Kolb-Archive.digest.vol-mk
October 20, 2012 - January 05, 2013
      David,
      A cord spiral wound around a round strut will reduce the drag and lessen the
      tendency to produce von Karmann vortices that cause the strut to strum.
      What you are doing is tripping the boundary layer, which moves the flow
      separation further back behind the strut and this reduces the drag.
      Spiral cord wrapping with a high pitch angle is much like the smoke stack which
      has to withstand wind loads from all directions.  But with
      a wing strut one has to worry about only one direction, and so the tripping
      can be accomplished by placing or gluing a wire to the top and bottom sides
      of the strut.  If you would like to see some better explanation of this
      check out page 20 on of:
      http://www.bakker.org/dartmouth06/engs150/11-bl.pdf
      The struts on my FireFly strummed, and I streamlined my struts and the noise
      disappeared.  How it was done can be seen at:
      http://jackbhart.com/firefly/firefly91.html
      Jack B. Hart FF004
      Winchester, IN
Subject: Test
Date: Oct 20, 2012
This site has not refreshed in about 10 days for me. Is it my computer?? Rex Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385699#385699 ________________________________________________________________________________
Date: Oct 23, 2012
Subject: exploring options in NE VA
Are there any Kolb drivers that live and/or fly out of the Winchester, Virginia area? I'm wondering what hangar rents are like, and if there are smaller (smaller than KOKV), turf, UL/LSA friendly airfields in the area (or closer to DC, but still outside the ring) with space. Thanks. -- Robert ________________________________________________________________________________
Subject: 'Tis the Season' Reminder
Date: Oct 24, 2012
The temperature-dew point spread tells a pilot how close the air is to being 100% saturated, Fortunately old wise men 503 Rotax pilots rarely fly in such conditions. There seems to be a general consensus that two strokes gas /oil mixtures are invincible to icing, if you have the BING 54 carbs on your two stroke 503 as most Kolb Firestar pilots have they are not as prone to carb icing, because it works with a piston and not a valve as most other carbs do so most ice that will be formed will by design be sucked into the engine, and heated up to melt down preventing the carb piston itself from freezing in a fixed position. The highest probability for carb icing is during a long decent. It's good General Aviation airmanship to add carb heat and clear the throttle at intervals during a glide approach, keep the power up, and remain with gliding distance of good fields until you get home and don't reduce power until you are sure you can make the field. Fly Safe, stay revved up ! -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385941#385941 ________________________________________________________________________________
Date: Oct 24, 2012
Subject: Re: 'Tis the Season' Reminder
I wonder what risks a diaphragm carb suffers with carb ice? ( I.e. a Tillot son ) At least there's no slide to stick. Perhaps just reduced air intake, resulting in higher oil-to-fuel ratio? Assuming the whole throat doesn't fill up with ice, does that mean fouled p lugs are the biggest problem? Phil H FF11-4-76 --- On Wed, 10/24/12, Dennis Thate wrote: From: Dennis Thate <retroman(at)frontier.com> Subject: Kolb-List: 'Tis the Season' Reminder Date: Wednesday, October 24, 2012, 6:37 PM The temperature-dew point spread tells a pilot how close the air is to bein g 100% saturated, Fortunately old wise men 503 Rotax- pilots rarely fly i n such conditions. There seems to be a general consensus that two strokes gas /oil mixtures ar e invincible to icing, if you have the BING 54 carbs on your two stroke 503 as most Kolb Firestar pilots have they are not as prone to carb icing, bec ause it works with a piston and not a valve as most other carbs do so most ice that will be formed will by design be sucked into the engine, and heate d up to melt down preventing the carb piston itself from freezing in a fixe d position. The highest probability for carb icing is during a long decent. It's good G eneral Aviation airmanship to add carb heat and clear the throttle at inter vals during a glide approach, keep the power up, and remain with gliding di stance of good fields until you get home and don't reduce power until you a re sure you can make the field. Fly Safe, stay revved up- ! -------- Both optimists and pessimists contribute to our society.- The optimist in vents the airplane and the pessimist the parachute.- ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385941#385941 le, List Admin. ________________________________________________________________________________
Date: Oct 24, 2012
At 07:28 PM 10/24/2012, Phil wrote: >I wonder what risks a diaphragm carb suffers with carb ice? ( I.e. a >Tillotson ) At least there's no slide to stick. Perhaps just reduced air >intake, resulting in higher oil-to-fuel ratio? In a traditional carb, ice tends to build up on the butterfly, so I assume it would be the same with a Tillotson or Walbro. The oil in the mix and slight puffback of a 2-stroke I think is the main thing that helps us, not the fact that the Bings are slide carbs. -Dana -- The most exciting phrase to hear in science, the one that heralds new discoveries, is not Eureka! (I found it!) but rather, 'hmm.... that's funny...' --Isaac Asimov ________________________________________________________________________________
Date: Oct 24, 2012
At 06:37 PM 10/24/2012, Dennis Thate wrote: > >There seems to be a general consensus that two strokes gas /oil mixtures >are invincible to icing, if you have the BING 54 carbs on your two stroke >503 as most Kolb Firestar pilots have they are not as prone to carb icing... ... but it still can happen. I have had two engine failures that I can only attribute to icing... no other apparent cause, very close temperature and dewpoint. In my case it's a Mikuni, but that's very similar to a Bing. I was lucky, in both cases I was able to restart, but I was sure picking landing fields! -Dana -- The most exciting phrase to hear in science, the one that heralds new discoveries, is not Eureka! (I found it!) but rather, 'hmm.... that's funny...' --Isaac Asimov ________________________________________________________________________________
Date: Oct 24, 2012
One of the rules that I have adopted from my Light Sport instructor was to not fly if the dew point is within 6 degrees of temps. Easy to do, worth doing. Larry On Wed, Oct 24, 2012 at 5:31 PM, Dana Hague wrote: > At 06:37 PM 10/24/2012, Dennis Thate wrote: > > > There seems to be a general consensus that two strokes gas /oil mixtures > are invincible to icing, if you have the BING 54 carbs on your two stroke > 503 as most Kolb Firestar pilots have they are not as prone to carb icing... > > > ... but it still can happen. I have had two engine failures that I can > only attribute to icing... no other apparent cause, very close temperature > and dewpoint. In my case it's a Mikuni, but that's very similar to a > Bing. I was lucky, in both cases I was able to restart, but I was sure > picking landing fields! > > -Dana > > > -- > The most exciting phrase to hear in science, the one that > heralds new discoveries, is not Eureka! (I found it!) but rather, > 'hmm.... that's funny...' > --Isaac Asimov > > * > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Oct 25, 2012
Years ago my brother in law was flying his Quicksolver MX, had a Cuyuna with a Mikuni on it, and it was a fall day, humid and damp. It was acting up, so we pulled off the aircleaner, tied it down, and let it run for awhile. After a while, we got to watch a little "half-volcano" of ice crystals build up around the front side of the slide needle as the fuel was coming up around the needle. It never got big enough to close the throat, but it did get big enough to alter the proper airflow function of the carb. If I remember right, it was about 3/8" high, and 1/4" wide at the base. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385976#385976 ________________________________________________________________________________
Date: Oct 25, 2012
It seems that carbs that have cross structure down stream of the fuel disch arge point ice more readily.The Bing 64 on the Jabiru is the worst I've exp erienced.Have any of the 912 engines had this issue? G.Aman MK3 C Jabiru 2200A 765 hrs electric carb heat -----Original Message----- From: Dennis Thate <retroman(at)frontier.com> Sent: Wed, Oct 24, 2012 9:54 pm Subject: Kolb-List: 'Tis the Season' Reminder The temperature-dew point spread tells a pilot how close the air is to bein g 100% saturated, Fortunately old wise men 503 Rotax pilots rarely fly in su ch conditions. There seems to be a general consensus that two strokes gas /oil mixtures ar e invincible to icing, if you have the BING 54 carbs on your two stroke 503 a s most Kolb Firestar pilots have they are not as prone to carb icing, because it works with a piston and not a valve as most other carbs do so most ice that will be formed will by design be sucked into the engine, and heated up to melt d own preventing the carb piston itself from freezing in a fixed position. The highest probability for carb icing is during a long decent. It's good General Aviation airmanship to add carb heat and clear the throttle at inte rvals during a glide approach, keep the power up, and remain with gliding distanc e of good fields until you get home and don't reduce power until you are sure yo u can make the field. Fly Safe, stay revved up ! -------- Both optimists and pessimists contribute to our society. The optimist inve nts the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385941#385941 ________________________________________________________________________________
Date: Oct 26, 2012
Gary, Unless your Jab2200 is a very very early one, the Bing carb on it is a 94 (40mm). They used a 64 model (36mm) for only a short while and it didn't take them very long to determine it was not big enough. However, they are of similar design and function much the same way, I've not had any carb icing in my Slingshot with Jab2200 but in the 11 years I've been flying Rotax 912 engines, I've had two carb ice incidents. Detecting it early both times, I was able to get rid of it by cycling the throttle idle to WOT, back and forth a couple times. In both cases it was in warm weather with high humidity. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386030#386030 Attachments: http://forums.matronics.com//files/carb_icing_chart_144.jpg ________________________________________________________________________________
Date: Oct 26, 2012
I had a similar episode last spring... about 60 65 deg f humidity was up ,high but not extremely high, I had been out about an hour and was coming back into the pattern when I pulled the throttle back, I heard some funny/different noises,,, cycled the throttle a couple of times, a bit more noise, and landed promptly. when I shut the engine down I hurried out and could see a very thin film of ice on the outside of the carb. I have a friend that moved here from florida,,, and he said on a humid day after a rain, carb ice was routine on his 912. he had to add a carb heater or limit his flying days. he was flying a plane in tractor configuration. boyd young mkiii 912 utah >>>>>>>>>>>>>>>>>>>> Gary, I've not had any carb icing in my Slingshot with Jab2200 but in the 11 years I've been flying Rotax 912 engines, I've had two carb ice incidents. Detecting it early both times, I was able to get rid of it by cycling the throttle idle to WOT, back and forth a couple times. In both cases it was in warm weather with high humidity. -------- Thom Riddle Buffalo, NY (9G0) ________________________________________________________________________________
Subject: Firestar II copit photos...
Date: Oct 26, 2012
Hello Kolbers, Winter is closing in, here in the far north, and it is time to get busy building again. I am trying to complete the kit that has the Kolbra "prototype fuselage." For my conversation with Jim Hauck, who built the prototype, what I have is basically a Firestar III. I have a pile of instruments, and gear that needs to find a home on the panel and in the front. If you have a Firestar and like the way you have set things up, please post a photo so that I can benefit from your knowledge. Thanks, for the help! Nick Cassara Palmer, Ak N607AK ________________________________________________________________________________
Date: Oct 26, 2012
Is there a carb heat mod for the 503? --Gerry On Fri, Oct 26, 2012 at 9:48 AM, b young wrote: > > I had a similar episode last spring... about 60 65 deg f humidity was > up ,high but not extremely high, I had been out about an hour and was > coming back into the pattern when I pulled the throttle back, I heard some > funny/different noises,,, cycled the throttle a couple of times, a bit > more noise, and landed promptly. when I shut the engine down I hurried > out and could see a very thin film of ice on the outside of the carb. > I have a friend that moved here from florida,,, and he said on a humid day > after a rain, carb ice was routine on his 912. he had to add a carb > heater or limit his flying days. he was flying a plane in tractor > configuration. > > boyd young > mkiii 912 utah ________________________________________________________________________________
Date: Oct 26, 2012
It must be a 94.Don't see any identification on the casting,just looked lik e a 64. G.Aman -----Original Message----- From: Thom Riddle <riddletr(at)gmail.com> Sent: Fri, Oct 26, 2012 8:19 am Subject: Kolb-List: Re: 'Tis the Season' Reminder Gary, Unless your Jab2200 is a very very early one, the Bing carb on it is a 94 (40mm). They used a 64 model (36mm) for only a short while and it didn't ta ke them very long to determine it was not big enough. However, they are of sim ilar design and function much the same way, I've not had any carb icing in my Slingshot with Jab2200 but in the 11 year s I've been flying Rotax 912 engines, I've had two carb ice incidents. Detect ing it early both times, I was able to get rid of it by cycling the throttle id le to WOT, back and forth a couple times. In both cases it was in warm weather wi th high humidity. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386030#386030 Attachments: http://forums.matronics.com//files/carb_icing_chart_144.jpg ________________________________________________________________________________
Date: Oct 26, 2012
The ice will build at cruise power settings,and the power loss is so gradua l that you may not catch it.But you WILL notice when the ice breaks loose a nd the engine gags on it for a couple of revolutions.It gets me at warm up speeds,1100rpm,and will almost die without heat.If you go to idle it will q uit.It must ice over those small ports just aft of the throttle plate as we ll.You've seen some pictures of the fog we get up here,great flying above t he broken stuff but icing down low. G.A. -----Original Message----- From: b young <byoungplumbing(at)gmail.com> Sent: Fri, Oct 26, 2012 10:48 am Subject: Re: Kolb-List: Re: 'Tis the Season' Reminder I had a similar episode last spring... about 60 65 deg f humidity was u p ,high but not extremely high, I had been out about an hour and was coming back into the pattern when I pulled the throttle back, I heard some funny/different noises,,, cycled the throttle a couple of times, a bit mor e noise, and landed promptly. when I shut the engine down I hurried out an d could see a very thin film of ice on the outside of the carb. I have a friend that moved here from florida,,, and he said on a humid day after a rain, carb ice was routine on his 912. he had to add a carb heater or limit his flying days. he was flying a plane in tractor configuration. boyd young mkiii 912 utah >>>>>>>>>>>>>>>>>>>> Gary, I've not had any carb icing in my Slingshot with Jab2200 but in the 11 year s I've been flying Rotax 912 engines, I've had two carb ice incidents. Detecting it early both times, I was able to get rid of it by cycling the throttle idle to WOT, back and forth a couple times. In both cases it was i n warm weather with high humidity. -------- Thom Riddle Buffalo, NY (9G0) ________________________________________________________________________________
Date: Oct 26, 2012
Subject: Re: : Kolb-List:CARB HEAT// Re: 'Tis the Season' Reminder
Yes, and simple.http://legacy.rotax-owner.com/si_tb_info/serviceinfo/4ul94. pdf --- On Fri, 10/26/12, Gerry Visel wrote: From: Gerry Visel <gcvisel(at)gmail.com> Subject: Re: Kolb-List: Re: 'Tis the Season' Reminder Date: Friday, October 26, 2012, 12:42 PM -- Is there a carb heat mod for the 503? --Gerry =0AOn Fri, Oct 26, 2012 at 9:48 AM, b young wrot e: =0A I had a similar episode -last spring... - about 60 65 deg f -humidity was up ,high but not extremely high, - - -I had been out about an ho ur and was coming back into the pattern when I pulled the throttle back, I heard some funny/different noises,,, -cycled the throttle a couple of tim es, a bit more noise, -and landed promptly. - when I shut the engine do wn I hurried out and could see a very thin film of ice on the outside of th e carb. =0AI have a friend that moved here from florida,,, and he said on a humid d ay after a rain, carb ice was routine on his 912. - he had to -add a ca rb heater or limit his flying days. he was flying a plane in tractor config uration. =0A boyd young ========================0A=0A ________________________________________________________________________________
Subject: Re: Firestar II copit photos...
Date: Oct 26, 2012
Hi Nick, I visited your area 4 years ago in an RV with my Dad towing my amphib. trike and we flew over the Knik glacier from a nearby ROUGH bush flying field. The one thing that sticks with you after flying in Alaska and seeing so many cool looking bush planes is all those BIG tires. I love to land out and I put BIG tires on my trike as soon as I returned to Texas. When I bought my Kold Firestar II a few months back, it had 18" tundra tires on it that were worn out and needed replacing. I bought the largest tires I could afford - 21" tires for $100 each plus $40 BIG tubes to go inside them. The next step up is real 26" Alaska Bushwheels for $1,000 each. I can land my Kolb on the roughest fields with these BIG marshmallow tires as long as my LOW wingtips on my "high" wing won't scrape the bushes (or grader terraces in some cases on gravel roads). My recommendation for any airplane flying at Kolb Firestar speeds is to get the BIGGEST tires you can afford. Here's a pic of the shadow of my Kolb flying over one of my crosswind practice areas. I love it because it highlights those BIG tires! Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386092#386092 Attachments: http://forums.matronics.com//files/kolb_big_tires_shadow_435.jpg ________________________________________________________________________________
Date: Oct 27, 2012
Here is my panel. I didn't have enough room to put the two fuel gages that I used before, so the alum side panel supplied a spot for them. The only guy with a Kolb in the Medford area is Roger Hankins, who has a KXP. I am not sure if he monitors the list, so if you don't hear from him before you get there, email me and I will give you his phone number. I am sorry that I live about 8 hours from there. Larry On Fri, Oct 26, 2012 at 10:46 AM, Nick Cassara wrote: > Hello Kolbers,**** > > ** ** > > Winter is closing in, here in the far north, and it is time to get busy > building again. I am trying to complete the kit that has the Kolbra > =93prototype fuselage.=94 For my conversation with Jim Hauck, who built t he > prototype, what I have is basically a Firestar III.**** > > ** ** > > I have a pile of instruments, and gear that needs to find a home on the > panel and in the front.**** > > ** ** > > If you have a Firestar and like the way you have set things up, please > post a photo so that I can benefit from your knowledge. **** > > ** ** > > Thanks, for the help!**** > > ** ** > > Nick Cassara**** > > Palmer, Ak**** > > ** ** > > N607AK**** > > ** ** > > ** ** > > * > =========== =========== =========== =========== > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Oct 27, 2012
Subject: oops!
Sorry about inflicting my reply to Nick on the group. Getting forgetful I guess. :-/ Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Oct 27, 2012
Nick, Attached is a shot of my Slingshot panel, same size as Firestar panel. All engine and flight parameters are monitored with the EIS, except for ASI. I don't trust electronics for my airspeed indication. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386120#386120 Attachments: http://forums.matronics.com//files/img_0533_smaller_193.jpeg ________________________________________________________________________________
Date: Oct 27, 2012
Date: Wed, 24 Oct 2012 16:28:26 -0700 (PDT) From: Phil <phactor9(at)yahoo.com> > I wonder what risks a diaphragm carb suffers with carb ice? ( I.e. a Tillotson ) At least there's no slide to stick. Perhaps just reduced air intake, resulting in higher oil-to-fuel ratio? > Assuming the whole throat doesn't fill up with ice, does that mean fouled plugs are the biggest problem? > Phil, >From the few flights I have with the MZ 34 with a Tillitson carburetor, I found that it will ice up. Always I make a high approach so that if the engine quits I can always make the field. This means that one must close the throttle and spill altitude and results in a cold engine when one reaches the point of round out and flare. After roll out the engine starts easily. Since I use mixed fuel, there is no reason to expect fouled plugs. To get around this icing up problem, I searched the web and found some small bolt heater that is used on KTM motorcycle engine carburetors. I drilled the Tillotson carburetor and mounted one. I have not had a chance, as yet, to check it out but you can see how it was done at the bottom of: http://jackbhart.com/firefly/firefly153.html Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Oct 27, 2012
When I was flying 172s, the SOP was to turn on carb heat when entering the pattern and pulling the throttle back as there was a greater tendency for carb icing. Sent from my iPad Brad On Oct 26, 2012, at 8:48, "b young" wrote: > > I had a similar episode last spring... about 60 65 deg f humidity was up ,high but not extremely high, I had been out about an hour and was coming back into the pattern when I pulled the throttle back, I heard some funny/different noises,,, cycled the throttle a couple of times, a bit more noise, and landed promptly. when I shut the engine down I hurried out and could see a very thin film of ice on the outside of the carb. > I have a friend that moved here from florida,,, and he said on a humid day after a rain, carb ice was routine on his 912. he had to add a carb heater or limit his flying days. he was flying a plane in tractor configuration. > > boyd young > mkiii 912 utah > > Gary, > I've not had any carb icing in my Slingshot with Jab2200 but in the 11 years I've been flying Rotax 912 engines, I've had two carb ice incidents. Detecting it early both times, I was able to get rid of it by cycling the throttle idle to WOT, back and forth a couple times. In both cases it was in warm weather with high humidity. > > -------- > Thom Riddle > Buffalo, NY (9G0) > > > > ________________________________________________________________________________
Subject: Newbie Questions?
Date: Oct 28, 2012
I'm looking at a Mark III Classic, with which to get my LSA ticket. I have 50 hours toward my private 30+ years ago, but now the kids are grown and gone and its time to fly again. I was looking seriously at a Quad City Challenger II, but am leaning more toward the side-by-side layout of the Mark III as a training aircraft. Can anyone compare the two as a trainer aircraft? The one I'm looking at has a Rotax 618 engine, which is no longer sold. Should I stay away? Any major issues? Thanks for any feedback! Gerry Visel ________________________________________________________________________________
Date: Oct 29, 2012
Subject:
Gday All, Here's a short video of unloading and rigging my Firefly and flying from Brian Ranch Field near El Mirage lake bed, CA. http://youtu.be/DltfEwTEIq0 This is a very active ultralight field, with about 60 aircraft hangared here. Mostly Quicksilvers, but Bob in a clipped-wing Firestar dropped in from his private strip nearby. I had a brilliant day climbing up to 10,000ft over the San Gabriel mountains to get a view of the Los Angeles basin, (and that's as close as I want to get)...... Could see all the way to Santa Catalina Island. Still climbing 200fpm. JG ________________________________________________________________________________
Subject: Re: Newbie Questions?
