Kolb-Archive.digest.vol-nk
March 10, 2015 - April 28, 2015
      http://forums.matronics.com/viewtopic.php?p=439230#439230
      http://forums.matronics.com//files/img050_medium_168.jpg
      http://forums.matronics.com//files/p1040429_medium_413.jpg
      http://forums.matronics.com//files/p1040428_medium_669.jpg
Date: Mar 10, 2015
Subject: Re: Headset Modification
Larry, I fly an RV-4 using a QT Halo earplug style headset, and it is quite a bit quieter than the old Lightspeed 15's (active noise cancelling) I used to use. The Halo actually has the speaker elements mounted on the headband, with small tubing connecting to the ear plugs. I would have thought that the Clarity Aloft would be even quieter. Are you sure you had a good seal between the ear plugs and your ear canal? If they don't seal up completely just like regular noise blocking ear plugs, then they won't block external sound very well at all. I've flown with earplug style in-ear phones (Sony in-ear monitors designed for musicians) under Lightspeed active noise cancelling headsets, and it is a bit quieter with a noise cancelling headset on top, but at the expense of wearing the headset. One of the things I love about the Halo is that I don't have the weight/heat of the bulky headset on my head. I've never tried any type of in-ear active noise cancelling headset, but if you could rig one with a mic, that sounds like the ultimate solution for those of us who can tolerate 'earplugs' in our ear canals. For those who have never used any of this stuff: There's a huge difference between 'earbuds' like what came with your iphone and earplug style systems like the Halo and Clarity Aloft. Regular earbuds do not seal to the ear canal, so they don't really block much sound at all. All regular earbuds will get you is louder sound (and quicker hearing loss). Charlie On 3/9/2015 9:28 PM, Larry Cottrell wrote: > What a great idea. Kind of makes one wonder why they didn't think of > it themselves. I bought the ear bud type of headset from Quality aloft > or some such thing, and it works great. The only problem is that the > noise still comes in through the head bones or what ever, and though > you can hear whats being said and or music through the set, the noise > is still there, and what you end up with is still a lot of ambient > noise. The ear buds is just louder than the engine noise. I had been > considering using either my regular headset or a set of ear muffs to > help block some of the ambient noise. > > Thanks, > Larry > > On Mon, Mar 9, 2015 at 7:51 PM, > wrote: > > I just posted a new video tip for adding cheap earbuds to your > headset to cut down on the engine/prop noise. It's effective and > economical. > http://www.youtube.com/watch?v=ETiRiRqb5_I > > Enjoy > Malcolm Morrison > www.wienerdogaero.com <http://www.wienerdogaero.com> > ________________________________________________________________________________
Date: Mar 10, 2015
On Tue, Mar 10, 2015 at 1:34 PM, Charlie England wrote: > > > I fly an RV-4 using a QT Halo earplug style headset, and it is quite a bit > quieter than the old Lightspeed 15's (active noise cancelling) I used to > use. The Halo actually has the speaker elements mounted on the headband, > with small tubing connecting to the ear plugs. I would have thought that > the Clarity Aloft would be even quieter. Are you sure you had a good seal > between the ear plugs and your ear canal? > > ------------------------------------------------------------------------------------------------------------------------ > I just finished modifying my Sig S45 headset with a set of "ear buds". Using a "pencil solder gun" I had no problem at all with soldering the wires? to the speaker. Perhaps it was the type of flux core solder that I had. I also bought the QT Halo headset, and I liked it for the most part. I had no problem hearing the radio, in fact I had to turn it down quite a bit, and the best part is that I could listen to my music while flying. Not very satisfying with a normal headset. I however was not a fan of the mic. I put an Oregon Areo mic cover on it and it helped a lot, but the "boom for the mic was as limp as 30 day old celery. I finally taped it to some alum wire to give it a bit of a spine. Other wise I had to hold it in front of my mouth if I wanted to talk to some one. My cockpit is just a cover (factory wrap around) over the area that I sit. If I turned my head it would crack the squelch and I would get a shot of full motor noise. So it was necessary to turn up the squelch a lot to keep it from cracking. You asked about seal, and I did have a good seal, but you also pick up ambient noise through the bones that surround your ear as well. While I could hear great, I felt that the noise of that HKS was still too loud. I was considering using a set of ear muffs to help with the noise. To be clear- I never had any problem with hearing the radio or my music. My wife however often mentioned the motor noise was quite loud, and there was occasional static. ( I think that there are better mic's out there than the one that they use.) I have a base station here at the house so I can talk with the wife to get her input on clarity on her end of the conversation. I decided to try adding the ear buds to my Sig S45's. I have found them to be the best option for me even over ANR headsets. ( The ANR is set for GA and works best on the 2400 RPM's of those engines. Ours turning 6000 RPM, are out of the range that they generally work best at.) However wearing glasses I was not happy with the noise even with gel ear seals on the S 45's. I felt that I had to turn the sounds that I wanted to hear up to the point that my old experienced ears would be still getting damaging noise levels. I could not hear my music very well and if I played it as loud as I needed to hear it at all in the plane, it would cause me to wince at that level out of the plane. After completing the modification I rolled the plane out for some touch and go's. I plugged the ear buds in, covered my ears with the headset, and found that I had to turn the volume down on both the headset and the music radio for the first time. The noise level was substantially reduced from both the Halo set and the S45 before modification, with the ear buds. Upon landing my wife also confirmed that on her end the transmissions were a lot clearer, louder and without static. I will be using my Halo set as a backup. There was that much improvement. Thanks Malcom. Larry > >> > * > > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Headset Modification
Date: Mar 10, 2015
Larry C: Sounds great. Got to get me some "cheap" ear buds and go to work. I have several DC and Sigtronic headsets to play with. My hearing has gotten so bad and the noise level is so great in the MKIII it takes the fun out of flying. Biggest complaint I have trying to knock out 8 hour flight days. Noise is extremely fatiguing. BTW: No cockpit noise comparison between a Kolb and an RV4. Kolb is much, much louder and of a much higher frequency, engine and prop. Pushers are normally much louder inside as well as outside the cockpit. Irritates me how quiet my friends RANS S7 is with the same engine and prop I am flying. ;-) john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Tuesday, March 10, 2015 4:14 PM Subject: Re: Kolb-List: Headset Modification On Tue, Mar 10, 2015 at 1:34 PM, Charlie England wrote: I fly an RV-4 using a QT Halo earplug style headset, and it is quite a bit quieter than the old Lightspeed 15's (active noise cancelling) I used to use. The Halo actually has the speaker elements mounted on the headband, with small tubing connecting to the ear plugs. I would have thought that the Clarity Aloft would be even quieter. Are you sure you had a good seal between the ear plugs and your ear canal? ------------------------------------------------------------------------- ----------------------------------------------- I just finished modifying my Sig S45 headset with a set of "ear buds". Using a "pencil solder gun" I had no problem at all with soldering the wires? to the speaker. Perhaps it was the type of flux core solder that I had. I also bought the QT Halo headset, and I liked it for the most part. I had no problem hearing the radio, in fact I had to turn it down quite a bit, and the best part is that I could listen to my music while flying. Not very satisfying with a normal headset. I however was not a fan of the mic. I put an Oregon Areo mic cover on it and it helped a lot, but the "boom for the mic was as limp as 30 day old celery. I finally taped it to some alum wire to give it a bit of a spine. Other wise I had to hold it in front of my mouth if I wanted to talk to some one. My cockpit is just a cover (factory wrap around) over the area that I sit. If I turned my head it would crack the squelch and I would get a shot of full motor noise. So it was necessary to turn up the squelch a lot to keep it from cracking. You asked about seal, and I did have a good seal, but you also pick up ambient noise through the bones that surround your ear as well. While I could hear great, I felt that the noise of that HKS was still too loud. I was considering using a set of ear muffs to help with the noise. To be clear- I never had any problem with hearing the radio or my music. My wife however often mentioned the motor noise was quite loud, and there was occasional static. ( I think that there are better mic's out there than the one that they use.) I have a base station here at the house so I can talk with the wife to get her input on clarity on her end of the conversation. I decided to try adding the ear buds to my Sig S45's. I have found them to be the best option for me even over ANR headsets. ( The ANR is set for GA and works best on the 2400 RPM's of those engines. Ours turning 6000 RPM, are out of the range that they generally work best at.) However wearing glasses I was not happy with the noise even with gel ear seals on the S 45's. I felt that I had to turn the sounds that I wanted to hear up to the point that my old experienced ears would be still getting damaging noise levels. I could not hear my music very well and if I played it as loud as I needed to hear it at all in the plane, it would cause me to wince at that level out of the plane. After completing the modification I rolled the plane out for some touch and go's. I plugged the ear buds in, covered my ears with the headset, and found that I had to turn the volume down on both the headset and the music radio for the first time. The noise level was substantially reduced from both the Halo set and the S45 before modification, with the ear buds. Upon landing my wife also confirmed that on her end the transmissions were a lot clearer, louder and without static. I will be using my Halo set as a backup. There was that much improvement. Thanks Malcom. Larry get="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Mar 10, 2015
