Kolb-Archive.digest.vol-lb
February 10, 2011 - Present
From: "Larry Cottrell" <lcottrell1020(at)gmail.com>
Subject: Re: Heavy Passengers
Date: Feb 10, 2011
"With that said my personal feeling is that Kolb accidents are mostly caused by passengers panicking on approach to landing. I have had a number of people get excited and later comment that I didn't warn them strongly enough. The normal Kolb approach is a bit unsettling to everyone and even more so to private pilots. " I bought a Mark III when I was taking my P.Pilots training. I talked my young instructor into going around with me to sign off on it so that I could fly it with a Student lic. Every thing was fine and when I lined up for short final at 1000 feet above the ground, I put in full flaps when I was almost over the numbers, brought it back to a bit of a mush and landed on the numbers with no incident other than having to pull my instructor out of the wing gap seal. He did sign me off, but would not fly with me any more. Puss! Pat attempted to link heavy passengers and crashes with a weight and balance issue. Much too simple an answer, most likely it would be due to not taking into account the different flight requirements with a heavy passenger in the front. Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ________________________________________________________________________________
Date: Feb 10, 2011
Subject: Operating at maximum weight
You guys remember that part of your operating instructions that says you'll test the aircraft at max gross weight while in phase 1 testing? You know, buy four bags of sand or cement and put them in the passenger seat and test in all configurations and put this statement in the aircraft's log book, =93I certify that the prescribed flight test hours have been completed and the aircraft is controllable throughout its normal range of speeds and throughout all maneuvers to be executed, has no hazardous operating characteristics or design features, and is safe for operation. The flight test was completed under the following conditions: *maximum operating weight*, style/set of wing or sail, maximum demonstrated airspeed , and minimum demonstrated stall speed.=94? You all did that, right? By this discussion, I'd say not. Rick Girard -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Feb 10, 2011
That sounds interesting. -anybody else have stories about passengers invading the flight controls? Personally I have never experienced anything like that and I have given a lot of free rides. I did have one guy get so distraught at being too far away from mother earth that I immediately turned downwind and landed. Thankfully he didn't grab anything but the pipes in the windshield. I think full flaps with a passenger in a MkIII is not necessary and possibly hazardous. Now, getting on in years, I think I will discourage would be riders. BB On 10, Feb 2011, at 1:02 PM, Rick Neilsen wrote: > I have been flying quite a bit near or slightly over gross weight lately. Yes the plane does fly differently the most concerning is the bad combination of high power and flaps. I use flaps on landing but I tell myself and my passenger that if I have to add power for a go around that all flaps must be retracted. > > With that said my personal feeling is that Kolb accidents are mostly caused by passengers panicking on approach to landing. I have had a number of people get excited and later comment that I didn't warn them strongly enough. The normal Kolb approach is a bit unsettling to everyone and even more so to private pilots. The best advice I can give is to make it clear what the approach will look like and to warn you passenger to never never touch the controls without permission. Also be ready to use your elbow as much as necessary to enforce that rule. > Rick Neilsen > Redrive VW Powered MKIIIC > On Thu, Feb 10, 2011 at 12:25 PM, Pat Ladd wrote: > > there seem to be many fatal Kolb crashes while carrying passengers. >> > > Do you think that by some extraordinary chance that might be telling us that there is something in weight and balance after all? > > Cheers > > Pat (off to Tenerife and some sunshine at sparrows tomorrow. See you in a week) > bscription, > www.matronics.com/Navigator?Kolb-List" target="_blank">http://www.matronics.com/Navigator?Kolb-List > ronics.com/" target="_blank">http://forums.matronics.com > Matt Dralle, List Admin. > ==== > > > > > > > ________________________________________________________________________________
Date: Feb 10, 2011
You nailed that one. Several years ago I gap sealed my elevator to the horizontal stab in an effort to eliminate that particular problem. At the same time, added VG's to the lower forward horizontal stab. Should have done them one at a time to see which was the most effective. Not sure which of those 2 things helped the most, but together it has made a huge improvement in elevator authority with flaps and a passenger. (massive forward CG) Richard Pike Richard P/Kolbers: > I have stalled my MKIII with full flaps and a passenger on board. To my > surprise, the elevator stalled when I attempted to recover. That'll get > your attention. > john h Maybe I should correct the above and further explain my maneuver with full flaps that caused the elevator to stall. I was not performing a full flap stall, but a dive with full flaps, idle power, and an abrupt pull out when we reached 85 mph. Was down at Sun and Fun demonstrating my MKIII to a reporter for an aviation magazine. We were having a good time wringing out most of the neat little things a MKIII is capable of doing safely, when I got the idea to try something I had never done before. That was to pull in full flaps, idle power, push the nose over and dive to 85 mph. At 85 mph pull out of the dive abruptly. When I pulled the stick back abruptly the MKIII kept heading earthward with the elevator fully stalled. Surprise, surprise! First and only time I have had the elevator stall on my MKIII. I can not think of a scenario I could get myself into that would result in a replay of that maneuver. I normally use full flaps for every landing, unless it is really turbulent and/or a severe cross wind, and have no issues with elevator authority. Nope, not ready for VGs under my tail. ;-) john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: Operating at maximum weight
Date: Feb 10, 2011
Rick, I didn't enter the specific exercise in my log book but I did strap several 80 lb salt bags in the passenger seat for a free excursion before I took a passenger. I didn't want to hurt the salt bags. BB On 10, Feb 2011, at 2:29 PM, Richard Girard wrote: > You guys remember that part of your operating instructions that says you'll test the aircraft at max gross weight while in phase 1 testing? You know, buy four bags of sand or cement and put them in the passenger seat and test in all configurations and put this statement in the aircraft's log book, =93I certify that the prescribed flight test hours have been completed and the aircraft is controllable throughout its normal range of speeds and throughout all maneuvers to be executed, has no hazardous operating characteristics or design features, and is safe for operation. The flight test was completed under the following conditions: maximum operating weight, style/set of wing or sail, maximum demonstrated airspeed, and minimum demonstrated stall speed.=94? You all did that, right? By this discussion, I'd say not. > > Rick Girard > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhappy. > - Groucho Marx > > > > > ________________________________________________________________________________
Date: Feb 10, 2011
I have calculated this again it has been a while and I agree with you a Fa t man was not meant to fly in a small airplane, however if i fill my 20 ga llon fuel tank it would help the CG issue but then send the weight over th e Gross limit so I will tell him if he wants to fly to leave 100 lbs home or buy a ticket on a Delta Flight Ellery Batchelder Jr. -----Original Message----- From: Kirby, Dennis Civ USAF AFMC AFNWC/EN <Dennis.Kirby(at)kirtland.af.mil> Sent: Thu, Feb 10, 2011 11:19 am Subject: Kolb-List: Re: Heavy Passengers << speaking of passengers I have a friend that wants a ride in my MK3c and he is 350 lbs im not sure I should even attempt it, the most I have had with me is 250 lbs and 20 gallons fuel Ellery Batchelder Jr. >> Ellery =93 When I calculated the Weight & Balance for my Mark-3, it came out that the MOST heavy passenger I could =9Csafely=9D carry was 250 lbs. This was based on my weight of 190 lbs, and minimal fuel (less than a qu arter tank). In this configuration, the CG was at its forward-most allowa ble point, as specified by Homer. It=99s not a gross weight limitat ion =93 it=99s an out-of-CG issue. I suspect that you are correct =93 taking a 350 lb passenger in your Mark-3 might be a tad risky. Might even put your Kolb at the brink of de struction. Dennis Kirby Mark-III N93DK, =9CMagic Bike=9D New Mexico ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Feb 10, 2011
You guys remember that part of your operating instructions that says you'll test the aircraft at max gross weight while in phase 1 testing? Rick Girard Rick G/Kolbers: Sorry about the previous. I fired a blank. ;-( Was that 91.319? I have trouble remembering 5 minutes ago, much less when I test flew my MKIII. ;-) john h ________________________________________________________________________________
Date: Feb 10, 2011
You guys remember that part of your operating instructions that says you'll test the aircraft at max gross weight while in phase 1 testing? You know, buy four bags of sand or cement and put them in the passenger seat and test in all configurations and put this statement in the aircraft's log book, I certify that the prescribed flight test hours have been completed and the aircraft is controllable throughout its normal range of speeds and throughout all maneuvers to be executed, has no hazardous operating characteristics or design features, and is safe for operation. The flight test was completed under the following conditions: *maximum operating weight*, style/set of wing or sail, maximum demonstrated airspeed, and minimum demonstrated stall speed.? You all did that, right? By this discussion, I'd say not. Rick Girard -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Feb 10, 2011
Ellery: This is bc. You made me laugh out loud when I read your comment below. Maybe I should keep quiet and not share my crazy experiences with these little airplanes. I seem to get folks upset easily. ;-) How are you all making it up in iceland? It never got above 32F here today with snow last night. john ----- Original Message ----- From: "Ellery Batchelder Jr" <elleryweld(at)aol.com> Sent: Thursday, February 10, 2011 2:03 PM Subject: Re: Kolb-List: Re: Heavy Passengers I have calculated this again it has been a while and I agree with you a Fat man was not meant to fly in a small airplane, however if i fill my 20 gallon fuel tank it would help the CG issue but then send the weight over the Gross limit so I will tell him if he wants to fly to leave 100 lbs home or buy a ticket on a Delta Flight Ellery Batchelder Jr. -----Original Message----- From: Kirby, Dennis Civ USAF AFMC AFNWC/EN <Dennis.Kirby(at)kirtland.af.mil> Sent: Thu, Feb 10, 2011 11:19 am Subject: Kolb-List: Re: Heavy Passengers << speaking of passengers I have a friend that wants a ride in my MK3c and he is 350 lbs im not sure I should even attempt it, . the most I have had with me is 250 lbs and 20 gallons fuel Ellery Batchelder Jr. >> Ellery - When I calculated the Weight & Balance for my Mark-3, it came out that the MOST heavy passenger I could "safely" carry was 250 lbs. This was based on my weight of 190 lbs, and minimal fuel (less than a quarter tank). In this configuration, the CG was at its forward-most allowable point, as specified by Homer. It's not a gross weight limitation - it's an out-of-CG issue. I suspect that you are correct - taking a 350 lb passenger in your Mark-3 might be a tad risky. Might even put your Kolb at the brink of destruction. Dennis Kirby Mark-III N93DK, "Magic Bike" New Mexico =================================== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -=========================================================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -=========================================================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -=========================================================== ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Feb 10, 2011
Rick Yes I did load my plane up with salt bags to gross weight and test flew it. The suprising thing was my lack of understanding how much further forward the CG was with a real person than I had figured with the salt bags. The other suprising think was how much worse it gets with a high thrust line an d the extra thrust with the redrive. I did three different maximum weight flight tests with different engine configurations. Rick Neilsen Redrive VW Powered MKIIIC On Thu, Feb 10, 2011 at 2:29 PM, Richard Girard wrote : > You guys remember that part of your operating instructions that says you' ll > test the aircraft at max gross weight while in phase 1 testing? You know, > buy four bags of sand or cement and put them in the passenger seat and te st > in all configurations and put this statement in the aircraft's log book, =93I > certify that the prescribed flight test hours have been completed and the > aircraft is controllable throughout its normal range of speeds and > throughout all maneuvers to be executed, has no hazardous operating > characteristics or design features, and is safe for operation. The > flight test was completed under the following conditions: *maximum > operating weight*, style/set of wing or sail, maximum demonstrated > airspeed, and minimum demonstrated stall speed.=94? You all did that, rig ht? > By this discussion, I'd say not. > > Rick Girard > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhapp y. > - Groucho Marx > > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Feb 10, 2011
Rick I didn't build this particular airplane in fact I am the third owner of it ,it was not my job to do all this testing so I am using the numbers that have been scribed in stone in the paperwork that was included with it Ellery Batchelder Jr. -----Original Message----- From: Richard Girard <aslsa.rng(at)gmail.com> Sent: Thu, Feb 10, 2011 2:29 pm Subject: Kolb-List: Operating at maximum weight You guys remember that part of your operating instructions that says you'l l test the aircraft at max gross weight while in phase 1 testing? You know , buy four bags of sand or cement and put them in the passenger seat and test in all configurations and put this statement in the aircraft's log book, =9CI certify that the prescribed flight test hours have been completed and the aircraft is controllable throughout its normal range of speeds and throughout all maneuvers to be executed, has no hazardous oper ating characteristics or design features, and is safe for operation. The flight test was completed under the following conditions: maximum operat ing weight, style/set of wing or sail, maximum demonstrated airspeed, and minimum demonstrated stall speed.=9D? You all did that, right? By this discussion, I'd say not. Rick Girard -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy . - Groucho Marx ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Subject: IVO prop for Sale
Date: Feb 10, 2011
I have put it up on barnstormers. I am asking $800 OBO IVO 3 bladed in flight adjustable Ultralight Model Propller. 35" to 70" pitch range. 72" diameter (may be cut down to as short as 48" diameter). Includes Spinner. Also includes spacer blocks so you may use it as a 2 bladed propeller. New price is $1,200 without the spinner and blocks. It can be used on a Rotax 2 stroke in the pusher application or Rotax 912's in the tractor application (it might need some kind of adapter from IVO to make it fit the 912 bolt pattern) Jason Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330519#330519 ________________________________________________________________________________
Date: Feb 10, 2011
> Ellery: > > This is bc. > > You made me laugh out loud when I read your comment below. > > Maybe I should keep quiet and not share my crazy experiences with these > little airplanes. I seem to get folks upset easily. =3B-) > > How are you all making it up in iceland? It never got above 32F here toda y > with snow last night. > > john John=2C Saying it's bc=2C don't necessarily make it so!! Trust me=2C I know thes e things!! : ) Mike Welch ________________________________________________________________________________
Date: Feb 10, 2011
At 02:53 PM 2/10/2011, robert bean wrote: >That sounds interesting. -anybody else have stories about passengers >invading the flight controls? Not a Kolb, but years ago I had a girlfriend whose mother had been a glider CFI; she owned the school. On a flight with a student, the tow rope broke on takeoff. Just like an engine out in a powered plane, the procedure is to land straight ahead, which she attempted to do. The student panicked, and being male and much stronger than her, overpowered her on the controls and tried to turn back. About what you'd expect, stall/spin, crash, injuries. The student (who was a doctor and had money for lawyers) sued her, claimed the turning back was _her_ idea (she was, of course, legally PIC). She couldn't afford to fight it and lost her business. When I met her she was flying for some two bit commuter line. -Dana -- Alpha test version: too buggy to release. Beta test version: still too buggy to release. Release 1.0: alternate pronounciation of beta test version. ________________________________________________________________________________
Subject: Re: Insurance
Date: Feb 11, 2011
Since I have been correctly accused of not always being easy to get along with, I've made it a policy not to be worth more dead than alive, so the only life insurance I ever had was provided by my employers if/when they provided it for no cost to me. Ooops, not quite true. When I divorced my first wife, I carried life insurance for our daughter until she came of age. Life insurance is a misnomer anyway, it is income or wealth insurance that requires one's death to give it value. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330571#330571 ________________________________________________________________________________
Date: Feb 11, 2011
Subject: Re: club planes?
Another point of view, same basic subject - flight training in ELSA, a diff erent =0Aconcept of dealing with it.=0ARoger Mills has posted this followin g a conversation with EAA.=0A=0ADate: Thu, February 10, 2011 11:58 am=0ATo: <fly-ul@yahoogroups. com>=0A=0APer EAA---(as of 1 hour ago)=0A=0AAn E is a n E is an E! Regardless of whether it is kit or plans built, EAB or =0AELSA .=0A=0AAn experimental category aircraft of any type cannot be formally ren ted out or =0Aused by anyone "for hire" in any way!!!!!=0A=0ACost sharing f or 'friendly' use by other than the owner is OK to a point--be =0Aready to prove it.=0A=0AA group of people can form a "club" as an LLC, corp or partn ership for the =0Apurpose of building, owning and flying any experimental a ircraft.=0A=0AThe orgainization that functions as a fund raiser must be a s eparate entity from =0Athe one that owns the experimental aircraft.=0A=0ATh e members or partners can be the same people, BUT, separate organizational =0Achart etc.=0A=0A(Even EAA chapters, as the rules stand now, can build bu t not own an aircraft. =0AThis is being worked on to correct.)=0A=0APlans o r scratch built automatically qualify for the "51%", only approved kits =0A qualify, ELSA can be any % but exacly like the SLSA.=0A=0AA repairmans cert ificate for an EAB can be issued to only one person for any =0Aspecific air craft by N number only.=0A=0AA repairmans certificate for an ELSA requires the course and MAY include the =0Amodel???=0A=0AWithout a repairmans certif icate only an AP or better can sign the annual.=0A=0AAny flight instructor can be paid to teach in any experimental aircraft as long =0Aas they have t he qualifications necessary.=0A=0AThe flight instructor may or may not be a n owner/partner in the aircraft.=0A=0AFlight instruction may be given to th e level allowed by the equipment installed =0Ain the aircraft.=0A=0A(I thin k this last one means that you can get full IFR if the aircraft has the =0A stuff)=0A=0AThe individual owner/builder of a two place aircraft, who has r eceived an N =0Anumber for that aircraft, is the only one who can "teach" a nyone else to fly =0Athat aircraft until an otherwise qualified flight inst ructor has been "taught".=0A=0A(I am not sure how to really works--on the s urface it seems to mean that if you =0Abuilt it, flew off the restrictions and got an N number-you are a qualified =0Aflight instructor for that aircr aft only?????, and can be paid to teach in that =0Aaircraft???)=0A=0A=0A(I was specifically told that since flight instruction is desired--the FAA has =0Anot restricted the ability of a flight instructor to teach in an experi mental- =0A--EAB or ELSA. You just CANNOT charge a fee for the aircraft its elf.)=0A=0A(I was also told that insurance is problematic in an experimenta l of any =0Akind--Falcon insurance does it---rates are much different for a Christen Eagle =0Avs a Pete etc. I have not spoken with them.)=0A=0AAgain, Per the EAA. (my comments)=0A=0A-One small item to add--my comment---bas ed on the sum of the conversation and =0Anot specifically stated:=0A=0AThe way the rule is written it gets real grey if one partner pays more than his =0Aor her share of the hourly cost. Say 6 people form a partnership to bui ld an =0Aexperimental aircraft---If one partner pays the entire cost of a o ne hour flight =0Athen the others partners benefit. Confused me for a while but I can see where =0Athe FAA may see that as 5 owners renting the aircra ft to the sixth partner. I =0Asuspect that this kind of thing is why the FA A frouns on "club" ownership of an =0Aexperimental.=0APosted by : Roger Mil ls on UL forum=0A=0A=0A-Malcolm Brubaker =0AMichigan Sport=0APilot Repair =0ALSRM-A, PPC, WS=0A(989)513-3022 =0A=0A=0A=0A=0A________________________ ________=0AFrom: Malcolm Brubaker <brubakermal(at)yahoo.com>=0ATo: kolb-list@m atronics.com=0ASent: Tue, February 8, 2011 10:45:26 AM=0ASubject: Re: Kolb- List: Re: club planes?=0A=0A=0AThere has been some significant discussion o n the topic of training in ELSA =0Aaircraft on some other forums which I am involved in. -CGS Hawk, FLY UL, and =0ALINKDIN are a few. -The respons es in those forums spurred me to write this in =0Aresponse. -Please check out those forums if you are interested!=0A=0Asent to LINKDIN=0A=0AI want t o keep the focus. What we will be doing is essentially taking hamburger =0A and putting it all back together to make a steak.-=0AUltra light flying i s getting more difficult because of the non-availability of =0Atraining. No one is going to give hours of training time and the use of an =0Aaircraft for free. Ultra lights therefore, literally, fly under the radar.-=0ASpor t pilots can't do that quite so readily, but unfortunately, many are trying . =0AWhile an ELSA built to SLSA standards is an appropriate aircraft, many =0Aexperimentals simply do not fit the bill for appropriate training aircr aft. I =0Amake this statement to have it understood that I do not advocate training in ALL =0Aexperimental aircraft.-=0ABack to the focus of this di scussion.-=0AI do not have the background I believe is required for devel oping the type of =0Aformat needed here. I came up through the ranks of ult ra lights as a self taught =0Apilot. I received my BFI, trained several peo ple in ultra lights, then received =0Athe training I needed when Sport Pilo t came to be to transition to a sport pilot =0Alicense.-=0AI have passed the first step - the FOI test - toward getting my CFI. But I do =0Anot have the legal background or the depth of knowledge regarding the FARs I =0Afee l is needed to produce this format in a viable and usable program for the =0ASport Pilot training arena.-=0AMark, if you or someone else who is fol lowing this thread, or even a group of =0Aothers, have the knowledge to pul l this together, I would be willing to =0Acontribute what I can.-=0AThis subject has spurred a lot of discussion as you know here and in other =0Afo rums.-=0ALet's see if we can take it to a desired completion.-=0AThere are some people who would be comfortable training with only a verbal =0Acon tract.-=0AOthers will require a written contract with the basics of cost and damage =0Adeposit and a disclaimer of liability in the event of an acci dent included. =0AStill others will want a written contract in triplicate s pelling out every =0Apossible nuance, required insurances, and a liability waiver signed by the =0Atrainee's family before they feel comfortable takin g on the responsibility. And, =0Ayet others, will require a corporation dev elopment, corporate insurance, an =0Aaircraft meeting specified standards.. ...-=0AWe now need to develop a format that can easily be adapted to allo w each =0Ainstructor to use their own level of comfort as a guide to what t ype of contract =0Athey want to use.-=0AFrom hamburger .... to steak.-M alcolm Brubaker =0AMichigan Sport --=0APilot Repair =0ALSRM-A, PPC, WS =0A(989)513-3022 =0A=0A=0A=0A=0A________________________________=0AFrom: Ma lcolm Brubaker =0ATo: kolb-list(at)matronics.com=0ASent : Mon, February 7, 2011 5:19:27 PM=0ASubject: Re: Kolb-List: Re: club plane s?=0A=0A=0AWe have established the need. -We have proven viability. -We even have an =0Aapparent precedent. -So, what next?=0AAn easy to follow format with all the "legal" jargon included for the average =0A"layman" CFI or old BFI properly providing for that "equity position". -Could =0Asuch a "position" be covered by something so simple as a "damage deposit" on th e =0Aaircraft??-=0A-Malcolm Brubaker =0AMichigan Sport=0APilot Repair =0ALSRM-A, PPC, WS=0A(989)513-3022 =0A=0A=0A=0A=0A_________________________ _______=0AFrom: Mike Welch <mdnanwelch7(at)hotmail.com>=0ATo: kolb-list@matron ics.com=0ASent: Mon, February 7, 2011 9:27:30 AM=0ASubject: RE: Kolb-List: Re: club planes?=0A=0A> The FAA regs allow instruction in any experimental aircraft which is owned by =0A>the person receiving the instruction. > ---- ----=0A> Thom Riddle=0A=0AThom, & knowledgeable 'regs'-guys,=0A-=0A- Your statement above is excellent information, but what about the situation =0Awhere a plane is just given it's airworthiness certificate?=0A- I get the impression what you said is fine for a fully built, previous flown=0Aai rplane, but what about a brand new one?=0A- Once a plane is finally finis hed, aren't you supposed to fly off a certain=0Anumber of hours before some one can be in the plane also?=0A- How does that work?- I never have cle arly understood how this part works.=0A-=0A- After rereading your state ment, I think I'm getting more confused.- If a =0Aperson=0Ahad a CFI teac h him to fly, OF COURSE he could be taught in ANY (legal) =0Aairplane.=0A -=0A- My question is;- How can a guy learn to fly his brand new, neve r flown, just =0Alicenced, experimental airplane?- Can he have an instruc tor go with him on his=0Amaiden flight?- Does anyone know how this works? ?- =0A-=0A- We've had a few recent incidents where lowtime Kolb pilot s bent their planes =0A(and themselves).- What does the FAA regs-say to address this problem?=0A-=0AThanks.=0AMike Welch=0AMkIII=0A =0A=0A=0A ============ =0A=0A=0A=0A ________________________________________________________________________________
Date: Feb 11, 2011
I think you ought to tell him to contact his Congressional representatives. I wrote a fairly large detailed letter to my reps and others a while ago explaining the strangulation the FAA is placing on aviation. So far I have heard zeep from the over 40 letters that I sent. My take is that the mostly old gizzers in DC there would not know how to approach that, since the FAA is executing policy via a congressional mandate. I suppose if enough people contact their Reps, it may create enough pressure to have them look at the overly broad mandate that they gave the FAA, or conversely discover that the FAA is way overreaching, which is what I think. It's a political struggle that we in aviation cannot afford to ignore or loose, we are already seeing the results of us deferring to AOPA and EAA, who in general are no better than the FAA itself, or to express it clearly they are just as much of an "Organization Men" as the drones at the FAA are. They see things in "terms of control" not the way most of us see it as in "terms of freedom". I think it ought to become more obvious that part of our flying will have to start incorporating personal involvement in the political process to truncate FAA budget (most effective) and FAA power (somewhat effective), or else sooner or later they will start coming after our Kolbs Challengers or whatever we fly. The FAA is an agency that is running amok intoxicated by its own power and hubris. ---- Malcolm Brubaker wrote: ============ Ok Group. This was posted on the CGS hawk forum. I want to say Thank You to Danny Dezauche for a well thought out and candid statement. I agree. So, after you all have read it, chime in here and let's figure out what we are going to do about it! To whom it may interest I was told by the FAA that clubs were considered a commercial Entity and therefore were only legal for training with "certified Aircraft". I was also told "primary" training such as a sport pilot License has to be in a certified aircraft. I have been a member Of the oldest club in mobile ala for several years which used Cessnas etc for rent and training. These of course were certified Aircraft We here at cgs have lived with the loda and club question for Several years now. The belief and hope that training can and will Be allowed in Elsa aircraft has existed since the advent of the Light sport category Cgs has only sold 2 slsa models since 2005 and none since April 2009 since I purchased the business. I too see the need For trainers of the ultralight type. Remember. Two seat ultralights Were only allowed by waiver for training purposes only from the start The sale and use of two seaters outside the waiver was one of the reasons for the faa to implement this grand experiment in the U.S.known as Sport pilot. The word from the FAA now is that they will not Allow any More lsa models into the market without prior Audit by the FAA as to their qualifications and engineering Those of us in the lsa market can also expect to be audited By the FAA In The near future to make sure we are in compliance With all astm standards. The confusion over the elsa training issue has had a detremental effect on this segment of aviation obviously. i want to make it clear what my personal and business position is on this issue once and for all i have also said this to the faa we as manufacturers cannot force people to buy slsa aircraft. however if no trainers are available either slsa or elsa no new customers are trained or exposed to our aircraft. i would rather see training in elsa aircraft instead of not at all and that is where we are today we can build slsa's all day long but if no one buys them whats the point an elsa aircraft built by an individual puts most legal ramifications on the owner builder not the factory so i support any measures that will get this segment going and training again however faa is not happy with the results of their audit on the lsa industry which was done over the past two years. So we manufacturers await the future with some fear of the unknown. in a further effort to get slsa trainers out in the field cgs is putting on a sun n fun sale which will be posted on the web site i implore the group to choose someone whom is respected among you to contact the faa and report on their findings i dont expect anyone here to take my word for it and i prefer another voice to concur what ive said sincerely danny dezauche president/cgs aviation Malcolm Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS (989)513-3022 ________________________________ From: Thom Riddle <riddletr(at)gmail.com> Sent: Mon, February 7, 2011 8:49:22 AM Subject: Kolb-List: Re: club planes? Dana, The FAA regs allow instruction in any experimental aircraft which is owned by the person receiving the instruction. My FSDO said that partial ownership or indirect ownership (share holder in a corporation that owns the aircraft) qualifies as long as there is an equity position in the aircraft. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329948#329948 === -- kugelair.com ________________________________________________________________________________
Date: Feb 11, 2011
I have an old article maybe a year old. In it it cites EAA exemption #7162 where a person is allowed to rent and instruct in experimental. If that exemption has not been revoked which I don't see where that happened although it may? All FAA approved!!!!! Ron @ KFHU ============================ ---- Malcolm Brubaker wrote: ============ Another point of view, same basic subject - flight training in ELSA, a different concept of dealing with it. Roger Mills has posted this following a conversation with EAA. Date: Thu, February 10, 2011 11:58 am Per EAA---(as of 1 hour ago) An E is an E is an E! Regardless of whether it is kit or plans built, EAB or ELSA. An experimental category aircraft of any type cannot be formally rented out or used by anyone "for hire" in any way!!!!! Cost sharing for 'friendly' use by other than the owner is OK to a point--be ready to prove it. A group of people can form a "club" as an LLC, corp or partnership for the purpose of building, owning and flying any experimental aircraft. The orgainization that functions as a fund raiser must be a separate entity from the one that owns the experimental aircraft. The members or partners can be the same people, BUT, separate organizational chart etc. (Even EAA chapters, as the rules stand now, can build but not own an aircraft. This is being worked on to correct.) Plans or scratch built automatically qualify for the "51%", only approved kits qualify, ELSA can be any % but exacly like the SLSA. A repairmans certificate for an EAB can be issued to only one person for any specific aircraft by N number only. A repairmans certificate for an ELSA requires the course and MAY include the model??? Without a repairmans certificate only an AP or better can sign the annual. Any flight instructor can be paid to teach in any experimental aircraft as long as they have the qualifications necessary. The flight instructor may or may not be an owner/partner in the aircraft. Flight instruction may be given to the level allowed by the equipment installed in the aircraft. (I think this last one means that you can get full IFR if the aircraft has the stuff) The individual owner/builder of a two place aircraft, who has received an N number for that aircraft, is the only one who can "teach" anyone else to fly that aircraft until an otherwise qualified flight instructor has been "taught". (I am not sure how to really works--on the surface it seems to mean that if you built it, flew off the restrictions and got an N number-you are a qualified flight instructor for that aircraft only?????, and can be paid to teach in that aircraft???) (I was specifically told that since flight instruction is desired--the FAA has not restricted the ability of a flight instructor to teach in an experimental- --EAB or ELSA. You just CANNOT charge a fee for the aircraft itself.) (I was also told that insurance is problematic in an experimental of any kind--Falcon insurance does it---rates are much different for a Christen Eagle vs a Pete etc. I have not spoken with them.) Again, Per the EAA. (my comments) One small item to add--my comment---based on the sum of the conversation and not specifically stated: The way the rule is written it gets real grey if one partner pays more than his or her share of the hourly cost. Say 6 people form a partnership to build an experimental aircraft---If one partner pays the entire cost of a one hour flight then the others partners benefit. Confused me for a while but I can see where the FAA may see that as 5 owners renting the aircraft to the sixth partner. I suspect that this kind of thing is why the FAA frouns on "club" ownership of an experimental. Posted by : Roger Mills on UL forum Malcolm Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS (989)513-3022 ________________________________ From: Malcolm Brubaker <brubakermal(at)yahoo.com> Sent: Tue, February 8, 2011 10:45:26 AM Subject: Re: Kolb-List: Re: club planes? There has been some significant discussion on the topic of training in ELSA aircraft on some other forums which I am involved in. CGS Hawk, FLY UL, and LINKDIN are a few. The responses in those forums spurred me to write this in response. Please check out those forums if you are interested! sent to LINKDIN I want to keep the focus. What we will be doing is essentially taking hamburger and putting it all back together to make a steak. Ultra light flying is getting more difficult because of the non-availability of training. No one is going to give hours of training time and the use of an aircraft for free. Ultra lights therefore, literally, fly under the radar. Sport pilots can't do that quite so readily, but unfortunately, many are trying. While an ELSA built to SLSA standards is an appropriate aircraft, many experimentals simply do not fit the bill for appropriate training aircraft. I make this statement to have it understood that I do not advocate training in ALL experimental aircraft. Back to the focus of this discussion. I do not have the background I believe is required for developing the type of format needed here. I came up through the ranks of ultra lights as a self taught pilot. I received my BFI, trained several people in ultra lights, then received the training I needed when Sport Pilot came to be to transition to a sport pilot license. I have passed the first step - the FOI test - toward getting my CFI. But I do not have the legal background or the depth of knowledge regarding the FARs I feel is needed to produce this format in a viable and usable program for the Sport Pilot training arena. Mark, if you or someone else who is following this thread, or even a group of others, have the knowledge to pull this together, I would be willing to contribute what I can. This subject has spurred a lot of discussion as you know here and in other forums. Let's see if we can take it to a desired completion. There are some people who would be comfortable training with only a verbal contract. Others will require a written contract with the basics of cost and damage deposit and a disclaimer of liability in the event of an accident included. Still others will want a written contract in triplicate spelling out every possible nuance, required insurances, and a liability waiver signed by the trainee's family before they feel comfortable taking on the responsibility. And, yet others, will require a corporation development, corporate insurance, an aircraft meeting specified standards..... We now need to develop a format that can easily be adapted to allow each instructor to use their own level of comfort as a guide to what type of contract they want to use. >From hamburger .... to steak.Malcolm Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS (989)513-3022 ________________________________ From: Malcolm Brubaker <brubakermal(at)yahoo.com> Sent: Mon, February 7, 2011 5:19:27 PM Subject: Re: Kolb-List: Re: club planes? We have established the need. We have proven viability. We even have an apparent precedent. So, what next? An easy to follow format with all the "legal" jargon included for the average "layman" CFI or old BFI properly providing for that "equity position". Could such a "position" be covered by something so simple as a "damage deposit" on the aircraft?? Malcolm Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS (989)513-3022 ________________________________ From: Mike Welch <mdnanwelch7(at)hotmail.com> Sent: Mon, February 7, 2011 9:27:30 AM Subject: RE: Kolb-List: Re: club planes? > The FAA regs allow instruction in any experimental aircraft which is owned by >the person receiving the instruction. > -------- > Thom Riddle Thom, & knowledgeable 'regs'guys, Your statement above is excellent information, but what about the situation where a plane is just given it's airworthiness certificate? I get the impression what you said is fine for a fully built, previous flown airplane, but what about a brand new one? Once a plane is finally finished, aren't you supposed to fly off a certain number of hours before someone can be in the plane also? How does that work? I never have clearly understood how this part works. After rereading your statement, I think I'm getting more confused. If a person had a CFI teach him to fly, OF COURSE he could be taught in ANY (legal) airplane. My question is; How can a guy learn to fly his brand new, never flown, just licenced, experimental airplane? Can he have an instructor go with him on his maiden flight? Does anyone know how this works?? We've had a few recent incidents where lowtime Kolb pilots bent their planes (and themselves). What does the FAA regssay to address this problem? Thanks. Mike Welch MkIII ============ -- kugelair.com ________________________________________________________________________________
Date: Feb 11, 2011
I have an old article maybe a year old. In it it cites EAA exemption #7162 where a person is allowed to rent and instruct in experimental. If that exemption has not been revoked which I don't see where that happened although it may? All FAA approved!!!!! Ron @ KFHU Ron/Kolbers: Try this one: http://www.eaa.org/news/2007/2007-11-01_exemption.asp Folks, see if you can clean up your posts prior to hitting the send button. Leave enough of the previous post as a reference to know where you are coming from. Helps a whole bunch when we are searching for info in the Kolb List Archives. Thanks, john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 11, 2011
Hello All, When I was flying off my 40 hours I loaded up the cockpit with a couple of 80# bags of cement and tested the forward limit, I then strapped some diving weights around the tail to test the aft limit. The plane flew much better (lighter on the controls) near the aft limit than the forward limit. So much better that I would suggest anyone building a MKIII to set the airplane up so that with you in the pilots seat, you are at the aft limit. This would allow the you to put more weight in before you reach the forward limit and will make the airplane feel lighter on the controls when just tooling around solo. My $.02 Jason Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330613#330613 ________________________________________________________________________________
Date: Feb 11, 2011
*"ELSA can be any % but exacly like the SLSA."* This statement is true at the time the DAR or FAA inspector is examining the aircraft for issuance of the airworthiness certificate. At that time the aircraft must be exactly like the qualifying S-LSA *OR* there must be Letters of Authorization from the manufacturer listing the change and the specific N number of the aircraft with the change. Once the airworthiness certificate is issued, an E-LSA is no different than an E-AB. Any modification the owner wishes to do may be done. As Edsel Ford of the FAA's Light Sport Branch told me, "experimental is experimental". Rick Girard On Fri, Feb 11, 2011 at 11:01 AM, Malcolm Brubaker wrote: > Another point of view, same basic subject - flight training in ELSA, a > different concept of dealing with it. > Roger Mills has posted this following a conversation with EAA. > > Date: Thu, February 10, 2011 11:58 am > To: <fly-ul@yahoogroups. com > > > Per EAA---(as of 1 hour ago) > > An E is an E is an E! Regardless of whether it is kit or plans built, EAB > or ELSA. > > An experimental category aircraft of any type cannot be formally rented out > or used by anyone "for hire" in any way!!!!! > > Cost sharing for 'friendly' use by other than the owner is OK to a > point--be ready to prove it. > > A group of people can form a "club" as an LLC, corp or partnership for the > purpose of building, owning and flying any experimental aircraft. > > The orgainization that functions as a fund raiser must be a separate entity > from the one that owns the experimental aircraft. > > The members or partners can be the same people, BUT, separate > organizational chart etc. > > (Even EAA chapters, as the rules stand now, can build but not own an > aircraft. This is being worked on to correct.) > > Plans or scratch built automatically qualify for the "51%", only approved > kits qualify, ELSA can be any % but exacly like the SLSA. > > A repairmans certificate for an EAB can be issued to only one person for > any specific aircraft by N number only. > > A repairmans certificate for an ELSA requires the course and MAY include > the model??? > > Without a repairmans certificate only an AP or better can sign the annual. > > Any flight instructor can be paid to teach in any experimental aircraft as > long as they have the qualifications necessary. > > The flight instructor may or may not be an owner/partner in the aircraft. > > Flight instruction may be given to the level allowed by the equipment > installed in the aircraft. > > (I think this last one means that you can get full IFR if the aircraft has > the stuff) > > The individual owner/builder of a two place aircraft, who has received an N > number for that aircraft, is the only one who can "teach" anyone else to fly > that aircraft until an otherwise qualified flight instructor has been > "taught". > > (I am not sure how to really works--on the surface it seems to mean that if > you built it, flew off the restrictions and got an N number-you are a > qualified flight instructor for that aircraft only?????, and can be paid to > teach in that aircraft???) > > > (I was specifically told that since flight instruction is desired--the FAA > has not restricted the ability of a flight instructor to teach in an > experimental- --EAB or ELSA. You just CANNOT charge a fee for the aircraft > itself.) > > (I was also told that insurance is problematic in an experimental of any > kind--Falcon insurance does it---rates are much different for a Christen > Eagle vs a Pete etc. I have not spoken with them.) > > Again, Per the EAA. (my comments) > > One small item to add--my comment---based on the sum of the conversation > and not specifically stated: > > The way the rule is written it gets real grey if one partner pays more than > his or her share of the hourly cost. Say 6 people form a partnership to > build an experimental aircraft---If one partner pays the entire cost of a > one hour flight then the others partners benefit. Confused me for a while > but I can see where the FAA may see that as 5 owners renting the aircraft to > the sixth partner. I suspect that this kind of thing is why the FAA frouns > on "club" ownership of an experimental. > Posted by : Roger Mills on UL forum > > > Malcolm Brubaker > Michigan Sport > Pilot Repair > LSRM-A, PPC, WS > (989)513-3022 > > > ------------------------------ > *From:* Malcolm Brubaker > *To:* kolb-list(at)matronics.com > *Sent:* Tue, February 8, 2011 10:45:26 AM > *Subject:* Re: Kolb-List: Re: club planes? > > There has been some significant discussion on the topic of training in > ELSA aircraft on some other forums which I am involved in. CGS Hawk, FLY > UL, and LINKDIN are a few. The responses in those forums spurred me to > write this in response. Please check out those forums if you are > interested! > > sent to LINKDIN > > I want to keep the focus. What we will be doing is essentially taking > hamburger and putting it all back together to make a steak. > Ultra light flying is getting more difficult because of the > non-availability of training. No one is going to give hours of training time > and the use of an aircraft for free. Ultra lights therefore, literally, fly > under the radar. > Sport pilots can't do that quite so readily, but unfortunately, many are > trying. While an ELSA built to SLSA standards is an appropriate aircraft, > many experimentals simply do not fit the bill for appropriate training > aircraft. I make this statement to have it understood that I do not advocate > training in ALL experimental aircraft. > Back to the focus of this discussion. > I do not have the background I believe is required for developing the type > of format needed here. I came up through the ranks of ultra lights as a self > taught pilot. I received my BFI, trained several people in ultra lights, > then received the training I needed when Sport Pilot came to be to > transition to a sport pilot license. > I have passed the first step - the FOI test - toward getting my CFI. But I > do not have the legal background or the depth of knowledge regarding the > FARs I feel is needed to produce this format in a viable and usable program > for the Sport Pilot training arena. > Mark, if you or someone else who is following this thread, or even a group > of others, have the knowledge to pull this together, I would be willing to > contribute what I can. > This subject has spurred a lot of discussion as you know here and in other > forums. > Let's see if we can take it to a desired completion. > There are some people who would be comfortable training with only a verbal > contract. > Others will require a written contract with the basics of cost and damage > deposit and a disclaimer of liability in the event of an accident included. > Still others will want a written contract in triplicate spelling out every > possible nuance, required insurances, and a liability waiver signed by the > trainee's family before they feel comfortable taking on the responsibility. > And, yet others, will require a corporation development, corporate > insurance, an aircraft meeting specified standards..... > We now need to develop a format that can easily be adapted to allow each > instructor to use their own level of comfort as a guide to what type of > contract they want to use. > From hamburger .... to steak. > > Malcolm Brubaker > Michigan Sport > Pilot Repair > LSRM-A, PPC, WS > (989)513-3022 > > > ------------------------------ > *From:* Malcolm Brubaker > *To:* kolb-list(at)matronics.com > *Sent:* Mon, February 7, 2011 5:19:27 PM > *Subject:* Re: Kolb-List: Re: club planes? > > We have established the need. We have proven viability. We even have > an apparent precedent. So, what next? > An easy to follow format with all the "legal" jargon included for the > average "layman" CFI or old BFI properly providing for that "equity > position". Could such a "position" be covered by something so simple as a > "damage deposit" on the aircraft?? > > > Malcolm Brubaker > Michigan Sport > Pilot Repair > LSRM-A, PPC, WS > (989)513-3022 > > > ------------------------------ > *From:* Mike Welch > *To:* kolb-list(at)matronics.com > *Sent:* Mon, February 7, 2011 9:27:30 AM > *Subject:* RE: Kolb-List: Re: club planes? > > > The FAA regs allow instruction in any experimental aircraft which is > owned by the person receiving the instruction. > -------- > > Thom Riddle > > Thom, & knowledgeable 'regs' guys, > > Your statement above is excellent information, but what about the > situation > where a plane is just given it's airworthiness certificate? > I get the impression what you said is fine for a fully built, previous > flown > airplane, but what about a brand new one? > Once a plane is finally finished, aren't you supposed to fly off a > certain > number of hours before someone can be in the plane also? > How does that work? I never have clearly understood how this part works. > > After rereading your statement, I think I'm getting more confused. If a > person > had a CFI teach him to fly, OF COURSE he could be taught in ANY (legal) > airplane. > > My question is; How can a guy learn to fly his brand new, never flown, > just > licenced, experimental airplane? Can he have an instructor go with him on > his > maiden flight? Does anyone know how this works?? > > We've had a few recent incidents where lowtime Kolb pilots bent their > planes > (and themselves). What does the FAA regs say to address this problem? > > Thanks. > Mike Welch > MkIII > > * > > * > > > ** > > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Feb 11, 2011
Jason, Please define "test the aft limit". Rick Girard On Fri, Feb 11, 2011 at 12:04 PM, Jason Omelchuck <jason@trek-tech.com>wrote: > > Hello All, > > When I was flying off my 40 hours I loaded up the cockpit with a couple of > 80# bags of cement and tested the forward limit, I then strapped some diving > weights around the tail to test the aft limit. The plane flew much better > (lighter on the controls) near the aft limit than the forward limit. So > much better that I would suggest anyone building a MKIII to set the airplane > up so that with you in the pilots seat, you are at the aft limit. This > would allow the you to put more weight in before you reach the forward limit > and will make the airplane feel lighter on the controls when just tooling > around solo. > > My $.02 > Jason > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330613#330613 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Feb 11, 2011
On 2/11/2011 11:01 AM, Malcolm Brubaker wrote: > Another point of view, same basic subject - flight training in ELSA, a > different concept of dealing with it. > Roger Mills has posted this following a conversation with EAA. > > Date: Thu, February 10, 2011 11:58 am > To: <fly-ul@yahoogroups. com > > > Per EAA---(as of 1 hour ago) > An E is an E is an E! Regardless of whether it is kit or plans built, > EAB or ELSA. > An experimental category aircraft of any type cannot be formally > rented out or used by anyone "for hire" in any way!!!!! > Cost sharing for 'friendly' use by other than the owner is OK to a > point--be ready to prove it. > A group of people can form a "club" as an LLC, corp or partnership for > the purpose of building, owning and flying any experimental aircraft. > The orgainization that functions as a fund raiser must be a separate > entity from the one that owns the experimental aircraft. > The members or partners can be the same people, BUT, separate > organizational chart etc. > (Even EAA chapters, as the rules stand now, can build but not own an > aircraft. This is being worked on to correct.) > Plans or scratch built automatically qualify for the "51%", only > approved kits qualify, ELSA can be any % but exacly like the SLSA. > A repairmans certificate for an EAB can be issued to only one person > for any specific aircraft by N number only. > A repairmans certificate for an ELSA requires the course and MAY > include the model??? > Without a repairmans certificate only an AP or better can sign the annual. > Any flight instructor can be paid to teach in any experimental > aircraft as long as they have the qualifications necessary. > The flight instructor may or may not be an owner/partner in the aircraft. > Flight instruction may be given to the level allowed by the equipment > installed in the aircraft. > (I think this last one means that you can get full IFR if the aircraft > has the stuff) > The individual owner/builder of a two place aircraft, who has received > an N number for that aircraft, is the only one who can "teach" anyone > else to fly that aircraft until an otherwise qualified flight > instructor has been "taught". > (I am not sure how to really works--on the surface it seems to mean > that if you built it, flew off the restrictions and got an N > number-you are a qualified flight instructor for that aircraft > only?????, and can be paid to teach in that aircraft???) > (I was specifically told that since flight instruction is desired--the > FAA has not restricted the ability of a flight instructor to teach in > an experimental- --EAB or ELSA. You just CANNOT charge a fee for the > aircraft itself.) > (I was also told that insurance is problematic in an experimental of > any kind--Falcon insurance does it---rates are much different for a > Christen Eagle vs a Pete etc. I have not spoken with them.) > > Again, Per the EAA. (my comments) > > One small item to add--my comment---based on the sum of the > conversation and not specifically stated: > > The way the rule is written it gets real grey if one partner pays more > than his or her share of the hourly cost. Say 6 people form a > partnership to build an experimental aircraft---If one partner pays > the entire cost of a one hour flight then the others partners benefit. > Confused me for a while but I can see where the FAA may see that as 5 > owners renting the aircraft to the sixth partner. I suspect that this > kind of thing is why the FAA frouns on "club" ownership of an > experimental. > Posted by : Roger Mills on UL forum > > Malcolm Brubaker > Michigan Sport > Pilot Repair > LSRM-A, PPC, WS > (989)513-3022 A couple of thoughts: quote The individual owner/builder of a two place aircraft, who has received an N number for that aircraft, is the only one who can "teach" anyone else to fly that aircraft until an otherwise qualified flight instructor has been "taught". unquote I've never seen that in the form that it's written. I wonder if it is specific to the 'exemption' for transition training in a homebuilt experimental. That exemption isn't for what most would consider flight training; it's an exemption to provide *transition* instruction for a qualified pilot to get comfortable in *that particular design*, new-to-him/her experimental a/c. For example, a 5000 hr ex-military pilot who's only flown C-130's & never a light plane, would need instruction to handle a taildragger homebuilt like a Thorp T-18 (or Kolb). On the overall question of 'club' a/c: people may be getting the wrong (undesirable) answer because they are asking the wrong question. The word 'club' probably does trigger a reaction from the FAA, because most clubs operate as businesses, charging monthly dues, etc. If the question was phrased as 'multiple owners', or 'partnership', there would probably be a different answer. If you search FAA records, you'll find many experimental homebuilts registered to partnerships, and even corporations. As the EAA said, any experimental can be used for instruction, as long as there is no payment to the owner for the use of the a/c (commercial use). I have read about (but have no direct experience) that an experimental can even be loaned to a non-owner for training. Memory is less clear on whether a third-party instructor can be paid in that scenario. The question of 5 owners 'renting' to the 6th owner probably wouldn't come up as long as most of the owners fly at least occasionally, & all share more or less equally in fixed costs like insurance & annuals. I'd bet that a more likely problem is going to be finding an instructor whose liability insurance will cover him while instructing in a homebuilt. Not saying it makes sense; it's just an unfortunate reality. Charlie ________________________________________________________________________________
Subject: Re: Heavy Passengers
Date: Feb 11, 2011
its the opposite of testing the forward limit :) I did not test how far aft the CG could be, I tested it at the aft limit that was published in the builders manual (or what I got from searching this list). I am not brave enough nor do I have the skill to actually test it to the physical limit. I just felt that if I was going to make the entry in the log that I had tested it through out is operating range I should take it to the limits I published in my weight and balance documents. I do not remember what those limits are off the top of my head. [quote="rickofudall"]Jason, Please define "test the aft limit". Rick Garrard On Fri, Feb 11, 2011 at 12:04 PM, Jason Omelchuck wrote: > > > Hello All, > > When I was flying off my 40 hours I loaded up the cockpit with a couple of 80# bags of cement and tested the forward limit, I then strapped some diving weights around the tail to test the aft limit. The plane flew much better (lighter on the controls) near the aft limit than the forward limit. So much better that I would suggest anyone building a MKIII to set the airplane up so that with you in the pilots seat, you are at the aft limit. This would allow the you to put more weight in before you reach the forward limit and will make the airplane feel lighter on the controls when just tooling around solo. > > My $.02 > Jason > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330613#330613 (http://forums.matronics.com/viewtopic.php?p=330613#330613) > > > > > > > > ========== > arget="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx > [b] [Wink] [Wink] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330666#330666 ________________________________________________________________________________
Date: Feb 11, 2011
I understand setting weight and balance for the aft range of the cg envelope. The question was meant as what did you test? Stalls with all flap settings, both approach and departure? Stalls while banked to right and left? Accelerated stalls? Rick Girard On Fri, Feb 11, 2011 at 5:49 PM, Jason Omelchuck <jason@trek-tech.com>wrote : > > its the opposite of testing the forward limit :) I did not test how far > aft the CG could be, I tested it at the aft limit that was published in t he > builders manual (or what I got from searching this list). I am not brave > enough nor do I have the skill to actually test it to the physical limit. I > just felt that if I was going to make the entry in the log that I had tes ted > it through out is operating range I should take it to the limits I publis hed > in my weight and balance documents. I do not remember what those limits are > off the top of my head. > > > [quote="rickofudall"]Jason, Please define "test the aft limit". > > Rick Garrard > > On Fri, Feb 11, 2011 at 12:04 PM, Jason Omelchuck wrote: > > > > > > > Hello All, > > > > When I was flying off my 40 hours I loaded up the cockpit with a coupl e > of 80# bags of cement and tested the forward limit, I then strapped some > diving weights around the tail to test the aft limit. =EF=BDThe plane flew much > better (lighter on the controls) near the aft limit than the forward limi t. > =EF=BDSo much better that I would suggest anyone building a MKIII to s et the > airplane up so that with you in the pilots seat, you are at the aft limit . > =EF=BDThis would allow the you to put more weight in before you reach the forward > limit and will make the airplane feel lighter on the controls when just > tooling around solo. > > > > My $.02 > > Jason > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=330613#330613 ( > http://forums.matronics.com/viewtopic.php?p=330613#330613) > > > > > > > > > > > > > > > > ========== > > arget="_blank">http://www.matronics.com/Navigator?Kolb-List > > ========== > > http://forums.matronics.com > > ========== > > le, List Admin. > > ="_blank">http://www.matronics.com/contribution > > ========== > > > > > > > > > > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > > It isn't necessary to have relatives in Kansas City in order to be unhapp y. > =EF=BD - Groucho Marx > > > > [b] > [Wink] [Wink] > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330666#330666 > > =========== =========== =========== =========== > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Feb 11, 2011
Several heavy pilot vignettes from of old: #1 In the M2 days I took up a passenger who weighed 350 lb.; this with a 503. Hardest part was keeping his overflowing blubber from interfering with the control stick. Take off and climb were predictably anemic, but once cruise was established it wasn't too bad. This was from Kolb Int. where we had 3,000 ft of runway. I forgot how long the TO roll was. Significant back stick pressure was required. #2 An impromptu flying session of hopping rides from a mowed hayfield with a 582 M3 went well until someone got in who was very heavy. He was huge!. I figured I could get him off the ground, but the gear and very nice wheel pants would take a beating on the rough field. What to do?? The answer was on short final and about to arrive . the seat belts would not reach around his considerable girth. But! Then he said, that's ok - I don't need a seat belt. Well . the conservative side of a very wild flyer surfaced surprising quickly and spurted, sorry - can't do that - not safe. Saved by the belt! So, this is a very diplomatic solution to the overweight problem - just provide enough belt length to encompass a passenger you don't mind hauling and you won't have too worry about what to say to the wide bodies that plop in you airplane. #3 Take-off from SNF with heavy passenger and stiff cross wind in 582 M3 with full swivel non-steering tailwheel. Not very smart! Crosswind soon had me at full rudder and still drifting to the right toward planes and people. Too much momentum toward the crowd to stop. All of a sudden I realized how much directional control the tailwheel provided :-o But too late to do anything except push the throttle harder and start praying for altitude. The passenger looked over at me wondering if I was paying attention to our heading. Just in time we were in the air with a bit more speed and control reestablished. That was the end of our non-steering tailwheel project. Dennis _____ From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: Friday, February 11, 2011 9:21 PM Subject: Re: Kolb-List: Re: Heavy Passengers I understand setting weight and balance for the aft range of the cg envelope. The question was meant as what did you test? Stalls with all flap settings, both approach and departure? Stalls while banked to right and left? Accelerated stalls? Rick Girard ________________________________________________________________________________
Date: Feb 12, 2011
Several heavy pilot vignettes from of old: Dennis Dennis S/Kolbers: Thanks for sharing your stories. I am looking forward to many more. There is a lot of Kolb history, but most of it is in our memories and not on paper. What I thought would remain vivid in my memory yesterday is not necessarily so today. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 12, 2011
When I was flying off my 40 hours I loaded up the cockpit with a couple of 80# bags of cement and tested the forward limit, I then strapped some diving weights around the tail to test the aft limit. Jason Jason O/Kolbers:\ John Williamson did the same thing you did during testing of his Kolbra, only he took it a bit further. John kept increasing weight until the Kolbra would not fly, either forward or aft excess cg. During one test of the rear CG limit, John stalled the Kolbra to discover it would not recover from the stall. Full power was required to get out of the stall and fly again. I sure miss my flying buddy. john h MKIII Titus, Alabama ________________________________________________________________________________
Date: Feb 12, 2011
for those following this thread in-depth and looking toward a solution, ple ase =0Aread this article and give your feed-back.=C2- also, looking into templates for =0Aagreements...=0A=0ACo-Ownership: Navigating Airplane Partn erships -=C2-Plane=C2-& Pilot...=0A21 Oct 2008=C2- This is t he simplest=C2-multiple-owner=C2-arrangement.=C2- There are =0Aseveral agreement=C2-templates=C2-online (for example, try=C2-AOPA 's=C2- indirect operating =0Acosts like pilot=C2-training, han gars, etc.=C2-=0A=C2-Malcolm Brubaker =0AMichigan Sport=0APilo t Repair =0ALSRM-A, PPC, WS=0A(989)513-3022 =0A=0A=0A=0A=0A________________ ________________=0AFrom: Charlie England <ceengland(at)bellsouth.net>=0ATo: ko lb-list(at)matronics.com=0ASent: Fri, February 11, 2011 2:58:00 PM=0ASubject: Re: Kolb-List: Re: club planes?=0A=0AOn 2/11/2011 11:01 AM, Malcolm Brubake r wrote: =0AAnother point of view, same basic subject - flight training in ELSA, a different =0Aconcept of dealing with it.=0A>Roger Mills has posted this following a conversation with EAA.=0A>=0A>Date: Thu, February 10, 2011 11:58 am=0A>To: <fly-ul@yahoogroups. com>=0A>=0A>Per EAA---(as of 1 hour a go)=0A>An E is an E is an E! Regardless of whether it is kit or plans built , EAB or =0A>ELSA.=0A>An experimental category aircraft of any type cannot be formally rented out or =0A>used by anyone "for hire" in any way!!!!!=0A> Cost sharing for 'friendly' use by other than the owner is OK to a point--b e =0A>ready to prove it.=0A>A group of people can form a "club" as an LLC, corp or partnership for the =0A>purpose of building, owning and flying any experimental aircraft.=0A>The orgainization that functions as a fund raiser must be a separate entity from =0A>the one that owns the experimental airc raft.=0A>The members or partners can be the same people, BUT, separate orga nizational =0A>chart etc.=0A>(Even EAA chapters, as the rules stand now, ca n build but not own an aircraft. =0A>This is being worked on to correct.) =0A>Plans or scratch built automatically qualify for the "51%", only approv ed kits =0A>qualify, ELSA can be any % but exacly like the SLSA.=0A>A repai rmans certificate for an EAB can be issued to only one person for any =0A>s pecific aircraft by N number only.=0A>A repairmans certificate for an ELSA requires the course and MAY include the =0A>model???=0A>Without a repairman s certificate only an AP or better can sign the annual.=0A>Any flight instr uctor can be paid to teach in any experimental aircraft as long =0A>as they have the qualifications necessary.=0A>The flight instructor may or may not be an owner/partner in the aircraft.=0A>Flight instruction may be given to the level allowed by the equipment installed =0A>in the aircraft.=0A>(I th ink this last one means that you can get full IFR if the aircraft has the =0A>stuff)=0A>The individual owner/builder of a two place aircraft, who has received an N =0A>number for that aircraft, is the only one who can "teach " anyone else to fly =0A>that aircraft until an otherwise qualified flight instructor has been "taught".=0A>(I am not sure how to really works--on the surface it seems to mean that if you =0A>built it, flew off the restrictio ns and got an N number-you are a qualified =0A>flight instructor for that a ircraft only?????, and can be paid to teach in that =0A>aircraft???)=0A>(I was specifically told that since flight instruction is desired--the FAA has =0A>not restricted the ability of a flight instructor to teach in an exper imental- =0A>--EAB or ELSA. You just CANNOT charge a fee for the aircraft i tself.)=0A>(I was also told that insurance is problematic in an experimenta l of any =0A>kind--Falcon insurance does it---rates are much different for a Christen Eagle =0A>vs a Pete etc. I have not spoken with them.)=0A>=0A>Ag ain, Per the EAA. (my comments)=0A>=0A>=C2-One small item to add--my comm ent---based on the sum of the conversation and =0A>not specifically stated: =0A>=0A>The way the rule is written it gets real grey if one partner pays m ore than his =0A>or her share of the hourly cost. Say 6 people form a partn ership to build an =0A>experimental aircraft---If one partner pays the enti re cost of a one hour flight =0A>then the others partners benefit. Confused me for a while but I can see where =0A>the FAA may see that as 5 owners re nting the aircraft to the sixth partner. I =0A>suspect that this kind of th ing is why the FAA frouns on "club" ownership of an =0A>experimental.=0A>Po sted by : Roger Mills on UL forum=0A>=0A>=0A>=C2-Malcolm Brubaker =0A>Mic higan Sport=0A>Pilot Repair =0A>LSRM-A, PPC, WS=0A>(989)513-3022=0A>A coupl e of thoughts:=0A=0Aquote=0AThe individual owner/builder of a two place air craft, who has received an N =0Anumber for that aircraft, is the only one w ho can "teach" anyone else to fly =0Athat aircraft until an otherwise quali fied flight instructor has been "taught".=0Aunquote=0A=0AI've never seen th at in the form that it's written. I wonder if it is specific =0Ato the 'exe mption' for transition training in a homebuilt experimental. That =0Aexempt ion isn't for what most would consider flight training; it's an exemption =0Ato provide *transition* instruction for a qualified pilot to get comfort able in =0A*that particular design*, new-to-him/her experimental a/c. For e xample, a 5000 =0Ahr ex-military pilot who's only flown C-130's & never a l ight plane, would need =0Ainstruction to handle a taildragger homebuilt lik e a Thorp T-18 (or Kolb).=0A=0AOn the overall question of 'club' a/c: peopl e may be getting the wrong =0A(undesirable) answer because they are asking the wrong question. The word 'club' =0Aprobably does trigger a reaction fro m the FAA, because most clubs operate as =0Abusinesses, charging monthly du es, etc. If the question was phrased as 'multiple =0Aowners', or 'partnersh ip',=C2- there would probably be a different answer. If you =0Asearch FAA records, you'll find many experimental homebuilts registered to =0Apartner ships, and even corporations. As the EAA said, any experimental can be =0Au sed for instruction, as long as there is no payment to the owner for the us e of =0Athe a/c (commercial use). I have read about (but have no direct exp erience) that =0Aan experimental can even be loaned to a non-owner for trai ning. Memory is less =0Aclear on whether a third-party instructor can be pa id in that scenario. The =0Aquestion of 5 owners 'renting' to the 6th owner probably wouldn't come up as =0Along as most of the owners fly at least oc casionally, & all share more or less =0Aequally in fixed costs like insuran ce & annuals. =0A=0A=0AI'd bet that a more likely problem is going to be fi nding an instructor whose =0Aliability insurance will cover him while instr ucting in a homebuilt. Not saying =0Ait makes sense; it's just an unfortuna ====================== =0A=0A =0A=0A =0A_________________________________________________________________ ___________________=0ADon't get soaked. Take a quick peek at the forecast /shortcuts/#loc_weather ________________________________________________________________________________
Date: Feb 12, 2011
John Hauck > Folks, see if you can clean up your posts prior to hitting the send button. Leave enough of the previous post as a reference to know where you are > coming from. Helps a whole bunch when we are searching for info in the Kolb > List Archives. > > Thanks, > > john h > mkIII > Titus, Alabama Posts can be cleaned up using the "edit" button to the right. Here's how you do it: Log in and go to your post that you made. It doesn't matter how old it is. Click the "edit" button to the right (not the right mouse click) and change/delete what you need to and click on "submit" below. That's it. Try it and then look for the new posting. I thought you guys might like to know since there are a lot of posts that are sent and later changed by adding a new posting. Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000 hours 24 years flying it Kolbra 912UL N20386 3 years flying it 150 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330784#330784 ________________________________________________________________________________
Subject: changing a posting
Date: Feb 12, 2011
Posts can be cleaned up using the "edit" button to the right. Here's how you do it: Log in and go to your post that you made. It doesn't matter how old it is. Click the "edit" button to the right (not the right mouse click) and change/delete what you need to and click on "submit" below. That's it. Try it and then look for the new posting. I thought you guys might like to know since there are a lot of posts that are sent and later changed by adding a new posting. Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000 hours 24 years flying it Kolbra 912UL N20386 3 years flying it 150 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330785#330785 ________________________________________________________________________________
Date: Feb 12, 2011
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: changing a posting
- Ralph- I don't have an "edit" button, or a "submit" button.- Maybe yo u have a different format than I get. - ------------------------- -------------------- Bill Sullivan ------------------------- -------------------- Windsor Locks, Ct. ------------------------- -------------------- FS 447 --- On Sat, 2/12/11, Ralph B wrote: From: Ralph B <rstar447(at)gmail.com> Subject: Kolb-List: changing a posting Date: Saturday, February 12, 2011, 2:19 PM Posts can be cleaned up using the "edit" button to the right. Here's how yo u do it: Log in and go to your post that you made. It doesn't matter how ol d it is. Click the "edit" button to the right (not the right mouse click) a nd change/delete what you need to and click on "submit" below. That's it. T ry it and then look for the new posting. I thought you guys might like to know since there are a lot of posts that a re sent and later changed by adding a new posting. Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000 hours 24 years flying it Kolbra 912UL N20386 3 years flying it 150 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330785#330785 le, List Admin. ________________________________________________________________________________
Date: Feb 12, 2011
ME EITHER=0A-Chris Davis=0AKXP 503 492 hrs=0AGlider Pilot=0ADisabled from crash building Firefly =0A=0A=0A=0A=0A________________________________=0AF rom: william sullivan =0ATo: kolb-list(at)matronics. com=0ASent: Sat, February 12, 2011 2:33:03 PM=0ASubject: Re: Kolb-List: cha nging a posting=0A=0A=0A- Ralph- I don't have an "edit" button, or a "sub mit" button.- Maybe you have a =0Adifferent format than I get.=0A=0A- ------------------------- ------------------- Bill Sullivan=0A ------------------------- -------------------- Windsor Locks, Ct.=0A---------------------- ----------------------- FS 44 7=0A=0A--- On Sat, 2/12/11, Ralph B wrote:=0A=0A=0A>Fr om: Ralph B =0A>Subject: Kolb-List: changing a posting =0A>To: kolb-list(at)matronics.com=0A>Date: Saturday, February 12, 2011, 2:19 m>=0A>=0A>Posts can be cleaned up using the "edit" button to the right. Her e's how you do =0A>it: Log in and go to your post that you made. It doesn't matter how old it is. =0A>Click the "edit" button to the right (not the ri ght mouse click) and =0A>change/delete what you need to and click on "submi t" below. That's it. Try it =0A>and then look for the new posting. =0A>=0A> =0A>I thought you guys might like to know since there are a lot of posts th at are =0A>sent and later changed by adding a new posting. =0A>=0A>=0A>Ralp h B=0A>=0A>--------=0A>Ralph B=0A>Original Firestar 447=0A>N91493 E-AB=0A>1 000 hours=0A>24 years flying it=0A>Kolbra 912UL=0A>N20386=0A>3 years flying it=0A>150 hrs=0A>=0A>=0A>=0A>=0A>Read this topic online here:=0A>=0A>http: //forums.matronics.com/viewtopic.php?p=330785#330785 =0A>http://www.matro nics.com/Navigator?Kolb-Lis-----> http://forums.matronbsp; - - - =0A>---- List Contribution Web Site - http://www===== ===================0A>=0A>=0A>=0A> =0A ============ =0A=0A=0A=0A ________________________________________________________________________________
Date: Feb 12, 2011
williamtsullivan(at)att.n > Ralph- I don't have an "edit" button, or a "submit" button. Maybe you have a different format than I get. > > William, you can get on the list here instead of getting your Kolb postings in your email. This will free up your email from the Kolb postings and then you can edit and post as I stated. This is much better than the email version. http://forums.matronics.com/viewforum.php?f=5 Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000 hours 24 years flying it Kolbra 912UL N20386 3 years flying it 150 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330800#330800 ________________________________________________________________________________
Date: Feb 12, 2011
I understand setting weight and balance for the aft range of the cg envelope. The question was meant as what did you test? Stalls with all flap settings, both approach and departure? Stalls while banked to right and left? Accelerated stalls? Rick Girard Hello Rick I did power off stalls only, with flaps and no flaps. All of the other configurations are too exciting for me. Jason Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330801#330801 ________________________________________________________________________________
Date: Feb 12, 2011
On 2/12/2011 2:58 PM, Ralph B wrote: > --> Kolb-List message posted by: "Ralph B" > > williamtsullivan(at)att.n >> Ralph- I don't have an "edit" button, or a "submit" button. Maybe you have a different format than I get. >> >> > > William, you can get on the list here instead of getting your Kolb postings in your email. This will free up your email from the Kolb postings and then you can edit and post as I stated. This is much better than the email version. > > http://forums.matronics.com/viewforum.php?f=5 > > Ralph B > > -------- > Ralph B > Original Firestar 447 > N91493 E-AB > 1000 hours > 24 years flying it > Kolbra 912UL > N20386 > 3 years flying it > 150 hrs Or, if you prefer email, like me, then start with opening your email by clicking 'reply', as you normally would. Then, just point your mouse at the starting point of the text you want to delete, hold down the left mouse button, & drag the mouse to the end of the text you want to delete, and release the button. That text will be highlighted (typically changed to a blue background on a 'stock' windows system). Then, hit your choice of or or or or just about any other text or number key, & all the highlighted text will disappear & be replaced by one keystroke of whatever key you hit (enter, space, backspace, etc). Type your response normally & hit send. (But please leave enough of the original message that your response has some context. Some of us get hundreds of emails a day in our inboxes & may skip to the most recent post to save time.) While we're talking about list courtesy, how about this: If we reply to a message that already has a previous reply, try to follow the reply format of the previous reply (top reply, top reply again, or bottom reply, bottom reply again). We each have our preferences, but a half-dozen replies with half on bottom (where they should be :-) ) & half on top & the email has become nothing but gibberish. It would be nice to preserve chronological order, even if it's backward order. Thanks, Charlie ________________________________________________________________________________
Date: Feb 13, 2011
..."During one test of the rear CG limit, John stalled the Kolbra to discover it would not recover from the stall. Full power was required to get out of the stall and fly again..." John, You just pointed out one of the very few, if not the only, real advantages of high thrust line aircraft like our Kolbs. Other aircraft with "normal" thrust lines may not have been able to recover from this condition. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330867#330867 ________________________________________________________________________________
Subject: registering an experimental aircraft
Date: Feb 13, 2011
Kolb guys=2C I am nearing the final stages of building my MkIII=2C or at least I can s ee light at the end of the tunnel. If I were to 'guess' at this point when I think I may be finished=2C I'd say around May. (one things for sure=2C I can get more don e when the temos warm up!! Supposed to be upper 50s today...woo hoo!!) Back to my point. I have just gone to the EAA "OSHKOSH 365" for members =2C and read their directions for registering an experimental aircraft. First question=3B Has anyone bought their "$12.99 forms/instructions kit "=2C and found it not worth the money......or is it a pretty good deal? The reason I ask is because they do list all the forms=2C etc=2C online =2C and give a brief synopsis of the steps involved. They even provide links to all the referen ced forms so a guy could print them. Any thoughts on their kit? Since I have never gone through this process=2C I have very little idea o f what to expect. I have plenty and sufficient=3B photos=2C receipts=2C logs=2C parts brochures=2C etc. I think I have this part covered fairly well. Of course=2C I will have the W&B and Aircraft Limitations already filled out. Does anyone have a sample of their "OPERATOR LIMITATIONS" handbook they are proud of=2C and wouldn't mind sharing a copy of?? From your experience=2C what are the types of things a DAR is going to lo ok for? Will he be mostly concerned with documentation=2C or will he be focused on the airplane itself? Or both?? Do you have any recommendations=2C so I can save myself the added expense of a second trip for him? Like I said=2C I'm beginning the initial stages of registration. All adv ice and pointers are greatly appreciated. Mike Welch MkIII ________________________________________________________________________________
Date: Feb 13, 2011
Kolb guys=2C when the 'temps' warm up. I'm not sure what a temo is. M ________________________________________________________________________________
Subject: Re: registering an experimental aircraft
Date: Feb 13, 2011
Like I said, I'm beginning the initial stages of registration. All advice and pointers are greatly appreciated. Mike Welch Call your nearest FSDO. Get them to send you a packet for registration and inspection of your homebuilt. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 13, 2011
Hi Mike/Gang. I just got my Airworthyness Cert last week. I did all my registration paperwork using the KOLB instructions and sending all that off to the FAA before I got the EAA package. That part is straightforward and you just need the correct documents and ma il it all off. Don't forget to get correct notarization. The EAA package is worth it , IMHO, because they give you the stickers you need. and its all very clear. I only got one "EXPERIMENTAL" sticker but wan ted two, so got some more from Aircraft Spruce. They even send you a firep roof plate to attach to the tail after you get it engraved. All the rest to label the cockpit was in the package. I got in touch with the Local EAA chapter and got a volunteer to come and d o an inspection of my plane, boy was I surprised at all the stuff he "Sugg ested" I change.. mostly making sure bolts and nuts were put on correctly a nd had two treads showing on locknuts. This cost me lunch..Good deal. I would highly recommend this step. This REALLY helped. Then I called the FSDO and they said use a DAR. I cal led the DAR and he quoted $500 to come do the airworthyness check, but he would also do a thorough inspection.,. (But Expensive!!) I got back in touch with the FSDO after talking to my local flight school a nd getting a contact they deal with, and got a schedule for an inspection within a week... Great. They came and took a look at the aircraft, asked a few questions and then w e sat down and went thru the paperwork for the Airworthyness.. and that wa s it... Cost = Taxes $0. = Cool. The contents of the EAA package were complete and the FSDO folks liked what they saw. I'm sure it would work for a DAR too. Good luck, frankD M3X, N1014S. -----Original Message----- From: Mike Welch <mdnanwelch7(at)hotmail.com> Sent: Sun, Feb 13, 2011 8:08 am Subject: RE: Kolb-List: registering an experimental aircraft Kolb guys, when the 'temps' warm up. I'm not sure what a temo is. M ________________________________________________________________________________
Date: Feb 13, 2011
The $ 12.99 was, for me money well spent.- My DAR was mostly interested i n =0Apaperwork.=0AFor what it's worth=0AFrank=0A=0A=0A=0A=0A_______________ _________________=0AFrom: Mike Welch <mdnanwelch7(at)hotmail.com>=0ATo: kolb-l ist(at)matronics.com=0ASent: Sun, February 13, 2011 9:25:14 AM=0ASubject: Kolb -List: registering an experimental aircraft=0A=0AKolb guys,=0A-=0A- I a m nearing the final stages of building my MkIII, or at least I can see =0Al ight=0Aat the end of the tunnel.- If I were to 'guess' at this point when I think I may =0Abe =0A=0Afinished, I'd say around May.- (one things for sure, I can get more done when =0Athe =0A=0Atemos warm up!!- Supposed to be upper 50s today...woo hoo!!)=0A-=0A- Back to my point.-- I have just gone to the EAA "OSHKOSH 365" for members, =0Aand read their directio ns for registering an experimental aircraft.=0A-=0A- First question;- Has anyone bought their "$12.99 forms/instructions kit", and =0Afound =0A =0Ait not worth the money......or is it a pretty good deal?-- =0A- Th e reason I ask is because they do list all the forms, etc, online, -and g ive =0Aa brief =0A=0Asynopsis-of the steps involved.- They even provide links to all the-referenced =0Aforms =0A=0Aso a guy could print them.- ------Any thoughts on their kit?=0A-=0A- Since I have never gone through this process, I have very little idea-of what=0Ato expect. -- I have plenty and sufficient; photos, receipts, logs, parts =0Abroch ures, etc.=0AI think I have this part covered fairly well.- Of course, I will have the W&B =0Aand=0AAircraft Limitations already filled out.=0A- D oes anyone have a sample of their "OPERATOR LIMITATIONS" handbook they=0Aar e proud of, and wouldn't mind sharing a copy of??=0A-=0A- From your exp erience, what are the types of things a DAR is going to look for?=0AWill he be mostly concerned with documentation, or will he be focused on the=0Aair plane itself?- Or both??=0A- Do you have any recommendations, so I can save myself the added expense of =0Aa second trip for him?=0A-=0A- Like I said, I'm-beginning the-initial stages of registration.- All advic e and =0Apointers are =0A=0Agreatly appreciated.=0A-=0AMike Welch=0AMkIII ============== =0A ________________________________________________________________________________
Date: Feb 13, 2011
I hope this fellow doesn't mind me using his picture to show for weight and balance purposes. He would be the limit on passenger weight I would take in my Kolbra. On takeoff with the 80hp 912, it climbed ever so slow. I let him have the stick after reaching altitude and we flew for about 15 minutes. I brought him back to the airport and came in hotter than usual to make a very smooth landing. He was impressed and it was a good day. The weight and balance states that I can take no more than 250 lbs in passenger weight with a full tank of fuel. I feel more comfortable with 200 lbs or less. He was well over 200 lbs and over 6 feet. I'm at 200 lbs and my wife is a 200 lb lady, so I got used to carrying heavy loads. Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000 hours 24 years flying it Kolbra 912UL N20386 3 years flying it 150 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330892#330892 Attachments: http://forums.matronics.com//files/paul__139.jpg ________________________________________________________________________________
Date: Feb 13, 2011
Hi Mike/Gang. I just got my Airworthyness Cert last week. I did all my registration paperwork using the KOLB instructions and sending all that off to the FAA before I got the EAA package. That part is straightforward and you just need the correct documents and mail it all off. Don't forget to get correct notarization. The EAA package is worth it , IMHO, because they give you the stickers you need. and its all very clear. I only got one "EXPERIMENTAL" sticker but wanted two, so got some more from Aircraft Spruce. They even send you a fireproof plate to attach to the tail after you get it engraved. All the rest to label the cockpit was in the package. I got in touch with the Local EAA chapter and got a volunteer to come and do an inspection of my plane, boy was I surprised at all the stuff he "Suggested" I change.. mostly making sure bolts and nuts were put on correctly and had two treads showing on locknuts. This cost me lunch..Good deal. I would highly recommend this step. This REALLY helped. Then I called the FSDO and they said use a DAR. I called the DAR and he quoted $500 to come do the airworthyness check, but he would also do a thorough inspection.,. (But Expensive!!) I got back in touch with the FSDO after talking to my local flight school and getting a contact they deal with, and got a schedule for an inspection within a week... Great. They came and took a look at the aircraft, asked a few questions and then we sat down and went thru the paperwork for the Airworthyness.. and that was it... Cost = Taxes $0. = Cool. The contents of the EAA package were complete and the FSDO folks liked what they saw. I'm sure it would work for a DAR too. Good luck, frankD M3X, N1014S. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330893#330893 ________________________________________________________________________________
Date: Feb 13, 2011
Subject: Registering an aircraft
No matter FSDO or DAR, make sure you get your repairman's certificate for the aircraft. Without it you'll be paying an A & P for an annual conditional inspection every 12 months. Some do it without being asked, some don't. Just be sure you get it. Rick Girard -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Feb 13, 2011
Frank=2C Thank you for that very informative=2C and up-to-date response!! I'll pr int it out and make sure I have all the bases covered you suggested. Excellent detail of what I'm about to go through. Thanks! Rick=2C Yeah=2C re=3B the repairman's certificate. That's a biggie for me. I sa w the form and it is one of my "favorites". Thanks for the reminder!! John H=2C I did contact my FSDO a couple of years ago=2C and had then send me some of the necessary registration forms=2C but it's been so long=2C I can't rem ember exactly what the guy sent. (I'll bet it didn't include the rep'r certifica te form). I wanted to know if spending the money on the EAA kit was worth it. (but it looks like I have this part covered thanks to Mike S) I think rounding up all the right forms is one of the easier parts of the process. Like I said=2C the EAA membership can download all the forms from their onl ine tutorial. If I can do that=2C I will=2C otherwise I will get ahold of my a rea FSDO=2C like you suggested. Thanks!!! Mike Sharp=2C Mike Sharp had purchased the EAA registration kit=2C and has sent me a co py of the booklet. All I need now are the actual forms. Thanks=2C Mike!!! Th e only thing I don't get is the 'experimental' stickers=2C or the engraveable plate. No problem on those=2C I know they are obtainable elsewhere. All=2C I appreciate everyone's help. Thanks a bunch!! I have one more question regarding DAR's and FSDO inspectors. Do I have to find a DAR AND also a FSDO inspector? Can just the FSDO guy do the job?? There's not likely going to be even a DAR near me. I'll probably have to r un the plane up to K.C. or St Louis.=2C or does the FSDO guy come to me if I ask him to? Mike Welch MkIII installing the ELT ________________________________________________________________________________
Date: Feb 13, 2011
Mike... check with FSDO on your repairman's cert too...Here in Michigan, you had to do it on line and they gave you a number for one of the FSDO guys to look over then I had to bring my build book,and all paperwork for them to go over,then we both sat at the computer and filled out the rest of the forms...Whew !! an hour and a half later I had my temporary cert. It's not like it used to be ,so make sure you check ! Good luck! chris ambrose M3X/Jab N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330914#330914 ________________________________________________________________________________
Date: Feb 13, 2011
I did contact my FSDO a couple of years ago, and had then send me some of the necessary registration forms, but it's been so long, I can't remember exactly what the guy sent. (I'll bet it didn't include the rep'r certificate form). I wanted to know if spending the money on the EAA kit was worth it. (but it looks like I have this part covered thanks to Mike S) Mike W/Kolbers: The Birmingham FSDO will send you a packet, as I mentioned in my previous. This packet will consist of all necessary instructions and forms to prepare for your upcoming aircraft inspection and air worthiness certificate. I can not vouch for other FSDO's, but I would think they would also offer a similar packet for homebuilt/experiemental aircraft. May have to ask them. Never know when you might be talking to a newbie that does not know about the packet. It worked for me in 1991, bet it will still work. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 13, 2011
Hi Mike, Regarding my local FSDO, San Jose, Ca. they used to be open to walk-ins, now the door is locked and you have to schedule a visit by phone. The reply I first got when I called was " We don't have the manpower to do air worthyness inspections, go see a DAR!" OK. It took me awhile to find a cooperative person and they came to where the plane was hangered, 42 miles from the office.. No charge. The DAR would have come to the plane too but would have charged $100 for travel. I guess that manpower scheduling is an issue and that cutbacks are part of the FSDO around here. I hope you have an easier time. I asked about the repairman cert and was told to fly off the 40Hrs first and then apply, so I don't believe you have to hurry about that, but its a good thing to have. One document I got from the FSDO years ago (When the doors were open) is the Advisory Circular "Amateur-built aircraft and ultralight flight testing handbook" AC No:- 90-89A. Its full of advise on preparing for test flight, and its my bible right now. Have fun FrankD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330947#330947 ________________________________________________________________________________
Date: Feb 14, 2011
Hi Mike/Gang, to answer Mike's question about the test flight, I have found a local guy with a MKiii that will take me up to get the "Sight Picture" of the Kolb, especially at landing. I am also doing quite a few hours landing practice in a Champ, 85hp, to make sure I get my feet and stick skills up to par. I am writing a test plan for each phase of the flight and will have buddies on the ground help me when I do high speed taxi, 1st flight, 2nd flight, etc. using this test plan. That booklet helps. I will also wait for no wind conditions. I've spent 10 years building this thing and am not going to rush now. I have asked around and some folks who were GA pilots just got in and went fly! And lived to tell the tale. I believe its "When YOU are GOOD & ready" is the trick. I also am getting lots of advise from local EAA members. The operating limitations the FAA lady gave me is a two page document to be kept in the aircraft. BTW, she told me there is no FAA definition of congested areas so I guess its up for interpretation.. (Loop hole!) Fly safe. FrankD, M3X. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331027#331027 ________________________________________________________________________________
Date: Feb 14, 2011
I also am getting lots of advise from local EAA members. FrankD, M3X. Frank D/Kolbers: If I may guess, I would say most new Kolb pilots make the mistake of not managing airspeed. Low altitude stalls get a lot of good Kolb people. Until one gets used to flying the Kolb, any model, an approach, and landing/touch down speed of 50 to 60 mph will keep you above the stall. 50 to 60 mph is a good flying speed. I like the instruction Homer Kolb made in my 1984 Ultrastar Builders and Flyers Manual. Take off, climb to about 1,000 feet above the ground, stall the airplane to get an indicated stall speed, then keep the airspeed above the stall. It worked for me then and it still works for me. john h Titus, Alabama ________________________________________________________________________________
Date: Feb 14, 2011
Frank Getting landing hours in a champ is good but your Kolb will slow down a whole lot quicker than a champ when you flair for touch down. Review this in your intro flight in the Kolb. On your first landing carry lots of power to touch down. Power will make the Kolb land like a champ. Then "*gradually"*reduce the approach power a bit with each landing. Get used to starting your landing flair at around one-two foot. The normal GA landing flair at twenty-fifty foot will bite you in a Kolb. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Feb 14, 2011 at 11:01 AM, Frankd wrote: > > Hi Mike/Gang, > > to answer Mike's question about the test flight, I have found a local guy > with a MKiii that will take me up to get the "Sight Picture" of the Kolb, > especially at landing. > I am also doing quite a few hours landing practice in a Champ, 85hp, to > make sure I get my feet and stick skills up to par. > I am writing a test plan for each phase of the flight and will have buddies > on the ground help me when I do high speed taxi, 1st flight, 2nd flight, > etc. using this test plan. That booklet helps. > I will also wait for no wind conditions. I've spent 10 years building this > thing and am not going to rush now. > > I have asked around and some folks who were GA pilots just got in and went > fly! And lived to tell the tale. I believe its "When YOU are GOOD & > ready" is the trick. I also am getting lots of advise from local EAA > members. > The operating limitations the FAA lady gave me is a two page document to be > kept in the aircraft. BTW, she told me there is no FAA definition of > congested areas so I guess its up for interpretation.. (Loop hole!) > Fly safe. > FrankD, M3X. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331027#331027 > > ________________________________________________________________________________
Subject: Ameri-King ELT - the remote control
From: "cristalclear13" <cristalclearwaters(at)gmail.com>
Date: Feb 14, 2011
I noticed that the sticker I placed on my instrument panel that shows the expiration date of the battery on my ELT remote control is Dec 2010. I want to replace the batteries before flying again. The itty-bitty nuts and bolts holding it on the panel are in a difficult place to reach. Does anyone have one of those remotes for the Ameri-King 406 not installed right now that you can tell me where the battery compartment is on it? I'm feeling for it and can't find it by just feeling. And I looked as far as I could...could only see the underside, and didn't see any battery compartment opening. Thanks! -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Sept 2007 Private Pilot Aug 2008 ELSA Repairman for N193Y April 2008 Rotax 2 stroke maintenance April 2009 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331058#331058 ________________________________________________________________________________
Subject: Plastic gas tank grommets, etc
Date: Feb 14, 2011
While putting in my new battery I had to take out my gas tanks since my battery is at the back of the cage. I cleaned out the plastic gas tanks but then noticed that the metal fuel thing-a-ma-jig where the gas comes out is really rusted. I see that jbm industries sells the grommet but who sells the metal thing-a-ma-jig that the grommet goes around? Next question...how to get it out and back in? There is no way I can reach through the opening of the gas tank to work on it (too small and too far of a reach)...does it just pull out with force through the hole and then force it back in with the new grommet and metal thing-a-ma-jig (yes you can correct me to what it is actually called). Thanks! -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Sept 2007 Private Pilot Aug 2008 ELSA Repairman for N193Y April 2008 Rotax 2 stroke maintenance April 2009 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331061#331061 Attachments: http://forums.matronics.com//files/plastic_gas_tank_grommet_3_211.jpg http://forums.matronics.com//files/plastic_gas_tank_grommet_2_130.jpg http://forums.matronics.com//files/plastic_gas_tank_grommet_1_207.jpg ________________________________________________________________________________
Date: Feb 14, 2011
Subject: Re: Plastic gas tank grommets, etc
Cristal, This is probably what you have. http://www.aircraftspruce.com/catalog/appages/ffelbow.php <http://www.aircraftspruce.com/catalog/appages/ffelbow.php>A PITA to remove, especially with the tank in place, more so if the grommet has age hardened. Basically it's an Armstrong removal. Support the area around the grommet as you pull the barbed fitting out so you don't damage the tank. Twisting as you pull helps. Coat the new fitting with some lithium grease when installing. Rick Girard On Mon, Feb 14, 2011 at 3:20 PM, cristalclear13 < cristalclearwaters(at)gmail.com> wrote: > cristalclearwaters(at)gmail.com> > > While putting in my new battery I had to take out my gas tanks since my > battery is at the back of the cage. I cleaned out the plastic gas tanks but > then noticed that the metal fuel thing-a-ma-jig where the gas comes out is > really rusted. > I see that jbm industries sells the grommet but who sells the metal > thing-a-ma-jig that the grommet goes around? > Next question...how to get it out and back in? There is no way I can reach > through the opening of the gas tank to work on it (too small and too far of > a reach)...does it just pull out with force through the hole and then force > it back in with the new grommet and metal thing-a-ma-jig (yes you can > correct me to what it is actually called). > Thanks! > > -------- > Cristal Waters > Kolb Mark II Twinstar Rotax 503 DCSI Sept 2007 > Private Pilot Aug 2008 > ELSA Repairman for N193Y April 2008 > Rotax 2 stroke maintenance April 2009 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331061#331061 > > > Attachments: > > http://forums.matronics.com//files/plastic_gas_tank_grommet_3_211.jpg > http://forums.matronics.com//files/plastic_gas_tank_grommet_2_130.jpg > http://forums.matronics.com//files/plastic_gas_tank_grommet_1_207.jpg > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Feb 14, 2011
Just pull it out, when you get it out you will be able to clearly see how t he =0Aelbow presses the grommet out to seal the fitting.=0A=0ASteve Spence =0AMk3X-tra=0AAuburn Hills, MI=0A=0A=0A=0A=0A______________________________ __=0AFrom: cristalclear13 <cristalclearwaters(at)gmail.com>=0ATo: kolb-list@ma tronics.com=0ASent: Mon, February 14, 2011 4:20:37 PM=0ASubject: Kolb-List: talclear13" =0A=0AWhile putting in my new bat tery I had to take out my gas tanks since my battery =0Ais at the back of t he cage.- I cleaned out the plastic gas tanks but then =0Anoticed that th e metal fuel thing-a-ma-jig where the gas comes out is really =0Arusted.=0A I see that jbm industries sells the grommet but who sells the metal =0Athin g-a-ma-jig that the grommet goes around?=0ANext question...how to get it ou t and back in?- There is no way I can reach =0Athrough the opening of the gas tank to work on it (too small and too far of a =0Areach)...does it jus t pull out with force through the hole and then force it =0Aback in with th e new grommet and metal thing-a-ma-jig (yes you can correct me to =0Awhat i t is actually called).=0AThanks!=0A=0A--------=0ACristal Waters=0AKolb Mark II Twinstar Rotax 503 DCSI- Sept 2007=0APrivate Pilot Aug 2008=0AELSA Re pairman for N193Y April 2008=0ARotax 2 stroke maintenance April 2009=0A=0A =0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/view topic.php?p=331061#331061=0A=0A=0A=0A=0AAttachments: =0A=0Ahttp://forums. matronics.com//files/plastic_gas_tank_grommet_3_211.jpg=0Ahttp://forums.mat ronics.com//files/plastic_gas_tank_grommet_2_130.jpg=0Ahttp://forums.matron - - - - - - - - - - - - - - - -Matt Dralle, L ======= ________________________________________________________________________________
Date: Feb 14, 2011
Subject: Re: Ameri-King ELT - the remote control
I don't recall on mine, thought it was just a switch/reset/test button.- I =0Adidn't think there were any batteries in it.- Are you sure that isn' t just a =0Areminder to change the ELT battery?=0A=0ASteve Spence=0AAuburn Hills, MI=0A=0A=0A=0A=0A________________________________=0AFrom: cristalcle ar13 =0ATo: kolb-list(at)matronics.com=0ASent: M on, February 14, 2011 3:55:42 PM=0ASubject: Kolb-List: Ameri-King ELT - the stalclearwaters(at)gmail.com>=0A=0AI noticed that the sticker I placed on my i nstrument panel that shows the =0Aexpiration date of the battery on my ELT remote control is Dec 2010.- I want to =0Areplace the batteries before fl ying again.=0AThe itty-bitty nuts and bolts holding it on the panel are in a difficult place =0Ato reach.=0A=0ADoes anyone have one of those remotes f or the Ameri-King 406 not installed right =0Anow that you can tell me where the battery compartment is on it?- I'm feeling =0Afor it and can't find it by just feeling.- And I looked as far as I =0Acould...could only see t he underside, and didn't see any battery compartment =0Aopening.=0AThanks! =0A=0A--------=0ACristal Waters=0AKolb Mark II Twinstar Rotax 503 DCSI- S ept 2007=0APrivate Pilot Aug 2008=0AELSA Repairman for N193Y April 2008=0AR otax 2 stroke maintenance April 2009=0A=0A=0A=0A=0ARead this topic online h ere:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=331058#331058=0A=0A ================ ________________________________________________________________________________
Date: Feb 14, 2011
> Does anyone have one of those remotes for the Ameri-King 406 not installe d right now that you can tell me where the battery compartment is on it? I' m feeling for it and can't find it by just feeling. And I looked as far as I could...could only see the underside=2C and didn't see any battery compar tment opening. > Thanks! > > -------- > Cristal Waters Cristal=2C I am in the very process of installing my ELT today. I have the Ameri-Ki ng AK450. I don't know what the difference is between yours and mine=2C but according my booklet =2C you're going to have to pull out the 4 retaining screws and be able to hold the remote unit in your hand. There are 3 screws on the side of the remore unit. You need to remove th ese to have access to the battery. The AK-450 uses the Duracell MN1300. Hope this helped. Mike Welch ________________________________________________________________________________
Date: Feb 14, 2011
I don't recall on mine=2C thought it was just a switch/reset/test button. I didn't think there were any batteries in it. Are you sure that isn't jus t a reminder to change the ELT battery? Steve Spence Auburn Hills=2C MI Hi Steve=2C Like I told Cristal=2C I am in the very process of installing the ELT locator in my MkII today. Yesterday=2C when I was reading the installa tion manual=2C I was surprised to find out that there is=2C indeed a little one of those flat=2C round batteries in the remote unit. Now that Cristal mentioned it=2C I looked at my AK-450 remote on my workb ench. I've had this ELT for quite a while=2C and what do you know? My remote uni t's battery was due to be replaced by NOV 2010!! Thanks for the heads-up=2C Cr istal. Mike Welch ________________________________________________________________________________
Date: Feb 14, 2011
Cristal, There are three small phillips head screws in the side of the case. There's a 6V Lithium Ion battery in the leg of the "Ell" next to the socket for the line cord coming from the ELT. The case splits down the middle, you have to remove it from the panel to disassemble. Rick Girard On Mon, Feb 14, 2011 at 3:51 PM, Stephen Spence wrote: > I don't recall on mine, thought it was just a switch/reset/test button. I > didn't think there were any batteries in it. Are you sure that isn't just a > reminder to change the ELT battery? > > Steve Spence > Auburn Hills, MI > > ------------------------------ > *From:* cristalclear13 > *To:* kolb-list(at)matronics.com > *Sent:* Mon, February 14, 2011 3:55:42 PM > *Subject:* Kolb-List: Ameri-King ELT - the remote control > > cristalclearwaters(at)gmail.com> > > I noticed that the sticker I placed on my instrument panel that shows the > expiration date of the battery on my ELT remote control is Dec 2010. I want > to replace the batteries before flying again. > The itty-bitty nuts and bolts holding it on the panel are in a difficult > place to reach. > > Does anyone have one of those remotes for the Ameri-King 406 not installed > right now that you can tell me where the battery compartment is on it? I'm > feeling for it and can't find it by just feeling. And I looked as far as I > could...could only see the underside, and didn't see any battery compartment > opening. > Thanks! > > -------- > Cristal Waters > Kolb Mark II Twinstar Rotax 503 DCSI Sept 2007 > Private Pilot Aug 2008 > ELSA Repairman for N193Y April 2008 > Rotax 2 stroke maintenance April 2009 > > > Read this topic online here: > > http://forums.matronics. -Matt============= > > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Feb 14, 2011
Thank you Rick and Steve. If I don't have the strength to do it, I'll find someone who does! :) -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Sept 2007 Private Pilot Aug 2008 ELSA Repairman for N193Y April 2008 Rotax 2 stroke maintenance April 2009 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331075#331075 ________________________________________________________________________________
Date: Feb 14, 2011
Cristal That thing-a-jig is called a in tank elbow in the Lockwood catalog. Grab the elbow with a pair of pliers and twist it while pulling and it will come out. I recommend you get replacements that have the finger strainer and a shut off valve. Be sure to lube the elbow before installing the new elbow in the bushing Also my ELT remote doesn't have a battery that I know of. I think it is powered by the main unit that my remote is wired to. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Feb 14, 2011 at 4:20 PM, cristalclear13 < cristalclearwaters(at)gmail.com> wrote: > cristalclearwaters(at)gmail.com> > > While putting in my new battery I had to take out my gas tanks since my > battery is at the back of the cage. I cleaned out the plastic gas tanks but > then noticed that the metal fuel thing-a-ma-jig where the gas comes out is > really rusted. > I see that jbm industries sells the grommet but who sells the metal > thing-a-ma-jig that the grommet goes around? > Next question...how to get it out and back in? There is no way I can reach > through the opening of the gas tank to work on it (too small and too far of > a reach)...does it just pull out with force through the hole and then force > it back in with the new grommet and metal thing-a-ma-jig (yes you can > correct me to what it is actually called). > Thanks! > > -------- > Cristal Waters > Kolb Mark II Twinstar Rotax 503 DCSI Sept 2007 > Private Pilot Aug 2008 > ELSA Repairman for N193Y April 2008 > Rotax 2 stroke maintenance April 2009 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331061#331061 > > > Attachments: > > http://forums.matronics.com//files/plastic_gas_tank_grommet_3_211.jpg > http://forums.matronics.com//files/plastic_gas_tank_grommet_2_130.jpg > http://forums.matronics.com//files/plastic_gas_tank_grommet_1_207.jpg > > ________________________________________________________________________________
Date: Feb 14, 2011
I don't recall on mine=2C thought it was just a switch/reset/test button. I didn't think there were any batteries in it. Are you sure that isn't jus t a reminder to change the ELT battery? Steve Spence Auburn Hills=2C MI Steve=2C everyone=2C Now that I think about it=2C I'll bet that itty-bitty battery's main function is to light that little red LED on the remote unit. Yes=2C the remote unit has a little battery=2C and yes=2C it also has an expiration date. Now=2C I'm headed back out to my shop to get it installed... Mike Welch ________________________________________________________________________________
Date: Feb 14, 2011
Thank you Rick and Mike. That isn't the news I wanted to hear, but it was what I was expecting. Thanks again! -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Sept 2007 Private Pilot Aug 2008 ELSA Repairman for N193Y April 2008 Rotax 2 stroke maintenance April 2009 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331076#331076 ________________________________________________________________________________
Subject: Re: Sun and Fun 2011
Date: Feb 14, 2011
I will be in close pursuit of Kip's Waiex workschedule permitting. Not with the Kolb though, but with my VariEZE. John Hauck wrote: > Latest dates for Sun and Fun 2011: > > Sun n Fun > March 29, 2011 April 3, 2011 > Lakeland Linder Regional Airport in Lakeland, FL > 37th Annual SUN n FUN International Fly-In & Expo > > > I am going to try to fly down on Mar 28 or 29. > > See you all there. > > john h > mkIII > Titus, Alabama -------- Kolb Mark III Xtra (under construction) Rutan VariEZE (flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331079#331079 ________________________________________________________________________________
Date: Feb 14, 2011
Mike Welch wrote: > I don't recall on mine, thought it was just a switch/reset/test button. I didn't think there were any batteries in it. Are you sure that isn't just a reminder to change the ELT battery? > > Steve Spence > Auburn Hills, MI > > Steve, everyone, > > Now that I think about it, I'll bet that itty-bitty battery's main > function is to light that little red LED on the remote unit. > Yes, the remote unit has a little battery, and yes, it also has an > expiration date. > Now, I'm headed back out to my shop to get it installed... > > Mike Welch > > Yes, my DAR specifically made me label the expiration date for the remote unit. -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Sept 2007 Private Pilot Aug 2008 ELSA Repairman for N193Y April 2008 Rotax 2 stroke maintenance April 2009 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331080#331080 ________________________________________________________________________________
Date: Feb 15, 2011
Subject: Re: club planes?