Date: Oct 29, 2012
Never flown a Challenger, but one of the guys in our club bought one several years ago. This guy flies everything for a living, and he described it as one of the worst flying airplanes he had ever flown. Back before I got my MKIII, the wife and I went to a Challenger dealer and tried one on. Unless you are slim and agile, you don't want to be in the back seat. Getting out is a media event. Funny Home Videos media... The MKIII is not inherently stable, and requires active pilotage in all three axis at all times. Learn to fly in it and you will be good at flying anything. It will spoil you for flying other taildraggers, because it is the easiest taildragger to fly imaginable. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386182#386182 ________________________________________________________________________________
Date: Oct 29, 2012
Hi Jerry, Hardly anyone on this list will mention the Challenger without spitting. I disagree. I flew the Challenger with a 503 engine very happily for several years.It wandered a bit until the forward extension of the tailfin was fitted. That improved it a lot.It did everything I wanted .A selfstarter would have been nice but I could stand at the side with my left hand on the throttle and pull the cord easily. I never chocked the wheels.The flaperons worked to some extent but were more use in trimming the plane than as flaps. That didn`t matter as she would side slip as though the wings had fallen off and recover immediately on kicking off the slip.The U/c survived unscathed through some really horrific landings/takeoffs from some appalling fields.. Unlike the Kolb which will put a bend in the u/c legs if you drop it in a bit heavily.The tricycle u/c made ground handling a doddle. Unfortunately advancing age made getting in and out of the Challenger a bit difficult and I wanted a 4 stroke engine.and a bit more comfort. I had admired the lines of the Kolb for years.and bought a Mark 3 Xtra with a Jabiru. The visibility is superb and the design well tried. The side by side cockpit with a lid on looks very desirable and comfortable. I trained on a taildragger so the change back from the Challenger was not a major consideration. Macho too.`Real pilots fly taildraggers` but I wish I hadn`t bothered. Trike u/c is superior in every way. No need for toe brakes.No problems taxiing in a crosswind etc. It is nice flying side by side and certainly better for receiving instruction but if you fly mainly solo the decreased frontal area of the Challenger makes for better efficiency.If you are big the cockpit is a bit cramped. The big cockpit of the Kolb leaves plenty of room for maps, food and general storage if you intend doing extended X country trips.The doors make for easy access. Unfortunately because of back problems I can no longer do the ground handling, refuelling, maintenance etc and do not fly at all but if I was forty again I would have a Challenger with a 4 stroke engine fitted. I loved the open cockpit. If I was seventy again I would probably have a Kolb Xtra but only if available with tricyle undercart. This will probably provoke howls of disagreement on the list and will provide material for a new thread for weeks to come. Sift through the comments and you will learn a lot. Maybe even enough to make an informed decision. Stick with the Kolb list whatever you do. They are a great bunch, helpful and knowledgeable. Good luck Pat ________________________________________________________________________________
Date: Oct 30, 2012
I think it is important to differentiate between the Long Wing Challenger and the Clipped Wing version. The Long Wing is much less responsive in roll than the clipped wing and with the enclosed canopy installed can be difficult to manage in windy situations, even with the horizontal stabilizer mods. For a given amount of power, the Challenger is faster than a MkIIIC (never flown an Xtra so I can't comment from personal experience). This is largely due to the engine being hidden somewhat behind the fuselage substantially reducing drag compared to Kolbs mostly above wing engine mounting. The Clipped wing Challenger is faster than the Long Wing and much more pleasant to fly. I've instructed in both a Challenger and MkIIIC and for instruction, I prefer the MkIII. For solo flight or with a passenger, I prefer the tandem seating configuration, except for long x-country flights. If you are interested in the tandem seating, I consider a Clipped Wing Challenger to be viable but Kolb's Firestar II, Slingshot, and Kolbra are better all around airplanes. Of these tandem seat Kolbs, the Kolbra is the only one with dual controls. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386267#386267 ________________________________________________________________________________
Date: Oct 30, 2012
Does anybody on the list here with a Mark III live around northern Illinois? It sure would be nice to see one up close before investing... Are there any support/dealers in the area? Thanks, Gerry Visel Winnebago, near Rockford, IL ________________________________________________________________________________
Date: Oct 30, 2012
As an alternative to the Challenger, you might also consider the Excalibur - reportedly the better flying plane. I looked at a kit under construction and liked it: adequate room in both seats, dual controls, amazing STOL performance, but the big wing is not that easy to take off, and there is virtually no baggage space. For me, the question is how to store the plane between flights. Here in the NW, we don't have to worry too much about frost and snow, but it does rain a lot. If you have a hangar, a plane like the Challenger or Excalibur (tube & fabric wing) makes sense. If you want to store in a partial hangar or a trailer, the Kolbs can't be beat, with their easy and fast wing folding. If you need to tie down in the elements, an all-metal wing is better. I am in that last group: I am working with Mark Beierle of Earthstar Aircraft to design me a tandem version of his eGull 2000 (electric propulsion), and I have flown his staggered-seat side-by-side Odyssey with him (HKS). All Mark's designs use a single-piece cantilevered (no struts) all-aluminum wing, similar to the Titan Tornado. If that does not work out, the Kolbra is my plan B. On Tue, Oct 30, 2012 at 4:30 AM, Thom Riddle wrote: > > I think it is important to differentiate between the Long Wing Challenger > and the Clipped Wing version. The Long Wing is much less responsive in roll > than the clipped wing and with the enclosed canopy installed can be > difficult to manage in windy situations, even with the horizontal > stabilizer mods. For a given amount of power, the Challenger is faster than > a MkIIIC (never flown an Xtra so I can't comment from personal experience). > This is largely due to the engine being hidden somewhat behind the fuselage > substantially reducing drag compared to Kolbs mostly above wing engine > mounting. The Clipped wing Challenger is faster than the Long Wing and much > more pleasant to fly. I've instructed in both a Challenger and MkIIIC and > for instruction, I prefer the MkIII. > > For solo flight or with a passenger, I prefer the tandem seating > configuration, except for long x-country flights. If you are interested in > the tandem seating, I consider a Clipped Wing Challenger to be viable but > Kolb's Firestar II, Slingshot, and Kolbra are better all around airplanes. > Of these tandem seat Kolbs, the Kolbra is the only one with dual controls. > > -------- > Thom Riddle > Buffalo, NY (9G0) > > Kolb Slingshot SS-021 > Jabiru 2200A #1574 > > Diamond Katana DA20-A1 > Rotax 912 F3 > > Don't worry about old age... it doesn't last very long. > - Anonymous > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=386267#386267 > > ________________________________________________________________________________
Subject: Fwd: Kolb Homecoming
Date: Oct 31, 2012
All, I'm trying to find a MK III Xtra to compare to the Classic. Is anyone who owns a MK III Xtra going to Kolb's homecoming on 16th and 17th of November? Apparently Kolb doesn't have a Xtra for Demo. It seems that every time they build one it gets sold. Is there any difference in cabin width or length between the Classic and the Xtra?According to the Kolb website the Xtra is a couple feet longer but that could be a longer tail boom. Has anyone flow both, the Xtra and Classic? Thanks in advance, Brad ________________________________________________________________________________
Date: Nov 01, 2012
Subject: PLEASE READ - Matronics Email List Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's through solely through the Contributions of List members that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. Your personal Contribution counts! Once again, this year I've got a terrific line up of free gifts to go along with the various Contribution levels. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on Matronics Lists and have been either donated or provided at substantially discounted rates. This year, these generous people include: Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and very useful aviation-related product line. I would like publicly to thank Bob, Andy, and Jon for their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you for your support! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 01, 2012
Subject: RE: Kolb-List Digest: 1 Msgs - 10/31/12
Hello Brad. I flew in Richard Pike's Classic with him. There was room for us both though a little tight in the shoulders and leg room. I am building an Xtra. There is a little more width in the cabin and definitely more length in the cabin for long legs. I am 250lbs and 6'3" tall. I like the Classics doors better but the Xtra's seem to work well. The newest version of the Xtra for a while had flaps and ailerons but I heard they were going back to the flaperons, which is what I have. I am using a Great Plains Aviation VW conversion 2180 cc with re-drive built by Steve Bennett and with a wood prop on mine. This will give me 100hp for take-off and 65-70hp for cruise. I plan to get up to the fly-in this month but the plane will not be flying by then. I am sure Richard and I will be glad to take some measurements for you if you like. Bob Green Building N830PB ________________________________ Message 1 _____________________________________ From: Brad Nation <nationcap(at)comcast.net> Subject: Kolb-List: Fwd: Kolb Homecoming All, I'm trying to find a MK III Xtra to compare to the Classic. Is anyone who owns a MK III Xtra going to Kolb's homecoming on 16th and 17th of November? Apparently Kolb doesn't have a Xtra for Demo. It seems that every time they build one it gets sold. Is there any difference in cabin width or length between the Classic and the Xtra?According to the Kolb website the Xtra is a couple feet longer but that could be a longer tail boom. Has anyone flow both, the Xtra and Classic? Thanks in advance, Brad ________________________________________________________________________________
Date: Nov 01, 2012
Subject: Kolb Homecoming
> > From: Brad Nation <nationcap(at)comcast.net> > Subject: Kolb-List: Fwd: Kolb Homecoming > > All, > I'm trying to find a MK III Xtra to compare to the Classic. Is anyone who > owns a MK III Xtra going to Kolb's homecoming on 16th and 17th of November? Where do I find info on this get-together? Where is it happening? Thanx, Gerry ________________________________________________________________________________
Date: Nov 01, 2012
Where do I find info on this get-together? Where is it happening? Thanx, Gerry Gerry/Gang: The 2012 Kolb Homecoming will be held: Friday through Sunday, 16-18 November, weather permitting. We'll keep a close eye on the weather. If it looks like "out of towners" will not be able to fly in and return home, a weather decision will be made as early as possible by Kolb Aircraft. This is a pay as you go flyin for food, unlike previous Kolb Homecomings where everything was provided free of charge. We felt the Kolb Family would be more than happy to pay our own way to enable Kolb Aircraft to host another Kolb Homecoming. Camping, of course, is free, as is attendance. Look forward to seeing all you Kolbers in a couple weeks. I plan on departing Gantt International Airport either Thu or Fri, depending on which day has the best wind and weather, and if I am ready to go by then. I haven't seen my airplane in more than 3 months. Hope it is still in the hanger. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: Fwd: Kolb Homecoming
Date: Nov 01, 2012
The Xtra is wider so you can put your legs straight out. In the classic you have to kick your legs inward slightly. I have a bad disc and that was uncomfortable for me. That's why I changed to the Xtra. The Xtra is also supposed to have a slightly higher cruse speed. Rex Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386509#386509 ________________________________________________________________________________
Subject: Re: RE: Kolb-List Digest: 1 Msgs - 10/31/12
Date: Nov 01, 2012
Bob, Thanks for the information, which leads to more questions. What is the difference between the Classic and Xtra doors. Why did you choose the VW engine and what other engines were you considering? Hope to see you at the homecoming. Brad On Nov 1, 2012, at 7:36 , Bob Green wrote: > > > > Hello Brad. I flew in Richard Pike's Classic with him. There was room for us both though a little tight in the shoulders and leg room. I am building an Xtra. There is a little more width in the cabin and definitely more length in the cabin for long legs. I am 250lbs and 6'3" tall. I like the Classics doors better but the Xtra's seem to work well. The newest version of the Xtra for a while had flaps and ailerons but I heard they were going back to the flaperons, which is what I have. > I am using a Great Plains Aviation VW conversion 2180 cc with re-drive built by Steve Bennett and with a wood prop on mine. This will give me 100hp for take-off and 65-70hp for cruise. > I plan to get up to the fly-in this month but the plane will not be flying by then. > I am sure Richard and I will be glad to take some measurements for you if you like. > Bob Green > Building N830PB > ________________________________ Message 1 _____________________________________ > > > From: Brad Nation <nationcap(at)comcast.net> > Subject: Kolb-List: Fwd: Kolb Homecoming > > > All, > I'm trying to find a MK III Xtra to compare to the Classic. Is anyone who owns a MK III Xtra going to Kolb's homecoming on 16th and 17th of November? Apparently Kolb doesn't have a Xtra for Demo. It seems that every time they build one it gets sold. > Is there any difference in cabin width or length between the Classic and the Xtra?According to the Kolb website the Xtra is a couple feet longer but that could be a longer tail boom. > Has anyone flow both, the Xtra and Classic? > > Thanks in advance, > Brad > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 01, 2012
Subject: Re: Kolb Homecoming
In a message dated 11/1/2012 9:55:28 A.M. Eastern Daylight Time, gcvisel(at)gmail.com writes: Where do I find info on this get-together? Where is it happening? Gerry, It will be held at the Kolb Aircraft Company, 8375 Russell Dyche Hwy., London, KY 40741-9264 Contact: Travis Brown 606-862-9622 Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive ________________________________________________________________________________
Date: Nov 02, 2012
Brad You can save over $10,000 by putting a VW on a Kolb over the cost of a Rotax 912. It is more work, there has to be some reduced reliability, it gets hot quickly on the ground, and it weighs more. My redrive VW has been extremely reliable, easy to work on and when it comes time to rebuild the engine it can be done for less than a gasket set of a Rotax. My redrive VW powered MKIIIC weighs 598lbs but worked at keeping it light. Rick Neilsen 1st Redrive VW powered Kolb MKIIIC On Thu, Nov 1, 2012 at 9:27 PM, Brad Nation wrote: > > Bob, > Thanks for the information, which leads to more questions. > What is the difference between the Classic and Xtra doors. > Why did you choose the VW engine and what other engines were you > considering? > Hope to see you at the homecoming. > > Brad > > On Nov 1, 2012, at 7:36 , Bob Green wrote: > > > > > > > > > Hello Brad. I flew in Richard Pike's Classic with him. There was room > for us both though a little tight in the shoulders and leg room. I am > building an Xtra. There is a little more width in the cabin and > definitely more length in the cabin for long legs. I am 250lbs and 6'3" > tall. I like the Classics doors better but the Xtra's seem to work well. > The newest version of the Xtra for a while had flaps and ailerons but I > heard they were going back to the flaperons, which is what I have. > > I am using a Great Plains Aviation VW conversion 2180 cc with re-drive > built by Steve Bennett and with a wood prop on mine. This will give me > 100hp for take-off and 65-70hp for cruise. > > I plan to get up to the fly-in this month but the plane will not be > flying by then. > > I am sure Richard and I will be glad to take some measurements for you > if you like. > > Bob Green > > Building N830PB > > ________________________________ Message 1 > _____________________________________ > > > > > > From: Brad Nation <nationcap(at)comcast.net> > > Subject: Kolb-List: Fwd: Kolb Homecoming > > > > > > All, > > I'm trying to find a MK III Xtra to compare to the Classic. Is anyone > who owns a MK III Xtra going to Kolb's homecoming on 16th and 17th of > November? Apparently Kolb doesn't have a Xtra for Demo. It seems that > every time they build one it gets sold. > > Is there any difference in cabin width or length between the Classic and > the Xtra?According to the Kolb website the Xtra is a couple feet longer but > that could be a longer tail boom. > > Has anyone flow both, the Xtra and Classic? > > > > Thanks in advance, > > Brad > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 03, 2012
Subject: FireFly Analysis
Gday All, I've just added an analysis of the flying and landing characteristics that I found with my FireFly. See http://jgwalkaboutusa.blogspot.com/ JG ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 1 Msgs - 10/31/12
Date: Nov 02, 2012
Went out tonight and did some measurements, my MKIII Classic is about 34" across the hips, and 42" across the shoulders. The foot pedal bar is movable with a little work, and when I took Bob for a ride, it was in the middle position, since I am shorter than he is, and I am not long-legged for my height. There is 4" total adjustment ability on the MKIII Classic rudder pedal mechanism. Currently I actually have the pedals back another 2", since I have been taking my 5' tall 10 year old niece flying, hoping for her to learn the basics of stick and ruddering in the MKIII. So far it is not going real well... but it is consistently entertaining. Or at least to me - For her to reach the pedals, we had to make a special booster foam seat back to get her close enough. The Classic and Xtra doors hinge different. The Classic doors hinge from the tube that goes along the edge of the windscreen via piano hinges, the Xtra doors hinge from welded pivots near the front of the doors. So the Classic door swings up and over, the Xtra door swings out. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386575#386575 ________________________________________________________________________________
Date: Nov 03, 2012
Subject: RE: Kolb-List Digest: 3 Msgs - 11/02/12
Thanks Richard and Rick. I sent the Xtra measurements to Brad. The Xtra is 43" at the hips and 55" from the gear leg to nose cone attach point. I appreciate the input and am sure Brad does too. I sure did enjoy the ride Richard. How the years get away from us. See you at Kolb? Have a great weekend. Bob MKIIIX with GPAS VW conversion with re-drive. ________________________________________________________________________________
Date: Nov 03, 2012
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Re: RE: Kolb-List Digest: 3 Msgs - 11/02/12
Date: Nov 04, 2012
Richard, Rick, an Bob, Thanks for nicking out to your airplanes and gathering the data. The information it has been most helpful! Hopefully we will meet at the homecoming in a couple weeks. Sent from my iPad Brad ________________________________________________________________________________
Date: Nov 05, 2012
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Make sure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 06, 2012
Subject: A Message From AeroElectric's Bob Nuckolls...
Dear Listers, The well known Bob Nuckolls of the AeroElectric posted a great message Monday on the AeroElectric-List regarding the Matronics Lists and the importance of supporting the operation during the Fund Raiser. Please take a minute to read Bob's commentary below, reposted to the other Matronics Lists with his permission... Date: Mon, 05 Nov 2012 08:58:41 -0600 From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: AeroElectric-List: Re: Please Make A Contribution Today! At 02:14 AM 11/5/2012, Matt Dralle wrote: > > Each year at the end of the List Fund Raiser, I post a message > acknowledging everyone that so generously made a Contribution to > support the Lists. Its my way of publicly thanking everyone that > took a minute to show their appreciation for the Lists. > I will add my voice to this suggestion. It's easy to enjoy the benefits of what's available to us off-the-shelves at the corner mega-marts. It's seldom that we give pause to learn and understand the processes and tools that made it possible to reach out and select from dozens of options. This, and all civil societies, runs on talent, energy and mobility. Mobility exploited by thousands of hands, machines and transportation that figure into the 'infrastructure' that puts the boxes of Wheaties and Pop Tarts on the shelves. See "I pencil" http://tinyurl.com/36xkhq Any break in that chain of time, talent and resources at least interrupts if not totally halts flow of that benefit. Matt's room full of byte-thrashers is like the natural gas pumping station a few miles from my house. If those pumps stop, who ever is expecting the furnace to come on at the other end of the pipe is at risk for reduced service and/or higher costs for that service. Matt's yearly endeavor to keep his pumps running is a trivial burden on the members of the Lists but of incalculable value to those who participate on them. No donation is too small. We go to a fly-in a willingly chuck a few bucks into the coffee can at the drinks and donuts table, let's chuck a few bucks into Matt's coffee can too. 50,000 pounds of value doesn't get to the shelves on time if one 18-wheeler runs out of gas. The T-bytes of data flow we all enjoy don't get from your keyboard to the screens of others unless Matt pays the light bill and strokes the machines to keep them happy. No, $5 won't get you a free copy of the 'Connection or a fuel sampler but it will go toward the assurance that logging onto your favorite List will open doors that you would be sorely missed should you find that hitting the return key doesn't produce the expected response. $5 from every List customer on Matt's system will go a very long way to keeping the byte-pumps running. $More$ will go a long way to upgrading the size and quality of the machines as the old ones get long in the tooth. No matter what size of donation you choose . . . please do it now . . . Bob . . . Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: work inside home?
Date: Nov 07, 2012
I have been working on relocating to a cooler climate, less urban, etc. I will either buy a place with a nice large-ish workshop or I will build one. I need to recover my Firestar and have been waiting for the workshop, but it looks like it won't happen till next summer. While I have some people staying in my home (I am a widower) I noticed that the formal 'parlor' gets almost zero use. I have a large living room that is used a lot, and a sort of rumpus room the kids play in. I am thinking of moving the nice furniture out or stacking it and recovering my wings in there. I will be using the Stewart's System so there shouldn't be too much odor in the house. That sound right to you? I can block off the traffic, and seal the room off with plastic if necessary. Double-door access and plenty of space. Any thoughts on this? I am emptying my garage but I would need to insulate it and heat it to work in there. -------- GeoB "Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387144#387144 ________________________________________________________________________________
Subject: Re: work inside home?
Date: Nov 07, 2012
I am thinking of moving the nice furniture out or stacking it and recovering my wings in there. > No prob. I had a mate who did a lot of work on an Auster including recovering the wings. Of course the wings stuck into the garden and he couldn`t close the patio doors all winter. The engine was on the dining room table. His wife divorced him and the kids went to boarding school. Apart from that it was quite straightforward. Good luck Pat ________________________________________________________________________________
Date: Nov 07, 2012
Stewarts is a great product! I used it totaly on my Mark 3 c. My wife and I did =0Aall covering and uv painting in the house during winter months.We a lso have =0Adouble doors on the house so we were able to carry the plane in or out.Their =0Aglues are nontoxic and there is no need to even turn off t he furnace.It is a =0Agreat way to keep working during the cold months.Easy to use,highly =0Arecomend.Received airworthyness a year ago this month.=0A -=0AGary Jindra=0AMark 3 c=0A107 hours=0A=0A=0A=0A=0A____________________ ____________=0AFrom: GeoB <gab16(at)sbcglobal.net>=0ATo: kolb-list(at)matronics.c om=0ASent: Wed, November 7, 2012 3:56:14 AM=0ASubject: Kolb-List: work insi =0A=0AI have been working on relocating to a cooler climate, less urban, et c. I will =0Aeither buy a place with a nice large-ish workshop or I will bu ild one. I need to =0Arecover my Firestar and have been waiting for the wor kshop, but it looks like it =0Awon't happen till next summer.=0AWhile I hav e some people staying in my home (I am a widower) I noticed that the =0Afor mal 'parlor' gets almost zero use. I have a large living room that is used a =0Alot, and a sort of rumpus room the kids play in. I am thinking of movi ng the =0Anice furniture out or stacking it and recovering my wings in ther e. I will be =0Ausing the Stewart's System so there shouldn't be too much o dor in the house. =0AThat sound right to you? I can block off the traffic, and seal the room off with =0Aplastic if necessary. Double-door access and plenty of space.=0A=0AAny thoughts on this? I am emptying my garage but I w ould need to insulate it =0Aand heat it to work in there.=0A=0A--------=0AG eoB=0A=0A"Members of Congress should be compelled to wear uniforms lik e NASCAR =0Adrivers, so we could identify their corporate sponsors"=0A =0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/v ========= ________________________________________________________________________________
Date: Nov 07, 2012
Subject: Idle problem?
I have a 447 on a firefly with 220 hours my idle has gotten so bad that I won't fly it now? It will run past 3000 RPM fine. I checked the idle jet and rebuilt the pump. It will run good if i keep pushing in the primer so its a fuel problems? HELP Bill Long 2000 FireFly Holt MI ________________________________________________________________________________
Date: Nov 07, 2012
if the fuel through the idle jet is ok... next thing I would check is for a vacuum leak through a seal, gasket, carb adapter, pulse line. etc. any changes in the air cleaners? are the plugs the same color they use to be after a hard run? if they are a lighter color, it may be telling you it is running a bit leaner. what happens when you pull the enrichener? boyd young most of this is the easy stuff to check.. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>> From: William Long Sent: Wednesday, November 07, 2012 5:42 PM Subject: Kolb-List: Idle problem? I have a 447 on a firefly with 220 hours my idle has gotten so bad that I won't fly it now? It will run past 3000 RPM fine. I checked the idle jet and rebuilt the pump. It will run good if i keep pushing in the primer so its a fuel problems? HELP Bill Long 2000 FireFly Holt MI ________________________________________________________________________________
Subject: BMW R100 engine for sale on Barnstormers.com
Date: Nov 07, 2012
I sold my Kolb Mark 3 Classic but the buyer did not want the BMW engine (he wanted more bhp). Check out my ad on Barnstormers.com by searching BMW. Asking $3500. 65 BHP. Runs great. -------- Tim BMW powered Kolb Mk 3 Classic Tucson, AZ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387202#387202 Attachments: http://forums.matronics.com//files/dscn0430_737.jpg http://forums.matronics.com//files/dscn1604_121.jpg ________________________________________________________________________________
Date: Nov 08, 2012
Subject: Make A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Subject: Twinstar Gear
Date: Nov 08, 2012
Hi everyone, I have a Twinstar MK II and I am wondering if anyone has ever tried adapting fiberglass gear legs to this. I have only put about 15 hours on it so far and I noticed that one of the gear legs is starting to bend already. I fly from a bumpy strip on a farm that is not mine and the owner doesn't want me to do much to smooth it out so I have to use it the way it is. I also own a CGS Hawk Classic with fiberglass landing gear that has no problem flying from this field. thanks for any responses, Lee.. ________________________________________________________________________________
Date: Nov 08, 2012
Subject: Re: Twinstar Gear
Tundra Tires? On Thu, Nov 8, 2012 at 7:42 AM, Lee wrote: > Hi everyone,**** > > I have a Twinstar MK II and I am wondering if anyone has ever tried > adapting fiberglass gear legs to this.**** > > I have only put about 15 hours on it so far and I noticed that one of the > gear legs is starting to bend already.**** > > I fly from a bumpy strip on a farm that is not mine and the owner doesn't > want me to do much to smooth it out so I have to use it the way it is.**** > > I also own a CGS Hawk Classic with fiberglass landing gear that has no > problem flying from this field.**** > > thanks for any responses,**** > > Lee.. > ________________________________________________________________________________
Subject: Has anyone tried Oratex fabric?
Date: Nov 08, 2012
Hello GeoB and all, Has anyone tried Oratex Fabric yet? There is a J-3 Cub here a Palmer that was recovered with Oratex a year ago and looks good. Water based system and pre colored fabric saved time and weight. You might check in to if you're doing a plane in your house. I hope to use it next spring. Enjoy, Nick Cassara Palmer, AK 607AK ________________________________________________________________________________
Subject: Re: Idle problem?
Date: Nov 08, 2012
I think you are on the right track with the idle jet. I'm sure you know what you are doing but just to level set check the attached picture to make sure you are looking at the #4 idle jet. This jet has a tiny, tiny orifice and that is probably blocked. I'm surprised they don't get blocked all the time they are so small. Check that jet again and report back. [Wink] Scott Olendorf -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387325#387325 Attachments: http://forums.matronics.com//files/bingprts_103.gif ________________________________________________________________________________
Date: Nov 08, 2012
Subject: Re: Has anyone tried Oratex fabric?
At 02:04 PM 11/8/2012, you wrote: >Has anyone tried Oratex Fabric yet? There is a J-3 Cub here a Palmer that >was recovered with Oratex a year ago and looks good. Water based system >and pre colored fabric saved time and weight. You might check in to if you >re doing a plane in your house. I hope to use it next spring. There was some discussion of Oratex on the http://homebuiltairplanes.com forums. A bit pricey, and people looking for a very shiny finish don't like it. OTOH the ease of application is appealing... I've been considering it for a new ultralight I'm designing. -Dana -- A tree: first you chop it down, then you chop it up. ________________________________________________________________________________
Date: Nov 08, 2012
When I owned a Titan Tornado I operated from a paved but very poor condition runway with pot holes and regularly landed on any grass airfield in the area. It had fiberglass gear legs and it handled the rough stuff with no problem at all. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387335#387335 ________________________________________________________________________________
Date: Nov 08, 2012
Bill Long & Others: I have had trouble similar to what you are experiencing. After cleaning the carburetor several times with no improvement, I replaced the idle jet and that corrected the trouble. The reason I chose to replace the idle jet was because it had become discolored and I thought perhaps that was a build up of some contamination, thus causing a lack of fuel flow through it. I use regular grade auto fuel and it contains up to 10% ethanol. I also started using StarTron, an additive advertised to help eliminate problems with ethanol laced fuel. Stabil also makes a product to fight ethanol. Hope this is of some help to you. Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive In a message dated 11/7/2012 7:42:39 P.M. Eastern Standard Time, blong6826(at)sbcglobal.net writes: I have a 447 on a firefly with 220 hours my idle has gotten so bad that I won't fly it now? It will run past 3000 RPM fine. I checked the idle jet and rebuilt the pump. It will run good if i keep pushing in the primer so its a fuel problems? HELP Bill Long 2000 FireFly Holt MI (http://www.aeroelectric.com/) (http://www.buildersbooks.com/) (http://www.homebuilthelp.com/) (http://www.matronics.com/contribution) (http://www.matronics.com/Navigator?Kolb-List) ________________________________________________________________________________
Subject: Mark III Classic Weight & Balance Calcs
Date: Nov 08, 2012
Can anyone tell me what the moment arms for the pilot(s) and for the fuel in a Mark III Classic are? I'm considering buying one and wanted to run some numbers. What is the allowable CG range? Max gross? Thanx muchly! Gerry Visel ________________________________________________________________________________
Date: Nov 08, 2012
The other good thing to check is the O ring on the idle jet needle. If this has perished and has cracks in it it will give you a lean condition in the idle range . Tony Downunder MK111c going well. Just coming into spring . Great flying weather -----Original Message----- From: olendorf Sent: Friday, November 09, 2012 9:18 AM Subject: Kolb-List: Re: Idle problem? I think you are on the right track with the idle jet. I'm sure you know what you are doing but just to level set check the attached picture to make sure you are looking at the #4 idle jet. This jet has a tiny, tiny orifice and that is probably blocked. I'm surprised they don't get blocked all the time they are so small. Check that jet again and report back. [Wink] Scott Olendorf -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387325#387325 Attachments: http://forums.matronics.com//files/bingprts_103.gif ________________________________________________________________________________
Subject: cg mkiii
Date: Nov 09, 2012
guess it depends on the weight of the pilot.... mine worked out about =934 inches..... kolb=99s belly button method worked within 1/4 inch of what I calculated, I did the cg with the plane empty, then did it with me in it, and did the math to find the cg of me...then measured from the leading edge to the belly button... and the measurment and calculations were really close. as for the cg of the fuel tanks..... I have the 16 gal alum tank offered by the original kolb company. the cg of that tank is 21 to 21 1/2 inches I would have to go out to the plane and look at the w&b sheets , which worked out to be very near the rear cg limit of 35% so with me solo. I start at the rear cg and as I burn off fuel the cg does not move... if I have a passenger I am at a point forward of the rear limit. and as I burn off fuel, the cg moves forward. if you have the 2 plastic tanks, I don=99t know where you will come in,, but my best guess is it will be somewhat close,,,,, weigh the plane and do the math. it is probably something you wont want to guess with or use someone else=99s numbers. I put together a spread sheet to do the math... but you still have to get accurate weights and measurements for the spread sheet to work for you. when making the measurements, make sure the plane is in the correct attitude. or you just did a lot of work for nothing. my blue prints show the cg range from 25 to 35 percent of the wing cord. boyd >>>>>>>>>>>>>>>>>>> Can anyone tell me what the moment arms for the pilot(s) and for the fuel in a Mark III Classic are? I'm considering buying one and wanted to run some numbers. What is the allowable CG range? Max gross? Thanx muchly! Gerry Visel ________________________________________________________________________________
Date: Nov 09, 2012
Bill, Your idle problem may not be a carb issue. If you have a points ignition, I would look there. I have a 377 that had the exact same problem that you have described, ultimately I convereted to CDI and the problem dissapeared. Just a suggestion. Points on a Rotax are very sensitive. With the air cleaner off does it spit fuel back ? For what it's worth. roy On Wed, Nov 7, 2012 at 7:42 PM, William Long wrote: > I have a 447 on a firefly with 220 hours my idle has gotten so bad that I > won't fly it now? > It will run past 3000 RPM fine. I checked the idle jet and rebuilt the > pump. > It will run good if i keep pushing in the primer so its a fuel problems? > HELP > > Bill Long > 2000 FireFly > Holt MI > > * > > * > > ________________________________________________________________________________
Date: Nov 09, 2012
Subject: Tests of fuel additives
On the Yahoo! HKS forum this test of fuel additives was posted this morning. I thought it would prove valuable. I know the Sea Foam acolytes will like it. http://www.biobor.com/Practical-Sailor-Fuel-Additives-That-Fight-Corrosion.php You'll have to cut and paste the link, it didn't come across as clickable for some reason. Rick Girard -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Nov 09, 2012
Subject: Re: Mark III Classic Weight & Balance Calcs
Earlier this year I did flight testing of a Mk IIIX to get performance numbers at weights up to 1200 lb. MTOW. While the plane will fly at that weight, it must be flown very carefully. I set the max weight for the plane at 1100 lb. when I did the log book entry. At that weight it flew quite well. For my own Mk IIIC I used 1050 lb as MTOW. I've attached the Excel spread sheet I use for my IIIC. On Thu, Nov 8, 2012 at 9:06 PM, Gerry Visel wrote: > > Can anyone tell me what the moment arms for the pilot(s) and for the > fuel in a Mark III Classic are? I'm considering buying one and wanted > to run some numbers. What is the allowable CG range? Max gross? > > Thanx muchly! > Gerry Visel > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Nov 09, 2012
You may also have an air leak, either at a gasket in the intake system or t he rubber carb socket which does crack internally .If the exhaust gas temp s are running higher than normal( for the ambient air temps ) at cruise rpm , it may be an indicator of an air leak. G.Aman -----Original Message----- From: Roy Spangler <roy.spangler(at)kirtland.edu> Sent: Fri, Nov 9, 2012 8:33 am Subject: Re: Kolb-List: Idle problem? Bill, Your idle problem may not be a carb issue. If you have a points ignition, I would look there. I have a 377 that had the exact same problem that you have described, ultimately I convereted to CDI and the problem dissapeared. Just a suggestion. Points on a Rotax are very sensitive. With the air cleaner off does it spit fuel back ? For what it's worth. roy On Wed, Nov 7, 2012 at 7:42 PM, William Long wrot e: I have a 447 on a firefly with 220 hours my idle has gotten so bad that I w on't fly it now? It will run past 3000 RPM fine. I checked the idle jet and rebuilt the pump . It will run good if i keep pushing in the primer so its a fuel problems? HELP Bill Long 2000 FireFly Holt MI _blank">www.aeroelectric.com .com" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com ________________________________________________________________________________
Date: Nov 09, 2012
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: Idle Problem?
