Kolb-Archive.digest.vol-mu
June 29, 2014 - August 18, 2014
      With your particular installation, engine current demand, and typical
      flight duration, it may not be a factor at all. For bigger homebuilts
      that typically fly longer missions, it can be a big issue. In any case,
      I'd want to know whether my engine will quit 10 minutes or 2 hours after
      the alternator stops making energy.
      On 6/28/2014 9:56 AM, Rick Neilsen wrote:
      > Charlie
      > Lithium batteries have been used in cell phones, and laptop computers
      > for years and ARE known for their large total capacity. We are now
      > seeing them in cordless drills because people want light long lasting
      > power. I understand the drill market is driving lithium development at
      > a much faster pace than expected. My lead acid battery was a 12 AMPH
      > it would just barely start the engine and if it got below 50 degrees F
      > it wouldn't without a jump from my external charger. When I installed
      > the new lithium battery I turned off the master fuel valve and cranked
      > five times for 5-10 seconds with a cool down with no change in
      > cranking speed. My old lead acid battery would drop off near the end
      > of the second crank. When I first got the lithium battery I was
      > convinced they forgot to put the guts in the battery case it is that
      > light.
      > Yes my ignition system is electrically dependent. Luckily I have a
      > alternator that is bolted to the flywheel so as long as the engine is
      > turning it will produce current. It does have a external regulator
      > which could fail but so far it has been much more reliable than my
      > fuel pumps. Even though the external regulator hadn't really failed it
      > is now new as is most of the electrical system along with extra ground
      > wires, switches, fuel pumps, fuel filters, and a host of other things
      > that I fixed looking for my electrical issue.
      > Also my empty weight was 598lbs with the new battery and lighter
      > redrive it is 587lbs.
      > Rick Neilsen
      > Redrive VW Powered MKIIIC
      > On Fri, Jun 27, 2014 at 10:01 PM, Charlie England
      > > wrote:
      >     On 6/27/2014 5:48 PM, Rick Neilsen wrote:
      >>     It is finally Fixed.
      >>     Thanks for everyone's input on the issue I was having with my VW
      >>     powered Kolb MKIIIC. You may not remember but I had a ammeter
      >>     that started fluttering from -20 amps to + 20 amps. Turns out it
      >>     was the primary fuel pump. Since it just started doing it after
      >>     12 years it was likely it was in short failure mode.
      >>     About seven years ago I replaced the Faucet back up fuel pump
      >>     when it stopped without warning but it was just a back up pump so
      >>     no big deal.
      >>     The new replacement pump is a Carter automotive inline pump. This
      >>     pump doesn't allow fuel to pass through it when turned off so I
      >>     had to re plumb my fuel system to put the pumps in parallel with
      >>     a check valve on the Faucet pump.
      >>     Any way it is fixed. Now I need to go back and undo some of the
      >>     changes I did to track down the problem.
      >>     In the process I also changed the battery to one of the new
      >>     Lithium batteries like Aircraft Spruce sells  called AeroVoltz it
      >>     is a 15 AMP battery and I usually use a cheap 12 AMP lawn mower
      >>     battery. Any way the battery is more than 10 lb less and boy does
      >>     it spin the starter.
      >>     Rick Neilsen
      >     Hi Rick,
      >     I've forgotten; is your VW 'electrically dependent'? If so, have
      >     you verified how long the lithium can keep it running if you lose
      >     the alternator? I ask, because many of the lithium starting
      >     batteries have tons of starting power, but very limited total
      >     energy. There's a big discussion among bigger homebuilt guys right
      >     now about how to determine total capacity. Bob Nuckolls recently
      >     wrote a good article about the issue in Kitplanes.
      >     FWIW,
      >     Charlie
Date: Jun 29, 2014
Subject: Re: Electrical Issue With My VW Powered MKIIIC
Chairly You have hijacked the point of my post. If you want to debate lithium on your own thread be my guest. I have a fixed airplane and I'm happy with it. Rick Neilsen 1st Redrive VW powered MKIIIC On Sat, Jun 28, 2014 at 10:34 PM, Charlie England wrote: > I understand all the points you make, but the batteries in cell phones, > drills, etc are sized specifically for those applications. On the other > hand, most, if not all of the current crop of lithium batteries being > offered for starting duties are sized based on their ability to dump > tremendous current in a short period of time. That ability does not address > the *total energy* available in the battery. There's a difference between > available power, and available energy. > > Consider a hypothetical Corvette with a 450 hp engine and a 5 gallon fuel > tank of fuel, vs a long range econobox with a 100 hp engine and a 20 gallon > tank of fuel. The Corvette has over 4 times the power, but the econobox has > 4 times the energy available. > > The watercraft, motorcycles, etc using the new lithium starting batteries > are getting batteries sized like the Corvette with big motor & small tank > of gas. > > My question was, have you checked the energy capacity of your new lithium > starting battery to be sure that it can keep your engine/fuel pumps, etc > running long enough to find a safe landing spot if the alternator or > regulator fails. > > With your particular installation, engine current demand, and typical > flight duration, it may not be a factor at all. For bigger homebuilts that > typically fly longer missions, it can be a big issue. In any case, I'd want > to know whether my engine will quit 10 minutes or 2 hours after the > alternator stops making energy. > > Charlie > > > On 6/28/2014 9:56 AM, Rick Neilsen wrote: > > Charlie > > Lithium batteries have been used in cell phones, and laptop computers > for years and ARE known for their large total capacity. We are now seeing > them in cordless drills because people want light long lasting power. I > understand the drill market is driving lithium development at a much faster > pace than expected. My lead acid battery was a 12 AMPH it would just barely > start the engine and if it got below 50 degrees F it wouldn't without a > jump from my external charger. When I installed the new lithium battery I > turned off the master fuel valve and cranked five times for 5-10 seconds > with a cool down with no change in cranking speed. My old lead acid battery > would drop off near the end of the second crank. When I first got the > lithium battery I was convinced they forgot to put the guts in the battery > case it is that light. > > Yes my ignition system is electrically dependent. Luckily I have a > alternator that is bolted to the flywheel so as long as the engine is > turning it will produce current. It does have a external regulator which > could fail but so far it has been much more reliable than my fuel pumps. > Even though the external regulator hadn't really failed it is now new as is > most of the electrical system along with extra ground wires, switches, fuel > pumps, fuel filters, and a host of other things that I fixed looking for my > electrical issue. > > Also my empty weight was 598lbs with the new battery and lighter redrive > it is 587lbs. > > Rick Neilsen > Redrive VW Powered MKIIIC > > > On Fri, Jun 27, 2014 at 10:01 PM, Charlie England > wrote: > >> On 6/27/2014 5:48 PM, Rick Neilsen wrote: >> >> It is finally Fixed. >> >> Thanks for everyone's input on the issue I was having with my VW powered >> Kolb MKIIIC. You may not remember but I had a ammeter that started >> fluttering from -20 amps to + 20 amps. Turns out it was the primary fuel >> pump. Since it just started doing it after 12 years it was likely it was in >> short failure mode. >> >> About seven years ago I replaced the Faucet back up fuel pump when it >> stopped without warning but it was just a back up pump so no big deal. >> >> The new replacement pump is a Carter automotive inline pump. This pump >> doesn't allow fuel to pass through it when turned off so I had to re plumb >> my fuel system to put the pumps in parallel with a check valve on the >> Faucet pump. >> >> Any way it is fixed. Now I need to go back and undo some of the changes >> I did to track down the problem. >> >> In the process I also changed the battery to one of the new Lithium batteries >> like Aircraft Spruce sells called AeroVoltz it is a 15 AMP battery and I >> usually use a cheap 12 AMP lawn mower battery. Any way the battery is more >> than 10 lb less and boy does it spin the starter. >> >> Rick Neilsen >> Redrive VW Powered MKIIIC >> >> Hi Rick, >> >> I've forgotten; is your VW 'electrically dependent'? If so, have you >> verified how long the lithium can keep it running if you lose the >> alternator? I ask, because many of the lithium starting batteries have tons >> of starting power, but very limited total energy. There's a big discussion >> among bigger homebuilt guys right now about how to determine total >> capacity. Bob Nuckolls recently wrote a good article about the issue in >> Kitplanes. >> >> FWIW, >> >> Charlie >> > > * > > > * > > ________________________________________________________________________________
Date: Jun 29, 2014
Subject: new subject...Nexus 7 moving map software
A bud bought a Nexus 7 to install "free Moving map Aviation software ".. I met a guy at a flyin who was using such... I had the name of the software but cannot locate it..using the usual search engines... anyone using a Nexus 7? anyone know of free(non Garmin) software? Herb ________________________________________________________________________________
Date: Jun 29, 2014
Subject: Re: new subject...Nexus 7 moving map software
On 6/29/2014 8:44 AM, Herb wrote: > > A bud bought a Nexus 7 to install "free Moving map Aviation software > ".. I met a guy at a flyin who was using such... I had the name of > the software but cannot locate it..using the usual search engines... > > anyone using a Nexus 7? anyone know of free(non Garmin) software? > Herb > I've got this one on my 1st gen nexus: https://play.google.com/store/apps/details?id=com.ds.avare&hl=en I've only done a few xc flights with it, but it seems to work fine. Charlie ________________________________________________________________________________
Date: Jun 29, 2014
Hi Rick, It was not my intention to offend you, or hijack your thread. It was simply to ask if you'd considered one possible downside to your battery change. Sometimes changes can have unintended consequences. I've had it happen to me, and I suspect that it's happened to almost everyone, especially those who dabble in experimental aviation. Please accept my apologies, and I'll try to refrain from offending you in the future. Charlie On 6/28/2014 11:49 PM, Rick Neilsen wrote: > Chairly > > You have hijacked the point of my post. If you want to debate lithium > on your own thread be my guest. > > I have a fixed airplane and I'm happy with it. > > Rick Neilsen > 1st Redrive VW powered MKIIIC > > > On Sat, Jun 28, 2014 at 10:34 PM, Charlie England > > wrote: > > I understand all the points you make, but the batteries in cell > phones, drills, etc are sized specifically for those applications. > On the other hand, most, if not all of the current crop of lithium > batteries being offered for starting duties are sized based on > their ability to dump tremendous current in a short period of > time. That ability does not address the *total energy* available > in the battery. There's a difference between available power, and > available energy. > > Consider a hypothetical Corvette with a 450 hp engine and a 5 > gallon fuel tank of fuel, vs a long range econobox with a 100 hp > engine and a 20 gallon tank of fuel. The Corvette has over 4 times > the power, but the econobox has 4 times the energy available. > > The watercraft, motorcycles, etc using the new lithium starting > batteries are getting batteries sized like the Corvette with big > motor & small tank of gas. > > My question was, have you checked the energy capacity of your new > lithium starting battery to be sure that it can keep your > engine/fuel pumps, etc running long enough to find a safe landing > spot if the alternator or regulator fails. > > With your particular installation, engine current demand, and > typical flight duration, it may not be a factor at all. For bigger > homebuilts that typically fly longer missions, it can be a big > issue. In any case, I'd want to know whether my engine will quit > 10 minutes or 2 hours after the alternator stops making energy. > > Charlie > > > On 6/28/2014 9:56 AM, Rick Neilsen wrote: >> Charlie >> >> Lithium batteries have been used in cell phones, and laptop >> computers for years and ARE known for their large total capacity. >> We are now seeing them in cordless drills because people want >> light long lasting power. I understand the drill market is >> driving lithium development at a much faster pace than expected. >> My lead acid battery was a 12 AMPH it would just barely start the >> engine and if it got below 50 degrees F it wouldn't without a >> jump from my external charger. When I installed the new lithium >> battery I turned off the master fuel valve and cranked five times >> for 5-10 seconds with a cool down with no change in cranking >> speed. My old lead acid battery would drop off near the end of >> the second crank. When I first got the lithium battery I was >> convinced they forgot to put the guts in the battery case it is >> that light. >> >> Yes my ignition system is electrically dependent. Luckily I have >> a alternator that is bolted to the flywheel so as long as the >> engine is turning it will produce current. It does have a >> external regulator which could fail but so far it has been much >> more reliable than my fuel pumps. Even though the external >> regulator hadn't really failed it is now new as is most of the >> electrical system along with extra ground wires, switches, fuel >> pumps, fuel filters, and a host of other things that I fixed >> looking for my electrical issue. >> >> Also my empty weight was 598lbs with the new battery and lighter >> redrive it is 587lbs. >> >> Rick Neilsen >> Redrive VW Powered MKIIIC >> >> >> >> >> On Fri, Jun 27, 2014 at 10:01 PM, Charlie England >> > wrote: >> >> On 6/27/2014 5:48 PM, Rick Neilsen wrote: >>> It is finally Fixed. >>> >>> Thanks for everyone's input on the issue I was having with >>> my VW powered Kolb MKIIIC. You may not remember but I had a >>> ammeter that started fluttering from -20 amps to + 20 amps. >>> Turns out it was the primary fuel pump. Since it just >>> started doing it after 12 years it was likely it was in >>> short failure mode. >>> >>> About seven years ago I replaced the Faucet back up fuel >>> pump when it stopped without warning but it was just a back >>> up pump so no big deal. >>> >>> The new replacement pump is a Carter automotive inline pump. >>> This pump doesn't allow fuel to pass through it when turned >>> off so I had to re plumb my fuel system to put the pumps in >>> parallel with a check valve on the Faucet pump. >>> >>> Any way it is fixed. Now I need to go back and undo some of >>> the changes I did to track down the problem. >>> >>> In the process I also changed the battery to one of the new >>> Lithium batteries like Aircraft Spruce sells called >>> AeroVoltz it is a 15 AMP battery and I usually use a cheap >>> 12 AMP lawn mower battery. Any way the battery is more than >>> 10 lb less and boy does it spin the starter. >>> >>> Rick Neilsen >>> Redrive VW Powered MKIIIC >>> >> Hi Rick, >> >> I've forgotten; is your VW 'electrically dependent'? If so, >> have you verified how long the lithium can keep it running if >> you lose the alternator? I ask, because many of the lithium >> starting batteries have tons of starting power, but very >> limited total energy. There's a big discussion among bigger >> homebuilt guys right now about how to determine total >> capacity. Bob Nuckolls recently wrote a good article about >> the issue in Kitplanes. >> >> FWIW, >> >> Charlie >> > ________________________________________________________________________________
Date: Jun 29, 2014
Yep...that is the app that I was thinking about...I just found the business card that I had written it on..at the flyin... I think it was separate from Google a year or two ago... Herb >> >> A bud bought a Nexus 7 to install "free Moving map Aviation >> software ".. I met a guy at a flyin who was using such... I had the >> name of the software but cannot locate it..using the usual search >> engines... >> >> anyone using a Nexus 7? anyone know of free(non Garmin) software? >> Herb >> > I've got this one on my 1st gen nexus: > https://play.google.com/store/apps/details?id=com.ds.avare&hl=en > > I've only done a few xc flights with it, but it seems to work fine. > > Charlie > > _ ________________________________________________________________________________
Subject: Re: New video program
Date: Jun 30, 2014
Looks like you've found the right combination. Smooth and sharp video and gr eat stills. Always enjoy seeing your work. g. Aman Sent from my iPhone > On Jun 28, 2014, at 2:23 PM, Larry Cottrell wrot e: > > I have been having trouble with my copy of "Movie Maker" that came with my computer. It had been cropping my videos down from full screen. So much so t hat I decided to purchase a video program. ( drastic step there ) After look ing on the internet I found a program called "Cyberllink power director." It was reputed to rate a 10 for ease of use. I will not go into all the crap t hat I had to suffer through just to download it on my computer. Lets just sa y that it took better than two days just to get in on the computer. I was su re that I had made a mistake, but they already had my card info, so making t he best of it was the only option. > > Perhaps I am just a dummy, or the guy's that rated it easy had already bee n through much harder learning curves than I am willing to go through. Of co urse the manual is on line, and about 200 pages long. That in its self gives you an idea of the problem. The damn thing does too much. I merely want to c ut out the boring parts of the flights, add some narration and music. I real ly don't want to be famous, I don't want world acclaim, just a simple video o f high quality that I can share with a select number of people that share my interest. Apparently I am close to one of a kind. That feature is tough to f ind in this program. > > So far it has taken me two and half days to produce and upload to vimeo a 2 min 30 second video. I think a lot of my problems stem from me wanting to k eep it private. > > I have for some time realized the handicap of a full enclosure when it com es to pictures and videos. While the brain compensates for the distortion of Lexan, the camera does not. I put a short wind screen on the Kolb and found that it dropped my speed by about 7 MPH. No way, much too impatient for tha t. I have a wrap around "full enclosure" from Kolb that is scratched from us e on the right side where I got in and out. I decided to cut a window where I would normally look, for the lens of my camera. I bent a couple of pieces o f Lexan to form a wind deflector. It works fine. I got my speed back, the wi nd doesn't hit me and I can now see, even if there isn't a camera stuck thro ugh it. > > To test it out, I decided to try an early morning flight, just as the sun c ame up, to the Pillars of Rome. I have a lot of pictures of them, but nothin g really good. I got up before dawn, but there was a storm front blowing in a nd the sun wasn't showing through. Finally later in the morning the clouds b roke enough that I thought that area may possibly be in the clear. I wanted t o test the port hole any way. I am very pleased with the result. I will be a ble to continue to use the enclosure and not have to replace it after all. > > The video taken also gave me a chance to try out the new editing program. H ere is the result. > > https://vimeo.com/99418916 password- owyheeflyer > > Larry > > -- > If you forward this email, or any part of it, please remove my email addre ss before sending. > ________________________________________________________________________________
Subject: Kolb Mk iii / Geo 1.3 engine
Date: Jun 30, 2014
I'd like to converse with anyone building a mark iii or using a geo 1.3 engine. I'd also like to meet any of these builders who are in the north texas area. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425814#425814 ________________________________________________________________________________
Date: Jul 01, 2014
Subject: Lithium Batteries
We had a discussion last year about these batteries. As time goes on we are getting more experience with them so please share your experience in your airplane. Some basic facts about these batteries are they are much lighter, smaller and currently more expensive than equivalent lead acid batteries. They need to be charged with a special balance charger at least infrequently to achieve a long life. Battery manufactures rate their batteries with two terms, amperage hours (ah) and cold cranking amps (cca). I'm not sure these terms exactly equate to lithium batteries but this is all we get. AH is the total energy in the battery, CCA is the short time cold starting power or in third grade analogy a big engine with a small fuel tank. With many products there are some that may over state the performance/values of their products. Impressions about Lithium batteries are that they are, voltage and temperature sensitive. The Lithium batteries that are being sold as lead acid replacements like mine are described as Lithium Iron Phosphate. The claim is Lithium Iron Phosphate batteries don't catch on fire and don't do other bad things??? I have very limited experience. My new Aerovoltz lithium iron phosphate battery is rated at 15ah, 275cca, weighing 1.8lbs it cost $180 including shipping. My old lead acid batteries were all 12ah with app 185cca weighing 12lbs. When I installed the new lithium battery I did the recommended top off charge then turned off the master fuel valve and cranked five times for 5-10 seconds with a cool down (for the starter) with no change in cranking speed or voltage. My old 12ah lead acid battery would drop off near the end of the second crank. When I first got the lithium battery I was convinced they forgot to put the guts in the battery case, it is that light. I always kept a battery maintainer on my old lead acid battery because it was so low in power and they do self discharge. With the tested power of the lithium battery I will not be using the battery maintainer. I also don't know if the maintainer is ok with lithium batteries. The manual with my Lithium battery states that there is less than a 10% discharge per year. Also I stated from memory that my plane weighs 587lbs empty, well opps that was before the battery change and redrive upgrade. It now weighs 576lbs. Redoing my weight and balance calculations Please share your facts and label you "impressions" as such. Also if you are debating with someone please read the others responses. Rick Neilsen 1st Redrive VW Powered MKIIIC ________________________________________________________________________________
Subject: Re: Lithium Batteries
Date: Jul 01, 2014
I converted my motorcycle to lithium and figured out the hard way. I used to be able to go 3 weeks between rides and my battery would be fine. With lithium I can't go 4 days without putting it on a charger. I think you'll find that they do NOT rate their batteries in AH like they should. They usually use LEAD-equivalent AH rating. So perhaps they have a 5AH lithium and that cranks the engine like a 15AH lead acid would they can call that 15AH Equivalent. Very misleading when you are trying to figure out how long your battery will run your load when the engine stops. If you find one rated in real Amp-hours then you're good to go. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425869#425869 ________________________________________________________________________________
Date: Jul 01, 2014
I have one in my Honda 1800VTX motorcycle and it started up no problem after sitting all winter, not sure why yours discharged in 4 days? -------- Gerry Uebbing Firestar II 503 b-box (not flying yet) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425872#425872 ________________________________________________________________________________
Date: Jul 01, 2014
That I'm not so sure about either. There is definitely a constant draw on this bike for some reason. A BMW f650gs, fuel injected with a clock. I don't know what sucks the juice down. Not really the battery's fault but those AH are really are important to me. Maybe I just have a defective battery. All I'm saying is to be mindful of AH and pbeq AH. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425883#425883 ________________________________________________________________________________
Subject: Short Field Landings
Date: Jul 01, 2014
Went out this morning and practiced landing a bit. I setup a camera to see what it looked like from the ground side of things. There was basically no wind at ground level and I placed the camera 400 feet from the threshold of the runway. I seldom actually hit the threshold because there are power lines on that end and they make me nervous. On all the landings power was set at idle on the downwind and not touched until I was on the ground. All these were made with full flaps. I'm sharing this not because I think I'm particularly good at it as you can see, but because it was fun to do. Hopefully you won't find it too boring. https://docs.google.com/file/d/0BxdXwdWJkFExd2hiWE9fRDRjaXc/edit Thanks, Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425895#425895 ________________________________________________________________________________
Date: Jul 02, 2014
Subject: New video
I have been fooling with the exposure of my Drift camera. I have been unhappy at the quality, which to me didn't seem as good as it could have been. I finally decided to change the exposure of the camera. These two videos are shot with the lens stopped down 2 F stops, and it is better, but the video still seems to be a bit overexposed. Since two F stops are all that is available, I will have to be satisfied with that. The sun can be a bit bright here and the terrain is a bit dull with little contrast sometimes. I did a video of the same area last year, but I flew up the canyon then, and had some problems with raising terrain. This time I decided to start at the top. I also had a camera that only shot in 480, and I wanted to try the change in lens aperture to see if the definition was better. https://vimeo.com/99607014 Is the first video. It is long enough that I cut it into two parts https://vimeo.com/99607015 This is the second part. Password as always is - owyheeflyer I had looked forward to being able to take some stills through my camera port, and did get a few before my camera battery went dead. Sigh! High winds were forecast for the area later in the morning, but I felt that I could squeeze the flight in before they arrived. By the time of the opening scenes of the first video they were picking up quite a bit, and I was glad to drop down into the canyon where I would be sheltered from most of the wind. When I came out of the canyon the wind was coming up pretty good, and I finally had to drop down to the Sage where the friction slowed the wind enough that I make some headway towards home. My GPS was showing a ground speed of 39 MPH at 1000 feet agl. I like the quality of the recorded video much better, but I am still behind the curve. You might notice a bit of a glitch on the "credit" screen of Part two. The little Firestar handled the winds and the terrain quite well. Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 02, 2014
Hmmm. Possibly there is a button cell in there. Time to crack open the owner's manual. Maybe I should just ride it more! Nothing I like more than to ride to the airport and go flying. Good times. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425907#425907 Attachments: http://forums.matronics.com//files/bikeplane_163.jpg ________________________________________________________________________________
Date: Jul 02, 2014
I got my lithium battery a little over a year ago and it's been turning over my 912 very well for all that time. I have had times during the winter and during carburetor tuning when I have had to spin it quite a bit and so far it hasn't failed to to do well. It has also gone through several weeks of not being used and still seems to hold a full charge. I'm not sure how it would do in really cold weather. This information may not be helpful regarding providing ignition for long periods but there do seem to be several types of lithium batteries. Some designed for starting and others for deep cycle for use in powering electric cars and the like. My specs: Weight: 1106 grams (2.44 lb) Voltage (Charged): 13.6V Amperage: 20 Pb-eq A/H Pulse Cranking Amps: 410 CCA Thanks, Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425915#425915 ________________________________________________________________________________
Date: Jul 02, 2014
I really love the tours you take us through there in your area of the country. Beautiful, and and there is just nothing like seeing it from the air like that although a lot of it just begs to be hiked, fished and camped. Thanks much for this and all your videos. Enjoyed it a bunch. Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425916#425916 ________________________________________________________________________________
Subject: Re: Short Field Landings
Date: Jul 02, 2014
I've used a number of editing software packages looking for one that is relatively easy to use and still has the features I want. I'm currently using Pinnacle Studio 17 largely because I had a friend who let me see his training video and I have come to like it pretty well but with these things I think it's mainly what you get used to. I tried Corel Video Studio, CyberLink PowerDirector, Avidemux and a few others. I think the Corel was probably the easiest but all of them seem to have strong and weak areas so when I actually purchased one I just chose one with the features I wanted and determined to spend the time to learn it. It's still a struggle because I don't use it often enough to stay up on everything. They all seem to take time to do a decent job and I'm still way back on that curve. Thanks, Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425918#425918 ________________________________________________________________________________
Date: Jul 02, 2014
I liked your video, and thought that the instruments being visible when you were doing the landings was nice. For that particular video especially. With my intended applications, it wouldn't work. I guess what I liked about both your software and mine is the ability to record it in MPEG 4, which seems to be the sharpest format. Perhaps you can do some more videos soon. :-) Larry On Wed, Jul 2, 2014 at 8:24 AM, Larlaeb wrote: > > I've used a number of editing software packages looking for one that is > relatively easy to use and still has the features I want. I'm currently > using Pinnacle Studio 17 largely because I had a friend who let me see his > training video and I have come to like it pretty well but with these things > I think it's mainly what you get used to. I tried Corel Video Studio, > CyberLink PowerDirector, Avidemux and a few others. I think the Corel was > probably the easiest but all of them seem to have strong and weak areas so > when I actually purchased one I just chose one with the features I wanted > and determined to spend the time to learn it. It's still a struggle > because I don't use it often enough to stay up on everything. They all > seem to take time to do a decent job and I'm still way back on that curve. > > Thanks, > Allan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425918#425918 > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 02, 2014
The GPS info is just an included file that is combined using the camera software prior to any other editing if desired. I actually think that for what I was trying to do that just a view of the flight instruments would have been more helpful but this looks cool.. lol. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425923#425923 ________________________________________________________________________________
Date: Jul 02, 2014
On 7/1/2014 9:38 PM, Larlaeb wrote: > > Went out this morning and practiced landing a bit. I setup a camera to see what it looked like from the ground side of things. There was basically no wind at ground level and I placed the camera 400 feet from the threshold of the runway. I seldom actually hit the threshold because there are power lines on that end and they make me nervous. On all the landings power was set at idle on the downwind and not touched until I was on the ground. All these were made with full flaps. I'm sharing this not because I think I'm particularly good at it as you can see, but because it was fun to do. Hopefully you won't find it too boring. > > https://docs.google.com/file/d/0BxdXwdWJkFExd2hiWE9fRDRjaXc/edit > > > Thanks, > Allan > Love the format. Seeing the cockpit view, flight data, and the ground perspective at the same time is really nice. On the subject of power lines, have you thought about contacting the power company to have their 'orange balls' added to the lines? They will probably try to charge you, but one of the original members of my airpark pitched it this way: when they asked for payment, he pointed out that the power company owned the lines, and if someone couldn't see them & it caused a crash, the power company would be liable. They installed the balls for free. Charlie ________________________________________________________________________________
Date: Jul 02, 2014
Yes that has been discussed with the field management and I have made that suggestion myself. The portion of the field that I was landing on is not actually owned by the airport but is an extension which is privately owned. Typically I land on the 'actual' strip which is another 5 or 6 hundred feet further on. I think the balls would be a great thing to have in any case especially for folks trying to land there who aren't familiar with the place. Thanks, Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425926#425926 ________________________________________________________________________________
Subject: videos
Date: Jul 02, 2014
with my last trip up to Larry=99s home,, the rock house,,, I picked up Larry's old tachyon micro hd camera...( don=99t tell him,,, we w ill keep it our secret). on my first video to the Alvord Larry helped me set it up,,, I used Larry's old camera mount, on his plane he mounted it on his right wing strut,,,, I kind of bent it around a bit and mounted it on my left wing strut... it ended up a bit out of level.... when I go t home I made a new camera mount and I am giving it a go. on my first vide o with the new mount is still a bit out of level... sorry I am working on in. my first video is a flight to the Alvord from Larry=99s home. http s://vimeo.com/98587855 and the second is a flight up the Bear river. https://vimeo.com/9974832 1 the password for both is beekeeper hope this all works. boyd y --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Date: Jul 02, 2014
Subject: Re: videos
