Kolb-Archive.digest.vol-nb
October 16, 2014 - Present
Subject: Re: Question for the builders...
Date: Oct 16, 2014
I'd drill em now, just use aluminum rivets in every 6th hole or so to hold t hings aligned as you drill, than remove and deburr before covering. Than bur n out the holes in fabric with a solder pencil before you paint while you ca n still see the holes. If you drill after you cover you are going to be patching holes. Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA > On Oct 16, 2014, at 1:10 PM, "Nick Cassara" wrote: > > Hello Kolb builders, > > I have all my surfaces ready to cover. I have laid out my wings flaps and a ilerons. The only thing I have not done is drill the holes to test mount the hinges. Is there any reason I could not wait and drill the hinge rivet hole s once everything is covered? Thanks as always for your thought! > > Nick Cassara > Palmer, Alaska > > Kolbra N607AK > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Question for the builders...
Date: Oct 16, 2014
Nick, My firefly was a quick build where the factory had already attached all the hinges with temporary rivets. All of the other rivet locations had a "dimple" where the holes were to be located but they were not dilled out. I drilled out the temporary rivets so I could use the drill press to finish the holes in the hinges. I then waited until all covering and painting were done before drilling the rest of the holes in the airframe, using the now drilled hinges as guides. As I covered, I kept the holes cleaned out, so they were easy to locate later. Although what I did worked out well, I kind of wished I had drilled everything before covering. I think it would have made final assembly easier. One think that I do regret is when I put the rudder half hinges on the rudder laying on the bench. Then I mounted the tail post halves on to the airframe separately, thinking I could just line up the hinges and drop the pins in place. I had done this on the wings with no problems, but on the rudder, for some reason the lower hinge would not align without a LOT of force on the rudder. I wound up slightly bending the bottom of the rudder and put a wrinkle in the fabric. Did not even notice it until it was all done. L My take is to pre-drill all the holes and be VERY careful with light weight structures. Worth what you paid for it.. Stuart From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Nick Cassara Sent: Thursday, October 16, 2014 12:10 PM Subject: Kolb-List: Question for the builders... Hello Kolb builders, I have all my surfaces ready to cover. I have laid out my wings flaps and ailerons. The only thing I have not done is drill the holes to test mount the hinges. Is there any reason I could not wait and drill the hinge rivet holes once everything is covered? Thanks as always for your thought! Nick Cassara Palmer, Alaska Kolbra N607AK ________________________________________________________________________________
Date: Oct 17, 2014
Nick, When I was a youngster, my dad used to argue with me saying "you can do it any way you want to, but if I were doing it", and then he would proceed to tell me his way to do something. Well, I won't say it quite that way, but here's an idea that is especially useful for the wings and ailerons. Drill the holes smaller than for the rivets and use # 6 sheet metal screws (4 per hinge) to hold things together. After checking the folding operation and making any minor adjustments to hole location, remove the screws and drill all the holes out to the rivet size. Be sure to mark each hinge assembly so it can be properly repositioned after covering, because the hole locations will probably not all be exactly alike. This was not my idea, read it somewhere, maybe even in my Kolb FireStar builders manual. Bill Varnes Original Kolb FireStar Audubon NJ Do Not Archive In a message dated 10/16/2014 1:11:01 P.M. Eastern Daylight Time, nickc(at)mtaonline.net writes: Hello Kolb builders, I have all my surfaces ready to cover. I have laid out my wings flaps and ailerons. The only thing I have not done is drill the holes to test mount the hinges. Is there any reason I could not wait and drill the hinge rivet holes once everything is covered? Thanks as always for your thought! Nick Cassara Palmer, Alaska Kolbra N607AK ________________________________________________________________________________
Subject: firestar for sale
Date: Oct 17, 2014
Have new project in the hangar so I need the room. 5 rib single seater. Strong running Rotax 377 recent service by rotax service center. gearbox and 3 blade Ivo. ballistic chute needs repack. Tinytach, airspeed, altimeter, compass, cht, egt, New fuel tank, new factory tailwheel. Summer and winter enclosures. needs nothing. $4500 located central NC east of charlotte. white with blue trim. Gary 704-467-2282 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=431996#431996 ________________________________________________________________________________
Subject: Fiberglass droop tips?
Date: Oct 18, 2014
Hello Kolb builders, Thank you all for the great help with my questions! Here is the next one. I was fitting my fiberglass droop tip on to my right wing end. The inside of the fiberglass tip is not the same shape as the steel end rib. When I slide the tip on the end rib, it will not slide back and make contact with the leading edge tube, and there is a =BE inch gap. It is not possible to spread the tip at all, and the trailing edge does not line up with the trailing edge of the aileron. I have never worked with fiberglass, and all I can think is to try and grind the inside to try to gain more forward fit=85.an recommendations for grinding glass? I honestly don=92t know if I can remove enough glass to get the fit. Thanks again, Nick Cassara Palmer, Alaska 607AK ________________________________________________________________________________
Subject: Re: Fiberglass droop tips?
Date: Oct 18, 2014
Any possibility of pictures showing the specifics of the problem? That would help a lot. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432014#432014 ________________________________________________________________________________
Date: Oct 18, 2014
From: william sullivan <williamtsullivan(at)att.net>
Nick- One trick is to take some lipstick and coat the outer end of the wi ng. press on the droop tip, remove, and look for the marks inside the fibe rglass. The soft wax of the lipstick makes for a good transfer. There are the usual cautions of explaining to the wife just where her lipstick went. ..=0A=0A Bill Sullivan=0A=0A=0A=0A________________________________=0A From: Nick Cassara =0ATo: kolb-list(at)matronics.com =0ASent: Satur day, October 18, 2014 3:21 PM=0ASubject: Kolb-List: Fiberglass droop tips? =0A =0A=0A=0AHello Kolb builders,=0A =0AThank you all for the great help wi th my questions! Here is the next one. I was fitting my fiberglass droop ti p on to my right wing end. The inside of the fiberglass tip is not the same shape as the steel end rib. When I slide the tip on the end rib, it will n ot slide back and make contact with the leading edge tube, and there is a =C2=BE inch gap. It is not possible to spread the tip at all, and the trail ing edge does not line up with the trailing edge of the aileron.=0A =0AI ha ve never worked with fiberglass, and all I can think is to try and grind th e inside to try to gain more forward fit.an recommendations for gr inding glass? I honestly don=99t know if I can remove enough glass to get the fit.=0A =0AThanks again,=0A =0ANick Cassara =0APalmer, Alaska=0A ================= ________________________________________________________________________________
Date: Oct 18, 2014
I have been think of putting the drooped wing tip on my MK111. I had put th em on my Challenge 11 clip wing special and it made a big difference in bot h speed=2C stall and handling is why I am think of installing them. Date: Sat=2C 18 Oct 2014 17:03:09 -0700 From: williamtsullivan(at)att.net Subject: Re: Kolb-List: Fiberglass droop tips? Nick- One trick is to take some lipstick and coat the outer end of the wi ng. press on the droop tip=2C remove=2C and look for the marks inside the fiberglass. The soft wax of the lipstick makes for a good transfer. There are the usual cautions of explaining to the wife just where her lipstick w ent... Bill Sullivan From: Nick Cassara <nickc(at)mtaonline.net> To: kolb-list(at)matronics.com =0A Sent: Saturday=2C October 18=2C 2014 3:21 PM Subject: Kolb-List: Fiberglass droop tips? Hello Kolb builders=2C Thank you all for the great help with my questions! Here is the next one. I was fitting my fiberglass droop tip on to my right wing end. The inside of the fiberglass tip is not the same shape as the st eel end rib. When I slide the tip on the end rib=2C it will not slide back and make contact with the leading edge tube=2C and there is a =BE inch gap. It is not possible to spread the tip at all=2C and the trailing edge does not line up with the trailing edge of the aileron. I have never worked wit h fiberglass=2C and all I can think is to try and grind the inside to try t o gain more forward fit=85.an recommendations for grinding glass? I honestl y don=92t know if I can remove=0A enough glass to get the fit. Thanks again=2C Nick Cassara Palmer=2C Alas ka 607AK =0A =0A =0A href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics. =========================0A " target="_blank" href="http://forums.matronics.com/">http://forums.mat --> =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Subject: Droop tip
Date: Oct 19, 2014
Kolb builders, Here are a couple pictures showing the droop tip protruding ahead of the wing leading edge, in reference to yesterdays post. Thanks, Nick Cassara Palmer, Alaska ________________________________________________________________________________
Date: Oct 19, 2014
Subject: Re: Droop tip
Nick- Where did you get the tips? Not even a close fit. Bill Sullivan -------------------------------------------- On Sun, 10/19/14, Nick Cassara wrote: Subject: Kolb-List: Droop tip To: kolb-list(at)matronics.com Date: Sunday, October 19, 2014, 8:59 PM Kolb builders, Here are a couple pictures showing the droop tip protruding ahead of the wing leading edge, in reference to yesterdays post. Thanks, Nick CassaraPalmer, Alaska ________________________________________________________________________________
Subject: Droop tip
Date: Oct 19, 2014
There has to be something wrong to fit like that. I have worked with F/G fo r years and as thin as that has to be you'll have problems. They may have s et you the wrong ones or have a bad mold. As I said I had put a set on my Challenger with out any problems which fit a lot better than the photos show. > Date: Sun=2C 19 Oct 2014 18:29:35 -0700 > From: williamtsullivan(at)att.net > Subject: Re: Kolb-List: Droop tip > To: kolb-list(at)matronics.com > et> > > Nick- Where did you get the tips? Not even a close fit. > > Bill Sullivan > > > -------------------------------------------- > On Sun=2C 10/19/14=2C Nick Cassara wrote: > > Subject: Kolb-List: Droop tip > To: kolb-list(at)matronics.com > Date: Sunday=2C October 19=2C 2014=2C 8:59 PM > > Kolb builders=2C Here are a couple pictures > showing the droop tip protruding ahead of the wing leading > edge=2C in reference to yesterdays post. Thanks=2C Nick CassaraPalmer =2C > Alaska > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Oct 20, 2014
Subject: M3X Roll Problems
Test flying my Mark 3X after initial flutter problems found that flaperons were impossible to move in flight and all roll control was by secondary effect of rudder. Balance rods were fitted to balance tubes, but otherwise they appear normal on ground. Anyone had any similar issues? ________________________________________________________________________________
Date: Oct 20, 2014
Subject: Re: M3X Roll Problems
Further to this, I figure I've 'over-balanced' the ailerons as Kolb did not include the anti-flutter kit with mine and it only came to my attention through this forum. Maybe someone could send me pics of their balance rod installation as I'm thinking mine must extend too far forward of the hinge point. On 20 October 2014 22:51, Tony Malins wrote: > Test flying my Mark 3X after initial flutter problems found that flaperons > were impossible to move in flight and all roll control was by secondary > effect of rudder. Balance rods were fitted to balance tubes, but otherwise > they appear normal on ground. > > Anyone had any similar issues? > > * > > > * > > ________________________________________________________________________________
Date: Oct 20, 2014
Hi Tony, Don't know about the xtra , but on my MK3 the twin sticks were about 1&1/2 In.too long and when pushed forward and to one side or the other, The off side stick would hang up under the tube that runs from the panel and Back overhead that the windscreen Is mounted on. Causing the Ailerons to lock up. Hard to find the problem Because of my panic when aileron Control is lost. And my reluctance To voluntary enter that condition. For me a simple cure--I cut 1&1/2 Inches off the sticks. Hope your problem is as easily cured. Good luck Frank Sent from my iPhone On Oct 20, 2014, at 8:16 AM, Tony Malins wrote: > Further to this, I figure I've 'over-balanced' the ailerons as Kolb did no t include the anti-flutter kit with mine and it only came to my attention th rough this forum. Maybe someone could send me pics of their balance rod inst allation as I'm thinking mine must extend too far forward of the hinge point . > > On 20 October 2014 22:51, Tony Malins wrote: >> Test flying my Mark 3X after initial flutter problems found that flaperon s were impossible to move in flight and all roll control was by secondary ef fect of rudder. Balance rods were fitted to balance tubes, but otherwise the y appear normal on ground. >> >> Anyone had any similar issues? >> >> >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Oct 20, 2014
Tony M/Kolbers: The aileron counter balance rods are just that. They should extend far enough forward to balance the ailerons. Here is how I balanced my ailerons: -Disconnected the aileron push/pull tube at the aileron horn. -Adjusted the aileron counter balance rod fore and aft until it balanced the aileron. -Replaced the aileron push/pull tube at the aileron horn. Works for me. No aileron flutter after installation of aileron counter balance weights. john h mkIII Titus, Alabama Further to this, I figure I've 'over-balanced' the ailerons as Kolb did not include the anti-flutter kit with mine and it only came to my attention through this forum. Maybe someone could send me pics of their balance rod installation as I'm thinking mine must extend too far forward of the hinge point. On 20 October 2014 22:51, Tony Malins wrote: Test flying my Mark 3X after initial flutter problems found that flaperons were impossible to move in flight and all roll control was by secondary effect of rudder. Balance rods were fitted to balance tubes, but otherwise they appear normal on ground. Anyone had any similar issues? ________________________________________________________________________________
From: Colin Hudson <colin.scott.hudson(at)gmail.com>
Date: Oct 20, 2014
Tony you didn't state if you had dual controls or not. I changed from singl e control to duals in my X-tra and had the same problem. Moved easy on the g round but not in flight. Found too much play in the controls and a leverage problem with the duals. Went back to single control and flys like a dream a gain. Scott Hudson N424AL A/P Sent from my iPhone > On Oct 20, 2014, at 7:51 AM, Tony Malins wrote: > > Test flying my Mark 3X after initial flutter problems found that flaperons were impossible to move in flight and all roll control was by secondary eff ect of rudder. Balance rods were fitted to balance tubes, but otherwise they appear normal on ground. > > Anyone had any similar issues? > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Re: GRT EIS for sale
Date: Oct 20, 2014
Will this unit work with a cuyuna? I need rpm cht egt Thanks bob -------- 1984 kolb ultrstar Former 1997 kolb firestat Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432089#432089 ________________________________________________________________________________
Subject: UltraStar Project for sale
Date: Oct 20, 2014
Subject: UltraStar Project for Sale. Contact: Mr. Chuck Moon, Wimauma, FL. CELL: 813-390 1222 Price: $1,500 This is a sale by third party following the death of the acft owner before he could complete the repair/restoration. Background: Ultrastar, in garage storage since approximately 2002. Suffered right wing damage when wooden prop disintegrated at cruise and the prop fragment passed upward through outer portion of wing. Engine was shut down and acft was successfully landed without further damage. Structural damage appears confined to aft portion of one rib, but fabric removal around damage will be required to verify. Airframe appears straight, with no observable, significant corrosion problems evident. Condition of fabric on remainder of airplane is unknown, but looks OK. The following YouTube link provides photos taken this week: http://youtu.be/Wp7j1wh7OSE Engine: Cuyuna (Carburetor is missing). Propeller requires replacement. Seasoned Kolbers on this list may remember The late Skip Staub, CDR, US. Navy, F8 Crusader driver extraordinaire and Kolb enthusiast. This Ultrastar was Skip's and he was flying it over Palmetto, FL when the prop failed. Beauford FF-076 Brandon, FL ________________________________________________________________________________
Date: Oct 21, 2014
Thanks Frank. I suspect that is the problem. On 20 October 2014 23:52, Frank wrote: > Hi Tony, > Don't know about the xtra , but on my > MK3 the twin sticks were about 1&1/2 > In.too long and when pushed forward and to one side or the other, > The off side stick would hang up under > the tube that runs from the panel and > Back overhead that the windscreen > Is mounted on. Causing the Ailerons > to lock up. Hard to find the problem > Because of my panic when aileron > Control is lost. And my reluctance > To voluntary enter that condition. > For me a simple cure--I cut 1&1/2 > Inches off the sticks. > Hope your problem is as easily cured. > Good luck > Frank > > Sent from my iPhone > > On Oct 20, 2014, at 8:16 AM, Tony Malins wrote: > > Further to this, I figure I've 'over-balanced' the ailerons as Kolb did > not include the anti-flutter kit with mine and it only came to my attention > through this forum. Maybe someone could send me pics of their balance rod > installation as I'm thinking mine must extend too far forward of the hinge > point. > > On 20 October 2014 22:51, Tony Malins wrote: > >> Test flying my Mark 3X after initial flutter problems found that >> flaperons were impossible to move in flight and all roll control was by >> secondary effect of rudder. Balance rods were fitted to balance tubes, but >> otherwise they appear normal on ground. >> >> Anyone had any similar issues? >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > > ================================== > ://www.matronics.com/Navigator?Kolb-List <http://www.matronics.com/Navigator?Kolb-List> > ================================== > cs.com <http://cs.com> > ================================== > matronics.com/contribution <http://matronics.com/contribution> > ================================== > > * > > * > > > * > > ________________________________________________________________________________
Date: Oct 21, 2014
Good thought Colin, I have dual controls..will check. On 21 October 2014 01:06, Colin Hudson wrote: > Tony you didn't state if you had dual controls or not. I changed from > single control to duals in my X-tra and had the same problem. Moved easy > on the ground but not in flight. Found too much play in the controls and a > leverage problem with the duals. Went back to single control and flys like > a dream again. > > Scott Hudson > N424AL > A/P > > Sent from my iPhone > > On Oct 20, 2014, at 7:51 AM, Tony Malins wrote: > > Test flying my Mark 3X after initial flutter problems found that flaperons > were impossible to move in flight and all roll control was by secondary > effect of rudder. Balance rods were fitted to balance tubes, but otherwise > they appear normal on ground. > > Anyone had any similar issues? > > * > > D============================================ > List"">http://www.matronics.com/Navigator?Kolb-List > D============================================ > //forums.matronics.com <http://forums.matronics.com> > D============================================ > ot;">http://www.matronics.com/contribution > D============================================ > > * > > * > > > * > > ________________________________________________________________________________
Date: Oct 20, 2014
Do all mark 3 Kolbs require balance tubes? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432098#432098 ________________________________________________________________________________
Date: Oct 20, 2014
Highly recommended. john h mkIII Titus, Alabama Do all mark 3 Kolbs require balance tubes? ________________________________________________________________________________
Date: Oct 20, 2014
I have rounded wingtips. Is there another option? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432101#432101 ________________________________________________________________________________
Date: Oct 20, 2014
I just sold my Mark 3X with flaperons about 6 months ago and while the airplane has some very nice features, the roll control is not one of them. They are extremely heavy and quite ineffective. But that is typical of simple flaperons. Here are a few points to consider: The balances you are talking about are mass balances to control flutter. They have no measurable impact on control feel. Aerodynamic balances lighten the control forces and there are some pictures on the web of "spade" types on the M3X, I am not sure how well they have been tested. Spades work fine on sturdy ailerons like on aerobatic airplanes, but I am not sure the Kolb is meant for large control deflections. As John H likes to say, be careful making big changes to Homer's design. Note that the tube that is the forward spar of the flaperon looks like a torque tube at first but when you look at where the hinge points are you can see that it is actually in bending. To prove this you can move the flaperon to full travel using the mass balance and then gently twist in the same direction. You will see the tube bend with the stick at its stops. Like others I made a small change to get more mechanical advantage and lower the force, but I gave up aileron travel in the process. When you are flying the airplane you can move the linkage with enough force but the flaperon barely moves at all. This is because the tube is bending and absorbing most of the motion. As an aerospace designer, I can tell you that flaperons are compromises. They move together to lower stall speed, which mine did some, and differentially to roll the plane, which mine did poorly for the reasons mentioned above. Ailerons are very different. They have less area which makes them easier to move and it is way out on the wing where it produces relatively more roll control for a given deflection. If I were building a Kolb I would go with traditional ailerons. Jim On Mon, Oct 20, 2014 at 6:33 PM, Tony Malins wrote: > Good thought Colin, I have dual controls..will check. > > On 21 October 2014 01:06, Colin Hudson > wrote: > >> Tony you didn't state if you had dual controls or not. I changed from >> single control to duals in my X-tra and had the same problem. Moved easy >> on the ground but not in flight. Found too much play in the controls and a >> leverage problem with the duals. Went back to single control and flys like >> a dream again. >> >> Scott Hudson >> N424AL >> A/P >> >> Sent from my iPhone >> >> On Oct 20, 2014, at 7:51 AM, Tony Malins wrote: >> >> Test flying my Mark 3X after initial flutter problems found that >> flaperons were impossible to move in flight and all roll control was by >> secondary effect of rudder. Balance rods were fitted to balance tubes, but >> otherwise they appear normal on ground. >> >> Anyone had any similar issues? >> >> * >> >> D============================================ >> List"">http://www.matronics.com/Navigator?Kolb-List >> D============================================ >> //forums.matronics.com <http://forums.matronics.com> >> D============================================ >> ot;">http://www.matronics.com/contribution >> D============================================ >> >> * >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > > > * > > ________________________________________________________________________________
Date: Oct 21, 2014
Thanks James, a lot of good info to digest, but I'll work on this. On 21 October 2014 11:03, wrote: > I just sold my Mark 3X with flaperons about 6 months ago and while the > airplane has some very nice features, the roll control is not one of them. > They are extremely heavy and quite ineffective. But that is typical of > simple flaperons. > > Here are a few points to consider: > > The balances you are talking about are mass balances to control flutter. > They have no measurable impact on control feel. Aerodynamic balances > lighten the control forces and there are some pictures on the web of > "spade" types on the M3X, I am not sure how well they have been tested. > Spades work fine on sturdy ailerons like on aerobatic airplanes, but I am > not sure the Kolb is meant for large control deflections. As John H likes > to say, be careful making big changes to Homer's design. > > Note that the tube that is the forward spar of the flaperon looks like a > torque tube at first but when you look at where the hinge points are you > can see that it is actually in bending. To prove this you can move the > flaperon to full travel using the mass balance and then gently twist in the > same direction. You will see the tube bend with the stick at its stops. > Like others I made a small change to get more mechanical advantage and > lower the force, but I gave up aileron travel in the process. When you are > flying the airplane you can move the linkage with enough force but the > flaperon barely moves at all. This is because the tube is bending and > absorbing most of the motion. > > As an aerospace designer, I can tell you that flaperons are compromises. > They move together to lower stall speed, which mine did some, and > differentially to roll the plane, which mine did poorly for the reasons > mentioned above. Ailerons are very different. They have less area which > makes them easier to move and it is way out on the wing where it produces > relatively more roll control for a given deflection. > > If I were building a Kolb I would go with traditional ailerons. > > Jim > > On Mon, Oct 20, 2014 at 6:33 PM, Tony Malins wrote: > >> Good thought Colin, I have dual controls..will check. >> >> On 21 October 2014 01:06, Colin Hudson >> wrote: >> >>> Tony you didn't state if you had dual controls or not. I changed from >>> single control to duals in my X-tra and had the same problem. Moved easy >>> on the ground but not in flight. Found too much play in the controls and a >>> leverage problem with the duals. Went back to single control and flys like >>> a dream again. >>> >>> Scott Hudson >>> N424AL >>> A/P >>> >>> Sent from my iPhone >>> >>> On Oct 20, 2014, at 7:51 AM, Tony Malins wrote: >>> >>> Test flying my Mark 3X after initial flutter problems found that >>> flaperons were impossible to move in flight and all roll control was by >>> secondary effect of rudder. Balance rods were fitted to balance tubes, but >>> otherwise they appear normal on ground. >>> >>> Anyone had any similar issues? >>> >>> * >>> >>> D============================================ >>> List"">http://www.matronics.com/Navigator?Kolb-List >>> D============================================ >>> //forums.matronics.com <http://forums.matronics.com> >>> D============================================ >>> ot;">http://www.matronics.com/contribution >>> D============================================ >>> >>> * >>> >>> * >>> >>> get="_blank">http://www.matronics.com/Navigator?Kolb-List >>> tp://forums.matronics.com <http://forums.matronics.com> >>> _blank">http://www.matronics.com/contribution >>> >>> * >>> >>> >> * >> >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > > > * > > ________________________________________________________________________________
Date: Oct 20, 2014
Fly slower Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA > On Oct 20, 2014, at 8:39 PM, "pipercolt" wrote: > > > I have rounded wingtips. Is there another option? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=432101#432101 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 21, 2014
When I first flew my MKIII I was disappointed in how heavy it was in roll. After about 50 or so hours in it, I no longer noticed. I have since sold the MKIII but I do have a set of steel aileron spade brackets that I asked TNK aircraft to make me. They have a flat plate on one end which you would attach a piece of aluminum as your spade and the other end is a half pipe to rivet to the aileron. The section in between is airfoil shaped. I would sell them for $30 plus shipping. Jason Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432129#432129 ________________________________________________________________________________
Date: Oct 21, 2014
How did the spades work on your MKIII? john h mkIII Titus, Alabama When I first flew my MKIII I was disappointed in how heavy it was in roll. After about 50 or so hours in it, I no longer noticed. I have since sold the MKIII but I do have a set of steel aileron spade brackets that I asked TNK aircraft to make me. They have a flat plate on one end which you would attach a piece of aluminum as your spade and the other end is a half pipe to rivet to the aileron. The section in between is airfoil shaped. I would sell them for $30 plus shipping. Jason ________________________________________________________________________________
Date: Oct 21, 2014
Hey Jason I would like to talk to you about the spades. If you don't mind please call me at 765-346-2622 Thanks Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432138#432138 ________________________________________________________________________________
Subject: Legal Twinstar
Date: Oct 21, 2014
Looking for some ideas. Ill try to keep this short but give as much detail as I can. I bought a Twinstar MK II as a rebuild project. Would like to be able to register it and be all legal when the build is complete. Here is the situation. Purchased from the second owner who started the rebuild but could not complete. First owner built from kit and flew. I was told that it had been registered by first owner but I do not have any proof of this. Second owner did not have any placard or N-number or paperwork. If anyone has any ideas of how to best go about being able to register later I sure would like to hear them. I am contemplating contacting the local DAR for input but am a bit hesitant yet. Thanks in advance. -------- Mark Twinstar MKII Great Bend, PA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432144#432144 ________________________________________________________________________________
Date: Oct 21, 2014
You should be able to search the FAA database online using either the builder's name or the serial number of the aircraft. It has been quite some time since I have looked at the online database, but in the past I was able to find this kind of information. If you are an AOPA member, they may be able to help, I know they do title research work. Possibly even the EAA. Best of luck, Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Shadow94 Sent: Tuesday, October 21, 2014 8:04 PM Subject: Kolb-List: Legal Twinstar Looking for some ideas. Ill try to keep this short but give as much detail as I can. I bought a Twinstar MK II as a rebuild project. Would like to be able to register it and be all legal when the build is complete. Here is the situation. Purchased from the second owner who started the rebuild but could not complete. First owner built from kit and flew. I was told that it had been registered by first owner but I do not have any proof of this. Second owner did not have any placard or N-number or paperwork. If anyone has any ideas of how to best go about being able to register later I sure would like to hear them. I am contemplating contacting the local DAR for input but am a bit hesitant yet. Thanks in advance. -------- Mark Twinstar MKII Great Bend, PA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432144#432144 ________________________________________________________________________________
Date: Oct 22, 2014
Thanks Jason. I'll talk further to Travis about it. Cheers Tony On 22 October 2014 04:55, John Hauck wrote: > > How did the spades work on your MKIII? > > john h > mkIII > Titus, Alabama > > > When I first flew my MKIII I was disappointed in how heavy it was in roll. > After about 50 or so hours in it, I no longer noticed. I have since sold > the MKIII but I do have a set of steel aileron spade brackets that I asked > TNK aircraft to make me. They have a flat plate on one end which you would > attach a piece of aluminum as your spade and the other end is a half pipe > to > rivet to the aileron. The section in between is airfoil shaped. I would > sell them for $30 plus shipping. > > Jason > > ________________________________________________________________________________
Date: Oct 22, 2014
I don't know how they worked, I never installed them. I have seen them on a MKIII but I never tried them. John Hauck wrote: > How did the spades work on your MKIII? > > john h > mkIII > Titus, Alabama > > > > When I first flew my MKIII I was disappointed in how heavy it was in roll. > After about 50 or so hours in it, I no longer noticed. I have since sold > the MKIII but I do have a set of steel aileron spade brackets that I asked > TNK aircraft to make me. They have a flat plate on one end which you would > attach a piece of aluminum as your spade and the other end is a half pipe to > rivet to the aileron. The section in between is airfoil shaped. I would > sell them for $30 plus shipping. > > Jason Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432153#432153 ________________________________________________________________________________
Subject: Dennis souder
Date: Oct 22, 2014
Anyone know if Dennis is around and contact Info would be appreciated. Bob -------- 1984 kolb ultrstar Former 1997 kolb firestat Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432167#432167 ________________________________________________________________________________
Date: Oct 23, 2014
did Kolb send instructions as to what angle the spade should be mounted? boyd young >>>> I don't know how they worked, I never installed them. I have seen them on a MKIII but I never tried them. --- This email is free from viruses and malware because avast! Antivirus protection is active. http://www.avast.com ________________________________________________________________________________
Date: Oct 23, 2014
Typically you would mount them with he spade parallel to the airflow in level flight. When you deflect the surface you also expose the surface of the spade to the airflow and it helps move the surface. Size of the spade is what would be the unknown. Just how much area do you need to get the results you want without over stressing the aileron system or introducing roll rates that the wing is not designed to handle. Jason byoungplumbing(at)gmail.c wrote: > did Kolb send instructions as to what angle the spade should be mounted? > > boyd young > > > > >>> > > > > > > I don't know how they worked, I never installed them. I have seen them on a > MKIII > but I never tried them. > > > --- > This email is free from viruses and malware because avast! Antivirus protection is active. > http://www.avast.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432187#432187 ________________________________________________________________________________
Date: Oct 23, 2014
Complicating this is the flaperons both droop, putting both spades under load. Not sure how well that works. On Thu, Oct 23, 2014 at 1:29 PM, Jason Omelchuck <jason@trek-tech.com> wrote: > > Typically you would mount them with he spade parallel to the airflow in > level flight. When you deflect the surface you also expose the surface of > the spade to the airflow and it helps move the surface. Size of the spade > is what would be the unknown. Just how much area do you need to get the > results you want without over stressing the aileron system or introducing > roll rates that the wing is not designed to handle. > > Jason > > > byoungplumbing(at)gmail.c wrote: > > did Kolb send instructions as to what angle the spade should be mounted? > > > > boyd young > > > > > > > >>> > > > > > > > > > > I don't know how they worked, I never installed them. I have seen them > on a > > MKIII > > but I never tried them. > > > > > > --- > > This email is free from viruses and malware because avast! Antivirus > protection is active. > > http://www.avast.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=432187#432187 > > ________________________________________________________________________________
Subject: Damaged FS II for sale, N-numbered and registered ELSA
Date: Oct 23, 2014
After an axel bracket failure, and nose over, upon landing in August of 2013. I have decided to sell my FSII rather then repairing it. There was extensive damage to the cage and boom tube, also damage to one wing tip. I am asking $3500.00 for aircraft, Rotax 503 DCDI with electric starter, 72 hours on the hour meter. Includes the following, three blade Ivo Prop, BRS 5 VLS 750 repack expired 12/13, rocket good until 2020. Manual brakes, Kuntzelman strobes, dual fuel gauges, blue prints and manuals. Open aluminum diamond plate trailer large enough to haul the FSII, includes three spare rims and tires. Or $3000.00 without the trailer, $2500 without the trailer and BRS. Sold as is where is. First person that hands me the money, and signs a sales agreement, owns it. (cash or certified check) Located near Catawissa, Pa. 17820. E-mail is donaho1(at)verizon.net. Phone is #570-799-0198 if I don`t answer leave a message. Please only contact me if you are a serious buyer. ________________________________________________________________________________
Date: Oct 23, 2014
Subject: Kolbra I been try to sell my kolbra , Im down to 16500.00 really
nice flying, You can see it on youtube pull it up type in Kolbra short feild take- off. It been on barnstormers and trade a plane and no
a plane I keep dropping the price What I'm doing wrong =8B ________________________________________________________________________________
Subject: Re: Kolbra I been try to sell my kolbra , Im down to 16500.00
really nice flying, You can see it on youtube pull it up type in Kolbra short feild take- off. It been on barnstormers and trade a plane and no
Date: Oct 23, 2014
Where you are advertising this beauty may be part of the problem. I can't find it on eBay or Barnstormers. ----- Original Message ----- From: Larry Gitt To: Diget Server, Kolb-List Sent: Thursday, October 23, 2014 8:36 PM Subject: Kolb-List: Kolbra I been try to sell my kolbra , Im down to 16500.00 really nice flying, You can see it on youtube pull it up type in Kolbra short feild take- off. It been on barnstormers and trade a plane and no a plane I keep dropping the price What I'm doing wrong =8B ________________________________________________________________________________
Date: Oct 24, 2014
really nice flying, You can see it on youtube pull it up type in Kolbra short feild take- off. It been on barnstormers and trade a plane and no ________________________________________________________________________________
Subject: ultrastar cuyuna prop shaft breakage
Date: Oct 25, 2014
A long time ago these shafts were plagued with breakage. Supposedly there was a fix. Anyone have knowledge of this issue? -------- 1984 kolb ultrstar Former 1997 kolb firestat Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432266#432266 ________________________________________________________________________________
Date: Oct 26, 2014
Subject: Fw: bob barinngers planes
=C2-this is a couple planes we have for sale one is a kolb=C2-=C2- ch eck it out=C2- =C2-=C2-a special thanks to my wife Jeanne for all her effort in making these slide shows=C2- please check them out and let us know what you thi nk=C2-baby great lakes=C2-=C2- http://youtu.be/smlmjiqTi2o?list=UU7 bvKi16Ksu42bb-7vtVPsw kolb slide show=C2- =C2-http://youtu.be/eSR41x-MUbU?list=UU7bvKi16Ksu 42bb-7vtVPsw=C2-=C2- and my favorite by far=C2- http://youtu.be/smlmjiqTi2o?list=UU7bvKi16Ks u42bb-7vtVPsw=C2- Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.comLSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022=C2-=C2-=C2-=C2- ________________________________________________________________________________
Date: Oct 25, 2014
Never knew there was a problem with Homer Kolb's redrive and prop shaft, much less a fix. The prop shaft was pretty husky for a 35 hp engine and a 50 inch wooden prop. john h mkIII Titus, Alabama A long time ago these shafts were plagued with breakage. Supposedly there was a fix. Anyone have knowledge of this issue? -------- 1984 kolb ultrstar Former 1997 kolb firestat ________________________________________________________________________________
Subject: Re: ultrastar cuyuna prop shaft breakage
Date: Oct 25, 2014
I agree but.... In my ultra stars documents is a hand written letter by homer himself talking about the prop shaft failures. He stated there was a fix and most we're upgraded but I'm looking for some details here to decide whether I need to address mine. It sure looks beefy tho... A shaft failure of a pusher would be bad indeed. He also states that eventually the cuyuna cranks will break from belt tension. Looking for some info on this as well. -------- 1984 kolb ultrstar Former 1997 kolb firestat Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432280#432280 ________________________________________________________________________________
Date: Oct 25, 2014
Do you know when the US kit was purchased? I bought mine Feb 1984, one of the first US kits to be shipped with factory welded fuselage and components. Earlier versions were shipped as material kits with builder required welding. Don't know when the ULII02 replaced the 430, but may have been a factor in possible crank shaft failures. john h mkIII Titus, Alabama I agree but.... In my ultra stars documents is a hand written letter by homer himself talking about the prop shaft failures. He stated there was a fix and most we're upgraded but I'm looking for some details here to decide whether I need to address mine. It sure looks beefy tho... A shaft failure of a pusher would be bad indeed. He also states that eventually the cuyuna cranks will break from belt tension. Looking for some info on this as well. -------- 1984 kolb ultrstar Former 1997 kolb firestat ________________________________________________________________________________
Subject: Re: bob barinngers planes
Date: Oct 26, 2014
The Kolb video was fantastic. That's how you sell a Kolb! -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432294#432294 ________________________________________________________________________________
Date: Oct 26, 2014
Subject: for sale Kolbra
So you make a video where do you list it at , Has barnstormer will not let put you tube in your add at all , trade a plane same way. I no it harder to sale This type of plane as it a Experimental and requires a licence. yes it can be flown as a lite sport Just need to find a buyer ________________________________________________________________________________
Date: Oct 26, 2014
Scott What video? Where can I access it? On Oct 26, 2014, at 10:06 AM, olendorf wrote: > > The Kolb video was fantastic. That's how you sell a Kolb! > > -------- > Scott Olendorf > Original Firestar, Rotax 447, Powerfin prop > Schenectady, NY > http://sites.google.com/site/kolbfirestar/ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=432294#432294 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 26, 2014
Go here. http://forums.matronics.com/viewtopic.php?p=432294#432294 It's in the first post of the topic. They really need to get rid of the email version of the Matronics lists and just go exclusively with the web forum. It's way less confusing. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432317#432317 ________________________________________________________________________________
Date: Oct 26, 2014
I hope Matt doesn't get rid of the email version of the Kolb List. I have been using it for the past 16 years, and prefer it over the BBS. john h mkIII Sevierville, Tennessee They really need to get rid of the email version of the Matronics lists and just go exclusively with the web forum. It's way less confusing. -------- Scott Olendorf ________________________________________________________________________________
Date: Oct 26, 2014
I agree with John i would hate to loose the Email it has been real good to me Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly On Sunday, October 26, 2014 5:59 PM, John Hauck wrote: > > >I hope Matt doesn't get rid of the email version of the Kolb >List. I have been using it for the past 16 years, and >prefer it over the BBS. > >john h >mkIII >Sevierville, Tennessee > > >They really need to get rid of the email version of the >Matronics lists and just go exclusively with the web forum. >It's way less confusing. > >-------- >Scott Olendorf > > ________________________________________________________________________________
Date: Oct 26, 2014
John, I'll check on the date but it was a materials kit. I was wondering what happened to you when the leading edge failed causing you to parachute to safety? Something I need to be worried about? -------- 1984 kolb ultrstar Former 1997 kolb firestat Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432324#432324 ________________________________________________________________________________
Date: Oct 27, 2014
On the Ultrastar it was the upper aileron bell crank that failed. Was a factory welded kit and there was no brace on it, as depicted in the plans. Homer Kolb decided since the kit was TIG welded it would be stronger and not need the brace. I proved him wrong. john h mkIII Sevierville, Tennessee John, I'll check on the date but it was a materials kit. I was wondering what happened to you when the leading edge failed causing you to parachute to safety? Something I need to be worried about? -------- 1984 kolb ultrstar Former 1997 kolb firestat Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432324#432324 = Photoshare, and much much more: = = = ________________________________________________________________________________
Subject: Re: Legal Twinstar
Date: Oct 27, 2014
Thank you all for your input. The replies were interesting and very informative. I spent an hour on the phone the other day with an EAA representative. My membership has already paid off. He was able to offer more insight into the experimental and experimental exhibition. It really does look like the exhibition just might be my best path forward. It will take some more research into all the steps needed to complete the process. It would allow me to get my Twinstar registered and the restrictions would fit into the flying I want to do with the plane. This forum as well as the Kolb Facebook page are great sources of info and Kolb sense. -------- Mark Twinstar MKII Great Bend, PA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432384#432384 ________________________________________________________________________________
Date: Oct 28, 2014
Subject: Lipstick on a pig..
CkNsZWFuaW5nIHVwIHRoZSBjdXl1bmEuIC4uCgpCb2IK ________________________________________________________________________________
Date: Oct 28, 2014
Date: Oct 28, 2014
Subject: Voltage Regulator Question
Date: Oct 28, 2014
I have a Rotax 503 DCDI on my Firestar with a three phase regulator that's got me wondering. After I start the engine (electric) & turn on the EIS, I get a warning light and the EIS flashes 16.9vdc, slides up to 18.2vdc. This lasts about one minute and then the voltage slips back to about 14.4-14.5 & stays there. This has happened the last two times that I've flown the plane. Has anyone else experienced anything similar to this? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432437#432437 ________________________________________________________________________________
Subject: Re: Voltage Regulator Question
Date: Oct 28, 2014
I've never had the problem... first thing I would look at is whether the sense line to the voltage regulator from the battery/ 12 v buss,,, has a good connection. sometimes a bit of corrosion will cause problems.... pull and reset the connector, and check the wire connection to the connector. educated guess. boyd I have a Rotax 503 DCDI on my Firestar with a three phase regulator that's got me wondering. After I start the engine (electric) & turn on the EIS, I get a warning light and the EIS flashes 16.9vdc, slides up to 18.2vdc. This lasts about one minute and then the voltage slips back to about 14.4-14.5 & stays there. This has happened the last two times that I've flown the plane. Has anyone else experienced anything similar to this? --- This email is free from viruses and malware because avast! Antivirus protection is active. http://www.avast.com ________________________________________________________________________________
Subject: Serenity flies!
Date: Oct 29, 2014
