________________
Date: Jan 24, 2011
Subject: New Dremel accessory
A couple of months ago I was in Lowe's when I remembered I needed a package of cut off wheels for my Dremel. At the display I found they have a new cut off wheel and drive mandrel out. The old ones were fragile and used a single screw to attach the wheel to the mandrel. The new one uses a spring loaded collar on the mandrel with a positive drive key to engage the wheel. The whole thing is just plain slick. The new cut off wheels last 3 to 4 times as long as the old ones even going through alloy steel. I cut the heads off two AN 5 bolts and the wheel only lost an 1/8" off its diameter. If you go to Lowe's look carefully I found the mandrel and five wheels as a special for $15. Separately they're about $18. Just to keep this specifically Kolb related, I was removing the elevator hinge from the horizontal stabilizer of a Mk IIIX yesterday. The original builder did a poor job of drilling the holes and every one of the stainless steel pop rivets spun before the drill separated the head from the body. I used the edge of the new Dremel cut off wheel to shave the head head of the rivet until I could just see the line concentric to the center hole. A light tap with a punch and the rivet was removed with no more damage to the hole. I did all 48 rivets in about a half hour and moved on. The cutoff wheel barely showed any wear. Rick Girard -- Zulu Delta Mk IIIC Thanks Homer, GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jan 24, 2011
>A couple of months ago I was in Lowe's when I remembered I needed a packag e of cut off wheels for my Dremel. Hi Rick=2C Hmmm. You find a nifty tool=2C and you wait a couple of months to share. Hmmm! >Just to keep this specifically Kolb related=2C I was removing the elevato r hinge >>Rick Girard Tools to use building airplanes are ALWAYS Kolb related!! No further exp lanation necessary. Speaking of Dremels..... I have a Ryobi cut-off tool. I have always li ke it=2C but it is 99% dead now!! It won't stay running for more than a few seconds=2C may be the brushes are burned up=2C but it's not worth trying to fix (IMO). At any ra te=2C I want a new cut-off tool. Since I just had a birthday a couple of days ago=2C I decide d I will get me one for a birthday gift....to me!! Since you recommend { finally : ) } the Dremel=2C and especially the new anvil mount=2C I'll head over and check them out!! Thanks=2C Rick BTW=2C are you referring to those fiber reinforced cut-o ff disks? The ones that come in that handy blue "slide out" container? I've used those for years. They are VERY durable! I used to break the cheapies in minutes=2C all the time. Sometim es=2C in only seconds. Mike Welch MkIII ________________________________________________________________________________
Subject: Re: New Dremel accessory
Date: Jan 24, 2011
Hmmm. You find a nifty tool, and you wait a couple of months to share. Hmmm! Mike Welch Mike W/Rick G/Gang: Realize this is not quite subject related, but wanted to share with you all, if you don't mind. I'm a die grinder kinda guy. I have a straight and a 90 degree grinder. Probably paid 15 or 20 dollars a piece for them. A few drops of Marvel Mystery Oil through the air intake every once in a while and they go forever. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 24, 2011
> A few drops of Marvel Mystery Oil through the air intake every once in a > while and they go forever. > > john h John=2C There's no doubt I demand a lot from my tools. Probably a lot more than they were originally intended to put out. I guess my approach is=3B if this too l can't get the job done=2C then "I'll get the next bigger model!!" I haven't tried the Marvel oil maintenance....but I will from now on. Da rn sure couldn't hurt. I kinda think my present Ryobi is toast=2C but what the heck=2C right now it's like an old 'straight six' running on 4 cylinders. I'll see if a little oil will h elp.... I did find on eBay that neat=2C new mandrel Rick was talking about. It h as a kind of butterfly hole in the disk=2C that spins and locks into the mandrel head. Nice feature. MY problem is: I liked the Ryobi because it had about 8-10 speeds. I don 't think the Dremel does. I'd miss that feature. In the last year=2C I burned up two hand-held grinders!! My old faithful Makita=2C and it's replacement Milwaukie. I'll be a little easier on my brand new Mi lwaukie. Plus=2C from now on=2C I'll use some Marvel oil once in awhile... Mike Welch ________________________________________________________________________________
Date: Jan 24, 2011
Mike, The old cut off wheels I was referring to are the fiber reinforced ones with a 1/16" center hole for mounting. They were just too fragile for most anything and if you pushed them too hard the center cracked out and you were done. As you can see the new ones are much more robust. Rick On Mon, Jan 24, 2011 at 11:17 AM, Mike Welch wrote: > >A couple of months ago I was in Lowe's when I remembered I needed a > package of cut off wheels for my Dremel. > > > Hi Rick, > > Hmmm. You find a nifty tool, and you wait a couple of months to share. > Hmmm! > > > >Just to keep this specifically Kolb related, I was removing the elevator > hinge > >>Rick Girard > > Tools to use building airplanes are ALWAYS Kolb related!! No further > explanation > necessary. > > Speaking of Dremels..... I have a Ryobi cut-off tool. I have always > like it, but it > is 99% dead now!! It won't stay running for more than a few seconds, maybe > the > brushes are burned up, but it's not worth trying to fix (IMO). At any > rate, I want a new > cut-off tool. Since I just had a birthday a couple of days ago, I decided > I will get me > one for a birthday gift....to me!! > > Since you recommend { finally : ) } the Dremel, and especially the new > anvil mount, > I'll head over and check them out!! > > Thanks, Rick BTW, are you referring to those fiber reinforced cut-off > disks? The ones that > come in that handy blue "slide out" container? I've used those for years. > They are VERY > durable! I used to break the cheapies in minutes, all the time. > Sometimes, in only seconds. > > Mike Welch > MkIII > > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jan 24, 2011
From: william sullivan <williamtsullivan(at)att.net>
- Mike- I don't think you can lube the electric tools.- Maybe a drop on the bearings.- If you use a Dremel for end grinding, like pushing straig ht in, the main shaft gets set back.- My battery powered Dremel did that- my fault.- I was able to disassemble and push the shaft back into positi on.- John was talking about the air powered ones.- If you have a compre ssor, get the 1/4" drive tools.- By name brand ones, like Ingersoll or Ch icago Pneumatic, or Snap-on.- Craftsman used to make a 1/4" drive electri c die grinder- 110V. - ------------------------- ---------------------- Bill Sul livan --- On Mon, 1/24/11, Mike Welch wrote: From: Mike Welch <mdnanwelch7(at)hotmail.com> Subject: RE: Kolb-List: New Dremel accessory Date: Monday, January 24, 2011, 1:38 PM > A few drops of Marvel Mystery Oil through the air intake every once in a > while and they go forever. > > john h - ________________________________________________________________________________
Date: Jan 24, 2011
Hi Rick=2C The disks that I was referring to were fragile=2C unreinforced kind. If you breathed on them hard=2C they broke!! Pretty near useless=2C IMO=2C unless you were cutting balsa wood....slowly!! The 'much better' ones I was referring to are the fiber reinforced ones. I generally got lots of mileage out of these....that is=2C unless I bumped them sideways=2C or layed the tool down too hard. I have bent in half dozens of these. Yes=2C they do have the rediculously little 1/16" hole!! I haven't seen the new cut-off discs you're referring to. I'll make it a point to check them out. As I previously stated=2C I really liked the Ryobi rotary tool. But=2C I 'm open to recommendations regarding the Dremel. Does anyone have a "preferred model" they like.....and why? Mike Welch ________________________________________________________________________________
Date: Jan 24, 2011
Hi Bill=2C Thanks for pointing that out re: air tools. I didn't catch that. Doh!! No=2C I never use the rotary tool for anything except the cut-off discs. I know about oil in air tools. That's not new to me=2C I just misunderst ood what he was getting at. Thanks=2C Bill. Yeah=2C I know what you are getting at regarding the "name brand" tools. I think that is where they got that expression=3B You get what you pay for !!! Mike ________________________________________________________________________________
Date: Jan 24, 2011
- Mike- if you have a compressor, then I really recommend a 90 degree too l with the 3M "Roloc" disc accessory.- The sanding discs will remove a lo t of metal, and the "scruffy pad" discs will polish.- Nice for brazing pr ep and finish, and polishing welds.- Very controllable. - ------------------------- ---------------------- Bill Sul livan --- On Mon, 1/24/11, Mike Welch wrote: From: Mike Welch <mdnanwelch7(at)hotmail.com> Subject: RE: Kolb-List: New Dremel accessory Date: Monday, January 24, 2011, 3:27 PM Hi Bill, - - Thanks for pointing that out re: air tools.- I didn't catch that.- Doh!! - - No, I never use the rotary tool for anything except the cut-off discs. - - I know about oil in air tools.- That's not new to me, I just misunder stood what he was getting at.-- Thanks, Bill. - - Yeah, I know what you are getting at regarding the "name brand" tools. I think that is where they got that expression;- You get what you pay for !!! - - Mike ________________________________________________________________________________
Subject: Dremel rotary tool
Date: Jan 24, 2011
Hi Bill=2C Don't get me wrong=2C tools I've got!!!! I've spent a life in constructi on and have TONS of tools. Air tools=2C hand-held electric=2C battery powered =2C you name it=2C I've got it. If I don't 'got' it=2C I'm not likely to get o ne now. My wife says wants me to start downsizing=2C too=2C "so we can retire". I have one of those air grinders you mentioned=2C but I hardly ever use i t. Yes=2C I have a compressor. Actually=2C I have 3 shop types. I did recent ly sell my 'tow behind' Ingersoll-Rand diesel compressor=2C tho. Naw=2C what I'm looking for at this point is a new A/C rotary tool... either Dremel=2C or Ryobi=2C or possibly another brand that comes highly recommended. I would consider a battery rotary tool=2C but only if it always sat in th e charger (when not in use). That way=2C it would always be charged up. I have three hand-held grinders. My 4" Milwaukie=2C my 4 1/2" Ryobi=2C a nd my industrial model...7" Milwaukie. The little rotary tool I have (the Ryobi) was for really little intricate stuff. Like the kind of stuff that needs a 1" cutting wheel. Thanks=2C Mike ________________________________________________________________________________
Subject: Re: Dremel rotary tool
Date: Jan 24, 2011
Don't get me wrong, tools I've got!!!! I've spent a life in construction and have TONS of tools. Air tools, hand-held electric, battery powered, you name it, I've got it. Mike Mike W/Kolbers: Doncha think Mike ought to have that mkIII flying by now with all those tools. ;-) john h( Brother Jim was cutting and welding up my mkIII fuselage at Homer's 20 years ago.) mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 24, 2011
> Doncha think Mike ought to have that mkIII flying by now with all those > tools. =3B-) > > john h John=2C House completion=2C odds and ends=2C freezin' cold shop=2C and all kinds of other poor excuses!!! I could turn the heat-pump on in my shop=2C but I found ou t that gets a little expensive. Add on top of all that=2C 3 weeks ago today I hurt my upper back while wo rking on my storm cellar. I can't carry those 100 pound bags of mortar like I us ed to. I've had a pinched nerve and nagging headache every day since!! Ya ca n't get much done when you're 'uh hurtin'". By the way=2C a progress update=3B I installed my front instrument panel /radio console a couple of days ago. I had a couple of minor antenna cable issues =2C but I got those all resolved today. Just for s & giggles=2C I made a little wind tunnel for the pitot system =2C prior to carrying the panel over to the shop. (I borrowed my wife's hair dryer =2C which surprisingly=2C worked VERY well. I taped up the 'heat' button=2C so it blew only cold air) Here's what I found out=3B The Dynon D10A EFIS and the UMA airspeed indicator were virtually exact in their respective readings. In fact=2C it surprised me how much they rea d the same. One thing=2C though. The UMA airspeed indicator was "not as precise". I t seemed to lag about 2-3 mph. This trait did NOT appear to be a safety problem=2C just a little annoying that it wasn't as gnat's-ass accurate as the Dynon. The Dynon was phenomenally sensitive to the slightest change in air pressure. I get the impression it is accurate to less than 1 mph=2C whereas I would give the UM A an accuracy of about 2 mph. Either one of them would be plenty qualified to be a primary source of airspeed information=2C it's just that the Dynon was soooo much more precise!! (What would you expect for the $$? Remember the "you get what you pay for" adage?) I was very surprised to find out that they both coincided in their readin g so well. I feel a lot more confident that I have (at least one) excellent=2C trust worthy airspeed indicator!! Before my little wind tunnel test=2C I did not know t his!! For the record=2C I wasn't trying to establish that either one of the air speed indicators was "exact" in their accuracy=2C but rather=2C that they=2C in fact=2C work ed at all!! I do NOT want to get myself in a situation where I ASSUMED everything will work prop erly=2C just because I want them to!! I'm a firm believer in 'trust=2C yet verify! !' I look forward to warmer weather. Can't get much done in this kind of cold temps. I think I should be able to fire up the engine in a couple of weeks=2C or so. Now=2C THAT should be interesting!!! Mike W ________________________________________________________________________________
Date: Jan 24, 2011
One thing, though. The UMA airspeed indicator was "not as precise". It seemed to lag about 2-3 mph. This trait did NOT appear to be a safety problem, just a little annoying that it wasn't as gnat's-ass accurate as the Dynon. The Dynon was phenomenally sensitive to the slightest change in air pressure. I get the impression it is accurate to less than 1 mph, whereas I would give the UMA an accuracy of about 2 mph. Mike W Mike W/Kolbers: The UMA may turn out to be a better ASI than the one you spent all that money on, the Dynon. I don't know that. However, the UMA lags, am guessing you mean it does not change indication instantly, because it has a built in dampner to prevent the needle from bouncing around at every tiny, minute bit of disturbed air, air pressure, etc. Without the dampner the needle would probably be a blur. Just guess, of course. To me the most important aspect of the ASI is that it will indicate to me where my stall speed is so I can stay above it. ASI's are very reliable. Usually alway work well enough to establish stall speed, unless one forgets to take off the pitot cover, a dirt dauber or spider takes up residence in the pitot tube, or someone blows into the pitot tube to see if the ASI really works. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Dependable instruments
Date: Jan 24, 2011
> The UMA may turn out to be a better ASI than the one you spent all that > money on=2C the Dynon. I don't know that. Hi John=2C The UMA being the better indicator=2C naw=2C I don't think so. It's hard to describe very accurately=2C but the Dynon airspeed readings were smooth. With the pitot inlet propped up in place=2C directly inline with the airstr eam=2C I could vary the airspeed readings by adjusting the distance from the pitot opening from the hair dryer flow of air. I could get a reading of about 60 mph max @ 1"=2C or as little as 10-15mph @ about 12". So=2C with both units reading....let's say 50 mph. If I don't move anyth ing=2C they both continue to read the same airspeed fairly well. They also both seem t o agree closely=2C almost all the time. Any disparity was never more than 3 mph. Now=2C if I stick my finger in the airsteam just a bit=2C the Dynon will reflect a modest decrease=2C 1=2C 2=2C maybe even 3 mph=2C but the UMA...no change. If I remove my finger out of the flow of air=2C the Dynon goes back to 50. In the meantime=2C the UMA never left 50. Would a more expensive pitot style airspeed indicator have performed bett er? Absolutely!! There is a reason why they cost several hundreds=2C and this UMA only costs $169. I've heard it said=2C you get what you pay for. > However=2C the UMA lags=2C am guessing you mean it does not change indica tion > instantly=2C because it has a built in dampner to prevent the needle from > bouncing around at every tiny=2C minute bit of disturbed air=2C air press ure=2C > etc. Without the dampner the needle would probably be a blur. BTW=2C it wasn't such that the UMA 'lagged'. With small airspeed changes =2C it didn't lag=2C it just didn't change at all!! If the airspeed pitot pressur e exceeded 4-5mph=2C then the needle would move. I am not knocking the UMA. It has shown it performs plenty good enough t o provide accurate (enough) airspeed readings. But=2C I am convinced a much more expensive unit would be 'more sensitive'=2C that's all. > To me the most important aspect of the ASI is that it will indicate to me > where my stall speed is so I can stay above it. I couldn't agree more!!!!! As was previously established in an earlier t hread=2C regardless of whether your airspeed indicator says 40 or 400=2C (at stall) THAT'S the magic number to stay above!! > ASI's are very reliable. Usually alway work well enough to establish stal l > speed That's what I wanted to establish=2C namely=2C that these things simply w ork!! By all accounts=2C they seem to be functioning quite well. This fact is all I was counting on! Whatever reading they say at stall=2C that will be the 'magic number' to stay much higher than. =2C unless one forgets to take off the pitot cover=2C a dirt dauber or > spider takes up residence in the pitot tube=2C or someone blows into the pitot > tube to see if the ASI really works. > john h > mkIII > Titus=2C Alabama Had that happen to me once. I was half way down the runway and the airsp eed indicator was still stuck at zero. Slow down=2C turned off the runway=2C d id some investigating. A mud dauber had made a new home in my pitot tube. Dug out the dirt...worked like a champ!! BTW=2C is anyone curious how fast a hornet is when he is 8" away from you r hand=2C while you're checking your oil? Let's just say=2C faster than you'd think! ! And yes=2C they do leave scars!! Mike Welch ________________________________________________________________________________
Subject: Re: Dependable instruments
Date: Jan 25, 2011
Now, if I stick my finger in the airsteam just a bit, the Dynon will reflect a modest decrease, 1, 2, maybe even 3 mph, but the UMA...no change. If I remove my finger out of the flow of air, the Dynon goes back to 50. In the meantime, the UMA never left 50. > john h Mike W/Kolbers: Sorry, I misunderstood your initial post comparing the two ASI's. The UMA is probably not slow and/or lagging, but insensitive to small changes. Probably a cheap bellows and operating mechanism. I tried to get a new UMA tach to work on my 912 some years ago. Worked with the factory techs through three different new UMA tachs. Never could get it to work correctly. Finally, went back to the Rotax tach. I wanted a 3 inch tach instead of the 2" Rotax tach. I haven't bought an ASI in some time, but I have always used Winter brand built in Germany, primarily for sail planes. You are correct, Michael. You get what you pay for. That's why I have flown with the 912 series engines since 1994. They are outrageously exensive, but reliable. john h mkIII Titus, Alabama - Watching the rain drops fall. ________________________________________________________________________________
Date: Jan 25, 2011
> > >The UMA is probably not slow and/or lagging, but insensitive to small >changes. Probably a cheap bellows and operating mechanism. > John is correct in that each instrument will have a different threshold to incremental change due to the mechanisms internal resistance or friction. If you are going to compare two different ASI, it is best to put them in the same flying environment. What was the poorest performing may equal the best performing when both are subjected normal vibrations due to powered flight. I use a Winter ASI in the FireFly. I was disappointed due to it's slow reaction time. I minimized the reaction time by drilling out the flow control orifice to the point that it is a little on the nervous side. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jan 25, 2011
Another factor may cause lagging response in an otherwise good system. A bug. Insect residue such as a small piece of spiderweb can cause a small enough restriction to give a lagging or a small series of steps in needle response. Not enough to prevent a steady state reading which will still be accurate. Disconnect at the panel and blow out in reverse. Sorry if this is too obvious. BB On 25, Jan 2011, at 10:48 AM, Jack B. Hart wrote: > >> >> >> The UMA is probably not slow and/or lagging, but insensitive to small >> changes. Probably a cheap bellows and operating mechanism. >> > > John is correct in that each instrument will have a different threshold to > incremental change due to the mechanisms internal resistance or friction. > > If you are going to compare two different ASI, it is best to put them in the > same flying environment. What was the poorest performing may equal the best > performing when both are subjected normal vibrations due to powered flight. > > I use a Winter ASI in the FireFly. I was disappointed due to it's slow > reaction time. I minimized the reaction time by drilling out the flow > control orifice to the point that it is a little on the nervous side. > > Jack B. Hart FF004 > Winchester, IN > > > > > ________________________________________________________________________________
Date: Jan 25, 2011
Jack=2C Hi. Hiding out from the snow=2C lately??? Regarding the UMA airspeed indicator=2C it isn't that it "lags". Very sm all airspeed changes do not move the needle....at all. It frankly just isn't that high of a quality of an indicator!! There are $ 170 A/S gauges and there are $800 A/S gauges. The 'more expensive' gauge will likely be=3B more accurate=2C more smooth in operation=2C and in gener al=2C basically perform better. Maybe not always......but most of the time. My UMA A/S indicator is a $170 version. It is 'entry level'. I chose it because I knew I had a back-up. However=2C as I said before=2C it IS reaso nably accurate. It performs an adequate job. If it was my ONLY A/S indicator=2C I would still feel confident I could depend on it (after testing it and verif ying that it operates just fine!!) Having never flown with either the Dynon or the UMA=2C I just wanted a li ttle 'piece of mind' that they simply worked!! Accuracy I can work on later (bu t from appearances=2C I doubt I'll need to!!). But=2C a completely 'non-work ing' airspeed system may not give me a 'later'=2C and that's all I was trying to avoid with the test. : ( Mike Welch ________________________________________________________________________________
Date: Jan 25, 2011
Anyone I have a UMA asi. It stopped working a couple times. 1st I thought it was the air flow pitot cover. Not. Started woking during climb. 2nd time I hit ET (gauge cluster) on the head and it worked. What should I look for besides a new one? Vic 912ul xtra -------- Vic 912ul Xtra Maine Too old to cut the mustard but not the cheese. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328430#328430 ________________________________________________________________________________
Date: Jan 25, 2011
> I have a UMA asi. It stopped working a couple times. > Vic > 912ul > xtra Hi Vic=2C I took apart a poorly working TSO'd airspeed indicator once. (I've taken apart two airspeed indicators=2C and put them back together) If I remember correctly=2C there was very slight metal corrosion on the internal moving and touching parts. I carefully cleaned them up with an electronic parts cleaner product=2C put on a couple of tiny drops of mineral oil (really tiny!!!) on the moving parts where they contact=2C and it worked like a champ!! I even took the time to clean the dial face real nice=2C and purdy. I polished the glass lens=2C and put the whole arrangement back together. It was given to me for free. I sold it for $130 to a guy on eBay. He installed it immediately after getting it=2C and said it worked flawlessly for his flight back to Los Angeles. So=2C in a nutshell=2C I'd say you might have some light corrosion. Take it apart=2C and look. BTW=2C you'll want a spotless work environment!! Lay out a clean light colored towel. Light colored so you can see the tiny little screws =2C when you drop them. Just a thought.... Mike Welch ________________________________________________________________________________
Date: Jan 25, 2011
Subject: Re: Dependable Instruments
- Mike- One note on the ASI.- Check it again after you install it.- I thought I was safe if my ASI read under 20mph.- Didn't move at all while taxiing.- Turned out it was hooked up backwards, leading to my surprise flight.- I had depended on someone else saying the needle had moved while testing it.- I think it must have moved backwards, or something. - ------------------------- ------------------- Bill Sullivan ------------------------- ------------------- Windsor Locks, Ct . (snowing again) ------------------------- ------------------- FS 447 ________________________________________________________________________________
Date: Jan 25, 2011
All the talk about airspeed indicaters leads to me to ask if I am the only one =0Athat routinely practices flying=0Awith out useing the ASI ,take off, landings, slow flight , stalls ,unsual =0Aattitudes .especially takeoffs a nd landings=0Afrom differant alt above sea level --35ft to over 6000ft .dif ferent aproch =0Aspeeds , landing uphill- downhill or anythin=0Aelse I can think of that will help me to fly the airplane.=0AFrank Goodnight=0A=0A=0A =0A=0A________________________________=0AFrom: Mike Welch <mdnanwelch7@hotm ail.com>=0ATo: kolb-list(at)matronics.com=0ASent: Tue, January 25, 2011 11:18: 09 AM=0ASubject: RE: Kolb-List: Re: Dependable instruments=0A=0A> I have a UMA asi. It stopped working a couple times. > Vic=0A> 912ul=0A> xtra=0A- =0AHi Vic,=0A-=0A- I took apart a poorly working TSO'd airspeed indicat or once.=0A(I've taken apart two airspeed indicators, and put them back tog ether)=0AIf I remember correctly, there was very slight metal corrosion=0Ao n the internal moving and touching parts.- I carefully cleaned=0Athem up with an electronic parts cleaner product, put on a =0Acouple of tiny drops of mineral oil (really tiny!!!) on the moving=0Aparts where they contact, a nd it worked like a champ!!=0A-=0A- I even took the time to clean the d ial face-real nice, and purdy.- I=0Apolished the glass lens, and put th e whole arrangement back together.=0A-=0A- It was given to me for free. - I sold it for $130 to a guy on eBay.=0AHe installed it immediately afte r getting it, and said it worked=0Aflawlessly for his flight back to Los An geles.=0A-=0A- So, in a nutshell, I'd say you might have some light cor rosion.=0ATake it apart, and look.=0A-=0A- BTW, you'll want a spotless work environment!!- Lay out a clean=0Alight colored towel.- Light color ed so you can see the tiny little screws,=0Awhen you drop them.=0A-=0A- === =0A ________________________________________________________________________________
Date: Jan 25, 2011
Frank, there are those who can and those who shouldn't fly without an ASI. If you are in the former group, you are both a better pilot and better practicing it. In my aeronca I flew more than one season with it inop. -Didn't make any difference. I knew the plane that well. -although comparing it to a Kolb is apples to oranges. The aeronca gave more airspeed feedback via control heaviness than a Kolb. Most of the old taildraggers were the same. Of course there is a big inertia difference between a 800 lb plane and a 1300 lb plane which also has less drag. The only thing I glanced at occasionally was the oil pressure gauge. On 25, Jan 2011, at 12:40 PM, frank goodnight wrote: > All the talk about airspeed indicaters leads to me to ask if I am the only one that routinely practices flying > with out useing the ASI ,take off, landings, slow flight , stalls ,unsual attitudes .especially takeoffs and landings > from differant alt above sea level --35ft to over 6000ft .different aproch speeds , landing uphill- downhill or anythin > else I can think of that will help me to fly the airplane. > Frank Goodnight > > From: Mike Welch <mdnanwelch7(at)hotmail.com> > To: kolb-list(at)matronics.com > Sent: Tue, January 25, 2011 11:18:09 AM > Subject: RE: Kolb-List: Re: Dependable instruments > > > I have a UMA asi. It stopped working a couple times. > Vic > > 912ul > > xtra > > Hi Vic, > > I took apart a poorly working TSO'd airspeed indicator once. > (I've taken apart two airspeed indicators, and put them back together) > If I remember correctly, there was very slight metal corrosion > on the internal moving and touching parts. I carefully cleaned > them up with an electronic parts cleaner product, put on a > couple of tiny drops of mineral oil (really tiny!!!) on the moving > parts where they contact, and it worked like a champ!! > > I even took the time to clean the dial face real nice, and purdy. I > polished the glass lens, and put the whole arrangement back together. > > It was given to me for free. I sold it for $130 to a guy on eBay. > He installed it immediately after getting it, and said it worked > flawlessly for his flight back to Los Angeles. > > So, in a nutshell, I'd say you might have some light corrosion. > Take it apart, and look. > > BTW, you'll want a spotless work environment!! Lay out a clean > light colored towel. Light colored so you can see the tiny little screws, > when you drop them. > > Just a thought.... > > Mike Welch > > > > > ________________________________________________________________________________
Date: Jan 25, 2011
Yes=2C Frank=2C but how many BRAND NEW=2C NEVER FLOWN airplanes=2C with "never proven that they even work" airpeed indicators in them have you flown?? When I take my maiden flight=2C it will be the FIRST time my plane will have ever been in the air. It will also be the FIRST time the airspeed instruments will ever be asked to show a useful reading. No one=2C (NONE) has said anything about needing an airspeed instrument=2C or NOT needing one. The subject has just been about the accuracy of cheaper vs. more expensive ones. When I had my Cessna 172=2C I used to fly all the time not looking at the airspeed indicator. I especially like "super slow flight"=2C where I was practically hanging on the prop=2C and the stall horn 'a blarin'. I've crashed an ultralight once. Hurt so damn bad=2C I can't even face thinking about it. I darn sure don't want to do that again. It was one of the top two injuries in my life!!! Sorry if I sound miffed=2C but you make it seem as if I'm concerned about nothing=2C either that=2C or you didn't catch the point of the discussion. Several of our Kolb friends are not with us anymore. I'd like to NOT join them!! After a person is familiar with their plane=2C sure=2C then they can practi ce lots of flying without an airspeed indicator. But for me=2C I'd rather be over-cautious with my track record of new flights. Mike Welch Date: Tue=2C 25 Jan 2011 09:40:49 -0800 From: frank.goodnight(at)att.net Subject: Re: Kolb-List: Re: Dependable instruments All the talk about airspeed indicaters leads to me to ask if I am the only one that routinely practices flying with out useing the ASI =2Ctake off=2C landings=2C slow flight =2C stalls =2Cunsual attitudes .especially takeoffs and landings from differant alt above sea level --35ft to over 6000ft .different aproch speeds =2C landing uphill- downhill or anythin else I can think of that will help me to fly the airplane. Frank Goodnight From: Mike Welch <mdnanwelch7(at)hotmail.com> Sent: Tue=2C January 25=2C 2011 11:18:09 AM Subject: RE: Kolb-List: Re: Dependable instruments > I have a UMA asi. It stopped working a couple times. > Vic > 912ul > xtra Hi Vic=2C I took apart a poorly working TSO'd airspeed indicator once. (I've taken apart two airspeed indicators=2C and put them back together) If I remember correctly=2C there was very slight metal corrosion on the internal moving and touching parts. I carefully cleaned them up with an electronic parts cleaner product=2C put on a couple of tiny drops of mineral oil (really tiny!!!) on the moving parts where they contact=2C and it worked like a champ!! I even took the time to clean the dial face real nice=2C and purdy. I polished the glass lens=2C and put the whole arrangement back together. It was given to me for free. I sold it for $130 to a guy on eBay. He installed it immediately after getting it=2C and said it worked flawlessly for his flight back to Los Angeles. So=2C in a nutshell=2C I'd say you might have some light corrosion. Take it apart=2C and look. BTW=2C you'll want a spotless work environment!! Lay out a clean light colored towel. Light colored so you can see the tiny little screws =2C when you drop them. Just a thought.... Mike Welch ________________________________________________________________________________
Date: Jan 25, 2011
Hi Mike' sorry if I touched a nerve.Didn't mean to upset anyone. No problem=2C Frank. I would agree if anybody said I was touchy about flying my new Kolb=2C though. I applaud you for your two maiden flight successes. Oh=2C how I dream of that day (and live to brag about it!!) Back when I crashed my U/L=2C it was MY fault. I did not have sufficient or recent training. I do NOT want to make that mistake again! If I were to crash like the last time=2C and I were given the choice of the same pain=2C or death=2C it would be a tough call=2C you can believe me on that one. I think all pilots should be completely familiar with as much of the flight experience as they can be. Practice=2C practice=2C practice. The more practice we have=2C the safer we should be. And safe is always a good thing. Mike W ________________________________________________________________________________
Date: Jan 26, 2011
It will also be the FIRST time the airspeed instruments will ever be asked to show a useful reading.>> Hi Mike, It is a bonus if your ASI reads spot on. Most ASI`s do not. What IS important is that you know where on the dial the needle points when you stall. It really doesn`t matter what the numbers read. If it reads 30, stay above 30. If it reads 40 stay above 40. That should get the feathers flying Cheers Pat ________________________________________________________________________________
Date: Jan 26, 2011
Hi Pat=2C You are absolutely correct=2C and I'm quite aware of that. In fact=2C I stated what you said several times. "Whether it reads 40 or 400" comes to mind. Plus=2C t he "that's the 'magic' number to stay above"! This aspect of an ASI I am well aware of . Thanks I also said I wasn't exactly interested in it being "perfect"=2C but rath er=2C that it works at all. If it consistently reads 6 mph fast...or 8 mph too slow=2C I can live with this information=2C providing it does so across it's entire reading scale. In fact=2C I can say that I understand that it doesn't even need to have ANY numbers on it's maiden flight. Right? I mean=2C what a guy would be looking for i s that exact location on the dial where the needle is when a stall is imminent. It would seem to me that an ASI should be more viewed as a "stall warning indicator"=2C in the early stages of initial flights. The pilot should not be so focused on a number=2C but rather the needle's precise position. A 'slightly off' calibration is very tolerable. An ASI that's reads a co nstant 30 whether you're traveling at 45mph AND also 85mph won't be very useful. My little wind tunnel project was simply to establish that "they worked"=2C nothing more than a b asic proof that little spiders or other creatures hadn't made their homes inside the holes. ....(I didn't really think that=2C I was just kidding=2C they are both brand new=2C and kept in their factory boxes prior to installation) However!! Have you guys ever bought something "brand new".....and it work? I have! !! Years ago=2C I owned an old Datsun pickup. It was running poorly and I c ouldn't figure it out=2C so I called a mobile mechanic. He suggested we change the "points and cond ensor"=2C which we did. But after they were installed=2C the truck would not start!! ! We assumed we had the points off a bit=2C or a milion other ideas we tried. Nothing!! A fter screwing with absolutely everything there is to work on for about 3-4 hours=2C and being certain of everything.....we said let's get another new set of points and consensor (a t a different store). Off to the different store=2C then back home=2C installed the new sets. Turned the key....vrooooom. Ran like a top!!! We spent the biggest part of a day wasted=2C due to a de fective "brand new set" of parts. (the condensor was bad) I just didn't want my airspeed system to be included in that list of unpr oven parts=2C that's all. Mike Welch ________________________________________________________________________________
Date: Jan 26, 2011
List=2C In my previously reply to Pat=2C I asked if everyone had bought something brand new=2C and it worked. Duhh!!! My typo!! I meant "didn't work!!" I had originally said it correctly=2C but then modified it. But after I read it again=2C I reworded it back to what I origanally said=2C but I accidently omitted "didn't". Sorry for the confusion. Mike ________________________________________________________________________________
Subject: Sun and Fun 2011
Date: Jan 26, 2011
Latest dates for Sun and Fun 2011: Sun n Fun March 29, 2011 April 3, 2011 Lakeland Linder Regional Airport in Lakeland, FL 37th Annual SUN n FUN International Fly-In & Expo I am going to try to fly down on Mar 28 or 29. See you all there. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: Sun and Fun 2011
