Kolb-Archive.digest.vol-mo
June 15, 2013 - August 17, 2013
Subject: Re: Microburst topples Kolb Trailer - Injures my Firestar -2
Date: Jun 15, 2013
Mahesh, Sorry to hear about your loss. It's nothing but heartache, but if you can find it in yourself to rebuild your Firestar, you will be a happier man. One attitude worth taking is to tell yourself that you can rebuild it better than it was before and maybe add a few things that you thought about when building it the first time. Once it's flying again, this tragedy will be a fading memory. Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 26 years flying it Kolbra 912ULS N20386 200 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402733#402733 ________________________________________________________________________________
Date: Jun 15, 2013
Thanks Ralph. I agree! I am planning to bring about a few modification to my Trailer. I plant to weld eyebolts on to the bottom and top so that I can strap it down just like a tiedown....Earthquake would be the only concern then :-)) Mahesh Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402736#402736 ________________________________________________________________________________
Subject: Jig To Install Hinges
Date: Jun 15, 2013
The picture shows a jig which immobilizes the hinge in position for drilling. -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402738#402738 Attachments: http://forums.matronics.com//files/firefly_may13_028_536.jpg ________________________________________________________________________________
Subject: Jip To Cut Bushings
Date: Jun 15, 2013
Bushing can be cut square to an exact length. Use bee's wax on hacksaw. -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402739#402739 Attachments: http://forums.matronics.com//files/009_348.jpg ________________________________________________________________________________
Subject: Sport Instructor Central Ohio
Date: Jun 15, 2013
http://www.heavenboundaviation.com/ Aircraft Dealer, Engine Dealer/Rebuilder, Airfield, Electronics. Cell: 740-644-4690 Address: 8878 Harmony Church Rd., Johnstown, OH 43031 -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402741#402741 ________________________________________________________________________________
Subject: IVO Prop Vs Warp Drive - Rotax 503 - FS2 - Advice
Date: Jun 15, 2013
Kolbers, I have to replace two of my current 3 blade 72" IVO Props because of the microburst impact for my Rotax 503. Should I switch to a 3 blade warp drive or just stick to IVO. On the forum I have heard good things on the warp drive prop and since they cost almost the same, I wanted some input from you all and then proceed ahead! Thanks in advance! Mahesh Iyer FS-2, Rotax -503 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402755#402755 ________________________________________________________________________________
Date: Jun 15, 2013
Should I switch to a 3 blade warp drive or just stick to IVO. On the forum I have heard good things on the warp drive prop and since they cost almost the same, I wanted some input from you all and then proceed ahead! Thanks in advance! Mahesh Iyer FS-2, Rotax -503 Mahesh/Kolbers: If I was in your shoes, I'd go with a two blade Warp Drive. Been flying with Warp Drive since 1993. That equates to well over 3,000 hours on my old MKIII without a prop problem. john h mkIII Somewhere between KC, MO, and Lincoln, NE. ________________________________________________________________________________
Subject: Re: IVO Prop Vs Warp Drive - Rotax 503 - FS2 - Advice
Date: Jun 15, 2013
Thanks John. What was the length of your prop? Will it give me the same thrust as a three blade IVO. Are there any advantages, disadvantages of a two blade vs a three blade? Appreciate your input! Mahesh Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402763#402763 ________________________________________________________________________________
Date: Jun 15, 2013
What was the length of your prop? Will it give me the same thrust as a three blade IVO. Are there any advantages, disadvantages of a two blade vs a three blade? Appreciate your input! Mahesh Mahesh/Kolbers: Talk with Daryl at Warp Drive. He will give you the correct length. The two blade Warp has several advantages over the three blade: -weight savings of one blade. -overall height of the aircraft is reduced for storage. john h mkIII Grand Island, NE ________________________________________________________________________________
Date: Jun 15, 2013
> >..........Should I switch to a 3 blade warp drive or just stick to IVO. On the forum I have heard good things on the warp drive prop and since they cost almost the same, I wanted some input from you all and then proceed ahead! > Mahesh, Check out the spec for your gear box to find out the maximum propeller moment of inertia it can swing. Also remember that the smaller the propeller moment of inertia the easier it is for the propeller to absorb the engine torque impulses due to individual cylinder/piston firing impulses. This also translates to less engine generated vibration being transmitted to engine crank, gear box, the cage and gives a smoother ride. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Subject: Re: Sport aviation mag.....
Date: Jun 15, 2013
http://www.contactmagazine.com/FreeLunch.html -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402773#402773 ________________________________________________________________________________
Date: Jun 15, 2013
http://www.contactmagazine.com/FreeLunch.html -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402774#402774 ________________________________________________________________________________
Date: Jun 15, 2013
http://www.contactmagazine.com/FreeLunch.html -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402776#402776 ________________________________________________________________________________
Date: Jun 15, 2013
Thank you John and Jack. I have a 2.28 'B' Box and my current prop is a 3 blade 72 Inch IVO. It has never given me an issues in the last 8 years, Did well on climb and cruise, but if there something better out there in the market then I will surely like to try it out! Mahesh Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402778#402778 ________________________________________________________________________________
Date: Jun 16, 2013
A friend who has run both has told me the Warp produced a lot more thrust than a same sized Ivo on a 503 Phantom he used to own. The Warp is way tougher. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA On Jun 15, 2013, at 4:23 PM, "miyer2u" wrote: > > Kolbers, > I have to replace two of my current 3 blade 72" IVO Props because of the microburst impact for my Rotax 503. > > Should I switch to a 3 blade warp drive or just stick to IVO. On the forum I have heard good things on the warp drive prop and since they cost almost the same, I wanted some input from you all and then proceed ahead! > > Thanks in advance! > > Mahesh Iyer > FS-2, Rotax -503 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402755#402755 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 16, 2013
In a message dated 6/16/2013 12:41:39 A.M. Eastern Daylight Time, miyer2u(at)yahoo.com writes: I have a 2.28 'B' Box and my current prop is a 3 blade 72 Inch IVO. It has never given me an issues in the last 8 years, Did well on climb and cruise, but if there something better out there in the market then I will surely like to try it out! Mahesh Check with the Warp factory, but I think you will find the Warp is way too heavy for a "B" box. Having said that, I ran a 68" 3 blade Warp with taper tips on my FS II.. I had a "C" box w/ 3.47=1 ratio. I could out=climb every other FS around. It is the toughest prop there is. Shack ________________________________________________________________________________
Date: Jun 16, 2013
Thanks I will check it out..... -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402821#402821 ________________________________________________________________________________
Date: Jun 16, 2013
Mahesh I have run both props in these recomendations. The cruise was faster on the two blade Warp by 3 or 4mph but the IVO better in take off. the IVO was definately noticably smoother. On a Mark III or heavy airplane I would definately use the Warp but for an Ulltralight I prefer the smoother IVO. I have recently swapped my 3 Blade 60" IVO onto a 503 powered Firestar KXP that had a 64" Warp tapered tip and that owner really liked the IVO better but could not afford at at this time. I have it for sale for $350 plus shipping. It is in excellant shape with all new quick adjust hub 67 hours ago. I kept it when I sold my Firestar several years ago intending to use it on my next UL but bought a Mark III instead. I do like the Warp for its durability but liked the IVO better on the Firestar. Both good props for that airplane. You can contact me off list if you want it. PS 2.58-1 was the gearbox ratio on mine and the 503 that we just installed it on. Dennis Long -------- Dennis Long Oakland TN 2000 Aeroprakt A20 Vista Cruiser Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar. 600+hours since 1/1/2009 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402824#402824 ________________________________________________________________________________
Date: Jun 17, 2013
Subject: Kolb MKIIIX 06/16/13
Hello Kolbers: I am giving serious thought to selling my MKIIIX project. It has a new Gr eat Plains Aviation 2180 c.c. VW engine built by Steve. Never been run. Dual ignition and Valley Engineering re-drive with new wood prop as recomme nded by GPAS. The wings, flaperons, horizontal stabilizers, elevators, ver tical stabilizers and rudder are all complete through color coat. (Nevada S ilver). The cabin area is where I have been working when able to do so re cently. Have not installed brake system, fuel, system, pitot system and th ough I have the battery mounted I have not wired the system as of yet. I do have the plane registered with an "N" number but I am thinking there is enough work left to be done to say I have done a little over 40%. I assemb led and rigged the airframe before starting to cover the individual pieces. Everything needed to complete this project goes with it. The only exception would be if the future builder made changes to accommoda te his preferences. If there is any one seriously interested or if you men that have sold a pro ject have any recommendations write to me at my BG285P(at)yahoo.com email add ress. Bob Green ________________________________________________________________________________
Subject: Joining the Club
Date: Jun 17, 2013
Hi All, Recently I purchased a Kolb MkIII Classic from John Bickham. Many of you have seen this plane and/or the videos and blogs he has posted. He did a great job on the plane and when I got in the market for a Kolb, friends pointed me towards his as one of the best around. He is chest deep in another plane building project at this time. Although in my younger days I had flown quite a bit and owned a Stinson 108-2, I had not owned or flown a plane for about 28 years. When I got the bug again I begin to research the kind of plane I wanted and to take some lessons in a Citabria and then in a Cub to see if I could still do it. I settled on the Kolb MKIII and began looking for a good one while getting some flight time in at the same time. John and I came to an agreement and he flew the plane down to where I live, here south of Houston. I had hoped to get some dual in the Kolb or some type of ultralight but finding anyone to provide that proved to be frustrating. John had given me all the tips he could and I had spend many hours pouring over the many posts here in the lists, reading and viewing the videos. John had recommended I get several hours in just sitting in the Kolb and getting used to the visual and then doing quite a bit of taxing. I did that over the course of a week or so, gradually working up to some fairly high speed taxis with the tail up. Last Thursday I went up in the Cub again and did about 10 landings just to get my confidence up and then Friday morning I went out to my hanger with the idea that if it felt good I would go for it. It did and I did. There was no wind and the takeoff was uneventful. Climbed out at about 55-60 knots, 912 sounding good. Climbed to 2500' just circling the airfield (no traffic on this little 2000' grass strip). Settled into cruise to get a good idea of the visual horizon at level flight. Did some turns and trim adjustments for various speeds and rpm settings. Worked on decent speeds and practiced leveling out and then went down to 1000' agl and did some turns around a point. I then returned to the field and did a practice approach with the idea of simulating the landing at a couple of hundred feed. That went pretty well so I decided to try one for real. I flew the last part of the pattern at about 50 knots adjusting my decent rate with the throttle. About 3400rpm seemed to be giving me the gentle decent I wanted for this first attempt. Turned final and I could see I was a little high. I came on down a bit and since I was about half way down the field I throttled up and climbed out again after getting down to about 10 feet or so. Climbed back up into the pattern to try again. Same basic approach but pulled the throttle off and kept the nose down to hold 50knots. As I approached my touchdown point I eased the nose up and added a bit of throttle, felt the wheels touch (! probably doing about 40knots here) and pushed the nose forward a bit to keep her down and closed the throttle. Pulled the tail down after we slowed and we were home. Not a 'KOLB' landing but I felt pretty good anyway. I did a little more flying that day and over the weekend and now that I have a few hours and several landings I can say that I enjoy flying this plane more than I have any other. It seems very forgiving and although I like the Cub it feels very 'loosey goosey' compared to this MKIII. Ground handling is great and so far (knock on wood) it has been very forgiving of my ham handed efforts. I will say that I now know what nervous means. After not soloing anything for almost 30 years and never flying an ultralight of any kind I was definitely there but the Kolb didn't let me down. Thanks for all the input I got from you guys that helped make this (so far) a successful and fun experience. Thanks, Allan Garvin Kolb MKIII N308JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402878#402878 ________________________________________________________________________________
Date: Jun 17, 2013
Subject: Re: Joining the Club
I know that you will like the plane, it has been to my house and did quite well, although the guy flying it was a bit nervous. :-) Take the landings slowly, and let yourself get used to it, and things will be more fun than you have ever had. Welcome, Larry Cottrell On Mon, Jun 17, 2013 at 10:59 AM, Larlaeb wrote: > > Hi All, > Recently I purchased a Kolb MkIII Classic from John Bickham. Many of you > have seen this plane and/or the videos and blogs he has posted. He did a > great job on the plane and when I got in the market for a Kolb, friends > pointed me towards his as one of the best around. He is chest deep in > another plane building project at this time. Although in my younger days I > had flown quite a bit and owned a Stinson 108-2, I had not owned or flown a > plane for about 28 years. When I got the bug again I begin to research the > kind of plane I wanted and to take some lessons in a Citabria and then in a > Cub to see if I could still do it. I settled on the Kolb MKIII and began > looking for a good one while getting some flight time in at the same time. > John and I came to an agreement and he flew the plane down to where I > live, here south of Houston. > > I had hoped to get some dual in the Kolb or some type of ultralight but > finding anyone to provide that proved to be frustrating. John had given me > all the tips he could and I had spend many hours pouring over the many > posts here in the lists, reading and viewing the videos. John had > recommended I get several hours in just sitting in the Kolb and getting > used to the visual and then doing quite a bit of taxing. I did that over > the course of a week or so, gradually working up to some fairly high speed > taxis with the tail up. Last Thursday I went up in the Cub again and did > about 10 landings just to get my confidence up and then Friday morning I > went out to my hanger with the idea that if it felt good I would go for it. > It did and I did. There was no wind and the takeoff was uneventful. > Climbed out at about 55-60 knots, 912 sounding good. Climbed to 2500' > just circling the airfield (no traffic on this little 2000' grass strip). > Settled into cruise to get a good idea of! > the visual horizon at level flight. Did some turns and trim adjustments > for various speeds and rpm settings. Worked on decent speeds and practiced > leveling out and then went down to 1000' agl and did some turns around a > point. I then returned to the field and did a practice approach with the > idea of simulating the landing at a couple of hundred feed. That went > pretty well so I decided to try one for real. I flew the last part of the > pattern at about 50 knots adjusting my decent rate with the throttle. > About 3400rpm seemed to be giving me the gentle decent I wanted for this > first attempt. Turned final and I could see I was a little high. I came > on down a bit and since I was about half way down the field I throttled up > and climbed out again after getting down to about 10 feet or so. Climbed > back up into the pattern to try again. Same basic approach but pulled the > throttle off and kept the nose down to hold 50knots. As I approached my > touchdown point I eased th! > e nose up and added a bit of throttle, felt the wheels touch (! > probably > > doing about 40knots here) and pushed the nose forward a bit to keep her > down and closed the throttle. Pulled the tail down after we slowed and we > were home. Not a 'KOLB' landing but I felt pretty good anyway. I did a > little more flying that day and over the weekend and now that I have a few > hours and several landings I can say that I enjoy flying this plane more > than I have any other. It seems very forgiving and although I like the Cub > it feels very 'loosey goosey' compared to this MKIII. Ground handling is > great and so far (knock on wood) it has been very forgiving of my ham > handed efforts. I will say that I now know what nervous means. After not > soloing anything for almost 30 years and never flying an ultralight of any > kind I was definitely there but the Kolb didn't let me down. Thanks for > all the input I got from you guys that helped make this (so far) a > successful and fun experience. > > Thanks, > Allan Garvin > > Kolb MKIII N308JB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402878#402878 > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: Mike Pres
Date: Jun 17, 2013
I didn't send this so be ware Mike Sent from my iPad On Jun 17, 2013, at 4:43 PM, Mike Pres wrote: > How are you? > http://www.bitangmbh.de/bryhn/pe/z/tjl/tpv/y.html > > > > > > Mike Pres ________________________________________________________________________________
Date: Jun 17, 2013
Thank you all! Mahesh Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402914#402914 ________________________________________________________________________________
Date: Jun 18, 2013
Not my best but a record of an early attempt. https://docs.google.com/file/d/0BxdXwdWJkFExSlR5UkhGZmJFN2M/edit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402947#402947 ________________________________________________________________________________
Date: Jun 18, 2013
Subject: http://stores.shop.ebay.com/ROTAX-RECREATIONAL-ENGINES-LLC
Kolbers , Hi , has anyone ever done business with these folks?- http://st ores.shop.ebay.com/ROTAX-RECREATIONAL-ENGINES-LLC in Paridise Mi. thanks Ch ris=0A=0AChris Davis=0AKXP 503 492 hrs=0AGlider pilot=0ADisabled from crash building Firefly ________________________________________________________________________________
Date: Jun 18, 2013
Lar, great video , it just so happens that I hear that song in my head ever y time I fly!! Thank you for great video , audio compilation Chris=0A=0A=0A Chris Davis=0AKXP 503 492 hrs=0AGlider Pilot=0ADisabled from crash building Firefly=0A=0A=0A>________________________________=0A> From: Larlaeb <larla eb(at)gmail.com>=0A>To: kolb-list(at)matronics.com =0A>Sent: Tuesday, June 18, 20 13 12:00 PM=0A>Subject: Kolb-List: Re: Joining the Club=0A> =0A>=0A>--> Ko lb-List message posted by: "Larlaeb" =0A>=0A>Not my best but a record of an early attempt.=0A>=0A>https://docs.google.com/file/d/0B xdXwdWJkFExSlR5UkhGZmJFN2M/edit=0A>=0A>=0A>=0A>=0A>Read this topic online h ere:=0A>=0A>http://forums.matronics.com/viewtopic.php?p=402947#402947=0A> - - - - - - - - - - - - -Matt Dralle, List Admin. =======0A>=0A>=0A>=0A>=0A>=0A> ________________________________________________________________________________
Date: Jun 19, 2013
Nice pics but with all the music in the world to choose from why use that awful row?. Flying is a gentle, smooth and quiet experience. Some Mozart or Puccini, a Waltz perhaps. Look what 2001 did with The Blue Danube as the soundtrack to the approach to the Space Station. Your soundtrack would be a good backing for a wrestling match. I can always tune the sound out I suppose More pictures please Nit picking Old Git Pat ________________________________________________________________________________
Date: Jun 19, 2013
Well, music is always a matter of taste and I certainly appreciate the good classical selections you propose however I don't agree that flying is 'always' a gentle and quiet experience and I selected something that I thought might help convey the nervous anxiety of my first solo in almost 30 years. I promise if I do more of these I'll be using some more melodious background stuff. :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402982#402982 ________________________________________________________________________________
Date: Jun 19, 2013
I don't think I would worry about it all that much. Use what you would like and what it means to you. There is no way to please everyone in this crowd. :-) Like he says there are two buttons on everyone's computer, mute and delete, one of which should make it tolerable. I am interested in what you used for a camera and where you mounted it. Larry On Wed, Jun 19, 2013 at 6:41 AM, Larlaeb wrote: > > Well, music is always a matter of taste and I certainly appreciate the > good classical selections you propose however I don't agree that flying is > 'always' a gentle and quiet experience and I selected something that I > thought might help convey the nervous anxiety of my first solo in almost 30 > years. I promise if I do more of these I'll be using some more melodious > background stuff. :D > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402982#402982 > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jun 19, 2013
The camera and mount I inherited from John who was experimenting with the best mount and location. The camera is a Tachyon XC which is fairly old (for this type of technology) but seems to work well and I know they have newer versions available with more bells and whistles. The mount is on the upper part of the windshield which I probably would not have done but from a camera location perspective is pretty good. There is a wireless remote that can start and stop the video from inside. He has four bolts through the windshield with foam padding on both sides of a metal plate and the camera mounts to the plate. A safety wire passes through the camera latch to hopefully keep the thing out of the prop on a hard landing. I attached a picture that shows the location. I can take a closeup and submit it later if you are interested. Thanks, Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402986#402986 Attachments: http://forums.matronics.com//files/kolb_with_912_175.jpg ________________________________________________________________________________
Date: Jun 19, 2013
Where are the jury struts on that fine specimen of a Mk3? Dennis Rowe Mk 3, N616DR 690L-70, Powerfin > > > > > Attachments: > > http://forums.matronics.com//files/kolb_with_912_175.jpg > > > > > > > ________________________________________________________________________________
Date: Jun 19, 2013
They may have fallen off on my first few landing attempts.... [Embarassed] However I don't recall seeing any on a MKIII other than the one owned by John Hauck. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403002#403002 ________________________________________________________________________________
Date: Jun 19, 2013
They may have fallen off on my first few landing attempts.... [Embarassed] However I don't recall seeing any on a MKIII other than the one owned by John Hauck. Kolbers: In 1991, jury struts were included in the plans for the MKIII. Homer Kolb asked me to put jury struts on my MKIII when we were building it at the factory in Feb 1991. Gave me some 4130 stream lined material to make them. Figured if I put them on my MKIII that others would follow suit. It didn't work. john h mkIII Rock House, Burns Junction, Oregon ________________________________________________________________________________
Date: Jun 19, 2013
Okay, I thought they all had them.y kit was a 91 kit that I bought half built in 97, and completed in 03. I have the streamlined aluminum struts, wouldn't feel comfortable doing pushovers without the jury struts. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA On Jun 19, 2013, at 2:15 PM, "John Hauck" wrote: > > > > > They may have fallen off on my first few landing > attempts.... [Embarassed] However I don't recall seeing any > on a MKIII other than the one owned by John Hauck. > > > > Kolbers: > > In 1991, jury struts were included in the plans for the > MKIII. > > Homer Kolb asked me to put jury struts on my MKIII when we > were building it at the factory in Feb 1991. Gave me some > 4130 stream lined material to make them. Figured if I put > them on my MKIII that others would follow suit. It didn't > work. > > john h > mkIII > Rock House, Burns Junction, Oregon > > > > > > ________________________________________________________________________________
Date: Jun 19, 2013
On 06/19/2013 04:50 AM, Pat Ladd wrote: > Nice pics but with all the music in the world to choose from why use > that awful row?. > Flying is a gentle, smooth and quiet experience. Some Mozart or > Puccini, a Waltz perhaps. Look what 2001 did with The Blue Danube as > the soundtrack to the approach to the Space Station. > Your soundtrack would be a good backing for a wrestling match. > I can always tune the sound out I suppose > More pictures please > Nit picking Old Git > Pat > *So, Pat, if it's got to be classical, what do you think about Stravinsky? ;-) Ya gotta be careful about dissing another's taste in music(especially if it's by a good-ole-boy risingfrom Mississippi roots). Next thing you know, you'll have to defend your choice of airplanes, too. A lot of the pilots I know won't fly in an experimental, much less some 'ultralite', but if if I had to fly their planes, I'd stay home on the couch. I'm pretty sure that the same would apply to musical tastes. Charlie (come on down & visit us at Slobovia Outernational, a 45 minute flight from Leland) ** * ________________________________________________________________________________
Date: Jun 19, 2013
I thought might help convey the nervous anxiety of my first solo in almost 30 years.>> It certainly did that. Congrats on your flight I look forward to more videos optically and aurally Cheers Pat ________________________________________________________________________________
Date: Jun 20, 2013
I promise not to keep doing these until I get something more impressive to look at but I went out and did a few more landings this morning and made this to address Pat's concerns (and cause I like it). :) https://drive.google.com/?tab=mo&authuser=0#my-drive Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403043#403043 ________________________________________________________________________________
Subject: Share your Passion 'Dusty Crophopper'
Date: Jun 20, 2013
With the dwindling numbers of young pilots a concern to all of us, here is a great new film to inspire young people and generate some interest in aviation.....Share your Passion! http://www.youtube.com/watch?v=qfnWYHO7Id4 Its officially official: Disneys Cars spinoff Planes is getting a theatrical release after all. Though the film was initially set for a direct-to-DVD release, hints started surfacing this past summer that Disney was considering releasing the film theatrically instead, as John Lasseter had grown particularly fond of the pic. Today, Disney announced that Planes will indeed open in theaters on August 9, 2013. That puts it opposite Neill Blomkamps sci-fi film Elysium and the Jennifer Aniston/Jason Sudeikis comedy Were the Millers. As one can surmise, Planes takes place in Cars terrifying world of anthropomorphic vehicles and centers on an eclectic international cast of the aerial variety. The story focuses on Dusty, a small town dreamer who longs to enter the most epic around-the-world air race despite his fear of heights. Essentially its a cross between Cars and the atrocious Cars 2, but with planes. The film is not, however, being produced by Pixar. -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403051#403051 Attachments: http://forums.matronics.com//files/slice_planes_disney_toon_studios_pixar_103.jpg ________________________________________________________________________________
Date: Jun 20, 2013
Subject: Re: Share your Passion 'Dusty Crophopper'
I was afraid that something like this would happen when I saw that you had put a child's seat in your Firestar. :-) A mostly innocent victim of temptation, Larry On Thu, Jun 20, 2013 at 1:02 PM, Dennis Thate wrote : > > With the dwindling numbers of young pilots a concern to all of us, here i s > a great new film to inspire young people and generate some interest in > aviation.....Share your Passion! > > > http://www.youtube.com/watch?v=qfnWYHO7Id4 > > > It=92s officially official: Disney=92s Cars spinoff Planes is getting a > theatrical release after all. Though the film was initially set for a > direct-to-DVD release, hints started surfacing this past summer that Disn ey > was considering releasing the film theatrically instead, as John Lasseter > had grown particularly fond of the pic. Today, Disney announced that > Planes will indeed open in theaters on August 9, 2013. That puts it > opposite Neill Blomkamp=92s sci-fi film Elysium and the Jennifer > Aniston/Jason Sudeikis comedy We=92re the Millers. > > As one can surmise, Planes takes place in Cars=91 terrifying world of > anthropomorphic vehicles and centers on an eclectic international cast of > the aerial variety. The story focuses on Dusty, =93a small town dreamer who > longs to enter the most epic around-the-world air race=85 despite his fea r of > heights.=94 Essentially it=92s a cross between Cars and the atrocious Ca rs 2, > but with planes. The film is not, however, being produced by Pixar. > > -------- > Both optimists and pessimists contribute to our society. The optimist > invents the airplane and the pessimist the parachute. ~Gil Stern > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403051#403051 > > > Attachments: > > > http://forums.matronics.com//files/slice_planes_disney_toon_studios_pixar _103.jpg > > =========== =========== =========== =========== > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Pre-Purchase Inspection, Firestar
Date: Jun 22, 2013
Greetings to the Collective - new member here. A little background on me: 57 y/o A&P, Fixed-wing pilot (been out of flying/aviation for the last 10-yrs). Wanting to get back to flying but on a tight budget. Interested in UL's and Powered Paragliders. The Kolbs appear to me to be most like 3-axis general aviation aircraft that I'm very familiar with so I think it might be the route to go especially since it's easy to store. I found a deal on a Firestar, 477 Rotax, 90 TT AF & Eng. Built in '96. Obviously sat for awhile but has been recently flown. I'm concerned about UL light wing loading. Can I expect to fly it as I would the Taylorcraft BC12D I used to own? The only differing characteristic I've seen addressed is the landing flares. What are the things - airframe & engine I should be particularly attentive to in inspecting for issues before I decide to close a sale on it? Thanks, Paul -------- "A good traveller has no fixed plans and is not intent on arriving" Lao Tzu (570-490 BC) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403143#403143 ________________________________________________________________________________
Subject: Re: Pre-Purchase Inspection, Firestar
Date: Jun 22, 2013
