Kolb-Archive.digest.vol-mq
October 27, 2013 - December 19, 2013
      Congrats on  the solo! -- but as to flying with bent gear? I sure
      wouldn't chance it. Even if you TO OK, you still have to land! If the
      gear's out of track you can have a wild handful on landing. But I
      haven't even seen the extent of the bends.
      I assume you plan to keep this lil bird?
      Russ
      On Oct 27, 2013, at 7:56 PM, Larry Dunphy wrote:
      > I just did my solo today in a Kolb Mk III Xtra, and during my
      training, I did a few hard landings. My landing gear (s) are bent out
      some. I will be replacing them this winter, but want to get flight time
      in before the cold weather sets in and I put the plane away.  Am I at
      risk in take off/ taxi with my gear bow legged????
      > From: Roy Spangler
      > Sent: 27 October, 2013 12:48 PM
      > To: kolb-list(at)matronics.com
      > Subject: Re: Kolb-List: Xtra Steering Problems
      > Brad,
      > In the for what it's worth department. If the wheels toe out even a
      little bit
      > you'll have a handful.
      > roy
      > On Sat, Oct 26, 2013 at 3:43 PM, Brad Nation
      wrote:
      > I=92m having steering problems with my Xtra. Two Issues:
      > I was doing some familiarization taxing. I taxied it down the runway
      at about 3000 RPM and it was all over the place. At first I though I was
      just over controlling it but I don=92t think that is the case. I tried a
      few times with the same result. I the last attempt I ended running off
      the side of the runway.  I had another experienced Kolb  pilot (Dennis
      Kirby) taxi it as well.  We aborted the taxi test because we were unable
      to turn to the right even with full right brake and power. After getting
      back to the hanger we had a look at the tail wheel and noticed that the
      linkage from the rudder to the tail wheel seemed loose. I shortened the
      chains by one link. However, can the chain linkage be too tight?
      > The tail wheel is somewhat hard to unlock going clockwise (nose is
      12:00) and very very difficult, if at all,  going counter clock wise. I
      have regressed the tailwheel  but that doesn=92t seem to help.
      > Thanks in advance,
      > Yellow Bird 1
      > (Brad)
      > MKIII Xtra
      > N952DK
      > get="_blank">http://www.matronics.com/Navigator?Kolb-List
      > tp://forums.matronics.com
      > _blank">http://www.matronics.com/contribution
      href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics
      > href="http://forums.matronics.com">http://forums.matronics.com
Subject: Reklaw Fly-In
Date: Oct 27, 2013
Kolbers, I flew up to the Reklaw event in East Texas Friday & ran into Travis Bennett. I hadn't seen Travis since the Nauga Fly-Around back in November of 2011. It was my first time Reklaw and it's a great one. I'd guess there were 400 planes there of all types and most everyone was camping. I sold my Firestar a while back as I was close to completing my Zenith 750, and it was good to see a Kolb again. Travis was the first one to fly early Saturday morning. I took this photo of his Kolbra at his campsite. Jimmy Y Houston TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411559#411559 Attachments: http://forums.matronics.com//files/100_0245_509.jpg ________________________________________________________________________________
Subject: Re: Xtra Steering Problems
Date: Oct 27, 2013
I do ... the legs are more =93bowed=94 than bent ... I understand this is common with the Kolb aluminum gears. I taxied and flew today with no issue, but saw the post from someone who did have issues, and the reply concerning the toe-out. From: kinne russ Sent: 27 October, 2013 8:24 PM Subject: Re: Kolb-List: Xtra Steering Problems Congrats on the solo! -- but as to flying with bent gear? I sure wouldn't chance it. Even if you TO OK, you still have to land! If the gear's out of track you can have a wild handful on landing. But I haven't even seen the extent of the bends. I assume you plan to keep this lil bird? Russ On Oct 27, 2013, at 7:56 PM, Larry Dunphy wrote: I just did my solo today in a Kolb Mk III Xtra, and during my training, I did a few hard landings. My landing gear (s) are bent out some. I will be replacing them this winter, but want to get flight time in before the cold weather sets in and I put the plane away. Am I at risk in take off/ taxi with my gear bow legged???? From: Roy Spangler Sent: 27 October, 2013 12:48 PM To: kolb-list(at)matronics.com Subject: Re: Kolb-List: Xtra Steering Problems Brad, In the for what it's worth department. If the wheels toe out even a little bit you'll have a handful. roy On Sat, Oct 26, 2013 at 3:43 PM, Brad Nation wrote: I=92m having steering problems with my Xtra. Two Issues: 1.. I was doing some familiarization taxing. I taxied it down the runway at about 3000 RPM and it was all over the place. At first I though I was just over controlling it but I don=92t think that is the case. I tried a few times with the same result. I the last attempt I ended running off the side of the runway. I had another experienced Kolb pilot (Dennis Kirby) taxi it as well. We aborted the taxi test because we were unable to turn to the right even with full right brake and power. After getting back to the hanger we had a look at the tail wheel and noticed that the linkage from the rudder to the tail wheel seemed loose. I shortened the chains by one link. However, can the chain linkage be too tight? 2.. The tail wheel is somewhat hard to unlock going clockwise (nose is 12:00) and very very difficult, if at all, going counter clock wise. I have regressed the tailwheel but that doesn=92t seem to help. Thanks in advance, Yellow Bird 1 (Brad) MKIII Xtra N952DK get="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronic s.com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronic s.com/Navigator?Kolb-List href="http://forums.matronics.com/">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution ________________________________________________________________________________
Date: Oct 27, 2013
I flew up to the Reklaw event in East Texas Friday & ran into Travis Bennett. Jimmy Y Houston TX Great photo, Jimmy: Makes me antsy. Haven't done any serious flying and camping in a while. I had to take the lopping shears and weed eater to the airstrip today to get my airplane out of the hanger. Haven't flown Miss P'fer in about 5 months. The trees and bushes had grown up under the nose of the MKIII. After 5 months my solar maintainer had kept the battery up to snuff. She cranked right up and had no fuel problems after the long storage. I might add, I had 10 gals of 100LL in the tank. Flew over to Wetumpka Airport and put 10 more gals on top of that. After a bad experience with 93 oct alcohol laced fuel, 3 years ago when I broke my leg and did not fly the airplane for 6 months, I always try to store it with 100LL only in the tank. It works. Despite the dirt, barn dust, bug crap, bird crap, and carpenter bee droppings, my MKIII flew like a champ. First take off she turned 5400 and was singing her song. There were times during my 4 month, one week trip West this year, I wished I had her with me. I'm hoping I will feel up to flying back out West next year to celebrate my 75th year. We will have to see if I am up to it, and still want to do it. It is not an easy flight from here to the Rock House near Burns Junction, Oregon. Always high winds and turbulence in the vicinity of the Rockies. Usually, the wind is blowing the wrong way. 40 mph ground speed doesn't get it. Much easier flying in to the Fish Camp in the Owyhee River Canyon than doing the 56 mile one way trip on an ATV. As long as I have room for the big cast iron frying pan and my little pack stove to fry the small mouth bass and blue cat fish. Might have to try to get back out there a little earlier than last year. Last of June is really hot in the high desert of SE Oregon. Take care, john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Oct 28, 2013
If flying off a grass field, there will be no problem. If flying off pavement, there COULD be a problem, but generally, Kolb taildraggers are not overly sensitive to toe error. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411575#411575 ________________________________________________________________________________
Date: Oct 28, 2013
THANK YOU for your input... I will be flying off grass, but being a new 61 year old pilot ... I'm a bit cautious. The learning curve is a LONG slope when you get older!! -----Original Message----- From: racerjerry Sent: 28 October, 2013 8:29 AM Subject: Kolb-List: Re: Xtra Steering Problems If flying off a grass field, there will be no problem. If flying off pavement, there COULD be a problem, but generally, Kolb taildraggers are not overly sensitive to toe error. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411575#411575 ________________________________________________________________________________
Subject: Re: Reklaw Fly-In
Date: Oct 28, 2013
This was my first time at Reklaw and it was a blast, saw all types of aircraft and surprised I was the only Kolb in attendance. Here is a link to my youtube video of my early morning Saturday flight. http://www.youtube.com/watch?v=ClK6NCzMWHw Travis Bennett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411594#411594 ________________________________________________________________________________
Date: Oct 28, 2013
=C2-=0AI would suggest you remove the gear and straighten them with a hyd raulic press ! Quick and easy repair till you get new ones after you perfec t your landings ,not that anyone ever feels perfect1=C2- CHRIS=0A=0AChris Davis=0AKXP 503 492 hrs=0AGlider Pilot=0ADisabled from crash building Fire fly=0A=0A=0A>________________________________=0A> From: Larry Dunphy <skime 2(at)roadrunner.com>=0A>To: kolb-list(at)matronics.com =0A>Sent: Sunday, October 27, 2013 7:56 PM=0A>Subject: Re: Kolb-List: Xtra Steering Problems=0A> =0A >=0A>=0A>I just did my solo today in a Kolb Mk III Xtra, and during my trai ning, I =0Adid a few hard landings. My landing gear (s) are bent out some. I will be =0Areplacing them this winter, but want to get flight time in bef ore the cold =0Aweather sets in and I put the plane away.=C2- Am I at ris k in take off/ taxi =0Awith my gear bow legged????=C2- =0A>=0A>=0A>From: Roy Spangler =0A>Sent: 27 October, 2013 12:48 PM =0A>To: kolb-list@matron ics.com =0A>Subject: Re: Kolb-List: Xtra Steering Problems =0A> Brad,=0A> =0A>In the for what it's worth department. If the wheels toe =0Aout even a little bit=0A>you'll have a handful.=0A>=0A>roy=0A> =0A>=0A>=0A>=0A>On Sat, Oct 26, 2013 at 3:43 PM, Brad Nation wrote:=0A>=0A >I=99m having steering problems with my Xtra. Two Issues: =0A>>1. I was doing some familiarization taxing. I taxied it down the runway at ab out 3000 RPM and it was all over the place. At first I though I was just o ver controlling it but I don=99t think that is the case. I tried a fe w times with the same result. I the last attempt I ended running off the s ide of the runway.=C2- I had another experienced Kolb=C2- pilot (Denni s Kirby) taxi it as well.=C2- We aborted the taxi test because we were u nable to turn to the right even with full right brake and power. After get ting back to the hanger we had a look at the tail wheel and noticed that t he linkage from the rudder to the tail wheel seemed loose. I shortened the chains by one link. However, can the chain linkage be too tight?=0A>>=0A> >=0A>>2. The tail wheel is somewhat hard to unlock going clockwise (nose is 12:00) and very very difficult, if at all,=C2- going counter clock w ise. I have regressed the tailwheel=C2- but that doesn=99t seem to help. =0A>>=0A>>=0A>>Thanks in advance, =0A>>=0A>>Yellow Bird 1 =0A>>(Bra d) =0A>>MKIII Xtra =0A>>N952DK =0A>>=0A>>=0A>>=0A>>=0A>>get="_blank">http ://www.matronics.com/Navigator?Kolb-List=0Atp://forums.matronics.com=0A_bla nk">http://www.matronics.com/contribution =0A>=0A>href="http://www.matro nics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List =0Ahref="http://forums.matronics.com">http://forums.matronics.com=0Ahref ="http://www.matronics.com/contribution">http://www.matronics.com/c =0A> =========== =0A>=0A> ________________________________________________________________________________
Subject: best way i have found to set alignment for tracking
Date: Oct 28, 2013
the best way I have found to check the wheel alignment is to place a straight edge behind the mains at axel height. then use a carpenter square and align it against the straight edge and against the edge of the tire,,,, measure from the square to the rim ( not the tire, because of differences in the rubber) at the front and rear of the rim. repeat for other wheel. if the measurement from the square to front of the rim is the same as the measurement from the square to the back of the rim, the wheel is straight, if the front measurement is greater than the rear the wheel has toe in. and if the front is less than the rear, the wheel has toe out. for the best tracking on solid surface runway, my mkiii with the solid tapered steel gear required about 0.6 deg toe in. on each side. if your gear is more or less stiff the toe in requirements for your plane will be different. I did the math,,, and although it is not 100 % exact,,, it is close enough,,,, if the points on the rim front to back are 5.725 inches apart where you measure to the square, the degree of toe in or toe out equals 10 times the different in front and rear measurements as measured in thousandths of an inch. example,,, if the difference between the front and rear measurements is 0.062 thousandths of an inch,,, the toe in or out is 0.62 deg if you want to do your own math,,,, the deg of toe in equals the tangent of the opposite side divided by the adjacent side. the tangent of 0.62 = 0.010821 opposite side divided by the adjacent 0.062/5.725 = 0.010829 or you can do an inverse tangent function Tan =931 power ( 0.062/5.725)= 0.6204 or very near 0.062 *10 = 0.62 the way the inverse tangent function looks may vary pending on your calculator. one last thing,,,, when measuring it is best to have the wheel placed on a grease plate, which is made by putting a few pumps of grease between 2 smooth aluminum plates, or similar materials.. this is probably worth archiving. boyd young ________________________________________________________________________________
Date: Oct 28, 2013
Hi Travis, nice pictures but there is a problem of conflicting requirements here. With the camera attached to your head, and your head constantly moving, as it should be if you are keeping a proper watch for other a/c the picture is constantly on the move. Secondly. The main thing anyone with a camera is taught. Don`t zoom in and out and don`t constantly pan. If you must pan, do it slowly. Two irreconcilable requirements. Perhaps fixing the camera to an attachment on your shoulder might be a part answer. Looked a nice fly in. Pat ________________________________________________________________________________
Date: Oct 28, 2013
Bending them back is easy and proper to do, just make sure that you put a 2x4 or something between the gear and the press. No scratches allowed. Larry On Mon, Oct 28, 2013 at 9:42 AM, chris davis wrote: > > I would suggest you remove the gear and straighten them with a hydraulic > press ! Quick and easy repair till you get new ones after you perfect you r > landings ,not that anyone ever feels perfect1 CHRIS > > Chris Davis > KXP 503 492 hrs > Glider Pilot > Disabled from crash building Firefly > > *From:* Larry Dunphy > *To:* kolb-list(at)matronics.com > *Sent:* Sunday, October 27, 2013 7:56 PM > *Subject:* Re: Kolb-List: Xtra Steering Problems > > I just did my solo today in a Kolb Mk III Xtra, and during my training, > I did a few hard landings. My landing gear (s) are bent out some. I will be > replacing them this winter, but want to get flight time in before the col d > weather sets in and I put the plane away. Am I at risk in take off/ taxi > with my gear bow legged???? > > > *From:* Roy Spangler > *Sent:* 27 October, 2013 12:48 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: Xtra Steering Problems > > Brad, > > In the for what it's worth department. If the wheels toe out even a littl e > bit > you'll have a handful. > > roy > > > On Sat, Oct 26, 2013 at 3:43 PM, Brad Nation wrote : > > I=92m having steering problems with my Xtra. Two Issues: > > 1. I was doing some familiarization taxing. I taxied it down the > runway at about 3000 RPM and it was all over the place. At first I tho ugh I > was just over controlling it but I don=92t think that is the case. I t ried a > few times with the same result. I the last attempt I ended running off the > side of the runway. I had another experienced Kolb pilot (Dennis Kir by) > taxi it as well. We aborted the taxi test because we were unable to t urn > to the right even with full right brake and power. After getting back to > the hanger we had a look at the tail wheel and noticed that the linkag e > from the rudder to the tail wheel seemed loose. I shortened the chains by > one link. However, can the chain linkage be too tight? > > 2. The tail wheel is somewhat hard to unlock going clockwise (nose is > 12:00) and very very difficult, if at all, going counter clock wise. I > have regressed the tailwheel but that doesn=92t seem to help. > > > Thanks in advance, > > Yellow Bird 1 > (Brad) > MKIII Xtra > N952DK > > > * > > get="_blank">http://www.matronics.com/Navigator?Kolb-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > * > > > * > > href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronic s.com/Navigator?Kolb-List > href= "http://foru ms.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c * > > *http://wf="http://forums.matronics.com/" target="_blank" rel="nofo llow">http:===================== == > target="_blank" rel="nofollow">http://www.matronics.com/contribution* > > > * > =========== =========== =========== =========== > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Oct 29, 2013
Subject: Re: best way i have found to set alignment for tracking
Boyd, Best explanation of alignment on an ac that I've seen. Should be a big help to a lot of folks. thanks roy On Mon, Oct 28, 2013 at 1:18 PM, b young wrote: > the best way I have found to check the wheel alignment is to place a > straight edge behind the mains at axel height. > then use a carpenter square and align it against the straight edge and > against the edge of the tire,,,, > measure from the square to the rim ( not the tire, because of differences > in the rubber) at the front and rear of the rim. > repeat for other wheel. > > if the measurement from the square to front of the rim is the same as the > measurement from the square to the back of the rim, the wheel is > straight, if the front measurement is greater than the rear the wheel > has toe in. and if the front is less than the rear, the wheel has toe > out. > > for the best tracking on solid surface runway, my mkiii with the solid > tapered steel gear required about 0.6 deg toe in. on each side. if > your gear is more or less stiff the toe in requirements for your plane > will be different. > > I did the math,,, and although it is not 100 % exact,,, it is close > enough,,,, if the points on the rim front to back are 5.725 inches apar t > where you measure to the square, the degree of toe in or toe out > equals 10 times the different in front and rear measurements as measure d > in thousandths of an inch. example,,, if the difference between the > front and rear measurements is 0.062 thousandths of an inch,,, the toe > in or out is 0.62 deg > > if you want to do your own math,,,, the deg of toe in equals the tangen t > of the opposite side divided by the adjacent side. > > the tangent of 0.62 > = 0.010821 > opposite side divided by the adjacent 0.062/5.725 = 0.010829 > > or you can do an inverse tangent function Tan '1 power ( > 0.062/5.725)= 0.6204 or very near 0.062 *10 = 0.62 > > the way the inverse tangent function looks may vary pending on your > calculator. > > one last thing,,,, when measuring it is best to have the wheel placed on a > grease plate, which is made by putting a few pumps of grease between 2 > smooth aluminum plates, or similar materials.. > > this is probably worth archiving. > > boyd young > ________________________________________________________________________________
Date: Oct 29, 2013
Call Travis and about the steel legs. You won't have to worry about bending them. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411707#411707 ________________________________________________________________________________
Subject: Re: Larger, one-piece fuel tank for a Mark-3
Date: Oct 31, 2013
From: "Kirby, Dennis Civ USAF AFMC AFNWC/ENS" <Dennis.Kirby(at)kirtland.af.mil>
<< Dennis.Kirby wrote: I am looking for suggestions and recommendations for installing a new, larger-capacity fuel tank in my Mark-3 Classic. >> Kolb Friends - Thanks to all who responded to my Fuel Tank question! I now have a few options to investigate. Travis at Kolb tells me they still have the patterns to fabricate a one-piece aluminum tank (approx. 15 gal) for my Mark-III Classic, but they haven't built one since the early-2000s. (Seems like that could still be a popular option, for new kit buyers.) Their metal-fab wizard Dennis Jackson could build it. Would require cutting a few steel tubes to get it in - not that big a problem. Am considering that option. Thanks Boyd, for sending pictures and detailed descriptions of your Kolb-factory 16-gal tank, from the mid-1990s! Rev Pike - your homemade above-the-cabin fiberglass tank fits nicely. Sadly, I have no fiberglass skills or experience to build such a beauty. So I'll hafta pass on that possibility, for my Kolb. John H - I've seen your custom 25-gal tank before in Miss P'fer (at Monument Valley). Definitely gives you enough gas - especially for your kind of flying. But it's more than I think I want for my Mark-3 ... lookin' more for 16 to 18 gallons capacity. But your tip for doing a good job of slosh-coating the inside is well-taken! Will let you all know how it turns out, when I make the choice! Dennis K. Mark-III / 912ul / stock plastic fuel jugs ________________________________________________________________________________
Date: Oct 31, 2013
Hey Dennis, does the one from Travis install without cutting tubes? If so, m aybe if I ordered one too, we could defray their costs by doubling the order . Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Oct 31, 2013, at 10:58 AM, "Kirby, Dennis Civ USAF AFMC AFNWC/ENS" wrote: > > << Dennis.Kirby wrote: I am looking for suggestions and recommendations f or installing a new, larger-capacity fuel tank in my Mark-3 Classic. >> > > > Kolb Friends =93 > > Thanks to all who responded to my Fuel Tank question! > > I now have a few options to investigate. Travis at Kolb tells me they sti ll have the patterns to fabricate a one-piece aluminum tank (approx. 15 gal) for my Mark-III Classic, but they haven=99t built one since the early -2000s. (Seems like that could still be a popular option, for new kit buyer s.) Their metal-fab wizard Dennis Jackson could build it. Would require cu tting a few steel tubes to get it in =93 not that big a problem. Am c onsidering that option. > > Thanks Boyd, for sending pictures and detailed descriptions of your Kolb-f actory 16-gal tank, from the mid-1990s! > > Rev Pike =93 your homemade above-the-cabin fiberglass tank fits nice ly. Sadly, I have no fiberglass skills or experience to build such a beauty . So I=99ll hafta pass on that possibility, for my Kolb. > > John H =93 I=99ve seen your custom 25-gal tank before in Miss P =99fer (at Monument Valley). Definitely gives you enough gas =93 especially for your kind of flying. But it=99s more than I think I w ant for my Mark-3 lookin=99 more for 16 to 18 gallons capaci ty. But your tip for doing a good job of slosh-coating the inside is well-t aken! > > Will let you all know how it turns out, when I make the choice! > > Dennis K. > Mark-III / 912ul / stock plastic fuel jugs > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Oct 31, 2013
Sorry, just reread your post and see there is cutting involved. I'll have to find out exactly what needs cut before I would commit to that. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Oct 31, 2013, at 3:32 PM, Dennis Rowe wrote: > > Hey Dennis, does the one from Travis install without cutting tubes? If so, maybe if I ordered one too, we could defray their costs by doubling the ord er. > > Dennis "Skid" Rowe > Mk3, 690L-70, Leechburg, PA > > > >> On Oct 31, 2013, at 10:58 AM, "Kirby, Dennis Civ USAF AFMC AFNWC/ENS" wrote: >> >> << Dennis.Kirby wrote: I am looking for suggestions and recommendations f or installing a new, larger-capacity fuel tank in my Mark-3 Classic. >> >> >> >> Kolb Friends =93 >> >> Thanks to all who responded to my Fuel Tank question! >> >> I now have a few options to investigate. Travis at Kolb tells me they st ill have the patterns to fabricate a one-piece aluminum tank (approx. 15 gal ) for my Mark-III Classic, but they haven=99t built one since the earl y-2000s. (Seems like that could still be a popular option, for new kit buye rs.) Their metal-fab wizard Dennis Jackson could build it. Would require c utting a few steel tubes to get it in =93 not that big a problem. Am c onsidering that option. >> >> Thanks Boyd, for sending pictures and detailed descriptions of your Kolb- factory 16-gal tank, from the mid-1990s! >> >> Rev Pike =93 your homemade above-the-cabin fiberglass tank fits nic ely. Sadly, I have no fiberglass skills or experience to build such a beaut y. So I=99ll hafta pass on that possibility, for my Kolb. >> >> John H =93 I=99ve seen your custom 25-gal tank before in Miss P=99fer (at Monument Valley). Definitely gives you enough gas =93 especially for your kind of flying. But it=99s more than I think I want for my Mark-3 lookin=99 more for 16 to 18 gallons capa city. But your tip for doing a good job of slosh-coating the inside is well -taken! >> >> Will let you all know how it turns out, when I make the choice! >> >> Dennis K. >> Mark-III / 912ul / stock plastic fuel jugs >> >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> List"">http://www.matronics.com/Navigator?Kolb-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Oct 31, 2013
Date: Oct 31, 2013
Hey Dennis I would also be interested in the larger tank from Kolb. Keep me informed if you don't mind. Thanks Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411810#411810 ________________________________________________________________________________
Date: Nov 01, 2013
Subject: PLEASE READ - Matronics Email List Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 01, 2013
Gday Dennis, I found a tank from Moeller that fit just perfectly behind the seat in a FireStar ll. They have a really wide range of sizes and shapes. They're made to be permanent below-deck fuel tanks for boats, so are very high quality with very good fittings. I got mine from Amazon, free shipping. http://www.moellermarine.com/oem/fuel_tanks/fuel-tanks/ JG ________________________________________________________________________________
Date: Nov 01, 2013
JG Those tanks look good how much did the one you bought cost? I could not find any prices. thank you Chris=0A=0A=0AChris Davis=0AKXP 503 492 hrs=0AGl ider Pilot=0ADisabled from crash building Firefly=0A=0A=0A>________________ ________________=0A> From: JC Gilpin <j.gilpin(at)bigpond.com>=0A>To: "kolb-li st(at)matronics.com" =0A>Sent: Friday, November 1, 2 013 8:08 AM=0A>Subject: Kolb-List: Re: Larger, one-piece fuel tank for a Ma rk-3=0A> =0A>=0A>=0A>Gday Dennis,=0A>=0A>=0A>I found a tank from Moeller t hat fit just perfectly behind the seat in a FireStar ll.=0A>They have a rea lly wide range of sizes and shapes. -They're made to be permanent below-d eck fuel tanks for boats, so are very high quality with very good fittings. - =0A>I got mine from Amazon, free shipping.=0A>=0A>http://www.moellerma ==================== =0A>=0A> ________________________________________________________________________________
Date: Nov 01, 2013
rowedenny(at)windstream.net wrote: << . just reread your post and see there is cutting involved. I'll have to find out exactly what needs cut before I would commit to that. Dennis "Skid" Rowe >> bob.pipercolt(at)yahoo.com wrote: << would also be interested in the larger tank from Kolb. Keep me informed if you don't mind. Thanks Bob >> Denny, and Bob - Travis told me that the Mark-III Xtra one-piece fuel tank is an option on that model, but is not retrofittable to the "Classic." Cages are different. The patterns they still have at Kolb are for a tank they used to offer as an option for the original M3 in the days before the Xtra was conceived. It was a $450 option in the late-1990s. I believe they built it into the welded cage, and shipped it to you that way. For this retrofit, on a standard M3 cage, it appears you'll have to cut the three 3/8" tubes that are just behind the seats to get this tank in. Boyd (who has one of these factory tanks in his 1990s era Mark-III) says his is about 16 gallons. The tank would sit on the same framework intended for the plastic jugs to sin on, and would have a "tunnel" hump in the center, as the tank straddles the aileron torque tube. Last week, Travis said they could fab one up for me for about $950, plus shipping. They would make it with all the proper orifice fittings (fuel fill, vent, outlet, etc.), an internal anti-slosh baffle, and with aluminum-angle mounting brackets. If enough Kolb folks want these, maybe they could fabricate a batch of tanks, and be able to sell them a little cheaper. Dennis K. ________________________________________________________________________________
Date: Nov 01, 2013
Thanks John, Will be crawling all through my bird with a tape measure soon to see which o ne of these I could shoehorn in there. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Nov 1, 2013, at 8:08 AM, JC Gilpin wrote: > > Gday Dennis, > > I found a tank from Moeller that fit just perfectly behind the seat in a Fi reStar ll. > They have a really wide range of sizes and shapes. They're made to be per manent below-deck fuel tanks for boats, so are very high quality with very g ood fittings. > I got mine from Amazon, free shipping. > http://www.moellermarine.com/oem/fuel_tanks/fuel-tanks/ > > JG > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Nov 02, 2013
The 14 gal one that I got cost about $159.00, which I thought was really good considering the quality. Then found a filler neck with secure screw-in cap for another $20. It was meant to be a thro-deck fitting but just cut off the big poly flange that was meant to seal at the deck. The outlet connection is on top of the tank so can't leak fuel, an internal pipe feeds from the bottom. There's also a fitting on the top for a breather. Also built-in is a fuel level sender, so you only need to buy a gauge to to have a fuel gauge on panel. Lots better than the polyethylene jugs with rubber outlets that can be ripped out by hand...... JG ________________________________________________________________________________
Date: Nov 02, 2013
The 14 gal one that I got cost about $159.00>> What sort of weight change is there between the metal and the plastic.? Any C of G problems? Pat ________________________________________________________________________________
Date: Nov 02, 2013
If you look up West Marine they carry the line of Moeller fuel tanks with p ricing=0A=0AGary Jindra=0A =0A=0A________________________________=0A From: chris davis =0ATo: "kolb-list(at)matronics.com" =0ASent: Friday, November 1, 2013 10:49 AM=0ASubject: Re: Kolb-List: Re: Larger, one-piece fuel tank for a Mark-3=0A =0A=0A=0AJG Tho se tanks look good how much did the one you bought cost? I could not find a ny prices. thank you Chris=0A=0AChris Davis=0AKXP 503 492 hrs=0AGlider Pilo t=0ADisabled from crash building Firefly=0A=0A=0A=0A>______________________ __________=0A> From: JC Gilpin <j.gilpin(at)bigpond.com>=0A>To: "kolb-list@mat ronics.com" =0A>Sent: Friday, November 1, 2013 8: 08 AM=0A>Subject: Kolb-List: Re: Larger, one-piece fuel tank for a Mark-3 =0A> =0A>=0A>=0A>Gday Dennis,=0A>=0A>=0A>I found a tank from Moeller that fit just perfectly behind the seat in a FireStar ll.=0A>They have a really wide range of sizes and shapes. -They're made to be permanent below-deck fuel tanks for boats, so are very high quality with very good fittings. - =0A>I got mine from Amazon, free shipping.=0A>=0A>http://www.moellermarine .com/oem/fuel_tanks/fuel-tanks/=0A>=0A>=0A>=0A>JG =0A>http://wwtp://www.bu ildersbooks.com/" target="_blank" rel="nofollow">http://www.mebuilthelp .com/" target="_blank" rel="nofollow">http://www.homebuilthe.com/" targ et="_blank" rel="nofollow">http://www.mypilotstore.com/onics.com/contri bution" target="_blank" rel="nofollow">http://www.matro.com/Navigator?K olb-List" target="_blank" rel="nofollow">http://www.matttp://forums.mat ronics.com/" target="_blank" rel="nofollow">http://foru===== ======================= ________________________________________________________________________________
Date: Nov 02, 2013
That sounds like a great tank and a good price the fact that they build boa t tanks says a lot to me as I was a commercial fisherman for 31years and kn ow how much trouble a rough sea can cause in a fuel tank. thanks Chris=0A =0A=0AChris Davis=0AKXP 503 492 hrs=0AGlider Pilot=0ADisabled from crash bu ilding Firefly=0A=0A=0A>________________________________=0A> From: JC Gilpi n =0A>To: "kolb-list(at)matronics.com" =0A>Sent: Saturday, November 2, 2013 4:42 AM=0A>Subject: Kolb-List : Re: Larger, one-piece fuel tank for a Mark-3=0A> =0A>=0A>=0A>The 14 gal one that I got cost about $159.00, which I thought was really good consider ing the quality. -Then found a filler neck with secure screw-in cap for a nother $20. -It was meant to be a thro-deck fitting but just cut off the big poly flange that was meant to seal at the deck. -The outlet connectio n is on top of the tank so can't leak fuel, an internal pipe feeds from the bottom. -There's also a fitting on the top for a breather. -Also built -in is a fuel level sender, so you only need to buy a gauge to to have a fu el gauge on panel.-=0A>=0A>=0A>Lots better than the polyethylene jugs wit == =0A>=0A> ________________________________________________________________________________
Date: Nov 02, 2013
I have an 18 gallon plastic tank from a Searey if anyone is interested in th at. I can send photos Daniel Myers Sent from my iPhone > On Nov 2, 2013, at 10:23 AM, "chris davis" wrote: > > That sounds like a great tank and a good price the fact that they build bo at tanks says a lot to me as I was a commercial fisherman for 31years and kn ow how much trouble a rough sea can cause in a fuel tank. thanks Chris > > Chris Davis > KXP 503 492 hrs > Glider Pilot > Disabled from crash building Firefly > > From: JC Gilpin <j.gilpin(at)bigpond.com> > To: "kolb-list(at)matronics.com" > Sent: Saturday, November 2, 2013 4:42 AM > Subject: Kolb-List: Re: Larger, one-piece fuel tank for a Mark-3 > > The 14 gal one that I got cost about $159.00, which I thought was really g ood considering the quality. Then found a filler neck with secure screw-in c ap for another $20. It was meant to be a thro-deck fitting but just cut off the big poly flange that was meant to seal at the deck. The outlet connect ion is on top of the tank so can't leak fuel, an internal pipe feeds from th e bottom. There's also a fitting on the top for a breather. Also built-in i s a fuel level sender, so you only need to buy a gauge to to have a fuel gau ge on panel. > > Lots better than the polyethylene jugs with rubber outlets that can be rip ped out by hand...... > > JG > http://w= --> http://www.matronics.com/Navigator?Kolb-List<==== ======= > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Nov 02, 2013
I bought a Moeller 12 gallon for my gyroplane... I was very impressed... it's quite solid. I got mine from Bass Pro Shop, on-line. -- Robert On Sat, Nov 2, 2013 at 9:20 AM, chris davis wrote: > That sounds like a great tank and a good price the fact that they build > boat tanks says a lot to me as I was a commercial fisherman for 31years and > know how much trouble a rough sea can cause in a fuel tank. thanks Chris > > Chris Davis > KXP 503 492 hrs > Glider Pilot > Disabled from crash building Firefly > > ________________________________________________________________________________
Date: Nov 02, 2013
Robert, what gyro do you have? I'm thinking about one. Frank Goodnight Sent from my iPad > On Nov 2, 2013, at 9:47 AM, Robert Laird wrote: > > I bought a Moeller 12 gallon for my gyroplane... I was very impressed... i t's quite solid. I got mine from Bass Pro Shop, on-line. > > -- Robert > > > >> On Sat, Nov 2, 2013 at 9:20 AM, chris davis wrote: >> That sounds like a great tank and a good price the fact that they build b oat tanks says a lot to me as I was a commercial fisherman for 31years and k now how much trouble a rough sea can cause in a fuel tank. thanks Chris >> >> Chris Davis >> KXP 503 492 hrs >> Glider Pilot >> Disabled from crash building Firefly > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Nov 03, 2013
* What sort of weight change is there between the metal and the plastic.? Any C of G problems?Don't know about the wright of the metal tank, but I don't think there's be a significant difference in CofG, since the tank is near the CofG.In my case I really needed a change, cause the Cof G of my aircraft was way aft when I bought it. Needed a lot of forward stick to keep it level. I weigh only 170lbs and the previous owner was maybe 100 lbs heavier, so it was way out of balance with me. The original two 5 gal tanks were in the regular place, behind the center of lift. I worked out that this new tank, in place of the pax seat in the FSll, right behind the pilot seat, worked out just right. Now it flies hands-off just perfectly.JG* ________________________________________________________________________________
Date: Nov 03, 2013
Hi JG, I forgot that you do not have a limiting weight to define the machine as an ultralight as we do in the UK But I would suggest that you do an accurate `weight and balance` calculation after you have the tank fitted. "Not much change because its near the C of G is not really good enough." If she stands on her tail and you can`t get the nose down you may wish you had done so. If you are a real lightweight it may be worth carrying some lead. I fixed some in the nose of my Xtra (Make sure it IS fixed.) I cut sheet lead into approx 4"X4" squares until I had the weight I required. Drilled a couple of holes through the pile of sheets and fixed then in the nose as far forward as I could easily work through the fibreglass. I put a piece of ply between the lead and the nose cone to spread the load and used big washers on the outside for the same reason. When I was gliding and the gliders were being used by club members of different weights the women, who tended to be the light weights had their own cushions with a piece of lead inside. It worked but becaus e the pilot tended to be near the C of G the weight required was sometimes large. Better to have a little weight well forward. Hope this is useful. Pat ________________________________________________________________________________
Subject: How to remove tail wheel?