Well guys, we finally did it. Last Saturday I took Serenity to the airport and got to taxi her around a little. Found a couple of minor things to adjust, then test again. Taxied around the ramp slowly, then went to the west end of the grass strip. At this point, I have to say pavement SUCKS! The weather was warm and the breeze light and variable. Made several trips up and down the runway at varying speeds, getting braver with each pass. Got the tail up and was able to hold it there while keeping straight. No irregularities at all. Engine running well with temps in the right range. A quick check of the radio, no other planes in the area, time to quit messing around. Partial power up, tail up, glance at the windsock, limp and straight down the runway. More power, getting light and bouncy. Oops, not going straight anymore, glance at windsock, right crosswind, fed in some right aileron and left rudder. She feels ready to fly, oh, oh, runway light in the cross-hairs! More power and pull back, airborne well before edge of runway. Holy CRAP! I'm airborne! Left wing dropped, over corrected. Nose came up, over corrected. Nose went down, pulled off some power, got it level with elevator. Crap, right wing went down, over corrected, but not as much. Warning light on EIS, EGT or something out of whack. Wings have a mind of their own, tail does too... What the HE!! have I done? I won't die up here, it will be when I hit the ground out of control. Panic setting in! Every time I touch something, EVERYTHING changes. AAAGGGG! Wait, calm down and just fly. Whew, that is better, where am I? Why is that warning light still on? Let go of throttle to hit button on EIS. Throttle shuts down and nose comes up. HUH? Push nose down, grab throttle and start the PIO all over again. Wait, calm down and fly. OK, not so bad, oops bumps in the air. Gee I must be above pattern altitude, can't see the altimeter because the EIS on the warning page. Looks like high EGT, but not too bad as I have the limits set kind of low. Turn crosswind before I get out of gliding range. Left wing drops, fixed, not going the right way. Was that the plane or an air bubble? Mushed it around finally pointing the right way. Looked for traffic, none seen nor heard. OK more bumps and more PIO. Throttle up, down and everywhere in between. YIKES, what have I done? Wait, calm down and fly. Whew, better, time to turn downwind. Glance at airspeed, somewhere north of 60, OK we probably won't stall and spin in a gentle turn. This one went better. On downwind leg, getting a grip and just flying. Turned base leg, more bumps, more PIO. Recovery was smoother and faster. Got it around to final leg. Decided to just stay at that altitude, whatever it was and just fly around the patch one more time keeping the runway slightly off to my left so I can see if I am going straight. Some guy on the ground calls me on the radio and says "is it rough up there or are you having problems?" WHAT? I am 90 seconds into my first flight and YOU want to talk about it, NOW? Are you planning on coming up to help? Found the transmit button and managed to squeak out "I think it's me". Managed to drop the button, oh-oh, this thing is flapping every which way but loose again! OK, calm down and fly, OK better. Managed to get all the way around to base leg again and only had a few "burbles and PIO's". OK, plan on making a standard approach and fly the length of the runway, then go around and do it again. Radio calls, someone 5 miles out, headed my way. That is a Champ, he will be here before I can get out of the way. On final now, wishing I could find that transmit button to let him know my intentions. Back off the throttle a little and push the nose down. Not so bad, holding 50 MPH. Keeping lined up, still 50. OK. Hey, I am pointed at the numbers, well, if there were numbers, that is where they would be. Still going 50, all is well. Champ is getting close, better just set it down and get out of the way. Wait, what? Landing? Man, that runway got here fast, backed of the throttle and started to flair. How high am I? Where did the center of the runway go? Still pointed straight, slowing down. How low do I put the nose? I don't want to nose over. I don't want to do a 3 point, do I flair anymore? Didn't matter, Serenity decided for me. We did a 3 point landing on 2 wheels. Boing! One good hop of maybe 6", then all 3 wheels hit and stuck. Jerked the last of the throttle off and was stopped in the middle of the runway in seconds. WOW! I am alive! Wow, I am still in the runway with traffic in the pattern, somewhere. Powered up and taxied off the runway, just in time to hear the Champ on downwind for the runway I was on, no problems there. Just reaching the taxiway when something big and heavy with low wings comes screaming in on the main runway and touches down. Right about where I would have been if I had done a go around. If he used the radio, I certainly never heard it. It might have been a Cherokee or something like it, I only saw a flash. That certainly was enough for me for the day. Looking at the windsock it was halfway out and crosswise to all runways, good time to hang it up. Found my transmit button and and announce "Down and clear". Taxiing back to the hangar, I heard the Champ on final and clear of the runway. Never did see that other plane again. Man, will I EVER have nerve enough to do THAT again? Really, really unsure at this point. My wife who had been watching from the edge of the runway finally gets back to the hangar and congratulates me. She didn't seem excited at all? She said it looked great, but then again, she usually can't tell the difference between a Cherokee and a Champ when they are in the air..... Got Serenity folded up and put away. Gee, will I ever get an appetite again? Can I still drive? Should I just walk home? It is only 20 miles and walking is probably safer. When I got home and looked at the videos my wife took, two things were obvious. One, my wife can't run a camera, LOTS of blue sky and engine sounds. Two, (she did manage to film the landing) my landing was not nearly as bad as I thought while I was doing it, and in my mind afterward. Took two days of "digesting and analyzing" to begin to come to grips with what happened. Lessons learned, or at least re-learned: Flights rarely go according to plan, have options. Basic instruction (if done right) is always with you, ie: calm down and fly, and cut your corrections in half. Thank you Mr. Thomas, all the way back to 1973. If you didn't bend it, you did good. I am now ready to do it again. Well, not again, better next time. I tell this story partially for my own therapy, and for others to hopefully learn from. If nothing else, maybe it will entertain some of you. One thing I have not been able to figure out, is why it veered right on take off. Taxi testing showed no propensity to go anywhere but straight, so I don't think is a landing gear problem. My prop turns clockwise (as viewed from behind), so P-factor should turn it to the left. Dead bugs and oil droplets on the tail would indicate the air is hitting the left side of the vertical stabilizer more than the right side. That should push me left, not right. Maybe my old Chief training took over and I was applying right rudder without knowing it. Only a re-try will tell for sure. Hopefully I will get some dead air time yet this fall. Thanks for listening, Stuart -------- "I don't care, I'm still free. You can't take the sky from me" - Josh Wedon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432479#432479 ________________________________________________________________________________
Date: Oct 29, 2014
Subject: Re: Serenity flies!
Well you survived. You might want to reconsider the name- Serenity??????? Didn't sound too serene. It sounded more like my first flight. I took a nap after mine. Larry On Wed, Oct 29, 2014 at 10:41 AM, Airknocker wrote: > > Well guys, we finally did it. Last Saturday I took Serenity to the > airport and got to taxi her around a little. Found a couple of minor > things to adjust, then test again. > > Taxied around the ramp slowly, then went to the west end of the grass > strip. At this point, I have to say pavement SUCKS! > > The weather was warm and the breeze light and variable. Made several > trips up and down the runway at varying speeds, getting braver with each > pass. Got the tail up and was able to hold it there while keeping > straight. No irregularities at all. Engine running well with temps in the > right range. > > A quick check of the radio, no other planes in the area, time to quit > messing around. > > Partial power up, tail up, glance at the windsock, limp and straight down > the runway. More power, getting light and bouncy. Oops, not going straight > anymore, glance at windsock, right crosswind, fed in some right aileron and > left rudder. She feels ready to fly, oh, oh, runway light in the > cross-hairs! More power and pull back, airborne well before edge of runway. > > Holy CRAP! I'm airborne! > > Left wing dropped, over corrected. > Nose came up, over corrected. > Nose went down, pulled off some power, got it level with elevator. > Crap, right wing went down, over corrected, but not as much. > Warning light on EIS, EGT or something out of whack. > Wings have a mind of their own, tail does too... > > What the HE!! have I done? I won't die up here, it will be when I hit the > ground out of control. Panic setting in! Every time I touch something, > EVERYTHING changes. AAAGGGG! > > Wait, calm down and just fly. Whew, that is better, where am I? Why is > that warning light still on? > > Let go of throttle to hit button on EIS. Throttle shuts down and nose > comes up. HUH? Push nose down, grab throttle and start the PIO all over > again. Wait, calm down and fly. > > OK, not so bad, oops bumps in the air. Gee I must be above pattern > altitude, can't see the altimeter because the EIS on the warning page. > Looks like high EGT, but not too bad as I have the limits set kind of low. > > Turn crosswind before I get out of gliding range. Left wing drops, fixed, > not going the right way. Was that the plane or an air bubble? Mushed it > around finally pointing the right way. Looked for traffic, none seen nor > heard. OK more bumps and more PIO. Throttle up, down and everywhere in > between. > > YIKES, what have I done? Wait, calm down and fly. Whew, better, time to > turn downwind. Glance at airspeed, somewhere north of 60, OK we probably > won't stall and spin in a gentle turn. This one went better. On downwind > leg, getting a grip and just flying. > > Turned base leg, more bumps, more PIO. Recovery was smoother and faster. > Got it around to final leg. Decided to just stay at that altitude, whatever > it was and just fly around the patch one more time keeping the runway > slightly off to my left so I can see if I am going straight. > > Some guy on the ground calls me on the radio and says "is it rough up > there or are you having problems?" WHAT? I am 90 seconds into my first > flight and YOU want to talk about it, NOW? Are you planning on coming up > to help? Found the transmit button and managed to squeak out "I think it's > me". Managed to drop the button, oh-oh, this thing is flapping every which > way but loose again! > > OK, calm down and fly, OK better. Managed to get all the way around to > base leg again and only had a few "burbles and PIO's". OK, plan on making > a standard approach and fly the length of the runway, then go around and do > it again. Radio calls, someone 5 miles out, headed my way. That is a > Champ, he will be here before I can get out of the way. > > On final now, wishing I could find that transmit button to let him know my > intentions. Back off the throttle a little and push the nose down. Not so > bad, holding 50 MPH. Keeping lined up, still 50. OK. Hey, I am pointed at > the numbers, well, if there were numbers, that is where they would be. > Still going 50, all is well. Champ is getting close, better just set it > down and get out of the way. > > Wait, what? Landing? Man, that runway got here fast, backed of the > throttle and started to flair. How high am I? Where did the center of the > runway go? > > Still pointed straight, slowing down. How low do I put the nose? I don't > want to nose over. I don't want to do a 3 point, do I flair anymore? > > Didn't matter, Serenity decided for me. We did a 3 point landing on 2 > wheels. Boing! One good hop of maybe 6", then all 3 wheels hit and > stuck. Jerked the last of the throttle off and was stopped in the middle > of the runway in seconds. > > WOW! I am alive! Wow, I am still in the runway with traffic in the > pattern, somewhere. > > Powered up and taxied off the runway, just in time to hear the Champ on > downwind for the runway I was on, no problems there. Just reaching the > taxiway when something big and heavy with low wings comes screaming in on > the main runway and touches down. Right about where I would have been if I > had done a go around. If he used the radio, I certainly never heard it. It > might have been a Cherokee or something like it, I only saw a flash. > > That certainly was enough for me for the day. Looking at the windsock it > was halfway out and crosswise to all runways, good time to hang it up. > Found my transmit button and and announce "Down and clear". Taxiing back > to the hangar, I heard the Champ on final and clear of the runway. Never > did see that other plane again. > > Man, will I EVER have nerve enough to do THAT again? Really, really > unsure at this point. > > My wife who had been watching from the edge of the runway finally gets > back to the hangar and congratulates me. She didn't seem excited at all? > She said it looked great, but then again, she usually can't tell the > difference between a Cherokee and a Champ when they are in the air..... > > Got Serenity folded up and put away. Gee, will I ever get an appetite > again? Can I still drive? Should I just walk home? It is only 20 miles > and walking is probably safer. > > When I got home and looked at the videos my wife took, two things were > obvious. One, my wife can't run a camera, LOTS of blue sky and engine > sounds. Two, (she did manage to film the landing) my landing was not nearly > as bad as I thought while I was doing it, and in my mind afterward. > > Took two days of "digesting and analyzing" to begin to come to grips with > what happened. > > Lessons learned, or at least re-learned: > > Flights rarely go according to plan, have options. > > Basic instruction (if done right) is always with you, ie: calm down and > fly, and cut your corrections in half. Thank you Mr. Thomas, all the way > back to 1973. > > If you didn't bend it, you did good. > > I am now ready to do it again. Well, not again, better next time. > > I tell this story partially for my own therapy, and for others to > hopefully learn from. If nothing else, maybe it will entertain some of you. > > One thing I have not been able to figure out, is why it veered right on > take off. > > Taxi testing showed no propensity to go anywhere but straight, so I don't > think is a landing gear problem. My prop turns clockwise (as viewed from > behind), so P-factor should turn it to the left. Dead bugs and oil > droplets on the tail would indicate the air is hitting the left side of the > vertical stabilizer more than the right side. That should push me left, not > right. Maybe my old Chief training took over and I was applying right > rudder without knowing it. > > Only a re-try will tell for sure. Hopefully I will get some dead air time > yet this fall. > > Thanks for listening, > > Stuart > > -------- > "I don't care, I'm still free. You can't take the sky from me" > - Josh Wedon > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=432479#432479 > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Oct 29, 2014
Perhaps you should have let Wash make the first flight. ----- Original Message ----- From: "Airknocker" <airknocker(at)harnerfarm.net> Sent: Wednesday, October 29, 2014 12:41 PM Subject: Kolb-List: Serenity flies! > > Well guys, we finally did it. Last Saturday I took Serenity to the > airport and got to taxi her around a little. Found a couple of minor > things to adjust, then test again. > > Taxied around the ramp slowly, then went to the west end of the grass > strip. At this point, I have to say pavement SUCKS! > > The weather was warm and the breeze light and variable. Made several > trips up and down the runway at varying speeds, getting braver with each > pass. Got the tail up and was able to hold it there while keeping > straight. No irregularities at all. Engine running well with temps in > the right range. > > A quick check of the radio, no other planes in the area, time to quit > messing around. > > Partial power up, tail up, glance at the windsock, limp and straight down > the runway. More power, getting light and bouncy. Oops, not going > straight anymore, glance at windsock, right crosswind, fed in some right > aileron and left rudder. She feels ready to fly, oh, oh, runway light in > the cross-hairs! More power and pull back, airborne well before edge of > runway. > > Holy CRAP! I'm airborne! > > Left wing dropped, over corrected. > Nose came up, over corrected. > Nose went down, pulled off some power, got it level with elevator. > Crap, right wing went down, over corrected, but not as much. > Warning light on EIS, EGT or something out of whack. > Wings have a mind of their own, tail does too... > > What the HE!! have I done? I won't die up here, it will be when I hit the > ground out of control. Panic setting in! Every time I touch something, > EVERYTHING changes. AAAGGGG! > > Wait, calm down and just fly. Whew, that is better, where am I? Why is > that warning light still on? > > Let go of throttle to hit button on EIS. Throttle shuts down and nose > comes up. HUH? Push nose down, grab throttle and start the PIO all over > again. Wait, calm down and fly. > > OK, not so bad, oops bumps in the air. Gee I must be above pattern > altitude, can't see the altimeter because the EIS on the warning page. > Looks like high EGT, but not too bad as I have the limits set kind of low. > > Turn crosswind before I get out of gliding range. Left wing drops, fixed, > not going the right way. Was that the plane or an air bubble? Mushed it > around finally pointing the right way. Looked for traffic, none seen nor > heard. OK more bumps and more PIO. Throttle up, down and everywhere in > between. > > YIKES, what have I done? Wait, calm down and fly. Whew, better, time to > turn downwind. Glance at airspeed, somewhere north of 60, OK we probably > won't stall and spin in a gentle turn. This one went better. On downwind > leg, getting a grip and just flying. > > Turned base leg, more bumps, more PIO. Recovery was smoother and faster. > Got it around to final leg. Decided to just stay at that altitude, > whatever it was and just fly around the patch one more time keeping the > runway slightly off to my left so I can see if I am going straight. > > Some guy on the ground calls me on the radio and says "is it rough up > there or are you having problems?" WHAT? I am 90 seconds into my first > flight and YOU want to talk about it, NOW? Are you planning on coming up > to help? Found the transmit button and managed to squeak out "I think > it's me". Managed to drop the button, oh-oh, this thing is flapping every > which way but loose again! > > OK, calm down and fly, OK better. Managed to get all the way around to > base leg again and only had a few "burbles and PIO's". OK, plan on making > a standard approach and fly the length of the runway, then go around and > do it again. Radio calls, someone 5 miles out, headed my way. That is a > Champ, he will be here before I can get out of the way. > > On final now, wishing I could find that transmit button to let him know my > intentions. Back off the throttle a little and push the nose down. Not so > bad, holding 50 MPH. Keeping lined up, still 50. OK. Hey, I am pointed > at the numbers, well, if there were numbers, that is where they would be. > Still going 50, all is well. Champ is getting close, better just set it > down and get out of the way. > > Wait, what? Landing? Man, that runway got here fast, backed of the > throttle and started to flair. How high am I? Where did the center of the > runway go? > > Still pointed straight, slowing down. How low do I put the nose? I don't > want to nose over. I don't want to do a 3 point, do I flair anymore? > > Didn't matter, Serenity decided for me. We did a 3 point landing on 2 > wheels. Boing! One good hop of maybe 6", then all 3 wheels hit and > stuck. Jerked the last of the throttle off and was stopped in the middle > of the runway in seconds. > > WOW! I am alive! Wow, I am still in the runway with traffic in the > pattern, somewhere. > > Powered up and taxied off the runway, just in time to hear the Champ on > downwind for the runway I was on, no problems there. Just reaching the > taxiway when something big and heavy with low wings comes screaming in on > the main runway and touches down. Right about where I would have been if > I had done a go around. If he used the radio, I certainly never heard it. > It might have been a Cherokee or something like it, I only saw a flash. > > That certainly was enough for me for the day. Looking at the windsock it > was halfway out and crosswise to all runways, good time to hang it up. > Found my transmit button and and announce "Down and clear". Taxiing back > to the hangar, I heard the Champ on final and clear of the runway. Never > did see that other plane again. > > Man, will I EVER have nerve enough to do THAT again? Really, really > unsure at this point. > > My wife who had been watching from the edge of the runway finally gets > back to the hangar and congratulates me. She didn't seem excited at all? > She said it looked great, but then again, she usually can't tell the > difference between a Cherokee and a Champ when they are in the air..... > > Got Serenity folded up and put away. Gee, will I ever get an appetite > again? Can I still drive? Should I just walk home? It is only 20 miles > and walking is probably safer. > > When I got home and looked at the videos my wife took, two things were > obvious. One, my wife can't run a camera, LOTS of blue sky and engine > sounds. Two, (she did manage to film the landing) my landing was not > nearly as bad as I thought while I was doing it, and in my mind afterward. > > Took two days of "digesting and analyzing" to begin to come to grips with > what happened. > > Lessons learned, or at least re-learned: > > Flights rarely go according to plan, have options. > > Basic instruction (if done right) is always with you, ie: calm down and > fly, and cut your corrections in half. Thank you Mr. Thomas, all the way > back to 1973. > > If you didn't bend it, you did good. > > I am now ready to do it again. Well, not again, better next time. > > I tell this story partially for my own therapy, and for others to > hopefully learn from. If nothing else, maybe it will entertain some of > you. > > One thing I have not been able to figure out, is why it veered right on > take off. > > Taxi testing showed no propensity to go anywhere but straight, so I don't > think is a landing gear problem. My prop turns clockwise (as viewed from > behind), so P-factor should turn it to the left. Dead bugs and oil > droplets on the tail would indicate the air is hitting the left side of > the vertical stabilizer more than the right side. That should push me > left, not right. Maybe my old Chief training took over and I was applying > right rudder without knowing it. > > Only a re-try will tell for sure. Hopefully I will get some dead air time > yet this fall. > > Thanks for listening, > > Stuart > > -------- > "I don't care, I'm still free. You can't take the sky from > me" - Josh Wedon > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=432479#432479 > > > ________________________________________________________________________________
Subject: Dual controls for my twin star
Date: Oct 29, 2014
I just bought an older 1991: twin star. It has the single center stick controls and I am wanting to put in a set of dual controls. Has anyone got experience doing this or do they make a kit to convert it. Any help or suggestions would be appreciated. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432496#432496 ________________________________________________________________________________
Date: Oct 29, 2014
I just bought an older 1991: twin star. It has the single center stick controls and I am wanting to put in a set of dual controls. Has anyone got experience doing this or do they make a kit to convert it. Any help or suggestions would be appreciated. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432497#432497 ________________________________________________________________________________
Date: Oct 29, 2014
Two stoke powered Kolbs turn right at full power , use the left rudder pedal. Glad all ended well. Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA > On Oct 29, 2014, at 12:41 PM, "Airknocker" wrote: > > > Well guys, we finally did it. Last Saturday I took Serenity to the airport and got to taxi her around a little. Found a couple of minor things to adjust, then test again. > > Taxied around the ramp slowly, then went to the west end of the grass strip. At this point, I have to say pavement SUCKS! > > The weather was warm and the breeze light and variable. Made several trips up and down the runway at varying speeds, getting braver with each pass. Got the tail up and was able to hold it there while keeping straight. No irregularities at all. Engine running well with temps in the right range. > > A quick check of the radio, no other planes in the area, time to quit messing around. > > Partial power up, tail up, glance at the windsock, limp and straight down the runway. More power, getting light and bouncy. Oops, not going straight anymore, glance at windsock, right crosswind, fed in some right aileron and left rudder. She feels ready to fly, oh, oh, runway light in the cross-hairs! More power and pull back, airborne well before edge of runway. > > Holy CRAP! I'm airborne! > > Left wing dropped, over corrected. > Nose came up, over corrected. > Nose went down, pulled off some power, got it level with elevator. > Crap, right wing went down, over corrected, but not as much. > Warning light on EIS, EGT or something out of whack. > Wings have a mind of their own, tail does too... > > What the HE!! have I done? I won't die up here, it will be when I hit the ground out of control. Panic setting in! Every time I touch something, EVERYTHING changes. AAAGGGG! > > Wait, calm down and just fly. Whew, that is better, where am I? Why is that warning light still on? > > Let go of throttle to hit button on EIS. Throttle shuts down and nose comes up. HUH? Push nose down, grab throttle and start the PIO all over again. Wait, calm down and fly. > > OK, not so bad, oops bumps in the air. Gee I must be above pattern altitude, can't see the altimeter because the EIS on the warning page. Looks like high EGT, but not too bad as I have the limits set kind of low. > > Turn crosswind before I get out of gliding range. Left wing drops, fixed, not going the right way. Was that the plane or an air bubble? Mushed it around finally pointing the right way. Looked for traffic, none seen nor heard. OK more bumps and more PIO. Throttle up, down and everywhere in between. > > YIKES, what have I done? Wait, calm down and fly. Whew, better, time to turn downwind. Glance at airspeed, somewhere north of 60, OK we probably won't stall and spin in a gentle turn. This one went better. On downwind leg, getting a grip and just flying. > > Turned base leg, more bumps, more PIO. Recovery was smoother and faster. Got it around to final leg. Decided to just stay at that altitude, whatever it was and just fly around the patch one more time keeping the runway slightly off to my left so I can see if I am going straight. > > Some guy on the ground calls me on the radio and says "is it rough up there or are you having problems?" WHAT? I am 90 seconds into my first flight and YOU want to talk about it, NOW? Are you planning on coming up to help? Found the transmit button and managed to squeak out "I think it's me". Managed to drop the button, oh-oh, this thing is flapping every which way but loose again! > > OK, calm down and fly, OK better. Managed to get all the way around to base leg again and only had a few "burbles and PIO's". OK, plan on making a standard approach and fly the length of the runway, then go around and do it again. Radio calls, someone 5 miles out, headed my way. That is a Champ, he will be here before I can get out of the way. > > On final now, wishing I could find that transmit button to let him know my intentions. Back off the throttle a little and push the nose down. Not so bad, holding 50 MPH. Keeping lined up, still 50. OK. Hey, I am pointed at the numbers, well, if there were numbers, that is where they would be. Still going 50, all is well. Champ is getting close, better just set it down and get out of the way. > > Wait, what? Landing? Man, that runway got here fast, backed of the throttle and started to flair. How high am I? Where did the center of the runway go? > > Still pointed straight, slowing down. How low do I put the nose? I don't want to nose over. I don't want to do a 3 point, do I flair anymore? > > Didn't matter, Serenity decided for me. We did a 3 point landing on 2 wheels. Boing! One good hop of maybe 6", then all 3 wheels hit and stuck. Jerked the last of the throttle off and was stopped in the middle of the runway in seconds. > > WOW! I am alive! Wow, I am still in the runway with traffic in the pattern, somewhere. > > Powered up and taxied off the runway, just in time to hear the Champ on downwind for the runway I was on, no problems there. Just reaching the taxiway when something big and heavy with low wings comes screaming in on the main runway and touches down. Right about where I would have been if I had done a go around. If he used the radio, I certainly never heard it. It might have been a Cherokee or something like it, I only saw a flash. > > That certainly was enough for me for the day. Looking at the windsock it was halfway out and crosswise to all runways, good time to hang it up. Found my transmit button and and announce "Down and clear". Taxiing back to the hangar, I heard the Champ on final and clear of the runway. Never did see that other plane again. > > Man, will I EVER have nerve enough to do THAT again? Really, really unsure at this point. > > My wife who had been watching from the edge of the runway finally gets back to the hangar and congratulates me. She didn't seem excited at all? She said it looked great, but then again, she usually can't tell the difference between a Cherokee and a Champ when they are in the air..... > > Got Serenity folded up and put away. Gee, will I ever get an appetite again? Can I still drive? Should I just walk home? It is only 20 miles and walking is probably safer. > > When I got home and looked at the videos my wife took, two things were obvious. One, my wife can't run a camera, LOTS of blue sky and engine sounds. Two, (she did manage to film the landing) my landing was not nearly as bad as I thought while I was doing it, and in my mind afterward. > > Took two days of "digesting and analyzing" to begin to come to grips with what happened. > > Lessons learned, or at least re-learned: > > Flights rarely go according to plan, have options. > > Basic instruction (if done right) is always with you, ie: calm down and fly, and cut your corrections in half. Thank you Mr. Thomas, all the way back to 1973. > > If you didn't bend it, you did good. > > I am now ready to do it again. Well, not again, better next time. > > I tell this story partially for my own therapy, and for others to hopefully learn from. If nothing else, maybe it will entertain some of you. > > One thing I have not been able to figure out, is why it veered right on take off. > > Taxi testing showed no propensity to go anywhere but straight, so I don't think is a landing gear problem. My prop turns clockwise (as viewed from behind), so P-factor should turn it to the left. Dead bugs and oil droplets on the tail would indicate the air is hitting the left side of the vertical stabilizer more than the right side. That should push me left, not right. Maybe my old Chief training took over and I was applying right rudder without knowing it. > > Only a re-try will tell for sure. Hopefully I will get some dead air time yet this fall. > > Thanks for listening, > > Stuart > > -------- > "I don't care, I'm still free. You can't take the sky from me" - Josh Wedon > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=432479#432479 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Dual controls for my twin star
Date: Oct 29, 2014
Where are you located? I have dual sticks in an Xtra & would consider changing to a single center stick On Oct 29, 2014, at 5:03 PM, Guideman wrote: > > I just bought an older 1991: twin star. It has the single center stick controls and I am wanting to put in a set of dual controls. Has anyone got experience doing this or do they make a kit to convert it. Any help or suggestions would be appreciated. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=432496#432496 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 29, 2014
Dennis, cant help but be curious. Why the right turn? On Oct 29, 2014, at 6:12 PM, Dennis Rowe wrote: > > Two stoke powered Kolbs turn right at full power , use the left rudder pedal. > Glad all ended well. > > Dennis "Skid" Rowe > Mk3, Rotax 670, > Leechburg, PA > > > >> On Oct 29, 2014, at 12:41 PM, "Airknocker" wrote: >> >> >> Well guys, we finally did it. Last Saturday I took Serenity to the airport and got to taxi her around a little. Found a couple of minor things to adjust, then test again. >> >> Taxied around the ramp slowly, then went to the west end of the grass strip. At this point, I have to say pavement SUCKS! >> >> The weather was warm and the breeze light and variable. Made several trips up and down the runway at varying speeds, getting braver with each pass. Got the tail up and was able to hold it there while keeping straight. No irregularities at all. Engine running well with temps in the right range. >> >> A quick check of the radio, no other planes in the area, time to quit messing around. >> >> Partial power up, tail up, glance at the windsock, limp and straight down the runway. More power, getting light and bouncy. Oops, not going straight anymore, glance at windsock, right crosswind, fed in some right aileron and left rudder. She feels ready to fly, oh, oh, runway light in the cross-hairs! More power and pull back, airborne well before edge of runway. >> >> Holy CRAP! I'm airborne! >> >> Left wing dropped, over corrected. >> Nose came up, over corrected. >> Nose went down, pulled off some power, got it level with elevator. >> Crap, right wing went down, over corrected, but not as much. >> Warning light on EIS, EGT or something out of whack. >> Wings have a mind of their own, tail does too... >> >> What the HE!! have I done? I won't die up here, it will be when I hit the ground out of control. Panic setting in! Every time I touch something, EVERYTHING changes. AAAGGGG! >> >> Wait, calm down and just fly. Whew, that is better, where am I? Why is that warning light still on? >> >> Let go of throttle to hit button on EIS. Throttle shuts down and nose comes up. HUH? Push nose down, grab throttle and start the PIO all over again. Wait, calm down and fly. >> >> OK, not so bad, oops bumps in the air. Gee I must be above pattern altitude, can't see the altimeter because the EIS on the warning page. Looks like high EGT, but not too bad as I have the limits set kind of low. >> >> Turn crosswind before I get out of gliding range. Left wing drops, fixed, not going the right way. Was that the plane or an air bubble? Mushed it around finally pointing the right way. Looked for traffic, none seen nor heard. OK more bumps and more PIO. Throttle up, down and everywhere in between. >> >> YIKES, what have I done? Wait, calm down and fly. Whew, better, time to turn downwind. Glance at airspeed, somewhere north of 60, OK we probably won't stall and spin in a gentle turn. This one went better. On downwind leg, getting a grip and just flying. >> >> Turned base leg, more bumps, more PIO. Recovery was smoother and faster. Got it around to final leg. Decided to just stay at that altitude, whatever it was and just fly around the patch one more time keeping the runway slightly off to my left so I can see if I am going straight. >> >> Some guy on the ground calls me on the radio and says "is it rough up there or are you having problems?" WHAT? I am 90 seconds into my first flight and YOU want to talk about it, NOW? Are you planning on coming up to help? Found the transmit button and managed to squeak out "I think it's me". Managed to drop the button, oh-oh, this thing is flapping every which way but loose again! >> >> OK, calm down and fly, OK better. Managed to get all the way around to base leg again and only had a few "burbles and PIO's". OK, plan on making a standard approach and fly the length of the runway, then go around and do it again. Radio calls, someone 5 miles out, headed my way. That is a Champ, he will be here before I can get out of the way. >> >> On final now, wishing I could find that transmit button to let him know my intentions. Back off the throttle a little and push the nose down. Not so bad, holding 50 MPH. Keeping lined up, still 50. OK. Hey, I am pointed at the numbers, well, if there were numbers, that is where they would be. Still going 50, all is well. Champ is getting close, better just set it down and get out of the way. >> >> Wait, what? Landing? Man, that runway got here fast, backed of the throttle and started to flair. How high am I? Where did the center of the runway go? >> >> Still pointed straight, slowing down. How low do I put the nose? I don't want to nose over. I don't want to do a 3 point, do I flair anymore? >> >> Didn't matter, Serenity decided for me. We did a 3 point landing on 2 wheels. Boing! One good hop of maybe 6", then all 3 wheels hit and stuck. Jerked the last of the throttle off and was stopped in the middle of the runway in seconds. >> >> WOW! I am alive! Wow, I am still in the runway with traffic in the pattern, somewhere. >> >> Powered up and taxied off the runway, just in time to hear the Champ on downwind for the runway I was on, no problems there. Just reaching the taxiway when something big and heavy with low wings comes screaming in on the main runway and touches down. Right about where I would have been if I had done a go around. If he used the radio, I certainly never heard it. It might have been a Cherokee or something like it, I only saw a flash. >> >> That certainly was enough for me for the day. Looking at the windsock it was halfway out and crosswise to all runways, good time to hang it up. Found my transmit button and and announce "Down and clear". Taxiing back to the hangar, I heard the Champ on final and clear of the runway. Never did see that other plane again. >> >> Man, will I EVER have nerve enough to do THAT again? Really, really unsure at this point. >> >> My wife who had been watching from the edge of the runway finally gets back to the hangar and congratulates me. She didn't seem excited at all? She said it looked great, but then again, she usually can't tell the difference between a Cherokee and a Champ when they are in the air..... >> >> Got Serenity folded up and put away. Gee, will I ever get an appetite again? Can I still drive? Should I just walk home? It is only 20 miles and walking is probably safer. >> >> When I got home and looked at the videos my wife took, two things were obvious. One, my wife can't run a camera, LOTS of blue sky and engine sounds. Two, (she did manage to film the landing) my landing was not nearly as bad as I thought while I was doing it, and in my mind afterward. >> >> Took two days of "digesting and analyzing" to begin to come to grips with what happened. >> >> Lessons learned, or at least re-learned: >> >> Flights rarely go according to plan, have options. >> >> Basic instruction (if done right) is always with you, ie: calm down and fly, and cut your corrections in half. Thank you Mr. Thomas, all the way back to 1973. >> >> If you didn't bend it, you did good. >> >> I am now ready to do it again. Well, not again, better next time. >> >> I tell this story partially for my own therapy, and for others to hopefully learn from. If nothing else, maybe it will entertain some of you. >> >> One thing I have not been able to figure out, is why it veered right on take off. >> >> Taxi testing showed no propensity to go anywhere but straight, so I don't think is a landing gear problem. My prop turns clockwise (as viewed from behind), so P-factor should turn it to the left. Dead bugs and oil droplets on the tail would indicate the air is hitting the left side of the vertical stabilizer more than the right side. That should push me left, not right. Maybe my old Chief training took over and I was applying right rudder without knowing it. >> >> Only a re-try will tell for sure. Hopefully I will get some dead air time yet this fall. >> >> Thanks for listening, >> >> Stuart >> >> -------- >> "I don't care, I'm still free. You can't take the sky from me" - Josh Wedon >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=432479#432479 >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Oct 29, 2014
Yeah, that will take some getting used to. It must be air forces on tail, not P-factor. I surprised me mostly because I did not notice it on my tail up taxi tests, and it went against the logic of the P-factor effect of a clockwise prop. My first instructor (the previously mentioned Mr. Thomas) used to make me take off while he ran the throttle. Full throttle until tail up, then he would back it off to just enough to keep the tail up. I would have to steer the whole length of the 2600' grass strip. Then at the last moment he would firewall it and we would take off. Go around and do it again. After I FINALLY got the hang of that, the rest of the buildup to solo was fairly easy. When turning a pre-war Chief, always lead with your feet. Time to switch feet. :) Thanks, Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Dennis Rowe Sent: Wednesday, October 29, 2014 5:13 PM Subject: Re: Kolb-List: Serenity flies! Two stoke powered Kolbs turn right at full power , use the left rudder pedal. Glad all ended well. Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA > On Oct 29, 2014, at 12:41 PM, "Airknocker" wrote: > > > Well guys, we finally did it. Last Saturday I took Serenity to the airport and got to taxi her around a little. Found a couple of minor things to adjust, then test again. > > Taxied around the ramp slowly, then went to the west end of the grass strip. At this point, I have to say pavement SUCKS! > > The weather was warm and the breeze light and variable. Made several trips up and down the runway at varying speeds, getting braver with each pass. Got the tail up and was able to hold it there while keeping straight. No irregularities at all. Engine running well with temps in the right range. > > A quick check of the radio, no other planes in the area, time to quit messing around. > > Partial power up, tail up, glance at the windsock, limp and straight down the runway. More power, getting light and bouncy. Oops, not going straight anymore, glance at windsock, right crosswind, fed in some right aileron and left rudder. She feels ready to fly, oh, oh, runway light in the cross-hairs! More power and pull back, airborne well before edge of runway. > > Holy CRAP! I'm airborne! > > Left wing dropped, over corrected. > Nose came up, over corrected. > Nose went down, pulled off some power, got it level with elevator. > Crap, right wing went down, over corrected, but not as much. > Warning light on EIS, EGT or something out of whack. > Wings have a mind of their own, tail does too... > > What the HE!! have I done? I won't die up here, it will be when I hit the ground out of control. Panic setting in! Every time I touch something, EVERYTHING changes. AAAGGGG! > > Wait, calm down and just fly. Whew, that is better, where am I? Why is that warning light still on? > > Let go of throttle to hit button on EIS. Throttle shuts down and nose comes up. HUH? Push nose down, grab throttle and start the PIO all over again. Wait, calm down and fly. > > OK, not so bad, oops bumps in the air. Gee I must be above pattern altitude, can't see the altimeter because the EIS on the warning page. Looks like high EGT, but not too bad as I have the limits set kind of low. > > Turn crosswind before I get out of gliding range. Left wing drops, fixed, not going the right way. Was that the plane or an air bubble? Mushed it around finally pointing the right way. Looked for traffic, none seen nor heard. OK more bumps and more PIO. Throttle up, down and everywhere in between. > > YIKES, what have I done? Wait, calm down and fly. Whew, better, time to turn downwind. Glance at airspeed, somewhere north of 60, OK we probably won't stall and spin in a gentle turn. This one went better. On downwind leg, getting a grip and just flying. > > Turned base leg, more bumps, more PIO. Recovery was smoother and faster. Got it around to final leg. Decided to just stay at that altitude, whatever it was and just fly around the patch one more time keeping the runway slightly off to my left so I can see if I am going straight. > > Some guy on the ground calls me on the radio and says "is it rough up there or are you having problems?" WHAT? I am 90 seconds into my first flight and YOU want to talk about it, NOW? Are you planning on coming up to help? Found the transmit button and managed to squeak out "I think it's me". Managed to drop the button, oh-oh, this thing is flapping every which way but loose again! > > OK, calm down and fly, OK better. Managed to get all the way around to base leg again and only had a few "burbles and PIO's". OK, plan on making a standard approach and fly the length of the runway, then go around and do it again. Radio calls, someone 5 miles out, headed my way. That is a Champ, he will be here before I can get out of the way. > > On final now, wishing I could find that transmit button to let him know my intentions. Back off the throttle a little and push the nose down. Not so bad, holding 50 MPH. Keeping lined up, still 50. OK. Hey, I am pointed at the numbers, well, if there were numbers, that is where they would be. Still going 50, all is well. Champ is getting close, better just set it down and get out of the way. > > Wait, what? Landing? Man, that runway got here fast, backed of the throttle and started to flair. How high am I? Where did the center of the runway go? > > Still pointed straight, slowing down. How low do I put the nose? I don't want to nose over. I don't want to do a 3 point, do I flair anymore? > > Didn't matter, Serenity decided for me. We did a 3 point landing on 2 wheels. Boing! One good hop of maybe 6", then all 3 wheels hit and stuck. Jerked the last of the throttle off and was stopped in the middle of the runway in seconds. > > WOW! I am alive! Wow, I am still in the runway with traffic in the pattern, somewhere. > > Powered up and taxied off the runway, just in time to hear the Champ on downwind for the runway I was on, no problems there. Just reaching the taxiway when something big and heavy with low wings comes screaming in on the main runway and touches down. Right about where I would have been if I had done a go around. If he used the radio, I certainly never heard it. It might have been a Cherokee or something like it, I only saw a flash. > > That certainly was enough for me for the day. Looking at the windsock it was halfway out and crosswise to all runways, good time to hang it up. Found my transmit button and and announce "Down and clear". Taxiing back to the hangar, I heard the Champ on final and clear of the runway. Never did see that other plane again. > > Man, will I EVER have nerve enough to do THAT again? Really, really unsure at this point. > > My wife who had been watching from the edge of the runway finally gets back to the hangar and congratulates me. She didn't seem excited at all? She said it looked great, but then again, she usually can't tell the difference between a Cherokee and a Champ when they are in the air..... > > Got Serenity folded up and put away. Gee, will I ever get an appetite again? Can I still drive? Should I just walk home? It is only 20 miles and walking is probably safer. > > When I got home and looked at the videos my wife took, two things were obvious. One, my wife can't run a camera, LOTS of blue sky and engine sounds. Two, (she did manage to film the landing) my landing was not nearly as bad as I thought while I was doing it, and in my mind afterward. > > Took two days of "digesting and analyzing" to begin to come to grips with what happened. > > Lessons learned, or at least re-learned: > > Flights rarely go according to plan, have options. > > Basic instruction (if done right) is always with you, ie: calm down and fly, and cut your corrections in half. Thank you Mr. Thomas, all the way back to 1973. > > If you didn't bend it, you did good. > > I am now ready to do it again. Well, not again, better next time. > > I tell this story partially for my own therapy, and for others to hopefully learn from. If nothing else, maybe it will entertain some of you. > > One thing I have not been able to figure out, is why it veered right on take off. > > Taxi testing showed no propensity to go anywhere but straight, so I don't think is a landing gear problem. My prop turns clockwise (as viewed from behind), so P-factor should turn it to the left. Dead bugs and oil droplets on the tail would indicate the air is hitting the left side of the vertical stabilizer more than the right side. That should push me left, not right. Maybe my old Chief training took over and I was applying right rudder without knowing it. > > Only a re-try will tell for sure. Hopefully I will get some dead air time yet this fall. > > Thanks for listening, > > Stuart > > -------- > "I don't care, I'm still free. You can't take the sky from me" - Josh Wedon > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=432479#432479 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 29, 2014