I liked it Boyd. It is nice to see other parts of the country where other people are flying. The camera seems to do better than I had remembered, but then again, If your terrain is bland, then there is a good chance your pictures might be as well. Yours has some better definition to it than mine. Not much green where I fly. I see that your video was produced with a reduced screen size to it as mine was before I changed video programs. Movie make wasn't that way until just recently, and that was the reason that I bought another program. Perhaps there is a tweak that will make it full screen. If you use "lithium" batteries it will record for about 5 or 6 hours. Larry On Wed, Jul 2, 2014 at 12:09 PM, b young wrote: > with my last trip up to Larry=99s home,, the rock house,,, I pi cked up > Larry's old tachyon micro hd camera...( don=99t tell him,,, we wil l keep it > our secret). on my first video to the Alvord Larry helped me set it > up,,, I used Larry's old camera mount, on his plane he mounted it on h is > right wing strut,,,, I kind of bent it around a bit and mounted it on my > left wing strut... it ended up a bit out of level.... when I got home I > made a new camera mount and I am giving it a go. on my first video with > the new mount is still a bit out of level... sorry I am working on in. > > my first video is a flight to the Alvord from Larry=99s home. > https://vimeo.com/98587855 > and the second is a flight up the Bear river. > https://vimeo.com/99748321 > > the password for both is beekeeper > > hope this all works. > > boyd y > > > ------------------------------ > <http://www.avast.com/> > > This email is free from viruses and malware because avast! Antivirus > <http://www.avast.com/> protection is active. > > * > =========== onics.com/Navigator?Kolb-List> =========== =========== om/contribution> =========== > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 02, 2014
Subject: Re: videos
Funny you see what get when I upload in hd. My alvord uploaded In standard deff, with that one I can change the size to larger than the hd video..go figure. I have another In progress, I think I finally got the camera straight. We'll see. Boyd On Jul 2, 2014 12:36 PM, "Larry Cottrell" wrote: > I liked it Boyd. It is nice to see other parts of the country where other > people are flying. The camera seems to do better than I had remembered, b ut > then again, If your terrain is bland, then there is a good chance your > pictures might be as well. Yours has some better definition to it than > mine. Not much green where I fly. I see that your video was produced with a > reduced screen size to it as mine was before I changed video programs. > Movie make wasn't that way until just recently, and that was the reason > that I bought another program. Perhaps there is a tweak that will make it > full screen. If you use "lithium" batteries it will record for about 5 or 6 > hours. > Larry > > > On Wed, Jul 2, 2014 at 12:09 PM, b young wrote : > >> with my last trip up to Larry=99s home,, the rock house,,, I p icked up >> Larry's old tachyon micro hd camera...( don=99t tell him,,, we wi ll keep it >> our secret). on my first video to the Alvord Larry helped me set it >> up,,, I used Larry's old camera mount, on his plane he mounted it on his >> right wing strut,,,, I kind of bent it around a bit and mounted it on m y >> left wing strut... it ended up a bit out of level.... when I got home I >> made a new camera mount and I am giving it a go. on my first video with >> the new mount is still a bit out of level... sorry I am working on in. >> >> my first video is a flight to the Alvord from Larry=99s home. >> https://vimeo.com/98587855 >> and the second is a flight up the Bear river. >> https://vimeo.com/99748321 >> >> the password for both is beekeeper >> >> hope this all works. >> >> boyd y >> >> >> ------------------------------ >> <http://www.avast.com/> >> >> This email is free from viruses and malware because avast! Antivirus >> <http://www.avast.com/> protection is active. >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > > > -- > *If you forward this email, or any part of it, please remove my email > address before sending.* > > * > =========== onics.com/Navigator?Kolb-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Subject: Re: videos
Date: Jul 02, 2014
Nice videos and thanks for sharing. My camera mount is a bit crooked too but luckily my plane flies with one wing low so it works out... :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425941#425941 ________________________________________________________________________________
Date: Jul 02, 2014
Subject: The FlagFly
SGkgS29sYmVycywKU29tZSBvZiB5b3UgYXJlIHByb2JhYmx5IGF3YXJlIHRoYXQgbXkgRmlyZUZs eSBpcyBsaXN0ZWQgZm9yIHNhbGUgb24gQmFybnN0b3JtZXJzIGJ1dCBmb3IgdGhlIHJlc3Qgb2Yg eW91LCBoZXJlIGdvZXMuwqAKCkxhc3QgZmFsbCwgd2l0aCBhIG5ld2x5IG92ZXJoYXVsZWQgZW5n aW5lIEkgdG9vayBvZmYgZm9yIHRoZSBmaXJzdCBmbGlnaHQuIEJlZm9yZSBJIGhhZCBlbm91Z2gg YWx0aXR1ZGUgdG8gcmV0dXJuIHRvIHRoZSBzdHJpcCB0aGUgZW5naW5lIHNodXQgb2ZmLiBJIGNo b3NlIGEgc295YmVhbiBmaWVsZCB0byBsYW5kIGluIHRoaW5raW5nIHRoZSBiZWFuIHBsYW50cyB3 ZXJlIDcgb3IgOCIgaGlnaC4KCldoZW4gSSBrbmV3IEkgY2xlYXJlZCB0aGUgdXRpbGl0eSB3aXJl cyBhbG9uZyB0aGUgcm9hZCBJIGdhdmUgaXQgZnVsbCBmbGFwcyBhbmQgZmxldyBpdCBvbnRvIHRo ZSBiZWFucyBhdCBhYm91dCA1MCBtcGguIFN1ZGRlbmx5IEkgd2F0Y2hlZCB0aGUgd2luZHNoaWVk IHN1cHBvcnQgdHViZSBjb21lIGludG8gbXkgZmFjZSBhbmQgb25seSBzb3liZWFucyB2aXNpYmxl IHRocm91Z2ggdGhlIHdpbmRzaGllbGQuwqAKCk15IGVkdWNhdGlvbiBmb3IgdGhlIGRheSB3YXMg dGhhdCBzb3liZWFucyBhcmUgb3ZlciBrbmVlIGRlZXAgYW5kIHRoZSBzdGVtcyBhcmUgbGlrZSB0 d2luZSBqdXN0IGJlZm9yZSBoYXJ2ZXN0LCBzbyBteSBiZWxvdmVkIEZsYWdGbHkgYmVjYW1lIGEg bGF3biBkYXJ0IHRoZSBpbnN0YW50IHRoZSBtYWlucyBkZWNlbmRlZCBpbnRvIHRoZSBiZWFucy7C oAoKVGhlIGVuZ2luZSBzdGFydGVkIGZpcnN0IHB1bGwgYWJvdXQgYW4gaG91ciBsYXRlciBidXQg c2lnaHRpbmcgdGhyb3VnaCB0aGUgZXhoYXVzdCBwb3J0IHJldmVhbGVkIGEgc2NvcmVkIHJlYXIg Y3lsaW5kZXIuwqBJIGhhZCBhIG1lY2hhbmljIHRlYXIgZG93biB0aGUgdG9wIGVuZCB0byByZXBh aXIgdGhlIGVuZ2luZSBhbmQgSSBzdHJpcHBlZCB0aGUgZmFicmljIGZyb20gdGhlIGNhZ2UgZm9y IGFuIGFpcmZyYW1lIHJlcGFpcm1hbiB0byBkbyB0aGUgcmVwYWlyIHdlbGRpbmcgYnV0IGNhbGxl ZCB0aGVtIGJvdGggdG8gc3RvcCB0aGUgd29yay4gSSBsb3ZlIHRoYXQgbGl0dGxlIHN1Y2tlciBz byBtdWNoIG15IG9ubHkgdGhvdWdodCBpbml0aWFsbHkgd2FzIHRvIGdldCBoZXIgcmVwYWlyZWQg YW5kIGluIHRoZSBza3kgYWdhaW4sIGJ1dCBtYWRlIHRoZSB0b3VnaCBkZWNpc2lvbiB0byBzZWxs IGl0IGFuZCBnZXQgYSB0d28gcGxhY2UuwqAKCkF0IHRoYXQgcG9pbnQgaXQgZGlkbid0IG1ha2Ug bXVjaCBzZW5zZSB0byBwYXkgdG8gaGF2ZSBpdCByZXBhaXJlZCB3aGVuIHRoZXJlIGFyZSBsb3Rz IG9mIGJ1aWxkZXJzIHdobyBoYXZlIHRoZSBza2lsbHMgYW5kIHdvdWxkIGxvdmUgdG8gZml4IGl0 IGFuZCBoYXZlIGl0IGZvciB0aGVtc2VsdmVzLsKgCgpJJ2xsIGJlIGF3YXkgdW50aWwgdGhlIDh0 aCBidXQgaWYgeW91IG9yIHNvbWVvbmUgeW91IGtub3cgd291bGQgbGlrZSBhIHNob3QgYXQgaXQs IHNob290IG1lIGFuIGVtYWlsIGFuZCBJIHdpbGwgZ2V0IGluIHRvdWNoIHdpdGggZXZlcnRvbmUg d2hlbiBJIGdldCBob21lLsKgCgpEYXZlIEt1bHAKQmV0aGxlaGVtLCBQQQpGaXJlRmx5IDExRE1L CgoKCgoKClNlbnQgZnJvbSBteSBWZXJpem9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lCgo8 ZGl2Pi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS08L2Rpdj48ZGl2PkZyb206IGIg eW91bmcgPGJ5b3VuZ3BsdW1iaW5nQGdtYWlsLmNvbT4gPC9kaXY+PGRpdj5EYXRlOjA3LzAyLzIw MTQgIDI6MDkgUE0gIChHTVQtMDU6MDApIDwvZGl2PjxkaXY+VG86IGtvbGItbGlzdEBtYXRyb25p Y3MuY29tIDwvZGl2PjxkaXY+U3ViamVjdDogS29sYi1MaXN0OiB2aWRlb3MgPC9kaXY+PGRpdj4K PC9kaXY+d2l0aCBteSBsYXN0IHRyaXAgdXAgdG8gTGFycnnigJlzIGhvbWUsLCB0aGUgcm9jayBo b3VzZSwsLCAgIEkgcGlja2VkIHVwIExhcnJ5J3Mgb2xkIHRhY2h5b24gbWljcm8gaGQgY2FtZXJh Li4uKCAgZG9u4oCZdCB0ZWxsIGhpbSwsLCB3ZSB3aWxsIGtlZXAgaXQgb3VyIHNlY3JldCkuICAg ICBvbiBteSBmaXJzdCB2aWRlbyB0byB0aGUgQWx2b3JkICBMYXJyeSBoZWxwZWQgbWUgc2V0IGl0 IHVwLCwsICAgSSB1c2VkIExhcnJ5J3Mgb2xkIGNhbWVyYSBtb3VudCwgIG9uIGhpcyBwbGFuZSBo ZSBtb3VudGVkIGl0IG9uIGhpcyByaWdodCB3aW5nIHN0cnV0LCwsLCAgSSBraW5kIG9mIGJlbnQg aXQgYXJvdW5kIGEgYml0IGFuZCBtb3VudGVkIGl0IG9uIG15IGxlZnQgd2luZyBzdHJ1dC4uLiAg aXQgZW5kZWQgdXAgYSBiaXQgb3V0IG9mIGxldmVsLi4uLiAgd2hlbiBJIGdvdCBob21lIEkgbWFk ZSBhIG5ldyBjYW1lcmEgbW91bnQgYW5kIEkgYW0gZ2l2aW5nIGl0IGEgZ28uICBvbiBteSBmaXJz dCB2aWRlbyB3aXRoIHRoZSBuZXcgbW91bnQgaXMgc3RpbGwgYSBiaXQgb3V0IG9mIGxldmVsLi4u ICBzb3JyeSBJIGFtIHdvcmtpbmcgb24gaW4uICAKIApteSBmaXJzdCB2aWRlbyBpcyBhIGZsaWdo dCB0byB0aGUgQWx2b3JkIGZyb20gTGFycnnigJlzIGhvbWUuICAgIGh0dHBzOi8vdmltZW8uY29t Lzk4NTg3ODU1CmFuZCB0aGUgc2Vjb25kIGlzIGEgZmxpZ2h0IHVwIHRoZSBCZWFyIHJpdmVyLiAg ICAgaHR0cHM6Ly92aW1lby5jb20vOTk3NDgzMjEKIAp0aGUgcGFzc3dvcmQgZm9yIGJvdGggaXMg ICAgICAgICBiZWVrZWVwZXIKIApob3BlIHRoaXMgYWxsIHdvcmtzLgogCmJveWQgeQoKCiAJClRo aXMgZW1haWwgaXMgZnJlZSBmcm9tIHZpcnVzZXMgYW5kIG1hbHdhcmUgYmVjYXVzZSBhdmFzdCEg QW50aXZpcnVzIHByb3RlY3Rpb24gaXMgYWN0aXZlLgoKCgoKXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgIC0g VGhlIEtvbGItTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZl YXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1 Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2Fk LCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2gg bW9yZToKXy09Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tv bGItTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVN UyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9y dW1zIQpfLT0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0K Xy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQpfLT0gIFRoYW5r IHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT0gICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1h dHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cgo ________________________________________________________________________________
Subject: Re: The FlagFly
Date: Jul 02, 2014
Damn, That's the nicest fly I ever saw. =F0=9F=98=A2=F0=9F=98=A2=F0=9F=98=A2=F0=9F=98=A2=F0=9F=98=A2=F0=9F=98=A2 Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Jul 2, 2014, at 4:45 PM, undoctor wrote: > > Hi Kolbers, > Some of you are probably aware that my FireFly is listed for sale on Barns tormers but for the rest of you, here goes. > > Last fall, with a newly overhauled engine I took off for the first flight. Before I had enough altitude to return to the strip the engine shut off. I c hose a soybean field to land in thinking the bean plants were 7 or 8" high. > > When I knew I cleared the utility wires along the road I gave it full flap s and flew it onto the beans at about 50 mph. Suddenly I watched the windshi ed support tube come into my face and only soybeans visible through the wind shield. > > My education for the day was that soybeans are over knee deep and the stem s are like twine just before harvest, so my beloved FlagFly became a lawn da rt the instant the mains decended into the beans. > > The engine started first pull about an hour later but sighting through the exhaust port revealed a scored rear cylinder. I had a mechanic tear down th e top end to repair the engine and I stripped the fabric from the cage for a n airframe repairman to do the repair welding but called them both to stop t he work. I love that little sucker so much my only thought initially was to g et her repaired and in the sky again, but made the tough decision to sell it and get a two place. > > At that point it didn't make much sense to pay to have it repaired when th ere are lots of builders who have the skills and would love to fix it and ha ve it for themselves. > > I'll be away until the 8th but if you or someone you know would like a sho t at it, shoot me an email and I will get in touch with evertone when I get h ome. > > Dave Kulp > Bethlehem, PA > FireFly 11DMK > > > > > > > Sent from my Verizon Wireless 4G LTE Smartphone > > > -------- Original message -------- > From: b young > Date:07/02/2014 2:09 PM (GMT-05:00) > To: kolb-list(at)matronics.com > Subject: Kolb-List: videos > > with my last trip up to Larry=C3=A2=82=AC=84=A2s home,, the rock hou se,,, I picked up Larry's old tachyon micro hd camera...( don=C3=A2=82 =AC=84=A2t tell him,,, we will keep it our secret). on my first video to the Alvord Larry helped me set it up,,, I used Larry's old camera mou nt, on his plane he mounted it on his right wing strut,,,, I kind of bent i t around a bit and mounted it on my left wing strut... it ended up a bit ou t of level.... when I got home I made a new camera mount and I am giving it a go. on my first video with the new mount is still a bit out of level... sorry I am working on in. > > my first video is a flight to the Alvord from Larry=C3=A2=82=AC=84=A2 s home. https://vimeo.com/98587855 > and the second is a flight up the Bear river. https://vimeo.com/997483 21 > > the password for both is beekeeper > > hope this all works. > > boyd y > > > > This email is free from viruses and malware because avast! Antivirus prote ction is active. > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > ky=C2=B7=C3=A8=C5=BE=C3=9B"=C3=8D=C3=AD=C5=93=C2=A2Z+=C3=93M4=C3=93G=C3=9A q=C3=A7(=C2=BA=C2=B8=C5=BE=C2=AEw=C2=B0r=B9=C2=AB=B0=C3=C3=93 =C3=A2=C2=A8=A2=C2=B2=C3=A2=C2=B2=C3=91&j)E=C2=A2=C2=BB=C2 R=C3=87=C2=AD=C3=A3=1A=C2=B6=C2=BA'=B0=C3=8B=0B=C5-=C3=8BEy =C2=ABn=C2=AD=C3=AB j=C3=B8 j=C3=9A+=C2=B6-=C3=AB=C2=A3=0B=1E=C2=B6=17 =C2j|=B9=C5-=C3=8Bn=C2=B6)b=C2=B6'=C2=AC=C2=B2=C3=A7!j=C3=82=C3=A2 =C2=B2=C3-'=C3=BD+=BA=C2=B1=C3=8A=C3=A2=C2=C3=98=C2=A8=C5=93 =C3=9C -+=C3=9EI=C3=C2=ABr=10=C3=A8=C3=82yhi=C3=9E=C3=83k k=C2=A3=0B=1E =16 =C2=AD=14=04=0F-=B9h=C2=B2=16=C2=ABy=C2=A9=C3=9D=C5=A1=C3=A7!=C5 =A1=C3=A7!=C5=A1=C5-=C3=9Ej=1A=C3=9E~=1Bm=C2=A7=C3=C3=B0=C3=83 =C5 =A1=C2=B6=C2=BA'=B0=C3=8B=1C=C2=A2o=C3=8Dj=C3=B8 j=C3=9A+*=B0[.+ --=C3=9Bi=C3=C3=BC0=C3=82f=C2=AD=C2=AE=B0=C3=A2r=C3=87( =BA=C3=B3Z=C2=BE(=1A=C2=B6=C5-=C3=8A=C2=A2V=C3=8B=C5-=C3=8B=7Fh=C3=13 D=C3=A3H %=9E=04S=98P=C3=84=99jg =C2=AD=C3=C2=AD r=B0=C3=ADz{Z=93=C3=8A=1A=C2=BD=C2=A8=C2=A5i=C2=B9^=C2=BE&=C2=AD =C3=A5=C5=BElZ+=C2=BAk=1A-=C2=B7=C5=B8-=C3=9Bi=C3 =C3=B7=C3=A8=C2=AE=C3=A9=C2=AC=84=A2=C2=ABk=C2=A2x=C5=93=C2=B1=C3=8A& -=C3=9Bi=C3=C3=B7=C3=A8=C2=AE=C3=A9=C2=AC=84=A2=C2=ABk=C2=A2x=C5=93=C2 =B1=C3=8A&=C3=BD=C2=A2=C3=A2=C2=B2=C3=90=C2=A8=C5=BE=C3=9A=C3=A2n=C3=ABb=C2=A2 u=C5=BEm(=C2=ADy8Z=C5=BEL=C2=A8=C2=B9=C3=BA+=C3=8A=B9=C2=AB=C2=81=C3=A9 =C3=9E=C2=AE=B9=C2=AC=C2=B2=C3i=C2=A2=C2=BBLj=C3=9BC=C2=AD=C2=A9ex=C2 =B8=C2=AC=C2=B4=07f=C5-v=C2=A1=C2=AD=C3=A7=C3=A1=C2=B6=C3=9A=7F=C3=0C0 =84=A2=C2=ABk=C2=A2x=C5=93=C2=B1=C3=8A&=C3=BD=C3=8A'=C2=B6=C2=B8=BA=C2 =BA=C3=98=C2=A8=C5=BE=1Bm=C2=A7=C3=C3=B0=C3=83 =C5=A1=C2=B6=C2=BA' =B0=C3=8B=1C=C2=A2o=C3=9C=C2=A2{k=B0=C2=BB=C2=AD=C5-=B0=C3 k=C3=B6=C3~=B0=C3=AD=C3=BE=C5=A1=C3=9E=C3=BD=C2=BA=1D=C3=8B=C3=B8 m=C5=A1 ________________________________________________________________________________
Subject: Annual
Date: Jul 02, 2014
Kolbers, Its time for my first annual on my Xtra. As I purchased the plane I dont have any reference on doing an annual. What can I do myself and what must be done by an A&P? I would think that I should have an A&P do the engine portion. Any suggestions would be appreciated. Brad Nation Yellowbird1 N952DK ________________________________________________________________________________
Subject: Rotax 670 test run
Date: Jul 02, 2014
With Dave Lewis helping out I was able to run the 670 on the Kolb tonight for the first time. If the tach is correct it idles smoothly at 1600. Only revved it to 5k so far but first impressions are positive. Very quiet, and even smoother than the very smooth 690L-70 I took off. Hopefully more run time tomorrow and will see what it'll turn up to wide open. Possibly the extreme smoothness is from ignition timing that may be too retarded. Will have to see how it revs out tomorrow to see if a little advance is in order. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA ________________________________________________________________________________
Date: Jul 02, 2014
Subject: Re: Annual
On 7/2/2014 9:50 PM, Brad Nation wrote: > > Kolbers, > Its time for my first annual on my Xtra. As I purchased the plane I dont have any reference on doing an annual. What can I do myself and what must be done by an A&P? I would think that I should have an A&P do the engine portion. Any suggestions would be appreciated. > > Brad Nation > Yellowbird1 > N952DK > What kind of a/w cert? If it's experimental homebuilt, the only thing you need an A&P to do is sign off the annual condition inspection. Legally, anyone can do anything else. Repairs, mods, general service, anything. Having said that, it doesn't necessarily mean that just anyone *should*, at least until they gain some experience. Anyone in your area that has experience with Kolbs? If so, they could probably help the A&P, because most A&Ps don't deal with experimentals much. Charlie ________________________________________________________________________________
Subject: videos
Date: Jul 03, 2014
Hi Boyd=2C That was great! I cant wait to finish up my plane and get up to BMC. I am r esurfacing the IVO leading edge with the stainless steel tape. I need to do some small patching of the old hanger rash still. Just a few more little t hings still need to be done. GREAT VIDEO! Thanks=2C Kurt Mark III 582 DCDI Date: Wed=2C 2 Jul 2014 12:47:55 -0600 Subject: Re: Kolb-List: videos From: byoungplumbing(at)gmail.com Funny you see what get when I upload in hd. My alvord uploaded In standard deff=2C with that one I can change the size to larger than the hd video ..go figure. I have another In progress=2C I think I finally got the ca mera straight. We'll see. =0A =0A Boyd=0A On Jul 2=2C 2014 12:36 PM=2C "Larry Cottrell" wro te: =0A I liked it Boyd. It is nice to see other parts of the country where other p eople are flying. The camera seems to do better than I had remembered=2C bu t then again=2C If your terrain is bland=2C then there is a good chance you r pictures might be as well. Yours has some better definition to it than mi ne. Not much green where I fly. I see that your video was produced with a r educed screen size to it as mine was before I changed video programs. Movie make wasn't that way until just recently=2C and that was the reason that I bought another program. Perhaps there is a tweak that will make it full sc reen. If you use "lithium" batteries it will record for about 5 or 6 hours. =0A =0A Larry On Wed=2C Jul 2=2C 2014 at 12:09 PM=2C b young w rote: =0A =0A =0A =0A =0A =0A with my last trip up to Larry=92s home=2C=2C the rock house=2C=2C=2C I =0A picked up Larry's old tachyon micro hd camera...( don=92t tell him=2C=2C =2C we =0A will keep it our secret). on my first video to the =0A Alvord Larry helped me set it up=2C=2C=2C I used Larry's old camera =0A mount=2C on his plane he mounted it on his right wing strut=2C=2C=2C=2C I kind =0A of bent it around a bit and mounted it on my left wing strut... it ended =0A up a bit out of level.... when I got home I made a new camera mount and I =0A am giving it a go. on my first video with the new mount is still a bit out =0A of level... sorry I am working on in. =0A =0A my first video is a flight to the Alvord from Larry=92s =0A home. https://vimeo.com/98587855=0A and the second is a flight up the Bear river. https://vimeo.com/9974832 1=0A =0A the password for both is =0A beekeeper=0A =0A hope this all works.=0A =0A boyd y=0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A This email is free from viruses and malware because avast! Antivirus pr otection is active.=0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A get="_blank">http://www.matronics.com/Navigator?Kolb-List=0A tp://forums.matronics.com=0A _blank">http://www.matronics.com/contribution=0A =0A -- If you forward this email=2C or any part of it=2C please remove my email ad dress before sending. =0A =0A =0A =0A =0A =0A =0A get="_blank">http://www.matronics.com/Navigator?Kolb-List=0A tp://forums.matronics.com=0A _blank">http://www.matronics.com/contribution=0A =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Date: Jul 03, 2014
The old guys sideslipped before flaps roy On Wed, Jul 2, 2014 at 11:08 AM, Charlie England wrote: > > > On 7/1/2014 9:38 PM, Larlaeb wrote: > >> >> Went out this morning and practiced landing a bit. I setup a camera to >> see what it looked like from the ground side of things. There was >> basically no wind at ground level and I placed the camera 400 feet from the >> threshold of the runway. I seldom actually hit the threshold because >> there are power lines on that end and they make me nervous. On all the >> landings power was set at idle on the downwind and not touched until I was >> on the ground. All these were made with full flaps. I'm sharing this not >> because I think I'm particularly good at it as you can see, but because it >> was fun to do. Hopefully you won't find it too boring. >> >> https://docs.google.com/file/d/0BxdXwdWJkFExd2hiWE9fRDRjaXc/edit >> >> >> Thanks, >> Allan >> >> Love the format. Seeing the cockpit view, flight data, and the ground > perspective at the same time is really nice. > > On the subject of power lines, have you thought about contacting the power > company to have their 'orange balls' added to the lines? They will probably > try to charge you, but one of the original members of my airpark pitched it > this way: when they asked for payment, he pointed out that the power > company owned the lines, and if someone couldn't see them & it caused a > crash, the power company would be liable. They installed the balls for free. > > Charlie > > ________________________________________________________________________________
Subject: EIS tach setting for single CDI Rotax
Date: Jul 03, 2014
Tach seems to read a little low on the 670, anyone out there know the programmable EIS tach setting for a 447 or 377, should be the same as my 670. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA ________________________________________________________________________________
Subject: Re: Annual
Date: Jul 03, 2014
When I first purchased my Firestar II, I had an A&P do an annual for me. He charged me the outrageous sum of $50. There are no panels to open & no hidden control housings. He took about half an hour & I was right beside him. We then did a weight & balance to check the numbers. The paperwork took almost as much time....... :) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426045#426045 ________________________________________________________________________________
Date: Jul 03, 2014
From: "brubakermal(at)yahoo.com" <brubakermal(at)yahoo.com>
Subject: Re: Annual
$50.- omg I only charge. $42=0A=0ASent from Yahoo Mail on Android=0A=0A ________________________________________________________________________________
Subject: Re: Annual
Date: Jul 03, 2014
Woody. I don't know where you are, but $50 seems reasonable to me (I'm in Maine) for an hour's work by a certified professional, who's spent a lot of time & money getting certified. Russ K On Jul 3, 2014, at 9:09 PM, woody wrote: > > When I first purchased my Firestar II, I had an A&P do an annual for me. > He charged me the outrageous sum of $50. There are no panels to open & > no hidden control housings. He took about half an hour & I was right beside him. We then did a weight & balance to check the numbers. The paperwork took almost as much time....... :) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426045#426045 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 03, 2014
Subject: Re: Annual
Russ, I don't know, but strongly suspect that there was a missing ;-) in that message from woody. Charlie On 7/3/2014 9:30 PM, kinne russ wrote: > > Woody. > I don't know where you are, but $50 seems reasonable to me (I'm in Maine) for an hour's work by a certified professional, who's spent a lot of time & money getting certified. > Russ K > > > On Jul 3, 2014, at 9:09 PM, woody wrote: > >> >> When I first purchased my Firestar II, I had an A&P do an annual for me. >> He charged me the outrageous sum of $50. There are no panels to open & >> no hidden control housings. He took about half an hour & I was right beside him. We then did a weight & balance to check the numbers. The paperwork took almost as much time....... :) >> >> >> ________________________________________________________________________________
Subject: Re: Annual
Date: Jul 04, 2014
I think you're right! On Jul 3, 2014, at 11:35 PM, Charlie England wrote: > > Russ, > > I don't know, but strongly suspect that there was a missing ;-) in that message from woody. > > Charlie > > On 7/3/2014 9:30 PM, kinne russ wrote: >> >> Woody. >> I don't know where you are, but $50 seems reasonable to me (I'm in Maine) for an hour's work by a certified professional, who's spent a lot of time & money getting certified. >> Russ K >> >> >> On Jul 3, 2014, at 9:09 PM, woody wrote: >> >>> >>> When I first purchased my Firestar II, I had an A&P do an annual for me. >>> He charged me the outrageous sum of $50. There are no panels to open & >>> no hidden control housings. He took about half an hour & I was right beside him. We then did a weight & balance to check the numbers. The paperwork took almost as much time....... :) >>> >>> >>> > > > > > ________________________________________________________________________________
Date: Jul 04, 2014
Subject: Forth of July flight
The weather guesser site claimed that the winds would be 2 MPH until at least 12 PM, so I rolled the Firestar out to check the ranch next door's Pothole field for bogged cows. I decided that if the winds permitted I would go back up into the hills for a fun flight. I filled my coffee cup, did my preflight and headed out. I both wanted to fly, and to have something new to practice the video editing program. So you will again be burdened with another video. I have a friend that believes that 2 to 3 minutes is about right for a video. I guess I am too long winded to do that. I cut this one at least three times, and it still is too long. The flight covered 1 hour and 24 minutes, and I had a headwind both directions. The wind went right through 2 MPH and ended up at about 10 MPH. My destination was a ranch owned by the father of my neighbors. He has a Cessna, and at a recent birthday party next door, enquired as to why I had never come up to his ranch. I decided that I would take care of that problem. Larry https://vimeo.com/99954471 password - owyheeflyer -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: Forth of July flight
Date: Jul 04, 2014
Thanks for that. Good video and you have excellent taste in music. I spent my day working on the hangar. Cold front came through last night and we had a July 4th that only got up to about 78 degrees. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426110#426110 ________________________________________________________________________________
Date: Jul 05, 2014
You've sure mastered that editing program, Larry. And editing is the key to good videos. Also the choice of music, and particularly the commentary, make your videos a joy to watch. Keep it up. JG ________________________________________________________________________________
Date: Jul 05, 2014
Thank you for the compliment. Are you still in this country, or have you gone home? You've been pretty quiet lately. Larry On Sat, Jul 5, 2014 at 6:07 AM, JC Gilpin wrote: > You've sure mastered that editing program, Larry. And editing is the key > to good videos. Also the choice of music, and particularly the commentary, > make your videos a joy to watch. Keep it up. > > JG > > * > > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: EIS tach setting for single CDI Rotax
Date: Jul 05, 2014
According to my manual for an EIS 2000, tach setting for Rotax CDI engines is 6. Rotax 912 requires a setting of 1. Most non CDI engines require a setting of 2. Hope this helps. -------- Gregg Kaat 2011 Firefly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426176#426176 ________________________________________________________________________________
Date: Jul 05, 2014
Thanks, I guess mine is right, thought maybe the sled ignition was different. Dennis "Skid" Rowe Mk3, 690L-70, Leechburg, PA > On Jul 5, 2014, at 8:40 PM, "t41pilot" wrote: > > > According to my manual for an EIS 2000, tach setting for Rotax CDI engines is 6. Rotax 912 requires a setting of 1. Most non CDI engines require a setting of 2. Hope this helps. > > -------- > Gregg Kaat > 2011 Firefly > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426176#426176 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 05, 2014
Subject: fire fly for sale
I- got the fire fly i have for sale home to my hanger Friday .now i can g o over it a little moor and run the engine and taxi test it , it has never flown! of that i am sure.- we found the BRS and moor paperwork to add to the slide show listed on my web site. the builder died last fall when a tre e he was cutting spun and fell on him.- now his doughtier is settling the estate , what s sad and hard thing to deal with.=0A- today i had a conve rsation with the owner of another plane i have for sale it is really in Rou gh- shape needing a rebuild or some real updating when i told him of an o ffer we had for it- he said all angry like that he would give it away fir st, meaning to his doughtier he would leave it for his only child to sell t he mess after he is dead he is 87 , there are so many people in this same s ituation locally and all over the country . a year ago he wanted $20,000 fo r it- today he was offered $4K, its probably not worth that to most build ers ..again the slide show is on my web site. =0A=0AFriday- Brian Taylor came up and bought a quicksilver sport he payed $3,500 18 months ago we lis ted the plane for $9K- the seller had realized its a buyers market it was a sad day for both of us for several reasons, but at least this quicksilve r will be flown- again i don't think this 1989 avid mk 4- with only 35 hrs and a Subaru E81- will ever- be put in the air again . =0A=0A-=0A Malcolm & Jeanne Brubaker =0AMichigan Sport Pilot Repair =0Ahttp://michigan sportpilotrepair.com=0ALSRM-A, PPC, WS=0AGreat Sails - Sailmaker =0Afor Ult ralight & Light Sport=0A(989)513-3022=0A-=0A-=0A-=0A-=0A=0A=0A_____ ___________________________=0A From: t41pilot <t41pilot(at)frontier.com>=0ATo: kolb-list(at)matronics.com =0ASent: Saturday, July 5, 2014 8:40 PM=0ASubject: Kolb-List: Re: EIS tach setting for single CDI Rotax=0A =0A=0A--> Kolb-Lis t message posted by: "t41pilot" =0A=0AAccording to m y manual for an EIS 2000, tach setting for Rotax CDI engines is 6. Rotax 91 2 requires a setting of 1.- Most non CDI engines require a setting of 2. Hope this helps.=0A=0A--------=0AGregg Kaat=0A2011 Firefly=0A=0A=0A=0A=0ARe ad this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p =========================0A = ________________________________________________________________________________
Date: Jul 06, 2014
Subject: Owyhee River flight
Possibly my last video of the season. Even I get bored with them. The main change is the picture quality, and there are more photos than flying. I had not been down to the River this year, and even though this is the only time of the year when I don't have the area to myself, The weather was cooperating, so no excuse not to go. I am using a 503 on the plane at this time, and it uses a bit more fuel than the HKS, so I took four gallons with me. The weather site assured me that if I started early I would have a tail wind both ways. Sure, most likely a head wind both ways. They say that "paranoia is merely an heightened sense of reality". It pays when flying here. Sure enough there was a headwind that had a pretty bumpy layer, so I climbed up about 1500 feet. I still had a head wind, but it was smooth. There were a couple of campers down on the River, but for the most part I still had it to myself. The River is very low this year. I landed in one of the large empty smooth areas and refueled. The flight was 2 hours and 18 minutes. I found a quiet layer of air at about 2000 feet AGL, and made my way back home. https://vimeo.com/100053125 password- owyheeflyer Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 07, 2014
Yeh, still in the US, really only just started this trip. Haven't done any flying yet, been too busy on this project in Denver. Helping friend Tony build a Savannah S kit, an all metal two place sort of like the one I have in OZ. Today we finished the build, and prepped it for painting. Took us 230 hrs over 20 days. Not bad for a couple of older fellas..... This ICP Savannah kit is great. They really know how to use CNC equipment to best advantage. 14,000 holes and they all lined up! So just a matter of finding the right pieces in the big box and clecoing and riveting. Slowest part is reading the construction manual, which is pathetic..... So it's mostly just like a big jigsaw puzzle, dig around through the pieces looking for one with the pattern of holes that will match the last piece, and then usually it's the right piece and won't fit anywhere else.... I'll be here until the end of the month, then on the road, and hope to catch the biker's rally in Sturgis, SD before heading on up to Alberta for the mandatory relatives visit. JG ________________________________________________________________________________
Subject: Re: Owyhee River flight
Date: Jul 06, 2014
Larry, What happened to the HKS? Sent from my iPhone > On Jul 6, 2014, at 5:06 PM, Larry Cottrell wrote : > > Possibly my last video of the season. Even I get bored with them. The main change is the picture quality, and there are more photos than flying. > > I had not been down to the River this year, and even though this is the on ly time of the year when I don't have the area to myself, The weather was co operating, so no excuse not to go. I am using a 503 on the plane at this tim e, and it uses a bit more fuel than the HKS, so I took four gallons with me. The weather site assured me that if I started early I would have a tail win d both ways. Sure, most likely a head wind both ways. They say that "paranoi a is merely an heightened sense of reality". It pays when flying here. Sure e nough there was a headwind that had a pretty bumpy layer, so I climbed up ab out 1500 feet. I still had a head wind, but it was smooth. > > There were a couple of campers down on the River, but for the most part I s till had it to myself. The River is very low this year. I landed in one of t he large empty smooth areas and refueled. > > The flight was 2 hours and 18 minutes. I found a quiet layer of air at abo ut 2000 feet AGL, and made my way back home. > > https://vimeo.com/100053125 password- owyheeflyer > > Larry > > -- > If you forward this email, or any part of it, please remove my email addre ss before sending. > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 06, 2014
Not too long for me. Thanks again for sharing. Thanks in advance, Yellow Bird 1 Brad Nation MKIII Xtra N952DK On Jul 4, 2014, at 19:10 , Larry Cottrell wrote: > The weather guesser site claimed that the winds would be 2 MPH until at least 12 PM, so I rolled the Firestar out to check the ranch next door's Pothole field for bogged cows. I decided that if the winds permitted I would go back up into the hills for a fun flight. I filled my coffee cup, did my preflight and headed out. I both wanted to fly, and to have something new to practice the video editing program. So you will again be burdened with another video. I have a friend that believes that 2 to 3 minutes is about right for a video. I guess I am too long winded to do that. I cut this one at least three times, and it still is too long. > > The flight covered 1 hour and 24 minutes, and I had a headwind both directions. The wind went right through 2 MPH and ended up at about 10 MPH. > > My destination was a ranch owned by the father of my neighbors. He has a Cessna, and at a recent birthday party next door, enquired as to why I had never come up to his ranch. I decided that I would take care of that problem. > Larry > > https://vimeo.com/99954471 password - owyheeflyer > > -- > If you forward this email, or any part of it, please remove my email address before sending. > > > ________________________________________________________________________________
Date: Jul 09, 2014
Subject: Flying the pattern at Oshkosh
Hi Everyone, Since the first time I went to Oshkosh in 1998 I've had the dream to bring my plane to Oshkosh and fly the pattern with the ultralights. So far that dream has never been realized and it's looking like this year could be no different. I was very close two years ago when I trailered my yellow MK II up there, but my ignition got wet in a rain storm and it just didn't happen. Anyway, I got to thinking that even though my current aircraft project isn't going to make it, perhaps someone else would have a plane there that I could get a ride with. If you or anyone you know is planning to have a two seat sport aircraft at Oshkosh this year, I'd be willing to pay for a ride around the patch a couple times. You would seriously be making my year. Email me direct off group at radiobluebook(at)gmail.com if you can point me in the right direction. Sincerely, Duane ________________________________________________________________________________
Date: Jul 09, 2014
Subject: video?