Date: Jan 26, 2011
I'll be there too with the searey...I'll definitely stop by kolb and hang out there for a while...I'll be parked next to the mk3x amphibian again this year Thanks, Daniel Myers Cell: 407 920 7700 On Jan 26, 2011, at 5:32 PM, "John Hauck" wrote: > > Latest dates for Sun and Fun 2011: > > Sun n Fun > March 29, 2011 April 3, 2011 > Lakeland Linder Regional Airport in Lakeland, FL > 37th Annual SUN n FUN International Fly-In & Expo > > > I am going to try to fly down on Mar 28 or 29. > > See you all there. > > john h > mkIII > Titus, Alabama > > > > > > > ________________________________________________________________________________
Date: Jan 27, 2011
Subject: test
=0A=0ATest--------I- think my e-mail is broke.=0AFrank=0A=0Ado not arch ive ________________________________________________________________________________
Subject: Firestar to MK III C transition.
Date: Jan 27, 2011
To all Please give me in the simplest form the major differences between the Firestar I and a MK3C. I have sold my Firestar KX to a fellow in TX and I am buying the MK3C owned by Keith Anderson in Oregon. I intend to get my SP rating and I have an instructor lined up. I have 100+ hours in an Ultrastar and 100+ hours in the Firestar all within the last 2 years. I have been reading the old posts and I am looking for the most important tips you all have for me on this transition. I know I will have to learn the 912 80hp engine but I have plenty of local help for that. Thanks Dennis Long in W. TN. Moving on up. -------- Dennis Long Oakland TN 1990 Kolb Firestar KX 80+ hours since June Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328729#328729 Attachments: http://forums.matronics.com//files/100_3297_191.jpg http://forums.matronics.com//files/plane_kolb_065_136.jpg ________________________________________________________________________________
From: "Larry Cottrell" <lcottrell1020(at)gmail.com>
Subject: Re: Firestar to MK III C transition.
Date: Jan 27, 2011
To all Please give me in the simplest form the major differences between the Firestar I and a MK3C. I have sold my Firestar KX to a fellow in TX and I am buying the MK3C owned by Keith Anderson in Oregon. I am familiar with Keith's plane, and own a Firestar II and have owned a Mark III. If you can fly a Firestar, you shouldn't have any trouble with the Mark III. Its bigger, should be faster, land pretty much the same if not a bit slower, carry more weight. The comparison that I would make is that you are trading a sports car for a van, but you will have more range and can carry more stuff. Should be no problem for you. Larry Oregon Note: If you forward this email, please delete the forwarding history, which includes my email address. ________________________________________________________________________________
Date: Jan 27, 2011
The comparison that I would make is that you are trading a sports car for a van, but you will have more range and can carry more stuff. Should be no problem for you. Larry Larry C/Gang: I agree with Larry. If you can fly one model Kolb, you can fly them all. Since Larry hurt my feelings referring to MKIII's at "vans", I will have to fly circles around him next June, if I can make it back to the Rock House. ;-) Sitting here getting antsier waiting on warm weather and some cross country flying. Last cross country was Sun and Fun 2010. john h MKIII Titus, Alabama ________________________________________________________________________________
Date: Jan 27, 2011
Since Larry hurt my feelings referring to MKIII's at "vans", I will have to fly circles around him next June, if I can make it back to the Rock House. ;-) Works for me. Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ________________________________________________________________________________
Date: Jan 27, 2011
In a message dated 1/27/2011 3:42:00 P.M. Eastern Standard Time, lcottrell1020(at)gmail.com writes: To all Please give me in the simplest form the major differences between the Firestar I and a MK3C. I have sold my Firestar KX to a fellow in TX and I am buying the MK3C owned by Keith Anderson in Oregon. My experience flying Kolb's started with some dual in a MK lll to give me some idea how a Kolb was to fly, I then purchased a Kolb firestar ll and have put a lot of hours on it and enjoy it. I had as with every airplane to get used to some things. This last summer I put a lot of time in a MK lll C and found it to be the same airplane as far as traits as the Firestar. It is a good airplane and you will enjoy it. You need to get used to it, I would suggest spending time just setting in it to become familiar with were things are, spend some time taxing, become familiar with the required speeds, in other words the things you would do when flying any different airplane....I would not fool with the flaps until I had got somewhat used to the plane. I would use no flaps on take off and when I was used to flying the plane then I would deploy the flaps at proper airspeed and with some altitude to get used to them, I would also suggest that upon the lst flight to go up to a safe altitude and do some stalls to find out where the indicated airspeed stall is . I am sure I have repeated a lot of things you already know but it is always good to be reminded. The most important thing is to always fly the airplane', don't let it fly you.... Jim Swan up in cold and snowy Michigan Do not archive FIRESTAR ll 503 Michigan jswan GPS FOR MY RUNWAY N 42 deg 28.581 W084deg 44.825 ph. 517-663-8488 ________________________________________________________________________________
Date: Jan 27, 2011
I feel the need for a bit of a disclaimer here. The plane that he is buying has a 80 horse 912 on it and if he is getting the whole package, ( trailer and goodies) is getting a good deal. The plane will fly faster than his Firestar, I would expect the cruise to be about 75 to 80 true airspeed, and the 912 is pretty easy on fuel. The Mark III that I had was powered by a 582 and sucked gas. That by the way was the only reason that I got rid of it. Didn't think I could afford a 912. If it had flown like John's Pfer I sure would have kept it. ( Now are you happy, old man?) I am quite sure that you will like the plane and get a lot of enjoyment out of it. If your path goes any where close to here you are welcome to stop by for the night. Klamath Falls is about 6 hours ( 330 miles) from here. 42 40.919 N 117 51 198 W Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ________________________________________________________________________________
Date: Jan 28, 2011
"If you can fly one model Kolb, you can fly them all.... john h " The following does not really apply to the original question but I just couldn't let the above statement go by without comment. I agree that if you can FLY one Kolb you can FLY them all, but landing and take-off on pavement in a Slingshot is a different story. It is not hard to learn but it is not really much like the short leg Kolbs; more like a traditional tail dragger with excellent visibility. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328813#328813 ________________________________________________________________________________
Date: Jan 28, 2011
elleryweld(at)aol.com wrote: > > The firestar Held 10 Gallons of fuel and would sip 2.7 GPH > The MK3C Holds 20 Gallons of Fuel and Gulps 6.+ GPH > Ellery Batchelder Jr. > -- What kind of engine were you using that burns more than 6 GPH? My 582 burns less than 4 unless I am running it wide open. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328815#328815 ________________________________________________________________________________
Date: Jan 28, 2011
when trying to keep up with everyone else I fly with the 582 is to thirsty for my budget at a much reduced power setting when I am flying alone it will burn a bit above 4 but it will take you all day to get there it seems Ellery Batchelder Jr. -----Original Message----- From: Richard Pike <richard(at)bcchapel.org> Sent: Fri, Jan 28, 2011 8:25 am Subject: Kolb-List: Re: Firestar to MK III C transition. lleryweld(at)aol.com wrote: The firestar Held 10 Gallons of fuel and would sip 2.7 GPH=C3=AF=C2 =C2=BD The MK3C Holds 20 Gallons of Fuel and Gulps 6.+ GPH Ellery Batchelder Jr. -- hat kind of engine were you using that burns more than 6 GPH? My 582 burns less han 4 unless I am running it wide open. Richard Pike KIII N420P (420ldPoops) ead this topic online here: http://forums.matronics.com/viewtopic.php?p=328815#328815 ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jan 28, 2011
What kind of engine were you using that burns more than 6 GPH? My 582 burns less than 4 unless I am running it wide open. Richard Pike Richard P/Gang: Fuel consumption is based on how the MKIII is flown. Most 582's on MKIII's burn 5 gph. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 28, 2011
Forgot to include the rpm in my previous msg. Fuel consumption is based on how the MKIII is flown. Most 582's on MKIII's burn 5 gph at 5800. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 28, 2011
From: "Kirby, Dennis Civ USAF AFMC AFNWC/EN" <Dennis.Kirby(at)kirtland.af.mil>
<< Please give me in the simplest form the major differences between the Firestar I and a MK3C. Thanks - Dennis Long in W. TN. >> Dennis L. - >From the picture you posed, it looks like a very nicely-built M3-classic. You should have many hours of fun, reliable flying in your future! I was intrigued with the small fairing installed between the gap seal and the windshield top. I too, would like to have such a fairing for my Mark-3, but the Kolb factory does not manufacture these. The one on your airplane is likely homemade, by the builder. Is it a fiberglass fairing? From the picture, it looks like it is attached only to the leading edge of the gap seal - true? Just trying to get ideas, for when I fabricate my own. Many thanks - Dennis Kirby Mark-III, 912ul, in Sandia Park, NM ________________________________________________________________________________
Date: Jan 28, 2011
Subject: Re: Fwd: Check out these flying skills
At 04:30 PM 1/28/2011, russ kinne wrote: >Don't know if this has hit the List previously, but it's an awesome >example of complete control. I'm especially impressed with the knife-edge >flight; the fuselage is flat, but the rudder is small; very little area to >produce lift. >Doubt if a Kolb could come close to these maneuvers, and I hope no one >ever tries. But has anyone ever rolled a Kolb? Done any (deliberate) >unusual-attitude flying? >I'm NOT suggesting anyone tries! Many people have looped and rolled Kolbs. Of course with a model like in your video, with the insane power to weight ratio and absurdly low Reynolds numbers, and no pilot to endure the g-loading, you can get away with a lot more. -Dana -- As I learn the innermost secrets of the people around me, they reward me in many ways to keep me quiet. ________________________________________________________________________________
Date: Jan 28, 2011
Subject: Check out these flying skills
Hi All, Back in the early 80`s I watched John H. do hammer head stalls in his Firestar. It was at the flight farm in Horsehead NY. I was flying my brand new to the market Paraplane. My first step toward flying a Kolb. The Paraplane was first marketed by Steve Snyder. Steve was a very smart and very nice man. I watched him do two snap rolls in his jet about 50 feet above the runway, the day I purchased my Paraplane. Unfortunately, he was killed in that same jet, a few years after Introducing the Paraplane to the market. I`m not sure what happened, it was his private jet. I was told he had a flame out at low altitude. A real shame, as I think he would have contributed so much more to the world of aviation, if he hadn`t been killed. Lanny N598LF ________________________________________________________________________________
Date: Jan 28, 2011
Subject: BFR
Hi All,=0AJust finished my BFR a few minutes ago--Yes, I passed ,just barel y-I think----we =0Aused a 172.=0A-This is the first time in 2&1/2 years I have flown anything other than my =0Afirestar. It amazed me how much I t ook =0A=0Athe kolbs preformance for granted. The 172 was very smooth &-di d everything I =0Aasked it to,but for want of a better=0Aword felt numb sor t of-like your mouth does after a shot of novocain. The Kolb =0Aon the ot her hand feels almost alive=0Avery responsive,and quick, even with its heav y alerons eager to go places and do =0Astuff. I fell bad that I have taken =0Afor granted the extreamly pleasant experince of flying my airplane , som etimes =0Ato the point of being bored.=0AI-plan to pay more attention in the future.=0A-Everone Have Fun , Enjoy , and stay safe=0AFrank-- ________________________________________________________________________________
Subject: Re: BFR
Date: Jan 28, 2011
Ever since my ppl When I turned 17 I have only flown my firestar and searey until the other day. I grew up flying maule float planes and hopped in one for the 1st time in years. The first flew landings were terrible at best. Amazing how these planes change the way you fly!!! Thanks=2C Daniel Myers Cell: 407 920 7700 21 Years old-200hrs in fs2 and mk3/mark extra. 500 in searey On Jan 28=2C 2011=2C at 7:25 PM=2C frank goodnight wrote: > Hi All=2C > Just finished my BFR a few minutes ago--Yes=2C I passed =2Cjust barely I think----we used a 172. > This is the first time in 2&1/2 years I have flown anything other than m y firestar. It amazed me how much I took > the kolbs preformance for granted. The 172 was very smooth & did everythi ng I asked it to=2Cbut for want of a better > word felt numb sort of like your mouth does after a shot of novocain. The Kolb on the other hand feels almost alive > very responsive=2Cand quick=2C even with its heavy alerons eager to go pl aces and do stuff. I fell bad that I have taken > for granted the extreamly pleasant experince of flying my airplane =2C so metimes to the point of being bored. > I plan to pay more attention in the future. > Everone Have Fun =2C Enjoy =2C and stay safe > Frank > > =========== =========== =========== =========== > ________________________________________________________________________________
Subject: BFR
Date: Jan 28, 2011
>Amazing how these planes change the way you fly!!! >Thanks=2C >Daniel Myers Daniel=2C Change the way you fly?? Could you elaborate? I'm curious what you mean=2C since I've never neen a (running) Kolb. So far=2C 99% of my flying experience has been my own 172's=2C and about 15-20 hours of Quicksilver II=2C dual=2C never soloed. Mike Welch MkIII CX ________________________________________________________________________________
Subject: BFR
Date: Jan 28, 2011
Typo again! I meant "been in" a running Kolb=2C I've never been in a running Kolb. In other words....what's it like=2C especially compared to a 172? Thanks=2C Mike From: mdnanwelch7(at)hotmail.com Subject: RE: Kolb-List: BFR Date: Fri=2C 28 Jan 2011 17:03:46 -0800 >Amazing how these planes change the way you fly!!! >Thanks=2C >Daniel Myers Daniel=2C Change the way you fly?? Could you elaborate? I'm curious what you mean=2C since I've never neen a (running) Kolb. So far=2C 99% of my flying experience has been my own 172's=2C and about 15-20 hours of Quicksilver II=2C dual=2C never soloed. Mike Welch MkIII CX ________________________________________________________________________________
Date: Jan 28, 2011
I bought a Sears Craftsman Trade name Rotary grinder, it may be a Dremel or Dremel look alike over 10 years ago. I use it often. So far it has held up well. I see no sign of it giving up the ghost. ============================== ---- Mike Welch wrote: ============ Hi Rick, The disks that I was referring to were fragile, unreinforced kind. If you breathed on them hard, they broke!! Pretty near useless, IMO, unless you were cutting balsa wood....slowly!! The 'much better' ones I was referring to are the fiber reinforced ones. I generally got lots of mileage out of these....that is, unless I bumped them sideways, or layed the tool down too hard. I have bent in half dozens of these. Yes, they do have the rediculously little 1/16" hole!! I haven't seen the new cut-off discs you're referring to. I'll make it a point to check them out. As I previously stated, I really liked the Ryobi rotary tool. But, I'm open to recommendations regarding the Dremel. Does anyone have a "preferred model" they like.....and why? Mike Welch -- kugelair.com ________________________________________________________________________________
Date: Jan 28, 2011
Talking about instruments. I had to convert to a mode S trnspndr FAA requirement for me. Anyway I have available for sale a mode C trnsponder including the mode C encoder. The stuff works when I removed it. I thought I am going to use it on my M3X, but I rather have the money. If anyone wants to buy it contact me offline and make an offer. Ron @ KFHU ===================== ---- Vic Peters wrote: ============ Anyone I have a UMA asi. It stopped working a couple times. 1st I thought it was the air flow pitot cover. Not. Started woking during climb. 2nd time I hit ET (gauge cluster) on the head and it worked. What should I look for besides a new one? Vic 912ul xtra -------- Vic 912ul Xtra Maine Too old to cut the mustard but not the cheese. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328430#328430 -- kugelair.com ________________________________________________________________________________
Subject: Re: BFR
Date: Jan 28, 2011
I meant "been in" a running Kolb, I've never been in a running Kolb. In other words....what's it like, especially compared to a 172? Thanks, Mike There is no comparison between flying a Kolb and a 172. Kolbs make one free and alive. Kolbs do things spam cans can not do. Kolbs are an adventure. john h Kolb builder/pilot Titus, Alabama ________________________________________________________________________________
Date: Jan 28, 2011
That damned Pterodactyl I flew a while ago had no gauges at all, not even a one. I bought an ASI the plastic tube one to feel fancy in the last couple of flights. Really don't need gauges, its easy to sense when you ain't feeling no wind and the nose points down. Flew the Sierra that way too a couple of times back when I used a tennis ball for pitot tube cover. No big deal either. It does not take long to get the feel for it, like 30 seconds. ============ Yes, Frank, but how many BRAND NEW, NEVER FLOWN airplanes, with "never proven that they even work" airpeed indicators in them have you flown?? When I take my maiden flight, it will be the FIRST time my plane will have ever been in the air. It will also be the FIRST time the airspeed instruments will ever be asked to show a useful reading. No one, (NONE) has said anything about needing an airspeed instrument, or NOT needing one. The subject has just been about the accuracy of cheaper vs. more expensive ones. When I had my Cessna 172, I used to fly all the time not looking at the airspeed indicator. I especially like "super slow flight", where I was practically hanging on the prop, and the stall horn 'a blarin'. I've crashed an ultralight once. Hurt so damn bad, I can't even face thinking about it. I darn sure don't want to do that again. It was one of the top two injuries in my life!!! Sorry if I sound miffed, but you make it seem as if I'm concerned about nothing, either that, or you didn't catch the point of the discussion. Several of our Kolb friends are not with us anymore. I'd like to NOT join them!! After a person is familiar with their plane, sure, then they can practice lots of flying without an airspeed indicator. But for me, I'd rather be over-cautious with my track record of new flights. Mike Welch Date: Tue, 25 Jan 2011 09:40:49 -0800 From: frank.goodnight(at)att.net Subject: Re: Kolb-List: Re: Dependable instruments All the talk about airspeed indicaters leads to me to ask if I am the only one that routinely practices flying with out useing the ASI ,take off, landings, slow flight , stalls ,unsual attitudes .especially takeoffs and landings from differant alt above sea level --35ft to over 6000ft .different aproch speeds , landing uphill- downhill or anythin else I can think of that will help me to fly the airplane. Frank Goodnight From: Mike Welch <mdnanwelch7(at)hotmail.com> Sent: Tue, January 25, 2011 11:18:09 AM Subject: RE: Kolb-List: Re: Dependable instruments > I have a UMA asi. It stopped working a couple times. > Vic > 912ul > xtra Hi Vic, I took apart a poorly working TSO'd airspeed indicator once. (I've taken apart two airspeed indicators, and put them back together) If I remember correctly, there was very slight metal corrosion on the internal moving and touching parts. I carefully cleaned them up with an electronic parts cleaner product, put on a couple of tiny drops of mineral oil (really tiny!!!) on the moving parts where they contact, and it worked like a champ!! I even took the time to clean the dial face real nice, and purdy. I polished the glass lens, and put the whole arrangement back together. It was given to me for free. I sold it for $130 to a guy on eBay. He installed it immediately after getting it, and said it worked flawlessly for his flight back to Los Angeles. So, in a nutshell, I'd say you might have some light corrosion. Take it apart, and look. BTW, you'll want a spotless work environment!! Lay out a clean light colored towel. Light colored so you can see the tiny little screws, when you drop them. Just a thought.... Mike Welch -- kugelair.com ________________________________________________________________________________
Date: Jan 28, 2011
John Hauck wrote: > Forgot to include the rpm in my previous msg. > > Fuel consumption is based on how the MKIII is flown. Most 582's on MKIII's > burn 5 gph at 5800. > > john h > mkIII > Titus, Alabama I guess that explains why I never go anywhere, 5800 is above my comfort zone. I would rather roll with the punches than fight back. Have to be content with looking at the pictures the rest of you take. So keep taking those pictures & post them. (But not at full size, please) Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328881#328881 ________________________________________________________________________________
Subject: Re: BFR
Date: Jan 29, 2011
Beauford, come to think of it, sounds a lot my first wife. Your first one must have been a hoot! Anybody know how to compare a 172 to a Kolb? I don't. john h mkIII Titus, Alabama .....except for the alimony part, you have come very close to describing my first wife.... Crazy Louise... beauford FF-076 Brandon, FL ________________________________________________________________________________
Subject: Re: BFR
Date: Jan 29, 2011
John, You are comparing a full size Buick sedan to a rag top MG TD. PCKing ----- Original Message ----- From: John Hauck To: kolb-list(at)matronics.com Sent: Saturday, January 29, 2011 10:38 AM Subject: Re: Kolb-List: BFR Beauford, come to think of it, sounds a lot my first wife. Your first one must have been a hoot! Anybody know how to compare a 172 to a Kolb? I don't. john h mkIII Titus, Alabama .....except for the alimony part, you have come very close to describing my first wife.... Crazy Louise... beauford FF-076 Brandon, FL ________________________________________________________________________________
Subject: Re: BFR
Date: Jan 29, 2011
Close, but I would prefer an analogy to a VW bug. MG TDs had a reliability problem. The 172 is a fine airplane but these days cost a bunch to own and fly. -besides needing WAY too much runway. What always perplexed me were the guys who would sign one out at the local FBO to fly SOLO on saturday morning.??? 150s were cheaper and did the same thing. An 85 hp 140 will run right alongside a 172 and consume much less fuel. I guess some guys just like to cruise down the expressway in a Buick. BB (I only had a first wife. There isn't any replacement) On 29, Jan 2011, at 10:50 AM, PCKing wrote: > > John, > > You are comparing a full size Buick sedan to a rag top MG TD. > > PCKing > > ----- Original Message ----- > From: John Hauck > To: kolb-list(at)matronics.com > Sent: Saturday, January 29, 2011 10:38 AM > Subject: Re: Kolb-List: BFR > > > Beauford, come to think of it, sounds a lot my first wife. > > Your first one must have been a hoot! > > Anybody know how to compare a 172 to a Kolb? I don't. > > john h > mkIII > Titus, Alabama > > > .....except for the alimony part, you have come very close to describing my > first wife.... Crazy Louise... > > beauford > FF-076 > Brandon, p; Navigator Photoshare, and href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronicp ; via the Web href="http://forums.matronics.com">http://forums.matronics.com > _p; generous bsp; href="http://www.matronics.com/contribution">http://www.matronics.com/c= =============== > > > > > > ________________________________________________________________________________
Date: Jan 29, 2011
Subject: Re: BFR
Hi Robert,=0AI like your analogy- of the VW to the Buick ,-Both have th ier place, and will =0Aboth get you where are going.=0AYou would probally h ave a better chance of haveing fun in the vw.=0A- Same with the kolb,-o n any trip ,lots-more opportunitys for fun.=0AI have regained my-apprec iation for the flying qualities of the firestar2. And =0Ahope not to take -it for granted again.=0AFrank=0A=0A=0A=0A=0A____________________________ ____=0AFrom: robert bean <slyck(at)frontiernet.net>=0ATo: kolb-list(at)matronics. com=0ASent: Sat, January 29, 2011 10:46:35 AM=0ASubject: Re: Kolb-List: BFR =0A=0AClose, but I would prefer an analogy to a VW bug. -MG TDs had a rel iability =0Aproblem. =0A=0A=0AThe 172 is a fine airplane but these days cos t a bunch to own and fly. --besides =0Aneeding WAY too much runway.=0AWha t always perplexed me were the guys who would sign one out at the local FBO =0Ato fly SOLO on saturday morning.???=0A150s were cheaper and did the sam e thing. -An 85 hp 140 will run right alongside =0Aa 172 and consume much less fuel.=0A=0AI guess some guys just like to cruise down the expressway in a Buick.=0ABB=0A(I only had a first wife. -There isn't any replacement )=0A=0AOn 29, Jan 2011, at 10:50 AM, PCKing wrote:=0A=0A-=0A>John,=0A>- =0A>You are comparing a full size Buick sedan to a rag top MG TD.=0A>-=0A >PCKing-=0A>-=0A>----- Original Message -----=0A>>From:-John Hauck=0A >>To:-kolb-list(at)matronics.com=0A>>Sent:-Saturday, January 29, 2011 10:3 8 AM=0A>>Subject:-Re: Kolb-List: BFR=0A>>=0A>>--> Kolb-List message poste d by: "John Hauck" =0A>>=0A>>Beauford, come to think of it, sounds a lot my first wife.=0A>>=0A>>Your first one must have been a hoot!=0A>>=0A>>Anybody know how to compare a 172 to a Kolb?- I don't.=0A >>=0A>>john h=0A>>mkIII=0A>>Titus, Alabama=0A>>=0A>>=0A>>-.....except for the alimony part, you have come very close to describing my=0A>>first wife ....-- Crazy Louise...=0A>>=0A>>-beauford=0A>>FF-076=0A>>Brandon, p; -------- Navigator Photoshare, and =0A>>href="http://www. matronics.com/Navigator?Kolb-List">http://www.matronicp;--- via =0A>> the Web href="http://forums.matronics.com">http://forums.matronics.com=0A >>_p;-------- generous bsp;---------- --------- =0A>>href="http://www.matronics.com/contribut ion">http://www.matronics.com/c============== ====0A>>=0A>>=0A>>=0A>>=0A =0Ahref="http://www.matronics.com/Navig ator?Kolb-List">http://www.matronics.com/Navigator?Kolb-Listhref="http:// forums.matronics.com">http://forums.matronics.com=0Ahref="http://www.matr onics.com/contribution">http://www.matronics.com/contribution=0An =0A=0A> ============== =0A ________________________________________________________________________________
Date: Jan 29, 2011
[quote="lcottrell"]The comparison that I would make is that you are trading a sports car for a van, but you will have more range and can carry more stuff. Larry Oregon > [b] Having owned a MKIII since 1995 and having a FSII in the hangar next to me since 2005 (which I could fly whenever I wanted,) let me weigh in on this. If you leave the aileron bellcrank which connects to the aileron pushrods the standard distance between the two pushrod bolt holes, then I would agree with you, and would also add that both of them require heavy stick forces to extract maximum agility. If you reduce the distance between the bolt holes to improve your stick leverage on both airplanes, then the FSII simply becomes a lot less labor intensive to fly, and the MKIII becomes not only less labor intensive, but a lot more agile in the process. This might seem a bit counter-intuitive, nonetheless that is how it works, probably because none of us is likely to try and get serious agility out of an airplane when it seems like it takes "too much muscle" to do it. Modified you have a situation where the FSII handles like a smaller sports car, and the MKIII like a well designed sports sedan with all the handling options. Plus room for sweet thing & a picnic lunch... MKIII aileron mod: http://www.bcchapel.org/pages/0003/pg7.htm FSII aileron mod: http://www.bcchapel.org/pages/0003/FSII%20ailerons.html Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328936#328936 ________________________________________________________________________________
Date: Jan 30, 2011
Subject: FSII
I have just purchased a firestar two in flying condition after working on one in my basement for 15 years. I realized I would never finish it before I got too old. It is as much fun to fly as I have imagined, particularly after adding the vortex generators. my 503 has a clutch in the C gearbox and a three bladed warp drive prop. As you know this allows the prop to freewheel when gliding and adds a lot of drag. also if it ever quit on me in flight an air restart would be impossible. are the advantages of the easier start and smoother idle worth the tradeoff? Thanks, ________________________________________________________________________________
Subject: Re: FSII
Date: Jan 30, 2011
If you are expecting the air to turn your prop fast enough to restart, it won't do that with or without a clutch, but you can add a starter and start it anywhere. Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ________________________________________________________________________________
Date: Jan 31, 2011
Subject: Re: FSII
Mike, I voted with my feet, as they say. The first major work I did on my engine / drive when I got home from Rotax school was to get that rice king clutch out. Some like them, I don't. Rick Girard On Sun, Jan 30, 2011 at 9:03 PM, Mike Hale wrote: > I have just purchased a firestar two in flying > condition after working on one in my basement for 15 years. I realized I > would > never finish it before I got too old. > It is as much fun to fly as I have imagined, particularly after adding the > > vortex generators. > > my 503 has a clutch in the C gearbox and a three bladed warp drive > prop. As you know this allows the prop to freewheel when gliding and adds > a lot > of drag. also if it ever quit on me in flight an air restart would be > impossible. > are the advantages of the easier start and smoother idle worth the > tradeoff? > Thanks, > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jan 31, 2011
Subject: Re: FSII
I'm not sure what voting with my feet means??? >From a engine/drive line stand point the clutch does a lot of good things. Assuming that the clutch is reliable the reduced stress on the airframe, engine crank shaft, reduction drive, prop, prop bolts, etc. etc. there should be a big gain on over all reliability. As for increased drag: If I want to land and stop short this might be good. If you land on black top you could actually slow down without heavy braking action. I had a reduction drive failure a few years back that allowed my three bladed F Model PowerFin prop to free wheel. During the excitement of the uneventful forced landing I didn't notice any increased drag but again I was busy. As always worth what you paid for it Rick Neilsen Redrive VW Powered MKIIIC Back from Panama & Costa Rica On Mon, Jan 31, 2011 at 7:27 AM, Richard Girard wrote: > Mike, I voted with my feet, as they say. The first major work I did on my > engine / drive when I got home from Rotax school was to get that rice king > clutch out. > Some like them, I don't. > > Rick Girard > > On Sun, Jan 30, 2011 at 9:03 PM, Mike Hale wrote: > >> I have just purchased a firestar two in flying >> condition after working on one in my basement for 15 years. I realized I >> would >> never finish it before I got too old. >> It is as much fun to fly as I have imagined, particularly after adding the >> >> vortex generators. >> >> my 503 has a clutch in the C gearbox and a three bladed warp drive >> prop. As you know this allows the prop to freewheel when gliding and adds >> a lot >> of drag. also if it ever quit on me in flight an air restart would be >> impossible. >> are the advantages of the easier start and smoother idle worth the >> tradeoff? >> Thanks, >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhappy. > - Groucho Marx > > > * > > * > > ________________________________________________________________________________
Date: Jan 31, 2011
Subject: Re: FSII
Rick, Take it as putting my money where my mouth is. Experience and reporting on the effect of the clutch seems to be dependent on one's feelings for it. I didn't like it. I've landed my Mk IIIC engine out with the prop stopped and with the prop freewheeling and the clutch reduced the glide by half. Rick On Mon, Jan 31, 2011 at 11:59 AM, Rick Neilsen wrote: > I'm not sure what voting with my feet means??? > > From a engine/drive line stand point the clutch does a lot of good things. > Assuming that the clutch is reliable the reduced stress on the airframe, > engine crank shaft, reduction drive, prop, prop bolts, etc. etc. there > should be a big gain on over all reliability. > > As for increased drag: If I want to land and stop short this might be good. > If you land on black top you could actually slow down without heavy braking > action. I had a reduction drive failure a few years back that allowed my > three bladed F Model PowerFin prop to free wheel. During the excitement of > the uneventful forced landing I didn't notice any increased drag but again I > was busy. > > As always worth what you paid for it > > Rick Neilsen > Redrive VW Powered MKIIIC > Back from Panama & Costa Rica > > On Mon, Jan 31, 2011 at 7:27 AM, Richard Girard wrote: > >> Mike, I voted with my feet, as they say. The first major work I did on my >> engine / drive when I got home from Rotax school was to get that rice king >> clutch out. >> Some like them, I don't. >> >> Rick Girard >> >> On Sun, Jan 30, 2011 at 9:03 PM, Mike Hale wrote: >> >>> I have just purchased a firestar two in flying >>> condition after working on one in my basement for 15 years. I realized I >>> would >>> never finish it before I got too old. >>> It is as much fun to fly as I have imagined, particularly after adding >>> the >>> vortex generators. >>> >>> my 503 has a clutch in the C gearbox and a three bladed warp drive >>> prop. As you know this allows the prop to freewheel when gliding and >>> adds a lot >>> of drag. also if it ever quit on me in flight an air restart would be >>> impossible. >>> are the advantages of the easier start and smoother idle worth the >>> tradeoff? >>> Thanks, >>> >>> * >>> >>> get="_blank">http://www.matronics.com/Navigator?Kolb-List >>> tp://forums.matronics.com >>> _blank">http://www.matronics.com/contribution >>> * >>> >>> >> >> >> -- >> Zulu Delta >> Mk IIIC >> Thanks, Homer GBYM >> >> It isn't necessary to have relatives in Kansas City in order to be >> unhappy. >> - Groucho Marx >> >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> ttp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Re: FSII
Date: Jan 31, 2011
Rick, Take it as putting my money where my mouth is. Experience and reporting on the effect of the clutch seems to be dependent on one's feelings for it. I didn't like it. I've landed my Mk IIIC engine out with the prop stopped and with the prop freewheeling and the clutch reduced the glide by half. As I understood the mans question- it was concerning restarting his engine by diving to build up airspeed to turn the prop fast enough to restart. I am not sure what that speed would be, but I am sure it is past VNE. In other words, it isn't gonna happen. Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ________________________________________________________________________________
Subject: bad news good news
Date: Jan 31, 2011
Bad news is there's one less Kolb out there. Good news is the pilot survived to fly again. Ron M. owner of 57 Alpha Cafe at Rutherford Co. Airport (KFQD) crashed his Mark III yesterday. Plane is totaled but Ron escaped with a broken leg and serious cuts. Reports I've read say it's a miracle he survived. I moved to the area recently and Ron and I had talked about flying together when the weather got better and he could take the time. Oh well. KT Mark III, NC http://www.57alpha.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329149#329149 ________________________________________________________________________________
Subject: Re: bad news good news
Date: Jan 31, 2011
Hello, I am glad he's, relatively speaking,ok.... does anyone know how or why this happened ? chris ambrose M3X/Jabiru n327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329156#329156 ________________________________________________________________________________
Date: Jan 31, 2011
I don't know any details for sure. I'll try to report when I see him again. The FAA was called but said since it was a "light-weight"??? aircraft, they would not investigate. I should be so lucky if something like this happened to me. KT Mark III, NC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329161#329161 ________________________________________________________________________________
Date: Feb 01, 2011
At 12:32 AM 2/1/2011, ktnc420 wrote: >The FAA was called but said since it was a "light-weight"??? aircraft, >they would not investigate. I should be so lucky if something like this >happened to me. I am sure the FAA will investigate. More likely, somebody called it an ultralight, so the reporter called the FAA about an "ultralight crash" and the FAA would naturally say, "we don't investigate ultralight crashes." When they learn that it was a certificated aircraft they will look into it. -Dana -- Place a half full glass of water before a pessimist, optimist and an engineer: The pessimist says the glass is half empty. The optimist says the glass if half full. The engineer says the glass is larger than it needs to be. ________________________________________________________________________________