Greeting Paul, welcome to the group. Since I just did my annual yesterday, I would suggest checking it over just as you would when you annual it. Pop the exhaust header and look at the rings and the cylinder walls, stick a dental mirror in it and look at the underside of the head. Are the rings free? Do the piston and cylinder walls look good? Is the underside of the head fairly clean or is it all carboned up? How about the inside of the exhaust manifold? Is it all caked up? Get a general idea of how it is running. Drain the gearbox oil. Is it pretty clean or is it pretty nasty with lots of metal dust on the drain magnet? Mobil 1 keeps it cleaner. How are the carb boots? Cracked or nice? Does it have an after muffler and silencer box? Those two items help keep moisture further away from the exhaust ports and crankcase when the engine cools down after you run it. The airframe is simple, and what ever you would look for on any classic light fabric covered aircraft is what you would look for on a Kolb. Cosmetic items and new Lexan are things that are easily addressed, you are looking for signs of corrosion and poor workmanship overall. As far as flying - good control authority, but a lighter experience. Biggest difference you will notice is flying in the middle of the day, or windy days. Not that a Taylorcraft would punch through turbulence, but compared to a Kolb, or any other very light aircraft - yeah, it kind of does. In that respect, the Kolb is as good as any, and better than most very light aircraft, but it is still going to fly lighter than the T-craft. Aside from that, you will like the view a lot better and the handling is good. Plan to enjoy it. In fact, I need to finish this, I am going flying right now. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403145#403145 ________________________________________________________________________________
Subject: Kawasaki 4 cyl fuel injected engine
Date: Jun 22, 2013
Anyone have a guess or specifics as to the viability of the Kawasaki water craft engine on a mkIII...? I can get the whole craft for 1250.. It is a 4 cyl , fuel injected beast...Somewhere in the 2006 or 7 vintage...Herb Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403146#403146 ________________________________________________________________________________
Date: Jun 22, 2013
Subject: Rotax 447 RPM Varies
Problem with Rotax 447 not holding steady RPM. After climbing to altitude and reducing the RPM to my cruise setting of 5,000, the RPM slowly decreases to about 4,000. I bump the throttle lever and get it back up to 5,000, and then it continues on up to 5,500 or even to 6,000 RPM. I cannot seem to get it to stay at 5,000 RPM. I had this problem about a year ago and at that time I tried cleaning the carb, fuel tank, installed new fuel lines and added fresh fuel (auto regular with up to 10% ethanol but adding stabil for control of that) to no avail. The problem eventually went away on it's own. Now it's back. Any ideas? Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive ________________________________________________________________________________
Date: Jun 22, 2013
Thanks for the reply Richard. I'll incorporate your checklist. Not going to see it for another week or so. We're not too distant from each other. Perhaps a rendezvous in the future. P. -------- "A good traveller has no fixed plans and is not intent on arriving" Lao Tzu (570-490 BC) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403148#403148 ________________________________________________________________________________
Date: Jun 22, 2013
Do a weight & Balance to make sure your aft CG Kolb is a safe flying machine. Many lighter Kolb Pilots need some nose ballast to be safe. -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403155#403155 Attachments: http://forums.matronics.com//files/dscn4207_680.jpg ________________________________________________________________________________
Subject: Re: Kawasaki 4 cyl fuel injected engine
Date: Jun 22, 2013
Engine conversions take considerable effort even if it is well suited for the application. Don't think that engine has been done before. Heavy is bad. The string response was worthless. Rick Neilsen 1st redrive VW on Kolb Sent from my iPhone On Jun 22, 2013, at 4:18 AM, "herbgh" wrote: > > Anyone have a guess or specifics as to the viability of the Kawasaki water craft engine on a mkIII...? I can get the whole craft for 1250.. It is a 4 cyl , fuel injected beast...Somewhere in the 2006 or 7 vintage...Herb > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403146#403146 > > > > > > > > > > ________________________________________________________________________________
Subject: akron flyin of B-29
Date: Jun 22, 2013
Got to see it up close and hear those 3350's sing. ________________________________________________________________________________
Date: Jun 22, 2013
rick I know all the standard stuff about engine conversions...how much time it takes to make a custom engine install...And the Kolb MkIII out West used a three cyl variant ...but was not sure of the manufacture ;Yamaha? . I was more interested in actual , hands on, experience with this engine(not that many 4 stroke , Kawasaki engines in water craft...maybe just this one...?) ...Someone who would know its actual wt etc.. or who had did some preliminary research.. I did the usual search with Google and Yahoo... Of course, I doubted that anyone was using it on a Kolb...never hurts to ask...unless someone wants to discuss string theory! :-) I have to get back to the boat dealer on Monday to get the model number,,,and so on.. Without going through the hoops; guessing that a full vw with redrive would max out the MkIII airframe...and naturally I know where to get the answers to that... :-) Herb On 06/22/2013 01:26 PM, Richard Neilsen wrote: > > Engine conversions take considerable effort even if it is well suited for the application. Don't think that engine has been done before. Heavy is bad. > > The string response was worthless. > > Rick Neilsen > 1st redrive VW on Kolb > > Sent from my iPhone > > On Jun 22, 2013, at 4:18 AM, "herbgh" wrote: > >> >> Anyone have a guess or specifics as to the viability of the Kawasaki water craft engine on a mkIII...? I can get the whole craft for 1250.. It is a 4 cyl , fuel injected beast...Somewhere in the 2006 or 7 vintage...Herb >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=403146#403146 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jun 22, 2013
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Subject: Spark Plug question
I've always used NGK BR8ES plugs (solid cap) on both my 503 and 582 engines .=0A=0AToday a friend showed me NGK BR8EIX (solid cap) plugs which he's jus t started using. NGK claims that this Iridium fine wire plug causes smoothe r idling, faster spark resulting in quicker engine starts, and less fouling . He's used it for about 5 hours in his 582 and says that the claims are ju stified. The plugs are twice as expensive as the BR8ES, but have a longer =0Alife. (Just how much longer he didn't know.)=0A=0A=0ADo any of you have experience with these plugs, and what's your verdict?=0A=0AArty Trost=0ASan dy, Oregon=0A=0A-=0Awww.LessonsFromTheEdge.com/uladventure2009.htm=0A=0A =0A"Life's a daring adventure or nothing"=0AHelen Keller=0A=0A=0A"I refuse to tip toe through life just to arrive safely at death." ________________________________________________________________________________
Date: Jun 22, 2013
http://www.jetski.com/article.cfm?id=618 Rick On Sat, Jun 22, 2013 at 2:48 PM, Herb wrote: > > rick > > I know all the standard stuff about engine conversions...how much time > it takes to make a custom engine install...And the Kolb MkIII out West used > a three cyl variant ...but was not sure of the manufacture ;Yamaha? . > > I was more interested in actual , hands on, experience with this > engine(not that many 4 stroke , Kawasaki engines in water craft...maybe > just this one...?) ...Someone who would know its actual wt etc.. or who > had did some preliminary research.. > > I did the usual search with Google and Yahoo... Of course, I doubted > that anyone was using it on a Kolb...never hurts to ask...unless someone > wants to discuss string theory! :-) > > I have to get back to the boat dealer on Monday to get the model > number,,,and so on.. > > Without going through the hoops; guessing that a full vw with redrive > would max out the MkIII airframe...and naturally I know where to get the > answers to that... :-) Herb > > > On 06/22/2013 01:26 PM, Richard Neilsen wrote: > >> >> Engine conversions take considerable effort even if it is well suited for >> the application. Don't think that engine has been done before. Heavy is bad. >> >> The string response was worthless. >> >> Rick Neilsen >> 1st redrive VW on Kolb >> >> Sent from my iPhone >> >> On Jun 22, 2013, at 4:18 AM, "herbgh" wrote: >> >>> >>> Anyone have a guess or specifics as to the viability of the Kawasaki >>> water craft engine on a mkIII...? I can get the whole craft for 1250.. It >>> is a 4 cyl , fuel injected beast...Somewhere in the 2006 or 7 vintage...Herb >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/**viewtopic.php?p=403146#403146> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Re: Rotax 447 RPM Varies
Date: Jun 22, 2013
If you have a variable pitch prop, try changing the pitch a bit to load the torque curve in a different location. I had a 532 that would do that when the load on the prop was too great. Might not work, but at least it is a cheap experiment... -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=403185#403185 ________________________________________________________________________________
Date: Jun 23, 2013
Can I expect to fly it as I would the Taylorcraft BC12D I used to own? ABSOLUTELY NOT. The Firestar is a great flying airplane, but because it has a high thrust line, is very light, has low inertia, and is quite draggy, when you get off the power, it slows down immediately. You must be ready to get that stick forward to maintain airspeed when coming off the throttle. If you want to live to age 58, do yourself a large favor and find a guy to give you an hour or two of dual instruction in a 2-place Kolb Mark III. Its the best money you will ever spend. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403201#403201 ________________________________________________________________________________
Date: Jun 23, 2013
I have a 447 with about 30 hours on it and as undoctor points out, the rpm will change as the pitch of the aircraft changes with a given throttle setting. Pitch changes the load on the engine so pitch up equals more load and less indicated rpm and vice versa. My rpm changes are 200 or 300 rpm in either direction as pitch changes. not 1000 as you are describing. So, the important thing here is whether your problem occurs at a constant altitude or not and just around your cruise setting or across the entire throttle range. If you are maintaining a steady altitude, then you do have a problem. If it occurs just in the 4 to 5 grand range and nowhere else, then the midrange circuit in the carb needs looking at. Check for worn needle and that the clip is still fitting snuggly in the grooves. Make sure the rubber o ring on top of the clip is secure. Make sure your throttle cable is snug and properly adjusted at the carb inlet. Pulse line for fuel pump should be as short as possible and stiff as possible. Pump has to lift fuel quite a ways on a firefly. A partially plugged fuel filter will cause engine surges too. I've read that paper style fuel filters are not recommended when using auto gas because of the alcohol. Not sure how true that is but for a couple of bucks I changed mine out to a different type just for peace of mind. So far so good on my engine. I'm presently using 89 octane auto gas. I manage my pitch during flight with a vertical deviation indicator of my own design that works quite well. I find that I use it alot to help maintain a constant altitude which also helps maintain a steady EGT temp. -------- Gregg Kaat 2011 Firefly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403226#403226 ________________________________________________________________________________
Date: Jun 23, 2013
From: WhiskeyVictor36(at)aol.com Date: Sat, 22 Jun 2013 08:48:59 -0400 (EDT) >Problem with Rotax 447 not holding steady RPM. > >After climbing to altitude and reducing the RPM to my cruise setting of >5,000, the RPM slowly decreases to about 4,000. I bump the throttle lever >and get it back up to 5,000, and then it continues on up to 5,500 or even to >6,000 RPM. I cannot seem to get it to stay at 5,000 RPM. > Bill, I had similar problems with both the 447 and the Victor 1+. The Victor did better than the 447 at holding a steady rpm but had they both had similar problems of not holding steady EGT's. It drove me nuts and that is why I went to an adjustable air/fuel control on the Victor. But not all the problems went away. I removed the Bing and looked at the barrel and plunger/needle assembly and noticed an odd wear mark inside the barrel bore. It looked like the plunger and needle, return spring, and the control cable assembly were letting the plunger and needle dance or resonate inside the barrel bore and the main jet. As an experiment, I found another spring that I could slip inside the ordinal spring and ran the two springs. Much improvement. I called the Bing guy and found out that they produce three different strength springs. I ordered the strongest spring, installed it and all my rpm and EGT variations disappeared. I hope this helps. Jack B. Hart FF004 Winchester, Indiana ________________________________________________________________________________
Subject: Storm Aftermath
Date: Jun 23, 2013
Most likely a derecho caused this, enhanced by downburst clusters embedded inside the storm and some of the loudest thunder I've ever heard. Only in Kolb can you get this perspective on a storms aftermath. A derecho is a widespread, long-lived, straight-line wind storm that is associated with a land-based, fast-moving band of severe thunderstorms. Rainbow Country -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403250#403250 Attachments: http://forums.matronics.com//files/dscn5001_210.jpg http://forums.matronics.com//files/dscn4888_176.jpg http://forums.matronics.com//files/rainbow_country_180.jpg http://forums.matronics.com//files/dscn4955_138.jpg http://forums.matronics.com//files/flooding_281.jpg ________________________________________________________________________________
Subject: Re: Storm Aftermath
Date: Jun 23, 2013
I really don't want to hear about let alone see photos of too much water. We are in the middle of a drought here in the New Mexico desert. Other than that the rainbow was rather nice. Is drencho a meteorological term? :-) Don't archive. Brad Nation On Jun 23, 2013, at 19:42 , "Dennis Thate" wrote: > > Most likely a derecho caused this, enhanced by downburst clusters embedded inside the storm and some of the loudest thunder I've ever heard. Only in Kolb can you get this perspective on a storms aftermath. > A derecho is a widespread, long-lived, straight-line wind storm that is associated with a land-based, fast-moving band of severe thunderstorms. > > Rainbow Country > > -------- > Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403250#403250 > > > > > Attachments: > > http://forums.matronics.com//files/dscn5001_210.jpg > http://forums.matronics.com//files/dscn4888_176.jpg > http://forums.matronics.com//files/rainbow_country_180.jpg > http://forums.matronics.com//files/dscn4955_138.jpg > http://forums.matronics.com//files/flooding_281.jpg > > > > > ________________________________________________________________________________
Date: Jun 23, 2013
Hard to please some on this forum......try this, the the perigee-syzygy moon. -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403262#403262 Attachments: http://forums.matronics.com//files/dscn5060_273.jpg ________________________________________________________________________________
Date: Jun 23, 2013
Hard to please some on this forum......try this, the the perigee-syzygy moon, or tonight's 'Super Moon' ! -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403264#403264 Attachments: http://forums.matronics.com//files/dscn5060_458.jpg ________________________________________________________________________________
Subject: thrust
Date: Jun 24, 2013
Hey everyone, I know this subject probably has been beaten to death but here goes anyway. I have a 503 Rotax with a gearbox and a 60 inch three blade IVO prop. (not sure of the gear ratio. This is on a Twinstar MKII. I have it set to give me 6500 rpm on climb out. Is there a way to get any more thrust out of this with a prop change or am I maxed out with what I have ? I am trying to get off the ground quicker. (it is fine for one person, but uses a lot of runway with 2) Also I am still looking at landing gear issues, would the person that made spring steel gear please contact me and let me know what size, wall thickness, grade material and hardness he used for his. thanks for any responses. Lee, Twinstar MKII and CGS Hawk Classic ________________________________________________________________________________
Subject: Re: thrust
Date: Jun 24, 2013
A 66 or 68 inch prop might help, if you could change to a C gearbox with the 3.47 to 1 ratio and use a 68 to 72 inch three blade you would get the most p ossible out of the 503. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA On Jun 24, 2013, at 8:51 AM, "Lee" wrote: > Hey everyone, > I know this subject probably has been beaten to death but here goes anyway . > I have a 503 Rotax with a gearbox and a 60 inch three blade IVO prop. (not sure of the gear ratio. > This is on a Twinstar MKII. > I have it set to give me 6500 rpm on climb out. > Is there a way to get any more thrust out of this with a prop change or am I maxed out with what I have ? > I am trying to get off the ground quicker. (it is fine for one person, but uses a lot of runway with 2) > Also I am still looking at landing gear issues, would the person that made spring steel gear please contact me and let me know what > size, wall thickness, grade material and hardness he used for his. > thanks for any responses. > Lee, > Twinstar MKII and CGS Hawk Classic > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Re: thrust
Date: Jun 24, 2013
Typically you get more acceleration and climb as you make the prop longer. With a 503 and a longer 3 bladed prop - say 64" or 66" - you can get to the point that you have a lot of acceleration but you are top end limited, in effect you end up with a pure climb prop. The reason for this is if you try and crank in enough pitch into a longer 3 blade for a decent cruise speed, the engine will likely not have enough torque to rev up properly, it will be constantly overloaded. A 2 blade prop should not normally have this problem. Since the Ivo is flexible, it will be just as smooth with 2 blades as it is with 3. Right now I am running a 2 bladed 68" Ivo with a 582 and am very happy with the performance. Take off is prompt, climb is excellent, and top end is good. The engine will hit red line at full throttle in level flight and never lugs at any RPM. I had to make motor mount spacers to get the engine higher for boom tube clearance. Before I made the spacers the longest prop I could use was 66". 66" was good, 68" is better. I did have a bit more top end with the 66", but not much, and since I always cruise around 65 anyway, the 68" is all good. If I were you, I would sell the 3 blade and get a 66" 2 blade Ivo and try that. If your engine fails to make enough torque to handle it, you can trim it down to 65" or even 64" and either way you will see quite an improvement over the 60" prop. Can't help you on the landing gear. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403285#403285 ________________________________________________________________________________
Subject: Looking for a 3.47 to 1 gearbox
Date: Jun 24, 2013
Kolbers, I am still trying to find a 3.47 to 1 gearbox to adapt to my 2SI engine. If anyone knows of a fair priced used C or E box please let me know. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA ________________________________________________________________________________
Subject: Re: thrust
Date: Jun 24, 2013
This makes me want to try an old two blade 68 inch Ivo I have laying around. I currently use a 68 inch three blade Powerfin F model. Always looking for more performance. I didn't think two blades would absorb 70hp. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA On Jun 24, 2013, at 9:26 AM, "Richard Pike" wrote: > > Typically you get more acceleration and climb as you make the prop longer. With a 503 and a longer 3 bladed prop - say 64" or 66" - you can get to the point that you have a lot of acceleration but you are top end limited, in effect you end up with a pure climb prop. The reason for this is if you try and crank in enough pitch into a longer 3 blade for a decent cruise speed, the engine will likely not have enough torque to rev up properly, it will be constantly overloaded. A 2 blade prop should not normally have this problem. Since the Ivo is flexible, it will be just as smooth with 2 blades as it is with 3. > > Right now I am running a 2 bladed 68" Ivo with a 582 and am very happy with the performance. Take off is prompt, climb is excellent, and top end is good. The engine will hit red line at full throttle in level flight and never lugs at any RPM. > > I had to make motor mount spacers to get the engine higher for boom tube clearance. Before I made the spacers the longest prop I could use was 66". 66" was good, 68" is better. I did have a bit more top end with the 66", but not much, and since I always cruise around 65 anyway, the 68" is all good. > > If I were you, I would sell the 3 blade and get a 66" 2 blade Ivo and try that. If your engine fails to make enough torque to handle it, you can trim it down to 65" or even 64" and either way you will see quite an improvement over the 60" prop. > > Can't help you on the landing gear. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > richard (at) bcchapel(dot)org > Kingsport, TN 3TN0 > Now faith is the substance of things hoped for, the evidence of things not seen. > Hebrews 11:1 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403285#403285 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 24, 2013
Subject: Mike's Kolb MkIII
Mike Wondering how your Kolb is coming along...Herb On 06/24/2013 08:47 AM, Mike Welch wrote: > > Dennis, > > Here's a start > > ________________________________________________________________________________
Subject: thrust
Date: Jun 24, 2013
Also I am still looking at landing gear issues, would the person that made spring steel gear please contact me and let me know what size, wall thickness, grade material and hardness he used for his. thanks for any responses. Lee, Twinstar MKII and CGS Hawk Classic Lee/Kolbers: I use .120" wall 4130, heat treated to 48 Rockwell. I don't know what the diameter of the gear leg sockets of a MKII are. Probably 1.125". Good idea to weld the axle socket to the gear leg, rather than use the standard "gear leg/axle socket" that bolts to the end of the gear leg. Welding, for me, proved to be much stronger than the bolt on socket. All alignment and drilling should be done prior to heat treating. john h mkIII Rock House, south of Burns Junction, Oregon ________________________________________________________________________________
Subject: Re: Mike's Kolb MkIII
Date: Jun 24, 2013
Hi Herb, The plane is coming along quite well, its mostly me that's the hangup. Since I retired a few years ago, finances have been slim pickings, and the other problem I'm having is a health issue that I am mostly recovering from. My wife an I are making plans right now to move to Florida to a retirement village, where I will go back to work and have some pocket money, and therefore I should be able to afford the flight training and sundry costs of actually flying the plane. As far as the plane goes, it virtually finished, with the exception of firing up the engine and dialing everything in. In the meantime, for the last few months I've been working on my GlaStar. Since I have all the parts on-hand, it doesn't cost me anything to tinker with it and get it closer to being done, too. Sure is hard to get much done in this sweltering humidity. Don't mind the heat, but god does the humidity get me down!! Here is my plane out on my front lawn. Underneath the wing gap cover is my ballistic parachute. If you look closely, you can see my video game modified joystick, complete with the push-to-talk com radio button and the coolie hat for electric trim. I left the doors off. Kinda seems dumb to have doors on with this heat. Best regards, Herb=85.and thank for asking!! Mike Welch Kolb MkIII CX w/ tubo Suzuki Now=85..got to go out and mow that lawn!!! On Jun 24, 2013, at 9:30 AM, Herb wrote: > > Mike > > Wondering how your Kolb is coming along...Herb > > > On 06/24/2013 08:47 AM, Mike Welch wrote: >> >> Dennis, >> >> Here's a start=85=85 >> >> > > > > > > ________________________________________________________________________________
Date: Jun 24, 2013
Subject: Re: thrust
Lee =C2- I think I had a 68" 3 blade IVO on my MKII with a 503.=C2- Below is a lin k to a video showing takeoff performance. =C2- http://www.youtube.com/watch?v=wAkNU2UcADw Malcolm ----- Original Message ----- From: "Lee" <lmorgan100(at)charter.net> Sent: Monday, June 24, 2013 8:51:56 AM Subject: Kolb-List: thrust Hey everyone, I know this subject probably has been beaten to death but here goes anyway. I have a 503 Rotax with a gearbox and a 60 inch three blade IVO prop. (not sure of the gear ratio. This is on a Twinstar MKII. I have it set to give me 6500 rpm on climb out. Is there a way to get any more thrust out of this with a prop change or am I maxed out with what I have ? I am trying to get off the ground quicker. (it is fine for one person, but uses a lot of runway with 2) Also I am still looking at landing gear issues, would the person that made spring steel gear please contact me and let me know what size, wall thickness, grade material and hardness he used for his. thanks for any responses. Lee, ====================== == ________________________________________________________________________________
Date: Jun 24, 2013
Absolutely beautiful job..!! Mike Its begging to be flown... Humidity? Florida?? :-) Good luck...Herb On 06/24/2013 11:23 AM, Mike Welch wrote: > Hi Herb, > > The plane is coming along quite well, its mostly me that's the hangup. Since I retired a few years ago, finances have been slim pickings, > and the other problem I'm having is a health issue that I am mostly recovering from. > > My wife an I are making plans right now to move to Florida to a retirement village, where I will go back to work and have some pocket money, > and therefore I should be able to afford the flight training and sundry costs of actually flying the plane. > > As far as the plane goes, it virtually finished, with the exception of firing up the engine and dialing everything in. In the meantime, for the last few months > I've been working on my GlaStar. Since I have all the parts on-hand, it doesn't cost me anything to tinker with it and get it closer to being done, too. > > Sure is hard to get much done in this sweltering humidity. Don't mind the heat, but god does the humidity get me down!! > > Here is my plane out on my front lawn. Underneath the wing gap cover is my ballistic parachute. If you look closely, you can see my video game modified > joystick, complete with the push-to-talk com radio button and the coolie hat for electric trim. I left the doors off. Kinda seems dumb to have doors on with this heat. > > Best regards, Herb.and thank for asking!! > > Mike Welch > Kolb MkIII CX w/ tubo Suzuki > > Now..got to go out and mow that lawn!!! > > > On Jun 24, 2013, at 9:30 AM, Herb wrote: > >> >> Mike >> >> Wondering how your Kolb is coming along...Herb >> >> >> On 06/24/2013 08:47 AM, Mike Welch wrote: >>> >>> Dennis, >>> >>> Here's a start >>> >>> >> >> >> >> >> ________________________________________________________________________________
Date: Jun 24, 2013
How about a pic or two of the engine install...I bought and resold a 4 cyl Geo engine with the high dollar Canadian ign and injection system..Had a belt redrive from a guy out in the mid west...Now out of business.. The engine will run ok with default settings if the same system...Herb On 06/24/2013 11:23 AM, Mike Welch wrote: > Hi Herb, > > The plane is coming along quite well, its mostly me that's the hangup. Since I retired a few years ago, finances have been slim pickings, > and the other problem I'm having is a health issue that I am mostly recovering from. > > My wife an I are making plans right now to move to Florida to a retirement village, where I will go back to work and have some pocket money, > and therefore I should be able to afford the flight training and sundry costs of actually flying the plane. > > As far as the plane goes, it virtually finished, with the exception of firing up the engine and dialing everything in. In the meantime, for the last few months > I've been working on my GlaStar. Since I have all the parts on-hand, it doesn't cost me anything to tinker with it and get it closer to being done, too. > > Sure is hard to get much done in this sweltering humidity. Don't mind the heat, but god does the humidity get me down!! > > Here is my plane out on my front lawn. Underneath the wing gap cover is my ballistic parachute. If you look closely, you can see my video game modified > joystick, complete with the push-to-talk com radio button and the coolie hat for electric trim. I left the doors off. Kinda seems dumb to have doors on with this heat. > > Best regards, Herb.and thank for asking!! > > Mike Welch > Kolb MkIII CX w/ tubo Suzuki > > Now..got to go out and mow that lawn!!! > > > On Jun 24, 2013, at 9:30 AM, Herb wrote: > >> >> Mike >> >> Wondering how your Kolb is coming along...Herb >> >> >> On 06/24/2013 08:47 AM, Mike Welch wrote: >>> >>> Dennis, >>> >>> Here's a start >>> >>> >> >> >> >> >> ________________________________________________________________________________
Date: Jun 24, 2013
Excellent feed back folks - I appreciate it. W&B yes, yes, yes. Some dual -absolutely. Which begs the question, deadstick, this must be a handful. I'm thinking that a ballistic parachute is an absolute necessity. My impression is that of a helicopter - collective down, stick forward, maintain rotor rpm till just above the ground. P. -------- "A good traveller has no fixed plans and is not intent on arriving" Lao Tzu (570-490 BC) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403361#403361 ________________________________________________________________________________
Date: Jun 24, 2013
Nice looking Plane. Sent from my iPad Brad On Jun 24, 2013, at 10:23, Mike Welch wrote: > Hi Herb, > > The plane is coming along quite well, its mostly me that's the hangup. Since I retired a few years ago, finances have been slim pickings, > and the other problem I'm having is a health issue that I am mostly recovering from. > > My wife an I are making plans right now to move to Florida to a retirement village, where I will go back to work and have some pocket money, > and therefore I should be able to afford the flight training and sundry costs of actually flying the plane. > > As far as the plane goes, it virtually finished, with the exception of firing up the engine and dialing everything in. In the meantime, for the last few months > I've been working on my GlaStar. Since I have all the parts on-hand, it doesn't cost me anything to tinker with it and get it closer to being done, too. > > Sure is hard to get much done in this sweltering humidity. Don't mind the heat, but god does the humidity get me down!! > > Here is my plane out on my front lawn. Underneath the wing gap cover is my ballistic parachute. If you look closely, you can see my video game modified > joystick, complete with the push-to-talk com radio button and the coolie hat for electric trim. I left the doors off. Kinda seems dumb to have doors on with this heat. > > Best regards, Herb.and thank for asking!! > > Mike Welch > Kolb MkIII CX w/ tubo Suzuki > > Now..got to go out and mow that lawn!!! > > > > > > > > > On Jun 24, 2013, at 9:30 AM, Herb wrote: > >> >> Mike >> >> Wondering how your Kolb is coming along...Herb >> >> >> On 06/24/2013 08:47 AM, Mike Welch wrote: >>> >>> Dennis, >>> >>> Here's a start > ________________________________________________________________________________
Date: Jun 24, 2013
I guess I was too subtle or my sense of humor is a little off. Sent from my iPad Brad On Jun 23, 2013, at 22:30, "Dennis Thate" wrote: > > Hard to please some on this forum......try this, > the the perigee-syzygy moon, or tonight's 'Super Moon' ! > > -------- > Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403264#403264 > > > > > Attachments: > > http://forums.matronics.com//files/dscn5060_458.jpg > > > > > > > ________________________________________________________________________________
Date: Jun 24, 2013
Herb, I'll take a few pictures tomorrow. Mike ________________________________________________________________________________
Date: Jun 24, 2013
Unless the composition of paper filters has changed recently their main difference from screen filters is that they will not pass water. Up side - no water in carb, down side- no fuel in carb , and we all know about Ethanol and water. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403368#403368 ________________________________________________________________________________
Subject: Re: Firestar II stall speed...