- I had a similar problem with my 447, and John H. suggested I check the seal on the bottom of the enrichener.- Mine had totally disintegrated.- Replacement was very cheap.- The part does not come through in a carb ki t- it has to be ordered separately.- Easy to pull out and check visually. ------------------------- ------------- Bill Sullivan ------------------------- ------------- Windsor Locks, Ct. ------------------------- ------------- Original FS, 447 ________________________________________________________________________________
Date: Nov 09, 2012
Looks like it was the idle jet I took it out again and blew through it real hard and its better so im going to soak it in carb cleaner tonight. Bill Long ________________________________ From: Richard Girard <aslsa.rng(at)gmail.com> Sent: Fri, November 9, 2012 10:51:19 AM Subject: Re: Kolb-List: Idle problem? In addition to the idle jet be sure to clean the passages in the carb body. When my 582 was laid up for more than a year that was the problem area that prevented it from idling properly. Once they were cleared out the engine idled just fine. Rick Girard On Thu, Nov 8, 2012 at 8:10 PM, wrote: >Bill Long & Others: > >I have had trouble similar to what you are experiencing. After cleaning the >carburetor several times with no improvement, I replaced the idle jet and that >corrected the trouble. The reason I chose to replace the idle jet was because >it had become discolored and I thought perhaps that was a build up of some >contamination, thus causing a lack of fuel flow through it. I use regular >grade auto fuel and it contains up to 10% ethanol. I also started using >StarTron, an additive advertised to help eliminate problems with ethanol laced >fuel. Stabil also makes a product to fight ethanol. Hope this is of some help >to you. > >Bill Varnes >Original Kolb FireStar >Audubon NJ >Do Not Archive > >In a message dated 11/7/2012 7:42:39 P.M. Eastern Standard Time, >blong6826(at)sbcglobal.net writes: >I have a 447 on a firefly with 220 hours my idle has gotten so bad that I >won't fly it now? >>It will run past 3000 RPM fine. I checked the idle jet and rebuilt the pump. >>It will run good if i keep pushing in the primer so its a fuel problems? >>HELP >> >> >>Bill Long >>2000 FireFly >>Holt MI >> ============== ref="http://www.aeroelectric.com/">www.aeroelectric.com >>buildersbooks.com/ href="http://www.buildersbooks.com/">www.buildersbooks.com >>elp.com/ href="http://www.homebuilthelp.com/">www.homebuilthelp.com >>ef="http://www.matronics.com/contribution">http://www.matronics.com/contribution >>List >>href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List >> p://forums.matronics.com/">http://forums.matronics.com >> >> > _blank">www.aeroelectric.com .com" target="_blank">www.buildersbooks.com >="_blank">www.homebuilthelp.com _blank">http://www.matronics.com/contribution >get="_blank">http://www.matronics.com/Navigator?Kolb-List >tp://forums.matronics.com > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Nov 09, 2012
Richard, When you were flight testing, how did you know where to set the limits, for both CG and for weight? (What flight characteristics were noticed?) For max weight especially, why would you exceed the designer's recommendation? Have you done anything to the design to make it stronger than original? I would sure hope that the designer had done some stress calcs at the max rated g-loading, (or is that just the engineer in me coming out?) Gerry Visel > Earlier this year I did flight testing of a Mk IIIX to get performance > numbers at weights up to 1200 lb. MTOW. While the plane will fly at > that weight, it must be flown very carefully. I set the max weight for > the plane at 1100 lb. when I did the log book entry. At that weight it > flew quite well. For my own Mk IIIC I used 1050 lb as MTOW. > I've attached the Excel spread sheet I use for my IIIC. ________________________________________________________________________________
Date: Nov 09, 2012
Gerry, The owner wanted the MTOW raised so he could take flight training in his airplane. The airplane is rated for 4 g's at 1000 lb. Raising it to 1100 makes it 3.8 and they've been flown heavier than that, just ask Hauck. I used the same fore and aft limits as a Cessna 172 (and just about every straight winged aircraft ever built) and then flew the aircraft at both limits to see that I had enough elevator power to raise the nose at the forward limit and it did nothing funny when stalled at the aft limit. Rick On Fri, Nov 9, 2012 at 7:17 PM, Gerry Visel wrote: > > Richard, > > When you were flight testing, how did you know where to set the > limits, for both CG and for weight? (What flight characteristics were > noticed?) > > For max weight especially, why would you exceed the designer's > recommendation? Have you done anything to the design to make it > stronger than original? I would sure hope that the designer had done > some stress calcs at the max rated g-loading, (or is that just the > engineer in me coming out?) > > Gerry Visel > > > Earlier this year I did flight testing of a Mk IIIX to get performance > > numbers at weights up to 1200 lb. MTOW. While the plane will fly at > > that weight, it must be flown very carefully. I set the max weight for > > the plane at 1100 lb. when I did the log book entry. At that weight it > > flew quite well. For my own Mk IIIC I used 1050 lb as MTOW. > > I've attached the Excel spread sheet I use for my IIIC. > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Nov 09, 2012
Oh, JUST a colonoscopy. From: Richard Girard Sent: Friday, November 09, 2012 8:46 PM Subject: Re: Kolb-List: Mark III Classic Weight & Balance Calcs Gerry, The owner wanted the MTOW raised so he could take flight training in his airplane. The airplane is rated for 4 g's at 1000 lb. Raising it to 1100 makes it 3.8 and they've been flown heavier than that, just ask Hauck. I used the same fore and aft limits as a Cessna 172 (and just about every straight winged aircraft ever built) and then flew the aircraft at both limits to see that I had enough elevator power to raise the nose at the forward limit and it did nothing funny when stalled at the aft limit. Rick On Fri, Nov 9, 2012 at 7:17 PM, Gerry Visel wrote: Richard, When you were flight testing, how did you know where to set the limits, for both CG and for weight? (What flight characteristics were noticed?) For max weight especially, why would you exceed the designer's recommendation? Have you done anything to the design to make it stronger than original? I would sure hope that the designer had done some stress calcs at the max rated g-loading, (or is that just the engineer in me coming out?) Gerry Visel > Earlier this year I did flight testing of a Mk IIIX to get performance > numbers at weights up to 1200 lb. MTOW. While the plane will fly at > that weight, it must be flown very carefully. I set the max weight for > the plane at 1100 lb. when I did the log book entry. At that weight it > flew quite well. For my own Mk IIIC I used 1050 lb as MTOW. > I've attached the Excel spread sheet I use for my IIIC. ="_blank">www.aeroelectric.com ooks.com" target="_blank">www.buildersbooks.com et="_blank">www.homebuilthelp.com ="_blank">http://www.matronics.com/contribution le, List Admin. ========== arget="_blank">http://www.matronics.com/Navigator?Kolb-List ========== http://forums.matronics.com ========== -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx No virus found in this message. Checked by AVG - www.avg.com 11/09/12 ________________________________________________________________________________
Date: Nov 09, 2012
Yes, that's the right answer(s.) I was worried that someone might do that without thinking through the effects and risks of a higher max weight or "out of limits" CG. I went through all this in college as an aero engineer, but have done hardly any aero work my whole career, (mostly mechanical/hydraulic stuff.) Now that I am near retirement and getting back into flying, I finally get to use some of that practical stuff! (It's a whole lot more fun when it's real!) Gerry > Gerry, The owner wanted the MTOW raised so he could take flight > training in his airplane. The airplane is rated for 4 g's at 1000 lb. > Raising it to 1100 makes it 3.8 and they've been flown heavier than > that, just ask Hauck. > I used the same fore and aft limits as a Cessna 172 (and just about > every straight winged aircraft ever built) and then flew the aircraft > at both limits to see that I had enough elevator power to raise the > nose at the forward limit and it did nothing funny when stalled at the > aft limit. > > > Rick > > On Fri, Nov 9, 2012 at 7:17 PM, Gerry Visel wrote: > > > > Richard, > > When you were flight testing, how did you know where to set > the > limits, for both CG and for weight? (What flight > characteristics were > noticed?) > > For max weight especially, why would you exceed the > designer's > recommendation? Have you done anything to the design to make > it > stronger than original? I would sure hope that the designer > had done > some stress calcs at the max rated g-loading, (or is that just > the > engineer in me coming out?) > > Gerry Visel ________________________________________________________________________________
Date: Nov 10, 2012
Subject: Please Support The Lists...
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. There are some very nice incentive gifts to choose from as well! Please make your Contribution today at: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 11, 2012
Subject: California to Homecoming
Gday, During this coming week I'll be trailering my FireFly from California to the Kolb Homecoming Nov 16-18. The aircraft and trailer combo is for sale, so if anyone along the way is interested I can stop to visit. Looking forward to meeting everyone there. See ya. JG ________________________________________________________________________________
Date: Nov 10, 2012
During this coming week I'll be trailering my FireFly from California to the Kolb Homecoming Nov 16-18. The aircraft and trailer combo is for sale, so if anyone along the way is interested I can stop to visit. Looking forward to meeting everyone there. See ya. JG JG/Kolbers: That's great news. Looking forward to seeing you again. Was lucky enough to spend time with John G at the Rock House last June. Be worth anyone's time to come and visit with JG. He is a wealth of info on flying light planes in Australia as well as the US. I'll be arriving at the Homecoming on Thursday, after it warms up a bit, with my buddy James Tripp. James built and flies a MKIIIc, a clone of Miss P'fer, my MKIII. James's MKIIIc is powered with the 912ULS that powered my friend John Williamson's Kolbra. Hopefully, the weather will cooperate with us. If not, guess I'll have to put on more clothes to stay warm. My MKIII is ready to go. The last thing to do after an oil and filter change was give her a bath to wash the barn dust, bug and bird crap off after sitting in the hanger for three months. The top of the wings are dust magnets. Got that done yesterday. Now it is time to fly to Wetumpka Airport to my Chap 822 EAA meeting this afternoon. If I hurry I'll be there in time for grilled hamburgers and hot dogs. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 10, 2012
Subject: Re: California to Homecoming
You have an excellent price on the bird and trailer combo...cannot believe that it hasn't sold...Herb At 11:46 AM 11/10/2012, you wrote: >Gday, > >During this coming week I'll be trailering my FireFly from >California to the Kolb Homecoming Nov 16-18. >The aircraft and trailer combo is for sale, so if anyone along the >way is interested I can stop to visit. >Looking forward to meeting everyone there. >See ya. > >JG > > ><http://www.buildersbooks.com>www.buildersbooks.com ><http://www.matronics.com/contribution>http://www.matronics.com/contribution ><http://www.matronics.com/Navigator?Kolb-List>http://www.matronics.com/Navigator?Kolb-List > ________________________________________________________________________________
Date: Nov 12, 2012
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some pointd, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 22 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 12, 2012
Is the Homecoming for Kolb Pilots only, or can Kolb Wanna-bes attend? Seems like a great way to check out the full range of Kolbs. -Steve Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387685#387685 ________________________________________________________________________________
Date: Nov 12, 2012
it has always been, "the more the merrier"...everyone is welcome... I think we are on our own for all but the rest room? Herb At 08:59 AM 11/12/2012, you wrote: > >Is the Homecoming for Kolb Pilots only, or can Kolb Wanna-bes attend? > >Seems like a great way to check out the full range of Kolbs. > >-Steve > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=387685#387685 > > ________________________________________________________________________________
Date: Nov 12, 2012
Subject: Sandy!!!!
Morning Kolbers, I dodged the bullet again, well, almost. I got grazed. I keep my FlagFly hangared in a converted construction office trailer. Unfortunately, the airstrip is on the top of a hill with pretty nasty winds. When Sandy roared through she flipped my trailer 11/4 revolutions. The trailer is destroyed but amazingly the FlagFly sustained minimal damage. Both the owner of the airstrip and I are about done with trying to keep a trailer upright so it looks like we're going to put the FF in the end of the hangar. It'll cost more (less in the long run, I suppose), but it will take less time to set up, not having to untie and set up ramps, etc. The damage to the aircraft is a bend in the trailing edge of the left elevator, a bend from the prop to the trailing edge of the left wing, loosened aileron anti-flutter weights and one 1' and about 7 small tears in the fabric. I'm a landscaper and an 18 wheeler jockey and don't feel qualified to perform the repairs properly, so I'm looking for a builder I can hire to repair the wings and elevator. I can load the parts on my pickup and take them to the repair point so they won't have to travel. If you are interested in the job or know of anyone who may be, please contact me. I'll attach (if I'm successful) a few shots of the damaged parts, and a couple of the trailer, which should leave you dumbfounded, as it did me, that the FlagFly came through so well. When you open the last two photos it may be difficult to tell where the actual wrinkles are and what's been painted by Don G., but If you look for a few moments you can make sense of it. Oh, and take a look at the wind sock... Dave Kulp Bethlehem, PA FireFly 11DMK ________________________________________________________________________________
Subject: Re: Sandy!!!!
Date: Nov 12, 2012
Dave...get the Flagfly stretched out and send me some detailed photos of all the damaged areas..lots of them. -------- Don G. Central Illinois Kitfox IV Speedster Luscombe 8A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387729#387729 ________________________________________________________________________________
Date: Nov 12, 2012
You bet I will, Don!! If you go to the list you can see basic views, but I'll go up to the strip tomorrow afternoon and take more. dK Sent from my iPhone On Nov 12, 2012, at 9:23 PM, "Don G" <donghe@one-eleven.net> wrote: > > Dave...get the Flagfly stretched out and send me some detailed photos of all the damaged areas..lots of them. > > -------- > Don G. > Central Illinois > Kitfox IV Speedster > Luscombe 8A > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=387729#387729 > > > > > > > > > > ________________________________________________________________________________
Subject: Sandy!!!!
Date: Nov 12, 2012
Sad to hear about your damage, but very pleased that she is repairable. Beauford I echo Beauford's sentiments. Never gave a storm a chance to damage any of my three Kolbs. Didn't have to. I was able to total all three of them all by myself. ;-) john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 13, 2012
At 08:49 PM 11/12/2012, you wrote: >Morning Kolbers, > >I dodged the bullet again, well, almost. I got grazed... Yikes! With the trailer in that shape it's hard to believe the plane wasn't totaled! I was lucky. My trailer is also at a hilltop airport (coastal CT) but I was able to tuck it in between two hangars on the side sheltered from the predicted winds, and tie it down at a couple of points. No trouble at all, only damage at my airport was a couple of metal hangar roof panels ripped off. -Dana -- Q. What's the difference between Mechanical and Civil Engineers? A. Mechanical Engineers build weapons; Civil Engineers build targets. ________________________________________________________________________________
Subject: Can't wait to turn the lights on!
Date: Nov 13, 2012
My lights on the Kolb are ready. I add more lights every year. They will be lit the night after Thanksgiving. I move the Kolb one mile from the airport hanger to the display area. It's easy to push on the sidewalk without the wings attached. https://vimeo.com/53297642 Have a happy Thanksgiving and a very merry Christmas! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387798#387798 ________________________________________________________________________________
Date: Nov 14, 2012
Subject: Make Sure You're Listed! List of Contributors Published in
December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Kolb Homecoming, 2012
Date: Nov 15, 2012
Heading to Gantt International Airport to load the my MKIII and fly to London, KY, with James Tripp and his identical MKIII. About 4.5 hour flight. Weather here is overcast and 49F. A little chilly, but we should fly into clear air and sunshine as we proceed NE. Looking forward to seeing old and new Kolbers at the Homecoming. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 15, 2012
Hi Dana, The problem at Kessler Field is it's on a high point surrounded by mostly farmland. Very few trees locally to create a windbreak. Ground is too rocky to get any anchors in, but after it blew on its side last time I bought a 4 X 4 X 10, fed it between the leaf springs and frame and created an outrigger. I figured if it didn't get any momentum it wouldn't roll again. Wrong! Snapped the 4 X k4! Gonna go in half a hangar space now, which should end these calamities. Mom used to tell me how hard she prayed for my safety, considering my lifestyle. I believe she's still pestering God about it. Two weeks prior to Sandy I was heading down to Quakertown for supper on my Beemer with my 100# black Lab in a trailer when a big buck jumped in front of me. I T-boned him at about 50 mph, when horizontal for almost 20', came down on my left side and slid for over 100'. Nothing but some road rash and 10,7K damage to the cycle. Trailer and Bubba stayed upright. So it's been quite a month! dK On 11/13/2012 6:28 AM, Dana Hague wrote: > At 08:49 PM 11/12/2012, you wrote: >> Morning Kolbers, >> >> I dodged the bullet again, well, almost. I got grazed... > > Yikes! With the trailer in that shape it's hard to believe the plane > wasn't totaled! > > I was lucky. My trailer is also at a hilltop airport (coastal CT) but > I was able to tuck it in between two hangars on the side sheltered > from the predicted winds, and tie it down at a couple of points. No > trouble at all, only damage at my airport was a couple of metal hangar > roof panels ripped off. > > -Dana > > -- > Q. What's the difference between Mechanical and Civil > Engineers? > A. Mechanical Engineers build weapons; Civil > Engineers build targets. > * > > > * ________________________________________________________________________________
Date: Nov 15, 2012
Hope all your mishaps are over and you have a nice flight to the homecoming, John. I'd like to be there, but I'm up to my eyeballs in Sandy cleanup and repair. Maybe next year. dK On 11/12/2012 10:57 PM, John Hauck wrote: > > > > Sad to hear about your damage, but very pleased that she is repairable. > Beauford > > > > I echo Beauford's sentiments. > > Never gave a storm a chance to damage any of my three Kolbs. Didn't have > to. I was able to total all three of them all by myself. ;-) > > john h > mkIII > Titus, Alabama > > ________________________________________________________________________________
Date: Nov 15, 2012
Date: Nov 15, 2012
Date: Nov 15, 2012
Date: Nov 16, 2012
Subject: Who is Matt Dralle & What Are The Lists?
Dear Listers, Who is Matt Dralle and what exactly are these Lists anyway? I've been working in the Information Technology industry for over 28 years, primarily in computer networking design and implementation and more recently as an embedded software engineer. I have also done a fair amount of work in web design and development. I started the Matronics Email Lists way back in 1990 shortly after I started building my RV-4 with about 30 fellow RV builders from around the world. Since that time, I have added many other types of aircraft related Lists to the line up and numerous other List related services such as the Forums, Wiki, Archives and Search Engine just to name a few. For flexibility and reliability, I have chosen to run all of my own servers locally. Other List-related systems include a 1 Gigabit, fully switched network infrastructure, a commercial-grade Netscreen firewall, a Barracuda spam filter, a local T1 Internet router, and a bonded dual T1 commercial-grade business Internet connection with full static addressing. The computer servers include a dual quad-core Linux server for List web services with 24GB of memory, a quad -core Linux system dedicated to the email processing List functions, and another standalone Linux system serving as a remote storage disk farm for the archives, databases, and for an on-line hard drive-based backup system with multi-terra byts of online storage. This entire system is protected by three large, commercial-grade uninterrupted power supply systems (UPS) that assure the Lists are available even during a local power outage! Speaking of power, imagine how much electricity it takes to run all of these systems. On the average, the elctric bill is in the neighborhood of $7000-$8000/yr and the newly upgraded dual-T1 Internet connection runs roughly $6000/yr. A while back, I upgraded all of the computer racking infrastructure including new power feeds and dedicated air conditioning for the room that serves as the Computer Center for the Matronics Email Lists and followed that upgrade up with a second rack upgrade to house the MONSTER web system that didn't quite fit into the first rack! Here's a composite photo of the List Computer Center prior to the addition of the second rack: http://www.matronics.com/MattDralle-ListComputerCenter.jpg As you can see, I take running these Lists very seriously and I am dedicated to providing an always-on, 24x7x365 experience for each and every Lister. But building and running this system isn't cheap. As I've mentioned many times before, I don't use commercial advertisments to support any of these systems. It is supported 100% through List member Contributions! That means you... and you... and YOU! To that end, I hold a List Fund Raiser each November and ask that members make a Contribution to support the continued operation and upgrade of this ever-expanding system. Its solely YOUR Contributions that keeps it running! Please make a Contribution today to support these Lists! http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 17, 2012
Subject: Kolb MKII for sale
Hi Everyone, I'm selling my sweet little Kolb MKII. 150 hours total time engine and airframe. Electric start. Fires right up even after sitting for a long while. New tires. Conditional inspection done in August. You can see pictures of it posted on barnstormers right now. Search for Kolb MKII. Mine is yellow with red leading edge wings. I will sell to anyone on the Kolb list for $7500. Rotax 503 engine Frequently Asked Questions Will you deliver? Possibly in return for expenses How many gals per hour does it burn? Depends on how hard you push it. I would say about 4 gallons per hour, but haven't really checked. What is the N number? N6141D. Does it smell like peanut butter? No. ________________________________________________________________________________
Date: Nov 18, 2012
Subject: Kolb Homecoming 2012
Gday All, Well, I'm sure glad that circumstances led me all across the country to the Kolb Homecoming 2012. It's been a great gathering, and I really enjoyed meeting everyone here. Even got to hear Travis play the banjo. While here, Brian inspected my FireFly for Edy Linsay in Florida, and she has agreed to buy it. What a perfect place to make the deal, and for the little FireFly to see it's birthplace and meet some of its kin. It's been the excellent finale to this great USA Walkabout adventure. Special memories forever....... Cheers, JG ________________________________________________________________________________
Date: Nov 17, 2012
Subject: Re: Kolb Homecoming 2012
Hi JG I want to thank you very much for your report on the Kolb Homecoming 2012. I've been reading about your travel adventures and I believe you are about an equal to John h. Now how's that for a comparison? Sure wish I could have met you. You are an inspiration. Keep that Walkabout going, wherever it takes you. Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive In a message dated 11/17/2012 5:17:52 P.M. Eastern Standard Time, j.gilpin(at)bigpond.com writes: It's been the excellent finale to this great USA Walkabout adventure. Special memories forever....... ________________________________________________________________________________
Subject: penetrating oils
Date: Nov 18, 2012
Hi All, this from a mate in NZ. Thought it might be useful for someone. Dont know if these products are available outside the Antipodes but it might give you ideas. Pat. Machinist's Workshop MagT recently published some information on various penetrating oils Some of you might appreciate this. The magazine reports they tested penetrates for break out torque on rusted nuts. They are below, as forwarded by an ex-student and professional machinist. They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment. *Penetrating oils ........... Average torque load to loosen* No Oil used ................... 516 pounds WD-40 ..................... ... 238 pounds PB Blaster .................... 214 pounds Liquid Wrench ...............127 pounds Kano Kroil .................... 106 pounds ATF*-Acetone mix............53 pounds The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test. ________________________________________________________________________________
Date: Nov 18, 2012
Subject: Re: penetrating oils
On 11/18/2012 04:01 AM, Pat Ladd wrote: > Hi All, > this from a mate in NZ. Thought it might be useful for someone. > Dont know if these products are available outside the Antipodes but it > might give you ideas. > Pat. > Machinist's Workshop MagT recently published some information on > various penetrating oils > > Some of you might appreciate this. The magazine reports they tested > penetrates for break out torque on rusted nuts. > > They are below, as forwarded by an ex-student and professional > machinist. They arranged a subjective test of all the popular > penetrates with the control being the torque required to remove the > nut from a "scientifically rusted" environment. > > *Penetrating oils ........... Average torque load to loosen* > > No Oil used ................... 516 pounds > WD-40 ..................... ... 238 pounds > PB Blaster .................... 214 pounds > Liquid Wrench ...............127 pounds > Kano Kroil .................... 106 pounds > ATF*-Acetone mix............53 pounds > > The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic > transmission fluid and acetone. Note this "home brew" released bolts > better than any commercial product in this one particular test. > > I read about this several years ago, & used the mix on a 1950's era Massey Ferguson tractor when I had to disassemble to replace the head. I can testify; it works. Charlie ________________________________________________________________________________
Date: Nov 19, 2012
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 19, 2012
ok how long do you have to let it soak to get this kind of results? boyd young >>>>>>>>>>>>>>>>>>>>> No Oil used ................... 516 pounds WD-40 ..................... ... 238 pounds PB Blaster .................... 214 pounds Liquid Wrench ...............127 pounds Kano Kroil .................... 106 pounds ATF*-Acetone mix............53 pounds The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test. ________________________________________________________________________________
Date: Nov 19, 2012
how about marvel mystery oil and acetone?? Herb At 09:18 AM 11/19/2012, you wrote: >ok how long do you have to let it soak to get this kind of results? > >boyd young > > >>>>>>>>>>>>>>>>>>>>> >No Oil used ................... 516 pounds >WD-40 ..................... ... 238 pounds >PB Blaster .................... 214 pounds >Liquid Wrench ...............127 pounds >Kano Kroil .................... 106 pounds >ATF*-Acetone mix............53 pounds > > >The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic >transmission fluid and acetone. Note this "home brew" released bolts >better than any commercial product in this one particular test. > > ________________________________________________________________________________
Date: Nov 19, 2012
In my case, I really don't remember how long I let them 'soak'. However, I doubt that I waited that long. After all, the Acetone will evaporate fairly quickly. I won't speculate on why it works, but it does work. Charlie On 11/19/2012 09:18 AM, b young wrote: > ok how long do you have to let it soak to get this kind of results? > boyd young > >>>>>>>>>>>>>>>>>>>>> > No Oil used ................... 516 pounds > WD-40 ..................... ... 238 pounds > PB Blaster .................... 214 pounds > Liquid Wrench ...............127 pounds > Kano Kroil .................... 106 pounds > ATF*-Acetone mix............53 pounds > > > The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic > transmission fluid and acetone. Note this "home brew" released bolts > better than any commercial product in this one particular test. ________________________________________________________________________________
Date: Nov 19, 2012
Why? (Just to spend more money??) :-) On 11/19/2012 09:25 AM, Herb Gayheart wrote: > how about marvel mystery oil and acetone?? Herb > > > At 09:18 AM 11/19/2012, you wrote: >> ok how long do you have to let it soak to get this kind of results? >> >> boyd young >> >> >>>>>>>>>>>>>>>>>>>>> >> No Oil used ................... 516 pounds >> WD-40 ..................... ... 238 pounds >> PB Blaster .................... 214 pounds >> Liquid Wrench ...............127 pounds >> Kano Kroil .................... 106 pounds >> ATF*-Acetone mix............53 pounds >> >> >> The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic >> transmission fluid and acetone. Note this "home brew" released bolts >> better than any commercial product in this one particular test. >> >> >> > ________________________________________________________________________________
Date: Nov 19, 2012
Thanks for the tip, Charlie. Most of us will have ATF fluid around (even used should work), but I wonder if fingernail polish remover could sub for acetone? On Mon, Nov 19, 2012 at 11:16 AM, Charlie England wrote: > Why? (Just to spend more money??) :-) > > On 11/19/2012 09:25 AM, Herb Gayheart wrote: > > how about marvel mystery oil and acetone?? Herb > > > At 09:18 AM 11/19/2012, you wrote: > > ok how long do you have to let it soak to get this kind of results? > > boyd young > > >>>>>>>>>>>>>>>>>>>>> > No Oil used ................... 516 pounds > WD-40 ..................... ... 238 pounds > PB Blaster .................... 214 pounds > Liquid Wrench ...............127 pounds > Kano Kroil .................... 106 pounds > ATF*-Acetone mix............53 pounds > > > The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic > transmission fluid and acetone. Note this "home brew" released bolts > better than any commercial product in this one particular test. > > > * > > * > > ________________________________________________________________________________
Date: Nov 19, 2012
At 04:08 PM 11/19/2012, Martin Koxxy wrote: >Thanks for the tip, Charlie. Most of us will have ATF fluid around (even >used should work), but I wonder if fingernail polish remover could sub for >acetone? Sure, it'll be a _lovely_ flowery smelling bolt loosener! :) Actually, though traditional nail polish remover used to be acetone, I don't think the stuff sold nowadays is always acetone any more. -Dana -- Why did the chicken cross the Mobius strip? To get to the other, er, um.... ________________________________________________________________________________
Date: Nov 19, 2012
On 11/19/2012 02:16 PM, Charlie England wrote: > Why? (Just to spend more money??) :-) > > On 11/19/2012 09:25 AM, Herb Gayheart wrote: >> how about marvel mystery oil and acetone?? Herb >> >> >> At 09:18 AM 11/19/2012, you wrote: >>> ok how long do you have to let it soak to get this kind of results? >>> >>> boyd young >>> >>> >>>>>>>>>>>>>>>>>>>>> >>> No Oil used ................... 516 pounds >>> WD-40 ..................... ... 238 pounds >>> PB Blaster .................... 214 pounds >>> Liquid Wrench ...............127 pounds >>> Kano Kroil .................... 106 pounds >>> ATF*-Acetone mix............53 pounds >>> >>> >>> The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic >>> transmission fluid and acetone. Note this "home brew" released bolts >>> better than any commercial product in this one particular test. >>> >>> >>> >> > Just thought the experiment migh show some superior qualities of > the Marvey oil....Herb > * > > > * ________________________________________________________________________________
Date: Nov 20, 2012
Hi Folks: Well...the Kolb Homecoming 2012 has come and gone. It was the first in three years, and it was a good one. Although the weather was on the cool side at night, it was perfect during the day. We had sunshine and light winds all weekend. James Tripp (MKIIIc with Hauck mods) and I took off for the Kolb Factory Thursday morning. It was cold, but the sun broke out and warmed thing up. I was almost tempted to take off without wearing my jacket, but my better judgment encouraged me to put it on. Glad I did because the scattered sunshine turned to complete overcast shortly after takeoff. We broke out from under the overcast north of Anniston, AL, but the sun was behind us and we sat in the shade of the wing all the way to the Kolb Factory. Both MKIII's have the same performance. We cruised 5,000 rpm and a little over 80 mph. Soon we were landing at Fort Payne, AL, home of the country music group Alabama, for a short break which turned into a long break soon after we walked into the FBO. The couple that run the FBO were interesting folks and interested in James and I and our little Kolb airplanes. Next stop was Jamestown, TN, to take on fuel before landing at Kolb, 67 miles away. That 67 miles is over some seriously rough terrain with tall hard woods and few if any pig trails or roads. We were glad to see the cell phone tower and finally the Kolb airstrip come into sight. We had a headwind for the entire 330 mile flight. I logged 4.8 hours engine time, but the flight was 4.5 hours air time. Although we planned to camp out in our tents, Travis Brown convinced us that we would be a lot more comfortable camping in the office on the floor. We are glad we did because it did get down to freezing each night. Friday was a little slow, but Saturday was a busy day and a nice crowd of folks showed up to enjoy it with us. Bryan, Travis, and Dennis, did a great job preparing for us. I believe everyone had a good time. We all agreed that we did not need any more 3 year breaks between Kolb Homecomings. Looks like the next Kolb Homecoming 2013, will be the third weekend in May, 17-18 May 2013. This is the weekend between Mother's Day and Memorial Day. The flyin will be Friday and Saturday, but folks are welcome to arrive on Thursday and depart on Sunday. We are all looking forward to the Kolb Homecoming 2013. Thanks to the Kolb gang for taking such good care of us at the Homecoming. James and I loaded up and departed the Kolb Factory Sunday morning, another perfect day. We even had a little tailwind to help get us across the wild stretch of the Daniel Boone National Forrest. Dennis Long from Memphis, TN, tagged along with us for a while on his way home. We landed at Crossville, TN, home of Trade-A-Plane, to refuel. From there it was nonstop to Gantt International Airport, Alabama. Dennis left us near Chattanooga, TN, and James flew another 11 miles south to his home base at Wetumpka Airport, Alabama, 08A. Engine time was 4.3 hours. Actual flight time was 4.1 hours. I burned 50.0 gals of fuel in 10.1 hours and 700.8 miles. We had attendees from as far away as Australia, Jon Gilpin, the VG Man, who pulled his Firefly from California. We had folks from Michigan, Maryland, Virginia, Tennessee, Alabama, and a host of other places, and of course, Kentucky. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 20, 2012
We had attendees from as far away as Australia, Jon Gilpin, the VG Man, who pulled his Firefly from California. We had folks from Michigan, Maryland, Virginia, Tennessee, Alabama, and a host of other places, and of course, Kentucky. john h Folks: We also had a couple from Albuquerque, NM. I am sure there were others, but cannot remember at the moment. The date of the next Kolb Homecoming is the same weekend we used for so many years for the Unplanned/Unorganized Kolb Flyin, Monument Valley, Utah. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 20, 2012
Just speculating, methinks the acetone works as a very thin solvent that facilitates the lubricant working it's way into the rusted joint. So for the Kolb list: MEK? Wouldn't it work like acetone? All us Kolbers probably still have some, and now that the airplane is built, this might be a use for it. Worth a try - but don't get it on the paint. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388399#388399 ________________________________________________________________________________
Date: Nov 21, 2012
Subject: Some Nice Comments...