I know that I said that I was most likely done making video's, but last night while in the depths of boredom, and finding nothing to read on the list, I began looking at tutorials on the Cyberlink program. Most of them concern making little rocket ships with a sparkle trail to go across your screen, but there was one that mentioned "video enhancement". It will also "stabilize" the video as well. I have always been disappointed in the quality of the video's here in the desert. Most of the time that they are taken is in pretty inadequate light, therefore it is pretty flat. You guy's in the watered part of the world do not have that problem. I had a few things that I wanted to see yesterday morning, and I took off early, just at sunrise. I took my Drift camera along out of habit more than anything. In looking at the footage, it was pretty flat and hazy, so I set it aside. After "watching the directions" on the editing program, I decided that the footage was the perfect sample to try the "enhancements" on. I made a short video, and saved it as it came from the camera, then made another with the enhanced version. The difference is fairly striking. The sky is still washed out, but the terrain looks better than any I have done. Now I know this won't tell you how to build any part of your Kolb's, but it will show you what it is like to fly one. It seems to me that no one is doing much of anything any way. Compare this one with some of the other ones that I have done, and I think you will see that the pictures are a lot brighter and clearer. Perhaps I didn't waste my money on this program after all. https://vimeo.com/100369914 -owyheeflyer Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Uncaged bearing - the dreaded "tink-tink" sound
Date: Jul 09, 2014
I thought I would pass along a little tip that might save someone some grief. I've got a 377 on my 1985 Firestar with an unknown number of hours. One thing I always do on preflight is slowly turn the engine over and listen for any unusual sounds. On my last preflight, I heard a slight "tink tink" sound that was not associated with any one spot on the rotation of the engine, and irregular in tempo. It's not very loud and you might easily think nothing of it. Fortunately, I had heard this sound before on a snowmobile engine. It's the sound of the balls in one of the main bearings falling down the back side of the race after the plastic bearing cage has gone away. When the cage is gone, all the balls drop to the bottom of the bearing. Then when the crank is turned slowly, they climb up to the top of the bearing and then fall one by one back down again. Each time a ball comes over the top and falls, it makes a little tink sound when it lands on it's neighbors hanging out down in the bottom. The engine will still run, but a catastrophic and expensive failure is in your near future if you continue to run with an uncaged bearing. I'm not sure what causes this. In the engine in question it was the bearing on the mag end. On the snowmobile, it was the PTO bearing and one of the center bearings. The crank was slightly bent on the airplane engine. I'm thinking that could have been a symptom of running with a damaged bearing or it could be the cause of the bearing's demise. The bearings in the gearbox have steel cages. I've always wondered why they use bearings with plastic cages inside the engine. So pay attention to those little things during preflight and avoid the big things later on. -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426412#426412 ________________________________________________________________________________
Subject: Re: Uncaged bearing - the dreaded "tink-tink" sound
Date: Jul 10, 2014
Sorry about your engine. Please document your tear down and rebuild if you do one. Some of us guys are still running Rotax 2 strokes and would be very interested in watching along. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426426#426426 ________________________________________________________________________________
Date: Jul 10, 2014
Subject: 503 for sale
I have a 503 that has about 300 hours on it, but is still running strong. Dual carbs It has a intake silencer, and oil injection, that I would like to sell. I have not listed it on Barnstormers yet. I wanted to give the list the first chance at it. Larry - 541 586 5030 -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: trip to spiral jetty in the great salt lake.
Date: Jul 10, 2014
this is about a 5 min video it includes area around the great salt la ke.... for this being a desert there is a lot of water but not a drop to d rink... the area is a lot like the area that Larry flies,,,, exactly the same,,,,, only different..... https://vimeo.com/100428508 password is beekeeper boyd young --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Date: Jul 10, 2014
Subject: Re: trip to spiral jetty in the great salt lake.
Karen and I both liked it. This is what I envisioned- people showing the rest of the list the areas that they fly. What could be better? Larry On Thu, Jul 10, 2014 at 11:39 AM, b young wrote: > this is about a 5 min video it includes area around the great > salt lake.... for this being a desert there is a lot of water but not a > drop to drink... the area is a lot like the area that Larry flies,,,, > exactly the same,,,,, only different..... > > https://vimeo.com/100428508 password is beekeeper > > boyd young > > > ------------------------------ > <http://www.avast.com/> > > This email is free from viruses and malware because avast! Antivirus > <http://www.avast.com/> protection is active. > > * > > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 11, 2014
Subject: Airventure Latex Paint Forums
Hello Kolb friends, If you are attending Airventure 2014 in Oshkosh, stop in for one of the Latex Paint for Aircraft forums. I used latex on my MKII a few years ago. I have some updates to last years forum and the webinar, and it should be fun and informative. Hope to see you there! - Monday, July 28, 11:30-12:45 in the Forum 1 building - Wednesday, July 30, 10:00-11:15 in the Forum 6 building Malcolm Morrison http://wienerdogaero.com ________________________________________________________________________________
Date: Jul 11, 2014
Subject: Prop Strike
From: Colin Hudson <colin.scott.hudson(at)gmail.com>
.Guys here's a picture of what can happen if you don't secure your fuel caps good. This was a rather expensive lesson for me. In the future I'm going to attach lanyards to my fuel caps. While flying my plastic fuel cap came off and went through my Sensenich wooden prop on my Mark 3 Xtra. I was lucky there was a grass strip near by. Surprisingly the vibration wasn't too bad. Had that chunk departed, it would have caused an unbalanced condition. As it was, it just made a loud change in the prop noise. Colin Hudson N424AL M3Xtra Jabiru 2200 ________________________________________________________________________________
Subject: Re: Prop Strike
Date: Jul 11, 2014
You might want to consider a Warp Drive for your replacement prop. If you had one, you would have discovered you lost the fuel cap at your next re-fueling stop. Jimmy Young Missouri City, Tx Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426516#426516 ________________________________________________________________________________
Date: Jul 11, 2014
Subject: Fw: warp drive prop strike today
this happened on take off the pliers were sat on top of the jab 2200 mk3 ex tra,- and found in the grass. the runway is 100 ft wide. - the other- prop-- is not as bad but both blades are still junk.- he flew for 20 minutes like this and did not know he had a problem till the post flight i nspection .=0A=0A=0ASent from Yahoo Mail on Android ________________________________________________________________________________
Date: Jul 11, 2014
That is true, I managed to leave a heavy pair of side cutters on my wing while testing my engine inside the hanger. The cutters hit the ceiling, but didn't hurt the warp. Larry On Fri, Jul 11, 2014 at 6:27 PM, Jimmy Young wrote: > > You might want to consider a Warp Drive for your replacement prop. If you > had one, you would have discovered you lost the fuel cap at your next > re-fueling stop. > > Jimmy Young > Missouri City, Tx > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426516#426516 > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 11, 2014
Wakataka, Thanks for the warning. That's the first time I've heard of that happening to the Main Ball Bearing. I have heard of the Wrist Pin Needle Bearing Cage breaking, allowing all those little needles to fall out of place and crunch time. I had a 377 and changed those bearings to the uncaged type. Now I have a newer 447. Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive In a message dated 7/10/2014 1:02:18 A.M. Eastern Daylight Time, wakataka(at)charter.net writes: the balls in one of the main bearings falling down the back side of the race after the plastic bearing cage has gone away. ________________________________________________________________________________
Date: Jul 11, 2014
the tips of my warp are getting kinda chewed up from grass and weeds but it is still allot- stronger than a wood prop i liked my- GSC prop- my c urrant- warp has no nickle edge. the one on my 2ed kolb had a nickle edge - and i put a screw driver threw it at idle and it left only a small nick on the flat side =0A=0A-=0AMalcolm & Jeanne Brubaker =0AMichigan Sport P ilot Repair =0Ahttp://michigansportpilotrepair.com=0ALSRM-A, PPC, WS=0AGrea t Sails - Sailmaker =0Afor Ultralight & Light Sport=0A(989)513-3022=0A- =0A-=0A-=0A-=0A=0A=0A________________________________=0A From: Larry Cottrell =0ATo: "kolb-list(at)matronics.com" =0ASent: Friday, July 11, 2014 10:11 PM=0ASubject: Re: Ko lb-List: Re: Prop Strike=0A =0A=0A=0AThat is true, I managed to leave a hea vy pair of side cutters on my wing while testing my engine inside the hange r. The cutters hit the ceiling, but didn't hurt the warp.=0ALarry=0A=0A=0A =0A=0AOn Fri, Jul 11, 2014 at 6:27 PM, Jimmy Young wro >=0A>=0A>You might want to consider a Warp Drive for your replacement prop. If you had one, you would have discovered you lost the fuel cap at your ne xt re-fueling stop.=0A>=0A>Jimmy Young=0A>Missouri City, Tx=0A>=0A>=0A>=0A> =0A>Read this topic online here:=0A>=0A>http://forums.matronics.com/viewtop ic.php?p=426516#426516=0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A>====== ======0A>" target="_blank">http://www.matronics.com/Navigator?K olb-List=0A>============0A>MS -=0A>k">http://forums.m atronics.com=0A>============0A>e -=0A>- - - - --Matt Dralle, List Admin.=0A>t="_blank">http://www.matronics.com/cont ribution=0A>============0A>=0A>=0A>=0A>=0A=0A=0A-- =0AIf you forward this email, or any part of it, please remove my email add ==================== ________________________________________________________________________________
Date: Jul 12, 2014
This type of failure occurs with metal retainers as well and often leads to a top end melt down. Certainly there are numerous potential causes for most mechanical failures but I believe one of the leading causes for this type of bearing failure is rust. I remember one engine in particular ware the retainer was broken, ground and mutilated almost beyond recognition. Customer brought the sled in with a melted piston, piston melted because PTO seal was leaking, PTO seal leaked because crank wobbled, crank wobbled because bearing failed, when I examined what was left of the bearing I found rust. That engine was by no means the only one I found corrosion in. 2 strokes are rather difficult to adequately protect the lower end during storage. First unlike a 4 stroke a 2 stroke draws raw fuel into the crankcase on shut down when we kill spark but the engine spins down drawing fuel thru the idle circuit. especially bad if the fuel contains ethanol. Oil Poured in the spark plug hole will not necessarily find its way to the crank bearings and almost certainly will not reach the lower rod bearing. Fogging is an option but I don't like the stress on the engine as fogging oil forces a stall. Also on a 2 stroke if the piston is any ware near the top of its stroke at rest there will be a direct route for moist air to enter the crankcase thru the open intake port. This was a particularly frustrating aspect of being a snowmobile mechanic as almost no one would bother to properly store their machines. The failure occurs so long after the machine is put back in service that it is almost impossible to convince the customer of the true cause. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426531#426531 ________________________________________________________________________________
Date: Jul 12, 2014
This must be the season for it. One of the exhaust spring hooks broke and the pieces of it went through my prop the other day. Safety wire on the spring held so only the pieces of the hook made the hit. A couple of flat places in the nickle leading edge were the only damage and I was able to re-shape those pretty well as directed on the Warp Drive website. I am replacing all the hooks on the front connection. The rear hooks look ok but all the front ones are corroded pretty badly.I think this is because the exhaust joint faces that direction and any exhaust leaking around it would hit those and accelerate the corrosion process. See attached pics of the good and that broken. Anyway it's something that might be worth checking. I know I'll pay more attention to that area from now on. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426533#426533 Attachments: http://forums.matronics.com//files/photo_32_134.jpg http://forums.matronics.com//files/photo_33_647.jpg ________________________________________________________________________________
Subject: Ad in Trada A Plane
Date: Jul 12, 2014
I saw a kolb Xtra with a 912 in Trade A Plane. It had a 912 Rotax and was N numbered. The price was $14,500. It has already sold, but has anyone else seen them sell for this price? Here is the broker who sold it http://jacksaircraft.com/aircraft/ N2515F Does anyone personally know this plane? Wes -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426534#426534 ________________________________________________________________________________
Date: Jul 12, 2014
=0A-=0A=0Athis happened on take off the pliers were sat on top of the jab 2200 mk3 extra,- and found in the grass. the runway is 100 ft wide. - the other- prop-- is not as bad but both blades are still junk.- he flew for 20 minutes like this and did not know he had a problem till the p ost flight inspection .=0A=0A=0A=0A=0A=0ASent from Yahoo Mail on Android ________________________________________________________________________________
Date: Jul 12, 2014
Ouch, that hurt! Your lucky to be in one pice. YellowBird 1 Brad Nation N952DK M3Xtra ________________________________________________________________________________
Subject: Custom Built Kolb Mark III Trailer. MAKE OFFER
Date: Jul 12, 2014
I have a great custom made trailer for a Mark III but other Kolbs would also work. Nice wind blast shield perfect for protecting the aircraft at more rapid highway speeds. Single Person On-load and Off-load using installed hand crank winch. Tailwheel rides the center track shown in the photos and stops in a detent. Main tires lock in wells held by ramps. Includes 3 new spare tires. Tires on the trailer are in great shape. Weight in the 500 to 700 # range, very sturdy and very stable on the road. Length 21', overall length from the tongue to the rear of the trailer. The length of the deck itself is 18'. 3' width at the nose. No reasonable offer refused Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426561#426561 Attachments: http://forums.matronics.com//files/img_3635_172.jpg http://forums.matronics.com//files/img_3635_839.jpg ________________________________________________________________________________
Subject: Re: Prop Strike ; Corroded hooks
Date: Jul 13, 2014
> I think this is because the exhaust joint faces that direction and any exhaust leaking around it would hit those and accelerate the corrosion process. Almost any chemical reaction will go faster when hotter, particularly oxidation. It can happen completely without exhaust gas on it. ________________________________________________________________________________
Date: Jul 13, 2014
JBM industries has stainless springs available. They hold up much better- =0A=0AGary Jindra-=0AMark 3 912 ul=0A230 hours =0A=0A=0AOn Sunday, July 1 3, 2014 6:55 AM, George Bearden wrote:=0A =0A=0A=0A- =0A> I think this is because the exhaust- joint faces that direction and any=0Aexhaust leaking around it would hit those and accelerate the corrosio n=0Aprocess.=0A=0AAlmost any chemical reaction will go faster when hotter, particularly=0Aoxidation. It can happen completely without exhaust gas on i ================= ________________________________________________________________________________
Date: Jul 13, 2014
These hooks were stainless and the ones I replaced them with are also stainless. Got them from Titan. I guess that's why they call it stain 'less' and not stain 'proof'. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426594#426594 ________________________________________________________________________________
Date: Jul 13, 2014
When I had my FS II with 503, I got tired of all the ugly springs and safety wire and silicone and hooks. Aircraft Spruce and others had advertised stainless steel muffler joint clamps that worked very well. Cut off the spring hooks and no problems for the next 6 years. Shack In a message dated 7/13/2014 5:04:08 P.M. Eastern Daylight Time, gajindra(at)sbcglobal.net writes: JBM industries has stainless springs available. They hold up much better ________________________________________________________________________________
Date: Jul 13, 2014
Thanks for the info. I do wish these pictures were a little bigger however. My eyes aren't what they used to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426600#426600 ________________________________________________________________________________
Subject: Facet fuel pumps..
Date: Jul 13, 2014
Hello Kolb builder, I soon will need to buy a facet fuel pump for my Kolbra. I am wondering what make/style is favorite in the Kolb world? Thanks as always for your input! Nick Cassara Palmer, Alaska ________________________________________________________________________________
Subject: Re: Facet fuel pumps..
Date: Jul 14, 2014
Get one that only goes to about 3 pounds pressure, easier on the float valves. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426628#426628 ________________________________________________________________________________
Date: Jul 14, 2014
This chart gives you all the info on each Facet model, max/min pressure, voltage, GPH, and min lift. You'll have to go to the engine info, you are going to use, to determine min and max operating fuel pressure. http://www.facet-purolator.com/cube-fuel-pumps.php john h mkIII Thermopolis, Wyoming From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Nick Cassara Sent: Monday, July 14, 2014 12:10 AM Subject: Kolb-List: Facet fuel pumps.. Hello Kolb builder, I soon will need to buy a facet fuel pump for my Kolbra. I am wondering what make/style is favorite in the Kolb world? Thanks as always for your input! Nick Cassara Palmer, Alaska = = = = ________________________________________________________________________________
Subject: Firestar II for sale
Date: Jul 14, 2014
$7500 -------- Kirk Smith Columbiaville, MI Firestar II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426633#426633 ________________________________________________________________________________
Subject: Re: Firestar II for sale
Date: Jul 14, 2014
Please send me photos of the fs2 for sale Thanks Daniel H20maule(at)hotmail.com Sent from my iPhone > On Jul 14, 2014, at 10:41 AM, "Kirkds" wrote: > > > $7500 > > -------- > Kirk Smith > Columbiaville, MI > > Firestar II > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426633#426633 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 15, 2014
Larlaeb wrote: > Thanks for the info. I do wish these pictures were a little bigger however. My eyes aren't what they used to be. Here's what you do: When somebody posts a picture that is enormous, and you have to drag the screen back and forth to read the text, or see all of the picture, I go to the top right of the screen and use that little plus/minus thing in the browser to shrink the page down to where I can see the whole picture at once. Of course, you can't read any of the text, but - whatever. The process also works in reverse. You can make the pictures as big as you want, and then the text is really easy to read. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426709#426709 ________________________________________________________________________________
From: terry fivefiveseven <terry557(at)hotmail.com>
Subject: For Sale MZ35, 30 hp, 40 lbs
Date: Jul 15, 2014
Never-run MZ35=2C=0A single cylinder engine by=0A compactradialengines. Manufactured in 2006=2C includes muffler=2C =0A voltage regulator=2C coil=2C solenoid etc. The engine by itself=0A weighs 35 lbs=2C muffler/exhaust is 5lbs. Could work well on a=0A Firefly. Price on current version is listed on=0A website as $3370. Will sell mine for $2500. Contact me directly for more information. ________________________________________________________________________________
Date: Jul 16, 2014
Dragging the OVERSIZED photo to a new folder on your desktop allows quick convenient viewing at a normal size. Label the new folder TEMP so that you will know to dump it when you are done. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426764#426764 ________________________________________________________________________________
Date: Jul 16, 2014
racerjerry wrote: > Dragging the OVERSIZED photo to a new folder on your desktop allows quick convenient viewing at a normal size. Label the new folder TEMP so that you will know to dump it when you are done. Or maybe if people would be kind enough to simply resize their picture to "Large" using the default windows right click on their picture before posting it, none of us would be going through all this rigamarole and wrangling. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426767#426767 ________________________________________________________________________________
Date: Jul 16, 2014
I do agree that some pictures are larger than necessary but reducing them too much loses resolution and detail that can be useful for some things. You can't regain that just by increasing the magnification of the page. My thought would be to just use some judgement as to the size needed to illustrate what you want. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426773#426773 ________________________________________________________________________________
Subject: fill & bleed brakes on kolb
Date: Jul 16, 2014
Procedure for filling then bleeding brakes on kolb mark 3 xtra. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426780#426780 ________________________________________________________________________________
Subject: looking for a landing gear strut on on kolb M 3 xtra
Date: Jul 16, 2014
Looking for a landing gear strut on kolb M 3 xtra. 33" L X 1-3/8 " Dia. Chrome Molly. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426781#426781 ________________________________________________________________________________
Subject: RE: Kolb-List Digest: 2 Msgs - 07/15/14
Date: Jul 16, 2014
> I go to the top right of the screen and use that little plus/minus thing Also try the old -Mouse wheel thingee. GeoB ________________________________________________________________________________
Date: Jul 17, 2014
Subject: Re: looking for a landing gear strut on on kolb M 3 xtra
I have a right side steel landing gear strut for a Kolb Mk III. I beleve it is the same as in the Extra although it was used in a classic. It is 1-1/3 in in dia. and hardened 4130 steel. Ron On 7/16/2014 11:33 AM, barry9315 wrote: > --> Kolb-List message posted by: "barry9315" > > Looking for a landing gear strut on kolb M 3 xtra. 33" L X 1-3/8 " Dia. Chrome Molly. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426781#426781 > > ________________________________________________________________________________
Date: Jul 17, 2014
Sounds perfect. do u mean 1-3/8 " dia? Is it about 33" long? I believe they can be used on either side. what do want for it? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426849#426849 ________________________________________________________________________________
Date: Jul 17, 2014
Yes . It is 1-3/8 " in dia. However, they are not symmetric. There is about 4.5 degrees of toe in in the one I have. I don't know how you measured 33 inches, but depending where you measure from on the axle tube you can see 33". The strut has roughly a 45 degree a bend about 7.5 inches from the axle. I don't remember what I paid for the pair, I'll have to think about it. Where are you located-Shipping? Ron On 7/17/2014 2:03 PM, barry9315 wrote: > --> Kolb-List message posted by: "barry9315" > > Sounds perfect. do u mean 1-3/8 " dia? Is it about 33" long? > I believe they can be used on either side. what do want for it? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426849#426849 > > ________________________________________________________________________________
Date: Jul 17, 2014
Subject: Oil injection?
I have an aquaintence who is buying a Kolb that has a 503 on it with low time. The question is concerning the oil injection that is on it. He has heard some "horror" stories concerning oil injection. I am of the opinion that it is a good thing to have, but I have no real experience with that feature. I would appreciate all comments good or bad about this feature, so that he can make up his mind about whether to leave it on the engine or not. Thanks for all input, Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: Oil injection?
Date: Jul 17, 2014
Larry, Had over 700hrs on my oil injected 503,the first 100 hrs on 100LL av gas. It took 400hrs before the top ring got sticky andI did a decarbon. I loved it a nd have great faith in the Rotax503 engineering team and their oil injection system. G. Aman Sent from my iPhone > On Jul 17, 2014, at 4:59 PM, Larry Cottrell wrot e: > > I have an aquaintence who is buying a Kolb that has a 503 on it with low t ime. The question is concerning the oil injection that is on it. He has hea rd some "horror" stories concerning oil injection. I am of the opinion that i t is a good thing to have, but I have no real experience with that feature. I would appreciate all comments good or bad about this feature, so that he ca n make up his mind about whether to leave it on the engine or not. > Thanks for all input, > Larry > > -- > If you forward this email, or any part of it, please remove my email addre ss before sending. > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Clear Lake Flight Video
Date: Jul 17, 2014
I decided to try a narrated video like Larry and Boyd. This is my first experiment with this and while not very exciting, at least it was fun. Link is below: https://docs.google.com/file/d/0BxdXwdWJkFExSnl5M0lTM3k4bDQ/edit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426865#426865 ________________________________________________________________________________
Date: Jul 17, 2014
I premixed on my first powered parachute with a 582. I now have oil injection on my current machine. I asked the same question on another forum and like the following response best: The 582's oil mixture is a variable ratio mixture and if you disable the injector then you will be running the engine oil rich almost all of the time. When your engine is at idle the oil/fuel ratio is 100:1. When your engine is at full throttle the injector increases the oil volume to a ratio of 50:1. If you mix at 50:1 then you run too much oil at all throttle settings other than wide open. This will cause plugs to prematurely foul and will also cause excessive carbon build up inside the engine. Some people would rather change plugs more often and decarb the engine more frequently but my opinion is that the injector would be better off left alone. Just make certain that when you pre-flight look at the injector and make sure it is opening when you push the throttle to the open position. If it does not open then you will run too lean on oil and eventually burn up the engine, and PLEASE don't ask me how I know that! Let the oil injector work and do the job it was intended to do. I hope to be able to fly fixed wing one day. I have a 630 foot strip at my new property but will need to expand it to 900 feet. I really like PPC but there's something about these STOL capable, wing foldable, and great visibility planes! -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426869#426869 ________________________________________________________________________________
Date: Jul 17, 2014
Subject: Re: Clear Lake Flight Video
I enjoyed it very much, and I wish that others would show us where they fly. The narration makes it so much better. The volume was a bit low, even with headphones, but for a first try I thought it was outstanding. I would be interested is seeing where your camera is mounted and the type of camera that you are using. I tried to use a regular Samsung video camera on my other wing the other day and it was terrible, would not focus, and even with the stabilizer built into the camera was awful. Keep it up, Larry On Thu, Jul 17, 2014 at 6:10 PM, Larlaeb wrote: > > I decided to try a narrated video like Larry and Boyd. This is my first > experiment with this and while not very exciting, at least it was fun. > > Link is below: > > https://docs.google.com/file/d/0BxdXwdWJkFExSnl5M0lTM3k4bDQ/edit > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426865#426865 > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 17, 2014
They are right and left. At least mine were marked for my Mark 3 c. They do not work on the wrong side=0A=0AGary Jindra=0AMark 3C----=0A912UL 240 hours =0A=0A=0AOn Thursday, July 17, 2014 4:54 PM, Ron Hoyt =0A=0AYes . It is 1-3/8 " in dia. However, they are not symmetric. There is =0Aabout 4.5 degrees of toe in in the one I have. I don't know ho w you =0Ameasured 33 inches, but depending where you measure from on the ax le =0Atube you can see 33". The strut has roughly a 45 degree a bend about 7.5 =0Ainches from the axle. I don't remember what I paid for the pair, I'l l =0Ahave to think about it. Where are you located-Shipping?=0ARon=0A=0AOn 7/17/2014 2:03 PM, barry9315 wrote:=0A> -->- Kolb-List message posted by: "barry9315"=0A>=0A> Sounds perfect. do u mean 1-3/8 " dia? Is it about 33" long?=0A> I believe they can be used on either side. - what do want for it?=0A>=0A>=0A>=0A>=0A> Read this topic online here: =0A>=0A> http://forums.matronics.com/viewtopic.php?p=426849#426849=0A>=0A == ________________________________________________________________________________
Subject: video
Date: Jul 17, 2014
I didn=99t get a good one till I tried 4 o4 5 times,,,, and each vid eo had several voice over takes till I got something I could live with,,,, thanks boyd --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Subject: Kolb brakes fittingd
Date: Jul 18, 2014
Does anyone know why my clear brake line is 1/4" and where it attaches with a compression fitting on the caliper takes a 3/16 compression nut. Damdist thing, [/u] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426899#426899 ________________________________________________________________________________
Date: Jul 18, 2014
I bought an overhauled 582 for my Mk 3. The man that owned it before me took his injection off and ran the engine at 90 to 1 all the time. He said that when they overhauled it at 700 hours it looked perfect. The engine builder recommends running it 100 to 1. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426914#426914 ________________________________________________________________________________
Subject: to inject or not to inject...
Date: Jul 19, 2014
Hello Kolb Flyers, I claim Not to be an expert about oil injection, and most other things too. So here is one small data point for you to consider. Many years ago when Johnson came out with a new oil injected 70 hp outboard we were given one to use on a fall project. The oil was in a remote tank in the back of the boat. The cold moved in early that fall and we ended up killing the motor due to Oil starvation.the oil was too cold to flow well. The newer motors soon came out with the injection oil under the cowling, to keep it warm. I hope to fly in cold weather, and even thought I dislike premixing gas and oil. that is what I will be doing; until Airbus sells me an Electric Fan motor to put on my Kolbra!J Enjoy, Nick Palmer, AK ________________________________________________________________________________
Date: Jul 19, 2014
Subject: Re: to inject or not to inject...