Date: Nov 03, 2013
On my Firestar II the pizza cutter tail wheel is worn. I bought a new one from Travis at Kolb. I tried to take the old wheel off but it won't budge. It seems like the wheel collar is press fit onto the shaft? I could remove the snap ring and just install the new wheel, but as long as I bought the wheel fixed onto new bearings I'd like to use the new bearings also. I've banged on the wheel collar trying to get if off the shaft but afraid of doing damage. Is it a press fit onto the shaft? I bought a snap ring pliers to just replace the rubber wheel but having a hard time getting those snap rings to come out of the old & new wheels. So often a seemingly simple job turns into an ordeal :x -------- "Life should be lived as a bold adventure, I refuse to tiptoe through life just to arrive safely at death" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411999#411999 ________________________________________________________________________________
Date: Nov 03, 2013
Subject: Re: How to remove tail wheel?
Should just slid off. Use some penetrating oil.=0A=0A=0A___________________ _____________=0A From: Arizona Flyer <heracesthesun(at)yahoo.com>=0ATo: kolb-l ist(at)matronics.com =0ASent: Sunday, November 3, 2013 1:50 PM=0ASubject: Kolb "Arizona Flyer" =0A=0AOn my Firestar II the pizza cutter tail wheel is worn. I bought a new one from Travis at Kolb. I tried to take the old wheel off but it won't budge. It seems like the wheel colla r is press fit onto the shaft? I could remove the snap ring and just instal l the new wheel, but as long as I bought the wheel fixed onto new bearings I'd like to use the new bearings also. I've banged on the wheel collar tryi ng to get if off the shaft but afraid of doing damage. Is it a press fit on to the shaft? I bought a snap ring pliers to just replace the rubber wheel but having a hard time getting those snap rings to come out of the old & ne w wheels. So often a seemingly simple job turns into an ordeal :x=0A=0A---- ----=0A"Life should be lived as a bold adventure, I refuse to tiptoe t hrough life just to arrive safely at death"=0A=0A=0A=0A=0ARead this to pic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=411999# ================= ________________________________________________________________________________
Date: Nov 03, 2013
Tail wheel bushing will rust to the 4130 chromoly axle. Beating on it could deform the chromoly tube and make it more difficult to separate It will probably take a press. You might try heat. Good penetrating oil like Kroil: http://www.kanolabs.com/ Kroil beats all the others I have tried. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 03, 2013
The tail wheel looks like it's pressed onto a short tube that slides into t he larger pivot assy. tube.You had to drill a hole through both and put a c otter pin in it to keep them together.I'm sure they rust together eventuall y.Look for that pin,I think it's on the pilots side of the assy,and you can probably see a tube in a tube from that side. G.Aman -----Original Message----- From: William Long <blong6826(at)sbcglobal.net> Sent: Sun, Nov 3, 2013 4:56 pm Subject: Re: Kolb-List: How to remove tail wheel? Should just slid off. Use some penetrating oil. From: Arizona Flyer <heracesthesun(at)yahoo.com> To: kolb-list(at)matronics.com Sent: Sunday, November 3, 2013 1:50 PM Subject: Kolb-List: How to remove tail wheel? On my Firestar II the pizza cutter tail wheel is worn. I bought a new one f rom Travis at Kolb. I tried to take the old wheel off but it won't budge. I t seems like the wheel collar is press fit onto the shaft? I could remove t he snap ring and just install the new wheel, but as long as I bought the wh eel fixed onto new bearings I'd like to use the new bearings also. I've ban ged on the wheel collar trying to get if off the shaft but afraid of doing damage. Is it a press fit onto the shaft? I bought a snap ring pliers to ju st replace the rubber wheel but having a hard time getting those snap rings to come out of the old & new wheels. So often a seemingly simple job turns into an ordeal :x -------- "Life should be lived as a bold adventure, I refuse to tiptoe through life just to arrive safely at death" Read this topic online here: http://forums.matronics.com/viewtopic.phroElectric www.aget="_blank" href ="http://www.buildersbooks.com/">www.buildersbooks.comnbsp; * My Pilot Store www.mrrace.com ________________________________________________________________________________
Date: Nov 03, 2013
Take a saws all (reciprocating saw) and cut through the old wheel, being careful not to nip the axle too much...Herb At 08:17 PM 11/3/2013, you wrote: >The tail wheel looks like it's pressed onto a short tube that slides >into the larger pivot assy. tube.You had to drill a hole through >both and put a cotter pin in it to keep them together.I'm sure they >rust together eventually.Look for that pin,I think it's on the >pilots side of the assy,and you can probably see a tube in a tube >from that side. >G.Aman > > >-----Original Message----- >From: William Long <blong6826(at)sbcglobal.net> >To: kolb-list >Sent: Sun, Nov 3, 2013 4:56 pm >Subject: Re: Kolb-List: How to remove tail wheel? > >Should just slid off. Use some penetrating oil. > > >From: Arizona Flyer <<mailto:heracesthesun(at)yahoo.com>heracesthesun(at)yahoo.com> >To: kolb-list(at)matronics.com >Sent: Sunday, November 3, 2013 1:50 PM >Subject: Kolb-List: How to remove tail wheel? > ><heracesthesun(at)yahoo.com> > >On my Firestar II the pizza cutter tail wheel is worn. I bought a >new one from Travis at Kolb. I tried to take the old wheel off but >it won't budge. It seems like the wheel collar is press fit onto the >shaft? I could remove the snap ring and just install the new wheel, >but as long as I bought the wheel fixed onto new bearings I'd like >to use the new bearings also. I've banged on the wheel collar trying >to get if off the shaft but afraid of doing damage. Is it a press >fit onto the shaft? I bought a snap ring pliers to just replace the >rubber wheel but having a hard time getting those snap rings to come >out of the old & new wheels. So often a seemingly simple job turns >into an ordeal :x > >-------- >"Life should be lived as a bold adventure, I refuse to tiptoe >through life just to arrive safely at death" > > >Read this topic online here: > ><http://forums.matronics.com/viewtopic.phroElectric>http://forums.matronics.com/viewtopic.phroElectric >www.aget="_blank" >href="http://www.buildersbooks.com/">www.buildersbooks.comnbsp; * >My Pilot Store www.mrrace.com > > >courier new,courier" >size="2"><http://www.aeroelectric.com>www.aeroelectric.com >.buildersbooks.com">www.buildersbooks.com >help.com">www.homebuilthelp.com >tore.com">www.mypilotstore.com >com">www.mrrace.com >bution">http://www.matronics.com/contribution >tor?Kolb-List">http://www.matronics.com/Navigator?Kolb-List >tp://forums.matronics.com > ________________________________________________________________________________
Date: Nov 03, 2013
Sorry Jeff, That tail wheel assy is a hybrid.The wheel part is stock, and should remove as I said earlier, but the full swivel deal is a welded marriage of the tw o kinds.It was painful to hacksaw that 200.00 unit in half, but it worked g reat! G.A. -----Original Message----- From: William Long <blong6826(at)sbcglobal.net> Sent: Sun, Nov 3, 2013 4:56 pm Subject: Re: Kolb-List: How to remove tail wheel? Should just slid off. Use some penetrating oil. From: Arizona Flyer <heracesthesun(at)yahoo.com> To: kolb-list(at)matronics.com Sent: Sunday, November 3, 2013 1:50 PM Subject: Kolb-List: How to remove tail wheel? On my Firestar II the pizza cutter tail wheel is worn. I bought a new one f rom Travis at Kolb. I tried to take the old wheel off but it won't budge. I t seems like the wheel collar is press fit onto the shaft? I could remove t he snap ring and just install the new wheel, but as long as I bought the wh eel fixed onto new bearings I'd like to use the new bearings also. I've ban ged on the wheel collar trying to get if off the shaft but afraid of doing damage. Is it a press fit onto the shaft? I bought a snap ring pliers to ju st replace the rubber wheel but having a hard time getting those snap rings to come out of the old & new wheels. So often a seemingly simple job turns into an ordeal :x -------- "Life should be lived as a bold adventure, I refuse to tiptoe through life just to arrive safely at death" Read this topic online here: http://forums.matronics.com/viewtopic.phroElectric www.aget="_blank" href ="http://www.buildersbooks.com/">www.buildersbooks.comnbsp; * My Pilot Store www.mrrace.com ________________________________________________________________________________
Date: Nov 03, 2013
Sorry about that, John; that was sent from my "new" nexus7, which apparently replies to the actual sender instead of the list. And the tractor was only 5 0 yrs old (the nexus likes to exaggerate, too). Sent from my iPhone On Nov 3, 2013, at 7:31 PM, Charlie wrote: > 50/50 mix of acetone & plain old ATF. I tried it rebuilding a 500 yr old t ractor; it works. > > John Hauck wrote: > > Tail wheel bushing will rust to the 4130 chromoly axle. > > > > Beating on it could deform the chromoly tube and make it more difficult to separate > > > > It will probably take a press. > > > > You might try heat. > > > > Good penetrating oil like Kroil: > > > > http://www.kanolabs.com/ > > > > Kroil beats all the others I have tried. > > > > john h > > mkIII > > Titus, Alabama > > > > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ________________________________________________________________________________
Date: Nov 04, 2013
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 04, 2013
I know my weight and balance. A couple of pounds at a moment arm of one foot from the existing CofG isn't going to make a difference that you can detect in balance. A couple of pounds out at the tailwheel is serious..... I prefer to carry water instead of the dead load of lead. So I have a hydration bag full of water packed up in the nose cone. Could be very welcome if stranded somewhere..... JG ________________________________________________________________________________
Subject: E-gearbox on a 582 powered Slingshot
Date: Nov 04, 2013
My friend Dave Lewis is considering swapping his B box for an E box to get the electric start and keep his pull start the way it is. Anyone know if the E box will bolt right on without interfering with the airframe? He has his engine raised slightly in the rear to get the prop close to square with the tail boom, and to increase rear fuselage prop clearance. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA ________________________________________________________________________________
Subject: Re: E-gearbox on a 582 powered Slingshot
Date: Nov 04, 2013
Here is how it fits on the FSII, don't know if it is the same, but this may help. You can at least see the relationship between all the usual Kolb parts and the starter. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412099#412099 Attachments: http://forums.matronics.com//files/p1030347_medium_765.jpg http://forums.matronics.com//files/p1030346_medium_830.jpg http://forums.matronics.com//files/p1030344_medium_159.jpg http://forums.matronics.com//files/p1030345_medium_800.jpg ________________________________________________________________________________
Date: Nov 04, 2013
-Don't know about the slingshot. On the Mark 3 you have to raise the moto r or move it back. The starter hit- the rear mount=0A=0AGary Jindra=0A =0A=0A________________________________=0A From: Dennis Rowe <rowedenny@wind stream.net>=0ATo: Kolb-list =0ASent: Monday, Nove mber 4, 2013 8:49 AM=0ASubject: Kolb-List: E-gearbox on a 582 powered Sling indstream.net>=0A=0AMy friend Dave Lewis is considering swapping his B box for an E box to get the electric start and keep his pull start the way it i s. Anyone know if the E box will bolt right on without interfering with the airframe? He has his engine raised slightly in the rear to get the prop cl ose to square with the tail boom, and to increase rear fuselage prop cleara ===== ________________________________________________________________________________
Date: Nov 05, 2013
Raising the rear of the engine a bit on the Slingshot is a good idea anyway because the thrust line is higher than ideal (pointed up in front) if parallel to the engine mount tube. This is not the case for most Kolbs but it is for the Slingshot. -------- Thom Riddle Buffalo, NY (9G0) Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412133#412133 ________________________________________________________________________________
Date: Nov 05, 2013
I took apart the tail wheel, cleaned, polished, and greased it with new grease. When I put it back into the housing it turned both ways and releases just fine. However, when in put the flat arm that connects the tail wheel to the rudder I get the same problem of it being veeerrry difficult to free it up so that it swivels when I turn it clock wise. So how is the notch where the spring ping I the connecting plat supposed to look? Currently the spring pin fits like a glove vs. the cut out part on the that'll wheel housing? Should it be tapered like the on the tail wheel housing or a tight fit? Sent from my iPad Brad > On Oct 28, 2013, at 6:29, "racerjerry" wrote: > > > If flying off a grass field, there will be no problem. If flying off pavement, there COULD be a problem, but generally, Kolb taildraggers are not overly sensitive to toe error. > > -------- > Jerry King > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=411575#411575 > > > > > > > > > > ________________________________________________________________________________
Subject: Finally Flew Her
Date: Nov 05, 2013
Well wrapped up my tail dragger endorsement last week and the weather cooperated today. Finally took my Fire star Kxp up. I was surprised how smooth the takeoff went. She climbed great. Flew it around to get the feel of the Kolb. I will say you can't take your hand off the stick or otherwise she noses over fast. I took to the advice given about landing with throttle. Did some touch and gos and finally on 4th one felt comfortable to land her. Still think I'm coming in to fast but eventually ill have it mastered. So thanks to all for advice. Now I need to figure out how to enclose the cockpit for winter flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412167#412167 ________________________________________________________________________________
Date: Nov 06, 2013
Subject: Network Issues At Matronics Last Few Days...
Dear Listers, Starting sometime on Friday November 1st, my Internet Service Provider (ISP) began "upgrading" their Domain Name Servers (DNS). DNS servers allow the resolution of computer names such as "www.matronics.com" to real addresses such as 64.81.74.3. This also impacts email delivery as well, since there is another layer of resolution that applies to email names. Because of this upgrade on the part of my ISP, DNS service started getting unreliable around Friday sometime, but I didn't notice it until sometime on Saturday. When I used a tool called "nslookup" to test the resolution of name-to-address, about 50-75% of the time my ISP's servers would response with an "SERVFAIL" indicating that they didn't know the answer. I opened a ticket with the ISP on Saturday, and by Sunday afternoon I had no feedback on the ticket so I called in to support. "We upgrading the DNS servers, and it should back by Sunday at 5pm." 5pm came and went with no resolution. Well, long story short by Tuesday morning things were still not fixed and in fact much worse. So, I opted to move all my DNS service to a different service provider. I have a lot of DNS entries, so it took a while to get everything moved over. It generally takes about 24 hours for a change like that to fully propagate across the Internet which would be Wednesday morning sometime. I've noticed that the Matronics web server traffic is picking up again, so many sites have already propagated the new information. I really should have just moved the DNS on Saturday when I first noticed the troubles, but with stuff like this, you just keep believing that it gonna be fixed any minute now.... And, in fact, that's what my ISP kept telling me... Its always a giant bummer when stuff like this happens and particularly during the Fund Raiser. I apologize to anyone that has tried to make a Contribution in the last few days and had issues or was simply unable to connect. By the time you read this email, the DNS should be fully propagated, and I ask that you please try again. The Contribution web site URL is: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your kind consideration and patience, Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 06, 2013
Finally took my Fire star Kxp up. Congratulations! Hope you have many more safe flights. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: Finally Flew Her
Date: Nov 06, 2013
That's great! Congratz and enjoy! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412268#412268 ________________________________________________________________________________
Subject: 4130 tail wheel Strut
Date: Nov 06, 2013
I'm experimenting with a tail wheel strut made of 4130 tubing hardened to about RC 48 as I think others have done. So far I like it better than the solid aluminum rod. It seems to ride better over the grass and not bump as hard. I haven't tried it on pavement yet but so far so good. I think it may be a hair lighter too and I guess we will see how it holds up. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412270#412270 ________________________________________________________________________________
Date: Nov 06, 2013
I'm experimenting with a tail wheel strut made of 4130 tubing hardened to about RC 48 as I think others have done. So far I like it better than the solid aluminum rod. It seems to ride better over the grass and not bump as hard. I haven't tried it on pavement yet but so far so good. I think it may be a hair lighter too and I guess we will see how it holds up. Kolbers: Been using heat treated (48 RC) 4130 tube tail wheel struts since 1992, main gear legs also 4130/48RC since 1987. Seem to work better than anything else out there. Also lighter than 7075 aluminum. Yes, heat treated 4130 works better because it is a spring. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 06, 2013
zeprep251(at)aol.com wrote: > Sorry Jeff, > That tail wheel assy is a hybrid.The wheel part is stock, and should remove as I said earlier, but the full swivel deal is a welded marriage of the two kinds.It was painful to hacksaw that 200.00 unit in half, but it worked great! > G.A. > > > > > > > -- Thanks for the input guys. Gary; No problem. I'm just going to replace the wheel and hope the older bearings keep working, thanks... -------- "Life should be lived as a bold adventure, I refuse to tiptoe through life just to arrive safely at death" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412286#412286 ________________________________________________________________________________
Subject: tail wheel turning right
Date: Nov 06, 2013
is this the tail wheel you are having trouble turning right? and did you mention the wheel turns easy till the actuating bar is bolted on the top? if all above is true,,,,, there may be a missing washer under the actuating bar,,,,, or the housing may be a bit too tall. this is the wheel I am using now and wish I had changed from the pizza cutter wheel much sooner. I love it. and even more so since I put in better bearings. boyd young ________________________________________________________________________________
Date: Nov 07, 2013
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: tail wheel turning right
Date: Nov 07, 2013
byoungplumbing(at)gmail.c wrote: > is this the tail wheel you are having trouble turning right? > > [img]cid:9D2DD9D74D6F4CCD928710FFF260BAEF@BYoungHP[/img] > > and did you mention the wheel turns easy till the actuating bar is bolted on the top? > > if all above is true,,,,, there may be a missing washer under the actuating bar,,,,, or the housing may be a bit too tall. > > this is the wheel I am using now and wish I had changed from the pizza cutter wheel much sooner. I love it. and even more so since I put in better bearings. > > boyd young I like that. Do you know the inside diameter? I'd like to see if that will fit onto the male shaft coming from my rear boom. What does that one cost? Travis at Kolb told me the new tail wheel with 1" wide wheel is $300+ dollars but he said it's a whole new one that needs to be put on the boom. The one in your picture looks like it might slide right on my shaft. Thanks for the picture, I can finally see one! -------- "Life should be lived as a bold adventure, I refuse to tiptoe through life just to arrive safely at death" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412418#412418 ________________________________________________________________________________
Date: Nov 07, 2013
If the wheel is not exactly vertical ,or leaning when stationary,it will gi ve you a fit.The tail spring must be tight in the support tube and the rest of the assy tight on the spring rod.If it can move off of dead vertical it will be easy to steer on way and almost impossible the other.The rods get sloppy in the tube and the bolt hole elongates letting the rod twist.I cure d that issue on my Mk3 by clamping the rod in the tube G.Aman -----Original Message----- From: Arizona Flyer <heracesthesun(at)yahoo.com> Sent: Thu, Nov 7, 2013 1:09 pm Subject: Kolb-List: Re: tail wheel turning right byoungplumbing(at)gmail.c wrote: > is this the tail wheel you are having trouble turning right? > > [img]cid:9D2DD9D74D6F4CCD928710FFF260BAEF@BYoungHP[/img] > > and did you mention the wheel turns easy till the actuating bar is bolte d on the top? > > if all above is true,,,,, there may be a missing washer under the actu ating bar,,,,, or the housing may be a bit too tall. > > this is the wheel I am using now and wish I had changed from the pizza cutter wheel much sooner. I love it. and even more so since I put in b etter bearings. > > boyd young I like that. Do you know the inside diameter? I'd like to see if that will fit onto the male shaft coming from my rear boom. What does that one cost? Trav is at Kolb told me the new tail wheel with 1" wide wheel is $300+ dollars but he said it's a whole new one that needs to be put on the boom. The one in your pict ure looks like it might slide right on my shaft. Thanks for the picture, I can finally see one! -------- "Life should be lived as a bold adventure, I refuse to tiptoe through life just to arrive safely at death" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412418#412418 ________________________________________________________________________________
Date: Nov 08, 2013
*The one in your picture looks like it might slide right on my shaft.I mounted one of those wider tail wheels really easily on my FireStar. The inside diameter of the bearing is 5/8" and the original shaft on the assembly is 1/2", so just needed a short length of 5/8" tubing with a wall thickness such that it would slide over the original shaft. Found that in the offcuts from someone else's building project. Notched out one end so it would fit over the support tubing, then a 3/16" bolt to secure it. Could weld it if you had access to a welder. Works a heck of a lot better than that pizza cutter which finally collapsed.... The new tail wheel is Aircraft Spruce part #06-03500 $23.85.JG[image: Inline image 1]* ________________________________________________________________________________
Date: Nov 09, 2013
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 09, 2013
More on tailwheels. That tailwheel I mentioned is the replacement wheel for the 'Homebuilt' tailwheel mechanism. I think that's the same mechanism that Kolb offers. If you're getting the whole mechanism it's worth getting it from Kolb rather than Spruce, cause the hole for mounting on the tailspring is only 5/8" in the Spruce unit, while we need a 3/4" hole. It's very difficult to bore out to size because of shoulders on the housing so it can't be chucked in a lathe. Last year I made the mistake of ordering the Spruce unit when Kolb was out of stock. Cost another $140 for a machine shop to make up a special boring tool and do the job. Wouldn't dare try to just drill that out unless you could run the drill super slow and hold it back from biting into that big pilot hole..... Also, I found that the breakaway feature was just a nuisance unless maybe you have differential braking. Several times it broke away when taxiing, and couldn't get to re-engage without stopping and getting out and doing it by hand. Finally ground out the mechanism so that it stayed engaged. So might as well just have the original Kolb mechanism but with the wider wheel, as I've done this year. Saved $300 and a couple of pounds this way, and sure don't need any more weight way back there. The steering springs on my aircraft were way too soft, especially with the wider wheel. Got the stiffest ones that were the right length that I could find at Ace Hardware, and that's better, but still mushy. John H - How can you hook up 'compression' springs there?? When I get back I think I'll use 3/16" bungy cord, looped around as many times as necessary to get the right strength. Done that before with another aircraft and I liked it better than springs.... Just my experience, for what it's worth..... JG p.s.- How do you load photos to these posts?? The one that I tried to load with the previous post didn't seem to work..... ________________________________________________________________________________
Subject: Wanted firestar
Date: Nov 09, 2013
My brother is looking for a firestar II for sale that he will convert to an amphib full lotus mono set up. If anyone has a firestar for sale please em ail me at h20maule(at)hotmail.comdaniel ________________________________________________________________________________
Subject: Re: Wanted firestar
Date: Nov 09, 2013
My firestar 2 is for sale Call Frank goodnight @4792361121 No Eail please Tanks Frank Sent from my iPhone On Nov 9, 2013, at 8:13 AM, daniel myers wrote: > My brother is looking for a firestar II for sale that he will convert to a n amphib full lotus mono set up. If anyone has a firestar for sale please em ail me at h20maule(at)hotmail.com > daniel > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ________________________________________________________________________________
Date: Nov 09, 2013
The steering springs on my aircraft were way too soft, especially with the wider wheel. Got the stiffest ones that were the right length that I could find at Ace Hardware, and that's better, but still mushy. John H - How can you hook up 'compression' springs there?? When I get back I think I'll use 3/16" bungy cord, looped around as many times as necessary to get the right strength. Done that before with another aircraft and I liked it better than springs.... Just my experience, for what it's worth..... JG p.s.- How do you load photos to these posts?? The one that I tried to load with the previous post didn't seem to work..... JG/Kolbers: First.attaching photos. Don't know how others do it, but I copy the photo(s), the paste them to the email. We lucked out and I found a photo of my tail wheel and springs. I used some very small carabineers to attach the compression springs to the rudder and tail wheel. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 09, 2013
JG/All I use compression springs like John uses. I think I got them at Aircraft Spruce. I use four of the attachment things (technical term) to attach my springs. They look like the rear ones that John shows in the photo, seems like I got then at the same place. They install like the safety rings but are much stronger and don't come off in deep grass. I installed them as tight as I could but they still have a bit droop to the chains. The compression springs allow the tail wheel to snap to the direction of landing roll when I touch down without stressing the rudder assembly but allow for MUCH more positive control in cross winds. Rick Neilsen Redrive VW Powered MKIIIC On Sat, Nov 9, 2013 at 10:45 AM, John Hauck wrote: > > > The steering springs on my aircraft were way too soft, especially with th e > wider wheel. Got the stiffest ones that were the right length that I cou ld > find at Ace Hardware, and that's better, but still mushy. John H - How c an > you hook up 'compression' springs there?? When I get back I think I'll u se > 3/16" bungy cord, looped around as many times as necessary to get the rig ht > strength. Done that before with another aircraft and I liked it better > than springs.... > > > Just my experience, for what it's worth..... > > > JG > > > p.s.- How do you load photos to these posts?? The one that I tried to > load with the previous post didn't seem to work..... > > > JG/Kolbers: > > > First=85attaching photos. Don't know how others do it, but I copy the ph oto(s), the paste them to the email. > > > We lucked out and I found a photo of my tail wheel and springs. I used s ome very small carabineers to attach the compression springs to the rudder and tail wheel. > > > john h > > mkIII > > Titus, Alabama > > ________________________________________________________________________________
Date: Nov 09, 2013
Didn't look at my photo long enough before I sent it. I used carabineers to attach to the rudder and "normal" tail wheel spring clips to attach to the tail wheel. One could easily bend up to strong "s" hooks to do the same job for nothing. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck Sent: Saturday, November 09, 2013 9:46 AM Subject: RE: Kolb-List: Re: tail wheel turning right The steering springs on my aircraft were way too soft, especially with the wider wheel. Got the stiffest ones that were the right length that I could find at Ace Hardware, and that's better, but still mushy. John H - How can you hook up 'compression' springs there?? When I get back I think I'll use 3/16" bungy cord, looped around as many times as necessary to get the right strength. Done that before with another aircraft and I liked it better than springs.... Just my experience, for what it's worth..... JG p.s.- How do you load photos to these posts?? The one that I tried to load with the previous post didn't seem to work..... JG/Kolbers: First.attaching photos. Don't know how others do it, but I copy the photo(s), the paste them to the email. We lucked out and I found a photo of my tail wheel and springs. I used some very small carabineers to attach the compression springs to the rudder and tail wheel. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Bent pitot/static tubes loading onto trailer...