Larry, Might be worth a call to QT. He's 'local' for me, and I bought mine by walking into his office. Nice guy & would probably work with you on the issues. I haven't used mine in an open cockpit, so don't know about whether wind would affect boom position (but suspect that it should remove it from your head before it actually bends the boom, assuming that it isn't defective). No experience with open cockpit wind noise on the mic either (except getting it in the flow of the cockpit vent, which triggers *any* mic), but I have heard of some people getting the boom on backward & talking into the noise cancelling port instead of the front of the mic. Might be worth a check. Also, if the port gets clogged with debris it will kill the noise cancelling function of the mic. Agree that active noise cancelling doesn't do that much in open cockpit; most of the problem is wind noise, which is *much* higher frequency than even a 2 stroke. That's where good physical seal and a bit of mass really help. John, Are you talking about iphone/mp3 player type buds that basically hang in your ear? If so, be aware that using those inside a set of regular headphones will not reduce noise much if any over the headphones alone. Yes, you will likely be able to hear better than with headphones alone (for a short time), but all you're doing is making the volume of the radio reception louder, which is *adding* to the ear's total noise exposure. Any of us who have flown for a number of years, and/or abused our ears in other ways (I did concert sound work in one of my previous lives) need to not just hear today's radio comm, but keep whatever hearing we have left. :-) There are in-ear models that actually 'plug' your ear just like industrial earplugs (not as cheap), or you can have custom molded inserts made, (not cheap at all). What's your remaining hearing worth? As to noise levels in RVs vs Kolbs, I can't compare. But I have flown in the back seat of an Aircam with two 912s. Didn't seem that bad at the time, but maybe the 912s were cancelling each other. Or I was having too much fun to notice the noise... Charlie On 3/10/2015 5:11 PM, John Hauck wrote: > > Larry C: > > Sounds great.Got to get me some "cheap" ear buds and go to work.I have > several DC and Sigtronic headsets to play with. > > My hearing has gotten so bad and the noise level is so great in the > MKIII it takes the fun out of flying.Biggest complaint I have trying > to knock out 8 hour flight days.Noise is extremely fatiguing. > > BTW:No cockpit noise comparison between a Kolb and an RV4.Kolb is > much, much louder and of a much higher frequency, engine and > prop.Pushers are normally much louder inside as well as outside the > cockpit.Irritates me how quiet my friends RANS S7 is with the same > engine and prop I am flying.;-) > > john h > > mkIII > > Titus, Alabama > > *From:*owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] *On Behalf Of *Larry > Cottrell > *Sent:* Tuesday, March 10, 2015 4:14 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: Headset Modification > > On Tue, Mar 10, 2015 at 1:34 PM, Charlie England > wrote: > > > I fly an RV-4 using a QT Halo earplug style headset, and it is quite a > bit quieter than the old Lightspeed 15's (active noise cancelling) I > used to use. The Halo actually has the speaker elements mounted on the > headband, with small tubing connecting to the ear plugs. I would have > thought that the Clarity Aloft would be even quieter. Are you sure you > had a good seal between the ear plugs and your ear canal? > ------------------------------------------------------------------------------------------------------------------------ > > I just finished modifying my Sig S45 headset with a set of "ear buds". > Using a "pencil solder gun" I had no problem at all with soldering the > wires? to the speaker. Perhaps it was the type of flux core solder > that I had. > > I also bought the QT Halo headset, and I liked it for the most part. I > had no problem hearing the radio, in fact I had to turn it down quite > a bit, and the best part is that I could listen to my music while > flying. Not very satisfying with a normal headset. I however was not a > fan of the mic. I put an Oregon Areo mic cover on it and it helped a > lot, but the "boom for the mic was as limp as 30 day old celery. I > finally taped it to some alum wire to give it a bit of a spine. Other > wise I had to hold it in front of my mouth if I wanted to talk to some > one. My cockpit is just a cover (factory wrap around) over the area > that I sit. If I turned my head it would crack the squelch and I would > get a shot of full motor noise. So it was necessary to turn up the > squelch a lot to keep it from cracking. > > You asked about seal, and I did have a good seal, but you also pick up > ambient noise through the bones that surround your ear as well. While > I could hear great, I felt that the noise of that HKS was still too > loud. I was considering using a set of ear muffs to help with the > noise. To be clear- I never had any problem with hearing the radio or > my music. My wife however often mentioned the motor noise was quite > loud, and there was occasional static. ( I think that there are better > mic's out there than the one that they use.) > > I have a base station here at the house so I can talk with the wife to > get her input on clarity on her end of the conversation. > > I decided to try adding the ear buds to my Sig S45's. I have found > them to be the best option for me even over ANR headsets. ( The ANR is > set for GA and works best on the 2400 RPM's of those engines. Ours > turning 6000 RPM, are out of the range that they generally work best at.) > > However wearing glasses I was not happy with the noise even with gel > ear seals on the S 45's. I felt that I had to turn the sounds that I > wanted to hear up to the point that my old experienced ears would be > still getting damaging noise levels. I could not hear my music very > well and if I played it as loud as I needed to hear it at all in the > plane, it would cause me to wince at that level out of the plane. > > After completing the modification I rolled the plane out for some > touch and go's. I plugged the ear buds in, covered my ears with the > headset, and found that I had to turn the volume down on both the > headset and the music radio for the first time. The noise level was > substantially reduced from both the Halo set and the S45 before > modification, with the ear buds. Upon landing my wife also confirmed > that on her end the transmissions were a lot clearer, louder and > without static. > > I will be using my Halo set as a backup. There was that much improvement. > > Thanks Malcom. > > Larry > > ________________________________________________________________________________
Date: Mar 11, 2015
To make ear buds more like Clarity Aloft ear pieces I found a set of ear bu ds that=C2-had the=C2-rubber ear pieces that slipped over a small knob. =C2- Removed the rubber and found a small straw that would fit snugly ove r the knob.=C2- Purchased some of the hearing protectors that=C2-mash d own and using a small heated drill bit burnt a small hole through the lengt h of them.=C2- Cut the straw about 1/4 to 3/8" long and slide the base of the protector over it and the whole thing over the knob.=C2- The straw k eeps the hole open and will still allow the ear piece to be mashed enough t o fit into the ear cavity. ----- Original Message ----- From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Tuesday, March 10, 2015 6:11:23 PM Subject: RE: Kolb-List: Headset Modification Larry C: =C2- Sounds great. =C2- Got to get me some "cheap" ear buds and go to work. =C2- I have several DC and Sigtronic headsets to play with. =C2- My hearing has gotten so bad and the noise level is so great in the MKIII i t takes the fun out of flying. =C2- Biggest complaint I have trying to kn ock out 8 hour flight days. =C2- Noise is extremely fatiguing. =C2- BTW: =C2- No cockpit noise comparison between a Kolb and an RV4. =C2- K olb is much, much louder and of a much higher frequency, engine and prop. =C2- Pushers are normally much louder inside as well as outside the cockp it. =C2- Irritates me how quiet my friends RANS S7 is with the same engin e and prop I am flying. =C2- ;-) =C2- john h mkIII Titus, Alabama =C2- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@m atronics.com] On Behalf Of Larry Cottrell Sent: Tuesday, March 10, 2015 4:14 PM Subject: Re: Kolb-List: Headset Modification =C2- =C2- =C2- On Tue, Mar 10, 2015 at 1:34 PM, Charlie England < ceengland7(at)gmail.com > w rote: I fly an RV-4 using a QT Halo earplug style headset, and it is quite a bit quieter than the old Lightspeed 15's (active noise cancelling) I used to us e. The Halo actually has the speaker elements mounted on the headband, with small tubing connecting to the ear plugs. I would have thought that the Cl arity Aloft would be even quieter. Are you sure you had a good seal between the ear plugs and your ear canal?=C2- --------------------------------------------------------------------------- --------------------------------------------- I just finished modifying my Sig S45 headset with a set of "ear buds". Usin g a "pencil solder gun" I had no problem at all with soldering the wires? t o the speaker. Perhaps it was the type of flux core solder that I had. =C2- I also bought the QT Halo headset, and I liked it for the most part. I had no problem hearing the radio, in fact I had to turn it down quite a bit, an d the best part is that I could listen to my music while flying. Not very s atisfying with a normal headset. I however was not a fan of the mic. I put an Oregon Areo mic cover on it and it helped a lot, but the "boom for the m ic was as limp as 30 day old celery. I finally taped it to some alum wire t o give it a bit of a spine. Other wise I had to hold it in front of my mout h if I wanted to talk to some one. My cockpit is just a cover (factory wrap around) over the area that I sit. If I turned my head it would crack the s quelch and I would get a shot of full motor noise. So it was necessary to t urn up the squelch a lot to keep it from cracking. =C2- You asked about seal, and I did have a good seal, but you also pick up ambi ent noise through the bones that surround your ear as well. While I could h ear great, I felt that the noise of that HKS was still too loud. I was cons idering =C2-using a set of ear muffs to help with the noise. To be clear- I never had any problem with hearing the radio or my music. My wife howeve r often mentioned the motor noise was quite loud, and there was occasional static. ( I think that there are better mic's out there than the one that t hey use.) =C2- I have a base station here at the house so I can talk with the wife to get her input on clarity on her end of the conversation. =C2- =C2- I decided to try adding the ear buds to my Sig S45's. I have found them to be the best option for me even over ANR headsets. ( The ANR is set for GA a nd works best on the 2400 RPM's of those engines. Ours turning 6000 RPM, ar e out of the range that they generally work best at.) =C2- However wearing glasses I was not happy with the noise even with gel ear se als on the S 45's. I felt that I had to turn the sounds that I wanted to he ar up to the point that my old experienced ears would be still getting dama ging noise levels. I could not hear my music very well and if I played it a s loud as I needed to hear it at all in the plane, it would cause me to win ce at that level out of the plane.=C2- =C2- After completing the modification I rolled the plane out for some touch and go's. I plugged the ear buds in, covered my ears with the headset, and fou nd that I had to turn the volume down on both the headset and the music rad io for the first time. The noise level was substantially reduced from both the Halo set and the S45 before modification, with the ear buds. Upon landi ng my wife also confirmed that on her end the transmissions were a lot clea rer, louder and without static.=C2- =C2- I will be using my Halo set as a backup. There was that much improvement. =C2- Thanks Malcom. =C2- Larry