Thanks for the comment. I began to wonder if every one mixed their oil, or I was about the only one monitoring it. Larry On Sat, Jul 19, 2014 at 10:43 AM, Nick Cassara wrote: > Hello Kolb Flyers, > > > I claim *Not* to be an expert about oil injection, and most other things > too. So here is one small data point for you to consider. Many years ago > when Johnson came out with a new oil injected 70 hp outboard we were give n > one to use on a fall project. The oil was in a remote tank in the back of > the boat. The cold moved in early that fall and we ended up killing the > motor due to Oil starvationthe oil was too cold to flow well. Th e newer > motors soon came out with the injection oil under the cowling, to keep it > warm. I hope to fly in cold weather, and even thought I dislike premixing > gas and oil that is what I will be doing; until Airbus sells me an > Electric Fan motor to put on my Kolbra!J > > > Enjoy, > > > Nick > > > Palmer, AK > > * > =========== onics.com/Navigator?Kolb-List> =========== =========== om/contribution> =========== > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 19, 2014
lcottrell wrote: > > > ......SNIP..... > I would appreciate all comments good or bad about this feature, so that he can make up his mind about whether to leave it on the engine or not. Thanks for all input, > Larry > Pre-mix. Not a big deal to do it. I have control over what's going into that engine. I fill 6 gal cans with gas and at 50:1, that's a pint of oil. (Oil goes in the can first, then the gas. Gets a good mixing that way.) Required simplicity for a simple mind. A dis-advantage is that it is a little more of a bother if you are fueling at an airport fuel pump. Have to calculate how much oil you need based on how much fuel you are taking on and then making sure the oil gets mixed in well enough. Injection. Just one more mechanical thing that can fail. Don't hear of it often, but you only need once. Based on an incident (I believe at Oshkosh), having the oil tank mounted to the rear of the engine and doing repeated steep climb outs is something that should be avoided. Oil starvation can cause the two stroke to get a little testy and want to quit working. Travis may be able to correct or corroborate this. As Beauford says.... Worth what you paid fer it. -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426956#426956 ________________________________________________________________________________
Date: Jul 19, 2014
Thanks for your thoughts. Larry On Sat, Jul 19, 2014 at 2:57 PM, George Alexander wrote: > > > lcottrell wrote: > > > > > > ......SNIP..... > > I would appreciate all comments good or bad about this feature, so that > he can make up his mind about whether to leave it on the engine or not. > Thanks for all input, > > Larry > > > > > Pre-mix. > Not a big deal to do it. I have control over what's going into that > engine. I fill 6 gal cans with gas and at 50:1, that's a pint of oil. (Oil > goes in the can first, then the gas. Gets a good mixing that way.) > Required simplicity for a simple mind. A dis-advantage is that it is a > little more of a bother if you are fueling at an airport fuel pump. Have > to calculate how much oil you need based on how much fuel you are taking on > and then making sure the oil gets mixed in well enough. > > Injection. > Just one more mechanical thing that can fail. Don't hear of it often, but > you only need once. Based on an incident (I believe at Oshkosh), having > the oil tank mounted to the rear of the engine and doing repeated steep > climb outs is something that should be avoided. Oil starvation can cause > the two stroke to get a little testy and want to quit working. Travis may > be able to correct or corroborate this. > > As Beauford says.... Worth what you paid fer it. > > -------- > George Alexander > FS II R503 N709FS > http://www.oh2fly.net > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426956#426956 > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 19, 2014
I had an oil injection on a snow Mobile go bad. Twice. Had to rebuild twice... changed to pre mix and never looked back Boyd On Jul 19, 2014 3:00 PM, "George Alexander" wrote: > > > lcottrell wrote: > > > > > > ......SNIP..... > > I would appreciate all comments good or bad about this feature, so that > he can make up his mind about whether to leave it on the engine or not. > Thanks for all input, > > Larry > > > > > Pre-mix. > Not a big deal to do it. I have control over what's going into that > engine. I fill 6 gal cans with gas and at 50:1, that's a pint of oil. (Oil > goes in the can first, then the gas. Gets a good mixing that way.) > Required simplicity for a simple mind. A dis-advantage is that it is a > little more of a bother if you are fueling at an airport fuel pump. Have > to calculate how much oil you need based on how much fuel you are taking on > and then making sure the oil gets mixed in well enough. > > Injection. > Just one more mechanical thing that can fail. Don't hear of it often, but > you only need once. Based on an incident (I believe at Oshkosh), having > the oil tank mounted to the rear of the engine and doing repeated steep > climb outs is something that should be avoided. Oil starvation can cause > the two stroke to get a little testy and want to quit working. Travis may > be able to correct or corroborate this. > > As Beauford says.... Worth what you paid fer it. > > -------- > George Alexander > FS II R503 N709FS > http://www.oh2fly.net > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426956#426956 > > ________________________________________________________________________________
Subject: Kolb STOL
Date: Jul 19, 2014
Can a Kolb Mark 3 take off like other STOL aircraft? I have been watching youtube videos on short takeoffs. Lots of Zenith, Kitfox, and Cubs. Is is just because their are less Kolb out there? -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426985#426985 ________________________________________________________________________________
Date: Jul 20, 2014
A very timely discussion. After a short flight yesterday, I found oil all over the front of the engine. One of the delivery lines from the oil pump had cracked open at the fitting on the pump. Sure lucky it wasn't a longer flight..... New lines on order..... JG ________________________________________________________________________________
Date: Jul 20, 2014
OK now. For disenting opinion on oil injection. Think of this scenario, you are on a long climb out, you pull the throttle back and that small moment where you go lean and egt's spike. With oil injection you still have good oil flowing because your throttle setting is still pretty high, with premix you just went lean on oil too. Or on an unloaded engine set at say 4500 for a decent but the prop is unloaded so the engine isn't using much fuel, hence not much oil. The Reason rotax was able to get them ASTM certified was because of the oil injection. Do your maintenance, check cable is moving the oil pump lever on your preflight, annually check the shaft that drives the pump, maybe replace the pump annually if you want to and you will love your oil injection. It gets a bad rap from older setups like the remote oil tank on early evinrude/johnson outboards. Suzuki has always had the oil tank above the pump and probably has never had lube failures? OR jet ski folks who just never added oil to the tank. That Mikuni oil pump is well proven. BUT don't trust the stained oil level mark in the tank, look inside. And monitor your oil usage to your fuel used and calculate your fuel to oil ratio. If so I bet you will never have problems. I love the oil injection, but of course I fly a lot. But I'm still an old guy from the premix days but I learned. Thanks for listening, Dennis -------- Dennis Long Oakland TN 2000 Aeroprakt A20 Vista Cruiser Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar. 700+hours since 1/1/2009 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427005#427005 ________________________________________________________________________________
Date: Jul 20, 2014
I flew 785.0 hours on premixed fuel, back in the 80's. On flights to the NE US with my 447 powered FS. I carried 12 quarts of Pennzoil for air cooled engines. This was before Rotax recommended two stroke oil for air cooled engines. Could not buy it locally. Made contact with the SE US Pennzoil distributor to work out a plan to drop ship cases of Pennzoil Air Cooled Oil to the Jiffy Lube in Montgomery, AL. Only had one problem on cross country flights. Refueled at Norwich, NY. Dumped in the amount of oil I needed, topped off with 100LL, and took off. Low power on climb out. Looked behind me and saw a smoke screen. Pulled the enricher full open. That gave me enough power to do a 180 and land. Big mistake when I refueled. I forgot to rock the FS back and forth to mix the oil. All the oil was in the bottom of the tank. My float bowl was full of oil. In 1992, I originally powered my newly constructed MKIII with a 582. Used oil injection and loved it. Saved a lot of oil. Simplified cross country flying. Put 225.0 hours on the 582 before I swapped it out of a 912 in 1993. If I was flying a two stroke, I would fly it with the oil injection. I believe to inject or not is a personal decision. Really doesn't matter one way or the other. Sorry for the late reply. First WIFI in a while. john h mkIII Rifle, Colorado ________________________________________________________________________________
Subject: Kolb STOL
Date: Jul 20, 2014
This is not a take off, but a short field landing: http://www.youtube.com/watch?v=oMYsdarPcnY Here's a takeoff and landing: http://www.youtube.com/watch?v=TXmqZBeWOrs Kolbs are great super STOL aircraft. john h mkIII Rifle, Colorado -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of alienwes Sent: Saturday, July 19, 2014 10:18 PM Subject: Kolb-List: Kolb STOL Can a Kolb Mark 3 take off like other STOL aircraft? I have been watching youtube videos on short takeoffs. Lots of Zenith, Kitfox, and Cubs. Is is just because their are less Kolb out there? -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426985#426985 = Photoshare, and much much more: = = = ________________________________________________________________________________
Subject: RE: to inject or not to inject...
Date: Jul 20, 2014
My only experience with oil injection was years ago on 2-stroke motorcycles. I loved it. I used far less oil, I kept my hands clean when fueling, the engine carboned up less. I am interested in using it on my 447 or 503. OPTIONAL (off-topic): Years ago I bought a Rototiller at a yard sale. Huge heavy thing, self-propelled, gear box, built like they usta build. Cast iron, etc. It had a big single cyl engine under a cowling in front. So, I used the thing a few times, it ran great, it was quite a machine. After a while I figgered I'd check the valve lash, change the oil, etc. Tore into it, to my surprise it was a 2-stroke! Yeah, I know, makes me sound dumb. But it ran so slow and had such torque. So after a few hours of operation I finally started giving it oil in the gas. No apparent damage. ________________________________________________________________________________
Subject: Re: Kolb STOL
Date: Jul 20, 2014
John, thanks for the links to your videos. I bet your were off the ground in under 200 feet. Is that a 912 100 hp? Frank, thanks for sharing your experiences and how you shoot approaches. -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427031#427031 ________________________________________________________________________________
Date: Jul 20, 2014
Subject: Re: RE: to inject or not to inject...
Hi guys,=0A=0AMy only Rotax 2-cycle experience is on a 503 with injection. - My Firestar has over 500 hours on it and the injection system has perfo rmed faultlessly.- I suspect the injection system is responsible for long plug life and reduced oil expense.- I have had no problems in cold weath er.=0A=0AJon L=0AMinnesota=0A=0A=0A=0AOn Sunday, July 20, 2014 9:21 PM, Geo rge Bearden wrote:=0A =0A=0A=0A--> Kolb-List message posted by: "George Bearden" =0A=0AMy only experience w ith oil injection was years ago on 2-stroke motorcycles.=0AI loved it. I us ed far less oil, I kept my hands clean when fueling, the=0Aengine carboned up less. I am interested in using it on my 447 or 503.=0A=0AOPTIONAL (off-t opic):=0A=0AYears ago I bought a Rototiller at a yard sale. Huge heavy thin g,=0Aself-propelled, gear box, built like they usta build. Cast iron, etc. It had=0Aa big single cyl engine under a cowling in front. So, I used the t hing a few=0Atimes, it ran great, it was quite a machine. After a while I f iggered I'd=0Acheck the valve lash, change the oil, etc. Tore into it, to m y surprise it=0Awas a 2-stroke!- Yeah, I know, makes me sound dumb. But i t ran so slow and=0Ahad such torque. So after a few hours of operation I fi nally started giving=0Ait oil in the gas. No apparent damage.=0A=0A=0A=0A ============== ________________________________________________________________________________
Date: Jul 21, 2014
Subject: Alvord video
The smoke finally cleared enough that I could make a trip to the Alvord. I had been trying since Friday to get over there, but the smoke from the fires was just too heavy. It finally cleared today. https://vimeo.com/101271886 -password - owyheeflyer Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 21, 2014
To clarify, I really like the oil injection as well, but would add another item of maintenance, after my last experience with the broken oil line. Any such plastic/nylon/rubber lines carrying oil or fuel and exposed to the weather need to be replaced regularly, even if they still look OK. JG ________________________________________________________________________________
Date: Jul 21, 2014
Thanks to all of you for your insights and information. Like most things, simple is better and as close to foolproof as possible. As with most things however maintenence is the main solution. Larry On Mon, Jul 21, 2014 at 6:49 AM, JC Gilpin wrote: > To clarify, I really like the oil injection as well, but would add another > item of maintenance, after my last experience with the broken oil line. > Any such plastic/nylon/rubber lines carrying oil or fuel and exposed to > the weather need to be replaced regularly, even if they still look OK. > > JG > > * > > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 21, 2014
Wes: Yes, 100hp 912ULS. Those of us that have flown the Kolbs a bit forget what it is like to fly other aircraft. We get used to the great performance and forgiving attitude Homer Kolb designed into them. john h mkIII Lake City, Colorado -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of alienwes Sent: Sunday, July 20, 2014 9:12 PM Subject: Kolb-List: Re: Kolb STOL John, thanks for the links to your videos. I bet your were off the ground in under 200 feet. Is that a 912 100 hp? Frank, thanks for sharing your experiences and how you shoot approaches. -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427031#427031 = Photoshare, and much much more: = = = ________________________________________________________________________________
Date: Jul 21, 2014
For every failure of oil injection there is probably a failure of the pilot to remember to add oil when pre-mixing. -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427090#427090 ________________________________________________________________________________
Date: Jul 21, 2014
In my Firestar 2 503 oil injected over 700 hrs, the first 100 on 100LL.Did a de-carbon at 450hrs when the top ring got sticky at inspection time.I hav e lots of faith in the Rotax engineers that developed the oil -injection sy stem. G.Aman FS-2 700hrs MK-3 Jabiru 2200A 850 hrs -----Original Message----- From: George Bearden <gab16(at)sbcglobal.net> Sent: Sun, Jul 20, 2014 10:20 pm Subject: Kolb-List: RE: to inject or not to inject... My only experience with oil injection was years ago on 2-stroke motorcycles . I loved it. I used far less oil, I kept my hands clean when fueling, the engine carboned up less. I am interested in using it on my 447 or 503. OPTIONAL (off-topic): Years ago I bought a Rototiller at a yard sale. Huge heavy thing, self-propelled, gear box, built like they usta build. Cast iron, etc. It ha d a big single cyl engine under a cowling in front. So, I used the thing a fe w times, it ran great, it was quite a machine. After a while I figgered I'd check the valve lash, change the oil, etc. Tore into it, to my surprise it was a 2-stroke! Yeah, I know, makes me sound dumb. But it ran so slow and had such torque. So after a few hours of operation I finally started giving it oil in the gas. No apparent damage. ________________________________________________________________________________
Date: Jul 21, 2014
Hi everyone: This subject of oil injection is pretty timely since I'm on the verge of installing an injection unit on a Rotax 503 DCDI. It seems to be pretty straightforward but there is also a problem. I use prime instead of manual choke on the 503 to get it started and the prime line goes to the nipple on each intake manifold. That seems to be the same place where the oil lines have to go also. Can anyone suggest a workaround? Would a tee fitting work? Does the manifold need another nipple? Thanks for any help anyone can give. Frank Fanelli On 7/21/2014 7:37 PM, Gary Aman wrote: > In my Firestar 2 503 oil injected over 700 hrs, the first 100 on > 100LL.Did a de-carbon at 450hrs when the top ring got sticky at > inspection time.I have lots of faith in the Rotax engineers that > developed the oil -injection system. > G.Aman FS-2 700hrs MK-3 Jabiru 2200A 850 hrs > > > -----Original Message----- > From: George Bearden <gab16(at)sbcglobal.net> > To: kolb-list > Sent: Sun, Jul 20, 2014 10:20 pm > Subject: Kolb-List: RE: to inject or not to inject... > > --> Kolb-List message posted by: "George Bearden"> > > My only experience with oil injection was years ago on 2-stroke motorcycles. > I loved it. I used far less oil, I kept my hands clean when fueling, the > engine carboned up less. I am interested in using it on my 447 or 503. > > OPTIONAL (off-topic): > > Years ago I bought a Rototiller at a yard sale. Huge heavy thing, > self-propelled, gear box, built like they usta build. Cast iron, etc. It had > a big single cyl engine under a cowling in front. So, I used the thing a few > times, it ran great, it was quite a machine. After a while I figgered I'd > check the valve lash, change the oil, etc. Tore into it, to my surprise it > was a 2-stroke! Yeah, I know, makes me sound dumb. But it ran so slow and > had such torque. So after a few hours of operation I finally started giving > it oil in the gas. No apparent damage. > > > get="_blank">http://www.matronics.com/Navigator?Kolb-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > * > > > * ________________________________________________________________________________
Date: Jul 22, 2014
Subject: RE: Kolb-List Digest: 6 Msgs - 07/21/14
Prime lines go to the carbs. Injection lines go to the manifolds Sent from my U.S. Cellular=C2=AE Smartphone <div>-------- Original message --------</div><div>From: Kolb-List Digest Se rver
Date:07/22/2014 2:08 AM (GMT-06 :00)
To: Kolb-List Digest List
Subject: Kolb-List Digest: 6 Msgs - 07/21/14
* ======================== Online Versions of Today's List Digest Archive ======================== Today's complete Kolb-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Kolb-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=htm l&Chapter 14-07-21&Archive=Kolb Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt &Chapter 14-07-21&Archive=Kolb ======================== ======================= EMail Version of Today's List Digest Archive ======================== ======================= ---------------------------------------------------------- Kolb-List Digest Archive --- Total Messages Posted Mon 07/21/14: 6 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 05:50 AM - Re: Oil injection? (JC Gilpin) 2. 06:20 AM - Re: Re: Oil injection? (Larry Cottrell) 3. 08:45 AM - Re: Re: Kolb STOL (John Hauck) 4. 03:13 PM - Re: Oil injection? (alienwes) 5. 04:37 PM - Re: Re: to inject or not to inject... (Gary Aman) 6. 06:06 PM - Re: Re: to inject or not to inject... (Frank Fanelli) ________________________________ Message 1 ______________________________ _______ Subject: Kolb-List: Re: Oil injection? From: JC Gilpin <j.gilpin(at)bigpond.com> To clarify=2C I really like the oil injection as well=2C but would add anot her item of maintenance=2C after my last experience with the broken oil line. Any such plastic/nylon/rubber lines carrying oil or fuel and exposed to the weather need to be replaced regularly=2C even if they still look OK. JG ________________________________ Message 2 ______________________________ _______ Subject: Re: Kolb-List: Re: Oil injection? From: Larry Cottrell <lcottrell1020(at)gmail.com> Thanks to all of you for your insights and information. Like most things =2C simple is better and as close to foolproof as possible. As with most things however maintenence is the main solution. Larry On Mon=2C Jul 21=2C 2014 at 6:49 AM=2C JC Gilpin wro te: > To clarify=2C I really like the oil injection as well=2C but would add an other > item of maintenance=2C after my last experience with the broken oil line. > Any such plastic/nylon/rubber lines carrying oil or fuel and exposed to > the weather need to be replaced regularly=2C even if they still look OK. > > JG > > * > > > * > > -- *If you forward this email=2C or any part of it=2C please remove my email address before sending.* ________________________________ Message 3 ______________________________ _______ From: "John Hauck" <jhauck(at)elmore.rr.com> Subject: RE: Kolb-List: Re: Kolb STOL Wes: Yes=2C 100hp 912ULS. Those of us that have flown the Kolbs a bit forget what it is like to fly other aircraft. We get used to the great performance and forgiving attitude Homer Kolb designed into them. john h mkIII Lake City=2C Colorado -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of alienwes Sent: Sunday=2C July 20=2C 2014 9:12 PM Subject: Kolb-List: Re: Kolb STOL John=2C thanks for the links to your videos. I bet your were off the ground in under 200 feet. Is that a 912 100 hp? Frank=2C thanks for sharing your experiences and how you shoot approaches. -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427031#427031 Photoshare=2C and much much more: ________________________________ Message 4 ______________________________ _______ Subject: Kolb-List: Re: Oil injection? From: "alienwes" <elliott.wesley(at)yahoo.com> For every failure of oil injection there is probably a failure of the pilot to remember to add oil when pre-mixing. -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427090#427090 ________________________________ Message 5 ______________________________ _______ Subject: Re: Kolb-List: RE: to inject or not to inject... From: Gary Aman <zeprep251(at)aol.com> In my Firestar 2 503 oil injected over 700 hrs=2C the first 100 on 100LL.Di d a de-carbon at 450hrs when the top ring got sticky at inspection time.I hav e lots of faith in the Rotax engineers that developed the oil -injection sy stem. G.Aman FS-2 700hrs MK-3 Jabiru 2200A 850 hrs -----Original Message----- From: George Bearden <gab16(at)sbcglobal.net> Sent: Sun=2C Jul 20=2C 2014 10:20 pm Subject: Kolb-List: RE: to inject or not to inject... My only experience with oil injection was years ago on 2-stroke motorcycles .. I loved it. I used far less oil=2C I kept my hands clean when fueling=2C th e engine carboned up less. I am interested in using it on my 447 or 503. OPTIONAL (off-topic): Years ago I bought a Rototiller at a yard sale. Huge heavy thing=2C self-propelled=2C gear box=2C built like they usta build. Cast iron=2C etc. It ha d a big single cyl engine under a cowling in front. So=2C I used the thing a fe w times=2C it ran great=2C it was quite a machine. After a while I figgered I 'd check the valve lash=2C change the oil=2C etc. Tore into it=2C to my surpri se it was a 2-stroke! Yeah=2C I know=2C makes me sound dumb. But it ran so slow and had such torque. So after a few hours of operation I finally started giving it oil in the gas. No apparent damage. ________________________________ Message 6 ______________________________ _______ From: Frank Fanelli <frankf@flying-models.com> Subject: Re: Kolb-List: RE: to inject or not to inject... Hi everyone: This subject of oil injection is pretty timely since I'm on the verge of installing an injection unit on a Rotax 503 DCDI. It seems to be pretty straightforward but there is also a problem. I use prime instead of manual choke on the 503 to get it started and the prime line goes to the nipple on each intake manifold. That seems to be the same place where the oil lines have to go also. Can anyone suggest a workaround? Would a tee fitting work? Does the manifold need another nipple? Thanks for any help anyone can give. Frank Fanelli On 7/21/2014 7:37 PM=2C Gary Aman wrote: > In my Firestar 2 503 oil injected over 700 hrs=2C the first 100 on > 100LL.Did a de-carbon at 450hrs when the top ring got sticky at > inspection time.I have lots of faith in the Rotax engineers that > developed the oil -injection system. > G.Aman FS-2 700hrs MK-3 Jabiru 2200A 850 hrs > > > -----Original Message----- > From: George Bearden <gab16(at)sbcglobal.net> > To: kolb-list > Sent: Sun=2C Jul 20=2C 2014 10:20 pm > Subject: Kolb-List: RE: to inject or not to inject... > > --> Kolb-List message posted by: "George Bearden"> > > My only experience with oil injection was years ago on 2-stroke motorcycl es. > I loved it. I used far less oil=2C I kept my hands clean when fueling=2C the > engine carboned up less. I am interested in using it on my 447 or 503. > > OPTIONAL (off-topic): > > Years ago I bought a Rototiller at a yard sale. Huge heavy thing=2C > self-propelled=2C gear box=2C built like they usta build. Cast iron=2C et c. It had > a big single cyl engine under a cowling in front. So=2C I used the thing a few > times=2C it ran great=2C it was quite a machine. After a while I figgered I'd > check the valve lash=2C change the oil=2C etc. Tore into it=2C to my surp rise it > was a 2-stroke! Yeah=2C I know=2C makes me sound dumb. But it ran so slo w and > had such torque. So after a few hours of operation I finally started givi ng > it oil in the gas. No apparent damage. > > > get="_blank">http://www.matronics.com/Navigator?Kolb-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > * > > > * ________________________________________________________________________________
Date: Jul 22, 2014
Frank,it needs another nipple,it's on the bottom of the manifold Sent from my iPhone > On Jul 21, 2014, at 7:05 PM, Frank Fanelli <frankf@flying-models.com> wrot e: > > Hi everyone: > > This subject of oil injection is pretty timely since I'm on the verge of i nstalling an injection unit on a Rotax 503 DCDI. It seems to be pretty strai ghtforward but there is also a problem. I use prime instead of manual choke o n the 503 to get it started and the prime line goes to the nipple on each in take manifold. That seems to be the same place where the oil lines have to g o also. Can anyone suggest a workaround? Would a tee fitting work? Does the m anifold need another nipple? > > Thanks for any help anyone can give. > > Frank Fanelli > > > >> On 7/21/2014 7:37 PM, Gary Aman wrote: >> In my Firestar 2 503 oil injected over 700 hrs, the first 100 on 100LL.Di d a de-carbon at 450hrs when the top ring got sticky at inspection time.I ha ve lots of faith in the Rotax engineers that developed the oil -injection sy stem. >> G.Aman FS-2 700hrs MK-3 Jabiru 2200A 850 hrs >> >> >> >> -----Original Message----- >> From: George Bearden <gab16(at)sbcglobal.net> >> To: kolb-list >> Sent: Sun, Jul 20, 2014 10:20 pm >> Subject: Kolb-List: RE: to inject or not to inject... >> >> >> My only experience with oil injection was years ago on 2-stroke motorcycl es. >> I loved it. I used far less oil, I kept my hands clean when fueling, the >> engine carboned up less. I am interested in using it on my 447 or 503. >> >> OPTIONAL (off-topic): >> >> Years ago I bought a Rototiller at a yard sale. Huge heavy thing, >> self-propelled, gear box, built like they usta build. Cast iron, etc. It h ad >> a big single cyl engine under a cowling in front. So, I used the thing a f ew >> times, it ran great, it was quite a machine. After a while I figgered I'd >> check the valve lash, change the oil, etc. Tore into it, to my surprise i t >> was a 2-stroke! Yeah, I know, makes me sound dumb. But it ran so slow an d >> had such torque. So after a few hours of operation I finally started givi ng >> it oil in the gas. No apparent damage. >> >> >> >> >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> >> >> >> >> ========================== ========= ========================== ========= ========================== ========= ========================== ========= >> ________________________________________________________________________________
Date: Jul 22, 2014
The prime nipple is on the carb Sent from my iPhone > On Jul 21, 2014, at 7:05 PM, Frank Fanelli <frankf@flying-models.com> wrot e: > > Hi everyone: > > This subject of oil injection is pretty timely since I'm on the verge of i nstalling an injection unit on a Rotax 503 DCDI. It seems to be pretty strai ghtforward but there is also a problem. I use prime instead of manual choke o n the 503 to get it started and the prime line goes to the nipple on each in take manifold. That seems to be the same place where the oil lines have to g o also. Can anyone suggest a workaround? Would a tee fitting work? Does the m anifold need another nipple? > > Thanks for any help anyone can give. > > Frank Fanelli > > > >> On 7/21/2014 7:37 PM, Gary Aman wrote: >> In my Firestar 2 503 oil injected over 700 hrs, the first 100 on 100LL.Di d a de-carbon at 450hrs when the top ring got sticky at inspection time.I ha ve lots of faith in the Rotax engineers that developed the oil -injection sy stem. >> G.Aman FS-2 700hrs MK-3 Jabiru 2200A 850 hrs >> >> >> >> -----Original Message----- >> From: George Bearden <gab16(at)sbcglobal.net> >> To: kolb-list >> Sent: Sun, Jul 20, 2014 10:20 pm >> Subject: Kolb-List: RE: to inject or not to inject... >> >> >> My only experience with oil injection was years ago on 2-stroke motorcycl es. >> I loved it. I used far less oil, I kept my hands clean when fueling, the >> engine carboned up less. I am interested in using it on my 447 or 503. >> >> OPTIONAL (off-topic): >> >> Years ago I bought a Rototiller at a yard sale. Huge heavy thing, >> self-propelled, gear box, built like they usta build. Cast iron, etc. It h ad >> a big single cyl engine under a cowling in front. So, I used the thing a f ew >> times, it ran great, it was quite a machine. After a while I figgered I'd >> check the valve lash, change the oil, etc. Tore into it, to my surprise i t >> was a 2-stroke! Yeah, I know, makes me sound dumb. But it ran so slow an d >> had such torque. So after a few hours of operation I finally started givi ng >> it oil in the gas. No apparent damage. >> >> >> >> >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> >> >> >> >> ========================== ========= ========================== ========= ========================== ========= ========================== ========= >> ________________________________________________________________________________
Date: Jul 22, 2014
I have a question. On an engine with oil injection, as you add or retard the throttle aren't you adding or retarding oil in roughly the same ratio from idle to full throttle and back? If you are suppose to run 50 to 1, wont you be at about that setting regardless of throttle position? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427182#427182 ________________________________________________________________________________
Date: Jul 22, 2014
RGVsaXZlcnkgaXNuJ3QgbGluZWFyLCBtdWNoIHRoZSBzYW1lIGFzIHlvdXIgY2FyYiBpc24ndCBs aW5lYXIsIGVpdGhlciAobmVlZGxlIGpldC8gamV0IG5lZWRsZSkuCgpKaW0gQmFrZXIKNDA1LjQy Ni41Mzc3CgotLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQpGcm9tOiBwaXBlcmNvbHQgPGJvYi5w aXBlcmNvbHRAeWFob28uY29tPgpUbzoga29sYi1saXN0QG1hdHJvbmljcy5jb20KU2VudDogVHVl LCAyMiBKdWwgMjAxNCAxOTowMwpTdWJqZWN0OiBLb2xiLUxpc3Q6IFJlOiBPaWwgaW5qZWN0aW9u PwoKLS0+IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogInBpcGVyY29sdCIgPGJvYi5waXBl cmNvbHRAeWFob28uY29tPgoKSSBoYXZlIGEgcXVlc3Rpb24uIE9uIGFuIGVuZ2luZSB3aXRoIG9p bCBpbmplY3Rpb24sIGFzIHlvdSBhZGQgb3IgcmV0YXJkIHRoZSB0aHJvdHRsZSBhcmVuJ3QgeW91 IGFkZGluZyBvciByZXRhcmRpbmcgb2lsIGluIHJvdWdobHkgdGhlIHNhbWUgcmF0aW8gZnJvbSBp ZGxlIHRvIGZ1bGwgdGhyb3R0bGUgYW5kIGJhY2s/IElmIHlvdSBhcmUgc3VwcG9zZSB0byBydW4g NTAgdG8gMSwgd29udCB5b3UgYmUgYXQgYWJvdXQgdGhhdCBzZXR0aW5nIHJlZ2FyZGxlc3Mgb2Yg dGhyb3R0bGUgcG9zaXRpb24/CgoKCgpSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6CgpodHRw Oi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTQyNzE4MiM0MjcxODIKCgoK CgoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRoZSBLb2xiLUxpc3QgRW1haWwgRm9ydW0gLQpfLT0g VXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0 aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLApfLT0g QXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQ aG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT0gICAtLT4gaHR0cDovL3d3dy5t YXRyb25pY3MuY29tL05hdmlnYXRvcj9Lb2xiLUxpc3QKXy09Cl8tPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAg ICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28g YXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyEKXy09Cl8tPSAgIC0tPiBodHRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20KXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0 aW9uIFdlYiBTaXRlIC0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEK Xy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWlu LgpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQoK CgoK ________________________________________________________________________________
Date: Jul 23, 2014
Study your 503 operators manual. Follow the instructions for starting a cold and a warm 503 using the enricher. Next remove the primer system. It is not necessary and poses additional chance for fire if you crash. I have never had a problem starting a Rotax two stroke in the winter with the enricher only. That goes for the 912 series engines as well. My opinion only. It works for me. john h Lake City, Colorado From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Frank Fanelli Sent: Monday, July 21, 2014 7:05 PM Subject: Re: Kolb-List: RE: to inject or not to inject... Hi everyone: This subject of oil injection is pretty timely since I'm on the verge of installing an injection unit on a Rotax 503 DCDI. It seems to be pretty straightforward but there is also a problem. I use prime instead of manual choke on the 503 to get it started and the prime line goes to the nipple on each intake manifold. That seems to be the same place where the oil lines have to go also. Can anyone suggest a workaround? Would a tee fitting work? Does the manifold need another nipple? Thanks for any help anyone can give. Frank Fanelli On 7/21/2014 7:37 PM, Gary Aman wrote: In my Firestar 2 503 oil injected over 700 hrs, the first 100 on 100LL.Did a de-carbon at 450hrs when the top ring got sticky at inspection time.I have lots of faith in the Rotax engineers that developed the oil -injection system. G.Aman FS-2 700hrs MK-3 Jabiru 2200A 850 hrs -----Original Message----- From: George Bearden <mailto:gab16(at)sbcglobal.net> Sent: Sun, Jul 20, 2014 10:20 pm Subject: Kolb-List: RE: to inject or not to inject... My only experience with oil injection was years ago on 2-stroke motorcycles. I loved it. I used far less oil, I kept my hands clean when fueling, the engine carboned up less. I am interested in using it on my 447 or 503. OPTIONAL (off-topic): Years ago I bought a Rototiller at a yard sale. Huge heavy thing, self-propelled, gear box, built like they usta build. Cast iron, etc. It had a big single cyl engine under a cowling in front. So, I used the thing a few times, it ran great, it was quite a machine. After a while I figgered I'd check the valve lash, change the oil, etc. Tore into it, to my surprise it was a 2-stroke! Yeah, I know, makes me sound dumb. But it ran so slow and had such torque. So after a few hours of operation I finally started giving it oil in the gas. No apparent damage. get="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution = = = = ________________________________________________________________________________
Subject: Re: Alternative Tail Wheel Steering System
Date: Jul 23, 2014
Would love to see a few pics of the tail wheelcompression springs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427213#427213 ________________________________________________________________________________
Subject: Wing hinge size...?