Date: Nov 09, 2013
Finally I'm ready to load my Firestar II on the trailer and go fly for only the 2nd time since I got it last spring. And this is only the 2nd time loading it onto my new trailer. What happens? It's getting dark, I'm tired. I remember the radio antenna under the nose but it sweeps back so even if the tip hits the trailer ramp a bit no big deal. But I forget about the pitot & static tubes, lift the rear of the plane a bit too high and crunch them on the trailer ramp [Shocked] They are bent back some at the fuse connection and also at the 90* bend points they are bent pointing up some. I'm about to try bending them back. Research on Google says heating them with a heat gun won't help soften them. I hand bent them some last night and the aluminum tubes seem pretty soft. I'm concerned they will crack while bending them back to proper position. There is a medium kink in each bend that will probably reduce airflow so I will use a vice grip to gently press the kink out to get back to round for proper airflow. I called a local aircraft mechanic this morning and he said those aluminum pitot tubes should be soft enough to bend back without them cracking but if they do he has new tubing and can bend & attach new ones. I have a sour nervous stomach wondering if they will bend back ok. My desert runway is only 1,000 feet long and I can't afford any inaccuracy in airspeed and risk a surprise stall and I don't have enough room to come in extra fast and possibly overshoot. I plan to takeoff and either go to a long desert road and come in fast holding the wheels just off and slow down watching airspeed and confirm stall speed is still accurate, or go up a few thousand feet and slowly do a level stall to confirm if airspeed is still accurate. Bending pitot/static tubes is a huge bummer, will never do it again! -------- "Life should be lived as a bold adventure, I refuse to tiptoe through life just to arrive safely at death" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412589#412589 ________________________________________________________________________________
Date: Nov 09, 2013
AZ Flyer: Do you have a name? Not much airflow in a pitot/static system. Pitot is measuring air pressure from the air stream. Static is measuring atmospheric pressure. As long as the pitot is not crimped shut, it will work. Same for the static tube. If you have a concern, disconnect the static tube from the ASI. Take off, climb to 1,000 feet or higher, see what the ASI is indicating when it stalls. Stay about 10 mph above that speed and you won't stall. Doesn't matter if it is accurate or not, it will always indicate the same stall speed. 1000 feet of runway is plenty to land a FSII, especially if you have good approach and departure paths. I am not encouraging you to do the above, but if it was me, that is the way I would do it. Then...when you have time, replace the tubes. john h mkIII Titus, Alabama - Got an hour this afternoon. Weather was perfect. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Arizona Flyer Sent: Saturday, November 09, 2013 11:56 AM Subject: Kolb-List: Bent pitot/static tubes loading onto trailer... --> Finally I'm ready to load my Firestar II on the trailer and go fly for only the 2nd time since I got it last spring. And this is only the 2nd time loading it onto my new trailer. What happens? It's getting dark, I'm tired. I remember the radio antenna under the nose but it sweeps back so even if the tip hits the trailer ramp a bit no big deal. But I forget about the pitot & static tubes, lift the rear of the plane a bit too high and crunch them on the trailer ramp [Shocked] They are bent back some at the fuse connection and also at the 90* bend points they are bent pointing up some. I'm about to try bending them back. Research on Google says heating them with a heat gun won't help soften them. I hand bent them some last night and the aluminum tubes seem pretty soft. I'm concerned they will crack while bending them back to proper position. There is a medium kink in each bend that will probably reduce airflow so I will use a vice grip to gently press the kink out to get back ! to round for proper airflow. I called a local aircraft mechanic this morning and he said those aluminum pitot tubes should be soft enough to bend back without them cracking but if they do he has new tubing and can bend & attach new ones. I have a sour nervous stomach wondering if they will bend back ok. My desert runway is only 1,000 feet long and I can't afford any inaccuracy in airspeed and risk a surprise stall and I don't have enough room to come in extra fast and possibly overshoot. I plan to takeoff and either go to a long desert road and come in fast holding the wheels just off and slow down watching airspeed and confirm stall speed is still accurate, or go up a few thousand feet and slowly do a level stall to confirm if airspeed is still accurate. Bending pitot/static tubes is a huge bummer, will never do it again! -------- "Life should be lived as a bold adventure, I refuse to tiptoe through life just to arrive safely at death" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412589#412589 ________________________________________________________________________________
Subject: q
Date: Nov 09, 2013
List -- want to put wingtip strobes on an Xtra. Any suggestions? Also, which Garmin works best in a Kolb? Thanx Russ K ________________________________________________________________________________
Subject: Re: q
Date: Nov 09, 2013
I've had Kuntzlman strobes on mine since 2003, no problems yet with em. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Nov 9, 2013, at 6:04 PM, kinne russ wrote: > > > List -- want to put wingtip strobes on an Xtra. Any suggestions? > Also, which Garmin works best in a Kolb? > Thanx > Russ K > > > > ________________________________________________________________________________
Date: Nov 09, 2013
Subject: video
https://vimeo.com/79004790 password- owyheeflyer I took a flight this morning to check for something to hunt. The plane allowed me to search the area that I was interested in, and find what I could never have found on foot or by vehicle. Open the video first then the attachment. Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Kawasaki 440A FireFly
Date: Nov 09, 2013
I would like to see how a few others have installed a Donaldson exhaust. The manifold, plus ball joint, plus pipe distance from engine to muffler is supposed to be 12-inches to get full power at 6500RPM. Since a manifold and ball-joint takes up at least 8-inches, that leaves four inches to connect to muffler. Using a 90-degree bend, 4-inch long pipe, that gives the max total of 12-inches from the engine to the muffler. Then the muffler could exhaust forward or straight up in the air. Also it makes the center of the muffler about 10-12 inches away from the engine. Another requirement beside pipe length is to not have the exhaust oil going into the belt redrive. I downloaded the Rotax Manual and see that the Median length of tube on a Rotax 447, 503 and 582 is 26-inches which would make it easy to have a pipe exhausting to rear. The muffler could go forward of the engine or over the engine with the muffler's axis perpendicular to the longitudinal axis but the pipe length would be 16-17 inches. -------- Dnul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412609#412609 ________________________________________________________________________________
Subject: Re: video
Date: Nov 09, 2013
is this one of the wild horses... or a horse from the ranch? boyd From: Larry Cottrell Sent: Saturday, November 09, 2013 6:00 PM Subject: Kolb-List: video https://vimeo.com/79004790 password- owyheeflyer I took a flight this morning to check for something to hunt. The plane allowed me to search the area that I was interested in, and find what I could never have found on foot or by vehicle. Open the video first then the attachment. Larry -- If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Nov 09, 2013
Subject: Re: video
Its a horse from the ranch. I wonder how much flack I am going to get from the picture? Larry On Sat, Nov 9, 2013 at 9:07 PM, b young wrote: > is this one of the wild horses... or a horse from the ranch? > > boyd > > *From:* Larry Cottrell > *Sent:* Saturday, November 09, 2013 6:00 PM > *To:* kolb-list(at)matronics.com > *Subject:* Kolb-List: video > > https://vimeo.com/79004790 > > password- owyheeflyer > > I took a flight this morning to check for something to hunt. The plane > allowed me to search the area that I was interested in, and find what I > could never have found on foot or by vehicle. Open the video first then t he > attachment. > Larry > > > -- > *If you forward this email, or any part of it, please remove my email > address before sending.* > > * > =========== m> ldersbooks.com> .com> com> om/contribution> =========== onics.com/Navigator?Kolb-List> =========== =========== > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: q
Date: Nov 10, 2013
Hi Russ, Strobes? Going to do some night flying? we have to be on the ground by sunset over here. VFR only. Sounds as though you are making progress. Lets have an update. Pat ________________________________________________________________________________
Date: Nov 10, 2013
Subject: Tail wheel springs, 11/09/13
Greetings Kolbers. The compression springs that John H. uses are preferred in my opinion for the tail wheel/rudder area. The Cessna 180 I flew in Central America used compression type springs and never gave any problem. I am using compression springs on my MKIIIX plane and expect the same good service. There are compression springs sold for screen doors at ACE hardware. Spruce also carries them. With four boys going in and out the screen door the springs on the door suffered a lot of abuse but never broke. :) It is fairly simple to take the spring apart and attach the chain directly to each end of the spring. The Kolb kit should have oblong attach rings or small "s" clamps to attach chain to rudder and tail wheel bracket. Bob G MKIIIX N830PB ________________________________________________________________________________
Subject: Re: Bent pitot/static tubes loading onto trailer...
Date: Nov 10, 2013
Hi, pitot tubes are a nuisance in any position. Underneath, they get crunched in long grass, tail lifting, rough ground. Sticking out in front, some twit will walk into it. That particular one can be helped by inserting a short length of rubber tube on the tube just where it leaves the nose cone. This will allow it to flex if is bent. Sticking up from the top of the nose cone is good. It is reasonably protected and incidentally gives you something to compare the horizon with while keeping your eyes outside the cockpit.. You don`t need several thousand feet to check on stall speed. Unless you are very ham handed she will just nod her head at the stall and recover at once when you release the back pressure. A thousand feet is plenty. It doesn`t matter if the speedometer is accurate. She will stall at the same INDICATED speed every time. Unless the tube is crimped shut don`t worry too much. There is not much airflow. 1000ft of runway should be plenty for landing unless you are trying wheelies. A manoeuvre which I have never understood. The object of landing is to get the wheels on the ground at the point when she loses flying speed. I always close the throttle as soon as the strip is made.( Someday you will have to land deadstick so you might as well practice) Flare and hold off with progressively more back stick until she lands. If you still have flying speed she will leap in the air again so don`t do it. Have fun Pat ________________________________________________________________________________
Subject: Re: q
Date: Nov 10, 2013
Pat, I run wingtip strobes during every flight as an anti collision measure. Anything I can do to see and be seen is a plus. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Nov 10, 2013, at 7:28 AM, "Pat Ladd" wrote: > > > Hi Russ, > > Strobes? Going to do some night flying? we have to be on the ground by sunset over here. VFR only. > > Sounds as though you are making progress. Lets have an update. > > Pat > > > > ________________________________________________________________________________
Subject: Re: video
Date: Nov 10, 2013
not from me..... and unless you were culpable in the horses demise.... you shouldn=99t from anyone... if the horse fell due to the normal course of events or killed by a predator.. it is natural and normal course of events. what do the animal lovers think happen to a carcass that is natural prey, or die of old age? in nature nothing is wasted. that concept is attributed to man. it should be no different than the white bleached bones your birds landed on last month.... these are just pre bleached. and in another week,,, it will be stripped clean and the bleaching will begin. any way to tell from foot prints in the dirt, or teeth marks on the bones what animals have been feeding, besides the coyotes? the penny just dropped..... the dead coyote in the picture,,, that probably was you. oops and as long as killing the coyote is legal... still should be no flack.... well maybe a bit from the extreme nut cases.... how is the savage working out? boyd From: Larry Cottrell Sent: Saturday, November 09, 2013 10:05 PM Subject: Re: Kolb-List: video Its a horse from the ranch. I wonder how much flack I am going to get from the picture? Larry On Sat, Nov 9, 2013 at 9:07 PM, b young wrote: is this one of the wild horses... or a horse from the ranch? boyd From: Larry Cottrell Sent: Saturday, November 09, 2013 6:00 PM To: kolb-list(at)matronics.com Subject: Kolb-List: video https://vimeo.com/79004790 password- owyheeflyer I took a flight this morning to check for something to hunt. The plane allowed me to search the area that I was interested in, and find what I could never have found on foot or by vehicle. Open the video first then the attachment. Larry -- If you forward this email, or any part of it, please remove my email address before sending. _blank">www.aeroelectric.com .com" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com ="_blank">www.mypilotstore.com ank">www.mrrace.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com -- If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Nov 10, 2013
Subject: Re: video
It is working fine. I killed the "boss hog" this morning at daybreak. Probably the biggest Coyote that I have ever shot. So far I have killed 7 Coyotes with this rifle, and missed only one. I checked it at 200 yards yesterday, and shot a one inch group with four shot. If it holds together It will be fine. Larry On Sun, Nov 10, 2013 at 8:33 AM, b young wrote: > not from me..... and unless you were culpable in the horses > demise.... you shouldn=92t from anyone... if the horse fell due to th e > normal course of events or killed by a predator.. it is natural and norm al > course of events. what do the animal lovers think happen to a carcass tha t > is natural prey, or die of old age? in nature nothing is wasted. that > concept is attributed to man. it should be no different than the white > bleached bones your birds landed on last month.... these are just pre > bleached. and in another week,,, it will be stripped clean and the > bleaching will begin. > > any way to tell from foot prints in the dirt, or teeth marks on the bone s > what animals have been feeding, besides the coyotes? the penny just > dropped..... the dead coyote in the picture,,, that probably was you. > oops and as long as killing the coyote is legal... still should be no > flack.... well maybe a bit from the extreme nut cases.... how is the > savage working out? > > boyd > > *From:* Larry Cottrell > *Sent:* Saturday, November 09, 2013 10:05 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: video > > Its a horse from the ranch. I wonder how much flack I am going to get > from the picture? > Larry > > > On Sat, Nov 9, 2013 at 9:07 PM, b young wrote: > >> is this one of the wild horses... or a horse from the ranch? >> >> boyd >> >> *From:* Larry Cottrell >> *Sent:* Saturday, November 09, 2013 6:00 PM >> *To:* kolb-list(at)matronics.com >> *Subject:* Kolb-List: video >> >> https://vimeo.com/79004790 >> >> password- owyheeflyer >> >> I took a flight this morning to check for something to hunt. The plane >> allowed me to search the area that I was interested in, and find what I >> could never have found on foot or by vehicle. Open the video first then the >> attachment. >> Larry >> >> >> -- >> *If you forward this email, or any part of it, please remove my email >> address before sending.* >> >> * >> >> _blank">www.aeroelectric.com <http://www.aeroelectric.com> >> .com" target="_blank">www.buildersbooks.com <http://www.buildersbooks. com> >> ="_blank">www.homebuilthelp.com <http://www.homebuilthelp.com> >> ="_blank">www.mypilotstore.com <http://www.mypilotstore.com> >> ank">www.mrrace.com <http://www.mrrace.com> >> _blank">http://www.matronics.com/contribution >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> tp://forums.matronics.com <http://forums.matronics.com> >> * >> >> > > > -- > *If you forward this email, or any part of it, please remove my email > address before sending.* > > * > > href="http://www.aeroelectric.com ">www.ae roelectric.com <http://www.aeroelectric.com> > href="http://www.buildersbooks.com ">www. buildersbooks.com <http://www.buildersbooks.com> > href="http://www.homebuilthelp.com ">www. homebuilthelp.com <http://www.homebuilthelp.com> > href="http://www.mypilotstore.com ">www.my pilotstore.com <http://www.mypilotstore.com> > href="http://www.mrrace.com ">www.mrrace.com > href="http://www.matronics.com/contribution ">http://www.matronics.com/chref= "http://www.matronics.com/Navigator?Kolb-List ">http://www.matronics.com/Navigator?Kolb-List > href="http://forums.matronics.com ">http:/ /forums.matronics.com <http://forums.matronics.com> > * > > * > =========== m> ldersbooks.com> .com> com> om/contribution> =========== onics.com/Navigator?Kolb-List> =========== =========== > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Nov 10, 2013
John; My name is Jeff. Thanks for the input, much appreciated. Pat, thanks for your input also. I was able to bend my pitot/static tubes back into proper position, and took the kinks out by gently using a vice grips to make them round again. After I finished I reasoned that the pitot probably doesn't need 'full flow' to register proper airspeed because it's pressure more than flow. Then I read your comments and knew for sure thanks. I was sweating until I realized the aluminum was soft enough to not crack, what a relief. Turned out to be somewhat of a blessing because I found some obstruction in the pitot tube so I cleaned it out and it wasn't easy figuring out how to do that with the long length & 90* bend. I have been working on several things for 2 months getting ready to fly the 2nd time and bending those tubes while loading on the trailer was a real heartbreak. I doubt I'll need to do any stalls to verify airspeed now that all is well but I might anyway. Yes, 1,000 feet is plenty for a Firestar. Heck, in Wisconsin I only had 650 feet and landed my Rans S-7 many times stopping well short of the end. Not having flown for 11 years except a quick flight last spring, I'm a bit nervous but know I'll be back in the groove real soon. Last spring I landed on 600 feet 4 times and had problems stopping in time, but my idle was set at 2300 RPM, too high. I turned both idle screws out a bit equally and have it down to 2200 but should go lower. I don't have a carb balancing tool and am concerned about getting them out of sync. They were in sync to start with but at the lower 2200 RPM it does not start as easily. With all my other 2 strokes years ago when cold I'd choke for 2 pulls then they'd fire right up but I don't remember if I bumped the throttle a little? I trailered my Firestar out to my desert 40 acres late afternoon yesterday. It awaits me for flight this afternoon and really looking forward to it. Will be 83* today, gentle breeze & clear blue skies for several days :D This Kolb forum has been so valuab! le I'm m aking my contribution today. Thanks again guys... -------- "Life should be lived as a bold adventure, I refuse to tiptoe through life just to arrive safely at death" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412639#412639 ________________________________________________________________________________
Date: Nov 10, 2013
At 11:28 AM 11/10/2013, Arizona Flyer wrote: >...I reasoned that the pitot probably doesn't need 'full flow' to register >proper airspeed because it's pressure more than flow. It's _only_ pressure; at a constant airspeed the flow through the pitot tube is zero (unless you have a leak). As you increase or decrease airspeed, there is a very small flow in or out until the pressure again stabilizes. Dana -- Space isn't remote at all. It's only an hours drive away if your car could go straight upwards. ________________________________________________________________________________
Subject: Kingsbury Fly-In
Date: Nov 10, 2013
Flew up to the Kingsbury fly-in yesterday. It's about 165 miles from my home port here in Hitchcock Texas. Really nice flight with only a little light rain. Lots of nice planes from days gone by as well as some modern stuff. My MKIII got more than her share of attention and a number of people had never seen one before. Also got lots of comments on the amount of runway we didn't need. Attached a few pictures. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412643#412643 Attachments: http://forums.matronics.com//files/img_0515_623.jpg http://forums.matronics.com//files/img_0500_138.jpg http://forums.matronics.com//files/img_0520_180.jpg ________________________________________________________________________________
Subject: Re: Kingsbury Fly-In
Date: Nov 10, 2013
Beautiful pictures, sharp & clear, thanks for sharing. -------- "Life should be lived as a bold adventure, I refuse to tiptoe through life just to arrive safely at death" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412644#412644 ________________________________________________________________________________
Subject: Re: q
Date: Nov 10, 2013
I just got an Ad from Aircraft Spruce today for a new manufacturer that has some new and reasonably priced LED Nav and Strobe lights. I also have a circuit for the DIY people that might want to build their own strobes that I have been running on my Firefly successfully for 2 years now. I used teardrop shape Motorcycle marker lights, pulled the guts out and installed my own High power LEDS inside for the strobe heads. I have 50 bucks or less into my strobes. Anybody interested in the circuit can E-mail me off list and I'll send a copy of the schematic. It would make a fun winter hobby project for somebody. The Aircraft Spruce price looks attractive though as well. http://www.aircraftspruce.com/catalog/elpages/navstrobesextant1.php -------- Gregg Kaat 2011 Firefly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412651#412651 ________________________________________________________________________________
Subject: Re: q
Date: Nov 10, 2013
Gregg, please e-mail me a copy of the circuit for your Led strobe system. I know there making realy bright leds now and would love to see the circuit you came up with using them. I will also be putting strobes and marker lights of my xtra for safety reasons. Thanks Gregg cktman(at)wildblue.net -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412657#412657 ________________________________________________________________________________
Subject: John H's old Firestar
Date: Nov 10, 2013
Was just checking out the old pics of John's Firestar that were posted on the Kolb Facebook page from Oshkosh way back when. Dang that was a good looking bird. I'd say that Firestar and Ms Pfer are about as nice of examples of either type that I've ever seen. Nice work. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA ________________________________________________________________________________
Date: Nov 10, 2013
I changed out my "pizza cutter" earlier this year. It had been together for 10 yrs. and didn't want to come apart either. I had to remove the entire assembly, use a vice, torch and vice grips. It did finally yield but not with out considerable effort on my part. While I had it apart I changed out the springs to compression type. I used a Dunn caster & springs from Aircraft Spruce. Have fun with that tail-wheel.... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412663#412663 ________________________________________________________________________________
Date: Nov 10, 2013
Was just checking out the old pics of John's Firestar that were posted on the Kolb Facebook page from Oshkosh way back when. Dang that was a good looking bird. I'd say that Firestar and Ms Pfer are about as nice of examples of either type that I've ever seen. Nice work. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA Thank you, Dennis, for the kind words. Just goes to show that anyone can build a decent Kolb. john h mkIII - 1992 - 3,232.0 hours FS - 1987 - 785.0 hours US - 1984 - 385.0 hours 4,402.0 hours In my own Kolbs. Without looking it up, don't know how many hours I have in Factory and other Kolbs. Flying for the Factory for more than 20 years, easily another 600.00, but that is just a WAG, and a big one at that. ________________________________________________________________________________
Date: Nov 10, 2013
In a message dated 11/9/2013 12:55:55 P.M. Eastern Standard Time, heracesthesun(at)yahoo.com writes: Bending pitot/static tubes is a huge bummer, will never do it again! Jeff, You say you will NEVER do it again? Ha ! I'll remember this the next time you post a report about having trouble loading your Kolb onto that trailer, again! Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive ________________________________________________________________________________
Date: Nov 10, 2013
In a message dated 11/9/2013 3:57:32 P.M. Eastern Standard Time, jhauck(at)elmore.rr.com writes: I am not encouraging you to do the above, but if it was me, that is the way I would do it. John h/kolbers, That reminds me of my Dad. When I was a teenager, he and I would be arguing about how to do something on the farm, and then he would say, "you can do it any way you want to, but if I were doing it.........". And you better believe, it was in my best interest to do it his way. Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive ________________________________________________________________________________
Date: Nov 11, 2013
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 11, 2013
Subject: Matronics Email Disruption Fixed...