Ha! I thought of that, but he was on the other side of the 'verse and I couldn't get a wave through to him. Probably helping Mal misbehave somewhere..... S -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of pcking Sent: Wednesday, October 29, 2014 3:06 PM Subject: Re: Kolb-List: Serenity flies! Perhaps you should have let Wash make the first flight. ----- Original Message ----- From: "Airknocker" <airknocker(at)harnerfarm.net> Sent: Wednesday, October 29, 2014 12:41 PM Subject: Kolb-List: Serenity flies! > > Well guys, we finally did it. Last Saturday I took Serenity to the > airport and got to taxi her around a little. Found a couple of minor > things to adjust, then test again. > > Taxied around the ramp slowly, then went to the west end of the grass > strip. At this point, I have to say pavement SUCKS! > > The weather was warm and the breeze light and variable. Made several > trips up and down the runway at varying speeds, getting braver with each > pass. Got the tail up and was able to hold it there while keeping > straight. No irregularities at all. Engine running well with temps in > the right range. > > A quick check of the radio, no other planes in the area, time to quit > messing around. > > Partial power up, tail up, glance at the windsock, limp and straight down > the runway. More power, getting light and bouncy. Oops, not going > straight anymore, glance at windsock, right crosswind, fed in some right > aileron and left rudder. She feels ready to fly, oh, oh, runway light in > the cross-hairs! More power and pull back, airborne well before edge of > runway. > > Holy CRAP! I'm airborne! > > Left wing dropped, over corrected. > Nose came up, over corrected. > Nose went down, pulled off some power, got it level with elevator. > Crap, right wing went down, over corrected, but not as much. > Warning light on EIS, EGT or something out of whack. > Wings have a mind of their own, tail does too... > > What the HE!! have I done? I won't die up here, it will be when I hit the > ground out of control. Panic setting in! Every time I touch something, > EVERYTHING changes. AAAGGGG! > > Wait, calm down and just fly. Whew, that is better, where am I? Why is > that warning light still on? > > Let go of throttle to hit button on EIS. Throttle shuts down and nose > comes up. HUH? Push nose down, grab throttle and start the PIO all over > again. Wait, calm down and fly. > > OK, not so bad, oops bumps in the air. Gee I must be above pattern > altitude, can't see the altimeter because the EIS on the warning page. > Looks like high EGT, but not too bad as I have the limits set kind of low. > > Turn crosswind before I get out of gliding range. Left wing drops, fixed, > not going the right way. Was that the plane or an air bubble? Mushed it > around finally pointing the right way. Looked for traffic, none seen nor > heard. OK more bumps and more PIO. Throttle up, down and everywhere in > between. > > YIKES, what have I done? Wait, calm down and fly. Whew, better, time to > turn downwind. Glance at airspeed, somewhere north of 60, OK we probably > won't stall and spin in a gentle turn. This one went better. On downwind > leg, getting a grip and just flying. > > Turned base leg, more bumps, more PIO. Recovery was smoother and faster. > Got it around to final leg. Decided to just stay at that altitude, > whatever it was and just fly around the patch one more time keeping the > runway slightly off to my left so I can see if I am going straight. > > Some guy on the ground calls me on the radio and says "is it rough up > there or are you having problems?" WHAT? I am 90 seconds into my first > flight and YOU want to talk about it, NOW? Are you planning on coming up > to help? Found the transmit button and managed to squeak out "I think > it's me". Managed to drop the button, oh-oh, this thing is flapping every > which way but loose again! > > OK, calm down and fly, OK better. Managed to get all the way around to > base leg again and only had a few "burbles and PIO's". OK, plan on making > a standard approach and fly the length of the runway, then go around and > do it again. Radio calls, someone 5 miles out, headed my way. That is a > Champ, he will be here before I can get out of the way. > > On final now, wishing I could find that transmit button to let him know my > intentions. Back off the throttle a little and push the nose down. Not so > bad, holding 50 MPH. Keeping lined up, still 50. OK. Hey, I am pointed > at the numbers, well, if there were numbers, that is where they would be. > Still going 50, all is well. Champ is getting close, better just set it > down and get out of the way. > > Wait, what? Landing? Man, that runway got here fast, backed of the > throttle and started to flair. How high am I? Where did the center of the > runway go? > > Still pointed straight, slowing down. How low do I put the nose? I don't > want to nose over. I don't want to do a 3 point, do I flair anymore? > > Didn't matter, Serenity decided for me. We did a 3 point landing on 2 > wheels. Boing! One good hop of maybe 6", then all 3 wheels hit and > stuck. Jerked the last of the throttle off and was stopped in the middle > of the runway in seconds. > > WOW! I am alive! Wow, I am still in the runway with traffic in the > pattern, somewhere. > > Powered up and taxied off the runway, just in time to hear the Champ on > downwind for the runway I was on, no problems there. Just reaching the > taxiway when something big and heavy with low wings comes screaming in on > the main runway and touches down. Right about where I would have been if > I had done a go around. If he used the radio, I certainly never heard it. > It might have been a Cherokee or something like it, I only saw a flash. > > That certainly was enough for me for the day. Looking at the windsock it > was halfway out and crosswise to all runways, good time to hang it up. > Found my transmit button and and announce "Down and clear". Taxiing back > to the hangar, I heard the Champ on final and clear of the runway. Never > did see that other plane again. > > Man, will I EVER have nerve enough to do THAT again? Really, really > unsure at this point. > > My wife who had been watching from the edge of the runway finally gets > back to the hangar and congratulates me. She didn't seem excited at all? > She said it looked great, but then again, she usually can't tell the > difference between a Cherokee and a Champ when they are in the air..... > > Got Serenity folded up and put away. Gee, will I ever get an appetite > again? Can I still drive? Should I just walk home? It is only 20 miles > and walking is probably safer. > > When I got home and looked at the videos my wife took, two things were > obvious. One, my wife can't run a camera, LOTS of blue sky and engine > sounds. Two, (she did manage to film the landing) my landing was not > nearly as bad as I thought while I was doing it, and in my mind afterward. > > Took two days of "digesting and analyzing" to begin to come to grips with > what happened. > > Lessons learned, or at least re-learned: > > Flights rarely go according to plan, have options. > > Basic instruction (if done right) is always with you, ie: calm down and > fly, and cut your corrections in half. Thank you Mr. Thomas, all the way > back to 1973. > > If you didn't bend it, you did good. > > I am now ready to do it again. Well, not again, better next time. > > I tell this story partially for my own therapy, and for others to > hopefully learn from. If nothing else, maybe it will entertain some of > you. > > One thing I have not been able to figure out, is why it veered right on > take off. > > Taxi testing showed no propensity to go anywhere but straight, so I don't > think is a landing gear problem. My prop turns clockwise (as viewed from > behind), so P-factor should turn it to the left. Dead bugs and oil > droplets on the tail would indicate the air is hitting the left side of > the vertical stabilizer more than the right side. That should push me > left, not right. Maybe my old Chief training took over and I was applying > right rudder without knowing it. > > Only a re-try will tell for sure. Hopefully I will get some dead air time > yet this fall. > > Thanks for listening, > > Stuart > > -------- > "I don't care, I'm still free. You can't take the sky from > me" - Josh Wedon > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=432479#432479 > > > ________________________________________________________________________________
Date: Oct 29, 2014
Most folks agree it's the prop wash swirling against the tail, 912 powered Kolbs need right rudder just like GA birds. The right turn at full power nearly bit my buddy Dave Lewis on his first Slingshot flight too, I had added a rudder trim tab to my Mk-3 before his familiarization rides with me so it didn't prepare him for the opposite rudder required in a Kolb compared to his Cessna ppl training. As a group, we need to do a better job of reminding new Kolb pilots of this little surprise. Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA > On Oct 29, 2014, at 6:59 PM, kinne russ wrote: > > > Dennis, cant help but be curious. Why the right turn? > >> On Oct 29, 2014, at 6:12 PM, Dennis Rowe wrote: >> >> >> Two stoke powered Kolbs turn right at full power , use the left rudder pedal. >> Glad all ended well. >> >> Dennis "Skid" Rowe >> Mk3, Rotax 670, >> Leechburg, PA >> >> >> >>> On Oct 29, 2014, at 12:41 PM, "Airknocker" wrote: >>> >>> >>> Well guys, we finally did it. Last Saturday I took Serenity to the airport and got to taxi her around a little. Found a couple of minor things to adjust, then test again. >>> >>> Taxied around the ramp slowly, then went to the west end of the grass strip. At this point, I have to say pavement SUCKS! >>> >>> The weather was warm and the breeze light and variable. Made several trips up and down the runway at varying speeds, getting braver with each pass. Got the tail up and was able to hold it there while keeping straight. No irregularities at all. Engine running well with temps in the right range. >>> >>> A quick check of the radio, no other planes in the area, time to quit messing around. >>> >>> Partial power up, tail up, glance at the windsock, limp and straight down the runway. More power, getting light and bouncy. Oops, not going straight anymore, glance at windsock, right crosswind, fed in some right aileron and left rudder. She feels ready to fly, oh, oh, runway light in the cross-hairs! More power and pull back, airborne well before edge of runway. >>> >>> Holy CRAP! I'm airborne! >>> >>> Left wing dropped, over corrected. >>> Nose came up, over corrected. >>> Nose went down, pulled off some power, got it level with elevator. >>> Crap, right wing went down, over corrected, but not as much. >>> Warning light on EIS, EGT or something out of whack. >>> Wings have a mind of their own, tail does too... >>> > > Dennis, cant help but be curious. Why the right turn? > >> On Oct 29, 2014, at 6:12 PM, Dennis Rowe wrote: >> >> >> Two stoke powered Kolbs turn right at full power , use the left rudder pedal. >> Glad all ended well. >> >> Dennis "Skid" Rowe >> Mk3, Rotax 670, >> Leechburg, PA >> >> >> >>> On Oct 29, 2014, at 12:41 PM, "Airknocker" wrote: >>> >>> >>> Well guys, we finally did it. Last Saturday I took Serenity to the airport and got to taxi her around a little. Found a couple of minor things to adjust, then test again. >>> >>> Taxied around the ramp slowly, then went to the west end of the grass strip. At this point, I have to say pavement SUCKS! >>> >>> The weather was warm and the breeze light and variable. Made several trips up and down the runway at varying speeds, getting braver with each pass. Got the tail up and was able to hold it there while keeping straight. No irregularities at all. Engine running well with temps in the right range. >>> >>> A quick check of the radio, no other planes in the area, time to quit messing around. >>> >>> Partial power up, tail up, glance at the windsock, limp and straight down the runway. More power, getting light and bouncy. Oops, not going straight anymore, glance at windsock, right crosswind, fed in some right aileron and left rudder. She feels ready to fly, oh, oh, runway light in the cross-hairs! More power and pull back, airborne well before edge of runway. >>> >>> Holy CRAP! I'm airborne! >>> >>> Left wing dropped, over corrected. >>> Nose came up, over corrected. >>> Nose went down, pulled off some power, got it level with elevator. >>> Crap, right wing went down, over corrected, but not as much. >>> Warning light on EIS, EGT or something out of whack. >>> Wings have a mind of their own, tail does too... >>> >>> What the HE!! have I done? I won't die up here, it will be when I hit the ground out of control. Panic setting in! Every time I touch something, EVERYTHING changes. AAAGGGG! >>> >>> Wait, calm down and just fly. Whew, that is better, where am I? Why is that warning light still on? >>> >>> Let go of throttle to hit button on EIS. Throttle shuts down and nose comes up. HUH? Push nose down, grab throttle and start the PIO all over again. Wait, calm down and fly. >>> >>> OK, not so bad, oops bumps in the air. Gee I must be above pattern altitude, can't see the altimeter because the EIS on the warning page. Looks like high EGT, but not too bad as I have the limits set kind of low. >>> >>> Turn crosswind before I get out of gliding range. Left wing drops, fixed, not going the right way. Was that the plane or an air bubble? Mushed it around finally pointing the right way. Looked for traffic, none seen nor heard. OK more bumps and more PIO. Throttle up, down and everywhere in between. >>> >>> YIKES, what have I done? Wait, calm down and fly. Whew, better, time to turn downwind. Glance at airspeed, somewhere north of 60, OK we probably won't stall and spin in a gentle turn. This one went better. On downwind leg, getting a grip and just flying. >>> >>> Turned base leg, more bumps, more PIO. Recovery was smoother and faster. Got it around to final leg. Decided to just stay at that altitude, whatever it was and just fly around the patch one more time keeping the runway slightly off to my left so I can see if I am going straight. >>> >>> Some guy on the ground calls me on the radio and says "is it rough up there or are you having problems?" WHAT? I am 90 seconds into my first flight and YOU want to talk about it, NOW? Are you planning on coming up to help? Found the transmit button and managed to squeak out "I think it's me". Managed to drop the button, oh-oh, this thing is flapping every which way but loose again! >>> >>> OK, calm down and fly, OK better. Managed to get all the way around to base leg again and only had a few "burbles and PIO's". OK, plan on making a standard approach and fly the length of the runway, then go around and do it again. Radio calls, someone 5 miles out, headed my way. That is a Champ, he will be here before I can get out of the way. >>> >>> On final now, wishing I could find that transmit button to let him know my intentions. Back off the throttle a little and push the nose down. Not so bad, holding 50 MPH. Keeping lined up, still 50. OK. Hey, I am pointed at the numbers, well, if there were numbers, that is where they would be. Still going 50, all is well. Champ is getting close, better just set it down and get out of the way. >>> >>> Wait, what? Landing? Man, that runway got here fast, backed of the throttle and started to flair. How high am I? Where did the center of the runway go? >>> >>> Still pointed straight, slowing down. How low do I put the nose? I don't want to nose over. I don't want to do a 3 point, do I flair anymore? >>> >>> Didn't matter, Serenity decided for me. We did a 3 point landing on 2 wheels. Boing! One good hop of maybe 6", then all 3 wheels hit and stuck. Jerked the last of the throttle off and was stopped in the middle of the runway in seconds. >>> >>> WOW! I am alive! Wow, I am still in the runway with traffic in the pattern, somewhere. >>> >>> Powered up and taxied off the runway, just in time to hear the Champ on downwind for the runway I was on, no problems there. Just reaching the taxiway when something big and heavy with low wings comes screaming in on the main runway and touches down. Right about where I would have been if I had done a go around. If he used the radio, I certainly never heard it. It might have been a Cherokee or something like it, I only saw a flash. >>> >>> That certainly was enough for me for the day. Looking at the windsock it was halfway out and crosswise to all runways, good time to hang it up. Found my transmit button and and announce "Down and clear". Taxiing back to the hangar, I heard the Champ on final and clear of the runway. Never did see that other plane again. >>> >>> Man, will I EVER have nerve enough to do THAT again? Really, really unsure at this point. >>> >>> My wife who had been watching from the edge of the runway finally gets back to the hangar and congratulates me. She didn't seem excited at all? She said it looked great, but then again, she usually can't tell the difference between a Cherokee and a Champ when they are in the air..... >>> >>> Got Serenity folded up and put away. Gee, will I ever get an appetite again? Can I still drive? Should I just walk home? It is only 20 miles and walking is probably safer. >>> >>> When I got home and looked at the videos my wife took, two things were obvious. One, my wife can't run a camera, LOTS of blue sky and engine sounds. Two, (she did manage to film the landing) my landing was not nearly as bad as I thought while I was doing it, and in my mind afterward. >>> >>> Took two days of "digesting and analyzing" to begin to come to grips with what happened. >>> >>> Lessons learned, or at least re-learned: >>> >>> Flights rarely go according to plan, have options. >>> >>> Basic instruction (if done right) is always with you, ie: calm down and fly, and cut your corrections in half. Thank you Mr. Thomas, all the way back to 1973. >>> >>> If you didn't bend it, you did good. >>> >>> I am now ready to do it again. Well, not again, better next time. >>> >>> I tell this story partially for my own therapy, and for others to hopefully learn from. If nothing else, maybe it will entertain some of you. >>> >>> One thing I have not been able to figure out, is why it veered right on take off. >>> >>> Taxi testing showed no propensity to go anywhere but straight, so I don't think is a landing gear problem. My prop turns clockwise (as viewed from behind), so P-factor should turn it to the left. Dead bugs and oil droplets on the tail would indicate the air is hitting the left side of the vertical stabilizer more than the right side. That should push me left, not right. Maybe my old Chief training took over and I was applying right rudder without knowing it. >>> >>> Only a re-try will tell for sure. Hopefully I will get some dead air time yet this fall. >>> >>> Thanks for listening, >>> >>> Stuart >>> >>> -------- >>> "I don't care, I'm still free. You can't take the sky from me" - Josh Wedon >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=432479#432479 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Oct 29, 2014
I'm am in Richmond Missouri which is about 40 miles east of Kansas City. If your interested email me at birdfever(at)msn.com and we can see if we can work something out. Thanks, Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432516#432516 ________________________________________________________________________________
Subject: 503 muffler system
Date: Oct 29, 2014
i am also building from the ground up a star flight. I need the elbow of the muffler system for a 503 . Anyone wanting to sell or trade some parts please contact me. Thanks Keith. Birdfever(at)msn.com Richmond Missouri Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432531#432531 ________________________________________________________________________________
Date: Oct 29, 2014
i am also building from the ground up a star flight. I need the elbow of the muffler system for a 503 . Anyone wanting to sell or trade some parts please contact me. Thanks Keith. Birdfever(at)msn.com Richmond Missouri Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432532#432532 ________________________________________________________________________________
Subject: Re: Serenity flies!
Date: Oct 30, 2014
Congratulations on your first flight! Just a thought on first flights if I may.Make it a long flight,getting the feel at slower speeds Sent from my iPhone > On Oct 29, 2014, at 12:41 PM, "Airknocker" wrote: > > > Well guys, we finally did it. Last Saturday I took Serenity to the airport and got to taxi her around a little. Found a couple of minor things to adjust, then test again. > > Taxied around the ramp slowly, then went to the west end of the grass strip. At this point, I have to say pavement SUCKS! > > The weather was warm and the breeze light and variable. Made several trips up and down the runway at varying speeds, getting braver with each pass. Got the tail up and was able to hold it there while keeping straight. No irregularities at all. Engine running well with temps in the right range. > > A quick check of the radio, no other planes in the area, time to quit messing around. > > Partial power up, tail up, glance at the windsock, limp and straight down the runway. More power, getting light and bouncy. Oops, not going straight anymore, glance at windsock, right crosswind, fed in some right aileron and left rudder. She feels ready to fly, oh, oh, runway light in the cross-hairs! More power and pull back, airborne well before edge of runway. > > Holy CRAP! I'm airborne! > > Left wing dropped, over corrected. > Nose came up, over corrected. > Nose went down, pulled off some power, got it level with elevator. > Crap, right wing went down, over corrected, but not as much. > Warning light on EIS, EGT or something out of whack. > Wings have a mind of their own, tail does too... > > What the HE!! have I done? I won't die up here, it will be when I hit the ground out of control. Panic setting in! Every time I touch something, EVERYTHING changes. AAAGGGG! > > Wait, calm down and just fly. Whew, that is better, where am I? Why is that warning light still on? > > Let go of throttle to hit button on EIS. Throttle shuts down and nose comes up. HUH? Push nose down, grab throttle and start the PIO all over again. Wait, calm down and fly. > > OK, not so bad, oops bumps in the air. Gee I must be above pattern altitude, can't see the altimeter because the EIS on the warning page. Looks like high EGT, but not too bad as I have the limits set kind of low. > > Turn crosswind before I get out of gliding range. Left wing drops, fixed, not going the right way. Was that the plane or an air bubble? Mushed it around finally pointing the right way. Looked for traffic, none seen nor heard. OK more bumps and more PIO. Throttle up, down and everywhere in between. > > YIKES, what have I done? Wait, calm down and fly. Whew, better, time to turn downwind. Glance at airspeed, somewhere north of 60, OK we probably won't stall and spin in a gentle turn. This one went better. On downwind leg, getting a grip and just flying. > > Turned base leg, more bumps, more PIO. Recovery was smoother and faster. Got it around to final leg. Decided to just stay at that altitude, whatever it was and just fly around the patch one more time keeping the runway slightly off to my left so I can see if I am going straight. > > Some guy on the ground calls me on the radio and says "is it rough up there or are you having problems?" WHAT? I am 90 seconds into my first flight and YOU want to talk about it, NOW? Are you planning on coming up to help? Found the transmit button and managed to squeak out "I think it's me". Managed to drop the button, oh-oh, this thing is flapping every which way but loose again! > > OK, calm down and fly, OK better. Managed to get all the way around to base leg again and only had a few "burbles and PIO's". OK, plan on making a standard approach and fly the length of the runway, then go around and do it again. Radio calls, someone 5 miles out, headed my way. That is a Champ, he will be here before I can get out of the way. > > On final now, wishing I could find that transmit button to let him know my intentions. Back off the throttle a little and push the nose down. Not so bad, holding 50 MPH. Keeping lined up, still 50. OK. Hey, I am pointed at the numbers, well, if there were numbers, that is where they would be. Still going 50, all is well. Champ is getting close, better just set it down and get out of the way. > > Wait, what? Landing? Man, that runway got here fast, backed of the throttle and started to flair. How high am I? Where did the center of the runway go? > > Still pointed straight, slowing down. How low do I put the nose? I don't want to nose over. I don't want to do a 3 point, do I flair anymore? > > Didn't matter, Serenity decided for me. We did a 3 point landing on 2 wheels. Boing! One good hop of maybe 6", then all 3 wheels hit and stuck. Jerked the last of the throttle off and was stopped in the middle of the runway in seconds. > > WOW! I am alive! Wow, I am still in the runway with traffic in the pattern, somewhere. > > Powered up and taxied off the runway, just in time to hear the Champ on downwind for the runway I was on, no problems there. Just reaching the taxiway when something big and heavy with low wings comes screaming in on the main runway and touches down. Right about where I would have been if I had done a go around. If he used the radio, I certainly never heard it. It might have been a Cherokee or something like it, I only saw a flash. > > That certainly was enough for me for the day. Looking at the windsock it was halfway out and crosswise to all runways, good time to hang it up. Found my transmit button and and announce "Down and clear". Taxiing back to the hangar, I heard the Champ on final and clear of the runway. Never did see that other plane again. > > Man, will I EVER have nerve enough to do THAT again? Really, really unsure at this point. > > My wife who had been watching from the edge of the runway finally gets back to the hangar and congratulates me. She didn't seem excited at all? She said it looked great, but then again, she usually can't tell the difference between a Cherokee and a Champ when they are in the air..... > > Got Serenity folded up and put away. Gee, will I ever get an appetite again? Can I still drive? Should I just walk home? It is only 20 miles and walking is probably safer. > > When I got home and looked at the videos my wife took, two things were obvious. One, my wife can't run a camera, LOTS of blue sky and engine sounds. Two, (she did manage to film the landing) my landing was not nearly as bad as I thought while I was doing it, and in my mind afterward. > > Took two days of "digesting and analyzing" to begin to come to grips with what happened. > > Lessons learned, or at least re-learned: > > Flights rarely go according to plan, have options. > > Basic instruction (if done right) is always with you, ie: calm down and fly, and cut your corrections in half. Thank you Mr. Thomas, all the way back to 1973. > > If you didn't bend it, you did good. > > I am now ready to do it again. Well, not again, better next time. > > I tell this story partially for my own therapy, and for others to hopefully learn from. If nothing else, maybe it will entertain some of you. > > One thing I have not been able to figure out, is why it veered right on take off. > > Taxi testing showed no propensity to go anywhere but straight, so I don't think is a landing gear problem. My prop turns clockwise (as viewed from behind), so P-factor should turn it to the left. Dead bugs and oil droplets on the tail would indicate the air is hitting the left side of the vertical stabilizer more than the right side. That should push me left, not right. Maybe my old Chief training took over and I was applying right rudder without knowing it. > > Only a re-try will tell for sure. Hopefully I will get some dead air time yet this fall. > > Thanks for listening, > > Stuart > > -------- > "I don't care, I'm still free. You can't take the sky from me" - Josh Wedon > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=432479#432479 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 30, 2014
Stuart, I had to laugh at this, it sounded like several of my first flights in a newly rebuilt plane. It seems like no matter how thorough you are, there is always something that needs tweaking to get it trimmed correctly and then add the fact that it may be an aircraft that you have never flown. Every plane that I have had was a rebuild so I have done this several times. My last one was going from a CGS Hawk trike gear with a 532 Rotax water cooled to a Twinstar MKII with a 503 Rotax air cooled with oil injection. This was my first oil injection motor. Well I did not get all of the air out of the injection line. On my first flight with the Twinstar, I seized the engine and had to land in a real bad field and I had all of the thoughts that you expressed in your flight and I may have added a few more new swear words. On my landing, I bent one landing gear and the tail wheel. Before the flight, on the ground my engine temps were fine, the problem did not show up until I had lifted up. All is ok with it now, I removed the injection and have it trimmed out pretty good. Anyway thanks for a good story and I hope your next flights are less exciting. Lee Quicksilver mx, Vector, Goldwing, CGS Hawk, Twinstar MKII ________________________________________________________________________________
Date: Oct 30, 2014
lmorgan100(at)charter.net wrote: > Stuart, > > My last one was going from a CGS Hawk trike gear with a 532 Rotax water cooled to a Twinstar MKII with a 503 Rotax air cooled with oil injection. > This was my first oil injection motor. Well I did not get all of the air out of the injection line. On my first flight with the Twinstar, I seized the engine > This brings up something else that would be good to pass along, a 2-stroke oil injection system can be easily purged by rigging up a little spacer or clip that will hold the oil pump lever at max. (Adding a little oil to the fuel can't hurt during this time, just in case.) Tie the airplane down, bring it up to about 3,500 rpm and let it sit and run for a while. It will smoke like crazy, but after 10 minutes or so you can be confident that you have safely purged all the air out of the lines. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432547#432547 ________________________________________________________________________________
Subject: Serenity flies!
Date: Oct 30, 2014
Thanks, my original intent was to climb up and out of the way of the traffic pattern and stay in close to the airport. Use the radio at least once per circuit to announce where I was and my intentions. Having the PPT button come loose and "disappear " on me, incoming traffic and my difficulty in controlling myself, and the airplane caused me to go to plan B, which was get down and out of the way. On my next flight, after proving I can fly calmly, I will move out of the area and climb up for the real test flying that needs to be done. Having a new to me slightly used engine that I have only run for a little over 2 hours, makes it seem prudent to stick close to a very nice grass strip at the airport. Wish I could close the airport for an hour or so. :) After getting my head wrapped around what happened, I am sure the EIS warning was because I backed off the throttle and was operating in the mid-range which runs slightly lean, causing high EGT's. I saw this during the engine break in routine. My cure on the ground was to open the enricher a little bit to cool it down. Unfortunately, I didn't think of that in the air. Going to more throttle would have gotten me out of that RPM range as well. Lesson learned. During these windy days, I will fix the PPT button mounting and reset the limits of the EIS slightly closer to the numbers in the Rotax manual. I had purposely set them low for break in so that I would have time to evaluate what was going on. Now that I am more familiar with the engine and the EIS, I can set the limits up a little. I have already tightened the throttle lever so it should stay put next time. As I said, after reflection and watching the video of the landing, it really wasn't as bad as it seemed at the time. On some advice from a friend, I will try putting my elbow on my leg and fly with my fingertips. That should help with the PIO problem. Of course, self-control is the most important one to get a handle on. Now that some time has passed, I am looking forward to the next flight. I really do think this Firefly is going to be a lot of fun, once I get to know it better. Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Gary Aman Sent: Thursday, October 30, 2014 7:41 AM Subject: Re: Kolb-List: Serenity flies! Congratulations on your first flight! Just a thought on first flights if I may.Make it a long flight,getting the feel at slower speeds Sent from my iPhone > On Oct 29, 2014, at 12:41 PM, "Airknocker" wrote: > > --> > > Well guys, we finally did it. Last Saturday I took Serenity to the airport and got to taxi her around a little. Found a couple of minor things to adjust, then test again. > > Taxied around the ramp slowly, then went to the west end of the grass strip. At this point, I have to say pavement SUCKS! > > The weather was warm and the breeze light and variable. Made several trips up and down the runway at varying speeds, getting braver with each pass. Got the tail up and was able to hold it there while keeping straight. No irregularities at all. Engine running well with temps in the right range. > > A quick check of the radio, no other planes in the area, time to quit messing around. > > Partial power up, tail up, glance at the windsock, limp and straight down the runway. More power, getting light and bouncy. Oops, not going straight anymore, glance at windsock, right crosswind, fed in some right aileron and left rudder. She feels ready to fly, oh, oh, runway light in the cross-hairs! More power and pull back, airborne well before edge of runway. > > Holy CRAP! I'm airborne! > > Left wing dropped, over corrected. > Nose came up, over corrected. > Nose went down, pulled off some power, got it level with elevator. > Crap, right wing went down, over corrected, but not as much. > Warning light on EIS, EGT or something out of whack. > Wings have a mind of their own, tail does too... > > What the HE!! have I done? I won't die up here, it will be when I hit the ground out of control. Panic setting in! Every time I touch something, EVERYTHING changes. AAAGGGG! > > Wait, calm down and just fly. Whew, that is better, where am I? Why is that warning light still on? > > Let go of throttle to hit button on EIS. Throttle shuts down and nose comes up. HUH? Push nose down, grab throttle and start the PIO all over again. Wait, calm down and fly. > > OK, not so bad, oops bumps in the air. Gee I must be above pattern altitude, can't see the altimeter because the EIS on the warning page. Looks like high EGT, but not too bad as I have the limits set kind of low. > > Turn crosswind before I get out of gliding range. Left wing drops, fixed, not going the right way. Was that the plane or an air bubble? Mushed it around finally pointing the right way. Looked for traffic, none seen nor heard. OK more bumps and more PIO. Throttle up, down and everywhere in between. > > YIKES, what have I done? Wait, calm down and fly. Whew, better, time to turn downwind. Glance at airspeed, somewhere north of 60, OK we probably won't stall and spin in a gentle turn. This one went better. On downwind leg, getting a grip and just flying. > > Turned base leg, more bumps, more PIO. Recovery was smoother and faster. Got it around to final leg. Decided to just stay at that altitude, whatever it was and just fly around the patch one more time keeping the runway slightly off to my left so I can see if I am going straight. > > Some guy on the ground calls me on the radio and says "is it rough up there or are you having problems?" WHAT? I am 90 seconds into my first flight and YOU want to talk about it, NOW? Are you planning on coming up to help? Found the transmit button and managed to squeak out "I think it's me". Managed to drop the button, oh-oh, this thing is flapping every which way but loose again! > > OK, calm down and fly, OK better. Managed to get all the way around to base leg again and only had a few "burbles and PIO's". OK, plan on making a standard approach and fly the length of the runway, then go around and do it again. Radio calls, someone 5 miles out, headed my way. That is a Champ, he will be here before I can get out of the way. > > On final now, wishing I could find that transmit button to let him know my intentions. Back off the throttle a little and push the nose down. Not so bad, holding 50 MPH. Keeping lined up, still 50. OK. Hey, I am pointed at the numbers, well, if there were numbers, that is where they would be. Still going 50, all is well. Champ is getting close, better just set it down and get out of the way. > > Wait, what? Landing? Man, that runway got here fast, backed of the throttle and started to flair. How high am I? Where did the center of the runway go? > > Still pointed straight, slowing down. How low do I put the nose? I don't want to nose over. I don't want to do a 3 point, do I flair anymore? > > Didn't matter, Serenity decided for me. We did a 3 point landing on 2 wheels. Boing! One good hop of maybe 6", then all 3 wheels hit and stuck. Jerked the last of the throttle off and was stopped in the middle of the runway in seconds. > > WOW! I am alive! Wow, I am still in the runway with traffic in the pattern, somewhere. > > Powered up and taxied off the runway, just in time to hear the Champ on downwind for the runway I was on, no problems there. Just reaching the taxiway when something big and heavy with low wings comes screaming in on the main runway and touches down. Right about where I would have been if I had done a go around. If he used the radio, I certainly never heard it. It might have been a Cherokee or something like it, I only saw a flash. > > That certainly was enough for me for the day. Looking at the windsock it was halfway out and crosswise to all runways, good time to hang it up. Found my transmit button and and announce "Down and clear". Taxiing back to the hangar, I heard the Champ on final and clear of the runway. Never did see that other plane again. > > Man, will I EVER have nerve enough to do THAT again? Really, really unsure at this point. > > My wife who had been watching from the edge of the runway finally gets back to the hangar and congratulates me. She didn't seem excited at all? She said it looked great, but then again, she usually can't tell the difference between a Cherokee and a Champ when they are in the air..... > > Got Serenity folded up and put away. Gee, will I ever get an appetite again? Can I still drive? Should I just walk home? It is only 20 miles and walking is probably safer. > > When I got home and looked at the videos my wife took, two things were obvious. One, my wife can't run a camera, LOTS of blue sky and engine sounds. Two, (she did manage to film the landing) my landing was not nearly as bad as I thought while I was doing it, and in my mind afterward. > > Took two days of "digesting and analyzing" to begin to come to grips with what happened. > > Lessons learned, or at least re-learned: > > Flights rarely go according to plan, have options. > > Basic instruction (if done right) is always with you, ie: calm down and fly, and cut your corrections in half. Thank you Mr. Thomas, all the way back to 1973. > > If you didn't bend it, you did good. > > I am now ready to do it again. Well, not again, better next time. > > I tell this story partially for my own therapy, and for others to hopefully learn from. If nothing else, maybe it will entertain some of you. > > One thing I have not been able to figure out, is why it veered right on take off. > > Taxi testing showed no propensity to go anywhere but straight, so I don't think is a landing gear problem. My prop turns clockwise (as viewed from behind), so P-factor should turn it to the left. Dead bugs and oil droplets on the tail would indicate the air is hitting the left side of the vertical stabilizer more than the right side. That should push me left, not right. Maybe my old Chief training took over and I was applying right rudder without knowing it. > > Only a re-try will tell for sure. Hopefully I will get some dead air time yet this fall. > > Thanks for listening, > > Stuart > > -------- > "I don't care, I'm still free. You can't take the sky from > me" - Josh Wedon > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=432479#432479 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 30, 2014
Did you have a problem with PIO when flying the Aeronca? If not, you shouldn't have a problem with the FF. You didn't mention stall speed. Way back in the Ultrastar Instruction Manual, Homer recommended, on first flight, climb to at least 1,000 feet AGL, check to see where the airplane stalls. Not safe to fly if one does not know the stall speed. I'd concentrate more on flying the aircraft than all those flashing lights, EIS, radio communication, etc. From your msgs, seems you are having difficulty flying. The only instrument I'd really be concerned with is the ASI and stall speed, once you have determined what it is. Keep you work load small as you can until you feel like you can fly the airplane comfortably. Keep your eyes out of the cockpit toward the horizon. This should help prevent over controlling the FF until you can fly by sight and feel. The FF flies like the Aeronca, or any other small airplane, but a bit more responsive to control input. The above are my thoughts and how I'd approach the situation. I'm not recommending you follow them. john h mkIII Titus, Alabama As I said, after reflection and watching the video of the landing, it really wasn't as bad as it seemed at the time. On some advice from a friend, I will try putting my elbow on my leg and fly with my fingertips. That should help with the PIO problem. Of course, self-control is the most important one to get a handle on. Now that some time has passed, I am looking forward to the next flight. I really do think this Firefly is going to be a lot of fun, once I get to know it better. Stuart ________________________________________________________________________________
Date: Oct 30, 2014
That reminds me....We broke that engine in per the instructions...One hour at the various speeds...all the time watching the temps... After the break in...my buddy hopped from his wheel chair into the trike and took off...The plan was to circle where I could see him in case of trouble...for he was helpless on the ground...paraplegic.. Wouldn't you know...hard head Fred...took off and went out of sight...to the point where I heard no engine noise....10 anxious minutes later...he came for a flyby and disappeared for good. Now what do I do?? Worried , I headed for the county airport about 5 miles away in the hopes that some of our buddies could mount a search if necessary... or fly to the strip, circle the area or see if he had come back... Another 15 anxious minutes...and here he came ..on final at the county airport...all smiles...no mention of the original plan to play it safe... thinking back...guess when your main parachute does not open and the back up tangles with the main...and you hit the ground hard hard enough to be in a wheel chair from 1969 til 2012...playing it safe is not in the cards...so I forgave him...76 years old and having the time of his life.. (he was supposed to cut the main chute away...! ) Ironically...the following spring he called a bud to meet him at the airport..when he landed said to call 911...that he was having a heart attack... he died a few hours later at the Cookeville Tenn hosp... Herb On 10/30/2014 09:24 AM, Stuart Harner wrote: > > Thanks, my original intent was to climb up and out of the way of the traffic > pattern and stay in close to the airport. Use the radio at least once per > circuit to announce where I was and my intentions. > > Having the PPT button come loose and "disappear " on me, incoming traffic > and my difficulty in controlling myself, and the airplane caused me to go to > plan B, which was get down and out of the way. > > On my next flight, after proving I can fly calmly, I will move out of the > area and climb up for the real test flying that needs to be done. > > Having a new to me slightly used engine that I have only run for a little > over 2 hours, makes it seem prudent to stick close to a very nice grass > strip at the airport. Wish I could close the airport for an hour or so. :) > > After getting my head wrapped around what happened, I am sure the EIS > warning was because I backed off the throttle and was operating in the > mid-range which runs slightly lean, causing high EGT's. I saw this during > the engine break in routine. My cure on the ground was to open the enricher > a little bit to cool it down. Unfortunately, I didn't think of that in the > air. Going to more throttle would have gotten me out of that RPM range as > well. Lesson learned. > > During these windy days, I will fix the PPT button mounting and reset the > limits of the EIS slightly closer to the numbers in the Rotax manual. I had > purposely set them low for break in so that I would have time to evaluate > what was going on. Now that I am more familiar with the engine and the EIS, > I can set the limits up a little. I have already tightened the throttle > lever so it should stay put next time. > > As I said, after reflection and watching the video of the landing, it really > wasn't as bad as it seemed at the time. On some advice from a friend, I > will try putting my elbow on my leg and fly with my fingertips. That should > help with the PIO problem. Of course, self-control is the most important > one to get a handle on. > > Now that some time has passed, I am looking forward to the next flight. I > really do think this Firefly is going to be a lot of fun, once I get to know > it better. > > Stuart > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Gary Aman > Sent: Thursday, October 30, 2014 7:41 AM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Serenity flies! > > > Congratulations on your first flight! Just a thought on first flights if I > may.Make it a long flight,getting the feel at slower speeds > > Sent from my iPhone > >> On Oct 29, 2014, at 12:41 PM, "Airknocker" > wrote: >> --> >> >> Well guys, we finally did it. Last Saturday I took Serenity to the > airport and got to taxi her around a little. Found a couple of minor things > to adjust, then test again. >> Taxied around the ramp slowly, then went to the west end of the grass > strip. At this point, I have to say pavement SUCKS! >> The weather was warm and the breeze light and variable. Made several > trips up and down the runway at varying speeds, getting braver with each > pass. Got the tail up and was able to hold it there while keeping straight. > No irregularities at all. Engine running well with temps in the right > range. >> A quick check of the radio, no other planes in the area, time to quit > messing around. >> Partial power up, tail up, glance at the windsock, limp and straight down > the runway. More power, getting light and bouncy. Oops, not going straight > anymore, glance at windsock, right crosswind, fed in some right aileron and > left rudder. She feels ready to fly, oh, oh, runway light in the > cross-hairs! More power and pull back, airborne well before edge of runway. >> Holy CRAP! I'm airborne! >> >> Left wing dropped, over corrected. >> Nose came up, over corrected. >> Nose went down, pulled off some power, got it level with elevator. >> Crap, right wing went down, over corrected, but not as much. >> Warning light on EIS, EGT or something out of whack. >> Wings have a mind of their own, tail does too... >> >> What the HE!! have I done? I won't die up here, it will be when I hit the > ground out of control. Panic setting in! Every time I touch something, > EVERYTHING changes. AAAGGGG! >> Wait, calm down and just fly. Whew, that is better, where am I? Why is > that warning light still on? >> Let go of throttle to hit button on EIS. Throttle shuts down and nose > comes up. HUH? Push nose down, grab throttle and start the PIO all over > again. Wait, calm down and fly. >> OK, not so bad, oops bumps in the air. Gee I must be above pattern > altitude, can't see the altimeter because the EIS on the warning page. Looks > like high EGT, but not too bad as I have the limits set kind of low. >> Turn crosswind before I get out of gliding range. Left wing drops, fixed, > not going the right way. Was that the plane or an air bubble? Mushed it > around finally pointing the right way. Looked for traffic, none seen nor > heard. OK more bumps and more PIO. Throttle up, down and everywhere in > between. >> YIKES, what have I done? Wait, calm down and fly. Whew, better, time to > turn downwind. Glance at airspeed, somewhere north of 60, OK we probably > won't stall and spin in a gentle turn. This one went better. On downwind > leg, getting a grip and just flying. >> Turned base leg, more bumps, more PIO. Recovery was smoother and faster. > Got it around to final leg. Decided to just stay at that altitude, whatever > it was and just fly around the patch one more time keeping the runway > slightly off to my left so I can see if I am going straight. >> Some guy on the ground calls me on the radio and says "is it rough up > there or are you having problems?" WHAT? I am 90 seconds into my first > flight and YOU want to talk about it, NOW? Are you planning on coming up to > help? Found the transmit button and managed to squeak out "I think it's > me". Managed to drop the button, oh-oh, this thing is flapping every which > way but loose again! >> OK, calm down and fly, OK better. Managed to get all the way around to > base leg again and only had a few "burbles and PIO's". OK, plan on making a > standard approach and fly the length of the runway, then go around and do it > again. Radio calls, someone 5 miles out, headed my way. That is a Champ, > he will be here before I can get out of the way. >> On final now, wishing I could find that transmit button to let him know my > intentions. Back off the throttle a little and push the nose down. Not so > bad, holding 50 MPH. Keeping lined up, still 50. OK. Hey, I am pointed at > the numbers, well, if there were numbers, that is where they would be. > Still going 50, all is well. Champ is getting close, better just set it > down and get out of the way. >> Wait, what? Landing? Man, that runway got here fast, backed of the > throttle and started to flair. How high am I? Where did the center of the > runway go? >> Still pointed straight, slowing down. How low do I put the nose? I don't > want to nose over. I don't want to do a 3 point, do I flair anymore? >> Didn't matter, Serenity decided for me. We did a 3 point landing on 2 > wheels. Boing! One good hop of maybe 6", then all 3 wheels hit and stuck. > Jerked the last of the throttle off and was stopped in the middle of the > runway in seconds. >> WOW! I am alive! Wow, I am still in the runway with traffic in the > pattern, somewhere. >> Powered up and taxied off the runway, just in time to hear the Champ on > downwind for the runway I was on, no problems there. Just reaching the > taxiway when something big and heavy with low wings comes screaming in on > the main runway and touches down. Right about where I would have been if I > had done a go around. If he used the radio, I certainly never heard it. It > might have been a Cherokee or something like it, I only saw a flash. >> That certainly was enough for me for the day. Looking at the windsock it > was halfway out and crosswise to all runways, good time to hang it up. > Found my transmit button and and announce "Down and clear". Taxiing back to > the hangar, I heard the Champ on final and clear of the runway. Never did > see that other plane again. >> Man, will I EVER have nerve enough to do THAT again? Really, really > unsure at this point. >> My wife who had been watching from the edge of the runway finally gets > back to the hangar and congratulates me. She didn't seem excited at all? > She said it looked great, but then again, she usually can't tell the > difference between a Cherokee and a Champ when they are in the air..... >> Got Serenity folded up and put away. Gee, will I ever get an appetite > again? Can I still drive? Should I just walk home? It is only 20 miles > and walking is probably safer. >> When I got home and looked at the videos my wife took, two things were > obvious. One, my wife can't run a camera, LOTS of blue sky and engine > sounds. Two, (she did manage to film the landing) my landing was not nearly > as bad as I thought while I was doing it, and in my mind afterward. >> Took two days of "digesting and analyzing" to begin to come to grips with > what happened. >> Lessons learned, or at least re-learned: >> >> Flights rarely go according to plan, have options. >> >> Basic instruction (if done right) is always with you, ie: calm down and > fly, and cut your corrections in half. Thank you Mr. Thomas, all the way > back to 1973. >> If you didn't bend it, you did good. >> >> I am now ready to do it again. Well, not again, better next time. >> >> I tell this story partially for my own therapy, and for others to > hopefully learn from. If nothing else, maybe it will entertain some of you. >> One thing I have not been able to figure out, is why it veered right on > take off. >> Taxi testing showed no propensity to go anywhere but straight, so I don't > think is a landing gear problem. My prop turns clockwise (as viewed from > behind), so P-factor should turn it to the left. Dead bugs and oil > droplets on the tail would indicate the air is hitting the left side of the > vertical stabilizer more than the right side. That should push me left, not > right. Maybe my old Chief training took over and I was applying right rudder > without knowing it. >> Only a re-try will tell for sure. Hopefully I will get some dead air time > yet this fall. >> Thanks for listening, >> >> Stuart >> >> -------- >> "I don't care, I'm still free. You can't take the sky from >> me" - Josh Wedon >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=432479#432479 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Oct 30, 2014