Date: Jul 23, 2014
Hello builder, Does someone know what size piano hinges are on the Mark lll wing? I am drilling hinges and realized I have size MS20057-5 and -6..plans just say "wing hinges". Thanks, Nick Cassara ________________________________________________________________________________
Date: Jul 23, 2014
I went to compression springs also but had to disassemble them and pinch the inside hooks to clear the spring I.D. so they would extend freely. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427234#427234 ________________________________________________________________________________
Date: Jul 23, 2014
Hi Barry, Here's a shot of the compression springs (other side is the same, of course) on the FlagFly. Also shows a wider tail wheel to replace pizza cutter. Dave Kulp Bethlehem, PA 11DMK On 7/23/2014 1:32 PM, barry9315 wrote: > > Would love to see a few pics of the tail wheelcompression springs > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427213#427213 > > --- This email is free from viruses and malware because avast! Antivirus protection is active. http://www.avast.com ________________________________________________________________________________
Date: Jul 23, 2014
Thanks James. If Rotax recommends running the engine at 50 to 1, at what power setting is that? Is it an average? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427244#427244 ________________________________________________________________________________
Date: Jul 23, 2014
Rmlyc3QuLi4uCgp3d3cucm90YXgtYWlyY3JhZnQtZW5naW5lcy5jb20vcG9ydGFsZGF0YS81L2Rv a3VzL2QwMjkzOS5wZGYKCllhIGtub3csIGluIGFsbCB0aGUgeWVhcnMgSSd2ZSB3b3JrZWQgdHdv IHN0cm9rZXMgd2l0aCBwdW1wcywgSSBjYW4ndCByZWNhbGwgc2VlaW5nIGEgZmxvdyByYXRlIGNo YXJ0IGZvciBvbmUuIEkgd291bGQgdGhpbmsgaXQgd291bGQgYmUgYSBrbm93biBpdGVtLi4uLi5w ZXJoYXBzIHNvbWVvbmUgZWxzZSBoYXMgc2VlbiBvbmUuIFRoZSBsaW5rIGFib3ZlIGp1c3Qgc2F5 cyB0byBtYWtlIHN1cmUgdGhhdCB5b3UgY2hlY2sgdGhhdCBvaWwgY29uc3VtcHRpb24gaXMgaW4g dGhlIDUwOjEgdG8gNzA6MSByYW5nZS4uLi4ubWlnaHQgYmUgdG9vIGxhdGUgdG8gc2F2ZSBhbiBl bmdpbmUgYnkgdGhlIHRpbWUgdGhhdCB3YXMga25vd24uIFNldCB1cCB0aGUgcHVtcCBwZXIgaW5z dHJ1Y3Rpb25zIGFuZCB5b3Ugc2hvdWxkIGJlIE9LLgoKIEkndmUgYWx3YXlzIHByZW1peGVkIGFu ZCBzaW5jZSAyMDAwIGhhdmUgYmVlbiBydW5uaW5nIGV2ZXJ5IHR3byBzdHJva2UgSSBvd24gYXQg MTAwOjEgd2l0aCBhbiBvaWwgZGVzaWduZWQgZm9yIHNhbWUuIFdvbid0IG1lbnRpb24gd2hpY2gg b25lIGJlY2F1c2UgaXRzIGlycmVsZXZhbnQuLi4uLmxvdHMgb2YgZ29vZCAxMDA6MSBwcm9kdWN0 cyBvdXQgdGhlcmUuIE9uIG15IFVMIEkgaGF2ZSBuZXZlciBjaGFuZ2VkIHRoZSBwbHVncyBvciBk b25lIGEgZGUtY29rZSBvZiB0aGUgdG9wIGVuZC4gTm8gbmVlZCBhcyB0aGUgcGx1Z3MgYXJlIGFz IHRhbiBhcyBhIGZvdXIgc3Ryb2tlLiBUaGF0J3MganVzdCBteSBtaWxlYWdlLi4ueW91IG1heSBu b3QgYmUgY29tZm9ydGFibGUgd2l0aCB0aGlzIG1ldGhvZG9sb2d5CgpKaW0gQmFrZXIKCi0tLS0t T3JpZ2luYWwgTWVzc2FnZS0tLS0tCkZyb206IHBpcGVyY29sdCA8Ym9iLnBpcGVyY29sdEB5YWhv by5jb20+ClRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQpTZW50OiBXZWQsIDIzIEp1bCAyMDE0 IDIwOjE4ClN1YmplY3Q6IEtvbGItTGlzdDogUmU6IE9pbCBpbmplY3Rpb24/CgotLT4gS29sYi1M aXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAicGlwZXJjb2x0IiA8Ym9iLnBpcGVyY29sdEB5YWhvby5j b20+CgpUaGFua3MgSmFtZXMuIElmIFJvdGF4IHJlY29tbWVuZHMgcnVubmluZyB0aGUgZW5naW5l IGF0IDUwIHRvIDEsIGF0IHdoYXQgcG93ZXIgc2V0dGluZyBpcyB0aGF0PyBJcyBpdCBhbiBhdmVy YWdlPwoKCgoKUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOgoKaHR0cDovL2ZvcnVtcy5tYXRy b25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD00MjcyNDQjNDI3MjQ0CgoKCgoKCgpfLT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0g ICAgICAgICAgLSBUaGUgS29sYi1MaXN0IEVtYWlsIEZvcnVtIC0KXy09IFVzZSB0aGUgTWF0cm9u aWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1 dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwKXy09IEFyY2hpdmUgU2VhcmNo ICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLApfLT0gUGhvdG9zaGFyZSwgYW5k IG11Y2ggbXVjaCBtb3JlOgpfLT0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9O YXZpZ2F0b3I/S29sYi1MaXN0Cl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklD UyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEg dGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29t Cl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAt Cl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0 dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24KXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KCgoKCg= ________________________________________________________________________________
Date: Jul 23, 2014
It's just like a chainsaw, or two stroke MX bike, weed whacker, leaf blower, whatever, mix a good oil at the manufacturer suggested ratio and let her rip. Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA > On Jul 23, 2014, at 8:18 PM, "pipercolt" wrote: > > > Thanks James. If Rotax recommends running the engine at 50 to 1, at what power setting is that? Is it an average? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427244#427244 > > > > > > > > > > ________________________________________________________________________________
Subject: FW: Rotax Releases two updated Service Letters
Date: Jul 24, 2014
You all have been discussing oil injection recently. Scroll down on the Rotax email to find a short video on oil injection. Don't know if it is good or bad. Did not take the time to watch it. Sitting under a shade tree in Lake City, Colorado, at Mean Jeans Coffee Shop, enjoying a cup of latte, and their free, but slow, WIFI. john h mkIIII Lake City, Colorado From: info(at)rotaxowner.com [mailto:info(at)rotaxowner.com] Sent: Wednesday, July 23, 2014 11:06 AM Subject: Rotax Releases two updated Service Letters ROTAX-OWNER.COM <http://lm.rotaxowner.com/mo/20140723/images/email_top.png> <http://legacy.rotaxowner.com/si_tb_info/serviceletter/sl-912i-005.pdf> get the service letter ROTAX RELEASES: SL-912i-005 Service Letter: "NON-APPROVED MODIFICATIONS OR USE OF ROTAX-UNAPPROVED ENGINE COMPONENTS OR ACCESSORIES FOR ROTAX AIRCRAFT ENGINES" This updates the previous service letter (for all engine types) to expand its applicability to the 912iS / iS Sport. It is recommended that users of all Rotax engine types review this service letter. Download the Service Letter <http://legacy.rotaxowner.com/si_tb_info/serviceletter/sl-912i-005.pdf> _____ <http://legacy.rotaxowner.com/si_tb_info/serviceletter/sl-912i-006.pdf> post <http://www.rotax-owner.com/support-topmenu/engine-manuals> ROTAX RELEASES: Revised 912/914 Service Letter ROTAX has updated a 912/914 series Service Letter, to expand its applicability to include the 912iS / iS Sport. It is recommended that users of all Rotax 912i / 912 / 914 engine types review this service letter. download <http://legacy.rotaxowner.com/si_tb_info/serviceletter/sl-912i-006.pdf> Service Letter SL-912i-006 "USE OF THIRD-PARTY AFTERMARKET PISTON KITS IN ROTAX ENGINES TYPE 912i, 912, 914 (SERIES)" _____ <http://www.rotax-owner.com/rotax-blog/item/23-rotaxflightschool> post <http://www.rotax-owner.com/rotax-blog/item/23-rotaxflightschool> View the Blog Post Reminder for Flight Schools: the ROTAX Flight School Locator ROTAX has created a global flight school locator web application. It's simple to use, and free. Flight schools world-wide are encouraged to add their listings! For full details, see our ROTAX-OWNER BLOG posting <http://www.rotax-owner.com/rotax-blog/item/23-rotaxflightschool> . _____ RECENT VIDEOS _____ <http://www.rotax-owner.com/videos-topmenu/rotax-minute/343-2-oil-inj> Video Thumbnail <http://www.rotax-owner.com/videos-topmenu/rotax-minute/343-2-oil-inj> WATCH VIDEO Rotax Minute - 2 Stroke Oil Injection Hookup & Purging This video demonstrates how to set the oil injection arm position and how to purge the oil pump ready for first start up on a Rotax 2 Stroke Aircraft Engine. Video Length: 2:53 <http://www.rotax-owner.com/videos-topmenu/rotax-minute/343-2-oil-inj> WATCH VIDEO _____ <http://www.rotax-owner.com/videos-topmenu/expanded-video-instructions/43 4-912is-ecu-flash-1> Video Thumbnail <http://www.rotax-owner.com/videos-topmenu/expanded-video-instructions/43 4-912is-ecu-flash-1> WATCH VIDEO Engine Control Unit (ECU) firmware update SB-912i-002 Clarifies the procedure for flashing of updated ECU firmware on the Rotax 912iS engine - while the ECU is installed in the aircraft. Released in conjunction with service bulletin SB-912i-002. Video Length: 14:31 <http://www.rotax-owner.com/videos-topmenu/expanded-video-instructions/43 4-912is-ecu-flash-1> WATCH VIDEO _____ BUILDER SERIES _____ <http://www.rotax-owner.com/videos-topmenu/builder/441-912is-ch750-10> Video Thumbnail <http://www.rotax-owner.com/videos-topmenu/builder/441-912is-ch750-10> WATCH VIDEO Rotax Builder Series =93 912 iS CH750 #10 The tenth installment in our series of videos following Skytek as they build a Rotax fuel injected 912iS powered Zenith CH750. In this video, our ROTAX Technical Expert discusses the first flight of the 912iS-powered CH750 with Zenair test pilot Roger Dubbert, and demonstrates the simplicity and elegant ergonomics of the panel systems. Video Length: 9:23 <http://www.rotax-owner.com/videos-topmenu/builder/441-912is-ch750-10> WATCH VIDEO _____ Previous episodes in this series: <http://www.rotax-owner.com/all-videos/builder/405-bs-750-1> #1 - 912 iS CH750 --- <http://www.rotax-owner.com/all-videos/builder/415-bs-750-2> #2 - 912 iS CH750 --- <http://www.rotax-owner.com/all-videos/builder/425-750-4> #3 - 912 iS CH750 <http://www.rotax-owner.com/all-videos/builder/426-7504> #4 - 912 iS CH750 --- <http://www.rotax-owner.com/videos-topmenu/builder/436-912is-ch750-5> #5 - 912 iS CH750 --- <http://www.rotax-owner.com/videos-topmenu/builder/437-912is-ch750-6> #6 - 912 iS CH750 <http://www.rotax-owner.com/videos-topmenu/builder/438-912is-ch750-7> #7 - 912 iS CH750 --- <http://www.rotax-owner.com/videos-topmenu/builder/439-912is-ch750-8> #8 - 912 iS CH750 --- <http://www.rotax-owner.com/videos-topmenu/builder/440-912is-ch750-9> #9 - 912 iS CH750 <http://www.rotax-owner.com/component/content/article/40-uncategorised/43 3-2013android> Subscribe or Renew and Win! <http://www.youtube.com/user/rotaxowner> youtube.png <http://www.facebook.com/rotaxowner> facebook.png twitter.png You have received this message because you are subscribed to ROTAX-OWNER.COM To Unsubscribe from these mailings, click <http://lm.rotaxowner.com/?p=unsubscribe&uid=efa93bf6d983627eb84ef032 06521f53> this link | To contact us please email info@rotax-owner.com> info@rotax-owner.com All information =C2=A9 <http://www.Rotax-Owner.com> www.rotax-owner.com ________________________________________________________________________________
Date: Jul 24, 2014
Google tail wheel compression springs and hit photos. john h mkIII Lake City, Colorado -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of barry9315 Sent: Wednesday, July 23, 2014 11:32 AM Subject: Kolb-List: Re: Alternative Tail Wheel Steering System Would love to see a few pics of the tail wheelcompression springs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427213#427213 = Photoshare, and much much more: = = = ________________________________________________________________________________
Date: Jul 24, 2014
Thanks Jim for your reply. I have ridden snowmobiles since the 70,s and obviously a lot of things have changed when it comes to oil. The man that I purchased my 582 from ran 90 to 1 all the time with no problems. I will be doing the same thing. I wonder why Rotax recommends 40 to 1 for a 583 engine. That engine puts out about 105 horsepower and uses RAVE valves. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427304#427304 ________________________________________________________________________________
Date: Jul 24, 2014
Or, google 'screen door springs'. Much easier to find. :-) http://www.lowes.com/pd_192145-37672-543001_4294710978__?productId=3115801&Ns=p_product_qty_sales_dollar|1&pl=1¤tURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo On 7/24/2014 12:40 PM, John Hauck wrote: > > Google tail wheel compression springs and hit photos. > > john h > mkIII > Lake City, Colorado > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of > barry9315 > Sent: Wednesday, July 23, 2014 11:32 AM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: Alternative Tail Wheel Steering > System > > > > Would love to see a few pics of the tail wheelcompression > springs > ________________________________________________________________________________
Date: Jul 24, 2014
Subject: Re: Oil injection?
SSBzdXNwZWN0IHRoYXQgdGhlIGNvbXBhbnkgd2FudHMgdG8gbGVzc2VuIHRoZWlyIGxpYWJpbGl0 eSBieSBzcGVjaWZ5aW5nIGhpZ2hlciBvaWwgY29udGVudC4gVGhlIHRyYWdlZHkgaXMgdGhhdCB0 b28gbXVjaCBvaWwgaXMganVzdCBhcyBiYWQgYXMgdG9vIGxpdHRsZS4gQmVmb3JlIHRoZSBhZHZl bnQgb2Ygd3Jpc3QgcGluIGFuZCBiaWcgZW5kIG5lZWRsZSBiZWFyaW5ncyB0aGUgaGlnaGVyIG9p bCBjb250ZW50IHdhcyBhY3R1YWxseSBuZWNlc3NhcnkgYnV0IGNlcnRhaW5seSBub3QgYXMgaGln aCBhcyB0aGUgMjAgdG8gMzA6MS4gT25jZSB0aGVzZSBiZWFyaW5ncyB3ZXJlIGludHJvZHVjZWQg b2lsIGNvbnRlbnQgY291bGQgZmFsbCBkcmFtYXRpY2FsbHkuIFRvbyBtdWNoIG9pbCBpbiB0aGlz IGNhc2Ugd291bGQgY2F1c2UgdGhlIGJlYXJpbmcgdG8gc2tpZCB2aWNlIHJvbGwuIFNhbWUgYXBw bGllcyB0byBiYWxsIGJlYXJpbmdzLiAKCkxlc3Mgb2lsIGluIGEgUkFWRSBpcyBiZW5lZmljaWFs IGZyb20gYSBjb2tpbmcgc3RhbmRwb2ludC4uLmtlZXAgdGhlIHZhbHZlcyBmcmVlIGFuZCB0aGlu ZyBhcmUgbXVjaCBoYXBwaWVyLgoKSSd2ZSBnb3QgYW4gb2xkIE1jQ29sbG91Z2ggMzBCIGNoYWlu c2F3IGZyb20gdGhlIG1pZCA1MHMgdGhhdCBoYXMgYSAxNjoxIHJlY29tbWVuZGF0aW9uLiBSdW5z IGZpbmUgYXQgNTA6MS4uLi4uanVzdCB3YXkgdG9vIGhlYXZ5IHRvIHVzZSwgdGhvIQoKSmltIEJh a2VyCgotLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQpGcm9tOiBwaXBlcmNvbHQgPGJvYi5waXBl cmNvbHRAeWFob28uY29tPgpUbzoga29sYi1saXN0QG1hdHJvbmljcy5jb20KU2VudDogVGh1LCAy NCBKdWwgMjAxNCAxNzozNApTdWJqZWN0OiBLb2xiLUxpc3Q6IFJlOiBPaWwgaW5qZWN0aW9uPwoK LS0+IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogInBpcGVyY29sdCIgPGJvYi5waXBlcmNv bHRAeWFob28uY29tPgoKVGhhbmtzIEppbSBmb3IgeW91ciByZXBseS4gSSBoYXZlIHJpZGRlbiBz bm93bW9iaWxlcyBzaW5jZSB0aGUgNzAscyBhbmQgb2J2aW91c2x5IGEgbG90IG9mIHRoaW5ncyBo YXZlIGNoYW5nZWQgd2hlbiBpdCBjb21lcyB0byBvaWwuIFRoZSBtYW4gdGhhdCBJIHB1cmNoYXNl ZCBteSA1ODIgZnJvbSByYW4gOTAgdG8gMSBhbGwgdGhlIHRpbWUgd2l0aCBubyBwcm9ibGVtcy4g SSB3aWxsIGJlIGRvaW5nIHRoZSBzYW1lIHRoaW5nLiBJIHdvbmRlciB3aHkgUm90YXggcmVjb21t ZW5kcyA0MCB0byAxIGZvciBhIDU4MyBlbmdpbmUuIFRoYXQgZW5naW5lIHB1dHMgb3V0IGFib3V0 IDEwNSBob3JzZXBvd2VyIGFuZCB1c2VzIFJBVkUgdmFsdmVzLgpCb2IKCgoKClJlYWQgdGhpcyB0 b3BpYyBvbmxpbmUgaGVyZToKCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMu cGhwP3A9NDI3MzA0IzQyNzMwNAoKCgoKCgoKXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgIC0gVGhlIEtvbGIt TGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5h dmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlz dCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBC cm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09 Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGItTGlzdApf LT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBT YW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0K Xy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAg ICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQpfLT0gIFRoYW5rIHlvdSBmb3Ig eW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAt TWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5j b20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09CgoKCgo ________________________________________________________________________________
Subject: Re: Wing hinge size...?
Date: Jul 25, 2014
They are 2" wide overall, outside to outside. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427352#427352 ________________________________________________________________________________
Date: Jul 25, 2014
If you need the diagram, let me know and I will scan it and post it. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427353#427353 ________________________________________________________________________________
Date: Jul 26, 2014
Subject: landing gear
I'm trying to attach my aluminum gear leg to the axle fitting but it=C2-w ill only go a half inch or so into the fitting.=C2- I'm assuming that I n eed to heat the fitting to expand it but before I do=C2- would someone pl ease advise me. =C2- thanks ________________________________________________________________________________
Subject: Hinge sizes......
Date: Jul 26, 2014
Hello Kolbers, When I bought my kit, it came from a third party. The kit was taken back to Kolb and Travis checked it over and then handle the packing and shipping. Of course Travis did a great job and the kit made it to Alaska in perfect shape. At the time Travis mentioned that where were extra materials that came in with the kit. It turns out that there were extra hinges in the kit, of the wrong size. It is pretty easy to mix up the sizes, and my direction where not clear on what the right size was. Travis was in route to Oshkosh, but I was able to get all call through to him and get straightened out. Thanks for the help Richard! Ailerons and Flaps use MS20257-5, Rudder and Elevators use MS20257-2 Nick Cassara Palmer, Alaska ________________________________________________________________________________
Subject: Re: landing gear
Date: Jul 26, 2014
I installed the steel legs on my Xtra. Had to use a flapper wheel with extensions to slowly work the legs into the leg tubes. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427374#427374 ________________________________________________________________________________
Date: Jul 26, 2014
Thanks Jim for your replies. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427387#427387 ________________________________________________________________________________
Date: Jul 27, 2014
Subject: re landing gear
I have a Firestar II Side by Side kit. it has both a tail dragger and a tri ke fitting. the taper of the aluminum leg will go an inch and a half into t he tail=C2-dragger fitting, just as the steel leg on my f/sII=C2-=C2- inserts into its fitting. The large portion of the=C2-"y" on the trike fi tting is shorter then the tail dragger however there is in inch and a half available before bottoming out if the=C2-taper would allow it. There is n o lip to remove on the fitting and I'm not sure I can take enough out of th e fitting. That leaves reducing the taper on the leg or expanding the fitti ng with heat (since no one has suggested this I guess its not an option). I 'd like as many suggestions as possible on this. =C2- thanks=C2-=C2- I' ________________________________________________________________________________
Date: Jul 27, 2014
Hi guys, I have a MkIII Xtra and I have never had to use heat to get the axle fittings on or the legs into or out of the fuselage tubes.. I originally had the aluminum gear legs and then switched over to the steel gear. I would certainly recommend the steel gear legs for the Xtra. I did put lots of grease on the legs before sliding them into the tubes and I think I did the same to the axle fittings. If you switch to the steel gear be careful to install left and right correctly, they are marked and it does make a difference. Maybe the Aluminum legs were not machined to the correct size for the axle fittings? I would check with the factory for size and advice before using heat. I think that would only stress the parts unnecessarily. FrankD N1014S. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427417#427417 ________________________________________________________________________________
Subject: Re: re landing gear
Date: Jul 27, 2014
Definitely call Kolb on this, these parts should fit with no modifications. Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA > On Jul 27, 2014, at 5:47 PM, mojavjoe(at)comcast.net wrote: > > I have a Firestar II Side by Side kit. it has both a tail dragger and a tr ike fitting. the taper of the aluminum leg will go an inch and a half into t he tail dragger fitting, just as the steel leg on my f/sII inserts into its fitting. The large portion of the "y" on the trike fitting is shorter then t he tail dragger however there is in inch and a half available before bottomi ng out if the taper would allow it. There is no lip to remove on the fitting and I'm not sure I can take enough out of the fitting. That leaves reducing the taper on the leg or expanding the fitting with heat (since no one has s uggested this I guess its not an option). I'd like as many suggestions as po ssible on this. > > thanks > I' > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 27, 2014
I had some legs made out of 4130 for my firestar II, I had them turned .010 and they just made it into the sockets. It seems that the holes drilled into the sockets has left some sizeable amounts of attached flashing on the inside of the sockets. Sandpaper & a file did little to remove them....... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427420#427420 ________________________________________________________________________________
Date: Jul 27, 2014
I have never seen a Firestar II side by side, how about some pictures. Larry On Sun, Jul 27, 2014 at 6:37 PM, Dennis Rowe wrote: > Definitely call Kolb on this, these parts should fit with no modifications. > > Dennis "Skid" Rowe > Mk3, Rotax 670, > Leechburg, PA > > > On Jul 27, 2014, at 5:47 PM, mojavjoe(at)comcast.net wrote: > > I have a Firestar II Side by Side kit. it has both a tail dragger and a > trike fitting. the taper of the aluminum leg will go an inch and a half > into the tail dragger fitting, just as the steel leg on my f/sII inserts > into its fitting. The large portion of the "y" on the trike fitting is > shorter then the tail dragger however there is in inch and a half available > before bottoming out if the taper would allow it. There is no lip to remove > on the fitting and I'm not sure I can take enough out of the fitting. That > leaves reducing the taper on the leg or expanding the fitting with heat > (since no one has suggested this I guess its not an option). I'd like as > many suggestions as possible on this. > > thanks > I' > > * > > D============================================ > List"">http://www.matronics.com/Navigator?Kolb-List > D============================================ > //forums.matronics.com <http://forums.matronics.com> > D============================================ > ot;">http://www.matronics.com/contribution > D============================================ > > * > > * > > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 27, 2014
I have never seen a Firestar II side by side=2C It is a recent Model. Check the Factory web site. ________________________________________________________________________________
Date: Jul 27, 2014
Talking to Kolb folks and figuring out what is wrong with the bores and diameters and fixing them would clearly be the first approach. If you must thermal fit, dry ice makes a lot more sense than heat. The thermal expansion coefficient for the Al is double that of the steel. -----Original Message----- From: Frankd Sent: Sunday, July 27, 2014 4:05 PM Subject: Kolb-List: Re: landing gear Hi guys, I have a MkIII Xtra and I have never had to use heat to get the axle fittings on or the legs into or out of the fuselage tubes.. I originally had the aluminum gear legs and then switched over to the steel gear. I would certainly recommend the steel gear legs for the Xtra. I did put lots of grease on the legs before sliding them into the tubes and I think I did the same to the axle fittings. If you switch to the steel gear be careful to install left and right correctly, they are marked and it does make a difference. Maybe the Aluminum legs were not machined to the correct size for the axle fittings? I would check with the factory for size and advice before using heat. I think that would only stress the parts unnecessarily. FrankD N1014S. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427417#427417 ________________________________________________________________________________
Subject: Wiring conduit and Airspeed indicator
Date: Jul 27, 2014
Hello Builder and flyer, I soon will need to run electrical wires in my wings, and I am asking for conduit suggestions. I will have wingtip running lights and strobes, and landing/Taxi light that I bought from Kuntzleman. Also, am interested in the Belite Airspeed/ Vertical speed combo indicator; is anyone using Belite instruments? Thanks for the help! Nick Cassara Palmer, AK ________________________________________________________________________________
Date: Jul 28, 2014
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: Wiring conduit and Airspeed indicator
I had the same problem running wires through odd pieces of truck equipment, and used plastic air brake tubing. Secure it with hot glue. Weighs next to nothing, and is slick- so it can't chafe. Use a length of speedometer cable to pull wires through- the rough surface lets you push it through, tapes wires securely, and pull without breaking. You can get a length as long as you want from an auto parts store. Bill Sullivan Windsor Locks, Ct. FS 447 -------------------------------------------- On Mon, 7/28/14, Nick Cassara wrote: Subject: Kolb-List: Wiring conduit and Airspeed indicator To: kolb-list(at)matronics.com Date: Monday, July 28, 2014, 12:18 AM Hello Builder and flyer, I soon will need to run electrical wires in my wings, and I am asking for conduit suggestions. I will have wingtip running lights and strobes, and landing/Taxi light that I bought from Kuntzleman. Also, am interested in the Belite Airspeed/ Vertical speed combo indicator; is anyone using Belite instruments? Thanks for the help! Nick CassaraPalmer, AK ________________________________________________________________________________
Date: Jul 28, 2014
The spar tube is a built in conduit, use a p-clamp at both ends to keep the w ire from moving around, hold the p-clamps in place with 1/8 pop rivets but u se a washer between the rivet and the clamp if you use plastic clamps. Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA > On Jul 28, 2014, at 12:18 AM, "Nick Cassara" wrote: > > Hello Builder and flyer, > > I soon will need to run electrical wires in my wings, and I am asking for c onduit suggestions. I will have wingtip running lights and strobes, and land ing/Taxi light that I bought from Kuntzleman. > > Also, am interested in the Belite Airspeed/ Vertical speed combo indicator ; is anyone using Belite instruments? > > Thanks for the help! > > Nick Cassara > Palmer, AK > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 28, 2014
Thanks for the input . I solved the problem by sanding the inside of the fi tting=C2-then slathered on grinding compound and turned the leg by hand u ntil it bottomed out. No ridge on the leg and the only way=C2-you can tel l anything was done is that it is polished where it enters the fitting. ________________________________________________________________________________
Subject: Re: looking for a landing gear strut on on kolb M 3 xtra
Date: Jul 30, 2014
Need left seat pilot side strut. can you take photo and text it me or email. 843-566-3104? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427550#427550 ________________________________________________________________________________
Date: Jul 30, 2014
Why not contact Travis @Kolb for the strut that you need. I am pretty sure that he can fix you up, and you can be assured that the one that you do get will be new and will fit as well. Just a thought, Larry On Wed, Jul 30, 2014 at 9:51 AM, barry9315 wrote: > > Need left seat pilot side strut. can you take photo and text it me or > email. 843-566-3104? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427550#427550 > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 30, 2014
i am ready to taxi test and crow hop a firefly I would like to talk on the phone to some firefly pilots please call me for some advise--- i have owned a fire star and a mk2-- and have over 1,200 hrs in lite planes a nd flew a fire fly a couple times several years ago, -- please call som ebody =0A=0A-=0AMalcolm & Jeanne Brubaker =0AMichigan Sport Pilot Repair =0Ahttp://michigansportpilotrepair.com=0ALSRM-A, PPC, WS=0AGreat Sails - Sa ilmaker =0Afor Ultralight & Light Sport=0A(989)513-3022=0A-=0A-=0A- =0A-=0A=0A=0A________________________________=0A From: barry9315 <barbob5 742(at)gmail.com>=0ATo: kolb-list(at)matronics.com =0ASent: Wednesday, July 30, 2 014 11:51 AM=0ASubject: Kolb-List: Re: looking for a landing gear strut on bob5742(at)gmail.com>=0A=0ANeed left seat pilot side strut. can you take photo and text it me or email. 843-566-3104?=0A=0A=0A=0A=0ARead this topic onlin e here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=427550#427550=0A =========================0A =================== ________________________________________________________________________________
Date: Jul 30, 2014
Thanks much Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427552#427552 ________________________________________________________________________________
Date: Jul 31, 2014
Subject: Kit 1
Someone told me they have the first kit for sale on this forum. I asked how much they wanted, and I never recieved a reply. I can't find the e-mail, but I still want to buy the kit to go with my frame. Please respond if this is you or you know who it is. Thanks. Sincerely, Denny Baber baberdk(at)gmail.com 309-796-2476 Preconceived notions are the locks on the door to wisdom ________________________________________________________________________________
Date: Jul 31, 2014
Dont do it. If it will fly get well clear of the ground,do some stalls to fix a landing speed. 1200 hours in Light planes will not prepare you for the way a Kolb will lose flying speed when you close the throttle.There is no inertia like a `normal` plane. She will just stop. Keep a trickle of power on right down to the ground, inches, not feet .Hold her off with progressive back stick and she will settle beautifully. Pat From: Malcolm Brubaker Sent: Wednesday, July 30, 2014 5:05 PM Subject: Re: Kolb-List: Re: looking for a landing gear strut on on kolb M 3 xtra i am ready to taxi test and crow hop a firefly I would like to talk on the phone to some firefly pilots please call me for some advise i have owned a fire star and a mk2 and have over 1,200 hrs in lite planes and flew a fire fly a couple times several years ago, please call somebody Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.com LSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022 ------------------------------------------------------------------------- ------- From: barry9315 <barbob5742(at)gmail.com> Sent: Wednesday, July 30, 2014 11:51 AM Subject: Kolb-List: Re: looking for a landing gear strut on on kolb M 3 xtra Need left seat pilot side strut. can you take photo and text it me or email. 843-566-3104? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427550#427550 --> http://fo= - List Contribution Web Site &nbs="http://www.matronics.com/contribution" target="_blank">http://www.mat============== ====== ________________________________________________________________________________
Subject: repairing bent chrom molly landing strut
Date: Jul 31, 2014
I know these can be fixex by bending hot or cold. hard landing bent my left strut 3-4 degrees. Anyone have a procedure for straighting? its for a kolb M3. I emailed kolb 2 days ago but no reply. better yet if someone has one to sell. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427628#427628 ________________________________________________________________________________
Subject: Kit 1
Date: Jul 31, 2014
There were a lot of Kit 1's, I assume. At least for each model, both prototype and production. Which one are you interested in? john h mkIII - Kit number 11, production. Conway, Arkansas From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Denny Baber Sent: Thursday, July 31, 2014 9:02 AM Subject: Kolb-List: Kit 1 Someone told me they have the first kit for sale on this forum. I asked how much they wanted, and I never recieved a reply. I can't find the e-mail, but I still want to buy the kit to go with my frame. Please respond if this is you or you know who it is. Thanks. Sincerely, Denny Baber baberdk(at)gmail.com 309-796-2476 Preconceived notions are the locks on the door to wisdom ________________________________________________________________________________
Date: Jul 31, 2014
Patrick L/Kolbers: Quit trying to scare new FF pilots. If one is half a pilot he probably has enough aptitude to maintain airspeed, airspeed over altitude. The FF will not stop if power is retarded, and it does have inertia, just not as much as a heavier, cleaner aircraft. The FF is a normal Kolb aircraft. Only thing abnormal about Kolbs is the pilots. john h mkIII Conway, Arkansas From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Pat Ladd Sent: Thursday, July 31, 2014 10:18 AM Subject: Re: Kolb-List: Re: looking for a landing gear strut on on kolb M 3 xtra Dont do it. If it will fly get well clear of the ground,do some stalls to fix a landing speed. 1200 hours in Light planes will not prepare you for the way a Kolb will lose flying speed when you close the throttle.There is no inertia like a `normal` plane. She will just stop. Keep a trickle of power on right down to the ground, inches, not feet .Hold her off with progressive back stick and she will settle beautifully. Pat From: Malcolm Brubaker <mailto:brubakermal(at)yahoo.com> Sent: Wednesday, July 30, 2014 5:05 PM Subject: Re: Kolb-List: Re: looking for a landing gear strut on on kolb M 3 xtra i am ready to taxi test and crow hop a firefly I would like to talk on the phone to some firefly pilots please call me for some advise i have owned a fire star and a mk2 and have over 1,200 hrs in lite planes and flew a fire fly a couple times several years ago, please call somebody Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.com <http://michigansportpilotrepair.com/> LSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022 _____ From: barry9315 <barbob5742(at)gmail.com> Sent: Wednesday, July 30, 2014 11:51 AM Subject: Kolb-List: Re: looking for a landing gear strut on on kolb M 3 xtra Need left seat pilot side strut. can you take photo and text it me or email. 843-566-3104? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427550#427550 -- <http://www.matronics.com/Navigator?Kolb-List> > http://fo= - List Contribution Web Site &nbs="http://www.matronics.com/contribution" target="_blank">http://www.mat==================== <http://forums.matronics.com/> <http://forums.matronics.com/> <http://forums.matronics.com/> href="http://www.matronics.com/Navigator?Kolb-List">http://w ww.matronics.com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.c om href="http://www.matronics.com/contribution">http://www.matr onics.com/c = = = = ________________________________________________________________________________
Subject: Re: repairing bent chrom molly landing strut
Date: Jul 31, 2014
thanks much. that what i was thinking. just wanted to be sure Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427634#427634 ________________________________________________________________________________
Subject: Re: Rudder Trim tabs for MIIIC w/ 912UL
Date: Jul 31, 2014
Really confussef. if your kolb m 3 x wants to fly left why the hell do you put the rudder trim on the left. trimming the rudder on the right side i would think would even things out Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427648#427648 ________________________________________________________________________________
Subject: Tach wiring uls
Date: Jul 31, 2014
Hi all, Just bought a mk3 classic with a 912 uls. The tach reading on the GR EIS reads about 1/2 the actual RPM , previous owner said it had just started. It is wired through a kuntzelman hot box. All the info I can find says the pickup Comes off a trigger coil that terminates at a two pin connecter. I can't find that Coil, or the 2 pin connector. I've looked in the rotax manuals, ( line maint, operating instructions and the heavy maint ). As the problem , I'm told , is likely a dirty connection , I would like to run that circuit down and clean up the connections. If anyone could show me how to find that coil and connection . Or just advise me on how to proceed I would sure thank you. Frank Goodnight Fayetteville , Arkansas MK 111 Clasic Sent from my iPad ________________________________________________________________________________
From: Colin Hudson <colin.scott.hudson(at)gmail.com>
Date: Jul 31, 2014