Dear Listers, Starting around midnight this morning 11/11/13, the Matronics Barracuda spam filter that receives all incoming email from the Internet, developed a problem and started rejecting all incoming email. I just got off the phone with the Barracuda technical support and we have If you have posted to any of the Lists during this time, you will need to resend your email to the respective List. My apologies for the disruption! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Re: Matronics Email Disruption Fixed...
Date: Nov 11, 2013
Matt, Did donations made during those hours go through? Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Nov 11, 2013, at 1:22 PM, Matt Dralle wrote: > > > Dear Listers, > > Starting around midnight this morning 11/11/13, the Matronics Barracuda spam filter that receives all incoming email from the Internet, developed a problem and started rejecting all incoming > email. I just got off the phone with the Barracuda technical support and we > > If you have posted to any of the Lists during this time, you will need to resend your email to the respective List. > > My apologies for the disruption! > > Matt Dralle > Matronics Email List and Forum Administrator > > > > > ________________________________________________________________________________
Subject: Re: Xtra Steering Problems
Date: Nov 11, 2013
Thanks for all the suggestions and help. I think I figured out the issue with my tail wheel not unlocking as it should. Upon further investigation I realized that the issue was that the spring chain assembly that connects the connection bar to the ruder wasnt allowing the wheel to turn enough so that the spring pin could retract. The compression springs were from Aircraft Spruce and were too stiff. I replaced them with heavy duty door springs purchased at the local hardware store.(Thanks Dennis Kerby for the suggestion.) Unfortunately I was unable to do a taxi test due to wind. But I think it will do the trick. Thanks again, YellowBird 1 Kolb MK III Xtra PS: I changed my userid to my Dads call sign when he was flying B-57s in Vietnam. ________________________________________________________________________________
Date: Nov 11, 2013
Demnis, Yes Contributions were normally received during the email disruption. Thank you for your support! Matt Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN Dennis Rowe wrote: > >Matt, >Did donations made during those hours go through? > >Dennis "Skid" Rowe >Mk3, 690L-70, Leechburg, PA > > >> On Nov 11, 2013, at 1:22 PM, Matt Dralle >wrote: >> >> >> Dear Listers, >> >> Starting around midnight this morning 11/11/13, the Matronics >Barracuda spam filter that receives all incoming email from the >Internet, developed a problem and started rejecting all incoming >> email. I just got off the phone with the Barracuda technical support >> >> If you have posted to any of the Lists during this time, you will >need to resend your email to the respective List. >> >> My apologies for the disruption! >> >> Matt Dralle >> Matronics Email List and Forum Administrator >> >> >> >> >> > > ________________________________________________________________________________
Date: Nov 12, 2013
Brad I'm not sure I understand what you are saying. If you were having problems getting the tail wheel to unlock then I have a better suggestion. The problem is that the tail wheel doesn't turn enough to unlock. This can be fixed by drilling the tail wheel bellcrank to allow the control chains to be attached closer together to effectively increase the turning ratio between the rudder and the tail wheel. The optional tail wheel has a much longer bellcrank than the stock tail wheel. The advantage of the compression springs is that they keep the tail wheel from a unexpected unlock in cross winds. The above suggestion on modifying the tail wheel bellcrank allows you to turn by unlocking the tail wheel without having to slam the tail wheel sideways enough to overcome spring tension for a tail wheel unlock. This also reduces the ground handling sideloading on the tail feathers which has been a problem on older Kolbs. I did this fix on my MKIIIC years ago and it has worked well. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Nov 11, 2013 at 10:58 PM, Brad Nation wrote : > > Thanks for all the suggestions and help. I think I figured out the issue > with my tail wheel not unlocking as it should. Upon further investigatio n > I realized that the issue was that the spring chain assembly that connect s > the connection bar to the ruder wasn=92t allowing the wheel to turn enoug h so > that the spring pin could retract. The compression springs were from > Aircraft Spruce and were too stiff. I replaced them with heavy duty door > springs purchased at the local hardware store.(Thanks Dennis Kerby for th e > suggestion.) Unfortunately I was unable to do a taxi test due to wind. Bu t > I think it will do the trick. > > Thanks again, > > YellowBird 1 > Kolb MK III Xtra > > PS: I changed my userid to my Dad=92s call sign when he was flying B-57s in > Vietnam. > =========== =========== =========== =========== > > ________________________________________________________________________________
Subject: Re: New Firestar battery Lithium Iron 1.46 lbs.
Date: Nov 12, 2013
Reporting on my new Lithium Iron battery... It's amazing, and is working very well in my FS-II. When I picked up the shipping box on my back porch which held the battery & charger it was so light I didn't think there could be much power in this battery. After opening the box I was shocked at how small it was, more shocked how light it was. I was thinking this could barely power a child's little electric car around the driveway. I thought how could it start a Rotax 503? I now have 2 flights on it and my 503 is cold blooded so it sometimes takes a bit of cranking to start and this battery shows no sign of wearing down. This Shorai Lithium Iron is fantastic, very pleased with my decision to get this. And it's only 1 1/2 lbs. It's very small and I just got a small cloth strap with Velcro from Ace hardware and was a 2 minute job to install. I picked up the old lead acid battery and it's so heavy and seems like ancient history now. Saved a little more weight by replacing that old big stainless steel strap with the feather weight cloth strap. If you want to save several pounds you've got to try one of these, a lot easier to mount also. -------- "Life should be lived as a bold adventure, I refuse to tiptoe through life just to arrive safely at death" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412889#412889 ________________________________________________________________________________
Date: Nov 12, 2013
I got one for my FSII as well, worth the few extra $ Sent from my iPhone > On Nov 12, 2013, at 2:48 PM, "Arizona Flyer" wrote: > > > Reporting on my new Lithium Iron battery... It's amazing, and is working very well in my FS-II. When I picked up the shipping box on my back porch which held the battery & charger it was so light I didn't think there could be much power in this battery. After opening the box I was shocked at how small it was, more shocked how light it was. I was thinking this could barely power a child's little electric car around the driveway. I thought how could it start a Rotax 503? I now have 2 flights on it and my 503 is cold blooded so it sometimes takes a bit of cranking to start and this battery shows no sign of wearing down. This Shorai Lithium Iron is fantastic, very pleased with my decision to get this. And it's only 1 1/2 lbs. It's very small and I just got a small cloth strap with Velcro from Ace hardware and was a 2 minute job to install. I picked up the old lead acid battery and it's so heavy and seems like ancient history now. Saved a little more weight by replacing that old! > big stainless steel strap with the feather weight cloth strap. If you want to save several pounds you've got to try one of these, a lot easier to mount also. > > -------- > "Life should be lived as a bold adventure, I refuse to tiptoe through life just to arrive safely at death" > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=412889#412889 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 12, 2013
my 503 is cold blooded so it sometimes takes a bit of cranking to start and this battery shows no sign of wearing down. Kolbers: There is one correct procedure to crank a cold Rotax, 2 or 4 stroke. If one doesn't follow the way the book says to crank it, it will be difficult to start, especially when cold. Bing carbs used on 2 and 4 stroke Rotax do not have a choke. They use an enricher system. If the throttle is not in the closed position when the enricher is pulled fully on, the enricher will not work properly. There is an enricher well in the float bowl and also an enricher jet. With throttle closed and enricher fully on, when the engine is cranked it initially pulls a big slug of fuel out of the enricher well, then continues to pull fuel through the enricher jet which is larger than the idle jet. During the start procedure the engine gets more air and fuel which also causes a faster idle. Once the engine starts, you can slowly increase throttle and rpm to whatever the books calls for warm ups. I have never had a need for primers on any of my aircraft, 2 and 4 stroke, when I use the recommend start procedure. Have started all my Rotax engines, well below freezing, with no problems, pull and electric start. Thought I would throw that tidbit out to you all. Your mileage may vary. ;-) john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: More info on tailwheel 4130 tube needed...
Date: Nov 12, 2013
Hello Kolb Flyers, A little while back a couple folks talked about replacing the Aluminum tail wheel tube with a piece of 4130 steel. I talked to my local shop and they want to know what wall thickness is being used and they are unsure about the Hardness available, but would see what they could get. Any additional information would be much appreciated ! Thanks, Nick Palmer, Ak 0607AK ________________________________________________________________________________
Date: Nov 12, 2013
You might have some difficulty drilling that part because it has been harden ed to reduce wear at the keyway.ate up some good drill bits Sent from my iPhone > On Nov 12, 2013, at 9:30 AM, Rick Neilsen wrote: > > Brad > > I'm not sure I understand what you are saying. If you were having problems getting the tail wheel to unlock then I have a better suggestion. The probl em is that the tail wheel doesn't turn enough to unlock. This can be fixed b y drilling the tail wheel bellcrank to allow the control chains to be attach ed closer together to effectively increase the turning ratio between the rud der and the tail wheel. The optional tail wheel has a much longer bellcrank t han the stock tail wheel. > > The advantage of the compression springs is that they keep the tail wheel f rom a unexpected unlock in cross winds. The above suggestion on modifying th e tail wheel bellcrank allows you to turn by unlocking the tail wheel withou t having to slam the tail wheel sideways enough to overcome spring tension f or a tail wheel unlock. This also reduces the ground handling sideloading on the tail feathers which has been a problem on older Kolbs. > > I did this fix on my MKIIIC years ago and it has worked well. > > Rick Neilsen > Redrive VW Powered MKIIIC > > >> On Mon, Nov 11, 2013 at 10:58 PM, Brad Nation wro te: >> >> Thanks for all the suggestions and help. I think I figured out the issue with my tail wheel not unlocking as it should. Upon further investigation I realized that the issue was that the spring chain assembly that connects th e connection bar to the ruder wasn=99t allowing the wheel to turn enou gh so that the spring pin could retract. The compression springs were from A ircraft Spruce and were too stiff. I replaced them with heavy duty door spr ings purchased at the local hardware store.(Thanks Dennis Kerby for the sugg estion.) Unfortunately I was unable to do a taxi test due to wind. But I thi nk it will do the trick. >> >> Thanks again, >> >> YellowBird 1 >> Kolb MK III Xtra >> >> PS: I changed my userid to my Dad=99s call sign when he was flying B -57s in Vietnam. >> >> ========== >> ="_blank">www.aeroelectric.com >> ooks.com" target="_blank">www.buildersbooks.com >> et="_blank">www.homebuilthelp.com >> et="_blank">www.mypilotstore.com >> "_blank">www.mrrace.com >> ="_blank">http://www.matronics.com/contribution >> le, List Admin. >> ========== >> arget="_blank">http://www.matronics.com/Navigator?Kolb-List >> ========== >> http://forums.matronics.com >> ========== >> >> >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Nov 12, 2013
I have used a Lithium battery in my MkIII with a 912UL for the last 5 months or so. Works great and I have had no starting problems. I may have a slightly bigger one that mentioned above. Mine weights almost 2 lbs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412896#412896 ________________________________________________________________________________
Date: Nov 12, 2013
A little while back a couple folks talked about replacing the Aluminum tail wheel tube with a piece of 4130 steel. I talked to my local shop and they want to know what wall thickness is being used and they are unsure about the Hardness available, but would see what they could get. Any additional information would be much appreciated ! Thanks, Nick Nick: .120 wall thickness. Heat treat to 48RC. Heat treating should be done after all welding, drilling, etc. The length of the tail wheel strut can be reduced by about a half of whatever the plans call for. Don't know why Homer liked the tail wheel strut so long. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: More info on tailwheel 4130 tube needed...
Date: Nov 12, 2013
Recently I did the same thing. Same thickness and hardness. I waited until after it was hardened to drill and it is a little more difficult. However with a slow speed and cutting oil I didn't have any trouble with a new carbide bit. In my case I'm glad I did it that way because the hardening process caused the tubing to curve slightly and I was able to use the slight curve to my advantage (up and down rather than side to side). Perhaps a better hardening outfit can avoid the distortion but I was told it was hard to avoid on stuff this thin. I like the way it rides better than with the solid aluminum, has some spring to it. Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412901#412901 ________________________________________________________________________________
Date: Nov 13, 2013
Subject: Please Make A List Contribution Today; Some Nice Comments...
Dear Listers, I've been getting some very nice comments from Listers along with their List Support Contributions. I've shared a number of them below. Please read them over and see what your fellow Listers think of the Lists and Forums. Please make a Contribution today to support the continued upgrade and operation of these services. There are lots of really nice gifts available this year, so please browse the selections and pickup something fun with your qualifying Contribution! You may use a credit card or your PayPal account here: http://www.matronics.com/contribution Or feel free to send a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator -------------------- What Listers Are Saying About The Lists -------------------- I wondered off for a few years & am coming back. I firmly believe you provide greater value to us than some magazine subscriptions. William F Thanks for helping me connect to people have truly blazed the trail. Terry M Thank you for the time and effort you put into keeping these lists going. I am on the verge of flying my RV 8 and would not be here without the help of Matronics. Michael W Thank you for providing a valuable service. Vaughn T Matt I like your forums. Jerry D Thank you for another year of service. Oscar Z Been a "member" for years - this has been a fantastic resource and a great gift to the aviation community. Reade G Thanks for the many years of support to RV builders. Roy H Best run list on the net. Roger C Thanks for your excellent forum! Fred D Truly respect your work and service to many readers!! Fergus K Thanks for an ad-free list! William A Thank you for your GREAT service. I read it every day. John B ..great service! Ralph C Thanks so much for being there. Your contribution to aviation knowledge is invaluable. Benjamin B Thank you for providing the list service. It's great! William V I'd never have finished my Glasair without them. Ronald C Thank you Matt for the valuable forum, am pleased to contribute! Jeffrey J Fine service. Byron G Thanks for your support of our community! Kenneth B -------------------- What Listers Are Saying About The Lists -------------------- ________________________________________________________________________________
Date: Nov 13, 2013
That is a surprisingly thick wall for that little 3/4 inch rod! =F0=9F=98=B3 Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Nov 12, 2013, at 8:32 PM, "John Hauck" wrote: > > > A little while back a couple folks talked about replacing the Aluminum tai l wheel tube with a piece of 4130 steel. I talked to my local shop and they w ant to know what wall thickness is being used and they are unsure about the H ardness available, but would see what they could get > > Any additional information would be much appreciated ! > > Thanks, > > Nick > > > > Nick: > > .120 wall thickness. Heat treat to 48RC. Heat treating should be done af ter all welding, drilling, etc. > > The length of the tail wheel strut can be reduced by about a half of whate ver the plans call for. > > Don't know why Homer liked the tail wheel strut so long. > > john h > mkIII > Titus, Alabama > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Nov 13, 2013
That is a surprisingly thick wall for that little 3/4 inch rod! =F0=9F=98=B3 Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA Dennis: That's what it takes to get the job done on my MKIII. I also have a plate welded to the end on my tail wheel strut to mimic a flat tail spring to attach a Maule tail wheel. Works well. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 13, 2013
Possibly overkill from a strength perspective but there is a lot of twisting force on that rod/tube when you start shoving the tail around and the bolt that holds it in tends to wallow out the hole so my take would be that the thicker stuff helps prevent that a bit. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412987#412987 ________________________________________________________________________________
Subject: Landing gear update
Date: Nov 13, 2013
Hi everyone, I wanted to give an update of how the steel landing gear has been working on my MKII Twinstar. I put the hardened steel gear on this spring after several tries of using the aluminum gear. (The camber and toe in/out with aluminum gear would be all over the place depending on if I had a passenger or not which would send me all over the runway when landing.) I have about 45 hours on the steel gear and it has been great ! with or without a passenger, it goes down the runway straight. (much better on a tar runway also) My runway is bumpy, uneven and a couple of spots that want to send me back into the air if I hit them fast enough. The gear has enough spring in it to handle it well. (I know it should be smoothed out, but I don't own the land and the farmer does not want me to do anything to it, I am not going to ruffle any feathers.) I had to make new wheel attachment brackets to fit the straight steel legs so I installed a set of hydraulic mountain bike brakes at the same time. I am surprised at how good these little brakes hold, I can run it up to nose over and the brakes still hold. I don't think the pads will last long but they are only about $8. a set. I also set it up with two brake handles on the stick, works really well for turning. I have included a few pictures of the setup. don't look to close to the gear paint, it was a quick spray on some paint so it doesn't rust deal. Also want to thank everyone for helping me out with the steel leg conversion. Lee, MKII twinstar, CGS hawk classic, Goldwing, Vector Lee.. ________________________________________________________________________________
Date: Nov 13, 2013
Gary/All Yes the bellcrank is hardened. I found a drill bit for hardened steel at Production Tool that drilled it with no problems. Rick Neilsen Redrive VW Powered MKIIIC On Tue, Nov 12, 2013 at 7:06 PM, Gary Aman wrote: > You might have some difficulty drilling that part because it has been > hardened to reduce wear at the keyway.ate up some good drill bits > > Sent from my iPhone > > On Nov 12, 2013, at 9:30 AM, Rick Neilsen wrote: > > Brad > > I'm not sure I understand what you are saying. If you were having problem s > getting the tail wheel to unlock then I have a better suggestion. The > problem is that the tail wheel doesn't turn enough to unlock. This can be > fixed by drilling the tail wheel bellcrank to allow the control chains to > be attached closer together to effectively increase the turning ratio > between the rudder and the tail wheel. The optional tail wheel has a much > longer bellcrank than the stock tail wheel. > > The advantage of the compression springs is that they keep the tail wheel > from a unexpected unlock in cross winds. The above suggestion on modifyin g > the tail wheel bellcrank allows you to turn by unlocking the tail wheel > without having to slam the tail wheel sideways enough to overcome spring > tension for a tail wheel unlock. This also reduces the ground handling > sideloading on the tail feathers which has been a problem on older Kolbs. > > I did this fix on my MKIIIC years ago and it has worked well. > > Rick Neilsen > Redrive VW Powered MKIIIC > > > On Mon, Nov 11, 2013 at 10:58 PM, Brad Nation wrot e: > >> >> Thanks for all the suggestions and help. I think I figured out the issu e >> with my tail wheel not unlocking as it should. Upon further investigati on >> I realized that the issue was that the spring chain assembly that connec ts >> the connection bar to the ruder wasn=92t allowing the wheel to turn enou gh so >> that the spring pin could retract. The compression springs were from >> Aircraft Spruce and were too stiff. I replaced them with heavy duty doo r >> springs purchased at the local hardware store.(Thanks Dennis Kerby for t he >> suggestion.) Unfortunately I was unable to do a taxi test due to wind. B ut >> I think it will do the trick. >> >> Thanks again, >> >> YellowBird 1 >> Kolb MK III Xtra >> >> PS: I changed my userid to my Dad=92s call sign when he was flying B-57s in >> Vietnam. >> >> ========== >> ="_blank">www.aeroelectric.com >> ooks.com" target="_blank">www.buildersbooks.com >> et="_blank">www.homebuilthelp.com >> et="_blank">www.mypilotstore.com >> "_blank">www.mrrace.com >> ="_blank">http://www.matronics.com/contribution >> le, List Admin. >> ========== >> arget="_blank">http://www.matronics.com/Navigator?Kolb-List >> ========== >> http://forums.matronics.com >> ========== >> >> >> >> > * > > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D > ot;">www.aeroelectric.com <http://www.aeroelectric.com> > books.com <http://books.com>"">www.buildersbooks.com > quot;">www.homebuilthelp.com <http://www.homebuilthelp.com> > quot;">www.mypilotstore.com <http://www.mypilotstore.com> > ">www.mrrace.com <http://www.mrrace.com> > ot;">http://www.matronics.com/contribution > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D > List"">http://www.matronics.com/Navigator?Kolb-List > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D > //forums.matronics.com <http://forums.matronics.com> > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D > * > > * > =========== m> ldersbooks.com> .com> com> om/contribution> =========== onics.com/Navigator?Kolb-List> =========== =========== > * > > ________________________________________________________________________________
Date: Nov 13, 2013
I made an extension for the steering arm on the bottom of the rudder. That let me drill several holes to vary the ratio till I found what I wanted. Much easier to do and to adjust as you like. On Wed, Nov 13, 2013 at 10:29 AM, Rick Neilsen wrote: > Gary/All > > Yes the bellcrank is hardened. I found a drill bit for hardened steel at > Production Tool that drilled it with no problems. > > Rick Neilsen > Redrive VW Powered MKIIIC > > > On Tue, Nov 12, 2013 at 7:06 PM, Gary Aman wrote: > >> You might have some difficulty drilling that part because it has been >> hardened to reduce wear at the keyway.ate up some good drill bits >> >> Sent from my iPhone >> >> On Nov 12, 2013, at 9:30 AM, Rick Neilsen wrote: >> >> Brad >> >> I'm not sure I understand what you are saying. If you were having >> problems getting the tail wheel to unlock then I have a better suggestio n. >> The problem is that the tail wheel doesn't turn enough to unlock. This c an >> be fixed by drilling the tail wheel bellcrank to allow the control chain s >> to be attached closer together to effectively increase the turning ratio >> between the rudder and the tail wheel. The optional tail wheel has a muc h >> longer bellcrank than the stock tail wheel. >> >> The advantage of the compression springs is that they keep the tail whee l >> from a unexpected unlock in cross winds. The above suggestion on modifyi ng >> the tail wheel bellcrank allows you to turn by unlocking the tail wheel >> without having to slam the tail wheel sideways enough to overcome spring >> tension for a tail wheel unlock. This also reduces the ground handling >> sideloading on the tail feathers which has been a problem on older Kolbs . >> >> I did this fix on my MKIIIC years ago and it has worked well. >> >> Rick Neilsen >> Redrive VW Powered MKIIIC >> >> >> On Mon, Nov 11, 2013 at 10:58 PM, Brad Nation wro te: >> >>> >>> Thanks for all the suggestions and help. I think I figured out the >>> issue with my tail wheel not unlocking as it should. Upon further >>> investigation I realized that the issue was that the spring chain assem bly >>> that connects the connection bar to the ruder wasn=92t allowing the whe el to >>> turn enough so that the spring pin could retract. The compression sprin gs >>> were from Aircraft Spruce and were too stiff. I replaced them with hea vy >>> duty door springs purchased at the local hardware store.(Thanks Dennis >>> Kerby for the suggestion.) Unfortunately I was unable to do a taxi test due >>> to wind. But I think it will do the trick. >>> >>> Thanks again, >>> >>> YellowBird 1 >>> Kolb MK III Xtra >>> >>> PS: I changed my userid to my Dad=92s call sign when he was flying B-57 s >>> in Vietnam. >>> >>> ========== >>> ="_blank">www.aeroelectric.com >>> ooks.com" target="_blank">www.buildersbooks.com >>> et="_blank">www.homebuilthelp.com >>> et="_blank">www.mypilotstore.com >>> "_blank">www.mrrace.com >>> ="_blank">http://www.matronics.com/contribution >>> le, List Admin. >>> ========== >>> arget="_blank">http://www.matronics.com/Navigator?Kolb-List >>> ========== >>> http://forums.matronics.com >>> ========== >>> >>> >>> >>> >> * >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D >> ot;">www.aeroelectric.com <http://www.aeroelectric.com> >> books.com <http://books.com>"">www.buildersbooks.com >> quot;">www.homebuilthelp.com <http://www.homebuilthelp.com> >> quot;">www.mypilotstore.com <http://www.mypilotstore.com> >> ">www.mrrace.com <http://www.mrrace.com> >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D >> List"">http://www.matronics.com/Navigator?Kolb-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D >> //forums.matronics.com <http://forums.matronics.com> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D >> * >> >> * >> >> _blank">www.aeroelectric.com <http://www.aeroelectric.com> >> .com" target="_blank">www.buildersbooks.com <http://www.buildersbooks. com> >> ="_blank">www.homebuilthelp.com <http://www.homebuilthelp.com> >> ="_blank">www.mypilotstore.com <http://www.mypilotstore.com> >> ank">www.mrrace.com <http://www.mrrace.com> >> _blank">http://www.matronics.com/contribution >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> tp://forums.matronics.com <http://forums.matronics.com> >> * >> >> > * > =========== m> ldersbooks.com> .com> com> om/contribution> =========== onics.com/Navigator?Kolb-List> =========== =========== > * > > ________________________________________________________________________________
Date: Nov 14, 2013
From: "Kirby, Dennis Civ USAF AFMC AFNWC/ENS" <Dennis.Kirby(at)kirtland.af.mil>
"Arizona Flyer" wrote: << Reporting on my new Lithium Iron battery... It's amazing, and is working very well in my FS-II. >> Kolb Friends - I am getting ready to replace the battery in my Mark-III, and have been paying close attention to reports of folks using Lithium-Ion batteries. The power density in these new technology batteries is impressive, and they still seem to also have plenty of cranking amps. Does anybody have experience with one of these batteries on a 912 engine? What size is recommended for a 912? Thanks ... Dennis Kirby Mark-III Sandia Park, NM ________________________________________________________________________________
Date: Nov 14, 2013
I'm using one for my 912. The one I have is a 20 AH, 410 CCA EVO2-LifePO4 battery marketed by Ballistic Performance Components. Part Number 2113-0265. I purchased this one on eBay. It has given me excellent performance for the 5 months I have been using it. The other day I did a carb balance and restarted the engine 7 or 8 times, only running it briefly while I checked the gauges. It never even began to slow down. I can't say it's the best size or type but it works for me. It has slightly more power than the old battery I took off and weights a little less than 2 lbs I believe. Hope that helps. Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413051#413051 ________________________________________________________________________________
Date: Nov 15, 2013
Subject: Make Sure You're Listed! List of Contributors Published in
December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: mkII landing gear and brakes again
Date: Nov 15, 2013
see if these pictures show up. I will take some better pictures for those that want and will send them of list. Lee ________________________________________________________________________________
Subject: pictures
Date: Nov 16, 2013
ok, I have tried to post pictures 2 times and I am doing something wrong. I tried to insert from a file and I did a copy and paste. how do you do it ? Lee ________________________________________________________________________________
Subject: pictures
Date: Nov 16, 2013
ok, I have tried to post pictures 2 times and I am doing something wrong. I tried to insert from a file and I did a copy and paste. how do you do it ? Lee Lee: Here is how I do it: -Copy the photo. -Anywhere in the message box of the reply email, paste the photo. Should automatically put the file in the Attached box. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: pictures
Date: Nov 17, 2013
Lovely picture John. Pat ________________________________________________________________________________
Date: Nov 17, 2013
TWO TIMES? Whatever happened to TWICE? Pat ________________________________________________________________________________
Date: Nov 17, 2013
Doesn't your English-to-American translation dictionary tell you that? On Nov 17, 2013, at 6:01 AM, Pat Ladd wrote: > > > TWO TIMES? Whatever happened to TWICE? > > Pat > > ________________________________________________________________________________
Date: Nov 17, 2013
UGF0LCBzdHJpY3RseSBvdXQgb2YgY3VyaW9zaXR5LCBkbyB0aGUgZm9sa3Mgb24geW91ciBzaWRl IG9mIHRoZSBwb25kIGNvbW1vbmx5IHNheSB0aHJlZSB0aW1lcyBvciB0aHJpY2U/CgpEYXZlIEt1 bHAKQmV0aGxlaGVtLCBQQSDCoCDCoC0gNSBocnMgWnVsdQpEbyBOT1QgYXJjaGl2ZQoKClNlbnQg ZnJvbSBteSBWZXJpem9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lCgotLS0tLS0tLSBPcmln aW5hbCBtZXNzYWdlIC0tLS0tLS0tCkZyb206IFBhdCBMYWRkIDxwai5sYWRkQGJ0aW50ZXJuZXQu Y29tPiAKRGF0ZTogMTEvMTcvMjAxMyAgNjowMSBBTSAgKEdNVC0wNTowMCkgClRvOiBrb2xiLWxp c3RAbWF0cm9uaWNzLmNvbSAKU3ViamVjdDogUmU6IEtvbGItTGlzdDogcGljdHVyZXMgCiAKPHBv c3QgcGljdHVyZXMgMiB0aW1lcyA+CsKgClRXTyBUSU1FUz/CoCBXaGF0ZXZlciBoYXBwZW5lZCB0 byBUV0lDRT8KwqAKUGF0CgoKXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0KXy09Cl8tPSAgICAgICAtLSBQbGVhc2UgU3VwcG9ydCBZ b3VyIExpc3RzIFRoaXMgTW9udGggLS0KXy09ICAgICAgICAgICAoQW5kIEdldCBTb21lIEFXRVNP TUUgRlJFRSBHaWZ0cyEpCl8tPQpfLT0gICBOb3ZlbWJlciBpcyB0aGUgQW5udWFsIExpc3QgRnVu ZCBSYWlzZXIuICBDbGljayBvbgpfLT0gICB0aGUgQ29udHJpYnV0aW9uIGxpbmsgYmVsb3cgdG8g ZmluZCBvdXQgbW9yZSBhYm91dApfLT0gICB0aGlzIHllYXIncyBUZXJyaWZpYyBGcmVlIEluY2Vu dGl2ZSBHaWZ0cyBwcm92aWRlZApfLT0gICBieToKXy09Cl8tPSAgICAgKiBBZXJvRWxlY3RyaWMg d3d3LmFlcm9lbGVjdHJpYy5jb20KXy09ICAgICAqIFRoZSBCdWlsZGVyJ3MgQm9va3N0b3JlIHd3 dy5idWlsZGVyc2Jvb2tzLmNvbQpfLT0gICAgICogSG9tZWJ1aWx0SEVMUCB3d3cuaG9tZWJ1aWx0 aGVscC5jb20KXy09ICAgICAqIE15IFBpbG90IFN0b3JlIHd3dy5teXBpbG90c3RvcmUuY29tCl8t PSAgICAgKiBSYWNlIENvbnN1bHRpbmcgd3d3Lm1ycmFjZS5jb20KXy09Cl8tPSAgIExpc3QgQ29u dHJpYnV0aW9uIFdlYiBTaXRlOgpfLT0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNv bS9jb250cmlidXRpb24KXy09Cl8tPSAgIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBw b3J0IQpfLT0KXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBM aXN0IEFkbWluLgpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgIC0gVGhlIEtvbGItTGlzdCBFbWFpbCBG b3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBi cm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3Jp cHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQs IEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPiBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGItTGlzdApfLT0KXy09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09 ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNv bnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0KXy09ICAgLS0+IGh0 dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0K ________________________________________________________________________________
