Kolb-Archive.digest.vol-ly
November 03, 2011 - November 22, 2011
      > href="http://www.aeroelectric.com">www.aeroelectric.com
      > href="http://www.buildersbooks.com">www.buildersbooks.com
      > href="http://www.homebuilthelp.com">www.homebuilthelp.com
      > href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
      > href="http://forums.matronics.com">http://forums.matronics.com
      > href="http://www.matronics.com/contribution">http://www.matronics.com/c*
      Zulu Delta
      Mk IIIC
      Thanks, Homer GBYM
        - Groucho Marx
Subject: Re: Headsets & hearing loss
Date: Nov 03, 2011
i had wondered about using regular ear buds, and plugging them into the aux output on the intercom.. , sigtronics spo22n, and running the wires under the ear cup seals. at least for a test, before i connected them into the headset. as far as impedance,,, most ear buds, because they are placed in the ear canal and need to move a much smaller volume of air to be just as loud, and will have a much higher impedance than the speakers in the headsets. the biggest difference in the impedance would show up in how they are connected, series or parole, to the headset speaker. i have nothing but a gut feeling on this one but i think i would go with parole. instead of hard wiring them into the headset,,, i have wondered about a small magnetic coupled connection, kind of like the new apple computer laptop is using for the charging cable. this would eliminate ripping something loose should it get pulled by accident. opinions welcome boyd young \mkiii utah/ >>>>>>>>>>>>>> I've used regular earbuds under active headsets by just using an adapter & plugging the earbuds into the a/c's headset jack instead of the headset plug. The headset mic plug stayed in the regular configuration. In a homebuilt (RV-4 in this case), it's so quiet I worried a little bit that I might not hear a/c noise that I would *need* to hear. Charlie ________________________________________________________________________________
From: "Larry Cottrell" <lcottrell1020(at)gmail.com>
Date: Nov 03, 2011
The biggest problem that I have using a headset is that most are not tight enough to the head to keep out the unwanted noise. David Clarks however are painful to me because they squeeze my head, Sigtronics and all the others that I have tried are too loose. I need to check into a chin strap I guess. Keep us posted with what you find out Boyd. Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ----- Original Message ----- From: b young To: kolb-list(at)matronics.com Sent: Thursday, November 03, 2011 9:27 AM Subject: Re: Kolb-List: Re: Headsets & hearing loss i had wondered about using regular ear buds, and plugging them into the aux output on the intercom.. ________________________________________________________________________________
Date: Nov 03, 2011
I'm currently using Sony ear buds under my Sigtronics head set that I added the headset inc. active noise reduction kit to. I got some adapters and plugged two sets of ear buds into my intercom one for me and one for my passenger. The ear buds provide almost as much additional noise reduction as ear plugs but do a better job with voice clarity than the heads sets so it works very well. I have been flying with this set up for about four years but now I occasionally loose one or both the ear bud connections and have to wiggle the adapters to get it working again. Richard P has developed a elegant solution but I wounder if a jack in the head set or in the intercom for the ear buds might be a better long term solution. I'm also getting close to wearing out the Sony ear buds and would not look forward to soldering in a new set with each change. Those tiny wires are a real pain with my fat fingers. I have never lost a ear seal from the ear buds but I have discovered at least with the Sony buds that the little handle on the ear buds bumps against the head set and isn't comfortable so I have scored and broken off the little ear bud handles. Rick Neilsen Redrive VW Powered MKIIIC On Thu, Nov 3, 2011 at 11:27 AM, b young wrote: > > i had wondered about using regular ear buds, and plugging them into the > aux output on the intercom.. , sigtronics spo22n, and running the wires > under the ear cup seals. at least for a test, before i connected them into > the headset. as far as impedance,,, most ear buds, because they are > placed in the ear canal and need to move a much smaller volume of air to be > just as loud, and will have a much higher impedance than the speakers in > the headsets. the biggest difference in the impedance would show up in > how they are connected, series or parole, to the headset speaker. i have > nothing but a gut feeling on this one but i think i would go with parole. > instead of hard wiring them into the headset,,, i have wondered about a > small magnetic coupled connection, kind of like the new apple computer > laptop is using for the charging cable. this would eliminate ripping > something loose should it get pulled by accident. > opinions welcome > > boyd young > \mkiii utah/ > > >>>>>>>>>>>>>>> > I've used regular earbuds under active headsets by just using an adapter > & plugging the earbuds into the a/c's headset jack instead of the > headset plug. The headset mic plug stayed in the regular configuration. > In a homebuilt (RV-4 in this case), it's so quiet I worried a little bit > that I might not hear a/c noise that I would *need* to hear. > > Charlie > > ________________________________________________________________________________
Date: Nov 03, 2011
neilsenrm(at)gmail.com wrote: > I'm currently using Sony ear buds under my Sigtronics head set that I added the headset inc. active noise reduction kit to. I got some adapters and plugged two sets of ear buds into my intercom one for me and one for my passenger. The ear buds provide almost as much additional noise reduction as ear plugs but do a better job with voice clarity than the heads sets so it works very well. > Rick Neilsen > Redrive VW Powered MKIIIC > I did that for a while, but ran out of patience with the plethora of wires. I have a low confusion tolerance, and I was always getting something tangled up. Probably it is just me... Anyway, splicing the earbuds into the headset eliminated the overabundance of wires. OTOH, before I spliced them into the headset, I could plug the earbuds into the mp3 player, which was nice if I was going off by myself with no expectation to talk to anybody. That option is no longer available. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=356833#356833 ________________________________________________________________________________
Date: Nov 03, 2011
[quote="lcottrell"]The biggest problem that I have using a headset is that most are not tight enough to the head to keep out the unwanted noise. David Clarks however are painful to me because they squeeze my head, Sigtronics and all the others that I have tried are too loose. I need to check into a chin strap I guess. Keep us posted with what you find out Boyd. Larry > --- You can use the Armstrong method on that stainless steel strap that runs over the top of the head, you know - fine tune the tension a bit. Along with that - was brain storming with a friend the other night - I am using silicon gel filled ear cushions on the head set - why would it not work to get a second set of gel filled cushions and then use some of that foamy double stick tape and stack the foam cushions atop one another to make things more comfortable? Feedback? -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=356834#356834 ________________________________________________________________________________
Date: Nov 03, 2011
Rick, You wore the David Clarks when we rode in my MK3.Were they enough to be com fortable or have I become accustomed to the din the Jabiru produces? G.Aman -----Original Message----- From: Rick Neilsen <neilsenrm(at)gmail.com> Sent: Thu, Nov 3, 2011 2:44 pm Subject: Re: Kolb-List: Re: Headsets & hearing loss I'm currently using Sony ear buds under my Sigtronics head set that I added the headset inc. active noise reduction kit to. I got some adapters and pl ugged two sets of ear buds into my intercom one for me and one for my passe nger. The ear buds provide almost as much additional noise reduction as ear plugs but do a better job with voice clarity than the heads sets so it wor ks very well. I have been flying with this set up for about four years but now I occasionally loose one or both the ear bud connections and have to wi ggle the adapters to get it working again. Richard P has developed a elegan t solution but I wounder if a jack in the head set or in the intercom for t he ear buds might be a better long term solution. I'm also getting close to wearing out the Sony ear buds and would not look forward to soldering in a new set with each change. Those tiny wires are a real pain with my fat fin gers. I have never lost a ear seal from the ear buds but I have discovered at least with the Sony buds that the little handle on the ear buds bumps ag ainst the head set and isn't comfortable so I have scored and broken off th e little ear bud handles. Rick Neilsen Redrive VW Powered MKIIIC On Thu, Nov 3, 2011 at 11:27 AM, b young wrote: i had wondered about using regular ear buds, and plugging them into the aux output on the intercom.. , sigtronics spo22n, and running the wires unde r the ear cup seals. at least for a test, before i connected them into the headset. as far as impedance,,, most ear buds, because they are placed in the ear canal and need to move a much smaller volume of air to be just a s loud, and will have a much higher impedance than the speakers in the head sets. the biggest difference in the impedance would show up in how they a re connected, series or parole, to the headset speaker. i have nothing bu t a gut feeling on this one but i think i would go with parole. instead of hard wiring them into the headset,,, i have wondered about a small magneti c coupled connection, kind of like the new apple computer laptop is using for the charging cable. this would eliminate ripping something loose shoul d it get pulled by accident. opinions welcome boyd young \mkiii utah/ I've used regular earbuds under active headsets by just using an adapter & plugging the earbuds into the a/c's headset jack instead of the headset plug. The headset mic plug stayed in the regular configuration. In a homebuilt (RV-4 in this case), it's so quiet I worried a little bit that I might not hear a/c noise that I would *need* to hear. Charlie om" target="_blank">www.aeroelectric.com ooks.com" target="_blank">www.buildersbooks.com ="_blank">http://www.matronics.com/contribution le, List Admin. arget="_blank">http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Nov 03, 2011
OTOH, before I spliced them into the headset, I could plug the earbuds into the mp3 player, which was nice if I was going off by myself with no expectation to talk to anybody. That option is no longer available. -------- Richard Pike >>>>>>>>>>>> plug the mp3 into the aux input in the intercom. best of both worlds. listen to music and talk to ATC. boyd young ________________________________________________________________________________
Date: Nov 03, 2011
I have in fact done that very thing several times, just not enough spring steel in Sigtronics to do the job I guess. I am thinking about some Velcro on each headset and a comfortable strap. Got the Velcro, no such thing as a comfortable strap as of yet. Actually my S45's do enough of a job to be tolerable, better for me than the DRE's, I do like to listen to music, and do so every chance I get, Quieter would still be very nice though and I am ready to listen (pun intended) and adapt every viable option. Larry Note: If you forward this email, please delete the forwarding history, which includes my email address. ----- Original Message ----- From: Richard Pike To: kolb-list(at)matronics.com > --- You can use the Armstrong method on that stainless steel strap that runs over the top of the head, you know - fine tune the tension a bit. ________________________________________________________________________________
Date: Nov 03, 2011
byoungplumbing(at)gmail.c wrote: > > plug the mp3 into the aux input in the intercom. best of both worlds. > listen to music and talk to ATC. > > boyd young I tried that, but never could get enough volume. Don't know why. Talk to ATC? I put in 30 years BEING ATC, I don't want to talk to them unless I need them. Which at the altitudes I fly, I mostly don't. I know how good their radar is, and I know how to hide from it... -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=356853#356853 ________________________________________________________________________________
Date: Nov 03, 2011
> > >Pick up some earbuds at your favorite big box store or drugstore, and glue the most comfortable silicon earpieces in place. if you don't glue them in place, they will come off the earbuds, fall out of your ear, and then into the recesses of your Kolb. Guess how I know this? > Richard, I have the same type of hearing problem. I tried the ear buds but I could not keep them located in my ears. I went to a hearing aid salesman and asked him to make me some ear molds. He did. I never got around to mounting the ear buds, but I believe they will take care of the fall out problem. Also, by making the right adaptor, one could use them while flying and on the lawn mower too, and may be get by just using ordinary muff ear protectors. Now if I can just find them.... Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Nov 04, 2011
> > > > I have the same type of hearing problem. I tried the ear buds but I could > not keep them located in my ears. I went to a hearing aid salesman and > asked him to make me some ear molds. He did. I never got around to > mounting the ear buds, but I believe they will take care of the fall out > problem. Also, by making the right adaptor, one could use them while flying and on the lawn mower too, and may be get by just using ordinary muff ear protectors. > > Now if I can just find them.... > > Jack B. Hart FF004 > Winchester, IN You can make your own molded ear plugs fairly cheaply, and mold them to fit around the ear buds, but it may take you more than one attempt. I bought several sets of these Radians moldable ear plugs http://www.amazon.com/Radians-Custom-Molded-Earplugs-Red/dp/B002XULPSQ/ref=sr_1_2?ie=UTF8&qid=1320411520&sr=8-2 and experimented with them. They are perhaps a bit quieter, not sure, but I could not come up with a combination that stayed comfortable for any length of time under the pressure of the head set. And they are tricky to get to fit when you are trying to insert them and dealing with the short length of wire. Or maybe I didn't mold them right. I would mold the flexible stuff around the earbud and then have my wife help me to get them properly seated in the ear, where it would set up in just a few minutes. It was one of those things that almost worked. Since the plain earbuds fit my ears ok and don't fall out, I decided that is good enough. You can buy the silicone tips for earbuds in various sizes, and in my case, one size fits very well, and the others either fall out or are uncomfortable. I assume you have already experimented with this? -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=356882#356882 ________________________________________________________________________________
Date: Nov 04, 2011
how about mounting a set of ear buds in something like this http://www.amazon.com/Surefire-Sonic-Defenders-Medium-Clear/dp/B0012XT8B6 /ref=pd_sim_sg_3 the link has better photo, and if you scroll down there are other options one of the options has a flap with a plug that would fit in the hole, so i am nearly sure they are hollow into the ear canal. been doing some searching for magnetic coupled connectors,,,, and found some patents and line drawings on what i would like to use to connect the ear buds to the inside of the headsets, but haven't been able to find a supplier. still looking. boyd young ________________________________________________________________________________
Date: Nov 04, 2011
Gary Seems like I reported that your Jabiru powered MKIII was close to the quietest I have flown in. Let me qualify that by saying that you added a bunch of sound absorbing foam and it seems like your high quality head sets had the active noise cancelling kit installed. I have ringing in my ears all the time but after exposure to high noise levels it get worse for a bit. I don't remember that I noticed any extra ringing after flying in your plane but it was, what three years ago. The nosiest Kolb I ever flew in was a 503 powered MKIIIC with a cheep head set/intercom that had non standard plugs that I couldn't plug my Sigtronics into. At full throttle (which we did a lot of) the noise was down right pain full. The quietest Kolb was John H's MKIIIC. My theory is that big fuel tank mounted high in the cage is a large viscus mass that absorbs sound and noise producing vibration before it gets to the cockpit. I don't remember the headset I used but I don't think he had and active noise canceling in the passenger headset. That 912S was just a soft purr, well maybe a bit higher pitch. I compare it to the old factory MKIIIC demonstrator (fat albert) with the 912 which always got my ears ringing. One configuration of my VW powered MKIIIC was actually quieter than John H's. It was the high mount redrive VW. The high mount used the same Rotax style vibration dampers but the engine was mounted high over the Rotax mount so as to allow clearance to the oil sump on the bottom of the engine. The engine kind of floated on the mount twisting a bit under power. One of the dampers failed after about a hundred hours. The noise level was so low with the 3200 engine RPM at cruise and 2000 RPM prop that I actually took my headset off for the briefest moment to see how bad it was. Rick Neilsen Redrive VW Powered MKIIIC On Thu, Nov 3, 2011 at 5:25 PM, Gary Aman wrote: > Rick, > You wore the David Clarks when we rode in my MK3.Were they enough to be > comfortable or have I become accustomed to the din the Jabiru produces? > G.Aman > > > -----Original Message----- > From: Rick Neilsen <neilsenrm(at)gmail.com> > To: kolb-list > Sent: Thu, Nov 3, 2011 2:44 pm > Subject: Re: Kolb-List: Re: Headsets & hearing loss > > I'm currently using Sony ear buds under my Sigtronics head set that I > added the headset inc. active noise reduction kit to. I got some adapters > and plugged two sets of ear buds into my intercom one for me and one for my > passenger. The ear buds provide almost as much additional noise reduction > as ear plugs but do a better job with voice clarity than the heads sets so > it works very well. I have been flying with this set up for about four > years but now I occasionally loose one or both the ear bud connections and > have to wiggle the adapters to get it working again. Richard P has > developed a elegant solution but I wounder if a jack in the head set or in > the intercom for the ear buds might be a better long term solution. I'm > also getting close to wearing out the Sony ear buds and would not look > forward to soldering in a new set with each change. Those tiny wires are a > real pain with my fat fingers. I have never lost a ear seal from the ear > buds but I have discovered at least with the Sony buds that the little > handle on the ear buds bumps against the head set and isn't comfortable so > I have scored and broken off the little ear bud handles. > > Rick Neilsen > Redrive VW Powered MKIIIC > > On Thu, Nov 3, 2011 at 11:27 AM, b young wrote: > >> >> i had wondered about using regular ear buds, and plugging them into the >> aux output on the intercom.. , sigtronics spo22n, and running the wires >> under the ear cup seals. at least for a test, before i connected them into >> the headset. as far as impedance,,, most ear buds, because they are >> placed in the ear canal and need to move a much smaller volume of air to be >> just as loud, and will have a much higher impedance than the speakers in >> the headsets. the biggest difference in the impedance would show up in >> how they are connected, series or parole, to the headset speaker. i have >> nothing but a gut feeling on this one but i think i would go with parole. >> instead of hard wiring them into the headset,,, i have wondered about a >> small magnetic coupled connection, kind of like the new apple computer >> laptop is using for the charging cable. this would eliminate ripping >> something loose should it get pulled by accident. >> opinions welcome >> >> boyd young >> \mkiii utah/ >> >> >>>>>>>>>>>>>>>> >> I've used regular earbuds under active headsets by just using an adapter >> & plugging the earbuds into the a/c's headset jack instead of the >> headset plug. The headset mic plug stayed in the regular configuration. >> In a homebuilt (RV-4 in this case), it's so quiet I worried a little bit >> that I might not hear a/c noise that I would *need* to hear. >> >> Charlie >> >> >> ====**==============================**= >> om" target="_blank">www.aeroelectric.com >> ooks.com" target="_blank">www.buildersbooks.com >> ="_blank">http://www.matronics.com/**contribution >> le, List Admin. >> ====**==============================**= >> arget="_blank">http://www.matronics.com/**Navigator?Kolb-List >> ====**==============================**= >> http://forums.matronics.com >> ====**==============================**= >> le, List Admin. >> ="_blank">http://www.matronics.com/**contribution >> ====**==============================**= >> >> >> >> > * > ic.com">www.aeroelectric.com > .buildersbooks.com">www.buildersbooks.comhelp.com">www.homebuilthelp.com > bution">http://www.matronics.com/contribution > tor?Kolb-List">http://www.matronics.com/Navigator?Kolb-List > tp://forums.matronics.com > bution">http://www.matronics.com/contribution > * > > * > > * > > ________________________________________________________________________________
Date: Nov 04, 2011
Rick, Adding all that Denso- Foam made the difference,in the center section in pa rticular. I think you are right about the liquid killing the noise in John' s plane.Took a tour of Kennedy space center last year and one of the intere sting pieces of information I recalled was the massive amounts of water the y poured on the launch pad at lift-off.I thought it was to cool the pad,but they said no,it was to control the noise. I still need to insulate the are as behind the fuel tanks.I have the foam,will carry it south with me this y ear and maybe get to it. Maybe meet up again with you and some of the guys that are local. G.Aman MK3C Jabiru 2200a -----Original Message----- From: Rick Neilsen <neilsenrm(at)gmail.com> Sent: Fri, Nov 4, 2011 11:32 am Subject: Re: Kolb-List: Re: Headsets & hearing loss Gary Seems like I reported that your Jabiru powered MKIII was close to the quiet est I have flown in. Let me qualify that by saying that you added a bunch o f sound absorbing foam and it seems like your high quality head sets had th e active noise cancelling kit installed. I have ringing in my ears all the time but after exposure to high noise levels it get worse for a bit. I don' t remember that I noticed any extra ringing after flying in your plane but it was, what three years ago. The nosiest Kolb I ever flew in was a 503 powered MKIIIC with a cheep head set/intercom that had non standard plugs that I couldn't plug my Sigtronics into. At full throttle (which we did a lot of) the noise was down right pa in full. The quietest Kolb was John H's MKIIIC. My theory is that big fuel tank mounted high in the cage is a large viscus mass that absorbs sound and noise producing vibration before it gets to the cockpit. I don't remember the headset I used but I don't think he had and active noise canceling in t he passenger headset. That 912S was just a soft purr, well maybe a bit high er pitch. I compare it to the old factory MKIIIC demonstrator (fat albert) with the 912 which always got my ears ringing. One configuration of my VW powered MKIIIC was actually quieter than John H' s. It was the high mount redrive VW. The high mount used the same Rotax sty le vibration dampers but the engine was mounted high over the Rotax mount s o as to allow clearance to the oil sump on the bottom of the engine. The en gine kind of floated on the mount twisting a bit under power. One of the da mpers failed after about a hundred hours. The noise level was so low with t he 3200 engine RPM at cruise and 2000 RPM prop that I actually took my head set off for the briefest moment to see how bad it was. Rick Neilsen Redrive VW Powered MKIIIC On Thu, Nov 3, 2011 at 5:25 PM, Gary Aman wrote: Rick, You wore the David Clarks when we rode in my MK3.Were they enough to be com fortable or have I become accustomed to the din the Jabiru produces? G.Aman -----Original Message----- From: Rick Neilsen <neilsenrm(at)gmail.com> Sent: Thu, Nov 3, 2011 2:44 pm Subject: Re: Kolb-List: Re: Headsets & hearing loss I'm currently using Sony ear buds under my Sigtronics head set that I added the headset inc. active noise reduction kit to. I got some adapters and pl ugged two sets of ear buds into my intercom one for me and one for my passe nger. The ear buds provide almost as much additional noise reduction as ear plugs but do a better job with voice clarity than the heads sets so it wor ks very well. I have been flying with this set up for about four years but now I occasionally loose one or both the ear bud connections and have to wi ggle the adapters to get it working again. Richard P has developed a elegan t solution but I wounder if a jack in the head set or in the intercom for t he ear buds might be a better long term solution. I'm also getting close to wearing out the Sony ear buds and would not look forward to soldering in a new set with each change. Those tiny wires are a real pain with my fat fin gers. I have never lost a ear seal from the ear buds but I have discovered at least with the Sony buds that the little handle on the ear buds bumps ag ainst the head set and isn't comfortable so I have scored and broken off th e little ear bud handles. Rick Neilsen Redrive VW Powered MKIIIC On Thu, Nov 3, 2011 at 11:27 AM, b young wrote: i had wondered about using regular ear buds, and plugging them into the aux output on the intercom.. , sigtronics spo22n, and running the wires unde r the ear cup seals. at least for a test, before i connected them into the headset. as far as impedance,,, most ear buds, because they are placed in the ear canal and need to move a much smaller volume of air to be just a s loud, and will have a much higher impedance than the speakers in the head sets. the biggest difference in the impedance would show up in how they a re connected, series or parole, to the headset speaker. i have nothing bu t a gut feeling on this one but i think i would go with parole. instead of hard wiring them into the headset,,, i have wondered about a small magneti c coupled connection, kind of like the new apple computer laptop is using for the charging cable. this would eliminate ripping something loose shoul d it get pulled by accident. opinions welcome boyd young \mkiii utah/ I've used regular earbuds under active headsets by just using an adapter & plugging the earbuds into the a/c's headset jack instead of the headset plug. The headset mic plug stayed in the regular configuration. In a homebuilt (RV-4 in this case), it's so quiet I worried a little bit that I might not hear a/c noise that I would *need* to hear. Charlie om" target="_blank">www.aeroelectric.com ooks.com" target="_blank">www.buildersbooks.com ="_blank">http://www.matronics.com/contribution le, List Admin. arget="_blank">http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution ic.com">www.aeroelectric.com .buildersbooks.com">www.buildersbooks.com help.com">www.homebuilthelp.com bution">http://www.matronics.com/contribution tor?Kolb-List">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com bution">http://www.matronics.com/contribution _blank">www.aeroelectric.com .com" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Advisory Circular 150/5345-27D
Date: Nov 04, 2011
Thanks for your inquiry. The standard for windsocks is found in FAA Advisory Circular 150/5345-27D. This says the windsocks have to indicate the proper direction at wind speeds as low as 3 knots and the windsock is supposed to stand straight out at speeds between 14 and 17 knots. When we changed vendors we made some observations of the competing windsocks. I dont think you can really judge the wind speed by looking at the windsock, but you can get a pretty good idea of the direction. Mn/DOT 651.226.2043 -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern These flying machines are just a fad and will never catch on Unknown Read this topic online here: http://forums.matronics.com/viewtopic.php?p=356925#356925 Attachments: http://forums.matronics.com//files/dsc01797_135.jpg ________________________________________________________________________________
Date: Nov 04, 2011
byoungplumbing(at)gmail.c wrote: > how about mounting a set of ear buds in something like this > > http://www.amazon.com/Surefire-Sonic-Defenders-Medium-Clear/dp/B0012XT8B6/ref=pd_sim_sg_3 (http://www.amazon.com/Surefire-Sonic-Defenders-Medium-Clear/dp/B0012XT8B6/ref=pd_sim_sg_3) > > boyd young > How about if you got some small diameter silicone tubing - the size that they use on model airplanes - attach it to the passage that runs through the Sonic Defender insert and let it extend to outside and below the headset cushion, and then attach the ear bud at that point? Hanging a few inches below the headset muff, with the tubing lying between your head and the headset cushion. Attach the ear bud wires to the head set as described in my previous post. Now the ear bud is not being smashed up against your ear by the inside of the headset, and you ought to have the best of both worlds. Sound dampening from the headset and from the insert both. Thoughts? One caveat: some earbuds have an opening in the back for some sort of acoustic reason - if you used it in this manner, would it be better to seal that up? Would that not let sound pass through the earbud and on up the tube? -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=356928#356928 ________________________________________________________________________________
Date: Nov 04, 2011
One caveat: some earbuds have an opening in the back for some sort of acoustic reason - if you used it in this manner, would it be better to seal that up? Would that not let sound pass through the earbud and on up the tube? -------- Richard Pike >>>>>>>>>>>>>>>>>>>>>>>>>> is the opening in the back an air passage way to eliminate pressure differences in the inner ear to the outside air pressure,, boyd young ________________________________________________________________________________
Date: Nov 05, 2011
Subject: Fund Raiser List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: seat material
Date: Nov 06, 2011
Hi everyone, I am in the process of repairing everything in the cockpit of a Twinstar Mark II, I am looking for a source for the material used on the seats. thanks, Lee.. ________________________________________________________________________________
Subject: Re: seat material
Date: Nov 06, 2011
Lee, If Kolb Aircraft can't fix you up, maybe try these folks; (you even have a choice of colors!) http://www.funspot.com/trampoline_fabric.php?source=Google_trampoline_fa bric Mike Welch On Nov 6, 2011, at 6:40 AM, Lee Morgan wrote: > Hi everyone, I am in the process of repairing everything in the cockpit of a Twinstar Mark II, I am looking for a source for the material used on the seats. > thanks, > Lee.. > > > > > ________________________________________________________________________________
Subject: Ultralight News video
Date: Nov 06, 2011
Just got thru watching the Ultralight News video by Dan Johnson on the new Firestar Side by Side and I thought I would share with the group in case nobody had seen it. Seems to me like they covered it pretty good and I hope it sells well for Kolb Aircraft. Travis Bennett http://www.youtube.com/watch?v=1HJkjLcuNF8 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357072#357072 ________________________________________________________________________________
Date: Nov 06, 2011
Subject: Re: Breeze up the boom tube
I have yet to test or see the practicality of it, but has anyone either tried to either narrow the opening in the back so as to create more or equal venturi effect than exist in the cabin. I agree that the simplest and easiest is to create a plug at the opening, but since we are experimental why not annoy ourselves by doing the hard stuff too. Just bored waiting for house to sell so I can get to Florida In Beautiful wonderful Arizona, don't you just wanna buy a home here and live here and enjoy sunny Aviation all year around? Hehehehehehe I got a house for sale for you if you do. Ron @ KFHU It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx -- kugelair.com ________________________________________________________________________________
Date: Nov 06, 2011
Subject: Re: Strut Fairings
Some while ago a member posted a video connection to some Brit experimenting with faired and unfaired flying wires the difference in his tests were just as amazing. I don't remember the link but its well worth looking it up in the archives again. Elliptical or Tear drop is way more aerodynamic than round. Ron @ KFHU ================================== ---- FIRESTARII wrote: ============ :D [Shocked] WOW Guys and Gals! When I purchased my FSII it came with two sets of wing struts, one with fairings and one without. The struts with the fairings were off a FS that went into the intra coastal water ways, thus salt water. I was very leery of that so I was not comfortable using them so I have been flying with the non-faired struts. I was however curious as to what impact they would actually have. So I removed the fairings from the struts and installed them on the ones I have been flying with. I just landed after an hour and a half flight with them installed and WOW is all I can say! Very much to my surprise they made an ENORMOUS difference! The airplane was way smoother cruised a good 10 MPH indicated better. The biggest surprise was in glide, best glide, best as I can figure based purely on feel is about 45-48 indicated. The difference was astonishing, at lest to me! In a totally non scientific, seat of the pants, guess, I bet it was 30% farther.! Now mind you I am guessing here but to not only see, but feel a difference so significant just amazed me. I'll never fly with out them again! Cruise speed to jumped a good 10MPH at 5500 and the airplane just "Felt" smoother to me. WOW! Any way I just thought I would let every body know what a difference it made on my airplane and highly recommend them to any one not currently using them! Let me know if you guys have seen such a difference and what else you can recommend to further improve my FSII. Fly safe and have fun every body! -------- Low and Slow FireStar II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=354135#354135 -- kugelair.com ________________________________________________________________________________
Date: Nov 06, 2011
Thanks Dennis No sooner I post my reply and you give the link. GMTA :-) Ron @ KFHU ==================== ---- Dennis Thate wrote: ============ http://www.youtube.com/watch?v=ftq8jTQ8ANE -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern These flying machines are just a fad and will never catch on Unknown Read this topic online here: http://forums.matronics.com/viewtopic.php?p=354144#354144 -- kugelair.com ________________________________________________________________________________
Date: Nov 06, 2011
Subject: Re: Off field landings
Very nice. ---- Mystic wrote: ============ I've been having fun playing "Bush pilot" in my Firestar. Maybe too much fun.... Broke it down to 3 parts on youtube. Check it out when you've got a few minutes to kill. BTW, My 447 is loving the change in weather. Needle is back to th middle, temps are back up in the green, and she's climbing like we stole somthing! John Tempest Firestar "Classic" 447 http://www.youtube.com/watch?v=1_hb2hQbklg http://www.youtube.com/watch?v=nlYBOxyX5Xw http://www.youtube.com/watch?v=Rox7IObjwXc Read this topic online here: http://forums.matronics.com/viewtopic.php?p=354255#354255 -- kugelair.com ________________________________________________________________________________
Date: Nov 06, 2011
Subject: RE: Kolb-List Digest: 0 Msgs - 11/05/11
I made a small contribution last week. Wondering if you received it??? BCG ________________________________________________________________________________
Date: Nov 06, 2011
Call Kolb Aircraft and talk to Travis I am sure he can fix you up with any of your needs for anything on a kolb 1-606-862-9692 Ellery Batchelder Jr. -----Original Message----- From: Lee Morgan <lmorgan100(at)charter.net> Sent: Sun, Nov 6, 2011 7:43 am Subject: Kolb-List: seat material Hi everyone, I am in the process of repairing everything in the cockpit of a Twinstar Mark II, I am looking for a source for the material used on the seats. thanks, Lee.. - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: - -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Nov 06, 2011
I Like Hi-tech foams,Jim Fix.He carries all kinds including sound absorbin g and has Temper foam,the stuff they use in the Shuttle seats.He'll ask you what you weigh and make up a 2 or 3 layer cushion custom for you.Not cheap but boy is it worth it! G.Aman MK3C Jabiru 2200A pampered tush ginal Message----- From: Michael Welch <mdnanwelch7(at)hotmail.com> Sent: Sun, Nov 6, 2011 8:47 am Subject: Re: Kolb-List: seat material Lee, If Kolb Aircraft can't fix you up, maybe try these folks; (you even have a choice of colors!) http://www.funspot.com/trampoline_fabric.php?source=Google_trampoline_fab ric Mike Welch On Nov 6, 2011, at 6:40 AM, Lee Morgan wrote: Hi everyone, I am in the process of repairing everything in the cockpit of a Twinstar Mark II, I am looking for a source for the material used on the seats. thanks, Lee.. style="color: blue; text-decoration: underline; ">www.aeroelectric.com href="http://www.buildersbooks.com"; style="color: blue; text-decoratio n: underline; ">www.buildersbooks.com style="color: blue; text-decoration: underline; ">www.homebuilthelp.com style="color: blue; text-decoration: underline; ">http://www.matronics.co m/contribution style="color: blue; text-decoration: underline; ">http://www.matronics.co m/Navigator?Kolb-List blue; text-decoration: underline; ">http://forums.matronics.com style="color: blue; text-decoration: underline; ">http://www.matronics.co m/contribution ________________________________________________________________________________
Subject: Slingshot
Date: Nov 06, 2011
I have been looking into the Slingshot but have not found much information besides through Kolb. Anyone own or have flown one? how does it perform? Is the rear seat even usable? I am interested in the Slingshot over the other Kolb models because of the increases performance (advertised). Thanks ________________________________________________________________________________
Subject: Amazing Footage
Date: Nov 06, 2011
http://www.dogwork.com/owfo8/ -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern These flying machines are just a fad and will never catch on Unknown Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357102#357102 ________________________________________________________________________________
Date: Nov 06, 2011
Subject: Kolb-List: Amazing Footage http://www.dogwork.com/owfo8/ Dennis Thate: What's your point? john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: Amazing Footage
Date: Nov 06, 2011
John Hauck wrote: > Subject: Amazing Footage > > > > http://www.dogwork.com/owfo8/ > > > > > Dennis Thate: > > What's your point? > > john h > mkIII > > The vortex dynamics ! > Titus, Alabama -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern These flying machines are just a fad and will never catch on Unknown Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357108#357108 ________________________________________________________________________________
Date: Nov 06, 2011
The Vortex Dynamics ! Silly [Wink] -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern These flying machines are just a fad and will never catch on Unknown Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357109#357109 ________________________________________________________________________________
Subject: Re: Slingshot
Date: Nov 06, 2011
bsrenter, I own and fly a Slingshot with Jabiru 2200 engine. My normal cruise speed is 85 mph at 3.6-3.7 gph fuel burn. I get 1200 fpm initial climb rate except on real warm days, then it is only 1,000 fpm. I fly it solo but there is room for a midling size person in the back. I'm 5'-10 and 205 lbs and the back is not too tight but probably not comfortable for a long flight. It is a tail heavy airplane in the sense that the tail on mine has about 110 lbs on the tailwheel in three point stance with full fuel but no pilot. Slingshots do not handle on the ground as easily as the short leg Kolbs, partially due to the longer main gear legs, but mostly due to the heavy tail. Getting some real tailwheel time (not a Firestar of Mk III) is essential before soloing a Slingshot. It is a hoot to fly. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Truth is what stands the test of experience. - Albert Einstein Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357110#357110 ________________________________________________________________________________
Date: Nov 06, 2011
The Vortex Dynamics ! Silly [Wink] Dennis Thate: Try to follow the Kolb List guidelines and keep your posts Kolb related. Helps keep the Kolb List running smoothly. Are you presently building or flying a Kolb? I remember you posted many times reference building your hanger door, but don't remember you sharing your Kolb building and flying experiences. If you have any, I'd like to hear about them. I can't speak for the other members of the Kolb List, but they would probably like to hear them too. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Twinstar MkIII
Date: Nov 06, 2011
Anyone know what the distance between the main gear wheels is on a Twinstar MkIII? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357114#357114 ________________________________________________________________________________
Date: Nov 07, 2011
Subject: Make A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 07, 2011
Interesting the way the wing root is fully stalled with the feathers blowing the wrong way and the tips are still flying. Nice pic Pat. ________________________________________________________________________________
Subject: Re: Twinstar MkIII
Date: Nov 07, 2011
On my MK3C from the outside of the tires is 82".They just go between the wh eel wells of a 8' wide car hauling trailer.I have the short spring steel ge ar legs. G.Aman -----Original Message----- From: Ozarkflyer <lragan(at)hotmail.com> Sent: Sun, Nov 6, 2011 11:14 pm Subject: Kolb-List: Twinstar MkIII Anyone know what the distance between the main gear wheels is on a Twinstar MkIII? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357114#357114 ________________________________________________________________________________
Date: Nov 07, 2011
Thanks. Exactly what I needed. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357203#357203 ________________________________________________________________________________
Subject: Somebody correct me if I'm wrong.