John I have to side wit Pat. I thought he gave Malcolm some sound advice. T he Kolb Quit is real. With all that flat plat drag airspeed bleeds fast whe n the throttle is cut. My M3xtra has a single control stick. I made the mi stake of letting my best friend try to land it (an ATP with 8500 hrs). I wa rned him the best I could, but at 3 foot he chopped the power and tried to l and it like a Cessna. Airspeed instantly bled off and we hit hard. I had t o replace the right landing gear. I've found if I carry power till the whee ls touch, I never have a problem. Scott Hudson N424AL ATP/CFII 10,200+ Sent from my iPhone > On Jul 31, 2014, at 2:26 PM, "John Hauck" wrote: > > Patrick L/Kolbers: > > Quit trying to scare new FF pilots. If one is half a pilot he probably ha s enough aptitude to maintain airspeed, airspeed over altitude. > > The FF will not stop if power is retarded, and it does have inertia, just n ot as much as a heavier, cleaner aircraft. The FF is a normal Kolb aircraft . > > Only thing abnormal about Kolbs is the pilots. > > john h > mkIII > Conway, Arkansas > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com] On Behalf Of Pat Ladd > Sent: Thursday, July 31, 2014 10:18 AM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: looking for a landing gear strut on on kolb M 3 xtra > > Dont do it. If it will fly get well clear of the ground,do some stalls to f ix a landing speed. 1200 hours in Light planes will not prepare you for the w ay a Kolb will lose flying speed when you close the throttle.There is no ine rtia like a `normal` plane. She will just stop. Keep a trickle of power on r ight down to the ground, inches, not feet .Hold her off with progressive bac k stick and she will settle beautifully. > > Pat > > From: Malcolm Brubaker > Sent: Wednesday, July 30, 2014 5:05 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: looking for a landing gear strut on on kolb M 3 xtra > > i am ready to taxi test and crow hop a firefly I would like to talk on the phone to some firefly pilots please call me for some advise i have owned a fire star and a mk2 and have over 1,200 hrs in lite planes and flew a f ire fly a couple times several years ago, please call somebody > > Malcolm & Jeanne Brubaker > Michigan Sport Pilot Repair > http://michigansportpilotrepair.com > LSRM-A, PPC, WS > Great Sails - Sailmaker > for Ultralight & Light Sport > (989)513-3022 > > > > > > From: barry9315 <barbob5742(at)gmail.com> > To: kolb-list(at)matronics.com > Sent: Wednesday, July 30, 2014 11:51 AM > Subject: Kolb-List: Re: looking for a landing gear strut on on kolb M 3 xt ra > > > Need left seat pilot side strut. can you take photo and text it me or emai l. 843-566-3104? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427550#427550 > > > > > > --> http://fo= - List Contribution Web Site &nbs="http://www.matronics.com/contribution" target="_blank">http://w ww.mat==================== > > > > > > > > > href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics .com/Navigator?Kolb-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > - The Kolb-List Email Forum - > --> http://www.matronics.com/Navigator?Kolb-List > - MATRONICS WEB FORUMS - > --> http://forums.matronics.com > - List Contribution Web Site - > Thank you for your generous support! > -Matt Dralle, List Admin. > --> http://www.matronics.com/contribution > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 31, 2014
colin.scott.hudson(at)gma wrote: > John I have to side wit Pat. I thought he gave Malcolm some sound advice. > > > Malcolm wrote: > > i am ready to taxi test and crow hop a firefly I would like to talk on the phone to some firefly pilots please call me for some advise i have owned a fire star and a mk2 and have over 1,200 hrs in lite planes and flew a fire fly a couple times several years ago, please call somebody > > > > Malcolm & Jeanne Brubaker > Michigan Sport Pilot Repair > What may have been overlooked from Malcolm's original post is that he has owned (and I assume flown some of those 1200 hours) in a Firestar and a MK 2. The FireFly will be only slightly different in handling on landing than the Firestar. A hundred hours in other Kolbs prepares one to land a FireFly much better than thousands of hours in heavier aircraft. IMO... Worth what you paid for it. -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427661#427661 ________________________________________________________________________________
Date: Jul 31, 2014
Learn to fly the airplane, no matter what it is. Without power, engine at idle, try landing the airplane on the ground, not three feet in the air. This maneuver does not take power to accomplish and the Kolb, no matter what model, will not fall out of the air, e.g., "Kolb quit", unless it gets below stall speed. All fixed wing airplanes quit flying when they get below stall speed. We keep our Kolbs above stall speed by pushing the nose down, maintaining airspeed above stall. Again, learn to fly the airplane. Your friend should be aware, when he is flying a Kolb, not to try to fly it like a Cessna. An ATP with 8500 hours, he should know how to fly by now. I have been flying Kolbs for 30 years as of this month. I taught myself to fly fixed wing aircraft, a Kolb Ultrastar, the first of three Kolbs I built and flew. I still fly my MKIII. My first fixed wing flight was also my test flight for the Ultrastar. Did pretty good on the first landing. No "Kolb quit". Not bad for a newbie, but ran out of cow pasture before I had finished my landing roll (no brakes installed). These little Kolbs are easy to fly, forgiving, with no real surprises, unless one quits flying at 3 feet when they are attempting to land. Kolbs do not stop flying when power is reduced to idle. As a matter of fact, Kolbs are great fun to fly dead stick. They really handle well. Makes good practice for the time when the engine stops. john h mkIII Memphis, Tennessee From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Colin Hudson Sent: Thursday, July 31, 2014 5:51 PM Subject: Re: Kolb-List: Re: looking for a landing gear strut on on kolb M 3 xtra John I have to side wit Pat. I thought he gave Malcolm some sound advice. The Kolb Quit is real. With all that flat plat drag airspeed bleeds fast when the throttle is cut. My M3xtra has a single control stick. I made the mistake of letting my best friend try to land it (an ATP with 8500 hrs). I warned him the best I could, but at 3 foot he chopped the power and tried to land it like a Cessna. Airspeed instantly bled off and we hit hard. I had to replace the right landing gear. I've found if I carry power till the wheels touch, I never have a problem. Scott Hudson N424AL ATP/CFII 10,200+ Sent from my iPhone On Jul 31, 2014, at 2:26 PM, "John Hauck" wrote: Patrick L/Kolbers: Quit trying to scare new FF pilots. If one is half a pilot he probably has enough aptitude to maintain airspeed, airspeed over altitude. The FF will not stop if power is retarded, and it does have inertia, just not as much as a heavier, cleaner aircraft. The FF is a normal Kolb aircraft. Only thing abnormal about Kolbs is the pilots. john h mkIII Conway, Arkansas From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Pat Ladd Sent: Thursday, July 31, 2014 10:18 AM Subject: Re: Kolb-List: Re: looking for a landing gear strut on on kolb M 3 xtra Dont do it. If it will fly get well clear of the ground,do some stalls to fix a landing speed. 1200 hours in Light planes will not prepare you for the way a Kolb will lose flying speed when you close the throttle.There is no inertia like a `normal` plane. She will just stop. Keep a trickle of power on right down to the ground, inches, not feet .Hold her off with progressive back stick and she will settle beautifully. Pat From: Malcolm Brubaker <mailto:brubakermal(at)yahoo.com> Sent: Wednesday, July 30, 2014 5:05 PM Subject: Re: Kolb-List: Re: looking for a landing gear strut on on kolb M 3 xtra i am ready to taxi test and crow hop a firefly I would like to talk on the phone to some firefly pilots please call me for some advise i have owned a fire star and a mk2 and have over 1,200 hrs in lite planes and flew a fire fly a couple times several years ago, please call somebody Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.com <http://michigansportpilotrepair.com/> LSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022 _____ From: barry9315 <barbob5742(at)gmail.com> Sent: Wednesday, July 30, 2014 11:51 AM Subject: Kolb-List: Re: looking for a landing gear strut on on kolb M 3 xtra Need left seat pilot side strut. can you take photo and text it me or email. 843-566-3104? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427550#427550 -- <http://www.matronics.com/Navigator?Kolb-List> > http://fo= <http://forums.matronics.com/> - List Contribution Web Site &nbs="http://www.matronics.com/contribution" target="_blank">http://www.mat============== ====== <http://forums.matronics.com/> <http://forums.matronics.com/> <http://forums.matronics.com/> href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronic s.com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c - The Kolb-List Email Forum - --> http://www.matronics.com/Navigator?Kolb-List - MATRONICS WEB FORUMS - --> http://forums.matronics.com - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. --> http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D List"">http://www.matronics.com/Navigator?Kolb-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ot;">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Jul 31, 2014
In a message dated 7/31/2014 6:22:30 P.M. Eastern Daylight Time, barbob5742(at)gmail.com writes: Really confussef. if your kolb m 3 x wants to fly left why the hell do you put the rudder trim on the left. trimming the rudder on the right side i would think would even things out Hi Barry, If you are using your right foot to maintain straight flight, that means your rudder is swinging to the right, which turns your Kolb to the right, thus making you fly straight. Now install a trim tab on the rudder so you don't have to use your foot pressure. The trim tab can be mechanically attached to either side of the rudder, BUT the bend, or off set of the tab, has to be towards the left (as viewed from the rear of the plane). The trim tab will then push the rudder to the right which will relieve the foot pressure you previously used to maintain straight flight. How much of a bend? Start with 10 or 15 degrees. Test fly and then bend more or less as needed to get straight flight without using your foot pressure. Hope this will help you understand how a trim tab works. Bill Varnes Original Kolb FireStar - builder & pilot Audubon NJ My 20th season flying Kolb ________________________________________________________________________________
Subject: Kolb landing
Date: Aug 01, 2014
Hi John, Not trying to frighten anyone and I don`t believe in the Kolb Quit but you know as well as I do that the techniques for landing a Kolb and a (say) Cessna are different. If you close the throttle just above the stall at 10 or 15ft in a Cessna its inertia will bring you in. if you try it in a Kolb she will shed flying speed VERY quickly and unless you are quick, which by definition in this case, you are NOT, she will stall like any other a/c and you do not have enough height to recover. That means a hard landing at best. As i said in my post, you should land inches above the ground NOT feet. Happy flying Pat ________________________________________________________________________________
Date: Aug 01, 2014
If you close the throttle just above the stall at 10 or 15ft in a Cessna its inertia will bring you in. if you try it in a Kolb she will shed flying speed VERY quickly and unless you are quick, which by definition in this case, you are NOT, she will stall like any other a/c and you do not have enough height to recover. That means a hard landing at best. As i said in my post, you should land inches above the ground NOT feet. Happy flying Pat Close the throttle, push the stick forward to maintain airspeed, land the Kolb. john ________________________________________________________________________________
Subject: Re: Kolb landing
Date: Aug 01, 2014
Pat Think you meant this for John? More later, Russ On Aug 1, 2014, at 6:21 AM, Pat Ladd wrote: > > Hi John, > > Not trying to frighten anyone and I don`t believe in the Kolb Quit but you know as well as I do that the techniques for landing a Kolb and a (say) Cessna are different. > > If you close the throttle just above the stall at 10 or 15ft in a Cessna its inertia will bring you in. > if you try it in a Kolb she will shed flying speed VERY quickly and unless you are quick, which by definition in this case, you are NOT, she will stall like any other a/c and you do not have enough height to recover. > That means a hard landing at best. > > As i said in my post, you should land inches above the ground NOT feet. > > Happy flying > > Pat > > > ________________________________________________________________________________
Subject: landing a Kolb
Date: Aug 01, 2014
I agree with John.......on landing a Kolb.....I have lots of runway and I most of the time use a bit of power and w heel land the firestar.. helps a lazy old pilot to land sm ooth....we are creatures of habit and those habit's are hard to change....yes a Kolb is light in weight and slows up fa st....a person can carry a bit more speed and no power and do the same type of landing as I do with a bit of p ower....that you have to do with a engine out.....I find it difficult to make good landings doing a full stall 3 point landing...I seem to be to high or to low and only once i n awhile do I get it right...yes it boils down to fly th e airplane....and if you do that the Kolb is a fun airplan e and in a price range that is hard to beat....I am goin g out right now and gas up.....blue skys and safe flying jswan ________________________________________________________________________________
Subject: Clear Lake Flight Video
Date: Aug 01, 2014
> I decided to try a narrated video like Larry and Boyd. This is my first experiment with this and while not very exciting, at least it was fun. > > Link is below: > > https://docs.google.com/file/d/0BxdXwdWJkFExSnl5M0lTM3k4bDQ/edit Good example of a Kolb landing. Don't stop flying, e.g., stall, before you land. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Aug 01, 2014
I agree with John.......on landing a Kolb.....I have lots of runway and I most of the time use a bit of power and wheel land the firestar.. helps a lazy old pilot to land smooth....we are creatures of habit and those habit's are hard to change....yes a Kolb is light in weight and slows up fast....a person can carry a bit more speed and no power and do the same type of landing as I do with a bit of power....that you have to do with a engine out.....I find it difficult to make good landings doing a full stall 3 point landing...I seem to be to high or to low and only once in awhile do I get it right...yes it boils down to fly the airplane....and if you do that the Kolb is a fun airplane and in a price range that is hard to beat....I am going out right now and gas up.....blue skys and safe flying jswan Yep, fly the plane. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Mk3 flap speed
Date: Aug 01, 2014
Hi all, Can someone tell me the max airspeed at wich i can lower full flaps and the max speed I can go with 1/2 flaps in a MK 3 Clasic . Thanks Frank Goodnight Sent from my iPad ________________________________________________________________________________
Date: Aug 01, 2014
Can someone tell me the max airspeed at wich i can lower full flaps and the max speed I can go with 1/2 flaps in a MK 3 Clasic . Thanks Frank Goodnight Frank G/Kolbers: Never seen anything published on flap extension speed. I usually use 60 to 70 mph for 20 and 40 degrees of flaps. Have experimented up to 80 mph max flaps, 40 degrees. Was demonstrating my MKIII at Lakeland some years ago. Had never done this maneuver before. Had an aviation reporter on board, a friend. Pulled in full flaps, pulled power back to idle, pushed the nose over straight down. At 80 to 90 mph I pulled the stick back abruptly. The MKIII continued in its vertical dive until I retracted the flaps, then pulled the stick back. Reckon those big flaps took the air off the tail section rendering my elevators useless in that situation. Other than the above, never had a problem with elevators and flaps. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: Mk3 flap speed
Date: Aug 01, 2014
Frank my research shows VFE for the classic to be 100 km, 52 knts or 62 MPH. Anything above that can cause structure damage. Scott Hudson Sent from my iPhone > On Aug 1, 2014, at 8:49 PM, Frank Goodnight wrote: > > > Hi all, > Can someone tell me the max airspeed at wich i can lower full flaps and the max speed > I can go with 1/2 flaps in a MK 3 Clasic . > Thanks Frank Goodnight > > Sent from my iPad > > > > ________________________________________________________________________________
Subject: Rotax 670 update
Date: Aug 01, 2014
Figured I'd update everyone on my 670 swap. I now have over 5 hrs on the 670 and am very happy with the performance. The Ski Doo Denso single ignition is incredibly smooth and idles fine at 1600 rpm with a two blade or three blade prop. Easily the best starting two stroke I ever owned. My old three cylinder 2SI 690L with 28mm Mikuni carbs is super smooth but this thing is even smoother. Must be the huge flywheel and I guess the crank rebuild is dead nuts on. I'm still fine tuning the pitch and am currently running two 68 inch Powerfin F blades until I get three blades cut to 66 inches. Performance is stout, it turns the same prop and pitch I ran on my 670 about 600 rpm higher than the 690 did. I added pitch to limit the over rev and am still fine tuning, basically my solo climb went from 850 fpm to 1250 fpm, top speed increased from 72mph to 85. Cruise at 5400 rpm used to be 62mph, now it's 70. Fuel burn is looking pretty close the same, around 4.5 gallon per hour at 5400 rpm. Still have some testing to do but am very happy so far. The 618 style exhaust is much quieter than my old engine and family and flying buddies say it sounds stronger from the ground. It definitely shits and gets on take off. So far so good. Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA ________________________________________________________________________________
Date: Aug 02, 2014
Frank, Watch my video on transitioning to the Kolb Mk III for GA pilots here: https://www.youtube.com/watch?v=mQ-YaW9WgEU Here's a view from outside the cockpit: https://www.youtube.com/watch?v=sGMvpQRHS-0 As for your question about flap deployment speed, I use 60 mph then settle on 50 for approach. Hope this helps. Rick Girard On Fri, Aug 1, 2014 at 10:31 PM, Colin Hudson wrote: > colin.scott.hudson(at)gmail.com> > > Frank my research shows VFE for the classic to be 100 km, 52 knts or 62 > MPH. Anything above that can cause structure damage. > > Scott Hudson > > Sent from my iPhone > > > On Aug 1, 2014, at 8:49 PM, Frank Goodnight > wrote: > > > frank.goodnight(at)att.net> > > > > Hi all, > > Can someone tell me the max airspeed at wich i can lower full flaps and > the max speed > > I can go with 1/2 flaps in a MK 3 Clasic . > > Thanks Frank Goodnight > > > > Sent from my iPad > > > > > > > > > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Re: Clear Lake Flight Video
Date: Aug 02, 2014
Yes pretty much everyone has had trouble hearing this. It sounds ok on my computer except when I mumble but I will probably redo the voice track when I get a minute to mess with it. Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427813#427813 ________________________________________________________________________________
Date: Aug 02, 2014
I'm still a low time pilot in the Kolb, just passed 200 hours in her and I have a little less than 1000 landings now. I try to do 2 or 3 at least every time I fly and I try to vary the type of landing I do each time. Full flaps, no flaps, wheel, three point, over obstacle, stop short etc. I think the Kolb, at least my Mark III, is a pretty easy airplane to land but it is not easy to land 'perfectly' 3 point power off EVERY TIME at least for me. As has been stated over and over it has to be flown all the way to the ground. You can't just get it in ground effect and let it land on automatic like some I have flown. Small mistakes turn what I think is a perfect landing into an average landing with a small bounce or a little bump. Leaving a little power on can make it float a little more like a GA plane and I found that easier in the beginning. Now the game is to pull all the power off on the down wind leg, not touch it again and put it where I want it, perfectly soft with as short a roll as possible. Oh yeah, and to walk away. :) (That's what I was trying to do in the short field landing video I posted a while back.) Thanks, Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427814#427814 ________________________________________________________________________________
Date: Aug 02, 2014
Sounds good! john h mkIII Titus, Alabama Figured I'd update everyone on my 670 swap. The 618 style exhaust is much quieter than my old engine and family and flying buddies say it sounds stronger from the ground. It definitely shits and gets on take off. So far so good. Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA ________________________________________________________________________________
Date: Aug 02, 2014
Thanks to all that answered the flap question. Frank Goodnight ( new to mk3 ) Sent from my iPhone On Aug 1, 2014, at 10:31 PM, Colin Hudson wrote: > > Frank my research shows VFE for the classic to be 100 km, 52 knts or 62 MPH. Anything above that can cause structure damage. > > Scott Hudson > > Sent from my iPhone > >> On Aug 1, 2014, at 8:49 PM, Frank Goodnight wrote: >> >> >> Hi all, >> Can someone tell me the max airspeed at wich i can lower full flaps and the max speed >> I can go with 1/2 flaps in a MK 3 Clasic . >> Thanks Frank Goodnight >> >> Sent from my iPad > > > > > ________________________________________________________________________________
Date: Aug 02, 2014
Allan/Kolbers: Homer designed his airplanes for low time pilots. He wanted the aircraft to sit level, or nearly level on the ground. His reason was to require more airspeed to take off, prevent pulling off too soon, flying out of ground effect and stalling. He also wanted them to land faster, thus the level attitude. I didn't like this level attitude. I wanted to get the nose of the aircraft up in a more conventional three point attitude. This helps me get off the ground a little quicker and land in a three point attitude. Homer also put most of the weight on the main gear to make his airplanes handle better on the ground. This works well with one exception, the tendency to nose over because of the light tail. I overcame this by moving the main gear 8" forward from the stock position. My MKIII is a now a true tail dragger. It is more difficult to handle on the ground, but has no tendency to nose over in most any terrain. There is over 100 lbs on the tail wheel. All the mods my Brother Jim and I did to my MKIII seem to be working well. They have been on this MKIII for more than 22 years and 3,300.0 hours. It is nice to fly an airplane that satisfies all your needs. Don't think there is anything else to do to Miss P'fer except maintain and fly her. Allan, I have seen your landings. They look good. john h mkIII Titus, Alabama I'm still a low time pilot in the Kolb, just passed 200 hours in her and I have a little less than 1000 landings now. I try to do 2 or 3 at least every time I fly and I try to vary the type of landing I do each time. Full flaps, no flaps, wheel, three point, over obstacle, stop short etc. I think the Kolb, at least my Mark III, is a pretty easy airplane to land but it is not easy to land 'perfectly' 3 point power off EVERY TIME at least for me. As has been stated over and over it has to be flown all the way to the ground. You can't just get it in ground effect and let it land on automatic like some I have flown. Small mistakes turn what I think is a perfect landing into an average landing with a small bounce or a little bump. Leaving a little power on can make it float a little more like a GA plane and I found that easier in the beginning. Now the game is to pull all the power off on the down wind leg, not touch it again and put it where I want it, perfectly soft with as short a roll as possible. Oh yeah, and to walk away. :) (That's what I was trying to do in the short field landing video I posted a while back.) Thanks, Allan ________________________________________________________________________________
Subject: RE: Kolb-List Digest: 13 Msgs - 08/01/14
Date: Aug 02, 2014
> The MKIII continued in its vertical dive Wow. I feel a spasm of my sphincter and I wasn't even there. ________________________________________________________________________________
Date: Aug 06, 2014
Subject: video
I have finished re-installing my HKS on my Firestar, with the help of Roger Hankins, who is much smarter than I, not to mention much more patient. The HKS is a great engine, but the installation for Kolbs means the muffler has to be mounted in front of the engine on the root tube of the cage. Since this thing is about 8 inches in diameter and round, the wind is very disturbed, and overheating has been a problem. I overcame it by shrouds over the heads, which kept the heat within acceptable limits. I decided that failing a better muffler configuration, or a smaller muffler, a streamlined one would be a help. Streamlining was out of my expertise, so I just made a flat plate that I attached to the back of the muffler. The theory being that it would at least direct the air into the heads. Well it works to the point of about 30 degrees or more CHT temps. I needed to make a longer flight to see for sure how it was going to do. The skies were very hazy with smoke, and visibility was not all that great, but the flight was just fine. The baffle kept things very cool. The highest reading was 289 at WOT, climbing up the face of a long hill, the average was about 268, and the lowest was 256. The water situation here is pretty severe. There are only two springs still producing water on the Sheep Heads. The only other water is that supplied by the ranch next door. Wild horses drank most of the water hauled up there. The flight covered an hour of time, I flew for 60 miles, burning 3 gallons of gas. An average of 60 MPH under all the conditions that I encountered, uphill and down hill. https://vimeo.com/102764515 Password-owyheeflyer -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 06, 2014
Subject: temps
I forgot to mentiion that the upper limit of CHT is 340 in the HKS. Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: video
Date: Aug 06, 2014
I liked the new video...... do you know a rain dance? or how is your ar tistic creativity for making one up.... you know it needs to happen... boyd From: Larry Cottrell Sent: Wednesday, August 06, 2014 2:30 PM Subject: Kolb-List: video I have finished re-installing my HKS on my Firestar, with the help of Roger Hankins, who is much smarter than I, not to mention much more patient. The HKS is a great engine, but the installation for Kolbs means the muffler has to be mounted in front of the engine on the root tube of the cage. Sin ce this thing is about 8 inches in diameter and round, the wind is very dis turbed, and overheating has been a problem. I overcame it by shrouds over t he heads, which kept the heat within acceptable limits. I decided that fail ing a better muffler configuration, or a smaller muffler, a streamlined one would be a help. Streamlining was out of my expertise, so I just made a fl at plate that I attached to the back of the muffler. The theory being that it would at least direct the air into the heads. Well it works to the point of about 30 degrees or more CHT temps. I needed to make a longer flight to see for sure how it was going to do. The skies were very hazy with smoke, and visibility was not all that great, but the flight was just fine. The baffle kept things very cool. The highes t reading was 289 at WOT, climbing up the face of a long hill, the average was about 268, and the lowest was 256. The water situation here is pretty severe. There are only two springs still producing water on the Sheep Heads. The only other water is that supplied by the ranch next door. Wild horses drank most of the water hauled up there =2E The flight covered an hour of time, I flew for 60 miles, burning 3 gallons of gas. An average of 60 MPH under all the conditions that I encountered, u phill and down hill. https://vimeo.com/102764515 Password-owyheeflyer -- If you forward this email, or any part of it, please remove my email addres s before sending. --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Date: Aug 06, 2014
Subject: fire fly first flight
i'm getting ready to fly this new firefly for the first time and would like to talk to a firefly pilot before i begin.-- so somebody please call! - mal =0A=0A-=0AMalcolm & Jeanne Brubaker =0AMichigan Sport Pilot Repai r =0Ahttp://michigansportpilotrepair.com=0ALSRM-A, PPC, WS=0AGreat Sails - Sailmaker =0Afor Ultralight & Light Sport=0A(989)513-3022 ________________________________________________________________________________
Subject: Re: video
Date: Aug 07, 2014
Enjoyed the video as always. Glad the engine cooling is improved and hoping you get some rain out there soon. I have a friend with that type of engine on his Kolb. I'll have to give the exhaust setup a closer look. Thanks, Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428165#428165 ________________________________________________________________________________
Date: Aug 07, 2014
Subject: Re: video
If you need more detailed photos let me know. Larry On Thu, Aug 7, 2014 at 12:27 PM, Larlaeb wrote: > > Enjoyed the video as always. Glad the engine cooling is improved and > hoping you get some rain out there soon. I have a friend with that type of > engine on his Kolb. I'll have to give the exhaust setup a closer look. > > Thanks, > Allan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=428165#428165 > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 08, 2014
Subject: ground effects
It took me two tries to get airborne this morning. There was a freak shower that basically covered my house and hanger. I had taxied out to the spot that I warm the engine up and the sprinkle turned into a rain shower. The wife suggested that I return to the hanger to wait it out. The shock to my system was so much that the wife had to throw a bucket of sand in my face to wake me up. It took about 5 minutes to stop so I rolled out and took off for my morning check of the Cows. I have been a little disappointed in the quality of my Drift video camera. The image just isn't as sharp and rich as I would like it. Operator error I am sure. I shut down the shutter two stops, and I intended to try it to see if it was better. The last couple of videos that I have made used the "enhancement " feature of my editing program, and they were better, but still washed out somewhat. I am expecting the delivery of a Garmin Virb camera this afternoon, and will be comparing it to the drift. I wanted the drift to be set properly for that comparison. I have since decided that one F stop would have been better. After I was in the air, I remembered that I had not turned on the camera for my second try. I didn't want to go home just yet, so I landed on the dirt road that goes to the Alvord from the ranch. The road is pretty smooth, but only one car wide, with an 8 inch berm on each side of the road. There were some twists and turns in the road for a ways, so I drove down the road looking for a straight enough road to take off on. After a couple of minutes I hit a bit of a straight stretch and started my take off. I was not quite up to comfortable flying speed when a curve in the road was fast approaching. No worries, I popped it up into ground effects and leveled it out just above the brush and kept it there for the few seconds that it took to gain flying speed. No problem! https://vimeo.com/102946520 owyheeflyer Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: ground effects
Date: Aug 08, 2014
guess I thought the drift had a remote start... before I can pop up in gro und effect I need longer gear legs,,,, always something to spend more mone y on. starting a soft checked as he typed =9CI want to see the video of th e rain dance=9D he decided it might not be something he really want ed to see. LOL boyd From: Larry Cottrell Sent: Friday, August 08, 2014 1:13 PM Subject: Kolb-List: ground effects It took me two tries to get airborne this morning. There was a freak shower that basically covered my house and hanger. I had taxied out to the spot t hat I warm the engine up and the sprinkle turned into a rain shower. The wi fe suggested that I return to the hanger to wait it out. The shock to my sy stem was so much that the wife had to throw a bucket of sand in my face to wake me up. It took about 5 minutes to stop so I rolled out and took off for my morning check of the Cows. I have been a little disappointed in the quality of my Drift video camera. The image just isn't as sharp and rich as I would like it. Operator error I am sure. I shut down the shutter two stops, and I inte nded to try it to see if it was better. The last couple of videos that I ha ve made used the "enhancement " feature of my editing program, and they wer e better, but still washed out somewhat. I am expecting the delivery of a G armin Virb camera this afternoon, and will be comparing it to the drift. I wanted the drift to be set properly for that comparison. I have since decid ed that one F stop would have been better. After I was in the air, I remembered that I had not turned on the camera fo r my second try. I didn't want to go home just yet, so I landed on the dirt road that goes to the Alvord from the ranch. The road is pretty smooth, bu t only one car wide, with an 8 inch berm on each side of the road. There we re some twists and turns in the road for a ways, so I drove down the road l ooking for a straight enough road to take off on. After a couple of minutes I hit a bit of a straight stretch and started my take off. I was not quite up to comfortable flying speed when a curve in the road was fast approachi ng. No worries, I popped it up into ground effects and leveled it out just above the brush and kept it there for the few seconds that it took to gain flying speed. No problem! https://vimeo.com/102946520 owyheeflyer Larry -- If you forward this email, or any part of it, please remove my email addres s before sending. --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Date: Aug 08, 2014
The drift does have a remote start, just not a turn on remote start. :-) There was no rain dance- I couldn't believe that it was actually going to rain. It started sprinkling just a bit as I prepared to get in the plane. I looked up and there was a hankerchief sized cloud up there. I thought well that will blow away soon, so I taxied out. When I couldn't see out of the windscreen, Karen asked "Are you going to take off in that"? That was when I realized it was actually raining, at least for a bit. Nothing got wet but my windscreen however. Larry On Fri, Aug 8, 2014 at 2:09 PM, b young wrote: > guess I thought the drift had a remote start... before I can pop up in > ground effect I need longer gear legs,,,, always something to spend more > money on. > > starting a soft checked as he typed =9CI want to see the video of the rain > dance=9D he decided it might not be something he really wanted to see. > LOL > > boyd > > *From:* Larry Cottrell > *Sent:* Friday, August 08, 2014 1:13 PM > *To:* kolb-list(at)matronics.com > *Subject:* Kolb-List: ground effects > > It took me two tries to get airborne this morning. There was a freak > shower that basically covered my house and hanger. I had taxied out to th e > spot that I warm the engine up and the sprinkle turned into a rain shower . > The wife suggested that I return to the hanger to wait it out. The shock to > my system was so much that the wife had to throw a bucket of sand in my > face to wake me up. > > It took about 5 minutes to stop so I rolled out and took off for my > morning check of the Cows. I have been a little disappointed in the quali ty > of my Drift video camera. The image just isn't as sharp and rich as I wou ld > like it. Operator error I am sure. I shut down the shutter two stops, and I > intended to try it to see if it was better. The last couple of videos tha t > I have made used the "enhancement " feature of my editing program, and th ey > were better, but still washed out somewhat. I am expecting the delivery o f > a Garmin Virb camera this afternoon, and will be comparing it to the drif t. > I wanted the drift to be set properly for that comparison. I have since > decided that one F stop would have been better. > > After I was in the air, I remembered that I had not turned on the camera > for my second try. I didn't want to go home just yet, so I landed on the > dirt road that goes to the Alvord from the ranch. The road is pretty > smooth, but only one car wide, with an 8 inch berm on each side of the > road. There were some twists and turns in the road for a ways, so I drove > down the road looking for a straight enough road to take off on. After a > couple of minutes I hit a bit of a straight stretch and started my take > off. I was not quite up to comfortable flying speed when a curve in the > road was fast approaching. No worries, I popped it up into ground effects > and leveled it out just above the brush and kept it there for the few > seconds that it took to gain flying speed. No problem! > > https://vimeo.com/102946520 > > owyheeflyer > > Larry > > -- > *If you forward this email, or any part of it, please remove my email > address before sending.* > > * > > p://www.matronics.com/Navigator?Kolb-List <http://www.matronics.com/Navig ator?Kolb-List> > ics.com <http://ics.com> > .matronics.com/contribution <http://matronics.com/contribution> > > * > > > ------------------------------ > <http://www.avast.com/> > > This email is free from viruses and malware because avast! Antivirus > <http://www.avast.com/> protection is active. > > * > =========== onics.com/Navigator?Kolb-List> =========== =========== om/contribution> =========== > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Brakes
Date: Aug 09, 2014
It's finally time to stick some brakes on my Firefly and I would like to attempt to use mountain bike brakes. If anybody is currently using that type of setup, I could use a couple of photos of your install to help get me on my way. I plan to use either a stick mount or lever next to me as a control. I sat in a firefly with the standard heel brakes and being short in stature, I found them too difficult to operate. Independent brakes are great but not a must have. I would like to try to fabricate something instead of buying commercial to save cost and give this retired guy something to do. I've got a buddy that knows somebody with a Bike shop so I may be able to get some parts reasonable in cost. -------- Gregg Kaat 2011 Firefly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428242#428242 ________________________________________________________________________________
Date: Aug 09, 2014
Subject: testing a new camera!