Date: Nov 18, 2013
Subject: Fund Raiser Behind By 25% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 25%. We got off to a slow start this year with the network DNS issues on the kickoff weekend, so please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Date: Nov 18, 2013
do the folks on your side of the pond commonly say three times or thrice?>> Hi, I was waiting for that. No, thrice has fallen out of use many years ago but I have never said `two times` in my life and certainly no one of my generation, or the following one, has done so.Always `twice`. When we learned our tables it was `Twice two are four` etc. (See Danny Kaye `Inchworm) `Two times` I have noticed is creeping into use now though. Just one more thing which raises my ire these days I know that language changes but, like most things it is changing too quickly for my taste. For instance when I asked my grand daughter (aged 16 ) if she would like to come to the theatre with me she answered. "No thanks, It doesn`t tickle my cheeky" What the hell does that mean? Cheers Pat ________________________________________________________________________________
Date: Nov 18, 2013
Doesn't your English-to-American translation dictionary tell you that?>> Hi Russ, The trouble is that your language is called `English` when it patently is not. If it was called `American` then we could treat it like any other language spoken by foreigners. I don`t know if you are aware of Flanders and Swann. A couple who wrote and performed there own stuff. Just piano and two voices. They wrote a piece called `A song of patriotic prejudice` with a chorus of The English the English The English are best I wouldn`t give tuppence for all of the rest The last stanza was It is not that they`re wicked or naturally bad Its just knowing they`re `foreign` that makes them so mad They probably wouldn`t be allowed to sing it now in case it upset someone's tender feelings. Cheers Pat ________________________________________________________________________________
Subject: RE: Kolb-List Digest: 4 Msgs - 11/17/13
Date: Nov 18, 2013
ok ok, I didn't think they went thru, when I got the list, they didn't show. Lee.. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Kolb-List Digest Server Sent: Monday, November 18, 2013 3:02 AM Subject: Kolb-List Digest: 4 Msgs - 11/17/13 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Kolb-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Kolb-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-11-17&Archive=Kolb Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2013-11-17&Archive=Kolb =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Kolb-List Digest Archive --- Total Messages Posted Sun 11/17/13: 4 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 03:07 AM - Re: pictures (Pat Ladd) 2. 03:08 AM - Re: pictures (Pat Ladd) 3. 07:25 AM - Re: pictures (kinne russ) 4. 07:39 AM - Re: pictures (undoctor) ________________________________ Message 1 _____________________________________ From: "Pat Ladd" <pj.ladd(at)btinternet.com> Subject: Re: Kolb-List: pictures Lovely picture John. Pat ________________________________ Message 2 _____________________________________ From: "Pat Ladd" <pj.ladd(at)btinternet.com> Subject: Re: Kolb-List: pictures TWO TIMES? Whatever happened to TWICE? Pat ________________________________ Message 3 _____________________________________ From: kinne russ <russk50(at)gmail.com> Subject: Re: Kolb-List: pictures Doesn't your English-to-American translation dictionary tell you that? On Nov 17, 2013, at 6:01 AM, Pat Ladd wrote: > > > TWO TIMES? Whatever happened to TWICE? > > Pat > > ________________________________ Message 4 _____________________________________ Subject: Re: Kolb-List: pictures From: undoctor <undoctor(at)ptd.net> UGF0LCBzdHJpY3RseSBvdXQgb2YgY3VyaW9zaXR5LCBkbyB0aGUgZm9sa3Mgb24geW91ciBzaWRl IG9mIHRoZSBwb25kIGNvbW1vbmx5IHNheSB0aHJlZSB0aW1lcyBvciB0aHJpY2U/CgpEYXZlIEt1 bHAKQmV0aGxlaGVtLCBQQSDCoCDCoC0gNSBocnMgWnVsdQpEbyBOT1QgYXJjaGl2ZQoKClNlbnQg ZnJvbSBteSBWZXJpem9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lCgotLS0tLS0tLSBPcmln aW5hbCBtZXNzYWdlIC0tLS0tLS0tCkZyb206IFBhdCBMYWRkIDxwai5sYWRkQGJ0aW50ZXJuZXQu Y29tPiAKRGF0ZTogMTEvMTcvMjAxMyAgNjowMSBBTSAgKEdNVC0wNTowMCkgClRvOiBrb2xiLWxp c3RAbWF0cm9uaWNzLmNvbSAKU3ViamVjdDogUmU6IEtvbGItTGlzdDogcGljdHVyZXMgCiAKPHBv c3QgcGljdHVyZXMgMiB0aW1lcyA+CsKgClRXTyBUSU1FUz/CoCBXaGF0ZXZlciBoYXBwZW5lZCB0 byBUV0lDRT8KwqAKUGF0CgoKXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0KXy09Cl8tPSAgICAgICAtLSBQbGVhc2UgU3VwcG9ydCBZ b3VyIExpc3RzIFRoaXMgTW9udGggLS0KXy09ICAgICAgICAgICAoQW5kIEdldCBTb21lIEFXRVNP TUUgRlJFRSBHaWZ0cyEpCl8tPQpfLT0gICBOb3ZlbWJlciBpcyB0aGUgQW5udWFsIExpc3QgRnVu ZCBSYWlzZXIuICBDbGljayBvbgpfLT0gICB0aGUgQ29udHJpYnV0aW9uIGxpbmsgYmVsb3cgdG8g ZmluZCBvdXQgbW9yZSBhYm91dApfLT0gICB0aGlzIHllYXIncyBUZXJyaWZpYyBGcmVlIEluY2Vu dGl2ZSBHaWZ0cyBwcm92aWRlZApfLT0gICBieToKXy09Cl8tPSAgICAgKiBBZXJvRWxlY3RyaWMg d3d3LmFlcm9lbGVjdHJpYy5jb20KXy09ICAgICAqIFRoZSBCdWlsZGVyJ3MgQm9va3N0b3JlIHd3 dy5idWlsZGVyc2Jvb2tzLmNvbQpfLT0gICAgICogSG9tZWJ1aWx0SEVMUCB3d3cuaG9tZWJ1aWx0 aGVscC5jb20KXy09ICAgICAqIE15IFBpbG90IFN0b3JlIHd3dy5teXBpbG90c3RvcmUuY29tCl8t PSAgICAgKiBSYWNlIENvbnN1bHRpbmcgd3d3Lm1ycmFjZS5jb20KXy09Cl8tPSAgIExpc3QgQ29u dHJpYnV0aW9uIFdlYiBTaXRlOgpfLT0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNv bS9jb250cmlidXRpb24KXy09Cl8tPSAgIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBw b3J0IQpfLT0KXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBM aXN0IEFkbWluLgpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgIC0gVGhlIEtvbGItTGlzdCBFbWFpbCBG b3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBi cm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3Jp cHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQs IEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPiBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGItTGlzdApfLT0KXy09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09 ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNv bnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0KXy09ICAgLS0+IGh0 dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0K ________________________________________________________________________________
Date: Nov 18, 2013
Hi Pat, I thought that you would be interested to know that your old Kolb Xtra which was deregistered by the chap that bought it from you and sold the engine, has now been bought by one of our club members and is in the process of having a reconditioned Jabiru 2200 fitted to it, it will be re-registered, permitted and flying again in a month or two, excellent news that as it was such a nice looking aeroplane, Cheers, John Codd, North Lincs in UK, Kolb Mk3 Xtra with Jabiru 2200, From: Pat Ladd Sent: Monday, November 18, 2013 11:26 AM Subject: Re: Kolb-List: pictures Doesn't your English-to-American translation dictionary tell you that?>> Hi Russ, The trouble is that your language is called `English` when it patently is not. If it was called `American` then we could treat it like any other language spoken by foreigners. I don`t know if you are aware of Flanders and Swann. A couple who wrote and performed there own stuff. Just piano and two voices. They wrote a piece called `A song of patriotic prejudice` with a chorus of The English the English The English are best I wouldn`t give tuppence for all of the rest The last stanza was It is not that they`re wicked or naturally bad Its just knowing they`re `foreign` that makes them so mad They probably wouldn`t be allowed to sing it now in case it upset someone's tender feelings. Cheers Pat No virus found in this message. Checked by AVG - www.avg.com 11/18/13 ________________________________________________________________________________
Date: Nov 18, 2013
I'm nit-picking, but have been an editor & rewriter for years & this got my attention -- you say > performed there own stuff. and it should be 'their' But I still like you! Russ On Nov 18, 2013, at 6:26 AM, Pat Ladd wrote: > Doesn't your English-to-American translation dictionary tell you that?>> > > Hi Russ, > > The trouble is that your language is called `English` when it patently is not. > > If it was called `American` then we could treat it like any other language spoken by foreigners. > > I don`t know if you are aware of Flanders and Swann. A couple who wrote and performed there own stuff. Just piano and two voices. > They wrote a piece called `A song of patriotic prejudice` with a chorus of > The English the English The English are best > I wouldn`t give tuppence for all of the rest > > The last stanza was > > It is not that they`re wicked or naturally bad > Its just knowing they`re `foreign` that makes them so mad > > They probably wouldn`t be allowed to sing it now in case it upset someone's tender feelings. > > Cheers > > Pat > > ________________________________________________________________________________
Date: Nov 18, 2013
For instance when I asked my grand daughter (aged 16 ) if she would like to come to the theatre with me she answered. "No thanks, It doesn`t tickle my cheeky" So, I am curious did you insult her as well? Larry On Mon, Nov 18, 2013 at 4:15 AM, Pat Ladd wrote: > do the folks on your side of the pond commonly say three times or > thrice?>> > > Hi, > I was waiting for that. > > No, thrice has fallen out of use many years ago but I have never said `two > times` in my life and certainly no one of my generation, or the following > one, has done so.Always `twice`. When we learned our tables it was `Twice > two are four` etc. (See Danny Kaye `Inchworm) > `Two times` I have noticed is creeping into use now though. Just one more > thing which raises my ire these days > > I know that language changes but, like most things it is changing too > quickly for my taste. > > For instance when I asked my grand daughter (aged 16 ) if she would like > to come to the theatre with me she answered. "No thanks, It doesn`t tickle > my cheeky" > > What the hell does that mean? > > Cheers > > Pat > > * > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Nov 18, 2013
On 11/18/2013 5:15 AM, Pat Ladd wrote: > do the folks on your side of the pond commonly say three times or > thrice?>> > Hi, > I was waiting for that. > No, thrice has fallen out of use many years ago but I have never said > `two times` in my life and certainly no one of my generation, or the > following one, has done so.Always `twice`. When we learned our tables > it was `Twice two are four` etc. (See Danny Kaye `Inchworm) > `Two times` I have noticed is creeping into use now though. Just one > more thing which raises my ire these days > I know that language changes but, like most things it is changing too > quickly for my taste. > For instance when I asked my grand daughter (aged 16 ) if she would > like to come to the theatre with me she answered. "No thanks, It > doesn`t tickle my cheeky" > What the hell does that mean? > Cheers > Pat I wouldn't call it 'creeping'. When I learned multiplication tables in the American South early in the Cold War (late 1950's), it was always '2 times x equals y'; never heard it any other way. It boils down to cultural differences. If you look at the setup routines for computer software & operating systems, many will actually offer options for 'American English' and British English'. I must say, though, that the American Southern way is actually more consistent. How would you translate '13 times 7'? Charlie ________________________________________________________________________________
Date: Nov 19, 2013
and it should be 'their'> Of course it should. Enny fule no that. Grovelling apologies Pat ________________________________________________________________________________
Subject: q
Date: Nov 18, 2013
List, my apologies. That was meant for Pat alone Sorry. ________________________________________________________________________________
Subject: pictures
Date: Nov 18, 2013
List, my apologies. That was meant for Pat alone Sorry. >> >> > ________________________________________________________________________________
Date: Nov 19, 2013
Subject: Re: q
list is slow..I am enjoying the banter! :-) Herb in Ky ps Churchill said it best... two countries divided by a common language....something like that...?? On 11/18/2013 06:01 PM, kinne russ wrote: > > List, my apologies. That was meant for Pat alone > Sorry. > > ________________________________________________________________________________
Subject: Re: q
Date: Nov 19, 2013
I put strobes on the wingtips of Ed's FSII when I rebuilt it, they turned out nicely. This is from the archives. http://forums.matronics.com/viewtopic.php?p=292469#292469 http://forums.matronics.com/viewtopic.php?t=69825&highlight http://forums.matronics.com/viewtopic.php?t=73071&highlight If I had it to do over, I would have bent the counterweight tubes to lay closer to the wingtips. But it looks good and fly's good. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413428#413428 ________________________________________________________________________________
Date: Nov 20, 2013
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 20, 2013
Subject: RE: Kolb-List Digest: 5 Msgs - 11/19/13
Richard: Always amazed at your innovations for up grades on the Kolbs. Thank you for posting these photos and info. Bob G N830PB MKIIIX w/GPAS VW From: "Richard Pike" <richard(at)bcchapel.org> I put strobes on the wingtips of Ed's FSII when I rebuilt it, they turned out nicely. This is from the archives. http://forums.matronics.com/viewtopic.php?p=292469#292469 http://forums.matronics.com/viewtopic.php?t=69825&highlight http://forums.matronics.com/viewtopic.php?t=73071&highlight If I had it to do over, I would have bent the counterweight tubes to lay closer to the wingtips. But it looks good and fly's good. -------- Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413428#413428 ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 5 Msgs - 11/19/13
Date: Nov 21, 2013
Thank you, you are very gracious. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413639#413639 ________________________________________________________________________________
Subject: Split Wheels
Date: Nov 21, 2013
I installed new tires on my Firestar and when putting the wheels on the axle I notice they would not spin freely due to the brakes dragging. These are Azusa wheels and the halves fit tightly together but I had to deflate the tires and loosen the tie bolts then hit the halves with a rubber hammer to more align the halves. With a little tapping they would spin freely. -------- Bob E Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413644#413644 ________________________________________________________________________________
Subject: Rotax 670
Date: Nov 21, 2013
Was wondering if any Kolb drivers have installed or know someone who runs a Rotax 670 built by Rotax Rick in Naples Florida? Talked to him for an hour tonight picking his brain and need to talk to end users to find out how theirs are working out. Thanks Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA ________________________________________________________________________________
Date: Nov 21, 2013
Subject: Re: Rotax 670
http://ppcflyingforums.com/forums/showthread.php?t=8540 Can't get something for nothing....... Jim Baker -----Original Message----- From: Dennis Rowe <rowedenny(at)windstream.net> Sent: Thu, 21 Nov 2013 19:53 Subject: Kolb-List: Rotax 670 Was wondering if any Kolb drivers have installed or know someone who runs a Rotax 670 built by Rotax Rick in Naples Florida? Talked to him for an hour tonight picking his brain and need to talk to end users to find out how theirs are working out. Thanks Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA ________________________________________________________________________________
Date: Nov 22, 2013
Subject: Please Make A Contribution Today...
Dear Listers, A quick reminder that November is the annual List Fund Raiser and the List of Contributors is quickly approching. The Matronics Lists are 100% member supported and all of the operational costs are provided for by your Contributions during this time of the year. Your personal Contribution makes a big difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 22, 2013
http://ppcflyingforums.com/forums/showthread.php?t-03 Sounds like Baron is pretty happy with it. -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413846#413846 ________________________________________________________________________________
Date: Nov 22, 2013
Sounds like Baron is pretty happy with it. -------- Wesley Elliott Sport Pilot-PPC That's based on a couple flights last summer. Reckon he's still happy with it? john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 23, 2013
Getting some good feedback on the 670. One PM from a Kolb driver with 50 hrs on one that replaced his 582, so far he loves it. Has a ways to go before we know if it makes the 300-400 hr life span we 2 stroke drivers have to live with but it does perform to the claims of the builder so far. Hopefully info will keep coming my way. Waiting on more positive feedback or a good deal on a used 912. Just don't have quite the climb or cruise I'd like to have from my 2si. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > > > > Sounds like Baron is pretty happy with it. > > -------- > Wesley Elliott > Sport Pilot-PPC > > > > > That's based on a couple flights last summer. > > Reckon he's still happy > > ________________________________________________________________________________
Date: Nov 23, 2013
I've been using my Rotax Rick 670 for 2 summers now and am really happy with it. I get great performance, fuel burn and haven't had any problems. T he motor looks and runs same now as it did when I got it. Rodney Payne Apalachin NY 2002 kolb Mark 3 xtra ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Nov 23, 2013
I've been using my Rotax Rick 670 for 2 summers now and am really happy with it. I get great performance, fuel burn and haven't had any problems. The motor looks and runs same now as it did when I got it. Rodney Payne How many hours would that be? john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 23, 2013
Rodney, Here are some pics of the motorcycle you sold my son a few years ago http://www.advrider.com/forums/showthread.php?t=649516&highlight=fairbanks I'm putting together a MKIIIc this winter with a grey 582, i might be looking to upgrade in a year or so Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413899#413899 ________________________________________________________________________________
Date: Nov 25, 2013
Subject: [PLEASE READ] Why I Have A Fund Raiser...
>From the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that elk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Subject: Re: Please Make A Contribution Today...
Date: Nov 25, 2013
Is my contribution of $20 not good enough? This site is important to me, let me know something.... -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414067#414067 ________________________________________________________________________________
Date: Nov 25, 2013
Must have slipped through the cracks Rick, I quit getting those messages as soon as I sent my $20. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Nov 25, 2013, at 1:39 PM, "Rick Lewis" wrote: > > > Is my contribution of $20 not good enough? This site is important to me, let me know something.... > > -------- > Rick Lewis > > (VW Watercooled Engine) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=414067#414067 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 25, 2013
That kinda makes me wonder if he ever even got my contribution then...maybe I'm waisting my time, sure hope not.... -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414074#414074 ________________________________________________________________________________
Date: Nov 25, 2013
Is my contribution of $20 not good enough? This site is important to me, let me know something.... -------- Rick Lewis If you are concerned about your contribution, send Matt a back copy message to his email address instead of the Kolb List. I doubt he reads every msg posted to each of the many lists on Matronics. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Nov 25, 2013
yea I'm kinda wondering if he checks on these things also John. -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414078#414078 ________________________________________________________________________________
Date: Nov 25, 2013
I can assure you Matt checks on "these things". Not necessarily "read every message that comes across every message board in Matronics". Shoot Matt a personal bc message about your concerns and he will respond. Here's Matt's email: dralle(at)matronics.com john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Lewis Sent: Monday, November 25, 2013 2:22 PM Subject: Kolb-List: Re: Please Make A Contribution Today... yea I'm kinda wondering if he checks on these things also John. -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414078#414078 ________________________________________________________________________________
Date: Nov 25, 2013
Thanks John, I do feel better about this, didn't know that you knew him that well. I never have seen my name on the list of contributers but that doesn't really matter... -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414088#414088 ________________________________________________________________________________
Date: Nov 25, 2013
Johns right, I sent my contribution the same day Matt posted that there was some problems with the list. I replied to his post about the list being down asking if it affected my contribution getting through and he replied promptly. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Nov 25, 2013, at 4:31 PM, "John Hauck" wrote: > > > I can assure you Matt checks on "these things". Not necessarily "read every > message that comes across every message board in Matronics". > > Shoot Matt a personal bc message about your concerns and he will respond. > > Here's Matt's email: dralle(at)matronics.com > john h > mkIII > Titus, Alabama > > > > > > > > > > > > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Lewis > Sent: Monday, November 25, 2013 2:22 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: Please Make A Contribution Today... > > > yea I'm kinda wondering if he checks on these things also John. > > -------- > Rick Lewis > > (VW Watercooled Engine) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=414078#414078 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 25, 2013
At 11:55 AM 11/25/2013 Monday, you wrote: > >That kinda makes me wonder if he ever even got my contribution then...maybe I'm waisting my time, sure hope not.... > >-------- >Rick Lewis Hi Rick, Your contribution was received, thank you! It is very much appreciated. There are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them. Thank you again for your kind contribution! Matt Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 26, 2013
Subject: Of Pencils & Airplanes [Repost From AeroElectric-List]...
[Dear Listers, last week, Bob Nuckolls of the AeroElectric fame, posted a very nice message discussing the Lists and Forums at Matronics. It is a very insightful piece and I asked Bob if I could forward it to the rest of the Lists for the other members to enjoy and contemplate as well. He gladly agreed, and so below I have included the text from that message. Enjoy. -Matt Dralle, Matronics Email List and Forum Administrator] "As most of you know, Matt's ISP was fiddling with some crucial details for the exchange of data on the 'net a few weeks ago. The Lists, Matt's business site, and AeroElectric.com got really flakey. . . I was 'unhooked' from the List and all of three of my e-mail services for several days. Out of business and out of touch. After two days, I was beginning to worry. I had no idea as to root cause nor was there a time table for resolution . . . I began to mull over plan-B options. Of course, plan-B would have entailed seeking a new home for aeroelectric.com and ancillary services. NOT a quick, inexpensive or happy thing to contemplate. The time talents and resources that go into fabrication and maintenance of some of the 'simplest' features of our lives often go unnoticed . . . not because they're unappreciated . . . but simply because we're unaware of their significance. I will invite you all to read an essay by one Leonard Read written in 1958 titled "I pencil". See: http://tinyurl.com/me3q3hj It's a fascinating and well crafted peek into a society of unacquainted, self-interested individuals who exploited uncountable windows of opportunity for what has been called "spontaneous order" in the manufacture and sales of the simple wood pencil. The point of citing Mr. Read's essay is to examine two features of the human experience that contribute to the success of this List and our various interests in airplanes. The first point I'd like to make is that we cannot know the millions of individuals who contributed to the materials and infrastructure that make this List possible. We sit at the top of a pyramid of work-product derived from the time, talents and resources of millions of people who we'll never know. Another feature I'd like to emphasis is our ignorance of the criticality for any single component for a host of materials and components for the manufacture and sales of a simple pencil or an affordable airplane. Suppose any one of the materials or processes described in Read's essay were simply unavailable. How would that impact the price of a pencil? Would the pencil even continue to exist at it's new price? The really big question is, "How might some seemingly small loss ripple throughout the economy of our existence?" The time, talent and resources that support infrastructure for this List, my website, Matt's website, and our e-mails cannot be accurately known. That infrastructure stands on an exceedingly complex array of activities that arose from the ingenuity and spontaneous organization of free- market enterprises. But from our perch at the top of this pyramid we need only look down a few layers and see that this resource upon which we depend is vulnerable. There are risks we all assume . . . Matt could get t-boned in an intersection tomorrow. Lightning could strike the pole behind his facility and do catastrophic damage to the hardware. Yours truly could take a deer through the windshield on his way to Wichita some morning. Other risks are less catastrophic. They include things like amateurish behaviors by maintainers of the Internet highway's potholes. Perhaps some material critical to the manufacture of terabyte hard drives dries up. Or maybe the cost of keeping the lights on and the bytes herded become more than Matt can justify given his personal needs for existence. Several times a year I get an opportunity to plant new seeds of thought in the minds of fellow citizens. One of my favorites is to be standing in a long line at Panera's waiting to purchase a bagel and coffee and hear somebody in line complaining about the wait. I suggest to them that to wait in line for a much desired product is a GOOD thing. Not having to wait is a BAD thing if there is not enough business to encourage them to be open tomorrow. It goes without saying that few, if any of us, possess the talents, resources or motivation to step up and do what Matt does. At last count, there were about 1600 individuals who subscribe to this List [Aeroelectric-List]. . . certainly many more make up the population of subscribers to all of the Lists on Matronics. A few years back, Matt was besieged by legal trials and tribulations over the naming of his products . . . seems somebody claimed ownership of the words 'scan' and/or 'scanner' . . . We here on the AeroElectric-List perceived a risk to Matt's operations and came up with several thousands of dollars to contribute to his defense fund. We need make no greater 'investment' in Matt's operations now than it takes to stand in a line for a Quarter-Pounder Combo . . . or a fist full of pencils. You and I can have no more positive influence over the manufacture of pencils and hard drives than to continue to purchase such things and encourage those with the time, talent and resources to continue doing what they do best. Let's contribute to the comfortable maintenance of this service which is probably more valuable than we know. Just a little bit from thousands of us on the Matronics Lists can make a big difference. Bob . . ." Please take a minute to make your Contribution today: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 26, 2013
Thanks Matt, we all appreciate the good work your doing. The forum is very important us.... -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414177#414177 ________________________________________________________________________________
Subject: New Gear Legs
Date: Nov 26, 2013
Several years ago, Kolb sold off their last set of machined, tapered gear legs for the MKIII, and I got them. Since the gear that was on the airplane was working OK, left them on the shelf for years. Took the MKIII apart last week and put it in the garage for a major going through this winter, and since the aluminum tapered gear was a bit bent, decided it was time to try the high-class gear. Back when I put the original gear legs on, I aligned them by getting a straight copper grounding rod from Lowe's and sticking it through the axle holes to get the alignment 0-0. Always worked good, so did the new gear the same way. Stuck the new legs in place, took a couple small bungees and strapped the same rod in place, and got everything perfectly parallel. Scribed the new legs by poking a scribe through the gear leg socket holes. (If you don't have machinist's bluing, a fresh Magic Marker works just as good) Took it to a local machine shop and told them to make the hole start exactly at the scribed hole mark on one side, and come out exactly through the middle or the scribed hole mark on the other side. They did it. $20. WOOT! Time to get to work. (Thanks, Travis!) -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414218#414218 Attachments: http://forums.matronics.com//files/gearleg_102.jpg ________________________________________________________________________________
Subject: Re: New Gear Legs
Date: Nov 26, 2013
That looks like a good way to align the gear. I used a laser pointer shooting to a target on the wall and compared each side with the center line of the fuselage. Your way seems just as accurate and much easier...Thanks.... -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414222#414222 ________________________________________________________________________________
Date: Nov 26, 2013
What I don't know is - the stiffer aluminum solid gear has almost no flex. This thing will probably be flexible. So that may make things very different. Who knows! -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414225#414225 ________________________________________________________________________________
Date: Nov 26, 2013
it was all the flex that caused the jackhammer ride..... I went from 2 de g, ( 1 deg per side) down to 0 deg... and it would shake hard enough t o make me think the dental work on my top teeth would end up in the bottom row.... I had to bend some toe in back in... as I remember it was around 1.2 deg total... .6 on each side. to make it ride smooth. the way I tested was the wheels on a skid plate, an angle sheet metal acr oss the back of both tires, and a carpenter square along the sheet metal, to the side of the wheel. check the photos. if you have any questions, l et me know. boyd mkiii utah -----Original Message----- From: Richard Pike Sent: Tuesday, November 26, 2013 6:58 PM Subject: Kolb-List: Re: New Gear Legs What I don't know is - the stiffer aluminum solid gear has almost no flex. This thing will probably be flexible. So that may make things very differen t. Who knows! -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414225#414225 --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Date: Nov 27, 2013
Subject: Make Sure You're Listed! List of Contributors Coming Soon!