Date: Nov 07, 2011
I'm trying to differentiate between a Twinstar and a Mk II, or maybe they're one and the same. My understanding is that the Twinstar was originally a Mk II with a 5" spar and typically a Rotax 503. When the Twinstar Mk III came out it was beefed up with a 6" spar and typically a Rotax 582 plus some other minor differences. Is there any difference between this Mk III and the Mk IIIC that we know today, or is the Mk IIIC designation there to differentiate from a Mk IIIX? I'm so confused. :? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357218#357218 ________________________________________________________________________________
Subject: Re: Somebody correct me if I'm wrong.
Date: Nov 07, 2011
easy to be confused. twinstar was a reference to side by side seating. Both the mkII and MkIII were called twinstars (as far as I know) and the MkIII was just an upgrade in structure heaviness. I have an original manual that came with mine that called it a "caribbean" -that's some kind of a Bean I think. heh heh. -and now we have a new side by side Firestar, with a nose wheel no less, to confuse you. BB MkIII (there never was a MkIIIC) suzuki. On 7, Nov 2011, at 7:07 PM, Ozarkflyer wrote: > > I'm trying to differentiate between a Twinstar and a Mk II, or maybe they're one and the same. My understanding is that the Twinstar was originally a Mk II with a 5" spar and typically a Rotax 503. When the Twinstar Mk III came out it was beefed up with a 6" spar and typically a Rotax 582 plus some other minor differences. Is there any difference between this Mk III and the Mk IIIC that we know today, or is the Mk IIIC designation there to differentiate from a Mk IIIX? > > I'm so confused. :? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=357218#357218 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 07, 2011
I'm trying to differentiate between a Twinstar and a Mk II, or maybe they're one and the same. My understanding is that the Twinstar was originally a Mk II with a 5" spar and typically a Rotax 503. When the Twinstar Mk III came out it was beefed up with a 6" spar and typically a Rotax 582 plus some other minor differences. Is there any difference between this Mk III and the Mk IIIC that we know today, or is the Mk IIIC designation there to differentiate from a Mk IIIX? *************************************** Twinstar: First Kolb two place, side by side, open cockpit with a nose cone and small windshield. Powered with a 447. 7 rib wing and 5" spar and tail boom. Twinstar MKII: Enclosed Twinstar, 5" spar and tail boom, 7 rib wing, powered with a 503. Twinstar MKIII: 6" spar and tail boom, 10 rib wing, powered with a 582, 912UL and 912ULS. The "c" was added to the MKIII after The New Kolb Aircraft Company purchased Kolb Aircraft to differentiate between it and the new modified MKIIIx. john h mkIII (Built and flown long before the Extra was thought of, therefore no "c" in my model number.) Titus, Alabama ________________________________________________________________________________
Date: Nov 07, 2011
Sorta gives new meaning to "full flaps" -------- Kolb Mark IIIX 582 Blue head Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357223#357223 ________________________________________________________________________________
Date: Nov 07, 2011
I had one of the original Twinstars back in '89; 5" spars and tail boom, si de-by-side seating, dual rudders, single stick, Rotax 503, 5-gal tank, no n osecone, canopy or flaps, before it was renamed to Mk. I can't remember how many ribs. Phil H. --- On Mon, 11/7/11, John Hauck wrote: From: John Hauck <jhauck(at)elmore.rr.com> Subject: RE: Kolb-List: Somebody correct me if I'm wrong. Date: Monday, November 7, 2011, 8:02 PM I'm trying to differentiate between a Twinstar and a Mk II, or maybe they'r e one and the same.- My understanding is that the Twinstar was originally a Mk II with a 5" spar and typically a Rotax 503.- When the Twinstar Mk III ca me out it was beefed up with a 6" spar and typically a Rotax 582 plus some other minor differences.- Is there any difference between this Mk III and the Mk IIIC that we know today, or is the Mk IIIC designation there to differentiate from a Mk IIIX? *************************************** Twinstar:- First Kolb two place, side by side, open cockpit with a nose c one and small windshield.- Powered with a 447.- 7 rib wing and 5" spar and tail boom. Twinstar MKII:- Enclosed Twinstar, 5" spar and tail boom, 7 rib wing, powered with a 503.--- --- Twinstar MKIII:- 6" spar and tail boom, 10 rib wing, powered with a 582, 912UL and 912ULS. The "c" was added to the MKIII after The New Kolb Aircraft Company purchase d Kolb Aircraft to differentiate between it and the new modified MKIIIx. john h mkIII (Built and flown long before the Extra was thought of, therefore no "c" in my model number.) Titus, Alabama le, List Admin. le, List Admin. ________________________________________________________________________________
Date: Nov 08, 2011
Subject: Building a landing strip in Pa
A friend of mine, and I are looking for land, to put in our own landing strip. There is NO hanger space where I fly from now and I am getting too old to drag my FSII up onto my trailer each time I fly. ( not to mention we feel the land would be a good investment). Has anyone done this, and what hoops must you jump through before buying the land? This would NOT be open to the general public, and only he and I would take off and land there. Thanks in advance for any guidance you can offer. Lanny N598LF ________________________________________________________________________________
Subject: Re: Building a landing strip in Pa
Date: Nov 08, 2011
> Has anyone done this, and what hoops must you jump through before buying the land? Lanny N598LF > Lanny, Yes. But call me. Too much to go into via email. Mike Welch 573-480-9802 PS. Don't give out my phone number to anyone. Up until now, only you and I know it. ________________________________________________________________________________
Date: Nov 08, 2011
Lanny/All I already owned the land so I just took the stand that it was better to ask forgiveness than to ask permission. I build a 1400 ft one way grass strip in Michigan that I flew out of for 20 years with no problems. I did make the rounds to neighbors every few years or so to talk about any issues. This seemed to be the key and not too much traffic. Never had a minutes problem with neighbors or any government. At one point I looked into making it a class D airstrip which would have given me tax exempt status on the runway but didn't have enough length for the required approaches/and length. The runway was plenty for my kolb and very convenient as it was next to my house and hanger. Not much better than being less than 20 minutes form your living room to in the air including a good preflight. By the way, the house, 19 acres, hanger and strip is 10 miles west of Lansing MI and is for sale if anyone is interested. Contact me off the list if you are interested. Rick Neilsen 1st Redrive VW Powered MKIIIC On Tue, Nov 8, 2011 at 1:30 PM, Lanny Fetterman wrote: > > A friend of mine, and I are looking for land, to put in our own landing > strip. There is NO hanger space where I fly from now and I am getting too > old to drag my FSII up onto my trailer each time I fly. ( not to mention we > feel the land would be a good investment). Has anyone done this, and what > hoops must you jump through before buying the land? This would NOT be open > to the general public, and only he and I would take off and land there. > Thanks in advance for any guidance you can offer. Lanny N598LF > > ________________________________________________________________________________
Date: Nov 08, 2011
Never had a minutes problem with neighbors or any government. Rick Neilsen Rick N/Folks: Good idea to stay on the good side of your neighbors by visiting with them to see if there are any issues. I've been flying out of a cow pasture for 27 years. Never had a complaint from my neighbors. To keep on their good side, I occasionally take aerial photos of their houses and acreage. Putting them in a nice 8 X 10 inexpensive picture frame also adds a little bit to the personal side of this gift. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 08, 2011
If any of you hard-of-hearing pilots use hearing aids you should try the T-Coil setting, if so equipped. The T-Coil switches OFF the hearing aid microphone and gets its signal from the emf (electromagnetic field) generated by the coils in the headset. This way, the only major sound you get comes through the radio and/or intercom. The T-coil was designed for use with telephones (hence the name) but works as well or better in a noisy airplane cabin with headsets. I went completely deaf over the years in both ears and now have bi-lateral cochlear implants. The only way I can use the radio now is with the T-coil set which makes a HUGE difference in speech intelligibility. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Truth is what stands the test of experience. - Albert Einstein Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357246#357246 ________________________________________________________________________________
Date: Nov 08, 2011
I live in northeast Pa and am doing the same thing. Went to the Township building and spoke with the local officials and they told me there are no zoning laws in the township that would prohibit me from doing this. Every township is different you should check with they first. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357247#357247 ________________________________________________________________________________
Subject: Re: Headsets & hearing loss
Date: Nov 08, 2011
Thom Riddle wrote: > If any of you hard-of-hearing pilots use hearing aids you should try the T-Coil setting, if so equipped. The T-Coil switches OFF the hearing aid microphone and gets its signal from the emf (electromagnetic field) generated by the coils in the headset. This way, the only major sound you get comes through the radio and/or intercom. The T-coil was designed for use with telephones (hence the name) but works as well or better in a noisy airplane cabin with headsets. > > I went completely deaf over the years in both ears and now have bi-lateral cochlear implants. The only way I can use the radio now is with the T-coil set which makes a HUGE difference in speech intelligibility. > > For more information on T-coils see this: > http://www.tecear.com/Turn-On-To-T-coil.htm Excellent device, how do you install it into a headset? Or make it work in an airplane? How is yours set up? -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357248#357248 ________________________________________________________________________________
Date: Nov 08, 2011
At 01:30 PM 11/8/2011, Lanny Fetterman wrote: > >A friend of mine, and I are looking for land, to put in our own landing >strip. There is NO hanger space where I fly from now and I am getting too >old to drag my FSII up onto my trailer each time I fly. ( not to mention >we feel the land would be a good investment). Has anyone done this, and >what hoops must you jump through before buying the land? This would NOT be >open to the general public, and only he and I would take off and land >there. Thanks in advance for any guidance you can offer. It depends on the state and local laws. For private use, it may be that nothing is required. Here in Connecticut the state only gets involved if more than 35 takeoffs and landings per year or 10 per day are done, then you need a state airport license. I know that in NJ _all_ flying must be from a state licensed airport. Local zoning may apply. We built a strip here in CT and first the zoning people told us we couldn't fly because zoning regulations didn't list it as a permitted use. We requested special permission and they changed their mind and declared that the zoning regulations didn't actually prohibit it, either... subject to not annoying anybody, we could go ahead and fly. They didn't want to set a precedent by giving us formal permission. -Dana -- The most exciting phrase to hear in science, the one that heralds new discoveries, is not Eureka! (I found it!) but rather, 'hmm.... that's funny...' --Isaac Asimov ________________________________________________________________________________
Date: Nov 08, 2011
T-coils are built into all modern hearing aids, I believe, and cochlear implant speech processors. I know that all the hearing aids I had over the 25 plus year period I could use one, had T-coils. Each manufacturer of aids/implants has their own way of switching from mic to T-coil, and back when you are done flying or using the telephone. Mine just requires pressing two small buttons on the processor for 3 seconds to switch to T-coil mode. Same for switching back to microphone. Some have a way of mixing both mic and T-coil. Mine is set (via programming) to keep 10% of the sound coming from the mic with 90% coming through the T-coil. I would prefer it be 100% T-coil but that is not possible on mine. When the T-coil is OFF, all sound comes from the microphone pickup. There is no external device required, no wired connections or anything. The mere close proximity of a telephone or headset is sufficient to pickup the telephone/radio/intercom output. Just use the telephone or headset as you are using now but with the hearing aid switched to T-coil. If you don't have hearing aids I know of no way of rigging anything like this. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Truth is what stands the test of experience. - Albert Einstein Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357250#357250 ________________________________________________________________________________
Date: Nov 08, 2011
Mike, I just found the listing for the land today. I will give you a call if we move forward. We are going to go look at it tomorrow. Lanny At 02:10 PM 11/8/2011, you wrote: >> Has anyone done this, and what hoops must you jump through before >> buying the land? Lanny N598LF > >Lanny, > > Yes. But call me. Too much to go into via email. > > >Mike Welch >573-480-9802 > >PS. Don't give out my phone number to anyone. Up until now, only >you and I know it. > > ________________________________________________________________________________
Date: Nov 08, 2011
There is no external device required, no wired connections or anything. The mere close proximity of a telephone or headset is sufficient to pickup the telephone/radio/intercom output. Just use the telephone or headset as you are using now but with the hearing aid switched to T-coil. If you don't have hearing aids I know of no way of rigging anything like this. -------- Thom Riddle Thanks for the hearing aid info. I am in the process of getting a new pair. I tried them in 1978 and 1980, when I retired from the Army, but never gave them a chance for me to really get adjusted to the new noise. Being able to hear any better than I do now would make my flying much more enjoyable. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 09, 2011
Subject: Reminder
Dear Listers, Just a quick reminder that November is the annual List Fund Raiser. The Matronics Lists are 100% member supported and all of the operational costs are provided for my your Contributions during this time of the year. Your personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 09, 2011
Lanny, A fews years ago, I helped a guy do what you suggested regarding buying some land, and putting in a runway. With a background in being a contractor, a real estate agent, and land development, I have some experience in these matters. ( I ended up buying the Caterpillar road grader a couple of years after the landing strip was put in, to go along with several other pieces of heavy equipment I had) As suggested by a couple of list members so far....the absolute FIRST thing you should do is call your local Planning & Zoning Dept. They will be able to tell you the specific zone category the land you are interested in, and whether you can 'legally' build and use a landing strip. One thing I wouldn't do is; buy the land, build the runway and THEN ask if it's okay. Hellava lot of time/money/risk if it all doesn't work out. Just like every other real estate investment, there is a proper order for things!! To go about it backwards may be an expensive lesson. A couple of 'obvious' suggestions to consider regarding picking out that piece of property. A) Slope, if any. B) Length of 'usable' runway you can actually build. C) Direction of prevailing wind. D) Proximity to power lines, neighboring homes, tall trees, etc. E) Is the property so secluded that someone can break in and steal parts off your plane? (This happened to my friend, someone broke into his metal-siding hangar and stole his 503 motor from Quicksilver) Just a couple of thoughts to consider..... BTW. Just kidding about the ix-nay on the phone number. My anemic attempt at humor, which evidently is on life-support. Mike Welch On Nov 8, 2011, at 12:30 PM, Lanny Fetterman wrote: > > A friend of mine, and I are looking for land, to put in our own landing strip. There is NO hanger space where I fly from now and I am getting too old to drag my FSII up onto my trailer each time I fly. ( not to mention we feel the land would be a good investment). Has anyone done this, and what hoops must you jump through before buying the land? This would NOT be open to the general public, and only he and I would take off and land there. Thanks in advance for any guidance you can offer. Lanny N598LF > > > > > > > ________________________________________________________________________________
Date: Nov 09, 2011
Including mine there are four grass strips within 2 miles. Not much fear of collisions as I'm the only one who flies with any regularity. We are fortunate to be in an agricultural district which usually is aviation friendly. None of us ever attempted to comply with any local regs or zoning. -but we have all been established for over thirty years. Despite that, it is obviously important to maintain friendly relationships with neighbors. I make a practice of NEVER flying over a house, nice guy or not. One comment someone offered that aerial photos of homes make a big impact. I put them on CD and give them to the owners. BB MkIII, suzuki still nice here today On 9, Nov 2011, at 10:52 AM, Michael Welch wrote: > > Lanny, > > A fews years ago, I helped a guy do what you suggested regarding buying some land, and putting in > a runway. With a background in being a contractor, a real estate agent, and land development, I have some > experience in these matters. ( I ended up buying the Caterpillar road grader a couple of years after the landing strip > was put in, to go along with several other pieces of heavy equipment I had) > > As suggested by a couple of list members so far....the absolute FIRST thing you should do is call your local > Planning & Zoning Dept. They will be able to tell you the specific zone category the land you are interested in, and whether > you can 'legally' build and use a landing strip. > > One thing I wouldn't do is; buy the land, build the runway and THEN ask if it's okay. Hellava lot of time/money/risk if it all > doesn't work out. Just like every other real estate investment, there is a proper order for things!! To go about it backwards > may be an expensive lesson. > > A couple of 'obvious' suggestions to consider regarding picking out that piece of property. A) Slope, if any. B) Length of 'usable' > runway you can actually build. C) Direction of prevailing wind. D) Proximity to power lines, neighboring homes, tall trees, etc. > E) Is the property so secluded that someone can break in and steal parts off your plane? (This happened to my friend, someone broke > into his metal-siding hangar and stole his 503 motor from Quicksilver) > > Just a couple of thoughts to consider..... > > BTW. Just kidding about the ix-nay on the phone number. My anemic attempt at humor, which evidently is on life-support. > > Mike Welch > > > > > > > > > > > > > On Nov 8, 2011, at 12:30 PM, Lanny Fetterman wrote: > >> >> A friend of mine, and I are looking for land, to put in our own landing strip. There is NO hanger space where I fly from now and I am getting too old to drag my FSII up onto my trailer each time I fly. ( not to mention we feel the land would be a good investment). Has anyone done this, and what hoops must you jump through before buying the land? This would NOT be open to the general public, and only he and I would take off and land there. Thanks in advance for any guidance you can offer. Lanny N598LF >> >> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Nov 09, 2011
> Including mine there are four grass strips within 2 miles. Not much fear of collisions as I'm the only one > who flies with any regularity. We are fortunate to be in an agricultural district which usually is aviation friendly. > None of us ever attempted to comply with any local regs or zoning. -but we have all been established for over thirty years. > > Despite that, it is obviously important to maintain friendly relationships with neighbors. I make a practice of NEVER > flying over a house, nice guy or not. One comment someone offered that aerial photos of homes make a big impact. > I put them on CD and give them to the owners. > BB > MkIII, suzuki > still nice here today Mornin' Mr. Bob, Important to maintain friendly relations, I agree. John's idea of photos is a nice touch. But you can never bet the farm on that one anal butthead that just can't keep their nose out of everyone else's business. I seem to recall a story about someone complaining about "those dangerous ultralights" flying out of Sandpoint Airport, N. Idaho. The airport manager kicked ALL ultralights out of the airport. IF a guy 'already' owns the land, then putting in a landing strip isn't that much of a gamble, because you already own the land and the most someone can say is "no, you can't do that". What I'm cautioning is, 'buying' the land first, and then expecting to do whatever you want. Maybe you can....and maybe you can't. Too much risk, when it was easier to ask P & Z first. Then, if that butthead complains, you know you don't have anything to fear if the 'regs' say it's ok. My friend that put in his landing strip and hangar, put it out way past any houses. That was also far enough out that when someone broke into his hangar, they knew there'd be no one around to catch them. Be sure to include some kind of security precautions in your hangar (motion lights, alarms, fake or real cameras, signs threatening they are being video'd, etc) There definitely are parts of the country that are more 'lightplane" friendly than others. There's also lots of places with old farts with NOTHING better to do than to cause trouble. I lived next door to one, three years ago!!!!! Mike ________________________________________________________________________________
Subject: Re: Fun at Sunset
Date: Nov 10, 2011
A couple more for your entertainment... :D At the local RC field... http://www.youtube.com/watch?v=jviqf8mxhww Stalked by a VariEze... http://www.youtube.com/watch?v=Xa-VPEQ0YFw -------- 2000 Firestar II R503 DCDI VLS 750 2010 Waiex Jabiru 3300 2020 Pitts Special S-1C Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357402#357402 ________________________________________________________________________________
Date: Nov 10, 2011
That was very good Kip! That Vari-eze tried to slow down as much as he could ... Thanks, Ralph B not not archive -------- Ralph B Original Firestar 447 N91493 E-AB 1000 hours 24 years flying it Kolbra 912UL (engine and avionics stolen on 5/17/11. Hanger break-in) N20386 done flying it 150 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357416#357416 ________________________________________________________________________________
Date: Nov 10, 2011
Subject: twin cam ?
hey Kolbers is this a twin cam ?sorry to be off subject Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly ________________________________________________________________________________
Date: Nov 10, 2011
Way to go Kip! Just challenge him to a slow flight contest. -----Original Message----- From: Kip <klaurie(at)mindspring.com> Sent: Thu, Nov 10, 2011 3:44 pm Subject: Kolb-List: Re: Fun at Sunset A couple more for your entertainment... :D At the local RC field... http://www.youtube.com/watch?v=jviqf8mxhww Stalked by a VariEze... http://www.youtube.com/watch?v=Xa-VPEQ0YFw -------- 2000 Firestar II R503 DCDI VLS 750 2010 Waiex Jabiru 3300 2020 Pitts Special S-1C Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357402#357402 ________________________________________________________________________________
Date: Nov 10, 2011
Hehe. I had it wound up pretty good just so he would not pass by during the slow flight... zeprep251(at)aol.com wrote: > Way to go Kip! Just challenge him to a slow flight contest. > > > > > > -- -------- 2000 Firestar II R503 DCDI VLS 750 2010 Waiex Jabiru 3300 2020 Pitts Special S-1C Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357427#357427 ________________________________________________________________________________
Date: Nov 11, 2011
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 11, 2011
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Subject: Re: twin cam ?