I finally decided to try Garmin's Virb video camera. I have been dithering for months as to whether it was worth the expense or not. Finally I decided to give up and get the thing. One of the features that I liked was that you could show your speed on the camera. I seem to have trouble remembering my actual flying speed, since there are so many distractions when one is suspended between the clouds and the ground. After I added the "baffle" to the muffler,( a 5 inch flat plate that seems to realign the air flow coming off the 8 inch round muffler ) I seemed to be going a lot faster than I remembered before I added it. One of the things about the Virb is that the GPS in the camera records the speed, and a whole lot of other things. Not being that interested in my heart rate, I think I will pass on that one. My measurement of excitement is how dry my mouth gets. I stuck it on the other wing on the tube that holds the wing when it is folded. That seems to be the least amount of vibration on the entire plane. I did get some harmonics, especially when I throttled back. The camera is supposed to have a "stabilization feature" but apparently flying isn't that stable. The colors produced by the camera did not require me to use the "enhancement feature" of my editing program. It seemed to be a little dark, but I tend to fly early in the morning and the lighting is not always the best then. In Sept the air should stabilize enough to be able to fly during the middle of the day when light is better. All in all, I like the camera. There are lots of features that could be if not helpful, at least interesting. As for the comparison to the Drift- About the only improvement to the drift is the GPS features. When the drift is set properly ( in this case minus one f stop) there is not a lot of difference between the two. I still think I will keep the Virb however. https://vimeo.com/103023194 owyheeflyer Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 09, 2014
I put these on my Firestar. They work great. One finger will bring me to a screeching halt. They are cable activated bike brakes. Avid BB7 Road Disc Brake 140mm x 6 Bolt I hope you can see what I did there. I had to make two brackets out of aluminum. One bracket plate has the four bolts going through the rim on one side and six bolts holding the rotor on the other side. I switched to narrower tires to make this work. I may have been able to use longer bolts but I like the way this came out. The second bracket is for the caliper to mount to. I thought three bolts on the axle plate would work but I couldn't get a bolt through there so it is held on with just two bolts and is plenty. The nice feature of these brakes is that the individual side pads can be adjusted easily with your fingers. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428252#428252 Attachments: http://forums.matronics.com//files/brakes3_114.jpg http://forums.matronics.com//files/brakes2_125.jpg http://forums.matronics.com//files/brakes1_187.jpg ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 09, 2014
Forgot the hand controls. One lever controls both cables. I also use a wooden wedge to lock the lever open as a parking brake. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428253#428253 Attachments: http://forums.matronics.com//files/rebuild4_139.jpg ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 10, 2014
Thanks for the help Scott. Pictures are always worth a thousand words in my book. Just a couple questions if you don't mind. Do you use the brakes on your landing rollout to slow down or just on the ramp? I used to fly off a grass strip and brakes weren't really necessary but that airport closed so now I'm on a paved airport. I'm concerned about a noseover if the brakes are applied too hard after landing. Also, did you have to buy new axles from Kolb or did you buy some stock yourself? I'm pretty sure the original axles are heat treated. My axles were cut down to fit during my build since I wasn't using brakes, so I need some new ones to accommodate the brake assembly. I'm not sure if a regular pipe threader for plumbing can do steel for the threads needed on the end of the axle. You can buy 5/8 #8 Bolts at the hardware which are hardened but I'm not sure they are strong enough to do the job. My landings are pretty good but not all are greasers. -------- Gregg Kaat 2011 Firefly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428258#428258 ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 10, 2014
Nicely done,very light clean installation Sent from my iPhone > On Aug 9, 2014, at 9:36 PM, "olendorf" wrote: > > > I put these on my Firestar. They work great. One finger will bring me to a screeching halt. > > They are cable activated bike brakes. > > Avid BB7 Road Disc Brake 140mm x 6 Bolt > > I hope you can see what I did there. I had to make two brackets out of aluminum. One bracket plate has the four bolts going through the rim on one side and six bolts holding the rotor on the other side. I switched to narrower tires to make this work. I may have been able to use longer bolts but I like the way this came out. The second bracket is for the caliper to mount to. I thought three bolts on the axle plate would work but I couldn't get a bolt through there so it is held on with just two bolts and is plenty. > > The nice feature of these brakes is that the individual side pads can be adjusted easily with your fingers. > > -------- > Scott Olendorf > Original Firestar, Rotax 447, Powerfin prop > Schenectady, NY > http://sites.google.com/site/kolbfirestar/ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=428252#428252 > > > > > Attachments: > > http://forums.matronics.com//files/brakes3_114.jpg > http://forums.matronics.com//files/brakes2_125.jpg > http://forums.matronics.com//files/brakes1_187.jpg > > > > > > > ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 10, 2014
I do use the brakes on landing rollout, taxiing and as a parking brake while I'm getting into the plane since I start the engine outside then get in. You need to use the brakes carefully because you will nose over. Not as much an issue when landing because you have more air over the tail to help keep it down. Its really only an issue when trying to do a run up with the brakes locked. I can't get over 4000rpms in a runup without nosing over. Another concern with using a single handle brake lever is that you will want to adjust your calipers so you get an even pull on both sides. I do that by holding a little brake while taxiing and feel if it is pulling one way or the other, then get out and adjust them. My axles were already adapted for brakes. They had the flange welded on. I don't have the knowledge to turn a bolt into an axle. That seems like a bad place to take a shortcut. I would buy the proper axles and have a flange welded on. I do know that plumbing threads are not the same as regular nuts and bolts threads. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428260#428260 ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 10, 2014
Thanks Scott. You've been most helpful. I mis-spoke on the bolt. I meant Grade 8 not #8. They make those bolts long enough already to use as axles and are threaded on the ends but I'm guessing they are not strong enough or they would be in use already. Unless there are any other ideas for new axles, I will have to call Kolb for a price on new ones. Ultimately I will compare the cost of building a brake system and compare it to the cost of a commercial black max system. -------- Gregg Kaat 2011 Firefly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428261#428261 ________________________________________________________________________________
Date: Aug 10, 2014
Subject: Re: Brakes
You should check with Travis, they have the axles already made up with the flange already there. I am sure if you needed something special that Travis could have it for you in nothing flat. Not a whole lot of sense in cobbling something together. I liked the hand brake, but I wanted independent braking. Since I have little patience and a welder I decided to make my own. Its not all that much different than the single brake lever. Larry On Sun, Aug 10, 2014 at 7:53 AM, t41pilot wrote: > > Thanks Scott. You've been most helpful. I mis-spoke on the bolt. I meant > Grade 8 not #8. They make those bolts long enough already to use as axles > and are threaded on the ends but I'm guessing they are not strong enough or > they would be in use already. Unless there are any other ideas for new > axles, I will have to call Kolb for a price on new ones. Ultimately I will > compare the cost of building a brake system and compare it to the cost of a > commercial black max system. > > -------- > Gregg Kaat > 2011 Firefly > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=428261#428261 > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 10, 2014
Subject: Re: Brakes
I installed mountain bike brakes on my Firefly...worked fine...cost about 70 bucks...using my lathe and labor...Herb ps the long cable runs caused some stretching...so they felt a bit spongy.. On 08/10/2014 08:53 AM, t41pilot wrote: > > Thanks Scott. You've been most helpful. I mis-spoke on the bolt. I meant Grade 8 not #8. They make those bolts long enough already to use as axles and are threaded on the ends but I'm guessing they are not strong enough or they would be in use already. Unless there are any other ideas for new axles, I will have to call Kolb for a price on new ones. Ultimately I will compare the cost of building a brake system and compare it to the cost of a commercial black max system. > > -------- > Gregg Kaat > 2011 Firefly > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=428261#428261 > > ________________________________________________________________________________
Date: Aug 10, 2014
Subject: Re: Brakes
Here is a set for sale on ebay...Herb http://www.ebay.com/itm/BB5-BB-5-MTB-Mechanical-Disc-Brake-Front-and-Rear-160mm-Rotor-Black-/251448329773?pt=US_Brakes&var=&hash=item3a8b7d062d ps if I were doing it again...I would try the hydraulic versions... On 08/10/2014 10:17 AM, Herb wrote: > > I installed mountain bike brakes on my Firefly...worked fine...cost > about 70 bucks...using my lathe and labor...Herb > > ps the long cable runs caused some stretching...so they felt a bit > spongy.. > On 08/10/2014 08:53 AM, t41pilot wrote: >> >> Thanks Scott. You've been most helpful. I mis-spoke on the bolt. I >> meant Grade 8 not #8. They make those bolts long enough already to >> use as axles and are threaded on the ends but I'm guessing they are >> not strong enough or they would be in use already. Unless there are >> any other ideas for new axles, I will have to call Kolb for a price >> on new ones. Ultimately I will compare the cost of building a brake >> system and compare it to the cost of a commercial black max system. >> >> -------- >> Gregg Kaat >> 2011 Firefly >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=428261#428261 >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 10, 2014
These are the same BB7 brakes but I used the parallel levers under the seat and just reached down for equal braking or differential braking. Worked great. Sold the airplane but these pictures should help. Dennis -------- Dennis Long Oakland TN 2000 Aeroprakt A20 Vista Cruiser Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar. 700+hours since 1/1/2009 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428268#428268 Attachments: http://forums.matronics.com//files/100_3392_128.jpg http://forums.matronics.com//files/100_3391_210.jpg http://forums.matronics.com//files/100_3364_158.jpg http://forums.matronics.com//files/100_3394_152.jpg http://forums.matronics.com//files/100_3393_946.jpg http://forums.matronics.com//files/100_3301_977.jpg ________________________________________________________________________________
Date: Aug 10, 2014
Subject: Re: Brakes
I used spacers also...I wanted to turn two spools instead..but I could not find any large diameter aluminum at the salvage yard... plus , my wheel barrow rims were not true and I needed to add shims...Herb On 08/10/2014 10:50 AM, Thumper wrote: > > These are the same BB7 brakes but I used the parallel levers under the seat and just reached down for equal braking or differential braking. Worked great. Sold the airplane but these pictures should help. > > Dennis > > -------- > Dennis Long > Oakland TN > 2000 Aeroprakt A20 Vista Cruiser > Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar. > 700+hours since 1/1/2009 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=428268#428268 > > > Attachments: > > http://forums.matronics.com//files/100_3392_128.jpg > http://forums.matronics.com//files/100_3391_210.jpg > http://forums.matronics.com//files/100_3364_158.jpg > http://forums.matronics.com//files/100_3394_152.jpg > http://forums.matronics.com//files/100_3393_946.jpg > http://forums.matronics.com//files/100_3301_977.jpg > > ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 10, 2014
With apparently lots of available braking, why would you go with the hydraulic version next time? Looks like price is only a little higher. I need to change from band brakes on a MkIII, and this looks like a really elegant solution, along with the dual under seat handle configuration. Bob "ps if I were doing it again...I would try the hydraulic versions..." On 08/10/2014 10:17 AM, Herb wrote: > -----Original Message----- From: Herb Sent: Sunday, August 10, 2014 8:34 AM Subject: Re: Kolb-List: Re: Brakes Here is a set for sale on ebay...Herb http://www.ebay.com/itm/BB5-BB-5-MTB-Mechanical-Disc-Brake-Front-and-Rear-160mm-Rotor-Black-/251448329773?pt=US_Brakes&var=&hash=item3a8b7d062d ps if I were doing it again...I would try the hydraulic versions... On 08/10/2014 10:17 AM, Herb wrote: > > I installed mountain bike brakes on my Firefly...worked fine...cost about > 70 bucks...using my lathe and labor...Herb > > ps the long cable runs caused some stretching...so they felt a bit > spongy.. > On 08/10/2014 08:53 AM, t41pilot wrote: >> >> Thanks Scott. You've been most helpful. I mis-spoke on the bolt. I meant >> Grade 8 not #8. They make those bolts long enough already to use as >> axles and are threaded on the ends but I'm guessing they are not strong >> enough or they would be in use already. Unless there are any other ideas >> for new axles, I will have to call Kolb for a price on new ones. >> Ultimately I will compare the cost of building a brake system and compare >> it to the cost of a commercial black max system. >> >> -------- >> Gregg Kaat >> 2011 Firefly >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=428261#428261 >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Aug 10, 2014
Subject: Re: Brakes
Just the ease of running the lines...and I do not think the cost is very much more? And the cable stretch that I mentioned... Kolbs do not need super brakes...that is certain...Haven't check on the price of a nose cone lately! :-) On 08/10/2014 12:59 PM, Bob wrote: > > With apparently lots of available braking, why would you go with the > hydraulic version next time? Looks like price is only a little > higher. I need to change from band brakes on a MkIII, and this looks > like a really elegant solution, along with the dual under seat handle > configuration. > Bob > > "ps if I were doing it again...I would try the hydraulic versions..." > On 08/10/2014 10:17 AM, Herb wrote: >> > > -----Original Message----- From: Herb > Sent: Sunday, August 10, 2014 8:34 AM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: Brakes > > > Here is a set for sale on ebay...Herb > http://www.ebay.com/itm/BB5-BB-5-MTB-Mechanical-Disc-Brake-Front-and-Rear-160mm-Rotor-Black-/251448329773?pt=US_Brakes&var=&hash=item3a8b7d062d > > > ps if I were doing it again...I would try the hydraulic versions... > On 08/10/2014 10:17 AM, Herb wrote: >> >> I installed mountain bike brakes on my Firefly...worked fine...cost >> about 70 bucks...using my lathe and labor...Herb >> >> ps the long cable runs caused some stretching...so they felt a bit >> spongy.. >> On 08/10/2014 08:53 AM, t41pilot wrote: >>> >>> Thanks Scott. You've been most helpful. I mis-spoke on the bolt. I >>> meant Grade 8 not #8. They make those bolts long enough already to >>> use as axles and are threaded on the ends but I'm guessing they are >>> not strong enough or they would be in use already. Unless there are >>> any other ideas for new axles, I will have to call Kolb for a price >>> on new ones. Ultimately I will compare the cost of building a brake >>> system and compare it to the cost of a commercial black max system. >>> >>> -------- >>> Gregg Kaat >>> 2011 Firefly >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=428261#428261 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 10, 2014
The separate spacers were stiff enough to keep the brake disk from getting out of calibration? I hadn't considered that. I thought the spacer would have to be a solid assembly of some type. I guess the key would be to buy a brake disk whose mounting holes line up with the wheel bolt holes if possible. I'm running the stock azusalite 5 inch wheels right now. I figured I would have to make a template of the hole pattern to take to the bike shop/amazon/ebay and see if I could get something to already line up. That would make the job easier compared to having somebody fabricate a special spacer for me. Thanks for all the photos. They are saved in my archives now -------- Gregg Kaat 2011 Firefly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428280#428280 ________________________________________________________________________________
Date: Aug 10, 2014
Subject: Re: testing a new camera!
R2xhZCBpdCdzIG5vdCBhIHByb2JsZW0gd2l0aCBvdGhlcnMuIEknbGwgdHJ5IGFnYWluIGxhdGVy LiBNeSBzZXJ2ZXIgbWF5IGhhdmUgYmVlbiBvdmVybG9hZGVkLsKgCgoKU2VudCBmcm9tIG15IFZl cml6b24gV2lyZWxlc3MgNEcgTFRFIFNtYXJ0cGhvbmUKCjxkaXY+LS0tLS0tLS0gT3JpZ2luYWwg bWVzc2FnZSAtLS0tLS0tLTwvZGl2PjxkaXY+RnJvbTogTGFycnkgQ290dHJlbGwgPGxjb3R0cmVs bDEwMjBAZ21haWwuY29tPiA8L2Rpdj48ZGl2PkRhdGU6MDgvMTAvMjAxNCAgMzowNyBQTSAgKEdN VC0wNTowMCkgPC9kaXY+PGRpdj5Ubzoga29sYi1saXN0QG1hdHJvbmljcy5jb20gPC9kaXY+PGRp dj5TdWJqZWN0OiBSZTogS29sYi1MaXN0OiB0ZXN0aW5nIGEgbmV3IGNhbWVyYSEgPC9kaXY+PGRp dj4KPC9kaXY+VGhhbmtzIGZvciB0aGUgaW5wdXQsIGJ1dCBpdCBoYXMgdG8gYmUgb24geW91ciBl bmQuIEl0IGRvZXNuJ3QgZG8gdGhhdCBoZXJlIG9yIGFueW9uZSBlbHNlIHRoYXQgSSBoYXZlIGhl YXJkLiBUaGV5IGFyZSB0aGUgaGlnaGVzdCBxdWFsaXR5IHRoYXQgSSBjYW4gZ2V0IG9uIHRoZSBu ZXQsIHNvIHRoZSBzaXplIG1pZ2h0IGJlIHlvdXIgcHJvYmxlbS4gWW91IGNhbiBhbHdheXMgZGVm YXVsdCB0byA3MjAgcmF0aGVyIHRoYW4gdGhlIEhELgpTb3JyeSB0aGF0IGl0IGRpZG4ndCBzaG93 IGFzIGludGVuZGVkLgpMYXJyeSAKCgpPbiBTdW4sIEF1ZyAxMCwgMjAxNCBhdCAxMjozOCBQTSwg RGF2aWQgS3VscCA8dW5kb2N0b3JAcHRkLm5ldD4gd3JvdGU6CkhpIExhcnJ5LAoKUGxheWVkIHlv dXIgdmlkIGFuZCBoZXJlJ3Mgd2hhdCBJIGZvdW5kLiAgSSBoYXZlIHR3byBicm93c2VycywgRmly ZWZveCBhbmQgSUUuICBJIHVzZSBGRiBmb3IgYWxtb3N0IGV2ZXJ5dGhpbmcgZXhjZXB0IHZpZGVv cywgYXMgbm8gbWF0dGVyIHdoYXQgSSd2ZSB0cmllZCB2aWRlb3MgZnJvbSB5b3V0dWJlIGFuZCB0 aGUgbGlrZSBjaGF0dGVyIGFuZCBqdW1wLCBhbHRob3VnaCB0aGUgc291bmQgaXMgdXN1YWxseSB1 bmJyb2tlbiwgc28gSSB1c2UgSUUgYXMgZGVmYXVsdCBmb3IgdmlkZW9zLgoKT3BlbmVkIHlvdXIg dmlkZW8gYW5kIGl0IGp1bXBlZCBhbmQgc3R1dHRlcmVkIGZyb20gYmVnaW5uaW5nIHRvIGVuZC4g IFRoZSBzb3VuZCB3YXMgT0suICBPdXQgb2YgY3VyaW9zaXR5IEkgb3BlbmVkIGl0IGluIEZpcmVm b3guICBOb3Qgb25seSBkaWQgdGhlIHZpZGVvIGp1bXAgYW5kIHN0dXR0ZXIsIHRoZSBzb3VuZCBz dHV0dGVyZWQgYXMgd2VsbC4gIEkgZG9uJ3Qga25vdyBpZiBpdCdzIG15IGNvbm5lY3Rpb24gb3Ig dGhlIHZpZGVvIG9yIHZpbWVvIHRoYXQgaXMgY2F1c2luZyB0aGUgcmVkdWN0aW9uIGluIHF1YWxp dHkgYWNyb3NzIHRoZSBib2FyZCwganVzdCB3YW50ZWQgdG8gbGV0IHlvdSBrbm93IHNvIHlvdSBo YXZlIHRoZSBkYXRhIHlvdSdyZSBsb29raW5nIGZvci4KCkJ5IHRoZSB3YXksIGhlcmUgaW4gUEEg aWYgd2UgZG8gdG91Y2ggYW5kIGdvZXMgb24gYSBsYWtlIHdlIHdvdWxkIGdldCB2ZXJ5IHdldCBh bmQgaGF2ZSB0byBmaXNoIG91ciBhaXJjcmFmdCBvdXQgb2YgdGhlIHdhdGVyLgoKQlRXLCB5b3Vy IEhLUyBzZWVtcyB0byBiZSBhIHNpZ25pZmljYW50IGltcHJvdmVtZW50LgoKRGF2ZSBLdWxwCkJl dGhsZWhlbSwgUEEKCkRvIE5vdCBBcmNoaXZlCgoKT24gOC85LzIwMTQgNjo1NyBQTSwgTGFycnkg Q290dHJlbGwgd3JvdGU6CkkgZmluYWxseSBkZWNpZGVkIHRvIHRyeSBHYXJtaW4ncyBWaXJiIHZp ZGVvIGNhbWVyYS4gSSBoYXZlIGJlZW4gZGl0aGVyaW5nIGZvciBtb250aHMgYXMgdG8gd2hldGhl ciBpdCB3YXMgd29ydGggdGhlIGV4cGVuc2Ugb3Igbm90LiBGaW5hbGx5IEkgZGVjaWRlZCB0byBn aXZlIHVwIGFuZCBnZXQgdGhlIHRoaW5nLiBPbmUgb2YgdGhlIGZlYXR1cmVzIHRoYXQgSSBsaWtl ZCB3YXMgdGhhdCB5b3UgY291bGQgc2hvdyB5b3VyIHNwZWVkIG9uIHRoZSBjYW1lcmEuIEkgc2Vl bSB0byBoYXZlIHRyb3VibGUgcmVtZW1iZXJpbmcgbXkgYWN0dWFsIGZseWluZyBzcGVlZCwgc2lu Y2UgdGhlcmUgYXJlIHNvIG1hbnkgZGlzdHJhY3Rpb25zIHdoZW4gb25lIGlzIHN1c3BlbmRlZCBi ZXR3ZWVuIHRoZSBjbG91ZHMgYW5kIHRoZSBncm91bmQuCgpBZnRlciBJIGFkZGVkIHRoZSAiYmFm ZmxlIiB0byB0aGUgbXVmZmxlciwoIGEgNSBpbmNoIGZsYXQgICAgICAgICAgIHBsYXRlIHRoYXQg c2VlbXMgdG8gcmVhbGlnbiB0aGUgYWlyIGZsb3cgY29taW5nIG9mZiB0aGUgOCBpbmNoICAgICAg ICAgICByb3VuZCBtdWZmbGVyICkgSSBzZWVtZWQgdG8gYmUgZ29pbmcgYSBsb3QgZmFzdGVyIHRo YW4gSSByZW1lbWJlcmVkIGJlZm9yZSBJIGFkZGVkIGl0LiAgT25lIG9mIHRoZSB0aGluZ3MgYWJv dXQgdGhlIFZpcmIgaXMgdGhhdCB0aGUgR1BTIGluIHRoZSBjYW1lcmEgcmVjb3JkcyB0aGUgc3Bl ZWQsIGFuZCBhIHdob2xlIGxvdCBvZiBvdGhlciB0aGluZ3MuIE5vdCBiZWluZyB0aGF0IGludGVy ZXN0ZWQgaW4gbXkgaGVhcnQgcmF0ZSwgSSB0aGluayBJIHdpbGwgcGFzcyBvbiB0aGF0IG9uZS4g TXkgbWVhc3VyZW1lbnQgb2YgZXhjaXRlbWVudCBpcyBob3cgZHJ5IG15IG1vdXRoIGdldHMuIAoK SSBzdHVjayBpdCBvbiB0aGUgb3RoZXIgd2luZyBvbiB0aGUgdHViZSB0aGF0IGhvbGRzIHRoZSB3 aW5nIHdoZW4gaXQgaXMgZm9sZGVkLiBUaGF0IHNlZW1zIHRvIGJlIHRoZSBsZWFzdCBhbW91bnQg b2YgdmlicmF0aW9uIG9uIHRoZSBlbnRpcmUgcGxhbmUuIEkgZGlkIGdldCBzb21lIGhhcm1vbmlj cywgZXNwZWNpYWxseSB3aGVuIEkgdGhyb3R0bGVkIGJhY2suIFRoZSBjYW1lcmEgaXMgc3VwcG9z ZWQgdG8gaGF2ZSBhICJzdGFiaWxpemF0aW9uIGZlYXR1cmUiIGJ1dCBhcHBhcmVudGx5IGZseWlu ZyBpc24ndCB0aGF0IHN0YWJsZS4KClRoZSBjb2xvcnMgcHJvZHVjZWQgYnkgdGhlIGNhbWVyYSBk aWQgbm90IHJlcXVpcmUgbWUgdG8gdXNlICAgICAgICAgICB0aGUgImVuaGFuY2VtZW50IGZlYXR1 cmUiIG9mIG15IGVkaXRpbmcgcHJvZ3JhbS4gSXQgc2VlbWVkIHRvIGJlIGEgbGl0dGxlIGRhcmss IGJ1dCBJIHRlbmQgdG8gZmx5IGVhcmx5IGluIHRoZSBtb3JuaW5nIGFuZCB0aGUgbGlnaHRpbmcg aXMgbm90IGFsd2F5cyB0aGUgYmVzdCB0aGVuLiBJbiBTZXB0IHRoZSBhaXIgc2hvdWxkIHN0YWJp bGl6ZSBlbm91Z2ggdG8gYmUgYWJsZSB0byBmbHkgZHVyaW5nIHRoZSBtaWRkbGUgb2YgdGhlIGRh eSB3aGVuIGxpZ2h0IGlzIGJldHRlci4KCkFsbCBpbiBhbGwsIEkgbGlrZSB0aGUgY2FtZXJhLiBU aGVyZSBhcmUgbG90cyBvZiBmZWF0dXJlcyB0aGF0IGNvdWxkIGJlIGlmIG5vdCBoZWxwZnVsLCBh dCBsZWFzdCBpbnRlcmVzdGluZy4gQXMgZm9yIHRoZSAgICAgICAgICAgY29tcGFyaXNvbiB0byB0 aGUgRHJpZnQtIEFib3V0IHRoZSBvbmx5IGltcHJvdmVtZW50IHRvIHRoZSBkcmlmdCBpcyB0aGUg R1BTIGZlYXR1cmVzLiBXaGVuIHRoZSBkcmlmdCBpcyBzZXQgcHJvcGVybHkgKCBpbiB0aGlzIGNh c2UgbWludXMgb25lIGYgc3RvcCkgdGhlcmUgaXMgbm90IGEgbG90IG9mIGRpZmZlcmVuY2UgICAg ICAgICAgIGJldHdlZW4gdGhlIHR3by4gSSBzdGlsbCB0aGluayBJIHdpbGwga2VlcCB0aGUgVmly YiBob3dldmVyLgoKCmh0dHBzOi8vdmltZW8uY29tLzEwMzAyMzE5NCAgIG93eWhlZWZseWVyCgpM YXJyeQoKCi0tIApJZiB5b3UgZm9yd2FyZCB0aGlzIGVtYWlsLCBvciBhbnkgcGFydCBvZiBpdCwg cGxlYXNlIHJlbW92ZSBteSBlbWFpbCBhZGRyZXNzIGJlZm9yZSBzZW5kaW5nLgoKCgoKCgogCQpU aGlzIGVtYWlsIGlzIGZyZWUgZnJvbSB2aXJ1c2VzIGFuZCBtYWx3YXJlIGJlY2F1c2UgYXZhc3Qh IEFudGl2aXJ1cyBwcm90ZWN0aW9uIGlzIGFjdGl2ZS4KCgoKCmdldD0iX2JsYW5rIj5odHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGItTGlzdAp0cDovL2ZvcnVtcy5tYXRyb25p Y3MuY29tCl9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgoKCgoK LS0gCklmIHlvdSBmb3J3YXJkIHRoaXMgZW1haWwsIG9yIGFueSBwYXJ0IG9mIGl0LCBwbGVhc2Ug cmVtb3ZlIG15IGVtYWlsIGFkZHJlc3MgYmVmb3JlIHNlbmRpbmcuCgoKXy09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAg ICAgIC0gVGhlIEtvbGItTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBM aXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0 aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERv d25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNo IG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdh dG9yP0tvbGItTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VC IEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBX ZWIgRm9ydW1zIQpfLT0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0K Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQpfLT0g IFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT0gICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPSAgIC0tPiBodHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cgo ________________________________________________________________________________
Date: Aug 10, 2014
Subject: another One :-/
I am beginning to think that I might have a problem. I am going to check in to videographers rehab tomorrow. I plugged my Virb into the computer and they informed me that there was an update available. Well I think they have a bug. I wasn't able to use it and had to use my regular editing program, so there is not speed or altitude information on this video. It is a bit different than the others however, and the quality is good. https://vimeo.com/103099119 owyheeflyer Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: another One :-/
Date: Aug 11, 2014
lcottrell wrote: > I am beginning to think that I might have a problem. I am going to check in to videographers rehab tomorrow. > > Great video, Larry. We're going to have to get you a travel mug for your coffee. Wouldn't want you to spill any. [Laughing] -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428291#428291 ________________________________________________________________________________
Date: Aug 11, 2014
Thanks for sharing. I think the new camera has a better picture. -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428323#428323 ________________________________________________________________________________
Subject: Re: Annual
Date: Aug 11, 2014
My kolb is registered as an N numbered experimental -------- Brad Nation, Albuquerque, NM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428339#428339 ________________________________________________________________________________
Date: Aug 12, 2014
Subject: Re: Annual
Brad, There are two types of experimental certificates most commonly. One is experimental amateur built (EAB), and the other is experimental light sport aircraft (ELSA). Only the original builder can get a repairman certificate for an EAB so a non-builder owner has to hire an A & P to do the annual conditional inspection. The owner of an ELSA can take a 16 hour class and get a repairman inspection certificate for his/her airplane ONLY. When you get the license from the FAA it will have the N number of your aircraft on it. There's also the off chance that your aircraft is registered experimental exhibition (EE). If you have that you'd be making annual reports to your local FAA Flight Standards District Office (FSDO) outlining what flying you're going to be allowed to do, so I doubt your aircraft is EE, but you should check, just in case. For all you $50, one hour annual folks. Go to FAR 43 Appendix D and take a look at all the things required on an annual and tell me how you check all that in one hour and do the paperwork. Either you've hired Speedy Gonzalez or you're doing a pencil whip. Since you're already in FAR 43, go to 43.12 and contemplate what it says. Take a moment to think about what a lawyer could do to you if there were a crash involving serious injury or loss of life. Think about having everything you've worked for in life taken from you, possibly even your freedom. Still think that $50 looks reasonable? Rick Girard On Mon, Aug 11, 2014 at 11:00 PM, yellowbird1 wrote: > > My kolb is registered as an N numbered experimental > > -------- > Brad Nation, > Albuquerque, NM > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=428339#428339 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Video of me folding my Kolb. Sped up to 46 seconds.
Date: Aug 12, 2014
I added a sped up video of me folding my Kolb on to YouTube. http://youtu.be/nNyJ5oMBD3o I know, boring, but you don't have to watch it. :) -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428369#428369 ________________________________________________________________________________
Date: Aug 12, 2014
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: Video of me folding my Kolb. Sped up to 46 seconds.