There has been a lot of discussion, mostly positive, and it has all been =0Ainteresting, much of it very helpful. =0A=0AFrom the Sport Pilot Instruc tors forum Phil Dietro, Arlynn McMahon, and a few =0Aothers have discussed the options they have utilized. Thom Riddle has posted =0Asome inciteful qu estions and possible solutions. =0A=0AThis is what we are looking for : oth er "outside the box" forward thinking =0Agroups or individuals who can help us generate a solution to the growing problem =0Aof SPCFI shortages and th e costs involved in being able to operate. =0A=0AArlynn has offered to shar e info regarding how an SPCFI might go about =0A"affordably" operating with out the backing of a "regular" flight school. This is =0Anot a sarcastic st atement. =0A=0APhil mentioned the addition of PPC & WS training - are there existing LODAs in =0Aforce to provide for that training in ELSAs? =0A=0AHa ving come up through the ranks of Ultralight to Sport Pilot, I also know ma ny =0Anew UL flyers who are desperate for training they can't get. =0A=0AOu r focus is how to go about establishing an LLC and fractional ownership pla n =0Acentered around ELSA craft & EABs to use for the additional purpose of training =0ASP & UL student pilots; and making this information available to all SPCFIs. =0A=0AI have priced even the USED (aka- well flown) SLSAs, t here aren't many =0Aavailable, and they are still in the $70,000 to $100,00 0 range. =0A=0ANot exactly within the "affordable" range of even a school w ith more than 1 =0Ainstructor. =0A=0AThere has been response from the NAFI (National Association of Flight =0AInstructors) that has been on a positive note. They are very interested in =0Aworking on this solution as well. =0A =0AAs a group, Sport Pilot may simply need to do the same thing that other =0Aminorities have done in the past, Stand up, be counted, be recognized, a nd not =0Atake NO for an answer. It will take time. We all realize this. Bu t with more of =0Aus working toward the same goal, we will obtain it sooner rather than later.-=0A-Malcolm Brubaker =0AMichigan Sport=0APilot Repa ir =0ALSRM-A, PPC, WS=0A(989)513-3022 =0A=0A=0A=0A=0A______________________ __________=0AFrom: Charlie England <ceengland(at)bellsouth.net>=0ATo: kolb-lis t(at)matronics.com=0ASent: Fri, February 11, 2011 2:58:00 PM=0ASubject: Re: Ko lb-List: Re: club planes?=0A=0AOn 2/11/2011 11:01 AM, Malcolm Brubaker wrot e: =0AAnother point of view, same basic subject - flight training in ELSA, a different =0Aconcept of dealing with it.=0A>Roger Mills has posted this f ollowing a conversation with EAA.=0A>=0A>Date: Thu, February 10, 2011 11:58 am=0A>To: <fly-ul@yahoogroups. com>=0A>=0A>Per EAA---(as of 1 hour ago)=0A >An E is an E is an E! Regardless of whether it is kit or plans built, EAB or =0A>ELSA.=0A>An experimental category aircraft of any type cannot be for mally rented out or =0A>used by anyone "for hire" in any way!!!!!=0A>Cost s haring for 'friendly' use by other than the owner is OK to a point--be =0A> ready to prove it.=0A>A group of people can form a "club" as an LLC, corp o r partnership for the =0A>purpose of building, owning and flying any experi mental aircraft.=0A>The orgainization that functions as a fund raiser must be a separate entity from =0A>the one that owns the experimental aircraft. =0A>The members or partners can be the same people, BUT, separate organizat ional =0A>chart etc.=0A>(Even EAA chapters, as the rules stand now, can bui ld but not own an aircraft. =0A>This is being worked on to correct.)=0A>Pla ns or scratch built automatically qualify for the "51%", only approved kits =0A>qualify, ELSA can be any % but exacly like the SLSA.=0A>A repairmans c ertificate for an EAB can be issued to only one person for any =0A>specific aircraft by N number only.=0A>A repairmans certificate for an ELSA require s the course and MAY include the =0A>model???=0A>Without a repairmans certi ficate only an AP or better can sign the annual.=0A>Any flight instructor c an be paid to teach in any experimental aircraft as long =0A>as they have t he qualifications necessary.=0A>The flight instructor may or may not be an owner/partner in the aircraft.=0A>Flight instruction may be given to the le vel allowed by the equipment installed =0A>in the aircraft.=0A>(I think thi s last one means that you can get full IFR if the aircraft has the =0A>stuf f)=0A>The individual owner/builder of a two place aircraft, who has receive d an N =0A>number for that aircraft, is the only one who can "teach" anyone else to fly =0A>that aircraft until an otherwise qualified flight instruct or has been "taught".=0A>(I am not sure how to really works--on the surface it seems to mean that if you =0A>built it, flew off the restrictions and g ot an N number-you are a qualified =0A>flight instructor for that aircraft only?????, and can be paid to teach in that =0A>aircraft???)=0A>(I was spec ifically told that since flight instruction is desired--the FAA has =0A>not restricted the ability of a flight instructor to teach in an experimental- =0A>--EAB or ELSA. You just CANNOT charge a fee for the aircraft itself.) =0A>(I was also told that insurance is problematic in an experimental of an y =0A>kind--Falcon insurance does it---rates are much different for a Chris ten Eagle =0A>vs a Pete etc. I have not spoken with them.)=0A>=0A>Again, Pe r the EAA. (my comments)=0A>=0A>-One small item to add--my comment---base d on the sum of the conversation and =0A>not specifically stated:=0A>=0A>Th e way the rule is written it gets real grey if one partner pays more than h is =0A>or her share of the hourly cost. Say 6 people form a partnership to build an =0A>experimental aircraft---If one partner pays the entire cost of a one hour flight =0A>then the others partners benefit. Confused me for a while but I can see where =0A>the FAA may see that as 5 owners renting the aircraft to the sixth partner. I =0A>suspect that this kind of thing is why the FAA frouns on "club" ownership of an =0A>experimental.=0A>Posted by : Roger Mills on UL forum=0A>=0A>=0A>-Malcolm Brubaker =0A>Michigan Sport =0A>Pilot Repair =0A>LSRM-A, PPC, WS=0A>(989)513-3022=0A>A couple of though ts:=0A=0Aquote=0AThe individual owner/builder of a two place aircraft, who has received an N =0Anumber for that aircraft, is the only one who can "tea ch" anyone else to fly =0Athat aircraft until an otherwise qualified flight instructor has been "taught".=0Aunquote=0A=0AI've never seen that in the f orm that it's written. I wonder if it is specific =0Ato the 'exemption' for transition training in a homebuilt experimental. That =0Aexemption isn't f or what most would consider flight training; it's an exemption =0Ato provid e *transition* instruction for a qualified pilot to get comfortable in =0A* that particular design*, new-to-him/her experimental a/c. For example, a 50 00 =0Ahr ex-military pilot who's only flown C-130's & never a light plane, would need =0Ainstruction to handle a taildragger homebuilt like a Thorp T- 18 (or Kolb).=0A=0AOn the overall question of 'club' a/c: people may be get ting the wrong =0A(undesirable) answer because they are asking the wrong qu estion. The word 'club' =0Aprobably does trigger a reaction from the FAA, b ecause most clubs operate as =0Abusinesses, charging monthly dues, etc. If the question was phrased as 'multiple =0Aowners', or 'partnership',- ther e would probably be a different answer. If you =0Asearch FAA records, you'l l find many experimental homebuilts registered to =0Apartnerships, and even corporations. As the EAA said, any experimental can be =0Aused for instruc tion, as long as there is no payment to the owner for the use of =0Athe a/c (commercial use). I have read about (but have no direct experience) that =0Aan experimental can even be loaned to a non-owner for training. Memory i s less =0Aclear on whether a third-party instructor can be paid in that sce nario. The =0Aquestion of 5 owners 'renting' to the 6th owner probably woul dn't come up as =0Along as most of the owners fly at least occasionally, & all share more or less =0Aequally in fixed costs like insurance & annuals. =0A=0A=0AI'd bet that a more likely problem is going to be finding an instr uctor whose =0Aliability insurance will cover him while instructing in a ho mebuilt. Not saying =0Ait makes sense; it's just an unfortunate reality.=0A ================= =0A=0A=0A=0A ________________________________________________________________________________
Subject: Minimum allowable altitude
Date: Feb 15, 2011
From: "Kirby, Dennis Civ USAF AFMC AFNWC/EN" <Dennis.Kirby(at)kirtland.af.mil>
(NOTE - subject line changed, to reflect current topic. Formerly "registering an experimental aircraft.") "Frankd" wrote: << BTW, she told me there is no FAA definition of congested areas so I guess its up for interpretation.. (Loop hole!) >> Frank, and Kolb Friends - The reason a clear definition of "congested areas" is important to us is so we know when it's necessary to keep 1000 feet above the ground, as dictated to us by the FARs. Due to a lack of a definitive definition for this term, the criteria I use is the yellow area on a sectional chart that depicts towns and cities. Many other pilots I know also use this as their interpretation of a "congested area." If I'm not flying over yellow, I know it's legal to be only 500 feet above the ground and man-made structures. And if it's a remote area with no man-made structures (which is most of the state of New Mexico), the FARs allow us to fly as low as we wish, consistent with safety. How could the FAA ever argue against THAT interpretation? Dennis Kirby Mark-3, 912ul in Sandia Park, NM ________________________________________________________________________________
Subject: ELT batteries
Date: Feb 15, 2011
Cristal=2C I gave you the wrong battery number for the little battery in the ELT rem ote unit. The battery number I gave you is the Duracell "D" batteries=2C that go to t he main unit=2C and according to the booklet=2C it is mandatory to use that specific Durace ll brand and that specific battery number=2C the MN1300 "D" cells. I should have given you the correct remote unit number=2C which is "DL1/3 NB". If you need me to scan the battery R&R directions=2C let me know=2C and I c an scan the sections on battery replacements. Mike Welch MkIII ________________________________________________________________________________
Subject: Re: Minimum allowable altitude
Date: Feb 15, 2011
"How could the FAA ever argue against THAT interpretation? Dennis Kirby Mark-3, 912ul in Sandia Park, NM " The FAA argues whatever it wants to argue and each case is taken in context of whatever else they can think of. There have been many cases (I can't quote them but have read about them) where the FAA ruled against pilot flying less than 1,000' over a group of three houses close together but a long way from any other buildings. If the FAA wants to rule against you they will with little reliance on logic. The cynic in me says they refuse to quantitatively define a congested area for just that reason, as a catch all infraction. Because it is not quantified it is applied inconsistently and could probably be beat by a good expensive attorney. But even if you win, then you are on their "we don't like you" list. Once you are on that list, I suspect some FAA employees take great pleasure in making your life less fun than it should be. Because of that I rarely fly below 1,000' AGL in western New York, which is nothing at all like New Mexico's outback. The only places in this part of the world that don't have communities fairly close together are the swamps, forests and of course the Great and Finger Lakes... and who wants a close to ground engine out over these areas? If I lived in NM, I'd probably fly a lot lower a lot of the time. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331160#331160 ________________________________________________________________________________
Subject: Re: Kolb/Jabiru carb overflow
Date: Feb 15, 2011
Hello all.... Well,I got the head back on yesterday and flew it todayfor .5 hrs and it ran perfect ! Ellery's catch can worked perfect and my fuel pressure stays between 1.4 to 1.7 and absolutely no problems running what so ever! Thank you Thom for making me look closer and the crankcase vent system as that was my problem from the start. I believe condensation in the line froze blocking the venting and raising the pressure in the engine causing the fuel pump to go wild!. It was 16* today when I flew it and all was good ! Now to build trust in her again...lol chris ambrose M3X/Jabiru A-2200 175.0 hrs N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331167#331167 ________________________________________________________________________________
Date: Feb 15, 2011
Hi Chris, Glad its back working again. Good to hear your back in the air Fly safe. FrankD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331175#331175 ________________________________________________________________________________
Date: Feb 15, 2011
Chris, all, One trick to keep the oil vent line from freezing shut is to cut a slit in the line about 1/3rd of the line diameter near where the line attaches to the engine. In normal usage the slit won't leak as the structure of the line keeps it closed. Should condensation freeze the line shut the slit is near enough to the warmth of the engine there will be no ice there and the excess pressure will be vented. Picked this one up from the LongEZ drivers. Rick Girard On Tue, Feb 15, 2011 at 4:57 PM, ces308 wrote: > > Hello all.... > > Well,I got the head back on yesterday and flew it todayfor .5 hrs and > it ran perfect ! Ellery's catch can worked perfect and my fuel pressure > stays between 1.4 to 1.7 and absolutely no problems running what so ever! > > Thank you Thom for making me look closer and the crankcase vent system as > that was my problem from the start. I believe condensation in the line froze > blocking the venting and raising the pressure in the engine causing the fuel > pump to go wild!. It was 16* today when I flew it and all was good ! Now to > build trust in her again...lol > > > chris ambrose > M3X/Jabiru A-2200 175.0 hrs > N327CS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331167#331167 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Feb 15, 2011
Chris, I am happy to have helped and more importantly, that you found and fixed the problem. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331187#331187 ________________________________________________________________________________
Subject: landing gear toe in - out
Date: Feb 16, 2011
OOOOOKKKKKK i need to apologize to the list... in the past the question has come up as to what the value of toe in - out was necessary. many on the list have said you need some toe in,, and my response has always been copied from the kolb builders manual. which states in short, neutral, if you have to err, err on the side of toe out. from my experience this week that is wrong. toe in is needed,, but how much is still evading me. while driving the kolb around on snow and ice,, i would notice that when 1 tire was on a slick spot and the other on dry surface, my mkiii would jump in the direction of the tire on the ice, now i had believed my gear to be quite neutral when i last visited the subject 9 years ago.... but this experience convinced me i was toe in by quite a bit. and more sophisticated measurements has confirmed that. now i am using the solid tapered steel legs i bought from kolb. and the camber has always been off since i installed them new, so i have decided to do something about it. so i did some work on the calculator to decide how much i wanted to bend the gear legs down to correct the camber, then how much i wanted to bend the gear back to eliminate the toe in,, figured the angles to do both with 1 bend. after bending the camber is perfect, and i left a tiny bit of toe in, and figured before i tried bending more i would try it. it felt as if i was driving down the railroad track on the railroad ties. it was near impossible to look out the windows to see and keep things straight down the runway,,, but what i think was happening is the rolling resistance would flex the gear backwards, till i was in a toe out position,,, that would increase the rolling resistance, bend back more till the wheel would loose traction then the gear would spring forward, the wheel would slide, skip, roll, bounce, all at the same time and do it at 30 times a second. or there about. long story, but i will start bending some toe in back in the gear, bit by bit,, and keep trying till i get a smooth roll out. in the past if i inflated my tires to 15 lb or so, it could get a bit darty, but if i kept the tire pressure at 8 psi or so, there would be enough flex in the side walls to roll correct. so i will be doing the test with 15 psi in the tires and try and get the toe in so that when the gear flexes back, the tires will be tracking true. so i am thinking my final be will be back near where i started. when i come up with some final answers i will post to the list... one last thought, when i had the alum, gear legs it seems that they flexed less than the spring steel legs. so my results may not fit everyone's needs. but my lessons and experience may help. boyd young mkiii utah. ________________________________________________________________________________
Subject: Re: landing gear toe in - out
Date: Feb 16, 2011
when i come up with some final answers i will post to the list... one last thought, when i had the alum, gear legs it seems that they flexed less than the spring steel legs. so my results may not fit everyone's needs. but my lessons and experience may help. boyd young Boyd Y/Kolber: I always use a lot of camber and a tad of toe in. Heat treated (48rc) 4130 gear legs are more flexible in all directions than 7075 aluminum legs, especially the extra long legs on the stock MKIII. Braking will cause the main gear to toe out. Toe out spreads the gear legs and reduces camber. My gear legs are 24" total with 18" outside the gear leg sockets. Don't get near the flex with the short stubby legs. john h Titus, Alabama ________________________________________________________________________________
Date: Feb 16, 2011
Boyd, The gear is toed in slightly on both my Firestar and Kolbra. It taxies fine on both aircraft and have not noticed the type of problem you are seeing. When either aircraft is picked up by the tail and moved backwards, the gear spreads out and it looks like I had a very hard landing. I will usually put my back to the cockpit and lift underneath with my hands. This will spring the gear back to their original position to make it look like it's not spread out like that. If one side is not sprung back, it can make your wings look like they are not level even if it's sitting on level ground. Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000 hours 24 years flying it Kolbra 912UL N20386 3 years flying it 150 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331231#331231 ________________________________________________________________________________
Date: Feb 16, 2011
I always use a lot of camber and a tad of toe in. john h Titus, Alabama >>>>>>>>> john and kolbers been doing a lot of investigating the last couple days... it seems the best i have learned about camber,,, it that it should be positive, on an empty plane,,, but when the plane is loaded to grose wt,, they should be netural. i guess the book furtherer clairified that they should be netural at the normal loading of the plane,,, example,, if you normaly fly at 80 % gr, wt. then you should set it at netural at that wt.... if occasional you are at 60 or 100 % you would be only slightly pos, or neg, camber. this will maximize the tire wear. likewise the 'toe in' should be equal to the amount the wheel pulls back due to the rolling resistance,, which will vary depending on the flex for and aft in the gear leg, and the loading of the plane. kind of hard to measure at 50 mph... guess you go by feel at that point.. everything else is just a starting point. trouble in a kolb,,, once it is set,,, its kind of hard to change. boyd young mkiii utah ________________________________________________________________________________
Date: Feb 16, 2011
> kind of hard to measure at 50 mph... guess you go by feel at that point.. everything else is just a starting point. trouble in a kolb,,, once it is set,,, its kind of hard to change. > > boyd young > mkiii utah This obviously is one of the shortcomings of Kolb aircraft. It's a guessing game on toe-in. What I did for the Firestar is to adjust it to neutral to begin with and then equally toe in on both sides. With the aluminum gear, it tends to toe out quite a bit with added weight. Once the gear leg hole is drilled, there's no re-drilling, unless you get another gear leg. One advantage to this type of gear, is that it can be removed easily. That's got to be a big plus. Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000 hours 24 years flying it Kolbra 912UL N20386 3 years flying it 150 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331234#331234 ________________________________________________________________________________
Date: Feb 16, 2011
Boyd, The gear is toed in slightly on both my Firestar and Kolbra. It taxies fine on both aircraft and have not noticed the type of problem you are seeing. When either aircraft is picked up by the tail and moved backwards, the gear spreads out and it looks like I had a very hard landing. I will usually put my back to the cockpit and lift underneath with my hands. This will spring the gear back to their original position to make it look like it's not spread out like that. If one side is not sprung back, it can make your wings look like they are not level even if it's sitting on level ground. Ralph B >>>>>>>>>>>>>>>>>>> what type of gear legs do you have? other than my camber being way off... it drove ok before i started.. except when i was on ice. i may end back wher i started with toe in. wish now i had only adjusted camber. hind sight. i am getting too soon old and too late smart boyd ________________________________________________________________________________
Date: Feb 16, 2011
Subject: South Florida Flyers
Hey South Florida Flyers or any one that wants to fly in somewhere in Florida some morning. I don't have my Kolb down here this winter but I'm renting a SportCruiser out of Charlotte county and I can meet most any where. How about it? Gary A, Buford, George A, and anyone else want to meet some where? I have a plane available (right now) this Saturday 2/19/ 11 AM we could meet at Arcadia or Wauchula. Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Date: Feb 16, 2011
Boyd It sounds like I have the same solid steel gear legs. I really like the gear but don't like the look of negative camber. Where/how did you bend the gear and did you remove the gear to bend it? I clamped a staight 2X4 between both axles notched for the brake attachment while installing my gear legs so I think they are neutral. But they flex under load so much that things could change. Keep us posted Rick Neilsen Redrive VW Powered MKIIIC On Wed, Feb 16, 2011 at 11:03 AM, b young wrote: > OOOOOKKKKKK > > i need to apologize to the list... in the past the question has come up as > to what the value of toe in - out was necessary. many on the list have said > you need some toe in,, and my response has always been copied from the kolb > builders manual. which states in short, neutral, if you have to err, err on > the side of toe out. from my experience this week that is wrong. toe > in is needed,, but how much is still evading me. > > while driving the kolb around on snow and ice,, i would notice that when 1 > tire was on a slick spot and the other on dry surface, my mkiii would jump > in the direction of the tire on the ice, now i had believed my gear to be > quite neutral when i last visited the subject 9 years ago.... but this > experience convinced me i was toe in by quite a bit. and more sophisticated > measurements has confirmed that. now i am using the solid tapered steel > legs i bought from kolb. and the camber has always been off since i > installed them new, so i have decided to do something about it. so i did > some work on the calculator to decide how much i wanted to bend the gear > legs down to correct the camber, then how much i wanted to bend the gear > back to eliminate the toe in,, figured the angles to do both with 1 > bend. after bending the camber is perfect, and i left a tiny bit of toe > in, and figured before i tried bending more i would try it. it felt as > if i was driving down the railroad track on the railroad ties. it was near > impossible to look out the windows to see and keep things straight down the > runway,,, but what i think was happening is the rolling resistance would > flex the gear backwards, till i was in a toe out position,,, that would > increase the rolling resistance, bend back more till the wheel would loose > traction then the gear would spring forward, the wheel would slide, skip, > roll, bounce, all at the same time and do it at 30 times a second. or there > about. > > long story, but i will start bending some toe in back in the gear, bit > by bit,, and keep trying till i get a smooth roll out. in the past if i > inflated my tires to 15 lb or so, it could get a bit darty, but if i kept > the tire pressure at 8 psi or so, there would be enough flex in the side > walls to roll correct. so i will be doing the test with 15 psi in the > tires and try and get the toe in so that when the gear flexes back, the > tires will be tracking true. so i am thinking my final be will be back near > where i started. > > when i come up with some final answers i will post to the list... one > last thought, when i had the alum, gear legs it seems that they flexed less > than the spring steel legs. so my results may not fit everyone's needs. > but my lessons and experience may help. > > boyd young > mkiii utah. > > > * > > * > > ________________________________________________________________________________
Subject: New Videos to watch....
Date: Feb 16, 2011
Hi All! Took these yesterday...first will be the flight...second will be us digging out the plane after it fell through the crusty snow....third is taxiing out of the mess....and forth is of the well jacks I made to get the plane in and out of the hangar.... http://www.youtube.com/watch?v=kM3zDj729Wc http://www.youtube.com/watch?v=4BiwRQX6VfY http://www.youtube.com/watch?v=rvYpzzN64nE http://www.youtube.com/watch?v=vNfz07uUfwM chris ambrose M3X/Jabiru A-2200 N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331239#331239 ________________________________________________________________________________
Subject: Re: South Florida Flyers
Date: Feb 16, 2011
I fly out of Lantana Airport in west palm beach and have been considering heading to okeechobee airport one of these days... Here are some other florida flyers: http://forums.matronics.com/viewtopic.php?t=55393&highlight Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331249#331249 ________________________________________________________________________________
Date: Feb 16, 2011
Subject: Runway Lenght for Kolb M3
I'm wanting to create a grass strip for my Mark3 on a farm my brother owns in central Indiana. How much runway do I need assuming clear approaches (no obstacles) at both ends. This is all level land and is currently being farmed in corn or beans. Thanks. Mark Rinehart Indy Kolb Mark3 N68MR ________________________________________________________________________________
Date: Feb 16, 2011
Boyd It sounds like I have the same solid steel gear legs. I really like the gear but don't like the look of negative camber. Where/how did you bend the gear and did you remove the gear to bend it? I clamped a staight 2X4 between both axles notched for the brake attachment while installing my gear legs so I think they are neutral. But they flex under load so much that things could change. Keep us posted Rick Neilsen >>>>>>>> Rick yes i had to remove the gear,,, my son bought a pipe bender that goes up to 2 inch,, the bending was easy,, but wish i had left toe in alone and only did the camber. b oyd ________________________________________________________________________________
Subject: Re: Runway Lenght for Kolb M3
Date: Feb 16, 2011
I'm wanting to create a grass strip for my Mark3 on a farm my brother owns in central Indiana. How much runway do I need assuming clear approaches (no obstacles) at both ends. This is all level land and is currently being farmed in corn or beans. Thanks. Mark Rinehart Indy Kolb Mark3 N68MR >>>>>>>>>>>> with good skills and lo altitude,, 600 ft seems to work for some,,, less skills and higher altitude = longer. mark it out on the runway you are using now and compare, your mileage may vary. boyd young mkiii ________________________________________________________________________________
Date: Feb 16, 2011
A friend of mine has a level strip with good approaches in both directions that is exactly 1,000' long, and when I have a passenger and it is hot, I wouldn't want any less. What works when things are optimum is not what you want on those occasions when things are less than ideal. If you can come up with 1,200' - take all of it. My home field (3TN0) is 750' long, but it has a good slope to it, takeoff is downhill into the prevailing wind and landing is uphill, and a sloped runway makes a huge difference. I wouldn't want any less, because every once in a while I use most all of it. Not all landings turn out the way you plan, and once I touch down, (headed uphill towards the neighbor's house and trees) there is no go-around. Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331273#331273 ________________________________________________________________________________
Date: Feb 16, 2011
How much runway do I need assuming clear approaches (no obstacles) at both ends. Mark Rinehart Mark R/Gang: Gantt International Airport is 750 feet useable. Approaches aren't all that clear. Plenty room for me and my mkIII. I also fly passengers out of Gantt, which is a cow pasture. john h mkIII Titus, Alabama ________________________________________________________________________________
From: "Larry Cottrell" <lcottrell1020(at)gmail.com>
Date: Feb 16, 2011
Mark, I would consider John's 750 feet, a bare minimum, get more if you can. Keep in mind that John is a much better pilot than most of us. The only time the runway is too long is when you have to push the plane. Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ----- Original Message ----- From: John Hauck To: kolb-list(at)matronics.com Sent: Wednesday, February 16, 2011 3:55 PM Subject: Re: Kolb-List: Runway Lenght for Kolb M3 How much runway do I need assuming clear approaches (no obstacles) at both ends. Mark Rinehart Mark R/Gang: Gantt International Airport is 750 feet useable. Approaches aren't all that clear. Plenty room for me and my mkIII. I also fly passengers out of Gantt, which is a cow pasture. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 16, 2011
I would consider John's 750 feet, a bare minimum, get more if you can. Keep in mind that John is a much better pilot than most of us. The only time the runway is too long is when you have to push the plane. Larry Larry/Kolbers: I beg to disagree. Gantt International was 600 feet when I made my first solo flight in a fixed wing aircraft, the Ultrastar I built in 1984. Of course, I crashed on my first landing, but two weeks later armed with new main gear, nose, and prop, I learned to land on my second ever attempt. That was without brakes too. I'd have a longer strip if I could. Get all you can get while you can. Larry is used to flying off his own 2,600 foot gravel strip with no trees in his part of the State of Oregon. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 16, 2011
Take all that is available you will be coming up with friends that can not use a kolb strip Ellery Batchelder Jr. -----Original Message----- From: mark rinehart <capt_riney(at)yahoo.com> Sent: Wed, Feb 16, 2011 2:18 pm Subject: Kolb-List: Runway Lenght for Kolb M3 I'm wanting to create a grass strip for my Mark3 on a farm my brother owns in entral Indiana. How much runway do I need assuming clear approaches (no bstacles) at both ends. This is all level land and is currently being far med n corn or beans. Thanks. Mark Rinehart ndy Kolb Mark3 N68MR ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Feb 16, 2011
I am not sure which part John is disagreeing with, but I am used to it. :-) I didn't always fly where there were no trees. My last runway before this one was about 400 feet. I had to touch down under power lines, the small ones, and there was a wall of Ponderosa trees that I was landing up against. I did it, didn't like it! You just had to get it right, every time. It was always exciting. Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ----- Original Message ----- From: John Hauck To: kolb-list(at)matronics.com Sent: Wednesday, February 16, 2011 4:54 PM Subject: Re: Kolb-List: Runway Lenght for Kolb M3 I beg to disagree. Gantt International was 600 feet when I made my first solo flight in a fixed wing aircraft, the Ultrastar I built in 1984. Of course, I crashed on my first landing, but two weeks later armed with new main gear, nose, and prop, I learned to land on my second ever attempt. That was without brakes too. I'd have a longer strip if I could. Get all you can get while you can. Larry is used to flying off his own 2,600 foot gravel strip with no trees in his part of the State of Oregon. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: New Videos to watch....
Date: Feb 16, 2011
Chris, good videos. You could have plowed through that snow if the skis were waxed. Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000 hours 24 years flying it Kolbra 912UL N20386 3 years flying it 150 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331309#331309 ________________________________________________________________________________
Date: Feb 16, 2011
Ralph, The snow was to deep and packed and frozen...once it broke through,it was all done...I have Lexan on the bottom of the skis and it really works good ! The first flight with the skis was without the Lexan and there was still some grass showing...maybe an inch or 2 of snow and I could feel the drag on the skis...next day I put the Lexan on the bottoms and holy cow...what a difference ! I had to be careful with the throttle coming up to the hangar it was so slippery! chris ambrose M3X/Jabiru A-2200 N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331312#331312 ________________________________________________________________________________
Date: Feb 17, 2011
railroad track on the railroad ties. it was near impossible to look out the windows to see and keep things straight down the runway,,, but what i think was happening is the rolling resistance would flex the gear backwards, till i was in a toe out position,,, that would increase the rolling resistance, bend back more till the wheel would loose traction then the gear would spring forward, the wheel would slide, skip, roll, bounce, all at the same time and do it at 30 times a second. or there about. Boyd/list This brings to mind years ago when they first started putting radial tires on the steering axles of 18 wheelers. For a while we had our jobs cut out for us to keep the it in one lane. The rig would lurch right, then left; kind of where ever it wanted to go, and the driver was left with the task of getting safely to our destination. Through experimentation and testing they found that the toe in normal for years with bias tires didn't work with radials. I believe the amount of weight had something to do with it. The greater rolling resistance with bias tires pulled back on the steering and suspension, causing the wheels to roll parallel. But with the reduced rolling resistance of radials, the toe in remained intact, consequently the steering axle wheels "argued" with each other which one was in charge at any given moment. The resolution of this problem was welcome for those of us who fought with it for thousands of miles!! Good luck getting it right. Hope this info gives you some insight, like experimenting with tire pressure, which is easier to change than bending, and not nearly as "permanent." Dave Kulp Bethlehem, PA FireFly 11DMK ________________________________________________________________________________
Date: Feb 17, 2011
Subject: Grass Strip for Mark3
Thanks to all for the responses. Sounds like I don't want anything less than 750 ft, and more is better. I'm going to the farm this weekend to walk the ground and see what location would be best. Mark Rinehart Indy Mark3 N68MR Sent from my iPad ________________________________________________________________________________
Date: Feb 18, 2011
Subject: Re: Grass Strip for Mark3
Mark, from my experience flying a MK lll with a 80 hp rotax at 900' above sea level with a full load you should be ok with a 1000' with clear approach on both ends....more of course would be better....for what it is worth....Jim Swan Do not archive FIRESTAR ll 503 Michigan jswan GPS FOR MY RUNWAY N 42 deg 28.581 W084deg 44.825 ph. 517-663-8488 ________________________________________________________________________________
Date: Feb 18, 2011
Rick, I'm good for that on Sat,either place.Been off line until today (fri.A.M.)3 30-819-3000 verizon.Let me know G Aman -----Original Message----- From: Rick Neilsen <neilsenrm(at)gmail.com> Sent: Wed, Feb 16, 2011 2:11 pm Subject: Kolb-List: South Florida Flyers Hey South Florida Flyers or any one that wants to fly in somewhere in Flori da some morning. I don't have my Kolb down here this winter but I'm renting a SportCruiser o ut of Charlotte county and I can meet most any where. How about it? Gary A, Buford, George A, and anyone else want to meet some where? I have a plane available (right now) this Saturday 2/19/ 11 AM we could meet at Arcadia or Wauchula. Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Date: Feb 18, 2011
From: william sullivan <williamtsullivan(at)att.net>
Subject: Fw: Plane crash- Ellery
- Ellery is okay. http://new.bangordailynews.com/2011/02/17/news/bangor/ultralight-plane-cras hes-in-stetson/# - ------------------------- ------------------------ Bi ll Sullivan ------------------------- ------------------------ Wi ndsor Locks, Ct. ------------------------- ------------------------ FS 447 ________________________________________________________________________________
Subject: Re: Fw: Plane crash- Ellery
Date: Feb 18, 2011
Ellery is okay. http://new.bangordailynews.com/2011/02/17/news/bangor/ultralight-plane-crashes-in-stetson/# Bill Sullivan Bill S/Kolbers: Glad Ellery is ok. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 18, 2011
Gary & Other South Florida Kolb Flyers I can't get a plane for tomorrow. How about next Saturday 2/26 Rick Neilsen Redrive VW Powered MKIIIC On Fri, Feb 18, 2011 at 8:23 AM, wrote: > Rick, > I'm good for that on Sat,either place.Been off line until today (fri.A.M.) > 330-819-3000 verizon.Let me know > G Aman > > > -----Original Message----- > From: Rick Neilsen <neilsenrm(at)gmail.com> > To: kolb-list > Sent: Wed, Feb 16, 2011 2:11 pm > Subject: Kolb-List: South Florida Flyers > > Hey South Florida Flyers or any one that wants to fly in somewhere > in Florida some morning. > > I don't have my Kolb down here this winter but I'm renting a SportCruiser > out of Charlotte county and I can meet most any where. How about it? Gary A, > Buford, George A, and anyone else want to meet some where? I have a plane > available (right now) this Saturday 2/19/ 11 AM we could meet at Arcadia or > Wauchula. > > Rick Neilsen > Redrive VW Powered MKIIIC > > * > > > ========== > > tor?Kolb-List">http://www.matronics.com/Navigator?Kolb-List > > ========== > > tp://forums.matronics.com > > ========== > > bution">http://www.matronics.com/contribution > > ========== > > * > > * > > * > > ________________________________________________________________________________
Date: Feb 18, 2011
Rick, Just give me notice when and where.I could also keep a seat open for a pass enger I could pick up anywhere in between. Thanx G.Aman -----Original Message----- From: Rick Neilsen <neilsenrm(at)gmail.com> Sent: Fri, Feb 18, 2011 10:54 am Subject: Re: Kolb-List: South Florida Flyers Gary & Other South Florida Kolb Flyers I can't get a plane for tomorrow. How about next Saturday 2/26 Rick Neilsen Redrive VW Powered MKIIIC On Fri, Feb 18, 2011 at 8:23 AM, wrote: Rick, I'm good for that on Sat,either place.Been off line until today (fri.A.M.)3 30-819-3000 verizon.Let me know G Aman -----Original Message----- From: Rick Neilsen <neilsenrm(at)gmail.com> Sent: Wed, Feb 16, 2011 2:11 pm Subject: Kolb-List: South Florida Flyers Hey South Florida Flyers or any one that wants to fly in somewhere in Flori da some morning. I don't have my Kolb down here this winter but I'm renting a SportCruiser o ut of Charlotte county and I can meet most any where. How about it? Gary A, Buford, George A, and anyone else want to meet some where? I have a plane available (right now) this Saturday 2/19/ 11 AM we could meet at Arcadia or Wauchula. Rick Neilsen Redrive VW Powered MKIIIC tor?Kolb-List">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com bution">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?Kolb-List ttp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 18, 2011
Just give me notice when and where.I could also keep a seat open for a passenger I could pick up anywhere in between. Thanx G.Aman Wish I could go with you all, but started an annual inspection on my MKIII yesterday. Will be a while until she is flying again. Still planning on flying to Lakeland about 28 Mar 2011, for S&F. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 18, 2011
I'll be driving down for the week. Looking forward to meeting up with Bryan, and meeting any other Kolbers! -------- Gerry Uebbing Firestar II 503 b-box (not flying yet) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331421#331421 ________________________________________________________________________________
Date: Feb 18, 2011
Subject: Astro Pneumatics
About 4 years ago I bought an Astro Pneumatics PR36 pneumatic pop rivet gun. At the time I bought it specifically for pulling 3/16" stainless steel rivets. If memory serves it was about $70 at the time (I just came across the current price at Pegasus Racing and they're $77 now). Anyway, I was getting ready to make an extended nose piece for pulling some rivets that were exceptionally close to a flange when I discovered the other three nose pieces were missing from the bag I keep the riveter in. The next morning I did a search and found Astro Tools in Mount Airy, NC, got their service dept on the phone and asked them about replacement nose pieces. Maybe it was because it was Valentines Day, I don't know, but they sent me out a new set for free. They didn't even charge for shipping. So, if you're in the market for a pneumatic riveter, Astro Tool makes a good one, and they certainly have my thanks. -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: cheap alternative to SPOT
Date: Feb 18, 2011
NOT Kolb specific but may be of interest to Kolbers and other aviators. I'm not selling or pushing this just thought some might be interested, if they have an iPhone. If you are not interested, just skip on to the next or flame me, as you see fit. A couple days ago I downloaded a free App to my iPhone, called MotionX GPS Lite. It is the free version of their have-to-pay-for version. Yesterday I tried it out to see how the tracking and notification service went, not in an airplane but in my car. It works. The difference between the free version and the oh-so-expensive version ($3) is the number of tracks and waypoints you can save and a few other features. This is what was sent to my email when I told it to do so. Name: Track 001 Date: Feb 17, 2011 2:18 pm Map: (valid until Aug 16, 2011) View on Map Distance: 22.8 miles Elapsed Time: 39:03.1 Avg Speed: 35.0 mph Max Speed: 59.9 mph Avg Pace: 01' 43" per mile Min Altitude: 526 ft Max Altitude: 626 ft Start Time: 2011-02-17T19:18:30Z Start Location: Latitude: 42.985869 N Longitude: 78.828044 W End Location: Latitude: 42.985917 N Longitude: 78.828064 W The "View On Map" shown above was actually this link: http://maps.google.com/?t=p&z=15&ll=42.985869,-78.828044&q=http://share.gps.motionxlive.com/shr/x/kmz/1eabb671c39da7bbb21cbc14b09e6ca5 For more info, see: http://news.motionx.com/category/motionx-gps/ I don't think it is as functional as SPOT but it appears to do all I want it to do, so I may pop for the expensive $3 version! -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331430#331430 ________________________________________________________________________________
Date: Feb 18, 2011
Rick=2C Positive feedback about various companies is always good to hear. My Icom A200 comm radio rubber knob covers were old and dry rotted. I called the Icom Co. to order some more (3 pcs.). The guy said=2C send me y our address via email=2C and I'll ship them out to you. I did=2C and they did =2C for free. It didn't even cost me the postage. Great customer service is ALWAYS good advertisement!!! Thanks for the plug for Astro Pneumatics. We know where to go to get a good riveter! Mike Welch So=2C if you're in the market for a pneumatic riveter=2C Astro Tool makes a good one=2C and they certainly have my thanks. -- Zulu Delta Mk IIIC Thanks=2C Homer GBYM ________________________________________________________________________________
Subject: Re: Plane crash- Ellery
Date: Feb 18, 2011
Glad to hear that you are OK, Ellery. I like the comments in the article...good job... [Laughing] -------- 2000 Firestar II R503 DCDI VLS 750 2010 Waiex Jabiru 3300 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331454#331454 ________________________________________________________________________________
Date: Feb 18, 2011
neilsenrm(at)gmail.com wrote: > Gary &Other South Florida Kolb Flyers > > I can't get a plane for tomorrow. How about next Saturday 2/26 > > Rick Neilsen > Redrive VW Powered MKIIIC > > There is an "event" at Venice Municipal Airport (KVNC) on 26 Feb. They bill it as an Open House and Fly In. If I get any more info on it, I'll post. -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331474#331474 ________________________________________________________________________________
Subject: N213 Wreck
Date: Feb 18, 2011
Well Here is The skinny of me and N213 thursday afternoon I was out flying when all of a sudden I got a real violent Vibration enough to set the ELT off it shook the whole airplane this way and it was violent enough to she d both carbs then I was getting some glider time in, and only one small bo g covered with 3 feet of snow I was not... in a panic mode at all I ended up landing 200 yards short and in the woods the mk3 didnt make it but I got a bruised ankle and a small scratch on the back of my hand, I spent the day with the FAA and talking to the NTSB and insurance company and th e rest of the day taking what was left of the airplane apart and out of th e woods before the airplane pirates could find it The FAA guy said the propellor was the cause of this situation as far as he can see, one of the three Warp Drive Blades lost 2/3 of its blade. I never been fond of Warp drive Props and now I can never change my mind ab out what I thought of them, im Thinking this could have taken my life or worse someone elses life, The NTSB wants to take possession of this Prop Ellery N213 Down & Out ________________________________________________________________________________
Date: Feb 18, 2011
Subject: Re: N213 Wreck
Ellery, glad to year you're OK, sorry about the plane. Funny, I always had the impression that Warp Drives were the toughest out there? -Dana At 09:16 PM 2/18/2011, Ellery Batchelder Jr wrote: > >Well Here is The skinny of me and N213 thursday afternoon I was out flying >when all of a sudden I got a real violent Vibration enough to set the ELT >off it shook the whole airplane this way and it was violent enough to shed >both carbs then I was getting some glider time in, and only one small bog >covered with 3 feet of snow I was not... in a panic mode at all I ended up >landing 200 yards short and in the woods the mk3 didnt make it but I got a >bruised ankle and a small scratch on the back of my hand, I spent the day >with the FAA and talking to the NTSB and insurance company and the rest of >the day taking what was left of the airplane apart and out of the woods >before the airplane pirates could find it >The FAA guy said the propellor was the cause of this situation as far as >he can see, one of the three Warp Drive Blades lost 2/3 of its blade. I >never been fond of Warp drive Props and now I can never change my mind >about what I thought of them, im Thinking this could have taken my life or >worse someone elses life, The NTSB wants to take possession of this Prop > -- Do YOU trust a government that won't obey it's OWN LAWS? ________________________________________________________________________________
Date: Feb 18, 2011