Date: Jun 24, 2013
Thanks very much for posting this topic AZ. As an aspiring Kolb pilot, I found the discourse exceedingly helpful. Cheers and eternal tailwinds, Paul Arizona Flyer wrote: > Thanks so much guys I really appreciate the input! t41pilot & wakataka; We are flying in a parallel universe with the exact same experiences. My Firestar II is 419lbs and it's pretty loaded with a Rotax 503DC, electric start, EIS, ASI with dual pitot tubes, fuel gauge, Facet aux fuel pump, 3 blade Ivoprop. Being only 148 lbs I really expected a 30mph stall speed. During my short flight with my light weigh I had to turn the trim knob all the way for level flight. Looking back, and not having flown for 11 years, even with my long experience flying these types (Quicksilver Sprint II, Quicksilver Sport, Buccaneer SX amphibian, Rans S-12, Avid Flyer Mark IV, Rans S-7) I should have taken the Firestar to a longer airstrip. zeprep251(at)aol.com; Yes my first flight was a little scary and a few hundred feet up, the desert airstrip I made on my property that seemed plenty long on the ground @530ft well it sure got small looking down from above but I had planned to practice some landings at a slightly longer airstrip just south of my place where I had graded a runway for RC model airplanes, it is about 600ft and more open. That stall drop & 2 bounces on my first landing rattled me a bit and I drifted left off the runway but not much, and it took almost all of the length to stop. 'Get right back on that horse' I took off again and my 2nd landing was good but I still drifted left. I may have started braking at too high a speed but the runway end was coming up fast. Years ago I was very good at tracking my Buccaneer SX, Avid Flyer, and Rans S-7 tail draggers but I remember I took some practice and I was a little surprised at how rusty I was with the Firestar. On the 3rd landing I did pretty well, the 4th landing was perfect. I was exhausted from the last 6 weeks of getting all this work done, and nervous before my 1st flight, so after the 4th landing as I sat there with the engine running I figured I could probably get it into my strip but SAFETY FIRST, don't push it especially when tired so I parked the nose unde! r a tree and tied it down. All this week I have been working on extending my runway and I am up from 530ft to 800ft now. Also I think I'll put on VG's from StolSpeed as a poster here said they brought his Firestar II stall speed down 5mph, from 35mph down to 30mph and says it handles better at slower speeds and also feels safer. Not that the Firestar is unsafe in any way but it would help with a shorter strip and add some piece of mind. That abrupt stall drop still haunts me but I know after a couple more flights and landings I'll be smiling ear to ear :) For what it's worth, my yellow Firestar II was built in 1999 by Gary Aman and I bought it last month from 'Captain' Ron Larson of Port Charlotte Florida. A very good mechanic nicknamed 'Rotax Rick' did a rebuild on the 503 and has greatly helped me with questions & info. The airplane is in good condition and Ron only wanted $7,800 so I bought it. Rotax Rick, Travis & Brian at Kolb have said I got a very good deal at that price. It did cost me $3,075 to have Bill Wilmeroth at Deland Barnstormers transport it from Florida to Arizona and he did a great job. So happy with my purchase. Thanks again for the great input guys :) -------- "A good traveller has no fixed plans and is not intent on arriving" Lao Tzu (570-490 BC) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403370#403370 ________________________________________________________________________________
Date: Jun 25, 2013
At 09:34 PM 6/24/2013, Allonsye wrote: > >Excellent feed back folks - I appreciate it. W&B yes, yes, yes. Some dual >-absolutely. Which begs the question, deadstick, this must be a handful. >I'm thinking that a ballistic parachute is an absolute necessity. My >impression is that of a helicopter - collective down, stick forward, >maintain rotor rpm till just above the ground. Not at all. Kolbs glide pretty well, though they're certainly not sailplanes. What you lose in glide ratio you get back in the ability to use a small field. A BRS is for structural failure, NOT for an engine failure! In the event of an engine failure, you need to get the nose down NOW to maintain flying speed, because the plane is so light (and counteract the pitching tendency when that high mounted engine stops pushing), but then you're fine. Dual is good, in at least something similar. It was some 15 years since I last flew my Taylorcraft (or any other plane), a few hours in a 2-place Quicksilver with a friend, and I felt ready to fly my Ultrastar. Except for the landing speed and the need to flare at six inches, not six feet, a Kolb flies more like a T-Craft than a Quicksilver. Dana -- Space isn't remote at all. It's only an hours drive away if your car could go straight upwards. ________________________________________________________________________________
Date: Jun 25, 2013
Success was not made possible by four leaf clovers or rabbits feet. Practice!...Practice! ... Practice! -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403394#403394 Attachments: http://forums.matronics.com//files/grass_strip_959.jpg ________________________________________________________________________________
Subject: Re: thrust
Date: Jun 25, 2013
gliderx5 wrote: > Lee > > I think I had a 68" 3 blade IVO on my MKII with a 503. Below is a link to a video showing takeoff performance. > > http://www.youtube.com/watch?v=wAkNU2UcADw (http://www.youtube.com/watch?v=wAkNU2UcADw) > > Malcolm > > Nice video. It is certainly possible to run a 3 blade 68" Ivo on a 503, my only question would be - what was your cruise speed, and what rpm were you turning at that speed? In order to get the 503 to turn 6500 rpm, you will need to take out a lot of pitch, and then then your cruise speed goes to pot. Back when I had a 532 on the MKIII, I started out with a 64" 3 blade Ivo. Given that the 532 did not have as flat a torque curve as the 503, still, in order to make the engine run properly, I had to run it with the prop in fairly flat pitch and it had a great takeoff and climb, but at cruise it was turning 5800-6000 rpm with poor airspeed. Around 62 if I remember right. Took away one blade, repitched the prop, and the cruise rpm became sane, cruise speed went up, and it kept it's good takeoff and climb behavior. With the 582 and a 68" 2 blade, cruise speed is 65-70 at around 5500 rpm and 4 gph. Takeoff is typical Kolb - great. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403398#403398 ________________________________________________________________________________
Date: Jun 25, 2013
Allonsye; Glad this topic helped you my friend. Anything that comes to your mind please ask and I will do my best to help... -------- "Life should be lived as a bold adventure, I refuse to tiptoe through life just to arrive safely at death" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403403#403403 ________________________________________________________________________________
Date: Jun 25, 2013
. I'm thinking that a ballistic parachute is an absolute necessity>> No it isn`t. Its nice if a wing falls off but unless you fly over some totally unlandable territory an ultralight has so little inertia and flying speed is so low that you can usually find a usable spot. if it is just an engine out just fly the plane to the ground.You are in control. You are not once you have pulled the chute Cheers Pat. ________________________________________________________________________________
Subject: Re: thrust
Date: Jun 25, 2013
Richard, do you have the light or medium Ivo blades? Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA On Jun 25, 2013, at 10:21 AM, "Richard Pike" wrote: > > > gliderx5 wrote: >> Lee >> >> I think I had a 68" 3 blade IVO on my MKII with a 503. Below is a link to a video showing takeoff performance. >> >> http://www.youtube.com/watch?v=wAkNU2UcADw (http://www.youtube.com/watch?v=wAkNU2UcADw) >> >> Malcolm >> >> > > > Nice video. It is certainly possible to run a 3 blade 68" Ivo on a 503, my only question would be - what was your cruise speed, and what rpm were you turning at that speed? In order to get the 503 to turn 6500 rpm, you will need to take out a lot of pitch, and then then your cruise speed goes to pot. > > Back when I had a 532 on the MKIII, I started out with a 64" 3 blade Ivo. Given that the 532 did not have as flat a torque curve as the 503, still, in order to make the engine run properly, I had to run it with the prop in fairly flat pitch and it had a great takeoff and climb, but at cruise it was turning 5800-6000 rpm with poor airspeed. Around 62 if I remember right. Took away one blade, repitched the prop, and the cruise rpm became sane, cruise speed went up, and it kept it's good takeoff and climb behavior. > > With the 582 and a 68" 2 blade, cruise speed is 65-70 at around 5500 rpm and 4 gph. Takeoff is typical Kolb - great. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > richard (at) bcchapel(dot)org > Kingsport, TN 3TN0 > Now faith is the substance of things hoped for, the evidence of things not seen. > Hebrews 11:1 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403398#403398 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Pre-Purchase Inspection, Firstar
Date: Jun 25, 2013
And then there is the question of will you use it? You're in an emergency situation where things have gone to junk as a result of your action or inaction and now according to the BRS theory you will do something you have never practiced, cannot preflight for, and do not know the outcome of should you do it. Rick Girard Rick G/Kolbers: Yes, I would use my BRS if the need arises. I practice and have engrained into my mind what to do should the need arise. I also preflight the system, ensuring the safety pin is removed and the bridals are in good shape. I have faith in the system. Quite a few folks have died because they never thought of their parachute before they hit the ground. When something catastrophic happens, one must react instantly in most cases. A split second may make the difference between success and failure, life and death. Some situations the parachute probably will not save you, such as the recent crash Rick G mentioned. No matter, if I wasn't flying, I would not hesitate to pop the chute. john h mkIII Rock House, Oregon - Two time member of the Caterpillar Club. ________________________________________________________________________________
Date: Jun 25, 2013
John h And just what is this Caterpillar Club? Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive In a message dated 6/25/2013 3:23:18 P.M. Eastern Daylight Time, jhauck(at)elmore.rr.com writes: john h mkIII Rock House, Oregon - Two time member of the Caterpillar Club. ________________________________________________________________________________
Date: Jun 25, 2013
http://www.merkki.com/caterpillarclub.htm Bill: The above URL will explain the Caterpillar Club. Membership is free. ;-) And just what is this Caterpillar Club? Bill Varnes ________________________________________________________________________________
Subject: Re: Caterpillar Club
Date: Jun 25, 2013
Vintage Parachute of WWII -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403441#403441 Attachments: http://forums.matronics.com//files/232323232fp63554_nuequal_988_6_7_258_wsnrcgequal35477696_8349nu0mrj_211.jpg ________________________________________________________________________________
Date: Jun 25, 2013
Below is a link to a video shot from an original Firestar. The last minute or so shows a deadstick landing from base leg at about 500 feet agl. The glide angle is not extreme. In fact, I can't tell much difference between glide angle at idle and deadstick. I think what trips up a lot of pilots transitioning to ultralights is the ground rush during the last few feet of the descent. If you're not used to the wide visibility and the low to the ground seating position, it feels like the earth is rising up to smite thee and the temptation is to round out too soon. Without the engine to provide a burst of power, that can result in dropping it in from several feet up. The trick is to fly it right down the ground before beginning to roundout and flare. http://www.youtube.com/watch?v=9uOCAwEj8VQ -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403442#403442 ________________________________________________________________________________
Date: Jun 26, 2013
Never heard of Switlick. I was under the impression that Irvin Co. was the starter of the Caterpillar Club and in fact it had to be an Irvin chute involved. I see that both Switlick and Irvin claim the honour. I have only known one member of the club. He was a guy from whom I bought an Olympia 2 glider back in 1965. He was a top class gliding competitor and while thermalling a glider below him surged up and stuck its wing up through the floor of his glider and out through the canopy and then broke off. He took to his chute and it is rumoured that he could be heard over 3 counties cussing the other competitor all the way down until he landed. The other glider landed hard in a wood but the pilot got away with it.. Incidentally about a week ago a light a/c at a local field had trouble and tried to get into a school playing field. He couldn`t make it but he had a chute fitted to the plane which he pulled. The whole plane descended into a couple of back gardens and the pilot was OK. I think this is the first time this has happened in the UK. Pat ________________________________________________________________________________
Subject: 912
Date: Jun 26, 2013
A friend has a titan tornado and put a used 912 ul on it. Runs great except for egts. firstly; was pitched to take off at 5800 rpm. Was okay but when backed off to 5000, egts climbed. One side real high, to 1550 plus I guess. Has black exhaust. Pulled plugs and left bank had black plugs while right had nice brown to white. Set up carb okay, with vaccum system. Engine was in tractor configuration now in pusher. Could the needles or jets be different for tractor: Ted Cowan. slingshot, 912 zoom zoom. ________________________________________________________________________________
Subject: Re: thrust
Date: Jun 26, 2013
Thanks everyone for the responses to the prop thrust question. It looks like I am in the market for a used 66 to 68 inch IVO prop. keep in mind funds are low, but if anyone has one for around $200. I am interested. thanks, Lee ________________________________________________________________________________
Subject: Re: 912
Date: Jun 26, 2013
Ted, Might check the diaphragms.JBM has replacements if you find a leak. It sho uldn't care if it pushes or pulls.It may have been out of whack before he g ot the engine. G.Aman -----Original Message----- From: Ted Cowan <tc1917(at)bellsouth.net> Sent: Wed, Jun 26, 2013 5:57 am Subject: Kolb-List: 912 A friend has a titan tornado and put a used 912 ul on it. Runs great excep t for egts. firstly; was pitched to take off at 5800 rpm. Was okay but when backed off to 5000, egts climbed. One side real high, to 1550 plus I guess. Has black exhaust. Pulled plugs and left bank had black plugs while right had nice brown to white. Set up carb okay, with vaccum system. Engine was in tractor configuration now in pusher. Could the needles or jets be different for tractor: Ted Cowan. slingshot, 912 zoom zoom. ________________________________________________________________________________
Subject: Re: thrust
Date: Jun 26, 2013
[quote="rowedenny"]Richard, do you have the light or medium Ivo blades? Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA [quote] Just the light ones. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403454#403454 ________________________________________________________________________________
Date: Jun 26, 2013
Subject: RE: Kolb-List Digest: 16 Msgs - 06/25/13
Gliderx5 and Bro Pike: I enjoyed the video of the takeoff and landing performance. A question: Is that lexan you have for the door? I noriced it seems to be flexible but very functional. Thanks for any response. Bob Green MKIIIX N830PB ________________________________________________________________________________
Subject: Re: thrust
Date: Jun 26, 2013
This thread has me excited to try a 68 inch two blade Ivo I got from a friend several years ago and never thought it would be enough blade to absorb my 70hp. If it works, I'll buy a two blade hub for my Powerfin and give that a try. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA On Jun 26, 2013, at 9:07 AM, "Richard Pike" wrote: > > [quote="rowedenny"]Richard, do you have the light or medium Ivo blades? > > Dennis "Skid" Rowe > Mk3, 690L-70, Leechburg, PA > > [quote] > > Just the light ones. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > richard (at) bcchapel(dot)org > Kingsport, TN 3TN0 > Now faith is the substance of things hoped for, the evidence of things not seen. > Hebrews 11:1 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403454#403454 > > > > > > > > > > ________________________________________________________________________________
Subject: Fuel pump replacement - 912
Date: Jun 26, 2013
Just received a service bulletin from Rotax about replacement fuel pumps on the 912uls engine. When I printed it out, I learned that mechanical fuel pumps are considered to have a five year life. Oops... probably should have noticed that! Mine is a bit older. This is a Pierburg (sp?) and I was under the impression it was bullet proof. Am I the only one who has not been paying attention? Has everyone else with a 912 been replacing them at 5 years? Gulp! Dave W. Mk III classic Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403486#403486 ________________________________________________________________________________
Date: Jun 26, 2013
Am I the only one who has not been paying attention? Has everyone else with a 912 been replacing them at 5 years? Gulp! Dave W. Dave W/Kolbers: Did not know about the 5 year life of the Pierberg fuel pump. However, last year my old Pierberg developed an oil leak and I replaced it with the new recommended pump. john h mkIII Rock House, Oregon ________________________________________________________________________________
Subject: Re: Fuel pump replacement - 912
Date: Jun 27, 2013
Spoke to Lockwood today. The Svc Bulletin starts out with the statement that all mechanical fuel pumps have a five year life span, then should be replaced. Then it goes on to describe a problem with Bing pumps. The manual says all rubber hoses should be replaced every five years, and if the fuel lines are integrated with the pump, it should be replaced too. Lockwood said if its an Experimental, the owner/operator makes the call "on condition," which I take to mean, "if it ain't broke, don't fix it." He went on to say Pierberg pumps are tough tough little muthas and he's seen them do fine well after ten years of service. Never mind! Annual is finished, biannual flight review done, plan to go flying this weekend if the weather cooperates! Don't worry, be happy! Dave Watkins Mk III C Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403546#403546 ________________________________________________________________________________
Date: Jun 27, 2013
Subject: A.N.U.G. in David City NE this weekend.
I know this is pretty late posting, but if you are in or around Nebraska this weekend, it's the 14th Annual Nebraska Ultralight Gathering in David City. There is nothing much planned except a bunch of flying and then some more flying with a little bit of additional flying. Oh yeah, and lots of hangar talk and BSing. In the past others have put a lot of time and effort into this event, but the last couple of years everyone has decided to pare it back to what really makes these events fun; Flying! There is a website http://www.anug.org Here's the official announcement Good place to be this week end, is the David City Airport attending the 14th annual =93=94ANUG=94=94 Fly-in event. where you can meet other flying enthusiast and swap lies, BS, etc. What events are planned ???, none, just come and have fun together. Those that fly in or show up tomorrow night Friday, June 28th will get to eat free Pizza. Camping is available at the airport, and auto gas is also available at the airport The weather is going to be clear and sunny , and rather cool Friday-Saturda y and Sunday, with top temperature around 80%, with light NW winds during the early mornings and evening hours, but Gusting up to 16 to 19 during the midday hours. ________________________________________________________________________________
Subject: Re: thrust
Date: Jun 28, 2013
If anybody needs an Ivo prop spacer, let me know, I've got one. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403566#403566 ________________________________________________________________________________
Subject: Apple iPad 4 Retina 128GB Wi-fi UNLOCKED
Date: Jul 01, 2013
It's happening again at V2B COMMUNICATIONS LIMITED . We are offering a Special Bonanza to all our current and new customers who are willing to purchase genuine and original Smart-phones for personal use or retail purposes. OUR SERVICE IN LIFE IS NOT TO GET AHEAD OF OTHERS, BUT TO GET AHEAD OF OURSELVES TO BREAK OUR OWN RECORDS, TO OUTSTRIP OUR YESTERDAY BY OUR TODAY (Enquires available 24 hours a day) CONTACT PERSON: Jenifer Douglas (marketing manager) CONTACT EMAILS & SALES INQUIRY: v2bcomltd(at)gmail.com V2bcommunicationslimited(at)hotmail.co.uk We take this opportunity to introduce ourselves as one of the leading Approved dealers, specialized in the distributors of Mobile phones,Laptops,Games,Mobile accessories,computer e.t.c. Our objective is to develop long-term relationships with our customers. SHIPPING METHOD: FedEx,UPS & URBAN SPEED SERVICE. DELIVERY/ANALYSIS: 48Hrs Via FedEx Express Delivery, (OVERNIGHT DELIVERY ALSO AVAILABLE @Affordable charges). PAYMENT METHOD: PAYPAL,BANK TRANSFER,WESTERN UNION,MONEY GRAMM, PERFECT MONEY Our BONANZA are: Buy 2 units and get 1 unit FREE including shipping Buy 4 units and get 2 unit FREE including shipping Buy 5 units and get 3 unit FREE including shipping Buy 2 units Apple iPhone 5 64GB --@ $350 Each = $700 USD and get 1 unit FREE Buy 4 units Apple iPhone 5 64GB --@ $350 Each = $1,400 USD and get 2 units FREE Buy 5 units Apple iPhone 5 64GB --@ $300 Each = $1,750 USD and get 3 units FREE Why buy from us ? * Your privacy is guaranteed * Our prices are second to none * Insurance Secured Transactions * We ship Monday through Saturday. * Free shipping on qualified orders * We offer a reasonable discount bulk purchase * We ship the same day after confirmation of payment. * We offer a 30 days return policy and a 100% money back guarantee. If you are interested, forward your questions and inquires to us via email your order and shipping details. we give 1 year warranty for every product sold out to our costumers, our product are company class 1 tested and approved by global standard organization of wireless industries. Below is our current mobile phones price list: NO TAX on all products! DON'T CONTACT US FOR FAKE OR REFURBISH PHONES. WE SELL ORIGINAL PHONES ONLY. Price listed Also applies for Oversea Shipment Apple iPad 4 Retina 128GB Wi-fi UNLOCKED --- $400 Apple iPad 4 64GB with Wi-Fi ---$350 USD Apple iPad mini ----------------$290 USD Apple iPad 3 Wi-Fi + 4G 64GB..........................$300 USD Apple iPad 3 Wi-Fi 64GB...............................$280 USD Apple iPad 2 (Wi-Fi + 3G)-----$250 Apple iPad 2 (Wi-Fi)----$240 Apple iPad 2 (CDMA)---$230 Apple Tablet iPad 64GB (Wi-Fi + 3G)---$220usd Apple Tablet iPad 32GB (Wi-Fi + 3G)---$200usd Apple Tablet iPad 16GB (Wi-Fi + 3G)---$190usd Apple iPhone: Apple iPhone 5 16GB---- $300 Apple iPhone 5 32GB---- $330 Apple iPhone 5 64GB---- $350 Apple iPhone 4S 64GB ..............$300 Apple iPhone 4S 32GB ..............$280 Apple iPhone 4S 16GB ..............$270 Apple iPhone 4 CDMA---$260 Apple iphone 4g 32gb----$250 Apple iPhone 3GS 32GB- $180 Apple iPhone 3GS 16GB- $180 Apple iPhone 4GB $90 Apple iPhone 8GB $110 Apple iPhone 16GB $115 Apple iPhone 3G 8GB $125 Apple iPhone 3G 16GB $135 BlackBerry: BlackBerry Z10 ...... $350 BlackBerry Q10 ---$280 Blackberry TK Victory......$350 Blackberry porsche 9981--$500 BlackBerry Porsche P9531-$500 BlackBerry Curve 9380---$265 BlackBerry Bold 9790---$260 BlackBerry Curve 9370---$250 BlackBerry Playbook WiMax......$250 BlackBerry 4G Playbook LTE.....$250 BlackBerry Torch 9850---$270 BlackBerry Torch 9860---$265 BlackBerry Torch 9810----$260 BlackBerry Curve 9350--$250 BlackBerry Bold Touch 9900--$255 BlackBerry Bold Touch 9930--$250 BlackBerry 4G PlayBook HSPA+--$245 BlackBerry PlayBook WiMax--$240 BlackBerry PlayBook---$230 BlackBerry bold 9780------$270 BlackBerry Curve 3G 9300--$250 BlackBerry Torch 9800-----$260 BlackBerry Pearl 3G 9100---$240 BlackBerry Pearl 3G 9105---$230 BlackBerry Bold 9650---$220 Windows Phone: Windows Phone 7 -----$250 HTC HTC Butterfly-----$380 HTC EVO 3D PG86100--$240 HTC One SU--------$380 HTC One SC--------$350 HTC DROID DNA-----$350 HTC One SV--------$350 HTC Desire X------$350 HTC Desire VT-----$330 HTC Desire SV-----$350 HTC One VX.....$350 HTC One X+.....$330 HTC One X......$300 HTC Titan II --- $300 HTC Vivid ----- $ 300.00 HTC Rezound----$260 HTC One XL----$250 HTC Rhyme---$250 HTC Sensation XL---$250 HTC Panache---$240 Htc Advantage X7510----$240 HTC Sensation XE--$260 HTC Titan--$260 HTC Jetstream--$255 HTC Trophy--$250 HTC DROID Incredible 2--$245 HTC Sensation 4G--$240 HTC Inspire 4G--$235 HTC Freestyle---$230 HTC Aria--------$225 HTC Evo 4G--$220 HTC Wildfire---$210 HTC Desire $200 HTC HD mini $200 HTC Legend - $200 HTC Google Nexus One $200 Nokia: Nokia Lumia 920 ---------$300 nokia-lumia-820 ---------$300 Nokia 808 PureView-----$280 Nokia Lumia 900----$280 Nokia Lumia 610---------$270 Nokia N9.......$270 Nokia N950......$265 Nokia 500.......$265 Nokia X7-00.....$265 Nokia E6.......$260 Nokia Astound------$250 Nokia Oro-----$230 Nokia N950......$270 Nokia T7---$260 Nokia X2-01--$250 Nokia C5-03--$245 Nokia X5-01 - $240 Nokia N8----$240 Nokia X6 8GB--$230 Sony Ericsson: Sony Xperia Z----$300 Sony Ericsson Xperia mini pro --- $ 270.00 Sony Ericsson XPERIA Play ------ $ 250.00 Sony Ericsson Xperia arc S--$260 Sony Ericsson Xperia neo V---$250 Sony Ericsson XPERIA Arc---$230 Sony Ericsson BRAVIA S004...$220 Sony Ericsson Spiro..$230 Sony Ericsson XPERIA X10 mini pro $220 Sony Ericsson XPERIA X10 mini $210 Sony Ericsson XPERIA X10 - $200 Sony Ericsson Xperia X2 $190 Sony Ericsson XPERIA X1 - $150 Sony Ericsson Aspen $230 Sony Ericsson Vivaz Pro $210 Sony Ericsson Vivaz $200 Samsung: Samsung I9500 Galaxy S4----$350 Samsung I9505 Galaxy S4 --- $350 Samsung I9190 Galaxy S4 mini ---$300 Samsung Galaxy Note 8.0 N5100 ---$300 Samsung Galaxy Note 10.1 N8000 -----$320 Samsung I9300 Galaxy S III-----$300 Samsung Galaxy Young GT-S6310 --$250 Samsung Galaxy Tab 8.9 4G P7320T---$300 Samsung Galaxy Nexus Telus--$270 Samsung Galaxy Prevail ---------- $ 260 Samsung I9001 Galaxy S Plus ---- $ 260 Samsung Galaxy Note--250 Samsung Galaxy Pocket S5300--$250 Samsung Galaxy S II T-Mobile---$250 Samsung Galaxy S II Epic 4G Touch--$250 Samsung Conquer 4G--$245 Samsung I9100 Galaxy S II--$240 Samsung i997 Infuse 4G---$240 Samsung Google Nexus S--$230 Samsung Galaxy Tab ---$230 Samsung Vibrant----$220 Samsung W960 AMOLED 3D---$240 Samsung Galaxy A---$210 Samsung I9000 Galaxy S---$210 Samsung I6500U Galaxy---$210 Motorola phones Motorola MT917 ----------- $ 350.00 Motorola XT928 ----------- $ 350.00 Motorola Milestone XT883--$260 Motorola DROID XYBOARD 8.2 MZ609 --$250 Motorola DROID XYBOARD 10.1 MZ617---$250 Motorola XOOM 2 Media Edition---$250 Motorola MOTO XT316--$250 Motorola XPRT----$250 Motorola XOOM MZ604--$250 Motorola XOOM MZ601--$240 Motorola XOOM MZ600--$230 Motorola ATRIX 4G--$230 Motorola QUENCH $220 Motorola XT720 MOTOROI $210 Motorola BACKFLIP $215 Motorola XT800 $205 LG Phones LG Spectrum---$255 LG Optimus Big LU6800--$250 LG Phoenix--$250 LG Thrive---$245 LG Thrill 4G---$235 LG T315-----$230 LG Optimus 3D P920--$220 LG KH5200 Andro-$220 LG GS290 Cookie Fresh-$210 LG GW820 eXpo - $200 LG GT540 $200 LG GD510 Pop $200 Video Games Console: Playstation: APPLE LAPTOPS Apple Macbook Air.$400usd Apple Macbook Pro MC240LL/A ..$385usd Apple Macbook Pro MB990LL/A $400usd Apple MacBook (MA700LL/A) Mac Notebook$410usd Apple MacBook Pro (MA611LL/A) Notebook$390usd Apple MacBook (MA254LL/A) Mac Notebook$300usd Apple iBook G3 (M7698LL/A) Mac Notebook..$395usd Apple MacBook Pro (MA609LL/A) Notebook$420usd Apple MacBook Pro (MA600LLA) Notebook$410usd Apple MacBook Pro (MA610LL/A) Notebook$420usd Apple Macbook Pro (885909119400) Notebook..$415usd Other: Canon EOS 5D Mark II --- $1000 Others :: Canon EOS 5D Mark II .... $1000 HP ENVY 14 Beats edition series...... $999.99 Bose Lifestyle 235 Home Entertainment System ........... $1,599 Bose Lifestyle V25 Home Entertainment System ........... $1,610 Bose Lifestyle V35 Home Entertainment System ........... $2,200 Playstation 3 Slim 320GB ........................ $299 Pioneer CDJ-1000MK3/DJM-800 Package with Coffin Case ...... $1,548 Samsung 55" (138cm) Series 9 3D Full HD LED TV - UA55C9000 ... $2,000 Sony NEX FS10 ................................................$4199 Sony HXR-NX5U - PAL - NXCAM Digital HD Video Camcorder ..... $1699 Apple MacBook Air - Core 2 Duo 2.13 GHz - 13.3 ------ 400.00 Kindly Contact us for more product that are not listed above. Note : Bulk purchase (3units above) Prices are negotiable. ETC CONTACT EMAILS & SALES INQUIRY: v2bcomltd(at)gmail.com V2bcommunicationslimited(at)hotmail.co.uk SIGNED Mgt 2013 V2B COMMUNICATIONS LIMITED All Rights Reserved. Products carry 1 year international warranty . Powered by V2B COMMUNICATIONS LIMITED Copyright 2013, V2B COMMUNICATIONS LIMITED Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403717#403717 ________________________________________________________________________________
Subject: Wells fly-in
Date: Jul 01, 2013
Here's a video of the Wells MN fly-in yesterday: http://youtu.be/yl3owqCknmA -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 26 years flying it Kolbra 912ULS N20386 200 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403747#403747 ________________________________________________________________________________
Subject: Re: Wells fly-in
Date: Jul 01, 2013
Yup ...that was me turning final as you departed. I had to carry along extra fuel for this one. Great little Fly-In and with real eggs! -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403767#403767 Attachments: http://forums.matronics.com//files/dscn5151_161.jpg http://forums.matronics.com//files/dscn5152_133.jpg http://forums.matronics.com//files/dscn5140_171.jpg ________________________________________________________________________________
Subject: Alan's new MK III
Date: Jul 02, 2013
Here is an in-flight photo of Alan G.'s new MK III I took this past Saturday. He is doing a good job of familiarizing himself with flying his new Kolb adventure machine he recently bought from John B.. It is a well built Kolb that Alan is very proud of owning. I was chasing in my Zenith 750 and had to run 80 mph + to keep up with him. We had a record temp. that day of 107 in Houston. The air was very dry for our area, the only way we ever see those kinds of temps. It was some nice flying weather once you got up a little to cool off. Jimmy Y Houston TX -------- Jimmy Young Missouri City, TX Kolb FS II/HKS 700 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403777#403777 Attachments: http://forums.matronics.com//files/100_0300_156.jpg ________________________________________________________________________________
Date: Jul 02, 2013
I'm always surprised how much attention my Kolb Firestar generates at a Fly-In. They parked me in the front row . Experimental and Pushers are not that common around here. Looking back, it was a good time ! -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403804#403804 Attachments: http://forums.matronics.com//files/looking_back_187.jpg ________________________________________________________________________________