=C2-
=C2- =C2- =C2- get="_blank"> http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com _blank"> http://www.matronics.com/contribution =C2-
=C2- -- If you forward this email, or any part of it, please remove my email addres s before sending. =C2- =C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- - The Kolb-List Emai l Forum - =C2-=C2- --> http://www.matronics.com/Navigator?Kolb-List =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2- - MATRONICS WEB FORUMS - =C2-=C2- --> http://forums.matronics.com =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- - List Contribution Web Site - =C2- Thank you for your generous support! =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2- =C2- -Matt Dralle, List Admin. =C2-=C2- --> http://www.matronics.com/contribution =C2- = ________________________________________________________________________________
Date: Mar 10, 2015
The MKIII suffers from the drum effect. Prop and engine noise is magnified and confined to the enclosed cockpit. Open cockpit is not as loud. Wouldn't do me much good to hand an ear bud on my ear. I've been wearing hearing aids since 1978, while still on active duty and drawing flight pay. Larry shot me a bc to get good ear buds that actually seal the ear canal. The DC H-13.4 do about as good a job as any passively. The additional passive noise reduction of the ear buds should allow for me to hear with lower radio/intercom volume. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Tuesday, March 10, 2015 7:36 PM Subject: Re: Kolb-List: Headset Modification Larry, Might be worth a call to QT. He's 'local' for me, and I bought mine by walking into his office. Nice guy & would probably work with you on the issues. I haven't used mine in an open cockpit, so don't know about whether wind would affect boom position (but suspect that it should remove it from your head before it actually bends the boom, assuming that it isn't defective). No experience with open cockpit wind noise on the mic either (except getting it in the flow of the cockpit vent, which triggers *any* mic), but I have heard of some people getting the boom on backward & talking into the noise cancelling port instead of the front of the mic. Might be worth a check. Also, if the port gets clogged with debris it will kill the noise cancelling function of the mic. Agree that active noise cancelling doesn't do that much in open cockpit; most of the problem is wind noise, which is *much* higher frequency than even a 2 stroke. That's where good physical seal and a bit of mass really help. John, Are you talking about iphone/mp3 player type buds that basically hang in your ear? If so, be aware that using those inside a set of regular headphones will not reduce noise much if any over the headphones alone. Yes, you will likely be able to hear better than with headphones alone (for a short time), but all you're doing is making the volume of the radio reception louder, which is *adding* to the ear's total noise exposure. Any of us who have flown for a number of years, and/or abused our ears in other ways (I did concert sound work in one of my previous lives) need to not just hear today's radio comm, but keep whatever hearing we have left. :-) There are in-ear models that actually 'plug' your ear just like industrial earplugs (not as cheap), or you can have custom molded inserts made, (not cheap at all). What's your remaining hearing worth? As to noise levels in RVs vs Kolbs, I can't compare. But I have flown in the back seat of an Aircam with two 912s. Didn't seem that bad at the time, but maybe the 912s were cancelling each other. Or I was having too much fun to notice the noise... Charlie On 3/10/2015 5:11 PM, John Hauck wrote: Larry C: Sounds great. Got to get me some "cheap" ear buds and go to work. I have several DC and Sigtronic headsets to play with. My hearing has gotten so bad and the noise level is so great in the MKIII it takes the fun out of flying. Biggest complaint I have trying to knock out 8 hour flight days. Noise is extremely fatiguing. BTW: No cockpit noise comparison between a Kolb and an RV4. Kolb is much, much louder and of a much higher frequency, engine and prop. Pushers are normally much louder inside as well as outside the cockpit. Irritates me how quiet my friends RANS S7 is with the same engine and prop I am flying. ;-) john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Tuesday, March 10, 2015 4:14 PM Subject: Re: Kolb-List: Headset Modification On Tue, Mar 10, 2015 at 1:34 PM, Charlie England wrote: I fly an RV-4 using a QT Halo earplug style headset, and it is quite a bit quieter than the old Lightspeed 15's (active noise cancelling) I used to use. The Halo actually has the speaker elements mounted on the headband, with small tubing connecting to the ear plugs. I would have thought that the Clarity Aloft would be even quieter. Are you sure you had a good seal between the ear plugs and your ear canal? ---------------------------------------------------------------------------- -------------------------------------------- I just finished modifying my Sig S45 headset with a set of "ear buds". Using a "pencil solder gun" I had no problem at all with soldering the wires? to the speaker. Perhaps it was the type of flux core solder that I had. I also bought the QT Halo headset, and I liked it for the most part. I had no problem hearing the radio, in fact I had to turn it down quite a bit, and the best part is that I could listen to my music while flying. Not very satisfying with a normal headset. I however was not a fan of the mic. I put an Oregon Areo mic cover on it and it helped a lot, but the "boom for the mic was as limp as 30 day old celery. I finally taped it to some alum wire to give it a bit of a spine. Other wise I had to hold it in front of my mouth if I wanted to talk to some one. My cockpit is just a cover (factory wrap around) over the area that I sit. If I turned my head it would crack the squelch and I would get a shot of full motor noise. So it was necessary to turn up the squelch a lot to keep it from cracking. You asked about seal, and I did have a good seal, but you also pick up ambient noise through the bones that surround your ear as well. While I could hear great, I felt that the noise of that HKS was still too loud. I was considering using a set of ear muffs to help with the noise. To be clear- I never had any problem with hearing the radio or my music. My wife however often mentioned the motor noise was quite loud, and there was occasional static. ( I think that there are better mic's out there than the one that they use.) I have a base station here at the house so I can talk with the wife to get her input on clarity on her end of the conversation. I decided to try adding the ear buds to my Sig S45's. I have found them to be the best option for me even over ANR headsets. ( The ANR is set for GA and works best on the 2400 RPM's of those engines. Ours turning 6000 RPM, are out of the range that they generally work best at.) However wearing glasses I was not happy with the noise even with gel ear seals on the S 45's. I felt that I had to turn the sounds that I wanted to hear up to the point that my old experienced ears would be still getting damaging noise levels. I could not hear my music very well and if I played it as loud as I needed to hear it at all in the plane, it would cause me to wince at that level out of the plane. After completing the modification I rolled the plane out for some touch and go's. I plugged the ear buds in, covered my ears with the headset, and found that I had to turn the volume down on both the headset and the music radio for the first time. The noise level was substantially reduced from both the Halo set and the S45 before modification, with the ear buds. Upon landing my wife also confirmed that on her end the transmissions were a lot clearer, louder and without static. I will be using my Halo set as a backup. There was that much improvement. Thanks Malcom. Larry ________________________________________________________________________________
Date: Mar 10, 2015
From: "brubakermal(at)yahoo.com" <brubakermal(at)yahoo.com>
Subject: Re:firefly parts for sale
I have a wind screen- axil- fittings- and folding wing brace for sale i can send pics off list .make a offer =0A=0ASent from Yahoo Mail on Andro id=0A=0A ________________________________________________________________________________
Date: Mar 10, 2015
"Charlie wrote" Might be worth a call to QT. He's 'local' for me, and I bought mine by walking into his office. Nice guy & would probably work with you on the issues. Charlie, I really do not have any substantial complaint about the Halo headset. Yeah the wimpy mike boom is a bother, but not a real complaint. I feel that in the normal course of things it is something that the manufacturer would clean up in due time, but not enough of a problem to be a deal breaker. The reason that I am using the S45 with ear buds is just that it is better, and quieter. If I was flying a C150, I would use the Halo. In my operation however, it just isn't the best one. Larry On Tue, Mar 10, 2015 at 6:35 PM, Charlie England wrote: > Larry, > > Might be worth a call to QT. He's 'local' for me, and I bought mine by > walking into his office. Nice guy & would probably work with you on the > issues. I haven't used mine in an open cockpit, so don't know about whether > wind would affect boom position (but suspect that it should remove it from > your head before it actually bends the boom, assuming that it isn't > defective). No experience with open cockpit wind noise on the mic either > (except getting it in the flow of the cockpit vent, which triggers *any* > mic), but I have heard of some people getting the boom on backward & > talking into the noise cancelling port instead of the front of the mic. > Might be worth a check. Also, if the port gets clogged with debris it will > kill the noise cancelling function of the mic. > > Agree that active noise cancelling doesn't do that much in open cockpit; > most of the problem is wind noise, which is *much* higher frequency than > even a 2 stroke. That's where good physical seal and a bit of mass really > help. > > John, > > Are you talking about iphone/mp3 player type buds that basically hang in > your ear? If so, be aware that using those inside a set of regular > headphones will not reduce noise much if any over the headphones alone. > Yes, you will likely be able to hear better than with headphones alone (for > a short time), but all you're doing is making the volume of the radio > reception louder, which is *adding* to the ear's total noise exposure. Any > of us who have flown for a number of years, and/or abused our ears in other > ways (I did concert sound work in one of my previous lives) need to not > just hear today's radio comm, but keep whatever hearing we have left. :-) > There are in-ear models that actually 'plug' your ear just like industrial > earplugs (not as cheap), or you can have custom molded inserts made, (not > cheap at all). What's your remaining hearing worth? > > As to noise levels in RVs vs Kolbs, I can't compare. But I have flown in > the back seat of an Aircam with two 912s. Didn't seem that bad at the time, > but maybe the 912s were cancelling each other. Or I was having too much fun > to notice the noise... > > Charlie > > On 3/10/2015 5:11 PM, John Hauck wrote: > > Larry C: > > > Sounds great. Got to get me some "cheap" ear buds and go to work. I > have several DC and Sigtronic headsets to play with. > > > My hearing has gotten so bad and the noise level is so great in the MKIII > it takes the fun out of flying. Biggest complaint I have trying to knock > out 8 hour flight days. Noise is extremely fatiguing. > > > BTW: No cockpit noise comparison between a Kolb and an RV4. Kolb is > much, much louder and of a much higher frequency, engine and prop. Pushers > are normally much louder inside as well as outside the cockpit. Irritates > me how quiet my friends RANS S7 is with the same engine and prop I am > flying. ;-) > > > john h > > mkIII > > Titus, Alabama > > > *From:* owner-kolb-list-server(at)matronics.com [ > mailto:owner-kolb-list-server(at)matronics.com > ] *On Behalf Of *Larry Cottrell > *Sent:* Tuesday, March 10, 2015 4:14 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: Headset Modification > > > On Tue, Mar 10, 2015 at 1:34 PM, Charlie England > wrote: > > > I fly an RV-4 using a QT Halo earplug style headset, and it is quite a bit > quieter than the old Lightspeed 15's (active noise cancelling) I used to > use. The Halo actually has the speaker elements mounted on the headband, > with small tubing connecting to the ear plugs. I would have thought that > the Clarity Aloft would be even quieter. Are you sure you had a good seal > between the ear plugs and your ear canal? > > ------------------------------------------------------------------------------------------------------------------------ > > I just finished modifying my Sig S45 headset with a set of "ear buds". > Using a "pencil solder gun" I had no problem at all with soldering the > wires? to the speaker. Perhaps it was the type of flux core solder that I > had. > > > I also bought the QT Halo headset, and I liked it for the most part. I had > no problem hearing the radio, in fact I had to turn it down quite a bit, > and the best part is that I could listen to my music while flying. Not very > satisfying with a normal headset. I however was not a fan of the mic. I put > an Oregon Areo mic cover on it and it helped a lot, but the "boom for the > mic was as limp as 30 day old celery. I finally taped it to some alum wire > to give it a bit of a spine. Other wise I had to hold it in front of my > mouth if I wanted to talk to some one. My cockpit is just a cover (factory > wrap around) over the area that I sit. If I turned my head it would crack > the squelch and I would get a shot of full motor noise. So it was necessary > to turn up the squelch a lot to keep it from cracking. > > > You asked about seal, and I did have a good seal, but you also pick up > ambient noise through the bones that surround your ear as well. While I > could hear great, I felt that the noise of that HKS was still too loud. I > was considering using a set of ear muffs to help with the noise. To be > clear- I never had any problem with hearing the radio or my music. My wife > however often mentioned the motor noise was quite loud, and there was > occasional static. ( I think that there are better mic's out there than the > one that they use.) > > > I have a base station here at the house so I can talk with the wife to get > her input on clarity on her end of the conversation. > > > I decided to try adding the ear buds to my Sig S45's. I have found them to > be the best option for me even over ANR headsets. ( The ANR is set for GA > and works best on the 2400 RPM's of those engines. Ours turning 6000 RPM, > are out of the range that they generally work best at.) > > > However wearing glasses I was not happy with the noise even with gel ear > seals on the S 45's. I felt that I had to turn the sounds that I wanted to > hear up to the point that my old experienced ears would be still getting > damaging noise levels. I could not hear my music very well and if I played > it as loud as I needed to hear it at all in the plane, it would cause me to > wince at that level out of the plane. > > > After completing the modification I rolled the plane out for some touch > and go's. I plugged the ear buds in, covered my ears with the headset, and > found that I had to turn the volume down on both the headset and the music > radio for the first time. The noise level was substantially reduced from > both the Halo set and the S45 before modification, with the ear buds. Upon > landing my wife also confirmed that on her end the transmissions were a lot > clearer, louder and without static. > > > I will be using my Halo set as a backup. There was that much improvement. > > > Thanks Malcom. > > > Larry > > > * > > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Mar 11, 2015
Charlie =C2- The earbuds that I reference in the video are the in ear canal, rubber type that cost $10 at Walmart. Perhaps I used the wrong term but I assumed that all the "thingys" that you put in your ear were called earbuds. Sorry for the confusion. Whatever they are called, they work better for me than expen sive headsets. =C2- Malcolm ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Tuesday, March 10, 2015 8:35:52 PM Subject: Re: Kolb-List: Headset Modification Larry, Might be worth a call to QT. He's 'local' for me, and I bought mine by walk ing into his office. Nice guy & would probably work with you on the issues. I haven't used mine in an open cockpit, so don't know about whether wind w ould affect boom position (but suspect that it should remove it from your h ead before it actually bends the boom, assuming that it isn't defective). N o experience with open cockpit wind noise on the mic either (except getting it in the flow of the cockpit vent, which triggers *any* mic), but I have heard of some people getting the boom on backward & talking into the noise cancelling port instead of the front of the mic. Might be worth a check. Al so, if the port gets clogged with debris it will kill the noise cancelling function of the mic. Agree that active noise cancelling doesn't do that much in open cockpit; mo st of the problem is wind noise, which is *much* higher frequency than even a 2 stroke. That's where good physical seal and a bit of mass really help. John, Are you talking about iphone/mp3 player type buds that basically hang in yo ur ear? If so, be aware that using those inside a set of regular headphones will not reduce noise much if any over the headphones alone. Yes, you will likely be able to hear better than with headphones alone (for a short time ), but all you're doing is making the volume of the radio reception louder, which is *adding* to the ear's total noise exposure. Any of us who have fl own for a number of years, and/or abused our ears in other ways (I did conc ert sound work in one of my previous lives) need to not just hear today's r adio comm, but keep whatever hearing we have left. :-) There are in-ear mod els that actually 'plug' your ear just like industrial earplugs (not as che ap), or you can have custom molded inserts made, (not cheap at all). What's your remaining hearing worth? As to noise levels in RVs vs Kolbs, I can't compare. But I have flown in th e back seat of an Aircam with two 912s. Didn't seem that bad at the time, b ut maybe the 912s were cancelling each other. Or I was having too much fun to notice the noise... Charlie On 3/10/2015 5:11 PM, John Hauck wrote: Larry C: =C2- Sounds great. =C2- Got to get me some "cheap" ear buds and go to work. =C2- I have several DC and Sigtronic headsets to play with. =C2- My hearing has gotten so bad and the noise level is so great in the MKIII i t takes the fun out of flying. =C2- Biggest complaint I have trying to kn ock out 8 hour flight days. =C2- Noise is extremely fatiguing. =C2- BTW: =C2- No cockpit noise comparison between a Kolb and an RV4. =C2- K olb is much, much louder and of a much higher frequency, engine and prop. =C2- Pushers are normally much louder inside as well as outside the cockp it. =C2- Irritates me how quiet my friends RANS S7 is with the same engin e and prop I am flying. =C2- ;-) =C2- john h mkIII Titus, Alabama =C2- From: owner-kolb-list-server(at)matronics.com [ mailto:owner-kolb-list-server@ matronics.com ] On Behalf Of Larry Cottrell Sent: Tuesday, March 10, 2015 4:14 PM Subject: Re: Kolb-List: Headset Modification =C2- =C2- =C2- On Tue, Mar 10, 2015 at 1:34 PM, Charlie England < ceengland7(at)gmail.com > w rote: I fly an RV-4 using a QT Halo earplug style headset, and it is quite a bit quieter than the old Lightspeed 15's (active noise cancelling) I used to us e. The Halo actually has the speaker elements mounted on the headband, with small tubing connecting to the ear plugs. I would have thought that the Cl arity Aloft would be even quieter. Are you sure you had a good seal between the ear plugs and your ear canal?=C2- --------------------------------------------------------------------------- --------------------------------------------- I just finished modifying my Sig S45 headset with a set of "ear buds". Usin g a "pencil solder gun" I had no problem at all with soldering the wires? t o the speaker. Perhaps it was the type of flux core solder that I had. =C2- I also bought the QT Halo headset, and I liked it for the most part. I had no problem hearing the radio, in fact I had to turn it down quite a bit, an d the best part is that I could listen to my music while flying. Not very s atisfying with a normal headset. I however was not a fan of the mic. I put an Oregon Areo mic cover on it and it helped a lot, but the "boom for the m ic was as limp as 30 day old celery. I finally taped it to some alum wire t o give it a bit of a spine. Other wise I had to hold it in front of my mout h if I wanted to talk to some one. My cockpit is just a cover (factory wrap around) over the area that I sit. If I turned my head it would crack the s quelch and I would get a shot of full motor noise. So it was necessary to t urn up the squelch a lot to keep it from cracking. =C2- You asked about seal, and I did have a good seal, but you also pick up ambi ent noise through the bones that surround your ear as well. While I could h ear great, I felt that the noise of that HKS was still too loud. I was cons idering =C2-using a set of ear muffs to help with the noise. To be clear- I never had any problem with hearing the radio or my music. My wife howeve r often mentioned the motor noise was quite loud, and there was occasional static. ( I think that there are better mic's out there than the one that t hey use.) =C2- I have a base station here at the house so I can talk with the wife to get her input on clarity on her end of the conversation. =C2- =C2- I decided to try adding the ear buds to my Sig S45's. I have found them to be the best option for me even over ANR headsets. ( The ANR is set for GA a nd works best on the 2400 RPM's of those engines. Ours turning 6000 RPM, ar e out of the range that they generally work best at.) =C2- However wearing glasses I was not happy with the noise even with gel ear se als on the S 45's. I felt that I had to turn the sounds that I wanted to he ar up to the point that my old experienced ears would be still getting dama ging noise levels. I could not hear my music very well and if I played it a s loud as I needed to hear it at all in the plane, it would cause me to win ce at that level out of the plane.=C2- =C2- After completing the modification I rolled the plane out for some touch and go's. I plugged the ear buds in, covered my ears with the headset, and fou nd that I had to turn the volume down on both the headset and the music rad io for the first time. The noise level was substantially reduced from both the Halo set and the S45 before modification, with the ear buds. Upon landi ng my wife also confirmed that on her end the transmissions were a lot clea rer, louder and without static.=C2- =C2- I will be using my Halo set as a backup. There was that much improvement. =C2- Thanks Malcom. =C2- Larry === ________________________________________________________________________________