I thought they were the toughest out there but I just didn't like the ide a of how they pitch the blades and the design of the Prop Hub on this particular model Ellery Batchelder Jr. -----Original Message----- From: Dana Hague <d-m-hague(at)comcast.net> Sent: Fri, Feb 18, 2011 10:05 pm Subject: Re: Kolb-List: N213 Wreck Ellery, glad to year you're OK, sorry about the plane. Funny, I always had the impression that Warp Drives were the toughest out there? -Dana At 09:16 PM 2/18/2011, Ellery Batchelder Jr wrote: Well Here is The skinny of me and N213 thursday afternoon I was out flying when all of a sudden I got a real violent Vibration enough to set the ELT off it shook the whole airplane this way and it was violent enough to she d both carbs then I was getting some glider time in, and only one small bo g covered with 3 feet of snow I was not... in a panic mode at all I ended up landing 200 yards short and in the woods the mk3 didnt make it but I got a bruised ankle and a small scratch on the back of my hand, I spent the day with the FAA and talking to the NTSB and insurance company and th e rest of the day taking what was left of the airplane apart and out of th e woods before the airplane pirates could find it The FAA guy said the propellor was the cause of this situation as far as he can see, one of the three Warp Drive Blades lost 2/3 of its blade. I never been fond of Warp drive Props and now I can never change my mind ab out what I thought of them, im Thinking this could have taken my life or worse someone elses life, The NTSB wants to take possession of this Prop -- Do YOU trust a government that won't obey it's OWN LAWS? ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Subject: Re: kolb toe in
Date: Feb 18, 2011
ok kolbers.. my toe in numbers are in. this is quite long,,, and if you are not interested hit delete now. my starting numbers may not be as accurate as I would have liked them to be, my measuring technique improved with time. but not with standing this is what I have. the camber of both wheels was a neg 3 deg. this was due to the way the axels were bent at the factory, when the plane was hoisted in the air the axels were parallel to the ground, and when the weight of the aircraft was put on them, both wheels went neg, and when I climbed in with a passenger it went to 4 1/2 deg neg, the tops of the tires were angled in and the gear looked squatted down. recent post about toe in had me wondering. and I had quoted what was in the mkiii construction manual for "toe in". which was "neutral, and if you have to err, err on the side of toe out." a while back my son bought a very nice pipe bender. so I had him bring it over and we did some work on the gear. my original measurements which may not be as accurate as I would have liked,, best I knew how at the time, were: left wheel .70 deg toe in,,, right wheel 1.000 deg toe in total for both wheels of 1.70 with neg 3 deg camber each side. with the air pressure in the tires low (6 to 8 psi) it drove around what I thought was ok... if I pumped the air pressure up to 15 it would dart across the runway and made it hard to keep the white line between the tires. so for 600 hours I ran low tire pressure. I figured if I was going to put in a bit of positive camber, I could correct the toe in at the same time. so my son and I proceeded to bend steel. and by varying the bend angle, I could adjust for camber and toe in at the same time with one bend. what we ended up with was about 3/4 deg pos camber on the right and 1 deg pos camber on the other right (left), and the toe in was neutral on both sides,,, I was quite thrilled, until I took it out for a drive. from the neutral toe in as I started rolling for take off, the rolling resistance pulled the gear back till I was in a toe out condition. at that time the drag on the wheel increased and the gear flexed back till the tire started sliding, and the gear would spring forward.. it felt like I was riding a jack hammer. so back to the drawing board. a friend and I went out this afternoon and started bending some "toe in" back in the gear. what we ended up with was: left wheel .78 deg right wheel .70 deg both wheels 1.48 deg... my goal was 1.5 deg,, I came real close. it was less then my 1.7 I started with,,, I went for a test taxi and it would dart across the runway,, not as bad as before,,,, and the jack hammer was gone,, I figured if I lowered the tire pressure it would be ok... but we tried one more time. this time we only bent 1 gear, and I ended up with left .52 deg "toe in" and right stayed .7 deg "toe in" total for both wheels 1.22 deg,,, I increased the camber to 1.5 deg pos camber each side. with my friend sitting on the side each side would go to neutral camber. I went for another taxi test,,, the darting across the runway went from manageable to barely noticeable.. but there was a tiny bit of shake in the right side when I hit the brakes. I am quite certain that if I lower the air pressure it will go away. a test for another day. I ran out of daylight. from my experience and if I had computerized bending equipment, I would go with .625 deg toe in per side for 1.25 deg for the combined figure. or I would redesign the landing gear sockets to make them adjustable. for "toe in" then you could dial in exactly what you need. I will fly like this for a while.. but I may experiment again with the tubular steel, hardened to 48 rockwell. my gear is the solid tapered spring steel gear legs that the new kolb company sold for the mark iii. your mileage may vary. the aluminum gear (i think) would not be as flexable, so less toe in would be required. I took a few pictures if any one is interested.. I will have to get them off the camera, resized and posted. boyd young mkiii utah ________________________________________________________________________________
Date: Feb 18, 2011
I thought they were the toughest out there but I just didn't like the idea of how they pitch the blades and the design of the Prop Hub on this particular model Ellery Batchelder Jr. Ellery B/Kolbers: What model hub and blades were you flying? Have you talked to Darryl at Warp Drive? First time I have heard of a blade seperating on a Warp Drive. Again, glad you are ok. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 18, 2011
I'm just glad to hear that your ok. Insurance can replace the bird so you can fly again. It does speak volumes on the safety of the design. One of the reasons I picked a Kolb. -------- Gerry Uebbing Firestar II 503 b-box (not flying yet) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331485#331485 ________________________________________________________________________________
Subject: toe in
Date: Feb 18, 2011
kolbers,, this is how I calculated the angles for toe in on my mkiii initial figures were done by hanging a pipe under the fuselage on the centerline, then hanging a 5 ft pipe along the outside of the wheel, then measuring from each side to center,, I think this was prone to more error as the pipe along the wheels could vary in angle by whether the pipe was on the sidewall or on a raised letter. subsequent measurements were made after picking the brain of an a&p I made a piece of wood cut to the diameter of the wheel , and placing a piece of sheet metal to keep it centered on the rim. then added a side piece to help hold a carpenter square. then placed the wheel on a grease plate, (2 pieces of floor tile with a layer of grease between them. could use alum sheets) by putting a straight board, or I used a steel angle supported with sections of 2x8 to hold it at the correct height. and held against the back of both tires. then used a carpenters square to hold against the straight angle. and laid it on the wheel bracket. then holding the square against the back of the block measured the distance from the edge of the square to the front of the block. or more specific a spot on the block 5.725 inches from the back edge of the block. this measurement was chosen because of the ratio between the measurement and the angle. if the measurement from the square to the tick mark on the front (left) side of the block was .052 inches the angle is determined by moving the dismal 1 space to the right. or .52 deg (I learned this nice little association with the distance from the square and tick mark at 5.725 inches and angle quite by accident while playing with a spread sheet,) and it will only work while the angles are very small. the tangent of the angle = the measurement of the opposite side divided by the adjacent side. but we know the opposite and adjacent, we use the inverse tangent function. the inverse tangent function = the ratio .052/5.725 or TAN-1 power is .52 deg Toe In. I measured the distance using a caliper depth indicator, on the back of the block it measured 1.5 inches, or the width of the square, and the left side measured at the tick mark 1.552 for the difference of .052 inch. to measure the camber, place the wood block vertical, and hold the square on the floor and against the block going vertical. boyd young mkiii utah ________________________________________________________________________________
Date: Feb 18, 2011
Great to know Ellery is alright. Ron @ KFHU --- william sullivan wrote: ============ Ellery is okay. http://new.bangordailynews.com/2011/02/17/news/bangor/ultralight-plane-crashes-in-stetson/# Bill Sullivan Windsor Locks, Ct. FS 447 -- kugelair.com ________________________________________________________________________________
Date: Feb 18, 2011
Great that you made it out. Well I guess I am not going to get a Warp drive either. I like that Tennessee prop anyway. Too bad they don't make a 3, 4 blader's. ---- Ellery Batchelder Jr wrote: ============ Well Here is The skinny of me and N213 thursday afternoon I was out flying when all of a sudden I got a real violent Vibration enough to set the ELT off it shook the whole airplane this way and it was violent enough to shed both carbs then I was getting some glider time in, and only one small bog covered with 3 feet of snow I was not... in a panic mode at all I ended up landing 200 yards short and in the woods the mk3 didnt make it but I got a bruised ankle and a small scratch on the back of my hand, I spent the day with the FAA and talking to the NTSB and insurance company and the rest of the day taking what was left of the airplane apart and out of the woods before the airplane pirates could find it The FAA guy said the propellor was the cause of this situation as far as he can see, one of the three Warp Drive Blades lost 2/3 of its blade. I never been fond of Warp drive Props and now I can never change my mind about what I thought of them, im Thinking this could have taken my life or worse someone elses life, The NTSB wants to take possession of this Prop Ellery N213 Down & Out -- kugelair.com ________________________________________________________________________________
Subject: Re: registering an experimental aircraft
Date: Feb 19, 2011
Jason, Roger willco. My plan is to borrow a copy of more reasonable Operating Limitations from a friend's airplane and offer that as a model for emulation. Wish I had kept a copy from my previous airplane. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331497#331497 ________________________________________________________________________________
Date: Feb 19, 2011
Ellery, I'm glad to see that you made it out ok. How many hours did you have on the Warp Drive prop? Did it have any nicks that you could see? How many hours did it have? Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000 hours 24 years flying it Kolbra 912UL N20386 3 years flying it 150 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331500#331500 ________________________________________________________________________________
Subject: Re: toe in
Date: Feb 19, 2011
There is an easy way to see toe-in that I think I may have gotten off this list several years ago. BTW, the steel legs that I bought from TNK to replace the aluminums a couple years back installed with a mild but visible amount of positive camber. Positive camber wheels, when installed parallel will want to track wider and need compensating toe-in. I just guessed at what would do the job. If you have a concrete floor with enough room, mark a center line from the tail through the cage to a spot at least ten feet forward of the nose. Chalk line works, then mark the floor with a felt tip. Now run the chalk line from behind the wheels, touching at the centerline of the tire and just grazing the front to a point ten feet out. Snap the chalk line at both wheels and measure the half distances for individual toe and compare to the distance at the main wheels. I think I did something like 1/4" each wheel. It handles the same on either grass or pavement. BB On 19, Feb 2011, at 12:18 AM, b young wrote: > kolbers,, > > this is how I calculated the angles for toe in on my mkiii > > ________________________________________________________________________________
Subject: Re: toe in
Date: Feb 19, 2011
Boyd, Thanks for the explanation and photos of how you did the toe-in measurements. If you experiment with the hardened tubular steel gear leg toe-in and and camber, please let us know how it goes. After bending my Slingshot hardened tubular steel gear legs last summer, I straightened them by eyeball in my tube bender. Once mounted on the airplane the left gear has negative camber (eyeball) but appears to be about neutral in toe-in. The right gear appears neutral in camber with some apparent toe-in. This is with full fuel but nobody in the seats. I flew it several times after this mod before winter came. It now tracks perfectly true during slow taxi on paved runway but darts side-to-side at a faster pace with much higher pressure in the 600-6 tires than you normally carry. There is no tendency whatsoever to vibrate fore-and aft as you described but this could be due to the completely different angle the gear legs come out of the sockets compared to the standard MkIII leg angles. I'm not satisfied with this so I plan to do some more adjusting(bending) when weather warms up and will try your method of checking the toe-in/out angles. The only thing I see wrong with this measurement method is that it does not reference the centerline of the fuselage, so it is possible to get camber and toe-in on both sides adjusted just the way you want them and yet the fuselage could be going down the runway at an angle. That should not be a big issue though as it won't affect the tracking on the ground, but could look a little peculiar. To check for this all you have to do is measure the angle between the piece behind the tires and the boom tube. If it is 90 degrees, it is square with the fuselage. Please keep us posted on further adjustments or handling results. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331505#331505 ________________________________________________________________________________
Date: Feb 19, 2011
I will be looking for the paperwork on that Prop and get that info out the NTSB wants to know also I'll get you guys that info Ellery Batchelder Jr. -----Original Message----- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Fri, Feb 18, 2011 11:03 pm Subject: Re: Kolb-List: N213 Wreck I thought they were the toughest out there but I just didn't like the ide a f how they itch the blades and the design of the Prop Hub on this particular model llery Batchelder Jr. Ellery B/Kolbers: What model hub and blades were you flying? Have you talked to Darryl at Warp Drive? First time I have heard of a blade seperating on a Warp Drive. Again, glad you are ok. john h kIII itus, Alabama ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Feb 19, 2011
171 Hours on the Prop Ellery Batchelder Jr. -----Original Message----- From: Ralph B <rstar447(at)gmail.com> Sent: Sat, Feb 19, 2011 8:51 am Subject: Kolb-List: Re: N213 Wreck Ellery, I'm glad to see that you made it out ok. How many hours did you have on the Warp Drive prop? Did it have any nicks that ou could see? How many hours did it have? Ralph B -------- alph B riginal Firestar 447 91493 E-AB 000 hours 4 years flying it olbra 912UL 20386 years flying it 50 hrs ead this topic online here: http://forums.matronics.com/viewtopic.php?p=331500#331500 ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Feb 19, 2011
and not a nick visible until this incident Ellery Batchelder Jr. -----Original Message----- From: Ralph B <rstar447(at)gmail.com> Sent: Sat, Feb 19, 2011 8:51 am Subject: Kolb-List: Re: N213 Wreck Ellery, I'm glad to see that you made it out ok. How many hours did you have on the Warp Drive prop? Did it have any nicks that ou could see? How many hours did it have? Ralph B -------- alph B riginal Firestar 447 91493 E-AB 000 hours 4 years flying it olbra 912UL 20386 years flying it 50 hrs ead this topic online here: http://forums.matronics.com/viewtopic.php?p=331500#331500 ======================== =========== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Subject: Good job Ellery
Date: Feb 19, 2011
Ellery glad to hear your Ok Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331511#331511 ________________________________________________________________________________
Subject: Firestar II wing tips
Date: Feb 19, 2011
Hi all Thinking of putting MK3 droop wing tips on my Firestar II Has any one done this and with what out come? Thanks all . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331512#331512 ________________________________________________________________________________
Subject: Re: toe in
Date: Feb 19, 2011
-second try........... There is an easy way to see toe-in that I think I may have gotten off this list several years ago. BTW, the steel legs that I bought from TNK to replace the aluminums a couple years back installed with a mild but visible amount of positive camber. Positive camber wheels, when installed parallel will want to track wider and need compensating toe-in. I just guessed at what would do the job. If you have a concrete floor with enough room, mark a center line from the tail through the cage to a spot at least ten feet forward of the nose. Chalk line works, then mark the floor with a felt tip. Now run the chalk line from behind the wheels, touching at the centerline of the tire and just grazing the front to a point ten feet out. Snap the chalk line at both wheels and measure the half distances for individual toe and compare to the distance at the main wheels. I think I did something like 1/4" each wheel. It handles the same on either grass or pavement. BB On 19, Feb 2011, at 12:18 AM, b young wrote: > kolbers,, > > this is how I calculated the angles for toe in on my mkiii > > ________________________________________________________________________________
Subject: toe in
Date: Feb 19, 2011
>There is an easy way to see toe-in that I think I may have gotten off this list several years ago. >I just guessed at what would do the job. >BB Hi Bob=2C When setting up my gear legs=2C I used a nylon string=2C rather than a ch alkline. I set a very heavy weight on each end=2C after I found the centerline of the plane with a plumb bob. However=2C later=2C I found this isn't really necessary to have a centerline. Here's why=3B If you slide two 5/8"tubes (like chromoly tubing) EXACTLY the same amount=2C into the axle sleeves=2C they will meet at the exact center of the fuselage (assuming the fuselage is square). By eyeballing between the two tubes=2C you can mark a spot that is dead-nuts straight bet ween the two gear legs. You can see this in my second photo (except my axles are twisted forward for toe out). The cinderblock/wood shims show how I came up with the positive camber=2C because you also see where the fu selage is shimmed to be level. Using my digital level showed the tubes were raised 3 degrees up from pure level. In the second photo=2C you can see how I came up with 1) the tow out=2C a nd 2) the positive camber. Once I was satisfied with the chromoloy tubing being perfect=2C I tack welded th em in place. Next=2C I cut off the excess tubing=2C and took them to my welder buddy to TIG weld them. All this talk about toe out=2C tow in=2C etc. was mostly after I set the tow out on my axles. However=2C the concensus seems to be I would have been better off with a slight toe in=2C rather than the tow out I did. For setting toe in or out=2C I find it easier to slide the 5/8" tubes thr ough the axle sleeves (to the exact midpoint)=2C mark them for zero=2C (straight line between axles)=2C and twist the axles for adjusting toe in/out. Yes=2C this DOES affect the camber a little twisting the axle=2C but not enough to change it much. Rather than using trigonometry like Boyd did=2C I did it a little differe nt. I'll use example numbers=3B let's say the tape measure gap between the axle sleeves is 80". Because I have a tiny bi t of camber=2C this causes the distance to increase a small amount=2C when using two tubes. I mark each chromoly t ube exactly 40"=2C and slide them in the axle sleeves. The marks are about 1/4" each inside the sleeve. I can eyeball the 1/4" each side to insure the tubes are equal!! By definition=2C they meet at the plane's centerline !! Mark a spot on something that helps support the two tubes (like my cinder block/wood support)=2C at a point that is straight (zero toe). Here is my math=3B let's say the axle is actually rotating from 2 3/4" f rom the tube marks. This adds up to 40" + 1/4" gap + 2 3/4" = 43" So=2C we have 43" from axle pivot point to the centerline of the plane. The circumference of a circle pi x D=2C where 'D' is 86" (2 x 43"). 3.1 4 x 86" = 270.04 inches. I know a circle has 360 degrees=2C so I divide 270 by 360=2C which equals .75". T herefore=2C if I want to adjust those gear legs=2C I know every 3/4" I rotate the axle equals 1 degree. In the final product=2C my gear legs ended up being 2 1/2 degrees positve camber=2C which I really like=2C and 1.25 degrees toe out. I'm willing to listen to arguments recommending toe in=2C tho. Very easy way to set the gear legs. Anybody care to recommend the EXACT toe in they find that works the best on a MkIII? Mike Welch MkIII ________________________________________________________________________________
Subject: toe in
Date: Feb 19, 2011
Bob=2C everyone=2C I had pictures attached=2C but had to run off for a minute=2C so I sent m y email to the 'drafts' box. When I pulled my message back from the draft box=2C I didn't notice my photos were dropped. Here are the two pictures I took while setting up my gear legs. Mike Welch /9j/4UexRXhpZgAATU0AKgAAAAgADAEOAAIAAAAIAAAAngEPAAIAAAASAAAApgEQAAIAAAAMAAAA uAESAAMAAAABAAEAAAEaAAUAAAABAAAAxAEbAAUAAAABAAAAzAEoAAMAAAABAAIAAAExAAIAAAAK AAAA1AEyAAIAAAAUAAAA3gITAAMAAAABAAEAAIdpAAQAAAABAAABGsSlAAcAAAAoAAAA8gAAOK5E Q0YgMS4wAE1pbm9sdGEgQ28uLCBMdGQuAERpTUFHRSBTNDE0AAAAAEgAAAABAAAASAAAAAFWZXIu MS4wMHUAMjAwMzowNDowOCAwMzoyMTowNABQcmludElNADAyNTAAAAAEAAEAFgAWAAIBAAAAAQAB AAAAAQEAAAAAACGCmgAFAAAAAQAAAtSCnQAFAAAAAQAAAtyIIgADAAAAAQACAACIJwADAAAAAQBA AACQAAAHAAAABDAyMjCQAwACAAAAFAAAAqyQBAACAAAAFAAAAsCRAQAHAAAABAECAwCSAwAKAAAA AQAAAwSSBAAKAAAAAQAAAuSSBQAFAAAAAQAAAuySBwADAAAAAQAFAACSCAADAAAAAQAAAACSCQAD AAAAAQAYAACSCgAFAAAAAQAAAvSSFAADAAAABAAAAwySfAAHAAA1fAAAAxSgAAAHAAAABDAxMDCg AQADAAAAAQABAACgAgAEAAAAAQAACOCgAwAEAAAAAQAABqigBQAEAAAAAQAAOJCkAQADAAAAAQAB AACkAgADAAAAAQAAAACkAwADAAAAAQAAAACkBAAFAAAAAQAAAvykBQADAAAAAQAjAACkBgADAAAA AQAAAACkBwADAAAAAQAAAACkCAADAAAAAQAAAACkCQADAAAAAQAAAACkCgADAAAAAQAAAACkDAAD AAAAAQADAAAAAAAAMjAwMzowNDowOCAwMzoyMTowNAAyMDAzOjA0OjA4IDAzOjIxOjA0AAAAAAEA AAA8AAAAHgAAAAoAAAAAAAAACgAAACAAAAAKAAAHNQAAAQAAAAAAAAAAAQAAADIAAAAKBAADAAgA BgAACAAAAAcAAAAETUxUMAADAAcAAADkAAADegAQAAcAADKoAAAEXgAgAAcAAAFiAAA3BgBAAAQA AAABAAl02ACIAAQAAAABAAm/pwCJAAQAAAABAABkqQ4AAAcAAAAoAAA4aAAAAAAAAAAAAAAAAAAA AAYAAAAAAAAAAAAAAAMAAAAAAAAAAAAAACsAAABgAAAAIgAAAAAAAAAAAAAABgAAAAEAAAAAAAAA AAAAAAIAAAdfAAAAAAAAAAAH0wQIAAMVBAAAACIAAAAAAAAAAAAAAAAAAAAAAAACOgAAAQAAAAF8 AAAAAwAAAAMAAAABAAAAAAAAAAYAAAAEAAAABwAAAAAAAAAAAAAAAAAAAAMAAAAAAAAAAAAAAFgA AARwAAADVAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEAAAABAAAfQAAAAAivr6+vAAUbSwAE 3iwABLrAAATrHwAE3fwABGtJAARI3AAETjQABDNQSAKgIEAAIFAkACAKCQBAoSigDECKDSRAQACA VWAAAoIlGACAIoBoECmAABDsKIYAFBAAwQqkAAZAEAgSWQACAgUQBoJBYERAQgwQxBAAAgpEAQCM mJlAgAAwAEFLpAQAAgAMQHBGAAQBKAQoAgIYCAUYiIYYiEAABAgACcIAQIBUAQiLAARAgFJEABoA ATEAUQCCAoZAQAAMQAAAyCgAgEogUAhBBBQdAmYEAgTECCAUqQCBQgQIiKAgAgIIABIAQiAkgQOB CCSkgAAQAwAIQAKkAig4AAiIREAAAqoEQBQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAADLTYAAvNAAAMXyAADKgIAAyR1AALtUQACuTkAAqefAAKCZYCABiBFIUAigIwAQIAA FEkSgogARBIBJAUABICcMBqCSIiAQIoAgiCKIiIIBECA9AgJACBkGgBCAIkCQAQMiEAURYgICCiA CCAIACChRACP5IBAhgQIBCDZiIiAEAAAQgpAACAggEBIBIQAKIAABRBogAQAAAAgg4UKAAIBokBI qWHAYAJMDIARQgwBgMRAogVQgQQgAABBIARgBALEAIaJICiCxkQRKBAAAAGgAABIuKCBABCAIATB AgEg0QgBkCkCQIiMTABAgAAkQIIDAE5lwAEgJAIhgIZEAAwgTgCAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAACdAAAAqQAAAMYAAADHAAAAxAAAAJ0AAACaAAAAqgAAAKQw CKEghAAAwUAAgGCBKhgQAsQgKAAKQBBIhACiDQAAMEgCAAJkkAAAigRAAKACBALLBDQ0UIIAgCQE AhCgEAgELAAAiACCQACKAAYFAgBAAAJmAJAEBAEECABABKUkSFAIgEAQgEkAIAACBAVAAAIkpAAA YhPAGGjQIAQAIQkCLAAAADIghAACgwAAQAAAIADCoCBBAA0IJKCBAYVUgQASGACAJADAAhwBQSAA LJUQAhoFABQEARoEDCgAAgYgAAMgEQAAkJwAQBwgACoKBAgAASogQIQQwACSAIAAQEliAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA+ysgAN5+UAC7vLAAy/WQAMPh8ACO0Q AAjkjwAKnuYACk+iqAUEIACEAVKRIASEIIYAABACoAQCAAGKACAIAHgQAEQEFCBAAAwEACEAgQgg gCkIAwAItRkKAEC0BAEQABQCAoYlAgKGCgAi0UQEUqAACYAyYSBUKAIACSAARMAJIQgAAAEBgRBA AWAgAAAAJBQARCIgAEFCEAACEAQCAAEAAQkAAEmAkjCBAgAqQiQgZAAkAAEATAAJIgCIqCQEADEw EJBImABCAAAA6gAAAIEACUBRCgBAAFABQEgAAAgoQgDgESgKQOBgAACEAsFCApAACAwEAArAISBg AAwiQECCiIMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPv//99d/X7/7//9/3++/+3mFt387fV/9en/r3fv//+/ 3/6/V93/3n/r/v/+vvv//e//f/vv3/9u3e//y/m//939/32/rvf/39v1987l//3tX+V9+37vv/9t /37Xn8vt/r/fnn76/t/399///9/9///9/f/f/f393ff9f53///333//9779ex+/v9/9f/n7td2Tf z/Xt9/2/67v/7b////fv////5X276/19/v5/fv/2937//e//z/87f+/ffv3f/59/387n/v913vf/ /vn1+/vs/Pf//67/7939/97+///3AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC5e3f3ft2/9//979bn1r9/+9f/ f2V07/8bePv/t9/v2t7/v/3+///N7q//6/9t/3n//392/25/f393/+zf31/95/97vr956/3df/3v XWm+//+b//s7///+/t79zk+5/82t6/vv/93/y/7///9N8+/979V0v/79d9f37ft3XV9372/v+75/ 5/P/Xr3W53ef//329vv+9Wv33393//dmv99v/3579e7e+/9/e9/f7///b/237+/u2/t1/93+/Of3 63/+f/3T3f/v399u///e83/7/R3/f/f/XP9z+j9/bb++/wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAA2QcQANPogADObzAA0Q2QAM5v8ADJGPAAxa6wAMVXkADDrJ7vrvvr/c 3/Xq3//v8///a31///7+/3/cz+bv/26////7f/rzeP/P/u7+t++s/1f/+nrf/et/v/9562+/z/f1 92/v2X/v/+6+/+//vlX+///xv93t/n73/sfn7/vP/3/H+t///2ff+/+///8/pn//+1/+//3n7f/7 X33//1fP//z9/m///+3/Xf3t/vfvb/vf3fvfvs+9/v9b/+tu4f9/bdL3715i3/e03z9////9f5/O ////u9//z1l/f/+9/t/f2r//vv7+v9913///7ru/73fr6v5sr/3//P///3fHfe8AAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADCvQAAycBAAMNxAADI/YAAvlBAALaOQACwGUA Ap8MAAKSn/u3//dr/f+vzzf/PXnf925d7v/7Wvvz/vZ+//Lj/v/fv+/3+d3f/39///+///Pf/z/v 3//+3u/r/9u9/+/////7vt/X33t/7tbvfe/vv//++en3f2/7//ebbfW///7++979/917v///X//9 9uf+/v//1/3f8Pf7//v2/ld/v/70/8bsr5fd39t93/dX7vt//0v//dmX+97bPfvc//17r/1P/f/s 3n7+3tz+/r/f/3/f/X3nvdz9/7787Xf//L7/7v/29/f3/u/rv3Pf3//0/9NX/e/3bH///+7//9vp +3bzAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAESAAAA8AAAANIAAADa AAAAzAAAALEAAAC3AAAAvAAAALZKIZCBEEJAAwBInAgARQAEpoUJhyqDBAiSAACBgCEAAKgMxGAI A6gSgABAoAEAAgghEgNClSMErIEhBAAiCMIEisAgYQFIIAAApSwgCKAAAAgBAAQAoAQAEABQAEgE IEhACEBISNjASBUmAECiKJFEQgGFABAlkBGEpIAAqCSAQBQoYAAkQgQCEAQF4EQQAAEEgQBAgAAA KgEgAUEIgAEgAkBMJACChIgAkEQIQAQAAIBSkSAACQGgSBokAShEAoABmIoAgCigAZCGgggACBGA wQAZEAiYAhAAEEkgUABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAWc 5QAFKz4ABNUrAAT3oQAEyXUABEOeAARGCQAE110ABRDkAiiASABBgQgAYkRFCggggQgEAAAAAQCA gEjiiEhiAkAB6QAgCBpAAAkAIQACKYIAhCEICMQpAARAARQKAsYEAAAKABACACaAQgBCAgABCQBK DKBEgVAQWCiEgwDETCQApACAIBBAAEUQCgIIgAIQABAQwYBAiAIQGQIDgQhAAIIIAQAAAQEAAACg AAhECAIAgEgAAgkMAIBAMEAnAEAAAABBhgAIQDAABUFAAAhABAAJQQUCAEACBAAEwcBCmAGIACIg AEwIAgAOBMAAAIEBCICIIQQAiggCAACACIQEKQQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAACw1UAAsQ7AALCGAAC7xMAArh6AAKi1wACkRoAAnATAAJpmxNrAAIwAkwYAoCg AsQBCAiYAoihkKgBAEAlIAJpAQEBkAAgAZjAEACAxoCAIQAAEBuIAAQYKiSSiwACAICAAQCIEYwy gQACQAREAAAkCwwICgAAAIEEogGizAYAAigEICGAAAAoBEEAAIQgAAIABADGAAAAAgIEBIQBiAAF BgAgAQACVDCAwEABogAggigITAEgqAAiAAAAQkgJAIBQAIAIhAAAQgUBCCaEAABJAgAAgQIAA6gI EAFgAQiAxkBITcAFSFWOCACASEQAEgLAAAAAIAAAIQIgRhAqAFhKKBkCAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFKAAABLgAAAP4AAAEPAAABAAAAAO4AAADuAAAA9AAA APMUAAQJAAEEgkQAACCABAAADEUgoAUpYIJAACCkIQAoAQwgAAAKgSQECCQIgECECAIIEAAAAScC IgRBgURAoAAgiEgJQCEgICEIZQAACAkiAIBKBAIAkAIAAAAERAUCAoAjyEDCVAEIAESghFKAgYAm CAhCAEUAAMaARQAAgKISAEGBBBACggCFhQAhwhAIAUghEAQAQwUAIAUgAAgABEgIWCBkEAQAEACC IAFIaIAAUMIwgIACoICAACEBIIkAAMJgJAMEBAEAAIoIJoCEKUAEYAAAAFsAggJAOACMTkAQQgAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAUCEIEhAAKDiIEwBQAACAIiIACCk EABQgCIAgEAAAAAAJSCWAGQAggCCBJgQJQhAIEAAAHwEQhFFYAQAIkAAQEAUABBGAAAAAgQAICaB QhSIhAAAJ0AEdBBYIIAAJQlJAJAABQgGRCwyCAEEAgASIkIAANQEACIBAACAAWgCVAJEAAAAJIEA SChQACAYAQCgRIAAIIUAiAAFBgAEAAQAAAoEAQBkIAAkZEBBSYgJACCAABQAIjwAAhCIApAAAgEE IAQAYEEhMAsEBAAIoIACAJBAAIwWEAAIlxIAgEBRIgRMIIhIABgAAhIkgKYhAgAAkEUCADIAYjok lCAo1DgCBAFiiBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAECCiIMgIgIA AAFEGIQJhEADAKAE0BVERISMSCgACUDEgAAARMABCgWggqhQQwCBAEKkgQDAREgMIoSCAHCAJgQA CQAQiQAGAKJAgBJkAoABDIAESCQGACIDBAAAUACgEZBSAEBggQAgFAggAAAgEBJBQAAAAQAIAQQi QAAAIEQABARAAmAFgCT+3////f3/3v7dv792///2f/b//////9////f9/3td/9dX/9/2/+3f/rf/ 77///fvi+//9+v//+7P9//9r/f/f3n//39W//////X///f9+/+7//fb37e//39///9/v//f/e/+/ p9/+/7/8///+2v/39//9/37/v//+///7AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAABq5v/d733+z+395//99+v9v3//7/u5/+//59/7l//9/7/+3v7d7+t/5f//97re7+/N399/ rff/d//ub//399/33vz1+5vX3f5fv//+/v3/7+f2/+/9///v6t////v+///63f//3/379v//7e// /vf+n0/3/u/33//+/e/2zf//993n9/0r//7X3/3/3/673/+b3f//z/b9d8vv9v/n32/vX35/993u 39mfH9/X0/79/bvL//++93vbyzf/L9v2/9/+/9//f///37/97tv37//7fT3f9//fvv/b/9r93v// /9zv///+7/+V91f/X6793v/9V///V//3t/ff/PylXf3fbv7fbwAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA ///+NP///9YAAAFvAAAC9QAABI8AAAYuAAAG4QAAB2YAAAdm////1gAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAP/////////W////////////////////OP/////////E////1gAAAAEAAAnE AAAAAAAE4E4AAyQQAAx5TAAAAAAADQGsAAMcygAAAAAAAtcaAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAD/AAAAAQAAAP8AAAD/AAAA/wAAAAEAAAD/AAAAAQAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC 9QAAAAAAAAAJAAAAAAAAAAEAAAAAAAAAAQAAAAEAAA///////wAAD/8AAA//AAAAAQAAAAAAAAAR AAAAGQAAAAwAAAAQAAAFpQAAAAAAAAAAj0BBAAAuAggBKgAAiMIEAAAIAAAAjQBAQCIIAAFJAAAA QAwCQAgAQAQAAAIAAQAAQAIBAAGEiAACgFEAIEQAgAJCAAACIQAECUAAAEVSIACAAAoCAFgAAQYQ MQIBBgAAY4kBgBAAQAACwQEAAhYAAIwoCAAAhIRCG8gCEOSYQIAICIwCAQhAEEAkABAAAEAASAQA SEAoQAjI2IBIFSYAAKIokQRCAQQAECWAAYSkAACoJIBAFChgACRCBAIQBAVgRBAAAQSBAECAAAAq ASABQAiAACACQEgAAIIAiADQRAgACcAABKMABIBBAAAARAQECIAAAJAEIAACCgKgAQoAAAAAJQAA AAAAQSGMiAxJACGGyAgBgAxIAAQlAoAAQAQAAAAAAPnZ67///v3f3Ov//9+f+////779Xnr/3+7/ /74AAAAMB18kGwb7BvvO//1vAAD6+QAABCUENgRCBDoEPfu/f6sEL3/CAJyABgPoAAD//wAAAfQE LwRuBBsAAAAeBAYELQQtAAAAAgAAAIAAAAAA5dd+7/3/u//j/v2r9Xfv93//7Nf7/2/bfX//7d// /f/r//1e//9r2f+//90DEwNCA0IbAwAAAAEAAQAAAAAAAQAAbC4AAAAAAAEAAAABAAAAAAAAAPuA Xu8A6wABb6t/AAABAAAAr6+vrwAA+wAAbgBhAAAAAAEAAJABT05WAQUFCQAJFACwAAYiIgoLAAGN XAAAAAAAAABuBAAAAAAAAAAAAAAAAAAAb1AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFgA AAAAAAAAACTxAAAm7gAAJi8AAAAAAAAAAAAAAAAAAAAAsACxALIAswACOgEAAXwAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAQAAAAAAAAAAAAEAAAAAAAAAAAABAAIlAWQAAAAAAAAA AAAAAAAAACUIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFByaW50SU0AMDEwMAAAAAQAAQAWABYAAgEA AAABAAEAAAABAQAAAAAAAgABAAIAAAAEUjk4AAACAAcAAAAEMDEwMAAAAAAACAEDAAMAAAABAAYA AAESAAMAAAABAAEAAAEaAAUAAAABAAA5FAEbAAUAAAABAAA5HAEoAAMAAAABAAIAAAIBAAQAAAAB AAA5JAICAAQAAAABAAAMjQITAAMAAAABAAEAAAAAAAAAAABIAAAAAQAAAEgAAAAB/9j/2wCEABAK ChAYKDI8DAwOEho6PDYODBAYKDhEOA4QFhwyVlA+//////////////////////////////////// //////8BEBIYLmJiYmISFBpCYmJiYhgaOGJiYmJiLkJiYmJiYmL///////////////////////// ///////////////////EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCxAAAgEDAwIEAwUF BAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0 NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKj pKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6AQAD AQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEH YXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZX WFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLD xMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIAHgAoAMBIQACEQEDEQH/2gAM AwEAAhEDEQA/ALHhCOF4mE6RkbgSzfwh4jWPG07MVRWkPUAD76HvUxFPzI49OXszDvj0q1a2IUgt tbB3qemBVkmqZo/Rv0qtPIp+7+VO4GdqClxwpHpWO1qw/hb8qljQuwjsaglHtSGMoQ4pAOYg9RTQ BQMkFKGoASXkVXoAUj6UsUWT/OgDqvC91MMCDOGKiT2Ck1Z0WREusPgEM0MLeo3dKICqep1mpaDB NyoEcn98fxmufu9JmhP71OOiuOjVaE0VvLYdcEelQyQsPUelAFaVCO+aqyCkBGVpjCkMjYe1RlPa gCMoPSk2D0FIYuz2pTEf7poAaU9jTTCO4FADorN3OIYWc+iipDplwv3reVOxO00AT2d80Sgxls52 8Y6c1r2d9IZwCkJyQcygHHmAUQFNnowqtcRs55V9vdOMOTVIH5GadGZif9HMa/wNkHc1Z91p+w/v YnT096P6QjPureMdM1mvGueGNDGOWzJ6E017Fh3pAQG1Y9Fz/SkNg392kMgntmH8JqNID3wKALEd nnoQT2A7025hEf3txPUgDoGFDY0iO1jEm7AxhTKAD/dAqjDKznAbsX/3dqk0CZs6K1wsZNuqnP8A rCSOFXNYjaldZ4uZjnnk/exVMlFy2OIzvDjBG4A4IJIq9p32eN1KvIG4kww6c1MBzXmepQtkDPpn 8xTqoEZepazFGQId88mSWhjPUBTUSadLdYa/uF2fehghPC1Xr8henzOZ8X3KINsCCOQNtcgH5o8G uVju5s8StntUMZ6lpFjAYlMloCxwrk9z61ZXSrZlGbeMnr9TTAyZ7OIAFbPy/wCFiQcKciqclgoO POt24wTg8lGoGjJ8V2rW8aH90HYkhkzzGFFc1aTyyOoMoXJEe7H3dxpMDpxqF1YKVvbSOSPpFfQD rxXM/ayc4Kgfe2L03ECofkV6lvw6CS2WxlGfgDkbwKg0QKXHy84OT6AgirJOsCKE4RRhc8d2IrhY HOegOMun+8eKbJRrxhXRivcb2H+0opkbP8hKEDGxW/vhWqY/8Ecv+AenrqkcUamfdzhIEXrMSoqJ YL65/wCPljaRf88U+84q15k+nzKOuywWuxbXbEci5lIOC0anFXfDEw8vazKXUkSgHru5pjRkfEeL CIylQc+Uw9QRXDWMmHUpGS2QyKP42B6VDGd7a+LjI23+zRFJ93ypZiCW9K0Gu70f8wVfoJ6Yxi3N 520FD6fvhWZq900ZDXGmWsBB84ZnG52yKAOU8R6nLMFDtKUGWg3D+BsVB4RUG5j3LuG7OPcCkB6l c6bBIMSpuXoU9Qa5rVvAUB+bSSkD9fIflZaSQ2Ztlp1m7bNUtHsrj7sajG24FaaeEoIs/ZcK/wB0 HnkZph6iXFncFD5cUbkjgq3HIrkZvDuoIOLQ/wB5iCOopslI19P8N30AJvLX9z/y8RhhkwnrXaWP h7TAoMVtHIv34WbnhqVv8h/8OU9IIurhmjAFvF/olio6NN3NdJVCRUutJtJTm4tY5D0LEdsVYht4 0/1UaIO+B1pDOO+JsxCxgHg7nI91C1xukH96n+8v/oYpMR6brNlYSrnUViUdBOTgx1zltqd3A2NH nm1KAfeR1P7kDtQykSWmtz3bFbnUhp/Ow2yAhnresfDunx8pbiZ+rSy/MWaheYPyON+JMu6ZcHgI OPQl3rK8If8AHzH9SfyQ0Enp5uKYbj3plGX4hsxcRkJ/rB++tWHVZVpNE1gXESs33/8AV3A9JV60 CLTSL2P4VBLIndh+NAzX8xSPn24+6wPcGuOg1C+tTLFaB5EwRprMygWyOx5pkl/w9q0lvCqw6aQf +Wm5gPPlY10cdzqBHzWdkh6nMrcH8qAHY1A/8tLFP+AsaPJvz96+tR7rEf8AGgDhPiG0okUTXLTf L5gJAGzc5rmbIZdcStHkhRIP+WZLdaTA9D/4RizP/H7Ld3b95JZG4rC1i+so2McNrOCMRCVpXwhx QxlO5NqF/d2u/wDhkcyNmKrFsLxAG0++u7yHo1v5jBoQO1ShmJr955zkg3OOE2zHJQqORR4a3+en ly+WeSr4zt/dmmJncGS97XtsfrEef1qJrm/H8Vm//fQqgK11qt6uP9Htf90Of3orEs9blt5HIs5A jHzPJB/1ctTcZpReLI2OJLW4j7MxA+UVpR3kb/6qRWHQ47VQjnJvF3mJi4h3Hna/91iKq6frYtyD EBLMf9dLMOIkobISLf8Awl5VyUt1lb/liznhW9a7/wALX73ECtOwLnIfHs5pIo1f8ikwR3oA8v8A HtwXuG5yAFiX2G0GsfTlBYZUk5GPpSYHoUOpFh8yc9zXC+JZP37/AIEfii02BmCZh0dsdcetaWg6 hKsgw5CnIkUfxAKakZN4nmVipQDPKyN/exiqOjXWyRSAMjr7hgaAO0hvg38VPadT0NWBgeJb+SMj yiMdSD3Oaxf7WZv9cinsGH8NSwFfU5F/1U27scjtVjQLtzIcscYJf35FCBmUaTFBJNBA7H5Fyegr 1TwrG0MKqxGRlmPqWOapAa/2g98UnmP2U/jTA5PxV4cjmYscq54cg9cCsOx0SSNvkkGexxSYzRle aP7xB7kiuX1ty7k5zn731AoYGcTVzR3AkG8AjkEH3U1IGjqMMUg4JX+JQO1Z9vZ7WGHB7D8aGM2o 1kX+L/61WEmbuxpgQahaLMPnY56o3oTWBcaZKnTDD1oYFcxMOoxU9nM8ZyhGeh+lIRoP4fkHRlxT F0vB5OT3p2EdLoWjwrzJHz2JrrbeZFGFQfSrSEWPNH8OBTHuMdWJ78UDKF5KGHIHtWTIAOgApMDO vZifSsK+tww9O4NJjMp7cjqaktI/m45qALjcUQkZ5oY0a6yoRxUMko7E1Qxvnn1zSPIrfeFAirNC D2Bqs9sO3FSxnXRxZ6jPvU8OkxdcDPrWpmX4bTHQn2FTs7r/AAtj1pgC6gQOR+PrTTenumewNAFW a6XuWHtVO4lB6OPoKQ0Ztwo7k1QnqGMoSr7UyJcHjipGSPzTFOO9AFuGXPUn2p5YelMZGzU0SUAB kppI70COsgYd/wAavQt/cH1rUgtx8dR706SQHpQBGuO4H409pI1HzY9sUAZt5Ip+6o+tZsxHpSYI pzN71SlNQyis8dMC49aQxrN7VGTSAejkdxUokNAwLexppb2pgNLmkyaAOuiPtV2FmP8AFj3rUyLS SEdTSNMB/TFADjOx/wDrdxUEh9xQBSmcdiP8az53HehjRUleqzkVmyyN2FQuwpAQv7UykAA08NQA 7fSbqYCbqA1IZ1aM3Y1Ol3jqAK2MiYXy45Yeh/Gnrdqejfh60wEF2v8ACR78012z/EfpmgCjcSe+ KoyyVLKRVlkqs8npUMZEWphzSGMJppNIBM0BqAHA0uaAEz70BqAOmSf0OPWn+cT0x6GtjMFUn7zD /Cphbj+KXHt7UDDCr911PoahknI6OKAKrz+4qvJLnuKljK5Oe9RMBUjIy1NZqQyNjTCaQDc0oNAD gaXNABmk3UAf/9kAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAA/9sAhAAEAwIEBgsOEQMDBAUHEBEPBAMEBgsQExAEBAYIDhgWEQUGChATHx0WBgoPEhcdIBoO EhYYHSIiHBQaGxwgHB0cAQQFBg0cHBwcBQYHEhwcHBwGBxAcHBwcHA0SHBwcHBwcHBwcHBwcHBwc HBwcHBwcHBwcHBwcHBwcHBwcHBwcHBz/xAGiAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgsQ AAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYX GBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqS k5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz 9PX29/j5+gEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEQACAQIEBAMEBwUEBAABAncAAQID EQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RF RkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqy s7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/wAARCAaoCOADASEA AhEBAxEB/9oADAMBAAIRAxEAPwD5V0Ajdz6ZP19vrXSWsTK3zkY7L6HNeTUPTiX5ovmOPrn1P/16 wvEVuTE3QgYOD65/pUw9SJLzOj8LSO9um/02tnvye1e5/s0+CLGbWoWvrSGQCOWWKNx96cR/xL/s iunD779zoivyuvuPSPih+xjFrWsO3hYW0SCFZtTtiMCG9Yn7smesi7eMceoFeC+IP2btZsJGE1o0 ZB2sFHYH+Jcf1r0as7Wv6sxw1JNavXWfyKVl4Q1qE/NaSOOx9vbj1roPtUsBAuFaNsbijdxn+laa W91mWJw7X5Gvbzhh1z2P1PpU3kA9Dk9j6D2qDz35ejITp57xn/eqJ7TH8OR1I96fzIsVnhPPP0xU LRHsSP4gR3FW/Qn5+o63Ru7D3H+H1qyUx0yO/wBKG/8AJhb/ADIHXHQD0J+tEZ6ZbPt7Cmv+AgRP 5eRx9QPWqkloy87fb8TQgY4SOvTjsuO/1qaOQkjI+pPbFV6+orFozZHyMPr602WFWHzfQk9xS+QM yr3TgPukD29a4rxBZOFPH/AvUD0+tD9SEjzW7iIY447YqLYew/8AriokjRf8ATyCexHoP/r0gUjr 06A+oqRkoUdgcelaNnI44LnHUD0FFwS7+hcVjnnOOvPrWjZbf4QPQZ/w96uwr9zcgIxyPbHv9azt Qt1I5+v0NFwTMv8AtQxn5iD3z7+1aFvrCN95seh9T71m0Wn2JZLkMPQdNw9fasm6UH1z0z6/jUMa GrGD1x6H/PvVdrNR1yfQHsf/AK1SUkI0XPP0B9V9qsW11n7z4HQLWkWZy8jat7JJBwR6HPcj2p83 hfj5Y9x6kDsCe30rpj5kIxL7wyecRn0A9PrWDJYunUNj+6B1P0qHHsO5EY9vUEHow9DShPcn1+pq Lf5Md/8AMsRJ9T6fStTTLYFhg8dx/ezVRYHv3hCzIjHGccEjtkd66dbdvqOuPQ10IiS8/Usi09yP X3qbaAOQR9PWqRHr6CMhHQ57g+tVihbqD6gemPShAQm2HGT7Ee9ONkP7vsQO1IE+4wQBeg/+v+FT AZ6An+gqrBfyCQD/ABp0K56qB7+v1+tShE32bPQD0P1oa0XuvsR9Kd+xXq/Uh+yqT90+31HrUv8A Zit1/wD1ij1H8yF9FB7H1B9fxqs2jlf6fSkNf8ARtJHdvp9aa9iv8Qye31pehK8xrWoA4GT6moHt Rzg+wA/z3p/IJIhS0B+6T6g+v/66kazz2HqR6mmxWKslqPp3qpJb4PK+x+tIohe3z90++PYCmiLH r7t/9epXmhgYM9Cw9xRDFnuR6fWmhXHSW7npn3xUKxsOh+p9qTGl39R+xl7ZPVQe61IJyByD6Y96 a/4AkvPzGrKw6Mfp7mh3YdSfTB/z2p38hJf8Apy3Q/hX6+9V5JgeoI9WFR8yr+RRuMN0GPQ+p/8A r1h31gD/AA5Hc+h9zUSRS/4Bz1/YoP4D7H2rGnsOOFPrn+7isGap/wDBM6aybv8A7wP0qo8H+yfQ +9QOxF9jB68f3age3x3Oe59KQvmQmL0GfWmGHHQn1OKX/DGjEXHdfamso9BS/wCGAXOeoPr+FIV9 cj1x3FL/AIYX/DibP7ufr608J/8AroCKHCL/AGgPQ+1AUep9Afen8h2/yY/yz/e9iB3+lOQgdvZR S+XqL+kSD/aUeoPtUgnI/wA9KpB8/UmExH16YPep1nJ64B6YP9aolDhKx/r9KDIT/LPoDSQ79vUU N6EgevqaUAdl+vsar1ZSXd+gZz0HuSOx/wDr0vJ9R2I9KGSl/KKSezD2Ht/9ekU47e4+v1qP+HD1 YK57ADvj1pQw9GP9B9KH5egWAgn+Een0NG7HbI64Paq9QaHbx6gnrx2oMrD+I/8A1qVw/wCHYgkz 147g+4qNpwOxPqT7+goGv+CU7yUkfqPpWVIuOmPQj/GoZaIfw9x7GlJz6Y6Z9frQJDAM9RxSDHfP +NDAlwOw/CoyfUfT3pgwyfQH/Cjcf8+tIF5egYHcfQ+1Jgd/oaBWE/H8KMDvQxeoFf8Aa/D2pV46 j6e9BdiUZ/8A1elJvH932NIkUsvZfYfT60FgOgHvQhjS/wD9ajzB3z9aYDTj/wCv7UhPuaA+YAel G32PpSEJjHakOe+PWqAAvr+HtSlR9PX3oY/UM+n0pM49/wClIXp6C7R6n1NKFHpQMAM+tbVoox8w z7etVYn+mXNg/hHPam+XjuPbHel/w5VhCo74H9TTGX0PsR7+9O4eo1xnoPY+9QtCf4T+HrS/pjv2 Imj9j6Ee5poXP3ycdDQvMA5zznHU05WA6kfT/Ck2IiuGOO5HT6E1nFD2H1HtT9A+Y1gOxpApH8z7 0hfMAM+vt9KCPX8DT/4YH/wRNw+nb8KCfT6/UUIa/wCHA5HT/I96Avrz7UAAGOgpufQe5PvU2Bi7 R9aMj0HoT/n0p/8ADAG30GaMe/v9KH6A/wDgCY9fw9xTselMCeInufw9DUof2/3vrSAkXPb8vSnB 1PX6Gq9fUr1HKD/UY9v8KcMev/66P+HM/Uk3D+mfWlJx0P1Hv9aSRXz8h2f7zHPQD1NCqT94EdgP Wm/+CDH7fXHoR6ioiw/un04osP1+Q5QPb29jTsew/CqEvQUAHqeeoNSEjvg/1+lJf8BABXPUfn60 oI/h6dM+oqkIftz14HtQWI659MnsP/r1LQJdgI9FHuKOO+SegPqPrSX/AABhvwe/v9aUk9/XANO3 cE+4MqY5Oe5x2waaAOwPvjtj1+tJIoUp3B9h9KYQe+fVh6f/AKqf/DCYZ9Pq3tQVHY475/vCmJ+Y eVjuT6D1FOEQ79egPtSF6+oFCP4R6Mf9o+9LuJ+7kH09adivkNKk9Dn1+tKV9ASejD0pWJT/AMga PPbHfikMbdhn6/w4o9QY1Yz/ABcjofqaR1P4dh/9ei/kVbzK0+f/AK1ZsrHPr/T/APVQTYhZvU// AF6jx9fxoAYR+NM3D0OfWpaGAIHaggH09RQ2Kw3B9KAP/rimAZx/Qf40Fh3+gxU27B/w4mB/nsKN g7D6k9qLABA/oKNn59MetP1AMHv9D9aCR6D3+tAf8OIF/wDr+5pd2On1z70eo1/wRCp9Pxpyof8A 63rS+YhwQf3eev0FSiP0P/AfakNDxH68dhSlB6f/AFqQxWHv7Uw+31/ChDQwj6+59RUbD2+tNg/Q YAD6/X/Cmlf/ANfpVEIAB6fj707aO4+vtS/4YY1jnpx/WmcHqTnrmn8hf8MIVz/P60oJHT8c/wBK VgEGPf296N3tTsKwoAHQ59vekwewo/4YYBT6fX2oCn0H09TQSh6L7fQVdgAPX8vSqAn2jt9aMeo/ /VSQGrojEN/KuvVRkZH1J7V5dVHpx8vQtSls/ex/Fx2rM1m3LRNt5GOh7tg9azXkKRoeBZWa3XBz jhf/AK31r2T4Q/28upW3/CN3UcFxv8rzX6CCbgiVfRlPv6124ePvfgdFON935M+9/D/g6OwDk3Ml zcSH7Rqd9J1uJfZR0CDoO1YHxA8CpOhktokaVRuukYf62BR2HqtddbX9Dio1LNcu3wfI5LwT4D0n Uc+ZaRccuwHf3X3rjP2h/wBm+38qO48Ps0Lxn7LqMQ6SQTEYJGP4CMe3uOnPh2+/kdmZT6f9vI8X uPBmp2ke+a3laLqZF6Ee3FZ1v4ogYfK2OxJ74PvXqKN17vzPAuacesxt0dPRl9fqPapPNU/dI9x6 Vjy9wIJI4z0+marzWg7r7U/mN+ZWMDKflH1qwpJHzL/n/wCtQSNlj9x7Go1jB7D6+oqhllIQOhH0 9c+/tUpRD1zjoT6GmK/+Yn2Je4A7j6ikOnKew9D7ihML9n5kclg6/wCrOB7dxVaS7cdQfQ+9Uv8A hhMoXs4bqxX6d65jVS2OX46fgfahohefqee39vg8fQfSqQX2Gen1FZs1QkiZ6gj29KjEfr07exqR kkdoSRzn2+lXY4HQ/Mh9T9KuIvV+heVweoHoAewqW2GT8p/E9j9KBM6KzjOPmO7uBVXUlx0B9CPW i3+YpeXyOblg39/qfcelKNLf+FmI+8o9azbNUXoo5h94HHTB7fUe1LLGCPmbnt/+us2/8yrBBH7f U+9Om08n7o98en40rf8AAKv2KcsBHVfqP8+lQquDx+frVxI/4c2NPlx1PPSuxsJVfG/afTj7p9vr XXA55E91pcZHzr9fr71zWo+GIeyD0BA/pVNEKRyuo6GYz8n0I9TWXtx9fX2rCSNYslVfc+n0rT05 9p4bnsPf604ouR9A+CHZoxke+R36116we3H9a3/4czkWUt8/eFPa19Bj096ohsje0fsPY1Alk3b6 YPrQhehG9owP3foR6UvlEe3r70mUvIYEz0B9f/1U5UH09KBMJACOR/8AWpsAHqR/hTSH6k6lv4QP cnsKkMfqD6/jQDXmNC88Ae+ewx2q3BGg7Z+vamFhzoP7oFVpIwc/KPY+lIixUZSOn4fWmPFnuAer D1osX8/IrtC3fkdc+3tTGXHRPwP9aBCFPUY9xURT1z6Aepo9CrFeaEd0x6/X/wCvVORd3UED+Z/+ vUi/4cgEY7rz0GPSpBAD1Bx3/wDrCnfuMPsoHcehFJFb+gI9PcUWKsTNakZ+Y+hPqPb61B9iI7Z9 fb6Uv+GBeoSWp/uj0+n4U0WZA+VR9ff60JibIvsnoCfQ+9MmgYdAaV+4W7GdNGw69Bwfce1QlGI4 BHfH940DZXmP19/asa7cDOefXPpUMafl5mFdsG7H1H0rKmAz0x6fSsWjVIozxKPfsw/un3qhLDn+ ePQViyio0ZH8/wD9dQSjP3B9c9qYl5kDwjuffHvURGOq49Pb61CZo13G+WB0/E/4U0j2/D0Bo/4Y lsFVh0P59qUID/Ue1IaXdg6j+H6Z9M0BAO/4nvij1H6Idgdx7geppwQD7w9sehp+hV/+CAx2A9AT /DUmz2/+vTIHIB6fge4pVQe3ufQUegW8h6qvb8M1Jg+gPqPQ0L/gkJf5DlOccEHuPen9c9B7Dt/+ uqHbsOD+h/8Ar0pYd8+pI9KLgwR8dCvpj1FKD6fjmlfyEn29UL5g/u4PTPqaCx9M9jRbuDHADt+f oacu4dG98j+lFykNZvY/4n3+lIc/xZ9PpQxr/gIUIR0H09hSEk9M+p//AF0CGgjv06fUGo5MepPr 70WHbsVJyP7px0A/xqhKgHXjv9aliv2Ic00g+tL1GNII6f5NKW9vp70wQoc+ppM+mPU/WgQADufp Rkjp+IpFIQj1x9aD9f8A69HoAgU+tGB9Pf1oH/w4u09xSDJ+nagQ8Nj/AB9RRu/+tSGhm71/Kgj/ AD60/QQmT7Uuf8aH/wAAEJvHf6ijI70CDA9f/wBdHmHv9KB3AZ/+vQV9/c/WgAyf8RRj6UxAB6Cl K/45oAQewH+0aduFIaYqA9q3rRsD+92HsPencaROG/w/P3pNv1/xqv8Ahg9fUGiz3A759aa8Y9v8 an/hxv19CPBHRvofWo3T1Ix0J96fyJSIyD/dGO5qJkB7D/69FxiBs9Scd/p9KMeij2J9KVu4rkc5 z1Htn/AVRdf8+poAYUA/rTcfX/69AgCjsD6k+9G0f4UhvyE5HT6H2PvR+PvTF6+iDI7/AJUc+/oR SYBkdvoT7UhIH9B60D/4YCD3/wD1UYA9PUZp2ATJ7ZoIA6H/AD7UAG3/AOtT1AHUDNNATBT2+pqQ Aev/ANekwJFGOtOA9R7Cm/8AgE/8OAY9wvtTiD6++KLf5opL/gAZj7+/0pwI7HND/wCCUh3Pr7VI XH8Xb7p98U0TbzFL/Q9801Aw649KBj2Vu2PTPt/9enZPfHox96PV+Ym+3oKUHZR9T607Gep47Y9a VwsOHvj8fSjA/hAP9M0f8OJocEH8WfalDH+ufeqv2GvMXjv16bvSkU+mfTHr/wDroF6eooA9h2bP r7UMT35Hr6Y9qV/8hgQOw9vr+PvQoA6fl6ZoYvUVmHoT2I/xpAD7fX1oKsMGf689x7UBMfeUZ6A+ g96YB5fqAD0x7f8A1qUbh39s+1JhbuOK/wC1749aFXHVQO34n/GhDXn6ilfqf6imkemfQ+x9qP8A hyW/8hCQOmfbPajafXGecDsDSQ0wCgjnr2pjKR1Oe4p/0gZTnfPX9KoSEdj9PpT5fMVyBiPT8fSo iPr9akLjc/8A1/c+1Iw9KL9gv3E2n29zQR649R7ikgsJtPbFIAf6fhSQWE3H+hBoK56j6Uw+YYPs D6elGM96BICvrx2FG0D+dAwwfpRwP6D0pAJg4pAh9B6A0NCHov8Ae+mKeIz2/KkUh6jHQU8KT2oH 6jwP/wBdCg/4UWF6B+I9z701hnpn1JpMoYyjsajfPr/9emiP+GGFD3x6jHrTcev4mmCDB9Bin8f0 oF/w5ExP/wBf2pMHsfwo9QuJn1pCv1NNMA249vf0NJtI6fWgAC/4fWl5HcH+lFwAk9vz9aM//Xov 39Cb9kSoD6D2q3Evt7U7jZZC8cD6H1oCE9PoR6GmHp6lvTJSG4J9M+gruYkLAZI9eewrzKp6MH29 C7cwYxsbGRhx9Kp3Nkzq3I6E7fUgHp+NYxXcQnw6ZjCQ2Mg4A9xnp9DXt3wt1t7W/tnGRiWNJD/e V5B/OvQwr975nVSe2h+hRpjxKwIcZBGxx6qwrpPGkeJ2+oNoWoFJWxEx3R4GAyP0/IV6r4k0GPUr WWPhg6FIuP8AlrjI49mA71yUutz1scrqL8uVnnXwp0zTtUsGh1m2SSSM/ZL2Nh80PHGM+lebfEX9 iSRSz+HMsn3ykYGRjP3k969WhO3xep5EF3PnLXvBuu6WxF3BOuOVbH8A/vE+pqjbeOZo/wDWsf8A a3e3rW1WHYzkjftfHsD43FVPXd6gj0rUTxJC/SRD3B9fz9K5LGbfcpX/AIjij+8SO5I/u1DpvjS0 m/1d0pPQD1BoXoC/4DNwOjfcx6nPcClwv9fpVIpMVV/uZ9T7Ypys2OMD39M1f/DCt2fkx6gH7p/O pcnt07il6fMT8hS4PXI/xqlcQZ6gf/XpkmLf2o7Z9R7j2rmdQU9lP0PYU0R/wxxmsQgfdGPXHqfa sMMfQeh9qlmqY5ifb6+tRiUDsPUH1NRYn1JUY+me49mq3FesfvAZ6fhTv2KsTpIc/dUdvqPerEaE deD2oXkBpQ3ci9c+ikdqtPc7x8ynPqewFN/8AVjn7q3ZDkY+ntRa62vRxx6eh+tZstGtHdQuOoz0 x/8AXqvcLj7oB7j2HvUtDT7kdvn+pPtVwTn+LJ+v+NTb/JGxSmAP3cD0PrmqbIo+8Ofp1qkR6ov2 F1gjcOO5HbNdVYzDjZ+Psa6oPsYSj2+RvE7h19wPXPpWXeWzHsD/AI1sZW/yOZ1SxLfwkeh/vfQ1 yk9q6nlcevsKxZpEag9evceufWtGyJB9PcdqiKLXme+fD2dGi+VgccKPVcH+Vd4gPYn3H+fStl/w 4plyFfVh7GpFI75+tV6GQ9VB7VF5QJ+6KbAJbI+3qcf4VX+x56KPfPek/wDgCRGbT+7+AppsSOi5 PUj2/wDrUkUMa2PcDHpUcMBxwp9PriquFvMmXceAMd/oKmVB2U/X1+tKwxzRA9Bz/SpUiHqPf3NM QO5PXHoahbGO+P5UCKUsQ781Ggz1HPYH1+tMZHIWzyx9FNIYx35Pr7//AF6QDTGvp+HvUbQDv9B7 0rdh/wDDlWe2z1yPU+9U5I2HQk+o9B7UmC8yuox2J7f5+lP8tz9O31pD9B+AB8w//X7UyFVz3HYZ 7/WnfsImPtn2z7en1oU4+/8AX/8AVTuMa4B+7gj/AAphGB1GOm33P+NAn/wQEY/qAajlUnGB7kn0 x2qbd/UpFK5tc9V49fSs54sfdyPSpGU5owei/ge9Ylw4H3+nfHp7UmvPyHbz9TEuZh2z6Y9R7/Ss 2Z1zyAew+tYPz9C0ZskinqB6n6/Wqc3uff6Y9ahrsUv+AVHIPp7GomVSOnsWqWiiuQO+3HQE9vp9 ajKe4+lHyC/l5DGix1+p9iaaQR1/4CKljsNCjufakHHQ/j6GmvNEscz+p+uO5pAoHT6EUrlL/gjh GPb0H1P+FAU/Xvmp/wCHGhQBngfX6f8A1qePdjnqMfWrTEPAHYH0PtTsY6L/ALx/z60vVg/L1AKP T8alVfp6EVdyUv8AMXHTcR6ZHqPan8/3friiw15inH/6uwprKe/4j0FSkT/wwh49+5HoaeFI/qfW n8ykKrk/eJPoacAx6DJ+99cUAKo/vfXHpT9h9Djpx6UXJYmxu2fX6gUrMe+ff8Pf2pDG4PoPb6Uu 71HsAO9Nf8OO5GQvoB3qOQn+6Qein1H/ANai435ehAeOoz/SqUkYz1B7Um+xRWKjtj/CmsT6Y7/W pJI9ppQvr+FNgv8Ahx6kCkI9eO9IdxpQDqTQSe340J9xW8w4FG0+5oAPpRn6elAwOex+tBPoPxoF 6ihj/F9B9KQ/X6UDTEx9TSZ+tJv/ACELj/Z9j9KTHoM9qbGwIP8AdoxjqRTD/hhAw7A/T1FBXHX/ APVQL0DGf6ilwexpB/w43J7/AJ07J9M0/wDhw9Qx6/T60UrAGfb8aXd/eA9//rUNeY0TRID/AJ6V tQgAcofRc9h9aLdgv5EmT2Gf8KUHH8iKv/hg+fqKVOfX1HvTSfQ4oXkAki4+6MnqKjeM+o9fqfep uDIjH6Ae49qj246KSOmfemIT7Pj7oHoAfT3o2HsPzpXHb/MSSM9vp9az3i9f/wBdK42RmM9+ew9h TNn/ANf3FNITX+YEHu34ehpMf40JAJj1/Klwe30PvUiG4PZT6UY9s9vpVALj2Hr9aNo7g/WhDEIP 19PYUjN70xBkn09vagf5+tSNChfb605F9R/+umH/AA5YQD/D608IfT8aEJIcTn19OKXH1+nvTuNi gHsKNvpkeo9aLl/MCffPpjvTlAH3fzo/4Ym3mBQ+uOxpykDsfQ+//wCumFvMl2n+LjuAPQ0LGfc9 8UkFvMcrHvn0DDtUi4xx17H1+tHyJDJ75/wp+T2Ye59KL+XkVf8A4IuPx/qB/jSbR2BHcn0NNvv6 A/P0HYGOpz3PofpQD6A+p/8ArUyX5gWHfNKB7k+mfWhDXmOA/H1Hr/8Aqowe/wBQPepH8wye31x6 Y9TQEJ7H0P8A9emmDXmOGPU+m33prr6KfX6igIsTIB/Qe1GCemP8c0hIAf8A6596UHP8hn1pP/gD TFwexPoT6mlCHvj1Gaq3cX9MXcf6g+tMPHTH19B9KaY2v+CIB/ePPp7fWkJyOMY6UybCkHv+ftUR X2P1pPyKZSmbHYehP/1qoufekyWQt/8Ar9qZsP8AepXGNJz/AE9/xphPp+f+fWj0C4mT3NH1OfT6 U7gBX0x6mkBqUH/DiY9Pr+XpRuHfj2NMBpPv/wDXpQPXP+NL/hhIVufT1Psab/8AqNAx2Cf6UgT0 xSsFhc+ufT8aBH6jHvTsMcq+oHufT/8AXUix5/h9/wAPekxIeFHengCkMXntn603B7Z9/wD9dFxs Me/HejcR39qAQx19AB61EQe49vwoX/DCY1lPv6r9KYQf8+tNA/IUDPUfT3pSR2z+PY0WFf8AyGMS ev4//WpuD36VQhGH4+nt+FKPakIOe36+tGfUfQUxibT3Hv8AhSEZ7/iKVhsXI78dhSA/T60APWT6 n/CrsA9PwFVYl/8AALYUUu32+tBSJ9PIDDf9K7y1QYGGJ9c+teZVR3w8/U1J0G0ZUZ6fUe9U54ge nHf6gD+tYR9Rvy9Sn8P5hulGAOd6gfwk/wCNeteF7gxzxHHIkjfn0WQd/au7DL3vuZvSex+j4bPT 6/nRXdI8motX62PGvjvoxURSwD5gTBIR6KCRz+Ndf8MPGYv7Vd75dQIpc9Swz2/yK4b6/ie3GN6f ozj7yY+HNYDbnWwu+Js/dt7wkDgjphufTmvZv8/Wu7/hj5+5yfi/4OaPrCEXtnEspztnA+8SP+Wg 96+OfjL+y5d6GpeG2LwZwJUHGCe/4V0QqdJP0CT7+qPBmjZfTH8OOw+lSxanMn+rkx3+uPWs2zJP y9C4viWVh++QN2I9RTEe0DZjh8p+pkFNr/gh6ep0Nl41RAN0hI6E1txeL7Z+siey+1P/AIYn/hy/ FrMJxskHpn29zVsagnYjHYe31oX/AAQb7EomX+Ej6/41IGH976D1peoX8yJlJ+65/vZqIyuB+9cN 6n+6apPuBn3ZXv0/gx6fSuY1CNTnGfw/w96tGZyWp2vX5f8AP/1qw/s69iR2+tQ0Vbt6CvbLj5VG OufeqDwe49c0i7+XqSRWx7P+fb/9dSJbOOw9fovsaLAn3L0CE/eH0q9EpPehvsNLualnbkcOMg8h v7tXprFCO47ZH8RoJv8A5HP6giLnv2x71zRBB4//AFj6Uil/wC/bTP8A3jjv7GtqJ1cfP9QaiRVi SG2H8PH071cFgCORkdD71m/+CWmU7vTwoHy+xPp+NZzoc9AfQ+oFAPz9QiYdl561t6bqxH3j9R7C uiBlLyOwsb0MOo9APXNWJNPJ6AeuK60jCxRm0QN/CP8AaHrXM6p4SznEYA7L6/jWc0VfucvJprJ2 wegHrUsMBH3cqff+tZWNf+HPYPhvqpHyhSOwX+8mP6GvVYsDqD9P/r1vYmaJ0nHYH3qcS/8A2XvQ QiRJwO3uPen+eCecD19hTEWBLGRzj0A9ajbb2wPf0osCfchdV/hA98+lMaMd1FKIEbFT7dvrUZCj rx60/wDhwuIsoHQ/nUhnX+lAn/wRouAfX0z7e9L9pHfgdAfencPUN4PUke/rTHYfwk/X0pX7epRB Mw7HPr7VEpQ9z6AGkIhmPofbI9PpSHI+906gepplJ/8ABGeYD2PoBTC4B6H2B7D60hkUkinoPfBq hI47Zz1P/wBamIgjA9OOo/z7VOyL2PuQOwpNf5iI2CH+MjufwpsSjsSewz6H2pIu5IzE9cY9fpTN mRz+J9qb8vUVvITzc/wnH3Sfag/Xjrj3FK4L1Gbwev0z6fhTmUH+I+in0pf8MBVuI/8Aa9iazZ4v YD1z2A9Kd/IopXCDuCPQ+nFc3fsex9gfSs5sP+HOfuZCPf396ybiUjufUe9YN9zVf8EoSy9ex/ka oyMfU+59D/8AXqGP0K0k/oD/AJ/xqEz+pPpj0qH/AMEd/MaW+ntmmmQHocep9TR6PzAaW9Tnv+Xr THb256E+1FxsTAHQfQUm7Hb3GfapT/zHYAR26/ypynHr/db3JoSGOyM8gH6+tOVT2JA/kf8A61UO 3n5hjH8We49/xp313eufSj5E/wDDEgYn0x1HuKVAD6/X3oBscqjuSf608D0/yRSBf8AcSO31NPJ4 4HPYep96pCv2F2nsAO/1phQe/qfekvIVu/zBUB6g+xNPCHs31HrT9R8v+Y8DH8IpQPr7EUr+QMeQ R3x/exSAg+voTQvIb8wYf3en8RPr7UbM9R+FMEIYx6H1+tIwPv7YoRNxMerH6ep+tQOo7mk0XYjY ADkj1z6f/rqpcKP4V+o9aViiowUfe+h+tRsv+A+lJoh/8AaRjv8Ah6GgDPT/APUaEL09B6qe31Ye tMLZ6/5+lIphz2+ppMDvR6ErzFwOxz/Q0bT3OOxHtTKt2EP0pNvr/wDqoEKo9T/9ejce3HbNH/Dj YA4+7/8AqpCT6n3xTEgwe/8Ak0Dnpj1qQsIB9f8AAUo/z9KYwH+99PcU0fT8KBWF2+n5elG33/8A rUDYgz2Y+uaXP09eaBLzE60oA9/Q+9MaXcM/l2+tABHpSYC5Pv7il47c+uaBk9u/POK1llz1J9gO 9NIExwJ/h/OgzZ649MetIVxyv6n6+1IZT24HT6mqTC3mNLn1z2OKM8cnPofah+gxGBH3SD3z6UgU Z6/7RUdvrQhf8OJujHWPPYD1+tJuOPu+4X2qbeZVxhz2Ge4Hp9KrPAD0Uj09/rTEQtGD1471E0WO gI/qKLg0NEQ9KQx/X6UXEkNMeP8APWlCenP9KBjTFjvn/GgIPf1x70MdhGjPv60mPTJ9zQiRMD6e opdg9/Y0BYaAOwNLs/xFJMLChPX/ACaVfrmhlFiMj1I9/QVJg+59Pemv+CJ+QvPYY7/lTsE+nr+F ILgDj6dz6mlLZ6k+4NVYLAGHZfpnsKUrj7o9xj1+tO4AEHq3qQexp2QOoye3sKV+3qT8xQ+ev1P1 /wDr08L9fr6GqTKQ8MO/4fWnA5HTHqR2/wD11I0v+AKMZ6c9x9P8KUE87hnnA9jQn2E12fmDSe/0 x7+tOZmPQn+7/u0wYm49hz/OnBj/AHT7/WquTf8AzF3Y6rnvg0o9gR/Fj1NSOw7d6YHr70gC+h9Q f8KP6Y/+GFxjpgn+lPWMjv70k+4hDz90Ae9Lg+nsfY0MbfYiC57D2PtUiqD94/h7Cga/4ca1uvb6 59KDGO5//XVNgl5ihR/Ev+yVP9acVJ6YxSYl5iMgHc/4imO+f4QO3+RTBeYqr/eA9QPWl59CPUil f/MaQYHp7fjUUoIHGfRgPT3oQv6RmXH09vp9aps1JktETD0/EntTCh7/AJ0WCw0n8vSkIz346EUr jG/gSO/tQPcD60enqICPXJ+lJj3o9Bibh6n2pdp7n3FFw/4YT6jI/kaP85oBhtA6DP8ASk2H0+pp X7hbsLtPYUZ9P1pi9BQCfT/61OAPcD1H0qbleo8L/gD6Cnhsdh9fakFh3Hr+FOA9vpQUkLz/APWp uT3z9PagQhOen4UZz1yPUCmCGMB/9f1qIr6n/wDVTFbt8xp9v8im4J9PX60AKqn0HrQzf7I9j60f MSGkY6kU3mnf/ITDb64pAP8AGhjADPb3ow307UXEG4+vtgd6Mg/4+lA15h8p649KAnp9T70CQ5E9 Mg1oW6e31q0BaVR6Z7Zpxj9M/X1pjQtqORx7/jXe6fK2OFJHY+30ryqp3RRqmclAWUA52MPXPrUE luSOOPUewrAteRk+DXCXMoQgZ+dT7bfSvVdJlO5cOVwyuW+jiu+l8S+RdF7WR+j+m3BeKMnuiyH6 sgq1XfPdnnVt36s4b4uaQJ7CQlR8hFzn/ZBxx+deVfAnxW8dw8cpbacyID2bB6fSvOqbr7j3suV4 yT9T1n4o/DltYs2FoHF0n+naO6Hn7Qg6KT/z1HFUPg98Wk1q123Uw+2w/wCgazCwwQ8fGWT3wQe2 c16C2/E+Ye56JXIfEuGxms5I9UiWRJB5QU/w47g/7NQ3/mOZ8AeN/hpLZOTZlZYs/Lj+BSTXBSgj qrDt9DVxl/kQ0NBI+4T6fU+5oDqfvZHrWgr9mPyMfL+XvQHI7L7f7J/+vSSHYljuZV+5K/psz2Pt V6HxJcpj96x7nPf/APVVJi9TUi8ZzjqSfXFX7fxw/wDGDnrg+lP1E129CwPG5PVce3pVd/GS/wAQ Prgdj9PaqIsU5fFDHo3uCewrKudWkPV/Zj9aq5PL5kCWEs3fPrnv+NVrjwuV6qQf4v8A9VJvsV8/ UzZLDb1Y+nHtWXd2e0/IP8+5qH6eRQQwOMc5/wAaviMY4HuaEx27iQsR95x7e1TrdFepI7Z9qBmz YTB/r0U+g9q15gAOf8//AKqXzJaOS1Utk8HHQfWshIA3VR7k9j7fWhruUi1bQgHhfY59DWpHEoHI