Subject: Metal Fatigue
Date: Jul 03, 2013
I rotated the shaft from a previous bend, but once you bend aluminum metal fatigue will lead to breakage. I was slowly taxing straight ahead when this snapped. -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403898#403898 Attachments: http://forums.matronics.com//files/dscn5278_113.jpg http://forums.matronics.com//files/dscn5272_166.jpg ________________________________________________________________________________
Date: Jul 04, 2013
Subject: Re: Kolb-List Digest: 1 Msgs - 07/03/13
Just a quick note to to say I'm selling my Kolb Firestar 11, It's a GREAT Airplane but it's time for me to try something different. All the info on it ( N2552A ) is on Barnstormers. I want to thank all for all the great tips and information since I started the build. The Kolb company is a the best people to work with, they have always been there when I need anything. I'm staying on the list because I just can't cut all the ties. Fly Safe... Tim On Thu, Jul 4, 2013 at 2:01 AM, Kolb-List Digest Server < kolb-list(at)matronics.com> wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-07-03&Archive=Kolb > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-07-03&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Wed 07/03/13: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 02:53 PM - Metal Fatigue (Dennis Thate) > > > ________________________________ Message 1 > _____________________________________ > > > Subject: Kolb-List: Metal Fatigue > From: "Dennis Thate" <retroman(at)frontier.com> > > > I rotated the shaft from a previous bend, but once you bend aluminum metal > fatigue > will lead to breakage. I was slowly taxing straight ahead when this > snapped. > > -------- > Both optimists and pessimists contribute to our society. The optimist > invents > the airplane and the pessimist the parachute. ~Gil Stern > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403898#403898 > > > Attachments: > > http://forums.matronics.com//files/dscn5278_113.jpg > http://forums.matronics.com//files/dscn5272_166.jpg > > ________________________________________________________________________________
Subject: Difference between mark II and mark III
Date: Jul 05, 2013
Is there a way to tell the difference between a Mk II and a Mk III just by looking? I'm looking at a plane that is listed as a Mk III. It was originally used as an ultralight trainer and wasn't N numbered until 2003. The current owner knows the history of the plane but because it was an estate sale records are missing prior to 2003. I don't mind which model it I and I'm going through the entire plane. Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404020#404020 ________________________________________________________________________________
Date: Jul 05, 2013
Is there a way to tell the difference between a Mk II and a Mk III just by looking? I'm looking at a plane that is listed as a Mk III. It was originally used as an ultralight trainer and wasn't N numbered until 2003. The current owner knows the history of the plane but because it was an estate sale records are missing prior to 2003. I don't mind which model it I and I'm going through the entire plane. Mike Kolbers: There is a great deal of difference between a MKII and a MKIII: -MKIII has 6" tail boom and main wing spars. MKII has 5". -MKIII airframe completely different and much, much stronger. -MKIII has flaps. MKII doesn't. -MKIII has unique updated folding elevator control mechanism. MKII doesn't. -Much more room in the MKIII. -MKIII and MKII are not in the same ball park. Of course, the above comments are my own opinion. john h mkIII Rock House, Oregon ________________________________________________________________________________
Subject: Re: Difference between mark II and mark III
Date: Jul 05, 2013
Well this definitely has flaps. Thanks its exactly the type of information I was looking for. Are the specs for early Mk III's similar to current models? Gross weight, cruise speed, Vne etc? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404023#404023 ________________________________________________________________________________
Date: Jul 06, 2013
On Behalf Of mike91911 Are the specs for early Mk III's similar to current models? Gross weight, cruise speed, Vne etc? Kolbers: Specs for MKIII Classic's should be the same throughout the build years. You can find info on all Kolb models here: http://www.kolbaircraft.com/ john h mkIII Rock House, Oregon ________________________________________________________________________________
Subject: q
Date: Jul 06, 2013
List Can someone tell me which Garmin GPS works best in a Kolb? Also what VHF radio? I'd appreciate your answers Thanx Russ K ________________________________________________________________________________
Date: Jul 06, 2013
Subject: Re: Rotax 447 RPM Varies
Ducati SS Thanks for your input regarding my problem with the RPM not staying in place. If the rain and nasty hot and humid weather ever clears away, I might get a chance to experiment with the suggestions you all gave. When and if I find the cure I will let the list know the results. Thanks again, Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive ________________________________________________________________________________
Date: Jul 06, 2013
Subject: Re: q
Russ ,=0AIam really happy with my Area 500. A little pricy but works great. =0A-I believe that any of the hand helds will work pretty good as long as you get a GOOD antena , coax=0Aand conectors. I use a Vertex .=0A-Good l uck and worth what you paid for it.=0AFrank Goodnight=0A=0A________________ ________________=0A From: kinne russ <russk50(at)gmail.com>=0ATo: kolb-list@ma tronics.com =0ASent: Saturday, July 6, 2013 8:50 AM=0ASubject: Kolb-List: q =0A=0AList=0ACan someone tell me which Garmin GPS works best in a Kolb?=0AA =========== ________________________________________________________________________________
Subject: q
Date: Jul 06, 2013
Can someone tell me which Garmin GPS works best in a Kolb? Also what VHF radio? I'd appreciate your answers Thanx Russ K Russ K/Kolbers: Don't know what the best GPS and VHF radio is for a Kolb, but I have flown all over the lower 48, Canada, and Alaska, with an ICOM A6 and a Garmin 196. Both have worked flawlessly in my MKIII. The ICOM A6 is the latest ICOM handheld. The Garmin 196 is an older model, but is still being supported 100%. Don't have any idea how long Garmin will support the 196. I think the length of service of this GPS is indicative of how well it is designed and how well it operates. The 196 has all the Jeppesen data base, plus obstacle warnings. For comparison, the Garmin 296, which was introduced some time after the 196, was discontinued 4 or 5 years ago. john h mkIII Rock House, Oregon ________________________________________________________________________________
Date: Jul 06, 2013
Subject: Re: q
I've used a 196 to fly cross-country many times... it's quite up to the task, but getting long in the tooth. On Sat, Jul 6, 2013 at 8:50 AM, kinne russ wrote: > > List > Can someone tell me which Garmin GPS works best in a Kolb? > Also what VHF radio? I'd appreciate your answers > Thanx > Russ K > > ________________________________________________________________________________
Subject: Two blade Powerfin hub, F model
Date: Jul 06, 2013
Does anybody have a used Powerfin F model two blade hub they want to sell? Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA ________________________________________________________________________________
Date: Jul 06, 2013
Subject: Re: q
I saw a nice app for the Droid Nexus 7 at a flyin a few weeks past... Avare.....Herb http://www.appszoom.com/android_applications/transportation/avare_cuhtu.html On 07/06/2013 01:44 PM, Robert Laird wrote: > I've used a 196 to fly cross-country many times... it's quite up to > the task, but getting long in the tooth. > > ________________________________________________________________________________
Subject: RE: Kolb-List Digest: 8 Msgs - 07/06/13
Date: Jul 07, 2013
> which Garmin GPS works best in a Kolb? I dunno- but whatever you get make sure you can still get data updates. I want a 'solution' that I can use for car navigation, displaying charts etc for my sailboat and a good aviation app for my Kolb. I haven't been seriously looking but it may end up being an iPad or something like that. GeoB ________________________________________________________________________________
Date: Jul 07, 2013
Thank you everyone for all of the help. Being new to Kolb aircraft any suggestions as to things I should look for or change? (for safety, comfort or aesthetics) It has a 503. I'd like to replace that with a 582 but I'll have to see how the funds are. It has a single center stick and throttle. I'd really like to convert this to dual sticks. It has an ELT, chute, 2 five gallon fuel tanks, sling seats (replace?), brakes and doors. Avionics are basic steam gauges. My training will be done in a Challenger II and we have 2 other Kolbs flying in the club so I should have the opportunity for help transitioning into the Kolb. My instructor can also do a tail wheel endorsement. Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404118#404118 ________________________________________________________________________________
Subject: Rotax 582/ Firestar
Date: Jul 07, 2013
This is the first Firestar II with a Rotax 582 that I've seen. Anyone on this forum using this engine application...if so, we would like your feedback on how the weight/HP trade-off has worked out. Thanks -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404129#404129 Attachments: http://forums.matronics.com//files/fs2_with_rotax_582_158.jpg http://forums.matronics.com//files/582_185.jpg ________________________________________________________________________________
Subject: Re: Rotax 582/ Firestar
Date: Jul 07, 2013
If mounted correctly the 582 will not add any significant extra weight and should provide at least 10 or more HP than the 503. I believe the Firestar pictured has some structural enhancement modification to the cage to cover the stress of the extra HP. On my Firestar I have had a 582 for over 300 hours, and now have 618 for more than 650 Hrs all without any structural enhancement to the original cage frame. I believe you'll like how the extra HP will make your plane fly like a whole nother bird. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404137#404137 ________________________________________________________________________________
Subject: Fwd: BRS for Xtra
Date: Jul 07, 2013
I'm going to add a BRS to recently acquired Xtra, but I'm not sure which one of the two recommended by the BRS rep to go with. The two sizes are the 1050 and 1350. The l350 is about $1000 more but it will be slower decent. The 1050 is the recommended size on the Kolb web site. So I have a few questions for the Kolb flyers out there. Is anyone using the 1350 or is everyone using the 1050? Does anyone have any recommendations of one over the other? Any suggestions as to where to purchase it other than from the factory and why? Thanks in advance. Brad Nation N952DK ________________________________________________________________________________
Date: Jul 08, 2013
I have not read all the responses yet so some of this may be old news and some may be conflicting. I have been flying a MK111C 503 for 200 plus hours from sea level and into some mountain country .I have flown it to 7000 ft above sea level with out any performance issues . I would agree that stepping up to a 582 would be wise. The centre stick, like you I was going to change that and the throttle , after a couple of flights the need to do that went away . The only reason I could think of for changing it now would be if your were doing a lot of training and need to be a little more convention .The sling seats have never been a problem. Carry a couple of spare large cable ties with you as I found when I first started flying the Kolb some broke. Since they have been replaced with new ones no more problem, that was about 6 years ago . The transition to the Kolb was a non event, before purchasing it { 60 hrs TSN } I did 1 flight from an air force base in rough weather with the builder. On arrival at my home airport { by trailer } a local high time GA pilot who is also a rated ultra light instructor flew the Kolb for about 30 minutes ,then I went for a check flight with him, after three take off/ landings he climbed out and said enjoy . I had just completed about 100hrs in a aronca champ so the tail dragger was not new to me also the 100 hrs before that were also tail dragger mixed with some trike time.The Kolb is fun to fly, very forgiving and responsive . It will fly onto the ground nicely or it will 3 point nicely , I would recommend to fly it on the first couple of times then move to three point landings. You need to make sure that the wheels are touching the grass tops before running out of flying speed and that will happen fast once you flare. Have fun the Kolb is a safe fun machine . Downunder MK111c 503 Regards Tony ________________________________________________________________________________
Date: Jul 08, 2013
That is Ed Martin's FSII. Here is the page showing it in it's original state: http://www.bcchapel.org/pages/0003/kolb.htm It has been pictured on the Kolb list for many years, got rolled up into a ball a while back, was rebuilt and has been flying now for 3 years. The 582 is delightful, amazing climb rate, cruises at around 4800 rpm at 3 gph. A classic example of how a big engine loafing is nicer than a smaller engine working. Maybe if I get ambitious, I'll update the web page to show the airplane in it's current state. Maybe. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404180#404180 ________________________________________________________________________________
Date: Jul 08, 2013
I agree with the statements on the center control stick. When I first got the plane I was convinced that I would need to move the stick to the center or at least the throttle lever to the left side. After flying for just a few hours, the stick position seems natural and reaching the throttle across my lap with my left hand is no problem at all. I've abandoned any plans to move them and I'm convinced that the ease of entry that the current configuration allows in the MkIII classic more than makes up for the control positions. Just my 2 cents. Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404197#404197 ________________________________________________________________________________
Subject: Ivo prop bell cranks, pre 1994
Date: Jul 08, 2013
Kolbers, Been doing a bunch of experimenting with propellers lately and find myself in need of two of the little torque arms that bolt onto the root end of the torsion rod on the pre 1994 Ivo prop blades. They have a little square hole that fits over the twist rod. If anybody has a couple from a broken ivo, drop me a note. Thanks Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA ________________________________________________________________________________
Date: Jul 08, 2013
My bigger concern was the throttle location. To me it would be awkward reaching across from the left but I won't change anything until I have some time logged in the plane. Easier entry and exit with the center stick is something I hadn't considered. Thanks. Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404207#404207 ________________________________________________________________________________
Subject: VHF Radio in a Kolb
Date: Jul 08, 2013
From: "Kirby, Dennis Civ USAF AFMC AFNWC/ENS" <Dennis.Kirby(at)kirtland.af.mil>
kinne russ asked: << Can someone tell me which Garmin GPS works best in a Kolb? Also what VHF radio? Thanx Russ K >> Russ - Last year, I finally installed a "real" aircraft radio in my Mark-3 (as opposed to using a handheld), and I am quite happy with it. It is a FlightLine-760. Cost was about $600. Built-in intercom, fits in a 2-1/2 inch instrument hole. Made in Japan. Excellent quality. Dennis Kirby Mark-3, 912ul ________________________________________________________________________________
Date: Jul 08, 2013
Like several others I was ready to install a dual stick when I first start ed flying. After a few hours I found that the center stick position had a natural feeling to it. I did not like the center throttle position at all and designed a dual throttle system. The throttles are located on the out s ides and can now be operated from either seat using the right or left hand. When the throttle is pulled all the way back it clears the door openings f or easy access. > Subject: Kolb-List: Re: Difference between mark II and mark III > From: larlaeb(at)gmail.com > Date: Mon=2C 8 Jul 2013 08:29:43 -0700 > To: kolb-list(at)matronics.com > > > I agree with the statements on the center control stick. When I first go t the plane I was convinced that I would need to move the stick to the cent er or at least the throttle lever to the left side. After flying for just a few hours=2C the stick position seems natural and reaching the throttle a cross my lap with my left hand is no problem at all. I've abandoned any pl ans to move them and I'm convinced that the ease of entry that the current configuration allows in the MkIII classic more than makes up for the contro l positions. Just my 2 cents. > > Allan > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404197#404197 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Re: Know your Kolb
Date: Jul 08, 2013
"Ralph B" wrote: << There have been many accidents attributed to big plane pilots flying ultralights and Light Sport after flying the big ones. The classic example is flaring too early on landing and stalling the airplane. It comes down hard and bends the gear. How many times have we heard about that one? >> Ralph - How true! You told my story exactly. That is what happened on the maiden flight of my newly-built Mark-3. Bent both gear legs. After that, I went down to the Kolb factory and flew the whole weekend with Bryan Melburn and Norm Labhart in the factory demonstrator Mark-III Xtra. All we did was patterns & landings for about 3 hours of flight time. Best spent flight training money I've ever spent! The good news is, replacing a Kolb landing gear leg is relatively inexpensive! Dennis Kirby Mark-3, 912ul, Powerfin Sandia Park, NM ________________________________________________________________________________
Subject: Re: VHF Radio in a Kolb
Date: Jul 08, 2013
Dennis, If you could post some pics of your installation I would love to see them, I 'm getting pretty tired of the tangle of wires with my Icom, portable interc om and headsets. I need some ideas of how to tidy it up. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA On Jul 8, 2013, at 5:04 PM, "Kirby, Dennis Civ USAF AFMC AFNWC/ENS" wrote: > kinne russ asked: << Can someone tell me which Garmin GPS works best in a Kolb? > Also what VHF radio? Thanx Russ K >> > > Russ =93 > > Last year, I finally installed a =9Creal=9D aircraft radio in m y Mark-3 (as opposed to using a handheld), and I am quite happy with it. It is a FlightLine-760. Cost was about $600. Built-in intercom, fits in a 2- 1/2 inch instrument hole. Made in Japan. Excellent quality. > > Dennis Kirby > Mark-3, 912ul > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: 912 propeller, 4" prop hub ext, Exhaust for sale
Date: Jul 08, 2013
Hello All, For the 912 engine I have: A 68" 3 bladed taper tip Warp Drive propeller with nickel leading edge $400 A 4" propeller hub extension $100 A Stainless steel exhaust system (at least I think it is stainless as a magnet just barely sticks to it) $150 Attached is a picture of the exhaust configuration. All are in great condition and buyer pays for shipping. Regards Jason Omelchuck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404244#404244 Attachments: http://forums.matronics.com//files/exhaust_167.png ________________________________________________________________________________
Date: Jul 08, 2013
Subject: blog report of the Rockhouse fly-in
http://highdesertflier.blogspot.com/ - password - owyheeflyer This is a report of the part of the Rockhouse fly-in that I was able to participate in. There are two short videos within the blog page, as well as a lot of pictures of the area that we used for our fly out. The first video is of an excellent example of how the Kolb can and should be used. You do not need a password to view the blog, but you will for the videos. Even though it was extremely hot, we all had a good time, although it was cut short for me as I had to work on a range fire in Northern Nev. Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 09, 2013
Subject: Re: 912 propeller, 4" prop hub ext, Exhaust for sale
Can you send a larger clearer picture ? I can't see if i can use it from th is pic.=0AThanks=0AFrank-=0A=0A=0A________________________________=0A Fro m: Jason Omelchuck =0ATo: kolb-list(at)matronics.com =0AS ent: Monday, July 8, 2013 8:21 PM=0ASubject: Kolb-List: 912 propeller, 4" p son Omelchuck" <jason@trek-tech.com>=0A=0AHello All,=0AFor the 912 engine I have:=0A=0AA 68" 3 bladed taper tip Warp Drive propeller with nickel leadi ng edge $400=0A=0AA 4" propeller hub extension $100=0A=0AA Stainless steel exhaust system (at least I think it is stainless as a magnet just barely st icks to it) $150- Attached is a picture of the exhaust configuration.=0A =0AAll are in great condition and buyer pays for shipping.=0A=0ARegards=0AJ ason Omelchuck=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forum s.matronics.com/viewtopic.php?p=404244#404244=0A=0A=0A=0A=0AAttachments: ============= ________________________________________________________________________________
Subject: Re: Ivo prop bell cranks, pre 1994
Date: Jul 09, 2013
I have one. Be glad to mail it to you. Let me know. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404280#404280 ________________________________________________________________________________
Date: Jul 09, 2013
Hello Frank, I will search for a better picture but the exhaust has been pulled off of the aircraft already. The exhaust can is nestled under the gearbox with the exhaust pipe exiting downward on the right side. The cylinders closest to the gearbox have a very short header before it enters the exhaust can, the cylinders farthest away from the gear box have the header curve back around under the cylinders and go back to the can. There are welded in bosses for EGT's in all 4 headers. The exhaust will only have enough prop clearance if you are using a prop hub extension. The set up would work very well on any Kolb using a 912 engine and you would not have the added clutter on top of the engine. Best Wishes Jason Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404286#404286 ________________________________________________________________________________
Date: Jul 09, 2013
Subject: Transitioning to the Mk III
Dennis Kirby, all, For pilots transitioning from GA to a Kolb Mk III I made this video to help several years ago. Look at how the position of the horizon on the windscreen changes with flap setting. Hope this helps. http://www.youtube.com/watch?v=mQ-YaW9WgEU Rick Girard -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Re: Transitioning to the Mk III
Date: Jul 09, 2013
Rick, you know how to land a Mark III. Good job! Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 26 years flying it Kolbra 912ULS N20386 200 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404297#404297 ________________________________________________________________________________
Date: Jul 09, 2013
I agree. I found these videos very helpful during my transition, I probably watched them 20 or 30 times. I would recommend in my limited experience that you move to flaps (especially full flaps) only after you have the no-flap landing down pretty well. I did practice approaches and slow flight with flaps at altitude which helped. Also it seems to me that the video approaches don't look as steep as the ones in real life. :) In addition I've noticed that with additional weight forward (passenger) that elevator authority is different and changes the flair timing and stick movement a bit. Thanks, Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404299#404299 ________________________________________________________________________________
Date: Jul 09, 2013
"Larlaeb" > In addition I've noticed that with additional weight forward (passenger) that elevator authority is different and changes the flair timing and stick movement a bit. > > Thanks, > Allan You sure got that right. The Kolbra is a different airplane with a passenger. The sink rate increases dramatically and the stall is higher. The majority of my flying these days is carrying my wife who runs the camera from the back seat (she also is a "back-seat driver"). I flew it solo yesterday and it climbed like a Firestar. I did six takeoffs and landings and forgot how to land solo. Not that the landings were poor, but I had to compensate for the lack of weight. Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 26 years flying it Kolbra 912ULS N20386 200 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404316#404316 ________________________________________________________________________________
Date: Jul 09, 2013
Subject: Re: Fwd: BRS for Xtra
From: Colin Hudson <colin.scott.hudson(at)gmail.com>
I talked with the Reps at BRS on that subject prior to making my purchase. I asked for their opinion on the matter. I was told that they put a rather large margin of safety in their chutes and they said the 1050 would more than safely carry me down at max gross weight. Not sure what engine you have on your X-tra. I am running the Jabiru 2200 and did have a problem. At first I installed the BRS Model VLS. It disrupted the airflow into my cylinders and my CHT went out of sight. The BRS folks recommend that I try the 1050 canister model and it worked perfectly. It set right in the middle and the air flowed right around it into the cylinders. I will also add that the folks at BRS were great to work with during this crisis. You will have to modify your center section plexi-glass to slid around the BRS cable, but it's not too difficult. I can provide photos if you get serious. Colin Colin Hudson Retired Army 10,000+ N424AL M3 X-tra On Sun, Jul 7, 2013 at 10:40 PM, Brad Nation wrote: > > I'm going to add a BRS to recently acquired Xtra, but I'm not sure which > one of the two recommended by the BRS rep to go with. The two sizes are the > 1050 and 1350. The l350 is about $1000 more but it will be slower decent. > The 1050 is the recommended size on the Kolb web site. So I have a few > questions for the Kolb flyers out there. > Is anyone using the 1350 or is everyone using the 1050? > Does anyone have any recommendations of one over the other? > Any suggestions as to where to purchase it other than from the factory and > why? > > Thanks in advance. > > Brad Nation > N952DK > > ________________________________________________________________________________
Date: Jul 09, 2013
All, Thanks for the input. I talked to Travis at Kolb about the various systems a nd ended up buying a 1050 VLS from him which shouldn't be a problem with the 912.. It should be here in a few weeks. Colin: photos would be great, thanks for the offer. Sent from my iPad Brad On Jul 9, 2013, at 19:52, Colin Hudson wrote: > I talked with the Reps at BRS on that subject prior to making my purchase. I asked for their opinion on the matter. I was told that they put a rathe r large margin of safety in their chutes and they said the 1050 would more t han safely carry me down at max gross weight. Not sure what engine you have on your X-tra. I am running the Jabiru 2200 and did have a problem. At fi rst I installed the BRS Model VLS. It disrupted the airflow into my cylinde rs and my CHT went out of sight. The BRS folks recommend that I try the 105 0 canister model and it worked perfectly. It set right in the middle and th e air flowed right around it into the cylinders. I will also add that the f olks at BRS were great to work with during this crisis. You will have to mo dify your center section plexi-glass to slid around the BRS cable, but it's n ot too difficult. I can provide photos if you get serious. > > Colin > > Colin Hudson > Retired Army > 10,000+ > > N424AL > M3 X-tra > > > On Sun, Jul 7, 2013 at 10:40 PM, Brad Nation wrote : >> >> I'm going to add a BRS to recently acquired Xtra, but I'm not sure which o ne of the two recommended by the BRS rep to go with. The two sizes are the 1 050 and 1350. The l350 is about $1000 more but it will be slower decent. Th e 1050 is the recommended size on the Kolb web site. So I have a few questi ons for the Kolb flyers out there. >> Is anyone using the 1350 or is everyone using the 1050? >> Does anyone have any recommendations of one over the other? >> Any suggestions as to where to purchase it other than from the factory an d why? >> >> Thanks in advance. >> >> Brad Nation >> N952DK >> >> >> >> ========== >> arget="_blank">http://www.matronics.com/Navigator?Kolb-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 10, 2013
I found these videos very helpful during my transition, I probably watched them 20 or 30 times. Hi You are making a mountain out of a molehill. I changed from a Challenger to a Mk111 Xtra.in a couple of days. The obvious change is tricycle to tail dragger. Tricycle is so much better in every way it amazes me that anyone bothers with taildraggers. Steering is accurate and precise without having to bother with differential brakes. Side winds problems are much reduced with easily controllable weathercocking.. That said there is something romantic and `veteran` about a tail dragger that I .like or I would not have bought the Xtra. Hold the stick right back when taxying and point the stick into wind. Taxy around your field until you can point the plane in the right direction. Do a couple of runs along the runway until you can lift the tail (gently) and balance on the mains.Find the trim position. When you can keep straight and on two wheels just set up the longest run you can, select one notch of flap, open the throttle SLOWLY or she will swing, until you are flat out. and go for it. It will be obvious when she wants to fly, don`t mess about watching the ASI, just let her lift off. Climb at full throttle at about 50ish. Its not that critical, just don`t get slow.Take the flap off at around 5/600ft Get 1000ft on, throttle back, play with the trim and get used to the flying position. Do some gradually steeper turns in both directions and just play with it for half an hour. Check the indicated stall speed with one notch of flap.which is what you will use for landing. Landing. Set up your approach giving yourself plenty of room. No steep turns in the circuit. Circuit height is probably around 700ft agl. Reduce power and trim for about 50. on the downwind The change in attitude is not great but.the nose will tend to lift as the power comes off. I never did a flapless landing, why would you?. You want increased lift at decreased speed when landing. Thats what flaps are for. One notch flaps,watch for attitude change, trim out for 50/55. Turn final . I alaways cut the throttle when the field is made. Let the plane sink until the blur of the grass changes and you can see individual blades of grass. Flare and try to keep the plane in the air, just off the ground as long as possible. She will eventually stall and you should be a few inches off the ground at that point. You have a perfect three pointer. KEEP THE STICK BACK and apply brakes if you must, but GENTLY. Raise the flap and taxy in. You will not need more than one notch of flap except in an emergency .She REALLY comes down steeply if you do. One more thing. If you sideslip and there is really not much point as the flaps will drop you quite quickly enough watch for a slight lift of the nose. The sideways motion of the air across the curved nose produces a bit of lift. No problem, just be aware. Good luck Pat . ________________________________________________________________________________