Subject: magnetic connectors,,
Date: Mar 11, 2015
Richard that is what I spent time looking for a while back.... I think you could p ut one of these on the inside or out side of the headset, then would not h ave to worry about wire breakage. and it would not interfere with normal use of the headset. thanks boyd >You got me browsing for magnetic connectors and found a web page for peopl e who >go to cosplay events and make their own clothing with lights embedded --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com ________________________________________________________________________________
Subject: headsets
Date: Mar 11, 2015
a friend of mine has a halo style headset that is blue tooth capable, whi le he is in the air in his crop duster he can make and receive phone calls. he loves it. I was left with the impression it was in the 600 dollar ne ighborhood.... ouch... niche market boyd --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com ________________________________________________________________________________
Date: Mar 11, 2015
Hi Malcolm, I don't think you used the wrong term; it's just that there probably isn't a universally accepted convention of terms and I was trying to be sure that any late adopters understood the difference between typical hang-in-the-ear style buds that come with iphones, etc, and 'plug' style devices that actually seal into the ear canal. Charlie On 3/11/2015 9:34 AM, gliderx5(at)comcast.net wrote: > Charlie > The earbuds that I reference in the video are the in ear canal, rubber > type that cost $10 at Walmart. Perhaps I used the wrong term but I > assumed that all the "thingys" that you put in your ear were called > earbuds. Sorry for the confusion. Whatever they are called, they work > better for me than expensive headsets. > Malcolm > > ------------------------------------------------------------------------ > *From: *"Charlie England" <ceengland7(at)gmail.com> > *To: *"kolb-list" > *Sent: *Tuesday, March 10, 2015 8:35:52 PM > *Subject: *Re: Kolb-List: Headset Modification > > Larry, > > Might be worth a call to QT. He's 'local' for me, and I bought mine by > walking into his office. Nice guy & would probably work with you on > the issues. I haven't used mine in an open cockpit, so don't know > about whether wind would affect boom position (but suspect that it > should remove it from your head before it actually bends the boom, > assuming that it isn't defective). No experience with open cockpit > wind noise on the mic either (except getting it in the flow of the > cockpit vent, which triggers *any* mic), but I have heard of some > people getting the boom on backward & talking into the noise > cancelling port instead of the front of the mic. Might be worth a > check. Also, if the port gets clogged with debris it will kill the > noise cancelling function of the mic. > > Agree that active noise cancelling doesn't do that much in open > cockpit; most of the problem is wind noise, which is *much* higher > frequency than even a 2 stroke. That's where good physical seal and a > bit of mass really help. > > John, > > Are you talking about iphone/mp3 player type buds that basically hang > in your ear? If so, be aware that using those inside a set of regular > headphones will not reduce noise much if any over the headphones > alone. Yes, you will likely be able to hear better than with > headphones alone (for a short time), but all you're doing is making > the volume of the radio reception louder, which is *adding* to the > ear's total noise exposure. Any of us who have flown for a number of > years, and/or abused our ears in other ways (I did concert sound work > in one of my previous lives) need to not just hear today's radio comm, > but keep whatever hearing we have left. :-) There are in-ear models > that actually 'plug' your ear just like industrial earplugs (not as > cheap), or you can have custom molded inserts made, (not cheap at > all). What's your remaining hearing worth? > > As to noise levels in RVs vs Kolbs, I can't compare. But I have flown > in the back seat of an Aircam with two 912s. Didn't seem that bad at > the time, but maybe the 912s were cancelling each other. Or I was > having too much fun to notice the noise... > > Charlie > > On 3/10/2015 5:11 PM, John Hauck wrote: > > Larry C: > > Sounds great.Got to get me some "cheap" ear buds and go to work.I > have several DC and Sigtronic headsets to play with. > > My hearing has gotten so bad and the noise level is so great in > the MKIII it takes the fun out of flying.Biggest complaint I have > trying to knock out 8 hour flight days.Noise is extremely fatiguing. > > BTW:No cockpit noise comparison between a Kolb and an RV4.Kolb is > much, much louder and of a much higher frequency, engine and > prop.Pushers are normally much louder inside as well as outside > the cockpit.Irritates me how quiet my friends RANS S7 is with the > same engine and prop I am flying.;-) > > john h > > mkIII > > Titus, Alabama > > *From:*owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] *On Behalf Of *Larry > Cottrell > *Sent:* Tuesday, March 10, 2015 4:14 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: Headset Modification > > On Tue, Mar 10, 2015 at 1:34 PM, Charlie England > > wrote: > > > I fly an RV-4 using a QT Halo earplug style headset, and it is > quite a bit quieter than the old Lightspeed 15's (active noise > cancelling) I used to use. The Halo actually has the speaker > elements mounted on the headband, with small tubing connecting to > the ear plugs. I would have thought that the Clarity Aloft would > be even quieter. Are you sure you had a good seal between the ear > plugs and your ear canal? > ------------------------------------------------------------------------------------------------------------------------ > > I just finished modifying my Sig S45 headset with a set of "ear > buds". Using a "pencil solder gun" I had no problem at all with > soldering the wires? to the speaker. Perhaps it was the type of > flux core solder that I had. > > I also bought the QT Halo headset, and I liked it for the most > part. I had no problem hearing the radio, in fact I had to turn it > down quite a bit, and the best part is that I could listen to my > music while flying. Not very satisfying with a normal headset. I > however was not a fan of the mic. I put an Oregon Areo mic cover > on it and it helped a lot, but the "boom for the mic was as limp > as 30 day old celery. I finally taped it to some alum wire to give > it a bit of a spine. Other wise I had to hold it in front of my > mouth if I wanted to talk to some one. My cockpit is just a cover > (factory wrap around) over the area that I sit. If I turned my > head it would crack the squelch and I would get a shot of full > motor noise. So it was necessary to turn up the squelch a lot to > keep it from cracking. > > You asked about seal, and I did have a good seal, but you also > pick up ambient noise through the bones that surround your ear as > well. While I could hear great, I felt that the noise of that HKS > was still too loud. I was considering using a set of ear muffs to > help with the noise. To be clear- I never had any problem with > hearing the radio or my music. My wife however often mentioned the > motor noise was quite loud, and there was occasional static. ( I > think that there are better mic's out there than the one that they > use.) > > I have a base station here at the house so I can talk with the > wife to get her input on clarity on her end of the conversation. > > I decided to try adding the ear buds to my Sig S45's. I have found > them to be the best option for me even over ANR headsets. ( The > ANR is set for GA and works best on the 2400 RPM's of those > engines. Ours turning 6000 RPM, are out of the range that they > generally work best at.) > > However wearing glasses I was not happy with the noise even with > gel ear seals on the S 45's. I felt that I had to turn the sounds > that I wanted to hear up to the point that my old experienced ears > would be still getting damaging noise levels. I could not hear my > music very well and if I played it as loud as I needed to hear it > at all in the plane, it would cause me to wince at that level out > of the plane. > > After completing the modification I rolled the plane out for some > touch and go's. I plugged the ear buds in, covered my ears with > the headset, and found that I had to turn the volume down on both > the headset and the music radio for the first time. The noise > level was substantially reduced from both the Halo set and the S45 > before modification, with the ear buds. Upon landing my wife also > confirmed that on her end the transmissions were a lot clearer, > louder and without static. > > I will be using my Halo set as a backup. There was that much > improvement. > > Thanks Malcom. > > Larry > > ________________________________________________________________________________
Subject: Things are warming up in Minnesota
Date: Mar 11, 2015
After taking up space for a year or so I finally got to fly my Firefly today. A short trip around the block but was much fun for my first flight since purchasing it a year ago. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439270#439270 Attachments: http://forums.matronics.com//files/kolbkrnh_905.jpg ________________________________________________________________________________
Date: Mar 11, 2015
Proud of you. Looks cold up there. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of west1m Sent: Wednesday, March 11, 2015 10:52 PM Subject: Kolb-List: Things are warming up in Minnesota After taking up space for a year or so I finally got to fly my Firefly today. A short trip around the block but was much fun for my first flight since purchasing it a year ago. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439270#439270 Attachments: http://forums.matronics.com//files/kolbkrnh_905.jpg ________________________________________________________________________________
Subject: Re: Things are warming up in Minnesota
Date: Mar 12, 2015
Weedhoppers and weight shift Eipers don't carry temp gauges. When I got my Firefly running i added the EIS system. While on this little hop I couldn't help but notice the exhaust temps up into the 1200 range. (Rotax447) Unfortunately I did not scroll through the monitor to see both cylinders just the highest was showing. What is a normal looking cruise temp, say 5500-5800 RPM? -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439273#439273 ________________________________________________________________________________
Date: Mar 12, 2015