John, No, the Chief and I got along just fine for many years. While the Chief and the FF fly similarly, the FF is SOOOO much lighter on the controls. I "Knew" it would be lighter, but I was not prepared for how much lighter, thus the PIO. Not helping any, I think I was at the altitude where the shear turbulence was. It was light, but when you only weight 500#, it does not take much. In the Chief, you led with some rudder, rolled in some aileron and there was definite "push back" from the controls, as well as a bit of a lag before anything happened. With the FF, there seemed (at least in my heightened state of mind) that there were NO forces on the controls, and everything I did happened instantly. My friend with the elbow on the leg and fly with your fingertips advice said it is probably like flying a helicopter, you don't move the controls, you hold them and think about moving them, then you go where you were thinking about. I have never flown a helicopter and he has never flown a FF, so it is nothing more than advice offered in helpfulness. If I left the impression that I was "head in the cockpit", please rest assured that was not the case. I think I only saw the ASI twice in flight, once in my first turn and then again on my final descent, I watched it fairly closely. The rest of the time I was trying to fly straight and level and figure out pitch and power. My references to the EIS were no more than fleeting glimpses, thus I was not exactly sure what it was telling me. I had looked to see what my altitude was, but it was on the warning page and the one time I did look closely enough, I saw EGT at 1229. I have the limit set at 1200 but know that 1250 is the redline. In retrospect, I am fairly confident the plane is just fine, although I may need to put a trim tab on somewhere, it was just my nerves that tried to get the better of me a couple of times. There were some moments when we flew straight and level with no problems. The fact that I was able to regain control of myself and the airplane is a testament to my primary instructor. Since I have to be student, test pilot, and instructor all at the same time I have to rely on past training and experience as well as the words (and videos) of others. As for stall speed, agreed, I really need to do that learning ASAP, but not at the expense of keeping the shiny side up. I am sure that will come on the next flight, and would have on the last one, if I had stayed up like I had planned. This reminds me of an online discussion several years back. A fellow was learning to fly a trike of some kind and could not get the hang of landings. He asked at what speed I landed the Chief. My reply was, "I have no idea, but somewhere under 40". I explained that once I crossed the fence, my eyes are outside, divided between down the runway, and between the wheel and the nose. Down the runway gives me direction and horizon, between the wheel and nose gives me height. The hands and feet do what they need to. Repetition makes the training. Readings on gauges have never been as important to me as the readings I take with my backside. Well, except when doing instrument work, but there is nothing to look out at anyway. I very much appreciate the comments, advice, anecdotes, stories, etc. They all go into the memory bank, hopefully to be recalled when needed. I guess it is appropriate that I scared myself a little, after all it is nearly Halloween! Someone please send me some calm air, so I can try again. Thanks, Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck Sent: Thursday, October 30, 2014 10:00 AM Subject: RE: Kolb-List: Serenity flies! Did you have a problem with PIO when flying the Aeronca? If not, you shouldn't have a problem with the FF. You didn't mention stall speed. Way back in the Ultrastar Instruction Manual, Homer recommended, on first flight, climb to at least 1,000 feet AGL, check to see where the airplane stalls. Not safe to fly if one does not know the stall speed. I'd concentrate more on flying the aircraft than all those flashing lights, EIS, radio communication, etc. From your msgs, seems you are having difficulty flying. The only instrument I'd really be concerned with is the ASI and stall speed, once you have determined what it is. Keep you work load small as you can until you feel like you can fly the airplane comfortably. Keep your eyes out of the cockpit toward the horizon. This should help prevent over controlling the FF until you can fly by sight and feel. The FF flies like the Aeronca, or any other small airplane, but a bit more responsive to control input. The above are my thoughts and how I'd approach the situation. I'm not recommending you follow them. john h mkIII Titus, Alabama As I said, after reflection and watching the video of the landing, it really wasn't as bad as it seemed at the time. On some advice from a friend, I will try putting my elbow on my leg and fly with my fingertips. That should help with the PIO problem. Of course, self-control is the most important one to get a handle on. Now that some time has passed, I am looking forward to the next flight. I really do think this Firefly is going to be a lot of fun, once I get to know it better. Stuart ________________________________________________________________________________
Date: Nov 01, 2014
Subject: PLEASE READ - Matronics Email List Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 03, 2014
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 04, 2014
Subject: trailering a fire fly
we need to deliver a fire fly by open trailer next week=C2-=C2-=C2- =C2- the wing attach points and bridle where never installed by the build er however it was a quick build =C2-, he never intended to fold or hall i t . now he is dead=C2-and the estate needs it=C2-sold, My question is h ow to fold and haul it safely?=C2- any pics would really be helpful =C2 -=C2-=C2-Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.comLSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022=C2-=C2-=C2-=C2- ________________________________________________________________________________
Date: Nov 03, 2014
How far do you have to haul it? I took mine 20 miles to the airport. I followed the instructions in the builder=99s manual for folding and I made a tail boom stand out of an automotive jack stand. It made it, but I would not want to go much farther than that as there was enough movement of the wings against the bracket that it wore all the powder coat off of the bracket. I could not tell how much material was worn off of the aluminum spar, but it had to be at least some. For a longer move I would want the wing tips supported to the trailer, not the tail boom. $50 worth of 2X4=99s, screws and carpet scraps could save a lot of damage. In short, I think the wing fold brackets are find for sitting or moving in and out of storage, but are not good for long travels, especially on an open trailer. Search the archives, you will find much discussion and several pictures of how this has been accomplished by others. I have a few photos of the firefly folded, but will have to look to see if there are any of it loaded on the trailer. Stuart From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Malcolm Brubaker Sent: Monday, November 03, 2014 8:34 PM Subject: Kolb-List: trailering a fire fly we need to deliver a fire fly by open trailer next week the wing attach points and bridle where never installed by the builder however it was a quick build , he never intended to fold or hall it . now he is dead and the estate needs it sold, My question is how to fold and haul it safely? any pics would really be helpful Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.com <http://michigansportpilotrepair.com/> LSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Subject: Re: trailering a fire fly
Date: Nov 04, 2014
When in doubt, remove the wings and secure them separate from the fuselage, i t's only one more bolt per side and it makes the whole plane much less vulne rable to damage and 10 times easier to handle. Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA > On Nov 3, 2014, at 9:33 PM, Malcolm Brubaker wrote : > > we need to deliver a fire fly by open trailer next week the wing attac h points and bridle where never installed by the builder however it was a qu ick build , he never intended to fold or hall it . now he is dead and the e state needs it sold, My question is how to fold and haul it safely? any pic s would really be helpful > Malcolm & Jeanne Brubaker > Michigan Sport Pilot Repair > http://michigansportpilotrepair.com > LSRM-A, PPC, WS > Great Sails - Sailmaker > for Ultralight & Light Sport > (989)513-3022 > > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Nov 04, 2014
how wide is the boom tub?=C2-=C2- how long should the tube that fits in to the wing=C2-=C2- be?=C2-=C2-=C2- how far out from the center o f the boom tube the wing support tube is =C2-should depend on how much pa dding I have between the boom tube and the wing, this problem totty took me by surprise. I think I have a good handle on it,=C2- no pun intended=C2 - =C2-=C2-=C2- =C2- Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.comLSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022=C2-=C2-=C2-=C2- From: Stuart Harner <stuart(at)harnerfarm.net> To: kolb-list(at)matronics.com Sent: Monday, November 3, 2014 11:26 PM Subject: RE: Kolb-List: trailering a fire fly How far do you have to haul it?=C2- I took mine 20 miles to the airport. I followed the instructions in the builder=99s manual for folding and I made a tail boom stand out of an automotive jack stand.=C2- It made it , but I would not want to go much farther than that as there was enough mov ement of the wings against the bracket that it wore all the powder =C2-co at off of the bracket.=C2- I could not tell how much material was worn of f of the aluminum spar, but it had to be at least some.=C2- For a longer move I would want the wing tips supported to the trailer, not the tail boom . =C2- $50 worth of 2X4=99s, screws and carpet scraps could save a lot of da mage. =C2- In short, I think the wing fold brackets are find for sitting or moving in and out of storage, but are not good for long travels, especially on an ope n trailer. =C2- Search the archives, you will find much discussion and several pictures of how this has been accomplished by others. =C2- I have a few photos of the firefly folded, but will have to look to see if there are any of it loaded on the trailer. =C2- Stuart =C2- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@m atronics.com] On Behalf Of Malcolm Brubaker Sent: Monday, November 03, 2014 8:34 PM Subject: Kolb-List: trailering a fire fly =C2- we need to deliver a fire fly by open trailer next week=C2-=C2-=C2- =C2- the wing attach points and bridle where never installed by the build er however it was a quick build =C2-, he never intended to fold or hall i t . now he is dead=C2-and the estate needs it=C2-sold, My question is h ow to fold and haul it safely?=C2- any pics would really be helpful =C2 -=C2-=C2- Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.com LSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022 =C2- =C2- =C2- =C2- =C2- =C2-www.aeroelectric.comwww.buildersbooks.comwww.homebuilthelp.co mwww.mypilotstore.comwww.mrrace.comhttp://www.matronics.com/contributionhtt p://www.matronics.com/Navigator?Kolb-Listhttp://forums.matronics.com =C2- ________________________________________________________________________________
Date: Nov 04, 2014
Subject: Video of Flight Along Lake Michigan
This is more of that first flight with my Drift 170 video camera. I have a bunch more of different areas around my back yard. Now that I have settled in here in Florida for the winter I will post them. The plane is a Kolb MKIIIC with a reduction drive VW motor. This video is taken from a short mount attached to my left wing fold fitting. The camera is pointing down 15 degrees and to the left 10 degrees. The link to the video is: https://vimeo.com/110925614 The password is again: Mears Rick Neilsen ________________________________________________________________________________
Date: Nov 04, 2014
UmljaywgdGhlIHBhc3N3b3JkIGRvZXNuJ3Qgd29yayBmb3IgbWUuwqAKRGF2ZSBLdWxwCgpEbyBu b3QgYXJjaGl2ZQoKClNlbnQgZnJvbSBteSBWZXJpem9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBo b25lCgo8ZGl2Pi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS08L2Rpdj48ZGl2PkZy b206IFJpY2sgTmVpbHNlbiA8bmVpbHNlbnJtQGdtYWlsLmNvbT4gPC9kaXY+PGRpdj5EYXRlOjEx LzA0LzIwMTQgIDQ6MTkgUE0gIChHTVQtMDU6MDApIDwvZGl2PjxkaXY+VG86IGtvbGItbGlzdEBt YXRyb25pY3MuY29tIDwvZGl2PjxkaXY+U3ViamVjdDogS29sYi1MaXN0OiBWaWRlbyBvZiBGbGln aHQgQWxvbmcgTGFrZSBNaWNoaWdhbiA8L2Rpdj48ZGl2Pgo8L2Rpdj5UaGlzIGlzIG1vcmUgb2Yg dGhhdCBmaXJzdCBmbGlnaHQgd2l0aCBteSBEcmlmdCAxNzAgdmlkZW8gY2FtZXJhLiBJIGhhdmUg YSBidW5jaCBtb3JlIG9mIGRpZmZlcmVudCBhcmVhcyBhcm91bmQgbXkgYmFjayB5YXJkLiBOb3cg dGhhdCBJIGhhdmUgc2V0dGxlZCBpbiBoZXJlIGluIEZsb3JpZGEgZm9yIHRoZSB3aW50ZXIgSSB3 aWxsIHBvc3QgdGhlbS4KClRoZSBwbGFuZSBpcyBhIEtvbGIgTUtJSUlDIHdpdGggYSByZWR1Y3Rp b24gZHJpdmUgVlcgbW90b3IuIFRoaXMgdmlkZW8gaXMgdGFrZW4gZnJvbSBhIHNob3J0IG1vdW50 IGF0dGFjaGVkIHRvIG15IGxlZnQgd2luZyBmb2xkIGZpdHRpbmcuIFRoZSBjYW1lcmEgaXMgcG9p bnRpbmcgZG93biAxNSBkZWdyZWVzIGFuZCB0byB0aGUgbGVmdCAxMCBkZWdyZWVzLgoKVGhlIGxp bmsgdG8gdGhlIHZpZGVvIGlzOgoKaHR0cHM6Ly92aW1lby5jb20vMTEwOTI1NjE0CgpUaGUgcGFz c3dvcmQgaXMgYWdhaW46IE1lYXJzCgpSaWNrIE5laWxzZW4KCgoKXy09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09Cl8tPSAgICAg ICAtLSBQbGVhc2UgU3VwcG9ydCBZb3VyIExpc3RzIFRoaXMgTW9udGggLS0KXy09ICAgICAgICAg ICAoQW5kIEdldCBTb21lIEFXRVNPTUUgRlJFRSBHaWZ0cyEpCl8tPQpfLT0gICBOb3ZlbWJlciBp cyB0aGUgQW5udWFsIExpc3QgRnVuZCBSYWlzZXIuICBDbGljayBvbgpfLT0gICB0aGUgQ29udHJp YnV0aW9uIGxpbmsgYmVsb3cgdG8gZmluZCBvdXQgbW9yZSBhYm91dApfLT0gICB0aGlzIHllYXIn cyBUZXJyaWZpYyBGcmVlIEluY2VudGl2ZSBHaWZ0cyBwcm92aWRlZApfLT0gICBieToKXy09Cl8t PSAgICAgKiBBZXJvRWxlY3RyaWMgd3d3LmFlcm9lbGVjdHJpYy5jb20KXy09ICAgICAqIFRoZSBC dWlsZGVyJ3MgQm9va3N0b3JlIHd3dy5idWlsZGVyc2Jvb2tzLmNvbQpfLT0gICAgICogSG9tZWJ1 aWx0SEVMUCB3d3cuaG9tZWJ1aWx0aGVscC5jb20KXy09ICAgICAqIE15IFBpbG90IFN0b3JlIHd3 dy5teXBpbG90c3RvcmUuY29tCl8tPSAgICAgKiBSYWNlIENvbnN1bHRpbmcgd3d3Lm1ycmFjZS5j b20KXy09Cl8tPSAgIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlOgpfLT0KXy09ICAgLS0+IGh0 dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24KXy09Cl8tPSAgIFRoYW5rIHlvdSBm b3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT0KXy09ICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgpfLT0KXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgIC0g VGhlIEtvbGItTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZl YXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1 Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2Fk LCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2gg bW9yZToKXy09Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tv bGItTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVN UyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9y dW1zIQpfLT0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0K Cg= ________________________________________________________________________________
Subject: Re: Video of Flight Along Lake Michigan
Date: Nov 04, 2014
neilsenrm(at)gmail.com wrote: > . . . . SNIP > > The password is again: Mears > > > Rick Neilsen > > > > Works OK with lower case "m" Password: mears -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432861#432861 ________________________________________________________________________________
Date: Nov 04, 2014
The password works in lower case. mears not Mears. ----- Original Message ----- From: "George Alexander" <gtalexander(at)att.net> Sent: Tuesday, November 04, 2014 6:07 PM Subject: Kolb-List: Re: Video of Flight Along Lake Michigan > > > neilsenrm(at)gmail.com wrote: >> . . . . SNIP >> >> The password is again: Mears >> >> >> Rick Neilsen >> >> >> >> > > > Works OK with lower case "m" > > Password: mears > > -------- > George Alexander > FS II R503 N709FS > http://www.oh2fly.net > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=432861#432861 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 04, 2014
Subject: Re:Vw setup
Rick Do not recall that you have posted much info on the Vw setup..Tell us something about it...Herb ________________________________________________________________________________
Subject: Serenity Flies, Take 2
Date: Nov 04, 2014
Well, Mother Nature provided a small window of =93calmness=94 this afternoon. Forecast was for 5 to 8 MPH down the grass strip. When I got to the airport, the windsock was indicating that the forecast was correct. I decided that if nothing else, I would go taxi around a little. While unfolding and doing the preflight, an RV was doing touch and goes on the grass strip, no one else around. By the time I got warmed up and strapped in, the RV was headed to the hangar. Taxied past the windsock, it was completely limp. There was a cloud bank moving in from the west, good, no sunshine in my eyes, visibility should be better, or at least easier. Lined up, and throttled up. Tail up, speed coming up. A little push/pull on the stick confirmed that I had elevator authority. Added more throttle, it felt light, but was able to keep the nose from going down. Added more throttle, and was airborne! No real warning, just in the air and flying. Took the throttle to full and held the nose up, YAY! Indicated speed was at 55, and climbing, so I started adding back pressure, and we were climbing smooth and straight. Again, YAY! Held it at 60 and just climbed away. No wing rocking, no changes in pitch or throttle, just steady and smooth. I don=92t know my rate of climb as I had a different page up on the EIS keeping an eye on engine temps and altitude. At about 400=92, rolled in some left rudder and aileron, normal turn, not real steep, roll back to level seemed =93normal=94. Kept climbing and got out of the pattern. Didn=92t go very far but got up to 2000=92 AGL. Backed the throttle down to 6000 and was able to hold 60 MPH, but I think I was still slowly climbing. Had I been able to reach the panel, I would have changed the EIS to show rate of climb. Did some shallow turns, left and right, checked the aileron/rudder co-ordination. Slowed to 50 and did the same turns. Slowed to 40 and did it again. Nothing seemed weird, so went on with the plan. Backed off on the throttle and slowed to about 35 and all of a sudden the nose dropped. I had stalled and it stayed straight and level, just tucked the nose. So, instinct took over and I added throttle and pushed the nose down. Oops, that made it worse. This time instead of backing off the throttle and pulling back, I just pulled back. OK, that was better, did not take long to be back up at 60 MPH, but it still seemed like I was =93pointed down=94. Managed to get everything stabilized and headed back to the airport, as the cloud cover was getting thicker and it was starting to get kind of dark. Made a powered descent towards the airport. Flew around and entered the pattern at 800=92. Made my turns and got lined up on final, but it seemed kind of high. Backed off the throttle some more and pushed the nose down to maintain 60 MPH. Well, that did not work too well, as I was still high when I passed mid field. No problem, added power, picked up the nose and went around. This time, I flew the pattern a couple of hundred feet lower and kind of overshot my base to final turn. Knowing that this was a really bad situation to be in, I was extra careful about keeping the speed up until I was lined up , then backed off and held 50 on final. Problem was, I was going to land about mid-field, where I had been warned that the intersection with the concrete was kind of rough. Decided to add some power and just fly it across the intersection as there was still lots of room to land, or to go around. All was going well until I got close to the intersection, which is the high point of the grass strip, I made the mistake of pulling up to clear it instead of adding power. I did not realize just how slow I had gotten and ran out of airspeed before touching down. That was kind of a surprise, and it hit a little harder than I would have liked. One good bounce and then the next time we touched, it didn=92t bounce any more, although I felt the gear flexing a little. Stick all the way back and we quickly came to taxi speed. A quick check, everything looks and feels OK. I can steer just fine, so taxied back to the hangar. Closer inspection indicated no damage done. So, all in all, a very good flight. By the time the hangar door was closing, there was mist in the air, so we squeezed all the flight time out that we could have today. It was good to =93get back on the horse=94. Things proven today: The plane flies just fine, except it may need a little left rudder trim tab. This seem to be common to the plane/engine combination. The PIO experienced on the first flight was a combination of turbulence and pilot ham fistedness. Lessons learned: Fireflies like to fly, they don=92t like to descend, kind of like the Chief. A light touch is all that is needed, and when used, you can actually feel the feedback. Anything but perfect straight ahead flight brings wind around the windshield and hits me in the face. Sometimes makes my eyes water or takes my breath away. Need different headgear/clothing. 60 MPH is not enough to take the kink out of the piece of yarn my wife gave me for a yaw string. J There is no warning before the stall. This one kind of surprises me, I cannot think of another plane I have flown that did not give some kind of warning. The old Chief got mushy on the controls then had a definite =93shudder=94, during which if you relaxed the back pressure, you could avoid the stall. If you wanted to stall, you had to hold back pressure through the shudder to get there. Level flight visibility is WAY nose lower than I expected. This will take some getting used to, but will be necessary to be able to accurately judge approach and landing. I exceeded EGT again while using partial throttle. At one point I saw 1267=B0F on the back cylinder. It did not last too long, as I throttled up and cooled it down, but it happened when I did not really want more throttle. I think 30 seconds at this temp didn=92t do any harm, but would like to not do that again. The same things that always require practice in other airplanes are present here too: Slow flight Stalls, of all kinds, at altitude of course Approaches Slips Flaps Landing speed and attitude Practice, practice, practice. Even if the weather keeps me grounded until spring, at least I won=92t get to my next flight and be terrified of it. My self-confidence and confidence in the plane took a big leap today. I needed that! Sorry this got so long, but again, I tell my story for my own therapy and to document these experiences so maybe they will help someone else. Thanks everyone for listening and special thanks to Bryan at Kolb for doing such an awesome job on this kit, and Travis for the great support. Stuart and Serenity ________________________________________________________________________________
Date: Nov 04, 2014
Subject: Re: Serenity Flies, Take 2
I exceeded EGT again while using partial throttle. At one point I saw 1267=C2=B0F on the back cylinder. It did not last too long, as I throttled up and cooled it down, but it happened when I did not really want more throttle. I think 30 seconds at this temp didn=99t do any harm, but would like to not do that again. --------------------------------------------------------------------------- ---------------------------------------------- Until you get your jets straightened out keep in mind that if you pull the enrichner circuit on, it will lower the egt's . Much better, perhaps Serenity isn't such a bad name after all. :-) Larry On Tue, Nov 4, 2014 at 6:32 PM, Stuart Harner wrote : > Well, Mother Nature provided a small window of =9Ccalmness=9D this afternoon. > Forecast was for 5 to 8 MPH down the grass strip. > > > When I got to the airport, the windsock was indicating that the forecast > was correct. I decided that if nothing else, I would go taxi around a > little. While unfolding and doing the preflight, an RV was doing touch a nd > goes on the grass strip, no one else around. By the time I got warmed up > and strapped in, the RV was headed to the hangar. Taxied past the > windsock, it was completely limp. There was a cloud bank moving in from > the west, good, no sunshine in my eyes, visibility should be better, or a t > least easier. > > > Lined up, and throttled up. Tail up, speed coming up. A little push/pull > on the stick confirmed that I had elevator authority. Added more throttle , > it felt light, but was able to keep the nose from going down. Added more > throttle, and was airborne! No real warning, just in the air and flying. > Took the throttle to full and held the nose up, YAY! > > > Indicated speed was at 55, and climbing, so I started adding back > pressure, and we were climbing smooth and straight. Again, YAY! Held it > at 60 and just climbed away. > > > No wing rocking, no changes in pitch or throttle, just steady and smooth. > I don=99t know my rate of climb as I had a different page up on the EIS > keeping an eye on engine temps and altitude. > > > At about 400=99, rolled in some left rudder and aileron, normal tur n, not > real steep, roll back to level seemed =9Cnormal=9D. Kept clim bing and got out > of the pattern. Didn=99t go very far but got up to 2000=99 AG L. Backed the > throttle down to 6000 and was able to hold 60 MPH, but I think I was stil l > slowly climbing. Had I been able to reach the panel, I would have change d > the EIS to show rate of climb. > > > Did some shallow turns, left and right, checked the aileron/rudder > co-ordination. Slowed to 50 and did the same turns. Slowed to 40 and di d > it again. Nothing seemed weird, so went on with the plan. > > > Backed off on the throttle and slowed to about 35 and all of a sudden the > nose dropped. I had stalled and it stayed straight and level, just tucke d > the nose. So, instinct took over and I added throttle and pushed the nos e > down. Oops, that made it worse. This time instead of backing off the > throttle and pulling back, I just pulled back. OK, that was better, did > not take long to be back up at 60 MPH, but it still seemed like I was > =9Cpointed down=9D. Managed to get everything stabilized and headed back to > the airport, as the cloud cover was getting thicker and it was starting t o > get kind of dark. > > > Made a powered descent towards the airport. Flew around and entered the > pattern at 800=99. Made my turns and got lined up on final, but it seemed > kind of high. Backed off the throttle some more and pushed the nose down > to maintain 60 MPH. Well, that did not work too well, as I was still hig h > when I passed mid field. No problem, added power, picked up the nose and > went around. > > > This time, I flew the pattern a couple of hundred feet lower and kind of > overshot my base to final turn. Knowing that this was a really bad > situation to be in, I was extra careful about keeping the speed up until I > was lined up , then backed off and held 50 on final. Problem was, I was > going to land about mid-field, where I had been warned that the > intersection with the concrete was kind of rough. Decided to add some > power and just fly it across the intersection as there was still lots of > room to land, or to go around. > > > All was going well until I got close to the intersection, which is the > high point of the grass strip, I made the mistake of pulling up to clear it > instead of adding power. I did not realize just how slow I had gotten an d > ran out of airspeed before touching down. That was kind of a surprise, > and it hit a little harder than I would have liked. One good bounce and > then the next time we touched, it didn=99t bounce any more, althoug h I felt > the gear flexing a little. Stick all the way back and we quickly came to > taxi speed. > > > A quick check, everything looks and feels OK. I can steer just fine, so > taxied back to the hangar. Closer inspection indicated no damage done. > > > So, all in all, a very good flight. By the time the hangar door was > closing, there was mist in the air, so we squeezed all the flight time ou t > that we could have today. It was good to =9Cget back on the horse =9D. > > > Things proven today: > > The plane flies just fine, except it may need a little left rudder trim > tab. This seem to be common to the plane/engine combination. > > The PIO experienced on the first flight was a combination of turbulence > and pilot ham fistedness. > > > Lessons learned: > > Fireflies like to fly, they don=99t like to descend, kind of like t he Chief. > > A light touch is all that is needed, and when used, you can actually feel > the feedback. > > Anything but perfect straight ahead flight brings wind around the > windshield and hits me in the face. Sometimes makes my eyes water or take s > my breath away. Need different headgear/clothing. > > 60 MPH is not enough to take the kink out of the piece of yarn my wife > gave me for a yaw string. J > > There is no warning before the stall. This one kind of surprises me, I > cannot think of another plane I have flown that did not give some kind of > warning. The old Chief got mushy on the controls then had a definite > =9Cshudder=9D, during which if you relaxed the back pressure, you could avoid > the stall. If you wanted to stall, you had to hold back pressure through > the shudder to get there. > > Level flight visibility is WAY nose lower than I expected. This will tak e > some getting used to, but will be necessary to be able to accurately judg e > approach and landing. > > > I exceeded EGT again while using partial throttle. At one point I saw > 1267=C2=B0F on the back cylinder. It did not last too long, as I throttl ed up > and cooled it down, but it happened when I did not really want more > throttle. I think 30 seconds at this temp didn=99t do any harm, bu t would > like to not do that again. > > > The same things that always require practice in other airplanes are > present here too: > > Slow flight > > Stalls, of all kinds, at altitude of course > > Approaches > > Slips > > Flaps > > Landing speed and attitude > > > Practice, practice, practice. > > > Even if the weather keeps me grounded until spring, at least I won =99t get > to my next flight and be terrified of it. My self-confidence and > confidence in the plane took a big leap today. I needed that! > > > Sorry this got so long, but again, I tell my story for my own therapy and > to document these experiences so maybe they will help someone else. > > > Thanks everyone for listening and special thanks to Bryan at Kolb for > doing such an awesome job on this kit, and Travis for the great support. > > > Stuart and Serenity > > > * > =========== m> ldersbooks.com> .com> com> om/contribution> =========== onics.com/Navigator?Kolb-List> =========== =========== > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Nov 04, 2014
Larry, Thanks. I had discovered the enricher trick during the ground runs, and was reaching for it, when I realized I was in the landing pattern and really did not want to make a change that might cause it to stumble or quit. Of course, frying a piston and quitting is worse, so I opted for the additional throttle. This of course, contributed to a higher speed, which lead to the sloppy pattern and overshoot. Everything has consequences. Wide open throttle at what I think was level flight was showing about 6350 RPM. Not sure if I should dial out a little pitch on the prop or leave it be. Also, the temps run perfectly below about 4500 and above about 5500. I am not sure if I should try raising the needle one notch or try a different needle or jet. More flying experience will tell me if I can operate outside of this lean range or if I need to try and correct it. Y19 has a field elevation of 1940=99, but it was cooler than standard today, so without doing the real math, my guess is that DA was under 1000=99. More things to test after I get some more stick time. Yes, MUCH better this time. I am now confident that we can continue on with a normal learning curve and flight testing. Thanks to everyone who gave examples, advice and encouragement. It really DID help. This time I am anxious to get back up there for more. Stuart From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Tuesday, November 04, 2014 8:52 PM Subject: Re: Kolb-List: Serenity Flies, Take 2 I exceeded EGT again while using partial throttle. At one point I saw 1267=C2=B0F on the back cylinder. It did not last too long, as I throttled up and cooled it down, but it happened when I did not really want more throttle. I think 30 seconds at this temp didn=99t do any harm, but would like to not do that again. ------------------------------------------------------------------------- ------------------------------------------------ Until you get your jets straightened out keep in mind that if you pull the enrichner circuit on, it will lower the egt's . Much better, perhaps Serenity isn't such a bad name after all. :-) Larry On Tue, Nov 4, 2014 at 6:32 PM, Stuart Harner wrote: Well, Mother Nature provided a small window of =9Ccalmness=9D this afternoon. Forecast was for 5 to 8 MPH down the grass strip. When I got to the airport, the windsock was indicating that the forecast was correct. I decided that if nothing else, I would go taxi around a little. While unfolding and doing the preflight, an RV was doing touch and goes on the grass strip, no one else around. By the time I got warmed up and strapped in, the RV was headed to the hangar. Taxied past the windsock, it was completely limp. There was a cloud bank moving in from the west, good, no sunshine in my eyes, visibility should be better, or at least easier. Lined up, and throttled up. Tail up, speed coming up. A little push/pull on the stick confirmed that I had elevator authority. Added more throttle, it felt light, but was able to keep the nose from going down. Added more throttle, and was airborne! No real warning, just in the air and flying. Took the throttle to full and held the nose up, YAY! Indicated speed was at 55, and climbing, so I started adding back pressure, and we were climbing smooth and straight. Again, YAY! Held it at 60 and just climbed away. No wing rocking, no changes in pitch or throttle, just steady and smooth. I don=99t know my rate of climb as I had a different page up on the EIS keeping an eye on engine temps and altitude. At about 400=99, rolled in some left rudder and aileron, normal turn, not real steep, roll back to level seemed =9Cnormal=9D. Kept climbing and got out of the pattern. Didn=99t go very far but got up to 2000=99 AGL. Backed the throttle down to 6000 and was able to hold 60 MPH, but I think I was still slowly climbing. Had I been able to reach the panel, I would have changed the EIS to show rate of climb. Did some shallow turns, left and right, checked the aileron/rudder co-ordination. Slowed to 50 and did the same turns. Slowed to 40 and did it again. Nothing seemed weird, so went on with the plan. Backed off on the throttle and slowed to about 35 and all of a sudden the nose dropped. I had stalled and it stayed straight and level, just tucked the nose. So, instinct took over and I added throttle and pushed the nose down. Oops, that made it worse. This time instead of backing off the throttle and pulling back, I just pulled back. OK, that was better, did not take long to be back up at 60 MPH, but it still seemed like I was =9Cpointed down=9D. Managed to get everything stabilized and headed back to the airport, as the cloud cover was getting thicker and it was starting to get kind of dark. Made a powered descent towards the airport. Flew around and entered the pattern at 800=99. Made my turns and got lined up on final, but it seemed kind of high. Backed off the throttle some more and pushed the nose down to maintain 60 MPH. Well, that did not work too well, as I was still high when I passed mid field. No problem, added power, picked up the nose and went around. This time, I flew the pattern a couple of hundred feet lower and kind of overshot my base to final turn. Knowing that this was a really bad situation to be in, I was extra careful about keeping the speed up until I was lined up , then backed off and held 50 on final. Problem was, I was going to land about mid-field, where I had been warned that the intersection with the concrete was kind of rough. Decided to add some power and just fly it across the intersection as there was still lots of room to land, or to go around. All was going well until I got close to the intersection, which is the high point of the grass strip, I made the mistake of pulling up to clear it instead of adding power. I did not realize just how slow I had gotten and ran out of airspeed before touching down. That was kind of a surprise, and it hit a little harder than I would have liked. One good bounce and then the next time we touched, it didn=99t bounce any more, although I felt the gear flexing a little. Stick all the way back and we quickly came to taxi speed. A quick check, everything looks and feels OK. I can steer just fine, so taxied back to the hangar. Closer inspection indicated no damage done. So, all in all, a very good flight. By the time the hangar door was closing, there was mist in the air, so we squeezed all the flight time out that we could have today. It was good to =9Cget back on the horse=9D. Things proven today: The plane flies just fine, except it may need a little left rudder trim tab. This seem to be common to the plane/engine combination. The PIO experienced on the first flight was a combination of turbulence and pilot ham fistedness. Lessons learned: Fireflies like to fly, they don=99t like to descend, kind of like the Chief. A light touch is all that is needed, and when used, you can actually feel the feedback. Anything but perfect straight ahead flight brings wind around the windshield and hits me in the face. Sometimes makes my eyes water or takes my breath away. Need different headgear/clothing. 60 MPH is not enough to take the kink out of the piece of yarn my wife gave me for a yaw string. J There is no warning before the stall. This one kind of surprises me, I cannot think of another plane I have flown that did not give some kind of warning. The old Chief got mushy on the controls then had a definite =9Cshudder=9D, during which if you relaxed the back pressure, you could avoid the stall. If you wanted to stall, you had to hold back pressure through the shudder to get there. Level flight visibility is WAY nose lower than I expected. This will take some getting used to, but will be necessary to be able to accurately judge approach and landing. I exceeded EGT again while using partial throttle. At one point I saw 1267=C2=B0F on the back cylinder. It did not last too long, as I throttled up and cooled it down, but it happened when I did not really want more throttle. I think 30 seconds at this temp didn=99t do any harm, but would like to not do that again. The same things that always require practice in other airplanes are present here too: Slow flight Stalls, of all kinds, at altitude of course Approaches Slips Flaps Landing speed and attitude Practice, practice, practice. Even if the weather keeps me grounded until spring, at least I won=99t get to my next flight and be terrified of it. My self-confidence and confidence in the plane took a big leap today. I needed that! Sorry this got so long, but again, I tell my story for my own therapy and to document these experiences so maybe they will help someone else. Thanks everyone for listening and special thanks to Bryan at Kolb for doing such an awesome job on this kit, and Travis for the great support. Stuart and Serenity _blank">www.aeroelectric.com .com" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com ="_blank">www.mypilotstore.com ank">www.mrrace.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com -- If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Nov 05, 2014
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 05, 2014
Herb Sorry but I'm going to have some fun with this. Where have you been? I was the first to put a VW on a kolb. I wrote a article for the EAA's light sport magazine with all the details of putting a VW on a Kolb. The Kolb VW engine mount is based on my mount thanks to Rick Lewis. My plane has been to the EAA's airventure 4 times, Sun N Fun and one of the New Kolb homecomings. Over the last 15 years I have posted to the kolb list at least a hundred E-Mails about my VW powered MKIIIC. Check the archives. Except for, a failure of the series one Valley redrive (not designed for composite props) (currently flying a series three redrive) and last summer my primary fuel pump was trying to tell me it was dying the engine has been flawless. Rick Neilsen Redrive VW Powered MKIIIC On Tue, Nov 4, 2014 at 8:30 PM, Herb wrote: > > > Rick > > Do not recall that you have posted much info on the Vw setup..Tell us > something about it...Herb > > ________________________________________________________________________________
Date: Nov 05, 2014
Rick Just asking for the new comers....:-) On 11/05/2014 04:26 PM, Rick Neilsen wrote: > Herb > > Sorry but I'm going to have some fun with this. > > Where have you been? I was the first to put a VW on a kolb. I wrote a > article for the EAA's light sport magazine with all the details of > putting a VW on a Kolb. The Kolb VW engine mount is based on my mount > thanks to Rick Lewis. My plane has been to the EAA's airventure 4 > times, Sun N Fun and one of the New Kolb homecomings. Over the last > 15 years I have posted to the kolb list at least a hundred E-Mails > about my VW powered MKIIIC. Check the archives. > > Except for, a failure of the series one Valley redrive (not designed > for composite props) (currently flying a series three redrive) and > last summer my primary fuel pump was trying to tell me it was dying > the engine has been flawless. > > Rick Neilsen > Redrive VW Powered MKIIIC > > On Tue, Nov 4, 2014 at 8:30 PM, Herb > wrote: > > > > > > Rick > > Do not recall that you have posted much info on the Vw > setup..Tell us something about it...Herb > > =================================== > br> fts!) > r> > /www.aeroelectric.com" target="_blank">www.aeroelectric.com > w.buildersbooks.com" target="_blank">www.buildersbooks.com > p.com" target="_blank">www.homebuilthelp.com > e.com" target="_blank">www.mypilotstore.com > " target="_blank">www.mrrace.com > target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > =================================== > -List" target="_blank">http://www.matronics.com/Navigator?Kolb-List > =================================== > FORUMS - > _blank">http://forums.matronics.com > =================================== > > > * > > > * ________________________________________________________________________________
Date: Nov 05, 2014
Great write up! Having a Firefly I have not flown yet, your article is excellent information on what to expect. I tried taxing up and down the runway with a 90* crosswind the other day just see what to expect. It was a wild ride! -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=432983#432983 ________________________________________________________________________________
Date: Nov 06, 2014
One method of supporting the boom tube on a Kolb MkIII (and other aircraft) is by using a PVC "saddle". This saddle is originally made for irrigation piping, but works perfectly with a little modification. The saddle itself requires no tweaking, but there is a pipe that connects to the saddle-tee, and the base of *that* needs a large castered wheel. Another good solution for supporting the boom tube while trailering is to find a "base" for the pipe that comes out of the saddle-tee, and affix the "base" to the trailer... then, after the Kolb is in place on the trailer, put the saddle-tee in place on the boom-tube, then screw a connecting pipe on to it and the base. One source: Irrigation Station LLP 11929 Windfern Houston, TX 77064 281-890-6574 sales(at)irrigationstation.com Part: 6 x 2 PVC IPS FIPT Saddle, product code 4460-20 @ $41.00 (The above part description, part #, and price is as of Aug 2008) The part information above is only for the saddle-tee. Also needed is a pipe, connected to the saddle-tee, and of course the wheel. (When I find a photo of the saddle in place on the boom tube, I'll post it here.) I've used this method (with the caster wheel for over 7 years with my Mk III. I also have the base that attached to my trailer floor, for securing it while transporting it. Below are mfg pix of saddle-tees. [image: Saddle-tee] On Tue, Nov 4, 2014 at 1:21 PM, Malcolm Brubaker wrote: > how wide is the boom tub? how long should the tube that fits into the > wing be? how far out from the center of the boom tube the wing suppo rt > tube is should depend on how much padding I have between the boom tube a nd > the wing, this problem totty took me by surprise. I think I have a good > handle on it, no pun intended > > > Malcolm & Jeanne Brubaker > Michigan Sport Pilot Repair > http://michigansportpilotrepair.com > LSRM-A, PPC, WS > Great Sails - Sailmaker > for Ultralight & Light Sport > (989)513-3022 > > > ------------------------------ > *From:* Stuart Harner > *To:* kolb-list(at)matronics.com > *Sent:* Monday, November 3, 2014 11:26 PM > *Subject:* RE: Kolb-List: trailering a fire fly > > How far do you have to haul it? I took mine 20 miles to the airport. I > followed the instructions in the builder=99s manual for folding and I made a > tail boom stand out of an automotive jack stand. It made it, but I would > not want to go much farther than that as there was enough movement of the > wings against the bracket that it wore all the powder coat off of the > bracket. I could not tell how much material was worn off of the aluminum > spar, but it had to be at least some. For a longer move I would want the > wing tips supported to the trailer, not the tail boom. > > > $50 worth of 2X4=99s, screws and carpet scraps could save a lot of damage. > > > In short, I think the wing fold brackets are find for sitting or moving i n > and out of storage, but are not good for long travels, especially on an > open trailer. > > > Search the archives, you will find much discussion and several pictures o f > how this has been accomplished by others. > > > I have a few photos of the firefly folded, but will have to look to see i f > there are any of it loaded on the trailer. > > > Stuart > > > *From:* owner-kolb-list-server(at)matronics.com [mailto: > owner-kolb-list-server(at)matronics.com] *On Behalf Of *Malcolm Brubaker > *Sent:* Monday, November 03, 2014 8:34 PM > *To:* Kolb-list matronics.com > *Subject:* Kolb-List: trailering a fire fly > > > we need to deliver a fire fly by open trailer next week the wing > attach points and bridle where never installed by the builder however it > was a quick build , he never intended to fold or hall it . now he is > dead and the estate needs it sold, My question is how to fold and haul it > safely? any pics would really be helpful > > Malcolm & Jeanne Brubaker > Michigan Sport Pilot Repair > > http://michigansportpilotrepair.com > > LSRM-A, PPC, WS > Great Sails - Sailmaker > for Ultralight & Light Sport > (989)513-3022 > > > *www.aeroelectric.com <http://www.aeroelectric.com>* > > *www.buildersbooks.com <http://www.buildersbooks.com>* > > *www.homebuilthelp.com <http://www.homebuilthelp.com>* > > *www.mypilotstore.com <http://www.mypilotstore.com>* > > *www.mrrace.com <http://www.mrrace.com>* > > *http://www.matronics.com/contribution * > > *http://www.matronics.com/Navigator?Kolb-List * > > *http://forums.matronics.com * > > > * > > _blank" rel="nofollow">www.aeroelectric.com <http://www.aeroelectric.co m> > " target="_blank" rel="nofollow">www.buildersbooks.com <http://www.bu ildersbooks.com> > ="_blank" rel="nofollow">www.homebuilthelp.com <http://www.homebuilth elp.com> > ="_blank" rel="nofollow">www.mypilotstore.com <http://www.mypilotstor e.com> > ank" rel="nofollow">www.mrrace.com <http://www.mrrace.com> > _blank" rel="nofollow">http://www.matronics.com/contribution > get="_blank" rel="nofollow">http://www.matronics.com/Navigator?Kolb-L ist > l= <http://www.matronics.com/Navigator?Kolb-List > l=>"nofollow">http://forums.matronics.com > > * > > > * > =========== =========== =========== =========== > > * > > ________________________________________________________________________________
Date: Nov 06, 2014
Very interesting, thanks for posting. Question? Is the MKIII tail boom 6=9D in diameter? The firefly is 5=9D, so this may be too large unless you glue some padding of some kind inside of the saddle. Carpeting comes to mind. From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Robert Laird Sent: Thursday, November 06, 2014 8:58 AM Subject: Re: Kolb-List: trailering a fire fly One method of supporting the boom tube on a Kolb MkIII (and other aircraft) is by using a PVC "saddle". This saddle is originally made for irrigation piping, but works perfectly with a little modification. The saddle itself requires no tweaking, but there is a pipe that connects to the saddle-tee, and the base of that needs a large castered wheel. Another good solution for supporting the boom tube while trailering is to find a "base" for the pipe that comes out of the saddle-tee, and affix the "base" to the trailer... then, after the Kolb is in place on the trailer, put the saddle-tee in place on the boom-tube, then screw a connecting pipe on to it and the base. One source: Irrigation Station LLP 11929 Windfern Houston, TX 77064 281-890-6574 sales(at)irrigationstation.com Part: 6 x 2 PVC IPS FIPT Saddle, product code 4460-20 @ $41.00 (The above part description, part #, and price is as of Aug 2008) The part information above is only for the saddle-tee. Also needed is a pipe, connected to the saddle-tee, and of course the wheel. (When I find a photo of the saddle in place on the boom tube, I'll post it here.) I've used this method (with the caster wheel for over 7 years with my Mk III. I also have the base that attached to my trailer floor, for securing it while transporting it. Below are mfg pix of saddle-tees. Saddle-tee <http://texas-flyer.com/img/saddle-tee.jpg> <http://texas-flyer.com/img/saddle-tee3.jpg> <http://texas-flyer.com/img/saddle-tee-demo.jpg> On Tue, Nov 4, 2014 at 1:21 PM, Malcolm Brubaker wrote: how wide is the boom tub? how long should the tube that fits into the wing be? how far out from the center of the boom tube the wing support tube is should depend on how much padding I have between the boom tube and the wing, this problem totty took me by surprise. I think I have a good handle on it, no pun intended Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.com LSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022 _____ From: Stuart Harner <stuart(at)harnerfarm.net> Sent: Monday, November 3, 2014 11:26 PM Subject: RE: Kolb-List: trailering a fire fly How far do you have to haul it? I took mine 20 miles to the airport. I followed the instructions in the builder=99s manual for folding and I made a tail boom stand out of an automotive jack stand. It made it, but I would not want to go much farther than that as there was enough movement of the wings against the bracket that it wore all the powder coat off of the bracket. I could not tell how much material was worn off of the aluminum spar, but it had to be at least some. For a longer move I would want the wing tips supported to the trailer, not the tail boom. $50 worth of 2X4=99s, screws and carpet scraps could save a lot of damage. In short, I think the wing fold brackets are find for sitting or moving in and out of storage, but are not good for long travels, especially on an open trailer. Search the archives, you will find much discussion and several pictures of how this has been accomplished by others. I have a few photos of the firefly folded, but will have to look to see if there are any of it loaded on the trailer. Stuart From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Malcolm Brubaker Sent: Monday, November 03, 2014 8:34 PM Subject: Kolb-List: trailering a fire fly we need to deliver a fire fly by open trailer next week the wing attach points and bridle where never installed by the builder however it was a quick build , he never intended to fold or hall it . now he is dead and the estate needs it sold, My question is how to fold and haul it safely? any pics would really be helpful Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.com LSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022 www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com www.mypilotstore.com www.mrrace.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com _blank" rel="nofollow">www.aeroelectric.com " target="_blank" rel="nofollow">www.buildersbooks.com ="_blank" rel="nofollow">www.homebuilthelp.com ="_blank" rel="nofollow">www.mypilotstore.com ank" rel="nofollow">www.mrrace.com _blank" rel="nofollow">http://www.matronics.com/contribution get="_blank" rel="nofollow">http://www.matronics.com/Navigator?Kolb-List <http://www.matronics.com/Navigator?Kolb-Listl=> l= <http://www.matronics.com/Navigator?Kolb-Listl=> "nofollow">http://forums.matronics.com ________________________________________________________________________________