x9PT6Vn6lyl5Etsi54AHr7/Wty3CD7/T+Gs5eRaIr6yyDjPqv0rmpYWHUD6DvQn/AJkoQIp7H6+g q3aYHQc9APT6VtAlnX6Y/A2sQf7o9BXQwyH1z3NdsTlkvMniWNuq59vXPvUdzp8Dj5owD0Bpi9Wc vrHg+LqiD14/z3rmodGJbhfwPc1nY2R7F4E8JiM5I5xjI7//AKhmvShaJ/Dj0A9qZc2PW1Xt9PrT msh2z/8AXpmQCz54X6n0NRy2RHr7D1+tIH/wCGWOQ/dJ9hTBJL3Of6H2phbsAkk9fY//AKqU3Dfx fTNIP+HEEvqB6imyHPUZ7Ee1UC9CJ4m/hI9xUiz4++g9NvoaQCNJ/s00Ek8H6e1NASY9cn0P+fSn Mc9CfUj1NSxWK0qY6An19qhAHb8Kf9MpPv6jZAfb3+vtTJUwO/uKXz8wa7MhDk/0BqNwT0P+famy V6ld2b6+57YqnIGPXIPTI9PrS9fUv5kPnY/kaZ9t9OOxPoKS/wCCD816DvtYx0OfbuKZDdn0I9j2 zS/4cLdyw9wD6euKi/tBSOAPfND/AOHC437SCOKUTEjgf/Xpob8xouD3IPc//W+tNeUep9aF5AV5 Lj2z7+hqrNID1IJ9uxqX5eoLzKdy4Gclj7VhXtn/ALJx3b1BqLf8Aq5z19YMOmD9P896xLm1cdcf /WrFmqXcy5opP4QPp/hVSSJj1zjo1R/THcqta/7Rx157/So2tQe2e4NTf/MEv8iN4m7r9APT3qPy 8fd4/oakLf5jfL/u5NM8sn1PfPoB/hQhvyFOOxHpn/GmLGfUg9M0A12HqP736U4Y759frQH/AAw5 VOOB/wAC9DTxH659yP6UXLQmFP16fU1ICR3x2x60CfkP2k9gR0Psf/r0uRx19T7U0IeAR0APoP8A 61SqRnnju3vTJfl6Dgue3196f5YPr9R2ouUhwiPbJ7U1YT7+vHpTT8iX5DzbhujH1BPvQYBjqPYf 4il6DX/AJPL9Np9vQU1Rn7vHfHvQvUbfkKYh6j3oWL0Yex9TSv2+QeojRD1HuaNp7H2I9afN3XqL 0HbAOnXv75/wqNkA/nu9PqKY7f5kcgHv7e9RNke3c/hU/wDDFJkeR2B9yfWq86Hv16lvahvyIT/y KThfc+gPtURf29x9KVv8h37DCf8APrSZ9D/+uheYiRCP4j749TTMevHvSSL+Qb/rj196Q+5P1oEh cj3+voaNp7j3B9aYhPqD7fSl2e59cUANyP7v/wCqlGB1/L1pDQY+poJPpS+YLyFz9aQD0Hv+FMPV jcj1/AUoUep/xoFYaPp9KXd6j/8AXQCFAx0FBTH1oQ/UMj29PrSfXFArh+lKPqPY+lDKE3ev5+tO B/z60xCbfTFAFAfMsW4HoPetJF9CR/h/9ahefoHoKGA6g04n0Ht9RUtdvmV8gCn29foKdtz0P/66 r0F/ww0kdif/AK9IJM9Oe2PY/wCFACD3J9VNIWPr9cUn/wAMOwPKe3HqvtTdx9T/ALNNf8OL1BiO xPoPY1E5z0//AF0ird2RbT7elM259++D6+1Amv8AMTAPp64+nrSbR/UH3pML/wCQ0gDsD7+n4Umw ds+5ov2En3GmP/61IyDt07n3oHb/ACEK+n1GfSmnPYZ759KpITEKnvQQe3T0oYCH6e34UY9P8mkI MGgLjv8AQ+hoAmjPrmpQfSnYYbSen1/CnA/3iR6UeoWDePf0wO9Lhu+D7+mKd+4enoOwPQk9/agB h3PoB6UDv2Fz9fr60udvU/Q+lP8A4YSXccApHU+lKCOwJ9T6n6Uk/wDIbXYA3rjPQg+n19qUPnpk dm96dxW7imTH3SP/AK31pyyD3FK3mFv8mOQH1PoPalMnrn6j1pgvNgJT2Y+n1zUikH1J6c0pBfzF 347D0B/+vS8+gPcfQUJg35Cl19PcexpDjuBnsfQ1SAAR6+5+op4bPfA659/akCGhvb2A9j/hS7vY +jA1VhJ+QoYd2OOn0FND+/0qC/6Q5nP09vUUm449uho/4cm3Z+Qu4n+E/X1FLn1z6/WhDFBz1+o+ lN2D14/mapf8Ad+6AL6/h9PpRn/An2oZIDA7n1/Go3Yf/X9qQL/gGdPF6Z9xVFl9Ppip9QIiD3Pt +VR5PcZ9PY+9MkaT6mjPvQOwgY+2OmfWjH0qQX/AGkDsfoKQ57ken4U/kHo/MTH+fSl2/Qj+dDFY TB9OOtOCgdvxoG15iADs3v8AWgN7k98elD9A+YvPr74pNo/+v70gt5hgDufQ+/0pyj2P/wBb3oK9 BwJ7A+h+tPH4n09vpSEiXnvn0/CjcKQ/+GAt6E/4GjJ70f8ADBfsIV/PsPSmlvT8RTCw1sf4fWoy aPVgRsfb6j0owD0J9frTEKD9fc+1Bx2oF6jSoPr9aZ06YPrTQMCPr6mk59B/jQJ/8AM+h9hQSR1p AKQO3NIR7Zpjfl8xRjuo9/rQBnv7j3FAJEsa57D6e1acKDHHH+NNCJ1jXt9SKVlJ6H2+lU2V6EVv uz1J9Aa77SpQR8p7ZIPcY/rXmVTup+ZrxMxT7p909Oaacd8+pFcyLv2MXQ5BHft8oCkEgemV7H6V 6lYREkbWA5DM391FP+Fd1PdX8rjp+p+iXhC4aSzty7biYo2Lf3v3Q/nWzXpVN36s4K+79Wc947tT JZTgD+An/vn/AAr5n+G+om31BcnGcxkHtg+v515tbdfM+gybaR9cq3p9a8H8daTc+FdRS90mItp8 uLTxNaJx5Urkcr/10HI6YI468ejTf+R8vWWvzsz3Gy1O3uUV7GZJYmAmt5V6PGw9a8k+OHiBrdfv hQFyme7sT/OspIlnyFrWuyyhvNlZxy0ZP8WT2HtXm95KrH5OP7wHeuShPubV49vQriRl69KXCnuO fvH1r0rnIkKnH09fWpwiHvt78djjv9apf8EsckZHTHpg9qkIU/wgnpn0qF5E3JVhGOCfU+4FSoB9 T0XPcVov+CP0J49v8afQn+lWBCh6r+X+NBL9PMDp8R6Rj2PtTJtNDdkHt60a9ykLBDPDzGit2YHt n/CpL2+lk/5dMdsp9O9O/wDkTy/5nPXNhcfxQsP9kD19frWbNZMeseD2zRfsXGIyOzdfvJirPkEd ifY9j/8AWo9SXFlCRHB+Ue9PgEj/AHx7k/8A1qQ1F/odJplgy9VPsPetm4gDDpj1+lIJL/IwLrS2 f7sbEdBmqI8PTKfmiA+n9RUPzKj5ImGjsp+Zfw9qklTA+6B3+tS2P/EV4TzyfYGtmC4GOg9/xpP1 LFvL4qPlOex9xWHcSLnp+PoaSIuQ4B7Ajpz6VYiUg8qR6exraP8AwAb7eh0+kuw6kH39K6uyXd9/ Pua6oeRzSXb1NWLSl7D2z6AelQ3GmgfcJPcg9selNkevqynqGlFl4DE9V9wK5/S/DhlbLFuvAH8Q P+FS2aQ82exeG9MMa8rnjg+hrpEtPb8KZcicW47VL9mHr+FFyRogI6Hnrn0pxhz1GT0oC3+ZG1uB 1H/1qYbAfw4x3z2oERNYD+AZ/vH/AApG0rPQe9O4Df7NA6j3J/wprWJ7D3Ge1O4/6ZEbHHp6596V bE9wPrSQCyWXog9MjsKjW1A7c9SfSj0JB4QOh9zScdh78etDQEUv69P/ANdVcgHp/wDWqRoSRF/+ KPr9KhcY6DPcH1FMdyHYP4seg+lMYY6/T8KL9xMhkj9QP/r1VcHHzADtj1of/DDZVeIn1XvkdxTP sw78/wB76fWl6fIdu4Lajscf3T7VXAAPIOehNIq494/R/cj1qAouevuAaPUm/kPyO4wfX/61JHIR 0Jx2/Gj0D/hhC+Pvc/0HtUbzen0b6/SlYf8ATIWc+h+voKpsx7c9h9D702xNdiNpfVQR2+uKpXCZ 9M9FPt/9apfl6loxLm3B6HPc/wC6PSsa7tF5wB6jP9361g/UtP8AyMqazXtkdiPp7+9UJbYZ+XPH BB7E+tZ37l/P0K0luPTnoaryQ88D2BFK3+YyFoPqO2RURt89h6fU0vUTY0wJ7/T0pv2cAcY+npSs XfsRm3H07nHamm29Afak0Sv+AKIx2z/gKb5J9f8A69MbHBT2P/1zQB9R70DT/wAh6k9/r9Pp9ads B9T3PtikIdsA6N7Y9TTgD/Dj6016hYkB+mfX0p+4c5x6j3poQK3sP8akWU+gHpRYS8xyzHvz7+1A cDogP19DR8x/0x3nHsD/AHc+tO3j0GfX2oYhxb2HqD60bh2IB64o9CrCBQfvKpPqPQelKW9OR6eg oaJ/4YaSe4GOo9xSED+mP8KB+oKR2BI/i9jTdw7gUDQx3B9cdz71E49M/wC17UwYxhxwPxqGYH+v /wCupYIpSg9gB7e1Qbsep7D2pDX/AARhA7fj7Gkz6D2peoh6PnqB6ZpCf9n2GaVuzKv5Ddp70v1/ GmvMQY/+vSc9/pihi9ABP/1qUjH1/lQwQ0D1PvmgL6fWmmFhc46Z980m4+57Y9KXyGwz7fSjaPU+ xobCw3B7/SgIT7/4UEige/8A9Y0g56/n9KChdx/h496M+tACBAeuPpSlB2oH/wAOH1FIV9SR2pIk XYe2B3oHuPemNAGH/wBajPoPxpIH5E8AHqa048n+dWhPyHkjPU+oHrSAn+lKw1/w4hJ9vr/hTgR2 Ue7eopsBCynqCPUHvS5/D3HapfmMjLEdMjsPpQFPt6f/AKzTf/AENyR1P4+lBQnrg98+1NjXn8xC PXPv71GR7fQ/59aSBv8AyAoT/M57AVE3tz2B9aP6ZXoIQP6H3FJs9F+h9f8A9VT/AExSQ3I7ijGf u/j9KYxu3Pf6/Sm4z6ev4/Sl/wAMT/TG/jj2pNmOn059TTX/AABCDPY89D9KQxjtn3oYJhtz1/8A 10Y9enrQP19RMD3J6/hTlGf/AK9AN/5ksY9c56D6U/Zj7wOPbt+FMEKG+vv7U5VHoTQNC7T2J9sU AH+EEnq31o+Yh209hn+9QBj1Hp75p3H8kKWB6jnofahge/PZcdwKBegAD+I47j3P/wBenKGPU47E en4UWAUMf8M9/pTWJ9h60kOw4Antx/Wjee31x6/jTv3C47ee5I9CKFkJ7E9s0MQo9wB9advHpjsP pSv3EkO347Z/oKFkHoT/AHv/AK1NPsVYergdPw9h9abvH+16f5PtQT6McGHb5v7x9DSh/wDa+nvT X/AH8w8z/GlMme3uT6H3FDH6CHI70K47gfWmHqIHJ6NmlwfXj+tK/deRKX+YCX159aXcR/Fx1x70 k+/qV/wwCX8e5+lKX+n+FU2O3cToeST6e/8A+qjzPXPp9T70MlgST0/Ee9RsSOmPp/hS+Y7f5FWT n7ykj0qnJb56Z+ppNE3ICnr16fjUW3+9x9O9AhpQnvjsvsKQg+3sfYUmNCbfQ++fejdj09KLDQzc fQe1GfXH09RR8yF/wBNuPT/GjB9vcf8A1qGU1/kGMd8j274oAPbHufWk2SIR64pACelMt+T8x7D6 f4mlIH9cUvQGJtHoR/e9jS7vf2+tP/hxMep//XUit7exNT/w4Dx7Z9zShf8AZoL9RM/n0+opMkdP pS/4Ym3+Y1gc8ZoJ9AT6/WgEMYH0/wD11GwPeqQ0N4/HoKTI/wDrUxMcSR6/SmsT/wDW9BS/4YH5 eo3b7+1Jk+tUIOfUfX1FJg9/p+FShB9BikyfT8/SmAA/3cj29fxpST6imAEk9PxoAxS/4cGyeIDI /wA4rWhjJHHPc0xpEqxn0HqTSgE9APcmqt3Hb/IrxEg9P/1V3WiZZRu+nPpXnVWdtLz9Tfjj+Vgr be+B3I/vVAcgdBnrx6VyWNDBQlL5ODznn0GP6CvVrOMfwj2Uf59K647q4U3+p99fCa7Mul2hY5Pl hGPuhI/pXZV6tXd/eceI3ZT1e082GRduco0YHqWQ9q+OLG7a1vYyq4w+wn1Ysev4V51fdfce7kb+ L7z7LsbsSopAxkZA9BVfXPC9lqUMkWrQCWCRTb3Mf+y3dWHdTyK7IvsfP4mOr9bHjfwv8S3Phu7b TvFN+XQk3Xg28mPNzFJk7Qx9cHAA4wR0qz8fNKV/LMqMVKtHntuU9z7g1dT/AIJwqR8h+IGxkbcA ZCe4Pqa80uiQ3XC9j/hXn0zsq/8ABLPBX7v0PpVZLbH3XOevPeu2Mjzk+5PGuT8zD0xUv2c/XtW6 f+RuvXzH7iOv51IIvQgf3felcL+Q8Tnpn3+v41YQg9T7Aeg+laRE2WShP3WI/wAMd6kRgPTHf/61 TYL9yZGUdhj+R9qf5IPbI7Z7UW8/ILjlU/xEH6U9Ux0yP7x9TVWHcmUN3wf4QT2zTDaxt9+KI9zx 1/EVPoP5i/2LZt963QHvgdvarMXhHTH6xlD0z7VTX+Q79vmQTfC+1X/Vze5UDr9SKoP4DRDwhPZc enuKmPn8ht+fmydNLlT7sXH8OPQetS4P/LWFx3AI/nTfkZ28yFrmIfeiPHJAB6/hUU11CP4R6AY9 aza8y0jPu7jP3EHqD6CsWe4kP3l/3SO5qfUpx/zIELL/AAj6e9SnVnXt7H2pMGuz8hr6gX6t789j 7VE6sx5xVxj3RJKtmWPGAP4j61rWelZxkA9j7CtYLyIbR01jZIuMg+u4fxD/AOtW9bOgPzcjrj1+ ldETBy7GlDqsfcD0yPUeppZr5GHQZ7n2Ht7UP1Iv3+ZnXOtwqMO5H8Kn2+tR6Vqtor/fXPqe/wCH vUtdhx8j1XRLyJ1GHBHUH0z7fWtxYx24/rQbN+Y7yj/Dn1xTliPf8femDHhQfX/CnpGP4iPTHqKL iGtAP/1dqjZR6/h60hDFI/h/E1IY8jg07/5Dt/kRkHv+XtTMew9aYh3kD046/U1FsA/hB9PagEx7 xKeo+lNMCnpj0/Gj/hhtlaW1x1A/+tVYxgdOPf1ApMXqyN4x/Ccn+Ie1VJIeeeO/H9TRHzG/JDHX 3A7A+1RgDuPbP/1qd+w7EckGfunHfPrUbL6/gfSlYaZFJD/ewfUetU3jH+A9qPQSXcqzKw+6Djof aoftHqQPUetIfoR/agPRR2Ud/r9aiecZ4x659TQNjGmJ/h+pqJrnPUfj6H61LQJf5D0mY9OfY/4e 1Hmev04oFcJF9cemPWogT/GfxpgyCRz2yT0x6gVSeQnuBjqPel6ghCxPUge9VZwe5HsallL/AIcy 7qId+D/eFY04HcE9vwrNr/MuJn3EI/hJHqPrVGRB7fX3HrWT/wCCUvP5FOVR6DPUioHUHt/9cVFy /UhMfsRTDEp7EHoaBpkZth/CeP8APSmG2J+6Pf649qlhYaYc9Py9BUZjPb8qrQLkXlEenr9DSGLB 5A9MelIaQhXHRf8A69OWM98Y7e1K3/AFbsKCfX6+5/8Ar07GOn1H1oXmF+48YPUH/aI9aUpx8vPc +3/66dvMaX+Y4IO+R3P1p5jH8WT3B9KtvsIcFPpj6U4E9gfXJ9alB/wwq5/hJz1Pt9KGOOmf9n6U P/gAvMTHufcehpSD6n6e3/1qAFDsO2e4HtSF89eD/P6mkiH5Dt5P3fof/rUpmUdz7j3p3/4AxoJH 8X/1hSCQdv8A9dFxvz+QpY98+mKY7gdME9F+lDfkJ/8AAG+aD1Hvx3/ClL+wHpn1pW/yGmRkk9B+ HtUMqk9GI7N7U7Bbz8ircREeh9D7VVJJ6/8A66n1GQ7MdM+/1p2fQj8O9DBDkPp/k+1DKe7f/q9q kY0t7mgA96d/IGwyOx+nvS7R3/Ae9Kw0N2ev5nuaQD0zVMQu0+tJj0ye9IELn8fT2oAH+H0pAJk9 gP8AEUZPp7mmMQAf59aXb6fnQyRCT6Y9TQAPQ0h3AD/9XtQce/4UxXF2j/Ee9GfUfh6igYm0f1xR jP8AnoKBegu0fX29qQn/AANJjTF8v0/EUAHsB7UwsSxe3Hr71pqyjofb6igpL/MUv7n2NG9h3BPQ fQ00+5L8hFb1Ge2fSld/QcdM+h9z70xjHGOuQeuKQMfc9/wo/wCGEKZG7dOufQ03cD14/vA/0qEu xV/8hWweg9vqfembj647ZqrhbsKGY9ST2+opNwx8wwakVxu4DoMf7PsaTb6H/wCtVBEY2e5PqPp7 03a3pjvn1FQmJeo0Ad/oGo2AdyPem/8Agj/4YQqO4+ue9Nx6fkO9UNiMhHX6Gjyx26dc+1IVu4jK vof/AK9JtJ/z1ph6ICgPU4o2Dt+VIBAg989/b6U9EPcfQ+1HqH/DEiqPf8PanbgfUdznvTG15jgo PtSkn/4n3FNoBQoHU+xHvSeXjoTQw+Y8IPf6U8IO3H9KX/DADRAdc/X2FNK+xHYe9Fwt/wAAZgd6 UE/1z9KLEocHHYe+KUID1/Ef/Xp+pa/4IgT8PX60uR2B98dqViV/w4uc9Me3uPpShsdMeuR2PvR/ w5bf+QFAenJ6c0AEdCc96ZNu/qO3f/ZGlTJ6fh7il/SAU49frQOfX0przAXH5d/akC4/hAHbHqf8 aExW/wAh5BH+e1NJA6E+mD3pr/gA3/wB6uT2z3+gpm5uw/H2oQJ/8AeGJ7H0Psaap9/p70f8MO/+ QDPdeO7Dv9aM+mD/AEFJoS/4Aocf3R70hQfh3Hoaq/8AkF+48gfw/iaCfY/j6/Wgr5jN3ufw9/Wk Zz/EMnoT/hUpEpkRJHb3HtUMkYHc/wCFN/8AABFWSJewP/16hZB6UMV+xEx/D+tMOB0I/wA+1QwQ 0r6//qpo9x9SP600AhP90cfzFBP09Oe4pAJvpcj29T9KY7iDHb6UADvj1GaQhCopSPQ++Pemn3Qm wz6ZpSCf8KA+Y3P+NKGH+fWpGSqD7j096lHH+e9SND/r/wDroBH+e1P0KuIR/iaXgdfw9zR/w4l5 jSf8foKaxH/1vU0Ct/mMI9Pr9ajJ9c+31poY0H6+hPvRg9h9aYrihj7D29//AK9Nz649qYriZ/z/ AJ9aMj098e9ADce3uPak57Y/+tRYQoz/AI/X6Um7Pb/9VAw2n1PpilKDufr7/SgXzDjt+FLg/wCe 4oB+RYhjGe9bECH0HoaafkNMk2+x9vrTgg7YP+16Gmv+CN/8ApL15+ldvocgKDd16D6V59VHbTOn jjUg7vzHc+1VFHqCO5Hp9a44+Zr6vzOe1OTZcwFsA5wWPck/1r1mCZg3ygZ+/n0z/hXalsTT/U+5 PgTqBl0mDKbdu6AD/ZEhPP4GvR69Wrv+Jy4pav8AroGAeoz2I9RXxX4ztjbXbeYpQrJwo7fvD0rz cT09T18ker9D658I6gJraMg5+Ubj6mtuuuJ5eNXvP1PO/i/8HE122DWUTDUYc33h64jOG85R91ZO P9Z27Zwaw/BXjex8aae8WoTLHqkP+iazE4w1pfqCNxQ9nYEH3B71ozyKq/zR8l+MtAu7R5YtRtzF KrGN0bsFJ+6R2cf/AF68lvYmBO5cdlB7j2+lcaW9/U6nLRa9CWzYMDkE9wT2x6fWqV0MH5ZsHuB2 HvWh5631KtvrIBImAP8AzzcenvXQWDRsPvjHt2H0rsTNky9PaxH27OSOmPeojYsOYTvHXjuP/r0i 7/5FcE/xIPQH0/D2p6lh90f/AFyapeoywl9/ePP9KsrPuxtwOxPr9aGJ/wDAJjx98jHRcd6mV89e ex+lNE/0x6Ov9zHsPb/GpASe/uR6YptljkLDtx1yfapoo89Dx1OfQUL/AIImx4VW6k/7J9CPWpUf A+8D2/Gq9Sky5BfyL98qR3x3H1q+kkEv3lwevHaoa7ehBFLpqrjGCOoPv71XaNT94D0qi21+g2a1 DdY0P0HSoH0iI/fgU993oPYVLX+RTl2Iz4Zt26xDHXI7j/69RP4OtD0RwemD0P8AkVEkCfd+RUk+ HVsT+7dwPvdOuRVOX4axk/LOPcN3+lVbyDm8iD/hWUnVHVgPlyB3+tMb4b3w+4gI7/8A1vrSv3Hp 1GHwlqC9bNh7/wCRSfZ9Qj4W0YnuT3H1xWnN2+ZMoLuNXWr9fuWzD+8W7H2yKUeKL8dbdz7HPJFW p+ZPsvP0Fj8b3APMUn0A7+9WJPiPKB86H0Bx1H1qmzJ0n/mUbzxm0nWNtv3vofrWaNbbOW3g/wAO B9we31qX5AoPqdz4T+KUkBHnTvt6DP8ADiva9G8WRXC/u5BnufY/41SC3f0N1L0Ho2e230xUvmg9 CKXzBf8ABImu2Xpg/wBakW7B68ds+tUInLg9gDTWXPt2JpXAhzj+hp6AelO4xcA/yx6VEYwOo9h9 aAFWUDqPbFKVQ9sdzTFYa65/nikUeuPTAoQPzEkUdx7YqlJbgdh6ikgZWY47e2PQVDKCeg+vtRYd +5WKg9SM9B7iofLI9Pf3o9RhI6j+tQ7foR0A+vtQ2HoRzJ7H3z6iqcpweR+Xb60v6Q7FOZwehP8A iKp3EWfQjrj1peqGvIrFT3I9EHoaQgfxE/3cUv8Ahx/8MLxj5ef9qoShH3QT3IHYChebEv8AgiBj /Fj1AFPMpHYe49M0r9gt3+Qpfd049fr7VETjqP8APv8AWncditKT3HPb6VWkIGducdOe4ov2El5k TS+n0+p+lVZpAPuKPU+1Df8AkFihcAHo1Z0iZ+6B6kewrFvsWv8AgFGRF54w38OO4HvWdcR5+8CO 4+hrN/8AAKKMkI7H3PvioWiHcj1+lSW2RmL2H+yRTWjB65Hakwv2GtGOx4/rUZAGcfUE9qhl/wDD ERKe+euPU0xiO3+79DQn5EqQhAHUNnuPf3pDAD2z6fSgaGeQO4x6GlFqf6Eeoqri/wCHHrbj6ep9 DTvs4Hrj+EUrCHpAB0APYinLB9Pp61RaYvkgdh9DQYMdz7inYm5KIP7ucd6RoAPUnv7c9vpQkHzF aHJ4Jx2P+FI0Q7g+n4UC/wCGGmLH3frn+99aCPUDHbHenb/MH6+QzaD29gf8KTj0J9/f3qLFLy9R pbaeB7fT8KCD2wO4PqfeqIa7MQk+h/229abn2OOufakvTzG/P5CNNnqeKaSPT3x60n5/Iob5p9CP TFNM3rn3HvSv5Bb/ADF80dhg+nvUW8nrk9z7E0/X0B+vmRsQevPY+1VpIgOh/wDrVH/Djt3Idvof qfWmg+n5exot/mJ/8AE4Penv9frmgd+w3b9Pak/AfT2oFbv6iAj3+voKUgjv7/Q+9MP6YhyerH/G hV/+tSKS7hz/AFpSfQH/ABoFfuJg+n0o3A9yDSEhMjtn1HtQDn/E9qobAAen+fakA9//AK5pMAJ9 T9PrRk+ntQF/8hCw7j6Uu0etMQZx/PHpQW9B+J70fMYZz1//AFUbvQ/U0mJAR6fnQD6/gKAFJx1z SZPcfj6imNlmBD/9erSSfT/Zz2pD/wCGFD/7QpDLnv8A59qaF6Ax9xnr+H0pDMPf1PuR6UAIX9f/ ANVKZfQ//Wo+Y35oTdj19j6ikLjsOe/uPpQg/wCHELE9CR2BHpSiUepPpnvVf8OS2GRjnIPVfakL Adfqfce1Tcr0EIP+NIMfwf8A6qLgl2E2g9efX60jyntn0x6UW7juN47Y9AfekJPp/wDqpMm4pI7n 2yfWm4I7Y78f4Uf8ONgWz0HHv2oD/TH8qB3/AMxCD3wOw+tNI9vp7Ur/AOYSYgcfX3o2HsB65o/4 cS8hd2Ow9z60mT2pgSqwqRQO/P8ASgqw7bjoCe+PT8aUKP6j6U1Lv6Ejunb6+1Nyf4RVA13Hg+uT 2z6U4Adx+dQAE46/h9KTBPr9fb2pi9BNoP8ACD3BPelKjvj6HvTfqNAF9uOx9qbu9B7EehoY/kOA z2Hr9TSgn+H6Ee1O/YBAB9O/1FOCgfdye5NSgHBuOme4poYDrn3FUib+YuB7/wD1qdvI75HTp94V JX/DDQ3qSff0+tPGQO3+Jp/8MFh2SP4eepo3ge/p/s/Sk0DQHP8AESf4QPQUgXPTj+8T6+1MLd2O bd6cd/YmjaoHJPqcdj7UIlAFA7n3NIf/AK+fb2FFx+gm3HQ+zL6ZoVee3oM96YDiPXHtj0pQnofw pJB/TEII6c9s+goJ/wAn2pjG7T/Qj3pu7/J7fShCS/4AjEd+fUD/AD2qFwD29qT9RldvcA/XsagY +tIkhIqIoPb3HvRcEN/T1pMH3+lAJDSR6+30ppPrz7+tC8w9Bcf/AFvY0m4D1/8Ar0B6i5H8Jx7e gpMf/W96QBg/57GkwB1PPSqF6jiMf/X7Uik/4H2pFMXHqPp7inIh/rSAlx/9b3p+R6H/AApILDgf /r0oUUXGl39Q2D1/H1FIVPb6fhU+gMQgdx7MfX8KjP8A9cGj/h2A1nB6Z96jLDsPwq16Cv3G4PpQ qsen1wexosAH/P1prA/XsKZIAjv+FIAf89qBibT3HuB9KQMfenYm/wDmPx9fQ0mD24759qBhke/1 o+g+tIGKBjoPwpV/3T/9egLmhawH0B9fpWtGmOv5U15AvMl2+hH/ANek2juPcmrRbfczMeuff2rs tAYFfkz9fQ151T/hzrp+vmddaAE4zgdSfQYqqVXPQk9Meo+vtXEjRnN+KBsMTMGzuABx1Gf6V6np crFRuyOM89uP6V1x6a+QU/L1PuL9n4SDS085wx3Ng+g46/Q16hXr1Xr/AF2ObFbv5fkAr5H+NunN b30pZdoJFwjD+5KM8D2rzsVt+J6OTP3vke+/CTUvOso/mBwAmfp6V3ddMTmzJe8/vDNfP/xX0W58 MX8OoeHrUm3dhY+NbaIgblcffcd96jGOoPtnGsf+AePV/wCAyv8AtA/DC11W0W98NlJNq+fqbJ/y 96btOG+sB69eOPp8QX8pYksMDqoHYCuaUf8AIxpy6fNEOm3Az1Jqve2iqTtO7/a+laIiW5gS5B4x 9fQ/SrNvqksXKscdSB3rWK7jv3Xmadp4zaTiRQ3qh/hx6H2rds9XhIGJSmRhkJ6Y9RWrRpfsWnWF hxIAeo/2m/8Ariq28j74x3B9vapHEXyx/Xd6mhQ6/wAZ9cCq9UP/AIZFyC6Vv9Yo9QfWrQTHRj6j A6fjTYCo7ehz1P1qVWP8AOe/uKbEn5E0bgfeHtz2FTrGP4cexHfPpT9H5Mf/AA48cdUPorevH9aN rD7oGD/D6VVh/wDDk4bH3gvoCPT/AOtQkzg/KcdsjuPakO3+ZoRX4P3mH+yPpSvbKR1IbsR6VNv8 if8AhiBmkQ/oM9zUizjv+PPUmmNIkjuMdVz6/wCfapHkU9Px96n1C/caQO+fXI9PpQLVH/iK9ySO tJjuQNvTO5Mj+Er3XPerEVyO5yemPamx/MuRSFT6HqcdiKtCIH7wU+oI9fWoHYjk0mM9YI2HQ5H3 TTY9CsTjfYRN2II6n6//AF6dgbFl8GaTJ0syD3IPU+/FU5PhppzdYMHpuH9Af8ad/wDIfM/IpzfC DTycxkg9SxHQ+3/66qf8KUgP+rnTPXkc/j+FLX9Cr90V2+Djj7kqY6KQf6n0rU07wbr1rj7HcA9x HnhlHrj1q+by8xadTrdN8RaovF5bN7FB1X3Nbcfi5x99SO3I6/jWnN3MXD+VlhPFCHv+Hp+NPfxG SPlP+0B6/SnfzMnFmHP8TLiF8S6bcsveVRkfpXUWni6OQZII9j2psbh2ZM2uw9nH4d/rQutR9n+u e1MQ5NWU98Dt7Gl/tBPUZ6/UUB/w4v26M9G9wvoKDer2YfSgP+HFjvAeuD/WpBL/AHMH/E0XAHkH 07mopAD6emfX/wDXS9AKzRA+g9T6Z9KgeEHr9Me9F/8AIa/4JVktSPX2Hv7moZLQ9nOew9DQMja3 AHAz33H1qF19x6n6UeomRSA9mz257VUeLP3T9Qe9A7mfKB3B9j/n0qOSPA5HuP8Adpeo7lRh6de3 1qB8/wBwY9D3I9TQwv5eYsbN3Ax/CfekJIPJ/D1//XSt3KX/AARucdR+Pv7UyRyOpBJ5x6ihAxom 9yvsKje4z6E00Iha79B+Pv8AWoWmB7fh6VPyBEOV7DHfcP7w96rSEH271Mgv29ClOoHpjt7VRmUd seufapsaL/gGfJGewJ9z2qk8OOpHuPUVmyolV7U/3fbb6CoWtye3sF9R71AyIwnsPw9qieL0HH8Q 9DQEvJkTxeh+lNIH905qSkyBkA+4Off+7SGNT90GpBCeWB657n2oKE+vpn1//VQO/mHlHtj0we+f anD/AGgB9PT2+tMkURjt9SPWlKqf4SD0x70/QQ4R+xJ7Y9MUuQPvL+PpQhv/AIArgd198+9AXPX/ ACaa/wCAK/YkCDvmn+Xj+X1NU3/kICM+x6cd6Zt/vHHcD1pr/glCBQeowPX3/wDr0xofQZ9DSv2F ykZUdif/AK9IQOx+vuan1Q0R7M+memPc+hpSf8AaXoP0GZx97jt9aQoR1P0+lO3n5Bf/ACI2jPbH ufUU19w6HnofcUv+GGRqP9v32/8A16Qnn5hjsD/9eqYo/wDAGkDuPr9PakA9DgdOPWp9WD/4Awr6 Z9ye9MkjJ64+vvUj9fQhkjI9PTH+NRFM9PpQCf8AkhQuOv049aT/APXmhFXEI9s9/qKTcPU+uPb6 0gYE+vHofUUEAdj9PWmKwYI96QH2P1oEKTn+nsKMn8e30oAPx/8Arikz/h+NIAx9fQn3o3fjTC4p B7gfSmbR3H0PpSD19Rc+h/8A10E4/qfemAEev4U0nPr74o+QxcDt/k0uff8A/XSEhM+mfWk57g/T 2oAM+lLj+8aYBvPc+/1FLuP940gv/kSxynseP5fhVjcT1I9Sff6Uyv8Ahhd/4dj/ALVI0pPfjrj3 pXFfv8xUk9iO5HpSKx7/AEqkC/4IYz1/MelKJMdG56YPYUkh+oiv7jHp9aCT7f8A1qP+GC/+Qm89 voMetIGx/U+9N+XoFgLfl0x6j/61G4n1PuewFSAZPdfz9qMg9Pw9xRbsVYQK3cfjTTJ6j/6wqiL9 /UML2Jx6etJk9uOw9qVwDPqQf8aQse/1/GpACSPT60j+4+tMP+GFbI9R6D0/GmEnuT/hQhsXPpj/ AApMr6/h6mkOPmG0ep/wo2+/HTHqaYiRUHcY7g+oqRCPU+ufSlcb8iUN/dP4ntTxn+LPpTS/zExo b1x7e1OXI9D3U1XqN+YpPX8h+PrRx269fpj3NIm4vlg9cemaCR6nPehFMdtI6Y9MUgUY6k+oPp7U v+GD1EJPGMCmhsnuPf8Axpg/+ANV8dPwNKCV+9j0+tOwvkKG9fy9KA/49waVgbF3j+Ac9CPWjdjs abQC78/dzQG9+Ow+tIbAvn0/Dt/+unAe/wD9am/Um3n5DiP7pz/T8aTcOwz9fWgpv/IUKO/Hb6kU bh/EB6/XFMVv8h4Y9ifUj2H+FB5+79QR3z7Un5DX/ADefXPY0gAPXB7ECiwkhMY6Y9vY0gOevXua Lf5Al/wB4Yevv+H0pOD069QT3P1psfp6ChyOq57UgYds+i+xpf8ADE/0xpBA9frSbSeuBQK/b0GO B/CfYj+9UTN0yPY0/wDhi15+hWZie2B6VCwHv60hf0iFv/r5qMj0PvR6+ol5kZY+/wD9ekLH/H6U WBsAB26f1pu72BpW7ibAAdiQO3saCR3J+o7UB/w4n+ce1KFHYn1zRcYm71P0pMDvn60CHZ9PoPp/ 9alVT/TFIP8Ahx2w9h9alWP3+tD9SrDwo70uP/rCkl3C/YUse9BY446UrFegm89/wPtRg9vy9qCQ xn+R9qDEexphYjaL0+lMMXsfc1VykAiPf/P1pCh7cf1H/wBegn0GtH7fl60gjwOfyp27iHeSD/nr SCIduOx9zQAbMenoKQx56n8P8+lK4INnt9frQYz347UxAYl7j/8AVS+UB049KPmO3+QgiJ7flU0F pnqT9aP+HEjZtLEgcg/U+n0q4IQOufx7UehXr8hwUfxZ9qUL68emPX/61OIjIAyB09Pr/wDqrrPD a5B6DuMd8D0rz6j7HbTX/BOssXQEbtyg/KCPf1zTpIyp5P09ia5UzR+TOa8XI3lg5bhgQfQbu3+9 Xo+hTB40JLdAHHqTnoK3T2062Cn118z7L/Zm8SmezljP/LOQFCf4o5ox29ite3V7NRfo/wADmxK1 17JhXzX+0RpW24DEn5kUr9UJHP1ArgxOx15U/eXzR2H7PmsCS02iUtg+WB6AZ6/SvZK2gaZuve/E K434qaBBe6fMl2gZCAWB7EMOo9jWqPDmeQ/AP4iPau9h4knEyHc+gNKc+ZERym5v7y8gdu3FfOnx 9+Bz+G9QZYIHFjL/AKb4fnwMAMTlOO8H0APaol6f3jhT1/8AJGeR27hG5YnsfxqzqsaZ/dk464Hv Sj5ejCo9fwOclgOeceqn1HvUbtgEKAR1JPfFax8g9fQyS7Icoxz3PoK6DSNUaTAc89FPrXQ13Kgz oBFMn+rDH69hVkNIfvZ9/cUmdK/4JNHdf3sgdgewqxGwPT9e+aVuxN/Ifs9BgdR/+urEd9IPvYA7 j1HvSf8AwQv5eRYWYHo/4VKoPr7YHf61difUl+bvyOg+tPR3HQcdxVWKf/ALquD2z6Z7AetKuO2P Ug+vtS/4YleTJRbBs5QD0HqB/hSvaHjaT7+9F/IaXdjSpHQEdlB7Z96txXg/jXj0HYfWpHbzJ3hD j5OfY9s+v1pjWZH3UAPqf8fen8x/8MIbQj0HcgH/AD1qVVIHKj0A9KkPQesGPvDjtUpgz0HuPcUD uM8gN1Htg+lV2sCp/d7T6ke1Jrs/JDSJUkA9QepNTi7IOTISOhH09KGu4l53LseoL2PHp9alW6Ru 3t/kU35g2ToifwN9akC46HPp7iixbX+Q089M4/hHpSMT2J9GpXFfuKYmxxyO+O1TwTMOqnH9KAfk W1dh9w8dSD2pTdR90B9Pr/8AXot5ifl6DA0bfwKOxPtUi/ZweVA9B71TBeYr2kR+7+fvULIBwrGk F+4kkbL9yRvQH0P1pirKR8k3zdTnvT5yWhjT3C/x7vQZ+7UR1y4HXB9eegFWpEuIq+KHX+Bs+opf +EuI6qSeh+lPm8w5B58ZIOhPrj0FTR+Nx/fNO4pR7k48ZoTxMc96cfGS/wB8c84qiEh3/CTp3cZ7 t71GfFKD+LmkwFbxEh6sPTB9f/r0HWYz/F+FDB+Q37evr749v/rVFcToe49MjuKaGvMhE4x8vHfP v/8AXpsjr3wO9SNeZQmYZ4A9M/8A16qSTD6+p9zS+fmNIqs+Oh9j9DUckv8As89h6j3NDfZlEYkx 90D1IPenSux+4B9PSgV/IQRk84z2yfb2qvM57kfhTv8A5oVit557k+/vUTXQB4H19yf8KBLz9SIz gd89ufQ1GbjP8P8As5NJepZF9rI7j0+oqGSUH7uc9fxqX5BbsVnJPUD8KqTYHTp1Yj1qBr08ypOg ydyE+xqtJGD0XPpUNFt9iu8J7/Qgd6ruhPQe31Hv9KRRWaA+nuD7/wD16geM/wCIqL/5IbREyeo9 gP8AGmGMds++exqbh/w5G0ftnuPYCo/JH8Qz3+maSX+RSQm3HUj0b2ox/dJ9x7VTIuBAzyPoPQ/W jJ7gexqWXcQE9sD+lPyvbr/FjvQ2SKD7f/WpQ2f5c+lUkO/ccDjufUn0o2g/ToD6GnfsH/DEitn+ I+uPcU7Poc9yPSmvNEAPcj0GO1MYevXtQmVbzFMvrj6+hNRkD+L8R6UvkFxjKfT6D1HvTZF/+uT2 pMLkbqexx6GkY+w9fr9KQf8ADDd2ewPse+KY+fXHfj+lV8xWGZx3J9c/57U0j6eg+tKRX9Mj2/3h 9T7+1IVH+HtUDfoM3+59x70E4/nj0NP5CXmR7znqfb2phz/Hn1U+hp+nqUMLY7Z7fiaiOP7vvmoA bnHv3H0oJ9R+NUITB9T/AI0gPtSH6AW/vA//AFqTk9enahBcCh9T/wDWpc+o+tAxAw7fhmgMfQGg kMj1Hv7img+n40kD/wCALv8AajHv9KADJ74z2oJ9s/0pgxMeh/D2oB9fwpgJkd6APoO/FSwD6fWg H14/rTAMjuDj1pC3p+FIBaQD8PU+tNALk+g+lLk0wFVgP5AVMGPej+kFu7FHPUk+mf60pPrgUDX/ AA4vm47gDufWkEp9/T8aTC44OP4cD0po56Y9x60X7+oenoO3DuPpj/Cmk+nT1poLhv8A7p/+vQV/ H1+tK4fMXd64PYfSkJ+vrQMUjP3jnsKFJ/z2ouNeogYn/D0FKSPw6UNjXn6jd47D8KCD6f8A1qXq T6DNp/rmk3H1+lBI7B+vfPpSY9T9DQVYaT6E0ZHf6Y9aQMXjsBSbfXH0/wAKYWHADvn0x6fWlK+u faj1D5jwoPc//qp+0Dp+XoKTRVv8iQH2PqD7U9m+p7D2FX/wxLYoIx19/pSFR/ex/X/9dT6if/Dj i3Tbgnv7UoB9vTn/AAqn5jSGh2PoKeqg9eO2f8aB+o5k/uH6+1IUP8IHufX/APVQgkhrA/xAepAp mT2H4+3tQH/DDdv1Pqfejn0P49h9aPUF5egZ55B9h70u/wCh7fShEr/giEY7/iOwp24n1P8AdJ7f WhDsICT39h70pc9sHtn/ABpjv/mxQ2Ow+vpQWHf6ZFITBXz0P0I7inK2e/uB7UNdhjt47MfX6Gg5 98f0qgt2+Y5XA/z/ADFAJ9Pf6VLD0Ex7Ee/ofcU4N6L7H3piAjPp7A+1Nwew9sUr+fqMdnHUDHcU bifp29qPUH/wRvmnv07j0NDdOuB2Hr9aLCQmVHf2x/hS7QfvnHbj29qp+XoKwxx6cf4VC31P+FSP /hyFyOxJ96ruT3x9KQSZXdvT6Uwkdh9PbFMS/wCCMJb29aaW9/p7Un5AJjH09PU0uB9O5HpQwEB9 PyNJn3x6igXp6Dt3p+JpB7H3pDD64+npRu9sf1oC4DH9KcoH9KYLyJVX8/X2qVQfT2PvU3GhSvsP XPpSA46E+p+ooQ7C/j7/AIfWkB9OnpSACB64HQCnLj/PrQMlWLH8zUnlD29cetH/AAwf8MNMS91x 3zURiFUJ+Qwx56Y/Cjyj/wDXpk3G+SaPK9varJuHkn1/GjyR2B9R9KkY1oQev5Uwx/h2+lMQnl// AF/agp6E/j7Uv+HGAWniL/DHvQMsR2ZPQH/69adtpmMbhz1x/jQFi8FAHp3wKC5Pp+PYUIfr6iY+ mP4fbFBPqwHce5FNCRkooPUf/rrovDcoBOS3TKY9R/jXBNHZH1OzghBA65649eamvEXcQCPXHpmu NM3Od8UWmYWyWGMHI9Qe49q7fwlcl4IyWycZfP8A7L9K3jt8yafX7z66/ZW2BLoKMHcjE/3htPQ1 9E17dV7eiMMXuvRBXhv7RemEpC+Mj5rd/YAZ4/OuHELR/eaZe/eX3GL+zdq20yIT334PVSR3r6Mx VU3/AJndnS95egVj+KrEzWswUAnYWA9SnP8AStj5+R8YeItSuYLhZNPkaK4jIuLZweu0+3rXuPjX wzZ/ETQw1hAPt6j7ZpsanmDVol5Q+1wOOfapT7nBUX/ySPz4njkVmE0LxyKTFdI3BjlQ4w6n0qzO 6ugIY+4HtVJeXoKo9rGJcw5xgH1B9R7VFHGSeevYHsAK0j5ibMu4AB6Y7nHpWhojAMCzEdifUYrU peR61odlaXCjz5AP4S47/Ue1bdz4LitxmZFljPKSL3X6U7eRaq9zDu/DkTH/AERcj7y/T6+1UH0u ZOqk98H1quXuaRuPiBP3sepB9aPsvoeOnHr7fWs/+GH6ieWw6ZPt7+1WYroj7wz2x7+9V6A/UvRz K3THpg/41KD/ALKnvmqS7iHpIueRjtxVoFT/AHQ3RR7UW8wRIJD3Oe1Txuf4lJ9CfQ+hpDT/AMx3 k5+6QR159RSNbKfQfTtSFd9fVjY5XXozY6k+orVttSifHnYz0BPcD2psbfYsPp6n7q5HUe4qoUHc cdNtL1LuSptIGW46j61YEan7qA92z2AqREUloOxA/wAcf1qIWrAcnA6geuPahlIRoQeoHrTGsWA+ XLegb1Pqfan6i/4cYEcdevVfb8alDyDGcepx65osCJ4r3PVceuO4q/FeL/F+J9vpQ/UfzLIkVun5 etSLbg/dx6n/AOtSGSJbMRwM98+1SxEjO+JPYnt9KQ7dhUuUBwyjH8Q/Cp5LeBhwuO+R/Si5BBti Hfn1ppji9T6ZPc0wv/mSJEq4w4x/F7Emo7ggH5M+lKwELTn+IjHQ+xppjzyPofxoa/zKt39RmQw5 PsfrVSTTJQfmBFFxpFf7PIO2R79zSCL+8hI6EepPpTERTWBB/wBXntg9jTBYqexWlf8A4BSXf1IZ NKkH3ee2fUVX8ifPB+vuB6impEpEiyTj1Pv6CnpM+fmyO249zVKXZg4luKCX+GQH1P8Ae+lTNDMD 3HcEUX/zIcexGJZh/e/x/wD10v26UdQ1U5f5it2YyXUXH3gR/So/7XJ+9+FNMOQY+qk/db8+5qsd THYfWj5kWA6mh+9genvVea9Ttn1yOxHtQvMpog/tFfU/3SPSnLqA/hbI7D1pf8MFvMcdRVfc9cVD Jd5HzE/Sm/8AgB6kBc9icdz7e9Vp1+vtj09z7UrDSGFCepPrx61C249AfY+lT/w6H6jjbkdBn60q WzehJ747Ckn5eQf8MH9nEj5fw+vvVWfTWHUY749aPkUU5bPHUe+f8KrSWxx8q+x981m0V/TKr2fv 9cetQPbgZyMHow9CKmwFSRD3x6j8PSqzx56t7gn0+tQ/P1D/AIYrlPcew9vemNBnqeO2P60NDv39 Bph4/lUZjA7/AP1xUlsYYx/dB789wKaFHbjuM+n1pv8A4JL9PMRl/wB09seoppX/AOuPSnfv6j+Q uwDrn3HvQCOy/wD66VxMNze2P4sd6coPqce/Y/8A16cR+voKQT3+vvTiTn5cEdFJ9KBNj8L/AAsf r6ijB/g/76FWhW8/JCgjHU56nHbHrQ7jHQ/WpC/cbn06dCKbgDoffPtQ329At2BiP/sfSmMR6fh6 fjTRT8yJmA757D3+pqMgHp9CKCULx6e31qNyvv6496n/AIcaY0gDp9M+v4VC/wD9bHofpTt/mDGs Pr7Cm7PUZ96L/wDAGvP0GEn/AA+tMOe5PuTUJjt/mIVH978aRj6Ent9Kd/Id+w1h+Pqfeo2Pt9Aa SQr+REV9/wAfel2f/q9TUisN3++aAR3/AD/+tTfoCfcUkd8+q+4pCPb3+hpDaFJPb8abn29qYXAD 1x/jQD6mkAmM9MfX1oz7+1MA47n6j1pGJ/wHtQHoHHp7k0Aeo/Kl8xCD3zQ30zVAG3I7emPahlH9 Mev1qRgV9Rj6UZ9AD2z/APWptCSFC57++KaPcfSgbDb7/Q+tKV9h9aENgT/9f2ozjr+BpkjlA7Y+ lTAD6dvrSY0/LzFce3/1xSMQOnHofWhDBfc57j2pd390fUnuaTBenkJu9R9PY0g9h+P+NAIcfc/T 2pqkj+o9aYmOCg9voff60bfUn0FA7/5i5A6j6Umf7vHvU3H/AExQPcegA/rSnA9ffH9ar0EIVx3+ o9DSFvf6ihsb8mG4Hp+tG4ge/TNId+w0c/1pDz0x/wDXoJTEAx6n196XbnqPp9KbH/wwmR3J9MUp UdvwPpUjG59Pp9BSgn1piQuwdvpS4Hc0Cf8AwR6kHp/31Ug9wfp7UX7+g0yQMfX/APVSh/8A6/1o fkDYD6ge1OwPw7n29qoPQDjsOO3vRj1+o/2TRfz8x+g7Yvce5z6UGYDufc+tILi7h7+lKZM+o7E+ gp+g2xrN7n0H0pA47r7EUn5k+ow8dKTr0Legz3pghwYDsPr6fWgKM8knvU2D/hxMen0P0p2T6E/X /PamhJ9hpbHXPsPSjB9Rn+H2+tU/IoFz35PTPqPelGO/4D3qP+GD0EHPQD1x6gUAgfe+n5+lNAOD ewHoPanBj2x6VVyRA5I5ye4FO83HXn+lAxQ3r+A9DSge5Pf8DU3H8xQWP+NHAHGfx7fQUwbAD1Pv 9aAD2+v1z60PzEDH6Ee3YUnHbn0J9Kb8h3QAAdgff0puf9k+nHY0r+Yrf5iGM/xEH1+tRFB756fh RcGQbvbHp9ahaMf/AFvSlcbXcheLHb6e9RNH7VRK8xm3H8x7/WmEf4k+9ZsBPx980mfT8vWrB+QH 3H1HvSEHtj/AUIQoJ/oaBg9Qc+3al6DDA/wpAvuT2o+QMUj29yKeBjpz7+tAehIpz1H4jtUwb0Bx 3NQNPuO69hTdw/x+lIr/AIYTg9KQsB2/GqJDB/8Are1PUj0FDAnRvX8DS+aO+D7en/6qTK/4YY04 7HPb60wv+H9aaJfkJvHY4/rRuHqatEf8OPB96Aw9Pf8AKncq3+Qbh2/yabupCfkNJ/H+lRkA9vfI oD/hxv8AkH2pMn+mD3p/0gHKv+fQ1YhQHrjP8qXoNPua9pajvwev1q3nHQfj70Mf9MQt60zjunPZ vaiw/wDh2NUn0OPQ05iO2fUj6+9WC/4YyYicfzNbnhycK/Pphh7159Rdjpp+Z3kBOBznu2f4TVi5 C7umD1A/z61w27s3uY3iCBWicZOcdR2OK2Ph3MzWyb5d38KY7KOv510R2/EUVq/Sx9cfsveL7GJ7 iO6ukjlYLc2it0ljjHOG9q+lBrFoel5B/wB9CvT9on16WM8VF6csXtYd/aVv/wA/MP5ivPvi94Tb VLdFsZIXcMZApYcoV7ms6jVt/IywzaabT3uzz34SfD3VNGuWOqpAkbfKGVs5AP8AF/k19FKwP3GB HUEdx7GppPtfsehmlRNrl9GLtqrqSr5T+Y4VdrB3P8K7D1J9BW/yZ4UmfCXjnUVjlBiLNjKMF/jw a7j4FfFtdLuwk8u2yuCIpueLe/UcFhn+LpUdd/I55baLyZ5/+138BV0S9F1pcSpY3R8u6iUcWutK pJwc9LheQMDHOPb53srs9C2P7remfatzlj+WhXu2IIwT7fUVXEpJ5z659WNNIb/4Bn3MJ3cfj/8A XNWNP27hnPoR7Gt4lxPRNLjIPyucdAB/EK7WwmlcYklO3oqnoB7/AFrVM463/BOlsfBhkH+jKrue Qvrx2NQ6h4ejUEXljJCw+U5HBP1PrRKPZm1Ctfr5HLT+H1H+p2n19hVU6ey9OB1X6/Wpa7nWvMQ2 Wf4T/gajFqw/hB7kepPpUtFehIGwPun047n3pUkYds9znsPan6isWAuevHfNSKzdlHoc+1DQ15+h KGIPr9P8amFw4+n8PsKF6hcsxzD+E+7D1+tWEVX+7jPQe4/+tU2Bjmtjj7o+ntUZsWH3WOP4T6Zp ehfoWYLuVOkuR0K+n1q35UcnT73UD/Gn8hNFceZGeVyPU+tTfayfucHuR/Sp9fVgkN+1n1J7knsf pU3nKfX0U0Nlej8kDD29wB2qeOMkfqffPt7Uf8MFyQWKMPnC+iD0qF9M29Of6il/w47kBCj7yEHo T/e+lSJCD91sjpg9j/8AXosK/YnMUg+44I6H/ZP0p8d2w6N9R6Yo+Q7luHV2HXI7g+9XI9TjP+sG PUjvS9AS7P1GTeU33Mf7Xvmmeay9Hz3HuPrVMBrTKe3PXHrSLPn7wA7qT2pCSI9wPG72pfNK8Nz6 +9L/AIcbXYm8lD90++BTViI6nI6035juStp24fuiR3JHc/SqqXTrw6kjrz6/Wl8wuTzRE9FwPX1/ GovKX+4D7+poYL/gEuIz1UA/zqFrONvT1z6imkTf/MkES/xBfUGq0umoOdo9AB6UrFepAGjH8C+5 +tPItz/yyXPTJFOxFyczW5/5ZAHs47VHNKuO2PX1+tFikyKORSOoP90+tRuTnjB7Z/vYp+qBeSHx vA4/exLnoc9sf40ybRIyMxgehApIVzOl0PHr68dvwqvJ4bf+FCR1H0NL/hhopSaTKn8JPp7fQ1AL VucDn7xP/wBeqTG4+XkRSQuOoPvjvTQxXqAO+fQ/WncVu/oKWPfn3qMXIHVR659TUt9iWhhmyeQf b3FNZkPQbeze596bkO3mAlUd/Zh9aSMqev8A3170/wDhhWZZF5H/ALJHUY9aRpI/4WAPUD1FP/hi f+GIodQHOVII9fT6e1MkukJ+Q+4J9KG/MtIgfY3XB7gj1+lVJI1x90emD3NZtdyipLAOx9x7fSqU kfqufU+9TYLlVoR/RRWRqnmxgeTGW9VHpU2Kf/AMeK7nJ+eJx6ZFayx57H1b60vQpLz8xDEc849K iNt7geuO1IZG0YH8JPpjvTTGO6sD0x7e9K/+RPzGshH3046L7ZpCpHZfp6Z/wqX6+QL/AII0KB2/ GkC49frTb/yKSHGHPRRnsR6U/ZgcgGj5gl3DyvTjvn1FBjI69fX2NNEMcIyOv0/ClVcfcY+xHc1S BIdj/aHoR/8AXpm/HT8/ekH/AAwzLdxn696Mt6fQf/X9qPQdhNo7AD1xTMjPBP1p3ATaD/PPpSFB joD3BFS2AwKQeB+fc0xogOv4r6GpuNETx56HHsfWopB+J9fXH+NMloQqe+4dwaaQw6dP4fcUrlpk ZXPf8fQ01oye2fQ+mKf/AA4XG7QBxyf5U0E98e49qCbijHY/7WfSmEMe/PTPrUr0K/4YjeI+vv8A jSA/X1B9aA/4YYR6YPtSYJ6Ae9BImPX8KcSfXPakUMKmnFT2wKCRu33zS5x1HtTGmB+o9z6/SgqO 350Iqw3jsD9aXB/+v70yRc47e2fekzU2GBx2P4UmCelMPQDj09qTJ9h2oAXd7H0PvTcnsPwpiuKc f4ilwO+fWkwsIQD6+tLu9SfSlYBfqP8A69Jx/gPemkMcCf8AGpMA/wAj7Ci4Ckjtk9vwoDev0ApI oXb6D/eoIHY/hTF8w2+w+g9KMY6Efj2pAhMev+TRtz2z2BPamL0AqR2H09aXHv74pX/yC3cMfU+g PYfWjIP3v09aB+ouR6Y/rSADt+I96CgJz0//AFUY9T+PrQhfMbt98+vtSk/l6UWEIRn1HrRj60AN we30Boz689vxp2D5gR+Pf8aQD6juRSHYVl/+vSY96BtDgCO59B9accnsPr60XEOC56YHbFPX6Z7E fSgPkODDuxHoB3NPI/uk+1MF/wAEAoHXPpn0/wD10Ify9f8APrT/AOGD/hh3P/6qASOwPrntU+no U329Q3D+LHt9KN+fb09vxptEP0HNIe5HuPUUEg9M+v40/T1BiZx97JPX6H/61Jkdx+I7mk/+AVb/ ADECns2f6UoZj1Y+oJ7D2oEGMdxj+vvS5yP60xpf5CbGx2x3HqKUkjGR9PekSDbT9e1NKDv+A9qr 1GO3Af57U3I7fr2PtSuP1DAHbn+YpSn+GKa8vmCf/BEIPGfxH+FPzn29D7Urjv8A5CA/4AHvShB3 47nHr7UiWKT9fTPpQW9M+maLlLyF3kdMj+8adv8AVs+o9DTJS7+gpIPUn6/WjJ7dOzegHvRbuHoN yvYn/wCv70uV/vEeuOwpIaQA+mf970H/ANegPjoT6E0/+HBLzGFR2+ufemEHsB6Cl6+gNEbL6qPT PqahYe3v+NFgIyv+fWo3Qds+/wBKLC9CB19MH1HpUZQDoTQL0GN9c03I/wA+tFwf/AE/Glx/hn1p C/4cOB/SjB78f4UhtgEP17j2FBIHQe/HpVCaE4HenBqARLHIew9qlDHtx7+tSyh4/wDr0YPt7j2q UUNxnp9fxoI9f/11TF/w4hb1BH+FKJB/iKSAPP8Ac/SmG49MVSFcUSnvgen0o833/wD10wELe4/H 1pRIexNMkXef8+tG/wBz74oD5ilz/X60m8/40gEEv19frTfM+g9KYITHt+HpSYPc/h6UXE1/mPUj 6D196nhfP+FAzbtct1B9Cf8ACrXlj/PpTQ2IyHsvs34UbDn5hgdCPQihFMa0WfXHT6ketIYs9PwF CX+Yf8MY8Jz90Anrz61raM5WQfNx0Ye//wBauCTOiPkzv7SZG+6eOhP+NXrxBxj8/UVxWOm5nX8S srZwOCGz3wKPhnIfIwSAVOGx6kmtujFDf5HsXwv8QrZajA0k4jQk2UzEcMsvr9TX1zcQxljwD2U+ 30reC7eh2vZfNFS4lC9fyqJr/A+8cdKpp9TlOf17xRa26EzSEfxAeuPSvE/EHxIub04tLy7gjHC+ W5G8e+DUxb+y/MUY90jmEvtVY/6Nr2qp/DlZmyG9etFz4i1VGA/t3VZAeLlHmYiRB6gmtXKXWT8z pdOPWETH8QahI38TZ6gnt/8Aqqh4f15gxRpGQk+faTDrFMv9xvUmqX/BPn6kdHY+xtOtbH4gaHJB rEsf2rb9iuZGGTaanCMpJt9CwHpnmvzk1jw9qGl3MsOswtDdRM1nfRn++jHlPZxXZHy9Ty7/AI7e pVnkz1H0I75qFCM8j6VcWVfuVLqM55Ge6n/CixQ7vmx9PStkwX/APQtLmI2/54967/S7XevXnqR7 1tFHNW8juvD0UgCmPK46gdj9a9U0vwnZ6gu3VYFcEbWbAyeOxPpVzOOlvoZGpfseXBLHRmeQffiA /h46YNeNa54D1GxYi8s5VOSGbHTB9acGme9Hb8GYwk2/fjU9myPX1pojRvvLj2FYSQk/82RSWRHb jqR7H39qZ9mI6dOhPrRYLieS3O8kdwD6ikR2Hb2//XQvP1Ff/MuRsD0GD7egqRYs9PzPc0gT7omS 1P8ADgev4etS+UV+6p+o7gH+lJ/8EstiQn73ynofenocdfqT7VH/AA479vQQlf4R7Aev1pqzY7nP 8hTS8x/0i1FqAI/eqGHUH0xTXkQHMTkf41KRPoPVEPU4Pp6g/wCFWPsw/gYEfwkUW7lCmEjqffBq ZHC9wfpTt2HcDOvoQacb0egP9R9KVu5L8vRCSlW+8o9cjsKheID/AFJz2BPf60f8MV8yLz2AO4MP U+ox2pou17n2Lf3j9Pen8wJ4JwepyOw/+vVjz0bOAMdMnvUJFX/zEaRgPlbHpnviprbUQP8AXAE9 jQwXoXVggblZOf4x71II4X4baCOVb/PrSEmV5NNA+649/Y//AF6gezYfdy307immCYqSkffUgdR7 LU8c6H7xPt9KLdh2JY73Z9xuPX0H1pl/LC4zCQrenofY+1C8yfQqJqJH3uR/I1MZ0I4bnoVHamhv yKr3uD3YdR7AetI2pIR+7GPUHtn1+lK/+QkwXVf7xHoD6VKb0noc0XC5AyDsuB1qKVwPu49RS5hj FmB9FPcDvipROpH7zI759RVf8OJefqVnjA+6fcD0qA3e3q7Y9DRcq3mStk8q35djSjUSPusf9on1 9qBN/wDAJheE9D9RntTor8/7IHT6/Whf8EHcsefGR/ql9Mn+maqtZwA5RAfwqvQlvzIptNibqgFZ 17oaD7o3D1P9KLGiZQksfTp1cf8A1qibSVK/LkdsVl6A/Iij0h26MOOmOp//AFVONCJ/iHoc9qLd wbCTw8w++dy9dw9T70j6CwHUY9fUU7f5juUrjRJF5XB7Yp0Wlu33x7qPU/WmNPv6EFxpjA4wfUe9 QtpTjqG9QPUe1El2J+fkRi0Yfd3Hv9fpUTQN/Fn1A9D9an1GM+wE9c5/mKa+l5ztA9/qaPT0F/wx XOhsR1H0FRf2GP4uB0I9TU/8MFyFvD4P3Qv+J+tVz4bbPK/h7e30osVcjPh1v4Fz23HsPao5PDsg 6p7c96PUpEDaBIOm71z6fWq76Q46Bj3qH6eRPqR/2XIfvJ+HvSHSn7xn/PvUspDRpsneMj19vpUT 2TDqh9FI7iqf/BC3n6ALNx94HPTil+yn/wCKA7E0vQEu/oJ9mx1BYdB7imm2P8I9yDQN/wDADy8d QfTPtThGPQY6A1fzISGrH/8AX/8Ar0piHr/ug0WEl3BoyP4c+vuf/rU3aO3Xsv8A9ep9Chrj0X/6 9RkAdQCe3tn2pfMTfkJ5I9fckd6Yw9ie4NMPUaynsaiYnuB7Y9RSfkD/AOCM2k9eT1zUbRE9M+v4 fWmUIynsTTDGf7x9h/jUeoPyfoRkA9T+HqKQr6KT2I9BiqEl3Y3YO+fUCmsB6UMXoNAH8OfQmkMZ A4P/AOo0v+GBETlR3NRqw9SfX2pLzRV/8gEfrQVx396QrDSP/wBdKVx/nvTGIQf8fagg9/yoE0HH fP0FNxj+WPai4C5H9B+NGT247fWgdwB9vqfekBJ/z2osMUIfX6/SkA9fz9KBBn6/UUdOufTHrQwQ mB7f4UYoGhSPTH19aQChCAnHT6Yo+nX09qADaf6UH2/A+tNIQH6//WpNtCH6DlB/hqZSPT2/H60k NPuOLHHYe9Nbr8ufc1PoO4mT6n3NO3Mewx0qiRSB7euaQoKbKt29ROe4x2PvSlsdj6VKJTFwD6e3 0pGb8O2fQ0yn/wAAUH1z7j3pD7Ae3uKmwAc/X1oyP6Y9apoXqxQB3J9gO9Nx7Uh+gAnH6UhB7fjT +YAR/tH3PpQMj1P9aQejDI/iU/h60hXHY47+1AMNw7/lRkn6dOe9AP8A4AhH/wBYUpJ9Pr70WKFD en0JNLn1z7CkK4u49qlU59PrVf0xJ9xQp7c07IPTj2FO4R8h27I5bjsKQAf/AFqRT/4IbiOx9vpS r/tH3x7UWJ/4Ycqg+3fPt9KTHp9abAUe2PX8aQH1GPQ+tIL/AOQm89gfXn0oBz0/4CPShlL/AIAZ HYHNJ5Y7kn0oXoTYUkdx7gev/wCqlxjoxI9aleY7f5C5o3H+Lr0Oe1P+kJeYhGPu4/u/X6Ck3A/5 6fhVA/IUMP4R7c96RQf7/tt9T9aAb7Icf9rGegH1/wAKGA7j6ihDt39Q59vY0oT1B/wBoXqH9IOO 2fp6CnbF9/7w+tKwIQt9aUKP6j2ot3F6DtvoAe4PoKQxeoPoPce9O4W7hke/pn3oKY/iJ9vb/wCt Tv3Q0hPryO5Pak2DsT7n1Apegmh28+n/AOv3oEnqB649aRVxobH9PpTHb/EfX61QiMr6/gfX8Ki5 7/UCkCZHJz7eoqNmPb6fWp/pksiKnt9MelREH0/CqsMiYenHt6GkEX/6/ekhWAg9qbg/SmT6C7fU /SjcPrSGGfQ/j6ikA9iO30oY7hx2z7/WlDe3tihCTHI5+lTLL9aGMkDmnZ98e1QNMT6fTijIFAxp Y+v4epqNmB7496aBsYW+v0oz/e59v8aYAJPQe5FKJPQYoRFw3Z68+g9aUP6Zx/I1QMBIOxJ9TSg4 /rQHyDd7n1o3j6d/rQNoC34dqQj2OehqWJ+QoP19c0ZHr+NUMVVHrU9uhz/KgPQ6CA4HH5+tTMw7 fUn3ql/wC7d36DgwPQn3P+FHTuT7ClYT9Q2ew/xoVh3Ue9FwZhQE9h9fY1p6ewVxzj1964pHXD/g noEQRQcZx6e3tWg7hkHynHTnuK875mzRSuY8/f5GMMfQAVT+FzDEykjIfLf7Q5/rXQtn8iYrX5WP XfCOjwTXUH2osE8xM7T/ANNBX363hewP/LqvoOTx/wDqr1KUdF8/0KrzaSt3K0vgTTX/ANZA2exB 6Vj+Ivh7brbynTXkSVUaa2LYwXjUnkY705LyOD2r8j4Z8cfG7xHI227hg4yGRePmz2x/e/Gva/gb +zzpmvWRm8QXtwshPkx2sOB9nxzlywP3s0qEetl2PbdOybd3bVHqEH7HPhyMEC/vjn+I7eAPwqlN +xF4eY5i1a/Q9QSFOGP4Ct3PvCJwPFd4vsfN/wATfhnJpc0qLOJVRjCJsffiIyCw9QDXj8l1IjAx EK4O5Cex9q5ZRPMjLv6nvHwY+NTaVdI8kp+yviy15SeE3YwzZP8AyzNW/wBtj4ArmPUdDtDLkJpv ih4z92BQdkhGe4+XgZ6Z46b0fX+6eXW8ujufI6IrLnd7fUVXaI9vp+FaoPmVrhW789wD6UkCYPTH fIrRBE9F0RFCjzFV84AY/wAFej6JCgXh90h+VE/DsPpW8X/kzCr/AMA9F0DRZBgFcDo2fSvVPD8a xbdpDY4Lf/W96qT/AMzkpo9j0GYFfl+rfWsvxd8INK1dT9pgWKbrFcoOrEf8tB71xKVnofQUttD5 Y8efs66jphJa0LR8uko6MgPYj+6K84k0R0+8jA9MH0Pr9K9RpPWLM5LuM+yt/EBjsfX8KY9qD2/+ uf8A61c7XYhPuV/s5HUZP8xUX2c+4z94egFFu68hX/yHCHB4JHYkentViG4X+Pn0IrP/AIcv5mhH CvG36k+pPp9KnCA9RjsPp9am3+QW/wAyTYO49/qaUIP41z6H0+lFjT19UPNoD9w+xHvUTWv/ANY+ tIZH5BHT86PIYffII7EdxRbuVfsR4P8ACW9VB7D61YhuHHQHHY+gpNk+pYWQ9+R2J7fU1IXXseP4 jSv5+Qkuwsj56HPaolkB6Oc+h7/j7UIaJUmx1GO5Pr/+upvLDfd+v/66YxNi+gx6+v8A+uoJbMH7 px/EB64qWO5AqlDycHt7/wD6qPOlJ+YL6EjsPpRf/IL9vmTrcMPvjI6EUbwfuZ/2T6UkNB9skXoC OxPrU66kT1P1PoaoVu3oTDUD/Ex+o71diuG/5ZEEfxA9voKSBomX/pomex9qcNMiYfIuOxpgMfSx ztc+uB/hVabTX7L+Pp+FKxV/8ii9rIvVD6E+gpHtmH3WJ7D60mwj5sz5pZR/eH+Psap/aWHcnsfw psh+of2tgdG9Mnt9BSrrDDoT/sg9z9aSGvQnXW5OzZ7EGl/tTd147kjsfamxDTdH29Nw7ikN8x6E ntn1oXmMYL1++cdvrQHLdSPf2NDBr/MZ9oZf72OuD3+hpWlLD5TkdCPQ/T3pXBL/ACIxeOPvDHYe wHpT11DPXj1Pr/8Arpgl3ZP/AGiy/df2x9f8KSPVmHcf7QPp7U/Qn5Eh1Qjt+FTHUEkHzfTPqfai 47FFkwT0x3B7H2phgx0Yj+8PWoZaI/KdOUP1I9P/AK9CTZ6rntj0NNPuKwpLfxAjuB6j3pv27+8p PoT/AJ7U2+wW8/MhuSeu0kdVB71TXUnI4yO/0oT7ia7MRbj1AJ6AnsfrTJbsg89eg980XFb/AII2 O4z1A9P8ioZJifu4A6kHt+FS35eov+HEkmGOFXPQn3qmW5+Uk9znsPrR6epd/IfLIQP1I9D/APXq ssgbqWouJh5i9m/3fcGh3b+8P8CfSkykMLY6sfXPrSEse59selSF+/oRMFGcZJPJPsPSkIXttH90 +hpDIwo7oD6E+vtSNEO/UdR9aP8AhxL1ZCyr1K4Hf2pDZxHHyj1X2FA2xr2MPZOOoIHU/wD16Y+n qeiAdx70n5jb7B/ZyDtx3Hp9KjfT4T0X2b3qbDTGnTFx7dMfWm/2QnYEH09KLdvQaYHRkI6j0I9T TP7DT2B/rVIGJ/Yh9SPb/CmDQz/AwB7g0vQlv/IZJobdiB3NMOhN/dAHY/8A16TLv5DToLjoCff/ AD6VH/YUnOAx7E+n0ov/AJBfuIfD8p/hAHb3NQPocg6oc+o/rQVYiGiyeh/z6U06LJ2B9/f8aG/I lIY2iyf8829x60w6HIeqH6etK4RX+Qw6PIP4T6gewqP+yHPRSB6U2xrzIzYP/d/+vSGwb+6KQrdi M2B9PbHqfpUZtJO6HPXPtTVv1G/+HIbqwlYfIvsRVdNLmX749z9fYVKYmhwtm7r7EU02zdgaF/wB 28hRbsOw/wADSNC/90/3s+oot3Fb/Ia0R9Me3pSeUe+TVCt39RfK9R75HYUhj+o71P8AwwfIbsI6 j8Pel2egPr9aY1/wA2Y7fhRsOOv1pMYgU+w/qP8A61JsP+A9aCf+HDZ/kU4g9ifcehpMfoMx6/5F BH93OOtFhMQoe2fWlKf59aYgK+v4n2oKeg/GgAwf/rUEA9h/hRcYbR3/ADpdo9/amAqgnvUoQn0/ xqQSHbST82R7e4pNuP5Ypj+YgX/ZFLsHcH6UJ/5ANYD3x1/Clx/d49aYl/wQBH9KXB7/AKdqSKYH 3Ge31FBUn09AtAP/AIIuPb2+h/8Ar0m3B6exo/4YVwyB1NGB/UNSBAVHqcdfoaQMPQ+gFJsoQnPU 47fUUgXHU0yRQAe2O31NDHHv6+5oH6fMRSR1P4fWm89yfr60WC4u09vzpNtFxAVx1H40N7fgfemO w4D2/wDrml2/4fWoH6i7fY+v1+lSKD7etWhWFU+px6VITj19M+9BVhB05HPb604DPX86PQQEgdAf fFHfof8AE+9MUv7o4En0919qQHHb2NSmCfcM88cds+hpoJ+nce//AOuqEx28dx+I9abjH9B6mi4x 2F/Gm59frx3FS1/kF+/oKOev4A9ifT60M59famkNPz8hcZ7j6ev40hH94n2z3piAIAOPr9aMnsAO 5HrikKKFCn6d6UqR1wOxHp9aY/QAT9ff1FAXHfPr9KY7gZCOw9T7mgqexx/e9s+1SCHNgdz9aBgd SfQe340/UXowKkdeR1B9RQWJ/h/Chi/4YUSZPcduP89qHYH19v8A6/1o9Cr92KAf4h+X8NN3Edjj ofY0W/zBtiAZ+8c9qUJ6EZ6Z9B7iqD/hxSfQfh601WB7Y7H/APXU/wDDiHbfYeuaYWJ7Z7Ee3/1q L9xtELMOwH09f/101iD2+o9/akxJdvQhI9vrntTSg7Z9vamDfYYx/D6VE6/X3NAv+GImA7g03B7A Dtmlcdxu38Pr3pCP8PwoYhuPb6fWjBH9frRcVgAx1Hvmgr6U/UGG760uPUj0xSF6gCP6fSpFYduf WhlIlBPY/wD1qeW9T+FL1HYTeKMj0+ppIZG7g9/oPamE+/sKdhWG8H+dNye/0/CkHoDEDvn3oL+n 41QrCh8dvb6UufQn3p/MXzDd/wDW96dvouCEye34igP649j70gFz/iMUbvc/40xiqB2JpNp74/wN ArCr/kVo2UQ7j8PSkCNiOP1xj1Pf6VNtPYk+vt9Ko0H8d8+pPqRQx/DvQT/wwmP8ePSlJ9h659ad hmFbj1J9R7fhV+BeRgnqDx7GuGRun5nodmxx1BHQH1FaAdivXgfL9a4H/wAE62+yKzL6Hrx9Af8A Gs34flUuLhQSBnOD2YgdRWq6/eT1373PZPC8gE8WSeJEYN6fvBX6Ek169L4V8ycTt8xKjuLYSKwY AggxkHuGHf60M80/O3x/o4jnb5CSGZCfUqx6/Wvq79myMpZEEYB2yqvocH+ZrLDPR69bI+uxUfdf oj2ij68dyfQVqfIHyd8eYoJZ7g2bJIvyvuX+KQRgHaR/tCvla9hKsd496mTJpryNDw9rq27kXErF Gwn+656EH2Nfa/wg8W2fijTZrPxciXDKh029TJzd6VKOCpznMXqD1wRRH/go46q/H3WfBPjb4R3/ AIZvp7TVm3NGfO0uU4zd6VKTtc4/56j6c5B5Fcw0LDqfYj3rsf8AwUcsPl2ZWuUPYD0Ge4qOBQTx 9CT61S/4BpH/AIB2Gk3DoBuYkDlBXsfgC6iLgyxg4+Usf4Wx/St0RPy9T1G1DlvlYJGeUUenua7j RVA+7k+p9aDgiev+F5Dt7+tdFXFUPfobEF5plvcKVvIElQ8MjD+X0rx7xt+ytazqW0IZcfvPs5HL A/8APNq1oVbb/M2a7niGtfCGe2J3wuD0dSOv1zXI3WhvH94ED/Cu+cexyS8yi1p7Y9M+lQGyU/eH uCfWsZeRmmV3t/8AZGOmfWmGM9vxqeX/ADNE128i7AZB0BI6geo9quRSBh8wIPXntmoLJVI/vZ/r QHHf/wDVQJv/ACJY7jB7EdwfWrAQN6D0Hrn0qSr9hjID94Adgaha2YZwc9gPX/8AVSt3AjaIj7wx 7DvUq2wPXPuD3z/jSsUvMcYiOgJ7HHp71B5pXoMD19aEH/DEgkHbjt9RS+Uf4V+h9qLf8EEO81h1 +pI9B6Crtuue+D7djQNCtbueo9wRVaeBs/Ln/aUf1pegrf5FWZFb+/u9PQfWnxWrj72fVfpQXYcY 27A/X2pVJH3/APgI9frTFbsyyoD9VU98+lOGnq33eP8ACo9Aj5kq6aB6n29v/rVZjhZehBHrQh3L aXCnqM+lSiYdsr6ken0FV/TFYja1Yk+XJn+Lj2HpVdp5k65x3FALzIZdRRhyo9W9/wA6rpeqegAH f3oEQTToTxg9wPQiqlzaI33FCdmI9aX9ILFNrKM9Sfc+9VzZ/wB3B7c9walf8EZG1sw6LjsQew+l Ct9T2A9vamh2LUdq3uR059vercen45UK3t9f8aBJkx04c4UEdR6gfSo3sFx8uQe/tQNv/IiktEI+ 8pPQD3qsLRkPyOfTHof/AK1Sl/wAbEe1DjsO/wBfpVcQkdhjqfrTsK/kTeUSPmC+wPf6fSlS1+hH Q/8A1qaGWPsi/wAXHpUIgKdjjrgd6BejEeXI6Y9TTEc9z7AnvRb/ACHcsB1UdvTNRKiA/MR/9ehe XoK//BJpU44UHvx3/wD1VRkUZ5QA9cD1/wDr0B6ehKSrA5znsPQn/GsgRgE7gfQfX2ptDS/4AKVX 7wz2A9G+ntTJ4s/19h7UmIZtUfcB+vrUDx7umB3J9h71JX/DiNASOTz1+oFU8ehH+FF/+CT/AMML OB/9b1qOJCDwT6YNBQjxDPJB9qc0H9/HqDR8x27rzGjac5+pJ/pSMB/d9wfUUrf5ktf5IYYsfwj6 e1RSAZ4H/wCupRf/AAwjJnqBjqff8KQkntj19zS+fmBG0fqo5/QCm7F9WPZRVf8ADg/MbtY+hHQD 296XYT0GO+B6D3qQX/ABk44OfWmHPakxtBg4+7z1BphcD1J7iqX/AAAYbgemD2PsfekMg7dehH0p WFcUN3ZiB0wO5pvmEdc+x9PrSv2Hb/McpLdAP7x+lMEp74/H0FNevkS3/kKspPTr2NKsp/DuPel6 jQ7z0A5I/wDiaiecEfLz6H1B9velYv8A4cSJF/vf/WOP600qO491/wA+9CRN+wIo9PYinMi8blHp +FH/AA4X7B5SHqgHcsOx9vrTHtosfcHocd/wp2/zH/w5G9tF2jBHf3+tRfYIj/ACOoIqRX/yGrpc R+8gB6j2NMOmRA8xqezZ/iNFvMdxf7HgH8H4Dtmmf2FD/Cpx6n+9UuJpf0IT4ej7Ae3vUf8Awjaf 4H1FVb/IlMY3hmP0H19aYfDadj7EelMbYh8MRAfeHsT61GfDKHoR68/571Fgv/kMHhdR/iOxpp8O D2/2fYUrP9B3/wAyu/h0noB7fWmt4bb3z1BFBN+4Dw4/p9SajPh9jnGfVj/hVJDv2Gt4eb1P09BT H0CT+CP6H1P1p3EMGgyehHr/APWofQ5R0UEdz7+1T/w4hDokncEe3rTTpEnZD/n1ouMT+yH/ALmP XHek/sl+ymmgG/2XIOopBpr/AN3jv/n3ouHKH9nP/Cp9SR7U37Cx6gj0HrQwsB09/wCE5/hx60hs G7A+/tSTHyjvsL9wfce9OFsw6fQ+wqrk28waF+y/j7UCAnsfU+1ILB5LDqPYUhiJ9fenfyHbuIYj /c/E1DLE/wDCvt9akB0cRH3s+uKl2n049fUU2FhCD/d+h9v/AK1Jt9/r70f8OH/DiYNKPfv0osL0 ECf/AFz7e1Ls9/b8aGH/AAwbfUH/AOtSZPofw9KX/Dj/AOGE2E9B9DSFD357H2ptk2Yu0fxcemaU Ie5Hqfak/wDgFDAgHTr0oCkdjn1o/wCGJFK+ufemk+g+tCK/4YMHsD/9elAI9fpQNCq//wBf60YH bPv7U7A35jwDjoD/AI09V9fpj2pf8OMXZ7+x9qfj347j6UNkgU9Dn2pcH+ED0P0pplCh27fTHpSg Y6HnofYmk0FhFXHQfU+pppPofp7/AI01/wAAiT7ChQOpPr9KcR6D6se9MBjDHf6H3pyEHpg+/vSE vMU+3H9aYZQPX2PtRcoXZnqf/wBVJsx0Y+9NeYOI5QexwPT1pCCfSgQ7Yf4j+A7ikUA9MUkU0Lk+ uaXr1+tMP+HGhvT8z3FOCD/PYfSl8xW8xxTPUjPY03H95iPX3x/jTt2E/XyAKefyGfSlBA6jPp/9 ei4eobv9nHcfShiP4SSPehlXDBB+Uk98egpWjz9w8difShEhz3/4DSNnsT7j1oLBAe4z3x6UufRP c/596ZD/AOGDIPr6ke9Lj1A9/Y0/l5DQ3dj+I+1MZSPun2Pvn/Co9R3IWX2+n09qaSMcfT6ihsP+ GGbM9z9PX6VGwI/pQIaQPT3J9ajIHr+VBIxkJ/rnvUTJn2/rQAwkntSZH9D7U7D/AOGDPpj6UmT2 P0osA0Ed8/UUpA98dh70hBnNIQ3f/IoD1FB/+v705W+nvT+YyRXPb8D7Uvmehz9ahoEw3/8A66Vn J6nH+NMZGG/H3NMZz35pi/4cCR2Hsfc0ojJ6n3/GpAbn2Hr9aQqfU/SrQmBb1J9qXf6UILgHx1J+ lKSO35UWGHmHvxSiQHt+PtSFcTzKUyn29M0DTEEv1x0PvSiQ0xE0MZJ6cevvWxbwbR0+v40AvMu7 z3A+nqKk889/z9h61RQvmk9AT2J9KfsJ6sD3+hoGOVwOq+x+hoYD+H6D6e9NIV+xhwED3+tXrfAP I9wR2rga/wAjoS8j0HTQCgKkntj3rVRCVOOn8yPWuCSOr5+ZWljBHXHY57MP8axvCR2X8gBBz85z /fCdq2h1uyeunoet6RcFZE+ToysAfXd3av0N0+dnjQyEliqu5PdmQdT9a9aj8PzFiNvnb8CzSgUz zGfCHxn0U295PtbcvmMygf739K9U/Z9+KvkW7iSFpI1X5kXqNg7D3rzoT3t3ufaVIXgv8Nzf1X9s oyZGg6akfOzfLySw9Mccn2NcXq/xS8X6jnzLq4C5zFFHkAAj+ED1+lVKo38CfY46GXpfxn5mF4nM wiYXSMJdu4rJ1HB65r571WMBjhs/1FdEVtf0Z83VesuX5GTcgDGFz7+9enfC74uTaZPFNbGRpIj5 F7CDzd2LnkHJHUepxW6Xc82f/BPoL9pz4MW/ijTY73wisc11Av25GA51DQpF+ZeO8H3uh6EH1Hwf NB3GcHlc/wBa2i+/+E5mtf8AyZFKeLj+lV0THT64963X/BBHW6KsbL82fVP96vUfBtw68RvgHll9 QK0iTUXZ+R7ToaLPgKOegPqB6V3eiWwX75PsPUikcyXc9W8MsMcfTH4V0dclQ9yjsFFZG5la34L0 +/Ui/tlJ6LMo5XP+1Xgvjf8AZ6uLQloQ00PXzVH3M/369DDVOk36GU4nlGpeEHjJ+U56H3FYMuml eqn1H0rolE47f8AqSWPoM9/pVSSzYfcBz3z2PtWQ7lu0cDoAT2z/AFNWSkbDgc/yNQ/JeRUWMVT3 H4+oqYW394gg8rj196TRY/7Pn/lmPfPemnI6BvcetSNf8ER3k7j2HuKZ50idQcddvpmgbQpvwTyh HoT2PvU1vcoT+8Y+p9qVhtksgX+BgfX3pn2dT94AdwB3oSBPuNNp6Anvn0pYz/ePsPel6hfsSi3y OFHocetTC3Ze5HZh60rjY9ZWHfjp9RSzMvZc92+v0o+YyNY4jyQPTaR1HvVkyR/wAAdMegperHf/ ADHmeDvGp9femG3tiOMg+h7mkL0IFjVfukE9fpVgFf4Bz/EvoR6Cj/hwbFSbPXI7Z9KsrECOpz1H uKTGvQYhUdQfc+5qZbsDoc9jn2pia/zInugOQ20+1O+1sfvqT2NCH6+pDNp8T/cLD1HvUC6M3bb7 j/Gl/wAOP/hypc6RIvYkfeyO1VJNw/h9snuKbYrf8AqsoH3gfQgenvUbsw6KPxpXKTIXJbt/ve1M IC/wn/Z//XR6E28y9HqOBzkf1NSrq+OhA74Hc00D/wCGJ4r7PVx/9aiRh2Pv9M0/QL/5CLEMfdHo T9feoZGH8QJH8j7mp9AbGm24OwA+mfQVWMZ9D+NALyfkN8snqc9sUecV+9kdvrS/4cocZieo/H1p 32okfKo9D9aohEWxj1Of7w9BULK38B46AHtn3plsU+ZnhgR0Yev1pxuCeic9c9j9PrUpkMkS8YDk AehHp7j3qu8pzyB6Cm/IdhovGHf2ZfQ1DcHPKDHcn1NHzAq78nJGP7341YCp6g+o9v8A61T/AMMP 19SAhT6Z7H2Ht71A0S9h7k+/tQvIb8hHj9MDvj1qotsoJyfc5/hIHpSJBk9yfUnvUeSOoJ9KX/Dl oiMBPUgd9vr9adn1wfb3ouJLuRkAZw3PRSf4aaW/vAemPQ0B/wAONmI9T6Aj1qIqp6nPqT6e1P5D 0G/L6E9s+tNx7kdz+PvUhfv6AVA9cdz60wDP8wD2PtT9PQLf5AVHYAf7X/1qbgDoc9j7/Wp9PUbE wfUemPT8KYSe2T2PsKGDAn2P19PpTSg9s1ImKCf8Mdz/APWpBt9D7n1p/wDDBb/MaGA6cfXvn0pr A9x7A0f8OVf/ADAcdOD6+1KI1P3sD196h+Q7eXqIWJ6Aeh+lIAP4tw7qR/eH+NX8xeg1ge4z6inZ H8KD6f40n6juKqD2/wDr0bP734H3qv8AhiU/IXao659MfX3o3A9Bjvn1FR6A/wDgEZJ9R/d+tMMj D/0H60MPR+QwsfT6+x+nvR5uBxn0/wD10y35jWZuxH+A9qTeW+9j1+tNEv8A4YUyk/d+lKS3so74 7mpv/kCQ0yjsTnt7U0zY/vEep9Pb6UL/AII7CMPcjsR6Gk8z2B/hJ9M0kyvUYR/ewe34j0FBC9s+ p9qpmfqDRjnDfTHfNRqmemf/AK9JD/4cRovXPt/+qkEYA5H4+1NhYTyx3BPpR5Q/w+tJFfPzHJbe qDPf3FTNagdAP730/Gl/w5KZGbVex98nt9PpTPsyeh+vr9RTGiGSAdse1DQovoalrsOP/AEEYPRQ P6GmiNfQfX/69UkJ+XyEkiH91f73HvUTKv8AEoz1B/8ArUmuxTfci8heyc9T70hCf3Bn+VJruTbz FEK/3Vz7dqDEg6qvrSa7AvUa0K9kU+o9aQ20XeMH3PY0ehQv2dP7n0HtUZt4wOQR3Hv+FFhXEe2j HrjsKabSPseO/sKaQ79xn2ROxz6fSmtaqPT3PqPpR8gES2j9cduO1NaBP4SMdAf8B70rDT7jGtkP Ruen1oNmvr+HoKEibgbEDrz/AIUfYgOmfUZ9KEVFiGyJ6kZ6jHZaPsB/h+uaV/8AIBGsD7H/AD6U n2I/w59CR60eomw+wsO3sc0CyI6j249aLl3/AOANNgT2z6g+lI1qewPv9aq4gbT2HVSOxFNNiexP 09fwoHbsJ9kPYH/GhbNh2/D/AApE37ifZn7Z/wDr0G2fuOf6UAILRu+PY+1Kbc+n4+oofqIcsA7g +4p/kfX1HtSGAQ+hNBhPv7//AFqoSFCkdM+hpfKOfmHtkd/xpg/UPJb+79D6mk8vPqPUUXBr/MXA HXP09vegIB0B+npQ2P8A4YVlYfdyfX6UhU/459KLgv8AgFKQyZ4Q49fSrMEZ/iHvj1xSFYeCR0GB 0x6Ck2EfTr+NP0BeY7I7c/0pFcH+E56/Wgd/8gIHuPQep96U5+g6Eeppf8OJCbQerH6+lKSR1yOw PrTQ/mKWHp7H3NJuJ+6Mf4fWmvUVxQM9Cff60KPT6ip9QXn8heO4/wD10pU+30p+gLyG7m7Z/wBr /wDX704R59fce9P0D1fkNMftk+vtThGPah+QJf5C7Pf6+w9qNqj2+nf/APVRYLdxVJ9AO+73prsP /r+tAXBXz047H2pQnv8AT6e9L0EKwA6n6gd6jDbugYeo9wadwbFI9TmmlVA6n3PoPai/kD8iMZ7d OoNRn6fQml6eoX/yEK47/h71EVbsB70kNERceh9KCn1/wpBYYV9KiePP+NUDQzZ6j6Uwx/T0P0pC EVPQCk2DvVMLBs+v/wBakx6Y+poAXH4joKNvv/8AWpCEETdsnv8ATFOUgdeaB/8ADDgR/SjB7f5F DF/wwufUn29qRsnpj8e596SKEZPQ+wHpTfL9MehPrii4mKF9R9Kfn2PofY0f8OIjYHsPbFGPU/hQ O43y8dz60bPTn+lAgEfp/wDrFKIiemPcntTF/wAML5R7596Nh/z2pD9Buw+p9jShfb3FOwIURHtk euamS29Rnv8AhQg/4Y0rSwHf6/jV4Edgv+0fUUeoEctxjvx2NRi9Y+lMpFuCXHUkf571OJgPTP8A Si/+QevoOEo/oxPc03zx68e3rVDv/mY0DY+8PrWhGD6fWuFm6O80G5yg5B7Z9f8A9Vb1qQwbb1+9 9APb3rgl/wAE6r+XkU5lyOM/X2/+vWFpbCPUVzxuU8juRitI/oSt/wAD1GPUliORg4+Zxz82056D 1r7f8K/tBeHJ7SFnvHiYxr5kDjmN1QDBP1FdWHq6Wf8AiLqwbXuLrcoa1+1TpFvxYWzzN/yzdzxn PdR/jXnmsftQeJLhgNNAiQ8s0YxtXP8Afx2HvWvteyKo5fJ/xDyT4jTyykmcksf3sjN3c+p967f9 nTw9Lc7wFXa2UIPQMV71wYWO/N8z6mrFJadrHtmj/sr6Fb83rNcN99xgcsT6+/0rvLHwZpVsP9D0 u2TspxnAPua9e3ZHyeIx0n8Lt0PGf2jNLJ8llhXBWSB3H8bgD7x9hXxlq1ntPy/8B9gPepmv+CeN Hrf1OeviMcc9z7VBpOtvA4I5H3WHqp9RWsTjnufZP7M3x2jDfZNXuwY3zceGDLjiTHzRqx67gMgd f6eJftN/s3jwzdeZpEBTTJ2M+lrni0vnyWjQn+7yQPTpwMC4efqc9bo/+3GeFS24I5B9fz96opHj +E56/hW6EvXzOn0c5HUDnIx3B9PpXo3heHn5GOen0xW8H2Jn5+h7b4PnkUjK7sfKc+hFem6TajPz AjPIqJMyij0jw7levTtXTVyVD16AUVkdIUjxKwxIisp4ZG6MPcGj0A828X/AG1ucto6LG/V7c/xg f88z6ivB9f8AhzLCSLiCSJx8pVh/nrXrUp3Wu5y1I9vmcfcaHLGfuD6eorPm03PTI7lfSqa7rzOd kH2HH3gB34p/2cEfJgHuT/EP/rVjcpPsCs38QA9CP4qn3KOg+tK3+RomWY5Yz0GOwFKyKeg9jWfq Vf8AzBrRPRT3HtUTWf8As59j/SkvMbIZLAH+H6+x/wDrVWeFl6A59u9NCuJvkX19/apo75j1BHoP b/69IdxzTA9Mg+nvUeD3+oHp9Kl/8Ar1HpO/8Lkd8Z7VMuoMPvqWHRsepp/8MK/b1J49Wi7qB2I9 T9anjvIz0Ufj3+tFv8wX/AL8dtA/R1HYY7g0yTSgvRlI7n/A1P8Aw47lafTm/wCWTJ7qT1FZj3sk Z/fKB/CrDuPej0Gv+ABunPKkgdvpT01A55z6Fh2/GkBcV2PfI6qfUVIWI+6x9SfQ1RSf+Q+PU2X/ AF0YI7N9Kvx28Mn+rb6qfSkRfyFm0lwOAp78elUR5y/wZ9aEO/YmWXH8JHrQbhv4fqaYWGnUSep/ D3qm4RvvBfXPvUW8il5GbNaqOxPcD0+gqk0AOepHQj0P/wBenYbfYjMJHQH0/CmCb6+gz6g1C8xW 7/IlQBuifjj+RoksCPuxY/ix6ZqwSGAMP4T9P8KkFw4/vN2INIleQNct6t9B2phuGY/Ju9x/9ej5 B6kyXYXrn0Iod1PRgD1x/hSQrdiubjb2BHUE+vtSGdD1znsfrTfkWN8sD7ox2yKZgHqxB6sB3HvQ K/cU8fxY9Peq7TMT1yOwHej/AIcd+w1pyOm4dmx6n/CmC8YdB/8AXpX/AMh27PyYv27H3vl7DHrT pLoH0z3z6016iXmxhlx0Az13e3/1qr+cCflbjufXHtQNshEp/wDrnuKcrg9/w/z6Uv8AhxDBMV7A 9s+hokZvX60JhcaZc/dPtn39jUZbHQfQ+3vQJoa0qnvx1+hphIPXn2FJoBjJ6VFhu+fQj3/+tQn5 ANZT/eHoQOze9R7c9CQeh/8A11K/4A2I0Y/iH0PqPpUeV9z2GP8APamV6jWJ9z2H1PrTC5/i+uKk BpY9unQmkYnsOP8AGqQkwVgPvcf3cd/xpgT1z7VKB+YhT+6SO/40pJ7DJ9fr/hQP/h0NLEdye59j 70zaO4A9/wC8KQWGso7HPYe4pHB9x7imigKk9jnr+Hufagye2PX3NT6ML/8AAFD5/hA/qPemBvTn sT7+1NC9BNo7AfX/ABpS+OmPUAdjUsa80IGx/j7e9ICw+6CO7Y9KPl6gxWb6+qj1FCyf7Iz6HsKb fYSGmYn7ufp70oDdxj1A71P/AA479kNIA+7n0A9F+tJj1OO5Hqaf/DjYgcnoOetMLA9c/wCJot2A UA9sgdD9TQUHcD0B9f8A9dVYBCPb6UjHPc+hqP8Ahw/4cYVJ9/Q+lMIPcEkdfYfWn6juNKnuT6ge hppHpkeo/wDrU0O/f5CkjsW9/r7UgIPTPqPwpomwrHngNnq3/wBak47r/wDr+lL0HccQfQf3ef8A CkVD3X/9VDC3n5hs/wBn3HuPpQoz/teuexpEt+XkiVDn7y/Q+31p0koP3sHt+FHp6jv2InB7Zx0+ n4+9QlgOgPrn2oZXqyLC+9RumO34elTf/IX/AA4bsD5evQ+9Nw2ecY/nTD0E3+2O4J71E5+vt9aG xXGYf1A749vekyfb3+tHqMUY7YHYCkkBA+79D60kw+RALiT+6c9CfUe1Ik7H7ynHpTHy+ZMXPt64 9qawJ/nj2pCt2F3A9QfQVGSR1OR1+lFxti7QPT0+lRMD/Qj0/wD10xNf5jDEf4SfX8aikJ/u5PYj 1qX5+oWK5nbvkdifXNSxyvjnp0x61V/IdiRcnq3t9f8A9VPxn1I6knuKm4egBv7gx6e1O3/7Puf9 72p2C4pcd8Hu3ufem7s9Mev4UP8A4AP0HLIe5GOtG8/X+8adv8yRvnHsoPse/wCNLsx7+3oaV+4/ l5i7z7D0Ht70m8c9Pr/hSC4AE9Mev0pGHrn3PqafyHYUDP3ue5p+F7gfX0FHoHqHlIOuP8Sf8KFV OyD03HtQv+CNCCNeygd8+tJsHcH2HqKSC4uwfw4Hf8B/jQI/VR6EUD+YeTz90jvx6CpPsyn7oPtm mQv+CJ5GPvfl6GmNAPQ+ufSlbzKT7ieSD9f6VILZfUehHp/+qiw79vUGs/Q8fzprWgHYevFOwN/5 jPswx2P+JpDb47fTH8JpND/pCLbg9c+3+famNAT3Pv8AX/69HoIBbEdB9cdqFt29c+g9aYrdhfIY nnPsPQUptG7EjuB6im35AAsz6H8PWlFo38Qz6e1Kw0L9lY9B+Pp9KQ2zenv9KP8AhhsaLZvQ/wD1 6Ggb29PqKfqToNEYHQcdfoaPoGPfH/16EL0HbMffPsKUt6CgpIQKfQepNIHPYD0J9BQRb/MTPsPQ n0p271I/xNFik+6I9394HHp60YJPb147UAPJA6CkLEntjqcf0pX/AMhNDQx/iwewFK0rd1/P0FMY xnb0GOpPp9DSA4/hOOn4mm/IlIMe4x057GmsoH+e1JjAqD1X6AVDJAfcdwKX/DB6ehH9hb+8fw9K X7GR6470DB7TB6cdh6fWmm1J7D0z70f8MFv8xn2NuwPqMUfYD6D/AAouKw1rL2Gen5Un2E9xj1Hv QHqvMQWR/uj0zSmwP90emR60CsINPP8Ad/Kj7Af7v4elK/YYn2Aj1/xpv2E+hp37AOFj6L9fal+w Eds0MXoIbJuwP+NOFh6j3ofkNALA9lPv9KQWB7LTF/wwosCO34+tOFkT1H196Tf+Qxp08+hHv/jQ dNPpn696BJf5A2nY7H0o+wnsMevvSBiixPpnvQLA9gP/AK9MYv2Gm/YD6e3PrTSABp7D7wI9j2NO +wHuv4UmKwosP/rE9xUyW4HYf400FifzwOgHsR3FKZh3XPt6GhD+RCYx3PsB6U9Cq9V9vrTaGh4u sdjjqKcbr3P+FT/wwLz9UJ9o/vZ/w+lBu29SO31A9aaJXn6FWPJP+elaEbHufY1xyZ0xZ1/hi4DA jBHYD0J/xrrbZzk4GPp3AriqI6kvPzK7uOenv7iuYu5mjvYT91TkY9CD/jTpLu/JCvtc9Nkt89O/ zfT616r4G+FGsavBEdO0+52AGNpVBwxz/e/+v+Na0Kd9vmephWtfaPzPaPD/AOyQEx/bF2id3RcE tgev1969C0z4IeHrbGLHzmHJaT+I47qP/r16SiuiOfFZg/8Alz6HhX7SvhK1t5YmsoEhRkPmxoOD LGx6AeoxT/2cfHGiafC/9t6hBZnI8uWbgOH/ANr/AGjXPTjq+VeZ1LE+5+8l3h+J9L2Gs2d0obTL 23uYzws0LAgn6j0qzXY13PlEzyL9oS1b7HGygna+xh6rKnf8q+KPEFuqsdox3YDsc+lZVBQX+Rxm pSEjoAfSsIPg8ke3vW9I4ajZ1vhnxXNCy+XO8cikT2UynBimQ5G1v9k190eHdf0T4k6RJDrhiW8U fZtViYDNnqCD5JY488rIeevPI4PQb7epMlf9D4Q8VfDq90O5mt/FMTw3cZPlRjpcWbk7Xib+7MBk fkea49QQT8v+yD7V0evqjkg/5vRm7pC54zgdx65r0zwarIy71BPZ66V/wSpr/M9n8L3EiNwM9jns T7V6/o8wcDzRj+tZVERTO60VumOnQD2rpcVyVD1aAUVmdIUUAFYviDwFYaiuLyFQ/wDyyuAOVJ/v VpTnbYTR4r4p+DNxZEl4Fkj6xzKOCvuf9kV5xqXgzn92rDu49DXq3vrE4po5y70lk+8pHqfWqEtq y/cII/iHoagi/wDkRMp9s9Pz/wAKidH7Y/2T6VFu78y0xqXki9Rjtn0NaCXJI7e496j/AIcPmTKA e3PUe/1pWlI+8B759Papt/mV/wAMAVT6g9H9x9aieA/4fSkUiJgwHQkdMfX2qM28bdeOwH/1qTBM URqPvLj+6fUU17XPTKnrk98e1JFjEsD/AHsGpfsTDoTjqAOxpBFf5DXsCOx+vv8AWowZB3z3P1+l MEWYbw456+o9alOuSdCMjru9fqPagH5Ia16W+6SO30HvUU8isPmA9c+9K3+QIrfaiv3GyP4fpTlc Hrj13Urdgj5ksNwy+vuPStmGeCUf3W6H3z/hT9GNeY2a1dfvjcOm5R1+tVluHjOUY/7Q9PpSAvQe JWH+sx/iB7VpxX9rL93CnqV/z60yP6Qs1lA3+rJ9hVRtLb1Hrn2peo15lWWwkHRVx0yKrtpzH7uQ e5+lJmiKzWbjrj0I96rTae38K5J5OPUetJgym9o4+9n6+lVvLIPHPfB7D2o9RNdiWO92dY/b6Gry amjjgL6EGj0B+XoAuYz1RfUH0FLtiI5x/sj2psUSKWBP4Tjsw/vGoXjQfc/Eeh9qTKuVJQ3ce4Hr 9BUODnq2erfX2pkpCxyf3icdqlkiX+Ef/WNJehdiNScfN+A9PrUMpPY59cdxQBAxb+En0J9M0wSM Dxk/7PoKCUDXB+nt6j/69QOxGcc91B7fjQykNWVj1wPUUr7h0P8A+r/61Im3cAzHrk/4VDtIPT3z Qn/kNMWRQO5HoD6UyMHt/vf8BpMbf+SHeYvdSO+ac8Q7fTjuaVw/4ZEW1h7e3qKQpn+nvml/w4Ia bY+h9h6fWmlB7jv9TVX7Bf8AyI1Uj7x+h9fwo2Z68HsaQr9iMgHsP9o+9MKeh4+6+P8AClcVxuD3 AA7H0qKSMDoCO+fT/wDXQNrzEAPYnnrn/PamOoH3s5/pTuW/IbsU9M+p9qNme3Hc+9J+YIZIvoSP Yd/rSbTjj8vX8KUfP0GxpPufU0vPZsDoVHfP+FH/AAxF/wDgDGUHv9KPLx1FJlL/AIcQxofT1A96 AMdT/uketSSMK4zuJ+vuaFRccgnuKqxQFfUj0GP60LCP4jgdSB3+oqH5BfyFMAPfA64qLyl7Eg+l X6FAYyOuT6n1NN2EdCT7D0pfIXqPWMN9447geoHrSsg/gBx0+g96QeoLEo9PQe9I5J7j0yO9NIb8 l5jNmPTP8vxpNhHUn/Gj1J/pgUPYD0JPv71F5Y7hvQ47g0XK9B6xgdvxppI/vfU/4U7jv/kMJYdu Oo9qazEDnp94j3FT/wAMEV/kNEh/hz6g+n40oB9SfU+tL1F/wwmfp659KYD6n2x6/T6UxX7sd5QH YEdz600D+79Me3/1qRYDHY49M+9BQ9yT6n39quwn/wABBtz/AEFKZD2znox9v/r0Nf5g/JjTjt16 /hShh/dOO1T/AMMJ+bHNL/d+mD2Ht9ajLj0J7k+hPp9KSC3mRbyPvJn2/wAajyOef94H09qBpAG9 senvTd4PfnuR607d/QEvMYVz6etRkEdMe2KQX7DcEjofr6UoU+n+R/hSYEMrHHA9yfamqAf4R6UL /gB6+o/GegH19qX69OnH9aPQp/8AAABR0ApGUf3f/rGiwrkajn5Bnux+n+FOK4HPHYe9NMS/4cTY B1Huf/11XMwz0565FK40TqvHzD/d9zSmFfU+mPehBcURjvj3PvSPZxnuwPp65/wpWAq/2Wnr/wDr pWswPT2Pv9aaQmxq2ZB5IPoB/nvTjAR/Qe5pPyBj/s5HXaPamlD2z9Kv1D/hmNePP8I9Sff2o8pR 90H0H/16X/DDk/8AMNo/iB9BjvQIyep+g9RSt3F/w4bB/FjPUAdsUvJ6/Uj3+lL+kO//AAAIz1Jx 0J/wpqEds+n1qk/8yb+YoYZ5B/xpdwH/ALL70f8ADlL/AIAm3Pb6n6U7bjr16Ae/vU3/AMyfUUp9 R9O9KBxyg9B/9eqRov8AgiMpHXB9KUrnpge9T6EX7jQPb2B9aXa3br3Pp/8AqpteY79hxBHTHv7U 9XYd/cj/AAp27ja7CmbPX8KYVJ659M+n1qUJv/IRR6Eeg9sGnhfUgf5/rTuJf8OODL6fUHsfamll 9vpT+ZS8xpGf4RQEB68d/wAaT/4I1/ww0qB1AI9f/rUhVf4Qcdcegp+jJHlAB8oP0Hf6ijy89AR6 /WkxjliI6Yx1Jp4h/wD1/wCfWncXoOIHb649qUcdCD3we30p+oIa0oHQj6e1MJH8QHqfek/+CL19 SMyAdc+34+1Mb/65PvSHb/JCYP8AQj2H+FIAPYelF/IfKG33Hrj1pFf2yPT1przRXoNDDuD9B2U0 pY57eoHt/wDWoIuDH0UAfw+496Qc9s98e309qV/MfyG7SeoH90+1PKDvj3PqfpTD0GBcen1/+tRs 9Bge1TfuCEK4649QB6UjFT29j9f/AK1Ni9fUNoPX/P8A+qmg/T2I7EVQenoJt9B+PqaULx0Ue9Sw Xp5Cbc9fr/8AqpSg9PoPaj/hh38vITYR0/Ae1NI9vf8AyKEK4bAegA9vWlyo6gGj09R3Bh6Y9abs Pp9R6GmNeb8xAAPvDj19CKCv0/2vf8KkTfb1F2+nB/mKQH2/D0NNjEHt9SD605Qe2D359PrTJj/w RoHqMD/PSlyPTI9PfFT/AEhxECn09qMN/TNUmJ/8BgR6DHvTgPUZ/vf/AFqQ35IUj1AoCt36ensa L90FxCoHp/tD0NJkDoox0/Gm0HqvIAPTk98+lG3PXPoRUhb/ADBk/wAQDRsz2H+1QvMPkIU/DtTl jHfGfQ+lMP6QmzHQZpCpHXr2x60x2E3j+LPvSE46f5FSvMTEy3fp/MUmT7+n4CqXr5Cfr5CmI+3+ FBVvUfUUX7Dt2AD86TJHXB/xo+YW/wCCKW9MfT0pdvqf/r4pIBFBP07+34U3aD93/vqmJ/8ADDI2 9PqKvqB3z659a5JHRFm9oOpbDlhkfdYD0Neg2A+YEEAEHg9gwrhreh1x9Co2MnAHrj1Fcz4jlVJo CB0PlnPfe3b6U4f8Ez+XoerxKuf3YVv7mfXH9a+2fgLrkdxpUIiKZTdaTICPldXJ5A9c16GFas/v LrS0evY7rVPF2k2IzrWs2FkP4TcSKu7P90MRXB65+2X8LdOB/tX4laEpHzGKJ95P0SIN1ruUH2PD dXyZ88/Fb/god4K1UhPBHhq81uYAx22q3aFIoGc/wq3JwB3C8Hjnp5R4b0v+0ZFGpyiVyTNKSAFT cedq9gAa6qNOxi6knpJ6fZR78+peJtERH+EeivqWxg+rWCKSt7ZkHcZVBGMnHOeO1dv8Bf2yZPGc 11Hf+G49HmgOEtPM3Myq2D5pIX/Vt/sinUh/mzejF/b86kfQ7f4y6Z52nS/LnaVuD7BXH8s18K+L IcSHBI9/UnNebNFR338zgb6HcDnJ7EViPHGMfMc9HAH3fx962p+Rw1GSA/8APNj6gehHvXqnwq+P t7oVws2mr5uMQazY5x9tsieQCe4HIyRzjkU2v+CFz6h+N3wV0zx9pqXXgTy7m/RTd6My8HUIVBzF ICRh0bIGeh4PqPgJhyQyFWUmC5iIwYp4zgh1PQxsCCO3et4P8NGck1rstfeRq6Nnd198+v4ewr0j wyW3jjJ6J7cf4V0xX+RbX+Z7NoEjK3zIV7hT2FewaI4IH6g9qyqrt6EUjvNHHTmulzXJM9WiFFZn QFFABRQAyW2jkBE8aup4dGHUfSvN/FPwNVwW0MAfxG1PbP8AcNdNCpb4jOcTxHX/AAbPCSJ4pFYf eBB4PtXKzacVPIz3Oew+tek12OJopT6YR/qxn1J7/Q1Ue1weQwPQ1g12GvMqtZk5yMex7kVGqyL/ ABN6EehpSQ7d/U1bRz/dx2B9B71Zdoz2HqM+lZepoRGI9xx1yOx+lBIbt7D6ewoYXI+B93ntuNRM npj/AOvSZVu/oIAD95SD60qyBOJRuHVW9D71Fhp9vQmW2Vvuk57e5+vtQIWHU4PUn3p3C/8AmIUb 39T9KhkgOfl/4EB7+1C8/UbX8rAQjsPbHpSNCP7hJ65pFX7EX2Zj90YpFhfkEA+n4elAepVeF0J3 Z9APQe1IpPbGOuB3qfQVixGOeV47Y9T61NHIynq3pgU7DuaserMPcdMHuKSXy3+7Hg9GXPU0WFbz KpQfxqfQfSgrj/VEe49afp6gy7b6qB97Pv8AX2q/Hfg9Dn09qGDEaYnoB6kehqOQv/Co/D1FH/DC SKRuiD80Qz1L+v1pY7xFzvUeg9/p9Kmw0RzQQOPl2g9c+v1rNm05R9wZPt6e1DBehVk04AcjPsfS qMtqVPHHf/8AVSKX/BEW4b1I9aa1w3YnHYnsaLeYvUf9rP8Aeyew9P8A9dNa7/vZA6fhSJuO+0Kf ut7Kf9n2+tDFW/jOeg/GmVcjZiDggf59aFmyeTj19zR8h3/yF80Z6t6Njv8A/qpCmDwF9N3fH19q aEvNDFtQPvMzZ5LH+lRT2X9w896P+GFfzIvszfxFc9PqabJYHs31PqTUX/yLuQNaEDnOfT2pQn90 Z9c9h9abX+aE2PNsfUj/AOt/jUfl+v0/4FU2/wAxrz9Brwg/eI+vvR5Xrg/wrjuKpgJ5YH8IPbPo fangD29cjvSYJ9/VDWA7dO2e1MGP4tvuPf60J+XkFxm7PVivoPUCmyFTzsx649R7UCfmM2gdQD3+ p9qi2j09z+FJ+o7f5kbAn72PYD0phUj7uR6+9FhMY49PxqN3z1HsSfQelDBjcH2x1z6fQUyR89OO /PoP8aheTKt5i4Pr7E+tNwO2PUinbuA3Psfp6Yo8zH8Off1oT/yBCOpH8jQsYHt7etHqVcTb/e57 ke9JsHbntj/PpUtkjDgfeHP8jTmj9Qvqc96odu/oxrAY6cf1prEDG7OOoHox9aRV+wjKR90YPQn1 P1puz/az2IHehCT/AMxu31x64pM+uPYUv+GGAYHH3sdCPTNIVH8I+nsKYvn6E3lY+8nPQn3+lNdC Og/2SfUCpsNIUD+5gd2z6e1MRQf4OOw9D70/mMcY/Uj1wP8ACjygOufUewHtSYR8vVjXiz1z6/lS