I've added the page from the 447 operating manual that contains the nominal operating temps for the 447. 1200 Deg EGT is max. I've set my Grand Rapids unit to reflect that as Red Line. I normally see EGT temps around 1120 and CHT around 350 during cruise depending on weather. The chart says normal EGT is 860 to 1000. I see the 1000 range during climb out and at wide open throttle but not during cruise. Nose down and unloading the prop causes the EGT temp to rise quickly. Don't be surprised if you see the EGT rise quickly in the 4000 RPM range. That is the leanest area of the mixture curve for the Carb. I try to stay out of that area as much as possible. If you experience high EGT all the time, then you may have to visit your prop pitch setting and dial in a little more pitch. I probably could dial in a tad more on mine but my Firefly is performing very well where it's at so I haven't messed with it. I live in Michigan and still have some snow. I hope to be flying by the beginning of April somewhere. Kudos on your Firefly. Nice Pic -------- Gregg Kaat 2011 Firefly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439281#439281 Attachments: http://forums.matronics.com//files/447_168.jpg ________________________________________________________________________________
Date: Mar 12, 2015
Envious...mine is in a trailer in a U store it lot in Conn....2000 mile round trip!! Hope to have it home by the end of the month... Herb On 03/11/2015 11:21 PM, John Hauck wrote: > > Proud of you. > > Looks cold up there. > > > john h > mkIII > Titus, Alabama > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of west1m > Sent: Wednesday, March 11, 2015 10:52 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Things are warming up in Minnesota > > > After taking up space for a year or so I finally got to fly my Firefly > today. > A short trip around the block but was much fun for my first flight since > purchasing it a year ago. > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439270#439270 > > > Attachments: > > http://forums.matronics.com//files/kolbkrnh_905.jpg > > ________________________________________________________________________________
Date: Mar 12, 2015
High egt temps could be either or a combination of prop pitch, or possibly running a bit lean. If it has sat for a year you may want to pull the jets and make sure they are clean. if they have a film on them that could restrict fuel and lean things some. Or maybe a larger jet. Good luck Boyd ________________________________________________________________________________
Date: Mar 12, 2015
Thanks everyone for the quick response. I will have look into this much closer after looking at the chart and the responses . I have a three blade Warp drive prop in the corner of the garage I may try out some day but until then I will check and clean the jets, maybe bump up a notch on the needle if I can or change the jet. I also need to check if both cylinders are the same, I worry about seal leaks on two strokes. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439295#439295 ________________________________________________________________________________
Date: Mar 12, 2015
Great looking Firefly. I know the drive you are looking forward to. I bought my Firefly and most of a Firestar from a guy in New York. (I am in Minnesota) It two trucks towing two trailers (one came with the Firefly) A small fortune in toll both fees and a hotel night or two. Not sure why I did it , but what the heck, Everyone loves a road trip. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439297#439297 ________________________________________________________________________________
Date: Mar 12, 2015
If I remember correctly the cold air throws off the EGT reading. So if it's 30degrees colder than 75F (egt manufacturer calibration temp) your gauge will show 30degrees higher. Also the cold air will cause you to run leaner. I raise my needle a notch in the winter and return it in the spring. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439299#439299 ________________________________________________________________________________
Date: Mar 12, 2015
Subject: firefly stuff for sale
=C2-we have a gas tank , folded wing boom tube =C2-Brace,=C2- wind sc reen and axil fittings =C2-for sale cheep=C2- call any time malMalcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.comLSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022=C2-=C2-=C2-=C2- From: B Young <byoungplumbing(at)gmail.com> To: kolb-list(at)matronics.com Sent: Thursday, March 12, 2015 10:58 AM Subject: Re: Kolb-List: Re: Things are warming up in Minnesota High egt temps could be either or a combination of prop pitch, or possibly running a bit lean.=C2- If it has sat for a year you may want to pull the jets and make sure they are clean.=C2-=C2- if they have a film on them that could restrict fuel and lean things some.=C2- Or maybe a larger jet .=C2-=C2- Good luck Boyd ________________________________________________________________________________
Date: Mar 16, 2015
Subject: Flight Simulator Aircraft Configuration For Kolb
Has anyone done or know of a aircraft configuration for a Kolb on Microsoft Flight Simulator. Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Date: Mar 16, 2015
Subject: There a nice Kolbra for sale on Ebay
Date: Mar 16, 2015
Subject: Kolbra for sale
Nice Kolbra for sale on E bay for the money i put in it some one will get a good deal ________________________________________________________________________________
Date: Mar 16, 2015
Subject: Re: Kolbra for sale
That is a pretty good deal. How much do you think you have in it? On Mar 16, 2015 5:06 PM, "Larry Gitt" wrote: > Nice Kolbra for sale on E bay for the money i put in it some one will get > a good deal > > * > > > * > > ________________________________________________________________________________
Date: Mar 16, 2015
My wife say's close to 30 and you don't argue with your wife, Now were divorce I think around 26. I just built a gyor from scratch end up with 11 in it. t On Mon, Mar 16, 2015 at 5:45 PM, Duane Ransdell wrote: > That is a pretty good deal. How much do you think you have in it? > On Mar 16, 2015 5:06 PM, "Larry Gitt" wrote: > >> Nice Kolbra for sale on E bay for the money i put in it some one will >> get a good deal >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?Kolb-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> * > > > * > > ________________________________________________________________________________
Subject: Firestar project for sale, $2000
Date: Mar 16, 2015
Looked at a wrecked Firestar today, it was built in 1987, 5 rib wing. 300 hours more or less, airframe and engine. Rotax 447, single ignition, wood prop in good condition. Hit hard on the nose and mains, sheared the rivits that hold the top of the gear ring to the main tube and the gear ring detached from the tube & folded back. The longeron tubes at the lift strut attachment point are all crumpled, the gear legs look able to be straightened, and the gear sleeve tubes do not appear to be bent. All it basically needs is a new cage to built. Called Travis, Kolb will make you one for $3500. If I didn't already have a Kolb, I would jump on this, and make a new cage myself, using the old one for a template & parts. It might be possible to use part of the present cage, specifically the top tube with the motor mounts and the rear verticals. In any event, I think there is enough of the present cage left to straighten out and use as a template to build a new one, assuming you are good with gas welding. Wings, boom tube and tail assy. appear to be undamaged. The lift strut tang under the left wing is bent, that is why the wings have anhedral. There are some wrinkles in the fabric on the underside of the left elevator, but they do not appear related to the crash. Has a BRS parachute, the aluminum case is squashed, but the chute appears undamaged. A good candidate to transfer into a soft bag for a hand toss chute, would count towards getting the weight into legal U/L range. It has brakes and some instruments, functionality unknown. Cosmetics of the paint on the wings, boom and tail is excellent. Aircraft is located 5 miles South of Abingdon, VA. If interested, email bpbuchanan(at)centurylink.net or call 276 -628 -3604 -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 "Living for your own pleasure is the least pleasurable thing a man can do. If his neighbors don't kill him in disgust he will die slowly of boredom and powerlessness." - Joy Davidman Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439458#439458 Attachments: http://forums.matronics.com//files/dsc02030_medium_159.jpg http://forums.matronics.com//files/dsc02029_medium_738.jpg http://forums.matronics.com//files/dsc02028_medium_112.jpg http://forums.matronics.com//files/dsc02027_medium_145.jpg http://forums.matronics.com//files/dsc02024_medium_968.jpg http://forums.matronics.com//files/dsc02023_medium_184.jpg http://forums.matronics.com//files/dsc02022_medium_167.jpg http://forums.matronics.com//files/dsc02020_medium_203.jpg http://forums.matronics.com//files/dsc02019_medium_175.jpg http://forums.matronics.com//files/dsc02018_medium_135.jpg http://forums.matronics.com//files/dsc02017_medium_914.jpg http://forums.matronics.com//files/dsc02016_medium_799.jpg http://forums.matronics.com//files/dsc02015_medium_528.jpg http://forums.matronics.com//files/dsc02014_medium_104.jpg http://forums.matronics.com//files/dsc02013_medium_556.jpg ________________________________________________________________________________
Subject: MK III - New Nose
Date: Mar 17, 2015
Damaged my nose cone and since a new one was not available I had to make one from scratch. Obviously changed the look a bit and I'm not sure if I'm happy with it yet or not. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439470#439470 Attachments: http://forums.matronics.com//files/newnose_900.jpg ________________________________________________________________________________
Date: Mar 17, 2015
Subject: Re: MK III - New Nose
Well it is a bit different, but that's not to say that one wouldn't get used to it. Perhaps you should rename the plane to "Woody" . It does have that penetrating look. You just need a Walter Lanz sound track to go with it when landing. :-) Larry On Tue, Mar 17, 2015 at 10:03 AM, Larlaeb wrote: > > Damaged my nose cone and since a new one was not available I had to make > one from scratch. Obviously changed the look a bit and I'm not sure if I'm > happy with it yet or not. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439470#439470 > > > Attachments: > > http://forums.matronics.com//files/newnose_900.jpg > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Mar 17, 2015
You think maybe some eyes and a more 'beak' like color scheme might help? :) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439477#439477 ________________________________________________________________________________
Subject: Re: MK III - New Nose - Nice Job
Date: Mar 17, 2015
What's wrong with it. It looks factory. You did a nice job. I wouldn't change a thing. ----- Original Message ----- From: "Larlaeb" <larlaeb(at)gmail.com> Sent: Tuesday, March 17, 2015 1:00 PM Subject: Kolb-List: Re: MK III - New Nose > > You think maybe some eyes and a more 'beak' like color scheme might help? > :) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439477#439477 > > > ________________________________________________________________________________
Date: Mar 17, 2015
Looks Great! any picts of the building process? -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439479#439479 ________________________________________________________________________________
Date: Mar 17, 2015