Dear Listers, There's just a few more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2013
The pictures make perfect sense, thanks for that. How did you bend the gear legs a little at a time until you got the desired toe in? I have a tubing bender - or did you slip a pipe over the axles and armstrong it? -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414320#414320 ________________________________________________________________________________
Date: Nov 27, 2013
Subject: Kolb-List Digest: 5 Msgs - 11/26/13
Boyd, How did you bend the legs/axles to get the result you wanted? Bob MKIIIX N830PB ________________________________________________________________________________
Date: Nov 27, 2013
The pictures make perfect sense, thanks for that. How did you bend the gear legs a little at a time until you got the desired toe in? I have a tubing bender - or did you slip a pipe over the axles and armstrong it? -------- Richard Pike I've had good luck bending with a long section of water pipe slipped over the axle. Of course you have to support the main gear where you want to make the correction. Happy Thanksgiving to all the Kolbers out there. You all are a special family of special builders and flyers. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: New Gear Legs,
Date: Nov 27, 2013
Richard and others my son bought a pipe / tube bender so he could fabricate roll cages for his and friends jeeps he has fabricated bunk beds for the kids, it is a hea vy duty bender,,, it is floor mounted with 4, 1/2 inch bolts into concr ete. it has replaceable dies that fit in the center and on the moveable a rm that fit the diameter of the material you are bending. there is also a plate that is marked in degrees that can be rotated to any position, it ha s a little friction plate so it stays put while you are bending. and it h as a fixed pointer that hovers over the degree plate. after placing t he gear in the bender at the position needed to correct the problems. I ad just the degree plate to zero under the pointer, then proceed to bend. be cause it is spring steel. you have to try in small increments then relax and see if the steel has bent or only sprung then returned to normal. it seems that I had to take the gear to 10 to 12 degrees past where I wanted it to be in order to get the gear to bend, anything less than that and it w ould spring back to the starting point. 1/4 to 1/2 would have been conside red a very large bend.... most of the bends I did was under a quarter of a deg. while trying, I would pull the bender to increasing number of d egrees past where I needed it to be. and then relax in between. until it did not return all the way to zero on the pointer and plate. the increasin g number would increase by very small amounts, once I kind of figured out how much past I needed to go... it was quicker on subsequent bends as I k new where permanent change to the gear would start to happen... so I coul d sneak up on the amount of movement needed quicker in order to get the ben d I wanted. finally when I got to the end and I figured I needed 1/10t h of 1 deg it was tricky, that is not a lot of bend,,, and if you go to far, you have to bend it back..... every time I would get noticeable chan ge in the gear, I would re install and measure again,,, when I was close I would then take it for a hi speed taxi or short flight to see how it turn ed out. the gear comes out of the gear socket down to a bend just where th e brake mounts, and the wheel fits on.... I did all the bends in the 6 in ches or so just up from the factory bend. where the steel was small in dia meter in comparison to the area just outside of the gear socket. in my humble opinion... the factory bend, at least in my gear was too much , when I had the plane on stands and was installing the gear, the camber a ngle of the wheels looked real good. when I put the weight of the cage on the gear it still looked good. but when I mounted the 912, the gear starte d looking squatty. and when me and a passenger got in,,, the gear looked a s if I had landed too hard and bent the gear. when I got finished, I could take off and land without the oscillations fore and aft that would give a jackhammer ride. and I could inflate the t ires without the plane wanting to veer all over the runway. all the measurements were made with the wheels on a grease plate, I was t oo cheap to buy aluminum plates to put grease in between.... so I used som e pieces of floor tile. if I rolled the wheel on the floor tile... someti mes it would break off the edges of the tile... so I had to jack up the wh eel and place the floor tile under the wheel. it was amazing how much mov ement there is in the gear with the wheel on the grease plate. don =99t try the adjustments with the wheel on the floor, there is too much f riction and it would be extremely hard if not impossible to get where you w ant to be. if I was going to install gear again.... I would use the strait edge metho d with a carpenter square with both wheels on grease plates. to keep the g ear from going too far into the gear sockets, I would put in a piece of woo d dowel in the gear socket followed by the gear. I would do all this with the engine mounted, and a hundred pound of wheat in both seats. I am going to my sons for thanks giving, and could take pictures of his pi pe bender if you would like. boyd young -----Original Message----- From: Richard Pike Sent: Wednesday, November 27, 2013 6:56 AM Subject: Kolb-List: Re: New Gear Legs The pictures make perfect sense, thanks for that. How did you bend the gea r legs a little at a time until you got the desired toe in? I have a tubing bender - or did you slip a pipe over the axles and armstrong it? -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414320#414320 --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Subject: new gear legs
Date: Nov 27, 2013
Richard and others I just visited Google and did a search on pipe benders, my son=99s pipe bender looks very similar to this one, but his has two of the saw tooth ratchet arms, one arm is fixed and the other attaches to the actuati ng arm. they are set up so with one pull of the actuating arm you only move things one tooth,, but with the second arm... you can hold tension on the piece while you moved the primary arm to a new notch , then pull again. as I remember he told me that it would bend up to 1 1/2 inch solid steel r od. I cant see the fixed pointer in this photo. but it lines up just above the bottom plate marked off in degrees. boyd --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Subject: Introducing myself--help needed.
Date: Nov 27, 2013
Hi friends, I am the recent new owner of a Mk IIIC project that I am in the process of completing, so I want to introduce myself to this list and say hi! I am in Colorado Springs and am installing a Rotax Rick 670 due to the higher field elevations out here. (I was very interested in the post I just read on the 670, posted earlier this month). Being a newbie, I feel I have lot's to learn, and remain very "teachable". I hope to have the project flying within the next 3 to 6 months. 22 years of Air Force flying, laid it to rest for a number of years and now have the itch again! I'm excited about the aircraft and about the community that I find here. Seems everyone is really enjoying the flying and the commeraderie. How many of you are flying Kolbs in the mountains--just curious what advice you may have. Has anyone put together a POH of sorts? I am unaware of anything available through Kolb, but maybe I'm wrong about that? (I'm guessing most people put something together as a result of their Phase I test period but it would be nice to have a starting point.) The critical question: I have most photos from the previous owner builder's log but he was unable to locate pictures of the early construction of the cage and tail boom. I'm wondering if it might be possible to replace those with some generic pictures to complete my builder's log. My aircraft has a white painted cage structure. I would be very grateful. thanks so much Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414361#414361 ________________________________________________________________________________
Subject: Re: Introducing myself--help needed.
Date: Nov 27, 2013
Welcome aboard Mike, Will be interested in following your progress on your Mk 3. Also look forward to learning more about your engine installation. You will want to get some dual in a Mk-3 or a Kolbra to adjust yourself to the low inertia high drag world we Kolbers operate in. Our birds may be slow, but things happen fast in them. Enjoy your project, and enjoy the list. If you check the archives we had a thread recently on the POH, I believe I posted pics of the front and back of the checklist sheet I made for my bird. Also got some solid suggestions for adjustments to it. If you can't find it, hopefully someone better at using the archives can dig it up. ;-) Dennis "Skid" Rowe Mk3, 2SI690L-70, Leechburg, PA > On Nov 27, 2013, at 6:07 PM, "lownslow" wrote: > > > Hi friends, I am the recent new owner of a Mk IIIC project that I am in the process of completing, so I want to introduce myself to this list and say hi! I am in Colorado Springs and am installing a Rotax Rick 670 due to the higher field elevations out here. (I was very interested in the post I just read on the 670, posted earlier this month). Being a newbie, I feel I have lot's to learn, and remain very "teachable". I hope to have the project flying within the next 3 to 6 months. > > 22 years of Air Force flying, laid it to rest for a number of years and now have the itch again! I'm excited about the aircraft and about the community that I find here. Seems everyone is really enjoying the flying and the commeraderie. > > How many of you are flying Kolbs in the mountains--just curious what advice you may have. > > Has anyone put together a POH of sorts? I am unaware of anything available through Kolb, but maybe I'm wrong about that? (I'm guessing most people put something together as a result of their Phase I test period but it would be nice to have a starting point.) > > The critical question: I have most photos from the previous owner builder's log but he was unable to locate pictures of the early construction of the cage and tail boom. I'm wondering if it might be possible to replace those with some generic pictures to complete my builder's log. My aircraft has a white painted cage structure. I would be very grateful. > > thanks so much > > Mike > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=414361#414361 > > > > > > > > > > ________________________________________________________________________________
Subject: Kolb Mk3 POH/checklist
Date: Nov 27, 2013
Mike, Here is the front and back sides of my laminated sheets. These passed my air worthiness inspection as a POH. My engine is single ignition so you will hav e to edit in your dual ignition check, and you may not want to turn on your E IS (if you use one) until after the engine is started to avoid inductive spi kes from the starter motor and solenoid coil that could harm your electronic s. I hope this helps. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA ________________________________________________________________________________
Subject: Re: Kolb Mk3 POH/checklist
Date: Nov 27, 2013
awesome! thanks Denny! I appreciate it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414368#414368 ________________________________________________________________________________
Date: Nov 27, 2013
On 11/27/2013 5:07 PM, lownslow wrote: > > Hi friends, I am the recent new owner of a Mk IIIC project that I am in the process of completing, so I want to introduce myself to this list and say hi! I am in Colorado Springs and am installing a Rotax Rick 670 due to the higher field elevations out here. (I was very interested in the post I just read on the 670, posted earlier this month). Being a newbie, I feel I have lot's to learn, and remain very "teachable". I hope to have the project flying within the next 3 to 6 months. > > 22 years of Air Force flying, laid it to rest for a number of years and now have the itch again! I'm excited about the aircraft and about the community that I find here. Seems everyone is really enjoying the flying and the commeraderie. > > How many of you are flying Kolbs in the mountains--just curious what advice you may have. > > Has anyone put together a POH of sorts? I am unaware of anything available through Kolb, but maybe I'm wrong about that? (I'm guessing most people put something together as a result of their Phase I test period but it would be nice to have a starting point.) > > The critical question: I have most photos from the previous owner builder's log but he was unable to locate pictures of the early construction of the cage and tail boom. I'm wondering if it might be possible to replace those with some generic pictures to complete my builder's log. My aircraft has a white painted cage structure. I would be very grateful. > > thanks so much > > Mike Did the previous builder keep notes during that phase of the build? Pics aren't required. ________________________________________________________________________________
Date: Nov 27, 2013
wow, didn't know that..... that's good news; the builder kept good notes in a word document that I was going to upload into kitlog pro, but I'm wondering if that's worth my time thanks! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414380#414380 ________________________________________________________________________________
Date: Nov 28, 2013
lownslow wrote: > wow, didn't know that..... > > that's good news; the builder kept good notes in a word document that I was going to upload into kitlog pro, but I'm wondering if that's worth my time > > thanks! If they are in Word, hit print and put them in a binder. That is more than enough documentation. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414385#414385 ________________________________________________________________________________
Date: Nov 28, 2013
I have had the privelage of standing by when an airplane was inspected by an Faa employee....She simply said" did you build it?" "Its experimental...so I guess you did?" "what is it called?" and with that...she did whatever paper work that was required.... The truth was...my bud had no builders log...for he had assembled the plane from two or three projects that he bought along the way... In another situation ..a friend bought a plane and did some finish work...mostly paint and instruments......The airline pilot Dar created some impossible tasks to make the plane certifiable...and after some months ...my bud found another Dar who signed it off in two hours... My impression is...that if the DAR's occupation depends on the good graces of the FAA...then give him a pass and shop for another ...Ask around , they are out there..Herb On 11/28/2013 06:04 PM, Larry Cottrell wrote: > I suppose that a lot of what is required depends on the examiner. It > may have even changed since I had mine in for registration. I had a > POH, he didn't even look at it or want it. Builders log was a similar > nonevent. The fact that I had one was all he cared about. He was very > interested in the safety factor of the build, and not much else. The > anticipation of all that could go wrong was much much more than the > actual fact. Perhaps you could find someone who had used the guy or > the office where the inspection would take place, and get some idea of > what to expect. I would suspect that you are much harder on yourself > than what the examiner will be. Mine was a paid examiner, not an > actual FAA employee. > > Having all the above in mind I would be as prepared as I could be, but > I wouldn't obsess over it. > > Good Luck > Larry > > ________________________________________________________________________________
Date: Nov 29, 2013
Subject: Just Two Days Left...
Dear Listers, There are just a couple days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least four of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2013
It must be my locality, being so close to the Air Capital of the World, but both the DAR I used for my trike, the Mk 3, and the Firestar, and the FAA inspector who did the Cumulus were all equally thorough. Since I was bringing previously built aircraft into the system under the LSA grandfathering clause of FAR 21.191(i)1 I didn't have to have a builder log, but they each spent about an hour going over the aircraft and another 30 minutes on the paperwork, so it appears the advice to shop around for a DAR is good. Since they charge upwards of $200 just to show up, I'd suggest contacting your local EAA chapter as well as other builders in your area to find a DAR who will give you a thorough inspection without getting hung up in subjective minutae. Rick Girard On Thu, Nov 28, 2013 at 6:55 PM, herb wrote: > > I have had the privelage of standing by when an airplane was inspected by > an Faa employee....She simply said" did you build it?" "Its > experimental...so I guess you did?" "what is it called?" > > and with that...she did whatever paper work that was required.... The > truth was...my bud had no builders log...for he had assembled the plane > from two or three projects that he bought along the way... > > In another situation ..a friend bought a plane and did some finish > work...mostly paint and instruments......The airline pilot Dar created > some impossible tasks to make the plane certifiable...and after some months > ...my bud found another Dar who signed it off in two hours... > > My impression is...that if the DAR's occupation depends on the good > graces of the FAA...then give him a pass and shop for another ...Ask around > , they are out there..Herb > > > On 11/28/2013 06:04 PM, Larry Cottrell wrote: > >> I suppose that a lot of what is required depends on the examiner. It may >> have even changed since I had mine in for registration. I had a POH, he >> didn't even look at it or want it. Builders log was a similar nonevent. The >> fact that I had one was all he cared about. He was very interested in the >> safety factor of the build, and not much else. The anticipation of all that >> could go wrong was much much more than the actual fact. Perhaps you could >> find someone who had used the guy or the office where the inspection would >> take place, and get some idea of what to expect. I would suspect that you >> are much harder on yourself than what the examiner will be. Mine was a paid >> examiner, not an actual FAA employee. >> >> Having all the above in mind I would be as prepared as I could be, but I >> wouldn't obsess over it. >> >> Good Luck >> Larry >> >> >> > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Nov 29, 2013
very helpful thread! thanks for all the discussion! Hope everyone had a great thanksgiving! Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414518#414518 ________________________________________________________________________________
Date: Nov 29, 2013
Denny mentioned the wisdom in getting some dual in a Kolb, and I agree, a great idea. Does anyone know of a Kolb close to Colorado where I might do that? Or maybe catch someone at a Kolb flyin. I need to find out when those happen. Sun'n Fun would be ideal, but I was hoping to fly mine before then.... Thanks everyone! Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414520#414520 ________________________________________________________________________________
Date: Nov 30, 2013
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again; the big 50, in fact! But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Fwd:Mk-3 616DR POH
Date: Dec 01, 2013
Ok guys, here is a PDF of my POH/checklist. Hope it's useful to someone. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA Begin forwarded message: > From: "M.D. Mainhart" <mdmainhart123(at)gmail.com> > Date: December 1, 2013 at 9:20:02 PM EST > To: rowedenny(at)windstream.net > Subject: Diabetes > ________________________________________________________________________________
Subject: Re: Kolb Firestar avialable
Date: Dec 02, 2013
Do you still have your Firestar and if so how much are you asking for it. Also do you have pictures and where are you located Guideman Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414760#414760 ________________________________________________________________________________
Date: Dec 02, 2013
Do you still have your Firestar and if so how much are you asking for it. Also do you have pictures and where are you located Guideman Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414761#414761 ________________________________________________________________________________
Date: Dec 02, 2013
Do you still have your Firestar and if so how much are you asking for it. Also do you have pictures and where are you located Guideman Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414762#414762 ________________________________________________________________________________
Date: Dec 03, 2013
I still have it but have decided to wait until Spring to put it back on the market. -----Original Message----- From: Guideman Sent: Monday, December 02, 2013 11:25 PM Subject: Kolb-List: Re: Kolb Firestar avialable Do you still have your Firestar and if so how much are you asking for it. Also do you have pictures and where are you located Guideman Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414762#414762 ________________________________________________________________________________
Date: Dec 03, 2013
I do not know anything about this airplane, just happened to see it listed http://elmira.craigslist.org/for/4195977972.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414770#414770 ________________________________________________________________________________
Subject: Change of plans
Date: Dec 04, 2013
I recently approached my friend and co-owner of my Mk 3 about my desire to upgrade to a used 912 to improve our take-off performance. Due to his busy business schedule, he has only rode in the Kolb twice with me in the 10 years it has been in operation, and only participated in the construction as a financial partner. I did 100% of the build and also hanger and fly it from my home. Not surprisingly he asked instead if I was interested in buying him out. Of course I am, but this unexpected expense, as well as doubling of my share of a new engine has eliminated any chance of me affording a 912 setup any time soon. Enter plan B. Have decided to build a 670cc Rotax sled engine into an 85hp aircraft engine. I'll be relying on Rotax Rick to do the bottom end as there is extensive machine work on the PTO end of the crankshaft as well as the cases to make it work with the aircraft gearbox and to fit the 582 ceramic water pump seal. The top end and cooling system I'll handle. Will also be using Ricks 618 style exhaust to insure the power delivery is smoothed out for our application. Also helping to make this a more affordable installation is the ability to use the same prop from my current engine as well as all the probes and EIS unit. Additionally I'll also use two of the three Bing carbs from my 2SI engine as I swapped them out for 28mm Mikunis a couple years ago. Should be a very straight forward swap, and using the same prop is going to make it clear how much more power the new engine has over my 690. My 690 has been a 'SMOOTH', solid engine and performs fine other than the gearbox being incessantly leaky, but flying out of my 600 foot strip in the middle of the woods makes me desire more climb performance. The engine core is on it's way from a sled salvage outfit as I type. Let the discussion commence. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA ________________________________________________________________________________
Subject: Re: Change of plans
Date: Dec 04, 2013
Dennis, THANK YOU for sharing your experiences & future ones as well. That will be enormously helpful to the List; this sort of thing is what it's all about Fair winds & happy 670cc-ing Russ On Dec 4, 2013, at 10:49 AM, Dennis Rowe wrote: > > I recently approached my friend and co-owner of my Mk 3 about my desire to upgrade to a used 912 to improve our take-off performance. Due to his busy business schedule, he has only rode in the Kolb twice with me in the 10 years it has been in operation, and only participated in the construction as a financial partner. I did 100% of the build and also hanger and fly it from my home. > Not surprisingly he asked instead if I was interested in buying him out. Of course I am, but this unexpected expense, as well as doubling of my share of a new engine has eliminated any chance of me affording a 912 setup any time soon. > Enter plan B. > Have decided to build a 670cc Rotax sled engine into an 85hp aircraft engine. > I'll be relying on Rotax Rick to do the bottom end as there is extensive machine work on the PTO end of the crankshaft as well as the cases to make it work with the aircraft gearbox and to fit the 582 ceramic water pump seal. The top end and cooling system I'll handle. > Will also be using Ricks 618 style exhaust to insure the power delivery is smoothed out for our application. > Also helping to make this a more affordable installation is the ability to use the same prop from my current engine as well as all the probes and EIS unit. Additionally I'll also use two of the three Bing carbs from my 2SI engine as I swapped them out for 28mm Mikunis a couple years ago. Should be a very straight forward swap, and using the same prop is going to make it clear how much more power the new engine has over my 690. > My 690 has been a 'SMOOTH', solid engine and performs fine other than the gearbox being incessantly leaky, but flying out of my 600 foot strip in the middle of the woods makes me desire more climb performance. > The engine core is on it's way from a sled salvage outfit as I type. > Let the discussion commence. > > Dennis "Skid" Rowe > Mk3, 690L-70, Leechburg, PA > > > > > > > ________________________________________________________________________________
Date: Dec 04, 2013
I can feel your pain for the lousy partnership in your Kolb. I went through the same situation with a partner. Building an aircraft with a partner does not work, does not work.....will never do it again.... -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414866#414866 ________________________________________________________________________________
Date: Dec 04, 2013
I can feel your pain for the lousy partnership in your Kolb. I went through the same situation with a partner. Building an aircraft with a partner does not work, does not work.....will never do it again.... -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414868#414868 ________________________________________________________________________________
Date: Dec 04, 2013
My experience is: works great, really bad, works great. Afraid to try it again, seems like really bad is next Sent from my iPhone > On Dec 4, 2013, at 6:43 PM, "Rick Lewis" wrote: > > > I can feel your pain for the lousy partnership in your Kolb. I went through the same situation with a partner. Building an aircraft with a partner does not work, does not work.....will never do it again.... > > -------- > Rick Lewis > > (VW Watercooled Engine) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=414868#414868 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 04, 2013
Guys, Didn't mean to give the impression I have been unhappy with my Kolb co-owner. Even though I did all the building and maintenance, I enjoyed it and since it was my third aircraft build, I had strong ideas of how I wanted to do things. Also basing it at my home made it seem like I was the sole owner. since I was doing all the flying anyway, I haven't even asked him for any $ toward upgrades such as the carb conversion and other upgrades I've done. Which means my buy out cost has not gone up in 6 years :-) Jay was a low maintenance partner. Also was nice to have only half the financial burden during that building period when money was tight. I am blessed to have at least four friends who I wouldn't hesitate to partner in an airplane with. In fact two of them are my current partners in our 1948 Cessna 170 project and my outgoing Kolb partner Jay Swager is another. You meet the nicest people at airports. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Dec 4, 2013, at 8:11 PM, Will Ricketts wrote: > > > My experience is: works great, really bad, works great. Afraid to try it again, seems like really bad is next > > Sent from my iPhone > >> On Dec 4, 2013, at 6:43 PM, "Rick Lewis" wrote: >> >> >> I can feel your pain for the lousy partnership in your Kolb. I went through the same situation with a partner. Building an aircraft with a partner does not work, does not work.....will never do it again.... >> >> -------- >> Rick Lewis >> >> (VW Watercooled > > ________________________________________________________________________________
Date: Dec 04, 2013
Dennis, Good luck with your 670 build. I know Rick real well, and I am sure he will do a good job doing the Machine work for you. I have two 670's myself, but I have decided that a Rotax 618 has plenty of enough ponies for my Firestar II The 618 I have needs to be rebuilt and I plan on having Rick do the work for me. I was real lucky this summer to find a Brand New 618 exhaust on E-Bay, it has never been used. I also plan on letting Rick doing a 670 for me as I plan to have a Two Place side by side one day. Hopefully it will be a Mark III Extra or a stretched avid flyer. Anyway keep us informed on your Progress -------- Kolb Firestar II 503 C-Box / RK400 Soon to have a Rotax 670 DCDI with a C-Box and RK 400 Clutch Challenger II 503 Tall Drive Location : Buffalo South Carolina Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414876#414876 Attachments: http://forums.matronics.com//files/image_940.jpg ________________________________________________________________________________
Date: Dec 04, 2013
Just some info that some may not know. All 670's that Rotax made are not a good candidate's to be converted for aviation use. That is if you want Dual Ignition. and some are not easily made to be provision 8. Their are 2 years that are preferred the 93 and 94 model year. If the 670 has a black rubber cover on the Mag end then you will not be able to have it become Dual Ignition Many people think that Rotax was planning on making the 670 into an aviation engine like they did with the 617 that became a 618. If they did it would have been competition for the 912. here is a picture of the early model PTO end, that can be made to accept a c-box or e-box. you could even use a b-box but I think it would not hold up to all the extra HP -------- Kolb Firestar II 503 C-Box / RK400 Soon to have a Rotax 670 DCDI with a C-Box and RK 400 Clutch Challenger II 503 Tall Drive Location : Buffalo South Carolina Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414878#414878 Attachments: http://forums.matronics.com//files/image_981.jpg ________________________________________________________________________________
Date: Dec 05, 2013
Subject: RE: Kolb-List Digest: 8 Msgs - 12/04/13
Skid: Have you given any thought to a Great Plains VW engine for you plane? The 2180 with re-drive should give you 100 hp for take-off and about 70-80 for cruise. It is already beefed up in the crank and other areas of significance. I do not want to obligate the folk at GPAS by stating a price but my brand new engine built by Steve at GPAS with re-drive was less than what the Rotax two stroke, two cyl was. My engine is a four cyl. four stroke air-cooled with dual ignition,starter, alternator, etc. Just a thought. Bob Green MKIIIX ________________________________________________________________________________
Date: Dec 05, 2013
Carolina Flyer wrote: > Dennis, > Good luck with your 670 build. I know Rick real well, and I am sure he will > do a good job doing the Machine work for you. I have two 670's myself, but I have decided that a Rotax 618 has plenty of enough ponies for my Firestar II > The 618 I have needs to be rebuilt and I plan on having Rick do the work for me. I was real lucky this summer to find a Brand New 618 exhaust on E-Bay, it has never been used. I also plan on letting Rick doing a 670 for me as I plan to have a Two Place side by side one day. Hopefully it will be a Mark III Extra > or a stretched avid flyer. > > Anyway keep us informed on your Progress Noticed that you are thinking of going big block on your FSII: feel free to contact me if you need any ideas or pictures of how we added structure to beef up the upper fuselage. Back before we began our conversion, Kolb was concerned about the extra torque from the bigger engine being a potentially serious problem for the stock tubing. -------- Richard Pike Kolb MKIII N420P (420ldPoops) richard (at) bcchapel(dot)org Kingsport, TN 3TN0 Now faith is the substance of things hoped for, the evidence of things not seen. Hebrews 11:1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414909#414909 ________________________________________________________________________________
Date: Dec 05, 2013
Richard offers some sound advice, a 582 or 618 is really getting up there for a Firestar 2. Careful throttle control is highly advised. Further clarification of the non 93-94 Rotax 670 engine cases that are not dual Ducati ignition compatible and possibly not provision 8 compatible. If there is a big hole in the top of the Magneto end housing that may have a black plastic cover over it, the Ducati ignition will not bolt up. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Dec 5, 2013, at 10:37 AM, "Richard Pike" wrote: > > > > Carolina Flyer wrote: >> Dennis, >> Good luck with your 670 build. I know Rick real well, and I am sure he will >> do a good job doing the Machine work for you. I have two 670's myself, but I have decided that a Rotax 618 has plenty of enough ponies for my Firestar II >> The 618 I have needs to be rebuilt and I plan on having Rick do the work for me. I was real lucky this summer to find a Brand New 618 exhaust on E-Bay, it has never been used. I also plan on letting Rick doing a 670 for me as I plan to have a Two Place side by side one day. Hopefully it will be a Mark III Extra >> or a stretched avid flyer. >> >> Anyway keep us informed on your Progress > > > Noticed that you are thinking of going big block on your FSII: feel free to contact me if you need any ideas or pictures of how we added structure to beef up the upper fuselage. Back before we began our conversion, Kolb was concerned about the extra torque from the bigger engine being a potentially serious problem for the stock tubing. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > richard (at) bcchapel(dot)org > Kingsport, TN 3TN0 > Now faith is the substance of things hoped for, the evidence of things not seen. > Hebrews 11:1 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=414909#414909 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: RE: Kolb-List Digest: 8 Msgs - 12/04/13
Date: Dec 05, 2013
Bob, I have a local friend, "Roger Sell" who is nearing completion of an Xtra with the GP/Valley Engineering set up. Very nice indeed. Should be a hot performer. Really looking forward to trying it out next summer. My fuselage is 1991 vintage and is not modified for the VW engine. I am also a weight freak and am pretty confident I'll keep my weight within 10 pounds of the 475 pounds my bird weighs with it's current powerplant. The 85+ hp the 670 offers should be more than ample to hurl my light Mk-3 into the sky at a satisfying clip. It also should make 65-70 hp in the lower 5k rpm range which will give me a solid 65-70 mph economy cruise. As I am doing some of the work myself, reusing my instrumentation and propeller, and starting off with the stock single ignition, I should be able to keep the total close to $5k. If it's over that, wifeys going to crap! Ok, she'll crap even if it's under. ;-) Anyhow, this option offers me the easiest path to a 85hp and should it not work out, swapping back to my 2SI will be a one day project. Can't beat that with a stick. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Dec 5, 2013, at 7:58 AM, Bob Green wrote: > > > Skid: Have you given any thought to a Great Plains VW engine for you plane? The 2180 with re-drive should give you 100 hp for take-off and about 70-80 for cruise. > It is already beefed up in the crank and other areas of significance. > I do not want to obligate the folk at GPAS by stating a price but my brand new engine built by Steve at GPAS with re-drive was less than what the Rotax two stroke, two cyl was. > My engine is a four cyl. four stroke air-cooled with dual ignition,starter, alternator, etc. > Just a thought. > Bob Green > MKIIIX > > > > > > > > ________________________________________________________________________________
Date: Dec 05, 2013
Hello Richard Pike, In regards to strengthening the cage for the additional torque of a 618. I called the Kolb Factory and they told me I should talk to Denise Jackson (The Factory's Welder) and him and I discussed this matter and I am going to use his advice. I am having the modification done this winter once deer season is over. I do not Hunt but the Welder that does all of my Welding for me is a Deer Hunter. Once the Modification has been completed I will post some Pictures. Joe -------- Kolb Firestar II 503 C-Box / RK400 Soon to have a Rotax 670 DCDI with a C-Box and RK 400 Clutch Challenger II 503 Tall Drive Location : Buffalo South Carolina Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414924#414924 ________________________________________________________________________________
Subject: Rotary valve oil reservoir.