Date: Feb 01, 2011
I am sure the FAA will investigate. More likely, somebody called it an ultralight, so the reporter called the FAA about an "ultralight crash" and the FAA would naturally say, "we don't investigate ultralight crashes." When they learn that it was a certificated aircraft they will look into it. -Dana IDENTIFICATION Regis#: 457A Make/Model: EXP Description: KOLB MARK III Date: 01/30/2011 Time: 2000 Event Type: Incident Highest Injury: None Mid Air: N Missing: N Damage: Unknown LOCATION City: RUTHERFORDTON State: NC Country: US DESCRIPTION AIRCRAFT CRASHED UNDER UNKNOWN CIRCUMSTANCES, RUTHERFORDTON, NC ________________________________________________________________________________
Subject: 503 clutch
Date: Feb 01, 2011
Thanks fellows for the info Looks like an air restart is out as the prop will stop turning if the engine quits in flight? Right? So I would need an electric starter. However double the glide would be very handy as my plane drops like a rock How bad is the vibration at idle? I have no relatives in Kansas City but I was born there. Mike in Seattle Sent from my iPhone Cell 206-963-2118 ________________________________________________________________________________
Date: Feb 01, 2011
Subject: Re: 503 clutch
Mike, I lived in the Seattle area for 28 years. Lovely place to fly when the sun is out. The "C" gearbox on my 582 has 4.00 to 1 gears and when the engine stopped so did the prop. I can't say if the 2.62 or 3.00 gear set would make a difference, but I doubt it. Even though my 582 has an electric start, I restrung the pull starter so I could pull it from the cockpit (the Mk III has a pulley bracket to redirect the rope and a loop to hold the handle built in so it was easy. Should be a relatively easy project to adapt to the FS II. Where do you fly out of, Arlington? Rick On Tue, Feb 1, 2011 at 10:28 AM, Hales West wrote: > > Thanks fellows for the info > Looks like an air restart is out as the prop will stop turning if the > engine quits in flight? Right? So I would need an electric starter. > However double the glide would be very handy as my plane drops like a rock > How bad is the vibration at idle? > I have no relatives in Kansas City but I was born there. > Mike in Seattle > > Sent from my iPhone > Cell 206-963-2118 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Feb 01, 2011
Glad the man is okay. What kind of motor did he have in there. Too many Kolb crushes in the past few years. Has anyone tried to compile Kolbs V/s say a Challenger in terms of accident stats? I think the Kolb is good stats wise just that we here keep track pretty well of anything Kolb related. But still I would be interested in the stats if anyone ever compiled them. Ron @ KFHU ============================ ---- ktnc420 wrote: ============ Bad news is there's one less Kolb out there. Good news is the pilot survived to fly again. Ron M. owner of 57 Alpha Cafe at Rutherford Co. Airport (KFQD) crashed his Mark III yesterday. Plane is totaled but Ron escaped with a broken leg and serious cuts. Reports I've read say it's a miracle he survived. I moved to the area recently and Ron and I had talked about flying together when the weather got better and he could take the time. Oh well. KT Mark III, NC http://www.57alpha.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329149#329149 -- kugelair.com ________________________________________________________________________________
Date: Feb 01, 2011
Good point! Well, the first thing I would say to any Samaritan if I can say anything is " my *ultralight* lost power even if a frigging wing came off". The last thing I want is some guy from a FSDO adding to my misery, which they will. ---- ktnc420 wrote: ============ I don't know any details for sure. I'll try to report when I see him again. The FAA was called but said since it was a "light-weight"??? aircraft, they would not investigate. I should be so lucky if something like this happened to me. KT Mark III, NC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329161#329161 -- kugelair.com ________________________________________________________________________________
Date: Feb 01, 2011
At 11:28 AM 2/1/2011, Hales West wrote: > >Thanks fellows for the info >Looks like an air restart is out as the prop will stop turning if the >engine quits in flight? Right? So I would need an electric starter. If the starter rope is routed right, you may be able to pull start it from the seat (I can on my UltraStar). -Dana -- I'm as confused as a baby in a topless bar. ________________________________________________________________________________
Date: Feb 01, 2011
> IDENTIFICATION > Regis#: 457A Make/Model: EXP Description: KOLB MARK III Ron=2C I was curious what particular model the MkIII was (for no particular reason other than I was just curious). According to the FAA registration records=2C the MFR year (manufacture date) is listed as '1991'. I guess this may be the year the kit was sold a nd this would evidently make it a "Classic"=2C I suppose. The engine was listed as a Rotax 912S. It appears the owner has had it flying for about 3 years=2C since the registration was issued in early 2008. Here's the MkIII's FAA registration info=3B http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=457A Too bad the plane was total loss. Best regards for Don=2C hoping for a s peedy recovery. Mike Welch ________________________________________________________________________________
Date: Feb 01, 2011
According to the FAA registration records, the MFR year (manufacture date) is listed as '1991'. I guess this may be the year the kit was sold and this would evidently make it a "Classic", I suppose. Mike Welch Mike W/Folks: Prior to acquisition of Kolb Aircraft by Bruce Chesnut and Bryan Blackwood, there was no MKIII Classic. It was simply a MKIII. When TNK (The New Kolb Aircraft Company) redesigned the MKIII and designated it the MKIII Xtra, the MKIII began to be referred to as the MKIII Classic. My MKIII is a MKIII because if was built and flown long before the MKIIIx came into existence. It is not a MKIIIc. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 01, 2011
http://www.thedigitalcourier.com/#top_stories_anchor From: mdnanwelch7(at)hotmail.com Subject: RE: Kolb-List: Re: bad news good news Date: Tue=2C 1 Feb 2011 10:35:02 -0800 > IDENTIFICATION > Regis#: 457A Make/Model: EXP Description: KOLB MARK III Ron=2C I was curious what particular model the MkIII was (for no particular reason other than I was just curious). According to the FAA registration records=2C the MFR year (manufacture date) is listed as '1991'. I guess this may be the year the kit was sold a nd this would evidently make it a "Classic"=2C I suppose. The engine was listed as a Rotax 912S. It appears the owner has had it flying for about 3 years=2C since the registration was issued in early 2008. Here's the MkIII's FAA registration info=3B http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=457A Too bad the plane was total loss. Best regards for Don=2C hoping for a s peedy recovery. Mike Welch ________________________________________________________________________________
Date: Feb 01, 2011
The more MKIII x built without detailed plans the more likely that accidents may happen. I get all the help I think I need by calling the factory and talking to Brian. Hopefully I ask the right questions to make my plane safe to fly but I have to admit that at times I'm building scared. This is not my first plane I have built. My first aircraft was totally plans built, every piece built from raw material. This 3 passenger, 180 MPH airplanes plans were very detailed and I had no problem building it and did so with complete confidence. Even though the Kolb is simple to build it still needs to be done correctly and properly rigged. I've been told I will get a good set of plans when they come out. I wounder how much longer I should wait to cover the wings............ -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329257#329257 ________________________________________________________________________________
Date: Feb 01, 2011
Mike, A lot of surmises, but the aircraft was probably flying as a fat ultralight, then brought into the system under the provisions of FAR 21.191i(1). That would explain the category "registered prior to 1/31/2008" in the Airworthiness block as that was the expiration date of that provision. Rick Girard On Tue, Feb 1, 2011 at 5:59 PM, K I wrote: > http://www.thedigitalcourier.com/#top_stories_anchor > > ------------------------------ > From: mdnanwelch7(at)hotmail.com > To: kolb-list(at)matronics.com > Subject: RE: Kolb-List: Re: bad news good news > Date: Tue, 1 Feb 2011 10:35:02 -0800 > > > IDENTIFICATION > > Regis#: 457A Make/Model: EXP Description: KOLB MARK III > > Ron, > > I was curious what particular model the MkIII was (for no particular > reason other than I was just curious). > > According to the FAA registration records, the MFR year (manufacture > date) is listed as '1991'. I guess this may be the year the kit was sold > and > this would evidently make it a "Classic", I suppose. > > The engine was listed as a Rotax 912S. > > It appears the owner has had it flying for about 3 years, since the > registration was issued in early 2008. > > Here's the MkIII's FAA registration info; > > http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=457A > > > Too bad the plane was total loss. Best regards for Don, hoping for a > speedy > recovery. > > Mike Welch > > > * > > arget=_blank>http://www.matronics.com/Navigator?Kolb-List > ttp://forums.matronics.com > =_blank>http://www.matronics.com/contribution > * > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Feb 01, 2011
>but the aircraft was probably flying as a fat ultralight=2C >Rick Girard Rick=2C You may be right. Thanks for the clarification. Mike W MKIII not C ________________________________________________________________________________
Date: Feb 01, 2011
<< The last thing I want is some guy from a FSDO adding to my misery, which they will. >> Not always. After I went mountain logging with my Prospector I got a call from my FSDO while still in ICU. While really drugged up I told him what I still say: I let myself get distracted and ignored the many warning signs of carburetor icing until it was too late. Totally my fault. He said: I think the proper action in this case is counseling and we just did that. Never heard from them again. Couldn't ask for better treatment given my stupidity. Tom Kuffel ________________________________________________________________________________
Date: Feb 02, 2011
If it was not the motor, I wonder if he wants to sell it and what price would he want for it. Seeing that the fellow is okay sans some none life threatening injuries. Ron @ KFHU ================================ ---- Mike Welch wrote: ============ > IDENTIFICATION > Regis#: 457A Make/Model: EXP Description: KOLB MARK III Ron, I was curious what particular model the MkIII was (for no particular reason other than I was just curious). According to the FAA registration records, the MFR year (manufacture date) is listed as '1991'. I guess this may be the year the kit was sold and this would evidently make it a "Classic", I suppose. The engine was listed as a Rotax 912S. It appears the owner has had it flying for about 3 years, since the registration was issued in early 2008. Here's the MkIII's FAA registration info; http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=457A Too bad the plane was total loss. Best regards for Don, hoping for a speedy recovery. Mike Welch -- kugelair.com ________________________________________________________________________________
Date: Feb 02, 2011
Rick Wow I'm more than a bit surprised. I got my kit from Kolb before New Kolb. The kit had large rolled blue prints for most of the plane and two 8 1/2 X 11 booklets. One booklet had text instructions but not real detailed. The second booklet had detailed drawings and modifications. Did you get that much? At no time did I feel that the instructions weren't clear enough for me as a first time builder. What do others think? Are there others that have received New Kolb kits that are less than comfortable with the instructions? The Kolb MKIII & MKIIIX are very close I'm sure someone would share the older plans with you but I would talk to Travis and /or Brian first. I can't believe they would leave you hanging if they knew. Rick Neilsen Redrive VW Powered MKIIIC On Tue, Feb 1, 2011 at 9:19 PM, Rick Lewis wrote: > > The more MKIII x built without detailed plans the more likely that > accidents may happen. I get all the help I think I need by calling the > factory and talking to Brian. Hopefully I ask the right questions to make > my plane safe to fly but I have to admit that at times I'm building scared. > This is not my first plane I have built. My first aircraft was totally > plans built, every piece built from raw material. This 3 passenger, 180 MPH > airplanes plans were very detailed and I had no problem building it and did > so with complete confidence. Even though the Kolb is simple to build it > still needs to be done correctly and properly rigged. I've been told I > will get a good set of plans when they come out. I wounder how much longer > I should wait to cover the wings............ > > -------- > Rick Lewis > > (VW Watercooled Engine) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329257#329257 > > ________________________________________________________________________________
Date: Feb 02, 2011
Thanks I was almost expecting to hear that it was a 582. I don't think we should discount a motor malfunction as it could be fuel starvation etc.. Now its even more curious as to what happened. Ron @ KFHU ====================== ---- Mike Welch wrote: ============ > IDENTIFICATION > Regis#: 457A Make/Model: EXP Description: KOLB MARK III Ron, I was curious what particular model the MkIII was (for no particular reason other than I was just curious). According to the FAA registration records, the MFR year (manufacture date) is listed as '1991'. I guess this may be the year the kit was sold and this would evidently make it a "Classic", I suppose. The engine was listed as a Rotax 912S. It appears the owner has had it flying for about 3 years, since the registration was issued in early 2008. Here's the MkIII's FAA registration info; http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=457A Too bad the plane was total loss. Best regards for Don, hoping for a speedy recovery. Mike Welch -- kugelair.com ________________________________________________________________________________
Subject: Mark-III Plans
Date: Feb 02, 2011
- NOTE - Subject Line changed Formerly "bad news good news" << Even though the Kolb is simple to build it still needs to be done correctly and properly rigged. I've been told I will get a good set of plans when they come out. I wounder how much longer I should wait to cover the wings............Rick Lewis >> Hi, Rick - I was not aware Kolb's blueprints for the Mark-III were not a good set of plans. I built mine from an "Old Kolb" 1997 model year set of plans, and my Mark-III seems OK. I discovered a few typos here and there, but overall, a sound aircraft resulted from those drawings. I still have my set of plans - if there's a detail you need (wings?), I'll be happy to copy a page or two for you ... lemme know. Dennis Kirby 912ul, Powerfin-72, 130 hrs tt Sandia Park, NM ________________________________________________________________________________
Date: Feb 02, 2011
Subject: Re: kolb plans
Hey folks, are the construction documentation (plans) presently being shipped with a FS-III from the factory conveying any less information or detail than the plans for a FS-II or the FireFly? jerb ________________________________________________________________________________
Subject: Re: Mark-III Plans
Date: Feb 02, 2011
Thanks Dennis but Travis e-mailed me on this and was told that Brian has completed the plans for the MKIII Xtra and is sending them. There is differences in the two panes. The plans I received, when buying the kit, was bits and pieces of the MKIII clasic. There was no blue print. -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329392#329392 ________________________________________________________________________________
Date: Feb 02, 2011
Rick The plans I received, when I bought the kit, were bits and pieces of the MKIII classic and had no full size drawings of the plane I was about to build. I did see those nice blueprints your talking about for there other planes and they were in such great detail that anyone could easily build from them. Travis e-mailed me on this and was told that when Brian took over ownership of Kolb, his first priority was to finally come up with usable plans for the MKIII xtra. Travis has sent the new plans to me and they should arrive soon. I am really looking forward to looking them over and see what, if anything, I have done wrong. -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329396#329396 ________________________________________________________________________________
Date: Feb 04, 2011
Subject: viking engines
Hi All,=0AIs it just me or- does any one else think that the kolb list is turning into a =0Acomercial for Viking=0Aengines?Frank ________________________________________________________________________________
Date: Feb 04, 2011
>Hi All=2C >Is it just me or does any one else think that the kolb list is turning in to a comercial for Viking >engines?Frank Frank=2C I'm not sure I understand what you're getting at. I don't recall seeing anything about Viking engines. In fact=2C I don't think I've ever heard of a Viking engin e. What references are there to these engines are there? I must have missed them. ???? Mike Welch MkIII GEO turbo PS I hope to be able to start my engine soon=2C but if it would warm up=2C it would be a lot sooner!!! Sure is hard to get a lot done in my shop=2C when my soda pop fr eezes up solid. (it really did!!!) ________________________________________________________________________________
Date: Feb 04, 2011
Subject: RE: suds
Mike!!! Beer has a lower freezing point!! :-) Herb At 10:25 AM 2/4/2011, you wrote: > >Hi All, > >Is it just me or does any one else think that the kolb list is > turning into a comercial for Viking > >engines?Frank > >Frank, > > I'm not sure I understand what you're getting at. I don't recall > seeing anything about >Viking engines. In fact, I don't think I've ever heard of a Viking >engine. What references >are there to these engines are there? I must have missed them. ???? > >Mike Welch >MkIII GEO turbo > >PS I hope to be able to start my engine soon, but if it would warm >up, it would be a lot >sooner!!! Sure is hard to get a lot done in my shop, when my soda >pop freezes up solid. >(it really did!!!) > > ________________________________________________________________________________
Subject: RE: suds
Date: Feb 04, 2011
>Mike!!! >Beer has a lower freezing point!! :-) Herb Herb=2C Hahahahaha!! That it does=2C Herb=2C that it does!!! Today=2C I'm taking hot coffee=2C tho. I'm trying to get that nosecone ready for it's final installation. I redid the airspeed indicator mount=2C after I walked into it a couple of times. (and I was worried about the need to zap 10 year old kids. ha) I backed it up about 3". Still will work fine=2C and not so easy to bump into. Mounted my comm radio antenna in the nosecone=2C too. Kind of funny how the location works out. I used a 1/8" steel welding rod to make the an tenna=2C and mounted it where it sticks up through the nosecone about 3" ahead of the Lexan windscreen. The rod protrudes about 4-5"=2C so I bent the top end into a little loop=2C perfect for tying a little length of yarn. Looks like it was planned! Well=2C I guess it was!! I've got a small project to complete before I can permanently mount the nosecone. I have to make a little mounting device for the Dynon magnatomet er (for the EFIS). Easy job=2C shouldn't take but a few minutes. Got to get at it! Mike Welch ________________________________________________________________________________
From: "Larry Cottrell" <lcottrell1020(at)gmail.com>
Subject: Fw: hello
Date: Feb 04, 2011
Am I the only one getting these? Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ----- Original Message ----- From: celinah koneh Sent: Tuesday, February 01, 2011 1:24 AM Subject: hello Hello dear Greetings to you,My name is Celinah, a young girl, i saw your profile in this site at (forums.matronics.com) and i decide to communicate with you and it will please me if you will be my friend, i wish if you will respond to my mail box so that i will tell you more about my self, i hope to hear from you. yours Celinah ________________________________________________________________________________
Date: Feb 04, 2011
Subject: Re: Fw: hello
No, you're not. Most of the time Chrome sends them to my spam folder, but occasionally one sneaks through. Rick Girard On Fri, Feb 4, 2011 at 12:58 PM, Larry Cottrell wrote: > Am I the only one getting these? > Larry > > Note: If you forward this email, please delete the forwarding history, > which includes my email address. > ----- Original Message ----- > *From:* celinah koneh > *To:* undisclosed recipients > *Sent:* Tuesday, February 01, 2011 1:24 AM > *Subject:* hello > > Hello dear > Greetings to you,My name is Celinah, a young girl, i saw your profile in > this site at (forums.matronics.com) and i decide to communicate with you > and it will please me if you will be my friend, i wish if you will respond > to my mail box so that i will tell you more about my self, i hope to hear > from you. > yours Celinah > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Re: viking engines
Date: Feb 04, 2011
DQpJZiB0aGVyZSBhcmUgYXMgZ29vZCBhcyB0aGUgSG9uZGEgbW90b3JjeWNsZXMsIGJvYXQgZW5n aW5lcyBhbmQgb3RoZXIgc21hbGwgZW5naW5lcyBJIGhhdmUgb24gZXF1aXBtZW50IEkgaGF2ZSB1 c2VkIGZvciBtYW55IHllYXJzIEkgd2lsbCBiZSBjaGVja2luZyBpbnRvIHRoZW0uIA0KSSBsaWtl IG15IDkxMiBVTCBhbmQgNTAzIGJ1dCB0aGV5IGhhdmUganVzdCBnb3R0ZW4gb3V0IG9mIGxpbmUg aW4gcHJpY2luZyBhbmQgcGFydHMuICAgDQoNCj4gRGF0ZTogRnJpLCA0IEZlYiAyMDExIDEzOjIx OjU0IC0wNTAwDQo+IEZyb206IHJtdXJyaWxsQGNveC5uZXQNCj4gVG86IGtvbGItbGlzdEBtYXRy b25pY3MuY29tDQo+IFN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IFJlOiB2aWtpbmcgZW5naW5lcw0K PiANCj4gLS0+IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogPHJtdXJyaWxsQGNveC5uZXQ+ DQo+IA0KPiBUaGUgVmlraW5nIChIb25kYSBGaXQpIGlzIGEgaG90IHRvcGljIG9uIHNldmVyYWwg b2YgdGhlIG90aGVyIE1hdHJvbmljIHNpdGVzIGJlY2F1c2UgdGhlIGZpcnN0IDI1IGVuZ2luZXMg YXJlIG9uIHRoZSB2ZXJnZSBvciBqdXN0IGRlbGl2ZXJlZCBmb3IgdGhlICBhcHByb3ggJDEwSy4g ICBPbmx5IG1lbnRpb25lZCBpbiBLb2xiIGFyY2hpdmVzIGxhc3QgU2VwdGVtYmVyLiAgSSBzdWJz Y3JpYmUgdG8gc2V2ZXJhbCBvZiB0aGUgTWF0cm9uaWNzIGxpc3RzIGFuZCBoYXZlIG1vcmUgdGhh biBvbmNlIHNlbnQgYW4gYXBwcm9wcmlhdGUgcmVzcG9uc2UgdG8gdGhlIGluYXBwcm9wcmlhdGUg bGlzdCBncm91cC4uLi4uLi4uDQo+IA0KPiBCb2INCj4gDQo+IGRvIG5vdCBhcmNoaXZlDQo+IA0K PiANCj4gLS0tLSBUaG9tIFJpZGRsZSA8cmlkZGxldHJAZ21haWwuY29tPiB3cm90ZTogDQo+ID4g LS0+IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIlRob20gUmlkZGxlIiA8cmlkZGxldHJA Z21haWwuY29tPg0KPiA+IA0KPiA+IEZyYW5rLA0KPiA+IEl0IG11c3QgYmUganVzdCB5b3UuIEkg ZG9uJ3QgcmVjYWxsIHNlZWluZyBWaWtpbmcgZW5naW5lcyBtZW50aW9uZWQgZWl0aGVyLi4uLiB1 bnRpbCB5b3VyIHBvc3QuDQo+ID4gDQo+ID4gZG8gbm90IGFyY2hpdmUNCj4gPiANCj4gPiAtLS0t LS0tLQ0KPiA+IFRob20gUmlkZGxlDQo+ID4gQnVmZmFsbywgTlkgKDlHMCkNCj4gPiBLb2xiIFNs aW5nc2hvdCBTUy0wMjENCj4gPiBKYWJpcnUgMjIwMEEgIzE1NzQNCj4gPiBUZW5uZXNzZWUgUHJv cCA2NHgzMg0KPiA+IA0KPiA+IA0KPiA+IERvbid0IGFjY2VwdCB5b3VyIGRvZydzIGFkbWlyYXRp b24gYXMgY29uY2x1c2l2ZSBldmlkZW5jZSB0aGF0IHlvdSBhcmUgd29uZGVyZnVsLsOi4oKs77+9 w4IgDQo+ID4gw6LigqzigJ1Bbm4gTGFuZGVycw0KPiA+IA0KPiA+IA0KPiA+IA0KPiA+IA0KPiA+ IFJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToNCj4gPiANCj4gPiBodHRwOi8vZm9ydW1zLm1h dHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTMyOTU5MSMzMjk1OTENCj4gPiANCj4gPiANCj4g PiANCj4gPiANCj4gPiANCj4gPiANCj4gPiANCj4gPiANCj4gPiANCj4gPiANCj4gDQo+IA0KPiAN Cj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0NCj4gXy09ICAgICAgICAgIC0gVGhlIEtvbGItTGlzdCBFbWFpbCBGb3J1bSAtDQo+ IF8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UN Cj4gXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRp b24sDQo+IF8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQs IEZBUSwNCj4gXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCj4gXy09DQo+IF8t PSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGItTGlzdA0KPiBf LT0NCj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0NCj4gXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAt DQo+IF8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9y dW1zIQ0KPiBfLT0NCj4gXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KPiBf LT0NCj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0NCj4gXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNp dGUgLQ0KPiBfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KPiBfLT0g ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQo+ IF8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQo+IF8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 DQo+IA0KPiANCj4gDQogCQkgCSAgIAkJICA ________________________________________________________________________________
Subject: Re: Hello
Date: Feb 04, 2011
well perhaps I should be flattered, she sounds just dumb enough to be interested in my finer points. What had me surprised was that she got my name not from a porn site, but from the Matronics forum? I thought that I had sent it to Matt, because I thought he might be interested, but I while I am getting invitations from (probably an unwashed hairy dude) this little chick, I haven't heard anything from Matt. Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ________________________________________________________________________________
Date: Feb 04, 2011
No your not! Have anything against young girls? ________________________________________________________________________________
Date: Feb 04, 2011
Apoligies to- Kolb list, Some how I got on an E-mail list from Viking Eng ines =0A(Honda Fit) got-about-dozen a day. They=0Awere mixed up with th ose from the Kolb list. I just didn't pay enough attention =0Ato who they w ere coming from. Been going on for about a week. try to stay more =0Aalert in the future. Thanks for your patience.=0A=0AFrank=0A=0A=0A=0A=0A_________ _______________________=0AFrom: frank goodnight <frank.goodnight(at)att.net> =0ATo: kolb-list(at)matronics.com=0ASent: Fri, February 4, 2011 8:37:46 AM=0AS ubject: Kolb-List: viking engines=0A=0A=0AHi All,=0AIs it just me or- doe s any one else think that the kolb list is turning into a =0Acomercial for ==================== =0A ________________________________________________________________________________
Date: Feb 04, 2011
From: "Dallas Shepherd" <cen23954(at)centurytel.net>
Subject: Re: Hello
------------Boundary-00=_6074DL51VA4000000000-- ________________________________________________________________________________
Subject: BRS mount on FSII?
Date: Feb 04, 2011
Hello all, Im looking to pickup a used brs from a trike and am curious as to how i would mount it on my firestar II. If have seen brs's mounted with what looks like an angles bracket, but it doesnt look like the one im looking at comes with it. Its pictured below. Would this mount work at all or would the angled mount be needed? Thanks! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329658#329658 Attachments: http://forums.matronics.com//files/45345435_105.jpg ________________________________________________________________________________
Date: Feb 04, 2011
Several people on the Homebuiltairplanes.com forums have gotten this exact same email. All of the recipients were people who had put their email address "in the clear" in a forum post (never a good idea). -Dana At 01:58 PM 2/4/2011, Larry Cottrell wrote: >Am I the only one getting these? >Larry > >Note: If you forward this email, please delete the forwarding history, >which includes my email address. >----- Original Message ----- >From: <mailto:celinahkoneh28(at)att.net>celinah koneh >To: undisclosed recipients >Sent: Tuesday, February 01, 2011 1:24 AM >Subject: hello > >Hello dear >Greetings to you,My name is Celinah, a young girl, i saw your profile in >this site at (forums.matronics.com) and i decide to communicate with you >and it will please me if you will be my friend, i wish if you will respond >to my mail box so that i will tell you more about my self, i hope to hear >from you. >yours Celinah > > > ><http://www.matronics.com/Navigator?Kolb-List>http://www.matronics.com/Navigator?Kolb-List ><http://www.matronics.com/contribution>http://www.matronics.com/contribution > -- Clothes make the man. Naked people have little or no influence on society. ________________________________________________________________________________
Subject: Christmas Came Today
Date: Feb 04, 2011
Today I received my long awaited plans for my MKIII xtra. I bought the plane over three years ago and have been using a set of plans that were for another type and a lot of things simply didn't make sense so there were a lot of calls to Brian. He is a great guy to talk to and was always able to answer any questions I had. The first set of plans were given to me by Donnie and I was told to use them until they had the xtra plans re-done. Brian bought the Kolb company and one of his first projects was to make a good set of plans for the MKIII xtra. I have looked over these new plans and they are outstanding. They came with over 600 pictures on cd and a notebook of detailed text and drawings. I now also have the blueprints others have talked about. Brian has done a wonderful job on these. They are some of the best set of plans I have ever seen. I know this was a lot of work, he obviously took great care in making them. Thank you Brian, Travis, and Dennis. :D -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329666#329666 ________________________________________________________________________________
Subject: Re: BRS mount on FSII?
Date: Feb 04, 2011
Looks like ill just call Brs and see if this mount is available to buy: Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329669#329669 Attachments: http://forums.matronics.com//files/mount_415.jpg ________________________________________________________________________________
Date: Feb 04, 2011
Pity. Sounds like fun! On Feb 4, 2011, at 3:10 PM, Vic wrote: > No your not! > > Have anything against young girls? ________________________________________________________________________________
Date: Feb 04, 2011
Update: Well ol' Ron really balled that thing up. I saw the wreckage yesterday and it is truly amazing he lived through the crash. I only know a Mark III from an extra by the nose and there's no way I could tell by what I saw. He's in worse shape than I had heard. Both legs, pelvis, 7 ribs and some vertebrae. No health insurance either. Friends are asking for donations. It was not mechanical but pilot error. He had 300 hrs. in the plane but got behind it and it was a stall-spin, almost a snap, and it just dropped from about 75'. FAA did investigate. Over and done. The 912 ULS is undamaged I've been told. My Mark III with it's maligned 582 is my first plane and I wasn't really planning to upgrade but I may put a bid in on the 912. My thoughts and prayers are with Ron and his family. KT MarkIII NC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329676#329676 ________________________________________________________________________________
Date: Feb 04, 2011
It was not mechanical but pilot error. He had 300 hrs. in the plane but got behind it and it was a stall-spin, almost a snap, and it just dropped from about 75'. My thoughts and prayers are with Ron and his family. KT My thoughts and prayers for Ron and his family also. Very few Kolb crashes are caused by mechanical failure of the airframe. Engines, components, pilots, and Murphy, seem to be a major contributing factor though. john h mkIII titus, alabama ________________________________________________________________________________
Date: Feb 04, 2011
Hello All, In my opinion, 90% of all Kolb (especially MKIII) accidents are the classic stall at low altitude. They slow down so darn fast and if you do have enough altitude to recover it is almost impossible to get yourself to push the nose down when you are low. Jason Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329693#329693 ________________________________________________________________________________
Date: Feb 05, 2011
"He's in worse shape than I had heard. Both legs, pelvis, 7 ribs and some vertebrae. No health insurance either. Friends are asking for donations. " KT, If you can, find out where one could send a donation to help Ron out. -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329697#329697 ________________________________________________________________________________
Subject: Re: RE: suds
Date: Feb 05, 2011
I redid the airspeed indicator mount, after I walked into it a couple of times.>> Mike, cut the probe off. Put a short piece of the appropriate diameter plastic tube over the stump. Reinsert the probe. This makes a flexible hinge which can be walked into without causing damage. But of course you knew that. Cheers Pat ________________________________________________________________________________
Subject: Kolb list: Pitot probe
Date: Feb 05, 2011
