Kolb-Archive.digest.vol-nj
January 21, 2015 - March 10, 2015
      This is just a few miles North of Phoenix, AZ.
      The video is from Pleasant Valley Airport.
      Leland
      http://forums.matronics.com/viewtopic.php?p=437391#437391
Subject: Support column spacers..on engine mount?
Date: Jan 21, 2015
Kolbers, My Kolbra plans call for "support column spacers" going around the AN6 bolts that support the engine mount plate. The plans do not say what to make the spacers out of and there is nothing with the kit that looks appropriate. Can someone tell me what to use? Thanks, Nick Cassara Palmer, Alaska 607AK ________________________________________________________________________________
Subject: Re: Support column spacers..on engine mount?
Date: Jan 21, 2015
I got some round bar stock and a friend cut it to length and then used a drill press to drill a hole right down the middle. Since it sits on the Lord mounts anyway, it is not terribly critical. I think mine is 1" diameter, but it is cold and dark and I am not going out to the hangar right now. If you want more details I will go check tomorrow. Let me know. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437450#437450 ________________________________________________________________________________
Subject: Re: My First Passenger in the Kolb Mark 3C
Date: Jan 22, 2015
Thanks for sharing the video. Looks like good old New Mexico to me as well. Looks like a great place to fly. What do you think your takeoff distance was? -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437488#437488 ________________________________________________________________________________
Subject: 503 oil pump cable end wearing
Date: Jan 23, 2015
This 503 came from the factory without oil injection. At 80 hours I installed an injection system. The engine now has 136 hours so only 56 hours on this cable. You can see it is worn about 1/4 of the way through the barrel swedge on both ends where it contacts the oil pump lever. The pump lever is not worn at all. I noticed the swedge is brass. Too soft??? I have lubed it with LPS about every 10 hours. The engine is on a Kitfox so I had California Power Sports make a cable with the 503 oiler swedge on the pump end and a barrel swedge to fit the Kitfox throttle reverser bellcrank on the other end. I think I gave them measurements either too short for the inner cable or too long for the outer cable. I had to put both lock nuts on the adjuster below the bracket as shown to make the line on the lever line up at 3000 rpm. This caused the cable to not pull straight up on the lever at full throttle as shown in the photos. Could that be my problem I really like the convenience of the injection and it is supposed to be better for the engine but this is no good. Anyone else have this problem or have any ideas. I called CPS and they do not custom make cables anymore. I iknow this is not a Kolb but I have had better luck asking two stroke questions here. On the Kitfox forums if you don't have a 912 you might as well not show up at the dance on Saturday night. -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437514#437514 Attachments: http://forums.matronics.com//files/post_130_0_61384800_1420677060_thumb_328.jpg http://forums.matronics.com//files/post_130_0_99218200_1420677044_thumb_111.jpg http://forums.matronics.com//files/post_130_0_35242800_1420669680_122.jpg ________________________________________________________________________________
Date: Jan 23, 2015
Have you tried Matronic's ROTAX Engine List? Guessing engine vibration is causing your cable stop to wear. Oiling the fitting may be attracting dirt and grit which is accelerating wear. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Tom Jones Sent: Friday, January 23, 2015 8:06 AM Subject: Kolb-List: 503 oil pump cable end wearing This 503 came from the factory without oil injection. At 80 hours I installed an injection system. The engine now has 136 hours so only 56 hours on this cable. You can see it is worn about 1/4 of the way through the barrel swedge on both ends where it contacts the oil pump lever. The pump lever is not worn at all. I noticed the swedge is brass. Too soft??? I have lubed it with LPS about every 10 hours. The engine is on a Kitfox so I had California Power Sports make a cable with the 503 oiler swedge on the pump end and a barrel swedge to fit the Kitfox throttle reverser bellcrank on the other end. I think I gave them measurements either too short for the inner cable or too long for the outer cable. I had to put both lock nuts on the adjuster below the bracket as shown to make the line on the lever line up at 3000 rpm. This caused the cable to not pull straight up on the lever at full throttle as shown in the photos. Could that be my problem I really like the convenience of the injection and it is supposed to be better for the engine but this is no good. Anyone else have this problem or have any ideas. I called CPS and they do not custom make cables anymore. I iknow this is not a Kolb but I have had better luck asking two stroke questions here. On the Kitfox forums if you don't have a 912 you might as well not show up at the dance on Saturday night. -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437514#437514 Attachments: http://forums.matronics.com//files/post_130_0_61384800_1420677060_thumb_328. jpg http://forums.matronics.com//files/post_130_0_99218200_1420677044_thumb_111. jpg http://forums.matronics.com//files/post_130_0_35242800_1420669680_122.jpg ________________________________________________________________________________
Subject: Re: 503 oil pump cable end wearing
Date: Jan 23, 2015
Okay, I'll try the Rotax Engines List. Thanks -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437517#437517 ________________________________________________________________________________
Date: Jan 23, 2015
Brad, Hmmm..... a very rough guess is maybe 500 feet. I was trying to be smooth and not scare my wife so I put in throttle real easy and then let it run a little beyond normal Lift off speed. Solo it seems to get up in less than 300 feet with out trying too hard. Dual there was 370 pounds of people and 15 Gallons of gas. I am certainly not an expert and I am hardly qualified to talk about the capabilities of this aircraft. I really am learning (very slowly) what this airplane can do. Hope this is useful. Leland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437537#437537 ________________________________________________________________________________
Date: Jan 24, 2015
Subject: Repairing a kinked boom tube
I have a friend that bought a Firestar that has a kinked boom tube, right under the prop. It had a collar over it, and it was being flown like that, but he wants a better fix. A firestar II boom is available. Will a firestar II boom fit a firestar? Can a used boom tube be fit to another airplane. Is there another fix? Thanks Malcolm Morrison www.wienerdogaero.com ________________________________________________________________________________
Date: Jan 23, 2015
Going to take a new 5" tube and H Brace. There was enough variation in fuselages, even though welded up in the same jig, to prevent a tube fit to one fuselage being used on a different fuselage. Don't recommend flying with a kinked boom tube. john h Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of gliderx5(at)comcast.net Sent: Friday, January 23, 2015 9:20 PM Subject: Kolb-List: Repairing a kinked boom tube I have a friend that bought a Firestar that has a kinked boom tube, right under the prop. It had a collar over it, and it was being flown like that, but he wants a better fix. A firestar II boom is available. Will a firestar II boom fit a firestar? Can a used boom tube be fit to another airplane. Is there another fix? Thanks Malcolm Morrison www.wienerdogaero.com ________________________________________________________________________________
Subject: Re: Repairing a kinked boom tube
Date: Jan 23, 2015
You will need to compare the tubes & cages. Is the wall thickness the same, and is the OD of the tube the same? Is the distance from the front collar to the H brace & aft bolt hole the same? When Ed folded up FSII N582EF (before & after pictures here - http://oh2fly.net/oldpoops/kolb.htm - ) we found a basket case FSII in Florida and went and got it. As it turned out, the boom fit perfectly and assembling the two basket cases into one good airplane was pretty simple, and the boom tube into the cage almost a no-brainer, line the pieces up, a big rubber hammer and - ka-ching. As John said, there may be variation between a FS and a FSII. In our situation, we were using 2 FSII's, and everything fit very well. Your results may vary - measure carefully. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437546#437546 ________________________________________________________________________________
Date: Jan 24, 2015
I would try LEAF (Leading Edge Air Foils) Here are some of the parts you'll need. http://store.leadingedgeairfoils.com/index.php?cPath=522_284 After you make the cable, it is dipped in solder pot to make it secure. Also, I have shortened the cable sheath with a pipe cutter. It's just as good as lengthening the cable. The kind with a cutting wheel and you can adjust the pressure on the wheel with a knob. Respectfully, Dennis Baber Rough diamonds may sometimes be mistaken for worthless pebbles ________________________________________________________________________________
Date: Jan 24, 2015
Thanks Dennis. I ordered a cable splitter like that from Spruce. The parts places all seem to hold the information close to the chest on how the other end of the splitter connects to the throttle wire from the hand throttle. When It gets here I'll then see what else I need to put it all together. I also notice the Lockwood catalog has a stainless Steel oil injection fitting for the 503. http://www.lockwood.aero/p-2127-oil-injection-cable-fitting-stainless-503-only.aspx . All the other suppliers seem to use the brass fitting like wore out on mine. Doing a little more research I have run across a couple other 503 owners that have removed their oil injection for this same reason...the brass cable fitting wears out quickly. -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437549#437549 ________________________________________________________________________________
Date: Jan 24, 2015
Just looking at the top picture, it appears that the bracket is not properly aligned with the pump arm. Why not either twist the bracket a bit to line up, or fabricate a new bracket that puts the fitting in a better position? Then you need a new end fitting, you can get one from CPS, I noticed they have 2 sizes, a smaller one for the 582 and a bigger one for the 503. Looking at the close-up of the swedge, you can see where the solder has run up the cable for about 3/4". That will certainly retain it, but also make the cable stiffer. There is a foolproof way to solder a swedge end on without a solder pot, and the solder does not run up the cable as far. The swedge end will typically have the cable hole on one side the exact diameter of the cable and it will be cut off flush with the surface. That is your entrance hole, the cable enters the swedge from that side. The other side has the hole somewhat flared or countersunk and also slightly larger in diameter. That is your exit hole. If it is not slightly oversize or countersunk & flared, make it so. Just a little bit, it doesn't take much. With the cable extending slightly from the exit side, take a rib stitching needle, ice pick or similar, and thoroughly rat tail, unweave and debraid the cable, you goal is to physically enlarge the diameter of the cable so that it cannot pull back through even if you didn't solder it. You will be surprised how easy and effective this is. Now solder it, and you ought to see a bit of the solder flow back out through the cable on the entrance side. What the solder is doing is making it impossible for the steel cable to compress & get any smaller. The adhesion of the solder to the swedge is now no longer the primary securing method, it is now complimentary to the physical size difference between the cable & the swedge. Clean up the excessive rat tail by taking a Dremel wheel and trimming the rat tailed exit end back smooth with the swedge. Now you have a cable that is oversized on its exit side, and cannot be compressed & pulled back through a tapered and smaller hole. Plus it is still soldered to the swedge anyway. Using the solder pot method, the hole and the cable are a constant diameter, and rely entirely on the strength of the solder joint, in which case a solder pot is mandatory. Food for thought, worth what ya paid for it. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437551#437551 ________________________________________________________________________________
From: "Michael Velemirov" <mvelemirov(at)neo.rr.com>
Subject: RE: Repairing a kinked boom tube.
Date: Jan 24, 2015
I purchased my MK II with a bent tube and one bent landing gear. The tube was bent behind the H truss. I chose to replace the tube rather than repair it. if the H truss is bent replace it otherwise you can reuse it and the tail post truss. it is fairly simple to match drill the holes with a template. you can purchase a new tube from Travis, for under $500. I spent 35 years as a machinist and 13 years of that was in a mechanical engineering shop in the Aerospace industry. I learned about metal properties from the =9Crocket scientists=9D I worked with. My experience tell me to replace not repair. Stand on an empty pop can that has no dents in it. it will support your weight. Put a little dent in it and it will collapse. Just my opinion. Michael Velemirov Mk II N5067R ________________________________________________________________________________
Date: Jan 24, 2015
My hat is off to anyone that could match drill a Kolb tail boom to reuse an H brace! Was difficult for me to accomplish with new H braces. Over the years installed 13 on my three Kolbs, if I counted correctly. Not easy when on runs out of fingers. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Michael Velemirov Sent: Saturday, January 24, 2015 9:51 AM Subject: Kolb-List: RE: Repairing a kinked boom tube. I purchased my MK II with a bent tube and one bent landing gear. The tube was bent behind the H truss. I chose to replace the tube rather than repair it. if the H truss is bent replace it otherwise you can reuse it and the tail post truss. it is fairly simple to match drill the holes with a template. you can purchase a new tube from Travis, for under $500. I spent 35 years as a machinist and 13 years of that was in a mechanical engineering shop in the Aerospace industry. I learned about metal properties from the =9Crocket scientists=9D I worked with. My experience tell me to replace not repair. Stand on an empty pop can that has no dents in it. it will support your weight. Put a little dent in it and it will collapse. Just my opinion. Michael Velemirov Mk II N5067R ________________________________________________________________________________
Date: Jan 24, 2015
Thanks for that tip on soldering the swedge Richard! I am going to order one of those stainless steel swedges from Lockwood and do that. I feel a lot better about getting this done now. -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437555#437555 ________________________________________________________________________________
Date: Jan 24, 2015
Good 'splanation.....Richard Strikes me that silver solder would be more durable? Herb On 01/24/2015 09:19 AM, Richard Pike wrote: > > Just looking at the top picture, it appears that the bracket is not properly aligned with the pump arm. Why not either twist the bracket a bit to line up, or fabricate a new bracket that puts the fitting in a better position? > > Then you need a new end fitting, you can get one from CPS, I noticed they have 2 sizes, a smaller one for the 582 and a bigger one for the 503. > > Looking at the close-up of the swedge, you can see where the solder has run up the cable for about 3/4". That will certainly retain it, but also make the cable stiffer. There is a foolproof way to solder a swedge end on without a solder pot, and the solder does not run up the cable as far. > > The swedge end will typically have the cable hole on one side the exact diameter of the cable and it will be cut off flush with the surface. That is your entrance hole, the cable enters the swedge from that side. The other side has the hole somewhat flared or countersunk and also slightly larger in diameter. That is your exit hole. If it is not slightly oversize or countersunk & flared, make it so. Just a little bit, it doesn't take much. > > With the cable extending slightly from the exit side, take a rib stitching needle, ice pick or similar, and thoroughly rat tail, unweave and debraid the cable, you goal is to physically enlarge the diameter of the cable so that it cannot pull back through even if you didn't solder it. You will be surprised how easy and effective this is. Now solder it, and you ought to see a bit of the solder flow back out through the cable on the entrance side. What the solder is doing is making it impossible for the steel cable to compress & get any smaller. The adhesion of the solder to the swedge is now no longer the primary securing method, it is now complimentary to the physical size difference between the cable & the swedge. Clean up the excessive rat tail by taking a Dremel wheel and trimming the rat tailed exit end back smooth with the swedge. > > Now you have a cable that is oversized on its exit side, and cannot be compressed & pulled back through a tapered and smaller hole. Plus it is still soldered to the swedge anyway. Using the solder pot method, the hole and the cable are a constant diameter, and rely entirely on the strength of the solder joint, in which case a solder pot is mandatory. > > Food for thought, worth what ya paid for it. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=437551#437551 > > ________________________________________________________________________________
Date: Jan 24, 2015
Subject: Re: RE: Repairing a kinked boom tube.
I have used 1/16th thick lexan strips to match hole..making sure one has a tight fit with the thru bolt hole before starting... By the way...I bought a bunch of scratch and dent 5 inch tubes from TNK some years back..Perfectly good...the factory could not sell anything but perfect tubes so they had a trailer full of these in 6 and 5 inch... Cannot imagine shipping them...but would gladly sell them for half retail to anyone who wants to pick them up...South cent Ky I also have a set of Firefly spars...but all the holes are drilled for I replaced them when I went to the single lift strut wing as is on the Firestar... could be a match hole nightmare...but doable...If I had a hole off by a bit...I would go to the next size rivet.. 400 bucks!! Wow!! And I know Travis ain't making a bunch on them...Wish I had bought the whole trailer load...!! By the way...have my Firefly secured on a U storage lot in Conn....hoping to get it by end of March... and....I am rebuilding the Firestar wings that Bro Richard gave to me....Seriously thinking about trying them on the Fly... :-) On 01/24/2015 10:12 AM, John Hauck wrote: > > My hat is off to anyone that could match drill a Kolb tail boom to > reuse an H brace! > > Was difficult for me to accomplish with new H braces.Over the years > installed 13 on my three Kolbs, if I counted correctly.Not easy when > on runs out of fingers. > > john h > > mkIII > > Titus, Alabama > > *From:*owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] *On Behalf Of *Michael > Velemirov > *Sent:* Saturday, January 24, 2015 9:51 AM > *To:* Kolb-List Digest Server > *Subject:* Kolb-List: RE: Repairing a kinked boom tube. > > I purchased my MK II with a bent tube and one bent landing gear. The > tube was bent behind the H truss. I chose to replace the tube rather > than repair it. if the H truss is bent replace it otherwise you can > reuse it and the tail post truss. it is fairly simple to match drill > the holes with a template. you can purchase a new tube from Travis, > for under $500. I spent 35 years as a machinist and 13 years of that > was in a mechanical engineering shop in the Aerospace industry. I > learned about metal properties from the rocket scientists I worked > with. My experience tell me to replace not repair. Stand on an > empty pop can that has no dents in it. it will support your weight. > Put a little dent in it and it will collapse. Just my opinion. > > Michael Velemirov > > Mk II > > N5067R > > * * > * * > ** > * - The Kolb-List Email Forum -* > ** > ** > ** > ** > ** > * -->http://www.matronics.com/Navigator?Kolb-List* > ** > ** > * - MATRONICS WEB FORUMS -* > ** > ** > * -->http://forums.matronics.com* > ** > ** > * - List Contribution Web Site -* > * Thank you for your generous support!* > * -Matt Dralle, List Admin.* > * -->http://www.matronics.com/contribution* > ** > * * > * > > > * ________________________________________________________________________________
Date: Jan 24, 2015
From: william sullivan <williamtsullivan(at)att.net>
I replaced the boom tube on my original Firestar with a new one from Travis. I don't remember the cost, but at the time it was reasonable- aluminum prices vary widely from time to time. It showed up well packaged, within about a week. I strapped down the old tube, and got a height center on the rivets with a square and a tape measure. I drew a pen line horizontally on the new tube. I then took a circular saw and cut templates from the old tube, clamped them in place ( a right and left upper quarter, well marked for front, rear, top, and bottom) and drilled through the old holes. The old H brace went right in, all holes lining up perfectly. I did the same for the tail. Just make sure to de-burr both the templates and the new holes. Bill Sullivan Windsor Locks, Ct. FS, 447 ________________________________________________________________________________
Date: Jan 24, 2015
SSBraW5rZWQgdGhlIGJvb20gdHViZSBvbiBteSBVbHRyYVNyYXIgaW4gYSByb3VnaCBsYW5kaW5n IGZyb20gYW4gZW5naW5lIG91dC4gSSBnb3QgYSBzY3JhdGNoIGFuZCBkZW50IGFuZCBIIGJyYWNl IGZyb20gSG9tZXIuIFJhdGhlciB0aGFuIHJlLWRvIHRoZSB0YWlsIGZlYXRoZXJzIEkgY3V0IHRo ZSB0dWJlIGEgZm9vdCBmb3JlIHRoZSB0YWlsIGFuZCBjdXQgdGhlIG5ldyB0dWJlIHRvIGV4YWN0 bHkgbWF0Y2ggdGhlIGxlbmd0aCBvZiB0aGUgcmVzdCBvZiB0aGUgYm9vbS7CoAoKQWZ0ZXIgaW5z dGFsbGluZyB0aGUgSCBicmFjZSBhbmQgdGhlIG5ldyBib29tIHR1YmUgaW50byB0aGUgcmluZywg SSBjdXQgYSAxJyBwaWVjZSBmcm9tIHRoZSBvbGQgdHViZSwgY3V0IGEga2VyZiBlbmQgdG8gZW5k IHdoaWNoIGFsbG93ZWQgbWUgdG8gcmVkdWNlIHRoZSBkaWFtZXRlciBvZiB0aGUgcGllY2Ugc28g dGhhdCBJIGNvdWxkIHJ1YmJlciBtYWxsZXQgaW50byB0aGUgdHdvIGVuZHMgb2YgdGhlIG9yaWdp bmFsIGFuZCBuZXcgYm9vbSB0dWJlIHNlY3Rpb25zLsKgCgpUaGVuIEkgcml2aXRlZCBib3RoIHNp ZGVzIG9mIHRoZSBzcGxpY2UgdG8gdGhlIGJvb20gdHViZSB0byBtYWtlIGl0ICJvbmUiIMKgSSBh bHNvIHNtZWFyZWQgYWRoZXNpdmUgb24gdGhlIGtlcmZlZCBjb3VwbGluZyB0byBhc3N1cmUgaXQg ZGlkbid0IGJlZ2luIHRvIG1vdmUuwqAKCkkgaGF2ZSBzb21lIHBpeCBvZiB0aGUgcHJvY2Vzcy4g wqBJZiB5b3UnZCBjYXJlIHRvIHNlZSB0aGVtIGVtYWlsIG1lIG9mZiBsaXN0LsKgCgpTcG9rZSB3 aXRoIHNvbWUgZXhwZXJ0cyBpbiBtZXRhbHMgd2hvIGFzc3VyZWQgbWUgaXQgd2FzIGxpa2VseSBz dHJvbmdlciB0aGFuIG9yaWdpbmFsIGF0IHRoZSBzcGxpY2UuwqAKCldvcmtlZCBmb3IgbWUuIFlv dXIgZml4IGlzIHlvdXIgY2hvaWNlLCBvZiBjb3Vyc2UuIMKgCgoKU2VudCBmcm9tIG15IFZlcml6 b24gV2lyZWxlc3MgNEcgTFRFIFNtYXJ0cGhvbmUKCi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2Ug LS0tLS0tLS0KRnJvbTogSm9obiBIYXVjawpEYXRlOjAxLzI0LzIwMTUgMTE6MTIgQU0gKEdNVC0w NTowMCkgClRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQpTdWJqZWN0OiBSRTogS29sYi1MaXN0 OiBSRTogUmVwYWlyaW5nIGEga2lua2VkIGJvb20gdHViZS4KIApGcm9tOiBvd25lci1rb2xiLWxp c3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1rb2xiLWxpc3Qtc2VydmVyQG1h dHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBNaWNoYWVsIFZlbGVtaXJvdgpTZW50OiBTYXR1cmRh eSwgSmFudWFyeSAyNCwgMjAxNSA5OjUxIEFNClRvOiBLb2xiLUxpc3QgRGlnZXN0IFNlcnZlcgpT dWJqZWN0OiBLb2xiLUxpc3Q6IFJFOiBSZXBhaXJpbmcgYSBraW5rZWQgYm9vbSB0dWJlLgogCkkg cHVyY2hhc2VkIG15IE1LIElJIHdpdGggYSBiZW50IHR1YmUgYW5kIG9uZSBiZW50IGxhbmRpbmcg Z2Vhci4gIFRoZSB0dWJlIHdhcyBiZW50IGJlaGluZCB0aGUgSCB0cnVzcy4gIEkgY2hvc2UgdG8g cmVwbGFjZSB0aGUgdHViZSByYXRoZXIgdGhhbiByZXBhaXIgaXQuICBpZiB0aGUgSCB0cnVzcyBp cyBiZW50IHJlcGxhY2UgaXQgb3RoZXJ3aXNlIHlvdSBjYW4gcmV1c2UgaXQgYW5kIHRoZSB0YWls IHBvc3QgdHJ1c3MuICBpdCBpcyBmYWlybHkgc2ltcGxlIHRvIG1hdGNoIGRyaWxsIHRoZSBob2xl cyB3aXRoIGEgdGVtcGxhdGUuICB5b3UgY2FuIHB1cmNoYXNlIGEgbmV3IHR1YmUgZnJvbSBUcmF2 aXMsIGZvciB1bmRlciAkNTAwLiAgSSBzcGVudCAzNSB5ZWFycyBhcyBhICBtYWNoaW5pc3QgYW5k IDEzIHllYXJzIG9mIHRoYXQgd2FzIGluIGEgbWVjaGFuaWNhbCBlbmdpbmVlcmluZyBzaG9wIGlu IHRoZSBBZXJvc3BhY2UgaW5kdXN0cnkuICBJIGxlYXJuZWQgYWJvdXQgbWV0YWwgcHJvcGVydGll cyBmcm9tIHRoZSDigJxyb2NrZXQgc2NpZW50aXN0c+KAnSAgSSB3b3JrZWQgd2l0aC4gICAgTXkg ZXhwZXJpZW5jZSB0ZWxsIG1lIHRvIHJlcGxhY2Ugbm90IHJlcGFpci4gIFN0YW5kIG9uIGFuIGVt cHR5IHBvcCBjYW4gdGhhdCBoYXMgbm8gZGVudHMgaW4gaXQuICBpdCB3aWxsIHN1cHBvcnQgeW91 ciB3ZWlnaHQuIFB1dCBhIGxpdHRsZSBkZW50IGluIGl0IGFuZCBpdCB3aWxsIGNvbGxhcHNlLiAg SnVzdCBteSBvcGluaW9uLgpNaWNoYWVsIFZlbGVtaXJvdgpNayBJSQpONTA2N1IKIAogCiAgICAg ICAgICAtIFRoZSBLb2xiLUxpc3QgRW1haWwgRm9ydW0gLQogICAtLT4gaHR0cDovL3d3dy5tYXRy b25pY3MuY29tL05hdmlnYXRvcj9Lb2xiLUxpc3QKICAgICAgICAgICAgICAgLSBNQVRST05JQ1Mg V0VCIEZPUlVNUyAtCiAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KICAgICAgICAg ICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQogIFRoYW5rIHlvdSBmb3IgeW91ciBn ZW5lcm91cyBzdXBwb3J0IQogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFs bGUsIExpc3QgQWRtaW4uCiAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0 aW9uCiAKCgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PQpfLT0gICAgICAgICAgLSBUaGUgS29sYi1MaXN0IEVtYWlsIEZvcnVtIC0K Xy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQpf LT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwK Xy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLApf LT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOgpfLT0KXy09ICAgLS0+IGh0dHA6Ly93 d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0Cl8tPQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAg ICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBh bHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gICAtLT4gaHR0cDovL2Zv cnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRy aWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBv cnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBB ZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24KXy09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT0KCg= ________________________________________________________________________________
Date: Jan 24, 2015
a very knowledgeable fellow with Kolbs...going back to the early days...sometimes on this list...indicated that what you did was perfectly good.. I would not be concerned with the same or similar splice on the inboard end of the main spar...inboard of the lift strut... The trouble comes when one is ready to sell...disclosing these types of fixes, as we must, is sure to kill the sale..! Herb On 01/24/2015 12:00 PM, undoctor wrote: > I kinked the boom tube on my UltraSrar in a rough landing from an > engine out. I got a scratch and dent and H brace from Homer. Rather > than re-do the tail feathers I cut the tube a foot fore the tail and > cut the new tube to exactly match the length of the rest of the boom. > > After installing the H brace and the new boom tube into the ring, I > cut a 1' piece from the old tube, cut a kerf end to end which allowed > me to reduce the diameter of the piece so that I could rubber mallet > into the two ends of the original and new boom tube sections. > > Then I rivited both sides of the splice to the boom tube to make it > "one" I also smeared adhesive on the kerfed coupling to assure it > didn't begin to move. > > I have some pix of the process. If you'd care to see them email me > off list. > > Spoke with some experts in metals who assured me it was likely > stronger than original at the splice. > > Worked for me. Your fix is your choice, of course. > > > Sent from my Verizon Wireless 4G LTE Smartphone > > > -------- Original message -------- > From: John Hauck > Date:01/24/2015 11:12 AM (GMT-05:00) > To: kolb-list(at)matronics.com > Subject: RE: Kolb-List: RE: Repairing a kinked boom tube. > > *From:*owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] *On Behalf Of *Michael > Velemirov > *Sent:* Saturday, January 24, 2015 9:51 AM > *To:* Kolb-List Digest Server > *Subject:* Kolb-List: RE: Repairing a kinked boom tube. > > I purchased my MK II with a bent tube and one bent landing gear. The > tube was bent behind the H truss. I chose to replace the tube rather > than repair it. if the H truss is bent replace it otherwise you can > reuse it and the tail post truss. it is fairly simple to match drill > the holes with a template. you can purchase a new tube from Travis, > for under $500. I spent 35 years as a machinist and 13 years of that > was in a mechanical engineering shop in the Aerospace industry. I > learned about metal properties from the rocket scientists I worked > with. My experience tell me to replace not repair. Stand on an > empty pop can that has no dents in it. it will support your weight. > Put a little dent in it and it will collapse. Just my opinion. > > Michael Velemirov > > Mk II > > N5067R > > * * > * * > ** > * - The Kolb-List Email Forum -* > ** > ** > ** > ** > ** > * -->http://www.matronics.com/Navigator?Kolb-List* > ** > ** > * - MATRONICS WEB FORUMS -* > ** > ** > * -->http://forums.matronics.com * > ** > ** > * - List Contribution Web Site -* > * Thank you for your generous support!* > * -Matt Dralle, List Admin.* > * -->http://www.matronics.com/contribution* > ** > * * > * > > > * > ~,gM4Gqz.'8*[.+-fZ+`axr^jzZ(j|n)b'!j'+ry'C > { > ,x(ZP!jrrj|-&j',r5h%lm 'ojj+*[.+-08IaT1 > jgrz{Zi^&lZ+ky+k&j',r+k&j',rhB{ky.+jY^.+-i0fr((nbxm-&j',rr&*''k{w/tml ________________________________________________________________________________
Date: Jan 24, 2015
I only ever did this with brass. Did not know that you could solder anything to stainless steel. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437568#437568 ________________________________________________________________________________
Date: Jan 24, 2015
I don't know how the fittings are connected to the Rotax oil pump but most cable fittings rotate so that there is little or no ware on the soft cable ends or bending of the cable. Could you consider changing the attach fitting? Rick Neilsen Redrive VW Powered MKIIIC On Sat, Jan 24, 2015 at 2:24 PM, Richard Pike wrote: > > I only ever did this with brass. Did not know that you could solder > anything to stainless steel. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > My soul shall be joyful in the LORD; It shall rejoice in His salvation. > Psalm 35:9 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=437568#437568 > > ________________________________________________________________________________
Date: Jan 24, 2015
Soldering stainless steel requires a good flux. I did some experimenting..if I fluxed the SS cable and used a soldering iron without much success.... melted some solder in a half inch copper cap and dipped fluxed SS cable in the melted solder and it worked quite well Boyd Young ________________________________________________________________________________
Date: Jan 24, 2015
Richard Pike wrote: > I only ever did this with brass. Did not know that you could solder anything to stainless steel. I was thinking of soldering the steel cable to secure it in the swedge using your method. The swedge is the only stainless part. > The adhesion of the solder to the swedge is now no longer the primary securing method, it is now complimentary to the physical size difference between the cable & the swedge. Clean up the excessive rat tail by taking a Dremel wheel and trimming the rat tailed exit end back smooth with the swedge. -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437579#437579 ________________________________________________________________________________
Date: Jan 24, 2015
Tom, To solder the stainless steel you have to get through the oxide layer on the stainless. Most of the fluxes to accomplish this are acidic. The flux will wick up the cable and is difficult if not impossible to remove. On top of that you're going to have to get both parts red hot. Both operations are going to be bad for the cable. Rick Girard On Sat, Jan 24, 2015 at 4:17 PM, Tom Jones wrote: > > > Richard Pike wrote: > > I only ever did this with brass. Did not know that you could solder > anything to stainless steel. > > > I was thinking of soldering the steel cable to secure it in the swedge > using your method. The swedge is the only stainless part. > > > > The adhesion of the solder to the swedge is now no longer the primary > securing method, it is now complimentary to the physical size difference > between the cable & the swedge. Clean up the excessive rat tail by taking a > Dremel wheel and trimming the rat tailed exit end back smooth with the > swedge. > > > -------- > Tom Jones > Classic IV > 503 Rotax, 72 inch Two blade Warp > Ellensburg, WA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=437579#437579 > > -- Believe those who are seeking the truth, doubt those who find it. -Andre Gide ________________________________________________________________________________
Date: Jan 24, 2015
Well, I guess I'll go back to brass and hope for the best. I ordered 4 brass swedges so I can replace them every 20 hours or so I guess. -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437583#437583 ________________________________________________________________________________
Date: Jan 24, 2015
SSBzdXJlIHdvdWxkbid0IHNldHRsZSBmb3IgMjAgaHIgcmVwbGFjZW1lbnQuIEdldCBpbnZlbnRp dmUuIAoKVGhlIHdlYXIgaW5kaWNhdGVkLCBpZiB0cnVseSBmcm9tIGV4Y2Vzc2l2ZSB2aWJyYXRp b24sIHdvdWxkIGluZGljYXRlIHRoYXQgdGhlIGJhcnJlbCBlbmQgaGFkIHdheSB0b28gbXVjaCBy b29tIHRvIG1vdmUuIFRoZSBhcm0gaXMsIEkgYmVsaWV2ZSwgc3ByaW5nIGxvYWRlZC4uLmFueSB0 aG91Z2h0IHRvIGluY3JlYXNpbmcgdGhhdCB0ZW5zaW9uIHdpdGggYW4gYWRkaXRpb25hbCBzcHJp bmcgc28gdGhlIGNhYmxlIGlzIHVuZGVyIGdyZWF0ZXIgdGVuc2lvbj8gSSdkIGFsc28gdGhpbmsg dGhlIGdyaXQgaW5kdWNlZCB3ZWFyIHRoZW9yeSBpcyBvdmVyYmxvd24uCgpJIHdvdWxkIHByb2Jh Ymx5IG1vZGlmeSB0aGUgY2FibGUgZW5kIHRvIHRoZSBmb3JrL3N3YWdlZCBvciBzb2xkZXJlZCBi YWxsIGRlc2lnbiBhbmQgcmVwbGFjZSB0aGUgYnJhc3MgYmFycmVsIHdpdGggYSBib2x0LiBXaXRo IGEgc21hbGxlciBiYWxsIG9uZSBjb3VsZCBmb3JnbyB0aGUgZm9yayBhbmQgY291bnRlcnNpbmsg dGhlIGJhY2sgb2YgdGhlIGJvbHQgdGhydS1jYWJsZSBob2xlIHRvIHByb3ZpZGUgYSBzZWF0IGZv ciB0aGUgYmFsbC4gQW55IG51bWJlciBvZiB3YXlzIHRvIG1vZGlmeS4gSSdkIGFsc28gbG9vayBh dCBzb21lIGxhcmdlIHNjYWxlIFIvQyBhaXJjcmFmdCBmaXR0aW5ncyBmb3IgaWRlYXMgKCBzbWFs bCBhbGwgbWV0YWwgaGVpbSBqb2ludCBmaXR0aW5ncyBjb21lIHRvIG1pbmQgKS4gCgpodHRwOi8v c3RvcmUucmM0d2QuY29tL0hpZ2gtUHJlY2lzaW9uLUJpbGxldC1UaWUtUm9kLUVuZC1NMy1TaWx2 ZXJfcF82NDEuaHRtbAoKSmltIEJha2VyCjQwNS40MjYuNTM3NwoKLS0tLS1PcmlnaW5hbCBNZXNz YWdlLS0tLS0KRnJvbTogVG9tIEpvbmVzIDxuYWhzaWtoc0BlbGx0ZWwubmV0PgpUbzoga29sYi1s aXN0QG1hdHJvbmljcy5jb20KU2VudDogU2F0LCAyNCBKYW4gMjAxNSA3OjExIFBNClN1YmplY3Q6 IEtvbGItTGlzdDogUmU6IDUwMyBvaWwgcHVtcCBjYWJsZSBlbmQgd2VhcmluZwoKLS0+IEtvbGIt TGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIlRvbSBKb25lcyIgPG5haHNpa2hzQGVsbHRlbC5uZXQ+ CgpXZWxsLCBJIGd1ZXNzIEknbGwgZ28gYmFjayB0byBicmFzcyBhbmQgaG9wZSBmb3IgdGhlIGJl c3QuICBJIG9yZGVyZWQgNCBicmFzcyBzd2VkZ2VzIHNvIEkgY2FuIHJlcGxhY2UgdGhlbSBldmVy eSAyMCBob3VycyBvciBzbyBJIGd1ZXNzLgoKLS0tLS0tLS0KVG9tIEpvbmVzCkNsYXNzaWMgSVYK NTAzIFJvdGF4LCA3MiBpbmNoIFR3byBibGFkZSBXYXJwCkVsbGVuc2J1cmcsIFdBCgoKCgpSZWFk IHRoaXMgdG9waWMgb25saW5lIGhlcmU6CgpodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmll d3RvcGljLnBocD9wPTQzNzU4MyM0Mzc1ODMKCgoKCgoKCl8tPT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRo ZSBLb2xiLUxpc3QgRW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0 dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNo IGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwg Ny1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1v cmU6Cl8tPQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Lb2xi LUxpc3QKXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMg LQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVt cyEKXy09Cl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KXy09Cl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8t PSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0KXy09ICBUaGFuayB5 b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEKXy09ICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRy b25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQoKCgoK ________________________________________________________________________________
Date: Jan 25, 2015
Jim, thanks for those ideas. I have thought about your idea, "With a smaller ball one could forgo the fork and countersink the back of the bolt thru-cable hole to provide a seat for the ball". I am also wondering about the fit of the brass barrel being a little loose in the pump lever. The only place these parts seem to be available is from after market parts suppliers...not directly from Rotax. The suppliers all specify the barrel is 5/16. Every other part on my Rotax engine is metric. I was wondering about using an 8mm bolt for a better fit. -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437607#437607 ________________________________________________________________________________
Date: Jan 25, 2015
I think Jim B is correct, vibration and not grit. I also think reinventing with bigger and different band aids won't fix the problem, which most likely is severe vibration. Had a 582 with oil injection on my MKIII initially. Flew it about 225.0 hours in six months before I removed it permanently and went to a 912. As far as I know there was zero wear on this cable component. Replacing every 20 hours isn't the solution I'd be looking at. Fix your vibration problem and most likely you will also fix your oil injection cable fitting problem. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of jimbaker(at)npacc.net Sent: Saturday, January 24, 2015 9:28 PM Subject: Re: Kolb-List: Re: 503 oil pump cable end wearing I sure wouldn't settle for 20 hr replacement. Get inventive. The wear indicated, if truly from excessive vibration, would indicate that the barrel end had way too much room to move. The arm is, I believe, spring loaded...any thought to increasing that tension with an additional spring so the cable is under greater tension? I'd also think the grit induced wear theory is overblown. I would probably modify the cable end to the fork/swaged or soldered ball design and replace the brass barrel with a bolt. With a smaller ball one could forgo the fork and countersink the back of the bolt thru-cable hole to provide a seat for the ball. Any number of ways to modify. I'd also look at some large scale R/C aircraft fittings for ideas ( small all metal heim joint fittings come to mind ). http://store.rc4wd.com/High-Precision-Billet-Tie-Rod-End-M3-Silver_p_641. html Jim Baker 405.426.5377 -----Original Message----- From: Tom Jones <nahsikhs(at)elltel.net> Sent: Sat, 24 Jan 2015 7:11 PM Subject: Kolb-List: Re: 503 oil pump cable end wearing Well, I guess I'll go back to brass and hope for the best. I ordered 4 brass swedges so I can replace them every 20 hours or so I guess. -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437583#437583 =========== =========== =========== =========== ________________________________________________________________________________
Date: Jan 25, 2015
QWxsIHRoZXNlIGJhcnJlbHMgYXJlIHRocm93YmFja3MgdG8gbW90b3JjeWNsZXMgYW5kIHRoZWly IGFzc29jaWF0ZWQgY2FibGVzLiBBbGwgdGhlIHJlYWwgb2xkIGJpa2VzIHVzZWQgbm90aGluZyBi dXQgdGhpcyBraW5kIG9mIHRlcm1pbmF0aW9uLCBldmVuIGZvciBicmFrZXMuCgpUaGUgZWxlZ2Fu dCBzb2x1dGlvbiBhcmUgdGhlIGhlaW0gam9pbnQgZml0dGluZ3MuIENhbiByZW1vdmUgYWxsIHNs b3AgYW5kIHRoZSBhbmdsZSBvZiB0aGUgY2FibGUgdG8gdGhlIGFybSBiZWNvbWVzIGxlc3MgY3Jp dGljYWwgdW5sZXNzIGl0IGlzIHJ1YmJpbmcgZXhjZXNzaXZlbHkgb24gdGhlIG91dGVyIHNoZWF0 aC4gVGhlIGRlc2lnbiBiZWNvbWVzIHNlbGYgY2FwdHVyaW5nIHdpdGggdGplIG9ubHkgZmFpbHVy ZSBwb2ludCBiZWluZyB0aGUgYm9sdCB0aHJ1YnRoZSBoZWltIGJhbGwuIFRoZSBiaWxsIG9mIG1h dGVyaWFscyB3b3VsZCBiZSBvbmUgZmVtYWxlIHRocmVhZGVkIGhlaW0sIG9uZSBkcmlsbGVkIHRo cmVhZGVkIHNoYW5rIHRvIHdoaWNoIHRoZSBjYWJsZSBjb3VsZCBiZSBzb2xkZXJlZCwgYSBudXQg dG8gcHJldmVudCB0aGUgc2hhbmsgZnJvbSByb3RhdGluZyBpbiB0aGUgaGVpbS4gRG9uZS4KCkpp bSBCYWtlcgo0MDUuNDI2LjUzNzcKCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tCkZyb206IFRv bSBKb25lcyA8bmFoc2lraHNAZWxsdGVsLm5ldD4KVG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29t ClNlbnQ6IFN1biwgMjUgSmFuIDIwMTUgODo1NyBBTQpTdWJqZWN0OiBLb2xiLUxpc3Q6IFJlOiA1 MDMgb2lsIHB1bXAgY2FibGUgZW5kIHdlYXJpbmcKCi0tPiBLb2xiLUxpc3QgbWVzc2FnZSBwb3N0 ZWQgYnk6ICJUb20gSm9uZXMiIDxuYWhzaWtoc0BlbGx0ZWwubmV0PgoKSmltLCB0aGFua3MgZm9y IHRob3NlIGlkZWFzLiAgIEkgaGF2ZSB0aG91Z2h0IGFib3V0IHlvdXIgaWRlYSwgIldpdGggYSBz bWFsbGVyIGJhbGwgb25lIGNvdWxkIGZvcmdvIHRoZSBmb3JrIGFuZCBjb3VudGVyc2luayB0aGUg YmFjayBvZiB0aGUgYm9sdCB0aHJ1LWNhYmxlIGhvbGUgdG8gcHJvdmlkZSBhIHNlYXQgZm9yIHRo ZSBiYWxsIi4KCkkgYW0gYWxzbyB3b25kZXJpbmcgYWJvdXQgdGhlIGZpdCBvZiB0aGUgYnJhc3Mg YmFycmVsIGJlaW5nIGEgbGl0dGxlIGxvb3NlIGluIHRoZSBwdW1wIGxldmVyLgoKVGhlIG9ubHkg cGxhY2UgdGhlc2UgcGFydHMgc2VlbSB0byBiZSBhdmFpbGFibGUgaXMgZnJvbSBhZnRlciBtYXJr ZXQgcGFydHMgc3VwcGxpZXJzLi4ubm90IGRpcmVjdGx5IGZyb20gUm90YXguICBUaGUgc3VwcGxp ZXJzIGFsbCBzcGVjaWZ5IHRoZSBiYXJyZWwgaXMgNS8xNi4gRXZlcnkgb3RoZXIgcGFydCBvbiBt eSBSb3RheCBlbmdpbmUgaXMgbWV0cmljLiAgSSB3YXMgd29uZGVyaW5nIGFib3V0IHVzaW5nIGFu IDhtbSBib2x0IGZvciBhIGJldHRlciBmaXQuCgotLS0tLS0tLQpUb20gSm9uZXMKQ2xhc3NpYyBJ Vgo1MDMgUm90YXgsIDcyIGluY2ggVHdvIGJsYWRlIFdhcnAKRWxsZW5zYnVyZywgV0EKCgoKClJl YWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToKCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92 aWV3dG9waWMucGhwP3A9NDM3NjA3IzQzNzYwNwoKCgoKCgoKXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgIC0g VGhlIEtvbGItTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZl YXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1 Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2Fk LCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2gg bW9yZToKXy09Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tv bGItTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVN UyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9y dW1zIQpfLT0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0K Xy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQpfLT0gIFRoYW5r IHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT0gICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1h dHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CgoKCgo ________________________________________________________________________________
Date: Jan 25, 2015
> Tom, There's .002" difference between 5/16 and 8 mm, .3125 vs .3145. I'd base the decision on which is cheaper, a brass cable stop or a steel oil pump bell crank. If it were me I'd rather the stop wear than the crank.Just a thought. > Rick Girard > Our EAA club technical councilor has the same thinking as you do Rick. I asked him why they didn't make the swedge out of steel instead of brass. His reply was "Probably so the swedge will wear and not wear out the pump lever. -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437617#437617 ________________________________________________________________________________
Date: Jan 25, 2015
How about making a new cable swivel (barrel) and using a new cable / splitter with a free end - no swaged fittings at oiler. Make a new barrel from brass rod cross drilled to snugly fit cable. Drill rod lengthwise and tap hole for machine screw thread - full length of barrel. Move adjuster to a better position where it is not trying to kink cable. Slide new barrel to best position and firmly tighten set screw to secure cable. I would make the barrel slightly longer at the outboard end (cable hole not centered) to provide more meat for thread engagement. I would also use a short Allen bolt in place of the set screw to enable better tightening - no tiny Allen keys. You can Locktite the set screw, but it's probably not necessary. Keep things clean and use a drop of oil - not WD-40 on the barrel. WD is primarily a moisture displacer with marginal lubricating properties. If you want a belt & suspenders approach, you can splay the back end of the cable strands and solder the wire ends, but this really works well only on zinc coated cables - not stainless. Unfortunately, solder wicking up the cable strands makes the cable rigid and almost guarantees eventual breakage at the stress concentration point where the solder wicking ends. Hope this helps. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437618#437618 ________________________________________________________________________________
Date: Jan 25, 2015
I would be tempted to make one out of Oilite bronze. Self lubricating. Bill Sullivan -------------------------------------------- On Sun, 1/25/15, Tom Jones wrote: Subject: Kolb-List: Re: 503 oil pump cable end wearing To: kolb-list(at)matronics.com Date: Sunday, January 25, 2015, 11:34 AM "Tom Jones" > Tom, There's .002" difference between 5/16 and 8 mm, .3125 vs .3145. I'd base the decision on which is cheaper, a brass cable stop or a steel oil pump bell crank. If it were me I'd rather the stop wear than the crank.Just a thought. > Rick Girard > Our EAA club technical councilor has the same thinking as you do Rick. I asked him why they didn't make the swedge out of steel instead of brass. His reply was "Probably so the swedge will wear and not wear out the pump lever. -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437617#437617 Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jan 25, 2015
Subject: Bourke engine
Click on various stuff in this link. My brother sent it to me, thinking I'd be interested. With Rotax dropping the small 2-strokes, there is a need for replacements. The weight to HP ratio looks pretty good. Does anyone have any experience/comments on this one? http://www.bourke-engine.com/ani Bill Sullivan ________________________________________________________________________________
Date: Jan 25, 2015
Subject: Re: Bourke engine