Gorgeous shot of a single seat Maxair Drifter - just like the one I've been flying for about 20 years.=0A=0AArty Trost=0ASandy, Oregon=0A=0A-=0Awww. LessonsFromTheEdge.com/oshkosh/=0A=0A=0A"Life's a daring adventure or nothi ng"=0AHelen Keller=0A=0A=0A"I refuse to tip toe through life just to arrive safely at death."=0A=0A=0A________________________________=0AFrom: chris d avis =0ATo: "kolb-list(at)matronics.com" =0ASent: Thursday, November 10, 2011 3:05 PM=0ASubject: Kolb-List: twin cam ?=0A=0A=0Ahey Kolbers is this a twin cam ?sorry to be off subject =0A=0A-=0AChris Davis=0AKXP 503 492 hrs=0AGlider Pilot=0ADisabled from cr ________________________________________________________________________________
Date: Nov 11, 2011
From: william sullivan <williamtsullivan(at)att.net>
- Arty- Just out of curiosity, have you ever tried a Kolb?- Your opinio n, for comparison purposes.- And thanks for all the great stories. ------------------------- --------------------- Bill Sulliv an ------------------------- --------------------- Windsor Loc ks, Ct. ------------------------- --------------------- FS 447 --- On Fri, 11/11/11, TheWanderingWench wrote : From: TheWanderingWench <thewanderingwench(at)yahoo.com> Subject: Re: Kolb-List: twin cam ? Date: Friday, November 11, 2011, 9:44 AM Gorgeous shot of a single seat Maxair Drifter - just like the one I've been flying for about 20 years. Arty TrostSandy, Oregon-www.LessonsFromTheEdge.com/oshkosh/ "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe through life just to arrive safely at death." From: chris davis <capedavis(at)yahoo.com> Sent: Thursday, November 10, 2011 3:05 PM Subject: Kolb-List: twin cam ? =0Ahey Kolbers is this a twin cam ?sorry to be off subject =0A=0A-=0AChris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly=0Ahttp://www.matro====== ===============0A=0A ========================0A=0A ________________________________________________________________________________
Subject: condition inspections
Date: Nov 11, 2011
I highly recommend this Mike Busch webinar. It is long, about 1.5 hours, but worth your time. http://www.eaavideo.org/video.aspx?v=1268563560001 -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Truth is what stands the test of experience. - Albert Einstein Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357519#357519 ________________________________________________________________________________
Subject: Concrete or Chiropractor !
Date: Nov 11, 2011
A Crushed Rock Hangar Floor was not a good Idea. I spent all week putting in concrete. Busted my buns, but was well worth it ! -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern These flying machines are just a fad and will never catch on Unknown Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357572#357572 Attachments: http://forums.matronics.com//files/let_there_be_concrete_194.jpg ________________________________________________________________________________
Subject: Re: Concrete or Chiropractor !
Date: Nov 11, 2011
It depends on how it's done. The worst enemy of equipment stored is moisture. -rising up through the ground. I never had that problem with my old shed up on the strip because it is so well drained. My new barn, on the other hand, is located just a few feet from the foot of a large hill which exudes bounteous quantities of H2O. In this case, in addition to several hundred feet of subterranean plastic tile, I spread heavy black plastic, covered with several inches of fine crushed stone. The barrier has given me a dry floor. Nonetheless, I shall be paving the whole works with 5 inches of reinforced concrete next year. BB MkIII, suzuki semi retired On Nov 11, 2011, at 4:29 PM, Dennis Thate wrote: A Crushed Rock Hangar Floor was not a good Idea. I spent all week putting in concrete. Busted my buns, but was well worth it ! -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern These flying machines are just a fad and will never catch on Unknown Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357572#357572 Attachments: http://forums.matronics.com//files/let_there_be_concrete_194.jpg ________________________________________________________________________________
Subject: Re: condition inspections
Date: Nov 12, 2011
Yes it was good, and it also does a great job of demonstrating a huge change in the focus of the EAA, and why I am no longer a member. The entire focus of the webinar was that the owner is not the builder, and does not do his/her own maintainance. The webinar was more for the owner of a Cessna or Piper than for a homebuilder, and this is the direction that the EAA is currently progressing in. Over the last few years, they have begun transitioning from being the Experimental Aircraft Association to being the Recreational Aircraft Association, with "Recreational" to include anything and everything that flies, on the assumption that somebody is enjoying it. And the EAA would like to that person to become a member and send money to Oshkosh, and come spend money at "Airventure." And instead of encouraging their chapters to have fly-in's with spot landing contests, and flower bomb contests, they want you to instead spend an exhausting day taking kids for rides. (Many of whom could apparently care less, since they don't even say "Thank you") Sorry to be such an old curmudgeon on such a pretty day, but that's how I see it. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357617#357617 ________________________________________________________________________________
Date: Nov 12, 2011
BB You are absolutely correct about the moisture issue. I did put a plastic layer barrier under my pour before hand. -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern These flying machines are just a fad and will never catch on Unknown Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357622#357622 ________________________________________________________________________________
Date: Nov 12, 2011
Thom Riddle wrote: > Richard, > > The reason I posted the link is that there are lots and lots of Kolbers who did not build the Kolb they are flying (me included) and are not A&P mechanics. These folks must get an A&P to do their inspection logbook entry and might benefit from at least part of the presentation. > > And a perfectly good reason it is. Please forgive me if I sounded critical, I did not mean to be. I was just venting. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357645#357645 ________________________________________________________________________________
Subject: Utah Desert
Date: Nov 12, 2011
After watching the posted videos from the Kolbers in the east=2C I feel somewhat sheepish sharing this video. I need to find a better place for the camera mount. Not only that=2C the haze in the air detracted from the majestic mountains. Critiques are welcome. I am learning what looks good in a video. http://www.youtube.com/watch?v=dzlqpWF2hEs&feature Kurt South of Salt Lake City Kolb FSII Rotax 503 ________________________________________________________________________________
Subject: Re: Utah Desert
Date: Nov 12, 2011
I liked it. Is that a go kart track or a sports car course behind your field? What sort of camera mount are you using, it doesn't have much vibration. And what kind of camera? Also, what computer program are you using to edit and add music to your video? My camera films in Quicktime, but if you add music in Quicktime Pro, when you upload it to Youtube, it discards the music track. So I add the music in Windows Live Movie Maker, but that is not a user friendly program, and it has a lot of limitations. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357650#357650 ________________________________________________________________________________
Date: Nov 12, 2011
The track you can see to the west of the field is a police training course. The camera I use is a Go-Pro with 1080P. I use a bicycle handlebar mount on the cage. I have noticed the harmonics of the engine does transfer to the video. As the RPM of the engine changes=2C the picture tends to become dist orted similar to a heat wave appearance. I am going to use the chest strap next time and see how it looks. I can=92t use the helmet strap. I am 6-2 an d I have just enough head room for the top piece of my headset. I will be moving the camera around in the future. The camera has a port for a microphone jack. I also want to try and hook it to my radio box to get the radio traffic. I have enjoyed watching the video of the other Kolbers. Larry Cotrell in Or egon has provided some great desert video. The editing program is the Microsoft software that came with my computer. I t is working okay for now. Thanks for the response. Kurt Kolb FSII Rotax 503 > Subject: Kolb-List: Re: Utah Desert > From: richard(at)bcchapel.org > Date: Sat=2C 12 Nov 2011 15:47:13 -0800 > To: kolb-list(at)matronics.com > > > I liked it. Is that a go kart track or a sports car course behind your fi eld? > > What sort of camera mount are you using=2C it doesn't have much vibration . And what kind of camera? > Also=2C what computer program are you using to edit and add music to your video? My camera films in Quicktime=2C but if you add music in Quicktime P ro=2C when you upload it to Youtube=2C it discards the music track. So I ad d the music in Windows Live Movie Maker=2C but that is not a user friendly program=2C and it has a lot of limitations. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > richard (at) bcchapel(dot)org > Kingsport=2C TN 3TN0 > Now faith is the substance of things hoped for=2C the evidence of things not seen. > Hebrews 11:1 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=357650#357650 > > > > > > > =========== =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Nov 13, 2011
Subject: Make Sure You're Listed! List of Contributors Published in
December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 13, 2011
You have a nice playground, there... [Shocked] -------- 2000 Firestar II R503 DCDI VLS 750 2010 Waiex Jabiru 3300 2020 Pitts Special S-1C Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357746#357746 ________________________________________________________________________________
Subject: in-flight video
Date: Nov 13, 2011
This could be the most spectacular in-flight video you'll ever see. NOT taken from a Kolb, therefore not Kolb precisely Kolb related http://vimeo.com/32001208 Be sure to go to full screen, the bigger the better. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Truth is what stands the test of experience. - Albert Einstein Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357759#357759 ________________________________________________________________________________
Subject: Nauga 2011 (video link inside)
Date: Nov 13, 2011
Just got back from Nauga 2011 today and thought I would put together a quick video on youtube. I spent more time talking than taking video so I did not have a bunch to splice together. I had a good time and met some great people there. (and ate way too much). Hopefully some others in attendance have some videos of their own that they can post. Travis Bennett http://www.youtube.com/watch?v=v8owLkywDKM&feature=feedu Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357768#357768 ________________________________________________________________________________
Date: Nov 13, 2011
Just got back from Nauga 2011 Travis Bennett http://www.youtube.com/watch?v=v8owLkywDKM&feature=feedu Hi Travis/Folks: Thanks for posting. We had a ball. Thanks to John Bickham and Sandie, and the rest of the Starhill Gang that helped John B host a terrific event. Emphasis this year was remembering our good friend and fellow Kolb pilot, John Williamson, RIP Brother. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: Nauga 2011 (video link inside)
Date: Nov 13, 2011
Thanks Travis, Nice video!! Kind words.. Glad you and others passed a good time! You and James are now on the short list of pilots with Nauga Field (LS35) in the logbook. Way to go! Best news, everyone arrived, enjoyed, and then made it home safely! All home and accounted for. Don't get no better than that. "IronMan Kolb Pilot" award goes to Jimmy Young and his HKS Firestar. He fought some stiff headwinds to get home. I think he said he logged 6 hrs and 34 mins to get home. At one point, 24 mph groundspeed. True Kolb grit! Sandy resting. She done good! Looking forward to the next time we can get together already. Come visit anytime. -------- Thanks too much, John Bickham Mark III-C w/ 912UL St. Francisville, LA I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357776#357776 ________________________________________________________________________________
Date: Nov 14, 2011
The two best Fly-Ins I've ever been to were both at Nauga Field. The slogan "many bigger, non better" is a perfect description, thanks to the effort of Sandie & John Bickham and the rest of the Starhill gang. It was good to see friends again and meet new ones like Travis Bennett, the youngster of the group at 37, and Larry Cottrell, who I've spoken with many times but never met in person. John B - regarding my trip home, I don't qualify for any "iron man" status in the world of Kolb flying but I'll accept a "bladder man" award. I believe my body weight gain while at Nauga slowed me down as much as that headwind. I did a little scud-running to get home quicker. The higher I flew the stronger the headwinds, & down low it was a bumpy ride home. I picked speed over comfort. In my boredom I made a quick, poor-quality video cruising the Intercoastal between Port Arther and Galveston. Thanks for a great weekend - http://youtu.be/0AIjHmsbaUc -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357796#357796 ________________________________________________________________________________
Date: Nov 14, 2011
Based on the video, I'd say you were definitely busy keeping things straight and level. Good video! -- Robert On Mon, Nov 14, 2011 at 4:42 AM, Jimmy Young wrote: > > The two best Fly-Ins I've ever been to were both at Nauga Field. The > slogan "many bigger, non better" is a perfect description, thanks to the > effort of Sandie & John Bickham and the rest of the Starhill gang. It was > good to see friends again and meet new ones like Travis Bennett, the > youngster of the group at 37, and Larry Cottrell, who I've spoken with many > times but never met in person. > > John B - regarding my trip home, I don't qualify for any "iron man" status > in the world of Kolb flying but I'll accept a "bladder man" award. I > believe my body weight gain while at Nauga slowed me down as much as that > headwind. > > I did a little scud-running to get home quicker. The higher I flew the > stronger the headwinds, & down low it was a bumpy ride home. I picked > speed over comfort. In my boredom I made a quick, poor-quality video > cruising the Intercoastal between Port Arther and Galveston. > > Thanks for a great weekend - > > http://youtu.be/0AIjHmsbaUc > > -------- > Jimmy Young > Missouri City, TX > Kolb FS II/HKS 700 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=357796#357796 > > ________________________________________________________________________________
Date: Nov 14, 2011
I did a little scud-running to get home quicker. The higher I flew the stronger the headwinds, & down low it was a bumpy ride home. I picked speed over comfort. Jimmy Young Jimmy Y/Gang: >From your video I can tell how turbulent it was by watching the airspeed indicator. Flight conditions for James Tripp (MKIII) and me (MKIII) were just the opposite of Jimmy's. We all flew from Nauga Field west across the Mississippi to False River Airport to refuel. James and I departed to the NE. At 1,000 feet at 80 mph our ground speed was 105 mph, but turbulent. At 2,000 it was 108. At 3,000 about 110. At 4,000 feet we settled down to 114, give or take a few. We flew for 3.2 hours nonstop, covered 337 sm. Above 3,000 feet it was smooth as silk. We also saved 5 gal of 100LL over our flight west to Nauga. We got 17 mpg west and 22.5 east. As I approached Gantt IAP I started my decent out of 4,000. When I hit 3,000 it was like riding a wild horse. When conditions are like this I know I am going to have an exciting time getting back into Gantt IAP which is lined by very tall trees (turbulence generators) on three sides. However, we made it one more time and 750 feet of grass was more than enough to return to earth. Here is a couple photos of us and our airplanes. john h mkIII-3,114.2 hours 912ULS- 545.7 hours Titus, Alabama ________________________________________________________________________________
Date: Nov 14, 2011
Gang, After I watched Jimmy Young's video, the following one presented itself on the site. Bunch of Ultrastars having fun! Anyone know the age or location of the video, or seen it before? http://www.youtube.com/watch?v=5NVT1VkBDWE Dave Kulp Bethlehem, PA FireFly 11DMK On 11/14/2011 5:42 AM, Jimmy Young wrote: > --> Kolb-List message posted by: "Jimmy Young" > > The two best Fly-Ins I've ever been to were both at Nauga Field. The slogan "many bigger, non better" is a perfect description, thanks to the effort of Sandie& John Bickham and the rest of the Starhill gang. It was good to see friends again and meet new ones like Travis Bennett, the youngster of the group at 37, and Larry Cottrell, who I've spoken with many times but never met in person. > > John B - regarding my trip home, I don't qualify for any "iron man" status in the world of Kolb flying but I'll accept a "bladder man" award. I believe my body weight gain while at Nauga slowed me down as much as that headwind. > > I did a little scud-running to get home quicker. The higher I flew the stronger the headwinds,& down low it was a bumpy ride home. I picked speed over comfort. In my boredom I made a quick, poor-quality video cruising the Intercoastal between Port Arther and Galveston. > > Thanks for a great weekend - > > http://youtu.be/0AIjHmsbaUc > > -------- > Jimmy Young > Missouri City, TX > Kolb FS II/HKS 700 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=357796#357796 > > ________________________________________________________________________________
Date: Nov 14, 2011
Anyone know the age or location of the video, or seen it before? http://www.youtube.com/watch?v=5NVT1VkBDWE Dave Kulp Dave K/Gang: That video was made at Sun and Fun, Lakeland, FL, March 1984. The white Ultrastar is the Kolb Factory US flown by a very young Dennis Souder. He could make that little airplane do just about anything but hover. It was amazing to watch him fly. That was Sun and Fun was number one for me, one of 27 consecutive S&F's I have attended. I sent Homer Kolb a check for $3,495.00, the month prior. When I left to drive to Lakeland I had already received the Builder's Manual and the Plans to build my Ultrastar. When I got back from Lakeland I had a call to come up to the country store and pick up some stuff the UPS man had dropped off. It was my Cuyuna ULII02 and some parts for my new airplane. Three months later I flew my US for the first time. I had never flown anything but Army helicopters. Was not qualified to fly a fixed wing aircraft. Took two landings to get the hang of flying an fixed wing US. The first landing I wiped out the main gear and broke the prop. My landing was ok. The damage occurred when I landed at the wrong end of my 600 foot unimproved airstrip in the same cow pasture I have been flying out of for the past 27 years. Had no brakes. Overran the knoll at the north end of the strip, down the hill and through a cow path that was just deep enough to take my main gear off. Those were the good old days. Since those days I have logged nearly 7,000 landings and still can't do it very well. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Ultralight History
Date: Nov 14, 2011
Folks: Never thought I would see this Lazair on floats fly again, but found it after watching the Ultrastars fly at S&F 1984. http://www.youtube.com/user/OldChuckie#p/a/u/2/CaVLBrv4eQQ At the same S&F 1984, there was an ultralight ditch filled with water that served at the UL Seaplane Base in the UL area. One of the prettiest of the float equipped ULs was an Ultrastar, red and white sunburst, on fiberglass floats. There was also this 4 engine Lazair on floats. As you will see, the pilot flew barefooted with his britches legs rolled up. He must have had a little of Dick Rahill's (Kolb Firestar Factory Pilot) blood in him because he flew almost continually. Take off, very short circuit and plop back down in the ditch, just to take off again. Those were extremely good days. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 14, 2011
Somebody posted that awhile ago... I believe it's Homer Kolb, and perhaps Dennis Souder. -Dana At 11:57 AM 11/14/2011, David Kulp wrote: > >Gang, > >After I watched Jimmy Young's video, the following one presented itself on >the site. Bunch of Ultrastars having fun! Anyone know the age or >location of the video, or seen it before? > >http://www.youtube.com/watch?v=5NVT1VkBDWE -- The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government. - Thomas Jefferson ________________________________________________________________________________
Date: Nov 14, 2011
Dennis Souder!!!!!! Flying sideways about 5' AGL!!! I'd heard a lot about his expertise, including folding a wing testing G forces and throwing out a handheld 'chute, but never saw him fly. Now I have a much better picture. Thanks, John. BTW, saw you land a number of times at Homer's fly-in and you sure looked good to me. One or two bent gear legs in 7K landings is a pretty noteworthy record, especially considering some of the places you've landed in the NW. Thanks again for the info, John, Dave Kulp FireFly 11DMK Bethlehem, PA On 11/14/2011 12:20 PM, John Hauck wrote: > --> Kolb-List message posted by: "John Hauck" > > Anyone know the age or location of the video, or seen it before? > > http://www.youtube.com/watch?v=5NVT1VkBDWE > > Dave Kulp > > > Dave K/Gang: > > That video was made at Sun and Fun, Lakeland, FL, March 1984. > > The white Ultrastar is the Kolb Factory US flown by a very young Dennis > Souder. He could make that little airplane do just about anything but > hover. It was amazing to watch him fly. > > That was Sun and Fun was number one for me, one of 27 consecutive S&F's I > have attended. I sent Homer Kolb a check for $3,495.00, the month prior. > When I left to drive to Lakeland I had already received the Builder's Manual > and the Plans to build my Ultrastar. When I got back from Lakeland I had a > call to come up to the country store and pick up some stuff the UPS man had > dropped off. It was my Cuyuna ULII02 and some parts for my new airplane. > Three months later I flew my US for the first time. I had never flown > anything but Army helicopters. Was not qualified to fly a fixed wing > aircraft. Took two landings to get the hang of flying an fixed wing US. > The first landing I wiped out the main gear and broke the prop. My landing > was ok. The damage occurred when I landed at the wrong end of my 600 foot > unimproved airstrip in the same cow pasture I have been flying out of for > the past 27 years. Had no brakes. Overran the knoll at the north end of > the strip, down the hill and through a cow path that was just deep enough to > take my main gear off. Those were the good old days. > > Since those days I have logged nearly 7,000 landings and still can't do it > very well. > > john h > mkIII > Titus, Alabama > > ________________________________________________________________________________
Date: Nov 14, 2011
Somebody posted that awhile ago... I believe it's Homer Kolb, and perhaps Dennis Souder. -Dana Wasn't Homer flying. Only time I can remember Homer flying at Lakeland was once in the 1985 Factory Firestar that went on to take the Gold Lindy Trophy for 1985 Oshkosh Grand Champion Ultralight. Homer flew my newly rebuilt Firestar at S&F 1989. Got photos of both around here somewhere. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 14, 2011
BTW, saw you land a number of times at Homer's fly-in and you sure looked good to me. One or two bent gear legs in 7K landings is a pretty noteworthy record, especially considering some of the places you've landed in the NW. Thanks again for the info, John, Dave Kulp Dave K/Gang: I wish that were true, just a couple bent gear legs. I've wiped the main gear off my mkIII twice, and I could not tell you how many times I bent and broke landing gear on the Ultrastar and Firestar. The one thing I have never done is bend somebody else's Kolb, but I sure have bent mine. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 14, 2011
Subject: John Cooley out there?
Tried to email you but it kicked back...shoot me a note... -- */Jeremy Casey/* */Jeremy(at)kilocharlie.us /* ________________________________________________________________________________
Date: Nov 14, 2011
Subject: Re: John Cooley out there?
Hi Jeremy, Here's a note. Got yours OK. Dave Kulp On 11/14/2011 3:15 PM, 1planeguy wrote: > Tried to email you but it kicked back...shoot me a note... > -- > > */Jeremy Casey/* > > */Jeremy(at)kilocharlie.us /* > * > > > * ________________________________________________________________________________
Subject: Nose wheel on a Kolb MK3X
Date: Nov 14, 2011
I have not worked on my MKx in quite a while but have been re-motivated with the thought of building it with the new nose wheel option. What do you guys think about this option? -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357860#357860 ________________________________________________________________________________
Date: Nov 14, 2011
Subject: Firefly landing gear dimensions, please?
To the Kolb list: - I am modifying my newly bought TSC trailer and I need the wheelbase and tai l wheel dimensions for the Kolb Firefly. My Firefly kit is arriving soon (m y 2nd Kolb), and I'm laying out the trailer in the meantime. Can anyone out there with a Firefly give me the spread between the centerli ne of the tires and the length to the tail wheel? Also the length to where you are currently supporting the tail boom for transport. Much obliged! Phil H. http://phactor.com/i/f2.jpg - ________________________________________________________________________________
Subject: Re: Nose wheel on a Kolb MK3X
Date: Nov 14, 2011
Hi Rick, I think it could be a good idea. I'll work with ya on the design. I've already scribbled a drawing just for grins. BTW, what do you mean "with the new nose wheel option"? Are you referring to the Firestar's new front wheel or has Kolb Aircraft come up with a new bolt-on option for the MkIIIX? (or will the Firestar front wheel work with either one?) Mike Welch On Nov 14, 2011, at 4:14 PM, Rick Lewis wrote: > > I have not worked on my MKx in quite a while but have been re-motivated with the thought of building it with the new nose wheel option. What do you guys think about this option? > > -------- > Rick Lewis > > (VW Watercooled Engine) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=357860#357860 > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Ultralight History
Date: Nov 14, 2011
Ah, yes! The Good Old Days! Thank you! -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357873#357873 ________________________________________________________________________________
Date: Nov 14, 2011
John, Yup very young, and apparently feeling very invincible. The guy sits down and takes off ,,,,, no seat belt? ? ? ,,,,,, in an Ultrastar ???? I'll bet the man now wishes that little bit of "bravery" was not quite clearly so documented. Gene, On Nov 14, 2011, at 12:20 PM, John Hauck wrote: > The white Ultrastar is the Kolb Factory US flown by a very young Dennis > Souder. He could make that little airplane do just about anything but > hover. It was amazing to watch him fly. ________________________________________________________________________________
Date: Nov 14, 2011
John, Just a quick question.Your gear legs,alum or steel? G.Aman -----Original Message----- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Mon, Nov 14, 2011 9:07 am Subject: RE: Kolb-List: Re: Nauga 2011 (video link inside) I did a little scud-running to get home quicker. The higher I flew the stronger the headwinds, & down low it was a bumpy ride home. I picked spee d over comfort. Jimmy Young Jimmy Y/Gang: >From your video I can tell how turbulent it was by watching the airspeed indicator. Flight conditions for James Tripp (MKIII) and me (MKIII) were just the opposite of Jimmy's. We all flew from Nauga Field west across the Mississippi to False River Airport to refuel. James and I departed to the NE. At 1,000 feet at 80 mp h our ground speed was 105 mph, but turbulent. At 2,000 it was 108. At 3,00 0 about 110. At 4,000 feet we settled down to 114, give or take a few. We flew for 3.2 hours nonstop, covered 337 sm. Above 3,000 feet it was smooth as silk. We also saved 5 gal of 100LL over our flight west to Nauga. We got 17 mpg west and 22.5 east. As I approached Gantt IAP I started my decent out of 4,000. When I hit 3,000 it was like riding a wild horse. When conditions are like this I kno w I am going to have an exciting time getting back into Gantt IAP which is lined by very tall trees (turbulence generators) on three sides. However, we made it one more time and 750 feet of grass was more than enough to return to earth. Here is a couple photos of us and our airplanes. john h mkIII-3,114.2 hours 912ULS- 545.7 hours Titus, Alabama ________________________________________________________________________________
Date: Nov 14, 2011
At 05:14 PM 11/14/2011, Rick Lewis wrote: > >I have not worked on my MKx in quite a while but have been re-motivated >with the thought of building it with the new nose wheel option. What do >you guys think about this option? Why put a training wheel on a perfectly good taildragger? -Dana -- Alcohol, tobacco and firearms should be a convenience store, not a government agency. ________________________________________________________________________________
Subject: Re: Firefly landing gear dimensions, please?