Did you keep the mold? You aren't the last person who will want a new nose. ----- Original Message ----- From: "west1m" <west1m(at)hotmail.com> Sent: Tuesday, March 17, 2015 1:19 PM Subject: Kolb-List: Re: MK III - New Nose - Nice Job > > Looks Great! any picts of the building process? > > -------- > West1m > Hastings, MN > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439479#439479 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 17, 2015
I guess it just depends on how brave you are. Apparently we are the only ones who watched cartoons as a kid. At least in that time frame. It does look good, just a bit perkier than the factory. Larry On Tue, Mar 17, 2015 at 11:00 AM, Larlaeb wrote: > > You think maybe some eyes and a more 'beak' like color scheme might help? > :) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439477#439477 > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Mar 17, 2015
Unfortunately most of my pictures of this process were lost when my phone was destroyed (another unrelated story). I didn't use a plug or a mold. Not to say it was the right way but this was done with three pieces of flat fiberglass sheet, a small piece of foam, two pieces of PVC (removed after use), some pop rivets (also removed), some fiberglass tape, resin, filler and paint. I do have a few pics that I will post when I can pull them together. Thanks, Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439483#439483 ________________________________________________________________________________
Subject: Re: FireFly Page Is Back UP
Date: Mar 17, 2015
Hello Jack Hart. Thank you for your FireFly page. I am the owner of FireFly 0058. It is without an engine right now as thieves took the Rotax 447 before I got it. I am now in process of getting a Hirth 2702 installed by Matt Dandridge at Rec Power. Your pages are just so interesting and filled with great ideas and skills well demonstrated. One day I would like to meet you. Tommy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439484#439484 ________________________________________________________________________________
Date: Mar 17, 2015
That sounds like a quick build. The story would be worth telling. ----- Original Message ----- From: "Larlaeb" <larlaeb(at)gmail.com> Sent: Tuesday, March 17, 2015 2:43 PM Subject: Kolb-List: Re: MK III - New Nose - Nice Job > > Unfortunately most of my pictures of this process were lost when my phone > was destroyed (another unrelated story). I didn't use a plug or a mold. > Not to say it was the right way but this was done with three pieces of > flat fiberglass sheet, a small piece of foam, two pieces of PVC (removed > after use), some pop rivets (also removed), some fiberglass tape, resin, > filler and paint. I do have a few pics that I will post when I can pull > them together. > > Thanks, > Allan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439483#439483 > > > ________________________________________________________________________________
Subject: Re: Flight Simulator Aircraft Configuration For Kolb
Date: Mar 17, 2015
I have one for a Firefly on Microsoft X. I don't remember where I got it but pretty sure it was a download from a search I did for Kolb on Google. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439487#439487 ________________________________________________________________________________
Subject: Re: New (free) Aviation App
Date: Mar 18, 2015
I still get a lot of questions on how to download the Airport Courtesy Cars app on an iPad. So here are some simple instructions on how to do so. The app is approaching 1400 car listings with over 6,400 pilots that have downloaded the app. Glenn Go to the app store on your iPad, Click the search box and search for Airport Courtesy Cars, The search will not show any results, however when the search is complete a bar of menus will appear along the top of the page, The very first one on the left says "Ipad only", Click it to show a drop down menu, Choose "iPhone only" and Airport Courtesy Cars" will be displayed, and you can download the app. -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App www.RVairspace.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439530#439530 ________________________________________________________________________________
Date: Mar 19, 2015
Here are a few pictures and a description of the process. 1. I drew a template of the existing instrument panel shape and transferred that to the fiberglass sheet and cut it out. I then attached some tabs for the top and sides to attach to. 2. I clamped the template to the appropriate place on the frame. 3. I fixed two pieces of PVC tubing about 1 inch in diameter along the bottom of the frame representing the bottom edges of where the nose needed to go. Make sure these are at the angle you want the bottom of your nose to be. 4. I bent a sheet of fiberglass over the panel template and riveted it to the pvc and the tabs on the panel. 5. I did not use a template for the front. Just made sure it was an even curve. The front will be open at this point. 6. I did the same thing to the bottom sheet. 7. I sanded the edges so they merged with the PVC pretty well. 8. Coated the PVC with mold release wax. The edges of the fiber glass sheet need to be left smooth so that a layer of fiberglass will stick but not stick too well. Don't fasten down the edges of this tape. I had no trouble with this but this outside layer will need to be peeled off. 9. Once you have shape you want, lay up one layer of fiber glass over the PVC lapping over the panels an inch or so. (This layer will be removed) 10. Once that setups up drill out the rivets and remove the pvc tubing. 11. Layup fiberglass inside the cone using the thin outside layer to give you a smooth radius. 12. Once that has setup, Peel off the outside layer. (You should be able to remove the cone from the frame at this point. 13. Fill and sand the joints smooth. 14. Take a small block of foam (you can build this up from a few thin pieces) and attach it to the open front. I carved the back of the block to fit the hole and left a gap in a few places to run strips of fiberglass from the inside of the nose to the outside of the foam plug. 15. Sand the foam to the shape you want and then glass the outside overlapping the pieces already there. Edges should done by creating a 'lip' along the bottom (see photo) that the top can make a good joint with. Then fill and round out with lightweight filler. 16. Fair it and paint it. 17. I removed the front nose attachment and used tabs welded to the front of the cage that attached to a Z shaped lip within the cone. Pretty easy to reach from inside and invisible from the exterior. This is not necessary however and you can use the old attach points. Hope that makes some sense and I'm remembering all the steps. It was actually easier than it sounds I think. Note that to use fiberglass on foam you will need to use epoxy as the polyester stuff will melt it. Thanks, Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439601#439601 Attachments: http://forums.matronics.com//files/nosecone_brace_104.jpg http://forums.matronics.com//files/img_0145_503.jpg http://forums.matronics.com//files/nose1_135.jpg ________________________________________________________________________________
Subject: Re: Pi Day Flight
Date: Mar 19, 2015
OOOPs, you took off 10 minutes late! -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439612#439612 ________________________________________________________________________________
Date: Mar 22, 2015
Subject: Riveting question?
list What is the(desired) length of the rivets that are used to fasten the drag strut gussett to the spar tube? There is the plate thickness, the spar tube thickness and the H section thickness to deal with... Obviously I can call my buds at Kolb tomorrow...but would like to order tonight...Lots of Stainless 1/8th rivets on ebay...and yes I know I can always use overly long ones... Herb ps rebuilding the Firestar wings that I got from Rev. Pike... ________________________________________________________________________________
Subject: Re: Riveting question?
Date: Mar 22, 2015
maybe this helps, I have a complete set of plans and the book for Firestar -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439749#439749 Attachments: http://forums.matronics.com//files/dragstrut_124.jpg ________________________________________________________________________________
Date: Mar 22, 2015
here is another pic -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439751#439751 Attachments: http://forums.matronics.com//files/dragstrut2_134.jpg ________________________________________________________________________________
Date: Mar 23, 2015
Thanks...but guess I did not make it clear...it is the drag strut fitting plates, which attach the strut to the Spar tube and into the H section..at the lift strut attach area... There are two gussets; the thick one on the bottom of the wing and the curved thin one on the side.. Herb On 03/22/2015 09:57 PM, west1m wrote: > > here is another pic > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439751#439751 > > > Attachments: > > http://forums.matronics.com//files/dragstrut2_134.jpg > > ________________________________________________________________________________
Date: Mar 23, 2015
hurb my plans call for 1/8 1/8 steel rivets on the side gusset and 1/8 1/4=C2- steel rivets on the bottom, these should be steel and not stainless mojavjoe=C2- ----- Original Message ----- From: "Herb" <Herbgh(at)nctc.com> Sent: Monday, March 23, 2015 8:03:56 AM Subject: Re: Kolb-List: Re: Riveting question? Thanks...but guess I did not make it clear...it is the drag strut fitting plates, which =C2-attach the strut =C2-to the Spar tube and int o the H section..at the lift strut attach area... There are two gussets; the thick one on the bottom of the wing and the curved thin one on the side.. Herb On 03/22/2015 09:57 PM, west1m wrote: > > here is another pic > > -------- > West1m > Hastings, MN > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439751#439751 > > > > > Attachments: > > http://forums.matronics.com//files/dragstrut2_134.jpg > > > > > > > =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Date: Mar 23, 2015
Thanks... Wondering if the steel rivets are stronger in shear? Herb On 03/23/2015 07:15 AM, mojavjoe(at)comcast.net wrote: > hurb > my plans call for 1/8 1/8 steel rivets on the side gusset and 1/8 > 1/4 steel rivets on the bottom, these should be steel and not stainless > mojavjoe > > ------------------------------------------------------------------------ > *From: *"Herb" <Herbgh(at)nctc.com> > *To: *"kolb-list" > *Sent: *Monday, March 23, 2015 8:03:56 AM > *Subject: *Re: Kolb-List: Re: Riveting question? > > > Thanks...but guess I did not make it clear...it is the drag strut > fitting plates, which attach the strut to the Spar tube and into the H > section..at the lift strut attach area... There are two gussets; the > thick one on the bottom of the wing and the curved thin one on the > side.. Herb > > On 03/22/2015 09:57 PM, west1m wrote: > > > > here is another pic > > > > -------- > > West1m > > Hastings, MN > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=439751#439751 > > > > > > > > > > Attachments: > > > > http://forums.matronics.com//files/dragstrut2_134.jpg > > > > > > > > > > > > > > > &nbs================ > > > * > > > * ________________________________________________________________________________
Date: Mar 23, 2015