Date: Dec 05, 2013
Does anyone have a Rotax rotary valve oil reservoir from a Rotax twin or a suitable substitution? I need one for my 670 project. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 6 Msgs - 12/05/13
Date: Dec 06, 2013
Yeah i have. I will check it out and post back to you. Tedcowan Sent from my iPhone On Dec 6, 2013, at 2:01 AM, Kolb-List Digest Server wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-12-05&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-12-05&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Thu 12/05/13: 6 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 04:59 AM - Re: Kolb-List Digest: 8 Msgs - 12/04/13 (Bob Green) > 2. 07:38 AM - Re: Change of plans (Richard Pike) > 3. 08:31 AM - Re: Re: Change of plans (Dennis Rowe) > 4. 09:04 AM - Re: Re: Kolb-List Digest: 8 Msgs - 12/04/13 (Dennis Rowe) > 5. 09:17 AM - Re: Change of plans (Carolina Flyer) > 6. 10:38 AM - Rotary valve oil reservoir. (Dennis Rowe) > > > > ________________________________ Message 1 _____________________________________ > > > From: Bob Green <bgreen(at)bimi.org> > Subject: Kolb-List: RE: Kolb-List Digest: 8 Msgs - 12/04/13 > > > Skid: Have you given any thought to a Great Plains VW engine for you plane? The > 2180 with re-drive should give you 100 hp for take-off and about 70-80 for > cruise. > It is already beefed up in the crank and other areas of significance. > I do not want to obligate the folk at GPAS by stating a price but my brand new > engine built by Steve at GPAS with re-drive was less than what the Rotax two stroke, > two cyl was. > My engine is a four cyl. four stroke air-cooled with dual ignition,starter, alternator, > etc. > Just a thought. > Bob Green > MKIIIX > > > ________________________________ Message 2 _____________________________________ > > > Subject: Kolb-List: Re: Change of plans > From: "Richard Pike" <richard(at)bcchapel.org> > > > > Carolina Flyer wrote: >> Dennis, >> Good luck with your 670 build. I know Rick real well, and I am sure he will > >> do a good job doing the Machine work for you. I have two 670's myself, but I > have decided that a Rotax 618 has plenty of enough ponies for my Firestar II >> The 618 I have needs to be rebuilt and I plan on having Rick do the work for > me. I was real lucky this summer to find a Brand New 618 exhaust on E-Bay, it > has never been used. I also plan on letting Rick doing a 670 for me as I plan > to have a Two Place side by side one day. Hopefully it will be a Mark III Extra >> or a stretched avid flyer. >> >> Anyway keep us informed on your Progress > > > Noticed that you are thinking of going big block on your FSII: feel free to contact > me if you need any ideas or pictures of how we added structure to beef up > the upper fuselage. Back before we began our conversion, Kolb was concerned about > the extra torque from the bigger engine being a potentially serious problem > for the stock tubing. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > richard (at) bcchapel(dot)org > Kingsport, TN 3TN0 > Now faith is the substance of things hoped for, the evidence of things not seen. > > Hebrews 11:1 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=414909#414909 > > > ________________________________ Message 3 _____________________________________ > > > Subject: Re: Kolb-List: Re: Change of plans > From: Dennis Rowe <rowedenny(at)windstream.net> > > > Richard offers some sound advice, a 582 or 618 is really getting up there for a > Firestar 2. Careful throttle control is highly advised. > Further clarification of the non 93-94 Rotax 670 engine cases that are not dual > Ducati ignition compatible and possibly not provision 8 compatible. If there > is a big hole in the top of the Magneto end housing that may have a black plastic > cover over it, the Ducati ignition will not bolt up. > > Dennis "Skid" Rowe > Mk3, 690L-70, Leechburg, PA > > >> On Dec 5, 2013, at 10:37 AM, "Richard Pike" wrote: >> >> >> >> Carolina Flyer wrote: >>> Dennis, >>> Good luck with your 670 build. I know Rick real well, and I am sure he will > >>> do a good job doing the Machine work for you. I have two 670's myself, but I > have decided that a Rotax 618 has plenty of enough ponies for my Firestar II >>> The 618 I have needs to be rebuilt and I plan on having Rick do the work for > me. I was real lucky this summer to find a Brand New 618 exhaust on E-Bay, it > has never been used. I also plan on letting Rick doing a 670 for me as I plan > to have a Two Place side by side one day. Hopefully it will be a Mark III Extra >>> or a stretched avid flyer. >>> >>> Anyway keep us informed on your Progress >> >> >> Noticed that you are thinking of going big block on your FSII: feel free to contact > me if you need any ideas or pictures of how we added structure to beef > up the upper fuselage. Back before we began our conversion, Kolb was concerned > about the extra torque from the bigger engine being a potentially serious problem > for the stock tubing. >> >> -------- >> Richard Pike >> Kolb MKIII N420P (420ldPoops) >> richard (at) bcchapel(dot)org >> Kingsport, TN 3TN0 >> Now faith is the substance of things hoped for, the evidence of things not seen. > >> Hebrews 11:1 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=414909#414909 >> >> >> >> >> >> >> >> >> >> > > > ________________________________ Message 4 _____________________________________ > > > Subject: Re: Kolb-List: RE: Kolb-List Digest: 8 Msgs - 12/04/13 > From: Dennis Rowe <rowedenny(at)windstream.net> > > > Bob, > I have a local friend, "Roger Sell" who is nearing completion of an Xtra with the > GP/Valley Engineering set up. Very nice indeed. Should be a hot performer. > Really looking forward to trying it out next summer. > My fuselage is 1991 vintage and is not modified for the VW engine. I am also a > weight freak and am pretty confident I'll keep my weight within 10 pounds of the > 475 pounds my bird weighs with it's current powerplant. The 85+ hp the 670 > offers should be more than ample to hurl my light Mk-3 into the sky at a satisfying > clip. It also should make 65-70 hp in the lower 5k rpm range which will > give me a solid 65-70 mph economy cruise. As I am doing some of the work myself, > reusing my instrumentation and propeller, and starting off with the stock > single ignition, I should be able to keep the total close to $5k. If it's over > that, wifeys going to crap! Ok, she'll crap even if it's under. ;-) > Anyhow, this option offers me the easiest path to a 85hp and should it not work > out, swapping back to my 2SI will be a one day project. Can't beat that with > a stick. > > Dennis "Skid" Rowe > Mk3, 690L-70, Leechburg, PA > > >> On Dec 5, 2013, at 7:58 AM, Bob Green wrote: >> >> >> Skid: Have you given any thought to a Great Plains VW engine for you plane? > The 2180 with re-drive should give you 100 hp for take-off and about 70-80 for > cruise. >> It is already beefed up in the crank and other areas of significance. >> I do not want to obligate the folk at GPAS by stating a price but my brand new > engine built by Steve at GPAS with re-drive was less than what the Rotax two > stroke, two cyl was. >> My engine is a four cyl. four stroke air-cooled with dual ignition,starter, alternator, > etc. >> Just a thought. >> Bob Green >> MKIIIX >> >> >> >> >> >> >> >> > > > ________________________________ Message 5 _____________________________________ > > > Subject: Kolb-List: Re: Change of plans > From: "Carolina Flyer" <joe.a.lawson(at)gmail.com> > > > Hello Richard Pike, > In regards to strengthening the cage for the additional torque of a 618. I called > the Kolb Factory and they told me I should talk to Denise Jackson > (The Factory's Welder) and him and I discussed this matter and I am going to use > his advice. I am having the modification done this winter once deer > season is over. I do not Hunt but the Welder that does all of my Welding for me > is a Deer Hunter. Once the Modification has been completed I will post some > Pictures. > Joe > > -------- > Kolb Firestar II > 503 C-Box / RK400 > Soon to have a > Rotax 670 DCDI > with a C-Box and > RK 400 Clutch > > Challenger II > 503 Tall Drive > > Location : Buffalo South Carolina > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=414924#414924 > > > ________________________________ Message 6 _____________________________________ > > > Subject: Kolb-List: Rotary valve oil reservoir. > From: Dennis Rowe <rowedenny(at)windstream.net> > > > Does anyone have a Rotax rotary valve oil reservoir from a Rotax twin or a suitable > substitution? > I need one for my 670 project. > Dennis "Skid" Rowe > Mk3, 690L-70, Leechburg, PA > > > > > > > > > ________________________________________________________________________________
Date: Dec 06, 2013
Subject: RE: Kolb-List Digest: 6 Msgs - 12/05/13
Sounds great Dennis. Bob Green ________________________________________________________________________________
Subject: Change of plans part 2
Date: Dec 08, 2013
The engine core and ignition components arrived last week for my 670 build. N ow I have to get an estimate on the parts and machine work I need. The cheap part is behind me. :-/ Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA ________________________________________________________________________________
Subject: How much fabric to cover a Mark IIIc?
Date: Dec 09, 2013
I'm researching the option of recovering my Mark IIIc in Oratex UL 600. How much fabric is required to cover a Mark IIIc? Better yet does anyone happen to have a list of what is required (fabric and tape). I haven't ruled out polyfiber but I'm a little dissapointed with the Kolb recommended supplier. (not why I'm considering Oratex) I contacted them on 3 separate occasions about ordering the kit to do the Mark IIIc and they never got back to me. This seems odd because I've heard nothing but good things about them and they were extremely nice when I talked to them but they just never followed up. The Oratex is about 71" wide and sold by the meter. I'm trying to figure out how many feet of 71" wide Oratex I need. I can then convert to meters. Kolb shows the Polyfiber kit as costing $1870 plus shipping and includes everything but the finish paint. How many gallons of finish paint (polytone) should I expect to use? Thanks, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415270#415270 ________________________________________________________________________________
Date: Dec 09, 2013
Subject: Re: How much fabric to cover a Mark IIIc?
Mark, I cannot help you with quantities, but I just covered the wing and tail feathers of my Earthstar eGull with Oratex. Easy, odor-free, non-toxic, and I saved a bunch of weight (no paint!). I found that I needed to use a real clothes iron set to fairly high to get the glue to trigger where it rests on aluminum. Cost-wise about the same (more expensive fabric, shipping charges, but no chemicals or paint). No direct experience with how long it lasts yet, but I do plan to keep my plane outside for most of the year. Lars and Paul at Better Aircraft Fabric were easy to work with. Contact me off-forum if you want particulars. Good luck! Martin Koxxy On Mon, Dec 9, 2013 at 6:29 PM, mike91911 wrote: > > I'm researching the option of recovering my Mark IIIc in Oratex UL 600. > How much fabric is required to cover a Mark IIIc? Better yet does anyone > happen to have a list of what is required (fabric and tape). I haven't > ruled out polyfiber but I'm a little dissapointed with the Kolb recommended > supplier. (not why I'm considering Oratex) I contacted them on 3 separate > occasions about ordering the kit to do the Mark IIIc and they never got > back to me. This seems odd because I've heard nothing but good things > about them and they were extremely nice when I talked to them but they just > never followed up. > > The Oratex is about 71" wide and sold by the meter. I'm trying to figure > out how many feet of 71" wide Oratex I need. I can then convert to meters. > > Kolb shows the Polyfiber kit as costing $1870 plus shipping and includes > everything but the finish paint. How many gallons of finish paint > (polytone) should I expect to use? > > Thanks, > Mike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415270#415270 > > ________________________________________________________________________________
Subject: 582-99 water pump housing
Date: Dec 10, 2013
Kolbers, My quest for odds and ends I need for my 670 project continues. I now am looking for a used Tee shaped dual inlet water pump housing that comes on the 582 blue head. And also a couple coolant outlet elbows that bolt on the heads of the liquid cooled Rotax twins. I can adapt a single inlet pump housing with a plastic tee in the line if I have to, but the dual inlet will make a much cleaner looking installation. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA ________________________________________________________________________________
Subject: propeller to boom tube clearance?
Date: Dec 10, 2013
I have a MKIIIC w/ 582, installed a 66" two bladed prop mounted with a 3.5" spacer. The clearance is .875", it looks awful close? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415303#415303 ________________________________________________________________________________
Subject: Re: propeller to boom tube clearance?
Date: Dec 10, 2013
My distance is 1.5", but I have heard of some that are less than an inch. My current engine is super smooth so it doesn't shake too much, when I swap to the 2 cylinder Rotax 670 I'm going to maintain at least my current distance as I have heard they are a little rough below 2500 rpm. Pretty sure you'll be ok, but check with other 582 operators. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Dec 10, 2013, at 6:04 AM, "tombaisley" wrote: > > > I have a MKIIIC w/ 582, installed a 66" two bladed prop mounted with a 3.5" spacer. The clearance is .875", it looks awful close? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415303#415303 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 10, 2013
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Although this happened in a Drifter - the placement of the boom and propell er is similar enough that I'll share my own experience. I was testing a new prop that was slightly longer than the one I'd been flying with. There was about 1.5" clearance and it seemed fine - so I took it for a test flight. It was a fairly windy day and I landed at a friend's airport; due to the co nfiguration of hangars and hills and wind, I ran into mechanical windshear. I bounced upon landing, the boom flexed... and I ended up trucking the Dri fter out for repairs. =0A=0AI had flown many times in that level wind, had ignimoniously bounced before - but never with such disasterous results. I a ttribute it totally to the longer prop that didn't allow for sufficient cle arance.=0A=0AThe guys on this list will probably tell you what the correct clearance should be - and perhaps say that my Drifter experience has no sim ilarity to your Kolb. But your question brought up vivid memories!=0A=0AArt y Trost=0ASandy, Oregon=0A=0A=0A-=0Awww.LessonsFromTheEdge.com/uladventur e2009.htm=0A=0A=0A"Life's a daring adventure or nothing"=0AHelen Keller=0A =0A=0A"I refuse to tip toe through life just to arrive safely at death."=0A =0A=0A=0AOn Tuesday, December 10, 2013 3:10 AM, tombaisley =0A=0AI have a MKIIIC w/ 582, installed a- 66" two bladed pr op mounted with a 3.5" spacer. The clearance is .875", it looks awful close ?=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.c == ________________________________________________________________________________
Date: Dec 10, 2013
I can adapt a single inlet pump housing with a plastic tee in the line if I have to, but the dual inlet will make a much cleaner looking installation. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA Dennis R/Kolbers: Had a nylon 1" hose barb fail on my well pump supply line recently. This plastic fitting was under ground with nice cool water flowing through it. I would consider the cooling system critical on a 582. Failure of a fitting would most likely put you down very quickly. Personally, I would go with aluminum pump housing. Check with Ronnie Smith, South Mississippi Light Aircraft if you cannot find another source. He probably has a used one. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 10, 2013
I have a MKIIIC w/ 582, installed a 66" two bladed prop mounted with a 3.5" spacer. The clearance is .875", it looks awful close? Tom B/Kolbers: Without digging out the MKIII Manual, I believe tail boom to prop tip clearance is 1". My last flight to Alaska I flew with a 72" Warp Drive 3 blade prop with 3/4" prop tip to tail boom clearance. Take a look at the way the engine mounts and airframe are designed. Then see how much you can deflect the engine downward. I don't recommend anyone flying with less than the published factory prop tip to tail boom clearance. However, 3/4" prop clearance was thoroughly tested before, during, and after my last flight north. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 10, 2013
Although this happened in a Drifter - the placement of the boom and propeller is similar enough that I'll share my own experience. Arty Trost Sandy, Oregon Arty T/Kolbers: Although the placement of the prop tip and tail boom on a Kolb, all models, is similar to a Maxair Drifter, that is where the similarity ends. If my recollection serves me correctly, the Drifter engine is mounted on a single square aluminum root tube that projects aft of any main fuselage down tubes for vertical support. Sitting here at my computer I can visualize that root tube deflecting downward during a hard landing. I once stalled my mkIII during takeoff from a very confined area at about 30 feet altitude with full flaps. I hit the ground so hard, in a level attitude, it wiped the main gear off the aircraft. After I finished crashing, I noticed two things. One, I was sitting much closer to the ground, and two, I could not find my glasses. Was wearing David Clark headset at the time. I hit the ground hard enough my glasses ended up in the nose pod. Despite the other damage, there was no prop strike. The prop was still turning when I hit the ground. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Dec 10, 2013
Tom, I used a finger width as my gauge for clearance on the same setup. If you need more clearance you can flop the motor mounts, depending on how you have them set, so that the long side is down on the front pair and up on the rear pair. The change in angle also helps the airplane trim up a bit easier, too and you don't have to buy any new hardware. Rick Girard On Tue, Dec 10, 2013 at 5:04 AM, tombaisley wrote: > > I have a MKIIIC w/ 582, installed a 66" two bladed prop mounted with a > 3.5" spacer. The clearance is .875", it looks awful close? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415303#415303 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Re: 582-99 water pump housing
Date: Dec 10, 2013
Good tip John, I'll check with Ronnie, Rotax thinks highly of their parts so we'll see what a used one goes for. If I do go with a pumas tic one, I would make sure ifs rated for the heat swings inherent in a cooling system. Was thinking of something from an automotive heater system. 1" lines. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Dec 10, 2013, at 9:50 AM, "John Hauck" wrote: > > > > > I can adapt a single inlet pump housing with a plastic tee in the line if I > have to, but the dual inlet will make a much cleaner looking installation. > Dennis "Skid" Rowe > Mk3, 690L-70, Leechburg, PA > > > > Dennis R/Kolbers: > > Had a nylon 1" hose barb fail on my well pump supply line recently. This > plastic fitting was under ground with nice cool water flowing through it. > > I would consider the cooling system critical on a 582. Failure of a fitting > would most likely put you down very quickly. > > Personally, I would go with aluminum pump housing. Check with Ronnie Smith, > South Mississippi Light Aircraft if you cannot find another source. He > probably has a used one. > > john h > mkIII > Titus, Alabama > > > > > > ________________________________________________________________________________
Date: Dec 10, 2013
Mike Oratex looks like a great product but it seems a little pricey for me. I lean to the frugal end of the scale using uncertified cloth and latex primer and paint. Even if it took 30 yds of material it would only cost around $300 for everything ($400 tops). I know it doesn't answer your question, but non-toxic food for thought! Malcolm Morrison ----- Original Message ----- From: "mike91911" <ko1m.mike(at)gmail.com> Sent: Monday, December 9, 2013 8:29:27 PM Subject: Kolb-List: How much fabric to cover a Mark IIIc? I'm researching the option of recovering my Mark IIIc in Oratex UL 600. How much fabric is required to cover a Mark IIIc? Better yet does anyone happen to have a list of what is required (fabric and tape). I haven't ruled out polyfiber but I'm a little dissapointed with the Kolb recommended supplier. (not why I'm considering Oratex) I contacted them on 3 separate occasions about ordering the kit to do the Mark IIIc and they never got back to me. This seems odd because I've heard nothing but good things about them and they were extremely nice when I talked to them but they just never followed up. The Oratex is about 71" wide and sold by the meter. I'm trying to figure out how many feet of 71" wide Oratex I need. I can then convert to meters. Kolb shows the Polyfiber kit as costing $1870 plus shipping and includes everything but the finish paint. How many gallons of finish paint (polytone) should I expect to use? Thanks, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415270#415270 ________________________________________________________________________________
Date: Dec 10, 2013
Denny, I have installed the radiator from the mid 80's Honda Magna motorcycle on two different 582 systems. They have the advantage of being A) cheap to buy and B) need no modifications to work. The last on a 582-99 performed a climb out to 6000 on a day when the temperature was 117F without ever getting to the red line on the temp gauge. The article I wrote about the installation is in the archives but if you cannot find it let me know and I can send you it to you. Ask your engine builder but you might want to consider the waterpump cover for the -90 rather than the -99. The later cover was designed with the PPC crowd in mind where the throttle is the elevator and the problem of flash cooling is endemic to them because of it. Rick Girard On Tue, Dec 10, 2013 at 10:59 AM, Dennis Rowe wrote: > > Good tip John, I'll check with Ronnie, Rotax thinks highly of their parts > so we'll see what a used one goes for. If I do go with a pumas tic one, I > would make sure ifs rated for the heat swings inherent in a cooling system. > Was thinking of something from an automotive heater system. 1" lines. > > Dennis "Skid" Rowe > Mk3, 690L-70, Leechburg, PA > > > > On Dec 10, 2013, at 9:50 AM, "John Hauck" wrote: > > > > > > > > > > I can adapt a single inlet pump housing with a plastic tee in the line > if I > > have to, but the dual inlet will make a much cleaner looking > installation. > > Dennis "Skid" Rowe > > Mk3, 690L-70, Leechburg, PA > > > > > > > > Dennis R/Kolbers: > > > > Had a nylon 1" hose barb fail on my well pump supply line recently. This > > plastic fitting was under ground with nice cool water flowing through it. > > > > I would consider the cooling system critical on a 582. Failure of a > fitting > > would most likely put you down very quickly. > > > > Personally, I would go with aluminum pump housing. Check with Ronnie > Smith, > > South Mississippi Light Aircraft if you cannot find another source. He > > probably has a used one. > > > > john h > > mkIII > > Titus, Alabama > > > > > > > > > > > > > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Dec 10, 2013
Thanks for the advice Richard, I'll look into that rad, right now I was plan ning on using a Honda TRX250R rad I have had for a while that looks to be id eally sized, but I will have to have larger spigots installed to fit the 1" r ad hoses of the Rotax. So I take it if you used the single inlet pump housing, you either blocked o ff one of the two water outlets in the head, or you installed a tee in the r eturn line to the pump? Or maybe you have the 582-90 single outlet head. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Dec 10, 2013, at 7:07 PM, Richard Girard wrote: > > Denny, I have installed the radiator from the mid 80's Honda Magna motorcy cle on two different 582 systems. They have the advantage of being A) cheap t o buy and B) need no modifications to work. The last on a 582-99 performed a climb out to 6000 on a day when the temperature was 117F without ever getti ng to the red line on the temp gauge. The article I wrote about the installa tion is in the archives but if you cannot find it let me know and I can send you it to you. > Ask your engine builder but you might want to consider the waterpump cover for the -90 rather than the -99. The later cover was designed with the PPC c rowd in mind where the throttle is the elevator and the problem of flash coo ling is endemic to them because of it. > > Rick Girard > > >> On Tue, Dec 10, 2013 at 10:59 AM, Dennis Rowe w rote: >> >> Good tip John, I'll check with Ronnie, Rotax thinks highly of their parts so we'll see what a used one goes for. If I do go with a pumas tic one, I w ould make sure ifs rated for the heat swings inherent in a cooling system. W as thinking of something from an automotive heater system. 1" lines. >> >> Dennis "Skid" Rowe >> Mk3, 690L-70, Leechburg, PA >> >> >> >> > On Dec 10, 2013, at 9:50 AM, "John Hauck" wrote: >> > >> > >> > >> > >> > I can adapt a single inlet pump housing with a plastic tee in the line i f I >> > have to, but the dual inlet will make a much cleaner looking installati on. >> > Dennis "Skid" Rowe >> > Mk3, 690L-70, Leechburg, PA >> > >> > >> > >> > Dennis R/Kolbers: >> > >> > Had a nylon 1" hose barb fail on my well pump supply line recently. Th is >> > plastic fitting was under ground with nice cool water flowing through i t. >> > >> > I would consider the cooling system critical on a 582. Failure of a fi tting >> > would most likely put you down very quickly. >> > >> > Personally, I would go with aluminum pump housing. Check with Ronnie S mith, >> > South Mississippi Light Aircraft if you cannot find another source. He >> > probably has a used one. >> > >> > john h >> > mkIII >> > Titus, Alabama >> > >> > >> > >> > >> > >> > >> >> >> ========== >> ="_blank">www.aeroelectric.com >> ooks.com" target="_blank">www.buildersbooks.com >> et="_blank">www.homebuilthelp.com >> et="_blank">www.mypilotstore.com >> "_blank">www.mrrace.com >> ="_blank">http://www.matronics.com/contribution >> le, List Admin. >> ========== >> arget="_blank">http://www.matronics.com/Navigator?Kolb-List >> ========== >> http://forums.matronics.com >> ========== > > > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhappy . > - Groucho Marx > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Dec 11, 2013
What are the dimensions of the TRX250R rad and hose inlets? thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415377#415377 ________________________________________________________________________________
Date: Dec 11, 2013
Dennis, My engine is a -90, the IIIX I worked on had the -99. I plumbed both as required. You're right about the -99, I had forgotten they have a dual spigot at the thermostat housing, too. Rick On Tue, Dec 10, 2013 at 10:21 PM, Dennis Rowe wrote: > Thanks for the advice Richard, I'll look into that rad, right now I was > planning on using a Honda TRX250R rad I have had for a while that looks to > be ideally sized, but I will have to have larger spigots installed to fit > the 1" rad hoses of the Rotax. > So I take it if you used the single inlet pump housing, you either blocked > off one of the two water outlets in the head, or you installed a tee in the > return line to the pump? > Or maybe you have the 582-90 single outlet head. > > > Dennis "Skid" Rowe > Mk3, 690L-70, Leechburg, PA > > > On Dec 10, 2013, at 7:07 PM, Richard Girard wrote: > > Denny, I have installed the radiator from the mid 80's Honda Magna > motorcycle on two different 582 systems. They have the advantage of being > A) cheap to buy and B) need no modifications to work. The last on a 582-99 > performed a climb out to 6000 on a day when the temperature was 117F > without ever getting to the red line on the temp gauge. The article I wrote > about the installation is in the archives but if you cannot find it let me > know and I can send you it to you. > Ask your engine builder but you might want to consider the waterpump cover > for the -90 rather than the -99. The later cover was designed with the PPC > crowd in mind where the throttle is the elevator and the problem of flash > cooling is endemic to them because of it. > > Rick Girard > > > On Tue, Dec 10, 2013 at 10:59 AM, Dennis Rowe wrote: > >> >> Good tip John, I'll check with Ronnie, Rotax thinks highly of their parts >> so we'll see what a used one goes for. If I do go with a pumas tic one, I >> would make sure ifs rated for the heat swings inherent in a cooling system. >> Was thinking of something from an automotive heater system. 1" lines. >> >> Dennis "Skid" Rowe >> Mk3, 690L-70, Leechburg, PA >> >> >> >> > On Dec 10, 2013, at 9:50 AM, "John Hauck" wrote: >> > >> > >> > >> > >> > I can adapt a single inlet pump housing with a plastic tee in the line >> if I >> > have to, but the dual inlet will make a much cleaner looking >> installation. >> > Dennis "Skid" Rowe >> > Mk3, 690L-70, Leechburg, PA >> > >> > >> > >> > Dennis R/Kolbers: >> > >> > Had a nylon 1" hose barb fail on my well pump supply line recently. >> This >> > plastic fitting was under ground with nice cool water flowing through >> it. >> > >> > I would consider the cooling system critical on a 582. Failure of a >> fitting >> > would most likely put you down very quickly. >> > >> > Personally, I would go with aluminum pump housing. Check with Ronnie >> Smith, >> > South Mississippi Light Aircraft if you cannot find another source. He >> > probably has a used one. >> > >> > john h >> > mkIII >> > Titus, Alabama >> > >> > >> > >> > >> > >> > >> >> >> ========== >> ="_blank">www.aeroelectric.com >> ooks.com" target="_blank">www.buildersbooks.com >> et="_blank">www.homebuilthelp.com >> et="_blank">www.mypilotstore.com >> "_blank">www.mrrace.com >> ="_blank">http://www.matronics.com/contribution >> le, List Admin. >> ========== >> arget="_blank">http://www.matronics.com/Navigator?Kolb-List >> ========== >> http://forums.matronics.com >> ========== >> >> >> >> > > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhappy. > - Groucho Marx > > * > > D============================================ > ot;">www.aeroelectric.com <http://www.aeroelectric.com> > books.com <http://books.com>"">www.buildersbooks.com > quot;">www.homebuilthelp.com <http://www.homebuilthelp.com> > quot;">www.mypilotstore.com <http://www.mypilotstore.com> > ">www.mrrace.com <http://www.mrrace.com> > ot;">http://www.matronics.com/contribution > D============================================ > List"">http://www.matronics.com/Navigator?Kolb-List > D============================================ > //forums.matronics.com <http://forums.matronics.com> > D============================================ > * > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Dec 11, 2013