Date: Nov 14, 2011
Hey Phil, Nice wing walker. ; ) Gene, On Nov 14, 2011, at 5:15 PM, Phil wrote: > Much obliged! > Phil H. > http://phactor.com/i/f2.jpg > ________________________________________________________________________________
Date: Nov 14, 2011
John, Just a quick question.Your gear legs,alum or steel? G.Aman My gear legs on the MKIII, and the original Firestar, are/were 4130. Both use .120" X 1 1/8" tubing. My tail wheel strut is .125 X 3/4" 4130. Everything heat treated to RC48. They make good spring, but are not hard enough to break. I have bent the gear legs 90 degrees before. I use a 24" long leg on the MKIII with 6" inserted into the socket. James Tripp is using my old Firestar gear legs, which were 35.5" long, cut to 24" on his MKIII with Jim Hauck main gear. The main gear on my Ultrastar was rigid and 4130 tubing. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 14, 2011
The guy sits down and takes off ,,,,, no seat belt? ? ? ,,,,,, in an Ultrastar ???? Gene, Gene/Gang: Look at the clip again. Looks, to me, like he cranks, gets in, and taxies to take off. As he flies back by the camera, I think I can see the seat belt attached. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 14, 2011
Thanks. That's my 1988 Twinstar. No canopy, nosecone, enclosure, just bugs- in-the-teeth flying. I miss it very much. I'm at a point in my life now tha t I have my own little home in Tennessee, I'm totally gearing up my garage into a shop (on the dirt-cheap), and it's time to fly again. I live RIGHT n ext to Dallas Bay Skypark - 1A0 - and I have my Firefly on order; my 2nd Ko lb - I get it in a couple of weeks. But right now I sure could use some Firefly dimensions! The plans have none for the cage or landing gear. I keep my ICON IC-A5 on in the garage and listen to the guys out at the fie ld. The Kolb is, hands-down, the winner in my book. I'm keeping my new Firefly 103 legal. I get the kit(s) sometime around Than ksgiving weekend. At some point later I might fab my own nosecose and fairi ng. Phil http://phactor.com/222.jpg http://phactor.com/i/f1.jpg http://phactor.com/i/f3.jpg - --- On Mon, 11/14/11, Eugene Zimmerman wrote: From: Eugene Zimmerman <etzimm(at)gmail.com> Subject: Re: Kolb-List: Firefly landing gear dimensions, please? Date: Monday, November 14, 2011, 7:21 PM Hey Phil, Nice wing walker. - ; ) Gene, On Nov 14, 2011, at 5:15 PM, Phil wrote: Much obliged! Phil H. http://phactor.com/i/f2.jpg ________________________________________________________________________________
Date: Nov 14, 2011
Thanks Mike for the reply. Kolb has NOT afford an option for the MKX, as far as I know, but they have impressed me with what they have done so far on this. I talked to Brian today about this modification on the MKX and I will be going to see them in a fews days to look at a prototype. If others are interested in this I will submit pictures that I take. I Will be looking for other positive replies on this. -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357887#357887 ________________________________________________________________________________
Date: Nov 14, 2011
And why not?? Nobody is asking ya to put one on yours. -------- Kolb Mark IIIX 582 Blue head Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357889#357889 ________________________________________________________________________________
Date: Nov 14, 2011
Thanks ss568 for the remark -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357890#357890 ________________________________________________________________________________
Date: Nov 14, 2011
Rick, I would be interested in converting my mk 3 to a tri . If you get some pictures they would be appreciated. Thanks, David d. -------- Kolb Mark IIIX 582 Blue head Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357892#357892 ________________________________________________________________________________
Date: Nov 14, 2011
Cool.... [Twisted Evil] -------- 2000 Firestar II R503 DCDI VLS 750 2010 Waiex Jabiru 3300 2020 Pitts Special S-1C Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357893#357893 ________________________________________________________________________________
Date: Nov 14, 2011
Yes John, Upon a closer look, I believe you are correct. I just remembered how close those seat belts could get to the prop if you ever forgot to secure them. The ultrastar was one of the sweetest flying planes Homer ever sold. Prop ground clearance was its main draw back. Gene On Nov 14, 2011, at 7:52 PM, John Hauck wrote: > Gene/Gang: > > Look at the clip again. Looks, to me, like he cranks, gets in, and taxies to take off. As he flies back by the camera, I think I can see the seat belt attached. > > john h > mkIII > Titus, Alabama ________________________________________________________________________________
Date: Nov 14, 2011
Gene, I do remember landing at SNF one time with the seat belt not fastened, but I think that was in a FS. But even if I did that in an UltraStar and that was the most stupid thing I ever did . I'd feel much better. Fact is, I did far more stupid things than that - there just wasn't a camera pointing at me. Dennis From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Eugene Zimmerman Sent: Monday, November 14, 2011 7:05 PM Subject: Re: Kolb-List: Re: Nauga 2011 (video link inside) John, Yup very young, and apparently feeling very invincible. The guy sits down and takes off ,,,,, no seat belt? ? ? ,,,,,, in an Ultrastar ???? I'll bet the man now wishes that little bit of "bravery" was not quite clearly so documented. Gene, On Nov 14, 2011, at 12:20 PM, John Hauck wrote: The white Ultrastar is the Kolb Factory US flown by a very young Dennis Souder. He could make that little airplane do just about anything but hover. It was amazing to watch him fly. ________________________________________________________________________________
Date: Nov 14, 2011
Just curious....Why don't you like the tail dragger version??? They are so easy to handle...not sure why you would want to go through the extra work....Please post the pictures ..I would never do it ,but would like to see how they set it up... chris ambrose M3X/Jabiru A-2200 238.hrs N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357901#357901 ________________________________________________________________________________
Date: Nov 15, 2011
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some pointd, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for over 21 years (yeah, I really said *21* years) worth of on line archive data available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power this List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 15, 2011
On Nov 14, 2011, at 10:26 PM, Dennis Souder wrote: > Gene, > > I do remember landing at SNF one time with the seat belt not fastened, but I think that was in a FS. > But even if I did that in an UltraStar and that was the most stupid thing I ever did =85 I=92d feel much better. > Fact is, I did far more stupid things than that ' there just wasn=92t a camera pointing at me. > > Dennis Dennis, Hey man trust me, I know what you mean about "stupid" and the pointing camera also. Ain't God good! Gene ________________________________________________________________________________
Subject: Link to Nauga 2011 Pics
Date: Nov 15, 2011
For those that are interested, here is a link to pics I took through the weekend: http://kolbadventures.shutterfly.com/506 Just press the button on the camera and hope for the best! -------- Thanks too much, John Bickham Mark III-C w/ 912UL St. Francisville, LA I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=357991#357991 ________________________________________________________________________________
Date: Nov 15, 2011
Folks: Right off hand I can think of a couple things that a nose gear might affect on a MKIIIx or a MKIIIc. -The nose wheel and mount will add a lot more weight and drag than a tail wheel. -We already have an inherent problem with a high mounted pusher configuration. The high thrust line wants to push the nose of the aircraft down. Takes a lot of nose up trim to keep it happy. If we add a nose wheel, it will add to the nose down trim problem. Low drag up front will combine with a high thrust line to try and push the nose down even more. The standard main gear on Kolb aircraft places most of the weight on the main gear with a light tail wheel. It is very easy to handle on the ground. As easy, or more so, than tricycle gear. That is why Homer designed it that way. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 15, 2011
John Valid points...but---- Looks as if we already have a similar configuration with the Tri Firestar....The interview that I saw with Brian, indicated good flying qualities.. Maybe Travis will give us some feedback on the ground handling qualities and your concerns? Herb At 07:37 AM 11/15/2011, you wrote: > > > Folks: > >Right off hand I can think of a couple things that a nose gear might affect >on a MKIIIx or a MKIIIc. > >-The nose wheel and mount will add a lot more weight and drag than a tail >wheel. > >-We already have an inherent problem with a high mounted pusher >configuration. The high thrust line wants to push the nose of the aircraft >down. Takes a lot of nose up trim to keep it happy. If we add a nose >wheel, it will add to the nose down trim problem. Low drag up front will >combine with a high thrust line to try and push the nose down even more. > >The standard main gear on Kolb aircraft places most of the weight on the >main gear with a light tail wheel. It is very easy to handle on the ground. >As easy, or more so, than tricycle gear. That is why Homer designed it that >way. > >john h >mkIII >Titus, Alabama > > ________________________________________________________________________________
Date: Nov 15, 2011
Looks as if we already have a similar configuration with the Tri Firestar....The interview that I saw with Brian, indicated good flying qualities.. Herb Herb/Kolbers: I've never seen the new tri-gear Firestar, nor have I talked with the designer and test pilot. Know virtually nothing about it. I have flown a MKIIIx and am familiar with it. I think that is what we are talking about here, adding a nose gear to the MKIIIx. I am a tail wheel guy and partial to that configuration. This doesn't change the inherent problems mounting a nose gear on a MKIIIx will generate. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 15, 2011
We have machines here that started out as taildraggers, I had one. The change to the nose wheel option has happened without any drama and although I have no figures I would guess that the tricycle is now in the majority. I think you are wrong in describing the Xtra as `light on the tail`, mine certainly is not, although you are right in saying that it would require a major trim change to accommodate a front wheel. That would have to be a redistribution of weight rather that just trimming it out. I would certainly be interested in a trike gear but under our rules I suspect that I would have to jump through quite a few hoops to get it accepted on the register. I don`t think that I will bother. Pat ________________________________________________________________________________
Date: Nov 15, 2011
> I don`t think that I will bother. > > Pat Pat, others, I suspect the nosewheel/tailwheel argument is a lot like VGs, Mystery Oil, Seafoam, and a host of other unending discussions. Whether pro-tailwheel guys like it or not, there are probably lots of other guys who 'might' prefer a nosewheel. That doesn't make either side wrong, it just may be what we are used to, or have a preference for. Much like VGs, or NO VGs. That being said, without a doubt, to install a nosewheel on an Xtra would certainly require a heckava lot more than simply bolting on a ready-made front wheel. (IMO) The main gear's present location, which is designed for a taildragger weight distribution, would be a very poor place to adapt for a nosewheel. It should be placed several inches rearward (after proper design calculations). Plus, the added stresses a nosewheel would place on the very front portion of the fuselage would likely require some beefing up. In other words....done properly, a nosewheel Xtra would need a signifcant re-design, strengthening the front end and relocating the main gear mounts, maybe about 30" rearward or more. There may also be other design considerations...I would imagine. If Kolb Aircraft were to seriously tackle this concept; a) I would think the fuselage would require the appropriate modifications and new shape. b) there darn sure would be a market for a nosewheel Xtra c) it should be renamed, to clarify the distinction between nosewheel and tailwheel models. The idea that a high thrustline doesn't make for a good nosewheel airplane seems a little weak, to me. If I had to guess, I'd bet there are FAR more nosewheel/high engine lightplanes than there are tailwheel/high engine lightplanes. Titan Tornado, Quicksilvers, Carlsons, Rans S12, to name just a few. Whether there are more of one or the other, doesn't mean the opposite style won't work, especially when designed correctly. Just my humble little opinion. Mike Welch MkIII ________________________________________________________________________________
Date: Nov 15, 2011
I started flying nose dragging airplanes and may still have more hours in them than tail daggers. With all the stories around I was also concerned about the Kolb before I flew it. Bottom line it isn't as much the nose verses tail as it is the overall aircraft design. Of the planes that I have flown there is one nose wheel airplane that is much more difficult to fly (drive on the ground) than my Kolb and that is a Piper Saratoga. The higher landing/take off speeds with the weight of the plane makes this nose wheel airplane a challenge. Another plane I now rent in the winter, a Sport Cruiser has differential braking with no link to the castering nose wheel. This configuration took more adjustment than a Kolb. I will say that I once landed down wind on a paved runway and my Kolb was a challenge. The Kolb flying off grass is the easiest to handle of any airplane I have ever flown. So with that said get a flight in a Kolb before you add the weight, drag, and complexity to a perfectly fine airplane. Rick Neilsen 1st Redrive VW Powered MKIIIC On Tue, Nov 15, 2011 at 8:37 AM, John Hauck wrote: > > > Folks: > > Right off hand I can think of a couple things that a nose gear might affect > on a MKIIIx or a MKIIIc. > > -The nose wheel and mount will add a lot more weight and drag than a tail > wheel. > > -We already have an inherent problem with a high mounted pusher > configuration. The high thrust line wants to push the nose of the aircraft > down. Takes a lot of nose up trim to keep it happy. If we add a nose > wheel, it will add to the nose down trim problem. Low drag up front will > combine with a high thrust line to try and push the nose down even more. > > The standard main gear on Kolb aircraft places most of the weight on the > main gear with a light tail wheel. It is very easy to handle on the > ground. > As easy, or more so, than tricycle gear. That is why Homer designed it > that > way. > > john h > mkIII > Titus, Alabama > > ________________________________________________________________________________
Date: Nov 15, 2011
the entire time i was building my mkiii, my brother kept telling me that it needed a nose wheel... it needs a nose wheel,,, it needs a nose whee... so when it was done i took him for a ride, when i showed him some slow s turns down the runway with the tail in the air,,, and told him that this was the hardest part of flying a tail dragger, he said,,," guess it dont need a nose wheel, this dosent seem as bad as i had been led to believe." many pilots when starting with a tail dragger, get a bit behind what is going on and end up "stomping on snakes" when making adjustments to the rudder. if , or should i say when, you learn that you should use a constant steady pressure, and only enough to get the desired results, the tail dragger tames down and is no longer a scary monster. ask me how i know about the "stomping on snakes" my first few flights in a super cub,,, well i am glad the runway was 75 ft wide. and now landing on a 2 track road is doable. my 2 cents boyd young mkiii utah ________________________________________________________________________________
Date: Nov 15, 2011
> the tail dragger tames down and is no longer a scary monster. > > boyd young > mkiii utah Boyd, I suspect you are hitting the nail on the head the best. For those of us with little, or NO tailwheel time, I think all we want is a stable, unscary plane. Whether it is nosedragger, or taildragger, we mostly prefer non-wingdragger. Like Rick N. suggested, maybe we should just get a flight in a MkIII and relax. By all accounts, evidently Kolbs are some of the best taildraggers around. Mike W ________________________________________________________________________________
Date: Nov 15, 2011
The idea that a high thrustline doesn't make for a good nosewheel airplane seems a little weak, to me. If I had to guess, I'd bet there are FAR more nosewheel/high engine lightplanes than there are tailwheel/high engine lightplanes. Titan Tornado, Quicksilvers, Carlsons, Rans S12, to name just a few. Whether there are more of one or the other, doesn't mean the opposite style won't work, especially when designed correctly. Just my humble little opinion. Mike Welch MkIII Mike W/Folks: No argument here. I simply tried to contribute the effects of adding a nose wheel to a MKIIIx, probably with the big nose (I am assuming the gentleman has an older model MKIIIx). I didn't say, "a high thrust line doesn't make for a good nose wheel airplane." There is no comparison between a MKIIIx and "Titan Tornado, Quicksilvers, Carlsons, Rans S12, to name a few," when comparing nose and tail wheel aircraft. If and when you ever fly a MKIIIx, you will probably be immediately aware of the high thrust line and how it affects flight characteristics and performance, especially in cruise. Add a nose wheel to this characteristic and it will only add to the high thrust line effect. Sort of like riding a bicycle with one pedal. Then getting the other foot on a pedal and riding with two. Suddenly there is a lot more force being applied. The drag on the nose wheel will tend to compound the high thrust line and its characteristic of pushing down on the nose. I have no argument for or against, either nose or tail wheel, as I have no argument with or without VGs. I have been there and done that, with experience to back up my thoughts. My MKIII and the couple other MKIII's with Hauck mods are "real" tail draggers. Thom Riddle talks of his heavy tailed Slingshot. I can assure you the Hauck/MKIII has more weight and much longer arm than a Slingshot. I have flown both, many times, and can give a good comparison between my airplane and a Slingshot. It will be much harder for a low time Kolb pilot, or high time pilot of a standard built Kolb to adjust to my MKIII. However, once you get the hang of it, in a short time it becomes normal, and the benefits of not having to worry about getting your Kolb up on its nose, either from power application or terrain surface or taxiing in a tail wind will become quite apparent. In over 3,100 hours I have never had my MKIII attempt to get the tail high and the nose low while maneuvering on the ground in all types of terrain. I have put the Firestar, Firefly, and the factory MKIII on their noses at one time or the other. john h MKIII Titus, Alabama ________________________________________________________________________________
Date: Nov 15, 2011
Like Rick N. suggested, maybe we should just get a flight in a MkIII and relax. By all accounts, evidently Kolbs are some of the best taildraggers around. Mike W Mike W/Kolbers: Maybe get some "actual pilot time" in a MKIII will help get a better picture of that aircraft's handling characteristics. I find it difficult to make effective changes to a proven aircraft design without having actual experience flying that aircraft. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 15, 2011
my extra two cents.... I do not think it is about liking one design or the other...It is what sells...and allows one to stay in business... Innovation shows that Kolb is a viable company... I suspect that they could have sold many times as many planes had the nose dragger been in the stable... Most people train in that miserable straight jacket of a plane, the cessna 150, and most of the time their instructor has no tail time....It is during this stage that the tail dragger fear is instilled in the neophyte... Too...Kolb has to be concerned about what engines will be available in the near future... no 447 or 503 I hear... imho again Herb At 10:21 AM 11/15/2011, you wrote: > > > the tail dragger tames down and is no longer a scary monster. > > > > boyd young > > mkiii utah > > >Boyd, > > I suspect you are hitting the nail on the head the best. For > those of us with little, or NO >tailwheel time, I think all we want is a stable, unscary >plane. Whether it is nosedragger, or taildragger, >we mostly prefer non-wingdragger. > > Like Rick N. suggested, maybe we should just get a flight in a > MkIII and relax. By all accounts, >evidently Kolbs are some of the best taildraggers around. > >Mike W > ________________________________________________________________________________
Date: Nov 15, 2011
my extra two cents.... I do not think it is about liking one design or the other...It is what sells...and allows one to stay in business... imho again Herb Herb G/Kolbers: Yes, I agree "staying in business" is of primary concern to Kolb Aircraft. Another reason for all of us that build and fly Kolbs to give Kolb Aircraft as much support as we can. Every little bit we use Travis Brown to supply our parts, even if they cost a dollar or more, is a little bit more insurance we are going to have Kolb Aircraft when we need them. If we fly long enough, we are going to need repair and replacement parts. I fly and have been flying my mkIII for nearly 20 years because I like my airplane, I like what it does and what it doesn't do. If I didn't, I'd either change it to suit "me" or I would sell it and build something else. This flight to Starhill, LA, last weekend was great for refreshing my memory of how much I enjoy the mkIII and my friends and folks that fly Kolbs. When the mkIII sits in the hanger for months on end, I get those feelings I probably need to sell it because of the cost of insurance, etc. Then I get over to the airstrip, break ground, and I know why I still have it. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 15, 2011
> > If and when you ever fly a MKIIIx > john h > MKIII > Titus, Alabama John, I'd say we're pretty much on the same page on this debate. Re; the "if and when", at the moment, that and a few other things is the question. The latest glitch is a recent episode of glaucoma in my left eye. My vision was down to about 30% at it's worst. I can see shapes and colors, but zero detail. Glaucoma usually causes irreversible nerve damage. This is likely the case for me, too. I've been back and forth to the Eye Doc in the last couple of months. I had the laser surgery on the last visit, gawd that hurt like hell!! Progress is slow, if at all. The super expensive eye drops to lower my excessively high internal eyeball pressure have finally began to work. Now the IOP (inter-occular pressure) is within acceptable ranges...and maybe 'some' healing can begin. I'd guess my left eye vision has improved to about 70% of normal. Certainly better than it was. The internal retina photographs do show a significant degree of permanent eye loss. Most of my tunnel vision is here to stay. Regarding my plane, it's REALLY close to being done. I only have a couple of days of tinkering with odds and ends to wrap it up! At the moment, it's on hold. Apologies to all about the Sad Sack dribble. Mike Welch Here's a shot of my plane last June. ALL Lexan has been installed since this photo was taken. ________________________________________________________________________________
Subject: Joy Of Flying A Kolb
Date: Nov 15, 2011
Kolbers: Sorry to hear about Mike W's medical problems. I was already aware of them through correspondence a couple weeks ago. A reminder of why we put all the hours of work and sweat into building a Kolb. John Bickham took these photos at False River Airport, LA, as we were getting ready and departing for Alabama. Don't think he was using a telephoto lens for the aerial shots. ;-) john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 15, 2011
The only good reason for a nose wheel is to avoid having to S turn a blind ship down the taxiway. That isn't a problem in a Kolb. You would have to try hard to ground loop one too. BB MkIII, suzuki Scottsville, NY Floral City, FL On Nov 15, 2011, at 12:02 PM, John Hauck wrote: Like Rick N. suggested, maybe we should just get a flight in a MkIII and relax. By all accounts, evidently Kolbs are some of the best taildraggers around. Mike W Mike W/Kolbers: Maybe get some "actual pilot time" in a MKIII will help get a better picture of that aircraft's handling characteristics. I find it difficult to make effective changes to a proven aircraft design without having actual experience flying that aircraft. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 15, 2011
John I really wanted to say that was before my time but... I was there and remembered seeing that four engine Lazair. I was flying a Weedhopper nose dragger at that point. I now enjoying flying my relatively ultra reliable VW Powered MKIIIC. Thanks for the memories. Rick Neilsen On Mon, Nov 14, 2011 at 12:30 PM, John Hauck wrote: > > Folks: > > Never thought I would see this Lazair on floats fly again, but found it > after watching the Ultrastars fly at S&F 1984. > > http://www.youtube.com/user/OldChuckie#p/a/u/2/CaVLBrv4eQQ > > At the same S&F 1984, there was an ultralight ditch filled with water that > served at the UL Seaplane Base in the UL area. One of the prettiest of the > float equipped ULs was an Ultrastar, red and white sunburst, on fiberglass > floats. > > There was also this 4 engine Lazair on floats. As you will see, the pilot > flew barefooted with his britches legs rolled up. He must have had a > little > of Dick Rahill's (Kolb Firestar Factory Pilot) blood in him because he flew > almost continually. Take off, very short circuit and plop back down in the > ditch, just to take off again. > > Those were extremely good days. > > john h > mkIII > Titus, Alabama > > ________________________________________________________________________________
Subject: Re: Rotax 912 for sale...
From: "EdgePerformance" <post(at)edgeperformance.no>
Date: Nov 15, 2011
Hi, I am looking for a 912UL, but I cant manage to acsess to this site. Can you please forward a direct link ? Thomas -------- Kitfox IV w\ Jabiru 2200 Turbo\Aerocarb Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358038#358038 ________________________________________________________________________________
Date: Nov 15, 2011
Gees, I hope it's not mine (the one that was stolen on 5/17/11) ... (serial #4400582) Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000 hours 24 years flying it Kolbra 912UL (engine and avionics stolen on 5/17/11. Hanger break-in) N20386 done flying it 150 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358057#358057 ________________________________________________________________________________
Date: Nov 15, 2011
Thank you all for the replies on this subject. I've taken in all this information and thoughts on the idea of a nose wheel for my MK3X and I will probably weld in extra support needed in case in the future I decide to put one on. My cage has not been covered yet so this is the ideal time for me to do this. I definitely will NOT test fly with a nose wheel. I only hope I can get a little flight time with Brian before I test fly. Years ago I test flew my Cozy III without instruction and did ok but it really wasn't very smart, very fast airplane. If the weather is good next week I will be going to the Kolb factory to visit with Travis, Dennis, and Brian. They have a prototype cage for me to look at and I will take pictures. Rick Lewis -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358065#358065 ________________________________________________________________________________
Date: Nov 15, 2011
Back in the day a Canadian ultralight called the Lazair could be built with a wheel in the nose, but you would hardly call it a nosewheel. It was in front of the pilot's feet. It was there to keep the nose from digging in if the tail came up on landing. No steering. No brakes. The bottom of the wheel hung below the fairing, or the front tubes. It was a fat plastic wheel that might have started life on an all terrain garden cart. ----- Original Message ----- From: "Rick Lewis" <cktman(at)hughes.net> Sent: Tuesday, November 15, 2011 6:55 PM Subject: Kolb-List: Re: Nose wheel on a Kolb MK3X > > Thank you all for the replies on this subject. I've taken in all this > information and thoughts on the idea of a nose wheel for my MK3X and I > will probably weld in extra support needed in case in the future I decide > to put one on. My cage has not been covered yet so this is the ideal time > for me to do this. I definitely will NOT test fly with a nose wheel. I > only hope I can get a little flight time with Brian before I test fly. > Years ago I test flew my Cozy III without instruction and did ok but it > really wasn't very smart, very fast airplane. If the weather is good next > week I will be going to the Kolb factory to visit with Travis, Dennis, and > Brian. They have a prototype cage for me to look at and I will take > pictures. > > Rick Lewis > > -------- > Rick Lewis > > (VW Watercooled Engine) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=358065#358065 > > > ________________________________________________________________________________
Date: Nov 15, 2011
Actually that nose wheel on the Lazair started life as a wheel for hang gliders. You slipped them over the base tube and used a stop collar on one side only. That's why the funny shape, so they wouldn't rub on the down tube should you happen to use them. Rick Girard On Tue, Nov 15, 2011 at 6:56 PM, pcking wrote: > > > Back in the day a Canadian ultralight called the Lazair could be built > with a wheel in the nose, but you would hardly call it a nosewheel. It was > in front of the pilot's feet. It was there to keep the nose from digging in > if the tail came up on landing. No steering. No brakes. The bottom of the > wheel hung below the fairing, or the front tubes. It was a fat plastic > wheel that might have started life on an all terrain garden cart. > > > ----- Original Message ----- From: "Rick Lewis" <cktman(at)hughes.net> > To: > Sent: Tuesday, November 15, 2011 6:55 PM > Subject: Kolb-List: Re: Nose wheel on a Kolb MK3X > > >> >> Thank you all for the replies on this subject. I've taken in all this >> information and thoughts on the idea of a nose wheel for my MK3X and I will >> probably weld in extra support needed in case in the future I decide to put >> one on. My cage has not been covered yet so this is the ideal time for me >> to do this. I definitely will NOT test fly with a nose wheel. I only hope >> I can get a little flight time with Brian before I test fly. Years ago I >> test flew my Cozy III without instruction and did ok but it really wasn't >> very smart, very fast airplane. If the weather is good next week I will be >> going to the Kolb factory to visit with Travis, Dennis, and Brian. They >> have a prototype cage for me to look at and I will take pictures. >> >> Rick Lewis >> >> -------- >> Rick Lewis >> >> (VW Watercooled Engine) >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/**viewtopic.php?p=358065#358065> >> >> >> >> >> >> >> >> >> >> >> >> > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Nov 15, 2011
Could something like that be an alternative to a nose wheel? You would have a taildragger with a fat tire in the nose just in case. ----- Original Message ----- From: Richard Girard To: kolb-list(at)matronics.com Sent: Tuesday, November 15, 2011 8:23 PM Subject: Re: Kolb-List: Re: Nose wheel on a Kolb MK3X Actually that nose wheel on the Lazair started life as a wheel for hang gliders. You slipped them over the base tube and used a stop collar on one side only. That's why the funny shape, so they wouldn't rub on the down tube should you happen to use them. Rick Girard On Tue, Nov 15, 2011 at 6:56 PM, pcking wrote: Back in the day a Canadian ultralight called the Lazair could be built with a wheel in the nose, but you would hardly call it a nosewheel. It was in front of the pilot's feet. It was there to keep the nose from digging in if the tail came up on landing. No steering. No brakes. The bottom of the wheel hung below the fairing, or the front tubes. It was a fat plastic wheel that might have started life on an all terrain garden cart. ----- Original Message ----- From: "Rick Lewis" <cktman(at)hughes.net> To: Sent: Tuesday, November 15, 2011 6:55 PM Subject: Kolb-List: Re: Nose wheel on a Kolb MK3X Thank you all for the replies on this subject. I've taken in all this information and thoughts on the idea of a nose wheel for my MK3X and I will probably weld in extra support needed in case in the future I decide to put one on. My cage has not been covered yet so this is the ideal time for me to do this. I definitely will NOT test fly with a nose wheel. I only hope I can get a little flight time with Brian before I test fly. Years ago I test flew my Cozy III without instruction and did ok but it really wasn't very smart, very fast airplane. If the weather is good next week I will be going to the Kolb factory to visit with Travis, Dennis, and Brian. They have a prototype cage for me to look at and I will take pictures. Rick Lewis -------- Rick Lewis (VW Watercooled Engine) Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=358065#358065 om" target="_blank">www.aeroelectric.com ooks.com" target="_blank">www.buildersbooks.com et="_blank">www.homebuilthelp.com ="_blank">http://www.matronics.com/contribution le, List Admin. arget="_blank">http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Nov 15, 2011
Well, it worked for the Barling Bomber, not. Rick Girard On Tue, Nov 15, 2011 at 8:13 PM, pcking wrote: > ** > > Could something like that be an alternative to a nose wheel? You > would have a taildragger with a fat tire in the nose just in case. > > > ----- Original Message ----- > *From:* Richard Girard > *To:* kolb-list(at)matronics.com > *Sent:* Tuesday, November 15, 2011 8:23 PM > *Subject:* Re: Kolb-List: Re: Nose wheel on a Kolb MK3X > > Actually that nose wheel on the Lazair started life as a wheel for hang > gliders. You slipped them over the base tube and used a stop collar on one > side only. That's why the funny shape, so they wouldn't rub on the down > tube should you happen to use them. > > Rick Girard > > On Tue, Nov 15, 2011 at 6:56 PM, pcking wrote: > >> >> >> Back in the day a Canadian ultralight called the Lazair could be built >> with a wheel in the nose, but you would hardly call it a nosewheel. It was >> in front of the pilot's feet. It was there to keep the nose from digging in >> if the tail came up on landing. No steering. No brakes. The bottom of the >> wheel hung below the fairing, or the front tubes. It was a fat plastic >> wheel that might have started life on an all terrain garden cart. >> >> >> >> >> >> ----- Original Message ----- From: "Rick Lewis" <cktman(at)hughes.net> >> To: >> Sent: Tuesday, November 15, 2011 6:55 PM >> Subject: Kolb-List: Re: Nose wheel on a Kolb MK3X >> >> >> >>> >>> Thank you all for the replies on this subject. I've taken in all this >>> information and thoughts on the idea of a nose wheel for my MK3X and I will >>> probably weld in extra support needed in case in the future I decide to put >>> one on. My cage has not been covered yet so this is the ideal time for me >>> to do this. I definitely will NOT test fly with a nose wheel. I only hope >>> I can get a little flight time with Brian before I test fly. Years ago I >>> test flew my Cozy III without instruction and did ok but it really wasn't >>> very smart, very fast airplane. If the weather is good next week I will be >>> going to the Kolb factory to visit with Travis, Dennis, and Brian. They >>> have a prototype cage for me to look at and I will take pictures. >>> >>> Rick Lewis >>> >>> -------- >>> Rick Lewis >>> >>> (VW Watercooled Engine) >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/**viewtopic.php?p=358065#358065> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> ====**==============================**= >> om" target="_blank">www.aeroelectric.com >> ooks.com" target="_blank">www.buildersbooks.com >> et="_blank">www.homebuilthelp.com >> ="_blank">http://www.matronics.com/**contribution >> le, List Admin. >> ====**==============================**= >> arget="_blank">http://www.matronics.com/**Navigator?Kolb-List >> ====**==============================**= >> http://forums.matronics.com >> ====**==============================**= >> le, List Admin. >> ="_blank">http://www.matronics.com/**contribution >> ====**==============================**= >> >> >> >> > > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhappy. > - Groucho Marx > > > * > > href="http://www.aeroelectric.com">www.aeroelectric.com > href="http://www.buildersbooks.com">www.buildersbooks.com > href="http://www.homebuilthelp.com">www.homebuilthelp.com > href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Nov 15, 2011
Hey Phil, Sorry, I don't have the dimensions you need. I do have one of those mid 80's vintage Twinstars with no canopy or nosecone over at the Collegedale airport. You should come check it out sometime. Dan [quote="phactor9"]Thanks. That's my 1988 Twinstar. No canopy, nosecone, enclosure, just bugs-in-the-teeth flying. I miss it very much. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358081#358081 ________________________________________________________________________________
Date: Nov 15, 2011
Subject: Some success at last
After my neighbor offered the observation that I seemed to need an awful lot of rudder to keep the Mk IIIX flying straight on take off I started investigating and found that the vertical stabilizer was off ever so slightly. See picture 1. I removed the rudder trim tab and flew the airplane. You can see from picture 2 that the airplane flew a bit sideways. The Yaw string is about 8" long and I'd guess it is deflected about 2.5" giving a side slip of a little over 18 degrees. If you look carefully at picture 3 you can see how much the rudder is deflected to keep the airplane flying straight in level flight. Sorry, I've never tried to take a picture over my shoulder while trying to fly an airplane straight and level. After the vertical stabilizer was moved to align it straight down the tail boom, I flew it again, still without a rudder trim tab. Under power, there was no change in the results shown in picture 2. Pull the engine back to idle and yaw string flows right down the line on the windscreen and the ball is centered. Where the improvement really shown was in the power off stall characteristics. Before removing the trim tab, the airplane had a bad break to the left almost immediately at the onset of buffeting and it took rapid application of forward stick and right rudder to break it. Now with the trim tab removed, the airplane flies straight with the engine at idle and my feet off the rudder peddles. The stall is much more like that of my Mk III, no wing drop and recovery only requires releasing the back pressure on the stick. I still have no idea why P factor is so strong in this airplane. I've checked the engine alignment and it is straight down the centerline of the airplane as best as I can measure it. Because Ken's prop no longer fits after I lowered the engine mount to the factory recommended height, I'm using my prop, adjusted for the difference in the gearbox ratios of Ken's engine (2.62) and mine (4.00). So, I'm taking heart in the fact that the airplane no longer wants to break into a spin when stalled without power. I did not do a departure stall with it, if the weather is nice again tomorrow, I may work up my courage and give it a try. My airplane would not do a departure stall, it would just hang on the prop until I release back pressure. Somehow I don't think I'll get the same results with this airplane, but I've been wrong before. Anyway, I think the airplane is much safer, although I can only fly it for about 30 minutes before I get a cramp in my left calf. Rick Girard -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Nov 16, 2011
I still have no idea why P factor is so strong in this airplane. Anyway, I think the airplane is much safer, although I can only fly it for about 30 minutes before I get a cramp in my left calf. Rick Girard Rick G/Kolbers: Before I doubled the size of my rudder trim tab my mkIII flew about 1/2 bubble out of trim. Other than bugging me because it was not perfect, the mkIII flew great that way. In fact, I flew the 17,400 mile flight in 1994, that way. I decided to experiment to correct this problem by offsetting the leading edge of the upper vertical stabilizer. Moved it three times in 1/2" increments. Each time there was insignificant improvement in the adverse yaw. After the experiment was over, I returned the upper vertical stabilizer to its centered position and doubled the length of the rudder trim tab, from one rib bay to two. That fixed the adverse yaw problem. Now my mkIII flies in yaw trim with my feet off the pedals. I believe the adverse yaw problem is caused by the way the rotating prop blast hits the tail section. My prop turns counter clockwise when observed from the rear. All the oil that is blown from the oil tank breather hose hits the left side of the upper vertical stabilizer and the top of the left horizontal stabilizer. My rudder trim tab counteracts this force. That big pusher prop does a lot of weird things to some Kolbs. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: taildraggers?