eSB/Cc9MH39qoQOBjjr0AFV2X1Xj29an/hwfkIsZP3iM/wAPv/8AqprAH69c+4FJ+ofPyGEf3c+3 vQoHdiOxA7GmCYxwT936nHejH/1ge1F/8wYE+xHb8DQR7Y9Md/8A9dP19A9QG3+Iexz3NK4HbA7f UUX8/IP+GQ0kD+eaQuPw9af/AAw0hmCe4I6j3B9KVSfXHr7H2FTcXqxGkHYD6+h9qYZT3J+tAJEZ x+PWkOD069T7j/69IExCV7fp60zaD2Prz2+lFv8AMbXb0EAx936596Yyeo/2hj/CkCGHPdiOykU8 Aeg/2T6imNDWfPQj+6R6EetM2KOgHqCPWkl/mFxef7oI/i+vsKUADoCOxz6mmifn5gY/THofak2j +L8jRLy9B2E2jsSPf/PrSb89Ppz2pWGxoA759KasH0x1z70fIleXzFAI747UZx1wR6+1Aw8xuxz3 A9h/gKC4PRh6j2//AF0DAuCOAM9M+o96jwe49s0E/wDDsMemR2/D3pCPc+3v9KE+6KXmw47/AFA9 RTVYY+VAT3B9frTXqH/Djtx7E+gHp/8AqpvAHf8AwpFXGgD056n60KxPU+/FIleXoN2n6HvTmB7c Hrn1x/hQH/DifN/Fz6n/AApQoH3R759c+tU/IVvIQqT6gdCKBgdc/wCApevyG/Uflff2pNme31Pu KQMXZj7ufU5o80HHT1IH+NUK3+YMB6fT2oP4+hA7mlfuOwu4dgc+vpSFiB8ufWmxihfT8vU0gI7/ AEJpIF5gT/8AFDHp9adub/H8KbXmAiZP8J/3qeEPc8f1FSkSmCoPX2xSBB3A9KoY/wDAe59KTYB6 nuTSt5jkKI/9gkdvpTeD936N/vU7dwHgEjjj0NPRc9ckd/qKQkxVUDqQPUDvSMwPQU/QoQ89CPQ4 qPee2fY+op+pL/4A0sP6k0ws38Of/wBXtUX7+grDQfr+Pb60hU/wZI65Pancr0Ymfw759/akIPbG ew/+vTv5eYte4uR6lT2I9fakKn+I47YNIaYgXHc+i/SnKfT/AIEB60XfUEIWPcZ/oaB9f/rfhSY/ 6QmR6/X2NNJb+7x/Wn6kv08gEmOgIPf/AGRRuB6bsfyot39QuBY+3p9frRn0z7e1DK9RoDDoB7Y7 mmlSO1BLXkOC+n1+gpNufvD3x60evoNPswwO34D0pFU9voTRzdx+jG7j+PTHr+PtTtufr1z6j60w T/4AhHt759KaQOw+v/66Eu3qQ/Id5f09/rRtGe/rn2qS2IP936++aMkdCfT6fjTfkK4gBxwPbJ7m lxnqOf5fWiwmAQenvu9KULjowP8Ae+lNFf8ADiMM/wAsetBB7/r2NFhLyF2nsM9j7UAD096X/DDD Zn+g9T70pOPT3PqaEL/hxMj+IEikYeik9x9fepXmK3mKE9FB7k/59KAg/wATVoq/+QgHtj+tAOOu fpSJ+fkKWH17GkYgdR/s59TQO4gb1oYe/t9KH/wwfMZjHU+4HrmjI9/r6UA2IDj7r/n6n2o2emT3 B9aH6Db7eguD357DNIQR15/pRYX9MFX+9+VJsH9FHt70/wDhikhMAevsPalCe2f6ULyJHeWO4Ge4 9qTCnr+BphYU89MfT3+lJj0OPWkD/wCGKkTHuR7itNWJHy59/Y471xyN15nReEUSQnzVUnrt9R/9 au5gyrL5UjAfwn2PrXHVOuPn6MbPAATwMfwn1HtXIeM9yrGd2MOrKfYt2pU/Uif/AAT1GCdWVdh7 AKf73/6657xlBqyWp/sTWdTsDvBvzZysnmK3/PQqR14rpwN7+62LFR02L/ws8a6HZwsLvRotR1A5 hvdTvmZmTcMYBYn7q+/qep44fxf8KneZ5dI06N4mPnXe1f8AVTOeSqD+8a+gT7t92eBPfTT7Ni/p 3hH7PGN64kPzui/wH0P1r6V+F3wlsWjjHiFmt5bjMWjqBy0EY+ZlX/Zz3pzlpodeBgm/L4UfXHhP 4fabosCxaLCyxjl5HJJmkJ6ux9/yrwD4Tfs2R2niHVLiHX/L2ThoNNh25+z6hEGxOgJIBHTgZ7cV hTqbuXqzrc1zXlHukj3fx9p5msbhVGcoTj/d5/pXwL43jKSEBABjIz2zXNJaHDfU8/ltmweAT/IC uank9Rj1I7/hWtNdjiqiRXBHRSewz61ZtJ3jbkAY4Of4s/4VbXdkxXc+if2f/wBqRfD8wj1q4b+y ZTsvZD00i6PR254VjgHg+p4GR1H7Vn7KkY3ah4OtYzGQJ/F8MOMCMD/XAjqCMZ9OvTOHB9/QzrR0 06a/I+XNMiJPyEHuAPWvTvB0LlxuKjHzHPcA+9dkf+GM0z2G2XEgZDwRtX3X2Fem+H704G4//WqK iM4f8E9K0STIFdKtcMj16ItFQdIUUAFFABRQBja54F0+/U/aoFD/AMEwHQ/7VeHeMvgpeWeSIRJF 1SVRwR74HavRw9TpJ+hhUh2PNbnSJI/voeOCD2qm9iCPujPXPrj3rokuxyp9ym9jjrF/n61Xk01v TA659/8A69YspPuRrE69sHquO+PSnrdf319s+gqbFolS5XsxA9KCufut/u1AN/5ifZn7Ln29MjtV co/cOvbI7CkP0+Y3zG9Aff2pV3Hqnv8A5+tD9fMr09BCpX7hPsB2qx5+RycH2pP/AIIf8MBkI7E9 s0ol/vH2Pv8AWpSGl/kNKjPyj/6+KVoz2OD0z6CgbHDA9G7c9hUTRr/9b3+tJ+XoNEUkRPD4/u59 ai/skj/Uknsy/Skl/wAEE/PzBdw++CvY+/PrTxOD6E9GNOw0v8yVZfUfj6VaVw3Qgdjj1pL/AIAP /giSMO2fYHtVbzQOn0HtQ/L0EP8AOUdevr6VJFeFerf7o9hQgv8A5F6K8LDnHv8AT6VK5J7D1PsP pTYepXliP8OM/wCe1UJomzxjPUn1NJf8Ab9Cp5zjoT9D3x/hSi4bnAX2x60w9PUjySeT9Qf4jimm zdv+WY9WPoPakD9fIgk0d8fxAdA3vVc6Ux+7n3H09qPQGRNYMemeOv8A9aomtpFPMY/u5P8AU+1H qC8hpsz/AA5PYr2z/wDXpzWxB5LehHof/rUkyhpjK9Bnsx/z6VG8WeVAJ6Z9BTQvQcJ2H3voB/hT vtOPuAk/xD0FFgY5Zs/wj3B7H2okk47DsT7VIP08hmFP3jg9yKilDZ+XPr+FNenoMiZGPQ+7H0NM EjDqD7DH86Lg2HnsO2T0x60hdj94e5FBNhnmn0/D1FMkkJ+4MD72f8KlDt5+gwzE9c+/0p6Sj+hI oHbuDTqvQk/3gf4T7Uwvnpz3U+1L0K+Q1nB+9j2Pt/8AXqMlR/GfQD3NOwrgdvYn0J9KiJ+uOgx3 PvSD5+RE4Gecjtj1/CmE5659QPSmyPUTPufc+gNREA9fxpIq4D3YY6n3IpgKnoP/AK9L0G1/kBRR 1z/sgdwf8KilBHQZPTHr9aBscU55A9D7H2pA3rk/5/pUib/yEcj1H0pu71bd7HuPr7UDYhI9c+57 f/qpoUjqffj0/wDrVS8xBuH90H/E+9Jj+9mhlpACvY+4HoaaM9zk9cH0o9CW+wxn+vqcdj9KUc9R +P8AjSHcQxE9FGepNKISe2fXPYUv6Q/T0JpY1HQDHr6/SmBF75H09f8A69STYNjH+MAdS3uPf3pI 2Hckin/w4r+Y1wM/MvHYep96dGg9/T8T6Ur/AORYu4Z6fX60uevH4elMIjfKI+8c/wB0Dv8AWkYL /ApA6Hnp/wDroQiJ4j+HqO1RtgdGz23eoPt70vRAvMQ7B1J9MEen+NMZMdcj29RT+SCyI2jHYn1x 6j/61MZR2/yaT8xjSP7pwe+O1KAT1APY/X60ADDPXj0pwVvb1J9aPmP/AIYTce5z2I/xppb1wfQ/ X29qEF+/qN2KRzn6eo96GJ7sf/rf/WpWKRCB+Xp70DGflP4+/wD9eqI5e/qHmnsuP/ZqayDHXPYe wpB/TGkAdvcUhQ98Z6gjsPeheb8wt/mIwA7fX3NIVz94Y7D2/wD1Uy15+ozHoPYe2Pf3ppT/AOua RFhGQc4AJ6Y9P/1UmSPvLn+E/T6UvmN+QhCj7qD/AGfenbCvUe+fU/8A1qGg9BOPf1OPWlx/ez6E mj/hx3AgHtj1b/Go9o9SfU+tDYgGe/Pp7D3pCvsB7etFvMP+HE2Y/h/CnY9EC+o9R70/UEuw1gMc Ae2aj8o/xH/dx/WkUhpQn7wOe59qQREdfw9sUX/4AevoKo9cf407YT/EcdAPQ0vT1FcbjH3s46Cl wO3P17mqJ/4caxHdR7n1FNwR0Hv+FTb/ACGN8w/wqf8ACk3Y65PqKpL/ACGvNjjnv17/AP16QEdl 9zjsfpU/8MP/AIYN+euPT/JoKn+FR+NH9IX9IGOO49SD2NJg9sfT1/GmL/hgYY6DHrilPt+Oe5qQ t2FbH07EDt/+qkPHUk9sfX/CmkO/+Y5VY9+O49BTQp9QB3p/0ybf5C7z6+w+lISfT2J+tIYv+6T/ AIim+Ww9f/rUNjHbvTPv9aUg++PX3FP/AIcVv8hUU9lH19D9KMn1J7n6+woYJ/5jguevX+Rpceo4 9P8AGixXyBmIHy9ehPv9aViB1+p9zQK/YFGOgNByO2ff0FJeYMQI3vTwo7n/APXVf0wDHrjHTI7U g478dAR3osJeYol9/b8aZux7diKT/wCCWvUaSff6+1N3Z9f/AK3tQhIHQ+uB1BPemkjHJ/Kh+gkC Be3H8IJ7/WgEdwPpU2D/AIYNueoH4elN2D0PpR/wxVwIA6Choj3Ax1P1oJQh568Hpn0o8vPUn1UD v9apob8mCjHbPcn3phU54/AnvTJFMOOoB9vejyz3+mPaoKA27eme/wCFL5bdl/H3NU3/AJAhBH6M 3ufQ+xpTEPX8KTQ/UNp9cdvwFNC/3QPfPp7Uxt/8AQxf3VHpgdqaB/8AXo9SLdw2DvjPQ0jIR0IP f6Urf5gh2T2Ue3tTAPqPb1FHzBieXn270CI9hx1NP/hg9EKI/rQqkdRz0K+goHcUEjr07fjSA468 9z7fjUjBB/t/X3P0pCB2BH07/WmhMQD+9n1H0/8Ar0u3jgDPXNFw9BQMdPoPxpQinqx+nqfei/8A kO3mJuA9fb3pfMH1/oPakFxN57AY6/5FIcdvrkdqYn/wABPcH/CjJH8R/wBrHeiweggA7j6j3pQx HTP+1TTEgKseufb8Pajbn7xHqv8An3qblr/gDdpPUn0+o9qCvvx1FP5E28w57ADsD/jSEH+Nie5+ tH/DhYb5eOuMdj65pwUdh7Z96BxfcZsP8Kn1z7Uqk9xjvzV2/wAwt5C7QaBH9T/eNZiuAUd8+309 qPK9fzpj9BdvqB/sj1Ht9KQnHQj0we1XYljSwHVc/wCPtSFx/dx6D0qbefmO/YBL6cdsn+IU0sT1 A9ce1AehDGlXYlJHJP19B/8AWrkl/wAA3S/zZt+FnYSfKSeOcdvpXdKzKRjHXGPf6e9cVU6oIu3Q AbgHHQCuW8bW5aDKqeCrD8G7VFJd/Qmfkd9orM8EZJB4wT6Ae1e4fBXXfhbAJl+IFxYrdsVltxqS ny3tFX/l3YjGVY857Yx3x04R66PyRtVla/KvQ8Z/alfwBZ31tJ8FpbFXZJP+EwjsG/dOS42GKPJG 5cvnAAxjHTA5/wCHfiu6dJX1ic7MBLW2P8cjA9fy/wAK96Hr5M+ZrSWrd/L1Ow+GXgRtcv41mVoo cmWc5HMcaknO7HQCvSJPF80viBWsLC4ttLixpvh2PB2lIyMsGYc+e+cE9sYqar1+Wh7GTRV1d/32 fZ9tOHUEZ5Gef618k/AXxZcat4p1aa4YAb30+GOMHAtrLYi+YfUog/HoBSoR3u+j/Jkpe9r/AHmf V2rW/mQyDGcoyAepKGvz9+IcQ3KWBBIKv7kev41izhe+p50q8nOCOg9h71y+qWjBvk4/vH3z/DWl N9jgrf8AAINzD73J7H2FJhiDnP19D/8AWqwt5+Ra07UCh5Pynh1PcV9i/szftKxuq2Pi2ZZYSPI8 N3M3IaNgcxTFuxHT06dMYU4/5opefoeafHP9mCTwpd+ZokZ/smZ/MsCef7NvJCSYx7dx2x06YHN6 KWEgw3HU47g11wkcdu/oexWUaNg5IP3lX0B969D0SQjGAMdSfU0S8yYnqOhSH/61dWh4rimetRHU VkdQUUAFFABRQAU2SBHGJY1dTwyMOCPcGmn2A828ZfAeC4y2kJhus1r/AHx/0z+leO6j8OriLP7k +hI9vUY7V6tKpda+jOSpEw5tBkX70bZ65x2qp/ZZ7/l6UGViB9OX+JQD29qjbRE7jju3vWb8irld 9BPO1xjsPaq7aWw+4T6H2JqPkaIjQSg98joT61KLiTPOB6n3+lDYriyOB96JP94dx70blPRV9Prj 1qL/APAKS/zIh8p9B3+vvViO0V/usAeoFHoBLFGo4kUZ6fWp20mDPzKR2JHfj1pIr5itpCD/AFTZ HTnuarSacPUehoD/AIYrS2zr90fh9PaoSjnqBjpij5i9BPsrdvpj1qQZH3wB7jvUocV3JlUOOY1Y dR+H+FU30tf4Mj/Z9TS/plLyK8ltPnhQR0IPpSgOn8LD3/un3+tCD1+RM1wR1Bx/KkL47gjrk+tM TAyeh/D2qQIjHrjuM9hmlcZYRQOhH09q04pV/iAPYg9qLdwHNaq3QD0/D/61QPpYPQgf+zVSX+Yf 8MUJ9FP8IP19/aqJ0SVTy3tgdqQWHtprf3lB64NQtNKn3eB2PqKlMTXYgN9Ieuf8Kje5Pfdnuff3 p+nqUl39CFp27AEenv8AWkOoDoy8dWx60vmL09Bsd0o+5GGHRs9uPSo5CD3OepHtRb/IE+xE7k/e I9Bj096hWQ/w5I65/wDr07+Rcl3ZGWB++CO+fQe1Izbfu5pW7krzFL9MYB/i9x7mnmZudzD2HqBQ hMj2n+EEdwvripUz/Euf65oD/hxsjk9FA9RUTuo659x6MaaRV+/qMD/3Y/fd6gUCYD7yj39zUvzY mv8AJkTTg9RgdMe49qY0i9hu9D6H6UmK3/AI85PQ+9KCoPJPrj1/Gn8xp9wlw3XI7cdzTM46E46A HtmkyhHA+vt6VG/bGB3P1zQ3/mSkMLZ6Ek9T9aYZh3/H2+tSUN3g9x6YPemqSeh56H6e9P8A4YSG M2TwpHvTGHqOfu/UGnbt6AMZR36dR9aR5P7o+pqLeZXoN3t6j1NISR65/u/3h7mh+XzD5+RGGPf6 Ee9BkPZfqff/AOvQ/L0EIGXnr6j3JpMEdBz3H+FJgkNB/wD1+lBTPYntn0H/ANem/wDgDX/AEznt 9DQGz7f1xQ2HoI34e9GMdB9R7ewpRAhkU+p9seh9aeiH0z/CR6H3qm+/oP5koUDqcevuTSiQjoue CQT3/GofkNMYxPc59QOx+vtTWJHQD6+v0oJTG4IHYnoM98+1PLMO231FBX/DgSD3wfX3p4fjjP8A h/8ArpNf5gKG9SR/ED9KRRn7zYPTPqKdw+fkHmEfXvj19hUIcHocfxAn2pX8hNhtHbHuf8KhKnsp +noB607Dv/kRNKP89zTWc9gSeufQUv8Ahhgzg9vY+5phHoSO2PTFACBcdOvUkdv/ANdNyR0IHr70 LzEhwIxyDntTwoPcnsR7j3p+nqF/+CIcd1x2NRNGewx6n2pWGIfbPv7CmsnsPQihC+Y3aPXj0pOn QCkxoHx7+oFRMPQ5789qfqJjgR/THoPb6Ubl7Z9gO5NJ+Q/+GI3GO/P8hTCjDqQD1BHp/wDXpi9P QRiT1OP7o9RSfgB7CgBSvqCD0z6U35h1GfQ+3vSaH6AB/eXJ6L/n2pWT+9+VC/4ABsx/gaQ89cY7 j1pthfyGM3oM/wBBSEH6/wAWT2FJ+Yv+HHIAP/ZhTHQHpn3FBS/4I7aB0Pv9D75prE9uvceo+tF+ 5LYhjT+8x9fajj/lmMDrz6mlYd/Mbhj0/H2oB9+e+Pem0OJGVH9aUA/xEnuPpQD8mIz/AOIPp9ab uPce+B3p3ENLeuT2I9D70oH1x/I0mDff5iF8dOvY+v400knqB7++KEJv/ICOO3v7imqjfT09xRYY oQd8emKUA/3iO+fakJAqg9fxpMdMHj2707d2X/w4YHqCOrH2+lLnPbjt7UIlP/IQHPXnsD6/WnYH 8QHPQegpejGv+HDJHUgHoB6ClMfqD9RR8/MPQasYHYe59zQyHvgd+f8APekUxVyei/8A6qVl9c+o HpR6EJ/5jjGR0H1+lNKA/e6ds96f/DFMcUH8X4e+adtA7Z+vrQSv+CG71yO/H+NKMDufT8aZX/Di ZHcn3FISD0yKQhQ57k+gFJuI7e2KEMkBH8ZPoF96CvHAI7mgEvMTZ6fh70m4D0HvTuDQh/2efT6U hA/j/P1/Ckwdv8xmcHgnPb6Cl3H+6M9cnsBT+Q0+wgT6+w9DShAOuc9Vx60rj9Q2ep49KYUA6A/Q ehPrQ3/kJ+YpX2H/ANb/AOtRsPbg+v8AhTEGAfujJ6ilKkdB7ZHb8KT9fULeYuzA557AelAhPY/U ehFL/hhD1tSeqgdvwFO8gDuT2+n41ZTY1oAPukA+v1pgUdufT6CpJGhh2yD39xSKcfeAPfFO3f0A VmP8IA9PpTOD1PsRQvMp+bGs5P3to9x6fShiB/PjuaVv+AFhrMf4Mf40hVu4HvQxP/hhcHv+XpSb ff6D6e9CBiHP933I9fpSux9Pofb3oY7iYHqT3A9B/wDWpdh9/XFAhpdj1GewPoKEwOmc9WIofl8x Lz9BSB/EQO4/z70gUjtjscd/qKPUoCo7fiaFGBzn0BFJCv8A5jCF7c98ntS4PpxTQr9gOf4VJHb2 NBLf3frR/wAMNMTeewx6UuB2z6qaEhf8MAAP880gDdsDtn+8P/rUD9B23HQA96RmHb649QKGxW8x VjJ6L7/Sgp+XX60PyD/hmLuPc47g+1Ax2Ptn1osC8xFVe5Oen0//AF0eWB6+g+lO4f8ADi8dufQe lM5Pb3Iof/AHfsNwOw/+v9KcE/8Arj1FJoQAD3HtS7M9SfYelNFX7CMB/wDX9KXcO5B+lAv+HIzL 6DHYCkMxHXjucevtR8x3ELE9cjsDTcen5nvSuT6hj3/4DRgHqD7GmyvmJtPfn0FBUdwc9QR6UC/4 ciiTngD6fhVm2c4OT7Z+tcjZskbnhmRlkG3PcH3GK7tkyMopJzgD1H/1q46p1x23L95wRgjoGGO3 +TXO+K4g9u4yccSHH8JT0NZQM5/8OdR4Rm821iIct8uHHpz/AFqDxP4RS/glzcCHaMuT/Egb+pqo PX5m9bZ3fmeP6d4VAcb9pHG6QfxKPU+4r0HV9Wt0WMaFZ+QB+7ucNkXLseuCOOMfj+Q+kjI+fqQ6 W82b+pazrzkWfg0zRXrD7T4kubfk2kEfIBcd1xzzgfxV13wv+J/jNJ1j1R01O3yFea5ADQYPWOTA 7fp+FPnj9pLujvwNCV7rvp6I/Q3RLkPEhBzx19c+lfHH7N3x20zQ9X1Cy8bWFrYX0t1LJYasSMPc ea37uRz/AM9M5HTng+omhs7Ptb8QrO0n84/kfau0dxnsfcV8CfE/SvKYgpjDvFk9lDn+fFY/1+Zw zPHJbkITgn6j09qxtQlDnhsjqo9K0gcdVFJGPoPQGnAH1I7MfX6VVxL/AIJHA3PTHpmtbTdc8pgJ GdVyJLeVTgwzKeDHIOhVuQRyDWnqJM+6/hJ8YNN8cWMln49Ec92F8qWQnB1K2XpJER0eDgnGPUdw PC/EPwjvvD140OojzFBMmm3Q4+1WLscEqO+OCeOfTpRRf/ySMq0ev/brOx0qeMkbVx6A9hj+teka Ev8AeOP7n0raXr5GUf8AgnpmgXH/ANauwhbIrjmj06DJKKyOwKKACigAooAKKACsfVvBVpd53II3 PO8fxN/tD3rSErbfMTXc8t8V/DG8tgTDYecnXenof71ea30TLkNp8kR6E46cV6kUn8LOScTCl3D7 yfj601bpR1AHsfWokjMcbuL2B9Paq7CNuhGeuPrWZTID5fcge5qCYp/Ac+h9akd+5Sct2JJ71Hhx 0H0NQ2VH/gg0jn+H8PUf/Wp8Ezjop9QaTf8AmaevyNQJvGdwz15qe3mBHzgHtj1+v1pXBLt6j2tH /wCWJDeo9Kqukn8ec96YPy9SGSGQfcA9efU1XeFx7Z7Uv+GHbsgSQ46kn+I+lAQnp9B7AelK/kFh fKZR8p56g+lDSnuAe59hTaKuG7PTB7Y9KT7GzfdC5+8wPoKVu5JG0RJ+79fYD0qjKrDscf56/WlY r5eRAJ27Z9Dn1qQK3bIPf2NK3mO3+bJ1uJh/Cp7HPoKtx6sw+8o9h/8AXp3J9fkTrrGfft9PpT/7 XHdj6D2ouRbv8iN9YcdWI7jHb8arf2k56gH39Kb9fUpL/MrPfN6Z9/QU6OVH+8g9s9qLCS8ywIIF 6BT2II6MfSkksrdh8gQdiP734UreZV/8hg0uEfwqD396rtpsYzuRfqP60f8ADBcjXS4e3HfafX2p f7Otsc5yevutDXYXyIJNNhHc+gx/EKhfSE/gYnvij1G339SA6b6HPqD6/T2qOTS2BzuX0A9T9aL9 xp9wOlIRwg9ePWmf2eD2I7Z9RSa8/MV+xJ/ZwA+V/qfUU42Bxw/uc/1qUHqQG2K9FDDoR6NUDxn+ 6D6+2fQ1aH8iBlPYewPoR7VGWH8QOehI9PrSEn5+YkjJ2yOwPrUZjH8Byf4vpUtFtkRBHQ47UhOO hPp9CR/Sm/QVu4hlYDvnqD600tke/r6VNyr9l5DSjAckjP6f/qoEfr9Qaq/+RC9SMoD0Jz14pgjU febnoR61CKDyx9P7ue9Rs5HUkH7v1HvTE/IQuR29vpTGYjoT7e+P8alBfsN3/wB/6nA7+1IT1yOO oU+lUPmG7sdV46n3Ioz9c9/c+wpfMafcZtI6gepA9v8AGkZR3H4eppW7gN2n8emB2z/hSZx/F/8A X+lKwgJJ6jH94U109Fx/dPvVPyHccIv93/8AXSYB6jHoP731qLDGNB6qMdzSFfUHHr6VSYmhrR4z xj/P9KA57D8PUUvUPVBu9Tn6e1LknoeO4ppD9PVhgHoDnp/wL/69BJA+8c9vap+QhjH2z/WlDEdV 9hjtn1+tO3cYgbJ5QU9M9wfoPSp+Yv8Ahxdx7Y9/b/8AXSZ9uexpJdgv5eYm8+4PQGmLFjqcnpn1 z6Cq+Q7eYhIHQE+oPr/9aopHHb8WHc//AF6f/DDIcjuKcVHr7ED1Poamwf8ADjNpP3mJ7j2x70KF PRsdvx+vvT/4cL935Dtm327E+v0phiBxuGe/0I9an/hwa7AOP4fYe2P8aCMfdPv9B9femgX/AAGK Dn7w46n60qqe5GP50WGvIQpjqePT3qFvYH1A/wDr0JCZCq+qgdyT6/8A16Aw7g/jSQIZuz0/GkYA 9Fwe3ufen/ww/wDhgJ+nofxppbHQexPvSQP/AIImD3xnrn1Wmhl/hBHfPrTJv3E2A9cj+770deg9 2PuPehsfp6gI/TGerGnYGe/+BFK5f/DAUPfA7gjtTGB7knuaE/8AIh+Q4gHv/u/Wo/19aGV6eoYA 6Zz149PekIJ7H2+lJPuL+mMAJ6/8CNKNo9/Q+g9qdhMM5PUmmn2BP+FHyG2MKk9AR7Hv+NIF9Vx6 D0NP0Cwu8difc+uaXIHTnsT6ipH6CeWB2pjZ+v8AhQL0GEepJHXHoPagDJ4H0PrTBsQn1P5+9ICR 3x2ApS9At3EY46Y9hSc+v+TVIP6Qm8H+E567vpRsP+FSH/DjgB3INAHr9R7Gl6/If9Ibu+uemfal ZT6AdjiqYeoYHofT/wDX9aXyh/Fx6getTcLChD6YHUn3oyPUjucevtVW7C+YA57D6ntRuI/lQx/8 OKW9CD9e1BA9P90etK42+wBR7e49f/1Uuwjuf/r015ABJPXj1P0ozn7xz9f7v/1qQkBz2Ueuf/rU ob6+gpvy+YvQXcR7d8j0FHl56/8A66E/8x3Ewe4PuaNoHTHuP8+lJ+Qn5eopJoJB9fpTLXoKGHYY 7dP6U7afUH1z3pMl+Qwj+9x/d/GkKk9F9/wo+Ywx7D1U+lGz/DFDJXoAQD73HtQMHoPoaPn5lf0g 2D0Hp9fwo8s/xEDtz2NMGgKY6YP94+3tQfb86X/Dh/ww3ee4HsD3/wD10CT1OT2HtQ15+Qeou4D7 n0J9zSA+/wBB/wDXp+pPp8hQB2OaejAdQD/Wkyh5ul7DHb6monlP8IU9yD3Bql5it/kR7vYD0HpS Mufutj/Af40hiADPIHp9PoaCvoPbNHzCwm4+nsTSEg9F+p9KPn5ibDaD7n0pMDv9B7//AKqTZXqN Bz0A9Mn0NLs9R+A9Md6q3mTcQNn7oHqW9fw9qdgfxEe+O9SNeY0A/wAP+QKQq2eMe59RQxDip9Mf T0FNCk/T+ZoHbsxxU9j/AL2PT3pvPfB7A+v1+lH/AA5VxCoB5BPcH1NHmZ+8GHbI9ff607Ev/hxD nHXjpzSBB6n6ep+tMb8xQT2/HHY04/T2z61L8hX8hNuO59l9B9fejb6ZHfmh/wDBBIQ+4ApsY9c+ uPUUXAdtH8OB/hQqD+8c9Avv9aYwYZ659M07YPTHofWgPQAG9x3A9T7mgjPXP19RR6A/MQgdx/sj 3HvTQuOgx2z9KL9yBQg/2vf60qR+gz2Hv+NFyhfIB7Af5/rSCJh6fT0FL1E35CBQP5gUoYH09Oab YL/gjGkz1/L6e9IXH+H0+tBaXmR7yP8A4k/40i5HT/IobJTBVPb6U7YPQcfLx/WkCXkJsJ9cdM+n 4UmwDoM+hpgl3EVM/j3p4iJ6Ak+vpQNIQw569en0pfLYD5gPbHpR/wAMKxVifB+XPofoRUittzke 49hXKbf8Mbfh99silTj0Hsa9GDY/hPuD2I9TXFVX+R1wLVxF905xxgD+9k/0rL1izLROMA5BBB9M VhH/AIApxLfw5uVezTcOhMeB6Z71s6qnySjazFkKxKP4mxxuPtW1OPvfM1qLTRdLEvwi/Y78W+I4 Xk02zihtwClvc3J2i6uQD8trnqVIGf4QeCRzjxfU9RvIJGS6MiNG72u3+5NE5BwPYivoq6Sfu+jP MxEbO3lzS8jvfg38X9d0O+36E0MskqmwmacfdSUjlB04xjp+tdzrcc1tdLul8pg48wqcBssO3vXm 1ZO6ufS5VDR3X9xen9M/QDwFqHnWkZ/2Rk+vH9a+bP2tP2MW1MnUPB8D/bUUN4osohzqFrbpxJEB /HbjHIGSOuR076ErPX0Z87mS95273PS/2Vfi82u6RH9u1V7q8gP9lass334gigr5wPZ1PB7/AFBr xL44WKpd3CovyiQuqn0f/wCvRV68r80cle11y+p886hGRnGD2A96w54mxweepI7H2PtRT/4B59ZF SMkfT7w+tTTE7fvY9APT/wCvVtdkQkQxJ6sT6D+6P/r0XEBB6kdx7fQ1tFDl6+R2Pgb4gahp8qPo +oNbXcZE9lORw7Kfuyr3WTofbpX3PJ/ZPxH0xXsVWy1SLmJc86bqYHKtyMpc44zjPsRxlLQUlp+K 9TxfSI5onK3sLRyoTb3MbdUlQ87voa9S0W4DJ8oGe/sRXTI5Is9G8OScDdnPQ13VueK46h6dAlor E7QooAKKACigAooAKKAAqD1AI6EHuD6j3rj/ABD8HrG8ybUiCTqw7Mfp7VvSqW/UlrueT+IvhHd2 h+e1kI/hkAyCfZq4m48KzLnER9WOP5mvSuvsnHKPdmVPpxHVR6k1SfTyOjE+nsKxBsY2lk9JQT79 /rVea1kU9R/tEdj7Vm0Uiu6v/CT6Ypu5x6Efy+lIGuwC9deqg9uewPpU8Um77qH6en1+lQ35Fxf+ RYWCQfdTHr9Kt2SvnBiPqD6gUgXr5M1TbhOqgDt/+qq9y6jpFn3HqPWkU329CqzEfdU49T6//Xqv JfofvQge+OtH/DAirLPGPvIB3B9PxqAXUX8bgDpkdvp9aLjROLyFh97PoPaoPNT1X0Pt9TQwD7TG Oh9h9frTHvlB+8D6MO9L5gl/kRG+A6HPf6CpGuoXx5o47n0PsKdxRX+TK5iiHRuPQ1YghjH3SD/g PWpsXck+zJ2we7D2pWgix8oA9cdj/wDXpokZ5CdmI7HPYVCbMH7kg9uen1pFNkLW0gx8/uPYinLa SY4IHYfjTsT6IjNjIp+bn2q3FaK33BjsQfWi4y0LQdHdQe5NRnTEP3Dg9yPSl6Bf/Mcmmk9HHoCe 3/66qS2Eik7wCOzD1+lP1AalmccZz1+lMFsjeue/1ov/AJlf8MMaxY9+egqD7DIPvdegI7j60ybj RZyDsSOgz2pXtG7nj+v0qWV8/IieFl6Ajtn0Bprxn+A//XFK3f0ERYYZz+K//WpgkY/d5Hf2FMF5 icn7xPqaaxIHyk47e/1PtSuDXmVSevHtn0BqF1B6rx6n0p2FbuROB6cevoPrUWFHTPuT3Ht9alor 09RphB6D6+1RlGHGffHrj/Ci3YCJ4j6j1B9R70wMy/dzjocdxQvP0GSGQHooHaml1HfHovoaVw9R u8j+RP8AhUTOp+6T9fegleY3ce7ew9v/ANdRhiOuPShIu3mBmH90ev1/CkbHfP196LE+gwsR6Dtj 0NIV9V+uO4pNeZKQ1m9V/wB32oJ9celS1/kaWGhQOgOOuT7U0yA9z6D/APXTuJ+TDJ9fr/8AWFNc epz/AFoQ35+gm0jr9CKQpxyPfHoaGCEVD2wO/PYUEg9P/wBYo/4cF8hVUe3p9AaTOemcd/Y0kNeX oxGUehz0B9jQsZ9R6L7ipaHfv6DTFjsfUD3pAAO4z0+pHpVCT/yHBR6HPT6U0bfU+gz60L1KEznq 230+v1oAI64Pf6Gp+ZJHwe/4f7VSK/oD7D0NV/wwrf5CA5+8D9ff3pSAOw9CfWpbH6CEk9//ANdN OR14/rTD0Gsx7n/61QYLdQPr7D2qRhsz7/0NNJB7Y/iPsfancEDDHXp/M0Bieufb3pIcX3E2/wB4 nHp6GmmQ+49vX6/Wm/8AgCQGT1/DHpR53/6h6ULzBeYNMD65pFYjqPYexp3GODE+h9T7/SonYjsf Yjvmpv5Dt/kQsD/9f0xSeXnuf8KbZERoA/hz6fWmlvQf/rpWL9BoUfT0pDGf4ic9ce1F+wgOexHo KQg9hj0I9KF5oGAkI9Cf73t9KQ89z/8AXoBP/McoHfHr9D9aXA7HPpj1oBMbtz3/AAprIe3PqB2o QW/zEDZ6YHbHrQWA/kwpsn1Glj7ehxQox3H+z7ilYsGjK+nuD601UB6t/wDXz/hRcXr6CbfbH+17 Cml8dBn+83/16SfcASLA65HXjtj1NLnPqPp2o9BpjQgB5I/+uKM/3W9iT3oXoCI2wMbT9fc/Wkzn rn2poZEy+49cU4DP3c+uB3FAgIz/AE+tJvXvn3PoaAXmNxzzn60E47e/FL5iQmc9j6H2NKVPrn09 hQFxACPfuf8A9VG3+9j8P607hYcIye+PSmYP8RI7A+uKENi7jjqPx759PpTsH+ED1J9PpSfmC8mJ n/7L2o2Y6n6UxNDtvoMe3vTQx9PbJ7ilcYrD/Ae4+ntQwI/oPUVVhNeYoI9Ae59j705gR1OexPrU lIXJP+e1J5eOn401/wAESDBPRfxNOSJiOg9foBSGv+HHCA/h0/E/40pjA659ce1DD/hhGQ9sY7/h 6CmsoHbPYU/T1D/hgAU9GoIx1H4igVxWI7Y/+vRz/Fj1B9PwpIf/AA40J7D1I9c05lx0P4+1IYHg 9fx96aG9v/1fWmvL5g/L1QMrd2GO3sPYUgP4dgPf3o9BDg/5/wAjUZb0znpzQx27MXOf6getN8vn 5Sf931oE/IXae7fhRsHf/P0pW7D9QJA6AgdTSbsdM/7PuKozl5eoLIw6Y9M+ooJP/wAUPekX/wAO hoDHuPp6il2EdgPYdz70XF6/Mbg47/T39qVfp7fhRYLefkDIvoPcetN3f3Rx/LFDFcXPrnHUj2pp Uj19R7CgqQpA7ZB6f5NAUd/oPxo9fVFXBYz3HHYHvQYgPugA9foPr707iYuw+g/2h6E01lA6n2B+ tFgFKDtn8O1JtHcEf1FSgf8AwAKDtn+7z3pCq9yfT6j/AOtTYBtX+H8c9qTb6igPQTJPXjuuO4pN 59PcE96peof8ML5Wev4il8r/AGj9PUCpfkJv/McoHpj+vFIBnoTjoR6n600xiBT6Z7AUhQjt7H6U EsUxA45P+0fX6fSkEIHQnH/oVJsY5Y/T/dI9Px96eISOoHqD6imDAxr/ABfX603P91B/dHvmkgv/ AJDWQn1z3/8ArUq2xPVj6j2p37egreYpgA9Pr6/Sm7B/XNJLv6lCqAO+Pagso6/iPWj/AIcT8mMa T0/P0qMuD97J9frVvyEvMN5749vb6UwHPUEf1NSvMpPy8hdhPT6fhSeUf4jn0A7ZpB/w4vkk/wA/ pS+UfX3oJHBMdF98ijyx6n6e/uaZfoBHuc/56U/7AT29sjvUOQ1EikQJ1J+h7D2rovCPhltQYrCo Z+qIP6n6VUWRN2/Uo6r4ektJWW8jZGB2FW6gj1FNk09WjO3k/ewPb2qKzOuMNfxOcyQep9sVYOc/ d9x71i2Zx8zT0uba6465wSK9QEa4PJz0J9RjuK5Kx0wLbEFBkcjgZqtdwb0IwOhIz67fWuX/AIcu T7ehU+F7j7OwPVWK59mPp7V7V8LPC2hXuowJ4paM27b/AN27YEs6xnAdv9o12UZLm975G0Htf1Z9 zaXo1laRomkWsFvboBBZ20IAWGJOyKPSvzC/aQ+BF94e1WUSyQXFrMza9p88fWKG5lb5Z4z0MZH0 PUY6D1W+6fc8CU9b/Jkn7P3wbHiLUoo4boW6qDfXM56rHEOiL/tHFdj8YfDzaffyxu7HYwZZP74/ AD+QrnxEXpf1Prsunsrbp1WfZvwW1UT6fEd4J2jcB2PPWpPi1+0t4a8GW4l8Vy3MjuTDo2l2q5k1 O4QdIFJA+XIySwArppq/U8LNtJOy8kfNv7O3xLe+8QXEvhrwnLpWnXSme801ellJHjDMw4BmcE9Q DzsGBWt+0TpiJeTcAbgk7EdlMQ/ma68RC3fbX10PPqxdo868j5h1KLn5ce9YzxMQcYHc+4rnh5+p 59Xz9DMaMZ5P/wBY+9PnbgYCn1PoK2v/AJEL/hxkPHQe+fUVNeYP8J9/r/8AWrWPqKXn8hkBIwUY g8Mo9x/jXuvwa+PF3oFwskYaSA4h16zH/LzbdzGCeqdR+RqZLv6DufUXxK+Htjeql74b2yoyhtUM fSe1xw5Ud4uh7+vSsTw+Bx3H3iPr7UovTX0ZzOOv/kyPUfDtqpHy/UGuwtwcc1hNnpUkTUVkdYUU AFFABRQAUUAFFABRQAyW2jkGJ41de6MOtcNr3wYglydJbyzyXtm6OD/cPtXRSqW3IkjyrWvhzPCS JrKRD1LY7f8A164+50N0zlMHp9BXe1/K/M5ZRM59N9c+gH+NVZbLH3uPWsmBF/ZoPXHsfWoZNNI9 D3J9PwqCrjVsFPcZ75pw0mReYgPX6/Wov/kUTAzDrGT6H1FWEif+7g+vvSS/zHbsOkuZT/rCfTPv 71GTIf4z6fT6Ur9x/IheOT++cdAfeoVt3P3gT/SpAdJZ7h86L6A+o96hOhgf6xW9Px9x7UIoQ6CB 9zPuB3zUH/CP+h98etNCT7jf+EflHVQR1+v1pj+H5COVBHQ57fQUvmWhh0mT/ax0I9vcVH/ZMg7N 7n2+lHyFbzGvYydgfQn1/GmiGZCNm5fUDuPegEhs0cx7N/dPHX60xZrlfvA7ewHemn39At2LIuyf vxE9ifU+9NMwHSP6GpuFv8wW4HZiO1TLfYHJz7/Smn3Fb/IlF8n8TD/ZHvTRKP8Alm+D0J9DQvNE itKx+8eex9ab9sZTwT6Ypr/goLdxDqnPOR3HsPera6irD5x9T7/Si4WIhexKfkX22t6mmSXEecoO e6+h+tDff0GE80Zxt+uf71R/aAfUdiP/AK1JB8vUkSbjsfQ+gppgA6n2NMYs1up+6oH+16CqUlso +vc+tK3n5BzeRDPbDrG3sQe9VvLI6BR3JqWxrzIwrDrj6juPepVtsjjHrzSGvP0Kkll6gj1x2/Cq j7h1Q+hz3X2q79yf+GIpD/dBA6KPUe9M2g9R7N7VJS8vQYG+vpn296AVJ/zwR61PzGhhRT/D9PoP 8KTyQen1/CqS7k2I2twOn4+zf/Xpj2/sR6//AFqQ/mRsmeo9h9KY0IHTnvz6mkO/f0IvIYdWz6j2 P+FMkgI9PoO5ov2GRtbn+HP+2P7po2emD/jSENMbD19fp/8ArpoGOmfQge9A7j2B9PYioird/wAv Wp9QF2HuCfQ0xg3fGOmPX/8AVTv5AIZD2B9QB3PuaU59fqPSj/hhP/giEr6n3+tBYd2wP89aL90H r6ibB2bPp7igLn29vWpv5jUe7EXHbA7898elKAfcds/X1NP09SoiH6E+o9qNgb7yj6HuBUvyEvP0 F2A+vuKNi+oB/kParsA0DHQ57n2puc9wT29/rSBDdhP+eppDHkfzHoB70L0FbuxCqr9P4iO5pxU/ /q7ikhsQqT0Ix1/D3ozn7vX0P+NFh/8ADA0J7kHuQPWmSKf4j/vD/GgaX+ZBJMQeCPX8aOD04PrR buJsCpGefwPakMZPoe34ewofl6DsG0dseuT2I9KayDsT659DSf8AwATGbCOwPpn+lIVYdCfXHtQL 5jcHtkehHrSE47c/xZ7GmNeogc/3c+poLEepHT8D/jSv3BiZP09B7U2THr7rn6UguR5B6j3B9aJJ PQ+2fSnft8gf/AGKPQn0/D2pAR/TFP8A4cEAAHp6ikJ9Bj3PakJsQH347/8A1qFJ7c9ifai3/BBP /NDSQOw9B7U4Y/iA9c+hoS7Mr/hxdhPXGPfuKaAB7d/pSXmDQgU9iPpRvHoPcev0oEn5CBB2HuCe xppA9Sf8aEK3djdv1x2Hqf8A61IvHb6H1xTuO4oUn72fr60gjA/xpDGlD3BHv6UoVx3Hr+VCJsNC H0x3z7ikYHHcHoT7UIF5AVPfGew9xTC+eqj1J9CfSgf/AAw3kZyT6ke1R7yO3upHpT9BikDt+I/+ vSDB6ADvU2/zHf8AyAtnpn0/Cm8/T1+tNIV+w5S3YfXPp7UFT3osNDFYDquezfX6e1LwB90/X/61 SvL5i/pBtXtgew9aaAD29j70/UPT1AEHpj0x704R/j6fhVCX/BEZR3Cnsw9f/wBVBAPXj3Hal6sa 8kIQexOPU98f405V9Rj3o9RWBgf4SPcUpU+n/wBej0K9ADewJ/pS7fUkDr9aEJAAp+7kDrg96N/s PYj0pW7+oXHfMe+O+8e1GPV/ck+poTGxwI+vvUign0x0wO5pgvJjzjuT60hY9wMfwH1FK/clMaWH b6fSmE+2fU/Wmyo+Ynl+v4GlCA9/Y/U0hf8ADIMe3/6x6UAH6e1HoP0Exn09T7mlZvX8aLdxPy+Q wNnoo9v8+9KoJ65+lMQ3P97n1J9KQqO3XoRSt/mUIVY9PoAfX3NPx/s+4H+FK3+Q4/8ADCCEjvTs Y6DHcH0ptf5C9fUPJ9fxppjPoT6n/wCt7UxWFJ9c+3vimsjN0wB1/wA/WgdxNnoCexo2Dv8A5+n0 oYAEP0749qXYfU49Pf8A+vUjXmIwPsPQj2pAP7zfXPt/jTX/AAGD9RCnoBSAHuoHtQhCOnsPXPoK AR/D9SPal6C+Q7IA5z6D2NNHt/8Ar+tP/hkO3YcSe4P09CPekZ/bBosHqJk/40GNe5z3A9DTXmDF CgfzBpMnuR6Ae1IpeTEJPf6Eex9KC5xwcjoBRYL9/QRUB6Zz0x6UoB+vp9fp70kiUBjY9Qv0HYUo Uen/AOuhjuL06/ShlJ6HHr/n3pE/MUwf3gc9CaRIj6n2Hp9aq3/AGmOEPrn2P+1SiEdiSehz6/Wh /wDAGNaPHX/Jo2AdvcEf1oJY1s/w4Hr/APXoVW9fZfYU2C/4AC3A+8T7mpNgHTP1pDQmV9fx96aZ PUewPtTsO3f5jGYj/D1prOT29hn1H+NS35eRI3k9Tz6f4U3p0UZ649atFJgRnqPoKQL6sM9Me3tS EvUVY/Xnvn/GneWR6kddtFygVT6UBAOwPbPqTTt2Iv39BRF9T3GPWl2Z6/j9Km3+ZSHGHA4zT41B 7kjpkd6Tfl5lehpadoMk5AjVmPQ47j3+ldLf+BhAvz7RxkkV4mOxNrJHZQp90edazOin5Wz2J9K7 T4U+M4tLk8y6C4yDGW7AAdPqa7aFTT8DHEU+x7745+EejeLLUS6GI474ASsqf8tkA9PX/Ir57g8O Gxyt6z7h+6kVh0I9AfWuzF7e76oMLK697p7rOFwPQj0NWFA45yehNYszj/wS7aNsIOM8/kSe1enW rF1+fccjdt9RiuSt/wAA6qbL0buYhvHTt7moSwx17YJ9CR/SuWJTM/4aMq/aF3OMPlD/AHsj+tdu Zogym4yVBDuB3Gf4T7j3pz3+42j0PMviH4ume8c+GdQ1qwgGEhgWZgYWQDoc/wBOetYp8faxPn+3 L+71AH5PPunLMFAwPnbsor3Kc20ueT8jxZQ7xR7l+yFqpg12IMTseOWHP+2Y+P1r0L9qDQiupu0S FQY0lZh/FIU7/wC9inittH0/U+iy96x16OJ6x+zr4wkOnoIyhf8A1ahv4VUd/pW/8R/2bbfxm1uf EF0qQws0qOgHzqw/5Yj1Zsc56Vrh521ZzZnFc15f4megeDfhRoegxBPDunRwj71zPgbrmTHWV/p+ A7V4P+0no5E+dmQ0Qc+wiJH61pKbd+b1PExM77+i8j5Ju4gx9+qn0BrBvFEZw64PTPr9amBwVigV A+8Aff8AwouLYDG3GP4vbPtWlzNf8AiCgdM57VNck4Hftn/69bQ/4In5kUCsDnA9D7E1rWmszRMC jEr/ABJ6j61aQvX1Prf9nD4+LbkW2tTLJZS8aTJJ/wAuNyw5Vyf4Z/0Pt09b1LwHDpcx8pXFu+Xs T/cJ6rn/AGD+nSuZ+XqFu/8AhZ1uiWsoX92Rt7fSuohUj7xFc7Z6Kt0JaKDUKKACigAooAKKACig AooAKKAILnTYJhi6gSQfdyR0Hsa4TxB8EYZcnTcevlN2/wB0100qnciSPMdb+Gk8P34WUjjHv9a5 O80Jl+8jZ9a62c7XYzpNMI6KfUGqz2zfxZ9fqaysKxWe2+vqRShmHVj6LjuKmxaLCyk9X9zn1qVY mJ+VgPT6/Wpb7FXFNjKc5ZfXHrUUlmx6Aj1I7/jU2/zHcryW8mPlwfr2qA3Uw+7nHTPtR/wwNeY6 LU2Iw2PVSfWraXiMOVGe1L0Fr1+Q8SRjsfrTykWev0Jpiv8A5khMY+64PcA9qRfK/j2n/Giw3Lv6 D47OM9AvrSvo49E+gPf6UvUd+xG2lr/Gi+oA71C2jxf3Se/0NCQJ9hG0iMfwnHX/AIFUf9gRnrjP YH0p2HzELaAnYgd8+9R/8I8p+6oH973J9KLeXmO5C3hxR/IY/wAKa3hxR0bB68f1NC9BX/zK7aD6 ZJ7+1V20Nh90HHoe/wBM0PyHchfSZR/y1b+6D6VGbSVf+Wme271oYLz9BjROP493cH2oN3KOhHo3 sM9zU3Jt2GG5cjooPbHf8aaWb0XnkfUe/vTAb9qcffAHcgdjmpTeD2z2Pv8AWj5lJDBqBB4x6Z9P pTjq7ds57H/ZoE/IcmsEdcf/AK6jnvwfusPceuaF6gokP2zI4c/7p7f/AK6gknQ/xH3OOg9jUfIa 8wFyp9D6H2+lO+0DtgjuD6U790K4efu+8MdvrULDP3iR3J9/rTfkFuxE0We49xUTwAfwj6DsPeoX /AGiIRY/h9uf6UGLH8I9VPoBVNdh+qI2iA6qCemPekKgd/qB2qWJETEY+Yfl2qPcPw7Z/wAKYeg0 uD1Xn+H2FQsn936k/wB3FJv/ACH6EZT/AGj6Ee9ROjDqvHb2/wD10WHbsNDP7+59KRkI6A+rVNx3 Ggk9TjtTPLI+6T6k+tAX/wCCKxPcknqfc0mw/wB73z6GmHoNIbu3Pr70bf7yqe/1pCsN+g9se9Nb A649RSAax9B7lvU//XpCvqAff/PpR/wxTQqqB1BP+NJgE9x2JHZv/rUNdhP1FJHc59DSdu/uKB+g pAA45P8AEKYue7n1Ue5oBPsI8j5OSPbHYUnmH+mD2o9PUXqLu+o/rSI6joAP7x9T9aQDyRn5s+mf amcdlz2JP+e9IsRmHf8AKkE/ofrTJv3AOD0Bx0z709TnuB/X/wDVSv8A5Feg75fUZ9R2qM7T0HPU n/69UD/4BWeFQeM57fWk2k9vofehCcf8gLY649PoTQRjv7E+9Rf/AIA/RjN49MjufRv/AK9I4H8J NP8A4cljRHnqx9vw/wAaVlB659CPrT/4cSEaHA6nPTI/rTGjJ6fQ+9Tcq3b0Hbcdx6Y9PqaZtbP3 voPQe1MGR7vc56Ae1EkRPU9OD/8AqosMaUPYH2pjpjqo9WHpS/4YY0pnp/8AroKc/d+tHr6EiNEv b6DHbPpTSo9/Rh6f/rp37Dt2Dyj/AI+34UhUfw8Ci4NBs9ST6fWjjHCnPY+opIVxTn+JMdto7ChV 9ifTPce9O5Sff0Ex6c99tDKB6e3v9aGHoMz6Lz3FDJ7D3Hoam3mIaVA+6Mn+n/1qCpPUj2Hr+FA2 AA7HntntTAp7fifeqXmL0JDkfeGf8KdsY9APX6Cj/hx3/wAhDA46D6n0qJkI+9n1pBciJ9T75ppw P5/T/wDXSuK3mMP59v8AJpSX7Aj+77U15+oxoyOoz6fWkI+nuPamxL1DBHb3+lIy+p+gNT6hYAvq 3096TymHr7/SqQICo7/Ufh/jRnPT8c96i/8AkCYY/wAfr/8AqoKgenqD6imvMH5CKuPvAeuf8+tO 2nt+AoQL08xir+fU+/4UrKT1/wCBH3oBeQuCeuPQD2pdp7tx2HpSY/8AhxNh7D357H6e9Lkr6/59 KaQ/QD9AP8fenbAOhz2x6U7CDy89eOw96Xy8dh6CgF/wB3lkZyff6/Sm+Wff1/CpQ2gC/X29hTyD 2Az0z6VVxJCls9Poc9j7UiuAOBz0qQsIVPYfU+po/Tv9aa/4YX/DgCT1A9MU4sR1H/1zTt5lfLyE yB0GPQD3pQfRQfY9v/10hNdvUbtJ9vWk2kevofpTbH/w4Enuce9KUC46nt+f+FCEvId5P94fU05b cHt7fSgaFNuO2705/pSsig/MOOm09if8aAGbj3Ax1pjKD16dDQAHPbr70YbsBnrn1FFuwW7sYVYH lD/9b2pwQ/h0PtTYl5+grZ7DH936VH5i88knp/unFSmU/IMn+HOOhPqaAW/iBI9PQ0Ahpjz0bjuv v7UhI7c+lNCt/wAAUo3rnufx9KTCj72fRce9NIP+HBfx9PqKXywMYA+h71I7DTH9cegpQp/h4/wp WJ+YmD3OfYd//wBVCn1Ge2aoq4KMdvb60cDpj0AHbNBKf+YpX0+v+RSEehGP4T6ikyvQcIs9B7fW k8gDrwaLhYVYwOxz0JpwXHYH396bC3YFiP8Ad+g9qPsxHTJPoexpXC3YUIOw/D/ClCAehHXmhr/M Gg3jvn2/+tSZP8J46mheZNu43BPfHc+9IfM7cDofrQWl/mDLn+pPrR5JA+8D6j0JpsT/AOCIUx1G e2fSlD+3sQe1P09Cb/5gZPQY7c03eT7dsetK/wDkNP8A4Axg3v6fSg5A+XHrz3ouMblif/HSKGQ+ gJ7D0NIn/hgwD29setL5fpn60x3DyD2B9Mn+lL9mPbH1oXmD9R6259MHqfY0jxY6g+u7/wCt707A vNkUm4H09vUVHJcBf4vw9qlIEu/qSWcyvnDHI5H0A7mljv4T/HlumPUCom/8zSC/yNhrG38oHeA2 cYHdff61BI9mhwkoB6BT3NZyZpT8ka2j+KLbTzunnJz0A6j/AHR7U3xJ8Vre6X/R5SR0Qn+77ivn 62Hbd2vI7FUseeojXUgALHJyxH93Nbmo3USukcTHAwZOOrg9/rXrRjt95z838z8z2b4ZfGSXTHAn mPl8Bwf4kB5yazPj74u0O+nifw3cqJW+bUkUcPKD3J/vD/PWu5NfaMKSaei3Vpep4tk9vyqeEnHz L7fSsH5FRLcBOeg9eexFen6TICi4xnGHHq3tXJWOmBpxBSjZyPVff6VX57KcY+Y+x/8ArVzfM0a/ zMrwMzLdXKq4x99ceiqOo98V2t6VA5DddpHuauW6+RUNl9yOB8U/CvxJG8si+HtTkhP+kC4ETbVj C8kvt/h781xBu5CMPGykcOpH8f417ThtZo46sH9r1Oi8G/EjW9CuYp/C9+Le6jO+AuMiRGBBWZO6 yKSD+hzXqsXx08S+KZJX8Yz2s02AtqkCALFaxL0RR6nJPvSrba+p1ZZ8Su31SPo/9mD7NJAyyqrk Hy1TP3VIPf3yDX0vbWUcKhYECoPljUdh/wDXNVH/AIJtnG5LXzV8d5bqa4bz4yI9ptLI+sYXnj/a bNVc+dmj5F1JdpGHOR8rH/aX0NYuq3CvjI3H+NvX/wDUK1gjkr/8EzCinoAOx+lFwrdmz6VozMr4 /vD/AOvVmYKQMN7n2xWkCZIgjVSeCSOoPrV1BkcDjoCe/wCFaoR0nhbxM8DgSyuqnmCVSQYm/wBl x6V95fCf4nxeI7PytanR76MeW0xGDcxr0cL6gdfXrWFRf5lR/wCAdXpSTW7bZtwI+Vge+PT611Vr Lu71ztHRTZaoqTsCigAooAKKACigAooAKKACigAooApaj4ftLpcXkIYdN46r9GrzPxJ8GruME2L/ AGhP4lxygHqAO9ddGp0l8jOcTzO/0lo/vROD0IIPBHsaxJLc/wBw+x+vvXTJGDRRe2A+8PcH0qL7 Op6D3+lc8i4kf2b6en0qVbRz0P0+lJlJ90WxZyjqQfQjsKmFsWHUCgXoR/2d6498dzUT6MW+4qjs fce1TYfr6lNvDbdj/n2pv/CMTj7m339x7U0xrzEXRbgdye+PQ+1D6Xdjqp9TntSC3n6EIsZx/Dj2 /wAaY4uP4l/3sd/pQ32JaGLfTKfusO3NIdYfPKN/tfSmmFu5bj1xT1znvjtVuPUV7Efj3oYyyJg/ Qg9znsKUSEHke+KVxDSwP8I/2vrSYU/eRQexFNC/4cR7FD0HPb3qE6evZjnvnuPai5TIG0tj0c+4 FV5NOlP8XsoHpUt+QFSXTZe649D7/SqksB/iRj6n2pN/5DS8ynJCO+QOv0quYT/D06N7ihob8ho0 8H7u78fWlfQ5SPl356qTSv3BeYi+HZz95SD2FK2gyj7y4/vD0am/L1H8wXSG7jnoPemjRZD1B9R7 Z9KSKQh0Rv4R/wDrph0hu5J7mj0HcQaOPUj/AGf731PtR/ZIA6E9ufT/AOvQ/MXqiq2kYzggfSkO n7fu59CR3I96fqT6Ia1m/wDdBPUAdhjv9BUIYntju2e2PepD/hhjs3YHHb8KjN6R05PTntmiwrdv kNecHpz3Oe5qu0/p16Y9AKpseow3bdlB7E+1NM+epGevHpUDuMM4P0phnHfr/KgX/DkZuT2x9Pf/ AOvSCQtnOB6+/wCFJIE/8hhJPQkj+lIZG7g4/kKZV+xGw+n0P8VAUn2749qlPuTb/gDcYH9femE+ xPYn1FFh/wDDBx6Y9/Q0hx6fQmgE+yEAA9ffNNwOwx2/D60Mf/DgyL6E+p96jKc8AH6/0FHz8xr/ AIAm1h94e2PQ01lAPG71b3PsKS8htjgR3x7Um8eme5PrQkJoQuPTH0pAc9Tjtg96RC/4AvTGB7n3 NN8sDqeeh9s0FLyAg9/oD6kUzB7DJ7n/AOtTTB+QvmA9VP8AtY9T/jTQg7KB6D0FSVfyE4PGM9j7 g0p+uB0wKL9wuMzn19PwprHHVR9P/r1QvX0HEhfvAj1x2NJ53XgewPcfX2qSv+GFDkj5gV7/AC98 HuaUyf3v+An2psE+5DJISeWPoPb8aRVP8R9x9KXoFx3ljP8AUf570jWx7ruHXHrQv+ACXYBCW6DH uOxFN8k/xH8fpQ/+CDXcXaOyH0GfWkeFu+PQn1NIBChOMKB/eHuPem7T7en/AOqmvP0FfsMKj+EE 9yKbnHUfQjtTY0iPyz3GPX2J9KU5/DoT60r/AOQf8MAIHcn60jqfQZ9fak2JLzGsgHTA9/Woip7j 2J9KH/wQbARn0Hrj2pocH+Efj6e9HoF/IVFz1/8A1GnAL0x9D70enqUIygdDx3+v0pGH0/wpIT8v kM246D3I9aV5Bk4OB2PpTf8AwEVf/MZ5i9gf8TTSx78dwD2o9fQXzEyx+7n0z6UpDD/Gj0BIFtW9 fwNOEOf4foR/jSXkKxfXQsqDlcHp+HoKiutJeP8A1mPXB+vamgv5FNx/e+o+g9KYz/3WI7jFFv8A IQNOw+8T6gVFI5PQH1J9BQU/Ij2j0Pvj0FGB7+gx3+tDQf8ADgVHYj1x70pY9+PX3oB+QwqT3yO5 /wAKTYO6j3PqKPn5sT9BSoPr6Aep/wDrUghx1GT1wf4f/wBVO/cH5AIwe3/66Qr6E56Z9aBjWHt7 sfU0qgH+H3+opCDcPQD+E/8A16QoP4sY6A+lL/hx3/zEA9RmnFj3z6D6UAn/AJCbR2/DPajaR/h/ 9en/AMMJ+Qcjr9Pp9BS7W7AE9/pQkF/MUt6D8PT6mjjtj3PrTQXFCegPqx9aeIB3ye5+tJ+o0PKe 30NJIpPX6HPp9KV/8xp/5B+OfT2oUH+EfXNDBP8A4A3yz2J9/el2AdGPqR/dpsQhRh/P8aUED+H2 z7UD/wCHAg+o9jRsHcH60hN/5Aw+g+vf/wDXSGP0+uPUUegxVXPRR7il57Yx1P1p/wDDlBj1Bx/K nFQehB9fYD2pE/8ADCYB7H0wf8aUIfc+/qBT/pAn/kAJ7AY9adx/CcevvQxCbj3x+H+NIye3uc9/ pSK9fkIFz/Dz1BHcUuz29qYrjTHjrSkAdM/59BR/w4DMjvuPYE9jTQx7n6e4pWC4H/dOeh9hRgf3 ceo9TTSGn5CMPQH1J9R7UpUD72aBXEKgfd+hpMD0B9BSHYbj39hRtx3/AApp9ybdmIwHYkdh9B70 pX0pD+fkNLHtn6ev40o9sjsR60NDQz5h2HsfWlJx1OKZNx3lnvn/AD/jSFR2A9SaGULtPcD0OO9K ABjGfQE0hC7W7n347mnLHnufXJ/rS/4YdyRbdvT2B9/epltQPvlR6fUUBFiBQO2fcdj7fWmtMD0U emD6/Wqt2FciJPbA9cf570mCeq+/40vmHp6ikcdR9femmNB1Jz39h7UJAPMa/wAJz6H0FMz/ALQP bHpRYfoxCwHTHp9aaJAPv8+o9BQvMT/4cazn0ppGfvDnoB6/j7U15DE+b2PbjsaFDep9fofpQhX/ AMxxGOn047mkMJPXPrg+1H/Di/4cPLPtj19acIc9j6/5NA4+g8W7Dpx/dI9PelFoxP3ff6H6Uf0h 3/yJBZMfXHX6mrCaJI3/ACzbHUEjoauwcpr6P4EuZ8nZJgfeYjoB7+9YPiG38piI8+hYe3v71aRf L2Rzst7KegJqtLPPIQCGz0X6D1rKUezIjF9jd0rRpEBLgAkbcZ6ZqW38KsoO1hvPMZHYe9ckjqjH /M1m0WeK3OUJPAVv7xx3+tUrHwlIfmuzhcboV+lVJ6aLyJS/zOe8RWs5PJGOqD29sVzW2SM/MG/v c9zVwSsRV8jtvCtglvE8t6F3H5LRD/CcVk6TbyzyFpCxHr/tVjHd/wDgI+n4HWxyOv3iD2z6fWsK 8lDy/dOBwh9AT2+lS99DdbP8DOj5Gc+4X1FTxSEjnI9Kt/8AAOZeRZjIPUn3b0+lej+HrgmNNq8Y 27vQ571yVjqp+Xqb9mhO4bu27Prj1+tVySeh98ehrlt29TW/cxPCqqmoOCduULMR/wAtGA6/yr0W PUDFyUV2UiQK3cq3pWl9VcuD2PsPwv8AtqeBL4Il7qo0+cqBJbXK4UNgZCSjggZFeQfFn/gnlpOt ETfCG8063Y7pL+1MmUnkds5ixnGP88V7fqjjcXf3u+vkeB6z+x14w0n/AJDfhrUJCDiS5t13KQP7 jqO9ekW/w18L2+nQt4W0q8j1LDDxeZQfknOcBVP9327VnWWmjPRwmjTi49m/I7v9mPU9ssqE4b72 09v/ANVfWytkf59KqI853XoLXzJ8Y7yVrp1nuPMCH5P+mazJnGPXkVTX+Z85I+Tdbb5m2gdSAPUb vSuYu5wPvcf0xWsPI46n/AM8XKnqTjsPb6VKzgdW+uOw+tbmaRF1PJz3+lWGjG35VJ7k+1aR8yGv PyIo0A9fcen4VdU8fPkd/wAKtPyJJ0QEcE+qj0r2P4W/Eu8sZI3s7kpOh4x0uICOQ49HHanJeXqV B9j7j0rXrLWIEm0llORtmQdUlXqr47xmtTTlYfeFcL/4B1JdvU06KzOsKKACigAooAKKACigAooA KKACigAooAxNa8BWN4DvhSOQ/dlA6t/tj3ryPxH8Kp7PPmws6feE6jjH19hXbSn0l8jKcex59qun eS3C7l6geoNZTRH0I9KuUTFPyK7p6n3x7043DDoxPuO9Zsu/+RImqsvUE9segqYa1jqv1x2FFvMf oSDWEx2+vtR/bsa9iT1FSA4azGw6j3HpU4vkP+rYA9ceo9vpSQX8vMUTJ2ZfqO5FOlmA7g+p9DQN MqvKp+8AfQ+hHqahYqfvfQAdqQv6ZTntAemD/ePp9Kz5YF98dyB1FBf/AA46IRDpgDsx9Pen74v7 /HVSKaJ+XmyxCYT1uNvoD3q1HPF/z8qOwb1HtSB+hKQh+7Kh7cf4077Mx6Op7kDuKPkC/wCAIYpe y++ajlgm7E/hTHYg2zDrnPf2+tBeTsuex9s+1MSQzax6qfbNNktsjlB6lvT6UmhFSXToz1UAeuO1 VpNKVfugD0pf8MWmV5NLOOCM9R71CsUo+6zeoI9qQW8/MelzPn/WN/n3qRrmU9Rns3H9aV+y9Qa8 xRd7R88Sn0Pv+FH9oKPvR4/qKon/AIcX7ZA3KIR6A/0pBLCTxj3J7UmPUYRGeiqR0z6CpGgjA+XH v9aPUq5VeKE9Yx6kj1Hr9KgNvGBxz3FP0FcrSW4/gJPYn0qq1ivrz1I/xqX/AMAf/DkIsuOcHH3f /wBVQSWCntk9TkUgT7leSxI6D2OKhksiOoGfX2/+vT/4YVxn2Ze//AQPX61D9lHfGemPSp9C/wCm RNaL2bv8x/wqNoD/AA59ceopE/LyGvAff0P1pFQjqCP7tC/4BX/DgYwe/wCFMKjucDoV9afp6Cfl 6EbAen0/+tTWU/xYx02+1SFxvk8fLnHT8aCv94/Q0m/ISGEAep74oYnuw9T9Kp+QeggA9fbHt9aT cOwH1qWWn5DfLz0Yjvx34pWI7D24/wA96T8h28/MaSB1GPUCkY88YxTX/DiXmMYhj0x/CP8A6wpz RgfcIPbJ9TTuAgwOp9ulBUDqD6D2FJoX9MAPT649RQyjuMf3j649KY1/wRVj/wAQPSkMa9uP659B UsaXcNo5yo9Qvqfc0wgen09xTC/f5i+Qv8Ix3PsKQ2meje/4e9QIg+zE9Mf/AF6TyvXJ7Z96Y0MI Pv8AWkEZ+p7+xo9Q5f8AJCI79x70Fzn7v19vpRcb/wCAOMeeuD359aVUz9zp1B9BQv8AgiSFaMfw kj1Hr9KUOQOQPX6GheY7iCQj+eB6mmsc9MZ6rn1pr08gf/DgXHdf/rD/AOvTWkH8P057GhvzAXaT 6ep+lMOMf09T70CsJgnuPQH1qMQk+h7keiipBMaITnt6gDtTvKUDqfTHpR6eg0/8yJkUd+Oh96Cm Pu59VPtTQXGsh9QT6e3tUe1h2z3Oex9qL9/UGJg+309vrTeD2HofpU+gxxiPqfUD1pfLPoPqPWj0 9BWGHPOFHufQ0GI46ADuR3p3EIU+uOw9BUflt3GPb2p/Md/8wKegPpn3pPLJ9P8ACpD0APnoM9s+ lPKMffsPrQhsUN/z0ViOpI/pWlCIG+6kgPXj096diZevqVnDD7rsvdcdsVWnmkb/AFrE98+lUyn/ AMAgI98H09c1Gzj+LPpj1NKwWELk9Rx2PvTcDv8AQD1pWEIR/dAHYgf1pPLPc49/WgXoNKen0PvT wM9/bFMBMfh6e5pu0kc59/rSS/yKf/BQix+/Hp60uAOgx3GO3/66P6YvQMDsfc570zB789z7Gh/8 ALf5gB7H0z/9akIx2/8ArULzBjcDvn14pQw75x0z70Jf5hF9wGO4GO3uKF+vsM0DXl6gMZ6fX2/H 2pwU9vqTSH6CBAfvH3H0pdoPqfX3FIlgY/QH1GOxqQRDsP8Aeqr9gY7gfdB9/alz+fQ/Sl6j9RMe h/L0pGB659iPaj+kH/DsVIif4vcg/wBKCo/qB6Gi/cb8xQxHRRmnFPRee59qBpjdh7ClEZ7Aewp/ 0yWOMRPUZ7c9qPIHv/iaViv+HDyz3APbNIEPbnsM9qYmJgZ75/n+NL5Z7fUe1Jh/wwo3fQ+voBQs A/vY7FvemJIdsHvn0ppjB/vfT0xRbsFuwqx+wHv70v2Vvdvf2osMUwkdh65pogJ7H296A/4YX7K/ 9057j0//AF077K3ofXNN/wDAYxjQei++TSGyY9Ov86QNdhrWbY4Hufb8aPspx1B9PYUfMGL9jJHB I/xpptyOh+tNPuN/8Fgbcjt/uj2prwt2GOx9qmX/AARIb9mJ9T60hhI9D2b6ewp3/wCCKwzy/Tp3 Hp9frS+X6D64piQ3ySf4SP8AH6Upj9FP496gr0G7PZh/FTmU/wB0+o981XzBCbcdMHuR6GnCEt1U H0pL/hhND/sTn19VH/16cLRj1Bz2HpTB+o8ac3oPemGzI6f5PtQiku7GmIjp+JpcY9Pr/n1of/BJ /wCHHiZuwHoD6fSlyfUn+n/66lLzEn2QrQe/PUj/ABqIoO4x3qvRjbEwvv8AT6+9DSAdPxHqaSQX GmU44/KmGU9s56EetMlLzAE+h9CPammMjpj1ov8A5FWEwMcqD/if8KCv09c+3vQv+AFhuR6+3/66 Vz6MfTHpT/4cZH5wXsT6Zp4nTuzZ649v/rUE+obvrnqR9KkCscdR3/H6+9J/8ApLz8iaLT5W+7H/ AJ9q07XwxcyfdiIHT6mi5SX+Ru23wzunHywOT0BA610mjfAe/m6wPjrg/wAI9/rRzdjTlXVnXaZ+ zNMzfvUUdhnt9RXb2H7NGmJj7YzP/eQdgPU1F+w3P+VHTj4T6MqbLe2CJ1fGP881ymr/AAO8Irnz LHzGPJQdWJ9celNyfQUZvol3ZjW/7OXhuQ4GmlF7DPX/AHqqa7+xv4elcG0vHtTjACdyf8Ki7LhU 7q5RH7IWnIQBrLt/dLDjgdzTX/ZIgUjyNYA/u8Ywc/Spd+huqi/lJ7z9mseXsS7j543Z6Y9zWLff staiiAWV4jHHKswzkelS35ApLr6o5V/2VdUjOb4JK3WLkfKD7e9Yupfsua+7Dy7EKmckjumewFUp eT7BJR6PyJvEnwW1cRpHZ6fLtX/Xle7H+8Kx4PhfqFrwbNlA56HJb3GKzh5+o3FdGu4j+F7tc7re RexBHUY9KwU8NXIYl4zjPyrjrii3+Q3E55XbnIwRlNp7bD3qxATg/oPUe9VJHDB/5kynHXkdCPrX o3haZfJ4JJ+6q/3V/wDrVy1tjqpv/I6eyYAkKxPBJGOxB/lVFR7c+n/164v+HNX6+RgQTiLUI+VX KtHuPcnpn8a9A1CxSRSCWx99h/fK+9VJ7X9QitD1/wAPfH34OXNrBb/ErwXa20oT7O96Ys7pMYLG 4UAgyd/mNdRp/wCzP4cuiJPgf8YL7S3P72KxEodAzL08tsHqB6170X29WeK8Q0/fRrjxp8cfD4x4 m8L2Pi206S3Fk3ztERyWjAHT6Gm6d+0h8M9VyniXR7vwvdNxcQ3MZXEgOD84GPve1Pl/l9WehRrJ /BJeZ03hf4G2NpP9o8E+Ibe/hYZltlK8A/3GX3Gefwr1zStZ84YktpoJBxPFIPunP8LUW8vJm2Kq XSv0NEV8s+P/AA/cXJv7iIExLIE3eighev1+n0ql/wAA8rvftc+V/EQ2Mcrx1yPRj/WuQv7hWHLc dM/41UF29DlqIxkuTngnjk+4q4W9/qP8+tashIWNl7f8CB74rQjiyvb0NaU/UykRKnPQY6nPcfSr SovYZ789vwrRf8Agt28Y9vQj0roNMnmhIMRJP8QPcH/CtF5sqPkfS3wc+Mp0yUfa5T9jkxHqK54h lzw2P9jv7da+rECHBgZWU/PGy/xKw7H3rhqL/I6YE1FYnWFFABRQAUUAFFABRQAUUAFFABRQAUUA FNeJGGJUV16MjDgj3Bo9AOI8Q/AzS7rmyiWF+mzsR7fQ15F4i+Es9mcMki9wzfxAeje1d0Kl/iMm uyOUm8OOvXn0Ppn0qi+muD2A9fekyESL4eY/dlDdz7Clfw5J/C30P+FTcaZC+gz9l/Edz71E+jzf xRsD6+o+tIq3ZkX2CT+4fQ+w96iMEg67v8D7UXEkJ58i/dY+ufr6U9dSlH3iT7+tK/8AmJocNUf+ 6P8AZPpR/akh+9GCeq47/Wl8x/MmW8J+9Fx1NDrGf9Xx6g96PT5jSKMlondmx1Htj2qFIE/vHHT6 ii/+Q0+5O2mw93c9wD6+2KT7FAP4iCOFx6fWl6D9B8cEY/1bn1b61bW/ZejD6+oq0+5FidNYx3/A +tP/ALXBP3R9frSBrux/nZ/h+tJ54Hb3JpiXqNacnov5+lQG4H8agjufQ0rFkbSjsD/n2qpM5/iU /Ud80xf8MV5Cp7EDqB6CqzIR0Jx1+hPtUth/wxAQw7H2z70xppB1Y57fT61K9BtdvUjN85649MHu aebxh94D2I7fQUN+QRXcUX5/ur6AH09yKb9vU/fhXHQkd/qKA+Ysmqwf8s4W6Z+p+tQPerjhDnqB TJIDcED7hz0bn7pNQSXmOisO2Bzke9F+xaX+TIWlc/c3L6j1NKJJAPvH1B9KkSInlk9Cfc1Gbh+6 j3b0Ht9aCreZG0pHr6D/AOuaiMhP31HqpH9fxqifQQle4OfX1/Go9vqq+oHqKlj+ZFj/AGff/gIq FlB6D2JoQmyKSIdj7/gKjZycZzjovsKVvMdxjLg8n8uxqIg+319vekJevmI7D0Pt7Cm5PcD6/wD1 qVh+g12P49QB6fWmE56gjuo9TQO/YG6c49CB6e9M8kdseg98UeorDiox8h98eo+tMKj0Ge49KLl3 /wAgMAHQgH73HYUEEnhvcn1IHYVI7dxBET97n0HtQ0QHQA9ifTFUhW/zFNvg8Mf8OO5pnlMepPsK i/ZBbsBQn7wx9P8AGg7u+fZj6UCYGP0wP6mjc3fI7/Wmv+CUv+AOUkfez6kDv9aV8D7oz/dz2NUm V8yPfkcg/jSMxH3QP9qpsTb/ACGq+eg57Y7gUu/Pb8fXNK3cSAKvO4/N0x/9ao3B74Hrj2oXmNIY 0JB4fj09P/10wr6E88hvT6D2p+oW7PzEWH/aA7n6CkKjsTTF6oftI6AgdhThu7jHYE9gPagaFZAf 6fSo2RT/ADHsam4L0Agdwfr71Hgdzz1HvQF/+AL5Z7kD19vpTTHnp09PU0reQeo0Iw+6pPY0m1uw x6/Wqf8AwBjWRvYemOxqIo3fJPcCgl+fqKVJ+9j29qAMdenr60k+3qNIRnx2z24759qaWI65x2// AFUosY1sY5/P/GmsfVvfjvQDGCME9cd80qrnqB7n3oBeYu3HUH2NG8jo3vg+nt9KT/4IriHHYfVv X6UFce/9c0W7DG9PvZ9h6U1zn7v/AOo+1P0F6DSMfeP4e9Jscjuo/veo9hQikT2truPyKD2x9fWt FvDzL/rCqnup7j6UkF+/yFbSMDqv93PofcVS+1Kh+Rs/wviq9RNjJdU3fdj+relU5CT1z6GkK3n5 sj8sDrkD09PpSCMeufQU2+xSX+QpUdh9Qf6UmB6DPTPpSsFhu0en196Q5/unHXHt9KSG2G36Y7fW kVGPQkew7mgheQbl/iB/xNBUDrx3p+rLuMYgdc+lIf8A6/40CFYL/FzTcD+7x70CEC/7PsGpMeuc 0mVbzALz8wB7bfUfhSeVj+H3z6CnbzJFAU9uPegAd1x6j2oBvshUQnpgemfSkCE9c+2f6UmV8w8s nrg9hTlT+79c+mPamhJdhQfYDuT6ken1p28dlBPbNH/DDuDEHqvsRTiR9D/Dn0pXIt5gYsdTz/Ok H1/E0Iq/b5jioP3iCOn4UqxegPtnvTf/AABX8vIkMJ9Bjv7UqQ9QF57k9vwpeha8/kTpp7HsfU+/ /wCqmmH0Ye3uaTX+Yvn5gLU9yfpTmtwP429cetUv+AN+pE0fp06UgQdj9frRbuK/+YogGf6/3qc0 RA+77ken0o/4cfz8xPJPf6fSnLZnuR9fSkmT6fMkTTpD0BPc+w/+tViPQ3PUe4PrTXl8il/wCcaH j7wFSGw4+4Af73tRcrTqRnSgeuzHX6Glh0+JeSwPYr9P8aZD8kStbp2Xjo3tn2pBaoeoA9AP6igP +HQ02KdseufSoJbVF7nHU0ht9iAiMdCp9/8ACovNj7D3J9RQ1/mJeYNcRcbFb/a/2jULXAPRR/n3 9qA9X5CCUego3+o9/rRfuNeXzEMmPup9D6GomJPUH0z7Ul5gn3E8nPQDPpQEI9vej5ifl6ibeeme zexpQP74I/u4p+nyC4GL2P19aDFj/wCt2NJjj5jfsvqB6j3/ABqWMAdFBx1z6mmJ+Q9rsnqox2Ho fanLcY6gHuPb6Umx2D7dnqMdj71G8uOv4D0NF/8AISXf1Im5HT2IPc0wqP4l9l/2gP8AGhsdu3ox QR2z649KNzg9eDyfcU0+40Blbt9R7CmNnvkdj7H/AOvSBiGQDsR6g+9AjJ6g+v1FH/Dkry9BPJz9 4Eei+opGjPYe/wBCKHIpeYAH+vHeomVh256Y9x600iLiqjf0pxtSRxn1P0FQUiDy/wC6Wz1pzRHv 9TVMVu/oAsmP9B6fWpRYH+IA+/vTS/yEi3HphH3kz7+hra03w6kvU478+lZVJ9jeEf5vQ7bSPAUD AbzHzwP/AK9eoeH/AIU2RUfutw++zn+L8K44y13OmS8vQ61PDlpCP3NvGD06dVrTsYpkB8iJfp7V 2o5pepes7edj8oAPVj7+1aH2O6Pp6Z9fxobJ+ZQ1IXUI+TbuPABPX61i/wBlzHJk5Pf/AOtSbKS8 xIrlkPyx+7D1HvUF14lj3Hzyqn7oX0ptAiSO6jbBVx6j2+lPLgn5iSew9KVykyGUDOTK30qCefP8 Z9frUt/5Foz7ieQkHzBjsPp6/SpRfznH7wjHGc9AaXy8gZRvdSIPySN6N7GsSe+zjgfQ9yPWpa8v Mqxn3UyMeYIm7EY+99aoTxWbcGwhx/EAOg+vvU28/MVz5y1/TEgncRtkZ85f+2hz0qlbkjocdj9P /r1b/wCCc0P+ATRg+n/1hXe+D5SUPzc5G4nuOa56vmdVL/gHR22tqlwisW+YNjjqFX+hIp7rtJyQ OefZa4jZeZy2qWsZu4DIzYyYy3oD/hXp1zAMfuxgfdT2wPX3pVHt9xUNvmeY+LdQukaPyIY5VwY7 gSD7xz/Wq+l+Jp7cg2rzWsnBWW3OMH6CvVpS/lfkzzqtNdUeyeDP21viDpWBFr0epwD5VtbsAkD/ AH/avYIP21fAWurs+Kfw/hRj8k10UDBcjqr4zwfeuxeWh5cqTX8O/c29L+AvgTUjv+D3xQvdFnPz x20EuV3uP44ZOeDW5/afxv0DH2q003xZajhpY+JGix3UAdDz39PSrv8A8/F5nVSxPSp6Glov7dnh 0kJ400fVfDlzx5sN5G21WYkcSED+Ielb39g+Hta0+5i8IeJbK5afMy3CsP3c7sCC0fsRSXl/iZ08 n8r8j5k+JH7F3jmBd1hpaagoAEi2pyTjPRMd6+a9e8PajZMV1fS9QtXH3luI2HT0LDtVw8vUzq0H 9nUw0jz/ABcdRj0PvWhGueh+h9RWskca9CQAdCM9zV63OewA67R/hTiYVF29QUc9PbNWYwf4FHoT 71sjEuQDHr/hit60BOOSfT8KqxSZ6j8NVilkEczlSwJtm/6a+mT/AHjX038LvHs9s32bXmdSONIl k9Cfuhj2Hb0rnqL/ADRtB/5HrmKK5DuCigAooAKKACigAooAKKACigAooAKKACigAqC70yCdSLuF JF6YYfdz/dNNPsJnk3ij4LPCSdNUtF1Uf888+v0rzLVPD00WfOiI9wP612xZjbt6GC7H+Bj7Gpkv p+xz6fSpsJDm1uVPvop/vVei8TQt99QvZ1A649qkSJVvrU9NmOmMfzqJ4bduiKe2D3pFX/yKlzpM J6AD6VmTaMw9x1BHcUik+/qVGgIPf2/+vT1twP4j659P/wBdCQ0WokQj5XU9h9PelawiI4cZ6AAd APSnYLkP9jw9p+fu59R9ajOkDHyyA9lb1/ClYL+RBNbSr/CT2yP8KgMTjon1+tF/+CAKAp+aP9Op /wDr043RXouOwHpmkmK3b1AXQ7/XPpVtJlPYfSi4eqH+cfYd/p9KVZM/ebB6D6VQLzFaIn/lsD3J 9vamiNh92Tjow9T9KEwv5hIQPu49D+NKUX1U/wCz6ihsLjXgiP3sewFQNBH6YPTHpj0qGNP/AIJA 1uvcE+x7EVWmhyPue4P09KpAv+AUXtHP3oiPX3FNFoR/CfQ8Un/wB2HfY/Td6k+n1qB7fb94nHb6 1Pr6it2Ea3B7+xNQmH/b98n09qpvuikKUJHX/gXt9KrvA3Y/QetJoF5jGjl7MD3x6UeXJ7juw9fq KLeQkiMrJ3Un+EkdvqKhcOeufUCgREVkP8OB2+tMw/fP/wBepbBIjkcnoox0z7/So/NP9M/4UPyB efqRSDI6nPTj1pgcH74oHykWQfunPY00jnr7496Xr6gl/kRuoOcEDPH0phiHYmkn39Rpf5CEYHT2 AHb61ESewPv9PpQxsY7MPX29hTdzdlz3PtU2/wAwuNK5/h/AetLgjrn6Gj/h2Uv+AICPRvXP/wBe l+U+nqfw/wAaokTII6f/AFxStGfp7f3aS/4JTFzjHX0zSFG9SexX1B/wpeokG0DqPoB3pSvTA4/r St29BpiMh/p+FOVc9QPb6fSqS8/IT/4APBnouPQ+o/8ArUfZ/QH6UIr19BfsxA4z6H8aT7Lnv+H/ ANekIU2uev1yPSkFkv8AeJ7DPoKSD/hxn2AHrgf0X/69NFgc84x2I7/Wqf8AwBrzG/2eo6Aep980 37Mvb6bqP6Q2xptyOo/D2+lRra46qfUH2+lSJf8AAD7K46AD39z6UhtG7g+n1psdgEDDqTj37H2p 4hY9PqPpSENMZPf2Y+n1qOVB2OAOCB3PvQgt5jHV/wC6B6fT2qIA+mPf2pryBkpAHcH29KTb6sfw 7Uf8MC8xGBHqR3Pq3tSFG7jHqv0pW8w9Bvl+mT2+hPr9aHjUfe49/Wq9PkCG+UoHzc90H+NMAGP1 we9JIH/wRGjUfdx9aiZB3c+mP/r1mCGbPXHoB7e9IYx3A9APY+taIQ8RL3HtQYsdD7A+oqWyrDD7 Z9CR3x6U1lI42nPfPY1SF/wwZ9Rimlx2BHv6UIL/AOYADvz/AHs9qAhHQA9uPSpD/hhJLc/xdOoB 7/Wnsp74Ht6Ckv8AgDt5+Y6JyvRj7D0//XUjXcj53yn1+p+tNeQMgeaQ/elcgctn1qPyx/EOeg9q teYv+GY11A6E/T0pqhR94n0H196zSGGAfvE5+6Pf8fanCzfPCBu6j0FO4L1A6e3fP0/xoFgR0x/t e+advPzFbz8hgtfUAHt9B6/WmtbE9D749KP+HK9UNaAdx9PeoxkHgD1WkhNdl5Ay56kDuAP60hQ9 /pn0p+pK/wCHGiPPTHpn1+tBQn+EZ7D+8frSb7eo1/wBCB2//VikVSevT+RosHqIU9D9KNoHbn+I nuKQ/QTAP8/xoxjqfqPej+kFhdrf3R6/QmkKntj1J9KF5i/4cOvX8/Q0oX0J9xQFg5Pb3HsfYUgJ 7ECmkWOx6g+hHpS+WPb/APVRcXqxAhHUnB6inFDjgAnqvsRTf/AF6eoKn97r0I9KcYgBzux0yO/N JjS7j947AY6Z96XeffPUH2pMPkOe6fsD7n6URuy/dI9TmncGvPyJDfznoxXuB6E+1R+aw7n1Huf/ AK1JP/giS7C+fIevHrQXPqR6UfML9wDn1z3NIIyexz6eg+tMtEkcTDofoPehg/Yn0OPT/wCtQTbz F8hv7xPualXev3cHvj1pISRMl1cD+LA68fxAe1SRatcL90jP8J9BVJj9R7arM3dR2BprX0naXHt7 0Njdu3oMNy3Y57t70wSn+Ilf4sDsKExSYG5I/jOP5j3pFuAPuyPnqM0gEe6ZhySe5HuKjaQnqSe2 aSf+Y7f5DCvqoI7H1puAPuqPXHqaLlW/yAtn+ED0x6+1M8nHTn2NNMj0AqR/CPr6U07h/Fx1I9f/ ANdH9Ib/AOAOLH1HoF9BTTjsTj+tDXYf/DCbB3ZqQjHU57L7Glb/ACHYaVJ7c9SfUilIPtn+dJeX qL1QFn9Tnp07UnPfPr9aZPp6jsH2/wA+lBib+LPqDSv2HJ9vUPs5P88ewpAh7H/9VCXcEIYVGec9 vqaRkB6Ow/vHHenYbX+QBf72T/hTdo7k+gPtS/4Ydw2N/dOOgoKei/8A1qLA/UQRsPvfh70YHdc9 yfpQTf8AyAkDoPbmguT/AJ6H6VQ5LsKSD0B9FPqD60BMdRnsB6ZpCuNKADuT3x2pgT1wT1H0pBbs KEHfr6elO809h7fhSf8AwAUf8xBDn7p+nuKka2xjI9qaZVv8hGZY253DuT6fWtawNnJj9+kbdGD/ AMf0JreEfMwky5ewNEPkiLr/ABOvPI9MVn2viV1PyBvQD1Pv9K53QfU7Y1FbdHo3w5kur64VPJcp 96Rz/C2ehHuK+mY9FWDiMDb0Hvij2Ft15mUqt/hYjacn90Z7+w+tXrW04xjHf6/jVcpLZPBaeX/n vQZ2HRvoPSpkgMW6mMjHe5PYfUU1uB1H+FSkXcowyANyR65HevOdc1ZvMcqqtyQijsfY1o4/5hB9 x+keILkDN6xX+6npx3HtXU2Orxv1fB7D1Y0S8hKRPO6r1OD1A9qqSDf9wA9wT2OKxsbKSI2tye4/ CkNuccMMdge/41Vu4/8AhyhNY5+8xJ7ewqpLoqH+IeoPr9KTj2+Q+Ypy6CexAPU+wqo2gv2we34n 3qbdx3PnHxdppjkRm/jUSjHRvcH3rCRcHrUnPTXckR8e3Y/Su08JSD5skdtrf3PoKwqHVT8ztoUU OvALD5EcdgfQ0y6jIY5yRnA/D3rgRrbzOW8SDa8R4GHXH+6W7n3r0mITtkzxFF+9G39/PqtOSWl/ RFRRSj+F2paqpOk2Ek5B2YUE4J9MDsK3rD9h3xxdAeT4c2A/xS5G0H+8SK9vDxVtRqkvttI6uw/4 Jw+MeC8dhEevMg6iutsf2DPEsf8Ax+2mkXK9DG0nUe/Fd0eXq2YTUekkXJv2ALtAW0xpdPufvI1r IMZHuPQ1a0zwt8bfD4/4l+oTanCvLW043bhnsdvb61tBp/H6HmVaCfwyXkT3X7YOmSfuvjH8NWUf 6uaYx7gCc4yjL3IPSq9v8G/g9rx3fDrxpceHLo5ZEtJNuXbnmCT0b0Nc84NfCcanKO5sP4F+OegY PhjxTp/ie0GSLa5xvaLts3D09DVDUv2qbOT938a/g7cQ/wDLKS6eIsu3r8rFe/s1Zemh69GtF7Oz 2Rh3P7OvwG8Uc+DvES6NOclYIW2gbufmhkH8OezVxXin/gmV4rthnwjrFhq8P3grttZkH9zjGSPe tFU/nRdSmnurdLnjHiD4IeLNKJ/tvwvqluB1m8tiFx6MB3rDghI+8Dn+IMMYP410QXZnm1qDXT5j pISD0+o9z7VaiibsP8//AFq2scCXkXrW0Y9ifc9q6CxsHP3Iye+fUD0rSKEo9jr9GtJ4iGt2ZHHz xY7OPWvpXQ4o/EloGtwY7+L5Z0yQzyp3Vh69jWFVf8ErlfbzR6N4C+IMt4vl6udt4nySE/8ALyi9 8eq9/wA67OuOa7eqOymworM1CigAooAKKACigAooAKKACigAooAKKACigCKVAeuPQg9xXMax4BtL gHYiq3UL2Y//AF62gzB+R5H4i+EdwhOyAxnsx7geh9xXKSaNe2hzJArj7vTqp9vaugS9SN4rGTPm ROh6jA/i+h96zJbNR90k9xj+tS0MgaPB4+g9ialSCQfxN68en0qGhk8YJ/1kjDtn61ow2cbDi4jb 6npj2ofkhpdyF/CzH/VlfUAH+lM/4Q+U9dvqf/rUXBPsH/CLY9R6Af1qOTQSfvKfZvQ1Nx/8OQSa OfQ+mfUVCtiy/dB9/qKYhxlk/ugj+tMdWx/qwexz6/Wnb/gh6+pUkdj96AH3HYfSo2QH/lkR3z6E UmuwL1BIEPUD29qabb/aBHQ4ouP1GtEf6MfWmtBt6OfcHuKP+GFciZm/hY+/1/8ArUzzJB0Yt2wf X2NJspr/ADH/AG2Xuo9fyqJr2YdB+Apr1IsQrqU2flU/UjpU41ec/eQMeoz3x6n3oKcexKNXBPzw j3X1/Gl/tiA/8siO5Pv7UvmKzGNq0PZAfc9h9KRtYUj/AFSY/h+tDBLzIP7Vx1RPp61A9/F7j2pA rlaS9jz8qKR6HvxVWaRT79gPUUkF+6K+w9mb3X0xRkdpPoD2FVf/ACRQ3cR0YnuAOw+lN+1OO3vk /wAVJDtoB1OQdsn+VMOo4+8vtQv+CTbz8gkv1A+cD2I9T7VE1xu6L7sPei3+Y7efmQOyHqAPUCo3 VP8ABfr/AIUm+wkRMqjuD6fWoJAPbNJP/MCJj6DHb61ESD/Dz0JoGiEk/wCA9qQs3ofb3+tTcdhv nt3yPX6UgmQ42k+3vTXkJ/8ADCecO/5HsaMgdVGPQdxSHYcNn8KqP7oHoKbIAegGeh9hSSKiIsag cE/U96a0Y7keoA7UIVv8gCDsAfX2P0oCt/EAff1H/wBamNoUHB+Zc9iPQ0/GeoFSxXG+WCflX/eI 9KeUUj5D/wDWPvTKS/zYGMd+P73v9KQRk9OOwb0+lT6iYqpj7+SexPpTiPTnsuO1UO3n5AoH8XTo PY0BQe3+97//AK6VxABnoF9h7Uxj9fUY7D6e9P1G2Obd3/D2pu09iB3+tIfqI+31Prmomt19Wx/C Pf600wYjLk9B6H2H0oEY7n6A96AuISew9s0mwf0z6mot29R37LyI2BJ+bGO3sfpS7wPu59G9x/8A WpkCuiY4z9ar7cduOwPc0vUq3mG1e6jPXd7+1M2oOoHsf8Kr0C/kIY17pu/iB9KcYgPvZ9CP8KQf MjMI9T/u/X1pxtiP5EeuKX/DFMRbf+4B7fSopbc/xcjqaH5egku4jYPX8f8AaxTdoPTim/8AgMBG iz16dvZqTyR65/xpMdvMb9lI6AehPp/+uo2iUdCT7e//ANan6CEK+hPuaayt2x7/AEpBbzGumPuj B7Z7n/69IQfUe9UH/DCBF/iBPp9Kj3L6YqUxf8MOCA9Afr71JJEsf8PzdCR2+poH/wAMRgA/wgnt n09jTlibuBjt7j2+lK4khfII7j2+vvTdwH3Tn0J9aaGJj/YHoT6/WomAHRcGmSxMHvj60mwepPf8 KV+5S/4AmPQ+4Pt9PetfTrRH4Xk9AD9PWn8gZdl8Ny7SUjBHUkdgPasNwwOG3Dsc9v8A9VCX+RN/ 8xrgD09M+oqMhfU/X3oKfmR4BPGT/gP8KjkjUngfQ+oFC8/UL9/UaYfYntn0NNKD39wO5oYl5iED swHY+9BRh/I1CY0huD9PX6/WmlCc5wPUe/tTB/8ADCCE+mex+tLgj72fUewpki4z3Oe1N2g9M+x9 aVx3Alh9/PsPpSlM9QMf57e9O/8AmNBtx/CPf/8AVQY/b3FCYAo/2qcIh2JI7+x/+vRfy9AQKR3H HUD0pfLB9B3I96GD9BdufXPQH0oCEfeIz3Pv/wDXqUxevoPEQPQH3Pril2/h/h7Uf8OU/UPKH94n 1PrTxHx1/Knf/IdhfLzTvs4HQZ9R/jSAUW47ufYf/XoCDvn2A7Cq/wCGEl5ilhj5x7/T6UxgT94j 60DYFgOx9yO4NKGbtgdwRS/4cLeYbz2/E+9L5h5/IEd6EIXzj7DsT6n6UCU/3qL+QhS7difXjuKF lJ65B6KPX6mhepb/AOAO3j+Ikf1wKb5o75Pofb3p3EIXz0Ix2x2/ClJz/F9DSEGwdnJ7ke9GwDuM 9h6U7C9CTCjp16n/AOtSGRD93Hv70i7f5gXXuPw9PxpolB6L7GlbzG/Qbuz29yT2oaTPRf8A9VNE 28/QQkA/L+fof/r0K5P3kA7Y/u/SmAGM+i+n1B9fpSCIk8AepB9fancEh3kE9R9RSJbevB9aj/hz ReofZj3BI6bvQ0CD1XPYH2x3+lBLHNFjjB9h6UhiI6c9s+hoEl/kJ9nB6/gT3NIYzjoPUE1TfYQn lk9znpn0zS+Rn+R+tIIibD6L9fQ00r7jPXikH/DCEf3sD1x3NIY/QD0H+1T9PUPX0Qvlj39CPemh AOpHqR700gsIVHofr6/hSeUe7fQUWHYPKB+8ffj1o2L347D3/wD11Ieo5VXsR6k+v/66WOPecR9e wH+FUvIkku9NaP8A1gI9TVEzRj7zAds+uKU/Mtx/yIJ9VhH8fPTA9PrVBtfz/q1PtnuKxcjZQLen arlv3gVR2Hoa2XuYgfklVu5cdz7VCl/mE12LdxFEVUwwrI5O1yTgAe5960o/C9ucZa0x97YT6jsD X0eEpKyPnsXWd9LlSxurnz3X7XCkI+URdS49wfWu80L4G65rRU+HgvkA7bqZEzvY/wB0gfWvQhBf bt5nPCTbsr9z3rwP+zTqOlSK95BMo4Riy+vvivSda0qK0TdckKv3Qx9TXm46Sb/d2/lPUoU2viOa OuWTfduYv7w56j61JB4rtA4UOp7sw6Ae7e1cDj/mbKX+Zl+JPiRZQcW93C7dyD1/H3rnrH4pxkN9 rdUP3YSP4x/9es5QLv5eZYufE8cahpmwDyoz1JqFvF0DjmVQOn50oQFKZWl12IfddcdSx7j2rynV /F9tFKBPIcElpB6rn+lelSpp7nM5u2jMDxj8WbW1ZRbuSO5HUj6e1XtE8eTXiZtrxY8cxuDyzfQ1 xVKTsdCqrS9iKH4sarG224uixHDM38ZrtNI+LSFcTKm4/efPTP8AdrmVuvqdNSP8pd1L4i29pGGk LsM4yvJx7getUvDvxTj1M40uzupD02BTkj8B2Fbqn2M5T7tF7V/FVzauFn0fUN3XHlnjNUb3xrcx gltGvCPvMdh4H+yK6nh/NFKXZruZDfFNiPl066PqzKRj/dyKgf4rjcFazuAx+45B5+grmdHsa6/5 nhmsGQ29u03JIZEf/ZU9D9Kx3HofbPrXnvy9BRYqpg/Nn2NdV4VmAb5lBGOMdmH+FYVPI3peZ3sb 8qRnPTd6fSp9TJEjAZVf4R64/vV55u/+Acf4yQCMEkjDK4b23j+Zr1CzuA6KR93aAmf4sDH6U59P uKg9/vPoP9mbx1Y20V2kiRrKrrKjN1aJ0PrXuC/E+J/uyjHZvX8a9em9NDHEy136Eo+IsJ6TKfUg 9PqauweN4D96QHv9R7VqmcrgX4fE1o//AC8KPr61fWQH7jqfcVrY52jI8Q/D/RdWjZPEWj2l5GRs cSqMqP8AYk6gqeeDXxv8a/2QbDQZBNpLyR2THaksY+aylLfxsvY/h/hom/8AIza7+jKGrWXxA8JR wzeG/Hkl5ZviSPDblQnoJQf73sTXQeH/APgodqEgCeOvCen6nEfkkkTGWGP44iCORWad/i9GclWn ZvkZtRN8BfErfv8ATxoN4eBJEChSQZ5BHHOfT61s2f7M/jXTvn+Evxde7h6x2N6QQyA9N6g9R7Cr v31N6OKf/LxeTLo+P3xM0cFfib8MjqkA/dy6hYLuEqg8kxqCOV9RVZda+BniXI1TSrbRrr7swkTy 2jdewkxjj6URX/Pt/I9aM0/ga80ZOvf8E39LuVL+CPFaNn5oorjBX8JYwf5V5nqP7D3jayfE+lpc x9p7c7gPyHf6Cu2nWX/LxeRzuhF7O3c7Xw/+wdr8uDqKQQIeQWYZRfdMf0r0zSf2GbCIf6brbg9k iQYX8Tj+VTKuvso6PZ01u7m7D+x3oSY2ahc8dMKvU+1bvhv4Dx6TJu0nV5mB+W5hkUYkT6rWLqv7 SRhKUOkH5E3i/wABSA+foTeTcp+9uIwDi4jX0Ve6/rXTaB4kW+iVgmxvu3Ef9yUDt9ah7fgcUI9j TorI0CigAooAKKACigAooAKKACigAooAKKAKOseI7LT4Xl1e6S3t0BuL24bpFEvc4ri7v9pTQFQN p6XN4D8wCDGAB3J9a6aVFv8AI461a23qZ+h/FSXWvMe2Z7RY8JDa5BMhI53t7fSux0fxBHdoCCA/ R19ce3vW1SFtvQmD7vzZea1hlGLqJZF6FW9PY+1cxq/wfWc50y78kHl439D6GslLujaJ5J4p0V9O lKanaKMYZLhOjo/9361RtNAE4JtXhfHzCNj1UVpJdh37/Iy7zSSh/fQkd8D1qT+1Y1XAt4Xxym4c 5+tZtD+ZFc3VvKB/oyRn+Mj1/wDr1U+zxj/VswHb3qfQaBSQfldvYeg/+vWtZPJJ3OOpOaH6jt2L jR/3nP1H+FU5Ip0/1TBh1Kn0pAQSXUv8S/UVIjJj7qfj70xf8ORyCM/fiT0wO9RGFMfdP4UxohaC H3HvSCwhb7pB7g0reYIibRYx9wj/ABH1qFtJXHyn/wCuPek0JMgbRAf9Xx3we1V20KXuT7gdx7mn 6juv1I5NPlXoAR057U0uP4ogO+R6+1Sw9COS4jPTOf4vrTP7QUdIUY9ST3oFbzFOrp/HCuOpwOpH pT11q2I+aBcHlSOy/Wnp0BX6gL6xb/Vx4/i3Y6j3pBJY98qf4uP5GnYdxsmn2Z+48Z9Qe6/SmNYW zfdkXP8AnvU28xX8g/sy3P3XB9D6fQ1EdDjboR65/wAKGNMhfQl/gKn0Pp+NVJNFx90DPcj0pDv5 FN7FgeAfp6VCYM9Uwf5gU/mN+QhjIHCAds+n0+tRbT3XP8IPvRccl29RhVD1Qg9vfFRyon8W7Pp6 fX6UhehH5SA/Kd3t7fSoHbHQfUUf8ML0ZEf9nGOuT6/T2pjf7/Hce9T6ARlx257c9qZwPu/Q+4/+ tQ3/AJDS8/Mj27uo98/4U07cfKfw/wA+lJf8Afr8iMEE/N9Pqf8A69NJHpj+8ff2piX/AABnB6/g KQRD+HGf6e1JIHEayjvGD2FHlqP4B/tA+ntR6FenoGB/d4659/rSE/7vrk9qXqxCBR3znqf/AK1I BnsAfX/Gl8yuYUk+w7k+9IJvQD/Z9waRQwOO+fr6mgSg9vf64qiUhfPOPlAHb8RR9obuuO31+lDH YT7USe/oR709rojqntilYheYn2r0T/ZHt9aUT+oA7jPZqd/MoPtJ7j6UG5PYY9frSYWI/tQP8Leh HrTjdnsAPb1FNImw5bwfxZ9Mev4017hT1H41LLYnnKep+hphl+v+FJEkZkBPQjsG+tSSOAeoJ6gD v9BVXLv/AJgJR6fj6VIEx948dFB96V+3oDYnkr2Uf3iR6/SkW3/Pr+FUSxrQADn6ketMZQeoP0Hv UjXl6kTon8PH90e1R+UvfnuMdj7035jb/wAhwK98juMd6CF9W9M+h+lDf+RKQhK9seh9x/8AWoZB 2YHsD60enzK/4YAxHQr7GjcO659fr/8AXqX5eom2RPCv8J92HpTVhXuBj+X0qh+nzD7OO5OOuR6U Nbgfdx649PrUpd2F+3oMKAjoPTHvTDZ+6j2p3/yHb/IY0JHTn1FI0J7LjufpSENcH0z2yfSo3iH8 QP09Pxo9A/4cidwOgPofpTdo7YPoD2osNPsTIAB9056qfQCmmEnPIHfHqP8A69HoK/kHkEevv/8A WpyqR0B9M0WD/hhxjJ+8T65potvcZ659TSX/AARgbcn7uB/j9ajMI7k+9WS1/kKtm3p7ZpBaDuD6 fh9aGymv8xwgHbA/wFO8pB9xip6/h7H3pN/8Em/kOEzjpcPjqBnpioGcHqSfb1NS/L0HcaF9gfWo 9hHcH0PoKYIZtHdR9aRlx2H+Bp+vqK/ZDT/tcdhTCo/u8+lT8ymMZAPf39KAv90/Sn8hXGuoPqfT 2/8A1U3Z6kZ6/U0g/wCGFVc9SR3IHrQHHfPpg+h9R70f8MHqN2kfy4pSCf60xL/hhAR35/iOe5pR GT0Vc9N1K3kC8wwexz2NLj0GO+B2/wD10Jf5FIUR+mPVgfWk2k/w+/PenYT8hygdxnvg0oiA6HJ7 /QUn5fML/wDAAe4I9KccdwfY0f8ADj9fUUH6+/0pwA54PtnuKdu3qH9McoPfB7fhShPQD3qP6ZbJ BJjopHv/AJ9acHJ+8B6inbzJ+XkG9T/CfamYJ+6Pam0KX/DgIwf4T6c9qb5DHopHcH6U7jQ7ycjk D3o8ojoPb8KTYJCmA9l9qf8AYj3J9Djv/wDqpCaD7Hjr+A/+vSrZZ6hfT8Ka/wCAV8hwsW9T6AU1 bP1J9KBLzHLYKM7R7E+9J9i9c/Qdx9KPUoBY/Wk+wj+LgdM+pp/8OR6jvsnHT359Pag2577fb6Gk Un/mNNtjruz2FKLc9cD0I9qE/wDIGP8As69xkdcD+lH2cdwAOuPakPm7eoC3U9B7j6UwRr2Rc9Kd v8xSX+YbB3GP8aCE9fbJ7GncVuw3zF9v/r0u9Pp9KlP/ACD+kNEgPfHqPUUnnj1PsPaqaG/L0ATA e/f60ebnoD64PYj3qWL5kZmz0HsR/hTTKV+79TTl5egriiU9/qPpTPObtz2A9MUDt/wRouH7Aj+8 PU0rO3r9R60WEn5eQhX0OOxHvRs4/UH1ob7fMLdmJ5ZHb3Ap4J7gZ/hHqaSKuN2t2A/2h6UjBj90 j0PtTuO3+Y1iR1PsPak3N3IJ6Z9DSTIfl6iOGHT8aaZh347sp7E/4UMpf8Epz6lt6Kx7n612vwWs LPUb8Lrsot7cKZHklOA0vpuOPT1qqfmRUWmnqjU+OJ021kZfDs8bAfLvU9Wz2IrxVLiQj55WJ681 lWfc6aUtNR7dPmORTQpPQj2NciN/kWIkz1JPc/596sxLjhOB2A/ve9UmM62C2iJjDLPKR8+xM9T/ AHj7V1kMaJkjSioAO9j2P/1vpX2eF2X3nxeLeukvI5vwvAhaVoNOIJJMsk3cjPQe3/16/Rj9mgaa NFgOj6dcQD52vZJ+TeXe85YOCeG7cjA4wOlPFQfK2n2uOjPXX/Cjs/FfjFUjKxQhnb5Qzf8ALMj2 9/rXzV8SfiRq8hEUtr+73bkkHQqpH3gK8uNP+b/Ee5Slf8zmdL8L3N5IBbLNK/3WK9FT/az6Vp+J b3TNKjKXMwe7P7vyI+RGmP4yPX6Vi/L1Hbt6mH4Q8C297KRfMyZXdB/10ArKvdNETMrIFZW2bT2x /wDFVlJ/5mkWtdPM5Lxn4tmSYLJKdoAdYSfusf8ACsY+PpmP724YL2QHqPcVMJBVj/wDTb4gqqEC UE449vwFeM+KPGcs8p8u7bA+Uj1Yeh9q0jVfT0MoxVtV5o5u4vmbmRy3bcfX61qeG/G8unuGjBf/ AKYnpk+1axrX+L0MpU+3qjrz4qW9bcm1SeWjH8BPt71Zg1doz8nXox9h/hXm1Fqd8JXX4Mb4m+LP kRBVLMTyUH96l8Gfte+JNBGdCtrQdpDIgOQDnjj1ruoPv6HPiIrZvzPTof8AgpF4gkAfWPCOmXI6 Z5+cAdkHp9a6LTf28Yr2Jm1Dwtb20Z4JiHIQ+gPp/wDqr1VFfZfkjhjT/vvshdM+N3hO5QtJb3KL 96UmP72Pf3qaH4l+CbhCy2t4QOA3lHkDPXFSsLLy7M7VW7P+6fLUwlNsnmsSgY7AedrMOw9xVJVO OVJHUY7V8zJHYv8AhxWIxxn/AGfpXQeF5tsi7hxgj6nH9awnt+B0QPRUIIG/OBzx2bNWNXXkHgAj f/n61550Sff1OT8WBXt24BIIckdihrvtDvEkgiIPBQEf7WPWipt8xU+t/JGR4i8S6vp8M8ugXkkD ja00i94t3ce9clB+1X41QD/icMw/iT+9+NerhtvwOGs9fyNyy/bV8XRdY4nB4cZ5x7nFdBaft5+I 0+9pULDpv39R/u4r0Ipdzmcn0Z2uhftvahMB5tqQerqD0A9eK7nRP2yL12wlrMnfcD1U/wCFdUYL oYuT6+p6XpXx91SflZQV6DLc80zxd4i1DVraWK7tkkRlO0E5+ZVP8jWNTTYa9T5C8OfErW1s7qzu iJYkLS23mE5tTCTnyj/tnnv/AFrx4+ILjcTDcSR5+fZnv7j60opf+3GNZfkmaVr8Q7wf8fCxTDqC R1I967nw5+0Df2ZB07Vb+zI5UIxwCfVfahr+UylHuvI988F/8FBPEsGBq72urx/xF8BmXHZlFekJ 8f8A4T+IMDxr4VgtJT8vnyxfdZv+m6Af1qEuzsRFtfC2dBp37OOjv+8+E/xFvrDrLHDFIHTzCMfP GefzzWxBrXxR0kn+2NNsPENuMBbi14cKByTGAOv+7VX/AJ0ehTr3+I29J/aN0Sc7dYgvdIm4Lw3a EbSxx97H972rXvNMuNQXPh7xm8Y5ZfK2kHr97HoaTj5I6abS3VzgtY8I/Ea2JNtfjUE7CF+WXHeI gd/euUHxw8UWbY1eTUbc91mjPOf72R3qkr7WPTjUh1ij0Twt8e1ugPt6xSL91pU6j/fU13+n2Fqm TYIqI371lX+J/Uipa8vI5MTSS1p7PQvUVmeeFFABRQAUUAFFABRQAUUAFFABRQAUUAeR/H3xS0Fm UUY3YGT/AMtASOg/2a+WdO8X3Fq+BIzxniQMfun2r3MNHT8Twqr1d35HtvwY1u3JlLqCh6ue25e4 rsrXUJLS4P2eQ+WDwP76N/hWVRau51R6XPRbXVknGYD7tjsTWrZuWHzfQVwTR1QM3xN4V06/j26t aiRf4HHVPoa8c8Q/AC4tQJNAuSV/jtU9CT1ArSlLv6BJ9/VHMRTuONUtZSehDA8kej4qncaFFIc2 MjD1jb+hqmgKM2lXcf37WRh1UgHBx6moxKMfNC69/wD9YqGuxoriE5+6D+PerFvM6/c47g+lTYPU upeyY+bb/iaR5pT0Qeo56/WkCRIm4/eiHvilks4z1THqfSkDK72ajpu9vrVZrdh9yY+q4/rVDINs o+8wP0pomk7KPSkL0GGeXu+PXHeo1L9z7/5FF/8AMQ3Yx/jYf4U17eTPFw3qy/T/ABqv+HYmRGKU 9ZSfU+tA0xz/ABexz/WpsWvQhfQn/wCeg9sdhVd9Dk7EZ6Z/z6VIJldtIkGckHuAPSq72Mg6qfVv p9Kdh+r8hBaA9Px9qkGluOmT6j0NJDIZNPlXpCfTJ7CmC0YdRj0A/wAKb8mJg0Ug6FvU4oMsq/cB /wDr0rjUf8xpu5+wOemD6U03dyPvoDjp/tAetDFbsRPczk8Rr/tEdsDsaiLTdkHrn0+lNsGhjRuf uqfXH/16gaCbuB7D0+ppIqMu5E8Uufufie1RtbOegAPQn0/OpD0Izan+FCe5/wBkD6VE9mx9u4z6 UxEJtHHRR7E9wfaovs7nsPUk9jU3Hfz9CJ4z/EPY49T71CY/9gH2Pen/AMOSxNh9Pp9KYwJ7H6ep qRtieWPr6n0+lMdU9OOuD3pjUe7GZP8ACCT6H+HPofaomcjqOaSAazHvn6D1pnn+oJ7/AEGaaExx m9R9BTS/que+aEH/AAwqyE9FI7fhTsA9xnsPUfT2qGX/AMMLx2yf6Uh2nopHb8aG/wDMXN2FMOPT 1P1oWIeg9D9fr7U/UpPz8hSgP8I9c0eR6sD3BqQv5AtsWHBwe5x/Kg2eevI6gnv9adgsH2UH+Ir3 bHanC1JPQnvk+wot3EmN+x47ewpHtiOoI+nr70DY5bTI5xjqPqKRrUentz3FFu3oC8xn2dT1we+D 6+1MeEA9Meo9PrQxN9xpjX+LGOuB3NNYr7ntgdhQNf8ABRGSccjjsp9aYUx1PsD60kJP/IQIfYf7 Xqfp7U/Mnuf7xPamOwC4PcH1FS+f2zz1J9KLg/Ia9xjqAewz6fWkMqEdDnv7UCDYh9PY+1RGEfws c9D+PoKkpf8ABENsB94nPQj0NJ9lI+63+7n19zRYL/5jTbMfr3+nvSGIn7pb39gPSgVwNqwzk/59 qaEcDr9RTX/BKT/yI3Rx0J9CPT8KBKB94H0/GkTbuyQzRjqGx/Oo96/3v8+1C9fIqw5Ys/dP4jtT zYMfuAkdm9/rR6CQh0+QnhDn09SKilgkX/Wpjtj/AOtQ/wDhhr/hyBzn7w246D1FNLA9ck+pH9Pa j/hxWA24booB6E+lILVQOMt2+v4UMLCBFPVjn0FAhXsTnp+NT/w4IGJ/jY+ij3p0bEeh9c9vpV3J v/kOaUHoR7exqLcB1P4UJlpdxwuQBwoPoT2//XTN2eRn+6QO5/8Ar0risH2hz91fcH/61BMvcAew 9KGxDCrdt3qT6fQUhhPp7n6UN9wsRmP6/wCfagRAdsdx/n3o/wCGK9RAoxwD6/hSNF6A+pov/kJk bx/3SfX8aYVH8QHofrSfqA0D/Zz9aYxx7Hr9DTaE2AJ74x6js1Rhx6Z75o/4YIruBcfT1NN8wH+X 4UMbGmUDvj1PrQ0o/hB9fpUoF5+oN79O1KrY6AemPTNAxpcn+EU4H1HsQKd/Mm3mOyPT3J96UPnq B6r9KGyl5ClvYev4Ubm7gnsT/j9KA9fVjkde/wBAPSlwR0XntR6h/wAOGSep+pHanY+vocdqSYwC +oz7+1P2HtTXqHo/IlSJR94f/XFKI8/y+lNAP8tT2PqSacYlHsOn1+tSHMKsXoPw9qk+zJ2Az3/C h+THcUIoHI/H396AnoB6Y9BTTE/+CDwg9EX3I7ihQPb6e9ArdhWVR1HvkUnA64z02n+tNB8h2c+n p9CKRgM8HHqPQ0v6Y/UUOB9w5x94H+lJvBPAIoXmMQsB0BPb8DQzsOik9v8A9f0p3J1FLAfXufU+ 1NDHtx657UIoaWI6cj/Gl3+mPX8R6Gk2Sl29BC+epx/SmNLjr06Bh3P0oS7epVvPyAXJxxnPf6U1 pyR1GPb0p27iQLIfX2+v4e9RtIf7uff0peo2JhyeM+49RRg+n1oaBefqBjI6jjoR6mk2H+Lr2PtS SBoQA+w7Af59aX5u4x2x6j2ot/wRX/zF2gen09qGjA6Eeox3HvTsHp8xvlrxhcf3jQUUeh9GpgvL 1EWMHtnsT6Ghol9APcdx/wDWov29Cv6QeX7H0x6gUMB3Bz0x7UiX5jCw9DjsP8KSP2GO3HemhNCM jdvqR700yA9c/wCP1pX7+hXqRvdoOhA7fUVVk1uNf+WmD2I9Pal6CuUJ/FUS9CPUVDb+MELqHzgk ByOwz2FC8yNenqdTrkluzD7AzeXjBJ6u1ZEynsD6gj+tZfM6o7ajUOPT0I9RVuEuv3Mjvx3+mK0X kT6GNrLnuw9QD3rKE2P/AGUelY1H3NI+RIkm7rTAcdBx3PvXOka38icTnH65+lWrKcswwCTkDj3P 9K0jETZ39hayGT5rxYgOGKdQQO+PTitjVZljhdhqjZxiJm6Bj9fSvt6C02Piam/wmX4N0ZLwpHHd T3U8p8m1CcCVn/u49q/SrwtYjRrOKK2uAqoixqv9xtg4Xj+GumpD3dert9xxVJvmVvOZx2veILuV /muTLjLIvHp6j0rz3/hE9S1KcC7ijii+9LOx+6g968vGWXwrofRYPb3peaJtW16OyRovCcSs3S81 L0OOiP7D/GvM7rw+szZM5nkJ/fTP/f8AZjXlI7v+HZ0OiztYlDcMxZSBhe8Y+noKx/HZeO5BSMJG /wC9bH8DH3rJsqmvPoeB/EHXj9qfY52jjOep+v0riJvEE7MP3jY6fSsl/wAE0n/wC3Nr0gU/MfQk 9vwrhbu4LsTk/wCIzRAmQoIwAc9cYPoTWjfLCB+7I3dGPqwo9CIm54Fs5JJCZ3XYBkAnr9BW3q8/ lElXZR6f/XqJvv6GtLrr5nmera80rHJJHY1XXVZCMBjjsvvXXBGE2XTrt0F2sxCdl9fwrWtvEt6I 9obEfXAHWvSo/wDBOeS/zR02geKr502QQq0f8ZPYAdjXV6X4slRChiXafv8A+yw9BX0uGpp9f7zP OqN9H5nAoim3Oc5DbR9GHaqkD5HJ56H3Jr83kfSQf+Y8A9/pz3xW3oE2yRcnvgewrGZ0U/M9IIG0 5baOpx6D0qh4q1FzGn2Zm5ypYf3Sf6V56NZf8A4XWpb2GMb7oy7vmJX/AJZpnuK9U8FXCSWcOPmw vlMT0cA9/rWlfbRBS6mb47vjHbyKPuOPLkA7Mp4x9K8VWX6HsfeuzB7HHWepKs3pVi3usfe6dVHo a9CJyM39FvwD8rFT6+31r1zwtrtoFw6EtwA57j3NdCkxNf5HqFhMUbat1GejFVP3CexI969cttWi hCfaJYlwMynI53CprPsidO3kfFmt6j9n1O6W0cqGLxkHujqeo+v+RXk05Kngbe2PQg1UF+hz329C WNz2zWhbQsT8p/3j6fWtgs+h1GieD7uUgxtNEo4aQcfL/snFei6clzOFWyVWjUbrueQ/60e5PtXB Un/wD2qWE0/eL+8/JEkfxYt9LfGm6pcW8n/LU2jEAMT6D/CvY/Bv7dGvw4Euo2eqRfxxXPDbSP4X Hoa6IJ299Hh14pP92/Q9o0z9qHwbq4C+KdJWAnCsbhA6Bj6SY4wfauhtfhR4ZvBu8Ha3NZk52NZS ZCFzzmJvRvcUNPoXSrdzQitfGViebi01eHqA3D7cf0PuatJ4n0m/GzxFpJt3xl4LxOwP/LOQjsfp U/4T0ItP4fUw7/8AZ3sM7vDV2LNifM8rGVYE9iP/AK9dtommzQRhblgWHoeAD6H3qpT7m7q6Wfqj RorE4wooAKKACigAooAKKACigAooAKKAELgdahlv1QEtkgfMwHcAdqpLsZTkfKvxs+KmpanOsT6O lrbxfOh3Za4mkHV2wOEHbB+teTjQPOz5Xyt1wO//AOqvoacbJWZ4S3fN6nqXwmtLq3hlE9rIQ2BC T1UqK9Z0rwrLMq7WLMRls9h7n6Vy1X/kehGL6+h0fhzRJrNiH3bG+Yj1cen1rrmukgA38k8hR7f4 VwVPI6E/8jK1HxQ2D5ShB/ET3/8A1VytrfTSOd8rBf4UHf610U4HO339Sa+0S1uQRdQqe28dR+Pt XMzfCto/+QUY27+Wx+8PqabRrCfcmNjfwJ/pmnBkHEx7KnqfpXO3+j2k3MVoI89x25rBrsdPo/My m8KA/dx9KhPhph/AT2PtWKKCPQ/RM+gParq6eq/fshjocHv7mlcPmV5I4s8Qsn9fxpFEBx5gfHQg f40/mK/kWDptmw+UyjtioLjw/A33GYHoM9xRcXyM5tAcfdfPp7j3qEaFP7H/ABp37gv+CMbSJP4o hn+IjvTDZH+KM/Wmh2E+xRnqGXsT6D2FK2lxH/lpj/63+ND8iSNrGMdZM9iD2pJIIR0f3I+lFuw7 kDFf4XAHXn+tNDxn7sqf3SD2zQJoQ6cW+7JHjsB3A9qjbQGbrIi9xz1oYX7mbNoEwzjZ6qynqPcV Eba4XsfXHqKS8hxFfVboZ3YfPy7T2X6gVGLpD/rLfHY+/wBKLf5Al5+Yv2iA9Bt7Nn19qDGP4VBH 86Lf5FXK8wJxtiC9s+oqSG0U/eP/ANY0mIsDSoj0b3P0+lNOkwjseOMeoP8AhTfoHN5ldtJj/hY5 9PQVDLYL9D6etHqH/DleS1XuOeg+nvVXyF7gN3IPcVNikyCWFR0474qs8ft7fXiqJv8A5ELxf3se hPr/APqqt5Zx8p/+uv1qLia7ELxEdBnuB61CxB6gjsPxppf5j9SEIR90+2T3pjeYOgGP4sHt9Kn1 Kv2GFXzwB/tr6H6Uwj1T8fekxDWQdlYDu3qaYY/p7+4pFJDCg/hGKQQgdGI7fiaXoAeUB3P+NHle hHofY0xP/ggYSOhPofcimbc9Bjtn1ot/mU2PCD0P0pQP7xx7UE+j8xQgz09h9PeniAeo+g7ihlRf l5gYCD0OOjD0/wD10CPHr64qUBIDk8DHqPSjy8fxex9xQwf/AABCn9xfcA9h7GmknsD6Aehof/BH bt/iF8s/3QD6D+tQsx7A+hPv/wDXoTHYY0+Pu/8AAh7n0pn2n3/PtQn39Bf8OBl9ye+T/j7UGcdw f8AKEgsRmQHooHYe5oIAHDY/ofaqJTGBAP8AWPx3H/1qbhD2P19KhLsO/wDmIY17AEdcH+9/9agK e4z6UvUafYFjB9M9foRQ2e34mqYxjRMfvfUe/NAi9s9jn1pvy9Av3F24+6Dj+L2b2pSSOike/qPp SuFhGJ7nnrj2NNIY9MfX1FTcm3YAJDnIXPUEVGC/fPoR6GquWkNZ2P3gB2/GmmRz1bA+6T9Kf/Dk Py9BhU9hnvikMZP8OP6Got2Y/kJ5ZPr6D2qQW47MPQ57GhDJFX/bx7eoqQ37rwkg2jn6k+lC/wCA T/w4h1CcnJlbPQN6Ef8A1qrzSs333ye5Pc07+RS9fIruoP3uew+lCwsfQ9h7fjTt/kD8yY+4I/vA U0gdgMdPxP8AjUlL1Gsh7AD6d6aF9fy9KRLf/BHNbjtj0B9PrTChHQH6f59KaYhhjJPQex/wo8k9 uD0p3K/4YkWyY/dBz3X0x/hQLP3/AApJ9xer9RY7Ij7xHrn0pzQnucn27g0X7fIYzyT3I/2R7+5p u1vbPbNOwr9vQTySOuPw7GmMn/1j6UXCL7iMn90AeuO496hZF/u+5HqP/r0JDGsqnrn1+lRNCT0w fQ0ga7DZI2H8OfUjtUTRjuCPX8apvsxNEbIf6mo3hYdPw/8Ar1KB+XqKbc45/H2qPyvTI7A+oouN +QPAB159QaXy/THqKVxW8/QQ8+v+NKAO2fRj6Gq/4cF/wBdq9vzpVU9wfT8KH/wA9BwH1P07ilLE fdxn37VHqNMTA7/gfWnbT/h7D3qwQ/b7An1pdn94EnuPTH+FSHoOCE9ACO/0pSp7HjpVIH5ChSOv 0P0p6pjrn3PpSQWHA4+8fpTlc9ic9cDv9afqgHl2P3lBPQn0o3H+LIPZT3NL0Ka8gBcf1x2xTt+e h9s0egl/wQIB6sfqO5FOVh7eh9jSX/BH/wAMJ5bHqwHf/wDXQc+vHQ+9O4rd/kBLHqcd8DuPegBf 4s57D1xSKsOCehGOufek2juB6jHeiIP/AIAmSTwAPU+lOL+igemKqwk+4biOpH/16Yc+uPSpF6+g uT659vQU7ae4z2z7e1CQk+zGlR6e34e9NMPPH0I9RTsU/IRVA/i9jn1z60bMe/8ASiwl5hsXuSO+ R/nvTRGMcgD39frTa/zG2P2AjhR7H0FAgP8AdHv+HrUoVxfsxPt3z604wAegHr6mm/JFDPKJHIGe v4Co5IT/AHs9s/59KEhDTE3p9M9sUoRj1HHXP/16Bq36IBD/AHsemPehoiPT3HoaH5i9AMAPYfh/ h70PAO2B2wPSi4enoCqR/DjsR/dNM8th90Ln1P8Adp/8OSOPP3HUD1qNhno5NSl/wRsjLqOp/wDr UjX6DsAfX2+lS2UvL0My98TwR9ZMdz9fesS48eR/wMc9sev1oRLXcybjxZK/3d349vwqm97M/WVh 7U7gkRKWPUn2PrVyyJ3DGP72fQj0oEdpDclgNx6/NgetTAA9ef6VlY3i/wDIRY175Hp9BVhFHuPT /aFaxf8AmIwdfkjB/dk5/iJ9fasRZP7+T6e1ZTQ4/wDBJbeckHj8fWnBgO596wsbXLEcYYfdI7E+ tbHhvTkaQbsEDLgHs4HrW1JakVXoer/D3RYG3tPAjsSdmR95R/hS/FmGIW6pCkabjvkx1ZFPQ/Wv uILTY+IUve363Mb9n3xzoelaqs/xFupLeygUvpdsq5El6Tj5kx/Cvr/KvpvVf+Cgfge4z/ZuqTzA najBW4+nHr7fSvRwkE171SC6v1/4axy4uEua9GDenK2bvgb4gW+tAyaepMf+rVm9/rWt4r1eztyF uLzbxgQRdZZT/eFfN4/dqLv0PoMFey5l6nEas+9c3NwtnAcgRr1kz/eH1rgrvXUQqLJSUB3PITy1 eW/+Cekjqba+hlQMoEYP7tcnJVvr71h+I5xIFEk2+RSSM/3QKzfn6hB9vRny74r1AtcSbWyN2EH9 wVgLdEHgnPUGsmdFQW+vmAPzk+vuawA2T/MUQMpeo6WcBhtycdB6GpZjI3SMjviiUhQj2H2viC4t jmLI9R6j3FT6v8R7u6UBoY4h/EV/jI9T7Vo4r9SLf5HOMSeufqasWrKpyfrWqZDRcuL5XxwMdcH0 962k8QQeXjCZ6D/Z/GuqnLz8zOS8jrfDHjTTbVADIA/VyO49zSt4tgeUlHQAncAPf/GvewNXXV+S OCrDfTzRj6fKrQSBgM5Uwn0Hf8qqRogz85r4iX/APoIlgSxHoWP/AMV/+urmlyMrrg9wVP41jI3j 5M9RUl1OTx1K+uaj1TT0khX5AMZAI/iB968ts6bHFv4ddlPyMyjOR/dBB6n3rsfADyvZBYiUwxTe P4FHpn1rWb0/EqK/K47xlp6m3OXZ8c5bqc56Y9K8QjLD7+30OexruwW34nFiE7+6i3DAT6Dtkevt TjEy9Pyr0EczgaekpJu5GP7p9q9G0dnUdx/Cp9jW8SJL/gnpOixMFyBz0ZfUmu+061muiiW6iMYJ eQnptHqfUUpS8zGx82/EfS2ttUlK5XPKA/xqe5Nea39vhztBPUZPYk96v0MYR/yLum6JLMR5EbSH oAvY++K+ofhD+wjdXwWXxfvtbb7yW5HN1nPSM9M/p1rKvUt8O+x7uAwv2qy0W3mz2XxdZ/Dfw9bs q6PZMwBBZukYA/i57/n3618ba/8AFKWfcug77a3J3GResy57ZHSuajD+Z+ZtjsS7WXXbyRgpZgDJ JJ+859XNSi1XOVXB+8jDqpx2NeqvI+Tb8zoNO8W6tbY+y37OP+eb9OD3HvXovhz4/wCo2zfvI5oe yzWxILHH9welDh2Jt2Po3wj+1Xqaop1OeOeI4CG5G1uT/f8Ac9K9c0n4t6Bqa4vUjjPXypgCP+Ay D/61cso9kbU6nf0Ohi0OJedNu5EX7yopyrfQH/Gr0Rk/5a7c9yO9ZN9z0FIkopAFFABRQAUUAFFA BRQAUUAFFABRQBxvjPxzeWMsC2dvvRyz37H+GNMYycdz7iuf1Hx7qZaTKBYwMWioOXkI/iOOin2N elRgrfiebVb/AEPKb3wFfXJQ6wsguXy6gDO4A9z7Cu38I/sv2Efz66rc/wCqgOMyD3I/vV2VKumn oiaFNdfQ9Tt/AWkIgFlYRwgcKqdj7iiDRUgP3TjoMeleVz9zsl6Fxri2A/flUx/qiff0rH1nxZZI AWnU442+59PrVQizCpPscTqnjOS4/wCPOPy16Bu7D6Vo6Jp8qrmdjnooPcGu3/hjKK7mqAP8frTJ DjoakF/wS1Z+PIIOL5laM/Kw/ug+o9MVpT/D/RrpM2sKRg/PDPD3B9q5aum3zOmlPv8AI4TxF4Au LHBDxyochGXrkf3l9hXOBSew9D9awZvGXb0Ek00jp06ge31qqbRx3PqAO9JljDYq33h9R70z+zF/ uGhMQv2fb2PsTSeW57//AFhTuFhrxN6H6elNCA9tv9DQKwbM9cHvn/69RSWq9kH4+lVbzBlU6UG6 ce/+FMfRB3NCYiM6Ih7mmN4chP32PrnHf2oZS80QN4cg/hLn1XHaq8nh6L+7/wDXpW/yHfshn/CM ofuhh7jsaT/hGX/hkYdyc9/cmncGgk8N3A+64b3PcVWfRrnjf16UXJsUpNCnzypH09aRfDErfd/D Pr7n3ob/AMx2Jf8AhBrg/dTPcn0+hqB/B97H91WX+g9uKRTa/Ugk0a9HVAR1+rfT2qs9lOPvQgHo MdvxobFYrvFcL0Vqb9ouAON3ov1ouHL/AMAiXUrofeQ5701tWkH3lPoOP50JktELan/fU/XHb61G 10h6A5/nTbE0QuyHt9frUB2/1UHt9Km4+X/MjkTjn6g1XIPcAjop/wAaH/wBJeZXaI4+6fUD2qCS Js+nei/cdvMjeLHt6+30phhYdCP8DU3LRDsbuFI9PUj1NIyepPtjt9KGwX/BIXwPug+mKax/vL9C KVvMr+kMEh/2vTH94fWkI/uc+oPYCkkQN2t7fX2pBC3dj6qPQUm/IX9MFDdyW/un0FSCMnqR9BQm UgKHsfbHrQFA6g+ij0Hv9KP6Yeg5Rt6c+oPv7e1KMnqR6Z/ukelO3+QIcWB+8M9vrUgTPTj3+ntQ v+AUO871A9D700OvdMHoBRYVu4qn1+g+lNJP8QHr9BUr/gghQMfdUehz3/GmlVzyD7fX2p/8MMga 2A75PUD0FRvaA9eO+aAf/AZEYGHQFh1AHcCjyTxnk9x6fSgEweIe2OmPanLEnf6/WkNv/MUxqe2f XPYVGYB2H/16PmJ/8OM8og/0HoKGUnqSB/SpKt29BChPqfQUwg+h9BiqE/IXym9RjsPSgKw9Px7C gSGMw9ffjvj/ABpnmE9z9PXFH/DA3/kKRn7wx/hUilB0B9c+1IY77Svb5f8AD2qJrlT9xTjq34e1 O3mL09RkgU9s/SmOqj7uT3+gqbdh2Izjtn6H0pR/vH6U35egDiQDz19fWmkg9MehHt9KVhMRlz1y D0xTXhHfA7EjtVL/AIBVhcgfdPHof8PeozgdcZ/g9hSJ/pCrAp+8AfQUdPujHcY9frSTKt5eYuB6 e31pMHHyjnrTEKIM9OvTaP8AGh7cjsfWkhjMH+LHqR71GsRJ6D0PuKdx2FKDtmk5P19f8+tT/SFb zJo2Ppg+vvT1UfxfgR3PvTQLzBlYdfoaYXPf6A+gNP1B+fyGFfTGPf0ppUjsR6A+lFwSGgnuB7fS muh7j6e4/wD10Ly9RW7ehGST7diPU+9MKMf5gD1+lNP/ACBL/MZ5ePvD8R/9amlcd/x9vep9Cmxu 0f3iO59z71HlfQ+h/wA+9CX+QX/yGlAM8D0A9jUZX1GOxzSuT/ww1UP0749qRifU+31p2BPzG7Ce mfUe1J5GOjH1I96VuyCwCM0gQjuPX6j60AvIBEe/P8WPTFAcj0Hv65ppf5isODenXtRhj0IP1/z2 ov3Kt/mKF9R75/vH2FOLE9GI7Y9h/hQif+GHBeOAc/dYDtTguOo/KheZQ8L65x0A+lPEee+McY9c +n0oC/8AkLsJ7Aj37D2p2wepI6Jj+tHoO4qxA9Me59BTwBnoB70v+GJv5D1GOrZPUN6inDBxkg+n vQl3L/4dknlqegyPQdvxpVtQfuj6j0Uf4VSYh5tk/hDY6YNH2ZD0yPUf4VN+xX/DAbVB0LegX0NJ 9jX1x2IPqP8ACmxenyE+zqOh/wDrj6U3yVH3SfTPpSG329Br22Txj/69AjUe56D3NMVu4uFHUnPf 3/CmEY7n2FFhPyF8vPX6r9Kj8rA46+voPpR6obQEepPuacM/w/madyEuw4Rg9gT1OfT2pWXB+Uj3 Hv7UrefmV/w4mOOR7qP8KTyyeOAOh96Qc3kJ9mx2Hvj/AAoEYHUe4Jp2KYhB75A68U4e/wBce1Nk v/gDWcnr9PoKYB6sfbP+FMQu9j93BPY/T3o256j8D3NL5Dv2QgDdsfSlxnqR7fX6UykvIYRjtnvS uueRt9SPWpRKQ3cD93gdMetIVOPlHtj6elH/AAw3/wAAcFk/h3erEetMMDD+H3waaX+Q+Xt6FS8v 0h/1hA7j3Arnrzx9AvCPk9Tj1oE/+CUYfGjzE7c+nPf8KlbU5T95j6H2FclV9joopdTmNVB3/eY+ /t/9aqQz2/OtoPuZ1SVFPr9PrUhOP6UMyQiyD1+tW7I5b5R7E+1VbsTc6+0JAHX6e1XAVxwcf1qb 9jeCHK3r9M+lSeZ6/n7/AEpoPn5HPa6wz1B9PasjjsT6/jWcyk/8iSAkdR9KcxPf8axZaLsMwA4A J6fSuh8MoE8xtowFwD/eb6e9dGGWqMsQ9H9x7J4E0VjArSzMufnaMfxMw9PY1xfxjuXkuIVhcqir 5s+D29x719u9j4qgve+9nD+IL6G5Qf2QhwBtumH/AC2b2qjoVzJaLm+JAP8AqYcdDnvXmpu/uv1P Utptqfafwa1m3tbPfd3GAR5sEaj+MjsP9mojdzTO8kxjTnzWu5TgRL/vGuCe7+466C019DzzxV8T rYsQt3FeY+QENnGP7ormdL8fWsrkXs32deWV37lfQe9TOHY0b7I0IPFjFv8AQbkuv3iR0AHp9a2L bUpZ2J+RgAXkJ74B7VzSX/BNoy8vJnzp4guD5rkcZYsG9QfSsMTcjaT/APXrCS7eh1VBt/ICOTg/ yxWQJAvU89velAxmNjmJbk1q2kV1Mf3G4D/V7j0Vfcn0qZxKhI0dV0rSoI/m1eOe4/ighGRGP9qT 3H+fTmD5PdiauP8AwxMmIRD2Y0R2jN9yrTMyYaVMei5/oKcunyf3D6gHuBVKQn6ltdOmC8wn+99K zXuX7M49QD3rX2j6Ni5TttNuAIZP3a7uHjb+7j396qRnPQn3rzpLt8zsiTQgDt/9ardsSCOccgj6 A1nI3gerafKzIPcY+ox/SrTgNEfLxgHDD0YjvXlSOyxhvaE59+w78Vd+Go/dSqCRsfAX2bP+NNvR 6FR/4BvarJaRLm+tVuIgQ9xbt/y1QHpx6iupf4ofs/Xf/IT+F9zpue8IJCE/3Dn+GujCy9Tvw8G/ 4bgrau63Gt4B/ZwvR/omv6vprZ3Rb14iHtxUq/sg/Cq/50D4zyA/885QuBn1DYr0ud+RpPDv/l5Q i/NCw/8ABPNT/wAgL4oaHdL96LzHUEEf7K/4mtyL9hbxYg/capok464Eo+bH93I7fjW0a3dM4auF j0jUXTU3dN/Zh8WxDDW1q/csko+UD1xXWWPwb8QwY/0SMH7pcP8AdyPWrdRdmcE8J2mjznx7+w/4 u1W4V9MXTkGPLuJJpQCAT/So9M/4Jd3TtnxT4utrZPvSJbkEgY6AkDqfyqfbfypnVRw1Nfxm31SP UND+Fnwm8HDL3NtqFyOUnuACzOo/hjXjn/63rXIfEf8AbmhCkabuhUggYPzy+yAf3q59W9ToqVNL 1I8qWsV3PlPxR8UNU1l838jxxZzFbA/eH/TX61lRMvbGP5fQV6MY9j5StVbd5fI0QCOufbPepYvp k9Pqa6onnX8zRt4c+g7Ej1Ndx4f0a2gXzdSK7B/qIT1lY+1aX/yBsv3us3OpyA6i4AHFrCP+WSn6 dyPau68LPqEWPsOoTAdom6fhQ15eRMV/wT6H+HOs6nKyq0jJxlpAeML/ALJ9RXr0auP9YwJ7kdz9 K4aq7HqU46D6KwNQooAKKACigAooAKKACigAooATeKWgVzlfiBpVxNb/AOgRxNKCHjZzjYv+8a47 Qra8kTOoXcMz/dKp0Tj/AAr0KL01R581rv5G7pmkpJKnnHGDgj+8tdfe2hzkMcd19PpU1ZGsI6fi S2UgI4NVtR11YfuAM/Rf9nPrXOo6lylp+RgGdWbN87P/ABSY9P8AZFcjeaMbmRzbIwjJzCp7Liu6 K/yOZf8ABZq6V4JKcyhfZT3rcNmx6IfUgD+lNsprsSLpDnpG1Rz+GpnHCMPf0qOddWCgZH/Cuhn5 iQe5buPxp97ZjS4yX8Qy2i9BEp+8/wDspTbv0CT/AMkeQ6l4xvpZCyX10x+7CzMfufQ0608a3qf8 fkMNyvXkYJHsRXl1amvuryR3Uqdlr/iOj0XU4b/P2SIxEcvC5+4T/tVevvCd5D/rYGUdUx3rGFZP Z+R0Ok1v6mU+5fvgg+9IZ2/hI9zXSYNEZfP3uff3pp2jv+FMRMLiM9QPT8aRjH/dHof/ANVUkK4w pH2T6fSo2WP+79cd6YDQyDqD/hUbbT1bHtTExCE78/Xuab5qemO1FgE2oemPbHao3hU/wA+/r/8A qpDE8sjoAO+PUU0xn+JR/iKoBAQf4SP8PpSYQfeUfQ9jUiv/AJDlEH8cYPb6VJtsx/yy59PSgY3M XYHHoPWo1tY2+9Mw9B6Cmg9fQil0iI/8tR6YPeqE+jBegB7jFIdzNmtjn/VDH0+6fbFQJaQn70S5 6ZI64/xoYxj2Vu3WNQeh9qrvotsf4U91Pcf/AF6m3+YmypLoMXZF9CfX8arSeHYv7iDvuHYe1K3n 6l37lSXQE7EkdCR3+oqvJ4dU/dyff6UWC5Xk8Psp+8TnnHtUJ0RuxHsfrQ3/AJgvQgbRJB1Yew9q rvpEhHIA9B6n/wCvRfyFb/IqXWmSAH1/qKzYop9o3NuPVmH8X0FDYWGStIvUAd//ANQpSJQOIwT/ AAn+8PapFby8iGaZ1+9Ew9/TIphuyR91gO+R3+lAPyfqNFyG6Kfr/wDWpWZW6pkdPqTQv+AAvy/x j2we/wBacUBHYeo9fwqbefmCGtEexGKkCn+AD1I9hVJFWECkdOPUe5pxQdgPr6mgd+w0oR1BP9DS mLPYfUe9TcSQYZemCeo9vxoWN+xOe49PwqvUYojY+vp9TSmB+7H1wfb1pgSeW3YH1x6CmsjfxD3D Dsfr71K/4IfMTc4H3Rnqc9vpQQ/dOOg+tD/4IMaWJ/hI7H3FL5Pt+FIE/wDMjMQHXJ/xqNrU9lJ9 R/jVW7sXzGfYGP3VA7rj1PrR9gYfeBHYH6etDf8AmCX+Q42rDt7Z9vpSi29R9D60ihu091Ht9Pak Kj0HqQO1L1B+QpkUfwD29z71E756k46/hRb/ADJY3Yo7Z7YPamlFH8Ofb2pX/wCCCInRT2OfT0pu B9D90e496bRVv8xMN/Hn1P0oKn+978djSJv2GeSc9D6Y9Meg96PLx1AH+z6Gj0HHzGtCO2R3B/wo ELH7rH3H1obKt3JEsieoGfSlexcHlVx2A9Pb60BYY1lIv3wM9QPaojCe2PXA9aF5Ca7AIWPb8DTG H1I9/wClFxsj4H3T749qUW4PLHPse60vQF6eaHZP8A47n3p6g/Ud/rTSGn3Gm3X0K/3x6tSsgB74 HGD6+4o/4cljhOV6Io9Cv96my3jv94A/wr7ChPuP/hiEk+nt9KUA98fX1NKwJgo9AB2we+aQuPQe n1NCRKQbT6H296mHupJ659qaZS8xCD/dHpj1p3ljuB9felcLdxhjHcfX2NNMB/pg9qEgt/wBvkEf dwfT2IpgQHr16Z9DR/THf/IYyHvj1H1pjpnuPcntVPyJS8yLYexAHXNNK+hHofekwISnsD/WmOh7 /j7Cj/hx2Gtx0yOzD0NRs3qT/s57ikkFxpPqfy7im5PqT3x6f/qpolr/ACEy3c475FM8wdwx7YpX /wCAOwuR7e4pGcHpn/61UIUKPU/T0NKij6+vsam4/wDhxQmc5/D6U7bjoP8A9X1oa/4BXqOK49PX jsDRgDoAO/Hakl3F/wAOG3PYeh+v/wBapcDHTnrVeg/+HAr6Z9/rUisD94fQ+p96X/DgvMFQjoeP 5GnBT2JP+f6UhIftJ6HA6N9KURA9Bnt/vU7/APBG0OEbD+D2K+v/AOqlK47fQelA7DwWHQkGnqxP UnPUH0/CmhMPNI7k+p96Xz2PT8an5Cs/1FVs989gD3oAUfeXnoPY5/rQ2V6+ooT3Hr/n6UwEd+vT I7mmh+g7co7H+6R6fWkVl7g+x/xpi9RDIP4Rz/F7ClVx3H+yT7UEvyXmKRn7y47DHp/9emNCB/Km h3/4BGLdvT/61O8rHqe3Pakx/wDDsURnPBPuKcI/oPT2/wD10rlWECHt+BHp/wDWoIPGc0CYoYD+ HPYn2xSEuP4QR0/D6UPzHbt8xwVj1Ht+NIbM9gT2J9D/APXpoloYbZu3PqD6U37M5z8uD059B6Gk P0QggPofoO9P+zsfvq319qL9wsH2YZ5BHYEdx70v2Qjsf9kj+tTf/Id+xDImPX1x9KhMoPQA9zjv +FNvsJofb2c7n93E57cDrn0PtXWaX8Mr2UZa1cD++f4frWkf+CK3d+ZvQfCcD/Wuo7kDufbHrWgn wx09eWWRz0IPYmhIfP2PGvjho0NpLGLICNSpLKvds9z9K8gbH9frQKp018y3pj4buO4Poa6FBn/P WuGsbYcxtagUEbf+BD3zWaFHataY6yH7vrT3BA/p61ZzCKh/u/hWnotqWb5lOO5/wqibHV+QARhT 9Pb6VY8licbc9z/s1L8vQ6kSRRD+JgB13epH+NPMI7Dnqvufeq/4cmRzuqwZf5iQerD/AGqqjTFP f6VMkTF9mRGMIeHB7k+hokk9D+fesJI2iyW2wen0FdXoNqfIby87mbbn1APb6114KOq+85sW9H9x 774atY44kWNiMAKQB3/+tXjnxEW61C6kTS1V3B2SxL1IH/66+vqPQ+RwiV9TGi0KbSAv9o2cgdv3 UVuR9+Vz7+hNfQeifsieHHhRtf1a4kuWAnnRFGIEPQLn/PrXkuVtrHsSunt5I3/FB0nw/bA2d6Xi XEcNu45lf0r5f8afGbVtTY/abuRIesNkhwsa57oO9Yx01Z1x9D0L4efBzTtShDQeJLZJOsluAMpI B0/z/jTPG3wYkt0++ky9fNUdGxRd9X5mVKp0a8jhvBGo3i3HkzXUUan/AFTycZ57sa9fTwhexjC6 jbtnKkK3Cj/a+tczRrKaT1v/ADHkPj74czWJzPLGQ3KBT0DHtXABVB5b/wCtXNUR1c99UV7uISHv 7VTOnfU+grOJL/4A5bIjpj1zTmWQj/XOB3QHqT7UBYqmyA6fjiovs/t/+ummSxY7LPXI9PerK6ee zEdvxqhIhdmHR2+tKl5MOkjehHtRcGu5fXxVdBcblx0b3qg0+f4R6k+9DY1/wTstPkIhk3KoHClh /CxPb61VgfAG78fqPWsJep0Q/wCATxyYzgZqxbyAHofcelZGsWeqaBOHjXB5x09Bk/yrVjjAjfhc 8Nkdq8mR3GQp9SSen1+tHgGXZLcq5H3hID6KV9Pcmn3+8cX+TRu+IlYwuAoz95H9CAe9eGya3cxs dxHHAB7114OO9zGdeSfuP1Hx+KGHWFT6g96mj8UQ5/eWEPouO1dro9n5nVTzN/bRp2Xj8KcR+anf 5ScY+grvNH1/X5I92naveRoMCRg5+Qt2Kk9+avkfdnbDMo/8vEjtvDfx6+IOnbl0/WVkVx5RSVd2 znrGT3zW+nxG+Lc6/NMcD+8ME59TmrUH2MXWpXu5PvYo+L/iT8R9MhV9fvGtoidq3EYJLMewPv8A SvLtT/aY1Rx/pfiDVbrtsDYBz6FQKiEH28grY2l9lX7HHXfxh1CX/jyt1tj0adjliPqc9awvtksj E3EzSOeS7f8Asv1rthC23zPnMXiXL4npskXoZB3J9QPYVdt3Gflzj0P8QPvWqXc841snbwfYf7NP iHqx9QR61ukcrNvSrZSR5pG0cvnv/wDrrbuNU89uBtQfJAh7YrSP/DCl/wAE2tKgPoM9WP8Asj/G vXvBekM5G1D9KtouP/APorwP4UngYMYSFxgsff29q9Crzar/AMj1IhRWIwooAKKACigAooAKKACi gALVWN6xOI4yf7xP8IFUl/mRJ9vQl8k9mI9feoLm2um/49boRHsxAOPwNCfdEuPZs8n+InhPxcib /wC0Tf24/wBdBFwYQR1aMDkZ+tc/4Q0fxOxB0zSJQn8RkyAGx3J9a9anONvwPPVJ309bnpkOiaqw +eDyZR0dSOG9jW9oN/qEyMNZtFjkX900inidSOoFcdS36o6orzRX8N3jyCQAj5W8vB/hP/16be+F 7pjlZlPrj/CjmSeouX/Mrf8ACPy45Qk9AT61bsfCjKP3hHq3/wCqrdRdxKH+Rqpo0Q6jP171YFrG OkaiuSU2dEYIcFA+6PyqjfeKbC3/AOPy9jj9VP8A9alGLexM5pHE+IPjnp6j/iV2ss8v3VlYYEZA /izXj2t67e37k6lOzc5SPPAH0rtUbLc5Fq7v1K8ccY+8w9QPSq2p61BbIxlKjHAHrIfYe9eXKNvz PUU+3odZ8NIXKB5Cctkkn0Ht7V6Vd38shAgVpD93H91c9/pXhU1Z3b/vs9St5f4S+/w1tbj/AI/o xGeiFeecdzXN6v8ACa6gybVvOT+8vXB/2RXTSxqb/A5GlscpPpzofnVx9Qf5VWkjx/X3r2ovscs4 9xm0euB1PvT90f8AAB7n1q0Z/IRpfTPvUfn/AOfenYBu/P8ALPrSOQe4z7dsU35DuR+cvcfj70jy L6f/AKqZLI2lQdaYJ0HRiPb3pDGmf0YfT1prSN/eHofagQ3zz6n1J9f/ANdBn3dR/wDWqQG+djpj /wCtTDKR06+nqKod/LzGtcMf4cdwPWmeee456/QUAMa5HqR61C1w4ztnYeg9KTYNEDam4/1gDdtx 9fpULakh/wBZCp98fzpMq3mVzND2A9vYVE0adnFNE/IqyRH+Bz7j1qu0cn8LE9x7j3+lK4v+GKxe YfeTI9R2Hv8AWomuWX7yH1I9qL9zReRD9pUeo78+pqP7UCeo/wDr/SkCY15F7EemPc+tQFsdAD6g /wANSK/YheMt94D3Pqo/wqkNPRR8qkjpu9MnvTZfoRPYI3VUbsQf6/SmvZAfd2gd/oB2pImPmQXO nlsbFX0P+2T6/SmS2AYAMgyOCvrS+Q/+GI3skGNsZ9DgdB71MdMi7KfUY9KYl/wwz+xYj2Oeox60 1tETjaoB6EDuf/r1KNLf8AQ6Mufnx7D0am/2UfYev1+lJEjDpTHoM9z70f2a46qT2A9Px9qpeY2u w7+z2/hPHQ/h6ULZjuBjuP8AGp9F5iHf2Xnoxx0ye30pV0kHodvYE9yf8apsBRpjjofcD0NKdPbu c9z9alIVw+zycYUEdj6fhSGwJ6qcdG/+tVFf8OL5KDpGff3+goMSnsfXHqfahh6Mj8tB99CR0/Gl 8pM/KvbcT7/WhGbfYaUTspPoP8TUjWqY+VT6nPbNSkaN9hrQAdBx1J9TUQX0UnuDVW7k+hG0Hrj/ AOvUMtv/ALRA+6MdqPmNvsRmP0Ptg9zTCpPVc98D1pMm/wDwAe2B+8APUegqJrQHoTjopH9BSXqX /wAMKLFj1JHcH1H1pTZE9xjsfU0Jf5gQvZH+Ecdj6n/61QNbEfeyfX/61Fg/4cXy8/eX8D/UU0qf 7ufX3o/4YGhCCOR06ED19xSGMdgc9T7H2o/4Yn0GgHuSP7o9RTQ2OmPQf/r96SLf/BHYI+6w/H+p pfMbszHuQO1Jf8BibEad/XPfPtTRK4xsGe+fQ00/+AF+/qBcnlsnufqarlmPRf8A7HNH/DD9PUck KL/rCT7elJ5p/hyF9u4qUu7FbzJIwPQe3uKeIifuqPU1a8mP/hxxspB95B6nP9Kikjx6+g9qXqHz 80RAeuR60u3PUf7pPpQw9fUPLHYezH0z70PEO+PqP8KF/wAMHy9RWjTjr6MPVvpSfZ2/uj1/ClcX p6jlt/U49B7f/Xp6xDsB6H/ZPv8AWhFJd35IacnqDjt7n6UoB7fQ0CfmBjz7d8Ux4yvTkd8+lO/+ QS8mNKEfz/ComX1x9PSj/hwX/BYxoh3x6j/Z/wD11GV9h65PYfWlcehD5YHqe5//AF0m7PUfl2I9 6ZKRCcDqR649cVHgH7x49PWl6eg7+XmRyH+6CPb61EYSO3HX6VP/AAwn5MCR/EPoKjcf3Tz0z6Cq C4Mf7vSmbgOufY+mKSAQj1H0+n0pd4PTI7D6Uf8ADiQgBHXOOn1NSBCP8D3HvTfkNR7jgoPbHc0u 0epx/Okh/wDDscDn7o+nvSlPT6jHam/+CFuw4MT/AAAf3j6inY9PoD9aF5MPUcV9SMfwn1+tKq+p HsPQUNhckCeo9hjvUnlY9PQ47ml6D+QoYdgR2wfT60pb39hj0+tNLuJjtx7cd/w/+vQc9gaLf5le g7JPYex9Pxp6pjrg9s+pNJvsK3+QG3+o7HHYn0pTbn+HJ7AnvR/w4W7ki6eT0z68dvxpw0xj2Y9s +31p3/zKViVdGf0P+IqQaG56g+2PWgEyT+wWHTHoc+vvSf2GfQZ64+lF/IdhP7Gb/H2Jpw0I9mHr +FVcB50M9lOP4Sf6mj+wGPc+4NT/AExNDv8AhHnPpjuPWkGg46D6e9DKa8hp0Fh1H5dzSHQX/jx9 P8aEibiDRQPXHUYHepBo8f8AECT0yOx9xSsFyRdLt+6n2z7VINPhB/1YHr7f/qp/MLjhBCP4Pp70 1ki/55jH8XsfrRbsJjDbQjqmB0/CmvFCv8I92+tL1HchMsA6Kv8AgKqS6rCv3tp9j6VAm/Mzp/Fl ov3pY17Dkfe9/rVyG7MoBRhz8yEeh7rWVSSXxPyRpRV9vVmF4i8S/ZMgjno2O9c/oPiue4mVWUBC drE/xcVpTkgqQ8/M+lfCnhyzjx/o6k/eLMOp9h7V191MwGBjH3cD+6K6oLsc1/8AMyDHk9T6kf4V Kbcdj749BWqX+RTXmfP/AO0NColhIJ+6Qo9ct/F9K8QK+n4/Sspf8Aup09Caxcqw49s+ua6SE/8A 6vSuCsa0GUdYgyoIyeze1Y62zHoPp7iro+ZpWL9n4avJv+Pe1lc9AADyfwreX4Tak5HnqsC9A0h/ nWxzNdzcs/hNp8Y/0/VWb0SPHI92q7HDo9sf9Gt1J6M7H73/AOqlcSf+ZmXGsJI2USNR0UL2H0qU z553HONvHce/0pM1TAN9Pr/eqXBPf3BPYCnFk28znNRGHOcehP8AgaWI46c/0+lXYhf8Ey7pvm+X J96egyOfqPcCuaZ0xN3QtDikUtdz+Wmdm4clmI/hWtCbxxZWO1YYpmA/es+OWYnsK7sMraq3Y4sT rp8zobP9qGKAf6JpE7HorO33D9RVr4WftQaH4aupbjUfAC6/cyDbD574Flz/AAryOeO3H48erKvf dtdG+x5FPDW6rzPYG+N3hfx8yveeGLbSriMicW4OQBGOAhAH1/8ArV3H/CQx9m4H3Fz2HpWMmvst 90bcz+300R88fHTxXc3EyRQOckiONB0EkpH/ANerviP9lAw2itp0qST7ftFwnYnHPPt/n0qJM7FK 1rr1PP8AwZpeo6dIfsc0nmcu1sM4BT6eldzL8f7+4Pk32mQKT8rTDJJI9c/4VN/Nmcqet+25554y tjZ3UbRqQep9w3r9Ca9Kt/GAZBhiDjIx6ikxVFt6WOB8ea8020bz13P7kCuCIHc5789q5ajNYbFr StOjnbEsoQdM+grX17wfaWzD7Pd+auN2ffHp7GoivNFJ/wCZzk6qp+Qg+/rVbHr9azZqIxU9B9Pe oCmPX0pJiY5G9Pripwcjp7H61fqZlGQ896jBPpQMXI7fSmk/X/61AHoOmRxmCXzWYE7VHHBfJ71l ouO+fX3rGR0J/wCZaUj09+OxFTwA5GAD3+tY3N/Q9A8KXRKDeD6AHtj/ABrq4SCrgkgYxgfxfWvN qI7GYscZB+UY9T/n1qPwopS+nDqBuXzsHuUX09jS7+gR6X8zp9XLNGfl7YH+8Ae9fP2pgiRtx75B 9R9K6sA9/vOLFdCqQff0oCn1HufSvZPPZPESDwcH+96fWu+0TWfLXmVl6BlH8f4VrBf5ibPR9Jvo d6FZ2VuGdB6D0Ne0+HdYW4RmadpTkeUp9Rnp9P8A9Vbv0M7eZT+Onh559GkY4JTE+fbNfEV0oxyB /ex/gKyjsZt6v7yrGfSrUR9fw96peQGnB7gD1PtV6FT7+3tTS8yL9jWiIK989PpUsSN6g+mfSt15 HKmalpOwGFP++T/EAa2rK3J6c9wPpVxY2dz4Z8PzTuBDExJ4GPSvp74f+B4bUD7QoeTgZ7A/T2oq y00Kh/wx7ZZA7R+g9qsV5bPTgFFIsKKACigAooAKKACigAqOW5RB+8bA6k+gpomTOebxRqErD+x9 MaWPOJZpMgbf9nI7/pXRqv8AeUA/xAev1rWpFdH6mVNP7Xqh1RTXiJ94/QCskjWTKE+vlfuQK3Yh j1HuKoP4guT91wo7BR0H1rqhHucc5Poyub247TyDuT61t6TcEg7nyev4VdRaaIVPz9DnPDszxXcy nof3mP8AaGO3tXZ1jW/Q6KO34BSZFc5sV7nVreH/AI+Z0j7nPoKwbr4kwj/jztnlP8LngZ/EVvCn /Mc06n8hzWreLdSmH7y8itl6FVIzz/tfSuTvdQ0xQfteotI3JOcnBPpXUl/Ijm06u5yN94nsj/qG Yj6dTWJd+IEP+riOeo9615e5HN2MS512YdAR3HsazbjUzIMXKFgein2NclaK2TOuk31PZvh5rFtJ EiplXA2uD3J9PpXrmjwJCP3Z3MeWk/wr4LMa9tIejPo3Hv8AI2Ipj3PuPpVpJcdDXFh5d2ebNFLU PC9jdf8AHxboG6+co559frXnHib4Z3Nr80CmeHoZAPuA/wB9RX1eFq92F7/F8jjZkI649/pUDsB9 017SOZgt4B97659qf56H0p2JuI0i9qQkds/WmFxhx6j2+tQyKP6A1INkDRH+/wDQepqMwH+NT7e9 Njv2A2zdmPuPakEJHQ+34UegCiFh3P49qUqR1NAxuz1zQx9QfofSkCIz/wDr+lBjB7//AKqGNEMk an7pYe/rUEkXpx6+9AyIwr/EM9z7GoXtlPb/ACPakNspPagdGI9PrVWW2Pr+XqPWkhX/AMhhVgO5 7H2qMux7kdh70Mr/AIcZvbnr61XYt3IJ/hJ7j/69J+QW8ys8Geoz/eHoPYe1VTbnsPYn0pMhIgMD Drx3B9QKiZpB91uO59P/ANdDLS7kTSSD+HJ7kdvqPemmdv41How9/ej/AIYbEMq45XHY57ioXKHu Qe2O49zSRP8AwwwbT/Hg/wDoKj1NG739g3qaJDXkIz/883J/vE+v/wBamcjox+voPap+QMUyt2OB 1Gf4hTst2U+o9gPeqS8ykw83r8gHoBQx45U+vFJCfmO3n0z6n0o2k9R9F+tO3+Yf8OO8j0UfQd6P snqB6jHel6MQ4WLfwg+uBR9kY/eBJ6jPb/8AVSsVYT7JJ2B9c+tAtJD91T6FvequJocbSQdAf9n6 Un2Zu4PqD7CpuKwwQnvF/k+v0pgiH8cY+v8As/8A16pjt2BhH/FE3sD6U1oU7EehHo1SCIvs5H8R HcD0qQW47HPqfU+wq0wH+So9c9vaovJx3Ho34+1C/wCAC8iM2iHoc+lMayB6DnHBPelb/If/AA5G 1ivv/n1pFsMdRj29aGxCNpwJ6Y7DP9aRbH/ZHrmqXm/QNej8xHtj6H6f/Xphs/735fSp9BDBAe6k dsj+tMeyz6f4fQUkvMpERsl7EfU+tRNZKP4snuBU2C5X8kfxD/6xpVReM49eP60W/wAg9CN1XsPb 8acsa/xIT2+n4Ueo3/ww2RFJOxSB1JI6keh96hCDnjB6t7Gj/hwSGM5//V/EM96a747n1Bp38if+ HY0Hd0Ax6+9WEtVH3VbPQgdznvQmXYQog+8hPb6Gj7OD/eHoB2IqbB8x6WhPTk9QT6f/AFqtrpks f3lP94H2/CqXl6BfsQNdSr2GOgJ9DVdtx+9j/eHc/SkyF6iGBj069Pr+NKtqT94E/T/GnYosf2cM dOfUdqja0H91vXPvSt/mJvv6CrZD/wCv7n1o8g/X1NOxQLZEnjmkNvk8jHfP+NCRIG2x/Hn2NNMf oo9/akvMaXn5IPL9c+x9h/hSNbDsTjqT6Umu47DPIHrURgB9c989/wAaaXcP+GEaJfT6iq7J6c9q Bf8ADEZhA6jB6H3FQsvr9M+v0pLyF6EckWOgOP5VCyD+6KLBbuRNg9Mf7R9f/wBdRhc9c46Z9P8A 9dP0KGtEf7x9x/hTRHjrn1GPWp9SRQB2Htk96Qxjtz2pjb/yE8sewPT6UoUc4Jx6+jUBbv8AIfu/ vnP900GNu6j1PtSS8/IL9vUcRnouB0JHrR5A/Dr9cU0wsKkX4f1FSeR7e3Pei4X7Id5JPYY/vetL 5B7gfQd6fqNeZItrn09actsOxHvntU/LzAf9kP8ADT1tT689wKX/AAxUvUkNlnuM9T9T609bNeOR /texpsglFiOxHoff6VJ/ZSnuT6+4popEw0xOx47Z71KNNX0HoMelCRT8h66V+P8AdHqKlGlKf4F9 D7n2FP0D1JItKJ6rx29v/wBdTJpwHqe4PofrULzGTCxx1A9frUiWhGMN7qPerX/AF/w4ptgfvA57 59/SlFmg6I3pn1H1PpRfsK48wjsg9CPSk8le8Y9vcChjt3Axjj5R/wDW+lOKZ7fT2oGvMUhV6MT7 e/sKZ5II4z6ih/8ABEvUTA7nHqf71N+zr3YgdfqaLiT/AMhm1e+MdOe5qJmUdV+o96T82P1K0rg9 AB2x71XNyB1IHtS9PQGitJrCL99gPb3+tZ0vjG3HWVQOjD+8aVwt5GVefE63jzukDf7Pt9BVGP4h vOhNlbFh90MfWhMiS7mHd+LNab/Vwxx9iTzxWBqGoav1ubxwOhC+h9DVX8gt5lbQPD1xqU6IJZHG fOu2P8FunXOfavaNJuYZpCLNVCJm2iXsVUdz715WLd2l299ndhV/8icN44nBY4A65A9Mf41l+D4S Z48ttG758dxXXRWhOI8j658OQgY53dgT/ntW7frnqPb5e5r0of8AAOFL/MoxReoP+8PSpZIx2A9c n0/+vVIH5ngP7REIBgJ3dNgP+yCf5mvCGib0PuB2z7Vmyp9C7YaJdSEeVbSNzgED+ZrvLH4cahJ/ rY1gB43yHp9RXJUj2NKTt8Rtv8KNMwP7T1cH+J0iA5Ue5py2fhmzH+i6XHI3TzJTkhs/57VUY+fm E6nZFK6+JiR5+zmGEdAIwAdvtj0rnLz4tBuIy7j37mn6GVv8jEuPHF3J/qzsHb2FZ8mr3B+/Mx7E ev1piRJa6ky9WI7n3rcsvEat/rH/AC9aoF5ehsRXCnoVPcCrSrnqT7YpI0MK6G6Q5xjt+A7UjW5A 5GP7v0+tU/MUTDd8k5P09xU6MPf1HtXLM1Xma9jqMartuELAnKsP6/Wr9r8Nb7UZgIwkYPyhW7D3 r0MLG5xYmdtX8jpr39mOe1hd5r2BkUeY4B+79cetL8P/AII6FfxO+q+LbS0YcwRP/GAD0bPYf564 9OrQtscFPEJ/DHyZu+EtL0WzkYaHfG+KnZLeIMK/+5/vV6hb3jleHYVxpPqb1F5HivjiNvt8ZuXZ wHVwV6Yz3r6Pl1MPASkgjUpw57Lt7H60P/gDq7r0ufN2lePP7OuJXjCu5zEkjfwRn+4a5qx1O5vL 5Ps0LMCd0pPRYx3z9at+RtPrr5ifEzVhLdgRsG2/I5HZlx/Kr2ja9uADg+gHtjuaxuZzW1vQyfFM gJGzcP72f71c9FbF+n/6q5ZmsSXT0YE5b2GKlv52P+ukY4+VPYUr+Q0l19DEeQk8E1Gzn396gYgY 07Pvnv8A/rpDTGqxHQCpVJ7/AFqrk2Krk9qYPxpoBCaUAHofahjR3odlt22YGWUOfXGeh+tZkQPc +5rnbN1/wC4q+h9vqKntlPHOP4c+xrM3Xkdj4blcgASHrnjtXa6TcqZGV1YgD73qCD/WvOqf8Mdi 8zOkjIbCkjuf/wBdYcmqfZb5DGDuZDECP6/SiKBbrXyOyu45pV/dTIW6gA/f+teGeJ7N4bhhLGFJ +dT6p7fjW2BkcuLRmrKG6H2+lAOPvD6H0Ne2jzGWYyO31Y11mjxIw5z6/l/9eto+RL/4B6HZyxoy mNl3Y2ke3v8A71eieGL5gwPmsAfl2J0P1Fb+voZp/wCR6r4r0IXelTJJcHmMyAH+Jlz2r8+5WBHC n+6R9DWNN6fMmotXfsisg/8Ar49Ktxe/PeqQjSgz2+pBq/EpPc468dz/APWoIa7GvADtOWX+7n1z 6VNFAfU+pHoBW68jnaNS2hHY57nPqPSuq0LSHlICKWY/KMdifX6VpH/gi9PQ+l/h98LIrdVLyZkP Lnule06F4bIxsQkd2rCpI2S7eiO0ijCj9KkzXEd8QopFhRQAUUAFFABRQAUUANklVRljgdz6VElx DKONrjo4P9apLsQ33HG4RemB7CmNfRr958ego5WS5mfdeJMcQD23n+grJl1X/npIf/rV0QgYSkMW +D/dyfengr/FVi9SQeWe+KntLgxNlWBHRh7Gi/cLdiJNNaO93gHy2Ugsem8CtuTX7VPvTjP8KjuK zqLa3axcZWM668Z4/wCPe33H+8T0P0rn9S8e3C/624VP9lBz+lXGC6mUpPqzlrvxVNIflj3dwznv 9KxrrWrtv9ZdMg7BOw9q1bJUf8zFuSZPvTSP2yf4h9Kz5dGjPSFR2JPfPrQ5jjAoT6Uq5+Rfoapv pvuPXA96rm7jUe3qZ13p4xlyAOu70/8A11z11qtvnC/MegJ74PrUSj2KjPv6Hd+DfEHkkZYD/A17 foXi1GA3SD/69fnmZ0He9vM+mpyutWdVDfo/RqvQ3A7EV5tNHNUgWllHY1JuUgh1BU/K6nupH9a9 mjUOI8j8Y+AvsrEwRN5R+aBx0VfQn2rgpwyn5jx0FfV0J3Wj9TKov8yIS56ke1PW1J+4wJ6lfaum 5AMzL0Uj1x2NNN449f8ACkNIaNRI6qPXPqPpS/bEPf3x6fj7UxepEbpD0+lL9oHY570x2GNe+uT2 IHel+2IeuR3qQFMy/wAPPqaQsD0z/wDqpMbG7wOjH3Hv9KRpCepGeh9hSAY6t6cd6Zlh2+lBVyMy MOx+tQtMP6D60C/4YayHH3ge596hYMOx9AKLgQsB3+vP+e9VnAHQfX/9VDF/w5XkIPp747VA4H0H oam3cpFdn9CT2H096rSyE+w6j3NNB6EMoGe5749Me3tVdrj0x6fWmw/4YjeQdseh+lQyTL3A9T+F Z3C3n5kTTqPunnqp9D7VGzj+Ig+57mmvMt+RCyqepPqD6VC5X+HOPvM390/X3qUTb/IgLr6kf0FO 357j057GkykvIQse+fQgetMMh7g/3enb3NFwf/DDhKvqfRs9yf7v0p4uPqP4Tz1+o9qf/DDuKJ/7 hz2p6v6gjtn0z70f0xW/zFDHtnHUMe//AOqpAOeCD2z6/wD66lBbuOAI6fiP8+tORsevoB9f8KpD ViWOdu2c/wAX4+9TCXI+4PQn1FOXkNEguR/Eox1C+lKbhccDH8XTv7Gp9CfmOE6kcqPUE+tNLDP3 Qff2qrBdgUU/wAe/pQ9jCfT0IHr70iiJtNQ/dHsPcCmnRV5yNp7kd/r9KEK3b1E/sZSepJ9PQ0z+ xWHQ/QH1H+NL5j9fUYdNkP3vwx2qM6Qf4frj3NAho0lx2we/0qR9Nfso/wBk0XK9PQrnSJeyKfUE +lH9mTdfL46Ejtn0oYrDDbP/ABIR2/D60w25/gT8T/dqhjDbH0PrmomZ+65HbPb6VNyWu3qKAp74 Pt6//WqJ7cnqc+/pSFYryIB291FQsrHoo9Wx6CquNEf2Rv7vHp71GYR/EuO2P8amw79hhtT3H/66 NrKflz7H/Chf8APkNV3/AIgvsR1OfUe1Ibcd+Ow9wf8ACi3Ya/4JWkiA6AHt9fpUCwM5+QD0+h96 PUC59jA7fh6VJHCw+5kds+o96d+/zFfuOGns33VJ/vfT/wCtVuPw7Iw+VT9PQ/Wi/YSXdkkeitH9 8rn0z0xRd6gxACsQOrAf1P1o/wCHHYzZLZj2z6//AF6mgs1P3s/QevvUhb/Mm+yoOCoz1H/6qeIc fdXHYH1ov5+YX7jWiI7/AIev4Uxoz/CB/sj/AAqriY1oT3Az1+lNMDD2/vfX3pX7FDHjfH3fYY9K GiP/ALL+FNeoP/gDDDn72MdMUmwdjx3OP5CgPUbsJ6lgOoPrSOPYAd896BW/4Iw9fb19xTGPsPUj 1P1o9RJETJ7YHoO9QtGPQjuPYVNuw7Eb5PY+/t9Kh8r+8nP8JNP5hcY6HuAPXHrULRgdT9Pyo/4c ogMSAck+wHrTNyj7zDHf6/8A16GTf/IaZFHrj0/wpu/1Uf7PtQT8huR3/P0FMOT2/wDrin6h6+op Lf3fofT6U0j/ABPvn2o9PQpihz6/jR5hPr7+1Kwk+w7cfXPcH0pUlA6v9c9zSsNPshyXHqSB2/z7 mniUd/ocetAMf9o9M+mPUfWnpIT2P+zjtTaCxKGfuAT149qmWF+8ZNO5SJ0tpfT3HtU8emTHqefu vx1PvUf8OHKWV0eTvkdiB3NWI9DY/wAIz057fhTbHYmj0Rj1P/16nj0wDrn/AOvTD0JV05f4gfX6 VKtmvYD1zSuCHrbqOmR3+h+tOFuvZR9fX/8AVTXqA9YQO35U7yc9B7/U/Sp/4cpC+V/s/wD1vrSm P6jsMdqaBIFj9Rnvn1NOKE/fJA7L6/8A66bX+Yl6+obSehx3z/gKTygOv4H1oGvMQLj+LPc0wkfw /ke1DQv+GELehHp9aazgdCfUj0HtS9QS/wAivJdHHJU+nu1V3vx/ER9fSlckpT67Go+Z89vxrNm8 WwqP9cnrjPceoqW+5aXZGRd/EBB/qgzdgf8A6x9KypvFt03f33egHpXPKp2+RvGl3MfU9auXH+uc f3m9QPf3rIZWYjcxbsST1qVLuauPYoaguM4+h966jwrABAMYPO7PqSK6IbHDU3DUZpF/1SZ9vQ1h 6uJDGPlyxIVEHdiew96q/wDmCX+Z0NnZR6Bas13kX0owiHrbRnsfetv4cxyeRl85ObiVh3Jz3968 la3f/bkfQ9BaWV/77OX8ZzAv367uO/PcVF4YUJPESSPmBYf3hXoUel/QwxB9eeH4FAGQcYyp9Qfe ta8VQeM16EfI4ov/AIJEhjT/AFrqo6Eseh9/pWTqHjPT4h+9ndu2IxnOPWtUv8yWzyf4gRadrJX7 XM8Ua/dA/iPsK5GHQ/D9qD5dgspzuSWU9FUfwiuepIvXqNuPHVnBjyjBH6BMZB/CqVx8SZJP9VKz jop9qwnLyKhEyL3xLcuDhyD7etcjPq1yx/eTye4FZxkbVIlff15z7nv+NVkOfStUc0n/AJkyg+uK fj6e9NiQ0n34qxC2Pukj3oRojVh1YxD94xx95j6gV9FeHf2XNXu9OS6h8vymX7SsWefKIP3/AMf8 +m8I/wCQlJX97roeIatYPDKwkGDnG30I/wDr1Tu7ltvLH2Hocf1pzj/kOS1OfD8/4VcRcdea4ZGt +5o2VqGdRnjIJHqAf617L4H00zysZpSqj7qjuv1r2MqWrPFzWWmjOl+IblLKRbduW/dJnpjH8Rrw nR9St0K26EtvIjmkx1kb+77f5Ne1XfdnnYTb3e/MfTejfCLTdPVVsbEJxmV/+er/AO0frVtiGlEV nHbq5BmaaXgIi9g3qx/+vivCp+b8z1U9NP8AEfMvjDxoWunE0CvtYxJMh4bYf4cetdC/7QbTWwjZ 3TA2SNjl1X1PtTl/wTarF30Mjw74dt9ScFoXZBywP8YJ/iP0rrte1jQdGQ/2bFCblhsUR/8ALID0 9wapIzb1/M4Twv8ADi71VjJe3AjDfMGf+Ik1oz+HBaTFBKrY+83rmsJLsXfsYniq1Ckcn1x71zS3 LL9z8T61yyNYkcV26ngbj1oub1m+/wAd/rSTGl/mVN6ep9fpUZYf4n1oKEBB6fQVJJbsg549jRYS IQw/z2p6EnuPrQybkJIz1HvSEr/WgYmR3P0pu4dqYHc3N0wgAKfxbs+4HrWfCRnn6mud/wDBN0Xl cnoPb6fSp7ZyCPlBHQ/j6VmzZHU6DMQ4529zjuDXfaaUWf5yIgQQVb1APWvNqnfDz+RTuk2McEHv n1HtWBeIDeQbAq53R5/L+lKPqTFbHcQ6SYeXYgDocd/p714r8RLoyXPAHAMSt/z0Gev4VrgdzDGe XzOcg2Hr9D9KluIlU/KPY+5r3EeY7CRk+hHtXV6DMB6/4f8A662izL+kd9G0SAeaHJIBXb3Oa9E8 LadN8pS3nGOZODhAfXFdLff0FCPY9lunje1IuiuCjIT3IYH7i18C63YrFJIEBGGZMei7j/MVz0lp 8zOu9flYxkBHUZ9atRH0PtWiM9f1ZqQD0/M1diHTBJ7Y/GmJv/M1YCD1Ugfzx61etY9x5xjoSe3/ AOut4GDO28NeCLm+YLplhPcv9zy41J+Y+wFfSvw0/ZA1pfn1uOO0XrbxS/eGM/eUf3uPSnzWMZS8 z2xNO8LaIv8AxONZtgw7zMBk4PSMeozWLdftVaEDt8PWFxfn7qug2qG/3iO1ZKm38RnCv0oK/Rvs b3hvWtd1HDakFtIvveQo5Ye7frXagY6VzVLfZ9D2aMf5nfqxaKyNwooAKKACigAooAKKAKF/hwRI uVP3h/eA/wDr1l2QSFSLNdq5yR6sPUmuiH/BOWTCS/b3qjcPIesxA7D1FapEMozXYX+Int9arpfx t/rU+n1rRIm5K80ij9yykdce1Qprq/8ALQ49R70WFcbJ4st0+8WPsO9V38eqP9XC2euT/U0+TuTz dhH8e3c2A4GBwPXB96nGsgffI3d/b8aTj2HF9yrLqU85xZ8dnk/uj2NVrjSAv3CWbo7nuaVv+CUl 3+RUOj8/Oh9cetQzeH2P3I1x/OhLuU2U28NXA6RJjopz1J9qiPhC4b+4PYHpWqSFr3LH/Co7pxkw zSDqQq/e/Ssi++GWrL/x46HOe29lIz9OKfMurRp7N9DmNX+C3iZ1/wBI0+5KdWVEb5QPXjvXPzfB 6/TG2wnz6FT1/Kto8vRoz9i+w6z8H6zAebKbHcEHgewxXXaPrupRY82znA6k4POPQYrysZhE9reR 30ZyW9+x2emfERhjzA69yGB4PuK6W2+IUJ6ygdhXytbAP7K80emp9zatfG8Lf8tF9a1IfE8LdJB/ 9auJ0JLozOUF0LEt3aXClbtEkQ8Op7H2+leZ+Kfg/PH82jbbmPq0RPMZ/wDr16WCrNfHcxlT/wCA ec3FtPG2JIWjYcbW7/TNCwP3yD1/Gvp4+R58o9xxMo+82PpTDLJ/z047j1piI3jb1HqPpSpGf4lF JlJjtyd198mlLRDqvtn2+tId/wDIQXFueg+pPr/9elMER+6fqPelYLjBZH39ceopDEw9T6D0pB/w 414T3X34qMoOwI9AO9A7CrIB1Zge49BR5w/hfjpg0rja/wCCIZB2IPr7iopMHoB65FA/+HIWYd+P Q1E8xHoaRNvMrSSk9f8AIqrIT3JU9R7j3p+hREWH+e9VHlJPIx3X8KTQ1/wCCRx2U465Pf6VWd/Q keoo9At2I3cHv9PYVVkIXouR1B9PpUeoepXeRfcDt7H/AOvVdpF7lif6UW8wt/kQZA9Ceqk9qY8o PXgfeI9/pSv5lehGbtT1/A0zG/uQOjAf4UhIiKL/AHj70gjUdGOejD0NK/kWn3FWRx0Ax159aQXB /iA9CKkS/wCAOaZG6KB6j0/Ggxr6n2Iq79g9F5DhCB93J7sPenIWHcsOoH+J9qm40vMeHYDn6j2F PWQ+3rmqF8yRZQep9jn3qcAdunc+houH/DjgD2JPcj0FShEP3jn0HoaL9hR8/kOCjv8AQUoiI6Z9 j7UrjFKH69/oaesZ/iwfb0H0qhNhg9jn0NIB65PbPofemL+kGSP4vcH2/wDrU/z/AEIx6+v0pW7D T7iLI/8AeHqPanF5D3HquOw9zR6gDTHuMdsUodc8KPcnviq9BjfMUddxPXB7D3+tG9e+D247Cpa/ 4A9Rm1O2fQ+1BjXswI/z2pshkTIP7wIPr2ApuwD7pH19frS/4c0XkMMHsPZfTNQmw3fwnHXH+FFu wv8AhiJ9HB9h/Wo30cLyTntx3J9an09AfkisdIznd19D2FA0RiPkK+pH0ofp5giBtPcfxEj696rt bH3+tUvQPmP+xMc71AHQ/X2pG0px3BHXHt71LH6lOe3ZfuAep+vtVI3h/iBPZc0ITQzczdB7A+gq 3FbbOw/2vc0P/ghYkVGP/LM/X/Gni3bsOOnHb8KbQJFuDSpWHOcdU98ev0qRtPcDmVj3z/dNShtd iP7CO7H0zUbWIPRS3bJ/rR8ykgWyJ6Kw7Y9R7fSpFtP7inP3ifXFVfyJ9PVkwgP9wepP90YpgiJ7 cdMev/6qWgmg+xN2Q+mfSkOmH2/Cn6lWGnTT9O31FB0s+p9cDtj1o9BIadP9Q3sfQCojYDuT9fX6 0gEa0X+79c+o9aabJR0UDvgVXzD/AIcYbX3Hrt9BUfkD0Ht9KlDuNe1yOi//AFqgdf8A6x9Kdu4r kJCjt+Hriq7uF649MUITIS2fuk+pP90e1QgD+8G7g0WEvUhLL3BHt6momjXuff8AyafqCIXK/wCO KhZ0H8XscjpRcGM85fX6+/4UxrlR1z/hUi+Yn2oDoOPX1pn2sd8/T396Y2DXZB6exJ7n2NNa5Y9F P93p0/Cl8xpdvQVA5/5Zt9Pb608WUx/hIH8P1ob/AMw5f+CSpolw3WNx74/rU6+G5P4gQfX1A9al vsNL/JFlPDJ/ib6mrMfhpO5HrgdqSfcdvIsp4ehHfPt7f/Xq0uiwDqgH9aZVv+ATppkPZOegPqPa p1tlPZQO2O5HrS9fkJenkSLCnpgelTps/hQH3PpRfv6C+Y8H+7gDoWHYn0HtTh7DPo3rTsUPRz6E 9jinbj6f/qqvQP8AhxVPofYn6U4AA9fcj0NS0V6McR6Ae3ufenEAdT7YHc/ShITFDe4Hp7/WlIJ7 ke471SQWHhh6/QH0oMg7Aeo9h9aLBcjLAdCKQzN3bPp9KGxL/giluOMY6fQ0nnY6fTB9f/r1I/Qj 8/PRfYD0NQT32374A7CmFuyM+bxHEgO+Uen+7/wKsa5+IMAzidTjg45wR61k5dyoxfT5nN3PxbHP k2zHsGb+Mn29607vWZ44Va4Bjkb94F/ux+5PvRzf5Cce/oca2qXEpPmXEmD0GegpQuPu59K5pvzO qC7DGU9wPb60okPv659P/wBdZM1VynqF0GHyADtn1yaqwIC3zcfwkn/PaqiiJMztUC7mwfYY/pXW +HoQlume4zj0Arsjt+BwT3ElLE8Jk+38Va0NhY6evna2iu4+ewtj/wA9PU/j/wDWrkxc9LQer91H XQj3W255rr3iq51CQveO3rEn9xc+lew+B7UxWo3McFS6j3K9/pVSp2Vl6ERnd3fyOF1zT7i4lAt4 JZD6oO5Pc10ei/CvUxLG0sHlxqRLI7nHA9j610U15eY6rXV+h7vF8Rra2HyorN0YHpu/2QPSsy9+ LMhPDkH7yhfXHrXamcMIvoZ//CRardcWVnPKx+bA/hJ9SfWpoPhf4hmH+lNDbZ5Yuei/7hov/ka2 X2vU4r4seHJtGiQ292ssjHZIQOI/ofevEZ/EF5Kf3ty34Vk13+Q6nkV3J/iJPck9/wD9dbOnyDb/ AJ4rnqsKW5oOvHT8fQ//AF65i5TBP5VhROmuivK+BxUcYHp/9euxHntk6r70uPT8TQOI7ZirEUI/ iFCNB96o2Nz22r9Sa/SXw7AbXw/bKoIHkI8mexZewrto7P5fqctVar1PhXxbKGuZMHHzEEe31rmt SlAGAeP6VnWO6e+vqY0YJPBA/rVyI88//rFcDA3fD9o0sy7AOPn2n+IAdzXs/gV4od3mbQScc9x9 a9zK1/meDm3/AASL4pX0lxAqabKQdw+0lcfKD9fauAsfhzdWLrNbrHPKv721tyes3+3ivTrxv08z iw87L8GfSOhah4hmgibVbe2hkYeZLGp/1ceT09/0HrT9X8BWd/8A8fjSq3QmPuP/ANdeLNa+6erQ fZeRyk/7LWgSZIeTd/CW/iJ9Xrz3xH+ypfQk/wBmQB06hvUfhWbOyFS/xmVYfDbxZCNtjY3S/wAG 6MYAX3Y+tWo/gDqOd3iFjJ6Qg9CPWtZTIsuj8joItIMAxbqUA4AHZgKwU8B6jNMzm1kZPvNJj+FR 3PtzUxXb1MXpe/ocF4w1aB3IjkBI+V8diPX61yn2gf8A165aiOiK7DVvdp+X61HLMz9x6n2NZDX/ AASFigHzE59PX8aZCrPnaD6/hWyj/mZ3Om8BaTBd3Krcwh/42B7qPU1qfFeytLedVsIEhG3dIi92 z6fjSa8yYPX5XPPDO4o+1t/jU2LGidj2/GnqxP8AWiwyy8I2jge9PtrRT978BSG2dddSsYBwPvYD d849az4cj0z3rBm8S/C4xzz2x6VaVQDxjHpWT8jf/hjZ03UhEy7hu5AGO/NdzHcfv4yyt3+X157/ AEriqo7KXn6Fu9Q7z5gA5OQOw9qwda/dSwFccNtD/wB3cR1+tYxGl5dT0a5HvuP3ifUn0rwb4iQB bk/MMclVHYHFVgXr+By4xHLxuB/MVM7qTxn6+tfQI83/AIYlSZR/Djtmui0cqPu8/wAWPatYiv2P QbK5EijgZH3T6MK9l+Hvia5KbLtQ38Zc9CQOx9xWk1pr6ipvX8z0CC4iIY3aBuNsMQ9Men1r4z+K uhta30qtEI84nMY/gLf40U1/mc1Z6qxwCAZ5HHoe9WoyvYfh6UMGaNqnp9Sa0Ykz/q0J7EDsT6it LGTfY67Q/hxq1z/qrE7OrTtwMj/ers9N+E+l25B8Qau3ZmgjAwF/2nPoKqDPPxFdL4Xdnt2kfte+ CvCsPleBfDZv7r711e5wHmI/5auefk+oriPEn7Y3jjWQVN8mnQnIMdrwWjbPHmD0X368itoRX2tW cUac5fxXZbpdzP8ADug3epSD7VLdX0h4HmEnDMe619N+CPhrZWKg3saSy/wxj/lmwH8X0qa0vM9u hBJe6l5HqWluT9Ow9PwrbFedI7qXmFFSbBRQAUUAFFABRQAUUAQXNqzj5MZ7ZrLbRZh91QB7e/8A jW0JdzCUBjaNN2jyf51Qn8L3zn7gA/hXNbxmurIcBh8HXbfejX86hbwHe/8ALOOP8T29qv2i7h7P sxn/AAgOo9gn/fVNPw4vj/BF9N3en7WPcapeaIG+Fl+eoh9fvf8A1qT/AIVJeH7zQj8f/rUe2j3Y ey8ywvwquV+48IP94np9OKdH8JZ/47yL0PXp+VL20fMPZlyL4cTRjEV1Cv8Aebnn9KP+FZyH/Wal j12jv7cVPtl2K5O9x3/CrIz/AKzVJ/wA4+lA+E1r31G6P5VHt+0EWoLsxw+Etj/Hd3Tduo5/SrUH w40+M5Dzsf8AaI/wodd/yoaguiN5UCjCAAdFA7AU7JrkZoGTTWiRvvxo3bkU0+zF8yFtLtT96ztz 65Uf4VG2g2J+9p1r/wB8D/Cq53/MwXqQv4P0pvv6Van1+Wq8nw80NvvaNa/lS5n1ZopvyIm+GWin 7unqnb5T2qL/AIVdpY/1QuE7Da3Ss2l1ih+0fkH/AAriEf6rUrxPQcf4U/8A4QiZf9VrE/0YDn8q xdJfyotVe5m6h8JY7nm6miZuplxzmuX1P4C36c6fPDOPvFDwQB6cV105W3MpW6XOP1Hwfe2xxeWU kfcEjqfb6isSa0I6qfcV0tdjBruVjD6fiPanm3P/ANb3qSRjW5/iz9KiNuezD29jSKRHLaP6Lnpm oyXXp9SPelcEO/tKUdBntj/69SJrbD78YPbI7ip9QSD+1kPVMd6Pt0JPzbh2B9KVvMaTGPNH/fB9 QfSkLp/FwO5HcUWCTIiI+30z7Uht4/X3UUwv/kQvCvv6moZEA6NkdAfQUrFf8OVpHx/GR2qJ3z1P PY+3vST/AMxX/wAiB5VHQg9ifSoHbPQD15/z3oHbz9SpLyensR7Gqjtjpn0Q+tCD+kQlyOw9we9V 5JP9kf4VJT/4JUkdR0J9CD3qJnHZsdh7Gj/hwsQG4IJJGP7vuB7VC8hJ557sT2B9Kzfl6FMjklTs Dn+QqN1X+GTHpnvRbuJIaTnvjs3v+FAKn+I/U/40h/ICp7tkdGHoKMEd8nsfam/IdhQD3B9cHt+F PA9B9fagPQcMeuPQ+p/+vUxhOBuK56kD+EUf8ONeo/yz2DH1I749qesIPUcdcehoT/zDlJ1iGSCh A6gHvxUiWw9T6Z9/pQL/AIYlaxYfeYjsFHce9OCgdiO4x/nvRcBywk+3v9amWEf1+tW/IF/wBQjn +Af73+NOZV9GI6fh7mpaFfyECqezD/ClWJGHygjufqf8aduwJCvp4PRh6Z9Pw96DYf3T7gnuKaYv QBY4659z70n2Hd0ZvVcdzQ/+CN+gv2I/3wcdfY//AF6GsCejD0X2+tN/8EF5+ow2BH3jn1//AF0n kH0/D0NL0H/w4w257ofXH1qNrdh/D/8AXH1p27ifmV2if+IH1z/9erCxIR8yn2I7fWhopefqx3lg dAT3BPpUTTEdH/8ArZoEyCW6b+DJ9/U/T3qMyyHrn/ax3FTf/ML/AOQxlI6pnsF9BURi3Z3IwH8/ oafqxWK5iHYNjp/ke1RMhHTPoB6j/wCtQg/pEeSeoI7Y9TTXmcdGPt71PqO3coXN0f4z/wDWxVKP Mp5T5fUd8H0p+gNdzQgsdv3EHoc9xVg23oob1HqP/rVHqVb/ACJBbnuT6fhVmHTsn5SDj7ue9F/8 h/PyHm2kH/LTA7r6j/61AiJ++Sw6U2hDjFxwgx6+hp0dqpHzKD2z659AaLdgQ9bRR1I+nrj/ABp4 s17gH+JR6cdqbGvIQWwPRfcH1FI9pjoMeuO4oBr/ADQeUR179x/h70GJR0OD1z6UNgvL1EERP3SD 6g9j7/Smvb9cOc9Prj0+op37IPQT7IT0Y49D6VE1rn0NS35Bbt6kZtW9Pz71G1m2en+yR7iheYeo w2DHrz2Knt9KjNg/932x/wDWpg12+RG+kk9v/wBdQvo0pHG4dvoTSuS129GVm0WQdz9apS6ZKP4T 6A+hPpTUgt2ZWexmHWNh23eo9qiOmS/wo3oKb8g5f8iCTTJf4ojnsfUVA9hL6H0x6VKff0E12K7a dKP+WZP96mHSpieEPqo9PxpplW7if2HOeqH3PrUqeHZD047nPepv29RWFbws/dx6lR2qUeHF4yAD 0J9aWpTX+ZMNAjHuff8ApUo0eMdB7/5NIH5PzJFslHVR6j/69TJEvdSO2Md/wpC9RwDA8Aj39KcF Ydz7n1xTsCHjcOqt6j/61SIpA4z759PpQ3/wQb8/Meo+vqRT9n09D7ij19WO49WA6N74p6KP4vwP /wBei4Mf8vYCpUPpgehqhCgn69/rinhfcei+wNMdu7HBiOnPv6fSncn7vPZie30oAcHI6/Qj1P0p +4H+E+gP+NHoHr8h4x3PPTHv/wDXpPLx97jsD6j3NL5gxSw7Lz/Cw/u+9KJh2J9/rR6jE87+8QO+ 4+gqJ7lB91/fPqfanfsBG2oqPQj+tM/tQf7P+BFSBCdSY/cyT/CPU+xrpNC+H2pX5Gw7R3JI4H4+ grOpVsve9UbUof8ABPTdF/Zksxj+1tdtrcdCHcc/VPesf4kfs0RXIUeDPFWnIwBFxJKy/M5P8A9h j/PFeDXzG2yfoerSgvtRdurPHtV/Y/8AF8cZD6rZXLH5vPSQYAU9D06iuLu/gnrdgh+2WZfgsxjO QcemPWuOlmafxJrqdP1eP/LqRl+FvA1xd3KrNbyImfOu2YfciT1NaPjy8iMxWzyI1+RQO6r6/Wvo Kc10a7nkVqTvqvM5aGM44H0q0Iz25PUEdx7fSpkxxX+ZE4I+9+A9PpT1RT1Bx0+hqH/wTZFDUECk AKSOpb1NQIvPb1+tXEyl/wAEyNQY8/Jx1x6V3Gi2rtCgRWJxjaPeu1bHnyWuhswaPHbZaWB55fur GoP7sn6Vk6/4B1zUSC0QhX7wEhwEX3B9BXDSg27yW2kUd8pJK1xNP+AVnx/a2uAfxMkC5z7bj616 JbXGl2kYW3geVAAgEh/hA7getehNL7T9DzoX6IpX3xHgjGNPS2tm7CMDO0Vzt18UJJHVWndmJEMZ /wBpj3+lEfTyKt3v3PaND+CFtKqnV9SnY43yRxDqD/te9dbZ/DfRLfH2bSoSR1lk5JreMe5PtP5T bjjCD9xGkS9NqAfd98VFKg7jI6YPpXQomVzxL9ou2U2kRXIw+CfVWr5k2HPQetYz8zeeyHkjufr9 a09KcEHPNcVQKb/yNZD64+nrXOahH8x6+tYUjtq7GfO3+fShCOw+grsR5jJgfp/9elUkf0+lD8hp /wCQ4Nnr+VXYwPeg0QTR7gB0JKoMfxbmHWv0x1uEwaPECSP3KDA/hIjz+ldtLb5nLLdH5+6xdb5n zkncTn1BNczqs43YwD3z6EVnXXZnZLcoQk5/QVehj55I+tcEil5nS+GIXDMQ2MDCH+7k+teiyWkV hYNLdTStOfltQx6O3oPqK97L1oeHj3rb/t085MFzL5K3N3cFmPmyAk/MWPavoTQPA9gwQCyDHhZG fJO+vVh5t9keXXe3J6s9au7VRgCIIqjyo1H8Kj2qq0IHT6Z9K8KTPagtNBFiI6j3x71aiVuDkj+l R8yid4nYdWx/EB3HuPese88PI3WMeoI7Gk12Ki+xg3ng6E/8sFJ6kY649qydZ0uGztpWYMgCkE/3 Sw9B604lyXkfIE6K7EjuTJn13etVjD6D61y1XqdEvL0IzCP8BTSh7fUVmyWUpVYHn8jTlvWUccdi R3roTMWjvfhLbIbnMhxxjnuMH+tUPilfCS9fbggARg+pFRcKe79DiiM/4VHn1JpFCrz2qwsWPr6U hly4jAVcnnqRT7ID/wCt6Ugkjpb1sQrhj1Pyn1x6VQRc9MisH5nQi9Efzq4vOP5eorJm8V3ZejGS u0HGRsHoff6V6baWzEBpgN3UH+7kdhXDWf8AkddNlnUQQ3GD3z6nHb61zfiaNfLU9wyn/dyw/pWE P+AXc9EnKlVMeOQC59RivF/iRpw80tt5zsLfU/1rbB7mGMRwqhR/OpFY9j74r3zyWTRMT2H41v6T IAeG9g3qK0iiD0DRYW52sf7wI7ivX/A+pOxUeUMDhG/vD3/Ot2u/qKC7HqFvL5cn7+3G3nYB2OO3 0r5V+P2lsL7dljuGxmPfZ/8AE0qX6HLXWqv6HkJt8twD6ADuTXT6B8LNbvcfYdKn29WmkGFUY/jZ vaqRM5pfEzu9O+BdtAM6/rsafxPbQcnPpu//AF1pf8Jj4W03jTtLSWUfMZH5JI9h/wDWpN9jyZ1p PSin2Mu7+MGo3J/0VFhU9Qc9P932rHnvruYg3V3K/qgPGfpWsTanh0t9e5ctsD730+hrotLtwxGc 9cYHcj1+lXA615n0P8M7ZLX/AFC/MeGkbrz6GvbtLdSOB9a56ppF9/kdjpLAd62lrlkdtMWipNgo oAKKACigAooAKKACjFABijFABijFABijFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFAEc 9nDKMXMKSL3RxXBa98DYJcnR5fLP3mtpOmD/AM829q1hPuHqed6t8OtQtc/aLSRf4VbH3sf3WxXO y28qdc+4Pp9K6muxk49vUj+1A9h/hSmcf88s+ntWLQkRtdJ3Q+h9qUJGexHr71LKQn2FD0P/AOv6 1XexX1P096T9BsjFjnoyg9Meopn2UHv9BSt/kNMja1PoD6//AF6ieJ+7H/PoKEhjCjd2OO3sfaky 38OfT/JpXBIjZnH9Qe4/+tVd52/hz7+xpg/+AQSTMeuf/r1C8rDoT6fQ1KBFd5WHYD1x6VDJJkcA n1PoPY07h6+pXMx7Zx0APY1XYk/eH4HsTQ/XzD5ld5c/fU+xqpLK3YH0JPpSSKuVZWx0J9/c1XeU j+Jj9P8APaoQJMiNwP4h9KaLtT147ke//wBep/4cq/YZ9pHoPeoWuEPXI/vY9RTsAizRnqz49T9K eCndh6j61L8gQ7zc9MY7j0NG84+Vj7D3oSC/+ZJuH976getKyk/wgD+tJD9PUeIx2H4+9Sxj+8AO 4I71S8/UfL3+ROh9Mj1AqdYz2I9PqaVgfqSKjd+vQH2qZYT2LewqrdvURIqsPvKfTPrUoX1X2B9K pJCsTLEp+n9fpTvJB6qf7wI/hNKwD0ss/eP4Uv2UY6fT3qrdvUdxn2Unpx35p3kf3RQ0L1FEB75H fNKIz/CTnoKVhDvKbvzS/Zz2JA6/gKb8wbA2/sP7w96abY/wjPcE9j7VNu4/+HGC1f8Ai2464z1+ opGgH09h/jVP/gCSGOp/iyT0B9hTDHjsT6+1AX/yHGNCOv1HrTWt0HRfrjt+FJf8Ef8Aw4nlL6fQ +tVDZc9V9QPf60WD/hyFoDnkex+opEQr0H0HvWdiv+HBr8Yw0CHuzev5etNXUnAwsSbenHv7Y71X /DhYikuCT/qVA9v61XkCnogHqvqKLeof8MVJIwOg9selVZyO7AelShtGc1k8p+Xp/Efb6+9XbfSV j+6T7e+PeqJj5v1Ly6e38Rz/AEqRLMDtz0Pt9ag0aHCwkH3UbHXOOmPSpUtWHb3P1/8ArU/+GJS7 En2Zj95c/wB0+h9qkSwI64x1AH+NO/8AmFu4p0wnqSP7o9v/AK1CaWD1Len0NF+wX7epIunRr0Ue mfUfSnLaHsP/ANX1pP1Bf8EUwA/w+yn0FMaEDpnHTPr+NNMfr6kYthngEjrz60jRDuD6Y9/ehhcR bdB2Y+o9x6UohPZfp/8AXp3FcBH/AHh/u+x+tJ9lz0PufrQ0UvUaLMemfYeppPsif3fcf7JqRX8h RZehz3pPsgH3uO4Ip2H6fIT7Kn8J49fX/wDVUckKj+IHufw9PrSaFchaNB1A9gfb3qF1U/w59AR0 xTsCRWe3XvED3wfWongJHyqAO3t+FIduzIntiR8+COmfT8arvZqD1yOmT3qJegrEL2yj6dwO5qNr cdgPamibjTEO34+496YYU9D6H3p3/wAi7CNbg/dA9RTWVO4OfX3oXmTfuNwp/D7o/wAaGA7nH+e9 APy9BS6Z7H196b56j7w9sjsaEv8AIbF+0E+/ufT/AOtTvPz94Adh7fhTfl6g/wDgMUXPqfbPpQJG z94+496lg1/kP3juDnvn19qf5g9cj+76VT9QJPO54B/2vcU/JPYe2Owo/wCHC3+ZIjD29QD2P196 eGH8X4f596YmO87H3sn0H+NL9p9vYfSkUvUX7Tj7v4n1zSrcE/xn396F5kjvOJ9Px/iz6/Sj7UPX /wCvn39qdv8AgDbHecB0/XtSfb1H3m+n/wCupD0G/wBqr2J9/c1E2r4+4wz1yPT6+9Fx2Kx1Rj1b PcD1qtLqSD7zfVfQ/Smibf5FafWwgzxtPCt/hV3R9E1PUWA0mwuJs8eco4Gf9o+lJzXV+RtGk/tH sfhz9mmVSDr14sX8flxckYH8R969Lk8P+FtLjzdzTZxhVDfeJ9EX1Nck4J/GdHN/z7XkQR3+nXQX +ytCVExgzy5y+T3B9fxr5h/arvLyxvIU0jU7mzBi+1TxQnGZGbvj2rONCPWKZ0Qm9denMeS2njnX 44QV8S6hvyAXLZ3A+ufSuptPjNr1tGWmvGusDkydyexI9a86vg4dIJdDSlVfV+Z6voTy/wBkJe69 Z2tqZnNnplopO65iX+LaB0znvXFXnh/SLs5VBEx/1r/3j+J7ms6uEnH+DJvqVTxCfxr+6YU/w1VP +Pe5Rl7Aenv9az5fB9ynSPjsR6fSphiv+fit0ZrKivsMyZtIlU/NG3sfUVNa6RKekbH1J9Pc12+0 XQw5Bl14auZSPs8QY9Me1aNh8FNal5a2RVP+rd/7uPU1vTfk+5z1ZLqy9H+z/YD/AJDWvD+9LHAM 49jn1rpYI9Bs1C2lvNKANgZzjcB6n2rv5f5vU89z/lXoQXXjq2h/49/Kh7r5YGT9Xrk9U+LVnBzP 5k7dIozk/mRTi/5UEl3Zy8vxjvJWUW1siKSIzn+EMf4RXodxaRpAS/meZwu/3PtXNWdupth13PMJ AzTMS7/3QT2HsKZC5M0ec8OhyP8AeHStqbCovM+4dCH7pMD+EEk+471omM8ZA9z613xRwwHFCO30 NVJue31HvW42zxr9oRA1kuR0fH+6MDpXy8oJ6k+pI71zTNW9EBx3/Kr2lS4P61yTCH/ANuMD+v0N YmrR4bgn/AiuSm9TuqbfiYkhJPNPUH/69egeWSqRS596QyRFz6mrcZx39iKRaLWnW4kmhDZ5ljTP qDKP51+lfxQfydMQJ/cSMAdsR9/pXbS2+djC3vL5s/PbVJAZX7ck7R6N/wDWrkr2XcxyT9fas63k dUt/xI4jzx+tXBJt64z/AJ/lXC/+AWjrPCsJMbHAAJ2Aev8A+uun8b6mblra3tCxAwZ1H8TH2r6L BrQ8DEv3vTUr3OjoNRiSPkIANoHQgeh9MGvpTwfpimQnACqCzn+9J9PeuxvR/eeXVWq9LnUajqEM YzLIuT9wE9Tn0qpHIGHOCOwHvXhtHu3JFiz3/GrccQ/pTSNC2kX4U5rYHr+BoEjMutOUdvbPpXnP xMuVSxmz6bWz24PX6VPobQep8fBR2z7Z/wA9qY//AOv2FckzZ/8ABIWXHQ1Y06wE0ihpFQEhS5/h BPf6VKEy34w8FzWLgSLlT80Ug6N9DXLEVcX/AJEzXb1R0/gfXDazqSxA+65P90+tUvF2pi4uZGUg 5JwR3HtTsZR/Sxhgn2/xpCuOpoL/AOHJoIMcnp1/GnRsXPQ+gHtSAuXRJPPbgfSpbRfb3/KkDOm1 K2QQx4kJJJ81P7uO+fc+1ZiL7n1/yKxZ0l2Ej0/z71bGMdz3A/8Ar1kzoX/BNbRZUDDeu4d1PevU kdXXlQCMBB6AD19q4a67M64PTT0YX5yBknpzn19vwrB8SWwNu33Tysh9trd6xiwsdpYymSKM8AbQ cfUd68w+Jtq2CQwxkNgfxDI+79avC76vyIxux5opA6/h705EPc//AFq948V+XqyVGx/nqK2tLlbI yvHVfc/St4mV/M9F0HVdn+rQE4yQ3Rvr9a9E8J+LZ1dMgleUkf8AuA+9dCRCl/wT2aa6V9rQTyH+ JyB0De9eS/FPwfo+oOpv9WaAqd5aMZJTB6/X/PesaN+q8kebjcSvsu73PPR408F6IP8AiXabDc3H Rrmf5mB9o19KwNX/AGjtWueLNDHH/ApwMA/7C1pHzOKNKcneq7Lscw+vX9xzd3cj99oOBz7D0qe3 UD7iYP8AEfX6mpv3PWhTS+FeRpW+4fw+/wCHvV8LjliB/dHrmtosUkaMMqk9/fHc13nhSyjHMi5P QL6L7VpHyIkeyeFNRCEdCO/tzXs+h3qt90msKxpTZ3GmseK6BRjqc+9cbO2kLRSNwooAKKACigAo oAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAbJBG4xNGjr/Ejj IP1BriPEXwSsrkE6WRbydoj91zjt6YrWE/8AggeFarp09s5W5jaORTsnQ9mU9jVZdXUfeB9D9a1k u3qYEguFboPYD3qzHsPr6Y9DU/8ADlMsrbL6genuB7VE8Ufcj3Hv9KQyo0cGeD9SKj8pD0PsBQyk OUeig+oPtTWi3fwAdsCkv+AFirNaMPu5x/P/APXVUlu4PvUh6EbSg/w/7p9//r1CxX+6R/jVFf8A DkLSqP4fp7VA0in+dQ/+AO3+RA7J7H3qtKy/wj/eHoPpRYV/8itKyj+YxVN519CfQ+lSFyq8wA5b Pf6VAZRzlcd/w9qm40QvMp7ADqvsKieVD0wT6HsPYVKGmQsY/RfXPoc96rtFF3Iz0BHcfWi4N9vU ha1T+8fY/T/GmtbA9/f6EUFW7sQ2474PqT2pRCPQkdMj1pv1GvX1G/ZsdGIPT6GjYw9PRs96Eyf+ HHAt647AU9JCP4f/AK//AOukNeRIsx7kjuV9qnSY9gPXNCQlctxOD93js4PoKmjkHcY7gehqrf5M b8/QtRg9wQehPvVhAT93PqPpTT7Ek6ISecDvn6Cpo1GPun2ppdi7kogHbr3B7VIsX/PM/U+v1pWI HiM/3efQelPVM9UHr9D9Paqt/kFu/wAxy2x/u++fpR9lOPu8dCR2Puadv8wTF/s8d1J/z600WQ/h BHbNP5+Yr+QosG7HHr9aRrVuxB9Qe9IoYbUjPAPofT6UxoHPUj60eo2uwnlt3HPU+9I0X+zj6dqX qSiNoB6Ef3qiZME9/Rvaiw0xoiPHB+o9famS7h0P1HtSsDfkR+W3cn2PoDTDA3egbXYjKHng46Co zCf4Rj0PvSD5kLIT1HsR659KjNuR2IHX60gv5jTA2PlB/wBkHvioposdOT0PuaSKS7lSXcPQeh9q ojT3k+8Djp/vD6U7jNCDTFI5Qgdz7/8A16mFgv8ACuO4P1qQSRYW1PofbPr9KcLY/wAQznkk96Xo VcshZOMvx2H19KEsj/d9yPert/mSiU2g/hYDvipJIj/DjP8ACR3HvSBefqDRjt9CT3+lNMA7fjju aF5k27sc0A7f5FMdR2/DHenYpf8ADjPKb2HtQI/UD1z6mp9CUJs9QPU49aTyh3HFU13HbyGMi9vy 9fxpxwOmPXHvS/4YPUY6g/e+mf8ACmEg54Pop/2frS+Y7CAkfw57Z9QP8KOT90EY6fT2qhJdg8tx 6ex9fp9ajaE9wx9f/wBVK5X/AAw0xE/xYPQ/Smm2Udcn1z3zRJ9hrzInjAx8o/2T6/T6VEzcfOgH uO1Fu3qib+XqQlQO3ufaoX91OOqjHUULyQ15lWQf7PvtPp/9aoJHI7A/TtQ/MP8AhiF3weg9x6mo TJ+HoPWpsT/wxEAec5Pb6Uxgez8dSD2+lJDI94PRmHvUZOBxx3B9c/4VQ2hoYn73P+fSmyNnuR3P vj2pX7IgRnx3x/U03zh/eB7NSNF/wA88dmJPf2xTfPbufcfSl/wxN/8AMeDjq/0NSBx2YY6n8fSn 6jt/mP8APTu3up9RSi5A6N759KTE/IUXOejc9/8A9dPW9GOSfb60wQovcdef608Xn93B7H/Zo/4c aFW6b+JfYfWkF63cfQ0MP6Y77Q59T7U8GX0ODzu/wpoL+ZNHFMerD1UewpjK/dge/Hp7GhMGQlye j4/ukd/pUbOf75Ht6j/61F+wX7CLGCDuc+2e4p/2Pplyf7oHcD2oSGk+iNjSfhvql+wFhp0zk/MT g8r9fevZPBP7CWoXrBvETRWcA/e3MrnkQL2OcdvpWNapZaHXCml/E+SI9Y+GHhK41BLbRbQvaiNr +7vlX5b6OB8fumzyCe+Ofpiu3WPT7JAunxWdlHkRwouBwPUnFcGFjK3vu9/eOnET/K7MrxD8RrS0 IVblHkP3lBHyljUugeERckP4inif5t9nCx+5H/unua62n28mcqmuj9DuLpLKLiJ4B32rjpj+6PSv iP8Aa31aGbVcQMrbYkiJH8AbHFXDyKpve/Y8jLDYoC4H3x74/wAK3NM8J3msSQW2kkPNO62wHaGM uMlj/sLzWajdr1Gpaa9rn0Z8a9TtFngs9HjRLGyiXS4I4xgSXqKAzSDuWxyT1rzR9JiP3QT6A+nv XZX8vU5aeyu/7wsNoidHYd2AHUCm3mquBiMuR0ye1eXVw6e6R1wrPuzLbTZpADLNGsZOFJPKqPRa 2HtNCgX5rm6uu7r0Uvj29a0p4VdX6EVcQ/s+jKv/AAsOztx/odlaQfxCQDn8SfWsPUfjHdS58u5k I6lQeMY9B/hXVzLpbsjnUO7Zx2p/F68OPs0RB/vk9ia2hqErIpkkwSNzY7sfQVT/AOAZXM25k/vN u9z2H1rlddfkDnPRvc5q1/wQbKmkwFpowMfeBwe4B/wr3DWZ2WEDnHbPoo7iuPE9PvOjCnliglmJ JPJwT2UVWRyJE+bHzqVI/wB4VtTJn/wD7s0GNvJT/dG3347/AFrWEQ9ffBr0YHBD/gDHB/DsaqTq PXP07/hWyQ2zx/4/RA2I2qfvgMPUgjr9eK+WgnvXPU8zZrRDGT29/rU1hLhvvfWuSQI6GNlH8waz dbU9STnoSexFcUNzvexzf1zUqj616NjymSKM9Me9Ox6n/wDXUlj0f/8AXVlCPx7+1MpGr4fkQXNu ZM4E0bv/ALqyD+dfon8X9bgawUpIqrsG0Huu3sf9muylt8znv7yPgHVLo73OAeSFJ/hrkHbJ6f8A 6qyqnY2KgI9asbhn5unp61yNAeg+FoF8lfkbqZeOyqe49q1fAmlveXzyXakhMlc9M/7Jr6HDPRfe fPYn7TX+FFzw4jXOpSuUYAEiDd/Co/xr6BtvEdlpFm0ur3Kxljstk/ilYjpGnuRXRWehhTh7y+SP JNd1TxfqTxzi3mtLBW/cQMcG4hB6lPcf/Wr1/wAP62JY165xjHqCP6V5T8j2K8Vpb/Cb6Tj+77Gr cZ9T7Aehqfl5EXLaMfX6e5p0k6qOvv8AWkUl/meafEX9oOy0lNkaCWckDyx/yzTPVlHpXDeOPFq3 mlyMAvIDOB/Cx9KTNUrWufM+8dsgdh6DFNZh3Ptn3rjqG5C3uPqfSoGkdfuHHoalEs9K0a8h1y1M d2/+koM27n+NFHc15ff6dLAxWdSrA7WB9quPp5oUXp6afI3rDQCbVpEzuBxjHRMetc1LKzH5uTT9 SI/8AjwO/wCdO8rd0496AJ5nCjCn/e+tS6bblmH+cil/w4yWclmOOBngf4CtbRdLaZ1VELEnacdl z/QVI2aWr2ZQR/vGyRuCegJ/rVJYwPvDB9D3rJnRFlqEevHqavRgY5578egrKR0RLmnsA4456An0 zXqdqcJ8qAjq5P8AFXBWfY6qb0LV2Ayjvxj6rn/CsjVIA8LAbQMYA9wDXOipHQeF5Q1rH0zt2Bv7 3/6q4T4naezIfmxgbiR3AbPP4Vrh/i072M8W9PxPKVUH+ePQ1PHCfr2xX0KPFZdtbAvjYu4nlVUZ LD2Ar1XwB+yh451k50bw5OsPVry6GxVUDs0mPugV0QXf1OSc138ke76P+yb4Z0jB+Jnje1tiMG6s 7bBLKRnDsPRcdqx/Efx/+G+nkp4M0JJMdLmbOS6n+GP3H/160TfU+fq4mUtMNftJ9jz3Wf2htUvv 9WxhTOEhTgbB6qKzrzXkv7aVF2JNtMiSZ5Zv/rikjvp4RJe87vqzxTZjrnPRyfUeuasRr6EfX0P1 qbHpI0bbB64+taEDk9Dx04oIbNO3f3I/oP8A69aSRgjk8f1rSJMi7boR2x3JP9K9B8NZIHOPcen/ ANet4sykereFoFJ+Y4759/avZ/D4K4z06Z+lc9UKZ3+mSZ9faujQ8VxHoUh1FBuFFABRQAUUAFFA BRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQB438bPBboBPZQ sw/499UUfwgDhse/TpXgw19AeSR3AauyO34M5pPuWo/EIT7pyOwPercPjKI9QB7+hqGiky9HqyN9 1x6g+/uaR70/xID6H0PtSt5lc3kJ9qHp+HpT1um/uZ/wHtRbuCY4XBP3UPrn2qQyP3wPepKuRySj 1H09qrkgfwg9wD3+tJIdyrIiduKia3Hbn+8fagLkLwL2IPv7VWkjHZlPp9alvyGvJlKVVHUD0PvV SXAHBBPYf40Mdv8AIqNIPUehqtI6f0zUlrzKbMPQHsR6D3qs5GODg/8Asvt9an/hhf0io+7HBz2J P97FREOOij1DetK/+Q0u3oQtn0x7+/8A9emuG4yG9QfX/wDVUSYJdyIye2fQ+uKaXJ78dx6Gncdh d2ep/wD1Uq3PoR6/Ue1Fv8xgt1z8ufRh6mnmbHUY7H3NN+XqSShwOuG7r9KegJ6gfT2ov3Kfp6j0 j56g9gPUVYW3YfdBz2B7Cmn3BPt6FkWYJHX2J7mrCWB9CPQ0xv8A4JaTT2PQkep9TVqLT5O3HqaE u4iwttKP9o9PoP8A61WEtnHUfhVryJZMLdz96P2BPcVKtq3cfh9KaEyRI/8AY9s09YT/AHR7mm0L 1FELfwnK9QPb/wCvTjA38IPv707ANKv/AAjPce4FIUc9Vx64ov39QYojPZffPt9aj2n0x6n1pf8A DjuOwf7nsc+lK0K/Xvj3osH/AAxGIgeoAPXHpSm3XuPYfjRbuP0Qx7VR0HsfrVY2K/xKT7+lSkIS a2K9CR/WoHiTuT6UxkDQj+EnPUH1+tRMD2P1NZtjRCzL2U+jA9800un93jowNVIQC3z0yR61Eykd fwHqB60mVFEUtwO30UD1qlLeIvrn0oQNeYyOzeXk5C9PotX4bBAOB7D2/D3qR/8ADD1tQP6gdvrU qxoOoOf6Uf0wXmOMeei++KUW/oM+v1pDfkSra+i5PoamWEd0x3H+0Kr0J9WHlf7P0HrQIz/EAPUf 3TSRXoMMJPp/hz3oNuv8WD3H1pit3AkHp9B7fWjyAfU+3vSbGNNrj+E+/v8AWm/ZX7gj1X6UxIa0 DD+EAeo7Z9aQ2zEcbfTJ7YoZVxhtfYepPrSG3B6/QU0iQEK9256ge1OKjsB6fSpS7j5hpUDp8v8A ntSBR1B+tNeYDCaj3kdif/r0er9B37+owsf4uO34/WozMQO/oT7Un5E+hDI3ow9CPWomm56jPb/d FIfr6FWb689SPUVAx9z6n2+lMcv+AVZGP8JJ9B7VXZieh9seje9SyU+xXkc85OexHtUbN6Ln0B7/ AI0f8ONPt6EDu30/2fU1HuY+np+FMP8Ahxjl/UA/0xTWzxuOfX3/ABqLjv8A5EZUj/2X6e5poib+ Ikf0p3Fbt6iFD3PuDTfLTufqPU0/T1Ad9nA6ufRge31+lAhUdz6c+tS32KHbFHUk+oPr/wDWoEY7 n8PSi4gWMfxt7fjUwQfh0B9R70wS8x2wdxx0zUiRoPX1IPf8alrzJS7jvl7oPb2p2Qeiezf/AF6t L/IocRjrn/Z96FIHYf7R9KV+/qIfkDoPbNPEhH3fwH0oS8w9PQVST9/6/Uims309gPQ/4UenoOwx u+FyPuge59BWlp3gvUrr/jwsJ5P4s4PCgeuKLrqzop077LzPQvAH7KOsasVOqKLK2LGJppf+War1 IXjOP/1GvpDQf2M/Bdqf3E6XjqP3skmMFz7qTWd/5fQv2ltlfo32O00v4YafYlv7PW0QY8qLyiBs c+5rmvGvg+VoWj1nxfqVtBId9zHaAfvYV/hZwDw/f8jUyXeK7MhTu9b90Y+sfDDRYbb7ReS3EEIj Fpb3pwPLtAOPk9Bj0r4V+MWl6Fctnw/441OeQHCwGQ4jLerZ7f8A1+5q4pr4bdjZ1NPfX90xfD/w p0owmTxJ8ZnsrjA+y2UTFiGOf9YSeNv4fzx6x8O/F/gbToc+N/i1LeNyLG1QEmLB4JYeo/oOuaer 2t3Ryc38tNmz4k+Nnw/hQNoHje8nlPzJBGrHag/vE185/FHUrW8kE1vrIu5JObiMDm2ReAG+o9qi NN9Wuxu6v80bdGcstzlVA7dPcZr6x/Y5+G8MMd7quuRDyLZH0vwy79JdR2ZZo2P9wFV9eeK2oQ12 8/0MJy00/wABw93qdxdySS3rEyyMby5c5+Zm9z61JaCzKyG8uXVgP9ChRc+dKT/E3+yK1qrX8Bt9 vQoO5x9z5uAG9FxVSazPQk+9c7XYZg61cLCuEdi5PbstYkckjDDyv6kH+orkqzfQ6qcUZmpEDrn2 HtWdEw2NgY7Ef3SaiD7sJnP3TY+7+A+lSN4svT1mwB8qD0HsK9GKPMmRt4iuz1mPoB6VXlvJHP71 yx6ZNMg1vCVtvuY8YyMuCexH+Jr1rxDLiP7xPG4+zVw4nod+F6nm3Kg7sHPJHqT6VmzXOwqeSQyu B7Bh/SuiCM5s++PDClreI4Ayi5A9StbQQHr+VejE4Yf8EjkXHYVQmi9P8itg/wCHPKPjnbFtPbgc MCB/d47flXyiQe//AOuueqdHRfMicg9z9KZC+1h19MVykHURHH8sVT12Ilc/hXAlqenbT8TmAvp/ +oVIo/z6V6J5A9eP6+9OB/xqS0OUj39Ksqc9vemi0j0TwB8LnvJIneRdgkVkiP8AEAw6mvoj9pS4 u7WKFLGZo12qs0Q/jOfX3ArrpGdNK+vmfP8A/wAKe1GVP3M6Fj8xDEZwfUH0rHl+BurRn51iPcjc M/8AfNZ1PQtNdX5leT4SaqoybdfcA9R7AetZN14UvE627f3SfQ1g0apLozs/Dmo6vDHtg0ZJl+75 rjop9MV0dtqd1bqSz2dpnl4sfeHv+Nd9Cq+r8jzq9BdHfqyey8QxWmZLzU7dQfljhjUZupGPAA/2 j6da9K8NfCTU9VdZ/HQlSDiXSdGb+GI9DNH9P8BWtSq+pjCFtUn2R6Rr+nrNEFEahB8sUYHCKB2H sK5rSbRoeMY7j2rA2vpr6o6WF/f3+tXo3Ptj+p9KZJajY/w59T7CvNviD8a3t2EHhGA3+pP+5dY+ Rabh/ER3UURNILu/NlHSv2dLSGBm8TSG+v3zJczPyIsjoin+6a8w8eaVNZ2rojsik4RfbJ6GpkzS Dvu+t0eG5weT7H/61IzD0/8Arn3rjl/wS2RlqqzkdifcehqUDJ9D1+azlDQTMuDl/wDdP+Feh+N/ B8d9Cs+koGJAN6EHSX6e9XL/AIBNLfXr7vzE0K0RbB/OAyRzx1Psa8rkHucdj7VVyY9fUjx/n1pQ 57UhhjPr7/WtjQ4uScngFgfce9JiIdu48GvUPhX4bSWXdKCVXlD/ALQA7/Wom9NjVLX8DjdTuWSQ hZ2YDCZI6YHb6U3zA33856fWs2aR8y3CM9Rx6HvirUb9e3qB6e1ZM3Rat5cEcfl9a9U0qdpYgSh/ uMPUL6/WuKt/wDrpL/gFx5C0a4yOqhf7tUp0VkYSRg8EKfTiuQv1Zd8APutFBl5BKbT2IJ6ViePb ZTFJvRs7SSnuPWtKT97QyxS00XSx4tHERjIJPYD1+lexfCb9k3WfEhL3F5b6Tp6YfU9TuSP3SyEg bITj7xB7gV9NE+frVEt35nu58c/APwCANCsI/F+pj5ZbuThRKM8sWGBluOFY49a8w8c/8FFvGusZ XT7hNNteVgtLYYxGT0aXqcfgPSuj/H8l2PnWpT+C6Wzf869Oh4pf+LdVvSTqupyyE/eGT8w9zntU NmyIfu57k+oqG+/oe3QoRX8OJ0lg+ei+4B7CrFnrKQvl0Urghwe+R6exqE+x0yXc4i9KFjtXAyWA +pojP/1/atn/AMEwNG3U9149K0bYeg/D0qfmJefqjTgIx8w59a04pAB0P49x7VpAmbLVvGT0z+Pa u+8JzggZH4eorW/czv39D1jw9NsPIP8AsH1r1bw9q24Y3dOMetZVfMyjL/I9J0afIGf/ANQrrIjx XCelSH0UHSFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQ AUUAFFABRQBV1PRLe8jdL6MPE4MMy+zD+E+qmvhbWLTYxEgG4Exsp/hKMe/tXZQ2Zz1TBk1eeI/e 3DsD2/CprXxPC5wZCjdeRx+Z9aqSMYvubdtroH3iCOqkdjWvbawHIy+339RUP1NUzSWAnkTEj+dW FgI6SH6+/t9Kl+ZV+xObdz91se/vTDA/8T8dMU/kVfuQtGw/i+tVZGI/jyOuKkleRE0o/wBn6HvV WVh2f2Aot29CkU5Jv7r4PUkd6pz3xXrIf932/wDr1DXl5FFGXVQerH2H+NUW1lB0PPTPoaQ2+3qV m12P6Hqp9TVR9cQdWH09BWcn2H8ypJ4hiGdv69jVZ/FEAPMqn1Hr9AKQXI28SwfxOPaq7eJoR1lH sB3PvUs0uRHxJFjl19c+pqE+IYj1mB7gDuKPVegkxBrsPaQemP8AGga3Gf4hjpj1pW8wv2H/ANrx t1I9SfQU86hGeg47e1L1Hf8AyHDUF/hz+HtThqKHufUewqox7sF/wGSjUAc7f+Be/wBBVuO6z/AM 9c+woS7lX/zJ0m9Bjt+dW4nJ6hvc+/1pk3L8Jz1TP8Q9/wAKvwOvZD7H2+tWNGhCB2jYdquRQrjh WI7nHehLuBaWJW6KfQ8d6tx2i+hHr71diGyf7Ah7ex+pqYaZ/sn6elO3Ydx40fJ5GO31pRpIH8J9 PrQA46QOwX1OfT2pjaUo7Ed/rTF6/IT+zx6Y7A03+zW7/XPrik0A3+y27fh7GojpDn+vvS9BDzpT exqRdEz0A9fxoKE/scd0Oe1L/Yyn+E56j600NkLaCe6gHp9KhfSH7off3NN/8ECvLprH78efQD0q lNYn/nmR/UVNh/MrPYt/Cp9OneqzWT+g9zUNC/4ZEf2ED7wY/T0pr2GOg9v/ANdUUQNAV7Ee3rUL k+pz0zWb8vmBl3Usw4CY/ukevvin2ujvIc3aZ/iVfU+9K/b0D19Dbi08dgB3AFPFl6AfSmUv+GHJ pBP3VAHpSrpyjr1/z3pS8hr0JBZp6ZPc+9PWzHfJppE3/wAx4th/Cg+v+NL9jJ6pg/dA9xVDsI0D jqPamNav3U/X1FShpf5jDbP7emfaj7IR1B+vvTJf/DgLZh0UH/Pel8ph1J9DR6ifkN2MOq+31FNa L0J/+vQ/L0Hfy8iMxkdee+PX/wDVUZj9VA+n8VL5iv5CCL8R796PIz3we/8AsmgpCraeo46E0iQZ 6L7Lnvij0JQG29cN3IPb/wDVUYtfUYHX60epbYNaZ6gAdQc/1pn2VR/F7A+1NoTf+RG1qp9PRSe5 HtVdrb246H6+341NguRPaY7D3B7/AEqF4VHUZ75HYUn/AMAditJEvcc9B9KqvGB0G3/Cn/wwSKks S56e2fWqrsB0x6ke9D9PUXovQgZvT8PfNRbl7n6+1L/hgv5EcgHrntn2qBiuOcemT3zUtjf/AAxH 5y/wsD7+gFMa7AHOPqew9qT9RfMY10O+P/rUkk5PTJHVSO49s0ibjDd+3sR6imrdgZwuO+aaRV/L zFNyT1IpDdr6Ed/x96Ldg/4YcJPUgjr9KeJfUj2NCYJf8EXzVHT8c9z7U8TAev0pP1D5iiQkdR64 9RTxdk/3vQZ/hx/hVJ+Ql6+ZIJifT2P4U7cfqP4gfX3FA/n5CiY9sDsfcU1rvH8vqKYn5+ohvF/h z6D6+1MjvW7Kfr6Y96EUl2LWmRXd423TrWadh8r7ATsJHcj1r1Twr+yH4p1DBurVrKH73my8EH/Z BqHJdPQ6qdL/AJ+M9g8NfscaBaEHWpzfP1kiUAA/VzXrFjoGnWEZGk6TbW64+RlHIAB/i9qwl5mj n/IrHPeEXRrNDIxDZZ1T1DSHqBWlZsrZ8mQjndIFPf3NbryOepu79yTyYx0I65Y+9ZHiLxdcRxgW zJn/AFYdhny0b0BofmxRRyXxR8TalNpMq32oARqmF4A8x9vAOP7o6Zr85LxmJOcnsCe/4UkzZ7ad 7ld7bPWME+pHelaxA+/Gp9OOlBzNPzJzbxqPkx2DBRyD9BWZqiY6KR3OR1PuKpeQWfW5Bb295csk elW0k1xIy6dp8KdZbmdsAIB/eJr9Aviilv4T0Wy0nQYpY5fLS98TT/8APSQ5LfvM/wDLa4JPQ4AA FddCPdvv/X4GV9V/4EeAvZspw2ffHYe9PFsnZAvdR61zT9fM3XkPjsCeqknrupraef4gAOSx9APb 2qR37+h53rF40shK4x0ix2Ue9V4lH/1x3zXnVT0If8OZWqkZ46f0rHmIC/KPr7j3q6aMqph3hA7c 9fpVP6/ia74nlzYUuKoi50/gS0LXGcDgZH0z/QV6N4rcBQMAjGNwP3iT/WuGu9T0MKt7ryPPbggK MZ/u4rE1GTaBg85BA9SGFdNMwqeR+gfhGMm0gJJ/1akD0JXtW6Yvp6cf4V6EDgpvT8CCVR/9aqE5 x0x7e9bpFfLyPMPjUinTpODwyn6jB7fSvkqSMDpk+3pXNV8joWxXceufWq+75hyfX6VzEnV2rZAz n/69N1OPchxn1P0FcDPTjscjj3/D0pyiu88lko465oHPb6UIZaSxc9j60EsvQHPT6UWKufQfwds2 ka1SPezFhI6DsF9foK9D/aZNxJPHmNxGAqI3q4YdvpXbT8xUVrv0bOAhmKgct04z3X/61MkuGb+J v7oJ9R70rlRj/kUmmkGdzcdj9azf7DaZsuc9x/8AXrGSL+Xkb1lZyrjccjuvbj6VvaD4Fh1OXbP9 lTguTcHAyO2T61vFdjn9PUNN/Ztb7bG+vXcTwIwuUVCMLGh4wD9PSvebvxFayMSkqhfuwqeyD/AV o4vsYVnr7vayKst7HIPldT3GPb3rFZEB4x/j+NQ1/mSi7FMP4ePc9quQTjsc9yT2Uev0oQr/AOZ5 j40+Mt9dyfZvAC+fct+7vb+POLVD12N6iuu8AfBey0RN0x+1X7/NqF7J1BPZGPv+fenb/gms3pZL f3pHS38vBz9D75rxH43WCpa5ESg5GH/vAHv9KVv8iqG58wPx0Ht/+um7h/Rq4JGxCTj+lU7qTH8v rQiblUS+v/669Q+GHjtBuh1Jg0TcQbv4Xb0H+zVszb7eqN7xrYfYoGWDcEPMZ9Qf8K8Wkz2Of60o m8l26+8Rf5+ooyP/AK1BkKAa6PQ4MRyE4wBt/E+lJgv+AVLeAn7v4mvobwTo6WFoC6csN8u7upHe sK7OiktTwm+djI2/Oc4cehH+FSpj+hol5Dj5lyFvf/8AXVqCQntz3J7DFZs2Rat1I6HA6fT8a9R0 WTMS7XYcHK+9cVZHVRf+ZowwkxHGBg/99gjsKqsqkc5PGVPqcetcbN7dx/gBz5UgYAbXIC+x9/at PVPCb3ySgSLGQjSvITyIkHO3PoK0g9TLEbfK/wCB5Jb6toOlj9xGL2fok787COuxPf61maz8WNZv V2m8mhh6+QpwCSO6Lx0Ar6Zf8E+LjRcta603SOdWIdWyzfd3t/jUwfHb3+ooueoor7KJUcd8etW4 ZSD90EdwPT6VbEbVtfyAgbODxn0PuKnv9Nl6bAvcn1+lEYib7/I5e9g2k5IJ6E+v0pkRHfd7e9aI i3cvwyegI9frWnEfT6/QULy9DKxpW+7PP1x7Vpxtxwo9j6D2rSKJkvP0LcAYfdJ/3fX612Ph6VlP yk+/0Nax815GTXmewaGyOB5MhJ6HFekaApU/MOOmfesajM0j0/QpRgYNdratkVwno0mT0UzrCigA ooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACoZr+GMjz5kjJ+SHcfvuB2P0ppCb/y Jhz0we4I7ijFDXdBfzCjFIG+4jOFGXZVA+Z2P8Kj1PtTY7iNxmGRHXqrqcgg+hFO3kCfYfRSGFFA BRQAUUAGcdSAOpJ7Cviv4k6hps1/cnRLiGWDzNqSxEFWnCjdsYf3ZcjrXXh1uctdnAXKZzwPX8Pb 61jXMJB4Xj19K6GYxCHVJ4v9TKSO6Hv+Nbum+KN3Xdnp9DWTiaXOrsNXdvuZPqDW7FHNyTEyr1wf 8Kmxp8/Qmh1dD97Pp+IqSTUl/gQHsopW8yrFKS/Uf6xSB2HpVaW5B+6Cff1FPl/zHYqvdD+JDjri qr3a45U+oUVBVu5l3F6M9GB7+/4e1ZVzqD9yf8RSaJZl3GpOOoI/iyO49qz5b1ux+p9/pUX/AMi0 ijNqJPceh96oyXx7E+mKyY0im1yT0+nJ6CqLyAe3cH+9Sv8A5DIzIG+9k+vuKjaQn7xH+yP/AK/t Rcr+kRl8/wB3Hf8A/V9aQynsQPb0qfUTFWQj1z6f40guT6fXPofei47diVbsjuPQH0FSLqb/AN4g dcH+I+xo+Y35epMNYYfdP/AvT/8AXU6aye4J/qfYU7EpluHVgfUHuD/EP/rVfg1YfxHnoPrQh83+ TL1vek/xA98ema07Wcnqx9OO9NPyA2bSEdiT/C2e2fQVuW1sSP4cenpn0qmv8ykaMOnMejAH+Q9q vRaRIP8AloD6L6Cq+Qmy0mkS98evFXUsZO6Aj+EelVYVi3HYsekanuc9vpVqPTZD/CfTB9TTSETr pEndMf59acujMf4SfrVWEOOinuP/AK30qNtHHdD9TSsMRtGB6px6GmnSR2UDtgf0pDE/sle49qQ6 UP7v19qQgGjqf4T6Y/xqVNHUdEI70hokGj+in6e1PXw/n+E/59qaXYf/AAw1/DpH8Gexz6+1V5NF HaP8aGDK8mhg/wAI96qyeHV/jH4VI7EMnh6MdhVN/DEZ+7j0z6/hRfyBefyK58I46kjuMd/wqtN4 Xc/cjbPoO49xUtlIzZvC9wOsbEdxj+Ks+40Vx1icnrtA6UhpCWvhW5fn7M5/uqR1HuDWhB4SuePO iI9AfT6+1SNrv6stDw3IvWMA980+Lw63cL9D/QUxNdiePRx0Mm31wPT/ABpRosR6An+6cd6d/wDM SfkH9ir3iHoTij+yf+mePQ+tMa9RrWBX/ln7fh70wWp7L7p9akb8mMawkP8AyyPru9TSNaSd4yPb 60MLefqI2nt2i+vv9aabN/7gPY57D2oBrz8iN7WQdFH/ANao2sSe2P602+wELWzj+A+49qYbWU9V 4/hP+P0pf8OK3dkDWMp6J7k+3t9aFgkPWI/7I9qLhYaYXHWM+h/+tR5D9k56/Qe1MEu/qIIJOdyM D6e9AEn932x60gt5kLRSjopPbHpSMr/x598UC9BpRh1QkevrUWAOiHPr6fWnf/MqwjsO6HHUED+L HY1C5z2IP9PpT+fkR8hhdT1z6HNRSbew9s+9TYr19Co7qeqiqM7KOmPr70f0ym/IpOBzuAPY57VU kTP3ceozSv8A5Elbywf4h659DUTwJ35/2vUVL8vUPQjaBR/T2NVpYQejHP8AEPQe1L19BtmelnIp OX/3cdgaGj9z9fQe1C9ByGsnH3vYe4qMyHsfYH0NL1Fb/IYLs/X/ABqfzQevHt/9agVv8xTOo6L/ APqprXH90fUen40v6YP/AIKGGdR1z6Z9/akE2eh+tIaXn5D1dvY+xqVSW6knvgdqbFbv6iqD3wKl Cn++B/ShMbfl5D1mA6tnsv8A9akN8B91uehz2zVJhbsRPqOOrH0J96ZbX0k7hbZXlkP3Y0GScD2o El/wD1jwp+yX4s1LaWtGtY2+YyTDAVSeoJr2nwz+wvoNuJD4j1B7pwrSJHH0V0Q9XOOvtisZT/lP QSS2s3+Rc/Zs8O6ZBZTvbaZbCZrhoFuCBlbeFRgIfrmvZnncj52J749Pwo5e5NZau3oiFcZ5/wD1 mnampCHBI4ZvyU0pGaOV8LWhFnFtiPK+aXPfJPSrWlkgNwBzg49h3+tasmRHc3yLnceO496wrlFl +8c9wPoagEcN8ctQCaW+GBZjsYeiqvTj1r4f8O+H4765VJ95Q5dlU8kDHQ00zWW3zPYJvgtoSYEl tKpHzMR1wPUe1crqXgKB2Y29tHBbg+TG5PM5B46+v69qxUvMd+6XYvaF4b0+JwEs7ZiDm4lYdQT2 B9q8v+JyxLduLZAqZ3RqP4QfQfSrgzF9fvNT4B6PPLrFtJbyBBbsNcaQgEJLbHIyp9GFeofFf4+X 9/fPJqd3Jet/qIGbA8m1Q8BEXAA78Cu7n06d/wCvuOOC1du1jBtPidaPxPCy98ryM/596vf8JnYE jZKrN0weMVg/J+ZrG/2kXbbXo3/5aRg/dUAjp9fem6hqihSI2CkjYXHXn0/Crt39CFL/ADOX/wCE YtgPvPnoxY9Wpn/CKRj/AFUoPbB7Z9KqVBPaw1iH1Rj33gO8f/j3Ct2xnuPWsG88HX0a4e3cn+Mq Pu4rJUOyN1XT6+RzOo6VMv34ZB9Qefz9KzTbMPvKfYVoo90c0l2GGNh2IpNv/wBehIix2/w1t8yu ccgbVPqMV2Hihwfu8DGAfU159ZanpYdabnBXmex//VXP6sWxxz0xnsc110zkqI/QzwPAv2K3wQf3 aDPrhB29zW4YyOo/KvQicFPYqzxkd8+lULhQP89MVrc1/wCHPPfi2m7T5cg8YkB9x6D2NfHzc+tc 0ze+nzK8h+vpj0H/ANaquTnn/wDXXKQv+CdVp8gKj9P/AK9W7iJSpye2AvrkV58j1ae2pxTx4PP4 /X2ox6GvRR5UkPz6VJbqCw4PWqRLOsdVC8Rgdi3qT6Vzt03PH0I9BV2EvU+tv2YtFk+1QfaPKYbT Mpx0Ax1P1r0z9o2GOQoAiAg5Xj7wHqPauuK22HQevyseEeS2OI0J6q3qMdqYtqw/1kS567R3/L1q GvM1T8/QgezY5/dKO2D3WoYrWTkiAKegBPb3NRYqT8/I7j4Z6DZX02zVGdXIP2fYP/QhXr3/AAyB pznKaxcNzuCOMDGex/8Ar1hUbvp6m1Ca15o3Jk/Zvs7Es97cSMMGO2SN+rerA/3a52f4ZRN/qtVv EHTZwcEfX/GuinN9fQ5cRJdEiuPhdej/AI9teJ9nXvVGbwvrkH3rq1mHROcbnNae07o5tOqfcpvL 4gT/AFdlC3YkOOH9q5TWPB/jrUvl/tVdOtz8kzKw3Ov/ANb601NdExx5erv2O98A/DrTNCjxp+55 jzeX79ZWPuf7x966yTV17sM9AD3z/jU/8MYt9yrJdo33ufY9jXjvx9vl+zJtHfBHoCcfrQ0bUHrq fL0jYJxn0zUZPp+f+IrhZuiJx61RuRntSRJUx9fT61a0+5eN1MbYIIK/XP8ASrM2j6Lu9NTU7RRK Szbd24/wso7H3rwDVdGltnKyqVI42+3/ANaoj/wx0U3ePoZhOOv4UA+lWYkiqK67TLIi1ckADIUn 069/eoZUSHw7o01zMiw88gyn/YyO30r2rxjrsdnakKxzj7Pbj/nmOOn0Fc1c7MOtfxPEr1W3tlg3 JBYdyDUkTcc5/wDrVo/Ixj5luNxjofqO1XIh0z9SPWs5I2T8yzCx/iwR2A7Y9a9J8MPmIYBOPlDH sCK46/qdVHy9Tds4fkbcQD96PHZRVOMEZBY56D2U+1cRuh3gohXuFHHzCSP2DAdfqaueKZGVThiO CkrDvx2oT1JqrT5HzgbN1Y7s5yQcnpz6+1TRxHvj2r6ZM8G3ZEoB9OP609fcfj6mqXl6kskx6fUj 3qzb4B4J+vofrWqIZr28uw5bc3fj1HtXo974TivrRJNPU70BF96tn2+n41f/AAxMttOnvHkOqRKG O0knvnsKrxg9x+NNehBfiYA9/RfetW3J7Aen1xTEaFuf7o9s+ma17WInp+ftTj5mMvIsJAw6bh6e wNdV4dYgjGT/AAkn1/8ArVrHyIZ7T4Ot5eyAjGUPoa9Q0rT5xjcgHc/SueoxJHf6LEwA/X6121kT jvXGdlJFsEUVR2BRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABXK/EHQpbm1P 2YEuhF0gHdF64+imqiTL/gnh7zzJ9y6uIx1Gxj1/Ct/T/jz4gtgA91BeKOEFwvJX/alWu+S7/I0S Reuv2mda6Q6TpsJPKyksdv0XiuWvviHrd2xa91m7z0jjhbCxr/sRr/8ArPeohBdDT2S6tl2wlvrk gXN9dzKcbo3ckPj1Br3fQNN8iFAU28cr6fhSrLQLaaJGlRXEYhRQAUUAGK4Xxz+0P4a0HI1G/W4u 8CRNJtyC+1s4MvoGIPX8BWtODe3zMak7fofLfxF/ah8S65lTcNplkeY9OtWOZo/+nuYAE8duBnnF ed6LqgiOx8bD/qVA+5gHvXqOC+yeen3fqas3PReegz61RubRj0Bz6emKya8zVFL7Ceyge/8A9apI LMx/e+o9qz9C790dRpN4BjcT9fau104mX/Vlz2x6D6e9LlOj0NZvCRjAzDMvcEjq1a+kfDG7uUzF bNL3YgdFJquXubRi+pHqvwyuLcfv7Fkz8iMR1b2NPtPgnfyrmK0nYH7pAOCR6EelCXmOMX+phal8 M9QtnC31pLDnmNnU/MP97Faafs86zIMrp8/qgCnnI+ncUJLui1Du/M5y++Ed/FLsuNPuElPMMbL9 8HunHeud8XfC7UtLAOradPAjHy4pZAcPJjopI64qHFd13CUPTscDeyIvVhjp+NYs14ndgO3+fpXG mYrzfkihNcx44cHuce/qazpb5OzLjp9fxqS0+xVe4U9CMdV/Cq0s57kD29ahsm5Fg95DjoAexpsk gH3SPcmlcv5+ZH5wxy49c56/SmCdP4j0+8p9RRfsL/hhy3aHpKnqoB/mBUnnxZw8yg9wPb2pX8iu b/Ia9xEfuXEYP90nqahmu1A5uB7L/jRfyJcv8iS3vYe06t3x6Nip4tYgA/16k9D/ALP/AOun6hcn /taAnmZCO5Pf/wDXVuDW7XndMD/c56EUAasPiizXG66iHHAz1+taFt41s/8AnqpPoO/1q0JvyOgs /FUbcx4x1J9OK9E0bw7qM8Ikg0yeSD7guQOCzeh96u/+RpFP9TrdH+GGr3UipDpkgdsvmTgKiKfv FvX6Vs2/wM8R+YUOlMpA3l9wwy4/hf3q1JGigus0dfB+zvqZjQieASHBnhJ5jVvU47D3rQi/Z+vg SGubcAD9y4PEpI7jHatOdCdu/qQ6b8DdUJ/0uOGNecvu7g+g9a6S0+CcSg+fcqG/hCjv7k0lNE6d /Ml/4U1F2uF9/f8ASg/BuPtdL+P/AOqn7RdUF12YD4OJ3uI/YD/9VNk+DSn7t1H+Pc/lRzrsF12Z myfBi9/gaA+hz1/DFVLn4MakFJiigcgblQNy5A6L9fwqHNdLjsu5xL2tyPvafMPw7/8A1qPImH37 Kb2XB4+tFvMhrzNHSPDV5dti0sJWIG9yRgKv+8a6a1+Emon/AFlqiepJ6n60myox7yRor8HrgdTF nuM/yNaOm/CiNf8Aj9ZfTavUj601NdBtroGqfCiJ/wDjxI/3W7Ee/vXPXXwmu06Qg/w4B7/hUuXk Gncz9Q+Ft5CMzKFHXd7++KoQ/Da7lGYY/MXoW9M+9TcVl38yhqfga4tlzdQFV6bz6/8A16yrbw+0 4zbRhx03D/61K/8AkMU+E7kD/j3Y+vtSJ4TvCRtspWzxFtB5HuQKmT7+hpGD6epFqHgbU7dv9Lia JMbmRgeR7Ulr4IllUvbWRdBhZJlGQhPqay5l3Hy+fqbWmfB/VLvP2aJsDgsxAHPpmqN38ObyKQpL ayeYMsUHdVHUEdsUuZfqW4ruvMpr4KuXOI4WY/dRQOpqKbwZOjFZYm8wfLMhHMZHqPatL/5oyt29 BB4XckBYST0UerVXutGaIkTRbWHDqf4SPUVXoJ/8Aptag/wj6A9/cVG0AHUqOx9zTRF/PyFey2/6 wY9Ce59vrUTQR55UL6j1NHoNjfLX69jSPEoHI9jR8hohaUdiB7/SoTInfHoT65pEvzGSRAfeQ46Z PcVASp6D2YelNr/MoX7I558s465x0A96qyHHYDsfrTY3HuvNELSepBPfHoPWkSbd938PY1Ar/wCY wz464/8Ar0odT93n+6o7/wD6qLA/L0HtA/dcH29PeoXDD73P90H09qfyKa7rzFSAt0GfVfSmyWzc ZUY7H1B9KpLyFYY1kf7vuFPp+NVjEF6jHf8AOqcRepGIR2AI659AKjkgA/hPoxPp7GoX/BD/AIZF Yxg/eA9CB3H/ANemNaAdvwPcj0qvQdvPzKstovdT9D3rPuLRP4VB9B6VFmSyhcWY/jUjtkevvVCW Feyg9s+uKGVbuUnjJ64x0Pt9agZAOhA9F/wpejEl/mQOMfxH6e1V2Lf3s+3pUpgQuP8Aa9yKikfH 3WH+0PQ/Wk2Irs7jOGHpkdifeq7Tv2K+4NIBhufUH1+hprakfQex9RTX/BB+vkxp1QfxZB/pTP7V U/db2albzG2OXV0PRhjpu9T7CnJqEfZgP6D/AOvS9RP1JBqKnqwx6etPN76uPUD0ot5juKNQHdz/ AIilfVkHV9vYn1qv+HIRVm8SIP4s/wB33H1qs2us/wBxSO7H/a9qEJvsSKkrj95M2PT+6B719T/s pfBq3VGvNRsY5c5t9FeXnJz1Rf8AZqZPv8jWHmfUL3kjFd7n0A9BnsKiuJgsU5z0jkIPofLNYPyO qJ5l+zwyrpCkkZaaVzj+I7vX616m8nFasdR6u/qMi5I/lTfEd0UifZ2RmPthDWUhRKnh2JRYwbeS Y1difcdqpm6WNSEx3Zj6n3reRl/mc/c3bN93BH86rxalAn/Hy+3+6Px9KzNWuxxH7RDQ2+kZRMF3 AgDdSqjsPavjz4WyFL4M0AcqjSbT2Huf9mrj5jqbI96F1azjKldx4nI/g9ga4jxNp6SSJHZs5Q/v rl1/hAPp7msVEE+/yK0Hhu5imbzyQpwY1X/lnGPf1rxz4nSD7U+CcD5OfRQKqmxTW9vU7X4Vwf2b ZyyyqvnS/uYCeq2w9fxrlvEM5kcmQA/xA+taTl/kY0FvcoW5I+6x9APapjI/qT65rnv5+R0W7luC Zl+4zL7gnkj1FWBrF033rlyBwq/3R7D3pOo/1D2a7eRYXXJk6M3qD6flVyLxHL/EAe49q0jiH19D OWHXQafH0cZw77exH+NXk8awfxSqOxI7/WvRhWR59Wk1+ZKNcs5f9ekMg7hgODVeXQNDmB83TI/T enGSfUVvoY83ZmZc/CvRZP8AUyyR55AH8IHr9fpWZdfBNOtnqYf0Rx39zUuHb0LjV7o1PCHgS4sG Y3bK2eUC9k/2jVvxJBI/KRk9lC9x7fSvOq0nfRHdRrLucJd2kmeVYH+6RXN6kjE9Dnrj1Oe9bU0Z 1Gfoh8PCDp9sWOP3aqyj+FiO34VvO393OO4Pc12pHFT2Kcy5757gen1qhOh9eOv0q7/5lr1OB+KE YawmyTwMjHvXxy/vyemfXj+tc9Q6Vtp3Ksjeo9//ANVVifUGuZkx8/Q6LR5cr19sela4YH73THT1 OK4Kh6NE429iKsf85qEA+ldsTzqu4uD2+lWbFcsMZ9vY1ojL1OquZPlH5fh7/SublAJ6jrjJ9c1p fsJI+2v2a4le5QbeFi3598f4itD9oPV5ftaB2+ToqDueOc11xf8AmGHjq/S558kKt/CB3wPT2FJJ AD/CCezegPv7VTRld9yt9nTGCM9skdOaj+zIP4F+nr9azf8AwCte53PwbsIzfKSoyAQCP7rEfyIr 64hRSRlF9wewrKoaR/4c4/x7qseQsSgdyB7e1cEFyefx96cf+CRUHiEn7uM+ntXjnivxJf318YNI nkjA/eXEq/whccAn2p/8OTFd/U6SH4cygc6rcBuhOchWI7fSpV8HaimM6s0gHGCPvE+hpJ+nYSa6 xOuTQNkYM55PA+nt+NUp7Jex/EdjVolFJ7Hd1b35749K8e+OemnyE2Nu537PQr6Gk2a0N9T5nl9/ oTUR/wD11xs0I2bHbP8AhVWf6CpQinjNWdPiDOMgdc/iKslo9i0bxyLZ0SeT5W+QN2H1PvWZ8QvC isS0a4P3wR/Ep/xqLdjbDf3u1zyuRCOopgPsKtoyZLGue/0+tet23hURaPvdTvaTCn0Tb6+1Qyqe 69R3wn0DLPJNFkAbYGPZ8/w/jVX4ma7JNIFWfKryQO78dfwrlnuehQWj+5HEgMxOfUnHpViJvf6j 1rWRyItqAO/HpWhbkjqB6HPqaykdEV/mTxBf4Vx6n3r0PwldHyyA/Hdfr61yVjopPsdHbxk5Cqf9 n2xVNAM89fvewHsfeuP/AIc2Xl6h4XTbdThuMhZVT2APf2FbevWweM5BPdSexx2+tR108hyen4nz nq8JSZwMDB+Ye7Cq0anuCPQV9PE8BljJHT6EHtTwhPQe9aRExSP9j3H0q7BB6Ee4961Rma1rae2e xPoa7/wT4rEDFL5ibd/3dyo/gB9qTZSt1+Zx3xL8HxWF04tGDxN++t39j6GuRiYen1FaLy9TmX/A LkWT/Ie1alsjdvypkPyZp2sZzxkd/wAa2bJT3Y/4GmvMzk/PyNIQNjg49B61saKGVhkk9gPU1dMi /meweE72VCNrnHXb6V7NpN9K2PMJ9SPes6qHDyZ3Wiue5rs7NiRzXEdtMdDdZdlPUYdR6oR6/WrN UzoiFFIsKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAoKg9QCOhB7g+tAHBeIfgb a3JJ0yYW7H52iYcbsH7h968b8SeFbzT2231s8JJxGW6SgE8o3fdiu2nPuETLZg2MjJ+4Qe1dX4Z8 AXF437lGbu3+yvvW0X39TraPYNB+FdlaYM4E0g+bBHCsP8K6quKrO/6GE5dgorEzCigAxXOeLPix oWipnXNQVXxugso+XuCenlxD+8e5IHqa0hBv4UZ1Jpb/ACPnTx5+1treohk0PdpNqf3LvGf3kic5 zPjjzB6AEeprxa7vGYkyyM7E7pHbq5PqfevXhC3w/M8uUv5jOdS3Yeufp6fWqrxMvK/KfvD3x71d v8x38vM6LT7wSjk89HJ7GrP2TP3yfUe4rma7mqXmRtpIJyAD7+grQsvCTy/djZj0X6e9EV2NoryN k/DbUYxn7FKV6lwp+Ue5Ar1H4ReAGmlH9oLhf9ZKPUr2A96ctDtpw/mXmfQknhnTnUrJptqyEeWy FRypHrWT4JASAqVCujtaXIHeRD3z6givP5nrd+Y+buaWvaT9qgddgZipaAEdJl5GM/7VHh69SW3i MQABRcgdnVefybNR0+Yip4u04SwEiPeyFbyL2ETjPT/YzW3HOrgGNgVIDxsP4lYdvrSC5z3imOKJ oJZowRHIIZJOP3MF4QpJJHRW2+lct8fY0Okz+YoZgUe2XH3pRIPun2XNVHpfvYL9/U/OPxL4kmDs I5COeg74PauSl1y7Yki8kA6iP+9+GKPkZtf5jJNXuMApcSZ6ED+H8aqtqlxn/XOB1APc+xqf+GG/ Qr/2hcFv3szD29Tj+tQPeyEAJcSHuxz1OfX3qdO3mCX+Q57mUE/6S3sM9Djt9aga/fA3TM2eD7j3 qC2xypJ2kYdh7ZqN7uVQcyMfcnofaheYX/zKEMrrysrbs5OallvZdwIz+fSq9SF/wQNu0jZSRlYf MWz1A/xqy86uP3rZPcHuKT8hpEUTxgfus56H2Bp0R46kdvrQ/MpEmX7uRjnAqZFzwkpC/eYn+9Qm +nqA0QTEnfnHQk+nvWnZW7IR5cjP9P4OPX3q7kr/AIJ6BYeITAqrMCUYYklXkgZ/hX3r9BYbKyTR YDotg9vEBFJ83VkLAEuc/wATf/qoUfzOq2mj9Tb8Nzu1zHkkja4IHYgDtXZmTbKeScqGA9CCamxi y3GcinVTM0GKKQwooAKKAClFAjzK5Ugnk9Tj2warNk9+Pbv9RW7QHTeC1IZ/TA/E5rr6ykhhSBwe n0PsakQtIyZoGZ+taIbuMp5pTPBb0FR6Z4chsYQls7uB9536uxP9ad/8x3M7xJoCX0RS4iMoPybP UMPX3rjvCXwmvNIDLLaxx2+NsGH3bWduevrU3NI+bXkdpNY2iptitUZQC7SMOZXx6/WtqxiiCJ5M aKoAMQA+4CO31qOXuJyfRnE/FSMSRIpZl3b0LjqoKjpVeys7ey0kR6OZWO1baWaTq1xPIMtI5HJY mrnHbReYQZ3MMMVlEBvJVQI/MP8AG57tj+8a5PxDryadexM6GaSSKSBV7LJGynJPsOK5bdvUbfb0 RU8LLAZx58iDAM29uMyD3/HNV9E8KzahPeyQXarG0n2OyZx98wxjOPbJHbmt2tdugoy7mppHgG5i kQyW9u2w4uJc9cn/AJZj2ryn4ihjfz4PGV2j/a8pa3S7f1sDZzHw60qOSaaW/kaWNQ1rawetyV6k f7AH/wBerPgP4bWMitdeMNVka33MdK0aM/NfMjH/AFijsrD2zjrTk+y8gXmvQu+LL5bsCRrCG2jL LFp9hF/BGXA+c+rZ/oKwdVtk+3yCHd5fHlQjopwOw9ayt/X3GjX+Z0tr8Ldcu1VtF0qB7YNm/upX 27bZD83kDuVA+nqaZ428EXNrbpJ9jaGN3xCynrAemR/tjnoPatFH1Kiu7Rwms2T4+TdDn955rf8A LKEemfWuLutaluLiGLR7yTlwdSnHQ2ytyF/3+lZRv1Ez3/42+GtPsba0/su1ELtuE8g6yqsan95+ JrzDQLB7siKJCZpJEgtZif8AVKzc/gB71ry6f13Ff/Jn1tZ/CLw/CgX+xoXAHlGV85l46sc96+Jd X1CQTziFzhXZLcD+6p7n61xUU+rN3O/y+Ew9U8TXCR77YkgczD0cA+lewfALwPaawJZvE0RNpHHv dDx/pE6nuP7iZP1xW0n29DFf8E83m1RnvJ448qiMVt891A9PYV6d8HfhpBqt641F3a3jj+0XAT/l pO7AAFvfk/hTltv0uUt9PU94m/Zw8MueLWRfoeoHrxXivxJ+F1lp5umsLxhHEoeCBuTJMyAkZx/A D7/Sohf7Xqauvf4oo1vgB4H8Na/YLJqF1FPeEsNRsEYbrAJIQPOj5/1q4IPSrXjH4S6S2q2ttopK +Yj6hrKHB+zWkB4JHH+swQK6bvqvNGEavRryPRD+zJ4a/hilx0Occj64/pXyp8YNQsNGu3j05jPF vNpBIOzxAbg3/XFiQfpTi31sVKpf7KOl+BnwxXxO0jTTGG1jxFPKOsl1IDgRj2Aya7H4r/s8Wuj2 rTWeqbo1xHcxyADljxtOe9K/ZBTktmv7x5H8LvCcviW7EWmOqoFN3f3R6W9uhAyR/tMQK9+m/Yti P+p1vB9SOmfTiqbt08x05RXxp+RzXjT9kl7C2klj1aNxGpuJR/sKPUgdPrXJ/D39lnVtbt1nW4ig gfL2Qcj97EpIyAB0YihzX8v91Gvud7dGcf8AE74IatoUm25iEiEedDOp4dcnofw9K8kvL14/9cpX 3PY+9Zyf+ZFSP8vqjJm8Sxj70i+rH0I9qqSeMIe8qk9az/4c5m/8io/jCD/nqo75zVb/AISyDtMt JRIcvMibxfEOsq+qgd/xqrN4tVj+6AUHpz1HvRbuUn3Kv9qE/elx7ep9hQmpD+JmHcHPak2NPsyU auo6kH0Y0o1ZD12gd19akV+wfbYz12gdCPWmm8h7KuehA7Uv+HNCEyx91B/iwfT6e1DPGPukexHr TsJevmNaQ9pPf6H601r+QdX46gn+n1pL0EyFtWl/ilbHYegFRG7d/vSE+nt+FaEjEnJ4z7GtGOYL 0BB60WF6k51EqPmcgdz7V778D/8AgoRodjBFZ+L9PNhEn+jabq8eSsmW4M/HGe/b04oUf8xNvo/M +vdM8SWl6FbSbyG5iI3wzRMCCPfBqTWb0JaXJ3YIikbd6fIa5prud1GWxwn7P8IXRLfOcl5Jif8A ekNemzSAYxVXKkyS0jBccn+8T6AVl+NLsJBN6+WwHuStZSLiiex3pbW4BUARqrqPULWTfMgXoMn+ ZrokYJdjFktXUfKo9FHt7mqU2krNIgOP7zMPQHuKzNUzz39rLVoBawpa4wMzSL6nI6/QV8r/AAkt 0N05unG0RkOvoCe/0rRbCqbI9ZXVdKhRhBclmJyF/vH2qjbatpqHMpzIeSv93HqaySIk/L1KN1r6 qcly3faP4jXgnjN3vL1hEmWZsIB/AhPc+1VDz9Am9DvNXv1tIUjglyABCM44b/ZrkNUYkjI5x1HY H1rOT/zHSWmoyEcdPbPrUise5J75NS/M0RdjJ/gB9M+lOjQDsR2OKwZrHyZI49Bj196nSNccn3z9 BWLZsvU5S/PzHJPXPFUrmY54Zh3FdtPyZxVFvczptXuVP7q4ce2ehqaDxvqSfdu3I7r6/jXoRked NLsaMPxRvV/1iK3Yn61qW/xfx/roiB/L8q1UvMxcex1Oj+LGuxm3ViO/tx3q8dcRT+9IBHr7e9L2 q6mnsna486paS/6yKFh/ECP5H3qlP4X0Wb/WWMYPQkH+YNdCS/Uzu+56z4Z+P1xYQpGmmxzRoBCj knLRr6nPaustP2l9Mcf6fZTwN93I5AJ9K1UfMySffzNa2+MOhT/c1CND0WNwfnqz/wAJNZSf6m8g f+IYPY+3tTcO5XN3uct8RpVewn2sjDbhBn7zn/61fHDocdB7/XH9a5aiO2EtNCjIp/iGfeomX/EY rlaCHmbOiOMYP1FbyR+uR6Y9K4Kp30TldYjCucDPvVDB/rXZT2OKvvoOyfarmlplxnFaowfn6HSX 64H3sfwn3+lc2oBcbhkFgpA+vpWjEj7t/ZgsALhyYzgRBA3+0x4qH43xpNcDafnBxg9k/wD111R8 x0Xq7drHDiFgB5ZBPQiqssk69I/Zgvc+1Ny8vIzVurKsl3MPvRMOx9qrl5McRyjswH8VHqa2XfzP VPgtZW8chf7Rum+79nP8EajvX0ZbeKVA/eI3oPrXHJ9zSMexwviHVDPISvP8IB9fc1kAHuB71ujl mFxepCjNMAQAXIPfaK8a+GOnNeXE874YFjHbsO8Z7D6imiXs/wDwE9Y2Y9h0x6H6VEZCPQ9h7/X6 1H/DisdDq848tOB0zg9ga56Vh61aBFSRx2wPTPpXkfxtnQQjd2ztP91jSbNaK11PluZiT0x6VAfb n29645Gj/wCGI2P0J6n2qpO/096SJRWJ9D/9cVf0ZC0gwe+asmRq+Ir1hIpjdgR86H+6y4/lXo+m 6wmq2gy4MyDZOh6sgHahefqCe11/dZ5NrFkUc5GBnKj0rPA9RQazRNFFkgDPJC4HcE9vwr6P8caH JaaZaoiCMMBIYR3BHr7g+9Swo7r5y/APDdhBp9mfNJHHmvjs+f4vqa8V1jUzNIzMSc/MSe2T/SuO O7v6I9JbfiUrYnHzMWPdvU1YUHPH+TXQzhiv8i2in8O9aEGex46/WsWaxZYjkAPzD6V3vhCRgDtw R0I9q5ay/wAjpo+R1FvKVc5zkjjHbjt9KrBgG9D0PtXC13OlLsR6XMq3/wAjEbkJK/7S46f7tdTq AbB3429cj0HtUS6D6fgY3iz9l7R9at0n+G+qub/aJNd0+dhi4lA58le2059c+vavBL/Q9QspCmtW UttKPlKSjG/H9wmvpab0/A+Zc9Xf5C44zwe2fb2pyE+h/wARW0f+AWyQrk/KB75/z2q/axeox2IH c+9aryMm/M2NPiVQQCxJ6gnoPYe1a8dgwX904z98BeuB6YrTk8iObz9DG8QanNd4N9cNKwGxWYdE HpWHb6Y7fcjY9+lbRpPojnlNd/M04PD1wfu29we4wp5zW3ZeDdQY/Lpl+x9om4/HFX7MzcuzN+x+ GOuP93w/qhPQL5Tcj2OK6Ky+CPilv9V4S1f0yIW+c/l2qowXWSM5S8mdNYfs3eMZgPL8LaufYxH5 D7nH9K6HS/2U/G4YbvDF6oHVnUjLflTSX80TFyfRPsj1Dw9+zj4miIL6UEPRt5xyPqK9Q0v4T6su PtUUa/3/AJhwfY1yVpLoddPzOr03wdcw/wCsMf1z/SuhggZR82PfFcTO6nFlKSwlWcMgBQr5E49G BrTqn/wDoQUVJQUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAV5R8dI8xQHaD 87L9AyVtR3EzyCCBw3zRsB13Y6D619AfDK3VYOgDHlj6rXVUemnodcXo/uO2orzzlCigArK17xvp Olpu17U4LVOkQc8zMo6RIOScegqoxb+FETlbc8C8bfti38+V8GW/2KPJR76cAvcRYPMKjO3dwe5+ h6eH6hrc07Fru7lmlJ8yaaQ5LOf9o+te1Sglt8zy5Sb3+RmyT56MT/eP/wBaq7QE9enY1oZ+pC2C MIh46N61F/ZzH7wJ9R6/jUFehqaXp8kbD5Dg/wAOOhrqI9IY9VyfWs5LudMEaFp4PklICRv6kqPf 1r274afB6Nju1GA7B8yAj7ze2aUtF+R20Y9/U9mh0u2jGILWFF+5tUDlcd/rXm/hHSBZahLGTgAs 9qP+mEi5GB7Ka8+Enrftc0u76vyPT65zT5RBeTISAJFXU7YepQBWx9TzWURHR5rnfC0nlGaInPlP i3HpaXK7h+WTRHr94HQSQq4IkAKkFHB7qw/rWH4P1HzINruWliZtLvgf4ZoMYyT6xlTS/wCHD/hy D4g6jZQWM51S4SJNh8gnq94oyojU9S0gHFeQ/Fb4ry3ekR7o0WSVBNPIT96ZE/hH+03PenHz9UZv yfa58Ha9PGpOcMfukn1+lcxcup68+pH8RpLzLb8ivDKDwsZ7tuHb8KhV8n96xA6D2PvU3/zJEV1Y nK5HRH9RVdmU8oVAHQHuak0/4ch+xseZXIz83+9STRL/AMslP19DRfsK3YaWkcEISvcn2HpVV0Aw BIzdn9jVX/zBssw20WDuVgf4F9frSEqB90Z6A1LBIW4DIAQuD3A7mq08T5+bOPT1B/wpia7k8Rx/ q41x39hVjcmRvI9dvofek15jT7iEEn7oHp71J5LZ6H/649aaQieaFzwHAH8eOxrb0VYEyHIlz8gB 759PpVNAjpzdw20kBZT5IKtMG/5ZIZBnb9RX6c+I7S0GmYsfLWAJE9iE6GEMmNuP7wrSPT1N3LT5 3ZmeGbpEuI95PIaND/tkDr9a7ZgPN+X+7859OexrMzZNZsdoyxbtk+xP8qsZpEBRQMKKACigApRQ Jnm14mGP1OD+NVfLz9K3YHX+EIFCsRnOQuT/AHQK6OspFBUMYIY5zzh1P4f0pEsmpCwH8qQwOex/ H0NZ1ppksCt9ou5Lhi3miR+yk9MD+6KYv6Q9Sdy/KTzjHplT/Kn6igKHeCegUe+akorJYFwcAdMD Pc4rQhdSo2YC4GzHZcf0p2/yBv8AzOH+JbnbDsx1fB9tq1YlhEumgviIBVnG3+JonB5/3iKKmy/r uOB0c9mL2P8A18kSsBJG6Dkbh1APpXmnjPS3ivLcXF/KyBGxI3XywR0HrmsYR2vY0v5eZoad4cim P7vIBbbDER99R3kPtVjwdrtvaJeBLhHkW4dbeD1MkSYO30Yg10L1/rQzfkjp9B1jCKtw26TpJL/z 0kY85Hua8R8YhH1GYTMQpkWOU/3YioBwPpTgNeZ3tr8NtHtGdPDlg1yVVpI4N3FvNMp5lkPeU+4P 0rB+HvgfSJbO3FtiW8kLXOoyn/l1to5TuwgJA4wB6k0Jd/n+JpF97Hpd18PfDcSE3OjWuxR5pds5 XA7MT1NfOFyqHUJvKUAnCRr/AHC3YClHzfkCm+p9Kf2bHBDFBBIqMQICMfet4gC5x/tDj8a4f466 9bQ2iIoRpTIkkUI/5ZxRA/fUevbitI+n94iL/wAz5p8Z+Ir65fN5I54zIdv+sGO2PQVsfAL4Y2up X+dQRNig3hxx5iwuMBD6u5z9Aajl8v7w011PW/2jygjtQgXaC4Qf7AVOn0rnfgX8L7TUpZJb6SUL CVgs4ozjN3IpOWP/AEzXPtzV20/ruLm/zPcW+GNvECYfEWt268vKDN8oQL/y03DoPqK+L7bwqt5c XHlX4ht1dzczsP4Axx5a9/MqOX+7bojSNVPt8jl/GlxZyBIPDasmWC3lwOcxq2Tn/eFfQmm6Xc6H o8K2moQqLp1Z4EHzC3Tb1f2VRn61MYvp6siU+/ojxdI1GpXR2qMMY1z3XH+NfQ3wLv5dPt5Xk04S CZ/OglDAYigXHzD6g/rWtKjfSL6XRFasl8XoeqxfFSwAJu2VDgvDGpyZiP7oFfOPxF8WzXb3iBuV jaa9H/T3KSTx/sDjvRWoOP8AEXmRhqqf8N+R8221zLblXsLi4tZRh4bqBirRP/sspHSvpb9nDxVZ x3FxceN9f/0po47K3u7s5M6O3O2Q/wB3aoxjp0qqab0ir9ImlWSV2/Q+itf+M/h/T7V55dXtZo1U y2sKMN17OqnCQIe8rDHp68Zr88viJq898LdrqcmaRpL25mP8RkbJx/vU502v4i8vzMqFRP4GfSv7 IHibSNO0+4TW9d0y0nN091bxXEqq0ljLbQhdocjPzK1c7+0r8c7bWZRa+HtULWcZI1u8i+7c6i3a OToRbLnnpkn0rL5+n3G8fT0IP2UNb0TS9QnhvLqCGaWNU8NSyHAuhA5LpG56tJw2OpAPpX2XilJ9 15ETf+SPHv2lPEckOmeVZM5uLmRNJtI0xllZ8nr6YHr1r0fwf4WXTbO3hVAvlRR2TqP+ekMQB5/2 mBoe34ot7fieSftM6ZFPbxgzRwSfP5c/d1AHAHs2Pzr4i8a+YgHzHPAkbHViPT3rKR1LZHlGpyzp /rDnPzqo7D3xWYJic7up4JPpRf8AyOSRTmgx06dTjsaroSuduc9c+gp38/IzsRPcyH+M037TJ/z0 b1470gHnUJgPldvxo/tiYdZM9/oaSFYX+1Z+8nvj0po1m4H8X0pFEq61P/z0/H0NKdenH3W59v8A PeqD5ijxBP8A8tOn+f5VPHrg7k/Wk0BcW6LfdbNOLt/9b1qSkJgnqT6VHJNt+5x6e9NE/wDDE9tk ff696uLOT2I9/UUWC/8AkZWt6uQMIQD0I/xrnCQfvjI7r6mrRMvXzO++GX7R/irwlKH8L35mg+9c 6RcHKSjH/LMHoT7V9a6d/wAFC/DGs6XcrfbtM1Vo2t/sDdJJ5V/5YPxkA+nPt6RUjc2pS10PZfgt arHotkCy7ipmfHZnY9vrXdTOB1Az0BrmOu5Z06cBufTGawPHUwFvL/umL/vs1BrAtNP5cS+ZwQoA X0AFcq2vLKTtJLDPA/hIFa37mUUPt70yryDnpj0xUlsqhvmbHcH0poZ4F+1JeLsTYAQF27j/AHmP f6189/C63VpZckklNrp/fYdvwo6F1WrK/qela14YtYEQzuRLjzCmfun3Ht+NcfqGvWsSM6xRIc4G Op47j3NZx/4Yxb7GcvjqzdMuSWAy5Pc4rlvCdot3cSTTKojUkQqe7kf0rSxm3/kO1XVxNLgkYHO3 3/8ArVn38oLcHPb6gelYyOqL0BAQOc+1PjOSMg+ppMEXolA6fj7VPEnqfxrGbLh5jime/HrTmTaD g/72f6Vzs6Ejlbwjd8pHufQ1QvFOeT/+uu6Bx1VuY075PrUeK7UjzpCYH+e9BApknr3w/tWjgyqg jG5vcVneILog8EDqfrXnX13PVitPxOXl1WdAdkrA9Bz0qrD43v4lJMofvz3Ar0acu55k0fU/w+/Z 3XVLCKZtc8t3USyREcK7/wB3Oen0qS9/Zq1iPP2Ka3nH8LAjgj2Ndqk+voTTkrar+6cxqHws16D/ AF2jyHHyhxzx7D6VhvZXkPElvdRHooAPOPpWymN0/wCVoZJq906lbm4uCh4ljbPzL9KwLjwxpMn3 4AvqynofxqJ/8Az1WyMy4+GFo3+pvAvfaew+v/1qy5/hTcn/AI9Z4XHULnpj2NYSh2NIVP5kR2Pg nUIW/f24C9AQeprS+wOOqMO2fQ1w1qb6I7aE13RzPiCzw33T65rF8o+hqqS7mOI30HeWR1/Or2jw jfzn6jt+Fbo52bupAkdSeyn1FZGn2TtIuFY8gkDuAf6VTGmfafwF+Juh6R5p8SavFbZUJCrd3X+7 j/D+tY3jTxnb6nOX058xliYGcctGT1x710xemnoFPd6doooiNU65xj5W9frULTJ/fx3Hsf8A69ae vyOe3ZEMpiI+eUAdQv8Aj9aajA9GX0/CkXbyPdfhj8LY7L95JbqzuMkD+FT6/WvT7t7dIyWgIbqp 9DXFKWv4HVFeZ5zcSFjzx3PtihB7/wD6639DhbOO+KfiM2tm5VyGb/R4x/tP6fWqvwy8Ni0tUypV yPNnJ/56MO5+lNP/ACCqtFr1ude8RHeqbJkj9frSQ0betE7UyewGR2NYEoP4+tBPqUpR/eY+gPtX jXxxmURKCzcgqQPX/wCvQ/Q2ovXY+a5W/wAPwqEgdh9K45FsiJHr7VTmcdvwNJAVtw/+tWpoSgvy fcn0FWZyJdbuCz+3atHwf4sazlG9sxn5ZlPdT/jSXmEv+GNjx9oMaENbIDG371CP4QfeuDwKb/4B rJ7GhpNzBHIrXm8oCJHCDlgD2Fe2X3xSl8QSQrBaNFBGBBAX7Rj2FZz/AOCFFa3v0siX4g6vHa2w SFiHb5ZCOrRg/wCNeNEZ6n61y0/P5Hp1dl94sbY6c98+9WRFz/OtjgS/yLKH6fX0FXYJMdRnsTUy 9TeL7lmGQZ+Yn2Ud67LwrcFSQDtzz9SBXJVOmj/w52KTBHG44Y/dA7Ee9ReSQxwpPO4N6/8A6q88 6IleFyl5CRwGDxsPT5fWu1voV2naQeoUn+6B3+tZzWxfT8DzaXxRd6RMv9nXkkWQZVC9C24/eFdx bfE3w5ryCPx5pETv/q4dRUcpu77h/dr3aMuzPn8TQfReaNO7/wCCbur3cHm+BtftLmA5e1spiNzg do2APUe9eVXvwCurB9viTUGsZP4o2TGB/s7h3r0YS8vU86vWt9lvoXIfhH4b4M3iiZs8ttTpj0Oa 7Twr8EPh1M//ABPfG91AnVpAoG36A1vFvtHyPIni5fyM9l0T4f8A7M9mub3xRDeOMB5Z3bqB2VV7 muni8Y/s0RD93Ho7L2Bjkxz65Heui0u8F8yY4h/ZjN/Ihuvjl+zJaH59O0M99yWxOT7AjtTH/bQ/ ZztcfY9H0t+/7uxXoPXK1ahP/n6ZutLpQfYf/wAPEPggg/0XQ4zj+FbNRt/DbTU/4KZ/DJf+PHwt dkdYysKjzAPTC1Lg/tVmUnPpQX3h/wAPTvCi5+x+C9TYj7q7gM5/4DVaT/gqnYsf9C+H98VHLl5h nHt8o/rS9lH7VRjtU6xS+ZC3/BUWZs/Zfh+w/uiSXv74AqB/+Clmtv8A8e/gyyi4ypdyefz7Ueyj 3ZShU/5+EVr/AMFBPF0n/MF04H7q57ce3pWja/tveMZPvafpwPTOOo9hinyx6IqMJ9az7m5Z/tX+ LpSMwWHJ25C//WrvPD/xc8TXR/era+own+etYzUekUd1KMv+fkj0LSb/AFN03aisWCdqIvBAz3Fb dckvL0PUgn1fmFFQahRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABXmHxpOIo Dkf6wjn0KVrS3Ezhtat1CKYowBkBj6Bh/WvaPBumRxW6+WSSfmc++e1ayeh1J6P7joKK5TmCquo6 3Z2aF9UvIbaIcyTSHAHHb61UV2RMpdzw/wAZ/tkKpKeC7QN/e1a4HBPP+ohPp7j8PTwjWPGF/euW 1W9lupT96WU9cnt+P4DtXr0qaXX1PKqVG/0MWa7PHT3FVmO7tjtitTNsjBUfwnPUgentS/ZXbHU9 j7mmxL0LUWjMx4Ujtn1rf0vwDcTn93E59x2FVBdzphDv6HrPhL9mO6ucNdRmJOm5+w/Ku7v/ANmC 1Rc6beM78b0YD51z2I9K5qtZbJeTPUjBJe96m94d+CVpbc36qzdRGvQN7n2ruYrdEAEMaoo+VEXs BXBWqX2Kb/lH15146kbT7qGeBNyn/R75Acb1jI6H/aQms6b/AMjM72PV7R1DRXcLRsPMhkBHzofS vOPiZ4xbTLmzmgcSIC8N1Ep/19tMF7j0GcZ4zWtCm/tJ9TGVVdPQ9EOsw7A6ODEQHWQdlb1xXlWs /EhdJ1fdNOPsUyJbagSOIWVRh8/9M/yxmtqVB63/AMJz+31svU9QbxPZA/8AH0nYgezDjn3FfN/j P4u+J9H1e6XQboQ28oSV/MG5UkjjwDBG/ALd+Of4ugrSOGaTdWPTTz1RnTxN3aL9TO8Jzwaxej/h MtTuL19rPAk758x8H7ijHAOOBgelV/jqkcVrENObcikpKq9Itx6ce1cE3r+SPUt2Xmz5B1uMbuSu OWOfU1zrKpPBGO1QTPzRRlvxnEac9PqahxIMmSNc9gf4ePT3pWIX/BRGl2zdflH8QpZBA3+q47MT 3NL/AIYu5GzjPyEHHc/xfhTMnP3eO4qUO5XndVP3uP51C6MTkcDqQPT/AOtTQi4pz93JHqfShYE/ iP0HvUFCKrZO8e49jTLi1cnlx6IB2+opgyUQ7eqnPU/WqpG5vmJ45x6U0yWi0J2foFBH3Se9W4ro heWOc5xVkp/5ivM2eQB2YGtHSyCQUAGORjuf/r1SY/kd1q2kQzrbk8kssLx9iGlHUfSv0bufDzW2 joq3D4WOJ2Rv7u5eAf8AZOKF09Tp0t87EGgy7Z4endTnsGWvRXtiz5SQrgbGA/i3H/2WpZkzOg1u FVYQyJI6kl0HbnuRVi2uLiRiWmATjyoQP9Xgc5b/AGqRNi+hp1IAopgFFABSigTPN7tssfTJP6mq wX1rcDrfCEmVf2Ix9CtdHWUigpNgqRC01iO/+TSAdUVx0piM6eZlx5bYPY/59abNqbspDoM5A3eo 3elKxVi3FPtVu2MlT6nFV9PLyooOAgA3qO59zQFjm/iLBvEQX1Ykei4WorlvK0/a0olB2Rue0UMs o4JPtVTWi+8cf+Cdhe61DAVWJRJM3y2Nmp5kVB1Y9gg715Z4te5e+h/tHYZArKEToucYx9RWUX/m NevoekaX4eFvGD9lWSf74UnGCe272FeQ6Pey/a7o+QXfzMylAcRKV6kirT/yKR2Phx5p7lOG8lNx DY/1kxX1/wBmvMfG4/024OSP3nDL1G1R/I1pAVjd8J/F7Uo0MFp4ZurYFXnTUZlYbjt6rkdqq/Cj XX0GxefV7APbSuVsrhWGfLV2GNv+2w9B+NdMYJuye9kzJppPm9UbPiH42yakqJZ2MlrCcXF27NzK gPAxgd+T/OvNlydQm2A5BVlb+8V9T7VnOKT0dwpt219TX8cftKSaU7z3WtJCyp/Z8Z6gqWziG2PV nb2/SuPXxjd6pp0VxqUFwiys97aNMctdWqE/M/8AvY9PpmnfTVf3Yiiuz9TzDTv2hNT8V3IgtPD9 tbwIC8t4OsVlB3fj+M8f/WArU1L9om78MXcFv4XggM0zxWmsTuM/Zbea4AAC+rZJ6j3zXo1ZRuvZ x2V5nPTpuz55PV3XkfQn7RKEfY1J6CRj/vKqfzr561z48eKvDgVPAvmPPO20WcQJNxMCBwoB5P0r mw81dOSTWra+bOirTurX8j2fwpceKrWHf8Z9ZH2qUE6R4XtyMouOt9IvTnrz7da8I1XULhHlEErx gsxLL/dLdj7VOKrXfuqK6RRFCnZWV+9yv4bsY1Mkt8wWNFZlJ7oqkkj3Ndj4J1O6uYYJNTkmLyML +CI/8u1s7/KAF/uKO1ctOW9v8LOia2v6oxTOP7Qu92AN7F3PZF5Jb/dWvCfEPxd1m5nlOn63eQWw bZYRIxAEC99v+2BXdl1Rp3gltYxxUE/iR79+zNpNxBaXV/4pv765B/0LQxO7ECOEdYlY4/eyccD6 1cg1CaSK7a5J3OhuLuU95JG6An0rnx1Zt++/7qNMPTSXupI8kCzzGKO3XcCRPcsP+Wcaeg/2qyPi pqRkmSKyabEa7rvbkbbmQ56D+6uKWGeqs/NDmr7RN/wHY3LxE3+oXNxtPkW6yknYpHbNX/HtsiG2 HK4DS7u21m7fiKeJqNv33foZ04W29DD1LRUMkbskY2/vFZurKRxg+xpt3r6zkCArt/5eD2c+31rj 5vM3XkXmliuVCzxnaBiJl6hl/ukV6B8Pv2iPiDo8ipYeKLu6sgpZNNv08wRonTy3YbhtPHDAfpWs X3+YpK/Q9j8D+PtX8datbSa/o0FjZ2qvfWtkMsJb1iMHe+OQwXsenHrX1Lg0pr+X5Eyfd+Z8o/tS fE2MTQxxyRsiHY0a9ZLuVh99vSID/wDXXzL8RrFom/eE7iA8in+AkdBj2pTW1jovtbsePagpB4YN 2I/uisUzr/Cp/wDr1mYv/gkErn0PqfqKhkbcOU9iB/FRYkqH3XHfFG0+g9vagTQ4gnqRjoT61DsB 6DFIEhACe/0oMh9DmmIckZ7n60SE546dKkbGsT3J9jQMD19WFMV/8y3DeMp+Vie+PpWlDqgcDcMH r9D9aBomViehH1pv2XLcsPQL61K8imXUA7gDt+NFxciIZZhjuB3phY5G5ujIxJzz8wHoKiB//XWl jJih6dlT94Z7Z/8Ar0Ame6fCP9u/xN4Z8uPWo21nSk+WG1zh7KJj/wAsZD/c7Z+lfa3gX9pPwn4n Td4Z1iFm6T2Ehw8LEfxRtjrWdSPb5m9OZ6PpE6uxK/ga53x3MTA4HdkjA/vbpRXHHc9CD7Br93Kh XL4GAmD349fauAdgJT5ZcDOMD+Ie9bpEw8jp7KZwvQ46jPeoppSp+9/vD0OalMGj53/aSvGlj+fl gVTJ/hIPT8a+Z7DxJdWbZsJtjdSfXH09KcGOutET6n8R9Zuzm91SZv4VQdAPasmXWLhhhrmQr1KH ufer9Ecpm3F84GFdh/CMdya9AtLY6faDd8pI86492bPGKGu5Hp6nI2M/mPl8Hvz3FWbiUM3y49QB 6e1YT3OyO34ImQHt07+x+lSRDnrnv+AqWxpdy7G4/iB9vY1ZjPHT2PsawkXF9hd3+fWmyyYB43Du fSsLHQn/AJnL3MoJ5/HFZt0TnnPt7V3UziqsyJcZ4+tNxXYecxMH1+lHJ61Qj3HwvYmK3GCB8v5g jvXHeIZST1P09a8qD1Z7D20OWvGAX36fUVnSodpwOxx+VenA8qp5H378DwTo9qSxzsGV9sdvpXYS qexPqf8A9Vd63OamvzKrOy/dY4/hHqT7VmXltFKMXFvE/cFgKu3ka38/U4nxb4O0sQSsmmxLKFLQ yKOjgHv9K+ULjxbcg8qpPYD0zWE/XyOi11q/QRPH7/xKw7YHrV2P4gQYwzsp/iJ/oahTOVUy9D41 hcjbcBuyj0NXjr4IxtyM7h7Z96tyXX0CMew2QWE3/Hxao/csfX2FVZPCmkS/6oGPsAe30JpWXRi5 n19Cq/w0hkx9lvcseNpHc1YtvhnJan/SnBboVA6Y9aTRrGXkbMfhmAj57cyepb+E/Sr1r4biQ/u7 ZE7FAOh+tZs2saiaYpPzxgnpz3Hua7W0solVDt7Zb2b6VqTbt8jSaIkfdI/pVR9LPfaV64+vr9TX U15nHF9yrJo4Y8MPbPrTYtBwy752QAiSXb/Eqn19qVvM2jU/mR9VeDfF+lTIv2O/hlwBHtBHy4Hc e1anizW4xGBEyknuvevNgtdfU6L90cEd3r9TT1j/AMM+tdp59jyT4uXLXU8EEZ3ZInuEP8KL6ivS 9Os1iRQmRgBMHvgelBVRbfeTMpxz+tVlUE859velcm3+Zra3gbOx2/rWE5x1APb8/wDChMLbFCZ8 fdBPbFeLfHZW2rlwMDJH1PcfWh/8E2ob/ifN0uD1JPofaoCfX8K4pFsjY/8A1/eq0sPrQhlPHt/+ qtfRQ+f3a5+vpVmT8/Qr30mWP5CqwbHf3pFM9F8Pamuo25iuthlX5raRupQDoK4W7sGiYhgcjjJ7 in/w4Q29NUNiU9hXsvw20kxoHnQBT8qMf4VFYVnpv5GtLfY5bx94n+1TnY7lB+6iHqM1y2T6/Ws4 LT8TvrvXT0Go+O319qvxsTVvyONEwHv9RVqBvXnsD6VDRrEtRyYPPXoPxrqfDVxiT58sD/ET0b6e 1c9Q6KXr6neggsCqKPRvUe1SSxnJzkevsf8A69eZI7ImfqDKs0JbAwfLL+7+v1rtL6Jtp27W/hz/ AJ9azn0GeKeMdbhSdROr4IK/7u0//XqhBP8A8+8u5e8Z7ivYgrJBScZK03rtE9B8EftG+KNCYHQN alReC1nLysoHYqfWvouz/bF+H3iGNI/ib4WhLEGK5uZEyIZG7q/bH1rrhLseDi8K18UfQx9f/wCC dvgzXFMnwi8dm3c/vBYzPlAzf3T1GD7V4N4u/Yi+IejEnU/DEt9GM5u7Fiy4B64H+Fd8Kn855kYL su5wll4XUPtuLJ4pR96KVSChB7qw9favSYPhLevETFYblxv4HRcelXUXn5nTCC7Luzy3V9KSNsNC Ny/u3yOhPrWQtsiniNAenTsKq7ORW6epehjH90A9Mj09q1LUDP3fbPvTbEl/maSAZ4A9P+A+9X4A eC/TqPahLv6DlEuoQMYOfWtaGIt0x6ge309q0v8A5GTRr6dEwPJPsK9D8MeDbm6x5UbEf8tD/dPu falJiUT3Dwp8I7KLH22RpWHQejE+vtXsOhadbQD/AEe2jTtkD+prglJnVB9jo0UY6fQU6kdqCigo KKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAK8u+OK/wCjxdP9Zjn3U/yrSnuL /M4XVrhvs/3uPlCj0b/61ez+Bi/2ZPMk3fwqfYD+tay2Oro/Wx0lRz3cMSlrqeOGMDzJ5pCAIo17 u59K50uxyN92eO+N/wBsDTLTcnhOEahOP3YvmB8uCUjso5bZ7YHoa+evFHxI1bVZC2u6pPcn7qxH hIlBPEUI47+mT3r1aFO2+/5HmVZ36+hzsl76H2A9BUYdyfm/D2GK6PUwSFwP4/mPQA+n1pqQluoI 9cd6ED9fJlmLTG7Y/wDrH/Gtyx8LSyH91GzdxgdKaRtBeR6T4R+At7dkf6M23qzvwAPcn0r3bw38 HtMsAN8KzSdTnopHoPaufEVbaQZ60IW3+R1wUD7oAHYDt+FGK8n1H6hRSEFc1480AXVo+1CXXF3b EfwtGecfVc1USZHzp4jkuY4WOnyvFnmQofvj3Fcd4b8S3VzvS+vLmZ/+Pi08wE7VXjCnFe3CXuu/ yOC2uxb1/W/F0ar/AGBqWqeSPvWkakhpM8Z4PWp9D0rxXqSt/bWlXrTggwySKRvjK9mIH3far9ou XRq5UaWt5WRPcfBf4k+Zu0rW7e1i+8RPOo8vA/hU5rRT4Z3DID4x8aaUk4wsskTglsD0x/hRWxl4 pOL7MmGHineOvodT4F8K+FrOZpNP1UapdqpWHII8mNhzt+o/EV5T8X/GMrqxgRltnJaOM/8ALKcZ +79f1rxJedux6Ld+jR80Xrb2O7O0cAH+I+wrBubcDnBRuip6L71P9MlmfcQMgBU7u59jVZ5iw+fI 75HcCpJ/pDWuBj5IwP7x9abDbp/y03HPIx2pfMteZHJYNGcktj09jT5ZHx8rcdAfapuIhe2LgCMg n+Nj2/GpI7ROjsT2+vFL/hx2EiYgfKSvb61EXyOpz6HtQD/4A7MmTtwf7zeopGLjnj1H1pj+ZKtx J1BA7HHvTEQkH5VyeC3pQl29CWxblkUfKGJ6sfQexqWCQ8BCQOpJ7mrSJXmOMUrMQzA44z6iuj0Z Ij1QcfeI/iYD0pvyGvI9F8OaRFfS2i3NylrEJo42mfvNLMANx9ycdfxr9KfGMMMNlIFT5Qghtk9C pAHPtTT21N5PTTvc4Ox8QW0dxbr5n7wkyIgH3go7t/s59q759WlVvlJhBBDKe5B7E+lJkkNlp0EK MLeILnkn1bPc/WtLSyx98cM3vUeozTUGnUEBRTAKQuB1I9h60ALkUBhQJnnFyPmOfU4H41Xzn/Gt 2Fzp/CL/AHxx2b6nmuorKQwoqQCggd6ACqOsXrxRMYoXlbhYo1HLOzDsKaAoWlpesgOo26wuefLB zsGO5FR3kUqqcqV/un0P1o9CreY+O2l2/v5C3GQB2JHpS2E8kajy8YxjB7Y9KkGjI8ayr+68zk4L A/lXLax4uC2skcM4MgAlgQf8sGU5BYn0P1+lbW0/Ezv/AJmxpei3dsglj1SO4umRTqV9MckgL0jT PYdvxNc1f280t5BtfdKVaQMx+/IW9TWUV5eRq32O6n1TVCNt5coJekwTACJ7kf3q4bw7rNzbm8VZ oLaJn3XF43JQMmPkT1YdOKaXZCS8/M6bwvfanPJF9ljjtNMQEW6HltQkYdXJ6fN+deba/LINQlaC COZlm8xIH6TurjhyezVcfT1Kt5+p6Zr3iDUb7dFFbQWzIjXeryFwfLAQ4CkD+L9PWuH020hfw/B/ arWqRq3npGDk3TpcPjcc9WPOKum7fDfo0TbTVvzOM8JyXur+ZLaWpS2En2WO8bhZBGOfJJ6gHjji s2/uDHd3Gx2Zf4yg5kCr/APespvz8/yNEv8AI8G/4Un4x8W6kDrWly2mm7tzl2IFhpcfJ2ggfM4H X1r6I8XrG1tGml28cVsqtYaLbr0jtUXAx9fpW1RrRRfr6k8ndruedfDj4J3Ohwuk6RSahKfOvGU/ 6i1QcKxH948muaP7I3ia6vUn1TULIsZ49TmjJ5WKGVTiPj+6PT8aqNRXd79kVyLqz6V/aHkZ5bYD +48rAdgWH864r4falb2TM9hoEN5qn/Hvo+ozdNJiYclIyOrAnntWfTf+rktefkLFo99eXDtJftcy qf8AS79+d8pB4jHoo+lcHo/w/OpvORdtEsZaSckdcZ+6D6AViaJI0bX4Jwapaskt7JbW7EKzpyZ7 ZCCeD/f6dfrmrlqIklQWo2xqRb2wH/PGM4HPsK0h5/Mmfl6nP6F4Pg1LUbxL2Vo4yWLsndD7H1+h rZt/2NvA5wF0+7c/d+91B9frTpza2+ZpzeS7m98QNPtNItoLPSbdIIEH2q7gH/LOGLp5nvKcn+de d2evvdJc7YgIRHiBR3x3I+tY3119SGzO+H3glLmZcBgpwGP9yBPf3r2//hX2ghiU0CxZz8pmdeSf 8+1O76PyKb7HkutafbxTutnbxxoDhkjHBc+wriviTZFzbjzWUBTIEH/LQq/c+hxWjMk/82bXw9/Z y8SeK0L22nyfZE/0ZpM4E84GcRseu0Yzjp0zWfrHw0tNMkaO5tRHIpMcy90kBoUe3qzo5dNGvNdi OxuBCR9mhhyOVOAevqa6Kx8U3IY7igfG1FAHLH2x2NX8jjUfN9z6B8A/BrxZdW6PZeJZNGc533EY G6YN2UYPC8V2Fn8AvFyuDf8Axb1q4Uf6y3J+WTPqox0qlNfynSnH7akfJP7S1neW1y6ySB5BNHbW 9wp/1gDDqR6nP8q5D4lQmM4lYs2BvY9xt9axmtvv/Ic+nKeH3855CkDuSO//AOus0MAOPpn3rOxz N+XkVyAPvOT3x9aiLDtkeg9aSBEMso9PYioTMf7o9vagTY3eT3/D2odj6D1P1pMQ0Pn/AD2pQATw Mf40DQu4D72fYDu3vQzH0H0oGxhyOufYelSBTjkn/a9hRcBTLgfJk+h96m8+RcYT/wCuKQGraXas Pu4PcVZ+Udj70DJ4Y2boh/vZ9hWBql5IxwG4HVR3PvVxX+Y2n28jL2+31B7UFfX/ACKtmAmMdBSh s9RUjHhyOhqzpmq3dnIH0W/nsrhfmhuITjDD1FA/+HPrz4If8FM4rUCH4sWr84S38QQDgN/09xj1 9q+kdU8c6XqcCSaNqttdRvLGls8ZHIEg9fSuaUNdPQ7KU+5r+Io43IFwcDpn2B9K4BIQJTtKkbsx N6KaS9Tog9NDrY58D5lB9Pc//XrOv5ivPHsD2FQ/UpLufMX7Q+rPtAHUsHIPVgD3r5zkc9//ANdX FBXexEzE+/bntULsB2//AFUzkfkTeG9De9uFCIWRf385/wBz1P8AtV0fjzX5QAp4J4Cr/DEvtVMi Pn6HPaZF6gnv9atEc/oPeueR0x2J95HcfWpIl9x/hU/8Masuhhxvx7Z9KuquPu89selYyRpBf5iK FHX6j3qrcOMHLH1wPf8AwrFGyXmcxPPk8DHpVS/JB5PbP6V6FNHn1GY8j+3096bz/nvXWjhbE6VP bx7mHXqMfnSY0e66ekiW3BHQRkDsGHavPNblJbkk9ue+K8yjuetPZHM3zZIwT6kVWlXg89jnPbiv UgeTUZ98/AUbtFtsj+HC4/hUDt9a7WUY6qCfT1ruOem/zKLR59+9Up41PY1ovL1NjA8R27NBLjGN jE57gL/jXw9qAAY/Nn1z2PtXPVX+Z0R2266GcB7fX61G2a42KAlrJtYYJ9Ppmu3tnz0P196xrvsX QXf1GalNKiZhxnoT7n296wo/F84+8Aexp4eX8w8TBdEb2hfE2O2cG5iLgchff6+1dxbfFnQrtiZf NQ9WJH8q6m+zOSK7ehqQ+KNDc/LfKufuhhztP+FbUFnp6YYzRuvVgp++me+PWj1LdTv8izFaW85J s5Vx0ES/wqPVvatpkhcRi3PAGZWP8co9D71TW2vmbU5d0Xg2RyQOwA7/AI+9M2f3uO5Hp9a7zgZR nt2JOLjjpg9vpTDAwH+vOccN6fSl6FLzXkj0z4MeFrf955rh2JyT6kL2x6c16DrbqjbYmyBwD7+1 cUlrqzolPTVGYq+p+op4UDr0+8x9AK1OQ8Y01n1PVpGyWjj/AHOP7jZ/xzXsCoQO3pn1+lDHUevy URjj/wDV6CoIwMjA79ffP9aCTQ15xlcgZxjI75/xrDdwO+e6mhDa8ypKR3//AF14b8ebkDaDzxn6 tn+tJ/8ABNaL1PnZz6Z9j7VAyHt9K5GatEbEd/r9KpzXI7D60khXKufUmtzRxtUkcdgfSrZk2Zs7 5J5P1qIH1oKZo6NrMlrIGjPT7/utb/imKGTbJb5w2DLj+CQ/T0oHD/gGVo+jSXMqJCCSxCAjsK95 1tItNttqMoCjytg7y+4rkxD6fM7MLHX8Tw2WVnYlwc8sw9z/AIVWklI+7WiXkVN6jwg7H6D1+tXL cE/zP4UNnOi0wHfJPT8as28ZHr6f/qrNs3iiz5QB+975rb0V23ja/fBHoD/hXPM3pb/iz0lgU+6e M7fpn0qaWXLckjPJ9j9K81nZYoa8pVFJIKh1I+pcfzruJkQr8uOf3hPoSP6VnPoVb8zwr4qWsYli MfB+dJQe3Pb61xVvqMkZ/dyHHTHqa+gobK6PE57P3X1N238Sxn/j6UDsH9D/APqrZtbzP/HvOGHT Ye4rOcex71OrGStV36G/pHjTUbAhtJv7yxcdJID1/wCAivcPB37e3jCyG3VZ4dVi6HzOGx7suOta Rn/MjxcVgmtj0eP9p34Wa7g+NfBVraz9TdPECUbHUSqB1ru9J0rwBfDHhnxDagH5PJyOBjpzXUm+ jueU2+q9Tx/x7/wTR1LUZnk8JeI9O2tybWc4A2jsVH9a8g1T/gnD8U7XPl6HaXg6BoJM7gP7ox3+ tdMaq6pkQiukkcvefsrfES0/4/fAWre5jjJx+IFZw+F/iOE/6T4U1qPvkwPj8TiuhJdJLsPkfREo 8LX6j97pF+p6FWjYc++RVuPRZh/rLaVT3TaePrkVVgcH2fmT/wBnsPvBsDkf/WArQsrIHG3c3qw6 AfWmonM4nbeHvBkszDy4yV/jIHQ+5r6F8KeGpEjVbO0Y95HUfeOe5+tY1f8AhzWMH0R6fovgm84L QsnqX4x+BrsrTRvLHztk+grhZtCn3LwIFLQdQUUDCigAooAKKACigAooAKKACigAooAKKACigAoo AKKACigAooAKKACvLvjvH/oaHbnEq5PoCjfzq6e4n+qPG5/GsssYjFoqjhDMOSxX1WvoD4aJqSWw /teEQqP9UzdXQd+e2MVtUXa/c7ZWs+ZnOeOP2ufD+l5XRSNYusmKSOBvktHTOftE/wDsMMYGTn8c fOvi744a9rZP9t6gGiyWt9PiyqQpuOMx9ygxyTz7dK7KNK3xb/kfP1Kl9vl5nGtqXqfbA9KjEu7+ I+gI9q6P6RgOwB1P4U5WLfdBx6jv/wDrp/8ADFLyLcGlk9M/4mtmx8OyOeImJ6HHvTUf8i1Hsd/4 Z+C17dn93aufU49Pf2Ne3eGPgFY2mDqSrI/Xy16Bv9o/7NY16ttvQ9SlTtrL5HoENtHGAIIlRR8q IvYU+vHb7stvuFFIQUUAFBQH7ygj7rKe4PqPegR82+MdDNjLIjW4dVOYYz0lt5OR+hqrp/iC4Qf6 Do2mRv8AdSbb2I/ve9ehd9G+5ytd3boXF8T+JJCqwaxDATxDHEq/MSfU+9bsnwX8VT/8f+vzZ6sq v98+gCjvWE5r+Q6qcF9ptnF6R4Gsbu8Nvf31wsoyxaQnkoOxb+9Xbn9mvTBxAwY87QR1cD/Gs3J9 X5mkEukTzfw34his75o7/SXSRSbOOKLrMcfxfhz+leY/Gi5lhmaOAMI9xuFhP/LEyex9O9S1/mSk zwm+AU/McnocetYt1OD0YnsAO4pRJbKc5JxhCO/HpVGcH+FQCPT39aVuwL/gEO8E/NkD+I+pqQk4 +RR7Z/hAqbBcjlnIxvbHce9VpQxH7s89Bj0FK3/BExEZ1x+857j0p6deR+NNh/wwsjHH6EDsPaoZ CzH5MDH60DbHrJxznJ+97mg88A+49qAb/wAhyj247+9WoYo8HHHp9f8A69CH8hWtPMI8s8+nofrT JonU/OAD2NUvJkPyLUMLMMqrf3S3p+Nbek24UjaSD/F7k+tUgSPSbK7l8uCLT5YMvMl1dySnGwRz A8SD2x3x69K+8ta8XahcWm25uLedGUNNeqMGfB7L/tEdhSX/AATWS9e5heH7qNp4/KZXIYRtjqjG vTdVhUuPMHTJUeuD3okhpi28crKxUrs+6cf3vp7VY0K0nQuZnO04MSf3CP8AGpA21J70tBAUhIHU 496AObuPFl+nDWsCtyvmDJwAeoH+1VJbeWGVZJdVe8ncbUgAGIE44RBTl/dLhbr6GraStdSfvAQq D9/GCeZSejitxUA6CpiOou3qeeXqEM3Hc4/Oqwx3FdBkdF4SPzvz2H866us5gFFQMKKACjFADJGI xgZ/oMVX1MN5bbELHG5EH8TD0HvQgOH1Pxxq9oyrqOlwruTzkKuDtIOMHA/hqxovxBtZBjUAID91 GHIYH+8frXp08NdXgziq1rP3vUzPiPrMYeIRTK3yF2VT0Bbvj1wa88uryCKOYlQHcLG7f3iD3PsK wcHbVeR0RmujI4NfltB+7nIBwrKx6/hWxNrSz3FuwcphGKt6SD39qwk/8jRHW6b450OBHOsvJLPn FpCuT9oUgY2FfVs9fwo+H/h7Rr1Z31W1t5pvNJuY5TxbxBBg7Tjrk9qzS8/NfgaKXZeSOq0PTbSe QyWAdbZMwaUqn5Z328sqnspyB/8Aqrxu4he71Blt3MZeYrE/9wl+pA/ugZrWP/AGn3Xmz2lfhpoc at59mGOCt1dOxyyYPJYHsCe1eJaP4Osbqx3+J/EZs9OV2j0+0TBa5iLnO1fWYjA4J69qSfl6D5+6 XkZt74ie9EUWlWJ0rSIiF0rSEP8ArEVut0/cueeSaoWcSm+nAUdtg9Khoaf/AATqL+WSNfLikw7f vNQI/wCWUIPAHu1YPipCkUPkr0JYD0ApJf5kpl3RtMlwXuwTM/zSEj7qY7Cul0vwvcTfMoCoCC8z 9EOe5NNL/gAZnx1bdPbeW2f3RBYdxvHSuY8M3Zt4JDbIGuGItrJcf6vK8nH+z/8AqrRLT+u43/wD o9J8NtbIAN2eXmc/xSsD1/GvM/DzzqbiKyU7pXxPOP8AlnbqTnH+9Sa/zKO6uWSzgbygAqr5EA/v O4x198159pkQ8xPMOeQWz7HvSiiJMreCLyOPUb1pZEVclmZuxOfuj2rtbDx/cXMwTQ4cRDNxqGpM P9TbxDnZ/vfh70vUbWv4nOp4cfXJJ5PtJjQn7PYs/wDFEoPT6Cstfh3d6bDcm4wyFRHHIO/Ppjv+ NTFf5F6fqdf8HPAExtzJ5U0hb5ISBwkKnnn3NegXnh64t0ZpLeQKAZMkdCFPU1q4DcX+p89eRIzM 02CzEyv7lj2rnPiFpJ325CMo8ty7ekm//PrTlHt6EJdz7O/Z30yC20S2KOoBV7q5k9X81gST7Ba+ efiPpE2tXE89tELe03mRruYY3wk4Xy0PUyD/AOvgVS63X91Frrf0PKzp9vb58ks7ep6tg/yWus+E Pw7n1i9/eH5VKx5bors3cj0pR8zJf8E+99O0mO1jRIMbVAhQgY3bR/dHqalnlCqxZyoALM4/hAHY e1YMhn5vfHnVo5pkMUsxYzhpnfqzLJjgH+7WF8StJljfNySdwHkAn/lmtaVl/X3HTJ6/geI6vboC fK49azokA+8PY+5rC/8Amc0v+CQtGOyg+ntVaZlx1/3vY+1CC5Afc59D600Rr3yD6UEjNuOnXpTD k/eJz0570AkDIR0A9c+goI54z/hSGBB/qKfj1OT0x6UDG+Yw64Pp9aUED/WZ9fxoAXzV7ZPf6D2q eFlPcjsM0xXL9irE+3fHcfSuj8OaC2q3ccNsFiaRltIpP7jSMOXJ7LU+hpFdz7p8F/8ABPLw/pLb tduBrAK7EhHCoz98ew/+tiuF+Lf/AATbE4aT4fxBDy8ll38z/YrLmf6M9WnOOzjpt8z4/wDFnwi1 zR3K6/pc8DDhmYdwe/H9K5Z7cj+E/UV13/lPOxFG35pkZQ+n1NJt/wAKRyCH3/8A10o/yKQXFyD9 8A+xroPCfxK1vQ5Efw7fvHtYXS2b8q8q/wCy2cZ9sUik/wDI+r/Bn7fGl6yVXxOH0u6xtVD9yaY/ 883x/FXqtnqMbYKuj7v3kMgOdyn0IrOS7HVRn0+46tL1eAzgt1Yeg/8ArVU1K4QKfMPT5v8AgI/x rkbO1L/M+UfjnfPOFYIdpP7pyOqZ7ZrwyRB3IPr7mtosVdbELAj0HbiqdxIF6/nVI5Gz0jwH4bFr atJcjY7nEfHPkD/GvPfEWrG5nJySv3U+gP8AWrIRb07J+6p9/cVZ2Z7+4rmaOiK0FJx1/L0NWYV+ nr9RSNP6ZNkk8HPYj1/H2q8tzgcD2PsKxkjSP/AH4yOBgdsdwPWs6acEHA46EetYpeZujnXGW/kP UVV1FwWPGO2PpXfA86ouxjufT603d9a6TiYuav6PbhpFyu7kDHrk0McT3O6hEMGACP7uey/WvLdV mBY4z6V5tFHq1Hpqc9cct6f0qMIDnOehyPXivTj5HkzPvb9neQNocGGHGY8+pU9hXcSr7mu5eZjT X5tFOYfh7DuapTY7cGrXkWzC14gwSg5xsbj/AGthr4Y1QAO2STyVJPfFYVF/mdMdn6oooMA9fX8K hf8A/V71xhH/AIJGjAEV2lhJkDoaxrlUNya/gLIeCO+B2xXEM+KjD/8ABOjFLsBb/DFbGjL6j6fj XYvI81kmoSY6D6+9bfgO1a8uAst5NEgBlcoT2x/CfetYhI+yvhP8BdITT5pNREtxKSRbSy9QoHQg ehri7mBA7AR42nZGR3UCujl7+o4Pf7kRyyIPvtg9WA7/AP6qrNLH3nI9F9//AK9aepFn29CtcWkR HFw+e2KrNbnvK3T5TntUX8vQ6F6eR6t8ILAhHLSk8/IxPVMevsa6+8nZmPf0NRLcwqSEQZ68fTuK z/EOrJbQSM7lcKcH1JU9/rUszSPOvhBo8hjeWYHdIxmyeoQ+hr1EnHQ/h6Vcn29CW9X6kTuOxx6+ 9Rxqdw54yMn15qV5j9C3rzHcAAOmB7D/AOvWM4PcflSXmN/8AqzL/wDWNeEfHadcqON23dgdiD/j Tl6mlFanz3Jn+gqAse5+griZZFKQO30rNkH/ANeqiDGD2Psa2rJiqH0702ZmYx9T7/jTQPX86Big /wCGa6PStREiFJ2GPvR57OB6+9IT/wCCdV8LtBLzlpgVSPLKSPvSjHStX4l+ImLBEc/89Jx6Ee1c VTf8T1sP1+5Hm3me/wCFKsanrj1z7+1dNzlf/DjlPtVmByDyfapJX/BLwIP+H+NWoV9SPoO1ZM3g Tsp9cepHcH2rV02Tawx9CfTn+tYS/wCAawf+R6bG2VHBA4bn1+tWryIEqd+Rj5v94V5tu53GXr5J hO3BIIZR/eCnufcV3FuVaNSR/CAoH8WB3rOZSe9v63PFfi1YbWUnBGdykdiRXnKKe9fQ4V6L7j5+ tuydc9/rU8NxJHgxOynqSD1NdXqiYyt8LfkbNh4yuI/9cqyDqCff/Gt+z8S6fN6xOOc88/jXNUpf yM9vC45bYheRuQsW/wCPe6jdeiqcd/WrcdzcRH5IgD13xHBUj0xWEZPrfzOmtgoP+FJHV6R8dPEd hj+z/EOoQdlUnIB9xXoukftw+NIcCTWbe5Hq69T+Vbqf8yR4VbLpLZPudxpn/BQfWVP+n6FZ3HZm R8bh7DFdZa/t76dJ/wAf3hO4x1O0g5H+zWqt0bPOlTkt7mpD+1/4Bn/4/wDQJEPTEkAOc++2rH/C 9vhDc/8AH1p2ng+ktqOD/vBa2V/s1COd/aXkWodV+C8/K2nhsfxDdFjOPUbavxad8IjzDZeHP9pg nf8AKrcpfzlKp/cNSx1f4cQf8eLaDGOvyqOcfh2rUT4t+EYv+PfWLJe22FTx/wB8rUWfWRpz/wB1 lW4+Pegr/wAe8k059QMD8GNZU/x+Ehxpthz91XJzhvc4pJd2a04SeyOl8N3d9dfNqExIH3Y16Bj6 4rpcUS8jacbbfMKKkzCigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACuN+Jfga 81a3SPTfLD+Ys0jv0SBFbP51UWS339WeZ6r4q8A+EB+/Ya7qQ+WO1jx+5b/aYZAz+J9q8b8cftG+ J9eOL28Nja53xaVakgFDn/j4k/iwD34zyAK9SlDrU+XkefiK7e2xwbXZX7o9iff6U0SO3Q89OO2a 2fqcyX+ZZWwCDNy6r/cUdSPcVE92DxCgA6E+4pr+98h+noyaCyL45Oehx/X6VuWWiSN/B7D3/wD1 1VjWK7eh3fhz4RXd0R5drIe3A6j/AGT717j4X/Z4tLcA6oAW6iIdx/tNUVaiX6Ho0qX8x6Ra6bbw DFnbxxL02oOw/wAKmrxZS7s1b7hRUiCigAooAKKAPMfit4TLlJIU6/6FfMP4c/dLfjkflXjusfs0 +MrpS1szyxn95awh8bo/QqBXqYSpFfxPRHNKnfqc9rV1qWgLF/bOnyR3y4MFs+cyIh+8zelet+DP 2yPDWpsE1uU6XdD5N8v3ZmH92Q1z11ro/NGtN9vQyvizp39nXkF1pUitGxC3LKeuCOc/7Yr1uDWo J0R7WQFGAlRvcj+hrn/4ZmqZ4p8VdJfTb6G60/aqsRHeY6CXp831WvKfjtokokE1uS8UnzW8h/ik I/hPt9KU/T+6OD8/I+btVtplP7zPrx3NYbygYyG9D7k+tSZvyXkV526kEjHCL7GqbynHHB67h7UM RFKxOC3XoB/jUbSYPJ9iKll3IpkUj5/wT2oiXcf3YIXsf/rUE+g0ED7xY+mfSh5cn90eOn4UASgL HkSuW9PdhSEccAeh/GpAC4HVc9iaaGHYfj6CqD/hx/J9B24qRCP4V9mPrSsCLMasANmR3H0FPeAO v3Cz9QPT8asf/DEomliGCgA6tn+E/wD1619JMhXKpvxxnPQmrS7PyJR3tpZLObX7TbFxuBREH3B5 nV8f57V9rxOkVmon88SBdpRxxsA7H2NJeZtLzZBouo2UE0Ji2oGdZGZe4Lckn2r0rxL4qtUkIics R8s7D+Fz2B9q7aeHb6HFVxCW/wAjU0cRTQEWEi93KjuT6j3NdBbIAo4wcfMPeuOpBp+96HTGXb1J qKzGFc54t8XJYx5fBYkQ20f/AD1mb0+lVFEyZgRancMoN/5ak8sn938axNfkuISr6bdNC46Sr2Q9 jWqJ9Gdx4I0J7eEmdmeSRjeTyt1kDAYz+FdKKykat/5Hn18pDtuB6n+dVR7/AP661JOi8KRkO3pj GPfdXU1nMAoqBhRQAUUAGKMUAcR460KeZ0NrEznayOR/CgINeVaqrrgK7Drt/wBrHrX0WXS0PJxs P8jC8SfEC20iNX1SznuVP7uNYzyu0H7xPpXOXHxNtNTiX+yUIywedWPKID0x7124ikn1X8xyUJSX /pJ02r6XfQqDfaZKMjfAzqcZx3OO9UjPe3IjFtL5cg+WRh3QHJ2ivmppWPoYxfX0PQdA8PwRYLgS Sddzf8s/9yseDUJEeUBmKFxJdQZ/1qxnpn0YVxxNX5HtOjfEzRbpVFpcrHJj/kHkYaIqOgX29uK8 Q0vxBaW+oK+qSCKHzi884ziE5ODJjtuxn0rpgu78zOMu68j1Hxt8RrQq0em3plkMb3E0UIzugRT9 9x0CjOfX865j/hR2l/2XGwjeS42x6skxY4QyYJATPQRmnD9Un+IRfl5HF7CGHAxkdO2D2qjpE0Ed 3cvMS5BCWUI/5ayuOrn0Wsn5GiR1Ph/wld3rkQJ5kxBnu3Yj5VHqT78ClPgm71CWFEt3SIsyxXDq drrEeSG/2cfjTS7+pSXn6ndaz8PNJ06PfqequsIwrqVGZPaMepqew8CyapGp1ZZrC0yJdN0ePr5S nrdMe8npTXdryQm10XmcF8ZdJBuY87iFTbFjtz3+tdV8OPhHp/kJJqCGaR/30CHpDHyB+fXrVNh/ SO0n8B6QFPnwbVALSOTjYmOuR/drx34b/BgXjTSpOkUJdoLSTHLEHkqPxHpRF9wUv5kiL4p+BJNN jQLdLKrklWIxzF6j6EV5noFxZidBqSyGLOZfLHJwOx46n3FU129SGv5fUxPDfhFtS1C5W1LRIZDL Mf8Anjb59a7/AF8WVlCyeH7Z0aQ/YLeZeDNED8zE9eTxzXPJGv8ATOn8A/Cy3nZYjdyoEX7ReFBy QpHQn+8xFHxn8KafptsyWdw8jMvnzRP1RFYAcgdJGz27Vsu1v7w766rzPZ/BWlxW1lbrbRqiiKMk Du7RAk/8CNN8b63FaWczXABXYYgp/ieXgfqaUo6/PlMk+zPkTRvDUt7PFHaqAzuLaN/+eau3XA/u iu+/ac+GumW1raDS7GKHDNayyLwZ4lRf9cR1ya6YrXbu/wADSG+vmyt8Kvi/LJo6WljYXMl4rvpQ WLP+k2c0zN+7YdPkbB4xj9GeM/gh4tZAdRtW8hebO0g5W1Ru7hB1J9elKMV9p+aCnG/xNb3j5niu q+D7mE/6QhVs7ct/Cx/xr6a/Zt+GiW0DTTAFmYrbt/ewOct/s9Kmat+RFu/oe8VFdQK6sJGIUgq7 DspHbHpXGZo/ND4vtEZ4hHMWBm3AnsPO/ho+L99EzfMGO0eXGT9O30rev/mdNRa6ep4LfupPCEnu fTjuayyCPr0z7Vz/ANI5vX0IrhSAMN7t7/Wq0gTsST1x6fjSRNyBnPbA7jFRqT/ePpihAGD/AAqS f4h6f/qqNmz/AF9qBkuBj5j7Ee9RBeeScetCYh4B9setNBX+I+w+tL/hiheCeg9cf/WpZQp7H2FA iNY8dQR7e1XfJQgbmPvjtTY0a+mTov8AGV9x/QV6h+zp4Sk1DWoV+wgoA1w5fgIkY61m/P1NYr/M /Sy3jXAEZJwNp/D1NQ3esyW+MNLyfLXbn7x9celZo6UjnfGXwq0LxApXxNp6FyNqXOOUJ9fqa+OP iv8A8E7NU04NJ4UzeW4zIAvVU/2l9qISa226nZBpq1T/ALcfY+Y9R8N3VqxW8t5IpB8rowPUemfW s14iO1dno/M8mrTafvLyI9nqKTaf8+lSc9gA/wD10m73pIBx2t/rACPX0x6H2r0DwL+0jr+hsu6W TUbUYDWkp5RAf+WT+woKT7H2J8Of2oPDHiAE29zFb3XCPYzHBiI/+KrtdTUTJhSDn5FH95T/AIiu GcT0qU+58sftDahJ5qRBh5cf7sxqeDJ6n614YzjuPf61cHp+JeJ6feRlwOoOOwpNN0h7+dI4FOWI EvtHnua2ijjkz1bxzqkVlCqWjMFAEES+hxyR9a8UZstxnryT35oQmjo9PIAOCR2J9eP608Dnr9B6 VzHZ03EDE9x/iasW7ZP6UNELzZbgx2H0J9vepivHf1HtWL9TaJIj8ck+uf8AAVm3bkD9c+tZxRs5 djET73P1J9DVC9k3Mx3H1B9vauyH/APPmzMPPb/9VJs/+tXXY4n5Cba3/ClkJJkB9cn2AFRNmkPM 9l8RDy4gFGB6+oUd68kvXyxyfcewrgw56ldaGIzAkn/JoiU84z/9fFenE8eTPuj9mZy+hx9BhmXj 0yf5mvRpce3vXd6GNLr6soTofYe3tVCQjv8A5P0ov2NjG1QAxScZ+Rlwe+R/jXwtrC4kf/ePHoM/ 1rKobR2fqUsgD+dQyjjn8K4yokAFdho8ilB19CfTNZVxYd6mnKh2n6YDeuf8a4K4UAnjviscOdmK Ixz61vaOMDj6A+tdx5hHqLDtXZfCG0d7pjEm4hCrewb1P0rSIpeZ97eFYRDpH77AYgyMR/eb0FeI vcBpDsQ46ux/v12v/gDg9HfvoO8oZ+Ufj/gapXOms/3SF759DVv0MYvzIJNFB+9IuPUetRHw+B96 U4/hUdzUOJ0Kr3XmesfDlEhtmzGm7cQjDurVuBs+nqcVjM5nLsiUYP17Eevua89+LuueXahInBeR hCFH8IJ/wqUaU1/mze8HaKba3jUMDhQSf9rHet9sdgf8Pxqn5Ixh/wAEhbPcZ9PaiDO4cZ559hSu Mk12UF/mQg4GB6Aisli2Og9D/vU0U2VZWA6/SvBPjug3AhF6beOxJ70pF0nr+DPAH57VAyjufp+F cUjX/hivO3H9az259apEsb+da4lIj7+3402QZxHrSAev5GgYoH+fSrVtKyn5M+gHqTSGfQ/gfQYL S2DXMRVmHnyn/ZC1474j1g3EzkEkZ8pD6hf/AK9cMXr+CPVh8P4GOIz3+n1pxYgcYroZyoegHr9K mib1A/xFNr/MhP8AyLwf61biUe4/rWbNYv8AzLAB4wBntWjayAEZBPqPx9K55G0D1K2AZBtU9N23 6VcmnUovykH7rexya8x/8Oei/TyKOpQ74m2jt09ODXT+HpxJbxHAJKAOT/eGazm+3cIvv6nmnxks UCIVyOzj33f4V5Eq+p9vrXu4J6fgeBXWr+8nQ56kgd6Fdif89K70YNlhDnt7VpWOlPIf3f4j1/Cr iv8AMSX+RpM32fiHcpHzMfVh6Cus8Ba0ZrhV1OQPEfvIfw6/WphTT+L1OmGIa+CT7Hr3i34SeTaN PpFqdo5MH+wCeScegrwmP4souPtOlqT1LqTwTUzoLo/I7KOaS2qpM0ovibpf/Ps0QP3gAT+vtWva +O9IbGy7uI/TII49ua5vYy6M9H67Sf8AEgjYtvFthnA1aQdtx78en1rTt9ehYDy9VXnscc49aUYy 6xIXsXvY1YNSk7anbMOhDY5HvzWhBqh73tmf4QABx+tWm+zI+r0uk/M1bXU52xsvYge+0Dkf/XrV S5aNc3molF6OwHU47D61pZ9F5mbVJbsms/Fenj/ntM3bcDgr7E/4V2/hrWbi4I8qBIl6fL3Oe+a3 jD+b1Rx1cUtqET6P8P2JiiXcCCfnYen/AOutSsjlbCigQUUAFFABRQAUUAFFABRQAUUAFFABRQAU UAFFABRQAUUAFFABRigDlfGHxj0PRUJ1S78yUDfFp8PLyE9Pl7bj64r5t8f/ALUet6pldPuG0606 LbQ/ecc8zTj1GOMD1r0MPS6zXoedXqdn6njrsuSQPmPLMf4vqfeqzvk8Fsjo3oPrXY2cqXYsR2DY zPLtXux7fhSS6uin/Qo/bzf7xPoPakiv+HIAS5+YnPZjWpa6U7fdUn6fxZ9KpLt6lKPZHb+H/hnd 3JAhgYnoQPRj6V7v4O/ZsEeG1g7V6iLjJx6/71OpUS3PToUv5/kes6foFparixto4x0JA5bHqauV 4k5N7s2bCioJCigAooAKKACigCjrGiLeROjsF3DbG5H+rlHIJH+wwFY/hjxtbPaltSuY7doAbTxC 0pwLSS0Xkyk9toz6Vov+CS33Z8ifFf4jNrt48sUMkUAAs9Kifr9kjzzIvYysSenHTtXkWr6SsxBP yn70bjsD/dreVunoZpG7ofxV1OzRY7+aa+tV+SG2lY/uI/8ApmDX0l8GfjZ4QvYxBfagtvcZxYJc HG5dvRGPcVzvyOheh6p4w+D+n6lbPHOdufntbkHmBh3jB9a+dfiX8OraSxVLLWpCbQkywT9Xj/2n 9c469qTfl5iuu3mfKupzvIzeftc/3V/hC/T0rmrkoD0x6E9jQS/+AZ91EDnawJ6hvp6VmOrL1JB6 59BSRNu7IVmUH52Hr9SKikDMeD74Hf6/SgXzHK8bcEj0NX4VjjYhWB9Ae30qWio/8MVbhC2d2AOi 1X8sR4wxyenvj/Cj0AcQP+WmSeufSl8wH6dh7e9H/DA2ND8/KCR6f/WpygD7+T6fWgL/AORIqDsT /t+1OU4PBPpimgsXTcKOIxuPc+o9vwqzCwj5cMO6Adj9Ka8wsMmglkPzvt7jP8VaOkwMmBIxx1yv +FWvQlv/ACPVYIFWOA2d9NG5dUgZBnY+8dP9419ww+AJ5NMV7q9Ek3l7o19VYd29hRH08jZ7e8eN +JPiEumRRpaMPNUbJrnu8mO2Qfun3NN+FviHxDq9y6yrczqFEyKFyI0J/jYDjcenPPavt5cqWqXc +Xp03Jt6+R9N+C/CUlqGa8TbKf3YXP3EHqPeurxXx2Knd6eiPoqcbIKK5TQK4TxdpE13dwLGqsFV rjyzjlhjnn0rSAmjkNd8UqXZbqFYQDssps8yMB12+zVU8Oa9Jdxul4ys6kgN/eCj09xWy/4KIa/z PVvBmrvcW6+aQWX/AEZiPROmfwrfrCaLOD1JSJGz6kD2GaphP/rVoM6nwuow3AzwM+orfrKQ2FFS IKKACigAooAaYweoB7YPcH1HvWFqHwz0a5OZ7IKfVOMH1AxW1Kq18L8iZR7o8a+LXwCvPssjW0iT xRg3APdIlHVl9h/jXzF4W1Z7W6iwGCFl89T2CuO3tXv0q1/yZw1Kdvh9T7507x7pepKAII3Q8COQ A9R2HtXjPxU1HSdFvV8qNbaMgARRg/NPL/dUf4V4Did8Jf5k+meKJGAMFleSA8KVQ4wT1LY/hqmR mSTAYHdllP8ACcd/pWNjW3c6TwFCJL1Q2M7XKj0AXtXnupTOryFB8wdgpHqrd6qINB4d1u9heQ29 7Ikskb2l3MMZa3Zegz0xgdOldov7Q0UtlFBBaXMUwjWy1O6k6FYVAPlEH/luBTi+/qvxFJfymbYW FtMwFzcCKP7zuOwHoB61zMWpWcF5MJMAFtlqW7Kq/wAWPWkxxZ6n4C0yS8lYWd20USgLrDR9ZY3z hN3/AE06/T8K6vx3rMtqbZdEhie88wf2Vanp5YjIPmDI4KnHUVaf/BHf/NlCw+Hup312ZPF14lwI 8fZrGP8A1drKef3Sd8jB559e2PRs0pvt6ky8jxH4wyKblQzEfJu+hJr0/wADriyg4x8gP4mnPZf1 3KZa1Gxa8yizvHEP+P5k6yN/dDH9a5z4ZwLbpcQr5jCKeSGOZh/rYnAI5HfOaE9NvMVtPxZwHxwh uXmU394kNqoCafGCMyyyDkhfY8dPSqHgX9nSa/iWa4u0tkJ36fBjJniU9ZmHTLdhV3Li11TOA0SC 50y/vUWJfPLm0Q54j39Sjf17elen/Dj4YWmqytLqZaS3gb+ztNt1zi4ulUEtIT125H5/SofkunN/ X3lvr+B7NHo2mWe54bSC3wMTzIOsQ9ce9eFePPBWpta3Fx4gZ2kkZBYxOR/otmG4GxfUe/65oT/m 8oommv5v8KPdNATFvDxj93GuPTEQrzb48eIljt0iWQAu3nyj/pnF7/7XNaLf5tmUDz74FaKtxqBZ 0BEUZnT2eVgB+XNWP2rfF9motYhOjTZe5uY16wRMqgbh/wBNOa1he69G/wAy4v8AzOm/Zu+G8dra Ge5t08+UkWkn/POyjOPlHbzHBz345r236/Qg9xXPVeu/kTN/5HlfxT+D2lTxb7HT0S6LpDGkeP8A SpXOPunuRXoHhvw2un28ca4+RRHIw/ilxyc+5olLTVmk5aa+hqVzXjzXzaWkhjYKxUojE42rjnn6 VnBGMT84fipK5ubbLK2WV/l9TMPu1o/FxWlkwqKBgFmH9wD0rSq9vmbt+fmeG6k+wkInHVm9R9ax JCxPQDscdvpWJhJkVwoA6HPUf/XqkUJ7ke/vS/4cllZgQOD+XpSKCOn50MTFWZgOp9MDuKYc/wAH B64qRvyEQE9SPU/Wnuy9/wAvpSGNa4DfdAUf5/nTCEHXPriqsIdCwz0PpU5P94D149Pek12GvMWW IY+Uj39qdHNGPVj0P09qSQXNC2ZQ2UyD1jX6V9KfsimdtVlfUo48LCUtSP8Almzn+Mf7Qp+pcfNn 2tb64R0cL2P41vpcgpl8Z7fX2+lYyRvBlRp93LkH0z6VXk1Vo+jZHQoejA+o96X/AAxpfseYfEf9 lPwt4kRi1vHZXR5FxGo+eTHcV8R/Ev8AZI8R6E53WbTwDJjnX+NB9B6UUpW+I67KS97fp5nkMtsw PK4I4kQ/wn3FQGM/0rrZ404tfEiMp6UmMdvxo9DMSnbyOh/D3pMSJILqSNg1rK8Eo5jnjJBVh7iv b/hz+2xrGnsq+LWkvrcfILheqD/aH/16lxXX5GsZPoYnxH+IttrFw8lmzeWxLwqf4VJ/pXDsvt71 zxj39DtqVL/kVp3/ANr6+9eh/CLw0oEtxcpxza6fn1A5INawOWT/AMjA8b+IjcTEByVXIA/2yf8A CuKAy3X/AOvQv+CaTf8AkdDZg7eCfpUBuzngj0rmsdN9C3CufT1wfX61biQdhj6dqGJFqE+w9M1L ISB94k9P/wBf1rnn5G6f+QyJhj5ic9vrVC/OAODnoR9aEhswWfGfzrIkuGJrtpo8+qyMim5NbnON x7/Sux8BWpa4XAJ434+hrOrsXTPTvGEjhFBbPHmj2z6fhXkV3MRnr7j0riwyPRxLMkHj9c+tTRjA 7+mR2zXp/wDDHkn3B+y27f2Go9JGUj8e1elu474Psa7kZU1vbuUZpPUA9vpWbIc9hnoT6kUWNfUy 7/Gx88Ha20f7W09a+F9cT984JJO5hn1IPesKh0RWj1KEqD/PpVec/SuNDRB9AK6rw8xZOo9CD7Uq 234k0dzdVB3+mfQGuF1OAo5yo9DXLQev4nfiVp+JURj6e31roNPYKvzcd8+1d9zySleTBj8p4r1L 4D2wMszKM4URZPckf0rSn/wWTV2PuKS8t7TSo/P+YlRgegx2FeHxTJIW2qACeB6ivQaFHb5k59se 3sahZQP9YxHt6mhf8Az9SE5/hAPc5759KjfIHT6+30FH/DBfv8z0zw1aPFboHXDH98w9M/4itaI4 6fQiueX/AACIf8FEgPqT6YryHxnKb/UookOVQfaJ2HQOSP5Uo/8ABN4P8j1SziVVG1eMY/ECpCc9 QP8AEUepjEY+ccD2zRbD5h165z9KC7/5DtcY+Yckt2x6cf0rJkY9vwzQhW/zKjnP3vqP/r14F8dJ GLc7cdM+5NFjWktTwZ+OgPoPpULH0b2P1rhZqU7k4HH+TVDcfU1UUSxEHPP4e9akxIQcD6e1NkFH cfemgnvQhj1Gf5Zre8L6I91MixjIyC59Of61LKR7n4x15bG2ADENj7NAv91cd68HL7j/AJ61x0eu h6tXZWGux7fnTd2fQ+g963RyD4iD0OQfmB9c1YU+v5+/tTZlE0IFB/p9KsrKOx9vrWbNkWNxwOM9 v8irlvKeMMR6nH3axkbwZ6tpwHljBYkgHPsP/r1eADRjBJ7N/vH0FeX/AMMei3/wCMxBlIPoSQfY VpeCpy1tHvIyMxsfUBj1+lY1NhxRy/xhsFe2yoJYEMAf4Rn/AAFeFK3HzZ9Poa9vAPTfyPCxO+vq WIue30pwwOgJ9T6V6JyssQwljwDjoR6V2Oh2cSldyuCTtJHqTW0UJeR1fjDwBbq4FlEznG4sOzgV ymkGS0lUyxglTuZSfQjr9RWlN+RNtdT7Is76TVLJQsqFJYyBCv8AyzYKe3ua+EtR08wO6E52M1uc 9Rsc9R9Kptfqc8076kcTDvj6Vft2Pbj+7SQNmjFFgHKg93B7k+1X4VjH3kUjv7/Wh+RSf+ZfiK/8 s09jj0FXrYjP8Xpj/PrTS7kc/ZnbeHLqOP7zYH3iP8BWtd689yeSNg4RPf6VBm2/1NrRYC5GFBPY eo96+iPhl4QUIHvUx/FbxH+IHufpUVP+Ab03/wAA9vtHyo/L8KnrnR1xCimUFFABRQAUUAFFABRQ AUUAFFABRQAUUAFFABRQAUUAFFABRQBieJPiNoukKDr2pw2+eLaE8tcPg8RRj1wa8D8aftc6ndBl 8NQtpsOfJ+0tgyTR+qkdN46Y5Hfnp20KXWa9Dgr1ekfRnjF/rc0rE3M7yMf9ZIxyXz61izXPXb9D 713s5PX0Kq20jdSoXqzH+E//AF6Rr2GP/Ujeehc9B+FFu7H6Faa4kc/vWL9yfU+wpEgAPAx3K+h9 6DRLsdJofhee4IEEBc5x9M/4V794G/ZhuJAG1IeUnUhxyR6BcdxTlJLd+R34el1me6aJ4F03TwBp 9qoP3WmPVif8a168apNv4jplL/gBRWZAUUAFFABRQAUUAFFABXzh8cb6AXTJp7tHlVm1oRnia4xw JAPRcH9a1p+RnN9/meHX6cnjHUZHv6/Wuau9P9CD3/D2q2+wGJc27D+H6kd6z5lB67lbqJF4K49G rOXkaxO48G/tQ+KdCYeRfm+th92wuCTtiHZH9vpWl8Svi3ofia3la3S507VJCkf2fojwI/PmS9P1 /D0i/wDwSmu3oeBaxcGJiEATHKlP4gD13e9YbXAcHc4J6hT604/8Exl5vyIPJYgb/l7cf57VSuD1 AY+pJ7f/AKqYmv8AIzhbD3+vuaVYWJ5P0pCSJVsVU5Yj/EinLIOoJ+tS/wDgF2/zJHcHqePvYPao 1ZG5ChiOAfT6VIITeDnaDnow+lRpIwB+Qeh9uaLd2A4zAdhxx9TUD3SN2I7ketOwrj0mH8B/4D7V YgQsf1JqgRfgkEbHzCB6YHf/AOvUiXhYcHJ64Hamv+AF+5Mqq/3mO70Hb8av6erg/ugcdCT6+1aI