On 1/25/2015 11:18 AM, william sullivan wrote: > > Click on various stuff in this link. My brother sent it to me, thinking I'd be interested. With Rotax dropping the small 2-strokes, there is a need for replacements. The weight to HP ratio looks pretty good. Does anyone have any experience/comments on this one? > > http://www.bourke-engine.com/ani > > I'd suggest finding an independent engineering evaluation. My thoughts: Consider how severe the imbalance will be with both pistons moving the same direction, then how much the counterweight will weigh to counteract that force (without contributing any power). Then consider how long a sliding line-contact sliding bearing is going to last when subjected to those forces. The claim is 1/4 pound (0.25 lb) per hp/hr. This is better by about 30% than the most efficient internal combustion engine ever built, and it's still a 2 stroke engine. Isn't it a bit strange that a design that's been around long enough for the patents to expire, and is super clean, and beats the best tech out there by 30%, hasn't taken over every engine market on the planet? And it uses 'detonation' to extract more energy from the fuel? What happens to a piston when you have detonation in the combustion chamber? (Answer help: nothing good.) Current technology in 4 strokes can come pretty close to the same power/weight ratio as old tech 2 strokes. Just need someone to make them available at an affordable price. ________________________________________________________________________________
Date: Jan 25, 2015
UmVtZW1iZXIgYmFjayBpbiB0aGUgNTBzIG9yIDYwcyB3aGVuIHRoZSBXZW5rZWwgUm90YXJ5IGVu Z2luZSB3YXMgaW50cm9kdWNlZD8gT25lIHRyaWFuZ3VsYXIgcGlzdG9uIHdpdGggcm90YXJ5IHJh dGhlciB0aGFuIHJlY2lwcm9jYXRpbmcgbW90aW9uIGFuZCB2ZXJ5IGZldyBtb3ZpbmcgcGFydHM/ CgpHb29kIGlkZWEgYW5kIGl0IGNvdWxkIHNwaW4gdmVyeSBoaWdoIHJldnMuIFByb2JsZW0gaXMs IHRoZXkgY2FuJ3Qga2VlcCB0aGUgdGlwcyBmcm9tIHdlYXJpbmcgb24gdGhlIHRyaWFuZ3VsYXIg cGlzdG9uLCBzbyB2ZXJ5IGxpbWl0ZWQgYXBwbGljYXRpb24gaW4gdGhlIHJlYWwgd29ybGQuwqAK CkFsc28gcmVtZW1iZXIgYSBjZXJhbWljIGVuZ2luZSBvbiB0aGUgZHJhd2luZyBib2FyZHMgd2hp Y2ggd2FzIHRvIHJpdmFsIHNsaWNlZCBicmVhZCBmb3IgZ3JlYXRuZXNzLiBIYXZlbid0IGhlYXJk IGFueSBtb3JlIGFib3V0IHRoYXQgb25lLiBUaGF0J3MgT0suIEp1c3Qga2VlcCBpbnZlbnRpbmcs IG1hbnkgb3V0IHRoZXJlIGlkZWFzIGhhdmUgYmVlbiBzdWNjZXNzZnVsLsKgCgpEYXZlIEt1bHAK QmV0aGxlaGVtLCBQQQoKRG8gbm90IGFyY2hpdmUKCgpTZW50IGZyb20gbXkgVmVyaXpvbiBXaXJl bGVzcyA0RyBMVEUgU21hcnRwaG9uZQoKPGRpdj4tLS0tLS0tLSBPcmlnaW5hbCBtZXNzYWdlIC0t LS0tLS0tPC9kaXY+PGRpdj5Gcm9tOiBDaGFybGllIEVuZ2xhbmQgPGNlZW5nbGFuZDdAZ21haWwu Y29tPiA8L2Rpdj48ZGl2PkRhdGU6MDEvMjUvMjAxNSAgMTo0OCBQTSAgKEdNVC0wNTowMCkgPC9k aXY+PGRpdj5Ubzoga29sYi1saXN0QG1hdHJvbmljcy5jb20gPC9kaXY+PGRpdj5TdWJqZWN0OiBS ZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lIDwvZGl2PjxkaXY+CjwvZGl2Pi0tPiBLb2xiLUxp c3QgbWVzc2FnZSBwb3N0ZWQgYnk6IENoYXJsaWUgRW5nbGFuZCA8Y2VlbmdsYW5kN0BnbWFpbC5j b20+CgpPbiAxLzI1LzIwMTUgMTE6MTggQU0sIHdpbGxpYW0gc3VsbGl2YW4gd3JvdGU6Cj4gLS0+ IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogd2lsbGlhbSBzdWxsaXZhbiA8d2lsbGlhbXRz dWxsaXZhbkBhdHQubmV0Pgo+Cj4gICAgQ2xpY2sgb24gdmFyaW91cyBzdHVmZiBpbiB0aGlzIGxp bmsuICBNeSBicm90aGVyIHNlbnQgaXQgdG8gbWUsIHRoaW5raW5nIEknZCBiZSBpbnRlcmVzdGVk LiAgV2l0aCBSb3RheCBkcm9wcGluZyB0aGUgc21hbGwgMi1zdHJva2VzLCB0aGVyZSBpcyBhIG5l ZWQgZm9yIHJlcGxhY2VtZW50cy4gIFRoZSB3ZWlnaHQgdG8gSFAgcmF0aW8gbG9va3MgcHJldHR5 IGdvb2QuICBEb2VzIGFueW9uZSBoYXZlIGFueSBleHBlcmllbmNlL2NvbW1lbnRzIG9uIHRoaXMg b25lPwo+Cj4gaHR0cDovL3d3dy5ib3Vya2UtZW5naW5lLmNvbS9hbmkKPgo+CkknZCBzdWdnZXN0 IGZpbmRpbmcgYW4gaW5kZXBlbmRlbnQgZW5naW5lZXJpbmcgZXZhbHVhdGlvbi4gTXkgdGhvdWdo dHM6IApDb25zaWRlciBob3cgc2V2ZXJlIHRoZSBpbWJhbGFuY2Ugd2lsbCBiZSB3aXRoIGJvdGgg cGlzdG9ucyBtb3ZpbmcgdGhlIApzYW1lIGRpcmVjdGlvbiwgdGhlbiBob3cgbXVjaCB0aGUgY291 bnRlcndlaWdodCB3aWxsIHdlaWdoIHRvIGNvdW50ZXJhY3QgCnRoYXQgZm9yY2UgKHdpdGhvdXQg Y29udHJpYnV0aW5nIGFueSBwb3dlcikuIFRoZW4gY29uc2lkZXIgaG93IGxvbmcgYSAKc2xpZGlu ZyBsaW5lLWNvbnRhY3Qgc2xpZGluZyBiZWFyaW5nIGlzIGdvaW5nIHRvIGxhc3Qgd2hlbiBzdWJq ZWN0ZWQgdG8gCnRob3NlIGZvcmNlcy4gVGhlIGNsYWltIGlzIDEvNCBwb3VuZCAoMC4yNSBsYikg cGVyIGhwL2hyLiBUaGlzIGlzIGJldHRlciAKYnkgYWJvdXQgMzAlIHRoYW4gdGhlIG1vc3QgZWZm aWNpZW50IGludGVybmFsIGNvbWJ1c3Rpb24gZW5naW5lIGV2ZXIgCmJ1aWx0LCBhbmQgaXQncyBz dGlsbCBhIDIgc3Ryb2tlIGVuZ2luZS4gSXNuJ3QgaXQgYSBiaXQgc3RyYW5nZSB0aGF0IGEgCmRl c2lnbiB0aGF0J3MgYmVlbiBhcm91bmQgbG9uZyBlbm91Z2ggZm9yIHRoZSBwYXRlbnRzIHRvIGV4 cGlyZSwgYW5kIGlzIApzdXBlciBjbGVhbiwgYW5kIGJlYXRzIHRoZSBiZXN0IHRlY2ggb3V0IHRo ZXJlIGJ5IDMwJSwgaGFzbid0IHRha2VuIG92ZXIgCmV2ZXJ5IGVuZ2luZSBtYXJrZXQgb24gdGhl IHBsYW5ldD8gIEFuZCBpdCB1c2VzICdkZXRvbmF0aW9uJyB0byBleHRyYWN0IAptb3JlIGVuZXJn eSBmcm9tIHRoZSBmdWVsPyBXaGF0IGhhcHBlbnMgdG8gYSBwaXN0b24gd2hlbiB5b3UgaGF2ZSAK ZGV0b25hdGlvbiBpbiB0aGUgY29tYnVzdGlvbiBjaGFtYmVyPyAoQW5zd2VyIGhlbHA6IG5vdGhp bmcgZ29vZC4pCgpDdXJyZW50IHRlY2hub2xvZ3kgaW4gNCBzdHJva2VzIGNhbiBjb21lIHByZXR0 eSBjbG9zZSB0byB0aGUgc2FtZSAKcG93ZXIvd2VpZ2h0IHJhdGlvIGFzIG9sZCB0ZWNoIDIgc3Ry b2tlcy4gSnVzdCBuZWVkIHNvbWVvbmUgdG8gbWFrZSB0aGVtIAphdmFpbGFibGUgYXQgYW4gYWZm b3JkYWJsZSBwcmljZS4KCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRoZSBLb2xiLUxpc3QgRW1haWwg Rm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8g YnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2Ny aXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0 LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT0gICAtLT4g aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Lb2xiLUxpc3QKXy09Cl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8t PSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQpfLT0gU2FtZSBncmVhdCBj b250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyEKXy09Cl8tPSAgIC0tPiBo dHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAgICAtIExp c3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJv dXMgc3VwcG9ydCEKXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxl LCBMaXN0IEFkbWluLgpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1 dGlvbgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PQoKCgo ________________________________________________________________________________
Date: Jan 26, 2015
I called Lockwood Aviation tech support this morning and told him my 503 brass oil injection cable barrel swedge had worn out quickly and if he had any ideas why. He dodged the question and said he only uses stainless steel swedges and stainless steel cables. He silver solders them. They only make oil injection cables to fit the throttle cable splitters they sell. He said if I get the exact length measurements and size of barrel swedges on the ends he would make a stainless steel cable and stainless barrel swedge to fit the Kitfox throttle reverser bellcrank. He also said he sometimes bends the pump cable bracket to get better alignment of the cable. Several of you have suggested that too. As far as excessive vibration of my engine, I don't notice any excessive vibration and have had comments from other pilots on how smooth it is in flight. I really appreciate the number of replies I recieved from the Kolb forum on this question. There are a lot of good ideas for me to keep in mind. -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437656#437656 ________________________________________________________________________________
Date: Jan 26, 2015
I go back to my comment of finding the cause before proceeding to bigger band aids. For some reason, and the first to come to my mind is excessive vibration, that fitting is wearing abnormally fast. The vibration may not be felt in the airframe, but possibly could be a high frequency vibration being generated by the 503 engine which is probably fan cooled. Something is exciting that fitting to cause it to dance and wear. I don't pay a lot of attention to two stroke Rotax engines anymore because I don't live in that environment, and haven't since 1993. With my limited knowledge I haven't heard of others having this particular problem. If you don't find and fix what is causing your part to wear, when there are thousands of others out there that are not wearing, what good is it to replace with something else? john h mkIII Titus, Alabama As far as excessive vibration of my engine, I don't notice any excessive vibration and have had comments from other pilots on how smooth it is in flight. I really appreciate the number of replies I recieved from the Kolb forum on this question. There are a lot of good ideas for me to keep in mind. -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA ________________________________________________________________________________
Date: Jan 26, 2015
John Hauck wrote: > I go back to my comment of finding the cause before proceeding to bigger > band aids. For some reason, and the first to come to my mind is excessive > vibration, that fitting is wearing abnormally fast. The vibration may not > be felt in the airframe, but possibly could be a high frequency vibration > being generated by the 503 engine which is probably fan cooled. Something > is exciting that fitting to cause it to dance and wear. I don't pay a lot > of attention to two stroke Rotax engines anymore because I don't live in > that environment, and haven't since 1993. With my limited knowledge I > haven't heard of others having this particular problem. > > If you don't find and fix what is causing your part to wear, when there are > thousands of others out there that are not wearing, what good is it to > replace with something else? > > john h > mkIII > Titus, Alabama > I appreciate your comments John. I will pursue that possibility too. Thanks -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437667#437667 ________________________________________________________________________________
Subject: Met Malcolm
Date: Jan 27, 2015
Had the opportunity to meet Malcolm Morrison, have lunch and talk Kolbs and airplanes. It was nice to break up the bad weather and busy day by talking airplanes. Can't wait for spring and flying season. Thanks for taking time out of your day to meet me Malcolm. Mark -------- Mark Twinstar MKII Great Bend, PA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437687#437687 ________________________________________________________________________________
Date: Jan 27, 2015
R29vZCB0byBoZWFyIGZyb20geW91LCBQYXQuIEhvdyBhcmUgdGhpbmdzIGFjcm9zcyB0aGUgcG9u ZD8gwqBTdGlsbCBncm91bmRlZD8gwqBJIGFtIGFuZCBJIGRvbid0IGxpa2UgaXQuIEhvcGUgdG8g Y2hhbmdlIHRoYXQgZWFybHkgZmx5aW5nIHNlYXNvbi7CoAoKU29ycnkgSSBtaXNzcGVsbGVkIFdh bmtlbC4gTWVtb3J5IGdldHMgZnV6enkgZnJvbSB5ZWFycyBhZ28uwqAKCkhlcmIsIEkgd2FzIGF3 YXJlIE1hemRhIHVzZWQgdGhlIFdhbmtlbDsgZG8gdGhleSBvciBhbnlvbmUgc3RpbGw/CgpEYXZl IEt1bHAKQmV0aGxlaGVtLCBQQQoKRG8gbm90IGFyY2hpdmUKCgpTZW50IGZyb20gbXkgVmVyaXpv biBXaXJlbGVzcyA0RyBMVEUgU21hcnRwaG9uZQoKPGRpdj4tLS0tLS0tLSBPcmlnaW5hbCBtZXNz YWdlIC0tLS0tLS0tPC9kaXY+PGRpdj5Gcm9tOiBIZXJiIDxIZXJiZ2hAbmN0Yy5jb20+IDwvZGl2 PjxkaXY+RGF0ZTowMS8yNy8yMDE1ICA4OjI5IEFNICAoR01ULTA1OjAwKSA8L2Rpdj48ZGl2PlRv OiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbSA8L2Rpdj48ZGl2PlN1YmplY3Q6IFJlOiBLb2xiLUxp c3Q6IEJvdXJrZSBlbmdpbmUgPC9kaXY+PGRpdj4KPC9kaXY+UGF0CgogIElmIG1lbW9yeSBzZXJ2 ZXMsSSBiZWxpZXZlLCBNYXpkYSBoYXMgc29sdmVkIG1vc3Qgb2YgdGhlIHRlY2huaWNhbCBwcm9i bGVtcyB3aXRoIHRoZSBXYW5rZWwuCgogIGFuIGVhcmx5IHByb2JsZW0sIGZyb20gbWVtb3J5LCBj YW1lIGFib3V0IHdoZW4gdGhlIGZhY3RvcnkgZGVjaWRlZCB0byB1c2Ugc3RhbmRhcmQgYXV0byBl bmdpbmUgb2lsIHRvIGx1YnJpY2F0ZSB0aGUgYXBleCBzZWFscy4uLmFuZCBzaWRlIHNlYWxzLi4u ICBUaGF0IHJlc3VsdGVkIGluIHNvbWUgbmVjZXNzYXJ5ICBvaWwgYnVybmluZyBhbmQgYSBidWls ZCB1cCBvZiBjYXJib24uLi4gIE9uZSBjYW4gaW1hZ2luZSB0aGUgZGViYXRlIHdoZW4gZW5naW5l ZXJzIHN1Z2dlc3QgdGhhdCBsb3cgYXNoIHR3byBzdHJva2Ugb2lsIGJlIHVzZWQuLi4/IAoKICBU aGUgcG93ZXIgYW5kIGZ1ZWwgY29uc3VtcHRpb24gY2FtZSBmcm9tIHRoZSB0d28gc3Ryb2tlIGRl c2lnbi4uLiBGcm9tIG15IG1lbW9yeS4uLiBIZXJiIAoKICAgCk9uIDAxLzI3LzIwMTUgMDU6NDcg QU0sIFBhdHJpY2sgTGFkZCB3cm90ZToKPDxSZW1lbWJlciBiYWNrIGluIHRoZSA1MHMgb3IgNjBz IHdoZW4gdGhlIFdlbmtlbCBSb3RhcnkgZW5naW5lIHdhcyBpbnRyb2R1Y2VkPyBPbmUgdHJpYW5n dWxhciBwaXN0b24gd2l0aCByb3RhcnkgcmF0aGVyIHRoYW4gcmVjaXByb2NhdGluZyBtb3Rpb24g YW5kIHZlcnkgZmV3IG1vdmluZyBwYXJ0cz8+PgogCkkgaGFkIGEgY2FyIHdpdGggYSBXYW5rZWwg ICAgICAgICAgICAgICBlbmdpbmUuIEEgYmVhdXRpZnVsIGNhciB3aXRoIHRoZSBzdXBlciBzbW9v dGggbm9uIHZpYnJhdGluZyBlbmdpbmUuSXQgd291bGQgcnVuIGhhcHBpbHkgb24gdmVyeSBsb3cg Z3JhZGUgICAgICAgICAgICAgICBwZXRyb2wgYnV0IG9ubHkgZ2F2ZSBhYm91dCAyNW1pbGVzIHRv IHRoZSBnYWxsb24uIEFjY2VsZXJhdGlvbiB3YXMgbm90aGluZyB0byB3cml0ZSBob21lIGFib3V0 IGJ1dCB0aGUgbm9uIHJlY2lwcm9jYXRpbmcgZGVzaWduIG1hZGUgZm9yIHN1cGVyIHNtb290aCBy dW5uaW5nLiBBcyB5b3Ugc2F5IHRoZSB3ZWFyaW5nIG9mIHRoZSBjZXJhbWljIHRpcHMgb2YgdGhl IHRocmVlIHBvaW50ICAgICAgICAgICAgICAgcm90b3Igd2FzIGl0cyBkb3duZmFsbC4gR3JlYXQg cGl0eS4gSSByZW1lbWJlciB0aGF0IGl0IGhhZCBhIG1hbnVhbCBnZWFyIHNoaWZ0IGJ1dCBubyBj bHV0Y2ggcGVkYWwuIFRoZSBjbHV0Y2ggd2FzICAgICAgICAgICAgICAgb3BlcmF0ZWQgZWxlY3Ry aWNhbGx5IHdoZW4geW91IGhlbGQgdGhlIGtub2Igb24gdGhlIHRvcCBvZiB0aGUgZ2VhciBzdGlj ay4gU28gdGhlIGFjdCBvZiBjaGFuZ2luZyBnZWFyIGF1dG9tYXRpY2FsbHkgb3BlcmF0ZWQgdGhl IGNsdXRjaC4gSXQgaGFkIGEgZGV2aWNlIHdoaWNoIG1hdGNoZWQgIHRoZSBlbmdpbmUgc3BlZWQg dG8gdGhlIHdoZWVsIHNwZWVkIHdoZW4geW91IGNoYW5nZWQgZ2Vhci4KVGhlcmUgd2VyZSBzZXZl cmFsIFdhbmtlbCBhZXJvIGVuZ2luZXMgYmVpbmcgcGxheWVkIHdpdGggYSBmZXcgeWVhcnMgYWdv IGJ1dCB0aGV5IHNlZW0gdG8gaGF2ZSBmYWxsZW4gYnkgdGhlIHdheXNpZGUuIFBpdHksIGl0IGhh ZCBzdWNoIHByb21pc2UuCiAKUGF0CiAKRnJvbTogUmljaGFyZCBHaXJhcmQKU2VudDogU3VuZGF5 LCBKYW51YXJ5IDI1LCAyMDE1IDExOjA1IFBNClRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQpT dWJqZWN0OiBSZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lCiAKQm91cmtlIGJ1aWx0IG1hbnkg ZXhhbXBsZXMgb2YgaGlzIGVuZ2luZSBmb3IgdHJ1Y2tzLCBvdXRib2FyZCBtb3RvcnMsIGFuZCBh aXJjcmFmdC4gVGhleSBhbGwgd29ya2VkLCByYW4gZm9yIGh1bmRyZWRzIG9mIGhvdXJzIHdpdGgg bGl0dGxlIHdlYXIgdG8gYW55IHBhcnRzLCBhbmQgcHJvZHVjZWQgdGhlIGFkdmVydGlzZWQgaG9y c2Vwb3dlci4gT25lIG9mIHRoZSBhaXJjcmFmdCBlbmdpbmVzIGlzIGluIHRoZSBFQUEgbXVzZXVt LgpMaWtlIGFueSBlbmdpbmUgdGhlIHN0YXJ0IHVwIGNvc3RzIGdvaW5nIGludG8gcHJvZHVjdGlv biB3b3VsZCBiZSBhc3Ryb25vbWljYWwgYW5kIGZvciBhbiBhaXJjcmFmdCBlbmdpbmUgdGhlbiB0 aGVyZSBhcmUgY2VydGlmaWNhdGlvbiBjb3N0cy4gQWxsIGZvciBhIHNtYWxsIGRpbWluaXNoaW5n IG1hcmtldC4gU2FkIHRvIHNheSBpdCB3b24ndCBoYXBwZW4sIGJ1dCB0aGF0J3MgdGhlIHdheSBp dCBpcy4KIApSaWNrIEdpcmFyZApkbyBub3QgYXJjaGl2ZQogCk9uIFN1biwgSmFuIDI1LCAyMDE1 IGF0IDE6MDkgUE0sIHVuZG9jdG9yIDx1bmRvY3RvckBwdGQubmV0PiB3cm90ZToKUmVtZW1iZXIg YmFjayBpbiB0aGUgNTBzIG9yIDYwcyB3aGVuIHRoZSBXZW5rZWwgUm90YXJ5IGVuZ2luZSB3YXMg aW50cm9kdWNlZD8gT25lIHRyaWFuZ3VsYXIgcGlzdG9uIHdpdGggcm90YXJ5IHJhdGhlciB0aGFu IHJlY2lwcm9jYXRpbmcgbW90aW9uIGFuZCB2ZXJ5IGZldyBtb3ZpbmcgcGFydHM/CiAKR29vZCBp ZGVhIGFuZCBpdCBjb3VsZCBzcGluIHZlcnkgaGlnaCByZXZzLiBQcm9ibGVtIGlzLCB0aGV5IGNh bid0IGtlZXAgdGhlIHRpcHMgZnJvbSB3ZWFyaW5nIG9uIHRoZSB0cmlhbmd1bGFyIHBpc3Rvbiwg c28gdmVyeSBsaW1pdGVkIGFwcGxpY2F0aW9uIGluIHRoZSByZWFsIHdvcmxkLgogCkFsc28gcmVt ZW1iZXIgYSBjZXJhbWljIGVuZ2luZSBvbiB0aGUgZHJhd2luZyBib2FyZHMgd2hpY2ggd2FzIHRv IHJpdmFsIHNsaWNlZCBicmVhZCBmb3IgZ3JlYXRuZXNzLiBIYXZlbid0IGhlYXJkIGFueSBtb3Jl IGFib3V0IHRoYXQgb25lLiBUaGF0J3MgT0suIEp1c3Qga2VlcCBpbnZlbnRpbmcsIG1hbnkgb3V0 IHRoZXJlICAgICAgICAgICAgICAgICAgICAgICBpZGVhcyBoYXZlIGJlZW4gc3VjY2Vzc2Z1bC4K IApEYXZlIEt1bHAKQmV0aGxlaGVtLCBQQQogCkRvIG5vdCBhcmNoaXZlCiAKIApTZW50IGZyb20g bXkgVmVyaXpvbiBXaXJlbGVzcyA0RyBMVEUgU21hcnRwaG9uZQoKCi0tLS0tLS0tIE9yaWdpbmFs IG1lc3NhZ2UgLS0tLS0tLS0KRnJvbTogQ2hhcmxpZSBFbmdsYW5kCkRhdGU6MDEvMjUvMjAxNSAx OjQ4IFBNIChHTVQtMDU6MDApClRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQpTdWJqZWN0OiBS ZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lCiAKLS0+IEtvbGItTGlzdCBtZXNzYWdlIHBvc3Rl ZCBieTogQ2hhcmxpZSBFbmdsYW5kIDxjZWVuZ2xhbmQ3QGdtYWlsLmNvbT4KCk9uIDEvMjUvMjAx NSAxMToxOCBBTSwgd2lsbGlhbSBzdWxsaXZhbiB3cm90ZToKPiAtLT4gS29sYi1MaXN0IG1lc3Nh Z2UgcG9zdGVkIGJ5OiB3aWxsaWFtIHN1bGxpdmFuIDx3aWxsaWFtdHN1bGxpdmFuQGF0dC5uZXQ+ Cj4KPiAgICBDbGljayBvbiB2YXJpb3VzIHN0dWZmIGluIHRoaXMgbGluay4gIE15IGJyb3RoZXIg c2VudCBpdCB0byBtZSwgdGhpbmtpbmcgSSdkIGJlIGludGVyZXN0ZWQuICBXaXRoIFJvdGF4IGRy b3BwaW5nIHRoZSBzbWFsbCAyLXN0cm9rZXMsIHRoZXJlIGlzIGEgbmVlZCBmb3IgcmVwbGFjZW1l bnRzLiAgVGhlIHdlaWdodCB0byBIUCByYXRpbyBsb29rcyBwcmV0dHkgZ29vZC4gIERvZXMgYW55 b25lIGhhdmUgYW55IGV4cGVyaWVuY2UvY29tbWVudHMgb24gdGhpcyBvbmU/Cj4KPiBodHRwOi8v d3d3LmJvdXJrZS1lbmdpbmUuY29tL2FuaQo+Cj4KSSdkIHN1Z2dlc3QgZmluZGluZyBhbiBpbmRl cGVuZGVudCBlbmdpbmVlcmluZyBldmFsdWF0aW9uLiBNeSB0aG91Z2h0czogCkNvbnNpZGVyIGhv dyBzZXZlcmUgdGhlIGltYmFsYW5jZSB3aWxsIGJlIHdpdGggYm90aCBwaXN0b25zIG1vdmluZyB0 aGUgCnNhbWUgZGlyZWN0aW9uLCB0aGVuIGhvdyBtdWNoIHRoZSBjb3VudGVyd2VpZ2h0IHdpbGwg d2VpZ2ggdG8gY291bnRlcmFjdCAKdGhhdCBmb3JjZSAod2l0aG91dCBjb250cmlidXRpbmcgYW55 IHBvd2VyKS4gVGhlbiBjb25zaWRlciBob3cgbG9uZyBhCnNsaWRpbmcgbGluZS1jb250YWN0IHNs aWRpbmcgYmVhcmluZyBpcyBnb2luZyB0byBsYXN0IHdoZW4gc3ViamVjdGVkIHRvIAp0aG9zZSBm b3JjZXMuIFRoZSBjbGFpbSBpcyAxLzQgcG91bmQgKDAuMjUgbGIpIHBlciBocC9oci4gVGhpcyBp cyBiZXR0ZXIgCmJ5IGFib3V0IDMwJSB0aGFuIHRoZSBtb3N0IGVmZmljaWVudCBpbnRlcm5hbCBj b21idXN0aW9uIGVuZ2luZSBldmVyIApidWlsdCwgYW5kIGl0J3Mgc3RpbGwgYSAyIHN0cm9rZSBl bmdpbmUuIElzbid0IGl0IGEgYml0IHN0cmFuZ2UgdGhhdCBhIApkZXNpZ24gdGhhdCdzIGJlZW4g YXJvdW5kIGxvbmcgZW5vdWdoIGZvciB0aGUgcGF0ZW50cyB0byBleHBpcmUsIGFuZCBpcyAKc3Vw ZXIgY2xlYW4sIGFuZCBiZWF0cyB0aGUgYmVzdCB0ZWNoIG91dCB0aGVyZSBieSAzMCUsIGhhc24n dCB0YWtlbiBvdmVyIApldmVyeSBlbmdpbmUgbWFya2V0IG9uIHRoZSBwbGFuZXQ/ICBBbmQgaXQg dXNlcyAnZGV0b25hdGlvbicgdG8gZXh0cmFjdCAKbW9yZSBlbmVyZ3kgZnJvbSB0aGUgZnVlbD8g V2hhdCBoYXBwZW5zIHRvIGEgcGlzdG9uIHdoZW4geW91IGhhdmUgCmRldG9uYXRpb24gaW4gdGhl IGNvbWJ1c3Rpb24gY2hhbWJlcj8gKEFuc3dlciBoZWxwOiBub3RoaW5nIGdvb2QuKQoKQ3VycmVu dCB0ZWNobm9sb2d5IGluIDQgc3Ryb2tlcyBjYW4gY29tZSBwcmV0dHkgY2xvc2UgdG8gdGhlIHNh bWUgCnBvd2VyL3dlaWdodCByYXRpbyBhcyBvbGQgdGVjaCAyIHN0cm9rZXMuIEp1c3QgbmVlZCBz b21lb25lIHRvIG1ha2UgdGhlbSAKYXZhaWxhYmxlIGF0IGFuIGFmZm9yZGFibGUgcHJpY2VvbGIt TGlzdCIgdGFyZ2V0PSJfYmxhbmsiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/ S29sYi1MaXN0aHR0cDovL3d3dy5tYXRyb25pY3MuY29tPT09PT09PT09PT09PT09PT09CgoKCgoK IAotLSAKIAogCkJlbGlldmUgdGhvc2Ugd2hvIGFyZSBzZWVraW5nIHRoZSB0cnV0aCwgZG91YnQg dGhvc2Ugd2hvIGZpbmQgaXQuCi1BbmRyZSBHaWRlCgoKCmhyZWY9Imh0dHA6Ly93d3cubWF0cm9u aWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0Ij5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2 aWdhdG9yP0tvbGItTGlzdApocmVmPSJodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20iPmh0dHA6 Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpocmVmPSJodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29u dHJpYnV0aW9uIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vYwogCgoKCgoKXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAg ICAgICAgIC0gVGhlIEtvbGItTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmlj cyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRp bGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAm IERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBt dWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2 aWdhdG9yP0tvbGItTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1Mg V0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRo ZSBXZWIgRm9ydW1zIQpfLT0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpf LT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQpf LT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT0gICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPSAgIC0tPiBodHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cgo ________________________________________________________________________________
Date: Jan 27, 2015
R3JlYXQgcnVuZG93biwgQ2hhcmxpZS4gVGhhbmtzIQoKClNlbnQgZnJvbSBteSBWZXJpem9uIFdp cmVsZXNzIDRHIExURSBTbWFydHBob25lCgo8ZGl2Pi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2Ug LS0tLS0tLS08L2Rpdj48ZGl2PkZyb206IENoYXJsaWUgRW5nbGFuZCA8Y2VlbmdsYW5kN0BnbWFp bC5jb20+IDwvZGl2PjxkaXY+RGF0ZTowMS8yNy8yMDE1ICAxMToyNSBBTSAgKEdNVC0wNTowMCkg PC9kaXY+PGRpdj5Ubzoga29sYi1saXN0QG1hdHJvbmljcy5jb20gPC9kaXY+PGRpdj5TdWJqZWN0 OiBSZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lIDwvZGl2PjxkaXY+CjwvZGl2PkhlcmUncyBv bmUgcHJvamVjdCB0aGF0IHNob3VsZCBnZXQgdGhlIGF0dGVudGlvbiBvZiBLb2xiIGRyaXZlcnM6 Cmh0dHA6Ly93d3cuaHlicmlkY2Fycy5jb20vbWF6ZGEtY291bGQtcHJvZHVjZS1tYXpkYTItZXYt d2l0aC1yb3RhcnktcmFuZ2UtZXh0ZW5kZXIvCgpUaGVyZSdzIGFsc28gYSByZXBlYXRlZGx5IHJl c3VyZmFjaW5nIHJ1bW9yIHRoYXQgdGhleSB3aWxsIHJlLWludHJvZHVjZSB0aGUgUlg3L1JYOCBz cG9ydHMgY2FyIHdpdGggYSAxNlggcm90YXJ5IGVuZ2luZSAodGhlIGVuZ2luZSBpcyBhbHJlYWR5 IGRldmVsb3BlZCkuCmh0dHA6Ly93d3cubWF6ZGEuY29tL3N0b3JpZXMvcm90YXJ5LzE2eC8KCkNo YXJsaWUKCk9uIDEvMjcvMjAxNSAxMDowNCBBTSwgdW5kb2N0b3Igd3JvdGU6Ckdvb2QgdG8gaGVh ciBmcm9tIHlvdSwgUGF0LiBIb3cgYXJlIHRoaW5ncyBhY3Jvc3MgdGhlIHBvbmQ/ICBTdGlsbCBn cm91bmRlZD8gIEkgYW0gYW5kIEkgZG9uJ3QgbGlrZSBpdC4gSG9wZSB0byBjaGFuZ2UgdGhhdCBl YXJseSBmbHlpbmcgc2Vhc29uLiAKClNvcnJ5IEkgbWlzc3BlbGxlZCBXYW5rZWwuIE1lbW9yeSBn ZXRzIGZ1enp5IGZyb20geWVhcnMgYWdvLiAKCkhlcmIsIEkgd2FzIGF3YXJlIE1hemRhIHVzZWQg dGhlIFdhbmtlbDsgZG8gdGhleSBvciBhbnlvbmUgc3RpbGw/CgpEYXZlIEt1bHAKQmV0aGxlaGVt LCBQQQoKRG8gbm90IGFyY2hpdmUKCgpTZW50IGZyb20gbXkgVmVyaXpvbiBXaXJlbGVzcyA0RyBM VEUgU21hcnRwaG9uZQoKCi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS0KRnJvbTog SGVyYgpEYXRlOjAxLzI3LzIwMTUgODoyOSBBTSAoR01ULTA1OjAwKQpUbzoga29sYi1saXN0QG1h dHJvbmljcy5jb20KU3ViamVjdDogUmU6IEtvbGItTGlzdDogQm91cmtlIGVuZ2luZQoKUGF0Cgog IElmIG1lbW9yeSBzZXJ2ZXMsSSBiZWxpZXZlLCBNYXpkYSBoYXMgc29sdmVkIG1vc3Qgb2YgdGhl IHRlY2huaWNhbCBwcm9ibGVtcyB3aXRoIHRoZSBXYW5rZWwuCgogIGFuIGVhcmx5IHByb2JsZW0s IGZyb20gbWVtb3J5LCBjYW1lIGFib3V0IHdoZW4gdGhlIGZhY3RvcnkgZGVjaWRlZCB0byB1c2Ug c3RhbmRhcmQgYXV0byBlbmdpbmUgb2lsIHRvIGx1YnJpY2F0ZSB0aGUgYXBleCAgICAgICBzZWFs cy4uLmFuZCBzaWRlIHNlYWxzLi4uICBUaGF0IHJlc3VsdGVkIGluIHNvbWUgbmVjZXNzYXJ5ICBv aWwgYnVybmluZyBhbmQgYSBidWlsZCB1cCBvZiBjYXJib24uLi4gIE9uZSBjYW4gaW1hZ2luZSB0 aGUgZGViYXRlIHdoZW4gZW5naW5lZXJzIHN1Z2dlc3QgdGhhdCBsb3cgYXNoIHR3byBzdHJva2Ug b2lsIGJlIHVzZWQuLi4/IAoKICBUaGUgcG93ZXIgYW5kIGZ1ZWwgY29uc3VtcHRpb24gY2FtZSBm cm9tIHRoZSB0d28gc3Ryb2tlIGRlc2lnbi4uLiBGcm9tIG15IG1lbW9yeS4uLiBIZXJiIAoKICAg Ck9uIDAxLzI3LzIwMTUgMDU6NDcgQU0sIFBhdHJpY2sgTGFkZCB3cm90ZToKPDxSZW1lbWJlciBi YWNrIGluIHRoZSA1MHMgb3IgNjBzIHdoZW4gdGhlIFdlbmtlbCBSb3RhcnkgZW5naW5lIHdhcyAg ICAgICAgICAgICAgICAgaW50cm9kdWNlZD8gT25lIHRyaWFuZ3VsYXIgcGlzdG9uIHdpdGggcm90 YXJ5IHJhdGhlciB0aGFuIHJlY2lwcm9jYXRpbmcgbW90aW9uIGFuZCB2ZXJ5IGZldyBtb3Zpbmcg cGFydHM/Pj4KIApJIGhhZCBhIGNhciB3aXRoIGEgV2Fua2VsIGVuZ2luZS4gQSBiZWF1dGlmdWwg Y2FyIHdpdGggdGhlIHN1cGVyIHNtb290aCBub24gICAgICAgICAgICAgICAgIHZpYnJhdGluZyBl bmdpbmUuSXQgd291bGQgcnVuIGhhcHBpbHkgb24gdmVyeSBsb3cgZ3JhZGUgcGV0cm9sIGJ1dCBv bmx5IGdhdmUgYWJvdXQgMjVtaWxlcyB0byB0aGUgZ2FsbG9uLiBBY2NlbGVyYXRpb24gd2FzIG5v dGhpbmcgdG8gd3JpdGUgaG9tZSBhYm91dCBidXQgdGhlIG5vbiAgICAgICAgICAgICAgICAgcmVj aXByb2NhdGluZyBkZXNpZ24gbWFkZSBmb3Igc3VwZXIgc21vb3RoIHJ1bm5pbmcuIEFzIHlvdSBz YXkgdGhlIHdlYXJpbmcgb2YgdGhlIGNlcmFtaWMgdGlwcyBvZiB0aGUgdGhyZWUgcG9pbnQgcm90 b3Igd2FzIGl0cyBkb3duZmFsbC4gR3JlYXQgcGl0eS4gSSByZW1lbWJlciB0aGF0IGl0IGhhZCBh IG1hbnVhbCBnZWFyIHNoaWZ0IGJ1dCBubyBjbHV0Y2ggcGVkYWwuIFRoZSAgICAgICAgICAgICAg ICAgY2x1dGNoIHdhcyBvcGVyYXRlZCBlbGVjdHJpY2FsbHkgd2hlbiB5b3UgaGVsZCB0aGUga25v YiBvbiB0aGUgdG9wIG9mIHRoZSBnZWFyIHN0aWNrLiBTbyB0aGUgYWN0IG9mIGNoYW5naW5nIGdl YXIgYXV0b21hdGljYWxseSBvcGVyYXRlZCB0aGUgY2x1dGNoLiBJdCBoYWQgYSBkZXZpY2Ugd2hp Y2ggbWF0Y2hlZCAgdGhlIGVuZ2luZSBzcGVlZCB0byB0aGUgd2hlZWwgc3BlZWQgd2hlbiB5b3Ug Y2hhbmdlZCBnZWFyLgpUaGVyZSB3ZXJlIHNldmVyYWwgV2Fua2VsIGFlcm8gZW5naW5lcyBiZWlu ZyBwbGF5ZWQgd2l0aCBhIGZldyB5ZWFycyBhZ28gYnV0IHRoZXkgc2VlbSB0byBoYXZlIGZhbGxl biBieSB0aGUgd2F5c2lkZS4gUGl0eSwgaXQgaGFkIHN1Y2ggcHJvbWlzZS4KIApQYXQKIApGcm9t OiBSaWNoYXJkIEdpcmFyZApTZW50OiBTdW5kYXksIEphbnVhcnkgMjUsIDIwMTUgMTE6MDUgUE0K VG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29tClN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IEJvdXJr ZSBlbmdpbmUKIApCb3Vya2UgYnVpbHQgbWFueSBleGFtcGxlcyBvZiBoaXMgZW5naW5lIGZvciB0 cnVja3MsIG91dGJvYXJkIG1vdG9ycywgYW5kIGFpcmNyYWZ0LiBUaGV5IGFsbCAgICAgICAgICAg ICAgICAgd29ya2VkLCByYW4gZm9yIGh1bmRyZWRzIG9mIGhvdXJzIHdpdGggbGl0dGxlIHdlYXIg dG8gYW55IHBhcnRzLCBhbmQgcHJvZHVjZWQgdGhlIGFkdmVydGlzZWQgaG9yc2Vwb3dlci4gT25l ICAgICAgICAgICAgICAgICBvZiB0aGUgYWlyY3JhZnQgZW5naW5lcyBpcyBpbiB0aGUgRUFBIG11 c2V1bS4KTGlrZSBhbnkgZW5naW5lIHRoZSBzdGFydCB1cCBjb3N0cyBnb2luZyBpbnRvIHByb2R1 Y3Rpb24gd291bGQgYmUgYXN0cm9ub21pY2FsIGFuZCBmb3IgYW4gYWlyY3JhZnQgZW5naW5lIHRo ZW4gdGhlcmUgYXJlIGNlcnRpZmljYXRpb24gY29zdHMuIEFsbCBmb3IgYSBzbWFsbCBkaW1pbmlz aGluZyBtYXJrZXQuIFNhZCB0byBzYXkgaXQgd29uJ3QgaGFwcGVuLCAgICAgICAgICAgICAgICAg ICBidXQgdGhhdCdzIHRoZSB3YXkgaXQgaXMuCiAKUmljayBHaXJhcmQKZG8gbm90IGFyY2hpdmUK IApPbiBTdW4sIEphbiAyNSwgMjAxNSBhdCAxOjA5IFBNLCB1bmRvY3RvciA8dW5kb2N0b3JAcHRk Lm5ldD4gd3JvdGU6ClJlbWVtYmVyIGJhY2sgaW4gdGhlIDUwcyBvciA2MHMgd2hlbiB0aGUgV2Vu a2VsIFJvdGFyeSBlbmdpbmUgd2FzIGludHJvZHVjZWQ/IE9uZSB0cmlhbmd1bGFyIHBpc3RvbiB3 aXRoIHJvdGFyeSByYXRoZXIgdGhhbiByZWNpcHJvY2F0aW5nIG1vdGlvbiBhbmQgdmVyeSBmZXcg bW92aW5nIHBhcnRzPwogCkdvb2QgaWRlYSBhbmQgaXQgY291bGQgc3BpbiB2ZXJ5IGhpZ2ggcmV2 cy4gUHJvYmxlbSBpcywgdGhleSBjYW4ndCBrZWVwIHRoZSB0aXBzIGZyb20gd2VhcmluZyBvbiB0 aGUgdHJpYW5ndWxhciBwaXN0b24sIHNvIHZlcnkgbGltaXRlZCBhcHBsaWNhdGlvbiBpbiB0aGUg cmVhbCB3b3JsZC4KIApBbHNvIHJlbWVtYmVyIGEgY2VyYW1pYyBlbmdpbmUgb24gdGhlIGRyYXdp bmcgYm9hcmRzIHdoaWNoIHdhcyB0byByaXZhbCBzbGljZWQgYnJlYWQgZm9yIGdyZWF0bmVzcy4g SGF2ZW4ndCBoZWFyZCBhbnkgbW9yZSBhYm91dCB0aGF0IG9uZS4gVGhhdCdzIE9LLiBKdXN0IGtl ZXAgaW52ZW50aW5nLCBtYW55IG91dCB0aGVyZSBpZGVhcyBoYXZlIGJlZW4gc3VjY2Vzc2Z1bC4K IApEYXZlIEt1bHAKQmV0aGxlaGVtLCBQQQogCkRvIG5vdCBhcmNoaXZlCiAKIApTZW50IGZyb20g bXkgVmVyaXpvbiBXaXJlbGVzcyA0RyBMVEUgU21hcnRwaG9uZQoKCi0tLS0tLS0tIE9yaWdpbmFs IG1lc3NhZ2UgLS0tLS0tLS0KRnJvbTogQ2hhcmxpZSBFbmdsYW5kCkRhdGU6MDEvMjUvMjAxNSAx OjQ4IFBNIChHTVQtMDU6MDApClRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQpTdWJqZWN0OiBS ZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lCiAKLS0+IEtvbGItTGlzdCBtZXNzYWdlIHBvc3Rl ZCBieTogQ2hhcmxpZSBFbmdsYW5kIDxjZWVuZ2xhbmQ3QGdtYWlsLmNvbT4KCk9uIDEvMjUvMjAx NSAxMToxOCBBTSwgd2lsbGlhbSBzdWxsaXZhbiB3cm90ZToKPiAtLT4gS29sYi1MaXN0IG1lc3Nh Z2UgcG9zdGVkIGJ5OiB3aWxsaWFtIHN1bGxpdmFuIDx3aWxsaWFtdHN1bGxpdmFuQGF0dC5uZXQ+ Cj4KPiAgICBDbGljayBvbiB2YXJpb3VzIHN0dWZmIGluIHRoaXMgbGluay4gIE15IGJyb3RoZXIg c2VudCBpdCB0byBtZSwgdGhpbmtpbmcgSSdkIGJlIGludGVyZXN0ZWQuICBXaXRoIFJvdGF4IGRy b3BwaW5nIHRoZSBzbWFsbCAyLXN0cm9rZXMsIHRoZXJlIGlzIGEgbmVlZCBmb3IgcmVwbGFjZW1l bnRzLiAgVGhlIHdlaWdodCB0byBIUCByYXRpbyBsb29rcyBwcmV0dHkgZ29vZC4gICAgICAgICAg ICAgICAgICAgICAgICAgICAgRG9lcyBhbnlvbmUgaGF2ZSBhbnkgZXhwZXJpZW5jZS9jb21tZW50 cyBvbiB0aGlzIG9uZT8KPgo+IGh0dHA6Ly93d3cuYm91cmtlLWVuZ2luZS5jb20vYW5pCj4KPgpJ J2Qgc3VnZ2VzdCBmaW5kaW5nIGFuIGluZGVwZW5kZW50IGVuZ2luZWVyaW5nIGV2YWx1YXRpb24u IE15IHRob3VnaHRzOiAKQ29uc2lkZXIgaG93IHNldmVyZSB0aGUgaW1iYWxhbmNlIHdpbGwgYmUg d2l0aCBib3RoIHBpc3RvbnMgbW92aW5nIHRoZSAKc2FtZSBkaXJlY3Rpb24sIHRoZW4gaG93IG11 Y2ggdGhlIGNvdW50ZXJ3ZWlnaHQgd2lsbCB3ZWlnaCB0byBjb3VudGVyYWN0IAp0aGF0IGZvcmNl ICh3aXRob3V0IGNvbnRyaWJ1dGluZyBhbnkgcG93ZXIpLiBUaGVuIGNvbnNpZGVyIGhvdyBsb25n IGEgCnNsaWRpbmcgbGluZS1jb250YWN0IHNsaWRpbmcgYmVhcmluZyBpcyBnb2luZyAgICAgICAg ICAgICAgICAgICAgICAgICAgIHRvIGxhc3Qgd2hlbiBzdWJqZWN0ZWQgdG8gCnRob3NlIGZvcmNl cy4gVGhlIGNsYWltIGlzIDEvNCBwb3VuZCAoMC4yNSBsYikgcGVyIGhwL2hyLiBUaGlzIGlzIGJl dHRlciAKYnkgYWJvdXQgMzAlIHRoYW4gdGhlIG1vc3QgZWZmaWNpZW50IGludGVybmFsIGNvbWJ1 c3Rpb24gZW5naW5lIGV2ZXIgCmJ1aWx0LCBhbmQgaXQncyBzdGlsbCBhIDIgc3Ryb2tlIGVuZ2lu ZS4gSXNuJ3QgICAgICAgICAgICAgICAgICAgICAgICAgICBpdCBhIGJpdCBzdHJhbmdlIHRoYXQg YSAKZGVzaWduIHRoYXQncyBiZWVuIGFyb3VuZCBsb25nIGVub3VnaCBmb3IgdGhlIHBhdGVudHMg dG8gZXhwaXJlLCBhbmQgaXMgCnN1cGVyIGNsZWFuLCBhbmQgYmVhdHMgdGhlIGJlc3QgdGVjaCBv dXQgdGhlcmUgYnkgMzAlLCBoYXNuJ3QgdGFrZW4gb3ZlciAKZXZlcnkgZW5naW5lIG1hcmtldCBv biB0aGUgcGxhbmV0PyAgQW5kIGl0IHVzZXMgJ2RldG9uYXRpb24nIHRvIGV4dHJhY3QgCm1vcmUg ZW5lcmd5IGZyb20gdGhlIGZ1ZWw/IFdoYXQgaGFwcGVucyB0byBhIHBpc3RvbiB3aGVuIHlvdSBo YXZlIApkZXRvbmF0aW9uIGluIHRoZSBjb21idXN0aW9uIGNoYW1iZXI/IChBbnN3ZXIgaGVscDog bm90aGluZyBnb29kLikKCkN1cnJlbnQgdGVjaG5vbG9neSBpbiA0IHN0cm9rZXMgY2FuIGNvbWUg ICAgICAgICAgICAgICAgICAgICAgICAgICBwcmV0dHkgY2xvc2UgdG8gdGhlIHNhbWUgCnBvd2Vy L3dlaWdodCByYXRpbyBhcyBvbGQgdGVjaCAyIHN0cm9rZXMuIEp1c3QgbmVlZCBzb21lb25lIHRv IG1ha2UgdGhlbSAKYXZhaWxhYmxlIGF0IGFuIGFmZm9yZGFibGUgcHJpY2VvbGItTGlzdCIgdGFy Z2V0PSJfYmxhbmsiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0 aHR0cDovL3d3dy5tYXRyb25pY3MuY29tPT09PT09PT09PT09PT09PT09CgoKCgoKIAotLSAKIAog CkJlbGlldmUgdGhvc2Ugd2hvIGFyZSBzZWVraW5nIHRoZSB0cnV0aCwgZG91YnQgdGhvc2Ugd2hv IGZpbmQgaXQuCi1BbmRyZSBHaWRlCgoKCgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgLSBUaGUgS29sYi1M aXN0IEVtYWlsIEZvcnVtIC0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2 aWdhdG9yIHRvIGJyb3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0 IFVuL1N1YnNjcmlwdGlvbiwKXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJy b3dzZSwgQ2hhdCwgRkFRLApfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOgpfLT0K Xy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0Cl8t PQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNh bWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpf LT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAg ICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5 b3VyIGdlbmVyb3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1N YXR0IERyYWxsZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNv bS9jb250cmlidXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0KCg= ________________________________________________________________________________
Date: Jan 27, 2015
Subject: Wankel
TWF5IGhhdmUgc2FpZCBnb29kIGJ5ZSB0byB0aGUgT2xkIEdpcmwsIGJ1dCB5b3Ugc3RpbGwgaGF2 ZSBhbiBhdmlhdGlvbiBhdHRpdHVkZSwgUGF0LsKgCgpBbGwgdGhlIGJlc3QuwqAKCgpTZW50IGZy b20gbXkgVmVyaXpvbiBXaXJlbGVzcyA0RyBMVEUgU21hcnRwaG9uZQoKPGRpdj4tLS0tLS0tLSBP cmlnaW5hbCBtZXNzYWdlIC0tLS0tLS0tPC9kaXY+PGRpdj5Gcm9tOiBQYXRyaWNrIExhZGQgPHBh dHJpY2tqbGFkZEBob3RtYWlsLmNvbT4gPC9kaXY+PGRpdj5EYXRlOjAxLzI3LzIwMTUgIDExOjU3 IEFNICAoR01ULTA1OjAwKSA8L2Rpdj48ZGl2PlRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbSA8 L2Rpdj48ZGl2PlN1YmplY3Q6IEtvbGItTGlzdDogV2Fua2VsIDwvZGl2PjxkaXY+CjwvZGl2Pkkg d2FzIGF3YXJlIE1hemRhIHVzZWQgdGhlIFdhbmtlbDsgZG8gdGhleSBvciBhbnlvbmUgc3RpbGwK IApIaSwgTWF6ZGEgdXNlZCB0byBtYXJrZXQgYSBzcG9ydHkgY2FyIGNhbGxlZCB0aGUgU3B5ZGVy LiBObyBpZGVhIGlmIHRoZXkgc3RpbGwgZG8gc28uIE15IGRheXMgZm9yIHNwb3J0cyBjYXJzIGFy ZSB3ZWxsIG92ZXIgYWx0aG91Z2ggSSBkaWQgZHJpdmUvZmx5ICh3aGF0ZXZlcikgYSBob3ZlcmNy YWZ0IGR1cmluZyB0aGUgc3VtbWVyLiBHcmVhdCBmdW4uCk5vIGZseWluZyBJIGFtIGFmcmFpZC4g TXkgYmFjayBmaW5hbGx5IGRpY3RhdGVkIHRoYXQgSSBjYW4gbm8gbG9uZ2VyIGRvIHRoZSBwdWxs ZXkgaGF1bGV5IGludm9sdmVkIGluIGdyb3VuZCBoYW5kbGluZywgY2FycnlpbmcgZnVlbCwgY3Jh d2xpbmcgYXJvdW5kIGRvaW5nIERJYHMsIGRyYWdnaW5nIHRoZSBwbGFuZSBvdXQgb2YgdGhlIGhh bmdhciBldGMuc28gdGhlIG9sZCBnaXJsIGZpbmFsbHkgaGFkIHRvIGdvLiBIYXZlIGEgYGZsaWdo dGAgaW4gYSAgNzM3IFNpbXVsYXRvciBib29rZWQuIFRoYXQgcHJvbWlzZXMgdG8gYmUgZnVuLkFs c28gdHJ5aW5nIHRvIGp1c3RpZnkgdGhlIGNvc3Qgb2YgYSByaWRlIGluIGEgU3BpdGZpcmUsIGJ1 dCBpdCBpcyB2ZXJ5IHN0ZWVwLiBUaGUgcnVsZXMgaGF2ZSBjaGFuZ2VkIGhlcmUgaW4gdGhlIGxh c3QgZmV3IG1vbnRocy5UaGUgb25seSB3YXkgYSBTcGl0IGZsaWdodCBjb3VsZCBiZSBhcnJhbmdl ZCB3YXMgaWYgeW91IHdlcmUgYSBmdWxsIFBQTCBob2xkZXIgYW5kIGVuZ2FnZWQgaW4gY29udmVy c2lvbiBvciBgZnVydGhlciB0cmFpbmluZy4gTm93IHRoZSBhdXRob3JpdGllcyBoYXZlIHJ1bGVk IHRoYXQgaWYgeW91IGNhbiBwdXQgdGhlIG1vbmV5IGRvd24geW91IGNhbiBmbHkuIEkgZmxldyBh IFAgNTFkIHxNdXN0YW5nIGZvciBhbiBob3VyIGF0IEtpc3NpbW1lZSBtYW55IHllYXJzIGFnbyBh bHNvIFQ2LCAgYW5kIGEgSmV0IFByb3Zvc3QgdHJhaW5lciBhbmQgdmFyaW91cyBhbXBoaWJpYW5z IGluY2x1ZGluZyBvbmUgcmlnaHQgZG93biB0byB0aGUgd2F0ZXIgaW4gdGhlIEJheSBvZiAgSXNs YW5kcyBpbiBOb3J0aCBJc2xhbmQgTmV3IFplYWxhbmQuLiBBIGpldCBmaWdodGVyIGF0IE1hcmF0 aG9uIGRvd24gaW4gdGhlIEtleXMgYW5kIGEgc2VhcGxhbmUgYWxvbmcgdGhlIEF1c3RyYWxpYW4g Y29hc3QgYW5kIHRvdWNoIGRvd24gaW4gU3lkbmV5IGhhcmJvdXIgTm90IGRvbmUgdG9vIGJhZGx5 ICwgYWxsIG9uIGEgdWx0cmFsaWdodCBsaWNlbnNlIGJ1dCBJIHJlYWxseSAgd291bGQgbGlrZSB0 byBnZXQgaW4gYSBTcGl0LiBIZWlnaCBIbyAuUGF0CiAKRnJvbTogdW5kb2N0b3IKU2VudDogVHVl c2RheSwgSmFudWFyeSAyNywgMjAxNSA0OjA0IFBNClRvOiBIZXJiIDsga29sYi1saXN0QG1hdHJv bmljcy5jb20KU3ViamVjdDogUmU6IEtvbGItTGlzdDogQm91cmtlIGVuZ2luZQogCkdvb2QgdG8g aGVhciBmcm9tIHlvdSwgUGF0LiBIb3cgYXJlIHRoaW5ncyBhY3Jvc3MgdGhlIHBvbmQ/ICBTdGls bCBncm91bmRlZD8gIEkgYW0gYW5kIEkgZG9uJ3QgbGlrZSBpdC4gSG9wZSB0byBjaGFuZ2UgdGhh dCBlYXJseSBmbHlpbmcgc2Vhc29uLgogClNvcnJ5IEkgbWlzc3BlbGxlZCBXYW5rZWwuIE1lbW9y eSBnZXRzIGZ1enp5IGZyb20geWVhcnMgYWdvLgogCkhlcmIsIEkgd2FzIGF3YXJlIE1hemRhIHVz ZWQgdGhlIFdhbmtlbDsgZG8gdGhleSBvciBhbnlvbmUgc3RpbGw/CiAKRGF2ZSBLdWxwCkJldGhs ZWhlbSwgUEEKIApEbyBub3QgYXJjaGl2ZQogCiAKU2VudCBmcm9tIG15IFZlcml6b24gV2lyZWxl c3MgNEcgTFRFIFNtYXJ0cGhvbmUKCgotLS0tLS0tLSBPcmlnaW5hbCBtZXNzYWdlIC0tLS0tLS0t CkZyb206IEhlcmIKRGF0ZTowMS8yNy8yMDE1IDg6MjkgQU0gKEdNVC0wNTowMCkKVG86IGtvbGIt bGlzdEBtYXRyb25pY3MuY29tClN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IEJvdXJrZSBlbmdpbmUK IApQYXQKCiAgSWYgbWVtb3J5IHNlcnZlcyxJIGJlbGlldmUsIE1hemRhIGhhcyBzb2x2ZWQgbW9z dCBvZiB0aGUgdGVjaG5pY2FsIHByb2JsZW1zIHdpdGggdGhlIFdhbmtlbC4KCiAgYW4gZWFybHkg cHJvYmxlbSwgZnJvbSBtZW1vcnksIGNhbWUgYWJvdXQgd2hlbiB0aGUgZmFjdG9yeSBkZWNpZGVk IHRvIHVzZSBzdGFuZGFyZCBhdXRvIGVuZ2luZSBvaWwgdG8gbHVicmljYXRlIHRoZSBhcGV4IHNl YWxzLi4uYW5kIHNpZGUgc2VhbHMuLi4gIFRoYXQgcmVzdWx0ZWQgaW4gc29tZSBuZWNlc3Nhcnkg IG9pbCBidXJuaW5nIGFuZCBhIGJ1aWxkIHVwIG9mIGNhcmJvbi4uLiAgT25lIGNhbiBpbWFnaW5l IHRoZSBkZWJhdGUgd2hlbiBlbmdpbmVlcnMgc3VnZ2VzdCB0aGF0IGxvdyBhc2ggdHdvIHN0cm9r ZSBvaWwgYmUgdXNlZC4uLj8gCgogIFRoZSBwb3dlciBhbmQgZnVlbCBjb25zdW1wdGlvbiBjYW1l IGZyb20gdGhlIHR3byBzdHJva2UgZGVzaWduLi4uID5Gcm9tIG15IG1lbW9yeS4uLiBIZXJiIAoK ICAgCk9uIDAxLzI3LzIwMTUgMDU6NDcgQU0sIFBhdHJpY2sgTGFkZCB3cm90ZToKPDxSZW1lbWJl ciBiYWNrIGluIHRoZSA1MHMgb3IgNjBzIHdoZW4gdGhlIFdlbmtlbCBSb3RhcnkgZW5naW5lIHdh cyBpbnRyb2R1Y2VkPyBPbmUgdHJpYW5ndWxhciBwaXN0b24gd2l0aCByb3RhcnkgcmF0aGVyIHRo YW4gcmVjaXByb2NhdGluZyBtb3Rpb24gYW5kIHZlcnkgZmV3IG1vdmluZyBwYXJ0cz8+PgogCkkg aGFkIGEgY2FyIHdpdGggYSBXYW5rZWwgZW5naW5lLiBBIGJlYXV0aWZ1bCBjYXIgd2l0aCB0aGUg c3VwZXIgc21vb3RoIG5vbiB2aWJyYXRpbmcgZW5naW5lLkl0IHdvdWxkIHJ1biBoYXBwaWx5IG9u IHZlcnkgbG93IGdyYWRlIHBldHJvbCBidXQgb25seSBnYXZlIGFib3V0IDI1bWlsZXMgdG8gdGhl IGdhbGxvbi4gQWNjZWxlcmF0aW9uIHdhcyBub3RoaW5nIHRvIHdyaXRlIGhvbWUgYWJvdXQgYnV0 IHRoZSBub24gcmVjaXByb2NhdGluZyBkZXNpZ24gbWFkZSBmb3Igc3VwZXIgc21vb3RoIHJ1bm5p bmcuIEFzIHlvdSBzYXkgdGhlIHdlYXJpbmcgb2YgdGhlIGNlcmFtaWMgdGlwcyBvZiAgICB0aGUg dGhyZWUgcG9pbnQgcm90b3Igd2FzIGl0cyBkb3duZmFsbC4gR3JlYXQgcGl0eS4gSSByZW1lbWJl ciB0aGF0IGl0IGhhZCBhIG1hbnVhbCBnZWFyIHNoaWZ0IGJ1dCBubyBjbHV0Y2ggcGVkYWwuIFRo ZSBjbHV0Y2ggd2FzIG9wZXJhdGVkIGVsZWN0cmljYWxseSB3aGVuIHlvdSBoZWxkIHRoZSBrbm9i IG9uIHRoZSB0b3Agb2YgdGhlIGdlYXIgc3RpY2suIFNvIHRoZSBhY3Qgb2YgY2hhbmdpbmcgZ2Vh ciBhdXRvbWF0aWNhbGx5IG9wZXJhdGVkIHRoZSBjbHV0Y2guIEl0IGhhZCBhIGRldmljZSB3aGlj aCBtYXRjaGVkICB0aGUgZW5naW5lIHNwZWVkIHRvIHRoZSB3aGVlbCBzcGVlZCB3aGVuIHlvdSBj aGFuZ2VkIGdlYXIuClRoZXJlIHdlcmUgc2V2ZXJhbCBXYW5rZWwgYWVybyBlbmdpbmVzIGJlaW5n IHBsYXllZCB3aXRoIGEgZmV3IHllYXJzIGFnbyBidXQgdGhleSBzZWVtIHRvIGhhdmUgZmFsbGVu IGJ5IHRoZSB3YXlzaWRlLiBQaXR5LCBpdCBoYWQgc3VjaCBwcm9taXNlLgogClBhdAogCkZyb206 IFJpY2hhcmQgR2lyYXJkClNlbnQ6IFN1bmRheSwgSmFudWFyeSAyNSwgMjAxNSAxMTowNSBQTQpU bzoga29sYi1saXN0QG1hdHJvbmljcy5jb20KU3ViamVjdDogUmU6IEtvbGItTGlzdDogQm91cmtl IGVuZ2luZQogCkJvdXJrZSBidWlsdCBtYW55IGV4YW1wbGVzIG9mIGhpcyBlbmdpbmUgZm9yIHRy dWNrcywgb3V0Ym9hcmQgbW90b3JzLCBhbmQgYWlyY3JhZnQuIFRoZXkgYWxsIHdvcmtlZCwgcmFu IGZvciBodW5kcmVkcyBvZiBob3VycyB3aXRoIGxpdHRsZSB3ZWFyIHRvIGFueSBwYXJ0cywgYW5k IHByb2R1Y2VkIHRoZSBhZHZlcnRpc2VkIGhvcnNlcG93ZXIuIE9uZSBvZiB0aGUgYWlyY3JhZnQg ZW5naW5lcyBpcyBpbiB0aGUgRUFBIG11c2V1bS4KTGlrZSBhbnkgZW5naW5lIHRoZSBzdGFydCB1 cCBjb3N0cyBnb2luZyBpbnRvIHByb2R1Y3Rpb24gd291bGQgYmUgYXN0cm9ub21pY2FsIGFuZCBm b3IgYW4gYWlyY3JhZnQgZW5naW5lIHRoZW4gdGhlcmUgYXJlIGNlcnRpZmljYXRpb24gY29zdHMu ICAgIEFsbCBmb3IgYSBzbWFsbCBkaW1pbmlzaGluZyBtYXJrZXQuIFNhZCB0byBzYXkgaXQgd29u J3QgaGFwcGVuLCBidXQgdGhhdCdzIHRoZSB3YXkgaXQgaXMuCiAKUmljayBHaXJhcmQKZG8gbm90 IGFyY2hpdmUKIApPbiBTdW4sIEphbiAyNSwgMjAxNSBhdCAxOjA5IFBNLCB1bmRvY3RvciA8dW5k b2N0b3JAcHRkLm5ldD4gd3JvdGU6ClJlbWVtYmVyIGJhY2sgaW4gdGhlIDUwcyBvciA2MHMgd2hl biB0aGUgV2Vua2VsIFJvdGFyeSBlbmdpbmUgd2FzIGludHJvZHVjZWQ/IE9uZSB0cmlhbmd1bGFy IHBpc3RvbiB3aXRoIHJvdGFyeSByYXRoZXIgdGhhbiByZWNpcHJvY2F0aW5nIG1vdGlvbiBhbmQg dmVyeSBmZXcgbW92aW5nIHBhcnRzPwogCkdvb2QgaWRlYSBhbmQgaXQgY291bGQgc3BpbiB2ZXJ5 IGhpZ2ggcmV2cy4gUHJvYmxlbSBpcywgdGhleSBjYW4ndCBrZWVwIHRoZSB0aXBzIGZyb20gd2Vh cmluZyBvbiB0aGUgdHJpYW5ndWxhciBwaXN0b24sIHNvIHZlcnkgbGltaXRlZCBhcHBsaWNhdGlv biBpbiB0aGUgcmVhbCB3b3JsZC4KIApBbHNvIHJlbWVtYmVyIGEgY2VyYW1pYyBlbmdpbmUgb24g dGhlIGRyYXdpbmcgYm9hcmRzIHdoaWNoIHdhcyB0byByaXZhbCAgICAgIHNsaWNlZCBicmVhZCBm b3IgZ3JlYXRuZXNzLiBIYXZlbid0IGhlYXJkIGFueSBtb3JlIGFib3V0IHRoYXQgb25lLiBUaGF0 J3MgT0suIEp1c3Qga2VlcCBpbnZlbnRpbmcsIG1hbnkgb3V0IHRoZXJlIGlkZWFzIGhhdmUgYmVl biBzdWNjZXNzZnVsLgogCkRhdmUgS3VscApCZXRobGVoZW0sIFBBCiAKRG8gbm90IGFyY2hpdmUK IAogClNlbnQgZnJvbSBteSBWZXJpem9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lCgoKLS0t LS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLQpGcm9tOiBDaGFybGllIEVuZ2xhbmQKRGF0 ZTowMS8yNS8yMDE1IDE6NDggUE0gKEdNVC0wNTowMCkKVG86IGtvbGItbGlzdEBtYXRyb25pY3Mu Y29tClN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IEJvdXJrZSBlbmdpbmUKIAotLT4gS29sYi1MaXN0 IG1lc3NhZ2UgcG9zdGVkIGJ5OiBDaGFybGllIEVuZ2xhbmQgPGNlZW5nbGFuZDdAZ21haWwuY29t PgoKT24gMS8yNS8yMDE1IDExOjE4IEFNLCB3aWxsaWFtIHN1bGxpdmFuIHdyb3RlOgo+IC0tPiBL b2xiLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IHdpbGxpYW0gc3VsbGl2YW4gPHdpbGxpYW10c3Vs bGl2YW5AYXR0Lm5ldD4KPgo+ICAgIENsaWNrIG9uIHZhcmlvdXMgc3R1ZmYgaW4gdGhpcyBsaW5r LiAgTXkgYnJvdGhlciBzZW50IGl0IHRvIG1lLCB0aGlua2luZyBJJ2QgYmUgaW50ZXJlc3RlZC4g IFdpdGggUm90YXggZHJvcHBpbmcgdGhlIHNtYWxsIDItc3Ryb2tlcywgdGhlcmUgaXMgYSBuZWVk IGZvciByZXBsYWNlbWVudHMuICBUaGUgd2VpZ2h0IHRvIEhQIHJhdGlvIGxvb2tzIHByZXR0eSBn b29kLiAgRG9lcyBhbnlvbmUgaGF2ZSBhbnkgZXhwZXJpZW5jZS9jb21tZW50cyBvbiB0aGlzIG9u ZT8KPgo+IGh0dHA6Ly93d3cuYm91cmtlLWVuZ2luZS5jb20vYW5pCj4KPgpJJ2Qgc3VnZ2VzdCBm aW5kaW5nIGFuIGluZGVwZW5kZW50IGVuZ2luZWVyaW5nIGV2YWx1YXRpb24uIE15IHRob3VnaHRz OiAKQ29uc2lkZXIgaG93IHNldmVyZSB0aGUgaW1iYWxhbmNlIHdpbGwgYmUgd2l0aCBib3RoIHBp c3RvbnMgbW92aW5nIHRoZSAKc2FtZSBkaXJlY3Rpb24sIHRoZW4gaG93IG11Y2ggdGhlIGNvdW50 ZXJ3ZWlnaHQgd2lsbCB3ZWlnaCB0byBjb3VudGVyYWN0IAp0aGF0IGZvcmNlICh3aXRob3V0IGNv bnRyaWJ1dGluZyBhbnkgcG93ZXIpLiBUaGVuIGNvbnNpZGVyIGhvdyBsb25nIGEKc2xpZGluZyBs aW5lLWNvbnRhY3Qgc2xpZGluZyBiZWFyaW5nIGlzIGdvaW5nIHRvIGxhc3Qgd2hlbiBzdWJqZWN0 ZWQgdG8gCnRob3NlIGZvcmNlcy4gVGhlIGNsYWltIGlzIDEvNCBwb3VuZCAoMC4yNSBsYikgcGVy IGhwL2hyLiBUaGlzIGlzIGJldHRlciAKYnkgYWJvdXQgMzAlIHRoYW4gdGhlIG1vc3QgZWZmaWNp ZW50IGludGVybmFsIGNvbWJ1c3Rpb24gZW5naW5lIGV2ZXIgCmJ1aWx0LCBhbmQgaXQncyBzdGls bCBhIDIgc3Ryb2tlIGVuZ2luZS4gSXNuJ3QgaXQgYSBiaXQgc3RyYW5nZSB0aGF0IGEgCmRlc2ln biB0aGF0J3MgYmVlbiBhcm91bmQgbG9uZyBlbm91Z2ggZm9yIHRoZSBwYXRlbnRzIHRvIGV4cGly ZSwgYW5kIGlzIApzdXBlciBjbGVhbiwgYW5kIGJlYXRzIHRoZSBiZXN0IHRlY2ggb3V0IHRoZXJl IGJ5IDMwJSwgaGFzbid0IHRha2VuIG92ZXIgCmV2ZXJ5IGVuZ2luZSBtYXJrZXQgb24gdGhlIHBs YW5ldD8gIEFuZCBpdCB1c2VzICdkZXRvbmF0aW9uJyB0byBleHRyYWN0IAptb3JlIGVuZXJneSBm cm9tIHRoZSBmdWVsPyBXaGF0IGhhcHBlbnMgdG8gYSBwaXN0b24gd2hlbiB5b3UgaGF2ZSAKZGV0 b25hdGlvbiBpbiB0aGUgY29tYnVzdGlvbiBjaGFtYmVyPyAoQW5zd2VyIGhlbHA6IG5vdGhpbmcg Z29vZC4pCgpDdXJyZW50IHRlY2hub2xvZ3kgaW4gNCBzdHJva2VzIGNhbiBjb21lIHByZXR0eSBj bG9zZSB0byB0aGUgc2FtZSAKcG93ZXIvd2VpZ2h0IHJhdGlvIGFzIG9sZCB0ZWNoIDIgc3Ryb2tl cy4gSnVzdCBuZWVkIHNvbWVvbmUgdG8gbWFrZSB0aGVtIAphdmFpbGFibGUgYXQgYW4gYWZmb3Jk YWJsZSBwcmljZW9sYi1MaXN0IiB0YXJnZXQ9Il9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3Mu Y29tL05hdmlnYXRvcj9Lb2xiLUxpc3RodHRwOi8vd3d3Lm1hdHJvbmljcy5jb209PT09PT09PT09 PT09PT09PT0KCgoKCgogCi0tIAogCiAKQmVsaWV2ZSB0aG9zZSB3aG8gYXJlIHNlZWtpbmcgdGhl IHRydXRoLCBkb3VidCB0aG9zZSB3aG8gZmluZCBpdC4KLUFuZHJlIEdpZGUKCgoKaHJlZj0iaHR0 cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Lb2xiLUxpc3QiPmh0dHA6Ly93d3cubWF0 cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0CmhyZWY9Imh0dHA6Ly9mb3J1bXMubWF0cm9u aWNzLmNvbSI+aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCmhyZWY9Imh0dHA6Ly93d3cubWF0 cm9uaWNzLmNvbS9jb250cmlidXRpb24iPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jCgoKCgoK CmhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0Ij5odHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGItTGlzdApocmVmPSJodHRwOi8vZm9y dW1zLm1hdHJvbmljcy5jb20iPmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpocmVmPSJodHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5j b20vYwrvv71+77+9AwoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRoZSBLb2xiLUxpc3QgRW1haWwg Rm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8g YnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2Ny aXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0 LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT0gICAtLT4g aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Lb2xiLUxpc3QKXy09Cl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8t PSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQpfLT0gU2FtZSBncmVhdCBj b250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyEKXy09Cl8tPSAgIC0tPiBo dHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAgICAtIExp c3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJv dXMgc3VwcG9ydCEKXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxl LCBMaXN0IEFkbWluLgpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1 dGlvbgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PQoK ________________________________________________________________________________
Date: Jan 28, 2015