Date: Nov 16, 2011
Hi, It seems that some are making very heavy weather of the current trike versus taildragger posts. Some are just retiring to entrenched positions without really considering the alternative very seriously. I transitioned from gliders to microlights, going solo on a Quicksilver. The old design, with tip draggers operated by pieces of string, if you were lucky. I also had some instruction on a Thruster, an Australian designed taildragger which became very popular here. It was a tractor design but apart from that very like the Kolb with a single pole fuselage and a 503 with a high thrust line.There was never any point made that taildraggers were inherently more of a handful on the ground or of the `taildragger problem`. I didn`t know that there was one. I had never flown a trike gear and just accepted the fact that this was way airplanes behaved. Consequently when I bought a plane of my own, like many pilots I bought the design with which I was familiar.. A Thruster. I had many happy hours in it. Later I bought and built a Challenger. Not because it was a trike undercart, but because it scored over the opposition. Taxiing the plane for the first time was a revelation. It actually went where it was pointed. It did not need constant attention in a cross wind taxy. It sat firmly on 3 wheels and the rudder pedal linked nose wheel was as precise as a car. Take offs were simplified. You started in flying position, no raising the tail `to flying position` Just ease the front wheel off the ground and that seemed to be the speed to transfer directional authority to the rudder. Crosswind take offs and landing were a doddle. I had experienced no trouble with the Thruster in this regard but this was just so much simpler. The Challenger ran on rails. I still landed pretty much in taildragger fashion, on the mains and tail low but as soon as the nose was lowered, absolute directional control. Then the Kolb became available in the UK and with a 4 stroke engine. I had always liked the look of the Kolb ever since I saw its picture on the door of a clubhouse during training. I bought one. I didn`t think for a moment about `the taildragger problem`, What problem? I had never experienced one. I am pretty happy with the Kolb but had I been offered a choice of undercarriages when I placed the order then I would have unhesitatingly gone for the trike. How hanging a wheel on the front would have affected performance is open to argument. It would certainly have produced a plane with different characteristics, but better or worse, who knows?. I suspect that no argument will change the minds of some people but I have approached the problem, because of the training I received and the flying I have done in probably as neutral an attitude as possible and given all things being equal I would go for a trike configuration every time. That being said I do have a sticker on my car that says ` REAL PILOTS FLY TAILDRAGGERS`. Cheers Pat ________________________________________________________________________________
Date: Nov 16, 2011
Excellent! How often do you fly? I'll be looking forward to some trips over there by air to get together to fly; you, me, Bob G, Scott K... Phil --- On Tue, 11/15/11, Dan Breitigam wrote: From: Dan Breitigam <dbrtgm(at)me.com> Subject: Kolb-List: Re: Firefly landing gear dimensions, please? Date: Tuesday, November 15, 2011, 10:36 PM Hey Phil, Sorry, I don't have the dimensions you need.- I do have one of those mid 80's vintage Twinstars with no canopy or nosecone over at the Collegedale a irport.- You should come check it out sometime. Dan [quote="phactor9"]Thanks. That's my 1988 Twinstar. No canopy, nosecone, e nclosure, just bugs-in-the-teeth flying. I miss it very much. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358081#358081 le, List Admin. le, List Admin. ________________________________________________________________________________
Date: Nov 16, 2011
Subject: Re: Some success at last
Thanks, John. My Mk III is completely different from yours apparently. It has almost no trim tab and the tab has almost no bend in it, maybe 10 degrees. The plane needs just a smidgeon of left rudder in climb and the same amount of right rudder in cruise. No comparison to yours and none at all to Ken's X. I was pretty tired when I wrote last night and I got the wrong photo for number 3. Here's the correct photo. Rick On Wed, Nov 16, 2011 at 6:29 AM, John Hauck wrote: > ** ** > > ** ** > > * ***** > > I still have no idea why P factor is so strong in this airplane. **** > > ** ** > > Anyway, I think the airplane is much safer, although I can only fly it for > about 30 minutes before I get a cramp in my left calf.**** > > ** ** > > Rick Girard**** > > ** ** > > ** ** > > ** ** > > Rick G/Kolbers:**** > > ** ** > > Before I doubled the size of my rudder trim tab my mkIII flew about 1/2 > bubble out of trim. Other than bugging me because it was not perfect, the > mkIII flew great that way. In fact, I flew the 17,400 mile flight in 1994, > that way.**** > > ** ** > > I decided to experiment to correct this problem by offsetting the leading > edge of the upper vertical stabilizer. Moved it three times in 1/2" > increments. Each time there was insignificant improvement in the adverse > yaw. **** > > ** ** > > After the experiment was over, I returned the upper vertical stabilizer to > its centered position and doubled the length of the rudder trim tab, from > one rib bay to two. That fixed the adverse yaw problem. Now my mkIII > flies in yaw trim with my feet off the pedals.**** > > ** ** > > I believe the adverse yaw problem is caused by the way the rotating prop > blast hits the tail section. My prop turns counter clockwise when observed > from the rear. All the oil that is blown from the oil tank breather hose > hits the left side of the upper vertical stabilizer and the top of the left > horizontal stabilizer. My rudder trim tab counteracts this force.**** > > ** ** > > That big pusher prop does a lot of weird things to some Kolbs.**** > > ** ** > > john h**** > > mkIII**** > > Titus, Alabama**** > > ** ** > > ** ** > > > **** > > ** ** > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Nov 16, 2011
Rick Keep looking for that cure I don't think this is it. During primary training I was trained to keep the ball centered at all times especially in stall. In less I'm miss interpreting your description I have to believe you were allowing the plane with the trim tab to yaw when going into stall. I currently have the leading edge of my vertical stabilizer off set by about an inch. I really couldn't tell any difference but it has to help the trim tab do its work. My trim tab is defected about 45 degrees and seems to be about right. I add left rudder under full power climb, right rudder power off and just a bit left in cruise. Big high thrust props flying at a high angles of attack produce lots of asymmetrical thrust referred to a P factor. No thrust, no P factor. Your photo was taken from one side so it will naturally look like it is defected. Rick Neilsen Redrive VW Powered MKIIIC On Wed, Nov 16, 2011 at 9:35 AM, Richard Girard wrote: > Thanks, John. My Mk III is completely different from yours apparently. It > has almost no trim tab and the tab has almost no bend in it, maybe 10 > degrees. The plane needs just a smidgeon of left rudder in climb and the > same amount of right rudder in cruise. No comparison to yours and none at > all to Ken's X. > I was pretty tired when I wrote last night and I got the wrong photo for > number 3. Here's the correct photo. > > Rick > > On Wed, Nov 16, 2011 at 6:29 AM, John Hauck wrote: > >> ** ** >> >> ** ** >> >> * ***** >> >> I still have no idea why P factor is so strong in this airplane. **** >> >> ** ** >> >> Anyway, I think the airplane is much safer, although I can only fly it >> for about 30 minutes before I get a cramp in my left calf.**** >> >> ** ** >> >> Rick Girard**** >> >> ** ** >> >> ** ** >> >> ** ** >> >> Rick G/Kolbers:**** >> >> ** ** >> >> Before I doubled the size of my rudder trim tab my mkIII flew about 1/2 >> bubble out of trim. Other than bugging me because it was not perfect, the >> mkIII flew great that way. In fact, I flew the 17,400 mile flight in 1994, >> that way.**** >> >> ** ** >> >> I decided to experiment to correct this problem by offsetting the leading >> edge of the upper vertical stabilizer. Moved it three times in 1/2" >> increments. Each time there was insignificant improvement in the adverse >> yaw. **** >> >> ** ** >> >> After the experiment was over, I returned the upper vertical stabilizer >> to its centered position and doubled the length of the rudder trim tab, >> from one rib bay to two. That fixed the adverse yaw problem. Now my mkIII >> flies in yaw trim with my feet off the pedals.**** >> >> ** ** >> >> I believe the adverse yaw problem is caused by the way the rotating prop >> blast hits the tail section. My prop turns counter clockwise when observed >> from the rear. All the oil that is blown from the oil tank breather hose >> hits the left side of the upper vertical stabilizer and the top of the left >> horizontal stabilizer. My rudder trim tab counteracts this force.**** >> >> ** ** >> >> That big pusher prop does a lot of weird things to some Kolbs.**** >> >> ** ** >> >> john h**** >> >> mkIII**** >> >> Titus, Alabama**** >> >> ** ** >> >> ** ** >> >> >> **** >> >> ** ** >> >> * >> >> _blank">www.aeroelectric.com >> .com" target="_blank">www.buildersbooks.com >> ="_blank">www.homebuilthelp.com >> _blank">http://www.matronics.com/contribution >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhappy. > - Groucho Marx > > ________________________________________________________________________________
Date: Nov 16, 2011
http://www.av8n.com/how/htm/yaw.html=0A=0A=0A=0A___________________________ _____=0AFrom: John Hauck <jhauck(at)elmore.rr.com>=0ATo: kolb-list(at)matronics.c om=0ASent: Wednesday, November 16, 2011 6:29 AM=0ASubject: RE: Kolb-List: S ome success at last=0A=0A=0A-=0A-=0AI still have no idea why P factor i s so strong in this airplane. -=0A-=0AAnyway, I think the airplane is m uch safer, although I can only fly it for about 30 minutes before I get a c ramp in my left calf.=0A-=0ARick Girard=0A-=0A-=0A-=0ARick G/Kolber s:=0A-=0ABefore I doubled the size of my rudder trim tab my mkIII flew ab out 1/2 bubble out of trim.- Other than bugging me because it was not per fect, the mkIII flew great that way.- In fact, I flew the 17,400 mile fli ght in 1994, that way.=0A-=0AI decided to experiment to correct this prob lem by offsetting the leading edge of the upper vertical stabilizer.- Mov ed it three times in 1/2" increments.- Each time there was insignificant improvement in the adverse yaw.- =0A-=0AAfter the experiment was over, I returned the upper vertical stabilizer to its centered position and doubl ed the length of the rudder trim tab, from one rib bay to two.- That fixe d the adverse yaw problem.- Now my mkIII flies in yaw trim with my feet o ff the pedals.=0A-=0AI believe the adverse yaw problem is caused by the w ay the rotating prop blast hits the tail section.- My prop turns counter clockwise when observed from the rear.- All the oil that is blown from th e oil tank breather hose hits the left side of the upper vertical stabilize r and the top of the left horizontal stabilizer.- My rudder trim tab coun teracts this force.=0A-=0AThat big pusher prop does a lot of weird things to some Kolbs.=0A-=0Ajohn h=0AmkIII=0ATitus, Alabama=0A-=0A-=0A=0A Archive Search & Download, 7-Day ======= ________________________________________________________________________________
Date: Nov 16, 2011
Maybe it's normal construction method by now, but when I built my Firestar I made the front attachment for my vertical stabilizer a little wider than necessary =97 maybe just an 1/8 inch =97 so that I could shim it either way for desired trim. Seems like it was in the right place from the get go an d I never needed to mess with it. ..or I'm just not that discriminating. ; ) I'm not sure I know whether my prop induced yaw is P factor or corkscrew sw irl hitting more the top half than bottom half. I believe shimming the eng ine pitch angle will help either, but mostly the corkscrew effect. Cheers, -Ben Firestar KXP, 1994 From: Danny <dan42101(at)yahoo.com<mailto:dan42101(at)yahoo.com>> Date: Wed, 16 Nov 2011 08:17:15 -0800 tronics.com> Subject: Re: Kolb-List: Some success at last http://www.av8n.com/how/htm/yaw.html From: John Hauck <jhauck(at)elmore.rr.com<mailto:jhauck(at)elmore.rr.com>> Sent: Wednesday, November 16, 2011 6:29 AM Subject: RE: Kolb-List: Some success at last I still have no idea why P factor is so strong in this airplane. Anyway, I think the airplane is much safer, although I can only fly it for about 30 minutes before I get a cramp in my left calf. Rick Girard Rick G/Kolbers: Before I doubled the size of my rudder trim tab my mkIII flew about 1/2 bub ble out of trim. Other than bugging me because it was not perfect, the mkI II flew great that way. In fact, I flew the 17,400 mile flight in 1994, th at way. I decided to experiment to correct this problem by offsetting the leading e dge of the upper vertical stabilizer. Moved it three times in 1/2" increme nts. Each time there was insignificant improvement in the adverse yaw. After the experiment was over, I returned the upper vertical stabilizer to its centered position and doubled the length of the rudder trim tab, from o ne rib bay to two. That fixed the adverse yaw problem. Now my mkIII flies in yaw trim with my feet off the pedals. I believe the adverse yaw problem is caused by the way the rotating prop bl ast hits the tail section. My prop turns counter clockwise when observed f rom the rear. All the oil that is blown from the oil tank breather hose hi ts the left side of the upper vertical stabilizer and the top of the left h orizontal stabilizer. My rudder trim tab counteracts this force. That big pusher prop does a lot of weird things to some Kolbs. john h mkIII Titus, Alabama ollow target=_blank>www.aeroelectric.com /" rel=nofollow target=_blank>www.buildersbooks.com ofollow target=_blank>www.homebuilthelp.com llow target=_blank>http://www.matronics.com/contribution rsbooks.com> m> 5.1/5.0 This incoming message has been identified by the UCD central filter s as possible spam. This attachment is provided so that you can review the reasons the message was tagged, and to assist with additional filtering if you wish to supplement the central filters with your own local rules. If yo u have further questions please email ithelp(at)ucdavis.edu for assistance. Content analysis details: (5.1 points, 5.0 require d) pts rule name description ---- ---------------------- ------------------ -------------------------------- 0.6 SPF_SOFTFAIL SPF: sender does not matc h SPF record (softfail) 0.8 SPF_HELO_SOFTFAIL SPF: HELO does not match SPF record (softfail) 2.3 FORGED_YAHOO_RCVD 'From' yahoo.com does not match 'Re ceived' headers 0.0 HTML_MESSAGE BODY: HTML included in message 0.0 BAYES_2 0 BODY: Bayesian spam probability is 5 to 20% [score: 0.0710] 1.4 MIME_QP_L ONG_LINE RAW: Quoted-printable line longer than 76 chars ________________________________________________________________________________
Date: Nov 16, 2011
> ......................... > I still have no idea why P >factor is so strong in this airplane. > Rick, There are a couple of reasons. You have a high powered, high drag, and light weight aircraft. When one trims roll to level the wings during cruise, it counter acts propeller torque and possible P factor due to the propeller axis not being parallel to the direction of flight. If there is no trim on the rudder the aircraft will slip during cruise. To reduce this slip one can reduce the P factor by washering the engine mounts to tilt the engine front to back until one cannot obtain further improvement as indicated by the ball or string. After this you are stuck with adding a trim tab to the rudder to bring the nose around for your normal flight loading and cruise conditions. Fly at any other condition and P factor and engine torque will again come back into focus. Of course when you idle the engine all of these factors disappear. The reason it is so severe in Kolb aircraft is due to the fact that it takes more power and torque to fly at a given cruise speed than a sleeker aircraft of equal weight. Also there is a flywheel gyroscopic progression effect caused by the propeller, which indicates that low inertia propellers will reduc this phenomena. I am fortunate that I can rotate the reduction unit and off set the thrust line to the left or right to compensate and dispense with the use of a rudder trim tab at cruise. fwiw Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Subject: Re: Nose wheel on a Kolb MK3X
Date: Nov 16, 2011
It is interesting that we went over this topic about a year ago, here is the thread, with pictures of my original - and unneeded - nose gear assembly. http://forums.matronics.com/viewtopic.php?t=75465&highlight I still have the nose wheel assembly out in the hangar, and for whatever it takes to cover the cost of shipping, I'll send it to whoever wants it. Something we hashed over on another thread - as noticeable a difference it makes to your trim when you put streamline coverings on the main gear legs, I suspect that hanging a nose wheel down there is going to really add to the drag equation, and require substantial additional nose up trim. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358110#358110 ________________________________________________________________________________
Date: Nov 16, 2011
Rick G, I know you are pretty good at analyzing stuff, and with that MkIIIX you're getting a good work-out, but have you checked whether the tailfeather cables are EXACTLY the same length (i.e. matched sets) and are you certain they are tight enough? I recall John H. saying they need to be fairly tight to maintain good flight characteristics. Mike Welch ________________________________________________________________________________
Date: Nov 16, 2011
I recall John H. saying they need to be fairly tight to maintain good flight characteristics. Mike Welch They should be as tight as a banjo string. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 16, 2011
....you could put a handicap sticker next to the N number then too...lol JUST KIDDING !!!!...LOL chris ambrose M3X/Jabiru N327CS JUST KIDDING !!!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358120#358120 ________________________________________________________________________________
Date: Nov 16, 2011
Regarding my plane, it's REALLY close to being done. I only have a couple of days of tinkering with odds and ends to wrap it up! At the moment, it's on hold. Apologies to all about the Sad Sack dribble. Mike Welch Here's a shot of my plane last June. ALL Lexan has been installed since this photo was taken. Mike ...YOUR AIRPLANE IS BEAUTIFUL ! chris ambrose M3X/Jabiru N327CS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358121#358121 ________________________________________________________________________________
Date: Nov 16, 2011
Thanks, Chris!!! You're very kind. Like our buddy Scott Thompson said, "any plane can be made to look good from a few away". haha Thanks again, Amigo! > > Mike ...YOUR AIRPLANE IS BEAUTIFUL ! > > chris ambrose > M3X/Jabiru > N327CS ________________________________________________________________________________
Date: Nov 16, 2011
I still have no idea why P factor is so strong in this airplane. >>>>>>>>> i don't think that we are dealing with "P" factor,,, i think it is simple prop wash, and it is so bad because the prop is so close to the tail.... and there is no fuselage between the prop and tail. "P" factor as explained to me when flying a c 150. the air through the prop in straight and level flight should be perpendicular to the prop. thus the ascending and descending blades of the prop have the same bite in the air. when you are in a climb, the prop disk is no longer perpendicular to the air flow. the descending blade has a greater bite into the air then does the ascending blade. in a C 150 with the prop turning clockwise when looking from the rear, that means, in a climb, the prop blade on the right side has more pull than the blade on the left. turning the plane to the left. SO you have to add right rudder to fly straight. change the concept to the kolb, on the 912, the prop turns counter clock wise when looking from the rear, if the air is perpendicular to the prop in level flight, the pull should be the same, but in a climb, the prop blade while on the left should have more bite into the air,,, wanting to yaw the plane to the right,,, which should require left rudder,,,, but in fact as the swirling mass of air hits the rudder, it moves the tail to the right,(nose left) i have to add right rudder, not left as the "P" factor would suggest, the "P" factor counteracts partially the prop swirling factor, but not completely. this is the simple strait forward explanation,,,, now we have to add into the mix. the air that is being deflected downward from the effect of the wing. that will change the entire dynamic of the problem. to what extent,,, i dont know, that would probably require time in a wind tunnel, now with the 2 strokes, the prop turns clockwise looking from the rear,,, and the pressure are on the opposite side compared to the 912's, and the rudder inputs and trim requirements are opposite. boyd young mkiii utah ________________________________________________________________________________
Subject: Slingshot for sale
Date: Nov 16, 2011
I just saw a Kolb Slingshot w/ 503 posted for sale on Barnstormers.com. As it happens, for reasons of economics, I've decided to put my Slingshot up for sale too. Just posted an ad on Barnstormers. The reason for selling is that I am losing my hangar partner (splitting 50% of hangar rent) soon and cannot justify paying the entire hangar rent. I've been offered a share in a Diamond Katana (the one I've been maintaining for about six years) which will end up getting me back to about the same flying overhead cost I've had up until now. I'll miss the Slingshot take-off & climb performance but the Katana is lots faster and quieter. Anyone interested in my excellent Slingshot should contact me through the Barnstormers ad. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Truth is what stands the test of experience. - Albert Einstein Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358127#358127 Attachments: http://forums.matronics.com//files/slingshotforsale_177.gif ________________________________________________________________________________
Date: Nov 16, 2011
Subject: Where to buy two stroke oil?
Next topic: What oil do you use, why, and where can you get quantities, and at what price? Castrol TTS cannot be found (discontinued). My bike mechanic (Powersports Honda) recommended Amsoil hp injector ($35/gal) and Amsoil interceptor ($39/gal, higher temperature additives for "power valves"). I told him it wasn't for marine, snow or road transport but for an ultralight, and I wanted all the obvious qualities involved in feeding my two-stroke engine. He said HE could no longer get Castrol TTS from either of his suppliers, either, and suggested Amsoil would be the best. Phil H. ________________________________________________________________________________
Subject: FireFly - the plane I want!
Date: Nov 16, 2011
I got permission from the photographer of this plane to list. Is this a member's plane? I like it! Tom -------- Tom Stephens www.planeaday.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358129#358129 ________________________________________________________________________________
Subject: Greetings
Date: Nov 16, 2011
I'm a long time ultralight and gyro pilot. I recently bought a Firestar single seat. Have about 6hrs on it now and love it. I fly out of Bear Creek here in central N.C., a 2100ft grass strip. Any Kolbers in the area welcome to stop in. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358130#358130 ________________________________________________________________________________
Date: Nov 16, 2011
Subject: Re: Where to buy two stroke oil?
Check out Aeroshell II plus (I think that is what it is called). I haven`t tried it yet, however, after reading about it, I plan to use it next spring. N598LF At 03:28 PM 11/16/2011, you wrote: >Next topic: What oil do you use, why, and where can you get >quantities, and at what price? > >Castrol TTS cannot be found (discontinued). > >My bike mechanic (Powersports Honda) recommended Amsoil hp injector >($35/gal) and Amsoil interceptor ($39/gal, higher temperature >additives for "power valves"). I told him it wasn't for marine, snow >or road transport but for an ultralight, and I wanted all the >obvious qualities involved in feeding my two-stroke engine. > >He said HE could no longer get Castrol TTS from either of his >suppliers, either, and suggested Amsoil would be the best. >Phil H. > > ><http://www.buildersbooks.com>www.buildersbooks.com ><http://www.matronics.com/contribution>http://www.matronics.com/contribution ><http://www.matronics.com/Navigator?Kolb-List>http://www.matronics.com/Navigator?Kolb-List ><http://www.matronics.com/contribution>http://www.matronics.com/contribution > ________________________________________________________________________________
Date: Nov 16, 2011
Is this a member's plane? I like it! Tom Stephens Looks like Terry Swartz near Smoke Town, PA. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Greetings
Date: Nov 16, 2011
I'm a long time ultralight and gyro pilot. I recently bought a Firestar single seat. Have about 6hrs on it now and love it. I fly out of Bear Creek here in central N.C., a 2100ft grass strip. Any Kolbers in the area welcome to stop in. Thanks Welcome to the Kolb List. What is your name? Found three Bear Creeks in NC. Which one is yours? john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 16, 2011
http://www.conocophillipslubricants.com/brands-products/Single.aspx?pid=39&b rand That ought to fill the bill for Rotax air cooled engines. That is as far as I looked. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: Greetings
Date: Nov 16, 2011
Gary Safrit. I'm at NC79 4miles east of Mt. Pleasant. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358136#358136 ________________________________________________________________________________
Subject: Re: FireFly - the plane I want!