Must be the way my ailerons are hinged, but mine don't fold all the way down like that. Mine have to stay up, also to avoid getting tangled with the vacuum line and fuel lines. Bill Sullivan Windsor Locks, Ct. FS 447 -------------------------------------------- On Tue, 8/12/14, olendorf wrote: Subject: Kolb-List: Video of me folding my Kolb. Sped up to 46 seconds. To: kolb-list(at)matronics.com Date: Tuesday, August 12, 2014, 11:58 AM "olendorf" I added a sped up video of me folding my Kolb on to YouTube. http://youtu.be/nNyJ5oMBD3o Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Aug 12, 2014
I didn't find it boring at all. You cut 2 minutes off my best time. Larry On Tue, Aug 12, 2014 at 9:58 AM, olendorf wrote: > > I added a sped up video of me folding my Kolb on to YouTube. > > http://youtu.be/nNyJ5oMBD3o > > I know, boring, but you don't have to watch it. :) > > -------- > Scott Olendorf > Original Firestar, Rotax 447, Powerfin prop > Schenectady, NY > http://sites.google.com/site/kolbfirestar/ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=428369#428369 > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: Annual
Date: Aug 12, 2014
It is listed as an EAB. Is it even possible to get the registration changed to ELSA? Brad Nation On Aug 12, 2014, at 9:18 , Richard Girard wrote: > Brad, There are two types of experimental certificates most commonly. One is experimental amateur built (EAB), and the other is experimental light sport aircraft (ELSA). > Only the original builder can get a repairman certificate for an EAB so a non-builder owner has to hire an A & P to do the annual conditional inspection. > The owner of an ELSA can take a 16 hour class and get a repairman inspection certificate for his/her airplane ONLY. When you get the license from the FAA it will have the N number of your aircraft on it. > There's also the off chance that your aircraft is registered experimental exhibition (EE). If you have that you'd be making annual reports to your local FAA Flight Standards District Office (FSDO) outlining what flying you're going to be allowed to do, so I doubt your aircraft is EE, but you should check, just in case. > For all you $50, one hour annual folks. Go to FAR 43 Appendix D and take a look at all the things required on an annual and tell me how you check all that in one hour and do the paperwork. Either you've hired Speedy Gonzalez or you're doing a pencil whip. > Since you're already in FAR 43, go to 43.12 and contemplate what it says. Take a moment to think about what a lawyer could do to you if there were a crash involving serious injury or loss of life. Think about having everything you've worked for in life taken from you, possibly even your freedom. > Still think that $50 looks reasonable? > > Rick Girard > > > On Mon, Aug 11, 2014 at 11:00 PM, yellowbird1 wrote: > > My kolb is registered as an N numbered experimental > > -------- > Brad Nation, > Albuquerque, NM > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=428339#428339 > > > > > > > > ========== > " target="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > MS - > k">http://forums.matronics.com > ========== > e - > -Matt Dralle, List Admin. > t="_blank">http://www.matronics.com/contribution > ========== > > > > > > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhappy. > - Groucho Marx > > > > ________________________________________________________________________________
Subject: Re: Annual
Date: Aug 12, 2014
My A and P charges $200 to do my annual on a Powered Parachute. I think its a deal because the local shop at the airport told me $550. Maybe one day I will have a Kolb. :? -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428385#428385 ________________________________________________________________________________
Date: Aug 13, 2014
Subject: Re: Annual
Brad I believe that you cannot change to ELSA. Only airplane kits that have been demonstrated to be SLSA (factory built LSA) and are offered as a kit that cannot be modified at all are eligible to be ELSA. Furthermore, once it's registered EAB it cannot be changed. The only change allowed is for an SLSA to move to ELSA. Malcolm Morrison wienerdogaero.com ----- Original Message ----- From: "Brad Nation" <nationcap(at)comcast.net> Sent: Tuesday, August 12, 2014 7:32:41 PM Subject: Re: Kolb-List: Re: Annual It is listed as an EAB. Is it even possible to get the registration changed to ELSA? Brad Nation On Aug 12, 2014, at 9:18 , Richard Girard < aslsa.rng(at)gmail.com > wrote: Brad, There are two types of experimental certificates most commonly. One is experimental amateur built (EAB), and the other is experimental light sport aircraft (ELSA). Only the original builder can get a repairman certificate for an EAB so a non-builder owner has to hire an A & P to do the annual conditional inspection. The owner of an ELSA can take a 16 hour class and get a repairman inspection certificate for his/her airplane ONLY. When you get the license from the FAA it will have the N number of your aircraft on it. There's also the off chance that your aircraft is registered experimental exhibition (EE). If you have that you'd be making annual reports to your local FAA Flight Standards District Office (FSDO) outlining what flying you're going to be allowed to do, so I doubt your aircraft is EE, but you should check, just in case. For all you $50, one hour annual folks. Go to FAR 43 Appendix D and take a look at all the things required on an annual and tell me how you check all that in one hour and do the paperwork. Either you've hired Speedy Gonzalez or you're doing a pencil whip. Since you're already in FAR 43, go to 43.12 and contemplate what it says. Take a moment to think about what a lawyer could do to you if there were a crash involving serious injury or loss of life. Think about having everything you've worked for in life taken from you, possibly even your freedom. Still think that $50 looks reasonable? Rick Girard On Mon, Aug 11, 2014 at 11:00 PM, yellowbird1 < nationcap(at)comcast.net > wrote:
My kolb is registered as an N numbered experimental -------- Brad Nation, Albuquerque, NM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428339#428339 =========== " target="_blank"> http://www.matronics.com/Navigator?Kolb-List =========== MS - k"> http://forums.matronics.com =========== e - -Matt Dralle, List Admin. t="_blank"> http://www.matronics.com/contribution =========== -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx
Subject: Re: Annual
Date: Aug 13, 2014
Please correct me if I am wrong; but why in hell would anyone even want to change the registration from EAB to ELSA? If the airplane is registered with a max gross takeoff weight of 1320 pounds or less, most any Kolb qualifies for operation as a Light Sport Aircraft. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428398#428398 ________________________________________________________________________________
Date: Aug 13, 2014
Subject: Re: Annual
Jerry =C2- Someone might want to so that they could do their own inspections (assuming they don't hold the repairman certificate for their EAB already). By takin g the 2 day course you can do your own inspections on your ELSA. But, since you can't change the certification on your EAB it is dosen't matter. =C2- Malcolm Morrison Wiener Dog Aero ----- Original Message ----- From: "racerjerry" <gki(at)suffolk.lib.ny.us> Sent: Wednesday, August 13, 2014 7:44:48 AM Subject: Kolb-List: Re: Annual Please correct me if I am wrong; but why in hell would anyone even want to change the registration from EAB to ELSA? =C2-If the airplane is register ed with a max gross takeoff weight of 1320 pounds or less, most any Kolb qu alifies for operation as a Light Sport Aircraft. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428398#428398 =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Subject: Re: Annual
Date: Aug 13, 2014
Because according to my understanding of the FAR if it registered as a ELSA and I take the 16 hour maintenance course I can do my own annuals. Brad ___________________________ =93Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same, or one day we will spend our sunset years telling our children and our children's children what it was once like in the United States where men were free.=94 -- President Ronald Reagan On Aug 13, 2014, at 5:44 , racerjerry wrote: > > Please correct me if I am wrong; but why in hell would anyone even want to change the registration from EAB to ELSA? If the airplane is registered with a max gross takeoff weight of 1320 pounds or less, most any Kolb qualifies for operation as a Light Sport Aircraft. > > -------- > Jerry King > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=428398#428398 > > > > > > > > > > ________________________________________________________________________________
Subject: Weak gear leg fitting?
Date: Aug 14, 2014
More FSII gear leg problems today. Several years ago we virtually totaled N582EF for a really bad landing where the welded fitting that joins the landing gear leg to the axle failed. Had the fitting not failed, it would have been bad, but not a virtual total. So we rebuilt it. Today Ed landed the FSII in a friends hay field due to a fuel problem. It was a hard landing, but nothing remarkable. It should have been maybe a slightly bent gear at worst, pull the gear leg out and straighten it. Yet the fitting failed in exactly the same fashion as happened several years ago. Once we get the airplane home - hopefully tomorrow - I plan to take the factory fittings and beef them up as much as I can. I no longer trust them, and will be welding some straps or saddles over and around them. Just something for the rest of you guys to think about. PS: Note that the file has been resized to 64 kb, and fits very nicely onto the page. No resizing of the page or scrolling back and forth is necessary. [Wink] -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428472#428472 Attachments: http://forums.matronics.com//files/p1030786_medium_507.jpg ________________________________________________________________________________
Date: Aug 14, 2014
Subject: Re: Weak gear leg fitting?
I may be wrong,( the photo was so small :-) ) but the fitting appeared to be one of the early axles. Those were 60 thousands in thickness. The current models are the 120 thousand thickness. I had the thin ones on my plane and they too caused me a lot of problems. I have since gone to heat treated 4130 because of the problems with the axles and gear legs. I wouldn't go back. I realize that Homer felt that it would prevent damage to the cage to have the gear legs fail first, as a limit to the damage. That has not been reflective of my experience. Failing gear legs and sockets have caused heavy damage to the cage due to the legs failing for what would have been no more than a rough landing with the proper gear legs. for what its worth, Larry On Thu, Aug 14, 2014 at 8:38 PM, Richard Pike wrote: > > More FSII gear leg problems today. Several years ago we virtually totaled > N582EF for a really bad landing where the welded fitting that joins the > landing gear leg to the axle failed. Had the fitting not failed, it would > have been bad, but not a virtual total. So we rebuilt it. > > Today Ed landed the FSII in a friends hay field due to a fuel problem. It > was a hard landing, but nothing remarkable. It should have been maybe a > slightly bent gear at worst, pull the gear leg out and straighten it. Yet > the fitting failed in exactly the same fashion as happened several years > ago. Once we get the airplane home - hopefully tomorrow - I plan to take > the factory fittings and beef them up as much as I can. I no longer trust > them, and will be welding some straps or saddles over and around them. > > Just something for the rest of you guys to think about. > > PS: Note that the file has been resized to 64 kb, and fits very nicely > onto the page. No resizing of the page or scrolling back and forth is > necessary. [Wink] > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > My soul shall be joyful in the LORD; It shall rejoice in His salvation. > Psalm 35:9 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=428472#428472 > > > Attachments: > > http://forums.matronics.com//files/p1030786_medium_507.jpg > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 15, 2014
OK, did not know that they are now .120. After we get the airplane home, I'll call Travis and get some. Thanks. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428489#428489 ________________________________________________________________________________
Date: Aug 15, 2014
Fourteen years ago a single failed gear leg/axle socket put a stop to my second attempt to fly my MKIII to Point Barrow, Alaska. That single gear leg/axle socket cost me a torn up airplane, a lot of grief and money, plus 30 days to hitchhike and fly commercial to Alabama, find a 24 foot enclosed trailer, then drive back to northern British Columbia to retrieve my airplane. I have been using heat treated 4130 gear legs since 1987, but I was still using a bolt on gear leg/axle socket because it was easier for me to align the main gear. Brother Jim wanted to fabricate the steel gear legs with .120" axle sockets welded to the end of the gear leg, but I resisted and ended up paying dearly for that decision. I have been flying with the same set of steel gear legs with welded axle sockets since I rebuilt the MKIII in 2000 and 2001. Don=99t know how many hours or landings I have on those gear legs, but I am still flying with them. I have torn up Firestar fuselages with aluminum gear legs, i.e., ripped out gear leg sockets. The aluminum gear legs my save fuselages in some cases, but not in all cases. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Thursday, August 14, 2014 11:51 PM Subject: Re: Kolb-List: Weak gear leg fitting? I may be wrong,( the photo was so small :-) ) but the fitting appeared to be one of the early axles. Those were 60 thousands in thickness. The current models are the 120 thousand thickness. I had the thin ones on my plane and they too caused me a lot of problems. I have since gone to heat treated 4130 because of the problems with the axles and gear legs. I wouldn't go back. I realize that Homer felt that it would prevent damage to the cage to have the gear legs fail first, as a limit to the damage. That has not been reflective of my experience. Failing gear legs and sockets have caused heavy damage to the cage due to the legs failing for what would have been no more than a rough landing with the proper gear legs. for what its worth, Larry On Thu, Aug 14, 2014 at 8:38 PM, Richard Pike wrote: More FSII gear leg problems today. Several years ago we virtually totaled N582EF for a really bad landing where the welded fitting that joins the landing gear leg to the axle failed. Had the fitting not failed, it would have been bad, but not a virtual total. So we rebuilt it. Today Ed landed the FSII in a friends hay field due to a fuel problem. It was a hard landing, but nothing remarkable. It should have been maybe a slightly bent gear at worst, pull the gear leg out and straighten it. Yet the fitting failed in exactly the same fashion as happened several years ago. Once we get the airplane home - hopefully tomorrow - I plan to take the factory fittings and beef them up as much as I can. I no longer trust them, and will be welding some straps or saddles over and around them. Just something for the rest of you guys to think about. PS: Note that the file has been resized to 64 kb, and fits very nicely onto the page. No resizing of the page or scrolling back and forth is necessary. [Wink] -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428472#428472 Attachments: http://forums.matronics.com//files/p1030786_medium_507.jpg <http://forums.matronics.com/files/p1030786_medium_507.jpg> " target="_blank">http://www.matronics.com/Navigator?Kolb-List MS - k">http://forums.matronics.com e - -Matt Dralle, List Admin. t="_blank">http://www.matronics.com/contribution -- If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Aug 15, 2014
You might want to rethink modifying that. Forced landings will cause damage, it's just where you want it to happen. Sincerely, Denny Baber baberdk(at)gmail.com 309-796-2476 Preconceived notions are the locks on the door to wisdom ________________________________________________________________________________
Date: Aug 15, 2014
Subject: Re: Annual
Malcolm, all, An ELSA must only be exactly like its SLSA qualifying aircraft at the time of inspection for the experimental certificate. Once the certificate is issued it's an experimental and you can change ANYTHING you want. Rick Girard On Tue, Aug 12, 2014 at 9:04 PM, wrote: > Brad > > I believe that you cannot change to ELSA. Only airplane kits that have > been demonstrated to be SLSA (factory built LSA) and are offered as a kit > that cannot be modified at all are eligible to be ELSA. Furthermore, once > it's registered EAB it cannot be changed. The only change allowed is for an > SLSA to move to ELSA. > > Malcolm Morrison > wienerdogaero.com > > ------------------------------ > *From: *"Brad Nation" <nationcap(at)comcast.net> > *To: *"kolb-list" > *Sent: *Tuesday, August 12, 2014 7:32:41 PM > *Subject: *Re: Kolb-List: Re: Annual > > > It is listed as an EAB. > Is it even possible to get the registration changed to ELSA? > > Brad Nation > > On Aug 12, 2014, at 9:18 , Richard Girard wrote: > > Brad, There are two types of experimental certificates most commonly. One > is experimental amateur built (EAB), and the other is experimental light > sport aircraft (ELSA). > Only the original builder can get a repairman certificate for an EAB so a > non-builder owner has to hire an A & P to do the annual conditional > inspection. > The owner of an ELSA can take a 16 hour class and get a repairman > inspection certificate for his/her airplane ONLY. When you get the license > from the FAA it will have the N number of your aircraft on it. > There's also the off chance that your aircraft is registered experimental > exhibition (EE). If you have that you'd be making annual reports to your > local FAA Flight Standards District Office (FSDO) outlining what flying > you're going to be allowed to do, so I doubt your aircraft is EE, but you > should check, just in case. > For all you $50, one hour annual folks. Go to FAR 43 Appendix D and take a > look at all the things required on an annual and tell me how you check all > that in one hour and do the paperwork. Either you've hired Speedy Gonzalez > or you're doing a pencil whip. > Since you're already in FAR 43, go to 43.12 and contemplate what it says. > Take a moment to think about what a lawyer could do to you if there were a > crash involving serious injury or loss of life. Think about having > everything you've worked for in life taken from you, possibly even your > freedom. > Still think that $50 looks reasonable? > > Rick Girard > > > On Mon, Aug 11, 2014 at 11:00 PM, yellowbird1 > wrote: > >> >> My kolb is registered as an N numbered experimental >> >> -------- >> Brad Nation, >> Albuquerque, NM >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=428339#428339 >> >> >> >> >> >> >> >> ========== >> " target="_blank">http://www.matronics.com/Navigator?Kolb-List >> ========== >> MS - >> k">http://forums.matronics.com >> ========== >> e - >> -Matt Dralle, List Admin. >> t="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhappy. > - Groucho Marx > > > * > > 3D============================================ > -List"" target="_blank" data-mce-href="3D"http://www.matronics.com/Navigator?Kolb-List "">http://www.matronics.com/Navigator?Kolb-List > 3D============================================ > et="_blank" data-mce-href="3D"http://forums.matronics.com "">http://forums.matronics.com > 3D============================================ > uot;" target="_blank" data-mce-href="3D"http://www.matronics.com/contribution "">http://www.matronics.com/contribution > 3D============================================ > > * > > > * > > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 16, 2014
Firefly brakes. Have not taxied with these yet but they work well on the considerable slope of my driveway. Changed to these to save weight, had Black Max which worked extremely well but this setup is 4 to 4.25 lbs. lighter. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428555#428555 Attachments: http://forums.matronics.com//files/image_800x800_146.jpg http://forums.matronics.com//files/image_800x598_161.jpg http://forums.matronics.com//files/image_800x598_2_242.jpg http://forums.matronics.com//files/brake_2_800x598_270.jpg http://forums.matronics.com//files/brake_1_800x598_141.jpg ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 16, 2014
Very clean and professional installation. What size tires are you using? They look very small. Larger tires and low air pressure take a lot of shock load off the gear legs and airframe. john h mkIII Titus, Alabama Firefly brakes. Have not taxied with these yet but they work well on the considerable slope of my driveway. Changed to these to save weight, had Black Max which worked extremely well but this setup is 4 to 4.25 lbs. lighter. ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 16, 2014
I will need to go out to the hanger to check size but yes they are narrow. Given a choice I would much rather have the Black Max rims and tires, landings with those were very gentle. Unfortunately they were to heavy. With the products on the market I do not believe it possible to get much lighter than this setup. I called Travis and requested a new set of gear sockets with the axle tube 9/16" shorter than standard, this saved over 1" of 4130 and axle. All the bolts and axles are Ti, axle nuts are nylock AL, cable splitter is CF, Ti and AL, lever is a 37 gram bicycle unit, the splitter is under the rear of the seat to save running two cables to the lever, caliper carriers are drilled and wheel spacers are plastic. I also made an AL and CF BRS mount saving 1 lb and am currently adapting an auto racing 4 point harness, again saving about 1lb. Longer term I have a Kawasaki TA440 to install which will be about 10 lbs. lighter and allow me to reinstall the Black Max brakes if the narrow tires do not work out. One plus to the current system is a reduction of drag. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428558#428558 ________________________________________________________________________________
Subject: ELSA...?
Date: Aug 16, 2014
Hello All, In my case I bought a kit to recreate a prototype aircraft that no longer exists. It will not be an exact copy of the prototype plane that no longer exists, and the design was and will remain significantly deferent from the production model. Do you think I will be able to get an ELSA? Thanks, Nick Cassara Palmer, Alaska ________________________________________________________________________________
Date: Aug 16, 2014
Subject: Re: ELSA...?
If the kit was an approved as an esla kit you should be ok. Even if the prototype no longer exist. The inspector will only be able to compare your finished project to the esla approved plans. If you don't have esla plans. Imho in my humble opinion,, your only option is eab. And if you have esla plans and have made any modifications while building your plane does not fit esla rules. You would be left with eab Boyd young On Aug 16, 2014 9:40 AM, "Nick Cassara" wrote: > Hello All, > > > In my case I bought a kit to recreate a prototype aircraft that no longer > exists. It will not be an exact copy of the prototype plane that no longer > exists, and the design was and will remain significantly deferent from the > production model. Do you think I will be able to get an ELSA? > > > Thanks, > > > Nick Cassara > > Palmer, Alaska > > > * > > > * > > ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 16, 2014
DucattiSS, Those brakes look so clean they almost look like they were computer generated. Time to get them dirty. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428585#428585 ________________________________________________________________________________
Date: Aug 16, 2014
John Hauck wrote: > Fourteen years ago a single failed gear leg/axle socket put a stop to my second attempt to fly my MKIII to Point Barrow, Alaska. That single gear leg/axle socket cost me a torn up airplane, a lot of grief and money, plus 30 days to hitchhike and fly commercial to Alabama, find a 24 foot enclosed trailer, then drive back to northern British Columbia to retrieve my airplane. > > I have been using heat treated 4130 gear legs since 1987, but I was still using a bolt on gear leg/axle socket because it was easier for me to align the main gear. Brother Jim wanted to fabricate the steel gear legs with .120" axle sockets welded to the end of the gear leg, but I resisted and ended up paying dearly for that decision. I have been flying with the same set of steel gear legs with welded axle sockets since I rebuilt the MKIII in 2000 and 2001. Dont know how many hours or landings I have on those gear legs, but I am still flying with them. > > I have torn up Firestar fuselages with aluminum gear legs, i.e., ripped out gear leg sockets. The aluminum gear legs my save fuselages in some cases, but not in all cases. > > john h > mkIII > Titus, Alabama > > Talked to Travis and ordered new FSII aluminum gear legs and steel end fittings for the axle, he did not mention steel gear legs for the FSII. Are there any steel FSII gear legs? If so, I would like to know about it. Should I call Travis back on Monday and change my order? -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428588#428588 ________________________________________________________________________________
Date: Aug 16, 2014
baberdk wrote: > You might want to rethink modifying that. Forced landings will cause damage, it's just where you want it to happen. > > Sincerely, > Denny Baber baberdk(at)gmail.com (baberdk(at)gmail.com) > 309-796-2476 > Preconceived notions are the locks on the door to wisdom > This is what happens when the fitting on the end of the gear leg breaks, the wheel comes off, and the end of the gear leg stobs into the ground. How much worse could it be? -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428589#428589 Attachments: http://forums.matronics.com//files/p1130313_large_medium_490.jpg ________________________________________________________________________________
Date: Aug 16, 2014
I don't know. john h mkIII Titus, Alabama Talked to Travis and ordered new FSII aluminum gear legs and steel end fittings for the axle, he did not mention steel gear legs for the FSII. Are there any steel FSII gear legs? If so, I would like to know about it. Should I call Travis back on Monday and change my order? -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428588#428588 ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 17, 2014
Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA What kind of redrive are you planning for the Kawi? I've only ever seen belt drives but have heard that someone once made cases that were gearbox compatable for the 440. > Longer term I have a Kawasaki TA440 to install which will be about 10 lbs. lighter and allow me to reinstall the Black Max brakes ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 17, 2014
Scott, Probably will not get them dirty this year - perhaps next summer. If you are ever up around the Argyle area I would like to see your Firestar. I have a 8 to 900 ft. strip about 4 miles south of Dick's, near the cell tower, east of Rt. 40. Approach from the north, approx. first 500ft upgrade, at shrub line starts down grade last 100 to 150ft. very sloped. Depart to north. Hump at about 100ft. from North end, ask Bill S. Wind sock near shed. I have a micro v reduction for the TA - design and machining are impressive. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428616#428616 ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 17, 2014
Would love to see a pic of the reduction. Can it be mounted up like a gearbox? Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA > On Aug 17, 2014, at 2:47 PM, "Ducati SS" wrote: > > > Scott, Probably will not get them dirty this year - perhaps next summer. > If you are ever up around the Argyle area I would like to see your Firestar. I have a 8 to 900 ft. strip about 4 miles south of Dick's, near the cell tower, east of Rt. 40. Approach from the north, approx. first 500ft upgrade, at shrub line starts down grade last 100 to 150ft. very sloped. Depart to north. Hump at about 100ft. from North end, ask Bill S. Wind sock near shed. > > > I have a micro v reduction for the TA - design and machining are impressive. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=428616#428616 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 17, 2014
Subject: video
https://vimeo.com/103283685 owyheeflyer My neighbor has problems with Geese pulling up the new grass at the ranch, so in addition to checking for stuck Cows, I haze the Geese on the way back home. They then go down to our neighbors and tear up his fields. ( He is a bit , no that's too vague, make that a BUTT! ) This is my first run in with them. I didn't take my camera the second time that I flew so that I wouldn't be tempted to make a video of it as well. Its a bit too bad because the next chase was an arieal "dog fight". I had to be very careful not to close too quickly with them, and to keep above them. Its a bit more difficult than one might imagine. This first time I was splitting the flock, and they would go back to the ranch. My second time, I learned to herd them by always turning back to the ranch lands before they could. The third time I went over, as soon as they heard the plane they would take wing and head to the other Ranch for the day. In the evening they would go back over to the Ranch to spend the night. At least they were not eating both day and night. In case you were wondering, as my neighbor's "agent" I can harrass the Geese enough to keep them off the property. This video was done about a week ago. I made a two hour flight today down in the Owyhee, burning about 7 gallons of fuel, and having a good time while I was at it. Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 17, 2014
Nick, Here are the applicable FAR's on Light Sport Aircraft. For your Kolbra, Kolb would have to build a qualifying aircraft per the ASTM standard, document that it meets the standard, and get the FAA to certify their production and supply system. The manufacturer would then sell you a kit EXACTLY like their prototype. If you were to make ANY changes to the kit, the manufacturer would have to issue a letter of authorization (LOA) for EACH change. Part of the kit package would be a certificate of conformity that would be presented to the FAA or the DAR, along with any LOA's at the time your aircraft is presented for inspection for the experimental certificate, mistakenly called the airworthiness certificate by most people. So, the simple answer is that for you to get an ELSA designation, Kolb would have to have built an SLSA prototype of the Kolbra. Rick Girard 21.190 Issue of a special airworthiness certificate for a light-sport category aircraft. (a) Purpose. The FAA issues a special airworthiness certificate in the light-sport category to operate a light-sport aircraft, other than a gyroplane. (b) Eligibility. To be eligible for a special airworthiness certificate in the light-sport category: (1) An applicant must provide the FAA with=94 (i) The aircraft's operating instructions; (ii) The aircraft's maintenance and inspection procedures; (iii) The manufacturer's statement of compliance as described in paragraph (c) of this section; and (iv) The aircraft's flight training supplement. (2) The aircraft must not have been previously issued a standard, primary, restricted, limited, or provisional airworthiness certificate, or an equivalent airworthiness certificate issued by a foreign civil aviation authority. (3) The aircraft must be inspected by the FAA and found to be in a condition for safe operation. (c) Manufacturer's statement of compliance for light-sport category aircraft. The manufacturer's statement of compliance required in paragraph (b)(1)(iii) of this section must=94 (1) Identify the aircraft by make and model, serial number, class, date of manufacture, and consensus standard used; (2) State that the aircraft meets the provisions of the identified consensus standard; (3) State that the aircraft conforms to the manufacturer's design data, using the manufacturer's quality assurance system that meets the identified consensus standard; (4) State that the manufacturer will make available to any interested person the following documents that meet the identified consensus standard: (i) The aircraft's operating instructions. (ii) The aircraft's maintenance and inspection procedures. (iii) The aircraft's flight training supplement. (5) State that the manufacturer will monitor and correct safety-of-flight issues through the issuance of safety directives and a continued airworthiness system that meets the identified consensus standard; (6) State that at the request of the FAA, the manufacturer will provide unrestricted access to its facilities; and (7) State that the manufacturer, in accordance with a production acceptance test procedure that meets an applicable consensus standard has=94 (i) Ground and flight tested the aircraft; (ii) Found the aircraft performance acceptable; and (iii) Determined that the aircraft is in a condition for safe operation. (d) Light-sport aircraft manufactured outside the United States. For aircraft manufactured outside of the United States to be eligible for a special airworthiness certificate in the light-sport category, an applicant must meet the requirements of paragraph (b) of this section and provide to the FAA evidence that=94 (1) The aircraft was manufactured in a country with which the United States has a Bilateral Airworthiness Agreement concerning airplanes or Bilateral Aviation Safety Agreement with associated Implementation Procedures for Airworthiness concerning airplanes, or an equivalent airworthiness agreement; and (2) The aircraft is eligible for an airworthiness certificate, flight authorization, or other similar certification in its country of manufacture . 21.191 Experimental certificates. (i) Operating light-sport aircraft. Operating a light-sport aircraft that =94 (1) Has not been issued a U.S. or foreign airworthiness certificate and does not meet the provisions of =C2=A7103.1 of this chapter. An experimenta l certificate will not be issued under this paragraph for these aircraft after January 31, 2008; (2) Has been assembled=94 (i) From an aircraft kit for which the applicant can provide the information required by =C2=A721.193(e); and (ii) In accordance with manufacturer's assembly instructions that meet an applicable consensus standard; or (3) Has been previously issued a special airworthiness certificate in the light-sport category under =C2=A721.190. 21.193 Experimental certificates: general. (e) In the case of a light-sport aircraft assembled from a kit to be certificated in accordance with =C2=A721.191(i)(2), an applicant must provi de the following: (1) Evidence that an aircraft of the same make and model was manufactured and assembled by the aircraft kit manufacturer and issued a special airworthiness certificate in the light-sport category. (2) The aircraft's operating instructions. (3) The aircraft's maintenance and inspection procedures. (4) The manufacturer's statement of compliance for the aircraft kit used in the aircraft assembly that meets =C2=A721.190(c), except that instead of me eting =C2=A721.190(c)(7), the statement must identify assembly instructions for t he aircraft that meet an applicable consensus standard. (5) The aircraft's flight training supplement. (6) In addition to paragraphs (e)(1) through (e)(5) of this section, for an aircraft kit manufactured outside of the United States, evidence that the aircraft kit was manufactured in a country with which the United States has a Bilateral Airworthiness Agreement concerning airplanes or a Bilateral Aviation Safety Agreement with associated Implementation Procedures for Airworthiness concerning airplanes, or an equivalent airworthiness agreement. On Sat, Aug 16, 2014 at 10:38 AM, Nick Cassara wrote: > Hello All, > > > In my case I bought a kit to recreate a prototype aircraft that no longer > exists. It will not be an exact copy of the prototype plane that no longe r > exists, and the design was and will remain significantly deferent from th e > production model. Do you think I will be able to get an ELSA? > > > Thanks, > > > Nick Cassara > > Palmer, Alaska > > > * > =========== onics.com/Navigator?Kolb-List> =========== =========== om/contribution> =========== > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Re: Brakes
Date: Aug 18, 2014
Uses plates bolted to various locations on the engine, not the same as a Rotax gear box. It is currently stored in a box, I will try to pull it out and take a photo some time this week. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428643#428643 ________________________________________________________________________________
Date: Aug 18, 2014
Subject: videos
Here are a couple of videos that I took yesterday on a flight to Jordan Craters, and on to the Owyhee River. https://vimeo.com/103685104 I managed to get the date wrong. https://vimeo.com/103685105 Password for both- owyheeflyer A little better than 120 miles, 2 hours and 6 minutes, 7 gallons of fuel. Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: videos/Flight West
Date: Aug 18, 2014
I have decided to take Larry Cottrell up on his offer to see the countryside around the Rock House. Plan to fly my MKIII back through Monument Valley, Utah, on the way West. Hope to depart Gantt IAP about 7 Sep. My flight will take me about 2,100 sm and 26.0 flight hours one way. If I decide to return to Alabama the shortest route, I will fly about 1,850 sm and 24.0 flight hours. I plan to celebrate my 75th year and my MKIII's (Miss P'er) 22d year. I'll burn 300.0 gallons of 100LL in transit there and back, between 1,700.00 and 1,800.00 dollars for fuel alone. Ouch! I can fly commercial round trip for about 500.00, but it isn't near as much fun and I wouldn't have Miss P'fer to fly when I got there. Besides, I don't like flying commercial. I'd rather be in charge. My general route of flight is: Titus, AL Memphis, TN Sherman, TX Clovis, NM Los Lunas, NM Gallup, NM Monument Valley, UT Wendover, UT Wells, NV Rock House, OR Return flight: Rock House, OR Buhl, ID Rock Springs, WY Laramie, WY Fort Morgan, CO Goodland, KS Neosho, MO Memphis, TN Columbus, MS Gantt IAP, AL I plan my flights to average 75 mph ground speed. Over the years this has proven pretty accurate. My airspeed is 80-85 mph depending on how heavy I am. Probably get 75.0 hours on this flight counting the hours I fly after I get there. john h mkIII Titus, Alabama Here are a couple of videos that I took yesterday on a flight to Jordan Craters, and on to the Owyhee River. https://vimeo.com/103685104 I managed to get the date wrong. https://vimeo.com/103685105 Password for both- owyheeflyer A little better than 120 miles, 2 hours and 6 minutes, 7 gallons of fuel. Larry ________________________________________________________________________________
Date: Aug 18, 2014
Subject: video editing
June 29, 2014 - August 18, 2014
Kolb-Archive.digest.vol-mu