Dear Listers, I've been getting some very nice comments from Listers along with their List Support Contributions. I've shared a number of them below. Please read them over and see what your fellow Listers think of the Lists and Forums. Please make a Contribution today to support the continued upgrade and operation of these services. There are lots of sweet gifts available this year, so please browse the nice selection and pickup something fun with your qualifying Contribution! You may use a credit card or your PayPal account here: http://www.matronics.com/contribution Or feel free to send a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator -------------------- What Listers Are Saying About The Lists -------------------- I have been flying my Pietenpol for a month now and am enjoying the fruits of ten hard years of work. I seriously doubt it would ever have been finished but for the help, encouragement and friendships I've received and made through the Pietenpol list. Douwe B Outstanding service to the flying community. George A Matt, I look forward to support each others projects, Glenn B Great list!!! Thanks for all your efforts! Roger C Thank you for keeping up the lists. Without it i would never have completed my aircraft. Stan S Keep up the good work my friend. I don't think I could ever finish my Pietenpol Air Camper without the help I get from this List. Tom S Thank you for keeping these list alive. Lee V The List is invaluable!! Svein J Thanks for continuing to provide the list service! Earl S You have a really GREAT service. Thankyou so much I've been on for nearly 30 years and I still check-in every morning. John B I rely fully on the lists which govern my every decision. The flexibility provides the security I seek. Fergus K My RV 7 Finally flies... 7 years of Matronics.com certainly helped. Martin H Great service here, thanks! I am just getting back to a project I dropped for a few years, great to see your site and all the folks again! James C Thanks for the great site. Robert U The Rotax list is good and the AeroElectric list outstanding! Jay H Thank you for a great resource! Jack T Thanks for your great record of outstanding service to the homebuilding community! Larry W This service is invaluable. Michael W You're doing a great job Matt. Robert D Thanks for all your work, its a great asset to all. John F Thank you for your time & effort Matt! Ted W Matt, been a follower since 2005 on the -10 list, now starting an -8. Keep up the great work! John M Still my favorite place to hang out. William W I'm not a Piet builder, but this is the most informative and congenial list I've ever run across. Please forgive my lurking-I learn a LOT here! Ken M Many thanks for keeping this alive, keep pushing! Adrian C Thanks! Please keep r going! Rich Z Many thanks for your hard work. Robert C Thanks for the Lists! I probably need to subscribe to a few more... John M Been a quick 14 years. Think I subscribed to the Kolb List in 1998, when I got my first computer. Thanks for keeping everything running smoothly for all these years. John H Great resource - thank you. David M I don't post very much, but get the postings, a lot of really practical info. John N Great job Matt, thanks for all you do. Roger M Thanks for ANOTHER great year, Matt! True grassroots experimental aviation has been pushed aside in many ways. But the List represents the evolution of this great tradition of home-building. One man, the plans, the tools, and the List - that's all you need to build the dream! Robert B This message board is a real help to my project and creating friendships. John S Many thanks for your continuing excellent work. Mike G Thank you for your work Matt. Your lists have helped me a great deal during the construction of my plane. Hal B Nice List Van E These lists are priceless for builders. Ronald C Thanks for keeping me in touch with the Pulsar community. Otto S Thanks for keeping up this great warbird sight!! Yak Ron Thanks for providing all the lists for so many years. H H Thanks for all that you do. Your dedication is much appreciated! Warren H Best service on the internet! Owen B I have learned so much from the "list". Nick C Great Service You Are Providing! Giffen M Thanks so much for maintaining these great resources. Dave S I no longer fly due to age and health problems, but I still enjoy the reading from other pilots. Dallas S This is a wonderful site. Robert B Useful service over the last year - thanks. Om T -------------------- What Listers Are Saying About The Lists -------------------- ________________________________________________________________________________
Date: Nov 21, 2012
Here are a few pictures added to John's commentary. I took these when arriving on Saturday. Unfortunately my cameras were too cold on Sunday morning to work. Thought I was getting some great video footage and some stills Sunday when departing but the cheap cameras or batteries did not like the cold I guess. I hoped to have some great air to air pictures of John and James, but alas no luck. Fly safe my friends. -------- Dennis Long Oakland TN 2001 Kolb Mark IIIC 160+ hours since March 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388519#388519 Attachments: http://forums.matronics.com//files/100_4436_143.jpg http://forums.matronics.com//files/100_4443_515.jpg http://forums.matronics.com//files/100_4448_757.jpg http://forums.matronics.com//files/100_4447_705.jpg http://forums.matronics.com//files/100_4446_493.jpg http://forums.matronics.com//files/100_4445_850.jpg ________________________________________________________________________________
Date: Nov 21, 2012
Subject: RE: Kolb-List Digest: 3 Msgs - 11/20/12
Thanks to all for the update on the Fly-in at Kolb. I sure wanted to be there but had been scheduled to be in a Spanish Missions conference in a Hispanic church in Winston Salem, NC long before the fly-in was scheduled. Had a wonderful time and love to see these folk (most US citizens) and their precious little children (most speak English). Due to some changes in our ministry I expect (hopefully) to have more time to work on getting the Kolb MKIIIX finished. Maybe by May, 2013 I can fly it to London, KY. I really enjoyed reading John H's report. Would have enjoyed hearing about Jon G's experience too. Did he sell it to someone while at the meeting? Thanks to all of you Kolbers, people at the factory and Mr Homer Kolb for giving much enjoyment. Have a blessed Thanksgiving. Thank God for His unspeakable gift, the Lord Jesus Christ. Bob MKIIIX project, N830PB ________________________________________________________________________________
Date: Nov 22, 2012
Subject: FireFly and Trailer
Gday, I know this forum isn't for advertising, but I do need to pass the news that Edy wasn't able to buy the FireFly and trailer that I have for sale. Both she and Jim have joint problems so that neither can pull the rope starter hard enough. It's a sad turn of events for both of us, cause they have the spirit and wanted to do it, but physical limitations prevent it. I've been spreading the word that it was as good as sold, and putting off others who expressed interest, so now I just need to let them know that it's still available. JG 281 515 6020 ________________________________________________________________________________
Subject: Seafoam and VG's???? Thanks to all!
Date: Nov 21, 2012
Hello to all Kolb flyers and builder, Now that Seafoam and VG's got you attention. I want to thank you all for teaching me a lot about flying and building these great planes! Being perhaps the only Kolber this far north and west, the "list" and all of your contributions to the list, have really taught me a lot about the Kolb I am building. Thank you all, and many thanks to those of you that can contribute $ to Matronics too! A good Thanksgiving to you all! Sincerely, Nick Cassara Palmer, Alaska Kolbra 607AK ________________________________________________________________________________
Date: Nov 21, 2012
John: Put a battery and an electric starter on the Firefly. Much better than a pull start anyhow. Hope you can do this. john I've been spreading the word that it was as good as sold, and putting off others who expressed interest, so now I just need to let them know that it's still available. JG 281 515 6020 ________________________________________________________________________________
Date: Nov 21, 2012
Subject: Re: FireFly and Trailer
Jg How many hours on that engine/airframe? Herb At 11:24 AM 11/21/2012, you wrote: >Gday, > >I know this forum isn't for advertising, but I do need to pass the >news that Edy wasn't able to buy the FireFly and trailer that I have >for sale. Both she and Jim have joint problems so that neither can >pull the rope starter hard enough. It's a sad turn of events for >both of us, cause they have the spirit and wanted to do it, but >physical limitations prevent it. > >I've been spreading the word that it was as good as sold, and >putting off others who expressed interest, so now I just need to let >them know that it's still available. > >JG >281 515 6020 > ________________________________________________________________________________
Date: Nov 22, 2012
Putting a starter and battery on a Firefly would likely take it out of Part 103. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388573#388573 ________________________________________________________________________________
Date: Nov 22, 2012
There's 183 hrs on both engine and airframe. JG Sent from my iPad ________________________________________________________________________________
Date: Nov 22, 2012
> Putting a starter and battery on a Firefly would likely take it out of Part 103. How illeage is an aircraft that is a pound or two above a 103 limit? Who checks it? Has anyone ever been checked? -------- Kolb Mark IIIX 582 Blue head Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388575#388575 ________________________________________________________________________________
Subject: kolb left rudder in cruise
Date: Nov 22, 2012
I have a 1997 kolb firestar II that needs 1 inch of left rudder in cruise. Has any one ever offsetting the front of vertical fin to fix this problem. Older champs have this done when installing larger motors. any words of wisdom out there. My plane has no trim tab on it. Really hate to put the big trim tab in kolb planes on the plane. looks like simple fix for bad rigging or design thanks skidookid -------- roger trombley Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388596#388596 ________________________________________________________________________________
Subject: Re: kolb left rudder in cruise
Date: Nov 22, 2012
You can try that,probably"P" factor giving you the issue.I have seen the of f-set vertical but I'll bet you end up with the trim tab as well. -----Original Message----- From: skidookid <rwtsc(at)hotmail.com> Sent: Thu, Nov 22, 2012 11:46 am Subject: Kolb-List: kolb left rudder in cruise I have a 1997 kolb firestar II that needs 1 inch of left rudder in cruise. Has any one ever offsetting the front of vertical fin to fix this problem. Olde r champs have this done when installing larger motors. any words of wisdom o ut there. My plane has no trim tab on it. Really hate to put the big trim tab in kolb planes on the plane. looks like simple fix for bad rigging or design t hanks skidookid -------- roger trombley Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388596#388596 ________________________________________________________________________________
Date: Nov 22, 2012
skidookid wrote: > I have a 1997 kolb firestar II that needs 1 inch of left rudder in cruise. > = S = N = I = P > Attached is a picture of my FSII trim tabs. These alum ones have since been replaced with Lexan ones. Rudder is slightly smaller than one shown. My nickel's worth. -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388603#388603 Attachments: http://forums.matronics.com//files/tabs_03_medium_214.jpg ________________________________________________________________________________
Date: Nov 22, 2012
here are the trip tabs in lexan. Larry On Thu, Nov 22, 2012 at 10:41 AM, George Alexander wrote: > > > skidookid wrote: > > I have a 1997 kolb firestar II that needs 1 inch of left rudder in > cruise. > > = S = N = I = P > > > > > Attached is a picture of my FSII trim tabs. These alum ones have since > been replaced with Lexan ones. Rudder is slightly smaller than one shown. > > My nickel's worth. > > -------- > George Alexander > FS II R503 N709FS > http://www.oh2fly.net > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=388603#388603 > > > Attachments: > > http://forums.matronics.com//files/tabs_03_medium_214.jpg > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Nov 22, 2012
I have a 1997 kolb firestar II that needs 1 inch of left rudder in cruise. Has any one ever offsetting the front of vertical fin to fix this problem. Older champs have this done when installing larger motors. any words of wisdom out there. My plane has no trim tab on it. Really hate to put the big trim tab in kolb planes on the plane. looks like simple fix for bad rigging or design thanks skidookid -------- roger trombley MKIII had the same problem. Tried offsetting the upper vertical stabilizer, but it was not effective. Best cure was a rudder trim tab. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 22, 2012
Subject: RE: Kolb-List Digest: 6 Msgs - 11/21/12
Nick, any photos of your airstrip and project there in AK? Bob Chattanooga, TN MKIIIX with VW re-drive N830PB ________________________________________________________________________________
Date: Nov 22, 2012
I went to a flyin this year with my firefly. It has brakes and starter the FAA was there no problem. I did take my second 2.5 gallon tank off first :) ________________________________ From: David d. <david(at)PaulowniaTrees.com> Sent: Thu, November 22, 2012 7:52:15 AM Subject: Kolb-List: Re: FireFly and Trailer > Putting a starter and battery on a Firefly would likely take it out of Part >103. How illeage is an aircraft that is a pound or two above a 103 limit? Who checks it? Has anyone ever been checked? -------- Kolb Mark IIIX 582 Blue head Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388575#388575 ________________________________________________________________________________
Date: Nov 23, 2012
Subject: "Black Friday" For List Fund Raiser...?
Dear Listers, The number of List subscriptions are up by a fair amount this year, but support during this year's Fund Raiser is substantially behind last year, and there's only about a week left until the end of the Fund Raiser. I have always preferred a non-commercial List experience as many, many members have also expressed that they do as well. However, if the yearly fund raiser cannot generate sufficient funds to keep the bills paid, other sources of income might be required including some sort of advertising. Please don't let that happen! Your personal Contribution of $20 or $30 goes a long ways to keeping this operation a float. Please make sure your name is on this year's List of Contributors! The List Contribution site is secure, quick, and easy: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 23, 2012
Roger Yes I offset the vertical fin on my MKIIIC it didn't help much if any. I figure it wouldn't hurt so I left it offset when I added the trim tab. This isn't bad design it is just the way airplanes are. I have flown some bigger GA airplanes that have so much P factor that you have to set (required) extra rudder trim for takeoff and readjust for cruise. Our Kolbs need a bit more rudder on takeoff and opposite rudder on approach but with the right trim setting nothing is needed in cruise. The Kolbs good design keeps the rudder effort low enough that with or with out trim tabs the effort minimal. Rick Neilsen Redrive VW Powered MKIIIC On Thu, Nov 22, 2012 at 11:46 AM, skidookid wrote: > > I have a 1997 kolb firestar II that needs 1 inch of left rudder in cruise. > Has any one ever offsetting the front of vertical fin to fix this problem. > Older champs have this done when installing larger motors. any words of > wisdom out there. My plane has no trim tab on it. Really hate to put the > big trim tab in kolb planes on the plane. looks like simple fix for bad > rigging or design thanks skidookid > > -------- > roger trombley > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=388596#388596 > > ________________________________________________________________________________
Date: Nov 24, 2012
Subject: RE: Kolb-List Digest: 1 Msgs - 11/23/12
Thanks Rick N. The info about the offset of the vertical and use of the rudder trim is very helpful. Hope you and all had a great Thanksgiving. Bob G MKIIIX ________________________________________________________________________________
Subject: Mark3 stuff
Date: Nov 24, 2012
Still have the Mark 3 wings, tail, and fuselage if anybody's interested. Kirk -------- Kirk Smith Columbiaville, MI Firestar II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388797#388797 ________________________________________________________________________________
Date: Nov 25, 2012
Subject: Just A Few More Days To Make Your List Contribution...
There is less than a week left in this year's List Fund Raiser and only a few short days to grab one of the great Contribution Gifts available this year. Support is still significantly lagging behind last year at this point but hopefully it will pick up here towards the end. Please remember that it is solely the Contributions of List members that keeps the Lists up and running as there is no commercialism or advertising on the Matronics Lists and Forums. The List Contribution web site is secure, fast, and easy and you can use a credit card, Paypal, or a personal check: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I want to thank everyone that has already made a generous contribution to support the Lists! Thank you! Matt Dralle Matronics EMail List and Forum Administrator ________________________________________________________________________________
Date: Nov 26, 2012
Subject: Contributions Down By 23%...
Dear Listers, As of today, Contributions to the Matronics List Fund Raiser are lagging behind last year at this time by roughly 23%. I have a Fund Raiser each year simply to cover my operating costs for the Lists. I *do not* accept any advertising income to support the Lists and rely solely on the Contributions of members to keep the expenses paid. I run all of my own servers and they are housed here locally, and the Internet connection is a commercial-grade, dual T1 connection with public address space. I also maintain a full backup system that does nightly backups of all List-related data so that in the event of a server crash, all of the Lists and the many years of List archive data could be restored onto a new server in a matter of hours. All of this costs a fair amount of money, not to mention a significant amount of my personal time. I have a Fund Raiser each year to cover these costs and I ask that members that feel they receive a benefit from my investments make a modest Contribution each year to support the continued operation and upgrade of these services. If you enjoy the Lists, please make a Contribution today. I also offer some incentive gifts for larger Contribution levels. At the Contribution Web Site, you can use a credit card, Paypal, or personal check to show your support for the continuation of these services: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2012
Subject: Make Sure You're Listed! List of Contributors Coming in December!
Dear Listers, There's just a couple more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2012
John where is the plane now and would you sell without the trailer? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=389220#389220 ________________________________________________________________________________
Subject: Fire Star II for sale in Sunny Ohio!!!!!
Date: Nov 27, 2012
Hi every body! Been a while since I have been on the forum bc my FSII was down for engine rebuild. While I had the airplane down for engine overhaul A Kit Fox some how made its way into my garage and has captured my heart! As such it has been brought to my attention(by my wife) that I must sell my favorite ever airplane! I have the Firestar listed on Barnstormers and Craig's list. she only has two hours or so since major on the 503. If any body is interested just shoot me an email or call! Ccmfarms(at)aol.com 216-288-4210 Good luck and safe flying! -------- Low and Slow FireStar II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=389222#389222 Attachments: http://forums.matronics.com//files/image_150.jpg ________________________________________________________________________________
Date: Nov 28, 2012
Gday All, The FireFly and trailer is now sold. To Edy and Jim in Florida. I wish them well with it. So now the adventure is over. It was just great! Cheers, JG ________________________________________________________________________________
Date: Nov 28, 2012
Subject: Just 3 Days Left - Please Make Your List Contribution Today!
There are only three days left until the end of this year's List Fund Raiser. Please take a minute to show your support as so many others have this year and make sure YOUR name is on the forthcoming List of Contributors! Its quick and easy using the secure web site with a credit card or PayPal: http://www.matronics.com/contribution or by sending your personal check to: Matronics Lists c/o Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your support of these List services! Matt Dralle Matronics Email and Forum Administrator ________________________________________________________________________________
Date: Nov 28, 2012
Good luck mate. Your an inspiration to use older guys. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=389368#389368 ________________________________________________________________________________
Date: Nov 28, 2012
Subject: 25 year club
this club will be 25 years old next year check out the news letter http://www.michiganultralight.com/newsletter/DEC12/Dec12evers.PDF Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.com/ LSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022 ________________________________________________________________________________
Date: Nov 29, 2012
Subject: Just Two Days Left! - Still Behind...