Date: Nov 16, 2011
Tom Stephens wrote: > I got permission from the photographer of this plane to list. Is this a member's plane? I like it! > > Tom That would be Terry FRANTZ. Do believe that he dropped from the list. I will forward your email to him. He can contact you if he wishes. Here is another shot of him/his plane. http://home.comcast.net/~kolbplanes/Kolb05_04b.htm -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358137#358137 ________________________________________________________________________________
Date: Nov 16, 2011
Gary Safrit. I'm at NC79 4miles east of Mt. Pleasant. Gary S/Kolbers: Now I know where you are. Thanks, john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 16, 2011
Ooops John, wrong "Terry". Good friend Terry Frantz is the builder/ owner of that beautiful Firefly. He usually monitors the list and will be happy to see his plane featured favorably on this list. Gene Z On Nov 16, 2011, at 5:13 PM, John Hauck wrote: > > > > > > Is this a member's plane? I like it! > Tom Stephens > > > > Looks like Terry Swartz near Smoke Town, PA. > > john h > mkIII > Titus, Alabama > > > > > > ________________________________________________________________________________
Date: Nov 16, 2011
Ooops John, wrong "Terry" Gene Z Gene Z/Gang: That was about as close as I could guess on the last name. ;-) john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 16, 2011
Okay, I'll go through this one question at a time. "In less I'm miss interpreting your description I have to believe you were allowing the plane with the trim tab to yaw when going into stall." Yes, the trim tab was pushing the tail to the right (nose to the left) and causing the aircraft to break hard left when stalled. With the trim tab gone and my feet off the rudder peddles the yaw string and the ball are centered when the engine is at idle. Any power above about 2800 rpm causes the nose to push off to the right. The more power, the more the right yaw requiring left rudder. "Your photo was taken from one side so it will naturally look like it is defected. " It looks deflected because it is. It takes about half the left rudder travel to center the ball and the yaw string. It's obvious enough that it can be seen from 200 to 300 feet below, that's why my neighbor was able to make his observation. "have you checked whether the tailfeather cables are EXACTLY the same length (i.e. matched sets) and are you certain they are tight enough?" Yep, making new cables was one of the first things I did on this aircraft. They can be strummed like a base viola. One of the few things the OB did was to get the holes in the horizontal stabilizers where the wires attach exactly alike so the left and right "when you are in a climb, the prop disk is no longer perpendicular to the air flow. the descending blade has a greater bite into the air then does the ascending blade." Yep, that's the classic explanation, but both my plane and this X are 582 powered (prop rotation is clockwise viewed from the rear looking forward) and "P" factor is pushing the nose to the right, which means it's the ascending blade doing the pushing. Go figure. My interpretation of this is that the air flowing over the wing is pretty broken up in climb and both sides of the prop above the wing get that crappy inflow. The air coming from under the wing is cleaner so now the ascending blade, on the left has a lower angle of attack and the right side, descending blade is in a stalled condition. It may be wishful thinking, but my Mk III behaves the same way, except that it's not as extreme as it is on the X. When I flew approach stalls yesterday I did them with my feet pulled back so there's no way I was influencing the airplane's actions in yaw. Both clean and with half flaps the yaw string and ball were centered and stayed that way through the stall. I also did power off glides up to 65 mph and the yaw string and ball were centered then, too, again, with my feet off the rudder peddles. Rick Girard On Wed, Nov 16, 2011 at 1:55 PM, b young wrote: > ** > > ** > I still have no idea why P factor is so strong in this airplane. > >>>>>>>>> > > > i don't think that we are dealing with "P" factor,,, i think it is simple > prop wash, and it is so bad because the prop is so close to the tail.... > and there is no fuselage between the prop and tail. > > "P" factor as explained to me when flying a c 150. > > the air through the prop in straight and level flight should be > perpendicular to the prop. thus the ascending and descending blades of the > prop have the same bite in the air. when you are in a climb, the prop > disk is no longer perpendicular to the air flow. the descending blade has > a greater bite into the air then does the ascending blade. in a C 150 with > the prop turning clockwise when looking from the rear, that means, in a > climb, the prop blade on the right side has more pull than the blade on > the left. turning the plane to the left. SO you have to add right rudder > to fly straight. > > change the concept to the kolb, on the 912, the prop turns counter > clock wise when looking from the rear, > > if the air is perpendicular to the prop in level flight, the pull should > be the same, but in a climb, the prop blade while on the left should have > more bite into the air,,, wanting to yaw the plane to the right,,, which > should require left rudder,,,, but in fact as the swirling mass of air > hits the rudder, it moves the tail to the right,(nose left) i have to > add right rudder, not left as the "P" factor would suggest, the "P" > factor counteracts partially the prop swirling factor, but not completely. > > this is the simple strait forward explanation,,,, now we have to add into > the mix. the air that is being deflected downward from the effect of the > wing. that will change the entire dynamic of the problem. to what > extent,,, i dont know, that would probably require time in a wind tunnel, > > now with the 2 strokes, the prop turns clockwise looking from the > rear,,, and the pressure are on the opposite side compared to the 912's, > and the rudder inputs and trim requirements are opposite. > > boyd young > mkiii utah > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Nov 16, 2011
"Two stroke AeroShell Oil Sport Plus 2 is the first aviation quality oil that has been specifically developed for Light Sport, Very Light and Ultralight 2-stroke engines such as the ROTAX=AE air and water-cooled serie s engines." http://www.shell.com/home/content/aviation/products/lubricants/piston_engin e_oils/sports_plus2/ Rick Girard On Wed, Nov 16, 2011 at 2:28 PM, Phil wrote: > Next topic: What oil do you use, why, and where can you get quantities, > and at what price? > > Castrol TTS cannot be found (discontinued). > > My bike mechanic (Powersports Honda) recommended Amsoil hp injector > ($35/gal) and Amsoil interceptor ($39/gal, higher temperature additives f or > "power valves"). I told him it wasn't for marine, snow or road transport > but for an ultralight, and I wanted all the obvious qualities involved in > feeding my two-stroke engine. > > He said HE could no longer get Castrol TTS from either of his suppliers, > either, and suggested Amsoil would be the best. > Phil H. > > * > =========== =========== =========== =========== =========== > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Nov 16, 2011
Rick G/Kolbers: Prop blast is hitting the right side of the upper vertical stabilizer, clockwise prop rotation. Takes left pedal under power on the two stroke. Just the opposite on the 912 series. Prop turns counterclockwise, blast hits the left side of the upper vertical stabilizer. Takes right pedal or a proper size rudder trim tab to keep the aircraft trimmed in yaw. My Firestar had the same undesirable habit, but the Ultrastar, prop under the tail boom, did not. Don't think anything has changed with these airplanes until TNK stuck the big nose on the MKIII. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 16, 2011
Thanks guys! I see Terry has brakes, but no N number, so I assume he's running as an ultralight, as I would want to? Have any of you or others flown the FireStar and FireFly? I'm curious as to how they compare. Tom -------- Tom Stephens www.planeaday.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358160#358160 ________________________________________________________________________________
Date: Nov 17, 2011
Subject: Please Support The Lists...
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. There are some very nice incentive gifts to choose from as well! Your Contributions alone keep these services up and running. Please make your Contribution today at: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 17, 2011
John, your post is coming through too large to fit on the scheme, large font and blue in colour.. Have you inadvertently changed a setting somewhere? Anyone else with the same problem or is it me?. Pat ________________________________________________________________________________
Date: Nov 17, 2011
<> Really? I know I may be behind on the learning curve but could someone explain this to me. That means that someone in a vertical climb has the airflow approaching from 90 degrees to the direction of travel which is obviously not so. Curious Pat It seems to me that the airflow is always (apparently) approaching ________________________________________________________________________________
Date: Nov 17, 2011
At 05:40 AM 11/17/2011, Pat Ladd wrote: ><air flow>> > >Really? I know I may be behind on the learning curve but could someone >explain this to me. > >That means that someone in a vertical climb has the airflow approaching >from 90 degrees to the direction of travel which is obviously not so. Pat, this is the usual explanation of P-Factor. If the engine is set so the shaft is parallel to the airflow at cruise (prop disk perpendicular to the airflow; the usual condition), then when you're flying slower (as in climb) and at a greater angle of attack, the shaft is no longer parallel to the airflow, i.e. the prop disk is no longer perpendicular. In this case the difference in blade AOA between the blade going up and the blade going down causes an asymmetric thrust, or P-Factor. -Dana -- In general, liberalism consists of A & B getting together to see what they can make C do for poor old D. ________________________________________________________________________________
Date: Nov 17, 2011
Pat, Yes, I receive (most of) John H's post with really big fonts, lately. I thought he was just just thoughtful for the "poor sight crowd". (that was a joke) But those 1/2" tall letters do make it easier for me to read....and that's NOT a joke. What is weird is, 'your emails', and several other guys' emails come in SUPER tiny....I mean really "squint and focus" tiny. And what's worse, is sometimes they also come in light blue, too. Very hard to read light blue "warning label sized print". Obviously, someone has let loose the font gremlins recently. Mike Welch On Nov 17, 2011, at 4:25 AM, Pat Ladd wrote: > John, > your post is coming through too large to fit on the scheme, large font and blue in colour.. > Have you inadvertently changed a setting somewhere? > Anyone else with the same problem or is it me?. > > Pat > > > > ________________________________________________________________________________
From: Clyde MacQuarrie <clydemacquarrie(at)eastlink.ca>
Date: Nov 17, 2011
I found Castrol TTS at the local Wal-Mart here in Nova Scotia, Canada for $28.00 Plus taxes. Clyde MacQuarrie. From: Richard Girard Sent: Wednesday, November 16, 2011 8:30 PM Subject: Re: Kolb-List: Where to buy two stroke oil? "Two stroke AeroShell Oil Sport Plus 2 is the first aviation quality oil that has been specifically developed for Light Sport, Very Light and Ultralight 2-stroke engines such as the ROTAX=AE air and water-cooled series engines." http://www.shell.com/home/content/aviation/products/lubricants/piston_eng ine_oils/sports_plus2/ Rick Girard On Wed, Nov 16, 2011 at 2:28 PM, Phil wrote: Next topic: What oil do you use, why, and where can you get quantities, and at what price? Castrol TTS cannot be found (discontinued). My bike mechanic (Powersports Honda) recommended Amsoil hp injector ($35/gal) and Amsoil interceptor ($39/gal, higher temperature additives for "power valves"). I told him it wasn't for marine, snow or road transport but for an ultralight, and I wanted all the obvious qualities involved in feeding my two-stroke engine. He said HE could no longer get Castrol TTS from either of his suppliers, either, and suggested Amsoil would be the best. Phil H. _blank">www.aeroelectric.com .com" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Nov 17, 2011
John, your post is coming through too large to fit on the scheme, large font and blue in colour.. Have you inadvertently changed a setting somewhere? Anyone else with the same problem or is it me?. Pat Patrick/Kolbers: I apologize for the inconvenience. However, I haven't changed my Outlook settings, that I know of. That doesn't mean the gremlin didn't change it for me. Do you think visiting porn sites could do that? I'll try and write smaller and blacker. ;-) Our weather has changed from 64F yesterday when I got up to 46F this morning. The rain is gone. Maybe I can get some flying done if it doesn't get too windy. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 17, 2011
Have any of you or others flown the FireStar and FireFly? I'm curious as to how they compare. Tom Stephens Tom S/Kolbers: Both aircraft fly extremely well. They are easy to fly and will not bite you as long as you keep the airspeed above stall and below VNE. The Firestar has a 27 foot wing span and it 22 feet long, compared to the 22 foot wing span of the Firefly that is 19.5 feet long. Compared to the longer winged Kolbs, the FF is very much a little hot rod like its big brother the Slingshot. It has a quick roll rate and is extremely agile. Does well in rough air. Basically, all models of Kolb aircraft have the same easy, solid quality of flight. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 17, 2011
> Do you think visiting porn sites could do that? > john h > mkIII > Titus, Alabama John H, hahahaha......hahahahaha.... Doesn't seem to have affected my posts. Eeecks!! Mike (still chuckling) ________________________________________________________________________________
Date: Nov 17, 2011
<> Thanks Dana, Humm!. Not completely happy with that. If you have enough power to climb and NOT slow up, what happens then? As far as I can see the airflow direction in relation to the plane (what in sailing circles is called the apparent wind) is still directly on the nose. In that case it would appear that it is a matter of airspeed, not attitude. Therefore the P factor should change as you throttle back in the cruise. Does it? Still curious Pat ________________________________________________________________________________
Date: Nov 17, 2011
Subject: P-factor, maybe this will help, maybe not!
http://en.wikipedia.org/wiki/P-factor ________________________________________________________________________________
Subject: Re: FireFly - Someday, I'd like one like this one!
Date: Nov 17, 2011
It was brought to my attention (appreciate it!) that my subject was a bit confusing. I cannot buy a plane right now, I am still taking flying lessons (in a Challenger). I found the photo of Terry's plane and is a perfect example of a FireFly I'd like to have. The problem I have been having is that with our 2 airports (nice BTW), there is no affordable hangar space, which means I have to either leave a plane tied up outside, or tow it to the airport. I like the Challenger I am flying so much that I'd love to have one. But with the fuselage covered, rather than a tube, I'd have to cover the whole plane with wing covers. I've wanted to build an airplane for a long time now, but finally realized I just don't have the time. Thus the FireFly would be perfect in that I can tow it to the field. And if I'm lucky, I might be able to find space in someone's hangar for the folded bird. Tom -------- Tom Stephens www.planeaday.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358269#358269 ________________________________________________________________________________
Date: Nov 17, 2011
For those asking where I got Terry's photo: more Kolb photos contained within: http://www.flickr.com/photos/massey_aero/sets/72157623939871980/with/4551780446/ Bill Dougherty is the photographer. Tom -------- Tom Stephens www.planeaday.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358271#358271 ________________________________________________________________________________
Date: Nov 17, 2011
I like the Challenger I am flying so much that I'd love to have one. Tom -------- Tom Stephens If you like the Challenger that much, a Kolb would blow you completely away. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 17, 2011
John, Oh great, twist the knife ;-) I used to kart race, now I have a vintage kart. I really like being right out in front. The 'shadow' video I put on our home page is soooo cool, that's what I like in being right out there. So what ARE the chances of being able to keep a FireFly legally under 254? Jack Hart has an MZ34 on his, and says it's well under. I only weigh 160 dressed, so I figure it should work fine? Not looking for super performance. Tom -------- Tom Stephens www.planeaday.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358276#358276 ________________________________________________________________________________
Date: Nov 17, 2011
If you increase power to climb so you keep the same airspeed, then AOA is the same, and the amount of P-factor (zero or otherwise) should not change. -Dana At 10:12 AM 11/17/2011, Pat Ladd wrote: ><attack>> > >Thanks Dana, > >Humm!. Not completely happy with that. If you have enough power to climb >and NOT slow up, what happens then? As far as I can see the airflow >direction in relation to the plane (what in sailing circles is called the >apparent wind) is still directly on the nose. In that case it would >appear that it is a matter of airspeed, not attitude. Therefore the P >factor should change as you throttle back in the cruise. Does it? > >Still curious > >Pat > >www.aeroelectric.com ><http://www.buildersbooks.com>www.buildersbooks.com ><http://www.matronics.com/contribution>http://www.matronics.com/contribution ><http://www.matronics.com/Navigator?Kolb-List>http://www.matronics.com/Navigator?Kolb-List ><http://www.matronics.com/contribution>http://www.matronics.com/contribution > -- Everything that can be counted does not necessarily count; everything that counts cannot necessarily be counted. -Albert Einstein ________________________________________________________________________________
Date: Nov 17, 2011
Tom, You could do what I do... keep your Kolb folded, in an enclosed trailer, at the airport. I pay the outdoor tiedown rate, the plane is protected, and I don't have to tow it every time I fly (but it's easy to bring it home to work on it, or for the winter). I've never flown a Challenger, but I get the impression from those who have that the Kolbs are MUCH nicer flying planes. -Dana At 11:44 AM 11/17/2011, Tom Stephens wrote: >The problem I have been having is that with our 2 airports (nice BTW), >there is no affordable hangar space, which means I have to either leave a >plane tied up outside, or tow it to the airport. > >I like the Challenger I am flying so much that I'd love to have one. But >with the fuselage covered, rather than a tube, I'd have to cover the whole >plane with wing covers. I've wanted to build an airplane for a long time >now, but finally realized I just don't have the time. Thus the FireFly >would be perfect in that I can tow it to the field. And if I'm lucky, I >might be able to find space in someone's hangar for the folded bird. -- Why did the chicken cross the Mobius strip? To get to the other, er, um.... ________________________________________________________________________________
Date: Nov 17, 2011
I have ordered a Firefly from Travis and I am in the process of mapping out my winter building schedule. I will be flying in the Spring. I plan on kee ping it completely 103 legal. This will be my 2nd Kolb. - Phil H. --- On Thu, 11/17/11, Tom Stephens wrote: From: Tom Stephens <tom(at)planeaday.com> Subject: Kolb-List: Re: FireFly - Someday, I'd like one like this one! Date: Thursday, November 17, 2011, 12:20 PM John, Oh great, twist the knife ;-) I used to kart race, now I have a vintage kart.- I really like being righ t out in front.- The 'shadow' video I put on our home page is soooo cool, that's what I like in being right out there. So what ARE the chances of being able to keep a FireFly legally under 254? - Jack Hart has an MZ34 on his, and says it's well under.- I only weigh 160 dressed, so I figure it should work fine?- Not looking for super per formance. Tom -------- Tom Stephens www.planeaday.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358276#358276 le, List Admin. le, List Admin. ________________________________________________________________________________
Date: Nov 17, 2011
Tom -- I, too, did my UL training in a 2-seat Challenger. Later I had to chance to fly two other single-seat Challengers. I've also flown a Firefly, and I currently own a MkIIIC. Everyone has their own opinion, but I can tell you unequivocally that the Firefly is a ~much~ better UL than the Challenger, in virtually every category. The Challenger is a good aircraft -- and much better than the first UL that I owned, a Quicksilver MXL -- but the Firefly is just better... controls are lighter, and the frame and construction is much stiffer and stronger. The visibility is better, too, in the Firefly. I wish I'd known about the FF before I bought that Quicksilver. YMMV. -- Robert On Thu, Nov 17, 2011 at 10:44 AM, Tom Stephens wrote: > > It was brought to my attention (appreciate it!) that my subject was a bit > confusing. I cannot buy a plane right now, I am still taking flying > lessons (in a Challenger). I found the photo of Terry's plane and is a > perfect example of a FireFly I'd like to have. > > The problem I have been having is that with our 2 airports (nice BTW), > there is no affordable hangar space, which means I have to either leave a > plane tied up outside, or tow it to the airport. > > I like the Challenger I am flying so much that I'd love to have one. But > with the fuselage covered, rather than a tube, I'd have to cover the whole > plane with wing covers. I've wanted to build an airplane for a long time > now, but finally realized I just don't have the time. Thus the FireFly > would be perfect in that I can tow it to the field. And if I'm lucky, I > might be able to find space in someone's hangar for the folded bird. > > Tom > > -------- > Tom Stephens > www.planeaday.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=358269#358269 > > ________________________________________________________________________________
Date: Nov 17, 2011
In a message dated 11/16/2011 4:46:56 P.M. Eastern Standard Time, tom(at)planeaday.com writes: I got permission from the photographer of this plane to list. Is this a member's plane? I like it! Tom/All That would be Terry Frantz from the Lancaster, PA area. Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive ________________________________________________________________________________
Date: Nov 17, 2011
In a message dated 11/17/2011 11:27:27 A.M. Eastern Standard Time, slyck(at)frontiernet.net writes: P- factor, as in, "I really need to land soon" OK. Good definition. Nobody laughed at that comment yet, so I will Hahahahahah. Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive ________________________________________________________________________________
Date: Nov 17, 2011
At 02:02 PM 11/17/2011, Richard Girard wrote: >Dana, "If you increase power to climb", how exactly does P factor remain >the same? The flight condition we were talking about was cruise when the relative wind is parallel to the propeller shaft, so there's no P-factor. If you increase power to climb while maintaining the same airspeed, the AOA will also be the same, meaning that the airflow is still parallel to the prop shaft, i.e. still no P-factor. -Dana -- Clothes make the man. Naked people have little or no influence on society. ________________________________________________________________________________
Date: Nov 17, 2011
You beat me to that one john I was going to say the same thing I have flown a couple different challengers and the Kolb Airplanes are a better airplane Ellery Batchelder Jr. -----Original Message----- From: John Hauck <jhauck(at)elmore.rr.com> Sent: Thu, Nov 17, 2011 12:10 pm Subject: RE: Kolb-List: Re: FireFly - Someday, I'd like one like this one! like the Challenger I am flying so much that I'd love to have one. Tom -------- om Stephens If you like the Challenger that much, a Kolb would blow you completely away . john h kIII itus, Alabama - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Kolb-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Kolb-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Nov 17, 2011
The minute you start to climb the relative wind direction changes as you now have an upward vector and P factor ensues. Sorry, no free lunch. Rick On Thu, Nov 17, 2011 at 5:04 PM, Dana Hague wrote: > At 02:02 PM 11/17/2011, Richard Girard wrote: > > Dana, "If you increase power to climb", how exactly does P factor remain > the same? > > > The flight condition we were talking about was cruise when the relative > wind is parallel to the propeller shaft, so there's no P-factor. If you > increase power to climb while maintaining the same airspeed, the AOA will > also be the same, meaning that the airflow is still parallel to the prop > shaft, i.e. still no P-factor. > > -Dana > -- > Clothes make the man. Naked people have little or no influence on > society. > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Nov 17, 2011
You're climbing, you have an upward vector, but the plane pitches up by the same amount. If the airspeed is the same, then Cl and AOA have to be the same to generate the same lift (equal to the plane's weight). Actually the above isn't _exactly_ true, as the gravity vector shifts aft relative to the plane, but the effect is small for reasonable angles. In a normal climb, of course, you're flying slower than cruise, thus higher AOA, and P-factor does in fact increase. -Dana At 08:42 PM 11/17/2011, Richard Girard wrote: >The minute you start to climb the relative wind direction changes as you >now have an upward vector and P factor ensues. Sorry, no free lunch. > >Rick > >On Thu, Nov 17, 2011 at 5:04 PM, Dana Hague ><d-m-hague(at)comcast.net> wrote: >At 02:02 PM 11/17/2011, Richard Girard wrote: >>Dana, "If you increase power to climb", how exactly does P factor remain >>the same? >The flight condition we were talking about was cruise when the relative >wind is parallel to the propeller shaft, so there's no P-factor. If you >increase power to climb while maintaining the same airspeed, the AOA will >also be the same, meaning that the airflow is still parallel to the prop >shaft, i.e. still no P-factor. > >-Dana >-- >Clothes make the man. Naked people have little or no influence on society. > > >_blank">www.aeroelectric.com > >.com" target="_blank">www.buildersbooks.com > >="_blank">www.homebuilthelp.com > >_blank">http://www.matronics.com/contribution > >get="_blank">http://www.matronics.com/Navigator?Kolb-List > >tp://forums.matronics.com > >_blank">http://www.matronics.com/contribution > > >-- >Zulu Delta >Mk IIIC >Thanks, Homer GBYM > >It isn't necessary to have relatives in Kansas City in order to be unhappy. > - Groucho Marx > > >www.aeroelectric.com ><http://www.buildersbooks.com>www.buildersbooks.com ><http://www.matronics.com/contribution>http://www.matronics.com/contribution ><http://www.matronics.com/Navigator?Kolb-List>http://www.matronics.com/Navigator?Kolb-List ><http://www.matronics.com/contribution>http://www.matronics.com/contribution > -- Diplomacy: Saying "nice doggy" until you find a rock. ________________________________________________________________________________
Date: Nov 17, 2011
Tell me why I have to hold right rudder when applying power for takeoff? If there's no P=factor on the ground ? On Nov 17, 2011, at 9:05 PM, Dana Hague wrote: > You're climbing, you have an upward vector, but the plane pitches up by the same amount. If the airspeed is the same, then Cl and AOA have to be the same to generate the same lift (equal to the plane's weight). > > Actually the above isn't _exactly_ true, as the gravity vector shifts aft relative to the plane, but the effect is small for reasonable angles. > > In a normal climb, of course, you're flying slower than cruise, thus higher AOA, and P-factor does in fact increase. > > -Dana > > At 08:42 PM 11/17/2011, Richard Girard wrote: >> The minute you start to climb the relative wind direction changes as you now have an upward vector and P factor ensues. Sorry, no free lunch. >> >> Rick >> >> On Thu, Nov 17, 2011 at 5:04 PM, Dana Hague wrote: >> At 02:02 PM 11/17/2011, Richard Girard wrote: >>> >>> Dana, "If you increase power to climb", how exactly does P factor remain the same? >> >> The flight condition we were talking about was cruise when the relative wind is parallel to the propeller shaft, so there's no P-factor. If you increase power to climb while maintaining the same airspeed, the AOA will also be the same, meaning that the airflow is still parallel to the prop shaft, i.e. still no P-factor. >> >> -Dana >> -- >> Clothes make the man. Naked people have little or no influence on society. >> >> >> >> _blank">www.aeroelectric.com >> >> .com" target="_blank">www.buildersbooks.com >> >> ="_blank">www.homebuilthelp.com >> >> _blank">http://www.matronics.com/contribution >> >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> >> tp://forums.matronics.com >> >> _blank">http://www.matronics.com/contribution >> >> >> >> >> -- >> Zulu Delta >> Mk IIIC >> Thanks, Homer GBYM >> >> It isn't necessary to have relatives in Kansas City in order to be unhappy. >> - Groucho Marx >> >> >> >> www.aeroelectric.com >> www.buildersbooks.com >> www.homebuilthelp.com >> http://www.matronics.com/contribution >> -Matt Dralle, List Admin. >> Email Forum - >> http://www.matronics.com/Navigator?Kolb-List >> - MATRONICS WEB FORUMS - >> http://forums.matronics.com >> - List Contribution Web Site - >> -Matt Dralle, List Admin. >> http://www.matronics.com/contribution >> > > -- > Diplomacy: Saying "nice doggy" until you find a rock. > > > ________________________________________________________________________________
Date: Nov 17, 2011