Date: Nov 06, 2014
Relying on memory (a very dangerous thing!), yes, it's 6" in diameter. The PVC saddle has a thin (but not too thin) piece of rubber covering the entire inside surface, so that when it contacts the boom tube, it creates enough friction to stop the saddle from moving around on it (and protects the aluminum). Carpet might work, but you'd then have to worry about it moving around on you. I don't know if anyone makes a 5" saddle, but that's would be a better solution. Second-best would be to use something rubber-like with a lot of friction that would give a tight and very even "seal" around the tube. Until you mentioned the issue of its use with a 5" boom, it never occurred to me how lucky it is that this all works together so well! -- R On Thu, Nov 6, 2014 at 10:07 AM, Stuart Harner wrote: > Very interesting, thanks for posting. > > > Question? Is the MKIII tail boom 6=9D in diameter? > > > The firefly is 5=9D, so this may be too large unless you glue some padding > of some kind inside of the saddle. Carpeting comes to mind. > > > *From:* owner-kolb-list-server(at)matronics.com [mailto: > owner-kolb-list-server(at)matronics.com] *On Behalf Of *Robert Laird > *Sent:* Thursday, November 06, 2014 8:58 AM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: trailering a fire fly > > > One method of supporting the boom tube on a Kolb MkIII (and other > aircraft) is by using a PVC "saddle". This saddle is originally made for > irrigation piping, but works perfectly with a little modification. The > saddle itself requires no tweaking, but there is a pipe that connects to > the saddle-tee, and the base of *that* needs a large castered wheel. > > Another good solution for supporting the boom tube while trailering is to > find a "base" for the pipe that comes out of the saddle-tee, and affix th e > "base" to the trailer... then, after the Kolb is in place on the trailer, > put the saddle-tee in place on the boom-tube, then screw a connecting pip e > on to it and the base. > > One source: > > Irrigation Station LLP > 11929 Windfern > Houston, TX 77064 > 281-890-6574 > sales(at)irrigationstation.com > > Part: 6 x 2 PVC IPS FIPT Saddle, product code 4460-20 @ $41.00 > (The above part description, part #, and price is as of Aug 2008) > > The part information above is only for the saddle-tee. Also needed is a > pipe, connected to the saddle-tee, and of course the wheel. (When I find a > photo of the saddle in place on the boom tube, I'll post it here.) I've > used this method (with the caster wheel for over 7 years with my Mk III. I > also have the base that attached to my trailer floor, for securing it whi le > transporting it. > > Below are mfg pix of saddle-tees. > > [image: Saddle-tee] > > > On Tue, Nov 4, 2014 at 1:21 PM, Malcolm Brubaker > wrote: > > how wide is the boom tub? how long should the tube that fits into the > wing be? how far out from the center of the boom tube the wing suppo rt > tube is should depend on how much padding I have between the boom tube a nd > the wing, this problem totty took me by surprise. I think I have a good > handle on it, no pun intended > > > Malcolm & Jeanne Brubaker > Michigan Sport Pilot Repair > > http://michigansportpilotrepair.com > > LSRM-A, PPC, WS > Great Sails - Sailmaker > for Ultralight & Light Sport > (989)513-3022 > > > ------------------------------ > > *From:* Stuart Harner > *To:* kolb-list(at)matronics.com > *Sent:* Monday, November 3, 2014 11:26 PM > *Subject:* RE: Kolb-List: trailering a fire fly > > > How far do you have to haul it? I took mine 20 miles to the airport. I > followed the instructions in the builder=99s manual for folding and I made a > tail boom stand out of an automotive jack stand. It made it, but I would > not want to go much farther than that as there was enough movement of the > wings against the bracket that it wore all the powder coat off of the > bracket. I could not tell how much material was worn off of the aluminum > spar, but it had to be at least some. For a longer move I would want the > wing tips supported to the trailer, not the tail boom. > > > $50 worth of 2X4=99s, screws and carpet scraps could save a lot of damage. > > > In short, I think the wing fold brackets are find for sitting or moving i n > and out of storage, but are not good for long travels, especially on an > open trailer. > > > Search the archives, you will find much discussion and several pictures o f > how this has been accomplished by others. > > > I have a few photos of the firefly folded, but will have to look to see i f > there are any of it loaded on the trailer. > > > Stuart > > > *From:* owner-kolb-list-server(at)matronics.com [mailto: > owner-kolb-list-server(at)matronics.com] *On Behalf Of *Malcolm Brubaker > *Sent:* Monday, November 03, 2014 8:34 PM > *To:* Kolb-list matronics.com > *Subject:* Kolb-List: trailering a fire fly > > > we need to deliver a fire fly by open trailer next week the wing > attach points and bridle where never installed by the builder however it > was a quick build , he never intended to fold or hall it . now he is > dead and the estate needs it sold, My question is how to fold and haul it > safely? any pics would really be helpful > > Malcolm & Jeanne Brubaker > Michigan Sport Pilot Repair > > http://michigansportpilotrepair.com > > LSRM-A, PPC, WS > Great Sails - Sailmaker > for Ultralight & Light Sport > (989)513-3022 > > > *www.aeroelectric.com <http://www.aeroelectric.com>* > > *www.buildersbooks.com <http://www.buildersbooks.com>* > > *www.homebuilthelp.com <http://www.homebuilthelp.com>* > > *www.mypilotstore.com <http://www.mypilotstore.com>* > > *www.mrrace.com <http://www.mrrace.com>* > > *http://www.matronics.com/contribution * > > *http://www.matronics.com/Navigator?Kolb-List * > > *http://forums.matronics.com * > > > *_blank" rel="nofollow">www.aeroelectric.com <http://www.aeroelectric.c om>* > > *" target="_blank" rel="nofollow">www.buildersbooks.com <http://www.b uildersbooks.com>* > > *="_blank" rel="nofollow">www.homebuilthelp.com <http://www.homebuilt help.com>* > > *="_blank" rel="nofollow">www.mypilotstore.com <http://www.mypilotsto re.com>* > > *ank" rel="nofollow">www.mrrace.com <http://www.mrrace.com>* > > *_blank" rel="nofollow">http://www.matronics.com/contribution * > > *get="_blank" rel="nofollow">http://www.matronics.com/Navigator?Kolb- List <http://www.matronics.com/Navigator?Kolb-Listl=>* > > *l= <http://www.matronics.com/Navigator?Kolb-Listl=>**"nofollow">http ://forums.matronics.com <http://forums.matronics.com>* > > > *www.aeroelectric.com <http://www.aeroelectric.com>* > > *www.buildersbooks.com <http://www.buildersbooks.com>* > > *www.homebuilthelp.com <http://www.homebuilthelp.com>* > > *www.mypilotstore.com <http://www.mypilotstore.com>* > > *www.mrrace.com <http://www.mrrace.com>* > > *http://www.matronics.com/contribution * > > *http://www.matronics.com/Navigator?Kolb-List * > > *http://forums.matronics.com * > > > * > =========== m> ldersbooks.com> .com> com> om/contribution> =========== onics.com/Navigator?Kolb-List> =========== =========== > > * > > ________________________________________________________________________________
Date: Nov 06, 2014
brubakermal(at)yahoo.com wrote: > we need to deliver a fire fly by open trailer next week . . . .S N I P . . . My question is how to fold and haul it safely? any pics would really be helpful > Malcolm & Jeanne Brubaker > There are a wide variety of configurations at "Trailering a Kolb": http://oh2fly.net/Main_trailer_kolb.htm -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=433005#433005 ________________________________________________________________________________
Subject: Re: firestar for sale
Date: Nov 06, 2014
I listed the firestar on barnstormers and it sold in 2 hours. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=433011#433011 ________________________________________________________________________________
Date: Nov 06, 2014
Thanks for the link to your videos. You make it look easy. I used up a lot more of the runway the other day and I was just trying to motor down the runway straight. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=433018#433018 ________________________________________________________________________________
Date: Nov 07, 2014
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: wanting an ultrastar?
Date: Nov 07, 2014
I have two. One needs to go. Presently I have what I believe is a factory welded cage , nice wings, tail. All complete including prints and manuals but no engine. I'm about to start recovering it but this would be a great opportunity to see it naked so you can see what's inside. It's has brakes. Late model firestar spring landing gear. Elevator trim. Asking $2000. Located in Jupiter Florida. -------- 1984 kolb ultrstar Former 1997 kolb firestat Read this topic online here: http://forums.matronics.com/viewtopic.php?p=433112#433112 ________________________________________________________________________________
Subject: Re: ultrastar cuyuna prop shaft breakage
Date: Nov 07, 2014
Found the answer. The issue was the redrive mounting plate. It had holes drilled in it too close to the edges and suffered from cracking. Most were replaced. -------- 1984 kolb ultrstar Former 1997 kolb firestat Read this topic online here: http://forums.matronics.com/viewtopic.php?p=433113#433113 ________________________________________________________________________________
From: "KIRBY, DENNIS T GS-13 USAF AFMC AFNWC/ENS" <dennis.kirby.3(at)us.af.mil>
Date: Nov 07, 2014
Robert Laird wrote: << One method of supporting the boom tube on a Kolb MkIII (and other aircraft) is by using a PVC "saddle". This saddle is originally made for irrigation piping, but works perfectly with a little modification, and the base of *that* needs a large castered wheel. >> Malcom / Kolb Friends - Here's a picture of how I built my boom tube support for my Mark-3. The center saddle is made from a piece of 12-inch diameter PVC, cut in half lengthwise. I glued foam to the inside surface for padding. The two side saddles are for supporting the wings. This is much more supportive, and safer for transporting over long distances compared to the stock method of wing support, which uses the 1/2 inch tube that passes thru the fuselage tube. For added shock absorption, once the aircraft is on the trailer, I place an old tire under the dolly to raise it high enough to just get the casters off the deck, then tie down the whole aircraft. I have trailered my Mark-3 hundreds of miles using this, with no damage whatsoever. Dennis Kirby Mark-III, 912, Powerfin New Mexico ________________________________________________________________________________
Subject: Re: trailering a fire fly
Date: Nov 07, 2014
Hi Dennis, and other Klobers Please explain how you get the saddle under the boom tube. My mk3 tail is too heavy for me to lift. Do you use a jack under the Tail ? A hoist? Or are you just really strong. Your method looks good. Frank Sent from my iPhone On Nov 7, 2014, at 8:55 AM, "KIRBY, DENNIS T GS-13 USAF AFMC AFNWC/ENS" wrote: > Robert Laird wrote: << One method of supporting the boom tube on a Kolb > MkIII (and other aircraft) is by using a PVC "saddle". This saddle is > originally made for irrigation piping, but works perfectly with a little > modification, and the base of *that* needs a large castered wheel. >> > > Malcom / Kolb Friends - > > Here's a picture of how I built my boom tube support for my Mark-3. > > The center saddle is made from a piece of 12-inch diameter PVC, cut in half > lengthwise. I glued foam to the inside surface for padding. The two side > saddles are for supporting the wings. This is much more supportive, and > safer for transporting over long distances compared to the stock method of > wing support, which uses the 1/2 inch tube that passes thru the fuselage > tube. > > For added shock absorption, once the aircraft is on the trailer, I place an > old tire under the dolly to raise it high enough to just get the casters off > the deck, then tie down the whole aircraft. > > I have trailered my Mark-3 hundreds of miles using this, with no damage > whatsoever. > > Dennis Kirby > Mark-III, 912, Powerfin > New Mexico > ________________________________________________________________________________
Subject: Re: Right turn
Date: Nov 07, 2014
colin.scott.hudson(at)gma wrote: > Frank when I switched to dual controls on my M3Xtra I had the same problem, too much slack and not enough leverage. I hated it. Switched back to single control and the problem went away. You didn't say what type of controls you have, but that may be it. By the way, anybody that would like a set of dual controls, I'll sell them cheap. > > Scott Hudson > > > Sent from my iPhone > > > > On Aug 29, 2014, at 7:56 AM, Frank Goodnight wrote: > > > > > > > > Kolbers > > Just starting to get used to my mk3 classic. I have a question for those of you with > > experience in mk3s. I fly from the right seat, after a bit of fooling around with the flaps and wing incedence i have got the > > plane so it flys pretty much straight and level, handsoff. I find the ailerons to be very heavy > > and slow to react, much more so than my Firestar. If I enter a decending left turn at about > > 75 mph ---nothing radical just a normal turn to left base ,close pattern---to roll level takes about > > 3 seconds and enough right stick and rudder pressure that I'm almost afraid something will > > break I' m tempted to use both hands on the stick. Doesn't seem to matter much what power > > setting is used. If the initial turn is to the right there seems not to be a problem to roll left > > to level. From level flight the problem is much less pronounced, although it is somewhat > > easier to turn left than to turn right.Any thoughts and comments would be much appreciated. > > I don't think it's dangerous , but not sure > > Frank Goodnight > > Fayetteville ,AR > > 912 uls > > Sent from my iPad > > > > > > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=433145#433145 ________________________________________________________________________________
Date: Nov 07, 2014
colin.scott.hudson(at)gma wrote: > Frank when I switched to dual controls on my M3Xtra I had the same problem, too much slack and not enough leverage. I hated it. Switched back to single control and the problem went away. You didn't say what type of controls you have, but that may be it. By the way, anybody that would like a set of dual controls, I'll sell them cheap. > > Scott Hudson > > > Sent from my iPhone > > > > On Aug 29, 2014, at 7:56 AM, Frank Goodnight wrote: > > > > > > > > Kolbers > > Just starting to get used to my mk3 classic. I have a question for those of you with > > experience in mk3s. I fly from the right seat, after a bit of fooling around with the flaps and wing incedence i have got the > > plane so it flys pretty much straight and level, handsoff. I find the ailerons to be very heavy > > and slow to react, much more so than my Firestar. If I enter a decending left turn at about > > 75 mph ---nothing radical just a normal turn to left base ,close pattern---to roll level takes about > > 3 seconds and enough right stick and rudder pressure that I'm almost afraid something will > > break I' m tempted to use both hands on the stick. Doesn't seem to matter much what power > > setting is used. If the initial turn is to the right there seems not to be a problem to roll left > > to level. From level flight the problem is much less pronounced, although it is somewhat > > easier to turn left than to turn right.Any thoughts and comments would be much appreciated. > > I don't think it's dangerous , but not sure > > Frank Goodnight > > Fayetteville ,AR > > 912 uls > > Sent from my iPad > > > > > > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=433146#433146 ________________________________________________________________________________
Date: Nov 10, 2014
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Subject: Headphones
Date: Nov 10, 2014
Kolbers Can someone tell me what brand of noise-cancelling headset works well in a Kolb? And hopefully doesn't break the bank either! Thanx Russ K ________________________________________________________________________________
Date: Nov 10, 2014
Subject: Video Montage of Different Camera Mounts
I think I have finally found the camera mount that I like best for my Drift 170 video camera. The first clip uses a mount I made that plugged into the Kolb wing fold fitting. It was fairly stable but too close to the wing. I couldn't figure a way to extend the mount away from the wing enough to get the wing out of the camera lense and keep it stable. In the second and third clips I used the wing fold fitting but the mount was bent down 45 degrees and the wing is STILL in the camera lense. This mount does a great job of photographing things straight down. I'm going to use this mount to video a shipwreck of the Novadock that is just below the surface off Silver Lake State Park in Lake Michigan. The problem with this mount is it is very sensitive to bumpy air and it bends the horizon and other things not directly in line with the front of the lense. The fourth clip uses the Drift strap mount attached to the bottom of the lift strut near the midpoint of the strut right outboard of the jury strut. The Drift strap mount uses a quick mount system that introduced a bit of slop in the mount. You have to look close in the video to see it but on the ground, in bumpy air and some RPMs, shake the camera enough to make it very blurry. The fifth clip uses the strap mount rapped around web material in the same lift strut location as clip four. I also put some duck tape on the male side of the drift quick mount to take up slack that causes slight camera oscillations. The sixth clip is the landing from the fifth clip. It was getting dark so I increased the brightness on play back. The brightness increase or low light caused the video to look grainy, the brightness increase also wiped out a nice sun set. This is the stabilized strap mount. I couldn't resist showing this clip because it was one of my best landings and it was on video. The video is on Vimio again at: http://vimeo.com/111421520 and the password is mears yes all lower case sorry Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Date: Nov 10, 2014
I liked the landing too. Seems the older I get the worse my landings become. I do well on grass, but my landings on pavement usually suck. john h mkIII Titus, Alabama I couldn't resist showing this clip because it was one of my best landings and it was on video. The video is on Vimio again at: http://vimeo.com/111421520 and the password is mears yes all lower case sorry Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Subject: Re: Headphones
Date: Nov 10, 2014
The Sigtronics S-AR works good for me. It's the only one I've used so others may be better? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=433343#433343 ________________________________________________________________________________
Date: Nov 10, 2014
Subject: Re: Video Montage of Different Camera Mounts
A picture of the mounts might not be all that bad for those of us who are very visual. I kept checking my Drift to see why you were getting all that curve in the videos. I don't remember mine being that way. Mine is set for 1080, but there is some adjustment to the magnification of the lens at 720. That might account for it, or I am never high enough to see the horizon? Glad to see that you found a sweet spot, its not all that easy on a plane that vibrates as much as they do. Larry On Mon, Nov 10, 2014 at 9:01 AM, Rick Neilsen wrote: > I think I have finally found the camera mount that I like best for my > Drift 170 video camera. > > The first clip uses a mount I made that plugged into the Kolb wing fold > fitting. It was fairly stable but too close to the wing. I couldn't figure > a way to extend the mount away from the wing enough to get the wing out of > the camera lense and keep it stable. > > In the second and third clips I used the wing fold fitting but the mount > was bent down 45 degrees and the wing is STILL in the camera lense. This > mount does a great job of photographing things straight down. I'm going to > use this mount to video a shipwreck of the Novadock that is just below the > surface off Silver Lake State Park in Lake Michigan. The problem with this > mount is it is very sensitive to bumpy air and it bends the horizon and > other things not directly in line with the front of the lense. > > The fourth clip uses the Drift strap mount attached to the bottom of the > lift strut near the midpoint of the strut right outboard of the jury strut. > The Drift strap mount uses a quick mount system that introduced a bit of > slop in the mount. You have to look close in the video to see it but on the > ground, in bumpy air and some RPMs, shake the camera enough to make it very > blurry. > > The fifth clip uses the strap mount rapped around web material in the same > lift strut location as clip four. I also put some duck tape on the male > side of the drift quick mount to take up slack that causes slight camera > oscillations. > > The sixth clip is the landing from the fifth clip. It was getting dark so > I increased the brightness on play back. The brightness increase or low > light caused the video to look grainy, the brightness increase also wiped > out a nice sun set. This is the stabilized strap mount. I couldn't resist > showing this clip because it was one of my best landings and it was on > video. > > The video is on Vimio again at: > > http://vimeo.com/111421520 > > and the password is mears > yes all lower case sorry > > Rick Neilsen > Redrive VW Powered MKIIIC > > * > > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Nov 10, 2014
Faro G2 Active noise canceling. http://www.faroaviation.com/aviation-headset.html Brad ___________________________ =93Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same, or one day we will spend our sunset years telling our children and our children's children what it was once like in the United States where men were free.=94 -- President Ronald Reagan > On Nov 10, 2014, at 10:54 , Rex Rodebush wrote: > > > The Sigtronics S-AR works good for me. It's the only one I've used so others may be better? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=433343#433343 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 10, 2014
I have a 30 year old pair of H10 -30 David Clarks which I modified with Headsets Inc, noise cancelling kits which c ost 165.00 per headset I believe Rick N.had a chance to tr y them on a few years back.They work pretty well for me.th ey make kits for a bunch of brands and replace everything in the ear cups. Not that hard to install.=0A G.Aman MK3 C Jabiru 920 hrs=0A=0A =0A=0A =0A=0A =0A=0A-----Original Message-- ---=0AFrom: kinne russ <russk50(at)gmail.com>=0ATo: kolb-list <kolb-list@ matronics.com>=0ASent: Mon, Nov 10, 2014 10:39 am=0ASubject: Kolb- ss =0A=0AKolbers=0ACan someone tell me what brand of noise-cancelling headset works well in a Kolb? =0A=0AAnd hopefully doesn't break the bank either!=0AThanx=0ARuss K =0A=0A=0A =========================== =========================== =========================== =========================== ======================0A=0A=0A=0A=0A =0A ________________________________________________________________________________
Date: Nov 10, 2014
As Larry mentioned, It would be nice to see pictures of the camera mounting. Great videos and landing! -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=433372#433372 ________________________________________________________________________________
Date: Nov 10, 2014
Sorry my plane and camera mounts are in Michigan and I'm in Florida for the winter. No camera mount photos till the snow is gone. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Nov 10, 2014 at 11:41 PM, west1m wrote: > > As Larry mentioned, It would be nice to see pictures of the camera > mounting. Great videos and landing! > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=433372#433372 > > ________________________________________________________________________________
Date: Nov 11, 2014
Brad: I Googled Faro Electronics, and got a surprise. Hope you made out OK Russ K On Nov 10, 2014, at 6:41 PM, Brad Nation wrote: > Faro G2 Active noise canceling. > http://www.faroaviation.com/aviation-headset.html > > Brad > ___________________________ > =93Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same, or one day we will spend our sunset years telling our children and our children's children what it was once like in the United States where men were free.=94 > -- President Ronald Reagan > > > > > > >> On Nov 10, 2014, at 10:54 , Rex Rodebush wrote: >> >> >> The Sigtronics S-AR works good for me. It's the only one I've used so others may be better? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=433343#433343 >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Nov 11, 2014
Greetings All=2C I was able to bring my Mark III to Utah from North Carolina on a single axe l flatbed I made. I used cellophane wrap from Home Depot to cover the cock pit and engine. It provided rain protection and helped secure things. I had a fuselage boom support and wing support on the tail end. I used foam rubb er for other places I thought might be in contact with any other parts. the trip was made with out any incident. I also made sure the prop was not abl e to rotate in the wind. I also transported my previous Firestar II the same way. I picked it up in Minnesota. Kurt Sandy=2C Utah > Subject: Kolb-List: Re: trailering a fire fly > From: gtalexander(at)att.net > Date: Thu=2C 6 Nov 2014 08:38:12 -0800 > To: kolb-list(at)matronics.com > > > > brubakermal(at)yahoo.com wrote: > > we need to deliver a fire fly by open trailer next week . . . .S N I P . . . My question is how to fold and haul it safely? any pics would r eally be helpful > > Malcolm & Jeanne Brubaker > > > > > There are a wide variety of configurations at "Trailering a Kolb": > > http://oh2fly.net/Main_trailer_kolb.htm > > -------- > George Alexander > FS II R503 N709FS > http://www.oh2fly.net > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=433005#433005 > > > > > > > =========== =========== =========== =========== > > > /9j/4S/+RXhpZgAATU0AKgAAAAgACgEPAAIAAAAGAAAAhgEQAAIAAAAKAAAAjAESAAMAAAABAAEA AAEaAAUAAAABAAAAlgEbAAUAAAABAAAAngEoAAMAAAABAAIAAAExAAIAAAAGAAAApgEyAAIAAAAU AAAArAITAAMAAAABAAEAAIdpAAQAAAABAAAAwAAAA6hBcHBsZQBpUGhvbmUgNFMAAAAASAAAAAEA AABIAAAAATcuMC42ADIwMTQ6MDM6MTQgMTY6MjY6MDkAAB+CmgAFAAAAAQAAAjqCnQAFAAAAAQAA AkKIIgADAAAAAQACAACIJwADAAAAAQAyAACQAAAHAAAABDAyMjGQAwACAAAAFAAAAkqQBAACAAAA FAAAAl6RAQAHAAAABAECAwCSAQAKAAAAAQAAAnKSAgAFAAAAAQAAAnqSAwAKAAAAAQAAAoKSBwAD AAAAAQAFAACSCQADAAAAAQAQAACSCgAFAAAAAQAAAoqSFAADAAAABAAAApKSfAAHAAAAxAAAApqS kQACAAAABDYxNACSkgACAAAABDYxNACgAAAHAAAABDAxMDCgAQADAAAAAQABAACgAgAEAAAAAQAA DMCgAwAEAAAAAQAACZCiFwADAAAAAQACAACjAQAHAAAAAQEAAACkAgADAAAAAQAAAACkAwADAAAA AQAAAACkBQADAAAAAQAjAACkBgADAAAAAQAAAACkMgAFAAAABAAAA16kMwACAAAABgAAA36kNAAC AAAAIwAAA4QAAAAAAAAAAQAAB/0AAAAMAAAABTIwMTQ6MDM6MTQgMTY6MjY6MDkAMjAxNDowMzox NCAxNjoyNjowOQAAABQ8AAAB1wAAEu0AAAd+AAAdzAAAAu8AAABrAAAAGQZfBMcDcQNxQXBwbGUg aU9TAAABTU0ABgABAAkAAAABAAAAAAADAAcAAABoAAAAXAAEAAkAAAABAAAAAQAFAAkAAAABAAAA uwAGAAkAAAABAAAAvgAHAAkAAAABAAAAAQAAAABicGxpc3QwMNQBAgMEBQYHCFl0aW1lc2NhbGVV ZXBvY2hVdmFsdWVVZmxhZ3MSO5rKABAAEwAABBUOQjkVEAEIERshJy0yND0AAAAAAAABAQAAAAAA AAAJAAAAAAAAAAAAAAAAAAAAPwAAAGsAAAAZAAAAawAAABkAAAAMAAAABQAAAAwAAAAFQXBwbGUA aVBob25lIDRTIGJhY2sgY2FtZXJhIDQuMjhtbSBmLzIuNAAAAAYBAwADAAAAAQAGAAABGgAFAAAA AQAAA/YBGwAFAAAAAQAAA/4BKAADAAAAAQACAAACAQAEAAAAAQAABAYCAgAEAAAAAQAAJsQAAAAA AAAASAAAAAEAAABIAAAAAf/Y/9sAQwACAQECAQECAgECAgICAgMFAwMDAwMGBAQDBQcGBwcHBgYG BwgLCQcICggGBgkNCQoLCwwMDAcJDQ4NDA4LDAwL/9sAQwECAgIDAgMFAwMFCwgGCAsLCwsLCwsL CwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsL/8AAEQgAeACgAwEiAAIR AQMRAf/EAB8AAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKC//EALUQAAIBAwMCBAMFBQQEAAAB fQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5 OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeo qaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+v/EAB8BAAMB AQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKC//EALURAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYS QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQACEQMRAD8A+VPCc/n3 9hpHhvT0Nq6hpZMDEm7DE8Z25wOp4A716Z/aenaHLHbarc20OHjt1wMKrvwieoLdB64rm/2b/h7q HiTTptb8Tho4mAhihUBEG3HKnq/Ixk46fWvZ7XwtHBZMXiS5kwCS6jdLt5GeOuelf0DlLmqLrPS+ 1+y20Vj8zzRQnVVGOtt7d3u7u5zU+nC0tzIduT3PT8agF2r3w3bFMgIKv22+/rxW89q2oapEuwrF MhKgYbdyeCvsR+tcxHOkV7ItzHD5kdwAccANnbwcc8HkY79K8vMM1qLERnF+7d29dHY9bAZdTVCU Gve0v6a6ly/8TafoFrF/briCSeQxImC7OcZGAPXB61t6Tp9vrGnxXemOk1tOm9JF6EYrxz4i3guv GNjBODbWel/aJLlxhdzeUdvXHB3ZJ9h3r0D9mfxJDc+APsQa3LWZk+RDu2rvOADnoM49e9edkfGk 5ZrPA1ZLks7PrzK1/wBeh7Od8FJZRDH06UlPR3+zyu9tLadN3qdTb6d5tyiIn3++cev51LcaEV1S xTA+cyfov/16m0nzLzxFADgQupkRm42jaMDI4HX9TXQ3EMMet6QWz+9MyquOScDj+tfa4TOViqLd TS01r/29H/M+GxeVfVqqVPW8Xp/26zKTw53C9Kmi8N9cAflXcQ+Hg/Kj61OnhrOPlFfVRqJrQ+bl 7r1OGj8N+36VKnhvIOVHvXdR+Gv9kVNH4a/2RT5wUkcInhs+n6V03jLQMeHfDKMM7dOJ9+biY/1r ZXwyS33a3PFvh8ta6MjDiPToxg+7O39a4sRJOrRXm/8A0lnbQlanUfkvzR5T/wAI71yP0pf+Edye R+ld7/wjOf4aU+Gsfw10OSMlI4AeHQB90UHw/kcrXet4a9FpreHMHhawlIuLPhH/AIKB/soeKviZ 44tfFnhiK3k0XQdFdLgCUfaAQZXYqjEAgBh3rhf2dvjb8aP2F5bLUbTxf8Q/C+kTRxNYW8DFI45W LMm6C5V4DxJLx1zIT3Nfb37Ut0nhP4ZyyTSLEsjksHiV0cIpcBgwIxuVTmvhDRv+Cp3xfg0tdP8A G2o6H4ss4gqomr6PbzyRYwAySqqurjs2SRX49xZho1cdUjBvW19t/LS/4n6fwtiZww8KjhGSjeyd /wAdbfgfafgHQQmhwQpN5uIy6WluqsxYDOJCEGCd35k8121nom21iS3hkhbYH2MDuJ53Y7Z7+prD +EXxF1jxX47vrCLwXqNnZRTGG31Ca4hW3uU5O5fmzn+Ihscc88V7TYeG5W0zzNQWHeF/dwBOgHb6 kD8K+uwmLozg4QlsvNP8e9nY+NxUKlOopSW/mn+X66ngPifUBoGrx2kTRm5bIiZhw6s2cjuR3IHI 5rivi1fXGk6xY3Vt5ds+oXAs7lZDsePPUqWOAysoU89GX2r3/wCJfgq31jQ7m70loBJbL5qGYZ+z uGAD4PIx3OeQSK8b+ItrbeIfCl/Jf3SWl5o+p28hkZhIfm/d/u2IG5sN1YDK7cnIr5fHzUVOnKXn H5I+mwU3Lkml5P5tf5nl3iD4W3vi3QX1Wxv1itp2CiI7vNuWVcP8y/iD7j6CvQvg58LpPh1ool1O a3vTczGNjDuZ4I2AGCTznJyc596t6VZ2nw8/ZiS58SM1xfXVowCxyM0STSOdqjgKBkHcQOc565ro vAE41HwJcsZIVurWH7QE34+1Jg/KmRwRhyCepFfLU8LhcPjY1Yr33FS3fxdfvXT9T6yWb43EYCWG lL93zcrVuitbXy7/AKENiI4Nf0u1tZPMW4tZCApCkYKA9eNo+b8+9dD4pv3i8Q2a2TxhbZZS2eMq FB69mwP1rgfhbrtvq3xQs5ZjHZ2yWFzA3GCux4wAMHj5nAyc5H41u3F7IPiCJ78MYbxZFPluJMHJ C5BGF5UnHXhRzXp0sc44dwpvSU18rWdzx6mHUq6lNaqL/VHtngmJrzQo57pD+8kwMrt2rjOT3/8A 1V1cPhfco+TivP8A4P6neavqsV7q06waesxtYkddiyNuwdvqBgD3ya+jLHw2lzarJCjMpGfuHJ/D FfqGUZqq9Ba7d/zPzLO8G8PXfnfb8jzpPCnotSp4T9Ur0LSdGi1W3MtrFMqbiv7yJoySDg8MB371 fj8Ig/dUGvUWOjJXT0PHcJRdmtTzNPCnPKVpa94d8+a2AXiK1hTp/sA/1rv08HZP3P0qWbw19snY hP8AVrHHx7Rp/jXHWxidenr3/Jf5nZRT9jUfoeXDwtx9z8qD4V4+5XqH/CH5P+rp7+B1WyEjSRea 7bVhBzIR3bHYDI596qvmlPDpOb3aWzer22v9+y6hRoTrNqK2Te6Wi33/AC3PKW8K/wCxTH8K/wCz XpOq6F/ZogLW1xMs0oiJiQERZBO58nheMZ9SKUeE3dgfKAT3PP5UpY+O1y405WueL/Er4f2mveBt TsfEFstzZXcJiniJIEiE4IOOea8z+K/7Hfgb4mTeDrnxZ4c0mU6bcLKI0s40F2WRUCylVBdQGJCk 4zg9q+jfjFoa6V4CvZCoBYog9yWH/wBesrxXoqR634RtxjbK6tzxkYXH5kV81meIjVqzT7QX3z1P bwHNCnFx7zf3RPmHT9bsfhTrN9DdXVzqztbG6kgjD3dy7JwZQmShyQAxwRnHTivoq5+HWseLUh18 rNp15EF8mwkYrE8RO51ZQ2TIykjPGCBx1rwjRf21PBsXhe9ktrK/0qW8tp9OhebSSrPJt4JdTt5I 6Z45617Tdf8ABQD4Xa94egvLLVtSjKvAVVtLkQOXQsMEjnoT1r4qjnlJKV5q2h9NWyjENxapu/8A wxga94B07S5pIhL9lXUI7hVMsXmiaPzD8rjPzYdsE9RuBzXzX+1Doc3wq8OXPm3P2u8e8thLMjKT JEJYtqsNoU4BOCeQVY96+lfiB8f/AAZi3RNdUR2s007Wf2CSSZEcli0TlPl5UHDZ4z9K+b/2lvjx 4P8AFXwruYo7h5dWlv8AT3ubbLolxAJcHazY2nag3Mcc+uAa83HZnRr03FNX6anp4DA16M4ylF26 6FDxhqsV/wCHf7P1YSJa+HdOaMWMb+ZPLMqKQxXGAoA+fB6njnNXPA7QTW+gv4WlkZr+xDQNg+V5 qxkvC4fAYtjOMjqRwSKpeAdd8Ial4Gvb74ianqkiyxSyWaDT5gs94wdmkM56plgwPzAlsnpzHZ6Z JZ/D+w1rwfDeDTZbSGO/tltLlQ8iICJI5DGUDqcMVDgEKvHUV5FbFQ9sqjktl110PYo0KnsnBRf6 al/VtKu/Anxng1Bbc3+lyxvdGWJSyLbrJZsyxxdQ4SUKwOeFxyRWdD4nutdvLa91OS2tbm9vbqKO 4aRSLchFZQEJCgfO3zc8ngc5rkfE/wAa7aKbSo/7VkijuZZ9NllitpUig+0PE43cZDeWjZAz/qsd 81ofCXw/F8c/iPpFhbR3E9tJqV4thaQ28rPZwFXaLIKlnYgDJYgYHJwBhyzBSi40nvrZvr6jhgnG SlV9G0unofUfwv1LSLe38Pya7PPdRTXSWgl020a4S1kwNpPzbQclhl8455JxX274R8HfaPC1jqGl yT3Vlfp5kAmtxDIqkBgWBOc4cDkds96+Kf2eZfDnw7iMPgPxfeXLWGtWaXuh3CG3t4fMjhVrouYj kh22BQeRz2r6U8P/ALUmleBvDmmeGZ9ck8aRvsMuqpdm1nsYjbWzAFI42bjcSp/iAP4+xlubVMHi XVnN8ritE7xut7ef4v7j57PsuoV8Ko0oNyUnrZ81m1a6t+tlr5nfeEfBuox6UE1NUkkSSQNJGiLv +ckcZx0IHSrOtzaT4XktU8V3Nrpr30ghtxcyKhnckAKmT8xywGB6j1r5M/bD/bP8SfCvxrPH+yX4 s1f4lW9vp5SdZNKbTYdIlZ3cXEqBA80gQRgEqIXLEFQea+cvi/8A8FBdY/bV8Q6P428ReHToOk+G rkf8IxoenyLcaldSGSN/MmnZdp8zy1GEVAo/ibNehU4xhSo+78St93fyVu9jDK+BZ5li1GpJKm73 aaVn0WvVvsmfqqnhmLcPlwevoaq6L4ZEhusK3E59OcKo/pXmfwR/4KT+H/i5rdpod74Z1e21+81B dKjMflmwubpjhY0uHYKCeuD0GDnBr3fRpbhINQW70rzpLbzrqQC6gZyqtghU35bkY4HOPStXxZhZ SpVXVSUlZX0u3ay16nl/6r4qlGdJ023dba7XMFfCzOuVjYc87sVi3Hh6Y+PrWDyxj+z5n4bIP72I Z+tdL+zl8XPCH7SGm3s+hahbaBd2Df6Rp2txNZX8AYBldonA+RlIIcEg8+lcf4Y/aD8B+P8Axob3 wr4k0w20dq1vtuiYptwvPKLKuSzRnAfIzkbT7VtiOJoUmo31ur+S7k4fhytJOXLpZ/f2NXUPDMib d8KYDZxuJJ5Ht71teFfD2m2WuxT+N7d5dJh5uBDG7tyQq8JzjcwzXyV+0d+3V4u+GemaNqfwDs9A 8T6h4g8SzaRHBqDTNbiONXlE8flyqwiZVi5IA5brkGtb4c/txftC/GvTEFp4X+Eunx3sDXFsbXSr 4PdbEMhBZbnCDCluT1UGtYYvG5hh6lehH3NI83MlZu9t/Ru/Qxq0cLluIp0MTL37OSjyt3S5b7Lz St1PXv23rzw5rXw3jvPhfp1zZae9wiZlglh844Y5AkbORjngV5t8YNG1KDx54PtvB62s2opDC0ST oTHkEkhgCD0U9+uKyviB+0rN8Wvg1a2eoPDcTW12b2/kh/dx207RLvjCs7NjcHIOSOvNcxrHx/0b Q/Hdpr/h3w/DYzadMsE9tbyrm9uZomeNy+Nu5lmj68epHb5ulm65FCU233d2/dd3rbpf5n1cslqR qc6hG2jS5o299K2z69bbdbHz/pWoaVrOnQWfi3S4b1LG/lvrYXN2jxozMxXClSOFbHTrXbaXqugX PkC9itbSKAr5aw3IIiA6bV8rA4OMDFa9n4Pt3AEVvHhfTFaVv4TAQbYYYsf7J/WvzRYP/p7L7z7f 6x/cRYg1PwfeZM+tMzyLtYtbLISMdMmP39a8E/be+GGgeKfC+h6l4ZlN5Jp2p2i3sVraCGS5tzcJ uHzHb64J6bm6ZyPomz8JGVQGSI+oEfX9eK5r4/8AgC/n+COutolm1xeRokkMNuCXcrIpGMn05PPY 06eCjSkpe0l82v8AIbxLmrcq/r5k/hXwT4GsvDkp8RE3upSr5ht0s3FpDMFwm0fxFcKN5HOM4A4F 74ceHvCq/CPQ9H8d2rPf2tvsvI1tGkilbLAqXDKWXB6dK8W+KP7Z942uXdr+z3faLp+j6IWa/wDE t3p0V6biVBlktIZwUEa45kZWLHpivEtB/wCCwPxysvAfi3xVf+N9MtdG0mZbfToYPCOjiaaVsY8z /ReR88ecAdW9K9CGQupDWo1qtG3ddtl+B5889jTm0o3t2Wn4s9M/aB/Ym8AeLP2rPAcuhR6vpmla x5815a20GxFa3hLYiDscBwQDnpyRjNed/tafGC4+D/jHQU+GMttpcljNcx2JGnW63H+qcBWZgS+N 2FznGQRzg1h/Bb/gux8efE2vFfE3jbwvcQWw3SGbwXo8HlgggEO8Qyc4yAemetega7/wW1+JaaWz Jc/BnxBfQv8AKuq+ENPEcgxk5kjkUp9RW8slnSnGMpXsurf+Ri+Iacbrketui/zufOHgX9sb41fE Hx1p3hn4Ma59muNekCSwxafaly2Apkkcx7vlVVY88bdw5FfXq+Ih8G/CcWmRXEw1XQbSISLNa7fO 8tEjDEjBBPUHn05xWv8Atp/HjWLHx74I8X/CjTvCvhmDxT4P0jxEy6PpkCLA1zbL9p8iULv2b1kx ljkDFfMn7UnxU+KEHjaEeKtaDXQgjeN2tkkFzayvxJ8uChV2KnpgMrcAnHv08sng8NCvpyS1dt7f 1v2OWGbYXG1qlCpBymtI3ukn3dn22WzPfvGOvaN4outP1vxT4qXTrFtv2qS2h8+YE4XJBfLk7cbC NuPQ9POfhf4mub7Q0jv9atNaubeSSMTxvuyA7qu9doWNgmPkXIXgAmviCz/aU1s+NruPWbpI7qKd 7ZJJSqLHKCVTcT/CGxnqcD8a+iPEn7M1/wDsS+CfCdh4x8c6B451zxvNDcNHpN+V0vRRMxVY575y FLlw5ZVUquDls8V5lRRVSMo2WjSWmvX/AIc9PBU5UsNWhUV+dxd7Oyaf67H3d8DPiU9joOn+CvDd hr9tI2mTTw3626tpt1fyXTnzFJJUuiCJCXUN8mBwcn0zW4NP8H/GqK7v9Xm+3WM6XtrujhkKNAID 8ufmALIjFVwODXln7Lv7QXwf+BXwj0bQfiP8SPCf9rQzyXNw9qTcWlrM7/6tbt1wSOOcDnPYZr6A 8B/GT4c/EbxhJYfDrxLpOvazGjNKthfwySooxku8ceQOQOW9BXhyr4mFWpNxbi3putvvPdq4nD1s NQw60cFJNq15OT6tWbVtLO/XucZ8QrrwZ8b9FsLn4xa4bq7TT4raPZpKJNHEFX92JYsSleAcFsZ5 rzrQfhV8LPhz4iTVPCmg32o30amFZ/7O2MsRyAn764GVCnbjb04r6nl8M2upafNZWOhia2ZTG4Oq SIuCMYGCO3HFeZ65+z3oGmXTQ22nXunO33VttTuHA/ORh+lXCvGqv3rkvR6foeY4ujeNK1u3+fc8 68d/Gv8AsTwzdRfCbwbZRajfRG0knNiIDbxMuC8flkjeNkYHtkcVqeIv29/EnhTwdofh/wAE6H9j sNG0UaNHPb2BikbbEYxM8hG5nYMc4245qfXPgYLEn7Nq+rW79kmG8Ef8CXNczqXgTUbI4W8D46Fk U5/QV9Dl+eSwFBUKbTjzc3vK+vzXTp6s+ZzLh6jmNf6xVupcvL7rtp/SX3GS37Q2jXXgdlt4ZLPU LKxZ2gnjeMTSAcRh2mbcc5HCr1615f4c+LOuaf8ACaOeTV/BGg+Nb7Vf7Qk8jSpWtLSMpyroJC0s oxt8zd1wcYFej3/hW/LYM8Jwc5MOMfkeazbjwtqAhxMLedu5aP8A/XXDGvThDki+++u++6PUlRlK XM/L8Nj0xviVoGhon2y+hj8w5HmXCR7h6jnn8Kz9a/aY8L+GrV5mvtMQBti5mV3lb0X5sE/jXJ/8 E5f+CSd1+2z4F0vx58f/ABv4a0LSdZiFzZaJb3632tNE2MNKZsLbbhghdrtgjOK+9Ph7+xF+z7+x Zq8Wm+HvCts+u20av9pbTLjWLxdwyG8wI6xk9cLt6jivl4UcRW0dR/8Abq/U9WVajSfw/ez5a+HX jDxZ8YmT/hW3g7xXqFo3zLdNbGxtR9XkAB7960vi9+wB8Zfj18OIrS28QeEvAdxeRywXluZbm7l8 hmGY/NhTaSwHzHnjCjjdu+7bf4q6FdWz/wDCPaF431AwKGZY/Dd4oC5A4Jj569B710Fl4u8JSxBt RutQ04kc/b9HvLQA+mZYVFdmHwk8HNVYqUpeav8AgzCtiViIckrJeWh+PXiL/ghB8Z9R8HS6Jpfx U+HkWnyxeQYjpN8reXnoH8snnucZNcHqn/Bth8Yb7w/LpkPxF+G1xa3Fy1wyNLqSIucHG37Lgcjr ya/eTw7pmi+JrZ5PCV/Y6qkTbH+ySrN5bYztYKflOCDg461qJ4DkI/498D0xk13QzjEwbS39Fv8A ccH9n4d9PxP5273/AINhfjZpYb+wNY+Hl+HUBxHr88PmfhJaD+dcX4q/4Nw/2kNJdv7O8IeEr1FJ G+HxNp+Auc/KJGjJ/wCBV/RT8Y/F2k/BTwrc6t43lisrO3XLySHaoOOBn19q/Nj9rX/gq9daiLuw +DCtFCMg3RHJHqAOf5fU134TMcdi5Wha3doxrYLC0I3bevmeR/GXwFc/AB/gVY/tA+B5/Euk+Fvh rbaDr9taanHE1lexyThE3xSYYgPGSQSuM8mvnfxlB4Um8dat4j8Gab9hmjmMdtbXlzLMtuNm0IHY bnxG2M8jJPNZ3jv4+6t491ea88R39xeT8kNK/C8/wjoK+e/jl+07Z6JY3VhpFw13qVwphDI/yQlg Rkt3Iz0HpXv4apUow5ea728t76J6I82ph6c5c3Lb89ravdnlX7T/AIz0tf2m7nXNd0tdV0u4xL5M F4tv9pkXKl96BiDuXJyOce+a1Pj5+2lp/wC0Fo8kN18Obe1uVt1ht7pdVuHNu4YtuMaBUcHJ4YZ5 61yPwv8A2qPEvwr8HRaF4etvDlxZJKZS95pcc87MfWRvmx2Ar6O/Zt+IfiT44+HNS1DxPpmiwqs4 htJYrXy0lIHzjaSchcr3HU15teLv7Rx28z1qOIqezdBTdna66O233dD5/wD2fPAvif4/a8umaHeS xxW0Qa4nmZhHEo4wAAcn0Xiv1E/Z8+MXib9nL4caV4X8GANYaVbiNXubZd0vJJZjHtySWJyefUk1 5V4GjuPCtnJBcW0EUjHpaobeNj7jBBNejzxwWel29w9hdefKo3FztVT9Op/SoxNb28YwnG8Qo0/Z Nyi9T13TP2/fEltAi6npOnXanhipeFvc5O6tey/b2t71FGpaNdQZPWK5WTH0BC14QscNzEVmBJ7H nH0zVG58HwXUkn3Isc8Flx+Pf8q4nhMM942N/b1ltI+mbH9rjwZrLIdUnaOeM5X7VbM2w5/vDcK2 0+OPhTxFK0h1fSJJnP3i6g/k2K+M59GbSiPssxuHPQBiwT6g1n3Fzd2zt9u3IrdXKnn8BSeW0p6x kw+tzW8Ufcm/T/ExaXTZrHDDqkq/mADioW0C0RWNxavcbMBzHMMEnpggGvifTteuYAHsHl3D+NSR +orTs/jPrunjb/aeqQbDxmQuB7fNkVhLLJLRSuV9bT3R+ov7JHhnV9P/AGUbWDSfBumapH4l06O4 sza3cMl3p8UkMQMTwk+YHj2smAMcV4V8Ub67sPi94hi1aHULGe1vhB9mmWaOW3iWJAisI3+XCgfe A69D1PF/DP8AaaudN0W3HgnxbO+lzrvgieVLm2dTzuQSAqQfUGqHi7QvEXxd8Tapq3hXXG+33m26 mEelwXEcZRQgIBBIBAHHbtivLwOGdGahHZKy3udOLr+05qs+ru+2p674K+OeveF7YRaP4l1rS1eY sRHrl3ablVQAP9TyMueCDXQeIf2vfGFtj+zvHXiNOOCPEzN/6FbV4t8PfB97oumTal8U9csxbWcb SSyJp17bhFABdj5VyoboPpWl4ils5WZdP17SI0BON51VyB9DekV6jbhu/wAznilJef8Anqj3P4a/ tP8Aivxb8QtJ0fQvEN5p9/r88bazq4lVpp4bW0UorzBRnLXBGQATsA7V6h+yL8aW8ea349i/aH+I Hi+3l07xC9rpcb38tpbmzWCLaUKbS4LmUliTzxxXyb8NPF+jfCjxXPq+m+JtYnku7gXEttHFEluT t27dskMjEHj77MflFer3n/BQiG3Je1tzvUYUmKADOQQTttBk8dsV49WeJ9tJxjeP+L+mdXsqXIlf XrofNf8AwV/+Ktze6gmiweMfFWq6d/bUsliWv53tZ1jcAMwZ8HCZGSDwPxr8gv22f2hNQ8XeJp/D nhDU5o9H0za935EhAu7jrhmU8hMjA6bs9wK+1/8Agtf/AMFSNZ+Lvj7TfCtzFaXFh4etWljSSMMk TzfeONoBOFH8PA71+ZL3I17R9c1O8jiSWZwwCLtCk9gOlezkOBngqNTnqOTnJys9lfojnzfGQxkq UY01FQio6dfNnceOP2lNU1fw5axSSmzVrdEkWNv3twQoBJPYE15Hf6pcaxeLLcPtCHKqo4X/ABPv Vdy93LvuSWY9zW94D8Car4+1+LTfCNpLeXcx+6o+VB3Zm6Ko9TXu83MtdjyHvobfwa+FGqfGXxza aF4URPOuMvJM+fLtox96RyOw/Mkgd6/QX4WfCy78DaHa6FJ/ZLWmnQLHbpZxydf4ncyE5Zjk8Ack 1yn7OPwR0z4G+EWs40W61i+VXvrsDDO3ZEz0QdvU8mvU7CeV7IrbbUMRBEgbJrjrYj2rstkdlKjy K73Z1Wl6Qmk6VEhXzllQu4f5tmP7pHK+/NTr4i0e5tlhuddsI/MwsaS3qEjjqMt1+prGj1Yx2Fra NcHdO4UNtyzgZZhkcgEDGferNnb2bOFa1t4dpxvSABh7jtWUeV6zv8indbGzd+El0uyWYahiBx8m QV3+6kZB+uao/bblYdrXLyQjuT/9fn8adqulyXirsvpLpFTOyRvmA9h/SqcVrd6XOslrHkHowTK/ QmhO61Y2uxPBFdXCEwQCcjoUJA/GmrA75bWLSTdH/ECGBqeTW44SovbWNJhg8ZHPbBGKu2lyLkJ9 lmli3Nlo2YuvPfgetS6jW4+VGFe+HYrwpNCWhbpnsOe+OapXGnWol2zytluGGCA3511k+m3l26xx vauR0G5QW/M1n634PkXb9veKHcON3JPr/nNT7W27E4+R5j8Lbey+E/hMaB8O7NRpETMzQXMrXEbE 9SWcnGfRcCu5+H/7V3iz4XeOo9S8L6bo7Yg+zmaK6e1ZUyCPlIYOQQMcjNcCttLbRq0IgCkceZyf wFRTxCeSNTDIrdC44z+NeRLXzO9WWx3nxw/4KZ+N7+wurTX/AAhfXNlJBNayXlpZPco6SRtGWIjm LA4b+IHoK+bPCf7eGmeCfDun2fxA8c+N77UreIrNK9tLG0nJA3L5mVYDGc16lqc5mmNv4ZF4ckIv mdZj6KB16HFLJ8IrOa5X/hY1lbahdyEP9kl2kAf7eck/QfnWtOpGEbSjp5E1XUqy5nK78zz5v+Cl nhAKRJrvjG4XPbzlP/odc1rH/BT/AEfSJLl/C9t4o1F5kKqLu5IQN2PLnH5ZPrXqPin4H+E7y9X/ AIonw5EJCQrf2XGFwec8jk471n3XwD+HzzJFaeGPDjyEAZSwTIHrkcZz65raFWk/sswlCp3R8KfE n4t3vxW8Y32qa+dst/KZDucsVHZQT2ArO06a91Gxk0zRobi6NxKHEcCGQsQMdAMmvv27+BHheHUo 00rwboYDbRK/2aFNvqQu3rXQ6f8AD/TvDy+d4QtlTzB923iVPLIJ7AAH0rrhjVHZGEsM3uz4v+Dv 7F/i34l6pD/bdq2gaZn95cXg2yEeiR/eLHtnAr7L+F/w70j4X6FDongmzjtIo2AuJhGDLMwPLvLj LH68DsK3J42t7WK5nto73DkssPEi5Xo4Hvjn61Zh1wf2cJfszIWPIkX5gcdj+XFTKvKtuaQoxpbG 5qOkyXlurqY5oh8schGGXHI3Hv8AWodFsLi3j+a33EN8pPKsCe/4U3w94rZpUNxMowM427s55/H/ APXW7Y6otoxuLEg8EMByM+pH41F2i7kmsXVhpehPc3kYSeAE5xgEdCM9R/8AqqhY6hI0O9V823l4 2EEEenWqWvCdtSiXUSktjvWU/NsIIOQD60yPX1vL75cBSC20nDHn/PNaxZm9TWk1JRHujIZV4YSE sB+IH0qO91e4iVBLPuts8BWOE9wT0rFu7xZNwsjIWPKq/wAwPr9c1DbyyyApdopZkxsHODnit0up nc1o9RgfejzLMgP3ZG5596u6Z4rs9PKR31xGwDcBpcMK5WfU0guRFeqnBGNkQBIz9P1q7pN0GvB9 pnI/uho8Kaiauhp6nXxeMdMutQgl0DTNQurY7luUlV+cDhoz1B+nBGafrPivRYgi6heS2cruVSG4 DJ9AGbr+tYl343/sy622wcSqQRnkNjuO9aFvro1xyL6KKW3lGdmOMj+Hn+dcbXc0ueSx30mqwI14 CsKDcWRfvD65/wA4q/pei6j4vmKaIkrW0JUyyupMcWeCCepJ7Dk8UUV585WudUdTc1zxRpvww0OO HwjaxarqcrNBJqDj5YSApZUU8kgHtxk9TUXhTR7fxEY7+K+iBkyZAxPmKwGTyxyOnGc0UVbilG4u Zt2G+K4Vs7yGESArH9xhk9yMn1qra+FdPv3hnu5rtRuzuhkYh8ZwDg9M/wAqKKpbIh6F+fV9Mt9M mt9KmljMH3hIgJLY56fjWHpWvR6pfqtzieDBjYK5AYHjnuD06UUV08qRCkzoo/BBiltU0qb/AEac 7gwcqYh12sD+PNVviFpM2rSxGWN7W4tV2eUTtz7+46c0UVUW01YHqZ+gWk8qq6rGGiGS3mL8w7/M PpVq91SaG6hS7jEEczqqbiPn55+vQ9RRRW97szasjauit4rOd4AmICRL1GOuc9j6f/WrP0Z4bi8V WV3IZo1LAAMe4JP+PU0UVMXZg3dE2r6e9qmLeLHIywYAg+oPQ1m6o9xopWVd0sjkbQP4D7j9aKK0 hJvQzYyIprFyst1xNGCGGe9O1XUFsv3cKlVVc5J6f0ooouPzFsb77XChlZDkElnBZQR0B+tdBouu IkAEnlhyR908AdOh570UVhU2ZR//2QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD/2wCEAAEBAQEBAQEBAQEBAQEBAgQC AgICAgQDAwIEBQUGBgUFBQUGBwkHBgYIBgUFCAoICAkJCgoKBgcLDAsKDAkKCgkBAQEBAgICBAIC BAkGBQYJCQkJCQkJCQkJCQkJCQkJCQkJCQkJCQkJCQkJCQkJCQkJCQkJCQkJCQkJCQkJCQkJCf/d AAQAzP/AABEICZAMwAMBIgACEQEDEQH/xAGiAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgsQ AAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYX GBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqS k5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz 9PX29/j5+gEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEQACAQIEBAMEBwUEBAABAncAAQID EQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RF RkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqy s7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/ AP5+fiP4q0fR/Dmp+G73T7dbmZVdpy53MA24bF7HjGef4uK+N9M8YXelzPZaQJEupZCNr/N1/wA/ yr0Qx3/xR1uF3uEubjbkJuwzEd8+w/TpX1h8R/2XfDvw7/Z80L4lm1u7nx2zRzzq+BGwZgoAxg46 85I6Dmv2zjPifn5ISVrnnZBlUaUZTctEfPfgCw8UHxBpmpzaf9rfUZUggJHVycDA9uM+oziv0puL Pxzd+FbjSh4it0S0gZnggjUBZBwMuQME4z6ZA7V+bum/GG/8K6xoV8vh4R/8I9Iri32/KwxjqMfM fXivRbvxv8dvirH4g1/Qo9X8K2NvC5k06KFxCY16EjbzkH0wP1rv4M4fp1KjrVZaI8LizN8Y4qhh 4+71uVL7V9N0Sw0/xVqNxJdTrIUnijUF1A4CkZxk9MAnmu58MfB6++M+pWniHxvY3Fl8PmkBs4FO yWdUA+9k/MDx2wee1cl8GfA2meIdG0DVNV1SLVJtUkf7VBcDMkJUnIUHOTnp2wcg1+j/AIf03w5o drcRW1z5uowwIIocOUBPUgkYHTkdsCv1jK8uUqm+h8Zm+bOjTUUveGeE9B0zwxoVnoen2wstOjds hTksSxJYk+pOfx5712P2GJU1AMkiSzKFDdQvpn/PpXJ2HiKTU7q5hawNne6a+GjOGEnoB2Jx2PHN djcm6u7k2siuYIYgxEfUA9z+lfqWX4eEIKMFY/G81r1a9Rus7shkaO2tJre1heS8kGJG6qfQY7V8 Y/tU6rNoul23iC7MT2V1E2nxTgBJLcny1IP94fMce+OvNfckcCfYkjik/wBKc4+lfm7+3Lrctzef Dz4fNNFZ219KdTkkK/Nn/VDkEYB2tx7E8munGaUZehpw/JQxkJPoz2jwt+z5oMHgS2k1+zkg1i3t ftMV1ZMVlKOd2VIJDfeZs4zzjNfSvgi3vfg58DtTn0XxVNrVt8QVOg6P56eYYHZSGLH2QMAQf4QM DqeR8C2Nzp/hfwrpEd4Li3SxhWB3kZvMDIG+b0Az6+3GOet+IHhOPwHr3hjwb4eF3J4bj09dWlhn uC3kyyA7mjzzknYT0GD19fy7OoTjSjRT+Jn6zlmJhKdWt0R5YviPU/B0ennWPDF7JCmFlvLJN6Rs STuZevPJ5IGSea9Ni8Sx+IWW70kx30M8SDbEdxK4yDkdK2QHmvILFTFBJbRiQI38eR19889e1eS6 38JtPXXB4h8PnVdD1K6xFJ9ikaPcVOcIBxyT908c98mv0HJ8I6FCNPsj8nxVSNWpKSejPbr7Rp7n wZ4p1+/voIdJs9KnE9u0Zd3j2ENjHcg4HrX5HfDiA6/8SPtniyGDVPCukzsvl7WWKJxkxoTnru24 HfHuM/oJD448XeHrPWrW81N/Emj+HbljbrKV2vKM7Y2YDLYJxg9vSvBNB8IeBvCXhDxr4oh1S9tP EkLPeSRzEvCk7fMUaLquSSB7Y681+X55mtSeLnzLbY/Y+H8LSwuGjFK6lufdsGreE/A3hOPW/EZk msfFFj/oaxcS3BdSEYHuMn6Hpmvln4deD/DVro/iDU/FAfxRqsrNcfZFtjmEOfkIyQDgBhj6Vwfw T8c698VfEerWvi23nvbG0hEFrfyrts7dVwuwKOr8jHAwAa9z8RfCA6xYXlhY+K/GGhNZKWWWyvRE ZWJO3ZhcnbgZDdRjnvXh5bluPx9Z1K70PRrZjgMti6dLS+pj6fJ4ctvFNrJo3w6uJba9YQXl99qC i1BX+JW4IAJOBzgn1rxP9pW0uLTStQv7gWzRzbYba1gH726z0ZR3HHPc819Z+E9BGiaLaW2pXw1M 6HF5kplGzzXJyxbrgE9ck9OtfG3huWy+Inxl1vxp4muLjVPBfg8E2FpG+xbp1fGBnoCSenUBRxk1 7WM4Po0YutUeqOLBca18RXjQoq0Tufgx+z/o3hvw7pvinxret/b2oSRyG3L7EQAgqMg8nnGMgDBz nv8AW0Wn2ltNHO6R20KD5VUYO08n8T1ya57Rpbi8thqWtWD2c8brKY5APlTHygAcDiu3njk2l4ra ZopkBUP0U9c/T0HuK+h4OyGUP9oqLfY8jxE4ujUthqL+HcNPVIJFhB8hdxZDjOSaoCU2946WYkkt LhzyeD7ke2elWklkkhB2By/yHb1wPT/PrTZbaJpT5zmATYWSYniMeoHY/Tmv0ylTSPx/67Ke4554 /PmRlNu2wMu8/e9xUdpCftErWLCOfUcJMW/uLyOPrnkVahlsJ/MtxiSW0GUz/ET1A9/r6GrM5ZrR pZIRvxiNlGBkdj/nvW/KEqmhU1COOWDzI45N87Y445HH51k6g0k8Ai+0kxrHiRgOIx7+1aUqSGGY TSEmVcKvTaans7N44greZHNj5u+cen860jOyscFWjzvUoRxCTN1h7izt4wgdemR1/SpYrWS+SylZ d1qku0KnWX29q1ROo2WiCONphtIA4Q+p9fwql5kloZHkDyMi9PT/AOvUSd9RKmo+6iORbe5Di8Ek FxbNvgY9HI42474FPjtI0l3tKUaSPaxP8GP/AK9aqz6bfjzUglnuNmD6Lj/PSs6BdisTufklA33h /jVwZ1NaFG704XDPLCzRpZgO7no3b8K3Lby7WCZGL/aGUPGVwRUbxTLbzTpIEYJj5h8vsT7VRut1 5IlvFm3uVUct0f2GOp69a0cuZakUoqm7xVilcxedCP7RlMU4b5+Mbgfp0qS7t7pUtI3IjhiOYwwz x3PvVqWdkkeFY8rDHu8wgAL2579e9XX+z3MduZIrlWZQMA4Gfr2FbRegN33MqWzeDD2KTHZiSZX5 OD39hVrz7K7mUjzEMYCMyn7o9/8APeppIvKtECuF89zEuTyx9M1mXFtaG5WxWOb7TgEMT8rexH51 Ddzjr1eR2RYEPmXyMltIJQNsbjkY7HHeplnuoh5MJEiTZRBj7p7n3qa2WQxS2sis1wpwq/xAH0Hv 2pYxCsMEcchdraXIXOWY+mfanKStZGq7srfZSFu2AxPtAwB1FWrZbUlopJJGaFRIwzyvoDjtTLNv OlmjvsogYybk6knrn29q0bi1sbSxnv4EYu45cPnGOP8AGsJ9jam7OzGR6hLdzT3WGie3XazAfKwH p6HvWD9msZLyZpo7ieKYbUWM8hz/AD78VofvY44JoWl8m6UAqpwSPWmSwCVxLBCWtoxkbf73cfWt qUeXVHPi586s0WGkt44SvlSyrARhFIye1LaOszfZomRV3/NGRyfXmqCfZJd2YJ4baHLOzNkqe/1H oPcVbs5IJYzc3aS4l/dqm7DHHf0FZ+xJhEZeyfZ4J7YW9xeRI/yGMYIY/wCf1p39nzSoInRrqDAX bGPuH3961kSWGBILOE3oDFgpYAn8TVTT2uI1lAZohI+RuHBPcY64pt2OyxBYabHNqmm3F2qXVrbS BpYzkBlXs2O39apJpdnosOoxvJdXEd/H5bSEj95znC+mO34cmtSa4aeWOW2jkgTO2QnGB+X+eRUV 82ltB4eM16EvL25nX7EZBuuEjxyO55JJ9OOma8PMnKM4VVsj2coqRlTnQa1fUSwsXhRpQhMs6/eT 0HSmXNsZxCFLL9jfcBjhiexqeNfOuGufLnhkRR9nEb/f9APVvr1yPSq11FdSzrZwRywwYBlOTuP4 9q+gjU0PnX7uhZUu13BCUyksYcd9p/iBPSqsti81217MPLtR8g29D75rQv3kW9s9PFuQ11EXWIpn 7SuOQPXOOnsagtpI7l5JEcS2jjy8E7gD/jWUK6k7RZu6El8SLnhuMQ6hp7XEx+zwyk7lXH6e1dV4 m1e08R+I/E2oeHLsrYwTosiSp+/gYLiRSPTeG2t3Ga4m7ktLMsLm3vre0bCGQOV3H0BHQ/TnkV0O oWEFnr41bS3Hla9bRmYoh/ePEm3IzwMBRkeuc9c18hxFSl9ZpVWfbcM4mKwtWj87GPeLmSGAxyT3 MY3+UeDFnufwqz5E8mLaCeOaB1AnBGDj2/Gsm5d7m6KuDaSjlSSTu+p71buEg2I5a6NpcfL5yNgA jqv1/wAa+wpU9D4/21k+XZlFo5JlhmS7glt0k2gYIPHr7Us0EF35l8UmeO0+XYvB64znsKmiglER 8pDcFzsQqAPm+nepJIsLNAY3ka6Xb5aHbsPq3sfaumNOyPC9hqSHTLL/AEOTOy9mj37c8qv8LEdM ZzWtfTyW+naVdzWlyts0kkCXOz92kiYO0tnjIbIzx24OM2YPDupN4eg1qe2JuYiyZU8+WDgBvbJH 51B4g8T2F1e+EvA6mUNJE0kNzHgJ5jYDI3PUYzk5Ffnuc5pUnJ0t0j9UyHJqMFGqtL9Dd1x5bDxh 4bu1u5TBdaelzGrMAsjEsGJXg84AIzj5PetH4iXF7rFhpmi+I1tbjVTNkQBGQeS8YK7mB5yAMjIw B0rM8Trpt23h6ayvBfatounvZEI+TAm7cuc4ySSx59RzxXWeJNO0jUolENk41bRvD8OpTsxJClZG jGSeQCpUnnqw56V+TZypOrTqt7SX9fgfqWWaU6lKK3R5FJZy2cUjzWlzG+AqjIwvofx/wqPUtNub rw3YzGGbT0sdVWSQfKwYhXGwj1O7OMj36EHq9TlXWrkWF/qEMFnHGqwSMdqRnHRiPx6+gqnqWuaJ 4V8J6vq2uyQ6glo8HliN8GNzIFVuO5Bx+Yr9E4izaM8A+Zan5zkGQzpZnGVP4fyPONLjuItFfSYp C01vdTIwbLSIC+VznGSAQB3wM+9dZPYSBrayFxnS+MkcszYyR7YrQmtVu/FJtzAscMN6wLoNkW/G WHqMZ59itUr036OzrlBeyMT8oDQ/MSSR2PfivQ4VzqboU6S6mfFuSJYipWnq0Znjbwze3fw68R67 YarHp8OkOsdxOEGWjJKlTnPyhmXOOe9Y3iNp9W0TwrobaXHqOm6xq2FbZ8llHHubJbsSqkA9s+vF eyeMvC1pH4H8N+HftE9xqXiOd71wjgBY1XEe/nuXb8hXmeparaavpHgvTtN+yahb2W+7vBbhlecE KFG48clcYBOM4PWvksXmEZZhLS92fZYXAyjl8Yp2srlqWybUIPNiKt85Cuen1PsaV4wv2e1sUdGg IN1k7igJ+8R7npViS0lgjhjmuTCjIJHXp5YP+cVpRlHiBW0EbX527s43Aevt1/Ov2vCy/dxPw6re VWT7nIeJPDgur3wjrlnqMVtFa3FzHOwyDcI8RQxg9M7ghP8AuivSFht/D+g6dHdR3LS3Ad1Q8FlH T/DNY19FoNvY6be6tN/Y1pp9wykEnFxuBYkEcDBUEk46gd6xN2q317LrM93LcWN8BHaQli+xFzjL fT8OB9a+HrzdbESot6XP0ihQhhsJHFRj71v6/E9N+Hmjy+INe0Czk8y0k1y6FtaHaSdx4YjH3iBn 8q4FdKj0nV/FcejyvqOgrr1yiHqdsZ8vhj2+TA+gr1f4QTvb/FX4e6nJeXl7pttFKbe1ik2xpIrK GZvcjIzn+HHFeOaHcPLbPfNJd+Tql5NI4aNlUSByHdQemQAT65z3ryMJjvaZwqCekT0MZQ9nksqs t5C2hia4W6hnXchMbMDnv/OrN67xTT3BVp7iRRhxwuB2I9aqQQQCS5nZHaSPJV84Vs9sZxn3q1ct s2RuyzsFBUJ1jJ9R/npX69FH4yqknucX49j1+48EahBoWv8A9krbXUMs0IjV3ulZsqAD33KpUdyM V0lzFfLaSTXRDyWJLqI1xsJPIbNdTHol9qHh7xfpdrMsc2rWAEOQQY3DA7tw+7gc59u9Z+r2zOJn tN9xLO+FUfeXnjvzXg4bEuONlFH2OLoWy6FRPVfrcfJZtYGBYY5GFyobaP4sjNVYkgMLOsLy3sj7 SA3y4rUjtp5ES185YvLXJdh29R6fWpLzT9ts9q0xSZF+XAAwT6+te9c+bldoxLbWtR0ybUP7Vhea KPLMqx/MqjnA98VYsdU0nVdHa/RZ5/t3zYyAAv1H5ZH61BYB7B7ee7y/kS4MajLS4PQc9a6HU7GO 11/xBZ/2NcwRJsExThLdiMk7f9oFTx79cV89mdVwxNNLqexkdNrDVH1RzzNFsma2uBOyLnBH3R7+ 2an0y+S5utLW4EzLPKI8xHDD1x69OPwqvHYxyXYt4oRPa8iV84Yf4enfrWhpjKrCOKZjfWbY2BNp yTx09697FuLoyT7HzmBhJV4yXc9A+J2o/wBtfEfVZRAXGn2FtZi4BxsHlIzBh35wfqa82kt45DNE qFZEHyJnkNnua2vHFveQfEfVfEFldy3cNnptvZzxDHlq7xRls56sCqjPOMEVlQWpYMJFcfaCCZD0 j+n4V8lwfFKjJ+Z9dxir1oryHWztapbrLGNtu5beXwGz2/z70/xPD4wu10HUtLjmuvDl3I0UtuYk P2eUZBO7PA27CRnkdgQc15Ld1e8jkLzPCnmJtHBH09fyrto4bxPhXoGpG6gSzutedJmbJCxqrbQO cbt3U+9Pi5xjThV6pnTwRGTqVKeyaOD0+zt7pFmjZ1EEjLMMZ5XqPYjvWq12Z/s0EssYdX2pnuMV DHukee8gSaJCdnl4+/jvWn5MEcjyIsZu7VRKxAyCPTHr619PRleKbPkMRG1SUImNIwtrkwNDJbtu ywY/fB7j69q7DyNUufAN9HbT+Rp2r3SCYKBiVonDJyTxggfiB9Ky1MepXcrXKJIkigLuGOfb0ro9 NthqPhDXLC1jmSTRz56xhhlwzbeOe+Seo6V4fE8n7BJdWfQcLS/f2MQRagPDU9jpkjjSbacXbwAk kyg4Rg3UHcx6kCuV1C8niitlaMywSEgunTf3H8uO2a7SeF28HXDWqzwWd7ILOQgFgxOcAntkj1Fc e1jFZxQNeSyLcQLgwk/dPqT6frXmcJ6VZ27Hq8WxfsYPzOr0jRI76T7He6nEtpcBVkiC/vBnuD2H 4Hoa5+U22pXLBZhbW0A272+7KV7flgk9Oa6HQUu7mSUwRJHezQSLDuPDbkI59Ov61y+kJ9kgjWaO aZcCcqTuKE8lfbk8fhXoxpt5nzXOKpNf2Vytf1czm06znuEF5aTMofAAfBPuKtRLPG8yHImk47YU fwmtGJEkP2q4cQQhvmlk4C47Y78f/Xoe0Ed1eSoLl57kDau7n6/iOlfbxqX0Pzv2NhyOlzEmn3LK 13a8tcDhWB6cegFV7Vo7OeRLiGTMvyjnAwPSpNwhhPkAyKW+ZhyGPUj60rxlobUSSKjh9yFvmUj8 O3rWc0dKkyO7sNKtJHxJLHeLH5q8Fl+mP89KpSxxXP2a+uZBFEoA8sdZD7Ht/wDWrVE9ycsIZ5XX 5igxuA9fSqSzfZnSCGOG6WdsAlchO/INXFWIkx0Wn2dy07zrO0qHCqvGfTP64+lSyRTzafGkIeTz 2O0Y5AHX6mr8lrDB59pK0qrdqF2g42nr171Vjmh06FrCKC6uYtvmNOpOFJ9+1QpO5k4GTp9ztNyI HEczIVYAZaXHRQPWpvtjSWtuwgZN7Mdv/PTHYeh9a2bK22QyXcEcfmNwMr0qzdoyWRKp89yQfLON zHtg9hVJ6hZxRzs8MAiguov3dy7bdpU7c4+916eopftFx5UapZt5RO52PzFgOm0D/JBq5drDAbeC W2mimuDtPORJ9PSorGxvXjnv4gJfIGEiV8E+4HrXZCZwyp63EMCTG31SQGa/jOW2jBU+w6cc8Vfk zPd26SuZYoBneBjrUCXzyPbQSWwiLEb5E4JHsPatO804qivArwwycuXbP/6s1yVpbHfQ+KxT1Ca2 tPL+yWzyzPzGc5BP0qrbWD39k1vPN9me6JCxt1J9sf547VeuJbfT2haCM3FvIoIJOW3fxY9qmWGS 1uZI2I3XCCVQ3O7d2HpxU00bztexmeRdXc8AimgK2reW2R9zHf39Mda0J7qTyJHvbSVvLGGdTxj/ AD/MVnQ38CTXC3MckbxvxgnCdsn61uLbhgZj5s9yw4jU4C++PSlKA4bGbcrbrAiMs1jsGVEgOQT3 