Dear Listers, There are just two more days left in this years List Fund Raiser. Over the last couple of weeks I have received some more really nice comments from members on what the Lists have meant to them. I have included a few more of them below. Please read over the comments and ponder on your own feelings about the Lists and the support and camaraderie you have found here. We are still behind last year in terms of the number of contributions. I really want to keep providing these services to the homebuilt community, but it take resources. Since there's no advertising budget or deep pockets to keep the operation a float, its solely your generosity during the Fund Raiser that keeps things going. Please make a Contribution today. If you've been putting off showing your support for the Lists, now is the time to do it! Make a contribution with a Credit Card or though PayPal at that Matronics Contribution web site: http://www.matronics.com/contribution Or, drop a check in the mail: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List Administrator ==================== A Few List Member Comments ===================== I have been flying my Pietenpol for a month now and am enjoying the fruits of ten hard years of work. I seriously doubt it would ever have been finished but for the help, encouragement and friendships I've received and made through the Pietenpol list. Douwe B Hey-Long time subscriber, zero-time contributor. Just a note of thanks. This is first time I have the resources to contribute. Thanks for carrying a lightweight for years and a special thanks for your time and effort. Billy R My 601 hd is flying with the help with the listers. Noel G A very useful facility. Graeme B ..great site! Robert C Great Pietenpol site! Don Y Not active but always interested in keeping up. Enjoy when I can. Richard R Dave and Tim from Aircrafters just want to reiterate our thanks for hosting the lists. Tim F. I don't have a lot to give at this time of year, but I hope my contribution helps none the less. I really enjoy the message board. Mark C Thanks to your continued work on maintaining these lists. Ralph C The lists and the various contributors have been a great help while I was building and also now that I'm flying. Albert G Very helpful tools for the homebuilder. Vaughn T We appreciate your great help! Richard H Many of our customers have expressed to us that you provide them with an invaluable service - and we agree! Bill B I Fly a Quicksilver GT400 but love to read what the Kolb boys have to say and it was on your list that I found out about the Yamaha product Ring Free,, now called engine med, that shit works.. no carbon in my rings or any to speak of with the use of the Yamaha product with a premix 503 with over 300 hrs of use.. thanks to your Kolb bulletin board. Robert B You are providing a valuable service that helps a lot of people through information sharing. When I built my Pietenpol over 40 years ago we were largely on our own, working without a resource like this list. Graham H Thanks for the opportunity to link us all, keep the good work! Peter B ________________________________________________________________________________
Date: Nov 30, 2012
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, Its November 30th and that always means a couple of things. Its my birthday again; number 49 actually! But it also means that its that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Tail reinforcement... revisited
Date: Dec 04, 2012
Hello Kolber's, I thought I would take advantage of this quite time on the list to ask about tail reinforcement, to support the tail wheel. From what I read in the archives, it sounds like not everyone thinks reinforcement this is necessary. If you have reinforced your tail to support the tail wheel, could you tell what you have done, and post a picture ( reduce file size) please. Thanks, Nick Cassara Palmer, Alaska 607AK Might be the farthest North, but Henry is much further West! ________________________________________________________________________________
Date: Dec 04, 2012
I thought I would take advantage of this quite time on the list to ask about tail reinforcement, to support the tail wheel. From what I read in the archives, it sounds like not everyone thinks reinforcement this is necessary. If you have reinforced your tail -to support the tail wheel, could you tell what you have done, and post a picture ( reduce file size) please. Thanks, Nick Cassara Hi Nick C/Kolbers: Are you inquiring about tail post braces? or support for the tail wheel? For me, bracing the tail post was a necessity, unless I wanted to continue to make temporary fixes when it broke. It had broken 3 or 4 times over the years. In addition to bracing the tail post, we welded up a 4130 lower vertical stabilizer with a 4130 saddle to attach it to the bottom of the tail boom. Never had a problem in this department. However, I broke the lower vertical stabilizer aluminum leading edge tube on the Factory MKIII many years ago at Oshkosh. Most folks think the tail wires are "tail braces". Tail wires are spacers. They keep the horizontal stabilizer and vertical stabilizer in position only. The only bracing on the tail post is the two welds on the rear tail boom ring that attach it to the bottom tube socket of the upper vertical stabilizer and the top tube socket of the lower vertical stabilizer. The two braces from the ring to the bottom of the tail post lock the tail post to the tail boom ring. I have flown a lot of hours since we made this mod some years ago. No more cracked tail posts. Let me know if I need to clarify anything. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 04, 2012
Subject: Re: Tail reinforcement... revisited
I got away without a brace for about 450 hours. It is simple and easy to do if you do it before it breaks. A little tougher if you wait. :-) Larry On Tue, Dec 4, 2012 at 11:14 AM, Nick Cassara wrote: > Hello Kolber=92s,**** > > ** ** > > I thought I would take advantage of this quite time on the list to ask > about tail reinforcement, to support the tail wheel. From what I read in > the archives, it sounds like not everyone thinks reinforcement this is > necessary.**** > > ** ** > > If you have reinforced your tail to support the tail wheel, could you > tell what you have done, and post a picture ( reduce file size) please. * * > ** > > ** ** > > Thanks,**** > > ** ** > > Nick Cassara**** > > ** ** > > Palmer, Alaska**** > > ** ** > > 607AK**** > > ** ** > > Might be the farthest North, but Henry is much further West!**** > > ** ** > > * > =========== =========== =========== =========== > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Dec 04, 2012
Rebuild the lower tail fin with a heavier steel gusset and thicker wall tubing. Which will support a full swivel locking tail wheel. [Idea] -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=389868#389868 Attachments: http://forums.matronics.com//files/gusset_171.jpg ________________________________________________________________________________
Date: Dec 05, 2012
Rebuild the lower tail fin with a heavier steel gusset and thicker wall tubing. Which will support a full swivel locking tail wheel. Dennis T/Kolbers: The above is ok for a temporary fix. Eventually, the tail post will break again. With larger and heavier repairs on my MKIII, we continued to experience failures until my friend Dan Horton came up with the idea of two external struts which create triangles that laterally brace the tail post. Looks like lateral stress from ground handling is the culprit breaking our tail posts. Struts can be fabricated using 4130 or aluminum strap or tubing, and attached with 3/16 bolts. No need for welding which creates a need for paint and fabric repair. Has anyone had a tail post failure after installing external struts? john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 05, 2012
I added 1/8 by 1 inch aluminum straps one on each side (like John suggested) to better control the tail wheel stress on my VW powered MKIIIC. I'm a big believer of learning from others. I figured the two straps one acting in tension in each direction would be enough to strengthen the tail post. I have about 400 hours on the fix with no issues. I also have been criticized a few times about abusing the tail with aggressive ground handling on rough ground. Rick Neilsen Redrive VW Powered MKIIIC On Wed, Dec 5, 2012 at 9:12 AM, John Hauck wrote: > > > Rebuild the lower tail fin with a heavier steel gusset and thicker wall > tubing. Which will support a full swivel locking tail wheel. > > > Dennis T/Kolbers: > > The above is ok for a temporary fix. Eventually, the tail post will break > again. With larger and heavier repairs on my MKIII, we continued to > experience failures until my friend Dan Horton came up with the idea of two > external struts which create triangles that laterally brace the tail post. > Looks like lateral stress from ground handling is the culprit breaking our > tail posts. > > Struts can be fabricated using 4130 or aluminum strap or tubing, and > attached with 3/16 bolts. No need for welding which creates a need for > paint and fabric repair. > > Has anyone had a tail post failure after installing external struts? > > john h > mkIII > Titus, Alabama > > ________________________________________________________________________________
Subject: Tail up grades...
Date: Dec 05, 2012
Hello John, Thanks for figuring out what I was trying to ask the "List." I think I understand most of what you described, but where did you mount the "saddle" on the boom. Was the Saddle haft the circumference on the boom tube, and riveted to the boom? What material did you use, " In addition to bracing the tail post" for this bracing? Thank you very much, Nick Cassara Palmer, AK 607AK ________________________________________________________________________________
Date: Dec 05, 2012
where did you mount the =93saddle=94 on the boom. -Was the Saddle haft the circumference on the boom tube, and riveted to the boom? - What material did you use, =93 In addition to bracing the tail post=94 for this bracing? Nick Cassara Nick C/Kolbers: I included the two previous photos of my lower vertical stabilizer and tail post braces. At the forward end of the lower vertical stabilizer the 4130 saddle is visible. We fabricated the lower vertical stabilizer on my MKIII from 4130 because we knew this was a high stress area during ground handling/taxi. The saddle was cut out of a section of 4130 tail boom ring, welded to the forward end of the lower vertical stabilizer and pop riveted to the bottom of the tail boom. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 05, 2012
Subject: Re: Tail up grades...
I did it a little differently from John. I am sure that he and Jim did it right, I modified an existing screw up and just drilled through the ring at the back of the tube. The ring is under no stress, and a new hole in it isn't going to hurt a thing, so I could find no reason to make it any more complicated than necessary. I used some alum tubing for the brace. Just be sure you don't split it when you flatten the ends. Your options are open and do as you think right. Larry On Wed, Dec 5, 2012 at 3:03 PM, Nick Cassara wrote: > Hello John,**** > > ** ** > > Thanks for figuring out what I was trying to ask the =93List.=94 I think I > understand most of what you described, but where did you mount the =93sad dle=94 > on the boom. Was the Saddle haft the circumference on the boom tube, and > riveted to the boom? **** > > What material did you use, =93 In addition to bracing the tail post=94 fo r > this bracing?**** > > ** ** > > Thank you very much,**** > > ** ** > > Nick Cassara**** > > ** ** > > Palmer, AK**** > > ** ** > > 607AK**** > > * > =========== =========== =========== =========== > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
From: "Andy and Sheila Slinkard" <andysheila(at)eltopia.com>
Subject: Nose cone access
Date: Dec 06, 2012
Kolbers, tired of standing on your head to access the back of your instrument panel, especially if you have a battery mounted in the cone? This is my solution: Make five fiberglass layups on the inside of the cone where the cutout will be. Draw the desired cutout on outside of cone and use a small Drammel tool to carefully cut the desired opening. Use clear packing tape as a release agent on the inside of the cutout. Tape the cutout back in the hole on the outside. Make five more fiberglass layups on the inside. Remove the cutout and trim the five layers of glass for a flange where all metal floating anchor nuts ( Aircraft Spruce part # MS21059L06) will be riveted to accept and secure the cutout to the cone with #6-32 counter sunk screws. See pictures for reference. Have a good day, Andy N687AS Nose cone access 2 Nose cone access1 Nose cone access3 Nose cone access4 ________________________________________________________________________________
Date: Dec 07, 2012
Here is what we did on Ed's Firestar II, just a length of 1/8" aluminum flat stock on each side. Drilled one new hole on each side of the steel ring, and used the existing bolt that secures the tailwheel strut. I will be doing the same on my MKIII this winter. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390019#390019 Attachments: http://forums.matronics.com//files/p1020227_large_981.jpg ________________________________________________________________________________
Subject: Re: Nose cone access
Date: Dec 07, 2012
I'm not all the familiar with the nose of Kolbs as I don't have one yet, but wouldn't it be better to put the instrument panel on a hinge? Other than th at I like the idea, Sent from my iPad Brad On Dec 6, 2012, at 19:45, "Andy and Sheila Slinkard" wrote: > Kolbers, tired of standing on your head to access the back of your instrum ent panel, especially if you have a battery mounted in the cone? This is my solution: Make five fiberglass layups on the inside of the cone where the c utout will be. Draw the desired cutout on outside of cone and use a small D rammel tool to carefully cut the desired opening. Use clear packing tape as a release agent on the inside of the cutout. Tape the cutout back in the h ole on the outside. Make five more fiberglass layups on the inside. Remove the cutout and trim the five layers of glass for a flange where all metal f loating anchor nuts ( Aircraft Spruce part # MS21059L06) will be riveted to a ccept and secure the cutout to the cone with #6-32 counter sunk screws. See pictures for reference. > Have a good day, > Andy > N687AS > > ________________________________________________________________________________
Date: Dec 07, 2012
Brad, As you said, you don't have one yet. There's more to this than just getting at the instruments. There are pedal hinges to be oiled, pitot and static lines to inspect. If you have hydraulic brakes you'll be wanting to service the master cylinders and cables stretch on mechanical brakes. It is VERY handy to have access to the forward end of the nose cone without going in through the cockpit and a whole lot easier on your back. I used the same basic idea as Andy's on my Mk IIIC except I made the flange from aluminum and riveted it on. As I recall, John Hauck put his access hole on the bottom of the nose cone for the same reason. On Ken Holle's Mk IIIX I took out the rivets and used screws to attach the entire nose cone so the whole thing comes off. I could get at everything while sitting on a roll around shop stool. Again, very handy for those maintenance items that have to be attended to during every annual conditional inspection. Rick Girard On Fri, Dec 7, 2012 at 5:58 PM, Brad Nation wrote: > I'm not all the familiar with the nose of Kolbs as I don't have one yet, > but wouldn't it be better to put the instrument panel on a hinge? Other > than that I like the idea, > > Sent from my iPad > > Brad > > On Dec 6, 2012, at 19:45, "Andy and Sheila Slinkard" < > andysheila(at)eltopia.com> wrote: > > Kolbers, tired of standing on your head to access the back of your > instrument panel, especially if you have a battery mounted in the cone? > This is my solution: Make five fiberglass layups on the inside of the cone > where the cutout will be. Draw the desired cutout on outside of cone and > use a small Drammel tool to carefully cut the desired opening. Use clear > packing tape as a release agent on the inside of the cutout. Tape the > cutout back in the hole on the outside. Make five more fiberglass layups > on the inside. Remove the cutout and trim the five layers of glass for a > flange where all metal floating anchor nuts ( Aircraft Spruce part # > MS21059L06) will be riveted to accept and secure the cutout to the cone > with #6-32 counter sunk screws. See pictures for reference. > Have a good day, > Andy > N687AS > > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Dec 10, 2012
Subject: 2012 List of Contributors
Dear Listers, The 2012 Matronics Email List and Forum Fund Raiser officially ended about a week ago and its time that I publish this year's List of Contributors. It is the people on this list that directly make the Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Bob, Jon, and Andy for their generous support through the supply of great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Bob Nucklolls - AeroElectric - http://www.aeroelectric.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com And finally, I'm proud to present The 2012 Fund Raiser List of Contributors: http://www.matronics.com/loc/2012.html Thanks again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Dec 10, 2012
For pilots who like that.... [add-on look]..... How about this short field landing tail-hook device. [Wink] -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390276#390276 Attachments: http://forums.matronics.com//files/short_field_landings_172.jpg ________________________________________________________________________________
Date: Dec 12, 2012
Subject: 912 uls oil & cht temps?
Hi All, Does any one out there know what the MAX oil temp and the MAX cht are for a 912 uls ? My books are 1998 Don't know if anything changed since then. Frank Goodnight ________________________________________________________________________________
Date: Dec 12, 2012
Frank G/Kolbers: Try this one for an operators manual. It is for 912U and 912ULS: http://www.flyrotax.com/portaldata/5/dokus/d05487.pdf Did a Google search for "912uls operators manual" to pull this one up. Couldn't get to it going through Kodiak. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: spar tubing
Date: Dec 12, 2012
hi, where can I get the spar tubing? Thanks, Charlie Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390344#390344 ________________________________________________________________________________
Date: Dec 12, 2012
where can I get the spar tubing? Thanks, Charlie Best bet would be: Kolb Aircraft Company 8375 Russell Dyche Hwy. London, KY 40741 Phone (606) 862-9692 john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 12, 2012
Subject: aventura sold
a local Travis, Travis told me on the phone yesterday he is looking forward to Sebring to show off the adventurer. as you may not know Bob had owned the rites to many designs. Keuthan aircraft, barracuda, peruses, kappa, Zephyr, and a couple moor. Bob had the tooling and fiberglass forms to all the designs he owned. I felt for what Bob had to offer the price was quite reasonable, Travis comes from a aviation background and is excited about the new company their are several moor Ultralight designs that for now have been given another chance to survive. Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.com/ LSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022 ________________________________________________________________________________
Subject: KOLB in New Mexico?
Date: Dec 13, 2012
Hello group. I am a Sport Pilot flying a Powered Parachute in Roswell, NM. I am researching aircraft and really like the KOLB. Seems better than a Quicksilver and less cost than a Kitfox. Also seems easier to fit in a trailer. Maybe a pilot out there who wants to trade a flight in my PPC for a flight in their KOLB? Any CFI in the area who wants to give me a lesson in their KOLB? I have a 1000 foot dirt strip to fly from and welcome anyone to come land at my place. Thanks and hopefully I will join the KOLB following one day. Wesley -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390421#390421 ________________________________________________________________________________
Date: Dec 13, 2012
I have a 1000 foot dirt strip to fly from and welcome anyone to come land at my place. Thanks and hopefully I will join the KOLB following one day. Wesley Hi Wesley/Kolbers: Thanks for the invite. Been building and flying Kolbs for nearly 29 years. Was an Army Aviator prior to getting involved in Kolbs. No comparison between a Kolb and Quicksilvers/Kit Foxes. Hope you can find someone to help you with a Kolb flight. john h mkIII Titus, Alabama ________________________________________________________________________________
From: "Steve Simmons" <stevesimmons(at)charter.net>
Date: Dec 13, 2012
Hi Wesley; If you are interested in a Kolb I have a mark III Classic for sale reasonable. See attached PDF. Steve Simmons 423 748 4336 -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of alienwes Sent: Thursday, December 13, 2012 8:36 PM Subject: Kolb-List: KOLB in New Mexico? Hello group. I am a Sport Pilot flying a Powered Parachute in Roswell, NM. I am researching aircraft and really like the KOLB. Seems better than a Quicksilver and less cost than a Kitfox. Also seems easier to fit in a trailer. Maybe a pilot out there who wants to trade a flight in my PPC for a flight in their KOLB? Any CFI in the area who wants to give me a lesson in their KOLB? I have a 1000 foot dirt strip to fly from and welcome anyone to come land at my place. Thanks and hopefully I will join the KOLB following one day. Wesley -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390421#390421 ________________________________________________________________________________
Subject: RE: Kolb-List Digest: 4 Msgs - 12/13/12
Date: Dec 14, 2012
John B/Kolbers: Follow this link, find "subscribe/unsubscribe" and follow the directions. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 14, 2012
Forgot the url. http://www.matronics.com/Navigator/?Kolb-List ________________________________________________________________________________
Subject: Re: KOLB in New Mexico?
Date: Dec 14, 2012
That sure looks like an Extra. Sent from my iPad Brad On Dec 13, 2012, at 21:32, "Steve Simmons" wrote: > Hi Wesley; If you are interested in a Kolb I have a mark III Classic for > sale reasonable. See attached PDF. Steve Simmons 423 748 4336 > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of alienwes > Sent: Thursday, December 13, 2012 8:36 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: KOLB in New Mexico? > > > Hello group. I am a Sport Pilot flying a Powered Parachute in Roswell, NM. I > am researching aircraft and really like the KOLB. Seems better than a > Quicksilver and less cost than a Kitfox. Also seems easier to fit in a > trailer. Maybe a pilot out there who wants to trade a flight in my PPC for a > flight in their KOLB? Any CFI in the area who wants to give me a lesson in > their KOLB? I have a 1000 foot dirt strip to fly from and welcome anyone to > come land at my place. Thanks and hopefully I will join the KOLB following > one day. > > Wesley > > -------- > Wesley Elliott > Sport Pilot-PPC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390421#390421 > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 15, 2012
Thank you, it is just the photographic angle. I can assure you it is a classic SN 1163 -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Brad Nation Sent: Saturday, December 15, 2012 12:45 AM Subject: Re: Kolb-List: KOLB in New Mexico? That sure looks like an Extra. Sent from my iPad Brad On Dec 13, 2012, at 21:32, "Steve Simmons" wrote: > Hi Wesley; If you are interested in a Kolb I have a mark III Classic > for sale reasonable. See attached PDF. Steve Simmons 423 748 4336 > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of alienwes > Sent: Thursday, December 13, 2012 8:36 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: KOLB in New Mexico? > > > Hello group. I am a Sport Pilot flying a Powered Parachute in Roswell, > NM. I am researching aircraft and really like the KOLB. Seems better > than a Quicksilver and less cost than a Kitfox. Also seems easier to > fit in a trailer. Maybe a pilot out there who wants to trade a flight > in my PPC for a flight in their KOLB? Any CFI in the area who wants to > give me a lesson in their KOLB? I have a 1000 foot dirt strip to fly > from and welcome anyone to come land at my place. Thanks and hopefully > I will join the KOLB following one day. > > Wesley > > -------- > Wesley Elliott > Sport Pilot-PPC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390421#390421 > > > > > > > > > > > ________________________________________________________________________________
Subject: 912 ULS trying to overheat
Date: Dec 16, 2012
He thinks there was an air bubble in the water sys. Any one with thoughts , knowledge , or advice please respond. Thanks Frank Goodnight Frank G/Kolbers: Have no experience with enclosed 912's, so cannot help you there. My experience has been that the cooling system has to be bled and topped off until all the air is out of the cooling system. This probably means that you will have to raise the tail, or put the airframe and engine in whatever attitude it will require to bleed the air. In addition, you will need to insure the coolant recovery system is sealed and operating as required. If after doing the above, you can further lower temps by reducing the ratio of water to antifreeze. More antifreeze reduces cooling capacity. Less antifreeze increases cooling capacity. I usually operate with enough antifreeze to insure I am covered down to about 0F. Have you checked with Zenith to help solve your problem? john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: CFI with KOLB?
Date: Dec 16, 2012
I think the best way to learn if I want a KOLB is to find a CFI who trains in one. Does anyone know of a CFI with a KOLB? Also, any recommendations on who is the best for learning to fly a KOLB? I live in New Mexico and would appreciate any leads. I am a current Sport Pilot with Powered Parachute endorsement. Wesley Elliott -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390556#390556 ________________________________________________________________________________
Date: Dec 17, 2012
Subject: Re: CFI with KOLB?
For a CFI to train you in an ELSA Kolb that he owns (there are no SLSA Kolbs) will require him to get what is known as a Letter of Deviation Authority from the FAA. LODA's are granted for transition training, not primary flight training, so you might as well take the training for an airplane SP ticket from whomever is available in your area, then make arrangements to get the specific transition training afterward. Rick Girard On Sun, Dec 16, 2012 at 4:00 PM, alienwes wrote: > > I think the best way to learn if I want a KOLB is to find a CFI who trains > in one. Does anyone know of a CFI with a KOLB? Also, any recommendations on > who is the best for learning to fly a KOLB? I live in New Mexico and would > appreciate any leads. > > I am a current Sport Pilot with Powered Parachute endorsement. > > Wesley Elliott > > -------- > Wesley Elliott > Sport Pilot-PPC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390556#390556 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Dec 17, 2012
At 11:00 AM 12/17/2012, Richard Girard wrote: >For a CFI to train you in an ELSA Kolb that he owns (there are no SLSA >Kolbs) will require him to get what is known as a Letter of Deviation >Authority from the FAA. LODA's are granted for transition training, not >primary flight training... Actually, a LODA can now be issued for primary training in an "ultralight like" experimental, be it ELSA or E-AB. The hours don't count toward any certificate. I don't know how many, if any, have actually been issued, though. -Dana -- The only correct outcome to an armed robbery attempt is a dead armed robber. ________________________________________________________________________________
Date: Dec 17, 2012
ther is another way to get the experence you need =0AI sponsor a "fly for f un club". I was a BFI in the later days of Ultralight flying before Light s port was created. I now have an EAB and provide people with the experience of flying - for ultralights and some transition experience through my club, "Malcolm's fly for fun club". When a person joins my club, they read the m ission statement for the club and sign a waiver, after that they are a memb er for life. The dues they pay are directly related to the activty they par ticipate in. Because I am not a CFI their experience is not applicable to a ny rating. I follow the ASC BFI training syllabus and really enjoy doing it . I also go to fly-ins and give discovery flights; we really have a good ti me. =0AThe FAA has published some information on flying clubs, the EAA has also. I have talked to the EAA about this topic several times and feel I h ave a good handle on the concept and process. Some industry leaders have to ld me that the Club thing is probably the only thing that ultralights have left as far as training goes. =0AMy original concept was to have a nationa l organization dedicated to the idea of creating flying clubs; charging peo ple to join as a BFI, having requirements and offering benefits like the EA A, ASC and USUA once did. But, I have decided to take a different approach. Now I would like to post the guidelines and concepts for free on all the user groups. Kind of like a real grass roots flying club. It would be nice if people used the "fly for fun club" phrase in the name of their club, as this would lead to a recognition of the legitimacy of the program. It can be as complicated as the sponsor wants it to be; using a corporation, findi ng insurance, becoming a CFI or whatever the individual wants to do with it .=0AI decided not to become a CFI because in Michigan, if I fly 50 hrs a ye ar and charge the going rate for instruction, at $70/hr It would be hard to gross $3,500 a year and most 2 seat airplane operators know that would nev er come close to making a profit in this industry.=0AA club sponsor, the ow ner of the plane, would be responsible for promoting the club concept to ev eryone he flies with and would need to be vigilant when conducting club act ivities, as much as any other "professional" in the aviation industry . =0A The "Club thing" is not just a loop hole schemed up to raise havoc and chao s in the flying community . It's not for everyone. I know if a guy does not like the idea I'll never convince him; and I don't want to waste my time trying. However, the skeptics have helped me develop the concept. =0ASince the FAA has no requirement that a club be formed with a written contract,a corporation,or insured, once the concept is fully understood by the club s ponsor and the club member, an informal understanding between these 2 peopl e is all that is required for participation; and the flying club is up and running. =0AThis sounds simple, and it is. There are those who choose to i nsist that such simple things do not exist, such as "ultralights". But, ot hers of us realize that they do, and it is up to us to utilize them while w e still can. =0AAn "Ultralight" story by Malcolm Brubaker =0AOne day Bigf oot was down at the lake when the local Mermaid appeared. "It's been a whil e since I've seen you, Big Guy!" she said. "What have you been up to?". "Le arning to fly" was Bigfoot's response. =0A"I don't see any wings on your ba ck, Angel..." =0A"Of course not, I built an Ultralight aircraft!"=0A"What! Everyone knows there is no such thing as an "Ultralight."=0A"Sure there is. Wait here, I will show you."=0ABigfoot took off down the path. As he round ed a curve he saw Tinkerbell; she was hovering over what appeared to be a h uman, furiously beating her wings and apparently talking to herself. Bigfoo t thought, "what's that nutty blond doing now?" As he approached he could m ake out her words... "I DO believe in Ultralights, I DO, I DO..." over and over again.=0A"Tinkerbell, What are you doing! What happened to the human?" exclaimed Bigfoot.=0ATinkerbell responded, somewhat breathlessly, "Don't y ou know? Everytime someone says "There is no such thing as Ultralights", so mewhere, another pilot dies!"=0AMalcolm & Jeanne Brubaker =0AMichigan Sport Pilot Repair =0Ahttp://michigansportpilotrepair.com/=0ALSRM-A, PPC, WS=0AG reat Sails - Sailmaker =0Afor Ultralight & Light Sport=0A(989)513-3022 =0A =0AMalcolm & Jeanne Brubaker =0AMichigan Sport Pilot Repair =0Ahttp://mich igansportpilotrepair.com/ =0ALSRM-A, PPC, WS=0AGreat Sails - Sailmaker =0Af or Ultralight & Light Sport=0A(989)513-3022 =0A- =0A=0A=0A=0A =0A=0A_____ ___________________________=0A From: Dana Hague <d-m-hague(at)comcast.net>=0AT o: kolb-list(at)matronics.com =0ASent: Monday, December 17, 2012 12:55 PM=0ASu bject: Re: Kolb-List: CFI with KOLB?=0A =0A=0AAt 11:00 AM 12/17/2012, Rich ard Girard wrote:=0A=0AFor a CFI to train you in an ELSA=0AKolb that he own s (there are no SLSA Kolbs) will require him to get what=0Ais known as a Le tter of Deviation Authority from the FAA. LODA's are=0Agranted for transiti on training, not primary flight=0Atraining...=0AActually, a LODA can now be issued for primary training in an=0A"ultralight like" experimental, be it ELSA or E-AB.- The=0Ahours don't count toward any certificate.- I don't know how many, if=0Aany, have actually been issued, though.=0A=0A-Dana=0A =0A-- =0AThe only correct outcome to an armed robbery attempt is a dead arm ==================== ________________________________________________________________________________
Date: Dec 18, 2012
Subject: firefly for sale
our EAA has a firefly project for sale it is -a tottly factory built kit =0Athat was on display at sun fun it has been covered and needs silver and paint=0Ait comes complete with new in box 447,prop and instruments,- plea se contact me off list- mal=0A=0AMalcolm & Jeanne Brubaker =0AMichigan Sp ort Pilot Repair =0Ahttp://michigansportpilotrepair.com/ =0ALSRM-A, PPC, W S=0AGreat Sails - Sailmaker =0Afor Ultralight & Light Sport=0A(989)513-3022 ________________________________________________________________________________
Subject: Hours on Airframe and Fabric
Date: Dec 18, 2012
Hi Forum, Was wondering how high of hours can a Mark III have on the airframe with normal stresses? How long is the fabric on the wing good for if it is kept in a trailer and only exposed to light when flown? Sorry for the silly questions, Wesley -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390668#390668 ________________________________________________________________________________
Date: Dec 18, 2012
Was wondering how high of hours can a Mark III have on the airframe with normal stresses? How long is the fabric on the wing good for if it is kept in a trailer and only exposed to light when flown? Wesley Wes/Kolbers: I don't know how many hours one could put on a MKIII airframe under normal stress before retirement or failure. At this time I have 3,197.7 hours on my MKIII fuselage over a period of nearly 21 years. I don't think the fuselage is anywhere near the end of its serviceable lifetime. I have original fabric on all of my MKIII except the left wing, aileron, and flap. Which was recovered in 2000, after an accident. The upper and lower vertical stabilizer were recovered 6 or 8 years ago, I think. The original fabric still test good. I keep my MKIII in a T hanger with open front that faces east. Can't remember now how many coats of Polyspray was used, but enough to prevent any light from penetrating through using a 100 watt light bulb. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 19, 2012
Subject: Jabiru TBI
From: Colin Hudson <colin.scott.hudson(at)gmail.com>
In an effort to curb carb heat problems with the Bing carburetor I've purchased a Rotec TBI injector for my 2200 Jabiru. Before I try to work out all the cable and air filter problems, I was wondering if anyone has installed this TBI on their Jabiru? Pictures would really help and a pusher configuration would be even better as my Jabiru is installed on a Kolb Mark III X-tra. Thanks - Colin Hudson Belton TX ________________________________________________________________________________
Subject: Question about Airframe lifespan...inspection ports?