Undoctor =94 you should know that your posts come thru as gibberish. At least on a Mac. > On Jan 27, 2015, at 12:09 PM, undoctor wrote: > > PGh0bWw+PGhlYWQ+PG1ldGEgaHR0cC1lcXVpdj0iQ29udGVudC1UeXBlIiBjb250ZW50PSJ0ZX h0 L2h0bWw7IGNoYXJzZXQ9VVRGLTgiPjwvaGVhZD48Ym9keSA+PGRpdj5HcmVhdCBydW5kb3duLC BD aGFybGllLiBUaGFua3MhPC9kaXY+PGRpdj48YnI+PC9kaXY+PGRpdj48YnI+PC9kaXY+PGRpdj 48 ZGl2IHN0eWxlPSJmb250LXNpemU6OXB4O2NvbG9yOiM1NzU3NTciPlNlbnQgZnJvbSBteSBWZX Jp em9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lPC9kaXY+PC9kaXY+PGJyPjxicj48ZGl2Pi 0t LS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS08L2Rpdj48ZGl2PkZyb206IENoYXJsaW Ug RW5nbGFuZCA8Y2VlbmdsYW5kN0BnbWFpbC5jb20+IDwvZGl2PjxkaXY+RGF0ZTowMS8yNy8yMD E1 ICAxMToyNSBBTSAgKEdNVC0wNTowMCkgPC9kaXY+PGRpdj5Ubzoga29sYi1saXN0QG1hdHJvbm lj cy5jb20gPC9kaXY+PGRpdj5TdWJqZWN0OiBSZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lID wv ZGl2PjxkaXY+PGJyPjwvZGl2PgogICAgPGRpdiBjbGFzcz0ibW96LWNpdGUtcHJlZml4Ij5IZX Jl J3Mgb25lIHByb2plY3QgdGhhdCBzaG91bGQgZ2V0IHRoZQogICAgICBhdHRlbnRpb24gb2YgS2 9s YiBkcml2ZXJzOjxicj4KPGEgY2xhc3M9Im1vei10eHQtbGluay1mcmVldGV4dCIgaHJlZj0iaH R0 cDovL3d3dy5oeWJyaWRjYXJzLmNvbS9tYXpkYS1jb3VsZC1wcm9kdWNlLW1hemRhMi1ldi13aX Ro LXJvdGFyeS1yYW5nZS1leHRlbmRlci8iPmh0dHA6Ly93d3cuaHlicmlkY2Fycy5jb20vbWF6ZG Et Y291bGQtcHJvZHVjZS1tYXpkYTItZXYtd2l0aC1yb3RhcnktcmFuZ2UtZXh0ZW5kZXIvPC9hPj xi cj4KICAgICAgPGJyPgogICAgICBUaGVyZSdzIGFsc28gYSByZXBlYXRlZGx5IHJlc3VyZmFjaW 5n IHJ1bW9yIHRoYXQgdGhleSB3aWxsCiAgICAgIHJlLWludHJvZHVjZSB0aGUgUlg3L1JYOCBzcG 9y dHMgY2FyIHdpdGggYSAxNlggcm90YXJ5IGVuZ2luZSAodGhlCiAgICAgIGVuZ2luZSBpcyBhbH Jl YWR5IGRldmVsb3BlZCkuPGJyPgogICAgICA8YSBjbGFzcz0ibW96LXR4dC1saW5rLWZyZWV0ZX h0 IiBocmVmPSJodHRwOi8vd3d3Lm1hemRhLmNvbS9zdG9yaWVzL3JvdGFyeS8xNngvIj5odHRwOi 8v d3d3Lm1hemRhLmNvbS9zdG9yaWVzL3JvdGFyeS8xNngvPC9hPjxicj4KICAgICAgPGJyPgogIC Ag ICBDaGFybGllPGJyPgogICAgICA8YnI+CiAgICAgIE9uIDEvMjcvMjAxNSAxMDowNCBBTSwgdW 5k b2N0b3Igd3JvdGU6PGJyPgogICAgPC9kaXY+CiAgICA8YmxvY2txdW90ZSBjaXRlPSJtaWQ6bz k1 aXBzbGwwdHNvYmcybWRrNWRnbHdkLjE0MjIzNzQ2OTc1MDhAZW1haWwuYW5kcm9pZC5jb20iIH R5 cGU9ImNpdGUiPgogICAgICA8bWV0YSBodHRwLWVxdWl2PSJDb250ZW50LVR5cGUiIGNvbnRlbn Q9 InRleHQvaHRtbDsgY2hhcnNldD11dGYtOCI+CiAgICAgIDxkaXY+R29vZCB0byBoZWFyIGZyb2 0g eW91LCBQYXQuIEhvdyBhcmUgdGhpbmdzIGFjcm9zcyB0aGUgcG9uZD8KICAgICAgICAmbmJzcD tT dGlsbCBncm91bmRlZD8gJm5ic3A7SSBhbSBhbmQgSSBkb24ndCBsaWtlIGl0LiBIb3BlIHRvIG No YW5nZSB0aGF0CiAgICAgICAgZWFybHkgZmx5aW5nIHNlYXNvbi4mbmJzcDs8L2Rpdj4KICAgIC Ag PGRpdj48YnI+CiAgICAgIDwvZGl2PgogICAgICA8ZGl2PlNvcnJ5IEkgbWlzc3BlbGxlZCBXYW 5r ZWwuIE1lbW9yeSBnZXRzIGZ1enp5IGZyb20geWVhcnMgYWdvLiZuYnNwOzwvZGl2PgogICAgIC A8 ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+SGVyYiwgSSB3YXMgYXdhcmUgTWF6ZG Eg dXNlZCB0aGUgV2Fua2VsOyBkbyB0aGV5IG9yIGFueW9uZQogICAgICAgIHN0aWxsPzwvZGl2Pg og ICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+RGF2ZSBLdWxwPC9kaXY+Ci Ag ICAgIDxkaXY+QmV0aGxlaGVtLCBQQTwvZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaX Y+ CiAgICAgIDxkaXY+RG8gbm90IGFyY2hpdmU8L2Rpdj4KICAgICAgPGRpdj48YnI+CiAgICAgID wv ZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+CiAgICAgICAgPG Rp diBzdHlsZT0iZm9udC1zaXplOjlweDtjb2xvcjojNTc1NzU3Ij5TZW50IGZyb20gbXkgVmVyaX pv bgogICAgICAgICAgV2lyZWxlc3MgNEcgTFRFIFNtYXJ0cGhvbmU8L2Rpdj4KICAgICAgPC9kaX Y+ CiAgICAgIDxicj4KICAgICAgPGJyPgogICAgICA8ZGl2Pi0tLS0tLS0tIE9yaWdpbmFsIG1lc3 Nh Z2UgLS0tLS0tLS08L2Rpdj4KICAgICAgPGRpdj5Gcm9tOiBIZXJiIDxoZXJiZ2hAbmN0Yy5jb2 0+ IDwvaGVyYmdoQG5jdGMuY29tPjwvZGl2PgogICAgICA8ZGl2PkRhdGU6MDEvMjcvMjAxNSA4Oj I5 IEFNIChHTVQtMDU6MDApIDwvZGl2PgogICAgICA8ZGl2PlRvOiA8YSBjbGFzcz0ibW96LXR4dC 1s aW5rLWFiYnJldmlhdGVkIiBocmVmPSJtYWlsdG86a29sYi1saXN0QG1hdHJvbmljcy5jb20iPm tv bGItbGlzdEBtYXRyb25pY3MuY29tPC9hPiA8L2Rpdj4KICAgICAgPGRpdj5TdWJqZWN0OiBSZT og S29sYi1MaXN0OiBCb3Vya2UgZW5naW5lIDwvZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC 9k aXY+CiAgICAgIFBhdDxicj4KICAgICAgPGJyPgogICAgICAmbmJzcDsgSWYgbWVtb3J5IHNlcn Zl cyxJIGJlbGlldmUsIE1hemRhIGhhcyBzb2x2ZWQgbW9zdCBvZiB0aGUKICAgICAgdGVjaG5pY2 Fs IHByb2JsZW1zIHdpdGggdGhlIFdhbmtlbC48YnI+CiAgICAgIDxicj4KICAgICAgJm5ic3A7IG Fu IGVhcmx5IHByb2JsZW0sIGZyb20gbWVtb3J5LCBjYW1lIGFib3V0IHdoZW4gdGhlIGZhY3Rvcn kK ICAgICAgZGVjaWRlZCB0byB1c2Ugc3RhbmRhcmQgYXV0byBlbmdpbmUgb2lsIHRvIGx1YnJpY2 F0 ZSB0aGUgYXBleAogICAgICBzZWFscy4uLmFuZCBzaWRlIHNlYWxzLi4uJm5ic3A7IFRoYXQgcm Vz dWx0ZWQgaW4gc29tZSBuZWNlc3NhcnkmbmJzcDsgb2lsCiAgICAgIGJ1cm5pbmcgYW5kIGEgYn Vp bGQgdXAgb2YgY2FyYm9uLi4uJm5ic3A7IE9uZSBjYW4gaW1hZ2luZSB0aGUgZGViYXRlCiAgIC Ag IHdoZW4gZW5naW5lZXJzIHN1Z2dlc3QgdGhhdCBsb3cgYXNoIHR3byBzdHJva2Ugb2lsIGJlIH Vz ZWQuLi4/IDxicj4KICAgICAgPGJyPgogICAgICAmbmJzcDsgVGhlIHBvd2VyIGFuZCBmdWVsIG Nv bnN1bXB0aW9uIGNhbWUgZnJvbSB0aGUgdHdvIHN0cm9rZQogICAgICBkZXNpZ24uLi4gRnJvbS Bt eSBtZW1vcnkuLi4gSGVyYiA8YnI+CiAgICAgIDxicj4KICAgICAgJm5ic3A7Jm5ic3A7IDxicj 4K ICAgICAgPGRpdiBjbGFzcz0ibW96LWNpdGUtcHJlZml4Ij5PbiAwMS8yNy8yMDE1IDA1OjQ3IE FN LCBQYXRyaWNrIExhZGQKICAgICAgICB3cm90ZTo8YnI+CiAgICAgIDwvZGl2PgogICAgICA8Ym xv Y2txdW90ZSBjaXRlPSJtaWQ6QkFZMTY3LURTNTA2RUM3QTRCRjhDMjA2RUI1MDk5Q0RFMzIwQH Bo eC5nYmwiIHR5cGU9ImNpdGUiPgogICAgICAgIDxkaXYgZGlyPSJsdHIiPgogICAgICAgICAgPG Rp diBzdHlsZT0iRk9OVC1TSVpFOiAxMnB0OyBGT05ULUZBTUlMWTogJ0NhbGlicmknOyBDT0xPUj oK ICAgICAgICAgICAgIzAwMDAwMCI+CiAgICAgICAgICAgIDxkaXY+PGZvbnQgZmFjZT0iVGltZX Mg TmV3IFJvbWFuIj4mbHQ7Jmx0O1JlbWVtYmVyIGJhY2sgaW4KICAgICAgICAgICAgICAgIHRoZS A1 MHMgb3IgNjBzIHdoZW4gdGhlIFdlbmtlbCBSb3RhcnkgZW5naW5lIHdhcwogICAgICAgICAgIC Ag ICAgaW50cm9kdWNlZD8gT25lIHRyaWFuZ3VsYXIgcGlzdG9uIHdpdGggcm90YXJ5IHJhdGhlcg og ICAgICAgICAgICAgICAgdGhhbiByZWNpcHJvY2F0aW5nIG1vdGlvbiBhbmQgdmVyeSBmZXcgbW 92 aW5nCiAgICAgICAgICAgICAgICBwYXJ0cz8mZ3Q7Jmd0OzwvZm9udD48L2Rpdj4KICAgICAgIC Ag ICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgICAgICAgICAgPGRpdj48Zm9udCBmYWNlPSJUaW1lcy BO ZXcgUm9tYW4iPkkgaGFkIGEgY2FyIHdpdGggYSBXYW5rZWwKICAgICAgICAgICAgICAgIGVuZ2 lu ZS4gQSBiZWF1dGlmdWwgY2FyIHdpdGggdGhlIHN1cGVyIHNtb290aCBub24KICAgICAgICAgIC Ag ICAgIHZpYnJhdGluZyBlbmdpbmUuSXQgd291bGQgcnVuIGhhcHBpbHkgb24gdmVyeSBsb3cgZ3 Jh ZGUKICAgICAgICAgICAgICAgIHBldHJvbCBidXQgb25seSBnYXZlIGFib3V0IDI1bWlsZXMgdG 8g dGhlIGdhbGxvbi4KICAgICAgICAgICAgICAgIEFjY2VsZXJhdGlvbiB3YXMgbm90aGluZyB0by B3 cml0ZSBob21lIGFib3V0IGJ1dCB0aGUgbm9uCiAgICAgICAgICAgICAgICByZWNpcHJvY2F0aW 5n IGRlc2lnbiBtYWRlIGZvciBzdXBlciBzbW9vdGggcnVubmluZy4gQXMKICAgICAgICAgICAgIC Ag IHlvdSBzYXkgdGhlIHdlYXJpbmcgb2YgdGhlIGNlcmFtaWMgdGlwcyBvZiB0aGUgdGhyZWUKIC Ag ICAgICAgICAgICAgIHBvaW50IHJvdG9yIHdhcyBpdHMgZG93bmZhbGwuIEdyZWF0IHBpdHkuIE kg cmVtZW1iZXIKICAgICAgICAgICAgICAgIHRoYXQgaXQgaGFkIGEgbWFudWFsIGdlYXIgc2hpZn Qg YnV0IG5vIGNsdXRjaCBwZWRhbC4gVGhlCiAgICAgICAgICAgICAgICBjbHV0Y2ggd2FzIG9wZX Jh dGVkIGVsZWN0cmljYWxseSB3aGVuIHlvdSBoZWxkIHRoZSBrbm9iCiAgICAgICAgICAgICAgIC Bv biB0aGUgdG9wIG9mIHRoZSBnZWFyIHN0aWNrLiBTbyB0aGUgYWN0IG9mIGNoYW5naW5nCiAgIC Ag ICAgICAgICAgICBnZWFyIGF1dG9tYXRpY2FsbHkgb3BlcmF0ZWQgdGhlIGNsdXRjaC4gSXQgaG Fk IGEgZGV2aWNlCiAgICAgICAgICAgICAgICB3aGljaCBtYXRjaGVkJm5ic3A7IHRoZSBlbmdpbm Ug c3BlZWQgdG8gdGhlIHdoZWVsIHNwZWVkIHdoZW4KICAgICAgICAgICAgICAgIHlvdSBjaGFuZ2 Vk IGdlYXIuPC9mb250PjwvZGl2PgogICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9IlRpbWVzIE 5l dyBSb21hbiI+VGhlcmUgd2VyZSBzZXZlcmFsIFdhbmtlbAogICAgICAgICAgICAgICAgYWVyby Bl bmdpbmVzIGJlaW5nIHBsYXllZCB3aXRoIGEgZmV3IHllYXJzIGFnbyBidXQgdGhleQogICAgIC Ag ICAgICAgICAgc2VlbSB0byBoYXZlIGZhbGxlbiBieSB0aGUgd2F5c2lkZS4gUGl0eSwgaXQgaG Fk IHN1Y2gKICAgICAgICAgICAgICAgIHByb21pc2UuPC9mb250PjwvZGl2PgogICAgICAgICAgIC A8 ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9IlRpbWVzIE5ldy BS b21hbiI+UGF0PC9mb250PjwvZGl2PgogICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogIC Ag ICAgICAgICA8ZGl2PgogICAgICAgICAgICAgIDxkaXYgc3R5bGU9IkZPTlQtU0laRTogc21hbG w7 IFRFWFQtREVDT1JBVElPTjogbm9uZTsKICAgICAgICAgICAgICAgIEZPTlQtRkFNSUxZOiAmcX Vv dDtDYWxpYnJpJnF1b3Q7OyBGT05ULVdFSUdIVDogbm9ybWFsOwogICAgICAgICAgICAgICAgQ0 9M T1I6ICMwMDAwMDA7IEZPTlQtU1RZTEU6IG5vcm1hbDsgRElTUExBWTogaW5saW5lIj48Yj5Gcm 9t OjwvYj4KICAgICAgICAgICAgICAgIDxhIG1vei1kby1ub3Qtc2VuZD0idHJ1ZSIgdGl0bGU9Im Fz bHNhLnJuZ0BnbWFpbC5jb20iIGhyZWY9Im1haWx0bzphc2xzYS5ybmdAZ21haWwuY29tIj5SaW No YXJkIEdpcmFyZDwvYT4gPC9kaXY+CiAgICAgICAgICAgICAgPGRpdiBzdHlsZT0iRk9OVDogMT Bw dCB0YWhvbWEiPgogICAgICAgICAgICAgICAgPGRpdiBzdHlsZT0iQkFDS0dST1VORDogI2Y1Zj Vm NSI+CiAgICAgICAgICAgICAgICAgIDxkaXY+PGI+U2VudDo8L2I+IFN1bmRheSwgSmFudWFyeS Ay NSwgMjAxNSAxMTowNSBQTTwvZGl2PgogICAgICAgICAgICAgICAgICA8ZGl2PjxiPlRvOjwvYj 4g PGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIiB0aXRsZT0ia29sYi1saXN0QG1hdHJvbmljcy5jb2 0i IGhyZWY9Im1haWx0bzprb2xiLWxpc3RAbWF0cm9uaWNzLmNvbSI+a29sYi1saXN0QG1hdHJvbm lj cy5jb208L2E+CiAgICAgICAgICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgICAgICA8ZG l2 PjxiPlN1YmplY3Q6PC9iPiBSZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lPC9kaXY+CiAgIC Ag ICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICA8ZG l2 PiZuYnNwOzwvZGl2PgogICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgPGRpdiBzdHlsZT 0i Rk9OVC1TSVpFOiBzbWFsbDsgVEVYVC1ERUNPUkFUSU9OOiBub25lOwogICAgICAgICAgICAgIE ZP TlQtRkFNSUxZOiAmcXVvdDtDYWxpYnJpJnF1b3Q7OyBGT05ULVdFSUdIVDogbm9ybWFsOwogIC Ag ICAgICAgICAgIENPTE9SOiAjMDAwMDAwOyBGT05ULVNUWUxFOiBub3JtYWw7IERJU1BMQVk6IG lu bGluZSI+CiAgICAgICAgICAgICAgPGRpdiBkaXI9Imx0ciI+Qm91cmtlIGJ1aWx0IG1hbnkgZX hh bXBsZXMgb2YgaGlzIGVuZ2luZQogICAgICAgICAgICAgICAgZm9yIHRydWNrcywgb3V0Ym9hcm Qg bW90b3JzLCBhbmQgYWlyY3JhZnQuIFRoZXkgYWxsCiAgICAgICAgICAgICAgICB3b3JrZWQsIH Jh biBmb3IgaHVuZHJlZHMgb2YgaG91cnMgd2l0aCBsaXR0bGUgd2VhciB0bwogICAgICAgICAgIC Ag ICAgYW55IHBhcnRzLCBhbmQgcHJvZHVjZWQgdGhlIGFkdmVydGlzZWQgaG9yc2Vwb3dlci4gT2 5l CiAgICAgICAgICAgICAgICBvZiB0aGUgYWlyY3JhZnQgZW5naW5lcyBpcyBpbiB0aGUgRUFBIG 11 c2V1bS4KICAgICAgICAgICAgICAgIDxkaXY+TGlrZSBhbnkgZW5naW5lIHRoZSBzdGFydCB1cC Bj b3N0cyBnb2luZyBpbnRvCiAgICAgICAgICAgICAgICAgIHByb2R1Y3Rpb24gd291bGQgYmUgYX N0 cm9ub21pY2FsIGFuZCBmb3IgYW4gYWlyY3JhZnQKICAgICAgICAgICAgICAgICAgZW5naW5lIH Ro ZW4gdGhlcmUgYXJlIGNlcnRpZmljYXRpb24gY29zdHMuIEFsbCBmb3IgYQogICAgICAgICAgIC Ag ICAgICBzbWFsbCBkaW1pbmlzaGluZyBtYXJrZXQuIFNhZCB0byBzYXkgaXQgd29uJ3QgaGFwcG Vu LAogICAgICAgICAgICAgICAgICBidXQgdGhhdCdzIHRoZSB3YXkgaXQgaXMuPC9kaXY+CiAgIC Ag ICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgPGRpdj5SaWNrIE dp cmFyZDwvZGl2PgogICAgICAgICAgICAgICAgPGRpdj5kbyBub3QgYXJjaGl2ZTwvZGl2PgogIC Ag ICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgIDxkaXYgY2xhc3M9ImdtYWlsX2V4dHJhIj 4K ICAgICAgICAgICAgICAgIDxkaXY+Jm5ic3A7PC9kaXY+CiAgICAgICAgICAgICAgICA8ZGl2IG Ns YXNzPSJnbWFpbF9xdW90ZSI+T24gU3VuLCBKYW4gMjUsIDIwMTUgYXQgMTowOQogICAgICAgIC Ag ICAgICAgICBQTSwgdW5kb2N0b3IgPHNwYW4gZGlyPSJsdHIiPiZsdDs8YSBtb3otZG8tbm90LX Nl bmQ9InRydWUiIGhyZWY9Im1haWx0bzp1bmRvY3RvckBwdGQubmV0IiB0YXJnZXQ9Il9ibGFuay I+ dW5kb2N0b3JAcHRkLm5ldDwvYT4mZ3Q7PC9zcGFuPgogICAgICAgICAgICAgICAgICB3cm90ZT o8 YnI+CiAgICAgICAgICAgICAgICAgIDxibG9ja3F1b3RlIGNsYXNzPSJnbWFpbF9xdW90ZSIgc3 R5 bGU9IlBBRERJTkctTEVGVDoKICAgICAgICAgICAgICAgICAgICAxZXg7IE1BUkdJTjogMHB4ID Bw eCAwcHggMC44ZXg7IEJPUkRFUi1MRUZUOiAjY2NjCiAgICAgICAgICAgICAgICAgICAgMXB4IH Nv bGlkIj4KICAgICAgICAgICAgICAgICAgICA8ZGl2PgogICAgICAgICAgICAgICAgICAgICAgPG Rp dj5SZW1lbWJlciBiYWNrIGluIHRoZSA1MHMgb3IgNjBzIHdoZW4gdGhlCiAgICAgICAgICAgIC Ag ICAgICAgICAgIFdlbmtlbCBSb3RhcnkgZW5naW5lIHdhcyBpbnRyb2R1Y2VkPyBPbmUKICAgIC Ag ICAgICAgICAgICAgICAgICAgdHJpYW5ndWxhciBwaXN0b24gd2l0aCByb3RhcnkgcmF0aGVyIH Ro YW4KICAgICAgICAgICAgICAgICAgICAgICAgcmVjaXByb2NhdGluZyBtb3Rpb24gYW5kIHZlcn kg ZmV3IG1vdmluZyBwYXJ0cz88L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+Jm5ic3 A7 PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICA8ZGl2Pkdvb2QgaWRlYSBhbmQgaXQgY291bG Qg c3BpbiB2ZXJ5IGhpZ2ggcmV2cy4KICAgICAgICAgICAgICAgICAgICAgICAgUHJvYmxlbSBpcy wg dGhleSBjYW4ndCBrZWVwIHRoZSB0aXBzIGZyb20KICAgICAgICAgICAgICAgICAgICAgICAgd2 Vh cmluZyBvbiB0aGUgdHJpYW5ndWxhciBwaXN0b24sIHNvIHZlcnkKICAgICAgICAgICAgICAgIC Ag ICAgICAgbGltaXRlZCBhcHBsaWNhdGlvbiBpbiB0aGUgcmVhbCB3b3JsZC4gPC9kaXY+CiAgIC Ag ICAgICAgICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgICAgIC Ag PGRpdj5BbHNvIHJlbWVtYmVyIGEgY2VyYW1pYyBlbmdpbmUgb24gdGhlIGRyYXdpbmcKICAgIC Ag ICAgICAgICAgICAgICAgICAgYm9hcmRzIHdoaWNoIHdhcyB0byByaXZhbCBzbGljZWQgYnJlYW Qg Zm9yCiAgICAgICAgICAgICAgICAgICAgICAgIGdyZWF0bmVzcy4gSGF2ZW4ndCBoZWFyZCBhbn kg bW9yZSBhYm91dCB0aGF0CiAgICAgICAgICAgICAgICAgICAgICAgIG9uZS4gVGhhdCdzIE9LLi BK dXN0IGtlZXAgaW52ZW50aW5nLCBtYW55IG91dAogICAgICAgICAgICAgICAgICAgICAgICB0aG Vy ZSBpZGVhcyBoYXZlIGJlZW4gc3VjY2Vzc2Z1bC4gPC9kaXY+CiAgICAgICAgICAgICAgICAgIC Ag ICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgPGRpdj5EYXZlIEt1bH A8 L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+QmV0aGxlaGVtLCBQQTwvZGl2PgogIC Ag ICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgICAgICAgICAgICAgICAgIC Ag IDxkaXY+RG8gbm90IGFyY2hpdmU8L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+Jm 5i c3A7PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgIC Ag ICAgICAgICAgICAgICAgPGRpdj4KICAgICAgICAgICAgICAgICAgICAgICAgPGRpdiBzdHlsZT 0i Rk9OVC1TSVpFOiA5cHg7IENPTE9SOiAjNTc1NzU3Ij5TZW50CiAgICAgICAgICAgICAgICAgIC Ag ICAgICAgZnJvbSBteSBWZXJpem9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lPC9kaXY+Ci Ag ICAgICAgICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+Ci Ag ICAgICAgICAgICAgICAgICAgICAgIDxkaXYgY2xhc3M9Img1Ij48YnI+CiAgICAgICAgICAgIC Ag ICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIDxkaXY+LS0tLS0tLS 0g T3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLTwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgIC Ag IDxkaXY+RnJvbTogQ2hhcmxpZSBFbmdsYW5kIDwvZGl2PgogICAgICAgICAgICAgICAgICAgIC Ag ICAgIDxkaXY+RGF0ZTowMS8yNS8yMDE1IDE6NDggUE0gKEdNVC0wNTowMCkgPC9kaXY+CiAgIC Ag ICAgICAgICAgICAgICAgICAgICAgPGRpdj5UbzogPGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIi Bo cmVmPSJtYWlsdG86a29sYi1saXN0QG1hdHJvbmljcy5jb20iIHRhcmdldD0iX2JsYW5rIj5rb2 xi LWxpc3RAbWF0cm9uaWNzLmNvbTwvYT4KICAgICAgICAgICAgICAgICAgICAgICAgICA8L2Rpdj 4K ICAgICAgICAgICAgICAgICAgICAgICAgICA8ZGl2PlN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IE Jv dXJrZSBlbmdpbmUgPC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzcD s8 L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgICAgICAtLSZndDsgS29sYi1MaXN0IG1lc3NhZ2 Ug cG9zdGVkIGJ5OiBDaGFybGllCiAgICAgICAgICAgICAgICAgICAgICAgICAgRW5nbGFuZCAmbH Q7 PGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIiBocmVmPSJtYWlsdG86Y2VlbmdsYW5kN0BnbWFpbC 5j b20iIHRhcmdldD0iX2JsYW5rIj5jZWVuZ2xhbmQ3QGdtYWlsLmNvbTwvYT4mZ3Q7PGJyPgogIC Ag ICAgICAgICAgICAgICAgICAgICAgIDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgICBPbi Ax LzI1LzIwMTUgMTE6MTggQU0sIHdpbGxpYW0gc3VsbGl2YW4gd3JvdGU6PGJyPgogICAgICAgIC Ag ICAgICAgICAgICAgICAgICZndDsgLS0mZ3Q7IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieT oK ICAgICAgICAgICAgICAgICAgICAgICAgICB3aWxsaWFtIHN1bGxpdmFuICZsdDs8YSBtb3otZG 8t bm90LXNlbmQ9InRydWUiIGhyZWY9Im1haWx0bzp3aWxsaWFtdHN1bGxpdmFuQGF0dC5uZXQiIH Rh cmdldD0iX2JsYW5rIj53aWxsaWFtdHN1bGxpdmFuQGF0dC5uZXQ8L2E+Jmd0Ozxicj4KICAgIC Ag ICAgICAgICAgICAgICAgICAgICAmZ3Q7PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIC Zn dDsmbmJzcDsmbmJzcDsmbmJzcDsgQ2xpY2sgb24gdmFyaW91cyBzdHVmZiBpbiB0aGlzIGxpbm su Jm5ic3A7CiAgICAgICAgICAgICAgICAgICAgICAgICAgTXkgYnJvdGhlciBzZW50IGl0IHRvIG 1l LCB0aGlua2luZyBJJ2QgYmUKICAgICAgICAgICAgICAgICAgICAgICAgICBpbnRlcmVzdGVkLi Zu YnNwOyBXaXRoIFJvdGF4IGRyb3BwaW5nIHRoZSBzbWFsbAogICAgICAgICAgICAgICAgICAgIC Ag ICAgIDItc3Ryb2tlcywgdGhlcmUgaXMgYSBuZWVkIGZvciByZXBsYWNlbWVudHMuJm5ic3A7Ci Ag ICAgICAgICAgICAgICAgICAgICAgICAgVGhlIHdlaWdodCB0byBIUCByYXRpbyBsb29rcyBwcm V0 dHkgZ29vZC4mbmJzcDsKICAgICAgICAgICAgICAgICAgICAgICAgICBEb2VzIGFueW9uZSBoYX Zl IGFueSBleHBlcmllbmNlL2NvbW1lbnRzIG9uCiAgICAgICAgICAgICAgICAgICAgICAgICAgdG hp cyBvbmU/PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgICZndDs8YnI+CiAgICAgICAgIC Ag ICAgICAgICAgICAgICAgJmd0OyA8YSBtb3otZG8tbm90LXNlbmQ9InRydWUiIGhyZWY9Imh0dH A6 Ly93d3cuYm91cmtlLWVuZ2luZS5jb20vYW5pIiB0YXJnZXQ9Il9ibGFuayI+aHR0cDovL3d3dy 5i b3Vya2UtZW5naW5lLmNvbS9hbmk8L2E+PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIC Zn dDs8YnI+CiAgICAgICAgICAgICAgICAgICAgICAgICAgJmd0Ozxicj4KICAgICAgICAgICAgIC Ag ICAgICAgICAgICBJJ2Qgc3VnZ2VzdCBmaW5kaW5nIGFuIGluZGVwZW5kZW50IGVuZ2luZWVyaW 5n CiAgICAgICAgICAgICAgICAgICAgICAgICAgZXZhbHVhdGlvbi4gTXkgdGhvdWdodHM6IDxicj 4K ICAgICAgICAgICAgICAgICAgICAgICAgICBDb25zaWRlciBob3cgc2V2ZXJlIHRoZSBpbWJhbG Fu Y2Ugd2lsbCBiZSB3aXRoCiAgICAgICAgICAgICAgICAgICAgICAgICAgYm90aCBwaXN0b25zIG 1v dmluZyB0aGUgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIHNhbWUgZGlyZWN0aW9uLC B0 aGVuIGhvdyBtdWNoIHRoZQogICAgICAgICAgICAgICAgICAgICAgICAgIGNvdW50ZXJ3ZWlnaH Qg d2lsbCB3ZWlnaCB0byBjb3VudGVyYWN0IDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgIC B0 aGF0IGZvcmNlICh3aXRob3V0IGNvbnRyaWJ1dGluZyBhbnkgcG93ZXIpLgogICAgICAgICAgIC Ag ICAgICAgICAgICAgIFRoZW4gY29uc2lkZXIgaG93IGxvbmcgYSA8YnI+CiAgICAgICAgICAgIC Ag ICAgICAgICAgICAgc2xpZGluZyBsaW5lLWNvbnRhY3Qgc2xpZGluZyBiZWFyaW5nIGlzIGdvaW 5n CiAgICAgICAgICAgICAgICAgICAgICAgICAgdG8gbGFzdCB3aGVuIHN1YmplY3RlZCB0byA8Yn I+ CiAgICAgICAgICAgICAgICAgICAgICAgICAgdGhvc2UgZm9yY2VzLiBUaGUgY2xhaW0gaXMgMS 80 IHBvdW5kICgwLjI1IGxiKQogICAgICAgICAgICAgICAgICAgICAgICAgIHBlciBocC9oci4gVG hp cyBpcyBiZXR0ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIGJ5IGFib3V0IDMwJS B0 aGFuIHRoZSBtb3N0IGVmZmljaWVudCBpbnRlcm5hbAogICAgICAgICAgICAgICAgICAgICAgIC Ag IGNvbWJ1c3Rpb24gZW5naW5lIGV2ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIG J1 aWx0LCBhbmQgaXQncyBzdGlsbCBhIDIgc3Ryb2tlIGVuZ2luZS4gSXNuJ3QKICAgICAgICAgIC Ag ICAgICAgICAgICAgICBpdCBhIGJpdCBzdHJhbmdlIHRoYXQgYSA8YnI+CiAgICAgICAgICAgIC Ag ICAgICAgICAgICAgZGVzaWduIHRoYXQncyBiZWVuIGFyb3VuZCBsb25nIGVub3VnaCBmb3IgdG hl CiAgICAgICAgICAgICAgICAgICAgICAgICAgcGF0ZW50cyB0byBleHBpcmUsIGFuZCBpcyA8Yn I+ CiAgICAgICAgICAgICAgICAgICAgICAgICAgc3VwZXIgY2xlYW4sIGFuZCBiZWF0cyB0aGUgYm Vz dCB0ZWNoIG91dCB0aGVyZQogICAgICAgICAgICAgICAgICAgICAgICAgIGJ5IDMwJSwgaGFzbi d0 IHRha2VuIG92ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIGV2ZXJ5IGVuZ2luZS Bt YXJrZXQgb24gdGhlIHBsYW5ldD8mbmJzcDsgQW5kIGl0CiAgICAgICAgICAgICAgICAgICAgIC Ag ICAgdXNlcyAnZGV0b25hdGlvbicgdG8gZXh0cmFjdCA8YnI+CiAgICAgICAgICAgICAgICAgIC Ag ICAgICAgbW9yZSBlbmVyZ3kgZnJvbSB0aGUgZnVlbD8gV2hhdCBoYXBwZW5zIHRvIGEKICAgIC Ag ICAgICAgICAgICAgICAgICAgICBwaXN0b24gd2hlbiB5b3UgaGF2ZSA8YnI+CiAgICAgICAgIC Ag ICAgICAgICAgICAgICAgZGV0b25hdGlvbiBpbiB0aGUgY29tYnVzdGlvbiBjaGFtYmVyPyAoQW 5z d2VyCiAgICAgICAgICAgICAgICAgICAgICAgICAgaGVscDogbm90aGluZyBnb29kLik8YnI+Ci Ag ICAgICAgICAgICAgICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIE N1 cnJlbnQgdGVjaG5vbG9neSBpbiA0IHN0cm9rZXMgY2FuIGNvbWUKICAgICAgICAgICAgICAgIC Ag ICAgICAgICBwcmV0dHkgY2xvc2UgdG8gdGhlIHNhbWUgPGJyPgogICAgICAgICAgICAgICAgIC Ag ICAgICAgIHBvd2VyL3dlaWdodCByYXRpbyBhcyBvbGQgdGVjaCAyIHN0cm9rZXMuIEp1c3QKIC Ag ICAgICAgICAgICAgICAgICAgICAgICBuZWVkIHNvbWVvbmUgdG8gbWFrZSB0aGVtIDxicj4KIC Ag ICAgICAgICAgICAgICAgICAgICAgICBhdmFpbGFibGUgYXQgYW4gYWZmb3JkYWJsZSBwcmljZW 9s Yi1MaXN0IgogICAgICAgICAgICAgICAgICAgICAgICAgIHRhcmdldD0iX2JsYW5rIiZndDs8YS Bt b3otZG8tbm90LXNlbmQ9InRydWUiIGNsYXNzPSJtb3otdHh0LWxpbmstZnJlZXRleHQiIGhyZW Y9 Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0aHR0cDovL3d3dy 5t YXRyb25pY3MuY29tPT09PT09PT09PT09PT09PT09Ij5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb2 0v TmF2aWdhdG9yP0tvbGItTGlzdGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbT09PT09PT09PT09PT 09 PT09PTwvYT48YnI+CiAgICAgICAgICAgICAgICAgICAgICAgICAgPGJyPgogICAgICAgICAgIC Ag ICAgICAgICAgICAgIDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgICA8YnI+CiAgICAgIC Ag ICAgICAgICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgPC9kaXY+CiAgIC Ag ICAgICAgICAgICAgICAgPC9kaXY+CiAgICAgICAgICAgICAgICAgIDwvYmxvY2txdW90ZT4KIC Ag ICAgICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgIC Ag PGJyIGNsZWFyPSJhbGwiPgogICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgIC Ag ICAgICAgICAgIC0tIDxicj4KICAgICAgICAgICAgICAgIDxkaXYgY2xhc3M9ImdtYWlsX3NpZ2 5h dHVyZSI+CiAgICAgICAgICAgICAgICAgIDxkaXYgZGlyPSJsdHIiPgogICAgICAgICAgICAgIC Ag ICAgIDxkaXY+Jm5ic3A7PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8L2 Rp dj4KICAgICAgICAgICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9ImFyaWFsLCBzYW5zLXNlcm lm Ij48c3BhbiBzdHlsZT0iRk9OVC1TSVpFOiAxM3B4Ij5CZWxpZXZlIHRob3NlIHdobyBhcmUKIC Ag ICAgICAgICAgICAgICAgICAgICAgICBzZWVraW5nIHRoZSB0cnV0aCwgZG91YnQgdGhvc2Ugd2 hv IGZpbmQgaXQuPC9zcGFuPjwvZm9udD48L2Rpdj4KICAgICAgICAgICAgICAgICAgICA8ZGl2Pj xm b250IGZhY2U9ImFyaWFsLCBzYW5zLXNlcmlmIj48c3BhbiBzdHlsZT0iRk9OVC1TSVpFOiAxM3 B4 Ij4tQW5kcmUgR2lkZTwvc3Bhbj48L2ZvbnQ+PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgPG Jy PgogICAgICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICAgIDwvZGl2PgogICAgIC Ag ICAgICAgIDwvZGl2PgogICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgIDwvZGl2PgogICAgIC Ag IDwvZGl2PgogICAgICA8L2Jsb2NrcXVvdGU+CiAgICA8L2Jsb2NrcXVvdGU+CiAgICA8YnI+Ci Ag CgoKPHByZT48Yj48Zm9udCBzaXplPSIyIiBjb2xvcj0iIzAwMDAwMCIgZmFjZT0iY291cmllci Bu ZXcsY291cmllciI+CgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT 09 PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgLSBUaGUgS29sYi1MaXN0IEVtYWlsIE Zv cnVtIC0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIG Jy b3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcm lw dGlvbiwKXy09IEFyY2hpdmUgU2VhcmNoICZhbXA7IERvd25sb2FkLCA3LURheSBCcm93c2UsIE No YXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC 0t Jmd0OyA8YSBocmVmPSJodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGItTG lz dCI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Lb2xiLUxpc3Q8L2E+Cl8tPQ pf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT 09 PT09PQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbW Ug Z3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT 0g ICAtLSZndDsgPGEgaHJlZj0iaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tIj5odHRwOi8vZm 9y dW1zLm1hdHJvbmljcy5jb208L2E+Cl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT 09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgLSBMaXN0IE Nv bnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIH N1 cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTG lz dCBBZG1pbi4KXy09ICAgLS0mZ3Q7IDxhIGhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS 9j b250cmlidXRpb24iPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb248L2E+Cl 8t PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT 09 PT09Cgo8L2ZvbnQ+PC9iPjwvcHJlPjwvYm9keT4 > > <http://www.matronics.com/Navigator?Kolb-List> <http://www.matronics.com/contribution> > ________________________________________________________________________________
Date: Jan 28, 2015
Subject: Re: Bourke engine
SHVoLCBuZXZlciBoZWFyZCB0aGF0IGJlZm9yZS4gQW55b25lIGVsc2UgaGF2aW5nIGEgcHJvYmxl bT8KClJ1c3MsIHdoYXQga2luZCBvZiBnaWJiZXJpc2g/CgoKU2VudCBmcm9tIG15IFZlcml6b24g V2lyZWxlc3MgNEcgTFRFIFNtYXJ0cGhvbmUKCjxkaXY+LS0tLS0tLS0gT3JpZ2luYWwgbWVzc2Fn ZSAtLS0tLS0tLTwvZGl2PjxkaXY+RnJvbToga2lubmUgcnVzcyA8cnVzc2s1MEBnbWFpbC5jb20+ IDwvZGl2PjxkaXY+RGF0ZTowMS8yOC8yMDE1ICAxMTo0NiBBTSAgKEdNVC0wNTowMCkgPC9kaXY+ PGRpdj5Ubzoga29sYi1saXN0QG1hdHJvbmljcy5jb20gPC9kaXY+PGRpdj5TdWJqZWN0OiBSZTog S29sYi1MaXN0OiBCb3Vya2UgZW5naW5lIDwvZGl2PjxkaXY+CjwvZGl2PlVuZG9jdG9yIOKAlCB5 b3Ugc2hvdWxkIGtub3cgdGhhdCB5b3VyIHBvc3RzIGNvbWUgdGhydSBhcyBnaWJiZXJpc2guIEF0 IGxlYXN0IG9uIGEgTWFjLgoKT24gSmFuIDI3LCAyMDE1LCBhdCAxMjowOSBQTSwgdW5kb2N0b3Ig PHVuZG9jdG9yQHB0ZC5uZXQ+IHdyb3RlOgoKUEdoMGJXdytQR2hsWVdRK1BHMWxkR0VnYUhSMGND MWxjWFZwZGowaVEyOXVkR1Z1ZEMxVWVYQmxJaUJqYjI1MFpXNTBQU0owWlhoMCBMMmgwYld3N0lH Tm9ZWEp6WlhROVZWUkdMVGdpUGp3dmFHVmhaRDQ4WW05a2VTQStQR1JwZGo1SGNtVmhkQ0J5ZFc1 a2IzZHVMQ0JEIGFHRnliR2xsTGlCVWFHRnVhM01oUEM5a2FYWStQR1JwZGo0OFluSStQQzlrYVhZ K1BHUnBkajQ4WW5JK1BDOWthWFkrUEdScGRqNDggWkdsMklITjBlV3hsUFNKbWIyNTBMWE5wZW1V Nk9YQjRPMk52Ykc5eU9pTTFOelUzTlRjaVBsTmxiblFnWm5KdmJTQnRlU0JXWlhKcCBlbTl1SUZk cGNtVnNaWE56SURSSElFeFVSU0JUYldGeWRIQm9iMjVsUEM5a2FYWStQQzlrYVhZK1BHSnlQanhp Y2o0OFpHbDJQaTB0IExTMHRMUzB0SUU5eWFXZHBibUZzSUcxbGMzTmhaMlVnTFMwdExTMHRMUzA4 TDJScGRqNDhaR2wyUGtaeWIyMDZJRU5vWVhKc2FXVWcgUlc1bmJHRnVaQ0E4WTJWbGJtZHNZVzVr TjBCbmJXRnBiQzVqYjIwK0lEd3ZaR2wyUGp4a2FYWStSR0YwWlRvd01TOHlOeTh5TURFMSBJQ0F4 TVRveU5TQkJUU0FnS0VkTlZDMHdOVG93TUNrZ1BDOWthWFkrUEdScGRqNVViem9nYTI5c1lpMXNh WE4wUUcxaGRISnZibWxqIGN5NWpiMjBnUEM5a2FYWStQR1JwZGo1VGRXSnFaV04wT2lCU1pUb2dT MjlzWWkxTWFYTjBPaUJDYjNWeWEyVWdaVzVuYVc1bElEd3YgWkdsMlBqeGthWFkrUEdKeVBqd3Za R2wyUGdvZ0lDQWdQR1JwZGlCamJHRnpjejBpYlc5NkxXTnBkR1V0Y0hKbFptbDRJajVJWlhKbCBK M01nYjI1bElIQnliMnBsWTNRZ2RHaGhkQ0J6YUc5MWJHUWdaMlYwSUhSb1pRb2dJQ0FnSUNCaGRI UmxiblJwYjI0Z2IyWWdTMjlzIFlpQmtjbWwyWlhKek9qeGljajRLUEdFZ1kyeGhjM005SW0xdmVp MTBlSFF0YkdsdWF5MW1jbVZsZEdWNGRDSWdhSEpsWmowaWFIUjAgY0RvdkwzZDNkeTVvZVdKeWFX UmpZWEp6TG1OdmJTOXRZWHBrWVMxamIzVnNaQzF3Y205a2RXTmxMVzFoZW1SaE1pMWxkaTEzYVhS byBMWEp2ZEdGeWVTMXlZVzVuWlMxbGVIUmxibVJsY2k4aVBtaDBkSEE2THk5M2QzY3VhSGxpY21s a1kyRnljeTVqYjIwdmJXRjZaR0V0IFkyOTFiR1F0Y0hKdlpIVmpaUzF0WVhwa1lUSXRaWFl0ZDJs MGFDMXliM1JoY25rdGNtRnVaMlV0WlhoMFpXNWtaWEl2UEM5aFBqeGkgY2o0S0lDQWdJQ0FnUEdK eVBnb2dJQ0FnSUNCVWFHVnlaU2R6SUdGc2MyOGdZU0J5WlhCbFlYUmxaR3g1SUhKbGMzVnlabUZq YVc1biBJSEoxYlc5eUlIUm9ZWFFnZEdobGVTQjNhV3hzQ2lBZ0lDQWdJSEpsTFdsdWRISnZaSFZq WlNCMGFHVWdVbGczTDFKWU9DQnpjRzl5IGRITWdZMkZ5SUhkcGRHZ2dZU0F4TmxnZ2NtOTBZWEo1 SUdWdVoybHVaU0FvZEdobENpQWdJQ0FnSUdWdVoybHVaU0JwY3lCaGJISmwgWVdSNUlHUmxkbVZz YjNCbFpDa3VQR0p5UGdvZ0lDQWdJQ0E4WVNCamJHRnpjejBpYlc5NkxYUjRkQzFzYVc1ckxXWnla V1YwWlhoMCBJaUJvY21WbVBTSm9kSFJ3T2k4dmQzZDNMbTFoZW1SaExtTnZiUzl6ZEc5eWFXVnpM M0p2ZEdGeWVTOHhObmd2SWo1b2RIUndPaTh2IGQzZDNMbTFoZW1SaExtTnZiUzl6ZEc5eWFXVnpM M0p2ZEdGeWVTOHhObmd2UEM5aFBqeGljajRLSUNBZ0lDQWdQR0p5UGdvZ0lDQWcgSUNCRGFHRnli R2xsUEdKeVBnb2dJQ0FnSUNBOFluSStDaUFnSUNBZ0lFOXVJREV2TWpjdk1qQXhOU0F4TURvd05D QkJUU3dnZFc1ayBiMk4wYjNJZ2QzSnZkR1U2UEdKeVBnb2dJQ0FnUEM5a2FYWStDaUFnSUNBOFlt eHZZMnR4ZFc5MFpTQmphWFJsUFNKdGFXUTZiemsxIGFYQnpiR3d3ZEhOdlltY3liV1JyTldSbmJI ZGtMakUwTWpJek56UTJPVGMxTURoQVpXMWhhV3d1WVc1a2NtOXBaQzVqYjIwaUlIUjUgY0dVOUlt TnBkR1VpUGdvZ0lDQWdJQ0E4YldWMFlTQm9kSFJ3TFdWeGRXbDJQU0pEYjI1MFpXNTBMVlI1Y0dV aUlHTnZiblJsYm5ROSBJblJsZUhRdmFIUnRiRHNnWTJoaGNuTmxkRDExZEdZdE9DSStDaUFnSUNB Z0lEeGthWFkrUjI5dlpDQjBieUJvWldGeUlHWnliMjBnIGVXOTFMQ0JRWVhRdUlFaHZkeUJoY21V Z2RHaHBibWR6SUdGamNtOXpjeUIwYUdVZ2NHOXVaRDhLSUNBZ0lDQWdJQ0FtYm1KemNEdFQgZEds c2JDQm5jbTkxYm1SbFpEOGdKbTVpYzNBN1NTQmhiU0JoYm1RZ1NTQmtiMjRuZENCc2FXdGxJR2ww TGlCSWIzQmxJSFJ2SUdObyBZVzVuWlNCMGFHRjBDaUFnSUNBZ0lDQWdaV0Z5YkhrZ1pteDVhVzVu SUhObFlYTnZiaTRtYm1KemNEczhMMlJwZGo0S0lDQWdJQ0FnIFBHUnBkajQ4WW5JK0NpQWdJQ0Fn SUR3dlpHbDJQZ29nSUNBZ0lDQThaR2wyUGxOdmNuSjVJRWtnYldsemMzQmxiR3hsWkNCWFlXNXIg Wld3dUlFMWxiVzl5ZVNCblpYUnpJR1oxZW5wNUlHWnliMjBnZVdWaGNuTWdZV2R2TGladVluTndP end2WkdsMlBnb2dJQ0FnSUNBOCBaR2wyUGp4aWNqNEtJQ0FnSUNBZ1BDOWthWFkrQ2lBZ0lDQWdJ RHhrYVhZK1NHVnlZaXdnU1NCM1lYTWdZWGRoY21VZ1RXRjZaR0VnIGRYTmxaQ0IwYUdVZ1YyRnVh MlZzT3lCa2J5QjBhR1Y1SUc5eUlHRnVlVzl1WlFvZ0lDQWdJQ0FnSUhOMGFXeHNQend2WkdsMlBn b2cgSUNBZ0lDQThaR2wyUGp4aWNqNEtJQ0FnSUNBZ1BDOWthWFkrQ2lBZ0lDQWdJRHhrYVhZK1JH RjJaU0JMZFd4d1BDOWthWFkrQ2lBZyBJQ0FnSUR4a2FYWStRbVYwYUd4bGFHVnRMQ0JRUVR3dlpH bDJQZ29nSUNBZ0lDQThaR2wyUGp4aWNqNEtJQ0FnSUNBZ1BDOWthWFkrIENpQWdJQ0FnSUR4a2FY WStSRzhnYm05MElHRnlZMmhwZG1VOEwyUnBkajRLSUNBZ0lDQWdQR1JwZGo0OFluSStDaUFnSUNB Z0lEd3YgWkdsMlBnb2dJQ0FnSUNBOFpHbDJQanhpY2o0S0lDQWdJQ0FnUEM5a2FYWStDaUFnSUNB Z0lEeGthWFkrQ2lBZ0lDQWdJQ0FnUEdScCBkaUJ6ZEhsc1pUMGlabTl1ZEMxemFYcGxPamx3ZUR0 amIyeHZjam9qTlRjMU56VTNJajVUWlc1MElHWnliMjBnYlhrZ1ZtVnlhWHB2IGJnb2dJQ0FnSUNB Z0lDQWdWMmx5Wld4bGMzTWdORWNnVEZSRklGTnRZWEowY0dodmJtVThMMlJwZGo0S0lDQWdJQ0Fn UEM5a2FYWSsgQ2lBZ0lDQWdJRHhpY2o0S0lDQWdJQ0FnUEdKeVBnb2dJQ0FnSUNBOFpHbDJQaTB0 TFMwdExTMHRJRTl5YVdkcGJtRnNJRzFsYzNOaCBaMlVnTFMwdExTMHRMUzA4TDJScGRqNEtJQ0Fn SUNBZ1BHUnBkajVHY205dE9pQklaWEppSUR4b1pYSmlaMmhBYm1OMFl5NWpiMjArIElEd3ZhR1Z5 WW1kb1FHNWpkR011WTI5dFBqd3ZaR2wyUGdvZ0lDQWdJQ0E4WkdsMlBrUmhkR1U2TURFdk1qY3ZN akF4TlNBNE9qSTUgSUVGTklDaEhUVlF0TURVNk1EQXBJRHd2WkdsMlBnb2dJQ0FnSUNBOFpHbDJQ bFJ2T2lBOFlTQmpiR0Z6Y3owaWJXOTZMWFI0ZEMxcyBhVzVyTFdGaVluSmxkbWxoZEdWa0lpQm9j bVZtUFNKdFlXbHNkRzg2YTI5c1lpMXNhWE4wUUcxaGRISnZibWxqY3k1amIyMGlQbXR2IGJHSXRi R2x6ZEVCdFlYUnliMjVwWTNNdVkyOXRQQzloUGlBOEwyUnBkajRLSUNBZ0lDQWdQR1JwZGo1VGRX SnFaV04wT2lCU1pUb2cgUzI5c1lpMU1hWE4wT2lCQ2IzVnlhMlVnWlc1bmFXNWxJRHd2WkdsMlBn b2dJQ0FnSUNBOFpHbDJQanhpY2o0S0lDQWdJQ0FnUEM5ayBhWFkrQ2lBZ0lDQWdJRkJoZER4aWNq NEtJQ0FnSUNBZ1BHSnlQZ29nSUNBZ0lDQW1ibUp6Y0RzZ1NXWWdiV1Z0YjNKNUlITmxjblpsIGN5 eEpJR0psYkdsbGRtVXNJRTFoZW1SaElHaGhjeUJ6YjJ4MlpXUWdiVzl6ZENCdlppQjBhR1VLSUNB Z0lDQWdkR1ZqYUc1cFkyRnMgSUhCeWIySnNaVzF6SUhkcGRHZ2dkR2hsSUZkaGJtdGxiQzQ4WW5J K0NpQWdJQ0FnSUR4aWNqNEtJQ0FnSUNBZ0ptNWljM0E3SUdGdSBJR1ZoY214NUlIQnliMkpzWlcw c0lHWnliMjBnYldWdGIzSjVMQ0JqWVcxbElHRmliM1YwSUhkb1pXNGdkR2hsSUdaaFkzUnZjbmtL IElDQWdJQ0FnWkdWamFXUmxaQ0IwYnlCMWMyVWdjM1JoYm1SaGNtUWdZWFYwYnlCbGJtZHBibVVn YjJsc0lIUnZJR3gxWW5KcFkyRjAgWlNCMGFHVWdZWEJsZUFvZ0lDQWdJQ0J6WldGc2N5NHVMbUZ1 WkNCemFXUmxJSE5sWVd4ekxpNHVKbTVpYzNBN0lGUm9ZWFFnY21WeiBkV3gwWldRZ2FXNGdjMjl0 WlNCdVpXTmxjM05oY25rbWJtSnpjRHNnYjJsc0NpQWdJQ0FnSUdKMWNtNXBibWNnWVc1a0lHRWdZ blZwIGJHUWdkWEFnYjJZZ1kyRnlZbTl1TGk0dUptNWljM0E3SUU5dVpTQmpZVzRnYVcxaFoybHVa U0IwYUdVZ1pHVmlZWFJsQ2lBZ0lDQWcgSUhkb1pXNGdaVzVuYVc1bFpYSnpJSE4xWjJkbGMzUWdk R2hoZENCc2IzY2dZWE5vSUhSM2J5QnpkSEp2YTJVZ2IybHNJR0psSUhWeiBaV1F1TGk0L0lEeGlj ajRLSUNBZ0lDQWdQR0p5UGdvZ0lDQWdJQ0FtYm1KemNEc2dWR2hsSUhCdmQyVnlJR0Z1WkNCbWRX VnNJR052IGJuTjFiWEIwYVc5dUlHTmhiV1VnWm5KdmJTQjBhR1VnZEhkdklITjBjbTlyWlFvZ0lD QWdJQ0JrWlhOcFoyNHVMaTRnUm5KdmJTQnQgZVNCdFpXMXZjbmt1TGk0Z1NHVnlZaUE4WW5JK0Np QWdJQ0FnSUR4aWNqNEtJQ0FnSUNBZ0ptNWljM0E3Sm01aWMzQTdJRHhpY2o0SyBJQ0FnSUNBZ1BH UnBkaUJqYkdGemN6MGliVzk2TFdOcGRHVXRjSEpsWm1sNElqNVBiaUF3TVM4eU55OHlNREUxSURB MU9qUTNJRUZOIExDQlFZWFJ5YVdOcklFeGhaR1FLSUNBZ0lDQWdJQ0IzY205MFpUbzhZbkkrQ2lB Z0lDQWdJRHd2WkdsMlBnb2dJQ0FnSUNBOFlteHYgWTJ0eGRXOTBaU0JqYVhSbFBTSnRhV1E2UWtG Wk1UWTNMVVJUTlRBMlJVTTNRVFJDUmpoRE1qQTJSVUkxTURrNVEwUkZNekl3UUhCbyBlQzVuWW13 aUlIUjVjR1U5SW1OcGRHVWlQZ29nSUNBZ0lDQWdJRHhrYVhZZ1pHbHlQU0pzZEhJaVBnb2dJQ0Fn SUNBZ0lDQWdQR1JwIGRpQnpkSGxzWlQwaVJrOU9WQzFUU1ZwRk9pQXhNbkIwT3lCR1QwNVVMVVpC VFVsTVdUb2dKME5oYkdsaWNta25PeUJEVDB4UFVqb0sgSUNBZ0lDQWdJQ0FnSUNBZ0l6QXdNREF3 TUNJK0NpQWdJQ0FnSUNBZ0lDQWdJRHhrYVhZK1BHWnZiblFnWm1GalpUMGlWR2x0WlhNZyBUbVYz SUZKdmJXRnVJajRtYkhRN0pteDBPMUpsYldWdFltVnlJR0poWTJzZ2FXNEtJQ0FnSUNBZ0lDQWdJ Q0FnSUNBZ0lIUm9aU0ExIE1ITWdiM0lnTmpCeklIZG9aVzRnZEdobElGZGxibXRsYkNCU2IzUmhj bmtnWlc1bmFXNWxJSGRoY3dvZ0lDQWdJQ0FnSUNBZ0lDQWcgSUNBZ2FXNTBjbTlrZFdObFpEOGdU MjVsSUhSeWFXRnVaM1ZzWVhJZ2NHbHpkRzl1SUhkcGRHZ2djbTkwWVhKNUlISmhkR2hsY2dvZyBJ Q0FnSUNBZ0lDQWdJQ0FnSUNBZ2RHaGhiaUJ5WldOcGNISnZZMkYwYVc1bklHMXZkR2x2YmlCaGJt UWdkbVZ5ZVNCbVpYY2diVzkyIGFXNW5DaUFnSUNBZ0lDQWdJQ0FnSUNBZ0lDQndZWEowY3o4bVoz UTdKbWQwT3p3dlptOXVkRDQ4TDJScGRqNEtJQ0FnSUNBZ0lDQWcgSUNBZ1BHUnBkajRtYm1KemNE czhMMlJwZGo0S0lDQWdJQ0FnSUNBZ0lDQWdQR1JwZGo0OFptOXVkQ0JtWVdObFBTSlVhVzFsY3lC TyBaWGNnVW05dFlXNGlQa2tnYUdGa0lHRWdZMkZ5SUhkcGRHZ2dZU0JYWVc1clpXd0tJQ0FnSUNB Z0lDQWdJQ0FnSUNBZ0lHVnVaMmx1IFpTNGdRU0JpWldGMWRHbG1kV3dnWTJGeUlIZHBkR2dnZEdo bElITjFjR1Z5SUhOdGIyOTBhQ0J1YjI0S0lDQWdJQ0FnSUNBZ0lDQWcgSUNBZ0lIWnBZbkpoZEds dVp5QmxibWRwYm1VdVNYUWdkMjkxYkdRZ2NuVnVJR2hoY0hCcGJIa2diMjRnZG1WeWVTQnNiM2Nn WjNKaCBaR1VLSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJSEJsZEhKdmJDQmlkWFFnYjI1c2VTQm5ZWFps SUdGaWIzVjBJREkxYldsc1pYTWdkRzhnIGRHaGxJR2RoYkd4dmJpNEtJQ0FnSUNBZ0lDQWdJQ0Fn SUNBZ0lFRmpZMlZzWlhKaGRHbHZiaUIzWVhNZ2JtOTBhR2x1WnlCMGJ5QjMgY21sMFpTQm9iMjFs SUdGaWIzVjBJR0oxZENCMGFHVWdibTl1Q2lBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0J5WldOcGNISnZZ MkYwYVc1biBJR1JsYzJsbmJpQnRZV1JsSUdadmNpQnpkWEJsY2lCemJXOXZkR2dnY25WdWJtbHVa eTRnUVhNS0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnIElIbHZkU0J6WVhrZ2RHaGxJSGRsWVhKcGJtY2di MllnZEdobElHTmxjbUZ0YVdNZ2RHbHdjeUJ2WmlCMGFHVWdkR2h5WldVS0lDQWcgSUNBZ0lDQWdJ Q0FnSUNBZ0lIQnZhVzUwSUhKdmRHOXlJSGRoY3lCcGRITWdaRzkzYm1aaGJHd3VJRWR5WldGMElI QnBkSGt1SUVrZyBjbVZ0WlcxaVpYSUtJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lIUm9ZWFFnYVhRZ2FH RmtJR0VnYldGdWRXRnNJR2RsWVhJZ2MyaHBablFnIFluVjBJRzV2SUdOc2RYUmphQ0J3WldSaGJD NGdWR2hsQ2lBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0JqYkhWMFkyZ2dkMkZ6SUc5d1pYSmggZEdWa0lH VnNaV04wY21sallXeHNlU0IzYUdWdUlIbHZkU0JvWld4a0lIUm9aU0JyYm05aUNpQWdJQ0FnSUNB Z0lDQWdJQ0FnSUNCdiBiaUIwYUdVZ2RHOXdJRzltSUhSb1pTQm5aV0Z5SUhOMGFXTnJMaUJUYnlC MGFHVWdZV04wSUc5bUlHTm9ZVzVuYVc1bkNpQWdJQ0FnIElDQWdJQ0FnSUNBZ0lDQm5aV0Z5SUdG MWRHOXRZWFJwWTJGc2JIa2diM0JsY21GMFpXUWdkR2hsSUdOc2RYUmphQzRnU1hRZ2FHRmsgSUdF Z1pHVjJhV05sQ2lBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0IzYUdsamFDQnRZWFJqYUdWa0ptNWljM0E3 SUhSb1pTQmxibWRwYm1VZyBjM0JsWldRZ2RHOGdkR2hsSUhkb1pXVnNJSE53WldWa0lIZG9aVzRL SUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJSGx2ZFNCamFHRnVaMlZrIElHZGxZWEl1UEM5bWIyNTBQand2 WkdsMlBnb2dJQ0FnSUNBZ0lDQWdJQ0E4WkdsMlBqeG1iMjUwSUdaaFkyVTlJbFJwYldWeklFNWwg ZHlCU2IyMWhiaUkrVkdobGNtVWdkMlZ5WlNCelpYWmxjbUZzSUZkaGJtdGxiQW9nSUNBZ0lDQWdJ Q0FnSUNBZ0lDQWdZV1Z5YnlCbCBibWRwYm1WeklHSmxhVzVuSUhCc1lYbGxaQ0IzYVhSb0lHRWda bVYzSUhsbFlYSnpJR0ZuYnlCaWRYUWdkR2hsZVFvZ0lDQWdJQ0FnIElDQWdJQ0FnSUNBZ2MyVmxi U0IwYnlCb1lYWmxJR1poYkd4bGJpQmllU0IwYUdVZ2QyRjVjMmxrWlM0Z1VHbDBlU3dnYVhRZ2FH RmsgSUhOMVkyZ0tJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lIQnliMjFwYzJVdVBDOW1iMjUwUGp3dlpH bDJQZ29nSUNBZ0lDQWdJQ0FnSUNBOCBaR2wyUGladVluTndPend2WkdsMlBnb2dJQ0FnSUNBZ0lD QWdJQ0E4WkdsMlBqeG1iMjUwSUdaaFkyVTlJbFJwYldWeklFNWxkeUJTIGIyMWhiaUkrVUdGMFBD OW1iMjUwUGp3dlpHbDJQZ29nSUNBZ0lDQWdJQ0FnSUNBOFpHbDJQaVp1WW5Od096d3ZaR2wyUGdv Z0lDQWcgSUNBZ0lDQWdJQ0E4WkdsMlBnb2dJQ0FnSUNBZ0lDQWdJQ0FnSUR4a2FYWWdjM1I1YkdV OUlrWlBUbFF0VTBsYVJUb2djMjFoYkd3NyBJRlJGV0ZRdFJFVkRUMUpCVkVsUFRqb2dibTl1WlRz S0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUVaUFRsUXRSa0ZOU1V4Wk9pQW1jWFZ2IGREdERZV3hwWW5K cEpuRjFiM1E3T3lCR1QwNVVMVmRGU1VkSVZEb2dibTl5YldGc093b2dJQ0FnSUNBZ0lDQWdJQ0Fn SUNBZ1EwOU0gVDFJNklDTXdNREF3TURBN0lFWlBUbFF0VTFSWlRFVTZJRzV2Y20xaGJEc2dSRWxU VUV4QldUb2dhVzVzYVc1bElqNDhZajVHY205dCBPand2WWo0S0lDQWdJQ0FnSUNBZ0lDQWdJQ0Fn SUR4aElHMXZlaTFrYnkxdWIzUXRjMlZ1WkQwaWRISjFaU0lnZEdsMGJHVTlJbUZ6IGJITmhMbkp1 WjBCbmJXRnBiQzVqYjIwaUlHaHlaV1k5SW0xaGFXeDBienBoYzJ4ellTNXlibWRBWjIxaGFXd3VZ Mjl0SWo1U2FXTm8gWVhKa0lFZHBjbUZ5WkR3dllUNGdQQzlrYVhZK0NpQWdJQ0FnSUNBZ0lDQWdJ Q0FnUEdScGRpQnpkSGxzWlQwaVJrOU9WRG9nTVRCdyBkQ0IwWVdodmJXRWlQZ29nSUNBZ0lDQWdJ Q0FnSUNBZ0lDQWdQR1JwZGlCemRIbHNaVDBpUWtGRFMwZFNUMVZPUkRvZ0kyWTFaalZtIE5TSStD aUFnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJRHhrYVhZK1BHSStVMlZ1ZERvOEwySStJRk4xYm1SaGVT d2dTbUZ1ZFdGeWVTQXkgTlN3Z01qQXhOU0F4TVRvd05TQlFUVHd2WkdsMlBnb2dJQ0FnSUNBZ0lD QWdJQ0FnSUNBZ0lDQThaR2wyUGp4aVBsUnZPand2WWo0ZyBQR0VnYlc5NkxXUnZMVzV2ZEMxelpX NWtQU0owY25WbElpQjBhWFJzWlQwaWEyOXNZaTFzYVhOMFFHMWhkSEp2Ym1samN5NWpiMjBpIElH aHlaV1k5SW0xaGFXeDBienByYjJ4aUxXeHBjM1JBYldGMGNtOXVhV056TG1OdmJTSSthMjlzWWkx c2FYTjBRRzFoZEhKdmJtbGogY3k1amIyMDhMMkUrQ2lBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUR3 dlpHbDJQZ29nSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0E4WkdsMiBQanhpUGxOMVltcGxZM1E2UEM5 aVBpQlNaVG9nUzI5c1lpMU1hWE4wT2lCQ2IzVnlhMlVnWlc1bmFXNWxQQzlrYVhZK0NpQWdJQ0Fn IElDQWdJQ0FnSUNBZ0lDQThMMlJwZGo0S0lDQWdJQ0FnSUNBZ0lDQWdJQ0E4TDJScGRqNEtJQ0Fn SUNBZ0lDQWdJQ0FnSUNBOFpHbDIgUGladVluTndPend2WkdsMlBnb2dJQ0FnSUNBZ0lDQWdJQ0E4 TDJScGRqNEtJQ0FnSUNBZ0lDQWdJQ0FnUEdScGRpQnpkSGxzWlQwaSBSazlPVkMxVFNWcEZPaUJ6 YldGc2JEc2dWRVZZVkMxRVJVTlBVa0ZVU1U5T09pQnViMjVsT3dvZ0lDQWdJQ0FnSUNBZ0lDQWdJ RVpQIFRsUXRSa0ZOU1V4Wk9pQW1jWFZ2ZER0RFlXeHBZbkpwSm5GMWIzUTdPeUJHVDA1VUxWZEZT VWRJVkRvZ2JtOXliV0ZzT3dvZ0lDQWcgSUNBZ0lDQWdJQ0FnSUVOUFRFOVNPaUFqTURBd01EQXdP eUJHVDA1VUxWTlVXVXhGT2lCdWIzSnRZV3c3SUVSSlUxQk1RVms2SUdsdSBiR2x1WlNJK0NpQWdJ Q0FnSUNBZ0lDQWdJQ0FnUEdScGRpQmthWEk5SW14MGNpSStRbTkxY210bElHSjFhV3gwSUcxaGJu a2daWGhoIGJYQnNaWE1nYjJZZ2FHbHpJR1Z1WjJsdVpRb2dJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ1pt OXlJSFJ5ZFdOcmN5d2diM1YwWW05aGNtUWcgYlc5MGIzSnpMQ0JoYm1RZ1lXbHlZM0poWm5RdUlG Um9aWGtnWVd4c0NpQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNCM2IzSnJaV1FzSUhKaCBiaUJtYjNJZ2FI VnVaSEpsWkhNZ2IyWWdhRzkxY25NZ2QybDBhQ0JzYVhSMGJHVWdkMlZoY2lCMGJ3b2dJQ0FnSUNB Z0lDQWdJQ0FnIElDQWdZVzU1SUhCaGNuUnpMQ0JoYm1RZ2NISnZaSFZqWldRZ2RHaGxJR0ZrZG1W eWRHbHpaV1FnYUc5eWMyVndiM2RsY2k0Z1QyNWwgQ2lBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0J2WmlC MGFHVWdZV2x5WTNKaFpuUWdaVzVuYVc1bGN5QnBjeUJwYmlCMGFHVWdSVUZCSUcxMSBjMlYxYlM0 S0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUR4a2FYWStUR2xyWlNCaGJua2daVzVuYVc1bElIUm9aU0J6 ZEdGeWRDQjFjQ0JqIGIzTjBjeUJuYjJsdVp5QnBiblJ2Q2lBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0Fn SUhCeWIyUjFZM1JwYjI0Z2QyOTFiR1FnWW1VZ1lYTjAgY205dWIyMXBZMkZzSUdGdVpDQm1iM0ln WVc0Z1lXbHlZM0poWm5RS0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ1pXNW5hVzVsSUhSbyBaVzRn ZEdobGNtVWdZWEpsSUdObGNuUnBabWxqWVhScGIyNGdZMjl6ZEhNdUlFRnNiQ0JtYjNJZ1lRb2dJ Q0FnSUNBZ0lDQWdJQ0FnIElDQWdJQ0J6YldGc2JDQmthVzFwYm1semFHbHVaeUJ0WVhKclpYUXVJ Rk5oWkNCMGJ5QnpZWGtnYVhRZ2QyOXVKM1FnYUdGd2NHVnUgTEFvZ0lDQWdJQ0FnSUNBZ0lDQWdJ Q0FnSUNCaWRYUWdkR2hoZENkeklIUm9aU0IzWVhrZ2FYUWdhWE11UEM5a2FYWStDaUFnSUNBZyBJ Q0FnSUNBZ0lDQWdJQ0E4WkdsMlBpWnVZbk53T3p3dlpHbDJQZ29nSUNBZ0lDQWdJQ0FnSUNBZ0lD QWdQR1JwZGo1U2FXTnJJRWRwIGNtRnlaRHd2WkdsMlBnb2dJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ1BH UnBkajVrYnlCdWIzUWdZWEpqYUdsMlpUd3ZaR2wyUGdvZ0lDQWcgSUNBZ0lDQWdJQ0FnSUR3dlpH bDJQZ29nSUNBZ0lDQWdJQ0FnSUNBZ0lEeGthWFlnWTJ4aGMzTTlJbWR0WVdsc1gyVjRkSEpoSWo0 SyBJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lEeGthWFkrSm01aWMzQTdQQzlrYVhZK0NpQWdJQ0FnSUNB Z0lDQWdJQ0FnSUNBOFpHbDJJR05zIFlYTnpQU0puYldGcGJGOXhkVzkwWlNJK1QyNGdVM1Z1TENC S1lXNGdNalVzSURJd01UVWdZWFFnTVRvd09Rb2dJQ0FnSUNBZ0lDQWcgSUNBZ0lDQWdJQ0JRVFN3 Z2RXNWtiMk4wYjNJZ1BITndZVzRnWkdseVBTSnNkSElpUGlac2REczhZU0J0YjNvdFpHOHRibTkw TFhObCBibVE5SW5SeWRXVWlJR2h5WldZOUltMWhhV3gwYnpwMWJtUnZZM1J2Y2tCd2RHUXVibVYw SWlCMFlYSm5aWFE5SWw5aWJHRnVheUkrIGRXNWtiMk4wYjNKQWNIUmtMbTVsZER3dllUNG1aM1E3 UEM5emNHRnVQZ29nSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0IzY205MFpUbzggWW5JK0NpQWdJQ0Fn SUNBZ0lDQWdJQ0FnSUNBZ0lEeGliRzlqYTNGMWIzUmxJR05zWVhOelBTSm5iV0ZwYkY5eGRXOTBa U0lnYzNSNSBiR1U5SWxCQlJFUkpUa2N0VEVWR1ZEb0tJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJ Q0F4WlhnN0lFMUJVa2RKVGpvZ01IQjRJREJ3IGVDQXdjSGdnTUM0NFpYZzdJRUpQVWtSRlVpMU1S VVpVT2lBalkyTmpDaUFnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnTVhCNElITnYgYkdsa0lqNEtJ Q0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0E4WkdsMlBnb2dJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lD QWdJQ0FnUEdScCBkajVTWlcxbGJXSmxjaUJpWVdOcklHbHVJSFJvWlNBMU1ITWdiM0lnTmpCeklI ZG9aVzRnZEdobENpQWdJQ0FnSUNBZ0lDQWdJQ0FnIElDQWdJQ0FnSUNBZ0lGZGxibXRsYkNCU2Iz UmhjbmtnWlc1bmFXNWxJSGRoY3lCcGJuUnliMlIxWTJWa1B5QlBibVVLSUNBZ0lDQWcgSUNBZ0lD QWdJQ0FnSUNBZ0lDQWdJQ0FnZEhKcFlXNW5kV3hoY2lCd2FYTjBiMjRnZDJsMGFDQnliM1JoY25r Z2NtRjBhR1Z5SUhSbyBZVzRLSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdjbVZqYVhC eWIyTmhkR2x1WnlCdGIzUnBiMjRnWVc1a0lIWmxjbmtnIFptVjNJRzF2ZG1sdVp5QndZWEowY3o4 OEwyUnBkajRLSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lEeGthWFkrSm01aWMzQTcgUEM5 a2FYWStDaUFnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBOFpHbDJQa2R2YjJRZ2FXUmxZU0Jo Ym1RZ2FYUWdZMjkxYkdRZyBjM0JwYmlCMlpYSjVJR2hwWjJnZ2NtVjJjeTRLSUNBZ0lDQWdJQ0Fn SUNBZ0lDQWdJQ0FnSUNBZ0lDQWdVSEp2WW14bGJTQnBjeXdnIGRHaGxlU0JqWVc0bmRDQnJaV1Z3 SUhSb1pTQjBhWEJ6SUdaeWIyMEtJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ2QyVmgg Y21sdVp5QnZiaUIwYUdVZ2RISnBZVzVuZFd4aGNpQndhWE4wYjI0c0lITnZJSFpsY25rS0lDQWdJ Q0FnSUNBZ0lDQWdJQ0FnSUNBZyBJQ0FnSUNBZ2JHbHRhWFJsWkNCaGNIQnNhV05oZEdsdmJpQnBi aUIwYUdVZ2NtVmhiQ0IzYjNKc1pDNGdQQzlrYVhZK0NpQWdJQ0FnIElDQWdJQ0FnSUNBZ0lDQWdJ Q0FnSUNBOFpHbDJQaVp1WW5Od096d3ZaR2wyUGdvZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lD QWcgUEdScGRqNUJiSE52SUhKbGJXVnRZbVZ5SUdFZ1kyVnlZVzFwWXlCbGJtZHBibVVnYjI0Z2RH aGxJR1J5WVhkcGJtY0tJQ0FnSUNBZyBJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdZbTloY21SeklI ZG9hV05vSUhkaGN5QjBieUJ5YVhaaGJDQnpiR2xqWldRZ1luSmxZV1FnIFptOXlDaUFnSUNBZ0lD QWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lHZHlaV0YwYm1WemN5NGdTR0YyWlc0bmRDQm9aV0Z5WkNC aGJua2cgYlc5eVpTQmhZbTkxZENCMGFHRjBDaUFnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNB Z0lHOXVaUzRnVkdoaGRDZHpJRTlMTGlCSyBkWE4wSUd0bFpYQWdhVzUyWlc1MGFXNW5MQ0J0WVc1 NUlHOTFkQW9nSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQjBhR1Z5IFpTQnBaR1ZoY3lC b1lYWmxJR0psWlc0Z2MzVmpZMlZ6YzJaMWJDNGdQQzlrYVhZK0NpQWdJQ0FnSUNBZ0lDQWdJQ0Fn SUNBZ0lDQWcgSUNBOFpHbDJQaVp1WW5Od096d3ZaR2wyUGdvZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0Fn SUNBZ0lDQWdQR1JwZGo1RVlYWmxJRXQxYkhBOCBMMlJwZGo0S0lDQWdJQ0FnSUNBZ0lDQWdJQ0Fn SUNBZ0lDQWdJRHhrYVhZK1FtVjBhR3hsYUdWdExDQlFRVHd2WkdsMlBnb2dJQ0FnIElDQWdJQ0Fn SUNBZ0lDQWdJQ0FnSUNBZ1BHUnBkajRtYm1KemNEczhMMlJwZGo0S0lDQWdJQ0FnSUNBZ0lDQWdJ Q0FnSUNBZ0lDQWcgSUR4a2FYWStSRzhnYm05MElHRnlZMmhwZG1VOEwyUnBkajRLSUNBZ0lDQWdJ Q0FnSUNBZ0lDQWdJQ0FnSUNBZ0lEeGthWFkrSm01aSBjM0E3UEM5a2FYWStDaUFnSUNBZ0lDQWdJ Q0FnSUNBZ0lDQWdJQ0FnSUNBOFpHbDJQaVp1WW5Od096d3ZaR2wyUGdvZ0lDQWdJQ0FnIElDQWdJ Q0FnSUNBZ0lDQWdJQ0FnUEdScGRqNEtJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ1BH UnBkaUJ6ZEhsc1pUMGkgUms5T1ZDMVRTVnBGT2lBNWNIZzdJRU5QVEU5U09pQWpOVGMxTnpVM0lq NVRaVzUwQ2lBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZyBJQ0FnSUNBZ1puSnZiU0J0ZVNCV1pY SnBlbTl1SUZkcGNtVnNaWE56SURSSElFeFVSU0JUYldGeWRIQm9iMjVsUEM5a2FYWStDaUFnIElD QWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQThMMlJwZGo0S0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNB Z0lDQWdJRHhrYVhZK0NpQWcgSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lEeGthWFlnWTJ4 aGMzTTlJbWcxSWo0OFluSStDaUFnSUNBZ0lDQWdJQ0FnSUNBZyBJQ0FnSUNBZ0lDQWdJQ0FnUEdK eVBnb2dJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lEeGthWFkrTFMwdExTMHRMUzBn IFQzSnBaMmx1WVd3Z2JXVnpjMkZuWlNBdExTMHRMUzB0TFR3dlpHbDJQZ29nSUNBZ0lDQWdJQ0Fn SUNBZ0lDQWdJQ0FnSUNBZ0lDQWcgSUR4a2FYWStSbkp2YlRvZ1EyaGhjbXhwWlNCRmJtZHNZVzVr SUR3dlpHbDJQZ29nSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZyBJQ0FnSUR4a2FYWStSR0Yw WlRvd01TOHlOUzh5TURFMUlERTZORGdnVUUwZ0tFZE5WQzB3TlRvd01Da2dQQzlrYVhZK0NpQWdJ Q0FnIElDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdQR1JwZGo1VWJ6b2dQR0VnYlc5NkxXUnZM VzV2ZEMxelpXNWtQU0owY25WbElpQm8gY21WbVBTSnRZV2xzZEc4NmEyOXNZaTFzYVhOMFFHMWhk SEp2Ym1samN5NWpiMjBpSUhSaGNtZGxkRDBpWDJKc1lXNXJJajVyYjJ4aSBMV3hwYzNSQWJXRjBj bTl1YVdOekxtTnZiVHd2WVQ0S0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBOEwy UnBkajRLIElDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBOFpHbDJQbE4xWW1wbFkz UTZJRkpsT2lCTGIyeGlMVXhwYzNRNklFSnYgZFhKclpTQmxibWRwYm1VZ1BDOWthWFkrQ2lBZ0lD QWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnUEdScGRqNG1ibUp6Y0RzOCBMMlJwZGo0S0lD QWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBdExTWm5kRHNnUzI5c1lpMU1hWE4wSUcx bGMzTmhaMlVnIGNHOXpkR1ZrSUdKNU9pQkRhR0Z5YkdsbENpQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNB Z0lDQWdJQ0FnSUNBZ1JXNW5iR0Z1WkNBbWJIUTcgUEdFZ2JXOTZMV1J2TFc1dmRDMXpaVzVrUFNK MGNuVmxJaUJvY21WbVBTSnRZV2xzZEc4NlkyVmxibWRzWVc1a04wQm5iV0ZwYkM1aiBiMjBpSUhS aGNtZGxkRDBpWDJKc1lXNXJJajVqWldWdVoyeGhibVEzUUdkdFlXbHNMbU52YlR3dllUNG1aM1E3 UEdKeVBnb2dJQ0FnIElDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJRHhpY2o0S0lDQWdJQ0Fn SUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNCUGJpQXggTHpJMUx6SXdNVFVnTVRFNk1UZ2dRVTBz SUhkcGJHeHBZVzBnYzNWc2JHbDJZVzRnZDNKdmRHVTZQR0p5UGdvZ0lDQWdJQ0FnSUNBZyBJQ0Fn SUNBZ0lDQWdJQ0FnSUNBZ0lDWm5kRHNnTFMwbVozUTdJRXR2YkdJdFRHbHpkQ0J0WlhOellXZGxJ SEJ2YzNSbFpDQmllVG9LIElDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNCM2FXeHNh V0Z0SUhOMWJHeHBkbUZ1SUNac2REczhZU0J0YjNvdFpHOHQgYm05MExYTmxibVE5SW5SeWRXVWlJ R2h5WldZOUltMWhhV3gwYnpwM2FXeHNhV0Z0ZEhOMWJHeHBkbUZ1UUdGMGRDNXVaWFFpSUhSaCBj bWRsZEQwaVgySnNZVzVySWo1M2FXeHNhV0Z0ZEhOMWJHeHBkbUZ1UUdGMGRDNXVaWFE4TDJFK0pt ZDBPenhpY2o0S0lDQWdJQ0FnIElDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQW1aM1E3UEdKeVBn b2dJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDWm4gZERzbWJtSnpjRHNtYm1KemNE c21ibUp6Y0RzZ1EyeHBZMnNnYjI0Z2RtRnlhVzkxY3lCemRIVm1aaUJwYmlCMGFHbHpJR3hwYm1z dSBKbTVpYzNBN0NpQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ1RYa2dZbkp2ZEdo bGNpQnpaVzUwSUdsMElIUnZJRzFsIExDQjBhR2x1YTJsdVp5QkpKMlFnWW1VS0lDQWdJQ0FnSUNB Z0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNCcGJuUmxjbVZ6ZEdWa0xpWnUgWW5Od095QlhhWFJvSUZK dmRHRjRJR1J5YjNCd2FXNW5JSFJvWlNCemJXRnNiQW9nSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0Fn SUNBZyBJQ0FnSURJdGMzUnliMnRsY3l3Z2RHaGxjbVVnYVhNZ1lTQnVaV1ZrSUdadmNpQnlaWEJz WVdObGJXVnVkSE11Sm01aWMzQTdDaUFnIElDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0Fn VkdobElIZGxhV2RvZENCMGJ5QklVQ0J5WVhScGJ5QnNiMjlyY3lCd2NtVjAgZEhrZ1oyOXZaQzRt Ym1KemNEc0tJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQkViMlZ6SUdGdWVXOXVa U0JvWVhabCBJR0Z1ZVNCbGVIQmxjbWxsYm1ObEwyTnZiVzFsYm5SeklHOXVDaUFnSUNBZ0lDQWdJ Q0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdkR2hwIGN5QnZibVUvUEdKeVBnb2dJQ0FnSUNBZ0lDQWdJ Q0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDWm5kRHM4WW5JK0NpQWdJQ0FnSUNBZ0lDQWcgSUNBZ0lDQWdJ Q0FnSUNBZ0lDQWdKbWQwT3lBOFlTQnRiM290Wkc4dGJtOTBMWE5sYm1ROUluUnlkV1VpSUdoeVpX WTlJbWgwZEhBNiBMeTkzZDNjdVltOTFjbXRsTFdWdVoybHVaUzVqYjIwdllXNXBJaUIwWVhKblpY UTlJbDlpYkdGdWF5SSthSFIwY0RvdkwzZDNkeTVpIGIzVnlhMlV0Wlc1bmFXNWxMbU52YlM5aGJt azhMMkUrUEdKeVBnb2dJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDWm4gZERzOFlu SStDaUFnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdKbWQwT3p4aWNqNEtJQ0FnSUNB Z0lDQWdJQ0FnSUNBZyBJQ0FnSUNBZ0lDQWdJQ0JKSjJRZ2MzVm5aMlZ6ZENCbWFXNWthVzVuSUdG dUlHbHVaR1Z3Wlc1a1pXNTBJR1Z1WjJsdVpXVnlhVzVuIENpQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNB Z0lDQWdJQ0FnSUNBZ1pYWmhiSFZoZEdsdmJpNGdUWGtnZEdodmRXZG9kSE02SUR4aWNqNEsgSUNB Z0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0JEYjI1emFXUmxjaUJvYjNjZ2MyVjJaWEps SUhSb1pTQnBiV0poYkdGdSBZMlVnZDJsc2JDQmlaU0IzYVhSb0NpQWdJQ0FnSUNBZ0lDQWdJQ0Fn SUNBZ0lDQWdJQ0FnSUNBZ1ltOTBhQ0J3YVhOMGIyNXpJRzF2IGRtbHVaeUIwYUdVZ1BHSnlQZ29n SUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJSE5oYldVZ1pHbHlaV04wYVc5dUxDQjAg YUdWdUlHaHZkeUJ0ZFdOb0lIUm9aUW9nSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJ R052ZFc1MFpYSjNaV2xuYUhRZyBkMmxzYkNCM1pXbG5hQ0IwYnlCamIzVnVkR1Z5WVdOMElEeGlj ajRLSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0IwIGFHRjBJR1p2Y21ObElDaDNh WFJvYjNWMElHTnZiblJ5YVdKMWRHbHVaeUJoYm5rZ2NHOTNaWElwTGdvZ0lDQWdJQ0FnSUNBZ0lD QWcgSUNBZ0lDQWdJQ0FnSUNBZ0lGUm9aVzRnWTI5dWMybGtaWElnYUc5M0lHeHZibWNnWVNBOFlu SStDaUFnSUNBZ0lDQWdJQ0FnSUNBZyBJQ0FnSUNBZ0lDQWdJQ0FnYzJ4cFpHbHVaeUJzYVc1bExX TnZiblJoWTNRZ2MyeHBaR2x1WnlCaVpXRnlhVzVuSUdseklHZHZhVzVuIENpQWdJQ0FnSUNBZ0lD QWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ2RHOGdiR0Z6ZENCM2FHVnVJSE4xWW1wbFkzUmxaQ0IwYnlB OFluSSsgQ2lBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnZEdodmMyVWdabTl5WTJW ekxpQlVhR1VnWTJ4aGFXMGdhWE1nTVM4MCBJSEJ2ZFc1a0lDZ3dMakkxSUd4aUtRb2dJQ0FnSUNB Z0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lIQmxjaUJvY0M5b2NpNGdWR2hwIGN5QnBjeUJpWlhS MFpYSWdQR0p5UGdvZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUdKNUlHRmliM1Yw SURNd0pTQjAgYUdGdUlIUm9aU0J0YjNOMElHVm1abWxqYVdWdWRDQnBiblJsY201aGJBb2dJQ0Fn SUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZyBJR052YldKMWMzUnBiMjRnWlc1bmFXNWxJR1Yy WlhJZ1BHSnlQZ29nSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJR0oxIGFXeDBMQ0Jo Ym1RZ2FYUW5jeUJ6ZEdsc2JDQmhJRElnYzNSeWIydGxJR1Z1WjJsdVpTNGdTWE51SjNRS0lDQWdJ Q0FnSUNBZ0lDQWcgSUNBZ0lDQWdJQ0FnSUNBZ0lDQnBkQ0JoSUdKcGRDQnpkSEpoYm1kbElIUm9Z WFFnWVNBOFluSStDaUFnSUNBZ0lDQWdJQ0FnSUNBZyBJQ0FnSUNBZ0lDQWdJQ0FnWkdWemFXZHVJ SFJvWVhRbmN5QmlaV1Z1SUdGeWIzVnVaQ0JzYjI1bklHVnViM1ZuYUNCbWIzSWdkR2hsIENpQWdJ Q0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ2NHRjBaVzUwY3lCMGJ5QmxlSEJwY21Vc0lH RnVaQ0JwY3lBOFluSSsgQ2lBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnYzNWd1pY SWdZMnhsWVc0c0lHRnVaQ0JpWldGMGN5QjBhR1VnWW1WeiBkQ0IwWldOb0lHOTFkQ0IwYUdWeVpR b2dJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lHSjVJRE13SlN3Z2FHRnpiaWQwIElI UmhhMlZ1SUc5MlpYSWdQR0p5UGdvZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUdW MlpYSjVJR1Z1WjJsdVpTQnQgWVhKclpYUWdiMjRnZEdobElIQnNZVzVsZEQ4bWJtSnpjRHNnUVc1 a0lHbDBDaUFnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZyBJQ0FnZFhObGN5QW5aR1YwYjI1 aGRHbHZiaWNnZEc4Z1pYaDBjbUZqZENBOFluSStDaUFnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0Fn IElDQWdJQ0FnYlc5eVpTQmxibVZ5WjNrZ1puSnZiU0IwYUdVZ1puVmxiRDhnVjJoaGRDQm9ZWEJ3 Wlc1eklIUnZJR0VLSUNBZ0lDQWcgSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNCd2FYTjBiMjRn ZDJobGJpQjViM1VnYUdGMlpTQThZbkkrQ2lBZ0lDQWdJQ0FnSUNBZyBJQ0FnSUNBZ0lDQWdJQ0Fn SUNBZ1pHVjBiMjVoZEdsdmJpQnBiaUIwYUdVZ1kyOXRZblZ6ZEdsdmJpQmphR0Z0WW1WeVB5QW9R VzV6IGQyVnlDaUFnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdhR1ZzY0RvZ2JtOTBh R2x1WnlCbmIyOWtMaWs4WW5JK0NpQWcgSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdQ R0p5UGdvZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUVOMSBjbkpsYm5RZ2RHVmph RzV2Ykc5bmVTQnBiaUEwSUhOMGNtOXJaWE1nWTJGdUlHTnZiV1VLSUNBZ0lDQWdJQ0FnSUNBZ0lD QWdJQ0FnIElDQWdJQ0FnSUNCd2NtVjBkSGtnWTJ4dmMyVWdkRzhnZEdobElITmhiV1VnUEdKeVBn b2dJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWcgSUNBZ0lDQWdJSEJ2ZDJWeUwzZGxhV2RvZENCeVlY UnBieUJoY3lCdmJHUWdkR1ZqYUNBeUlITjBjbTlyWlhNdUlFcDFjM1FLSUNBZyBJQ0FnSUNBZ0lD QWdJQ0FnSUNBZ0lDQWdJQ0FnSUNCdVpXVmtJSE52YldWdmJtVWdkRzhnYldGclpTQjBhR1Z0SUR4 aWNqNEtJQ0FnIElDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0JoZG1GcGJHRmliR1VnWVhR Z1lXNGdZV1ptYjNKa1lXSnNaU0J3Y21salpXOXMgWWkxTWFYTjBJZ29nSUNBZ0lDQWdJQ0FnSUNB Z0lDQWdJQ0FnSUNBZ0lDQWdJSFJoY21kbGREMGlYMkpzWVc1cklpWm5kRHM4WVNCdCBiM290Wkc4 dGJtOTBMWE5sYm1ROUluUnlkV1VpSUdOc1lYTnpQU0p0YjNvdGRIaDBMV3hwYm1zdFpuSmxaWFJs ZUhRaUlHaHlaV1k5IEltaDBkSEE2THk5M2QzY3ViV0YwY205dWFXTnpMbU52YlM5T1lYWnBaMkYw YjNJL1MyOXNZaTFNYVhOMGFIUjBjRG92TDNkM2R5NXQgWVhSeWIyNXBZM011WTI5dFBUMDlQVDA5 UFQwOVBUMDlQVDA5UFQwOUlqNW9kSFJ3T2k4dmQzZDNMbTFoZEhKdmJtbGpjeTVqYjIwdiBUbUYy YVdkaGRHOXlQMHR2YkdJdFRHbHpkR2gwZEhBNkx5OTNkM2N1YldGMGNtOXVhV056TG1OdmJUMDlQ VDA5UFQwOVBUMDlQVDA5IFBUMDlQVHd2WVQ0OFluSStDaUFnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJ Q0FnSUNBZ0lDQWdQR0p5UGdv ________________________________________________________________________________
Date: Jan 28, 2015