Pat=2C Cutting off the probe is not possible. I have a Dynon EFIS probe=2C with the built-in AOA sensor port. It is exactly like this one=3B http://www.dynonavionics.com/images/AOA_new_unheated.jpg I added my own extension=2C to get it down low enough to not be affected by diverted air from the nosecone. (see photo) Besides=2C I've already relocated it. Now=2C I'm on to my next fiasco!!! My brake caliper leaked yesterday whe n I tried to bleed the brake system on the left one. The 1/8" NPT ports cracke d as I tried to tighten the fittings. Crap!! Plus=2C the discs brakes hav e NO identifying marks=2C writing=2C numbers=2C anything. I suspect my disc brakes are from a company no longer in business. I got the complete kit=3B discs=2C rotors=2C axles =2C bearings=2C wheels=2C etc) I got them in trade a few years ago. Nice parts=2C and all=2C but there is no way of knowing who the company is that made them!! Doesn't look like it should be too hard to duplicate the "puck holder" as they call it. I've got master machinist Rick G giving me pointers. >cut the probe off >Pat /9j/4S8yRXhpZgAASUkqAAgAAAALAA4BAgAgAAAAkgAAAA8BAgAFAAAAsgAAABABAgAJAAAAuAAA ABIBAwABAAAAAQAAABoBBQABAAAAwgAAABsBBQABAAAAygAAACgBAwABAAAAAgAAADIBAgAUAAAA 0gAAABMCAwABAAAAAgAAAGmHBAABAAAAAgEAAKXEBwAcAAAA5gAAAPIjAAAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgAFNPTlkAAERTQy1XMjAwAABIAAAAAQAAAEgAAAABAAAAMjAxMDox MjoxMiAxNjoxNjo1OQBQcmludElNADAzMDAAAAIAAgABAAAAAQECAAAAHgCaggUAAQAAAHACAACd ggUAAQAAAHgCAAAiiAMAAQAAAAcAAAAniAMAAQAAAH0AAAAAkAcABAAAADAyMjEDkAIAFAAAAIAC AAAEkAIAFAAAAJQCAAABkQcABAAAAAECAwACkQUAAQAAAKgCAAAEkgoAAQAAALACAAAFkgUAAQAA ALgCAAAHkgMAAQAAAAUAAAAIkgMAAQAAAAAAAAAJkgMAAQAAAB8AAAAKkgUAAQAAAMACAAB8kgcA DCEAAMgCAAAAoAcABAAAADAxMDABoAMAAQAAAAEAAAACoAQAAQAAAIACAAADoAQAAQAAAOABAAAF oAQAAQAAANQjAAAAowcAAQAAAAMAAAABowcAAQAAAAEAAAABpAMAAQAAAAAAAAACpAMAAQAAAAAA AAADpAMAAQAAAAAAAAAGpAMAAQAAAAIAAAAIpAMAAQAAAAAAAAAJpAMAAQAAAAAAAAAKpAMAAQAA AAAAAAAAAAAACgAAAJABAAAcAAAACgAAADIwMTA6MTI6MTIgMTY6MTY6NTkAMjAxMDoxMjoxMiAx NjoxNjo1OQAEAAAAAQAAAAAAAAAKAAAAMAAAABAAAABMAAAACgAAAFNPTlkgRFNDIAAAACUAABAE AAEAAAAAAAAAARAEAAEAAAAAAAAAAhAEAAEAAAAAAAAAACAHAAEAAAAAAAAAILACAAkAAACSBAAA QLADAAEAAAABAAAAQbADAAEAAAAMAAAAQrADAAEAAAACAAAAQ7ADAAEAAAABAAAARLADAAEAAAAB AAAARbADAAEAAAAAAAAARrADAAEAAAAAAAAAR7ADAAEAAAAAAAAASLAIAAEAAAAAAAAASbADAAEA AAAAAAAASrADAAEAAAAAAAAAS7ADAAEAAAABAAAATLAFAAEAAACcBAAATbADAAEAAAAAAAAATrAD AAEAAAAAAAAAAZAHACgBAACkBAAAApAHAAABAADMBQAAA5AHAJABAADMBgAABJAHALgBAABcCAAA BZAHAGgBAAAUCgAABpAHAEQEAAB8CwAAB5AHAJABAADADwAACJAHAJABAABQEQAACZAHAAABAADg EgAACpAHAMgAAADgEwAAC5AHAMgAAACoFAAADJAHAPQBAABwFQAAAKAEAAEAAAAFAACAAaABAAEA AAARAAAAAKEHAIgAAABkFwAAAaEHAJQBAADsFwAAAKIHAFQKAACAGQAAU3RhbmRhcmQAAAoAAAAK AAAA5wAAcABwCAAHAJoAgAX4igD5JwAAR14AUgAAAAAAAABSAAAAJYyHAAAA6gBt5wAAP2oA/s23 KAHqfQAAnPsAAKEAADDNiADNWzDNiCqKAABUAAAAuwDXAChwAADvGwAAyUAAANzWAADNiFswKoo2 ALYAcNjxfQAA6b4oAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAIOLYkR384E0aB AAAAAAAAAABw2LYAIwQAAIMFAADWtgAAAAAAAAAAAAAAAAAAAM0AAAAAAAAAAAB9becAAH4bUQEA AABKAAAAAAAAAAAAAAAAADwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEUAAAAAAAAAAAAAAAAA AAAOuUAAAAAAAAAAAADYGwBdYAAjAIDqAAAMABtwgHCAcJxwnHAMALB9gOqrIK6KAAAAAEO2J3D/ AH0AAAB9ABRAAAAUQD0OAA4BGwABAECsCAAAuwDNAAAAAAAoAAAAnggxAZUBAAFnAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAG8BbwEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA2L0AAeIIrgEAAQABAAEA AQABAAEAAQABpX1pbE8AlaCsfQug2ABvbHB9cAnxmVcTVDwA4Ac4AOAHOL29vb29vb29vb29vcXb 727iYhpScNcF4NUvG9i7I1qKG17tdUKICNhCt5hqqRO6ADHiM3Svvb29vb29vb29AADru4rnyIF5 BHGK8Iraiuq2F//GAAAAif3ImrbY5nuaBTSIqAAzAI0A4wC9vb29vb0lakfUckwWV9AaNkFM4lmT jMUAw1Vwb4OvwxysSb0lakfUckwWV9AaNkFM4lmTVXBvg6/DHKxPAEzij5NM4o+TOl2Sc0gHcxBa ObgtaFyVAUziWZMAAQAAAAAAAAAAAAABG7Z9GDmbLQDNAM0AAADi592uxAAAAAAAAAAAAAAAAAAA AAAAAAAIAQEBSkp5AAEBASgAtgDqfRUItgBw2AEAAEpKAL0BAAAAAAAABycA//8AAAgAAAAAAAAA AADEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAL29vb29vb29vb29vb29vb29vX0BShtKG0obShttG20b bRttG0obOACTAL0ANwEY3bYATt22AHLdtgAX3bYASf///0n///9J////Sf///7gAAAAAAAAAAAAA AACqjCkAAAAAAA14i4Vkt5UBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAEBAAABAQAAAQABAAAAAAAAAAAAAAAA6gAAAAAA AAAAAAgAAAAAAAAAAAABAAEAAQBnAAAAAAAbAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGw7qcHBw6g7qcIGV gXDqcIEkOCSBcHCVOEo4lXBwgSQ4JIFw6nCBlYFw6g7qcHBw6g7Ky5HLqe/aukyRt3WSjg+OLpHa 7uNPN3Uideh11/bEdehh1TI8dfp1vsvc9nJMcUFGYQuRLJHpkf51n+LCYQuxJ5G0R22RzHUL8MNl AzKFzx+xXdBfTw66YBqc8DrwVkeC7zSgs2w0oONRCGwr7O/sDJUQbGsoIGwfoOlsH2xUoM0otyjV kh+VNKDEbLSVAAAWKJKSZaDLUTSg2tM0oEDssZIYlcqVRFEo0///BOxou8SS05LSkjdRQpX9DLK7 SZLFDMcotAyMbDTXz2wh7LugVpW5DCfs7C8/oOxsP6DXoN0o15Xb0+dcxuzc7HlsnAwAAP1RRjlq 7F8ouijMuz6KfdOROSUMtCgMKDq7//87lbU5Z2pBXEZc7Awbu31RTdNWautqD9MAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA2AAAAAAAAAAAAAAAAAAAAAAAAAAAAB8bkRuPAQIbcEAHfUp9oRuBQCV9ln0ffYx9 4n2SGxIIDtimQG59oX2DQL0b3QAdfUZAoUAkQPZAbkAxASd9nkCHQPMIKECPQMcAxEDhfUlAjEA/ QI99+AElACwAPwDmAaMBwQjy53q+6FEhUd7sobs9iCcF4+cO2FAbjwipCMwIUAjeCB4IiQFdAQcB 4wEUAaMBuxvSG8cIawEjAXwAGQCAAMcAnwDUACcAgwB/ANAAzwDLAMsArAAjANwASwDEAHkA6gAb AOcAQABAABsAQAABAAAAAAABAAEAAQABAAAAAACsaUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAP// /////4gBUAFHCFgIxQFsAS8BhwHjQDFWhVYqCBwBUgHtANx9JGwTiD4ByAEDAawBrwj+KEIgVhsU AUsB1AFjAWLsoIGQAdEBSwEYAUUBNIq8vswIGgjzAYgBKgEh2A6+TOexDkVeGwBeAA4AfQB9AH0A fQAbAA4AiABwAAQAfQDYAAEAfQDXALsAQAB9AF4AAQABAIEAoABAAEAAQAAIAAEAgQCVABsAQAAI AAEAAQCKAL4AGwAIAAEAXgDYAM0A1wBpAL4AKACeAFYBoAHGANYAxgCEAHYA2AFECCAIEAEXAGgA vQAZAHII8xuLAIQA8gAxAF8AZRvCQAMAZgCYAHsAbQATG5NAUAC1ABEAggDDAIoI/wiGAAYAvwDk ABgATAGhCFkBkwi+GwAAAAAAAAAAAAAAAAAAAAAAAAEAAAAAAAAAAAAAAAAAVgBeAAAAAAAAAAAA AADnABsAAAAAAAAAAAAAAF4AfQAAAAAAAAAAAAAAAADNAAAAAQAIAAEAAAAAAAAAAAAAAAAAGwCl BKPqrIqziHiS0S8LXSQoAJJhKEegYdO0Xc1cVGo/XaDnhARk6gZwdddQoH+V2oHUvnKB7gx1bL2V OlEBUbyVAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAn2BRe0Q4cVo+Kw5JMDLy2DIoCtgIgY9c7DJ5s/igcDEh9StiuXjTn mc1p10LXkoogzeqKnrYqIFKBSJIYu/zXAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD/UVZdy1wmB6RMrOLq7xFM3oehTO4a SvBs773vUiQZ4qsg+4iWiLNpNLaBtidwropDtqq2vbbEtg62NHChcCdwAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAH0A AAB+BqwAkVQVAOEZFQDmrsQAh/EAAICADgCYGYoAAkkFALQeXgAkOAQAoy+IAJchaQC0WwQAgIAO AJgZigACSQUAtB5eACQ4BACjL4gAlyFpALRbBAAgPAAA2xwAACA8AADbHAAADQAAAMcnAAANAAAA xycAAIAbgBuAG4AbAAAAAACKAIgHimAgt4jf6ioEKgQAAAAAAAAAAP////9bMABwZXBJaY5wLLYl iLoFWzDf6gBwAHD/////NIppaXEF1IhtigSIWzDf6t8g7c0qBCoEAAAAACogW81AiiOIxIr8aXwg W83MMCPNACAA6lswW81mINnN+gVBiO+Kx4jRINrNWzBbzUAwJ80AcAAORSDqBWCKEYgeigCIkIrB aRwFzojbBekgAAAAAFcg183ituK2ZIpoiAdwX2kGiKUF97a6BQBe2BsIAQAAGw6KQEAbAA5M7EBA GwFA8GpAQEAbQBpcfUBAG0BpL7YFBABAfYheQEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB oAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgI3DgAAAAAAAEAAAEAAAAAAAAAAQAAAAAAAAAk eSR5AAAAAAAAAAAAPsKLAEoIAJVwaWm+vjIAAAAAAAAAAAAAAAAAAAAAAAA+wosAAB4AAHAAAAA0 wovEAAAAdFjzlQK3lQIkJCsAAAAAAHl5kXngkQK6AAAAAO9HAHAAqowpAAAAAAANeIuFZLeVk7oA lZq6AFFiywDTYssAtpvLAC+bywAkZnUAxJ51AOOldQB5AAAAAAAAAAAAAAAAAAAAAAAAAACAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAANlH0E1guvxqzSKMoukRzJCKZsCHvMr8mUwG1DWblPi1t72IOsAZTDsiX xixYzQA1EOUkEuB4Bjqyz1M019z8HXJnYjAvTqwuc9ZsFsx/3Vp8EQUVDyZ/GhCfEAvCRhvynU6v JtkMi3/V+fZaULXEfufIX1n3r44oEkw8CmI23S/M2HjfjquFAB6eFRJOm78aC4VCKdzzcyRjBFEg ZJ2/JhKcVAzdSj4tfe6SDoEWUw7YlwYtGM0ANQHlxBPNeAY6qM+zNSfd/B1jZ4IxX06sLj7WjBdM f90pbRHlFJ8mfxoAn/AKYkYb8o1OTydpDOkgmKJODcTnlDG4hvEVauKOKJ4M3AJGNtggzMWrBn6r hQFKFG8n91ZuHi1InjIhfz45mrIcBTkcogNPHcELy5W8KPkL1xaOWFgESQdiN7OfEiBl69M245sQ JOxiBDG7HsMGqRfwBwrCrx2sf84mvDhACpyXSjZYLrguctOTEj3YHCeSqZ84vK1CAycfPC8B5hAQ Y5ihKbTQ0AtC+dEFPQMqBH/BKRxDicwNVHFkAsUyQRTCu4Mj0M5RDCO1gjhTtKkPA2gtIrMV8DJD cAsvtGfQACZ56/fF6pEzZzmVDIuQLCGSB1Ay8iW7/ibfkcI2HEbddPoB5L7YDt8S2Q/fP67O+Jyr ud+OOXTDAH2Q7mTe/zf+qyTrUhsfRaGs/eD44Ufr4h4x/yWRSsnoWyvEvowrGE6ZpRq7ihoj3PNz JPMGUSB0nb8mgp5UDH1I3ixt7nIPMRSzD5vBt/7wwho1eeWcGe14vjG4z1M0N91EFndnbjAvTqwu LtZsFsx/3SkNEb0eCyZzGhCfEAvCRhvy7UyvJskMCSH4orQMbOcsOtiGqR+64o4o/gyECKY21CDc xUsHjquFAVoUjyaHV9YVPUhyMzF+PjmKsvwEGR2iA08dwQsrlKYohQuPHL5Z4A9ZB4I2k56qK3Hr PzeDmhAk/GLkMMsfwwbJF6gNjsOjHbx/LicsOUAKnJeqN+gvWC9W0mkT4dmkLPKpxzJ8rEIDRx9k JdXnHBBzmEEoVNHQC1L5MQS9ApIPa8HFHUOLzA1EcYQD9TBBFMK7gyNozUsMX7XaMhO2EQQTaM0j gxdIOVdw5y7kZdAANnkL9qXokTMHOc0G/5IgIYIHsDMs2s4Qs41NNa3uJS/PaSs05L6tPEx8VjON EWUi+JYcC/68vSXtDLo1tUtWLEcr2RwfGtIyzKn4KoZVjQe7uyUcJu+RA4D4IS3xh3k2ISG9JSdE VTNUsOg0zk7GKwyGliWQpV8WqXWNEM+o5Ai1kZk93t70F1EnySn1lxoXpBWeAi1iygggpusV0hY+ PH1wKiHjqGIGdSNoH+1rMBaImUEt3kuNO0UCGiMxACMsp3XrGdxwdQAP0FsWNRlPA/uRtQzryZEY V7plIBeaeSPgIAs57SSvOq418jKNb5UcOMQwDkYrIyypSWwTcRtKOHtOgwxZ04sy+O6UDY/04if+ 7hA0Y4t/PgBJhAIG9dgwvKQ6FOg4cyp3T8wsZqLWGHsn1zG9LY4fUsuJCuaGQwV37Xw7N4vRAwTj +iiLFR8JNOGWAxMUvSv2KKsrIEDOMluQeQv4HdgybamFCVXrNRi7PgIb0ePIG07NSS4HRVQ1h856 Igm0CyQm4hAlTvfSHxMkDgJ41OMOmzStFrnurxRlTZMAWESKEkEAzxUAe+gPb+lQENil2AtxO7E4 MKovOy6UQSQKEzwATMa3GJOiLTp77GgbdDASMyNO8Al008kSQgUREG8ERCNdDkALVPaTH6xmESz4 PvM1q8DDEx+2Pgub7vEpcwv6EVWivwgLrIYtEkRhCHrvSzp1FS0I50JNAHnByhkSy0wjXxqcMXUI NBLoJ5wEMsKbLjnymS5rg1w02hh/KY5uZCoo3T0XCxINJy1HQitWWPEz7ISQIQgYnBfikiI8V9vE Cv1UYxFYQsoXxpAKC30PiB+s3GwMEgr+C69M4j/f/nQoZSvjBfKqzznwfTwHf3gVCme4tQsj100n +Mj1GCIhziy7xVca4KROKsvouwyZub8R5BhsJ0q3tz/dO0QnqvxxOlehMA5UJEcU4q7oKq569jC3 proxDeGpKUCIgiFGbS0WBoArH3xjUAQidxEzmmYKMvBUijsmtG8oFgJDBD35zQS6DHcz6E3oFRfa PyEoMmwWZ25+B3wrUioh/TI2TqsOIThxmB/FJR0XGKmwAk7UjCdBOzQZ+bFMBhcd7SS3sdA2Yos5 NKosWgWvZ08tVjxTDv5/rgu5mOoLaf15GMwxeQhImVYGZPpWJxhoyC8PUHwpgGg7LoRnTioB7jUy beXjNNgy1gt2kFc6WRaRCEpEnwD5e9sadItPGdffCA1EvhwTnmIQEEiCNi7PEv8JBWobIA9h+x2H 75cVzTpOORpPkhVAj0YxgncQBo7+QRVxBLYGBkrsAvZksyAE3TwOIfGVMWAbqgERFOsqixuPHh0q 3waDr3YPzXLjHIfKJRT8t8kA54n1NjzxFB9vwTUijJsrKW4aeCosJVMPhkClMjg8HxV6Z/YFKfBi K8AHtDSNe/gEg03+CJNhwTLUJrU863a1B/je3CJXHiA1RDVFFMc+UB/5vtEaWHvqHpYaBitMe2QA U9AoPSXvLiXbTAQaLatKLdY5UilLfIIytkKIFarwmzi+GpgfFu2+JKEsZjMW7OQYaKIhB0rZNA12 8h8aMRj9OIpi1h43qrwbXZoLLl/W1h+ZrD8NACRjNGfWbxnEn60Jngz1L8r2TiryrnMoOs5+FocC lCRMGIYWqj4wOj1j9Dl+oBc7+Z4RORs4QDJwNSEZjIujArBnkDLSSYcEuRhMDtuN4AO9V+EYXKs/ GVRBei+qtDks0AImCYxq6Ck0Py8ZaRArBToHMSTpYVk6o7OTOD1CwSGaAjgK4gd3Cvo20zk3Erwl jnc1F2I9HT3WBLkWw/AyPQalgh7YphQ0hQFMEateviJUzzISSjp7BuAqciOQ7u0Vdu6BF6mtgAii KbEFopkpHVOTYgLGPpApMsM6AsPhoRLN0zcPUmPROgShXDNH3rANWC/QC0RbvCIh/nIYKfCVG8iZ GRM9t/kFlZ5zIj5A6x33aLUYwvqZB6wq1BogeaIc/COgKIBr6wQBNEg8u8NlAg0YrQhezMw2qPC2 Isnqaip7nbYajqVAEhU50QYDKSgeTTK9LWdY7xUcRE4JAds8Kpo2GDP5evc5rkN5N5Q3OgYb1O8d 9AuXChvGUhrGJ/YBsILMAHWW2Ac69GgmFQuZHEXsaDmCKEAoKMfRLv3OkSeO4PYhfEdBJ2lgKAkg NE0naQ2LA8802i4jkUUJoMItK8gsAQx7Jg0B/WSWAcz3rQUph8wE/fPbDY71fTuGbbUagQMGNvQI ax0UFoUrYlyUAWHYtw/KwCgulHvTIo9UtgqCVDcWiewaG1It0DTtrfoc1b9BM4mGFy9eTZMp6529 NSp5PxLqElwMdsb5E2U6gyFq3AwRcxq1PAOv4SGkyAoidEFYPLI6BhqA608WiXZbHLP72TeVw6Ii 7nkXFN0tZgqDC8QxUQXGFR+oPxzgM3AcwTIhO+8K7TDPgWYFfw2AO0rOARV/F2c4qm9TExScwh7V Y5sViE3hDVnd1jEULkkhV63HBMfzXipQ2PYqzNqzLzrCJBqpMWMSfL40M6zVrytxx0En0w6/FYN/ Tx9tZDAmfWM4OVk7sSkwnUI3QxOaIbvozzar0RU4Lz4fArEjxx/kIvQQ0v+FH5LA1gMWFZEsc2OU B5+a1SNdLqk6nsCpKNVXcCXKffYX2NYYJUxr3A2lM3kuwdwoC3bBHjOWl1EKHCo5IJUICSatWr4O EPopEJboMBpIktIqFQDPEuwOGhy752AqfU7DLGlMvS18jA0kYLRqO3ufoCDnN0wpe22gOrO/GySP X+AZfCPLNxsOJjTigE4zn/lXKprj/ya0KksHXdN8Imu1ZxNTdf8cCc2vHE3wkDxLt385fGR9EYlU Fh2eHes6A1F/CvqO1zADZaAYzysxBzhpKRratc0mqX12G/sJISqYk7ER2D4eFY/4PyyP5AAkmZln NfGvUTOzatMGAOEXAsN98hSrW+oVn/vMM/rcXQ/JVxcjAXQjOE4A8CW7G3IFdhtNIlLRczHwWywW 4xAQAgf9YRMQcfolcqmVMnbWthtVQyMFDpclLR88rixAbp057Zr4KnD8AQf9tIEVrCn6OKzU3D58 JPI0anGhPgIAAQACAAQAAABSOTgAAgAHAAQAAAAwMTAwAAAAAAoAAwEDAAEAAAAGAAAADwECAAUA AABwJAAAEAECAAkAAAB2JAAAEgEDAAEAAAABAAAAGgEFAAEAAACAJAAAGwEFAAEAAACIJAAAKAED AAEAAAACAAAAMgECABQAAACQJAAAAQIEAAEAAACkJAAAAgIEAAEAAACGCgAAAAAAAFNPTlkAAERT Qy1XMjAwAABIAAAAAQAAAEgAAAABAAAAMjAxMDoxMjoxMiAxNjoxNjo1OQD/2P/bAIQAEAsMDgwK EA4NDhIREBMYKBoYFhYYMSMlHSg6Mz08OTM4N0BIXE5ARFdFNzhQbVFXX2JnaGc+TXF5cGR4XGVn YwEREhIYFRgvGhovY0I4QmNjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2Nj Y2NjY2NjY2Nj/8QBogAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAA AX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4 OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaan qKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foBAAMBAQEB AQEBAQEAAAAAAAABAgMEBQYHCAkKCxEAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMi MoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpj ZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbH yMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/8AAEQgAeACgAwEhAAIRAQMRAf/aAAwDAQAC EQMRAD8A4EDmpCAB0qQQ3PJpygbcmhjQhwGwDSgHOaAAgbuTQSFwFxQGw7dnjA496RidwGBikO+g 1+WGc4pzLhM80xAhxwBmkPJPOKAvoKFAHB5NCnB+7uz60ADk4OBgU1RQHUCBSD0oATuKcQSMjpQA KCc8UbRjqaAsKibiMkZ96dJA8bYK9elAWGnjqMUmec4zQAoXI3DpSEEnBzgc4oCxIhXJHftTjkZz zUspbEK42E0oGTxVEijgkkUmQWwOlADuvy5pOB3pDELc8cmhR1FMQw07PGBxQIcuMA0uB+NIoaVw 3Un1qaOV4xtyGQ/wtTuKxLJFHOjPAMMPvIeoqsI3IAI4oegLUXkOBRIew6mkV0GglQMjp2NCnc+W 6emaBeQ7ClyMYFNY7TjFAPQQFjxjIFOAAJ4NAIAu8FhxigYHHU9aAE2jJNIpGMCmIaelApiHJlWy wpVPzAnpSGLv5OASKIwXcDnAPNId7kwBRw0fDL+tTSKHAZcjcNwH86Fqgas7kRwVyevQ1E+M4GAQ eKSKew7y5WTKoXz6LmmgbQVdGUjnkU7E311EUbo8A/NnvQ3DBGxj1oAXaAODjPtSDC8E80h7AzAA DrmmYyCemO1NCYNwMjpSZyeBk0xMO1Cdc0MFuObJFEavK2xeSaED3LyadIoDSSRop7nJz+QqaLTo d3NySSf4U/8Ar0WHc1Y/DsWPmllP4AVcg8PQ4VRHI4BJGW9fwoSsDdy7b+GbXkPaAjHck/zNZ+r2 iaUqMsEMYbjhFJo2C5ktqUpjYbht9Sf5CsmeVp5tzMRjoTSAYFYNkjr6UOcsAAetIetgJ5P8qYDz 0600JsUbfMyOlOz1yKBojIypAOaavH1pksWkGcnFAh3UGk5BBU4PtQMmE8gC7s4+tWGuDEyvGT8u CMnNK4z0e0uluLOGeNEAkQNwKmDknrVCHhj61zXjJA1tCx6B/wClJ7DW5yGweYNg+oqJ3+bleh4q VqN6Di+4ZBO/0oDEA7x19KLDuAxliRnPShGBcZAFAhJQC3yjn27VGVfac5xTTE0NUcHnFA64zTEF A+9QAqqWGPTvS7Sjc8/Si/QLdRcFmwMtipPmK5IG0dqQzvvDzh9CtiM8Aj9TWmtUIlFYHi/jTA+M 7XFJgjh0ZnbI4wO1K0fGcnHep2ZW6uJkiQAc54pJN3Ix0oAjyVb0qUuWiw68DuKbQkxPu9BQCRSK GyjpjvTBgDnrT6EvcQGg9aZJKvCcHnvSMeMZxS6lvYWNwowOSe9KWBb5h+NFtRX0O68LNu0KMejM P1rZWqESisfxUv8AxJ5D6EH9aTA4BZAHPoakLBiAoz61LRafQYx2/MOtIgBbjvzyaOhPUJVDNhB8 3emFZFAGetNMGuqJMAfKzDIpCnc8UiiMuM0gPFVYi4ygnimImRCV64pQOpPNRcuw0KRhWTGTUsvM YAAAHT1ND3BbHZ+EGJ0ZgRgiVv6VupVkkyis3xIh/sm4GMkLnFAHnTAPkuMHtTxntgHuKzZaGuAS FPJ9KY8ToBg5+lNMTXYRQ6MWPpzmlDszjIp6PUSutBAu9yOn86VkbaOcgUrjsMXAYZAzS7hvPy4p iIqD0qiSdG+VSentSZYy5Az7VNirjvMIHzKM5oeQFcbefelYdzr/AAXKH0+4TPKyZx9RXRx1ZJZh GZFHvVPXtslpdqBwFP8AKgDzNt5YlRx0pqoS+c96grVkjDY28DH0604sGGegB/Op8yutiJzjOe/S mKr57DA4qlsJ7gA+/cOCKk3Eg5A5odgVxNmfpULbv4hQhMipasgkiJK7QO9SKVXAIOallITcGlJI xihgXcnt2o2HuW9Nu7jT5/OtiBkYIPQiupt9ZnlVCNq7hzxVJ3E1Y6KzJMYd5Cx9hWN4sllhjJgm dVYcqOlMRxgBLfdP0qBv9aGBwM1mkXIlkbJ2kgqRmo3UIMAcnihaaA9dRJYysYwc1GFbqDxTvoTb UchTGGJBPFLIoiUFSev1pdR6WuMXlie/apVTI3GhginS1ZAqnBwO9Tnb1VMGkxobtbaScZ60BSVz vxjrSuOzJvlVQjHitjTDuhA9KcByOz05t1oufxqtrlob5QiZ6c1RPQ4u5tmt5ijglRxjNQ+UNp2I xyfSpafQaatqIltJ1aMsaQ2M7E4RuvHFFmK6JP7Mu5Fx5b/9809NEvSeIZCPTbRYXMTLoV4D/wAe 5GfUUk2i3a4yEA92Ao5R8zKktjFASJJwpHBC81WZ+MBs/hQ0ESrRTEHGRU5IC8fhSY0Ee47gT0p+ xV4PSpZS8xgVfXJ7CtDTrpbcgS5Vexq0ybG+nieK3QRxIHx1NOHjBthUWynPU4OaegXKo1z5y66c jfVM01dfZQdunQZyTkx0XQWIz4ln/gt4V+kQpjeJr7OFKp9FApXQrEb+IdRYf65/wNV/7avpc/vp D/wI0cw+VkTX9y3WVj+NQvcSMRvcgZpczDlIJX3EkkkdqYrHGSKW49mR0tUSIaVW4welADwTk7T7 09SC24A0hocWBGRwaC5ccZFJIbZNauEY7kBBrWhuhkBFXn15p9Q6GxaaXLcozujnI+VuwrMvYRaz MrDpQwTMiT7x4wOtV2JJA7HpRYVxoyF96XjblBg9yTSKI2Y9MdKHKlfUDvQK/cb170hOOPWgBlFU SL2ppGaAAEg09JMdaATHk56UbiBjFKw7k8LgIAQavWcyLJuKKee+eKBnaad4ht4oGC8ZHQ9c4rmt YuxPO0hH3jkAdqYWMiQM446VV3sjYwKV0xWaGs/pSl8jjtSsO41nG6k5I7YNAXuNAG7GaceT7UxH /9n/2wCEAAICAgICAQICAgIDAgIDAwYEAwMDAwcFBQQGCAcJCAgHCAgJCg0LCQoMCggICw8LDA0O Dg8OCQsQERAOEQ0ODg4BAgMDAwMDBwQEBw4JCAkODg4ODg4ODg4ODg4ODg4ODg4ODg4ODg4ODg4O Dg4ODg4ODg4ODg4ODg4ODg4ODg4ODv/EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCxAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcY GRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKT lJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP0 9fb3+Pn6AQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsRAAIBAgQEAwQHBQQEAAECdwABAgMR BAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVG R0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKz tLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIAeACgAMBIQAC EQEDEQH/2gAMAwEAAhEDEQA/APwNLjtzULsT3rIh2LduQyMHbC455pbgLHEiRvkEc+/1pdR6cvmV 40eViFUuQOwrTtrKRXSaVljUEfealKSRpCDk7mlMLqWV0UpHEehHWsEwOLxUk4cnnIrGm4rQ1qKT 1exfmgVYm2IrqByc9DRBdSW8BXgqR3HSrXvLUiT5JaEl0yvDGwYEkdM80sRWLSTJJH87kgHPWplf lLjyqTfkVY2l2kRkKrd6n3bYPIjk8yc8805WJg+/ojUibyrHKhWbJJ4x+dZF88LoAF/edcg9KiF7 3NaluWzIbexe4YDeFGCfm4qSRIlcR4KsuNqkfe960cm5WRiopRuy41xdxstzlWhK4CnvVsTSGCOW ZQh6gBcha55Rja6O2E5X971IriTzLNsgY4IcCslonUkjCpjnnk1vT0Vjjre9K5esXCzsEk2DbknH Wunju5XtYkREZM4kyeo9awqxu7nXQm1GyKE7RtvjVWRk+YAdPqKwbvmXefu44Ge9XSv1Mq9nsZyO 7XY+fYGPLE9q0rhliaSN34A+Vk7n2rdrU5Yu2rMtY3fqCR1FdONGaW4tihIjCAs56A46VnUnyNHR RpOdzYZEhi2xnEhGGJHalVXllLBDgLncfUCvM3V2ewt7IZteOWKWdVtmU/cLAh8859q1Y4pLos5U xSluRj71VOzVzOndSaZhXMMseoMGnVQ0g2pnBHtUa3DI6LcRiM4wcHPeteVSWhk5OMr7kyW0wlE8 sw81TuiQ+nbn61cNu9wYpWfy5lYtIgOQxrNzipehtGnKS1e+v/AMjV4Zo5nlZVfAChi27Ofb6etQ aYImcrLbq7MAoU/LznrXYnendM8ySaq2ZvxReTCYrhGCI+VzyGB71jaxcxppjJHKwR3IVB0IrCCc p+R2VHy0/M5PcCvzKM44OetP85jFtPze+a9Kx412XoY4jHkxmZz1GcYq1HazSsJSFcg/dJ6Vi3b4 johG9rI0by78q1VUf98BxxxWA95cSXDSO2xyuN6jHFZ0o+7qaV5e9oQrdXEcu4uSSOrc10FiP7Tu ZDdhWEWOCcZ/KqqJRXMiaUpSfI+p0MEdldXzlFIuUxvIOVX29KjmsZU1AyRTEIASwfkEc15zqShK 0j2lShOF4aMp3TXC6UyRspTBOCMVhJq7mMJIoAHBI6muqEFONzgqVJU5fImS7tPtLXEfDEfdx1qh e3kk8m0grGD9Oa2jB815HNKouT3epFLc27aYsBixcIciQc7s+tVopZopN8LFGI5ZT1rdJ2tI5XLW 63OnsNUle0+zzsnmg8CQY3/j61Vu3uBeeUPLKkn94o3YzzxXPGKjJo6nOThfqUzqF9bkqJmMa/dB GMU1dTvLqVIXKupYZBWtPZwepkq1RaXOnbwwsumm5WV0CAeYoTd+XrSWXh+8w7RENFIvG7gt3x9a x9qpRszr9jaSaMzU/DOoWsDXIRPLB6I2SDWrpNzLHpCK4Jc8sCvP40VJRnBNEU4OFUvO/n2jwyRh 9w5yexrjNStI7Sc7JRkjIQc4/GlRdnY0xCThcz/OZ4grPwTliaZG2Z1MWSRyecV2WPMvc0GtxdXj SEsQe+MVYFhbxR72dmb0rFztojohT5nzMcybpypQMpHFRtpgljD48s9T83FTz8pq6SmUZdPlWUbT z25p0tqyJuaQYwCze9bc6ujn9m0mRJsMLBCzTg/JgVoWLRSwyRyqfM7g96id+W46fLzK+xMYhuAQ gKB0zzUTxqrFuFb371Cepu0rHP8ANNY+tdRxdC9ZbN5Z0EgH8J4zVs20c96uF8sM2SM9qybcXc1S Ukka8aRwOqBNq9cgdaZdDYA0gXyi3Qnk1zLWV2dj0jYiE3lMZXQnIwqgdj3pZ1je8UHaJMZBzzV2 adybpqzEl2QWcjyN+8HTjGSa57zGY8sTWsNbs5qj1SLMasFJdirEgDPpSzuxiSIElF/Umq3ZG0fU YEnRATGwz0NaBgUlJY2Z5z1Ve1DYRjf1N61snEWyd+D2HGalm0qzdkK27O/AOxjj8ea86VVqXunr xoRcPfWpm6xZxwWgmCyRYOFHaseGdVlRmzJgd+o+ldUG507nFVUadUv6gYUsIymVYjITNUEkvIsz bTtAyQ3Q5qoq8PeM6jtUvHoMmupJkwQFB7Cp5Y7hbeGSRflYDcw9K1so2RleU02RoER96k5I4B6G tG3u5rVfmPmgDIXPH41MlzLUcJOD5kRC5uryXcuSckjHasyeVnkKZy5bkn1qoqK0FOUp+8yQ2Mw1 AWxw8zHjBrQGmXX9pQLKmeMkHkAVMqkUaQozk9upt+V9mkQiJWiI545FTS6otvbSupV8YPlleG9q 8y3tWj2HL2MWc+mqXcrOxjMwzkqOAPpUtvfzQXjHy3nc9GPIII5Fd7pRs0jy1WqO0ma41WG5mEV1 GYSdpZZVyBg9q17fUrF3ZNwTJyoLgZx71ySptRsdsK0XLmluPvYbfzo2dVwerHByRyKpmSOd0jRl Zx8ylFyNvOQTWC57HW5U7+ZNJHHFb/aXdEj2ZcnPBrLuNVs4tNZ7SdJJ8YxyMe9OEJVPQmrWjST1 1toc3a6q0MbLcR+erNlvmwTW7bXLajqT3NrCGKYw7jHl/l15r0Jw5byvoeTCpzWjbU0bh9WuwSxV Tjkng4HWsDUdMvY9LPmT+YFO4oRj9axpypQdkb1Kdacbs5xRmE5HzD36VqWGmSXjfO4hQ52s3QkV 3SkoptnBCHPJRLf2K407XY0uI/tHzZCK+N4PQ8VoXNnI582S5NqmACo5OTXPKUW097nXGE4qUX0M 19PuYpyATOh+UN1JNR31lPDcR2mxvNKBmHYnr1/StFKLaMHTlGLbJbm0t206P7JE3ntgOCckU60s LiCfckrlnJUleDn6Gs3NclpG0ad5KUDo3mubd4wBGkGcyyMwyKL24YKJ4w0kMgAUJyfrXnpKTTv/ AMOeneUE1Lp0Gx2cgt2JOTKp4J6HHH0rkoNMkaWX7QDC2cDB7110ais7HHXpv3WxYbXbcYeReOeO uKpXc8r3suWyGIOMADjpXYtWec1yxsJHbzyoriMspbqB0rqbWytoIwFjMzfxM3T1rnrTsrI6sPSv LmktCS5t47mxd0A3Key8g1zn22aF2VlDsGPLDBxRSvKLT6Dr2hJSXU0RA+o2yrHF5rqu4neOKmsD Bpc7/b41KZ7puOetU2+VxT1M1uqjWh00XiO0j0IiKYzSFgo3/KMdeR9avWGrQNbGS4uJAwOEhIGC T7joK5fZtK7Ot14yaQ281ALpsoik+/gOB90e+fxri557+1vCdiyKemBw341cIxasyKkpLWPQTULy 6hsxs+WRuHI5x9KwUmcwNG3KdWJ61004rluctWcufUgbaz/IePetqGziW2WQcydG+b+VaSlZamMI qTY6S6MdztZg2enantkuRtOT0INY2tqdPM3oxfJkj+6xKdcE80NcPvQsfu9fcVGknc0u4KzBphJF l9oBPHUGs+8ifyfMUFlBHOetbQ00ZhPUgiR1tTcxbt6n7yjpV6O/jNspmIMhPIC805xctSIS5N9m V5on+1+YrMiYHPepieRIrbyB8y9fxpblK6ZiYP1+lBRiehrc5t0SwsY25PU1oR3Ci+iYEYz1as5K 5rGVrHRSxo3lyAB4c5APNMMBk/d581Qc7ielcSlZHoyjd37jJREE3TMqGPjk9TXLvM/2mSRXJyeC etdNK73OOt7r0Ls0ouII0aQnON2apCDdMqqwLE/nWkfdRk3zPc143hclT8zL94EVTmuYy4CqWw+c HuKiKfMazlHluWJ9URrLyxH82Oo7Vd0OJ2Wa6IJxwCKzmuSm2XSl7SqvI2YAbhzIVki2kgg9DUVy ZheoI5zFBjLBfvE1yRS5rPU9Gcm4XvY2D5cunH7QY2GOC/f8+9cLrDQR6j5VsiqFGSU9avDt81uh liuVRT6la32upM8nzHuT+tXorT7RILWKXz3/AIQv9a7ZPlex50IqaWupGLK4t3kM6YVR8xBz1qgZ HNySC0kefu54pqSlqiZQlHfctsrvZtOIj5SEAnbwM1fsYILxkMkgGOCgPzGpnK0W0VGF5pS6mhaz SHWTbC08u2GVVlT9c1VvdLWKdriRlOXwVHG2ueMuSe97nbKLqUm9rDIdNlv7hXSXywowJM10rusN tl23lE4bPXjmsqzUmkjTDe4nJ9SCSCa9S3MRzGwDbkPXHY1S1rTXhtN+wRZTHzN3z/8AXpQkozjE upFyg5P5HKzytHCscXC4G5h1Jp9u97qF1FaxuTxgYHAFei1G3NI8lOUpcsTYl8PFbQu1+qSg4Afo T6ZrnpYrmKcJKrBgcYYVFOrGp0sa1qLp9bnRQQ3bWaRK4AJ/eFjk/hVc20/9qLFbMybV5OcY9RWH PDmZv7KXKu5au7G7GlpDFcl4z95GOMnOawjp04YgkKR6nrV0qkbbWIq0ZqWruVJI9kmCcv3Ga0NO u72CTNspdRy6gdRXRJRlGzOSLlCd1ub8XiG4t5p4p4FPB4cetY99q95ODHKMJjoBwRXLChFSudk8 TUlGxjK2zDe9dTDcLD4XMRljE5bdFuOWAPUVtVV7HPSdm9Q0udotUjubhxNIHCKWOePT2rq0js70 3NwsD2zR4PmMcYI7EVy1LqXMtjspNONnvuY2oaklrYLHHEVkBBG7sQetYU2qXF3MJ7l9xUcLjGBW lOl1e5nVr391bf5FqKSBkZw5Q4BXjof8Kha8ubbUUvXJmtTkIVPGcY596bhzXUjOM+TWPe5Bfaq1 2BCqlAx3OAeCaqRG887ELScHO0ZxirjTjGFmKdWdSd1uW/t92QyPcEb+CxFTQedJfJuk24BByeCf ehQhDZC551GlJla4WeLVXlaIED7vPQVorown0T7XuMrMc7l/hHpSnPkSaKhTc5Si+iuaOl2vl6Sz IoZsndn+KpZ1mRVZI9hJ5JOOK8+VnUdz2ad1RXKSM5WBpI8PtB3qx6Gsa3sBqEbyXTLCRIFyOpra i+VOXU5cRq1Fk1sLO3uHAkZPmxuQ4yaj1DMu91AmAJKkrgj61sr+0uzlvH2dkctMpFxxg5wRitCG e5LKxJVFOGZhkfnXW0mtThV1LQ6Sxv4biURsqsm0hmOOTVLUL2R3NrHC21fTrn1rjjG07PoejObl SvbcwrgXoiWSfeVxhSelS2yINLnkbBbpyRXVdKOhw+9ze+UkVjLkr8p59jWwzMY44zGPKxyQec0p 6tDp31IWt1mlDSAqRxgelaMmwWyueMDHHpWEpXaR0xjZNkQkclcZBznnvUjgOCzgDPIIHSpehqtd yBt4xuwH9x1FWCiPA4GcqfmwOPrV36mNtbMoW6fZ/MdW8zf/AAgVlXbu987SIEfjgKFH5CuiLu2c slaNi3DdeZCFkbngZ9qvCIRysiJ8rjLEHnHtUPRlw97UzVjUe/NJIuB6VoYtXVyqAWnX3NbsfkQy JFLtBzj7uazqXa0NqVldsvJIFlKxkMmeg6VaQkSDb3I71xtanoRs0Z17YeZcu6yM7NlguMgfU1mQ WsbNuduM/nXXGfunDOn7468gQQmSNsH6YzWerDy1JUbl6Y71pF8yMZLllYlJI+fI3enrUL4ChQVP uB3qyG7oIbeWd1VAGy2OtdqgTT9ICBlRcckHkmuSu72ijtwy5bzZE2oGWAwviOJlwTnmqAvPJgSK P5ok5w45/E0owshzq3dxZtcWXT5YGi3lhgdvxzXOMjh23ghvQ1vTp+zTMKlT2lmK2WReOg/OtiHU EsljaFMzbQWfp+FOcXNWIpSUJc1hJtU86aV1zE7LgbMYOeua6G1jtW09iAmUUeacAA+9ctSMoQVj uo1FOo3ItQ+R5BWMIYWH7xeorAmuIbDxTH9mVVZeG3jKjNZUuaTafU6K7hGKlHe5oz6jC8O1S1s/ Y9v0rM1WS7NukfnLPGcP5kYOB6cmtoU7NcxzTq8yfKZC3M8cokRzvA4zzSNcXHmlmypxz1rr5Vc4 HKRu2GoalHYFxMPLydof+lRXerXM9m6T4uY2YEBv4a5VShztrc7HVqclm9DBIJZgQeP0qS2a5hnL wMysvORXY7NWZxLmUrrc1bjWJZbUxzBJG3biHXOPYVWd521KK4uJlxIA24fN+lYKEYnQ6k5u/Y2/ t0MCJvdZJOMlKlQi6cyW7eapbk9K4ZU3HXoerTqxnotwaaNZvLkcK4ONrHnNW9W0u4XRlMCrK7Dd KvII7jFEHyTV+o6iVSEkt0cEuftBDj5geQa6bSb21iRt+yN+hcE5xXdWTcNDycPKMaqciSW3trm9 aa0cP5i8cd+/WoDZsiu0jK5AIYE5IqFPlST3LdLnba2Ma7jAI2DgdcDGKjtoHmvokjyGLcn0966L 2jdnMo3lY7Wz0BIJY5hc7s+uOv0roUtnS1KTytk8Z4+YE56ivJqVlN7antwoezW5ia9olnIi3FpO 3ntyQVJVvSvP5HI3I4O8Eg4ruw9RzhqtUediqUadS6d0x4nk8jaWNS2tubhm8xjtB+UD1rpempxa s2oNLMmQu0vwRmujgkaOxNvNGHZQMbT1FefVkqisuh6tCDou8tmcprP7vVDKsTR5HyfL8uf6mq8U 7uA0spjfOSoXIYe9dcFeCOOq0qsuhLNdGRn8vnC9GFQQ31+tqojeSONRj5eBinyRa1M1UaleJt2F 3thLQyu7d0bGCanutdWRXS5hBk2kKOx+orjdFynfZnoxxChDuivp9+buecXGyNsZ3EYGPelvLcDz JBlGYZLDvSs6dWyLTjWoub3MgBVyY/lbHc9a1obhW04hojExyQ5Oc9O3pXbJdzyoStLQx5NLnlBn RllU56HpXU6Y9vD4dEDFZpWJ3oRkg56EVhWleGh2UI2qcz6medOgjlMwzbyJlhs+YE+lNInXXI9y NKsgGXA4FRzc2++ppyOK07o0buCOaxmi8piRjHOM964KXHmkKTtB/GtcO3ytMyxSjdNGvGLhrfMi iNVXjAGfxqsspcEEnBPStUlqcjb0ubcUe60UMQRt/GptkZhYDGR0ya4ZN8x6sUnC73sU5MiFmdC5 9BUMJm2KZcqa30scrUrliaQOAH5YDjjpVeMyxpnG4AjeSMcURVo2YSd5aFK6nKXfmKBtz0B7VK2d RSUJCsciqCoJ+Zj35rotazOW7u0Zr2txFOFkiZG4PIrYCtCsQLeYeCfm5FOVmKMZJu5S6VE7HBFM krH5ZQTzzW4I45J/NcDfjOfrWc3bU2pJO9xQvk4SNC8hOQN3X8atnUVtSDMgaUj7q9qwa5/U6IyV NPsULnUZriFSQsKDP3f4jVWNlW0kEbeYx5+lb8vLGxzc7lLmYs8nmRQllK8ckjvSQQF/ugMx9ape 7Ezb55XJfsys7LJxIelRS2ygYEROBySe9HMPlVitBL9nlLHKsDkEVPLqEs95vcnyh/AabjeVxKbS sVhdSmQkYweikU43Eiq6yfxe1VyojmadzU0qe0jkbz0UYy29gM/QVn3c7XepyyouNx+UVNnzXNHJ cqihnkS29yjSr8obr2NbDac17K08cqfN8zKvaplNL3jSEG/dKc2mSw72JQ47Fu3rVHfIWZd7MW4I BzmrUozVzOUHB2ZbB1C3hMS5jU8ntmoDFcPdLuUtITncTQuVaoT537r6G6WgWzLSRGSReuT1qGMt cacUkCQRE7lJbGeax1SuzZWcmkiZrGCxaNrnbIr5KEN1xVczW3msyEuQR1HFJSc9UVJRgrPdGjNc 2409cR9a51Q1xqKxRfcJ/wAmimmk3IKjUmrErafL52C6hTzksKu2ltLHC6pEJSwAfPNXKSlGxnGL i7lWW2UTkmFmyc8NjAqGaNmm8qJGZgN3ynPbJq0+5DQ14c4dXDJxwexrWtpJLe0RQh2SHcSp/D8K VRJqzKpycXdC3FpHJfmcyYdmDbu31rbHillszHJbrKUGC4bGR3rmlD2qXSx0wq+yk79TibyeO61C W4jjEe9uE4wKbEYY5syxmRdvzAHoa67SUbdTi5ouV2jWsLiGK9WWDdsHZ+xrRllkurmXyIzIQpJI 6CuScfe5pHbTneLhH5F6xso5rRI7q2VzjcD3961bXSrSK7nuEVUz1weAPYVw1a01dX0Z6lLDwcVJ rVEc9zb+Y1vGWCqeuzj86gSX5yGnEYUFV3fxd+KzUHbU29pG+hbjmlmtCPLaR1OAZD156r7YqlqO i248M3lzBCksx5YgjKYPNaU5OE0k+pnUgp022tbaep58CwLAge+a17J13IM/MvJFexJaHzkXqX3v XtkEm4tkkrhf0ql/adwZlyvzO3zE55HtisVTR0OrJ2bJJpZJ4hlzLsG1dy4yP896gZbUSKmWWXGS D+dXFcuiM5Pmldj2CuV/d5jY/exwR3p0yQTRNGhaNI2+YZ4B9Kd9QsrFq1Qo7xFEglf7vy7lA9fa sOV5P7Wk3KJHDnH4UlrJg01BN9zYtkEincvzNwVHFa2yPEKNnKL84Y/f5rnlO0jpjDmhcyry0Nzq 0jqvkKw+V0X5TWg1q+n2sKySRToyZLg7gBVymmkJU2pN9hFltvKYjMZK/KOxrDDzQ6k1xbOCN2HH 9DTjHdMVSom046GlDdDzxHJ5jq+Fb5cAVrabGdt20lwrOz5Ck8gdqwq+7Gx10GpzTuOubiKGItNI yrj5QfX2rkJ3t5C0kSCJQT0U5J96ugnv0MsTKKXL1J7NUkuC0m0KfvEd6tPDHEWiRUMLDOSDurVt 81jnhFONywjlbfymQqygY460qKSm4j5c5wK53o2dkXdJPoTgRthVwSR39aYY1VS5IyDtqFfqaOxV VZVnR5U3I7YJHb2NXfspgWSSQL5AXOWbOfatm10OdJtu/Q5GV9+pFsfJu5GeMVrxWLzyfaBMsCg/ u1xmumUuVXZwxjzyaNmSQtpyvKGIU7CWP3/cegrGxFJdkfcJHLdc1jG6R0ytonuURyPmNNYcHIro OQpv9/nmtaymUzspXnHPFRNXiaUnaepsiWPZnYrAc1yt9cCe+aRF29sdayop81zau1ZDVdXi+fgi plkSKI+WwPOcjvXU1c4rvdELyu6nLcdhTrSXF4ivudGIBCnmnbQI/EjXuo5YJN7ZEbH5R3o89TE2 4844IrntzRVjqvyydytBZPqN6UiIVAcnJwKdqOj3FpJvUeZExwNozj61XtIqfKyfZSlTc0T2WnRP dbZGVnABHzd/Qim6vayCQSFRtXglR/OoVS9WzNXTtRutzIRVdQu3c/PStHTnDytEYlYdeTg1tL4W c0ElMsaoPLiVUUsp6sTmremndpbC3cJcYwx7kVzu7po6o2VV/gQXP9pPYHNuxyuGkx1FYsDTQ3hk jGJE5wV6VtBR5WkzCp7TmTZoRzStARI29lOWP1q0k6tJxHhux9aGtNCb66l4LHNasNoTHV896htU iuop4ZpfkReNo5BrGTahfqjop2lOz2Y+CBLiwkV0x5ZO3cevuB2rIhDx3cjtFkJwVI604Nu6uVUt HlaQ5lMlruAwpPHvUVtKLWSXhWZuGyMnFbdLHLtK6J7V2W6aTzVSNuDGMHI61qRvuk+XIGfoKzku por8tiO5hMoaVGwSQDkZqndAx+SU3h+3bn604u9kQ1bUht7q2QzDyQJH4Acbtv0NasBhYFwxGck5 FKakk2VCUbq5XvLgmMhCVwuDkdc1zeBnc3I+vWrprljqRVkpzuPVXkDbULFRkEdBWzof2YXU32kr vIwu7kfl3pVeb2btuOgo+1XNsaD2hhvnmjt/LiXPGBhuKu6CftGubQWjiKneNvHtXJKSlSbbvod6 i4Vkkram4IWj8T5ZS8APDKcc49PxqLU4ZX1GIwyKgDb2QvjdmuJTi5L0PSlTmoyfdnM61LLbXqjL Rq6jKqwIOKv2ciXNlCfLByuMv/WuqUf3MZI4YSft5RaLly97aQIkEKTxxMsilpDnPfmtiK708QPd EizaUb5lySpOO1c8tYrle+6OuN4yamttmeYak8Nzq088G5Y2bdtPXP4VZ0e3+0XrO+fLRSSfWvXk +Wld72PAUVOr6s6i3ktrgSJ9mBiTgEpzmsC7ZLbXNkaZCnKBuApIrlp83O0zsquHs00izMkV5bME BV4yASDjr1+tVViWS3Lna7LkK3Wum7W5yW6lZDsjILiIqcE9c1ZTP2aUzKvkMATIGpsSd9yW7Zp5 oYbfECEBcbuv40yO0ijfc53TKcOBnIpXtZFNJpnS29jayPEwuljYrkbqdcRLFJ5nMgjGCQOp/wAK 81ybnZnrxUVC6dw81G0/91GUjKYKv0z9a5S/SRbVpMgsGz8p4xXRh9G0znxWsU0T2cn2uMTzMXZG wQBzgCrz2/nQOYIkUKwIUfTHNbN8rOOK5nd7jY7aU2BkZ174JPFQR3iQ3KsUG5jtY56jNQ/3l0ja 3s7SZaihRneRLhrkyt8oIB2fhWdcaU32YkfLLkllQ8H35qYVOWVnobSpqpC/YitrVreQpc5Unnju K0JkQxqd5iIPAzjNXJ3kn0MKcUotPcYsZzuVWk+Xrnn6VGskiq7mUIoOF47980tHqaaxtZhOACJE XeScj5sGo0ZmYhwUO4d+TTWquQ9JGpbQvuMksu5UOfL6DGKiupY7vKI+YuM4PU1CavfsXLRWe7MC XTrhLoIpPzE7W6D8aqedcxSFHbhG7HvXbdTRwSi4SNq1FzLMWnJdNn3c8n3qJ1ghlILEFic5ByDW PXQ3S0vLcouCVJzTWYY561sczKkpyc961reNBpqzA5kZiG+nFZz+E1pL3mWpkJiQL8xJ7H7tI9lD LbbWKpIcfMOawU3FHZyKTZXu9P8AslkJF+fnOfasdnQqABh+5HeumEudXOKrD2cuURULdDx3q1BC pnBUlmBB61o2Yrc15hJNdlXfD7ScMchqrTeQls2Sw4/u4OawV7aHTJK7ciLTrjydQDoWzkAHHH41 18ly0un/ACoWYn5mAwAfpWNaN2mdGHlaNjBZHZhMGTcX+cMR8xq9eSCXTiEXarjBYjof61Mt0VHR M5DayzFP4gccV0unxxIpVQJpyAfLzzXVUb5TipJc+peurF/s+4JtLghI/Q/5zWroeiRWccVzcMzX eflUHCj/AB4rklU9y3VnoRo/vObaxe1iPUE06dobYxsQCoZeWz6Vw1vDK4ZLm2bzWJPKYyO/41dK Ps4tPRkVm5zT6Fa6kQ2sn2eLyl4BOMbjWfDNJHODlie3pXVFNrU4Jtc17F501BoXOW2tjgEjNSaf b3iebNGAp5U7xUScFFmkIVHURVuZLg3A82QfL2VuvvW5C6rpRmKcuMqzjk+opNLlVgTbm2yrJLFN pwufLKKpwMHqfpWAzs0xfcSc9fatIIiT1BWbcm7O0frW19rkNr5g/wBUDwc9KJWvqStmIur7UYiM u/bPT8a20tbi+0mG5aIM7PgpGQMrn1JrCdqfvM6KMXVbRRfw7cNqOLaRcbvk3/n1p09lNaT+TKA0 uMh0PysKUa0all1KqUJ0rt7Fe9Als8RgGTHfqfxrnCecda6IbanHNW1OxggtbXRPMGHDJu3ngnI6 VkWFoJtQDOwSMYOeuea54SdpSZ21IK8UjrdWjNpp8EkbLIsnAJP3ePSuZ07Uja67E8jO0O7lVY5r KlDmpM2rS5asX6HosN39q0ZrxAFLg8yDBHWsNEW6eOWaUxuvUAZBP+FebBezb7rQ9icvapLa+pam S1Gk3Cy26zSMwCPKvOcdqyoBDFZiKPCkH5SDnB963vNxt0OZKCle2pdhV1ZjM4dc5PPFZmvwltNE 6yokGB8o+859qVJr2yfQ0rL/AGdpvU4rD7XG7t69a6zQkjGlsVu081iQUwQQD3zXq1/4Z4FDSqtT Qt4mt7+SR2Z0bqueM1yWqzi61yQq2E7ZNc9B803LyOrExUIJeZpQmQRmVVwCo3Ip+97g1OAVsgrB TJj7pIyvPr3rpvqca2KN7bJCkXV2zlkVupPXNW43imtktSFRBjcxztH1pv4bkreyK9zYuIPtDOjh Q2Skg6f5NU7Oby590gM+75eWxjPvST5o6GjjySV9TYkaO3uvLYFnxkENng+vvVhNS2gOXYqOBGeg 9zWMo86ubQm6UrMJZsEs0/mRuDmMHAX6Vzl5cgr5UC7EP3jnn6VVKLvfYVaaatuXLHz4BCkkTKjK W3gdQa1Yo55dWzGWW0XJLbuKc7Xuyaalaxq3UcNvYbYpgWAyY1Uk4NYEUiqpWbZ5obc6BfX/AOtW FNNq/U6qrSsEc/2S5W5DFlI4Qc5rTUma/NxLIdzJwi9jjvUzVpc9i6TbjyfMkjtFu9ofnqM55A/p VVljs2eO5QvGsmRKeaSm5e6OVPk9/cJJo5QwgmWLPIPX+dKhtGSRZn2sFzuxwadpLZakc0HqxkQg +1gOzORzH8p/PpSahc2iXG+N1L4ww/zzmtLScrEOUeW/Uxru+KR7oZGKsvTNZMLzS3APLkclR3Fd UYpI8+U5SkbwuftaxBb54Aq4ZGX+o61nStGpeOJzLGRzkZyfWhK2li5PmV7m7plxFJpiRkgsnD5q LUYhcTI0B2uwOe3bvXPG8Zu51aSpIw927qfzpGUHmuo4VYryDFaVvKy6FIQN2GBPoP8AOamavE0p vlk35EMk43qRNuOOgFdLbrFIqy4DMQAea5qqairHXQknJ3JpohLbsknKngCufOkEyhkbYucYY8ms 6M1G5riKfO0+pEYEj1N4GOV6mp4bQpcsykbGHysDXU56X7nHGneXoXrKQG4DykrICyggZya0dQ0t 5d7TxER7QUQHGDXO5ckjpjDnhr8zMjtnggYKqEA8AN0psEs+6TY7FO7OBzVNqSZNnBpDvOBYqCpH Xp3oMygMrNw2MZPGanlZTmrle4WCKUSlNjnpnvVi1vBayebGqtIR1I5+tbNOcLHPzezqbFu316XI ORIAw3bh90Z5OO/Wu5GrWFvLBfq8d3axujqB2wfmFcjh7KrGS7nfCvz0mnuj6Eg1Hwd8TtMQzpa6 Tq0p/wBbFxEzH1UD5fwryjxl8PPEGi3kiWxWWFSQVjAbf6FX717VSjCuubqvxPHhVlSfKnueSXlp LLMljegRyCQAYTDH6+9bFv4W06O3eaWIyE52MzngevFeHWrSoqy6ntYehCveUtbGVqkC2se1G85A OByMD3rJa4jfTjbxybGbJY5q43nBMmSjTqSXyM2a0sv7Odxd4uEONmM7v8KrrfzLBHEGzs+6rLXe ryWp5crRej3J2kmltpElVQwGCMdqrw5S4jGwFs8hlyKaSSdgvJtM0LjSi15vVQsLAFVTnPP1rMvU mt72SOVGjXPygjG4euKmM1Ic4csW+hLYw/aIpF2gP/z0IztHfiuw0u6ddNiWRTPBHlVZRg4rmrpN WZ1Ybmi00iebVrKxuI5JFlI3dAvb1rK1Rpr7xD5lqgih8rcr7Th+O/vWNKm4Pnl2N61RVVyR7i2W l6hcwM8yiNeuGHNc3qELQXzxug2p91tu3cPWuunOMptI4qtOUIXkbNnp8lzZQJezyJG/MUaqWbHr gdqtato/9laZbv8Aad3JBCdyRkceuDS50p8qRo6UnTc29TKl1AXemNbrAVn2jMmTzjt+VYzCZGG5 WVlwcY5FbQjy6M5ZycrNI3NO1O4wElkaVB1BHI/Gurg057zT/wDRpwFLDDAgjr0rz6yVKV7aHqYd utGzept6nbXMempHsKysMMoHDY/lWFbWhCiSRFXk8Bs8964oyShe56Ti3O1iV54bWMy3ilLaQgEF efauV1m+S9ijTy/JePOwKcqynufeurDwlz819P6ucWLqR9nyW1/powir7WB+YdzjpVi0uDHc8ZZB jOOpr1WrxPFjdO51kkyw6dbyT5BlcjPsOprjb2KSG8zJllbLIxH3h61zUElc6a7crXJ1uJEt42hm bp8wYZANS7buVVmkBKk4BUYBPvW+i1ZypNrQ0JdHnkmikjukdiMMqtllPsPpXQtpjTaIsMNxsiaN S7Y5yPWuSpVS5XY9ChRu3qVf7ItoLeUXTDaThGwQxz7iqNlZrDfSwrGzxleGJznn9KlVXJM1lQjF x7lnUEiikSSZ8HG0Z4GPrXOyTwGH/R3b5W5LDlhWlJSt5HPiFC/mVftDOzCTgY4I9acuYhkKHJOe ecmuvY4N3csW9wAhhkI2YOc1px3WyA282XiC544wMZrGSOiDZM+oLOrLFIeAMbRyR6VkvdSvdS+R Htfo7MMkjFEYqITm5Wa2LNtBauYHWcO4GXjz0NbUUcr52AKuc7yBXPUd37x2UrW91mTc63LHeGGN F4fBA5zWn9mFxGzTmQRTLkREdDUyiqST6sqE3Wk12Oc1O1trGcwxTM8vdT0UVYs9St0gBvAzMgC7 R/EK67OpBPqcLcaVRpDbrWVld1jDxwhcRjjI+prNgWGfVB5rl8nJLdzVpOMTOUozYpjie6aJ5Nr/ AMOOhrU06ys11dre8zLEyZEkfVTj9KG2loKKXNqP+xSW8tyicRBvkdx97/GsRYbiW8eFV/e85AFE ZJ3Zcos67TbFLaBHkB8zn5iKbdrEycOYZGGRg4zXKpN1LnZyclOzOWz6UuRg5rrPP3RDLyKfAzm1 miU/eHP86b1QLSRbtYYvKB5aQmtUwSCBkiL8kklT0rCctdTphC6uiVJbmWLyAWj7hz1qK4ufstv5 dxN50mMgjqaw5Vey3OiU3y80jHtMz3crtuZjzmtVo/s+n74Ubg/M5PFdE97HLD4efqQRMZrkKJOA d24Dv7Vqyz3l1beSly5JGC5XIGOozWc1G6utjWDfK7PcYto4Tc0hxjDc96qXELBDGrP789azjO7N Z07Rv1MlGMOoBZT8h4Le1a0PkTK2cSKDkPyvFdM19pHJTaTszPv7hbgLGi7QrYDY4xTRci2tGhAB Zl5LDnBpqPu2JlK83Iz2dEuMgEKw/GtSUwvpa2llI8jOwZ1YdfpVyu7Gcba9yPT9V1XQ9QElrM8D qc7c8V9D+CPjVtu4rfXCGRhtkEqh0cYxzW9OfI+ZGNSLej6HrOraF4O8a7r/AMPxRadeSsWitTJu QD0V+o+h/WvGfEnhfxPoFo9t9je6cy4j34GwH1PQjnr+eKWJw0MSlPZnXh8VLDtx6GTrvhTxPoel I+saTGGkTJCgkYI4IOcHr2ry/wCwzJcMgj2rJxwucfU1xun7DRvQ3dR4h3SHPYbWUkBz0I6Gsi+s 2trrcyFYycgHrVQqKTsZVaTirlixl/c3gfmSRRsVh8reuT16V1lhaWa6MlyLbbOU+YOM/lk8VzYh uC06nZhYqo9VeyOIlupINVd7d3jCnMe48gVXmlmurkyyuZD6nmu2MVu9zzJSbuuh0UNncppvlII7 SQncS33mFXvtvlokL8KuAGPAJ/pXn1LVHoevRvS1l6eg3UI91sCCCzAEZXpmujtb/SG0yKy83y5Y 1BZlQ7envWc4zlRSiVCUIV25dSUarGSqLazy2yqVZxHzisme30u/lDTyNIq4Co42Nn3PcVjSjUo3 a1OitOlXa5k0aN7NNZ6Wv2aGKcIvG99pjUd/euS1Se9uLP7VdOr7D8m1wVx0/Ouigk0pPc5cS2m4 rYy7LUIIZ1eWIk5JYgZyewrq7TVrK8RmmjiWR1IZNnT8fStq9Ob96LOXDVYRbjJHPzWhu5ibe3+z lmwVDdRnrW9Y6adPmjKy5YnJX296ivVUYcr1N8NRcqntNjU1XWNSs9EKxgyuzcM3IUGuUk8QXUNu Ve2Ecx5Unj8cYrChQhOne5vicRVo1GuhQl1jU7yIl5AwGC3yjBxWo1k2rWy3Y/cXPCyrs2rkeld0 lCik0efB1MQ2pDpNHubBBNLMJrdl/eqCQD9ayms4oy7/ACjjKkniqhUU1zRFUpunpIQ213cENcuF hjXKY6YpIbW51TU4YlYuMhMseg61XNCKbWyM3CcpJPdlz7DcW+sSaWv7tmYHkZ3Dt/OtdrVja5mf 7oI9K56lRWTXU6aVJ87i+hXgsgxZ4pBn7yn1pJ7jULNGIuMkc7Ccg8VKlCr7rRUoTorniypb3Fxc Ro99JI8SkMgPc+ua3o2t5ZnIky+35kyQQPWlUjb4diqMrv39zOmiT7PItzIrQ9IlbPccc1Rj0n/R t2Eff9w5Ofx9KpVOSN+gpU+edjMuLCZXdhCyqncDiqUU8q3CZc43cj+ddkXGcdDz5RcJanULpUKQ xTlWdXY7XJzn6ineUZb9lmy6BMAhcZFcjnzandCm07IguLS486NLSLdzjhMEZ9faqP8AZk0F0VlV w3GCvrWtOpFx8zOrRlzO2xkyiS21FuoZT0rc07VGWxkiuYyw42sOorSpBTjdHPCTpzsxdVSxjtIb q1ZvtBb5ueh65qTRtSup7/7O7hyRuDOM4wOcVi489G89zojNU665NmX9de0geH9xm4bB3uP51KLC 0uZl823iVCM/usgn61gpzjTUrnXKEJ1nG3Y53VdLa3vCbdGlgIBzjPNY8ShpcM21j90n1rvhPnhz Hl1aTp1HEvm0WIxvOdyN/ED0NWb8TQ28RjkypXO7PJH1p3u1cXLp5mY91dybfNmZ9q4APaug0WFy r3b/AOsZuGPBHvWdS0YDpXlNIuXP22bIinCLuJDdQ349uaSeYJpyfakxcgY2gZyfasLJ25dzuu02 5bHLjpTgCQSfwrrPPvYhcHOc0+0Be72Zxuoewor3kjct08txCxAZSc8VaWURs+fmBPY5z7VxvWR6 KdoK5FI8klz+5IiAGSR/I1jXVndtcM7N5x6g1rBqMtTnnGU46PqPg+0RRIAvIPb+tbW2e4tnSR1h wCWVf6058u4RUrWK2nypGH2MJsAscr0P0rUhlm8gjcm0jcVVcZJrGr5nRRv0I48zxNlgj7sEBu9T JDCINss4d84BbqTWDb6G8UnuRCzSWZvMClR90dOade2yx6fv/dqI1yQRmrU3zJEunFRbZhSxzX9k vkoHEZ+8q7Rz2qpNpd9FYLcyIBH0+9yPrXapwj7rep50qc6l520KQjZAGdMg9CRXRacNM2FcyLd7 eHUng06nNy6CoqPP7xqziG5tX3ot0wXovXP1rlJdKukimmCEIjYIJ5rCjLlumdVeLm1JGzoHjHW/ D16jQXDPEp5ic5FfT/hH4naP4ntLex1Yec4wJYJH2t0xlW7Eduo/OvSpzcXboeXOClueo3NrdWvh rEYPibwaXIa3KgzWeR2PVTx06fzrw3xF4Qje3kv9CkWe2yCysuGT2Ydvr0qq1GNSNn8iqNWVKSkk eT3UaWxKyRk3LNjY4x3/ACrC8QpK9hGJf3ewZCmvEpxlCouY9qrOE6T5dtDlRLISgeQgDHPtWnDr Nyls8BbdGw2hj/DXfKnGa1PMhVlB3TKTsZpPLWHzJmb7w6mtWC3udO2TSWwnVhl425GP8aicopcr e5dOMpPnS2NaXV47maFHs/s7Ig2Mpzk56H2qeS/sREC6DeOchhiuL2MopJM9D6wnJtqxkXmp+YuB iXIGMdhWxo0Ea2kl1If3vy8k5K/TitJr2dKxlSkqlW8jadJ47maOUCNZgCEH8R7k1mX8M9xuMUIl WNCdmec1xU5RU0z0aik4NGNqd3NHpoD2gWcgI8hGdqjkVgI11eyCJjvQtngYAr1acYxje54lVzlP lsaA0ea8vHS1Xy4UUbiW3Ddjnmtd7S00yCUQzrPKi/vVx8wPpSnPmfKioU+X3mZ39vZnglFsAIjg D29DXbWd5YXUP21SvkqPnVj90+9cGJoyik16Hp4PERcmpepjatrCQh0tgJDnGSOFz0rhbh7i4uDN K5kLHG89PpXVhqXJG8t2cWMre0nyrZGlb/viIGeNvnAChSCfoa9NsNMaV4IwDGsakMN3AOO/rXPi 52sjqwMLtsj11Db28Vt/rI3PJQggn0rjjpVzcXfLCVgfliB24/D+lZUKkYU02b16Tq1PdLyyTzRi wugbaaX5fLfkbR3qaK0ks4BLLbxmBWw7JkvjPtWqtBct9zCTdR89tkNnltXnjvbe4IePKkyDnH19 KlikS7hVHkjeMt8r5+UmnJe76GcJL2jd9ytIoiuPmuVeMdx3rE1C7ilExWTICjYR3P8AnNaUo+9e xFeSUOW9zPS6eK1XA+jE9akbWZPK4jHmgYDg12OCbPPjUcSP+05/KXkuTnfuHb61tWmoRx6UqRWh YrkuxJ2jPfJrKpS5o2N6VZxndq5rqkN46xtICwXIwT1P865q5tba114RGYpcLLks4ytc9JyjeNjq rck7TbOkis7sXiW0ZWSBmMiEDgcc5qWPeVk3wbDv2q4bOR6/SsG4T1TOqCnDRor3OoPpU6SSBZFZ sAkc478Vdhb7eskkd1FNEzBolwdyn39s0cvLHnBzvU5DitZtpf8AhIJcHzDuAOB90+lPntL6yxBI nkuy/MT0z1616cWuWK8jyJxl7STJYrGC603Ybhv7SwT5OMKefU8ZxXS6V4ee3s1u/LMVyGzktuOP T05rKc1ZxfX8jWlTvJS7Et9Hvc/bLcMc5Xf/ABUkQjBHmy+VHt5zxxXnPmUVHc9dcrk5vRmXcXcQ iuIvOSVWUmN1OCPY56Vm21gl1aW0rurbQRtHDHmuyLdONzz52qytcCguPtNnbyhQjdHBOfU5q0LO JYUWSJnHqzEj6/4Vs5W9TBQ5tV/WpRvY7WFCxt3++NspPGM9MVt/a4ZkSAOjlkDLjjI/DpUSvOKk OFoTcepnu/lO0MPBB3bTnHNCpKwZp1UnHBTIx9aE7avct7+RhKvGTzmnn7uBXUcXQrSA7Tn86bbN sv0bNN/CQtJIvzzs2o7w/wA3HXjNRzXr7gQdoXkBahRVkVKcldXL1mIWgaaZirtzyetQyXDyT+XH PlOxxnFY2bk7rY6LpQWurL1izNqoWabJZThB0JrbMkcSSF8RoGyTgEmueo3zWR3UknC8jIkeKLWB IFCI6jceh/KrxjiSJMEKhwEYt1JompNIiDSb8iq8ZR5GdGGGwuB1/KraxRx7Nqh7ll3rGW5Iod+h cXHW+5LeebaxRzsB5sn3Yx9Ko2lwt1q3lyS5kb74x8pFTD4HIc2nUUWbq20iW+yF1+zDhtowKy72 4eGNI1I2knJIB3VEFzTTNKj5KbRzV1OUkYgjd/CMZrY0eAgG5nCeSRkbcc/XvXfUfLTPMpXlUsTQ x2t1rbyLPHsxzGM8++a1HI4/enamS4xkH+tccnO6TXQ74RjZyT6mW+n2tzdLHORFvchWHU+9Y1zo uqaVc/aY922M5WWJun+Fb061pcsvkYVqCcFOPTc9l+HXxl1DQtUig1a4cxnCGUEYdc/dcEEEfUV9 LGPw94utVv8AwnPHp+tSAt9hzlLnPJEZ6H/dNetCTfus8h6I8i8U+FbHWFmtZ7RdP1eP/lhjGWHX b6H/AGT+Ga+dvEWkajY3hS43Mu7bu65+tKrHW/UINXcTlQkhc4+cng4Gatpb3LWksa25UZBZsda5 20tzVJvoTWUc1rfJcvC/lDq23+tdfblnJkJMqN90MO1eZirP3j2cG3H3WvMz7rSpxqK3wG62zwMY x7UzVLeBdPacIBNIcYBHb1rSFTn5WvQyqU1TclJeaOat45Z9YhTADMR90dBXdxSpY6laWARpXmP3 mPp608R71o/P7iMJ7t5v0+82dRkTfEwVSAuMnr6nNZsTvCzXK3gCg7jlMkr3FeVTTsk1uezV5U7p 7HL6pq7i+njidJYpCd6sgPt1rnklkikVomPJ6Y/SvdpwUYWZ83VqOc79i9a6td2VvJFE+VfqjdBV iztpLqZ5yVjZiCDnhs05JQTl3CHNNqJo3MUUMTRTSAxuORGO9Ysf22C1maBz9n3YfBHPpUx95a9S prlej1RBIZpHfzJjvxyC+c1agjUaTJHIgMrt8oYcqfatHZLQxSbbbLGmWkM2s+VI7RSEEqx7EV6J HIzTKTe+VtGMnrj3xXlYudp6roe3gqScG07amVqUEDoDJOXEOWR8kYPrXHw63PDqkssreYpz7/TF XQgqtN3QYqp7ConF77mxo98t5qNxNKoM6IWDSN+Zz9K6mFY57NrlSzKT5kbHOG7c/wCFKunB+hGF kprXqZF5BBFp02LWMeYpMsgO0j04rjbW+MINvIx+zhiR7E1vQvUp3epz4pRp1bWsTX19bSkJBK6p /EdvWqMcFsbWSWSc4HRQOSa7I80Y67nny5ZT3KSqzSFUG41MFDIMKEwPmYnrWjMrEsUVwyuEXduX DY549au77qCyFtOcIcMoYZG0+lQ7N26mkVK11sa2i39tbXIa8kSZsZjOD8nt0qXXLGxfVftNtPln UOyBS2T7etcl5xr7aNHoL2c8PZv3ky5aamXmCCYxGEDazfLuOKjudbaKVYVEU4H+skAx17YHFcyo XnZnW8RanzL7jA1a4fUHW5A2KPlCZ5HvT9CWT/hIICq75FOdu/aW45613yShRs+x5ak6lZS7s9Ft 7C0+3S3CMqSt/rAwGT6VzGrLqE+uvaNP5qNIGJ5yRiuChO8ve6HqYiFoXj1f5lBtOJ+eNy0qEEBh wavR61qdis8d4EuUYAoH+Xb+Xaup8tXfRnn2lSd1sY11dXOr6gshLbFG2ME4CjritJmlNu0bxmYJ HtaSTrj2oklGy7BByleS6k1q8V/aBHtU8hRhW6HI61jMstrqHlxqXjL8YOeO1Ce8WypJtKdjft4J IJ/MKAP1G3GT6j3qHUjJOY5o52t3Bw4Hcelcid6ilud7i1Scdmc5fag8sUlpI5Kq+eg6/UVLpbQM zRuQJAMq5HbuK9Brkp6Hlc/tKq5i9Jl7lwgBIx05pkpfym3fNkcZ6ZrBWukdbty3MkkZppJJrs2P O8yOT7p7mqmSs6nvmqRn1uWLsmS+3AliFHehUGQzL05OalaRLesmzQ89PKDKcsD0xgCqYhBdpG+V s5CjoamN1e5c7Ow3zn+05B2tnjHFdXbTQTaekk7qRnHXBz/+usqy0TS1NsPJapmdfJCxO8nsS6// AFqswqFtEDSC4hPcLyPSs3J8iubKMed2ZM0jtHi2vF4JPzY/I06S6kjSKRiu5BjdgZ6dOlZ8qfTU 15rXd7mPc6jdD946NKezOMgZ9K27DTozpy6kx8s7d2ccA966GlTjp10OVN1J3fTUu3aM+gzy2LPK hTG9uAx7471zNkJDYOtyry+W2Fx0FRBJRfc0n7012sNbRNSub9CsJCyYKlj0FaRhmsonSO33MBtD buD+FE6kJ2jcIUqlO8rF22aGOAbYVaXA3BRgA/WoJTcT3bPBCfMC9R2/xrNbtyN305RjXCi0N3Or KTGVVWXnNX/D+riWfypoPtkjAKEKjBUepocPdb7CVX31Gxl+L7Szhvo5rW2Fo0mSY1bOKPCnjTVP DWpxFJWktA4YxluVPYqexrsoybpqVzzq6SqNH2hpvjHSvir4PtodRZG8SKoWDUyuWnOQAkuOjDgB hjP1xXn3iLRWWSWz1aE2+oxnCSsPv+zH19G716VuaF2cfM4zueNzaCum+IJLl9sKKdznb/IDvW1b 2trcX7tE5mV4g5BbAJPavmcXz05n0uD5KkF3K93YI1+sctwELsUjjZgFLZ4ApZ9LGno8UxjD5yqI 3zY9/wATXnOo3FI9WEIqTbexna3aXFp4ZtblGLwNJ+9PXyxxg4685rkbi9tGsfKfbcuGyHUkE5HT kcV6eF96F13Z4+MtCs09rIztMYjVkZBmQMMEN3613UbCdYJAybjIfNBYfKO2PetcQteYxwstOUy2 tb1b+6juJC0DHj5sg/j9KrX1xbWlin2Y4kRSmd2QM+lTG05pR2NKl4QfO9TmWjik0ppgSbhWyTnj b/8Arrb0PTYdW81bxvKZRkOFAZx/nvXbUm4wclujzacFOaT2Zp33hjS7eyeVruSKVifLViCXPpgd 80tpYwx6VCkbPKuwt5jrtyO+B7GuN1pThdo71QjCo0mYN3qRg1OVI0R49uFyc9utZt1FM1vHclsx ynt0rugrJeZ51SXM35FMIyZbGcDhs9DWn5oe3UzhC/BLA/M2R3qpb3ITsrM2BqdiYLS2MAjMScy7 cMTnPUVfaeGWB3in+cjKlen415k4TjZvU9ijUhK6WjHosrnzWJbf03cDp29q5y8t4ri/eKKD96Dk hBjd9Kug/fb2DEx/dpNXbZoWtl9iH2iM+Y+Adp5yO9dF/b+mqihfNhbcFeNWAVe3GaU06+plB/Vn qS3t/DLHD56q6kZWNOWPH8R6Yrh9Wsw9+Z7WJliZc4bvV4dez06E4l+2vLqYUkbxkB1+YjpV6xt3 kbzGi8y3XhzXoSeh5sItyJkjhbVQ7Tjy85JJ+YKP6025e1mv9ls5EJ5UsDlT6GoTd9i3y28zqtD0 W3bTDf3UsdwhynkKxBB9SaZf6dp4uIgky2pB2ujNux3zmuD203WdloeoqFP2CberK1x4fg+wNc2d 4spRSXUkY/DFVhb7Lf55v3igfdHKcZrVVnKN7amDoRUtHoX7OGO7uQrxkr0Bzgvxyfaq0umyKJlk QpMCQM8gj1HrSjUtJxY50bwUjImidrmOKMmVmAB+XGG9K1tJtbq112GS4hIiDAtzkEe+K2qSXI11 OanB8ya2R6ZELJpVMgO7GFAx/k1yN/qGfG7QxwiUqmwcgFuM8e9eVRi5N30sj2q81GKtvdEN1cIh m8uNlmX/AJZt6/WufvJDcaWLtpEkeQ7GiHLJxwenSvQppq0meZVkpXSK+nyNBfKXAhJGMenviukM hj0Ypu+03CjO7HJ5qayvURph3+7fdEAkkRtxjjjJPALdT3P86otv/tlUcbnx8pU5ye/tUq2r8im9 vU1YpHghDOwZd3bqPpXO6hqiTtLE8RmYMSHU7ev0qaEOaV0XiJqMbM5+aTfJnbtOAMZp0WfmG7HG c+1eo9jxNL3Omt7nzNPzG5Vyu1iD+tKY3f77knbg56GuL4WekveiZOOc96UgHvXUcdlcjcfL71Rk BB6800ZvuSRku5J9ea2ZPJFiqhd5IyWIqJ36Gkba3Moo7yNsU7AfnPpmphnzF3ZwT3qiNndmxd2F svlSRyB0C/OC3esCN5DKULkqOmOaxozlNXkdNeEacvdNTTFkudSS3dlfIJLHqBXbx6ZZmMR/NCuM Hbkr9fauXET5HZHdhYc8bs5u5sLSz1JkCHYjZL7sj2zUP2qS5tGXh8dWxjHpW0W52lI5p2p3jEww TNOYZZPKwxwfeu2sJ7VLaPTSZBMBuMhOVPtmtKrtHT1MqKUpa9dC757LLc2xQSjG5RkgLnvms3T5 ZoLWRk2eX5pySBhufXtXF0bfWx6KvzLyua9xeaolxbSGGPyv42B5ANZF+xbUSJHCMuXXaSQRUQUE 04mtR1LNSM6Se3tGe6lLPJOB8qtirumXrSQiTdiMZyzHGMdq6XByhdnKpxjOyMfV7+Oed4Ub5ODk jOT1xVzw9JFAGuTGxlLCMHP970reStRsckJXr8zGSaTfah4leS6OIi+C+dwwO31q5qGgzPZRqYhF s4ZyMKg64zjk1k6sY2S6G0aMpqTfUz9E1jUfCniFbiMs1u5xLHkgSL/Q19kaLqlh8SfB8StKj6pH bYtZm4acL1jf/bH96vUozT07nl1Ycm/Q8z1Sxa31JtM1EYc8Qu6/eHof61yDWp0y9nwxaOUgZbkK PQelcmMp89F90deAqKlWXNomZE8pbULe72xyTQyghiRuUE1c1e6fUZI7WJI5J3O7dLnA49R3r5+3 vRfY+jfwSWmv/DGxpps5LWY38W6RI9jAHgnHf2965/UPB1pqemMNFESXoYu0Zlz8vetadZ0p3fwm FWjGtC32jO0vw0tpbsZkW4vAeVLEBT3+tSapa2UFrLerblDEoLIj45z/APXqniJVauj02GsNGjQ9 5Xa/pmFbWWoalbC8hmAs/NwI5WP+T9a27XwvZXWqXYef7RIsOYYUyNrdifbrXVOuqbcYrbc4qdCV Rc8+uxxskLWl9cW8sHlqGxJG/BPsa1dN1hINcif7LuRyqKrHPHQcmumac4aPdHJSmoT1WzOn8RW9 uIEktDCt2rBirSDMfr+tOkQ3VnG9xIsiCLapBAznr0ryZSlGnF9T3IRhUqy7WM+00bQ5meKeKaRW chZAcKGx2x71iajDBZW5spC2wNhdy42j+prvhVnKfKzy6lKEKalG/mc2bZtjsZMryQPX3rq9D0uK 5gSa9G4qD8g9OxrprVOSnzHJQp+1q2JtbtrBQdiKPmJjZQFBHvWEtgywLdw5dQxLIp5AHUfnWNKb lSTl1N69OMartuiN9VvDCwWXbET/AKsDoPQHrWzZW/m30e6Zgvl7l3v1/GnOMacHZBCpKpUXM9rG sbu0jcWzSfvSmMeXwD1zzxXJSxwPr4898s5yDgAY9qigpQTbRtiXCpJWZs2ccYum+0fJKGyoU/Io /GuhisXeBptySJsOAoz+dctaTUkzpw0E4M53WrPTHitjaMzO+dyjJ8s/X0rms6jbSvZwB0bdksOp /GvTptzprnPIqLlqPkLEeh3byK0p5J6g5HvVy10cDVtl0zQRKc70YA8+lRKsrPl1Kjh5Jrn0RrWp ksL3yI5EudM3/MJGAYH1qnrP2i6vJbyOINbqNqY4GO/1rmhb2vO9Lr8Ttk26Ps1rZ6ehjWEck19F D5hj3cE+hrpJo5IpnYypJbqOMj5j+NaVpLm5bGeHhJxcr7FrT1e4mV7RA0y5KZGM8fyq7qiyGxtf tpNrMeG2H5WJ7A9q407VEnud1v3Ta2Zm6dbQDV3t5CDKpDIxXoO5z+NWbm9uY71Ul4t3kVEEajIH ufpW8vfqNPtoc0FyUk18xLx5xGHgYx+S24KTwawYZbvUdQ857REXzC7SRKQx9s5zitqfKo3uY1ub nsluVniZNReWJ5EAIOGPOaikECXMrIWWBs/I7bsfiK6Nb6HJaKWu5nStOQrJIsihiA2OW+vrWtGN QubSF/uAKdzAgcD1zTly21Jhz3siOe8lkVY7cvPOowCFyaptPfojKzNFJuOeMH/61JRjazKlKe6L VjqjKphu2MkZ6f7J+tTQvp0d07MhEhbgkZFZOEot8vU3jVhNR590M1C0tpNskXzMzH7i8Yx3rPi0 +aW1kYRsJAeB0zWkJ+5eRlUppz90fZtLbXk1vLGck/Mo7GrcUUwuLguSN44ccjFOVk2KHNouxQye vJNGec1oYgwJQ1SlByc800TK43cwQEDI7mpjJK1uvzc+9MRdsI52mdlYFNp3+9NlcpFvc85wARWV 05M1acYJ9zPMzbWG4/N1GetKrPn5Tg+1bWMdTp9JtYxCLtsmTccFe1dHFdzhsJPkY5Jrx6zc5tM+ iw8VCkmtGc1PLHFeXouf3zu5dQG/nWbFO0dyBC+zLZ5bivQgrx12PGqSSnpui/am2trsy6hGfMbL IeDnNdpocNnd2czk+YcsRtHI44rmrc3K30O2g4qSXUoaybqLT1e1jLANtdmzwM9fpWHa3S3F82mS uNsvK5H3X7UU4x9ndCqzn7XXS50Ms8tjahp7oRozjMbZw3tVSe6tW1G3kiuITuVw4J6elYQTb5ku 51Tkopwb7HOapavLq07JPE23GE3jkY5rUtoIbTwetz5q3Essh+SNxlcDnINd0pe4kvI86MUpybdz nYRY3NxGtxK8DFsEogwOa73RNPTTb+4tjc/aM7X8wIQuOxHr1rPESlycpeGUHPn7HSQ6ZaJPdTSl 4SxLSAHg+351Oby017Q1jglYCMEyRbuQBnPH1ryHKUve/lPb5YxfJ1kef3FklxpMkkcMkwZjt3HB Q5757fSrXgrxHe+EvGsdtPK0VpLIMkdEbsw/r7V7VColK19Txa9NtKVtD6g8TaavifwSur2YU3QX cwj6JIPT2YAj6j3ryfRXj1hzYyoTdjKFMc7h1r1payv3PHitdOhzeq+Hoob27trmBopSAM7jlsH0 9cVjWtnaOk5nup7dFfCE8AY447185Uc4SlB62eh9NTUJRjPa61/Ut6XbiBUmkka+l3tEzCU8gnIz 74rZjtLbTvGazW0/2FJQS+3LZyOhNYzad1bdbGkY2ce6e467njtPEEsS38bszF0c4+fPb3A5FYoA ku5orm4M9pNkSR7OjdjntXHBNe9bzR6MmpJR5tty4ojs9Jht4YkVA4C4fBUd/qap3y3trJNdacY4 LzaP3i4yy++eK2p2lLmn13OeteMOWNtNjlr9PtM7zXLtJdOSWfgBuKxSDFKYyu/IGcj+te7DRWPm ZXerD7JdTyYjc7M8bmwK2NPnlt4vs8jeaAcqe4/GpqxU42KpTdOVzbGr26TxRxqwiIJl2nv9K5Zt RN9qssl1H9pfkRhxwo98Vz0aDg3J7nbXxMaqUVt/wCUNEkwWfDBxjBFdnYiGLS4bmJQrAHcx5YjP Q4rPEuXL6l4Pl59dyVLa1ljw0f7oMWCnHGee9UrnT47KSRVt2BmGVlUcL9T2rgo1Z83Lc9bE0aaj z21PNLhZVunV85DHmvTdG0i7h8K200iR3Su2VjKZwCeST2+leziJJQS7nzuGhKVRvsiTVrGyS3lu lif90m7jhRj2/GvOJd00nmtKu5uR7+3Ss8NJzV2aYqMYtcppWFxcw3jPMnmhVBx6r9a6yO/tY4ZX imKKRny5OOD2rPEUpSd4m+Eqxj7tQxJry2HmPkeWzZSMNncfUe1a0UMq6bFctkTcMykcY7D8KKkn CCv1HSiqlR2MmKIqJHkmkndHLggnr34H8quQTSy2xiYBYiPXP86zb+0bKLXu7mRf6OxvysU6Ro+C qyPilvHv00SG0uFQIn3XUc8cda6ozhU5b7nC6U6fM1sU7B/LuWLHK7d3A5BrXaI3cYjM8ixSjhmH HNTV92XMzSh70HFM6H7NJYaJHLCVndCAxhO1h61k3lxdi6V3kMyA7syEY9gRXHDlm+Z7v7zsmpU0 4roUEu7yG9fUjG8kOSrsqA8nkD2q5b6jBcP5m4h1YFldegrqnT3kjkhU2i+upf1C5iazjjjlCGRu duCCO9Q+Y9uI2ikwGP8ACOTXPZqCT6nTeLndPYx9VuiX3OjNx83v6Vz63CSWZiYBG5y/tXpUk1BH lVpXqMmnt57S22hPNt5FDLKVI4Pp6UQapNEyJGob5dio33c+pHeq5VNakKUqUjprAW9vZoPLCXe0 s7kcEegrH1O8jvp1CKud33sYY1yRUpVeZnfNxjQ5bGLdRtbsqtkORnp2qIRyPEW8zI9K709LnlSX vWNeynEdsIuWHPGa24iDYeYHG4AZIrhqx6no4eV9JHL3/mR6sz7juf5gc1dj1JXtyJUyduMHo1dD jzRTRzqfJUaZTBbk0/HfNaGA5vu1TmHBoBkKAvlN2AetXHjCRBogWI9abJVrE6XBtYwFXJkHI71R lDvAHJwB2J4NQopScu5bk3FR7FdI3lfCIXbHQVMrCJhuGT7GtjNaamzZ6i0UaKqDZnL7uefatS+m WezPkyHcSD8oIH5158qf71SPUhXfsXFnO7ZJr/EnJJ+bJrRvtNjtNOhnDh2Y4I7A+ldUpcrSXU4V DmjKT6EUkEU2nRzB9spcLhm6Dv8AWuitpE0HThP89wjclAuQTnv6VE7tcprStGTn2Fn8Yi6tzHJC