Date: Dec 19, 2012
Hello Kolbers, Your question is not "silly" Wesley! The great thing about the Kolb list is that there are no "silly" questions; everyone on the list has a different background and bring a variety of experiences to the list. So ask away! Two days ago, the North American distributor of Oratex fabric asked me what I was planning on coating my wings frames with before covering them? My memory is that almost no one treats the aluminum with anything. I do have a recollection of the story of Kolb once coated a frame with Zinc chromate for a fellow who lived on the salt water of Chesapeake bay and intended to operate on floats. My question for the list how many inspection ports do folks put in their wings? Thanks, Nick Cassara Palmer, AK 607AK ________________________________________________________________________________
Date: Dec 19, 2012
My question for the list how many inspection ports do folks put in their wings? Thanks, Nick Cassara Nick/Kolbers: I use epoxy chromate primer on all the 4130 parts and fuselage. Nothing on the aluminum unless I am going to finish paint, then apply epoxy chromate primer. Put as many inspection rings on your wings, or any other place for that matter, that you think you will "ever" need in the future. All you have to do is process the inspection rings during covering and painting. If and when you ever need to get inside, simply cut out the inside of the ring, then place the pre-painted inspection covers on them. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 19, 2012
Brother Cassara: Not sure what the majority of folks do, but I put one ring on each side of the spar at the strut attachment fitting, and one at the root to look at the drag strut attachment to the wing butt rib. I open and use all three at each annual. No reason I can see that a man could not put more on the wing if desired. Guess it depends on how pessimistic one wants to be. Worth what ye paid fer it. Beauford FF-076 N173BW Brandon, FL From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Nick Cassara Subject: Kolb-List: Question about Airframe lifespan...inspection ports? My question for the list how many inspection ports do folks put in their wings? Thanks, Nick Cassara Palmer, AK 607AK ________________________________________________________________________________
Date: Dec 19, 2012
Subject: Re: Question about Airframe lifespan...inspection ports?
If you are planning on using the Poly Fiber series of chemicals, zinc chromate and any other one part primer will NOT work. The solvents in the Poly Fiber will eat through it and the bond of the fabric to the air frame weakened. The only approved primer is two part epoxy and if you use any other brand than Poly Fiber you should check with a factory rep to find out if it will withstand MEK. I used Tran Star epoxy primer sold by O'Reilly's Auto Parts. Rick Girard On Wed, Dec 19, 2012 at 7:33 PM, Beauford wrot e: > Brother Cassara:**** > > ** ** > > Not sure what the majority of folks do, but I put one ring on each side o f > the spar at the strut attachment fitting, and one**** > > at the root to look at the drag strut attachment to the wing butt rib. I > open and use all three at each annual.**** > > ** ** > > No reason I can see that a man could not put more on the wing if desired. > Guess it depends on how pessimistic one**** > > wants to be.**** > > ** ** > > Worth what ye paid fer it=85**** > > ** ** > > Beauford**** > > FF-076 **** > > N173BW**** > > Brandon, FL**** > > ** ** > > *From:* owner-kolb-list-server(at)matronics.com [mailto: > owner-kolb-list-server(at)matronics.com] *On Behalf Of *Nick Cassara > *Subject:* Kolb-List: Question about Airframe lifespan...inspection ports ? > **** > > ** ** > > My question for the list how many inspection ports do folks put in their > wings?**** > > ** ** > > Thanks,**** > > ** ** > > Nick Cassara**** > > Palmer, AK**** > > ** ** > > 607AK**** > > * * > > * > =========== =========== =========== =========== > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Dec 19, 2012
I don't have a Kolb yet, so I don't quite understand how an inspection ring w orks. A picture is worth a thousand words. Sent from my iPad Brad On Dec 19, 2012, at 13:09, "John Hauck" wrote: > > My question for the list how many inspection ports do folks put in their w ings? > > Thanks, > > Nick Cassara > > > > Nick/Kolbers: > > I use epoxy chromate primer on all the 4130 parts and fuselage. Nothing o n the aluminum unless I am going to finish paint, then apply epoxy chromate p rimer. > > Put as many inspection rings on your wings, or any other place for that ma tter, that you think you will "ever" need in the future. All you have to do is process the inspection rings during covering and painting. If and when y ou ever need to get inside, simply cut out the inside of the ring, then plac e the pre-painted inspection covers on them. > > john h > mkIII > Titus, Alabama > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Dec 19, 2012
I don't have a Kolb yet, so I don't quite understand how an inspection ring works. A picture is worth a thousand words. Brad Brad/Kolbers: The ring is a plastic reinforcement for the inspection hole covers. Keeps from tearing the fabric. Gives the cover springs something to hold on to keep them in place\. Here's a bunch of questions and answers about inspection rings: http://www.polyfiber.com/techquestions/inspectionrings/index.htm Google this, "fabric aircraft inspection rings" and hit IMAGES. You'll get a lot of photos of rings and how they are used. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Any Kolbers in Titusville, FL?
Date: Dec 20, 2012
I am thinking about relocating to the Space Coast of Florida. Are there any Kolb listers at Arthur Dunn Apt (X21?). It has a nice grass strip as well as a paved runway, and AirNav lists 20 "Ultralights." Dave Watkins Mk3 Classic Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390733#390733 ________________________________________________________________________________
Subject: Retrofitting inspection rings
Date: Dec 20, 2012
When I built my FSII, the plans didn`t call for inspection rings. Can they be retrofitted on fabric that has already been shrunk and painted? I still have fabric and paint. So all I would need is Poly-brush and the rings, correct? N598LF ________________________________________________________________________________
Subject: Re: Retrofitting inspection rings
Date: Dec 20, 2012
I spoke to a local pilot last week that has the same problem with his restored super cub. He was telling me about a product ( glue) that can be applied to the ring, the ring can then be positioned, removed and repositioned if needed right over the existing paint. I believe he said that heat activates the glue and the ring is permanently adhered. I will monitor the list and if no one has the name of the product I will contact him and get it for you. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390738#390738 ________________________________________________________________________________
Date: Dec 20, 2012
Thanks Ducati, I would appreciate that information. -----Original Message----- From: Ducati SS Sent: Thursday, December 20, 2012 8:49 AM Subject: Kolb-List: Re: Retrofitting inspection rings I spoke to a local pilot last week that has the same problem with his restored super cub. He was telling me about a product ( glue) that can be applied to the ring, the ring can then be positioned, removed and repositioned if needed right over the existing paint. I believe he said that heat activates the glue and the ring is permanently adhered. I will monitor the list and if no one has the name of the product I will contact him and get it for you. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390738#390738 ________________________________________________________________________________
Subject: Re: Jabiru TBI
Date: Dec 20, 2012
Colin, What are your "heat problems" with the Jab running the Bing 94? I have no experience with the TBI but have a good bit of experience with a Jabiru 2200 on a Kolb Slingshot. Perhaps I , or one of the other experienced Jabiru/Kolbers, can help. If you are determined to change to TBI, I suggest you ask your question on the Jabiru Engines Forum on Yahoo Groups website. In any case, they will want to know what you mean specifically by "heat problems". There are several on that list who have changed to TBI or AeroCarb, some with success, some not so much. Most of them (tractor configurations) did it to have manual control over mixture. If that is your desire, installing a HACman on the Bing will accomplish that, or even making your own is a fairly simple process. That said, I was able to get the EGTs with the Bing exactly where they should be at cruise and full power climb by installing Jabiru's economy tuning kit. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 no engine FOR SALE Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390740#390740 ________________________________________________________________________________
Date: Dec 20, 2012
On Behalf Of Lanny Fetterman When I built my FSII, the plans didn`t call for inspection rings. Can they be retrofitted on fabric that has already been shrunk and painted? I still have fabric and paint. So all I would need is Poly-brush and the rings, correct? N598LF Lanny/Kolbers: Retrofit inspection rings like you would apply a patch to the fabric. 1-Prep the area (clean and scuff). 2-Polytak the inspection ring to the fabric. 3-Cut out a round patch about the size of a No. 10/gallon coffee can. 4-Polybrush the patch over inspection ring. 5-Polyspray, if you want to, and paint. You don't have to cut out the hole in the inspection ring until you need to gain access for inspection. I would not try to glue the inspection ring to the fabric. It probably will not get the job done. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 20, 2012
Lanny, It depends upon the result you want. For results that will make it look like you put them there when you did your original cover you'll want to use MEK and remove all the coats down to bare fabric in the area where you want to put the inspection rings and install them per the manual. Treat them as you would a patch and install them with a 50/50 mix of MEK thinned Poly Tack, not Poly Brush. The next best method is to install over the current coatings, again using a thinned Poly Tack. Once you have the rings on and the cover fabric glued down use a Tape Down sheet, a product my company sells that allows you to use a sealing iron to melt the coatings and drive the edge of the fabric down into the existing Poly Tone for a perfect seamless installation. Tape Down is a high temperature fabric that allows the heat of the iron to pass through it without allowing the heat softened coatings to stick to the iron. Guaranteed to work or your money back. $12 for a 6 inch square sheet that lasts a life time. I sealed over 200 feet of tape edge on Ken Holle's Mk IIIX with a single sheet of Tape Down and it's still like new. It saves all the work, money and mess of removing coatings and pays for itself the first time you use it. The least perfect method is to just glue new fabric on and coat with Poly Brush, Poly Spray and Poly Tone to match the color with the original coatings. The fabric edges will stick up and it will look like what it is a scabbed on patch. It will be functional but ugly. Contact me off list to buy Tape Down. Rick Girard On Thu, Dec 20, 2012 at 7:28 AM, Lanny Fetterman wrote: > When I built my FSII, the plans didn`t call for inspection rings. Can > they be retrofitted on fabric that has already been shrunk and painted? I > still have fabric and paint. So all I would need is Poly-brush and the > rings, correct? N598LF > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: RE: Kolb-List Digest: 7 Msgs - 12/19/12
Date: Dec 20, 2012
> there are no "silly" questions; So ask away! If psychiatry is the answer, what is the question? :-) ________________________________________________________________________________
Date: Dec 20, 2012
Use polytak glue Ellery Batchelder Jr. -----Original Message----- From: hiwingflyer6219(at)yahoo.com Sent: Thu, Dec 20, 2012 3:50 am Subject: Kolb-List: Re: Retrofitting inspection rings I spoke to a local pilot last week that has the same problem with his resto red super cub. He was telling me about a product ( glue) that can be applied to the ring, the ring can then be positioned, removed and repositioned if needed r ight over the existing paint. I believe he said that heat activates the glue and the ring is permanently adhered. I will monitor the list and if no one has the name of the product I will contact him and get it for you. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390738#390738 ________________________________________________________________________________
Date: Dec 20, 2012
Let me preface this by saying I haven't done it this way myself yet, but I really trust the guy who gave me the information. He's a Reno racer who's built or rebuilt more than a dozen fabric airplanes. He say's the best way to retrofit inspection ports is to use Liquid Nails silicone adhesive that you can buy at Home Depot. It doesn't wrinkle the paint like Polytak will do. He puts the adhesive on both inner and outer rings and then clamps them together using Cleco Clamps, which are small little clamps that you can set using Cleco pliers. You need a lot of clamps (maybe 10 or 12) to keep the rings from wrinkling. He's been doing it this way for many years and has done test sections on spare pieces of fabric to test the bond. He claims it's stronger than Polytak. I bought the materials to put in some inspection plates in my Firestar but haven't gotten around to doing it yet. -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390759#390759 ________________________________________________________________________________
Date: Dec 20, 2012
He claims it's stronger than Polytak. I bought the materials to put in some inspection plates in my Firestar but haven't gotten around to doing it yet. -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Let us know how it works out. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 21, 2012
Subject: Kolb-List: Any Kolbers in Titusville, FL? From: "Watkinsdw" <david.watkins0(at)gmail.com> I am thinking about relocating to the Space Coast of Florida. Are there any Kolb listers at Arthur Dunn Apt (X21?). It has a nice grass strip as well as a paved runway, and AirNav lists 20 "Ultralights." Dave Watkins IMk3 Classic I have been flying there for 30+ yrs. Sent you an e-mail with my number,will be more than happy to help you out. I have an ultrastar,firefly,and 1/2 of an SE5A...and am trying to get a Terra and several others flying for others..Mark ________________________________________________________________________________
Date: Dec 21, 2012
Thom, no heat problems with the Jabiru engine. I am having carb-ice problems with the bing carb the minute the temp drops below 60 degrees on a humid day. No problem here in Texas during the Summer, but this time of year it gets your attention. I looked at the electric heating element, but chose the TBI instead. A little more money, but a lot more in fuel management. I did put that message on the Jabiru list, but no bites yet. I'll take your advise and try the Yaho sites. Thanks Colin Hudson Mark IIIX-tra with Jabiru Temple Texas On Thu, Dec 20, 2012 at 8:26 AM, Thom Riddle wrote: > > Colin, > > What are your "heat problems" with the Jab running the Bing 94? I have no experience with the TBI but have a good bit of experience with a Jabiru 2200 on a Kolb Slingshot. Perhaps I , or one of the other experienced Jabiru/Kolbers, can help. > > If you are determined to change to TBI, I suggest you ask your question on the Jabiru Engines Forum on Yahoo Groups website. In any case, they will want to know what you mean specifically by "heat problems". There are several on that list who have changed to TBI or AeroCarb, some with success, some not so much. Most of them (tractor configurations) did it to have manual control over mixture. If that is your desire, installing a HACman on the Bing will accomplish that, or even making your own is a fairly simple process. That said, I was able to get the EGTs with the Bing exactly where they should be at cruise and full power climb by installing Jabiru's economy tuning kit. > > -------- > Thom Riddle > Buffalo, NY (9G0) > > Kolb Slingshot SS-021 > no engine > FOR SALE > > Diamond Katana DA20-A1 > Rotax 912 F3 > > Don't worry about old age... it doesn't last very long. > - Anonymous > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390740#390740 > > ________________________________________________________________________________
Date: Dec 21, 2012
Wakata, all, NEVER, NEVER, NEVER use any product containing silicone on any painted surface or surface you will paint later. Silicone CANNOT be removed, EVER! Silicone is like molecular ball bearings, you cannot remove it by any method. Sanding or wiping simply spreads the contamination around. Nothing sticks to it so any contaminated surface cannot be painted effectively. Ask an autobody painter. They have a special primer that attempts to encapsulate the silicone and it works well enough to get the job out the door, but long term, the paint will come off. I spent many days in Boeing training classes getting certified to inspect sealing. Boeing practices complete segregation of silicone sealants and tools that are used to apply them. Their only regular use for it is to install windows and only then because they have never found anything that will handle the temperature and pressurization cycling to which an aircraft is subjected. Their painters hate the stuff almost as much as they hate rivet tape. If you're not convinced, do this experiment. Take some RTV and lay down a bead on a piece of scrap and let it cure. Spray with primer and watch what happens. The primer coagulates but doesn't stick. Rick Girard On Thu, Dec 20, 2012 at 6:20 PM, wakataka wrote: > > Let me preface this by saying I haven't done it this way myself yet, but I > really trust the guy who gave me the information. He's a Reno racer who's > built or rebuilt more than a dozen fabric airplanes. He say's the best way > to retrofit inspection ports is to use Liquid Nails silicone adhesive that > you can buy at Home Depot. It doesn't wrinkle the paint like Polytak will > do. He puts the adhesive on both inner and outer rings and then clamps them > together using Cleco Clamps, which are small little clamps that you can set > using Cleco pliers. You need a lot of clamps (maybe 10 or 12) to keep the > rings from wrinkling. He's been doing it this way for many years and has > done test sections on spare pieces of fabric to test the bond. He claims > it's stronger than Polytak. I bought the materials to put in some > inspection plates in my Firestar but haven't gotten around to doing it yet. > > -------- > There is something fascinating about science. One gets such wholesale > returns of conjecture out of such a trifling investment of fact. > > Mark Twain > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390759#390759 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Dec 22, 2012
Subject:
Gday All, Well, the adventure that started when I fell in love with a FireFly at Oshkosh year before last, has finally ended. Finally sold the aircraft to Jim and Edy in Florida, and wish them well with it. Now back to the routine at home in Australia...... The whole story is at http://jgwalkaboutusa.blogspot.com.au/ 525 photos now. A great adventure that I wouldn't have missed for anything! Wishing all a Merry Christmas, And lots of good flying weather in the new year. John Gilpin ________________________________________________________________________________
Subject: Re:
Date: Dec 22, 2012
Hi John, been following your adventures on the list from the UK. Good on yer. Pouring with rain and cold in POngolia at the moment when you are sitting there waxing your surfboard. `Christmas in Australia is basically bloody nice` Apropos of nothing, you are probably aware, in the hotbed of culture that is Oz that there is a long poem called John Gilpins Ride. It finishes with the line (roughly) Should there be such a ride again May I be there to see. I wish I had been in the States to see you. You could always `do` Europe and the UK of course. All the best Pat ________________________________________________________________________________
Subject:
Date: Dec 22, 2012
Great job John! I thoroughly enjoyed the 'journey' through your photos and captions. It's amazing to me more Americans don't have the same enthusiasm to see this great country as do many of our foreign friends. Good on ya Mate! Jack in Key West From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of JC Gilpin Sent: Saturday, December 22, 2012 3:34 AM Subject: Kolb-List: Gday All, Well, the adventure that started when I fell in love with a FireFly at Oshkosh year before last, has finally ended. Finally sold the aircraft to Jim and Edy in Florida, and wish them well with it. Now back to the routine at home in Australia...... The whole story is at http://jgwalkaboutusa.blogspot.com.au/ 525 photos now. A great adventure that I wouldn't have missed for anything! Wishing all a Merry Christmas, And lots of good flying weather in the new year. John Gilpin ________________________________________________________________________________
Date: Dec 22, 2012
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Subject: Re:
Hi John,=0A=0AWishing you a wonderful "routine" back home in australia. Som ehow, after having met you at Larry and Karen's Rock House in June, I can't imagine anything you do as routine.=0A=0AMerry Everything and Happy Always -=0A=0AArty=0A=C2-=0Awww.LessonsFromTheEdge.com/uladventure2009.htm=0A =0A=0A"Life's a daring adventure or nothing"=0AHelen Keller=0A=0A=0A"I refu se to tip toe through life just to arrive safely at death."=0A=0A=0A_______ _________________________=0A From: Jack Lockamy <jacklockamy(at)comcast.net> =0ATo: kolb-list(at)matronics.com =0ASent: Saturday, December 22, 2012 3:44 AM =0ASubject: RE: Kolb-List: =0A =0A=0AGreat job John!=C2- I thoroughly enj oyed the =98journey=99 through your photos and captions.=C2- It=99s amazing to me more Americans don=99t have the same enthu siasm to see this great country as do many of our foreign friends.=C2- Go od on ya Mate!=0A=C2-=0AJack in Key West=0A=C2-=0AFrom:owner-kolb-list- server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behal f Of JC Gilpin=0ASent: Saturday, December 22, 2012 3:34 AM=0ATo: kolb-list@ matronics.com=0ASubject: Kolb-List: =0A=C2-=0AGday All,=0A=C2-=0AWell, the adventure that started when I fell in love with a FireFly at Oshkosh ye ar before last, has finally ended.=0AFinally sold the aircraft to Jim and E dy in Florida, and wish them well with it.=0ANow back to the routine at hom e in Australia......=0A=C2-=0AThe whole story is at=C2-http://jgwalkabo utusa.blogspot.com.au/ =C2-525 photos now.=0A=C2-=0AA great adventure t hat I wouldn't have missed for anything!=0A=C2-=0AWishing all a Merry Chr istmas,=0AAnd lots of good flying weather in the new year.=0A=C2-=0AJohn Gilpin=0A=C2-=0A=C2-=0Awww.aeroelectric.com=0Awww.buildersbooks.com=0Aw ww.homebuilthelp.com=0Ahttp://www.matronics.com/contribution=0Ahttp://www.m atronics.com/Navigator?Kolb-List=0Ahttp://forums.matronics.com=0A=C2-=0A_ -======================== ======= ________________________________________________________________________________
Date: Dec 22, 2012
Subject: Re: : Kolb-List:
John, A Merry Christmas and a very Happy New Year to you. You're a lucky bloke to be able to fly home to summer. :-} If you go to an airshow and see the most beautiful Long EZ ever built say hello to Wayne Blackler for me. She's silver and sleek and you can't miss her on the flight line. Rick Girard On Sat, Dec 22, 2012 at 2:33 AM, JC Gilpin wrote: > Gday All, > > Well, the adventure that started when I fell in love with a FireFly at > Oshkosh year before last, has finally ended. > Finally sold the aircraft to Jim and Edy in Florida, and wish them well > with it. > Now back to the routine at home in Australia...... > > The whole story is at http://jgwalkaboutusa.blogspot.com.au/ 525 photos > now. > > A great adventure that I wouldn't have missed for anything! > > Wishing all a Merry Christmas, > And lots of good flying weather in the new year. > > John Gilpin > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Time of Day
Date: Dec 23, 2012
Do many here on the list fly during the mid day? I know other fixed wings fly mid day like a Cessna, but my concern is that a light plane like a KOLB will be bounced around too much. My current Powered Parachute flying is limited to morning or evening. I want to be able to fly more times of the day then that. Thanks, Wes -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390842#390842 ________________________________________________________________________________
Date: Dec 23, 2012
Subject: Re: Time of Day
I think you build up your tolerance for flying mid-day. Some people never e njoy it and don't fly ever mid-day - I fly mid-day on a regular basis unles s the wind gusts are more than I can tolerate. If it's gusting more than 15 mph I usually stay on the ground. On the other hand, I've flown in strong but steady winds that are much higher. I fly fixed wing "fat ultralights" - now registered LSA.=0A=0AArty Trost=0ASandy, Oregon=0A=0A=0Awww.LessonsFro mTheEdge.com/uladventure2009.htm=0A=0A=0A"Life's a daring adventure or noth ing"=0AHelen Keller=0A=0A=0A"I refuse to tip toe through life just to arriv e safely at death."=0A=0A=0A________________________________=0A From: alien wes =0ATo: kolb-list(at)matronics.com =0ASent: Sunda y, December 23, 2012 6:43 AM=0ASubject: Kolb-List: Time of Day=0A =0A--> Ko lb-List message posted by: "alienwes" =0A=0ADo ma ny here on the list fly during the mid day? I know other fixed wings fly mi d day like a Cessna, but my concern is that a light plane like a KOLB will be bounced around too much. =0A=0AMy current Powered Parachute flying is li mited to morning or evening. I want to be able to fly more times of the day then that. =0A=0AThanks,=0A=0AWes=0A=0A--------=0AWesley Elliott=0ASport P ilot-PPC=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matr - - - - - - - - - - - - - -Matt Dralle, List Admi ================== ________________________________________________________________________________
Date: Dec 23, 2012
Wes Unlike powered parachutes Kolbs in particular and LSAs in general can fly mid day with no problems. I have when traveling (flying all day) strapped aux fuel tank and camping gear down to keep them from flying around the cockpit. These airplanes at least Kolb airplanes are very rugged. When I fly for the fun of it, I fly mornings and evenings just like I do when I rent a Piper or Cessna. Rick Neilsen 1st redrive VW Powered MKIIIC On Sun, Dec 23, 2012 at 9:43 AM, alienwes wrote: > > Do many here on the list fly during the mid day? I know other fixed wings > fly mid day like a Cessna, but my concern is that a light plane like a KOLB > will be bounced around too much. > > My current Powered Parachute flying is limited to morning or evening. I > want to be able to fly more times of the day then that. > > Thanks, > > Wes > > -------- > Wesley Elliott > Sport Pilot-PPC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390842#390842 > > ________________________________________________________________________________
Date: Dec 23, 2012
Do many here on the list fly during the mid day? I know other fixed wings fly mid day like a Cessna, but my concern is that a light plane like a KOLB will be bounced around too much. My current Powered Parachute flying is limited to morning or evening. I want to be able to fly more times of the day then that. Thanks, Wes Wes/Kolbers: Been a few days, but yes, we fly our Kolbs generally when we want to, unless the wind is extreme. Extreme for me is anything over 15 mph. After that, most small airplanes are uncomfortable to fly. Was reminiscing a bit after I got an email from Russ Kinne telling me he had gotten a new home in Maine. I looked up the location on the map which sparked looking at a route I flew in my 1987 Firestar, summer of 1989. I was visiting Bert and Ellen Howland, designer of the Howland line of ultralights, in Maryland, NY, having flown there from Alabama in the Firestar. Decided to fly the New England states while I was there. I was able to fly New York, Connecticut, Road Island, Massachusetts, Maine, New Hampshire, Vermont, and back to New York in one day, a flight of approximately 546 miles, cruising at 60 to 65 mph. Highlight of that flight was flying around, but not too close, President Bush's vacation home in Kennebunkport, Maine. I don't recall how many flight hours involved in that flight. Wind was not a factor in whether I would fly or not. I departed Bert's grass strip early in the morning and landed about 2100, just as it was getting dark. Perfect timing. ;-) By the way, had I driven to the same places, the trip would have been 710 miles and taken two days to complete. Wish I could still fly like that. Discovered there was a lot of difference between age of 50 and 73. Merry Christmas and Happy New Year to all the Kolbers out there. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 23, 2012
Merry Christmas to you too John!=0A=0A=0AChris Davis=0AKXP 503 492 hrs=0AGl ider Pilot=0ADisabled from crash building Firefly=0A=0A=0A>________________ ________________=0A>From: John Hauck <jhauck(at)elmore.rr.com>=0A>To: kolb-lis t(at)matronics.com =0A>Sent: Sunday, December 23, 2012 12:24 PM=0A>Subject: RE k" =0A>=0A>=0A>=0A>Do many here on the list fly durin g the mid day? I know other fixed wings=0A>fly mid day like a Cessna, but m y concern is that a light plane like a KOLB=0A>will be bounced around too m uch.=0A>=0A>My current Powered Parachute flying is limited to morning or ev ening. I want=0A>to be able to fly more times of the day then that.=0A>=0A> Thanks,=0A>=0A>Wes=0A>=0A>=0A>Wes/Kolbers:=0A>=0A>Been a few days, but yes, we fly our Kolbs generally when we want to, unless=0A>the wind is extreme. - Extreme for me is anything over 15 mph.- After that,=0A>most small ai rplanes are uncomfortable to fly.=0A>=0A>Was reminiscing a bit after I got an email from Russ Kinne telling me he had=0A>gotten a new home in Maine. - I looked up the location on the map which=0A>sparked looking at a route I flew in my 1987 Firestar, summer of 1989.- I=0A>was visiting Bert and Ellen Howland, designer of the Howland line of=0A>ultralights, in Maryland, NY, having flown there from Alabama in the=0A>Firestar.- Decided to fly the New England states while I was there.=0A>=0A>I was able to fly New York , Connecticut, Road Island, Massachusetts, Maine,=0A>New Hampshire, Vermont , and back to New York in one day, a flight of=0A>approximately 546 miles, cruising at 60 to 65 mph.- Highlight of that flight=0A>was flying around, but not too close, President Bush's vacation home in=0A>Kennebunkport, Mai ne.=0A>=0A>I don't recall how many flight hours involved in that flight.- Wind was not=0A>a factor in whether I would fly or not.- I departed Bert 's grass strip early=0A>in the morning and landed about 2100, just as it wa s getting dark.- Perfect=0A>timing.- ;-)=0A>=0A>By the way, had I drive n to the same places, the trip would have been 710=0A>miles and taken two d ays to complete.=0A>=0A>Wish I could still fly like that.- Discovered the re was a lot of difference=0A>between age of 50 and 73.=0A>=0A>Merry Christ mas and Happy New Year to all the Kolbers out there.=0A>=0A>john h=0A>mkIII - - - - - - - - - - - - -Matt Dralle, List Admin. =======================0A>=0A> =0A>=0A>=0A>=0A> ________________________________________________________________________________