He's sending out Android multipart messages... Most email systems decode it just fine. Here's the header: ----_com.android.email_362066747291730 Content-Type: text/plain; charset=utf-8 Content-Transfer-Encoding: base64 I'll bet if you viewed his messages on a different email program, it would look fine (like it does for most of us). -- Robert On Wed, Jan 28, 2015 at 11:10 AM, undoctor wrote: > Huh, never heard that before. Anyone else having a problem? > > Russ, what kind of gibberish? > > > Sent from my Verizon Wireless 4G LTE Smartphone > > > -------- Original message -------- > From: kinne russ > Date:01/28/2015 11:46 AM (GMT-05:00) > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Bourke engine > > Undoctor =94 you should know that your posts come thru as gibberish . At > least on a Mac. > > On Jan 27, 2015, at 12:09 PM, undoctor wrote: > > PGh0bWw+PGhlYWQ+PG1ldGEgaHR0cC1lcXVpdj0iQ29udGVudC1UeXBlIiBjb250ZW50PSJ0Z Xh0 > L2h0bWw7IGNoYXJzZXQ9VVRGLTgiPjwvaGVhZD48Ym9keSA+PGRpdj5HcmVhdCBydW5kb3duL CBD > aGFybGllLiBUaGFua3MhPC9kaXY+PGRpdj48YnI+PC9kaXY+PGRpdj48YnI+PC9kaXY+PGRpd j48 > ZGl2IHN0eWxlPSJmb250LXNpemU6OXB4O2NvbG9yOiM1NzU3NTciPlNlbnQgZnJvbSBteSBWZ XJp > em9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lPC9kaXY+PC9kaXY+PGJyPjxicj48ZGl2P i0t > LS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS08L2Rpdj48ZGl2PkZyb206IENoYXJsa WUg > RW5nbGFuZCA8Y2VlbmdsYW5kN0BnbWFpbC5jb20+IDwvZGl2PjxkaXY+RGF0ZTowMS8yNy8yM DE1 > ICAxMToyNSBBTSAgKEdNVC0wNTowMCkgPC9kaXY+PGRpdj5Ubzoga29sYi1saXN0QG1hdHJvb mlj > cy5jb20gPC9kaXY+PGRpdj5TdWJqZWN0OiBSZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lI Dwv > ZGl2PjxkaXY+PGJyPjwvZGl2PgogICAgPGRpdiBjbGFzcz0ibW96LWNpdGUtcHJlZml4Ij5IZ XJl > J3Mgb25lIHByb2plY3QgdGhhdCBzaG91bGQgZ2V0IHRoZQogICAgICBhdHRlbnRpb24gb2YgS 29s > YiBkcml2ZXJzOjxicj4KPGEgY2xhc3M9Im1vei10eHQtbGluay1mcmVldGV4dCIgaHJlZj0ia HR0 > cDovL3d3dy5oeWJyaWRjYXJzLmNvbS9tYXpkYS1jb3VsZC1wcm9kdWNlLW1hemRhMi1ldi13a XRo > LXJvdGFyeS1yYW5nZS1leHRlbmRlci8iPmh0dHA6Ly93d3cuaHlicmlkY2Fycy5jb20vbWF6Z GEt > Y291bGQtcHJvZHVjZS1tYXpkYTItZXYtd2l0aC1yb3RhcnktcmFuZ2UtZXh0ZW5kZXIvPC9hP jxi > cj4KICAgICAgPGJyPgogICAgICBUaGVyZSdzIGFsc28gYSByZXBlYXRlZGx5IHJlc3VyZmFja W5n > IHJ1bW9yIHRoYXQgdGhleSB3aWxsCiAgICAgIHJlLWludHJvZHVjZSB0aGUgUlg3L1JYOCBzc G9y > dHMgY2FyIHdpdGggYSAxNlggcm90YXJ5IGVuZ2luZSAodGhlCiAgICAgIGVuZ2luZSBpcyBhb HJl > YWR5IGRldmVsb3BlZCkuPGJyPgogICAgICA8YSBjbGFzcz0ibW96LXR4dC1saW5rLWZyZWV0Z Xh0 > IiBocmVmPSJodHRwOi8vd3d3Lm1hemRhLmNvbS9zdG9yaWVzL3JvdGFyeS8xNngvIj5odHRwO i8v > d3d3Lm1hemRhLmNvbS9zdG9yaWVzL3JvdGFyeS8xNngvPC9hPjxicj4KICAgICAgPGJyPgogI CAg > ICBDaGFybGllPGJyPgogICAgICA8YnI+CiAgICAgIE9uIDEvMjcvMjAxNSAxMDowNCBBTSwgd W5k > b2N0b3Igd3JvdGU6PGJyPgogICAgPC9kaXY+CiAgICA8YmxvY2txdW90ZSBjaXRlPSJtaWQ6b zk1 > aXBzbGwwdHNvYmcybWRrNWRnbHdkLjE0MjIzNzQ2OTc1MDhAZW1haWwuYW5kcm9pZC5jb20iI HR5 > cGU9ImNpdGUiPgogICAgICA8bWV0YSBodHRwLWVxdWl2PSJDb250ZW50LVR5cGUiIGNvbnRlb nQ9 > InRleHQvaHRtbDsgY2hhcnNldD11dGYtOCI+CiAgICAgIDxkaXY+R29vZCB0byBoZWFyIGZyb 20g > eW91LCBQYXQuIEhvdyBhcmUgdGhpbmdzIGFjcm9zcyB0aGUgcG9uZD8KICAgICAgICAmbmJzc DtT > dGlsbCBncm91bmRlZD8gJm5ic3A7SSBhbSBhbmQgSSBkb24ndCBsaWtlIGl0LiBIb3BlIHRvI GNo > YW5nZSB0aGF0CiAgICAgICAgZWFybHkgZmx5aW5nIHNlYXNvbi4mbmJzcDs8L2Rpdj4KICAgI CAg > PGRpdj48YnI+CiAgICAgIDwvZGl2PgogICAgICA8ZGl2PlNvcnJ5IEkgbWlzc3BlbGxlZCBXY W5r > ZWwuIE1lbW9yeSBnZXRzIGZ1enp5IGZyb20geWVhcnMgYWdvLiZuYnNwOzwvZGl2PgogICAgI CA8 > ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+SGVyYiwgSSB3YXMgYXdhcmUgTWF6Z GEg > dXNlZCB0aGUgV2Fua2VsOyBkbyB0aGV5IG9yIGFueW9uZQogICAgICAgIHN0aWxsPzwvZGl2P gog > ICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+RGF2ZSBLdWxwPC9kaXY+C iAg > ICAgIDxkaXY+QmV0aGxlaGVtLCBQQTwvZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC9ka XY+ > CiAgICAgIDxkaXY+RG8gbm90IGFyY2hpdmU8L2Rpdj4KICAgICAgPGRpdj48YnI+CiAgICAgI Dwv > ZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+CiAgICAgICAgP GRp > diBzdHlsZT0iZm9udC1zaXplOjlweDtjb2xvcjojNTc1NzU3Ij5TZW50IGZyb20gbXkgVmVya Xpv > bgogICAgICAgICAgV2lyZWxlc3MgNEcgTFRFIFNtYXJ0cGhvbmU8L2Rpdj4KICAgICAgPC9ka XY+ > CiAgICAgIDxicj4KICAgICAgPGJyPgogICAgICA8ZGl2Pi0tLS0tLS0tIE9yaWdpbmFsIG1lc 3Nh > Z2UgLS0tLS0tLS08L2Rpdj4KICAgICAgPGRpdj5Gcm9tOiBIZXJiIDxoZXJiZ2hAbmN0Yy5jb 20+ > IDwvaGVyYmdoQG5jdGMuY29tPjwvZGl2PgogICAgICA8ZGl2PkRhdGU6MDEvMjcvMjAxNSA4O jI5 > IEFNIChHTVQtMDU6MDApIDwvZGl2PgogICAgICA8ZGl2PlRvOiA8YSBjbGFzcz0ibW96LXR4d C1s > aW5rLWFiYnJldmlhdGVkIiBocmVmPSJtYWlsdG86a29sYi1saXN0QG1hdHJvbmljcy5jb20iP mtv > bGItbGlzdEBtYXRyb25pY3MuY29tPC9hPiA8L2Rpdj4KICAgICAgPGRpdj5TdWJqZWN0OiBSZ Tog > S29sYi1MaXN0OiBCb3Vya2UgZW5naW5lIDwvZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgP C9k > aXY+CiAgICAgIFBhdDxicj4KICAgICAgPGJyPgogICAgICAmbmJzcDsgSWYgbWVtb3J5IHNlc nZl > cyxJIGJlbGlldmUsIE1hemRhIGhhcyBzb2x2ZWQgbW9zdCBvZiB0aGUKICAgICAgdGVjaG5pY 2Fs > IHByb2JsZW1zIHdpdGggdGhlIFdhbmtlbC48YnI+CiAgICAgIDxicj4KICAgICAgJm5ic3A7I GFu > IGVhcmx5IHByb2JsZW0sIGZyb20gbWVtb3J5LCBjYW1lIGFib3V0IHdoZW4gdGhlIGZhY3Rvc nkK > ICAgICAgZGVjaWRlZCB0byB1c2Ugc3RhbmRhcmQgYXV0byBlbmdpbmUgb2lsIHRvIGx1YnJpY 2F0 > ZSB0aGUgYXBleAogICAgICBzZWFscy4uLmFuZCBzaWRlIHNlYWxzLi4uJm5ic3A7IFRoYXQgc mVz > dWx0ZWQgaW4gc29tZSBuZWNlc3NhcnkmbmJzcDsgb2lsCiAgICAgIGJ1cm5pbmcgYW5kIGEgY nVp > bGQgdXAgb2YgY2FyYm9uLi4uJm5ic3A7IE9uZSBjYW4gaW1hZ2luZSB0aGUgZGViYXRlCiAgI CAg > IHdoZW4gZW5naW5lZXJzIHN1Z2dlc3QgdGhhdCBsb3cgYXNoIHR3byBzdHJva2Ugb2lsIGJlI HVz > ZWQuLi4/IDxicj4KICAgICAgPGJyPgogICAgICAmbmJzcDsgVGhlIHBvd2VyIGFuZCBmdWVsI GNv > bnN1bXB0aW9uIGNhbWUgZnJvbSB0aGUgdHdvIHN0cm9rZQogICAgICBkZXNpZ24uLi4gRnJvb SBt > eSBtZW1vcnkuLi4gSGVyYiA8YnI+CiAgICAgIDxicj4KICAgICAgJm5ic3A7Jm5ic3A7IDxic j4K > ICAgICAgPGRpdiBjbGFzcz0ibW96LWNpdGUtcHJlZml4Ij5PbiAwMS8yNy8yMDE1IDA1OjQ3I EFN > LCBQYXRyaWNrIExhZGQKICAgICAgICB3cm90ZTo8YnI+CiAgICAgIDwvZGl2PgogICAgICA8Y mxv > Y2txdW90ZSBjaXRlPSJtaWQ6QkFZMTY3LURTNTA2RUM3QTRCRjhDMjA2RUI1MDk5Q0RFMzIwQ HBo > eC5nYmwiIHR5cGU9ImNpdGUiPgogICAgICAgIDxkaXYgZGlyPSJsdHIiPgogICAgICAgICAgP GRp > diBzdHlsZT0iRk9OVC1TSVpFOiAxMnB0OyBGT05ULUZBTUlMWTogJ0NhbGlicmknOyBDT0xPU joK > ICAgICAgICAgICAgIzAwMDAwMCI+CiAgICAgICAgICAgIDxkaXY+PGZvbnQgZmFjZT0iVGltZ XMg > TmV3IFJvbWFuIj4mbHQ7Jmx0O1JlbWVtYmVyIGJhY2sgaW4KICAgICAgICAgICAgICAgIHRoZ SA1 > MHMgb3IgNjBzIHdoZW4gdGhlIFdlbmtlbCBSb3RhcnkgZW5naW5lIHdhcwogICAgICAgICAgI CAg > ICAgaW50cm9kdWNlZD8gT25lIHRyaWFuZ3VsYXIgcGlzdG9uIHdpdGggcm90YXJ5IHJhdGhlc gog > ICAgICAgICAgICAgICAgdGhhbiByZWNpcHJvY2F0aW5nIG1vdGlvbiBhbmQgdmVyeSBmZXcgb W92 > aW5nCiAgICAgICAgICAgICAgICBwYXJ0cz8mZ3Q7Jmd0OzwvZm9udD48L2Rpdj4KICAgICAgI CAg > ICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgICAgICAgICAgPGRpdj48Zm9udCBmYWNlPSJUaW1lc yBO > ZXcgUm9tYW4iPkkgaGFkIGEgY2FyIHdpdGggYSBXYW5rZWwKICAgICAgICAgICAgICAgIGVuZ 2lu > ZS4gQSBiZWF1dGlmdWwgY2FyIHdpdGggdGhlIHN1cGVyIHNtb290aCBub24KICAgICAgICAgI CAg > ICAgIHZpYnJhdGluZyBlbmdpbmUuSXQgd291bGQgcnVuIGhhcHBpbHkgb24gdmVyeSBsb3cgZ 3Jh > ZGUKICAgICAgICAgICAgICAgIHBldHJvbCBidXQgb25seSBnYXZlIGFib3V0IDI1bWlsZXMgd G8g > dGhlIGdhbGxvbi4KICAgICAgICAgICAgICAgIEFjY2VsZXJhdGlvbiB3YXMgbm90aGluZyB0b yB3 > cml0ZSBob21lIGFib3V0IGJ1dCB0aGUgbm9uCiAgICAgICAgICAgICAgICByZWNpcHJvY2F0a W5n > IGRlc2lnbiBtYWRlIGZvciBzdXBlciBzbW9vdGggcnVubmluZy4gQXMKICAgICAgICAgICAgI CAg > IHlvdSBzYXkgdGhlIHdlYXJpbmcgb2YgdGhlIGNlcmFtaWMgdGlwcyBvZiB0aGUgdGhyZWUKI CAg > ICAgICAgICAgICAgIHBvaW50IHJvdG9yIHdhcyBpdHMgZG93bmZhbGwuIEdyZWF0IHBpdHkuI Ekg > cmVtZW1iZXIKICAgICAgICAgICAgICAgIHRoYXQgaXQgaGFkIGEgbWFudWFsIGdlYXIgc2hpZ nQg > YnV0IG5vIGNsdXRjaCBwZWRhbC4gVGhlCiAgICAgICAgICAgICAgICBjbHV0Y2ggd2FzIG9wZ XJh > dGVkIGVsZWN0cmljYWxseSB3aGVuIHlvdSBoZWxkIHRoZSBrbm9iCiAgICAgICAgICAgICAgI CBv > biB0aGUgdG9wIG9mIHRoZSBnZWFyIHN0aWNrLiBTbyB0aGUgYWN0IG9mIGNoYW5naW5nCiAgI CAg > ICAgICAgICAgICBnZWFyIGF1dG9tYXRpY2FsbHkgb3BlcmF0ZWQgdGhlIGNsdXRjaC4gSXQga GFk > IGEgZGV2aWNlCiAgICAgICAgICAgICAgICB3aGljaCBtYXRjaGVkJm5ic3A7IHRoZSBlbmdpb mUg > c3BlZWQgdG8gdGhlIHdoZWVsIHNwZWVkIHdoZW4KICAgICAgICAgICAgICAgIHlvdSBjaGFuZ 2Vk > IGdlYXIuPC9mb250PjwvZGl2PgogICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9IlRpbWVzI E5l > dyBSb21hbiI+VGhlcmUgd2VyZSBzZXZlcmFsIFdhbmtlbAogICAgICAgICAgICAgICAgYWVyb yBl > bmdpbmVzIGJlaW5nIHBsYXllZCB3aXRoIGEgZmV3IHllYXJzIGFnbyBidXQgdGhleQogICAgI CAg > ICAgICAgICAgc2VlbSB0byBoYXZlIGZhbGxlbiBieSB0aGUgd2F5c2lkZS4gUGl0eSwgaXQga GFk > IHN1Y2gKICAgICAgICAgICAgICAgIHByb21pc2UuPC9mb250PjwvZGl2PgogICAgICAgICAgI CA8 > ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9IlRpbWVzIE5ld yBS > b21hbiI+UGF0PC9mb250PjwvZGl2PgogICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogI CAg > ICAgICAgICA8ZGl2PgogICAgICAgICAgICAgIDxkaXYgc3R5bGU9IkZPTlQtU0laRTogc21hb Gw7 > IFRFWFQtREVDT1JBVElPTjogbm9uZTsKICAgICAgICAgICAgICAgIEZPTlQtRkFNSUxZOiAmc XVv > dDtDYWxpYnJpJnF1b3Q7OyBGT05ULVdFSUdIVDogbm9ybWFsOwogICAgICAgICAgICAgICAgQ 09M > T1I6ICMwMDAwMDA7IEZPTlQtU1RZTEU6IG5vcm1hbDsgRElTUExBWTogaW5saW5lIj48Yj5Gc m9t > OjwvYj4KICAgICAgICAgICAgICAgIDxhIG1vei1kby1ub3Qtc2VuZD0idHJ1ZSIgdGl0bGU9I mFz > bHNhLnJuZ0BnbWFpbC5jb20iIGhyZWY9Im1haWx0bzphc2xzYS5ybmdAZ21haWwuY29tIj5Sa WNo > YXJkIEdpcmFyZDwvYT4gPC9kaXY+CiAgICAgICAgICAgICAgPGRpdiBzdHlsZT0iRk9OVDogM TBw > dCB0YWhvbWEiPgogICAgICAgICAgICAgICAgPGRpdiBzdHlsZT0iQkFDS0dST1VORDogI2Y1Z jVm > NSI+CiAgICAgICAgICAgICAgICAgIDxkaXY+PGI+U2VudDo8L2I+IFN1bmRheSwgSmFudWFye SAy > NSwgMjAxNSAxMTowNSBQTTwvZGl2PgogICAgICAgICAgICAgICAgICA8ZGl2PjxiPlRvOjwvY j4g > PGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIiB0aXRsZT0ia29sYi1saXN0QG1hdHJvbmljcy5jb 20i > IGhyZWY9Im1haWx0bzprb2xiLWxpc3RAbWF0cm9uaWNzLmNvbSI+a29sYi1saXN0QG1hdHJvb mlj > cy5jb208L2E+CiAgICAgICAgICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgICAgICA8Z Gl2 > PjxiPlN1YmplY3Q6PC9iPiBSZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lPC9kaXY+CiAgI CAg > ICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICA8Z Gl2 > PiZuYnNwOzwvZGl2PgogICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgPGRpdiBzdHlsZ T0i > Rk9OVC1TSVpFOiBzbWFsbDsgVEVYVC1ERUNPUkFUSU9OOiBub25lOwogICAgICAgICAgICAgI EZP > TlQtRkFNSUxZOiAmcXVvdDtDYWxpYnJpJnF1b3Q7OyBGT05ULVdFSUdIVDogbm9ybWFsOwogI CAg > ICAgICAgICAgIENPTE9SOiAjMDAwMDAwOyBGT05ULVNUWUxFOiBub3JtYWw7IERJU1BMQVk6I Glu > bGluZSI+CiAgICAgICAgICAgICAgPGRpdiBkaXI9Imx0ciI+Qm91cmtlIGJ1aWx0IG1hbnkgZ Xhh > bXBsZXMgb2YgaGlzIGVuZ2luZQogICAgICAgICAgICAgICAgZm9yIHRydWNrcywgb3V0Ym9hc mQg > bW90b3JzLCBhbmQgYWlyY3JhZnQuIFRoZXkgYWxsCiAgICAgICAgICAgICAgICB3b3JrZWQsI HJh > biBmb3IgaHVuZHJlZHMgb2YgaG91cnMgd2l0aCBsaXR0bGUgd2VhciB0bwogICAgICAgICAgI CAg > ICAgYW55IHBhcnRzLCBhbmQgcHJvZHVjZWQgdGhlIGFkdmVydGlzZWQgaG9yc2Vwb3dlci4gT 25l > CiAgICAgICAgICAgICAgICBvZiB0aGUgYWlyY3JhZnQgZW5naW5lcyBpcyBpbiB0aGUgRUFBI G11 > c2V1bS4KICAgICAgICAgICAgICAgIDxkaXY+TGlrZSBhbnkgZW5naW5lIHRoZSBzdGFydCB1c CBj > b3N0cyBnb2luZyBpbnRvCiAgICAgICAgICAgICAgICAgIHByb2R1Y3Rpb24gd291bGQgYmUgY XN0 > cm9ub21pY2FsIGFuZCBmb3IgYW4gYWlyY3JhZnQKICAgICAgICAgICAgICAgICAgZW5naW5lI HRo > ZW4gdGhlcmUgYXJlIGNlcnRpZmljYXRpb24gY29zdHMuIEFsbCBmb3IgYQogICAgICAgICAgI CAg > ICAgICBzbWFsbCBkaW1pbmlzaGluZyBtYXJrZXQuIFNhZCB0byBzYXkgaXQgd29uJ3QgaGFwc GVu > LAogICAgICAgICAgICAgICAgICBidXQgdGhhdCdzIHRoZSB3YXkgaXQgaXMuPC9kaXY+CiAgI CAg > ICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgPGRpdj5SaWNrI Edp > cmFyZDwvZGl2PgogICAgICAgICAgICAgICAgPGRpdj5kbyBub3QgYXJjaGl2ZTwvZGl2PgogI CAg > ICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgIDxkaXYgY2xhc3M9ImdtYWlsX2V4dHJhI j4K > ICAgICAgICAgICAgICAgIDxkaXY+Jm5ic3A7PC9kaXY+CiAgICAgICAgICAgICAgICA8ZGl2I GNs > YXNzPSJnbWFpbF9xdW90ZSI+T24gU3VuLCBKYW4gMjUsIDIwMTUgYXQgMTowOQogICAgICAgI CAg > ICAgICAgICBQTSwgdW5kb2N0b3IgPHNwYW4gZGlyPSJsdHIiPiZsdDs8YSBtb3otZG8tbm90L XNl > bmQ9InRydWUiIGhyZWY9Im1haWx0bzp1bmRvY3RvckBwdGQubmV0IiB0YXJnZXQ9Il9ibGFua yI+ > dW5kb2N0b3JAcHRkLm5ldDwvYT4mZ3Q7PC9zcGFuPgogICAgICAgICAgICAgICAgICB3cm90Z To8 > YnI+CiAgICAgICAgICAgICAgICAgIDxibG9ja3F1b3RlIGNsYXNzPSJnbWFpbF9xdW90ZSIgc 3R5 > bGU9IlBBRERJTkctTEVGVDoKICAgICAgICAgICAgICAgICAgICAxZXg7IE1BUkdJTjogMHB4I DBw > eCAwcHggMC44ZXg7IEJPUkRFUi1MRUZUOiAjY2NjCiAgICAgICAgICAgICAgICAgICAgMXB4I HNv > bGlkIj4KICAgICAgICAgICAgICAgICAgICA8ZGl2PgogICAgICAgICAgICAgICAgICAgICAgP GRp > dj5SZW1lbWJlciBiYWNrIGluIHRoZSA1MHMgb3IgNjBzIHdoZW4gdGhlCiAgICAgICAgICAgI CAg > ICAgICAgICAgIFdlbmtlbCBSb3RhcnkgZW5naW5lIHdhcyBpbnRyb2R1Y2VkPyBPbmUKICAgI CAg > ICAgICAgICAgICAgICAgICAgdHJpYW5ndWxhciBwaXN0b24gd2l0aCByb3RhcnkgcmF0aGVyI HRo > YW4KICAgICAgICAgICAgICAgICAgICAgICAgcmVjaXByb2NhdGluZyBtb3Rpb24gYW5kIHZlc nkg > ZmV3IG1vdmluZyBwYXJ0cz88L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+Jm5ic 3A7 > PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICA8ZGl2Pkdvb2QgaWRlYSBhbmQgaXQgY291b GQg > c3BpbiB2ZXJ5IGhpZ2ggcmV2cy4KICAgICAgICAgICAgICAgICAgICAgICAgUHJvYmxlbSBpc ywg > dGhleSBjYW4ndCBrZWVwIHRoZSB0aXBzIGZyb20KICAgICAgICAgICAgICAgICAgICAgICAgd 2Vh > cmluZyBvbiB0aGUgdHJpYW5ndWxhciBwaXN0b24sIHNvIHZlcnkKICAgICAgICAgICAgICAgI CAg > ICAgICAgbGltaXRlZCBhcHBsaWNhdGlvbiBpbiB0aGUgcmVhbCB3b3JsZC4gPC9kaXY+CiAgI CAg > ICAgICAgICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgICAgI CAg > PGRpdj5BbHNvIHJlbWVtYmVyIGEgY2VyYW1pYyBlbmdpbmUgb24gdGhlIGRyYXdpbmcKICAgI CAg > ICAgICAgICAgICAgICAgICAgYm9hcmRzIHdoaWNoIHdhcyB0byByaXZhbCBzbGljZWQgYnJlY WQg > Zm9yCiAgICAgICAgICAgICAgICAgICAgICAgIGdyZWF0bmVzcy4gSGF2ZW4ndCBoZWFyZCBhb nkg > bW9yZSBhYm91dCB0aGF0CiAgICAgICAgICAgICAgICAgICAgICAgIG9uZS4gVGhhdCdzIE9LL iBK > dXN0IGtlZXAgaW52ZW50aW5nLCBtYW55IG91dAogICAgICAgICAgICAgICAgICAgICAgICB0a GVy > ZSBpZGVhcyBoYXZlIGJlZW4gc3VjY2Vzc2Z1bC4gPC9kaXY+CiAgICAgICAgICAgICAgICAgI CAg > ICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgPGRpdj5EYXZlIEt1b HA8 > L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+QmV0aGxlaGVtLCBQQTwvZGl2PgogI CAg > ICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgICAgICAgICAgICAgICAgI CAg > IDxkaXY+RG8gbm90IGFyY2hpdmU8L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+J m5i > c3A7PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgI CAg > ICAgICAgICAgICAgICAgPGRpdj4KICAgICAgICAgICAgICAgICAgICAgICAgPGRpdiBzdHlsZ T0i > Rk9OVC1TSVpFOiA5cHg7IENPTE9SOiAjNTc1NzU3Ij5TZW50CiAgICAgICAgICAgICAgICAgI CAg > ICAgICAgZnJvbSBteSBWZXJpem9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lPC9kaXY+C iAg > ICAgICAgICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+C iAg > ICAgICAgICAgICAgICAgICAgICAgIDxkaXYgY2xhc3M9Img1Ij48YnI+CiAgICAgICAgICAgI CAg > ICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIDxkaXY+LS0tLS0tL S0g > T3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLTwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgI CAg > IDxkaXY+RnJvbTogQ2hhcmxpZSBFbmdsYW5kIDwvZGl2PgogICAgICAgICAgICAgICAgICAgI CAg > ICAgIDxkaXY+RGF0ZTowMS8yNS8yMDE1IDE6NDggUE0gKEdNVC0wNTowMCkgPC9kaXY+CiAgI CAg > ICAgICAgICAgICAgICAgICAgICAgPGRpdj5UbzogPGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlI iBo > cmVmPSJtYWlsdG86a29sYi1saXN0QG1hdHJvbmljcy5jb20iIHRhcmdldD0iX2JsYW5rIj5rb 2xi > LWxpc3RAbWF0cm9uaWNzLmNvbTwvYT4KICAgICAgICAgICAgICAgICAgICAgICAgICA8L2Rpd j4K > ICAgICAgICAgICAgICAgICAgICAgICAgICA8ZGl2PlN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6I EJv > dXJrZSBlbmdpbmUgPC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzc Ds8 > L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgICAgICAtLSZndDsgS29sYi1MaXN0IG1lc3NhZ 2Ug > cG9zdGVkIGJ5OiBDaGFybGllCiAgICAgICAgICAgICAgICAgICAgICAgICAgRW5nbGFuZCAmb HQ7 > PGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIiBocmVmPSJtYWlsdG86Y2VlbmdsYW5kN0BnbWFpb C5j > b20iIHRhcmdldD0iX2JsYW5rIj5jZWVuZ2xhbmQ3QGdtYWlsLmNvbTwvYT4mZ3Q7PGJyPgogI CAg > ICAgICAgICAgICAgICAgICAgICAgIDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgICBPb iAx > LzI1LzIwMTUgMTE6MTggQU0sIHdpbGxpYW0gc3VsbGl2YW4gd3JvdGU6PGJyPgogICAgICAgI CAg > ICAgICAgICAgICAgICAgICZndDsgLS0mZ3Q7IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBie ToK > ICAgICAgICAgICAgICAgICAgICAgICAgICB3aWxsaWFtIHN1bGxpdmFuICZsdDs8YSBtb3otZ G8t > bm90LXNlbmQ9InRydWUiIGhyZWY9Im1haWx0bzp3aWxsaWFtdHN1bGxpdmFuQGF0dC5uZXQiI HRh > cmdldD0iX2JsYW5rIj53aWxsaWFtdHN1bGxpdmFuQGF0dC5uZXQ8L2E+Jmd0Ozxicj4KICAgI CAg > ICAgICAgICAgICAgICAgICAgICAmZ3Q7PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgI CZn > dDsmbmJzcDsmbmJzcDsmbmJzcDsgQ2xpY2sgb24gdmFyaW91cyBzdHVmZiBpbiB0aGlzIGxpb msu > Jm5ic3A7CiAgICAgICAgICAgICAgICAgICAgICAgICAgTXkgYnJvdGhlciBzZW50IGl0IHRvI G1l > LCB0aGlua2luZyBJJ2QgYmUKICAgICAgICAgICAgICAgICAgICAgICAgICBpbnRlcmVzdGVkL iZu > YnNwOyBXaXRoIFJvdGF4IGRyb3BwaW5nIHRoZSBzbWFsbAogICAgICAgICAgICAgICAgICAgI CAg > ICAgIDItc3Ryb2tlcywgdGhlcmUgaXMgYSBuZWVkIGZvciByZXBsYWNlbWVudHMuJm5ic3A7C iAg > ICAgICAgICAgICAgICAgICAgICAgICAgVGhlIHdlaWdodCB0byBIUCByYXRpbyBsb29rcyBwc mV0 > dHkgZ29vZC4mbmJzcDsKICAgICAgICAgICAgICAgICAgICAgICAgICBEb2VzIGFueW9uZSBoY XZl > IGFueSBleHBlcmllbmNlL2NvbW1lbnRzIG9uCiAgICAgICAgICAgICAgICAgICAgICAgICAgd Ghp > cyBvbmU/PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgICZndDs8YnI+CiAgICAgICAgI CAg > ICAgICAgICAgICAgICAgJmd0OyA8YSBtb3otZG8tbm90LXNlbmQ9InRydWUiIGhyZWY9Imh0d HA6 > Ly93d3cuYm91cmtlLWVuZ2luZS5jb20vYW5pIiB0YXJnZXQ9Il9ibGFuayI+aHR0cDovL3d3d y5i > b3Vya2UtZW5naW5lLmNvbS9hbmk8L2E+PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgI CZn > dDs8YnI+CiAgICAgICAgICAgICAgICAgICAgICAgICAgJmd0Ozxicj4KICAgICAgICAgICAgI CAg > ICAgICAgICAgICBJJ2Qgc3VnZ2VzdCBmaW5kaW5nIGFuIGluZGVwZW5kZW50IGVuZ2luZWVya W5n > CiAgICAgICAgICAgICAgICAgICAgICAgICAgZXZhbHVhdGlvbi4gTXkgdGhvdWdodHM6IDxic j4K > ICAgICAgICAgICAgICAgICAgICAgICAgICBDb25zaWRlciBob3cgc2V2ZXJlIHRoZSBpbWJhb GFu > Y2Ugd2lsbCBiZSB3aXRoCiAgICAgICAgICAgICAgICAgICAgICAgICAgYm90aCBwaXN0b25zI G1v > dmluZyB0aGUgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIHNhbWUgZGlyZWN0aW9uL CB0 > aGVuIGhvdyBtdWNoIHRoZQogICAgICAgICAgICAgICAgICAgICAgICAgIGNvdW50ZXJ3ZWlna HQg > d2lsbCB3ZWlnaCB0byBjb3VudGVyYWN0IDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgI CB0 > aGF0IGZvcmNlICh3aXRob3V0IGNvbnRyaWJ1dGluZyBhbnkgcG93ZXIpLgogICAgICAgICAgI CAg > ICAgICAgICAgICAgIFRoZW4gY29uc2lkZXIgaG93IGxvbmcgYSA8YnI+CiAgICAgICAgICAgI CAg > ICAgICAgICAgICAgc2xpZGluZyBsaW5lLWNvbnRhY3Qgc2xpZGluZyBiZWFyaW5nIGlzIGdva W5n > CiAgICAgICAgICAgICAgICAgICAgICAgICAgdG8gbGFzdCB3aGVuIHN1YmplY3RlZCB0byA8Y nI+ > CiAgICAgICAgICAgICAgICAgICAgICAgICAgdGhvc2UgZm9yY2VzLiBUaGUgY2xhaW0gaXMgM S80 > IHBvdW5kICgwLjI1IGxiKQogICAgICAgICAgICAgICAgICAgICAgICAgIHBlciBocC9oci4gV Ghp > cyBpcyBiZXR0ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIGJ5IGFib3V0IDMwJ SB0 > aGFuIHRoZSBtb3N0IGVmZmljaWVudCBpbnRlcm5hbAogICAgICAgICAgICAgICAgICAgICAgI CAg > IGNvbWJ1c3Rpb24gZW5naW5lIGV2ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgI GJ1 > aWx0LCBhbmQgaXQncyBzdGlsbCBhIDIgc3Ryb2tlIGVuZ2luZS4gSXNuJ3QKICAgICAgICAgI CAg > ICAgICAgICAgICAgICBpdCBhIGJpdCBzdHJhbmdlIHRoYXQgYSA8YnI+CiAgICAgICAgICAgI CAg > ICAgICAgICAgICAgZGVzaWduIHRoYXQncyBiZWVuIGFyb3VuZCBsb25nIGVub3VnaCBmb3Igd Ghl > CiAgICAgICAgICAgICAgICAgICAgICAgICAgcGF0ZW50cyB0byBleHBpcmUsIGFuZCBpcyA8Y nI+ > CiAgICAgICAgICAgICAgICAgICAgICAgICAgc3VwZXIgY2xlYW4sIGFuZCBiZWF0cyB0aGUgY mVz > dCB0ZWNoIG91dCB0aGVyZQogICAgICAgICAgICAgICAgICAgICAgICAgIGJ5IDMwJSwgaGFzb id0 > IHRha2VuIG92ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIGV2ZXJ5IGVuZ2luZ SBt > YXJrZXQgb24gdGhlIHBsYW5ldD8mbmJzcDsgQW5kIGl0CiAgICAgICAgICAgICAgICAgICAgI CAg > ICAgdXNlcyAnZGV0b25hdGlvbicgdG8gZXh0cmFjdCA8YnI+CiAgICAgICAgICAgICAgICAgI CAg > ICAgICAgbW9yZSBlbmVyZ3kgZnJvbSB0aGUgZnVlbD8gV2hhdCBoYXBwZW5zIHRvIGEKICAgI CAg > ICAgICAgICAgICAgICAgICAgICBwaXN0b24gd2hlbiB5b3UgaGF2ZSA8YnI+CiAgICAgICAgI CAg > ICAgICAgICAgICAgICAgZGV0b25hdGlvbiBpbiB0aGUgY29tYnVzdGlvbiBjaGFtYmVyPyAoQ W5z > d2VyCiAgICAgICAgICAgICAgICAgICAgICAgICAgaGVscDogbm90aGluZyBnb29kLik8YnI+C iAg > ICAgICAgICAgICAgICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgI EN1 > cnJlbnQgdGVjaG5vbG9neSBpbiA0IHN0cm9rZXMgY2FuIGNvbWUKICAgICAgICAgICAgICAgI CAg > ICAgICAgICBwcmV0dHkgY2xvc2UgdG8gdGhlIHNhbWUgPGJyPgogICAgICAgICAgICAgICAgI CAg > ICAgICAgIHBvd2VyL3dlaWdodCByYXRpbyBhcyBvbGQgdGVjaCAyIHN0cm9rZXMuIEp1c3QKI CAg > ICAgICAgICAgICAgICAgICAgICAgICBuZWVkIHNvbWVvbmUgdG8gbWFrZSB0aGVtIDxicj4KI CAg > ICAgICAgICAgICAgICAgICAgICAgICBhdmFpbGFibGUgYXQgYW4gYWZmb3JkYWJsZSBwcmljZ W9s > Yi1MaXN0IgogICAgICAgICAgICAgICAgICAgICAgICAgIHRhcmdldD0iX2JsYW5rIiZndDs8Y SBt > b3otZG8tbm90LXNlbmQ9InRydWUiIGNsYXNzPSJtb3otdHh0LWxpbmstZnJlZXRleHQiIGhyZ WY9 > Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0aHR0cDovL3d3d y5t > YXRyb25pY3MuY29tPT09PT09PT09PT09PT09PT09Ij5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb 20v > TmF2aWdhdG9yP0tvbGItTGlzdGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbT09PT09PT09PT09P T09 > PT09PTwvYT48YnI+CiAgICAgICAgICAgICAgICAgICAgICAgICAgPGJyPgo > > ________________________________________________________________________________
Date: Jan 28, 2015
Russ' copied text is gibberish, but Undoctor's looks fine on a Win7 PC. Another attempt by Apple to drive everyone into the hive? :-) n 1/28/2015 11:10 AM, undoctor wrote: > Huh, never heard that before. Anyone else having a problem? > > Russ, what kind of gibberish? > > > Sent from my Verizon Wireless 4G LTE Smartphone > > > -------- Original message -------- > From: kinne russ > Date:01/28/2015 11:46 AM (GMT-05:00) > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Bourke engine > > Undoctor you should know that your posts come thru as gibberish. At > least on a Mac. > >> On Jan 27, 2015, at 12:09 PM, undoctor > > wrote: >> >> PGh0bWw+PGhlYWQ+PG1ldGEgaHR0cC1lcXVpdj0iQ29udGVudC1UeXBlIiBjb250ZW50PSJ0ZXh0 >> L2h0bWw7IGNoYXJzZXQ9VVRGLTgiPjwvaGVhZD48Ym9keSA+PGRpdj5HcmVhdCBydW5kb3duLCBD >> aGFybGllLiBUaGFua3MhPC9kaXY+PGRpdj48YnI+PC9kaXY+PGRpdj48YnI+PC9kaXY+PGRpdj48 >> ZGl2IHN0eWxlPSJmb250LXNpemU6OXB4O2NvbG9yOiM1NzU3NTciPlNlbnQgZnJvbSBteSBWZXJp >> em9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lPC9kaXY+PC9kaXY+PGJyPjxicj48ZGl2Pi0t >> LS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS08L2Rpdj48ZGl2PkZyb206IENoYXJsaWUg >> RW5nbGFuZCA8Y2VlbmdsYW5kN0BnbWFpbC5jb20+IDwvZGl2PjxkaXY+RGF0ZTowMS8yNy8yMDE1 >> ICAxMToyNSBBTSAgKEdNVC0wNTowMCkgPC9kaXY+PGRpdj5Ubzoga29sYi1saXN0QG1hdHJvbmlj >> cy5jb20gPC9kaXY+PGRpdj5TdWJqZWN0OiBSZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lIDwv >> ZGl2PjxkaXY+PGJyPjwvZGl2PgogICAgPGRpdiBjbGFzcz0ibW96LWNpdGUtcHJlZml4Ij5IZXJl >> J3Mgb25lIHByb2plY3QgdGhhdCBzaG91bGQgZ2V0IHRoZQogICAgICBhdHRlbnRpb24gb2YgS29s >> YiBkcml2ZXJzOjxicj4KPGEgY2xhc3M9Im1vei10eHQtbGluay1mcmVldGV4dCIgaHJlZj0iaHR0 >> cDovL3d3dy5oeWJyaWRjYXJzLmNvbS9tYXpkYS1jb3VsZC1wcm9kdWNlLW1hemRhMi1ldi13aXRo >> LXJvdGFyeS1yYW5nZS1leHRlbmRlci8iPmh0dHA6Ly93d3cuaHlicmlkY2Fycy5jb20vbWF6ZGEt >> Y291bGQtcHJvZHVjZS1tYXpkYTItZXYtd2l0aC1yb3RhcnktcmFuZ2UtZXh0ZW5kZXIvPC9hPjxi >> cj4KICAgICAgPGJyPgogICAgICBUaGVyZSdzIGFsc28gYSByZXBlYXRlZGx5IHJlc3VyZmFjaW5n >> IHJ1bW9yIHRoYXQgdGhleSB3aWxsCiAgICAgIHJlLWludHJvZHVjZSB0aGUgUlg3L1JYOCBzcG9y >> dHMgY2FyIHdpdGggYSAxNlggcm90YXJ5IGVuZ2luZSAodGhlCiAgICAgIGVuZ2luZSBpcyBhbHJl >> YWR5IGRldmVsb3BlZCkuPGJyPgogICAgICA8YSBjbGFzcz0ibW96LXR4dC1saW5rLWZyZWV0ZXh0 >> IiBocmVmPSJodHRwOi8vd3d3Lm1hemRhLmNvbS9zdG9yaWVzL3JvdGFyeS8xNngvIj5odHRwOi8v >> d3d3Lm1hemRhLmNvbS9zdG9yaWVzL3JvdGFyeS8xNngvPC9hPjxicj4KICAgICAgPGJyPgogICAg >> ICBDaGFybGllPGJyPgogICAgICA8YnI+CiAgICAgIE9uIDEvMjcvMjAxNSAxMDowNCBBTSwgdW5k >> b2N0b3Igd3JvdGU6PGJyPgogICAgPC9kaXY+CiAgICA8YmxvY2txdW90ZSBjaXRlPSJtaWQ6bzk1 >> aXBzbGwwdHNvYmcybWRrNWRnbHdkLjE0MjIzNzQ2OTc1MDhAZW1haWwuYW5kcm9pZC5jb20iIHR5 >> cGU9ImNpdGUiPgogICAgICA8bWV0YSBodHRwLWVxdWl2PSJDb250ZW50LVR5cGUiIGNvbnRlbnQ9 >> InRleHQvaHRtbDsgY2hhcnNldD11dGYtOCI+CiAgICAgIDxkaXY+R29vZCB0byBoZWFyIGZyb20g >> eW91LCBQYXQuIEhvdyBhcmUgdGhpbmdzIGFjcm9zcyB0aGUgcG9uZD8KICAgICAgICAmbmJzcDtT >> dGlsbCBncm91bmRlZD8gJm5ic3A7SSBhbSBhbmQgSSBkb24ndCBsaWtlIGl0LiBIb3BlIHRvIGNo >> YW5nZSB0aGF0CiAgICAgICAgZWFybHkgZmx5aW5nIHNlYXNvbi4mbmJzcDs8L2Rpdj4KICAgICAg >> PGRpdj48YnI+CiAgICAgIDwvZGl2PgogICAgICA8ZGl2PlNvcnJ5IEkgbWlzc3BlbGxlZCBXYW5r >> ZWwuIE1lbW9yeSBnZXRzIGZ1enp5IGZyb20geWVhcnMgYWdvLiZuYnNwOzwvZGl2PgogICAgICA8 >> ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+SGVyYiwgSSB3YXMgYXdhcmUgTWF6ZGEg >> dXNlZCB0aGUgV2Fua2VsOyBkbyB0aGV5IG9yIGFueW9uZQogICAgICAgIHN0aWxsPzwvZGl2Pgog >> ICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+RGF2ZSBLdWxwPC9kaXY+CiAg >> ICAgIDxkaXY+QmV0aGxlaGVtLCBQQTwvZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaXY+ >> CiAgICAgIDxkaXY+RG8gbm90IGFyY2hpdmU8L2Rpdj4KICAgICAgPGRpdj48YnI+CiAgICAgIDwv >> ZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+CiAgICAgICAgPGRp >> diBzdHlsZT0iZm9udC1zaXplOjlweDtjb2xvcjojNTc1NzU3Ij5TZW50IGZyb20gbXkgVmVyaXpv >> bgogICAgICAgICAgV2lyZWxlc3MgNEcgTFRFIFNtYXJ0cGhvbmU8L2Rpdj4KICAgICAgPC9kaXY+ >> CiAgICAgIDxicj4KICAgICAgPGJyPgogICAgICA8ZGl2Pi0tLS0tLS0tIE9yaWdpbmFsIG1lc3Nh >> Z2UgLS0tLS0tLS08L2Rpdj4KICAgICAgPGRpdj5Gcm9tOiBIZXJiIDxoZXJiZ2hAbmN0Yy5jb20+ >> IDwvaGVyYmdoQG5jdGMuY29tPjwvZGl2PgogICAgICA8ZGl2PkRhdGU6MDEvMjcvMjAxNSA4OjI5 >> IEFNIChHTVQtMDU6MDApIDwvZGl2PgogICAgICA8ZGl2PlRvOiA8YSBjbGFzcz0ibW96LXR4dC1s >> aW5rLWFiYnJldmlhdGVkIiBocmVmPSJtYWlsdG86a29sYi1saXN0QG1hdHJvbmljcy5jb20iPmtv >> bGItbGlzdEBtYXRyb25pY3MuY29tPC9hPiA8L2Rpdj4KICAgICAgPGRpdj5TdWJqZWN0OiBSZTog >> S29sYi1MaXN0OiBCb3Vya2UgZW5naW5lIDwvZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC9k >> aXY+CiAgICAgIFBhdDxicj4KICAgICAgPGJyPgogICAgICAmbmJzcDsgSWYgbWVtb3J5IHNlcnZl >> cyxJIGJlbGlldmUsIE1hemRhIGhhcyBzb2x2ZWQgbW9zdCBvZiB0aGUKICAgICAgdGVjaG5pY2Fs >> IHByb2JsZW1zIHdpdGggdGhlIFdhbmtlbC48YnI+CiAgICAgIDxicj4KICAgICAgJm5ic3A7IGFu >> IGVhcmx5IHByb2JsZW0sIGZyb20gbWVtb3J5LCBjYW1lIGFib3V0IHdoZW4gdGhlIGZhY3RvcnkK >> ICAgICAgZGVjaWRlZCB0byB1c2Ugc3RhbmRhcmQgYXV0byBlbmdpbmUgb2lsIHRvIGx1YnJpY2F0 >> ZSB0aGUgYXBleAogICAgICBzZWFscy4uLmFuZCBzaWRlIHNlYWxzLi4uJm5ic3A7IFRoYXQgcmVz >> dWx0ZWQgaW4gc29tZSBuZWNlc3NhcnkmbmJzcDsgb2lsCiAgICAgIGJ1cm5pbmcgYW5kIGEgYnVp >> bGQgdXAgb2YgY2FyYm9uLi4uJm5ic3A7IE9uZSBjYW4gaW1hZ2luZSB0aGUgZGViYXRlCiAgICAg >> IHdoZW4gZW5naW5lZXJzIHN1Z2dlc3QgdGhhdCBsb3cgYXNoIHR3byBzdHJva2Ugb2lsIGJlIHVz >> ZWQuLi4/IDxicj4KICAgICAgPGJyPgogICAgICAmbmJzcDsgVGhlIHBvd2VyIGFuZCBmdWVsIGNv >> bnN1bXB0aW9uIGNhbWUgZnJvbSB0aGUgdHdvIHN0cm9rZQogICAgICBkZXNpZ24uLi4gRnJvbSBt >> eSBtZW1vcnkuLi4gSGVyYiA8YnI+CiAgICAgIDxicj4KICAgICAgJm5ic3A7Jm5ic3A7IDxicj4K >> ICAgICAgPGRpdiBjbGFzcz0ibW96LWNpdGUtcHJlZml4Ij5PbiAwMS8yNy8yMDE1IDA1OjQ3IEFN >> LCBQYXRyaWNrIExhZGQKICAgICAgICB3cm90ZTo8YnI+CiAgICAgIDwvZGl2PgogICAgICA8Ymxv >> Y2txdW90ZSBjaXRlPSJtaWQ6QkFZMTY3LURTNTA2RUM3QTRCRjhDMjA2RUI1MDk5Q0RFMzIwQHBo >> eC5nYmwiIHR5cGU9ImNpdGUiPgogICAgICAgIDxkaXYgZGlyPSJsdHIiPgogICAgICAgICAgPGRp >> diBzdHlsZT0iRk9OVC1TSVpFOiAxMnB0OyBGT05ULUZBTUlMWTogJ0NhbGlicmknOyBDT0xPUjoK >> ICAgICAgICAgICAgIzAwMDAwMCI+CiAgICAgICAgICAgIDxkaXY+PGZvbnQgZmFjZT0iVGltZXMg >> TmV3IFJvbWFuIj4mbHQ7Jmx0O1JlbWVtYmVyIGJhY2sgaW4KICAgICAgICAgICAgICAgIHRoZSA1 >> MHMgb3IgNjBzIHdoZW4gdGhlIFdlbmtlbCBSb3RhcnkgZW5naW5lIHdhcwogICAgICAgICAgICAg >> ICAgaW50cm9kdWNlZD8gT25lIHRyaWFuZ3VsYXIgcGlzdG9uIHdpdGggcm90YXJ5IHJhdGhlcgog >> ICAgICAgICAgICAgICAgdGhhbiByZWNpcHJvY2F0aW5nIG1vdGlvbiBhbmQgdmVyeSBmZXcgbW92 >> aW5nCiAgICAgICAgICAgICAgICBwYXJ0cz8mZ3Q7Jmd0OzwvZm9udD48L2Rpdj4KICAgICAgICAg >> ICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgICAgICAgICAgPGRpdj48Zm9udCBmYWNlPSJUaW1lcyBO >> ZXcgUm9tYW4iPkkgaGFkIGEgY2FyIHdpdGggYSBXYW5rZWwKICAgICAgICAgICAgICAgIGVuZ2lu >> ZS4gQSBiZWF1dGlmdWwgY2FyIHdpdGggdGhlIHN1cGVyIHNtb290aCBub24KICAgICAgICAgICAg >> ICAgIHZpYnJhdGluZyBlbmdpbmUuSXQgd291bGQgcnVuIGhhcHBpbHkgb24gdmVyeSBsb3cgZ3Jh >> ZGUKICAgICAgICAgICAgICAgIHBldHJvbCBidXQgb25seSBnYXZlIGFib3V0IDI1bWlsZXMgdG8g >> dGhlIGdhbGxvbi4KICAgICAgICAgICAgICAgIEFjY2VsZXJhdGlvbiB3YXMgbm90aGluZyB0byB3 >> cml0ZSBob21lIGFib3V0IGJ1dCB0aGUgbm9uCiAgICAgICAgICAgICAgICByZWNpcHJvY2F0aW5n >> IGRlc2lnbiBtYWRlIGZvciBzdXBlciBzbW9vdGggcnVubmluZy4gQXMKICAgICAgICAgICAgICAg >> IHlvdSBzYXkgdGhlIHdlYXJpbmcgb2YgdGhlIGNlcmFtaWMgdGlwcyBvZiB0aGUgdGhyZWUKICAg >> ICAgICAgICAgICAgIHBvaW50IHJvdG9yIHdhcyBpdHMgZG93bmZhbGwuIEdyZWF0IHBpdHkuIEkg >> cmVtZW1iZXIKICAgICAgICAgICAgICAgIHRoYXQgaXQgaGFkIGEgbWFudWFsIGdlYXIgc2hpZnQg >> YnV0IG5vIGNsdXRjaCBwZWRhbC4gVGhlCiAgICAgICAgICAgICAgICBjbHV0Y2ggd2FzIG9wZXJh >> dGVkIGVsZWN0cmljYWxseSB3aGVuIHlvdSBoZWxkIHRoZSBrbm9iCiAgICAgICAgICAgICAgICBv >> biB0aGUgdG9wIG9mIHRoZSBnZWFyIHN0aWNrLiBTbyB0aGUgYWN0IG9mIGNoYW5naW5nCiAgICAg >> ICAgICAgICAgICBnZWFyIGF1dG9tYXRpY2FsbHkgb3BlcmF0ZWQgdGhlIGNsdXRjaC4gSXQgaGFk >> IGEgZGV2aWNlCiAgICAgICAgICAgICAgICB3aGljaCBtYXRjaGVkJm5ic3A7IHRoZSBlbmdpbmUg >> c3BlZWQgdG8gdGhlIHdoZWVsIHNwZWVkIHdoZW4KICAgICAgICAgICAgICAgIHlvdSBjaGFuZ2Vk >> IGdlYXIuPC9mb250PjwvZGl2PgogICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9IlRpbWVzIE5l >> dyBSb21hbiI+VGhlcmUgd2VyZSBzZXZlcmFsIFdhbmtlbAogICAgICAgICAgICAgICAgYWVybyBl >> bmdpbmVzIGJlaW5nIHBsYXllZCB3aXRoIGEgZmV3IHllYXJzIGFnbyBidXQgdGhleQogICAgICAg >> ICAgICAgICAgc2VlbSB0byBoYXZlIGZhbGxlbiBieSB0aGUgd2F5c2lkZS4gUGl0eSwgaXQgaGFk >> IHN1Y2gKICAgICAgICAgICAgICAgIHByb21pc2UuPC9mb250PjwvZGl2PgogICAgICAgICAgICA8 >> ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9IlRpbWVzIE5ldyBS >> b21hbiI+UGF0PC9mb250PjwvZGl2PgogICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAg >> ICAgICAgICA8ZGl2PgogICAgICAgICAgICAgIDxkaXYgc3R5bGU9IkZPTlQtU0laRTogc21hbGw7 >> IFRFWFQtREVDT1JBVElPTjogbm9uZTsKICAgICAgICAgICAgICAgIEZPTlQtRkFNSUxZOiAmcXVv >> dDtDYWxpYnJpJnF1b3Q7OyBGT05ULVdFSUdIVDogbm9ybWFsOwogICAgICAgICAgICAgICAgQ09M >> T1I6ICMwMDAwMDA7IEZPTlQtU1RZTEU6IG5vcm1hbDsgRElTUExBWTogaW5saW5lIj48Yj5Gcm9t >> OjwvYj4KICAgICAgICAgICAgICAgIDxhIG1vei1kby1ub3Qtc2VuZD0idHJ1ZSIgdGl0bGU9ImFz >> bHNhLnJuZ0BnbWFpbC5jb20iIGhyZWY9Im1haWx0bzphc2xzYS5ybmdAZ21haWwuY29tIj5SaWNo >> YXJkIEdpcmFyZDwvYT4gPC9kaXY+CiAgICAgICAgICAgICAgPGRpdiBzdHlsZT0iRk9OVDogMTBw >> dCB0YWhvbWEiPgogICAgICAgICAgICAgICAgPGRpdiBzdHlsZT0iQkFDS0dST1VORDogI2Y1ZjVm >> NSI+CiAgICAgICAgICAgICAgICAgIDxkaXY+PGI+U2VudDo8L2I+IFN1bmRheSwgSmFudWFyeSAy >> NSwgMjAxNSAxMTowNSBQTTwvZGl2PgogICAgICAgICAgICAgICAgICA8ZGl2PjxiPlRvOjwvYj4g >> PGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIiB0aXRsZT0ia29sYi1saXN0QG1hdHJvbmljcy5jb20i >> IGhyZWY9Im1haWx0bzprb2xiLWxpc3RAbWF0cm9uaWNzLmNvbSI+a29sYi1saXN0QG1hdHJvbmlj >> cy5jb208L2E+CiAgICAgICAgICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgICAgICA8ZGl2 >> PjxiPlN1YmplY3Q6PC9iPiBSZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lPC9kaXY+CiAgICAg >> ICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICA8ZGl2 >> PiZuYnNwOzwvZGl2PgogICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgPGRpdiBzdHlsZT0i >> Rk9OVC1TSVpFOiBzbWFsbDsgVEVYVC1ERUNPUkFUSU9OOiBub25lOwogICAgICAgICAgICAgIEZP >> TlQtRkFNSUxZOiAmcXVvdDtDYWxpYnJpJnF1b3Q7OyBGT05ULVdFSUdIVDogbm9ybWFsOwogICAg >> ICAgICAgICAgIENPTE9SOiAjMDAwMDAwOyBGT05ULVNUWUxFOiBub3JtYWw7IERJU1BMQVk6IGlu >> bGluZSI+CiAgICAgICAgICAgICAgPGRpdiBkaXI9Imx0ciI+Qm91cmtlIGJ1aWx0IG1hbnkgZXhh >> bXBsZXMgb2YgaGlzIGVuZ2luZQogICAgICAgICAgICAgICAgZm9yIHRydWNrcywgb3V0Ym9hcmQg >> bW90b3JzLCBhbmQgYWlyY3JhZnQuIFRoZXkgYWxsCiAgICAgICAgICAgICAgICB3b3JrZWQsIHJh >> biBmb3IgaHVuZHJlZHMgb2YgaG91cnMgd2l0aCBsaXR0bGUgd2VhciB0bwogICAgICAgICAgICAg >> ICAgYW55IHBhcnRzLCBhbmQgcHJvZHVjZWQgdGhlIGFkdmVydGlzZWQgaG9yc2Vwb3dlci4gT25l >> CiAgICAgICAgICAgICAgICBvZiB0aGUgYWlyY3JhZnQgZW5naW5lcyBpcyBpbiB0aGUgRUFBIG11 >> c2V1bS4KICAgICAgICAgICAgICAgIDxkaXY+TGlrZSBhbnkgZW5naW5lIHRoZSBzdGFydCB1cCBj >> b3N0cyBnb2luZyBpbnRvCiAgICAgICAgICAgICAgICAgIHByb2R1Y3Rpb24gd291bGQgYmUgYXN0 >> cm9ub21pY2FsIGFuZCBmb3IgYW4gYWlyY3JhZnQKICAgICAgICAgICAgICAgICAgZW5naW5lIHRo >> ZW4gdGhlcmUgYXJlIGNlcnRpZmljYXRpb24gY29zdHMuIEFsbCBmb3IgYQogICAgICAgICAgICAg >> ICAgICBzbWFsbCBkaW1pbmlzaGluZyBtYXJrZXQuIFNhZCB0byBzYXkgaXQgd29uJ3QgaGFwcGVu >> LAogICAgICAgICAgICAgICAgICBidXQgdGhhdCdzIHRoZSB3YXkgaXQgaXMuPC9kaXY+CiAgICAg >> ICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgPGRpdj5SaWNrIEdp >> cmFyZDwvZGl2PgogICAgICAgICAgICAgICAgPGRpdj5kbyBub3QgYXJjaGl2ZTwvZGl2PgogICAg >> ICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgIDxkaXYgY2xhc3M9ImdtYWlsX2V4dHJhIj4K >> ICAgICAgICAgICAgICAgIDxkaXY+Jm5ic3A7PC9kaXY+CiAgICAgICAgICAgICAgICA8ZGl2IGNs >> YXNzPSJnbWFpbF9xdW90ZSI+T24gU3VuLCBKYW4gMjUsIDIwMTUgYXQgMTowOQogICAgICAgICAg >> ICAgICAgICBQTSwgdW5kb2N0b3IgPHNwYW4gZGlyPSJsdHIiPiZsdDs8YSBtb3otZG8tbm90LXNl >> bmQ9InRydWUiIGhyZWY9Im1haWx0bzp1bmRvY3RvckBwdGQubmV0IiB0YXJnZXQ9Il9ibGFuayI+ >> dW5kb2N0b3JAcHRkLm5ldDwvYT4mZ3Q7PC9zcGFuPgogICAgICAgICAgICAgICAgICB3cm90ZTo8 >> YnI+CiAgICAgICAgICAgICAgICAgIDxibG9ja3F1b3RlIGNsYXNzPSJnbWFpbF9xdW90ZSIgc3R5 >> bGU9IlBBRERJTkctTEVGVDoKICAgICAgICAgICAgICAgICAgICAxZXg7IE1BUkdJTjogMHB4IDBw >> eCAwcHggMC44ZXg7IEJPUkRFUi1MRUZUOiAjY2NjCiAgICAgICAgICAgICAgICAgICAgMXB4IHNv >> bGlkIj4KICAgICAgICAgICAgICAgICAgICA8ZGl2PgogICAgICAgICAgICAgICAgICAgICAgPGRp >> dj5SZW1lbWJlciBiYWNrIGluIHRoZSA1MHMgb3IgNjBzIHdoZW4gdGhlCiAgICAgICAgICAgICAg >> ICAgICAgICAgIFdlbmtlbCBSb3RhcnkgZW5naW5lIHdhcyBpbnRyb2R1Y2VkPyBPbmUKICAgICAg >> ICAgICAgICAgICAgICAgICAgdHJpYW5ndWxhciBwaXN0b24gd2l0aCByb3RhcnkgcmF0aGVyIHRo >> YW4KICAgICAgICAgICAgICAgICAgICAgICAgcmVjaXByb2NhdGluZyBtb3Rpb24gYW5kIHZlcnkg >> ZmV3IG1vdmluZyBwYXJ0cz88L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+Jm5ic3A7 >> PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICA8ZGl2Pkdvb2QgaWRlYSBhbmQgaXQgY291bGQg >> c3BpbiB2ZXJ5IGhpZ2ggcmV2cy4KICAgICAgICAgICAgICAgICAgICAgICAgUHJvYmxlbSBpcywg >> dGhleSBjYW4ndCBrZWVwIHRoZSB0aXBzIGZyb20KICAgICAgICAgICAgICAgICAgICAgICAgd2Vh >> cmluZyBvbiB0aGUgdHJpYW5ndWxhciBwaXN0b24sIHNvIHZlcnkKICAgICAgICAgICAgICAgICAg >> ICAgICAgbGltaXRlZCBhcHBsaWNhdGlvbiBpbiB0aGUgcmVhbCB3b3JsZC4gPC9kaXY+CiAgICAg >> ICAgICAgICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgICAgICAg >> PGRpdj5BbHNvIHJlbWVtYmVyIGEgY2VyYW1pYyBlbmdpbmUgb24gdGhlIGRyYXdpbmcKICAgICAg >> ICAgICAgICAgICAgICAgICAgYm9hcmRzIHdoaWNoIHdhcyB0byByaXZhbCBzbGljZWQgYnJlYWQg >> Zm9yCiAgICAgICAgICAgICAgICAgICAgICAgIGdyZWF0bmVzcy4gSGF2ZW4ndCBoZWFyZCBhbnkg >> bW9yZSBhYm91dCB0aGF0CiAgICAgICAgICAgICAgICAgICAgICAgIG9uZS4gVGhhdCdzIE9LLiBK >> dXN0IGtlZXAgaW52ZW50aW5nLCBtYW55IG91dAogICAgICAgICAgICAgICAgICAgICAgICB0aGVy >> ZSBpZGVhcyBoYXZlIGJlZW4gc3VjY2Vzc2Z1bC4gPC9kaXY+CiAgICAgICAgICAgICAgICAgICAg >> ICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgPGRpdj5EYXZlIEt1bHA8 >> L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+QmV0aGxlaGVtLCBQQTwvZGl2PgogICAg >> ICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgICAgICAgICAgICAgICAgICAg >> IDxkaXY+RG8gbm90IGFyY2hpdmU8L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+Jm5i >> c3A7PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAg >> ICAgICAgICAgICAgICAgPGRpdj4KICAgICAgICAgICAgICAgICAgICAgICAgPGRpdiBzdHlsZT0i >> Rk9OVC1TSVpFOiA5cHg7IENPTE9SOiAjNTc1NzU3Ij5TZW50CiAgICAgICAgICAgICAgICAgICAg >> ICAgICAgZnJvbSBteSBWZXJpem9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lPC9kaXY+CiAg >> ICAgICAgICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+CiAg >> ICAgICAgICAgICAgICAgICAgICAgIDxkaXYgY2xhc3M9Img1Ij48YnI+CiAgICAgICAgICAgICAg >> ICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIDxkaXY+LS0tLS0tLS0g >> T3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLTwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgICAg >> IDxkaXY+RnJvbTogQ2hhcmxpZSBFbmdsYW5kIDwvZGl2PgogICAgICAgICAgICAgICAgICAgICAg >> ICAgIDxkaXY+RGF0ZTowMS8yNS8yMDE1IDE6NDggUE0gKEdNVC0wNTowMCkgPC9kaXY+CiAgICAg >> ICAgICAgICAgICAgICAgICAgICAgPGRpdj5UbzogPGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIiBo >> cmVmPSJtYWlsdG86a29sYi1saXN0QG1hdHJvbmljcy5jb20iIHRhcmdldD0iX2JsYW5rIj5rb2xi >> LWxpc3RAbWF0cm9uaWNzLmNvbTwvYT4KICAgICAgICAgICAgICAgICAgICAgICAgICA8L2Rpdj4K >> ICAgICAgICAgICAgICAgICAgICAgICAgICA8ZGl2PlN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IEJv >> dXJrZSBlbmdpbmUgPC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8 >> L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgICAgICAtLSZndDsgS29sYi1MaXN0IG1lc3NhZ2Ug >> cG9zdGVkIGJ5OiBDaGFybGllCiAgICAgICAgICAgICAgICAgICAgICAgICAgRW5nbGFuZCAmbHQ7 >> PGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIiBocmVmPSJtYWlsdG86Y2VlbmdsYW5kN0BnbWFpbC5j >> b20iIHRhcmdldD0iX2JsYW5rIj5jZWVuZ2xhbmQ3QGdtYWlsLmNvbTwvYT4mZ3Q7PGJyPgogICAg >> ICAgICAgICAgICAgICAgICAgICAgIDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgICBPbiAx >> LzI1LzIwMTUgMTE6MTggQU0sIHdpbGxpYW0gc3VsbGl2YW4gd3JvdGU6PGJyPgogICAgICAgICAg >> ICAgICAgICAgICAgICAgICZndDsgLS0mZ3Q7IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieToK >> ICAgICAgICAgICAgICAgICAgICAgICAgICB3aWxsaWFtIHN1bGxpdmFuICZsdDs8YSBtb3otZG8t >> bm90LXNlbmQ9InRydWUiIGhyZWY9Im1haWx0bzp3aWxsaWFtdHN1bGxpdmFuQGF0dC5uZXQiIHRh >> cmdldD0iX2JsYW5rIj53aWxsaWFtdHN1bGxpdmFuQGF0dC5uZXQ8L2E+Jmd0Ozxicj4KICAgICAg >> ICAgICAgICAgICAgICAgICAgICAmZ3Q7PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgICZn >> dDsmbmJzcDsmbmJzcDsmbmJzcDsgQ2xpY2sgb24gdmFyaW91cyBzdHVmZiBpbiB0aGlzIGxpbmsu >> Jm5ic3A7CiAgICAgICAgICAgICAgICAgICAgICAgICAgTXkgYnJvdGhlciBzZW50IGl0IHRvIG1l >> LCB0aGlua2luZyBJJ2QgYmUKICAgICAgICAgICAgICAgICAgICAgICAgICBpbnRlcmVzdGVkLiZu >> YnNwOyBXaXRoIFJvdGF4IGRyb3BwaW5nIHRoZSBzbWFsbAogICAgICAgICAgICAgICAgICAgICAg >> ICAgIDItc3Ryb2tlcywgdGhlcmUgaXMgYSBuZWVkIGZvciByZXBsYWNlbWVudHMuJm5ic3A7CiAg >> ICAgICAgICAgICAgICAgICAgICAgICAgVGhlIHdlaWdodCB0byBIUCByYXRpbyBsb29rcyBwcmV0 >> dHkgZ29vZC4mbmJzcDsKICAgICAgICAgICAgICAgICAgICAgICAgICBEb2VzIGFueW9uZSBoYXZl >> IGFueSBleHBlcmllbmNlL2NvbW1lbnRzIG9uCiAgICAgICAgICAgICAgICAgICAgICAgICAgdGhp >> cyBvbmU/PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgICZndDs8YnI+CiAgICAgICAgICAg >> ICAgICAgICAgICAgICAgJmd0OyA8YSBtb3otZG8tbm90LXNlbmQ9InRydWUiIGhyZWY9Imh0dHA6 >> Ly93d3cuYm91cmtlLWVuZ2luZS5jb20vYW5pIiB0YXJnZXQ9Il9ibGFuayI+aHR0cDovL3d3dy5i >> b3Vya2UtZW5naW5lLmNvbS9hbmk8L2E+PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgICZn >> dDs8YnI+CiAgICAgICAgICAgICAgICAgICAgICAgICAgJmd0Ozxicj4KICAgICAgICAgICAgICAg >> ICAgICAgICAgICBJJ2Qgc3VnZ2VzdCBmaW5kaW5nIGFuIGluZGVwZW5kZW50IGVuZ2luZWVyaW5n >> CiAgICAgICAgICAgICAgICAgICAgICAgICAgZXZhbHVhdGlvbi4gTXkgdGhvdWdodHM6IDxicj4K >> ICAgICAgICAgICAgICAgICAgICAgICAgICBDb25zaWRlciBob3cgc2V2ZXJlIHRoZSBpbWJhbGFu >> Y2Ugd2lsbCBiZSB3aXRoCiAgICAgICAgICAgICAgICAgICAgICAgICAgYm90aCBwaXN0b25zIG1v >> dmluZyB0aGUgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIHNhbWUgZGlyZWN0aW9uLCB0 >> aGVuIGhvdyBtdWNoIHRoZQogICAgICAgICAgICAgICAgICAgICAgICAgIGNvdW50ZXJ3ZWlnaHQg >> d2lsbCB3ZWlnaCB0byBjb3VudGVyYWN0IDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgICB0 >> aGF0IGZvcmNlICh3aXRob3V0IGNvbnRyaWJ1dGluZyBhbnkgcG93ZXIpLgogICAgICAgICAgICAg >> ICAgICAgICAgICAgIFRoZW4gY29uc2lkZXIgaG93IGxvbmcgYSA8YnI+CiAgICAgICAgICAgICAg >> ICAgICAgICAgICAgc2xpZGluZyBsaW5lLWNvbnRhY3Qgc2xpZGluZyBiZWFyaW5nIGlzIGdvaW5n >> CiAgICAgICAgICAgICAgICAgICAgICAgICAgdG8gbGFzdCB3aGVuIHN1YmplY3RlZCB0byA8YnI+ >> CiAgICAgICAgICAgICAgICAgICAgICAgICAgdGhvc2UgZm9yY2VzLiBUaGUgY2xhaW0gaXMgMS80 >> IHBvdW5kICgwLjI1IGxiKQogICAgICAgICAgICAgICAgICAgICAgICAgIHBlciBocC9oci4gVGhp >> cyBpcyBiZXR0ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIGJ5IGFib3V0IDMwJSB0 >> aGFuIHRoZSBtb3N0IGVmZmljaWVudCBpbnRlcm5hbAogICAgICAgICAgICAgICAgICAgICAgICAg >> IGNvbWJ1c3Rpb24gZW5naW5lIGV2ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIGJ1 >> aWx0LCBhbmQgaXQncyBzdGlsbCBhIDIgc3Ryb2tlIGVuZ2luZS4gSXNuJ3QKICAgICAgICAgICAg >> ICAgICAgICAgICAgICBpdCBhIGJpdCBzdHJhbmdlIHRoYXQgYSA8YnI+CiAgICAgICAgICAgICAg >> ICAgICAgICAgICAgZGVzaWduIHRoYXQncyBiZWVuIGFyb3VuZCBsb25nIGVub3VnaCBmb3IgdGhl >> CiAgICAgICAgICAgICAgICAgICAgICAgICAgcGF0ZW50cyB0byBleHBpcmUsIGFuZCBpcyA8YnI+ >> CiAgICAgICAgICAgICAgICAgICAgICAgICAgc3VwZXIgY2xlYW4sIGFuZCBiZWF0cyB0aGUgYmVz >> dCB0ZWNoIG91dCB0aGVyZQogICAgICAgICAgICAgICAgICAgICAgICAgIGJ5IDMwJSwgaGFzbid0 >> IHRha2VuIG92ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIGV2ZXJ5IGVuZ2luZSBt >> YXJrZXQgb24gdGhlIHBsYW5ldD8mbmJzcDsgQW5kIGl0CiAgICAgICAgICAgICAgICAgICAgICAg >> ICAgdXNlcyAnZGV0b25hdGlvbicgdG8gZXh0cmFjdCA8YnI+CiAgICAgICAgICAgICAgICAgICAg >> ICAgICAgbW9yZSBlbmVyZ3kgZnJvbSB0aGUgZnVlbD8gV2hhdCBoYXBwZW5zIHRvIGEKICAgICAg >> ICAgICAgICAgICAgICAgICAgICBwaXN0b24gd2hlbiB5b3UgaGF2ZSA8YnI+CiAgICAgICAgICAg >> ICAgICAgICAgICAgICAgZGV0b25hdGlvbiBpbiB0aGUgY29tYnVzdGlvbiBjaGFtYmVyPyAoQW5z >> d2VyCiAgICAgICAgICAgICAgICAgICAgICAgICAgaGVscDogbm90aGluZyBnb29kLik8YnI+CiAg >> ICAgICAgICAgICAgICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIEN1 >> cnJlbnQgdGVjaG5vbG9neSBpbiA0IHN0cm9rZXMgY2FuIGNvbWUKICAgICAgICAgICAgICAgICAg >> ICAgICAgICBwcmV0dHkgY2xvc2UgdG8gdGhlIHNhbWUgPGJyPgogICAgICAgICAgICAgICAgICAg >> ICAgICAgIHBvd2VyL3dlaWdodCByYXRpbyBhcyBvbGQgdGVjaCAyIHN0cm9rZXMuIEp1c3QKICAg >> ICAgICAgICAgICAgICAgICAgICAgICBuZWVkIHNvbWVvbmUgdG8gbWFrZSB0aGVtIDxicj4KICAg >> ICAgICAgICAgICAgICAgICAgICAgICBhdmFpbGFibGUgYXQgYW4gYWZmb3JkYWJsZSBwcmljZW9s >> Yi1MaXN0IgogICAgICAgICAgICAgICAgICAgICAgICAgIHRhcmdldD0iX2JsYW5rIiZndDs8YSBt >> b3otZG8tbm90LXNlbmQ9InRydWUiIGNsYXNzPSJtb3otdHh0LWxpbmstZnJlZXRleHQiIGhyZWY9 >> Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0aHR0cDovL3d3dy5t >> YXRyb25pY3MuY29tPT09PT09PT09PT09PT09PT09Ij5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20v >> TmF2aWdhdG9yP0tvbGItTGlzdGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbT09PT09PT09PT09PT09 >> PT09PTwvYT48YnI+CiAgICAgICAgICAgICAgICAgICAgICAgICAgPGJyPgo > ~,gM4Gqz.'8*[.+-fZ+`axr^jzZ(j|n)b'!j'+ry'C > { > ,x(ZP!jrrj|-&j',r5h%lm 'ojj+*[.+-08IaT1 > jgrz{Zi^&lZ+ky+k&j',r+k&j',rhB{ky.+jY^.+-i0fr((nbxm-&j',rr&*''k{w/tml ________________________________________________________________________________
Subject: Bourke engine
Date: Jan 28, 2015
I am running Outlook 2010 on a Windows machine and undoctor=99s messages are always blank for me. However, if I log onto the Matronics web site and view them in the forum, they are fine. Also, if someone does a reply and leaves undoctor=99s comments in the reply, I USUALLY (but not always) see the text of the original message. Very strange, I have always been curious as to what causes this. Stuart From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of kinne russ Sent: Wednesday, January 28, 2015 10:47 AM Subject: Re: Kolb-List: Bourke engine Undoctor =94 you should know that your posts come thru as gibberish. At least on a Mac. On Jan 27, 2015, at 12:09 PM, undoctor wrote: PGh0bWw+PGhlYWQ+PG1ldGEgaHR0cC1lcXVpdj0iQ29udGVudC1UeXBlIiBjb250ZW50PSJ0Z Xh0 L2h0bWw7IGNoYXJzZXQ9VVRGLTgiPjwvaGVhZD48Ym9keSA+PGRpdj5HcmVhdCBydW5kb3duL CBD aGFybGllLiBUaGFua3MhPC9kaXY+PGRpdj48YnI+PC9kaXY+PGRpdj48YnI+PC9kaXY+PGRpd j48 ZGl2IHN0eWxlPSJmb250LXNpemU6OXB4O2NvbG9yOiM1NzU3NTciPlNlbnQgZnJvbSBteSBWZ XJp em9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lPC9kaXY+PC9kaXY+PGJyPjxicj48ZGl2P i0t LS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS08L2Rpdj48ZGl2PkZyb206IENoYXJsa WUg RW5nbGFuZCA8Y2VlbmdsYW5kN0BnbWFpbC5jb20+IDwvZGl2PjxkaXY+RGF0ZTowMS8yNy8yM DE1 ICAxMToyNSBBTSAgKEdNVC0wNTowMCkgPC9kaXY+PGRpdj5Ubzoga29sYi1saXN0QG1hdHJvb mlj cy5jb20gPC9kaXY+PGRpdj5TdWJqZWN0OiBSZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lI Dwv ZGl2PjxkaXY+PGJyPjwvZGl2PgogICAgPGRpdiBjbGFzcz0ibW96LWNpdGUtcHJlZml4Ij5IZ XJl J3Mgb25lIHByb2plY3QgdGhhdCBzaG91bGQgZ2V0IHRoZQogICAgICBhdHRlbnRpb24gb2YgS 29s YiBkcml2ZXJzOjxicj4KPGEgY2xhc3M9Im1vei10eHQtbGluay1mcmVldGV4dCIgaHJlZj0ia HR0 cDovL3d3dy5oeWJyaWRjYXJzLmNvbS9tYXpkYS1jb3VsZC1wcm9kdWNlLW1hemRhMi1ldi13a XRo LXJvdGFyeS1yYW5nZS1leHRlbmRlci8iPmh0dHA6Ly93d3cuaHlicmlkY2Fycy5jb20vbWF6Z GEt Y291bGQtcHJvZHVjZS1tYXpkYTItZXYtd2l0aC1yb3RhcnktcmFuZ2UtZXh0ZW5kZXIvPC9hP jxi cj4KICAgICAgPGJyPgogICAgICBUaGVyZSdzIGFsc28gYSByZXBlYXRlZGx5IHJlc3VyZmFja W5n IHJ1bW9yIHRoYXQgdGhleSB3aWxsCiAgICAgIHJlLWludHJvZHVjZSB0aGUgUlg3L1JYOCBzc G9y dHMgY2FyIHdpdGggYSAxNlggcm90YXJ5IGVuZ2luZSAodGhlCiAgICAgIGVuZ2luZSBpcyBhb HJl YWR5IGRldmVsb3BlZCkuPGJyPgogICAgICA8YSBjbGFzcz0ibW96LXR4dC1saW5rLWZyZWV0Z Xh0 IiBocmVmPSJodHRwOi8vd3d3Lm1hemRhLmNvbS9zdG9yaWVzL3JvdGFyeS8xNngvIj5odHRwO i8v d3d3Lm1hemRhLmNvbS9zdG9yaWVzL3JvdGFyeS8xNngvPC9hPjxicj4KICAgICAgPGJyPgogI CAg ICBDaGFybGllPGJyPgogICAgICA8YnI+CiAgICAgIE9uIDEvMjcvMjAxNSAxMDowNCBBTSwgd W5k b2N0b3Igd3JvdGU6PGJyPgogICAgPC9kaXY+CiAgICA8YmxvY2txdW90ZSBjaXRlPSJtaWQ6b zk1 aXBzbGwwdHNvYmcybWRrNWRnbHdkLjE0MjIzNzQ2OTc1MDhAZW1haWwuYW5kcm9pZC5jb20iI HR5 cGU9ImNpdGUiPgogICAgICA8bWV0YSBodHRwLWVxdWl2PSJDb250ZW50LVR5cGUiIGNvbnRlb nQ9 InRleHQvaHRtbDsgY2hhcnNldD11dGYtOCI+CiAgICAgIDxkaXY+R29vZCB0byBoZWFyIGZyb 20g eW91LCBQYXQuIEhvdyBhcmUgdGhpbmdzIGFjcm9zcyB0aGUgcG9uZD8KICAgICAgICAmbmJzc DtT dGlsbCBncm91bmRlZD8gJm5ic3A7SSBhbSBhbmQgSSBkb24ndCBsaWtlIGl0LiBIb3BlIHRvI GNo YW5nZSB0aGF0CiAgICAgICAgZWFybHkgZmx5aW5nIHNlYXNvbi4mbmJzcDs8L2Rpdj4KICAgI CAg PGRpdj48YnI+CiAgICAgIDwvZGl2PgogICAgICA8ZGl2PlNvcnJ5IEkgbWlzc3BlbGxlZCBXY W5r ZWwuIE1lbW9yeSBnZXRzIGZ1enp5IGZyb20geWVhcnMgYWdvLiZuYnNwOzwvZGl2PgogICAgI CA8 ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+SGVyYiwgSSB3YXMgYXdhcmUgTWF6Z GEg dXNlZCB0aGUgV2Fua2VsOyBkbyB0aGV5IG9yIGFueW9uZQogICAgICAgIHN0aWxsPzwvZGl2P gog ICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+RGF2ZSBLdWxwPC9kaXY+C iAg ICAgIDxkaXY+QmV0aGxlaGVtLCBQQTwvZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC9ka XY+ CiAgICAgIDxkaXY+RG8gbm90IGFyY2hpdmU8L2Rpdj4KICAgICAgPGRpdj48YnI+CiAgICAgI Dwv ZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+CiAgICAgICAgP GRp diBzdHlsZT0iZm9udC1zaXplOjlweDtjb2xvcjojNTc1NzU3Ij5TZW50IGZyb20gbXkgVmVya Xpv bgogICAgICAgICAgV2lyZWxlc3MgNEcgTFRFIFNtYXJ0cGhvbmU8L2Rpdj4KICAgICAgPC9ka XY+ CiAgICAgIDxicj4KICAgICAgPGJyPgogICAgICA8ZGl2Pi0tLS0tLS0tIE9yaWdpbmFsIG1lc 3Nh Z2UgLS0tLS0tLS08L2Rpdj4KICAgICAgPGRpdj5Gcm9tOiBIZXJiIDxoZXJiZ2hAbmN0Yy5jb 20+ IDwvaGVyYmdoQG5jdGMuY29tPjwvZGl2PgogICAgICA8ZGl2PkRhdGU6MDEvMjcvMjAxNSA4O jI5 IEFNIChHTVQtMDU6MDApIDwvZGl2PgogICAgICA8ZGl2PlRvOiA8YSBjbGFzcz0ibW96LXR4d C1s aW5rLWFiYnJldmlhdGVkIiBocmVmPSJtYWlsdG86a29sYi1saXN0QG1hdHJvbmljcy5jb20iP mtv bGItbGlzdEBtYXRyb25pY3MuY29tPC9hPiA8L2Rpdj4KICAgICAgPGRpdj5TdWJqZWN0OiBSZ Tog S29sYi1MaXN0OiBCb3Vya2UgZW5naW5lIDwvZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgP C9k aXY+CiAgICAgIFBhdDxicj4KICAgICAgPGJyPgogICAgICAmbmJzcDsgSWYgbWVtb3J5IHNlc nZl cyxJIGJlbGlldmUsIE1hemRhIGhhcyBzb2x2ZWQgbW9zdCBvZiB0aGUKICAgICAgdGVjaG5pY 2Fs IHByb2JsZW1zIHdpdGggdGhlIFdhbmtlbC48YnI+CiAgICAgIDxicj4KICAgICAgJm5ic3A7I GFu IGVhcmx5IHByb2JsZW0sIGZyb20gbWVtb3J5LCBjYW1lIGFib3V0IHdoZW4gdGhlIGZhY3Rvc nkK ICAgICAgZGVjaWRlZCB0byB1c2Ugc3RhbmRhcmQgYXV0byBlbmdpbmUgb2lsIHRvIGx1YnJpY 2F0 ZSB0aGUgYXBleAogICAgICBzZWFscy4uLmFuZCBzaWRlIHNlYWxzLi4uJm5ic3A7IFRoYXQgc mVz dWx0ZWQgaW4gc29tZSBuZWNlc3NhcnkmbmJzcDsgb2lsCiAgICAgIGJ1cm5pbmcgYW5kIGEgY nVp bGQgdXAgb2YgY2FyYm9uLi4uJm5ic3A7IE9uZSBjYW4gaW1hZ2luZSB0aGUgZGViYXRlCiAgI CAg IHdoZW4gZW5naW5lZXJzIHN1Z2dlc3QgdGhhdCBsb3cgYXNoIHR3byBzdHJva2Ugb2lsIGJlI HVz ZWQuLi4/IDxicj4KICAgICAgPGJyPgogICAgICAmbmJzcDsgVGhlIHBvd2VyIGFuZCBmdWVsI GNv bnN1bXB0aW9uIGNhbWUgZnJvbSB0aGUgdHdvIHN0cm9rZQogICAgICBkZXNpZ24uLi4gRnJvb SBt eSBtZW1vcnkuLi4gSGVyYiA8YnI+CiAgICAgIDxicj4KICAgICAgJm5ic3A7Jm5ic3A7IDxic j4K ICAgICAgPGRpdiBjbGFzcz0ibW96LWNpdGUtcHJlZml4Ij5PbiAwMS8yNy8yMDE1IDA1OjQ3I EFN LCBQYXRyaWNrIExhZGQKICAgICAgICB3cm90ZTo8YnI+CiAgICAgIDwvZGl2PgogICAgICA8Y mxv Y2txdW90ZSBjaXRlPSJtaWQ6QkFZMTY3LURTNTA2RUM3QTRCRjhDMjA2RUI1MDk5Q0RFMzIwQ HBo eC5nYmwiIHR5cGU9ImNpdGUiPgogICAgICAgIDxkaXYgZGlyPSJsdHIiPgogICAgICAgICAgP GRp diBzdHlsZT0iRk9OVC1TSVpFOiAxMnB0OyBGT05ULUZBTUlMWTogJ0NhbGlicmknOyBDT0xPU joK ICAgICAgICAgICAgIzAwMDAwMCI+CiAgICAgICAgICAgIDxkaXY+PGZvbnQgZmFjZT0iVGltZ XMg TmV3IFJvbWFuIj4mbHQ7Jmx0O1JlbWVtYmVyIGJhY2sgaW4KICAgICAgICAgICAgICAgIHRoZ SA1 MHMgb3IgNjBzIHdoZW4gdGhlIFdlbmtlbCBSb3RhcnkgZW5naW5lIHdhcwogICAgICAgICAgI CAg ICAgaW50cm9kdWNlZD8gT25lIHRyaWFuZ3VsYXIgcGlzdG9uIHdpdGggcm90YXJ5IHJhdGhlc gog ICAgICAgICAgICAgICAgdGhhbiByZWNpcHJvY2F0aW5nIG1vdGlvbiBhbmQgdmVyeSBmZXcgb W92 aW5nCiAgICAgICAgICAgICAgICBwYXJ0cz8mZ3Q7Jmd0OzwvZm9udD48L2Rpdj4KICAgICAgI CAg ICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgICAgICAgICAgPGRpdj48Zm9udCBmYWNlPSJUaW1lc yBO ZXcgUm9tYW4iPkkgaGFkIGEgY2FyIHdpdGggYSBXYW5rZWwKICAgICAgICAgICAgICAgIGVuZ 2lu ZS4gQSBiZWF1dGlmdWwgY2FyIHdpdGggdGhlIHN1cGVyIHNtb290aCBub24KICAgICAgICAgI CAg ICAgIHZpYnJhdGluZyBlbmdpbmUuSXQgd291bGQgcnVuIGhhcHBpbHkgb24gdmVyeSBsb3cgZ 3Jh ZGUKICAgICAgICAgICAgICAgIHBldHJvbCBidXQgb25seSBnYXZlIGFib3V0IDI1bWlsZXMgd G8g dGhlIGdhbGxvbi4KICAgICAgICAgICAgICAgIEFjY2VsZXJhdGlvbiB3YXMgbm90aGluZyB0b yB3 cml0ZSBob21lIGFib3V0IGJ1dCB0aGUgbm9uCiAgICAgICAgICAgICAgICByZWNpcHJvY2F0a W5n IGRlc2lnbiBtYWRlIGZvciBzdXBlciBzbW9vdGggcnVubmluZy4gQXMKICAgICAgICAgICAgI CAg IHlvdSBzYXkgdGhlIHdlYXJpbmcgb2YgdGhlIGNlcmFtaWMgdGlwcyBvZiB0aGUgdGhyZWUKI CAg ICAgICAgICAgICAgIHBvaW50IHJvdG9yIHdhcyBpdHMgZG93bmZhbGwuIEdyZWF0IHBpdHkuI Ekg cmVtZW1iZXIKICAgICAgICAgICAgICAgIHRoYXQgaXQgaGFkIGEgbWFudWFsIGdlYXIgc2hpZ nQg YnV0IG5vIGNsdXRjaCBwZWRhbC4gVGhlCiAgICAgICAgICAgICAgICBjbHV0Y2ggd2FzIG9wZ XJh dGVkIGVsZWN0cmljYWxseSB3aGVuIHlvdSBoZWxkIHRoZSBrbm9iCiAgICAgICAgICAgICAgI CBv biB0aGUgdG9wIG9mIHRoZSBnZWFyIHN0aWNrLiBTbyB0aGUgYWN0IG9mIGNoYW5naW5nCiAgI CAg ICAgICAgICAgICBnZWFyIGF1dG9tYXRpY2FsbHkgb3BlcmF0ZWQgdGhlIGNsdXRjaC4gSXQga GFk IGEgZGV2aWNlCiAgICAgICAgICAgICAgICB3aGljaCBtYXRjaGVkJm5ic3A7IHRoZSBlbmdpb mUg c3BlZWQgdG8gdGhlIHdoZWVsIHNwZWVkIHdoZW4KICAgICAgICAgICAgICAgIHlvdSBjaGFuZ 2Vk IGdlYXIuPC9mb250PjwvZGl2PgogICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9IlRpbWVzI E5l dyBSb21hbiI+VGhlcmUgd2VyZSBzZXZlcmFsIFdhbmtlbAogICAgICAgICAgICAgICAgYWVyb yBl bmdpbmVzIGJlaW5nIHBsYXllZCB3aXRoIGEgZmV3IHllYXJzIGFnbyBidXQgdGhleQogICAgI CAg ICAgICAgICAgc2VlbSB0byBoYXZlIGZhbGxlbiBieSB0aGUgd2F5c2lkZS4gUGl0eSwgaXQga GFk IHN1Y2gKICAgICAgICAgICAgICAgIHByb21pc2UuPC9mb250PjwvZGl2PgogICAgICAgICAgI CA8 ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9IlRpbWVzIE5ld yBS b21hbiI+UGF0PC9mb250PjwvZGl2PgogICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogI CAg ICAgICAgICA8ZGl2PgogICAgICAgICAgICAgIDxkaXYgc3R5bGU9IkZPTlQtU0laRTogc21hb Gw7 IFRFWFQtREVDT1JBVElPTjogbm9uZTsKICAgICAgICAgICAgICAgIEZPTlQtRkFNSUxZOiAmc XVv dDtDYWxpYnJpJnF1b3Q7OyBGT05ULVdFSUdIVDogbm9ybWFsOwogICAgICAgICAgICAgICAgQ 09M T1I6ICMwMDAwMDA7IEZPTlQtU1RZTEU6IG5vcm1hbDsgRElTUExBWTogaW5saW5lIj48Yj5Gc m9t OjwvYj4KICAgICAgICAgICAgICAgIDxhIG1vei1kby1ub3Qtc2VuZD0idHJ1ZSIgdGl0bGU9I mFz bHNhLnJuZ0BnbWFpbC5jb20iIGhyZWY9Im1haWx0bzphc2xzYS5ybmdAZ21haWwuY29tIj5Sa WNo YXJkIEdpcmFyZDwvYT4gPC9kaXY+CiAgICAgICAgICAgICAgPGRpdiBzdHlsZT0iRk9OVDogM TBw dCB0YWhvbWEiPgogICAgICAgICAgICAgICAgPGRpdiBzdHlsZT0iQkFDS0dST1VORDogI2Y1Z jVm NSI+CiAgICAgICAgICAgICAgICAgIDxkaXY+PGI+U2VudDo8L2I+IFN1bmRheSwgSmFudWFye SAy NSwgMjAxNSAxMTowNSBQTTwvZGl2PgogICAgICAgICAgICAgICAgICA8ZGl2PjxiPlRvOjwvY j4g PGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIiB0aXRsZT0ia29sYi1saXN0QG1hdHJvbmljcy5jb 20i IGhyZWY9Im1haWx0bzprb2xiLWxpc3RAbWF0cm9uaWNzLmNvbSI+a29sYi1saXN0QG1hdHJvb mlj cy5jb208L2E+CiAgICAgICAgICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgICAgICA8Z Gl2 PjxiPlN1YmplY3Q6PC9iPiBSZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lPC9kaXY+CiAgI CAg ICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICA8Z Gl2 PiZuYnNwOzwvZGl2PgogICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgPGRpdiBzdHlsZ T0i Rk9OVC1TSVpFOiBzbWFsbDsgVEVYVC1ERUNPUkFUSU9OOiBub25lOwogICAgICAgICAgICAgI EZP TlQtRkFNSUxZOiAmcXVvdDtDYWxpYnJpJnF1b3Q7OyBGT05ULVdFSUdIVDogbm9ybWFsOwogI CAg ICAgICAgICAgIENPTE9SOiAjMDAwMDAwOyBGT05ULVNUWUxFOiBub3JtYWw7IERJU1BMQVk6I Glu bGluZSI+CiAgICAgICAgICAgICAgPGRpdiBkaXI9Imx0ciI+Qm91cmtlIGJ1aWx0IG1hbnkgZ Xhh bXBsZXMgb2YgaGlzIGVuZ2luZQogICAgICAgICAgICAgICAgZm9yIHRydWNrcywgb3V0Ym9hc mQg bW90b3JzLCBhbmQgYWlyY3JhZnQuIFRoZXkgYWxsCiAgICAgICAgICAgICAgICB3b3JrZWQsI HJh biBmb3IgaHVuZHJlZHMgb2YgaG91cnMgd2l0aCBsaXR0bGUgd2VhciB0bwogICAgICAgICAgI CAg ICAgYW55IHBhcnRzLCBhbmQgcHJvZHVjZWQgdGhlIGFkdmVydGlzZWQgaG9yc2Vwb3dlci4gT 25l CiAgICAgICAgICAgICAgICBvZiB0aGUgYWlyY3JhZnQgZW5naW5lcyBpcyBpbiB0aGUgRUFBI G11 c2V1bS4KICAgICAgICAgICAgICAgIDxkaXY+TGlrZSBhbnkgZW5naW5lIHRoZSBzdGFydCB1c CBj b3N0cyBnb2luZyBpbnRvCiAgICAgICAgICAgICAgICAgIHByb2R1Y3Rpb24gd291bGQgYmUgY XN0 cm9ub21pY2FsIGFuZCBmb3IgYW4gYWlyY3JhZnQKICAgICAgICAgICAgICAgICAgZW5naW5lI HRo ZW4gdGhlcmUgYXJlIGNlcnRpZmljYXRpb24gY29zdHMuIEFsbCBmb3IgYQogICAgICAgICAgI CAg ICAgICBzbWFsbCBkaW1pbmlzaGluZyBtYXJrZXQuIFNhZCB0byBzYXkgaXQgd29uJ3QgaGFwc GVu LAogICAgICAgICAgICAgICAgICBidXQgdGhhdCdzIHRoZSB3YXkgaXQgaXMuPC9kaXY+CiAgI CAg ICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgPGRpdj5SaWNrI Edp cmFyZDwvZGl2PgogICAgICAgICAgICAgICAgPGRpdj5kbyBub3QgYXJjaGl2ZTwvZGl2PgogI CAg ICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgIDxkaXYgY2xhc3M9ImdtYWlsX2V4dHJhI j4K ICAgICAgICAgICAgICAgIDxkaXY+Jm5ic3A7PC9kaXY+CiAgICAgICAgICAgICAgICA8ZGl2I GNs YXNzPSJnbWFpbF9xdW90ZSI+T24gU3VuLCBKYW4gMjUsIDIwMTUgYXQgMTowOQogICAgICAgI CAg ICAgICAgICBQTSwgdW5kb2N0b3IgPHNwYW4gZGlyPSJsdHIiPiZsdDs8YSBtb3otZG8tbm90L XNl bmQ9InRydWUiIGhyZWY9Im1haWx0bzp1bmRvY3RvckBwdGQubmV0IiB0YXJnZXQ9Il9ibGFua yI+ dW5kb2N0b3JAcHRkLm5ldDwvYT4mZ3Q7PC9zcGFuPgogICAgICAgICAgICAgICAgICB3cm90Z To8 YnI+CiAgICAgICAgICAgICAgICAgIDxibG9ja3F1b3RlIGNsYXNzPSJnbWFpbF9xdW90ZSIgc 3R5 bGU9IlBBRERJTkctTEVGVDoKICAgICAgICAgICAgICAgICAgICAxZXg7IE1BUkdJTjogMHB4I DBw eCAwcHggMC44ZXg7IEJPUkRFUi1MRUZUOiAjY2NjCiAgICAgICAgICAgICAgICAgICAgMXB4I HNv bGlkIj4KICAgICAgICAgICAgICAgICAgICA8ZGl2PgogICAgICAgICAgICAgICAgICAgICAgP GRp dj5SZW1lbWJlciBiYWNrIGluIHRoZSA1MHMgb3IgNjBzIHdoZW4gdGhlCiAgICAgICAgICAgI CAg ICAgICAgICAgIFdlbmtlbCBSb3RhcnkgZW5naW5lIHdhcyBpbnRyb2R1Y2VkPyBPbmUKICAgI CAg ICAgICAgICAgICAgICAgICAgdHJpYW5ndWxhciBwaXN0b24gd2l0aCByb3RhcnkgcmF0aGVyI HRo YW4KICAgICAgICAgICAgICAgICAgICAgICAgcmVjaXByb2NhdGluZyBtb3Rpb24gYW5kIHZlc nkg ZmV3IG1vdmluZyBwYXJ0cz88L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+Jm5ic 3A7 PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICA8ZGl2Pkdvb2QgaWRlYSBhbmQgaXQgY291b GQg c3BpbiB2ZXJ5IGhpZ2ggcmV2cy4KICAgICAgICAgICAgICAgICAgICAgICAgUHJvYmxlbSBpc ywg dGhleSBjYW4ndCBrZWVwIHRoZSB0aXBzIGZyb20KICAgICAgICAgICAgICAgICAgICAgICAgd 2Vh cmluZyBvbiB0aGUgdHJpYW5ndWxhciBwaXN0b24sIHNvIHZlcnkKICAgICAgICAgICAgICAgI CAg ICAgICAgbGltaXRlZCBhcHBsaWNhdGlvbiBpbiB0aGUgcmVhbCB3b3JsZC4gPC9kaXY+CiAgI CAg ICAgICAgICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgICAgI CAg PGRpdj5BbHNvIHJlbWVtYmVyIGEgY2VyYW1pYyBlbmdpbmUgb24gdGhlIGRyYXdpbmcKICAgI CAg ICAgICAgICAgICAgICAgICAgYm9hcmRzIHdoaWNoIHdhcyB0byByaXZhbCBzbGljZWQgYnJlY WQg Zm9yCiAgICAgICAgICAgICAgICAgICAgICAgIGdyZWF0bmVzcy4gSGF2ZW4ndCBoZWFyZCBhb nkg bW9yZSBhYm91dCB0aGF0CiAgICAgICAgICAgICAgICAgICAgICAgIG9uZS4gVGhhdCdzIE9LL iBK dXN0IGtlZXAgaW52ZW50aW5nLCBtYW55IG91dAogICAgICAgICAgICAgICAgICAgICAgICB0a GVy ZSBpZGVhcyBoYXZlIGJlZW4gc3VjY2Vzc2Z1bC4gPC9kaXY+CiAgICAgICAgICAgICAgICAgI CAg ICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgPGRpdj5EYXZlIEt1b HA8 L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+QmV0aGxlaGVtLCBQQTwvZGl2PgogI CAg ICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgICAgICAgICAgICAgICAgI CAg IDxkaXY+RG8gbm90IGFyY2hpdmU8L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+J m5i c3A7PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgI CAg ICAgICAgICAgICAgICAgPGRpdj4KICAgICAgICAgICAgICAgICAgICAgICAgPGRpdiBzdHlsZ T0i Rk9OVC1TSVpFOiA5cHg7IENPTE9SOiAjNTc1NzU3Ij5TZW50CiAgICAgICAgICAgICAgICAgI CAg ICAgICAgZnJvbSBteSBWZXJpem9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lPC9kaXY+C iAg ICAgICAgICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+C iAg ICAgICAgICAgICAgICAgICAgICAgIDxkaXYgY2xhc3M9Img1Ij48YnI+CiAgICAgICAgICAgI CAg ICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIDxkaXY+LS0tLS0tL S0g T3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLTwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgI CAg IDxkaXY+RnJvbTogQ2hhcmxpZSBFbmdsYW5kIDwvZGl2PgogICAgICAgICAgICAgICAgICAgI CAg ICAgIDxkaXY+RGF0ZTowMS8yNS8yMDE1IDE6NDggUE0gKEdNVC0wNTowMCkgPC9kaXY+CiAgI CAg ICAgICAgICAgICAgICAgICAgICAgPGRpdj5UbzogPGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlI iBo cmVmPSJtYWlsdG86a29sYi1saXN0QG1hdHJvbmljcy5jb20iIHRhcmdldD0iX2JsYW5rIj5rb 2xi LWxpc3RAbWF0cm9uaWNzLmNvbTwvYT4KICAgICAgICAgICAgICAgICAgICAgICAgICA8L2Rpd j4K ICAgICAgICAgICAgICAgICAgICAgICAgICA8ZGl2PlN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6I EJv dXJrZSBlbmdpbmUgPC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzc Ds8 L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgICAgICAtLSZndDsgS29sYi1MaXN0IG1lc3NhZ 2Ug cG9zdGVkIGJ5OiBDaGFybGllCiAgICAgICAgICAgICAgICAgICAgICAgICAgRW5nbGFuZCAmb HQ7 PGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIiBocmVmPSJtYWlsdG86Y2VlbmdsYW5kN0BnbWFpb C5j b20iIHRhcmdldD0iX2JsYW5rIj5jZWVuZ2xhbmQ3QGdtYWlsLmNvbTwvYT4mZ3Q7PGJyPgogI CAg ICAgICAgICAgICAgICAgICAgICAgIDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgICBPb iAx LzI1LzIwMTUgMTE6MTggQU0sIHdpbGxpYW0gc3VsbGl2YW4gd3JvdGU6PGJyPgogICAgICAgI CAg ICAgICAgICAgICAgICAgICZndDsgLS0mZ3Q7IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBie ToK ICAgICAgICAgICAgICAgICAgICAgICAgICB3aWxsaWFtIHN1bGxpdmFuICZsdDs8YSBtb3otZ G8t bm90LXNlbmQ9InRydWUiIGhyZWY9Im1haWx0bzp3aWxsaWFtdHN1bGxpdmFuQGF0dC5uZXQiI HRh cmdldD0iX2JsYW5rIj53aWxsaWFtdHN1bGxpdmFuQGF0dC5uZXQ8L2E+Jmd0Ozxicj4KICAgI CAg ICAgICAgICAgICAgICAgICAgICAmZ3Q7PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgI CZn dDsmbmJzcDsmbmJzcDsmbmJzcDsgQ2xpY2sgb24gdmFyaW91cyBzdHVmZiBpbiB0aGlzIGxpb msu Jm5ic3A7CiAgICAgICAgICAgICAgICAgICAgICAgICAgTXkgYnJvdGhlciBzZW50IGl0IHRvI G1l LCB0aGlua2luZyBJJ2QgYmUKICAgICAgICAgICAgICAgICAgICAgICAgICBpbnRlcmVzdGVkL iZu YnNwOyBXaXRoIFJvdGF4IGRyb3BwaW5nIHRoZSBzbWFsbAogICAgICAgICAgICAgICAgICAgI CAg ICAgIDItc3Ryb2tlcywgdGhlcmUgaXMgYSBuZWVkIGZvciByZXBsYWNlbWVudHMuJm5ic3A7C iAg ICAgICAgICAgICAgICAgICAgICAgICAgVGhlIHdlaWdodCB0byBIUCByYXRpbyBsb29rcyBwc mV0 dHkgZ29vZC4mbmJzcDsKICAgICAgICAgICAgICAgICAgICAgICAgICBEb2VzIGFueW9uZSBoY XZl IGFueSBleHBlcmllbmNlL2NvbW1lbnRzIG9uCiAgICAgICAgICAgICAgICAgICAgICAgICAgd Ghp cyBvbmU/PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgICZndDs8YnI+CiAgICAgICAgI CAg ICAgICAgICAgICAgICAgJmd0OyA8YSBtb3otZG8tbm90LXNlbmQ9InRydWUiIGhyZWY9Imh0d HA6 Ly93d3cuYm91cmtlLWVuZ2luZS5jb20vYW5pIiB0YXJnZXQ9Il9ibGFuayI+aHR0cDovL3d3d y5i b3Vya2UtZW5naW5lLmNvbS9hbmk8L2E+PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgI CZn dDs8YnI+CiAgICAgICAgICAgICAgICAgICAgICAgICAgJmd0Ozxicj4KICAgICAgICAgICAgI CAg ICAgICAgICAgICBJJ2Qgc3VnZ2VzdCBmaW5kaW5nIGFuIGluZGVwZW5kZW50IGVuZ2luZWVya W5n CiAgICAgICAgICAgICAgICAgICAgICAgICAgZXZhbHVhdGlvbi4gTXkgdGhvdWdodHM6IDxic j4K ICAgICAgICAgICAgICAgICAgICAgICAgICBDb25zaWRlciBob3cgc2V2ZXJlIHRoZSBpbWJhb GFu Y2Ugd2lsbCBiZSB3aXRoCiAgICAgICAgICAgICAgICAgICAgICAgICAgYm90aCBwaXN0b25zI G1v dmluZyB0aGUgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIHNhbWUgZGlyZWN0aW9uL CB0 aGVuIGhvdyBtdWNoIHRoZQogICAgICAgICAgICAgICAgICAgICAgICAgIGNvdW50ZXJ3ZWlna HQg d2lsbCB3ZWlnaCB0byBjb3VudGVyYWN0IDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgI CB0 aGF0IGZvcmNlICh3aXRob3V0IGNvbnRyaWJ1dGluZyBhbnkgcG93ZXIpLgogICAgICAgICAgI CAg ICAgICAgICAgICAgIFRoZW4gY29uc2lkZXIgaG93IGxvbmcgYSA8YnI+CiAgICAgICAgICAgI CAg ICAgICAgICAgICAgc2xpZGluZyBsaW5lLWNvbnRhY3Qgc2xpZGluZyBiZWFyaW5nIGlzIGdva W5n CiAgICAgICAgICAgICAgICAgICAgICAgICAgdG8gbGFzdCB3aGVuIHN1YmplY3RlZCB0byA8Y nI+ CiAgICAgICAgICAgICAgICAgICAgICAgICAgdGhvc2UgZm9yY2VzLiBUaGUgY2xhaW0gaXMgM S80 IHBvdW5kICgwLjI1IGxiKQogICAgICAgICAgICAgICAgICAgICAgICAgIHBlciBocC9oci4gV Ghp cyBpcyBiZXR0ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIGJ5IGFib3V0IDMwJ SB0 aGFuIHRoZSBtb3N0IGVmZmljaWVudCBpbnRlcm5hbAogICAgICAgICAgICAgICAgICAgICAgI CAg IGNvbWJ1c3Rpb24gZW5naW5lIGV2ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgI GJ1 aWx0LCBhbmQgaXQncyBzdGlsbCBhIDIgc3Ryb2tlIGVuZ2luZS4gSXNuJ3QKICAgICAgICAgI CAg ICAgICAgICAgICAgICBpdCBhIGJpdCBzdHJhbmdlIHRoYXQgYSA8YnI+CiAgICAgICAgICAgI CAg ICAgICAgICAgICAgZGVzaWduIHRoYXQncyBiZWVuIGFyb3VuZCBsb25nIGVub3VnaCBmb3Igd Ghl CiAgICAgICAgICAgICAgICAgICAgICAgICAgcGF0ZW50cyB0byBleHBpcmUsIGFuZCBpcyA8Y nI+ CiAgICAgICAgICAgICAgICAgICAgICAgICAgc3VwZXIgY2xlYW4sIGFuZCBiZWF0cyB0aGUgY mVz dCB0ZWNoIG91dCB0aGVyZQogICAgICAgICAgICAgICAgICAgICAgICAgIGJ5IDMwJSwgaGFzb id0 IHRha2VuIG92ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIGV2ZXJ5IGVuZ2luZ SBt YXJrZXQgb24gdGhlIHBsYW5ldD8mbmJzcDsgQW5kIGl0CiAgICAgICAgICAgICAgICAgICAgI CAg ICAgdXNlcyAnZGV0b25hdGlvbicgdG8gZXh0cmFjdCA8YnI+CiAgICAgICAgICAgICAgICAgI CAg ICAgICAgbW9yZSBlbmVyZ3kgZnJvbSB0aGUgZnVlbD8gV2hhdCBoYXBwZW5zIHRvIGEKICAgI CAg ICAgICAgICAgICAgICAgICAgICBwaXN0b24gd2hlbiB5b3UgaGF2ZSA8YnI+CiAgICAgICAgI CAg ICAgICAgICAgICAgICAgZGV0b25hdGlvbiBpbiB0aGUgY29tYnVzdGlvbiBjaGFtYmVyPyAoQ W5z d2VyCiAgICAgICAgICAgICAgICAgICAgICAgICAgaGVscDogbm90aGluZyBnb29kLik8YnI+C iAg ICAgICAgICAgICAgICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgI EN1 cnJlbnQgdGVjaG5vbG9neSBpbiA0IHN0cm9rZXMgY2FuIGNvbWUKICAgICAgICAgICAgICAgI CAg ICAgICAgICBwcmV0dHkgY2xvc2UgdG8gdGhlIHNhbWUgPGJyPgogICAgICAgICAgICAgICAgI CAg ICAgICAgIHBvd2VyL3dlaWdodCByYXRpbyBhcyBvbGQgdGVjaCAyIHN0cm9rZXMuIEp1c3QKI CAg ICAgICAgICAgICAgICAgICAgICAgICBuZWVkIHNvbWVvbmUgdG8gbWFrZSB0aGVtIDxicj4KI CAg ICAgICAgICAgICAgICAgICAgICAgICBhdmFpbGFibGUgYXQgYW4gYWZmb3JkYWJsZSBwcmljZ W9s Yi1MaXN0IgogICAgICAgICAgICAgICAgICAgICAgICAgIHRhcmdldD0iX2JsYW5rIiZndDs8Y SBt b3otZG8tbm90LXNlbmQ9InRydWUiIGNsYXNzPSJtb3otdHh0LWxpbmstZnJlZXRleHQiIGhyZ WY9 Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0aHR0cDovL3d3d y5t YXRyb25pY3MuY29tPT09PT09PT09PT09PT09PT09Ij5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb 20v TmF2aWdhdG9yP0tvbGItTGlzdGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbT09PT09PT09PT09P T09 PT09PTwvYT48YnI+CiAgICAgICAgICAgICAgICAgICAgICAgICAgPGJyPgogICAgICAgICAgI CAg ICAgICAgICAgICAgIDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgICA8YnI+CiAgICAgI CAg ICAgICAgICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgPC9kaXY+CiAgI CAg ICAgICAgICAgICAgICAgPC9kaXY+CiAgICAgICAgICAgICAgICAgIDwvYmxvY2txdW90ZT4KI CAg ICAgICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgI CAg PGJyIGNsZWFyPSJhbGwiPgogICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgI CAg ICAgICAgICAgIC0tIDxicj4KICAgICAgICAgICAgICAgIDxkaXYgY2xhc3M9ImdtYWlsX3NpZ 25h dHVyZSI+CiAgICAgICAgICAgICAgICAgIDxkaXYgZGlyPSJsdHIiPgogICAgICAgICAgICAgI CAg ICAgIDxkaXY+Jm5ic3A7PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8L 2Rp dj4KICAgICAgICAgICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9ImFyaWFsLCBzYW5zLXNlc mlm Ij48c3BhbiBzdHlsZT0iRk9OVC1TSVpFOiAxM3B4Ij5CZWxpZXZlIHRob3NlIHdobyBhcmUKI CAg ICAgICAgICAgICAgICAgICAgICAgICBzZWVraW5nIHRoZSB0cnV0aCwgZG91YnQgdGhvc2Ugd 2hv IGZpbmQgaXQuPC9zcGFuPjwvZm9udD48L2Rpdj4KICAgICAgICAgICAgICAgICAgICA8ZGl2P jxm b250IGZhY2U9ImFyaWFsLCBzYW5zLXNlcmlmIj48c3BhbiBzdHlsZT0iRk9OVC1TSVpFOiAxM 3B4 Ij4tQW5kcmUgR2lkZTwvc3Bhbj48L2ZvbnQ+PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgP GJy PgogICAgICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICAgIDwvZGl2PgogICAgI CAg ICAgICAgIDwvZGl2PgogICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgIDwvZGl2PgogICAgI CAg IDwvZGl2PgogICAgICA8L2Jsb2NrcXVvdGU+CiAgICA8L2Jsb2NrcXVvdGU+CiAgICA8YnI+C iAg CgoKPHByZT48Yj48Zm9udCBzaXplPSIyIiBjb2xvcj0iIzAwMDAwMCIgZmFjZT0iY291cmllc iBu ZXcsY291cmllciI+CgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09P T09 PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgLSBUaGUgS29sYi1MaXN0IEVtYWlsI EZv cnVtIC0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvI GJy b3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjc mlw dGlvbiwKXy09IEFyY2hpdmUgU2VhcmNoICZhbXA7IERvd25sb2FkLCA3LURheSBCcm93c2UsI ENo YXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgI C0t Jmd0OyA8YSBocmVmPSJodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGItT Glz dCI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Lb2xiLUxpc3Q8L2E+Cl8tP Qpf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09P T09 PT09PQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhb WUg Z3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfL T0g ICAtLSZndDsgPGEgaHJlZj0iaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tIj5odHRwOi8vZ m9y dW1zLm1hdHJvbmljcy5jb208L2E+Cl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09P T09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgLSBMaXN0I ENv bnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzI HN1 cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgT Glz dCBBZG1pbi4KXy09ICAgLS0mZ3Q7IDxhIGhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvb S9j b250cmlidXRpb24iPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb248L2E+C l8t PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09P T09 PT09Cgo8L2ZvbnQ+PC9iPjwvcHJlPjwvYm9keT4= class="">http://www.matronics.com/Navigator?Kolb-List class="">http://forums.matronics.com class="">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 28, 2015
Subject: Re: Bourke engine
When in doubt, blame Outlook. :-) Seriously, check on whether Outlook is set to display only plain text, or some similar setting. Charlie Win7 using Thunderbird email client On 1/28/2015 6:03 PM, Stuart Harner wrote: > > I am running Outlook 2010 on a Windows machine and undoctors messages > are always blank for me. > > However, if I log onto the Matronics web site and view them in the > forum, they are fine. Also, if someone does a reply and leaves > undoctors comments in the reply, I USUALLY (but not always) see the > text of the original message. > > Very strange, I have always been curious as to what causes this. > > Stuart > > *From:*owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] *On Behalf Of *kinne russ > *Sent:* Wednesday, January 28, 2015 10:47 AM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: Bourke engine > > Undoctor you should know that your posts come thru as gibberish. At > least on a Mac. > > > On Jan 27, 2015, at 12:09 PM, undoctor > wrote: > > PGh0bWw+PGhlYWQ+PG1ldGEgaHR0cC1lcXVpdj0iQ29udGVudC1UeXBlIiBjb250ZW50PSJ0ZXh0 > L2h0bWw7IGNoYXJzZXQ9VVRGLTgiPjwvaGVhZD48Ym9keSA+PGRpdj5HcmVhdCBydW5kb3duLCBD > aGFybGllLiBUaGFua3MhPC9kaXY+PGRpdj48YnI+PC9kaXY+PGRpdj48YnI+PC9kaXY+PGRpdj48 > ZGl2IHN0eWxlPSJmb250LXNpemU6OXB4O2NvbG9yOiM1NzU3NTciPlNlbnQgZnJvbSBteSBWZXJp > em9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lPC9kaXY+PC9kaXY+PGJyPjxicj48ZGl2Pi0t > LS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS08L2Rpdj48ZGl2PkZyb206IENoYXJsaWUg > RW5nbGFuZCA8Y2VlbmdsYW5kN0BnbWFpbC5jb20+IDwvZGl2PjxkaXY+RGF0ZTowMS8yNy8yMDE1 > ICAxMToyNSBBTSAgKEdNVC0wNTowMCkgPC9kaXY+PGRpdj5Ubzoga29sYi1saXN0QG1hdHJvbmlj > cy5jb20gPC9kaXY+PGRpdj5TdWJqZWN0OiBSZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lIDwv > ZGl2PjxkaXY+PGJyPjwvZGl2PgogICAgPGRpdiBjbGFzcz0ibW96LWNpdGUtcHJlZml4Ij5IZXJl > J3Mgb25lIHByb2plY3QgdGhhdCBzaG91bGQgZ2V0IHRoZQogICAgICBhdHRlbnRpb24gb2YgS29s > YiBkcml2ZXJzOjxicj4KPGEgY2xhc3M9Im1vei10eHQtbGluay1mcmVldGV4dCIgaHJlZj0iaHR0 > cDovL3d3dy5oeWJyaWRjYXJzLmNvbS9tYXpkYS1jb3VsZC1wcm9kdWNlLW1hemRhMi1ldi13aXRo > LXJvdGFyeS1yYW5nZS1leHRlbmRlci8iPmh0dHA6Ly93d3cuaHlicmlkY2Fycy5jb20vbWF6ZGEt > Y291bGQtcHJvZHVjZS1tYXpkYTItZXYtd2l0aC1yb3RhcnktcmFuZ2UtZXh0ZW5kZXIvPC9hPjxi > cj4KICAgICAgPGJyPgogICAgICBUaGVyZSdzIGFsc28gYSByZXBlYXRlZGx5IHJlc3VyZmFjaW5n > IHJ1bW9yIHRoYXQgdGhleSB3aWxsCiAgICAgIHJlLWludHJvZHVjZSB0aGUgUlg3L1JYOCBzcG9y > dHMgY2FyIHdpdGggYSAxNlggcm90YXJ5IGVuZ2luZSAodGhlCiAgICAgIGVuZ2luZSBpcyBhbHJl > YWR5IGRldmVsb3BlZCkuPGJyPgogICAgICA8YSBjbGFzcz0ibW96LXR4dC1saW5rLWZyZWV0ZXh0 > IiBocmVmPSJodHRwOi8vd3d3Lm1hemRhLmNvbS9zdG9yaWVzL3JvdGFyeS8xNngvIj5odHRwOi8v > d3d3Lm1hemRhLmNvbS9zdG9yaWVzL3JvdGFyeS8xNngvPC9hPjxicj4KICAgICAgPGJyPgogICAg > ICBDaGFybGllPGJyPgogICAgICA8YnI+CiAgICAgIE9uIDEvMjcvMjAxNSAxMDowNCBBTSwgdW5k > b2N0b3Igd3JvdGU6PGJyPgogICAgPC9kaXY+CiAgICA8YmxvY2txdW90ZSBjaXRlPSJtaWQ6bzk1 > aXBzbGwwdHNvYmcybWRrNWRnbHdkLjE0MjIzNzQ2OTc1MDhAZW1haWwuYW5kcm9pZC5jb20iIHR5 > cGU9ImNpdGUiPgogICAgICA8bWV0YSBodHRwLWVxdWl2PSJDb250ZW50LVR5cGUiIGNvbnRlbnQ9 > InRleHQvaHRtbDsgY2hhcnNldD11dGYtOCI+CiAgICAgIDxkaXY+R29vZCB0byBoZWFyIGZyb20g > eW91LCBQYXQuIEhvdyBhcmUgdGhpbmdzIGFjcm9zcyB0aGUgcG9uZD8KICAgICAgICAmbmJzcDtT > dGlsbCBncm91bmRlZD8gJm5ic3A7SSBhbSBhbmQgSSBkb24ndCBsaWtlIGl0LiBIb3BlIHRvIGNo > YW5nZSB0aGF0CiAgICAgICAgZWFybHkgZmx5aW5nIHNlYXNvbi4mbmJzcDs8L2Rpdj4KICAgICAg > PGRpdj48YnI+CiAgICAgIDwvZGl2PgogICAgICA8ZGl2PlNvcnJ5IEkgbWlzc3BlbGxlZCBXYW5r > ZWwuIE1lbW9yeSBnZXRzIGZ1enp5IGZyb20geWVhcnMgYWdvLiZuYnNwOzwvZGl2PgogICAgICA8 > ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+SGVyYiwgSSB3YXMgYXdhcmUgTWF6ZGEg > dXNlZCB0aGUgV2Fua2VsOyBkbyB0aGV5IG9yIGFueW9uZQogICAgICAgIHN0aWxsPzwvZGl2Pgog > ICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+RGF2ZSBLdWxwPC9kaXY+CiAg > ICAgIDxkaXY+QmV0aGxlaGVtLCBQQTwvZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaXY+ > CiAgICAgIDxkaXY+RG8gbm90IGFyY2hpdmU8L2Rpdj4KICAgICAgPGRpdj48YnI+CiAgICAgIDwv > ZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC9kaXY+CiAgICAgIDxkaXY+CiAgICAgICAgPGRp > diBzdHlsZT0iZm9udC1zaXplOjlweDtjb2xvcjojNTc1NzU3Ij5TZW50IGZyb20gbXkgVmVyaXpv > bgogICAgICAgICAgV2lyZWxlc3MgNEcgTFRFIFNtYXJ0cGhvbmU8L2Rpdj4KICAgICAgPC9kaXY+ > CiAgICAgIDxicj4KICAgICAgPGJyPgogICAgICA8ZGl2Pi0tLS0tLS0tIE9yaWdpbmFsIG1lc3Nh > Z2UgLS0tLS0tLS08L2Rpdj4KICAgICAgPGRpdj5Gcm9tOiBIZXJiIDxoZXJiZ2hAbmN0Yy5jb20+ > IDwvaGVyYmdoQG5jdGMuY29tPjwvZGl2PgogICAgICA8ZGl2PkRhdGU6MDEvMjcvMjAxNSA4OjI5 > IEFNIChHTVQtMDU6MDApIDwvZGl2PgogICAgICA8ZGl2PlRvOiA8YSBjbGFzcz0ibW96LXR4dC1s > aW5rLWFiYnJldmlhdGVkIiBocmVmPSJtYWlsdG86a29sYi1saXN0QG1hdHJvbmljcy5jb20iPmtv > bGItbGlzdEBtYXRyb25pY3MuY29tPC9hPiA8L2Rpdj4KICAgICAgPGRpdj5TdWJqZWN0OiBSZTog > S29sYi1MaXN0OiBCb3Vya2UgZW5naW5lIDwvZGl2PgogICAgICA8ZGl2Pjxicj4KICAgICAgPC9k > aXY+CiAgICAgIFBhdDxicj4KICAgICAgPGJyPgogICAgICAmbmJzcDsgSWYgbWVtb3J5IHNlcnZl > cyxJIGJlbGlldmUsIE1hemRhIGhhcyBzb2x2ZWQgbW9zdCBvZiB0aGUKICAgICAgdGVjaG5pY2Fs > IHByb2JsZW1zIHdpdGggdGhlIFdhbmtlbC48YnI+CiAgICAgIDxicj4KICAgICAgJm5ic3A7IGFu > IGVhcmx5IHByb2JsZW0sIGZyb20gbWVtb3J5LCBjYW1lIGFib3V0IHdoZW4gdGhlIGZhY3RvcnkK > ICAgICAgZGVjaWRlZCB0byB1c2Ugc3RhbmRhcmQgYXV0byBlbmdpbmUgb2lsIHRvIGx1YnJpY2F0 > ZSB0aGUgYXBleAogICAgICBzZWFscy4uLmFuZCBzaWRlIHNlYWxzLi4uJm5ic3A7IFRoYXQgcmVz > dWx0ZWQgaW4gc29tZSBuZWNlc3NhcnkmbmJzcDsgb2lsCiAgICAgIGJ1cm5pbmcgYW5kIGEgYnVp > bGQgdXAgb2YgY2FyYm9uLi4uJm5ic3A7IE9uZSBjYW4gaW1hZ2luZSB0aGUgZGViYXRlCiAgICAg > IHdoZW4gZW5naW5lZXJzIHN1Z2dlc3QgdGhhdCBsb3cgYXNoIHR3byBzdHJva2Ugb2lsIGJlIHVz > ZWQuLi4/IDxicj4KICAgICAgPGJyPgogICAgICAmbmJzcDsgVGhlIHBvd2VyIGFuZCBmdWVsIGNv > bnN1bXB0aW9uIGNhbWUgZnJvbSB0aGUgdHdvIHN0cm9rZQogICAgICBkZXNpZ24uLi4gRnJvbSBt > eSBtZW1vcnkuLi4gSGVyYiA8YnI+CiAgICAgIDxicj4KICAgICAgJm5ic3A7Jm5ic3A7IDxicj4K > ICAgICAgPGRpdiBjbGFzcz0ibW96LWNpdGUtcHJlZml4Ij5PbiAwMS8yNy8yMDE1IDA1OjQ3IEFN > LCBQYXRyaWNrIExhZGQKICAgICAgICB3cm90ZTo8YnI+CiAgICAgIDwvZGl2PgogICAgICA8Ymxv > Y2txdW90ZSBjaXRlPSJtaWQ6QkFZMTY3LURTNTA2RUM3QTRCRjhDMjA2RUI1MDk5Q0RFMzIwQHBo > eC5nYmwiIHR5cGU9ImNpdGUiPgogICAgICAgIDxkaXYgZGlyPSJsdHIiPgogICAgICAgICAgPGRp > diBzdHlsZT0iRk9OVC1TSVpFOiAxMnB0OyBGT05ULUZBTUlMWTogJ0NhbGlicmknOyBDT0xPUjoK > ICAgICAgICAgICAgIzAwMDAwMCI+CiAgICAgICAgICAgIDxkaXY+PGZvbnQgZmFjZT0iVGltZXMg > TmV3IFJvbWFuIj4mbHQ7Jmx0O1JlbWVtYmVyIGJhY2sgaW4KICAgICAgICAgICAgICAgIHRoZSA1 > MHMgb3IgNjBzIHdoZW4gdGhlIFdlbmtlbCBSb3RhcnkgZW5naW5lIHdhcwogICAgICAgICAgICAg > ICAgaW50cm9kdWNlZD8gT25lIHRyaWFuZ3VsYXIgcGlzdG9uIHdpdGggcm90YXJ5IHJhdGhlcgog > ICAgICAgICAgICAgICAgdGhhbiByZWNpcHJvY2F0aW5nIG1vdGlvbiBhbmQgdmVyeSBmZXcgbW92 > aW5nCiAgICAgICAgICAgICAgICBwYXJ0cz8mZ3Q7Jmd0OzwvZm9udD48L2Rpdj4KICAgICAgICAg > ICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgICAgICAgICAgPGRpdj48Zm9udCBmYWNlPSJUaW1lcyBO > ZXcgUm9tYW4iPkkgaGFkIGEgY2FyIHdpdGggYSBXYW5rZWwKICAgICAgICAgICAgICAgIGVuZ2lu > ZS4gQSBiZWF1dGlmdWwgY2FyIHdpdGggdGhlIHN1cGVyIHNtb290aCBub24KICAgICAgICAgICAg > ICAgIHZpYnJhdGluZyBlbmdpbmUuSXQgd291bGQgcnVuIGhhcHBpbHkgb24gdmVyeSBsb3cgZ3Jh > ZGUKICAgICAgICAgICAgICAgIHBldHJvbCBidXQgb25seSBnYXZlIGFib3V0IDI1bWlsZXMgdG8g > dGhlIGdhbGxvbi4KICAgICAgICAgICAgICAgIEFjY2VsZXJhdGlvbiB3YXMgbm90aGluZyB0byB3 > cml0ZSBob21lIGFib3V0IGJ1dCB0aGUgbm9uCiAgICAgICAgICAgICAgICByZWNpcHJvY2F0aW5n > IGRlc2lnbiBtYWRlIGZvciBzdXBlciBzbW9vdGggcnVubmluZy4gQXMKICAgICAgICAgICAgICAg > IHlvdSBzYXkgdGhlIHdlYXJpbmcgb2YgdGhlIGNlcmFtaWMgdGlwcyBvZiB0aGUgdGhyZWUKICAg > ICAgICAgICAgICAgIHBvaW50IHJvdG9yIHdhcyBpdHMgZG93bmZhbGwuIEdyZWF0IHBpdHkuIEkg > cmVtZW1iZXIKICAgICAgICAgICAgICAgIHRoYXQgaXQgaGFkIGEgbWFudWFsIGdlYXIgc2hpZnQg > YnV0IG5vIGNsdXRjaCBwZWRhbC4gVGhlCiAgICAgICAgICAgICAgICBjbHV0Y2ggd2FzIG9wZXJh > dGVkIGVsZWN0cmljYWxseSB3aGVuIHlvdSBoZWxkIHRoZSBrbm9iCiAgICAgICAgICAgICAgICBv > biB0aGUgdG9wIG9mIHRoZSBnZWFyIHN0aWNrLiBTbyB0aGUgYWN0IG9mIGNoYW5naW5nCiAgICAg > ICAgICAgICAgICBnZWFyIGF1dG9tYXRpY2FsbHkgb3BlcmF0ZWQgdGhlIGNsdXRjaC4gSXQgaGFk > IGEgZGV2aWNlCiAgICAgICAgICAgICAgICB3aGljaCBtYXRjaGVkJm5ic3A7IHRoZSBlbmdpbmUg > c3BlZWQgdG8gdGhlIHdoZWVsIHNwZWVkIHdoZW4KICAgICAgICAgICAgICAgIHlvdSBjaGFuZ2Vk > IGdlYXIuPC9mb250PjwvZGl2PgogICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9IlRpbWVzIE5l > dyBSb21hbiI+VGhlcmUgd2VyZSBzZXZlcmFsIFdhbmtlbAogICAgICAgICAgICAgICAgYWVybyBl > bmdpbmVzIGJlaW5nIHBsYXllZCB3aXRoIGEgZmV3IHllYXJzIGFnbyBidXQgdGhleQogICAgICAg > ICAgICAgICAgc2VlbSB0byBoYXZlIGZhbGxlbiBieSB0aGUgd2F5c2lkZS4gUGl0eSwgaXQgaGFk > IHN1Y2gKICAgICAgICAgICAgICAgIHByb21pc2UuPC9mb250PjwvZGl2PgogICAgICAgICAgICA8 > ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9IlRpbWVzIE5ldyBS > b21hbiI+UGF0PC9mb250PjwvZGl2PgogICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAg > ICAgICAgICA8ZGl2PgogICAgICAgICAgICAgIDxkaXYgc3R5bGU9IkZPTlQtU0laRTogc21hbGw7 > IFRFWFQtREVDT1JBVElPTjogbm9uZTsKICAgICAgICAgICAgICAgIEZPTlQtRkFNSUxZOiAmcXVv > dDtDYWxpYnJpJnF1b3Q7OyBGT05ULVdFSUdIVDogbm9ybWFsOwogICAgICAgICAgICAgICAgQ09M > T1I6ICMwMDAwMDA7IEZPTlQtU1RZTEU6IG5vcm1hbDsgRElTUExBWTogaW5saW5lIj48Yj5Gcm9t > OjwvYj4KICAgICAgICAgICAgICAgIDxhIG1vei1kby1ub3Qtc2VuZD0idHJ1ZSIgdGl0bGU9ImFz > bHNhLnJuZ0BnbWFpbC5jb20iIGhyZWY9Im1haWx0bzphc2xzYS5ybmdAZ21haWwuY29tIj5SaWNo > YXJkIEdpcmFyZDwvYT4gPC9kaXY+CiAgICAgICAgICAgICAgPGRpdiBzdHlsZT0iRk9OVDogMTBw > dCB0YWhvbWEiPgogICAgICAgICAgICAgICAgPGRpdiBzdHlsZT0iQkFDS0dST1VORDogI2Y1ZjVm > NSI+CiAgICAgICAgICAgICAgICAgIDxkaXY+PGI+U2VudDo8L2I+IFN1bmRheSwgSmFudWFyeSAy > NSwgMjAxNSAxMTowNSBQTTwvZGl2PgogICAgICAgICAgICAgICAgICA8ZGl2PjxiPlRvOjwvYj4g > PGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIiB0aXRsZT0ia29sYi1saXN0QG1hdHJvbmljcy5jb20i > IGhyZWY9Im1haWx0bzprb2xiLWxpc3RAbWF0cm9uaWNzLmNvbSI+a29sYi1saXN0QG1hdHJvbmlj > cy5jb208L2E+CiAgICAgICAgICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgICAgICA8ZGl2 > PjxiPlN1YmplY3Q6PC9iPiBSZTogS29sYi1MaXN0OiBCb3Vya2UgZW5naW5lPC9kaXY+CiAgICAg > ICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICA8ZGl2 > PiZuYnNwOzwvZGl2PgogICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgPGRpdiBzdHlsZT0i > Rk9OVC1TSVpFOiBzbWFsbDsgVEVYVC1ERUNPUkFUSU9OOiBub25lOwogICAgICAgICAgICAgIEZP > TlQtRkFNSUxZOiAmcXVvdDtDYWxpYnJpJnF1b3Q7OyBGT05ULVdFSUdIVDogbm9ybWFsOwogICAg > ICAgICAgICAgIENPTE9SOiAjMDAwMDAwOyBGT05ULVNUWUxFOiBub3JtYWw7IERJU1BMQVk6IGlu > bGluZSI+CiAgICAgICAgICAgICAgPGRpdiBkaXI9Imx0ciI+Qm91cmtlIGJ1aWx0IG1hbnkgZXhh > bXBsZXMgb2YgaGlzIGVuZ2luZQogICAgICAgICAgICAgICAgZm9yIHRydWNrcywgb3V0Ym9hcmQg > bW90b3JzLCBhbmQgYWlyY3JhZnQuIFRoZXkgYWxsCiAgICAgICAgICAgICAgICB3b3JrZWQsIHJh > biBmb3IgaHVuZHJlZHMgb2YgaG91cnMgd2l0aCBsaXR0bGUgd2VhciB0bwogICAgICAgICAgICAg > ICAgYW55IHBhcnRzLCBhbmQgcHJvZHVjZWQgdGhlIGFkdmVydGlzZWQgaG9yc2Vwb3dlci4gT25l > CiAgICAgICAgICAgICAgICBvZiB0aGUgYWlyY3JhZnQgZW5naW5lcyBpcyBpbiB0aGUgRUFBIG11 > c2V1bS4KICAgICAgICAgICAgICAgIDxkaXY+TGlrZSBhbnkgZW5naW5lIHRoZSBzdGFydCB1cCBj > b3N0cyBnb2luZyBpbnRvCiAgICAgICAgICAgICAgICAgIHByb2R1Y3Rpb24gd291bGQgYmUgYXN0 > cm9ub21pY2FsIGFuZCBmb3IgYW4gYWlyY3JhZnQKICAgICAgICAgICAgICAgICAgZW5naW5lIHRo > ZW4gdGhlcmUgYXJlIGNlcnRpZmljYXRpb24gY29zdHMuIEFsbCBmb3IgYQogICAgICAgICAgICAg > ICAgICBzbWFsbCBkaW1pbmlzaGluZyBtYXJrZXQuIFNhZCB0byBzYXkgaXQgd29uJ3QgaGFwcGVu > LAogICAgICAgICAgICAgICAgICBidXQgdGhhdCdzIHRoZSB3YXkgaXQgaXMuPC9kaXY+CiAgICAg > ICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgPGRpdj5SaWNrIEdp > cmFyZDwvZGl2PgogICAgICAgICAgICAgICAgPGRpdj5kbyBub3QgYXJjaGl2ZTwvZGl2PgogICAg > ICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgIDxkaXYgY2xhc3M9ImdtYWlsX2V4dHJhIj4K > ICAgICAgICAgICAgICAgIDxkaXY+Jm5ic3A7PC9kaXY+CiAgICAgICAgICAgICAgICA8ZGl2IGNs > YXNzPSJnbWFpbF9xdW90ZSI+T24gU3VuLCBKYW4gMjUsIDIwMTUgYXQgMTowOQogICAgICAgICAg > ICAgICAgICBQTSwgdW5kb2N0b3IgPHNwYW4gZGlyPSJsdHIiPiZsdDs8YSBtb3otZG8tbm90LXNl > bmQ9InRydWUiIGhyZWY9Im1haWx0bzp1bmRvY3RvckBwdGQubmV0IiB0YXJnZXQ9Il9ibGFuayI+ > dW5kb2N0b3JAcHRkLm5ldDwvYT4mZ3Q7PC9zcGFuPgogICAgICAgICAgICAgICAgICB3cm90ZTo8 > YnI+CiAgICAgICAgICAgICAgICAgIDxibG9ja3F1b3RlIGNsYXNzPSJnbWFpbF9xdW90ZSIgc3R5 > bGU9IlBBRERJTkctTEVGVDoKICAgICAgICAgICAgICAgICAgICAxZXg7IE1BUkdJTjogMHB4IDBw > eCAwcHggMC44ZXg7IEJPUkRFUi1MRUZUOiAjY2NjCiAgICAgICAgICAgICAgICAgICAgMXB4IHNv > bGlkIj4KICAgICAgICAgICAgICAgICAgICA8ZGl2PgogICAgICAgICAgICAgICAgICAgICAgPGRp > dj5SZW1lbWJlciBiYWNrIGluIHRoZSA1MHMgb3IgNjBzIHdoZW4gdGhlCiAgICAgICAgICAgICAg > ICAgICAgICAgIFdlbmtlbCBSb3RhcnkgZW5naW5lIHdhcyBpbnRyb2R1Y2VkPyBPbmUKICAgICAg > ICAgICAgICAgICAgICAgICAgdHJpYW5ndWxhciBwaXN0b24gd2l0aCByb3RhcnkgcmF0aGVyIHRo > YW4KICAgICAgICAgICAgICAgICAgICAgICAgcmVjaXByb2NhdGluZyBtb3Rpb24gYW5kIHZlcnkg > ZmV3IG1vdmluZyBwYXJ0cz88L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+Jm5ic3A7 > PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICA8ZGl2Pkdvb2QgaWRlYSBhbmQgaXQgY291bGQg > c3BpbiB2ZXJ5IGhpZ2ggcmV2cy4KICAgICAgICAgICAgICAgICAgICAgICAgUHJvYmxlbSBpcywg > dGhleSBjYW4ndCBrZWVwIHRoZSB0aXBzIGZyb20KICAgICAgICAgICAgICAgICAgICAgICAgd2Vh > cmluZyBvbiB0aGUgdHJpYW5ndWxhciBwaXN0b24sIHNvIHZlcnkKICAgICAgICAgICAgICAgICAg > ICAgICAgbGltaXRlZCBhcHBsaWNhdGlvbiBpbiB0aGUgcmVhbCB3b3JsZC4gPC9kaXY+CiAgICAg > ICAgICAgICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgICAgICAg > PGRpdj5BbHNvIHJlbWVtYmVyIGEgY2VyYW1pYyBlbmdpbmUgb24gdGhlIGRyYXdpbmcKICAgICAg > ICAgICAgICAgICAgICAgICAgYm9hcmRzIHdoaWNoIHdhcyB0byByaXZhbCBzbGljZWQgYnJlYWQg > Zm9yCiAgICAgICAgICAgICAgICAgICAgICAgIGdyZWF0bmVzcy4gSGF2ZW4ndCBoZWFyZCBhbnkg > bW9yZSBhYm91dCB0aGF0CiAgICAgICAgICAgICAgICAgICAgICAgIG9uZS4gVGhhdCdzIE9LLiBK > dXN0IGtlZXAgaW52ZW50aW5nLCBtYW55IG91dAogICAgICAgICAgICAgICAgICAgICAgICB0aGVy > ZSBpZGVhcyBoYXZlIGJlZW4gc3VjY2Vzc2Z1bC4gPC9kaXY+CiAgICAgICAgICAgICAgICAgICAg > ICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgPGRpdj5EYXZlIEt1bHA8 > L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+QmV0aGxlaGVtLCBQQTwvZGl2PgogICAg > ICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgICAgICAgICAgICAgICAgICAg > IDxkaXY+RG8gbm90IGFyY2hpdmU8L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+Jm5i > c3A7PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICA8ZGl2PiZuYnNwOzwvZGl2PgogICAgICAg > ICAgICAgICAgICAgICAgPGRpdj4KICAgICAgICAgICAgICAgICAgICAgICAgPGRpdiBzdHlsZT0i > Rk9OVC1TSVpFOiA5cHg7IENPTE9SOiAjNTc1NzU3Ij5TZW50CiAgICAgICAgICAgICAgICAgICAg > ICAgICAgZnJvbSBteSBWZXJpem9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lPC9kaXY+CiAg > ICAgICAgICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgIDxkaXY+CiAg > ICAgICAgICAgICAgICAgICAgICAgIDxkaXYgY2xhc3M9Img1Ij48YnI+CiAgICAgICAgICAgICAg > ICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIDxkaXY+LS0tLS0tLS0g > T3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLTwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgICAg > IDxkaXY+RnJvbTogQ2hhcmxpZSBFbmdsYW5kIDwvZGl2PgogICAgICAgICAgICAgICAgICAgICAg > ICAgIDxkaXY+RGF0ZTowMS8yNS8yMDE1IDE6NDggUE0gKEdNVC0wNTowMCkgPC9kaXY+CiAgICAg > ICAgICAgICAgICAgICAgICAgICAgPGRpdj5UbzogPGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIiBo > cmVmPSJtYWlsdG86a29sYi1saXN0QG1hdHJvbmljcy5jb20iIHRhcmdldD0iX2JsYW5rIj5rb2xi > LWxpc3RAbWF0cm9uaWNzLmNvbTwvYT4KICAgICAgICAgICAgICAgICAgICAgICAgICA8L2Rpdj4K > ICAgICAgICAgICAgICAgICAgICAgICAgICA8ZGl2PlN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IEJv > dXJrZSBlbmdpbmUgPC9kaXY+CiAgICAgICAgICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8 > L2Rpdj4KICAgICAgICAgICAgICAgICAgICAgICAgICAtLSZndDsgS29sYi1MaXN0IG1lc3NhZ2Ug > cG9zdGVkIGJ5OiBDaGFybGllCiAgICAgICAgICAgICAgICAgICAgICAgICAgRW5nbGFuZCAmbHQ7 > PGEgbW96LWRvLW5vdC1zZW5kPSJ0cnVlIiBocmVmPSJtYWlsdG86Y2VlbmdsYW5kN0BnbWFpbC5j > b20iIHRhcmdldD0iX2JsYW5rIj5jZWVuZ2xhbmQ3QGdtYWlsLmNvbTwvYT4mZ3Q7PGJyPgogICAg > ICAgICAgICAgICAgICAgICAgICAgIDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgICBPbiAx > LzI1LzIwMTUgMTE6MTggQU0sIHdpbGxpYW0gc3VsbGl2YW4gd3JvdGU6PGJyPgogICAgICAgICAg > ICAgICAgICAgICAgICAgICZndDsgLS0mZ3Q7IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieToK > ICAgICAgICAgICAgICAgICAgICAgICAgICB3aWxsaWFtIHN1bGxpdmFuICZsdDs8YSBtb3otZG8t > bm90LXNlbmQ9InRydWUiIGhyZWY9Im1haWx0bzp3aWxsaWFtdHN1bGxpdmFuQGF0dC5uZXQiIHRh > cmdldD0iX2JsYW5rIj53aWxsaWFtdHN1bGxpdmFuQGF0dC5uZXQ8L2E+Jmd0Ozxicj4KICAgICAg > ICAgICAgICAgICAgICAgICAgICAmZ3Q7PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgICZn > dDsmbmJzcDsmbmJzcDsmbmJzcDsgQ2xpY2sgb24gdmFyaW91cyBzdHVmZiBpbiB0aGlzIGxpbmsu > Jm5ic3A7CiAgICAgICAgICAgICAgICAgICAgICAgICAgTXkgYnJvdGhlciBzZW50IGl0IHRvIG1l > LCB0aGlua2luZyBJJ2QgYmUKICAgICAgICAgICAgICAgICAgICAgICAgICBpbnRlcmVzdGVkLiZu > YnNwOyBXaXRoIFJvdGF4IGRyb3BwaW5nIHRoZSBzbWFsbAogICAgICAgICAgICAgICAgICAgICAg > ICAgIDItc3Ryb2tlcywgdGhlcmUgaXMgYSBuZWVkIGZvciByZXBsYWNlbWVudHMuJm5ic3A7CiAg > ICAgICAgICAgICAgICAgICAgICAgICAgVGhlIHdlaWdodCB0byBIUCByYXRpbyBsb29rcyBwcmV0 > dHkgZ29vZC4mbmJzcDsKICAgICAgICAgICAgICAgICAgICAgICAgICBEb2VzIGFueW9uZSBoYXZl > IGFueSBleHBlcmllbmNlL2NvbW1lbnRzIG9uCiAgICAgICAgICAgICAgICAgICAgICAgICAgdGhp > cyBvbmU/PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgICZndDs8YnI+CiAgICAgICAgICAg > ICAgICAgICAgICAgICAgJmd0OyA8YSBtb3otZG8tbm90LXNlbmQ9InRydWUiIGhyZWY9Imh0dHA6 > Ly93d3cuYm91cmtlLWVuZ2luZS5jb20vYW5pIiB0YXJnZXQ9Il9ibGFuayI+aHR0cDovL3d3dy5i > b3Vya2UtZW5naW5lLmNvbS9hbmk8L2E+PGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgICZn > dDs8YnI+CiAgICAgICAgICAgICAgICAgICAgICAgICAgJmd0Ozxicj4KICAgICAgICAgICAgICAg > ICAgICAgICAgICBJJ2Qgc3VnZ2VzdCBmaW5kaW5nIGFuIGluZGVwZW5kZW50IGVuZ2luZWVyaW5n > CiAgICAgICAgICAgICAgICAgICAgICAgICAgZXZhbHVhdGlvbi4gTXkgdGhvdWdodHM6IDxicj4K > ICAgICAgICAgICAgICAgICAgICAgICAgICBDb25zaWRlciBob3cgc2V2ZXJlIHRoZSBpbWJhbGFu > Y2Ugd2lsbCBiZSB3aXRoCiAgICAgICAgICAgICAgICAgICAgICAgICAgYm90aCBwaXN0b25zIG1v > dmluZyB0aGUgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIHNhbWUgZGlyZWN0aW9uLCB0 > aGVuIGhvdyBtdWNoIHRoZQogICAgICAgICAgICAgICAgICAgICAgICAgIGNvdW50ZXJ3ZWlnaHQg > d2lsbCB3ZWlnaCB0byBjb3VudGVyYWN0IDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgICB0 > aGF0IGZvcmNlICh3aXRob3V0IGNvbnRyaWJ1dGluZyBhbnkgcG93ZXIpLgogICAgICAgICAgICAg > ICAgICAgICAgICAgIFRoZW4gY29uc2lkZXIgaG93IGxvbmcgYSA8YnI+CiAgICAgICAgICAgICAg > ICAgICAgICAgICAgc2xpZGluZyBsaW5lLWNvbnRhY3Qgc2xpZGluZyBiZWFyaW5nIGlzIGdvaW5n > CiAgICAgICAgICAgICAgICAgICAgICAgICAgdG8gbGFzdCB3aGVuIHN1YmplY3RlZCB0byA8YnI+ > CiAgICAgICAgICAgICAgICAgICAgICAgICAgdGhvc2UgZm9yY2VzLiBUaGUgY2xhaW0gaXMgMS80 > IHBvdW5kICgwLjI1IGxiKQogICAgICAgICAgICAgICAgICAgICAgICAgIHBlciBocC9oci4gVGhp > cyBpcyBiZXR0ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIGJ5IGFib3V0IDMwJSB0 > aGFuIHRoZSBtb3N0IGVmZmljaWVudCBpbnRlcm5hbAogICAgICAgICAgICAgICAgICAgICAgICAg > IGNvbWJ1c3Rpb24gZW5naW5lIGV2ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIGJ1 > aWx0LCBhbmQgaXQncyBzdGlsbCBhIDIgc3Ryb2tlIGVuZ2luZS4gSXNuJ3QKICAgICAgICAgICAg > ICAgICAgICAgICAgICBpdCBhIGJpdCBzdHJhbmdlIHRoYXQgYSA8YnI+CiAgICAgICAgICAgICAg > ICAgICAgICAgICAgZGVzaWduIHRoYXQncyBiZWVuIGFyb3VuZCBsb25nIGVub3VnaCBmb3IgdGhl > CiAgICAgICAgICAgICAgICAgICAgICAgICAgcGF0ZW50cyB0byBleHBpcmUsIGFuZCBpcyA8YnI+ > CiAgICAgICAgICAgICAgICAgICAgICAgICAgc3VwZXIgY2xlYW4sIGFuZCBiZWF0cyB0aGUgYmVz > dCB0ZWNoIG91dCB0aGVyZQogICAgICAgICAgICAgICAgICAgICAgICAgIGJ5IDMwJSwgaGFzbid0 > IHRha2VuIG92ZXIgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIGV2ZXJ5IGVuZ2luZSBt > YXJrZXQgb24gdGhlIHBsYW5ldD8mbmJzcDsgQW5kIGl0CiAgICAgICAgICAgICAgICAgICAgICAg > ICAgdXNlcyAnZGV0b25hdGlvbicgdG8gZXh0cmFjdCA8YnI+CiAgICAgICAgICAgICAgICAgICAg > ICAgICAgbW9yZSBlbmVyZ3kgZnJvbSB0aGUgZnVlbD8gV2hhdCBoYXBwZW5zIHRvIGEKICAgICAg > ICAgICAgICAgICAgICAgICAgICBwaXN0b24gd2hlbiB5b3UgaGF2ZSA8YnI+CiAgICAgICAgICAg > ICAgICAgICAgICAgICAgZGV0b25hdGlvbiBpbiB0aGUgY29tYnVzdGlvbiBjaGFtYmVyPyAoQW5z > d2VyCiAgICAgICAgICAgICAgICAgICAgICAgICAgaGVscDogbm90aGluZyBnb29kLik8YnI+CiAg > ICAgICAgICAgICAgICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgICAgICAgICAgICAgIEN1 > cnJlbnQgdGVjaG5vbG9neSBpbiA0IHN0cm9rZXMgY2FuIGNvbWUKICAgICAgICAgICAgICAgICAg > ICAgICAgICBwcmV0dHkgY2xvc2UgdG8gdGhlIHNhbWUgPGJyPgogICAgICAgICAgICAgICAgICAg > ICAgICAgIHBvd2VyL3dlaWdodCByYXRpbyBhcyBvbGQgdGVjaCAyIHN0cm9rZXMuIEp1c3QKICAg > ICAgICAgICAgICAgICAgICAgICAgICBuZWVkIHNvbWVvbmUgdG8gbWFrZSB0aGVtIDxicj4KICAg > ICAgICAgICAgICAgICAgICAgICAgICBhdmFpbGFibGUgYXQgYW4gYWZmb3JkYWJsZSBwcmljZW9s > Yi1MaXN0IgogICAgICAgICAgICAgICAgICAgICAgICAgIHRhcmdldD0iX2JsYW5rIiZndDs8YSBt > b3otZG8tbm90LXNlbmQ9InRydWUiIGNsYXNzPSJtb3otdHh0LWxpbmstZnJlZXRleHQiIGhyZWY9 > Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0aHR0cDovL3d3dy5t > YXRyb25pY3MuY29tPT09PT09PT09PT09PT09PT09Ij5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20v > TmF2aWdhdG9yP0tvbGItTGlzdGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbT09PT09PT09PT09PT09 > PT09PTwvYT48YnI+CiAgICAgICAgICAgICAgICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAg > ICAgICAgICAgICAgIDxicj4KICAgICAgICAgICAgICAgICAgICAgICAgICA8YnI+CiAgICAgICAg > ICAgICAgICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgICAgICAgICAgPC9kaXY+CiAgICAg > ICAgICAgICAgICAgICAgPC9kaXY+CiAgICAgICAgICAgICAgICAgIDwvYmxvY2txdW90ZT4KICAg > ICAgICAgICAgICAgIDwvZGl2PgogICAgICAgICAgICAgICAgPGJyPgogICAgICAgICAgICAgICAg > PGJyIGNsZWFyPSJhbGwiPgogICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8L2Rpdj4KICAgICAg > ICAgICAgICAgIC0tIDxicj4KICAgICAgICAgICAgICAgIDxkaXYgY2xhc3M9ImdtYWlsX3NpZ25h > dHVyZSI+CiAgICAgICAgICAgICAgICAgIDxkaXYgZGlyPSJsdHIiPgogICAgICAgICAgICAgICAg > ICAgIDxkaXY+Jm5ic3A7PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgPGRpdj4mbmJzcDs8L2Rp > dj4KICAgICAgICAgICAgICAgICAgICA8ZGl2Pjxmb250IGZhY2U9ImFyaWFsLCBzYW5zLXNlcmlm > Ij48c3BhbiBzdHlsZT0iRk9OVC1TSVpFOiAxM3B4Ij5CZWxpZXZlIHRob3NlIHdobyBhcmUKICAg > ICAgICAgICAgICAgICAgICAgICAgICBzZWVraW5nIHRoZSB0cnV0aCwgZG91YnQgdGhvc2Ugd2hv > IGZpbmQgaXQuPC9zcGFuPjwvZm9udD48L2Rpdj4KICAgICAgICAgICAgICAgICAgICA8ZGl2Pjxm > b250IGZhY2U9ImFyaWFsLCBzYW5zLXNlcmlmIj48c3BhbiBzdHlsZT0iRk9OVC1TSVpFOiAxM3B4 > Ij4tQW5kcmUgR2lkZTwvc3Bhbj48L2ZvbnQ+PC9kaXY+CiAgICAgICAgICAgICAgICAgICAgPGJy > PgogICAgICAgICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgICAgICAgIDwvZGl2PgogICAgICAg > ICAgICAgIDwvZGl2PgogICAgICAgICAgICA8L2Rpdj4KICAgICAgICAgIDwvZGl2PgogICAgICAg > IDwvZGl2PgogICAgICA8L2Jsb2NrcXVvdGU+CiAgICA8L2Jsb2NrcXVvdGU+CiAgICA8YnI+CiAg > CgoKPHByZT48Yj48Zm9udCBzaXplPSIyIiBjb2xvcj0iIzAwMDAwMCIgZmFjZT0iY291cmllciBu > ZXcsY291cmllciI+CgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 > PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgLSBUaGUgS29sYi1MaXN0IEVtYWlsIEZv > cnVtIC0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJy > b3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlw > dGlvbiwKXy09IEFyY2hpdmUgU2VhcmNoICZhbXA7IERvd25sb2FkLCA3LURheSBCcm93c2UsIENo > YXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0t > Jmd0OyA8YSBocmVmPSJodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGItTGlz > dCI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Lb2xiLUxpc3Q8L2E+Cl8tPQpf > LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 > PT09PQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUg > Z3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0g > ICAtLSZndDsgPGEgaHJlZj0iaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tIj5odHRwOi8vZm9y > dW1zLm1hdHJvbmljcy5jb208L2E+Cl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 > PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgLSBMaXN0IENv > bnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1 > cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlz > dCBBZG1pbi4KXy09ICAgLS0mZ3Q7IDxhIGhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9j > b250cmlidXRpb24iPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb248L2E+Cl8t > PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 > PT09Cgo8L2ZvbnQ+PC9iPjwvcHJlPjwvYm9keT4 > > * * > * * > *class="">http://www.matronics.com/Navigator?Kolb-List* > *class="">http://forums.matronics.com* > *class="">http://www.matronics.com/contribution* > * * > > ________________________________________________________________________________
Date: Jan 29, 2015
Subject: Trimming messages
Sure would be good if everyone trimmed the history of old messages from their postings..... Just leave enough to remind us what the post is replying to. JG ________________________________________________________________________________
From: "Michael Velemirov" <mvelemirov(at)neo.rr.com>
Subject: RE: Bourke engine gibberish
Date: Jan 29, 2015
I=99m getting gibberish also. I=99m using windows 7 and Windows live email Michael Velemirov Twinstar Mk II ________________________________________________________________________________
Date: Jan 29, 2015
SGkgTWljaGFlbCwKRnJvbSB0aGUgaW5mbyBJJ3ZlIHJlYWQgSSd2ZSBjb21lIHRvIHRoZSBjb25j bHVzaW9uIGl0J3MgYSByZXN1bHQgb2YgdXNpbmcgbXkgQW5kcm9pZCBzb21ld2hhdCBzbWFydCBw aG9uZSB0byBwb3N0IHJhdGhlciB0aGFuIG15IFBDLiBUaGF0IGJlaW5nIHRoZSBjYXNlIEknbGwg dHJ5IHRvIHVzZSBteSBQQy7CoAoKU3RhcnRpbmcgdG9tb3Jyb3cuLi4KCkRhdmUgS3VscApCZXRo bGVoZW0sIFBBCgpEbyBub3QgYXJjaGl2ZQoKClNlbnQgZnJvbSBteSBWZXJpem9uIFdpcmVsZXNz IDRHIExURSBTbWFydHBob25lCgo8ZGl2Pi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0t LS08L2Rpdj48ZGl2PkZyb206IE1pY2hhZWwgVmVsZW1pcm92IDxtdmVsZW1pcm92QG5lby5yci5j b20+IDwvZGl2PjxkaXY+RGF0ZTowMS8yOS8yMDE1ICA3OjU5IEFNICAoR01ULTA1OjAwKSA8L2Rp dj48ZGl2PlRvOiBLb2xiLUxpc3QgRGlnZXN0IFNlcnZlciA8a29sYi1saXN0QG1hdHJvbmljcy5j b20+IDwvZGl2PjxkaXY+U3ViamVjdDogS29sYi1MaXN0OiBSRTogQm91cmtlIGVuZ2luZSBnaWJi ZXJpc2ggPC9kaXY+PGRpdj4KPC9kaXY+SeKAmW0gZ2V0dGluZyBnaWJiZXJpc2ggYWxzby4gSeKA mW0gdXNpbmcgd2luZG93cyA3IGFuZCBXaW5kb3dzIGxpdmUgZW1haWwKTWljaGFlbCBWZWxlbWly b3YKVHdpbnN0YXIgTWsgSUkKCgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgLSBUaGUgS29sYi1MaXN0IEVt YWlsIEZvcnVtIC0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9y IHRvIGJyb3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1 YnNjcmlwdGlvbiwKXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwg Q2hhdCwgRkFRLApfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOgpfLT0KXy09ICAg LS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0Cl8tPQpfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3Jl YXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gICAt LT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAg LSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdl bmVyb3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERy YWxsZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250 cmlidXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT0KCg= ________________________________________________________________________________
Subject: Re: Wankel
Date: Jan 29, 2015
I believe that Mazda still puts a Wankel rotary engine in their RX-8. A car that will outrun anything in it's class including the Porches. I've watched this firsthand at Barbers road course in Leeds, AL. The engine, with two turbochargers, puts out tremendous HP & torque. Nobody can stay with them, coming out of the tight turns or on the long straights. I imagine these engines to be expensive to buy & feed as 2 stroke engines are notorious gas guzzlers. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437818#437818 ________________________________________________________________________________
Date: Jan 29, 2015
Subject: Re: Wankel
On 1/29/2015 9:30 AM, woody wrote: > > I believe that Mazda still puts a Wankel rotary engine in their RX-8. > A car that will outrun anything in it's class including the Porches. > I've watched this firsthand at Barbers road course in Leeds, AL. > The engine, with two turbochargers, puts out tremendous HP & torque. > Nobody can stay with them, coming out of the tight turns or on the long straights. > I imagine these engines to be expensive to buy & feed as 2 stroke engines > are notorious gas guzzlers. > > Yes, very light and quick, and not, not, and not. The twin turbo was the last generation RX7; the RX8 (Renesis powered) was normally aspirated (no turbo option). Unfortunately, the RX8 is no longer produced, and Mazda is not currently selling rotary powered cars, to my knowledge (definitely not in the USA). I previously sent links to two potential new rotary products from Mazda, a small (~300cc) 'sustainer' engine for a hybrid car (should be just about perfect for a Kolb), and the 16B, a larger displacement (1600cc), all aluminum rotary intended for a new sports car. The latter has us aviating rotor heads salivating. It will likely be around 250-275 HP normally aspirated, and the core engine will weigh around 120-130 lbs (the Renesis core weighs around 190 lbs & produces around 200 HP). Remember, those weights are for bare engines; what a V-8 builder would call a 'long block'. All up for flight, with radiator, oil cooler, etc, a Renesis weighs around 330-340 lbs. The weight & HP numbers for the Renesis are 'real world', proven-in-a/c numbers, not marketing hype from someone trying to sell you worthless stock options. The engines are relatively inexpensive from salvage yards; typically a few hundred dollars for the old 13B engines and from a few hundred to under a couple thousand for Renesis engines in near new condition. Fuel economy is slightly worse (~10%) than piston engines, but the normally aspirated engines prefer the lowest octane fuel you can find. And they are --not-repeat-not-- 2 stroke engines. They go through a normal 4 stroke power cycle just like a piston engine; but do all 4 strokes in one rev of the rotor. Engineers often call them 'rotary combustion' engines, since the combustion process travels around the engine as it occurs. I wouldn't claim to be an authority, but I am familiar with them; I've owned two RX-7's, I'm installing a Renesis in an RV-7 & I have a lot of friends already flying rotaries. If anyone wants more info, just let me know. Thanks, Charlie ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 0 Msgs - 02/03/15
Date: Feb 04, 2015
Friend looking for good twoplace kolb. I think an older mk might be good. Has hurricane for sale or trade. Also a 503 and 337 in running condition. Reply at tc1917(at)bellsouth.net or 256-642-0711. Ted cowan slingshot 912 zoom zoom Sent from my iPhone > On Feb 4, 2015, at 2:02 AM, Kolb-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-02-03&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 15-02-03&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Tue 02/03/15: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 06, 2015
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Subject: Please help me find the GPS thread in the archives
I remember a long thread about GPSs on this list - which were visible in br ight sunlight, whether to use an iPad or iPod or something else... I can't find it, and now that I'm ready to get a GPS, I'd love to re-read t hat thread before asking the list questions. Thanks - Arty TrostSandy, Oregon=C2-www.LessonsFromTheEdge.com/uladventure2009.htm "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe through life just to arrive safely at death." ________________________________________________________________________________
Date: Feb 06, 2015
I use the iFly 700, and find it really good in the sunlight. I haven't seen anything better. I don't think an iPad could do anywhere near as well. JG ________________________________________________________________________________
Subject: Re: Please help me find the GPS thread in the archives
Date: Feb 06, 2015
Hi, I use a mini I pad. Really washes out on sunlight--unreadable Hower I bought a cheap plastic Container that the bottom fits the I pad. With sides about 4inhight, painted The inside black. Makesthe I pad Perfectly readable in any light.I use the I pad for all fllight planing , as a GPS , charts and all navigation. Great setup and cheap. Good luck Frank. Sent from my iPhone On Feb 6, 2015, at 3:56 AM, JC Gilpin wrote: > I use the iFly 700, and find it really good in the sunlight. I haven't se en anything better. I don't think an iPad could do anywhere near as well. > > JG > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Feb 06, 2015
I believe the thread was "Modern GPSes", and the Garmin 60CX was mentioned as being viewable in daylight. On Thursday, February 5, 2015, TheWanderingWench < thewanderingwench(at)yahoo.com> wrote: > I remember a long thread about GPSs on this list - which were visible in > bright sunlight, whether to use an iPad or iPod or something else... > > I can't find it, and now that I'm ready to get a GPS, I'd love to re-read > that thread before asking the list questions. > > Thanks - > > Arty Trost > Sandy, Oregon > > www.LessonsFromTheEdge.com/uladventure2009.htm > > "Life's a daring adventure or nothing" > Helen Keller > > "I refuse to tip toe through life just to arrive safely at death." > > * > > > * > > ________________________________________________________________________________
Date: Feb 06, 2015
I use an original nexus 7 in an rv4 (bubble canopy) with no problems seeing screen details. The newer '2013' model is said to be much brighter still, and has more total pixels than a full size ipad with Retina display. I find the free Avare software to be more than adequate for basic navigation. FWIW, Charlie >I believe the thread was "Modern GPSes", and the Garmin 60CX was >mentioned >as being viewable in daylight. > > >On Thursday, February 5, 2015, TheWanderingWench < >thewanderingwench(at)yahoo.com> wrote: > >> I remember a long thread about GPSs on this list - which were visible >in >> bright sunlight, whether to use an iPad or iPod or something else... >> >> I can't find it, and now that I'm ready to get a GPS, I'd love to >re-read >> that thread before asking the list questions. >> >> Thanks - >> >> Arty Trost >> Sandy, Oregon >> >> www.LessonsFromTheEdge.com/uladventure2009.htm >> >> "Life's a daring adventure or nothing" >> Helen Keller >> >> "I refuse to tip toe through life just to arrive safely at death." >> >> * >> >> >> * >> >> -- Sent from my Android device with K-9 Mail. Please excuse my brevity. ________________________________________________________________________________
Subject: Powder Coat
Date: Feb 10, 2015