PsfzqvatixM9y4Ednkk5ADH0zV6+tftl00czS+bGgaRycrtxwPwH9KS30pPsq3EsyiAscSH7q47k elVGNtDmrUncgENwiGSADyfvFvc9fy9KsxwRrbwyMsjW2/Luo4JPp6HNVIgHHnW8rXsROCqcCPHq OnNbEL3elWgZLcXFrITu2D5XJ5xk96bOZU+5nrpct9dQOY3ymULHoF9/p/WsvyIJb3y7pJAufkcH 5Ux6+v4VoQM8VsZBezOskm3ylb5x7A+v+FW5LeKaRAodbZxiLnkn+L6kf5zWkZvqaqkmtBtldTKd 7jyrZ22RSuRtJHfjoMGnRK9x58Nr5t4jyFBKFwg9fc81V+xfZZ5YpfnWz+cMpJBzzyD29qe6TxmO RC772wfLO1XUdh789fpUs0p+67DbWVorWb7Q0YmdirEdGA6D2NOMiKgt/JnQXwUAnoPce5NT+ZFd 3izL5fk42lSvII65/wA+tPmIdnkaBXaE7YkB/wBVnjcfr29KR28zHRQbZFiSUeaDvTK/6pvU+3as x4Ea7hM0LKsLbk3HhT6n1zmnRZF0trPPLAt0cSSHqo/2fcVPCkboYbYFjByN/RgD1565qlKxw1Ox KkCRly9xH9n2nzt/Hy9x7fWsgWsVtdC4EcxhnTYF7lQe3+NahtvNkaKSCdrlQGAA6D6d80SXP2eP Mkwgt34jUj/XeoH0659q1hM56qvGxlG8jVlitreZ9pIkJBzj2H9anNzJGI/PPX5d56KB/UVowGKG 3W8DJOpfCgDOT6Y7n2qusTxHZOpaK6Y+U45Vcc9T39aomEGynLFaySw39vKrXSt/B0Yjpj365/Gt OK9v1nlDhlmuV2NheCP6H/GrP+j2am4t7FWvFwRj7rYxjjpVd7eREnNzOBc3K4ABPAPORQo30LjF rYrXcyXfl2wdFtoX3y/NwCOmSOnNathcyzWdyPOigjt8/vG+6fr6f/WqrceXK1rbiEFhGMpj/XD3 +tMjidp0d7e4jiUlAvHz49P61UqS6G0JtPcW4L6tFaHB5cDb3YDtW1KzQWzPDLEs0WA+/kKtUZpY HgCnOyHncnG0e/402GwtGsVuGnkf7S5+Xd970A981hKBvfUsXUiXVrbrNMsptG83Kcbfr/jVLNys rhpEjW4OAmOi9s/57VZGwWhR42Docnb1HsaVpbWWNpVfdFD8jvj/AFZ9Pc5opq2hv7a+5HHbW6K0 S3Cxs2TuIOM98+gqnpyrLKYE3TurliwGF/Aevap5WhiMTlJZLeEksueR7n2z2qad5GgNxHiNnXGF XaMHoR+FdV7on2tgN3MIxcDyBDDIRsb75x3z0Gc8fjVA2PnXUpe2mDxx7lBOCxPI/Ajp9agtoroW 9xi0uJAx9eVPt71tQWV4itM7v8w2hum3/wCuKzlGxyTxcp6NaDYtMeWTz1ntRd7QfL/u46ZH5/rV Vra986JYALtpnwyDA3UlpFdW9+zahBKzxPmDy2+Zge/uCKvTl2gmu45IxdjIynAFZ76BTjoST3Nl Zahh4ZCsK/ISw4fGCKRp0bP75JCR91eNx9B71lSxQW9wEdbia1uVy0R5kz169vrWlBbGLcmDHPLw Fem6fUvl1KlylzPApNtOiB9ryAZCD39P/rir0zwTiNLdWdsbHbPEeO59v8RV22l82O9hCuvkDnI+ Vz/+ush4NqM7pPGrNjaXwWI/u+n+GKSj0NadTl1K7WMxjdrpxCFbBx2x1PsMVYltLGa3F0HX7Uo8 tcdWA7D361Iskai9gaOZmkjG0MeD/n/CrU5c20f2SJZzcoI1ZQAVI7gd+fTmt6nNbQ51Tg375m/Y 8PaW17Z3NwtxkIqMFZvUD1NWfDAlitWt7hj51nPJA+4YBCnA/PGfyqOQalKxfUCiJb7TnoSM8bT2 NR6IYkN8fs91DGkrFFeTfnJJxnv1r+bfpFXWApp9X+jP2vwWcVialjpr+aePTNYkiRwq27EuoHzg DJH0x/MV+V/7Fmm26/FT4pW+nKLWS9tTawyTtuzGJX3KoHoQpGfVfWv1cES3OmaxZh0RZ7NkBkGV 6fMDjnBHH41+Un7F6+b8TvilAUu9QuxF9kj8oAHKXP8ArAvPBOB/wMV+SeBcP+FKx+p+I8/9hZ+l 6TGNbW1iV/K3fvpD04HA9v8A9VJ5k5Lr9klR5Aeg++B0x70+3RLry47pmRLVuQrYznucdqveQ+FY 3cMlszbVcKc4B/oOO9f3Iqfc/kCO+hA2oQXRkSYvaWkShthPCsBgn8azZruWWRbEwuZJ1Aif+HB5 B9+OfpV+dVty5nEU1u6lASOG9QR9KZ5uMSPG8iKMMyjIjX1PtWiSRlWqPZsiNlci4he4gkjgh456 ScdR9TjFPnsv7VWePJR7cBmXqSM1oF7aQukk0jwou/rx+fb/APVVY2ZjTaGeEtyGPY+/r9KvnZrC OhUadbKGJIA3+lMY2J5246n/AD61bvPNSK3hs498l0f3eeQ2R1+n+IqCVI7e2WONQVc4JkPQg8nP pn0rSsPJtPMmuJMJLx8xzs/wAFNy0HGD5jPtrs6XPcMVdXZBjgcnvii2aa2leR4zJdznO7oqL2Yj v/8AXq1GrCWN5kjE074jaThf9kf/AF+9QQfbYYHkkc/aIpMbiODg8Cr3QqkNyOWGQXdisqtLPby7 1bHyt36dxinorSzyC2mV/tGfMz90c859OanLz26st7btNJPw8inCAHkD61BL5kV0ZokZNLwCy4wS B1/X14pnP7MWNQbeBnUrOZDhFPBb1pwskWBJCJbp5W+cRnHGeP8A69LZlZZoLUIULvwH6gGrctrc I88QuQkEh2pInAUj1NB209iRrm/a6jYQbhbnadwwWPoB69Kzo3Mt693NbfaHdiiqpxsPr78dverl ws6IYZHVbiRBnnG/jt6U2xVYX8mSU3Zk+8E4/Ae471HJoOeLls2ZVyszfvGEktvAcMQOg9M9qksf tMfnXRj3lRsRSvT8PWrqMZUhhQ5jBJ3dAw9D60LZ2ht7pnuZRcQtkRk9vX6da2pO2hzSim7hpkkM FmqyO32iWUkPjOzPqO4qSa2tYZpLYvkA75PnyWz3HoPaqdm0LWsEUcMnkxyMd5POT1z/AJ9KsTQC KC9tZrL7Szp5agdZQe2fU9u9T1udaacFFlaK0SK5vod3mR3UeFTOCfetQWkNtbND9oSa4lADJjhV 7f8A66LaN9kKsrMygKFP3mx0UN64qsokluDHaNHMs7bSw/x9BQzOnyoo3Pm+S9lY28sEaJhnJB6n n6e31FXF8lray07esPkPwcfeHp6k1YnhgW62xM8j4xyeoqsbq3tr1pFRljKgbmAIHPI+tVyERepP cXlwCGjtZnubUgxv0Udhn1/+uKW5uku3RbkszwDc+3pz1q1e4WORHkDxbcjsAPrWOtnJK0UkPmBI iVY56H/P8xWfIjeviZWsbMaPYzW0iSJJeAg/LyVU/dOP85rOltvOuZJm3NNcuctjv3BqXyEtmDS7 5WlG0jOCauW8W63jChmdCcknG3Hr7VPLrdHLUg2rMoB49PkeNY3Mt4u0JnmT2HpSrPKbd2jBjtYS C6EZLe2frirbW7So/kq6zSHClhkg+31rKhtftORBJJFKG2yBuVY+3vVqJkuZWSLkERjW4u4ZFhuJ SBISM4Xt+NRyWMJu3mupHmnTjptJ9/pWgypFBFDctKoLYUqcEcevpVR9tikduI5wrnazu25m9gTz mg2q01KNmPktfscyt9mne3uccE8j8ew9PqKzH06W8nubmyd7a0c+W+/7yEdc+2cVoTWk1jc2V9Lq Dmzc4MPdiPc9Bg9OlJHH5m9rgvbIrfK/IVvQflVwdjl9jZldZ75pRBbukjWyAgbOWI4OB607Zb26 sLVXY3LEtk5we+Px7VZtrgx3sksURZrUdv8AlqPapItOaa8kuZp2e0n9Oo/HtjitY1OxfIzBa0ea 7hh1VG+xMAY3HAHvn6VtTQW2ouD5EjwWuCGBwJAOMf59RT9siXTWU5G2FcocdQauXEUenzW1tZtP EXXzN38H/wBf3/CrlVl0NadKOrZHbWSW1zG4GZHPyse/tS3PlNM8080dss37uQAZ89f7vsfcVl7b xZTHNBLNd3HCtGSMjPT/AD61pXVtc3Nvcea4yigYIwcj0x3rjqxbd2bQxUYrliisrIlimnB9lqWJ GfvJnv71HezTQyW6usn2d02QE/d46/8A6/pV5YrJIvtDkvcuAqrjg47fWopIhGrSiGXEg5DHJ45w Kqmuh0Td4XQ6zuZYYZPtFtKttcLtL4wPap7K1kthPc5Mix/OYcfMB60Bpj5UUQMlrMd0hXOAcdPY 9Paq9q2omd3MEqxTHa8SnkAHjHv/AI0jBLoyMWk7FmEct3DO+d8YHyAnvn06H3pxgGUMqGOC2BYj OcnpnPatWK6XDTRxGIP8hjzgDHr/AJz0qlOrgKwhkmDuGaQn5YueOP8AOaBSpq10Upbu1QJIDsRW AIY8kY6j0/GowI38t5oXuFSQ7QhwR/n+talzZx39zLfboxG6CORwvCj2Hr9KgfT7Z7VPKZoIXkID AnLkDt9f8a0i0jCpFuRT8uO6mt7iRJWa0cle20EY/Kr1mLsy3vmyRLBOoAwOvt9cVFLhTGqy/ZYY yFDHn5vT/PrWhbyJM9wl2RAsKD5wMKc+nvTczooxMtPkeFyFaG2bOM4Leo+tI00rXc11CrGFV2ZI 4b2HvWp9ieYzRyxGVLbDM0fU/T0/+vSbbV7RhapIEb5WG7JUjoQexP51MXYdSn2MwRiJ4YricSbc hgRyR6fWpEs7tpZPsomtboja3mjIQdjj16VNZ2pVy5E0uzhe5jx3J71f86eGaSNk89doPynHWqdS 2xFCmupSNiIVSO13pahttxIxzn1Hsff3FUy0sqLFFp88ENqSRux8w6Z/rW0bN7KeeaOY3CXQ3L6P 7D0x60kqzXUkcC7UAQMYv4yD6egpe07nV7GK2M43U2yOOOHyrqFAyO33QD03eoqEX7r5guIJiX4B Tord+tb8VvbS2yiCCUw5KsCclx/snsayktFiaSSRglrcfISxOFx61m5K9jjk9R8TW2n21wzndK3z HFWLi2mVHuYpHJYAhSOVFRzBvsrj7MXRRgnjlex/Hj86ssJ7jzoI5JHkKL93HTHAHvUxjY6oT91o xykq+ZcI3lwqMPxy34/lW756PBDP5vlRwNyD0IA9f89qzb54ILSO3S3kmtvuyFG3NGe7cn16j3qK 3aG9tZfstvclkwoyeJGHp/nuKKibOWMraEU0TTzupAgVv9UCM7iaYI4bS6hidvllOwhTkgfX1rSg W7ZJ45YPMYxhd0Z4U98dwR0qlawNcRzTJbTS2afKXDdDnByauDtoKcLskETT3c8ETq0Nqu9CRj5v 60ye34+03kbSzINpCHHHYY9a2LuLS7azjnjN0UxzhuSfTPaqNpbNdLZQlzBcs/zDP3B2P9e9Dncr 2XI9dSzbQgIkKwzRRqCrM3Yeo9/8aqBuZIZHM8KnhsY2/X27VcVCI7vTpbh0eLLCQngE8ZqJYBHb OtpHJLfRjLgnqPp2zSsdFTVIpR2btIyJG8ijBxjnr0/wq0tpa27P5YZ9wPmYbCtnqPbn9ah+eUgR Stb+WCzZPPNS28DSJNH9piBXjaRwff8AxrSaMI6OxbS2kS2hbaVR8kjIy49P61Ze28mdpVLPCiAj PRT/AJ/pVVIzEir5jlUO9gT8y5/pVa508yu04muUDDHll8bO3P1J4/CuRxNJ1SOXY08glnSKeVA3 I5I7YFQTWklrbS3cwBZ1ACY656Z+tWTYrFcFlbEa43b8tv8Ap6c/pVsWovlnM6XLwqMw7HC7z7ev /wCquiMmlY43T5pXM2ViDYySoS1q2eeDyPT6VIYcSu0qsGgwy8c4Pf8AKtSYxRKI0hSeKdQCR94Y 7Z/z1p91aE2wmt5hGu0ZZ84X1H1pcx1wpGVbWNi7IzwXO5zsUF+Hx6CkvLWDTZoZ4XLRyttdQens T/nmtOXURCTHaxpJFbr26qfWqUse55ncLJGR5gA53A9T9KSv1NJQSWhLcbvsKS28bz3SN+6weh/2 vUf1xS2ourKymkuASkHzOOmSfU+n/wBaqqKkSxpFuCRHIXPLcetXo7qwZoLSS9SC8kYmJW6OcHt0 9aU0THfUrwXolgmV4ZJEclSy8Y9vwqW1vRasszp5XnHYXY/LgdKWeK4tlWNgvm3TeWCBgE+w9cVb niJFvHJsW3hO/p0/Ht/+usrFy6ozVttQtpma4ZdkhLLxgMCf6cU9o7WBwbhjIH52x9V9/pUrGS5e FA7Szb9oTnp2oltJoitvMC6bvowz/StYbHJLcypbWG4tZgBhYmLo3bcf/rVYSxtba1tY4LqT51+Y Hrn296v3GnQBZreNpRNIoAQPzjPX6dffiq0yI18JoY9tpb4XBOcY/i9K19o7WQewi3doqJpklnHZ TI8iyiQu+QPlGOD/AJ9qtQRW7XVzdKwxbKJHX2PG4fU5q3qaLbRRtcSPctdHlUO3avb6fWq9tbWg SWa7ka2mxtVyflYdgRUe0voa8ltipZ2EKT3M0UL+VP8AOW3fKOc81alnlY2yWSnZLJhmPbinPc2b GC1t3Zrm6O3ap6Ed/wAavLabZ4bgu3lxdVXu3oR2HSlfWwRknsU7Zp47hdwMiTMV2p3P1qFJ5rs3 MkqrE0IOXIwowcCrM0dzBfNKbqO4jdclcbTj1HoORzUCuLm3vo493lxpkvnHOelLlREpIkEEJSK4 mSR4D8zYPKmqsmifaZTeq5m+XC8cMO6kevvVsRfaXhw8kcKxgO38KH/P9KW1a4tpDBAS8kvCjPEl O9tifq6lpIgnhnjghVYiXP8AyzyM4Hf6e/vU1taz+ZFMkbR3UH3XIzj2I7//AF60Xs4llijt1mgm IJzndye1U7OF1Jt8yGZJCXYscc+o/GkqnU6o0lF6Fe0gljuZorxd9xGNzSqMDnpkf561YuVgW3jj LtLcTuVMY4PPTHvVvbHI8bXHmrLM/lhMcnFU91vtkR7a4uERyomiIyhHb3I9PenGVzSTSHeTeRst vcyYikjBYAdV7Ae/vVa90mK5jEVuSAeD5hPzD04pED/ZDfbJJEibEsjNzt9vT/69TS3tlIokjMkE xXPlhuWHt2Hr/Or5XuZSqaWKcOnyRzyW8zMIrZQ7H1+lOhg+x3DT2sDXFtIds0YOCV/wzitUfZ3S P7JMz9WYljjn1+n6VSntXiurUIZD55/eoG5X/P41k23dBGilZpF1XW88prtGgEJKxg8Ffr68VXnU XM9zPGrgooVUIyWI6mr+JpnaHyzBHjO9xwB7fj3p0EEsUrSGMK+3hieBjufUVg9FobyvfUzTFLuZ yjGHbsPoT/WjUwGZEDD5UBVT0z61c3G7s5R5zdWGM4P5+1OiiWXRomdPKwT5hcZJx2zUxn3JUWyl bPCFuLiJikwQeb3DAenpS2IBt72QB/8ASfkVAOSc/wD16uwWKTWzuP3Uqclehx2NVWtktrqzkWaR th3SdlA/zmrTTJnSlFXZSc4naVonijjA3ZP3cdc/j/Or1q0SqGszsGMFWPPPU/QnpS3a2k8szNK0 PmgInYjHJ47nrVeSK1SKO6KXHnIu1Y0PzN6H05rZK6sckbJsjuLhJ0kju0kEUQ5Zf+WY9TWxaNaw 5iBMkuwMBnselZslq8tpCrHECsc8cmtO4WCKFJZIZIpXQR8HnA6fT/69ZVInXSXLPmCHylhuxKBG kv8ACTjC+ua2rPT9NhulKRlppIwCofkenFZSWFlamHy0mLSMMK0mSxPpmtFLFLe6jjZ5JWEn71o+ Rg8gex/yK4a8vdaPXoXlNWP2Q/4JQRrN8aVeaPz9qsgCggw7UYjPvnP1zX37/wAFadSfT/g74GEb W6vNqz48zox2qAB7ktxXw9/wSQs42+KJaC4lm8tJ5nIfKqQrrtPfOMnHstfZP/BWm3hu/Afw3SR4 F+yakZCZOQASB+B4IB96/wA6+Offzuqn1Z/W/CyccFBeR/O/+0hfTSftX/G+zUzfYbKSxsYA8ocR +Vb48skdXxgk/hXjD6eZLiQzSLK6EkKAQPxr0b9oqS7uf2xf2rJGXyLaDX1tUwNvlbN3HHQ9AO+M V5wxvQ5CArGg3b2HT6+o6V/ZvhPSUMnh5n8/8e0/9vnF9DGkN0bVwqTyajb7vIZCF8rqQfw9fpX1 l+1msMHxB+EehQWaxWmgfC/QXtjF8gjaeF5XLjuWL5x/tD0r5rigdrORDbLeNApkmBk2EBgQD7jO OPqe1fSf7aUcmmftCajazMqP4f8AB2g2Xlo+7f5enxZBHYAuTn3r6PMqkv7RowWx5GAjGOCqzl0P lOZ7CyhiWSCfzSzAKCBu/wA8mrNzbrGY3vF3jjy8Hbyeg+tWbRvtUi3cqbY0O7aR29arIYvMvrtD I/2YZVPvBecEkHoMZ/KvrlDufKe0uQaheRumnWlnCRDHKTKxP3D7/j9aBd20jgsz7IThhjke/wBK lkY4eBURVuxsBxnJrOiWf7NM0ygIjlXx1A6A57V001oYS3IxbPcxmSWOOSVpD5YB4A7fpWnLdzRs 8McbNcLGN+B98fwge9T2d0lvNuW3RvLQLgrw4p0UUaqTcPK6ZLEZ+Zc98/5xUykab7Gath9m+0x3 khDXa5dugi9j9O/4UsCGVE4LWwBDYH3sdBntU9vDdyX0jRxubNyAC/zADvmtN5fMlK2SebDB/Cv6 5rKUrHD7IwUa6M8EVlZslujEkkE7z7Vfh1Fyj3AtpWmQ7QM43Aenv0/OpNQ0ueTy5UneN37j7o+n uKkhtrQxyyqJWWFdrnOeR3xTlGMtzroynDWBBNdC7DWxZGF8MeQRz9f8+lVtRtBeWENqkMqGJiDy P3Z96ZbJ5c0flW5kLk4kJ6D+n196syzNfG4tYxJbSW55EnG4diMHkUKmuhv7fuT/AGkS74AjvLbo Gcjofp6f/XqG2gu2gkijjKwOSRI3QHuff6e9SObfbOykm/lQCNsYVyKcl3fFDE0Yt1AHbO76fWlO N1Yrm5tCBYlkt5BbxM11AS4TIzn19OajizLMtgZ4vtEo3H1X8PX/AAqac2rvG0kzWkuc4yc49eO3 WkcWjWLMu0OjZFyBkISMgMfTGeKzjTsznqRsYt0n2ONtUc+ZJanaNvRfr7GtC3tori3uJ5n+yPcp mVyeCB6ehq5pohaMXEbNPEwwvGNzd8+1XDZxNai7mhmgkaTYuTgH049DWsp9DSjhnujJQFLRJLpG UJkKPQdvzFTw2pgvI2RFZX/hY8g47kdRUkKus9zapBcyG2w6ZOQ2c9P8+lPtrhGSYurNepnZ2C// AF6dyHL3rGfcNLcX0MZJ8lMp5ePmX157n/Cpz9pEbyzOsMW4RoAMmT6VPb2cVn51yy3JuGUBfMcs p+mf89KiEt/K4aS2e3t3OFZhn8fof8KW+pTGXNs88lvHBC2922ltwxEfU5/zzVe6T7Lf2kUReZ5s c7cD8aty26XVqkjJcMIX2syvtLY9MfpVuO223ltdTSR7y2xEbnP9Caq9tQMZZfOgCwb9jO25gOCR UAT7TMxEPmCddihGwZCO1dBe23lJeSpC6XUgwADhPpj1/wDrVl2ap9k2CMb4nMjMDxGD/wDXolV0 0MPq15rm2NVrOKXDrG0MOAHjByWx0IPbNZWotJdXaCW3lWRxg4xwBxn6dPzFbLEXMG5BPA+MHecK SO49sfpWfqHl2n2aF5ZCjP75OR79a5lLU9GovdI5LG2liCSt5a2nPzHlT3P41FLYlLmCPy5GiY/u 8+uOfqMVqLbST2spgdLV4ckFxu2k9M+v0qvp7T2pSa5SRpYH+8TkSY9PSrc+hxchK0Gy12IRiU42 jqvufal01ZLSMx30YS5WQ/d42jsTzUflzrFvFuZV3dFGM+mc0+ORiWGw3lww+UqPlHoDk1LOmEba srbNguVZmkFydioOOfb36VDZacLOWYoVleQZkJ6nnoB7f41blZYHjmug1suQhGfm/D/OakuIGnvB I0Rt57Y53Hoy9vxP9aS00Nmo/E+gy5+0hFS3XLsf3eBkf/Xqo6NJe2SxuqXnVe+8+mP896tzee8y IttcxhXyDu+6fU+3+Ip28CFZUlRZ3lKKDwWYe/YVUY3MqsVIp6bGge7eXcInYq249CDWjNa2cMEs aIyQR/P97oT1OaimkWVGl+zyvAGxvU8KfenI9naIJZLhdkgwis3f09z1qZQd7kUYqC5THeD7Mly8 hZ0JxkDGw+tTPaTNLG1yWundAqhBgj2/KtmTTZLkpHKWtLa5A2K338+mfp0qGzl+yvdrdK919nXC sgAyB0HJ646mq9p0Jq4dS1kiBFEkUksTLGbdcgsM4/DvUV3ZPeWDxRzJLFJkEDovqD71PbfPETsM ErHzNr9cHp/+un3UYU26I7R285IcHqPx9+cfSka+zXLYznFjCrXdwWnEEYXKNjp2p8aJbKXMck3m EM+3ggDoB71ZSMxAR2sZdG+WNmXIj653etO/1JltvLeSWZclgc7B6+1Ns5/Z2Ka2e65kUFwxjEgG Pv59PamS2KxIb2SMtcS8IOzY7Y9f8RWnbxT3FrgJLc+Ux8tVOC3tn0q40Xlb45pPmmGQeoz7VJk6 WpRsJ5I4LSO3gGzzS0y9SBg/1+tV9StkuhGYWk862cyRORwjdwRnn/8AVSzTNaWqzWwURSyENt6j HU5+tPiM8vlXO7Yp+ZVYdf8AGs/Ze9zI6/ae7yszGs/Itbt5iUTaGklzhR+dbM9zFFKnmEYMShPV eOuO/FU40upyI4LaV4S5MsjHKn2H+HvVWC3axllkkilmW4YgBTnB9MnpkdK1k29zmpV/ZaRReSQN PLKBiGb5EXuSByPr3qGO5w7W6Qk3DglR2BNSzRIH8iCCRkY7mVGwyj+8Ca0JTbRQo7Wk8jo3ykYG O2fx/rWfLY6FX53dmXDdi3i/cld12+JuM7cZ/DOaqWen28tsyTLIC8jHYeGIPb61s74IH8uRUigu eSzdR349/pWU009r5paF7aONvvSDgjtWsZE1LWLNuREuzcv7kkEkfcHbIpllbQ3Nrd3dq8VuqMVO Tncc8j2NWLW3kjnOpGI7bhdrK4yE/wBrHce1UIrqKRLSHTp0h/fGMiQdu5A7n69uKTZnd3saENlE LW0gtxhpJCwHPGOp/Cqd1ayKkgZHM8bD7vQDNW7YzWDH7QN+zPlDdw59/wAOxrU823nVhdwPCyAM 20/e+h7Vm5tPQ6YU1KLTOaljupJo54UPngANGf4vTHuakW1ndFt3KhiclT3z/kVowJbvLMkkyiOF SVcHBQn19fTFRNbK8hWaZg+RnBOeen+fpWvMzzZYGKegaY9/a3SJMhCE7ASMfQfyqENLaPJbm3mf Y+8kc+dk9F/z3q7c2sT2T2wnYTryjB+mD0PrUDzytPZG8SaJofmRchfNb1H6cfSsKlJM2u9IvoTt aSs6GQeTHZkyBjgqc9j9Ko+ZcLcvbsqOoO5HB+6PU+3ap7qVJbqESrMrzHbtB4fPTj8f5VHHapNc Qk7oLtM+Xk5Xb05Hej2fKrHoYaVlyxE1qPz7UzTSeYEATJwAP8DWPHDDDeJHHBIjQAOSf4cjrz2/ xrfntZ7nzLRyLWziUb2c5EhPr6LjHWpp4Bc3Jhv0Zfsy7RsJVnbHXjtjoKunUtozixeXynLnRmWM VxZJcG4lhYyOTDz8ze4/Sp4byQZhaTz0tSXCKMbSeuabdWNldss1rb3Dzxna3z5VAOpI9M8U5bR7 aedoo5L2ZxuZYxgMM9ParlJW1NXRnK0VsU7SJ2wtwDFFIfmye3+NPFs5nWG0ZTYK2ZT1474960b2 RUhmS1hWRoYhKcgHBPbPrUttBb3UcNnbzRxiTk+pOOR9c1zt31M40HqmVgktyslqgEUJOIT12n39 asac1zK8tjMojto+p7v7j2qlbAxS3YklRbfOGJGGyOwP+HvVuMRxxMIZZTfIcq2cgA56r3HXisJL U7aU7KzH38UH2eSKJlZGwEGP4s+vvWJd6a8fmXBjaW8VMHkAH/CtaSOKBFLNN/pPyyKzfMO/y+hq lLLYQfY4b6O/jeNsna/OD03e3pWtGfLsZ4miqm4y1soEkR45AZgOVHIj9z69x9ane1tGYT2Mj293 bPl1Zt2T6+mCa19toIEmtwpWQ7ZGXso/kRjB/GqEPku5icKnnNgDoT7+/wD+upqVXLVip4dU48qJ ovtdzZpLCGfUIHJZAANwHYeh/GmTmWYpMCXC/I49vT61UvYZIrlRDJJHaz8ZzgE45Ax3/pV2DTbx ELiN4raf1PzD3H14xWcVrcxc90ivaPbWVwY7NJku71gr5IIi64Jpt1bXt1OZbSSKcxAbgR/rCOw/ z2pkGlROiyyTPb7nIUZ5OP8AGpwiQ34ht0uHihTL7TwPU/nVTavdGtK7jyPYkms5pYi8hBkBHlhR yCPWs+905Vt2kZbqdl6iIZ2/h39MVo3UM94H8l5BI2D+7bHljsasfb7mGRYwIjtQLvK8r7/yrP2j NJWWhBafZ4bWbSoo3k82PcrhuFJ9aqXUTSB7WdTscBWUDkitRnhuR+4kWI2w3OVBJx/+sVRuY4Fc 3UrS7owOQ3JH/wBb+tTC6lzFr3ocrMdbGGILahH8q2O7ap5APfNbIdY7ZHiVomQnn+7jvVi5Rlik uC5LSqN+Ou3tt7A+9RwST2lvIiW7+dtDDjjb2NaV5uW5nhoqE3YZeWrfYUlaN4bdSX8s9Xz6+g71 lTWULxWzQpG8MRLfN6nr/WtcXMs0YuJnNrKcxsrcqffH+TTI4DbtHHOphtrnKrnqeOq+9RT0RviG pF1rVbhILOS5jmtJMDZ0ZxjsfQVkXWk2FjAzySRpJppMiZbG33PtRdG5+SaGEvc25yoTop+ladxc pOY/OihDlAgJA4xk9ep6nr2ok5dGKi6bdprUfI8Dy239oBmaMZynGCRVG2liiudkEMr3UhALg9fQ UEyJDcI9u8cTrtSViP3mfTn8qjW0WO3mnvS8e0giTftH/wCuojTXU0l7rTiF0bm1lazhQXErtlAP +WbHufX0xVq+WSyQaaYd8zDzArn5AxHUnrj1qmsbXEsC2BnAtjuk80bhJ+Ocj9e1TyQTSE+e/Dvg s3atG7aHHVk2mUbF7i2gLRrh7c5YgZxnt9anjjSRISkfnXKv+7OcIT0wfp3qe3iuJDPBD5SxQjdI zDlh/THHPvS+bGkayxuzPIdjgDhAOh/Gnc5sNG0kytbJDbyz+deotjESSc8NzyQfT/Cp53e4gktC GtTcDGT/AA+h/LmmQT290L6a7jCKE2q2cbfVqbDdQxiadyqjy8DdzgDo309qxqU29j0vbpbkA02F ngtp5UKRKA5zjg9K/FH/AIKs3aS3PwP8OWwvY5LeS9MqMny3EYZfnQ9iSfrxnvX7WJL5otQiid3J Vty8NnjBB61+IP8AwVEu7a/+JXw6+xFm+z6a8TsZc4becnb0GF2j8B6V8Dx9dZfNM+x4HaeNjJH5 WyI0OEtIXRD0B5qtLA0+XkLYT5Rjg5rQumm89fKbcQONp5FZ7eRA0jxSmSEDf1Oc1/NMqh+7RZFb Qg3KpCsuW4VQOp/+vTHmkN1PvhH2iD5cv6egxVyK8t54nKlopgMMQPue496bPbLGY44nVxD827HQ n1PrWIypaXTyrNC0ZdoyeTwF9qi2T2UBiUmaCbkleo9vrTmO6K4VbVgJjgODxn3p5jcW0buX3RNt yp7+lJx6EX1I45YZPs6QrLvB4VvXvVqOZbe4CIryybvlx69qjgjgSFnmDwSDlFI5b6VYt7WP7WMu UWX5W3dGrmnEclofrD+xzf8Ak/Az4lM9syyarK8hlCAmdoIyNieh+c5J7j3r8qZpftzyTyJ5NtJK xRSMHOeRj8a/WP8AY5s7g/BzxTe3tneWtgs00bTbgQihV+fHfA/HLD0r8odVYy+Idcdbi3uYoLuR I2iXauA5+UD2r824RxX/AArYinY/Y+LMMv8AV6jUfdfqWrPykXzJI3dbfnk4yf8ACnJeT+RLcGNS wy27PB+n+e9VfthhVQE2u33VJ+Vj71KDcSxSOqJK44cBeF/+vX6bKJ+NTkbmn6mY7hJEKy+YozGw 747V6JZ3hvIPIIzcR/Nx29q8kh8gwR3MKmOaM4dP4j6c10Nvd300sO7fCq4JC8bqzStK6OLlPQYf H2qeGrzFpNLbXarsYlQQF9/bofyq74Y8d6jaPe3krpcpeNluMEj+mK8y1W4+QARmec/Ltz8wHuaT T7uGyuGjiWTy5BtAIyFPrXV9aluzGrhIM+7fBn7T3irwTCEsPGc6K1osMcZRSm1fu5GMHHA544r7 z+BX/BZb9p34KajpGteG/HfiPztNkVobWHU5jZ3eBg+db5CMvouT1571+H8s2nvDBGA0MqMegyXP 0qeBwsDKsgSUfN5xOFGe1azxbnFqaujh/sqleyP6f/hl/wAF1fjhoPxw1f48+KPiafF3iTX4EimS 706GC2s4VwWgXy8KYwR9wAcjOSSSf3o+En/ByV+z7eSaLZfHPwZf+H4GgMl1q/h2aO/gBCblbyi4 dQe+elf51Fxqv2fdaSX6oIArGUAgZI9faqknjC4vkWCO5eCOFdu8Ht/h+VeDjskwOJg4zgFDB16F T2lCSR+3H/BSv9rj4fft1/8ABQv9oL4qfD6e81D4XTw22laXdMRt1CK1iWHzk4BweOBkdfmOM196 f8EIP2JfAvxR/bdj8f8Aja6TxD4b+D3h4eIdL01UBS5ufN8tS7HnapYMQO4XPrX8yHwg8Rv4f8QN eTTpFb3QMZdxuAAPOf8APFfvP/wTP/4KVfCv9hn4zan8adY8P+KvHnh86FLpLabZ3KRNLKxyDuZt oQOOpBOOcVxYThiFOlKnhtND1cfn1ao4KvrbQ/0PvEehoE029mQyQ2TglYASW5G0Y+uK9adT9rgb Hy7GXOe+R/hX8TWrf8HO3xD8f+OLKTwr4G8D/DLwvpU5a10u8LSXWptwFWWUkpswf4B1x+H6jfs/ f8HCnwE8YwWafHnwxL8PpFR/O1LSHF9ZowIGcE+Zjkg4Bwc1+cT4Gx8E5OJ61LP6GkD9LP2lvH9r 4V8bf2ZMfLjezWR3IyFDZx+oavzrHgGL4l/CX4y6foXhGC4SVbiP+zzMQk8UrFl3Hodrrlsf7XrX xJ/wUc/4Kr/su/ET48eFPCnwA+MGk+OTcaBi61C1DraWkwdsqd4UltjJ0yQew60z9i79q7w7498U WXw98Yavq9p/wgNz/a8dnb3bQJrsTIBskCt+8XndgYPHPFcdLg/EVYSc4uLPYq51HDuNSGq6nCX/ AOzZ42+Gnw8+H+rjWLPXLPWXkhuJ/LIl0+RCcBwuVIz8vysw9cZ4+kfCf7Qvx+u/A1n8MdM+JHi7 SPDdnGLMgTIEto1UgBG5/dgDGw8YHINfp/8AEP4P6J4y+E2o2Pw50FJPD/iKRb99NtOTC5PzPARw jE/eHGT1xya+WPhN+xd498T+I7bSLzQLqy0BrjN9ezxPGsa8g/e/i2kjA9TXJlmZVsLN0J/1Y9XM cNhsZQjXpu5+s37K9zq2q/CzwnqlwbhNGSyEFn5wPmTqMfPk9sgj8K9v8a69D4c0Ge/kcLJLKkEQ zy7MwGB+GT+Bq/4a0vS9E0LS9G0WFYNJ0uIW9uoGBtXjP44z+Nfnt+0N8brHxR+2f+zV+yX4fkN/ fW7TeMPE4ikz9kgSGVLdXHYlmJI9GT1rur1HUlzs82hRUIpI+7vFGiaRqdjZ3GrwQS/2QTcpIxKi JgpGc9uCR9Ca8c+GPhrQdf8AFU/jO4sI9W1HRmdLW+wQkSybgyqD/Fx19CPWu3+MGoWdrouj6ZeP cJ/b119nxGcbgELHPqOBxXVfD25t7nwtpUlrp39l2xBWOPHLAEgMfqMH8a+PqYaNSu1I9aNVqinE /9D8bPFHwK8GeEfBOq69BY3Fvd+D7Np7ZrV3Mtww6rGcjc3IyW6dq8x+GHirxb8UZrTwfpF7fahp 2gRJcvaXx80QEDauSc4GSF2528j2r6s/aLv4NN8Ba7LZQ38Mt/Zm2iVDuG5iByO3BPPckDtXxd+y bLqngyfxLqlgk8PiS6kaCKedyqKpYk5XncM4PtgEdK/rLj7h3CUqUJRWp+QeGueYrFyqKu727mr4 GuV8PeIL7xA2lJf2UUslvc2bqrO+Mg7AegzgjkcfnX034n+JXh298GXkWiDX49S1y2W3jQR/Z5YZ Bwdp4GV7FSc9eal8E+FfDWnT314dEjW4swZri8ux+78w8jAPBGecdcHJ61jfCrwnqmueLPEPjHxF aXgsoA4sCyrCuC3LRR9QMcBu+CQQOuHDmAnSpx9hHc9fPqmGnUlKvJ3j2Pnnw6un6NrPhWG/t9Sv NBsLkQGe0B34+6z+pwCT6nGO9foJ4W09FtrGIw3bfYjkhjnaMcBm9fevNvHWmx6n418HpDZylbFi 0pPbC7iGPbK9Cenvnn6FgndoIo2tE06CRQCgUAqcck44NfoOTZZWhUbkfBZ9nNGtCLirWGrFbRSw rFZxRPA29TIgITd1cD3/ADpLm1Gn3M94JgI503Yz93HWpIra1aAy24upb+Q4xv6Eexq1NlJ7iExt c3MKhhAo+fPf/D8D1r7+lFRdkfnNVuWrOa8S3eo6JpBvrHSbzWpHG8QQ8SSnHYenT/69fnT8V/HX h3x18XvCl14x8M3I8O6EqQX1kkZ3SKwIXc+fu7iOBydo/vc/pXJPBYae+q6rfvp66Q32qdyMhYx6 jrjkYx1OB3r5a+Cfinw/44XxB/ZVnba3fNqk0l9fylXSCNP9Ug64yQ20DAAIzyM189xHm/sVGFtz 7ThDLadSNSrLdbH1H4bSxD6eIoHaS+kCJCmDtIGeAP5eteE/GD456dZfFPxDqHh6zk8T3umaZDp/ 2aORiyqMsUPGA2/oRyMkYr2LQbjSPCFprnjLxLb6naaPok4aYQyAG1UEfMM85w2TjoBXx38DhoPi f4keJPFVxbSatDpt0W02Iv8ANK7NlSwPGSnIJ5yDmvkqmOhVnHlvoe/leD9lCcK7919j7C8O3d5r WnaRrtrbpp9xqkKy/Zrhd0tspAIDj+9yMgehFdzoul32sa1C9k8ab2EcTysfJ8wdAxGTj8D2rATT r5riaQq6qRvXA+WQDsvqeldb4Xt5rLw/4v8AEQgnfTdPtGedSu8FSdpAB4DHdwT3I9K+6zDGuhg5 Vb6pfifD5bhozxigl7t/wPn/AMR/B/QdG+Oep32i2moW8tpapHeQOzOtzfCZ9+0ZwAATwOnrXjv7 WOi+GfC0ngHSDHJFretyyJqv2GYjdEVyqup4wGCEe5NfROnePdJ+H3hrUfE/ii9tdd16a4aX7OZD 591LICUHfCj5c9Mk9ya8P1zwzo82hQa34yvrbXviH8RrkQCGRwIYZJSNiKrZwASFyeMnpxX49Qcq tS8nqz9bnXjSje2xxfw3sPiH8NPB+n32h2Vp408OatIJ7i0jgzcWUTHCSl/4yBwRjOCMZ6V9mNFL qsGmvLJJp06oBsY524HQ45z71Q0bQRpAuLK3hBTTQFSEDlMdAfx7VzXiLxRcad9gtPDv2CbxLqjA RWk5MgkUHlyoIIXJHcfjX6jl9OOGp885aI/Js0zB4uu4wi7s6bXNP/tHwn4ps7jWrPTohZMwuFUC T8B/EfQdOK+SvhV4FhuPEulXa3O7R/BzCSUDOy6d0OASDgqpwcc5x379hd6Trviuy8QeL9a1gG2R BbLZQExxX8pb7ipk5XLfd5PQZ9faPA/gZNH0nT7R5Vk1WF/PuymAEbH3ODg7cnPXrjnFfMzxcswx yjTfuH6ZhcvjleUyrVNJs677ELzUBdTYCOwCCP5QG/3enHp7960rlgkYgV0lhVipx/GfY9h/9eoX ijsoGldZIUzyXOQ3+FOS9gWzhMsXmLC/JUffX6+o75r9Tw+HUYpI/EsZXc5Sct2ZFu13bLMkoQpA d6Og+59ffoPrWoskd9ZC++ztCkmY1Qj7+OuPf3qztEvnCGDzo5o8BeNyZ7+h9qmtI0NwIriQzeSN yoDjB6Zx6V0N2PPpxaZSiC280cTQIsc52xuAM57g1NBp8bXAjU3NyHJJVXOV9j/Sq8GjTmeaY3ny q3mLuQ8c8Y/z296v3ytbaikj3Agm2Ar8v3l54+vf6CiUr7HbRpWT5h7Wc0sslxFB6KT2UDpmqygi 6BimjnC4ACdVP9e361O08iEGOTfbaj8rYb5WI6j1znr9aqm5UCdUs5vI5GVb5h269vaqhfqYVakY vQE0i9v7oyC7gUyfKAAcRgdyfenGzuxdeVceVAyYw5+6SehI7gcZ9c1BaTXERdpYrwIgw8qnaUHY 065t7lbWS8VzOgyC/OAewPvzW/LYzjZkVlM0cUttcuIXkYg7B94eo9sf/qp6ZkfZAi3CZ2CQsAsT Dru/ljtWmJY57S2m8nyEZQMgA4PqT6VTimkFtcRWsKoiHLn+Lr1HfnjH402kdkYFvVbcLHDGhmkh wHLZOGY/0/8ArVTaHNzO0kOGgVQdvG0/0q9GpRLO4uS+J5CuCflx9PWsy2vrUTzrNHMLidjGGD8j HQj6Cinsc9dqMrIvSW86XJvgI7ZVQNJvGQQO/oBWaWWK4aBFnaPG9PmyFJPJPt+nStCxWLNxZBpZ Xm4YscLye3oazHtZlZLqVZIJlJTBORtHTv1ropvuYVKrUdC3JJF8ttKJLtbYbzHHwyE+pq/5Vrcy O0giRZoxGSONuP5f561mW9tCs9vPDHIGuGAZS3O7vVh2RdQmzG0UK4VQx+V/XGO/U/SsZx10JhPS 8yW+sQz2d5ly0mULo2PlH8X+faobSzS9mkFzHsTgcHH0bjsfap5r1llL7okt2GAGH3ffPTFWb6Ga ztT5JZECiQjG4+vFJ6bm0JqTvEijh8qGS0mkguOM4QEMw9u+f/r1nxC1lW2WzSeYyKd2GzwPUVZt bnELkwPCZR+7JOSp+taF2kMUUZs4WEzjcyqfmbj9Bmst2PW5murr9nfEqNnbs6lPf3z2rMlmlS4u NOQ+Tv5wMhnJ6D61vRTNHdW00tvI8WMAZyC3+f5iq73byzmYIfNY4wgAK12Q2OarAr2hvbTyVkTC WX7xi4BWQHtUoT7ZPMskAu0l5URHbwewPr2+tJ9lnu72OzgEvmuN7AsOBVwrh7eyktZLabdnhuWG ON2Ox7fWqlMuC0KEly2n3EcbqYmzjn+E+9bF4qQRCZ0lZ7jCsuefqPQ881VitGzJHd28s2MjgjJ9 s/ypZ43hZJit3LbxLnDnofQf59K5n2LT6DLmSFIora0Jtioy0rDcAfeqetaPYajpNtrTmzt5vDE4 f7UYwzokmI2Cj+8eOhBzjr0qzpzpJDc3k5LxvlQFH8vT3rS0PR7OS+uIrszJBcw5Ko2Q6nqwU9SB z7Yrzs1pJUHJ9NT0skqf7SoJb6GFGYIYLZA2+1lclZDkI7ex7D+ta9xcPMhgMZ+3RD93zg4PTPrV ZIri0sl0mJmvXVg8nO8Y52YJ6cDpU9hY+dJfBZPMm2Lgnp9M9/8A61VlWLVehGaKzzLZYfEypS9f vKHjXSk+xeGbrSbj/idrfsJjvKmWFoSH8o9A6sFB9mb1NXtMguIzbxhk/d5YRheWHt7/AOFacTw2 2ja1qEgaa80MI0TSFQjszhCB3Bw3P0pt3aNd6fFdaew8yYFm5wCfb0rxstm6eKnRZ7+cUlUwkKy6 KxmiT7fGbOeeKJYTtG7sCeCfX+del29rba98LZIJpm834d3YvYpwcCZJH2NG2OepTGewNecsmnWU ttFNIshA3EMerY9fTrxXp/w5mXVLy48Pi2kks/FK/YbkKABtz8vH1xjHOSK24qw8pYXmj01OPhGs o4rll10POL6O0jeO4eUPDZtuQL/y0z1GfX/CqjrcW0keUTymJcdwv4VLqumXsGqzSS+ZK+n3clnN AQUMTRsVKsD34qZbOUMNzG8dckRx/eX2Ne1kuI9ph4Tv0PLznCujiZ02ralTKS2hWKMQeVnDsThv X8Kfaw/akh8mV/Mt2ON2SW46H2xVU32dVtiLSXyeF2scBj6e1WY2RrxLe0ElrIH5IPc16deXutLc 8ek0pJtGN/aUGsa1qa6fqd/d2lrEttMFdkAcMQODx1U4BzwM8ZrnNbt9Ri8c/DiTTYUaGyNxLfE5 V7ZjFhVznknOe4GfYV0MFrp1j4m8Vi00trG+vpYy8kYPlN+7ACtnjex3NkfpkV2eoacx0nT5bKC2 v9ahkYtGrfvUb+BXJPI4GOeMmvyHOKjpw511Z+w5DSjUq8k9ktA1Pw/I3jC2vNK028ZJ9MWeUlsR qQcHPOGyQenSvSrS5g0z4l6vaamkklleaVZ210WfMfkPEGZXQ9DvAGR/dBrhvFf9rnxaujm5nisd H02O4kaAKrb5B8u49doAPTnI96teMPEmka74s1o6FrMbatoum20c8LdVOwjfIOMqTjA44x6V83DD Os0mtGfZ+0p0U2nqU7mxtdMnktXjYWKPlpc8D6Z6fjXnnxYkuNI0PxDplmNMvJNYtVEkykNDYMXR ofMQ5+bjOeBnHrivb/Fts2ox6Pq8YgTTfEkKxxyRYASSNQHXA4DDg8eteSa38P7bx3puveA76Rph 4khS3CRZDSuGBBxnoCoODxxXu4rL1WwktdjwMNmHsMbFPqdV4dvo7zxGQsP9l3EtrBdObpwLcsFJ LHOMAgk/THNYPh7/AEy/0ma5v4NVOq3PmLLbjEe0kkEjuD2xnqDXinwz/wCEusvDdv4Y+IEEtvca RBNpM1yORdohKIwLZI+TBBOenTFfQHgvS9L0W/8ACjlZLPw5oZjlJAZs+WuGx1bHH5+1fM8K5upS lCT0Wx9HxRlfK41I7yOzvNL1bXfH8enrD5l3f3S2NvGfkVSny47fLkdv5c18cad4u034U/Ej4y+H NP8AD9+mk3pGoWU8jSTfZsFfP2f3lMu/aAePm45FfVnhnxBcWNn8TfitdJd61bvqdx/YwUFYopJJ GWMbT0JO8Ed68O8XaLLpfiT4V2tlpc4W4+02V5fF/wBwgdMiOXPzEtJgr1wRjvTzDGOLTp9GVgqE ailCp1R6Ncxu10ro+bmTHyMMBc9CR0x6inoZ1WzeFVaaIk4JyGbP3QD3PX0xSwaXeWDl7iCUx20Y k8txguCPx/H/ADis/iCLTdOu5NPAu9fvDth8sBxCCRnIzgYUnnsfpiv13C8QUVh4+zd3b9D8cnwx iI1pKSsrvVl3xnplpqVtF4YvEguxpc6XVxOxOxJCD8m4HoAxBAIz9MZz7MiIwWc88RaUbYlUY4Hf 0x/ga0p7vQdC8Cwz+INN1hV1Z2XdBG0ilyCzhiuSCRlsjnkDvip4ItMmSz+0shiu0BiwArKrDK5P qRivneH8yjLF1adV++fY8SYFxwVKdP4R0nirxB4B8nxRouj/APCQWGkWj3XlREtKg+YF14IOCpyp HQ8Y74emM9zpNi0UN3ZPLGJIxJ95g3JAHbrwfpXVQrrN3p3xvS7+z6ZpOj+DZZ9LMcRM0gVG3qz5 xnf0PXGR3rn9OkWxNlDdP81vax3EBjO7aGUFVz3wprlyCjCWb1JNaoXEtVxyWmlsR3NnMQIXXMMq jcVI2qPf3qbUjFbGzljhkhiuFXy5jz5vUEAY5OQSOelTSGxv4SknnwmV9yNuPzN1Ix+ddTcpNPZR +fB9kt4otsMmOHx71+m47Euko+p+ZZJho1JTctbI52/s8eHvEVvNPqttD5IeSa3l2tGc8c9hkj26 UttMbi1jMcqTxov7p1TAkHv3JqzJ5cXhjWLjVLxEt3jIVSdrFUZS271GMfXHSqUemtZm2Ym4Wa2w Qjtk4xwue+P6V4mEq82NbPoserYBRBJ7gybHiNpKgwyMcsx9j7+lTSXJaDEYLXd0u1w3BC+o7D2N VL61Mrz33k3b2uQjFSQFPfntUmreJtHttR0zw/e2QstVuNr29w/G4kEkEEcKFUnJJ69BX0GKxcaS Tktz5vL8JOu5Ri9iBYJGvrKE3AWZZAECnBB7Hnr/APWrrfGvjLRPEni3xJc6E9xFc6XFFaSrIAPN kiijRmCg4wSuOeuM1iQxLEXuL1zIwy8QXhj/APW9Kz9Qbw/F4lvPtC3Nje39lDdyZBUMoBRWU9Mf KfXnJ6nnxM2adenI9TK1ahViRyzto2nXeuagot4kh3YkfALFgqgYHJLMuBWzY3EX2yOa1cCZFDSO oyU98eorNnhiu/C/iGC3hbWVnVITGHyUG9WDDPQ5X69qc9jFZ+WdNvJP9HUSSvKd+RjkEjGcf0qp YyUqkqb2sZ0cHGNCFRLW5zWmWmsp4j8Zad4gutQ1i40+RJckhXjQjEQXHGAAw5HOB35rqUNvpFrc X98Xm060USSKvWPJxlvQDvVvxFpb2/iq+1b7ZG0d3p8DuFO3aFXb684Jbg9j7Vp/YbmTSruNEiur TWYjC5ZAUAPBHPTqQfrXj5NiXSwja7nu5vgVWxkYy7GfBBaypFeWlyRa6iOeSc+49q6o6hpFt4O1 DSrprldVmvYxY/L+5DEPuL4JCrjOD/uj2rhrK11AtBbRoYBK/lZI4wOOK7jX4/sfg34iyi0gmu9D tbe5Rpv+WZE0fPvn5hxjGe+BXJxfjo08PGM9W2jo4UwkpV5uGiRxNs99HAqTupEQIDKMFsnpj16c 1egs1uLQtZpKqocMQ2cex981WuopIbqa3mjMIyf3bDB2kcD6gdT34NQCK9sIvDGnwSXMOp+IJ5Ui Ck7LhEAPzdcBcgk/7VfZU8ao4WNRo+LnlzljJ0U+5JPM8sap9nuXjkO390MeZg9M9vXjmpW1vXrH wd4sbRrZZlnaKKUyLyVDhjtwcgkJgfWrMrSCZBFcLsRsbgMjP+Fa2n2UWq+HfH0EccratpVpHcpG smFkw4z7Z27jz2NcOfYmEsC5rbQ9XJMNOGOVN+Zcg1rT9I8Fomqv+9nu1kY5IIK8qcDqQd2Rx/Su VMV2jXN1uQvbudwkTkZPQ+9dC9lBqfhS9nGnRazb6ftuZWQ53gZBI+uR096xLiYzFJdSa7hkvUW4 mBOS+Rnt1GT/ACr47g/HuWOnTW1kfY8Z4OMcvhPrc3dB1O7sLseIXs4dW/suCSYWHmFPtjIhKoCP U445/rXHaJBfXum6TqMttdaTFq7ZNtMAZlPfdg/jgGt/RFk+228UphkE7kKrHaGBH+FULJ5LJ7u0 1aZrPUtPaTdE27JVpCwwOgI3DOPXqRg19fjeanj4tPc+Wy/lq5XNSWxM+n2Sy3O6Z4omOFEh5BPH HvWa28+cfJl22Y4O7lj/AJ/nWn9nOoBb9mkZEb6b/wDZA9aluriJkwtp9lkICh2PykD19TX1dN6H wdQzIrYSCN5Ibi2tsh5gD97Pp6VbljW3WaKd47jz49qbcjbjkfj9KzrVtRvLotKwMRBCxAY4Hce9 bLRyRQW11Mnmu8hVgDjYo6c+tdMu4UnoVMXFys7KqQGKIbVA6Y4JPsabF50UMckDxbJG2TMy5x9P fNRWkE5nkmnLGIMeEOM/SrF0IYIoIgk6LCxYBf8AlsT0HvScr6GU9BtzOGmRYjIghX5WLfIT3JHf /wCvVhTPvna4tXhtsAoARmb/AD7+ves97j7Xa+W9oGhjXzWiIG4HPT2qxiS5EFwjSTiPlh02r3A7 e35VaViERL567rVlID5b5CeV7EHrQ8E9/cpZ28Mqz24DyL3Knoat2lon203AMz2TKMeX1cjnFW5J 4ZPt8kZkguoQAybuQO2frisnvodEKd1qYEscTq8Uc9xO5PzydfoB+tXhbRPLaW8gmRZMLvRsbfTJ q9NFpf2EvEZvtITL7WIwP8fpUM6NA9p5cwZZsLsIwxJFaRqaGdSik9BtxELdpEmVDOo8veDzj6fT pTSs88MCBj9ijJRlJ6e5qa5VY5ftQIMcC8d2YjqPrTI3lM0NpbwtObj5pFY42j/6x9KqxzTjbYr2 xcXty13buiKgW3j/AImx/iOhq48snkCNrd/NByhbgr9fb0rPb7RHe+ba29zIEwRI33X/AN38q15p bdrmOJ3nAxumK9V7/wA6fL0FSm3uZuoTGSCOOKFopkwTnHPv/X8allmurQpNa27SNcYXc/RCOaUS ODK8Cxh8D5XH3x2/PFaVzc3b7VmtZGt2Ub2VeAewz2//AFU1G510Ha9ylFc30MCjfmKaQkq68oD1 BPfJqRgby1YQxzXTyHbtToADTWuY7026S2cqeQTtKnA54H1yPr1FV7aQ2O9FaWWEuSEB+b6+w6UO LHVld6CvZ/ZfOFtPGsrjO0jAVR6/41PaXNxcJ9neGSCFThd5wGPfn0/kKIxI0QuimGkO3k4K+/p+ FSiWV44TERI0BwV24GBxuGf1qTjlEyrDS7ie8eFpTFbxHJ4wWP8As+nNac7xNI62s6P/AGecZzyp HBzTf+Wkkzz+XbRDna3LeuD2/Go4dPuoryKS7tpk3MChP/LQEcfzHHvW/KVSjZFe7uriO3VmXZbT HB+X5m+hq9Z2ccq2hhnKIp8wll+VR7+2f6VYRlt5Jh5eLR+DvfP4rnpzTLmNxpt6IZh5VqnnbUB/ P1x7VlKNinZMtR6Y1vI63EiSJcp80wGAn4VGkk2AQhAjOzgDj3b29Kggnd4Irm8LT+cAIRnAGPpw TUup3LshaNEj8oAkLzs9N3rmspSsd0JJoguPJcIk8DtHanLAHazfU+lSSSSh4vLgEYuh8yCPJQAZ 7dOnWmyxvJO927mZWVfM2jGzjgf0q21qJFCXDNFCnKyhyMj09zVROX2abM5UdLm3Eu6Fn5yf4hjj 9Pz4qS4jF1FbXF4qzx2bk2/HyKxxnI/i4A4q4tnhxPCk/wC/wBubOP8A61Mjt7ZYLiWZbiO3ckKo b7zdyP8APp6VrAJUNDElXdCkkUJEdq21T23d634pXbT4LG2hZ13ltzf3j1H51VEUMRDwq8qyjbkE gMR2x602O4Z47eTypUtpSUY4K7ucce+fStDGOj1JltS0QiWZRaxk/N6E9f1qmyXYgi3wyTbHIDKc 59v5U2SS6jgso9Ptp1SOQt83JnPp6Y/zxWh5zIxNoJS9oBKVRQdw6HrVQ3FKRFInmRmbcIooxtJI yznuAexzVS0luIvtY3tKrqAsZPI/GkCyt5glcpEhyE7sT0H1rSlQLaiGcIpHWVPl4/un3A/nW7Ej EUFbpbW6tZAsvL5PHPOD+FbUphjaJg7+XCfLZOPm46L6HHT2qs8Plys8qyLuT5d38fvVwSrcTPCS 2xkVRIB3HtWMmKM7NlfT7S4cC8dGXaxGz1HpnoT61VtQ63xkmVpBuIQJwBj+vufWtmdlhgSYMdls xkZYz0A7fjn9KqW8onjja3A8oSNvbHL+39ag2ctStLJZ6j532XT7ncD86g/fI9BV6xX7DFDLFbsE k5xKMk+mPSrcH2qSW4uYLdycABwAFb8PbvUFxKRIGvJpLny2z8p6/n/LtVX0sb+zsrjvtgeYpJaX MBjOYUAH78nrg/4+1SyPYSva213qKWMk7Hy2JJA4JwQO/BpU8yb7XFGi+UYw6ZOS3sfb0qrYvb3F pdtPbZt7QHc2fnGPesXAx9oJdz3+zTZzplzDErkIhxulHc5z0/xqvNb/AGfBjP76NvMlAPAT6evv WvAs80FttXzbVCfLCtjcfQehqD92klwEUyyLGPOQc5HpVxjYI+RFEWN1HGtu5t15OwgmP6+5/qKr yWdzPIryTrAnYEEtGfUkf0p+m75JID5EzQygruVunPHPf9aspdwWxMeHlmdyGOOVx0x6UzouorUz Y5JYpRLDLt2YUORwCOpxWrHBDM0kLTlpJxkSHJVTjoO4Oc+3NKV3ShhAqyzYHyqPmx0xT4raVIFM 0myed8BAOU/xNBy/a0KH2d7jMExkiVztB7o3rx/Kq99DM08cVvNmWADYF4yQOlbkNs1k8iPBLMl5 kbS2CT7e/P8AKqln9oWe5ScGC3Cgb3GSQT2rSMtDOehkTqJtSgt57a4vpEXzCitgpjkN7DP8xVXw /ZwWlqttZPKT9qkPzuX2Esc9a6G00+8tdXsb6EbtOkn2vvYfIO7MfQ9azfDTxqESW2beLmVTt+UH BIyPbI/Wv5s+kbX/ANiox8z9m8GKVsTOR3Cx+Vp2pTXiyQxQwkrKrhFUY53E9sdfavyx/Y00yS3+ LvxbsQmow6fFbiEEHE0aJcOcoefvYJGex6dCf1P1a+EOgamxhF6nkMDEFDDHfIPX6fSvzE/ZNleb 4z/FGRHvLS5e1NxtkfzNrvLIEj9AwJI44wPWvyTwPq/8KiSP1PxEX+wSZ+ggWMQEzSRoyNlUbue+ a1b2AbUaNmMqKHEX9w+hx2qhcyR3MMcUtksMa8XMhOdwHoe3PWtRLYcXEU3nTsu2LA+9jsPev7rs fyNF2IJJEks7iGe1aeNxkx5G+Hnrnt/9epVuookjtLVViKDPTJYfTvUDMtza3LT201tLtyMHDD6+ 3+NWYNjWcEOxZfNP31HIx2B7UJCkrmcr2xmdMeTHNxwc8+lTz3H2SC2jTbPaXBwwY5YDvg+tW0sr PZGs08bbiQ2RjHt9RVG4nExuIFjZjCMJHjnP/wBetPZmsZJaGtYwxztMsjptwDHgZaP3/KsyWyS6 jureMH7GG+ZyeuT0HvTPP3S2n2ZJkSBszYOG+mewz061fWSN0e0cMzXUmcAYVV9fxrNo2pyVydLv a/2i6VFs7ADarDnjjIPvxWdMkahWdHUO5cKT83J7VNPLBap5N4sk8LuOQcYz0GamfS86cPtDHFtm SIjqc/wk9+MUbajk7medsHlKxzaT/fyc7vp6VZmtLohltVKG2wyK5yWz29utSRQO81vIwRZh8pXH B+g9aqtCjXs1w7XSWyYTaGwQfUVucjCecQSWMriNI0JDgD5i/fn+nNPMkseHJRrR23KD0z35rWuo Ykg8yON8v0X+Z/z61nCHak9tPIjW0qYcgcw/j60pPQ1i+hLCskjG6RjLauCFbAJVh/Cf5fWsmSzn ZEmQs88LFy33QK1UgSCCaQvNHb2w++rYBpYp/PtfMt7eWcK5EjbsDHqPSlFnLW12KkC30kscEqQR EnciMvDE+vqDS3lncPJiOGa3NsNzqSG8z6Y6Uy6j+2KssTu0Uh2IBwwI9+/tVnzJo4Z533I9pFgE ng+5/wA+lUQpNKxQuP8ARbWG9ghMIkbai5z5p74/WriS/bLiO0jjdJigdD3Vvf2+lRSTQpbQQXKP lxmPJ7nvShbtiiwQYOMqwP3z6fUcfnTIjUd7DJpTqUEMUcMkB0xixzg7z0OP/r1HDA9tcBFObabo F9epPvVze6zJHbAySRL+8ReGU/WrP2RLlzZzNML2Ncq+AFAPpjv2qoM152VUVGEi/I88JJwOpz0/ /V9aWNbUyq10v7qA7lz1B75/pRZ3tvZJcEWMs9xbMUZcgZx/9eozHBLdrKEma5b5tgPUHoMfnWth 842RbZXgk3M1vvMmMn5T3zWs1k07zNb+ZDblRjJ6t7e//wBasbTmgaaeDyJke5O2PJ5jINa32J4I pHDyLNIxVU3HCY7ke/8AhWUo2NKTvoytJGs8Ijkhmgu4H7t8w/LtiiSVT5axASxbPnZD0xwRirEF 6jzL5QH2u6GNm3O0D+L6UtppyLdNJKZGgY5ba3OPUVJ0ySIIrhBZyO0nkSTfIPM/h/Lv9KRUC27z xBUdFyiv0z6n1qRNKRZZ4be7HkXTjaJckxnPrUlsHK3QKfNGNgRlB2/7XuDTatoZaFGySV3Mr3DT bnwQ4zgen1zU9/bXTr9o8sSLGNqsoxkdh9fen2mnCGyS2+0sl7csc7iTj0+lRR30Ul4kLlvNHyOM 8Ajv7d6mwNqJdmhe6tI5bmG4iis0UkNjLHp+XSqKK9yUSIBYg+ApGSx/wq5HFeTxSWkxkRt+5Hzk Y7ZHcY/mKgVWicuhkk8liNnAxx3Pfn8uKB2TY0RIl0wjSUMreWQx+5xnP4/yxSiCQ+ZBEZn8xuNr Y3k+n4/0rbkieS1t4/NAllIXL9ieR+f8hXN3VxJZwODb3cly83lrtO4qfXH+HqKqO9iKqstCT7TO skK6nGgWFv3WwYKnvz9Kl02Z0UNqkarOWbZnkLyQMenFRTxyyxqWmWF34ZWGTgfy+vsavzQMogAl WWWIbsAYKj3/AKe4rYwjLQgh1C6+0SpFZMYJT5YTPzqexJ754496t2LLvk4kmebjJOQeen1rLto0 E8ck3niLccbGxuPcGrvlvcxqjeciMSFCkg/n61nURtQg27l6TZJA0EcWJNx7Dc309KgKmOEWckEi vA2/f1wp/ve1U/LvmEzuklykTYCxja4xVxbi4mkUSo9sYzucOfvAf0rOx2+pnfap7BXuYw+xjtyB kH6D15rUZwkxnW2nnlIw+1tqgAdx/Oq92szXcbwl4pJlCrv/ANWAe5X+R96dF5kl15UJlVlAWXcf vegx2oOeWiM20ie2gnkuC9wuoSFEHI59P/1e1TSeQkEEKW1wZp5FQoX6knt2/wDrVfkaVYpz5LF2 OxI8j/voVWYyIYV88nzmAZASMdO/v2+lXGNznnUtuTTxz2UFvDGCN78RnqxqxKo06RbuSCXIOyRW OQvv7VbAkvbpJJI5EaNRkEAZ/wDr/wCNU7iZba3kku2ZhcOU5OTxzWfWx0ruJPp1pbMrWhlkcjdH k5AY/Xr1/lUU8tnqMEETKbQxkiRB1f159+o9KZdO8k8Nnp8VxdzxKGPIG3P+f/11VuIESQzKCwRM tID8retMTlYtKlxbFILRpbgEgoM9j1H+0f8A61Os2X7S8EFjLII/nEhP+rPfI781O9zFa3J2hXYx gockYOP8/rTYJboxxl5FE5kOzjaGz2A7np+FNK+hbnpqQ2a3MaTLawzXXkSEsQRwCccg9ugFaM6i V1giRt79RngVVtrb5mfzpJlZyJdjYIH+eKdBFapHMtxeSxRSqVViSCD9ev5UmjL2hALdrbzDdrcL DaAkAPgnP9P8aXyJGlRYyTaOozsG2Qepz6HtVi1he2R7WeZvMn/5aMc4HYVa8i4n09mMbrHZn5eR um7df8aDbm0KMRuJJpGjLRJAvyYHLE+nv9alkeBop1uoD5Ui4JY/d9xUjpBJYKls5VTkAqckE9ef 84qppqtJ58cwd0sxuTdz5hzzWcY6mHMr3Ej09GhTKzfO5Bbf8qg+35/mKnNvLbPOsMhL8IpJB6dg PXHrUi+TLKLeRnis4zlQhw0hPUZpJ1jslZV3Qyx48sk5DZPQ+9aGiZnzQQ3IMSQXEUsvEhB6j+n/ ANcVYgdoEQQQNO9vkoY+Fbtt9yKdqCiO2kmQP0yB7/1HtUaSeZaxSwb4FUYlZjnb61cUc3W5ZguI 0tLw3AlNxCu9EHWQk8AVBcQSXFhbnM9sskhLqHIwO271Htz2qoESa8JlSeSQKVijU7Sh7MfUYrUD SlLP7S+145MNgYBA6ZHpTdM6KEr7lZ2mgeyjvCZUZtgCgAhfU/pSnNqkdxCDKUlPK87qmbT7L+01 MskltauA7Nn5RnqfxNKsTon2NF8uKQkI7ceac9vShw0LlFFS4jH71pUlW1GGYsc7snse/wBKvXiS SPALWQL5IBH+0cdDSRQFLWDT4SZFVyOTkgntmrd5bwJBFaSC4nuJfkIQ4x7Vi5a2NJLQyJmSW9jj kAknkTKsg+QsOqnv0pfLt3uVjs5Q1x13Z4J+np1qSWxZbgIySG5iA8sA9PT61aSySZDJFMoWD5mm IwGPfHtW7locijcgWOTEokPnf3SvJZvSqNzGZco9wsEM5EYdsnkdR+AFad4qpIbVZGW5QBgVHytm o1vpNRkhhht41htgAzPghiOufbNZGck+awxrO5MzTBJTaREAAEHzff6VDeQXMDrK0nn2yLuwDjyf c/yqzIy2zvClzcNBu3OrtyAT2PYelXDvW0SNIXMZb77jBUe/+NTI7aNFNWRkJ/pIeeRZ7TyuAWz8 vvgf55FWbRvLia6kdmsoSECDlt3c/Xp+tWXnVXkie3nWORAoOeX+n+e9RJG0MKpIjsrnGB/FVpGP PZjEkZL6dhGDG6gu2MBx6Adj706O3gEDsk/lb5DuQsd0ffP05ps9iEghEd3LO6EtNjAwvbHsOlWb VzIs1vGkMqoApYL8349+OnvQWpXCKRricW3kosuMcKOPc/571RUCLy4WgDrI5wQnJ9cGtHybVhtS UsiDoDyD6E0zUvLt5LN7dbh8tnaevTp/n2pGvLpYZPGzzWOoLHI62jcIzEf596tM73FxBNBiCS5P lEMOBjvVV5S0wgfejkfKexJ7Y9aaYXa1KAO9+nMQDYB54z696XKiraj57aO1ufmZo5wcNznZUcVq 5uY5ozcSlGJUsxIJ7j9atiFr1Tc28JjvrdFSXJ3BPQ+mSf8ACo4Ls2kosbdZp1xu35+4x+vX0xQl YxdMrKYkvXmihkcvxICeX/3T25qzPHJEJpIMHI5HQN9Pcd6Z9lmkie5nyNQbkAfKJPQY+nOKZbQ3 IsvtTRSli5XbnLN7gen61TREXrYuRokkZ8zJ3L1HQf8A16qzW6TbsuBAY9rccJg9T/8AWqzFcupW IQOGc7FJHQj+dQuHubmLzMWqo3zt6AeoqOU0epTP2K2nPkxiSFFAGBycYzjHer0kVo90l25uoJo1 wU38MvoR69ahnsYFt1li3JdzyEIhIDSDsB79T9KlvA+RKVb7oXCj7uB1qzGOlyvcRLOjSMjrbqwM jegqAr5iLLDDIIw+1ucBv8P59PSr0iWrNbz3YvYJWXIhV8bhjg46H/8AVUySwwbLeRhO0wyQOPMX tt9x3+lIhyZJZJbndI80cbygB0Bx5YHQEdM+9ULyKOC6jjgf/j5f5No5zjJqGa2nhufLlV3CHdgf Lu9vrWrPIkcNu1jbSS3kh2lDyRRY6VK2gC5lnhRUdVDOUweoI6n2qgLryftE0oeWSHqi/eQdifr0 /CnwJHtupN77YxvOD834Gpby+gtTA6afO0dygHmZ4f6f570/Z3HKr1GGG/N1HJb7ZoowJHI59/y5 6fWlluXkZZreOWKIyfKSMhyOo96S1Z7l5ZDKbZ5xhI+/B7e9XdNukuYANLhMrPkHechT3P0pPQin 7xUuDduFEkZBU7kGOv1Hf/69VraO0TYzWKGWc+WwIBznuPQn+tbhgkVWt3lZ3KcytzuJ7DuKxYbF JftkEfmpchBnDc4z39uT6daqMtLE1FrY0J7cQLJKHjELKOR3+nvWVEks91Yh0lUROxVlP38ggD8A f5Grr26xQqkjT+RCOFGc89TTppDaXVuki7baB+JBnjrnI9P8ahI64vVItyLdRzrFCA6uMbzjEPvV QpfRPLJHNusnwH39eP6Z/wAK1r5ILySKzjZ1eQDdyRj8aRYI2nmgkEp8hAfXd7isDslBMy45JENw n2Yylk6DHT+talzKsFrPBIVlSGISYQ/Mw7H6VVmaRLt7WVmed1DRrGuG+g7ZA/l71CtnL5gvWGJE fcoU85A9P6Vn7MxlLl2LUMnmJDsLJKmGJPQfUflVeWC6itLuZYhnONwXOT3GPyqC5uJ7gxz3JNr9 pPlktwD7+31qaeQrp88YefbADvyfmHuKuNIznXurNEV9HaZt9QA8yaX5E2nPI6jHt61Q3wLNC0dw TKDwTyG9h7inraysvlNHOdoDfIQGYegz3p81pZNqIgjDecqBo0B+81dtJWPKqxle6Ll3cGGC3Nra TlHfEhY52D1+np9asiP7MQscc0/ngdTuLE+melUIb0NaC0Mbt5cpVHJxn29yP8KfJO2pl51SaC30 9cvhvv44O0etcs0enHU1piI5YY73aYbj5VAOOfr9PStawjltY1ePMtx5m3cQSR1IJPYDpyRyeKxW gt5/ssoaWdbY+YuWPAI71s2W+S5ikENz9ncBWRTgfU+x/PkV5uLXuM9XL9KiP24/4JJWz/8ACzbq eNPKt/s0xYEcsdrAHPcfK3519W/8FSNNj1mT4PaVIvyXd9uLGQqFKbipI7gHJweOM9q+ZP8Agklb 3TfEC6mRZYLaK0uC/mAfvAfugenLfkBX03/wUo05dT+If7O1jJ58sd7rFvEUR9oRTKwcnPByrEAe 9f528Yr/AIXKnq/1P654d/3WmvI/nH+NsaP+1R+1NP519eWw8XXEJ8x9y7hJIMg9SSuOfb2rz2SK O4hKJOyyythUB4x6E9zmuu+K87zfHj9pSSSOT+zf+Erv1S6UnMqfapip45+7kg988dK4mGS3ubO3 js1mQShm3sPvDtjv6/pX9reGMf8AhIpn87ceVLZjMtwQtH9ktHnWOWSVXTILbyGzj8sjH4V9D/ts K+p/td/GENGiWmkPbWH7sY81IYEjGPQnaD+OO1eG+CtKfWfGPgfQ3+06jc6/rdpZ+TGwDqrTKAee 2SAcc9TXof7SM+paj+078dtSvoLyLzvElxbNI2ArGKRkOB68AfhX1lWnF4yMnuv+CfMxnJ4eUUeF SSXKzFbeGSUKuMAcA/Sr+nSNNJEJcQhuhxgMfT3q7FLZ/wClxGOVpfuHB/r2Pr+FZF2paFpYC4aM kY7kj+lfRRPDlGwLcWzl44ldYEY9ed2DyKN5e1ul+ySp5al4zuH7zPH9Kka0ijutJa6uFjeVg4RW xk46H1B/pWpDFF5NwjrJ9ncsFYtjaT9On4e1LmFGOpnGQBokg2zXBUcD+D8KglkYTwx2dvczSAEu 4IIB9Oa0ILaGPbJHG7lyUbnqB1x/nvVaK3kgLyb2muAx2AcCIdiwzzxxUqVzaUHYW2kit7qOC7SV 7cjLbGxz/Ue1QXLRQfaDbCWK5x8hY4+h+hp8UV1JNHlFW6mYxpk53e+P89as3mno8TRzyQyvdKEc EHG3065B9xSl5nPyN35RkFzP9hml+zyMsafLuP3G7n6UyxUwLI/l7kk53sTjPUn8vyzVryEsbTzJ bkqE5wx4x7+2KjRUtr123w3NjJHmSMnlc/5/nS66HTT6JkN200jQvPGltJGxAiT5WI7ZGepHTNU/ s81n5l4IftK7d8pJzgegz0PTmpb6CaZZo4kaVyfl8s8qD1JPep5bCWOFvPEnmovTPT6it4Ssc2Jj Jv3UZAMlxNDMh2hTlSRw/tWokzXYKKVjTOBg/Mrd+atXFpHb6dIixpPLtHy5/wA9cVnrFiOOdDti UfO3QqB/hTjJSCneFrssySwi9hS6tEnW3T93gAfN3J9c05rgt/oVvbuiscyKADlf/wBfSo5IluJ0 ugzYVQA4PFOaKJZ4TbI4JXD4PUdz+f6mol2KlK4kHmQS3EQj2wIudo4Of6UxrjU7NDAsSz2+7eDI udpPqey/400ymRbqCzgmnkt8szE8DPY0b2aKHTpnlRrpcE5zsqbFRk+5Ze6gcJK0jweZ8pjzhwe/ PYUfZVdMW4Z7wnGew9OKqRCCGQ213FLMJ/3QIHII/l0/lWlGkljaBYEa6aZtrSKfue3tjp+NEloO MXcgvbG/ZUty7PI2A+0Y4/pVdZ2mW4t7eOS4jtxyGPp1APbmpolvILpofOeRyP3RlYtjjo396r1r p5j82cDZaJ+8mOeffP0/LpUR0NOVmEs0b3ERQTxvOceXnIb/APXVt4Tdwn7KTBNN8rEknGP1BPtU vlSQxSTWfl+crkggfeHtnp+NPgD2drNNcvtjizIePm9//rU5bGcpW0ILS2K+aZDMVZdqGR8hiP8A 9dK0MFpKt2xWT7R8gQcZarr22nSwQNHcSxh23ABjukzyRntUDSLLcMn2RwLU74d38Tfh1zWRcag6 KP7GzwOWna4XcE6Ng9h/SppP3cu9TG8YPQjpVW5jM0MzR3EYuHO0gdVP/wBb+hpdRmureGDbbtO6 IEjUDBY+vvUcprVbtqTEvLBLMsgVI5PLAIwT7/So5oXSNITIJbl8ZKjA9gM9DVSV5ZNOVGs7hLh5 MtFkKy/l/nmtCzgSS3jQTn7PBksxOXyeq/ga05epjTd2Rz/aLWSa3CSLbxqGbdwWJ7Z7UlwrmNf9 IEEW3IkxgA9xxznpz9KqziS7c/O0O47F7gAHqRSfZdrsEkeaNiFQk9+4PrVuBNTEcrua8F1Gm1GC TBlB3Fc7ffHes/8AfRzhriOQujbnkB+UDHcelalzmSzj2IVlgUr2DHAxwf8APaseM5jt7K5SWeO5 OFmByG/2T6/41zq9zoctLjS08N9IlopmjVfO8xjlce3f/wDXTmaJ2ZZLd7bz0xcF2wVHbjt9R6j0 p0ttBbXcASO4V0PzZbI29qfc2xuLozl2YYAJBxux0HtXRB9CfaDbS0Nnazy3BfE42xx7s7h6/WoR pguYWhYGC4jHmYY5LZ9Pzp6i8u547SFCzkliVXhfbHrVu2uk8lESCR5bVid7Hhs8ce/+IoqbEyd2 UZ7m8MqoiyziJdkqqPuf54pbiTdII7RJXZlHzj5gp7/r/hV++N1KscgYmSBsnYMYX3+lZjyW8LwL DIHhhbzHKZ+bI6ep70qa0JfYHV1SL7Q29ozuLj0q/NcQWdjJPdkBgm7kgbR2apIbm0Zz9qUiKdSC BjMI/vGqgskiZrqRBfWsXCh+Vz7+o7VmzSGiJPOdbIzMvmbBukEfBCnpjngn1ojtl0+5kYxiR7ld 7Eeh5wR2q3JdqZm+ZIJdoMnGfl7A/Q/yqDT5wPtBUOs2SqORkE+w/wA9qES6qK8EE6zENdGCF2y7 ngKO30+tMa1YI8kMjXUZJ2nPJNJmaeK4Mlw0+R5UkScBVz1Hoe2farUUH2VbZra6igBckmTkfT65 ppdzJTvoU7aKczNDexkiD5kHb6NUk8vkvd3EKl5o12gNyqgex4/lWtHbwaWzBbmW6tZP3j5bPkk9 SSe3+FNkUzQKIbcXMMjbVKn7341nKep1ci5TOV9z+UzMp2iQYJ+fP86ghkcGSGdwLSD9427qM1oT 2z2JFqtuzx9Q27Iyf5VRmWa2tZIpAXtHJZH6kfU960p6nm1VrZEF40kyMmlx3C28x3GZSDtx1569 cdOlSPGsVlNAWuG+QZYuSU/2s1PANwxDNHAzRjYp6SD29TT5NStpEjibAkjOXVeso9B706kUOF0V kV/JjdriO4ltlyy45A7H/PpTVvpodsd5FsgDco4+YA9/5Y+taErW1pJPiRGhMIlAB++T0GapfZkR 3klhnWaVBkMThvQD0P8A9as0rFybZcs5Ss7Isi/ZUySGHf2zVMQveI1sLaLzSSyuq481fQdwferl rbvG6s0YYznaFbk/Q/4VXuW8q6dJRJGB8xdTjb64x0xSUtTopR93UtW8UJQJPBMyZwYwQW98EnH0 9KjEcg08NNBNFEwJw45x0xUkYjWKGWSQpBE+FDNy5Oefce3aoJ5vMmkOZd6gJHJn5D1+Uj2/rUy3 1OjWxRa1URS+Qs8hn+TdnAx7HtWppdrbW181lM5Z5RgqTlhmoftANrHHJcBPOJWX5D90dvb6iqy2 0FvPZT2q3OVc7tz7mZev/wCr8PStbHNO90mLFbSS5tBaPCpzuZsHbz1FRT6abl5J5rkmPTlGEH3m HTKn/JrckCSeS8Em37Qegbn6fWqC201urCSR3WNs7cYPv9eO341nCVjSpRuZV3aWtzCkCNLBcTt8 u45VfUk/nWwkTWqSP5Ms7QR7vl+86juM9qtfaI4pXCwggqCFI5b/AOtSLOUtblTDcedcffAOCi9Q fQD/ACampPoa4VqJWnvBYJAZ3jk81snI++PSnuywagLwLNJvAG84xb8cZHfjj8aq3unzyx2V5dQu yRfvQgI3Jx8p/EH+Wac/2C5ht4RIxu2bDLuwSO3H5/rSSN6mId7IliaBY7hLVJLdy24gn7xz1/Hr QkhQLAJMO53FEHz49auLZMkYSz2/bDk4cbg34f54rKnht7aVZd1xC90cSS7vmiwfX6ikRCtK9jRn ktTLcaeDiMxB2wfmbP60i6JYxOpt1uHmQDP7w/Ln0Hr+tS3dqICkcNvKYpwQZFfnP888/SoLjz1k hMErQgL8pc8t7+4pRNZxVyq1zZKHidGAmcjcw4U/0qM2aWM7SIkiTyDEYZs7z/hTbaW3g1ASxwNJ CGIlkkb5V46gfX9K0bmJBuV0lc4JfaTuUeo74+lUZzVomfBdQzZjlBjmc9H5IPqPb29KtT2k73Kl 3h+zuoAdk3BR3z61BcxQRalYSuCkjfdYHg/hWqZHkaONgJWkbB28Fh7VlJGVKfca8sIih+z2zlWb arAj956ioLcRRyyS3du39oxD5Qh6A9BjpnGPzpnyx2zi7juIEtyXiyc5Oee/+eKieO3g2HUZvs9z Ou8qcjCnpx24zSjG5pUlfQq26tPcFJxIz/fSMfeUnv8AjT+PJN1G119rtT8is5we2MZxj6+1XfID X5m3MsKL8u48t/8AW9qrRRxlrhmaWVlcjcD95v7oHYinKJxSjqMV4pbxZnbLxYLnHH0Ap8kF59uD QbdiqD7SZHHvjvVt7SCezXYssDO2WQDl/pjpUfmwrpEz263EUYUqecsOfX6/lxWMpWOigiRY5IEZ JZGLRrukO3jk/wAv/rUoeJJN4cBo1yB1I9D71IyPuUbnlVIl3c8sf6f/AFqgksHt3kP2VvJmXc3P XPOAeoPQ/jTiy61N2GwSXUwdyYo5lGdqrgt6Y96pzpJCVOxjEGBY44Oe1Ps52uUkgZXPzECYcYx/ h0q1PPHE7I5Nu6J8yseZAfQf56GrcSacrRKq3NrFcpCyzh5DujVj1OO3oOD7VZaWaba9xbXiQqAd oYA5PTB9/wDCi6CNCltaEK9xgDf1UnvnsPSqlrHdoVtCTHqEbEJuJ2exI7ipsZOT5gWzaS4jM05M CHPlqMMw+vp/9enPcvPFH5qlRbuRz0A/w/8ArVemgLzGzE8jJI2CqcMzemafb2zzPEGeJJon+ViD tX0yO9BvBJmRbxi3vnWCQWb3ALMkvzFvXHpipbdLON5xfwylwc8vjir8N80iE+WXELHIBA3c44Pv 1+lUWxFdwvMyP5p+RcHbn39qBONi5HE6WDNEjztOSRFIc4Ht6Vn26ujGG4gma2JLEFs7c9cVfgd7 o3NxcTb1f5WRRgkD0/z2qVJ4Alyk0blgMg8bUz3P4fzoN3JNK5TjCWOWheSSJuXQfeI9s1MDbzvO ChffhDjPPoPY1kJO0lzJBAGkSBcg4/zxWtbQs/kSrJG+/wCVNvc+n1rKS1Oa3QilkEbqAqtEBgbR 19ae0TRMqG3aeJlDBlxjFStHEd9kkkhkkJHA5J9B70iTtdrJb26SMCMNj+EdMfWoNXBJGTOsCWW+ xL3boW87aciLnj8etQnyB/B8iKMnHArY+zm3jVrSRVigUk5HQ9yx9P5VWhAvLETq0UU10SsW/wDi I7Y79DV+16nPKk27IpPDZ2tsZ4t09xzIo38Eeh/lX4Lf8FQWuV+MPg+1ijnhkXQUeQNgOkjO/PHG 0oEx9R3Br977sWyqbaaFpVC7HKgbHBHQj1xX8/n/AAUukjP7RWn6fBeobay8NWvn4ZmbLNLhcn3H 8q/OfEWvy4GS76H6FwLS/wBqXkfnhI9vHs3yeU0SfOCMGqCWThrg25EzKu7HpW6NHik0aS9kvIIf Ik2bv4iT2xWJbxPIki2ofzT8rjPOPWv5mk2j9r2GQO1zG6QR2yzbMlduA1RPPNcQqqhQuzbk8Z/z 61FGv2e9cTKUSNe38Rp7SFWZoYxLn5QnY57UoyERPeeUyRIWeErhkA596jls5I4Wu7czFEbOAckG o5AWT5oncxdWA4FadrbT2sJkUSMiYdg38WfStXLubiz/AOkOslwj+bIgAwcYq9p00KzxSXLq8/8A dYZX2/Cs2WW2llRC72vl/OrHPJ9Kkjtrp5mlUxESZ5JwF+vp+FYSfUaR+tn7Mmpazpf7Nfj5BaT3 txcQytZ2qJgqS/zvvP3VIx7gbfevyVuLS/jknnklSV45mRhGMblBNfrL8INIjX9jTXr68vLyBnS8 dI8sNxXICgjnLFSMZxwOuOPye1F72aW5lMqpDKxDADGwZ6ivyngeopZriZL+tz9d4xusjw8WQszl TK0YaFxg8fd9fxqW2lRT5NtIxwMuN2eKhgmuY0d0VSi8DcOvpVaSZ7cxywhFnuGwwA4Ir9dsfjTZ 0Vw6y3KrZsBaxAKFJ5z3yfWrkc94Xzud0TA642fU1ghmKERQ7Wcktx8p/wDr1Zgn3OioMoww27ua nkRklrobUtxMztI8e5duA4PDj6f57VArwrawy+cUeZisg9h3FVriE20gZGJhXogNQ6jA/m2EceNj tuKeh7k+1Q4mjhodXYQIzCFQwRk3KzH73tWuJy9khlVUVzscEcY/DvXJabePeSXCOwb7OPlGMYH9 a1rm72Bot3nxFex+UUKHQwcdTRmv0gtRbkxxJdkoTKm41jeYywSW6RpO7fdIHB9BRcTLN/os8Ujq i8uo+YelY6rOu7Cn5yQoXOB7040+oHSW2ozughhd4o/+WrKOVx/Kum0/XJ5baazYeTbpwNnBY5/n 615jp99PBcETq/kAfMOhIraMoiMLxCSdLj7qqcc/41NW8djOVCMtWjtbTX5ra+E2/wCf7qMnbFPh 8TXiQXthZXc1tC8hc5JUE55LAde+Ca4qGW6ZrhCFbzB94DG36elTyTpcQQxGBg9u2ct94j0qIVZb XNY4Om90eiaf4t1SW+il00wp9iwFm2AkkEbsGv0O+DH7Tlrbanb3Woa7caBrenOstpIl20c8LKRz EVx27Yx17E5/LfTZXtS0KQM6l8q3TB+n+etdDPd28e1WaSK9bGHUkNH9PesqqvoddRJx5Wf3z/sA /wDBUfRb+w0vwr468e6R4Mu3jIjv9TcLZXDA4DkjG3cQAR2bHODX9IvgLxTfePrXT9Rvfir8Ndb8 KrAJXGh6hFILhSP4iCcL1/i7Gv8AIB0Hx9c6X51tBqM0sEueTIWC565BznP/ANfrXqEf7RXjuxsY 7TQ/FniPTVtQUAW+l8oKVK4KliMDJOTk+9ediuEsJibTc+V+lziw1SvQ92hH3T/Te/bg/wCCv/7K P7HegX/hzQPG3hf4vfHS7t5F0jwrod6lyI5FB5upYyViRdpLLnfxjAB3D8fP+CF3jXx9+0V+2z+0 H+0D8ab19d+IXjbQzeyELtS0R7j5RHjogEaqAO2K/iH8B+MrGDxPZavfCbVJIpPM+0GUs7HPzAux Lc5PPSv6Vf8Aglf/AMFbv2e/2FLP4u+MviD4M8c+P9X8VWUGnaQNKESIvkvIzIxcgoDvQD5WYlTx jBPCuEYU1JULzZ6OYZm1T5Xof3ieP9Kj1T+wQ8i2qWVyX844/dgjHGfXp+Iru9JgittM02CFQsUE CIvHQACv4xNc/wCDmnW/iH42sX0jwH4F8EeALW5aJbC6uJJb+6AIO7e6BD34AGOpx1r9uPg7/wAF y/2FfiHpdu/jTx5d/CfVEtjJNJrcCpZu4AJRJkZlLHPGeOOtfEf6kY6k3OUL3OuPEVGUVF6JH//R /GH9p349+KvDniO98HN4d8PJbataR7LaWMzTYOHLEggcAADv97058s/Zgvz4h8f6lPP4d1S7hgtv 9DnMObaG5Zto68E7PMHsdtbPxckkivr6+8WvLc61bWqQWFvNCNydeW43HgkZzmvaPgZc+D/A3hyD w1AiJ4+1KImWzQ4eLcQd8jEYCgnnuCR1Jr+pMfjI4nExhy3ij8/wmXTweDnK+r7Hsvj+zvZYdO8L aHp095q2uuwvGtox5VmnBLHP8WScsePqcA9h4b8PNYWlrZvCIIhlFQNudx13Mx5JJ7nnrXPaNomq x69Nq/26S+/tdfJcMGXaAOFUc/LnoOPXr19BsCdQ1FraWzuLdbVfLd2bHmdsAev+NfqGRRcXecbL ofkue2aUYO76njmu6la6f8Q/AEN9ezWcOptPDiUKyTHhUwCeudxAHpzxivcYYo3jEf2g3do4DIyH hfqe4P8AhXivxR0yDxT428KeH7RrA6b4cnW8laI7ZZJFAKMjDPG75GXGCK9L1DW28GaO99qdnJJF bL5oiUD5dx7juuT09xX0dOr+8bR4cqf7pRZ4n8VbbxFqviLwFpuieJbrwvqen6g927WszIZIFUDl Bw+SQOeuW9K+iIr6e2juGu7e4a+SIQ7+hJUds9DwM/XrXlnhnSrXXdeufGfkldRubMWCTSDkwbt/ y88ZJIyMHBIr1u8uLWxbS554p4284R+UwyZ+MjHHAwCfyr0IyuzglTtCx8vftO/ECXwr8NbjTbBx c6j4nkS1kIGBChy5znoxKKAemTXov7LXw0TwF4WtdSkgIvdWhi1C8BhVBIzoeg5yMPjJr50+LU+m +OfimkL3NhYWQuU8PxLPxBM3mYkcp02knHXPGehr7c8LeIoo9HtdIijispfD8Rju7q4nURKicL16 YGBjJPTivz/iKt7av7Pax+o5BgXhcFGpLeWv+Rm/FnzofhH4kv7v+zxFvFus0i4hjlzkFx2GVJHu MGvgi58Q2nwBsfDeqeHIEmutdzcyafOzSOrnaSVGeSc4HUdcZ6V9w+MvG+i+Ivhf8TvCVlcRXH2e 0/18p/cTSuSoCEZDMDjoc89B38h+Hfwha5tvDHjXxtDpWseJbJI/s7xxkpZwKMxjk4L88nnGcdyT 8tltNvFulDWx7OPrQjhvaTH+CfHfiybUvDFz4iWFtE8WwtJGse5DZsAWweSDxkHBwCBzX158Q9Wt PCvwl063v7i0sJ/GGoRRxNI5HnW6kO5wpG4cFeTwc+lfKPxmjl0zTNFiJfS77Xr1be1kLiMOCOQh PAwPXj2OMU39pvwv8RPiBY+BtT8B2p1r4f3CJotkbBzGYZgp+0TOT3I6k4IORtNehxLmPsYxw03r I4+HsBGvKWJhHRHOeHbT/hNviJrHxN1CJD4c8NQtaaYsYUI21SPMKn5SRnIY85btiuC+HekQ/GDx Zp2sYubzSrCVJboI33TlvJRs84BG4gdxXrer6VYaL8PtO8CR+dbLp1uZ7oJLukZFfJkG3GWZlbPY /pVPwZpEfw/8IeJddjdrF/FTJNEUz+62g7Mer4bJxgDPrzXXltGNOmk9+p5+NcpzfY9B17xVc6d9 r0fwqI9e8UyMyC1WUAhx13nqi85J9PfivmONPE+v/EQ+HNKuJ9O1u9TytSmWISTJvHzIozhMDoRj HXOa+kmtLHwb4G1jxVqK6e/jSXTheQ29q+Gu5G/1MYwPfkdjn0rF+Enha/8AD3h208VeJLW40XxR r+Ck1wyPPIcAqXYE8Lv4XPv1rqx+aKpTdJMWQ5JVw1T28YXXfyOlsvhZfeCdU0nTHgkGiaXbLdRy NP5kdy7LhmIYlickn6ivUJYXURxxRywXs6ggqNsY4GBge39KwNL0iV9UOq6ldXF9NdxLFI3mMQAC ccdsZ/XHOK7O4aKbKAShrcZGR97Hb8ufyr6XhHLnRpc9Rav8jw+MM9eJq+zg/dX5kE8moW9nM8Mc dxMqkR/LkSH6Go7d91uIlgDzXBC4xjkdQP8A61WIr5x5MsoVoE/1YVcEn/GtG0uoreVxKoQv+8+U fMnv/MV9u/dR8DywqStcxY5TZlI71YxDckg+WOQfcdqt2ltbptlV2dpG2bpDwufX1/8A1VyvxN8b aJ4S0RtXkuP7VtpnEMUdqQWMx/g3Dox6Cm+EdWvdV8NW+v6npUmhTzsd9tNIGKgcjAHQkEE9uozx WCqqRtVwbpvujqJRdXpkt0uVQx52SL0Ujg57kCsWKe/Z1cMMI+HyuenrmqXijxQ/hTSr3WLTT7jU Li1jEht0+9jOM/rz14BroPDt5pd1YjUUuYbhbyMSC4x+7UH2/Otac0lqY8jktCR8Oz7XjkRsfdBw pqRvKkmu5nS5H2OICMRkfMw7Ht+dS3DC6El1p8ckCRHksvDkfyB7fhVYsYislvGIiG3SqTnFaRmj jq0rbA1zLOsdwE+xyj5AhA47Z9DUKWz2qwxWoeSOB90zOcp9SD2znjnqPSqWt65oenYu5rtxBDj5 T/G5/hHuen+NTeHdUbV9LuY1t7q1uM+aEnQB8N0GQSD9K1c0VQpyujpLvy4o4Y40aO3l7fzxWRc/ YNHtby+ilkdgPMuAScInYe3fml3tcRzokzSzWy/eBOD6Aen9au29u9po988AieO9XypROnmA56gD 8elc2IqKMbnbGT5uWxzmmalp+tWpvEWa2E23EMkm4x5GQQw4GeeldJHHaC8gkfTg8sBBYPgeYe2P as3TNMsYyEnD2oKkABsbcHqfqOlTyWrSW0jrFOwlYxxvvwAAe+Pb9SKqjK6TOOvL3mFw/mGWCXET xc5jHWrFtFZXUts0sc2YBuKl+Jvb+tFnDb3SJJMxdBJsV14O4e3f+tQOttY3Ae582MAnBJ+V/p71 1tW0OenUvK5caxtZSsllBcNHbZ5DcFvT/Oe3pVYWTys0STJhfmXd1yeq/Wo2uLm7VVt4Z4ITksp4 U+5x/npTY5Lv7Wk6FY7cNsXIzn1J9qRVSSeiJo7CK7QyxqNxXytpbOdvU+nNXvLlSa1jlnSNCQsW 7+JsZxz1HHT61BbLJFB8wll8p8bgOVHvUKy3Nza3O63uLq2hlwyrwVOezdqVr7l0afLsMu7maN/3 FoVuGypXPyn0+lKIbq1dba6kF3cPH5gWMfNIT2A/z0q3FbSmaOMxvI5b0xvHoKLmNpp1v5GV3A2g 5xsVemTRy9Tdx1HQSLM6yWJM8cGBxg7W7g/j2qlq121xAjxRrDcRHDHAGwDufrWrHbQwwJdCfEr5 KYztUnqSO47VmSCx+0wXdyk32mM7Ww3yexx09evtTilcMQ5RhyovnzrnTooYId1xuLM0f+sz6e3/ ANep47S2tIIrq5bytRuZNiIScsf8+lNkQW32gQswjcA71Jxgjv8A41Uhsxc21vMRdsLJ2dmLnK+/ uOeB24okYRtYSC6jiu5Le8haKVuSd3C+xGev0qO78+d382Ce3ReYsn7y+vHWtG0ihbMiXltcXwPy AjgnsMf5zg1SgL3ZXTJX8qcMXiYj7+eo+taKmC21EWN1ZLedGNpKNxeM4+X/AD7U/TBaiezupzOh tpWAy3TIx0+mc+tXNHsZ7u8NmpE6Rj769FYdjUd5bQW9xFL5uRavmZQD8hHAI9fpXHjK0HF05dTo wMJRnGpHozFuLldC1BdK1ZolluWWG4kTIKlsGMrk8EhuM9dw9q0Fkl877RGqxW0XDKp++emD79Px r0fx7pNrqMJubuG11HVLzTYfJuoSN0RQnaDxjhQPXrg9K8ztJpbG4t7O5MSveRBJJowdm4DkkEkg evXrxXw/DOO9lOVCT0Z+lcXYP29KGIitVv6HR22oaHp+ieMrfWL20s7TVbNJA8/P2cxyKeB/tYxx 6+1UxFG5SytrhkjeP92gyT06n24pn9naf4otr7wtqNs5hu13FgQuAOck+mQD+VYXhnV9Lv8ARbXU 9PvGuo7Ym38lUMbQSJwyHPuOPbB7168OWGO9T52TnUwFuiNHO9hzGHtGKsGXLMR/n+dWkuprJFNg Zrc8+YM88+hHSk05bnyryV7YR728wOQDuJ67f0qWW1so7e4vHkmZn5dFc7vqvoa+lq04zi4zV0fN Uq8qclODs0XYYLdbKa6ikmFpIWZvNOcsT8xL92Jzkk5PfrmszRtM1FYdS1KKcwRx/eV+QQT1z26i ur0a6tNOit5YYbe6TUWMTQSoGWRsZ+YH6c15vofirxBruia5pmrabB4f8ROJLSS2jyI4XGRG6lt2 0kYb6Hvivz3LsyqYKvPDx1j0P0DMsDTxtKFed1JLU6RLaF7g21w6iSHEm9eFOe3rxUWnWNs0tzp9 zHLJFcSZjZGIduenrWFoeqnV9Js7qNRd3Fvi2llTITeqgMcE5xnIJPWuiMyFZtQbz4I7LbcG4iBL R+XzlQOScDp0r7z6zz0OdPdf1+J8P7BRrcltmU7ZLRp9Sd2kS2lnZYy4PzEcDn6L29BXUxajpvhs 6TcalIkeoxrJLdhnZN0W5SgxnAxtzu68kcVV8HT3tzd6Rbxx2E9j5gLqIycDOcdevasu5F1Jq9/c zXEV4bucoqxNuWOJSQmWODkjGQOnHXrX5nnmBeKpPDbXP0nJsVHDy+s9je8caxBrfxInnsrK/K+I NNtQ0iHYbciM7VIBwDncMr1rI8QW9rZeKY1ltBpGo6vZpJ88eBcMMg59RgZx7j0ps8+o2fjZ76Yz T2ItYmtMQhFRF3gkH+I5bb7bR2INM1pbOaTwxq19J/aF/pl1eLazyMWBLoAh5/u7SBzzvNfKYfGS wNOnRir62PppUPrU6lWTtpc9T+Ht7pkskngvXzIthqY329wyDdpsxPDY+9sJwpx2ORnpXIxaNqOl +I7h51NveWkpI2ybCzclQPQ4/wA8VmabqCGa3uHmKuh+aQc49sV1XiX4m3rQaY1v4b1DxBc6fE8o S2KBpigC46cY4JHJIr6niV1MFF11H3JLU+ayGNPGSjSm/ei9D5Y+JGsanpln4ZvNK0/VY7uW6kiK 3R/dz44dJOepIyrDPQ468+veBdSvtS8c/Dd9JI1fwtrV4thqdrJDuNsjNjeRnDjdwVOeRxjFM8P6 9aTW2matqB0s6dfRvcyxXyr5a7sgDknBxxkfpjNee+G9I0j4U67B8XtJ1vVU+FN2yXOo28aGUWF4 HALLglgrNyDyGIB4xX4RRzqlgJzj9mS37M/aKmVzxkYN6OPTufRHjKPTtN8PeE/AvnXVld/2tcai 9onH7lC/lZYf7e4/8Ar5q+KN94JvdDvTJ4+0LSNc0W4hmsIftQkn86KVWyFBxztK8/3q2f2mPh74 p+IHxK14aT411PQvBr2NvNa3Fi3zShwGkQpkfL8zDJB+969ee8G/BX4b6Cyf8SSzCFd5uLtQ0qk5 yVPRSdxIPY5PU1+h8BYSticunJq976nwXHWIpYfHUkpWt0Ol0TxQfHPgzU7Xw7Bc6fp1rvSS7t5h 50zt8xVSOgBIPTnd6VpeGdEnh0WzEqWzXksKuRHxJORwc89Cckc9zXlX7PXhjUPC9j4s8F6zdw2d 94f1aeCBY2P+lqH5cep57/3SO1eu6G7TW0xtVu7SbSrmVGSUgjZkbMDtnJP6V9zwtlsaDunc+Q4t zmVVOk422PYrPSrTWvhdrul38ksV9bu15ZuBuT5QQwIPGQCef90V5/Y20GnaXoFpFE0dgtqpSFuW XI3YB9BkAewrsNL/ALL8L2niHVNTe/mtbnTjM6eYWVzk5VBzjIJz07Vzu3zYrW7t8z/ZCOS3C5PC /QZx+Fc2V0l/bNWR35riv+ESjC+p3HgO50wXXxIsvEF6NL0jVvB97b3Fxkkxgr8m0eu4Hnt+FeXW 62Y0HQJrPS7mFLVmWNzIWWdR/vcn8enFei3dzplt4J8f6fdQw6jP400oWNqdwQwK0y+b7/wleOcM a5Zra0hkkiN/FNp6YjhfGBGq8An2x6elXwtGc87rSeyMeJ5xWR0oLdlW0lnuLV4oY1jG8/Njkitb VZLxtI8OTR5kjmupklXdxGqKCD75LYx0qsunoznyYp5VcYd1PHH+f1FQXFtemDSryCOa4gtbox+o hLAjcfQn7oPvX6bnKvBS7H5tw9eNRw7lTXvDqeL9HuYZ4Hf5P9HkjXEkL7SOPqGK++7uK0o9SQ21 5dtE7XcgCFCcgY7Adj649q29OMtnaaxcxzhZoLSQpnHyswKqfpkiuXZJIdOEV8okaOEbivBDnlm/ X8q8jB3eNSPax8rYC4y7vCzwJZSSpJne8LvlCcdcV558S/D8l54z+FvjOSbUoZYHm02a1XDCQSRE qxOflVQjH1rvraCd7qOARjzNoZcp83P9Kf8AE7WtasvBPg6aO0tL21stXdLqVrdmkt4lXDbNuWLY bGPc9uK7+KKyoUoytfU4+EYOrXlFu2hNIEuYFH2oPFHCCpjyCRjsex9667xfoyz3Xhy/mmEEK2Qi hRxuZiGLMrdPlO5T+XTvygcXNvaXGnSRTxKdiMjcMy8EH8a6HW5dY/4lGqT3CixuIXtIomjGd6lS fqMY9egxXl5zNuNKcHpc6Mlhyzq05HM+MdJ1i88C+Kbzw40thLAqBZYFG+NxIPu447Gtn7XBpeh3 MkN5Aly0oKlkB87r19Bx2Iq7qd68ejyWrtPaQSAJI6fdTLKeV9SVH1IFX9K0ptO0JbbxAqWr6dqa N5oI+V33BRnkjBwOo79OleDmuJcXKT6H0uUYNSjGnEq+LvscB8I7DOl5qVpItzDsAYxg/KshI4Ck scjnp61k3c8Giw6ZYxSXENrfMWuQ5yvGNufQZznHtmtTxVrMcet6Lpkpe7me1aOJNw3ToTu+boTj OAQcjj0zWOmof25LJPd6RPpvksbeEsQwlC9wP8a8nhau6vNR7s9bPcP7CKrPojX0pXg16xmmEs8V qxuTtAYKFBP3e4PAwO5HauggvdO1/wAB+M9Ui1qOC+1y9ikjguIziTNwoCo4GCx5ygHAANcjpuyx S61HfdSW1rE7xywk74XCnGMcnkYxUWkeFbm/8EXEUc9+994fhS+jVZkDrtfcHP0xuGP7mK9HjeHw RXQ87grWMpPqSapbuPOuYUncXMh8gb/Q+p6+/Ss+G3u4vGMkdxPcrZRpDmJn3JbF1G7gdnxn6Anr XZW1tp16oi0+5fULa4J+zSqTiX0xnkCuetbR28Rax41uYb6K1iQxmIOTHNEgAUAf3iVHzEcHgda7 cxzOMcNCN9kY5ZlkpYupJrdnP+C4kg8Ora/ap75vtMs8ZYYd1dz09s5x7Fa9F8ESaRHe6paa0NRt tLubWSK++z/60IyMMr6sCc4PtXn9nFNOl5PPPP5k9/IlugGBHEeQvHYEkA8k478mu803UYPD3hzX 5brTbq9+yoykp+8Jz2wMknFXiMWp5PKUetznWEcM3jB9DD8X3djH4S06e/uX8OLqM88xUq0rMkUR IGUyQzAtkDplR3xVJpIXgtIlMcUcUKru3BhIuBgqR0J616B4h0S01Twtptndu8enXlpJbLs+YwyH gtzn5h3znp7V5LobpJp+l6ZcW8cMOl2wt1kUYOFGFyeuAgAye+ea+U8NrxxUufdn0viL7+EShsjp tAsIrrxRpiCdkt522srnkjB+56E/yqPV7aWDX9auLlb3yY9Qkt5VnTbiJfuAdicg8+gU96TTby00 7VJbp4bp5IFVdo6r/tLngmtjWdNt9PvCZ0uEi1Am7iDOfnL8swB6+vpzX6bm91j6Tex+b5NK+X1Y IwvNvYdxhgMqRtwRg5HbPtjFWEsRPFcy3twLSBeYwx3O2epX+mcYqzHYkSyeYZPJdQynoCKS5tYJ WKrM80sXIwPlB/z1r62C0Pkp0tLFNYU04W832mIsV5crjj3H+ehpwtr6WSGOJ2aC1Pmb2wQ+e3v+ PqKn+x+Y0bRv9pmjwX4yo9Mg9hUmn2e6eSKCzvXVsucPwgHX6D/63pWjMadPozO8qCAyzSXPmQ2g 3EAnOfQ1cEkeoIsrzIkRGxFB+ZzQgUGCWKIETOchhlZB9KzHiVFRWDQvC5bnv6Dj05rSEeplUjZ2 ZYs5Uu7m+SCE7oFA68AZx/n6itnOYk8llEiriKPbzvHf3+lVbfS5EjQ286xPdDLFvvJ7cf0ojmvJ CPl8y8iODsTOB2JApVDbCx0dynbw/atLSadyirK0c2zqAO/tS21pPaOVKx3FvKdwyOTmteOVJENn KVV7jmNQPmz7+uaoXDFklnaGaNLI5BVx83bj1/8Ar1KiXUnZaE8KxR3BlaOR7grwAeOPbp/kUyVY ZJ4pnTEKMTkjlfcVmRfapNShFvA1xHABJlTncCOuPxxz3q5bXXn5tHt5JZrUk7SeuTx9R7VqqbRx fW4t2RLFE93NC4bEMchO5eQ3sPcd6Lm3U3xuY2Usoy6KOgHc+1WFV5IxMhkdy/ESnaq/hVQyOL1m QmKZj5TA/wAXtTKKc91dSWsrWtvcTukhDfP8vOBlc9PcVYdUktrfY5ac/KNxzuYdQfXHpVyO5vJJ 2Mtt9whFHA8zHFRXJtYrh2kgd4ZcKuCMt6j8Pw61cWkD01GLFGbZolAaJGy0m7kE1V+0XkcdzaR+ b5brgNnB+tXXgdBJPMrJboOQfX0/Ki/tngIvGngkj2AKBnKj/a7U4vUzcistmGMbvcbo4BiJF4I/ 3j3q/Y7IvNc2yyMrbWfqVPXHtTpGtSxjtSX8mMOxGRnPp9Kt2skt5NNHGkdrCyghwOFPQn61dRaW Lov3is8vms5kSFEY5ww4A/xqhI8EKmGNJfIlJXzc8Bu49uMfmKsQLD59xFIHEMn7uGPPzM/fJ7/0 pJYoXnTSZYZLaVzypbAA9ePWsEraGtVXK95pyRTWUMSyxAjf+8yVk9vc57UrRzNM0ssd55KqQCG+ VMf5/UVoT3Rklt5WVvKtjtVWH3iOOMVUlhu7sqxkn8lZM7ITtGfrW0HoZPsBjS5slZiD5mSpx0x3 qDzTbGKCDesgXcS3O31OPStN3t4oLaMRXEaW5zKXbkj69h1/MVBdLapdrMLS6Y3qhEQScqBzmm4m dRjLfZgRBXXziFRM8k+317VsXMckdu07pDYT2/DjAOR6sPes65gglZLy584KhG1ITg8dx6HFSi9Z pr0XVlcRieYQxMjhjIp5B+v4cdOa8vFVeWcYdzqwsOaEn2M2WOSf7OUQpDnd1xuP+FWF09YkmkVp 0k2ZXedwJ9cen/1qgiOw3rbpbaJhsVTyzH/Z98c0l1O1jBDfzCa5sfNWKco/3FOfm/MY9ea6K9aN OLnLZE4KnOrNU4LVl62lRbkmJpg6KOGOUY/Snn7XPclVZJJI+fLCdfw7/wD1qddCyDETTxxK+Wie LKh1BAyueSfXjuKUXO2RFkt7ldzbFKjlfrUYXFwrQ54bHXjMLOhN06m5Tiusww/Z7czW0Lkk5Hzn 0HpT/LgubOS63eWsp2rC3UnvxVpy9qBBsEkTNkYH36rys8U1wi2rl0AKK4ycHuB36/rXYk73Z5kp XKdzLKfs7ITH5nynf91R6/59Ku3EUR3xWcEgnSENJl87j2x6f/XqzHBBKirI0iwN8rkn5vw9KnvV LYmtXj+ySr5ZK87cdea1TCNO6uZrWwE1sjLK0178mAeTjsPf6UyGOK4t1SETR29s5LyMchef4j7c 5qy9m19KszyMvmgBR0Jx3HoDU15aSRxqVVrfzFG9mOVOP/rVUpdCJ+6Vbie6ltV+02r7IxiJgBn6 +4x/OolEK2z3CI0s2duc8KPXFJJBdxwQmASxsCSu/kZ+npWpD5lq7z6lAksjqDti4Vif5cVBgncq 3LtDukgH2icxY8oclv8A9fSo9MR2sUUMHuFbe8S/eYZ6CklufsQSG5YLC7fM2PuZq/GLeKG1lSNX tkkOJ1OMtQdEXrqV3uWW+azluGj+0MAOP9WDyOB6Ci7+zySPNdEiysxgOv3pD3A/zxVSWGe0upPL kS6ub4gpkY3c9v0zipE0++VLlzH5bBtxDjO714q3FGf1ubbi1oTlJdMQy2kHnCdQ5XPOD05NVoLe 3tdwlhmS4ufmlhL8lD0z6DrV+6S/8uxjkvY/PPzJheo/z/KqCQwrfySvvmu0jC7Q3zKD0J9sZxVK KIlfqWba1NtZDzTI5kYpGVJGfanyTXMUCw7HEGCzKp+diepz2H/1qknH25LZdssaWD5443DpUc8s NsGE0hjtbVw5fnc2T0H+FVyo6YysTLPa21vJEFKu3/juf6mo447WK6jhdZZ47oYcr1j4zz6Ciyi+ 0i7vJnjR5m2LFjhVHf8AP+VI2mPiGGyee6VyVVweT68+3Ss5RsVzXiPvo5raGKWCObziTsUDLOB6 Ukln/HLJIkk4HzZxjPYntj1+lXL5p5BCjK8kSEASLxz3APY1DIZ3MdrMuy2ZuHYdM9Tx1qDMqXDX WoWvyiUG2fahzkccZ+p96bavJLInmktAjbcEfc46k/WtxLWKSP7QGdYoZPLk5xtA71FbCMF1ihZ0 R8qw53+2PX/GmXKPUyZb9oJIyltJc2RkC3EeeTHnn6CsjTJGkmuYIPNCzXUjKXOS2WPIPet68trV bpfPbKMA5RWwDg/cPu3TiufsbaGOWe0dbqD7NMwt8N87uGPOe5IH8q/mn6R3L9SpPrc/ZvBrm+sV E9jQ8Sy+T4f1dAVVLeBpizH7pAz/AIj8a/Nj9iy5vU+LHxPuJLmzXTYtPit7/wA1SJGC3DBQp9S2 csPU+nP6O6/Gq6bfW9whWOS3kGXGUc7ThT78V+bv7Cq3A8ffESxkmid201NzkgiTbKxfYef7y4HX mvyXwLjfNEfqviBb6hK5+muyf97dQq8sUZJO0f6oepHp0/OrVmktpEsrzRss46Ie59Pf27GnWyzw hioOxgN2eu36flzUEbR3FnIkURjXeV5P3xnt6V/eit0P5BcSK0ke1vXBkje3kG14sk59ME/xE9c1 PPDNG728E32KVxkqw3censferiWEciTb7eZIlAOQ3c9/bt9eKp/YknHlgube3fIdT82fY9j9auxM SD7ClrLLsnZhKgMcTDv3Pvz9KmWJLnMqIYJWwJGJzuH9AK1TELmGa3S1dpo/lSYHAHrn3H9RVKS3 mhWCL7dbXGwlsBcM2ex9h/Q0Mq3Ysiyht4yHYySyDKEH7w9qpw28Lv5oF35ith1yBt9x6f8A1quO PNFokkcnkRkgEtgg1NfASvbwGSO3MoCgAYJ/L19vesnLU0jEpzGKfdEiSqHG0sew/wAfcUlsmoR2 csUdnJfJuwoVsbcHP4/T3rQiRLdLZL1Jo5pZCiJxkf7X049+o4rNka6sZmvLS6ZIZyUjVzkFh19q 03NHFpXJDJFcXRtpFcSkK2FGDnuv/wCqmWP2eSYxr5xijkLMkj7m29OvTHp6VZeeKOC5nAY3UaAt DxvGe/0Pas99NiVDMrNudQz4bGM1VjmLEsxhvJisjCIqGi3DO329zVm1i0+xjjWacrKVLEO2S3f8 sUsVqm43DOy3AUFVc8D8PemxK0g2LD+8nfYAyZKEf0pSiXFdxs8YQGOVZbnLeYI06KpHBP8AL61X WCSxtI/Js7m3s9QYq67sllHOM/561avrh4XtQhWX5/3v+0vpV+6uFlhtoYzJEiN+9x1Qdf8AOKlp Gnsr7FG0jHntA8jLbyYIRxyT7H/PSoLsWweTMwkeAgsgPHPQH9eParbwW9xL5scciunDnOOP6VA9 rbx/bLQwyS3d4MO5ONg7AD161RjKkkislnZ6jPIXaUbEGEPVj/hVm08hmxbuyPp+csxzgdPz69aZ 9mFmqEMsh6sM/Mnpk9s1ea3guopBHbzLcSrjcpxxVydzDkZm20kInM8c/lSQEli33WH+NaFzJBd3 LTqpikQY+Q431WhigtpHK7dky7GDf8syP4j7E9qa0Za6SOxDnA+d2X5QPWoCStoRm3jsYpZWLF2f fwMAd8n61Wh33ET3cMDo3KyEn/WDtj3q/PaSIjTSTojQDLKScfU+1SQKL5hIwKWsAwz9F49Pf1rS MrIIojniBhgvGb90/wAo2+v+cUkEs09s9jbTiaeA4wx+ZM9Ae9V9QguYhLbRQXUysNyOp4HPTrx/ 9cVaFu1nHc3EwcvOipuXgNj0x3/+tRKWg4LULG2Yi4SOCSHIyZGOdx74pFLXt2ttCfMD/IWU/L+P r9PerM5wFYRulnOu1+fz/HP88UyWGGRJXsn2xJ8pGTkkcED3zU7vQ2i7Cx2yy/aEdZVsoMIpLZMx 7gfSprNUadltQ0cUHzfMdxf2/A0ycvbWcSSJKqzDAwcE+pFFmotvMmVjvZMkKMECr9mUpWK94Gtb x47OD7RbXeAyqMMx7hfQ571BFaG0US3MM6XDPtU44IHc+3/1q0JHglkaGMvHM6YVj/CaeVuY4LW1 uHuYl3gmRvnynce59PT0rMmpK+xG0hhdJypG4Y/H296WSN4iZkCTW2OfUnvVnbDLBi33u0bH5WI3 MP5VVWQw3CxTo3nxfOwP3WXt/WkVAqSvDCiPAk0c0XzkSMWA/wDrZq3bRRXCtLO1xP5hDYXh19/f PYUvmxpfQQgi5hZ8vhf9Wvv646UxJbqV3uLdWeBWKRcf6xh2zTaJlruTXVvFYSqWJmnmwFA52j39 e9UYri4uLi4VIJP3hEbIfvgdhkd/TFaklxFcKEKko4K8dc98e9Q+SyyRQxSSm2kQqu3lg3rn1qoX JqaFbfbSXNuCgF9bPuEOQeB0yO/b861J4pZGlMBIWNcgAdz/ACrFsIobCWd5JoZWk+U7lyw9Tu7C rFt9oWcuJ1lhlO0sDwnPf6elEld2RrQrqC1Nt7iyhkD+cGU7VfniLjGT9azrg2y6g6NHLKoj3llO B+PtUF39nmspwFeAIdv/AF2PpT9LuYmDw3kZW4UDIzggfw/5FSqdldFTxfM+W2hbCCfOy6ty7DaF K5+mR6f4Gqd5a3FyfMjRRKjcyHhRx3x+VW4LdYlEqh7cpIWywyW+lIx2G43rI9vKuCqHGP8A69I3 cEVNl1F9nnaeO7s0yZgUA8rHv+IqFLWG/vYIR5hgu32YDfe/GtOzNtC0Ub/PBjaCT949wPce9Zlv YzWb3k/nO4uDtVAOUHb/AD3q4HBWhroPu0ijtUWOaVYI5Shw3zNg+tTMkBjSYS/6ODtORk5/pU8l 46wNItqzywLncOQnuR/nrVKW4Vhp9xEDteTG0Dhj7jpj86cY9TdXRa82Ha+IZIPMXYVLfNjtz71V e0aZIobRZra1jO6WQnJJ9PYVctHuSru9m948LEDauR9D6VZjMMUblo5IFuW2nLHn6f3frSnGzFyX GRM9vG7q0LKBuRCgLY9c981mMgufImlV42iY5zwCO233z+lWRM4jmEz7IkJAfGMfWp4Q8VvM0qMs gww3DoD0b24pwXUc30KH2WRVCQJcZL73C4yw9Pp/9atSKJLyWKxe3d3iG7PTI+tWbdFnLRIS6yDn B2kA+h/wqNFyZoGeaBFbGQ2Gx6g9qmT1FGGlyjqsSaeSjyNscZV8cKcdDTraSSVY0nSeJQBgH/lp +HpUckSqyqkM1wqMd5DdB/j/AI1egtppW3eTK8SDlc/eH9KSRbv0MaATacsweCWW2nckHOBn2NS2 khXM8ySJ9s+Ukn5UA9u34VanvFuZDHGN0cHzY67T06enXioPsjGOMF2SKAlwTzuPtXRTVzy6kJKW hXime5maJCEgiJbOPm/P8q1L1rVt7OMXToF55H5VQe2TT77TgqvdC9BA2nBXA64645x+dWxb2st9 LBIr7wg+Ungn29CaVSC6HVhpO3vCxW8Nvp1ykz3Vz5cW8P689Of89KsWkSG2jhkdSyruAUY69j9K ZJA8oja4eT7JG2G8sBR07+1P02EPDKsbtc3kGSNvBx24PrWfLZHbCktCORZI/PKRth1wGxWarOZ4 41ikRrfD7WOS59R7exrTVJEl2FJhNbHdgnJ5/r/jUyWti886xxyw3LLnczFgCf8AP5VKdgq07aIy JY3WeC8RJJ2mkKtGzZBPtVu7ihkSHTrkys1s3m7s4LA9h6YqOBHgEcrQTy3JcqSvzYHfjvUtrHLN fJKFLrI3zhxksPb0rXc51JvQTToUtY5Lp7ob522HcOgXoP1NSGcXhkjkhngmQ5jf+97j3/8ArVL+ 7juX3BnLjt93A6D2PqamnkvVYrYxwK6Y4Kg7gf4T71zzjZnXGPumbBbxXLtGZ5XLHc7huSBWjKRb rHJud2ZtsaKOTj1qXyYbWB72JWZ7f5uvAY0JJbwWbJNud7gZ83osZ74HrTCMVEo3Fssl68ZYxxxI HLE8D6mrN7Bb2k6NbeXEk6gBzjDMOvH+etMhSLBVjKyRnd1yW96WWG01J1hfzI2nGzbuwxHt6H3p mc1e7KlrbeYJbe8SbJGRwC0gI42+/wBfanho5IksVSacRgFiCcDHr/nvTYNPuDOHjneNLNsddxYU 27s7e2EF3M873kjmPYjFcj1A6VqoIwU3HYstBc7Hee3eQyfKm0/cA6EY79qoKtzcymIPtc44x94e g9D7/Wr1rbyuFmkkkAgJOQ5xjHB/XH1oiaQyzPfkvbyn5FUBWx/9cdKmWmxK7ksP2iKR13xeQijJ 2/NnuM0hvLGR4VkEkNw7HJU4LADH0xj8qcGhSAiNHAnO0sTkADqf/r1UuFFzcTosCs1ugZCvG41m Pna0RBbwreWtxMztEIHKqScdO/09elb8cD3UBCgruTj/AG/pUM0ccNkXlRJ1CfvIVGCwxyD2ourt p7aOWLFngY2k4BP9BVS3PQj8JnRYnWae/VoYEbEf8LZ9sd8VanhSRkS7k2qT1UFc+9WJbi1kt2lu 4JSUTEfPytjr9arIJ544rsSGG3fJaJkyxA7j05xUkc3REC208K3kUM5EWMnbndIPapIbOWKdle2m dJxtyCAF9/artqqqUlAZ2ZuFHYduaqyXcs8gtokMEced2fvEdyPrWisXLRFCNZbkR2pafyIWI8wn hieuD14/wrQtprsW6FDFO8bnYegP19qTMCPB56SeRM5CpuwT/iMVbu4Bp9jGQksqSkhiygbVznOf 6/Spkzldupl3Ud3c3WnuzhraN94hC4Yn6+/9DV1nSWW9yqweQnmNuPBHt6VXRP3sP2a4M3nuAxLc Lx2HrnH5VBJA8M8mm3okkZZfMyp5YHoKtK6sRzliHdIqqsUuwnbE390nnI/z3p0GmzQusspkR5JC AHbIc9cY/Wr6WiLAiRB5lh5wPX0zVjlrd4DMfMdcE91B7/Ss2jaK0MqS0uLxXhhSWV7fliv8Q9Pa mQxR2d1HNMxmkKgDnoB05qxaXMyREpvlFqxViBnp6/yp19dwjy7qcbIHBCjpgj739KWtyJwVvMkX 7RqEs0sNuDsBZ8jiQei+9Zs8CXsiRwyyxZOWCEjZj1NaWlrbRxPfRtMjOxEasc4Pr7daltYSryZt JFafhmznd7D/AD3FFyKkLow/7OI1LzXlYQNhcIcA+4H1q27zsq2pUm1iYkRkfM3sPeo7p4v3ED2l yLaWQxjD/MD6Ej/IzU+o7oUhljci5kA3h/4V7H2+tawOektyDTUaeAxIY7cb2MbEbsj0+tXbYWkU E9rO4gQkkr0YepyOxp6ST2toGKw7A2S+AFXPtVd4migdruN0jJyd2MsP9k9j3rOS1O6m7bkki3EF 0rxv5tvIgAzz+IqN1E0s2ZPs/lx7nfPb296niWIwRWqROfKz8wbBAPrVCNzazwCRJLq6jkIMY6+2 fbFVGBnUlqTW5W6jluJZg4myg28EkdQPcVIq2Qsbm0vrnY5/iPUj2ojtriU2wijEDTSeWyt/D7// AFv5U6VC15c2DWzKYhy+4cDswPvx+dS0KNTUgimik5jjktliUeUWbAlIHT1z39s1Ze4gllhgd/sx vAYyTx5fHJ+tWYYLWIyJ9phBPzOzdvdfTmo5bS20+1MrxveoxPzqcKf/ANQx+dZKB2e1lbQjtJIT cSwWssqPHyAxy6j196nnZ4WkJsZ7iVefkPA98f561XXT4QY76SbYyJk7jgjiprPy7dbiONbiYFMh VfJZvxpuCM+Zt6lG7kXfbykq9wnI4+VhngYPp696tsxt7VrYETuxIO0YKn/PH4VNFKdQe3l3GK0c ESAoMgjvnqBTblYZp4oolFrsOF4+Zuep55z2q0VKxAzQvFbeWlwJg/O05Ax1Pvnp9fpU2nMtpHdz O0Xk7z7tk9QSe3SmFrWGaaKNJJHkXaArfMPoapabC/mTxSSGNYRuO8/e9KvlMYy10NP7BFJtuYy4 yfuEcN+FSIVso7yKJoBFOMurjLD1/DNT295dEkCNY/4VZwPm+h7GqSwvPNG926pEJBIwU87Mfr/+ usJnY4dS7BdhYIZ47eeVA2zAwDGfU+1aVkxnkNjYXKW8sZ3HepYvnP3f8KyfKt/tMQRpLi1c4BVs B/pXUabE9tfpPhEltuSXGDJ7ewFeXjvdpSfkduCl+8ivM/cn/gj/AGXl654hnkjkMrQSbGbPyoGY Ac9zknPcEelfRH/BQYaj/wANAfslra2ZvbSfxBaRzKCN3M7dM8A+hPfAryL/AIJFwzfafFU+zeJI GLMqkBcNjnPv/OvXv26tUEX7UP7LkUdvcXb6VqdncSRpj5szvg47kdvrX+dXEfvZ1Vk/5j+vsjko 4aD8j+YfV9Ulufih8br+8El1e614w1DzPWFkuZjtK9BgMcY9TVeWC7OLq0XZ5zbGzztA6H/PtWL4 afUda1P4k319bPBdap4rvp/NckE7p5GfGOeSVwe9dTNLNaPGZJFPzFU2jjPv7V/b/hnG2T0vQ/mn jqTlmVRHt/7MumQXf7SfwJ2wg3ieKbDDMm4RfvR82OleYfEzUoNT+KHxT8SB9SuDq/iW+n2yuW8s NcSFcc4zggcdePSvcf2ObB5v2q/gM0zTbY9eS7nTzDysaSODgdvlOPcCvmKGQXOp6/fXQd5tUvp5 UUOSrKZW2Yz0JGM16PK/7Yv/AHTijUSy7l8x7W0EkSL5Mj7vnl2vgxjsSfQnjvSSw225kSNgXHPP 3eO/oKkjhktdsspkwxPT+H61Ba2jvdTx+cGVxnGfmOTzivsIdj5p6mcLL7TdWkjWdyiZMbSZ3BMc 9M9f8ajmdI7R7qNirxMRtLE7sHt7+34Vqxxva6jHFbW90bKA7mDNypPBJ9qia0hknlmZjNa8MkiN 8uT2P+fSt4xuKMSSzkhuEjneNluQRvweg7fSknldDcxR4VH4weGOOeD2qxB5NggSUmSSRyW2Afd9 arSQztJPiOS2t25QyHLNk8fSo5dbo05rR1IoJbRtQb7QGhaNRtBbhSex/D+dAkuIp1F6UNrvPmED BjXsT7dPzqaGZFcpLbJfzfdXbxtPoapLNFZm9lvFuFmRd2zOc8/l0/pWkYXOfnGOtw1zIh+RZDkM 3IIz3746VNbXbress9kEjtlxv7N749D/AFqdZ5Cz4gYpdbd0m306KT2+nSp7JBcNcRTRSgQnBOeu aJRQlUa1Ktvd28LmJEdd8nmRtnlj6fSpLyV7qR3jMkrKAdqjp7+/0qi9vELe8hEFxJekkZB6jtj0 6dquxF7Zba9J8+WcGJUB+6R1GO5qLGqqNshur4MrJBDJMkY2rg8scU11ijCyXodYGTcEQ4OfStGS 5jexvjbWzQXajcgYAsecZ6/j71mTXdrcfaoFtp96R7/Lz8zsfT09aEuxzVWyazmsr6eSWORo0wIx ERwMd8Colezl1S5MaTLcWkO5SDhZO3A79+KuQTBbdbO3jieKA581VAwf60230ZA86vNILm6OQzNy gJ/lWj7Dpq6KttczjIldI2bIGBgN7Gp5QrTJegqvk8KuPmJqVrZIJ7li3mqAI0yo3A9/bB7VOIvN WMbVBQ4LjgH6VB0QSM6WWGGNJGOX3ZBI4/H2qd4rqRwpnjgSfktjhh6e1LPZqySCJluoG/d7M/eI 64P+elW0LiEzRopYfKUPXjr9KlroMpSQRWMyzRmXKHJ3nNNi1WWV7yFo3j8jDtlflI/woltoHnga 5mkS4cnacnao9x3xUkNtMZ3t0HkWgX96zH7y/XtRHYH2KZhEUsexZnfG/aW+XB7/AErQfzI8GWB5 VK9Tjn2x+lRrBBbRCOymabeDIuec/wC7VSRLqXT3DkWcjt/rGOcj0HPXvTMZJiw6d5e5/LlWMHec t0X2qedxFLsVXkgQBt6+pqaCZDZpBHBeyWkSgSTFsk5649KhyYEcxxsgk+XJGcH1+nf8aVjSMbbF 6a18xGlM8VtEoA2uMMD9f8OeDWXOqXcH2ONbryd+Bz8zccnPb/8AVVqzln8m8F5Zy+RA+4OTnORx +H5daq2aR3Fy8UVvey3UXPBypH9Px9RRGIVK0bqPUuSRPa7pmdHHlgRIeWU+pPvxVSW5kN5HGttJ ++9PU96muw4drKeNp4Au9Sp4B789f8ipLh7eSA3CwzrHGuCN3KkcdaZok+hRZZpLK4lkdVFu5GV6 qPeofJuooZQ6lJYl8yPLEFj7en9KsXZgj+yzM7WqXRCMWztPpkfnzVy7kaWxjZIfN3t5fz4JKgVT 2MKlK+jEgjkvrKMyE+bJnIBwcfh/SrM6rb/ZLeAxM6gthTny/Rvxp8EcaxwwnMMUwK7QcEnuA3rV O3hax1R18xZPMGGyOXHXHscVytam3SxW+1pB5hKuJuq7+QT7U6GR5HWG5byGj5wBjcalvrm3lmuY 1tzBLB8uJMYI6A+3HerItreSeOZ3KR2sQYhjgLgdW9q2hsZyl0KkMzlLgWKPHdZxIpGdw9QO3+el BhtIICJ5HTzicjONp749KnspYWnu441mRyu/zWHDj0PoO9Wo7O0v0IieRgg5HJ3c9v8APaspPqEU 9ypGt7YoBDFI6Y43feX8fypInt2srVokheGVyoQqAWPf61LczRS/Z4I5JJHgbPDcyDGAPp6UHdNb tG1k7BMkhD97Hpjv/jUxOmCFgNtF5guZ4YZXAWMEf6zn+QqtPHIzwQJbykI+ZGU4DD6f56irU2zy UjZ0dy2cEcr6496yDmF4YZbqSBN5O3cdx7/l6CqUTDFSsrIty2kyZ81MRJ8wQDDNnvUCz27ZF2Xj WFSURPlLf596vyQ/a/IMc7Fm+4c8H/8AV/SozBb2sc1tJBMblRvDE8yE+meg/wAaqMTkVGdrsokx RTTljN9mvUEZOcBSPTFQtZ2s1pKWvjFHCP3hAJYevA6H3okYpMLGEjzQm5kC5Lg9B/OppLi3ktY2 tJt00DZlI+7CuOd/rXRyBHQ3JY7eRLSbY1uqIF5ORMoHUe/fmsq1uZpVkaKN5/NfAKDHlgfzHt70 9rmC3jaOaVjbzr0J+Vfx7H/Ckhj+zGRtPmCwuMMzc4/CueVJdTWVd6JE4WS5sZLuB0WIkiR3Gcgd h6c96pQB/tB3v5mFA8sjOP8AP9KvRWaRrPHNK8QcZ25PzH29Camty0hcmICKIZBJAGff2/xpRdhc t2VpoLa+092ViIIztCrwRjhufr+WKzYILWK5SZZIhDbjdll6nv8AX6e1W0eWaxmmELpNBIRFg5Vj 7/hSQKktqLqV4XO7G4DCjHUfUVrJLqNqxZt4HubkvPHEkb/d45I9f/r02VmbzGIkt0QbfnOePUel PbeiT/Zi7tOvRuq//Wz6UWtjNYP/AKYtxcx3TAgE5KHHQVi0bOI9LqKWRY0O5I1HlgL1fvn1+ntV S7W8aeSaMLbsy7TuAfJ6c+3+c0sjwRMkkp8p3J2bRwB649eOtTQQLevFJMzTeQ284O0EdBn86z5L aoS6JFeRdjWlg1tM2z5sDrzznnt+fWrc1s8VqlnkK053yqFyQDyOauKs8iuWJFvN8gOBmPHr6/hU SQraYnaR08xtm6VsrL7DP+elZqVjr5rFbdHb216sUJuXhj4x0Yj3/nVW1ha+VLy4ZbRZR5b4OCQP THSoHaeCaScrNIspx5Y/Qn+WKsxNqUV0qmA/YXHzgjGD657D8K6VsczqJzSRZuUklmCWlq0TJ36h vQ+1QTxbIUmnWYIxwQTzx/Q9qs2rQxvMVab7QTuVSeSfb0//AFVBNaWmoQozS3TSMxACy4K4659B /wDWrmsdVaTUXbckvrlraJfNjFvO6hwQc7Aeh4/x9agtLWGK1mkS4eQtHlZO2/2H9KghtpGKSSxz ND5hR27HHOMevSrVj5JlaCe2uINrbljk+U5+g/yauVNHn06snLUrxx3lzNIrLLAsIBIY4En09Klu I4bq6CxMwQAIVQbXOOuD9f5VryRRBE8xpBMmec8Ee4rPaSC+2iGCWO5R9ikDqfQe5qYxO6S0I9Mk uAyWl1G5mRyQ65zjt+n4USrIVum3AzTDbCXOQ5H/ANbmnpY3UCfad8vmAE4B5+mP5VBNObmJYY0m a5fhQowR7ik49DGG4iwXytHfXd1GiQ8ScHaFHcVdubRJ0dvNKyoA0bk/Kc/z/wD1VFIP9HWFlldj xHg/xdzVaSeCBrOJQzzW7ZmiyR8p9D0B60o6HU29yOzty1jdmYPDJOdqsDypB6j9Kvx6dLFN5kN6 rI+CzE/6kHsR9c/lRcxeZbxyWzKm7J+ZeBU48iFIPn328h+aReinFDZCfQzJ4RPeWSuw3RSZbBxu 44FLDc3xnneCBXiyVQIPnGPXPr2q/LbRsh8wqkZymR94/TvmqccIlN7um8lJY9q4bBGOM/X8qGjO cbEOXufJZy0MUfJjcZaRvTPp3pr3gu4fMb/RZIm27pVDDjp06evWuggsxBZNbrHLPKnzKc5LexP+ etc9cRzgeTGy+bI+0nblU/8Ar+poMVe5qX4cPHDBHG86KGHuPf1FVhZW8kkV67bmDYBQnAPqfarq zwItuLlP39p0VfvS/T/69ZVuwlkktkZkQsQyk4K55NFjaexqO8ttqNml1MHRyRG0YwCcd/UY7VCk cixyqkEzmViNmeXXsB7+9ZJsHjkS+iuLoXOnYAjchlYE9QO31PpVueed7i31Brsn7KNrRKDsi/8A r+9Yyo+ZNKukzYd44bVYZMxMo5b+96CqEN2kkO21W4zbEnLHdjrnPrz/AEqG+ieV4mW0uJjPgcvh W/8Ar1JdSS2r3DzDyDEo2RgYXd/iRU8ttDtlPmV0Z/l/ari1aB3Yq+ZApxxjqfUVZuYpvOhkmkSW 2i+UYX529h71etpoIftN09tLBHgBn4Cgfy/yKvPFtgIKma3n5V/Q0nJXsc3s7ow7K0GTcvE8KxEs hkbJQk9T7eg/wqQxPfwSM0zeagK+WnDfXP8AnpTWiuZruYOJDF5YwQNuB/nvVqIQ3MLNCshuLcbN qnDDHT65pjdNFWCGZv7P+zQTL5bnduf7xHv6e3uKFRH3m0aaN7dy58wkqw7j69etNh3W7xWd3I3l XJ+YlsZz2B7GtCB7ZZHskTYCM7ScuM9Pr3pN2NMOuhR+zpdtFFZXsKSxtvePncpPcfjVwx3A08JN BG15bBtp4xIO36Y5pVTEAAWGIWzkyv3VfX8BiseWWW3ZnaWeSFmOxmzl+/Ht6Uy8S7RVizcraeXN cRO4KRhZGB+VfXjsaZaWf2aKZrqYXkc42ImMBvVSD1NaEv8AZcW2CESxzIBIVJ/1mevHcdf8ioLQ GWVJbhfL8tvMRM8t6H2XGaDmWpJc3hniVoLKVmGE2LhTHjjn27fjVa5EltayXEclvcPCNzKhxsHv 6Y/oatwh3Ml5cOAu4iNF43L0+hpJLSBBdZVkz99mOBt/xqWuppJaOxnwvfSpAAiwlTlpiPlweme/ +RU2mR3RtwJH/chiwx95/wAe1aBto53STbcfYUUDKnA3DqD6/SpgixKIbVPPZyQcEYU/54rK5jSp TunJ3MFEkvYWMwkWC9Yxso4wAcfnVx7S3E6wMf8AUY2AHG0+n1/wqW8V1uofMlH2aVdjRqepPUD/ AGvpUknktAEWWWNsbi3Qkg/w+3+Fc7PQhHTUoX0Eew+ZOFuGk27jwX7Y/Dj8q/m3/wCClM+/9qzx Ba3l7JNLaaNp8beXGUSMiI8L6jdkf8BHrX9I1/F59hf3AUK0cRKv/CW7V/Np/wAFGb5dX/ap8aBX kWWPSNMieEjBQCDt6KT+OV5r838SJ8mDi/P9Gfd8CxUsRL0/VHxApm+yEXA3SyEgBeA1K4scxCOU RFE+Yt0z7/jUTeYiESHKRD5RzyKjxFK589l3Y+4ByP8A69fzxPVn6/GVynItw6G4jl2JnoRmrQRN iyEMlx1BHRvTiltLeO4RYzI6xwvkkHGT/hUdzFNI5ZVlZYfuqB0PrXM1bQ0cbIW2SZV37gpLZ+bs atx3bugS4KKyE4Kn7w7EVShjnty0t07LHuwGccH2HpU8wiZpfLUlyMDHTH09aRqmR3FjEzKxkkYv gmQDAH/1quaXIlrcs80mV29zw59qrsxZRAuH2KG47e31qbT4Emgkn2NukJVEA74rKu1yO5tQvzqx +w2kQDTv2Ebtr9ktvtWnXMtqYz8szSTE8HqdvfPPGa/HZrS4uF+ZmMjtk8/er9iNZki0j9gHR3E0 ZN7p5VkwW8lpDjAz3wMk/wCz71+OX70rFCJnihlcq5PJX8a/JfDei1jMVLza/E/WfEmMoYHC032/ RETXLbJLdgp8s42gcEfWnwb22BY2ABz83UY64FEe5rh4SyyI42ggffqEPIzoA48xGOFxya/ZobH4 vKDNGF7q/u7iaOFbaz4R8dAf89qsxxsZyEDLFCxy4HX8KyrYSwvkiWHPK56Oavi7SFGjZZFd+pof YcVY0Y7iNvNUTrExPGeSSP6VitNPcTwzPKvlSkoCB0x3pI3EsUzOEMzjaqjgN71aQx2zW4hj3MVy FxkE/wBaEi+bSxYtQoQxLIdvPI7+ufat4aRK9vDNHOUdlySBncPSuctJHjSa2kUSW8pyG/iDfX0H pWxZSSRKHRpzHb/M2Two/wA9qHfoZtLdmcmFlMM/2hYBnBBywI/nViG+ljgfyI3Vc43E/NURuTLM 0ShpFLfKwHINQi2mUS+cVa3jP3gOCfQ00+iMS3atbzfaCz7PLGcEck1UhuZ4bowKHnhkPO3qPX6V YigkjtY7gLsjfnkdf88U+G6jEsjJCvmy4VlH3vw9KzqK5tBaGjDLu3ySl444xwMcvjt9aurfQ3MC sCEZDjnt6VhxXM9xKGhtJJ4rZvuA8r617DN4f0K6g0dAYU1Cf5p0QYAyOOn4+tcdSrGmnKWx6GHw 0qklCJx2leb9qEk7CWKMDAxg/T34rQkWyh1ERy/vVuuQWbngc4/LpX6FfsMfsYf8NNfEvxHp1xqU 9v4I+G+nDUNXuFRg0m9tiRIezEkDcSACc89B9vftEfsz/B/9nn4MeNPEvhDwPe6r4y2i0torucyz WbbhhgHULnCSgnHTo3Az8Hn/AIhYXBVo0EuZs/ojgD6OGaZ/g54zmUIx777H4FanZfYokeMxj7fl F6dueax4RJbxtDNLhn5Y44Uf416XeXORNH4h8PzwOJDtK5UEew9BWDc2Oj3US+XqdtazznaA6noO fz/wr6fB8R0Z006mjPz3MvDHH0arpYdc6WlzHsdRTTHf7Id8o4OTnNdkmpTpDGbi7lRrj5fJDkfK fX0yO/0qTU/hD8QdA0fSfEeo+FNWh0PWjvs7poTHHdDGflJ5ORg4+vvjhdl2Jn1GeKeOCX92injB HY+9d1PMqNX+FNM+Tzvg7MMG/wDbKLi/NHUXeuQxh7Nld127fLcZA9//ANeazLTxfcpY6jpMTCGG 5HlzruJE6Z4Xrx9awI33RskyiNmPyuTwtZNxaobyOaOdtjtt2gdf8RXVSxE1tI+RdLW9j//S/mj+ MPim+8RfEBtfQ3j3gZYBIzHZc7R8vHYDpjA6dBX0z+yp/Yd7NrviXxR4is5PEd6fs8SOh/dqhG8Y 9iy9OmcdzXjWieD7nxV4cPibUrAppzym2spQSBcuAOcegBHuc1+hfwk8NaJY+AvDdvY6Glhd2im3 uFZFElw5wXJx1yeRnsRX9f5Tg5Srx7XPzTN84pxws5J2Z6TceN9GtzLFYabql/NGiws0ShFQjoAT 0OAPzFTx6nqOpi3eLTbuGaHO8OcM4A+X6j610bJbLpUm5UMhwsYwCGI7Z+n5VLHHbW+nFpmQJcAr knhPr9P5V+qxw0rH4tiMZCU7xd0fOGla3H43+IOp6no+q2jtpFukVyYAMyDc3Y9MfzGa6vxZc32t 6zB4Jm1K1vI9Zh33SqUEnkdGHPK+gPY4NeNQDTvh98bPF+l2ulR3Wr+JY4zbxWa+WglbkM46gHMn I7k969x8I+CdH0vUp/FN695deJL8PHc3Dy5RQcjKD+EbeADkrk+pJ4IQc58qPSxNNU4KpfRnWWPh GKx0ddMtJL20EMYiYGRmMcQ/2uucd68y+Kmr2WheFbpIvFmpabrbsggaa4cuwOVUCRu27B2g5wOn Ne83Mv2azuJTNMbdo1CRIMtJ6Y9znrx718dfFDQdJ+Nfi/QvDEurPHpnhRHfUzbNkQnJCt33AbgW UDJH6+liacaNK/Nqc+DxLr1k5RulueR/Eiz8OaPofhiLwrqjav4mu7Y3DpIpLxuCNzqhO4lmLAHn J5zXq1p8FfGOuaVYS634+1jTkmtUIh05yTEwBA3s332x1Yg4OcZ614z8AvA2rax8V/F2na/cxeJI dEuDaWcwBbzQrH5sA58vC7RznLAYwef0lDxRQTeQIfMihMKOz/KjIOBx0APoOma+EwWVzxOMk5PR H6HnnESwuEj7Pdnwl8RfDCfDt/Anwu8JeIL3b4sv/tkqyz+ZI8khCls4GOTyBx9ea+yPh7qR1XQt Jk1CdpL63X7PLJESIdyDaxweT8wb6DHrXwF4h8SzeOP2qvCNpdT3Etj4bvIdOSFk8t4WibMq4zlu WYnrX2z4L1a1sNT1O21G9SPRjMHhmLYgBHBXJ53HP/jvTNehGjQwVWc38zwnHEY+lB9z58/bJi11 rTRLSdomiaVYrSE9YmZX+ZsdiAAO5+asH4A+Jda8F6qPDGr3Wo61o9jZvc2sKjzN8sv3gq/3wAME +o59Zv2g9ZuvEXxdt7IW11d22l2sMmkwFskswxlgO5JwP9kj1r6B+FfguLSdS8TXt+lm0trYpaBl h+YyDDSY7gAE+vWviswbzLFxdLZH32XRhlWXzjX1bPnj4s/EO3s7PS5dc1K98I6nqN+RdxToEeCF D/qz6nBHQ46HPJz6VolneeOtNg1/xIL+38M6koh0mwtyyzSHnDED7wbAxt5b6V89ftK+OvBniLx5 4Y0aHTI9S07wPul1LfhkuCzYPsvCgY69a6TS/wBo3TLvULzUPDOlaprPidrdbDTIYcFNMXgMygcb yOCw2npxivax1f6suXdnzmWUfrS9otInvXgLQkvPiZbweK1vz4O8AbLu+iSXcrybWKIwAJYrxlPb nFe5pLc+MtRXUUjhttMtp2NjAcsSmcbiOOWGMenbpz5N8MY7p/CDaLqWn3miT+KpSiXMj5llJJ3s c56AkA885/H2fTbCTRoZ7W3s54ktwqqQS3tkk+uK4OGMllWxnPOWx9JxFn6w2D9nThvoasb3FvMt qJA7OSwdRjcOwHpirVpdTXNpdnUAIyzfezjgdD9Paq95PDp/mPcOYFgQsu48b+/4Y7Vz/hvVm1m1 S7IMcUsrGJmX5ZFHRgPQ/wCfWv29R5dD+fZe9dovSbrlg1pHdPOHxkNgEj27D/63pVPxb4mg0Pw9 eN9sWS6mAjjCRkyBv88D1zW3cX2l6NpUut6o10F8zyG8voQM4UL3br054r5c+MviTxZbeIP+Ka00 apqHiDTls7K0P3dPbkmfPVf9o/7QA5PM4vM4w9ywZZlU5tzbscPYjw38LPB76l4tvD4s8R+JHZba 1YjYsh5c+Xzhz8oJ5xyByTXt37P3jjWvGXhqaTxbBZ2viXS7029zbJC0Zt0JYoCrZ6KFJ9mXr1rA +G3wWt9HaSfVL+TXfEOUeeecB/sEhXkJnhThv69Tmvo630+201m1BiL+QII96YAAHTI7kYxSoVLx UjuxC1cOxLqPh+18R6drPhy8ntRYapbPG7yL90OMHnqBj3xwa8z+FV/pr+HH0tUa1uPCwNjeQSSf 6powMNzycqVyT1PNe3w2SyCa9VfPWSMNkEKhHTkngc8Emvnn4h+M/Cvw1ubx7J9Pa48Tt5rTRjck b4BLORkqCzHHqc9CRXBj81hQla9zoyrJqle6ij3eyvbZ4jNjyIQu0xMMb8env3pur6hHpunSvPFE 8jKPIDHafmPy8dWPP4184eG/H2raxfyaRpCadqb6pZiVWeNo4goxuYAk5JJ7f/r7jUvCfi3Uo9DX UPG00lzo1wsjyR2xWSJQc7R82DjoCewwQe/JSzf2ybpo0xmRToStWdrmzoelkrcLfr51zJcM0ayx 58hvr25z0x1xXa2drFFIBahkumOxQ/Zu9Z+iSvAjS6grPHA+E4BLevHfArREUiyLqNrcpdLyFUD+ ee3avosNDTU8SpK2xZRBbEFkHkpkr3+bufriqLX11c6qNIjgeygsfmDYLG83jIAPQYH45/DOm+nS lRISZLhf3gwxwCfr06/QUS21xHbLIjKbZiRkjv3YH09qxxeslG5th6fuSlYivGZdrLEGEeAWb0HY 1S1db4WcaxXiBZfuxhTuBHr6jnp7GnrHcxWYaKOadFbfvJLYz/P6e4qbR7t72OS71GS1tktZCAWG NwHf/PvXqUIJJI8GVZyumUtr20UcfktbuFDYPVj3P+fatG7km1aGzWeAwhX2CNgM5A7Y6np+dZV5 cxMzywNNMjH93v8Auj3P+znj8q2GigvJoZJlaGdVG9M5DH2Hau6UOpwq60IrxpblIZ7QCGzlxCYw cHcvB5/z0p7RXwlX95BI6rjCx9Bj0qNY5rOeN5A14pbBQCrUH2lrjcqNm7+QO3CqKjbQ7adK+5Db X7xMsgniNl91lxnP19abdxQXFwksk9xb2EyhWjBwVI65xUk9pCba8mluIhkHYSMAMOMEU2xM8NpH YXQEl0nzc85z29qHodO2hNfXl2zJKluYtOtkCsoGTIv19TxUccbWdtNOyyTRfff1bPIXPt6VPDIr 2zxgTlAx3SE/KuT09sH+YqJdM815bSG4a1W7wMTEkZHJP0qI66FVanKuZFmC5k1OxULaiEbPmTgk kcfhmojp0z742T/SioLZGML/AE7U2ykmWO7YFIpV/dRrjgEcZPsajtGktkklE7RzpwxZiQremKlU 7OyOaNeVWS5xymO3+0XZY/Z7Qf6sDknPf+lVnWW9vLgSbzbNGGxCSNv+fb1FXINSsb5pob2K7hu4 +THH8rk9vY+tVIrCeO7giad4YiSzMvRvYe/rWkVYyrX5rIktre0wGMcsrsdud2MD/P8ASp5LL7SY YoRzbglySRtHrnrk1DZq9vdSedHItnOTGhDZ2kdT759O2a15ZIvtMBSGadcYIQ43dufWs6tSyuax j0ZSezuI8PFM9vLjDEHAK/TvWVp15rFzoTwanaiz1BXeN2jYnAydmCcHJTH4+tdXqsFt9t1CWO2n 3OqeWA5GcLzgHjrk8etc5qkT2MOlXMjv9nml+zby4HlsSSq+5OePccda+axOMU2qkPQ+ow2UzhF0 56XO38Ixrq+j3OnMW+36WDjactIrHp656/ka5fWtKt/sLxwCNZXcpMzt9xQc7s84AI7YPNbfhK+S z8TaddWc4hjs5Q9xGw5HH3WPTOav+MPD8+k3l1ock8SSEiWJt5Pmo670IPXOGHXHINfPY7CR+tWW ikfS5ZmM4YK8tXHQZ4Ti/tbxT4akt5FS7UKEVo8iRsYxtBww745yMVwcOnmx1HVvPjNtZyX0qtBj MiruI69CxxkH0OK0ra+ufDOsaVPGk40fR3V5Nhz5WfvEc9Bydp46kVNbXf2231/WTfafcWP2x/JZ OGYE5AcnH94dh3rgwmYTp5jGjW0S2bN8RhoVcBKrR69EU5ke3hdg0n2K1IZvmxtzx17HpVrS3ltt su0TeQdyFxyrA9Pf6VW1zSdS1nwxe6PY+XNPrMEkK/KC3zKc7QQcgHb2PGT2rF8H6s2r2VsZi91f C2ignEYK7nx95BnCjHbOfWvtaudQVb2LW58pS4ek6H1lPZ7HtV7/AMTPR9UvYtGmNv5ezbAwDu64 J28jBye2D+VfOPiydPAHi8eNZ53Tw3fxFbzzFJZYguCxA+8VPzevPtg+8WOpXlrLb28dsstokeft GTnfnow6AAAc981wPxc8I6145+EnxHsoba2vJYrIzPb79rgFhtZMHgFgoOPUZzxX45xBz0K8+d2V 9D9ayb2VehBxSbtqaMmmW8urXNhpFxbtBLseIIAMOVy+7GOAMD8DUXi6KTTPDsVjBcw283iWVbWA pjcdrBnYDsMDv15HNcf8HPFsfjjwV4V8a3M0FpFNYwwTeTgFJVUbwxB5OV4zjkH0NWdIbTr3Wr6S yvJXMF2ZIXvWBhtN5b5cnAzkdeBgHvyfSyvieb5MG5ab/qedmfDtHkliYx12Ox0/WD4S0u88ZPBL LJ5q20KxEfu3Z8I3JwBkj8KtW2lXdjpmm3166ot2Wdyw2cd8j05Hr1FY15dWuplJNKkTUdP0TcIP LB8m4kfG5h0yOAM557HGK2te03UW8SeG55Jrv+yLOyM04lcLAG+Zcp3LcgEc9M/X2a+Ocaqn8jyc PgU6Hs36mzqnhWHxTqMWr6ZqN9a61oOkfaJYBc4gu4TKY2wnX5W8o9e/GMc4XxDGqaHq3h8LPp2o aMl7BEIooyGlllQqqk4woLjqe5xXWeF9ZsU+JHgeWexvYreaO4sblV2lbuIRltgY92OcDsVFcN8Q PFGmXWiaw8/hzU7a70tQiK0il0ZW4b03fj3r8hzjM6kMdyPVJ3R+m5bgoPCcyWrVhbZG05w13EJZ /MZGiC7TGfT046frSR22qp4d1zWIINQsZ7SdEguVOPJbJwUPryAfqK0NWXbFDJEHYqAeepAAwT/W n3l3reo+DNd0fQ76K01B41nQSEESfOMADnuOuMCv3fiup7fI5ytuj8SyVxp55CnCWiZyekQaF4x+ GlzfPplvbo7XOnanaEZO6NiokyOFRyHyvOcE8V5Z4BktvCerW/wytdZaDxd4gu3S6sLgLcWOrWDw l8LG2VDEqxySuCvfk17/AOB9FvPBPgvx+utazopuXiuJJ1t7TLRKWLo/PRgpQYx2964v9ob4ZeC/ hf4x/Z48d6JqcPiHUpNGhk1qGF8xMk+5E+Y4cD98pJ3HA3Y71/I+IwNFVI0ar90/p/D4yrGEqlJa nH+FfizrHxH8X+NfCviDwp/Zup+HrSBo/IuMgxpuXay9A46nkjn2zXpFlbo08EMQa6WZsMI+WjHq M9+uP/rVyGoeA/CngD4pfErxFa6lb6FpGoWVqbia9d2YzhAjKnO4M3OF985qTQ9XPiua08RQLdaX Yi3ZHs2AXeoOMuvctwe5/DNf054dVcNh8C8Nh3zWPwbxApVcRio4qpHl7mVPex+Hfi3exy6joOq3 vjRIxbWkUewusG7zGJY/MWDgZHfr77VrrVvdeKPFdrDpOoaPCwjlR5ZBIswxh3z2G4c8dQPWvL/2 hfBmo60vw8uNOvbLRPG3hGa6vNMnbfHMdqB2QkAk8lAe2D3xiuc8NfFLUfFnhK0+IV94fGj61oup SaZe2LNt+0I2FEiHGGTeyNt+X7oIyOK68FVdGpKM+jOHNcH9YpxnS6rU+optTsdQNz4SYiG+nsWv biJ2wUgLeWHHX+PtVTwgl5Lpd3AHE9rpNwYdx+7G2B8pHXO3b17EUmt+LLXSL7RbSHw88/8AaEkF nJMB+8umkwxTJ6INpIwRyRTZbm3sfEVtFazwWKapamaW2CECN2PDdl3Er3z97HevCwOaf8KNTEQ+ Hb+vuPbWWwlgYYWs/e6HFfFjVbbwvcfDue51wpdy6vFatbqhWVoZWB8wZOCqkEDnkp0Ga9NsLe5l SNJzDLvZjHHEBtZj2B+lcr+098OrbX/C/gm4eSTSdU8D6PNdwyFcyGdm3KxBB3qAFIyD36HkWPCF zPq2maX4iieW60rW7OGeGcALHMSo3FPTnPHbAr6PgnNaeJxVWcX1PE41yx4bC0qaTsjpNNgn1GKe 1tWkR0ZikbH72O455Ht/KtfT9NuJpxaWskpM4Dbd5AJXntXD6nc31xqEGhaIbYSTLvkcgkR4f58/ hgegLAn0rtNDluYr2W+ngkkj04F5bdfvOig55zX2mZV3OMoR6HyOVUlTnCrLqRarYiTw34pmaOdb G4ttkRL4LMGBODnpw2Pz7Vkaesi2WlWxIuiiffYYJIHp3H9Kxp/GLaz4F8SazDDNqNpYq0cO5AsU UecBixAJLDd14xjk5zWtZSR3Gm27C5UfbbSGRJ4mLBcoD19ADye9fO8MYmU8R7/RH03FOGjGjyxR dhSaOUTK8T3RcRK7MFC5OADnvkgfjS+MrPUbLRPh1Y6hpc95pXia8ure4kUbkjCqGcnPQbT1PcgD 24n4g+G9RuvAmrSWN4z32j3NvqdqIZfLZ3jmQ4DHuc4/Ou61LxVomo6xo+g6cz2EOk6amo+TJcF5 FeT74Yjrg/Xr2xWnFmYudWOGOXhTARpwnifkeafDVtU1LTbjT9We2XVtOuXhDW6BQVDsE3D/AHVH Pc5r3ed5k8H6POrJqc9hfOJpEIKiLGOpPXPQ9trewry/SdC1Tw5q2um1glGhaiUu4bp41XHBEieh w3PXuSeteq3dnPe+E/AMej3lppltFqdyt15gyzgrlRwehcSN69fSvDzDN+aEaLVlE9fLsnUKkqy1 cjhNe1KbQrDX9Q0uQNqMlti3imG4I3H8P8XGePpV9NWsdP0Lwz4cu31TVL2Wb7dqV7KcwbUBEcY3 HIYBux+uMVb1zTLW58MeJIZIX1G11WJYU8shXUK4Yur54+7jPHU1jHSblHtogZHt4bHB8nGYW/vH OCWOT6jtgU80r05SUbnRk1OcYtm548t/D+sSeD7iyj+3X3hCGe6M0OUktpHbaN+eQMYAIyPmx9OV 0R7+DRoP7WW5luVnfadgG1M8dOvf35r1T4k+CvEXhjxNpCaVoEY0TxN4Vt5ZtSUIVb/WMgbkEnJ2 n3H0rkEjb+z9LN2xWDcUnJXaVA/HjnHrXl8B0VPEVay2T0PS49r+ywlOi/iaNfRGt59I8SXVvDEk mk2e51lOdyuwUsOwO7GOOMmt/wAI6M954H+MOpG/8rT7fSENqsyE+U4kGSzA8jA2cf3q5lLc/wBi 2mmW00unzeI7hoPM2b/tMaEMygduQvORzgV6xNf6RoXw0+IOirdw20mpw2ml2zclmL3MbPle/CfX P0rbjHHJVZpLyOfg7BP2MG2eQWk+laf9p1DVbz+zNNsVMitvysrNwiqBk/MSMcd/ys3jXPh/RrTT dHvLZta1Vg0sWd6RR7w4JOcKT3yeP0rF8bz3miW3hiG00ltWs9Xbc2whfJ8sHEjHn5cnGOOc/Sqt sXudZuTLgwzWygMDjewPOB9O31rl51jXGjDotT0YKOCi683a7MTRr26jur3TtQRvtNldsgREI3AD gD0J2k88enXNd8UiPhbxVPpFvdTObURthyfLy4GevykHqfTNc9fSXFtqV/HBElrZ2Wxy+zJusqD5 gbP3QTjn1/GuzfWNG0fwV4ri1fU4NHvtctYTBDKmVukSYM5DZAwApyAcjjNe7mDjhsolBLbQ+ZpS dfOIzvuaU6JL4l0a3Cyxw6TBFuRX2jcckE4PzcZ65zxXnkWnNaIzqN265miny2S2JCVxzxgEKR6i n6b4ri8Y303jWxEN1CWEVtJA48grGo5I4DckZOOCTXRaxBbWG63jkmdlcMFc5Yswz+Pf6+/WuThH CypTp1JdT1uLK8J0KtOOtjBk8u5+yy3kW2RW2gGTZnHQZ7Htmq66nrWp694nXXTJM9hdBbaN8CUI FwmMHAQAEYwOg+pts9tKYIXDMytwi9d2Ov4+lVfKuIvFnikLE1rb3X2dop5FyjMYyX5/vZ7dK/QM 8ivrNFn5jkc/9nqo2FuUkjEcc/nSdTH0C+nNVtiW90YpFnhug2FgIwc/1+gqwRCkTBriOO4zuIIx uHt6fWoNdW606fRUTSpp112MyLHCwLQ4J3OxPQEKD16tjivQzDMpUHFRV7mOW4GFfm55WsV5TqkT STWTAwzkIURcl/b2OcVq6fJNd6b4muWjvdsNkTsiyzgryQAO7AYH1qg8cceoQMheeeEBvkOFGf6/ nUGrwa5pei+JZtCn8u+eBWDsN64aRcjGeuCf0rqzSovq7OHJacli0wt5f7QTe94FS4QGIBdoB7j/ APV6VahaG1V7yX5DGmSpIJx6gVPqlt5bXUdpbs80CBWdRgMe5C9sn+YqPStOtZrcyz3B+17vm3j5 Mfwj6/54roy+rbDxcuxzZtRbxU1FdSlIZoF+0CcSpdnIx/CKuEeXEmoQSGCSb92QTjeB2q+8FrFe ppqwGbyRulyw4B55Hb/69c1q+o6P4efTX1g3jxa3dG3sUUjMj87gT0AAz19O5rf63BLmb0IWFq35 FHU1JJreWSF93lyLzzwD7D3/AEqBrWd1uC4ugJeNg6k56e34U20s7pZ/sc8H+l2p83aRgordN2fw 61NayXDTJC8F1LFbSHc44AGehP14/Guq9tTzeTnvFkCs0LzwwusSRqAxHO7PYntU9vdSMkiRHZIT 91sE+n4VbS3eO5Ilt28mU468r7/jVTULFbaW2mtElSZpMcnhR2J9R/iK0jO5xyw/JothUtbuF32Q SzyqOOeef8/yq7LpKJaSXE0M0SKpkjG/5mb69xUJlQ6jbW/mTJuHzkNt3ccAfrS3M8koFjtuPK35 2sfvf/W/+tS5Ga06qW4jRG3tFuUhuFnvBtXee47j0olht1EK3Ucyxsvr37nPpWrp0RbzrW8ffK5C IP7g7VQuYw1wscayQ3Jco27ldvY4/M1lza2OquvcuiOyt2mSSSRi8Q6x5wcfXtVa4kDFIbGRSEPz 5GQuO2O5rQ05ZWeG1MY86Jy8mOA4PT6UqRQalJHHbxzQfZy21WAIbJ+9x/X2pxnrYypwvAwrxvsk 8NrGouJXAdo04MgPTGen/wBatCfS5JZY4bMzLHEd0iZ+Zge4Pbn1qxNKsFtLFOrXNxZ5Cyr0cegP XipjHdNcxySvLA0KK8YR8H/gXqPY+/WtpVU9i6dNp6ksGlrBGZI2je7tCJAM5x6cVVlunvboD7MJ 1YbQEPKn6/0q3LMUufJhXzIScysTzz6fjSWr2rOlmlvLavFl8nneSe/t/wDWFZHQ9tTKvZ4W2R2b yhrIlpGYZye4Hpj1rQtI1e1LF2D3B+VRwFA6k/XtXO/2/ZS393Z3EyWt7at5jQyAgSRgYLoB97Bw GHGMg10dvvvrd4Eb7FFJGdjkcn0yfTp+dVfQ4mveHyiIIpKkxpzyc7cdz61jkxXsv2hll8+PhU/r 9KurItsiwTJP5sfAYc8+v07/AJVMTG6BpUnRV+7jgyH2/wDr1opocY3KF7b3MoiZ28yNs7WTgHHX 6dqXUrl7i4NrtLTbVhKouCuFGQe2QMH15961VW6jtoUjjd1OWJXBwPb3rHR7LzrzUTOt1byXT2rM Qw25BAww75HOcdRz2rwc6ruDhKPc+l4fy6Ff2kJPoXvIeG2jl01WnaCIbkf5yTznH+enFDWNvfWJ klMipp08ZDK2yNJScrvOQcDBB6ckc1n6lqd9pDo0Fv51lIwN1nO+OLHLL+QrooLiN9Ds5Ip4PsF7 NmcK+VVRuPPHUbV9Bz14wcc6rtYd+YuHcLH64k9LHM6a095q97cRzNJaJN9kAkQ4jIAJwDx19Oow a30aNZRZNDLdQ5J8xDjn0z1rEg1V5gVS3dhBdu0bKMLIMAZC/QCr7rbh7faXl/tBysbF9qk+p9Bm tMkko4dN6Dz20sVJLUaJ5JpmmjDf6ODhGI+Y/wCNJDNBI4SIXM4uvv5bmI98nsM8D8Kt+VaWzlCH N0fvoh5Cjp+fPNSrJp8xt0mjcNIc7Fba2R0xivoYyTV0fPTjrZiLpcAiMcU00jPLvEhPykemP89R WbfuEeTTsSpDCQ7FTyxP9K0XBNiEhad5xKWABH70eg/OqEE1jeS3djKs9qunnc0pPMhPXH09DUp6 lyj7uhNBNcwW0EVtC5ccOuNxUfU/5FMkknciS5ZwLL94oJzv9vT86vC9EShrO3nlSHrH1Z19f/11 VvZFa80prTznmmlYTQnGEwONwPYk/pROrGPxGH1ac9Ij1hnMXlb3khlB5HUc5AB7U97k2qlGtp7m YqFyCNsY9T/L8auvbJY28D3TMiTOWVCeRj+lQwCCSW4JLojRjDZyV56j3ohNS1RPsXD3ZCNEkaGR lHyfdzzuPv61BPLPE9lJBCs6xSCQxkYEo9Ppj+YrQaSBruGWRC1tGPkQHO4+/qaNOttguj5xn5JB PO0k9KsUlYhnW1e6triQSPJKSkYB4B/z/Spprq2hacz3LvMqASbCdsa9s+n1qnKC7v5ccslowB3K funv+fb8KLmEmWKSFJkFw3llSPnk/wBn6+9OKuRGdjReDzZhKZ1RZI8opGFZvb8P6VjwW6WiOJEe e4dy0wzgsOw+n+FSLFDcC5tZVklezwybeC2eMfWrE8UEpeFZpFZThvRfXd7VulbQ2jG71IriDdLD 5az+eo/hPyge4/z2p13A1yrmCGQWrgJNKehI7fgatPbXNtcxSW8gMS4YxE5bOOv0Pp0q3HOubuCS xuLZJhlU3DD+pA/z2qZSsbKmnoYUlv5Wo2lxGylEjAlyflUY4O3/APXVm8tmlgtFdbyO1L9I22l/ fOelVmsvs7wnzBDMz/cfJHr+Z9K2PPuri3dvLZVtWGFPP1PtUSl2FSotXuU/NilAtEhuXKHAAfBH +f6irkVrcz5+0xNt+7tHBUj/AD+tRJbW8zyziT7JcQLnGc7T2z6+uKLZL1Vl8yR3jk4UKMHI61lJ GDerLEOneddSR7nmtgvXoqH396yrGVIorwGO6S4EhjG7+LH9336+lXZGnUCOFZZWcFsK3JpItMuf tEpuGWR5FBIQ5AHp7H3qzWUW9EVIrr7XPFIJyIkILTqv3AOp/T+dcrYvqLS3Ej20kMsUhkwDkDLH H1NdzuRUgjtLN7oCYZVMEnJAz7nP8q4yxnJudQtrVblLKO8l2LJ99V3HBz+X0r+avpH64Gj6n7V4 OUeXEzbd7lnxLPLaaHq0xtpr2S0tnlMKjJlwvQe9fmr+wQtpN8UPiO9ut213pOkiR23/ACQI84CP 7Hlsn1x61+k2v3CS+Gtaa1meIwW8ieax/wBUSMZ/M/5xX51fsEHS3+I3xMa8S9vHtrKBopYZhGsy yTMpDL/EvAYjtyfWvyXwJdszP07xHj/sEkj9OYrGD5IoZJmzxJ85PHqO4q/ZP5gvPMhkP2QfLxxJ 6EGs6ORV33ECsXhJRWByr+w96uSXU8xWFYyv2kYBTqtf3lBH8iSlcqtLLEjW8jyf6cCCR1Uemexx 6VYiS5bT2kVQ2PlZgOE9yO/4VGGgj3lyY0g5kLc4Hrx602XOns5nt7u5lumyhR8Aj0P4fzFaJGF3 uKsguylu/noWIClTgFv696s2iRQyH7VG52MfnI4f/wCtVqOCb7S0ZliZCBIVK4ESkdzUl9lJbaJI ZEtID5haQ583PYen/wBeomb0ncpacjs6pKLiSMEsq5BJz0+o9qmttPnupru4fDQW2SrDgnHpmrVs m6VHCOyXC71Ib7w9selZVsrxfbY4LtpIb75ZF3nCAHP86yOyNi7+9WOOHynecHd5j87PT/PvTXQJ awWtwjySFyeRjHerS4jty1nFNdCMbQS2fmqlb6ldEtELSV5ZV2hDgsD+Pr2/CnEqUlaxWtlgE8wm hljeM5O7+JfX6f4ipPsEVyLiyV+IB5gcMfkHv7VdvvNilkaVc/INrr0Y+lQ2nltJMWUwjZ8iv0J/ z1rc5pQ6Eaq+Yt0qiI8cjhzUcDTrdM0JMVoi7WEhyW9QD6+9OghL29zbTqyzF8kqfuZ7j/PetO3/ ALOtYhG0Nw4tF3yPI+cA96CYKxnvI0tu7rbnzbdjngYGemf0q/HaS2ypcF2IdciMjL5x/L0pkdqi T3aukxtp0DBlOAh/p/8Aqpl4ot28qKRzDaLvDMxyh9D/AJ9KhvWx2WsroLedLdZI2hk+0THDgjoP X8+Kr3y3MU1uZnJdfmjdBgMPQ+oApt7ParAsUkNzJK+H3q+Cn41UMouHh2LcTwZJBU4DH+6c9PX8 q0sedUqdEX3hMFr9pCSFJJP3ikbmyepOTgL3qv8AapbZlaONrtl+YGM4yPQ564p8f2hJJkRzdKif cA5Ptz/XikmigWVJAblGhxucfcX8KREG+pLd2cW0C0Zg18A3XO72FQ7oI/8ARzK0GVC7yfvH2q5d EskNpDE/nTcI55/KjTy5tY5ZXiVmlKA4yAB3z3NXbQJK7siOytDM+0pthgYFhJzv/wA/y4poV5mn t7SXCbsP3xjt7VLBLb3DyQRC4iCMcgn749Qe3/6qtWkdvCzzqv2aN+ZHz8q+/sag05LIrwSyxRzb yVkt/wB2RjIP90Y9f58U67SRbBrEE7pzvyxy3PPFNjZriaaZmLI3yRIR80oz09KbeXImurjTVjlF xDCG+UdB/P8Al1qlEItDn2xQGQkOkajnPBIHT2NQxbLwL9oimtFXDgK4zJ9MdKtyKkAEoQLZrjzV Y5Lcc4PbmqsVoI76COOGaC3nbLZ5yMdPbrVqNjGUtdCefbLPDHLtVF4Zew9x6H1rKWEW6HbHNInm EEhs/wD6q2xpsiTwgTK8ckh57qPekvprZWuHeCZFEZiUo+A2O/8A9f6UKYuV7lNotkptIiYTFiTz G5bB/wAjFXp4l+WcF3cfMDn5fy/pWbB/xL7EiSOWaeD54nc5L5/hOeat203mXiG7BW02fMw4EXuR 6UOHYXNrYqKkoe2n8xbbkgxr1b39gevrVt4ZTOmJlur5yAFUc49x/npTry3lkuIUsD5jq24f7A9f cVctFlw5DxPeIMjHp61SjZWOmD1EeGGO9MELwpdldrbxkH2A9f51RhW5aZoJg9xFFllMfGPag29m Y3uruSUOzHLq/BP+NKWtFVooZLhiTkuDjyvr3/KlyIVR9gEf2Zw8dtI90W+U5/pSRQPeXpgz9ikt R52D0I6Z47GoVnuYQ7lZJlkG3aPvkeo/pVyynlF1NNLCyPsG5H6yAHgVlNW2IpO8rFm8hgLOrQo6 T/u5snaSvt6H3rKMguJ5EsI1jgUBI0I4OOP8n+daknn3txM0YMkVydqOFG2L1471OmjGGQMFke4G eAcY96iDtubVaV9ImZHBDJHGLqOSISNs68t7DHeo4kUzwBYzvB2Zc8f/AFzUky/voWt3F854ZFON rf0qwFnbYPIZ13EMgGHX/PatL6WOdQ1L8UsqTiNmR4Y+JcLkqPasdbzdJNDBHNHbyOUjZsFm9hnv VxTOrebdpJFNjEYXnf6D61VhmNxMjIsixg48r+I460Qh1Op1eiIbqB1a3QBklzwPX0/GtONllEbW 8YaXPz85HtVGexiKT3F0tzCiPx8/BH+Tn8RUcN9NPYGOKAyRSOVYr8u7057dK3sYrezLtpZxyWs3 737UFZs4b9GPoP6VF9kjEyW6ExySjoBkv9PerltA0EMEULAKp+X3PcH3qAR3BmhffL5sDE4H31B7 /wA8fSsebsdDj3HJE9rAfsVykrAndIOVU+/Pr1+lSRXTyyxyG1zDMBuckFZPYe/+IqtJ5KSMkETJ aH72Twx78e/9auR+Ve7MOLck4jToob6Dr9KlsIroZWrwvHa30D/Iu3MRHOeenXrjirRV47GK1CyJ NKoA3HhcjuPWp5QIHdlhuLtzwdx4P0+n+FXLm4Nri5aKF4HXayv39RVJ6WAzbXT7iCynuEcyXELd c4VvaofJeGUxSsxkmxKMvjzc/wB3PftV68U3IEscn2WwjbcyjOMn09fpTba4iunXyyC1v8oOOR9a UlYqCSHPK1q5TbukhG+TC/wj/Ckingk854JJI/M+ZHZiVB7/AOfcVpzzwG1V/M2bTuHPcf0rGW2e WOR2gzKGHlyZwmM88eoHepKnuEiyeWGto0aWZivTIJ/x9evWor9LyztYFVHMjHBJGPL9T9K2Zm2y 2bhHYqdse3gA49O4pLWXf8k++S5WQ/e6/wD6qadjX2fumPbWdxLIJ55g00IABYfdHbNWbYTFpRMR Iy/xEYOfQ+1RzWktvc+SPPVZ2zvzx9Me39RVqxia9iaPMkNuJGXGRlgO+fStpS0PNtZ2FkiLIGv2 Nkijew3D5k7H8amtZbDa81s7bMHODzgdfxrOl0+ztmZXEn2Vif3ZPLk9eewpttF9mVSIXltwdvoB SauddKtyrRF+a2gnWN4JykKksRk7jn1PcVBfSz3E6y28afaZG2jZ91wPb1qBEnW6afbPDZ4wYyQc D1P1/Pmr2xY5mmDm1jYfL5nIT3rIJzuNUfY3u0EbSTzRY3E/Kg+n1qGJUMLyuJ0lY7QN2N309vTv Vy7iMNyqLhJJwFZs5wOv+cVWmeeN1cIHK/e4+6PWtYbHM3YhthPbNMbxJCkeCexHcdPw68VseZAs jwtC01xLHlpFOEA9PUH/ABrnpbXURdwbZPkn5XcOD7e9XHj824Vd0hOD5mDjygO5/wA+lOpSXccc XJaJGWn9oOZJYTIufuRsOAAe4zzk1pTywzXb4CeVAqyFPU9/oKSzEVuRIpknuA5JU8gr2x6GpbuC 3jWbbGFa6bY5Yngf0/ColHQmDb1JmUtci7hQ7SgDIv8AAB3/AFpkVvdKDdwFYFRifmGSvofofSo4 oop4/KZZ/JhbcJFbBJ6Y/D+tTOn2eMfaCVTOIxu5J/z/ADqZblc/QgW1vyiuW3yyufmj+Xr/AJ7V XWzeKKOC5eRInJAMhyfrmrVws0irNHJIy7cMq8AD/wDX3p6/apNk1y5G7jD88dvp2oi7EeRXj2ra hWjuHcSc7ThSPTPrVu5MFyZMgwz28YEsjcKi9vp3qeUQLCWjLj7L82Tzkn26evWo7COQpIhgeVZh uyxznP8AT/GiT1N4bESWlywCRh1hlAO09fqPT8KRtNmENxDIcSBQbcocE885/CtBJkR7SNZCftUh RM8bSOtV5pYBdRLNeobyIknJwABnA9vTPepNXBJaktoWBKzou9/l/D/GqywYaeBVRo5MkJKMgf4Z p8d3Cv7toH8ydsOi8Ee4NWp7NbS6ldJj/pCBFyc7SO/0NBd9Cja3UsscNtLClukZwS2P3fufbpS2 aP8AOkscsc07bUJ5A9OKhlsEyr3M0kIzliSQcf56VeaSaREJdGSAZRlXGz6+tBzO17jlKC0uF2M9 vH94gYIx16VWgtfNuob3AkVFHOeX9selLB9qtobiAqQlwxZyTyw9B3BpVgjup2hkM0a+WF2xHaye hPtQTKq3oJeNHK7xxQzypA+4PjHPoPb/AOtUCy3RnaEb2SNAXjkP+sHoB2NaMiylWjcSzxkYzGcF D6g1DYmyjaZPIu1aFBkyNkn6en/6qCql0xDZRRocSAJMduRkeVn1PX8qg+zSSXtrJILhFjyWI6MC Mc+3Q1qzS/bnKQN9jtrdc7sYOR1PHNVLSSe6trmPEwmV8M2RtYe3v/iKI3FBLqZ0mnmGS8ldbuGJ 3+Us+cn1x6c/qKfYx/aJTdF2mSMYBBxg9MH1rVdJHuPLvradIFXa0itwR7d89PzrLaRYGmyXiiYA Io6n3rTnbVmXJRjqi/FbG5nZiJEdTuwDwffHcVlyWha8Ml1JC81vJ1VfkI9AP6VrRym3eMr5iPeL 5aKWxu9T9P1qCfTVMjT3V3HFjDFd2PL56n2+lQjKV3sMUxSfaktGC87Zcjrj09KjhuLu4tpZfMmi lK7I26YI/qPWtIWMEaXpjLBp4xuIb8j7D6VYPk2UEe+CWRuhQjg+1TzK9kddOi+XU56KymaeNbeY xpb4YbxnzW749Pxq3NDHcxSf2ijtKoIRAeT+VSG1urdIVaY3MchYl042r6Yzn0Gfar1wgeOCJbOY fL80oI49/r7+4rSMrGEqVtjDhgu5bxZ7WP7Rbomx0flB9B2PNX/s11J5JWykubiJ8BVYHcB6dulR DTXtrq3Tz5XeMb+uNwI7ir1nHNb2lx58hKliyuTjHt7fWpbKhFlOVHeePaxjjun+UnquP5j2qCCK /ljM0in/AEVmdNo+cjPf1Aq/BYrqEM9uRP5knPLYKe/sK09Pjls0mF5J5yAYhVep9z60c7Q/ZXdj Mngilt7eaKcyyOeGQ8HHqO+DVGbTnlngmlmMdzIcAgngeuO9arDIaaK2la9c5QA4C/h05qvJYyfZ NrsY7mOQTKScuv0P40lK+opUraCPb3jTSf6NHJDBgAqQCx9vf1rNmb989rFPslnY45JCkdeKvDUr iC6kLXaT3M8e0W6pyMZ5A9Tj9DVmdE2xukIt55hkFxu5xWsbWBDYJkhgu723gO22THOCCw70yS2V YLeW4nBjvMBGQbQrEdMnvj+Ros2nmeZrSEralvKYNzk/xH6e1FzBJBbrZhwLcsRzk49qyNXG2qLH 2YWGwYkuIpz8ig4Y98e9ZyWrTBobsTqhYlZAT8p9P8+orUssTLHJMzO0TfKuORRcukOYi6vuO7bj G3Pf39qF2DlbVzHlktLm5snEflJjy4pwcLIw6g461els7qWQym7X96QSNvQDj/OKiaWR0m+xhl+z LkpgEt9M/p6VdtY7kpZXc9wlxBIdspUYZAOw9xxVzdtEY0qd3YUQLb6chvCxmRyVy3X0pLfaXu4Z Yfs164EmegIPTjtS/ZYpIbr7QHlUZK/N+VJbq1xAWklTDkq5BwBj37VzyZ39hbeObyVsY0YXCSeY rjA25Pb3/wAa3tOkYSiJWc+UNgZjnJ9KqRQ7vL3FnjI4bOCv4/lXS6bEih5IoBd24yCVHJIHI/z6 15GbTcaE2ux6GBjepH1P36/4JF2sEdl4odBKjxWQDA5IJZ936fMPzrf/AOCgXiKDTP2lP2flTTb7 ULm1uoXMUZwZ9vmSbVxyCdoGfrSf8EmdOSLRPE92sM8LGD5t75JJZSOnbDHH+Ndd+2BJK37XXwQu INJl1EaHaPdHAX5mjjmcD8F3Ma/zjzypzZrN/wB79T+u8qh/ssLdj+Un4fSstp4iujBd2ltJrV0W Zn+W3UPkK3PYlsn6V6JcrG8luYoZn/2s9f8ACvPPhbYtLo2q3cqywrqWqS3Me/J378Z3e+4HP1r0 0SoZ2t4bdp4pP3cjA9PYdwa/u/w6jbJ6CXY/mbjJf8KVR+Z9QfseG2tv2gfBmuI0Vle+F7PUtSZ5 FzjybGdlIx1w3OD/AFr5Qgs3EaWq5/f3DlUY7nCZOFJ7dsGvqP8AZliTS/EPxY1U2eovF4b8Bavc IY2yyPLayQr17Zl5PuK+Up3voXu5UtLiWC6neRXVuVyxOK9fDR5sfKS7HmV1yYWxNHOsxuRepKly g2R4fjGeDjoT1qpFHdRCaM27SbhujK8bvp/nvU8Utlcb7jyZxLwjSlht3DqB7jv9RWmXhZY7WFS8 7kbgzYdfT8M/nX08YtHgw2Kb/bPs6yJBPO7Dbu67QB1P+e9VpmhlUyWsLWhgUebHuyH98e/WlvBK MLPK8O5sMAcBx7elRafcMk8iw6Xc/ZIWwxk+bex689h7ds1YnOzZXuo54kS4tf3dxb/vMtzu78Cn 30xu0tWjkPkuQqkZHzkcg+tasEYjnu7qYrCyIFijc5PJ6+n9QDTCsJvLdCuwSvt6cA49P8KCJSuV I1ccTNu8kY3Lxn/9VEFp5VrcytO7TLlwWAPfpg9asSzjynYZQwPtx08znGBVm58lLKW6dfIKLnYx ySf880Giihxs3kiW2Eghd13CTHH4j2rO3SpEsTpLAyybc54fHXkevHvWlPOb62gaI4nwFGz5QT0w B61kR3v9oXUOnmCSN4GI3dlI7n1zQvMVS3Q0g1vLJHMVMIViAz8B/XHqKrXdniaSdQyWyrlwDnd7 j0qwPs8u+O2Ub5GKtcOcxw443ewyMflRFJJDbTJNMA7/ACygD7qnt9az5zRRsjMvx5skVmsdwomG 0N3TP9a0I5DvKi2kjkgjGyQAFcj1/wA96bNMhntgkd1bsh2mNhnzARwwPocZ9ayzeX0N3feXCz2E qjepPTtwe2T/ADraGpxV523JsR2j28cUX2zDb3VWOWz2pks9w9oJ7dMpCDk9c8+vSrctu07+ZErx tKoBj28sP6U2K2VIVEfmGzD5Y54Q9y3tn+lNyuaQj0G3T4+zM8bLbwjfLITwM/8A1/w5qK4uAbeN 54pZ03nakZwSewAzycVpMxjt5R5HmAHOG6D6+g/xqjHaNCl3PPI72kIJXaOSfQfSpCc7bDmQxIzD eFIGcdc/0qxDHHE0cU4Z2nwVyT83/wCrv+NLCq31mhWRVjY4TH/LM+retS2cT3FtOoYJsyu/HT8a RpGWhUljWWVYU3MW+ZthwUx3B+tRT2ZkjsmiaVpUk2su774/z/MVKlslylssqzo7P5eFbDMf8K2L e3JvGgksp7h5U8uMgkc+309fes7NbGtOSKVjgDyp4QmMnJA49s1RaTbK0HkSRojESPIOEOfQ1oNN BAYnLrhWI2sfu47n2qvJI9w5SVcWvqOCh9ffPFVHRahUsT+bPGBCym4SA5OFwAPf2qi0Fw8V09xs ZVXCKBtZRng+9WV8+3uWvJzI1hN8iSAfKMdfx6U2MG5E8qqbgsxUMhwFAPX9MfWmmYRbbsStZhmx FOsnkRBmGcnB6ZH8qylSWaJ5Y5HtJVJDnHYduK0La3mNzDIILhEAwpU8N65qYxm2uJo1jZfNHzHO cf5/qKpFujd8xmRQHT9jXLzTi7O0YPyjvV8l9yWyow6SeZngDtRH+/iLOGtrG2Yq24jc3v7D0plv G+LiRjKqSHClu2O4FJnRGNtBr2aB5DcTx3D3ihfubcYzxiqyRRRBwXPmRnaFAJzVu6maYw2dvNHL LG2ZH2gBM9setW2lSI2s0yNE9tlGYY+cduPWpUkTKXQxhBc3L2siSLFCH+UZ++2OcevB6VO4S3lb mTp+8k6kf/XpjSzkeY1vcW6OdwjZsg+49CeP0q1AsSM3nQzxyynGHbP0P4/4UmlbQUYa6lcQ3ssS mW2+2QO5B8vgqueDz7U2eC4tXmjgjbbcoAwzksv+fStbzFtre5MSSQRD725s7/YelUvLNrDIkjPL Ld8q2eVz6D1xWRjKNyWyhFhBGpb9+5O9QPug9KPktZzcm8VIo0y2wFWk/wAMVKq29tCFuTciQv5h lJ+Rc+vt/wDWqexWOZpBJG4RugJHzfX2xVJHTHYyEgdLaGdZUNv8370HAT8fXFQWCJBbvJYmSZZG JDA/K5zyAPr1+op9utusVxHIy+RJIcJngGmSIkN1ZWdpBLFYwkGQ7/vE/r/+utbGc6ltS9IrmWCF jvlf7pI/1Z9T6is22igku3mlPmTxkArnjjp9c1u3NpPPf7nLTIqEjbx5Y75x1FQQNZYFxMVP2MkB kbgnpz/nrUc1tjCXvhNGzeQ6P9mW1YuwI6DHH61mzgzXMc1ysqxFNzPuxwM4/wA+4ra1GeRpohas GZ14+X5Qff0FU57Xay24fat0oyxOQvrTpnfK3LYibZAiQeW1xdsN4KgZUHpkUlnY21vFJJbx7Y5W y+f+Whz39s1BEJJXdHhlL42rtPLY9K0p4106IybnCzgDYTk5FaOozCVNW1Kt3ZosE00MMshVTtgI 5ODyDntUcUMbQOksMpuT9xFOMVfhk3TK4ZljUbndz8hx2/DvS280To7TKsF5IrMFUcbc4zjvz1rF zbM1RV00NeSeK1NyVi3oCIzIPl3D+faq8qvLb3DXEbs0fzOy8L9D6Y/qKZaToPMgvLa4KYLuA+do BxkfWplSWeOOO4LqT0jXgY7ZHfioMmR2lrBGiSLI9xbkb9inp659f/rVJ9muJJ7dLKONrQSbznkA H1/GkgazhD29lJvkssvIinOc9jnt/hVh5o5El2zDe/yqqcAccg+/+FVKbOt04NK7MZZ7r+0b9LeG WeCEZcA/6og9c9u351cMl1eXCQrdfJajfJgcH04qpd2++KOKzLxDf5kuW+9k+o6VPYWt40hm3b44 zuUqOcdOT3q7aHG5PnsXbnyCJpZ7fmcBf3nXj09PwrGQlLhGiWSxgzhxIfvD1HpW3JcPaiSK9TzA AGGwY8sZ+971Fc6evmvcTGVYxHkqvVx6Vmjrq9GS7Zr3zTHMUlUBQCPlbHoOx9azdUFxI6W7P9oN uocYH+ryO471fvNQjC28VvazPDuwBFgZPpn1pJR5ryOUzLgKXU43jsPb61hGLuYVZ80WkVIhJE4s 5IWFlcRAxyk/MG+vpVhoJ4y32iUSlcDeOBn0I/SiytmhSdkMqX2flLEkKB0wPXP+FO8yW2upjeyb rnZmQqMbB2OO1a9SqdLl1ZIsacXTQttRCRzyfYepogu0ZHf7JGLntkZA+tQKJJlsCrfaIpZiBsbG 4en1q66lt9jAjyPJlyyrynHJ9hik46mrq3M+2gcXou3eeO1cEG3BPbv6elRB4V1RIp0cyTcLzwvv V2GVJIzPNcGY2ikny+BIAcfTI71LaRiW1kvk/wBM3gsFAw305okzNRSZmS3Tpetbx20zIeev3alm kurRRdLbSRq77ZEBG4L6j0p0lul5HKBcPbLHgjs0Z7n6VZ+wahc2iSSOfJB8tcNlsevv+NUkVKVy Jb3BMBB3OMlnPAHanW891kvf2w8yAk5QcKvYn8KmDRToPsoWaaDPmYx1Hb2NPlZHtMLKY2mOz5uC T6e//wBasGy1CzuZyxyQs06zeZn589Qo6/hWlDHbS35mESnem0DbwG7n6mmW+0M9rEswlx+8PYg9 quypcebZ2dtCBE5+eQHGOOmPWplKx0R1VjDmtoJJbeSKeR3uGMZAkyvGeMdM9fy5p5F0062q2k0I lbYrNjyz9f0/MVbST7Ks0bW7zFTnrgA5qHzYZbhbbUHlEoXesSuRnPf/AD6Uou+5jJag1vKWkRJY 70XXyh1H3cen8qb9kspbUw75Ve0fdkNzIOmD68mnGAw30NxC8j2042PCR8yY7j61I8SSQzX1us9v BZ5yp+9J2wPeqNkla7MuS/1COaG0sra4cRDfLIfuqDwPpzWnqEUSxpLdFo1uAF3qxCsR/n8qpyPa wQ3CQGXzbtQrEtkrj+VW7aNpLC2ssi58ljI2SS3PpnoBWvIcUpau5G/z7bp40nEJxtTqo6f1qFoZ R5LWsTOJG2k98f4VXMto8UgtA6TLIVc54j9yPStS0XDxSwl9j8bEPzPxjHpS2KWuhXDTxW0iTNG1 qWy74xxnp7duao3Asmha1hMhuL1vLXGeB2P6fjWvqDabHGtvIH/fsd6FuWPt+tR2MViVVZAUdDlF B5b/AOtxWVzCUbDIoDEUskZphAudueUPf8ae0HmXQjiceWY1Mzy/MoHr7c1UktolvZGLXE5uOch8 AHuPb/8AVUhuHhnZYYzmFflBP3yfQUuW51Upe6ky1PDC7tb3JlRUYE4OEPpx/ntVl1RUjnYzIj8e XnGcelZw+03jQ3EkqQwwclWGT+JqSeeaad44lZIbZdzq4y31H1rnnHU60Zt1qF0snmQxtc7W3NGM AgHjr6fWtrYrSNI6gS3Q3JHGMH61TsYbdHunRg0xAJRjknn09P8AChf9I2geZtRvvg8H3B6gZq3b oTSiyC6gZYLWSLfcSwzFrhWPzbT1H54x6VoXFt9mmW52kGFN6yN/CMc/kP5io57KKRL5XYz3vCqy OQBjsQP50sE8tzEI4syXSfKFbkEjtjv9KlxubKPLqU5ots26EurTplpC2VTr1H+FEbNPcw+XPH+7 XOCMk/T8auPHtnWUowm+64zlG9APfrmqsqLLcRTJG0Btsjg/f49KZyV5N6D3CBEljhmedXONo706 4s0n2otncwxE72JJ2yE9cH0z27cUsM93LdRxu8drE3GHAy7dsHt9KkvLvymhiLP97y854Y+g98Uk OGiKRtJ7lwnnJE1ucbfu8dqhuFukngRCZjEd84P93HpVyC3BifzJMzFz5sf95T3FWLuJHdriAFZ2 AUSg8Ljp+NNoQ3zIFs2SW7+zzf63OOAp6f1/KobW7s3C7i1qIfl3t0Y+/vVqK2hkjjXULhDJH82O marJPDL5pe2aC1hOCXI+b6enQVk4G602L0wiZ5LdFilkYBhz61nQrBemQuzCWNscHhQOM/Q05vMC swUR3afMFxnCnocehqOJZoUt1JiRmmaS4w2WVD9w+3T881nyoU6ttGYWs/brdoZbGSC2iaQq/nfN HEMcs47gdT3r+Z39uvUXH7XPxWZYFms1FrDEu3kL5CEsGPPJYkemfev6cLmS5je0v2Rbced5Ukjs NkCg8MRn6eucgfT+Xj9tm7j1X9q34u3Vjdte2s2pLHHMg4ysaKQPoVx+FfmfiZK2EUbdT9C8Ooc1 ecvI+XAxM7b1Z0txuQZ6n39qq/OjC5K/eOCMdf8ACr91C9sgiUrHsG7B+82fX2pqvLCrKxCvsGNy 5DfX2r+dW7n68opEsdpBLHFFIRYbzuUnPzGqchcSTPbO0jt94k4Xity7QrY6GY8mW43Haw5b1/Cu a8sIBhmaGeTDHHArGaNE+jJbvzle3W6UmHOOmMGmxQIsrxlyHc8c449DWlf/AGX7AlhC/mSxNv3n nI9BWGxSTyYiGeYHaQvBX3pxS6ktovLE3+kAyBkt+SF6c1dtJSEWdH8gDheMlSPbue9ZcdvA5cLP IJZONo6NWpbLAtoZ1Zot7Bcntg9c9u9cWLlaDfkzow13UivM/VH4kQRy/sQ+ENHN3KVsbPfJOjlY pdx3KMdQUztPr2r8ookIs1WG+iuOOSV6f5/pX6q/tE2X2P8AZa0K3itLvTopbKFUWaT5nOASQB6g HBPbJ61+T8Cy2zwxpGJQjZbt1r878O0nKvPvJn7L4q03Gjhk+36EkapGYY4pwZI8kHv+NMAmknkY P5OUwzdse3vmkbSjPdO+HgtWYc55Pr9K9J+J8ngy48Q20fgiOW08OQ6bAk3mNndPsHmkcD+LtX6p HY/GTglVo4jHKxaXAILdxUkW8ygbcLLwS3X8K0fEmqT+KLxNWv7iPzNqxsIYljDBVCjAAA6AUJFZ wJAUbMknILHtWcVrqYSjYytUg2BwsBtViOdpbk+9RHz7lLeaBXxH90evrTtTZJYytvOtwVOdwP3h /wDrpVWeU2cvneUsLbWCjr7VcpWMYxuW7FnUlbdERzgbmGVBP9a1Lm2VVhjPzv04bB/GqCWfmRz5 WVdhyVzhmHtVu4SN7a3huEaFt3UN1prYqXYqpF5UzieZWhKYJX+H/wCvTxHNZWojmZpTcDjPXHam MI5AY/MVTu/dknhv/rVUaW4up5Id7JDAuVBPNKMbExiSzMGtGileT7SWyMdEpkayShmVz57/ACgj qalijc3CxSAzQxgDd6VNdfaxMuwRoqnKoByv+cUT2N4bnV6TaGKaNQzGFQMN/eP9f/1V6jYX+jSP BaxTQotuMGQ/xnvn8a8TXUpDA1mJSHzv3DjbXU6RBc3Gq213asWeIY2H7i5/iIrxcdT5oWvY9/Lp ctRNK5+9H7Hf7cP7PH7G/wCz5r6+JbnX/E3xP8aXzyS6XpFsqlkRWW2WeWTCBAXlJ5JyIz/CQfin 9qP9uqP9oh9J0aLQ9e0XT9Fla5t/s96Hlu5ZE2iN3wp+VQMYyB68kj5M8P8Awg8Z/F/xx4W+H+hn bqPiadLaKcI/lx5z94LycDPHc45HUftL+zB/wTm+Gnw11a38SeK9Qk8f63Y+U9orQkRI6MGYlGLB 23dAflJAyMAA/iPE8cvoVvbVPen0P9BfB3D8SZxgpYXCrloxWv8AXy+78fD/AAR/wTl+OWoeGvA2 mXvxX+GunfEz4maXbazD4K1OCeSSzs7k/u5ZLkKQTg8jjGF56Zq+A/2OvhP4R+P/AI6u9d8deF/i JoXwhMO6ztt1vHqk33ZMKSxaIOygNgFsEgHAr9wtQ/ab0Lxb+yp8dv2hNJ8O6Joo1eea1+1XFlum sNO04xR2sUchGFHHzKMAjb1LZP8ANB+zN8Fvir+0N8YLnX7HV9Z0H4WaFqst9qmoxTSCKYbmbygF bLH5uvTOFHPA+YoZliMTKSc+WKP0HJuEKWXYmNepD2su1tL3tfbun9x7t+27cavrHjHw78MbTxEh uvC9nE1wWtgqWpmQssfAGWSMRqe/PXrn88NX8NeKvDwiGs2UV7pz8faI9rJ7BvT8eK/oB+E2veDd F+GPxo+LfiLRTe3eqSS6bp5ukV7NrK3BWWQgg/MSy4OOy5HZvhz9ij9m2D9pSb9ov4mfFG21PRvh v4a0OS90iRZWih1G585FCRBcqo/fKPunjqM9N8szlYWEo03oupXiBwbVzHEQr17JSdkvVn5uy/DU aj4buvFCWN7aW1oCzyFT5Tj2J4B5B/HHFVvDnwM+KHidEh8K+C9a1e2ujvW7RVaMjOOTnjB45r+n L9mz9ln4Razr2naP43mudP8Ah74Nsv7RvLiKQLLdBYziP+8/zKNqZ78kDJPm/wC2n8atB8GfD7Vd V0Oz/sKLW3l0PQLf7FCskLKQdxTaqkhVPzcdV55yfVw3ipXhBRhC7fc48d9EjKKlVfWJuGl21Zf1 Y//T/I3V/Elp8Nr7wtZ+MvDTXnhmC4LwSWhB8uQc4ZeSx549fXpXul3dg6NB8QfDlheQW6RJPdW4 OQ8G75crxyc7h3AOPUV5jBNpnxN+JltafYhqGieD48hXOwee5ACSr7gDA9jnA4r6aWG3htYIY4Ql uE8t0xgHHH9Pwr+/sHkEKVVOLvY/mPHZ/OeF5KsbSYmk3U+pWtve6VMlzY3ILFUTcJB6j05xUmsa o2laTd3E67Bbo0jIsW99qjdkL34GePQ1xei2+s+GPFem2dpDM+i+K5fIt7kR7RbynJ2EAneSSMDG OfXGcbxtrvleK9K+HGo3hfV9WkeTKIQ7hAS2TnIAQNkceh7A/RSxEIaTdj5rCZfVqK9NNo8u8CHV 9Y+Nni7xJLptrBYy6fFDHA8R8wRSAh3DHO1jtJ743ADvn6s08wPZuWT7SIDtVlwA4HGCPbv6147o 6WmnfE/WlF3mGDR1VIQgUgZUux9R8q4PbOe9d5cXGp+H9OMdj5U9/K5kSJ05IboozwW6V4mDxUVU lVm7H0uOw8pUo0Yq5h/EC2/tq1bQLbV20WPVEdbko4GyNcFyM8cZ98HFfPvwm0+bw9f+JtchR9VG qKi2UJcgDyRiNmbkjgsGPfPHrVz9qGK+sfhYut6zLNb69PcxW8Yt3MSwLnJ4z1bKjPI5rW+FHg3W 9X8DX2t6II5Nentljg82XEfmqDsVvTcpRj3+bnmvnsw4no1q/JGat0PosBw3OjgnJJ8z3Pnn9nzx J4kh/aA8fJfQKbSdJ44XsY9tshVi29f4gWfBz7ge5/R4W732nacv2m3itrpghJABkPoD/e/wNfCn gfxP4D0/44aZ4eQzad4zu9Pks7qAzJtMhVW2YB+8Wx6/XkZ/QzxG/hDwhpEeq+P/ABJpvh6wtIgs cbEb7iXHKKB1bOc49OtdOV5xRpSlKroeVn2SV6vLToq9j8sPjhpWmfD/APaQ0DxTNp8l8mu33nmS J9u1QSHU8ghmAJDf7RrpPE/7R/h258Jp4Wt7M6Xqsl80s+2UGW1gBJQA4ALE4z7cc858A/af+M/h /wCKXjO21DwpplzpWo6bEtrEkkm6WaNCxQuATtzv4Xk9M+/zZ45s7t7C01e3ZrK+8sJdSDnH+yfc En86/MOPOKYzqulQlo9z9K4TyGdLCwVVao/R/wCCviCL4i/ELV/Huo65p9xqXhe3juIIpVBaWSMq IwMcEKuTtAz8vTFdt46+NFtBA/hnRjDP4l1ndc3Wo2kwjtLO3YEbkAzl85zz1HGTxXxP8HPAni37 DbeJbKeSxW4HkbpDgSFlI4H94gnB6jGQeKu+KtXtBPcaF4Y0bU5dW0pSt8Ld/NdQvUAdj1rwOFs5 nRUoU9ZM+jzbIoV1F1/hOt8O/DT/AIW75vhrRtNuLWK3ZprjUI8RjBIDKOhLYOc4wOvXivv/AOEH 7PfhfwUj2WiWcM9+rEfbHXcc8Y5zwoGenJJzn04T9kq01BvhtbRX/h+5hupZZJWbySshQO2D7fKN 24/3xX01rPiXSfAFpCZNWtovEOrsLe3tA372RnHyALzzkg59M45r9ayvKLUniK7vNn5/nmb82KWF wqtCPbt/keT+JPFM0fxl0XQrLRB4j8N6VCsMjo4T7DI64Y7e7AY/AnGMc/QTalEPsizXdrsulyJF 6IAOM/59a5DRNGOhafP52iiPWrqWRromPDu7NknB5A6deevrXnHxh1ttF8JJpVnuHin4gn+ztLEW dqMQd7tweAOg9Se+K+ryfB+yh7WpofHcTY+pVrKjQ1SOG8S654i+JHxiTQ/DGptJ4O0iJf7R8yEG G5IwPLT+Ik7vm7cc8dfpaeCx0jQm1drho/sv3S/O7aMBQO/SuK+Gnw6l8NeGtI+029/b6rApupgo CCWTacs46/xEnnHpUXi3xXo+l20mreJNTs7C+0+MG20+RiWuecFtg/h9/b8avE5hyW5pHn4bCSlL ljEwPEvi66XD6paNfaxfurWOlxIrPFkHbnaPvHuQcADAyck2fh94B1syXup+Kr+0n8R+IGX7TDbR kCxgUY2REk4O7BYjPYDjk/NvgjxR4dt/FH2y407XvGPjG6gad0hjKQ2QJ2hhnnJDEcZ4yMgnn1+K D4n+JdRMus6vaaR4UuEWCO2t4WjurUgnf5jn26YLdulaYNqpK6Lx96MbPc97kvvDWjS241PXLLSH uJzAr3MojBJ4HB+9k8cZ5qJfHWnM9rb6BZyeIbt5fmQkRpCA2CWY5GO/0B615tpHwb8HaLdQandW 8+tarcAxRz3s0khmPUbgzYcD0IOK9bt9ItGsZIpYDaLjcPLAQsTjIJHbGDjtXuywtWquWDsj56Ne NPVq5keK9P8AEnja0n0nVNUu9I8OTAPd2mmkQtcIDwpfng8cce9UtK8KaTZvFb6Xo8MdvCQH+2D7 Us4AIAO7JOOvPFdnaamJT9mjjDvbrsGzGTjvUenTJaMAriZFcmVgOgJ6DPQ+9RR4cjBe9qVUz+dk oSsfKXxM+Hd54Pu9K1rwPrun+EIdPulnlWc/uJEbdujHB2FvlHHr+FfUOlQNq6wX1nctNc3EYk3k ZUg9CR0YA8Y9apeItC07xFY6lpd7bpNpt3G0couRvjfcMEEdTjOa+bfCc3xH+EPjHRfA+oaTe+L/ AIca1ctJZapY3SrJpSry29TgsM4yeMgAdTzMcP7CovZ6XNaeJliKTlVd7H1pDbySR3MLXCQXcY5H YL6/Sr1nGPs4WTMcNuPvY5b2z3Pes6CQahZ3LWuJVP71Sp5bnp7Z/LtSWUTG6ma8d5vKhDGJGwHz 0A/z+Ne/CB4csU07OJqQXM0HlmZk+Rz82OoPQY9qZ9pmuHvIo7i3uLZR+8iVcBh3x6e59qy72/tb O2hmv5/s8V7J5Me04Jweme5/wqaVbYvZiRJVR2KFVOC2eB9a89x5qlz0pVWqfL3LUmXs5Z2+6i5R FPBH8s/rThp8Rt1dLY2oKgpGx3MDjkk9wf0qbyoNPQRwS7rSAmQbmyAx68/lUlkty10ouons4cZX Jycn1/SvRjfoeTGldme+miSZ9qCCaBQQSMhiPUelQtC9tLCtsWY3JCAsvKknp/hj1rU1WKOAAW9x JL5zY+Vsbu/5Zqnaxx3BEbR3P2eUnL7sCE/59PUV2Qm3E5qsOV2J5dPee4WB5JFjQZHJ3H8e9Q38 UslrzcbFTKCRTgMR2HoR1p6ROkVxFdTzzwq5cuF2si9OtSRoZLKFYVMUKHeiuME89c+5rJu50KVk V4Iobxg8ymCFAE8rPzPgdQfU8mlka2gnt0cM9zuIxjITjjd6A81NB9tcpnAltTud2TChT0/H/Cq8 63yfaGhh+1Ix2gY5B+p69uKI6mEjUw0MBma0eOMk7gCD+P8ALj3rNlhjt1F8zPLMR90OeMdBj8ab axvGyW7x3IvN2/zQ2UJ7YH9PpUjyx3StBHBJJI52sVHU9CPb61py2HUl7tjO06KeVRa3YlWO6b94 3dFPI/8ArVamitbG8s7WJxP3C4P7zHt/jRYpIttcWRjZHn437/8AWe3saszRwwXNusEUv2xcHcfm GfpVylqc1Mjh8u7kac29wG4jCg857c/nWvbQKVhEoW7t42JKxjBX1NZ1/GEvltSskAcZk2nmT2B7 VbufNkjEdhL9mMg3McHK/lXPN3R1Und3ZBFHBdz2aQJMkNtOXBJPJ9/b0zx0qS7vluNc1eK/0qXR pY5RCu18qVAGGOO5znjHUVejjlRmjQxvMBs8wDh/wqXxP4kuZvFfhSyhg0210q20pra5kAHmyFDw S/fbuGc5PU8Y5+XzvGVKPLKOx9hw/gKOI5oy3RpatDNDpelXqyKlxMZI/nwcqm3H0+91/CvOfEFi utXDxR20ivZoskUgcqYJccMvYH6jByc5Fauo2UEWveGdec3j/ai1hPiYgSqAxjwOR19e2alSTzjM 7iWN4SVPGOhxWWSw5udSNs9rOPI0zK8OSSTJcXl3AYdQRytzEpxx2GM8E9RXqupqfFVhBLa2VxcX ulRtKZI1w0qDAAOOTg568c157rd1BHZTa1dwSRrpS77kwn5igwAevTHUe3HpWz4c1CSK803WNC1A Xun3eJIiASuAO4PvwR+B7VGPoOflJbGmW1Ixs94y3Fm06Z9iRxsp2h5AeTHn1/OvFPHMdhquk+Ot M8N61IbKCJbhoLSZoprV1+98ygk/OjAj6cV7L4stL638Ur4m03UDLpmp2oUWiqd1vOp+dieFCYKg D1PbBzzmqfDrSdE8b6vrOnxzW9v4ytYL67tEYiPfyrMhPQNgZ/zn43GYqljXGM3aS7bn02DwNTLu eVJc0H32MH4R+M7jxRY6Pq2oWxgvNPnNvdx7yRL5fVlZemQMnrgHr6cZo19d2PxU1HwLHZzeHrG1 MuoglAFvI5eV8sgnu3XA5BHNa+mmTwv4z1vwtp0WjraXLnV7Qw7gbgNxPtUgDcp5z1G/JGBW7ba3 oviv4jaje6boGtaGltZRQytdn5rlQPnI7bQy8EdQwP1l46dPFRhVVkup2rB06uDnKi7t9OzN/wDt trXUE063tPPhgUPNGJ8NIDnA3Hgc5J9hx0rb8O+LNF1LV7bR5b4aLLPKI7gXR2oQxxgenb9PanmO 1inmazsTi3x8zgFWJzgAnuea83vdIk8P6rBrdhcTap4avjuubIncYgAfMaM4yTyoIJ9wfU4pyt4/ Duph9bI4eHMweAq+yxStdnmthongr4XePfE3hjSbuTTPB9pJLe3BaU+TBKSQsWxjld5Vm4wBjBxz V+4e1+LVvav4X1+2Tw/FdNDftbvIjFYwd2NoB5xgj3zz38q8a/C3w78SPjFe3dh4lf8A4RnSLC3u CttM227cqSAeBxk89clCOMEV9c3mkz+FvDkGr6HokGkQW0AjtYxb+X56n938rdycnrz1x3FfmnD/ AA/Xo044h7p6n6Vjs5oVKjoPqtBdGhWxE2lwxNb2enxqUAY7UPA+bPrxW94usNXvPBvhOwS51A21 1qM0nnQoBIrAAgAk5KfdyvfGOAavz2VvfjzlAtoNodIweSMcg46n19xV3xBBFNH4NEcxi1exa5li to5N29di5cr/ALoB5/u1+3Zj7KrhqfIj8fyylWpYyrGozyy+8Q3eiaXd3uuW8q+JPBUa31o6giO4 HPKnnb8oZT1Ociq/xA1ywv8AwjY+IdWtp9CtNS2295b3BJllb5nPK9BtAHXk9O1ekJZWOsQXdjqC Wl7FJAUMchwrkg8EnpyevrXnnxM8KaxD8ONat9O1Oz1TTbNYri3uM82rfKCr54IX1HUCvxXxCwEc LjYzWil/X+R+u8E4qWJwjju0d7f+G77N3bGO4tobUBrcSN8wBGVyM5+6R6V434jsPE8XxE1WTS3N xpnhDRBcR4lZYZJjksuz+8cfeweG7Cvp7w5a2PiXRT4jXVLIWlpbf2hJd+buikjYfLgdd2D0Pc9q 8i8PRXGtW2p6rqaR2Wp+JpmR5HGDtUERxuQey8HHBwPSv0WOfLFYP6on0Vz4L/VmlhMd9dSd76XJ PAX2LUvhj4lm1QS2R1cSSbpJC6zgSAYjHZsgg/XHavYP2ovBvg3x7+zV8OtR1V/tHj7WDJo9tFCB EibXEiOw7AbmAPovtXzv4GifSPA3hywkmuZVv9UubaKR5d+FW4fnJOWAHJyehr2r4nf8IX/wgnwp m1G/LXFleajFfw3EbvEsaqm0bf4mbc546CvyzifJKVWinTdrdT9MybOJwq8s1e58ZeFPibonx0g8 Qa5FbmXxd4Ve2sZ45E8xJ5oIVT5G6hmUNzxgkn2r6O0qV5Y7fU9LW0W2vx5ZDMHa3x1VvcHHPeuB 8E/C3wT8OfGfiz/hCtO/s2z8XCDXVkWUlSxDB3QEliw3jJHGCPrXZWlla6HrF49pexyW+ot5skaI EjV8nDDjIJyQ3Y4B+v6d4fSo4bCpx1fU/NeN418RiXC1o7on1ZrSPXvCrahALm5sRPDKJU3L+9Rd u0nI3fLyPp0xz87W/h6fSfjL8RPhJo2pWt14R8d6QuqMJkAeyuFxmNQfbLdTxgcV9Ta2Lz7V4fk0 5pLRbNnZonAcz7xgnJ6KCAfbIAOOK8N+M3h7W9YOi/EHQdOk1XxZ8OpRdiKECNr6FQA0YYcsQikE DJxnrxj2qylUlOcPU58PyU4wp1PQ6XXp7LUoNH1PU9SNzpZktbdfsyY25cIXX1b5ic5xxXqdjo+n yx2V5LbXq6ho87XFv5rkgsATt9QGJwR05wQRXDz6ZoOraF4Z1i3j32Gozy3cFo4BePjJXI/2WIz7 16z4EZ7fXfDFxtuXNvcRxskn32VB8rDPHJHU9a+H4WUq9DExk77n0vE1KNHE4aUFY+ZfDPjmf4la 1491TxI8E/i+K7k0ttLmdh/o6ZUEqTg5xkHg8k9Ouh+z88dx4C0Xwzql7MNV8MXM2mSxKAkcaxuS j4BOCyFc88YHerXjXTtCj+OXjeKUrp7eKr1mt5La2CSRzxMSZAeysGYbfZR6185/BP4q+Nh47+LP w20vQDBe+G9Ymubu9mCbbePIP7tBzvYIT1xnnnoPT4NxcKVK1GNnexwcVYarVrONZ3ja/l/Wh9m3 WkedfajfaVA8La4++5ZnyyoPuoPp7euap6vPfXsq+HtIvbdlggAuz5jecBgALuzyexHucnjFaFtd aRoVqggLXF5fMWit4pDulcjqCeg3cn054qDQdF/s9FS4eJpm3SFkYnezHnnAOP61+q5ZhZ1E4zep +d5rj6ULSpKyWhpanpNjfWEml391Dbx69aSW1xE/+pmYJ8qnHTJwO4z6Vwvwce91PwHpvlXB1NLO STT7Z+SziF2QAk/xYUf5xXaT2WleJ2u9AvpGOnvEWeeNcmAqCePU5A+uK5j4ExLaeFp53nv9Nbwx qEpIyA0gMjMjpjjdtZSR1HH4eBjatPK8ZzzdotH0WUU3muFlCEbyX/Dnf3+nW1/apbXxVIJ5FjMf Uq4OcMB1x6Vzui3mjm5vNGl05ptb8NXKw3V6infKAcrGuAMkggjnoferXgjxZ4J8fadqeoaNrcNz ZaW0kcwEmGLxuVY9dxOcH8c+9N+Ic+r+EvEtnqeoQq0Gr2UMdtBbJg28uTnf2LkL3PGDzXxnH+eU akaVShL3/I+w4AySph5VaeKjaD7mF8Vv7a0qePxT4b8QajPD4bkxNpkvz29xHgCRAAc7+mGUE/KA M5OcDxl+0HpfiTR/h74LsPBur6XN4w1OSS11NJ0NuIEtyzvFjO9vlI524JHy8kV7LLP5kPkxxoIp nyq5GXOexz94kfT8q+FPjPL4x+FnjT4Z6Z4Nure18BeI/EB1HT7u6gT/AIkkjK0c8JYfdTG05HXJ FdGYYFwoU6lR/FucWXZnSqYirTofZufWPjfxJcaR4K1Gy8LtFdXwnUSWuxpHmXOdoHqeSPpXt8/h GDWvF62nw93G5SOJ4lJ3xk7BndjjOScjBwc8d68x0230bxP8PfiRL4lil0G90bSvMurYSH5JXGQ8 f8ROTwCBkEHoKvfCbWvFfw6+HVgJtW+23Njpa3kupTpt83cN8ZbGSCQV9cnrXwPF/EtPDYyLou7s fX8K5PKrhGqy6hF47n8X+IfGD3lxdXV/a350ceUzCFYrfKqY845zkEAHBz1xmtSwuoRfW1qIZZSx 8sq/If6Cua8EoIvCmj317Zm1uNeBvVZyGaRpDkjI64z+JJrqNZtLqHw9rOoQaJc6qIbCSRrcdb5S CuxMZIOSOcewyeK/WeEqkKGXe2lZN6/M/MuLOfF49Uo6paHKeHtS1nTtf8V3estcaXYWF29vo9nL cCVkxy0h28gEEABum0Vv/ESWez+DUPjmKFZdX0jVkaysnzE1y4Yq43AnDYLc/wBDiuW0HRIoYhZp bXn9pwQpEXlYuQD0UknBIYHk8+tetfEfSFufgx8OvByXLWz3uvz3d5vHM8USAhQT3Bk5PsD2r5ni 2nOOE9rJ+9J6H1vCdeE8Z7KMfchucLq/iWW7WITW4e5uir+YCo+zhgNuOAOO+AKorBHbWLXQiWPG RgH7w7kH15yee9SaVHZvefY4bBV0nT8pHgAu7tnfkHq3OQeuPTArS/s+CWNllt57cRAlhu3bfXOK +04D4f8Aq9Dnq6yPhvEfiL6zXdGjpFGLp8tqbqG0lnSC3vYVeQmUtsKcPsHXbk5A64FVP2jo9A03 9mvVta1aGZdUuFvotLmJH75fJKkAngAMVJI7GodTk1G/8dadY2Nnapot/paJJeBQTHtYK4Rcg7uM 5HXL5xgZ7z9qn+zZPh/4M8GTpHHaReHpbye0mjEpSefchUKPVFQkD29a+T8Qs3WHpclr3lt16nv8 BZW5zVSWyjueVfBYpaeAfCS6cIdR0u80uCVrmIgIWKBsAdQPm6exr1C+0k2rTa+8guIvEW1bl8n9 15QKqq+hA2+vWuO8Oafa+HvDej6XZ2/l21jbRxhEUKHIUL8o7dMV6pFeab/wjunWt3Mbb7NdlrYy naryNwyn8D+gr7iUfZ4WnWitj5iNZ1cbWoyempzVqJoJni2QYCh45COIye7DP547VwyarrGr+LPG 0eq2TFrUwrbTWsxMMm0fedOi/K2MjvgHpk9RdTTXLs9lauXWQqN/O36jv9Peububby/GlldNHFJZ axamzlEczReSVAywAOGbKkke2cjgH6DN56U8QfP5DR96rg7XudpbSQQ+X9tAt4I1WTzHONvvn07/ AEqlqWk63H4i1C4kubi6g1CKKNG3HEAG79Dx05Oa27a5eyS6gnFvdxiIFdy4wfXP8I967Hxa+m6e 3hVopkvLrXbSON4k4MJ37FVvqTkHpz2rh4ix8ITpzntc9fhfKJypVYxV5HFwabNqQktbVyFRT84H JI6nPYcUnmPDYaxd3lvPPDbwhfLBA88lgAFP97JB/AVY1bSrmTSb63S+nsGupVXKIrGVTkMhBBxw c545A61s6JeXunaL4lurVo7ryIcIhiDyQsxAXG7OT6fj9K0xOcRq05RRng8jdGtGUtzkNMWcTNf3 siwNM5xEDu3r2GegPTr06UiWb2uoxwxM06vIHa3VsMwY89euc1Ofs0F5/Y4mgj1TYZZBzsP+0B6E /wA60dJVtI069vdVeIyf6pFBG7DEnLNyNuPy4r2qeNjDBc77HhV8C5Y9w8/+CQ6PbW7243GRriaV mwXPmIvQA+vTr71k+PPD9r4gvPCBVBap4Xma6TYM/aXYAbT/AHQAo55zzxXoHg/S7GXWrLVr6Zv7 Ld1DEZ2rHnk9+x/lXN3oiubyNkuikdxcuyAqUC5J4x3/AP1V8xhsRGdSMJS0R9biKHLCU4x1ZDbW 1te3dxfsskbuNjKvGR3qK0vo5J7nS7GTfHAN0zE/Mw7AHtilkneINHprLdSzgg+Wcq3PGD6nFLZh 7F0Q2zwXU/Ktj/Wn0Hvmv0WlK8bo/MatBwk0yCc3ME8ds+9WHKO3XPp78U1o0kViEuAORIWb739R z/SnX1nqSvA8UMkdxO5XLgfuv9oZ7/T1qzF5VysFl5Mzyo2Q6n7x6Vstjlqw1M9raO5NzeJbvDc2 yAIpbPTjOPT/ABqqrfbkTzlnRYW5Ctgue5B9M9u1a86T2UgtZjGkhbKsw4Gf8/zrRlVhHCJlVdpz KQMFF9SPStVUMPqiejZRHnTARNEyFOd2fu+4pJnVL0Ozs7FQFYfx/T3qR5Y59OE1s7GNWKtJ0+pH tUctpGkMdzbzuYpurH7ox1P6/wAqxcTslZRUTTEFj9nd4ZMqoEUig4LD/GqlrEg3JGknkIcY/i9/ wqaRIXjjZC7s5wCv3RxSyS+TZwxiBzcE/ez15/z+dRyMtJGa06XLtFbWk4iifAJ659fxxwKuWoVb ySZHNx5Ywo6lT3FOieGZzHHJ5LQ5P++SORVdJJNKimmeF945UMMl/wDGtFE572ZalihSURMY4ZXO 7B7A9z7VBNITFCgmjWaGQlXA7Y6H2pZUSY2iIzSPNzg/fbI6Kex/woi0+3bSmdo57tkchgjYKj61 VtLkud3ocdrWmx6ppj6zZ27x67oUvnwl2AS5XIVk9QSM/Nn0zW3oF/ZalZeTBHe6dc2QCzW90AZU Y4O3jjHPHtWtPEVjjZEZpkOXCfLx2wOxritfsv7AuIPEUS3LfZAFmDkttTjG0D+EZ6YyOorKUncm nE7RHt7XaTbT3VxI+AFP3D2/z71akku7mC7hurKWyhVMF2XhfwH0rI024S6tYNTsrldQ0K7AlW6h Py5PYN357Vr2lxqDTxzu0t7bP+7MCgbmHqPXng5rnxGIVOHNPY9LA4OVWXs4blOG3b7VJE7MsMyL Hw2DJ3wB2NcdaNJbaP4ke1tU1CUXL3CkMVVBu24I554xx3Nd1q3l6VZ3GoiGa1aAOy8klsenuDz+ lU/CVmun29ktvaxwQuDI6McBgecfiSenqK8nE4unXpNw1sevQwVbDVbT0uV4baCWE31h51yVBAEv JC5OCex/zmseLUNe8BDT7zVXs7vwxq8k7WZmiRNk3AELt0AO8bSOeOa6y00R9MtpobSZZdNuGHkb G+WM4BJPfHIXHB479aueLrSx1XwE2jarbkxRpM6qw6Oe556EBMfTtXzecZop4WPLoe7kOTOONkp6 rc57SGRvDumXkci3v2pOdoyQwPzfU49PrXN61PfJ8TtQ0DT1EVhpeiQSyRuAQ8twQylTjhtqndye TVHwjKvgfQdM0jV1mv8ATLC0QWFyXIM5Cn5G6+g546DmtXw7p97qCv4puIxJcauBdfaEfcGQgCMY 7fu1j4/mea78FK8YQuebmFFxnOXKb91JNCtzJexHdo+CI425kVuBz3z6U24trNmeS1nDvEhaU4I2 45IwehrJv9Rgj8RaMbqz1N9P1mF7Zp4uY42jBbcTjI7gk8cjvVhrYPc2muWcotTbny/MjHTB+9jo etfUU8TJaHz8sPB6mjLKf7Omup7hrOaAbIICvzSMPu7iOgqPTNPKkNIiW8kn7z5ju+Y8nPr9O1cv qjajGsOlXsryq5DMzAlnUnuc5I//AFV2UbWLXEVql5DFLMoOGOS/HYenUitoYlSZz16TpxvuWomV ZoBcLKDG++HyjtdiPQ+v6VzfhqU3Ou6/qUu61XTJI0uCTu85WLhFA+iZ/KtmOOSKRruZJJjang7s AAHt7+tc7ZaBd2cOoWto80DajevKZ5HGJULFkx3IVWwPp6Yz4fEWL9nyRjuz6PhHCLEc8pKyR2lz 5V45NvKBsYEeb0kHPbsKqLBmZbYsxQciNR82T71ZFnI9rPOW2qnHl5JKr7e4H8qalgts6CVpE+2n bBET+8lOMkce3Oa9vBTjTpLnZ4GYU3Vrv2aFsrSZUae+CrcQNmNQPybFCtb26zDy5kTBYkHhTnnN YiR3UT3UwkuLoSDBQPjavv7/AE9DWssVvcw20O24Ec52l93U/wCf5ivRpvmVzyqqtLl7EsFyJYoW 8nyzK5CxkDIPrx/L60MzxzwyQ2k9y6HkbvTr/wDqqFkKXpQxFEYBEIHyoR3Pr36eoq5vFpqiW9rH PcQXIBb5wNx9vStoIzlHuQtHPc3RWJRFHtOXHVie1SRPewzuZWtnSdtvmBew/vfSq/lXot0aB9kb OQVf7wHfn8q0LeIWlq88UyvctlSW5Tj27U3LQVJ2ZmRJei7doIt5Jx1yce4/ka0JbyyGopcKpVlV Yyc/ex6frUk8cEs9rJCJU1NFwyK2M+mexqg/2djbRXDIgRywYDG3PXPqPzpcvc2lXcfhL8f2a4aS SBZkVGLfMehp9nFJBLI0t5FBZP8ANJuH6Z7f/rqNYPLuksxMoe4I2kDG/wBBRqlgfJB8xf3b4wTj J+noKzOmNTTUqXVpfQ3ht4YUWB2DFzyTn+nt71Z8q9WZ4ViZUwG81sAA/T09PrULzz3tuII7j7PL AQuXB4HSp7mWBPMXzJ5/l2uVYg49fbv0pHFOTuWltNi3F1M6rdQRAOV+X5c8fzqqkNxegtDMfnHz bRzt9fx/xqkbSd3DlwJhgfNnhexNaBnura2vFYFbZR87R8M3sPSg66S6srRW9/8AbLBoP9Ha2lDx EnGX+vf6VwXh50n02CODzN1tcvk9S4HVc/49BivUbNIUsLRLi5WaJ5MmR+RHk9W9QBzivLfDoeGI b0eKYSOhjP8Ay0wx5989c1/N30i5f7BTj/e/Rn7Z4PR/2mQniixbV/DfiK3iHlMLSXgkgOWQgZx2 Gcn2Br8/f2FLMSfE/wAfJsaHT00pQ940YeFVEpCxqo5ydw59z61+g/icSHw54kxIzSXVm7MFJy20 ZGMdOQK/Oz9gma0t/iN8TbBl1C2u2tLbEJlI8hxNIR3PscDtzX5H4GQ/4VdD9L8SrLLpNn6lfZ3t IJFSNtg5LZ6/1p9pZFTDfXE/l3A4HGFOfb6UsVtPdXEjTySfboMGLBO1gc8Edzg5rQe3nuoI4Le3 l8mF8buhY98elf3k59j+QKUU2x9tAzvHvDRZchcLgv8A41DcrMLV1Kjfbkk+kgz2p9zKyQSu0E/k 42gk4yfT/PqKI7LdALqZblYosSFC3LjHSlfZs3qUlaxlWDzsJmWORJTgEHuPUVYjtCkFzLcPNtvc hUYnII64/wDrVJqIM99ZvZSM9u5CsE+UpU1xJJHHcLcR3AULwY8bvYj0/wD1Vdzn5bEdvBPHqEbe YPKkQA5JwoHIqWazs7WHUlWI3DXHzum7HH9BVbTA9j9puJy04WPDeh5zwOx/+vU1kvNzeRW1xcLd fe3nIkHcDNRLTYqNTQgjubfT7V4IjttMZ3En5CepOe1S7WWKESyLBeseAR98dv0qwmmo0EN1A++3 t5dxQDcz8cj8OPX6VWmVLu+SJmVNn3Wb+I/3frRBD5yxIzWqfZpVZ1fneTkKar3G++aFoASkCjGw ff8A8478VdurT7SGWQldoG1s5yai2vbxGBtsMV18qbRhmx1579q1j5lcxFbRJLfJ50FyIHXLzbvl iwOMjt/9cUt5Z+bPPeorKY1GFzhWA9u1Nvw8d1aXCyqkUwCyMeE47fWpklkNs0s9vvt5sqy5yv0J +mKqNupXNZEIvJJIWmSeLbancy4+8Ox+lX5rSJ7qOZnBtp0G9ccpj1PeqUMVrbLa3cqzEFyhQDAP XqDWhHOm1w6lEI+XcOSfaspRD2uhn28OltNInlTzIrdd3DH0/D+tM8+BxM1tCBk7CMfeA7D3q99r gkkktLdCqvgSYHK47n2yKd5SyQu6KxaY7OgwCO/+fUVRz2uKioMXVvbPJ5wCFVIBXH6e1Okiiubq ayQzwW0UYkf/AGgT2P1/lUAZ47MxM7YyS4Xgsvt6dqI4J21JNRj+S1aMDaw5bFBpGJRWQ3TQWVlZ 3KiNyMs3zden+FSst1NpUlklq9vvc8FRleevHr/Wp4Lu2lkdfKeyhclDMxyGx2HpV6CWKBQyzNM2 7op+9WrWlkOkrSuzOjg+1QQwokjyIuCV/h7fnj+lDQx2+mTrvmnuTlBuOdwHQflVqSQQO8yhYoZD kvnGw9yfaiA2paOOa2uzHuLZ34555Pt7fSsiqlraGXbW08dqZoyzSDnaedn1qWNFXbdBJnKNubnB lPcA/wCe1WoIpY477y2PmXS7FXH+q/2vxqKO1lBUbjIiPmXdn5fp/hW8VbQ86SfQSLyrqZnuJA+0 7liU7c47e1NjnRZYLa3Ms8jsdxxyV9vQA1NLLb3asHtfO2gKkkXBAHT6/wD16vfJ5LRoPKdxhZMd /UUp7G9Gk5aFK1t2PmhJHnndyEZTgD2P+fSrVtHOSlmyRSyu25kbkqvY/jUiWAgKv5jFpDgnOC3+ FRTTTXFxaxK21ISWdhwW9h7/AF4rE7eSMVZmZqEtyLmUJbtLFCAUcYwhz3qxbbriIOro8cznPrkc YHpWvtRi8gt3DBRhSeG/z/UVQn8uzjtyFc2jvh9owT7A+tae06HG6Vne5nywSTaksdiJZ4shNytt C46j3Oa0Lny4HkEzE4UEqpGR9f8APWquo2zxW5kt5jDDjcQOGH0qy8jTvbvbIPIlQeYZBkp7n2z6 