Tom, The radiator is 13 3/4" wide, 9 1/2" tall and 1 5/8" thick. Has 3/4 inch fittings, and a cap. Hose fittings are located on the top left and bottom right corners, cap is on the top right. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Dec 11, 2013, at 7:44 AM, "tombaisley" wrote: > > > What are the dimensions of the TRX250R rad and hose inlets? > thanks > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415377#415377 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 11, 2013
I'm installing a 582 on a MKIIIc, I want to install the radiator below the gearbox aft of the fuselage, the Magna radiator is awkward because the inflow and out flow are on the wrong side when installed in the rear configuration, Surfing ebay I found a trx450 radiator, uses straight hose connections and is configured correctly but the the dimensions are 12x12.75"might be a bit large. The TRX250 sounds like the right size but the upper hose connection comes out at an odd angle? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415419#415419 ________________________________________________________________________________
Date: Dec 11, 2013
I take back my last post I found the 1988 trx250 use straight hose connections Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415420#415420 ________________________________________________________________________________
Date: Dec 11, 2013
Some of them come straight back, search eBay and you'll find some that come straight out. Or Bylers radiator in UT could probably change the spouts. If I use the the 250R rad on the 670 I'll have Bylers give it their full meal deal first. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Dec 11, 2013, at 8:16 PM, "tombaisley" wrote: > > > I'm installing a 582 on a MKIIIc, I want to install the radiator below the gearbox aft of the fuselage, the Magna radiator is awkward because the inflow and out flow are on the wrong side when installed in the rear configuration, Surfing ebay I found a trx450 radiator, uses straight hose connections and is configured correctly but the the dimensions are 12x12.75"might be a bit large. The TRX250 sounds like the right size but the upper hose connection comes out at an odd angle? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415419#415419 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 11, 2013
My bad, it's Mylers radiator repair, not Bylers. They do good work on aluminum rads only! Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Dec 11, 2013, at 8:32 PM, "tombaisley" wrote: > > > I take back my last post I found the 1988 trx250 use straight hose connections > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415420#415420 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 12, 2013
The poly fiber is a wonderful product to use but unbelievably high in price. They will also short you 15 feet in cloth so be prepared to have to buy more -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415487#415487 ________________________________________________________________________________
Date: Dec 13, 2013
Who are the "they" who short change buyers on fabric? I have dealt with The Millers and have always received prompt service and exactly what I ordered and for what I paid. In all honesty, if they and other providers know someone is just seeking information on amounts of fabric, etc. they probably do not respond as well as they would if a person is serious about purchasing their products. I can not speak for them or anyone but myself, but if my livelihood depended on selling fabric and certain products I would probably respond in a similar manner. They make their living in a very competitive market selling Poli-fiber products. I personally have tried to respect that fact with all the providers with which I deal. Poli-fiber seems costly but I have inspected and worked on other fabric covered planes and am convinced that Poli-fiber will last more than 15-20 years if applied correctly and it is definitely easy to apply, even for those working with fabric for the first time... like I was. Many years ago when I was buying an airplane from a friend I kept prodding him to come down on the price. He reminded me that he could not stay in business if he donated all his time and products, etc. I have nothing but respect for Jim and Dondi... if they are by chance the "they" mentioned. I do not mean to offend anyone and I know that even the greatest vendor drops the ball at some time or another, but they have never dropped it in my case. I had to order more fabric because of a mistake I made and I also used more materials because it was my first fabric job. Just my two cents worth... and it is free. Of course I have been told by some good friends that I don't have enough "cents" (sense) to be givining any away. :) Bob N830PB, MKIII Extra ________________________________________________________________________________
Date: Dec 13, 2013
I should have chimed in sooner on this. I have had the same experience as Bob with Jim and Dondi Miller. They are true class acts. I look forward to someday soon covering our 48 C-170's wings with products purchased from these fine folks at Aircraft Technical Support. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Dec 13, 2013, at 4:36 PM, Bob Green wrote: > > > > Who are the "they" who short change buyers on fabric? I have dealt with The Millers and have always received prompt service and exactly what I ordered and for what I paid. > In all honesty, if they and other providers know someone is just seeking information on amounts of fabric, etc. they probably do not respond as well as they would if a person is serious about purchasing their products. I can not speak for them or anyone but myself, but if my livelihood depended on selling fabric and certain products I would probably respond in a similar manner. They make their living in a very competitive market selling Poli-fiber products. I personally have tried to respect that fact with all the providers with which I deal. Poli-fiber seems costly but I have inspected and worked on other fabric covered planes and am convinced that Poli-fiber will last more than 15-20 years if applied correctly and it is definitely easy to apply, even for those working with fabric for the first time... like I was. > > Many years ago when I was buying an airplane from a friend I kept prodding him to come down on the price. He reminded me that he could not stay in business if he donated all his time and products, etc. > I have nothing but respect for Jim and Dondi... if they are by chance the "they" mentioned. I do not mean to offend anyone and I know that even the greatest vendor drops the ball at some time or another, but they have never dropped it in my case. > > I had to order more fabric because of a mistake I made and I also used more materials because it was my first fabric job. > Just my two cents worth... and it is free. Of course I have been told by some good friends that I don't have enough "cents" (sense) to be givining any away. :) > Bob > N830PB, > MKIII Extra > > > > ________________________________________________________________________________
Date: Dec 13, 2013
Poli-fiber seems costly but I have inspected and worked on other fabric covered planes and am convinced that Poli-fiber will last more than 15-20 years if applied correctly and it is definitely easy to apply, even for those working with fabric for the first time... like I was. I have nothing but respect for Jim and Dondi... if they are by chance the "they" mentioned. I do not mean to offend anyone and I know that even the greatest vendor drops the ball at some time or another, but they have never dropped it in my case. Bob N830PB, MKIII Extra Bob G/Kolbers: I covered my MKIII 23 years ago with Polyfiber. In 2000, after tearing up a wing aileron, and flap, during a crash at Muncho Lake, BC, Jim and Dondi Miller came to my rescue. They were at the Kolb Homecoming that year, as well as Homer and Clara Kolb. I shared my unsuccessful flight to Alaska with the group of Kolbers attending. At the end of my briefing, Jim Miller stood up and informed me that he and Dondi would provide me with all fabric, paint, and material to recover the wing, aileron, and flap, at no charge. And that also included shipping. I will never forget and will always be grateful for their extreme generosity. With their help, The New Kolb Aircraft, and a few others, I was successful in flying to Point Barrow, Alaska, the following year. I echo Bob Green's sentiments about Jim and Dondi. They have always gone out of their way to help all of their customers that I am aware of. And one thing for sure. You will always get a tremendous hug from Dondi. She is a exceptionally good hugger. By the way, the fabric on my right wing, aileron, flap, rudder, horizontal stabilizer, and fuselage are original 1991 fabric and paint. The left wing, aileron, flap and vertical stabilizer were covered and painted in 2000. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Change of plans, part 3
Date: Dec 13, 2013
Took the 670 core to my friend and Slingshot driver Dave Lewis's house for d isassembly of the top end. All went fine as frogs fuzz. Had some light scrat ches in one barrel dictating I have it over bored. Removed the oil injection pump as I've chosen go with premix for now. The cylinders and head are now a t my local machine shop waiting for the new pistons to arrive, and to get pa rticle blasted to look like new. The crank and crank case are waiting to be p roperly packaged for the trip to Naples Florida for reworking by Rotax Rick a nd to get the E gearbox and exhaust fitted. As that will be the major expens e of this project, wifey has appealed to me to put that on hold till the hol iday credit card Smackdown is paid off. In the meantime I have pretty much a cquired all the odds and ends I'll need to complete the project through some very successful eBay shopping. Just landed the power valves tonight. Life is good. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA
Subject: Re: Kolb-List Digest: 4 Msgs - 12/13/13
Date: Dec 14, 2013
Want to chime in here about poly fabric. Only time I had a problem was with the old aircraft spruce. They sent me the correct amount, just in three pieces! Apparently finishing rolls or something. Imagine my surprise when I unrolled the fabric onto the wing to cut only to find it in pieces. The sent me new fabric but the return order got lost in california. Took awhile but got it fixed. Was quite a mess on my credt card. Dodi always got it right. Be careful with the term "They". Ted cowan slingshot 912ul zoom zoom over 450 hrs and loving it! Sent from my iPhone On Dec 14, 2013, at 2:02 AM, Kolb-List Digest Server wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-12-13&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-12-13&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Fri 12/13/13: 4 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 01:37 PM - Re: Kolb-List Digest: (Bob Green) > 2. 02:35 PM - Re: Re: Kolb-List Digest: (Dennis Rowe) > 3. 02:51 PM - Re: Re: Kolb-List Digest: (John Hauck) > 4. 08:31 PM - Change of plans, part 3 (Dennis Rowe) > > > > ________________________________ Message 1 _____________________________________ > > > From: Bob Green <bgreen(at)bimi.org> > Subject: Kolb-List: RE: Kolb-List Digest: > > > > Who are the "they" who short change buyers on fabric? I have dealt with The Millers > and have always received prompt service and exactly what I ordered and > for what I paid. > In all honesty, if they and other providers know someone is just seeking information > on amounts of fabric, etc. they probably do not respond as well as they > would if a person is serious about purchasing their products. I can not speak > for them or anyone but myself, but if my livelihood depended on selling fabric > and certain products I would probably respond in a similar manner. They make > their living in a very competitive market selling Poli-fiber products. I > personally have tried to respect that fact with all the providers with which > I deal. Poli-fiber seems costly but I have inspected and worked on other fabric > covered planes and am convinced that Poli-fiber will last more than 15-20 > years if applied correctly and it is definitely easy to apply, even for those > working with fabric for the first time... like I was. > > Many years ago when I was buying an airplane from a friend I kept prodding him > to come down on the price. He reminded me that he could not stay in business > if he donated all his time and products, etc. > I have nothing but respect for Jim and Dondi... if they are by chance the "they" > mentioned. I do not mean to offend anyone and I know that even the greatest > vendor drops the ball at some time or another, but they have never dropped it > in my case. > > I had to order more fabric because of a mistake I made and I also used more materials > because it was my first fabric job. > Just my two cents worth... and it is free. Of course I have been told by some > good friends that I don't have enough "cents" (sense) to be givining any away. > :) > Bob > N830PB, > MKIII Extra > > > ________________________________ Message 2 _____________________________________ > > > Subject: Re: Kolb-List: RE: Kolb-List Digest: > From: Dennis Rowe <rowedenny(at)windstream.net> > > > I should have chimed in sooner on this. > I have had the same experience as Bob with Jim and Dondi Miller. They are true > class acts. > I look forward to someday soon covering our 48 C-170's wings with products purchased > from these fine folks at Aircraft Technical Support. > > Dennis "Skid" Rowe > Mk3, 690L-70, Leechburg, PA > > >> On Dec 13, 2013, at 4:36 PM, Bob Green wrote: >> >> >> >> Who are the "they" who short change buyers on fabric? I have dealt with The > Millers and have always received prompt service and exactly what I ordered and > for what I paid. >> In all honesty, if they and other providers know someone is just seeking information > on amounts of fabric, etc. they probably do not respond as well as they > would if a person is serious about purchasing their products. I can not speak > for them or anyone but myself, but if my livelihood depended on selling fabric > and certain products I would probably respond in a similar manner. They > make their living in a very competitive market selling Poli-fiber products. > I personally have tried to respect that fact with all the providers with which > I deal. Poli-fiber seems costly but I have inspected and worked on other fabric > covered planes and am convinced that Poli-fiber will last more than 15-20 > years if applied correctly and it is definitely easy to apply, even for those > working with fabric for the first time... like I was. >> >> Many years ago when I was buying an airplane from a friend I kept prodding him > to come down on the price. He reminded me that he could not stay in business > if he donated all his time and products, etc. >> I have nothing but respect for Jim and Dondi... if they are by chance the "they" > mentioned. I do not mean to offend anyone and I know that even the greatest > vendor drops the ball at some time or another, but they have never dropped > it in my case. >> >> I had to order more fabric because of a mistake I made and I also used more materials > because it was my first fabric job. >> Just my two cents worth... and it is free. Of course I have been told by some > good friends that I don't have enough "cents" (sense) to be givining any > away. :) >> Bob >> N830PB, >> MKIII Extra >> >> >> >> > > > ________________________________ Message 3 _____________________________________ > > > From: "John Hauck" <jhauck(at)elmore.rr.com> > Subject: RE: Kolb-List: RE: Kolb-List Digest: > > > > Poli-fiber seems costly but I have inspected and worked on other fabric > covered planes and am convinced that Poli-fiber will last more than 15-20 > years if applied correctly and it is definitely easy to apply, even for > those working with fabric for the first time... like I was. > > > I have nothing but respect for Jim and Dondi... if they are by chance the > "they" mentioned. I do not mean to offend anyone and I know that even the > greatest vendor drops the ball at some time or another, but they have never > dropped it in my case. > > Bob > N830PB, > MKIII Extra > > > Bob G/Kolbers: > > I covered my MKIII 23 years ago with Polyfiber. In 2000, after tearing up a > wing aileron, and flap, during a crash at Muncho Lake, BC, Jim and Dondi > Miller came to my rescue. They were at the Kolb Homecoming that year, as > well as Homer and Clara Kolb. I shared my unsuccessful flight to Alaska > with the group of Kolbers attending. At the end of my briefing, Jim Miller > stood up and informed me that he and Dondi would provide me with all fabric, > paint, and material to recover the wing, aileron, and flap, at no charge. > And that also included shipping. I will never forget and will always be > grateful for their extreme generosity. With their help, The New Kolb > Aircraft, and a few others, I was successful in flying to Point Barrow, > Alaska, the following year. > > I echo Bob Green's sentiments about Jim and Dondi. They have always gone > out of their way to help all of their customers that I am aware of. > > And one thing for sure. You will always get a tremendous hug from Dondi. > She is a exceptionally good hugger. > > By the way, the fabric on my right wing, aileron, flap, rudder, horizontal > stabilizer, and fuselage are original 1991 fabric and paint. The left wing, > aileron, flap and vertical stabilizer were covered and painted in 2000. > > john h > mkIII > Titus, Alabama > > > ________________________________ Message 4 _____________________________________ > > > Subject: Kolb-List: Change of plans, part 3 > From: Dennis Rowe <rowedenny(at)windstream.net> > > Took the 670 core to my friend and Slingshot driver Dave Lewis's house for d > isassembly of the top end. All went fine as frogs fuzz. Had some light scrat > ches in one barrel dictating I have it over bored. Removed the oil injection > pump as I've chosen go with premix for now. The cylinders and head are now a > t my local machine shop waiting for the new pistons to arrive, and to get pa > rticle blasted to look like new. The crank and crank case are waiting to be p > roperly packaged for the trip to Naples Florida for reworking by Rotax Rick a > nd to get the E gearbox and exhaust fitted. As that will be the major expens > e of this project, wifey has appealed to me to put that on hold till the hol > iday credit card Smackdown is paid off. In the meantime I have pretty much a > cquired all the odds and ends I'll need to complete the project through some > very successful eBay shopping. Just landed the power valves tonight. > Life is good. > > > Dennis "Skid" Rowe > > Mk3, 690L-70, Leechburg, PA > > >
Date: Dec 14, 2013
Jim and Dondi, at poly fiber are great people to deal with and wouldn.t buy from anyone else. I did come up 15' short on fabric and had to buy more. I was supper conservative on my cuts and wasted none but yet came up short. Brian. at Kolb said other and himself have seen this shortage of fabric before and his said I should say something about it in hopes to have this corrected. Please don't think that I am mad at the poly people as I am not, but thought all should know about this..... -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415561#415561 ________________________________________________________________________________
Date: Dec 14, 2013
all why use poly fiber at 8 to 13 bucks a yard...when peel ply in both weight's that we require are under 4 bucks? Aircraft spruce called it uncertified at one time...it is now called peel ply.... ever frugal Herb ________________________________________________________________________________
Date: Dec 14, 2013
Also would like to note that Aircraft Spruce ships gallons of poly products with no haz material charge... that could be expensive...Herb On 12/14/2013 02:14 PM, Herb wrote: > > all > > why use poly fiber at 8 to 13 bucks a yard...when peel ply in both > weight's that we require are under 4 bucks? Aircraft spruce called > it uncertified at one time...it is now called peel ply.... ever frugal > Herb > > ________________________________________________________________________________
Date: Dec 14, 2013
Thanks all. Bob ________________________________________________________________________________
Date: Dec 15, 2013
Subject: EAA proposal
Not sure if any of you are aware of this proposed legislation by the EAA, but it would make things a lot easier for a lot of the older pilots. Larry http://eaa.org/news/2013/2013-12-11_proposed-legislation-would-cut-third-class-medical-requirement-for-many-ga-pilots.asp -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Dec 15, 2013
Subject: Re: EAA proposal
On 12/15/2013 4:06 PM, Larry Cottrell wrote: > Not sure if any of you are aware of this proposed legislation by the > EAA, but it would make things a lot easier for a lot of the older pilots. > Larry > > http://eaa.org/news/2013/2013-12-11_proposed-legislation-would-cut-third-class-medical-requirement-for-many-ga-pilots.asp > > -- This is a *really* big deal. If you've never called your senators & reps in your life, do it now (in January, actually). I can testify from personal experience that a handful of persistent callers can swing a lawmaker's position from total ignorance of a bill to being a sponsor. Please, please, please make those calls next year. Call the current sponsors, even if they aren't from your state, and thank them. Call every rep and both senators from your state. This can happen, with just a handful of folks applying pressure. There is no downside for the lawmakers; no money to be spent. We can do this. Charlie ________________________________________________________________________________
Date: Dec 16, 2013
Subject: 2013 List of Contributors
Dear Listers, The 2013 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Andy, Bob, Corbin, George, and Jon for their generous support through the supply of many great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com Bob Nucklolls - AeroElectric - http://www.aeroelectric.com Corbin Glowacki - My Pilot Store - http://www.mypilotstore.com George Race - Race Consulting - http://www.mrrace.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com And finally, I'm proud to present The 2013 Fund Raiser List of Contributors: http://www.matronics.com/loc/2013.html Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Date: Dec 16, 2013
Just my 2 cents: I suspect that the bill in our dysfunctional congress has little chance of getting out of committee much less going to the floor for a vote. However, its mere proposal might spur the FAA into action on the EAA/AOPA proposal since the congressional proposal is usurping FAA territory. In fact, I suspect that those who wrote this proposal knew it would not pass but figured the FAA needed a kick in the butt to act on the EAA/AOPA proposal. I hope it works. -------- Thom Riddle Buffalo, NY (9G0) Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415724#415724 ________________________________________________________________________________
Subject: Tee wagon
Date: Dec 17, 2013
Thought this was a good view of my All terrain Kolb hauler. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA
Subject: Re: Tee wagon
Date: Dec 18, 2013
I like it, good job, thanks for the picture.... -------- Rick Lewis (VW Watercooled Engine) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415831#415831 ________________________________________________________________________________
Subject: Firefly/introduction
Date: Dec 18, 2013
Hello Everyone, My Firefly quick build kit arrived today. Partain Transportation delivered it from the factory. I must say, I don't think there was any way to get it here for less money and less hassle. The kit is excellent in workmanship and there is no way I could have done it as quickly or as well as the factory did. For me the quick build option is definitely the way to go. I would be most interested in hearing from other Firefly owners on any subject from the kit, covering, painting, or engine selection to flying characteristics. A little about me: I learned to fly in an Aeronca LB-65 Pre-War Chief as a teenager. I owned and flew a '63 Piper Cherokee 180 for a little over ten years and loved that airplane! Alas, it became too expensive to keep when my flying habits changed and cross country travel became a thing of the past. I flew the Chief for a few years, but life changes made that more difficult and the cost of owning a hanger and plane kept climbing, although my yearly logbook entries kept shrinking. I finally sold the Chief this spring and started looking for an ulta-light that I could keep and fly nearby. The hangar is gone too, so storage in a trailer was one of my prime requirements. Initially I was very intrigued by the BackYard Flyer. I contacted the company and was very excited to visit with them at Oshkosh, fully prepared to order one while there. I was greatly disappointed by the fact that they did not even bring a partially build unit to show off at Oshkosh. It seemed as though I was intruding on their family vacation by asking questions. I liked the design and the price, but wanted to see one fly and get a good firsthand look at the product. Delivery time was quoted at over a year and there were no versions near me to look at. I left my contact information with the company with promises to put me in touch with other owners so that I may find out more. I never heard a word from them. While walking the booths at Oshkosh, I found Kolb. I knew of them, but not about them. When I discovered they folded up, I got very interested. Visiting with Bryan and Travis was like a breath of fresh air, with a hint of used car salesman thrown in. But what the heck, that is their job. I found them to be friendly, and straight forward. I did not commit at Oshkosh, but thought about the Firefly all the way home and spent an entire day on the internet researching the plane and the company. I could not find any disparaging remarks AT ALL! I bit the bullet and ordered my kit. Kolb has been a delight to work with, and I expect to be in much closer contact with them as I get into the process of finishing the Firefly. Based on my experiences so far, I expect this is going to be fairly easy and lots of fun. I have no worries about getting support from the factory. I have not made an engine decision yet, but will be ordering the covering kit soon. I helped a friend cover and paint his Fisher Classic with Polyfiber products several years ago and was so impressed, I don't think I will use anything else. Anyone want to try and persuade me differently? Please let me hear from you. I am leaning towards the Hirth 2702 with a Warp Drive 3 blade, but again, I want to hear from others. One last note, I really liked the delivery service by Partain. I had not heard of them, but Travis at Kolb made all the arrangements. I could not have gotten the kit here by any other means for less $ and it was hassle free. I would definitely use them again. Thanks to Tony Partain and driver Michael! I have perused the forums and am hoping to start quite a lot of conversation about the Firefly. Thanks for your consideration. Stuart Harner Central North Dakota P.S. Anyone want a partially completed Loehle 5151 Kit? I certainly don't need it anymore, I have a FIREFLY!!! ________________________________________________________________________________
Date: Dec 18, 2013
Subject: Re: Firefly/introduction
It appears that all the experts are busy, so I will at least acknowledge that your question was seen at least by one. First congratulations on your smart choice. I believe that you will love the little bird. However unless there has been some serious changes with Hirth I would do a lot of checking before I committed to it. I have no solid evidence against them, other than the experiences of a couple of friends, which were not all that good. Good luck, Larry On Wed, Dec 18, 2013 at 6:27 PM, Stuart Harner wrote : > Hello Everyone, > > > My Firefly quick build kit arrived today. Partain Transportation > delivered it from the factory. I must say, I don=92t think there was any way > to get it here for less money and less hassle. The kit is excellent in > workmanship and there is no way I could have done it as quickly or as wel l > as the factory did. For me the quick build option is definitely the way to > go. > > > I would be most interested in hearing from other Firefly owners on any > subject from the kit, covering, painting, or engine selection to flying > characteristics. > > > A little about me: > > > I learned to fly in an Aeronca LB-65 Pre-War Chief as a teenager. I owne d > and flew a =9263 Piper Cherokee 180 for a little over ten years and loved > that airplane! Alas, it became too expensive to keep when my flying habi ts > changed and cross country travel became a thing of the past. I flew the > Chief for a few years, but life changes made that more difficult and the > cost of owning a hanger and plane kept climbing, although my yearly logbo ok > entries kept shrinking. I finally sold the Chief this spring and started > looking for an ulta-light that I could keep and fly nearby. The hangar i s > gone too, so storage in a trailer was one of my prime requirements. > > > Initially I was very intrigued by the BackYard Flyer. I contacted the > company and was very excited to visit with them at Oshkosh, fully prepare d > to order one while there. I was greatly disappointed by the fact that th ey > did not even bring a partially build unit to show off at Oshkosh. It > seemed as though I was intruding on their family vacation by asking > questions. I liked the design and the price, but wanted to see one fly a nd > get a good firsthand look at the product. Delivery time was quoted at ov er > a year and there were no versions near me to look at. I left my contact > information with the company with promises to put me in touch with other > owners so that I may find out more. I never heard a word from them. >
October 27, 2013 - December 19, 2013
Kolb-Archive.digest.vol-mq