Date: Jul 10, 2013
Well, better a mountain than a hole in the ground I always say. Probably some of us just need more help than others. I would argue that a Challenger fits into the lighter type of aircraft category which would give you an understanding of the deceleration issues which plague some GA pilots making the transition. As far as tricycles being better, I will agree that they are generally easier but not better for all applications. Just my two cents. Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404377#404377 ________________________________________________________________________________
Subject: Marking Center Of Tube
Date: Jul 10, 2013
Picture shows how to mark the center line of a tube using a C-Thru brand ruler. -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404395#404395 Attachments: http://forums.matronics.com//files/018_113.jpg ________________________________________________________________________________
Subject: Rudder Spring Length FireFly Question
Date: Jul 10, 2013
The picture of a new factory-built FireFly shows that the longitudinal axis of a rudder spring must bend whenever a rudder pedal is pushed. Would it be better if the spring on a pedal that is pressed is allowed to relax? -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404397#404397 Attachments: http://forums.matronics.com//files/firefly_may13_005_164.jpg ________________________________________________________________________________
Subject: Re: Rudder Spring Length FireFly Question
Date: Jul 10, 2013
Doug, The rudder pedal springs on Kolbs do relax when that pedal is pushed. They are in tension and shorten when the corresponding pedal is depressed. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA On Jul 10, 2013, at 2:23 PM, "Dnul" wrote: > > The picture of a new factory-built FireFly shows that the longitudinal axis of a rudder spring must bend whenever a rudder pedal is pushed. Would it be better if the spring on a pedal that is pressed is allowed to relax? > > -------- > Dnul > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404397#404397 > > > > > Attachments: > > http://forums.matronics.com//files/firefly_may13_005_164.jpg > > > > > > > ________________________________________________________________________________
Date: Jul 10, 2013
I made a small T bracket for the forward spring mount to eliminate this problem. Drilled and riveted to the 4130 cage tube so the bracket will not rotate. No binding or flexing of springs. Simple to make with 2 pieces of tubing and a triangular gusset. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404423#404423 ________________________________________________________________________________
Subject: Re: Marking Center Of Tube
Date: Jul 10, 2013
I spent a lot of time measuring and marking tubing until I came up with this method. Take the tube that needs to be marked. say 1/2" lightly secure to work table ( tape or wood blocks ) lay a piece of 1/2" tubeing parallel and a few inches away from part to be marked. take a third piece of tubing and either coat that piece or the tube to be marked with magic marker. Drag the third piece down the two parallel pieces together, the tube being dragged along the top will hit the exact apex of the two parallel tubes for as long a line as you want to make. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404425#404425 ________________________________________________________________________________
Subject: Re: Latex Pain Forum
Date: Jul 10, 2013
Painting my Kolb with latex paint sounds interesting if it will hold up to time and look reasonably good. Can you use latex paint over the silver Polly brush with success? Also can you remove the paint with MEK down to the cloth for repair? -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404434#404434 ________________________________________________________________________________
Date: Jul 11, 2013
I recovered my Challenger 11 CWS in 05 and used Flex Bon latex house paint. I sprayed it over the silver polly brush and had no problems. I researched several latex paints before using the Flex Bon being it was developed in F lorida and for it's sun resistance. The key is to clear coat it to keep the darker colors from fading also. I ran out of the clear coat on a section o f the tail feathers which faded after a couple years. Other than for that the paint still looks great even after all these years and still has it's s hine. I am in the process of recovering my Mark 111C and will use the same paint system. Yes you can use the MEK to remove the paint. $30 a gal for th e latex plus $80 for the clear coat is a whole lot cheaper than the other p aints used and looks as good. > Subject: Kolb-List: Re: Latex Pain Forum > From: cktman(at)wildblue.net > Date: Wed=2C 10 Jul 2013 18:31:47 -0700 > To: kolb-list(at)matronics.com > > > Painting my Kolb with latex paint sounds interesting if it will hold up t o time and look reasonably good. Can you use latex paint over the silver P olly brush with success? Also can you remove the paint with MEK down to t he cloth for repair? > > -------- > Rick Lewis > > (VW Watercooled Engine) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404434#404434 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Fitting an un-drilled panel onto blind tabs
Date: Jul 11, 2013
Kolber guys (and girls), In the spirit of offering helpful tips, as Doug (Dnul) just did, I offer this hopefully helpful tip to fit a panel onto hidden tabs. Here's the scenario; Suppose you have to make a custom panel that fits very tightly in a difficult-to-get-to place, like say, a floor panel. Once you have cut and trimmed, and filed, and sanded=85.and you've finally got your panel that precise shape that fit's like a glove, your mounting points (tabs) are now hidden, and you no longer have a decent vantage point to view where the mounting holes should be drilled. What to do, what to do??? Here's what I came up with; An un-drilled floor panel that I recently made for my GlaStar was placed in position. I could see the mounting tabs beneath the panel from the front of the plane, but no where near accurate enough to be to place a locating pen mark on the topside to drill the holes. So!! I took an old 3/16" bolt, chucked it into my drill, and turned on my bench grinder. I spun the bolt head against the grinder creating a pin-pointed top. It sort of looks like a rivet, but instead of the head being rounded, it came to sharp point. Then, I lifted up the floor panel, dropped the pointy-headed bolt in place, re-positioned the floor panel exactly where I wanted it to be located. Then, I took a small block of wood, roughly centered it above the first tab, on top of the panel and TAP! Next, removed the panel, looked for the tiny dent, and then centered punched it a little better, and drilled it out to 3/16". After placing the floor panel back into position in the floor, I dropped in a bolt=85.exactly locating the panel where I wanted it! But, before I had set it in place, I dropped that pointy-headed bolt into a tab on the opposite side of the panel. Then TAP! Voila'!! Second bolt hole dent. Removed panel, center punched second hole, drilled 3/16", and re-installed. Once you have two bolt holes drilled, and the 2 locating bolts inserted through the panel and their corresponding tabs (on opposite sides of your panel), that sucker is EXACTLY positioned where it needs to be, and then you just keep on working your way around the remaining tabs, dropping in that pointy-headed bolt per each next tab to tap a small locating dent on the panel's underside. I think my custom-made floor panel had about 8-9 bolts to hold it secure. Each one of those holes was as exact as they could be. It was as if I had access to underneath the tabs to drill them. I think this method offers several variations of uses to allow the builder to make very precisely located blind panels. Below is a duplicate of the bolt I ground down. It needn't be any fancier than a beat up old bolt, ground down to a sharp point!! BTW, the 1/8" height that it holds the panel up is a non-factor. Mike Welch MkIII CX ________________________________________________________________________________
Date: Jul 11, 2013
Variation of Ducati SS's method: Lay two same diameter tubes side by side, take a steel ruler and lay it on both tubes, drag it along the top of both tubes. The steel will leave a light scuff mark. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404480#404480 ________________________________________________________________________________
Date: Jul 11, 2013
I should get a 3/8" dia aluminum tube 8 and 3/4 inch long to hook the springs to so they're stretched 1 and 3/4 inches to get to the pedals in neutral since that is what the plans call for. -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404482#404482 ________________________________________________________________________________
Subject: Re: Fitting an un-drilled panel onto blind tabs
Date: Jul 11, 2013
Wicks has sheet back markers and strap duplicators. -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404484#404484 ________________________________________________________________________________
Date: Jul 11, 2013
Wicks has sheet back markers and strap duplicators. -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404485#404485 ________________________________________________________________________________
Subject: Drilling Center Of Tube
Date: Jul 11, 2013
To drill the center of a tube use a "V" block. Simply lower the drill on the drill press down to the bottom of the "V" to position for center. -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404486#404486 ________________________________________________________________________________
Date: Jul 11, 2013
If you already have reached the Poly Spray stage, you've already added all the weight to the fabric covering that you need, otherwise to save money why not do as Appendix A of the Poly Fiber manual suggests and go with one of the three PolyTone colors that have the silver in them and no Poly Spray is required. You save money and weight. If you're going to do latex paint, research what the successful experimenters have come up with. Latex has UV protection built in and will do the same thing that Poly Spray does. Using Poly Brush and Poly Spray and then overcoating with Latex is probably the worst of all worlds in terms of covering weight. As for doing repairs of Latex coated fabrics, good old commercial Goof Off will take the latex off to get down to bare cloth. Some find it hard to believe how much weight can be added with coatings. My Mk III is 35 to 50 lb. overweight because an auto painter slobbered on so much AeroThane until the fabric weave was completely filled. Light Kolbs fly better. The closer you can get to 500 lb. empty weight the happier you will be with your airplane. Rick Girard PS Is Latex Pain for masochists? Sorry, couldn't help myself On Wed, Jul 10, 2013 at 11:16 PM, Sky Biker wrote: > I recovered my Challenger 11 CWS in 05 and used Flex Bon latex house > paint. I sprayed it over the silver polly brush and had no problems. I > researched several latex paints before using the Flex Bon being it was > developed in Florida and for it's sun resistance. The key is to clear coat > it to keep the darker colors from fading also. I ran out of the clear coat > on a section of the tail feathers which faded after a couple years. Other > than for that the paint still looks great even after all these years and > still has it's shine. I am in the process of recovering my Mark 111C and > will use the same paint system. Yes you can use the MEK to remove the > paint. $30 a gal for the latex plus $80 for the clear coat is a whole lot > cheaper than the other paints used and looks as good. > > > Subject: Kolb-List: Re: Latex Pain Forum > > From: cktman(at)wildblue.net > > Date: Wed, 10 Jul 2013 18:31:47 -0700 > > To: kolb-list(at)matronics.com > > > > > > > Painting my Kolb with latex paint sounds interesting if it will hold up > to time and look reasonably good. Can you use latex paint over the silver > Polly brush with success? Also can you remove the paint with MEK down to > the cloth for repair? > > > > -------- > > Rick Lewis > > > > (VW Watercooled Engine) > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=404434#404434 > > > > > > > > > > > > > > > &===================== > >====== > > > > > > > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jul 11, 2013
Doug, From the picture it looks like either A) the tube that fixes the end of the springs is too short, or B) the springs are too long. You need to have the springs in the relaxed length when that rudder pedal is fully depressed, not when the pedals are equal, i.e. rudder centered. Rick Girard On Wed, Jul 10, 2013 at 1:23 PM, Dnul wrote: > > The picture of a new factory-built FireFly shows that the longitudinal > axis of a rudder spring must bend whenever a rudder pedal is pushed. Would > it be better if the spring on a pedal that is pressed is allowed to relax? > > -------- > Dnul > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404397#404397 > > > Attachments: > > http://forums.matronics.com//files/firefly_may13_005_164.jpg > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Re: Drilling Center Of Tube
Date: Jul 11, 2013
Here is what I use and it works perfect every time -------- Kolb Firestar II 503 C-Box / RK400 Soon to have a Rotax 670 DCDI with a C-Box and RK 400 Clutch Challenger II 503 Tall Drive Location : Buffalo South Carolina Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404497#404497 Attachments: http://forums.matronics.com//files/image_191.jpg http://forums.matronics.com//files/image_138.jpg ________________________________________________________________________________
Date: Jul 12, 2013
How would you use cheap house paint to do a small graphic detail on top of Polytone, on fabric, in order avoid buying some quarts of Polytone? You can get small sample cans of latex mixed colors at Lowes which are intended for people to use in choosing colors. -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404545#404545 ________________________________________________________________________________
Subject: Re: Jig To Install Hinges
Date: Jul 12, 2013
My other tip shows cutting bushings and someone asked "what bushings" on this thread showing the hinge drilling jig. FireFly uses bushings cut from 5/16 ID steel tube. They are used where horizontal stabilizer attaches at the back to the elevator and at the top and bottom of the lift struts. Bushings act as spacers on 5/16 bolts. -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404547#404547 ________________________________________________________________________________
Date: Jul 12, 2013
That would be great to order for drilling the vertical stabilizer post, the drag strut, or the landing gear leg and the universal joint on the aileron control tube which would be drilled inaccurately. It might be used to drill an innumerable number of holes in small tubing used in the wing. -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404548#404548 ________________________________________________________________________________
Date: Jul 12, 2013
http://www.skygeek.com/eastern-edf1-drill-rite.html sells the drill guide. -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404549#404549 ________________________________________________________________________________
Date: Jul 13, 2013
I painted latex over existing paint on some areas on my Titan Tornado. Some of it had been painted before I bought it, and I'm guessing it was Polytone. I washed the airplane with detergent and TSP to remove dirt and wax. Then just sprayed the thinned latex. The new paint had adhered great. There are a few spots where the base paint let loose of the fabric, but the latex has stayed stuck. If you are thinking of a small logo I would think you could mask and spray with a touch up gun, or just brush it on. Malcolm ----- Original Message ----- From: "Dnul" <doug.syler(at)att.net> Sent: Friday, July 12, 2013 1:52:29 PM Subject: Kolb-List: Re: Latex Pain Forum How would you use cheap house paint to do a small graphic detail on top of Polytone, on fabric, in order avoid buying some quarts of Polytone? You can get small sample cans of latex mixed colors at Lowes which are intended for people to use in choosing colors. -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404545#404545 ________________________________________________________________________________
Date: Jul 13, 2013
rickofudall wrote: > If you already have reached the Poly Spray stage, you've already added all the weight to the fabric covering that you need, otherwise to save money why not do as Appendix A of the Poly Fiber manual suggests and go with one of the three PolyTone colors that have the silver in them and no Poly Spray is required. You save money and weight. Rick, I have an older version of the Poly-Fiber Manual that makes no mention of three Poly Fiber colors with silver added. Could you elaborate? Thank you. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404590#404590 ________________________________________________________________________________
Date: Jul 13, 2013
Here is a tool that makes list posts easier to read. We won't need to scroll back and forth because the pictures are too big. http://imageresizer.codeplex.com/ -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404596#404596 ________________________________________________________________________________
Date: Jul 13, 2013
Yes the airplane had a cowling, it was an Aeroprakt A20. I still have a 300 hour Rotax 912ULS for sale that is perfect for a Kolb. It would come with everything needed to make it work on a Kolb. Engine, prop hub extender, 3 bladed 68" warp drive propeller, exhaust, radiator, oil cooler, oil tank, Grand Rapids EIS. The whole works can be had for 13K plus shipping. Regards Jason Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404622#404622 ________________________________________________________________________________
Date: Jul 13, 2013
I have a Kolb Firestar with a Latex paintjob. It is starting to show cracks in the paint, any suggestions on a fix? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404623#404623 ________________________________________________________________________________
Date: Jul 13, 2013
Per Appendix A: Ultralight & Very Light Aircraft. PolyTone 318M, Piper Trainer Blue, 220M Nevada Silver and 222M Rancho Silver are all formulated with the same amount of aluminum pigment in them as Poly Spray and will give full UV protection. Rick On Sat, Jul 13, 2013 at 6:28 AM, racerjerry wrote: > > > rickofudall wrote: > > If you already have reached the Poly Spray stage, you've already added > all the weight to the fabric covering that you need, otherwise to save > money why not do as Appendix A of the Poly Fiber manual suggests and go > with one of the three PolyTone colors that have the silver in them and no > Poly Spray is required. You save money and weight. > > > Rick, I have an older version of the Poly-Fiber Manual that makes no > mention of three Poly Fiber colors with silver added. Could you elaborate? > Thank you. > > -------- > Jerry King > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404590#404590 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jul 13, 2013
Tom I'm afraid that I don't have any bright ideas about fixing cracking paint. Did you do the paint job? Do you know what brand of paint, how it was applied, or how old it is? Malcolm ----- Original Message ----- From: "tombaisley" <tombaisley(at)yahoo.com> Sent: Saturday, July 13, 2013 6:09:05 PM Subject: Kolb-List: Re: Latex Pain Forum I have a Kolb Firestar with a Latex paintjob. It is starting to show cracks in the paint, any suggestions on a fix? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404623#404623 ________________________________________________________________________________
Date: Jul 13, 2013
I have no advise as to what may be needed to cure your problem. I know when I was looking at painting my plane with latex several years ago and laughe d at=2C I found that several brands would crack. I did several test panels with different brands of latex exposing them to the sun for a period of ti me. after a period of time I removed them for the frames that simulated bei ng stretched on a planes surface and allowed to be whipped around by the w inds. Most of them cracked to some degree except for a couple. I did this to see if the paint that had been used on banners used to stretched across the roads and then rolled up and used the next year. I am happy to say it h as held up great since 04...just clear coat it. Date: Sat=2C 13 Jul 2013 23:04:29 +0000 From: gliderx5(at)comcast.net Subject: Re: Kolb-List: Re: Latex Pain Forum Tom I'm afraid that I don't have any bright ideas about fixing cracking paint. Did you do the paint job? Do you know what brand of paint=2C how it was a pplied=2C or how old it is? Malcolm From: "tombaisley" <tombaisley(at)yahoo.com> Sent: Saturday=2C July 13=2C 2013 6:09:05 PM Subject: Kolb-List: Re: Latex Pain Forum I have a Kolb Firestar with a Latex paintjob. It is starting to show cracks in the paint=2C any suggestions on a fix? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404623#404623 =3B &nb================ == =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Subject: AVID Mark -4 , Complete Package for sale (Do forward)
Date: Jul 13, 2013
Kolbers, This is not Kolb related, but please do forward to those interested...Thanks in advance!) I am selling my entire package. Details as listed below: AVID Mark -4 Details: (Built for the Backcountry and pleasure flying It has got everything!) The airplane is completely covered and painted. The new engine has to be bolted and Instrument panel has to wired and it's ready to go. Installation manual supplied) Package Price: 17K Contact: Mahesh Iyer - Cell: 541-613-3329 Aircraft Location: Salt lake City Completely built airframe with custom built foldable heavy duty Trailer: 10,000 USD Brand new Rotax 582 in a box with B gear box and electric starter: 6000 USD (7127 + 300 USD shipping if you purchase from a rotax dealer) Custom built Bubble doors with Hydraulic Cylinders and gap insulation/Weather proofing: 2500 USD Additional instruments, Strobes and many others at reduced prices or give away Brand new Rotax 582 in a box with Carburetor's, Gear Box, Electric starter, Installation CD, Manuals, Rectifier units, Tool kit and rotax registration details: 6000 USD Firewall forward with complete Aluminum wall, Dyna Engine Mount and floorboard ready to go! New Dual Brakes with Matco cylinders New Heavy duty Backcountry GROVE Landing systems New Tundra tires 8.00 x 6 Maule Tail wheel Manuals and Drawings: Complete original AVID build manual with all drawing's included Build Pictures in original POH -Skystar Engine Includes the following: Warranty Rotax tool kit B gear box Electric Starter Rectifier Oil Injector Coolant Reservoir Overflow Reservoir Dual Bing Carburetor's Black heat resistant Painted and assembled Exhaust Exhaust Gaskets Avid Cowling mounted Dual Radiator Cooling System Custom Brackets for Installation Three blade Heavy duty WARP DRIVE prop with Titanium Leading edge and improved Blade system Warp drive Protractor for blade adjustment Aluminum Polished spinner with accessories Heavy duty powder coated AVID DYNA Engine mount for Rotax 582 Two CHT and two EGT Wasatch Probes Water /Coolant Temperature Probe Engine mounting accessories, screws, bolts, nuts included. RF Suppression capacitor with custom mount Firewall: Aluminum Firewall with Heat protector included Grommets and rubber seal Included Instruments: Dash Altimeter supplied by Avid Vertical speed indicator supplied by Avid RPM Indicator Airspeed Electronic Elevator Trim New Ignition/Master Switch New Circuit Breakers ELT Emergency locator ICOM Handheld Radio Dual Intercom Flightcomm Water Temperature Voltage Indicator Dual EGT and CHT indicator Turn Cordinator Hobbs Indicator Bubble Doors: Custom made BUBBLE DOORS for 8-10 Inches of extra space Brand new Hydraulic pistons for ease of opening bubble doors Stainless less steel nuts and bolts for mounting Gap seals Special drills and rivets for mounting Complete set of instructions Prefabricated door frame for COMPLETE view Painted door frames. Cowling: Fully painted and ready to Install AVID Fiber Glass Cowling Strobes and Nav lights: Brand new AEROFLASH Strobes and NAV Lights Extra flashing strobes for Landing gear PAINTS: Polyfiber polytone Bahama Blue Polyfiber polytone Lemon yellow Polyfiber Aerothane for that shiny look Polyfiber Rejuvenator Polyspray Silver Additional Fabric and tapes CDROMS: Avid 4 CD set on build and improvements Rotax Installation CD Many Others: Complete set of Hardware Nuts and Bolts per AVID specs New Dual Throttle cables New Fuel Primer set up Fuel lines Fuel Selector Valves Antennas Avid custom built Round Rudders Maule Tail wheel assembly Heavy Hauler Wings New Floor Panel New rudder cables and tangs Custom seats -2 PTT switch Powder coated body frame Transportation support bars and cushions Lead weights in case you are putting a different engine Decals and Markers Incabin Heater set up Two set of seat belts FAA registered, N numbered Reason for sale: I am moving to a 4 seater Cessna as it serves my purpose better. Thanks, Mahesh Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404635#404635 ________________________________________________________________________________
Date: Jul 13, 2013
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Subject: Heading out for the northern Cascades and Puget Sound
-Hi all,=0A=0ATomorrow morning I'm heading taking off for a four-day flyi ng/camping trip in my Talon. I'll be flying with Bob Coombs (Titan.) We're going to explore the northern Cascades and Puget Sound. =0A=0AIf you want t o follow our track, you can check out my SPOT tracker at=0Ahttp://share.fin dmespot.com/shared/gogl.jsp?glId=0j61d1nv67p9JS1b9PcrXbpphQ5YVWYgJ=0A=0AI 'm hoping my GoPro camera comes up with some beautiful shots. We're both pr etty excited, since the forecast is for severe clear.=0A=0AI won't have e-m ail or phone access - totally disconnected electronically. Yeah!=0A=0AArty Trost=0ASandy, Oregon=0A=0A=0A=0Awww.LessonsFromTheEdge.com/uladventure2009 .htm=0A=0A=0A"Life's a daring adventure or nothing"=0AHelen Keller=0A=0A=0A "I refuse to tip toe through life just to arrive safely at death." ________________________________________________________________________________
Date: Jul 13, 2013
Date: Jul 14, 2013
Subject: RE: Kolb-List Digest: 10 Msgs - 07/13/13
Jerry and Rick: The Nevada Silver is one of the colors that has the silver UV protectants in it. Jim and Dondi of Aircraft Technical Support are a great resource and source for info and products. I have used their services from the beginning of my MKIIIX project. Bob G. N830PB ________________________________________________________________________________
Date: Jul 14, 2013
Thanks for the part Richard, I'll try to get a card with a few bucks to cover your shipping and trouble out to you this week. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA On Jul 9, 2013, at 9:54 AM, "Richard Pike" wrote: > > I have one. Be glad to mail it to you. Let me know. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > richard (at) bcchapel(dot)org > Kingsport, TN 3TN0 > Now faith is the substance of things hoped for, the evidence of things not seen. > Hebrews 11:1 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404280#404280 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 14, 2013
Arty: Have a safe, fun flight. john From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of TheWanderingWench Sent: Saturday, July 13, 2013 11:16 PM Subject: Kolb-List: Heading out for the northern Cascades and Puget Sound Hi all, Tomorrow morning I'm heading taking off for a four-day flying/camping trip in my Talon. I'll be flying with Bob Coombs (Titan.) We're going to explore the northern Cascades and Puget Sound. If you want to follow our track, you can check out my SPOT tracker at http://share.findmespot.com/shared/gogl.jsp?glId=0j61d1nv67p 9JS1b9PcrXbpphQ5YVWYgJ I'm hoping my GoPro camera comes up with some beautiful shots. We're both pretty excited, since the forecast is for severe clear. I won't have e-mail or phone access - totally disconnected electronically. Yeah! Arty Trost Sandy, Oregon www.LessonsFromTheEdge.com/uladventure2009.htm "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe through life just to arrive safely at death." = = = = ________________________________________________________________________________
Subject: eBay listing - Avid Mark -4 package with pictures
Date: Jul 14, 2013
Kolbers, Attached below is the link with pictures. Please do forward it to your friends if interested! http://cgi.ebay.com/ebaymotors/AVID-MK4-Folding-wing-Complete-aircraft-New-Engine-with-Custom-Trailer-Sale-/121143219738?pt=Motors_Aircraft&hash=item1c34b2d61a&vxp=mtr Thanks, Mahesh Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404666#404666 ________________________________________________________________________________
From: "Andy and Sheila Slinkard" <andysheila(at)eltopia.com>
Subject: Re: Heading out for the northern Cascades and Puget Sound
Date: Jul 14, 2013
Hi Artie (TheWanderingWench), We would like to extend an invitation to stop at our farm if you get to the east side. Our air strip is WN31 on the map. We have extra bedrooms or you may camp if you prefer. I am a Kolb builder (nearly finished) among other airplanes. We missed you at the Rock house fly-in last year and this year. Andy and Sheila ----- Original Message ----- From: TheWanderingWench To: FlyingNuts(at)yahoo.com Sent: Saturday, July 13, 2013 10:15 PM Subject: Kolb-List: Heading out for the northern Cascades and Puget Sound Hi all, Tomorrow morning I'm heading taking off for a four-day flying/camping trip in my Talon. I'll be flying with Bob Coombs (Titan.) We're going to explore the northern Cascades and Puget Sound. If you want to follow our track, you can check out my SPOT tracker at http://share.findmespot.com/shared/gogl.jsp?glId=0j61d1nv67p9JS1b9PcrXb pphQ5YVWYgJ I'm hoping my GoPro camera comes up with some beautiful shots. We're both pretty excited, since the forecast is for severe clear. I won't have e-mail or phone access - totally disconnected electronically. Yeah! Arty Trost Sandy, Oregon www.LessonsFromTheEdge.com/uladventure2009.htm "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe through life just to arrive safely at death." ________________________________________________________________________________
Date: Jul 14, 2013
My Firestar was recovered using Stewarts, and painted using Latex, 3 or 4 owners ago in the late 90's I believe, I'm wishing it was done in Poly Fiber Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404682#404682 ________________________________________________________________________________
Date: Jul 18, 2013
Subject: Aero Thane Pain
G'day Kolbers, I was out pulling maintenance on my Exmark and with the heat and hunidity so high I was looking for a reason to go inside in the AC. Found the reason!! I bought a quart of Aero Thane Christen Eagle Blue #177 for my FlagFly and discovered upon receipt that what I needed was Insignia Blue. In the interim my hangar/trailer rolled in Hurricane Sandy and the can of Christen Eagle Blue got badly dented. No leaks, but it sure is dented. I have no use for it and would like to see it get used, so if anyone would be interested in almost a quart of paint in a can you'll probably have to replace once you open the lid, make an offer. Just about done with repairs from the hurricane, must finish new gap seal and tailwheel yet and I'll be aloft. Dave Kulp Bethlehem, PA FireFly 11DMMK ________________________________________________________________________________
Date: Jul 18, 2013
Subject: Matt's KLVK ATC Streaming...