Just wanted to share with the Kolb flock. Stopped by the power coater yesterday and got to see a naked Twinstar ready for the powder. Shop says I can pick it up tomorrow, weather permitting here. -------- Mark Twinstar MKII Great Bend, PA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438203#438203 Attachments: http://forums.matronics.com//files/img_0360_167.jpg ________________________________________________________________________________
Subject: Re: Powder Coat
Date: Feb 12, 2015
Just another update. Twinstar home from the powder coater yesterday. Came out real nice. Can't wait to get my goodies from Aircraft Spruce!! -------- Mark Twinstar MKII Great Bend, PA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438262#438262 Attachments: http://forums.matronics.com//files/img_0401_688.jpg http://forums.matronics.com//files/img_0369_570.jpg ________________________________________________________________________________
Date: Feb 15, 2015
Subject: new camera mount- version 3
As you might recall, I had a bone spur removed from one of my feet. The healing process has gone a bit better than the Doc thought it should. I am not able to do any extended walking, but within reason, things are fine. I realize that most of you poor souls are experiencing Global warming at its best. Apparently there isn't a large enough population here where I live to adversely affect the climate, so we are having our usual nice two weeks or so of great weather here in the West. Today was 61 degrees with no wind. The wife is out of town for the weekend, so there was no one to tell me that I shouldn't fly yet. You should look at today's video and be reassured that even your shitty weather will also pass. I have found that the only thing that stays the same is -every thing changes. The Virb camera that I have recently bought seemed a bit more difficult to get good smooth video than the Drift that I had been using. The Virb seems to have a bit clearer picture, and I do like the track and speed feature on it as well. So I want to make it my main camera. I tried it on the wing, and I have to hold it at a certain speed to keep the shake and jello out of it. I put it back on the nose, and had the same problem. The speed that the video was the least shaky at, was just a bit too slow for comfortable "yanking and banking". The next best speed was full throttle. Also not what I really wanted. Having nothing to occupy my time these last few weeks other than ice packs and TV, I formed the thought that the bar of Alum that I had fixed to fit behind the pitot tube holder and the nose pf the pod, might be contributing to the shakes. So this morning I dug out my virb box and got one of the sticky pads that they had for a helmet mount. I stuck it on the nose pod, fixed up a safety wire just in case, and tried my best to wait the recommended 24 hours for the base to be "firmly" attached. Well, I did my best, but if I was ever going to have "patients", I would have been a Doctor. I finally couldn't stand it any longer and rolled the plane out. I could have stuck it out of sight under the nose pod, if I had thought of it before, but I don't mind it up on top, although I do think it is raising hell with my "yarn" slip indicator. The video is the most steady through out the full throttle range that I have found yet, and of course I had a great time. Hang in there guys, better times are coming. https://vimeo.com/119720660 password- owyheeflyer Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: new camera mount- version 3
Date: Feb 16, 2015
Hi Larry, welcome back. Glad that your operation is sorting itself out more quickly than expected. Your camera mount seems perfect. It even dealt with the vibration when you were on the ground. Wx in the UK has been pretty good. In the south we have had not winter yet although Scotland and the North of England have had some snow. Nothing that persisted beyond a couple of days. Overcast and rain today but we have had several long periods of nil wind and good flying weather with a large high pressure area over us. No flying for me any more I am afraid although i am trying to convince myself that my bank book would stand a half hour flight in a Spitfire. I flew a Mustang for an hour in Kissimmee many years ago and I have managed to get into a couple of T6`s and a couple of jets over the years and I would dearly love to add the Spitfire. Heigh Ho. Pat ________________________________________________________________________________
Date: Feb 16, 2015
Subject: Re: Kolb-List Digest: 1 Msgs - 02/15/15
Very nice! Bob G Sent from my iPad > On Feb 16, 2015, at 3:06 AM, Kolb-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-02-15&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 15-02-15&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Sun 02/15/15: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 08:45 PM - new camera mount- version 3 (Larry Cottrell) > > > > ________________________________ Message 1 _____________________________________ > > > Subject: Kolb-List: new camera mount- version 3 > From: Larry Cottrell <lcottrell1020(at)gmail.com> > > As you might recall, I had a bone spur removed from one of my feet. The > healing process has gone a bit better than the Doc thought it should. I am > not able to do any extended walking, but within reason, things are fine. > > I realize that most of you poor souls are experiencing Global warming at > its best. Apparently there isn't a large enough population here where I > live to adversely affect the climate, so we are having our usual nice two > weeks or so of great weather here in the West. Today was 61 degrees with no > wind. The wife is out of town for the weekend, so there was no one to tell > me that I shouldn't fly yet. You should look at today's video and be > reassured that even your shitty weather will also pass. I have found that > the only thing that stays the same is -every thing changes. > > The Virb camera that I have recently bought seemed a bit more difficult to > get good smooth video than the Drift that I had been using. The Virb seems > to have a bit clearer picture, and I do like the track and speed feature on > it as well. So I want to make it my main camera. I tried it on the wing, > and I have to hold it at a certain speed to keep the shake and jello out of > it. I put it back on the nose, and had the same problem. The speed that the > video was the least shaky at, was just a bit too slow for comfortable > "yanking and banking". The next best speed was full throttle. Also not what > I really wanted. > > Having nothing to occupy my time these last few weeks other than ice packs > and TV, I formed the thought that the bar of Alum that I had fixed to fit > behind the pitot tube holder and the nose pf the pod, might be contributing > to the shakes. So this morning I dug out my virb box and got one of the > sticky pads that they had for a helmet mount. I stuck it on the nose pod, > fixed up a safety wire just in case, and tried my best to wait the > recommended 24 hours for the base to be "firmly" attached. Well, I did my > best, but if I was ever going to have "patients", I would have been a > Doctor. I finally couldn't stand it any longer and rolled the plane out. > > I could have stuck it out of sight under the nose pod, if I had thought of > it before, but I don't mind it up on top, although I do think it is raising > hell with my "yarn" slip indicator. > > The video is the most steady through out the full throttle range that I > have found yet, and of course I had a great time. Hang in there guys, > better times are coming. > > https://vimeo.com/119720660 > > password- owyheeflyer > > Larry > > > -- > *If you forward this email, or any part of it, please remove my email > address before sending.* > > > > > > > > ________________________________________________________________________________
Date: Feb 16, 2015
On 2/16/2015 3:02 AM, Kolb-List Digest Server wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-02-15&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 15-02-15&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Sun 02/15/15: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 08:45 PM - new camera mount- version 3 (Larry Cottrell) > > > > ________________________________ Message 1 _____________________________________ > > > Subject: Kolb-List: new camera mount- version 3 > From: Larry Cottrell <lcottrell1020(at)gmail.com> > > As you might recall, I had a bone spur removed from one of my feet. The > healing process has gone a bit better than the Doc thought it should. I am > not able to do any extended walking, but within reason, things are fine. > > I realize that most of you poor souls are experiencing Global warming at > its best. Apparently there isn't a large enough population here where I > live to adversely affect the climate, so we are having our usual nice two > weeks or so of great weather here in the West. Today was 61 degrees with no > wind. The wife is out of town for the weekend, so there was no one to tell > me that I shouldn't fly yet. You should look at today's video and be > reassured that even your shitty weather will also pass. I have found that > the only thing that stays the same is -every thing changes. > > The Virb camera that I have recently bought seemed a bit more difficult to > get good smooth video than the Drift that I had been using. The Virb seems > to have a bit clearer picture, and I do like the track and speed feature on > it as well. So I want to make it my main camera. I tried it on the wing, > and I have to hold it at a certain speed to keep the shake and jello out of > it. I put it back on the nose, and had the same problem. The speed that the > video was the least shaky at, was just a bit too slow for comfortable > "yanking and banking". The next best speed was full throttle. Also not what > I really wanted. > > Having nothing to occupy my time these last few weeks other than ice packs > and TV, I formed the thought that the bar of Alum that I had fixed to fit > behind the pitot tube holder and the nose pf the pod, might be contributing > to the shakes. So this morning I dug out my virb box and got one of the > sticky pads that they had for a helmet mount. I stuck it on the nose pod, > fixed up a safety wire just in case, and tried my best to wait the > recommended 24 hours for the base to be "firmly" attached. Well, I did my > best, but if I was ever going to have "patients", I would have been a > Doctor. I finally couldn't stand it any longer and rolled the plane out. > > I could have stuck it out of sight under the nose pod, if I had thought of > it before, but I don't mind it up on top, although I do think it is raising > hell with my "yarn" slip indicator. > > The video is the most steady through out the full throttle range that I > have found yet, and of course I had a great time. Hang in there guys, > better times are coming. > > https://vimeo.com/119720660 > > password- owyheeflyer > > Larry > > Great to have a new video from you, glad to hear that you're doing well after surgery and flying again. Really good vid! John Brooks Oakboro, NC Firestar II ________________________________________________________________________________
Date: Feb 17, 2015
Then go for it Pat. If it dosnt put you in the soup kitchen then it will be worth every penny,I lost two good friends on a training flight about 3 wee ks ago. The instructor on that flight tought me to fly over 20 years ago. J ack was 86 years young had flown most things and had many aviation awards f or his years of instruction and dedication to aviation,his pilots license w as 75 years old at the time of the accident, =C2-. His teachings included aviation is fun, go have safe fun .The student on that flight was a senior police officer ,he loved to fly . I had taken him for a flight in the Kolb about 3 weeks before the accident ,he loved it. Who could not like the way a Kolb flys ?Not trying to be morbid , just saying do it while you are abl e, none of us know what is around the corner ,=C2-So if you have the mean s go do it. I expect a debrief.=C2- Regards=C2- =C2- =C2- =C2- =C2- =C2-Downunder=C2- =C2- =C2 - =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- M K111c and not flying enough =C2- On Monday, 16 February 2015 11:45 PM, Patrick Ladd wrote: Hi Larry,welcome back. Glad that your operation is sorting itself out more quickly than expected. Your camera mount seems perfect. It even dealt with the vibration when you were on the ground.=C2- Wx in the UK has been pre tty good. In the south we have had not winter yet although Scotland and the North of England have had some snow. Nothing that persisted beyond a coupl e of days. Overcast and rain today but we have had several long periods of nil wind and good flying weather with a large high pressure area over us.No flying for me any more I am afraid although i am trying to convince myself that my bank book would stand a half hour flight in a Spitfire.=C2- I fl ew a Mustang for an hour in Kissimmee many years ago and I have managed to get into a couple of T6`s and a couple of jets over the years and I would d early love to add the Spitfire. Heigh Ho.=C2- Pat=C2-http://forums.matr onics.com _p;=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- generous bsp;=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2- href="http://www.matronics.com/contributio n">http://www.matronics.com/c=============== = ________________________________________________________________________________
Date: Feb 17, 2015
Larry, Nice video, and thanks for giving us that live in winter something to look forward to. It is interesting that the most stable spot you have found is at the far forward point of the nose. One would think that the long moment arms on the airframe would be the most sensitive to aircraft vibrations, wing tips, tail, and nose, while the closer you got to the center of mass, the more stable it would be. You said that the camera was pointed down at about 13 degrees. Curious, 13 degrees from what? Level flight, ground stance, fuselage? Whatever it is, it worked pretty well. Single digits temperature and strong gusty winds in central ND today, so just left with watching and dreaming. Keep them coming! Stuart Firefly Serenity From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Sunday, February 15, 2015 10:45 PM Subject: Kolb-List: new camera mount- version 3 As you might recall, I had a bone spur removed from one of my feet. The healing process has gone a bit better than the Doc thought it should. I am not able to do any extended walking, but within reason, things are fine. I realize that most of you poor souls are experiencing Global warming at its best. Apparently there isn't a large enough population here where I live to adversely affect the climate, so we are having our usual nice two weeks or so of great weather here in the West. Today was 61 degrees with no wind. The wife is out of town for the weekend, so there was no one to tell me that I shouldn't fly yet. You should look at today's video and be reassured that even your shitty weather will also pass. I have found that the only thing that stays the same is -every thing changes. The Virb camera that I have recently bought seemed a bit more difficult to get good smooth video than the Drift that I had been using. The Virb seems to have a bit clearer picture, and I do like the track and speed feature on it as well. So I want to make it my main camera. I tried it on the wing, and I have to hold it at a certain speed to keep the shake and jello out of it. I put it back on the nose, and had the same problem. The speed that the video was the least shaky at, was just a bit too slow for comfortable "yanking and banking". The next best speed was full throttle. Also not what I really wanted. Having nothing to occupy my time these last few weeks other than ice packs and TV, I formed the thought that the bar of Alum that I had fixed to fit behind the pitot tube holder and the nose pf the pod, might be contributing to the shakes. So this morning I dug out my virb box and got one of the sticky pads that they had for a helmet mount. I stuck it on the nose pod, fixed up a safety wire just in case, and tried my best to wait the recommended 24 hours for the base to be "firmly" attached. Well, I did my best, but if I was ever going to have "patients", I would have been a Doctor. I finally couldn't stand it any longer and rolled the plane out. I could have stuck it out of sight under the nose pod, if I had thought of it before, but I don't mind it up on top, although I do think it is raising hell with my "yarn" slip indicator. The video is the most steady through out the full throttle range that I have found yet, and of course I had a great time. Hang in there guys, better times are coming. https://vimeo.com/119720660 password- owyheeflyer Larry -- If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Feb 17, 2015
Hi Tony <<,I lost two good friends on a training flight about 3 weeks ago>> That is really rough. Commiserations. I lost two friends as well, many years ago. I had just started gliding, probably not solo. A friend who joined the club with me was with an instructor practicing `cable breaks`. If you have no gliding experience that is the equivalent of engine failure on take off. The last thing anyone heard was the instructor saying `Now, safety above all things`. The glider took off and at around 400ft the instructor disconnected the cable. The runway was a mile and a quarter and used by Stirling and Horsa glider combination during the war so the pilot had only to put his nose down, maintain speed and land. He elected to return to the launch point where we expected him to do a down wind landing as there was plenty of room. At around 100feet he tried to turn back into wind. Didn`t get his bank steep enough and his inside wing stalled and he spun in. Killed instantly. The instructor died a couple of days later. Cause of the accident was never established. we assumed that the P2 froze on the controls and the instructor could not over ride him. Very sad and made worse as it was Boxing Day. Thanks for the urging to have a go at the Spitfire flight. I must plan a campaign and start leaving posts encouraging me to to fly around the house. Cheers Pat From: Tony &Heather Oldman Sent: Tuesday, February 17, 2015 9:48 AM Subject: Re: Kolb-List: new camera mount- version 3 Then go for it Pat. If it dosnt put you in the soup kitchen then it will be worth every penny,I lost two good friends on a training flight about 3 weeks ago. The instructor on that flight tought me to fly over 20 years ago. Jack was 86 years young had flown most things and had many aviation awards for his years of instruction and dedication to aviation,his pilots license was 75 years old at the time of the accident, . His teachings included aviation is fun, go have safe fun .The student on that flight was a senior police officer ,he loved to fly .. I had taken him for a flight in the Kolb about 3 weeks before the accident ,he loved it. Who could not like the way a Kolb flys ? Not trying to be morbid , just saying do it while you are able, none of us know what is around the corner , So if you have the means go do it. I expect a debrief. Regards Downunder MK111c and not flying enough On Monday, 16 February 2015 11:45 PM, Patrick Ladd wrote: Hi Larry, welcome back. Glad that your operation is sorting itself out more quickly than expected. Your camera mount seems perfect. It even dealt with the vibration when you were on the ground. Wx in the UK has been pretty good. In the south we have had not winter yet although Scotland and the North of England have had some snow. Nothing that persisted beyond a couple of days. Overcast and rain today but we have had several long periods of nil wind and good flying weather with a large high pressure area over us. No flying for me any more I am afraid although i am trying to convince myself that my bank book would stand a half hour flight in a Spitfire. I flew a Mustang for an hour in Kissimmee many years ago and I have managed to get into a couple of T6`s and a couple of jets over the years and I would dearly love to add the Spitfire. Heigh Ho. Pat http://forums.matronics.com _p; generous bsp; href="http://www.matronics.com/contribution">http://www.matronics.com/c ================ ronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-L ist matronics.com/">http://forums.matronics.com ronics.com/contribution">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 17, 2015
On Tue, Feb 17, 2015 at 7:53 AM, Stuart Harner wrote: > Larry, > > > Nice video, and thanks for giving us that live in winter something to look > forward to. > > > It is interesting that the most stable spot you have found is at the far > forward point of the nose. One would think that the long moment arms on the > airframe would be the most sensitive to aircraft vibrations, wing tips, > tail, and nose, while the closer you got to the center of mass, the more > stable it would be. > > -------------------------------------------------------------------------------------------------------------------- > What causes the "Jello" and other problems is the vibration. The closer to > the engine the more you get. There are certain rpm ranges that the harmonic > vibrations dampen out. The nose pod had the least amount of vibration. > --------------------------------------------------------------------------------------------------------------------- > > > You said that the camera was pointed down at about 13 degrees. Curious, 13 > degrees from what? Level flight, ground stance, fuselage? Whatever it is, > it worked pretty well. > > > ------------------------------------------------------------------------------------------------------------------- > It was level with the ground. The Elite has a feature that shows when it is level side to side and forward and aft. As well as the number of degrees it is off. --------------------------------------------------------------------------------------------------------------------------- > > > Single digits temperature and strong gusty winds in central ND today, so > just left with watching and dreaming. > > > ----------------------------------------------------------------------------------------------------------------- > Hang in there it will get there. Larry > > > Keep them coming! > > > Stuart > > Firefly Serenity > > > -- > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > > *http://www.matronics.com/Navigator?Kolb-List * > > *http://forums.matronics.com * > > *http://www.matronics.com/contribution * > > > * > > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Feb 17, 2015
Pat - go for it, ole friend! I=99ll be right behind you, jealous as hell Fair winds, Russ > On Feb 16, 2015, at 5:41 AM, Patrick Ladd wrote: > > Hi Larry, > welcome back. Glad that your operation is sorting itself out more quickly than expected. Your camera mount seems perfect. It even dealt with the vibration when you were on the ground. Wx in the UK has been pretty good. In the south we have had not winter yet although Scotland and the North of England have had some snow. Nothing that persisted beyond a couple of days. Overcast and rain today but we have had several long periods of nil wind and good flying weather with a large high pressure area over us. > No flying for me any more I am afraid although i am trying to convince myself that my bank book would stand a half hour flight in a Spitfire. I flew a Mustang for an hour in Kissimmee many years ago and I have managed to get into a couple of T6`s and a couple of jets over the years and I would dearly love to add the Spitfire. Heigh Ho. Pat > > http://forums.matronics.com > _p; generous bsp; href="http://www.matronics.com/contribution">http://www.matronics.com/c= =============== > > > <http://www.matronics.com/Navigator?Kolb-List> <http://www.matronics.com/contribution> > ________________________________________________________________________________
Date: Feb 18, 2015
Larry Again great Video. The mount looks great. I need to start working on narration and adding music. It gives your videos a professional touch. My drift has those adhesive mounts I have used them on my Kayak a few times this winter. They work well on low vibration things. On my Kolb I found that a layer of duck tape between that two parts of their quick mount keeps the camera from bouncing around in flight. I personally like the effect of seeing part of the plane in the video. The problem has been finding a place where I can mount the camera pointing forward and not filling half the video with airplane. The lens has a real wide angle. I have a heel spur. I have so far been able to put off the problem with a different foot bed in me shoes Rick Neilsen Redive VW powered MKIIIC On Sun, Feb 15, 2015 at 11:45 PM, Larry Cottrell wrote: > As you might recall, I had a bone spur removed from one of my feet. The > healing process has gone a bit better than the Doc thought it should. I am > not able to do any extended walking, but within reason, things are fine. > > I realize that most of you poor souls are experiencing Global warming at > its best. Apparently there isn't a large enough population here where I > live to adversely affect the climate, so we are having our usual nice two > weeks or so of great weather here in the West. Today was 61 degrees with no > wind. The wife is out of town for the weekend, so there was no one to tell > me that I shouldn't fly yet. You should look at today's video and be > reassured that even your shitty weather will also pass. I have found that > the only thing that stays the same is -every thing changes. > > The Virb camera that I have recently bought seemed a bit more difficult > to get good smooth video than the Drift that I had been using. The Virb > seems to have a bit clearer picture, and I do like the track and speed > feature on it as well. So I want to make it my main camera. I tried it on > the wing, and I have to hold it at a certain speed to keep the shake and > jello out of it. I put it back on the nose, and had the same problem. The > speed that the video was the least shaky at, was just a bit too slow for > comfortable "yanking and banking". The next best speed was full throttle. > Also not what I really wanted. > > Having nothing to occupy my time these last few weeks other than ice packs > and TV, I formed the thought that the bar of Alum that I had fixed to fit > behind the pitot tube holder and the nose pf the pod, might be > contributing to the shakes. So this morning I dug out my virb box and got > one of the sticky pads that they had for a helmet mount. I stuck it on the > nose pod, fixed up a safety wire just in case, and tried my best to wait > the recommended 24 hours for the base to be "firmly" attached. Well, I did > my best, but if I was ever going to have "patients", I would have been a > Doctor. I finally couldn't stand it any longer and rolled the plane out. > > I could have stuck it out of sight under the nose pod, if I had thought of > it before, but I don't mind it up on top, although I do think it is raising > hell with my "yarn" slip indicator. > > The video is the most steady through out the full throttle range that I > have found yet, and of course I had a great time. Hang in there guys, > better times are coming. > > https://vimeo.com/119720660 > > password- owyheeflyer > > Larry > > > -- > *If you forward this email, or any part of it, please remove my email > address before sending.* > > * > > > * > > ________________________________________________________________________________
Date: Feb 18, 2015
Rick, The problem with having some of the plane in the video is that there is really nowhere that you can put it far enough back to do that other than on the wing, that doesn't rattle and roll. The drift has a ?tripod screw" in the bottom that allows one to utilize shorter connection links. I had some success with earlier cameras with drilling a hole in the lexan windshield and mounting it there. That left most of the nose in the picture, and I kind of liked that, but each camera is different in the way that it handles harmonic vibration. The drift is pretty good, but its length will require a rather long arm, and will thus intensify the vibration. You can always try. What do you have to loose, after all you only have to fly. The bone spur in my foot was about 3/4 inch long and it was on the facing part of my heel. When I stepped down it was digging into the pad that covers the bottom of your foot. A shot of cortizone would take care of it for a couple of months, but it was still digging a groove in the pad. I do a fair amount of walking in the summer and fall, so I decided to get rid of it during the slack time of the winter. I can only take two cortizone shots at the most any way. This from experience. You actually spend two weeks on crutches, and then it is just a bit weak for a while. The Dr says "all discomfort goes away at 4 months, just like clockwork." I actually had little in the way of pain. They gave me a bottle of pain pills, and I took three, and actually needed none. Looking forward to some of your videos. Larry On Wed, Feb 18, 2015 at 11:45 AM, Rick Neilsen wrote: > Larry > > Again great Video. The mount looks great. I need to start working on > narration and adding music. It gives your videos a professional touch. > > My drift has those adhesive mounts I have used them on my Kayak a few > times this winter. They work well on low vibration things. On my Kolb I > found that a layer of duck tape between that two parts of their quick mount > keeps the camera from bouncing around in flight. I personally like the > effect of seeing part of the plane in the video. The problem has been > finding a place where I can mount the camera pointing forward and not > filling half the video with airplane. The lens has a real wide angle. > > I have a heel spur. I have so far been able to put off the problem with a > different foot bed in me shoes > > Rick Neilsen > Redive VW powered MKIIIC > > On Sun, Feb 15, 2015 at 11:45 PM, Larry Cottrell > wrote: > >> As you might recall, I had a bone spur removed from one of my feet. The >> healing process has gone a bit better than the Doc thought it should. I am >> not able to do any extended walking, but within reason, things are fine. >> >> I realize that most of you poor souls are experiencing Global warming at >> its best. Apparently there isn't a large enough population here where I >> live to adversely affect the climate, so we are having our usual nice two >> weeks or so of great weather here in the West. Today was 61 degrees with no >> wind. The wife is out of town for the weekend, so there was no one to tell >> me that I shouldn't fly yet. You should look at today's video and be >> reassured that even your shitty weather will also pass. I have found that >> the only thing that stays the same is -every thing changes. >> >> The Virb camera that I have recently bought seemed a bit more difficult >> to get good smooth video than the Drift that I had been using. The Virb >> seems to have a bit clearer picture, and I do like the track and speed >> feature on it as well. So I want to make it my main camera. I tried it on >> the wing, and I have to hold it at a certain speed to keep the shake and >> jello out of it. I put it back on the nose, and had the same problem. The >> speed that the video was the least shaky at, was just a bit too slow for >> comfortable "yanking and banking". The next best speed was full throttle. >> Also not what I really wanted. >> >> Having nothing to occupy my time these last few weeks other than ice >> packs and TV, I formed the thought that the bar of Alum that I had fixed to >> fit behind the pitot tube holder and the nose pf the pod, might be >> contributing to the shakes. So this morning I dug out my virb box and >> got one of the sticky pads that they had for a helmet mount. I stuck it on >> the nose pod, fixed up a safety wire just in case, and tried my best to >> wait the recommended 24 hours for the base to be "firmly" attached. Well, I >> did my best, but if I was ever going to have "patients", I would have been >> a Doctor. I finally couldn't stand it any longer and rolled the plane out. >> >> I could have stuck it out of sight under the nose pod, if I had thought >> of it before, but I don't mind it up on top, although I do think it is >> raising hell with my "yarn" slip indicator. >> >> The video is the most steady through out the full throttle range that I >> have found yet, and of course I had a great time. Hang in there guys, >> better times are coming. >> >> https://vimeo.com/119720660 >> >> password- owyheeflyer >> >> Larry >> >> >> >> -- >> *If you forward this email, or any part of it, please remove my email >> address before sending.* >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Feb 18, 2015
Great Video Larry! Your 61 degrees sounds great, good to watch while still sitting inside here in Minnesota as it is still -2 outside. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438483#438483 ________________________________________________________________________________
From: "KIRBY, DENNIS T GS-13 USAF AFMC AFNWC/ENS" <dennis.kirby.3(at)us.af.mil>
Subject: JBM - Inferior Product, Poor Customer Support
Date: Feb 19, 2015
Kolb Friends - This post serves as an advisory to alert you of problems that I encountered with engine parts from JBM Enterprises, and the subsequent backlash I experienced with that company when I tried to talk to them about it. BOTTOM LINE: Avoid these guys at all cost! Rotax recommends replacing the rubber carb sockets every 5 years for the 912 engine. I was a couple years past due, so I decided to replace them even though the originals still looked OK. After seeing one or two generally favorable posts on this List recommending JBM, I went ahead and ordered a pair of new carb sockets from them two years ago. What seemed favorable at the time was their cost - $76 each, versus $104 for the genuine Rotax part. In the past 2 years, I've flown about 100 hours on my Mark-3. When I was doing my annual inspection last month, I noticed that one of the carb sockets was beginning to split. The split was NOT next to the clamp, where splits often occur due to overtightening. When I installed it, I was careful to follow the installation instructions precisely, and not over- or under-tighten the clamps. Rather, the split occurred at the junction where the flange meets the cylindrical rubber part - clearly a premature failure of either the material or the manufacturing process. I e-mailed the company, explained the problem, and asked if they would replace the part for me. I made it clear that I did not question the integrity of the company, but simply accepted that an occasional flawed part could find its way out the door. They refused, citing how their warranty only covered defective parts that are discovered upon receipt of the part. Accepting that, I asked if they could at least provide a replacement at a discounted price for me. Again they said no, so I figured that I'd just need to order a new one at the full price. I ordered the replacement, and asked if they might consider at least dropping the $7 shipping charge. JBM's response shocked me. They questioned why I still wanted to order anything from them if I thought their products were of inferior quality (even though I never said that), and then they CANCELLED MY ORDER! Needless to say, I was not going to continue that dialogue. I ordered the genuine Rotax part from Lockwood and have moved on. Even though I was willing to give them another chance by purchasing a replacement for a part that had failed, JBM's blatant disregard for any sort of Customer Service was made very clear to me. Other customers may have had different experiences, but I know that I shall never again order from, nor recommend them to anyone. If this saves even one fellow Light Sport pilot from having the same bad experience I had, then this was worth it. Fly safely - Dennis Kirby Kolb Mark-3 / 912ul Sandia Park, New Mexico ________________________________________________________________________________
Date: Feb 19, 2015
I've purchased SS exhaust springs for the Titan system and carb boots. Never had any dialogue with them though. Both products have been on my MKIII for several years and continue to be serviceable. john h mkIII Titus, Alabama Kolb Friends - This post serves as an advisory to alert you of problems that I encountered with engine parts from JBM Enterprises, and the subsequent backlash I experienced with that company when I tried to talk to them about it. BOTTOM LINE: Avoid these guys at all cost! Needless to say, I was not going to continue that dialogue. I ordered the genuine Rotax part from Lockwood and have moved on. Even though I was willing to give them another chance by purchasing a replacement for a part that had failed, JBM's blatant disregard for any sort of Customer Service was made very clear to me. Other customers may have had different experiences, but I know that I shall never again order from, nor recommend them to anyone. If this saves even one fellow Light Sport pilot from having the same bad experience I had, then this was worth it. Fly safely - Dennis Kirby Kolb Mark-3 / 912ul Sandia Park, New Mexico ________________________________________________________________________________
Date: Feb 19, 2015
Subject: Re: JBM - Inferior Product, Poor Customer Support
Dennis: Thanks for the heads-up on this company. I plan to change the carb socks along with other rubber parts at this year's annual. I will not do business with JBM in light of your experience. I will also pass your words on to members of the Rans list. Steve Spence Auburn Hills, MI former Mk3X owner current S On Thursday, February 19, 2015 3:40 PM, John Hauck wrote: I've purchased SS exhaust springs for the Titan system and carb boots. Never had any dialogue with them though. Both products have been on my MKIII for several years and continue to be serviceable. john h mkIII Titus, Alabama Kolb Friends - This post serves as an advisory to alert you of problems that I encountered with engine parts from JBM Enterprises, and the subsequent backlash I experienced with that company when I tried to talk to them about it. BOTTOM LINE: Avoid these guys at all cost! Needless to say, I was not going to continue that dialogue. I ordered the genuine Rotax part from Lockwood and have moved on. Even though I was willing to give them another chance by purchasing a replacement for a part that had failed, JBM's blatant disregard for any sort of Customer Service was made very clear to me. Other customers may have had different experiences, but I know that I shall never again order from, nor recommend them to anyone. If this saves even one fellow Light Sport pilot from having the same bad experience I had, then this was worth it. Fly safely - Dennis Kirby Kolb Mark-3 / 912ul Sandia Park, New Mexico ________________________________________________________________________________
Date: Feb 20, 2015
Whoa! Dennis has a problem with a company that has been in business for a good while. Dennis' is the first complaint about this company that I am aware of. Steve changes his mind, based on Dennis' one complaint, will not do business with JBM and is going to pass the word to the members of the RANS List??? All this based on one complaint? If that is how we do business I would have dropped Kolb 31 years ago when I was building my Ultrastar. I have been doing business with JBM for a long time. Currently flying with JBM carb boots and SS exhaust springs on my 912ULS. Maybe we need to back off and take a closer look at the situation before we try to kill a man's business that seems, for the most part, to be providing customers like me good products. Just my own personal opinion folks. john h mkIII Titus, Alabama - Still working on my first cup of coffee, waiting for Spring, and Sun and Fun 2015. Dennis: Thanks for the heads-up on this company. I plan to change the carb socks along with other rubber parts at this year's annual. I will not do business with JBM in light of your experience. I will also pass your words on to members of the Rans list. Steve Spence Auburn Hills, MI former Mk3X owner current S ________________________________________________________________________________
Date: Feb 20, 2015
I bought carb boots from JBM several years ago and they are still doing good, they have some minuscule cracks in their centers, but nothing to worry about. However I do coat all my rubber parts with dielectric grease at installation and at each annual condition inspection. I am very satisfied with JBM parts and will continue to use them. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 "Living for your own pleasure is the least pleasurable thing a man can do. If his neighbors don't kill him in disgust he will die slowly of boredom and powerlessness." - Joy Davidman Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438539#438539 ________________________________________________________________________________
Date: Feb 20, 2015
First, a disclaimer: I have no doubt that Dennis experienced what he says h e experienced with JBM. I know Dennis and have found him to be an honorable man...and very meticulous when it comes to his flying addiction. I just want to say that I have been using JBM carb boots and miscellaneous other small parts for some time, and have never had any problem with either the items or with JBM. Steve - if you choose to never use JBM, that's one thing. But I whole-heartedly agree with John that to start warning others o ff a company based on one complaint - even if it is totally valid - is hard to justify. Arty TrostSandy, Oregon =C2-www.LessonsFromTheEdge.com/uladventure2009.htm "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe through life just to arrive safely at death." From: John Hauck <jhauck(at)elmore.rr.com> To: kolb-list(at)matronics.com Sent: Friday, February 20, 2015 6:39 AM Subject: RE: Kolb-List: JBM - Inferior Product, Poor Customer Support Whoa! =C2-Dennis has a problem with a company that h as been in business for a good while.=C2- Dennis' is the first complaint about this company that I am aware of. =C2-Steve changes his mind, based on Dennis' one complaint, will not do business with JBM and is going to pas s the word to the members of the RANS List??? =C2-All this based on one c omplaint? =C2-If that is how we do business I would have dropped Kolb 31 years ago when I was building my Ultrastar. =C2-I have been doing busines s with JBM for a long time.=C2- Currently flying with JBM carb boots and SS exhaust springs on my 912ULS. =C2-Maybe we need to back off and take a closer look at the situation before we try to kill a man's business that s eems, for the most part, to be providing customers like me good products. =C2-Just my own personal opinion folks. =C2-john hmkIIITitus, Alabama - Still working on my first cup of coffee, waiting for Spring, and Sun and F un 2015. =C2- =C2- =C2- =C2- Dennis: =C2-=C2-=C2-=C2-=C2- Thanks for the heads-up on this company.=C2- I plan to change the carb s ocks along with other rubber parts at this year's annual.=C2- I will not do business with JBM in light of your experience.=C2- I will also pass yo ur words on to members of the Rans list. =C2-Steve SpenceAuburn Hills, MI former Mk3X ownercurrent S =C2- ________________________________________________________________________________
Subject: Part 103 legal Firestar?
Date: Feb 20, 2015
Spent quite a while looking through the archives tonight, and it is starting to look sort of doubtful, but I thought I'd ask anyway: does anybody, anywhere, know of a Firestar of any vintage that ever actually made the 254 pound weight limit? The reason is that a local pilot has a very early model with a wrecked cage and a good everything else that can be had at a good price, and I am considering starting a new project... Thanks. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 "Living for your own pleasure is the least pleasurable thing a man can do. If his neighbors don't kill him in disgust he will die slowly of boredom and powerlessness." - Joy Davidman Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438543#438543 ________________________________________________________________________________
Date: Feb 21, 2015
Subject: Re: Part 103 legal Firestar?
WW91J2QgaGF2ZSB0byBnbyB3aXRoIHRoZSBjcmFwcHkgbGlnaHR3ZWlnaHQgd2hlZWxzLCBwYXBl ci10aGluIHRpcmVzLCBvbmUgYW5kIG9uZS1oYWxmIGNvYXRzIG9mICJwYWludCIsIGFuZCBhIDMz NyBvciBlcXVpdmFsZW50IHNpbmNlIG5vIGxvbmdlciBpbiBwcm9kdWN0aW9uLiAiTWlnaHQiIGJl IGRvbmUgaWYgYnVpbHQgYWJzb2x1dGVseSBiYXJlIGJvbmVzLiBIYWQgYSBmcmllbmQgd2hvIGhh ZCBhbiBGUyAxIHRoYXQgd2FzIG11Y2ggbGlnaHRlciAoIDIzNSAjIGFzIEkgcmVjYWxsKSB0aGFu IG15IEZTIDIgd2l0aCBhIDMzNyBhbmQgd2FzIGEgYmV0dGVyIHBlcmZvcm1lciB0aGFuIG1pbmUg d2l0aCA1MCBIUCwgYnV0IEkgaGFkIGEgYmF0dGVyeSwgZWxlYyBzdGFydCwgYW5kIHRoZSAxMCBn YWwgZnVlbCB0YW5rcy4KCkppbSBCYWtlcgo0MDUuNDI2LjUzNzcKCi0tLS0tT3JpZ2luYWwgTWVz c2FnZS0tLS0tCkZyb206IFJpY2hhcmQgUGlrZSA8dGhlZ3JleWJhcm9uQGNoYXJ0ZXIubmV0PgpU bzoga29sYi1saXN0QG1hdHJvbmljcy5jb20KU2VudDogRnJpLCAyMCBGZWIgMjAxNSAxMTo1NCBQ TQpTdWJqZWN0OiBLb2xiLUxpc3Q6IFBhcnQgMTAzIGxlZ2FsIEZpcmVzdGFyPwoKLS0+IEtvbGIt TGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIlJpY2hhcmQgUGlrZSIgPHRoZWdyZXliYXJvbkBjaGFy dGVyLm5ldD4KClNwZW50IHF1aXRlIGEgd2hpbGUgbG9va2luZyB0aHJvdWdoIHRoZSBhcmNoaXZl cyB0b25pZ2h0LCBhbmQgaXQgaXMgc3RhcnRpbmcgdG8gbG9vayBzb3J0IG9mIGRvdWJ0ZnVsLCBi dXQgSSB0aG91Z2h0IEknZCBhc2sgYW55d2F5OiBkb2VzIGFueWJvZHksIGFueXdoZXJlLCBrbm93 IG9mIGEgRmlyZXN0YXIgb2YgYW55IHZpbnRhZ2UgdGhhdCBldmVyIGFjdHVhbGx5IG1hZGUgdGhl IDI1NCBwb3VuZCB3ZWlnaHQgbGltaXQ/CgpUaGUgcmVhc29uIGlzIHRoYXQgYSBsb2NhbCBwaWxv dCBoYXMgYSB2ZXJ5IGVhcmx5IG1vZGVsIHdpdGggYSB3cmVja2VkIGNhZ2UgYW5kIGEgZ29vZCBl dmVyeXRoaW5nIGVsc2UgdGhhdCBjYW4gYmUgaGFkIGF0IGEgZ29vZCBwcmljZSwgYW5kIEkgYW0g Y29uc2lkZXJpbmcgc3RhcnRpbmcgYSBuZXcgcHJvamVjdC4uLgoKVGhhbmtzLgoKLS0tLS0tLS0K UmljaGFyZCBQaWtlCktvbGIgTUtJSUkgTjQyMFAgKDQyMGxkUG9vcHMpCktpbmdzcG9ydCwgVE4g M1ROMAomcXVvdDtMaXZpbmcgZm9yIHlvdXIgb3duIHBsZWFzdXJlIGlzIHRoZSBsZWFzdCBwbGVh c3VyYWJsZSB0aGluZyBhIG1hbiBjYW4gZG8uIElmIGhpcyBuZWlnaGJvcnMgZG9uJ3Qga2lsbCBo aW0gaW4gZGlzZ3VzdCBoZSB3aWxsIGRpZSBzbG93bHkgb2YgYm9yZWRvbSBhbmQgcG93ZXJsZXNz bmVzcy4mcXVvdDsgLSBKb3kgRGF2aWRtYW4KCgoKClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVy ZToKCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhwP3A9NDM4NTQzIzQz ODU0MwoKCgoKCgoKXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgIC0gVGhlIEtvbGItTGlzdCBFbWFpbCBGb3J1 bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93 c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRp b24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZB USwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPiBodHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGItTGlzdApfLT0KXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAg ICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRl bnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0KXy09ICAgLS0+IGh0dHA6 Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgIC0gTGlzdCBD b250cmlidXRpb24gV2ViIFNpdGUgLQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBz dXBwb3J0IQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExp c3QgQWRtaW4uCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9u Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09CgoKCgo ________________________________________________________________________________