Helical propwash... In most planes you soon outrun most of it and can let o ff on the rudder correction.- Then one more stab on them when the tail co mes up.- I think that is the gyroscope influence.=0A=0A=0A- DjD=0A=0A=0A_ _______________________________=0AFrom: kinne russ <russk50(at)gmail.com>=0ATo : kolb-list(at)matronics.com =0ASent: Thursday, November 17, 2011 8:23 PM=0ASu bject: Re: Kolb-List: Some success at last=0A=0A=0ATell me why I have to ho ld right rudder when applying -power for takeoff? If there's no P=facto r on the ground ? =0A=0A=0A=0AOn Nov 17, 2011, at 9:05 PM, Dana Hague wrote :=0A=0AYou're climbing, you have an upward vector, but the plane pitches up by the same amount.- If the airspeed is the same, then Cl and AOA have t o be the same to generate the same lift (equal to the plane's weight).=0A> =0A>Actually the above isn't _exactly_ true, as the gravity vector shifts a ft relative to the plane, but the effect is small for reasonable angles.=0A >=0A>In a normal climb, of course, you're flying slower than cruise, thus h igher AOA, and P-factor does in fact increase.=0A>=0A>-Dana=0A>=0A>At 08:42 PM 11/17/2011, Richard Girard wrote:=0A>=0A>The minute you start to climb the relative wind direction changes as you now have an upward vector and P factor ensues. Sorry, no free lunch.=0A>>=0A>>Rick=0A>>=0A>>On Thu, Nov 17, 2011 at 5:04 PM, Dana Hague wrote: =0A>>At 02:02 P M 11/17/2011, Richard Girard wrote: =0A>>Dana, "If you increase power to cl imb", how exactly does P factor remain the same?=0A>>The flight condition w e were talking about was cruise when the relative wind is parallel to the p ropeller shaft, so there's no P-factor.- If you increase power to climb w hile maintaining the same airspeed, the AOA will also be the same, meaning that the airflow is still parallel to the prop shaft, i.e. still no P-facto r.=0A>>=0A>>=0A>>-Dana =0A>>-- =0A>>Clothes make the man.- Naked people h ave little or no influence on society. =0A>>_blank">www.aeroelectric.com =0A>>.com" target="_blank">www.buildersbooks.com =0A>>="_blank">www.hom ebuilthelp.com =0A>>_blank">http://www.matronics.com/contribution =0A>>get ="_blank">http://www.matronics.com/Navigator?Kolb-List =0A>>tp://forums.m atronics.com =0A>>_blank">http://www.matronics.com/contribution =0A>>=0A>> =0A>>-- =0A>>Zulu Delta=0A>>Mk IIIC=0A>>Thanks, Homer GBYM=0A>>=0A>>It isn' t necessary to have relatives in Kansas City in order to be unhappy.=0A>> - - Groucho Marx=0A>>=0A>>=0A>>=0A>>=0A>>www.aeroelectric.com www.builder sbooks.com www.homebuilthelp.com http://www.matronics.com/contribution-M att Dralle, List Admin.Email Forum -http://www.matronics.com/Navigato r?Kolb-List- MATRONICS WEB FORUMS -http://forums.matronics.com/- L ist Contribution Web Site --Matt Dralle, List Admin. http://www.matronic s.com/contribution =0A>=0A>--=0A>Diplomacy: Saying "nice doggy" until you f D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D ________________________________________________________________________________
Date: Nov 18, 2011
I like the Challenger I am flying so much that I'd love to have one>> Hi Tom, If you go for a Challenger in spite of the non folding wing be sure you get the model with the enlarged fin and rudder. The original was much to small and didn`t hold direction well at all. I built the original version and later updated with a larger fin and an extension forward along the top of the fuselage. I didn`t put doors on and enjoyed the open cockpit feel. I also enjoyed the superb controlled side slip possible in the Challenger. Unfortunately approaching old age and stiffening joints meant that I could not get into the cockpit without a struggle and a couple of drive belts shedding their teeth and putting me sharply down in a field made up my mind. I changed her out for the gentlemanly comfort of an Xtra which is the only Kolb available over here. It is very nice and I enjoy it but it won`t sideslip worth a damn. With the big flaps of course you shouldn`t need to sideslip but when I make `bomber approaches` with half flap I sometimes miss being able to pull the nose up, stick a wing down , give her a bootful of rudder and slide over the hedge. Cheers Pat ________________________________________________________________________________
Date: Nov 18, 2011
Subject: Re: Some success at last
At 09:23 PM 11/17/2011, kinne russ wrote: >Tell me why I have to hold right rudder when applying power for takeoff? >If there's no P=factor on the ground ? There _is_ P-factor on the ground in a tailwheel airplane with the tailwheel on the ground. There are four turning effects from the propeller: 1. P-factor, or asymmetric blade thrust, whenever the axis of the prop isn't parallel to the relative wind. 2. Spiraling slipstream from the prop, impinging more on one side of the vertical stabilizer than the other (this may be less, or even in the opposite direction with an engine mounted high over the rudder as in a Kolb). 3. Direct torque (causes a roll effect as opposed to yaw). 4. Gyroscopic precession, which causes the plane to yaw while pitching, as when you lift the tailwheel. -Dana -- "A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away." -- Antoine de Saint-Exup=E9ry ________________________________________________________________________________
Date: Nov 18, 2011
Thanks Dana, and Lanny, and Wikepedia, I think that at last I have got it. By visualising the reductio ad absurdum case of the airflow over the propeller if a plane is descending vertically but in a horizontal position. The airflow in that case would be travelling over the prop blade in the same way as the wind over a helicopter rotor with its well known, and easily visualised, advancing and retiring blade. I am still surprised however that the effect is noticeable in the case of the comparatively low power and small diameter props that we generally use. I would have just put it down to torque and coriolis force and the tendency of a spinning disc to precess. Think of a gyroscope. I know better now. Thanks for your patience. Pat ________________________________________________________________________________
Date: Nov 18, 2011
Hangars are very expensive at my airport, kpmp. I'm lucky in that the flying club of which I'm a member (we have two Piper Archers 180's,) has an end unit in a row of T-hangers where we keep supplies and tools. I rent room to slide my folded Mk III in the long side of the 1/2 "T". This trick might be a good option for anyone seeking affordable shelter. I pay a percentage of the rent based on the footprint of the Kolb. On the subject of rudder trim, all private pilots learn that turning tendency is induced by three forces- engine torque, slipstream and P-factor. My rudder trim tab mitigates the yaw in cruise caused by slipstream (prop wash.) In climb, the predominant turning moment is from P-factor (asymmetrical thrust by the prop.) In a turn, drag caused by the up aileron causes adverse yaw in most airplanes, requiring rudder to compensate. However, I haven't experienced significant adverse yaw in my Kolb. Hope that is helpful! Dave Watkins Mk III-C Built by Steven Green. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358353#358353 ________________________________________________________________________________
Date: Nov 18, 2011
As I understand things, if the plane/gyroscope is going straight ahead there should be precession, no tendency to swerve. I think the plane simply runs ahead of the helical propwash when it gains speed, so you can ease up on your foot pressure. Is there any practical difference between 'helical propwash' and 'P-factor'? On Nov 17, 2011, at 10:55 PM, Danny wrote: > Helical propwash... In most planes you soon outrun most of it and can let off on the rudder correction. Then one more stab on them when the tail comes up. I think that is the gyroscope influence. > > - DjD > From: kinne russ <russk50(at)gmail.com> > To: kolb-list(at)matronics.com > Sent: Thursday, November 17, 2011 8:23 PM > Subject: Re: Kolb-List: Some success at last > > Tell me why I have to hold right rudder when applying power for takeoff? If there's no P=factor on the ground ? > > > On Nov 17, 2011, at 9:05 PM, Dana Hague wrote: > >> You're climbing, you have an upward vector, but the plane pitches up by the same amount. If the airspeed is the same, then Cl and AOA have to be the same to generate the same lift (equal to the plane's weight). >> >> Actually the above isn't _exactly_ true, as the gravity vector shifts aft relative to the plane, but the effect is small for reasonable angles. >> >> In a normal climb, of course, you're flying slower than cruise, thus higher AOA, and P-factor does in fact increase. >> >> -Dana >> >> At 08:42 PM 11/17/2011, Richard Girard wrote: >>> The minute you start to climb the relative wind direction changes as you now have an upward vector and P factor ensues. Sorry, no free lunch. >>> >>> Rick >>> >>> On Thu, Nov 17, 2011 at 5:04 PM, Dana Hague wrote: >>> At 02:02 PM 11/17/2011, Richard Girard wrote: >>>> >>>> Dana, "If you increase power to climb", how exactly does P factor remain the same? >>> >>> The flight condition we were talking about was cruise when the relative wind is parallel to the propeller shaft, so there's no P-factor. If you increase power to climb while maintaining the same airspeed, the AOA will also be the same, meaning that the airflow is still parallel to the prop shaft, i.e. still no P-factor. >>> >>> -Dana >>> -- >>> Clothes make the man. Naked people have little or no influence on society. >>> >>> >>> >>> _blank">www.aeroelectric.com >>> >>> .com" target="_blank">www.buildersbooks.com >>> >>> ="_blank">www.homebuilthelp.com >>> >>> _blank">http://www.matronics.com/contribution >>> >>> get="_blank">http://www.matronics.com/Navigator?Kolb-List >>> >>> tp://forums.matronics.com >>> >>> _blank">http://www.matronics.com/contribution >>> >>> >>> >>> >>> -- >>> Zulu Delta >>> Mk IIIC >>> Thanks, Homer GBYM >>> >>> It isn't necessary to have relatives in Kansas City in order to be unhappy. >>> - Groucho Marx >>> >>> >>> >>> www.aeroelectric.com >>> www.buildersbooks.com >>> www.homebuilthelp.com >>> http://www.matronics.com/contribution >>> -Matt Dralle, List Admin. >>> Email Forum - >>> http://www.matronics.com/Navigator?Kolb-List >>> - MATRONICS WEB FORUMS - >>> http://forums.matronics.com/ >>> - List Contribution Web Site - >>> -Matt Dralle, List Admin. >>> http://www.matronics.com/contribution >>> >> >> -- >> Diplomacy: Saying "nice doggy" until you find a rock. >> >> >> > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > om > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > List > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > > > > > > ________________________________________________________________________________
Subject: Some success at last
Date: Nov 18, 2011
On Behalf Of kinne russ As I understand things, if the plane/gyroscope is going straight ahead there should be precession, no tendency to swerve. I think the plane simply runs ahead of the helical propwash when it gains speed, so you can ease up on your foot pressure. Is there any practical difference between 'helical propwash' and 'P-factor'? Russ K/Kolbers: That is what I have been sharing for a long time. The primary yaw problem in the MKIII is the effect of helical prop wash. Take that problem away and the adverse yaw problem goes away. Clear evidence of where the prop wash hits the left side of the vertical stabilizer and the top of the left horizontal stabilizer, on a 912 powered MKIII, is enough for me to understand by I have to have a large rudder trim tab to kick the rudder left and keep it in trim. I have experimented with changing angle of thrust up and down, left and right; moved the leading edge of the upper vertical stabilizer left; but the large rudder trim tab was the fix for adverse yaw on my MKIII. If you are ever around my airplane after I have made a long flight in turbulent conditions you will see where the byproducts from the engine crankcase breather hit the tail section. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 18, 2011
I had a friend that worked in the lab at Homelite. They tested all the oils on the market at the time. Texaco Havoline with Royalgard won. Any good quality organic oil is fine as long as it contains a TCW-3 which is a rust inhibitor. Do the Amsoil products contain a rust inhibitor? I've flown behind Rotaxes for over 25yrs now with no oil related problems. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358360#358360 ________________________________________________________________________________
Date: Nov 18, 2011
There is a lot of confusing adverse yaw discussion in this thread already. Adverse yaw is caused by ailerons. The down aileron has the extra drag and yaws the plane opposite of the intended turn. This stuff is confusing enough especially when you are just learning. Just saying. p.s. I also am impressed with Terry's Firefly. Nice. Scott Olendorf -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358362#358362 ________________________________________________________________________________
Subject: Folding Wings and Hangar Space
Date: Nov 18, 2011
From: "Kirby, Dennis Civ USAF AFMC AFNWC/ENS" <Dennis.Kirby(at)kirtland.af.mil>
"Tom Stephens" wrote: << . And if I'm lucky, I might be able to find space in someone's hangar for the folded bird. Tom >> Tom - Welcome to the Kolb List. Sounds like you picked the right airplane (Kolb) for your needs. Folding wings was a primary decision factor for me too, for exactly the same reason you mention: Expensive hangar rent in your area. The hangar in this picture rents for $180 per month - too much for me by myself. The folding wings on my Mark-3 allow me to squeeze in a small space in this hangar that I share with a Piper Pacer, and I consequently pay only one-third the rent. The affordability is worth the 15 minutes it takes me to erect the wings each time I fly. Dennis Kirby Mark-3, "Magic Bike" in Sandia Park, NM ________________________________________________________________________________
Date: Nov 18, 2011
Subject: Re: Folding Wings and Hangar Space
Tom, Another option you might wish to check out is half hangars. Every row of "T" hangars has a half hangar at each end of the building. I had one at KPAE (Paine Field at Everett, WA where Boeing builds the 747, 767, 777 and now the 787) and the rent was less than half what a full hangar cost. They were also quicker to get, too. There was a three year wait on average for a full hangar, but I got a half hangar within two months of getting on the list for them. Rick Girard On Fri, Nov 18, 2011 at 9:12 AM, Kirby, Dennis Civ USAF AFMC AFNWC/ENS < Dennis.Kirby(at)kirtland.af.mil> wrote: > "Tom Stephens" wrote: << =85 And if I'm lucky, I might be able to find sp ace > in someone's hangar for the folded bird. Tom >>**** > > ** ** > > Tom '**** > > ** ** > > Welcome to the Kolb List. Sounds like you picked the right airplane > (Kolb) for your needs. Folding wings was a primary decision factor for m e > too, for exactly the same reason you mention: Expensive hangar rent in yo ur > area. The hangar in this picture rents for $180 per month ' too much f or > me by myself. The folding wings on my Mark-3 allow me to squeeze in a > small space in this hangar that I share with a Piper Pacer, and I > consequently pay only one-third the rent. The affordability is worth the > 15 minutes it takes me to erect the wings each time I fly.**** > > ** ** > > Dennis Kirby**** > > Mark-3, =93Magic Bike=94 in**** > > Sandia Park, NM**** > > ** ** > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Nov 18, 2011
Thanks for catching my error, Scott. You are correct. It's the down aileron that pulls the aircraft in the opposite direction of the intended turn. Must be the aging process... Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358373#358373 ________________________________________________________________________________
Subject: Firefly under 254 - How did you do it?
Date: Nov 18, 2011
How many of you have/had FireFly's that were actually under 254? How did you do it? What motor did you use? Is this possible? Tom -------- Tom Stephens www.planeaday.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358383#358383 ________________________________________________________________________________
Date: Nov 18, 2011
Pat, I'd still consider the Challenger, but NO folding wings :-( All who are giving the FireFly flight characteristics, GREAT, thanks, I enjoy hearing!! Phil, What are you going to do to keep your FireFly within 103?... I'm very interested in this... well of course, as you can tell from my other post. What was your first Kolb and why did you decide upon the FireFly? Tom -------- Tom Stephens www.planeaday.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358403#358403 ________________________________________________________________________________
Date: Nov 18, 2011
Dennis, Thank you for the welcome! Your picture is worth 1000 words. Now THAT's what I am hoping will work out. Tom -------- Tom Stephens www.planeaday.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358404#358404 ________________________________________________________________________________
Date: Nov 18, 2011
I have been struggling with the same issue. Too bad we have to select our flying machines based on the hangar situation. For me, it boils down to: Have affordable hangar or barn: Excalibur Have partial hangar or enclosed trailer: Kolb No hangar: all-metal plane (Zenith) My FBO would let me keep an enclosed trailer on the field for the tie-down fee ($35/month), whereas a T-hangar would be $250+, plus waiting list. Martin Beaverton, OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358410#358410 ________________________________________________________________________________
Date: Nov 18, 2011
Keeping the Firefly 103 legal, in my studies, should be a piece of cake. I' m just going to follow the plans, and omit the nosecone and windshield to s tart. I'm using the CRE mz201 which is estimated at 73# including elec and pull s tart, exhaust and muffler, and 1.77:1 belt reduc, and I don't have a firm q uote yet, but it looks like I'll be swinging a 60-62" wooden TN prop. I decided on the Firefly because I like the Kolb over all other airborne cr itters I've seen, hands down, because I had a Twinstar before, I live 0.70 miles from 1a0 Dallas Bay Airpark, I don't want to go through inspections, registrations, etc., and because I wanted to taste bugs again. Phil H. http://phactor.com/i/f3.jpg --- On Fri, 11/18/11, Tom Stephens wrote: From: Tom Stephens <tom(at)planeaday.com> Subject: Kolb-List: Re: FireFly - Someday, I'd like one like this one! Date: Friday, November 18, 2011, 5:13 PM Pat, I'd still consider the Challenger, but NO folding wings :-( All who are giving the FireFly flight characteristics, GREAT, thanks, I enj oy hearing!! Phil, What are you going to do to keep your FireFly within 103?... I'm very inter ested in this... well of course, as you can tell from my other post.- Wha t was your first Kolb and why did you decide upon the FireFly? Tom -------- Tom Stephens www.planeaday.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358403#358403 le, List Admin. le, List Admin. ________________________________________________________________________________
Date: Nov 18, 2011
koxxy wrote: > I have been struggling with the same issue. Too bad we have to select our flying machines based on the hangar situation. For me, it boils down to: > Have affordable hangar or barn: Excalibur > Have partial hangar or enclosed trailer: Kolb > No hangar: all-metal plane (Zenith) > > My FBO would let me keep an enclosed trailer on the field for the tie-down fee ($35/month), whereas a T-hangar would be $250+, plus waiting list. > > Martin > Beaverton, OR Many select the Kolb for other reasons (not the least of which is that it's a great airplane) and then get the added benefits of lower berthing costs and portability. -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358413#358413 ________________________________________________________________________________
Date: Nov 18, 2011
Yes, of course. All these airplanes have their strengths and weaknesses. And the builder's budget plays a big role. But that's the point I am making: the hangar situation should not be the deciding factor, but for many of us, it is. If I cannot find a place to store the plane under some sort of cover, I'll have to pass on anything that is fabric covered, no matter how good the plane is otherwise. On Fri, Nov 18, 2011 at 3:35 PM, George Alexander wrote: > > > koxxy wrote: > > I have been struggling with the same issue. Too bad we have to select > our flying machines based on the hangar situation. For me, it boils down to: > > Have affordable hangar or barn: Excalibur > > Have partial hangar or enclosed trailer: Kolb > > No hangar: all-metal plane (Zenith) > > > > My FBO would let me keep an enclosed trailer on the field for the > tie-down fee ($35/month), whereas a T-hangar would be $250+, plus waiting > list. > > > > Martin > > Beaverton, OR > > > Many select the Kolb for other reasons (not the least of which is that > it's a great airplane) and then get the added benefits of lower berthing > costs and portability. > > -------- > George Alexander > FS II R503 N709FS > http://www.oh2fly.net > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=358413#358413 > > ________________________________________________________________________________
Date: Nov 18, 2011
Phil, "and because I wanted to taste bugs again" Ahhh, the most important reason ;-) How are you going to mount the MZ201? Tom -------- Tom Stephens www.planeaday.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358418#358418 ________________________________________________________________________________
Date: Nov 18, 2011
Take the front wheel off the nearest "English Racer", hold it by the axle a nd spin it up.- Now tilt it as if it were your prop disc when the tail co mes up.- The effect is quite strong but brief... =0AClick here to read mo re...=0A-=0A=0ATo: kolb-list(at)matronics.com =0ASent: Friday, November 18, 2011 7:59 AM=0ASubject: Re: Kolb-List: Some success at last=0A=0A=0AAs I un derstand things, if the plane/gyroscope is going straight ahead there shoul d be precession, no tendency to swerve. I think the plane simply runs ahead of the helical propwash when -it gains speed, so you can ease up on your foot pressure. Is there any practical difference between 'helical propwash ' and 'P-factor'? =0A=0A=0AOn Nov 17, 2011, at 10:55 PM, Danny wrote:=0A=0A Helical propwash... In most planes you soon outrun most of it and can let o ff on the rudder correction.- Then one more stab on them when the tail co mes up.- I think that is the gyroscope influence.=0A>=0A>=0A>- DjD=0A>=0A >=0A>________________________________=0A>From: kinne russ <russk50(at)gmail.co m>=0A>To: kolb-list(at)matronics.com =0A>Sent: Thursday, November 17, 2011 8:2 3 PM=0A>Subject: Re: Kolb-List: Some success at last=0A>=0A>=0A>Tell me why I have to hold right rudder when applying -power for takeoff? If there's no P=factor on the ground ? =0A>=0A>=0A>=0A>=0A>On Nov 17, 2011, at 9:05 PM, Dana Hague wrote:=0A>=0A>You're climbing, you have an upward vector, b ut the plane pitches up by the same amount.- If the airspeed is the same, then Cl and AOA have to be the same to generate the same lift (equal to th e plane's weight).=0A>>=0A>>Actually the above isn't _exactly_ true, as the gravity vector shifts aft relative to the plane, but the effect is small f or reasonable angles.=0A>>=0A>>In a normal climb, of course, you're flying slower than cruise, thus higher AOA, and P-factor does in fact increase.=0A >>=0A>>-Dana=0A>>=0A>>At 08:42 PM 11/17/2011, Richard Girard wrote:=0A>>=0A >>The minute you start to climb the relative wind direction changes as you now have an upward vector and P factor ensues. Sorry, no free lunch.=0A>>> =0A>>>Rick=0A>>>=0A>>>On Thu, Nov 17, 2011 at 5:04 PM, Dana Hague wrote: =0A>>>At 02:02 PM 11/17/2011, Richard Girard wrote: =0A>>>Dana, "If you increase power to climb", how exactly does P factor rem ain the same?=0A>>>The flight condition we were talking about was cruise wh en the relative wind is parallel to the propeller shaft, so there's no P-fa ctor.- If you increase power to climb while maintaining the same airspeed , the AOA will also be the same, meaning that the airflow is still parallel to the prop shaft, i.e. still no P-factor.=0A>>>=0A>>>=0A>>>-Dana =0A>>>-- =0A>>>Clothes make the man.- Naked people have little or no influence on society. =0A>>>_blank">www.aeroelectric.com =0A>>>.com" target="_blank"> www.buildersbooks.com =0A>>>="_blank">www.homebuilthelp.com =0A>>>_blank" >http://www.matronics.com/contribution =0A>>>get="_blank">http://www.matr onics.com/Navigator?Kolb-List =0A>>>tp://forums.matronics.com =0A>>>_blank" >http://www.matronics.com/contribution =0A>>>=0A>>>=0A>>>-- =0A>>>Zulu Delt a=0A>>>Mk IIIC=0A>>>Thanks, Homer GBYM=0A>>>=0A>>>It isn't necessary to hav e relatives in Kansas City in order to be unhappy.=0A>>>- - Groucho Marx =0A>>>=0A>>>=0A>>>=0A>>>=0A>>>www.aeroelectric.com www.buildersbooks.com ww w.homebuilthelp.com http://www.matronics.com/contribution-Matt Dralle, L ist Admin.Email Forum -http://www.matronics.com/Navigator?Kolb-List - MATRONICS WEB FORUMS -http://forums.matronics.com/- List Contrib ution Web Site --Matt Dralle, List Admin. http://www.matronics.com/contr ibution =0A>>=0A>>--=0A>>Diplomacy: Saying "nice doggy" until you find a ro ck.-- =0A>=0A>3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3Dom>3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3DList3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D>3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =0A>=0A>=0A>h ref="http://www.aeroelectric.com/">www.aeroelectric.comhref="http:// www.buildersbooks.com/">www.buildersbooks.comhref="http://www.homebuil thelp.com/">www.homebuilthelp.comhref="http://www.matronics.com/contri bution">http://www.matronics.com/contributionhref="http://www.matronic s.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-Listh ref="http://forums.matronics.com/">http://forums.matronics.comhref=" http://www.matronics.com/contribution">http://www.matronics.com/contributio = Archive Search & Download, 7-Day ======================== ====== ________________________________________________________________________________
Date: Nov 18, 2011
Absolutely. You aren't really flying unless you're eatin' bugs. I plan to mount the mz201 upright with the belt reduc down. The bolt patter n is 102 sts (side-to-side) x 202 ftb (front-to-back). I don't have the Rot ax 447 and 503 sts dimensions, but ftb looks to be 143 and 153, respectivel y. 201- 102mm x 202mm 447- ???mm x 143mm 503- ???mm x 153mm I also really hope I'm able to hang the muffler down in between the aileron pushpull rods, similar to the way this gentlemen did. I don't know where I got this pic, but I really like the idea! http://phactor.com/Kolb/DownExhaust.jpg I've yet to determine where to align the reduc, but I'm certainly going to attempt a left-of-center PTO. Jack Hart goes into a great discussion on P-f actor, trimming, and offset thrust by moving the PTO left-of-center by rota ting the reduc to the 305, 270 and 235 degree positions (roughly 10:30, 9:0 0 and 7:30 positions), here: http://jackbhart.com/firefly/firefly56.html http://jackbhart.com/firefly/firefly129.html http://jackbhart.com/firefly/firefly101.html Jack, if you're listening, please chime in! Phil --- On Fri, 11/18/11, Tom Stephens wrote: From: Tom Stephens <tom(at)planeaday.com> Subject: Kolb-List: Re: FireFly - Someday, I'd like one like this one! Date: Friday, November 18, 2011, 7:26 PM Phil, "and because I wanted to taste bugs again"- Ahhh, the most important reas on ;-) How are you going to mount the MZ201? Tom -------- Tom Stephens www.planeaday.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358418#358418 le, List Admin. le, List Admin. ________________________________________________________________________________
Date: Nov 18, 2011
Phil, I am used to the MZ-34 with the mount in back. Sorry about that. I see that the 201 is "normal": http://www.compactengines.com/MZ-201-lite1.jpg Tom -------- Tom Stephens www.planeaday.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358431#358431 ________________________________________________________________________________
Date: Nov 19, 2011
olendorf wrote: > There is a lot of confusing adverse yaw discussion If any of you feel incipient confusion, git yersef a copy of "Stick and Rudder", unless you have one already. GOOD explanations of alla this, as I recall. Not that you need it... I came into the discussion a few days late, sounds settled already. -------- GeoB "Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358439#358439 ________________________________________________________________________________
Date: Nov 19, 2011
Subject: The Value of a Forum...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Arn't the Lists worth at least that much to you? Wouldn't it be great if you could pay that same amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... Won't you take a minute to make your Contribution today and support YOUR Lists? Please make a Contribution today at: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Again, I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Subject: radio noise
Date: Nov 19, 2011
Pat Ladd, I bought some ferrite chokes from Radio Shack last week.They were about $3. 00 for a pack of two of them.I snapped them around the RG58 antenna cable a nd really reduced the amount of noise I was getting from the engines high tension electrics and the GPS. G.Aman ________________________________________________________________________________
Subject: Model Kolbs
Date: Nov 19, 2011
Kolb people, I have been kicking around the idea of building a scale Kolb model airplane. I'm not set on a particular model, any of the various designs would be okay. (Firefly, Firestar, MkIIIC or X, Slingshot, Kolbra....all good contenders) Has anyone, or do you know of anyone, who has measured ANY of the Kolb fuselages, and various structures, like wings, tailfeathers, etc., and come up with a set of scaled plans. Depending how much information there is, if I can get it close enough, I may try to make it RC controlled...or at the very least, it would make a nice home office hanging ornament. Mike Welch ________________________________________________________________________________
Date: Nov 19, 2011
Subject: Re: Model Kolbs
Someone brought one to a Kolb Homecoming some years back.... Radio controlled Firefly as I recall...Herb At 02:35 PM 11/19/2011, you wrote: > >Kolb people, > > I have been kicking around the idea of building a scale Kolb > model airplane. I'm not set on a particular model, >any of the various designs would be okay. (Firefly, Firestar, >MkIIIC or X, Slingshot, Kolbra....all >good contenders) > > Has anyone, or do you know of anyone, who has measured ANY of the > Kolb fuselages, and various >structures, like wings, tailfeathers, etc., and come up with a set >of scaled plans. Depending how much >information there is, if I can get it close enough, I may try to >make it RC controlled...or at the very least, >it would make a nice home office hanging ornament. > >Mike Welch > ________________________________________________________________________________
Date: Nov 19, 2011
Sounds good, 1.7 meter span. 4 cell poly pack, out runner with a 13 x 8 prop, 6 servos, all built up balsa. Covered in Solatex. Lot of fun to fly Send pictures when you are done. Sy Sent via my BlackBerry from Vodacom - let your email find you! -----Original Message----- From: Michael Welch <mdnanwelch7(at)hotmail.com> Sender: owner-kolb-list-server(at)matronics.com Date: Sat, 19 Nov 2011 14:35:15 Kolb people, I have been kicking around the idea of building a scale Kolb model airplane. I'm not set on a particular model, any of the various designs would be okay. (Firefly, Firestar, MkIIIC or X, Slingshot, Kolbra....all good contenders) Has anyone, or do you know of anyone, who has measured ANY of the Kolb fuselages, and various structures, like wings, tailfeathers, etc., and come up with a set of scaled plans. Depending how much information there is, if I can get it close enough, I may try to make it RC controlled...or at the very least, it would make a nice home office hanging ornament. Mike Welch ________________________________________________________________________________
Date: Nov 19, 2011
On Nov 19, 2011, at 3:21 PM, simonnelson(at)vodamail.co.za wrote: > > Sounds good, 1.7 meter span. 4 cell poly pack, out runner with a 13 x 8 prop, 6 servos, all built up balsa. Covered in Solatex. > > Lot of fun to fly > > Send pictures when you are done. > > > Sy Sy, Do you have any pictures of this plane you refer to? Mike ________________________________________________________________________________
Date: Nov 20, 2011
Hi All, I have read the discussion of Kolb storage with interest. I have chosen a solution that has worked very well for me over the last 16 years that I would like to add to the discussion. I have a Kolb Firestar II which currently has 510 hours. I keep it in my garage in town, and I use an uncovered trailor to take it to the airport and back. Typical trip to the airport is 25 miles one way. I could get an actual count of the times I have done this, but will rather estimate it at 175 times over the last 16 years. I have devised some simple jigs that make assembling an disassembling the airplane a quick and easy one-man job. A typical day of flying for me, such as today in which I flew 2.9 hours, is to roll the airplane out of the garage, put it on the trailer, got to the airport, etc. Coming home is just the reverse process. With a well thought out plan, it is simple, easy and quick. So, for those with the urge, a garage and no acceptable access to a hanger, there is another way. Vince Firestar II, Rotax 503 DCDI 510 hours N8233G ________________________________________________________________________________