UVlK7NoI5/WuRlO3VzcI2AG3KPUUqdL2aa7k1qvtJKXYV7n7YkxumcSklkOSQD36mqUefOGT0reK srGU5czUixJJvx0Vc9QO1XGvE8sQKMHkFugNJq4JooLCxlCZyxI245zXtFgosPBTIbZ7jUYIQ6lV 3ndnGPwrjxTvFLzO7BxalKRXgm1Kfw7bLqGnOzyoxuGzt8sHoT3yc9KS2hWw0GGHTohchXaO4Ytj A6lj9K8t2inFPRs9dc0mpyWqX/DkdlBIRLLdSKYpH3QhOgHv61zviaz36YZI0V3jYFWXrg1VKSVd NFVk3h2pb2PdPgb4lg1FF0TU5mVJx9nlbPIOPkb9B+Vc74/sb74e/G2HVLcvbW9zIGLKcbJBx/Qj 8K+olrSTPkvhqX7nXa/FaeMfBw1W1Zk1JYx9okQc+Zj734/TrXk8N0bd5NNbypZoyPNZ1+bPWvIx 0PdjNL1PawM/flBv0Odt57uC/uJPN85PNJYnhiO/Psa9Hiu9ObwnG4AdMElGXDE575rysTd8sonq Yb3VJT8zFvrC11PRp3tLRjcQDCSsMYPB79sVmaSgs9PikmT7SrOd3qD3rHnlKk4N63OqMFGuqiWj X4oi8YWUb+HjeRzNHNCwIjPG7n09RXF2t1qt5BF5shkiBIJGAce/qK9TC8sqCclseNjeeGJfK9zS urgtAiKq7I0wOBuP1/M1QOn3cth9tCgwrySTg4z+vNdikoq7PO5ZTTt2JIIp5SkSKXdjxjjiuut7 B7aWISIjIEIfKc57HNcuIqKOh14Wk5+8+hhalb28d6JwSrkksAOMVyjzNaaxM9vtkjJywI4x1rrp NzhqcdaKhUdiCeZZrsyqpXLZC5ziug07XJ4FW2eNME4BI5q6tNVIWZNKo6c+Y66PUEmh2TFVuRyo Y8H8apX2r28VizGSRWDcIcMGGPrXjwoWnoe3UxN6epwzXzyaut1KimJn5QAdK9Fsb5r24jto7p1I IXy1PIH0rsxNPRPexw4WprJPS5r3Gl29not28sxW3mX98rS7iR3H16ivN7XQXvrmafTomkt43G1J T8xH4VlhqrUZSlsdOKopyjCO51d/4dVraD7OwinA5hz19smuEv8A7bY6lLZzD5wMEYzxiumhNTVn uceIpum+ZbFC1aIX6/ac4/vc5U9q9Gt/9I06B5JmlRl3dxznr+dTid0x4NrVdSUW0Eepf8fIV14K gggg+tONvAJDCQqyfe3Dg15rcj2Ixi1vczfEP2J1ij585QPnY42j3rTuIre6s7a1jgyFUbnJyT/t ZzWzc404M50oSqzVjnGsbOa4nNkjRyRHaQAcNjrVmGa5gne3kKxsUyryc7T26V1ytU92W5xRbovn itC4l6h0uY3VwsUiEj9zg+Z6EZ6VlslzqTLDaKQqgYMh5f3NRGMYavZDnUlV0W7OosLyyuIfLWVY blhskVMKzAf1zmpRYxHzkjtWi8ybLvK3PTHXtxz+Nc0nODaZ2Q9nOzPMdVnY6zceU4ZFlbBUYHXt SxatPHCygfKR1IzXr8ilFXPDc5Rm7EUrTPGk9yx8pn5QH7wrR8nTbph5JEd3nITJwR6H8KUpOOsd ioqLdpbs7m2slvLB7KVQsJUAMo5A9q8x1WA2XiKeLyfKWN/lVmzkeua58NK7kvmdeLioxUvkdBb3 lsyR+W2+ZsDYBk9P0psmmNDudG3SldyL2zUp+yfvdS3FV4rkexiakJnvA0gy+MkA5xUCzj7GsbHj 1A5zXbHWKsebO6m7lyC12WE1y7OiYGzA6mq8r3QkVEl/1gyTwKE03qFpRjdGfI7OxLuXYdzUkETT XOwMFJGRk1rsjFXci56mlGdwJ/KoNSQnKk4qpLzn1oRnfoQRHExJ5q/uDyg5CqB0zTe9w3ViJtlx qqooIzxnPWtSXSXmhWK3BbbyGJ45rKc+Rq50U6ftE2tzUs9IW1cMzEyMOR2qO+0a2NiTDGyzZyct xXJ7Z89zveHiqdnujmlgKXC4bfg8ir6S3El2QjY3AjA4BFd0rNXZ5sU07IgNhMY2MMxkC9QAeT7V rWljdL4emaaPz45Txg5ZSKzlNNa6MuNOSlproZ8lm0c0cjRttBBAPT6Vfn1CWewWB5BGgLfudvOD z1pu07MScoJpmQ0GxWaM7ju7npU8EsuGEyxkAcb15q9HqRrEunSZ7q1S9gZHUr9zOCOcVPZadEkF wt2qtI/CgHlPeuSddcrUd0d0MNLmUpbNGff6eLe3Lo5m5HIXFVrK2gubp0mnMP7slCUJy3p7fWui FTmp81jnqUlCpy3Oy0HRPJMtzNGJCigpIMEL3yM12ugPeRT3E4tXnuY8mEyvhJgT0Pp+NeXiJqpf U9ahB0+XQteIXutSvYTHG1q6APMsbc8HI59K5OPUDP4guoI7UW8A5Z1GN5PB9jXHTV6dr7fidk3a onbd/cacF3Bd6mtlBuWSIgbTHhc/XvV69sTaWTo8ioxOd5GWb1GKxnenNRfU6oWnFyXocl4cvn0D 4tRGGTbHOwCkcAOOV/Xj8a+sfijpsfjv9nyy19YFN0LcFip53rgH+h/E19bSbnQ1Pjq6UKvzPn/4 VeJHttdSxvdxCZjlQ9WT/HGfyFdl8Q/DmmaX4/uH0+WS5spiDDcBFRijLuUsFJAODgjJwQRWVdc2 Gb6o6MPyxrRb32PJLm1WG7urtnaZFQh1jb7x9evBFdTp6rLaxYOSyAZfqK+arSbgpbH01CPLOUd/ yFuWkksLqEXj2V0F/dwlQysM8n8cYritO+36Z4nltp/LkWRxuVyCCDzkH1regoShOLWttzlxEqkK kJp6X29TV13WYpoVtHQEkFRIOSCPWuQikNrbytPKpuE5jYDAbjp9a68NT5IWfU48VUU58y6GU91e yyLczAOgboFC5/Kuhk1Z5ooo1Q2sIjH7lUyG9+e3eu6dOLtboedCpJXuty3FqX2WSOaRYxGSOFXk j611UEOv+IGjXQdEuNVnZeFt7d3bHfhQTXLLDOtNNXZ2UKs4RcYrU6XSv2dfjr4gie7j+G/iJo2y UMunSRJg98uAKv8A/DKH7Qly2xPhvdRqoyfMurdCR75k/SvXjQktHZfNHBKD5nzNXfmU7n9lD492 jP5vgOZSVLfJf2z9BntIa8J17w14k8KeI5NM8Q6TeaJqMZ5huoTG31Geo9xxVum0r6P0dzBx7O5t 6f4Xvn023vri6KFhuULICQvU9ehrC1HT3FvLcrI1xGsxVZA4ZSvrn1zXmQrQc2l6HXPD1FBN9rlG TTL+O2Er27hMbt3oPU1qaVrS6dqETvCHRVIJUYZj2JraajWg1FmUHKjVTkjp7vVW8QXVlbxHyLaJ C0p3cuxPP5cYrf0GSHT9QmeyjLCX91LvfAGO4BHXNePVXsqPs/vPaot1q/tH8jQvdXa4g+yvYoZl beZOMj3+teZ6lpl79sF6oM8pJMjKvbscUYSUaeknuVjKU615RWxRW3h/tVjICf7/ABjBPWta31iG 0kFss7FCDu6Fc+1elUg6qseVTlGg+Z73L8NpaSXDXv2g7jKrE569MCp0ihstd+0XErXTzklQvJIz wPpXC5SleNtdj0UoR99PzMrV49RvZbporPZFIoyGIyBnI79eKm0SS+swsN5ZERnkSM3INby9n7Hl T1OeEa3t+dx0NuK9sLeCXzG2sxLDA+8a5VIf7RfUftBmtbo4aNth2kdh/KssOpR5pvyN8TKEuWC8 zn457gTGMyBgmcnrW/o+txW6v57OGBwoA6/Wu6tT9pBpHl0KnsanM3oNX7JPr011LdDqSATgD68V Pq+tGTS0tbeZnRvvtuyCO+Kz5JSqK62Ojnpxpys9WcjsJcKn7wseAO9Wre3lxvKgrk4Q8kn6V3N6 HmqN3oa32F5rRI2RVJGVBYA1GmhTCQyMzBEPzMpGRWCqRsdPsZtm9BrzR2H2cho3XrIOdw9MVzmp zLcXzlsuFA52YJ4rKlTdOTZpVq+0hYr6WxGrM6IzkA7QvUiunkDlTgsOOh44rPEfHqb4S/s2ZGqt siSUMqsPuqQMmublkLt5h4bOeB3rpor3EcmIdptIsfbZ1jERl3Q4BK9c1XkuGcEk88YPpW6ikc3M +Wxp6Dplnqup3EN9qQ06OO2eVXMRcyMoyIxjoWPGTxWnFotolhHIblpLl926IDBXH/1qTkr2/rYc IJq7MnaeeafjC+9Ip6IfjK571VmHGaEQ9imMrIafHFJJISW2oBkv2qr21YkruyNbS4oSskrKXYHA JHFdBbSKuQAU5+8OledWu2z2MNaMU0i3cMJWBlRmKnKsO1U2ZpWXbIcEEbiea5Y6bnZNX9TMnhjh ndn2vM2PvcfWs6e6ihvlMKZUHnBzmvTptyR41W0ZF6W5E1qqwSFT0BNaUdwkOk+Q8h3uNqlD1J61 lUTsku5pRktW+xctHt2EZuovNXacsx+7XJXEsYvMA/KrHaD2FKhzXa6GmJ5eVPr/AMMWgTcQqUj3 MOhAqS2s3v7r7Oo2yj7xOePrW1+SLb6HKk6s0l1OhtrKaCMxqy7V4wCeasR2EEUr3QG64YfLl+M+ 9eW56t9z3VTXKovoY+oIy6XK0o3FvvH0PWuYkkEt2nkRiBcBflJJJ7mvRw+sTycWrTS6neS391p2 jW0dtbyShUAaXbwR7/rVzRtdv300pNHttyNgYLjPOelcdSjF03Lrc76daftVG2li3Nq95eawyRzN GgwCVk++oxwSP5Uyyk2ajci6tjHGg+UsPvZ9K5HTUY2XY7ITbne27NC0aRZlkyHbqABjd/8AXqS8 WefUPPuYyqoOIyetc2nPc7rN0zk9btJBZpdQgh4z5inoRzkV9efCTXk8SfCHUdBuWWRGtvPhQjlT k7/5sPyr6TBSvCx8pj4cs7nzV4otG8PfGeGcAR/vdkoHBxnGTXsmtWkeu/DeykAaWURHzG387lbK kf8AAdtb0k3TlH1Maso86n6M8JvDMNRjurRnt4/KJkDJuBOO+O+a2rRZ0gt38h7u5dsD7Op4HTge lfPypOcVGK12PpaU5c7lut7HoujeAfGviDUBJY+DNWvgY8b4dOkc4zxjAqhB+yh+0h4i1mSay+Ef iJ0klJRpLIxKcnjl8V34LC1oyldffp+ZzY684xei36o9S0r/AIJ+ftTajHE83gm30WJgd7arq9tC RgZOQXJ7jtz2r0Ww/wCCanxavI4T4g8ceEtAhPJBvZLlkHfhExn8a9RU6UZXnJfLX/gHlyjGKtKV /T+kj1PRP+CffgDwzpjDxn8bLa6OQXFjpojGP96R/r/DWlN+zl+x34f1i1vNY8Z6z4iktwQ1vHdo scg9MRJkD/gVcz+rRqc2r9f8l/ma+3bp+zhDbqzftdf/AGQPBJH/AAifwWsNWmi5SfULZrpifUtO W/lWxc/taTaVZtp/hLwppnhu1T5Y4raBEwD0wqKP5VUsRWkuWOi7I52p1NJP5dPwMYfFD9o3xyWl 0XwhrlxbNys8lmbSAj1Dy7FP4GvOvGXiD41+HtPkuvEsUNooYBla8WQ5PbKsRnr37VDp1FrJi9nT Ttc8hPxb8SyzkSTID3cE8fjmvJ/i945n174cXNhq6R3s0ZEsErjc6Nkchj09MCojJxehNrxufL1t 4mv7bTxbhjLGucbyeQRjn1Fb/hS2lvradWRDC8hIjZh8xHOAD1rOrThTptm1GrOdSN/Qval4fnEl xqEtw1uhixtY8KR0zntmuJOlXs2mPqZjaS2Eux5eiljzis8PXhKPa2hvicPOLWt76nR6WYU0gbUQ uDliTzWnNdILdJQgkKEsI/M27uK5aqcqvvHZQaVFWLsci3umxT4S3G3MgVup9c1QuuYCyMxj79x7 1zRXvcvbqdra5efuc/qEJEOd21iOhHX8ag07SrTUNJlaN/8ATEkzy2Pl4r11NwoqR4UqcalflZvx 6VbSWSxvFLHKBjIbnIrLljOk+Ibd2D3EAbkH72Dwa54VZVJOD8zpq4eNOCqLpY39SvIoolaNGeRz hQq8/SqMd3dtLKLlQsYwE5yTXKoLk5nudvtJKdl8zE1SDEDPGGYHkKOo9apRarcRgG4keRDwynHA 9q9SmlUpa7niVn7Kr5GpItndWEs9rBm5B3c9SKZFZrKQzqrSsPujj8KlTcVrui5QjJppaMdf6SXs JjHAYpAAxbPAGa5xrM280XmkPJu+aMHpXTCakjlnTcXqbM9rDCkbRfKzclTyRmtu1s4YtPWSQ/vG OdwXOK46lSXIu7O6nSg6jfRE8qKLRZ1VDIh5PXIqOKUXFqRC+xWxjaQN1c8XeN+x2Ssp27j54bVG ijliDSO2MqMZ9zWLcacovXiDrJ3OR078muqnUfXqcFakt47ozGuxZuFWJY1AyGTqxrTh1mO7sFN0 CskYP3E+97k1dSk5e91JpV+T3djO1Kazks02P58vXJHQe9c+w75z7V0U7qOpzV3BzuiTcn2YqRh8 +nUVErAHPf6Vrqc+hdtWK3BCjLMpFb6zCTR5PMMpmThXVsc+/wCFZy3ua03bRmWemacPXqaB9NR5 ORVaX7poJvozPP8Arh6VOihlkiaYjuqg8E+9U9iYpXNOygaCDM5+TO7APStHdHFM0iuW3jAj65+l cU3zS0PUhHliubdA87vbFmYoVGWUtggdcUsTxCQeVuYt8x44Ge1ZcvutI35nz3ZU1mXLIgOe7HHU 1zzHJ5P0ruo6QR5WId6rJ4JAsTKxPPIrZWa3j09fMB3o3G7oCac1ciD5dSjJqEhgKKxb1PrVEl5A 0jtljVRiooiU3N3Zt2R1M26R2iFLUuGJ9T35rZFxb2niVJppFVypZtvG/jv6c1yVYptpb2Z6FFtJ OWyehQn1q8bUi3lKYWfIAGcj611dsbaU+cEZ4sAlG4APqK5q1P2cVY7cPV9pN83QxNWvIJy1vbPv jb756Y9qsaVpGlyafHLOrLKJMvK0gXBzwoGea1jz0qPmYy5K2Ibex0tmkNxLcuYiLRAVVufmI68H tVWSwubqexOmed5Uzf6gQnLHB7YrDlm5Wtf/ADOuOq00f6XO00L4c+M9VfbpPgjVp3UfI1tpksm7 PoQDXpunfs3fG/WrbMPwy15AuAj3NoYs+v3yKTwmKnq19+n52OmMqNJe80vmdtp37GHx8ndZZPCU OnAgYN3qlsm0/TzCa6+0/Yb+Lt5fg6r4g8J6XCcBzcaqzOB9EQj9a1hgXe9SaXpqZTxuHivdd/kz rR+wlG8Eqa58WdFtxIMN9ltZJiv0yRmvQfAH7Jnw6+H9zDcP8VNQ1WaPeMQaasa7W6jknjrXo0IU sOnZuX4Hl4nEQrvSL+86LVf2av2dtW1Zr3WF17WrggBz9s8kHH+6oP612mm/DP4FaNZxWtl4Ae8t o+Ql1qMz5+uWrb2tm3GNrnJduNrLQ6HTdA+EOivu0b4MeFbZ924NLpaTMT6kuCa7W18ZHTU26N4Y 0TSQPui10qGPH5LU+1q97emhbnVkrSk7epsW/jzx3qV4trazlHb+GKILgevsPevRPG/h34geGfgn pviXUtYv0ubnUGtZIH2gJhc5GCSeQw/CqjDmi5Sf4mdkuh4Jcar4vukZjf3jD1D4rzXxcviiTwze sdSvIt0ZBIuiD69j61g4KxS0dz5K1KW8e4kFzNLO4OCZHLZ/EmsqYlYyCOtclktjrTuZSSx294rT x74lYFhnqKueF/iUngXxPNqumaXHean/AM/Fw25vrVptvQmpH3dTs9Y/ag+JmrWbLb6rFplvzuEE Y3D8TXhWueKdZ8SXzXOralc6jL95nmlJzWMptSvcuNOKj6nKXN1uYqr+WoQlh3NeReJdQknvmgy0 qqQXJP5CtYvQymnc87KzfamES5Vu2Ac1atrq50u+Dz27PsOUDZAQ+orpkoyXLfU5YuUXzJbFu58T 313pVzZzOHilbILjLKM5wDVKO/uf7KjspJ3ktN2Vhz8ueef1NZwoU6cbJdb/ADNKmIqVHdvpb5dj bsMG5dcrDG6/u+uGNdLa6Y99cxo0aybVPzZ6cdf1rzMRPklc9fBw54WLS6Mi24Ujy5GIGCCEI9M9 KrzxJp10be8yiq3zfOCM9u9csZSqSsd1TkpRucfr94ZWEKfKoOSN2TTNCDJcRsqMx3kF413ED6V7 NrULHz3M3iOZnaXN/Z2msG1kuRLJwdwGF5rlRb3WoanNdT3Yt4gzLGB83Ix/P1rkoQ5Lykuh6OIq +0ahF9S7ayi4LWM7LI6gEkZHHWpblomTEcqb4xzubv71m4uNSy2/zNIyUqPM99vuOanummgkjH3j 97HcdxU1jpd5dwiVnQw7slSvUY9cYr0vdpR1PG96tUSRca3u00aUWcLxKr4kaTg89gfwqXTiDAkc i7phx9786wk04Nrc7I8yqRUtjr/s4n0oAOkMrIVIcjpjn/IryXUUeDWnQEHoQw71ODad0x45JWdj X0sG4kR5GPlxtg59K7BUtbdPIMkjF3LKzHI//VUYm6dkVgbO7kZ2orbmNhykbcnyzgEj/Go7cWhZ MAhsZHJHP+NZxlLkOqcIe1uzZiH+hmSciTkY4B2/jWdPE82qSFpP9HK8rjBz9RWcJNMucLx83ucf ewloiMtlZCFyvBH1rRt7BTZk7NjBO56nFetOfKkzwoU+aexA9qHgLTIBLgjKdK5+SN45MNweo9xV U581ya1PksNZcleQMjvVyC1UXC/aDtHU4P8AWtW7HOo3NEtaCQM0PQ4DAnJqSSREVWjnDoDxGwrH 3r6nSnC2m5VHOe9Lnk461ZHQO2TxUbj5Tk0hNaGfLw2aIlX5nkYhhyuO9adDNb6m6LtGSICIk7fm A9KkkRd8MuBhTkl/vYrhcXBnpKamtF2JorbNrLJ9o83ccrx0FPS0KwGS2lYFVwEJ4z71HPra2ht7 NtXT1MieG92H7QhfLcsDn8KqxWcly/A8pQeWc8V3KUUro8txnKVnuJc2cltkEhxn5WU9aIJFQs0q CUkYCt61a95XI0hLUljfdfpGYgULcqB3rptNSK2sZ7VbU3VxMdqJs3Fz7DFZSjKXurqbQlG97Hbe HPhd8UPEEP8AxIfBWrT2zDiZrQxxD33uAv616Jov7InxQ1DUY31m80Pw7CTkvfaukj/isO85rsVD kbdRpfi/uQnK9uZ7f1/Vz1/TP2MtNjJfXfjRplgpGGhsdJmuCv0LFPzxXdW37LvwOsLcLqvxW8Q6 ht+8tlYQwbvxctWUvqis2nJ/d/mVGs4aJb+ZqQfBb9kzR1HnweJNedTybnV0jDH3EaCt+2sP2UND wLX4WW97IDkG91e5nyfXG/H6UnWj9mC/P8xxqVOll8v87nR2vxM+DWjQBNC+D3hmEJ90tpYlI/Fx W5aftGyQXkFvoHhLSNLaRwkfkabFHgk47Co9vWk7J29NPyKaqSXvyf3ntVt8QPHE1uGudXCMQPkt 4Qir+lLJ4m8T3efM1W5c+gc0+XvqY8qVig91rc7nfc3D59WNC2mozY3mU5/vNRZFaFuPTQMmd33e mOPzpkngzUNUmLQ+O4dAtz0S20lJZB9Xlcg/98UXjfX+vzBct7sB4Fu9PYMvxM1PV2B5jfTLFQfb 5YQf1rq7LSZZbNBLB8w/5bHC7/fFDs9V/X4DbXRWNlPD1t8peSQn/ZANakXh+0BXcXx/tJ7/AOfy o0DU9E8MP4e8O6jdTz2s2rGa18giHCZDYLHLdCMDBHXHavQfiD49j8c+CbbS47K/SWGcShnRSrZG DwpOCuWwc/zrRyTVv6+41bjY8Gk0C/EbFbS6Y+pjZv5iuD8R6BcSWM4ktZD8pyDbis7MzPg/xfca dpnie8jnnSOdX2mPGCMAfrXlGo+IIXuSYXcL3OQBXnS0ep3xVzkb7XBJNI6zZZQcgtnFcZNqckkz yK5yT29KuC6szqPW1ydLphbPJvXy1YDrzkjI4/Ol/tBGj2xygORljnvWFSNpaHRTkuTU4zVvFFlp djIjSi71IkgRqc4+p7V5e19cTzTTyTKZZCWOVzXXCOjbPPqTV0l0/M2/DkG69a4kiDMuWA7V100d pf2l3bSos64B68E+1eZiXNVuZdD2MHGDouLW9zh7/wAPWqErbSusobLxycnbjnbjqarJZRWTyTFt 6qjJsdSxDkdOmAa9GNWU4ao8ydGMJ3XQq2BlS6VmcSbfmXccYNdJB4gijt2E2+OQoC3ynDnscjkC pq0lV2HRrOi9djSn1KGPQBJvluNrBjtdjEpxxiuRttU+1Xs0+oAXTrlhuHAHfis6dN8smtzSpOKl G+vczL+7jub5pY/lVu23GK6HwzqXkakI4p1jk6jzBhSO4z6101IP2FmckZ3xF1omyfxLeG71OJLZ hdzxA75lH3yeSB7CotOsri+faW+zlFyTyKxUlToq/wBx0cjrV3b7wt7p9L1O4t/OEkL4EmRkg/Ws 3WIxNMsltIpYDnbkbsU4RtV5+jHOd6LpX1jsZiOYMMxZ3xznmrgvLhIjHFM0akHAHQZrrlFS+I86 E5Qem5jGeeXKyTu4J/iYkGuygs2sreKcMZGCbmA53VhXailHudVCLnJyvqjVh1mB7cMYGEytll3c Yx61yeqMJ5QxO6NhvVsjk/hWNCn7OR0Yir7aIts0MLxBoyFwCU5OT710kNzkf6QqsSP3a9qnERbs ysG+VtFGR4ZLkxyP5rjkqT0qFzuXev70dgOtZJNbnU3Ftu+pIt5JbozF90CcsjDn6VPbyGa5JWZn RvnIc5IB7U2ko3sKMrtJsebb7TpVzFGwR2fcGz1x2+lVNtwlgoEnnISA7Dgj8a15k00+hhyyupJ/ 1cq7rjfKr48snjHp61kajauJEmYHBOCfQVrScVLQwrRlKGu6MwqpuGC5244ya1Y4A+itJvBYD7p7 iuuTatc86NuYrxr/AKGQ3yZyOTnFPSNjZHc+516+4pX1KVmLnPOeacM4yaGMU5JwaHAK89aQb7md MOSKt2qq1nLvAOVGM05PQI/Ea0F5B5QCwkPjHTg0+O5hu5yGiAfpycCuJ053bbPRVanayQyeK7C8 bFiXjcD0qK3WaO6McchDPjeD0q1y8pEvac6NaFQJZYZgZBtyH2lhWXeXkUF0VSNJY8DcAMAmlBc0 vIVR+zjfqZlzqJuyoKLGqD5cVTUq02GbGe45Ndyjyqx50pOTv3O+8OaJpOq6paWr3L2298z3DDmM DqB25FfXHhbWfCHgjT430GygS7VfmvXiElw59d55X6LgVNOpKMX3/Q65Qhb3ex6Jovi7xz43vJYd DWJkX/lrfXPlp17Z5PXtXVt8LPjfqcMkieKPDFlGRwv22ck/iITVqMJK8pW/Ex5Yx3PJvF/hP4ke FLZpdb1/S73B/wBXaajJuP0DItefRalNIwaeeQn+LdJnBrnaitnc0i4y1La3alDnk7vWrSTBZIty 5JHHNRc2W9zVinZgVCHt3r0LwDp4vfix4ehlTzIzeJuXHUZzWtNWkiWz9B7bSoFiUC2H/Aq0ktAq lUREB6/5FbNs5mmTizQcySJn0ANWFt0yNsbSH2XOaku5oRaJeXY2pptw+eyx7a27P4da5eMNmk7D 6Sy4P5daqzQjsLD4WXKXCpe3EUDFcjylD7fUMCQQfwrtbP4U2brum1C5dT02W4Gfp8xpaFLU6a1+ GHhyLAlW6uZPQyY/MAV0Nv4B8MW5Bk0mJgT1lnYk/hmi9ugHV6f4e8I2V+rRaZaJhvkzbqxIz0Pv jP51cuNK0e3sN5FpFlQdrJEjAE56E/0q+a61NbqxhStpCghfsxPu8WP5iuL8Qizm0ycR20U42nPk MD+isf5VnzHOz8H/ANpbxdb6N8f/ABd4TWwgEUk6XS3KWqG4JIHytK2SFHzcKB75r5VutaEl00kH mRRbyUV5dxA9zgZ/KuOqpTaud8J2iZFzqEtxG7EYQn7x4FdL4d8RfCrSkjm8VQ6trt0Pv29jcrFE fbIBb9RVw9xWSuZTbb5mdbdfGbwfaRqvgz4SaPpUbIRHf6073pz6jeTz7dK8d1/Xb3Vr99S1O5iu jI4WWHToVgQYHHCAdq5a9erKSgv+AjuoUafs3Oo9unU4u58NyXOtZtbuH7PNGZrdSTuxxwQeR9az n8OajBJIs8DIEbD/ADAn8Oea1hiaatGW5y1MLUs6i1X5f0ia0W/0a5jnklUwbchSeSCcYNaE2uIz D7KBDIxBUJyPp9KmpRVWSktgo15UYuJs2WiXmp+Xruqym2sxzGseQ8mOoGOnTrXRTpY3umXF7p2B ZCNWSEj5twOGwT2ry61X3rR+GOnzPZoUmo3k/elr8v8AgnIarpMc9lPJalWZFU7VI3KT1B9MVas7 RbLSQLiMTQMc7pFyDxycjpzXT7VyppPc5VSUazktmiNLmC6uFtogqxMCFaNuM+mO/HNc1qumW9tq NuWcojgiXYeprSjKVOfL3JrwhVo83Ylk8MSxlGd0jiePcjZJOfcY4q5FpdrZ6Hcbma4mmAX5YckN ngjuB2qniueygRHBKDcpvoOuLeA6bZzaev79I8SBRgNjgmq7XFxZWZBST94vKOMLjuaqP7yPv73I l+4k3Daxmjzr7VkUxHa5A3j7oz3rW1q1itJLZQu25MIErZ+XiuhySqRijmUealKozn9pe43HAQ8H B61YuUVbB3hV1AGASQOv+TXRc5DKtrYPdjKF8H7o712H2DxFb3EqiA7GUhQ7KflI4696xrSp7TZ0 4dVN6a1OUmttQszKJFMbODwOcg9anN/bvp0cTx+VJGflEaDB9STW1lK0onPd021JEiXxe+ALK5PK lvX61v2oeWL944LLwAF+6K5qsPdN6FS07iGzY3DzR7TKEwz44FV4oYVlZUlYPnLDHJNc/O3FndyK 6dyV1diR5e7+8GGc1FOktoUiUpH5i53g4x7e1VFJ6Mio5K7tqZVxf3NqkkQuUkBOAyEn360tpq0s spiMZkDnIUE5zXVKnFwb2OONaUZqO9jW+UBknHykZAxyKrXRkvbXyUhPceZ2wPWuWGjTfQ7am1t2 zBvNOMECuZN0hBO31FIgMulKHOwE8GvQUuZXPIlDkkWFgP2RFJyy9x3pTCSm5SCVzkd8Urjt1IMm pV5psdhwOOuKRyCPWkIz5sZNLauRMo7Z5J9Kp/CKOkjTgjEnnc8A5wTSIJGGTH85ON2cYHrWV7ms Y63NoulvZoykSZGDubPbqaybW5SO4aSQnG7I4rnhFtNnXUqKMo3LdzqyyQFbdWSPnO3qawmR5LpG lQs7nCx4xnNdFKHItdzmqz9q79CSPT3+0ypOCvln5+RxVptIdNIa9jlDhTnb3I+tW6iTMY0+aN0V rfWbmzhPlPlt3GRXdaL4xSWNYLp/LkPr0z9abha5Sm20md5a6xqEcG+0uJEXs0TkfyrVbxjr62+F 1q9IA5BuWx/Os/dbNGpbmXLr95cuXubt5mPUuxNOj1c8DcCAcmqtpoRszVj13csYQKccmrlz4sto 0YENuUfKQO9c7T5tDpjK0bsp/wDCZ3MUCysWKk464r6i/ZW8RaH4q/af0fQNW1BNM1C8SRNOeYbl aXbkL2+YjdjrXXSs2ZtNM/Y+z+DwEKme8uJSR/BEBn8zXRWvwq0qHHnxXsoB6l1QfnWl0jE0ovh5 4bgk3NCFOcgNIHb9BW1F4a0KBBi0hbHRmBz+WcUrhcuO1lZQMtqbeJ+wEYxWDcX9xJuVrjKd1RsA /gKncZFDeqh4Ge/HatRPEF4iFYZPLT26/nSAR9d1F1I+0vj61W/tC5YkmZs9yDjNJIY4Xk4AYzuW H3fmPFX7YW1xo1/PdXrrPGo8iEIWMjZ6k9AAM01a92GtjAnclDzk1wuvSOtrIwYg44INID8HP2xt SurP9rvVH3o88lrCw3qSxHIz19q+VYrnWry03GZ0XvsAU4/LpUS5Ursa5noirPZ6hcXwWeJ23HEb SMSCfXJ4xVZlWBolWHM4c7zjgj/OaE01ZMXK1dyRt3mszFPsKW9v5I2s2RuCkjt6YHFbOk6JbSTg tcoWdCRx8jZ7fSvNryeGpprW56+FgsXVak7WNG8g1Wy18X1vaI9qI1SdSQAOBjB9BxUFxLc6p4fn llhForNshmlfB8z7wB/AHmuCEYVZRqJ6rc9GpKpRjOlJaNux5vqM9/IJYJGW4jiOHlQZBOfX611v g/RYor46lqT2qQiMNC0zArz1/GvbqyVOhaPU+coxdSunLod/f34v9ASEM89iWKGWNgBHx7cj61zA 1S10jRgYpFvLiLdGqbtx5/veteBCnOS5PPXyPpnVhH943008zA0rWUm1JkuyB5r/AHY4hw2e4xzX Q3s1xPKGt5BcQEFFSBAAD33E13ThGnU12POhUlUpaPUdBZ2It43twIZVycgAMG7g5685NZ0+nxvr MF/eyNLFGw+UDge59eaw9pJTd9zsVKEoLtdO3ob8iXN3YpPbxpMMFcFuEPqfasdVura1+1Eol0rY lj4YKc9QfeuelycvL1Oqs586l9mxYJ02/wAXaSAyI2CqDCEHr+tef6/cXNz4gKjcsaACJQCB0/nm vRwql7W0+iPIxvL7JSh9pnQ2+iarf6XZnToPsjxRFblGYr839859Riq1to99dXlw2qbmjgYqV3E7 885B9Oa1lXpxTf2kY08PVm0n8LNJ9GtJIykMRiKj74Pb+pqEaO8+jXFvI4eaMfuXYfw9e1ZwxGnv GlTCxT93zK+keHRcMbj7VgRS4kQxkZxjIzXQre3NzLL56NAgcqvOfyHpU15RqzfkXhoOjC615vws Kmk6pNeRXBjgktgxEmOWAI45+tch/wAI1NfzXF7NPBZQFjtAbjPp7VvRqwg9LmWIpzqpJ2RzF3aS 2d/JENrFR1Dbhxyau2d3dwrLLLckRuu0gDkn8q9J8rR4vK1I0IL2aIRqTtTOTk4B+tWjeTTX6m3W NUx94DqPSuZ0oufMdkK84w5Su+oOA275F5yc1hXky3E4EczPEOWyDmtoQ5DnqVXUepXllieE+XHt YcfUetT6Zcx2+oq7Drwp9KuUW4NGcZKM1I357wqG3LuP86w7bWLi3lk8z98p7E4wfauanSUoNHbV ryU0ytPdzz3TTDO3HCk5xV6yklewmeVSIoh8pCjmulpKNjj53KWpN9qh+UIyKVGWBGM00tJPMrLh ieBhutJJLVhdtpIrYJPqamQdyaYeouR3prdD3pah0KUwzk/lVWP72CeK0E7XNdAkFuZi2S46+ntU P2ksm9Xyw5AxWaXNqxyk4tJGrc2Bnso5WlKttB254NY+nt5eroPJ+0EnCp13HtURd00bzjySi3rc 7m4sEi8Py4iRZgpLrGcEE1xM8csQcOTvjA27+uD6VnRnz3ZdeDhZEyTu6DeWZiPm54IqxcSs+mpb iRsAfdzxWzSuc0ZOxzxj5IJyO+KuXGlzW9uk+5TC2CGB6ZrVySsZKm2m0aun63qmjMm4+bAwztJz kV1kfifTry12vL9llzkhhjP41g4a8yOuM9OSRMlzFIMpOrdxg1u6Lp1zrGtxWVoA0sjYDM4UfUk9 qthGzdj2ux+BvxCn07zIdEhVTyXl1W2Uf+jM/pXKeJvh1rvh/DautjFj/lnDqEUj/kDWUo8ju5Jv tqbNxfupHJXMFsmmlGZd3TGao6LrV54T8daL4l06cQXukX8N5bMG5DRuHH8qeHk4yTfcdRpTVj+o bwh8TNK8VfDLQ/EemzvdWWpWMVzDLHLuVldQev410L+KYnyDaeZ7tIa3atJo5HuZF54llBxb28cJ /vck1iy61fyk7rhgD1C8UtxFX7TLI2Xcsfc1YSQ7uTzTGWhJxjv3qUNnPOaAJlYmpd2c0hj9xPNT JPLGjKjkAjketAFWXlGJ5P8AOuJ10brSUd8UwPxV/a90/SIv2rba41JCJprBRE46ABmJz+dfN1lH JdRuEtFhgQlYZAy8ZHfkHnjrXz+M9pd8zslse5g1Cy5Ve+49re5i8Npbi5jlu0YkvLEBGoz/AHev tXG6/pUPkrPDGiXSA+Y8WWRj1yB2+lY4Wqoz06v8DfF0uaD8l+PU5qDP2G8kaCFYyFVmP3lO7OF5 5JxivQjMbjQLOSymgtpHAURTJhjzk44yeldWN9/l6pbmOAap82tm7WM3Ur02tlANYnKxhy1vJEMv yeR0/Oufvxa31xcyWWpP5LRZES5Ac/mPT0rLDRlG0kvdNMXKEm4N2krfkdT/AGdpPh34dXAvvmFy oJ8w7vMcjgAjoBXF6ffW82iTaZqiEWlwxFvcKvMRGDjPp7V2R55wc+t7r5HBJwhOMH2s/maGn6pH 9jk0y0s3ityyhld9pmAPJJ6/hWjb+G7ZYEngkKySXAeNHGQuDn6+ormq1JUG7633OulRWISS05di DxH4WNrYT61YTeRJA26WPnJ9x+dcd/wkWrPPE0Uqx7eWGBhie5row7hjKSlPdaHNilUwNZwhs9SO 81PUW1u4LSossmGPlngcdq1dD1V3ZNNu2EijJjB7nOcGta1CDo3jutfuM8NiZwxHv7PT7zvNPkDX s6RlY45OVB/hesJrW+01r572KO9juJgAI/5nP0rxqMoczi9G7Hu4iNSynulcr6xOln4aU20MdsrP hCi/ebueK5PS7yU6/aL5shk87BOc7gfavVoQvRlKW7ueLiaijiIxjtoe1SQtBopuWLRSnrk/eHoa 5Y3E0OoTOAkFs3JX04ryYWqRdj2J81GSbJ7G4tbmXP2lVjTc0gOMpz39q5rWPEdlbX6/2duumX7z suFY+1dlGhKU+VrTqcNbEwVPnW/Q0LLVZLjwUs8ReW4wQ5QfMW9D69vyrqvD4sruzeWVRJIhXdHu wxbocg+9Z1YOKlJdGb0qikoLo1+JbmcJLci1UxSRqWeFVJAB/nXDW/2TXry7gmtJrAly7Dd8rnHP bHvinQvGLn1ROI5XJQS3KOt2WnWkoZQBhCfnYkt0HWsWSEtoy/ZZAYyCcEZ5AJzmvUhJuKlI8mcE pOMdzDij+0kJPOsKYJ57mq0SSi/CRS/Nu4OcV3dzzWm7Gpsn1PMMELcMAQFyM+5rMmgmtLkxyZWR fvClGSvyvcuUZW5+hA27cwBOD2piMyzA5yQccjNaGGtzoHLQWpuCXJB2plcj1rBZg92zMcAtycVl DujWeyTNUNaJZP5O55mUhiRxiq9lPc/aQiMGQnBU8ikr8r5gdk1YtXllG16BEQCcZVexpTpsoyQ+ wjgYJyalVEkkzd0XKTaIlzzzU2fkPrVmQ3OTSYyc9TSGyrN39Kog/vatGTfU0I8zqqM+yMdSelQz QxRbhuJPYjpQtNg0erHiWZrHbvZzngc8fjWnp2myMftX2lbaSIFlGPmJAz3qJOMYs0hGU5rXYbNq OqXTJEqmRlJAITknuT71WkD3Do0mWkHDcd6UYQgrIqc5zd5F6GGKSPAk2yDilliMdvtbBGeuKjm9 6xap+5zGedPmNpJdJGTbrwW7ZqusLyIRu3YXIUGt+ZHPysURJ9pxIxUL1p62jXFyRBG0xHJCrnih ytr0Dlb0W5HND9nunjb5ZA3bitPSReNqcbJPKsYbkLKR/I0pNctxwT5kj12Ky1oWSySarqKxCMM0 QupCv061jzaTdXt3EX1C5tTIpYLJM/IwcGvCjife2ufRVMLFQ3swvPAt7No7XdrrkdwygBYjKQWP c5J+tcDe20tm7R3KHzQOSTkZPPXp0rvw2IjW0tZo87FYZ0He97n7ofsAePf+Ep/YdtNCnm8y+8N3 8ti4J58pj5sZ+mHK/wDAa+7Q3GetenU+K5xSetypctkg1X3e+TWfQV+pIGNWVYk80DLiPjGeatow PJoAsBgwFSg5OKRQ/OaXOaBDJMlD61yGsqfs8n0oJfc/JH9r7Qzd/GTSbxRGW+xuoDjk/N29+a+H 7bTPEdjql2bmX/iX7yAC2FYn3HSvnMTVpqrOM99LH02FpVHRpzj53/EsadstdYeKefERcmRXJzk8 9TWk5sftJEU53T5OAcg/4V5rcuZu2+p6VoWS7aHius2c1t4mnt1QuGlyADnnvXbnQNd0/TNP1nK3 MSrmNXcNtHqB1HWvpKs6apxU+q/M+XpU6rnJw+zr62Zz+veIHmtFgWBVY/edxwrH0FcjcWf2aElb uKQ43MAwznrxWmHpqhBR3uZ4qr9Zqc+1iK51O8u9KgtLmd5beE5iViTVzTb2ztDG90klwUJ2xcFR nHPPQ10zp+5yxOSlUSmpT1sap1uzj8SNIIleJlUeao5HFd/p+t2zQeVGVuXCEBVYbkPXOK8TFYeb irn0WDxUPaPu2Z2v6texaC0MMis8oCzB8MwB55BNebzwJLdNIZRuIyfLj2jPsPSuvAQjClddThzK blW5ZPZDI7Jz+8+ZieenNW1ga0vop/LchWDHI69+teg5J6HlxjJLmOmuNdtbOcT2MBnSR/MljdSN nHY1dGvx3Fl9oT90qjmOU9Bn1rxKmElpO59DSx8WnC1upXu3ivYoF2NPbO3Drj5c9+a5y70qW4la XS4pMW6hX3t8zHPUetdFGfslaT0W5hiKbrPmitXt91zr7TxOY4LTT9bgdikJ84tk7z26e1QKLRdO vA07PbzKTEknLRc/3j1H+c1nGk6Tbjqnqhyqqqkp6SirM4sG4h1F7WCCW5kncFTg/MnYgU+4tppL eVDA6XC/8s3GDjvXrqy1PEb3idBpUslnpNnb3G1IfOOTs+Yk+n411toblJJ7iCzkgcH9+Xi5JAxk Z7dDXk1UlJyvo/8AM9qi5OKg1qiwLzV/MjtmkW5EindKqBHjJ6ZBxn9axLjULTTImjSf7U6ktMcE bT04IGM1gocz5YdTocuVc03tseX313Pe6hI8sjSDcdoz0FX9Ka4eC5gEZbCEhh2PvXuzUVTt2Pn6 cpSrX7lFUbz04+YHoRxUzabM88rQFZ0A+8px7mrclF6kKLlsXNPtpIxNL9pMAPy4Q5Ln0+lZl27N qUz3D+ZKW5B5FQtZt2LkrU0rkaP0BUOM8c4KnNXw+n/aIUkhLzcBmBwKqXN0MoON/eOjggQ2ARlA jByV4PFZOp6fC0scsKEbzgKoxmuGlKSmz1qsYSpLTUzY1jsbplnKyA5BAP3fesg/6x3QkqDwRXoR u3c8mXurl6o6C2K3EBlDOrYA35zg1aWKW4AWBXldTguT+tcsnaWvQ64K8dN2ZfUZp2Tkmug5Otw9 6kzgZxSK1RUm5J9azpB81XEyky/as0jpDx8xAxjrW3eaYBa7otvy8sCevrWNSfJJLudFKnzxcupn zvBbyxCFQzxrmQnlTTIohdP50tyVkZvudBj2NWr25mS7OXKnY3JHit7f92+AoyVU8msF5SZfM+4G OQorKkndtnRWaski1byoJRlV3jnk9abeX4ddq8kVfI3O5i6loNLcSLUrldFltZlE8Dn5Iy3RvXFM W3vYrBpI4GG4cv1JFV7q+ZEeaXTVI2tE8N3N4skl5DIsZGEwOWNdK1rHpGh3Ti38oIhAfqST3PrX mVq6nV9kn2PYo4aVOh7aS1szzTIe4fcpl9GBx+NX7CaSDUkZfkdTkA9G9q9eSvE8SOkrnqWl+JNR k04Wd1iOCQ7I5m4wfXd0wKg1+HV7mfToon82SaJmt5YyWJC9uOnSvEjQp0q9z3p1qlWhb0/4BQTW Z7PwreWN4WtNXRQvlz5RlJ7gepFcK0kr2jR7cjduC4zzXfh6Sg5SXV3+R52Jqupyp9Fb5n6Jf8E3 vGE+mftK+K/Bs02LTV9IF0kZ6GaBxj/xyR/yr9rwSRnPFehPZPyObeKZXuOmapjmsxE68c96sK3G eppAWVJIq2p+XmmUWVPBqcE5qRki57mnjrnPNMBr8qTXLayP9EkoJZ+Un7Z0LRa/4fuUbY5aSMMf wP8AjX593+qalbTJFDvlLMA68lSPU/Q55r53EUoTxb5v60PpsNVnHBq39ajzZxahF9o+04k253cZ Fc4buWy1WffCXRUz5xY/MD047Gs6MVO8H0Krz9naa6l7RrO0eGPU9Wudlu8pDEjqewz6k16ELi51 HSL24soZIYrVGSO2lOFkP97Pp6VVd3leWiWhnh01C0d3r/XqeVa5p1s0Ml95qfPlXiUZIcDkj1Ga 4dbJWh/eSMZMgYAr2qM3yHh1qdpPUL+z+yxRlcumB16qfeqQt5y27yyWPIHciutSVrs5HGzsi8+m 3PkpKdoUrlck5qRbPUbOaG4khli3HMcgzgH6isPaU5qxs6VSBft3luNTcn9+XY+Zk7s5rrYNLgsI 4XMBa5V8y+Zx8vtXFXqezXKtLnbh6Uq0uZ62LkkmmPHvAjhfnIbofxqmqJNIEwCpOCM9BXmKVRK8 z23GnJpQ1MbxBpsmmzwTjZtk4+Q5qrZz2YaS3uJhHhRgCPJfPJ+v0r14zdTDqUdWeDKmqWJcW7Ic 17BYzzRWgZ41XapJ+XOc5+tbVrq9vHosLXfk+Y4J+WUbjycfL2rnq4ecoqXVnZSxUYTceiI5buxv NJut8TFg4Xy0PJOc9elVzpMdzeRTm7eK2iXJG3JI649hUxlOh7stRzgsT70dO5nTapd6hrUUWlWr uIUKDnLsvpkVJJYXNxqW6WGcvsx5a9Mj1rvilTVr6nlzvUlzW0MW/uL2z8QKCW3xAHy5RkZ68ivR tG8WDVbXyJHS0uSuGXsxxwRXPiqPPTUl0OrC1vZ1mpdSrrGu2tnJIl7iW6VTsjjbvjg5rhLbV7uV pLdIPMSXcNvU8nk89adCk407yKxNZSqpRV2dRFotnFiSdOduCB0PfmpT9nVS1ooCHgMDwK4XUqVX rsesqVKirpalKZI7a6EsiLGzDG4gZNaWnxQ/Z2wqROeS2cEDpmnPn5bmUVS5wudCtwWubW4XzeCQ VBwc1yF7pF07+aY84z8yjO4V20a19XuefWw/8pgNAyTFZVKt2GOamELNIMxlG4AZmr0r6XPHtZ6n Ry6jDBbrHtLl1xv6AfjUSaxAipH5DS7eQc/nXCqMmt7Hp+3jF7GDdSGa6klZADIc4A6VXnh8pFKt lG/nXelZWPLm+aTkWLad1gZPNA5PHrWnY6pNb5GW38/LjrmuedPmOilVad+xVzx0yaUH1rQnoHQU Z6jNIlDJRlOeTWZN1yatESL9sFitjcMm854JPQ/Sug1GcNpLyrJu3gAYauWonKafmdlJ8sJLyOes mQyyJcYKYrf/ALLCaO920sYiIPlqT+taTk4y9TKnBVItnO29xJDetLkSkAg5PWmXFy1xc+YQFfAz gVvyrmuZObUbFjT4Bd6h5TuVkYHY3v70lxa+RdNFLIqlDz1pOVnYnlukyO1CvLKZizELlAp+8a7C 31C4i8OhCF8voeASfxrnrLmsjroy5U35Fix8Xf2bG8Ys/N2qSh3HBY/0FUpdX1DU0mvZLiKOFjjy HOQP69a5Y4WEajqPW52SxlSdJUlol+JyjpLDdzRzoUlBGVPoeanigmuZGS3BkkHKqOpr1L6XPGs0 7dTtNNsI7rRQk90xBUlU24Ifpjn8a9K0/wAT2Gl+CY4h5lxdWkRwGOWkOf5V4WKjOquSPc+iwkoU rzl1R5fqOnX2rXAvtsk91Ow3iTlgT6n0AxUVvYmwncXCFrxFK8kbVJ71306seTkj/SPPqUZxnzy2 Z9CfsfatLo//AAUh+H0+/wDdXMs9m7BQobfbyKBx/tYr+hqM5iB616D+CJzPuRXP3Ko55PrWZJKG JFTr2oAtoc96toaYFpDxU65+tICUcn1p9ACN901zerjNnJnnimgZ+Xn7bEMMPhfQ7yd/LUaiEDEZ 5ZT/AIV+e0kahfmZ3VRjKY547V85j01Wvbc+ny+UXQavszmBqEUPiJYYo3Z5ZAqqyfez346VR1q9 hgkmtNg81iDIRyF6/wCNOjRkqib6oxr1oum0lsZdnqFvC8CXEIlt0cSBWJ4b1613UeuNFp02pSyS G1YcRNGACT0O7PTPaurEUeZpv+mzkw9blTto1+SPMtQ1tb29md/lDNkFRitLT2t4rO2nWUwyKxLM PmVwfUGuqcHTp2SOWnJVat2zN8TXkdxfgxkBXALEJjJHqKo6ZbSy6nbz+f8Aueh+YAj1zzW0dKGv Y55/7w/U6qcKssrRXkM1uGAZOjLngkHGKsalcxWmhiyildWkG8o2Dke9eSoPnirevyPZnUi6c3e9 tvmVvDk9rAZZHgWScMMH8Oa2dZuBd6E80qMkYG5gDtYDPYis63+8JvujTDpfVtOzuc9bvbSRM8Zz /dEj8N71u28cLKwWRRJjgN2/Gpr86eprh+S2hzupTie5EMzkxQvknb2z2Nc3qSWy6zL9mneSPcCr Hgj2r2cOuWKjY8DEy56kpNi/ZbqK22zRN8+SoPXtz61QE+24JdRwcFc8iupPmOWUXHc3NCutusNE P3iTAhwwyMf410RDxXyqh2gkkDPG2vJrq1V+aPbw13RTvszb8MRRs1z+5jV1vVErAcvH1612qXFl LqL26RKysDkgYKn2PWvLrzn7R2ex62HpU5Qu1/Vzz/xjHYJd2f2pAqJuDMcGSQ44ye4ry5iguB9n dlcthcjBAr3sLKUqKbPm8ZCEKzS3NqW1F7qkUSndImA8zfMGPv6DHFaraObQxMmPtLcINwwT7HpR Ook1AqnR5k5mu1xdRQNEwWYt2KkY+pqnFGyXDvLKrRkZ2hSAD3rz42SbPWfNK1+hQ+zRmeGWW+Jh JOEJBHJ/KrVvHBE0u65Vkb7u7rj0z061vObasonNGmr3ciaCeVXaS1nVyeqls5x1q1p2qosht76Q xzKcKRyAD3P51k4OSa6mqn7Np7oravZQy7pnVTPGNyFRyfr6iqbWy3GmW7RpFIzH7khIY46nPpz+ ldNCcuT3uhy4mnBVLrqhNZ0+y0+ygMNxFKSp3nfuUN0x+tcIwJnzFzluCK7aUnKN2ebWSg7Jly4Z olXzU57VFbWtxeliCdozyema0bUY8zOeMZSlyokexmt51Mvy4cA+49a1po43gwpypHBA54rGU72k jshDlvGW5SJ/OgEnr3rQwBgcU0Zzk/hSDcHJKc81nzDk5qokSuWbX94Io35UNyKL0zPIWkUoAcAY pac2o224lAMwBO7BrZ0e3XUb9LSacxhjkFjxirm7Rb7E09ZW7m7qWi6VY26oZi0yHcWQ7g4+tc3v ga4YJH5asB1OcH2rnpynNXZ0VYU6bSW5BIkizLImFHUYbmmBg+XlyTnkmunfU5PU39KPmOPIjiAL AMr9fwroWiEWSARGOvtXlV3adj3sOr0r2MTTbKaTxUHkYm1DH5pG7elVtVjA8RTPbWp8lWz8nQj+ ldUZp1dOxwyhJUdVrf5kZuP7QeQSwoJnIJlZjuGBjFakcR0y2OUSfjKuv3lPrmm/d9y5EVze/Y3n 1WO30a3vriPa6DAUAgvnrz9KybnVn/eXlvLkMjbAeNqntjuawjS1bfodMqytp6jLXxU4WL7TGS3A kdOpA9PeujspLG9kFx5T3MWSDGOXcH/61c1WhKk+aDO2jiYV/dqLU9e+D1pB4f8A2nPhrq9o0kfl eKrTdG5HCvMqnn6HFf0QW5JtVPtXo4eo6tDmlvd/ocOJpexaSGXH3Pes4Nz710nE2SA9cmrKnjrz SEWkPFXEJI5oGW0NTrmgZKD3zT/1oAGPyVz2qgm0kzzxQI/OX9s+wiuvg5BJNvCxahG/ydcnI/rX 5hahAsK+dBcfZHjAD+dyrH+fNeLi/wCMk10PZwt1QbT2ZxtzqljaxzXNmnms0hEqCU/KfUc5FZUv iOOazAFjErqjb8nPmEnqT1OPT2rphQb95uzOWrXUfdWqMp5JX3QpFHMzhTuVclcDoD/Ot6O11PUd Bgsg7SWtsWKozY+9ycVrVlCCUpdDKnGpUlyx6lm38EvfaRLNbsqyRcyb24b29qwLnS7zS5Hinjli BHyADcpOM8kVjSxUKrcHubVsLOg1NGRKZNQmjRY8uPvYU/rWlFp8j22IVaJVICkck+tdcpKnE4Yx lVnd7mvZBLeZlIwuP3u8c4Hf2FVr+2eWJ5pGEq5zGwf7o7Vy8/7w6fZXg2ZthO0OqKwkEcgBzkcE V2LXxubMNFAJUbAlAAyp9SPSs8RSUpqR0YSs4Jw3uU7yygW9tpHtzDIeNy9Bx3qnqV40EY2SKSOg Hfj1rGF6jSlqdFS1FScdDEF1DPABPOAWcJIX5ABPXHtWRM0K6tKsbCZY3AVgSBIBXrwTWh4U5XVz cupLPVnt53vmtymE2suduPes/XLexi1IfYpjKqoA5xxn1z3rODnFqFjoqKEoud9TPgd4JYZlm8ra 2cjPzfhW7fa2Xjb7MGYMABLjGD3xROlzzTYqVb2UGu5HoWrC01/zbjfJv+Utu+7nufWu9/tq2+0i SW6jhTd8jbsZ4rzsVQbqXSPVwWJjGDUmWL22tNSlhvZNmobF3Dj5WI9T3FctqVmYbVJLPSFkZyUd gTuU+w7VnQqSU1CTskbYmnTlBzirt6kVtYrYxsJCTeMoZ0B4UHkD3rLhOqLqpuGDCJDlQOn4V1Rn CTk5ddjllTnCEYwXqdZLcOZo2kkLkqeMDH/66z7u48qOZLeXdMQCA/BY+1cUFdrQ9Cb5U31MmCKc aok8ylP7ySYzn1onmU3qwmARxcYGcDPWu7Rzun0PM1jT95atmjA/m27J5KxXLAqHVRvA9fpTYrbz IgjzK91GPlldQcisXJx1/qx0Rip6f1cntd92X80ESAnPGFP0rH1iBbCVZELkyE5XHGPrWlKTjVce hlWgpYdT6o514769lSNf3qsNygHjFRsLm2lG6P5wcDjvXqJx2PFam1zENzPLNIBKcle1dDo+46eP KUZz8wrCurUzow+tW5cvIZZoyHQMw+6VPP41VtkYwNvDAg88VzJ/u7HfZ+1uzOHJ5NOJ4ziu1nlj yflznNR9TS3FsxWGIyTyfSqE3IJHIqkS9UQwMwulw+znk12UoW704mWQEqAVbb2rnraSizsw+sJR bOfu7BI42eNy2OGG3haz0LpIu05bsRXRGXMtTknDkkdJau0mnSxMP3wXCgjrUml6PdSEzGNdhOMu mcj1FYSmqadzphTlVkrGjfaCFjZ42JJbnOMMP6VkanpE1poyyiPcrtg45xisaVdSsmb1sLyNtdjL tLu5sY3EZCFx1YelWF1S+yC1xuB6ggYrplShJttHLCvVjFJPRHWW7JJYR3IbLFAdgHPvWPJqixQs DvLO5YKcZ+hrgp03JtdmenVqqCUu6OeTzLm8YqGLsxPyitqJbryfKlZgv5mvRmo6JnkwctX3LNxd 3k2notxBHNDFwFAxn3o07Tr3XXEFtAFjUj5hhV+n1qHywTk3oaLmqSUbbnRReBIoY1mvbsqM7TGB 1b29aguh/wAI/wDZr3TL5mdG2GOWAfNwQcZH1rijXWIfK1psdjoPDLmT1N7wl40vG+Mnha6cCGCH V7VwuORtmU5z+Ff012rbrKM9RtBr0aVJUaKS7v8AQ561aVf3mLPzHWXn5jV3ObcmU9easJ061TDq W0JPJq6hO3nk0kBaQ8GrCmkVe+5KOeetPzxmkHmDcqe9YepDMDc54oEz8/v2y7eQ/ss67dw5Etu8 UikdsSrmvxdvtVvZ0aGa8Zp9uVUcqcnpmsZQjKabWptGbVNq+hzCKfMIJbzM87f1pXU8YXCnPzet dPU5NtzpNHTf5rEb/J+ZTjcWJ7EdTXQNKTawXU4WC8VvLAXhdx7dfSvExK5qjX9a7n0GEajSu+v6 bF+21W7tbg20M37yRMtGRgMPX3rbjuBrfhiSO8tx5qluUChiexrzakFSaqI9OEnWTps4+yENlp96 sFmEuUUrIZlO7JODjtnB/Si0nQXFoybDIo+YOvXivQalJSk3c8iLipxSVrGletpTWzXIukS7f5XO BhhXKylLKw8iEiSMnLuBj5uTn6VNL2jsmrf8A2reyim07v8AzOSv2kSWKZSVcncp710+jpd6jYb/ ALQkU0h+Vd23zMHv0HWvWq2VO7PDp8zqaGzqUeq2Eapd2yLIw+ZgQQP6Vxkgk/tZIbiIlDyDjgD1 GK5qHs7XizqrOq7KaNA6P9ot3RPkVfmRlPU+9cvNGYbt1DiULwxHSuqlU5m0c1WnyRUhqFpZwoHG eakbYLdwrnIwfn7+1bswRGpa4kih3DOdq7jwMmugazuLbTpbGWONCrFxKDyxxx36GsZyUWos1pwl JOS6aGM8HlycPvlP3x0waJIblFTzI3jXPDFPWr5l1JcWtUdPb6lcaNBbWr/PEwLktkjB746jirZ8 VWLyxvJDLnd9wH5R7+9edPDe0fPB7nqU8UqS5Ki2NGSSe8AvHhAhkyYnH9wcZNVZGhW1MMjMsLfw q3NcNrStHX/gHqqV6blLS/6mRHLAL14oJXedScJIeo9KrvJI+oBHTLRQhgGGefrXpJe9d6HjuS5F bUsSSvDbeamdQRyGOOqZ5xTbeWGdFWa3LL94Bj8wP0qLPl5loac3vWevmRTxyPcosDhJDxnd8xHc VsWcdosUkeGhnU8q+Tn8amo24KxcFFTd9uhrC3YIkkbZX/aGQT36c1T14TP4fYzwFGwCAOQR/SsK es1c6KqtB9mjiLG+ezmLBd5II2ZGMVVaWSXUy6ny9zduea9hQtJyPA9peCj5j0sJri7k3yBnBBJ9 c1u2sQ09ZNjArwSCeh71jVlzLlOihBxlztkD6wjSllDNg9AKZDdF0fYNqbicE9c1n7JxjqdP1hSn ZGeuTjnkdqkOSM11nmp2FYgJg804KMZzUh1EcHyzVGUHJ5qkJrQgtwDfoWPGa66+u2g0xD8vzjCr jPGKwrLmnFHTQfLTkzMF0s+lnzLcFy3MmSM4qtp8JOsQSLnZnJyMD860iuVMiT5ppnoUdlFab5EG XYZLZzkGrFndOkIEoRSc5AyRXiyftE2z6CEPZ2SLU2p28loYkQYHUAdTWReSG4tzGTuBHHHQ1nCD jJXLqNSg7HH3EBcKZI9hVsbs5B9qrssC9wTnhQOte8npofNSS5rM0vtJh0eIRnzJmXKn0Gax2jZ3 WRmDFjnnjmppRSuy6072iuh3Wh6CHt5GkZVfGR82Nw781sS6YiJJCWTB6EjPOK8qriL1bLoezQwy jSvLqZp0t4IJFLpMNgGcEHd6/Suk8LxwWWjs3mFXeRlcYyUbinUqOpSdupNKkqdZX7fqR6uRY3sE ur3EyzoSyRtIuBkccCuQ1O4GrThnOYQQFZOxxnmtKCatK2i2MazWsW9XuULaJbbUbK4ilYvDMjgH pwc/hX9R3h+4+1+DtNus5861jk4PXKg/1r2070de55jSitDUn/1ZrIP+tNQZkwPHXPNWFNA7ouRn vVxOlIC2lWB0oKJhyM0/1pCA9PWsbURmFqYM+Kf2qtO+3/sr+NYQu5v7PdlyOMr839K/B7UNNv7a 9/fws3fgZ/lUuUVKzHaUoXRnmOe3u2cl4pRn2yDwefpkU1W8+7CIjM5PyoB1qrpq5lJS6noXg6xk kvndo1iwR+6mQnfzWtquk6hH4okn+zQ21v5jP5a/w9xt5P8Ajivna1WKxM79j6jDwbwsLb3G3L2z zQKyiO78sqjEjcO/FZ1pFN9tW1N5m4iYlnLEA7vUCudS/d+8v6/pnVy3qJp26fP+ka2v2lt9hs2e cxzPtiMqn5XA4JY/TPNcjeWATWTbWFydRKbQZoDlefc12YWo5Uldaa6nmY2lyVXZ66afImm0MNZm aMuLyEEbHTIxn1zWDJHPbiRri0eZhjAzwPy6iu2lVhUe+pwVKVSCvJaGBcN9pm81gQB29BXr/hjR rH+xhcXMRnuFAaOMDOAO/oT7VWJk4wVicNGMqjcugatbBre2uJZlkiOTHG2FODyOK5S/ksprj7NI UDnKxFc/jn0rjpXvddD0Kjjy+91/pBBC1tZLEkwd9uQXPDDuMVQvdBtCpuIneKNsFl4PHH9a7oSa d+55tVKS5d7DYrKyto2niiZlcERs4yM47g965e/ll81klt406/MqYyM11R1d2zlk1FWsUpfLe43Q p5aYHGc81pi5+0KgbKsBtEjOeB71UlswjJXdjR06xt31lUurhZI+q7M4c9eTiuxtYrZNRMUECvC/ zl87hnuCDXlYiU230Vj2cLGEVfd3G67oD6raxX1qygxnZgDGVPc15xLarDeMpViqHBye/eunC1Oa lZdDkxtLlrOT6npC3cVxpdtBbk+WYwCSQdvHIqjPbRLfM0UittX5fMOAT6V5kVKEmexJxnTT9Ci2 krDqElzMm2YnKFZPlOaZt85yfPPzggA4wv411c/M79jj9kortcfEwtbARSHI74yMipGW1a1aRUd5 FPVR1FQ+a911ZpHktZ7pFGBZLe7d55gZM5j4wcf40p1SSdLhWQzKVO1gTlvb2rbl5pc2yObn5Ycv U0tOnnttKt4vLIjJ3OHOWB9jWpd3Hn6NcqIsBkIAY8H6VzSX73mv1Oyn/Bs10PO1s1AR4rhZWZsK vII960hpoffHI6i4A3AY4b6GvWlUseFClzMpA3L7rWBWDrlmI5OB71noZnmJUsW7k/1q0o69zOTl Yvtao9qsqhlnY8nHB/xFUT5trduq5dBzkjvjrTTvoxNcrvEsKAGzTmPPBpPcroKAGGWpwAxk9aTC ye40vweaqS8jOapEsqxkC6BbkVopqRaJVliSYA9H6YpThzDhPkQT3gudtvHH5USDgA5ya6XTTbra QR3EeWx8u4de/FYVE407J6nVRcZ1bvY2Li5WWMNaysqDqCv6VmGbzY5IZGKr6DjcOtedBO2u6PWn Jb30ZKrhwPLcfN0qymBHGu7Lqfm5zmjbcL82xkarcSjUBEEBhY5AVcYJrF1KB7PUfLlKMzRq42MG ABHQ4716dJqyXc8WrGV230M/fKwUrkqDwV/Ougg08vPbyyjMbAFV9fUn0rSpNQRlTg5yPQNMtpEe dWdnzgpt6IMe9Tuzx+ZlS5HQM3JOa+a5oyk2tD6/llCC5tSw+xdDZuFncgtkdB3rznVFmdn8ubzb UynDA/KTj24zXoYWybbPJxjk7WMqZbtWVbgyccDfnp7VppmO3RnVyhO50U4yO3PavV0aVjyFzJ67 j7W5jJ+z3GElBJDqoPPYV/Tr8Obj7V8CvB9z3l0W1f8AOFTW0U1TfqW2nE7CfmI9zWO2fOzQZEqc 5zzVlCc+9LcC3GaupnGeppWYy4nSrA/WgCUdM1JSGBrJvhmFu9BJ8rftAWguvgP4rhI3K+mzA/8A fBr8NL+wmuCHjLFCo/ehshBnuenTjmuKu0pJs7qEXKLt5GLqaxfYwstqhfB2MTnHPWueji+yXS38 YizsOAw43e3v/jU03zQ33Jqx5arutjrbDV3u9s8UZjukjw7Kcq/+1gc1oahrc9zYjzgjX8ke0BB8 jYPU+hxx1rzKtKKq/wBbHr0ZS9jrs9vX/IkiWC5Nr51isgKE/aQfnQ+lU99qmqTuZQ8Cn/j5VwBn 0PvXEozldXvp+ux6TlCm4yatr+m5Dr93K1nFazzo0IBbbgbunB+ma5uwR4NQjEZKuSO3LE9vf8K9 DDpLC2PLxPvYzmv2Na7vntBNcrG5dkw+cgLyODWZ5iXmoK4csWHETtwePWlShyrnQV6ilL2bRmXW jSRJCJU8h5VLeuDk/nXf6Fq5sdKNkQky+XhU5znuffqTXbUarU1Y82nelVaZ574p1FpdeEdvIwit yQhJxkfTtwK56Iz3N7CxfcAeCT261304KME3ucFad5NLY69I3v45nmiKRrEQjgdH7A+3NXNN8+x0 uaKa2InP3Uly20GuOtJKDjc7sNBympNf10L9xuv/AA/DmVVKS5kjUfNjHUV59LJFceZbqpfLH5m7 e9PCt8noLGK0/VFOS1ltJv3mDvXj6U0BthOQuOgx1r0U1LU81pou290LVVaSPzZAQyK3Qcdf/rV1 FtryzRvvjSGQtnakWd4+v9a46tLn1ud1Gq4WVjQ1fVrp7KVdM/c28UStNu+TeD264P0rmbrVLCaz l8m08tQg8sHqG74/xNZ0KfLFW+ZriKvPNt/Ik0PUbma/8qUK0e0/ORgg+vua7SC3jv7cf2oEmaN9 yPFwBzwOP61yYlqnU93c78JzVaVp7HJzi6g1HUVuBI9uuRG0Z3Aj2pYrS4TTrc29uXJA/wBZwcf4 1q3Dps/8jFc6bvur+lrj5bfddvvAiGMBWfhiec+1V4pLi3vZlYr5Y4TJ+96/SlpKNmUm4y5kTzyp PDyoMijk7MkA9DWYkyPMUidSy8fU+1OEXy69AnKPMu7Na3vZ4rVIbhBKyZLP0zUeqXMkdirqQIm5 I25Ht9KzjGPtF2Lm2qTvuYVhEJYpnlX+HOPTNaUqs9sCq/vEA2vn3rsqN8x59JXh5sz5ZpLbV1nj OSANw6ZHoaDLBLK87oI4y2SimtEnyJrcxbTm09rmj9qjuNywccAAsvy8fSqCQ7tbkhIEvB59eKyh eCaZ01eWpyuPczlZSuDTiQG4rrZ5yd0Hfr1oJJ96WhXUhbOTnjmmSA+XmqJa0ZQfIfPemKc5H8XW tDH1NSxiieVJZThQQTk8Nz0r0v7NbyWSSBFDqvytjkE15mLlJNM9rAxjaV9zHvoZrG3YvvkYtwcZ qi0crwb9irKR1YcgCsYSXLzG1RS5+TsLFabXiYkhl7L3rWRVEblcZzz7mlUlzamlKCjuYepWzPey XEkisdo2qZAP0rmpll3OZARnkE/xCvSpO8UeNXTUriweblI1JOWyoHQmu+jiu4Zo5Ll8kAA9CD3I x6VjXcbpdWa4dStzdFY62JhKI3txhcfeNZEus2i3MqzOWIcnhDyfc14dGjKTdtz6WviIRim9gt9T mZJ5LmSP7KT+6GMEf41l6VeRW889uiw3ETNu2MOc9sV6Hs/dkkeV7VyqRk99TXOoTanPDHc2MdpG ZNpDDcT7nH+FM1PTIrK9mRblFikiAXPUfgaim1RmoJ3uOtetF1GrWOdjjRXdUALKvLleTX9JvwQu /t/7Inw1u9xfzPDNkxPqfITNe5Bt0233X6nly+E9QlyYzWO/+sOTzQZMkXOQasp1FAIuR5zV5KA1 LaVYHPekMmHTJOakFIYEd6zL0ZibvTEfPHxetftPwx1mEjdvtZF/NTX4JS6j9l1W5tre4ivYpUUS +REFGQOQSQMkHI+o615+KjzRPRwkmpaHOao3mwlYtxJblmAyoxXPaheTJ4b+zqkQjabcXx8wOOma jDq8UmVi7qbaOt8PNp9vb2OoJOTHtMd4B/yxJ6Dp0PtV69+zpqCtbWouJWchXB6Kepz6V5taNR1t dL/1+R6eHnT9krK9n+diz8k1kqxXckJRf4Rgq2enPGK1NLtbNopLO5gjSW5wZZEUEMxPGc+1cTlK FJrqd7h7SopXurfcc34p1K3tpIrGUxzLErB3CHOTwBnuKlsdVs4dnmRJNaom5VK8r9T1616HspTw qseR7eNPGtv0ZkzXrN4knnh2S2dyQBA5xgdenc1Vu7A3Jt7yCN7cxud8ROCw9Rjjp2qoONKzfaz+ 61yp81Zu217p/O9iO7umaxdzEyJE2FZjyRVCPxC1pNBI8BmiDksA+3gjkA4rtow5o2ueZiJcs790 X/sVjrfh2ee3tme7ijLTZyPmYcFT36c1zWn2U9rqite2zxjbwJAV6962p1PihJ6oyrU9IzitGdhp esW0eox2jjLhScDGMjnr3FNvbiS4v2dw43AENn9K86tBxq3Z6uGmpUbI6rRGs0sZgwLbkG8v0PfG KxLzw/pkWnvqEf7p8limcAd/yrno1Z05td2deIo06tNPsjg9aW6dI5XjKRAHa/Y1zwyACxyo5IzX 0sLcuh8lJvqOkmaWdpmzknsOKvw6obbS7mKOBC0q7S7D5gPapcbpK5SnZ3sZ/wBoma2ZDM2w4Bwe tCcjIOcdvWtbWM7yb1JormazvUmXAIGdpHavQIZfM0hZlLQmRfmUN1HvivKxcVpI9vATd5QfqRtF ILSS4iiYyN9xezn3qh5962hTvfs9qFICBOGxn8656fLJX3dzorKcZ8uysy7exeZl3k3mSMEFuoPY r6VhzaVdrZtkCRmAZizYbca3pVUlZmFahJu8WPW1kh07bNI4kKjftbPH5VLHDZxwj7VbeTtb92zc UpTlJXiVGmoWU9dBfszNfxyG4O0DG0DIb60/VoWZra3T95C52kr+maUZRdSPSwShKNOTve5mxwSW DTpOhCMhXk9fxqeS5t49KV4z+8wPkznn3rpknOSa2ZyRfs4tS0aMxszaZcTHb5quCMnkj2qS3CS2 vIAOcNxWstI+hzw1nd9S+IorFF3MGU9ApzWTvkXVTMMs+7IQHk1FNcycn1Nqr5bQXQzwcLkHkCpF fnJNdRxbD+vQ0/3B5qA6XFJ3feqKQgxnnmjqO90Z0v61LYwLdaokTsVVuWI7CtG+WLZnFc00jqrq 0tYbFTHGQQyge4/oa6nTbmCXRzGgkjIXjnPPsTXjVXOpSu+59DRjCnVcUuhQvLi9kZBIcp5n3VGf l9zWcxaETbpQzMSy7j09qI8qjZImblzOTY2B7iScAAPHsyStRz3E73kVrBkDOXcH9K2UY82pi6k+ VW9C3c2UT6valpWXIAYkjA+tUtVtkMzoZFLLgcdMVpTk3Y56sYq/qUY7OT7dbC1/eNt3MSMAfQ1t Xt1Glxt3t8vEiM4J3Hrj2q5rnku5nH3YNPqZzapdRxNHE+0P0JbnHpUqaXqs0QkVACRkiQ4Jz9aq Tp0leXUUI1q7tFXsPGl3iRh5ZVZCCQPU+/pXOJJKkjuZgrBgevXnpV0pwq3sTWpVKNnJ6m3pGrzx XpeTdMSc5LcD169a62XSV1C6W9e8LdC27r04Arjr2oVFNLyO+gniKbg3s7mTc21zHr32SyKyYQHJ OO3PU1/RF+y/dte/sE/C2VjuZdBhib6plD/6DXp0pJ0b9dP1OKalFPtc95l/1ZrGkH7096DDoOU8 81aTrQHS5cj6+tXk6UDLacj3qyvT1pDJlqTn8aAFIO2s+8GYW78UBseH/EaHzfBt+pGcxt/Kv56t atILLxvqsBxCFv5UI6dHNcOKb5V5nfg0uZt9DndTu4Chjj/eFOTxk+xzXGCVp71MqZEZjtU+tVh6 bjDUjE1FOroTJO9tekOjKiuFkRW6jPSu3sNZt4pI4YN0wZdzIw4Untn1qcRS9pEMPV9lO50Ums6M bc27SsJJCCGAyRjnj3/xrBv9f+wQXL2kOJpsF5CfvY4Bx2ry6eFqOSjPY9epi4cjcdzkDcXd7qIM CGVyd5Qnrgc12UZmtfD8UstmozxIVG5se/tXo1ZQjanezZ5NKnVk3VS0RFDFA8jXUU0MbglgSnzY wOn5VK/n3MsF0twbe2UncLpgrNgfeAB/SuVpc/vry/4Y7Odun7r31/4cwr2+hkimDHzX4IjXjcB3 xXKXEqTSfu0KoCTgtk/nXp0YcqPIqz59WdV4c/tS0uPt8cxjtFGXVgWEq9xjvjFWvEWrXWqX6v5f kwIAlsm3Hye/rzmuZxpyxHMuh13msJyy6/1+JnaFYzXetBxGBLnZyQODjOPeutSE6f4hhm1PTjf2 UDhnhWYqJ09NwzjjuKzrTiqyvqb4WL9i/M0tNx/ZHmllFqxO9iehHArE1bWbL7M1vF+8cfc3A8et cVCEp1bpHoYucIUd9/yOI1aWWXUFtizfZlVcDHPTOazn0u8+Zoo964J98V9BGUYrU+XlFy1RJFo2 oSs8v2ZhH3KY6/TNbVzotu/hpGtLeV71kywYEEEH8smsp1oppp6dTop0HK6ktehyTWsqNtlVkIOG B4I/Cr9nZPJqkQt5BMnDP8hG0Z71tKVo36HPCN3Z73PSX0hdRlEM9pGUVMDysbgK5nUop9E1VIXJ 8pQFEQ5+X3968ilL2nuM9yrH2Pvr0Z3ukCDU9Nia3kVgeQpHQe9VvEmmRrpGoy+YXaJBs6Lwev1+ teVTm6eI5Wtb/qe1Ugq2F579P0OTuY7K7sYV+aF41Cggk4OO/NXoL8zWEkZtUW/iUKwY/KOeo/Cv RlGbSu9n+DPKhKC1it1+KJ1mha4EySRyDcFKqPmHv/8ArqnqEUclwWnP7oLufcM8+9SrxncttTi7 mRFKsaXLS7QMlo1XuvrXM3epXEl7K0UrLExGB9P/AK9epSppybZ5Naq400luMa/upYiss7unX5jV 2C92+Gp7e4ckn/VEe/XP5frXS4JLQ4Y1G5XkzMSaQKSsuGX7oPOatabI0t3JvySQTnOMU5JWYJvm RbLuZirdQeWB5NDrtaM9X28NnmoWgm2zEyxzTgxHHetARMs3PvVhZM9TSaKvYm4I96gkB2561AGf KCTmrelyiLUSTySvBNVJXgxU5WqJs3XH2lnR5mj8og/LyCSK0dMlMKyxGQEqRgHgnNefJXp8tj1a crVeZs07qZ2Q+VsEnuOKyhHGNQjUwlkxlW6gH/Oa56eiOuaUndolVUg1NcLIZZgBt7ACqGo3kERm it5HWVWAbapz9M1tCLnNHPOUadN9zEN5du/nbmJU48zFSSX7PhmHmOw54xXpckenQ8dzk9yVNSQW z4LJJt4PpUdoy3s5FxJmQAnJ6t9TU8tk31Gpc7SHyWkttdySRqSE5G4ZDfStux1tpLOSCcf6QMBO OB7/AIVhVgq0b9UddCq8NNruW5lu5LMRS3ZZN2VYAfNxWKujSCeTehfjjdxkn09ailKME+hdaMqj Tbuxr2otoXZkZWOE5HC02O5u4NPZo7iRUDYUAkjJ/wDrV02jOOupyJypyutDTtWu7iBJnYqm7/Wy dc4HfNf0B/sX3bXf/BOj4el23PFFdQk/7t1KP5VcOW0kvL9TokpeyUpH1K/3TmseYfvjVHKxFq2m SaBF2Pk+9X05GaB+paQH6mrC880iicdfepQDnk0xD2HHWs66H7kmkHS55D44h83w3fL6xn+Vfzo/ EySez+OHjG0Pz+XrE4RAOVG8nFROCla5UJuF7dUeYzveJbB3LojEqxIx+FJZiB5JjcSFSFBiAXIJ 9DVaKPukK91zFc5JlYAlwOnt3rX027nzGGuhaQRjLyDJJ646c+1KpG8dUOnJqfa465tVuLx2syZX 8sMhJ+/k84B/zxVq2ktr228meI+ai4QA5LNn+v5cVzyu0n1R0rlTaWzNXSLGXTvFQlukYhEYbIcS YJGOcZGOtdnbTWLB4zJ5Iwcq+Rn6g14eL5qk+ePb5nvYKUKVPknvf5HH36Ws2qMbXekBURhkB2kk 9R6CprezvXs5LYQwzKpzknDL7Dj1rv8AaqnBe0eqPLVF1akvZbM5mayjg1aRnl8m4K7X38AE9RWT DLbwySKQsmM4BGcmvRg/aRv3POmvZyafQ2YNTvbmx+yWBESKmSgbj3PtUcN7c2tpJFckXbxsREu4 EYPfjqPaslThG6W/c3dWckpPboi9Y6yFvd8CmCYdQo4PrXfNrUdzYxxXcsW7avzADb06YHTtXJXo t69UdOHrKLa6Mz9a/fWS2trJGods7UHLN1/xrziVLm11F55I2EUeVJc85rfCxtTs9znxc71dNjX0 uB9Q1eCbyTeyM64XOOB2r0S4Z1t4LS+0+COcO3khBtA5wDnv2rjxcrNJOzO/BQ57trQqtNNZ6Syy 2YkfncY16D6jk8Vk+ZIbkACT51yjnnHfB964aaunrdM9Wr7tm1qkcd4gtmm1OfUYIw9vuCyFXyQc c5HbnNT+HI2k8Qxx8Rxn5hIQSOmcf/rr3W/9n9EfNcr+s3XVnqjQIkNxN9ojJCsUfkNnGcda8f1q /SfUZZFkMjN/fGB0riwUU5NnfjptW13Lug+I20iExPbedat98qcEmprbxULzVpYb1SIJZPkc9UHY H1rWeE5pymn6epnSx3JSjTa9fQ7KztdKnE88RE8Y7qMfMPXj0ppa3fa1rb5ndwJHYDjHf8K8xzm2 1LQ9mMYcqlFX7FUQvA9yEAEso+Z1AOR9aydTvljjt/ljuSGxNgg5H071pSjKrO5nXcaNJ6f1c4PU L97nV5JSgSMHAUcfLVaT/Sdvlx7MCvpIx5UkfJTnzybZEyCNsScDODV6Typ9N3Qbi8f3hsx175ol fRigk7rqZ6o0jc/hg9a04LqOHTMQWYM5IBkZs/j7VMk5dSoS5XfccxlmeSY5BJ5wOKei+ZIys6q6 j5cnqcVDaSNEm3fuY/ck0mCea0MWNzhsnmpVkIJJplIsq+RnNPL7oz696iwynKOCRyajtxmbLHgG tOhm9GdDbzut7yoKFNoQt/jWq6lEEvByBn1H0NedP3ZLzPVpe/TbfQadQt0B887XPUDmobXVY5NS 8jyzktgMOan2LkmylXUZJM6OeeOKQLwZFXcBj5sVyNxNDdX0+LdjcOflOeAfXH0qcPCSu2ViqkJW W5owaeqWhinnIgIy+f8ACqdxpVqIRc2spmt2Gdp4NdKqu+2jOR0U46vVfkYNxEkEgAO5sZbv1q3p 2l6hqEqNaRY5x5ueAa6ZTUYc0jlVOUqnLE1NRt9TtrKFL5fM3OdjK3H41hz+cl4wkcNLgF8etRTc JfCVVjOPxbneeFoZv7dspL6ItC0TMgb+M9q9GubB3ljmktuHbBcAHjB5r57GT/fe69P+HPp8DTXs byWrZ5x4ys7yK+tZpQFjkT5CBgN2/OuZtrtzClhcORZmUO4VcnP1r2MPaeHi0eHik4YmSfU6OKFm svLnZYkVf3YJGPZvriv3S/YSuvtH/BPrQEDKwg1G9Qben+vZv/Zq6aDvzWQ6itT1ep9kMPkPNY8/ +vOa1OLS4xeSfWrcfXPWgNmXohlsk81fQcc0DtoW0zVhfrR0GTAZ781OoJ+tICUofLJx0rNuR+6a mB5b4sj36XcjrlDX4PfEHRBa/tTfEi4MSSbdTJEbrw25Fb+ua4cZPkoNnbg4c+IRweoWdjqOnXH9 o2zQjHyuqjCH+96Vwur+HdLj0Vp9MuMTIhZlZ8mRevHvXk4evVg1F6xuetiMPRqc0k7SsedFJQpY qwXPDEYFXDbMZY0icEy4AAPc+1fStrc+WUXLQ76206W10bdcW22WONQWc4bqRgenNOg0GGzMchKv LICRGjEE/nXgzxHLdrW59HDDc7SlpY3bXUrGfRmLqLWaJTv2jDA55z69Kf8ANf2Eksx+0BgCgdAc DHbvXkzU6U7vvoz2aTpVoadtUYlnHBbPJkOrhuU4xj+lSS6nIjNM0TxEOQFDcnngj2xXZpXdpbnn NSwy5obdfI4/XdQOs6jC1tbOsgjIYlfv+/Fc1Nby29wvnLgnBYZ5Geea+gor2cFC+p85WftajqW0 bHWt/Laap58C5G0jBHQEdK6XT763Kh9QsFkRQMSKmCX6jNFSF02nZhSmk0mroybi4MWqSH+J23Ky NgYPNbVtqRi08Tpaee0bjMRbI+uevNEo3SGn7z0IZtcjku5bgBg5O8Jz8rema56/vrm+LTyEbN33 R0FaQjbVnO3zI6rwbPEmpqQzLdIS0QXI3EjpXo1/9sJS6njWZiAMpjI968DGJe11PpcvbVD3e+pR SQtmORyhHZj61z97dOmvJaIxjRo3IYctkDt61z0I3nqejiZWp3W+xXsdNshpDRrN5s8jq0mSfvZ6 49O1X3W0sRO0kKpM0YV2U/dBPAx+Fds5zlPl2ueVTpU40+bt+Zk6vr8k8ZCKWEXGduCVx0OO+K4V H+1ajIFVXL/d3cYNenQpqjA8ivP2s7G2unT6fpF1LMvnOCNmG+UDqSRWZ9qDbpPLVSCeg9aunJVL yRlWg6aSe50eh6y1pdYQhs4BRjw1dlHGzI8sr+X5gJ2RngH615WJpqNXm6vp6Hs4OtKdLk2t1OKl u4bC9vVa5kuXkJA2yYXnr361zV1DO0iTxrI277ue9enTVnzPS55lVykuW92gtbSSe6kSdfJbbnL/ AC0smnS/2YLlGycnjoeK3c0nY5FTb1M+SCVVRnBJkHHNdzomlQRwKk5zO5y2OR9M/Q1lWlaBtQi3 PU0tT0ILpiCMLPCCSCFw351wslsIbohEcKem48A/41NKpzRNK9PlZ0NvZxtpqKxG8kEH0+tTizTG CQZMEZCjk+lcjqPmZ3wprkXocNnc31oAOeDXpnkMQ5yTmgA7vWmQtywDhakJyvvUdTRaoqSEjvmo omxcrzjnOa0MetjZ8x5J97j5F4XHetRZTtWKXayHAXJxgVzyjdHTTlKI2801EzJLL5KMwAYDIPpS