VcXcL62KFsqWyv8AZoWmt4z5isxJRieuQfTvnjpV2NLSO4juXgdYpjtDF/lXjqfarFtJC04hEYkW I/vdwyCD2pxNvLczxeXv8gBlz90D3FKTsXykE/y3U0wja1d0EaeYPlJHcCrVreCC1lN8gkS3G7eB xJ7etPu7m5uZIfKgkmk2dwMDHoPX+mKqW7ussMYj8uTdzu5yfQD+lTJF0o2dyaeCK0ud7NIlxjzB HnG4fT05/lVB5jmSKOacm8TmQsTtPoOe1attOxnuVmSScyKBKxABQA9/bPT8KZcG3uYHuJF2qjEB EG04Hf6/yqYtdSqkG9mMggto2ZFkSNEUNubjHufaobtnwImaSR8/eTjA7dOen9KstDp8q232tZpr XfwI32OWx0/D0rPjZLaQWs4lDkAliCMZ9PT/APVVRtsZS03LiwrJCJb2QRSy/KOew6Hjufbnio2a CyQecWk2fOmz/lp7e3vU0QdizXAaKJhjkcr6VTtbU3Z8tLiNXsyZEEgyrEnnA9/6VogLWyW5MMiw zQK4zsc5MY9ce+asTWLSXEkjo8UcqqgROAfQ8eopiWnlJteedEfJB3YKHPIz1+npVxL1lg1KXyZr dIIspI5G2Y98D2rGW51wSsUL2WCJmCByUGx1B5B/pUwuYtOitPOlju5rl9ofGRHkdx+nrTFeaGBL mPT2mubkbSDjkduD0/8AriqjR7HZCjtDKNrv2j//AFUezT0YTul7ppFDqH2OaBCQjkSK4HA9T7fn TDbWlq832kuYGBVdh5U+oNPtJPIZEjDpGPmBbkP6/wCelQ3dkvmySosxLD5ctxmoUbbFW0uU5ba6 V54Y3ZbeaMMCGyef8+1aKW7RyRAMlwHUBt3ITjqfrUF9DC7C3QuLx0A+T+H/ABqeCK5hsoY7dVmm Yn944JDY/oKZjTV2VraCNZVji83qRhjkNk9Me3+FTbXhN1ZzW5gQD53zgtngYI6dvzq3HDG1rN5D eW23BLc81WivLqC4gHkExg4DOch6dyqsHEprYSWzqGZzbRAPuJ9e34VavsXgis4mYxZywU4LZ6gH tU8tybF7Z2ge7W4lOAOn06/h36jisxoN100flXG0N5hCsV2Z/pUpWMVLoW5/PimaAbp43QKuBzu/ uj3pJ4JZ4pobcTShV2tOp4jbp9avXk10sxlgRWGwBxj8vbmoLaAhJ75JHS7ByFVvlx3yOhpnQqth jx3SxRws4cIu5k/j5HUH1NZxWceTaWrum1t59vr6ituJo5i4DLGJcI2Blvc/T9azJYWuJbu3hkkW Zk2J24/vCtonHVfMJZ28Ue77RcNdOCW4PLH0wf8A9VLdy3vL2cBRBgFTzs96ls7S4jkUpMnT5yUz vH/66WVbgRh3BMTSleuNo9fenKViqdOysy5aqxsWmlGbg5OF/iFNgTz3mkkZT5YG1QOn1pkEe2zS 3iae6MLney4G4ZJPTnHOPWppBG0Qis94nx0Y5x/jWBs9FoUJLSUzyG9feindHsU/ux9O/FPuRCb+ 2ijLFJ128H759V/KmxMkvm299uFvEQW+c5x9R2q7HPGUnnSUfZI/4CuHI+v+elByy1KlvIJDNLFI XitDwp6oPU+o6Y9KhmbcklxCm4y8AD9c+oqWSLzXWeCN4NPzuZRwT68/41dtpIooImuEUTTSYVcf eHbA7fWnzGiV1YqQyTCCCKVoIZeSWVM4A6fjQksriZEtmlZUwVIBI9/8K0LryoJIGMUsclwTgDv+ HpWdcXkttFA1rJH9rvJDCrAcbvT61UY3L2RVuY5IUmtlm3M8YB2ggLnsfel+zWsirJPJNPLGoHlh uSf8KvyxQR6QkgbeY2ySTkFv4s1U1ILaQWUzur+aNzcY2jHUH9Kr2ZyS3K62k0twJrzzLWCIZ2E/ e9MfXr9KszPA0EsW4iID5M8YPv7UkKvJHaSvKJLRmO05Jx6g/T1qa3gC3DJNpl3NcSPtD9VC+mPX /EVTijekr7kLQzNbT2cLNOoTc5BwQD39x/hVu2WZbkyyQyogXbGqnkHpmp1ktIoV8h5I3lk28nIB Hf8A+tU6r5tzLLGGt44wBt9T3IHbPWsDopx7Gd9sDK8U0PlzFj8x6LzwfypLyxildUhBY4AYH7y1 Ou0rNFMgEu8sJcZyc9B6Vbja1i2LLHK87HJ2nG0e/tSbsbtaWEibzNkBtnt3tQCpYj5vx6//AK6z tVV2d7eV5HlfDJ5fGa3Y4IDbtLcHy7nJOFPOO1c5DK/2mGe8kjm8t9qqRg49/Uf4UR1RjOXQtfZ0 iEMSToN4zknI56jPr16VZiSO1Rpoy0qIclD196uXUcVrMtqbK4Y3S+YpJGAf5gf4isueVRCbfLvL Idvy9QPf1/DmqSvoZsJUTUIizwXFtLAw27X/AFyP6+tWDZ2FoiILxvtAPOc8H39qa1vJALVgs0WS MHqCfQ+pqVdvmyXRRg7DYxbkDHpSJjSIJoXt4fJYtsu/l2gc/mPWqtlLawC4OJkeAA/vOgGe9XtM S43zYMkkb5xk8L+dI0MqiCOZ4g8rFRgZC/731oNXTuiBle6UyNG9rGeOTwMd+PX+tKy3ZE0sbeX5 C5Ukghu35Vdm2WCKjDe0x2KhOSx9venTok4SKG0mcyjBcNgDHt/nrQNU7Ijaa4kuo90bhGjCmMdx jqPr/WqsFhA73cYE1y8RzvHRh6D6f1FLZRs7mRWuHmh4Eec7j/8AX9PpVjUInaZRatNbSAAyE9FH +Of6UGMryWpGsaQ3C3SxyTJbdZScouO31HeoZLo3GoQSKnlBCWn8zAwnQZHpUkEcA+UwXMVpna29 v9aw4J9h/wDWqsFMaBHgkW5uCRnIJi9M49vSmOEbbGvdy2ll9miLSBpSSAh6/wCeaq3UEs1rcSRX Lh2Xt1T/AD+FWUtpJUWJymXGCMfMV/oc1XWL+z7aQXTzHeTtcDHlDPfPWpUbHc5uwptjsjnZJJ5k TazK+0YHQ4/z2ps1xGg+z78Mw3ZP3UHTmnzMkqrJHdBiybNnof6Goo7dJJRLcW1wphGQwPHsT7H/ AAoZzSlcS0t0+0hDcN9occ7zkOPT2qw8EJIWSZrVA2Njcs4HpVmVrWX7PNNHIvkN8pTjtioYja3l zBOsrDy5juVv48dqlu+iN4JFe7s47aCOaG4mihPERPr/AHSe5qnFdz/Z7uWSORZVyFZhlQR7Vfl+ e4jZc7Ecudwyo7dKspDCkUqRBjJKpk2EnLD2raNupnNGLayzx29tDdCZWu8lpnODg8446Vq20MFy hkDXCRrxuJ4OPSmxK9x+9MmZn+Taw+6B3x0qO5tpRNaXrTMrWhJEcTEK46YI9e9QyYKzs9Qjt0RJ ZWRUdMyeZ3x/h/8AXqPT5bfy7u7ninmuI0L7Ixu6ZPA9+adFG90shjZ5YXbkdec889hmp/JbTYXD XEbwTMeg+aQdcD1qk9LEP4kVbS8jmVriJJI0l4HP3j6fn/hVkIZpdjIWOemcYPoailZblCkYAt4V 3SAHacHsD2PvUo3Nps15MWgEZ2sW42joDmpZvuZq2tsu147u4kd5SpEbY39cr7dD+VaMnkMsMOJJ 7iBi0qoBuCk8VetI1SCM4yJBgA9R7j3qjfW8s8cCGKeyWF/mUHEjepz2z2ojJXCUXFA9uILYXgET pGfmA/l9alkIlD29ijSRTRh9wPK+uKovsmXyYFfltrNu+X8fbNa0caWfloAs0YHz842j1pVJE0pF awZ5Ue2uYXYXHydQDEB6n3ojeea7EkUQNo7GIoyjDEew/P6VozKrIy2sscRYZCuPvH/PP4VmaYs5 lubU28qyPy75+VB2J+v9RWSV9TWcloaVnFYtGbW4aS9WM4+WQruOf5deK0oLkWUjXTzLYxMCEJ4R T/eIHasmWKOCS3Q5aJnxIo4P511+lP5d1IznAnTZtkA29OPp7/SvHzXTDzb7Hs5ZC9WKXc/oh/4J H6TNZfDzX57iCeCZoo42WQ5Iwf5ZBwfQ1F+2YiRftU+FtX+0yRS6F4U1C5TczCN2SynYIQOpJCnP YfWus/4JS2ht/hh4jkedLuafyHeRRhckMcY/OvMv22dTKftK+J4GRpDpfw21W5RUk2vxYTDI9OWH 5V/nBmD582n/AIj+u8uVsLFLsfzF/CNtQPhm5jvLXU9sd7KYZpCojuEzjIA7j39q9IjucQXd0YPL LtshOSRgd/r71xvwnF0/hOOArGbua6l2qqkrDhsZH1AHArsLv7Q1wsMcEz26H/SGB4C+3oa/0A4F VsrpJdj+WOKKn+2TbZ9K/s+ahFp3gj9q7WLuaaO60j4azIz7s+SJr22RW/3cMePQGvlayW8tINPG oXBkuJcH7u3JPPC/0r6d+HMAtvgF+2BqEJtjb3nhmy0w+YCPOV76F2XI6LtR/wAZB6V8yjTnvUtZ LWOYWsC4AdixU9yTnnP516GV05fXKsnsc2bVV9UpRS1Ls9pDDaukUhurmZi8aJ6+g9TVeOa41H+z r21glkaAnchHLgcEe/NTtcbniU2c0ksZ2xsGzjAx+eKsXCfY7ezis42to7pm84bz09Qe2a+lPmWm EBtp4ItRuo1gbdjZI44OeAe1OjinikkiKBhMd/ycAZ9qoJZZaeMs0Mdx8vzEnYfXFWL4i2sxGiyS TSpsDbsEA9/8+tTJ2L5dLkZW1eZ01KGUfZiUQxtgSDqCPU/WmRyw2kSAwyxJEd24vnb35Pr/AI1K Imtohb3SSbrdRJvPJTPr/nvSy2VndNHHLHLOqEFgrlQSO9Whwta4wAnzNkiTrcEkAp/q/r/9aoZ3 n8tp4U5t1AZcZHoPzNTrPbwKJI33o52tsGQPp6U6KR9lxcwKflXB52hh6Z7H37VpyDjPWxWuLS4k ktppxLJcIBEu0bFYfTv9avyMEhMsNq7zSHZjjP1qSSeSWOSZQWaIcH0Has+4laOCBHLLLMcZUEBe P89KiS6FstyXHk7Y4Ywvnclv4enT3+lWLRvtqPeGDDZ24wCq46kisa2ntsIkMF1JNGcIjDlj7+3W pFa2uL8RRC7jRwUbY5VWPcY/D+VZuJiql9i9LZyrNO1uH81xuUO2Tk+mf84qna2KxxX6MWeYIGYg nDZ7fnV1cRW7RyzNKqMWC5+bHr9KklmjWWJBAyeYMEk9T6fX/Gkk0P2Se5VspJYormd1KyADbz1x 6CoUnaFgxtpYTdfNhjkP7D3/AMa3JI4LlI1LF2QgB1G1VwO49KpNbSNNcWjzrO0YBIHVFPT6H39q ezN5xsjGtp2G+SIyPZRk988nOcH61JDPG4mSSK4azRcvk/dU+v8AT0rUkhgW1e1SNltYgSxjOGY9 +fXNQSSq4mhW0mtwi5wwGX9v8PqKtPscrj0Y21ieWASvNClnjAES4IHt74qgdSiKi3QSMqPkKp4P +Nat1bWUNpHNBKYs4TLPlQR1yKjkjtlghmUIl2ZM7gOhx6UhbFKznhiMMsYmkedzz/cx3+mafHf6 hbyzLPMiqxzn/ZNMuLlIknYWzzzx4YhONoPGcf561pefHclURCFKDa+0Ee49yKGkVGRmeSsT+XKn 2mA/vPlPJ/E9Kvz7ZHZ/KnbgBgOPl7H2qzLcm0hhSaHdLO3lRMFyB9azm1CRbieCB1faoLOBlVHv +NZqLsXOXQ0rVbK52xQtKsudu1uQh/8Ar1QDNI8yiNwkhMTAdOOOvY1Ne2ImVJJGcXpX/VRnaQvY n1Jyf0qpHqSraySKoD4KsSchMf1qoIcIq5DAs0fnWV7cvAPvo6EjIzxnn0rVs2htb1AYnnLgDe3I zg8E/nU0Nq90Ip7tTDHAu8J3Of8AINQG3Uw3b7pPO2429DgHp14NO+tj0IRTVzNktruZ5hb3Co9u AXXHD/Qf41djgDTwq0skc6AM/dVHrjufb6VIskS7YoreRHdQfmPLfT1+lR2tuoS8vLVLp5UbcCzf 6z/dH+e1EjKUehHJaQQutvLA0syvlzEdrHPfr+XpUNzDHGkUYjkntoJNzHJ45/iP17HitezG6Lz7 sCGXeWUY5HuTUvmghvlcMSfmA4rAz9mYtzDJK1uBFLdWsTcqrbTHnvn0zx7cVY3pLCY2IE3ISQ8K h7ZqK2efbO85WK0hyfNP3W/xxxUUenecm2GeeSPcZGcHhSeuBW0VoRUm+hYDwCG1WaYoI3Yy579e MU91mkRnuUSSW5HlxiMYKKOn449Oah8hrNBJhJZID5hH8Mo7Ae/rmrTWayW7S3MkiRuM8vt2g+/b 61nykUo9xJYwIZxdq5t5osFVP3xSW9uYbeWCK1laFEzwc8H6/wAveo5kka5ls7NlW2lj8yaaV8Ar zwh7HOOfQ1NZXqTw/arVZA8QyUY/eHT8RRc6VHoYqwzs5ggiM/2fDMwxg5rTkCS2qJPBKjRkqrg4 GPwqzdTyPaQmztDDeCQkxqOGz3OO3HSq97BJPHGxmMdxu5P8JHpjvzWkZGdSkraC25iikadJsw7d gYHPz9TkemCKjNvaw2jpesPKuMkluAc9h71PbweWs1kT+9CnIzgr/gaqyrPOYCvlOu7+IZ49fzqF HXU5U+XQrXk6tJZTQgLaINjbOAgA6t6/rV8Wb2yRXcZ813OAv/PU+gB4zWVEt5pME7vBIkUjHaAQ d2O9aluk8lnDezzqohbK8EbSP8O9auKjsaU6jluWHhntLpRmMyvhgw6p6YqKSOXi7KSSiFyr56MR 2HoeahvJJ38w3LRsvRWAwPXB98UwOI0AjkeKK5XgSHc27vWMiZS6CpA86ziRligY/K2OKvWLxXN4 LKK3eOLyxHI4wCVHTnr1/Wi7SV47cB47N5Dt2sNysPUgdjVG8gunkgFm72U0L7XMgyHH09Kk6aYD z4pbu0zzaNlfl5X3Pr0H5Grwj8+RITc29rd+XvYMM7R2Pv8ATtVe8eWCS3t28tbuf5llcZDD0+oq UMkSQqFdri5m2lRx17+wp26Exo9RtzaPdZjhjNrFMo2ShcNIR1z3IFMjNq08Nqh2zRna4OPm9x6Z 60h1Bby4BhuVdUBjdUPCHkZHpRBHDFcQyXCOZ9xUNjaD9B61XIxIJ44GVrYFREkhZgw5b29v/wBd VJn2vaWemJcWy2uXkctndn/PFW57QNecLLleApbv3xVyMJE+2GP5kGWJ/p+PFJO2gSWtzDMlqzW+ n3cciW6Nwyt1J6+9aSK91E1pb7xEmUjm649fyqu0EMkqTtBvuM5ntyAQRnjjsDzWossGLu6kSaGa 0wUY8IeMZIHUAZ6+1ZyZapmPDayW8dul+fPZCd3l8Dr1PtirsECCcXTTA4J3LtwFx0/Hrn8KZqSv LDBdO7pg4IU4zTrW1M9pNCxkgeUEBm/h96IbGShaRDdXkqTrbwKvmyHdHIw498fSrMEE9w5+1MC0 5+dyMZx0H5U1QBavE4ZgnyqQeXHsfX3qa+IsrW0VZG2TMY1U9SfTJqi6j6GbJbgzQx2+F89isLj7 qkdScdvpTdTvNsy5SW2u8fKQccdj/P8AyKdfW0yWwkNtcuIWwyp1HufQU9Yn3QXG13uZxtYP8xXj j8PTFBwRUndIr26PFYRxPiOBcnGMYPfnvV624hjLK8L3+I0HTOO4FTpHC9t5rAy7GKsFONpHWq7W 9kt5aRyLN5qnO4sQEz0A9+v6UGsbxWpJcTBbd0lDSR/dZh1jx6/lUdqFt/JijMzRyHcSr/KoOeTn tmo2gljl+z5MpU/Ie3Pt3NWEhmtUSOFfNG/d5meF47+o9qUloOlO8iA2D2VzcGKaO4dx8vy++eR3 pmpRfb44DhxBbOHUJguzAdj9K2bZfNgkicLDPu+Vzzis3ZixmjMdx5MrMDnhhzyQfTNYHq81kSXR nt4rdbXdOc72YYyRjpWZFdldUnaWTzLZIQy7Sc9e3v8A/XrURPtSQ2s6SXAh5OxiuRWfJ5CSmaQi IRuDA/3QWHQfX+dbxpq2py1JsnMZ1d4VdbqCFGIlzwX9hjoelTG1jiTzbi4hmJcrAc8HHUH8P5Vn vuS6sZljngiuXPyH+I9/z7fhW01ptilSKDzHdvmyeMn+VYShZihruZ9xf2yTadHK6nnGVPzKOnPq KdqVxML5bRpktbKUBd5H3T61Zl0yytX3JBJd3cC7o2z90nt78U23FvqClnPlJa5Mpft7j8v507dj os7amZcwxrEkZhNuuM+bxgH39v8AGq1vbTW8sn2KRiiLtIc5bPfPoK1J1SXVJ5oL5U8qMALjIY/T v/8AWNWLZozOIpFWCaRiemPM9x7HrVylbRHP7DmlqZz6U0UN26BJr3GY0Tpnrhs96t28d1DbwSRR ia5hO44OAo9Pr71Yha4mkuXngmsIAu0u+OVHU/8A16dFIIROkjkRzrwz8D8PwrH2je51RpRWxUaC 6LkvbGck9QM4HuO9PkuVa3Tzbb7Fk+WHPIY+x+nNRrbX0tzEiXTR2sxCyNGxXzF64498VO9yiTHz AZFQldmBgAdz61ErGU49CKSH7PbubNEfjL553f5NNjiW52XTReWXGGDDlR0JHp9aWO4dpmTZKsQH UH7h7Z/z3FVoYry5nkgnWSCGJskD5SR6fyxVw2M1GxLpltPZ7zBerdRGUlfMTOfb/P8AWpLjVGkM kNvYXFzcwH95sYYYf0A/wqvDdSpPJZPEyFjiIgY49SO4/rWhAsNvG8HnQbrmTDHb6c4+v8+aiaKc u4riLzI1wrM3CxpwWNUoomadGyZJJXKkrwqj6evanXEMcU5WFZ3uJsM2W+6Mc5HpnpirUbyASea8 bygZjiA2t7ZrOK0N6VREk0eyeMOWSXdh0UcsB2+v171UEFraTzQyJIrj95u3ev8AhV2ArH5c4eRW uOTI38hVUWrWEs91l795mLDJOV+mfXpxVI3lLoC+fujjRASnzq7jKr9Rnke1F1aWwaO4gFxiRiGZ myuB1wP0qo0737wmFZnVCS4VeUA603z7x4pI4IQ8qyE9PujsCM/15p8pyz3EljRnhtpFeWOU5BHV hVt5I47a5ZC7paJuZX5Eg9B7/XtToJY40uGeYS3Cp2HA/Pioo5ILSMLOWuBdEfLyCR9akVypELfU InvbBbuOcR4KyH5WPtS27yfJbONi2rb2287/AKf/AF61poobdGvUaO0lkUY3DK47cetZEbNZuIJH e+lPMoRfmCk8Uou5qtFqWXXfKsgt2QXR8uNX6t9KbaRW0jCKBJQ7MQ2TuLE/yFWdRsZ7jUoFlB+y W6h0+bb5pPt6dOtQXltPFDHJKZXaIlkEHyNJz0/AUcyHutCSS0CwTvCWCEEEhiSv0PrWKkl3cXTR qRPDajftU4MpPUf/AK+K1YdPdxHdLPN87Eyqp+6D2A6CqrQJtmijV2eElj5RwWx/nmjmRw16M272 IXvLaxns5NStroWME6STZcYkXPT6c9+B+Ffyk/tQXGn/APDRXxyu7KMW0MviC4jgGdwdFkKgj6gA 596/q3vY7oTaYHtrl/tLKJpokV1gjJG4kNxkLk5PGa/kg+PGpW+sfGL4rMFl8mTxLekKww6jz3C5 /D+Vfj/ilUXsYpdbn6n4axlGVTmPKNSZ0jjuEZ5Gkwo77aTEwt5N8bK7AbYz1JpGtopXtxFLKYYW 5YHAH/16ZdOEZoEfzYT/AA9xnvmvwKx+uWEa+vpbZYWjKCEbE5Bx71GVmtmhjYApIPm/2qkgtmZI 3hkGVJUB/wCH6+tLMr+bG1tIk0oGGGMis5ruachWcLPKyqZkDDn8Kn8m3jt1UfK8JyxByafhIhb7 5iJGY54yB9aS4aGIyG3iDyqQWfOVP1rJOxm0Q3PyvDJH+5Lc8ckH1retMLLAr3EUCoQ7eYu5Vx3K 9x7VyNv9qW4jecKgzj3HvXSaDF52okOQTIxVCf4Semf89xXNjI3pS9GdOC/jQ9Ufqj+02gT9mvw2 80MyX2oxx2kpRhtDGPdtIP8AHlTn0zj0FfkxcRXsEqQJGVEeAPVq/fHX/h1onxy8G+GRrNxiz0q0 jSb52iSVwoDEhemO5IOcGvlvxV+xHaXU32/w3qU6yJlfJ8vcswHTaxYbT74/wr8O4P4wwmBqVaOJ dm2f01x5wLjMzwtGvh2tFsfmP5F1NGsuUSVQBtxjge3+e9ULyMrEiywviNjk5xnNfYPiP9j/AOL+ iy3c+gaLL4k06CNpbhotqtAo/vAtnHOM4xXzv4s+HfjTw8lzdeIfD+paLBa4VxcLtwPU+361+u4D ijL67XsqqfzPwzG8EZphk3Uou3pc4e48hFgjIZIRggZyWz2p0lmr3DLJI7RbQTznaKtSaMkcqRXU 6maBRIQp+4MZyR1HFWfs05x+6jcocL2Jz619D7SL2dz5qth5xV5Jooy2ltblRbMYpX53nn8qS2QW 0BwXd0f72M4zV3UIvMtQsabLi2zz3JH8P+fWqymeOJPus7cPx9z3NYSZh7M0p7q3e2t4MtvhJyQP 85NUNQR7iKEAXEAjPAPf8ateU0fku6iXDZBHBFOku1WO4DRyXDSELHtOFU+9dFMiUehl9S/nhnUr hcDn/wDVUaxeRNGYUklOQfmNTWrpbTNJd4miX5MNzg1JIiBi0CyRtnIyc4rWVugki5DKZUK5WKQk hQw+9VeRpTIPMBa3PBwefxNRoGt4kZ4ZJ3kYncW/T2q1amSVM4IVTnkd/wDCsJS6GlMu21vEWXJ3 bvuyH+I+n4V7N4F0yRZvNkmSRSN24DG3t+Pp9a8beZGWFJ1fzC2cRjBYewr3bw8LqCxNxbwkpcER iNRknv1/KvBzuXLRdj7DhGmp4yKkj9Pv+CfPhdtT+L1743ijnnXwpapBFgjZ5kvmLuYdMBVkxnuF 9K/Uv49eIE+Hfwj8aa7E3kyXFq8dsQPnEjqQpQjqwPzc4HynvXiP7APgE+H/AIJ/2xcQ2sdz45vm kkMeMyG3ZlRc9sAktjruwa6T9ozWT4l8c/s//CC1uZIL7xJ4lN7qES8KsEUOYmzjo29vXlRx6/zB xNX9rjGux/s/4J5Qsv4epxTu5L/gHmn7YuvT/CL9h3wp+zt4Pv7eM/EG3t4b2zsh5jM4jE772IwG k/dsQvIPXtTVay+C3wG1K08H6bpXh2Sx0v7ElrGNqSSMoVSWP8RkbdnsK8h/aWey8RftafCT4XWm ryatp3w/SPWb5kBVLhpVCSkrgYUMiDBHGB6mvXfi14bsfGl78NvhFHrl1bHxVqLS6zc20O1IbeGJ jsXI4YsuM+oXvXmzlZI+3hlMIxqSp/E07f163+8+A/jzrXxH8BaN4P8Agl4p+LfgOfwzCj3N/pGi SyK1nuKyKkztiQsSxbac9CRgV9ZfA/8Aa/8AFmu+BtD+B+qXnhzQPgL4ddb6+1SKxWOTbG24RyTD LSKpVDtA7DdkCvFf2utH1H4p/Hn4UfAvwF4GttW8R6XaxJc3Zg3sYJycNPLgM7BUUjJ+6VA6En0B /wBk7SfAOkeK/Dg1/U9T07S0eVWlZoxJKQvyBdpyM5XGBnjPv9Es4wUMKqVSGrPw7KfDLPK2a3qz uoO6/T/I9A+HX7WN58Zfjf4y8F/Cq6mT4P8AhSzjWW4+wmGTUXBKtJnqFL8YHXjOTmuh8L6n4W+J P7Rz+HvG2l6z4s8AfA2NZ74wTPELi6lG2OP7QvzKE/ebiAclAOTivGPhr4Utv2bfgr4g8YalJGvi TVJpZFhZfLaTBzEAckE4HTIHAHQYrtfC19pPwp/ZytvBNvr+nr8a/wBofV/tes3LqZ5dPQFpwrDa MFgUAIYA7e205VWFPl9rShdH6liKVWtD+z8wqe89HbTT8D//1Pzh+EWm6lH498Z6udKtGj1J0YiJ gwdl4xz3IOc9j9RXvGptdRXkbZW7bfhBGuTGevTvjgYr4o03xNrHwM8fTWfivXLey8IX04EV1eOV MU5UFVLHgKe44z169fsS+1HWNftbOf4Xw2t5dPLufUbhS9tbcA5bp/eHHoRX9+vinB0L1ZyVj+bc w4UxdeoqNNXZwPin44+G/h9qRsp7+3h8aWMf2qxtw4kMjEfIdg5AB5OccZ7ivmX4Cv4o8YfEPxX4 58ezw3t3APIUsQHi3yA7kVeEG3cB3IZhXp3xX8K/DXTNc13V/GV/Nq/i++VI57rTMqOMA4yMKFG4 456jg5ryrUNc8P6abbxB8HdJ1DSPDNvOgvX1GZpVuXwA2/J+VTjIA7nOO1fmuc+IFHE1n9XptpdT 9LybgV4PDKNSorv7jr/HniLUNK+NOpOmqi3l0/To7WOSIbCxBb5WPXCg4PGflr1nQPGVpefDnUPE ur+OYr/WdDkdYC6pEtq24bWVQBuPIHJOdvvXw1428O3Hi7x/q9lB4mfSrzTrSOWMxEgTMcEAnuMv +nvX1f4F0Hw7pFnGfiKtjPLZWZVtPKgGRuhYrzkn5uPfrxX5/wAT8RYythpOg2kt0fbZZkeGw00q iTk9mfGPxH+OviT49+Jbbwd4m8Q6TpumXt3mG4htj5MgHAYqCOMKCOgOMADPP2V4c8J/HT4d6NfW On+LLJ4fCdozXMVvbBmvIzkZVf7wXvyelfIHjDwD8JNM+KKavaWl3a6RduGms3uDMYAc4Cgc5BPT PoPUV+n3gNNGuvC2h6foWrT39pPcM0Uok/fzK4HJb1yTzzjpXVwNgqWY0nGbtI8fizMKmAtOmvdP y81f9nfSfHWveH9ZsfinY6hrnieRttolzKb2B1+Zd0h5Vuevt1GKf8WvgN488H+GJrrTPE+o+Jb2 WNkNtJA88pwMs5YE5H3hnGckDJzX1d8ZfgLZ6X8VND8f+DpP7LuEmF89gJfKCzqMM59iWJYADkZH of0M1nUfCHwZ+HcXxP8AE8dtca/rtiqaXbXESyLF5gDF9rfxcdefu8YzXp5tU/s6MqFSblN7HJDG vGqFWjFRj17n8tPguSe/+Ifh17rT5xc2d+AqyAr58iE4U455I6ele1a5d6dafEi20jxlYy6Ro91I JZIY9uWTBJK9s4B7dawviSt1oHxe1jXp/D15oumX94+s2Ssu0MskjNuUem7IHbivXvB3iqO+1n/h M/FXwx1Lx6lhH5sJhRxEuPVgDyMYPtkcV+d4fLMTiMUtND6+njaMaDcdWe6+K/HUeofCyDGnN4Y8 EI8jaVdQLslZgBlt45ORgDJGd3arX7L+ieINNj1W6s/h3favcaxNGkl7LcC3RIiSGJU/6wZIHGeC xGe+b8a/iPqvjPwr4U0O1+Hmr6To3hS4d5dNMBa4aM7eHXuuUBGAMgjjFdh4V+NHxo8Uaa2k+Avh u/hOx0qRY4r28sTGuc9JA4Xt83GAT0x0r9M4TyanPE81/hPleK8xqUcG/d+JH6ARxXtrbQWKQpYt dYXcirFCoPTOMegH4V8q65rnwr0b4+XWo+M/G2m6RrOi2EQto7oPJGSCSrAqCA3Yc55IA5zWHD8L firdnxV4n+IvxJuIbFYlmS3sBshVQDuxtCkHOMdewOatfCL4XaLqnhe78a/Erwbp9zqSXL3kUk8n mSSBuEZAp2j5OSMYPPUV+wYrGK6pI/JsowHIpV5Pc93s/jL8LruxvJj4pmhu7dCQ7xu0d2/PypkD J45BORzmvjd/2o/D2j+Jr66ntNR8ReIhKIdNlBRRZbm4K5JzIBkDHbIByc15V8cYfFniH4j6V4W8 H6BHpmjyZjs1QJAWG0Eyuo6Kc8Ejnco7V6N4M/Zss/BuqaPca1Z6nqPxKVFvIo/NPk2wyGDMD3GQ euABjqTXjZhnlZv2MHofS4Hh3DqKxMtz6k0O9+KniebSfEvxC8RWvg/wlMyrZaTZxKJdRiA+VnJy yg5JyT17cc9t4X8AaPGNTn1Lw/Y6gdWnM/mXcfmug52sd2ceuAM89K63wnoV9JD5etXDavrCwr/p RjVVhb0VeiqOFA7AV3V0yQw/ZJHVJYV3O2OR7n2r1OHeG6qqe1xSvc+V4n4gpOPJhNLde5wum+GL Wzhk3ackNpbnKmM7DL6hsH5h0xniuovXkMEH22GGyh0xd0YKAbePT1xirw2pKksVwxeIbpgeAg7f 5+lNu2gv0tzHcLvyQzdQR2/rX6PSw8I/DGx+ZzrzlpKTZDKFeyMn2aczSrwM4x3H5/1FRG3kvopb eKQQxxDLM2RjNSPJkQW8qSBVICuDge2fWpp47oTm0LIjSckKOvoPrXdDTQzm2lZGbp7LbQKbq1kS 68wgyDARQPX3q4tjE0WpTiCVHmUYOeOP8/qKVYzcZh8p3uY/lYgYBHbj1rXii8qErezQvdwkbbde Cf8AE0VZaWMqUG3oVoUW2jjjuGU26/MflyU46n1FYK2Nlck2Ult8rsX+bOwA+o6gf41rzTWM3mNC 0jvkiWEtyuOn65qy0NrdRqvlyCVwFyD/ACxXPyq+p1RqOMbFaWK3kS3t7eSO1ZD8ojTYh46YHBqI 2qqbqZwz+QvzTIcKV9PY+9H2AWjtbrKGW1TzjK8oVdhOOrehyP6VR1fxX4P8NeWuveMPDWkLOuQ8 12mW9QEBLEj6fjTq4iEF7zJp4edTWKM7V/EEMfiTw5p95bGDT0XzIzswJGAJxk9yBxn8ffp49Rt2 8xr2MeUxLQ4GMfj9M18+eJPi3pMviLSdW8H2Nt430mytTa3EsZ3RyuTwF4xna2Dkc7sdRg+w6b4g 1zVXuNM1fwzLpm9UuI7nMYiUsM7MA5DdB2A/GvBweZwnW5Nj6DHZVUhSU9zcisXZ47x0mYSDdgnA A7HFWPtEkwunKyKtpGFABxuHTH19+PrUNneSW0Es09wBdljCYC2SCB0x24/lVomG4hDTH7P9vAhY A8IR/F9DzX0i7HjRvYrQ+ROCYZBG8PPlycmMnuT3B9PY1Bc+e8ysVe0CEDJ+6w+nrW89k+nwbAEe VORt/wCWw9Pb61El1bQPI1+pXeB9QP6ValbY5pq5NHGiys7To0IAIbpsOO56AVClrc6nElwQd1ux JQHG8dBz2PSmzwWrS2yxefJBIS3Xgn0qK2u7izlvI4nJgf5B/h9fepe1zOWjsFnI08stm/mA25wO cb/b+tQXN/NeSRxRxjY48tYU4Jxx1rSdPs1ohlMaq7EkgZbH1/z3qVHtg6ywtElzjIQr8zH2P9PY 0oFqncoNDLpCx2slxslZfMErnKqD/PFVrGfKtNFMsn2Zw06KvY9D9M1f1KxS7lEyyMi4+ZhyGH/6 6VrVVZJtPQLbouOMfNjrn8a15tBVaepXvIjBI43xwHPmfMeufQ9qLW0k+2QziGeSRTvBJ4YemO// ANcUy/kzGPtL7TMMLuHP1X/GiJFYC9jka2LrsjlYkqpHXK9xz096qOq1OeSsyaIvcXqLDbyXkin9 5jpjtnPvx78VbkTZHN9lhbc3905x7j05p1tzM7wwSxWN18kmW5k4+bBHTn+dRvKbVZPIRkEY3DOC AD3NY9bHRTj7nMZy2zxWgmFzeX88kuXgi42jsPr79zirOuS2MWjLdXsEu7w1IL1YzjKhiEbPuQR3 5C49aXyJwLiax3NDAu6Qqe/+eab/AMI4Nftb7R724vLaXXIjEkiAErnoee49+Olefm+EVWi+bpqe nkWLdDEJrrodPY6T/bej+LLeMrcXkdoDYzxkMBIGBIHPBAzn64rFnt7Nrg3cchLTKq7Wk3qrAY/E 9jj0pPhxHIllp+lzvc7xK1lujmBdmGcMcjqcryQfQZHNR3tslhdzacqZv7V3QgkruO49u3IIzXzu UVUq/LF6M+v4gwrWD5pLVMqvbOIpk1G0mniVSGhV8ecp7E+/6cVy9jJcaDImlW29dFu2NxBJGoQr IxGY25HGc4Izkjnk5PWy3fkWN9dXdlePbWUYeXOTtzxxjr16e/tUUtol1HO0MyRv5YB3crGD0LDu DnpXuYyhzrTc+ZyurKmlfZnceIUktrnwVplvrFtLPLcTXcsbxlcusWNgPvuII6YHPWt280j/AISP UdPhS3mku5IBHFErYNwM9FYEcgnpzwe2K8q1eTVNB0zwfrOv6dqOo6Fa6g1nayQr8sTyqFKs38Ry F5JycAdjWprc99P4a8D3toZYpE1q5trmOR8sqFckjn7wKkYOMbx0xX8+ZpTq+3lVpStNM/fcCqcq Uac1eDRR+L3w1vo47fWtGt4bPxZ4ZZZbffGEJPdCT0yvGfT1FYOgatpHi/wDqvjNLPVrLUPDY861 jR1intnVwksUi+ilh0wCOa9H8bax4hsfDmkalpdzJryaNKkz20pDC5CkB0ZidwG3rgkjb07HiPDV 54R0T4kavY6xpdz4K8A/E+1329+wElot4xIbkD5Sxx1GCeMgivReeVZ0vZ4qGq6o5I5HThNSw09O xPBb38+j2wu1Duw/fGMGMcjqOcj1xngEVZiUwJDLJMLVLWUeZjsv+Bqj4c1Kzt5L7wINSfxD4k8F qH1GORCjvvZtpIPCgkYx2wOxBr0h9J0Fbqz1qxF8lw5RJbd3BEWOrZPAGc4644r9ByTHRWF8mj89 z7L5yxXM/iTPH9f0fwX8Lfid4vsV06Sy8GeNPI1X9yuDZTOmA5wOEb5h16nPNdhd6yzxaffX2p2s 3gjY0UBw29nyBjqAOOhIOT6Yrg/HNjqGnfGbVZNWvJ73QPEOiJc2EOMsJFYrtOeAir0HfIrF8b+C NT1PRpP+EZkW2hIE8lo8LSKHUcupzlSy7gRjHOccYP51g8vxk4ynSd4pn6JUzLBU5Qp1tJPYb4C+ IfnXGu+FtX0jUtPutJ+WzW4fDmPOAC5OG4I+bIIyM+p7LVtGtU8SaT4jsXlurvUdOMJZJNr4yyBW yexI/D6186Q6TLrmkwWlv4hvru8E7x6fcqRFf6fJ0jjk4AbBOATw4IBAr1/wfP4p8V+HvCS+N9Hn sfFWgXM1tqn2iTylu1iP7t9qn5AwUZXPf0NevhuIeSEaVbdGdXhZTrTr078rR6j5HkRC2vhb/aLj 91KGXgjtj3/P6V554w8KHw3qEGkaDc6ha3uvzyyaikj+ZAAx3qyDHBJzx/PiupXxfYxajq3hSaRt VvLWAyQvaRZZGPzbTkryq8k9cYPcVseKdV0e51Lw54tt7yBrS+sUs/s11lGknQncCATyc4yPwr5X xWzHD4ilSnB6pnpeHuX1sNOcOW0Wed6PremR/EzQ9C0+9u7S1nsmuNVgij22aRO2zDIflOHweD/C OmSK9K1SPxT4QTWLq1TSPEbWNuRDDcuYVbIwAoHUn5F5PAbPavAfhfpnh/wx4k8ZxX88Ft40u5lv zcJGQLq3YsCuMkZWUtkDpuXvXu/xJ1mOLwP9ruZYpIZLeZbiGQ7XlCKNpDdhuZQSaxyzDT+o/XoO 2hvjcXBY36nNXPlT4Ua5cJqN94e8Vwjwz/ZN1Lqemzurtv8AtLgKCx7jBB9TIeOOftbx5b6TqPwA 0w22qWV7qXhrXXurmOGLdIYXjwWXuDuH6Yr5U+FerG81jxRHqlnqtxfOsfmssYWOSJRuijY8fPhi xx6r6Zr6zt49H0z4WfFa5M2maB4oFpAdCvJIx/o9wJM/vMdVwzEg8VOIoYn+xXXWydzPE1sNHOFS jo2jjfGOkfZtU8EatqGj74tZt/IWaP5RMkToD8wI42yDpxzj1pLnRJ9Zt10e3g+zTbx/x7IFlhUH KluRkdB788YNQXWseOPEnhn4b694muNN1nyYZrUGCFbYAuoIkXYOQWVSOeQPYYpWum6mrA3Wq3un 31kwPmQkox6EDjkH6/Svq/CzFQxOGnzL3j5fj+E6VWFn7ozWvEGuR6CYNagfTPF2j6nHHfRi32rc xgbVMQzlVJBzngAd66GC9guN1wJB5jyYzGAPLOeoGcdsdea8u+Nl34WPwx1ddWl1WTXtQie3sbm3 ZlZJFZSQ0mcLkjAJOM4Fdt8IHD+FNKs9Rub3UZWt0aSO5ciW3m24dd55IyM/iSK+hhUlgsRUhUV7 nk+yWMowlSdrHiOpve/DXUfCPw7t7bV5JhczX9jJO3mb2lzvVcncuPLI4z93pXvHgnxn4Vk8TeHt RgvU05jd5S3u5FDO3KkKpOXH0H9K8B/aCtPEPii70rWfCME09z4V1GKa3RZCvnGOPJQv1UZ3dcZx x1r1vSvB0/irTLXwv4dtnsG12dLzRpnCyTQyPyQGORwSAeo/Kvy/LuIIYbEV1D3VK5+h5hkc8RQp c65nEwfjr4e1STx/8WtQ8AtpcOoeFNXNxpt1LO7vBNGcyDGOhAxwedx4NeA/BHQ/7S8Z/EP4264s 0GqeLGitoxLbiJtQZSd7xkYHL4Ucc5OOor6s8G6Z4v8ADem+JNR8YabqKu+vTxxPPH++ZiQCsp/2 tpIP+0OteFfDXwlr2j/EfxfoPkaz4gtrW9a7junJWO3Mg3LFEvUt0DDoNq8ckn0cr9jSxEI06mrO LMalarh6jqQ0SPXPD2iXtrLc6rqple81aVTHgqfscaj5UbBJJy3UYGcgDvXa3MccCWd5BDNNFE+2 cAjGPX+ldF/wgXiTSEX+0LGazn3BpBOQpgDdAwz7jjPeujg0rQPOa01DUobZ1j3mE7skHjPA6f4V /QFHO8FhqaXPf0PweeS43ESacLepylpJeafFJrNpaR6lOq7/ACoowSQOQAD1PGMeuK+d/hfpmteB dE8YeGNWiil1uz165ngtgxaS4gkPmKd3ICjdt9iG619K6zfahpWkzDRHsPDFtG4Ed1cETNcFmC7V XOS25sD0PPQV85fBfUtW1zxR8Rry8tNDn0mCX+zp7lp280BOfLCnknkEHgDefTNfj/ifxBDE01Cl HTufr3hrkdTBN1pS17dDuPCVno8PhuyuPD9mQk5Z4LVFVXyD824j+EHgH2PrXWeOfB+l/EPQ9Rhs jriXnjKxVIHEhaOGeJNpaMHjOR0GQOPc1xPhfR/EGjWdxBp1laaBpt1A8X2ORxJcLESSdzDPJxnO DknOfX1228WwaHpGgaFNp02p2MExSOZdubXPBfk5zjAIz7jNfk9OpiqVFVK0bJbH6JiKlKvWlGLv fc+fPhH411TV/AerJr+mXV3eeB5Bp118+JVCRDeCw6tuyN47n8tO48OWnxc1bU/C+paPBBomkWif aRcyeZGgnLMr54+banTnoOea5v4i6ro8UPiXwN8DfAutatf+KtXLXt/Bc+XEJSVLxtyuCNmTggEA 561LpreIfiB408Wa+dYgtbpzZ6PFplqvlI0yIRJnpwSUJHPSvrJ8ZVcXSpwcbcp81g+EaWFqznGX xfefK/ijxH40+Glx4g+0DXNS8By4h0rVAiytNGQRHDK7BvkAzt7jgZ71+lXwL8U6P8fPAviLxF4h sba1huPC8yXskLGHyGgiEcahM4BcrGy4A4cetZPxE8F+HdX8Dt8N/tenWnha5iSTU9WVMx785Cxn qNpCk45J7V+Uvgr43eOfhfbXXwxtvExi0nxf4gOjJf2sa5tZVYKJGzhtu1YztyRj3Ar4vM8PKrUc +W59Th6ipQVOLtY/SH4WyaroeiQf8J14a1TT5ZCDp5imVorjsNvzfKuOen8PTNe66zqH9j+H73RZ 75LDUfHcawyswVEtIg4ZArnBEjFfXt0Hf558RfGfwb8Ntd1jQvHOqoNa0q3ha1hnDMz9QqbhkEkd FByMVyOnz+M/EPgD/hJfEug6x4Us7l5JPDdrqjD7Zqs7Px+7AykQzjPU47V9PTz6pGhChUk3bojx 4ZFSdWVenGze7Z9gadFo3hbQrTxRrEjeIWhV4dO06J9sl3IgADOxPCKGGSRzUniK6vpfCPwx1jUg 0+rW82oNdRxruSQNswFXtsBK+vGa8d8O6dqOlWMaeIb+4vdZg+86BVtos88YxuIXCkdsD0zXt3xS j1aHTfhV4ZgjXT7GTT5ryScpuZFaSNc5PJLKmBz/AHjX1OcYLGVKdKvU3k1ZHg5PmWFpVKtCir23 f9fM8x0y1Nq99IoKRybZUUsG+8N2R6E5rY0zYLu7mmuHhRUDKX4GPf8AXmmvYRJ88DTGPb5SsWyy qOmT3PoatanYqu20Zd8Tr+/DdZcjgAn7o/8A1V+8UcUqOFjHrY/Eq2BeIxs5P4bnAppUniH4t/CG 30C4mki1/V2spY7Zcp5JXceCcbmYZH+6ezGqn7SVpc+L/FFtcabqR8nS/EVvpkkkaf663t2WI8Ho pZcjHOSM8Cuj13xF4X8NeNfBN3Fd3MP/AAgm+QvFOwbzpYCsQyAeU6gfhxXn+vfZpdf8NeEbG5nu n0K2k1jUJzcFXhWT7hbJOTvPBz1zX868RZ9TxWcww7Wz/I/fshyaphsrlVT0seqeX9oQxW6LZfa5 mdY5gCQc+o6DjtV64VX8qO5gR2sPnYyjKkY/Q9MdR278W54b+xSz+wwRf2m0SmXzFBEasOhHrgj3 5qs8dlNORO9x5WMyqHwygdT6+35V/QmCVLE0HRtokfg+bOrhqvtk9W2Q6m8NuLZrhZbOYjO5V4bP T9On/wCqvNviJc3Tv8NtQOnuY9E1ciRhF91JAsZY89VUnOeu72r3rw7baDq5/sq91W38OyXwaPSr i6/1M0wI2xluxOcgZHI4744b4ueGL+PwZqehXiaql75yqI4flMrqdykHsoIzn+LNfHY7OqeFg8Ji Zap6H0uGyyWJqLFYRaNa+pPap/advO5txPbXR8tXBBSZT/d56Y7cYyK848dy31x8WPh7HZabfXmj +DGQyxi6VAZCm35mJ+Ybps47BDXT6RrFxL4f0yRLV9Lu7S3R5oGwRAfu4bBx2yee4+tT+O7H+2PG GkXOlapaeGtJ8Hp51+jws8+qzyRrFsTnGE+Tr1/OvE45zPmpUKt/dZ9DwHQl9Yr0pLVIv63Osz+F ruOHVDFqUkpcJIS0QRQQH59Dj0z6V0EWt6ToGnQHU9QtNI/ti4FvbtcSBRcEnIAPrwOpHoKxtUvL K/1jSEtJL2D/AIQu2kWaHG1b15SOcH+EBG4PIIB4zVLxF4d+H/iIeEb3xVO6anY6p5+n2XnugnJU g9PqB+P4H08J7+FlJ7OxzYt3xUY9rlhbpL6a81OWGDTXvHMKtkHEa9Dn1JBJ6d61pbbTY/D2s6VN duZfESC1jtwf32N26R0z04HtWfp9ppNnLBpFo6i3jJfyy5coCSTySc85+mKuJplzquuvNYlYtR8I 2TKVcZX5txXJwSN6sv5DpX0uLn7LARjJ2bPEwVP22Olyq9jomSHRdPt9FtjKWeFFZXY8IoG3+VVd LlgkbV47pJbpre0kXy9ueGUqDz3H3h9OKyNNvNUvbCC61RYP7a1FASuwDy/RCBwDj04q7d+IbXwp omuX93YXerRNEkaeSwzbkuNzNnqAPyweucVzYPA/7O59WYZhjH9cjTWy6GHZQXS2Gm2lpIl69tGq SyqQTK+ACCfr27celSpqbs9vZOyJJASwdhnP09D6+tWLS3SOGe8s4JE+1fvHBP3Sfbp1qvqESQyi MYdXAafHBwfQ9q/QcohbDwi+x8Pm9bmxEnaxdlk+3wW8RM0SQylixPJPtSi1S2IgjkWON/mdnbGw epPpTLnZHdQ3CQXAgjQMcN/rfYDt9fcVLLOkhmRHjVnzjeM7c+vqP8K9GeiseXJoY3nw3u6dftMe RyMHcvYgnrmoJbu+jhuDFZvcbHxvwSF9Afp3+oq95KXESW6yNI1gvmOV4DD+7ULygbLaKSUB1BIz nrz+P/6qyjPWxhKXQrxRFDHAba62XnLNnhfYD1/+tTLmQs06uuLbACKDgEipJLczRRyLPcRkMduW 5q/ve4clY4fPtUBIA+/7/jXQFtDMjiaKPEZMsUgK5zjb+NWIobcXC2v21ERk6Nkkk9fwqpcIVurf c2Y3+Yovb/CtiSGBJIhcKrxxncSPlMXGc0yYuxlxxWQury3gS53QoGdic/kPWpZYppLBo/M8x7Yf xdWHYE9q2vKiWZJIovvrlz0yO34VQaDO3ZDLuuG2kk/Lkdv8+1ESWUjaTQKi2sM5mdfmJOQv09P/ AK4q9FJNp9i4gVpWb5mHBz9Pcd6hcXElipt7jLwyltjdOOPy9celWHto7tPn81dg3yBWwV9/pVOQ RiuhnztDeRh4zL9tjIAcn92p9CBzjFX9RglleC6ieVTFgKUHK47/AP6uc1FNZeYkMVvIrwkbjIvA cEVNZJeq7C9R5LfG1HQ4wOxNYVdjWnCz1POFspvDeqtbSwyxaLq8n7pCdhhlPBZscYII9+h65reu fEA0XVtBjkjW7EE63MO048wrwQR3GD9K7ySG31yOaE232u1gBDICAzk8EDP9a8MvI5NPi1bR9SMh vtLJmtRK2Wniydu1gBkAFR6jjrXzk8Z7Xmo1FY+hlQlh4wxFJ3PaPirZxXNppD+GX+26Rrl5kxyS GOWHahMmOBkdBjAHOfSqdoyK7y288lw6rgMByADjB9SOlea6bqN/qcvh6a4lmE3htXfIG4fOAFzn P93jr3r1RNU0m71HUdKuC1trfli7n2nCyK3O+Mdcc8qOV+lfE5bm0cFiJ0az06H3WLy+ePw8K9Ba rcx9TdY9V03Ui0yabNbi0mRZ9i7i5Kt6ZJOCT0wvrWh47u92meGNKlguIoPELsnmrFlZYlPzhs9e APxHvV6609NTtbKOFf3ULi4glYD5XI49cHPf6V5rfahOvi+/1PZqN7pfhHRg+xWJiErnPyr1JOwZ 9CB7ivOzzGUnUjTvZNnrcP4aooyqRWqVv6+46PU9J0rXdCg0i/uY52LBZoBJnhRhFz75GR7CsfTJ X8J21rpmqzXN3pjSJEbuKAhInY8I4yRGoxwTkHgE1i+AG1qGK3vL+4a41fV7x5ZXmO5oNxzHGo6D A+Xjvk45rsdV0mG9k1W1NzMIdQRUnAOc+ox6deK+oyLDzqVPa30Wx8zxHmdHDUvYS3Zg+M4LW40b /Tp1gtNSvo7aWQDcApYLhQehYEj6lelbjvcaVZhYII59DtQRIm795GVGNykZ9MEfj258y8Z2i6l4 Rn8La091HqOkSpcW1wC6x3io+6M7sZOSnPce+c11d7Je6lc2WkWV3Ft1G0F1JGpwFHUsvOSeVBGM D1r6L3ZVd9T4/mkqaVh2jX1ldvbX94sthfalN5EPm8hlH3TuHQHn8SKd4lsUNxpmuxC6S60+cIks TBWgY8BgTwce/r7muvttNiktknJSJ7QglOwA4Bx3965vxJpyazpt3awXN9prSKRBKhB/ejBxzxjj +VdkqdlY5JVdbtl1teurO21i61hCZrO1aaGOIbfMcggbQByDwduODnsBXN3niW6s9Ls7yOF7dnvf JiiVGkeSNU4cjoq7lPzHruA561yPjHxZqc/w2vtY0u2jl8ZeErcX9vYxnY+ogY3BDycZCgryf1rI +Emja81tJqeseH30i716V7+e2F3562QduOcAY65A75681+aY7EYiWapR+GJ+t8P4XCvKajk7Skd3 oM/jXxSJFkvotJtFUzQrNANxJPTcp4AGe5HHStnQ9C1zRFuFOrT3rbTu85T5qKQMYJJ5yOOlXJdH 0ZpLiyljutX07UCEkhj3Hyc9RkHrx26dK6G40200dozZxTw2tko3vOxKoDxyT1GeMc4yK+9jUfQ/ Po4aN2pBHbPcJbHzgbmJA0oC43Z7jt61qwT2T7LYbWNqd2FI5z/U1iNYpcztnzXDD95sJw4/oK1I rCKKIfZ4JoEL9WOWk+h/z1r3aU58tmeNVp0VL3NRDM26+kWFo2t03ssh+8PQeh96ZJH5mmHUJbeQ SzDbycGMD/P6ip2t1kZvs4lSWIEsX5UE9j71btGdoDZ26s0luMknkyD2H8q9CDdjzKsLysV5bQLC u5pNygfKTyc+nvVKOGO2trxI1kNuo3lS+S2e2a2BNaMjmRhNM/ylQeT7D0IqrcxwLJHKD9nt5mEW HyRkD9BVQ3OarDlWhTFpcy26tp6AXCfMFP8AH7D3qwoSxvFa8hX7RL8gRyDgkZ4qnLHdRFrm3eUJ YtukCH5lX19COehrXtDbi++1XQfdKuU8znJrc54q7M+W3eOCRkZ2hYnHGWQjqaS8Pkva27PI7dW5 zkEcVYWZ7d0Kyj9+x3Iw7fTt/wDWq1KNIdSnkzys/G9X+63oPesDtvZFSezeXTpJEHk/KVVgOW9/ 8KI7SeG3gug8DSAAbcfeP8v8mr0vkQQvFEZGMqYAcnCj1/nUSQSwLZxSybhK5IB4JU+lJ+YpUru4 9I4JWjW1dmkushiDnOOuKsSR2EtuLZZs+b8mAxy2P/r1LfpAiP8AYl2XMybUQdPw9zzVGKELZXEY G2VhuRsZ+b0rKLOp6WRRtJBHN9lJjZl5VTg+bg9AO/OAR715/pZS2uwqRsLiVmzyWCgkk9e3WvTo X0yeL+z5Xe0lRM/u/wDWE9yCOh6kH6V5v4eAjl1FN3mW8dxJ85Jyy7z3PrgH8TX85/SKs8FS9f8A M/ZfBy7xE2UvFM4tNA1OWJCXuYWijYc4bHXn06+9fnj+wdGkvxQ+Jey3udQabT4ZIdmC0LiZzk5P Qru5x6fj+h3ilC2i648dvLPHFbPIYl5L7Rn8gRn3wBX56/8ABPe71HT/AIg/G6/tdNMK3elW8e24 x5luftLZ2tkjGX6ADGV96/KfAzTMrpdj9C8TnfL5JuyP1SQ2E7vGzT+bB84VZCDknufzq7LPFCLR kvEd5Dh3yQkf1HtTbaW2v7Rr29tXjZWK8EAsB1PFTFbS5KSQsrRwfex0PsfpX9zrzP5LhaL0KdzZ wS2/mvqE1z5zFU2k7WJ64H+e1akjB7Ga1jSRBGgAJbO4+9ZFrY3LPNdTgwuhwd3AI+nTFXX8qNJX jErRldzSbs898Vs46WB1rDdMSBBMUdU2NmTf94k8cfj0qW4ltxKlnPc+UxO8EgjH/wBakilSEq0i bSgzyOuemPenwXguYTC0L3EkUmCAoGf/ANeMfhUONmL2l00jMSHy72KWOdtsvBVslR6HH+FaN8N8 lrBFMfObIJj+6B9PXrUE6p8kbnm5JER2nAI/pVW7kd5xJlmii4ZkOMkcY9sCtGrnPy9C7NbosaBG mjm2gMUbjH97HbrUPkOkMcao14yZYiL71XWEcVl5LSh4ZBmQ5wVB9+w7VNbWkVvpa3ccVwZwWCfP ksM/XHPb61LVtjoUHLRGXHc3ElzLBHbtLKY8xg9F9Tip7u1WKK1uLt2ungO5ygx5ef5f/qqtcyPC 1xPAJ2DgEtnLL7fT0H86uYSXTo2kW4u7mRtu1OMmrMaUugtyscto8Fv87j5ij8kg9PwqxFaW0scc MPniGMbm3Hqx64/H+lQmZLW5ZJ1/eyx7GToy49PStG6AhS3mDhUuvkKY5Ujp+J6Vm59ju5Dn1uUJ msPP/dRnIfH9fapWjdbVUiAd925hnJx6g9q00sLWdXaZQs7nAXofrSRRjZLFBc2/mI22QAfNjtz2 /wD11u5JqxypS5tRLIBoJ50sne+ceWMY+fHQelQzW7k26Am1Rz0J5zj1q/p6rGk0JWVYmYtnJG7P XBpsm5roSPbSQB+I2Y7lAH8X41B0unbYy/sym5RnEt43Ch0+XB9x/nrUsMRF1MGka6S4Xy0j5G0+ v8x/+qpxLHbhJTHM6M5G8HAf2qIz2xwNs+8fvM5Gceo9qBNEt5s8pWNtK5X5dsZAz6nBqjbrBBOr 2rumz5t56D6Z71dNuqPcbYbi7Vk3Bd2Hx/8Ar9PanzqsOxp4W3uPl4wMj/61aqSM5Q7EEskFtC32 iN5IFG5pM4C//q7/AFFLO90qo8Sl4CmRtH3vTmpiiTKsF3HKsyc/KcZXt+P1oisZbWK4UtLtkGAc 4DD296iKMnJFCS8Rp7KCC3mWSUEMy8h/U49KfYx6pLOY78ottdMUQbNpIB6fp1qeCeSJkhSF2t8/ M2MlvXHpWrc3cUVqoWKZiD+6bqC3pn6f0q6ja2LhZ7mTHF9jvC8NsUsScBs5Ge+fb/Gr8ULpeHdD I8DjA54jPqagktk8m+SGS4unuYw21D0I7D3zx+VJYXMhuIlCSshQIEdhuj4/iNZ2HCfKySTT50jZ FlUhySNw6c9qz4LSWKe9luxKVlQJjd09/apLiR94EizXUryeXsRioixk8/yq9JCyrGsQadsBmJP3 T7+3+NIdWXNsOsobe5hjUySqA5zlseWB3+lQLP8A6VHJcWsjxWr5XH3SO2akVo7axaOJWWQkluTl j7HsKsxbpLeAvC4ac42MR8319qyk9Sr6DLu2/tGXZEjIv3z2BHtUcK2UkUsdrFKpdfLVi33j/n+d SNDNdC3SNXjsbhjG/wDfXHX8PSnxJCryoIJWaD7qKefbPt1q4zM47mKgNvo92luGuJ4GMkqqcscn HHoc/wCFW49PuZZ7sFDCk0YEMoO5Q2MnPoAPWiOwe8eK5LGKQSHeQxXA7H6f/WqVlukuJ4ZLS8iQ f6sEjbIfUY9f8K0T7j5exVgX7Pb2VwouTeFyhTfkNjoR9fetOe7jtmtvLhMk6sS7hf8AV59ay7aK ee6hvFBSzSTBUnlcdT+JrZlgS5uJmZiQyZIUEBgO3uf/AK1Emawk4oIhFH/orCSSS6+bj+LPb61Q k09bN55jvcxEExs3A9CfQGr6/YLYRmJg0pfgA5IOOlVrtr9NRW4W3eeJl2MQR8o7kg9ak0hK6EUx TyAC2me7jG8AED8AP5VFHEtxFG9wc7ZDzjp7UQK/nP5SNIkh2q6nhvYehq200USxwXluYvLO484w PU/X+tUnYzqU9RkpTMVnMWjtkG8kHlgfU+lU5YNu6JNqvEd+M4LD29M1J55WNruOymeLOHdujY7e wqxb3AuY2E25J5uNp4+XsB701O2hhKJTubkQRPBhXktvnyO2a0LQb0jSZhHazL+LHr8vp0qhHHPL DewiMSFmyOP9X25NadxCI5IHRGkaIZYA/fwOgNVOxtRvcqwrOLl7GITebboJd55wp7/59aek93Iw t3iRHBJMyjKOM9GGeOO/rir1tA8UsjpIY3mxsYj7pHpTBC9uJjfxqkNzmNQDgr9SPb+dYuR0PuVA YiXntt86WZ/eAnITNJI88oMMMokJGQo64Pb61YS3htbSKKBLiJ3Y4zlt3cA//X46VkxY3JIMxzKx wRklPU471UH1OeUrE8bXDQm5miJb7v3eRirct00UsErQ3AjiHyknCP64H9asNMgMl3d3Ie1jXy1C AABh7+vr9KhZVW1W6cTnyiZEVud2Ov4DP8qqUripys9B0El6l2We28y3xvGB/q89j/nvUrL55e2h DmUnPC5K+/tTLRkvrKOe1Fyqz53OT8wOen0B6VWhnnYTEecs4YKGToR9Kg39o5KxHJbG9thA0NxH JG2YirAeYR2FXLuJA9p5ySIeiKhO5uOc+tTXMctubeVIJWu7ZhKnlnGPTPt/iKrB5ibiea3mjG0b AWzub2/w9xQZOJEFtbqN7VFuXjzk846nAG73/SoQ0KGZrO6iWaDhsglauyRKEiePd9nB/etj7pPU H6GmxyRRFLbyGjeX70zp8rfh1xQYyWpWsladri6UPIsC/wAPAkPoPenWkbXWyc7nijboDjB9DWh9 mgRWSz81GHuOSP0/yKoxxtY/a4Hk89Z/nSPo2T2zWvMjalT7k8RjT7S0kjqLnKnJPy/T0psMc32m 2s4n/wBEH7wZ58xjUttaNBHftK832q5VSN/G0Dsv+e1ZclwI52t5ElKBAAAcF8+hqG7l1tNjV8pH d/sbPFNM2zJ7n+QqoHedpLMNHZwxLuMrDueOKvLY3Mt1B9iVzaIufvctVK/e2SPy2V3eH5gqcY/x qTjm2QxwQXM4CtKlqfkPPLDuQf61pXWlpJEbeGRVjYYGSRg+9SR+RJAltJZ3DtGNwZTt/AUye4Xm dD5m07XQH7oHt2OaTub0FHl1HSRBrWS2iaK4aNR+6j4ye/P9O1JHa29nayTMfId2C7mfG09h/Pik +ySyyRtYXBxtydvc9iD2HrVi5hSKIGQvcSof9Zjj8PWlzaGsuU5yeB7jVG8iSe5ZE3SKeSOeg9O/ 5VqNpsFzAiRzSJOpDKSMbW9PwqZo5xFJcRMts0w2Fx1X3FLLZzs0ZMrpcY8sJg/OccZFayndWOVR 1Mq5EaJHo0Pz+a2XOe/9KuXgkn2taRrKLdArqy8YHXaOxzjmrRgihszfSwB71VIVWYZbHcf571QW SFnRLCR3uJxhCx+XnrkelVGXcznB3K0McMrvdzSTG0ROdh4Ujjp+n5VYvLqSRkNqJiI+CV+7j3rU jDxT/Z2Rltroc8dSP89qqCNgLmCKWMwP/GvAj9TQ5mlN2Vh0PlieBFspCwXd83rjn/PuKWGJp47i Aw3P2krhcv8Ae9Bn/PapIGQzpL5NyluibVLHIJHGT7H+oqaNJfOheaC4dwTIk0f3RkYwf8+lZG8K gyNnG+JlVbuNQu4jhh24qlb75J2nWaOY8pKFHMY7fjVq3W41COTzWDiJ8Qg8Ozd/w/xpVba8F5a2 rxvbjEsJI+Yjrntnv+VTbcvnuyC63RypazhzLP8AMjr91QPUd6ijkimula5C/aCceVjG4eo7dq07 /wA8pcM0bJb3SgnaMMQOflPUHPWsvchnlCFZLpQEVwMgfh69M/hWlOOlhTWpZu7aIozrcMrKDuOf uD29KhME4C7QoicYY9Ng9TWq0PmpFJaGBy4O9hznH8z2NSW21bWd0V2d/lDM3y5qHUa0NKdJPUot aeVOtjbrdzFk3RAtkue4J7DPf6Cl8idHVbgxhF++q/cfvj60y4+2SXBZC32ZVB8wHG33+lTxWe1l je7nkuXJ+UkkMD0HX/OKalc05LD3eRLaS5jACJnMQHKD1/GlUi8iM7WNzGHi2lQcFx6g9v8A64pL 4XEl2k8cMsDWoG9MDbIB0z9asQWzzKt7IZRGgyYlbG72HpmsnMiElexjrYz3dpDbW84gbcQHcZ3D 2OetWrqxmjeGxjaWOSIA4ZuWHbn1NaMkcPk3H2iOTz5VG1FOMfT3qtKu5w00srmFc7xx09PpTjLu byasVrbdbzxrIDbzI/Qj7vH86llljnuDAzTSlcZCHAHpn/PpUTQS2yQwYO+XLB+uR/jS20kLu1kr iCYfN83Jb8vxrU85TGzBJ5be3RmRFkwfbjrUwtWimYRMgZvlVnGdw9verjLHBaldvk3L5285LH/D /wDVVOKOK2ibzbW9kR23CZWyh9Qc+/8ASpi2aJ2K9q19LlQAssLnDZ6g1btYDdyMUWZ/IOG3klQe /wCNV0Nwtytw5aNM4x6j2q3qNx5qyWTb0KrmXtuU9BTOiL0MyJZ5dRnhggEMKj5sjk/T27/nTWlv LFY9ts80zy7cZ6j2FXLe7jixhGneM4yTwxHQE+goTe92+EnG/rgFgh6/h/kVKlc5Kt9bFa51VLiO SdpI7mdONijA442/UY/Sp1dpGkWJB++UBMDgH6VYJuZJhD9nhSJ0/esVx5Xq31JA/WiwePzJracF lgBkEiHhgf8A9VVZCpQnfVmYrFJFtWnDrcEhgvPk++atvZTm5kllDRWoUbs/rt9z+laqRQLAXsxG ZZ+QduKTJnMTKrvMW2KM8Me49sDvUOZ26WKjXfkTCFUjSyJyvy/M5759qdceTIJ1iBnmuwFV16Lj 2/OluY4ImSUrLtj6An7x9P8APtViRnW5SK3aBIdgJGOhPZvQdMVPOTJq9iCBFiaOFH2y4yGIwufT 61lQWuoyXtxbSNHLYK3mB88Y9j+VaqW0zOoG5xbtvOP4gf5fjxSXkThDEsggRlLL83LeuP8APFUp 9zOcOqKsEcgaScqiQRHkYGCPWrk6QTT2lvPcRvE+H8pTjcKzrO1u440t98irctsHOSPer14Xs3aF SqiAbncjIcegpTfQcFZalkWkMrRswfapwArbdoHQ/wD16i1WwmmjMscrARt0JxuHcZ9arW80jWwm Z33ux3DH3h/SpJbZ4IUvI5pplXl8ZOz6g9fwqY9ypaqwRkRbf9HEEKncXAyH+lTSb5pTEpiSAgYB 4Mp/ziktLWK4LTESRKjESROTvUev0o1C2+03aNDiOONQrMv3B7/StJK7sZuPLEJY7mKOS4+z7Xi+ UhiOn9M1RF75Txs9vcwyqdwUHlif5j/61TolwI3inkZZDxk8hhV5LCGW3tpQ0i3CnKNkHp1/z2p2 SOP2rvoV4Uaby76RvKdm+WNv4h2x6101lcpIUe1t54pd5G6ZcqMdSQOqgiuf06Jrq8uLia4RVixG qNyT15/HtXX2OyyaBLqc/wCjfLmMcqDnkjvXgZ9K2Gn6H1+QRcq0L9z+mL/glzYx2vwg1h4lZkma By5Tbl2Dl8DsN2ePcV4N+29fvbfFv9oue0jjN1ZfCbUZHdiP3SfY3jz6qCZOvfHtX0d/wTHsbq1+ C2oS3oVZpJo02q2Qu0MD+uT+NfIH/BQK+a18TfteXTwvLb23wruULkAcl4VKkjkgrJtAPH41/m3X lzZlKS7n9c4FWoJPsfzv/De2upvC2kSi5A0+GeYlkjYF8AE49ByOv9K76CABL1d7RW043IXb9c9h XC/DW3msPBGmRqLsMxkDpIcKqlgdvuA+R+Fd1dzIEF09tNOgGzZGQCCPr2r/AEL4NpyjltJeR/KX ENOP12ol3PffDAfR/wBmL9o67ghvHOq6todg8QOfOGbmbODwOY1J9gteARMsMJtLUnzZI9+ScrtP +ePSvo7Ukmtv2QtYmhs7+0j8Q+O7e1iuHKmOVYrWVyCQeR+9zg8181xxpaoY/MWSdxwy9/pXp5RT 5qtST7nPmfuwhFFxEdUbYqoSMDI71kXsVwbpILm5iupLQ7wsfAVT0J9fSrkRvUaOPzVZX+ZvUf8A 1jTbm5jYyfZLd455flbPO4j/ADmve5bHiy1ILh1fbLJbSiJlGN7c5HYkVbw/l2qb41uJmxsc8juB Uc6/u4ZJpAPNIRmzjAHT6fhSSxSi6hWKSESuB5m9eq/T+tBn5DpI5keZfJMizD5ZWORn0/D+tVol WWYxKrtLCmPMU8R/X+Vahi8qW3RnYJdEqBnkkVSjinYvE9vMYUY/Op5x6n1HTFOOgJq1ipcWsUVj JFFukaNSxZOx9CatRTXEdutviBmSMEAHG361ALGaYmbzGdwTgIcZA6A1OtjJcwfaSN92cq204BGe Pp1rZO5mtHciCBprieWdlNiodo1G0DOe3T/OauzSwqVaGMyNNwQein1+lU7eVLVDGCyXcbbJAw3M 69vw4/WrsUa4WeQPBGeVVjk+/wBfpWUtx8+mpQtNQnhnubZ7bLpycAAjJ4A/SpbO1Szkkmkl2uxL PkcAVN5UirBqUBYOGZWYYPl/WnxvE0pgvILlkdQVdT936+tQ3YeGV9SuNtlIztaNOsr5BzyP/rf4 1DFHdS3RmNvLCScwLnJBHc+ua1rqCIJASGRC2NwJG7/IrLMbq8t0blwUO2JEU8t2J9sZ/KmjepLl ZO1xF5TTbZMx5Wb+7H7n8f5ioyk8DxLY3GLaSMF3YZZieo/CtBv9OVp5+Uf5HIPAI4/T0FZmx7qV pbUhZLEABQeJCD29D1/SpcDCVQszwSiAhXClTuVl+6c+tRwWchgglmMkknRj3ZR/nrT2mlL3bW0i NLZAEqTxk/5NTTrObWC/tXZ03Y8lSAzk+nY1VilIxGmjSc28FpP5CfMsjc7WPr6jP86mguJrUNBe xYeQ/Iyjr+HqKvqbeIvKFkeJBuwD1PcH2qYWcaxyK0jbrzlR/HGT6Ht+HNU7HNre5DJBAIFe5VnV hgqDjb9T9KpIr2t9a3MIFxbyg7EU5PHb61ptbtbJGhKzKx2r7/481GY75bmS4SBZIsBGAAymO/t2 pGxFPNNLMJIAWtyCPNJAU+3qMetOj+zQ3DKzJ9mt2OGj/iOPf+tJF/oySTMFL5y8jDC4Pb2/+vVq GxRLt7iKOfYgBbcRhP8APAoNrdSmVu1uYp2QdcOAPmGf8/WnJHFujilAx5hwmMH3PtToZbmLULV3 Xybe6lZHJxg8cDFSS2i3k4ntzIlxu2rhuBj1pCl3IJZ4rW8jkhjkRJPlkDNnAA6j07fnUct7DZxM Zo3fcpV34yc9sfypZ2jSaxP2dmYS7TkZMn0P506fTY7VZL0szPK+ACSQwHTA/WhRT3J9vUWkRJVs YxaIwnjlugAAzFigx155/wA+1MeU21wriO4lig6bG+Z/fHp9al+2LJp80kkTPLuwr4+571JJpkUE DXymUXYUEsznaB6kUpLoX7W61EaObbKYY/MctkqT94e3pTI4Wa5Ekcgmm6JGp4U+/qPai7Y2k8Mu ZZzMPu5xzj+XtVidraVLZbaImVshyCMg+478nj61Kple0voUUM88iLLZhm8zJcHCKBxkr3B7U9p0 YtcQ+ZbxQMUcPxtHqfanWcDiSeFnnxguGJzjJ/l/Km3sbi1kT7PLI9yNpkAAVR649asRLHc+bB5l xbidocgNGNuQOg69aJY4xuuZA6O3zIrHIx2yO4xTo/lCW0jeWJk2vsOMAjrTobNLeymjd5I4kyRN I2QP8BUSRalYhWNbZIZ3jf8A0qXYqls84zwPQjt1qyZhP56CKJJIVwFC4LH3HpVZfmWGb7lv/C5P Bx1IqOW0F1E91DIcEYXacfiafLfcipWtsWrR0tkub9XdkZNgikOSG7lR+QqBT510mZI49hzhu34U 7yZlgMsUiJOhxtI5bFSX1tCxhljtJpCR0B+bdjn9OlNKwoV77jJ4raDZLcMI2nJBXPKKO5Pv61Xt heLcPceQYo2AUhuhTsQO3XrTzbxF5AfPMtyNqxuclvYen/6qv3HmoY7KRX3P8ueORj+VQ5ahKnd3 Mu9kvbY20cTx3MM8hQIseXYnp7Y60+KO4jcWl6jeS6nPl/L+vUf41NcJfJZyPprA3sakBG7L/j+N XjLeS2OmRziMXcuVdVT5vYZ7nFRcuUbPQrT2kCRRtAD5MIO0k8D1z61BpsUH2WRIbeZri6kJWWQk 59gOw+nrSRxtcC9twshNrh9u44Jz/X0qtFc3LrGkzltrZXYu0k/3R9BSOaUbGhaFJXuCI5FijIA3 HO7HUfX/ABqK8kja8JSbeBtXA9cetNdZVe7jQyf6QOefu/j2pbZIYwk+9IzD8vqGP49DWkVqa0mP naOQxTy4kct5fA4GPT0NOki+0Ot2sjKqYDHBPyj2p0kW0SLaiWVMASADLKe+PenSmUIkix8Z2Eng cVB2xkrHP2dqlu7GCIyO0pYsOOvtV2a58nbdSDy4mYoxbke3Pb2rZjj22zK0y75wSJQuBGv+I9aq W1ojxG3Ija5TJQMeM/TvmrlWOf2dtiqIFjgLCK6M0zEiRmJ2j/P8xVu4sctErpc+bCw5VsBOO4/z 2qVYXge2eEywx2775Vdi27/62elWrqMt5kaSEbvvLnJHt/npXLJiTsypcKr+SYJFfc2fMU8Rj1Pq KVY388WKlzI/zKx5DfX1HtUzOpjVYreebYNq7OuR1+uKUrHA8u+cZxhWBxz6D3oUTYqrDEJUS/dN 0bbjsOAPT9KWO6uBPtaHbBEx+QgbyPX8eKr28xN9NLH5dzLONgRRjYfX61PcpCl1BcXMuxiCAucH gd/UZNaRjYhyRTijnMJjuGiR7pm2BRyo/wAahexD2qKJLiXyWw6yHLN7D0NPhOo3MhnktpY0GRAp HHBxn6f1p4u4lSaZoZ3fcI2UPgJ/tfnxWkY3M0uhNbRXS3EnzTlL4gYc5CY6A/y49qfbKEubjerC UHbjNU5obqWeK4iFwgiAYfNwnvjvn/Crn2e58xbiaKaeYjIVGxuA9PeiS1L9n2Mm4na3uHvLeC4c XLeUYVOTkdO+Mmr97FAqxRRrJiUjMjHOw9/wqFY5blEe0YO1u5O4j5VPoffitEW0MqoZ4pXlX5nL N8oPofasZS6HLyasyLrTr6WW28m7BlXkELTopZLjcjSiFomxKf4Svb6Veitb+2tQzEXUpbaWAwEH Y4zVeK0nF0wdS0c/QEfdP+17enpzVRlcqjTtIkjuYWuB+5u4LiBsKkhx53HYfn+npWmxglR5N4Rs fOjHoB6fjVeNpLa433sJRYRgSHow7D64qrPAk0k08rmIoN+1s8+n6VF0dVSXQciztJKYbd94HcjL j2qOylgurFYrqN7dvMYDcMFTnnOOT0qdovPgP2f7RCZF2sc8qf6U6WyecefJFKksDDCKQDKB/jVK ZiVftMqPL5ZZig2oUUHd9M96ilE88scilrW5hbc+4cEEeg6VMtxPIjlrdz5xKbIgMx+/+e9SeZcw zgXNvJMkf+sMWMsCOOfX/GqtclPUtQtLLYyXALKIcqx6s3Pb09qzxKX2W4V7SZSWMbe/Q8euM1XZ LwXEMsLSu+/bwcJL/s46Z/rWtPFudJyVjZzjbk7kUf3s9fr3qVTO2lK5QE9oLkpGonuhwRjBYj09 6kuIpb1YRIfsrSPty4+6o9CO/wDKpoomjgv7t4gskf3AR83uQe3HrjFRyAOiYuVeBFDGMDDZPXH+ exocdRSdtiW58+a7tZ7YyG2Q4k9CPU+g/wDrVFLAqyTRLD9okVyyiQ5G09MZ9qzbgW8UgiNzOskv RQTiMds+p+lbElgJIzcS3c32qWMBQvBQe69PX/IrIj2rBktYZ7eW1uyHtk3mAHJVv89qbO0UszSq 26V1CsGUbIyP4m747EfSlXTy74AV57gBCU/iA7/496SWwt13CVy0ijBwSBmstb6md7sUG3ke5a0Z tojABxgMf4sevP5U9rW2uLo3YllUtGF+9ggjqfbisq23yvb2UiXTzQsdoH8I7D/Oe1W4HeI3W+Bk 8gbgxPDfT/PetTphUWwjtOW/cKTFC2SRjcvuKJLp2sXaysXa4LnOeSvuf6Vdj8x544jB8rKNwA+Z gfSqAkazeV1jmaO4bZFEDkqR+nP+FTIxmgF5bMykwvDLKPKDscrkf1qGG1dHu7m7MzGL5CgGGUep /p+FNvbxWNnKiO7ySiLHdD647+1asguZrpVSCYJsWLc5+VznjPp9T7Vkzngyo8zTNHHMSkD/AHCn G4j09eKiaO6uopEhY28pbAZud4/2eeD/AEqeJVXyfllMplI2u3+rIPTrV7ZvYss0SoxIXvk9/wAK DtUmUbqOGOyVEkeKPOGKH5mx1FQ28U6qEMM0NvNzFk5YnvmrksHnQyQQbtzEn3PtUFzBq0FvbQiY JDLxNMSPkX/Z9D0FVzszl5Fa7jn+wSSfZ5Ypg/7vy03eZnofoOpzUsheWFftNuZtpBJBABPt6A+l awuUngntTFcRxkYLH+YqFFhttsNwSIZSAJD/ABd/rWclobU6b3GzWqTGHfIZhFh3QDqv09P8Kziy LdwmF2kihJzhugwep/8A11oMn2mGRWkKJKxRNpwygd/yqOK0FtJbRiCWGEj927HLOfqPXqPY1EET Xi7WG6aUuYTLADdNExUsgyWHYH1H9aW6YGF7m7LI8Ck7B1x2x2zSyW3kvdymWV4jGPkj+UqPr6+9 UoW22k8F/wCbNEy4jzncD1wzenpTcApSstS/Y20TLtSd/sU6+YXBwM//AK+tU1tlZwQg3K57enrV tdkFlEs0i7zhDwVGTzwB04qjHcJLHJIfM3klTnAyB7f596iUGVOsluOu1+3QvHGsM8O0NmXPksAc kk91wCDX8fHxc3an8WviVqFzfG6muNfvG3JH5aMPPcKQO2QBX9cd7plpePBuuXgZy0cA3kIJGGBn 2PPB+lfyBeLPtN54v8VPI04F/q13KkT8yAGdzjj09e+K/GPFCly+z+f6H614dVFUhO3kcsHFvBNE kDu4yGOeGzVMmJraRYiwVB82T8z+2frXYQ+HNWncxW9pPKsg2+XjDH6k9K2NJ+FviW9dF/s+SxtH fb5kzA7vXp2r8OlWhH4pH6nGhLZI4PSZ8ohmgLtEcY6BvT61Fe2E9rL5zkxNOeB0yK+otD/Z6nuD b/2nBd3VnJICzQEpjHue1evW/wACLmPUJXuo9PTT44gIo5xudM9/QcY5r57MOI8LTfuyuevDJq7j dqx8EP4fvmuIzbK8gxvLdBXYWHw68RX8cEkcAdH4K7OR7n2r7Osfg5Zxr9rmtxdSNIVORhWx0A9D 9K7ODw1BaSyQpbPp9xCoVYpBgs3oB1H418/i+MYpfuY3fmEMmle9Q+YND+DBmtQupREhF3EAjdJ7 DFeqad8M/DekQeRa6cpu9gO/OWXj+demHyVsnWBJo7udjFux/qyOw965k/a/NfzUfexws+cKnvj1 /wAa8avmtfEazke3hsBCkvdR0fhHxTqfh/LWOqX9vaOAj/vDtUKeMj2/wr19Pjv4i0Gzvr2+aC6x GBbqsYG4jofxGPT1r5ukv5Id4e4hcTAK+F549K5XX9akOnX1tBHKsO3GwkFkHqfqa+YrZDha8+ap DVn0WC4ux2FjyU56I+stC/bU+HGmbdL1lbuOSU/6TNEQ32c55BHXPHAGf5V7T4R+N3wB+JP9kC41 /wAOG+1C6aIveJHELZAflYxyDO088qD7gCv5+dUlnOpTws7tNuJOD1q3FqXlwOkt21rcoMKVJBYH scdaeO8JcFUjzUZuMvI+ny7xnx9GajVgpR7H9Fd/+zj8E/iNBqM/h/wx4eGqXA2O1nhWbac5YxkE Z67q8d8c/wDBPTwHeWsb+Hr2+8MTJbmWWZ7l5h5oHRI8ZOSRgEnOeo61+OGh/GPxzpFwl9ovjPxN pd7aphTHeSLHx6KDgGvrPwX+3p8b9CslSfUNK1ma2YSJLeWxlLgjBDZbBGPTGOor5h8D8Q4F8+Ex PMl0v/mfZUPEzh/HJ08fhkr+R1WvfsB/Eixie707xDpWsTNhgRbGEf7oQsSX9cHFfOnib9nX4v8A hf7Tdav8PPENl5CearGMFZVB6jBx+PuK/Sr4Uftvz+Np57fxB4QtkisrZY99vKAk75yQoOSDwOuc +1fUPhn4z/C3xOI5dRaPTI42Ee2+tlYqc8/c3Z79+c0f8RA4lwFTlxlLmXoaYbgzhDNly0J8j+7/ AIB/O9JZ3FtZRSXUaRXIkK7HAIOO319qy7yLy32SgLHj+L+A+p/z3r+kK98B/AnxI66WLbwlqV7P J5gmdV86GQjjgYYAAn5TXz38Vf2G/hVr9yJtHjufDdpeInlTJIXUnPzgngnJOQMkDpivocv8eMLK ShiKTj5ny+aeAkry+pV1JdD8MzHZxIqPHvkfjg/dHYn8aZPKZzZpa27rLnD8cNgcYr9HfE//AAT3 8VafamTw34k0/XLjzjJsaJoy0RHyDJJGcnk5I/2Vr5t1/wDZ1+MHhX99qfgrVWtyW8poog7yqO6B Scj3r9NwHiFlOJV6VZX89GfnWZeEee4b3pUbry1Pnc+VKTaAPHMF3MQf0qCWYxzoys8pcDcU6Af0 rcvLCfT7uYzWM8XmgjbKduSPvDnpg9R271BLY3C+TsKK0/zsgPOOw/8A1V9HTxlOa5oSuj4vEZNi aF1Vg1burFjTZi19G05PlRMpDsvCmvTT4r0iyv7e3SN72NsZjj6SeufQV5VpsFwxKXCSvmTlBjIF WZrfyNR8qYy2/PKgck+1LGYSNVcsx5RmFXD1OenufrBd/wDBTDxr4Q8GeFfAHw08E+GfDcPh2xFp Fc39ml6sw2KGJB29WBJOCcseRk5+a9M/bR+NPg7x/D8VdX1rR9e8R3URt9t7a77eIHPIUtgNg4B/ nXxlqtzcsy+bvCxDbG6n8x9a5a7+3Xklst5OTFEcKh618bU4Nw/M3y3P3qh4/wCexoxpuu1ba2h+ xH7MHxw0TxB4j+Ivx6+MPjLwtoutamq6dbWsrrAYkiZW/dqc5BGOn91vXB988G/tDfCDxf8AHbU/ E+peObHQvB2nadBp+n/btRjj+3OXPmlBj5eDxxngHrxX4Gx3l3aQJDC8jOjEqqZwD2z61mDWrqIG 4D+czthhjI4r5vMfDylUqNp2P2Lhn6XeZYXDxo1Yc9t2+p/Sh8BPHuj3utfFz4+arIJbfVb+4jsJ UiBMMEUoVSHA4GCFIJGckdCK+nvije+MNN8FJZ6x4Z1PQfF/iqOOTSjdWTIJUlYEPtbG5SgcDb0J HoK/mAj+Pnjy88LWvgYahdvoVu4uFt42MSEjbhn2kM3KL1P0xX1VqP8AwUU/aM8Raj4a1X4h+OIf HV14Utxa6ZJqNsHCRgYCcEZAHrnvivk8f4aVVHmpS18z96yP6YGXSkuan01fZn3x4s8K237S3xh0 L9nrVNe1+10PQNNbUL+30G4ihur2UDb5RLAjgc9uQ3cAj5A8QeAvC3g/4mWPg3wdbfEK4iunaKH+ 0iftcUcCt5kcuwAEoVb5l7YOTmuP+Ff7cPhr4d+DPi9p8fgptU+KvxIINjr0ZQPaMH3k5JycdNvI wuBwcD1z/gn/AC/D+1+KFt8e/wBp/wCM0XhHwhZm+ezW71FxJczzRtGWThyP9a5yqHlBnpgepgct xGGt7aPur8T4fNuPsNnGO+t4Ou23ur2S/H+tD//V/nw8aat8Zfj41tY2Xh23trJ7lm06AruJkK4G JSQGbH8IA4HWvePgz4W+KPh3Tbv4R/FDxZq+i6FdsDYWsExE0krA+Yu9TnGAMgnqAO+a+qPhrqOj 3HgvQ7x73w1p8shd1tkTKxpypOCTgnG4k+vXpnpviLd6CPDtpqBntEvdPk8zTGVcP54GF24xnOQC fQnPWv6yyjhaVbDc+LPybN+MI4eu6OFTPjL4k6Ynh2G08HX8c91rFnG1xazxz585FzhiTk4GTkHo ep6GvEPAGpeLYNBk8G6GIpz4knbziqg+SGxl+eBjGSf5nFenfHD4yah4utx8LNB0iG68Z6kUtEkj gxcIGfOI2PT5ge/TPtVb4Jfsm/FOzsjqviLxsdPsbpmENhbg+eCnczAtkZPI5BKjjFXhsvhCr7Kj E9rGYyUsMqtd2OA8QTX3w8+IA8NeK9f0aWzNkk0tyh+Zk27vTjBAGW79elN8V6v4u8R/Du4+Imky TutncNZo9uGLbEBKkEdySOT17cVy3x58AeFtX+K6eF/A2rXusX3h23+1alDI3nM0qKfNT5ew2jjH XPrX3V8OdT8Jat8G9Fi/s+DSLjTLGKz1Kx8kpLFOBh8Z5O51J9+PWuLHcNV1UksP13NqPEOG9jCd bZbH4Val4r8XWmqeRGlxBqVzJtXfneSTnPPU/WvuP4AfFH4s+G/CPi/WPsjXs2joZfJlQ+XKx3AI yjqxOTx6E17BqX7KGoalOniNLzwlcSvuVoLlHSS2XkrmQAjPPOeBnGasfs+Weka3cXMFlqNwLvRr 7FzpxhJabZkKQf7pOR07CvEpZbXymoqtWNl3R0TzWhmdKUMP7z7M5bwp+2PBLpkPh3xToup6n4h0 qd5GluSsbfNyIygHqOpOSoAzXXeAvEvj34xfEHwePiHrV3eeB/CEX2qGKaQ+WIxgKqg5LdffCq1f M/7WVxYaR8QtSvtJj0uy1FShutkYQW2RuIYf3hkZx7gCvpT4A/Cb4oeIvCdx4r1C/wBD8PtpenPf WkyzBhdkDgYwfLAXv/eyK48djniMXHESV0jTD5fSp4OVO3LJ9OgalpGm/Gv9pXxD4dt473UND8N2 oEjNysUMa8AY5++SNo9V6da+rf2VvDWl/Ab4f6l4j1Rkn8O2+rT3svmSefGqhvuDf/e2KSvfPevz K+A82v6b8UdU8S3EOr3Vs88xS7tZNpy5b/WN/dAJIzjJAr0WK91XxH4Wstdkg8QWtub4qRJcGSCT BO1gASuTx7114jH0pzkoKx2ZVg/ZwjHmv/w59n/DaK28deP/ABN4xuXtrBPtUlwm+Muln5rExhAM YKr8o/u5Ar6nhs/OlWODR9SvluMpGsbAeYf4h29DxwK+Hvgx8Q7r4d6Xcx3fgbVdUTxNc/Zo9Wkm aKztHABAdsEd8cjAyK+qvGWua5YyaRrVh4gGk3KR/a9MW1cOsm4YzxkHjBOB149q+n4VxVLB0G+W 7Z8/xxl2IzHFxjGpyxX9Ms/GXW49O0ddOsZNPtLPwnbG41eeVPlDceVHkHrnjBPzZzwK+AYfiZ8W PiJpWgaWtx9m1bV28iC3tYVhFz8xCiTOdsQyADznAxkdfqb4g+H/AAfH4T1L/hNJ7y9+IOu27P5M kxjmkcD723osak8+xPXNfPfwcvPiNfeJtTi8H6foOmFmFg93coJhbQLja0WefOPA54AY8cV0rH1J zb7mn9kUqdJR35T1nT9Hs/gzo13eeLL+x8YfEedxeTzQxrcS2Sr8qrluQq7mAxgdABmu88GeLNU8 RT29xpngfX7e1eRTNqV7EIkVs4wFbllB/A5J5rvrGPwhoFyl7eeIdI0i+e4JJ1CMy3THHRNqnI3d BwMZzXf6VfaVd2ZXQ9V07VoomZnS3mV2jPXkgnAyenQV9Tk2UJVFKbVz4fPM+VSjKhCLs+oafZAa bHI90Y4pJdiMpIIYfercUtcPc26QSl2QYJHLY9P896yYLK5jtJLx544EQkv5vAbB/h9McfhWibu6 WdVi2T3TkIxRlHlZHyjHqRX6jGpG+jPyKpzJe8hYbqKOMzSws0cb7TkfeYdj6/Q1fSyS+tJL24QQ Oz8RJgbh+HQY5rhb/wAZaBaz3lqNRsb+eMZd0cMijHzDAzlhz9DSz+O9GtILc6VoninXl1kCFZUj 8qCI8kksTggDOSOenfAqMTi+SPMjXL8N7SfK9jq5NPneCe2gMj3E6ZRc9AOg+vv9Krzx3aJbCB1m kUASuMYHY8+gPBq5pniLUNZtALnRF02MxkyQRyb5Y+cYLjr9QO9V7i8tlkW7Sa3tY+AqO3388fnm jCY6U1eSsbZjhYUnyxdx1opZ5pEcSaijBUI+VZfbHT3oDQzXUNwzGeUHaMcFD0Oc9f8A64rkfGHj fQ/DEC2hlW81e/U/ZrS2+eabHTAHQZwMnufpXGw6r8UfEljBPZaYngjzpPIZpkDTbRj5vlYgqeQO nI6EVNfMYR1TuZYTLKs3a1vU9R1K58P6G19f6nqEGnx2pLSKxJeVh1VVHJOT0rlV8Qavq1teHRtO gsLd+YZLhmY5B+YAAg5I6dh79D5Vqnw91jQNauPGtj4q1/xjqmnIvmaXfTBLXUFAO/aD91s4wWJO QOT0Pt/g/XtF8ZaK91pReCCWZxCxToB0Rv8Aa6+g4yK4adWtN+9ojsxFKlBe57zPOdY+HS/EPSoY fFniTXLy0V/Mf7LstizA52EAHjJyCfTmue8Ufs9+A9c8GXfh2Dwtp887gtYyeawurWQHOUlJ+8T1 ySD0x2r3W4tr35LWG3WP7P8APKhIHnD29OcGrj2sDtb2cd5FHcO4Krkkc+uK76eVQl1OOOd10rcq R8Q6H8Zfh98ONM8J6T4u0XUNE/0lNBuHgtPnsZ03HcwHzID8zEjIOScmvrDRLnwr4x0e2utE1a21 3RLpiRPbSlldenOOQOvUV8u/tofDPVb3wNP410LT7e6v7ndaS2oVRJ5ikNHNH2LY3KRwSD6jnS/Z S8NePdB8N6d4h17+z7az1rSo7f7DDtwwXAzkDhyFTJycY968KpSVOty8p9JQUqlD2rqfI9+s9EuZ ZtSbTNS1aRXmAhE8jFJFGPlHOD046YH1Neo6XCkEZinXzYkXccjJU98nuPQdqzbbM3nRPjEo+4mV b8D2+vHQ1YtnMdwkswkt7dRtBc53n1x6en/1q+pw9N2Z8xXrxuR2gm8+cSmVw2Sw5yB2wO34Vb22 n2dJJCJpGkKKeuz1J9f1x6UQSx5vL8zrvnXyosjPOeoHsPp0qWOXTZnaOGC4c2jAtg7QD3/HOf8A 69dVraHmuWpUF3Y2zQxxgXP2Uneh459MVbinsonWVy9tZTjDsw3GHvk0NpUK3EFwDHCJzhmcZX2y KW0eI/aLYslyJztQkfLEc87v5U7hLUmM6vLAglgSJxwzjcrEdvc+1ESiCC3jQIYg5JeQZYD69sVF 9hb7NIgkXdCcYz97PcVDbW87xGO0SW4idgkqkZLc9PzH6GnyJdTanWkt43HyyWMl7MwaeSFkx8hw oPf8ev8AjU0g2RS2wVvtG0OrL6dgB3/rXB6L8QtO1bWdT0a6YWUeiykGVIyVdOgZJANuQRgg46Z6 EE7La4tzHBHpWnalc2quM35/dqVwfuLyWOfUjuea8+eKinodv1SctTfhd57cw3CNOFO3p976VlyS 3V7JctbQ/wCiR4Rhxlsdx6V0MCQMFs5rC8jeGNQHZ8jp1OeSSMfnVCO2e0S7jFo0iTEiQKcFl9Qe xr0sNVurnk4vD3fKmAilgtpIdyqoUElTyo9z/Wn+f9r064uLmAusY8pznAcdse9V5YngtgLUDcuO D82werevpV+W2i1BLK3DN8koZsHAAA6r+Z/WtZwtdsmnNp8pDFPeW9mGdEMYby1CrgyL2H196l/0 S+WCQLcw+Ww8z94R5Y7ZwfrXTNZ6dYx2E810EhvXMYQgsAAM5J9K5i3sXXzos+XdyuWEbchlPTPt XkPFU6sXGLPTeFqUpJyRoS3/APwiniG01e3FrcxaoFNrGRtXfGuHAwMFySvJPYdOtdn43t45NTXW jaLLbeIrWO5jmLANI2MOo7YD5Ix2YA9K5PxV4e1LW/h9fSaKC/8AZGX3RuNgJ+U7iegLlR+XYV1f hK/i8cfDV9TgRL7T9LddTUhsSCSX/WKMc7Q3bI7+9fjNTEVcHjG735WfvVCjRxmBSatzI8w1XQf7 TtG0aWSaBdTcKdzlcE9D+f8AMelcd4B1+31CXW7D7NevrHhu9k07VLVwVe0ZD0Of0PpXqWpQ3d3I GMqW6WBEgXGfl9W9q8u8Maj4bj8Z+OLXSEd9Vku11DUZ8nDyyoCAc8nPLehO7uK/XaVbmgpdz8il Q5Kjp9jttf1+xh/4p7XJ0U6vNDb26Om6Bgwztkx6sODkYOB1Irnr7xZ4n0HSFtvEunS3Hhbw9rAd ruCAySr5gwA2M8gcepwTj15zW9S0nTfHNzY31je3j6lCur2l0X3QrIjbZVZPvAYUAEcc4r3T4f3k /wARPDvxM0C0tG0zxBocX2u0hKGeSVUZSJUIOcBC5PQ8V+IcQYSFLEzkt7n7LkmLqTw8ISelg0y6 Ov6XqKCOC4sGi/0WRAAGJyAHHOQeRkf0xXnfiDwfp2uaTbx6laXEcEW+2eISEiPjgkE4P3c454rz 7Wj4s8BarZ3fg1ItN/tR3FxBJETbzyDHB7BmG85PQjPtXTeF/FFpr91BLrUd3p7zKAEuiybeWHG4 YJ+UdCeuemK1oYhfWkqi0kjlr0Z/U5um9Ys+dtK8U63afFHWNJ1tPEN5feFrgx6neWczW6z6f8yx EBgRMo2xnqD7GvqmTRtYvvCrXtnqN7Y2WqIXsL+K4IEw/voRkOF4z/Ks/wCO1pLafCC/8Q6Xp7/a vBUixsRJ87wzyKp9chThgTwBn1rj/A3i3w6bfT5rK91H/hBPEUQNs8shA064H3gyj7oJO3cMew9f awmI5JzoJaHk4pe1hCrL4j1XxVrfiXWpfhFea6mm3tppFu2l3FzAm3zJMkxu3H3TnGD/AHgP4aun ShDeiC7W5RSxWWEuVMinqAew6/p6UnivUJh4E8TxW/h2/wDEGqWNt51hb2rKGWQfNuLDI2lFYfiO 4xXBeCvEniDX9EtL7XdEudCuUk3OJZxKjBgGDIR2KsMjscivZ4ZjGlUnSi9Nz57ia9WEKjWq0MPQ 7TwhbeO9Y8KWg0+916zH2lhFGsU8Ubu2wgnhsEnHXgjPrXQeI7PXkvLK6HiJbLU/DEDXduWhcR3Y 4HluoJJypPc4z171keMNP06PXtI8bWV3Fa31r/od5cpGCy255y2OWwRkAFe3PGK6/U/EyW3jnQrn V79v+Eb0qzjmfZERlZdyF2UfeTaVx6YGR6/mviflVODhVg+Vn6L4f53XqqVGceaJ8wR/HzT7TxTp nizWfBklhp99dm2dIHyIJNu0M7k8KD1/3sA1n/G34gDwvpHgXxzo3jHSbbVdZkur2xhji8xY5Yzt wUI4BVtwI49D3rrPi/8AB3wvaP448Q+ErXU7KPTSXvJonYWtwrHCMyMcKwB6hVOB3zynii48FeLV 8D6bqmiaXc6frofMc8Sp5arESo3Ywfmwp7HdX5VWm3OFCtLmuz9Mw0IezlUpx5WjU8Ma1BbWXhnx 3Iltf3dyplv/ALHjbcpIhJZR6Byjbc5yMcmvprTdK8O+NPDXirSru9F1pepaS8ltdRqGO9wQBg+5 xjHXb1xXg/8AwgMthNGug6K0N5EmG8t8xSx5JIKE9gR0xjHHevWPCuveGPh98PNRTVkvYrvUmdUt 7iTb5QDZBJ7DcT9crX6Fjsd/ZmEnhp6xktD4jC4eOY4iGJho47nH/B3w/wD2NpOqQ3chv7mzuJ2Z 5DtWbB+UDGcNtK5z647V7JqUPhG6+EHxbsPFov4H8QeHpUtHhVnltLhXUo4AJwMBsY67lHevnCHV /FngUP4gl0PX9b+HfiqY/bYrYBptOk3fNLGpOSCCowOoAIzg19f/AAattA8c/wDCV6cJ7PVPDPi3 RZLWx3kMWmVSck9QvzAnHTAPavZwWOVfJ+VvSxxZrhJQzP2klqfMeo6nrOo/CHwZcwaiuka3YS2l u16kZYBkTyyyqe24AY6c9McV6I15dpqNxceQ97bbdjucIsR9PQEY9DwRVDT4ota+F3jTS9Nu7e5v vDEKzoULGJ5BMoAB6jgYPXBAPpT9P8URPczeHtY0S5tmSFZVuPPDxz54JH8RH15BP5ex4fSoQryh SPnON51Pq/PNHC/E+Wx1D4Y+Po90drqMip9ls7pCyMN4y4I4JLbcjjjNee+JNLb4VWWheNdK8T6v JpWhRKL830wlhmjHGccMSPlGAT259fVfi0LGw+CfjvUrHWNHsLvwxa/aXhvixaRBguY8dGITgn0r 578cfFXwxeeD/BieFdPOt2V7ZQW91YtN5gbbgOdvRxjb8uckZHbFdvFmZwp4pxl1M+CsFKrhrxVl c9a+HPiVtS0UQfEnRbmyt7ecXdhOkij7cJWZjyMAYDJ1bPapPhH8W/hN4e+Jnh/wBealNb6tHfNd 21iLk+bdZJIVTyckgnjHP1FaHi/UND1j4beG5LfUm1XUp7yWC3ktJNwhby+i5yFYeh9h2Ar498Ke DNZ+D/7Wnwz+1eGtYa08XPJPBerciW4tE8tvMZSR/rAgLD3GK/BuI8vnUnL2L91fefuWT1qcIr2m jZ+lV18VdW8Pa7oEWi6jIl3PqcqvZ3MbXNxJs5wCeAQAeT3Kj2OPpvjzWPGHjLxXb31lNYPPPHJJ sgRZIDk71kAwAQCrce3FeF6BfeFNH+IV5401zUZdPvvEPiAeHtPM8zbQkYJjkUjhTJuOc45x719N fFK5vr7xfJ4Z8MaLbaHos9vHBe3GwK01wsYaQD+6vAP5+1eZk2GlCpTnTd5N2DOuT3oTVo2Garq9 jo8E+maKr+JL5rZ2jMMp8m3kPA8wkt2POAenbgVwz6j4t1yC+0u7OnaDJPbqBLbRHzpscHYzEnPp 0wcntXTRWFrZDToI7Y2UUC5M4OBIc4PHc5/HmkvrWKSTT4gZftFpceZb+U+H3e59OOlf0vw5lrqt xre8z8PzvG06ceaKsjm/C3g6w0P+zV1GTV9Va1lLrNNK0s4Pcu59Fzz9PavGPh/o2hXL/tHeGw1h B4nOsRwmCCNj5MM5IDsWxuZo1X7vT6kivpvzRplpNPd3G8sxICDIHfv7V8j/ABN8J3+i/tBfCzxZ oMuoWXhvxs/2a/VZnJu5ok3tgdAcmIKT0BI7VfFfDFOXs3eyvsYcL8QtznTiuh7hrGmeKNKvrPU/ DdxeavawWcdiNMn2sHK4VX8w4YcDDHJ5Oe2Kv6L4l0vxhZtZaM8MXi1IWVdLnkWO6t5UA3KQch1y ynI9z06dRp1slxbRj7Uj3U5JzHuGzBIyAfp2qWw8B6R4p1jRNG1GGUXct4I4b9JCskLOdoIYHIwe fSvczrh/DTy2VO3Q+cyvOsRDHpxfU4P4W6Bctrd5pR1GP+19Xnl1dbZI9qaSmEWRwRnJLnknufau 78LaGPAXgsz3Vrs8eahJcHT5402i1WTrcorE4ZgxAY+gxkV8maT8efiJ+zD8QPiFp/i62g1DX4hc +Go5hHFDJASQ21hghkCv1OfbnOPYftPj/Tp4PEMupX/iG8v0SS/+0BWRNudsQ/uqF6Y4+XJzX8sc MZNjsdjvZN2pxer8j+h86zjC4PCKsleT6eZveH/Bun+HrEWeoTapqNlBJJK1xeXLSu2/lsAkgAHp kZ6+pz4Rrvwx8HWOqfGrwN4n8G332vxje2finwM5KAQ3ActMQwycENn0wMemfRfiJ8ffC/gCwjhu YptY8XSKjRWduoAt2YcB2zjPzLxx19K4H9ozwt42+KvwS0z4z+FLu+0z4leGHXU5Ps8hje3TlHV0 Q4VVKnhT1I+lfqXGlChSwcYYSOz1Z8RwxUxU8TKvjdL7HKfDPwkPAHx08TeJPH3hu18d+NNV01To v24JJHpNyxG5nRiQWWPLE8gcZ5PP1rKlx4h1WbWdZ1ebWPEBjwbyZAVjUk/JGowFQDgADtXg/wAP Ph9f+EfFVhr2qz3/AIj1HWPDSHVLq5n+0ZmaRcqgP3WK5J5PABJzmvp+xZbW0mmZYWRTncq44x0H v0r6fgHg6k0sViVzSW3Y+Z8ROK6sZfVMPK0er7lWO1tNQkjeESRTRMVUrwjOM8KOmf0r0L4pappu n+INDsdd1a1VLfw3DJZJGCpDFn3kj1Ykn2Jx6Vgx3nh1Z9MfXJT/AGXcOIzFCGDc8nhfmJwDwAT6 V0/jDU/Avjf4m6zq1hqdnceE/DVvbaYHiUtIjRRDehOM8sxPTPPrXdxnm1sZRw0Vaxz8EZWlg6uI k73OTudZ8M+HbWS7vLy51DVDEjx2627xqylsBiWAXAHUjv34qDyUeed0nVBLI0o80kBWPYkdFzU/ jOWPxemqWUcMm68iW1yu0bUT7it642jjtWboV0ur2Ud8jQR6dcr5ciOpG5lJVuT23D/Pb6DCVqkY SqYmVtDz8VThKShh431POfiT418L6HYT65F4Rl1rU727VYrZVyqSKnAB45IBHqa4jSNA8S+H/Ft9 rlxqtuPE3jyyEGyRU32iqAxQL04OAM5xgjrmu++M3gzxPrngfwN4Q0q3h0aHW/Gb3Gn31qPKmdVh XdJu7nzpGAHTBHpmvKZfBGu+HvFtvfaL4i1C71HwFIBfW94vN/GwJdCykbSpzhuTwO2RX8+ZNg1V zSWLbvZ/qfsGPxFWOXrDQ00Pe2146PoLapqUF1dBDHbiOEFpclggb3ALDP40sOs6dq+qalFHHI0u lSi385RhWIUHd67cN0IB/KuFu/GN1qvgVr1JfD9lKpiuHghuY5hAnmgN5jEjJKDOBkgkccVqeAZN F1i+vrfQb3R7qaC8cymHG1i3I6feLEscY96/ofKM8w6xEYQmkj8dznhXH/UnUqUW3vex38N9Z3cp iuIS7IAIeyhh0Y47e30r0qPWdNvDpumeL7WK/wDDduGe4lPNxZoeC8eeuATx757c8L5eg2bWcV3b XS6hdO/yq/yxhO7c8Zq1qt7pun3setXl89vFZWnkyRLhc4JYEf7WDjn0B4rh8QMFhsdSSb26nLwN VxODq3a36HytL4uv/AfjrVvCmq3N1e6BBrS6na6hbwn/AI9igO3aMMeQuCOzfNnArpW+I+n6v4l8 Y3mmXlpdJYTQTxxgsDas5/d5fjJJXoOfavOPij43TVdM1y80yCSztNHuV+1Rtb4ZocAcEnLYY9eD jnGMVzHwntp7jx74c8FeVZouuyx6luucCOSMfMgcn+EkKDnjDc9a/jbizj7FYZfVIvmUHof2lwT4 dUJzjia9NxlNan0xZ+OfCtj4h1e11ZtQtdRubxpYZVtG8ncw6O4AVQdy4LYxgGut8UaRp2pWPg3X 5La7v9N+3Obe+tJlaO2fynwxZSd3cfLnotfGPxla/sPiL4vK6iEs7i+aJ2jHzW0aYTByOeBuH+9X 2fpHjnwn/wAKXn0zwnquoad4f8J6+q6cb22YrfB49s0m8DduJLLk/McqcYzXscH+PjjCGExS0vuf q/iR9ELCQy6Oc5XUbqTXwv7zVsoLddRigtITHPKOX4yvct7dCf51n+Ir670rSZ4NH1KOz1Txbqqf brgoX+yxLnbEB/E7ZwOgx6kV03wzvj4mi1LWLNYdXtfD0P2y5hjtykwjxlldR0OCpz05z344SLSN UsPES2k9vLNYaehuGLfNKJ5M7cMeFXa3HU/TFf1BiuJKGaulDBzUkj+AqHB+M4eqV4ZlTcZdmjpo opJY7gSP5C3GVDljgHuR6D0pNOtINSjv7CezN3BFCwVWOVJ77+vy8eh71cXT4pbUJfXEw+zncxHH y1v+H9MtU0bxTqEU5XURZSRx8fN8w2jg/Lxkn8DX6hmElSwbUvQ/JcFTlWx6nD1Of+1RzTxKkElt HNIU+U8K3PzY/u+n1rPu7NVnmVyzxMMKxP3vatSC0n8oxsY5mtQMFc/N6n+X506KMXizCclLcLww 5z9PevUyaVsPFeR4+bQviZrzKtsyxWqLP5kqE7VkXouO34UWsQ2ie3RHhjkJYZz7E1eudLAskBaW K3nH+jhushBwxz3Gazp3niSEWxKG0P7tB/y0PofXPavUjXhL4dTgxNKVPcreJDdmwhh0RX3TX0K3 mWK7oc/MARyDjnHGcVmeHZLrVbMX12XEVxI5idYtg8sMQDu7n5Sc8cEUeOtS1jQvBOraxpdkdQjg ljEsHmbZTuwAQ2DxvYDAwQOewFHh6PUk0ZF3o7W8CrNl2YM4Jzsz0HQ8f3iO1fJ4aq3mE4t7H2GN oRjlMJpa6HS3Jt/JWaNJJrOxw7SM3yZ9GPpUkFw81uYpLNrfdlZyp/1uf7vcfSolmnjMFq6Ogchy AMBvqPemRfvI7t2FysoBPAxkelfZI+E5mT2dsP7PEQhKLBIeCcsOfWqwlSe4RcPIHAU7eC49vQ+9 NtpI7S+t42nlSRDv65DZHQ+n/wBarl5H9oT9ziCXcctjgfWlNaGMpdiOZZ1lWa3c/KRv7gAcdKWX ny5CxVEOSo6H/JxWn9hkleOU71BQDBON+KbcbJ5w1kYNxAUrkELjg/rWSrLZsuFKb1SM3zQ9vcTA xCeRvLQNxuPYVYNgrW+LhX2SfJsDEEHHQmqWr6TFDJb3Nn5splJjChuN2OcitFJFmS2gdpvtMw2S MvBTj7w/p1rocrrQ1imnZjFSKFVgUSvFKu3G75k/z2qBUOnltNiuHnW8IClznOfT0P0p97c2iObO C+ikeMYkVepX69jnjPr9altrd5EV2KbLfOQw+7nr+NYSl0NWXoLfzv3MbG3VeCCeo9/UVy/xAk0y zn8K+IIgUvLZriGaOEhhOhUK5YHhVHynAwcmtVo4IIn1BbiVDaPh0kcEN7r+eOfSqPirQtJ8UaW1 qXuYbqBfMSeFyrwsSCCPxAyOh98V8lxHgak4c9H4kfW8MZvRpVFTxXws8jg1m0fxDDZrMJb3VYCs WwlVkKnGRnjaBj8xnFe5aBZ6U109rrOoRwLq8SxrcsvyW3r15zx1yBxXzEyad4U8Z3mh+I7iVNTn ltdn79iRFlw21Tx8wdM85+UA+/0Dq4e8vIJdKle/0/TVzNJGMRxBuvHXd/L86/JqlSGJozp1XaZ+ uqM8HXjVwutN/ih9pqGtwa3d6Ob2L+zrS2EtpMkhUzqTjt12/KOMnJ7YrIjtbyDU/HFto8iXWi6p 5KyTzEGSWRRl88fKoZsA9x2ruE8L6Np2mXGv6peywLAzzRyPIRtC/wAJx79Mc5xXmPhbxQPFU+qz WGqW9zo8V9cyOkMIXeVmwMtgZBOT/UjmvkI03WqwwPNeaZ9HHFRpxli2uWLOm0CI21lHaX+nPHe2 TsVYEZmfJwR3HGBg88Vptazx24vxbSPFM21lBAaLHc+x7dasXIuRcI6q22QADOAFPt6H/wCtVid7 xLa+SOfZeRRgAexPBA9eOtf0Zl+EnhMOqcXex/OueVaOPxjlO616bHj/AMVLbVNP8O6bqc6xJcQ3 giMcg2B0cHAPsTtA9/TNebfBLxzc+MNI0DW7jTJJlv8A5EumdogABtICHkruO0DJ5yeRg19BfFW5 urnwjc2UQT+2tQgdbO4wQ8c6ANCwA4wGJHOOvtXBfA+x1jTfAXh678cLZadq9lCskxtFAhjmJwyq oPLA8kDu1fPYbOI1sdKN7WPosVw9PDYFPl5r7M9QW8uI9QknNtGtvAdnlFdofAwc+g7+tZNvqWoS O6W0H2WINuGUyWxyT9OM1rSPPrcU00yzW8Up4jBxux6ke/p0qbT7C5W+cvKIh5Q2MBwv/wBevsaP NUi79T5PGKNOSSPEfGHgP+0fDd5qcSp/bfh5nu7cbwq3auwUx8HGGBOCTxnJHGK9U0nVY9Usoby/ DxQBywjyFJXvux2zkA+wrxz4reNp9AvtF8Gxabqulf8ACYRSvcOxCpa+UyASBuTtYsuQDxjOK9C8 HTxX/hzTYvCUEcOj2bbN7NumYdvvHgE8jI7n0r4bKcJL+0ZQqH22ZY1U8rjOj1O68mC1u1YSQabB tDJJIQFz/nFZ1xrunSxm2luo2lfh8gsGz0wPU81oRaJDI8eo3riWZWIijYnacdivQ96c8Qtr5XVb dXcHYxQde4xX6dSoRVnY/JnVm3uXbJYmVrq3jlhihGcdc1agja5W5vnnbMQ2pGONgHc0zT47tJGu DAX8w42Z7VnvLaCa7jV5HWAgsI3wR/nH6V2cpvCRZnbNnJAkTI04+aQHiP3Pt9PWnWsTWsivGGlm fiNgch6fdWkMsaW8lxIN+GUqcb/Y/wCe1TTypbRJIyvGyEKVHAb6ehNakOWtysbRmdp9jpJ1Q8cm ltmWw3XEnIk4CychT61rebb3GbhdwWEc4PQe4qpqVrDLstmmFuQfMj3MCXB7jv3pR3LqQjy7lJp5 bcSyJKmZRg8ZABqvbxMYVhuZiVOT05x6Z9quajAltpRe1t5XaRsDJGUx1Pv/AJ6VNH5NugeceU9z GAJT90e31Fac2hzxpkMVipSSCTyn3qBEyjDD+pqpPPDab0e3kaNvlBGMH1/HNW5LaJJxNCbhkQff JyFPP+f/ANVOmiNssck0LymVsP6AHp+NKL1LnT00HGJTFL990KBV5++euB69OlSRP58KQFGiaX5N /Zff8/Tmo2ihdI4RDOsanzFZW5Vj3FP1N5DJKJAyRxp+6I/h+vY8VEn1NYp2HOk7SLDv87yl4ZBg
October 16, 2014 - Present
Kolb-Archive.digest.vol-nb