Date: Nov 19, 2011
http://www.youtube.com/watch?v=F8XP5VRzOKo&feature=related -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern These flying machines are just a fad and will never catch on Unknown Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358550#358550 ________________________________________________________________________________
Subject: Re: radio noise
Date: Nov 19, 2011
Something I did that was easy and helped cut down radio noise a lot: I disconnected the radio hot lead from the avionics bus and ran the power wire and ground wire straight to the battery with a small inline fuse. The radio power is now separate from the rest of the airplane. Big improvement. The next biggest help - although a lot more trouble, and you need to do it when you build the airplane - use shielded wire for your mag switches. Those nasty little wires come right off your magneto and carry rapidly pulsing AC. Your spark plug wires are doing the same thing, at a higher voltage, but they are short, your kill switch wires are many feet long. Worth what ya paid fer it - -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358551#358551 ________________________________________________________________________________
Date: Nov 19, 2011
Greetings Vince, It seems you have the process down pat. Would you share some pictures of your jigs and trailer. Thanks, David d. -------- Kolb Mark IIIX 582 Blue head Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358552#358552 ________________________________________________________________________________
Date: Nov 19, 2011
ZGFuZyB0aGVyZSBmb3IgYXdoaWxlIEkgdGhvdWdodCBzb21lb25lIGhhZCB2aWRlbydkIG1lIGZs eWluZyBteSAgDQpmaXJlc3Rhci4uLnRpcyBhIGdvb2QgZmx5aW5nIG1vZGVsLiBlbmpveWVkIGl0 Li4udGhhbmtzIGZvciAgcG9zdGluZy4uLi5qc3dhbg0KIA0KSmltIFN3YW4gS29sYiAgRmlyZXN0 YXIgbGwsIDUwMyBSb3RheCAsIDYxNDcgV2lsY294IFJkLiwgRWF0b24gUmFwaWRzLCBNaSANCjQ4 ODI3IHBoIDUxNy02NjMtODQ4OCAgR1BTIEdQUyBGT1IgTVkgUlVOV0FZIE4gNDIgZGVnIDI4LjU4 MSBXMDg0ZGVnIDQ0LjgyNSAgDQoNCiANCkluIGEgbWVzc2FnZSBkYXRlZCAxMS8xOS8yMDExIDk6 MDc6MDEgUC5NLiBFYXN0ZXJuIFN0YW5kYXJkIFRpbWUsICANCnJldHJvbWFuQGZyb250aWVyLmNv bSB3cml0ZXM6DQoNCi0tPiAgS29sYi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiRGVubmlzIFRo YXRlIiAgPHJldHJvbWFuQGZyb250aWVyLmNvbT4NCg0KaHR0cDovL3d3dy55b3V0dWJlLmNvbS93 YXRjaD92PUY4WFA1VlJ6T0tvJmZlYXR1cmU9cmVsYXRlZA0KDQotLS0tLS0tLQ0KQm90aCAgb3B0 aW1pc3RzIGFuZCBwZXNzaW1pc3RzIGNvbnRyaWJ1dGUgdG8gb3VyIHNvY2lldHkuICBUaGUgb3B0 aW1pc3QgDQppbnZlbnRzICB0aGUgYWlycGxhbmUgYW5kIHRoZSBwZXNzaW1pc3QgdGhlIHBhcmFj aHV0ZS4gIH5HaWwgIFN0ZXJuDQoNCsOi4oKswqbDouKCrMKdVGhlc2UgZmx5aW5nIG1hY2hpbmVz IGFyZSBqdXN0IGEgZmFkIGFuZCB3aWxsIG5ldmVyIGNhdGNoICBvbsOi4oKswqbDouKCrMKdIA0K VW5rbm93bg0KDQoNCg0KDQpSZWFkIHRoaXMgdG9waWMgb25saW5lICBoZXJlOg0KDQpodHRwOi8v Zm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTM1ODU1MCMzNTg1NTANCg0KDQoN Cg0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT0NCl8tPQ0KXy09ICAgLS0gUGxlYXNlIFN1cHBvcnQgWW91ciBMaXN0cyBU aGlzIE1vbnRoIC0tDQpfLT0gICAoQW5kIEdldCBTb21lIEFXRVNPTUUgRlJFRSAgR2lmdHMhKQ0K Xy09DQpfLT0gICBOb3ZlbWJlciBpcyB0aGUgQW5udWFsIExpc3QgRnVuZCAgUmFpc2VyLiAgQ2xp Y2sgb24NCl8tPSAgIHRoZSBDb250cmlidXRpb24gbGluayBiZWxvdyB0byBmaW5kICBvdXQgbW9y ZSBhYm91dA0KXy09ICAgdGhpcyB5ZWFyJ3MgVGVycmlmaWMgRnJlZSBJbmNlbnRpdmUgR2lmdHMg IHByb3ZpZGVkDQpfLT0gICBieToNCl8tPSAgIA0KXy09ICAgICAgKiBBZXJvRWxlY3RyaWMgd3d3 LmFlcm9lbGVjdHJpYy5jb20NCl8tPSAgICAgKiBUaGUgQnVpbGRlcidzICBCb29rc3RvcmUgd3d3 LmJ1aWxkZXJzYm9va3MuY29tDQpfLT0gICAgICogSG9tZWJ1aWx0SEVMUCAgd3d3LmhvbWVidWls dGhlbHAuY29tDQpfLT0NCl8tPSAgIExpc3QgQ29udHJpYnV0aW9uIFdlYiAgU2l0ZToNCl8tPQ0K Xy09ICAgLS0+ICBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT0NCl8t PSAgIFRoYW5rIHlvdSBmb3IgIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPQ0KXy09ICAgICAg ICAgICAgIC1NYXR0IERyYWxsZSwgIExpc3QgIEFkbWluLg0KXy09DQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgLSBU aGUgS29sYi1MaXN0IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2UgdGhlICBNYXRyb25pY3MgTGlzdCBG ZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMg IHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3du bG9hZCwgNy1EYXkgIEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNo IG11Y2ggIG1vcmU6DQpfLT0NCl8tPSAgIC0tPiAgaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05h dmlnYXRvcj9Lb2xiLUxpc3QNCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgIC0gTUFUUk9OSUNTIFdFQiBGT1JV TVMgIC0NCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIg IEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+ICBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCl8t PQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0NCl8tPSAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgIC0NCl8tPSAgVGhh bmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQpfLT0gICAgICAgIC1NYXR0IERyYWxs ZSwgTGlzdCBBZG1pbi4NCl8tPSAgIC0tPiAgaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRy aWJ1dGlvbg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT0NCg0KDQoNCg0KDQo ________________________________________________________________________________
Date: Nov 19, 2011
makes a lot of sense to this old michigan kolb pilot... Jim Swan Kolb Firestar ll, 503 Rotax , 6147 Wilcox Rd., Eaton Rapids, Mi 48827 ph 517-663-8488 GPS GPS FOR MY RUNWAY N 42 deg 28.581 W084deg 44.825 In a message dated 11/19/2011 8:16:56 P.M. Eastern Standard Time, vincenic1(at)embarqmail.com writes: --> Kolb-List message posted by: Vincent Nicely Hi All, I have read the discussion of Kolb storage with interest. I have chosen a solution that has worked very well for me over the last 16 years that I would like to add to the discussion. I have a Kolb Firestar II which currently has 510 hours. I keep it in my garage in town, and I use an uncovered trailor to take it to the airport and back. Typical trip to the airport is 25 miles one way. I could get an actual count of the times I have done this, but will rather estimate it at 175 times over the last 16 years. I have devised some simple jigs that make assembling an disassembling the airplane a quick and easy one-man job. A typical day of flying for me, such as today in which I flew 2.9 hours, is to roll the airplane out of the garage, put it on the trailer, got to the airport, etc. Coming home is just the reverse process. With a well thought out plan, it is simple, easy and quick. So, for those with the urge, a garage and no acceptable access to a hanger, there is another way. Vince Firestar II, Rotax 503 DCDI 510 hours N8233G ________________________________________________________________________________
Date: Nov 19, 2011
i installed an aprs ham radio tracker,,, and every time it sent out a packet i could hear it in the intercom and it interfered with the eis... i installed a ferrite bead in the power line to the tracker and eliminated the noise and interference.. i also used coax for the mag switches. good ideas going around here. boyd young mkiii ut >>>>>>>>>>>>>>>>> Something I did that was easy and helped cut down radio noise a lot: I disconnected the radio hot lead from the avionics bus and ran the power wire and ground wire straight to the battery with a small inline fuse. The radio power is now separate from the rest of the airplane. Big improvement. The next biggest help - although a lot more trouble, and you need to do it when you build the airplane - use shielded wire for your mag switches. Those nasty little wires come right off your magneto and carry rapidly pulsing AC. Your spark plug wires are doing the same thing, at a higher voltage, but they are short, your kill switch wires are many feet long. Worth what ya paid fer it - ________________________________________________________________________________
Date: Nov 20, 2011
No, sorry, I design in my mind, just built a slope soarer in a day. An RC Kolb sounds good. Sy ------Original Message------ From: Michael Welch Sender: owner-kolb-list-server(at)matronics.com ReplyTo: kolb-list(at)matronics.com Subject: Re: Kolb-List: Model Kolbs Sent: Nov 20, 2011 00:23 On Nov 19, 2011, at 3:21 PM, simonnelson(at)vodamail.co.za wrote: > > Sounds good, 1.7 meter span. 4 cell poly pack, out runner with a 13 x 8 prop, 6 servos, all built up balsa. Covered in Solatex. > > Lot of fun to fly > > Send pictures when you are done. > > > Sy Sy, Do you have any pictures of this plane you refer to? Mike Sent via my BlackBerry from Vodacom - let your email find you! ________________________________________________________________________________
Date: Nov 20, 2011
re radio noise. Thanks Gary. Took the plane out of the air for the winter yesterday. Battery out, everything drained, wheels off the ground, plugs out and cylinders sprayed with oil so I won`t be able to do anything serious until the Spring. The day of course turned out to be one of the best we have had for weeks. Sunny, windless with high thin cloud. Dammit! To make me feel better today is misty, damp and cooler and the forecast is for dropping temps next week.This weekend last year the snow started and went on until February. This autumn is the most extended I can remember. Leaves are still on the trees and have not really changed colour. It has been sunny and warm. I have been wandering around without a coat. Birds are beginning to nest because they are responding to the Springlike weather. Very confusing. Cheers Pat ________________________________________________________________________________
Date: Nov 20, 2011
Here is a nice RC replica of a Kolb Mark III www.scttf.org/Club/members/KeathToney.htm Scroll to the bottom of the page. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358580#358580 ________________________________________________________________________________
Date: Nov 20, 2011
Yesterday was not a very pleasant day to fly.On a 180 heading at 2500 ft gr ound speed was below 40 and the return trip was bumpy enough to require ful l control inputs to keep the MK3 close to flat.Luckily I had a 230# passeng er and ground speeds in the 80,s while keeping the airspeed in the 50,s bec ause of the turbulence.In retrospect,should have followed Pat's lead and pa rked it. My passenger,Gary Jindra,had the final inspection of his MK3 on Friday mo rning and it,s first flight shortly after.A little more pitch in the prop a nd some left rudder trim and it should be ready for duty.A very nicely done 3 yr project,including a 582 with a heater core with a small fan nestled i n the nose cone.We'll see how that works out shortly.Temps were in the low 30's on Wednesday and back into the 60's by Saturday but with high winds ou t of the SW both days.Time to go south. G.Aman MK3C Jabiru 2200A 655hrs -----Original Message----- From: Pat Ladd <pj.ladd(at)btinternet.com> Sent: Sun, Nov 20, 2011 6:01 am Subject: Re: Kolb-List: radio noise re radio noise. Thanks Gary. Took the plane out of the air for the winter yesterday. Battery out, everyt hing drained, wheels off the ground, plugs out and cylinders sprayed with o il so I won`t be able to do anything serious until the Spring. The day of course turned out to be one of the best we have had for weeks. S unny, windless with high thin cloud. Dammit! To make me feel better today is misty, damp and cooler and the forecast is for dropping temps next week.This weekend last year the snow started and we nt on until February. This autumn is the most extended I can remember. Leav es are still on the trees and have not really changed colour. It has been s unny and warm. I have been wandering around without a coat. Birds are begin ning to nest because they are responding to the Springlike weather. Very co nfusing. Cheers Pat ________________________________________________________________________________
Subject: Re: Original Firestar II for sale.........thumbs
Date: Nov 20, 2011
SOLD -------- Gary Souderton, Pa. Firestar II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358606#358606 ________________________________________________________________________________
Date: Nov 21, 2011
Subject: Mz 201
Kolbers , Has anyone used an MZ 201 on a Kolb I was thinking about it for a Firefly as it would be lighter and I need to put hand controls on for my r udder as i cant use my feet , t,hey claim 69 lbs including electric start , reduction, muffler ,a complete-40 hp engine rig that only turns 4700 rpm ? that makes me wonder if I could get enough prop on it to make that thing fly like a Kolb should?=0AChris Davis=0AKXP 503 492 hrs=0AGlider Pilot=0ADi sabled from crash building Firefly ________________________________________________________________________________
Date: Nov 21, 2011
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: Mz 201
- Chris- The original Firestar got away with a Rotax 377, so why not?- And Jack Hart is using one smaller than that- the MZ 34, rated for 30hp. ------------------------- ------------------------- ------ Bill=0A Sullivan ------------------------- ------------------------- ------ Windsor Locks, Ct. ------------------------- ------------------------- ------ FS 447 --- On Mon, 11/21/11, chris davis wrote: From: chris davis <capedavis(at)yahoo.com> Subject:=0A Kolb-List: Mz 201 Date: Monday, November 21, 2011, 11:57 AM Kolbers , Has anyone used an MZ 201 on a Kolb I was thinking about it for a Firefly as it would be lighter and I need to put hand controls on for my r udder as i cant use my feet , t,hey claim 69 lbs including electric start , reduction, muffler ,a complete-40 hp engine rig that only turns 4700 rpm ? that makes me wonder if I could get enough prop on it to make that thing fly like a Kolb should?=0AChris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly=0A=0A=0A=0A ________________________________________________________________________________
Date: Nov 21, 2011
Subject: Make Sure You're Listed -- List of Contributors Published Dec
1! Dear Listers, The List of Contributors (LOC) is just around the corner! On December 1st I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. As a number of people have pointed out in their Contribution comments, the Lists are a whole lot more valuable than your typical magazine subscription! Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 21, 2011
Subject: Re: Mz 201
I've recently ordered my Firefly from Travis and the mz201 engine and get t hem both in a few weeks. I'm planning on swinging somewhere around a 60-62" Tennessee wooden prop - I don't quite know the pitch yet - call Steve at T N props - (931) 455-4516 for Qs. The belt reduc is 1.77:1. The prop therefore swings around 2,650 rpm at the mz201's 4,700 max rpm. I opted for a single ignition magneto version of th e mz201 (lighter!). A battery will still be needed if I want to take advant age of the elec start. - Phil H. --- On Mon, 11/21/11, william sullivan wrote: From: william sullivan <williamtsullivan(at)att.net> Subject: Re: Kolb-List: Mz 201 Date: Monday, November 21, 2011, 12:08 PM - Chris- The original Firestar got away with a Rotax 377, so why not?- And Jack Hart is using one smaller than that- the MZ 34, rated for 30hp. ------------------------- ------------------------- ------ Bill Sullivan ------------------------- ------------------------- ------ Windsor Locks, Ct. ------------------------- ------------------------- ------ FS 447 --- On Mon, 11/21/11, chris davis wrote: From: chris davis <capedavis(at)yahoo.com> Subject: Kolb-List: Mz 201 Date: Monday, November 21, 2011, 11:57 AM Kolbers , Has anyone used an MZ 201 on a Kolb I was thinking about it for a Firefly as it would be lighter and I need to put hand controls on for my r udder as i cant use my feet , t,hey claim 69 lbs including electric start , reduction, muffler ,a complete-40 hp engine rig that only turns 4700 rpm ? that makes me wonder if I could get enough prop on it to make that thing fly like a Kolb should? Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly ________________________________________________________________________________
Date: Nov 21, 2011
Subject: Re: Mz 201
Bill I understand all the numbers but real experiance is all I was looking for ? thanks for the comeback . Chris- =0APS I was just dreaming about fl ying a rocket like i remember my KXP=0A=0AChris Davis=0AKXP 503 492 hrs=0AG lider Pilot=0ADisabled from crash building Firefly=0A=0A=0A________________ ________________=0AFrom: william sullivan <williamtsullivan(at)att.net>=0ATo: kolb-list(at)matronics.com =0ASent: Monday, November 21, 2011 12:08 PM=0ASubje ct: Re: Kolb-List: Mz 201=0A=0A- Chris- The original Firestar got away wi th a Rotax 377, so why not?- And Jack Hart is using one smaller than that - the MZ 34, rated for 30hp.=0A=0A------------- ------------------------- ------------------ Bill Sullivan=0A- ------------------------- ------------------------- ----- Windsor Locks, Ct.=0A------------ ------------------------- ------------------- FS 447=0A=0A--- O n Mon, 11/21/11, chris davis <capedavis(at)yahoo.com> wrote:=0A=0A=0A>From: ch ris davis =0A>Subject: Kolb-List: Mz 201=0A>To: "kolb- list(at)matronics.com" =0A>Date: Monday, November 21, 2011, 11:57 AM=0A>=0A>=0A>Kolbers , Has anyone used an MZ 201 on a Kolb I was thinking about it for a Firefly as it would be lighter and I need to pu t hand controls on for my rudder as i cant use my feet , t,hey claim 69 lbs including electric start ,reduction, muffler ,a complete-40 hp engine ri g that only turns 4700 rpm ? that makes me wonder if I could get enough pro p on it to make that thing fly like a Kolb should?=0A>Chris DavisKXP 503 49 ad, 7-Day ======= ________________________________________________________________________________
Date: Nov 21, 2011
Subject: Re: Mz 201
Phil That sounds great I must admit that it was-your discussion with Tom Stephens that got me interested- , that and the fact that to stay legal w eight wise I will have a problem with the 447 that it was designed with .Yo ur plan sounds real good I hope it works out great .My firefly is on the ge ar but naked and a long way from flying , it is in Florida and I am in Ma. Only get to work on it when I go south in the winter which I dont know if i can afford this year . I am trying to sell the place I have down there and rebuild my shop here in Ma. we will see . thanks for the come back- mayb e someone who has one flying will answer my post and we will all be able to learn-------Chris=0A=0A=0AChris Davis=0AKXP 503 492 hrs=0AGl ider Pilot=0ADisabled from crash building Firefly=0A=0A=0A_________________ _______________=0AFrom: Phil <phactor9(at)yahoo.com>=0ATo: kolb-list@matronics .com =0ASent: Monday, November 21, 2011 12:48 PM=0ASubject: Re: Kolb-List: Mz 201=0A=0AI've recently ordered my Firefly from Travis and the mz201 engi ne and get them both in a few weeks. I'm planning on swinging somewhere aro und a 60-62" Tennessee wooden prop - I don't quite know the pitch yet - cal l Steve at TN props - (931) 455-4516 for Qs.=0AThe belt reduc is 1.77:1. Th e prop therefore swings around 2,650 rpm at the mz201's 4,700 max rpm. I op ted for a single ignition magneto version of the mz201 (lighter!). A batter y will still be needed if I want to take advantage of the elec start.=0A=0A Phil H.--- On Mon, 11/21/11, william sullivan wr ote:=0A=0A>From: william sullivan <williamtsullivan(at)att.net>=0A>Subject: Re : Kolb-List: Mz 201=0A>To: kolb-list(at)matronics.com=0A>Date: Monday, Novembe r 21, 2011, 12:08 PM=0A>=0A>=0A>- Chris- The original Firestar got away w ith a Rotax 377, so why not?- And Jack Hart is using one smaller than tha t- the MZ 34, rated for 30hp.=0A>=0A>------------ ------------------------- ------------------- Bill Sullivan=0A> ------------------------- ------------------------- ------ Windsor Locks, Ct.=0A>----------- ------------------------- -------------------- FS 447=0A>=0A> --- On Mon, 11/21/11, chris davis wrote:=0A>=0A>=0A>> From: chris davis <capedavis(at)yahoo.com>=0A>>Subject: Kolb-List: Mz 201=0A>> ovember 21, 2011, 11:57 AM=0A>>=0A>>=0A>>Kolbers , Has anyone used an MZ 20 1 on a Kolb I was thinking about it for a Firefly as it would be lighter an d I need to put hand controls on for my rudder as i cant use my feet , t,he y claim 69 lbs including electric start ,reduction, muffler ,a complete-4 0 hp engine rig that only turns 4700 rpm ? that makes me wonder if I could get enough prop on it to make that thing fly like a Kolb should?=0A>>Chris DavisKXP 503 492 hrsGlider PilotDisabled from crash building Firefly =0A>o llow target=_blank>www.aeroelectric.com/" rel=nofollow target=_bla nk>www.buildersbooks.comofollow target=_blank>www.homebuilthelp.com llow target=_blank>http://www.matronics.com/contribution=nofollow ta rget=_blank>http://www.matronics.com/Navigator?Kolb-Listet=_blank>ht tp://forums.matronics.comllow target=_blank>http://www.matronics.com/c ======= ________________________________________________________________________________
Subject: Mz 201
Date: Nov 21, 2011
Bill I understand all the numbers but real experiance is all I was looking for ? thanks for the comeback . Chris PS I was just dreaming about flying a rocket like i remember my KXP Chris D/Folks: If I was going to build and fly a Firefly, I'd put a 503 single carb on it. The 503 is probably the most reliable Rotax two stroke. I have flown the FF quite a bit with the 447. It performs about like my original Firestar with a 447. I wouldn't want anything less than a 447 on a FS. Most of us fly for the fun of flying, performance and that mighty Kolb climb. If you under power your airplane, it ain't going to fly for a Kolb. Some folks fly to say on gas with the very minimum HP they can get by with to get the Kolb off the ground. If you go light on power, you'll be flying behind the power curve more than yanking and banking and having a good time. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 21, 2011
Subject: Re: Mz 201
Chris, I've yet to hear of anyone with the mz201 on ANY Kolb yet speak up, although I'm aware of mz201/202s on trikes, gyros, etc. Steve at TN Props says they can adjust the pitch if needed. He said they ca n do this once to the wooden props, and that he does it often. I'm favoring the TN prop because of the savings in cost (1/2!) and weight. Phil --- On Mon, 11/21/11, chris davis wrote: From: chris davis <capedavis(at)yahoo.com> Subject: Re: Kolb-List: Mz 201 Date: Monday, November 21, 2011, 2:24 PM Phil That sounds great I must admit that it was-your discussion with Tom Stephens that got me interested- , that and the fact that to stay legal w eight wise I will have a problem with the 447 that it was designed with .Yo ur plan sounds real good I hope it works out great .My firefly is on the ge ar but naked and a long way from flying , it is in Florida and I am in Ma. Only get to work on it when I go south in the winter which I dont know if i can afford this year . I am trying to sell the place I have down there and rebuild my shop here in Ma. we will see . thanks for the come back- mayb e someone who has one flying will answer my post and we will all be able to learn-------Chris - Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly From: Phil <phactor9(at)yahoo.com> Sent: Monday, November 21, 2011 12:48 PM Subject: Re: Kolb-List: Mz 201 I've recently ordered my Firefly from Travis and the mz201 engine and get t hem both in a few weeks. I'm planning on swinging somewhere around a 60-62" Tennessee wooden prop - I don't quite know the pitch yet - call Steve at T N props - (931) 455-4516 for Qs. The belt reduc is 1.77:1. The prop therefore swings around 2,650 rpm at the mz201's 4,700 max rpm. I opted for a single ignition magneto version of th e mz201 (lighter!). A battery will still be needed if I want to take advant age of the elec start. - Phil H. --- On Mon, 11/21/11, william sullivan w rote: From: william sullivan <williamtsullivan(at)att.net> Subject: Re: Kolb-List: Mz 201 Date: Monday, November 21, 2011, 12:08 PM - Chris- The original Firestar got away with a Rotax 377, so why not?- And Jack Hart is using one smaller than that- the MZ 34, rated for 30hp. ------------------------- ------------------------- ------ Bill Sullivan ------------------------- ------------------------- ------ Windsor Locks, Ct. ------------------------- ------------------------- ------ FS 447 --- On Mon, 11/21/11, chris davis wrote: From: chris davis <capedavis(at)yahoo.com> Subject: Kolb-List: Mz 201 Date: Monday, November 21, 2011, 11:57 AM Kolbers , Has anyone used an MZ 201 on a Kolb I was thinking about it for a Firefly as it would be lighter and I need to put hand controls on for my r udder as i cant use my feet , t,hey claim 69 lbs including electric start , reduction, muffler ,a complete-40 hp engine rig that only turns 4700 rpm ? that makes me wonder if I could get enough prop on it to make that thing fly like a Kolb should? Chris DavisKXP 503 492 hrs Glider Pilot Disabled from crash building Firefl y ollow target=_blank>www.aeroelectric.com /" rel=nofollow target=_blank>www.buildersbooks.com ofollow target=_blank>www.homebuilthelp.com llow target=_blank>http://www.matronics.com/contribution =nofollow target=_blank>http://www.matronics.com/Navigator?Kolb-List et=_blank>http://forums.matronics.com llow target=_blank>http://www.matronics.com/contribution ="http://www.aeroelectric.com/" rel=nofollow target=_blank>www.aeroel ectric.com /" rel=nofollow target=_blank>www.buildersbooks.com f="http://www.homebuilthelp.com/" rel=nofollow target=_blank>www.home builthelp.com k>Dralle, List Admin. ark>Un/Subscription, more: k>Dralle, List Admin. llow target=_blank>http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Mz 201
Date: Nov 21, 2011
I must say listening to John's alaska story about ten years ago is part of what excited me about kolbs. My personal view though is that a 503 is more than neccessary on a true firefly. I had a firestar kxp 10 years ago, empty weight about 310 w ith brs. With the 377, 35 horse, i still climbed at 700-800 and cruised at 70-75. Just didnt see the need for a 503, 447 might have been cool for it. Renee Bas spellong blaned on ophone :) On Nov 21, 2011, at 11:37 AM, "John Hauck" wrote: > > > > Bill I understand all the numbers but real experiance is all I was looking for ? thanks for the comeback . Chris > > PS I was just dreaming about flying a rocket like i remember my KXP > > > > Chris D/Folks: > > If I was going to build and fly a Firefly, I'd put a 503 single carb on it . The 503 is probably the most reliable Rotax two stroke. > > I have flown the FF quite a bit with the 447. It performs about like my o riginal Firestar with a 447. I wouldn't want anything less than a 447 on a FS. > > Most of us fly for the fun of flying, performance and that mighty Kolb cli mb. If you under power your airplane, it ain't going to fly for a Kolb. > > Some folks fly to say on gas with the very minimum HP they can get by with to get the Kolb off the ground. If you go light on power, you'll be flying behind the power curve more than yanking and banking and having a good time . > > john h > mkIII > Titus, Alabama > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Nov 21, 2011
Subject: Re: Mz 201
John , because of the dual ignition and the fact that I never had any troub le with mine the 503 was my choice but "KOLB" told me the airframe would no t take the vibration of the 503 with out reinforcements- it would shake t hat ultralight chromemoly apart so I settled on the 447 , then came the wei ght factor of my "adaptive equipment "and the MZ201 seamed like it might be the answer 45 HP and 20 lbs less weight. Im considering all possibilities. -- Chris=0A=0A=0AChris Davis=0AKXP 503 492 hrs=0AGlider Pilot=0ADisable d from crash building Firefly=0A=0A=0A________________________________=0AFr om: John Hauck =0ATo: kolb-list(at)matronics.com =0ASent : Monday, November 21, 2011 2:37 PM=0ASubject: RE: Kolb-List: Mz 201=0A=0A =0A-=0ABill I understand all the numbers but real experiance is all I was looking for ? thanks for the comeback . Chris- =0APS I was just dreaming about flying a rocket like i remember my KXP=0A-=0AChris D/Folks:=0A- =0AIf I was going to build and fly a Firefly, I'd put a 503 single carb on it.- The 503 is probably the most reliable Rotax two stroke.=0A-=0AI ha ve flown the FF quite a bit with the 447.- It performs about like my orig inal Firestar with a 447.- I wouldn't want anything less than a 447 on a FS.=0A-=0AMost of us fly for the fun of flying, performance and that migh ty Kolb climb.- If you under power your airplane, it ain't going to fly f or a Kolb.=0A-=0ASome folks fly to say on gas with the very minimum HP th ey can get by with to get the Kolb off the ground. -If you go light on po wer, you'll be flying behind the power curve more than yanking and banking chive Search & Download, 7-Day ======= ________________________________________________________________________________
Date: Nov 21, 2011
Subject: Re: Mz 201
Agree - my Twinstar had a 503 single carb with a TN wood prop and it climbe d around 1,500fpm and flew like a scared bat. With two 235 lb.-people, it still climbed around 800fpm (guessing on that one). - Phil H. --- On Mon, 11/21/11, Renee wrote: From: Renee <ulflygirl(at)mysky.us> Subject: Re: Kolb-List: Mz 201 Date: Monday, November 21, 2011, 8:07 PM I must say listening to John's alaska story about ten years ago is- part of what excited me about kolbs. -My personal view though is that a 503 is more than neccessary on -a true firefly. I had a firestar kxp 10 years ago, empty weight about 31 0 with brs.- With the 377, 35 horse, i still climbed at 700-800 and cruised at 70-75.- Just didnt see the need for a 503, 447 might have been cool for it.- Renee Bas spellong blaned on ophone :) On Nov 21, 2011, at 11:37 AM, "John Hauck" wrote: - Bill I understand all the numbers but real experiance is all I was looking for ? thanks for the comeback . Chris- PS I was just dreaming about flying a rocket like i remember my KXP -Chr is D/Folks: -If I was going to build and fly a Firefly, I'd put a 503 sin gle carb on it.- The 503 is probably the most reliable Rotax two stroke. -I have flown the FF quite a bit with the 447.- It performs about like my original Firestar with a 447.- I wouldn't want anything less than a 44 7 on a FS. -Most of us fly for the fun of flying, performance and that mi ghty Kolb climb.- If you under power your airplane, it ain't going to fly for a Kolb. -Some folks fly to say on gas with the very minimum HP they can get by with to get the Kolb off the ground. -If you go light on power , you'll be flying behind the power curve more than yanking and banking and having a good time. -john hmkIIITitus, Alabama - ========= http://www.aeroelectric.com">www.aeroelectric.com >www.buildersbooks.com "http://www.homebuilthelp.com">www.homebuilthelp.com http://www.matronics.com/contribution">http://www.matronics.com/contributio n ========= ref="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.c om/Navigator?Kolb-List ========= ums.matronics.com">http://forums.matronics.com ========= http://www.matronics.com/contribution">http://www.matronics.com/contributio n ========= ________________________________________________________________________________
Subject: Re: Mz 201
Date: Nov 22, 2011
John, Although the size of the font is OK your posts are double spaced and still too wide for the screen. Everyone else's posts are OK. Pat ________________________________________________________________________________
Subject: Mz 201
Date: Nov 22, 2011
John, Although the size of the font is OK your posts are double spaced and still too wide for the screen. Everyone else's posts are OK. Pat Patrick/Kolbers: Glad I got one thing right, the font. I am using "plain text", automatic word wrap with 60 space lines. My email is Outlook 2007, with current updates. Other than that, I have checked all my "stuff" and
November 03, 2011 - November 22, 2011
Kolb-Archive.digest.vol-ly