Subject: MK III Engine Options
From: "ron.dace(at)yahoo.com" <ron.dace(at)yahoo.com>
Date: Feb 21, 2015
I would be interested to know the distribution of engines installed on MK III classic and xtra airplanes and the pros and cons of each. Would there be a common source for such information? 100 hp 912: 80 hp 912: 582: Jab 2200: Jab 3300: VW: Suzuki: Others? Reason for asking, I have a MK III Xtra airframe and am trying to decide what to do about an engine. I have a Suzuki 1.3 with a Raven on the shelf but am loosing confidence in it as an option (lack of support, complexity of the install, etc). -------- "But all the knowledge in the world is of no use to fools. And it's a long road out of Eden." - Eagles Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438544#438544 ________________________________________________________________________________
Date: Feb 21, 2015
Dennis has been on this forum for awhile. I have read his posts and they always seem logical and without ill intentions. I agree that it should be reposted on the Rans list. Maybe others will come forward with their experiences, hopefully not and the guy he talked to is new or just had a lapse in judgement. But by documenting his experience people have something to reference if they also have a bad experience. If those on this forum had the same experience as Dennis, I am sure they would have posted it here. -------- Wesley Elliott Sport Pilot-PPC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438547#438547 ________________________________________________________________________________
Date: Feb 21, 2015
Out of all those engines, to me, the best all around engine for the MKIII would be the 912UL, based on reliability and economy. Second best engine would be the 912ULS based on reliability and performance. Reliability is the number one factor for me in choosing power for an airplane, based on the environment we fly. We are not immune to gravity and there are many times I don't have a safe forced landing area. The past 21 years and 3,300.0+ hours flying my MKIII with a 912 (didn't have a 912UL in 1994), a 912S (that was the designation when I bought that engine) and a 912ULS, I have had two engine failures and both were fuel contamination and my fault, not the engines. The first two engines were sold at approximately 1,200.0 and 1,300.0 hours, both in excellent condition. The 912ULS has about 800.0 hours. I have no knowledge of the distribution of engines installed on the MKIII. The first engine I had on my MKIII was a 582. It seized at just over 200.0 hours. I have no personal experience flying the Jabs or VW. I'm guessing most folks don't power with the 912 series engines, going with alternatives, is price. There are not many VW, Suzuki, and BMW engines powering MKIII's. The above info is off the top of my head, and my experience and opinion only. If you don't fly a 912, please don't shoot me for my comments. john h mkIII Titus, Alabama --> I would be interested to know the distribution of engines installed on MK III classic and xtra airplanes and the pros and cons of each. Would there be a common source for such information? 100 hp 912: 80 hp 912: 582: Jab 2200: Jab 3300: VW: Suzuki: Others? Reason for asking, I have a MK III Xtra airframe and am trying to decide what to do about an engine. I have a Suzuki 1.3 with a Raven on the shelf but am loosing confidence in it as an option (lack of support, complexity of the install, etc). ________________________________________________________________________________
Subject: Re: MK III Engine Options
Date: Feb 21, 2015
> I'm guessing most folks don't power with the 912 series engines, going with alternatives, is price. Exactly, which is why I am looking. I will probably fly it in the 50 to 80 hour a year range (based on my current habits with a 172). An under 10K option would be optimal. If it cost more then a 912 would be worth considering. Buying new is expensive, buying used is fraught with risk. -------- "But all the knowledge in the world is of no use to fools. And it's a long road out of Eden." - Eagles Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438549#438549 ________________________________________________________________________________
Date: Feb 21, 2015
I have known of many Kolbers buying used 912 engines. As far as I know, no has gotten bit. A good source for 912's is Ronnie Smith, South Mississippi Light Aircraft. Google to get his number is interested. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of ron.dace(at)yahoo.com Sent: Saturday, February 21, 2015 8:58 AM Subject: Kolb-List: Re: MK III Engine Options --> > I'm guessing most folks don't power with the 912 series engines, going > with alternatives, is price. Exactly, which is why I am looking. I will probably fly it in the 50 to 80 hour a year range (based on my current habits with a 172). An under 10K option would be optimal. If it cost more then a 912 would be worth considering. Buying new is expensive, buying used is fraught with risk. -------- "But all the knowledge in the world is of no use to fools. And it's a long road out of Eden." - Eagles Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438549#438549 ________________________________________________________________________________
From: Colin Hudson <colin.scott.hudson(at)gmail.com>
Date: Feb 21, 2015
I've got a Mark 3 X-tra. Although I think the 912 is a fantastic engine I prefer my Jab 2200. It's very compatible to the 912 in price, performance and reliability. The thing I prefer over the 912 is like a Continental, the Jabiru runs directly off the crankshaft. Lower RPM and no gear reduction. I normally cruise around 2700 RPM. They rate the engine at 80 HP but the book says it's closer to 90. At max gross wt it will jump off the ground in 300' and climb at 1500' per min. There's been some talk about Jabs having cooling problems if they're not cowled right. In the open air pusher configuration of the Mark 3 I've had no problem with cooling. Scott Hudson N424AL M3X-tra Sent from my iPhone > On Feb 21, 2015, at 8:45 AM, John Hauck wrote: > > > Out of all those engines, to me, the best all around engine for the MKIII > would be the 912UL, based on reliability and economy. > > Second best engine would be the 912ULS based on reliability and performance. > > Reliability is the number one factor for me in choosing power for an > airplane, based on the environment we fly. We are not immune to gravity and > there are many times I don't have a safe forced landing area. The past 21 > years and 3,300.0+ hours flying my MKIII with a 912 (didn't have a 912UL in > 1994), a 912S (that was the designation when I bought that engine) and a > 912ULS, I have had two engine failures and both were fuel contamination and > my fault, not the engines. > > The first two engines were sold at approximately 1,200.0 and 1,300.0 hours, > both in excellent condition. The 912ULS has about 800.0 hours. > > I have no knowledge of the distribution of engines installed on the MKIII. > > The first engine I had on my MKIII was a 582. It seized at just over 200.0 > hours. > > I have no personal experience flying the Jabs or VW. > > I'm guessing most folks don't power with the 912 series engines, going with > alternatives, is price. > > There are not many VW, Suzuki, and BMW engines powering MKIII's. > > The above info is off the top of my head, and my experience and opinion > only. If you don't fly a 912, please don't shoot me for my comments. > > john h > mkIII > Titus, Alabama > > --> > > I would be interested to know the distribution of engines installed on MK > III classic and xtra airplanes and the pros and cons of each. Would there > be a common source for such information? > > 100 hp 912: > 80 hp 912: > 582: > Jab 2200: > Jab 3300: > VW: > Suzuki: > Others? > > Reason for asking, I have a MK III Xtra airframe and am trying to decide > what to do about an engine. I have a Suzuki 1.3 with a Raven on the shelf > but am loosing confidence in it as an option (lack of support, complexity of > the install, etc). > > > > > > > ________________________________________________________________________________
Date: Feb 21, 2015
> Jab 2200 Did you have to modify the mount? Do you have pics of your installation? -------- "But all the knowledge in the world is of no use to fools. And it's a long road out of Eden." - Eagles Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438552#438552 ________________________________________________________________________________
Date: Feb 21, 2015
If your pockets are deep enough the Rotax 912 is your best choice. Pick the power and pay the price. I flew a bit with a guy that had a Jabiru on a Kolbra and it was a bit under powered. Later I flew in a MKIIIC with a Jabiru and it did quite well even over gross weight. I think prop selection is critical to get good performance. My first VW was a direct drive on my Kolb MKIIIC. The engine turned more HP into noise than thrust. Cruise RPM was 3200 and takeoff 3600. Later switched to a redrive VW and the performance difference was startling. For the fist time I had to feed in power slowly to keep from nosing over. I ended up cruising 10 MPH faster burning 1 GPH less fuel. The VW is a good choice as a inexpensive option. The install is not for the faint of hart. The accessories are the weak part on the engine so pick them carefully. I seem to have the most problems with fuel pumps. I'm currently flying with electric dual pumps in parallel. I have had my back up Facet pump fail and a rotary primary pump warning me with electrical surges before I replaced it. Cooling can be a problem if you ask the engine to run too hard, but under 80HP it is fine. Ground handling is also a problem. Get in a long line for take off and you will overheat the engine. I had one guy complaining that he couldn't run full throttle for more than 5 minutes on the ground before it over heated. You just can't do that. Seems like I read that someone was concerned about the complexity of installing a Raven engine. If that is a concern buy nothing but a Rotax engine package. Rick Neilsen Redrive VW powered MKIIIC On Sat, Feb 21, 2015 at 10:29 AM, Colin Hudson wrote: > colin.scott.hudson(at)gmail.com> > > I've got a Mark 3 X-tra. Although I think the 912 is a fantastic engine I > prefer my Jab 2200. It's very compatible to the 912 in price, performance > and reliability. The thing I prefer over the 912 is like a Continental, > the Jabiru runs directly off the crankshaft. Lower RPM and no gear > reduction. I normally cruise around 2700 RPM. They rate the engine at 80 > HP but the book says it's closer to 90. At max gross wt it will jump off > the ground in 300' and climb at 1500' per min. There's been some talk > about Jabs having cooling problems if they're not cowled right. In the > open air pusher configuration of the Mark 3 I've had no problem with > cooling. > > Scott Hudson > N424AL > M3X-tra > > Sent from my iPhone > > > On Feb 21, 2015, at 8:45 AM, John Hauck wrote: > > > > > > Out of all those engines, to me, the best all around engine for the MKIII > > would be the 912UL, based on reliability and economy. > > > > Second best engine would be the 912ULS based on reliability and > performance. > > > > Reliability is the number one factor for me in choosing power for an > > airplane, based on the environment we fly. We are not immune to gravity > and > > there are many times I don't have a safe forced landing area. The past > 21 > > years and 3,300.0+ hours flying my MKIII with a 912 (didn't have a 912UL > in > > 1994), a 912S (that was the designation when I bought that engine) and a > > 912ULS, I have had two engine failures and both were fuel contamination > and > > my fault, not the engines. > > > > The first two engines were sold at approximately 1,200.0 and 1,300.0 > hours, > > both in excellent condition. The 912ULS has about 800.0 hours. > > > > I have no knowledge of the distribution of engines installed on the > MKIII. > > > > The first engine I had on my MKIII was a 582. It seized at just over > 200.0 > > hours. > > > > I have no personal experience flying the Jabs or VW. > > > > I'm guessing most folks don't power with the 912 series engines, going > with > > alternatives, is price. > > > > There are not many VW, Suzuki, and BMW engines powering MKIII's. > > > > The above info is off the top of my head, and my experience and opinion > > only. If you don't fly a 912, please don't shoot me for my comments. > > > > john h > > mkIII > > Titus, Alabama > > > > --> > > > > I would be interested to know the distribution of engines installed on > MK > > III classic and xtra airplanes and the pros and cons of each. Would > there > > be a common source for such information? > > > > 100 hp 912: > > 80 hp 912: > > 582: > > Jab 2200: > > Jab 3300: > > VW: > > Suzuki: > > Others? > > > > Reason for asking, I have a MK III Xtra airframe and am trying to decide > > what to do about an engine. I have a Suzuki 1.3 with a Raven on the > shelf > > but am loosing confidence in it as an option (lack of support, > complexity of > > the install, etc). > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 21, 2015
My friend has one built stock with a 447. When he bought it a few years ago he weighed it with the small stock wheels and it weighed exactly 254. He has since added slightly larger wheels but apparently can be done. If you were to go a few pounds over, how would anyone know? -------- Tony Vitiello St. Louis, MO Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438554#438554 ________________________________________________________________________________
Date: Feb 21, 2015
Hi all! Sam here in Idaho. I am currently building a MKIII Extra. My engine of choice is a converted Corvair Engine that I built for a different project. There are several pros and cons but the main reason for using a Corvair is price. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438562#438562 Attachments: http://forums.matronics.com//files/corvair_engine1_171.jpg ________________________________________________________________________________
Date: Feb 21, 2015
First and foremost, the 912 series is reliable first, has consistent power second, is not plagued with cooling problems, and is a super simple engine with extremely low maintenance. The down side is the price of the engine and the parts, but there is used stuff out there if one is willing to look for it. 4 gph at 80 mph in a MKIII ain't bad with the 912UL and 5 gph at 80 with a 912ULS. Also the 80 runs on 87 and the 100 runs on no less than 91 octane. I have had 5 engine outs and forced landings in my mkIII: -Ran out of gas in the mountains north of North Wilkesboro, NC, 10 minutes or less from the airport. 582 would not run on air alone. -Air filter, a double K&N on the 582, went AWOL and through a GSC 3 blade wooden prop. All 3 blades impacted the tail boom in the same place, bending it a few degrees out of column. Slung the carbs out of the "Rotax" sockets ;-) and the starter out of the aluminum bell housing. mkIII won't fly without prop blades, not for very long, and the 582 won't run unless carbs are installed in the sockets. -582 seized transitioning from takeoff and climb to cruise power. Solution: Get a 912 (they didn't have but one version of the engine in 1993). -Water and contamination in fuel. 912UL runs better on straight 87 octane. -Clogged fuel filter on same 912UL. Fuel will not pass through a completely blocked fuel filter. Do not be the first to get fuel from a new 1,000 gal fuel tank with new hose and nozzle that has not been flushed first. Flushing a new system into a tiny fuel filter will clog it completely. The above indicates one out of four engine outs were not pilot's fault. Pilot need to get his head out of his ___. Well, maybe I have. The last engine out was June 1994, just prior to my first flight to Alaska. Again of primary importance to me in engine selection is reliability. If my hobby was two dimensional and not three dimensional, I'd have a Kubota diesel pushing it. You get what you pay for, and you didn't pay for my opinion. So you're even. john h mkIII - 3,350.7 hours 912ULS - 782.2 hours Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen Sent: Saturday, February 21, 2015 10:28 AM Subject: Re: Kolb-List: MK III Engine Options If your pockets are deep enough the Rotax 912 is your best choice. Pick the power and pay the price. I flew a bit with a guy that had a Jabiru on a Kolbra and it was a bit under powered. Later I flew in a MKIIIC with a Jabiru and it did quite well even over gross weight. I think prop selection is critical to get good performance. My first VW was a direct drive on my Kolb MKIIIC. The engine turned more HP into noise than thrust. Cruise RPM was 3200 and takeoff 3600. Later switched to a redrive VW and the performance difference was startling. For the fist time I had to feed in power slowly to keep from nosing over. I ended up cruising 10 MPH faster burning 1 GPH less fuel. The VW is a good choice as a inexpensive option. The install is not for the faint of hart. The accessories are the weak part on the engine so pick them carefully. I seem to have the most problems with fuel pumps. I'm currently flying with electric dual pumps in parallel. I have had my back up Facet pump fail and a rotary primary pump warning me with electrical surges before I replaced it. Cooling can be a problem if you ask the engine to run too hard, but under 80HP it is fine. Ground handling is also a problem. Get in a long line for take off and you will overheat the engine. I had one guy complaining that he couldn't run full throttle for more than 5 minutes on the ground before it over heated. You just can't do that. Seems like I read that someone was concerned about the complexity of installing a Raven engine. If that is a concern buy nothing but a Rotax engine package. Rick Neilsen Redrive VW powered MKIIIC On Sat, Feb 21, 2015 at 10:29 AM, Colin Hudson wrote: I've got a Mark 3 X-tra. Although I think the 912 is a fantastic engine I prefer my Jab 2200. It's very compatible to the 912 in price, performance and reliability. The thing I prefer over the 912 is like a Continental, the Jabiru runs directly off the crankshaft. Lower RPM and no gear reduction. I normally cruise around 2700 RPM. They rate the engine at 80 HP but the book says it's closer to 90. At max gross wt it will jump off the ground in 300' and climb at 1500' per min. There's been some talk about Jabs having cooling problems if they're not cowled right. In the open air pusher configuration of the Mark 3 I've had no problem with cooling. Scott Hudson N424AL M3X-tra Sent from my iPhone > On Feb 21, 2015, at 8:45 AM, John Hauck wrote: > > > Out of all those engines, to me, the best all around engine for the MKIII > would be the 912UL, based on reliability and economy. > > Second best engine would be the 912ULS based on reliability and performance. > > Reliability is the number one factor for me in choosing power for an > airplane, based on the environment we fly. We are not immune to gravity and > there are many times I don't have a safe forced landing area. The past 21 > years and 3,300.0+ hours flying my MKIII with a 912 (didn't have a 912UL in > 1994), a 912S (that was the designation when I bought that engine) and a > 912ULS, I have had two engine failures and both were fuel contamination and > my fault, not the engines. > > The first two engines were sold at approximately 1,200.0 and 1,300.0 hours, > both in excellent condition. The 912ULS has about 800.0 hours. > > I have no knowledge of the distribution of engines installed on the MKIII. > > The first engine I had on my MKIII was a 582. It seized at just over 200.0 > hours. > > I have no personal experience flying the Jabs or VW. > > I'm guessing most folks don't power with the 912 series engines, going with > alternatives, is price. > > There are not many VW, Suzuki, and BMW engines powering MKIII's. > > The above info is off the top of my head, and my experience and opinion > only. If you don't fly a 912, please don't shoot me for my comments. > > john h > mkIII > Titus, Alabama > > --> > > I would be interested to know the distribution of engines installed on MK > III classic and xtra airplanes and the pros and cons of each. Would there > be a common source for such information? > > 100 hp 912: > 80 hp 912: > 582: > Jab 2200: > Jab 3300: > VW: > Suzuki: > Others? > > Reason for asking, I have a MK III Xtra airframe and am trying to decide > what to do about an engine. I have a Suzuki 1.3 with a Raven on the shelf > but am loosing confidence in it as an option (lack of support, complexity of > the install, etc). > > -List" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - _blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 21, 2015
@sfrIII - Corvair is a lot of engine. Do you know if there are other MK III's flying with one? @John Hauck - I would love to have a 912 and will keep that option open as my research continues. That was the engine that was originally on the my Mk III airframe. The owner/builder couldn't sell the plane intact so he parted it out and sold the engine first. -------- "But all the knowledge in the world is of no use to fools. And it's a long road out of Eden." - Eagles Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438565#438565 ________________________________________________________________________________
Date: Feb 21, 2015
RW5naW5lIHNlZWtlcnMsCgpIYXZlIGFueSBvZiB5b3UgY29uc2lkZXJlZCB0aGUgZW5naW5lIGZy b20gYSBIb25kYSBTVDExMDAgbW90b3JjeWNsZT8gwqBJdCdzIGHCoFY0IGFuZCBydW5zIHN3ZWV0 ZXIgdGhhbiBhbnkgQk1XIEkndmUgb3duZWQuIEkgcHV0IDEyOSwwMDAgbWlsZXMgb24gbXkgMjAw MCBTVCwgYW5kIEkndmUgZ290IGFib3V0IDE4MCwwMDAgbWlsZXMgb24gQmVlbWVycywgYm90aCBS IG1vZGVsIGFpcmhlYWRzIGFuIEsgbW9kZWwgYnJpY2tzLiBUaGUgUiBpcyBiZXR0ZXIgdGhhbiB0 aGUgSyBidXQgdGhlIFNULiBpcyBzd2VldGVyIHRoYW4gZWl0aGVyIG9mIHRoZW0uwqAKCkFuZCB5 b3UgY2FuIGJ1eSBvbmUgdXNlZCBmb3LCoGZpdmUgaHVuZHJlZCBidWNrcyEhIMKgR3JlYXQgZW5n aW5lLCBhc2sgRG9uIEdoZXJhZGluaSwgdGhlIEhvbmRhIE1vdG9ycyBlbmdpbmVlciB3aG8gYnVp bHQgdGhlIEZsYWdGbHkgSSBmbGV3LsKgCgoKU2VudCBmcm9tIG15IFZlcml6b24gV2lyZWxlc3Mg NEcgTFRFIFNtYXJ0cGhvbmUKCjxkaXY+LS0tLS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0t LTwvZGl2PjxkaXY+RnJvbTogInJvbi5kYWNlKGF0KXlhaG9vLmNvbSIgPHJvbi5kYWNlQHlhaG9v LmNvbT4gPC9kaXY+PGRpdj5EYXRlOjAyLzIxLzIwMTUgIDk6MzcgUE0gIChHTVQtMDU6MDApIDwv ZGl2PjxkaXY+VG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29tIDwvZGl2PjxkaXY+U3ViamVjdDog S29sYi1MaXN0OiBSZTogTUsgSUlJIEVuZ2luZSBPcHRpb25zIDwvZGl2PjxkaXY+CjwvZGl2Pi0t PiBLb2xiLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJyb24uZGFjZShhdCl5YWhvby5jb20iIDxy b24uZGFjZUB5YWhvby5jb20+CgpAc2ZySUlJIC0gQ29ydmFpciBpcyBhIGxvdCBvZiBlbmdpbmUu ICBEbyB5b3Uga25vdyBpZiB0aGVyZSBhcmUgb3RoZXIgTUsgSUlJJ3MgZmx5aW5nIHdpdGggb25l PwoKQEpvaG4gSGF1Y2sgLSBJIHdvdWxkIGxvdmUgdG8gaGF2ZSBhIDkxMiBhbmQgd2lsbCBrZWVw IHRoYXQgb3B0aW9uIG9wZW4gYXMgbXkgcmVzZWFyY2ggY29udGludWVzLiAgVGhhdCB3YXMgdGhl IGVuZ2luZSB0aGF0IHdhcyBvcmlnaW5hbGx5IG9uIHRoZSBteSBNayBJSUkgYWlyZnJhbWUuICBU aGUgb3duZXIvYnVpbGRlciBjb3VsZG4ndCBzZWxsIHRoZSBwbGFuZSBpbnRhY3Qgc28gaGUgcGFy dGVkIGl0IG91dCBhbmQgc29sZCB0aGUgZW5naW5lIGZpcnN0LgoKLS0tLS0tLS0KJnF1b3Q7QnV0 IGFsbCB0aGUga25vd2xlZGdlIGluIHRoZSB3b3JsZCBpcyBvZiBubyB1c2UgdG8gZm9vbHMuICBB bmQgaXQncyBhIGxvbmcgcm9hZCBvdXQgb2YgRWRlbi4mcXVvdDsgLSBFYWdsZXMKCgoKClJlYWQg dGhpcyB0b3BpYyBvbmxpbmUgaGVyZToKCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3 dG9waWMucGhwP3A9NDM4NTY1IzQzODU2NQoKCgoKCgoKXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgIC0gVGhl IEtvbGItTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1 cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2gg YXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3 LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9y ZToKXy09Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGIt TGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAt Cl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1z IQpfLT0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09 ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQpfLT0gIFRoYW5rIHlv dSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09CgoKCg= ________________________________________________________________________________
Date: Feb 22, 2015
you tube pics of Mike Richardson in his MkIII with BMW engine.... Last I knew he would sell it with or without the engine... I think that is the most telling thing..."with or without"....most people shy away from non standard engine installations on Kolbs.. and for that matter most other planes... no matter how well they are engineered...and Mike did a super job...excellent build and very good adaptation on the engine...Herb https://www.youtube.com/watch?v=1KGLy1FCWVU > Engine seekers, > > Have any of you considered the engine from a Honda ST1100 motorcycle? > It's a V4 and runs sweeter than any BMW I've owned. I put 129,000 > miles on my 2000 ST, and I've got about 180,000 miles on Beemers, both > R model airheads an K model bricks. The R is better than the K but the > ST. is sweeter than either of them. > > And you can buy one used for five hundred bucks!! Great engine, ask > Don Gheradini, the Honda Motors engineer who built the FlagFly I flew. > > > Sent from my Verizon Wireless 4G LTE Smartphone > > > -------- Original message -------- > From: "ron.dace(at)yahoo.com" > Date:02/21/2015 9:37 PM (GMT-05:00) > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: MK III Engine Options > > > > @sfrIII - Corvair is a lot of engine. Do you know if there are other > MK III's flying with one? > > @John Hauck - I would love to have a 912 and will keep that option > open as my research continues. That was the engine that was > originally on the my Mk III airframe. The owner/builder couldn't sell > the plane intact so he parted it out and sold the engine first. > > -------- > "But all the knowledge in the world is of no use to fools. And > it's a long road out of Eden." - Eagles > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438565#438565 > > > ~,gM4Gqz.'8*[.+-fZ+`axr^jzZ(j|n)b'!j'+ry'C > { > ,x(ZP!jrrj|-&j',r5h%lm 'ojj+*[.+-08IaT1 > jgrz{Zi^&lZ+ky+k&j',r+k&j',rhB{ky.+jY^.+-i0fr((nbxm-&j',rr&*''k{w/tml ________________________________________________________________________________
Date: Feb 22, 2015
Rick: What engine were you flying on the 1280 lb MKIIIX? john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: Sunday, February 22, 2015 9:03 AM Subject: Re: Kolb-List: Re: MK III Engine Options Sfrill, Great looking engine, but you need to consider its weight. Putting a 200 lb.+ engine in a MkIIIX reduces it to a single passenger airplane. I've flown the IIIX at 1280 lb. Very poor performance. My peronal recommendation is to not fly it at greater than 1100 lb. You also need to consider the strength of the rear portion of the fuselage truss. The MkIII was designed as a +4g airframe. Doubling the design engine weight seriously compromises the aircraft's designed strength margin. Rick Girard ________________________________________________________________________________
Subject: Engines
Date: Feb 22, 2015
With history and performance in mind the Rotax has it. For unequaled expense and basic cost it also has it. Gear box issues starter and sprague clutch and fuel pumps have been Rotax's problems and my friends have spent thousands repairing them on the S models especially On the Kolbs, a flat four is most practical,in cowled aircraft,the Viking Hondas are a great alternative at fractions on the cost. The D motor and the new V 4 are unproven but promising. I could maintain a 470 continental for less than a 912 uls. Sent from my iPhone ________________________________________________________________________________
Subject: Engines
Date: Feb 22, 2015
Only 2 of us in our group are flying Jabiru's. One , a 3300 has fought heat and carb issues in a 601xlb. My own 2200 early serial#1295 solid lifter has been pretty good so far, nothing but routine maintainence caps rotors plugs but it only has 930 hrs so not much history,but I believe a lot of engine issues are owner induced. Just my 2 cents worth Sent from my iPhone ________________________________________________________________________________
Date: Feb 22, 2015
From: william sullivan <williamtsullivan(at)att.net>
Richard: i have an original 5 rib Firestar with a 447. Wrecked at least a couple of times- once rolled over when a tie down broke, and the other time when I rolled it on landing. I am very confident it can be completed as a 103. Mine has a main fuselage tube that is a foot shorter than what I was told is normal, and because I have a BRS, my weight allowance is 278. The chute doesn't actually weigh that, so it gives a couple of pounds to play with. Somebody on the List has one where he left the nose cone off, and all of the heavy instruments. No brakes, and I don't know what he has for wheels. I have seen video of it flying. Following Jack Hart's guidelines, I think you could come in well under the weight limit. If I ever get to throw some money at mine, I think I can come in around 270. Bill Sullivan Windsor Locks, Ct. Original FS, 447 -------------------------------------------- On Fri, 2/20/15, Richard Pike wrote: Subject: Kolb-List: Part 103 legal Firestar? To: kolb-list(at)matronics.com Date: Friday, February 20, 2015, 11:54 PM "Richard Pike" Spent quite a while looking through the archives tonight, and it is starting to look sort of doubtful, but I thought I'd ask anyway: does anybody, anywhere, know of a Firestar of any vintage that ever actually made the 254 pound weight limit? The reason is that a local pilot has a very early model with a wrecked cage and a good everything else that can be had at a good price, and I am considering starting a new project... Thanks. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 "Living for your own pleasure is the least pleasurable thing a man can do. If his neighbors don't kill him in disgust he will die slowly of boredom and powerlessness." - Joy Davidman Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438543#438543 Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Feb 22, 2015
On Sun, Feb 22, 2015 at 10:59 AM, william sullivan wrote: > The chute doesn't actually weigh that, so it gives a couple of pounds to > play with. That's actually a misunderstanding of the rule... the allowance is only for the actual weight of the chute & mechanism (not to exceed the limit), not a raising of the weight limit. Of course, the chances of a ramp-check where weight is checked is so close to zero that for most of us it truly is zero, that "making weight" is something most of us have, at one time or the other, ignored completely. -- R ________________________________________________________________________________
Date: Feb 22, 2015
Ron/all There are a lot of good engines out there but are they suitable for a Kolb. The Rotax 912 series is the benchmark. It is really tough to find one that weighs as light as a 912. The VW at the time I chose my engine was the only engine close to power and weight. Even with the VW it is 10 + lbs heaver. Advertised weights and HP are frequently misrepresented. There are a bunch of issues that need to be considered before tackling a new engine on any airplane and even more on a light plane like a Kolb. Just a few are : Direct drive vs reduction drive, what RPM is best for the engine, does anyone make a working redrive for the engine (ask Larry Borne) , weight, how well will the engine hold up at 60-80% power, do you need to design and fabricate a engine mount, do you need to design and fabricate a exhaust system, what prop brand type diameter number of blades pitch (this is almost impossible to do right the first or more times), are the engine harmonics suitable for driving a prop, are you going to put a used engine on a airplane, what are parts availability like (motor cycle manufactures quit supplying parts fairly quick), will you ever be able to sell the plane with that engine on it (did you modify the air frame to mount the engine). Do you think Kolb is going to help you with a questionable one off engine? Send them big bucks or spend less and buy a 912. The VW engine is out of production for a bunch of years but you can still buy (with no end in sight) any part you want and there are inexpensive racing parts readily available. You can rebuild a VW for the cost of a 912 gasket set. Just food for thought Rick Neilsen 1st Redrive VW Powered MKIIIC On Sat, Feb 21, 2015 at 10:35 PM, undoctor wrote: > Engine seekers, > > Have any of you considered the engine from a Honda ST1100 motorcycle? > It's a V4 and runs sweeter than any BMW I've owned. I put 129,000 miles > on my 2000 ST, and I've got about 180,000 miles on Beemers, both R model > airheads an K model bricks. The R is better than the K but the ST. is > sweeter than either of them. > > And you can buy one used for five hundred bucks!! Great engine, ask Don > Gheradini, the Honda Motors engineer who built the FlagFly I flew. > > > Sent from my Verizon Wireless 4G LTE Smartphone > > > -------- Original message -------- > From: "ron.dace(at)yahoo.com" > Date:02/21/2015 9:37 PM (GMT-05:00) > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: MK III Engine Options > > ron.dace(at)yahoo.com> > > @sfrIII - Corvair is a lot of engine. Do you know if there are other MK > III's flying with one? > > @John Hauck - I would love to have a 912 and will keep that option open as > my research continues. That was the engine that was originally on the my > Mk III airframe. The owner/builder couldn't sell the plane intact so he > parted it out and sold the engine first. > > -------- > "But all the knowledge in the world is of no use to fools. And it's > a long road out of Eden." - Eagles > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438565#438565 > > ________________________________________________________________________________
Date: Feb 22, 2015
Hi Ron, I have looked Hi and Low for an EXTRA powered with a Corvair. People assume that this engine is very heavy. In reality, a running aircraft converted Corvair is only 30 LBS. heavier than a 912. Sam -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of ron.dace(at)yahoo.com Sent: Saturday, February 21, 2015 7:37 PM Subject: Kolb-List: Re: MK III Engine Options --> @sfrIII - Corvair is a lot of engine. Do you know if there are other MK III's flying with one? @John Hauck - I would love to have a 912 and will keep that option open as my research continues. That was the engine that was originally on the my Mk III airframe. The owner/builder couldn't sell the plane intact so he parted it out and sold the engine first. -------- "But all the knowledge in the world is of no use to fools. And it's a long road out of Eden." - Eagles Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438565#438565 ________________________________________________________________________________
Date: Feb 22, 2015
How does frontal area of the Corvair compare with the 912? john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Samuel Ragland Sent: Sunday, February 22, 2015 4:36 PM Subject: RE: Kolb-List: Re: MK III Engine Options Hi Ron, I have looked Hi and Low for an EXTRA powered with a Corvair. People assume that this engine is very heavy. In reality, a running aircraft converted Corvair is only 30 LBS. heavier than a 912. Sam -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of ron.dace(at)yahoo.com Sent: Saturday, February 21, 2015 7:37 PM Subject: Kolb-List: Re: MK III Engine Options --> @sfrIII - Corvair is a lot of engine. Do you know if there are other MK III's flying with one? @John Hauck - I would love to have a 912 and will keep that option open as my research continues. That was the engine that was originally on the my Mk III airframe. The owner/builder couldn't sell the plane intact so he parted it out and sold the engine first. -------- "But all the knowledge in the world is of no use to fools. And it's a long road out of Eden." - Eagles Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438565#438565 ________________________________________________________________________________
Date: Feb 22, 2015
Hi John, I found this photo of a running Corvair on a Peitenpol. I don't think it is any larger than the 912. Thanks, Sam -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck Sent: Sunday, February 22, 2015 3:54 PM Subject: RE: Kolb-List: Re: MK III Engine Options How does frontal area of the Corvair compare with the 912? john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Samuel Ragland Sent: Sunday, February 22, 2015 4:36 PM Subject: RE: Kolb-List: Re: MK III Engine Options Hi Ron, I have looked Hi and Low for an EXTRA powered with a Corvair. People assume that this engine is very heavy. In reality, a running aircraft converted Corvair is only 30 LBS. heavier than a 912. Sam -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of ron.dace(at)yahoo.com Sent: Saturday, February 21, 2015 7:37 PM Subject: Kolb-List: Re: MK III Engine Options --> @sfrIII - Corvair is a lot of engine. Do you know if there are other MK III's flying with one? @John Hauck - I would love to have a 912 and will keep that option open as my research continues. That was the engine that was originally on the my Mk III airframe. The owner/builder couldn't sell the plane intact so he parted it out and sold the engine first. -------- "But all the knowledge in the world is of no use to fools. And it's a long road out of Eden." - Eagles Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438565#438565 ________________________________________________________________________________
Date: Feb 22, 2015
Thanks for all of the good feedback. I am going to need a 100hp engine to get my 6'4" 250lb carcass off the ground particularly if there is any hope of carrying a passenger. What I have concluded so far: 912s - although expensive, probably the best option, no air frame mods required, good resale potential, known quantity probably the highest market penetration. (that is what I was trying to discern with my original post) VW w/re-drive - less expensive, overheating is a possible issue, would have to mod the air frame (additional cost with potential resale impact), there are a limited number currently flying on a MK III. Speaking of resale, it is always an issue with an experimental / kit built airplane. The original owner of the air frame couldn't sell it with the motor intact and get any where near the build cost. Parting it out was a better option. While some of the other options are intriguing and a good solution for some, maybe they aren't a good fit for me. -------- "But all the knowledge in the world is of no use to fools. And it's a long road out of Eden." - Eagles Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438597#438597 ________________________________________________________________________________
Subject: RE: Kolb-List Digest: 19 Msgs - 02/22/15
Date: Feb 24, 2015
> overheating is a possible issue I have often wondered if the nikasil cylinders for the VW would help with the marginal cooling of the heads. My answer, without a shred of empirical knowledge, is that it would. Back in the 60's my Ducati racer had a copper gasket between the head and the generously-finned cylinder (aluminum with cast iron liner). I was told by 'Ducati experts' that the cylinder drew a lot of heat away from the head. The nikasil cylinders would certainly cut some weight.. 10 lbs IIRC. Wonder if ceramic or other engine coatings would help with the head cooling. ________________________________________________________________________________
Date: Feb 24, 2015
Having built several Corvair engines over the years, while they can be made quite bulletproof, all the ones I have ever seen in aircraft use are tractors, so they can be easily cooled. As a pusher, cooling is going to get a lot more complicated. Besides; they are just too heavy. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 "Living for your own pleasure is the least pleasurable thing a man can do. If his neighbors don't kill him in disgust he will die slowly of boredom and powerlessness." - Joy Davidman Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438652#438652 ________________________________________________________________________________
Date: Feb 24, 2015
Subject: Re: RE: Kolb-List Digest: 19 Msgs - 02/22/15
George/All Great Plains Aircraft sold the nikasil cylinders for the VW for a few years. They talked about the weight savings and the cooling. They now say that they didn't work out. Never heard the why just that they don't recommend them any more. Rick Neilsen Redrive VW Powered MKIIIC On Tue, Feb 24, 2015 at 5:08 AM, George Bearden wrote: > > > overheating is a possible issue > > I have often wondered if the nikasil cylinders for the VW would help with > the marginal cooling of the heads. My answer, without a shred of empirical > knowledge, is that it would. Back in the 60's my Ducati racer had a copper > gasket between the head and the generously-finned cylinder (aluminum with > cast iron liner). I was told by 'Ducati experts' that the cylinder drew a > lot of heat away from the head. > > The nikasil cylinders would certainly cut some weight.. 10 lbs IIRC. > > Wonder if ceramic or other engine coatings would help with the head > cooling. > > ________________________________________________________________________________
Date: Feb 24, 2015
Hi Bill Sullivan & others, I have a FireStar with 5-rib wings just like yours. I built it and tried to keep the weight down per Kolb's instructions, i.e. go light on the paint; use sun block in the paint rather than the silver stuff, etc. My kit came with the skinny 1" diameter gear legs and plastic wheels. My buddy built a FireStar KXP with the same gear legs and wheels. He bent the gear legs on the first landing, so I opted to switch over to the fatter 1-1/8" Dia. legs before I flew mine, which was in 1994. We both think that after getting some experience, we could probably have used the skinny gear legs. But one place we wanted to fly to required brakes because of a downhill pavement taxi-way. Installation of the go-cart brake kit required the use of the heavier duty gear legs and the wheelbarrow wheels. This added weight. My wife suggested (strongly demanded) that I install a parachute system. I got a Second Chantz unit which I think was about 12 lbs. or so. Again adding weight, but with the idea that the parachute was less than the 24 lbs. allowance and the extra could be used to allow for the heavier gear, brakes and wheels. I didn't weigh the FireStar at that time, so no idea of the weight in that configuration. However, later on I installed a 3/4 coverage Lexan windshield and at that time I did weigh it at 275 lbs. empty (Bathroom scales). Seems to be a lot of different opinions about whether or not you can use the allowable weight of a parachute for other items. But at the time I built mine, the Kolb brochure stated that a parachute might be needed to make the 254 lb. weight, which seemed to reflect that you could. Bill Varnes Audubon, NJ Original Kolb FireStar In a message dated 2/22/2015 12:00:10 P.M. Eastern Standard Time, williamtsullivan(at)att.net writes: Following Jack Hart's guidelines, I think you could come in well under the weight limit. If I ever get to throw some money at mine, I think I can come in around 270 ________________________________________________________________________________
Subject: VW at Oshkosh 2014
Date: Feb 25, 2015
There was a builder that had a MK III with a VW at Oshkosh 2014. I only got the one picture. Does anyone know who the builder is and whether he has a published log? -------- "But all the knowledge in the world is of no use to fools. And it's a long road out of Eden." - Eagles Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438701#438701 Attachments: http://forums.matronics.com//files/vw_at_oshkosh_131.jpg ________________________________________________________________________________
Date: Feb 25, 2015
Subject: Re: VW at Oshkosh 2014
No one on this list!! :-) Herb On 02/25/2015 06:16 AM, ron.dace(at)yahoo.com wrote: > > There was a builder that had a MK III with a VW at Oshkosh 2014. I only got the one picture. Does anyone know who the builder is and whether he has a published log? > > -------- > "But all the knowledge in the world is of no use to fools. And it's a long road out of Eden." - Eagles > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438701#438701 > > > Attachments: > > http://forums.matronics.com//files/vw_at_oshkosh_131.jpg > > ________________________________________________________________________________
Date: Feb 25, 2015
> No one on this list!! Nonetheless, I thought someone might know who it was or have additional info about the plane. -------- "But all the knowledge in the world is of no use to fools. And it's a long road out of Eden." - Eagles Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438736#438736 ________________________________________________________________________________
Date: Feb 25, 2015
I was kidding...there are one or two folks on the list with vw's... Maybe they will chime in... Herb On 02/25/2015 04:25 PM, ron.dace(at)yahoo.com wrote: > >> No one on this list!! > Nonetheless, I thought someone might know who it was or have additional info about the plane. > > -------- > "But all the knowledge in the world is of no use to fools. And it's a long road out of Eden." - Eagles > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438736#438736 > > ________________________________________________________________________________
Date: Feb 25, 2015