Dear Listers, A couple of weeks ago I found a web site on the Internet called LiveATC.net that has the Air Traffic Control (ATC) tower communications on line for streaming for a number of airports around the country. Lo 'n behold, they even have a stream for my home base, the Livermore Airport. But, much to my dismay, the quality of their KLVK feed was just plain awful. It was obvious the airband source didn't have a decent antenna or perhaps even a good radio. I suppose that given that their site is a consortium of local citizens providing the feeds, the lack of quality goes with the territory. But, I really liked the idea of being able to monitor the LVK ATC and also the ability to bring up the archives and listen to my personal communications with the tower after a flight. Since I had a computer at the hangar along with a pretty decent Internet connection and, in the spirit of Experimental Homebuilding, I had an idea... I mounted an air-band antenna on the top of the hangar and brought the RG-58 coax down to near the computer and plugged it into my trusty Icom IC-A20 hand held. I was AMAZED at the quality of signal I was getting. It was picking up guys in airplanes 19 miles out like they were sitting next to my hangar! I set the radio to high-speed scan between the Tower and Ground frequencies so with a single feed I could get all communications. So next, I made an audio connection from the handheld to the Line In input on the computer. Sure enough, now I was getting great sound from the hand held on the computer! I found some software from Australia called BroadWave from a company called NCH ( http://www.nch.com.au/streaming ). It lets you connect to the Line In port on the computer and then generate real time audio streams that can be served up via the Internet. And sure enough, it works great! Next, I found some software from Germany called Loop Recorder ( http://looprecorder.de ) that let's you monitor an audio input on your computer and generate archive files. You can select an increment in which to rotate the files automatically, for example, every 30 minutes. I downloaded this software and installed it and sure enough, I was able to start archiving the ATC transmissions coming in, all the while streaming them live as well! The last piece of the puzzle was to enable the Web and FTP servers on the Windows 7 system and come up with a front-end web page that would tie all of these new resources together for easy access from the Internet. I'm happy to report, the whole thing came together very nicely and even allows you stream directly to your Android or iPhone as well as your desktop! Pretty darn cool! And so, without further ado, here is my new web site for monitoring the ATC communications at KLVK: http://klvk.matronics.com/ Just to state the obvious, the stream is silent if there isn't any current ATC or aircraft communications. During the day, you'll usually hear something within five or ten minutes. Sometimes much quicker. I contacted LiveATC.net and they were excited about adding my new stream to their web site as well. So, at some point soon, the LiveATC.net feed for Livermore Airport will be coming from my hangar! My site http://klvk.matronics.com will continue to be available as well. For entertainment purposes only! - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 170+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Subject: First flight
Date: Jul 19, 2013
Yesterday morning made my first flight in N553R! It's a Mark III X-tra with a 912S and a 3 blade Warp prop. It was one of the first Xtra's produced by TNK 13-14 years ago. Everything went pretty well but there are a couple of things that I would like to hear the group's comments on. The indicated stall was very repeatable at 55 MPH. This seems high to me but I did some quick glances at the GPS and I think my airspeed reads high. I will recheck this and may redo the static connection. I have a fuel pressure sender to the EIS and I noticed that when throttling down from say 5000 rpm to 3000 rpm I had a low fuel pressure (set at 2 psi) indication for only about a second. Then it came immediately back to around 4-5 psi. I did not have the electric boost pump on at the time. This happened several times on throttle back. I also noticed a fuel smell in the cockpit a couple of times which lasted about maybe 10 seconds. This seemed to occur when turning right? I checked all lined after the flight and there was no evidence of any leaks anywhere & all connections were tight. The tank vent is a ram air connection on the bottom of the cage, passenger side, about 3 inches from the landing gear socket. I'm thinking about relocating this. Any comments would be appreciated. Thanks guys. Rex Rodebush Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404940#404940 ________________________________________________________________________________
Subject: Re: First flight
Date: Jul 19, 2013
Rex, congratulations on your first flight. Disconnect the static line on your ASI and it should read correctly. Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 26 years flying it Kolbra 912ULS N20386 200 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404942#404942 ________________________________________________________________________________
Date: Jul 19, 2013
Congratulations Rex! Glad it went safely. Your stall speed sounds very high to me. Allan Mk IIIC 20 Hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404950#404950 ________________________________________________________________________________
Subject: Shipping stuff
Date: Jul 19, 2013
Had two great experiences this week with buying a used prop and a set of 2si gearbox gears from a couple fellow Kolb pilots. Both items were packed perfectly wrapped tight in bubble wrap and taped well, than pop corn foam packed super tight around it all to keep everything from shifting in the heavy duty boxes.,keep this in mind when shipping valuables, a little attention to detail is so important in keeping things from getting dinged or worse. Big thanks to Jimmy Young and Luray Weachter! Well done fellows! Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA ________________________________________________________________________________
Date: Jul 20, 2013
For the first flight of my Firefly I mounted a Hall airspeed indicator to the wing strut. They are cheap and supposed to be accurate. I was able to cross check with my panel ASI to verify readings. After verifying the panel ASI and plumbing I removed the Hall unit. I have a full enclosure and therefor use a static port mounted on the flat bottom of the nose cone. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404966#404966 ________________________________________________________________________________
Date: Jul 20, 2013
Subject: Fwd: Blog- Fire recon
---------- Forwarded message ---------- From: Larry Cottrell <lcottrell1020(at)gmail.com> Date: Sat, Jul 20, 2013 at 11:06 AM Subject: Blog- Fire recon To: http://highdesertflier.blogspot.com/ Here is an update on the range fires with a couple of videos. Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Upgrading from 503 to 582 on Mark III
Date: Jul 20, 2013
Without considering the cost of the engine itself, what would I be looking at to go from a 503 to a 582 on my Mark III? Also what would I have to change or add? I know I have to add a radiator. I'm told I can use the same carbs and exhaust (with a different y-pipe), same ignition and possibly the same gearbox and prop. Engine mount? I'm sure I'm missing things here. I'm trying to decide before I send out the 503 to be overhauled. I can get an overhauled 582 Blue Head for $3575 or a Grey Head for $2775 and he'd give me $1000 for trading in my 503. Thoughts and opinions... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405000#405000 ________________________________________________________________________________
Subject: Wheel Pants have important function
Date: Jul 21, 2013
Wheel fairings are often called "wheel pants", "speed fairings" or, in the UK, "wheel spats". These fairings are a trade-off in advantages, as they increase the frontal and surface area, but also provide a smooth surface, a faired nose and tail for laminar flow, in an attempt to reduce the turbulence created by the round wheel and its associated gear legs and brakes. They also have the important function of preventing mud and stones from being thrown upwards against the wings or fuselage, or into the propeller on a pusher craft. -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405007#405007 Attachments: http://forums.matronics.com//files/dscn5855_107.jpg ________________________________________________________________________________
Date: Jul 21, 2013
Subject: Re: Wheel Pants have important function
wow! who would have thunk it? This must be something new? On Sun, Jul 21, 2013 at 8:27 AM, Dennis Thate wrote: > > Wheel fairings are often called "wheel pants", "speed fairings" or, in the > UK, "wheel spats". These fairings are a trade-off in advantages, as they > increase the frontal and surface area, but also provide a smooth surface, a > faired nose and tail for laminar flow, in an attempt to reduce the > turbulence created by the round wheel and its associated gear legs and > brakes. They also have the important function of preventing mud and stones > from being thrown upwards against the wings or fuselage, or into the > propeller on a pusher craft. > > -------- > Both optimists and pessimists contribute to our society. The optimist > invents the airplane and the pessimist the parachute. ~Gil Stern > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405007#405007 > > > Attachments: > > http://forums.matronics.com//files/dscn5855_107.jpg > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: Upgrading from 503 to 582 on Mark III
Date: Jul 21, 2013
I understand that you can use the same carbs on the 582, don't forget to rejet them. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405043#405043 ________________________________________________________________________________
Subject: Rushford Fly-in
Date: Jul 22, 2013
It was a wonderful flight to Rushford with lots of scenery in the hills and bluffs of southern Minnesota. My wife Laurie took video of the flight and we both enjoyed the breakfast served here. We also enjoyed the fun we had with friends and the joking around that we do with each other. This is one of best fly-ins we've attended. The people here were very hospitable and entertaining. I also liked the operations area and the professionalism in conducting the fly-in. Hats off to them! http://youtu.be/Oe7ZlBOGPmk Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 26 years flying it Kolbra 912ULS N20386 200 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405073#405073 ________________________________________________________________________________
Subject: Re: Rushford Fly-in
Date: Jul 22, 2013
Ralph, Sorry I wasn't able to fly over. But thanks for posting a great little video and bringing some exposure to their fly-In and some positive energy to this forum. Fly Safe! -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405077#405077 ________________________________________________________________________________
Date: Jul 22, 2013
Thanks for the comments guys. I plan to disconnect the static line from the probe and move it inside the cockpit and see what that does. I do have the fuel return line per Rotax recommendations. The engine is new from the factory so I would think the fuel float would be correct but will research that and see what it takes to change it. Waiting on the weather for the second flight. It's either been gusty crosswinds or thunderstorms the last few days. Rex Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405082#405082 ________________________________________________________________________________
Date: Jul 22, 2013
This is no Forum for Elderly Men -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405100#405100 Attachments: http://forums.matronics.com//files/nocountryoldmen_698.jpg ________________________________________________________________________________
Date: Jul 22, 2013
RGVubmlzLApJIG1heSBiZSBhIGJpdCBvcGFxdWUgYnV0IEknbSBoYXZpbmcgc29tZSBkaWZmaWN1 bHR5IHVuZGVyc3RhbmRpbmcgd2hhdCB0aGlzIGhhcyB0byBkbyB3aXRoIEtvbGJzLiBJZiB5b3Ug d291bGQgZXhwbGFpbiB0aGUgcmVsZXZhbmNlIEkgY2FuIGFzc3VyZSB5b3UgdGhlIGFnZ3JhdmF0 aW9uIHRvIHRob3NlIHdobyB1c2UgdGhlIGZvcnVtIHByb3Blcmx5IHdpdGggS29sYiByZWxhdGVk IHBvc3RzIHdpbGwgYmUgcmVkdWNlZC7CoAoKClNlbnQgZnJvbSBteSBWZXJpem9uIFdpcmVsZXNz IDRHIExURSBTbWFydHBob25lCgotLS0tLS0tLSBPcmlnaW5hbCBtZXNzYWdlIC0tLS0tLS0tCkZy b206IERlbm5pcyBUaGF0ZSA8cmV0cm9tYW5AZnJvbnRpZXIuY29tPiAKRGF0ZTogMDcvMjIvMjAx MyAgNToxNiBQTSAgKEdNVC0wNTowMCkgClRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbSAKU3Vi amVjdDogS29sYi1MaXN0OiBSZTogV2hlZWwgUGFudHMgaGF2ZSBpbXBvcnRhbnQgZnVuY3Rpb24g CiAKLS0+IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIkRlbm5pcyBUaGF0ZSIgPHJldHJv bWFuQGZyb250aWVyLmNvbT4KClRoaXMgaXMgbm8gRm9ydW0gZm9yIEVsZGVybHkgTWVuCgotLS0t LS0tLQpCb3RoIG9wdGltaXN0cyBhbmQgcGVzc2ltaXN0cyBjb250cmlidXRlIHRvIG91ciBzb2Np ZXR5LsKgIFRoZSBvcHRpbWlzdCBpbnZlbnRzIHRoZSBhaXJwbGFuZSBhbmQgdGhlIHBlc3NpbWlz dCB0aGUgcGFyYWNodXRlLsKgIH5HaWwgU3Rlcm4KCgoKClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUg aGVyZToKCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhwP3A9NDA1MTAw IzQwNTEwMAoKCgoKQXR0YWNobWVudHM6IAoKaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tLy9m aWxlcy9ub2NvdW50cnlvbGRtZW5fNjk4LmpwZwoKCgoKXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09wqDCoMKgwqDCoMKgwqDC oMKgIC0gVGhlIEtvbGItTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBM aXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0 aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERv d25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNo IG11Y2ggbW9yZToKXy09Cl8tPcKgwqAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZp Z2F0b3I/S29sYi1MaXN0Cl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKg IC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZh aWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyEKXy09Cl8tPcKgwqAgLS0+IGh0dHA6Ly9mb3J1bXMu bWF0cm9uaWNzLmNvbQpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0KXy09wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC0gTGlz dCBDb250cmlidXRpb24gV2ViIFNpdGUgLQpfLT3CoCBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJv dXMgc3VwcG9ydCEKXy09wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqDCoMKgwqDCoCAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPcKgwqAgLS0+IGh0 dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24KXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KCgoK ________________________________________________________________________________
Date: Jul 22, 2013
Or better still just say, "Look at my new wheel pants. ain't they purty". On Mon, Jul 22, 2013 at 3:53 PM, undoctor wrote: > Dennis, > I may be a bit opaque but I'm having some difficulty understanding what > this has to do with Kolbs. If you would explain the relevance I can assure > you the aggravation to those who use the forum properly with Kolb related > posts will be reduced. > > > Sent from my Verizon Wireless 4G LTE Smartphone > > > -------- Original message -------- > From: Dennis Thate <retroman(at)frontier.com> > Date: 07/22/2013 5:16 PM (GMT-05:00) > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: Wheel Pants have important function > > > This is no Forum for Elderly Men > > -------- > Both optimists and pessimists contribute to our society. The optimist > invents the airplane and the pessimist the parachute. ~Gil Stern > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405100#405100 > > > Attachments: > > http://forums.matronics.com//files/nocountryoldmen_698.jpg > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 22, 2013
[quote="lcottrell"]Or better still just say, "Look at my new wheel pants. ain't they purty". On Mon, Jul 22, 2013 at 3:53 PM, undoctor wrote: > Dennis, > I may be a bit opaque but I'm having some difficulty understanding what this has to do with Kolbs. If you would explain the relevance I can assure you the aggravation to those who use the forum properly with Kolb related posts will be reduced. > > > > > Sent from my Verizon Wireless 4G LTE Smartphone > > > > > -------- Original message -------- > From: Dennis Thate > Date: 07/22/2013 5:16 PM (GMT-05:00) > To: kolb-list(at)matronics.com (kolb-list(at)matronics.com) > Subject: Kolb-List: Re: Wheel Pants have important function > > > > This is no Forum for Elderly Men > > -------- > Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405100#405100 (http://forums.matronics.com/viewtopic.php?p=405100#405100) > > > > > Attachments: > > http://forums.matronics.com//files/nocountryoldmen_698.jpg (http://forums.matronics.com//files/nocountryoldmen_698.jpg) > Subscription, > //www.matronics.com/Navigator?Kolb-List" target="_blank">http://www.matronics.com/Navigator?Kolb-List > ttp://forums.matronics.com" target="_blank">http://forums.matronics.com > -Matt Dralle, List Admin. > ==== > > > > > -- If you forward this email, or any part of it, please remove my email address before sending. > [b] lcottrell ask yourself...are you an embarrassment to this forum and Homer's legacy ? -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405121#405121 ________________________________________________________________________________
Date: Jul 23, 2013
You reap what you sow, in life and on this forum . Enjoy ! -------- Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405150#405150 Attachments: http://forums.matronics.com//files/sowing_my_wild_oats_204.jpg ________________________________________________________________________________
Date: Jul 23, 2013
This is the first time seeing the hill country of Minnesota from the air. I want to go back on my Goldwing to visit. It's truly a spectacular area! Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 26 years flying it Kolbra 912ULS N20386 200 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405156#405156 ________________________________________________________________________________
Date: Jul 24, 2013
> take your time use WD 40 for lube I think you guys are more experienced at this.. but I will tentatively suggest also trying chainsaw bar oil. It is viscous, stays in place a while and removes chips pretty good. You can dip the drill bit in it once inna while then go drill some more. I bought a gallon 30 years ago and it will last me the rest of my life. OFF TOPIC I also have a good amount of Roundup. Again, about 30 years ago I bought a gallon, split it with a friend and have used it carefully since. It too will last me the rest of my life. My wife passed a coupla years ago. She had so much STUFF. New stuff, Christmas presents she opened and put back in the box for safe keeping, 'special' pretty things that she never used. $50,000 worth of diamonds she would never wear. Her best china. I learned a lesson from that. I have made some nephews and cousins and stuff happy cuz I looked through my gun collection and figgered that realistically I'd never use THIS one or THAT one again, so I gave them away. One nephew received a Hi Standard .22 pistol. He was so excited he never put it down again till they left to go home. Oh, he was still holding it even then. Another got the .30-06 with the new Redfield on it. A Belgium Browning FN. I been doing that with lots of my stuff. I always have been an acquisitive guy, but I get a lot of joy outta doing this, while I'm alive to see it! I'm not feeling morbid but I am more in touch with my mortality (is that possible?). ________________________________________________________________________________
Date: Jul 24, 2013
Here are some hopefully useful thoughts on radiators - the Rotax radiator part # 995-699 measures 10.5" X 11" x 1.25" thick which equals out to 115 square inches. It costs $439. My MKIII N402RP is using a motorcycle radiator purchased for $75 from the local motorcycle scrapyard, it is off some sort of street cruiser, a big Honda, don't remember exactly. The radiator measures 16" x 7.5" x 1.25" or 120 square inches. The FSII with 582 is using a similarly sourced radiator, it measures 15" x 8" x 1.25" once again 120 square inches. In both cases the radiators were mounted below and behind the wing and engine, where prop draw and below the wing airflow will help move a lot of air through them. On both airplanes we had excellent results most of the year, but we had a little trouble in the heat of summer on extended hard climbs, the temp would get close to redline and we would have to slack off a bit, let it cool down, and then go again. Given that the Rotax radiator is slightly smaller, it would not be surprising if other 582 operators also had some heat problems during the heat of summer. So here is how we fixed things: added a second radiator. In the case of the FSII, we just piggybacked a second smaller radiator off some forgotten bike behind the original, problem solved. (You bleed the air out of the piggybacker by loosening the big top bolt) On the MKIII, I decided to get rid of the brass Rotax expansion tank that is normally used to add water by just adding a dirt bike radiator instead, and attached it to the fairing that goes in front of the engine and holds the oil tank. It doesn't even face straight ahead, it is at an angle, because that lets the pipe fittings line up better, and the fairing will get the air in just fine regardless. Since all these radiators are aluminum, the added weight is minimal. Temps now stay constant year around on both airplanes. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405235#405235 Attachments: http://forums.matronics.com//files/p1030177_large_939.jpg http://forums.matronics.com//files/p1030182_large_163.jpg ________________________________________________________________________________
Date: Jul 24, 2013
Thank you for that tip. This is the reason I stay active on this site. These simple tips mean a lot to me and I'm sure other also. Wicks and Spruce have gotten enough of my money on gadgets they have. I have an use for your suggestion right now, so thank you. -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405282#405282 ________________________________________________________________________________
Date: Jul 26, 2013
Subject: Auto Response
I am UNAVAILABLE. I'll respond after the sixth of August. ________________________________________________________________________________
Subject: MKIII wing incidence
Date: Jul 26, 2013
Bob Bean, asked me to post this for him, since he no longer posts to this forum, but thought it might be of interest to other MKIII pilots. MKIII owners: I have for years intended to change the incidence on my wings and tail. I drilled new holes in the spar attach ears probably three years ago but, somehow never got around to it. -until this year. The reason for doing it pertains more to my individual plane than a stock MkIII because of my wide windshield design. I felt a conflict of airflow between it and the wing angle, much like what happened with early versions of the Xtra. -Too much down pressure on the nose. I drilled the new wing holes about 5/8" above the originals which works out to about 1.326 degrees. I bought the adjustable tail brackets from Kolb but modified them substantially. They were angled to allow wing fold using any of the holes but this makes the HS stick out too far at the lower settings. I cut the ears off to the same width and drilled new holes for two settings. I used a combination of calculation and guesswork to figure what range I would need. I went with the highest holes which yields about -3.5 degrees from the engine mount, figuring the tail boom is -6 degrees. Good thing, because with those holes I can still fold the tail without pulling any bolts. I had crow hopped it a couple days ago and parked it without real flight. Today was perfect flying weather so I did a test flight. Naturally I was hoping not to encounter any "lawn dart" characteristics and I was either a very clever guy or blessed with dumb luck, take yer choice, because it was perfect first time up. I had previously been flying with one notch up on the trim, but for this occasion I lowered it to zero. -Just right. Neutral stick at normal cruise and slight back pressure for full throttle straight and level. All other trim stayed the same. There is a noticeable increase in dihedral but I didn't get to doing any rudder experimentation to see how much it is affected. The plane feels as if it has been freed up from an invisible restraint. Hard to describe but I was quite pleased. It appears to cruise about 5 mph faster at normal settings. I didn't look close to check full throttle speed, just how muck stick it took. -Full throttle speed doesn't matter to me because I don't use it for other than climb. I couldn't say whether a standard configured MKIII would gain from the same changes but you would definitely need the tall steel legs to compensate. Also, because of my center section design, the angle could be changed without any extra work. Reminder: Previous written by Bob Bean, I'm merely posting it for him and I have no further information on it than you now do. However, since many may not be familiar with Bob's customized MKIII, I've attached an old photo so you can see what his airplane's nose and center section look like. -------- Thom Riddle Buffalo, NY (9G0) Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405333#405333 Attachments: http://forums.matronics.com//files/bean_mkiii_and_allegro__bethany_209.jpg ________________________________________________________________________________
Subject: Re: MKIII wing incidence
Date: Jul 26, 2013
re: Why doesn't Bob post to the forum any more? Bob is the busiest retired guy I know. His many and varied interests keep him otherwise occupied. He even built his own house! He is a craftsman with competencies in so many things that it boggles my mind. I don't recall EVER having at any age, as much energy as he has at 72. -------- Thom Riddle Buffalo, NY (9G0) Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405335#405335 ________________________________________________________________________________
Date: Jul 26, 2013
Thom, Could you get pics from BB of his front horizontal stab mounts? Due to the stock windshield bow, thus mod would be pretty tough in a stock Mk 3. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA On Jul 26, 2013, at 7:38 AM, "Thom Riddle" wrote: > > Bob Bean, asked me to post this for him, since he no longer posts to this forum, but thought it might be of interest to other MKIII pilots. > > MKIII owners: I have for years intended to change the incidence on my wings and tail. I drilled new holes in the spar attach ears probably three years ago > but, somehow never got around to it. -until this year. The reason for doing it pertains more to my individual plane than a stock MkIII because of my wide windshield design. > I felt a conflict of airflow between it and the wing angle, much like what happened with early versions of the Xtra. -Too much down pressure on the nose. > > I drilled the new wing holes about 5/8" above the originals which works out to about 1.326 degrees. I bought the adjustable tail brackets from Kolb but > modified them substantially. They were angled to allow wing fold using any of the holes but this makes the HS stick out too far at the lower settings. > I cut the ears off to the same width and drilled new holes for two settings. > I used a combination of calculation and guesswork to figure what range I would need. I went with the highest holes which yields about -3.5 degrees from the engine mount, > figuring the tail boom is -6 degrees. Good thing, because with those holes I can still fold the tail without pulling any bolts. > > I had crow hopped it a couple days ago and parked it without real flight. Today was perfect flying weather so I did a test flight. Naturally I was hoping not to > encounter any "lawn dart" characteristics and I was either a very clever guy or blessed with dumb luck, take yer choice, because it was perfect first time up. > > I had previously been flying with one notch up on the trim, but for this occasion I lowered it to zero. -Just right. Neutral stick at normal cruise and > slight back pressure for full throttle straight and level. All other trim stayed the same. There is a noticeable increase in dihedral but I didn't get to > doing any rudder experimentation to see how much it is affected. > > The plane feels as if it has been freed up from an invisible restraint. Hard to describe but I was quite pleased. It appears to cruise about 5 mph > faster at normal settings. I didn't look close to check full throttle speed, just how muck stick it took. -Full throttle speed doesn't matter to me > because I don't use it for other than climb. > > I couldn't say whether a standard configured MKIII would gain from the same changes but you would definitely need the tall steel legs to compensate. > Also, because of my center section design, the angle could be changed without any extra work. > > Reminder: Previous written by Bob Bean, I'm merely posting it for him and I have no further information on it than you now do. However, since many may not be familiar with Bob's customized MKIII, I've attached an old photo so you can see what his airplane's nose and center section look like. > > -------- > Thom Riddle > Buffalo, NY (9G0) > > > > Don't worry about old age... it doesn't last very long. > - Anonymous > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405333#405333 > > > > > Attachments: > > http://forums.matronics.com//files/bean_mkiii_and_allegro__bethany_209.jpg > > > > > > > ________________________________________________________________________________
Date: Jul 26, 2013
I can ask him. I'm going to get out of the middle of this conversation and try to get BB to respond. -------- Thom Riddle Buffalo, NY (9G0) Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405347#405347 ________________________________________________________________________________
Date: Jul 26, 2013
Dennis, Pardon me if I cut into your conversation to Thom (since both Bob Bean and I have made the "new incidence change.) Bob Bean had some kind of fender-bender several years ago, and made his own replacement nosecone. If appears to be a hybrid from the original round nosed MkIIIC and the wedge shaped X. (Mine is a pure TNK part) In keeping with all the other changes I made to my OEM MkIII C, I added the newer, taller, steel gear legs. This necessitated an incidence change to the main wings from the "high angle" to the new lower angle, found on the new Xtras with the taller steel gear legs. Bob Bean was making the changes I already made a couple of years ago. As I remember correctly, the Kolb instructions told us to drill a hole "UP" 7/8" from the bottom of the tab. (or 5/8". or 3/4"=85whatever it said) Again, from a fading memory, it's been a long time since I did that=85.this would give an effective angle of attack to the MkIIIC main wings of around +9 degrees, give or take a degree ( I think=85.) But! If you are going to add the tall steel gear legs, that high angle of attack doesn't work nicely with 3-point landings because if you have such a 'very high' angle of attack, you will find yourself being launched into the air just as the tail end drops too far. Therefore, to counteract this problem, Bryan Melbourne lowered the incidence of the wings, which also required a lower horizontal stabilizer angle, too. Plus, the wide Xtra nose figured into the deal, but we'd need Bryan to chime in tell explain all the details. To achieve the "new lower wings' incidence, a builder would then drill the tab hole that same 7/8" distance=85..only this time he down came from the TOP of the tab, not up from the bottom. I think this gives about an 1" to an 1 1/4" distance between the holes. At any rate, now, by inserting a bolt through the UPPER hole, you will be lowering the wings a fair amount. As it turns out, the final intended angle (from Bryan @ TNK Co) is +3.4 degrees (instead of that +9 degrees for regular geared MkIIICs of Xtras). Later, in discussing this angle change with Bryan, he said we were looking for "2.8 to 3.4 degrees". When I did mine, I came up with 3.4 exactly, 'cause that's what I was told. If I remember correctly, our buddy Scott Thompson came up with near +2.8. I think this is why I called and talked to Bryan. Evidently it was "a range" we were allowed, centered around +3.0. With all this main wing incidence changing, you have to also take into account the rear horizontal surfaces. The leading edge of the H.S. must come down a couple of degrees, in order to work well with the "reduced angle main wings". What that angle measurement is exactly we don't know yet, and we are waiting for the Bean to get back to us. He believes he nailed it on the first try. I'm anxious to know what the digital angle reading is. I asked him if he could also take a reading of his main wings, too, while he was at it, to help me establish a sort of basic logical platform to deal with. NOTE: All angles, readings, etc. are assumed to be read with an initial setting of the MkIII boom tube propped up to "6" degrees (or -6 degrees) EXACTLY. It is whatever makes the motor mount "0.0"!! BTW, I think the hor. stab is supposed to come in at -4.8 degrees. That is where I have mine set at. I have 3 other holes to choose from, 1 upper, 2 lower. My plane is almost finished, but medical issues and finances are slowing me down at the moment. Here is a photo of when I attached the Xtra nosecone to my completely rebuilt MkIIIC front end. (first photo) I used exact measurements from a OEM Xtra fuselage to modify my MkIIIC fuselage. (Pat Ladd's wrecked frame) The stick on top was to show a different member the intended angle he should achieve. He was going to do the MkIIIC to MkIIIX change, too, but I haven't heard from him in a year and a half. Oh yeah. You are correct, Dennis. Yes, the wing incidence change will require you to make a new, (probably custom) wing gap seal. I did mine out of fiberglass, under which is housed the ballistic chute in the front compartment. (see second and third photo) We now return you to your regularly scheduled program. Mike Welch By the way, you can see the increased dihedral from all the "normal" MkIIIs. When you use your old struts, like we did, and you lower the leading edge, you end up increasing the dihedral to about double the O.E. setting.. =46rom what I've heard, this is a good thing. (It ends up being close to 3.0 degrees) ________________________________________________________________________________