Date: Dec 23, 2012
Hi Chris, unless you are mixed up in Texas thermals or fly regularly in the downdraft from a mountain wave system you can fly whever the wind is below what you are comfortable with. You will soon establish that. The Kolb will take more punishment than you will. That said unless you really have places to go the morning and evening flights are often the most enjoyable. Pat ________________________________________________________________________________
Date: Dec 24, 2012
Wes, I hear that winds in the Midwest really howl during the day. Even in the east, where the winds are generally lighter during the day, most powered parachute flying is still done near dawn or dusk. Sure, a 152 bounces around more than a 172 and a Kolb bounces more than a 152 etc. Here, ultralights are flown all day long. You will soon learn the limits of what you can tolerate and enjoy. I am sure that, at the very least, your flying hours will be greatly extended with a Kolb. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390874#390874 ________________________________________________________________________________
Subject: q
Date: Dec 24, 2012
List, is there a Kolb pilot in coastal Maine or nearby NH? I'd like to make contact. Russ ________________________________________________________________________________
Subject: q
Date: Dec 24, 2012
Russ/Kolbers: If you don't get results here, try searching the FAA Data Base for Kolbs in the registered aircraft section. You could also do a Google search for "Kolb aircraft Maine, NH. john h mkIII Titus, Alabama List, is there a Kolb pilot in coastal Maine or nearby NH? I'd like to make contact. Russ ________________________________________________________________________________
Date: Dec 24, 2012
Thanks group for all the responses. I want to use a Fixed Wing to help scout Elk and Deer here in New Mexico in addition to flying for fun. The Kolb seems like the best of both worlds for this as I can fold the wings and still have a STOL aircraft. How does the KOLB handle the backcountry takeoff/landings at high elevations? Wes -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390886#390886 ________________________________________________________________________________
Date: Dec 24, 2012
> we fly our Kolbs generally when we want to I have an '80's Firestar. Before I can fly it I need to finish re-covering it. I am not a pilot, have a few lessons so far. Do you guys feel a lil apprehension when flying in bumpy air? Do you start to wonder about just how strong are those attachment points? Do you fly with a parachute? Do you sometimes long for one? In bumpy air, could you idle the engine and soar? Assuming you aren't really headed anywhere in particular. A Wannabee just wondering, which is what I do best. -------- GeoB "Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390889#390889 ________________________________________________________________________________
Date: Dec 24, 2012
I can't speak for the high elevations being I am at sea level. I will say t he Kolb has been good to me. Here I have the cow pastures=2C back roads and sandy beaches to play with. Depending on which one you are looking at I wo uld look closely at the steel legs=2C over sized tires and VG's as they do make a big difference. Skybiker MK3/912/ul > Subject: Kolb-List: Re: Time of Day > From: elliott.wesley(at)yahoo.com > Date: Mon=2C 24 Dec 2012 10:54:24 -0800 > To: kolb-list(at)matronics.com > > > Thanks group for all the responses. > > I want to use a Fixed Wing to help scout Elk and Deer here in New Mexico in addition to flying for fun. The Kolb seems like the best of both worlds for this as I can fold the wings and still have a STOL aircraft. How does t he KOLB handle the backcountry takeoff/landings at high elevations? > > Wes > > -------- > Wesley Elliott > Sport Pilot-PPC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390886#390886 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Dec 24, 2012
How does the KOLB handle the backcountry takeoff/landings at high elevations? Wes Wes/Kolbers: Done a little bit of flying out West, as well as my old buddy John Williamson. Many years ago John and I were flying from Alamosa, CO, to Farmington, NM. Best way to get there was direct over the Rockies. John hit 15,000 feet and I was at 14,500 feet when we decided we had plenty altitude to clear the mountains. I have flown West from Alabama every year since 2003, except 2010. Those flights have seen 12,000 to 13,000 feet many times. In 2008 John W and I flew some of the Idaho back country airstrips. One of those was Soldiers Bar. It is pretty much back country: http://www.youtube.com/watch?v=90mqPLT1z4c . STEEP CANYON WALLS IN ALL DRCTNS. . ARPT ON BENCH 500 FT ABOVE BIG CREEK ON S SIDE. . CABIN CREEK ARPT APPROX 7 MILES WEST UP BIG CREEK CANYON. . WEST 1/3 OF RY HAS 4 DEG SLOPE DOWN TO THE NORTH. . GO-AROUNDS NOT RECOMMENDED. . NO TELEPHONE AVBL AT ARPT. . THR MARKED WITH ROCKS. This was a very exciting, rough, place to land. I also land on river sand bars from Alabama to the North Slope of Alaska, hay fields, dirt roads, paved roads ;-), and parking lots. Well...I have landed in parking lots back in my UL days, but have matured just a little bit and don't do that anymore. However, if I had to, I know I could do it. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 24, 2012
Depending on which one you are looking at I would look closely at the steel legs, over sized tires and VG's as they do make a big difference. Skybiker MK3/912/ul I don't have VGs on my Kolb, although I have flown other Kolbs equipped with them. Saying "as they do make a big difference" could mean a lot of things. What did they do for your MKIII? john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 24, 2012
Wes, I generally let others with more experience answer most of the questions about Kolbs and their flight characteristics. However I have done a bit of scouting for Elk, Deer and Antelope, so I know a bit about this subject. I fly a Firestar II with VG's and a HKS four stroke engine, and have the bigger tires and steel gear legs. All of this is in response to trial and error, mostly error on my part. Three of them so far. I do not have a chute. Most if not all of your flights over hostile terrain will be at or about 60 + MPH. Any and all landings with my set up will be initiated at 50 MPH with a stall coming at 32 or so MPH. At that speed even over open ground, if the critter is not moving, you most likely will not see it. You will however be able to find the routes that will take you to any part of the "hunting or fishing" area that you want with ease, and eliminate a lot of bumping around on the ground. You will also know the area better than even a native in a much shorter time. The handy part of it as you mentioned is that you can trailer it in to the area that you want to scout, take off on a dirt road, and return there when you are done. Landings in undeveloped country is another matter. What looks really good from the air, just might mean that you are either going to have to do repairs or walk out if you are able. I carry a roll of duct tape, good first aid kit, and a Spot locator with tracking, in an attempt to cover any stupid thoughts that I might entertain. I have landed out several times, but I have also chickened out many many more times. I guess it all depends on the area and how bad you want to walk around. Any sort of developed strip will be no problem. A single dirt road with enough clearance and distance is not that much of a problem either. Just keep in mind that what seemed like a good idea at the time, can be a source of serious consequence if things go wrong. The Kolb in all its various manifestations are in my opinion the best compromise that you can get. If I had to wreck my plane, I would rather be in a Kolb than any thing else. It is strong and will fly you to safety given half a chance. :-) The Kolb will tolerate rough air much better than you ever will. It isn't fun, but it is possible. Larry On Mon, Dec 24, 2012 at 11:54 AM, alienwes wrote: > > Thanks group for all the responses. > > I want to use a Fixed Wing to help scout Elk and Deer here in New Mexico > in addition to flying for fun. The Kolb seems like the best of both worlds > for this as I can fold the wings and still have a STOL aircraft. How does > the KOLB handle the backcountry takeoff/landings at high elevations? > > Wes > > -------- > Wesley Elliott > Sport Pilot-PPC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390886#390886 > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Dec 24, 2012
I don't mind flying in bumpy air; actually I enjoy it. For me the limiting factor to that enjoyment is the sluggish aileron response of my Ultrastar which can get dicey landing on a gusty day, and the wind I can handle while folding the wings. But I also fly PPG, so when I got the Ultrastar it was refreshing to fly all day and not really worry about getting caught upstairs. Dana At 02:17 PM 12/24/2012, GeoB wrote: >I have an '80's Firestar. Before I can fly it I need to finish re-covering >it. I am not a pilot, have a few lessons so far. Do you guys feel a lil >apprehension when flying in bumpy air? Do you start to wonder about just >how strong are those attachment points? Do you fly with a parachute? Do >you sometimes long for one? In bumpy air, could you idle the engine and >soar? Assuming you aren't really headed anywhere in particular. -- Democracy is three wolves and a sheep voting on what to have for lunch. ________________________________________________________________________________
Date: Dec 24, 2012
The Kolb in all its various manifestations are in my opinion the best compromise that you can get. If I had to wreck my plane, I would rather be in a Kolb than any thing else. It is strong and will fly you to safety given half a chance. :-) The Kolb will tolerate rough air much better than you ever will. It isn't fun, but it is possible. Larry Kolbers: These are extremely good points made by Larry C. Crashworthiness is worth its weight in gold when you need it. Never been injured in a Kolb crash, other than my pride and my pocket book. Like Larry, I have aborted far more off field landings than I have made. The only one I should have aborted and didn't was across the Alaska Highway from Rocky Mountain Lodge, Muncho Lake, British Columbia. That one resulted in tearing up my airplane and spending a month traveling to Alabama for recovery vehicle, return to Muncho Lake, and then get the MKIII back home. Sure wish I had aborted that one. ;-) john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 24, 2012
> the limiting factor to that enjoyment is the sluggish aileron response of my Ultrastar. Does my Firestar-I have better aileron response than your ultrastar? The ailerons look huge on mine! GeoB -------- GeoB "Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390902#390902 ________________________________________________________________________________
Date: Dec 24, 2012
What did they do for your MKIII?>> What the VG`s did for mine John was to make it legal by lowering the stalling speed enough to comply with the UK rules. Without them we would have no Xtra`s on the market here. Merry Christmas from a very waterlogged UK Pat ________________________________________________________________________________
Date: Dec 24, 2012
In bumpy air, could you idle the engine and soar?>> Depends what is causing the bumps.If it is thermals YES is the answer. Given a strong enough thermal you can soar a barn door. Certainly a couple of knots on the variometer is enough to scrape with a bit of engine. Given 4 knots you can climb with dead idle (or engine off if you are good enough and have enough confidence in your starting the engine again.) You need some gliding experience. Otherwise find a ridge with the wind deflected over it. Cut the engine and stay up all day. Merry Christmas Pat ________________________________________________________________________________
Date: Dec 24, 2012
At 05:14 PM 12/24/2012, GeoB wrote: > > > the limiting factor to that enjoyment is the sluggish aileron response > of my Ultrastar. > >Does my Firestar-I have better aileron response than your ultrastar? The >ailerons look huge on mine! It should... the problem with the Ultrastar is the wing itself twists, so the ailerons like a trim tab, the wing twists the other way and partially cancels it out. I believe the Firestar's wing is stiffer due to a different wing root attachment. The ailerons on the US actually work worse the faster you go. -Dana -- Ever notice there's no crime at a shooting range? ________________________________________________________________________________
Subject: Re: q
Date: Dec 26, 2012
As John has suggested, I performed the search for you using the Landings.com Aircraft Database. These are public records. N-number : N182EZ Aircraft Serial Number : FS 645 Aircraft Manufacturer : KOLB Model : FIRESTAR 11 Engine Manufacturer : ROTAX Model : 503 DCDI Aircraft Year : 1997 Owner Name : KANE LAWRENCE J Owner Address : 18 FROST ST SPRINGVALE, ME, 040831431 Type of Owner : Individual Registration Date : 20-Sep-2005 Airworthiness Certificate Type : Experimental Approved Operations : N-number : N3698V Aircraft Serial Number : M1070 Aircraft Manufacturer : KOLB Model : MARK III Engine Manufacturer : ROTAX Model : 912UL Aircraft Year : 1996 Owner Name : TEDRICK PHILLIP D Owner Address : 30 CHURCH RD READFIELD, ME, 043553730 Type of Owner : Individual Registration Date : 12-Sep-2011 Airworthiness Certificate Type : Experimental Approved Operations : N-number : N682FS Aircraft Serial Number : FS682 Aircraft Manufacturer : KOLB AIRCRAFT Model : FIRESTAR II Engine Manufacturer : ROTAX Model : 503 DCDI Aircraft Year : 1998 Owner Name : BARNES RICHARD S Owner Address : 26 CHURCH ST GOFFSTOWN, NH, 030451703 Type of Owner : Individual Registration Date : 16-Dec-2010 Airworthiness Certificate Type : Experimental -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390958#390958 ________________________________________________________________________________
Subject: Re: q
Date: Dec 26, 2012
Jerry, many many many thanx. That info will be very useful to me. Have a great flying 2013! Fair winds, Russ On Dec 26, 2012, at 6:49 AM, racerjerry wrote: > > As John has suggested, I performed the search for you using the Landings.com Aircraft Database. These are public records. > > N-number : N182EZ > Aircraft Serial Number : FS 645 > Aircraft Manufacturer : KOLB > Model : FIRESTAR 11 > Engine Manufacturer : ROTAX > Model : 503 DCDI > Aircraft Year : 1997 > Owner Name : KANE LAWRENCE J > Owner Address : 18 FROST ST > SPRINGVALE, ME, 040831431 > Type of Owner : Individual > Registration Date : 20-Sep-2005 > Airworthiness Certificate Type : Experimental > Approved Operations : > > N-number : N3698V > Aircraft Serial Number : M1070 > Aircraft Manufacturer : KOLB > Model : MARK III > Engine Manufacturer : ROTAX > Model : 912UL > Aircraft Year : 1996 > Owner Name : TEDRICK PHILLIP D > Owner Address : 30 CHURCH RD > READFIELD, ME, 043553730 > Type of Owner : Individual > Registration Date : 12-Sep-2011 > Airworthiness Certificate Type : Experimental > Approved Operations : > > N-number : N682FS > Aircraft Serial Number : FS682 > Aircraft Manufacturer : KOLB AIRCRAFT > Model : FIRESTAR II > Engine Manufacturer : ROTAX > Model : 503 DCDI > Aircraft Year : 1998 > Owner Name : BARNES RICHARD S > Owner Address : 26 CHURCH ST > GOFFSTOWN, NH, 030451703 > Type of Owner : Individual > Registration Date : 16-Dec-2010 > Airworthiness Certificate Type : Experimental > > -------- > Jerry King > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390958#390958 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 26, 2012
> >Do many here on the list fly during the mid day? I know other fixed wings fly mid day like a Cessna, but my concern is that a light plane like a KOLB will be bounced around too much. > >My current Powered Parachute flying is limited to morning or evening. I want to be able to fly more times of the day then that. > Wes, I have found that if my back does not come off the seat and if my rear does not move relative to the fuselage, I am comfortable flying in unstable air. I use a five point seat belt harness. See: http://jackbhart.com/firefly/firefly78.html The original FireFly design used 15 inch chord ailerons which were impossible to deflect at cruise speed. On cross country flights this ensured you arrived with a sore shoulder and an upset stomach due to continuous dutch rolls to pick up the falling wing. By shortening the aileron chord to 9 inches and reworking the aileron actuation mechanism, I am able, by using two fingers on the stick, to keep the wings level in rough air at cruise. See: http://jackbhart.com/firefly/firefly26.html With these changes, the FireFly is a good rough air flyer. Aileron response is excellent and, it forward and side slip very well with little stick pressure. When I am going some where, I cruise at 2,000 to 3,000 feet agl where I find the air smoother and gives me more options if the engine quits. The roughest art of the flight will be climb out and let down. I keep the speed around 40 mphi and only worry about keeping the wings level. I can take a lot of bouncing as long as I feel that I have immediate control response. Flying comfortably in rough air is an acquired skill. I developed it by flying the pattern, starting with quiet wind days and then flew additional flights on days when the wind was progressively higher. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Subject: Websites and 912's
Date: Dec 26, 2012
Hello Group, Researching and I like the Mark III. See two of them on barnstormers with 912's for sale. I am still atleast a year off from purchasing anything but am trying to get informed. Are there any other sites to find classifieds for small airplanes like the KOLB? Also, what do you think the percentage of Mark III's have 912's on them? Wes -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=391007#391007 ________________________________________________________________________________
Subject: Re: q
Date: Dec 26, 2012
i just did some work on phill tedrecks from reidfield russ that has a 912 8 0 hp on it Ellery Batchelder Jr. -----Original Message----- From: russk50(at)gmail.com Sent: Wed, Dec 26, 2012 4:28 am Subject: Re: Kolb-List: Re: q Jerry, many many many thanx. That info will be very useful to me. Have a great flying 2013! Fair winds, Russ On Dec 26, 2012, at 6:49 AM, racerjerry wrote: > > As John has suggested, I performed the search for you using the Landings. com Aircraft Database. These are public records. > > N-number : N182EZ > Aircraft Serial Number : FS 645 > Aircraft Manufacturer : KOLB > Model : FIRESTAR 11 > Engine Manufacturer : ROTAX > Model : 503 DCDI > Aircraft Year : 1997 > Owner Name : KANE LAWRENCE J > Owner Address : 18 FROST ST > SPRINGVALE, ME, 040831431 > Type of Owner : Individual > Registration Date : 20-Sep-2005 > Airworthiness Certificate Type : Experimental > Approved Operations : > > N-number : N3698V > Aircraft Serial Number : M1070 > Aircraft Manufacturer : KOLB > Model : MARK III > Engine Manufacturer : ROTAX > Model : 912UL > Aircraft Year : 1996 > Owner Name : TEDRICK PHILLIP D > Owner Address : 30 CHURCH RD > READFIELD, ME, 043553730 > Type of Owner : Individual > Registration Date : 12-Sep-2011 > Airworthiness Certificate Type : Experimental > Approved Operations : > > N-number : N682FS > Aircraft Serial Number : FS682 > Aircraft Manufacturer : KOLB AIRCRAFT > Model : FIRESTAR II > Engine Manufacturer : ROTAX > Model : 503 DCDI > Aircraft Year : 1998 > Owner Name : BARNES RICHARD S > Owner Address : 26 CHURCH ST > GOFFSTOWN, NH, 030451703 > Type of Owner : Individual > Registration Date : 16-Dec-2010 > Airworthiness Certificate Type : Experimental > > -------- > Jerry King > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390958#390958 > > > > > > > > > > ________________________________________________________________________________
Subject: Antioch, CA
Date: Dec 28, 2012
Hello, My name is Paul and I am new to California. Moved here for the job and I love flying. I've been flying GA for several years but sold my plane a while back. I would like to find something I can take home each day after flying and save the hanger rent. I'm interested in the Mark 3 X with a 912(used to the engine) but would consider other aircraft. If anyone is from the area I would love to meet up and buy a cup of coffee. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=391084#391084 ________________________________________________________________________________
From: "Steve Simmons" <stevesimmons(at)charter.net>
Date: Dec 28, 2012
Iam not from your area but I am sure transportation could be arranged -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of CaliPaul Sent: Friday, December 28, 2012 2:32 PM Subject: Kolb-List: Antioch, CA Hello, My name is Paul and I am new to California. Moved here for the job and I love flying. I've been flying GA for several years but sold my plane a while back. I would like to find something I can take home each day after flying and save the hanger rent. I'm interested in the Mark 3 X with a 912(used to the engine) but would consider other aircraft. If anyone is from the area I would love to meet up and buy a cup of coffee. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=391084#391084 ________________________________________________________________________________
Subject: Re: Antioch, CA
Date: Dec 28, 2012
Barnstormers has two 912 Mark III listed in December. Maybe look into one of those? -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=391107#391107 ________________________________________________________________________________
Date: Dec 28, 2012
Paul You can't do much better than a Kolb depending its mission. It is a STOL airplane that is not real fast. I think they advertise that a MKIIIX can be folded up in 15-30 minutes but it is a hassle that most of us don't do every time we fly. If you do you will not fly much. Setting it up takes longer because you need to make sure everything is right. I used to have a private short strip next to my home with a hanger and that was ideal. It pains me to say I moved and now keep it at a local airport. For a few years I folded the plane, loaded it in my enclosed trailer and hauled it home in Michigan for the 6 months I spend in Florida. Any way now I fold the plane up for the winter in the shared hanger for reduced rent. One winter I pulled the plane to Florida with my Toyota Sienna but that was a real pain pulling that long trailer. It added a day to traveling time and hanger space in Florida is more than twice the Michigan cost so it stays home now. Rick Neilsen 1st Redrive VW Powered MKIIIC On Fri, Dec 28, 2012 at 2:31 PM, CaliPaul wrote: > > Hello, > > My name is Paul and I am new to California. Moved here for the job and I > love flying. I've been flying GA for several years but sold my plane a > while back. I would like to find something I can take home each day after > flying and save the hanger rent. I'm interested in the Mark 3 X with a > 912(used to the engine) but would consider other aircraft. If anyone is > from the area I would love to meet up and buy a cup of coffee. > > Thanks > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=391084#391084 > > ________________________________________________________________________________
Date: Dec 28, 2012
Subject: Prop Bolts
All, A customer for one of my propeller extensions required 100mm length 8mm X 1.25 for his prop. Standard 8.8 metric hex head. I order from my bolt supplier in lots of 25 so I have three sets left. The shank is 2.85" long. Each set is complete with AN 960-5 washers and your choice of flanged or regular nylock jam nuts. $13 a set includes shipping. Rick Girard -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Dec 29, 2012
I found this video on the KOLB website. Shows how easy it is to fold the wings. http://www.kolbaircraft.com/foldingwings.htm He does it in 11 minutes and I am sure one could do it faster. Compared to unpacking and laying out a PPC parachute wing I would say it is comparable. I have read of some KOLB owners who are very happy to fold and unfold everytime. Some of the steps are part of a a good preflight checklist as well. Wes -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=391140#391140 ________________________________________________________________________________
Date: Dec 29, 2012
Wes, That was the best video I've seen in showing the steps involved. I must have overlooked it on their website when browsing it prior. Thanks for sharing. Over the course of time I have heard folks say that it really takes them 30-60 minutes to fold or unfold the wings however based off of this I'm going to guess it is more of the whole preflight or unloading off a trailer that maybe draws out that time. I'm now pretty confident my 14yr old son and I could do this by ourselves. Paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=391144#391144 ________________________________________________________________________________
Date: Dec 29, 2012
Wes Just trying to help. Sorry thought you were asking. With the wings folded the tail is overloaded and the ground clearance is very low. To move it home you need a long trailer and it needs to be loaded on the trailer so maybe that is the rest of the story. Check out the following web site http://www.oh2fly.net/Main_trailer_kolb.htm for trailer ideas. Also consider that most of these trailers require a big tow vehicle. Rick Neilsen Redrive VW Powered MKIIIC On Sat, Dec 29, 2012 at 10:19 AM, alienwes wrote: > > I found this video on the KOLB website. Shows how easy it is to fold the > wings. > > http://www.kolbaircraft.com/foldingwings.htm > > He does it in 11 minutes and I am sure one could do it faster. Compared to > unpacking and laying out a PPC parachute wing I would say it is comparable. > I have read of some KOLB owners who are very happy to fold and unfold > everytime. Some of the steps are part of a a good preflight checklist as > well. > > Wes > > -------- > Wesley Elliott > Sport Pilot-PPC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=391140#391140 > > ________________________________________________________________________________
Date: Dec 29, 2012
I unfold then refold my MkIIIC (Rotax 912ULS) each time I fly. Back in 2007, I made this video (which isn't so much an instruction as it is a demonstration): http://www.youtube.com/watch?v=uGblkR8cdYE It takes about 20 minutes to unfold, and about 25 minutes to refold my Kolb. I have a trailer but only use it rarely for transportation. Normally, my Kolb is rolled up into my large workshop, which only takes a couple of minutes. -- Robert P.S. I'm thinking about selling it. On Sat, Dec 29, 2012 at 10:07 AM, CaliPaul wrote: > > Wes, > > That was the best video I've seen in showing the steps involved. I must > have overlooked it on their website when browsing it prior. Thanks for > sharing. > > Over the course of time I have heard folks say that it really takes them > 30-60 minutes to fold or unfold the wings however based off of this I'm > going to guess it is more of the whole preflight or unloading off a trailer > that maybe draws out that time. I'm now pretty confident my 14yr old son > and I could do this by ourselves. > > Paul > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=391144#391144 > > ________________________________________________________________________________
Date: Dec 29, 2012
Another cool video on folding/unfolding! The time lapsed fast speed was cool. Have you posted your KOLB for sale yet or still unsure? Wes -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=391154#391154 ________________________________________________________________________________
Date: Dec 29, 2012
It's not yet posted. I'm currently replacing the brake cylinders... when that's done, I'll post it. On Sat, Dec 29, 2012 at 11:19 AM, alienwes wrote: > > Another cool video on folding/unfolding! The time lapsed fast speed was > cool. Have you posted your KOLB for sale yet or still unsure? > > Wes > > -------- > Wesley Elliott > Sport Pilot-PPC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=391154#391154 > > ________________________________________________________________________________
Date: Dec 29, 2012
It takes me 10 minutes to unfold my Ultrastar, starting with unlocking the trailer. I fold/unfold every time I fly. I keep the plane in the trailer at the airport for the outdoor tiedown rate which is far cheaper than a hangar, and tow it home only to work on it or for winter storage. Add a few more minutes if it's tied down inside the trailer for towing. Here's another video of the process: -Dana At 11:07 AM 12/29/2012, CaliPaul wrote: > >Wes, > >That was the best video I've seen in showing the steps involved. I must >have overlooked it on their website when browsing it prior. Thanks for sharing. > >Over the course of time I have heard folks say that it really takes them >30-60 minutes to fold or unfold the wings however based off of this I'm >going to guess it is more of the whole preflight or unloading off a >trailer that maybe draws out that time. I'm now pretty confident my 14yr >old son and I could do this by ourselves. -- If ignorance is bliss, why aren't there more happy people? ________________________________________________________________________________
Date: Dec 29, 2012