W+leTf5FwcgHGFwQa51Xahsdrw153TGzpfS2pljn8+NVz5g+9jPSjTUC7Z5mEGGyXPPFbcycWkcz jJTTlsdvbFkhmaOOGeJwA24Zb86om3WWSfFuYowwykWMkDrx+def8N2eh8TSOJ1iDb4ieGEE7sAJ 3Ht9a7Hw3f2kVk+nCGRZowxfcQDnvj8a7Kyc6Ct6nHh2oV2310KN7r0S3EkaRpdRLJvzJ1B9iKdJ aQaxeWt1FAtvBIMzOBkgjsP5Vi06MVNs3TjiZuNtTvIIk83aIvKiUAQkcAGres+Klt9GOnWwiS+Q gefKCUBPOCB7A14dODrVUn6n0deX1eldK3RHmuu69PrGjWttNdLMYsOxWHZtPoPzrDsJIrS9Wa4i MyhgRn+tfTwoqnS5IaHx9Ss51vaTdzdvWj1a9ka03eaEyExwRmv2z/4J3XTz/sHyW7/etvEN0gHo CI3/APZq3w940nF7pF1eWU3OOz/zPvM/cP8AOsa5z5pOaDn6EaHI9auR9aoC9FzWgn50mii2metW VFAEw/M1ZjGTzSEW3icwbyDjHXFY9wMxNnmgEzzbxKm6ym78Gvwx+PerRaX+2N4q0q/CW+mAx3cs uwksSqjoOvNcmKpe2otLc68LW9jWUmfPniPxwlxZzabpEW6D5sySDAKnuB/jWDpciQyq7wsLl4sN 6AH+VcCw0qGH5er3PQjiY4jFqTWi2Nh4tLvYPs9yuJDkoyrgqTXLX2jyWF4HQyBd42Shcg8+uKeF qyj+7n8h42in+9p/M3xeak+s29xqrvPbSMCEK5bPUcY710F7Ihaa/D+XIq/cI449PTiuStGKnFQ2 2O2hKfJJz3Wv4HIQzrPaXb2/lIgy8iMCSecnNar6ldWuoaeSpNjKrKu0DCEgYz64NdFWnGcuWW/6 2OSjUnCPtIvR/lcdarDey3V7EzIGOCWJ+bAxmoRbPOssZnEikkgHkDA7VxOThUaa2sj0opTpLlfx XM/Tw8EbzGHYmSQ56CpNW0+C8JvAfLlbG7bjDcf/AFq7PauFfmWpweyjUwvJLTqcQFzY7J4ztU4U qOvJPP51NbiWVfNUZ2cIrDivbduVtnziu2rFa9aQ3zLcjbIFA+7jjHFRRSsgJVjuOKrTlRLvzPuS NMElJuAXEicBDjB96p4IkZVGQe1X0M3e+pZtbmaz1aCZCQ8bg8cfWvWLrxBb67oQtGxbeYAFkj4I I6Zrz8TS52prdHoYWs6bcW9Gc9fX9xYHyJ0Z3CbmmT7u4/8A6qqprXn6JJuRWv43xFKB0U9TXNDD pxUv6t2PRq4qSm4tf8P3MK31eWC9SaHd5iMcHPJNdtb3TX2mW32mJ5JZGDMzIozkHv3xW2IppNT6 nLh6racNyGSwuTdm4to0jlMZjZyowTjoe341xcTRLqUfmxjPmYPr9adKXPF97CrRdNq5euNRmSSe METIPlLFOB9apHQ76R1aFN0TKHDjjg1tHkoq76mU1Ou7LVosxaVeQSuY1DsoznOMn0qFtU1W8doY gx2gg4/WmvZ1XzPoQ/aUFyrqUoXms9WaOWJHdlIcSc9avJdTrYOIQUhDjeQeF9s1o4p6mUZNeo67 vYWkL3CrcOY8HZL93nipd8c9isP2sFySRuGAPTmos0ky3K9xNKguf7RcXRyiq21SmQa3LWWG219Z JVPlucOAcYz6VzVHzScV2OqiuSmpy3ubt/qEdjpiwToZBIu+Fw+Rg5NcdLcQSeHpnfHnPIGjOccd +KVCLUU11KryUpWHW0g8u2d2xuOBV+6aPe0cc+GQhiD0Jx61Ek+fyNqbXJuefj5Tk0E5Jr1DxgBG 05OTQCBz70APZuetAbAPc0rARPnBJquDiYNnkGrRmzagJaB2C8cAnPSumtNJmuTFPcOIYI/m3Hq3 0FclWagm+p20Kbqz8jXjlsbuUWksbSK+SjKhwcc9e1Puo98jNEvz42txXlPmi0pHvJwnFyjvsUbO xMVg6SSMI9rEEADBPaq1tKtvOI3tibZjjf1FdMZc0pHDOPLGPU2PsA8xZ7eYoMj5UOM+vHSqV/fX NlbSTzzhzn5Fxg57D6CqTVSSTWplOLpx5rnAx3My35uQ+Jd24SHk5qZvt6sNUxKAZDmULhc+ma9R qPX0PJUpdPUjiLzyNIQOTyM+tdvBMdL0q1DlbyExbwImA+YnkE89K5q8VOPKdeGk6cuddDdbXDJa QyqTbnYAqsAQpPv3ptroMN7q6tNefvJZNxYnG1jzXjRX1VNpXZ7028bo3ZIXXPBtvYJtjuFlufvE Lzn6157epNFLsYKOe3evUw2I9stTxMTQdF6FRZCrqwdgwHJBxmv2z/4Jr3zz/sqeLrR2JMHiRmXJ zw0Ef+FepG3LJ+X6o5IN2dz9IG+6Sc9Kxrv79ZDIEOfer0fX3oF0L0XbNaCfnSKLie9WV9e9BRMB 781etl3SjIB570CZvz2hTQTIwKDOCc+vrXIT8o2aqQjz3xAubSbPOBX4JftoabNB+2TdzJGdtzps THB+9hmH9KWhO58mlZirIkRYIMkkjKj1yPrXT6BILuNkIaSQAhhjqM+tcWKSdFvsd2DlbEJPqdcs QS1eUwj90udpXLH2rMN1aLGjPKA7sSkc3LbuoX86+doqc72Pp8RKnBpS7HO2t3uv4wZ8SK/zZI/M V0Vwbk2/lIVkO8E7kPK9678RGMKkXI87CylUpSSYNYHIlgDQlh99cEYHYioDa3n224uJovPtY0BV VGdxPoK54VINe89djerSmp+6tCWKW0Fsz5EK5wykHj2x61WuxCpl8qQxy7eQBjPPFZ8tRTu9Tp56 Lo2WjSMy5Is/D7LcyFsjK89faoNPRLq0VmnCzn5tu8H5fpnjivSi3GDml1PIqRUpKm3stTqNK8Mx ahfSJcTCKAMCz7eenpUGqeG1s9YumtpXewHEeF3Nu7Zx2zWccV+95X/TIeE/dc6OO1O0iju42u4y szgMrAH5/rmsKZIlvH27RuGRgcDPavXg5ONzxpKPNruPWGJ7hDcyBU6GXaT9OBSyKYJRLayeYFb7 2O568Gru7+QOKav1NvT/AA/NfLcSMVWZB83zZ2/UVnypPaOixuqmPhh1B9eKzjUjKbj2LlTcYKXc qzy3l1FOZJWn2AHb0ABNZ6SywuQMrz2NbJRsYuUr3bJ2t2hkjljYTrwxx1ye1elx3VrFBY3tuYpG 8gs0cgJ8o88YyMHIrjxHvKPmdmHSi5dWjmtV8RXt5OY4EQGYhpfKTkkdM44rHjtkj1GORpwWI3MD 2NVyqnCy6lKTq1by6HTWWlxSWjuy/ffPJ+9jkCukaGSOzEY6BcMueRnvXjVKrm7M92lRjTXNHqZr wlZSykOwGWQ8A1LFZWaQzXMMEbI/LhSc5PUU1OUY6BOlCUtTB8R2PnWY1CHG2IANnqOenv1qppVk t34NvFlEgEkyncnJ46cfjXoqqnQUvM8mdG2IafZ/kcvfWMtjrBtp0ZMMME/xKeh/Kt24sDDGCuED Rgjcea651Fo+jOGFP3pLqiaC9lt4zHd3AkiONnB6/X0q4qzTMxmWPa7ErjqAK4ppQfMehTbqR5H0 OQurmdrw7mcAH5QTwKiuLuae5EjEAjlVC4Ar1FFdDxpSd3c6SxcXFjg4BXmjzlkdgwKPkg7ehrz3 H3n5HqwlaC8zlM8cnNIMmvQPM1sOHXNKVP36Q9LDTlm5qVD8pDHNDAjbGCe1VGzvzVIzkdfotqws 3myHcjdGp6Z967OCC8nsmfapbaGYL2PtXkV5LmZ72Gg1EufP9lzEkaXSsASwyR6/gRVqWFmjKQ7V udpxIRnJPY1597b/ANI9SSv8P9M5WW0vWtRHdSGGckhypyGOfakgayS4WCZyJVBGd3Gfeu5tS0ge Wk4+9U9DWW0jSwzbNtXBO4Px6n3rnRpOo6vqaT3UTQacrYZ5DjK9yB1OaKVSKbnLcK9OT5Yx2/Q6 KfwlogvbeWCdxAq5eMfxHOe+a09ZsDqHhgWKxRoEYGB4HyrD0YZ4P51Ht5Sa5+hTw0YQfJ1PIzG1 teGIoQ4OCDx+ddrpllH9gjd03KgyQ3O5u+K78RNRp37nnYak51bdjRgtobjWII5ZlRDlvJwCSP8A 6xrobi3iks8szQSQzBo5ARzjv+teJObTTfT8T6GML3Sej/A5LWNbngCL9ra4uweHZRgjPf8AOqV4 qXlha3O1VDuA4I4Bz7V6dKnyRjO1rnk16nPNw3t1NHUfDWn2DWc93MyQXDnJjAJQdOlfqr/wTXuE X4f/ABP06KQyRQ6rbPGW4JDRsM/+O13YarKrGTa0t+qMa1GFK8U9f+GP0+JODWRe/eJ963RxFSM5 FX4jk+tHUm6NGPPWr8fSkUXF/OrK560D1J19zWzpcfmagiZwTTW4nodtrNtLbeHJg+75kVvmz6+3 HevL5x8pqprUiOxwevj9xL9K/GH9tHTm/wCF96ZNjCz2BUnbk/K/+DVzVXy022dFJc87HxM2mG3L hCGjB+ZiM7h171Jb6WNRk+0N/wAS2TeQPKUruHqa8+eIioc/4HdSwsnPkenmVJNdu7KC60/7M0k0 bGNZdx3AE4BI/rWV9rmuVe1MUcrySqgmKZKHI6VvToQguZephVrznKz6aHWeJNBtLLxBojx+arXK RxySCLEe4DBwB374qzLfWdteC3W+S48teJVUru9Mjsa8+pzYinF2voejRlHC1Za21S/4IkF3C+qs xOUYH5VbOc1etLmG6uJVt/MaSIjcm08CvJnSqJN9j6GlXpyaTLeoobNYnmMbZ+YlXViRjqea871K 6VJs27K0rYzKxGT35r0cHCU5X6Hj46pGEbfaMW7v7nUJI0lP2hVAUBVxk967rwv4QlnsZr66m+zx hDgjlvwr1a9SGHo2PFo0p4qte53Vi+n6do1zdz5RXkKxTyZO5QMck++azLt9QuNTtEsX/wBAnGPM jXLI3v6DrXzqV67lU21t8j6dyUcKo0/i6+j6nOeK7KS48OWq3Ujm9iztkYEDaTgA/j/OufsvA2oX Nt50s8YgAJ/cHe31Pp/OvZji40aF2uuh89LC+2xFk+mp0w0SwPh0xRxQSrE4RyBlsDrXO2WiFru6 S4jCwhtqqFz175rkhiZxjLm3PSlhYTlBxWltWa2n2aaY+1Lo73J3WxznrgcVx2q2dxD4mVJYiDcP lWzgMCevNdlCrzVndWbRw4mi4UE07pP7iK4tdV02ZIFdTA8oCMnO5vT1p2p2DWvh9Z7qFIr0y8bT 1X1rvU4yacep5vJNJxl0Rl6deutyBLKAoPHyg9a9FihtWtgvymHA6nt+FcGN5otNHqZcozjJSOXv tHgtZSIp2O9/3e1SQlclJBKt+Ukbk5OccH6130KntIXaPOxdH2VRxTO28L6lDb7YrktNJMNiwA8D HQ57ZrvJtOuZlM6uzhE3MF6+4PevHxMVSrcz6nsYSbq0eVbowFia3kKRRGW5mkb5JSRgYGTntxni nQn7NFPb5A3tnaOjD/HNJ2fqzZb+hqGzs5EKzIZo3HzLn5a4rTpIkXULLcIxHKzISODRRcnCSfSw sQoe0g++hS18m5t4JljACn53zWWouruxWSGUs8XyuOxGPfrXqUrKkm+h49ZTlXdtLlCeeXzIxKwk EZ+6Rjmt/SLiWYyAybjjI3HpntWtWCdM56M5KqkxmqIj20eyJfNPcoePxHSsZrG8RWlktd0ajBwe lKlO0EpPUuvT/eNxWgtheGK72MC6k/d9a1Qwa/fajCMrkbux7mqlD3mzKFS0EmcvgnqcmnYI4PWt zBASce9SBiUxSKADrnk07jGRz60ARvkjNVpBj600RI7Lw3te3ZpXYgDChRXX6VLcSapdSmKWNC3l w7ZMJjHJIryqqTnJs9ui5csEiLV5Wh8QmSKTMEaZlYfxVb0bUo9T3OSYlB+Vn44rjlDmpc3Y9CnU 5avJ32C+jEbGKZvMjXLhgM+/FcdqWo27H5YFZ2Y5J9O3PXNbYeLm7rQ5sXKNJOLV2ZBmlkjR4bqX cXwI1JAr0iO8v4bW1EWlTzxkgEkYUccnB6V14inFxV3Y4sLVkpNpNlhbS7uiRGoJZ8j+8ntWdND4 iaze0jENkQ2BIsgJx6Y7158KlFazPTqU697U+pLf+E1XRo71r5J7iOPLgDDSd+/1qzYwIl/HDLOS pVQoPGB0pTr+2puy2Jp0Xh6y5nuWLjQ5YfE9td21wjqMLJAQc7fWtHUbeUwhTGIvfPWuOdVTlF26 HdCk4Qkm+uhwk2hvcXLCebe6udoB/hqHVI1sraO3SYiDcCPm6HvXtQrKpKMUtDxJ0PZRlNu7Zrae Jda1aOG6lSeHy8bNxycDj/Gv04/4JzSW1l4s+KejQOWfyrKZgTnkGYH+Yrow8pKq6a2t+oVIxdB1 H8TZ+q3UHnmsm+HX1rsPKeiKMZzWhFk4pjNOPoDV+POfU0mNFxB+NWVBIpBsWF5966rw5A0uvW4C b2LYAxnNVFe8KW2p6Z4u0qe28IRXDLgMMMAMAZ5/CvC7hcbu+O9aVbcxENEcNrq5tX+hr8kv21bK T/hKvDt1EwR8SqWK5/un+Wa4MRb2Lud2Fu8Qkt/+AfDj2UzaBHNtKtcEOcEdOw/n+dYl74ilguvK SyDyDjO4bSemfavAoU1iG4p7M92vW+rtSa3RV8MfZ7nxhcX99OlquDh5ED5Zj05z9K0vEw0mxvYf 7Lge21WM5MqfKpHXO3p+NerJTWIUVtax5N4fV3KXxX0MLVPE2sy6PsvPLulYAxTOnzxkcZBHfHFc KARcmUybmXkoG5YeldlGlCmnynHWrTqtOW6NWNwDuWd7eQqGAZSARzWpZXOoXMrvZSs/QSHOO3QV jUjCzlNHRTnU5lGD1ZqXWk679pglZTeEoH2lgSM9QeawNW027t76U/ZzEjHnJ4PsPzrOhXouSUSs RQrxi5SRqaFoTXipPPG0cCNhXJwp9fqea9Ol16yheHTLEK0yhQ6k9RnB9s45xXFi/wB7Vt0idWEf sabl1Y7XHmuNDSGwMki7grMMAhSQMn3qstpfya7AltPLHG4CvtiCkYXrkjk/SvNUoRpXeu56bVR1 dNL2MXWr5LbxBYaaXe8aIGOSR33NITk8n/OKzvD1tc2Km5lT7MiyZhQHLKD3PqD6e1dUpKFCz+1s vVs5qdKU6/Mtot3foXJNRhVruG1dMnLTIBj8/Q96w0hmMH2++upA2W2xwvtyvQE4qqcVDWS95lTl KUbRdoq+xdggkGowTO0c020DztgDEcnB/AiuX8X2kg1WG5E6yIw2r8x4xz+db4eaeJWnSxliabWD dn1TKWlwXer2sdsspQQfKu/pnOcj3rodYjSW0ltQBcyW8Y+994Eiuyc0qnKun6nBCDdPmfXT7jE0 6wgt7KcX0e1o5cgbfvgDPP511qT2MgULGscboCi9CPXPpXDifaVG2tkeng1RoxXNuxkttCFkaN97 gY27uvFcDfQxQwyjfvm3899oxV4KpOTcScwpQjFTb7kGk3EsGoLMwLwblE23rtzn+lezaX4gspJ2 TT2M8iwhmhZufce5A/OtcZS9pr0Rw4Gs6Ta7j9Tt01HTysUjW9yUyso4bJ61zs+k215d2xu5HBjJ w8bY5968+nUdOPmj1KlP2jfZ/nc6aK3iNqCFMkakrjoRxXE3OiRWd+6GYxrKdyZBOPY9qVKo05Lv +hdaknyy7GfPBKC0T4dcdcDkVPp9la2qyO0QETDJLEnHauj2j5HFdTFUk6ilLoLcaTp89vJNbLGJ Mc7lyea5aSEaLqUbt5s4IO4Y2iu2hUlNOEtzzsTShTaqx2Opsr2xubZFDIzFcKGOCD71X1VpLTTp kHDOMKc9Pr+Fc8ISVVKXc6ZVIyo8y7HJS6be2F+s6Dz41G8SY4NXtQuohotvLbSqk5YeaoH3eM4r 1bqbUkeJyumnGXyOaVscnmgsSea2MRc560/kLmkPqFSqcjHWkxpIjlJ3cVXkORzVIzdzpPDF6Le7 YFfMG4HbW7eM8GrziKY/6sMUVido71wyivbu/VHowk/q6d9ipaXOoanq7W6uPJIxvZO1dRZxWn2U xRH7W0DEMzDG1v8AJrlr2g7R+Z24ZyqLmn8iDWrqS00WUw5EkuIwHPI9xXn86XAtn82NTtOS1bYV KMLvdnPjHKVR21silDPNbXkc8TbZUYFeOM16xF42kTwzbzurXLqv7xDhQT7YrbE0fapHPhK3sua5 zX/CVXMlhPhBZxsx2LEMM5OerdehrQ8P6zYrAsN9L5JDfuyQTj8fSuephf3UlHc7KOLXtYymzuZN W0+201xNLGyYy3ByAfc/Wua0pEv9bvrdLhJYAMrOH5YdQPpXBRozpxlKWx6GIq06k4xW/wDmV3tb iH4jx3hvpBExbYzZIbA+79K6ecajeXNqgnQRknzN3Ydcjt1pVnBzi7bL/MeH5/ZyTetzE1FbWzug EkWa5+vQ+5rjNSljuruTzpi02Rls5AH+NdmHUm1Jo4cS42aTLtin2a8imtnKyqnyFccj1r9DP+Cc +qSj9rXxzYzSs/2rw95nzDBJjnQf+zmvWoJOo297M4bvk5b6H7N9uaytQyIS1aHJbqZcRJJrUi7U w23NOPkc1oR9OvNSNFxO9Wl/M0hssoM16Z4At45vE9uZACol5yeDkHj9K1hfmJlses+PXVfh1cqS AWZQAR1r5eufvNSn0FE4rW0Jt3PtX5Uftwx/Z/D2gXu1mK3rJlWwcMhz/KuepHng0dFKXJVUj4Lv Z/segCVA5heMeWmchQBx9K8lvrqOW7DCRy653hmyCxPUYHpjjnvXi5dF+9N9z2sznHmjBdENMbfY RcwLJF5hbc6n5SAOT7elRW9+kkCxzym4MSnylbtzn/GvZa5nc8TVFkRS31hNHaRNIoOQ+Mc9WA/w rIvLeW3nRV3IQuXDLyD7/h2ohJc3LfVGc4PlUie0tDfXUSTTquYyEaVsAe1dZ4alsdOuWgvEaRpC NjJnb9ea566lKm4xR10JKNVTkz0v/Qn02RlZJbyNQ5XeOnY15Pq80ty9wb5mAVsQjhSv1HfvXjYK DVZt7o9vH1L0Ulsy6ji88Irp8FyICHym7kN7Z7c81PomiXdt4pt5W2zMPmJDc59eeTXoVakadOae 7ueXRpudWEuisejtDqEOqZ86IbyGWF8A8DBx3PY/jU17rN5p2j/6c0cnPyvEpHHUc5NfOqFOryxS 1PouecJTlN6K7/yPMrvTNQvJHvwm+NiX80Hbg1tWd8b21CRWzBYFUCYjIc4wf8+9erXjTnBNP4Tz cNUqUpOMvtmReXTR3UkqWg+xtEN0x4LHtXPvcXk2mMltC2JG5DDduJ/u81tRhHSUn2+8mtUd3FRs 9X8je+zvNBZvdy/ZZEZSu5sAt0C/zrN8VQJbaWUmjEkjygxFcnacc1NGa9rGK7irRk6Upy2t+hyN rqUscDxrKYFx/wAsxgk/4VZudembRYrOMGJh/rpl+85znr6V7MqMZST8zxI15Qg7drECXF9qVrN+ /OyGLLh2PzCoonkR2SWWUKF3BN3frTUYpOKRDnOTu2Wb2/vCY8N5YKqCiDnH1qsQ1xARJnYx+/0J NTCMYK6NJznUdmZpaSBmQOdwPJB610Fs0qIjWzsJFBYyrwfU5NaTStqYwcr2Op0rxAFtZZbgSyyf wMx/i9Kt2+uvc2VxJPaCHy5Dlc5evHnhtW38j26WJbiu5q/2kx01ZVWSKORR5hOMgds+nFZhnMsg a2DTBBlm5wRXHGluz0XXVkUr0RmFbmOJi6KTIiN171BFBqFxYOwOI3w0avHjZ6jPetlyqC5jJyk5 +6ZkdpqcOuLKshdHGJEd+CKt3MlwkFwNQtwbQDAbk5Hp7V1NwlNOO9jhUakYvm1V/wADjr64t0uB 9gwkIHUZyT+P40iyz3DRfbZWWA4O9wSOOleny2jd7njyl71o7G9NqEE7paxSqbbYQxxgZxXMtD5a zK0qkqeFJ+9UUouKszSvJTd1sVMEMT1FIeT1rY5iXkjNBbK0FXsPTB6805u/pU3KIzyD3NV3HXPW rW5DRZ0vB1dFLlM55rsItNnkvnDTtIZhkAjB21zVJKM7vsdVKLnDfqbOlWltDeTRROrMmSyO3Oar 3PiRrfULiztrCOVT/Gr8k468V5/s5Vqj5nY9R1I0Ka5Vcy/Pu52Q3rNMyncoc9KwtUW4bVyqsTG2 Nqjp05r0oRjF27HjzlUau3qxW09ktIptysHGSAehp0MMoYL5p2Z+5nitOZSRm4uD1IblJmiy0RVF Py4HFbGj6PcXuJ5HW3jAzGZBwxx29aJzUKdx04OpVsams39zbaJDDPGjSS8swjAGAMDHHpWZZXKW UQltZPLuGGd5fBHqKwhFOlpszepNqtro0Xp/El3LbGAPuIIIYdBVe08QNDq5lvN15FsIGCchv0pR w8UtNy3iZSeuxHqMk13CLtVdoZchGIwDjGR9ef1rI2yRylh94Llg5reKSVmYSbcrmrb3p+zKiEec xwFK5GO/Nfc3/BP2/EH/AAUKkt2n8w3nh66jGT94gxvj8lNbUY2m/R/kUpNr+ux+6RBx61lah/yD mPoaDExoDmteE8c03YlGpH0BJrRj6Z60i1qi4lWl+vNAepaT616r8N9p8RyluQkfmZ9Mc1pTvzEy 2Oq+KeoQQ+H7aDzz5+7eYgf4f73v0xXzPdaokWqwwzXMSy3Egjhhxzu9Cw4FTPdCV7Gdqw8yxLcj Ocg9jX5q/toR28Hwysry5QPFFqC5JGcZVv61y1ouVGSW9jooyUK0ZPo0flbrviBzYJbW235m+Tpk DGAK4JrZridJvLOXOJWXse5rKhSVGmjWvUdaq2/kW7j7S1mY3Vp1UYjO4nCjtVa2sTLqkEYLQh+H XOMjvXRzwjF2OdxlKSuda6DRESOAl4pWPLv+H4VizW0Goa+5ilMcbgEru5LfU1wUnLklWtq/0O+s k6kaF9FZfeSSaU0etR5AdAMujcEqRg8iuy0mwzZbLi3jmtZBiHyjyOeRk8+n5Vz1cQvZp7HRTwrd Vx33+4fZRx6Z4iu58skm0k72wpXHfPpUdxp9trmqSNEFimlA81sZ3Y9PfHeuJVZRrur0seh7CNTD ez63Oc1jw22k6UJYJ1nux8zRAHKgnoP89qrab4vurO1BlVfPB+Q7ckY/z+leryxxdK7PG5pYSpZH UReJ5ta1W1c2sc18rFrclMKm0dc1iaxqOpS+MbS3vbtZfMwx2DoT2I+veuenRjTnyvdLQ2qV5VIO XRtXPSHjtbWxjKZntUhCSI8Z4P1+tc3pvnXFzcIWa3VnynQA8dQK8ZS5qcpSPc5VGrBRRnagl019 dxXLQsDDvWEnmXHTA7D6Vxc+qyOEilhFm6OCxUZOPQAivWw1OM1p0/E8vF1Zwlr1Oijk+2SRXU0P mYYGN2HX3rM17VIbqWK3kiM8MZ3uEYKcj3qKFJusnf4TbE1YrDNW1kcgbdpCxihleNz8m4ZPtT5N MubeGGS7jaESE438fjXv88U7X1PmOSTjzLY67QtPSXw7NBdx43OCjxj5sZ7+opmpeHRhVst3mjgb zln4z68V5LxHJWtfS57UcLz0Lpa2Oe+w3lyS0wdSq7cucH8qaLa6uNtpCC0iEhQeMmvQcqf3HnKN SO/UF0e9uLwQ/ZmMwHI6ECt60sZ43jWEiNN+JpC+GUgccVhVqwcbXNqNGaqXa8iaFZytzaTmFpwu +PygAzYz85PepLfT5o1ku7uIx3BUZG44PPUHNYuaW3U6FBvfp+h0Qkhi0yNvmS3aMs+APw/CuXg1 G5WORbW7RvnJGV2o2egBqKaum2jacrWV7HQLBI5WWeJRKkWdhfK7scj9a59rzWYb2WQI6wRsTHGq /KVPWs4+znL3vkU1VhBOK9Sw+q2mpRRQ24a0uQQSxBHPcdMc10kiRSaIgnQHahYsB94nufX6VlOE oNR6mtOoqicuh47qYH9uXKLEFAkPCjgDNOLqbTyWXK445PFfQK9kfNzdpvsSW9s8cD3Gd8OPm44H 1pRFbXMgLybpCCFwpxnHSpu9x8qe5l5POaTGMGqBoXdluTS53HFIQ8qRx1zQdx60ihNhLdeTSzKF jweTT6kvbUqwkLeozEqM8kV6rpV6k+mRkAuUO0MRzXHik3FNHoYJxu0zk7+C8i8R3KRs26YncUHU HtzVjSdPlhu7mTIfZ8oOfvA8Hiqc4qn8jGMJyqP5kVxNNZzSxKUnmVgSM5K+1QETTQmWVRvPQVrF K3N3MpXvyvoaum2QeHzJzvUHlPauttrXRpI/s09oglfJiZM5P1NedXqVFJqHQ9PD0abivadTE1W0 WGHda5ktkyWU9s1RMxstHiuZozIrn9yndRnnHoP8a1jP2sF32MnFUaj7JGNrOoXNxIts7fu1IKpj 7nHTmobOwmuYSxDMecACu6FqdPQ4KrdSq2acXh64ZZyoZNgDMWyFY9eDVS40p4rvy5V+ztjhhyD7 1nGvGUrIqVCUI69RbydLLFjbyNPHGwfeWJDHAzgdv/rVWnufPnMhhWNMg7QOtaxg2lJkSmk3FEc2 +O3SRBhyM17p+y74/j+HH7bHgfxfqMnlaTBemDUJW6RwTIYnc+yh934V1U7Kav6feTB+8f0p29xB dWMNzbypPBKgeORGyrqRkEHuMVR1TP8AZMrE5brUMGjnbRyTmtyE55oZLfY1Yjx1rRj5FIsuITmr SmkMtIfm9a9a+GywjxJK0u1SI8IxfHJHT3yM1tT+Ih6mT4+u0l8ZOQsMoiwNiM2GIOcEnvXzBqHg 6zm+JVzq1s8dgZgkk00kreYJFZmG1QykNlgc5x8oGCOKym2pFXZ21+WOkfOSSeRnr0Az+OM/jX5y /tv2D3P7LmqypkPBdQSAjt+8UH9CaQnrqfkNZ+HbieazV7lI0YM7sVOUU8j8+1dFaWtgl8ls0O+M DAkAJJPOflH868qvWc1yx6Hq0KMYNTl1NBoLUX8sUaNsCAlQM8+9Z5gs7i9j37AUPUnBUkdK8X95 GfMe5+6nDlZzPiGG/XUT87vbKRtwOD24x71f8M6PJdeKJ11CIwiGHdudMgZxj+tey6sVhHy72PDj SlLGLm7/AIGV4iuH/tqVIFO2FtoYEYbHOf8A61d7p15cPoVrNFHFhk/e57EjqMD3Fc2IpwWHhzHX hqlWWKqOP9aiXdjA11bw3EoHn8AHJMg65PHvUt/aR+HXjuWuQik7Yjt7YzXkvmbjC1+bY9mDglKb 05bXIJ7jzrGO5a2a8RlA3I3Iz3/U1499kkuvEi24LeY8xXa55zmvawT5YSbe3Q8LMIqU46avr3ud xBLZ6aqW0km1gpVlD5Oe/Tt9at6DZwa7rsl3NsF5b4kj2PtLIDz17VnU9pCMq3l+HUun7OpyUOt/ +GOs1K9WPTnXD+QgJx3buM+4riDrGJwzFVuCm9VfIB+p7H2ryaNJVVoexOp9X+Ld/wBItJq0Goxj zGRbtRhsHOPoe4qK40Ozlge9uIuWPOCcE/TvXbGVTCyt3OOcaeKhftqchLrU8MT20CqFDFVA6YHt 9KyYFeS/VycE84I+Wvdp0o0otrW589VrSrTUXpbRHpulWRj0uEApNcS42jduAGOlUdags7qX7DcS IZ1XerpzsPHBHpivIhKUsRzLoexNRhheR9R2mMy2RgtxFLPEh+ZQR/njFaXmyrqUiANvGNwP8OR1 rnrRSnLuddCb5Ivojm9duEspN6sGmYgFc5yKo6PY3V5JJd+cUKkEJj7wPuK7oWjh+d7s8+q+fEqE emp06WEh1KJXbbn5i55wO5plpc6fM2oWqXG2ZZcK7DC7vSsaac4bbHTVlGFTtcy7y2hWZ7ydkWeJ CuEJXJ9cZq5/aNxNpEJKrMdgMrDsO1byjzqLZxRk6cpdbgt3BJc5DFpVUAEKQhB9ulTzWlvd2Ko8 Me0Hd8vABz1GKxk6kJJnalSqQZnyautra+Z5bzR+btXr2ODnNddbTW11p9vOrCWycHcExlc/4Vji KTilL5GmFrJtxe5kXsdgiCRJkSbd0bv+NN+0iWERQBZwx5x0qEpNKcuhs3BNwXUzpfCcN5cPdvO6 FV3MEHDe3NYlzp2k2lsZJg8ePvANk1208VUm0onnVMFTheUyq8MASNrSQKjJgo67gwrElW6s2Z4Q EUqckdq76U+bSW551ekormhsYoLYJxTmJNdhwCN1z1NAyGz70g6lkkn5qTczN15pFE8YzNk9B1qG 4w0hweKS3DS1yi3D5PPNej6F9muNHeGRPm4cMDgmsa9+S5vh7c7uSmSCQSzo4SWJsNg5yB61nSXs SQTI0cqGQkpKhyM9lPFYqDe5u5qD06mBBt5mcNuB+b1Nblratcos8nyWobBk7Zrqm7K5xQXNKxqq sUZVomIjPqetaduZPLLbsA4zkdK8mo+57dNaXidBZ28FxL5LAqkoPO35T9TXn+pyLZ6q63Kefb7S hjJ6YPBFLDc3O4hi+TljK3kzHEElzCLxznaxwo+v8q6vR7SOWCKaeUQguREMYOe9d1ebhT09DzsP T9pV1OlvFmhWJJXWRJDtzyCQR29K4/WZvLsY7eF2Z449ql+T3zXBhbOa0PUxvuw1ZycOx5FWY7Mn ljzxVhreTzWMaeZED8rg+/pXvcyT1PneW+vUYj+U0hmXfIOEVhwau2Ile2uEBBkcBec4A7/jUO7T NItJo/Vb9iX9qeeyn0/4LfEnUf3QUR+GdWuGwAB/y7SMf/HCf930r9UtRbfpMvOciumT50prr+fU qorPmfU5q261tQtx1zSsZPQ1omyBWlG3qamxSLiMByWqX7XbR/6y4jT/AHnApBuWoL+yeQbbqJzn osgJrutD8RxaXPL5dtcXZfG0RLkEAYBI2kE8+nrVxlGLuwS1MXU7i7uvt2oz2lxFBChmnka2ZVjX uTwBXkGrfFr4eaTA0l/4kt4to/55Ox/RTUX5ncrkfU8q1n9pn4Mw74pPF6FuckWkuP8A0GviT9pb 48fCzxn8FNc8OaTrUmoXl3GqxiKAgA7gcknGOlEk1Bs0VPVXPz7sEWKwSC1hWaQDB3vt3Y6AntxV S6urq0dLya2t4xGM7R8xwRhhu9a+Pi1OfvPV/qfUzj7OGi+G2voNGu28ssQWNQZWCLJG446ZB7mq 2oadbpYTz28MouzINrgnJz3Yf1rohB4eSu9+5zylGvFtbpdCG8g1CHSRcsGYxbSr4OD6574rlrrx JrDyNFIYgsbZAVdpycHr1Ir0MPCnVjc82vUqUp26mJe6g13fGWaMrv8AvbOgPf0/KvSvCUwbTVDS rOi/IgJyUz1yPwox0eXDadCsvlzYvXqdJF5cWolWEe1TtXvtX0HpW/Nolhr0VqL2WTyo9wIHHbg1 8r7adKSqrdH18qEKkHSeiZhavdRab4flt7O0jN2oCwx7RtY55BJxjivFrkTy6ubtiLWXzCeOvqOn 496+iy6CVJybu2z5TNajlWjG1kkNtbKVruaZ91wjEk54LH1zmoof7R0y9knQSwcFWxggqewr2W4S XKzx486lzLodjpkd9faJHPeTlYMYhi2feHYsT3rG1LT4Io1ku5VjuWx8ysSB7V4kJKNdxgv66n0F SMp4ZSqPdX/yOfkvEtIA9s5kDZAVhyPp6Cu3sL6S48PRfa33BUJwF5x7AV2YmnzQTa1uedhavJVa Wxx2oNYR+JnadmTDDenlnoetZ13JEJ2Wz3JbucK/qO2feu6mpcqUuxw1OXnlbuVfPuIHX9+8boTs KnkZ61qW3lvKb3z2EuCWOQMsfb0pzVloiYNt6sutq3l3G6GLylXAfnDtx1/Wta6u5HeK3E0kcrxF mmx97PTmvPq0kpKT1PTo1XyuKZhXSwnTxcy3Ltdlio4xnsaqaXfTWEoRQxWXABzk/hXSo+0ptSX9 I5G/Z1U09evzO4hOoHUopJWD2bJjH8RNcVrd28uqS20KeX5bZ44Ykdz61lhnGUtOh04lSjC8t29D AnuJ3Ub5Gcjjlq6fRpPNsGtLiUxRuCBIByua66qSjoefScnO7Og225tpYJJTOgX5Qq4OOnUVqafZ SalZpZWTm2aPA3ls7/bHrXl1JqnBzlstT16cXUqKCer0Oc1tLyxhkF1Z/Z0WciMK4Ik47/WuOTUb lS22R4l37gqMQAfpXoUVCdO+6PPrynCdtmi09xfXiGV7jzBEBw7DJz3x3rrtLM1pYvJKygEAhwev 1FYYhRVNQR0YWUpVfaSNK51lYrJYoZtzSN8208Z96569khntHS4kUO33yvrXHSpODTW56NavzxcW Ja6cv2gvBMTHtGIwcgn+lac1tB9njjYFyQTJnjinOb501uRRpx9m4vY8zGQ5A5oJ969s+e6DD15O aeB6mkJKzJFdunWnAYG8n8qBkiyAo3FQMcnJpLcfQrycgmuh0i5aGONy4AztIY8YqaivEqlpI7K+ t4JNPDhfL2KMCMcE+prMs7qWBTAXDBjvCY5Ix2rhWsLM71eNS/kYVxCyahMVbakkmQucnHvXrlpp 8B8OBOkSRKUULnJ6n+dPEy5aSZOGgnVZzFyghuPLdFIVsZ6Vu2VtNIqK0WYw3znsBXmTd4qR7MPd vGxJeamNN154Yp0SIIpKsuMen4V5vqcc1950yZnYSkk5HINd2Fjb331R5eKlzLkXRsZaBftYtd3U bQScDPpXY6Vp0P8AaDW8rtKbZgACDkZ5JzWuJm4QJwcFOr5Gn4lWCXThEmRJFGTAS20gjvXl15I/ V5Hllx8vfPrmssC3KndmuYRUKmjK1l5Ut+qTyFFb+IDoTWzFbuNRzYh1kjcEOzgKAO5/HNelOXLe +1jzIR5rcu9zYvEttRdZpZk+1RLt2I33uaz4ykCt5S4APIJ71z0uZws+hrWUVUvF3ua9lqEH2eaC 7G1mw0cyn50Ycg5r7S8Eft2fGLwj8L7XQtX0jS/GtpabYYdVv3kS58voA5Q/OR/ePPrnrXVCfJJq Wzt8mXpOFrbH2/4S+OGr+KdGGoRarpyWbJG6yWemMxVXyASry7sbuM4x1zjFdHL8S9ZNtqN1F4rn NrYShZ2gt7RA/qF3qx+voOfWu7lbv5HPy66nKWPxlu9V1qLz9d8RRWCKHm+z3FsJWXbuOFWFcdcD r0/PMXx74u1nxFJBpOq6ndWBdlWS41c+YuUVk3gbVHLYOM9D04oUPMv3brzOx0TSfG+p3W+41J9/ mMXSWRmjVQUPLEls/PtHv3J6/SPgnwRrc9tLbm4iacW376dX5EmM7VIGMgcEdcruzggGWopaoaTZ 7lpuh6taWFjC2pgS7WO4FtuFXDcfKXIcjPfk9MVvjTtUUmaS/wDMjiYFCIgxkHGMgcMOAex9+lY2 Tu7Gk4yjsej6l9huPhw9qbaMXBQjzIoVV2HQZ7g9s+pFfnN8a/hwt1bXtzqOoz2sqysGjaLAIxkE HJBGORjJweccCtKcH0RlJc3vSe3c/Nz4l+BLXRr1xGsktoIyVdI9u9SFYOM8jKt3Ofl7Zr5F16zg W+lLBoiGKhS2enSqqWdNvyM2mpo0ocmzkTko6gB1GCMjkVhavbw3gj8mRoZlTDiR8k4/z+lfFUZu nWTtsfX4imqtFxvqaFpZ2lnptkz28AKOMvgK+T9a2PNtp9yQqonVS+SDn86ir7SreV31HR5KNk0l sR6g2NBuXmkyjx5UL0U5rxa/RzqdwzQtHHk7OOvoSa9XLk1TZ4mY2lVRnhP9EUmRS2cMM810/hW8 vP8AhJJI7G3V2lHzwmTaGwR0JOc5PSvUrwUqLUtjzsPOVOtGS3udtfXcFtfky3iJLHId6xuSTjHB H4+vasnWPFNxc2dvaWW+3Lud7rMBkDp9O/1rx6WC5mnJaL8T262PfLJLd/gPutYmPh+3t4meaFlW O5XHLEEDIJrUvLW2j0lY4oHYQgs6bRlm+vf0rOcXRilHq3cKdq825bpKxlWc0E86xTEwKFBeIgZU nt7UyfT4J7cRSOrxrPkLkklQOMkHNEJTpVLP1KqQp1qPMiuk/wDZPmFZje20bDZDt3hfUg+lc5r2 qLqF3mDBQlTt2Y2n6/WvQhSvVVU8uVZ+xdO5iJaSzXALR+VtY4AGSQe1d1oUFhayK9wTNMV8vbIN qL9Pet8RJuNomGHUVPmkcV4iKyeKbtfNMm08EY6cZrHtRNlgqB9o3DP8/euiGkFfsctTWo/U6Y22 nSeFZiWWS8CbmYE5U/jXM7eCjsdy9QPSs6Tk2+bub11FKPL1RHK2632RpjDZD/xV0tvfRS+HPssz Si9ALLIDkMBzj2p1otpW7kUZJS17FbT1t5NVieV2xkeYGORg9we3OK7a80/T7x90IW3mj/1bRkjn PXHQ152JnUp1E1sethKVKrTlGXxHQWdrCHgW5kByOXU/Ka5W+0XT9U1MRWxcXaOTNKowoJ6c968+ jWlCTmtj0cRRjVpqD3LN74LtbfUYFunMsjxhyIwFX3yag1XQohaxx2FuUnT5pGd8hwR2x0rtWJcp rm2PP+qRjF23OO1GDVdEnhjN/vcrlQq9AexyKdp1/remq13bzMjM+7cyhjnpznkda9BqlVp6rc81 OrSqaPYmvtZ1LWAX1BwAGwuxABu+lYE0e6dtqYOeAP4qunGNNcsdjOrUlVbnLdm7p2lBgl1cIWjI +VSOh9Sa0L25bYtpE2IurDPJNcLl7Wv5I9FU1Rw1+siT7N9m0lpHi8wgbinc/Q1Ba2kMuZo90Qcb mWQd6bnaDYRp3kkzoNK0lFmec7lQNyVPIzmtKSyaOF41tzeW0uRNL3QHp/kVz8ynK7OuzpqyPES3 50YJ969ux862Lgk0pA+8TSDzFVhk5z7U5shOvHpTDUmVgIwe1QSEMxxSGyuwODk1e06cRSDevmJu +YYzRLWIoNKWp0jXskltLtm25x8p7Cn6ba31/OxVt3y8MWAUAe9cz5YQbaOuMpTqaMbdQSWxdWjZ mY8yqPlDfX1rqdG8XfYIfIvR9oZVAV+v51FWn7alZFUqjo1PeIb7WbW7kPlp8zHcGIxzV6LxTHah ZXxKEGNuep9a4vq0uVRZ6DxcVJyOY1fXZdS81kRY4z947cnH1rAkuz5cUcBYEENu969OlSVOHKeR Vq883I39Ht7e6v0a6Vkl++sh+5n0Poa6WbVhZzRLFGY5zIEfn5D7Z+lcGIi6k+V7Hq4WSpU+db3J NenFxoPmiTy5AuMbveuEjhuJLiK4aN5AvCsq8fj+dPC2p0Pe0M8VetiXy6mrD4ekn1uFCEWHbllH BOOcfWtD7HBp/iNt0QhV4yNjDK4PrnpTdf2nuw7MpYb2KUqncxNQIg1NJrOIsikbnCnbn0qSWGVt OjupE2CX5uh9cV1wbUVzPU4KiTnLkWgsUJXUYI2t3nkYhgij7wror5dUtvCx/wBAZILg5LscfKMH genNTKUHJJscFOMW0j6Y+FOo3cvga9W3kfzYI0CIZSFG3dzjIHU56HoTX0Hot9ILnW4Wl/d3b5Rn GVDvkgsWOQxKHK4AIbjqM+ytYmL11bMfQ1u5vFVnahpJANitEFCksqAKzEnAbHfJBx6k19F6H9hh 02yW2tVcyGRZHafBAOMnCEZwSPvfgOard6EPWzsfTfhbTxd6bbbg8shIM5MeXjwzDcD/AA5LnHPB xn29x8PS22m2otklYXrnCwO5kkkIAQgnG0LhnG0sfuj6iJcrjbqd0LtpnoD6hFHok/nI17dqrIsi RGVS2APvrknHOMHJwfUg3F161hkjW5vbawuY41a3jXnaehyCc5wVGcEEd+DnB6rU2vFq1tTuZNSh ufC48y6kE5Tem1fkfPIGe+CO2M89DzXzL8Rbd5LS5e7VLx0TzSNwCoNhXeeoDKHHQgkqAe1OMnBW ITTjZn5YfFh7+30id2RE8sN/pDuRIwOBjr2VRjjI/WvgTxRNE900gbfIzEkZPB9/etp/w2tzilum c5Ct2t+HeXNuQDGqcNk8kH8quXtzstme1tt00QyGcFs5PIz7Zr5KUYymui/q59FFyVN31fT9Cpcy XFxaCbYZHVssjjH44rQs/tiaNHci2mGV2syHOAWwQT6VFoxilfqVzSlNu3QuazcC10hrXLMZRjgd B1Occ4FebS211dsLW3Bm48wnqT7EnpjpivVwS5aDkzxsa+bEJIZFpzR2U6X0JjI4BTnA/Aev411n gGHSbW8n1i+vEjMSARo7ZZMnaWI/zwa1rucqLUdb/qZUFBVU57L9D1+60vw5q4Cz6bHcE7niuozs 38DByPXB4rxXxdoH9i+KLaKyWaRJYS0bSAEHB5AOOuBXmYOvU9rySZ6eMoUlR9pHcqwpL/wiLXsk +JFnBaNiCBnvj1rqLK5lu7XYBsjCKxfBG71x6mtsTZwcmtmY4bm9rGN90U3toft7mRl+05CjjJwf etG308rp87o6rkhpAzAMTn9a8iUppK/l9x7sIwlt5/ecpd6lFZam0fkIVQ/u9g28dcH8aylaDWdT e5aIQP5geSNVwoHcjP419HThamp+R8tVadRx8z0ez0y2tLeG5mRJpOHcbRjn0q/qM+iahJC89oI5 ZAVZFXBBxwcj8PwrwHOrUqucXtc9x0qNOkoSWrseY69oTQ37Pt/0OQkwTHBIOOVJHf2rk5rOWEx3 CTBwTjkcqR619BRq+0gmfP1qLpzlHsTJHdyyyS2sLnbjcRyPXmr2mRvbzS3V5lph8oQgcjpV1XFp pbkU+ZNN7Fqe3Fxeys8PzMPlCAAgU2RZrfUre60+EpIsW194yG7HGfas1OMtGzSVOUNbGGZZvtrm UopkbJAAXbXd6AinWrm2ubmKSSGPfFIrgrjGSc9DWOLV6LtudOElasvUsX/iaziHk2zNOpk3FwoC 9emPpmujaew1C2F5px2DcoHGDxwQffNeJVw86cVM9+liYVako9tifWN1zfW8Ek3lJDEGZgOdp6g/ 59KggeaTTLlwynAwjNHyQB/KtHZ018jKDaqt9DifHcW6KDUDcOtxsUNFu4+oHauC/tK5e2VJJty4 xyMnNe3hUp0It9DwMXJ08Q7dTWNx9p0iIbQChIJXvVcQNtO/A6YJ610LQ4/iOns79ZNOFtIxdwoI QLjPvVK8SL7Qkygqd3zYBJPvXmxi6dVo9mUo1cMm90aTM8cW4DzCCPvHIOa19HsL/Ubx5ZbBDYMp BORUaRXNJ6luUpWjFG20nk6oltZ+XBbRkCWOZSA+e6nr7UzVnEOnzyWUXl3QUAAggfU+vFCiuZBz Ozv0PAc96cCT1NeyeA0OOSKaAS2OtIew/wAl+oOaRuVx/FQFu4u5imOuKQnA96BkLHOalsiPtyhj 8pPPNV0IVnI7u9jgTSVeGFXZ8FM9j3z3rqtE0q1j8ORiSQCadSZQpP7v+leROpJUvNv8j2404Oq3 0S/Mx7y4ttKhtdIW5xG0hkaRycEZ6HtisPVbrTTJM0cSRysd0flNnB7+2K6YKbakupyz5FFp9DIg k82/RHZYF/iZzxiusg0vTHTe07yW7DKkDqadacobGeHpQqL3mZ/iDR2s9Dt5rfc8ByzMP4eejVyV sGa4DZJB/Kt6M+eFzCtBwqWO30XUktrdrO4RDFI3MmQcHsKXVZ1jeQr8wDcDHauCVOX1jyZ6kKsf qnmjG3GbWYImlISRgQT2HWuwk+1LIqoqmJBgBQM5qcSleMWaYRuKlNbhDeSRXBuG3CVOh9DjvSap u1eZtYvp4d5RNsEY2gjHt2/WuWlalPnS12+87MRetS5W9N/uK+hPcvqlxHFIggjBJ5B3Z7AHnHvX W22rRJDt8ppZWTawkX5VGOOlZYuLnVduljXBuMaN5Le6L+n6slxbxlbZBcMeGKYYL7+nSqmvS2t/ qKrdXZa9t7VvKhMuF24OSR3+lctONSnWdtTprOlVox6anf8Awsu7j+xdRBRptPiVvPjDY3ZAbPpk bK+htF1CKbW5bKFMAWu6KO3UbZNkmQxOc5Ko3qcj0OK+9pq8Nex8c37/AN50ekSxWvie3jimF15k c8dxcAbiQI1IJBAJ2kIeAMDcecV6L4fv501G2MEpjk2KcMcHAG7AJ75XOeM8+tOV76bCk+XXqfW/ gO42wW9vI217xVLAuV34+YnPHJQg89OTkcV9A6Fq1sutbJfOnjtRlAGIMoAwSQSQO4GepPPXImdk 9djWDvTTv/Wp3MOqTwWEdutz9piRBKkUSAlkALE4POeTgkZ46jdgYthpEBtJta1O3j1AXbMPPLby 2GJxxnAOVXqTx1rC6Wpo05a9jq4oY7bWlRHlilPIjdVUpuXG0ZboCeuSc814p8VpzbLLBGBLO8zl wIsSRFVPAB6KcKMj+mKI6Dd0tfkfnn8VI4b2O9ga1klllHztIvUFCwZc45ztOe46Z5z+cniy2mt7 +48yIo7ctx68/h1/KtZWdM5J257j7Lwdc6z4Lt9UgISJFJY7sZI4INYg0u9Ftd/ZYmcW67peQQM4 4ya+Uu5TcZbJn0aSjFTju0amk2Mt1N5yqUuFQDYOmD1P1rpdOjs7DRdSiv5HEW1pP3jbcADkLj+t edNuU/ZryO+nFQp+0b11PIZtYe88VR3VuhiEQIiQjIwBjJ7mnJYR2E6zWd6bi2mQtOIyFYjPzAgN 8vPv059q+x5I0qSTPkLupVcjKkiW48yUNKY+VMckh+cj3+oqs+kyW9lDfFvtSNGxmjQN+6PYZ79j TclFpLr+BHK5Ju//AATpPBU/iSDUUlihefThnzBKP3e3B+7+ZrX8U+KVmuYIZFM/lKVaEnBU45b0 56DHavMVOnPF3juj0nOawdp7M5XTruO4s5EiiWORW80OWydpGD7Z/Cp9N1gweMlOpzMbfeUAbIyS Mj2NdM6XNTlHrY5IVLVoz80d5qMtvBPatEVdpQCDjAA/l6Vm3D7YiERt2GO485/+tzXy8IuLTlsf ZTlB3tuec34MmouJEAff8p5z6/lVrw9ZQS6uHnZVAO0LgHB/H/PNfUN8tDTsfHcvNX17npDXK3a2 ZZvtcEVz5c5zggqMZ4HPr0xS3kWl6fDNqPlkSIN25gSR2K/XFeC4yg1GPXT8T6C8J+9Lpr9yMXV3 e68M3ErSBYUKmPHCkn29etcK8djHKhuWluQ0fmuqfLs5/UHvXpYdcsLR7nl4m86ilLsTQarFa2Wo RWMbESqDlx0/+vVzTgUs7a98tLmN2xOGGSo7ECqqRsm3u/8AIVKXPNJbRX6mhCmnz6hMkspj2Kdj Lhif/rVQvmkivhZSFFOR5Z3H5s+v4Vy0eZVPeR1Ylx9l7pzGsafFZXy7XwjDGC2Tnvn061XinMMs n2OXywY2DAnqMdM45r1/jhdnjJcktClE3z5bgGul0HWE07UZJGBkjcEOnTJ6gj8aitT9pScTShUc Kqkd9Yata6pq88kcMlzmEkoUIKjpz61qGWKK1MflAScYxJ9wZ7jB7e9fN1ISg+Rn1VOSqrmiea+I dP1a+iurq4LHDl40H8Q6fyriWsrqK3aSaJlAIByvr0r6ShUpuCUeh8piaVZVOaXUsQQSzPhHEJUb mJOAav8AnszmMnzHcgcd/pW7aba7HM01HmXU2raW606V/tlv5cbIQGKDcR9a6GRftWl7YlVwy/ej 5bHrXm1kuZVEevh37rpy3MuytLpNTFg1tLK7g+XMR8mewzXoGnTXlraRrEYknRR5ke09e4NY1bSd +5rS0Vn00H3s9pcxvbXqrHdxYZGC475GPasu4uoYjbq1wsoZR5iuwBC47ev0ppSZV43bZ4Dz3pw4 PNe0fPj9/J+lHOfWpGmSbzv6/hTWOWJNAyYBPLJU/MaZJGRb72GDSAqP9aW3Oy/iJ/vVfQi/vHaX lz5WkKixAyq3mF+uBjpUVl4k1OPTJ7VZlQy8GRh0H9BXJCnGcNTtqVZQlZdjQuPC9zfWDX8V6L24 YD93GCQfoTWNF4a1UiV5LZ40j+9uHPTsO9V7enG6eljH2FSTvYzWikWOJ8HvuyuMYNdzo0EjaXb3 s8rm3LlY4hyuff2qa0o8mptQi/aEOt3pOj3KzITGcxxsmcMOuCaw7Pw9e3OmfaEHlFuVUjGR161n CpGhTvLqzSdOWJq2itUhs1tc2rmOaILkDinXE8rWG13yc/KuOTXXZStJHH70LxegQ3AjXM+DJkMr Z5GO1XrvW1uYytuhjUDrxkVhKhz1E30OyGIjSpuNtWSXeswJpkPkxJL5qEOpPzqe5Jos9aVdGaH7 IJG2lVO78jXOsM3DV63N3io87VuhH4YvIV8TsksLPJINsTKedxI6+2M16dG0JUkQssgfAbGN1edj 4yVW9+h62XTh7C1tmWbuW1ttLlmMHlzdwpwWPTFeVSyahrmty3Qt3KomAq8bccck1eXxsnVqPQyz Oac40qa16nqvgPUHtIboIC7vAoOSNoJZck59ATj3r6f8MTSkRahPC0rOTBasoRVbOxNjDknAbjjq R2NfW037qPnH8enQ73VYBZR/a5pwolukZYcAugePchCL1HJ/Pv1rd0m9d5LOQws0BG4BQzLvGCQu T2BBPXk+vXWMbq7Iqt2sz618ESz3V7Y7M3MUO7IZVEaYVsZAOScrnaM8Dj2+p/A+oWmo6N508SQS xb40RI2BA5J2q33Qd2TgHOcDrmuapHc1hKWl3/Wp2fmC4uIiJpr17eBoztQBkTI+UsCGC9unAIrB huLibWbKysYLi8i3tMLfzfmbnJxkkqfbPI61nr1K5rbHo8dpHc6Hp+sW4lkuLU4fep3/ACk5UjAz hgDznGeK8I+ITyyNqEk0C+VIC/kvMqnJypUBmOACQCSBwcDOAC4/EX5PqfCvxUvo7q3vYo5FjEap G/krgRIAoOB0wOnXkk88V+cnjj9/4wuoSC6rt+YnJY4GSfT6V1NKxx1G7Nvc41NX1Pw5APIhEsUr 42lSTn0pE8e3ImZ54hGoxuiVdin68c/jXz9bC+0vbRs9bDY3kUb62Ldt4ka+1ErYw/ZpnbZuVOFz 06cdDWD4qt9TOqKgEtxDKCISV+8erEge9YUKEKFdRm7s1xFd1qTcFoc41nBb2vnLHK8rYDLuwu4j tx1zVmziaa+W0ETNvTDYH8WOAfpXuOUeRtvQ8VKXNbqdm+h6VDBZafcRS/bZNyM2WG1sZB4B4/Cs +00S2u/EMun6lezWUSAnouxgB8uCR+NeP7aVnJ/I9R4dOSUfR+pBa+IZbZbnTRdri2JR5SAMjoAO OnHX1NcnfpLfshCrK+Mr5Tr3PIOP8cV10qEKbc+rMKuInUgoPZGhpWhXZZ5FidV2jJxjI/xqxqug atNayyQwRuisZN2FB5I689cYrN4mlTq69dCVh6s46K9jNuZbi109UluxMQANrjGB1HXvVUX2qy3y zxPuRdq7Mjax7ce9N0qTVylWqLS+pVuJJZQt40e4Nn7pxtx1/WqtsssfmKikZILM742ke1bRilHy MJyb16ncaLa2F1G8lvdtbaq+VdZGIU56le2cVu3U1z581nsFyy2+5w3KsTwD07V5FZt1Gp9D2KCt S5ovR7nJ3d1aBbWwu45PO3q1wVcZCg847Z61wVzMH1SZk3CLLFV+9wM4r0KEWo+R59eSvfqiOw2p qbSXDP8AZwMuy8jn1rpNLnsINSlhm3G3f/VspNaVYOUXYwpTUKibLEcsFqklwuJNxb5jgsF9hjnr VUPb305N07ox5WYdVGeuO9c8Iyu5HTUmmlEqXHhS/WwnuxcC4JcGNQhbzMn0HINNsfC+pyapHBf2 72URILMxCkj2Bq3iYezcupCw1R1lDv8Aqd9F4M0KXRfKE88l4rkCUkANkjj0qpbeBYzq0izSopGC pcHaPXjPWvH+v1EnzI93+zqejTN/SdHTw+bizW7Ms05GZyBtKj+HGeM/jUfiC80+G/t9Otzm/Yfv AO3Geaw1r1ub5/cdcXHDUOVvy+bMmVMAy8yKV5Uc89xXN3CW88MztasitjfGSQcDp0rrot7pnLXj Fu0lfRnIXNnEkjypII1BGxE5JB9aa7Pa3ELg8kZQsOce9fQJ3jqfLSjyyb7F9dTur+5RLh1NuoJO B04yatJq9tpN7K2n7pUfAHmHoOvHFZulpydDWNZt88tz0XQb3+07Zrtg8UIX5UXHDnvUt3ptrPdp LHqE+lX+eGRcowJycj65rx03CbW9j15WqU01pclvWmluxKtxFcwRqAVK5JIrmNRs7QXsl7LdeQcZ EbHA/wAmtabaCUIy3djyMepPND9OuTXsHgaDQTnOacWOMd6A2HIcseeaezevX+dIpMAG3ZHIqxcO XgAPJFAPYrBcwA9TVd+GznmqRDOihVjodxI53lox15yO9M0SP7TqttatGjFn5JPOPrWKekn2Ohr3 op9T2GAgafKYlwEP+sVhn8hVq2CPuiubry1bLABtp+or598zmfRRUYx1Od8R3OjwWG0JFdTs+15/ LycAdDXP6vqhXwrax2EAhjYYds85PTHoMV2Uqc3yub0ucdWrCPPyLW25yc11PJpEMD3DyESFyh6A 9K2LDxBc2ca21x+9hAwpx932r0q1CNSnys8zD4mVGtzX33G6nqst6diRAxA4RyOTWdFM9vIVlHOe VPpWlKChTUTOtU9pVcxfKluZpp4yqDJYITjA9vephoOovZLfRoJVLEgKfm2/3qcqkae5Eac6mqRl yRlW+beo4yGTt61Yt5JftCxxtvfICBV6561bta5Ed0dFc2t3c60rLEx6NlBtwBwTxXp9gNOvY4mW cMUh+UNIQ0fsFHUe9fO4yTlCLjrbc+qwMUpyjLS+xQeOLS76W6vLxbi1uZR5cU7jaMfrVhmV5Nls 8fkyMSHgycHBz061yvmkvaNWj+Gh1pQj+73lf56jvB80dvqs0coOCdmQvNfVPh37TbR2t2jRG1nV lLxqM712bMj1yFbHr+n2tG7ppnyU9JteZ6RqUMN1pu47724IhaSZ5WAAX5CvAxg5P0znI5zt2D3F jrb/AGfZdQo20eeoyRt27sqAMArjGOcHkkHHVeyMp25bpH0v8OdWs9P8SQTTMs6qdzdACMc+5Oe4 5HNfXOgX9uvhu5urSN3lnm/eAZbJ3cthRw2ABwe468muaom9i6T0uzoIrlhFLGkb293IWkt0lzuW MHHzEkL0BGCffkder0q3uX8RNqSxrPJNGNlwqqgwp5bbk84yCT05xx1z0S7m6fSJ0Givay+D727S DzreW5mVZPK3RkBiNw52gZ9x1zjvXg3xUluDG40oPNK83RQSyEbsDHPI6Y45PTA4mDd210Lasrs+ AfiJb3F5pUsVzIUlcAKzrvLjaAM8HGcBfTOOfT5P8XeAL9dQfVLqJFMqhzJGgC/MAeMdTng9BnNd b0SRw1HKbbbvc88XSZokFzBtW9tpBLGHAPIOQcGvOvG09prnjT7RHbR6NLdRAXkUCkRzSqeX5+UZ GOABjH41x1pSpJySuRQipz5ZaMrWEJtLa2iCjz0YeU6qMuc9/X6nNen2dvJPpSZ1ELKy+Y7xgbhu OSDkY56cV8tXlVcVOS63PrKMabm4xetrHH6zpEUv2i5dP9FEYZnVsgMp6Z7HGeee1UtM0aLS9et7 9nee2iHySrh0kP48H6469K7IVV9VundvRo4p0ZLFWkrLdM6DWIpLvSrO9WIW9x5x8jKYyR16n2rk Yre1KXL3jvLfrIQzk428ZXvXPKdopRW3+Z0Rjebb/rQ8zvLQ/wBtXbRgvbl/mU9B/X1rqPC+j3Ny JhbwREJuMT84y3Yk9s17dSoo0XJ+R4cKbnU5Dp2tZY7u0stUuHSRIzvSNSEfJzkH/wCvW4Z7Y6eZ LMtNFgoFdD8xHB6jn618xXcqmq0S/U+ow6jS3erX5I5HxNYW7XMYmt/siOgDTFOCpA52/pxXlt9K o1RYrGRiIidjkbVbHQgdjXv4Rv2VmfOYpJVXJGzqFrrMdnaw3cccpa2MkYh+9zgkt6nmsrT71kgl jngMjEM29mJJrqg4ukuUwqN+098lSW4dZJUDIvVI9p5PTGcda1Ek1iPareeIHXOScgVNRU3a4U5V EtCjqbXNviZYmkUrkuR0J/lXN20Hm30O9z5e/DOFJKj1qoO0dCZ+89WdBLYeSkjWty8yNIR5bJlt vqe2Kox2d9ayq0ds9wPULz+dOM3Je8rEyjGL913LEOlajNOu9GRCP4uMfWu8022ttI0oSxxC81Mq SGK/Kh9Oetc1ZSqe5E3oSjF88+hdnvLjVLFF1CzWKUYy8JA5559jUhtbKWx2zRz3EwG0SO/O386w eHnGPLDbzOuOIpufPPcyre21Kz1dpI7xmszyIpDk5+tdObi6nlVwioQOecg8VEsGpyUjRY2UYOJn 3NpdXEjtPJuZjngYFZeoWs8cTXZiWWQffkdctj610LCo51jDEa/vBCAHXZ2AHSltWW4YwzEksCAQ MfhVxwsIvYU8ZUa3JofDUC3btCjJIMHnnI/Go73wj9tvDNK8jSnAH/1vSu72bvfqef7RNcos/gxp raKOOIwOgGHjX5j9fWqUvw7v/KZ0MrOeQWjyCfwpxpzSMpVYOXYNN0LUrW3eE34tJwfvKxzHjqMd 6s3J1xrqI292b7ygCYRHtLHOT27jNeRKUHUaaPchGrGne5S/4Se8u9VNu9hF8sgEnZ1U+46/XFUP EGpxppzQSWG2YsdjyHO0evp+FaRpKNSNmZus5Rk5LQ8//i5NK2Ox5r0Dy/UaBnvQRzmgm19RQTmp d+UJJ5pF7DtxA60McrSAiLN0FRPynPWqJfmaCX8g0VrbeQCMEAdeaXT5AtypLlWB4YDp3pKKVynJ yaO9i1qZ7pn06HfAuPMDrw7e1Y0smqSeJ7mRUb7QXbOG4Ge2fSuCMKcJNy3selOpVlFWWhvW1i1x bJFcRLJKy/MoHArntWnSG+bT45A0MJx93GDiih79W3RFYj93Qv1ehnW0cc12RMNwwSNoPGK2INLj lmDP1zu2jqB2rurz5IX6nm0KXtJm61tZmJElh4459TXH6nbrFqzlc7BwQTXBh6km9TvxNGMY3SIY HH2xRyEzkknj6GvTLm7it9ItHgcKmAFkiUFQPSjE3coruaYR+5JsbJpf9qiK4l2RmRCEQE8jHf1I 5NYuk6Xb23jVbFv3joA0pbGT9OK5Y1nySguiOueGiqkakurPQ72K1WdVtEUEgYJPQ981yhtF0/xf DqUBzMx5GflBPB//AFV5uHb5nF9VY9bExXJGpH7LujdkMer6b5N/LDK+/wCZTHgkA89Pb8qn04WV oq29kNwhYrgvjbnnBzz3pVFNR9kttwo8jqe2fxP/AIco6SGTxFeKwDbZGL46D5zzXv2h6zdSWYit VdIXH71LYELt2bSehJyTkj36dK+zw7vSXofIT5lVlr1PbtBkhtdMg3S7L8yZkeRMwRoBjLnP+/nI /u4749A+ziTVLC8t4ilrcWwWRLYlgQHH3ST3B3deoH49fUykko2Z6p4StrOHWFh83z3jXb852deT 8vXPtkf0r7d+Gkt9DpuYbRbmJQw+RS7ZBAIBI9eB37g1Er9SaTutDv7zUtNubF9oOnbLfLM9ou1R yAw3DJY5zjGeB0JzUGn3uni6SwF/NcFFLyA5BPUk4HuAMj39ec9OnQ6/1/4BraLdwmK8ga2kAjll EPmsArouAuPmLHpnPTrzXA+OY7b7FfyCCSFGiTif5EVSMYXJyBjcCMnli3oBUdXdf1qWuWyXRHyj 4v8AD2i6jG6TQvcTThVVm5A5GTtB54Prj6cVweveDDf+DYNOMB3KvlxzKePlwwGMZA+Ynnr1pJ31 OOaZ8s+KvBUuixXkhyZ0Uldi58zj26H/AD6180eINEltLiOedP8ASGxL5UqD5CSCN3v/AIitJJSj Y4knCTbOSv47iSSSe4t4zdE/OyoqfL34AHPb8K6i01jQ08HoLyQNcQuAI4jgsuc4II5xXjYuMp01 GC1ue1hHCNRuT0salz4h0eTwq62oja3bA+zv/Dnucjr7e9Rr4tsG0dYFuPLRSAYTEGXb6DivIpYa oqLutbnsVcRSdbR6JGHfa7ZzqYY2eS2yzoJVJ2Mf89q4xYy2lXMYJWd5FIJQtuA9yeK9JUnHTpoe VOrd3XmZ8Om3EZJ8prglsHdgZXHrjIPP6VraRFd6fPIxiOWbKqrAACtq8VVpci3MMPNU6vOzSvzd 33mEJ5LtjD5yR3q2kl79gEbRq5Ukq+egPavOWCbgk2ei8cua9irqsV3q1j9nmKooUD5ck4FcvH4P iViTLI/zZ5AxXoUqbpQsjzatRVZXZ2Mk+pzwrG8iKFXAKwKDj0zjpXPr4WtViA8tyoOeMirpUo01 aJnVre1kpM1ItCCptWMkehrQGjyOmJI2YY9ar2KerRHt2laJYHh1XhJcZXHTGaF8MRFsqABj+5jF bRp26GDqNk48MKx4G7PTC1IPDK5OdxHXG2tFT1J5tL9Q/wCEXAXOxxz6VZi8MyKxYRlx24quRk+0 ZfTwwZASYWDZ4GKtjwhJKDsiY+vFV7NbidVd9R58CT4H7sk45ArTtPA9yI8CIs47EVo4mamk9TR/ 4QK7cjNsx47LRcfDe9exkD27FHBHTrT5epHtGndHkb/D3UYbi5hkgOY5Cpyp4qe18BXwvA3kOsnD BtppcjYOoonq9j8OruW406ZrN2+0IVHGMkc/413A+F8dnsfUGtrMgFtrMGJ/Lv1qrrbcztKTvEhu NN8E6TCTPdSXU6k8RgKrcHFQf8Jn4BttJkgn8Nx37beMzspX8RSs+rsbwpKL953Pk3VL21u/Fep3 dlEtpHJcyGKMNuG09j+dZGgvPpsd5LcSt57sCnzZAUdhzx6V89X5XKpZbv8AC59RG94voV7eDTb/ AFTUp4beaC8DAswbCuGPp9apauV0qze1uUW6jOSodB97HrUQcnUUZPUc1BQc1troeZMnJ4zTSGDc ivXPC1EwQuRzzUm4txigS0HMAMZ49ajPUnPHvSDcMn1zUm7MYGaCkIRjPNQuCQSaES9VqRn7uM5N dbotzpUdjNb3kBeWVeJAeVP4UTUnHQcOVP3jWs1dFextp02ZLLMFHPfvSpDNKLjzZmEUUm4uWKlj 39q45Wu9NTtTlypXGX81xHdNNZXbRswxsDc1ZPhcXmlw3ouMXJXMypyM/j3xSVRUoqy1NJU3WlK7 0Qyy0SURz3X2aSOCJdyySNjcp4PFdLbwrGkcCqiBgNzjnArkxU3JpI7MDCMU20QyeWtzKiOpfPyb h1HrXMeIIx/acU6oZACMqOn+c1OH0qammJSdK/mM1SYW+hRr9ljjkcYIzyo/CodNnluLaK1ErJGh JKAnbID6j2rsS/c3epwuT+scq0udnbXrWIRJmZApyNzfdBGCPyrnL7WEXxqbuBVI2BWkXIJHA9a4 6FKUqrl0sehiKsYUknumdxpt5pF9FA0l0DI2cgkhgfoaNYfSLdo2muj5nBSOMHIB78dK5VSrRq2S Op1aEqN5PTQ86l1WWeafBdIGclQOv51c0bWJLLWmllX7SkpAfeec9M/hmvanQUqTj1PCp4mUaqlu k9jttJmj/wCEm1BGm8uQswTjjOR+lfRPhmC3tLu2jinluyq7JZlAjV92FUKDz0yxPXtXoYa6pR9D Op/Gk33Z7z4ZuyyySTnybmEbjNtDtMgU7QQDjHYZyCAeOldV4fjYFLpy0ENvllZZNwcrnIGMd0LE c479hXbFa6nO5Nu61/4J67oT+Zq7bEG1JmJlUgE8qc5PfDKPr9RX1x8PNYlk+HqJLJFJqUfmGSSJ tp2Bi3IHzc5HQ8dOBzUdbiglDc9VG+ZFW4knlR184gviQlhn7rEHaMAAjjngdMUptK0+3lspbZ5l mkcRRIivGkUhOTlR8wGcntwfWskry5k9/vOmTVrP+v6ZdmSyslcG6WGBwiRM0iPsY5yd2SM9vpxj HJ4zxHqd7cRucyGZS0UMYL75Aqk7iSMDJwCoGfU0lzLXYeqlbucloHg6fUtVu5ZwGlkVo1cyCRVy 23BIGOQM5J54PSpdR8EzeHtSv4b63MVrJCptSjZk+8ch9xPzYHBHrzyKUvdkczVtEfH/AMZNH05t c+2WjlYZso/8AYA4OQSSAcZ6/kCBXyX480LS4pJ7+J1kZwU8naMKcfeBB9QOOla7nPKKu+x4XNps cV0wZhIhGzKgnPciuZ1Dwu8WZRu3Mc4x61hKPMOMuXZktv4fddTtITkLLuDnGRkDP9K6b/hE0Vuc n/gPWslB3G5XepYXwjvU4Qn0+XrVyLwW7Efuz+VP2dieZvqWo/BMjIpCMT3wKvR/D+b74gdz/u1f KiLuPUsxeAbp7jb9iORnrWmnw4vS3FuRx0FFtLk80dETL8Mb4nKwknrnFWT8Lb4gkxdumMVdra2M 1U1LUPwnu3HNuckcfKea1rb4O6m7DbaOykDGENOySByuzoYfglrDYxp0x9hDWsPgH4hljbydInKk cDyT+NSnEHuaNp+z14kbCvotwSxwP3Jwf8810Nr+zN4gmhMi6NPIuQDhTxzjn8apzj3I95rY2B+y /wCKlKAaDdOAeixnnP0rXsv2TvGtzINnhK+ldTz/AKOf1pOrBK9xLmWh11t+xn8QJkDt4RnjXI3C TCYz9TzXVWv7Evi/cHubC0tUGD+8vIwCDjn73vR7S/w3Zr7OctbM1l/Yxkgs3nvNQsIAGIK/ak4O QO556/lUz/snaJZKskvijTVjLD7k6v2yeh+oo5qj2Q1h5vVoh/4Z68F2kjC78W6dGoHUPk/5zxTr b4TfC+1M4vPEkCbMqNiEk+jdP0qv3vYr6s1c0v8AhDfgVZWfmT67cTThjuSOBQMZ6jnnjtikV/2d 7OZxNY3t9H6SXCxj9Mmp5Kr1vY0+rwW7vY80134jfszeD/GM0K/Ds61cXEQeYahqrCNXIxwIwCeM ck+tYF18cPgLqNjG8Hwc0KELwpjvroPgcYJEmTXV7CK1cncp08PFbNs8c+NXxb8I6j4T8NjwP4eh 8MJbbspDM0hyT83LEnqPXvXy1qnjq/umZpbh2Hc56/5zTdoJLyJm4xkuU8k8Q+MwjyEzFm/hUHmv OJ9c1u/heSJvLtcHIHLVwVqqjqzejBy6FBZI1SWcF5eA3U5z7VDJcILxL1ppbdwoCkngg9q8tKTb PTk4qP4kVzJd31xGVnCIq5WRMgHvzUd3bXF0C11dF8cI3J/nVc0YNK2qJ5KlRNt6M54nIOKjOeT1 4rsPOaZE5O7OOlIGI5zVGaepIMPnceetDbe1IpPQTa23PUe1JtPrQBJtZj60jr27UA0VT1PNXrTB l3kc9jmquZ9Tfg34QJ8wDfNk9q6cJbvNv3L5sqhQznK49u1efWbT0PUoRi43l8jEuM/235UiNFLE DtmLD5vr7Vced7doUN8ttMP3jMmSrADoaGr26ji2r9CK+8WXcu6KyhS3tcAFCNxYd857da2dPje4 Cyl9jMudrHjisq8FCF+pvhp+0qNfcOjkiGoNHNMolxk7uwPbNUdaukEtkkDZaJid5U4I9K56cZe0 V9jprTiqWj1ucheT3Yv5DN8zyHdtbpgn07V0uhRqgeCQC3vMeYpccMpGRiu+tb2Punn4dt1/f/pl 7UbO4u4fLQ+dMOc5I3e1Yc+ianFaOzW2Mru65O3rms6FenGPI9zTFYerKXMtjOg/eSLFL+6cNkPu 2Y/GprnULghYd29UztOM8fWvUaTZ5XM4obuK26MykjacAjjNLDGZZguNoVd3IPzVSWoPY6Hw5cod cxO7rlsFgMkZAH419LaNJJFFp80yrOk1sIw4j43YAwS3G4DGCB6d+a1jsUn1Z7loV4ItPSdWKqio YkdtzSDdhQVweOVYADqo616foV1JZ6Tbh3+1iFmSOcllDruKhhkE9Hyemc85xW7baNNNXtY9y8HK FRLRSLaKZVVmkO3ccFCxGME7hkk8ceoAr638F6Q9ro9zYu8lnfxyNPHGRHtbJblWBXHJkJzwQB+G Wsdevmbx5ZwZ35ZlsI44J1mZFBe3clBEQyHDbgQBnJBU564PAwl3dZgFyoEt9kbCwyyKflbLEnvk BW4HtgmmuW+ug0pcqt/X+ZNdQC48Py2dxLDMftIxbvZ+Y8RAxu27d4IAHsAc80uk+D73VbnzZo3W K8QI4Vzu8vJ2kup4AxjgYxjJ4NY80Y6iakn5LseyaRoVvpsEJWFliVC8ZQAMO2zKnoOBjJAPOa8T 8f674nm10WGn2sGoLcosVrmEbjtGXxlgW+XJ5Cg9O4pKSW/9dRaNtpXPjPx98HvH2sGa7udFaNJv mbyYyEhDfMCMcD5ccYHQgZwa81P7MGqB4JdYla1G0KTPB3I/iTOe/B4p89lbqcM4vnad9TutF/Yn std1WNJbmLTbNkV0li8x1Y4GW/iAyexIx+Ir06P/AIJ4+H5S8g8Q/ucqMW0HnsWJ2sxO7oOvCn8a y9rPojRYeVndnz98ef2Sl+GmufCyHSZP7SfXdfOmptiILuUG3uepyMEA8dK7Cw/Yy8ZXJHm6DKhJ +XK9sZp+0UdzlqU5RaTOttv2IfFTOhXR5I0IySzA5P8AT9a6i3/Yc8SbRvto4znJyQMUe1MlCb2N 60/Yj1HYnmS2sQOTuaVF/rWmv7GNtCrNdeIdNiCgFy1yuBRzzfwxZusPUu9DTh/ZI8H2iF7vxhpR KEE4l4/P8atL+zp8LrWXFz4usnC/eZZBj60m61vhD6tUjO7LFv8AB/4IWkv+l6/A0XQkNnccfWrT eAf2dreJ1l1YXEiqANoPbk8YpqFeT10LeGt1EEn7NOkyFJbNpHXhlY8kfTp1qvL8Tv2etOZvsfhu ORwCMO4APX61v9Xk/ikP2VLvqF1+0J8I7O2/0LwpZsy9TI2ePTFZMn7VPgm3nC2vhrTIVc4Jfn65 z0oWFh1Zo/ZRd7anPT/thaLbX0iRaPpkkakbGS3Clh3457k/54rk9Q/bRuIZ5xp0FhBDuYpH5Ckg E9M9fX8QK0+r0r6jVSMVdRRyWoftq+Kba2iJMVqkyl0kFuB5gP8AEPxB5+tcdqP7a/jW5iwNYkRe 21tvH4VrGnSi7pB7d9FY4u7/AGtPF968jTa5cuTksBLwTXH337S2tSiQvrFwrFiG/eE5HXp+dac1 lYmVab3epxl7+0L4glQompT4z8u5zxXN3Hxz19yR9vmJHQ7zwaXPoZ80r/1/Wpjz/GTV3uA322Qj Hzb5M5NZV18XtXJO69kbdjI3ce1RKoiLyTuYcvxR1eRX/wBLcZPJL9awbzx3qtwFxeuWB5I6MKj2 iHzJao8813XbvUNZF1czlpsY4rPh1udYdgnYYbIGah1NTO13c0bzWmHheCKWXJGf4u2a851XxJLL KbW1JLMfmbsPqaxnP3bs3hHmaucPewXMt7M4mFw6jJfPBHtWVb6tc2ty43h1Y4dT3FcbSqR1Onnl RldHYaTbLfmTgwqoLZB4b2rJ1GyW4uZI4srtAI3PuwfQ1yRkozbO2UXUh6mha2XkaNHFIwZ8kqcc HuaYqpPLJAXEbqM7SeormvduR2qKhGMLnDq4JIwM1NuXkZxXrngLYiK7m9j61ARgmgl9xcenXvTu enWmNEqybRgjIpC+584/CkCepbH+rGByarycPikDZRkB3k561taRCjH95G0jMcKAeB705tqDYQV5 6nbW2kxLMu+6KM6k7Vj4x6E+tTxx2sVw0LSYZAMHFeVKUp7HtQiqTSZb1AWP2ZI3/eTgfMQvOD61 yV9aRPcLAHMcjD77nP4GihKa3HiI02nbcxdQtHsJYkeQSsw3EgYA5q1Dqs8XklXDGMEKM4OD716S 5asEzyLyoVGl0NS2sL/XNVjKLsbOHkY8IPU962G06PRwy6tdhHz8jqpYe2DXHVqJWpQ3OyhCTvWn tc2ZNP0+fQ4Ljy1PRjMRktn27Vn6nYmTR47xYt/2f+IMFKj1yT0rzoVJc6Un1PXqU4qm5R66ksFx cpewRwRq4K72frxXQTEPaSLNC6PKhCjPTvwamSSkrbmiblF9jxy6Zjqs5Ytv8w8H61csYzcX0cAT exYE8Z6cn68Zr6O9oXPlUryNTyisJRQWxJ024BHf9auC3R42nnBgQfLcN3TnsO46Yq+eKSvuHs5N trZBMNIgsLW40+4Mt1HMyXJIwGH8JHr/APXr3bwZrMGpfDefS5JY49UtLiKexQxEtMrSASICDgdQ 3IJ+XAxk53j8T1Ek+XU958KPNe6HbQXETLOzPHJ+8yybcHODnnqfb8sez6LcCeG3gnSUIqjaOVZy FHOCQBnGMnp1rpfM2JtNI9w8Jan9ns7cJMI7pVHmyCHBbnjoR8nTOAScDOe30LovjLRvB3gnU9c8 U+IJdO0rTEV5Ls2/m/uywjQDB3ZzhQBn7w69adnb1N3OKdo2T/MxpP2mvhZDdRyWOp6/qghYYEXh oMG6MMncCwDDGD9ea0F/aa8Hy6bcx2/gXxxesIx5ckGm5VhuJYfPHhc8A9eOpJArG9BKzmr/AHnU nTirNozdH/aDE80kusfC/wAV3MAk3RgKIlKDGIzuUAd+RgZ7YOK9W039rHR7PTjBp/wr1kzrHjM+ t2UHQ46STD07D17U/dfvNv8A8BbLj7GUtZNfK/4jrv8Aa5u722fyPhUFzk/6d4wsUPXJ4UtjPqMm uE1T9pHxPeX6yWvg7wppscCqLf7V4plbyuPmK+VbEZPHJzj3rD2SktFJ/cv1KvhlZq7+5fqefXHx x1tb2a4hl8CaTclkJnm1XVLuQhBtUH9wq9CemOeTzg1zNx8eTLI9re6t4N1WUsGN0dM1B3cgEAkt MvQemK2dObXw2/7e1/CP6mTqYeOru/V/5IgX47aqBbwn4j6dGse5WWPw00h2nB27nuckcdD+fNdF F+1Hr+laRPaf8Lfu4EYEAWPhSzjLDgDLySyEHgc8njrVck0/sr73+qCGIpqycb/e/wDI801r482m veNvCniPxL8RPEPiTUPDGqpqWkxXRto4UmBB3FEiAPC45PRjjnmvVL79vzXprV0S7SMgnDrx+npT 5Lu8vysYSq+9e34WOduf24/FTxSStqjzKVxhZdu05HzD9a4y7/bM8Y3KMv8AwkE6c85kHetUopWM nVkcheftVeKZzzrs+3ByRLj6Yrlb79pbXLhAja1ORnp5hOad0YynOzZzlx+0Hqrkk6nO3OcmQ1jz ftAak0RBv5VJB6NwTS5ri9o7O7MiX46amy7P7QkAPOd9c3dfGnVZXYf2lIwz/fPSo5hc0k7mFN8V NRkLsb+Qg88sazJvibdmR2a5cqTnh+tTzie9iknxGuiz77xwOc4OetRP47uZWZluGKk92pczuTbW 6KNx4xuyyBronb79B6Vmy+LZTIzNOT7ZqeZjXM9ClJ4snKlTOduOhNUj4tmAOZCRnOPWk5hyu9yM +MJAPvndnsKoy+KWkJbJ3HrnvWbqFqEmVX8SSlc7jnPrUR8QzN3yfrS50Cg7kTa3JksXGfrUJ1rg lpMn2qOcfs2yFtdTBLSqPq1UpfEsCZAuYwf98VnzFey2OXvNcMuoZjlLq5wu05BNPhOozTqEt5mc 8fcPP51lUqxhq2bxotuyRp3ljq7Wuy7DW2RhRkFsjt7VyMkkto72Mr7VyGYNjOOvWsVVVY6HSlTR o2F3HcQzCyiLFANwfGDnjr371h6tZRf2sZ2Z4YpGO4svIOOD9DRSUozd9yKvLKmrGbDq13ayP9lY ojDCqTkD3rU0uO4I85pC8krdCaqqoxi33JoSnOaXY6ZmdIMFs8cCs5pU3yNKvzbMK1ebBO57U2kr nFYAye9MUE55yfWvaPm3fYlBIB3c1Ecs2McCkDHKDkk8e9GCT15piQMCDzzT41y+TyBzSHuy8mMl j+FRSBSxbHNLqV6mbKPmJ/rWnpt2IXKlgrZ4bHSnNc0LCpy5Z3O7sGu72xQI6GQy4B4wQPeq08d1 BrUiICYgu5mxkA15zUU2j1OabSY9rxlt5QDmQcSOOv0rm2JnFx5kgMq/NGNwBY1rSi4q/UxrT552 RRuBetFG12G8oD5Cw/rVaGJpZsR/Njkt6Cu1cqjocE+dy97c9h8M2v2dP7Xe22XUilWJOQy46j0N QeIoU1rWrWGUsltDydq4Yt+XNeHf/aHPse+1fDqHfU0PsJSzzBJ5cZABjlBAz0qlrUDDw9LZyQm2 8z5wynIzj1HY+hFY02nUTfc6KqaoteRlWcrpYaeySCLzIdnPOWx3rqrW8tm0/wDs6+lMt7GCfQ9M k06ik3dLVf8ABKpuKVm9zmreHR5fFU095EskbExoeDucAckfTNacc507SWe3tFWzWQGIsdrR9tx7 