The plane is a Kolb MKIIIXtra with a redrive VW on it. The construction looked very good. I talked to the guy quite a bit and made some observations he didn't like. Another guy that is helping on the build decided that the latest series III Valley redrive wasn't up to their standards so he built a new redrive that looks similar to a series II cog belt redrive. The series II valley drive had very nasty harmonics issues with my Powerfin prop and this one looked like it would also. Generally a light wood prop wasn't too bad but my Powerfin didn't do well. This guy is using a Warpdrive so maybe he will be lucky? Another area of concern was that this redrive uses only 5 of the 6 available mounting studs that the Valley redrive uses. Maybe the 6th stud is over kill and unnecessary? Now don't get me wrong the series III Valley isn't perfect but it is so silky smooth. It is still a belt redrive. If they had tacked a gear redrive with good harmonic dampening I would be cheering them on. The engine had a nice exhaust system and what looks like a fuel injection system. See the attached, another view Rick Neilsen RedriveVW powered MKIIIC On Wed, Feb 25, 2015 at 7:46 PM, Herb wrote: > > I was kidding...there are one or two folks on the list with vw's... Maybe > they will chime in... > > Herb > On 02/25/2015 04:25 PM, ron.dace(at)yahoo.com wrote: > >> ron.dace(at)yahoo.com> >> >> No one on this list!! >>> >> Nonetheless, I thought someone might know who it was or have additional >> info about the plane. >> >> -------- >> "But all the knowledge in the world is of no use to fools. And it's >> a long road out of Eden." - Eagles >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=438736#438736 >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Feb 25, 2015
Beautiful exhaust system until it reached the "T" at the bottom, where it hits a square wall and then separates left and right. If I had designed the exhaust system, I would have installed an mandrel bent 90 degree single outlet. I don't see any hangers/stabilizers on the exhaust system. Reckon it will stay together with that long run of tubing? john h mkIII Titus, Alabama The engine had a nice exhaust system and what looks like a fuel injection system. See the attached, another view Rick Neilsen ________________________________________________________________________________
Date: Feb 26, 2015
> The engine had a nice exhaust system Yup. I remembered seeing it and liking it but have the same reservations as John about more secure mounting. Also curving the outlet pipes down by the boom tube might reduce sound in the cabin. Also I didn't see where he had mounted the oil cooler. -------- "But all the knowledge in the world is of no use to fools. And it's a long road out of Eden." - Eagles Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438766#438766 ________________________________________________________________________________
Subject: Two Questions V. card compass and rivets
Date: Feb 26, 2015
Hello Kolbers, I have two questions. I have seen pictures of a couple of Kolb cockpits with Vertical Card compasses hanging off the Plexiglas windshields. I am thinking about hanging mine also, and would like to know what materials to use to adhered the hanger to the Lexan. Question two is.I need to rivet the horizontal stabilizer fittings to the Boom tube and stabilizer, but not sure what length of 3/16 rivet I should use, or were to get them? Thanks for the help, Nick Cassara Palmer, AK 607AK ________________________________________________________________________________
Date: Feb 26, 2015
Travis, Kolb, can send you SS rivets. I would use hardware store aluminum rivets to hang the compass. That is what I use to fasten the Lexan to doors. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Nick Cassara Sent: Thursday, February 26, 2015 2:17 PM Subject: Kolb-List: Two Questions V. card compass and rivets Hello Kolbers, I have two questions. I have seen pictures of a couple of Kolb cockpits with Vertical Card compasses hanging off the Plexiglas windshields. I am thinking about hanging mine also, and would like to know what materials to use to adhered the hanger to the Lexan. Question two is.I need to rivet the horizontal stabilizer fittings to the Boom tube and stabilizer, but not sure what length of 3/16 rivet I should use, or were to get them? Thanks for the help, Nick Cassara Palmer, AK 607AK ________________________________________________________________________________
Date: Feb 26, 2015
Subject: Re: Two Questions V. card compass and rivets
Two sided sticky (think go pro to helmet), SS bolts, alum rivets (non ferrous ), silicone( test on scraps ) May need to scuff the surface. Rivets for the horizontal. Check with Kolb Boyd Young ________________________________________________________________________________
Date: Feb 26, 2015
Nick, Do you have a picture of the fittings you need to rivet to the boom? When I did the fittings on the MkIIIX "Plane from Hell" I had to make custom rivets and special nose for my riveter. EAA published my builder's tip about making the rivets. If you need it, I can send you the nose. Rick PS I've never been able to find a lower price on pop rivets than McMaster Carr. And they're actual, honest to God, Pop Rivets, not some cheesy Hecho en Chine kind. On Thu, Feb 26, 2015 at 5:06 PM, B Young wrote: > Two sided sticky (think go pro to helmet), SS bolts, alum rivets (non > ferrous ), silicone( test on scraps ) May need to scuff the surface. > Rivets for the horizontal. Check with Kolb > Boyd Young > > * > > > * > > -- Believe those who are seeking the truth, doubt those who find it. -Andre Gide ________________________________________________________________________________
From: "KIRBY, DENNIS T GS-13 USAF AFMC AFNWC/ENS" <dennis.kirby.3(at)us.af.mil>
Date: Feb 27, 2015
"ron.dace" wrote: << I will probably fly it in the 50 to 80 hour a year range. An under 10K option would be optimal. If it cost more then a 912 would be worth considering. Buying new is expensive, buying used is fraught with risk. >> Ron / All - I must agree with John H's advice, that the Rotax-912 (either model) is a good bet for your money. When I finished building my Mark-3 in 2002 (before it was labeled "Classic"), like you, I too was looking to save a few bucks on an engine. I bought a new Verner-1400 (80 hp) because it looked like a good 2-cylinder 4-stroke engine with lots of torque. New price was $7500. I even flew in another Mark-3 with that engine installed to be sure. Seemed to fly fine with that engine. The engine sounded good and provided plenty of power. The Kolb Company was also experimenting with that engine, so I thought I made a good choice. Well ... Turns out the engine was creating an insidious and destructive harmonic vibration in my Kolb that made it unsuitable to continue use. Pulled it off after only 20 hours and began looking for a different engine. The guys at Kolb Co also concluded that the Verner was not a good match for the Mark-3, and scrapped further testing with that engine. I began looking on Barnstormers, and found a low-time 80 hp 912ul (with only 22 hrs TT) for sale for $8500. Bought it, and it was the best choice I could have made. I've put 300 hours on my Kolb since then, and it has never missed a beat. As Hauck said, reliability is key, and this engine delivers. Plug and play for a Kolb Mark-3. No experimentation or modification necessary to make it fit right. I'd rather spend my time flying instead of experimenting. So, keep your eyes on Barnstormers - the 912 does occasionally come up for sale. And if you buy one that's in good shape, you won't be disappointed. That was MY experience, anyway. Good luck ... Dennis Kirby Mark-3 / 912ul / Powerfin-72 Sandia Park, NM ________________________________________________________________________________
Subject: Re: New (free) Aviation App
Date: Mar 01, 2015
Now approaching 6000 pilots using the app with over 1350 listings, and a recent review on the EAA website. And in a feeble attempt to recoup my costs, I am now offering very reasonably priced ad's for aviation related businesses as I keep my word to keep this app free for pilots. If you or someone you know may be interested, please email me at airportcars101(at)gmail.com for rates. And please tell your FBO where you found them. Thank you. Glenn -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App www.RVairspace.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438851#438851 ________________________________________________________________________________
Date: Mar 04, 2015
Subject: FireFly Page Is Back UP
I just finished getting my web page back up on the web. It can be found at: http://www.jackbhart.com/firefly.html If you visit the site, I would appreciate it very much if you would report any errors or bfoken links that you find. I have been grounded for several years. Shortly I will be visiting the FireFly and getting it ready to fly. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Mar 04, 2015
Sorry Jack, I am getting a 404 error from your link. I am sure it is just some little thing, maybe the DNS servers need a day or two to get the update (if this is a new host for your domain name). I have referenced your old web page many times while building and have been toying with the idea of putting up a site about the building of my firefly. Just a matter of finding the motivation and time to get it done. As soon as it gets warm enough to get out and work on the hangar (or other outside stuff) I am afraid I won't be spending too much time in front of a computer. :) Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack B. Hart Sent: Wednesday, March 04, 2015 3:37 PM Subject: Kolb-List: FireFly Page Is Back UP --> I just finished getting my web page back up on the web. It can be found at: http://www.jackbhart.com/firefly.html If you visit the site, I would appreciate it very much if you would report any errors or bfoken links that you find. I have been grounded for several years. Shortly I will be visiting the FireFly and getting it ready to fly. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Mar 04, 2015
Subject: Re: FireFly Page Is Back UP
Try this: http://www.jackbhart.com/firefly/firefly.html On Wed, Mar 4, 2015 at 4:01 PM, Stuart Harner wrote: > > Sorry Jack, I am getting a 404 error from your link. I am sure it is just > some little thing, maybe the DNS servers need a day or two to get the > update > (if this is a new host for your domain name). > > I have referenced your old web page many times while building and have been > toying with the idea of putting up a site about the building of my firefly. > Just a matter of finding the motivation and time to get it done. > > As soon as it gets warm enough to get out and work on the hangar (or other > outside stuff) I am afraid I won't be spending too much time in front of a > computer. :) > > Stuart > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack B. Hart > Sent: Wednesday, March 04, 2015 3:37 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: FireFly Page Is Back UP > > --> > > > I just finished getting my web page back up on the web. It can be found > at: > > http://www.jackbhart.com/firefly.html > > If you visit the site, I would appreciate it very much if you would report > any errors or bfoken links that you find. > > > I have been grounded for several years. Shortly I will be visiting the > FireFly and getting it ready to fly. > > > Jack B. Hart FF004 > Winchester, IN > > ________________________________________________________________________________
Date: Mar 04, 2015
jbhart(at)onlyinternet.ne wrote: > I just finished getting my web page back up on the web. It can be found at: > > http://www.jackbhart.com/firefly.html > > If you visit the site, I would appreciate it very much if you would report any errors or bfoken links that you find. > > > I have been grounded for several years. Shortly I will be visiting the FireFly and getting it ready to fly. > > > Jack B. Hart FF004 > Winchester, IN Jack: It may be possible that you left out the file directory and the address should be: http://www.jackbhart.com/firefly/firefly.html This gets me to what looks like your page. -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439054#439054 ________________________________________________________________________________
Date: Mar 05, 2015
Second try! I just finished getting my web page back up on the web. It can be found at: http://www.jackbhart.com/firefly/firefly.html If you visit the site, I would appreciate it very much if you would report any errors or bfoken links that you find. I have been grounded for several years. Shortly I will be visiting the FireFly and getting it ready to fly. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Subject: Book
Date: Mar 06, 2015
Just leaning on everyones good nature to give a puff for a slim volume which I have written. It is called `Atrak the other Otter` and is an updated version of Tarka the Otter, Wind in the Willows etc. Being the well read lot I know you all to be you will be familiar with these stories. My book will be serialised at 10 pm UK time for the next 6 Saturdays, (starting tomorrow 7th March) in 30 minute chunks. Tune in your computer to www.dovercommunityradio.co.uk and press the cassette in the top right corner at that time and enjoy. If you have a small child aged around 8/9 around they might well enjoy it too, but on a different level. There is one chapter where Atrak goes flying, gliding I admit, but heigh ho, which you might enjoy. You won`t get all the jokes, in fact unless you are a certain age (remember Kilroy?) you will miss some altogether but I hope you find it amusing. Dover Radio programmes are broadcast on radio down a swathe of the UK South coast and streamed worldwide at the url above. Responses come from Oz,NZ, Canada, USA. Dover Radio and myself will be very interested in any feedback you care to pass our way. Thanks for your indulgence Pat ________________________________________________________________________________
Date: Mar 06, 2015
Subject: Re: Book
On 3/6/2015 11:57 AM, Patrick Ladd wrote: > Just leaning on everyones good nature to give a puff for a slim volume > which I have written. > It is called `Atrak the other Otter` and is an updated version of > Tarka the Otter, Wind in the Willows etc. Being the well read lot I > know you all to be you will be familiar with these stories. > My book will be serialised at 10 pm UK time for the next 6 Saturdays, > (starting tomorrow 7th March) in 30 minute chunks. > Tune in your computer to www.dovercommunityradio.co.uk and press the > cassette in the top right corner at that time and enjoy. If you have a > small child aged around 8/9 around they might well enjoy it too, but > on a different level. > There is one chapter where Atrak goes flying, gliding I admit, but > heigh ho, which you might enjoy. You won`t get all the jokes, in fact > unless you are a certain age (remember Kilroy?) you will miss some > altogether but I hope you find it amusing. > Dover Radio programmes are broadcast on radio down a swathe of the UK > South coast and streamed worldwide at the url above. Responses come > from Oz,NZ, Canada, USA. Dover Radio and myself will be very > interested in any feedback you care to pass our way. > Thanks for your indulgence > Pat > Hi Pat, Will it be archived for later downloads? Thanks, Charlie ________________________________________________________________________________
Subject: Re: Book
Date: Mar 07, 2015
Hi Charlie, i think the only way to do that is to leave a tape recorder running with the mic close to your computer. Too complex for me. Pat From: Charlie England Sent: Saturday, March 07, 2015 1:28 AM Subject: Re: Kolb-List: Book On 3/6/2015 11:57 AM, Patrick Ladd wrote: Just leaning on everyones good nature to give a puff for a slim volume which I have written. It is called `Atrak the other Otter` and is an updated version of Tarka the Otter, Wind in the Willows etc. Being the well read lot I know you all to be you will be familiar with these stories. My book will be serialised at 10 pm UK time for the next 6 Saturdays, (starting tomorrow 7th March) in 30 minute chunks. Tune in your computer to www.dovercommunityradio.co.uk and press the cassette in the top right corner at that time and enjoy. If you have a small child aged around 8/9 around they might well enjoy it too, but on a different level. There is one chapter where Atrak goes flying, gliding I admit, but heigh ho, which you might enjoy. You won`t get all the jokes, in fact unless you are a certain age (remember Kilroy?) you will miss some altogether but I hope you find it amusing. Dover Radio programmes are broadcast on radio down a swathe of the UK South coast and streamed worldwide at the url above. Responses come from Oz,NZ, Canada, USA. Dover Radio and myself will be very interested in any feedback you care to pass our way. Thanks for your indulgence Pat Hi Pat, Will it be archived for later downloads? Thanks, Charlie ________________________________________________________________________________
Subject: Re: Book
Date: Mar 07, 2015
Hi Pat, if you would like to save it for posterity, there is a free downloadable program that is quite safe called Audacity. http://audacity.sourceforge.net/ You can use it to record either from a mic, or it will record whatever your computer is playing through the speakers. It is open source software and designed to be user friendly, quite simple to configure, any 14 year old ought to be able to do it for you without reading the instructions in 2 or 3 minutes, or you could read the instructions and do it yourself in 10. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 "Living for your own pleasure is the least pleasurable thing a man can do. If his neighbors don't kill him in disgust he will die slowly of boredom and powerlessness." - Joy Davidman Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439128#439128 ________________________________________________________________________________
Subject: Re: Book
Date: Mar 07, 2015
Thank you Richard, I hope that someone will find that useful. As far as I am concerned, I have it all on CD. Although I must admit looking forward to tonights broadcast with some excitement. Pat -----Original Message----- From: Richard Pike Sent: Saturday, March 07, 2015 4:13 PM Subject: Kolb-List: Re: Book Hi Pat, if you would like to save it for posterity, there is a free downloadable program that is quite safe called Audacity. http://audacity.sourceforge.net/ You can use it to record either from a mic, or it will record whatever your computer is playing through the speakers. It is open source software and designed to be user friendly, quite simple to configure, any 14 year old ought to be able to do it for you without reading the instructions in 2 or 3 minutes, or you could read the instructions and do it yourself in 10. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 "Living for your own pleasure is the least pleasurable thing a man can do. If his neighbors don't kill him in disgust he will die slowly of boredom and powerlessness." - Joy Davidman Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439128#439128 ________________________________________________________________________________
Date: Mar 07, 2015
Subject: Re: Book
I saw someone say to put Recorder by the computer,,,, Could you use the sound recorder in the computer and make a digital recording Boyd On Mar 7, 2015 10:46 AM, "Patrick Ladd" wrote: > > Thank you Richard, I hope that someone will find that useful. As far as I > am concerned, I have it all on CD. Although I must admit looking forward > to tonights broadcast with some excitement. Pat > > -----Original Message----- From: Richard Pike > Sent: Saturday, March 07, 2015 4:13 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: Book > > > Hi Pat, if you would like to save it for posterity, there is a free > downloadable program that is quite safe called Audacity. > http://audacity.sourceforge.net/ > You can use it to record either from a mic, or it will record whatever > your computer is playing through the speakers. It is open source software > and designed to be user friendly, quite simple to configure, any 14 year > old ought to be able to do it for you without reading the instructions in 2 > or 3 minutes, or you could read the instructions and do it yourself in 10. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > "Living for your own pleasure is the least pleasurable thing a man > can do. If his neighbors don't kill him in disgust he will die slowly of > boredom and powerlessness." - Joy Davidman > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439128#439128 > > ________________________________________________________________________________
Subject: Re: Book
Date: Mar 08, 2015
Thanks for everyone who made suggestions about recording this broadcast. Unfortunately the broadcast itself was a disaster. The DJ who was on before my story was due to go out did 2 hours live He then switched to another computer which was scheduled to run automatically for another 2 hours of the DJ`s stuff and then play my story, and went home. Unfortunately the volume slider on the new computer was not advanced and the signal was going no farther than the mixing desk. The problem was realised by my brother in law who was monitoring things on his own computer at home He contacted the chief engineer who unfortunately lived 20 miles away and had to readjust things remotely and switch the broadcast back to the original computer. This took time and Atrak the OTHER Otter finally went out about 7 minutes late and as there was nothing going on but a carrier wave on the station I should think that all the listeners had given up in disgust. My chance at world wide fame, I was already signing the film contract, gone down the Swannee. Cheers Pat From: B Young Sent: Saturday, March 07, 2015 11:48 PM Subject: Re: Kolb-List: Re: Book I saw someone say to put Recorder by the computer,,,, Could you use the sound recorder in the computer and make a digital recording Boyd On Mar 7, 2015 10:46 AM, "Patrick Ladd" wrote: Thank you Richard, I hope that someone will find that useful. As far as I am concerned, I have it all on CD. Although I must admit looking forward to tonights broadcast with some excitement. Pat -----Original Message----- From: Richard Pike Sent: Saturday, March 07, 2015 4:13 PM To: kolb-list(at)matronics.com Subject: Kolb-List: Re: Book Hi Pat, if you would like to save it for posterity, there is a free downloadable program that is quite safe called Audacity. http://audacity.sourceforge.net/ You can use it to record either from a mic, or it will record whatever your computer is playing through the speakers. It is open source software and designed to be user friendly, quite simple to configure, any 14 year old ought to be able to do it for you without reading the instructions in 2 or 3 minutes, or you could read the instructions and do it yourself in 10. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 "Living for your own pleasure is the least pleasurable thing a man can do. If his neighbors don't kill him in disgust he will die slowly of boredom and powerlessness." - Joy Davidman Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439128#439128 -List" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - _blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Book
Date: Mar 08, 2015
Sorry for your troubles! =94 those damn=99 electrons Soon as Hollyweed signs my book contract, I=99ll tell them to buy yours. Fair winds, Russ > On Mar 8, 2015, at 8:07 AM, Patrick Ladd wrote: > > Thanks for everyone who made suggestions about recording this broadcast. Unfortunately the broadcast itself was a disaster. The DJ who was on before my story was due to go out did 2 hours live He then switched to another computer which was scheduled to run automatically for another 2 hours of the DJ`s stuff and then play my story, and went home. Unfortunately the volume slider on the new computer was not advanced and the signal was going no farther than the mixing desk. The problem was realised by my brother in law who was monitoring things on his own computer at home He contacted the chief engineer who unfortunately lived 20 miles away and had to readjust things remotely and switch the broadcast back to the original computer. This took time and Atrak the OTHER Otter finally went out about 7 minutes late and as there was nothing going on but a carrier wave on the station I should think that all the listeners had given up in disgust. > My chance at world wide fame, I was already signing the film contract, gone down the Swannee. > > Cheers > > Pat > > From: B Young <mailto:byoungplumbing(at)gmail.com> > Sent: Saturday, March 07, 2015 11:48 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: Book > > I saw someone say to put Recorder by the computer,,,, > Could you use the sound recorder in the computer and make a digital recording > Boyd > On Mar 7, 2015 10:46 AM, "Patrick Ladd" > wrote: > >> >> Thank you Richard, I hope that someone will find that useful. As far as I am concerned, I have it all on CD. Although I must admit looking forward to tonights broadcast with some excitement. Pat >> >> -----Original Message----- From: Richard Pike >> Sent: Saturday, March 07, 2015 4:13 PM >> To: kolb-list(at)matronics.com >> Subject: Kolb-List: Re: Book >> > >> >> Hi Pat, if you would like to save it for posterity, there is a free downloadable program that is quite safe called Audacity. >> http://audacity.sourceforge.net/ >> You can use it to record either from a mic, or it will record whatever your computer is playing through the speakers. It is open source software and designed to be user friendly, quite simple to configure, any 14 year old ought to be able to do it for you without reading the instructions in 2 or 3 minutes, or you could read the instructions and do it yourself in 10. >> >> -------- >> Richard Pike >> Kolb MKIII N420P (420ldPoops) >> Kingsport, TN 3TN0 >> "Living for your own pleasure is the least pleasurable thing a man can do. If his neighbors don't kill him in disgust he will die slowly of boredom and powerlessness." - Joy Davidman >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=439128#439128 <http://forums.matronics.com/viewtopic.php?p=439128#439128> >> >> >> >> >> >> >> >> >> >> >> >> ======================== =========== >> -List" target="_blank">http://www.matronics.com/Navigator?Kolb-List >> ======================== =========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> ======================== =========== >> >> >> > > > > href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics .com/Navigator?Kolb-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > <http://www.matronics.com/Navigator?Kolb-List> <http://www.matronics.com/contribution> > ________________________________________________________________________________
Subject: Dual throttle controls
Date: Mar 08, 2015
I am wanting to set up throttle controls on the left and right sides of my Mark 3 . If anyone has this setup and could send pictures or post pictures , it would help me . Or if you know where to purchase . Thanks , everyone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439150#439150 ________________________________________________________________________________
Subject: Re: Book
Date: Mar 08, 2015
UnVzcywgDQoNCiAgIEVsZWN0cm9ucyB3ZXJlIGlubm9jZW50LiAgSHVtYW4gZXJyb3IgYXMgdXN1 YWwuICA6LSkNCg0KTWlrZQ0KDQoNCg0KT24gTWFyIDgsIDIwMTUsIGF0IDc6MjQgQU0sICJraW5u ZSBydXNzIiA8cnVzc2s1MEBnbWFpbC5jb20+IHdyb3RlOg0KDQo+IFNvcnJ5IGZvciB5b3VyIHRy b3VibGVzISDigJQgdGhvc2UgZGFtbuKAmSBlbGVjdHJvbnMNCj4gU29vbiBhcyBIb2xseXdlZWQg c2lnbnMgbXkgYm9vayBjb250cmFjdCwgSeKAmWxsIHRlbGwgdGhlbSB0byBidXkgeW91cnMuDQo+ IEZhaXIgd2luZHMsDQo+IFJ1c3MNCj4gDQo+IA0KPj4gT24gTWFyIDgsIDIwMTUsIGF0IDg6MDcg QU0sIFBhdHJpY2sgTGFkZCA8cGF0cmlja2psYWRkQGhvdG1haWwuY29tPiB3cm90ZToNCj4+IA0K Pj4gVGhhbmtzIGZvciBldmVyeW9uZSB3aG8gbWFkZSBzdWdnZXN0aW9ucyBhYm91dCByZWNvcmRp bmcgdGhpcyBicm9hZGNhc3QuIFVuZm9ydHVuYXRlbHkgdGhlIGJyb2FkY2FzdCBpdHNlbGYgd2Fz IGEgZGlzYXN0ZXIuIFRoZSBESiB3aG8gd2FzIG9uIGJlZm9yZSBteSBzdG9yeSB3YXMgZHVlIHRv IGdvIG91dCBkaWQgMiBob3VycyBsaXZlIEhlIHRoZW4gIHN3aXRjaGVkIHRvIGFub3RoZXIgY29t cHV0ZXIgd2hpY2ggd2FzIHNjaGVkdWxlZCB0byBydW4gYXV0b21hdGljYWxseSBmb3IgYW5vdGhl ciAyIGhvdXJzIG9mIHRoZSBESmBzIHN0dWZmIGFuZCB0aGVuIHBsYXkgbXkgc3RvcnksIGFuZCB3 ZW50IGhvbWUuIFVuZm9ydHVuYXRlbHkgdGhlIHZvbHVtZSBzbGlkZXIgb24gdGhlIG5ldyBjb21w dXRlciB3YXMgbm90IGFkdmFuY2VkIGFuZCB0aGUgc2lnbmFsIHdhcyBnb2luZyBubyBmYXJ0aGVy IHRoYW4gdGhlIG1peGluZyBkZXNrLiBUaGUgcHJvYmxlbSB3YXMgcmVhbGlzZWQgYnkgbXkgYnJv dGhlciBpbiBsYXcgd2hvIHdhcyBtb25pdG9yaW5nIHRoaW5ncyBvbiBoaXMgb3duIGNvbXB1dGVy IGF0IGhvbWUgSGUgY29udGFjdGVkIHRoZSBjaGllZiBlbmdpbmVlciB3aG8gdW5mb3J0dW5hdGVs eSBsaXZlZCAyMCBtaWxlcyBhd2F5IGFuZCBoYWQgdG8gcmVhZGp1c3QgdGhpbmdzIHJlbW90ZWx5 IGFuZCBzd2l0Y2ggdGhlIGJyb2FkY2FzdCBiYWNrIHRvIHRoZSBvcmlnaW5hbCBjb21wdXRlci4g VGhpcyB0b29rIHRpbWUgYW5kIEF0cmFrIHRoZSBPVEhFUiBPdHRlciBmaW5hbGx5IHdlbnQgb3V0 IGFib3V0IDcgbWludXRlcyBsYXRlIGFuZCBhcyB0aGVyZSB3YXMgbm90aGluZyBnb2luZyBvbiBi dXQgYSBjYXJyaWVyIHdhdmUgb24gdGhlIHN0YXRpb24gSSBzaG91bGQgdGhpbmsgdGhhdCBhbGwg dGhlIGxpc3RlbmVycyBoYWQgZ2l2ZW4gdXAgaW4gZGlzZ3VzdC4NCj4+IE15IGNoYW5jZSBhdCB3 b3JsZCB3aWRlIGZhbWUsIEkgd2FzIGFscmVhZHkgc2lnbmluZyB0aGUgZmlsbSBjb250cmFjdCwg Z29uZSBkb3duIHRoZSBTd2FubmVlLg0KPj4gIA0KPj4gQ2hlZXJzDQo+PiAgDQo+PiBQYXQNCj4+ ICANCj4+IEZyb206IEIgWW91bmcNCj4+IFNlbnQ6IFNhdHVyZGF5LCBNYXJjaCAwNywgMjAxNSAx MTo0OCBQTQ0KPj4gVG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29tDQo+PiBTdWJqZWN0OiBSZTog S29sYi1MaXN0OiBSZTogQm9vaw0KPj4gIA0KPj4gSSBzYXcgc29tZW9uZSBzYXkgdG8gcHV0IFJl Y29yZGVyIGJ5IHRoZSBjb21wdXRlciwsLCwNCj4+IENvdWxkIHlvdSB1c2UgdGhlIHNvdW5kIHJl Y29yZGVyIGluIHRoZSBjb21wdXRlciBhbmQgbWFrZSBhIGRpZ2l0YWwgcmVjb3JkaW5nDQo+PiBC b3lkDQo+PiBPbiBNYXIgNywgMjAxNSAxMDo0NiBBTSwgIlBhdHJpY2sgTGFkZCIgPHBhdHJpY2tq bGFkZEBob3RtYWlsLmNvbT4gd3JvdGU6DQo+Pj4gLS0+IEtvbGItTGlzdCBtZXNzYWdlIHBvc3Rl ZCBieTogUGF0cmljayBMYWRkIDxwYXRyaWNramxhZGRAaG90bWFpbC5jb20+DQo+Pj4gDQo+Pj4g VGhhbmsgeW91IFJpY2hhcmQsIEkgaG9wZSB0aGF0IHNvbWVvbmUgd2lsbCBmaW5kIHRoYXQgdXNl ZnVsLiBBcyBmYXIgYXMgSSBhbSBjb25jZXJuZWQsIEkgaGF2ZSBpdCBhbGwgb24gQ0QuICBBbHRo b3VnaCBJIG11c3QgYWRtaXQgbG9va2luZyBmb3J3YXJkIHRvIHRvbmlnaHRzIGJyb2FkY2FzdCB3 aXRoIHNvbWUgZXhjaXRlbWVudC4gUGF0DQo+Pj4gDQo+Pj4gLS0tLS1PcmlnaW5hbCBNZXNzYWdl LS0tLS0gRnJvbTogUmljaGFyZCBQaWtlDQo+Pj4gU2VudDogU2F0dXJkYXksIE1hcmNoIDA3LCAy MDE1IDQ6MTMgUE0NCj4+PiBUbzoga29sYi1saXN0QG1hdHJvbmljcy5jb20NCj4+PiBTdWJqZWN0 OiBLb2xiLUxpc3Q6IFJlOiBCb29rDQo+Pj4gDQo+Pj4gLS0+IEtvbGItTGlzdCBtZXNzYWdlIHBv c3RlZCBieTogIlJpY2hhcmQgUGlrZSIgPHRoZWdyZXliYXJvbkBjaGFydGVyLm5ldD4NCj4+PiAN Cj4+PiBIaSBQYXQsIGlmIHlvdSB3b3VsZCBsaWtlIHRvIHNhdmUgaXQgZm9yIHBvc3Rlcml0eSwg dGhlcmUgaXMgYSBmcmVlIGRvd25sb2FkYWJsZSBwcm9ncmFtIHRoYXQgaXMgcXVpdGUgc2FmZSBj YWxsZWQgQXVkYWNpdHkuDQo+Pj4gaHR0cDovL2F1ZGFjaXR5LnNvdXJjZWZvcmdlLm5ldC8NCj4+ PiBZb3UgY2FuIHVzZSBpdCB0byByZWNvcmQgZWl0aGVyIGZyb20gYSBtaWMsIG9yIGl0IHdpbGwg cmVjb3JkIHdoYXRldmVyIHlvdXIgY29tcHV0ZXIgaXMgcGxheWluZyB0aHJvdWdoIHRoZSBzcGVh a2Vycy4gSXQgaXMgb3BlbiBzb3VyY2Ugc29mdHdhcmUgYW5kIGRlc2lnbmVkIHRvIGJlIHVzZXIg ZnJpZW5kbHksIHF1aXRlIHNpbXBsZSB0byBjb25maWd1cmUsIGFueSAxNCB5ZWFyIG9sZCBvdWdo dCB0byBiZSBhYmxlIHRvIGRvIGl0IGZvciB5b3Ugd2l0aG91dCByZWFkaW5nIHRoZSBpbnN0cnVj dGlvbnMgaW4gMiBvciAzIG1pbnV0ZXMsIG9yIHlvdSBjb3VsZCByZWFkIHRoZSBpbnN0cnVjdGlv bnMgYW5kIGRvIGl0IHlvdXJzZWxmIGluIDEwLg0KPj4+IA0KPj4+IC0tLS0tLS0tDQo+Pj4gUmlj aGFyZCBQaWtlDQo+Pj4gS29sYiBNS0lJSSBONDIwUCAoNDIwbGRQb29wcykNCj4+PiBLaW5nc3Bv cnQsIFROIDNUTjANCj4+PiAmcXVvdDtMaXZpbmcgZm9yIHlvdXIgb3duIHBsZWFzdXJlIGlzIHRo ZSBsZWFzdCBwbGVhc3VyYWJsZSB0aGluZyBhIG1hbiBjYW4gZG8uIElmIGhpcyBuZWlnaGJvcnMg ZG9uJ3Qga2lsbCBoaW0gaW4gZGlzZ3VzdCBoZSB3aWxsIGRpZSBzbG93bHkgb2YgYm9yZWRvbSBh bmQgcG93ZXJsZXNzbmVzcy4mcXVvdDsgLSBKb3kgRGF2aWRtYW4NCj4+PiANCj4+PiANCj4+PiAN Cj4+PiANCj4+PiBSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6DQo+Pj4gDQo+Pj4gaHR0cDov L2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD00MzkxMjgjNDM5MTI4DQo+Pj4g DQo+Pj4gDQo+Pj4gDQo+Pj4gDQo+Pj4gDQo+Pj4gDQo+Pj4gDQo+Pj4gDQo+Pj4gDQo+Pj4gDQo+ Pj4gDQo+Pj4gPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQo+Pj4gLUxpc3Qi IHRhcmdldD0iX2JsYW5rIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGIt TGlzdA0KPj4+ID09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KPj4+IEZPUlVN UyAtDQo+Pj4gX2JsYW5rIj5odHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCj4+PiA9PT09PT09 PT09PQ0KPj4+IGIgU2l0ZSAtDQo+Pj4gICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1p bi4NCj4+PiB0YXJnZXQ9Il9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1 dGlvbg0KPj4+ID09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KPj4+IA0KPj4+ IA0KPj4+IA0KPj4gDQo+PiANCj4+IA0KPj4gaHJlZj0iaHR0cDovL3d3dy5tYXRyb25pY3MuY29t L05hdmlnYXRvcj9Lb2xiLUxpc3QiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/ S29sYi1MaXN0DQo+PiBocmVmPSJodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20iPmh0dHA6Ly9m b3J1bXMubWF0cm9uaWNzLmNvbQ0KPj4gaHJlZj0iaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2Nv bnRyaWJ1dGlvbiI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2MNCj4+IA0KPj4gDQo+PiBjbGFz cz0iIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGItTGlzdA0KPj4gY2xh c3M9IiI+aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQo+PiBjbGFzcz0iIj5odHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQo+PiANCj4gDQo+IA0KPiANCj4gXy09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj4g Xy09ICAgICAgICAgIC0gVGhlIEtvbGItTGlzdCBFbWFpbCBGb3J1bSAtDQo+IF8tPSBVc2UgdGhl IE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCj4gXy09IHRoZSBt YW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQo+IF8tPSBB cmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCj4gXy09 IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCj4gXy09DQo+IF8tPSAgIC0tPiBodHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGItTGlzdA0KPiBfLT0NCj4gXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cj4gXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQo+IF8tPSBTYW1l IGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KPiBfLT0N Cj4gXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KPiBfLT0NCj4gXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cj4gXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KPiBfLT0g IFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KPiBfLT0gICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQo+IF8tPSAgIC0tPiBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQo+IF8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQo+IA0K ________________________________________________________________________________
Subject: Re: Book
Date: Mar 08, 2015
List, my apologies. That as meant for Pat Russ K > On Mar 8, 2015, at 8:22 AM, kinne russ wrote: > > Sorry for your troubles! =94 those damn=99 electrons > Soon as Hollyweed signs my book contract, I=99ll tell them to buy yours. > Fair winds, > Russ > > >> On Mar 8, 2015, at 8:07 AM, Patrick Ladd > wrote: >> >> Thanks for everyone who made suggestions about recording this broadcast. Unfortunately the broadcast itself was a disaster. The DJ who was on before my story was due to go out did 2 hours live He then switched to another computer which was scheduled to run automatically for another 2 hours of the DJ`s stuff and then play my story, and went home. Unfortunately the volume slider on the new computer was not advanced and the signal was going no farther than the mixing desk. The problem was realised by my brother in law who was monitoring things on his own computer at home He contacted the chief engineer who unfortunately lived 20 miles away and had to readjust things remotely and switch the broadcast back to the original computer. This took time and Atrak the OTHER Otter finally went out about 7 minutes late and as there was nothing going on but a carrier wave on the station I should think that all the listeners had given up in disgust. >> My chance at world wide fame, I was already signing the film contract, gone down the Swannee. >> >> Cheers >> >> Pat >> >> From: B Young <mailto:byoungplumbing(at)gmail.com> >> Sent: Saturday, March 07, 2015 11:48 PM >> To: kolb-list(at)matronics.com >> Subject: Re: Kolb-List: Re: Book >> >> I saw someone say to put Recorder by the computer,,,, >> Could you use the sound recorder in the computer and make a digital recording >> Boyd >> On Mar 7, 2015 10:46 AM, "Patrick Ladd" > wrote: > >>> >>> Thank you Richard, I hope that someone will find that useful. As far as I am concerned, I have it all on CD. Although I must admit looking forward to tonights broadcast with some excitement. Pat >>> >>> -----Original Message----- From: Richard Pike >>> Sent: Saturday, March 07, 2015 4:13 PM >>> To: kolb-list(at)matronics.com >>> Subject: Kolb-List: Re: Book >>> > >>> >>> Hi Pat, if you would like to save it for posterity, there is a free downloadable program that is quite safe called Audacity. >>> http://audacity.sourceforge.net/ >>> You can use it to record either from a mic, or it will record whatever your computer is playing through the speakers. It is open source software and designed to be user friendly, quite simple to configure, any 14 year old ought to be able to do it for you without reading the instructions in 2 or 3 minutes, or you could read the instructions and do it yourself in 10. >>> >>> -------- >>> Richard Pike >>> Kolb MKIII N420P (420ldPoops) >>> Kingsport, TN 3TN0 >>> "Living for your own pleasure is the least pleasurable thing a man can do. If his neighbors don't kill him in disgust he will die slowly of boredom and powerlessness." - Joy Davidman >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=439128#439128 <http://forums.matronics.com/viewtopic.php?p=439128#439128> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> ======================== =========== >>> -List" target="_blank">http://www.matronics.com/ <http://www.matronics.com/>Navigator?Kolb-List >>> ======================== =========== >>> FORUMS - >>> _blank">http://forums.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> target="_blank">http://www.matronics.com/ <http://www.matronics.com/>contribution >>> ======================== =========== >>> >>> >>> >> >> >> >> href="http://www.matronics.com/Navigator?Kolb-List <http://www.matronics.com/Navigator?Kolb-List>">http://www.matronics.com/N avigator?Kolb-List <http://www.matronics.com/Navigator?Kolb-List> >> href="http://forums.matronics.com <http://forums.matronics.com/>">http://forums.matronics.com <http://forums.matronics.com/> >> href="http://www.matronics.com/contribution <http://www.matronics.com/contribution>">http://www.matronics.com/c <http://www.matronics.com/c> >> >> =========== <http://www.matronics.com/Navigator?Kolb-List> =========== <http://forums.matronics.com/> =========== <http://www.matronics.com/contribution> =========== >> > ________________________________________________________________________________
Date: Mar 08, 2015
Jack ,I got it today no problem=C2- Chris =C2-Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly On Thursday, March 5, 2015 11:07 PM, Jack B. Hart wrote: Second try! I just finished getting my web page back up on the web.=C2- It can be fou nd at: http://www.jackbhart.com/firefly/firefly.html If you visit the site, I would appreciate it very much if you would report any errors or bfoken links that you find. I have been grounded for several years.=C2- Shortly I will be visiting th e FireFly and getting it ready to fly. Jack B. Hart FF004 Winchester, IN S - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Re: Dual throttle controls
Date: Mar 09, 2015
Hello Guideman, I have added a throttle linkage from the center console of my MkIII xtra to a left hand assembly. Both work together. I designed the linkage to run under the pilot seat and sent it off to KOLB AIRCRAFT to weld it up for me, they did a great job. I'd recommend you draw up what you want and send it to them. Hope that helps Frankd N1014S, MkIII Xtra. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439199#439199 ________________________________________________________________________________
Date: Mar 10, 2015
Subject: Headset Modification
I just posted a new video tip for adding cheap earbuds to your headset to cut down on the engine/prop noise. It's effective and economical. http://www.youtube.com/watch?v=ETiRiRqb5_I Enjoy Malcolm Morrison www.wienerdogaero.com ________________________________________________________________________________
Date: Mar 09, 2015
Subject: Re: Headset Modification
What a great idea. Kind of makes one wonder why they didn't think of it themselves. I bought the ear bud type of headset from Quality aloft or some such thing, and it works great. The only problem is that the noise still comes in through the head bones or what ever, and though you can hear whats being said and or music through the set, the noise is still there, and what you end up with is still a lot of ambient noise. The ear buds is just louder than the engine noise. I had been considering using either my regular headset or a set of ear muffs to help block some of the ambient noise. Thanks, Larry On Mon, Mar 9, 2015 at 7:51 PM, wrote: > I just posted a new video tip for adding cheap earbuds to your headset to > cut down on the engine/prop noise. It's effective and economical. > http://www.youtube.com/watch?v=ETiRiRqb5_I > > Enjoy > Malcolm Morrison > www.wienerdogaero.com > > * > > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Mar 09, 2015
I had thought of doing that but was trying to find a magnetic coupled earphone jack.... that way instead of pulling things out,, the magnet would release and it would come apart without breaking... and go back together quick and easy Boyd If someone knows where I can find such a devise let me know.. ________________________________________________________________________________
Date: Mar 10, 2015
Frankd wrote: > Hello Guideman, > > I have added a throttle linkage from the center console of my MkIII xtra to a left hand assembly. Both work together. > I designed the linkage to run under the pilot seat and sent it off to KOLB AIRCRAFT to weld it up for me, they did a great job. > I'd recommend you draw up what you want and send it to them. > > Hope that helps > Frankd > N1014S, MkIII Xtra. Could you post pictures of your throttle set-up Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439220#439220 ________________________________________________________________________________
Date: Mar 10, 2015
Frankd wrote: > Hello Guideman, > > I have added a throttle linkage from the center console of my MkIII xtra to a left hand assembly. Both work together. > I designed the linkage to run under the pilot seat and sent it off to KOLB AIRCRAFT to weld it up for me, they did a great job. > I'd recommend you draw up what you want and send it to them. > > Hope that helps > Frankd > N1014S, MkIII Xtra. Could you post pictures of your set-up Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439221#439221 ________________________________________________________________________________
Date: Mar 10, 2015
That does work really well, did that a few years ago with an old Comtronics headset and it did make a huge difference. You have 2 sound barriers instead of 1. Guess I got lucky, did it just like the guy in the video, it was very simple and easy to do. The Comtronics died of old age, am currently using a Gulf Coast Avionics noise canceling headset, and it is doing a good job - wonder what would happen if you attached the earbud speakers to the GCA headset speakers w/ their noise canceling function? Better? Worse? -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 "Living for your own pleasure is the least pleasurable thing a man can do. If his neighbors don't kill him in disgust he will die slowly of boredom and powerlessness." - Joy Davidman Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439226#439226 ________________________________________________________________________________
Date: Mar 10, 2015
[quote="byoungplumbing(at)gmail.c"]I had thought of doing that but was trying to find a magnetic coupled earphone jack.... that way instead of pulling things out,, the magnet would release and it would come apart without breaking... and go back together quick and easy Boyd If someone knows where I can find such a devise let me know.. > [b] You got me browsing for magnetic connectors and found a web page for people who go to cosplay events and make their own clothing with lights embedded (?!? whatever) - it uses magnets with wires attached to them for connectors. The author talks about embedding the magnets in acrylic. I am thinking it would be easier to just pot them in epoxy or silicone? Maybe right on the outside of the headset, and the wires from the earbuds potted so that the magnets on headset/wire would attract each other and keep the polarity? Scroll down the page about 2/3: http://www.fictionalclothing.com/blog/ -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 "Living for your own pleasure is the least pleasurable thing a man can do. If his neighbors don't kill him in disgust he will die slowly of boredom and powerlessness." - Joy Davidman Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439228#439228 ________________________________________________________________________________
Date: Mar 10, 2015
No pictures, removed it years ago, passengers kept trying to get their seat belts hung up over their throttle, so I removed the potential, but here's the basic principle: you use a pull/pull cable system. Advancing the pilot side throttle pulls the passenger side throttle lever open, while also pulling the carburetor cable slide up, and when you retard the throttle, it also pulls the passenger side throttle closed and lets the carburetor cable slide down. You do that by making the cable attach points and pivots 180 degrees out at the same pivot and attach lengths for the two different throttle levers. Crude drawing attached, the big loop is the cable inside the secured cable sheaths. You'll get the idea. You will need cable sheath attach points on your fuselage structure to anchor the cable sheaths into, and also cable adjusters in each half of the loop to get things adjusted. You will want the system to have no slop, yet not bind. It's not hard, but the devil is in the details of trying to get it to work smooth. I still had the old parts out in the hangar, it is not possible to assemble them to show the system, but here is some of the hardware I used. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 "Living for your own pleasure is the least pleasurable thing a man can do. If his neighbors don't kill him in disgust he will die slowly of boredom and powerlessness." - Joy Davidman
January 21, 2015 - March 10, 2015
Kolb-Archive.digest.vol-nj