k92+GNnLOFE0qRRb0bzSM7fm5wP9oe9fWniHx+tjaeXDccAFY/8AaiOa3w0LtaebDFVLLT5Hylqm rSXc3Ds+W8uNf9p2xxn3r7u+H/w1stEtI47K1SOUqs2rzdTc3zKMmR/9k8D0HAr2c5l29DkwEdPw Z0scW3uT/ESe5NPr5o7wopDCuB8fSSW01vLHK8a5axnZT2kHf61pT/4AmYNzbWbTH7d4WhvwObW6 kbAiAHJP5msrRmtLm4lfTbRbeDlEROjsF6r+NXFeb7A5eh6L4CgKxvkAfNu49SO1dZispjOH1dQJ X+uce1UQa0QzqPDOMN+B/Ct6s5AwoqRBRQAUUAFFABRQBFdWayoyuAQymFwe6uuOf/1V+el1ohtb nBG0gsi57Sox/ma9TA9fl+phX2/E67w98bzaN/r3jcHBjOcED2r0TStU0jXblLjV40umjGyzt3Py pKR1aP8A2f8A9VGLotbehOHme++H/EFpLgW8aJj7sYHCjHbHpXH+EPDWmXj3Z1KNHYTG3iIPKxhR 9we5PpXmpHYmzZ0L4QQ2d2JrTUJXQI1uLVh90yEc7vavBdVOXl2sAd759wHNUv8AgfmNsXR7Mq+S pPysxA9Nvf6Vy5dFXMshXqEA6kZ9KzSLkybTPGUsMiZBaIssbxH+JS396s7xlqKR3Uhb5Rkuqj+Q x/hVNkL0Ow8A/GW70K2m+yWolnlIktjIciwCAjJj78HOMj6mvYNRstKvJrT+wtZS6vWP2qfVEbJa 3jTlmUdCOcDAI6Grg11/xDT/AMvRHp9vZRxKBCpA6knq7k8lz6saiurmXgWoUuerN0jj9T+FR6+p mjxf4vQOLpcn/lmFLevPYfWu/wDBXiWKW0gSyl3z7AkyqP8Aj3CnkufbtWjW33mj9Dr7e1SMARjg d/7zHux/2jXjMnx5sdDkvla1nu7kztc6dboPlk3xqPnlGeIyvpn0pRW/3keh5LqWpajrNx5muSGa 4ciC2gX7tqjNwsEee2fqe5r6jmv49Ito1VYyyqttGjHALInJOPQ02Nvt6HyVp/jQfar6e/lL3BZo 9OUjrdSZGcf9Mx/9aug+F37UttoUkdtfWYmikl36jcLnfZXV1gbioByFIGR19PSiO+j6cpVTyPo2 TV01WUJprLLZoRNrVx2mmXBVEB9+T/nOF8cpHGmybFydyH6Yf+tSlt97Kpvaz82dlpWowx2sb3Uq RRiJJ55X6RxiIHLH2FfKnxG+KLatcuyM5h/1OmxP/wAs7VemV/2+p9zWttX9xMev3I6n4N/DzxO5 kfSNTOmwOv2S+vdobDI3S1DjqgznBAH16YP7Rnwv03TRbfYLq4muX3m6knbLSiPb8zP/ANNGY9c1 vCWq/H8WVFL+uh778HoWTSrQOefLyx9SXNdk8zjpGzDqcelcM92RNa6s4bSdfuNYvmItwthbgrZF utxqbn7zHP8ACvTjjrnmu+q6nT8QmAFeLfEjXor+2ummk226ZtbFB/y+xp1I9mbNFNf5IIf8A+Fv iTqKNdW23MYTYgjPbc4/nmtH4r66JJARkttAdccKeePxWnNba9x9dWeK6nfsT84x/dX1J/xrLkEg +9+A9qyf/AM2RSbj984HfHcfSqzyKDwD6Y9aj0D1K7sPTHqfSmBT/Dj6GgTfYa7Y7Aj+L60yScnp nP3QPagBrW5Hf2x/jSqmB93PYH0zSHYcq8cqD3pvkN/d+n0oQh6yEdFGfX0ApQ/tz0x60APMR7jP fFMgjIPKnH9KF/wBs2LWRd37nIP8JPY+xr3L4AadrFnPJNb3siQMnl3cg7hegB+tJs1gv8j6V8GT +I9clzpgb7IjYu7l+A+MZ+avcr+5SOFcSZI4PuB/jWM5HSl2MCPW1H3mz3C+oq2k6SDIG7uyjqv4 Un5giwsSuf3ABHcN2H0qrcaTbTqV1SzS4iPDxOM4H+yfasZGq8j54+Kf7COj6ll/Csi2s/LNbEf6 xv8AZPvXx54w+DOtaO5XVLCZQPlEm3hhnsfat6NTpN+hvVp8y91a9fM42S3YdQf8KjMeO/uPauw8 OS7+jGbf8+/tRsPekSJkijf/APXFSBNDeun3WOP7tX4tUVvvDB759fapaNIyIpoZZSFtwWdiIYVH d3PYV73rccOiWUcMTKGRRJen+9duOc/ShIq+q+88LlumkJL8k/Mx9zVGEAtx/n8KRbZvxthOp9hV Dce2PqK5jpZo2pJHLex+tXo2/ugf/X/+vUyKiTxOO598/wCFRy3B9f8AeB71m0aJkkUoIPX6+lU9 TfIGCfX6gVNi2/8AI5+U8fy+tZJjb+6a7aZ51VCGNvc/0ppi+v8A9etzmYLFz1/CvQ/hnau052pk Y2MPb2+orCtsb0Vqdl4+n2nAyCFwR/dz2ryG+YgfMSD0JHfNc+HR34kosfWrAGAM9/8APFejY8n0 PtD9lK5B0Zhk4WZ1x6Pz/MV6lK4J/kfX613f8AxpvfXqVZmzVCVSOvSg2Zl3keVbcAcqy8/7hr4a 1tf9Ik+UffY/Xn/Gsqh0Qej0Mydhng//AFjVeX6fj7VwoCLHp+FdB4bmPOf/ANYpVFoZ09zrFUe3 4VxXiO3KyHjjqM98/wCFcNDc9SvsZC/5+laUV3IBgH2/CvRPHIJST3PqfevbPgJpakTFwvJCdep4 /pW1Mzqs+uviIFg06IDOcDaB6Ed/xrx7TLRSvJIJ5Ye+PT3rtuaLZW9S4bdezn0A9frUZtQB97PY f7JqvQzT7r1IZYx/z0x/T8Kks7RpmVQxYkiJQO6k/wCFT8ykvLzPWCu3AQDAHljHoo9KchHf6isD CPmOkmVQSzYwC5PoMf0ryLwJA15eTyyBTyYUk9QDSXkaW0f3I9bDY7D2FNyD97P/ANehErzREzn+ 9/8AXqS1dtw4Ppn0oaH/AMMR6y3z/wAz7j2rLkKnrn6e9HoEvL0KkjY6L/wH/PrXgHx0lyRhRjj5 T2B9PpTb8zSi9TwqQ/8A1qhYZ6fj7muKRqildn/6/sapEfSmiGOiXngfWrtzJ06j1psRUJPrSA// AK6AJUH1/wAa9g+DvhiMlpZVBx8kRP8AfI7/AErGq9NPQ1pop/E/xQ1xNtTG0csB/f47fSuEhUd/ xrKmtPxZ3132Gug7Af8A1qjiXJ/z1rQwZ0fjj4ZXfh+9lt9QV8IfM06Rh/r7KTkFT/sjisTA7c9x 7VrUX+aOWk9PzL9o47j8anyf6fjWDOhItRMR/hV63fA5yT1HvWLN4+R6h4dnd4lycfwrnscVtRKR GdzHOcbh2zXlSPSb/wAxkascgZ6EZHcYqfwTxCVJGVYoG9VPqPeoltqil5ehS+JlqJLVxnafvhx6 D1FfOkfPqPUelerl22h4uLWpOjDtx2qT6k+3tXqo4mXbaRVIJdh649a7XQFjcg+cTjDEem329q2T Jv39Tudbv/M8o28pK42yrjpg+vtXL+JNG2sHgBwfvD0x7irgnYxm9dz1/wCEfj11iUSgN5ecD1DL /jXzn4xkVry5KIBukaY49G9PoKpr/Iib1+V2ZEMg759M+30q/Bz0qH/wBtf5mlErDqMfX0q9B/tL n6f57UJk2L0ZPc47EelW4sj7uM9Rn/H3rUy9Dfsro44Y5PJPpW7p7k4wfb6CsivQ9b+HHhEXTgzf LGvzOT/G6+lfRGiOoI2KAOiKOwFctSXn5Gn/AA56FZtlasUkdsQoplBRQAUUAFFABRQAUUAFFABR QAUUAFFABRQAUUAFFABRQBn6x4q07T03axfRWydELnmRgP8Almg64HtXiPjD9re5fK+EbYW6Z2Pq E+MunP8Aqoz0z75P0NddGl/Mv+Ccdar/ACfM8P1TxHcXDFr68nuJCS8skpJLOT2Le/8A9asSfUXP 3SCepB7GvTsee/8AglRw7dQM9j7e/wBKrzzRR/xhz7dyPSk12KM+W+eQ/eOPp1z6ipIdP3dI/wAD 0Ofem/IqJqW/hWd/+Pe3Y9goHTPrVuz8AahK+FtZcjhiR7fxZHYVE9NzphTZ9A/CbTfC2mMR4n1f TYroYNvFMwwu4c7nP9zAr6GjnRwDDIjqfmjdTkMv+yR615dWTe9+yPVn6O3fuOxVC58V6VC2281m whkH34ZJFBXI/iUnuKxS7GF/5VcqXPxG0OLH/E4tZWYiKGKBgxZmI6qmeme+K2sU2u5XK+qfYKKk QUUAFFABRQAUUAYvivxcNNgZ1QPJ/q7KM9HuG6b8dl69RXynrqSSsxuZGkkYmSeY9XlJ7n3Nb0zO Rxt9btzkZ965+5t/7pwe49fw96b8hoyLqFT95cf3QOx/+vWNdWoHQ59R71i2axZi3HHTd6D61nys 38Sg9jnuPrUtCb7epRubeFxycH+I+1c7eWcUZ4Bbvkdsf41UX/wSGu6LM0aMuYpwW6FO6gep9qo3 kAK5xtP8YPc/Sl8iX6+ZkI3HUe9AlA6/h9aAHNLnHGfU+lNcqPr6f4Uin6jDJuHTHofUU2AFeucd yPSgm45n2N8rgj396ekig8nP94HvSLuILVT/ABA98elEdgufnHvn1p3JaHKIAflX2b/aNTrMuflX HqB2FDGXIlRx8+Rnq390e1SxWMZB2SMD0X3PvVLyB/8AALMSgfeQD+ED1z61r2duc/Kvtj+7Vpk2 PrD9nz4Q2t5atPdoHjV/IWEn7zgdWB9q5z4rfFe4k1CVLRCluuIVTP332jk/T6V6OXP3tTHGrS3z ZnfDXwxLqF7bhEzmWNn/AAlByx/2cGv0KNXmktV82Xh1p+IlFeMbhRQAVleI/DSX8LI5wT+8t2/u zJ04+tVFiseaxJOVMeqwNkfu3I6SqPRvepDHDaIEsoljZuIoV7Anqa6H5epHp6Ho/h/SDbxAPjef 3sxH95v8K1K55M0OH1lf3r/Xr68Vngn1rRDOn8Mt97n3P1BroazkDCipEFFABRQAUUAFFACivhb4 j+HLi3vH8wPuDkyqezbj/wChCvTwL3+TMKyJtZt/DN/GM26284AXco6sB/X8KxPCfiF9KlCy3Bkh J8yOb0AP8R/z717mMimtH5nmYWTv71z6j8M+K7faHAVwRuXB+634VreA7NRCXlizPJI1zcsP4AGI AGP7or5H19Ge8jvLZWB+ZSO9fKPhX4X674gkmeO8k0+yEjpHdEc3BLH/AFAI6L6/lVxffy/UcF3+ Z7np/hSPR7J10uxheRY2in1GQ/POcHJlf3/CvCNO+D2v3lss1jYieI5aMqeWAJ+6v1perNI2/RHN 6V4G1Oa4UXdlPBGrhmWRSDLtPfI6A1F4ysVF85aJG2khIz0WTP8AhSb/ACG492VftzE5kYk9Meg+ ld54d8T3emrDLpfleapZ4o5M7ZUbIIdRj76n+opJefkYyfY9k0P9p7Sr1EA0+5hvXZbNbBvurPI2 M/asAbQfbPtXo9vZCP7zF3PzTSn/AJaN9Paqku3yM/X5HiXxivVF0uecIDgdsk9a9E+GMFn9hiaw 8slh5l46kf8AHwGIIcjvEeMdq0ltp8zR+pn+JfjjbwuYvDyfbLjlL26UHZp7KOjOBgsvpnA7+lfO tpepM07XjtJPv2pI3Vsk5JqV/wAOTbv8jofAGmpc39utwVA3faCD/wAtTAucFffFdL8X/jZYtcxR Wd4WjVvstzKnS4vnOCqEdfK79BnjOauwf8OfPN9erbtcvMSFR2kAHV2B4x/vGoPhvoEsam81xZfP kLDwtay9V3DBkIPQJ0HHuKyi/wD5FFy/4B9ufCiySLT4sHLnM96+f9ZcSnOT+BFUfjaD/Zku0gHK spPqHHXg9fpVrf52CD10+RzsvxBbxDaqmhztYacsav4r126+UW/loPliLcHBGevp0HXwq7l0y6uR H4RElxBuFot+4wb2Rm6xr6Ht0z1q+v4y9SY/8Fn2NZWlppduqu6xwxII5HHfYvUD1kb8zXyT8e9Z vrq5hk1G3uYI2Rv7MDgjZBu4CA+v61dHfT0RUVv9x9MfClcaZa8k/uxz6nJra8SeIWtIj9lXfcMR a6XCOstzIccD/Y61z21+dgktdCTw/wCGIrCFUhwT/rLqT/ntct1J+prTpTZEmc94v10wxBLcsbiY /YLBEPI3jllP/TMH8OK4r4n+GNP03RmjRpGC7Ujfq1zcM4yXA/vZJ9O1awW3m7mtLpp5n57eOpo2 1BN2MKyJtP8AeQitH4jXDSnMoReCQF6BcnpU1f8AgktankupLC4By2R973+hrMub1JMbFC9mx/Fj /GsmZtkDAHoPzqk4OeoHr7ms0IhMJz8uCexFQGcjr16ZqhD1QN6ep/Ck2qP89aQfIDjuPqfSo1Ye pH9TSKFB9TjuR605ZCOhPsKGwQ8wj+IgdwfakEQH3SSeopASCVvz5PtUoG7GSPU/SqFY0rB7dc+a CR0Pucd6+svhzpxm0e2j06QFnzcXbj/ll82MMfYCkzaMv8j6J0yaa1hjg0A+Thdtwy44buZCe5/G tnVLtQgEchYgbGPrgdzXHJ+XmdqX+bOTj1Blf/WMQBs29gxrf07U3j5WHcTyxPcD2q5vv6C5exZu J7o8hFTPIUdv/wBVRQXl1Gebk+pVuhNYXNbGrHrFqw/0wqrdjGO/v9aw9a8JaJqqlNb0yG4Q/uxO R80Yb+63tUtf8AcJNbHyz8Vv+CfFxDuk8FP50X+s8lRzj3X2r5d13wRqFg23U7CeFuxZSM4+vrXZ RqdJvyQYmjfWmvOaMNoyPbuaYQe/Supo8UaVP9fwpPrQIB/ke9KGI74o9QNPRfEbWcqSJGJHQiaE N/eX/Cuk8TfEiTUxmbcrE+ZcDt9F+n0qf+HKitd/I5st6E+vHpVOA/N3/wDr1D/4Jrc3dwCdT6Y9 v/rVURSOtcyZ0XL0BxV6Jz3/AD/+vSZpHyJRLx90HsD6D6VC8i9hkdPqahrsaJ+RLFMQDjGfukVS 1CQcdM9DR/w4MxZ5Tjg+5rPLHt+tdVNHDUY0sRUZatjnFiXnmvV/hJAhMjMSMERhvTAHT6muavsd NBFjx5eku205/gyewFeYXkhJAJ98/Ss8N/wTpxTKuMn1qd1Pv6fQ12o8x+R9ifskyBtImHcTMcH+ Ftv+FevSn+6SP89q9Fefl+RjSW/qVZFHdjVKdfX649qZqZlxDuBDYxg/iMV8Pa9GBcTZH8bAfUH+ tc1U6aT0d15mG7ZPH/6qilzXGkN/8Aix6VraBJhuSP8AEinUMoHYxEfwA/T3Fc14oiO4HcT2P19q 8+luerU2/EwY4c+npWhFbA9D7fSvSueSvMhZRn2r2n4IwuY2Ik2L5gRsfxEkfd+orWkS/NH1Z8Vb 4fZoREpbADEn02+nvXjFvdT/APLLUY48cxKR1THr7/Wur0N6MdFf1Hx312pyLyB/fHTPrzSJqlwx AMseTwrD+7U8/Y6PZrs+5av4wR8zOp/2e5Hqfeuu+HnhuJ8u85fbyoPZx/hSnI5raanas5J657/W pBj0+tScL/4BheNtfFnayNyGIMVuB/y0Zq5/4ZaQtvbKXTDt/pE5x3cdz7UX/wAim9Ne+h3azhui /wD16Rm9R9KSQv8AhhhYDuc/wn0qSyI3jOQepPsPWnYt+vmiDWB+8bByPX1rOIHPHucd/wAKpE+v qV2OCM59fpXzd8dLmVrgAsAowRH2H/6qls1orf7zxliD/hURA+v+Fccmaf8ADmfdsKqED/CqiTIs W0WTzUty+ep9h+FFxWK2c/560AZoBFiCIsflJz91QP6Cvorw7pkWmWQ8wgHb5rsexcelctc6cMtf xPE9W1JriRmYnJJYD0Woif7o/GqSOiq9SvI/v/8AWqWzjXPJ4700jFs+p/jf8P4/EOmLc6YrtqFt 896g63OnnqBj/nn1r5ZjnDAFeh5X6V0VF/kcdJ7q/mi9bY96tOB2BHYn3rmZ2LzfmWIU4457fWrc MpH06VhI3X/BPSfB8mYxuJI6LnsxPc108ABRwxI/ix/e/wD1V5kz0/8Ahxkakfd47Y9Rj+tP8Gyl TOoA++JCD2DLWUupMV+pN42tHktpAAmCMgHvj/GvmVYmXiQYx8p98V6WXPT8TyMW9fwJFHp09akZ mb7oHv8AhXro4fT5FmG2Yjjn6/0ro9MYqAFI/DuB6muiHmTJf5nY2d3uK+cxZOrgfwn6V0F9pRuk PkhQmN6oT0Cj+oroRg/+CyH4aXIS4KyqdpzF5Q7kA9vrXn3xHsDDfTgIU53EH0I9PepZEt16WOWi YjqR9a0IJM42gfX1+n1rOxb/AOAaCSt3GR0J9Kv25HGD9fal6E/0y6kgz0Deqn2q1GSemR6VovMh /wDBNewuUH3/AKD611/h+ykncBEHPUjsM1MvL1EmfR3hSzjgULDj1c+rV6fozLx8uD2PrXA/+CNM 7/T2yvNW6pHfEKKZYUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQBXvtWtbVC2o3UVvEPmlm kOAigdyfavIPGP7V0UW5fCVukr9BqU4+VXOf9XDwTt98f4dNClf4jlrVP5TwvXPGt/etu1a/muJO gdz0BP8ACK5251Fv4ifUV6lux57fmUmR26EnsM9hUUuxPvMCehA9aCF5lC4uWPRuPT1//XVIoB94 D/Zb3PpSZcR8FmSRjOfbvXrXw7+B17qzfu412jl2bogHdzVqS+16nZh6V3+Z9K+GPgHoungGa1S4 l/jLDhT7L7VmfFr4YSXNmx8L2kcFwn7+SK3UA3tso5VWHccGvLqVrvV6bHozl29T5ZfSkHWEk9JC 45DDrnPoa09J8b6zYDGj+IdSs16pFE5wB/uGok+57cEmtUjQu/jR4quARc+LtUkjPyuivtypH8RQ DrVKzVHOXBkJ+dmfku5/vE+taR/uqxlyrpFI9Y+HXgeSeZSsJAB86QgcIinqT7//AKq+hM1lW8zi xD2+8KKwOMKKACigAooAKKAKmpaHa3iFNQt1ljPVT/Cw7ofVa8p8V/s3yNltBkEo+/8AZn4II/uH vmtIS7jXmeJeIPBl3asRd2sqOOJEZSNv0z61xF/pg+h6HHY1pLyE13MC7tmH8II6ZrIuLY87cD+6 D6VhJf8ABKTMm5gT+NTn1Hb6Cse7gkH3RkfdGe4PqakoyJ4j/DgdiPaqElrGf9YPqfQewobJt/kZ 0+kD/liSD6j+KqV7bXBzli30/wAPehSE49jMEeOuVPcHuaj80N6exqjJoUhgPlJPfPrSF9x5X/6x osOwhRz0f3+lPO/+HHvj0pMF6kJnQn94rZ7H3pWXd9wke/oPr707AN+df4gfT/69TNdSAYUg9yfb 2NILgiRjqxz6elWwM/dOR0PuKYE39oLHxyT0Cn+E0+0jMmS8jKfvKg/iOf6VSfkC/wCAbMOnNkGQ gnrGR2+prq9F8PyykfaikeTtZvr6D3qhpdz268+OreG7Jbbw08UlzJgzxR/8sEz1d8Hlwc/zrH8S fCnV7N4jeyPdtOv9p/agMmTeemB/d/8A1816eDVvi6mFWN76P+U+gf2bPhVJG7TX9nIgQG2tJGGA 103XZnr5Sk57A+9fSlcuMlrv5HRGNt/UKK4RhRQAUUAcl4s8EXtwQ2hTJFJ0ulY8OvqD60zwz8Ll tjv1iYXNyfmYfwxkHjH+6K1U/LyEl5+h2FFZDOH1o/vX+v8ASs4H1/OtkUdN4XfO76f1ro6iQmFF QIKKACigAooAKKADNeKfE34XaZqk+9neFsDzCoH791GMuD6DFbUpNfD6DS7o81vf2Xpp3BsbxpCS EWJRyxPrj0r0GL9hvSigF3rU7SYzIQowHI6Bj/hXofWu68gjTj1i+xa0n9lW/sD/AMSvxKGi4P2e bONo9CB3Fd/oHgjUbIY+3WzD7zIM4zntkd65asovYvT7PMa2p395HG2y1MjbSqSRnpIRxxXO+BNJ sLKziiikXzFyLlD1a4ZjncCT1z61ytdgXl6GjrQxbXAlkVR5bkuf4AEPUmuV+Feu3SadbLNaiHCY jkB/18ZJ5x7/AFNL1C3b1Owbw7aXR/0q3Ut1MncY96+RvHssa302ZEQbiUDHrg9vxp8pUH3+RzzX 8ajJWV+drBVOA3swHeu0t3l+yx+YCpwzbT1QFu496rlG4vqn2MVtVP8AAzDuHH8JH9017D8Lf2iN cllWHWIl1KE4gtr3OJIZyeBIcfMGXPoRjkmriu68zJx7P0KXxou2F/gEY2Lke2P615mPHmsWvmR6 JqV1ZRyfJfvEf9cQOw+hxkAE9+1FwaPQfAvxFsJzBb6ottpFjDEWuZ4QS2r3ylR8zYOM5LdD37Yx 5rps6PJL9mZgpdmRW7Jnv9aVuzF6+p6H4C+FN/qzlrdkhiX5XumPSQ9lArzuXwHdSeIfL1Ug2dtu uprkdJJVQYwPWQt68Vp6duY1Uf8AM5i58NxajLN9svWt7MSm51RVPNxsbhFX/poR7VmeP/iR9nwL VYxcNiO2t88adZZAwV9WHtisY+SJk+yPtL4RSXcKPFqahJFSG7ij9IJoz3/2SvrxUfx91iODTJN8 gDMyQ2692Yt2HsKpb/O4qb2PmfWvEniKWCCDVWmtLFVF1YacFwLzcxw83rk9OSPSuk+D+jRz6nbq yoAN184P8RtkJAx7mqT7L+8P5+Z9IPeDWrgrCFfToGzfy5ONR1RQMKo7rb9/U+2K8k/azu444rQy cHdIsZx13KnQ+1a0Fqk33f4FR830bPVvhJfxHSbRmkVE8kSSOx/1aLnO4/7NHhW+TWZjcjcbZd2n eGEYffjBG5yD3dhj9O1Yd/uQn1v8jt6R5UUEyuqqPnkduiIB/ET6CsTI898FaqmuXUt15M620edG 8MrKP9ZGv3pEX/pqTx3wcHkVP8UPG/hu1gZPEzCUsM21svJWYdCTkYw3TkV0Na+70Ntb+6fmf4ru o59SxGpCmUIw9s9vpW54/heXH2e1AAPlFSfvDPcmpqP/ACDqeU63HJEoEkYT+IgfxA+9cyZQvJI9 Co7CsjCQ4SmTO0HHTJ/pVe6QDGz6sfeoYWIsEjg47GmfZMdWJPWgF5grr3Jz3Pt7U1tx6fh7igfz GFvQ/WlI/DvSC4in/EH0qRIQerH1FADsccn6e9PXd6D0BpDA+5z/AI06M+gp2EW7dweHxj+IetfQ n7P/AIsjt5zG99KEI3WkHYEDt9DSZrE+vtN1CFB+4+8Rtkdu5x/SquparGB+5kZ26SY/oK4pLseh TfcowxuR8sR/vMx7mtm11C6xl0+QfLz70qr/AMy6a7jX8UzH78Zx0Vc9B71FF4lWQ/OrL2GBWKXm a8pcjulfpLg9hj7w/wDrVYtjIx4kP/1qHIlryOk0eymlJM86Q2qDzdTuX6RwjqCfVhXinxe+HOhe L1aU2Isok/4lnhoqMG6j3fflUf8APU/j0HrWLlquX1ZpSf8A8i13PkLx/wDsn6/pHzLaPPCctG6j +EemPWvJZ9OZD86Op/iVv4SPUV7sJXPNr0usCuY//wBdM2Z9ao8//hhuz1o2k9fwFIA2ntT1lI6f hiiwFhLw9wPTPvSQxEHr7/Wosapmu33f0I9ajRM/56VznX/w5cTj0x1OfWrMcpPUf/XpWKTJmJPT HqB7VERj0/8Ar1maipL0yAf6VSvpB2/OmiX/AMAyXHHP5+1UnUZ4IrqgcVRdxhI/xqIn1P0rS5i/ Imtx6fSvaPhTZhYSSG5YuCOy47fSuTEPT8Drw5z/AI0vlZ22Z5JOfpXn1w2SeOnH1NPDorFv/Iih z7/4VK8g7j8fWus4EfXv7IEpOmXAIBImJIPYtGOle0Ofr7fWvRt+S/Iwp9bd7lOYH0P1PaqUz+oB 7A0zVP8AyM2ViehA4IBHb5TXxN4ugKXE2f75wPQf/qrmqnXT6nMqcnpTJm9q4xdCPHqKuaVNhxz7 U5IwR3ELjjGfr/n0rH8URFlByc/xH8e1edBansyWmjOVDEdDVmK4I/wr0Txx4QHqcetfR3wDiQWy AxxsxfzEYjoM9j71vSRFTyXqfQPxck8mBRMVRsADPc5/qK8ysbWzKDzLdCcclv4ifaur5msHorep PJpWnEc28eewHY1H/ZlmvRUz1TP8A9qUV3G6kutxJ7Vn6OuPuke9dt4N01reFiHYl23AY/hA/wAa Ul3Mqk9LI3kcdyf96pxn156geoqP+HMGea/FrVHl8mG3lZS53uB2jRufyrttH01Yo1GAAAFGPp2F T6eo59P/AAI0iVX/AD1phJ79KpeYf0xjKT39x7D2HvViwGXHfvg+1NCbKmrn94eO+FI7j2qkc9v0 oT7+oMrO4B+6D6g96+Y/jfIftWOem046AAD+dTI3w/X0PJSPT8/WoiT6VxMv0M26OT+mKr4Hp+NW iW+5egjwORUMzc/p+NShsgJPb6Ypyr/9erJOt8AeG/tdyodMouJZR7A9zXp3xP8AFflxBICEzjeg 6rGvqPeuKq3fT1PQwq3+88dLDPJNDyf3c1qQ2QEMf89q39C0OOX/AF+SOgX1Jq4oxm/+AfU/w48c pC4W7w8LD7PcRNyHjcHO5fpXz78X/g8/hq/kjiIeykJv/D846PBKenT/AJZHiuuou3qca3/8kZyl t75Ht7VZJ44+ufWuBnev+AXYWOOCfXjvViJz2/Ee/tWLRseg+CHBRtpJwQcHsMdjXX2kh+YFFORt we4x6e1eXWR6a/4BAhGerZ6Aj/GpPDURW4mD7SCAwz3YL/WsX6eZUfP0NXxFao0LZc5wcD+8fevl +YHc3mAZyQ2Oz59K9DLXueTjVqNRv/rZqUsc9R9fQ17SOBl63Hqf9r8RWxptwqHnB7Y9Cff2rWJL fY6uwYAD5iTnGB3z613Ol2ocfMDk/dUd2+ldETnku5jor6ffIdm0bgTnjBJ/rWL8d9PCakxAGGRZ AfXAHQ02/wDgGb6erR5nGPw9PerkLDsPfPp+FZ+pbNGIY68nox9avQt6ZHqPQiiwn5F2GTHUD3+p 9KuRA+nuMdwKpEPz9C7BkfcGT1wPavVvh5bBcGQgk449Bz0py9SG/wDgHuegXMZ5GR/d9zXpOhvy N369q8+SKh5notiRjg1bpo9CIUUywooAKKACigAooAKKACigAooAKKACigAooAKKAGy3EcYJnlSN B80sjnARR/eY+leXeL/2ntMs9y6CFu5/urO2Qkbn0452/gK3pU77/M5qtS2x4R4m+J2q6mxOs3ry j+CEcLEmeAqD0/WuUm1MnoBj+Eeo9q9aMf5fQ81vzKYkkk+6D649Mf4Uslqqc3EgY/eCj+tU0TYq T6izcQpsXo4HUj3NVDZNn5Qf/r/WhlxXdjl0aQ/dU+h9z/8AWpn9gXBOGhkU/wAAIPNTJG0IPojr dH+GaRAPrlylvGfmVe8qj+6nua+mfgtd2hhYafAyJwMn+ID+8RXDUl2Paw9LRs9RozXAYnDeLf2f dB1XcTAbO4PK3cAHMoHWSLvnv0J9a+SPEWlT207xiN2ZGa0mZASGeNscEDvW0X/N6HXQqvb5ozra G4U/PbXGOhJU8Ae9ek/C3QrHVLlYrmfycgy54y/lKTiIHuw/HGTWkX/K/M6edfbZ9VaV4btLFNun wBF/iPdyP7x9hV6ueT7nnTlfcKKkgKKACigAooAKKACigDI8Q+BtM1SMrq1mkgI2JL/FEf8AYcf3 TXyp4n+Et3bSugUyMpMZ9XQ9Dgf3lxWkH5hbucFqnhe4gz9otpIz0bcCMH3zXLX2nY/vD0Poac/Q troYNzCR94Z/2h3+tY9yNvUbu4X1rFgn/kY0V0sgyYmXsu70qrcWJ/gIPbPrUMbf+ZTeEr0J9TUL gH7w9jUlfMoXOkq/3QB2+tY8+hSJ/qySO49PpTUu/oTKPmU5WK9GOerD0AqMSoO7H1+tbo5/X0HE 88Nx2FOZCD8jH6etL/hgt/mBiZ+WPPY+wqMl+7YHT6mmhpf5iRKp++T6qfep45QP4M+9JibE8oen vViKdwPlYg9v/wBdMEu3qKgJ5cZPX8fet7SdPZhmPDdgv90Y70f8MUj1HwP8D9U10ouiRwtO+Uit twBUx9S5Ptz6V9JfCz9hy1jM48dadLNdwuotlB/dtC8ecxyEc+Zn8O9bLbR+Z2xj1dvI7af9lvwH dS75dILvxE0hI59se1ewaP8ACzR7dEE2m29wUUQ2rTKG8mIdgW9BTlUff0Mefsl3Oiit40AEESRq OEjQYCj2UU+udvu/NmQUUgCigAooAKKACigDhdcJ81+nXp+ArM3VsgOj8KTfMw9t35MK6qomAUVA BRQAUUAFFABRQAVyPi7wlfXbKdLMK7Rm6DdZeeijHVhmqi+5cfM0/DOgG2jzLtLt+8OP4EI6A+9b dEv+AS2FFSIK5q18FWE+6RTIruTJG8Z/1QDH7o+tNP8AyKizF8Z+E9Xa2mFvci5RlIYHqAB/EKk8 B6nZtBGLnZG6qIAh6LsHQfSlLyNf8J1ckgQ5g2svUY7/AI153H+zX4ckuHn1PT0vJWPnKkvIjY/3 V9qakTCXb0OytvBukqMDSLMDpt2j+WK81+JfgSzNzaxadaRWqy7onMY4Ry3Xb9K0i/MFJ9X5nMeJ v2Ob+M/8STVg8fQq+MqCew4/mK9n8C/CTTdEiVbW3QzYzc3J5JkI5w3+fypuXYpyX2fQ8V+N1ygv 2552IrD0yleRXU5DnJHqF9R7iqkvyJNTwxdM1ymwY689h8h7+1YovJY3by8Dkk/7fPesU+5L8/Q+ tfgdqdlPpsRsmi835hrEakZjvVcj96Af4lAI9q8Z8TzwRX0hhkzLdTGfcB00+1GB8w7Nj2H1qm+/ oXB76nht7qjW0snlIDl2dg3QtmvMNW0e+eYHM007yIo2gnMjSDAUD0qoPuJrz8z9AfFHxY0zwxOk mou9zevbR6fDocTDcZlIO6564C4Izg+wriPi14a8TT6d9p8a3cccrunkaPHnGmWrkkKoPfjJ7+ta 37L+6vvFRX/yKPNNa8banqrq+t3XmyhVtVCgARxJn7ij1Jrb8C+F9QvrhU0dnSZsxm4GcW8B6lyO yip/4Yz5fM+vPDfg+00uBItODbFGGkbrPMxyWkPq7f4Cvl/9sfUG8+yQMeQ0mB3zIP54p0Hr97/A 2pvf0bLnw/8AEniHWbe3sNMQ29moMmvanFnd/ZQlJxIx4AcsBgcn6Zr6hsNJt7WNUsYVjiQCC3jH 8MaD+tRU8n/ekZvyfmyxXlPxZ8XXtzJFY+GLmNLy4+bVp8Z+w6UvXeAf+WmMn/ZBHcVFNd/VhFf5 no+h+G7bT4Y4rBdsSKIIs/xkdS3vI2Sa+bP2k/E5E8aXGnIozttpTnMgUdT9c4q6e/4o0prt6nxH NdtJqcfzjHnKA69zn0r1DxzNZoG+zAlskiXGNo9l9ah/8Ajr+J4HrJkmb5mO3pz6j0FYA09ec59Q T7VNyZFf7YyrhCPr9Ki84sPmB9DUNEjp3C8KvsxPY0xiB/Fj29RSGV3bPoPSlxgd/agQgj9fxNLj 1B9h7UAKSP7uOwFSKpHUfUClfuOw5WXuCf7opzE54HHp7UXK9A3Bf5AeufSiMbj8oI7/AFFMRpWV mDjOfrXvHws0qDTpA+txMsYHnRzIMnp0wP8AGk12fobU1/wD3ofHHwhKM2evmLPAt5AQQMdyfStP Q/GlpcFhpL21ySPkcsOg7j6CodJ9UdPN/MvI63SoyyE3HQemOWI7VG8s4+6HK9QPX8K4JxOiEl38 iml1Ic7o9vbnuB/jUlrcSDmNFz2PsfepZuWodSIPzqvux7mt7w9ZteyBLJst96Vx0hjHdj7VDX+Z Ml/mO8Va3Hd/6PpU8i6ch26zdrjOr3iHlc/3f5+uKzLw2BQDyQqKQsMfQDb6D2rLDR6vrovQU/L/ ABP1K+oXNrIpF1CksfRoiOCpHpXgnjv9kLTdUDyaIqW0vUW4HDZ/uZr0b9iKb/m9D5c8XfB3VtJc jULSQL90S44P/wCuuQe3ZTz/APrrtjK/5M87EUrbeqImX1H1puz0B/wqkcgm0+lIV96AAEjt+PtU qTkdD+FSCL66iCPm4PWpVvEH9B7Vi0dMZErXisRhge49vxq1HcrkZOe5+o9aixqpdyea7Ud8/wB0 e1OWQfxYB6VLRfMMMwB9R2z3qldsD/iO1SkNyM6VuO+en4VSZf8APtXTBHLUZGy+9NYf/q961Ocn gX1z+Fe2/D+Xy7YYfsXKY/vLXFidtDtw5w3ia63Mc/LyWI9ea4yRs5znritaKDEvUdAv/wBakdvX 8K6UcSPrX9jyf/QbsEg/veV9AYx0+le5tL6EY713ry7L8jCHXTqVJ5v9r6e9Z07YHIUdmI9aZtcz LiUDlGUnnAJ/hx3+gr4r8b3CNdTGMtguXGa5akjop7P8Dl4ck8E0yVv/ANdco+gwCp7JsMOvoapm KO5tZWAGCfoO/wBaq64haPkE44Gf7teXbU9dbaHHbR2//XUsUZPf2+lemeSWmtD6Z7n8K+nfgjpz JHbhUCjIZh3IJ54963okzZ6v8brkuB5zEgAbSf4WB7D6V51prpLGDCdydN4/iI9q6DeOy/Asb9p5 X2jHuB3+tJhR/ebv16H2qvVlt9vQtx3QONqcng49T6CvTLa38lFVeMAM49HIqZHHVXmPPHqewPpV iP8A2evUN6fU1nbz8jJI8kvJft2qnJPlxDYT6P8A5NeqW6gAfex0GfQUFVF/kx7LkdsfyFIZD/CS B3PrQJDcD8eufb6Va0xWLj8jQIo6o5LnGM5IP51RJx1q0JsiK5PQf73p+NfK/wAZ5t12+GI52hfQ D0+tRI6KHX0PLWJ7fU1GxPcY7k1xMq/YzZxk/wBKiRcn/PWrEy+xHYexPvVOQ1ERyGYH9aUH1/Or IPbvhH4bEETSXUWC3yxhuwGen0rivGGum7uGOQVH7qJs9VWuLrr6I9Khs/uOeRQCc8jpQSO31rZm QRAE8j2H1NdppdkY1BXIPVwe1XDzMKh6XpWomMjGPVT6fSvRviL4DXxZo/8Ao4R9Stv9L0pv4p4s cjI9VFdzf+TOKW3p76Pkezuc9QVP3WU/wsP8KvgAj39RXnSXc9Cm/wDNF6JmC9MelSwqe+BXPI6I +Z3ngcLhuecjjtnHr7iu2tHAk+YnBBXnsSK82r5npx6EaxsDwfqfajSWX7ZjPylC2fUr7Vg/Ltct M3dWjPltj0Ix9RXy9qVsUkfd13HP1Nd+W9TyccVk/wBrnvVkqp6D3Ar3fQ85ruSo5HUn0IrSsic8 sfYen0rSJnI7PSXYj5X46N+Feh+FmjVlMjhgDucHvx0IroS7Gbff0HfEyzheNZoohkOGdAOgU9gP 7tc98d5La4FnJZMWVojFLIf45Y/f2H1of9fcZdPnc8ZUj0+hq1FIT6/U1m13KkaUbkjjHtnsPrWj DjuQPb1zUA1/kX7aNe4/H2q0FUHgsfb14q0zJov2fUdfTnuPevYfhoIHlAugCgDMwHdlU4zWkttP UlLyPXND1CMn92uB29xXpmkTdM5/+tXnyQ4M9E0mQFetaWaEehAKKZoFFABRQAUUAFFABRQAUUAF FABRQAUUAFFAB/kmvPvFn7Rmi6dxYMNQn5QpEflgdc/62X2Yds1tSp32+ZhVqWPBfFXxn1fVT/xM 71ggO63tYshYxzgFB12juc88+lcZLfbu5HqfU168Y/ynmSfdlCWdm+4Tjo3vSCBD/rWx6k/4VZFu 5G98B/qFI7Fx3Pt+FQNaufvbj2JPb8aSKS/yRbg0Vn+6p9yP4vrXU6F8Kr66IENo57DA6sfQYqkv 5vkddOn2PbfCP7K9rGA2tEeogXqR7nHetT4peA9E07TbiTStHtYbiNPMsbkDlZWcDr/tZrgnVu0o vS/Kz0ZaK0fRnyONduJCGv7l5X4JZz9wnsgr6d+AfjawaN4zPGkhYLsY43SjOAv+8KyqeS8jvpy0 a+SPb8UVxHniivlfxT4j0eCeZVu7ZZFkdbhWHJl8w/e+tZVYu3uX7sSlZ/K35GM/xc020jcrLb3M mPKggP8AfcHuPT615XaXrZJbJJPmDn7uT2I9DXVgabV+f0ObEVOx9EfAT4mGF/Jv72Qxtl7LzmJ2 OxJwHY+ufp246fRmK1xC11N4Pt6BRXKWFFABRQAUUAFFABRQAVwfxA0AQlLq1tzI8JDavbj/AJet NVhksPWAZP069KqPn6BfyNPV/AvhzxDADc2kM0brus72MYaOOQfwuOePTt9a+Zvib+yxqejpvspl vbXPlSSIMNBuJx50f+1wOM81SfRvyRTl3fkjwu9s2U4ljdT6HsfesW4tAeQB7fh7Vg/P1CxkT2oH 8PHXj3rPeJ+dmSP7vpipa7lRKsiRn/WZz7+vtVOeyI+7yPT61CLRTZ3X7w+lIyhup56c+tNrsJFG 60pH+9GoPZvSsiXRWX7gB+vpTjLuyZx7FRoCOoPqKVQw9T6Gui5hYUs3qaieQ56e596EL/hiSOIn /PerCxew9z71I7dh4Xjn6GniPii5RYECqowcnq2exrofDt1IANkY3ZwMd8nv9Kaf+RK8j6x/Zm06 O11SE3EoiZ0lt8MRiScxHA57sP1r7V1TVobZGNw+Bg4A/iwOwH90VXp6HVVe1vQ5+DUPDsIjFvGh jb99uVScM4BzN9Sa6mKZHAMTqyn5kYd19qGn3Oe/deaHbx/eFKB6VHyC4YoxQF/MMUYoC/mGDS7T QK/mG00mKdvId/MMUyW5jQZlkVR3Jot5MLnn+qXiySMVYEE5X2UD+tVVKfxOfbHetbefkNPyNDRt cgtX3TO20jyZAB91WPX8DXaLrNofu3cWOo57fSlJf5Eti/2rbf8AP1F+dA1W1PS7h/E1FvIL+TA6 tajrdw/mOlMOu2Q63kPqOeopW8gv5MafEunjrfRfSmnxTpw638X61XKxc3kxh8YaYOt8n0wf8KYf G+ljrfL+R/wqvZvyHfyGN4+0odbw+hO0/wCFQH4k6X/DLM3rhaXI+6H6Feb4p2S/6qCV/Qnjn3rn T8SL1S/lSx/NzGzA/ugB2GfSny9wt3JdL+KstuoW8txcAfLG6HBWMdsYP3RV8/Gq3/6BU/13CnZd Ww5X0YwfG+A9NIn9D84/wpP+F3Rf9Aab/vscfpT5V3YrPuiG5+NO5SIdKdCRt8wuPkB9ABWfpfxZ Nou2PSlkT7yDfjaT+B6miy7srkfdE0/x0lcELoiLn5XLPnAI9AK5W38QCInyYQqnlkHbPoKiSX2W y0mbdv4rcA/Z5G/2lz0x7V12n+O4ZIwJIgpHy59x7e9Zeo2uxoWl/FN/q5Bnoqnv9BXnPxH1p4tT sBaPHNcDfMloT9yJQPmcDsOPSrixL/gHfW2pyyn/AEjG7o2Ox9hWnFdOej+2T2FMix8m/GvxhF/a sw85cKEhJ/ulYh29jXmF14z0osd08skv3YUjUnOfUj/9dav9DSXkvI6Tw3cvHcIJYjC2GlUN/c2n r9TWLdSkO3LdT175Pb6VjYJoXw5d6l9pRNA1a9spn/dXbW7Eb7Efe87HGAmevFb2oeMLQXgaW4P3 v7O0aM5JkCk8r+PuPanJjUfI8y8R6msMkn2hiPmO0f3nz0A96Xwb4svNJmE6wwvcAEaXDKAfssjD 7xU91+n055pIiX/APS/gNqWn6hraN42vTdTsHvdNlum4bVkxtHJ/gUnaPUDAzXv/AO1DdxppiiSU KTNGkSZ/1jAN0X2HtWsXqi6ctUfNto21ep6fO3rj1PvX1n8G/hdFplqslx893MouZ3Ix9mtX5VEH sDk+p+gpP/gEJ/5HpFfGf7ZGo51CyVJEBEfnyDPIJuONwHrVYfcqHX0Z798BPDltBpkTwRoJZs3N 669yjsAM/wCyB+tenVlMhr/I57xv8StP0G1ebV5AFX93aQDreXj9FjH+2fbgZJ4FcN8FvAl6Vkvf FVtt1K6JuIw/W001sYCH0mABA7KAKpLT8EUv+Aj1qvnn9pqwtna2MiZkAldn/uQooP6nNKn/AJ/k aUN/vPz702cTajFswuZg7AdyHruPGeo72kzKuAzIqjqcH09qmoTfXY8kvLkr0J9m9KxJ73g4c88H 6e1QZzKeB/Dz6g9qFhkIG1gP7g9hTbIQswDHjJPc+9RyRDsfx9/apbNf+GK3lnufp7GnkerH6UGY xvYH/GnK2OoNAIkwPTnqaC/oCO4J71JQA9NoI7E+tSFiDyP/AK1UAw4P3s+n1q3b26t6+w9TQxM9 E+Gvwxl1aWQW7HEUT6peNg/uYoSOWIB7n0xX6QfDb9njwjPpdob3SUuJHhjuLm5PWWWRASefc1ol +jX4mqlb4fQZqf7CPgG4JKWEkDdcp2J+lctd/wDBOHQwSdH8SXtq3QbeMAn1Fac76ryOtV19uJz1 z+wF4ug/5AXxDuyB80ccj8bgfpVST4DfG+xz9j1m3vh0Tfg5A+gqPd6xNbxe0rHT+Cfgt8TrrLeN ptD0+H7zMSd0rAj/AJZgcDr1I+lelQfC7RrYH7b4khZumMDGfYZ715k0vslc/wDKrmDqfw6txzp2 oxTr94Be4B7fWrDodEsc2piS8uW+wwzOR/ods2Qcsf7vPfGa86rLt/hR0J916nNxaWbVAEMZQfLG 4YfN7k57026to7iP5NrEH5dpz8wHt6V206dujMJVF39ThNR125icrIrbR8rD+8a04fEylBhGTAyA fU+v0roaBrt6mNrlnpeoRbdYsY5kPG4jlR7H2rwbx3+x2Njy+FyHgUGWaP8AuKAevTqKmDt1Lkuk /Q+d73Q5oiRLC6EcMpHQ1SaAjqCPX2r0kux4k42GmP0zTNh9PrS/4YgaR6/lSY9M+tKwhd5Hr65q xDe7fvAH69qhoqLLMlwjD5AFPQAdz702FX7k/wCBrM3TLTRN/fIP3QT2NMeSVD8swPrj1pIqRPFL M3JOe3PYUsls7fe/HH+e9ZlJlK5GB8uce9Uip/xNbQMahGYz6/8A16TZ/hWhn6lhEwO+egP1r3bQ 4Bb2vQDCfe93rixH/AO7DbnlOvTknpj29Cfaubdv8+hreiZ4h6j04HI/GmuR6/8A6q3ORHv/AOzv 8ePDXhu1uh4ovpld2EtjawoS0x2dgPQ/5649C8NftU2usz7dK0uS1tx8st3dNjHHXaf734V1qS6v yMeV6/ehnjH4731ozDRpdPlwfLWRj95fUY9a8a1b9rDxkSQt5ZxjOFMa/wAI9z61HtOx0ci63MC5 /aW8aTDH9smMHhioGcH0Jrir6+mlJM8pdj88jn+Jj/jWM5eSHFdmQQE9yfTimyAk/wAvasiugnln 0p6EDH55/Gn8/MzOzsZsgZJ6cY9KlvYAUP0yD6Eeo968ye561Pb8DiCuParVsg759vpXoo8t+Zei Q4O089ifXHbNfWvwT8NMEt/KVixxLk+o9fpXVRRlUZ3Hxn09HO0y7CcKq9wT7fWuC0rwo1tGqrKz ADcWz1Y+o963NubRfeTnRpT3YHsR/UmmLpMmeWbHQD6e9Vby8xqaNfw9pMjSANGWyfMJP8IX1Ndy 75Jz07AdqzkzlqPUkRR6jFRajfxwRsz4wAWwfp6+9ZNgvI8x+G9mZmllfku2fm9Pb6CvU1J9Rnr9 BVP08hSer+4C3pz6j0PsKjPHr6n2pCFwMdc9s+tW9MJ3jA57j/PpTGzP1Jsudw7kk+n0qqzZ6c9s nv8ASnf/ACE/+ARSE9s56NjsP/rV8mfF6TN3JjBG45b0Oe34UNG1Dr6Hmx9se2KjZj/iTXE0UZrm i3iyf5GncGWZSQf6e9VM59amJU0NJ9PpVrTNMkuZFSJcsxAx/s5qiD6A1sf2baAQyBcKItn+2fQ1 4jLMWznB7n3J9K46XXU9K2iv6jVGB/nrUbgjufetWYF/RbQyOOeBy/8An2rtCyj7p+Xox9PwraK/ yMJPzOrguCCOf8+1ek/Djx2bOUFm3IfkmQ9HRvUfSuz/AIY54efoeS/Hn4VRaLqO/SIsadc5vdMI 6Q3ZHzKD9a4CID+pNcVVf5m9Dz6e4aBkBHH5+o/+tUiIQOGGOi5965GjtR2fgaR9xHy4xkD1GO/0 ruFH7xSc/wC1juT/AIV5lbc9Kn0uTOMMcEkZ+U+oqCFdl3H8pGQ0RP8AtEVhf/IuP/AOlvATGckr 1yfbB/mK+ZPEdsEncA5Gdwrty7d/eebj1tb1M9Ix3HHQ+2al2gdDkV7rPM9CcMCOMZ649KtQM4xk D/8AXW0TKTOs0W6ZSOBjqzelen+EooXBM0bDkeWv0/vH610Inl/zOs1nwXNe2zrZsuzBniQ9iqn2 714x4mimuLGEysR5bNA6+gPr+VO/+RlNfpJHmp4PyjjuD6VaQ+x9x61k2OSL0MhHQk96vxu3bg/x fh7e9AnL/I1LRmbocH73J6r71bNxn7qAH27j3oW+5Mi9YyHI+Y/T1Neh+F55omBhkdSflYjuG7fh Wnr6Myk+x7d4UlWQfOOeo9z716poUzMBu47L7CuGaKiuy8z0HRn46+1bXFSjugIkqt90g9j7EU6m ahRQAUUAFFABRQAUUAFFABRQAUUAFFABiuO8WfG/RNJyJpjdXA4+ww9UI/57SdBj8T7VpThfb5mV Sdv0PBfF37QWtankSTm0h5EdnbnAIP8Az2fqcD8PYV57NfqRgEDuV9x/jXrxjb4Ty5PuUZLxj2H0 qMRk/eYj+n0+taf8MSDXIA/dY/3j/nvTCGbrz/Fj0NL/AIYaXcng0x2+6h9cD1P0rpdI+H1zcECK 3kPrgfez6mqS7nRSh2R7P4Q/Zo6NqyCJfvFD1cf7p9a9e0rwpYWQAsLVEPRpcct9TXnYit0i/I9R K23zNGuB+Kz27QxpfOhjdir27H/j5eNcgbe+3rjn1rkp+XqjKT7njj/D7Q2+/pkSjqhHof8AGvKP FV5Lo92y6LdgAYuYiv8AyxYHjay91PNdNJvr6mVaf8r8j0Twl+3D4mhdR4jt7HUYSPKeUDa6vjgl lGOT14r6N8K/Eq21CPNw0Fu3UKTw0ZHYmpq019n0CnP1NGX4gaCgJk8RaXxlnAlUkBR2UH09q/P7 xVrUd5eTyRvxJLJdQkjkRPIcbgfVaqhDuvJGdSWq0fYzZoNgG3Hodv8AWrWnQs5wisT2X39x7V1G Ml2fqdboV08LjeXj52mQcGM59favs3wLrz3FuouJhJKgEMkn/PaLHBz7iuWudlE6WiuI2CigAooA KKACigAooAKCoP3gCOjA9wfUe9AHmsWsJ4XuRHqBCaROxOj3h4XRtQIzslHZZcdeg/76Ib8cNdki slWzKF5HVUz0aGM5OSPwrZLy82RJ/wCTPnbVvC1jeL+/iRG7zIPut/u+9ea+IPhfdQH9wBKv3ht/ i47isWv8jZS7/I4i6t2BIliK44PHpWZNbKei+6n2rN+vmXbsZ81tjPmA46hvTFVHVh91jj+tZv0G ivKUP+sA/wBk+pqpJZE/cI9T+HpSv2HYrFiPvDPcj1prhD0x6gD+HFBJUudMQ9Afc1Rl05h90A+g 9q0TCcexXKEHkYqBh83T6fStDnsSxH6irCEd/wATR6Bcc64HH0+tSMi45z9Pf3oQEjhgvTd3UCuo 8PSpEV3qPUr/AHvrVjT7nufgLxY8t1aCDMb+cjxsv8Dbx0avuPUbuZ3/AHszNglVU/3fpRF9jeSM +5lfH7sDJ4z6D/61LHKyj5GYDpgep/xq0zMcbuQf8tX+mab/AGhMPuzSfn0ouK3kH9sXPa5l/OkG sXP/AD8y+3NF/IVvIUavc/8AP1N+fekGr3Pe7mPfk0/kK3kIdWuO91Kfx/pTG1Cc/wDLxL65yafo FvJCfbpe9xL9Mmk+2v8A89ZPrk9aLjt5IYbxz/y0f35phuG/vN6H2FHN5jt5DMj0/wDr0pYen/1q kEJkUjMe/NFxDg/t7Zpd/oB9Kq/mJB5g7qPSkLj+EAepouMaZPemNL9Pai4DGn+h9vSo/O/wzSGR tP6VEbg0hkJl9ePeo3lHf8DQMiaU9vwphl9Sfr70hjNx9/8ACgOaAAnPWoyM9MikxjOe2frSFP8A EUDEUMD8pweuRV+012RP9aN46N7D/wCtSfmFv8zc0SO+u3I0t8gDzHDnG1Pdj71zXibwvqljqMVx fwyCIK1tPOBkMG/usP7v4UKJpFHaaV4vsSfmuzGDwmfQ+v0roLPVt0m1JUZeof1oMH5nx545+Gl3 4k8RXkdjJJ5MbKNSlA4gPlqcE+rV7h4N/Zi8OWqD7Tp6yv8A89WGTke59aqUu3kmdPMvsnXX/wAE NHk3OtsplVCUnb722NTgBvQV886H8D9X8QRzSaPJbxiN/srK5+/3OB7L/wDWzTS7maf83ob3ivwn pfhy2B8O6HdS6pIBp7XTAnZ5nVtwHGOccV4nd2V3Hqdos1tI4X99I+OEQDkyN9feiMe7Hr+iMfxR u+1MTCrqGZgD/C5PUD2rO8/J5GT6e1Sv+AYt9/Qe8Sv97OOo/wBk+qn2ru7zxjrN9YwjXNevr9Y2 8nT/ALQ5byogOmW9Bx9MDtWiZFu3ojZ8Fyw6ndQQZG55I7aRfSHeMn/gK196pCiACJQqgBI1H8KK O30FKaG3/mcn8RPjFpvhy3MmonzZmzDo2nr96+ugOgHomRk9vqQD8GfG5/EFzqcDeMLOeC6lVbkQ SAjyYS/ARD0C9Kqkv8kVFb/cj7o+DltHHpVqIJFdQpG9ejP5z52/8CzXby3EcYJnkSNADJNI5wI4 1HJZj2UVjIlnzrp0918QtS3vbiLw3aMYbVJCc65djHPl9vOIz1yEwCAWOPowKB90ADoqj+ED0HtV T8ipf8OFfPH7TfiDSkjAZXa7SOSXdjiKB16E+rUorsy6T1Pzu8Lzj7dBwFO8bseue5+tdfevDM9x vDPN5rLFGP8AlmuT1H0pVPP1J6s4HXUfOPLCAfKxHf6/WuYkiXtz2zULyJn5jWAU8oB2H1p6RlR+ 9z/sewpNCRWEpP3Fx3b3pjDnnOeppBciYnvnHb2oMWfut9fagGAQ+me/1pFPPI/H0oD0F809yT2+ oqRx7f8A1qQCohH3cH1HpThG56/n7U7i/wCHRKEH8Q9+O9XrZD/Cv1NA3/wD0f4aal4mikkj8CSO k88TadqhjUEzWeQSNrg9cV+qXgG1W0sLWN/MLJDHayFlI+eKMA8H3Fbxen9eZUo9vmdKssZ6EZ7D 1rm9a8c3llIRJ4ellh+8L1XGCD/se9cVaslvc1p077v0Obl/ac8PxnFzBdIem1ASTn0wO+a2T8aL IWzSxWN6if6qxjnUg3Mp/uKewP8A9avO/tCP2U+51/VH1fkYmi/FvRLnB1ye7kn5yrKdkIJ/gX2r rIrzQLr/AFf2KXsFYDoPc+lLC4uL+KS7sK1KS+H5EjeDNHIz9lhjQZZpUOAqj39q4fVfhXHrMTm2 lE9qcwWVvJn54gMfu2/2x7j2rTEU0/4b8x0KrX8ReR4dB+xLpd3O6Q+ItT0i4HzQ2yufmycfICfW uz8M/CuXwXEYtSv21B3JmhvJWyVVuOn4f5NdNGbt+8d/sM0rtX92P99eZi+JdISZwwiIH3H92HfH 0xWdDpgGfmJHRR/s/T3poaf+Qh02JmwrdsRp7+9WPE2k3MGl3BSQbcAF+n7wmpZaffvY+dPgf8Eh 431X7PqsbJZwodV8SXkfURK4ARGPQ3Dn34zwcVb/AGj/ANj+LQ7l/wDhD7eaSxUAO7Yyk7qDg4x0 +nNezSfl/fOKVrtO3dep8zXGnSxn543U/wASN/UVVMZ+nr9ayaPNku40p/8AX96btPt6/WkwGkeg oHtUCHhyOhxW7oni2K2z9p0y3uQeNz9UP+yRUSj5mkWbreLdKZf3fh2yLYIyWb5XI6ge1cyYtx+U e/HrWEY2+0+xu5+XmdN4T+Geq6ozDTvswwPMZXYAsPYH1FdRd/s3+LYuuk7uwIP3c+4FP1TN6aX2 peRkX37PniaP/j40pl7fX8SKwZ/hZqkf37B/Vsdj9KuM0E6XZoqP4GuR1tJV7gEd6gbwhP3gce+D 1qr+ZDpEJ8NXWQNj9QucdAT/AEr17U5HjtcSEjgRhfQe4+tctfobUY66nleqQSyH5AT3rKbSJT95 a6YHPVQNYyDqv+femHTnb7oPv/8AqrS5hyl62s9o+br2NWIb65j4guJIwf8AWbDjd+IqWwS/zK9w rqfkZ89ck9SfX61RkEzfeXPbPrST7sp/8EYInHVT/wDXprxMeq1V/Miw6JNvU/hUbGkW9hDIaaAf f6+hpmR1mlTgqO/HWtFhkH3B59eK4KiPUovQ4qdSCc/p3qaEE/0FdsTz5l63tZZWCwRs7khIlX1J 7AV9n+Ef7Q06OL7AqRTKu1jIP9USD0HqCa7KZzzW34mT4jXU5ZFOo3rTyM3mTzP/ABDPYdgBWqkY UfN06gelbw8yp/8AAKVzqwX7oJHXI/wqudZA/wCWR9sVV+3oVGmdR4RmL72O9SP3MZ9zjp9K3g4/ oT61hN9jCS8/JEsTexA7muT+JmtmC0IhcKz4hTPoT/D9TUsdMTwRowt4ECLzjfJn++fXPrXWMCOu Pf2NBncRnPpTfNPr9BTRQEk+me30q9pDneMkdzz2IpCM69fLHjvt3etVWbHT65H9KaG139CMOVPy g57v3UY/pXyH8UWP2qTqeSvP4Un/AME3o9Tz9iD6emKglAA5P+RXGx+pRY+lSWqc/wAqGMkuwQx/ nVPBogOYBfr/AI13/wALPDjzT7gAAvKN6OPelUegoo6b4neKg7COE7sDErepPqf9mvNmTPXH/wBe uaku56VZ7W7DC3r9PpTeT6e1anMb2hQBRk8duO2f8a3UmUjBPuPc10xOOT/yOpSRV/iz6fX2+tam m3xRh8x4+6R2J9q6bmCXb5nquq+EovF2mPBsRr2MfbdAl7rPHzhf98cfzr5LtBIMi6idJFJhuYm6 xzIeQw9jXLWR0Unq7f40apbIGR+I7CrEQG35sH+6T9a89/8ABPRR0/gZgJSJJG5+4vqCP8a9FRlB Hyj+79Of6V5tfc9GnsiW4UBjtx7D2qnO5SWFhg4OCfTdXPbv6Gi/4KOn1GB3yEYop4c/3V+ntXzn 44sEguXHPB4/2gK7Muev4nn41f5MwQo7n605Y89APQ471768/U8kmQEH5vofrWpZ2u/G8bewPqAa 0XqTJHW2mlxJKEhkD8bi/q59D7GvXNKvLW12KUSZlGL4f9NWHQkf3a6YmLl/L6Hc+FPEkrhhEsAB ysan+4R6+9fPnjm2kt3ljf5V3/aERehz3X6k0Pz9TPr73oeXTxlW4qaGU+vuKz9WV/wxfiyOh+ns Per0b+v+RQR/w5oQbh0x6Z9KvW+D/F7Fvamgku/qjVtlRcbgTz09Oa9H0GVSBtJ9fxpX7kyX/APX fCs5Uct9K9W0C86ZIPfHtXLME/8AM9B0SfPTp2rfaFTgntyPp71KOyH/AARtrPE4zbkFT3H97Pcf Wpqt+ZogopDCigAooAKKACigAooAKKACigAxXNeKvi1oejqf7Wv0MoG+LT4uXlLdMRjpu9SQKuEG /hXqZznbc8I8a/tMatqG5dNZ9PtSPLMcZ+eQHPLzjn5h6AY968tudUHVyST99j3Pua9elC23zPLl L+YovqOfuggdyPWm7Wb72cdfwrUzv/mMeYL79se9Rszn+X5+tP5+Y2ie2sGbqhPZh6A+9dDpngya Y/u4j6ZA6LSSN6dNnrPg/wDZ1uZsNdRLHH3Z+4PtXtOh/D7TbAf6JbIzfxSsByfYe9cWIrdIv1PV jG2xt0V5ogrwn9qGR1tbcxO6kSnaynGGMfr9a3ob/h+BhW2+aPm/WPiZqd1FGs8xiCAjKHmaRj1Z sfw/U1yL3bsx8yV3Y/6yRupA9z6V3LyOdr+b5CpcOD8mcdifUV7N4Q8Y63NAvkvF9kyttrLOQTDE x5IX2XPf+VJ+ZVJf5s+hrP8AZV8DoAYdHDOfna8VuZt/fcP72a+KfGWnwW17crZuxiSV7a0kPV4o 3I/WsqM31XkzTEy8l5GJ55B+8c9x6YrW06/kX/VEqejEfxH6+1dLXc5F5HWabBJNgNHkH5T/ALWf Ue9fTfwY0y7Vd0rsV2+RNu/iYMMY/wB3BrKpt+R3UI9z1uivMNgooAKKACigAooAKKACigDN1/wn Y6nC8WrQCSFxskHeNuxibsUPINfMnisavbMbTWtQkBi+bRLgn/WWUnQpns3T26HpW9N+X94ymu5w Q1k2TYvZV2fcmZ+znuPxq/q2lS3kf+gXfkyj95ZzjGHHoc/3qXqNvt6HlPinxLZwBRr9n5U5zG8k YPzle5HucVyjxW0vNlcB1PIXuPqvtXPUj2NYT7+hnTQk/ez7H296pz2fcA+mB6n1rH5mq8yhND/f A9z6mqjBl+4OOw9aX/DlkZdT95QD1A96gktMfcz68Uv+HJt5EPmH+IH3NM2qOpH4dqY7/wCTK89l n7oz7nsP/rVnTaY6nrx2/wDrVcX3JlHsMWPHXj+oqdWHYD/CtUYMklAP3SPXH+fWnSOuOTntn2Ht 70JdgLWxMDcwHYV0i2XlFSXUgDCH13GmNLuekfCu/wB+owiLO1Xj+Y95GkHQV+gt2x3H1z+Zqkv6 +43e25VdM4596bu/z71VjMQn/wDXTGz2+lAhmf8ACg5H+e9AmNL/AOH0pCT6j/61NgAb1/Kmlsf4 UCY0ue//AOuk8w0ABk/z70Z9PzoGAz60oB9DQMUqT/Sjae31oBoaUP8Aj70EGgQmaQmmAxs+tRsW /wDr0BYjOahdiO/uKaAjMvr9f8mmMD70mhjCPce1RlCe+aRSXkM2eufT8ab5XsfrRYq3ZDhbseis fwpVtG7I/wCR5+lFhqL7DlspT0ikPfAB5/Sn/wBlXB6W0x7YCn9eKLFcj7ANCuf+fS49MbTz+lB8 PXQ6WNz74U/4U0vNA4MnXwjfn7thcHuBtPSpk8B6m33NNuPcFT/hRbzQrd2jq/Avhi/tZXN5ZvEh UJG7fxyb+w9hXdSQI4ImjR1PyvGwyGU+qn1qJ+plLyZxWs/AvTJzu0t2sZQNoVOVc/7Sn39D+Fcj eaFrmktuuoJZEHMdzDkjb/00x0x+FF+5snff/hzkvBUBtbm5kudqm4l+13E/qipjGD6fh/WvZo72 IxhoHUchAPapt/kTNEsupE7liaPlGLuf4F2Hua8d+A/iW4htp0sNKLRmeRzqLHidcKMoMdGxWkX3 M7afieqyaILsf6aqPnqCPu/T6VzWpfAOwclrOJYJgDI9zGoJkVFPBJ7D8KlvsCl5nw34lcrNICSS HZV9wG9PasaKfnoM/dOfX3qpIKn/AAC5Ewfv/wDr+tdQ8AS0QFh98yYHcr7++an/AIcaOftPFmoa fOk2iXjWt1G32jTbkjIRxn76HqGGe1fVHgX/AIKHwT2jN4w8PSrfp+6t2sz+71d1B5y3KbeM8MO6 56DVL/NGKi/s+h1Pw5+EusazcDUPijGftB+fwloDD5dItsnDSRn2OQCMj7zfN08n/a4FtBfwySuv 2kwm10aM87ItxLNt9umT+FVF66LpZHVHr6WMj4Qf8FBH0XTYoNT8CXF40O+1k1BLkD7VE0rHc0Tq eRuwfmOeo64Fn4gft16h4ljNv4c0KfRrVhu1O/kkBkuo/wC7CEGAGI55JPt3l8v80r72MIp9bHSf Cf8Aa/0nQLWG21TwlcxW8YK3Gs2r7vPldyS09sQDls/3z7ADgfUWg+L9M1SFJfD+oQ3ls4321zEe GweQR2KHgg4IPWpnFfZfqZ37/Io+NPiTpug2sk+tykRoP3MCkbr26YcJbgkfNMff3PANfGHxU8Se IdVsmvPEGmXFnHKhW1tznYF3HAhZgM8cZxzilFf/ACKOqlH/ACR8o+D0BvbfOfvgge2O5qzqXiyW 1vbjCARl2RgO+T61Mn3It2M/XNatpVzG2R9456hvp9a4yUlj8vHc/T3rNImT/wAgmuDxuA9Qfaie /dxg9Ox9BQyCruI6H6Y71PDKp+916DNJoF/wBrsueTVdmx90nHb/AOvQVfsCSMDyT7+9SNLnoAO+ RSaC46FNx+bjvUrMp7+31NDQkNW49APap0V/XnqMUWC5PHCRzJ9fqa2dOQMPkUH+Ie2KH5eg/mfX P7IfhDU7O7aew0qO6gKfZNWkI/49onOco56FgB61932ut29wM2j+YOhI7EVo7f5lyj2fkzjNc8Sw rMVubmTPWO3tQWbK9iqf3QaqmPxBMpOk6JMyf8u/22QDeAP+eZyevtXi1ot/CvI9OC/naQyLwX4g mTfrt5pdsB+8khSPlEX/AGz/AHhTdc8Ja3rGwsjWtsozYRoRlwV6lT6j2+lckaWjvFX2NfaK+knp +JlSfBZnRw0mo+cR5doAwAikHduP4ataH+zvp8UY/tnULtZwMTyGXjcMdDmvNjhLPb1N5Yjsl5Gh F4P8Mw8Xfi6SWL/Vmykl4c/7ufXFb+lanolvkWGrIoPzKCOEH+wPYV6tCP8ALPyOKq5PenbqVtV+ G9hqalo9R8y4GZbO9jODFMB3CnoDXm7/AA01HW5vJ1zxBPYyREvMEALXkY7xc9BVSm09GtfzLpSX 247ar0MH4m+Ddb0meJPCVtcaxlDPLDKP9S0bD70ij+IEdh69q4pviddWRx4j8K3Fq5+VwP4B+NdF Kp/O9djf2N1em/7zQ9fixoEswFjZzqcFSpHLsOp4/u/hXPePvG8z2kgWaRYiQpt8n5mHfb7V1OJk ov7Rmfs1ftI+APBGn6hN4p1KU6rNcAQaRACz31hbwgRrGgGBtdpCScDB6kjFW9S+L2ma8rSXniu2 YuTc3Wmsc/Z2c9HHsK9VJpaa7JHly3d11seZ6/8ABTw3qI3WGs20cx5CAj5xj0J9a8O8QfDW7sy3 yGRAfLkkXore5FYxb6ryE2mcw9qy9RUfk+uf8as5f+GGGL0/CmlD/nvU2BjdmKMkVLGSxXLL3x6i u++G1x4AlmC/Eq61K0iPyR3cGdqZ/wCehHp9P58EV3HzP7PyPq3Qv2PfhfdqJPC3jS/h4BWeB1OC DnkH0Pt9a6pPgHcRDGmfGDU2HSOOeNCEGO30rot3jEpVv5oeTCf4JeJcjHxD027AG0QyxY/Mqe9V z8AvEbnLSeHLnvE4OMp+I7VHIuqNvartIo3f7PGqv/rfD2mMOm+OUZZvx9az7r9mC7k/5gWz2Rge PrUOmvs3NlW/vLsYl9+yhdqCbbSZ9/WNQPvOPeuJ8S/s/wDi/wArEfhy6kbIYKoP3B/hWMqPmbwq x6yXkUoP2YtVCL9r0+VZMfvoyD8r+59qoXP7Od6n3rSQHooK9APpWjh5kxt3Rj3HwLvE+/bMB3JB /nWdL8I5lHzK2PUjpUuAlExrj4b3y/6pEYdQT3FUR4A1MH5rdfU4Pp61N+5Hs+z9ChLpcjSbVjYv /GoHTFWn8KXC/wCsgdR0B9TQombiMPhmT/nmfQj1HuKryeGz/dI7EH3pNdw5SnJ4XfPBx6j/AOtT G8OP6nPT/Jqr+RPKRv4fcev196iOkSD+EfShEOH+Zrac+wfvDj0HrVx9atk++7buhUDtXPOHY6qc +6ObuEDsdqn1+lavh7wXqWpSCPRLV55TwAv8APdz7V1xRyS/4J9UfDb9myw0MiTV3t72+xuDdVtn I/hB7ivQJrIschx6nPf8K64nOjkPFsoWSMNE/wDsSegz6VqA4A3oD6+xrWJU1sVprGGT76D3PoB6 fWoTpEH8KY9D6HHY1TJU2dZp9msEQCjr++Y+pI9asQSD/Ae9c0jK/csqAepI+nrXmHxBvDdXMMUR 3KP3049lb/69H/Dlw/4J6Bp8ARRgEcbSPQgf1q2WOOc//XFT/wAOZr/gjy/94fU0hz2I/wAc015s p/8ABGknsAKu6UVLfvMkdW/+timJ+ZmXkoLHt7f41XAH8OfQj3NNBPyGuvBwSTjgepx3r5M+LSRC 5byskcsSez+1S/8AgnRR629Dzd+PX60ttpsk7BYVyTwCf61xg35mq/wynT/XXNsh6lSw6e1RjwTs 5S9gY9cA/dPufaq/4YtMguPCbt1uYGPTKn72aq/8IlL/ABPGB0Y56fhSRLJ5PDdqOlxnsx9CfSvX vCWiQ6ZakrsJIM8rE9V9vrWOI2N6EddTyjVtYe4ctKcknd9ATVIv6/n71NjoqvXT0RC7/wD1/pSZ x1z9KpGLZdj8TLGPljb0HuKnTxoB1jOf5V0xZySj/meogn2PpnsfapoJGB5OPX3rpMUux3vgjxm9 nKpSZuCCV9s+vvXMftD/AA2gsrlLvR4Nlpc4Fwiji31BRznH9+s6qLUtn/26zyrzDgdPf3FXYW45 x/sn1rypf8A9a5t+GZiky5OD0b6Y7fSvRjLsI3HJzj/gTf4159Zano0tlc071cNyoGfuD0BFZetK qhCyFsMrjH8IDDp9K5bmlzuJBGfXB5Uj0Yd/rXz18T9PKXPbnIB9RXRl+5wY1HGlD2PsDTlYj+df RxPHaJEkIPzDPfHvWhaXDn+JvRQP4c+gql/wDP0O18OmMEm4bBA/dn1f3/CvUvCdjE+WlAOcLtA/ hA9K6Y+vkZ+p6HapBAB9ntCrDJaUds+orxX4xaF5M8bKfvqckd+e49qb8/Qx6627Hi98uH5P/wBY 0RMO3Pv6VijWxft29h6cVoxxnsAO+Kf/AAxCLsUh74HfHuKtxyH+FsfxY9M1USZP/gGvaXHTJ9z7 j2r0bw3MMDChvb0FSwseq6FckD5Rz0IPbNeo+Hrkn+E/T61ySfcyiem6HCwx2HpXTPKqj5iAOrE9 h70ondAqWWkW0WWtFCBv30wB4kYjrj3FXgQelat9/Q2/4YKKkYUUAFFABRQAUUAFFABRQAVjeIvi Bo+lJu13UYrcHi3i6tcOAeIox6gfT1qoxb+FETklueD+MP2stTusr4aRtOg5UXGQZJ0BPIcA43jp g7h3Pp5Jc6zJKSZpDI5PmPK/VmP95q9enC23zPLnJvf5FCS9P8Rb1bHeoTIW65+la27Mz9Qyi9ev 90f1qI3Dk9WA9B3H1qvUbXYmjtCegY/X1rUsvD8j/djJ/u/WpS/yNox7Hp3hD4DXt4Rug2L1d26A e5r3Hw78H9LsAC0CTSdyRwpHoPrXLXq9Is9SnC2/yOtAA6AD0A7UV5YBRQAV4V+1M6LYwFzz5wWM f3sxN/OtqO5hX2+4+RLmfP3Oh+ZR6iqcUYZhuOB/GPb3+tek/M4lJmleXVucCBAoHypjuB6mt7wR 4gubd3VAzRuNskeePNAPb2qIrv6m0PL0Ptf4R6vPcabbm8YM6r9kZh3WHgf98rgV8G+K5i11OWd2 zJJMjHvmQ1nTjvbuv1N8VH8rfkYyKSe47mtzSgGIDEf7J9f/ANVbXOOP/Dn0X8JfgkdQG+6bZAMe dMOrt6Rj3/Svo/T9FtrVAtjCsaDgAd8eprjry6L5nrbLT1ZaorkICigAooAKKACigAooAKKACvIf j/4UjuLeKSLZHPGxjhuMcmGVfu7v9pgD3q4f8AiZ81axYQakhF3EPOHzSRt/y02+n0FYvhbxvZ27 iK4mKr/q4d/8Djtk1o129SIvujivjlqqPdokcSrsTc7j/lq7t6H0FeUJdzRkG3kZO5A7mlIEjTt/ HTN/x/x5HaQd/r9a0luYZf8Aj2cHufdR6A+tctSPb1OqE+/oQTRBhyoH90+oqnLbeg49Kw+ZqVZI 1H8Iz6+tVyrjpx3z6in6/IfoUL++EY+ZOeoPqKZa3IlHy5z1IqktNzK+pMVPcY7Een1qNoh6D3+v /wBeoNWQS2in7ygHqCPT6VAbIjpz3rSL7mc12QzI7/XPpSuMEZU+mK2uYMkkjLMMEgdFHvXSXs+1 Mvk4whUfxZHYVVvMbPSv2eNPmvtUjWCJd29Zooh3VCM9fpX6P3HhC8ZiVERHUHPY/wCFU/M3ey+8 i/4Qy9/uxf8AfVJ/whF53EOPrRzLzM/mKPA933MXuc0N4DuT0ki/OjmXmAL8Pp+88Q+lO/4V5Mf+ XmIe9F0Da7MB8Ope91H7+9IfhzL/AM/Ufv70cyC67MP+FcS/8/cdJ/wrWTveJ7cUcwXXZi/8K1fv er65Hf8ASgfDNu96v0x0ocguuzFHwz9b78h1p4+GifxXz/gBRfsO67Md/wAKzg73835CpV+HVsOt 1KffA5pc3khXXRMePh9af89pf0pf+EAs+8k3r2p83khc3kKPAFl/E8x/L/Ck/wCFfWH96f8AMf4U c3kgv5IP+Fd6d6Teh5H+FKvw904fwzfTP9KObyQc3khw+H2l94HPsT1+tOHgLSu9mD9TRzDU32Q7 /hBtK/6B8f60v/CDaR/0DIf15qbvuPnfZCHwJo566VAfrmlHgfSB93Srcds47Urvux+0fZDh4L0k dNLt/binDwjpY6aXbflRd/zMnnZIvhrTh93TbUf8BFPGh2Q6afa/98D/AAp3f8zFzPux40q1HSyt /wDvkf4U4WMA6W0I+iii77iu/wCZjxAg+7Gg+gpw46YpD5n/ADMXJoyaVhX82GTSZosIKKYBR/8A qI9RQBz2q/DDSLrJNqsEh6zRDqf9pK4rW/AHiCyX/iTxf2hH2CHDKgz1Q/0zVJ9zeMr/ABv0Z55q PxGvpEmF41zazFTBtZcFRtPqK6j4RPZ2+l2627oXA/0pc8mUnksx/vnPei3/AABzh/kek6fdhs44 I4x6fWtNL9QDuUnggAdzjsB60XMGj4Gk/Zq8d6leShNNFkm9jDPJg7o93BUj1HrzXbxf8E89TKn7 Z4kYufmcIB8re3HatnJX2OufL9orap+w9rMKL/ZV7CSv+s39Zm9z71x/ifwNqukQwx63AI5ctKoJ yHBbqD7ipfkSrfZPOrbT7i7lIX5YxxLL3x/sfSvsj4HfskxWqpP4ssQCMTaDpEo/1TDpJeqe5PIB 6dW56K//AACErb/L1Po3NfCX7YALa5BvmlIFszJH2jYt/D/vGnSW/pcmn1v2ufNyzTSQgZVQW/ev 6Hd2/wB6us0O3aJwok3/AC7jIe5+ntXO3qLp+B0sk+BgAHPUn+Jf9r616T8HvjVeeFkllkiu7zTi wiv9NRjgSEfetAeAw/UcHsRvF/5GUl2+R2Ph3UtT+Kmo+ZqFm+n+GrRgradI3z6lfsMgMF7yjknP yr8o5Oa6b9s1IodEzEqoqstvDCnAVGxwij+4BVx3VjrovVfifnf4Hf8A0+3x/fyQe6haz/FspN1P u6mRjj6n+grGW5lfcwTLnhhgdcVAyqOlQZkBXPU0wj60E+pG4pqqe/1oEhGPrSYJ6VPqWIRjqfpT kHp/+umJIeoI/lTgPT6ketFxirGP89qmQkfxH/CkFv8AMma8ZupIxwAKtRa7JboTGoJ4AB7gn1q0 gS/yP2J+D/w10nSdMtl0qySPdDHdag/Obm5miBJkJ/2j+XFdG3g2MKy2c8lsGJa4eLqFb/nm3apr w3s/I0hPui5pXhqwslxptokQ+9K/Vpn9ZZDySfc1dYMemfaosvImUn1ZgapoEtw3/EybzYMhxbIc byo/5ajvg1PNpkzD/Rb66gH3UQHhVHsfSuZpdTpT7IrL4NlHMt3dXL9drPjJ/wBo1yviDwr4rnYD S9P061t+k8zuWZhn+FB/s/rXBWX8lzppTX2x3hz4KWFoS99o51C7Y+dLc3B4SQD/AJZRnpt7da6x 7Fjw9pbRDp0HA9q7aCikZVZt7P0Q210iytcyNeJCqgyXMpbCrGP7+fQV594n1mdwuoeGJiEU/ZVR hxqOmlsEsp7Ejj9KyxMVb3P8RdB6+/1/dfedrb+J4LhkM6RwTFQ6zI2QyOOgP4/41p6n4d0q8x/b ulWlx/CkkgB+U/3W964aK6tf3glJr4JPsjl7n9nTwoG3WGkrZP8AeEsPv6A1yXiH9jbRL5WC6vcR bvvMwHy/QH/CvdpvyBYh/bR5Lq3/AASm0+QH7F4qYk/PlkGVPsRXD6h/wSd1RM/Ydfhkz/rCOrZ9 enWu9VfLyK54PeLRyV3/AMEx/GEA/wBFuHYDlCr8r9RWpN+zD4vsdNW2tvDMl5cGU6hqd43JWHH3 Uc/3h7Y9c8VXMuvqR7KOnLJd2ee6l+xv4qk5j8PXkLdTGV9PTFeXeIPhRrOnEjUtMnjI+UnB5/8A 1U1bo0ZSw/8AK0+5zMlkR/CfT8agaAjr9M+9Ytf5nntEbRmmtn/GoFcQj/8AX70Ej+LkdCPUUmNG 14d+IOs6SwOh6nNGnVrUn5W57KfWvbvDn7Yl3MAt/F5cv8bk8SH2Iq+buxJdvmeg23xp1CQAxIz5 5AU/w49a1rb46XwHzwzk9zx29RS5jq5fNdzQi+P10OqXGOo4PFWl/aSu06Ld+vGeB9PatFLzJ9n2 L9v+0pOPvSTHuGwePxq/b/tTP3vAB0ZT3H0pXXVIXsn0Hp+0lAT888JHQfU+9WV+P9i331tSf7rA c49B7U7rqhezfS49PjLpb/63T9Pk7klR0NYvjH4qeGRbN9m0Ox87oXx91B6fWhyXfzYQi+rfmeUp 4y0eQZk0yEZ6A5zj3+lQSavoK8GyQk8gZ+6PYD0rOSXR+Zpd9DtfCPwZ+Ht0gluXuUuDkNyPlGew x/ntXRz/ALPPgl/uatcJ3A4PX3rVRXRLsQq0vtJdihL+yd4Ub/VeJH9CHA6/TPaqMv7F+kvn7H4g tz2XdgZPvT5e6Rar94PsUJP2H0f/AFWr2rnthup9zWe/7D12B8s1rIOjMGGc+4NQ4+TD2y6oozfs X6mufLsIm9DuHzD2rPn/AGQ9Sj+9pUmep2gcj6inyF+0XdGTdfsy3SZLaTKg6NuXp+VZM3wBRf8A mGuT13FT09jWbp+ZTa+yy3of7N8d0+Li18mPrLM46D2HvXt3hfwBoukrt0HToYf4Zp9o3Sn3eqhF 9zCr5fM1LpEHTPqfc/SoYSz4wxPbB7GulmP/AA5x/jHULU3CeZdIcYE5B+6/0H92rMmoo3/HlPG+ eQMjt6c00E+n3MrtdXeTiFDjh+eje4FPtri6kYAwR8kKeeqH0+lK/r2NLR7+Z2c8wJA5AH7tR7LT onUfyH0rE42ifzMdSP7x9wK8o0Zvtt/I5yVU+VHnojDHT6UD6P7j1GEkdOfT/wCvUrN6jryPcVK8 xoXBI+bPtSKvqSfT61YP/gCMvqSD/npV3TGAJ+nIHY1PqJoy7jGT09fqDUKj+8B6D3FNf8AGNk+6 doHQgY9SO30r5F+KR/0k4Oerbj3Gals3o9bHAMP/AK1QvdOn3GIP8JHauUo0NMikuP8AW3xU9AWP T8an1PwpexciQyL03qeoNa+hKfl5og07w/dz5xKUA+8zHqfauv03wDpipnU9WlZycLFEO3f9Khmt uy8mZJ8JwTXarYvK8IO9mI5aIH+Ku08Z6sIoQscezI8hAeyqfSuWu9vvOvDrt2ueUsM9fw/Co3P+ NWQ2RPjt+NTwBP8Alp9KpGMmWAbTvGvvTWhsj1A9Rj0+tbf8Oc56wpA6MQew9vep43x3JHQg9xXR 6mJo2F7tPXHYY7V6lo0dv4gsZbTWXXLDzdKkbpBdIDjB/wBojtRJefmU1pp6o+XrjTrm2Zo9SiMc 8bG1uoyOjIff+9Vy2kGOckdQPevLqo9OEjR0W4Kyg478D1z6n2r06bTRdoAt48XIdrhOqlT2z64r zq+6t6HfS2Ne9iXC7Du4259Qv+NZetofKy7bQCpUjsA3b6Vx+r8jof8AwTsYFLKuJAcjPPYH/wCt XiHxfsts6HoOU47n6/XNaYF6nLjdvzPPC/r/AJPvViKFWBywGOfqfavpl5niMSM+v/Afer9jfGI8 Kueq57VoiGzUstddfvNtB64/wrtvC3jmeBgPtbbeuPcf4VrH0Jt39T3Dw94sS/IywA6St6sB3PvX HfGbRGmgDW8ClkOC/wDdQ/4itTmqx/8AkmfOF+nIx9R9KjjPv+FYmjZfgPqB7GtNHPr7kelBL8i1 EQOv6epq8hxjgemasH6eZo2zEdM46k/4Cu28NajICPLJ9TjsRWTYn/wx674euXYjzhj+In3Neq6J qBB/dHjoM9xXJP8A4Bij0/RNSLEbjxXU3dqs0bBicMCmR2yKcWdkDnPD2j6vaxtHqt4lzAuFsLk/ eER7SH/ZPTrXVIABxn0GfT3reb7ep0JjqKzGFFABRQAUUAFFABRQAVS1XxHYWKF9XvobWIcGWQ9W x0UdyR6AmqiuyJlLv6nh3jP9sZuV8F2wXqP7SuF5dR/zwgPTJ9c+4FeH6l4surly2o3k9xKcvJLK SSWY9iff8B2r1qVK3r1PLnO+/ojKkvCepHtUYkJ+nb/69dFjL/hyQlV++TnstQ+e38I+p9M0IT8y RbQnGCc9Sf8APpWla6K79EJ9Pr9Kdu5tGH+R2/h34P6jdkeTaMwPJHp9B7/WvcfCf7PdnagHVVDu PuwLjAb/AGmx2rlr1LfCerRppfEvQ9IhtY4wBBEiKPlRF7AU+vJb7lN9wopCD86r3+r2tqhbULmO CMfflc9CfT600uy8iXLuzzfVf2lASV8IeFr/AFhukM/KK5P93Kk8fQZrxf43+JvFl7bwt4t0dtPi 3n7LAiEKk0gON8jdSF/+sK7oU0t2rnPVTt72nWJ4HNCwJz06A/7VV0Qg/MTnoa6G+5zpdvU0bXSf Nb92gI9B6n/GvfPhf+zbdagd13EYLcfLJcN/y09ofqOvp/Ib6v0R20IdX6s+lLlbTR7NvsmyCGGM /ZhxhBGhxge7V+et9Ebh3ZGG0kvCx7r/APXrlovcVV3f/kxmmDHAOO2fQ1csTjG1sHqT6mulPt8z msfavwF8RwTWexdvmKd7n/npEQOfwIr1avPrbv7z0WworEkKKACigAooAKKACigAooAK87+NlpG2 nsZlYhGS4JX+EA+g9zVw8vQmXn6nyrfmOfDWHyzD+9n96q+lc/q+g6ZeDeyrbXK8XESj/Wt6g/5/ KtkyH/wUeReOtTa5uSSXYhREjP8A88wD/EfSuRMY9SexJ7mok/8AISZTmjU/zP0quLmSIkwSuD0V c9//AK9Q0XbzNW18W9rwN/veh+tacd5HJ/qSrdyQegA9K55R7G0ZeYktujdQD6/SqslsV6DcPb0/ +tWfqarzM+60tH+8qv2APp7/AFqKKyVeBGsfuPalf/gBbyHvEw6rntkd6Nyfx5Ht6UmV6+pG1kB0 JI7H0qIQD+8fUA96q5KXZjHtEP3wPb60ySwkP3CD7e3/ANarT7kuPYbbhgwBBzn5vYf/AF66DVLx I0/1W5yQi/7I961TMWew/sfuf7cgyRkiRSD3CxHp9MV+mVbTN57L5hRWRgFFABRQAUUAFFABRQAZ ooAKKACigAooAKM0AGRRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFAGRrfgPSNRGNY0yCfgo spHzIGH8Lj0rzyf9naewJbwpfsyf6z7BJgZGeiN71cZdzohU6T+RftNcuYMi9tZIZOkysOoH92pI /HMUrgRXAjxzID/E2PWk12IcS6L/AB/rFGSeq+57n3q/POIBmTp2H94iiLIaK9hr9leEhVGRxISO /sa8E/aU0KKfU9MitkLmV1tJIR/FFJOM9PUfStoblU/Psesr8B/CmlXSTQ6HBlPmtYl6LMR94Ie8 fb8xXotj4qsLni2u0Ld4m4I/A1m0yJT7lye7iiUm5niiQfNNLIQBGv8Atsa/Pj9pP4hafqmuM2g3 8d3BFB9je6j5SW6Uc+TJ38v1HGehqodbrpY0h1sunKeC20ZVA9zKyqoMxiGSCf8A64r3my+Deix6 JFqNx4yhkvJ9kdnpEJUiJJmYbDznegUk8cYIx3rnt29GNP8AmXkcW9254iyWP7uFfV2Ndb8T9Ti0 23trWycAhf7R1sg8tcnpvx+NaevqzO5mfBT9re/8FTv9qtmvtGmYTa3YIfms7rGPNsye+0AEdGHo QCPWP24Pi1pl5plouga5a3UUzDU0EDA77YgbWcA98n9a15uvyY6L1182j4t8AyA38GcdTk/8ANZH iFiZ5cuG+diCe65rnbGjHcntj6+1Q4B7/Qe9BDGZ9vr7VHu/xFAvUQj1/wD1UwD0qQGsv+TSA/59 DQAbR7//AFqeh9vegY4ew+o9Keqj0/8A10AKcd//ANZp4AoGPCZp9zAWXhR2Ye+1h1+oqk/8wTP1 4+E37Rvg6/022a18TWA2xrZ3UZbmGe3VQQ/uvH584PFd7B8SPDsw/ceJNMYdj5qjj8TVSfZihCX8 j7jX8QaOx48VWo7FFmX9cGoZfEmgD/XeI7b/AGgs3T8FNcrprrc6VGX/AD7ZFFc+F5P9Xq8DHuxl PJPqSe9WVs9Cb/V6rF6ECbp+GaPZrzKbl/KMm0nTiP3fiN4h0BEw4/Emuev2srX/AFnxBEa9g0qk gfQZrnnh10ubQm/+fZy+ofFaAIf7C8W32oTdIYY0J8x8dmA7iqugXnxAvh/pfhzyFPP2ickZU+q+ 9ebVw0v+Xcztjy2/eWXY3tY+GOt3qbNTg06eHGJLUOQsrD++D7iuW1P4c6tFGY2sd9v0+yJNkYXo AhPTiiphZ/ZqSfRk06sfL+ZGVbajrtmR9n0C8dR8iLkHCgd8+ldJa/GLxeIysHga4nByodv+WSkf w0qFKa0kvQ0qQi9XNGjpvx11WFgl14J1uY4A2cfu5PRZPaugsPjGks/l6toN3pLkeZbfaSP9IYnp GB/d/wD1V69BO+qZ59Wl2mu51yTKfu4I7GnZ9q77HABf1yewPpUbwqf4R9PWixSfmUZdLjP8A9x/ 9auV8U/A/wAPawpXWNMiJPAnA5BI7kUW7G0Kj6M+Q/ix/wAE5ru13P4TXz4/viIenuo9K+VNc8A6 jYsV1GzkhYcMGHUj0P8A9euqLTNa1NPWmvJo5+S0I6g+1QmL1z6VjJHmEbR//r96aF9qiwCBce1S Bh6/T6/Wiw0dPoHxQ1CyYeZdzyQ/8toh12/7J9q+mvh4fDOuqP7M8RTCXGLm2YDcjem0+lCXkiue 36nobfABB93U7g9uQOmPT2qJ/gHcceTqh9CGUc/l6fWlfukdin5EbfA3UecX1uw6MWX7v/6q5nxF 4YttLXOqaxpi54iiB+YtjsnvWM5/5GyX8qZyB8U2bj/Q9HvLj+LzI1++fYGoDr0jn5PBupMf4SYz z9T/APXrKMpdTaNPvNFhbe/c/uvBerAnoNp+b6mnv4f1BxhvBup46sGHTj+7Sal5j5F1nHzKo8Av j/StC1VO4AUnC/T6e9U08Bxk/PYa1GPuvlOh+pHYVzNz6JFci/nRuWmlQW67U1HVIB0UFfuH2P8A tGtvT9EQn5/Fd6g/hVk+6Pz7GuaWLmt4o09hHsbdv4TvHx9k8Twtn73mEDBz9avJ4M8Tp/x76pp0 w6KBIPmWtqeYP7cWc8sOvMpXN34vt/vWbP2yp9P9pfWqx+JviKL/AFthfA9WIBO4D0avUhi11OaW GX2WiL/hofU4v9fFfJ2k3g/L+frViP8AaZmU/wCuk9w2flx7GuuNVd0YTwz6Ikk/ahkcfJcRqv8A GD6e2ans/wBpGzwftDRM3SNWA5H+7VtrsjB0X0v5kVh8a9LmZjfyRoOWijH8f+6tXrH4l6CwJe7R W/giU9z7/WiK7MUovs+xZfxdpLKNl9GS3BTP+rX/AGq5Pxj4gjP7vSbuRmIzcyoeVUdlI9KqRdPf U83/AOFdW5z5ktyx/id2JIB9z60i/D6Jf9VqF9F/cKN1z61xuT6M6/kgXwtdxf8AHvrd6p9G5598 11vw90TUPPJu9VkljVSzKR96UY71rGb627mVZabeR6Stxk+nrmrEcvPPTsf/AK9UeavP0KfiDWBb W8jB8EKVjx6kdh9K5D4caIwj3EHc5+0yn+8SO/1oXoVJafOx6PHCw/w9qVlPrk9BTsH9IQSH+LPo BS7D2474NOw79hrv9Pr61b0wkA5I/wB41IGPK+W6n29qiLHufwp3E2RyzMFO3jgkEfwnHpXyN8S5 Sbg7idw7f7JP9Kho3odThWfPU4/w+tPtIrck/a3I/uketczKX/ALosbD/ljO6nqW9T7Vah1ySPhZ g6dMH0+nvRGXc6JQGf2sP+WbcdWUd6hl8UyRkGMYHXaO/wBaqRMH0fqdr4AtXn3SSqEz+6iY91as bxzrnnyYVlZF/dj2Yen1NcUtzpovR29Dk93rn0/GomwOvPt6VqkYsjDf4kVGyk9Dj2q0ZyGCNvf0 zQF9WNaIxPa0ZR3z/UVKp/vf/qNddjnZPDIAe47EeldN4c8SSWkitDMwIIcH0APai3+RcX/mWf2h fAUE6xX2hwDynAt/EioP9VKOAXH+1XjdrGccEH0x6CvNrr/I7MO/w0RasmCuOnUFgO4zXp1qwKEw kAghWQ/3vf615Vdnr0Xpt5m4WLKhx2+b/aOfWq+qRh4m3Dnrt9CD/Q1xM1kdNpc2+KMnH3QSf8fp XkfxmgfKEbduSuR/y0yfT61eD+L8jDGrR29TykgdwKnjb1PHcDvX1NzwfUesfufX6CplQf4mqTJL MSEdD7n2x61p2dyyn7wHc/5961X/AABHs3wy8QNKCuUXpJHz95h/iK9Vm8FJqFtMl66xNtL2+49H VT2PrV3Mqy7+p8XanGyEhkwQTCw90JH61WjPv7HNJr/IlP8AzLkD+mPf2rTjAHQZ/oPapl5DS7+h cgXPb3GavJjuD6AHsR600xNeZet5ye4HqfWux8PhgR83/wBb60pEf8Oj2Lw0sDBTJdhTjJHsPQe9 em+H5genI9a4pGaPSdFugMYHsK720fcKUWdlPyOA1nxJf6jbj+w4Sk4cLPHLkBWik6HGDwBXe6fc ySIpuIvLcjMqf3WFdczWn5+qLNFYlhRQAUUAFFABRQAVFc30EClry4igiUeZcTyEARRr3dz6U0u3 oJvueNeOP2wdPtdyeEIkvZsYGoyf6uGUg/cjOCfLP+6PQmvn/wAQ/ETVdTcvrmozXLn5URj8sSgn iOEcDk9h/KvWo0rb7/keZVnf9DBkvCepA7ZHp7Uzzcj5ST65rqf/AATH1AqB/rMfSk88j/VL75Pf 8aPmJrzJEjJ++T/h+FXoNJZiNsZb+8fQfSixqo/5o6/Qfhne3RHl2shzxGAPvE+gxXtvhL9m6KLD as20doB1I/2jjvWdaqlt6Hp0KfWa9D1Wx0a1tlxY2yRL6L3x6n2qzXiSl3NG+4UVIgpRQB5Lo+m/ ENpGW91OXZuK/aJAAFj3dY8DpjpXWxfCOxlYN4hmm1OYfdMx+VMj+FBXXKaX8NLuJRXX1OltdMto BiytYYV+6FjUDgeuPSvFv2pNZiTT4o3I3STK6D/pnboxOB7Eis6Sbau/7xnVff0PkWeIdunX8apP AR0GfUeldtzlsdB4Ku4TOv2xiAD8wHdSPWv0I0O3gSCIWaIsexTAq9NhQdB71lidjupPT8zyn9pX 4gNYacI7ckTXDfY0YEfu7aEBmPJ9do4B618ci4CgAfgKKS0/8mOVvV/+AorSufT606Cbb1Jz/CP/ AK9bozfr5H0N8AvHQhkAY4BG4r6r3H5V9VJKrAFDkH5lPqDXFXR3p/5DqK5gCigAooAKKACigAoo AKKACsTxjoQvLSZO5QtH/wBdI+RgfUCmn/mTLyPh/WZLpBnylVxyig/eb61kWd+LzP2tYYbgffXI xMo9M+lbyRCfc8d8Vyn7VLuTjOzYP4Pb8KwZAT0AH+f6VMl29QRRkg5GfqD/AImqbt7CoGyCTB6g +xqKO8li/wBU7Dtt9R70rdx37GrbeKV/5ehjtuFa0d5FJzEQ3qPXHqK55RN4y7/Ije3B9QemR6VD JbgdVB7Z9Cayb7Gq8iEKR0Jbtz6n3oNup6Lz60hjPnXrgj09qBGremfT2o/4cdiN7X0HP9KYC6n5 WIPXHofarM7diWHZkFhz03etWdRaST/VqG/ik/8ArVcX3FKJ7j+xzAf7eh88Bf3c0kY9xCev41+l FdMvIqotF8woqDnCigAooAKKACk2n1oATYaNh9aAF2jvQOaAFooAKKACigAoxQA0rjpShxQAtFAB RQAUUAFFABRQAUUAFFABRQAUUAFFABmjIoATePWk8we/rQBHPZQTDFzAkg6fMOg9jXz78Rtb0nQr kpe3YsPMzcaUz9GXIziT2Y+tNI1g/wDMk0b4kSED/SY5McqqkHcq9+PWtmf4pwyyBtWZvKH7tVXs CPQehpf0gS7HWLr2lrGP7IiEjsPMib2/2z7Cvmb4weOb+/17TYvDbpa3sQ+0XF0cH7JtYckMD95f bjrmqUv8xpd/Q93tLC83H+1tXlvpes8x6Mc/wKPQVtr4ft352qD1U+jD0Nap9jnKeseCrW7TZrlk byA5SSCQn5kYY5I9RXyV8Wfgnc2tzMfD/hi4SxALw+SpIigUZO9uevJ/+tQ0+/mdVHzt3R5DY/Fa W1triC3tbMW05U6hM65fy7XOBGT0AJPbnvngjI0mS1Rs2qlYhzbxMeBI/dV9WNYRT/zCXmvU9C8J WEjTq17BLHCgN88kykLIIwcYLYzkg9K4zxP4xn1CZ5JX5Y74gP8AlnD2AH0q2ZST+0jmL68J/wBZ kAfKy/3sev0pfEt0n2O2VAQSDcEfVuw+lYpvv6jRQ+HUmNQhwq/xnn18s/yrF1okzS/Jj52JHod1 N/8ABEmZZB70wDPQD/8AVSJGBwOoyaiYE9OKbExDj/GmoP8A9VKwIYwx1x9fejaPSgYnB/nTogf/ AK9ILD1JqRW+lMPmKQO9OA/H1NJASbamEZwcHsc57YFXf/IGz9Pf2NfCenf8I1aMPD+mrI5knvJy oJvJPtDjdKxHUqAOvFe03Pws0Kc5n8P6ZnrkRjr7YolHs33No1X3ZX/4Uh4XP3/D9me5wo605Pgf 4UXp4dtPyqXHzZarvoRt8BfCZ66FFzxwTx9OaqH9m7waeuhj3G9uv0zSUe1x/WZdoij9nHwgOmkN jpt3tz+Gantf2f8AwdDny/DlsxPJaTnBH93NVYX1iXaJ0Nl4btLUY061gt1Hyqsaj5VHocVNJZSN 1u5R6gf4U7eSMnN9WVm0IH707t9f/rVF/wAIvF3VSemTVMfMKuhbf9X5Y9OKmFvcL9yUClbyBy73 EaK67TgH+8B61l3ngW1uJFfUA08q/wDHs7f8sww/h+oprySBS7ehpxWoQfKDipcegpmYD3FKfpQA xyo64FN2KewPvQAnljuqkd1PevM/iL+yn4a8RKfPs47efqk6D7ze496afY6KNS35M+Hvi1+wtruh szWVu89t95XXnEY+npXz3faLNCcSxMh7qfX/AOtXS3fb5lYil1p7dfIzzB/s1CyHt+H4VgcA0of6 GmhSPSpAcCe4FT2GqXVq4fSrya0mHzQ3EJwVYepHpS+YXPp/4Sf8FC2hZIvihbs0X+rGuwjO0ADm 4jHrX0Jovx5t/ET+X8JdM+2IOL/xDegqloMH/VRnklh0/PFRWX8nzNqC/nem5e174L3EcLNrvja/ uJcYSCABVM5/uoP7v45ryzwf+ylb3ErS+LLq4u+f9CtSeEUf3z/n+tZwX8yXZHoOrp7it0R7Jp/w 10u2AFlpdugH3cjpj0NaqaDt+5Gi/QCuhrujmbfcjbQWPc/h3qvL4cc939Ovb3FO3kTcrP4Zcn7x Hb6VPH4EEiN5d7FDMRsgeQ/dB/w/SuXESsvdj5GtPzOBvf2Wr6Y7tZ8YT3B6IlqAACfY+gAqjN+z zp8X/HxcakR91gX+/wBfQ9q8uMov40j0pVP+fa8ipJ8GNAT78N23pmQ8j3x6Ui/DjRE/5bXaDHyg OeAPbNbxjHoYupLy7kT+HYEB+yeK7y3/ALqM3cjtn1NP0671e0P77xFBcRdWViOB7/hWdXDr7HyG p/zw8jXk8a6G/Oqx6Xcp96csAOR6H3qCK2+H1/jytMEA6LLjhifRs151ONTu+7NXLt6Elx+zfoc/ On29pKv3gFIyv1Ge9c9d/s6aWpIm0YNjuP4T+FevRxH8zfZmDXa3mZEn7OGhjk2Nwh6AK3X8Kpy/ s7aOc+XLexH+8h7ew9q9KMuzMZX7Igb9muw4MWs6mnp0+UexzU9r8CVtz/o+u3T990gHyj6mrcn2 XYyt3XmWG+Edw33tYlI6uQPvEelRv8LLhfvam/8Asggdfel8kNSXYib4aSj/AFl85/vFR1/Oul0f w6thEcTPI7HJdu0Y7cULz9DKvLTYtR3Cnv8AWriXQ9j2GfWtmjyl5lfU9IS9QpI+1Tw7DsPxruvC vw90qGJVF0gONuMj5QBVxCUu3qdEPh9bn/V3Ke+Mcj86qS/Dc/8ALGUHvg+lV8h8yKsnw9uF6BT3 wD1PsKpTeEblf+WRHcH2pWKv5mc+jyr1R/c+hqxp+kzbWJQgAfNSkNo5meUZOD/n2qtLcL3b3z6i l8hSff5mdf6yI1fYCSFLf7xA718ieLdZkuZnaVQDkoD6qD/Wokb0lo7PyObcDsB/hVZz6VyGkWNw fU/40eYf7x9PwoOi46K5Yd//ANVWokEzAKMk/KBQjOUex7CFh020CoMMF3Of+mh9celeRX12zsSe /wA2Pr/jXLDd/cddtPxKwJHTn3NMll9PxNbI5RI1/vHjoDTduelWvIhl+2sQynL47gHuQKx5396q 5LPZopiRz/8ArFWxID39ga7fmcjfclTI6/UAf1q/azbe2e/NK/8AkCX+R6x4B1ayv4ZbXXQHt5VM USsf9VMRxtJ/2q+etV8F3ujzyQatAUmjYwqD/wAtIT0I/wB5a4cQvLzOqlv6r8ipa5Djg9cY969F tWbLbASCNx93ryK//APZoLzOj027aSFd6MAOMHsT7+xqSeNSh3L2wT6DH9a4mjpfmafhmRWto/LB xghffDHr9K4D4x2qeWp+jHH8J3dhTw795etjnxe34njQUdwfpUiOPb3PpX0yPCLUSqPvfN3we9Wp o1GNg9z7Y9Kq5SX+QsC59R6+5q/Gi/xYP973rVMxfmzsvCmoGFwYpthHKg9xmvorStUW9iBt5G3M CGlH/LMbT/SqjIdSOh8ceJoik8oBBw7D6jd/WsqMH/PetJf8E5qexdtz9Pce1aUDE9T7Z9QKh+RS XmXYmyfmx64/wq9FIx6j6k+tCX+RTJUnI6n/AHj6E12vhqRWYbyMdBz1Pv8ASqn5GPqesaMVBGBk dQf8K9b8O3KbflGPQeo964pmbPQtEueleg6dJkdazidVKR5vP8WrC11J4ZdsUS/NK+CAt1MoP3/f I9a9F0u4MoylwHT7saDHyEe49a7ZRN6aNCisCwooAKKACigAoJA6kAdST2AoE33PMPGH7VfhzTCV sJTqdyMxvHB923kXP+tl/wBlhjjNfN3i/wCMus625OuX7NHnfbafHxHbKDwBH3IHUnk/kK9WhRtr JenkedVqX2OSllJ+6AP73vUTSn+8R3/3h712WMPT0Qm89gff/wCtU4uVH8JHrR6Er19RPJLdT9R7 e4q5Bp5bGAfZfaml5GkYnS6P4AubggLCx7KMdW/+tXtPhD9mlzg6pmJPvkMOW/3VP96oq1Et/kej RpfzHsGkeENPsVAsLVFPRpSOW+prTrw5zb3Ohv8A4AUVBIUUAFFABmigAAr4x+N3xUj1i8cQzH7N DnT9JyeGkU/Myr6zsOPbGa6sPH/JHLXf+Z5DiZRyxKnjr1x7e9Unuc5wcd8nviul+RmvMl0S/MUq knuAT6A//Xr7Q+E3xeto4fL1u9EaAedp1xJ0SMjJUv8A7PUfl6VjVOinLTY+cPjZ8X013UXaISrb RD+zdFRyf3kcZOX8rt57En1xjPoPO5b8fxBT3UjuTXVFefkjkj5P+8NW6Q9z/wDWpd4H8ZHYr/eH /wBagG/8jtPh34pezuFOTjIUk9gx7V9y+G9bWRQC+VI8y3b1B7fjXJXX+R203p+Bv0VxmgUUAFFA BRQAUUAFFABRQAUFQfvAEdCD3B9R70CPiP4keEP7Nu5o2mlOCZrZWGP9GmJKlAfbj04rxa5kRZOX mLjlH5+XPuPaupv/AOSMWcLrF0ZJZTgkliCx7kev41lSE84A9D/n3rJlJ9l6FSQDueemPb3qqFPd Rjrn39/rU/0hW7kLrjPcdPp9KqOgH3s0P/gl2GToo7H2xSQ3ssX+qYj0X/PrWdgv2Ne08Vg/69AP 9r3+lagu4pPuNkdRjtWE49johMikXA+T6kepqH7WrHrtPUipSKT8yTzwfvLj39QDSGLB4x+HcVL8 i79xyOD/AA4PX6imtaZ9M9cimvMRGbcjrgdz9alScj7hOfStY+grHofwb+O1p4W1KG51XTJ7m3Xd b6rFbjLi3njIzCpIBMRIOCQD0461+k3gX9oDwb4lj3eDPFVhfAYa4tgdslsXzjz7V8EZIP8ADg4O K2jF9PkRUk9DsFkU/ddT3wD2p22q5X/KzG4Y9xRtpWf8rFfuw2mjaafK+zFzLug2mjaaOV9mHMu6 DbTDKo+86D6mjlf8rHzdmHmp/wA9E/OgSp2kT86OV/ysOYT7RH3mj/Oj7TF/z2j9OtHK+zDmF8+P vLH+dJ56dpY/fmjlfZhzB9oTtLGfxpwcH+Jfzo5X2YX8xcH2o2n2o5X2YXF2mjaaVn2Yc3mNZCai aJu3HpRZ9mNSXdAGcdWX0696eJD3x+Yos+zDmXccCTTtp9qLPsLm8xMH0o2mi3kw5vMMH0pdpot5 MObzDaaTaaVvJhzeYY9cfWj6YNO3kFw59KMH0pDv5oT5v7tGH9BTt5BfzDa3tR5bf3jSt5Cuu4CM +ppfL+tAcy7h5ftR5ftQF13DZ7UbfagLruLtNfLH7a3w8uLm0hmgt/tCowsriAdSZicbR/tc1pTe v4G1GSvv/dPjPQfHHi3QXDaBb6kyjhrKdWZZE9MkHr9a9y8G/teaFqBVPHHhjVNCuOIDOkbPHcuw /wB3jJ9RVyin9oVmtj2fRvEk6x7tC/0u1HzQzj+4wzxkeleMW1tLFr3nXttN5bxPDbyY/wBW8jDq frXNJd/Q2jbufQHh7UpoR80ZlU/Op9K6eHVJnOQGjA+bYe4P+FXF/wCRlK36G9YeJkCk3U9t5ajd M0rAbB7fWqNz8WNAdSFuYVVgY50AzuRh7+tbWML9j5L179kW31C5kfTVsrK1ZvMhV3+Zix7KenFd Jpf7DqaVJDLLYadqiKwvjpjygC6CHpMewB9vr3FZt+UjrdRfMl/aQ+IL69ZxR+F9ATTnGVvxlcmE AfLEYx0Xb+Xavj69uHswVnDxsPkyevHoTUSf8vr6je2r9Smrxqm++Ejr0tbdQSbiRvUAdP51Z8cG 4VYBe2rW8nlgGEggxnceqmixHJ2Xkyl8NMNqMW5gPlkbd7+UeorB1KT94+AfvNkn03f0qGZ2KZJx 19x7CoRnufpR/wAMFiMjP+etGw+n/wBamxX7DHUj/GlRP/rikBFKR6fh7Uu0Y7e9JjQwL6A+9SIB 7emPSmA8Y/8Ar09VJA/KgBwB749M05VA65+tAh6qO+PXmrCrkHgdMEf3uO/1qgZ+m/7EnjOwm8NW
February 10, 2011 - Present
Kolb-Archive.digest.vol-lb