It takes me exactly 2 mins and 51 secs to unfold, trailer, fold, and store my Firefly- :) https://www.youtube.com/watch?v=iqSVwTGYO6o I also live 0.40 miles from Dallas Bay Skypark (1a0) so I keep my Firefly a t home in the carport. I have a very simple modified T-trailer. Phil H FF11-4-76 --- On Sat, 12/29/12, Dana Hague wrote: From: Dana Hague <d-m-hague(at)comcast.net> Subject: Re: Kolb-List: Re: Antioch, CA Date: Saturday, December 29, 2012, 1:08 PM =0AIt takes me 10 minutes to unfold my Ultrastar, starting with=0Aunlocking the trailer.- I fold/unfold every time I fly.- I keep=0Athe plane in t he trailer at the airport for the outdoor tiedown rate=0Awhich is far cheap er than a hangar, and tow it home only to work on it or=0Afor winter storag e.- Add a few more minutes if it's tied down inside=0Athe trailer for tow ing.- Here's another video of the=0Aprocess: =0A =0A-Dana =0AAt 11:07 AM 12/29/2012, CaliPaul wrote: =0AWes, =0AThat was the best video I've seen in showing the steps involved. I must =0Ahave overlooked it on their website when browsing it prior. Thanks for =0Asharing. =0AOver the course of time I have heard folks say that it really takes them =0A30-60 minutes to fold or unfold the wings however based off of this I'm =0Agoing to guess it is more of the whole preflight or unloading off a=0Atr ailer that maybe draws out that time. I'm now pretty confident my 14yr=0Aol d son and I could do this by ourselves. =0A--=0AIf ignorance is bliss, why aren't there more happy=0Apeople?-- =========================0A ====================0A=0A ________________________________________________________________________________
Date: Dec 29, 2012
Phil, Dana, Nice Vids! I noticed someone commented on youtube that they were jealous because there MX was difficult to fold. I was initially researching the Quicksilver line but was turned off by the lack of tranportability. Wes -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=391177#391177 ________________________________________________________________________________
Date: Dec 29, 2012
Hi I am a uk kolb owner. I keep mine at the airfield folded in its trailer as there is no available hangarage , and unfold /fold every time I fly and 15 mins is about right to unfold on my own and do a thorough pre flight inspection .I could do it faster but I would rather do it in a leisurely careful manner and then not be worried Ive missed something . Once you get used to the routine its not really a big deal. I have friends here who keep their aircraft rigged in the open with covers on and they can get the covers off faster than I can rig my plane , but then, I can de rig and be away before they have all their covers back on and the plane tied down. Sure I would like to just roll her out of a hanger and fly but that is not available in my area unless I pay at least three times the airfield fees( currently flying from a farm at Ince blundell just north of Liverpool uk ) and also would miss the good friends at this microlight ( ultralight for you ) club . Dont let the folding and unfolding put you of owning a kolb and make sure you have a good checklist ( I'm sure otheres here could help you far better than I with a proven checklist ) for your rigging to fly and you wont go far wrong Eddie Bayliss kolb mk111c 582 rotax arplast prop ----- Original Message ----- From: "CaliPaul" <paulandgeorgia(at)gmail.com> Sent: Saturday, December 29, 2012 4:07 PM Subject: Kolb-List: Re: Antioch, CA > > Wes, > > That was the best video I've seen in showing the steps involved. I must > have overlooked it on their website when browsing it prior. Thanks for > sharing. > > Over the course of time I have heard folks say that it really takes them > 30-60 minutes to fold or unfold the wings however based off of this I'm > going to guess it is more of the whole preflight or unloading off a > trailer that maybe draws out that time. I'm now pretty confident my 14yr > old son and I could do this by ourselves. > > Paul > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=391144#391144 > > > ________________________________________________________________________________
Date: Dec 30, 2012
Subject: Auto-response
Away on holiday from the 22 December 2012 till 29 January 2013 Wishing you a happy festive season . Merry Christmas and a Happy New Year from Viorel ... ________________________________________________________________________________
Date: Dec 30, 2012
Hi I am a uk kolb owner. Eddie Bayliss kolb mk111c Hi Eddie B/Kolbers: Good to see you posting. Hope all is well with you and the rest of the Kolbers in the UK. Happy New Year to all, john h mkIII Woodville, FL ________________________________________________________________________________
Date: Dec 29, 2012
Thanks John and the same to all on the list ,I dont post much but am lurking around and usually learning something all the time ________________________________________________________________________________
Subject: Non-Kolb related request for help
Date: Dec 31, 2012
Any Kolbers in the Wilmington - New Bern coastal area? Especially Holly Ridge/ Topsail Island? If so, I need some help, please contact me off list richard(at)bcchapel.org Thanks, rp -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=391295#391295 ________________________________________________________________________________
Date: Dec 31, 2012
Subject: Light reading
A neighbor of mine suggested a NACA report about simplified propeller design written by Fred Weick (designer of the Ercoupe, among other work) and while I was searching the database I found the attached report. Given the thick wing and the testing of both tractor and pusher configurations I thought some of you might enjoy it, too. Rick Girard -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Re: Light reading
Date: Jan 01, 2013
Rick, I finally got through it. Interesting reading. Thanks for posting. I don't recall ever seeing an airplane with wing mounted engine and extension shaft, either pusher or tractor, but there probably are some. The BD-5 comes to mind for fuselage mounted pusher with extension shaft. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 no engine FOR SALE Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=391334#391334 ________________________________________________________________________________
Date: Jan 01, 2013
Thom, The ill-fated Brabazon airliner built by the British following World War II used the technology from the report. It had a total of eight engines in four pairs buried in the wings. Each pair drove contrarotating propellers through a gearbox and an extension shaft. They only built one. I think it takes the prize as the largest tail dragger ever built. It had such a long takeoff run that they had to level a village to extend the runway adjacent to the factory where it was built. Rick On Tue, Jan 1, 2013 at 10:28 AM, Thom Riddle wrote: > > Rick, > I finally got through it. Interesting reading. Thanks for posting. > > I don't recall ever seeing an airplane with wing mounted engine and > extension shaft, either pusher or tractor, but there probably are some. The > BD-5 comes to mind for fuselage mounted pusher with extension shaft. > > -------- > Thom Riddle > Buffalo, NY (9G0) > > Kolb Slingshot SS-021 > no engine > FOR SALE > > Diamond Katana DA20-A1 > Rotax 912 F3 > > Don't worry about old age... it doesn't last very long. > - Anonymous > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=391334#391334 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jan 01, 2013
Subject: 2013
-HAPPY NEW YEAR ALL YOU KOLBERS (how did we ever get to 2013?=0AChris Dav is=0AKXP 503 492 hrs=0AGlider Pilot=0ADisabled from crash building Firefly ________________________________________________________________________________
Subject: KOLB Forums
Date: Jan 03, 2013
Are there any other KOLB forums on the internet that are popular? Wes -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=391554#391554 ________________________________________________________________________________
Date: Jan 03, 2013
Subject: Re: KOLB Forums
At 06:45 PM 1/3/2013, alienwes wrote: > >Are there any other KOLB forums on the internet that are popular? There's the <http://groups.yahoo.com/group/KolbUltrastar>kolbultrastar yahoo group, dedicated to the "high boom" Kolbs and not as busy as this one, and the <http://www.wingsforum.com/viewforum.php?f=180>Kolb forum on the Wings forum, which sees little traffic. -Dana -- Some people have a large circle of friends, while others have only friends that they like. ________________________________________________________________________________
Date: Jan 03, 2013
Are there any other KOLB forums on the internet that are popular? Wes Wes/Kolbers: Ask a few questions. Maybe we can find some answers. Usually, January and February are very slow months for the Kolb Builders and Flyers List. john h mkIII - 3,197.7 hours airframe 912ULS - 629.2 hours engine Titus, Alabama ________________________________________________________________________________
Date: Jan 04, 2013
Hi Eddie, anybody Liverpool way want to buy my Mark 3 Xtra with Jabiru> Less than 100 hours and she has just been sitting (hangared) since the last C of A as I am medically grounded. Not because I can`t fly but because I cannot now handle the pulley hauley on the ground, pushing in and out of the hangar, handling fuel etc. No reasonable (or unreasonable) offer refused. An absolute snip for someone. The kit alone is around 17K. I shall be starting to advertise again now with Spring just around the corner (heh heh) Happy New Year Pat ________________________________________________________________________________
Date: Jan 04, 2013
I'm interested. Pvt email sent. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=391619#391619 ________________________________________________________________________________
Date: Jan 03, 2013
Hi Pat not that I know of. Most people shy away from the tail wheel in these parts .there have only been a couple of pilots here I have been able to persuade to try mine and they all run back to their nose wheel aircraft .Cant for the life of me think why but there you go. I will repeat my offer if your ever in this end of the country look me up and we will go and have a potteraround the local area and get you a kolb fix Eddie ----- Original Message ----- From: "Pat Ladd" <pj.ladd(at)btinternet.com> Sent: Friday, January 04, 2013 4:56 PM Subject: Re: Kolb-List: Re: Antioch, CA > > Hi Eddie, > anybody Liverpool way want to buy my Mark 3 Xtra with Jabiru> > > Less than 100 hours and she has just been sitting (hangared) since the > last C of A as I am medically grounded. Not because I can`t fly but > because I cannot now handle the pulley hauley on the ground, pushing in > and out of the hangar, handling fuel etc. > > No reasonable (or unreasonable) offer refused. > > An absolute snip for someone. The kit alone is around 17K. I shall be > starting to advertise again now with Spring just around the corner (heh > heh) > > Happy New Year > > Pat > > > ________________________________________________________________________________
Date: Jan 05, 2013
they all run back to their nose wheel aircraft >> Hi Eddie, I still have a sticker on my car which says `Real pilots fly taildraggers` Cheers Pat ________________________________________________________________________________
Date: Jan 05, 2013
Paul, I suspect that you don`t want to come to the UK to look at my Kolb. Sorry about that. Of course if you DO. I am in the South of England and nowhere near Liverpool. Liverpool is in the uncouth Northern part of England where they talk funny and put salt on their porridge. (Sorry Eddie) Pat ________________________________________________________________________________
Subject: Engines
Date: Jan 05, 2013
I am soliciting opinions on the engines for the Kolb. I know this is going to vary. Do any of the engines have problems overheating in the pusher configuration of the KOLB? Which engine is the most reliable? 912? Is the 582 a bit underpowered in the Mark III? If you had a choice without consideration for the price differences, what engine would you choose? Wes -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=391641#391641 ________________________________________________________________________________
Subject: Engines
Date: Jan 05, 2013
I am soliciting opinions on the engines for the Kolb. I know this is going to vary. Do any of the engines have problems overheating in the pusher configuration of the KOLB? Which engine is the most reliable? 912? Is the 582 a bit underpowered in the Mark III? If you had a choice without consideration for the price differences, what engine would you choose? Wes -------- Wesley Elliott Wes E/Kolbers: I have never had an overheating problem with any of the Rotax or Cuyuna engines on Kolb aircraft. The 912 series engines are extremely reliable. I have been flying the 912 since 1994, before it was designated the 912UL. Presently flying with a 912ULS. The 582 has plenty power to fly the MKIII. That was my initial power plant on my MKIII. Lasted 220 hours before it seized. Suspected cold seizure. Thermostat was probably the contributing factor. I have flown well over 3,000 hours in front of the 912 series engines. That is the engine I choose to fly with. 912 is low maintenance. Change the oil, spark plugs, and clean the air filters, and you are good to go. john h Titus, Alabama ________________________________________________________________________________
Subject: Engines
Date: Jan 05, 2013
" I have been flying the 912 since 1994, before it was designated the 912UL " Not enough coffee this morning. Been flying the 912's since 1992, 21 years this coming March 15. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 05, 2013
Subject: Engines
A cure for the cold-seize-on the 582... -Manual radiator shutters. -You can even install a Vernier throttle cable to control them, then you can eliminate the thermostat altogether.-http://www.ultralightnews.com/fe atures/radshutters.htm Cold seize story... -http://www.reocities.com/hester-hoptown/582Tips/582t ips.html You will have to hold the mouse button down and drag to make the text show through the black "reocities" overlay... --- On Sat, 1/5/13, John Hauck wrote: From: John Hauck <jhauck(at)elmore.rr.com> Subject: RE: Kolb-List: Engines Date: Saturday, January 5, 2013, 8:03 AM I am soliciting opinions on the engines for the Kolb. I know this is going to vary. Do any of the engines have problems overheating in the pusher configuration of the KOLB? Which engine is the most reliable? 912? Is the 582 a bit underpowered in the Mark III? If you had a choice without consideration for the price differences, what engine would you choose? Wes -------- Wesley Elliott Wes E/Kolbers: I have never had an overheating problem with any of the Rotax or Cuyuna engines on Kolb aircraft. The 912 series engines are extremely reliable.- I have been flying the 91 2 since 1994, before it was designated the 912UL.- Presently flying with a 912ULS. The 582 has plenty power to fly the MKIII.- That was my initial power pla nt on my MKIII.- Lasted 220 hours before it seized.- Suspected cold seizur e. Thermostat was probably the contributing factor. I have flown well over 3,000 hours in front of the 912 series engines.- T hat is the engine I choose to fly with. 912 is low maintenance.- Change the oil, spark plugs, and clean the air filters, and you are good to go. john h Titus, Alabama le, List Admin. ________________________________________________________________________________
Subject: Engines
Date: Jan 05, 2013
A cure for the coldseizeon the 582... Manual radiator shutters. You can even install a Vernier throttle cable to control them, then you can eliminate the thermostat altogether. http://www.ultralightnews.com/features/radshutters.htm Kolbers: I cured the problem. After I rebuilt the 582, I traded it for an 80 hp 912. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 05, 2013
Subject: Re: Engines
Wes, The 582 has more than enough power for the Mk III C or X. I own a C and flew the X for a bit while restoring it for the owner. The problem is fuel cost. Even Rotax fuel comsumption graph shows a 5 gallon an hour fuel burn at 5800 rpm. Mine burns that no matter what I do. Then add the cost of oil, a bit less than a quart per hour and you're looking at $20 an hour to fly as long gas remains in the low $3 a gallon range. For cost and power, it's hard to beat the VW, although it's heavy compared to the 912. Having owned an HKS for seven years on my trike, that would be my engine of choice for purchase cost, weight, and low operating cost, but I have not tried it yet. The most important thing with a Mk III is weight. Keep it below 550 lb and performance with a 582 is great. Over 600 lb. and it is less. Rick Girard On Sat, Jan 5, 2013 at 8:07 AM, John Hauck wrote: > > > " I have been flying the 912 since 1994, before it was designated the > 912UL " > > > Not enough coffee this morning. Been flying the 912's since 1992, 21 years > this coming March 15. > > john h > mkIII > Titus, Alabama > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jan 05, 2013
Wes I was the first to fly a direct drive and now redrive VW on a Kolb. Its a good engine but if money was no object I would have put a Rotax 912 on it. Yes the VW has over heating problems on the ground. I have to limit run time on the ground but get airborne where air is moving through the cooling system there are no problems. But the VW is not sold as a engine package, it is easy to built and run these engines at high power levels that will overpower their ability to stay cool even in the air. Anything over 80-90 HP continuous is likely to over heat. I have no doubt that I will get flamed for this but The old reliable 912 isn't completely without issues. I just found out that the 912 powered Sport Cruisers that I normally rent in Florida have been sold because they just required too much maintenance. It seems that the high frequency vibration from these engines causes a bunch of metal fatigue issues with exhaust systems and other systems on and around these engines. Talk to any 912 driver that has any significant hours on their engines and they will report similar problems. Compared to higher RPM 2 stroke engines the issue is almost non existent. But compared to low RPM direct drive GA engines it is a problem. As usual worth what you paid for it. Rick Neilsen Redrive VW powered MKIIIC On Sat, Jan 5, 2013 at 8:32 AM, alienwes wrote: > > I am soliciting opinions on the engines for the Kolb. I know this is going > to vary. > > Do any of the engines have problems overheating in the pusher > configuration of the KOLB? > > Which engine is the most reliable? 912? > > Is the 582 a bit underpowered in the Mark III? > > If you had a choice without consideration for the price differences, what > engine would you choose? > > Wes > > -------- > Wesley Elliott > Sport Pilot-PPC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=391641#391641 > > ________________________________________________________________________________
Subject: Engines
Date: Jan 05, 2013
I have no doubt that I will getflamedfor this but The old reliable 912 isn'tcompletelywithout issues. I just found out that the 912 powered Sport Cruisers that I normally rent in Florida have been sold because they just required too much maintenance. It seems that the high frequency vibration from these engines causes a bunch of metal fatigue issues withexhaustsystems and other systems on and around these engines. Talk to any 912 driver that has any significant hours on their engines and they will reportsimilarproblems.Comparedto higher RPM 2 stroke engines the issue is almost nonexistent. Butcomparedto low RPM direct drive GA enginesit is a problem. As usual worth what you paid for it. Rick Neilsen Rick N/Kolbers: I've been doing this a long time, both two and four stroke engines. The old reliable 912 is just that. If the aircraft you reference had vibration problems, it was caused by prop balance and/or engine mounts. Not the engine, unless they let the carbs get excessively out of sync. As I said in an earlier post, the 912 is a low maintenance engine. Don't know if I am a high time 912 owner or not, but over 3,000.0 hours of 912 time in my MKIII, plus quite a few hours in Kolb Factory aircraft powered by the 912, over the years, I have not experienced the problems you describe. This is the first time I have heard of this problem with the 912 series engines. Based on my experience, there is no comparison between a two and four stroke Rotax. I personally prefer the 912 over a GA recip engine, and that is based on actual flight experience over some very hostile terrain in the Lower 48, Canada, and Alaska. You probably don't have a lot of actual experience flying a 912 powered Kolb aircraft. Because an engine is designed to operate at higher rpm's does not mean it is going to tear itself apart. That is the mentality that a lot of GA types have when comparing a slow turning Lycoming or Continental. The torsion vibration of a 912 is controlled by a very effective system. GA recip engines have no damper. Correct me if I am wrong, but your VW redrive system uses slippage in the drive belt to dampen torsion vibration. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 04, 2013
None taken Pat ----- Original Message ----- From: "Pat Ladd" <pj.ladd(at)btinternet.com> Sent: Saturday, January 05, 2013 11:54 AM Subject: Re: Kolb-List: Re: Antioch, CA > > Paul, > I suspect that you don`t want to come to the UK to look at my Kolb. > > Sorry about that. > > Of course if you DO. I am in the South of England and nowhere near > Liverpool. > > Liverpool is in the uncouth Northern part of England where they talk funny > and put salt on their porridge. > (Sorry Eddie) > > Pat > > > ________________________________________________________________________________
Date: Jan 05, 2013
John I don't think I said that there was engine reliability problem. I think it can be safely said that the 912 series of engine are just as reliable as a GA engine maybe more so. But the high frequency vibration of these engines even when properly maintained takes a toll on engine systems. It is fairly common to have a GA exhaust system remain crack free to the engines TBO and well beyond. Can you honestly say that about the exhaust systems on your airplane or others we fly with? You talk about letting the carbs get out of sync, isn't that maintenance, is this effected by vibration? How often does a GA engine have to have its carbs synced. Seems like you guys frequently replace the rubber carb sockets or what ever you call them. My point was, it is all based on your point of reference. A two stroke driver would think that a 912 is extremely reliable some would say bullet proof. A aircraft rental FBO that is used to maintaining GA airplanes would consider having to replace carb sockets, exahust systems, syncing carbs and other things as unreliable even if the engine runs just as long. On my last check ride my instructor commented that my VW was smoother than his 912. And yes my drive belts slip every minute my engine is running. I inspect them every time I fly and adjust them after the first hour and about every 40-80 hours. I can tell when the belts need adjusting when the RPMs start increasing over my normal full throttle climb RPM. I replace them every 100-200 hours or no more than two years. What was your point? I will say it again if money was no object I would be flying a 912 or a GA engine if they weren't so blessed heavy. Rick Neilsen Redrive VW Powered MKIIIC Rick Neilsen On Sat, Jan 5, 2013 at 11:13 AM, John Hauck wrote: > > > I have no doubt that I will get flamed for this but The old reliable 912 > isn't completely without issues. I just found out that the 912 powered > Sport > Cruisers that I normally rent in Florida have been sold because they just > required too much maintenance. It seems that the high frequency vibration > from these engines causes a bunch of metal fatigue issues > with exhaust systems and other systems on and around these engines. Talk to > any 912 driver that has any significant hours on their engines and they > will > report similar problems. Compared to higher RPM 2 stroke engines the issue > is almost non existent. But compared to low RPM direct drive GA engines it > is a problem. > > As usual worth what you paid for it. > > Rick Neilsen > > > Rick N/Kolbers: > > I've been doing this a long time, both two and four stroke engines. > > The old reliable 912 is just that. If the aircraft you reference had > vibration problems, it was caused by prop balance and/or engine mounts. > Not > the engine, unless they let the carbs get excessively out of sync. As I > said in an earlier post, the 912 is a low maintenance engine. > > Don't know if I am a high time 912 owner or not, but over 3,000.0 hours of > 912 time in my MKIII, plus quite a few hours in Kolb Factory aircraft > powered by the 912, over the years, I have not experienced the problems you > describe. > > This is the first time I have heard of this problem with the 912 series > engines. > > Based on my experience, there is no comparison between a two and four > stroke > Rotax. > > I personally prefer the 912 over a GA recip engine, and that is based on > actual flight experience over some very hostile terrain in the Lower 48, > Canada, and Alaska. > > You probably don't have a lot of actual experience flying a 912 powered > Kolb > aircraft. > > Because an engine is designed to operate at higher rpm's does not mean it > is > going to tear itself apart. That is the mentality that a lot of GA types > have when comparing a slow turning Lycoming or Continental. The torsion > vibration of a 912 is controlled by a very effective system. GA recip > engines have no damper. Correct me if I am wrong, but your VW redrive > system uses slippage in the drive belt to dampen torsion vibration. > > john h > mkIII > Titus, Alabama > > ________________________________________________________________________________
Subject: Engines
Date: Jan 05, 2013
I've sync'd the carbs on my present 912uls twice in 619.1 hours. The first time was when I mounted the zero time engine. When a 912 carb gets out of sync it is because cable stretch and normal hardware wear. Not because of a high freq vibration. If there is vibration, as I said in my last post, it is because of prop and engine mounts. How many GA engines have dual carbs? None that I know of right off hand. I've never flown in your airplane. You have flown in mine at Monument Valley, UT. You know which aircraft has the smoothest running engine and prop. I forgot what my point was, but seems ramped dogs and a slip clutch is a better system for torsion vibration damping than a slipping belt. I've replaced the carb sockets on my present 912uls once. I think that was last year. Been flying that engine since 13 Apr 2007. On my second exhaust system now. The initial system was designed by and manufactured for Rick Thomason to fly on an enclosed tractor, the Starlite. Didn't realize it at the time, but was poorly designed and built. John W and I both flew with that system. They came apart, not because of high freq vibration, but poor quality. Replaced with a Titan system that is working great. If an engine has a high frequency vibration problem, it doesn't take long for it to start showing up with cracked tubing in the airframe, especially with the engine mount system we use on Kolb Aircraft. I can see where carb sockets would not last as long on an enclosed tractor compared to an open pusher. There is a lot of heat inside that cowling, especially on the ground. john h mkIII Titus, Alabama But the high frequency vibration of these engines even when properly maintained takes a toll on engine systems. It is fairly common to have a GA exhaust system remain crack free to the engines TBO and well beyond. Can you honestly say that about the exhaust systems on your airplane or others we fly with? You talk about letting the carbs get out of sync, isn't that maintenance, is this effected by vibration? How often does a GA engine have to have its carbs synced. Seems like you guys frequently replace the rubber carb sockets or what ever you call them. My point was, it is all based on your point of reference. A two stroke driver would think that a 912 is extremely reliable some would say bullet proof. A aircraft rental FBO that is used to maintaining GA airplanes would consider having to replace carb sockets, exahust systems, syncing carbs and other things as unreliable even if the engine runs just as long. On my last check ride my instructor commented that my VW was smoother than his 912. And yes my drive belts slip every minute my engine is running. I inspect them every time I fly and adjust them after the first hour and about every 40-80 hours. I can tell when the belts need adjusting when the RPMs start increasing over my normal full throttle climb RPM. I replace them every 100-200 hours or no more than two years. What was your point? I will say it again if money was no object I would be flying a 912 or a GA engine if they weren't so blessed heavy. Rick Neilsen Redrive VW Powered MKIIIC Rick Neilsen On Sat, Jan 5, 2013 at 11:13 AM, John Hauck wrote: I have no doubt that I will get flamed for this but The old reliable 912 isn't completely without issues. I just found out that the 912 powered Sport Cruisers that I normally rent in Florida have been sold because they just required too much maintenance. It seems that the high frequency vibration from these engines causes a bunch of metal fatigue issues with exhaust systems and other systems on and around these engines. Talk to any 912 driver that has any significant hours on their engines and they will report similar problems. Compared to higher RPM 2 stroke engines the issue is almost non existent. But compared to low RPM direct drive GA engines it is a problem. As usual worth what you paid for it. Rick Neilsen Rick N/Kolbers: I've been doing this a long time, both two and four stroke engines. The old reliable 912 is just that. If the aircraft you reference had vibration problems, it was caused by prop balance and/or engine mounts. Not the engine, unless they let the carbs get excessively out of sync. As I said in an earlier post, the 912 is a low maintenance engine. Don't know if I am a high time 912 owner or not, but over 3,000.0 hours of 912 time in my MKIII, plus quite a few hours in Kolb Factory aircraft powered by the 912, over the years, I have not experienced the problems you describe. This is the first time I have heard of this problem with the 912 series engines. Based on my experience, there is no comparison between a two and four stroke Rotax. I personally prefer the 912 over a GA recip engine, and that is based on actual flight experience over some very hostile terrain in the Lower 48, Canada, and Alaska. You probably don't have a lot of actual experience flying a 912 powered Kolb aircraft. Because an engine is designed to operate at higher rpm's does not mean it is going to tear itself apart. That is the mentality that a lot of GA types have when comparing a slow turning Lycoming or Continental. The torsion vibration of a 912 is controlled by a very effective system. GA recip engines have no damper. Correct me if I am wrong, but your VW redrive system uses slippage in the drive belt to dampen torsion vibration. john h mkIII Titus, Alabama arget="_blank">http://www.matronics.com/Navigator?Kolb-List
October 20, 2012 - January 05, 2013
Kolb-Archive.digest.vol-mk