kZzXc1JxSk+iPLi4xm2lff8Ar+vMfd3+ltopFrKq3RfL7wDnJ5HNc3ql6uoJFHGoZVYGR0fAx71p GnN1E2TKcIwce5lz26wTzbl3GQ4wTkgcf/Xp+m6jcaTqSIZmQbv3b/0/OvRV4s8+59UeBfiTYCSP 7ZEs9yCGJZtuQFII/Edvb3r6K8PeJdJuNlytwLiKKJgm47TkjIyRyO/4jrxiu+LukLl10O8s/F2j 6b5WqbkllKgTQpGGUFHB3cng4wfr+GPN/Gfx4+0a1c2Nrds1vNPFlG/2ZldQR04IraVlFoxs38TO C1H9oTxLfaa1vPrNxLG+AY2mYrke3Subl+NevugDanK+BjDSk8f/AKqzU7FuTWz6/wBfmUn+Lurv ki8YA9fn61Tb4s6wRxfPke5pe0T3Je92Qn4rawc7r193+8elNb4q6pJHtN++7/fpc7Fe5Qm+JWov Ed12zEk85rKl8e3jDPnsSPelztbsTS3sUX8cXTuXWVg3QkHGahbxlfSg5mdhg5yajmGrtWIJPFl0 2B5pPqSarSeJrh1IMrDPcUvaIpRklqTxeKbkIVeR/wADUZ8STby3mEnPc1n7QOR+hDJ4jnYHMx5/ 2qgOvPgsZcn60e0W41CV9yq+uSHP74+2DVZtakPWQ4qHUYvZ63ZA+tNk/vevbNVDrG1iTNj6ml7R 9TZU7MafEEI3ZuAx/wB6oW1xGQkOWA9KhzezK9n1Q3+3Y+PlkY+yk5/SpY9cld9scMxOSB+7YZ/S snUilds0VJtjLjXriGMPLbTKGxglcZ/OqE3iGcbR9mkyxwAcf40KalswcFB67mfP4jvEYZtgu4Ag s/X8ql0/VNQ1LUzaqIUbBIJY8+3Sqn7kHJkRalNRtua0q3kE+y4ngt88AsrHn86jthJcXbQPfxpM jfNsiOP1rhdV8vMkd6pRVTlbH+TL/a8lo91M5VQ29EXBB9OKdHp8l1C8X26aKcn5GOMY9xisXXkt WbKjF7DbPTFNvdDUJn8xUb5lmJA9G6/pVNLe0VYEKfaWJIaTcQB7nJ5pe1nO9gdKNNK5RW2j/wCE qit0iRof4ztDZOMmrp03SrvW/KjdRPbplogMA+1bynOGq7anPCnTqNp9zQ+zWUTwyXDRxRpICpb+ Eiuph1KGKfzraZJ4c5DZGK8uanON3sexTjCE33OT1XxdbzayYFVZQ7Dc/QK2etc1q9m9yHuVdN7N 87AY3e1ejCLoON+p5lSUa0ZRXQoaU1zY30kltMA2CBt5AbHcU/WNWh1C0kSQsbj5RkLtUEdeO/eu 1e9U5luea/dpWexy6oXnRFOWPrXRwSPayJC8nzbcxkfnTrWasLD3UuYznuLx7o/vXI3E57AVrW3F qAzsxPCMRn8/SpnGKWhrCU3Jts5nexapM55rc5d9x/XrTgRg+vrUhuKVyOuc03YcdM0XC3Qafu/M MnsKnAHTH1piew4tznqaiY5Q84NIrqUpec9zT7dsEg4yT1NX0Mep0+nP5bSKsp9RtbHNdDt26DNL cPIkhHygtk+3Irjnqz0Kd7XMsMTYMxid525du2wdq56zUT6unnuETdnk9fatVpB2MNJTV+p10gjF qMlWTH8Q4rmhNZGZ22cBgow2DjPJFc9DmaZ2YhQUkeoQX0M2im2hPkzLACMNjaMZqjpc00NhHJcR CeaM7k2SZGPXNcMI8qkpdz0JtylFx2sbhuzNOWeUSozA7fQY7U6Se3azcXTuxLhBCGwee/vXHySU tDucocmpzrX2nW17LBE/n2qAsG2nG4dRz3rJbXJpNWaaC2jYMCqs6fMRXqU6MpO89Lnj1K8IRstW jN/eNr8kskYVZHyYs8Zq5capOguEKb1dVUJyQAK7HFO1zijPluzBjjkmlZpVOQ3Q5BOa7PStHurd LhNqyRnJwzY3DHQ/jj8q1nVhS1ZFKnKstNy1FHcI0E8kSSS7QChUKE59u9bMukWV7LbLqFqkyMMu EbAH4g5rzKlVzfPF66/cenCjGMeSa0/U5PVdNutH1sLprSXluyl4ypy6j+o/Wr9h441e2ikt1vHh ZvvAjDfTBr1MPXcoJvqebWh7Obj2NqPx7qv2RoWu2kUjncMj/PFYQ126n1WJnlLt5gI55J3ZrrnU ujBR5nct3FwzanLGtwGO845AqS6EtmI/tMiL5ihl2yq2Qfoaw9q0aezRWFwSP9dnJwMHrVxYr8oZ Etbh1HO4Qsf6Vm6hXJBbs0bfQfEl4Fa30PUZwy71aOxlYFcZyML0xVqDwj4tubgRxeHdUZ2bABsJ Rk4zjlfTNSqrd7CfsY7vc3Yfhl49mAI8N3iDjl4WH8xXS2XwW8cTpDLe6dcWtu7gborfz269lU5N S6ku/wCf+RcfZ33t9/8AkdaP2eNckhAhTxLcT4yRH4UGzBPBDtcjP86yJ/gR4lTXmsbP7XPKq7pm ubVLVYxjPzEyNimuZp6322u/zsdlSjTpxUk7+if62OIuvhz4gtNTNvKsETZ5El0Mjkg5wpx0p7/D jV0v5YRqVoShwSuXGfY8A1MuZHPDVtW2FPw11ZoDjVrf7Rhf3XkEHJ9Tupbv4YalFp13IdUAlij3 bPIAJbI45Pue1ZSk41OVrQ1jFzpcyWtjze+0lrfrfXBwPnBRRzjtxRp+hteod11cFim9QGHT349K 6ZtQjc44c05W7luHwxDv3zXcsqc/KspDZ/OqF7otvYSL5sc0qlSWZpCQDkYGM56ZrgWI55cqVj0X h3SipSdywmi6TNoNtsKS3skytsJ4C4OVbGSOxz9ahTw4Zb5khtLYQ4IEjLwQCScH8e/oK75zhRgn Pc82NOVeraJjvJNpGpyRNAu1W6lenoQcV0tpqdnJpphkSNZGLYA+83vXDWhz2nF6bno0JRjenJao e0ATSt6sN5+8yqG/H/GtKxgh+zpvvUuWX5gygcg9j/jXmttwemp6sVaa16GfJFFPExmQO6k+UW5/ So2WE+HBHBHsu/LJUgDBJ680oSlfV7MqrCLV0tWjzO5tzbyt5khzkghxz/8Aqp+nz/Z7qGcttj38 nHIr6R/vKfqfKpOnUTbPW7cWOtNGblC7oQUwMj86o3Ph+1utWW5gZ/KUMJVjG1iR65r52NWUHy9E fQzpe097qzCvLiTTbtLKPLbyBGxHIHuaS31H7HaRy3Mjuxfp5eSfUV0cnPC63ZHPyTs9omhNdadc zG4cSQ/IVC4+9kYNZiW8MNtDBcMAsrHZht2QPUirpKcY2MqzhKpfv/wC7qUCeRFJaqVcnZuRcFR6 1FaW/wDZ8bvcusk+7HmEnJz7mlKonDlW7LhTcJ3lsjl9cu45reaOPUFl5H7gAnkHnnpWRY315bzq sEjbX+UDPHv1r0acUqVmjy605e25kzUh0mJj9olY8EllHc1oPI7RFAuEXriuKpPnlr0O6hS5Fzdz OuzOVZowquRn5etcu6TeY0jAls5OK7qLXLc87E83PYIi3nBuAVOa6kpHJb+aTulA6AdKivumVhtm mVnLCAMsaqc4Ic5yKEnkP7plCsBnevTNZWvqdN3FnOgEoT1an5GMGu08wM89abuJkOeaNwJ1DOcL yaVldZcE54qVYq45gNoP8VO/g56mn0FYhbLdO1Nxwc8mgCrJnk1CGIbrVozZpwXKqCWPJ6dq2rS8 MsJhQlkLfMD3PrWc49TaEreptx3EECsFfzXIKqhGD7/WuIlfN3LJtxkkgA8CopL3m2aVnaKSNC3v 2ex+zTkiH+93x6Zosykmsxx48yBXJVQOtaW5b2MubmceY6qOWztkuQ6Sy3E0TARh/mRcf/Wq/pd5 Fb6JJ5smI4YcszfeINefODktfI9SnJRloZ2oajBL4ZZ4kMk7EBXA24x3/pXNJPcXFwEad5GIyGLH g120YJRdzir1G2mnpYsLbzzXsMClgM5z25r0KDR7aHTo4XL3DuOw5/DFcuIquCSRvhaSqtyfQrvo sflhQCs27lpDtOO/PeqI0XEbn7SGk3fKvt9axjXa31N3hk9tDEns2eZzG+5gOPf0rqtC1OEWz2V/ cBLsyARvIuBg9h2610117WlpuYYeXsa2uxuSxyreQW8duXD/ADeYBkVJPJHp+nO5mSRhIBJzkheu MV5ME3aPc9eo4tOb6HMR61i4ku449oZSqb8HH4elRX97YajaRi7jSWREJMqQgZ9BmvYp0FGSPFq1 VUi2ZtrpdjcQqxiaAM+0ETMMg859DjpWna2WlW32dntjcTKckSM3z89Ovp/OuqtF8vusxoOKl7x7 MPAeleJ/CWmyR2sejai5adbm2UlyjYwr87SBjI4ByxyTXVDwgdT1qw1fxR4s1Dxfe2EMdtaLfOQs UUY2oikknaoxgAjp0rljUk7wWx1uDjC66npcdtFBrVhaLaNMywmUBYA0UeOAGPUE9sZNdVHKYrx4 NVV47gIZ0WJGYFQOQB3A/nzVwim7dbHPUtHW3qehR2cxtbcwLvTZh5kwS6EAkD2Iq+PD6R63Bd2K lIy4M0bZIIwBkZ4U4zwPU1tH3dERJXXNbqLq/iGw0O2t2nYzb8tbxIw+XPBBbJAHGR9egzz5trXi zUtbaygt5X022CBvJjlJG8MerYBPHGOlF2pcvU6oxjGPMn1sYD22p3K6lI0dw8ssX7qLzSVGGBPU 9P8ACn6WNQsNMuorcGGGXb5m0Eb9qkdT6k9M4rKTkvebfkb+0lNKLdzGvNKS/wBXks7USXF5clUw kZLMSQcAdGHt3NYd3pzabdQwSZt7eJm+YxgNkdTg8kj07d6xnzJ8w4csny7s27mLTkvbefSruSWO K2QKJIsGQnLMWHbrnGT35qKbTWuhcTkN+/hYPE5+4emPWlXlZN3vsOjFKSi+tzwHxfpT28ixL+7R WJdTGAw79cZI/kc+tZemJNZYlkt2SAqNzHgNxjg10NOvD1R5d1Qq+jIblY1dJLdWa4Yk4LHGCeKo vZX9zBIbliZRg4HOa5JclFo6o+0qp6mVbIbTUbh3ZmJADru+8OOOnt+laeoa7Z20CSQmRwxI8vad y/nUYilPEWsa4WrHDNuXU5rVrttVv40tFdk2gsJcAtTpNOijtriSSRkuEQspX+WPSqtKlCMHv1Hd VpymtF0OZivp/Ma1W5eMntnhhnn8ea1Pst9aJ59tkIAA7/57YNdk1Th7slucUZVZPmXQltLq9Gpp 9pcyiMts3YwQf8mrFzdXCM5tY0Ruhz0968ipGHttNj3aU5vDty3MrVppJNDIuYUN033XHX6/lWBZ WN5fT7WbywAdpY8H2FenRajTueJiPeq679T0HTbm70Tw+Lee3ZYo3yZCOcHmry6qY4pZZN24n5V2 kBh9a82dBTk5LqepRxHJBRe6OZe6a61E3Dlt3AjDckD/APXW1FaLJoVxK0ameOXKMWPzcf8A661n H2cV3Moy9pJvo/6RhS/anuLiMTRxBnBhUEE47+9RJCllEZZnHmk8Bj3ra8eTlh1M0pOpzVHoi5p2 qmbT0MkW6ZnO1UO4YB70+/kj1GEpINygnGw42EfSuX2bp1OZdDsVRVaVn1OWuNGSPTmckySNkKUH GetZdqkizKzP5cickHoK9ONTmi7nj1KXs5o3YdQili+R8yAAsGGC3tTknMsrD7pI4AHH51xuHK3c 741OaKsVFXOrearhip2MGHBNZkrh9Q/d4GcnbnofSuuG/wAjhq7fMnK6dFxIpDsMk4JAqaIrFCfJ JZWOfzqJ8zXvF0uRS03RZUIQHIP1NUJJiJklUARtywXms4Jts2qtIwfMJzRu79TXeeV0HFgeSeac oyc0g6kyOyk4NGXaTcTmkPUcTlsnnHSmucrnPNAeonrzzTAxZjSK0uRyDn1qo33q0WxlIcHIXbni rlrcJHcfvM7SeWBwRQ1oCequdZFcxCXfvB+XIJHX/wCvWIbKW51VysZWJjncOnNc8fcu2dU/fSR0 stvpi2EUbAbIxh2xXMTeRaakr20plj6g9CPanT53e4qkYRV1uXbzWXmtlMOYJd3UfeAx69ap2EJu rvE0/lRZG5mPWtFHkj5kubqTte1z0nStNt4bCaCZjM2corDGc965vWooLSTyLWPYScmTHT2HeuCE 5Tq27nfVpxjRT6kmlo627zNKTtOAuOufeugF7NBZtJHvDhT5ZJxk1hWalOzOvDpwp3RLa6ncvbpJ fKs0jKBIAeBz2/CqzMZL+SKBdiOQWzzx3qElGT7GjbcVdajtSgih0tJQuGGQGI59q5WWZX8qcAFk YHaRwea76DcoXPMrLlqHpialJeQWjSosaJHvBj6qSBgCsi90+zeC4aXf9pkO7fJzx9e1cUeaFT3T umlKn7xzcttBC1zBDJGxVSy7zkkd6oxRPJpxkClkVsElsADsPzr3E7K73PEcbNpGnclI7SGJBsjX aQ+7BPBzx260+LVpImWJIUZ1cssjZzg/Tit5JSi0yItxd+x9IeFfEdnqfhWGL7R5U67Y5Y0Q4Hyt yT0AwDXXq9nqItxa3CyRB8cP39eK8mEZQq2PXqNSouSPUbBkt7uEg+ZKMLhSD1xnPp1FXdU10aPr UcsmmJNKx8qF5pQA2Ryqjk9+SeBj3oi7SuQ0pe6+pBefFaygtLew0TTTHJ5a7muWXbG3B+UA4PPc nvW5pfxU1abSmiNnaTXSDHmeWQoYjIAHr39MCtXVV2tylQSgmzkL+9uL6wuJrudmaR5Jfs5BCAsf vKMYJ6dhXT6Npm21tLOa3DxvEjBzjcmTks3pweKmHuvme7FU1Vtj6t+HPwb07VfhTrOt2OoRX8rw iNUnt8mAA5csMgBjgYIJH48V5b438Af8K/1jT2e/ttQgniMpdHz5aNldjoRuDZ4HUe/pfNKctUc0 VKPmebeIfCqw+FtFXT9d0+8TWBHvsLfcLqycbhv252jaV7MPv9+leY+I9Cms9ZOmXdpJavs3+U/L 5zzjPfHfnkY966cQnKCuLCXpTae7/r8ijp9g0UiyRDdAoHmbONy9AfX/APXWg93Lp+pwxwxxyMJV WNpMHdzj8+g5ry9otNHq6OSbPKPF+qySahNNcbJmR/lUoMhe/wDhXmxleW2Eksq+UXyPk4B9APSu zD3VNt7nlY3lliFy9iG4aKO1UuX8zzCXZhx+A/E1nxXYW/fBYhj82RwK4Kq5md1L3Y7kepS6b9nJ tsyMRuZmG0g9O1ca/lzyTNJMF2n5vVj3rqpTny3aOWrTgppJl7z40jtY3CuVBKNHEocr1IYqMn8a ra5Ok9ss0cbQlG25Y/eJ9D/jWceec1UlsaycYU3Tjujhyri4xkhl5OB1ru9Nv4TaLHdPLEfKKg53 KSehx7V1V4cy0OPDzcJaivDCLjfDMzLsDZwAHOPmPtzWc96gnzKNpHbtXmODnLTc9aFT2cFzPRs0 7Kxt9Z12BUY7B94seMnsPWvRrbw1YWVpEq+TJcxP5zq/y5HUAHvxRKcopQMuSM5uocB4n1i23yqo B3tv4OSK5+x8UzRaqh1KMT6cwO5QBuGemD7V0+wU6duvQx+sOnWuvmTQarY3mrypHGIUjYmEEY3f 4Vbi8QB5JY3YiJUJIfA3EdhzzUewlJtPWxt7eCSa6nLanqNs+pi8twzSqQc/wj2qcRxajqEVvd6n JbTSt8oaH5NvUZOeK61HkSbWqPPnNSk1F6M6H+wZ9E/dyyAuw3q69xSPs+yGSNgZidxXpk158580 nLuerSjyxUeyImka604xHMb9UJHG7HrXKz2k1vdG3u2UK+Du4Ofxq6MkrrqZ4mN4qXQtCGGCZTGV bjBOPvUgwLxgZdmQcAGr5nJ3ZKiox0EihuIbeRluhK+47QRx+NV5gsWou8qBTIoKbf73etlJN+py OLULvUY9jLNam6B3uo4jJ6in2c0m4wXERDjlSBTk1OPoKmnCav1LyNH5j70LoDgDOMVl3gXAhQGI E/KBxWcFaRtUacb2MMD5R2/CgjjjrXaec7DdpzycmpgcAbqCV5j+GPXJp+cpjpSKeojsAMd+9RFm 454oAc+Que9Ipyuc80FdRrHrVZwd3NUjNjP50E80zMtQ3RQbXG5PSunsDHNGZEYMw/gzyBWFVWi2 jrou81c0JYDc2DqCBuO8sBk+prKvTZI6vFbiPYqjB53Gs6bb0NakV8TKsVlLNH5hXbuzsyCc09bV I1lMsuCuNqj+I59a6edJ6HGotu7Ne91qae02xzhPLjAGRgn2BrH+0TzJE1w5cLgZJNZxgoo2nVct L6HRW0wAicDKLyCTwakudTZyxYbnH8KjtXA6XNPU9ONZQgJYzlp+SEcE4iPPBPp9a24tQit7qJpN q7TmQ45AHpSq07ysi6NT3eZkMupW9/b3MPll9zgRZBGSe1YMsctuMyLGrY4UkEA/QVtRi4LlZy4m anJTRRbUbyWUsJ3RQBgK239Kuzald3CIJZWl2oNzY5x6E118kUc/tZSurkh24NxnEYAA7g+opFki keTerwRt6d6I3bIdo+pHdQKQJFcyRZwCWGevpQHWMvGku5x04wTXYndGT31O00c3B1GNDCUutiNn O1TwRzx1wfzru7W9urCW3uLGXyL0Ar8w4YdG/DmvKrTcK10evQjzUXc7K28Xa7PeKlxPJMIw+9o1 woLDnoORyOPeuosEu7rwa1xDcJf6kHfz1EwkaCI5UHaO5Geeo4PGc1NueL187B7TlaVupUtVhfVI Jrq42RpGfOUEHPI4IyCMY+uO1egeFrrSDq8Kv5kqzkbYwcl2xmPK7u7AA5wMHn0NRTck3oKTSg9d D1TS9DvNfi1W706WK3bT7aM3x80KZHCqG2fLnG4+mM9eK7qx0HVHgtAinUrlYtzLDEHfrkE9BnGP 54xXZKMFOy2OCLkoanuOgalq6/A/+ydM8S3OjtNcx79Kg08h5d0gJcMiZzhVyc8jjnPHomsfDzQf iZ8OtOmsddh/4TyK3/0lJ4D5U8aPnK+WCFGGJ4ySBzgdOqdOUKd1bT8jHnc3bTb9TwbVfCdz4B8a TRz2VhrNzp801tD+4fy5cRsXUk4BOAxGc5wMAnIr5s8bSi78R3F/qdpmeddiBnbdCCSSCx9VOQfp nOAa5Kk+Wla2r/r8zqoRjzO++hwyXi6dodrp1zPIgZm85owDJgdMc5zxjtjr2rlNSv8AT4NA32tv ereqwMc010GSI4HzbdvU/X88Vw2V05Pc71J2djzXUNGvpfDA1m6vpy08nyAqDuQkAYUepxzmuE1F 7uwYI4imyQytyM8e/HHevUklFe7seE3KUveL8qXEmkPPlG+VT5Z+8TkZx+dVZpVksPOdUjlQdl5b tXl1YyTTR6dGUOWxzeqXkcsCRRRgkc5RcZ9f61nR6fv0mWZmaKc/cR/4+OQK6I+5FHO7TkYPlXKa k8EoVZjwFYjA989K7bVNNgm8JwiF0MiICWJ++fb170qsmpwtsVTV4zbMCOxVbBy+1Gxhlf0qeGGF LVYmImWQ5jI44+tZ1Kjtoa0aSlq/uJp7b/W+WNiFAqkNwD/jWDNp5QhZMl92Mj+If480Uai+0Fem 9EjcsrhbCECOMldwOSeR71sxaxcXUhSZ3CEEPJ0KDngmk4qUXUZafLUVJdTnZvDk0tldtZzpIXIK iQY2r35rMh8MX1zaup8pQmSzGQYJB7ep9qdGupu0tycRhZw1WqIbnQpNOkFxdsrwAKRsfBYkZxzz 9aq3UtvPJGkMZiXbwBzg/WvVTjyc3c8tq0rPRmWxNvcMVIDjghhkH1q1bS2sSjzdsrZBBZT8p/wr CUboqL5Wd+2rtrGlwSlNgjTaozngHB5rnbhInu5bQTGKXG8kdvxrxYpxlbt+h9BOSnC/csyzw2dl tllZlCE4PNZcN7Z6jGI5GJlXld5wR+NXGE1FzRE50+ZU5MiniZbxNh4B+cA5GKrTxiR94JSXoDWs XqmZyj7rTJ7aOVIiXkyT1GO/WpGhWWTFwd2TkAf49qUp+82iYU700pErSRf2lCrPsjOVCj1qtq0M n2RLmIkzRHP4VcHZq/UmaTTt0OaS5lW9MjuwBPzmteRo5EjlO6XYD1FdclaSsefF80XdmOxwuD/O kGMZzVmelxcHmmglic8ikLyHIPmJzmpgcZJpsLa6gyqQe5qsyv1Pb0oKeg4fd5605VJb1pDJvJYk 5qCWIjNCZMkUznJzSdutaGeghqaKeSCYPGxDCk1fcafK7m1BrEpXZnY571n3Ezve7yeM8DNRGCUj WdRyirnd6PdW0+kMpUmdTgKzdSfSqOrxWhuBtZEkUne2OCa5UmqrOqVnRRzvmZkbgyL24rXtoPOE QkAVHGeOc/WuubsjkguZl5NMiaABmaVi3QHoKtSWX2bTFlUFY1I3FuSa4fa3lZnpex5Y3M52lS7S dYyqOCCxUgg1JCLbyd807iTdjYTkMDW6v03Ob1NZ5I1iErR4WIHYc4ye1ZTzJJZsXceYozk/xGs4 J21KqWRk26edfNl8c5NbVuoNo6AEFvvL3NbzvcwprVl+KHFuQ4VkzjYexqPUWP2eJVxuzkgDqeP6 VhTk3M6qkEoXILOOR5gYUEzhWOw8846n6Zrp9O8N+dbzS3QAvV/eKIGBwDXRVqunH3dzGjS9pL3t tdRJJL+DW7R3uWVlZROWQBgue/4V20oH2YXkpBjydmDjcM8/hXBiW52mup6eFbXNGXQtadqiwu1u YiyyxksWk/MjA74FdbF4inHhRdLt7UQwGZrrzokPms+NoUsDwB9M0U5ezld9RVEpx0WxpaJrtxqW oPpN1MyWznDoZEEfX7zk44GQOp/WvU/B9u0GpOLa1GqwPcFFmBzKqghV+VT8uQT3/i4ORmu2CTip o5Jrlk00fWvwv8C33iUXmnW7xGztdpkEibUlyQSrZXb975fXkcdK+sPhh8H7bxlf3CWputKs/McX U09sS0rhx8rnhsbuwwNpXr1q78vXVficzblddD6L8PfA6wjt4di6pd3SRMjPcQGKNfmBwu9cEY7r ng446DF0v4U+JvDfxLRtMtZNLtLi1kVNkAnIZdpIVmHBYKeTxkgYxyO+rOH1Z2d3uefT54Ylc/5a Hg/xXsJdBj8UabcwRS32pIj3ZmPLujs0dyi/dDjLZ4xtAOcFhX58eNlvYdfuJSkaWDFTEkyEF95w Y8HkgMSBt7fN0Nc1Wi5xSPRp1oxd3q3/AFseGa1Imn+JXk803UioWiKLy/zcKW9vT0x2zXJeIdem jgdIIYYJ2RTujQsN3905+v044rz/AGSlJRfkdntuROT/AKZ5w15q8z70ZriB42i+ZPuc4+UduSf1 qHxfoWoQJo8lvPHfcvbwwpyzSDngkAEHnGP7p9q9SS921zyVKUnzNFey3W8kFjqsyxX8kCysCuAu eik9zx+tZV/cSf2nLA0qvDGPuZwWGc4Oelcc5RbsbqEmlLuczp96RfzOyQRqF4ycc5HA/An8q0de kZL63kidZbdRn93wUxg9ff1pOH7xO2hop2pM4q8Hmap+5kMsrfNuzlce59a6u3tJ0uksr64UXG1X CoQQEY+vqKVWUY2HSjKd2UtTUxa8bdpGkRcANu+Uj3/WpbVopPNkgZXUAqqsMbT7VlVj7isdFJ+8 2+5GxuJLDIdDcgnemevcfpWfOsgs7iRpH81WDLkdMjtWMUk9DWb5lruZ+nz/AGzUXkm3SybMRxls c98H6c10iWt3Z6mxluFksnAMWW4z6H3q68+RclvQihDnl7R9Hqatnqdq5lFukcqlwrucgg+nvWPe Tb9QFrDGu5WM2GGEyOx9SRXnxTjWbbPUm4ugktddDL12zubnzLld7ZYDyh0QY7fpxXPaXF/xOlE5 wFbDoxxkdK9WFXmo6dDwqtNqunLqT6hZ2qb5lkMsYchCpzn3qVLFf7JW5hAljCnI3DcaSnLlTkEo RdRxjqUGvZ7a1VISUjB4wOTVmzv5ZNRy8YfcQvIywHvVzpx5GxU60uaKfQ2tUsPtejneMOMbSOMV 56ytBdMsmQ6E5FRhXenY0xsbVFLub1nej7AzOCxHXnrT/t0Mg3N+7IJ7VMqTcm0XTrpQSkWopA7I VIbvV7zDJuHy7lPHHWuZxaep2JpoxYrB7/VJpXm8pFY4IbkH1+lPtJ9t8Uu52njVjgYzu+td101a 2x5b5k+a+7Me9RYr+R4kZUznawzVtbmGXTyrNg/xAcce1aSV7Myi0pNMoH0NRshySDWhiCkjryae B8pbPNSVuOVcdTTiQcjNDDpqJnvSkbh6ikNDggPNWI1APSluWT+tQMu9j3NIHqU5YCcnvVFxtJBr RMxd0xnXmg9etWQHc81MkgwVkG4Hv3FA1ZmhaTJCwO9jHnnb94e9az39vJEVfdMRkxs69D71jJNs 3jJJakNnfwRW1xHdDe5OVIXg5qzBcOlzEQu8AYwOOKXLZvzNObRHT2LBbuOYNmDaSwx/Wkup2a8e JlYxBsqDgjjntXn2989VtqC8xb0m90790I1dCNwByVOOtZdpJB5YFxiY5O/K7SKauoWW6JfK6ilL ZkN28TArFlVbOACSDUEqYsF2fvH43j+6K7afM46nnVuWM7IfFEPtgxHtJXOKvw3ED3IUqQ2OG9/W lK9rjha9mdEh86MBFXvyO47msXViixbAcyDqfauelfnOuq4qmU7Em2u184c4J7jgj/61el6TJARD I/8ArJkG3KkBkwPxxWtZNmWHaOjuIba40Y4ZFjjm3ktGo3AJjGSM45rlWmuIk8pzK4UEoduAAc9C OlZ87kkrbFKMYty77m6fD2tWllE0tlLbl0CCRh0U88nPBOe/Nazvf6IbW1v0aOdwJLdyDtlTOMg/ UH8RUyjKortao1hONOaV9GaNhDI11JL9nLxNKCG8rPmA4BAIHXJB6+lfQfhbSvsniaECwu0nhiW4 C253vGowQz46Y5BBwQT71vQilK8XYwqz01P1E+E8V9rf7K9/Pb6pFe+JV1W7jlsool3u7SGQSHYM EuufcAD8PS/2dPGfxU+KXjG80mQ2vh7wPodz9ke4jjJuJvLLbkTgjlgQXPGTxk8V1RpXl7yOWVb2 MWravY/RJY2SUBGVYQuAgTofr/8AWqlqTSx26SI0ahWyWft3/KrcZtWirszXLzJs+Cviz4b8Oatr za/cNeS29tpMsVta2szmYMoc+aXYnAXdwScAFV/uivzG8W6k0cNzbzaut/OIyskEcQ5UKgxgg7eV UfL36HNdEVOrTd7L/gaFTXs58zV1/wAH9T5y1soJ7q7uWhaQMPODFsovXYMEYBOOnTPtXBWM6xrq qgtLDJtaKUwsxjZWJKhv4c5wcGvOg0qtvvOipCThr5HM3OtX+k3BmFp5eiywNDPA7b8sekq7uVIY hsAjkEdKz9H8XJaavaW2pSNNeTM6NJIxKKrKQPlzhSc44wK701JpROO7WkkQfEGNLXxJuj2RwBIh FN54l3uYkdsY+7jcFwemPXIrz7U5beXMrSNBG7APIwBPPriuGUJKvdnWnejYzlitILqaWykW+t04 UzEZ3Ac9OoxzmpLpopxbtA/lxiT94j5zICAAOO3B79665aRZxQTukzpLbQLaXSVmaOGJF4aTf95T yR781NqtgcjWJI3LmFYllSMbCc9MjvgDt3r551XKpf1R76pQhTa9Gc5dhJ7OMsFlbfgr3UGq8LG3 kEUsBjjDZQqcYOP4hXe7uFmcaSjLmQy6Z7u06KkisGkKHqOMiqhlSS9hKkea+Rhh2HPWpStEqVm7 9zVhhslk+0xKqyMM7AefQn86s34trnSioJIVgy5PGa4JSqc6b6HpU40/ZtdzE1KKa20/FuyxgEPu jb1607TNahks2ilkDyqTkMOceucVsoqpS5jncnSrcr2saIv4fs7RBvNTqu7jH0rBv7AX0KzQgwyK Tyw+8OvWlTvTnd7F1uWrBpblG3tg2nGKQiMMpJz6+tTWg2IIoCnlAcuOSTW9SV00zjow5Wpdx9/b wT6cA3DKRhvr7VHFpy2NwpLl5NoIK9aSnL2XKN0l7fm7El9duLZt7/vHUBkJ6e+PWuTubd9rTuS/ bOOtdFBKMbnLiZOUrFMlkyudpI5GaA7nI3Bfc11+ZwO60JYJblM+W+FHGTV2A3NrfKw/eu/AQkgZ NZSUbtPqdEZVLJ9jo47XarB1Bdl+f5iMn0FVfKiWdpG9M8jgCuNSbud/IuW7ILj7PJZKyMjychgh +8O1c35WZ3eMjA6gmuyF7ann1UuhaOD1phU1aM7EZGc560DIGT1oEnoOLcY70wdSeppD9Rxbjpmn qTtOOTQNakw5XB61YU/nUlIeTnNIBgls0FFaV8kgHJqo8JY5qk7ENXK7xlTzz6VD35q0ZWAmimJC hmRsg81fiu1baJgNw6MP61LWhpF2eo7zB9pDbQxzweoNWLafbKWLneei0rFJq9jp7W7Ji252H9DW g0YZGKz7CRnnmvPk1GWx6lNOpBa7FNrWc+Z5L7d+ASe/qajksZcRIZQZc9ccEVXPG+xLpztqyu1u 8F7sZt2OvHFUpyCziU9HGCGxn867qeqTPPqJ8xet8yxB/wCMAhjnoKfI6xzktgKOTnuMVDTu0Wtr sufbIYtM3ISkjKcjJ9e9VCd8YnuCcEfuh1BPelGFncqdRONkUXuHLMIy0jN8mW5PNeyadIL/AEm3 R4wfs6gM4OCqjjH4+lZ4jWC7muGd5O5oTTQvMUY+XbpERHH/AA1f0a0lvdUt7aDASXKszHK5GMt7 AA1xU+Z3O2pZJWRa8U+LUudStNIhLSIhzcSSKFYsCQMgd8H65PQYq3ba1Zah8Pn0u4Lm9gYiznVF OxWfLA5XIHzN0YYOOOtenPnj70tjgioVPdWjPqTwz8ZvDGn+CLCw1AT3d3b2a73NmuySRVzjaOF+ bkt+PfFd54I+Nscev39tf6BYXenaruSa6W1xOIOSUJUjzOAT1Uk59a1c6SSslqKOHhe8j7u0fxLF ZaLZ3/w/8G3t34PuLEzQ/YNPMSzBsEFmZsljnhhgrnncOnq2m+JLD4Z6vbabogudFayVLmP7aVaG +jlB82LKhfn3ZYLxkgnvWtBxhUSi9Vuu/f8AUlxi1bt6/wDDn1RpHxIh8X+CrbUvDMrJK0yxzLPC yiJsZYNvAyOoypPUe9cZ4outfu7c32ka/b3pi3yOySFoi4UgqOcbfmPOcjGelP6xOi5xSv0v6/1/ VjRU7qMonxl8X/GXhmT4SaVrVpCYorNp0BF9vGo3S+YjrjOdp8zcWAIwuOSQD+bd3L5mhXmLYz6p IHd7gKFWJRG2cHuM4AGPXuRjnX7umt9Xp/XmzdxUmk29Dys2T69cTNZSNGscJkuYmXJYryWU9SOT /wB8+2a4S8M0VzbW1s726ylDIoPykNySe3UGuKdOpCnzdTojOE6tlqkP06PS9ctbiyvr21mvpJHi e3ZhhBgBXVuhJPOBzXmWp6VPF4yWTX9wnjuEUW7nDSoFIDBlHT5cE16VKLjH3lqeNVjeTa6sy/Fu ove+ICwURWRbK5HzM2OT9M+nbFc7NaRzWjfvBMyxhyncjHUfStZRTdzD3k9Opjtd2ttpsJjg3ZjP zYyWJ7fTGfzqeC806KzWcNvky2U6Y6YPXp1pWRWnQhvNXmudISwglxapIWKLn5gemT3rYsfFVwNF h0abDozBcseevX+lcE6EXFrs7ndCtJTTfaxHcWcqzuse1N7gtIpyCMcUskMv9kFLibzJTxndziuS M1KCfU7J05U6jT2OdjYWGrt5txth3ZwDwR71BqF3FcXBeEGOJcbCDgmu2Kcpc3kcM7Qg49ToNFKm yMhCucYVj1A7ii+kuFuNlvExjPzEHrj1rz5Ne2fMenDm9hoRxpc3FgJDGZEYYO5sHHeueiWK312R oSG+XHDc+4rSEubmijGpBxUZyNqZI5lWIuWcrny8c4+oq0YTBarCXC7xgAscjisbtJI3STd32MaF VEhgd8yK5API3Cpl2QSpuQhGchiv861km5WMIO0ebsUtQWOGYTwyEK2SysetRtqk87b2IiUcQnbk 1tyc8U2c7qOnNpddSotyJrqR7oAzA4zj71WDcLKxgVgYu4xnFaONl6GEZc0rvqZ17Z/OXUbQB+dZ shJl+4Y1A6VrCV0Y1IcrZYtLeWSfcg3KpBO6uiltEn1aAFiCuDnOAPSsKkvf06G9KP7u7NSbEk/k JGfkwNxOM9iax9RVE0qbbODLjGzPI5rKCs0jrqaxuc9axPJMOC4B+6D171uRWYWUyKymNz8ysvIN dU3Y8+lG+5k9+uTQTnrVku/UayZB5qE5HFBIu3JPOT70xs5oC4A5brU4bB45oBdyYEk5708ZNSyx +7GcmoJJdw2g80Ar9Spk78ZqYOc4PNNoVxzFXGMVTmj+YkdKaFYrFSDk80nfNWZAfrmgZ79aAHq7 L7ircbxtgjIf0oK9dy3FcOWdcnOfWtmK/chfOXIXoc81zzgmdFOo4mtHqCeQdxL8fKM9KrS3ktxt YIMAnBrGNJKVzrliOaKiipeSFrQjcfMJBOD2qMQTT2MR4QLyGJ5NdVrK5x3lK4eSx+RD+8DYbJ/M 1OC4cGQmSPOcAjcfr6VrFaamTb2M6YStIzsxYHBxn1pZWmCqGbaygjGOlVu7ib1aRc0oyrqBkTO9 EZh8ucHFdvpOqyxzyySldo4YE4Lj1Nc1WKk2zroT5bGve+IIDbG3hCMxwEcr0+tbun6/beHNe06S eVZLSS2815EHzEEkAY5PUdwKzp4duN79TpnVSlojL0+60y38W3Oqx2C36q5IWWVhgM3Ue+O5rWh1 CD/hKry6iMiRS3B/dPGH8sN6t35zWs0502nucdO0JqVz0W2g3WVqkOWkmmPllV3Hnlsj0AAOeeBX pPgu8HhfxmuovZi+1K1t3ka0uYMRwycBCVPDDnIyMHNYYdNq0tUj0a7gp/LU+ofCX7XXjnwxrosd TjstUtpJGEJFqkbwSBQuxVGAoGcYOB6V7DoPxStvjp4wg0/xlqTeF7kzy/2W9nbxSLA3HyNgKz5C gAAnkDgnr6HLGS54q0vwMf3ajaKs36nu1lplp8MvECXmrfFefTlhvFazhsLcTSzpyQz2/mFeQTyw I61yni348pbfDOeHwxC32GK7mjmudSaJjfyuN7yNkBFBVgCoGAGC44p61WpTXy/z20IXtIJc616f 1+R8heIvF2ueJNRH2+8k1aaZ9sW1DsiLFd2T3wDjH+1njOa8Y8W30+hyWy2yy20MissogfdIwDBW zz8q7gcEf0xUayqXfT7hykktPmeWSePHtPDy6ZHGjzC4ZorkQiOSRCOjv1JBY4HTGK83udckj1BZ gEKFg8qZJ57ce3SuKtU5lZHXSgoJvuyhFpsQ8P313p8kb+ajsYd4DDAz0J9M1iynV/ED6U+rzMkF vAEQhMPtAwFJ6np39TW8q7pQfNu9jijRc5csdn1F1PS1ulFkzeUsZDLgjjjr9KxWtr+3m2QwiUIA r9SJF6Y6+lctLEpRan8jath3zqUPK5yt9asly1vIQREpBccAEnkVzd7H5FyAwOMAjHQg13xnzHnz jyfItqYWtf3bhMc5bue+KsWyQNauyrvk3bWYkZAPf8KcddGKWmo4XVzE5iDPcW6yAowXBH+NLqF7 ciHzArovZmGOvUVyOnBSsjpVabjeW5zMkhkn3O5PPetqwt7aS6SNtzoRndWk24r3TCEVOV5Gtf3C 2ULfZ3VAo2qoxWZJr160atweBzWEaMaivLc7ZVpUpcsS5Fql8NOhdwD5rEbv730rEuQ4uWZc7SQW x2P1qYQjGbsKrUnOmrnUq8FnpcNzOS4CA5PJGe1ZGo6zbz2Kpbg+bnG70H1rKlBynz+ZvUqxhT5X u0YUVxIJFLPuBOcsMkVcGqOrPH5m1AcbgM8e1dsoczPNhUcYlYSS6hKVklPkx85C8kev1rTFk720 LRoduBuUnpWU5qGhvCDqNvqQppsguTPIMDdlRu60xI1tLhyZNglORGB0GfWkp87sglS5EpMtecyx v5g2g425rEupnkuJolI2k4wO5rSmiKkmku5JYh7TUCJSWUgfKO9dZF+9heRxG7OPlGcYrKok5cxp Rb5eUy5JrzzW8lVMqnKknjFZ9xLJJdZa0Bc4L5Xg1cVEmUnazRMY3gkaURLHJkEc8Y/xq0Z5JLpk 9fmOE4z7UNp6kJOJzm7IOaAxzW5zLyHHpScNkmkFrDCh6nBqMnIOaYm+ou3gEHNSds96RSJg3y47 08EDjrUlbkckg2kZqANgE96roMhz85J5OafnJ4NMnckDcHvURLM3WkNimP5c5qs6HORVJmbRGc89 6TnueaokWkBIOQcGgZet7sKcTKGU/wAQHNPeVxgq+R6jvUW1LvobNhcwS6VPBKdk4+ZHPSqf2iVH KFirjndSjpJplv4UzStz5riWZjLgYwe/1q6Y3Zgw4DcjFKTUS4pyXmOW1lZPNztLDBPv3FJdQGBM MCXK5yD3pRqrmsVKjJQ5jOEbNCxkJc9ApPT3p80Ya3jVI8ShvnYv1rr3Ry7OxageRLb7PHnzHxvI 7jsK2bW1lRVZgPNIOCehxXLOfK7HTTg5Xk+hYlt0SaN2kG8DJXHNaS2TXMJmEikAYJI5B/8A1ms4 Vu5vUouK0ILGKaDxDHbCJ7y4dgqJFzvHfAHXiugm068tp5YWMltHc7bhYQCPlOcA9+ua6qlTkXMY Uk6jSW52drdyzW0bGbyfkPzZA7DOCOldHZXEya1HOJzLHDEUZWkB4KbW3E9c88VxQqOlC0T1JQdR ps7Pw54s/svXvtd1Y23iO68oq0dzEWDArtGQCDwMcgg8dccV2GieMtR0Dxh/b2mJbWMG5ntotjPH GzDa6jeS3c9Tz7cCtqVSLXvL/IJ0oKV1udxY+L/EjWFt4kivngkikMX9oBjJLjZjZhjuUAHHy8Y9 avf8J9Y+I/DOoaNq+hrcaldFJDcWgRPJjRtziCJV2qx4zjdnkn1rtTUld6W6/wBdP67nJdO9/wCv 6/rqZd7qot/Csv8Awj9pPI8TFHs551eZkwOGKrw42fwkcqcZFeb6/rkupvrVpdzJPcR5SxuL4RQy SM7Kr52ANsUq3bqeSOQajG7tv+H9f8MYXVv6/pHjHiPTmsNbe2u51N0IlaOWMjZI2AeBnPfr61yF 3pd1fJbvbF1XAEy9+vU+vGa82q4UJqTO2Cq1ouKNC30lLWFF89WWLCtvbb69Mn3rpbK0tJlMhu43 7Abs44/SvHq1KlWd0j1KcI0qdnv1GXlk0ERn3xXaqCG25L7TwOfx/Sq9pPos1mbeSbIzklkIIPtV WvaSRi27OG5wutaJZR391dgyToy/Kcn09+teY3QZneeVT5TH5Q/8s16FGo5bnm1oWWnUz4dj3MjF CydI0J6k9K03lW2jyiDdITvX8K9FOyPOST1InaaO0C7vMBYsAG6GrkVq8n7meRCJBlVLdR/SueT0 v1N4xbdjK1G3WC5SF237TjKt0FNt7poXZV4Vfm4/lVaTjqZv93MJri1n3yTB1mbOAOlWNLSGS4ja cK8aglgeuff2qJc0YsqLhKabFm1Eq6RPAu1HO3aeADUg8qXfGSY2dgc54I6mpcXFXRrzKUrMuzTq bRrUv8m3aSDkEVyTKMuFB4PXPUVNBNJl4vldmvQh2kYbJOKkwCpbrntXbex5i7EsAxI67zGrDrnA B9669WCWkAQ7v3Yyw7+9cNdXPUwzd9GQNNM1uxKnaWJ2+lZUdyt0ywyqS0X3fzrKmkrtG9VvRPqV 764xC0X8benasVTiUbhkdcetdkFaJ5dZpzNOC482+jdht5Ge9bDAR6dIu/b1Jbp1PWsprVI3pO92 U3lkt1tf3hI3YdyM7q1pt32Zpt+UxnceoP0qX0ZrG9nczHuWa2EvzM+cLjuM9atXIdrbzIm2uRkH pVWV0Rdu5//Z ________________________________________________________________________________
Subject: Re: Kolb list: Pitot probe
Date: Feb 05, 2011
Hi Mike, << I added my own extension>> Nice neat job. Pat ________________________________________________________________________________
Subject: Re: BRS mount on FSII?
Date: Feb 05, 2011
Is the 2nd photo a flying airplane? Looks like the universal bolt is backed out. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329720#329720 ________________________________________________________________________________
Date: Feb 05, 2011
A word of caution to those who may encounter it: (Mike, not necessarily you). ---never use teflon tape on a tapered, pipe type fitting going into a casting. I learned that painful lesson many years ago. Stick with old fashioned permatex or a similar product. BB On 5, Feb 2011, at 9:36 AM, Mike Welch wrote: > Pat, > > Cutting off the probe is not possible. I have a Dynon EFIS probe, with the > built-in AOA sensor port. It is exactly like this one; > > http://www.dynonavionics.com/images/AOA_new_unheated.jpg > > I added my own extension, to get it down low enough to not > be affected by diverted air from the nosecone. (see photo) > > Besides, I've already relocated it. > > Now, I'm on to my next fiasco!!! My brake caliper leaked yesterday when I > tried to bleed the brake system on the left one. The 1/8" NPT ports cracked > as I tried to tighten the fittings. Crap!! Plus, the discs brakes have NO identifying > marks, writing, numbers, anything. I suspect my disc brakes are from a company > no longer in business. I got the complete kit; discs, rotors, axles, bearings, wheels, etc) > I got them in trade a few years ago. Nice parts, and all, but > there is no way of knowing who the company is that made them!! > > Doesn't look like it should be too hard to duplicate the "puck holder" as they call it. > > I've got master machinist Rick G giving me pointers. > > > >cut the probe off > > >Pat > > ________________________________________________________________________________
Date: Feb 05, 2011
Good catch...not sure. It was just a picture for one currently for sale on barnstormers. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329745#329745 ________________________________________________________________________________
Subject: Kolb list: brake capliper
Date: Feb 05, 2011
Mr. Bob=2C Hmmm? You might have mentioned this earlier!! haha Yep=2C that's what I did=2C use the teflon tape. I think one thing that compounded the problem is that the "pu ck housing" was a cast unit=2C and when it was machined for the various needs like moun tig holes=2C puck recepicle=2C etc.=2C they drilled out the NPT holes too close to the edge. This only left about 1/16" of meat on the sides of the hole. I suppose this might be beefy enough if you knew when to stop cranking in the fitting=2C of if you knew that the casting was going to crack=2C you could stop=2C but unfortunately you don't know this stuff until it's too late. The squirting brake fluid i s a dead give-away!! The good news is it's a really simple part. The original piece is a cast unit=2C but carving a new one out of solid aluminum ought to be fairly easy. Since the puck si mply presses on the back of flat brake pad=2C if it's off by a 1/16" in any direction=2C it isn't going to hurt a thing. Plus=2C when I duplicate the part=2C I'm going to be sure and give the NP T holes some extra edge distance....more like 3/16" minimum. Plus=2C next time=2C I'll find my container of pipe thread sealer=2C too! ! Mike W From: slyck(at)frontiernet.net Subject: Re: Kolb-List: Kolb list: Pitot probe Date: Sat=2C 5 Feb 2011 13:18:11 -0500 A word of caution to those who may encounter it: (Mike=2C not necessarily y ou). ---never use teflon tape on a tapered=2C pipe type fitting going into a casting. I learned that painful lesson many years ago. Stick with old fashioned permatex or a similar product. BB On 5=2C Feb 2011=2C at 9:36 AM=2C Mike Welch wrote: Pat=2C Cutting off the probe is not possible. I have a Dynon EFIS probe=2C with the built-in AOA sensor port. It is exactly like this one=3B http://www.dynonavionics.com/images/AOA_new_unheated.jpg I added my own extension=2C to get it down low enough to not be affected by diverted air from the nosecone. (see photo) Besides=2C I've already relocated it. Now=2C I'm on to my next fiasco!!! My brake caliper leaked yesterday whe n I tried to bleed the brake system on the left one. The 1/8" NPT ports cracke d as I tried to tighten the fittings. Crap!! Plus=2C the discs brakes hav e NO identifying marks=2C writing=2C numbers=2C anything. I suspect my disc brakes are from a company no longer in business. I got the complete kit=3B discs=2C rotors=2C axles =2C bearings=2C wheels=2C etc) I got them in trade a few years ago. Nice parts=2C and all=2C but there is no way of knowing who the company is that made them!! Doesn't look like it should be too hard to duplicate the "puck holder" as they call it. I've got master machinist Rick G giving me pointers. >cut the probe off >Pat ________________________________________________________________________________
Date: Feb 05, 2011
The plane is listed is for sale on Barnstormers. At that price it seems like a pretty good deal. It is a five rib original Firestar however, with a Rotax 503. I've seen the plane when owned by 2 previous owners. It was an immaculate Firestar. Unfortunately according to the add, it doesn't seem like the present owner will be flying it. Kolb Firestar KOLB FIRESTAR - $6,000 - AVAILABLE FOR SALE - N-93396 1050 HRS, 503 Rotax 290 HRS, New 2 Blade Prop, New Aircraft Tires, Alt, Airspeed, CHT, EGT, New Garmin 196 GPS, New David Clark Headset, Icom A-22 Radio, Eelectric Start, BRS, Hydraulic Disc Brakes, Streamline Wing Struts, Spare Nose Cone, Spare Tundra Tires, Spare Wing Struts, Completely Enclosed, Always Hangared, Patch On Right Wing, Aircraft in very good condition, Recent broken back has left me paralyzed below the waist and unable to fly it. Located in Orange, VA. 22960 Contact Mike French 540-219-6157 - Contact Michael W. French, Owner - located Orange, VA USA - Telephone: 540-219-6157 . - Fax: 540-672-5065 - Posted February 2, 2011 - Show all Ads posted by this Advertiser - Recommend This Ad to a Friend - Email Advertiser - Save to Watchlist - Report This Ad - View Larger Pictures - Finance Gene Z On Feb 5, 2011, at 11:30 AM, Ducati SS wrote: > > Is the 2nd photo a flying airplane? Looks like the universal bolt is backed out. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329720#329720 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Kolb list: brake capliper
Date: Feb 05, 2011
Stick with old fashioned permatex or a similar product. BB BB/Gang: I have been using Aviation Permatex No. 2 since my Model A Ford days in the mid-1950's. Probably same formula. Sure has the same look and smell as it did back then, 55 years ago. Had to run downstairs and check - Permatex Form-A-Gasket Part No. 2B, in a tube. I also have a 16 oz container of Aviation For-A-Gasket Sealant Liqauid Part No. 3B. I intend to use the 3B to put a 1936 John Deere D radiator and engine back together. Probably take the whole 16 oz. The engine is a 520 cu in two cylinder. That's 260 cubes a cylinder. High idle and max power is obtained at 900 rpm. Yes, it is hand start. Only thing electric on it is the spark the magneto generates. Sorry. Got carried away. Easy to do with something you love. I also use Permatex on my airplane and 912ULS. john h - Wishing for Spring. mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 05, 2011
I've seen the plane when owned by 2 previous owners. It was an immaculate Firestar. Gene Z Gene Z/Gang: Boy! That brings back some memories. In 1986, I was still building my FS. Drove down to Lakeland for Sun and Fun 1986. I was drooling on Homer's FS, the 1985 Oshkosh Grand Champion Ultralight. Homer asked me if I wanted to fly it. Told him I only had 385 hours in my US before I destroyed it, and that I had never flown a FS. He said, "Get in John. You won't have any problem with it." Homer was right. It was an easy, beautiful little airplane to fly in all the UL traffic at Lakeland, for the first time. That flight gave me a lot of incentive to head back to Alabama and complete my little bird. What is unique about this FS is the factory design and colors of the paint job. We had some fun, fun days back then. john h mkIII titus, alabama ________________________________________________________________________________
Date: Feb 05, 2011
Subject: Re: bad news good news
My injuries were almost identicle I hope he can walk I can with two quad canes but cant stand up without somthing to holds on to .I have very little income but I will give what I can .Please post wherewe can donate Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly ----- Original Message ---- From: Jimmy Young <jdy100(at)comcast.net> Sent: Sat, February 5, 2011 6:32:01 AM Subject: Kolb-List: Re: bad news good news "He's in worse shape than I had heard. Both legs, pelvis, 7 ribs and some vertebrae. No health insurance either. Friends are asking for donations. " KT, If you can, find out where one could send a donation to help Ron out. -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329697#329697 ________________________________________________________________________________
Date: Feb 05, 2011
AHA! gotcha!. the offishall Kolb PC police hereby declare that post not entirely true to our bylaws. well, sure I gotta backtrack a little, as I was the instigator. Truth is that old permatex, in spite of it being made of mostly pine resins and alcohol, has never failed me. Low tech. BB, geothermal heat pump compressor crapped out early this morning. Space heater time. good thing the refrigeration supply was open. Getting a little old for this kind of thing. ouch, my achin' back MkIII, covered with sawdust On 5, Feb 2011, at 2:38 PM, John Hauck wrote: > > > Stick with old fashioned permatex or a similar product. > BB > > > BB/Gang: > > I have been using Aviation Permatex No. 2 since my Model A Ford days in the > mid-1950's. Probably same formula. Sure has the same look and smell as it > did back then, 55 years ago. > > Had to run downstairs and check - Permatex Form-A-Gasket Part No. 2B, in a > tube. I also have a 16 oz container of Aviation For-A-Gasket Sealant > Liqauid Part No. 3B. I intend to use the 3B to put a 1936 John Deere D > radiator and engine back together. Probably take the whole 16 oz. The > engine is a 520 cu in two cylinder. That's 260 cubes a cylinder. High idle > and max power is obtained at 900 rpm. Yes, it is hand start. Only thing > electric on it is the spark the magneto generates. Sorry. Got carried > away. Easy to do with something you love. > > I also use Permatex on my airplane and 912ULS. > > john h - Wishing for Spring. > mkIII > Titus, Alabama > > > > > > ________________________________________________________________________________
Date: Feb 05, 2011
Truth is that old permatex, in spite of it being made of mostly pine resins and alcohol, has never failed me. Low tech. BB BB/Kolbers: As the matter of fact, the cleanup method for permatex is 188 proof denatured alcohol. I know it is difficult to get it off your hands. Usually wears off eventually. Of course, I have never tried to use 188 proof denatured alcohol. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 05, 2011
Subject: Re Kolb list: Caliper
Most folks will over torque a AN3 bolt, and often a AN4. A warning given me our AP&I. We checked a few practice ones with after tightening with a torque and he was right. Biggest problem are AN3's. jerb At 08:36 AM 2/5/2011, you wrote: >Pat, > > Cutting off the probe is not possible. I have a Dynon EFIS probe, with the >built-in AOA sensor port. It is exactly like this one; > > > Now, I'm on to my next fiasco!!! My brake caliper leaked yesterday when I >tried to bleed the brake system on the left one. The 1/8" NPT ports cracked >as I tried to tighten the fittings. Crap!! Plus, the discs >brakes have NO identifying >marks, writing, numbers, anything. I suspect my disc brakes are >from a company >no longer in business. I got the complete kit; discs, rotors, >axles, bearings, wheels, etc) >I got them in trade a few years ago. Nice parts, and all, but >there is no way of knowing who the company is that made them!! > > Doesn't look like it should be too hard to duplicate the "puck > holder" as they call it. > > I've got master machinist Rick G giving me pointers. > > > >cut the probe off > > >Pat > > ________________________________________________________________________________
Subject: New Kolb mechanic
From: "cristalclear13" <cristalclearwaters(at)gmail.com>
Date: Feb 05, 2011
My daughter helping me put my carbs back on my Rotax 503. Maybe I'll have everything ready to fly again by end of February...that's my goal anyways. -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Sept 2007 Private Pilot Aug 2008 ELSA Repairman for N193Y April 2008 Rotax 2 stroke maintenance April 2009 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329799#329799 Attachments: http://forums.matronics.com//files/imag0034_754.jpg http://forums.matronics.com//files/imag0033_335.jpg ________________________________________________________________________________
Subject: Re: New Kolb mechanic
Date: Feb 05, 2011
My daughter helping me put my carbs back on my Rotax 503. Maybe I'll have everything ready to fly again by end of February...that's my goal anyways. -------- Cristal Waters Looks like she has airplane in her blood, Kolb airplane. ;-) john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 05, 2011
My daughter helping me put my carbs back on my Rotax 503. Maybe I'll have everything ready to fly again by end of February...that's my goal anyways. -------- Cristal Waters Nice picture, good looking daughter....thanks for posting I and my wife enjoyed it....Jim Swan Do not archive FIRESTAR ll 503 Michigan jswan GPS FOR MY RUNWAY N 42 deg 28.581 W084deg 44.825 ph. 517-663-8488 ________________________________________________________________________________
Date: Feb 05, 2011
Subject: Use of gasket punches - non-Kolb related
NOT KOLB RELATED - HELP - LOOKING FOR SUGGESTIONS Email me direct if you do not want to post to the group. Actually the answer make be useful to others punching out gaskets, etc. I ordered some gasket punches off eBay. I tried the 3/4" one on a paper plate stamping it against a 2x4. It wasn't totally cutting through the paper plate all the way around and I was hitting it pretty good. I also tried a nicer ($$) set of punches I have, not much difference. Instead punching against a 2x4, do I need to punch it on a harder wood surface or a soft piece of material like a 1/16" - 1/8" thick sheet of rubber. What I will be punching out 3/4" dia circles of the suit symbol of playing cards. Will glue them into a wood block with slightly larger counter sunk holes. The block is used to indicate what is trump. They work great, hard part is punching out the circles where they are clean cut all the way through. Suggestions welcome. Thanks jerryb ________________________________________________________________________________
Subject: Re: Use of gasket punches - non-Kolb related
Date: Feb 06, 2011
Do not puch it against the grain on your 2x4 or the smooth side. Instead punch it on the end ,you know the bit the saw went through, The punch is going the same way as the grain this way. Will cut much better Downunder MK111c Sweltring in 40deg c today. Too windy to fly ________________________________________________________________________________
Date: Feb 06, 2011
Subject: club planes?
We had an interesting- discussion on linkedin this-weekend.-All about -flight =0Ainstruction and the idea of turning an experimental into a clu b plane so an =0Ainstructor could legally-use it to-teach-the owners - to fly.-- This theory is =0Aviable and there is-FAA approval to d o this.- =0A=0AWhat-I think would really jump start the process is a pr e-developed general =0Aformat.--One that would be easy for-people to follow- in developing their =0Aown-club and fractional ownership;-- not much different than the downloads a =0Aperson can buy to write their ow n will or start a non profit 401c3 corporation. =0AThese always contain sev eral disclaimers and liability waivers just like the =0Aones we used in the old days to teach ultralight flying.- =0A=0AThis would help the ultralig ht pilot and sport pilot want-to-be, as well as the =0Ainstructor. =0A=0ATh e idea of teaching someone to fly in a $14,000 plane with a 582 is not that =0Afar fetched. We all know people that-have.- It seemes like a better option than =0Athe $60,000 to $100,000 planes everyone thinks they current ly need .-When =0Aa-student-becomes a licensed pilot-they can trans ition up.- =0A=0AWhat this sport needs now is for people to stop focusing on the problem and =0Adevelope a solution.- The ultralight trainer was s o successful that it was =0Aturned into a sport pilot plane; and that took 20 years.----Even a 2 place Kolb =0Aclassic could qualify.=0A-Mal colm Brubaker =0AMichigan Sport=0APilot Repair =0ALSRM-A, PPC, WS=0A(989)51 3-3022 =0A=0A=0A=0A=0A________________________________=0AFrom: Pat Ladd <pj .ladd(at)btinternet.com>=0ATo: kolb-list(at)matronics.com=0ASent: Sat, February 5 , 2011 10:45:06 AM=0ASubject: Re: Kolb-List: Kolb list: Pitot probe=0A=0A =0AHi Mike,=0A<<-I added my own extension>>=0A=0ANice neat job.=0A-=0AP ============== =0A=0A=0A=0A ________________________________________________________________________________
Date: Feb 06, 2011
stamping it against a 2x4. > It wasn't totally cutting through the paper plate all the way around > and I was hitting it pretty good. > Thanks > jerryb Jerry=2C I made a few gaskets in my time=2C and what you are trying to do isn't much different. IMO=2C you are trying to use too soft of a backup surface to cut against. If it were me=2C I'd get a small piece of 1/8" thick aluminum sheet. (maybe 6" X 6" X 1/8") Next=2C I'd get something like a bigger piece of steel plate=2C or any in credibly non-deforming solid surface. Use a couple of strips of duct tape to secur e the aluminum sheet in place=2C centered on your steel surface. Then=2C stamp out your designs. The aluminum shouldn't hurt the stamp=2C unless of course=2C we're talking about Harbor Freight stuff. Mike Welch ________________________________________________________________________________
Date: Feb 06, 2011
Subject: Re: club planes?