Date: Jul 26, 2013
> >Bob Bean, asked me to post this for him, since he no longer posts to this forum, but thought it might be of interest to other MKIII pilots. > .................. >I drilled the new wing holes about 5/8" above the originals which works out to about 1.326 degrees. I bought the adjustable tail brackets from Kolb but modified them substantially. They were angled to allow wing fold using any of the holes but this makes the HS stick out too far at the lower settings. > >The plane feels as if it has been freed up from an invisible restraint. Hard to describe but I was quite pleased. It appears to cruise about 5 mph faster at normal settings. I didn't look close to check full throttle speed, just how muck stick it took. > Bob, You may want to adjust the thrust vector by trial washer elevating the front and/or back of the engine to the mounting plate. If you are all ready getting a plus five mph at cruise it may be a useless endeavor. But it may get you a little bit more cruise speed. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Subject: Kolb flyer on craigslist
Date: Jul 27, 2013
Kolb flyer on craigslist http://tucson.craigslist.org/for/3927605950.html ________________________________________________________________________________
Date: Jul 27, 2013
> I put the long steel legs on my stock 1991 vintage Mk 3 a few years ago Where can I get the steel legs for my '80's Firestar? I bought it needing a recover but haven't done it yet so I haven't flown it. And there is the small matter of not being a pilot. ________________________________________________________________________________
Subject: gear legs
Date: Jul 27, 2013
Good Morning I am looking for a good set of spring steel gear legs for a MK 111 Classic. If anyone has or knows of a pair for sale, please call me at 765-346-2622. Thanks Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405409#405409 ________________________________________________________________________________
Subject: Re: gear legs
Date: Jul 27, 2013
If you don't find used legs, give that working man Travis a ring and he'll slick you right up. It's reassuring to know you got the right stuff the first time. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA On Jul 27, 2013, at 8:17 AM, "pipercolt" wrote: > > Good Morning > I am looking for a good set of spring steel gear legs for a MK 111 Classic. If anyone has or knows of a pair for sale, please call me at 765-346-2622. > Thanks > Bob > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405409#405409 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 27, 2013
As far as mounting what is involved? Do I need a new mounting kit? Any idea what they cost? Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405437#405437 ________________________________________________________________________________
Date: Jul 27, 2013
Mike, I checked the Two Stroke Installation Manual and the 503 and 582 have the same mounting dimensions, 94 mm X 153 mm, so you should be able to just bolt the 582 on. As I said before, if you use an "E" gearbox you have to move the hole pattern aft 3/4" (.750") to clear the starter motor and the rear motor mount cross member on the Kolb fuselage weldment. Rick Girard On Sat, Jul 27, 2013 at 1:30 PM, mike91911 wrote: > > As far as mounting what is involved? Do I need a new mounting kit? Any > idea what they cost? > Mike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405437#405437 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jul 27, 2013
Thank you so much. This is all very new to me and I still can't believe I own my own plane. Most people seem to be trying to talk me into going with the 582. My budget is limited but I want to do it right the first time and not be sorry I didn't upgrade to the 582. I guess I have some decisions to make. [quote="rickofudall"]Mike, I checked the Two Stroke Installation Manual and the 503 and 582 have the same mounting dimensions, 94 mm X 153 mm, so you should be able to just bolt the 582 on. As I said before, if you use an "E" gearbox you have to move the hole pattern aft 3/4" (.750") to clear the starter motor and the rear motor mount cross member on the Kolb fuselage weldment. Rick Girard On Sat, Jul 27, 2013 at 1:30 PM, mike91911 wrote: > > As far as mounting what is involved? Do I need a new mounting kit? Any idea what they cost? > Mike > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405437#405437 (http://forums.matronics.com/viewtopic.php?p=405437#405437) > > > > > > > > ========== > arget="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx > [b] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405456#405456 ________________________________________________________________________________
Date: Jul 28, 2013
Hey Bob Give me a call at 765-346-2622 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405535#405535 ________________________________________________________________________________
Date: Jul 28, 2013
I have a B gearbox now. It was mentioned above that I'd be happier with a C gearbox. Could you elaborate? Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405538#405538 ________________________________________________________________________________
Subject: fuel tank
Date: Jul 29, 2013
I have an older 5 rib Firestar. Refueling the other day I found a crack about half way up the side at a corner. It is a plastic tank that looks like the 5 gallon jug that cooking oil for commercial use comes in. The opening in the framework where the tank fits is 9 3/4 inches square. I've looked locally for a replacement but have had no luck. Anyone know of a source for one. I'll call Kolb today and see if they can help. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405559#405559 ________________________________________________________________________________
Date: Jul 30, 2013
Bob Bean sent me more info on his wing incidence mod, as follows: My plane was not the result of a "fender bender" but the combined parts of two other guy's wrecks. There was no nose cone included in any of the parts and I wanted more foot room so the wider nose was the result. It comes off with 10-32 machine screws for accessibility. BB -------- Thom Riddle Buffalo, NY (9G0) Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405658#405658 Attachments: http://forums.matronics.com//files/bb_wing_incidence_3_101.jpg http://forums.matronics.com//files/bb_wing_incidence_2_449.jpg http://forums.matronics.com//files/bb_wing_incidence_1_103.jpg ________________________________________________________________________________
Subject: Kolb Firestar avialable
Date: Jul 31, 2013
I'm new to the list... have a Firestar that's been sitting in storage of approx 14 years with only a few hours on it. Looking for advise on value and where and how to list it... Thank you... John ________________________________________________________________________________
Subject: Re: fuel tank
Date: Jul 31, 2013
Did Travis hook you up? Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA On Jul 29, 2013, at 8:38 AM, "gyrodude" wrote: > > I have an older 5 rib Firestar. Refueling the other day I found a crack about half way up the side at a corner. It is a plastic tank that looks like the 5 gallon jug that cooking oil for commercial use comes in. The opening in the framework where the tank fits is 9 3/4 inches square. I've looked locally for a replacement but have had no luck. Anyone know of a source for one. I'll call Kolb today and see if they can help. Thanks > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405559#405559 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 01, 2013
I believe this is what I have for a fuel tank on my 1985 vintage Firestar http://beprepared.com/5-gallon-water-jug.html -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405786#405786 ________________________________________________________________________________
Date: Aug 01, 2013
Travis was headed out the door to Oshkosh. Someone emailed me a source close to my home. I ordered it on Tuesday and got it the next day. $5.00 shipping zorotools.com. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405787#405787 ________________________________________________________________________________
Subject: rides last evening
Date: Aug 03, 2013
I gave all my grandkids rides last evening. It was a very nice evening to fly. Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 26 years flying it Kolbra 912ULS N20386 200 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405850#405850 Attachments: http://forums.matronics.com//files/leanna_2__824.jpg ________________________________________________________________________________
Subject: Need explanation of fuel system w/dual 5gal pickups
Date: Aug 03, 2013
I am rebuilding a Firestar II project. It has two 5 gal tanks, I have the plans from the mid-90's and (I thought) I had a pretty good understanding of aviation fuel systems and venting. However, I am seeing both tanks fed together to a T and then up to the pump or primer etc.. What I am missing is how the fuel is drawn from the tanks equally. It seems to me that once air is introduced to EITHER fuel pickup, the system will be fuel starved. I realize there is something I am not picking up from the drawings. I do not see any depiction of the venting which may hold the key. In any event, I would appreciate a few comments on best practices for plumbing the two standard 5 gal tanks. Thanks, Dave -------- Dave Smith RV7 Flying Kolb Firestar II (in-progress) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405880#405880 ________________________________________________________________________________
Subject: RE: Need explanation of fuel system w/dual 5gal pickups
Date: Aug 04, 2013
> It seems to me that once air is introduced to EITHER fuel pickup, the system will be fuel starved. Are the tanks at the same level? Are the pickups descending from a fitting at the bottom of the tanks, or do they drop down into the tanks from above? If the tanks are level, then when you suck air both tanks will be almost completely empty. In the case where the tanks are not level, if the pickups descend from a bottom fitting the weight of the fuel will displace the air potentially introduced from the empty tank, and the fuel line will have fuel in it. I have no experience with what I'm talking about here, I was just visualizing the situation. I probably have misunderstood you cuz I imagine you have already thought of all this. ________________________________________________________________________________
Subject: Re: Need explanation of fuel system w/dual 5gal pickups
Date: Aug 04, 2013
If you are feeding fuel from fittings attached to the bottom of each tank; and both tanks are vented and at the same level, then gravity will do a good job of evenly emptying both tanks. I didnt care much for drilling holes in the bottom of the tanks, so I opted to feed fuel from the top of each tank. If you are feeding fuel sucking from the top of each tank, then things are a bit different. Fuel flow here is more dependent on venting pressures for each tank to empty evenly. You are correct in that if one tank sucks air, its GAME OVER. I had one forced landing because of this and attributed it to a small pressure difference between the tank vents (they are located fore and aft in a breezy spot behind the pilot/passenger) where most likely each vent was subjected to different airflow patterns. There was only a small amount of fuel left in the other tank; so the system worked OK as long as neither one got too low. You might try tying both vents together to equalize any pressure differences; but just dont let the fuel level get too low and you wont have to worry about it. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405886#405886 ________________________________________________________________________________
Date: Aug 04, 2013
If switching tanks does not appeal to you, think about adding a hopper tank. Go to Home Depot and purchase some 4" PVC pipe and flat end caps. They sell 3 types of PVC pipe, one is thick wall and heavy, and the other is thin wall. The third type has a foam core, don't get the foam core. Gasoline doesn't affect the PVC. Make it whatever size you can get to fit anywhere near the back seat and below the level of the stock tanks. Make up some appropriate brackets and clamp it securely in place. It doesn't need to be very big, it just needs to hold a quart or so and be the lowest point in the system. NAPA auto parts sells a metal tire valve stem with a wide flat flange on each side and rubber gaskets, you can drill it out and use it as a fuel fitting, put it into the flat end cap of the pipe. Set it up so that both of your stock tanks drain into the hopper tank, and the hopper tank goes to your Facet pump. The fitting that goes to the Facet pump is obviously the lowest point in the system. Also rig it for a sump drain. Since this little hopper tank is below your stock tanks, you don't care if one of them drains dry, you only have to be on the ground before both of them drain dry. If you want to spend about $150 for various pieces-parts (mostly on on brass T fittings) you can put in 2 of these things, mount them vertically beside the forwardmost stock tank, and gain a bit over 2 gallons of fuel. Figuring out how to arrange all the plumbing will have you making up a real flow chart, but if you want 12 gallons of usable fuel, here's how to do it: http://www.bcchapel.org/pages/0003/FSIITankMods.html -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405898#405898 ________________________________________________________________________________
Date: Aug 04, 2013
My Slingshot had two 5 gallon tanks with a connection tube between them close to the bottom so that they acted almost as if they were one tank. I say almost because the connection was not in the bottom but on the side wall close to the bottom. The line to the electric fuel pump was from the top in the rear of the two tanks since it is a bit lower than the front except in a dive. The vent from the top of front tank went down and exited below the fuselage. Since the connection line was small (1/4") the flow between the two tanks was not nearly as fast as the rate you can fill the tanks. It is quicker to fill both than wait for one to drain to the other. If you don't mind putting holes in the bottom of the tank, which is what I would have done had I been the builder, the connection line will make them effectively one 10 gallon tank. RANS Aircraft has an excellent fuel tank fitting for the bottom of tanks and they do not leak. -------- Thom Riddle Buffalo, NY (9G0) Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405903#405903 ________________________________________________________________________________
Date: Aug 04, 2013
Richard The metal tire valve you mentioned Also makes an excelant fitting if you want to feed from the bottom of The tanks. Just drill out the center And use a fuel proof gasket. Used them for years my firestar. Frank----they come in 2 sizes, the Long ones work best. Sent from my iPhone On Aug 4, 2013, at 8:36 AM, "Richard Pike" wrote: > > If switching tanks does not appeal to you, think about adding a hopper tank. Go to Home Depot and purchase some 4" PVC pipe and flat end caps. They sell 3 types of PVC pipe, one is thick wall and heavy, and the other is thin wall. The third type has a foam core, don't get the foam core. Gasoline doesn't affect the PVC. Make it whatever size you can get to fit anywhere near the back seat and below the level of the stock tanks. Make up some appropriate brackets and clamp it securely in place. It doesn't need to be very big, it just needs to hold a quart or so and be the lowest point in the system. > > NAPA auto parts sells a metal tire valve stem with a wide flat flange on each side and rubber gaskets, you can drill it out and use it as a fuel fitting, put it into the flat end cap of the pipe. > > Set it up so that both of your stock tanks drain into the hopper tank, and the hopper tank goes to your Facet pump. The fitting that goes to the Facet pump is obviously the lowest point in the system. Also rig it for a sump drain. Since this little hopper tank is below your stock tanks, you don't care if one of them drains dry, you only have to be on the ground before both of them drain dry. > > If you want to spend about $150 for various pieces-parts (mostly on on brass T fittings) you can put in 2 of these things, mount them vertically beside the forwardmost stock tank, and gain a bit over 2 gallons of fuel. Figuring out how to arrange all the plumbing will have you making up a real flow chart, but if you want 12 gallons of usable fuel, here's how to do it: http://www.bcchapel.org/pages/0003/FSIITankMods.html > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > richard (at) bcchapel(dot)org > Kingsport, TN 3TN0 > Now faith is the substance of things hoped for, the evidence of things not seen. > Hebrews 11:1 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405898#405898 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 04, 2013
Hi Dave, I have the two tank system in my MkIII Xtra. The fuel pickup tubes go to the bottom of both tanks and I have connected them with a T at the top and then this single fuel line I run down to a fuel pump placed at the height of the bottom of the tanks. The trick is to initially suck fuel from BOTH tanks so there is no air in the lines. Both 5Gal tanks are side by side so if one is full and one is half full the fuel will eventually flow from the full to the lower until they are equal. My vent lines just plumb into the top of the tank and I run them up about 6 inches and then down to the outside of the plane. In case I go inverted the fuel will stay outside the aircraft. This system acts like one tank, no switching required. Just fill both up equally and its fine. I'm thinking of adding another 5 gal tank and may add a valve as a control into the 1st two if I do that. Hope this helps. Oh, I also have two fuel filters, one just after the T at the top of the tank and one on the fuel pump. No problems so far, 50Hrs flying. FrankD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405914#405914 ________________________________________________________________________________
Date: Aug 04, 2013
I have never tried this, but offer it to you for your consideration,, you would have to do some experimenting to see if the system works, or how hard to eliminate all the air. if you come out of the top of both tanks,,, then loop the lines to below both tanks and put the tee from both tanks and the inlet to the engine in the bottom of the cage. you would have to start a siphon from each tank to purge the air from both lines and establish a siphon. then each tank will drain via the siphon line to the tee. if one tank goes empty the siphon for that tank will quit, the other will continue to siphon till it is empty, if one tank is empty the other tank will keep the area of the tee (going to the engine) flooded with fuel, this should keep the engine happy till the second tank empties and the second siphon is lost. at that point you are out of gas and are going to let gravity be a major part of flying the plane. down side would be if you had a vacuum leak that stopped the siphon on one tank... your engine could quit with one tank full. to prevent this,, you could put a =9Cleft right or both=9D valve at the bottom the cage in place of a simple T, just thinking out loud. boyd young >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> I am rebuilding a Firestar II project. It has two 5 gal tanks, I have the plans from the mid-90's and (I thought) I had a pretty good understanding of aviation fuel systems and venting. However, I am seeing both tanks fed together to a T and then up to the pump or primer etc.. What I am missing is how the fuel is drawn from the tanks equally. It seems to me that once air is introduced to EITHER fuel pickup, the system will be fuel starved. I realize there is something I am not picking up from the drawings. I do not see any depiction of the venting which may hold the key. In any event, I would appreciate a few comments on best practices for plumbing the two standard 5 gal tanks. Thanks, Dave ________________________________________________________________________________
Date: Aug 04, 2013
One way to do it is to just use the front tank to feed the carbs via the Mi kuni pump, and use a facet pump to transfer fuel in flight. -When you fee l fuel on the back of your neck you know your font tank is full... -Once you feel the fuel on your neck you will never take your hand off the pump s witch during a transfer again.=0A=0ASome good fuel system suggestions:- =0Ahttp://www.challengers101.com/FuelSys.html=0A-=0A=0A=0A=0A=0A=0A______ __________________________=0A From: dsmithlib <dsmithlib(at)ameritech.net>=0AT o: kolb-list(at)matronics.com =0ASent: Saturday, August 3, 2013 9:29 PM=0ASubj ect: Kolb-List: Need explanation of fuel system w/dual 5gal pickups=0A =0A =0A=0AI am rebuilding a Firestar II project.- It has two 5 gal tanks, I h ave the plans from the mid-90's and (I thought) I had a pretty good underst anding of aviation fuel systems and venting.=0A=0AHowever, I am seeing both tanks fed together to a T and then up to the pump or primer etc..- What I am missing is how the fuel is drawn from the tanks equally.- It seems to me that once air is introduced to EITHER fuel pickup, the system will be fuel starved.- =0A=0AI realize there is something I am not picking up fr om the drawings.- I do not see any depiction of the venting which may hol d the key.- In any event, I would appreciate a few comments on best pract ices for plumbing the two standard 5 gal tanks.=0A=0AThanks,=0ADave=0A=0A-- ------=0ADave Smith=0ARV7 Flying=0AKolb Firestar II (in-progress)=0A=0A=0A =0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtop - - - - - - - - - - - - -Matt Dralle, List Admin. ==== ________________________________________________________________________________
Date: Aug 04, 2013
can I throw another question out there? I am putting a "Rotax Rick" 670 on a Classic Mark III and I'm wondering if I am OK with an E gearbox(after seeing the comment regarding having to move the 582 mount back 3/4" to clear the starter going from the 503 to the 582 any thoughts? am I ok with the E gearbox? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405945#405945 ________________________________________________________________________________
Date: Aug 05, 2013
Thank you to all for replying. >From what I have learned here...... I will... use individual pickups from the top then connect with a T then go to a filter then to a elec facet pump then to the pulse pump I will T off at some point for primer They will be well vented but I am not sure how I will plumb the vents at this moment......sounds like they will also get T'd and then plumbed overboard. Thank you ! Thank you ! Thank you ! -------- Dave Smith RV7 Flying Kolb Firestar II (in-progress) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405973#405973 ________________________________________________________________________________
Date: Aug 05, 2013
I keep hearing people say they don't want to put the fuel pickup on the bottom of their tanks. I don't understand their issues. I have been flying my VW powered MKIIIC for fifteen years. I use the press fit bushings in the standard Kolb plastic tanks and have never had a seeping fuel issue. About 7-8 years ago I replaced the tanks just to be safe and again no issues. I now have the 6 gallon tanks ready to install and yes I have drilled the bottoms and installed the press fit bushings. I insert a fitting that has a finger strainer and shut off valve. My theory is feeding fuel from the bottom is the most reliable way to get fuel to my engine because there are fewer things that can go wrong. Fuel feeds evenly from both tanks and if one tank gets filled more than the other they will equalize in time. Again I have never had a press fit bushing leak but I have had a fuel line leak. When the fuel line developed a leak it was dangerous but it didn't cause a engine failure like would have happened if I was feeding from the top of the tanks. I did notice a fuel smell that got me looking. It would seem that fuel seepage would be the worst case problem for bottom feed. If you top feed and you get even a minor air leak you wouldn't know till engine start or worst case in the air. I use a stepped drill bit to drill the hole in the plastic fuel tanks for the fuel bushings. I think they drill a more rounded hole in thin plastic. Then I very carefully debur the holes. I tee the fuel tanks together. I have flown many different GA airplanes that have fuel selectors and they are a pain. Something else that you HAVE to do. On low wing airplanes with wing tanks, where it is necessary it is a necessary evil, it is ok. Why add something like a fuel selector that adds to the work load and is a potential problem? Just my opinion. As always this is worth what you paid for it. Rick Neilsen 1st Redrive VW powered MKIIIC On Sun, Aug 4, 2013 at 12:44 PM, Frankd wrote: > > Hi Dave, > > I have the two tank system in my MkIII Xtra. > The fuel pickup tubes go to the bottom of both tanks and I have connected > them with a T at the top and then this single fuel line I run down to a > fuel pump placed at the height of the bottom of the tanks. > > The trick is to initially suck fuel from BOTH tanks so there is no air in > the lines. > > Both 5Gal tanks are side by side so if one is full and one is half full > the fuel will eventually flow from the full to the lower until they are > equal. > My vent lines just plumb into the top of the tank and I run them up about > 6 inches and then down to the outside of the plane. In case I go inverted > the fuel will stay outside the aircraft. > > This system acts like one tank, no switching required. Just fill both up > equally and its fine. > I'm thinking of adding another 5 gal tank and may add a valve as a control > into the 1st two if I do that. > > Hope this helps. > > Oh, I also have two fuel filters, one just after the T at the top of the > tank and one on the fuel pump. No problems so far, 50Hrs flying. > > FrankD > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405914#405914 > > ________________________________________________________________________________
Date: Aug 05, 2013
X-mailer: Pegasus Mail for Windows (4.61) Murphy said it best - "Anything that can go wrong, will go wrong". Yours doesn't leak and hasn't leaked. That's not to say that at some time in the future it won't leak. The top plumbed units won't leak as yours might but still have a slight chance of leaking thru a cracked seam or some other mechanism. There is no advantage to top plumbed except possibly access and maintenance. Top plumbed allows me to but a bronze filtered clunk at the bottom of the tank standpipe without having to pull the tank out. All maintenance can be done with the tank as is, where is. Either methodology, top or bottom, will work, just depends on your point of view. I've had the same tanks for 18 years. There was never a time when I doubted the integrity of fuel delivery methodology chosen. Personal choice, not a denouncement. Subject: Re: Kolb-List: Re: Need explanation of fuel system w/dual 5gal pickups From: Rick Neilsen To: kolb-list(at)matronics.com Send reply to: kolb-list(at)matronics.com > > I keep hearing people say they don't want to put the fuel pickup on the bottom of their tanks. I > don't understand their issues. I have been flying my VW powered MKIIIC for fifteen years. I use > the press fit bushings in the standard Kolb plastic tanks and have never had a seeping fuel > issue. About 7-8 years ago I replaced the tanks just to be safe and again no issues. I now have > the 6 gallon tanks ready to install and yes I have drilled the bottoms and installed the press fit > bushings. I insert a fitting that has a finger strainer and shut off valve. > > My theory is feeding fuel from the bottom is the most reliable way to get fuel to my engine > because there are fewer things that can go wrong. Fuel feeds evenly from both tanks and if one > tank gets filled more than the other they will equalize in time. Again I have never had a press fit > bushing leak but I have had a fuel line leak. When the fuel line developed a leak it was > dangerous but it didn't cause a engine failure like would have happened if I was feeding from the > top of the tanks. I did notice a fuel smell that got me looking. It would seem that fuel seepage > would be the worst case problem for bottom feed. If you top feed and you get even a minor air > leak you wouldn't know till engine start or worst case in the air. > > I use a stepped drill bit to drill the hole in the plastic fuel tanks for the fuel bushings. I think they > drill a more rounded hole in thin plastic. Then I very carefully debur the holes. > > I tee the fuel tanks together. I have flown many different GA airplanes that have fuel selectors > and they are a pain. Something else that you HAVE to do. On low wing airplanes with wing > tanks, where it is necessary it is a necessary evil, it is ok. Why add something like a fuel selector > that adds to the work load and is a potential problem? > > Just my opinion. As always this is worth what you paid for it. > > Rick Neilsen > 1st Redrive VW powered MKIIIC > > On Sun, Aug 4, 2013 at 12:44 PM, Frankd wrote: > > Hi Dave, > > I have the two tank system in my MkIII Xtra. > The fuel pickup tubes go to the bottom of both tanks and I have connected them with a T at > the top and then this single fuel line I run down to a fuel pump placed at the height of the > bottom of the tanks. > > The trick is to initially suck fuel from BOTH tanks so there is no air in the lines. > > Both 5Gal tanks are side by side so if one is full and one is half full the fuel will eventually > flow from the full to the lower until they are equal. > My vent lines just plumb into the top of the tank and I run them up about 6 inches and then > down to the outside of the plane. In case I go inverted the fuel will stay outside the aircraft. > > This system acts like one tank, no switching required. Just fill both up equally and its > fine. > I'm thinking of adding another 5 gal tank and may add a valve as a control into the 1st two > if I do that. > > Hope this helps. > > Oh, I also have two fuel filters, one just after the T at the top of the tank and one on the > fuel pump. No problems so far, 50Hrs flying. > > FrankD > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405914#405914 > > > > > > > > ========== > arget="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > > > > http://www.matronics.com/Navigator?Kolb-List > _- =========================================================== > _- =========================================================== > _- =========================================================== > > Jim Baker Elmore City, OK 580.788.2779 home 405.426.5377 cell ________________________________________________________________________________