Had a discussion like awhile ago also on Oshkosh365, I think it was. Unfortunately the Oshkosh365 forum software is so bad participating there is a painful ordeal. I think it's a viable approach. I'd be pursuing it if there was a field near here suitable for instruction. -Dana At 08:49 AM 2/6/2011, Malcolm Brubaker wrote: >We had an interesting discussion on linkedin this weekend. All about >flight instruction and the idea of turning an experimental into a club >plane so an instructor could legally use it to teach the owners to >fly. This theory is viable and there is FAA approval to do this. >What I think would really jump start the process is a pre-developed >general format. One that would be easy for people to follow in >developing their own club and fractional ownership; not much different >than the downloads a person can buy to write their own will or start a non >profit 401c3 corporation. These always contain several disclaimers and >liability waivers just like the ones we used in the old days to teach >ultralight flying. >This would help the ultralight pilot and sport pilot want-to-be, as well >as the instructor. >The idea of teaching someone to fly in a $14,000 plane with a 582 is not >that far fetched. We all know people that have. It seemes like a better >option than the $60,000 to $100,000 planes everyone thinks they currently >need . When a student becomes a licensed pilot they can transition up. >What this sport needs now is for people to stop focusing on the problem >and develope a solution. The ultralight trainer was so successful that it >was turned into a sport pilot plane; and that took 20 years. Even a 2 >place Kolb classic could qualify. > >Malcolm Brubaker >Michigan Sport >Pilot Repair >LSRM-A, PPC, WS >(989)513-3022 > > >From: Pat Ladd <pj.ladd(at)btinternet.com> >To: kolb-list(at)matronics.com >Sent: Sat, February 5, 2011 10:45:06 AM >Subject: Re: Kolb-List: Kolb list: Pitot probe > >Hi Mike, ><< I added my own extension>> > >Nice neat job. > >Pat > > > ><http://www.matronics.com/Navigator?Kolb-List>http://www.matronics.com/Navigator?Kolb-List ><http://www.matronics.com/contribution>http://www.matronics.com/contribution > -- The gene pool could use a little chlorine. ________________________________________________________________________________
Date: Feb 06, 2011
Matco (brake company) recommends and uses Loctite 567. It is specifically for tapered threads for your application. I have used it for years on all my tapered threads and have never had a leak. http://www.rshughes.com/products/079340_56707.html -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329853#329853 ________________________________________________________________________________
Date: Feb 06, 2011
Well that's a good idea. Could certainly use it (My M3X) here in KFHU, it may even motivate me more to finish my project faster, which is 90% complete with 100% left to do kinda thing. However ignoring the FAA in this equation is pretty much kicking the can down the road. I think in terms of movement there has to be a wide ranging recognition the the FAA is the problem in general aviation. Fearing the FAA or thinking in terms of compliance with FAA all the time as we do now is strangling aviation. If there is no concerted effort to truncate their pervasive intrusion into aviation; the contraction will continue. I think I mentioned before that I almost never see young kids around taking flying lessons anymore. Its not because aviation has stopped firing up the imagination of the younger generation, its because the fun the freedom and the joy have been stomped out of flying by the FAA to an alarming degree. By all rights the Kolb factory should be busy and backlogged for orders, yet it is not happening. So the idea of a club to circumvent FAA rules is a valid and good, but it will not reverse the difficulty of being an aircraft owner aviator. The future is as it has always been in people owning their aircraft and plying the skies in freedom. I have yet to see an organization come about that makes it as its prime objective to restore freedom to aviate, by going after the source of the constraints. That is what we need most of all right now. ---- Malcolm Brubaker wrote: ============ We had an interesting discussion on linkedin thisweekend.All aboutflight instruction and the idea of turning an experimental into a club plane so an instructor could legallyuse it toteachthe owners to fly. This theory is viable and there isFAA approval to do this. WhatI think would really jump start the process is a pre-developed general format.One that would be easy forpeople to follow in developing their ownclub and fractional ownership;not much different than the downloads a person can buy to write their own will or start a non profit 401c3 corporation. These always contain several disclaimers and liability waivers just like the ones we used in the old days to teach ultralight flying. This would help the ultralight pilot and sport pilot want-to-be, as well as the instructor. The idea of teaching someone to fly in a $14,000 plane with a 582 is not that far fetched. We all know people thathave. It seemes like a better option than the $60,000 to $100,000 planes everyone thinks they currently need .When astudentbecomes a licensed pilotthey can transition up. What this sport needs now is for people to stop focusing on the problem and develope a solution. The ultralight trainer was so successful that it was turned into a sport pilot plane; and that took 20 years.Even a 2 place Kolb classic could qualify. Malcolm Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS (989)513-3022 ________________________________ From: Pat Ladd <pj.ladd(at)btinternet.com> Sent: Sat, February 5, 2011 10:45:06 AM Subject: Re: Kolb-List: Kolb list: Pitot probe Hi Mike, <> Nice neat job. P============== -- kugelair.com ________________________________________________________________________________
Date: Feb 07, 2011
When our group of three owned a Rans S6 Exp A/B and I had an active instructor's certificate, I considered this. I spoke to our insurance agent about it and learned the following. - Every member in the group must have an equity stake in the organization. Some "significant" equity at risk is required but need not be equal for all members. - The group instructor does not have to be a member. - Our insurance limited the total membership to 5 (at one time). Over that and the insurance policy would have to be for a commercial operation which would make the premiums on the order of 3 times as high. - Do not use the term "CLUB" because this implies (to insurance folks) a non-equity membership organization. - Students would have to pay an extra insurance premium until they received their full certificate (sport or private). So, this idea is viable and the aircraft insurable for small groups, but not for large clubs. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329942#329942 ________________________________________________________________________________
Date: Feb 07, 2011
At 08:05 AM 2/7/2011, Thom Riddle wrote: > >When our group of three owned a Rans S6 Exp A/B and I had an active >instructor's certificate, I considered this. I spoke to our insurance >agent about it... That addresses the insurance aspects and is useful information, but doesn't address the FAA (paid instruction in an experimental) aspect... although a similar logic _might_ apply. -Dana -- 2000 mockingbirds = two kilomockingbirds ________________________________________________________________________________
From: "Kolb Aircraft" <customersupport(at)tnkolbaircraft.com>
Subject: Re: Christmas Came Today
Date: Feb 07, 2011
You are very welcome Rick. Travis Kolb CO. ----- Original Message ----- From: "Rick Lewis" <cktman(at)hughes.net> Sent: Friday, February 04, 2011 6:50 PM Subject: Kolb-List: Christmas Came Today > > Today I received my long awaited plans for my MKIII xtra. I bought the > plane over three years ago and have been using a set of plans that were > for another type and a lot of things simply didn't make sense so there > were a lot of calls to Brian. He is a great guy to talk to and was always > able to answer any questions I had. The first set of plans were given to > me by Donnie and I was told to use them until they had the xtra plans > re-done. Brian bought the Kolb company and one of his first projects was > to make a good set of plans for the MKIII xtra. > > I have looked over these new plans and they are outstanding. They > came with over 600 pictures on cd and a notebook of detailed text and > drawings. I now also have the blueprints others have talked about. Brian > has done a wonderful job on these. They are some of the best set of > plans I have ever seen. I know this was a lot of work, he obviously took > great care in making them. > > Thank you Brian, Travis, and Dennis. :D > > -------- > Rick Lewis > > (VW Watercooled Engine) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329666#329666 > > > ________________________________________________________________________________
Date: Feb 07, 2011
Dana, The FAA regs allow instruction in any experimental aircraft which is owned by the person receiving the instruction. My FSDO said that partial ownership or indirect ownership (share holder in a corporation that owns the aircraft) qualifies as long as there is an equity position in the aircraft. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329948#329948 ________________________________________________________________________________
Date: Feb 07, 2011
> The FAA regs allow instruction in any experimental aircraft which is owne d by the person receiving the instruction. > -------- > Thom Riddle Thom=2C & knowledgeable 'regs' guys=2C Your statement above is excellent information=2C but what about the situa tion where a plane is just given it's airworthiness certificate? I get the impression what you said is fine for a fully built=2C previous flown airplane=2C but what about a brand new one? Once a plane is finally finished=2C aren't you supposed to fly off a cert ain number of hours before someone can be in the plane also? How does that work? I never have clearly understood how this part works. After rereading your statement=2C I think I'm getting more confused. If a person had a CFI teach him to fly=2C OF COURSE he could be taught in ANY (legal) a irplane. My question is=3B How can a guy learn to fly his brand new=2C never flow n=2C just licenced=2C experimental airplane? Can he have an instructor go with him o n his maiden flight? Does anyone know how this works?? We've had a few recent incidents where lowtime Kolb pilots bent their pla nes (and themselves). What does the FAA regs say to address this problem? Thanks. Mike Welch MkIII ________________________________________________________________________________
Date: Feb 07, 2011
Mike, You are correct. The phase one flying must be complete for more than required crew to be aboard. The builder of an experimental aircraft who is not already a certificated pilot must learn to fly like the rest of us, in another airplane that is legal for instruction. In the case of experimental aircraft that means one that is in phase 2 testing and owned, at least partially, by the wannabe pilot. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329956#329956 ________________________________________________________________________________
Date: Feb 07, 2011
Mike, You cannot take anyone along for any reason during phase 1 testing, UNLESS, you can show that that person is essential for some aspect of your test program and would have to be cleared by the FSDO that sets your test area and phase 1 testing requirements. Teaching you to fly your aircraft is not part of a test program of the aircraft. Your best bet is to get someone else, who has the experience, to do your initial test flights. Rick Girard On Mon, Feb 7, 2011 at 8:27 AM, Mike Welch wrote: > > The FAA regs allow instruction in any experimental aircraft which is > owned by the person receiving the instruction. > -------- > > Thom Riddle > > Thom, & knowledgeable 'regs' guys, > > Your statement above is excellent information, but what about the > situation > where a plane is just given it's airworthiness certificate? > I get the impression what you said is fine for a fully built, previous > flown > airplane, but what about a brand new one? > Once a plane is finally finished, aren't you supposed to fly off a > certain > number of hours before someone can be in the plane also? > How does that work? I never have clearly understood how this part works. > > After rereading your statement, I think I'm getting more confused. If a > person > had a CFI teach him to fly, OF COURSE he could be taught in ANY (legal) > airplane. > > My question is; How can a guy learn to fly his brand new, never flown, > just > licenced, experimental airplane? Can he have an instructor go with him on > his > maiden flight? Does anyone know how this works?? > > We've had a few recent incidents where lowtime Kolb pilots bent their > planes > (and themselves). What does the FAA regs say to address this problem? > > Thanks. > Mike Welch > MkIII > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Feb 07, 2011
- good advice. And be sure his experience isn't limited to the Cessna 150/cherokee varieties. That is how I came to buy a "slightly" damaged cage assembly for my hybrid MkIII. Some assembly was required. BB On 7, Feb 2011, at 10:57 AM, Richard Girard wrote: > Mike, You cannot take anyone along for any reason during phase 1 testing, UNLESS, you can show that that person is essential for some aspect of your test program and would have to be cleared by the FSDO that sets your test area and phase 1 testing requirements. Teaching you to fly your aircraft is not part of a test program of the aircraft. Your best bet is to get someone else, who has the experience, to do your initial test flights. > > Rick Girard > > On Mon, Feb 7, 2011 at 8:27 AM, Mike Welch wrote: > > The FAA regs allow instruction in any experimental aircraft which is owned by the person receiving the instruction. > -------- > > Thom Riddle > > Thom, & knowledgeable 'regs' guys, > > Your statement above is excellent information, but what about the situation > where a plane is just given it's airworthiness certificate? > I get the impression what you said is fine for a fully built, previous flown > airplane, but what about a brand new one? > Once a plane is finally finished, aren't you supposed to fly off a certain > number of hours before someone can be in the plane also? > How does that work? I never have clearly understood how this part works. > > After rereading your statement, I think I'm getting more confused. If a person > had a CFI teach him to fly, OF COURSE he could be taught in ANY (legal) airplane. > > My question is; How can a guy learn to fly his brand new, never flown, just > licenced, experimental airplane? Can he have an instructor go with him on his > maiden flight? Does anyone know how this works?? > > We've had a few recent incidents where lowtime Kolb pilots bent their planes > (and themselves). What does the FAA regs say to address this problem? > > Thanks. > Mike Welch > MkIII > > > > get="_blank">http://www.matronics.com/Navigator?Kolb-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhappy. > - Groucho Marx > > > > > ________________________________________________________________________________
Date: Feb 07, 2011
Contact me via e-mail and I'll give address. Thanks! KT Mark III NC ktony20(at)hotmail.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329998#329998 ________________________________________________________________________________
Date: Feb 07, 2011
Hi Rick=2C Thanks for the clarification. This is a confirmation of what I have alw ays understood. Mike Welch >Mike=2C You cannot take anyone along for any reason during phase 1 testing =2C UNLESS=2C you can show that that person is essential for some >aspect o f your test program and would have to be cleared by the FSDO that sets your test area and phase 1 testing requirements. >Teaching you to fly your airc raft is not part of a test program of the aircraft. Your best bet is to get someone else=2C who has the >experience=2C to do your initial test flights . >Rick Girard ________________________________________________________________________________
Date: Feb 07, 2011
We have established the need. We have proven viability. We even have an apparent precedent. So, what next? An easy to follow format with all the "legal" jargon included for the average "layman" CFI or old BFI properly providing for that "equity position". Could such a "position" be covered by something so simple as a "damage deposit" on the aircraft?? Malcolm Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS (989)513-3022 ________________________________ From: Mike Welch <mdnanwelch7(at)hotmail.com> Sent: Mon, February 7, 2011 9:27:30 AM Subject: RE: Kolb-List: Re: club planes? > The FAA regs allow instruction in any experimental aircraft which is owned by the person receiving the instruction. > -------- > Thom Riddle Thom, & knowledgeable 'regs' guys, Your statement above is excellent information, but what about the situation where a plane is just given it's airworthiness certificate? I get the impression what you said is fine for a fully built, previous flown airplane, but what about a brand new one? Once a plane is finally finished, aren't you supposed to fly off a certain number of hours before someone can be in the plane also? How does that work? I never have clearly understood how this part works. After rereading your statement, I think I'm getting more confused. If a person had a CFI teach him to fly, OF COURSE he could be taught in ANY (legal) airplane. My question is; How can a guy learn to fly his brand new, never flown, just licenced, experimental airplane? Can he have an instructor go with him on his maiden flight? Does anyone know how this works?? We've had a few recent incidents where lowtime Kolb pilots bent their planes (and themselves). What does the FAA regs say to address this problem? Thanks. Mike Welch MkIII ________________________________________________________________________________
Date: Feb 07, 2011
At 09:27 AM 2/7/2011, Mike Welch wrote: > Your statement above is excellent information, but what about the situation >where a plane is just given it's airworthiness certificate? > I get the impression what you said is fine for a fully built, previous > flown >airplane, but what about a brand new one? > Once a plane is finally finished, aren't you supposed to fly off a certain >number of hours before someone can be in the plane also? As others have said, the aircraft must be flown solo during the initial testing. I believe, however, than an instructor can sign a student off for solo in an aircraft still in Phase 1 testing... but of course the student would have to have prior instruction in something else, and the instructor confident in the student's ability to handle anything that might arise. -Dana -- The Definition of an Upgrade: Take old bugs out, put new ones in. ________________________________________________________________________________
Date: Feb 07, 2011
At 05:19 PM 2/7/2011, Malcolm Brubaker wrote: >We have established the need. We have proven viability. We even have an >apparent precedent. So, what next? >An easy to follow format with all the "legal" jargon included for the >average "layman" CFI or old BFI properly providing for that "equity >position". Could such a "position" be covered by something so simple as a >"damage deposit" on the aircraft?? You could pitch it to the prospective student as a "damage deposit". However, I think it would have to be, in writing, a purchase of a "share" of the corporation owning the aircraft. -Dana -- Come to think of it, there already are a million monkeys at a million typewriters, and the Internet is _NOTHING_ like Shakespeare! ________________________________________________________________________________
Date: Feb 07, 2011
>As others have said=2C the aircraft must be flown solo during the initial testing. I believe=2C however=2C than an instructor can sign a student >of f for solo in an aircraft still in Phase 1 testing... but of course the stu dent would have to have prior instruction in something else=2C and >the ins tructor confident in the student's ability to handle anything that might ar ise. >Dana Dana=2C In a private conversation=2C Thom Riddle and I came to the opinion that a student pilot can NOT fly an experimental airplane in 'phase 1' testing. For clarification's sake=2C could someone look this up? Thanks=2C Mike W ________________________________________________________________________________
Date: Feb 07, 2011
At 06:47 PM 2/7/2011, Mike Welch wrote: > > In a private conversation, Thom Riddle and I came to the opinion >that a student pilot can NOT fly an experimental airplane in 'phase 1' >testing. > > For clarification's sake, could someone look this up? It may depend on the operating limitations which are, I believe, at the discretion of the FAA inspector or DAR. Back in the Bensen Gyrocopter days (pre 103), it was permissible for a helicopter CFI to sign a student off for solo in their brand new never flown single seat homebuilt gyro (since there were no 2-seat gyros and no gyro CFIs). I don't know what the deal is nowadays. -Dana -- Giving money and power to government is like giving whiskey and car keys to teenage boys. ________________________________________________________________________________
Date: Feb 07, 2011
Date: Feb 07, 2011
For clarification's sake, could someone look this up? Thanks, Mike W Q: I've just finished building my Pietenpol, which is an experimental amateur-built aircraft that meets the LSA definition. I'm ready to begin the phase-one flight testing. I'm a student pilot working toward my sport pilot certificate and I don't hold a current medical. Is it legal for me to do the flight testing as a student pilot? Can a student pilot fly an experimental aircraft at all? A: Let's take the second part of your question first. There is no regulatory prohibition on a student pilot (sport pilot or otherwise) flying an experimental aircraft. Pilot requirements, privileges, and limitations are found in 14 CFR Part 61, and student pilot privileges and limitations are specifically found in subpart C. There is no specific limitation in that section prohibiting a student pilot from flying an aircraft with an experimental airworthiness certificate. Now let's look at the first part of your question regarding a student pilot (sport pilot or otherwise) flying an experimental aircraft during flight testing. Certification requirements for the pilot in command of an experimental aircraft are not found in the FAA regulations themselves but rather in the operating limitations of the individual aircraft. These operating limitations are issued by the FAA as a part of the aircraft's airworthiness certificate and will vary depending on exactly what type of airworthiness certificate the aircraft holds. For an amateur-built aircraft such as your Pietenpol, the operating limitations will contain the following statement: "The pilot in command of this aircraft must hold a pilot certificate or an authorized instructor's logbook endorsement. The pilot in command must meet the requirements of 61.31(e), (f), (g), (h), (i), and (j) as appropriate." Note that the pilot may hold a pilot certificate (which would include sport pilot) or an authorized instructor's endorsement. This would open the door for a properly endorsed student pilot (including a sport pilot student) to fly the aircraft. The limitation makes no distinction between phase-one flight testing and phase-two normal operations. This limitation is in place for all operations. The limitation does go on to require any appropriate endorsements called out by 14 CFR 61.31(e) though (j). The most common of these endorsements are for tailwheel aircraft, high-performance aircraft, and complex aircraft. The only endorsement applicable to the Pietenpol would be the tailwheel endorsement, so the instructor would have to endorse the student appropriately before allowing him or her to solo a tailwheel aircraft as well as give the standard solo endorsement in order to be in compliance with this operating limitation. Remember that, if the student seeks to solo an aircraft that does not meet the definition of a light-sport aircraft he/she would also need to hold a 3rd class FAA medical certificate. This would be the case whether the aircraft holds a standard or special (such as experimental) airworthiness certificate. The question you did not ask, but one I will answer anyway, is whether it is smart for a student pilot to perform the flight testing on an experimental aircraft. This is the most important question, and the answer is, no, it is not a good idea for a student pilot to perform flight testing on a new amateur-built aircraft. The purpose of flight testing is to verify the aircraft's handling characteristics and make sure it does not have any issues that would affect the safety of flight. Flight testing a new aircraft should be left to experienced pilots who are familiar with the normal handling characteristics of the aircraft being tested and are prepared to handle possible emergency situations that might arise. A student pilot does not have the background and experience to identify abnormal handling characteristics and may not be prepared to handle an emergency situation if one should present itself. So while it may be technically legal for a student pilot (sport pilot or otherwise) to fly an aircraft during the initial flight-test period, I strongly discourage this. Find an appropriate test pilot to perform the flight tests on the aircraft, then find a qualified instructor to check you out in the aircraft after it has been tested. ________________________________________________________________________________
Date: Feb 07, 2011
Ok. Perhaps a student pilot working toward sport pilot can legally fly an Exp a/b aircraft during phase 1 with proper endorsements. But, 61.87 states clearly that solo endorsements must be for a particular make and model aircraft. So the solo training and endorsement for the student pilot working toward sport pilot certificate to fly his Pietenpol must get that solo training and endorsement in a Pietenpol, not some other type of tail dragger. Since a phase 1 test flights in a Pietepol must be done solo, this student pilot must get his solo training for a Pietenpol in another Pietenpol which is not in phase 1 test phase. If he does not own the other Pietenpol then the instructor can not charge for his instruction in that airplane, since it is an experimental aircraft. So as a practical matter, it will be somewhat difficult to make happen, not impossible though. But definitely not wise for an inexperienced student pilot to be doing any testing of any newly built experimental aircraft. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330078#330078 ________________________________________________________________________________
Subject: Firestar Crash
Date: Feb 07, 2011
Kolbers: Bill Belcher of Brent, AL, crashed his FS into the trees near West Blocton, AL. He is in serious condition. It happened about 1730 yesterday. That's all I know of the accident. Bill flew out of Centerville Airport, a few miles from his home. I met him by chance when I landed at Centerville on the way to Tuscaloosa, Alabama, a few years ago. http://www.faa.gov/data_research/accident_incident/preliminary_data/media/A_0207_N.txt Then scroll down to accident number 9. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: Firestar Crash
Date: Feb 07, 2011
Terrible news. Hope he pulls through Thanks, Daniel Myers Cell: 407 920 7700 On Feb 7, 2011, at 10:04 PM, "John Hauck" wrote: > > Kolbers: > > Bill Belcher of Brent, AL, crashed his FS into the trees near West Blocton, > AL. He is in serious condition. It happened about 1730 yesterday. That's > all I know of the accident. > > Bill flew out of Centerville Airport, a few miles from his home. I met him > by chance when I landed at Centerville on the way to Tuscaloosa, Alabama, a > few years ago. > > http://www.faa.gov/data_research/accident_incident/preliminary_data/media/A_0207_N.txt > > Then scroll down to accident number 9. > > john h > mkIII > Titus, Alabama > > > > > > > ________________________________________________________________________________
Date: Feb 08, 2011
There has been some significant discussion on the topic of training in ELSA aircraft on some other forums which I am involved in. CGS Hawk, FLY UL, and LINKDIN are a few. The responses in those forums spurred me to write this in response. Please check out those forums if you are interested! sent to LINKDIN I want to keep the focus. What we will be doing is essentially taking hamburger and putting it all back together to make a steak. Ultra light flying is getting more difficult because of the non-availability of training. No one is going to give hours of training time and the use of an aircraft for free. Ultra lights therefore, literally, fly under the radar. Sport pilots can't do that quite so readily, but unfortunately, many are trying. While an ELSA built to SLSA standards is an appropriate aircraft, many experimentals simply do not fit the bill for appropriate training aircraft. I make this statement to have it understood that I do not advocate training in ALL experimental aircraft. Back to the focus of this discussion. I do not have the background I believe is required for developing the type of format needed here. I came up through the ranks of ultra lights as a self taught pilot. I received my BFI, trained several people in ultra lights, then received the training I needed when Sport Pilot came to be to transition to a sport pilot license. I have passed the first step - the FOI test - toward getting my CFI. But I do not have the legal background or the depth of knowledge regarding the FARs I feel is needed to produce this format in a viable and usable program for the Sport Pilot training arena. Mark, if you or someone else who is following this thread, or even a group of others, have the knowledge to pull this together, I would be willing to contribute what I can. This subject has spurred a lot of discussion as you know here and in other forums. Let's see if we can take it to a desired completion. There are some people who would be comfortable training with only a verbal contract. Others will require a written contract with the basics of cost and damage deposit and a disclaimer of liability in the event of an accident included. Still others will want a written contract in triplicate spelling out every possible nuance, required insurances, and a liability waiver signed by the trainee's family before they feel comfortable taking on the responsibility. And, yet others, will require a corporation development, corporate insurance, an aircraft meeting specified standards..... We now need to develop a format that can easily be adapted to allow each instructor to use their own level of comfort as a guide to what type of contract they want to use. >From hamburger .... to steak. Malcolm Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS (989)513-3022 ________________________________ From: Malcolm Brubaker <brubakermal(at)yahoo.com> Sent: Mon, February 7, 2011 5:19:27 PM Subject: Re: Kolb-List: Re: club planes? We have established the need. We have proven viability. We even have an apparent precedent. So, what next? An easy to follow format with all the "legal" jargon included for the average "layman" CFI or old BFI properly providing for that "equity position". Could such a "position" be covered by something so simple as a "damage deposit" on the aircraft?? Malcolm Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS (989)513-3022 ________________________________ From: Mike Welch <mdnanwelch7(at)hotmail.com> Sent: Mon, February 7, 2011 9:27:30 AM Subject: RE: Kolb-List: Re: club planes? > The FAA regs allow instruction in any experimental aircraft which is owned by the person receiving the instruction. > -------- > Thom Riddle Thom, & knowledgeable 'regs' guys, Your statement above is excellent information, but what about the situation where a plane is just given it's airworthiness certificate? I get the impression what you said is fine for a fully built, previous flown airplane, but what about a brand new one? Once a plane is finally finished, aren't you supposed to fly off a certain number of hours before someone can be in the plane also? How does that work? I never have clearly understood how this part works. After rereading your statement, I think I'm getting more confused. If a person had a CFI teach him to fly, OF COURSE he could be taught in ANY (legal) airplane. My question is; How can a guy learn to fly his brand new, never flown, just licenced, experimental airplane? Can he have an instructor go with him on his maiden flight? Does anyone know how this works?? We've had a few recent incidents where lowtime Kolb pilots bent their planes (and themselves). What does the FAA regs say to address this problem? Thanks. Mike Welch MkIII ________________________________________________________________________________
Subject: Re: Sun and Fun 2011
Date: Feb 09, 2011
I'll probably fly down with the the Waiex (boo...hisss, I know... [Embarassed] ) After making the 7+45 hour flight (one-way) three times I look forward to making it in 2+45. See you there...! Kip -------- 2000 Firestar II R503 DCDI VLS 750 2010 Waiex Jabiru 3300 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330264#330264 ________________________________________________________________________________
Date: Feb 09, 2011
I'll probably fly down with the the Waiex (boo...hisss, I know... [Embarassed] ) After making the 7+45 hour flight (one-way) three times I look forward to making it in 2+45. See you there...! Kip Kip/Kolbers: Looking forward to seeing you and the rest of the Kolbers at Lakeland. Kolb Aircraft has invited Miss P'fer, my MKIII, to spend the week with them as part of their display. Nothing new for her. She is 20 years old, faded paint, rock and gravel damage, but she still flies great. Unfortunately, her pilot doesn't look any better than she does. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 09, 2011
On Wed, Feb 9, 2011 at 8:58 AM, John Hauck wrote: > Kolb Aircraft has invited Miss P'fer, my MKIII, to spend the week with them > as part of their display. Nothing new for her. She is 20 years old, faded > paint, rock and gravel damage, but she still flies great. Unfortunately, > her pilot doesn't look any better than she does. > > But as long as HE still flies great, then no one should care! :-) -- Robert ________________________________________________________________________________
Date: Feb 09, 2011
Yeah!!! anyone that flies a Kolb don't need no stinking viagra!! :-) Herb At 09:03 AM 2/9/2011, you wrote: >On Wed, Feb 9, 2011 at 8:58 AM, John Hauck ><jhauck(at)elmore.rr.com> wrote: >Kolb Aircraft has invited Miss P'fer, my MKIII, to spend the week with them >as part of their display. Nothing new for her. She is 20 years old, faded >paint, rock and gravel damage, but she still flies great. Unfortunately, >her pilot doesn't look any better than she does. > > >But as long as HE still flies great, then no one should care! :-) > > -- Robert > > ________________________________________________________________________________
Subject: nose hoop
Date: Feb 09, 2011
Kolb guys=2C In an 'off list' conversation with a fellow Kolber=2C I asked about his thoughts on the MkIII nose hoop. He has chosen to go with one=2C but I know several Xtra owners have not. My question is=3B Is there a big need for a nose hoop? Are a lot of guys standing their planes up on their noses a lot? As best as I can guess=2C 99.9% of my MkIII T/O & landings will be on asphalt runways. There aren't very many grass strips around here=2C at least=2C not that I'll likely fly in to. Any thoughts on having a nose hoop? If I'm gonna add one=2C the time is now! Mike Welch ________________________________________________________________________________
Subject: Re: nose hoop
Date: Feb 09, 2011
Any thoughts on having a nose hoop? If I'm gonna add one, the time is now! Mike Welch >>>>>>>>>>>>>>>>>>>>>>>>mike where is your peto static system in relation to where your nose hoop will be located... would it protect it? boyd youngmkiii ________________________________________________________________________________
Subject: nose hoop
Date: Feb 09, 2011
>mike where is your peto static system in relation to where your nose hoop will be located... would it protect it? >boyd young Hi Boyd=2C The pitot probe is at the bottom=2C front=2C just off-center.....in other words=2C exactly where it would get wiped out first. I kind of always accepted the fact that if I ever stood it up on it's nos e=2C that the pitot probe would be on the list of repairs. Do you think flying from asphalt runways virtually all the time makes any difference in the need for a nose hoop? Mike W ________________________________________________________________________________
Date: Feb 09, 2011
My question is; Is there a big need for a nose hoop? Are a lot of guys standing their planes up on their noses a lot? As best as I can guess, 99.9% of my MkIII T/O & landings will be on asphalt runways. There aren't very many grass strips around here, at least, not that I'll likely fly in to. Any thoughts on having a nose hoop? If I'm gonna add one, the time is now! Mike Welch Mike W/Kolbers: Homer Kolb designed the nose hoop as a training wheel for those that don't fly well. ;-) Homer's factory MKIII did not have a nose hoop on it. However, I did put it on its nose at Sun and Fun one year with a very large, max capacity passenger. It happened when I stopped at the fence to unload my healthy passenger, hit the brakes with the stick full aft, tail in a good Lakeland wind, and up she went. No damage because we were stopped. That was pilot error, not MKIII error. If I had not gotten preoccupied with all that goes on when flying passengers at Lakeland, I would not have put the airplane on its nose, even with heavy cargo on board. Just as easy to put the mkIII on its nose on pavement as grass under the right conditions. If you don't fly off grass you are missing the best part of flying a Kolb airplane. Grass strips are what Kolbs were designed for and are where the good folks hang out. ;-) If you have doubts about keeping the tail on the ground, put a training wheel on it. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 09, 2011
Do you think flying from asphalt runways virtually all the time makes any difference in the need for a nose hoop? Mike W Mike W/Kolbers: Grass or asphalt runways do not put Kolbs on their nose, but pilots do. Stay ahead of the aircraft and you will do just fine. There are no guarantees in aviation except one: Gravity and Murphy rule! john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: nose hoop
Date: Feb 09, 2011
Having nosed mine over a couple times it helps when going slow but if at hi gher speeds I think it does more damage than helps. I am in the process of installing a Deleon skid plate in place of the hoop such as used on gliders . My battery and a 3 gal reserve fuel tank are located in the nose section. I was coming home from a XC when I encountered very strong winds which bow ed my windshield in. After pushing it back out a couple times I located a f ield to land in and when about 5-8 foot above the ground the windshield blo w in again and this time splitting and hitting me in the face knocking my g lass's and head phones off. Being to late to abort I set it down hard bendi ng the landing gear and nosing it over causing damage to the nose section a lso. I always carry duct tape=2C and after the winds let up flew it home bu t I was VERY lucky!!! From: byoungplumbing(at)gmail.com Subject: Re: Kolb-List: nose hoop Date: Wed=2C 9 Feb 2011 08:55:12 -0700 Any thoughts on having a nose hoop? If I'm gonna add one=2C the time is now! Mike Welch >>>>>>>>>>>>>>>>>>>>>>>> mike where is your peto static system in relation to where your nose hoop will be located... would it protect it? boyd yo ungmkiii ________________________________________________________________________________
Date: Feb 09, 2011
I was coming home from a XC when I encountered very strong winds which bowed my windshield in. After pushing it back out a couple times Sky Biker/Kolbers: Curious why your windshield bowed in? Are you using 1/8" Lexan? john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 09, 2011
I asked about his thoughts on the MkIII nose hoop.>> Hi Mike, As JH says. Its the pilot, not the plane. I don`t have a hoop on my Xtra and I wiped the pitot off a couple of times when I had her first. I was doing taxying runs prior to my first flight and after several years in the tricycle Challenger I didn`t keep the stick aft. Not sure that a hoop would have helped as I was weaving after a weathercock and trying to get used to indiviual toe brakes. Something else I didn`t need in the Challenger. I am sure that the hoop would have been wiped off by the sideways motion of the nose cone and probably done damage to the fixings. Pat ________________________________________________________________________________
Subject: nose hoop
Date: Feb 09, 2011
I was using .092 Lexan > From: jhauck(at)elmore.rr.com > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: nose hoop > Date: Wed=2C 9 Feb 2011 10:52:53 -0600 > > > > I was coming home from a XC when I encountered very strong winds which > bowed my windshield in. After pushing it back out a couple times > > > > Sky Biker/Kolbers: > > Curious why your windshield bowed in? > > Are you using 1/8" Lexan? > > john h > mkIII > Titus=2C Alabama > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Feb 09, 2011
Kolbers: I was very fortunate to help fly off the test time on the first MKIII in Feb 1991, while I was building my MKIII and helping Homer build a lot more of them. During those test flights I was able to determine what I needed to change on my MKIII to make me happy. Notice, I did not say to make my MKIII better, but to satisfy me and my style of flying. First thing my Brother Jim, who was working with Homer at that time, and I decided was to move the main gear 8" forward, put some weight on the tailwheel, and keep the tail on the ground. Jim designed new main gear and my MKIII has no tendancy to want to nose over. The reason we made the decision to go with the Hauck Main Gear was because Homer put the MKIII on its nose when he was carrying a very light passenger at the farm, turned the tail into the wind and promptly put the nose on the ground. We figured we were going to need to move the gear forward from experience with the FS. Using 35.5" long main gear legs helped reduce the nose over tendancy of the FS. Yep, I had an engine failure, put the FS in a pasture, one wheel hit a big fire ant bed just before it stopped rolling, I had no brakes, and she went right up on its nose. The more weight you put in the seats of the standard MKIIIc or x, the easier it will be to nose it over. john h - With well over 100 lbs on a tailwheel at the end of a long tailboom. mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 09, 2011
I was using .092 Lexan Skybiker/Kolbers: .125" is what the plans call for. Haven't gotten any feedback on windshild problems using .125" (1/8"). Are you flying a MKIII? john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 09, 2011
I started out with a nose hoop and am glad I did. On my first flight with a passenger, managed to nose it up during a full throttle runup with the brakes locked, even with the stick back. The hoop prevented any damage. John has covered a tailing wind with locked brakes, let me bring up locked brakes and the high thrust line. With the high thrust line, it is very easy to pick the tail up off the ground with any of our Kolbs. In order to save abuse on the tail wheel, boom, and lower vertical stab assembly (since my tail wheel is not full swivel) I blow the tail up off the ground with forward stick, locked left brake, and a shot of power to spin the airplane around to position it in front of the hangar so I can use the pulley and winch to haul it uphill and in. Obviously it is very different doing a tail-up turn when I have a passenger versus solo, and the potential is very high to screw up and stick the nose in the dirt. With the MKIII gear being where it is, when you have a passenger, locked brakes, and enough power to raise the tail off the ground, there comes a definite "tipping point" and it is probably not very high. Also, in that situation, careful power modulation is probably at least if not more important than what you are doing with the elevators, however I am not planning to experiment, I have enough repair projects going on. Anyway, tail up turns are definitely an acquired skill, not without certain obvious risks. And maybe the next time I go fly, I'll be patching the nose & pitot system - it could easily happen. But back to the hoop - once I had enough hours in it to get fully acquainted with what the MKIII would and would not do, I took the hoop off and just put the screws back in the holes, and in the 15 years I have flown it since, have not missed it. But when you are first getting started, as easy an option as it is to put it on or take it off, why not use it initially? Kinda like feeding crackers to a dead man - it isn't going to hurt anything... Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330295#330295 ________________________________________________________________________________
Subject: nose hoop
Date: Feb 09, 2011
I have and fly both=2C a CWS 2 Challenger and a MK111 and used the .092 thi nk ness for several years with out any problem. The material broke around t he rivet holes which attached it to the nose section which caused bowing in at the bottom and then splitting up words. I have snce made fiberglass pie ces that form to the nose section and better secure the windshield plus a g ap seal that fits between the center gap and the windshield which stopped the air from blowing in between the center gap section and the windshield. The air felt good in the summer but in the winter it was cold and I live in Florida. I have gotten older and remember the days when I would fly the ul tralights in the winter with skis ..no more!!! The cockpit heater feel grea t. LOL From: pj.ladd(at)btinternet.com Subject: Re: Kolb-List: nose hoop Date: Wed=2C 9 Feb 2011 08:57:53 -0800 I asked about his thoughts on the MkIII nose hoop.>> Hi Mike=2C As JH says. Its the pilot=2C not the plane. I don`t have a hoop on my Xtra and I wiped the pitot off a couple of times when I had her first. I was doing taxying runs prior to my first flight and after several years in the tricycle Challenger I didn`t keep the stick aft. Not sure that a hoop would have helped as I was weaving afte r a weathercock and trying to get used to indiviual toe brakes. Something else I didn`t need in the Challenger. I am sure that the hoop would have been wiped off by the sideways motion of the nose cone and probably done damage to the fixings. Pat ________________________________________________________________________________
Date: Feb 09, 2011
John has covered a tailing wind with locked brakes, Richard Pike Not exactly locked brakes, but using a little brake as I taxied up to the fence to drop off my passenger. I might add, we were on the brink of destruction as soon as my passenger got on board. Homer put most of the weight on the main gear, nearly all of it, to make his airplanes docile ground handlers. They are very easy to taxi compared to the SS and the few MKIII's that sport Hauck Main Gear. Mine is a little more difficult to control, but she doesn't try to go up on her nose, never has. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 09, 2011
With the Firestar II, a nose hoop is not an option. If you are foolish enough (like me) to try and power out of some tall grass or snow, you will get a chance to practice fiberglass repair. At zero forward speed it didnt do excessive damage, but it twice cost me some nice nose art. Because of the high thrust line, my Firestar II can nose over quite easily; maybe I could use a training wheel. The other problem is once up on the nose, it goes over center (CG slightly forward of main wheels) and wants to stay there. It takes some agility to climb out without letting the tail crash to the ground and cause more damage. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330304#330304 ________________________________________________________________________________
Date: Feb 09, 2011
Subject: Question for Richard Pike (winch attach point)
Richard, Where do you attach the winch cable to the airframe? I have a winch on my FSII trailer, but I only used it once in 10 years. I attached the cable to the tail wheel, (as I load the FSII tail first). However, I thought it put a lot of stress on the tail wheel strut as I pulled it up the loading ramps, and never used it again. As I get older, it gets more difficult to drag the Kolb up on the trailer by brute strength. I trailer every time I fly, as there is no hanger space at Numidia International. Thanks Lanny ________________________________________________________________________________
Date: Feb 09, 2011
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: Question for Richard Pike (winch attach point)
- I had the same problem.--I have a converted boat trailer, with a ha nd crank winch.- I loop the cable around the tail wheel strut, and then r un it forward to the main gear.- I run it around both legs near the top, and put the hook back on the cable.- The tail strut acts only as a guide, and all stress is at the top of the main gear.- Works like a charm.- J ust be careful that the loop on the tail strut has the cable over the secti on of cable running forward, so it won't straighten on you, and the cable i s inside the tailwheel cables.- I do this with the wings extended, and fo ld them after it's on the trailer.- The plane comes up with one finger. - ------------------------- ------------------------- Bill Sullivan ------------------------- ------------------------- Windsor Locks, Ct. ------------------------- ------------------------- FS 447 --- On Wed, 2/9/11, Lanny Fetterman wrote: From: Lanny Fetterman <donaho1(at)verizon.net> Subject: Kolb-List: Question for Richard Pike (winch attach point) Date: Wednesday, February 9, 2011, 2:04 PM Richard, Where do you attach the winch cable to the airframe? I have a winc h on my FSII trailer, but I only used it once in 10 years. I attached the c able to the tail wheel, (as I load the FSII tail first). However, I thought it put a lot of stress on the tail wheel strut as I pulled it up the loadi ng ramps, and never used it again. As I get older, it gets more difficult t o drag the Kolb up on the trailer by brute strength. I trailer every time I fly, as there is no hanger space at Numidia International. Thanks Lanny le, List Admin. ________________________________________________________________________________
Date: Feb 09, 2011
I'll probably make my annual 1 day visit. Work load will dictate what day I get to sneak off and come down. Look forward to eating collard greens and pot roast again, along with all the Kolb pilot fellowship. -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330318#330318 ________________________________________________________________________________
Date: Feb 09, 2011
Look forward to eating collard greens and pot roast again, along with all the Kolb pilot fellowship. -------- Jimmy Young Where'd we get those collards? Good eat'n is a big part of Kolbs and Sun & Fun. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 09, 2011
Hi Boyd, The pitot probe is at the bottom, front, just off-center.....in other words, exactly where it would get wiped out first. I kind of always accepted the fact that if I ever stood it up on it's nose, that the pitot probe would be on the list of repairs. Do you think flying from asphalt runways virtually all the time makes any difference in the need for a nose hoop? Mike W i think flying from asphalt would just about eliminate the chance of a nose over. and even with the hoop. the peto may get wiped off anyway.boyd ________________________________________________________________________________
Date: Feb 09, 2011
For those who are curious about the MkIII being "over center" in a tail up position.... When I did the engine out into the tall alfalfa three years ago it went on its nose for a distance and then plopped back on the tail. I was solo (good thing). It snapped off the tailspring. I could see from the stress marks at the break that it was going to go eventually anyway. The benefit was a shorter spring and a new pitot. :) BB genuinely ugly here in western NY today. ( the weather, not me) On 9, Feb 2011, at 1:09 PM, racerjerry wrote: > > With the Firestar II, a nose hoop is not an option. If you are foolish enough (like me) to try and power out of some tall grass or snow, you will get a chance to practice fiberglass repair. At zero forward speed it didnt do excessive damage, but it twice cost me some nice nose art. Because of the high thrust line, my Firestar II can nose over quite easily; maybe I could use a training wheel. The other problem is once up on the nose, it goes over center (CG slightly forward of main wheels) and wants to stay there. It takes some agility to climb out without letting the tail crash to the ground and cause more damage. > > -------- > Jerry King > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330304#330304 > > > > > > > > > > ________________________________________________________________________________
Date: Feb 09, 2011
John Hauck wrote: > John has covered a tailing wind with locked brakes, > > Richard Pike > > Not exactly locked brakes, but using a little brake as I taxied up to the > fence to drop off my passenger. > > I might add, we were on the brink of destruction as soon as my passenger got on board. > > john h > mkIII > Titus, Alabama "Brink of destruction" WooHoo - Best line of the week! Thanks for the LOL! moment. I have taken a few of those sort for a ride, so I know whereof you speak! Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330345#330345 ________________________________________________________________________________
Subject: Re: Heavy Passengers
Date: Feb 09, 2011
speaking of passengers I have a friend that wants a ride in my MK3c and he is 350 lbs im not sure I should even attempt it, I am 190 lbs what's you r thoughts on giving a heavy guy a ride? the most I have had with me is 250 lbs and 20 gallons fuel Ellery Batchelder Jr. I might add, we were on the brink of destruction as soon as my passenger got n board. ________________________________________________________________________________
Date: Feb 09, 2011
At 07:19 PM 2/9/2011, Ellery Batchelder Jr wrote: >speaking of passengers I have a friend that wants a ride in my MK3c and he >is 350 lbs im not sure I should even attempt it, I am 190 lbs what's your >thoughts on giving a heavy guy a ride? >the most I have had with me is 250 lbs and 20 gallons fuel It's your plane... what do the weight and balance limits say? -Dana -- Psychiatrists say that one of four people are mentally ill. Check three friends. If they're OK, you're it. ________________________________________________________________________________
Date: Feb 09, 2011
Date: Feb 09, 2011
speaking of passengers I have a friend that wants a ride in my MK3c and he is 350 lbs im not sure I should even attempt it, I am 190 lbs what's your thoughts on giving a heavy guy a ride? the most I have had with me is 250 lbs and 20 gallons fuel Ellery Batchelder Jr. >>>>>>>>>>>>>>> what does your plane weigh,, say 600 +you at 190 say 5 gal fuel. +30 you are up to 820 lb.. if you have 1000 lb gross,,, minus 820 leaves 180 pound passenger, you are up to gross wt.. maybe your plane weighs less or you could takeoff with less fuel... my .02 worth boyd young mkiii ________________________________________________________________________________
Date: Feb 09, 2011
I calculated and if I only used 3 gallons fuel ( A short Flight ) I woul d still be in the W&B window but I have never flown with that much weight in the MK3C Ellery Batchelder Jr. -----Original Message----- From: b young <byoungplumbing(at)gmail.com> Sent: Wed, Feb 9, 2011 8:39 pm Subject: Re: Kolb-List: Heavy Passengers speaking of passengers I have a friend that wants a ride in my MK3c and he is 350 lbs im not sure I should even attempt it, I am 190 lbs what's you r thoughts on giving a heavy guy a ride? the most I have had with me is 250 lbs and 20 gallons fuel Ellery Batchelder Jr. >>>>>>>>>>>>>>> what does your plane weigh,, say 600 +you at 190 say 5 gal fuel. +30 you are up to 820 lb.. if you have 1000 lb gross,,, minus 820 leaves 180 pound passenger, you are up to gross wt.. maybe your plane weighs less or you could takeoff with less fuel... my .02 worth boyd young mkiii ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Feb 09, 2011
Mike, The FireFly does not have a hoop, but it is very easy to put on it's nose. I have had it on it's nose several times. The first nose over can when making my first flight from grass. This was followed by trying to taxi across a wet soft grass field. My wife got me some red colored Duct Tape, and that is what holds the bottom front of the nose cone together. To keep from repeating the nose over, I chocked the main gear and tied a ground loop over the tail boom just a head of the vertical fin. Then I started the engine, climbed in and slowly advanced the throttle to see when the tail would lift off the ground. This gives me the maximum initial throttle opening for the take off roll. Your problem is a little more difficult, in that, you can carry a passenger, etc, but if you load up the passenger seat and test with a low fuel load should give you a workable rpm number. The snow and ice and ice and snow continue. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Feb 09, 2011
john , Glad to hear that you will be there ! Hope we can afford the trip hope to see you there . Chris&BeckyChris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly ----- Original Message ---- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Wed, February 9, 2011 9:58:54 AM Subject: Re: Kolb-List: Re: Sun and Fun 2011 I'll probably fly down with the the Waiex (boo...hisss, I know... [Embarassed] ) After making the 7+45 hour flight (one-way) three times I look forward to making it in 2+45. See you there...! Kip Kip/Kolbers: Looking forward to seeing you and the rest of the Kolbers at Lakeland. Kolb Aircraft has invited Miss P'fer, my MKIII, to spend the week with them as part of their display. Nothing new for her. She is 20 years old, faded paint, rock and gravel damage, but she still flies great. Unfortunately, her pilot doesn't look any better than she does. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 09, 2011
Run a W & B and you will find out. Assuming that your W & B says it's ok - bear in mind that with full flaps and a forward CG, the MKIII runs out of elevator authority in a hurry in that situation, so NO FLAPS. Even if the numbers come out right, I would add a strip of tape to the gap between the elevator and stab, and land w/o flaps, and keep the airspeed to 60 or 65 on final. With a LONG runway... Or just say no. (How would a 350 pound person even fit? That is going to foul your elevator push rod. Not to mention getting them back out of the bucket after the flight is over. Unless they are unusually agile for that weight, you are going to do some serious pulling and tugging) Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330391#330391 ________________________________________________________________________________
Date: Feb 09, 2011
speaking of passengers I have a friend that wants a ride in my MK3c and he is 350 lbs Ellery Batchelder Jr. Ellery B/Kolbers: Sometimes, especially at Oshkosh and S&F, flying for Kolb Aircraft, we pushed the limits in order to satisfy customers and bosses. The largest guy I ever got off the ground in the factory MKIII was a lopper. That means he lopped over the aileron torque tube between the pilot and passenger. It takes a big guy or gal to be a lopper, probably over 300 lbs. On take off to the north out of the UL strip at Oshkosh, it was up hill with a 90 deg brisk cross wind. I had everything working against me to include my decision to fly this guy. Finally broke ground about midfield. Soon as we got airborne the MKIII began drifting right towards the fence and spectator bleachers. I had full left stick and it was still trying to roll and drift right. A quick prayer and some luck, it slowly started to roll left and away from the fence before I hit it. I was able to climb out between and over the trees at the north end. Flew the traffic pattern at full throttle. Shot my approach at 75 mph. Did not chop power until the mains touched down. The only thing that flight proved was I had made a very stupid, dangerous decision that could have turned deadly. Sometimes it is hard to say no. After that incident, I never had a problem turning down a passenger when I felt the least bit unsure of a safe flight. Since then I have aborted flights on take off at S&F with extra heavy passengers. Didn't hurt a thing and the passengers were very happy that I made the decision when I sat them down and explained my actions. There's a lot of difference in handling and performance between solo and flying a normal category passenger. Takes a lot more up elevator trim. With no up elevator trim there are heavy nose down stick forces. This situation plays hell with low time MKIII pilots, and is not much fun for those with lots of experience. Don't make the same poor decision I did. You may not be as lucky. 350 lbs!!! I wouldn't even talk about flying with him. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 09, 2011
I calculated and if I only used 3 gallons fuel ( A short Flight ) I would still be in the W&B window but I have never flown with that much weight in the MK3C Ellery Batchelder Jr. Ellery B/Kolbers: My max gross is 1,200 lbs. When I make a serious, long cross country, my take off weight is approximately 1,200 lbs. However, my fuel and most cargo is behind the bulkhead and I don't have 350 lbs in the front seat beside me. I have never been able to make the W&B on a MKIII work out for me on paper. Through experiementation and experience I know how much weight and where it will fly safely with a very wide margin. If I am going to push the fore or aft limit, I will push the aft limit. I can't prove that on paper, but I can in the air. Remember, that is the way I do it. I do not recommend that anyone else fly their Kolb that way. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 10, 2011
If I am going to push the fore or aft limit, I will push the aft limit. >> Thats interesting John. Whats the reasoning? I would have thought that tail heavy the most dangerous. When the speed comes back ,for landing, and you are low a heavy tail is asking for a stall. If you are nose heavy at least when the nose goes down your speed goes up and that gives you more elevator control. Hopefully. Your all up weight is way above ours. Not to say that the Kolb wont handle it but here if you are overweight then you are no longer a `microlight`. That means that your pilots license is not valid and therefore your insurance is invalid as well.. You cannot fly legally here without third party insurance so you are in trouble with the law as well as the CAA. Pat ________________________________________________________________________________
Date: Feb 10, 2011
Subject: Re: club planes?
Ok Group. This was posted on the CGS hawk forum. I want to say Thank You to =0ADanny Dezauche for a well thought out and candid statement. I agree. So , after =0Ayou all have read it, chime in here and let's figure out what we are going to do =0Aabout it! =0A=0A=0ATo whom it may interest =0A=0AI was told by the FAA that clubs were considered a commercial =0AEntity and there fore were only legal for training with "certified =0AAircraft". I was also told "primary" training such as a sport pilot =0ALicense has to be in a cer tified aircraft. I have been a member =0AOf the oldest club in mobile ala f or several years which used =0ACessnas etc for rent and training. These of course were certified =0AAircraft =0AWe here at cgs have lived with the lod a and club question for =0ASeveral years now. The belief and hope that trai ning can and will =0ABe allowed in Elsa aircraft has existed since the adve nt of the =0ALight sport category =0ACgs has only sold 2 slsa models since 2005 and none since =0AApril 2009 since I purchased the business. I too see the need =0AFor trainers of the ultralight type. Remember. Two seat ultral ights =0AWere only allowed by waiver for training purposes only from the st art =0AThe sale and use of two seaters outside the waiver was one of the re asons for =0Athe faa to =0Aimplement this grand experiment in the U.S.known as =0ASport pilot. The word from the FAA now is that they will not =0AAllo w any More lsa models into the market without prior =0AAudit by the FAA as to their qualifications and engineering =0AThose of us in the lsa market ca n also expect to be audited =0ABy the FAA In The near future to make sure w e are in compliance =0AWith all astm standards. =0AThe confusion over the e lsa training issue has had a detremental effect on this =0Asegment of aviat ion obviously. =0Ai want to make it clear what my personal and business pos ition is on this issue =0Aonce and for all i have also said this to the faa =0Awe as manufacturers cannot force people to buy slsa aircraft. however i f no =0Atrainers are available either slsa or elsa no new customers =0Aare trained or exposed to our aircraft. i would rather see training in elsa =0A aircraft instead of not at all and that is where we are today =0Awe can bui ld slsa's all day long but if no one buys them whats the point an =0Aelsa a ircraft built by an individual puts most legal ramifications =0Aon the owne r builder not the factory =0Aso i support any measures that will get this s egment going and training again =0A=0Ahowever faa is not happy with the res ults of their audit on the lsa industry =0Awhich was done over the past two years. So we manufacturers await =0Athe future with some fear of the unkno wn. =0A=0Ain a further effort to get slsa trainers out in the field cgs is putting on a =0Asun n fun sale which will be posted on the web site =0A=0Ai implore the group to choose someone whom is respected among you to contact the =0A=0Afaa and report on their findings =0Ai dont expect anyone here to take my word for it and i prefer another voice to =0Aconcur what ive said =0A=0Asincerely =0Adanny dezauche =0Apresident/cgs aviation=C2-=0A=0A=0A =C2-Malcolm Brubaker =0AMichigan Sport=0APilot Repair =0ALSRM-A, PPC, WS =0A(989)513-3022 =0A=0A=0A=0A=0A________________________________=0AFrom: Th om Riddle =0ATo: kolb-list(at)matronics.com=0ASent: Mon, F ebruary 7, 2011 8:49:22 AM=0ASubject: Kolb-List: Re: club planes?=0A=0A--> Kolb-List message posted by: "Thom Riddle" =0A=0ADana, =0AThe FAA regs allow instruction in any experimental aircraft which is own ed by =0Athe person receiving the instruction. My FSDO said that partial ow nership or =0Aindirect ownership (share holder in a corporation that owns t he aircraft) =0Aqualifies as long as there is an equity position in the air craft.=0A=0A--------=0AThom Riddle=0ABuffalo, NY (9G0)=0AKolb Slingshot SS- 021=0AJabiru 2200A #1574=0ATennessee Prop 64x32=0A=0A=0ADon't accept your d og's admiration as conclusive evidence that you are =0Awonderful.=9D =C2-=0A=94Ann Landers=0A=0A=0A=0A=0ARead this topic online here:=0A =0Ahttp://forums.matronics.com/viewtopic.php?p=329948#329948=0A=0A=0A=0A =====0A=0A=0A ________________________________________________________________________________
Date: Feb 10, 2011
Took these this morning, the swivel tail wheel is on the FSII, the black and blue one (needs painting, huh?) is a Sorrell Hyperlight tail wheel on the MKIII. (The groove in the middle of the tire is because of a stone that got caught there and scored the solid rubber tire) The yoke for the MKIII is just a bent piece of aluminum flat stock with a couple holes in it. It slips over axle extensions that protrude from either side of the tailwheel yoke, and is tightened or removed with a thumbscrew. So it is removable from the airplane. The full swivel tailwheel on the FSII is the kind that Kolb sells, took two flat washers and welded a 3/16" bent rod to them to make the yoke extension, the washer on one side has two 3/16" rod extensions welded on to keep it from flopping up or down. It stays on the airplane. We have used this method for years to drag the airplanes up the hill into the hangar. I had to replace the tailwheel strut on the MKIII last year when it broke at the lower through bolt, but I seriously doubt that pulling the airplane into the hangar by the tailwheel was a factor. Since this is a hangar situation and not a trailer situation, we are using 100' of nylon rope to pull with. Just pick up the loose end (which has a loop in it) stick a screwdriver through the loop, and start walking backwards. When the tailwheel drops over the lip at the end of the track, stop. And that lip on the track keeps it from rolling back out of the hangar. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330420#330420 Attachments: http://forums.matronics.com//files/p1190143_large_120.jpg http://forums.matronics.com//files/p1190144_large_109.jpg http://forums.matronics.com//files/p1190150_large_209.jpg http://forums.matronics.com//files/p1190157_large_591.jpg http://forums.matronics.com//files/p1190168_large_192.jpg ________________________________________________________________________________
Date: Feb 10, 2011
Thats interesting John. Whats the reasoning? I would have thought that tail heavy the most dangerous. When the speed comes back ,for landing, and you are low a heavy tail is asking for a stall. If you are nose heavy at least when the nose goes down your speed goes up and that gives you more elevator control. Hopefully. Your all up weight is way above ours. Not to say that the Kolb wont handle it but here if you are overweight then you are no longer a `microlight`. That means that your pilots license is not valid and therefore your insurance is invalid as well.. You cannot fly legally here without third party insurance so you are in trouble with the law as well as the CAA. Pat Patrick L/Gang: My MKIII is placarded for 1,200 lbs maximum gross weight based on modifications the manufacturer (me) made during construction to satisfy me, the FAA, and my insurance company. I have difficulty making the Kolb paper weight and balance work in actual flight. I flew my MKIII with a 12 lb Maule 8" Tundra Tailwheel for several years. This blows the paper weight and balance away. My airplane is not supposed to fly on paper, yet it flew quite well. I stalled it in every attitude I could think of and the nose always dropped. I don't like the idea of running out of elevator before the wing stalls. The Kolb's high pusher configuration compounds the forward cg with a heavy passenger, especially on take off and in the event of a go around. I have never had the courage to stall a MKIII with a very heavy passenger, so I really do not know how the aircraft would respond. I don't have to worry about that anymore because I won't be flying large passengers in my aircraft, and I don't fly demonstration flights for Kolb anymore. I have stalled my MKIII with full flaps and a passenger on board. To my surprise, the elevator stalled when I attempted to recover. That'll get your attention. Have no statistics to back me up, but there seem to be many fatal Kolb crashes while carrying passengers. I don't know how valid that is. I have always flown with a recovery parachute. ;-) john h Titus, Alabama ________________________________________________________________________________
Date: Feb 10, 2011
From: "Kirby, Dennis Civ USAF AFMC AFNWC/EN" <Dennis.Kirby(at)kirtland.af.mil>
<< Kolb guys . Is there a big need for a nose hoop? Are a lot of guys standing their planes up on their noses a lot? Mike Welch >> Hi, Mike - As you are seeing from the replies, opinions on the Kolb nose hoop are varied. Here's my story, from last year: http://forums.matronics.com/viewtopic.php?t=75581 <http://forums.matronics.com/viewtopic.php?t=75581&highlight=nose+hoop> &highlight=nose+hoop And so, MY opinion is, I was glad I had it - saved me from scraping up the bottom of my fiberglass nose cone. Dennis Kirby Mark-3, 912ul (flew it last week in 16 degree F weather) Sandia Park, NM ________________________________________________________________________________
Date: Feb 10, 2011
Hi Guys, responding to Pats comment about weight and insurance, do aircraft in the US require insurance to legally fly?? I know you have to have car insurance but I can't find anything that says you have to have aircraft insurance. Also, has anyone had luck getting life insurance when you fly an experimental?? (My wife REALLY would like this!) I can get life but only if I fly certified aircraft and no ACRO.. Looking for answers. FrankD MkIII Xtra, Now legally airworthy. Soon to fly. no more excuses. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330451#330451 ________________________________________________________________________________
Date: Feb 10, 2011
<< speaking of passengers I have a friend that wants a ride in my MK3c and he is 350 lbs im not sure I should even attempt it, ... the most I have had with me is 250 lbs and 20 gallons fuel Ellery Batchelder Jr. >> Ellery - When I calculated the Weight & Balance for my Mark-3, it came out that the MOST heavy passenger I could "safely" carry was 250 lbs. This was based on my weight of 190 lbs, and minimal fuel (less than a quarter tank). In this configuration, the CG was at its forward-most allowable point, as specified by Homer. It's not a gross weight limitation - it's an out-of-CG issue. I suspect that you are correct - taking a 350 lb passenger in your Mark-3 might be a tad risky. Might even put your Kolb at the brink of destruction. Dennis Kirby Mark-III N93DK, "Magic Bike" New Mexico ________________________________________________________________________________
Date: Feb 10, 2011
Subject: Life insurance
Frank and All, I bought life Ins. through the EAA. They were the only one that I could find, that covered you, if you were PIC. However, everything must be legal. Both the aircraft and the pilot, or the coverage is void. Lanny N598LF ________________________________________________________________________________
Date: Feb 10, 2011
You do not have to say NO. Do him and yourself a great favor and rent a 172 for an hour and take him up. Or give him a present and BUY him a sightseeing flight at your local airport and go with him. Good advice about No flaps and increasing landing speed; but with such a large percentage change in gross weight and CG, even if successful, you will be operating in very unfamiliar and dangerous territory. Flight characteristics will change greatly, at which point you will become a test pilot with a large frightened passenger who is most likely restricting stick movement. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330462#330462 ________________________________________________________________________________
Date: Feb 10, 2011
there seem to be many fatal Kolb crashes while carrying passengers. >> Do you think that by some extraordinary chance that might be telling us that there is something in weight and balance after all? Cheers Pat (off to Tenerife and some sunshine at sparrows tomorrow. See you in a week) ________________________________________________________________________________
Date: Feb 10, 2011
Subject: Insurance
I have been flying legally for thirty years, ultralights (no license), general aviation (private pilot), and now LSA (private pilot without medical) with no insurance. Quite a few life insurance companies don't have any flying exemption. I once checked the wording on a term life policy I had that my work provided and there was no stipulation against flying. I have a friend that is a insurance agent. His comment is if you ask a agent they are very well trained to answer in a way that will indicate you need more insurance. Rick Neilsen Redrive VW Powered MKIIIC On Thu, Feb 10, 2011 at 11:37 AM, Frankd wrote: > > Hi Guys, > > responding to Pats comment about weight and insurance, do aircraft in the > US require insurance to legally fly?? > > I know you have to have car insurance but I can't find anything that says > you have to have aircraft insurance. > > Also, has anyone had luck getting life insurance when you fly an > experimental?? (My wife REALLY would like this!) I can get life but only if > I fly certified aircraft and no ACRO.. > > Looking for answers. > FrankD > > MkIII Xtra, > Now legally airworthy. > Soon to fly. no more excuses. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330451#330451 > > ________________________________________________________________________________
Date: Feb 10, 2011
I have been flying quite a bit near or slightly over gross weight lately. Yes the plane does fly differently the most concerning is the bad combination of high power and flaps. I use flaps on landing but I tell myself and my passenger that if I have to add power for a go around that all flaps must be retracted. With that said my personal feeling is that Kolb accidents are mostly caused by passengers panicking on approach to landing. I have had a number of people get excited and later comment that I didn't warn them strongly enough. The normal Kolb approach is a bit unsettling to everyone and even more so to private pilots. The best advice I can give is to make it clear what the approach will look like and to warn you passenger to never never touch the controls without permission. Also be ready to use your elbow as much as necessary to enforce that rule. Rick Neilsen Redrive VW Powered MKIIIC On Thu, Feb 10, 2011 at 12:25 PM, Pat Ladd wrote: > > there seem to be many fatal Kolb crashes while carrying passengers. >> > > Do you think that by some extraordinary chance that might be telling us > that there is something in weight and balance after all? > > Cheers > > Pat (off to Tenerife and some sunshine at sparrows tomorrow. See you in a > week) > > ________________________________________________________________________________
Date: Feb 10, 2011
At 11:37 AM 2/10/2011, Frankd wrote: > >responding to Pats comment about weight and insurance, do aircraft in the >US require insurance to legally fly?? > >I know you have to have car insurance but I can't find anything that says >you have to have aircraft insurance. There is no legal requirements for insurance, but many airports require insurance for aircraft based there. -Dana -- I only drink to make other people more interesting. ________________________________________________________________________________
Date: Feb 10, 2011
John Hauck wrote: > > > I have stalled my MKIII with full flaps and a passenger on board. To my > surprise, the elevator stalled when I attempted to recover. That'll get > your attention. > john h > Titus, Alabama You nailed that one. Several years ago I gap sealed my elevator to the horizontal stab in an effort to eliminate that particular problem. At the same time, added VG's to the lower forward horizontal stab. Should have done them one at a time to see which was the most effective. Not sure which of those 2 things helped the most, but together it has made a huge improvement in elevator authority with flaps and a passenger. (massive forward CG) Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330482#330482
January 20, 2011 - February 10, 2011
Kolb-Archive.digest.vol-la