Subject: Re: rides last evening
Date: Aug 05, 2013
Thanks Ralph, she looks like she's having a ball. Fun is what it's all about..... :D -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406003#406003 ________________________________________________________________________________
Subject: Re: Upgrading from 503 to 582 on Mark III
Date: Aug 05, 2013
You'll be fine, moving a 670 rearward a little shouldn't cause any CG issues as it is much lighter than 912s and VW engines many are using. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA On Aug 4, 2013, at 11:30 PM, "lownslow" wrote: > > can I throw another question out there? I am putting a "Rotax Rick" 670 on a Classic Mark III and I'm wondering if I am OK with an E gearbox(after seeing the comment regarding having to move the 582 mount back 3/4" to clear the starter going from the 503 to the 582 > > any thoughts? am I ok with the E gearbox? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405945#405945 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 05, 2013
awesome Dennis, thanks so much, sir! I figured that was the case but wanted to be sure. I appreciate it! Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406019#406019 ________________________________________________________________________________
Date: Aug 06, 2013
> I use the press fit bushings in the standard Kolb plastic tanks I am not 100% sure I know what you mean here. Is 'press fit' the gadget that is held in place in the hole by a neoprene grommet? It is a short tube with a sort of barb on the end so the fuel line won't come off? > Venting. Something I haven't seen discussed on the forum is venting that will not become a drain The circle track racers wind the vent tube around the tank 2-3 times. ________________________________________________________________________________
Date: Aug 06, 2013
George The press fit bushings are ultralight/light plane standard fuel fittings They are inserted into a hole in plastic fuel tanks. They are a fuel proof rubber like material. After they are inserted a metal fuel fitting is pressed into the bushing which locks the bushing in place and makes the assembly highly leak resistant. They do require that the proper sized hole is drilled, that is the hole is carefully debured, and the fuel fitting is lightly lubricated when it is installed. Rick Neilsen Redrive VW Powered MKIIIC On Tue, Aug 6, 2013 at 4:51 AM, George Bearden wrote: > > > I use the press fit bushings in the standard Kolb plastic tanks > > I am not 100% sure I know what you mean here. Is 'press fit' the gadget > that > is held in place in the hole by a neoprene grommet? It is a short tube with > a sort of barb on the end so the fuel line won't come off? > > > Venting. Something I haven't seen discussed on the forum is venting that > will not become a drain > > The circle track racers wind the vent tube around the tank 2-3 times. > > ________________________________________________________________________________
Date: Aug 06, 2013
"Rick Lewis" > Thanks Ralph, she looks like she's having a ball. Fun is what it's all about..... :D Hey Rick, I've been giving a lot of rides lately. All my grandkids, friends, and wife ride but not at the same time :). The Kolbra has a lot more power with the 100hp than that 'ol worn out 912 80hp that the thieves stole. In fact that one had very little compression and would have needed rebuilding soon anyway. I'm having a lot more fun now than ever before. We like the new engine much better. I didn't let the terrorists win! -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 26 years flying it Kolbra 912ULS N20386 300 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406049#406049 ________________________________________________________________________________
Subject: Evan rides in the Kolbra
Date: Aug 06, 2013
My grandson Evan got a ride last Sunday afternoon. Here's a short video of the flight: http://youtu.be/j6OFL7n8ggs Ralph B -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 26 years flying it Kolbra 912ULS N20386 300 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406059#406059 ________________________________________________________________________________
Date: Aug 07, 2013
Subject: RE: Kolb-List Digest: 4 Msgs - 08/06/13
Rick: Where do you order these press fit bushings? Thanks. Bob From: Rick Neilsen <neilsenrm(at)gmail.com> George The press fit bushings are ultralight/light plane standard fuel fittings They are inserted into a hole in plastic fuel tanks. They are a fuel proof rubber like material. After they are inserted a metal fuel fitting is pressed into the bushing which locks the bushing in place and makes the assembly highly leak resistant. They do require that the proper sized hole is drilled, that is the hole is carefully debured, and the fuel fitting is lightly lubricated when it is installed. Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Subject: Re: RE: Kolb-List Digest: 4 Msgs - 08/06/13
Date: Aug 07, 2013
Bob JBM has them.Buy them on line,get them in 2-3 days -----Original Message----- From: Bob Green <bgreen(at)bimi.org> Sent: Wed, Aug 7, 2013 2:43 pm Subject: Kolb-List: RE: Kolb-List Digest: 4 Msgs - 08/06/13 Rick: Where do you order these press fit bushings? Thanks. Bob From: Rick Neilsen <neilsenrm(at)gmail.com> George The press fit bushings are ultralight/light plane standard fuel fittings They are inserted into a hole in plastic fuel tanks. They are a fuel proof rubber like material. After they are inserted a metal fuel fitting is pressed into the bushing which locks the bushing in place and makes the assembly highly leak resistant. They do require that the proper sized hole is drilled, that is the hole is carefully debured, and the fuel fitting is lightly lubricated when it is installed. Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Date: Aug 08, 2013
Bob Also Kolb, Aircraft Spruce, or any of the ultralight parts venders. Rick Neilsen Redrive VW Powered MKIIIC On Wed, Aug 7, 2013 at 8:13 PM, Gary Aman wrote: > Bob > JBM has them.Buy them on line,get them in 2-3 days > > > -----Original Message----- > From: Bob Green <bgreen(at)bimi.org> > To: kolb-list > Sent: Wed, Aug 7, 2013 2:43 pm > Subject: Kolb-List: RE: Kolb-List Digest: 4 Msgs - 08/06/13 > > > Rick: > Where do you order these press fit bushings? > Thanks. > Bob > > From: Rick Neilsen <neilsenrm(at)gmail.com > > > > George > > The press fit bushings are ultralight/light plane standard fuel fittings > They are inserted into a hole in plastic fuel tanks. They are a fuel proof > rubber like material. After they are inserted a metal fuel fitting is > pressed into the bushing which locks the bushing in place and makes the > assembly highly leak resistant. They do require that the proper sized hole > is drilled, that is the hole is carefully debured, and the fuel fitting is > lightly lubricated when it is installed. > > Rick Neilsen > Redrive VW Powered MKIIIC > > get="_blank">http://www.matronics.com/Navigator?Kolb-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > * > > * > > ________________________________________________________________________________
Date: Aug 10, 2013
George/All I was just looking up the fuel bushings we were talking about. I found a supplier that makes a viton bushing that they claim is more resistant to the ethanol in our fuels. See the following link then go to page 18. On the same page they sell a gascolator that has a quick drain that is real good to put in the lowest part of your fuel system before the filter and fuel pump. Also on page 17 they sell a fuel fitting (that I use) for use with the bushings that has a finger strainer and a shut off valve. http://onlinecatalog.leadingedgeairfoils.com/skin/entrymap/entrymap_singlebook.asp?SkinId=7.1.6.20 Rick Neilsen Redrive VW Powered MKIIIC On Tue, Aug 6, 2013 at 9:10 AM, Rick Neilsen wrote: > George > > The press fit bushings are ultralight/light plane standard fuel fittings > They are inserted into a hole in plastic fuel tanks. They are a fuel proof > rubber like material. After they are inserted a metal fuel fitting is > pressed into the bushing which locks the bushing in place and makes the > assembly highly leak resistant. They do require that the proper sized hole > is drilled, that is the hole is carefully debured, and the fuel fitting is > lightly lubricated when it is installed. > > Rick Neilsen > Redrive VW Powered MKIIIC > > > On Tue, Aug 6, 2013 at 4:51 AM, George Bearden wrote: > >> >> > I use the press fit bushings in the standard Kolb plastic tanks >> >> I am not 100% sure I know what you mean here. Is 'press fit' the gadget >> that >> is held in place in the hole by a neoprene grommet? It is a short tube >> with >> a sort of barb on the end so the fuel line won't come off? >> >> > Venting. Something I haven't seen discussed on the forum is venting that >> will not become a drain >> >> The circle track racers wind the vent tube around the tank 2-3 times. >> >> >> >> >> >> > ________________________________________________________________________________
Date: Aug 11, 2013
Subject: Fuel Systems
I have been reading the discussion about fuel tank systems. I fly the Firestar 11, and found the same problems with the top fuel draw system. The aircraft fly's with the tail high, so the tanks are not level in flight the rear tank will run dry before the front one will, and as soon as the the rear tank runs dry and starts to suck air the engine will stop due to fuel starvation. So I decided to go to the bottom delivery system. I personally did not like the rubber push-in tank grommet in the bottom of the tank, I must say I have never heard of this system failing, but I did find this "Tank Access Bulkhead" in CPS cat. p/n 8561for $12.95 and the "Threaded Hose Barb" p/n 8521 for $1.59, for me to have piece-of-mind that is was screwed together and it made it easy to add a gascolator too. Fly safe.. Tim ________________________________________________________________________________
Date: Aug 11, 2013
Subject: Re: Fuel Systems
On 8/11/2013 11:23 AM, Tim Bjork wrote: > I have been reading the discussion about fuel tank systems. I fly the > Firestar 11, and found the same problems with the top fuel draw > system. The aircraft fly's with the tail high, so the tanks are not > level in flight the rear tank will run dry before the front one will, > and as soon as the the rear tank runs dry and starts to suck air the > engine will stop due to fuel starvation. So I decided to go to the > bottom delivery system. I personally did not like the rubber push-in > tank grommet in the bottom of the tank, I must say I have never heard > of this system failing, but I did find this "Tank Access Bulkhead" in > CPS cat. p/n 8561for $12.95 and the "Threaded Hose Barb" p/n 8521 for > $1.59, for me to have piece-of-mind that is was screwed together and > it made it easy to add a gascolator too. > Fly safe.. Tim Some years back someone posted of a way to empty the rear tank first by not venting the front tank and running a fuel pickup thru the top of the rear tank into the top of the front tank then venting only the back tank. It will empty the rear tank first then act as the vent for the front tank. Who ever it was said it worked fine. Just a though!! Jack Carillon FS II Akron Ohio ________________________________________________________________________________
Date: Aug 11, 2013
SSBoYXZlIGEgZmlyZWZseSBhbmQgdXNlIGEgMiAxLzIgdGFuayBiZWhpbmQgdGhlIDUgYW5kIEkg dXNlIHRoZSBzZWNvbmQgdGFuayBhcyB2ZW50IGl0IGVtcHRpZXMgZmlyc3Qgd29ya3MgZ3JlYXQu CgoKU2VudCBmcm9tIG15IFZlcml6b24gV2lyZWxlc3MgNEcgTFRFIFNtYXJ0cGhvbmUKCi0tLS0t LS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS0KRnJvbTogSmFjayA8cGNhcmlsbG9uc3JAbmVv LnJyLmNvbT4gCkRhdGU6IDA4LzExLzIwMTMgIDI6MjAgUE0gIChHTVQtMDU6MDApIApUbzoga29s Yi1saXN0QG1hdHJvbmljcy5jb20gClN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IEZ1ZWwgU3lzdGVt cyAKIApPbiA4LzExLzIwMTMgMTE6MjMgQU0sIFRpbSBCam9yayB3cm90ZToKSSBoYXZlIGJlZW4g cmVhZGluZyB0aGUgZGlzY3Vzc2lvbiBhYm91dCBmdWVsIHRhbmsgc3lzdGVtcy4gSSBmbHkgdGhl IEZpcmVzdGFyIDExLCBhbmQgZm91bmQgdGhlIHNhbWUgcHJvYmxlbXMgd2l0aCB0aGUgdG9wIGZ1 ZWwgZHJhdyBzeXN0ZW0uIFRoZSBhaXJjcmFmdCBmbHkncyB3aXRoIHRoZSB0YWlsIGhpZ2gsIHNv IHRoZSB0YW5rcyBhcmUgbm90IGxldmVsIGluIGZsaWdodCB0aGUgcmVhciB0YW5rIHdpbGwgcnVu IGRyeSBiZWZvcmUgdGhlIGZyb250IG9uZSB3aWxsLCBhbmQgYXMgc29vbiBhcyB0aGUgdGhlIHJl YXIgdGFuayBydW5zIGRyeSBhbmQgc3RhcnRzIHRvIHN1Y2sgYWlyIHRoZSBlbmdpbmUgd2lsbCBz dG9wIGR1ZSB0byBmdWVsIHN0YXJ2YXRpb24uIFNvIEkgZGVjaWRlZCB0byBnbyB0byB0aGUgYm90 dG9tIGRlbGl2ZXJ5IHN5c3RlbS4gSSBwZXJzb25hbGx5IGRpZCBub3QgbGlrZSB0aGUgcnViYmVy IHB1c2gtaW4gdGFuayBncm9tbWV0IGluIHRoZSBib3R0b20gb2YgdGhlIHRhbmssIEkgbXVzdCBz YXkgSSBoYXZlIG5ldmVyIGhlYXJkIG9mIHRoaXMgc3lzdGVtIGZhaWxpbmcsIGJ1dCBJIGRpZCBm aW5kIHRoaXMgIlRhbmsgQWNjZXNzIEJ1bGtoZWFkIsKgIGluIENQUyBjYXQuIHAvbiA4NTYxZm9y ICQxMi45NSBhbmQgdGhlICJUaHJlYWRlZCBIb3NlIEJhcmIiIHAvbiA4NTIxIGZvciAkMS41OSwg Zm9yIG1lIHRvIGhhdmUgcGllY2Utb2YtbWluZCB0aGF0IGlzIHdhcyBzY3Jld2VkIHRvZ2V0aGVy IGFuZCBpdCBtYWRlIGl0IGVhc3kgdG8gYWRkIGEgZ2FzY29sYXRvcsKgIHRvby4KwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoCBGbHkgc2FmZS4uwqAgVGltCgoKwqDCoMKgIFNvbWUgeWVhcnMgYmFjayBzb21lb25lIHBv c3RlZCBvZiBhIHdheSB0byBlbXB0eSB0aGUgcmVhciB0YW5rIGZpcnN0IGJ5IG5vdCB2ZW50aW5n IHRoZSBmcm9udCB0YW5rwqAgYW5kIHJ1bm5pbmcgYSBmdWVsIHBpY2t1cCB0aHJ1IHRoZSB0b3Ag b2YgdGhlIHJlYXIgdGFua8KgIGludG8gdGhlIHRvcCBvZiB0aGUgZnJvbnQgdGFuayB0aGVuIHZl bnRpbmcgb25seSB0aGUgYmFjayB0YW5rLsKgIEl0IHdpbGwgZW1wdHkgdGhlIHJlYXIgdGFuayBm aXJzdCB0aGVuIGFjdCBhcyB0aGUgdmVudCBmb3IgdGhlIGZyb250IHRhbmsuwqDCoCBXaG8gZXZl ciBpdCB3YXMgc2FpZCBpdCB3b3JrZWQgZmluZS4KwqBKdXN0IGEgdGhvdWdoISEKCsKgwqDCoMKg wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgSmFjayBDYXJpbGxvbiBGUyBJ ScKgIEFrcm9uIE9oaW8KCgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgLSBUaGUgS29sYi1MaXN0IEVtYWls IEZvcnVtIC0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRv IGJyb3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNj cmlwdGlvbiwKXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hh dCwgRkFRLApfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOgpfLT0KXy09ICAgLS0+ IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0Cl8tPQpfLT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpf LT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQg Y29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gICAtLT4g aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgLSBM aXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVy b3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxs ZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmli dXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0KCg= ________________________________________________________________________________
Date: Aug 11, 2013
Not to beat a dead horse but I have a Flightstar IISC in the shop for an annual right now. I was in the process of rewinding the bungee cords on the main gear and had to move the fuel tap on the bottom of the tank to get access to the left main gear. All I did was twist the push in fitting slightly and it began to drip gas. Nothing I could do would stop it once it had started, yet I could see no evidence of previous leakage. I drained the tank and removed the fuel grommet. Sure enough, it was split. I guess all it took was moving the fitting to finish off the split. Thankfully I had new grommets in stock and it didn't happen while the owner was out flying around as there is no fuel gauge in the aircraft. Not that bottom taps are bad, they're just one more inspection item. Rick Girard On Sun, Aug 11, 2013 at 3:33 PM, blong6826 wrote: > I have a firefly and use a 2 1/2 tank behind the 5 and I use the second > tank as vent it empties first works great. > > > Sent from my Verizon Wireless 4G LTE Smartphone > > > -------- Original message -------- > From: Jack <pcarillonsr(at)neo.rr.com> > Date: 08/11/2013 2:20 PM (GMT-05:00) > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Fuel Systems > > > On 8/11/2013 11:23 AM, Tim Bjork wrote: > > I have been reading the discussion about fuel tank systems. I fly the > Firestar 11, and found the same problems with the top fuel draw system. The > aircraft fly's with the tail high, so the tanks are not level in flight the > rear tank will run dry before the front one will, and as soon as the the > rear tank runs dry and starts to suck air the engine will stop due to fuel > starvation. So I decided to go to the bottom delivery system. I personally > did not like the rubber push-in tank grommet in the bottom of the tank, I > must say I have never heard of this system failing, but I did find this > "Tank Access Bulkhead" in CPS cat. p/n 8561for $12.95 and the "Threaded > Hose Barb" p/n 8521 for $1.59, for me to have piece-of-mind that is was > screwed together and it made it easy to add a gascolator too. > Fly safe.. Tim > > > Some years back someone posted of a way to empty the rear tank first by > not venting the front tank and running a fuel pickup thru the top of the > rear tank into the top of the front tank then venting only the back tank. > It will empty the rear tank first then act as the vent for the front > tank. Who ever it was said it worked fine. > Just a though!! > > Jack Carillon FS II Akron Ohio > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Giving a friend a ride
Date: Aug 12, 2013
Took a friend of mine up for ride. He has the hanger next to mine and owns an Avid Flyer. I was interested to hear his comments. He took some video and seemed to enjoy himself. The link to the YouTube video is below: http://youtu.be/2m4nv3jy5g4 Thanks, Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406523#406523 ________________________________________________________________________________
Date: Aug 12, 2013
Subject: Registration
I just got my notice for re-registration. It states that it is due Sept 1st, but that the registration expires on Jan 31, 2014. It also states that the renewal fee must arrive before Nov 30th and the early filing will not affect the new expiration date. Do I correctly recall that someone else had a problem with filing early? Thanks Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 13, 2013
Brother Cottrell: Some free (almost gratis) advice, sir. Kindly excuse me if you already know about this distinction. Be thou exceedingly cautious in this process, lest you fall into the same federal mudhole 'ol Beauford did. Your e-mail mentioned "re-registration" . The correct terminology here is "registration renewal", not "re-registration".. The proper form is the AC Form 8050-1B for renewal, and NOT the AC Form 8050-1A, which addresses re-registration of an acft. The fun-loving lads in Oklahoma sent back my One-Alfa Re-Registration form along with a mildly insulting letter and a copy of the blank "renewal" form one bravo, with which I was invited to repent (and send five more bucks). I promised to reform myself, executed the One-Bravo form, and re-sent the Oakie Caesar his re-due. This item is submitted in hopes of preventing any other Listers from making the same dumb error I did. Worth what ye paid fer it. beauford FF-076 Brandon, FL If you forward this e-mail, please remove my name before sending it... I promise to do the same for you... Thanks... From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Subject: Kolb-List: Registration I just got my notice for re-registration. It states that it is due Sept 1st, but that the registration expires on Jan 31, 2014. It also states that the renewal fee must arrive before Nov 30th and the early filing will not affect the new expiration date. Do I correctly recall that someone else had a problem with filing early? Thanks Larry ________________________________________________________________________________
Date: Aug 13, 2013
Subject: Re: Registration
Thanks Beauford, I have already sent in my renewal although the link that they provided to do so did not work on my computer, :-/ go figure! I went to bing and apparently got lucky and typed in the proper wording. I just checked my copy and it appears that I might have gotten lucky and did it right. Larry On Tue, Aug 13, 2013 at 3:37 PM, Beauford wrot e: > Brother Cottrell:**** > > ** ** > > Some free (almost gratis) advice, sir=85 Kindly excuse me if you already > know about this distinction.**** > > ** ** > > Be thou exceedingly cautious in this process, lest you fall into**** > > the same federal mudhole =91ol Beauford did=85 Your e-mail mentioned > =93re-registration=94 =85**** > > ** ** > > The correct terminology here is =93registration *renewal*=94, not > =93re-registration=94=85.**** > > ** ** > > The proper form is the AC Form 8050-1B for renewal, and *NOT* the **** > > AC Form 8050-1A, which addresses re-registration of an acft.**** > > ** ** > > The fun-loving lads in Oklahoma sent back my One-Alfa Re-Registration for m > along with a mildly insulting letter**** > > and a copy of the blank =93renewal=94 form one bravo, with which I was in vited > to repent (and send five more bucks).**** > > ** ** > > I promised to reform myself, executed the One-Bravo form, and re-sent th e > Oakie Caesar his re-due=85**** > > ** ** > > This item is submitted in hopes of preventing any other Listers from > making the same dumb error I did.**** > > ** ** > > Worth what ye paid fer it=85**** > > ** ** > > beauford**** > > FF-076**** > > Brandon, FL**** > > ** ** > > If you forward this e-mail, please remove my name before sending it... I > promise to do the same for you...**** > > Thanks...**** > > ** ** > > *From:* owner-kolb-list-server(at)matronics.com [mailto: > owner-kolb-list-server(at)matronics.com] *On Behalf Of *Larry Cottrell > > *Subject:* Kolb-List: Registration**** > > ** ** > > I just got my notice for re-registration. It states that it is due Sept > 1st, but that the registration expires on Jan 31, 2014. It also states th at > the renewal fee must arrive before Nov 30th and the early filing will not > affect the new expiration date. Do I correctly recall that someone else h ad > a problem with filing early?**** > > ** ** > > > Thanks**** > > Larry > **** > > * > =========== =========== =========== =========== > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 13, 2013
Larry, Beauford, et al, Are you guys not getting the notice with the eight digit code for online renewal? I put in my N number and the code and the form filled itself out. All I had to do was verify that none of the information had changed and give them my Visa number and expiration date. Because I did it so late I printed out a copy of the receipt to carry with me just in case, but my new registration came in the mail six days later. Rick Girard On Tue, Aug 13, 2013 at 5:12 PM, Larry Cottrell wr ote: > Thanks Beauford, I have already sent in my renewal although the link that > they provided to do so did not work on my computer, :-/ go figure! I went > to bing and apparently got lucky and typed in the proper wording. I just > checked my copy and it appears that I might have gotten lucky and did it > right. > Larry > > > On Tue, Aug 13, 2013 at 3:37 PM, Beauford wr ote: > >> Brother Cottrell:**** >> >> ** ** >> >> Some free (almost gratis) advice, sir=85 Kindly excuse me if you already >> know about this distinction.**** >> >> ** ** >> >> Be thou exceedingly cautious in this process, lest you fall into**** >> >> the same federal mudhole =91ol Beauford did=85 Your e-mail mentioned >> =93re-registration=94 =85**** >> >> ** ** >> >> The correct terminology here is =93registration *renewal*=94, not >> =93re-registration=94=85.**** >> >> ** ** >> >> The proper form is the AC Form 8050-1B for renewal, and *NOT* the **** >> >> AC Form 8050-1A, which addresses re-registration of an acft.**** >> >> ** ** >> >> The fun-loving lads in Oklahoma sent back my One-Alfa Re-Registration >> form along with a mildly insulting letter**** >> >> and a copy of the blank =93renewal=94 form one bravo, with which I was >> invited to repent (and send five more bucks).**** >> >> ** ** >> >> I promised to reform myself, executed the One-Bravo form, and re-sent >> the Oakie Caesar his re-due=85**** >> >> ** ** >> >> This item is submitted in hopes of preventing any other Listers from >> making the same dumb error I did.**** >> >> ** ** >> >> Worth what ye paid fer it=85**** >> >> ** ** >> >> beauford**** >> >> FF-076**** >> >> Brandon, FL**** >> >> ** ** >> >> If you forward this e-mail, please remove my name before sending it... >> I promise to do the same for you...**** >> >> Thanks...**** >> >> ** ** >> >> *From:* owner-kolb-list-server(at)matronics.com [mailto: >> owner-kolb-list-server(at)matronics.com] *On Behalf Of *Larry Cottrell >> >> *Subject:* Kolb-List: Registration**** >> >> ** ** >> >> I just got my notice for re-registration. It states that it is due Sept >> 1st, but that the registration expires on Jan 31, 2014. It also states t hat >> the renewal fee must arrive before Nov 30th and the early filing will no t >> affect the new expiration date. Do I correctly recall that someone else had >> a problem with filing early?**** >> >> ** ** >> >> >> Thanks**** >> >> Larry >> **** >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > > > -- > *If you forward this email, or any part of it, please remove my email > address before sending.* > > * > =========== =========== =========== =========== > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: q
Date: Aug 13, 2013
Okay guys, I'm ready to roll. Looking to buy a nice, well-made and well-equipped Xtra, preferably in the NE part of our country. Parachute & transponder would be a big plus. Not interested in a half-fnished kit, or a doggy aircraft. Please write! Russ K ________________________________________________________________________________
Subject: Re: q
Date: Aug 13, 2013
Oh really, are you sure this time??????????? -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406668#406668 ________________________________________________________________________________
Subject: Re: q
Date: Aug 14, 2013
Rick, have a little consideration for all the people reading this list. If you have any more snide comments send them to me off-list Thanx Russ K do nit archive On Aug 13, 2013, at 8:39 PM, Rick Lewis wrote: > > Oh really, are you sure this time??????????? > > -------- > Rick Lewis > > (VW Watercooled Engine) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406668#406668 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: q
Date: Aug 14, 2013
Sorry Russ and all, you are right. Good luck in finding your plane, I'm sure you will find the Kolb a wonderful plane to fly. I have decided to finish and fly mine, can't wait. I'm doing a lot of painting on it right now and once the engine is reinstalled I will be ready. Of course I do still have to buy a prop. -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406694#406694 ________________________________________________________________________________
Date: Aug 14, 2013
did my renewal same as Rick Girard...worked excellent...got new registration in mail... Jim Swan Kolb Firestar ll, G (https://In a message dated 8/13/2013 7:38:57 P.M. Eastern Daylight Time, aslsa.rng(at)gmail.com writes:Larry, Beauford, et al, Are you guys not getting the notice with the eight digit code for online renewal? I put in my N number and the code and the form filled itself out. All I had to do was verify that none of the information had changed and give them my Visa number and expiration date. Because I did it so late I printed out a copy of the receipt to carry with me just in case, but my new registration came in the mail six days later. Rick GirardOn Tue, Aug 13, 2013 at 5:12 PM, Larry Cottrell <) ________________________________________________________________________________
Subject: Mounting light on Rudder?
Date: Aug 15, 2013
Hello Kolbers, I am wondering if anyone has mounted a light on the trailing edge or top of the Rudder? If so how did you do it, and how did it work out? Thanks, Nick Cassara Palmer, Alaska Kolbra 607AK ________________________________________________________________________________
Subject: Re: Mounting light on Rudder?
Date: Aug 15, 2013
Never did it, but ill recommend you go with the top mount as the trailing ed ge mount would increase the chance of flutter. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA On Aug 15, 2013, at 1:04 PM, "Nick Cassara" wrote: > Hello Kolbers, > > I am wondering if anyone has mounted a light on the trailing edge or top o f the Rudder? If so how did you do it, and how did it work out? > > Thanks, > > Nick Cassara > Palmer, Alaska > > Kolbra 607AK > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 16, 2013
Well, Cessna mounted a light on the rudder trailing edge; but please remember that if you do, you are adding mass in the WRONG DIRECTION that will increase the chance of FLUTTER. Not Recommended. My vote is for mounting on top of the vertical stabilizer. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406841#406841 ________________________________________________________________________________
Date: Aug 16, 2013
My MKIII needed a counterbalance to stop the rudder flutter, probably due to the addition of a light. If I had it to do over again, I would have mounted one on each wing tip instead. Here are the pictures and description of the light and counterbalance: http://www.bcchapel.org/pages/0003/pg6.htm -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406844#406844 ________________________________________________________________________________
Date: Aug 16, 2013
When Cessna mounted a light on the trailing edge of the rudder, you can bet they BALANCED the rudder -- so it wouldn't flutter. They recommend that even when you repaint a control surface, you re-balance to compensate for this very slight weight difference. This is important, even at the low speeds of a Kolb. Flutter can destroy a control surface in a couple of seconds. Russ K On Aug 16, 2013, at 8:21 AM, racerjerry wrote: > > Well, Cessna mounted a light on the rudder trailing edge; but please remember that if you do, you are adding mass in the WRONG DIRECTION that will increase the chance of FLUTTER. Not Recommended. > > My vote is for mounting on top of the vertical stabilizer. > > -------- > Jerry King > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406841#406841 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 16, 2013
Subject: Mark III POH
Anyone have a POH for a Mk3 Classic that I can use (will modify the V-speed numbers for my airplane)?-Thanks.- ________________________________________________________________________________
Date: Aug 17, 2013
if I remember... the regs say that the light should be mounted on the most rear part of the air craft... that way the light can be seen from any angle with out being blanked out. if you don=99t want to add the chance of flutter... make a bracket for the light and mount it to the forward part of the tail wheel support rod where vibration would be at a minimum. boyd >>>>>>>>>>>>>>>>> On Aug 16, 2013, at 8:21 AM, racerjerry wrote: > > Well, Cessna mounted a light on the rudder trailing edge; but please remember that if you do, you are adding mass in the WRONG DIRECTION that will increase the chance of FLUTTER. Not Recommended. > > My vote is for mounting on top of the vertical stabilizer. > > -------- > Jerry King > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406841#406841 > ________________________________________________________________________________
Date: Aug 17, 2013
Subject: video
https://vimeo.com/72565099 password owyheeflyer A short flight to check a recent fire at the base of the Steens Mtn. While I was flying my EIS alarm went off at 7000 feet altitude. My oil pressure jumped to 99 lbs. Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: video
Date: Aug 17, 2013
Hi Larry, Please keep us HKS users in the Loop when you find out what happened. Good luck. Frank Sent from my iPhone On Aug 17, 2013, at 5:55 PM, Larry Cottrell wrote: > https://vimeo.com/72565099 password owyheeflyer > > A short flight to check a recent fire at the base of the Steens Mtn. While I was flying my EIS alarm went off at 7000 feet altitude. My oil pressure j umped to 99 lbs. >
June 15, 2013 - August 17, 2013
Kolb-Archive.digest.vol-mo