My mk 3 plans show. 1/8 x1/4 rivets on 1/2 in spacing. Where drag strut gusset attaches to Wing spar into H section my H section is uninstall chrome Molly steel. If you have thick wall aluminium H section you will probably need longer. Boyd Young On Mar 23, 2015 6:19 AM, wrote: > hurb > my plans call for 1/8 1/8 steel rivets on the side gusset and 1/8 > 1/4 steel rivets on the bottom, these should be steel and not stainless > mojavjoe > > ------------------------------ > *From: *"Herb" <Herbgh(at)nctc.com> > *To: *"kolb-list" > *Sent: *Monday, March 23, 2015 8:03:56 AM > *Subject: *Re: Kolb-List: Re: Riveting question? > > > Thanks...but guess I did not make it clear...it is the drag strut > fitting plates, which attach the strut to the Spar tube and into the H > section..at the lift strut attach area... There are two gussets; the > thick one on the bottom of the wing and the curved thin one on the > side.. Herb > > On 03/22/2015 09:57 PM, west1m wrote: > > > > here is another pic > > > > -------- > > West1m > > Hastings, MN > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=439751#439751 > > > > > > > > > > Attachments: > > > > http://forums.matronics.com//files/dragstrut2_134.jpg > > > > > > > > > > > > > > > &nbs================ > > > * > > > * > > ________________________________________________________________________________
Date: Mar 23, 2015
Steel would be stronger than aluminum. But I don't know between steel and stainless steel. The stainless steel won't rust. All the pulled rivets in my kit were stainless Boyd On Mar 23, 2015 7:10 AM, "Herb" wrote: > Thanks... > > Wondering if the steel rivets are stronger in shear? Herb > > On 03/23/2015 07:15 AM, mojavjoe(at)comcast.net wrote: > > hurb > my plans call for 1/8 1/8 steel rivets on the side gusset and 1/8 > 1/4 steel rivets on the bottom, these should be steel and not stainless > mojavjoe > > ------------------------------ > *From: *"Herb" <Herbgh(at)nctc.com> <Herbgh(at)nctc.com> > *To: *"kolb-list" > *Sent: *Monday, March 23, 2015 8:03:56 AM > *Subject: *Re: Kolb-List: Re: Riveting question? > > > Thanks...but guess I did not make it clear...it is the drag strut > fitting plates, which attach the strut to the Spar tube and into the H > section..at the lift strut attach area... There are two gussets; the > thick one on the bottom of the wing and the curved thin one on the > side.. Herb > > On 03/22/2015 09:57 PM, west1m wrote: > > > > > here is another pic > > > > -------- > > West1m > > Hastings, MN > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=439751#439751 > > > > > > > > > > Attachments: > > > > http://forums.matronics.com//files/dragstrut2_134.jpg > > > > > > > > > > > > > > > &nbs================ > > > * > > > * > > ________________________________________________________________________________
Date: Mar 23, 2015
These H sections are cro molly... I am rebuilding a set of wings...In the case of one wing the drag strut gussets were torn out and the root rib sustained damage and I replaced most of the ribs..... just a matter of match hole drilling a new set of gussets...I have the match hole strap "tool"...and it should work well.. Should be ready to cover in a day or so.. 7 rib Firestar wings.. They will be covered and in silver , ready to paint,,and will probably be for sale at a later date......Lift struts included.. I may try them on my "new to me" Firefly first......when and if I make it to Conn. to retrieve it... Any ideas as to how these wings might work on the Fly? Herb (heading to Fastenal ) On 03/23/2015 08:54 AM, B Young wrote: > > My mk 3 plans show. 1/8 x1/4 rivets on 1/2 in spacing. Where drag > strut gusset attaches to Wing spar into H section my H section is > uninstall chrome Molly steel. If you have thick wall aluminium H > section you will probably need longer. > Boyd Young > > On Mar 23, 2015 6:19 AM, > wrote: > > hurb > my plans call for 1/8 1/8 steel rivets on the side gusset and 1/8 > 1/4 steel rivets on the bottom, these should be steel and not > stainless > mojavjoe > > ------------------------------------------------------------------------ > *From: *"Herb" <Herbgh(at)nctc.com <mailto:Herbgh(at)nctc.com>> > *To: *"kolb-list" > > *Sent: *Monday, March 23, 2015 8:03:56 AM > *Subject: *Re: Kolb-List: Re: Riveting question? > > > > > Thanks...but guess I did not make it clear...it is the drag strut > fitting plates, which attach the strut to the Spar tube and into > the H > section..at the lift strut attach area... There are two gussets; the > thick one on the bottom of the wing and the curved thin one on the > side.. Herb > > On 03/22/2015 09:57 PM, west1m wrote: > > > > > > here is another pic > > > > -------- > > West1m > > Hastings, MN > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=439751#439751 > > > > > > > > > > Attachments: > > > > http://forums.matronics.com//files/dragstrut2_134.jpg > > > > > > > > > > > > > > > &nbs================ > > > * > > get="_blank">http://www.matronics.com/Navigator?Kolb-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > * > > > * ________________________________________________________________________________
Date: Mar 23, 2015
As I recall...the early Kolbs used steel rivets...and they worked very well..and the galvanic corrosion was not a problem as some thought...I rebuilt a MkIII and Ultrastar and both used steel rivets..Herb On 03/23/2015 09:09 AM, B Young wrote: > > Steel would be stronger than aluminum. But I don't know between > steel and stainless steel. The stainless steel won't rust. All > the pulled rivets in my kit were stainless > Boyd > > On Mar 23, 2015 7:10 AM, "Herb" > wrote: > > Thanks... > > Wondering if the steel rivets are stronger in shear? Herb > > On 03/23/2015 07:15 AM, mojavjoe(at)comcast.net > wrote: >> hurb >> my plans call for 1/8 1/8 steel rivets on the side gusset and 1/8 >> 1/4 steel rivets on the bottom, these should be steel and not >> stainless >> mojavjoe >> >> ------------------------------------------------------------------------ >> *From: *"Herb" <Herbgh(at)nctc.com> <mailto:Herbgh(at)nctc.com> >> *To: *"kolb-list" >> >> *Sent: *Monday, March 23, 2015 8:03:56 AM >> *Subject: *Re: Kolb-List: Re: Riveting question? >> >> >> >> Thanks...but guess I did not make it clear...it is the drag strut >> fitting plates, which attach the strut to the Spar tube and >> into the H >> section..at the lift strut attach area... There are two gussets; the >> thick one on the bottom of the wing and the curved thin one on the >> side.. Herb >> >> On 03/22/2015 09:57 PM, west1m wrote: >> >> > >> > here is another pic >> > >> > -------- >> > West1m >> > Hastings, MN >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=439751#439751 >> > >> > >> > >> > >> > Attachments: >> > >> > http://forums.matronics.com//files/dragstrut2_134.jpg >> > >> > >> > >> > >> > >> > >> > >> &nbs================ >> >> >> >> >> * >> >> >> * > > * > > get="_blank">http://www.matronics.com/Navigator?Kolb-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > * > > > * ________________________________________________________________________________
Date: Mar 23, 2015
Subject: Auto Pilot for less than 100 bucks...
On another subject.... spent my career in the computer business...Hardware and little software...too little software...for computer hardware is sold like candy bars...and the real emphasis is in programming.. always interested in computers...built my first one in the 1970's...Motorolla 6800 chip..running at a blazing 1 mhz...:-) 1 k of memory...hot stuff!!! that said....I bought two credit card sized computers...one called Ardunio and the other is a Raspberry Pi... The Ardunio has had many additional plug "on" logic boards built for it...One of interest is called the 10DOF...It encompasses a three axis accelerometer.. three axis gyroscope.. a compass(magnetometer) and a barometer that can serve as an altimeter... GPs boards are also available. I believe that many of the "so called" drones use a similar device that can be bought from hobby shops.. for a lot more money...the 10dof cost about 30 bucks...and Chinese clones(9DOF) sell for 12 or so...The Ardunio knock off's sell for 8 bucks...I bought the Fundunio...:-) All to be found on Ebay.... Lots of canned software....and much info on You tube..and elsewhere.. Pretty sure the C band satellite servo's , available from your neighbors yard for free would have enough power to operate trim tabs.. Or large hobby ones..for more money.. wondering if anyone else has thought of trying one on a Kolb...with strong servo's on the trim tabs...it should be possible to fly long distances with minimal input...naturally, rough air would throw it off...and cause gyrations as happens on "real planes" with auto pilots ...:-) Herb ________________________________________________________________________________
Date: Mar 23, 2015
Most steels are stronger than stainless. Stainless is usually 'tougher', but has less strength than high carbon steel. If you do a little googling, you can find charts that show both shear and tension strength of rivets all kinds & materials. I fly heavier (won't say 'bigger' to avoid offending John H) homebuilts, and in that world, most of us are pretty careful about deviating from the designer's instructions in structural areas. There can even be situations where 'stronger' may actually increase risk of failure in the overall structure, so following the designer's specs is the safest path, unless we are at least as qualified at engineering as he was. :-) Charlie On 3/23/2015 9:09 AM, B Young wrote: > > Steel would be stronger than aluminum. But I don't know between > steel and stainless steel. The stainless steel won't rust. All > the pulled rivets in my kit were stainless > Boyd > > On Mar 23, 2015 7:10 AM, "Herb" > wrote: > > Thanks... > > Wondering if the steel rivets are stronger in shear? Herb > > On 03/23/2015 07:15 AM, mojavjoe(at)comcast.net > wrote: >> hurb >> my plans call for 1/8 1/8 steel rivets on the side gusset and 1/8 >> 1/4 steel rivets on the bottom, these should be steel and not >> stainless >> mojavjoe >> >> ------------------------------------------------------------------------ >> *From: *"Herb" <Herbgh(at)nctc.com> <mailto:Herbgh(at)nctc.com> >> *To: *"kolb-list" >> >> *Sent: *Monday, March 23, 2015 8:03:56 AM >> *Subject: *Re: Kolb-List: Re: Riveting question? >> >> >> >> Thanks...but guess I did not make it clear...it is the drag strut >> fitting plates, which attach the strut to the Spar tube and >> into the H >> section..at the lift strut attach area... There are two gussets; the >> thick one on the bottom of the wing and the curved thin one on the >> side.. Herb >> >> On 03/22/2015 09:57 PM, west1m wrote: >> >> > >> > here is another pic >> > >> > -------- >> > West1m >> > Hastings, MN >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=439751#439751 >> > > ________________________________________________________________________________
Subject: Re: Auto Pilot for less than 100 bucks...
Date: Mar 23, 2015
Back when I was building my firefly, I thought of installing electric trim for an elevator tab. I did some research on RC servos and wind loads. I took worst case scenarios for a trim tab at 90 degrees to the airflow and found that sail winch servos for boats had more than enough torque to do the job. I came up with a circuit using a 555 timer and a bargraph to show position of the trim tab (assuming no mechanical failure of the linkage). I never installed the system though so have no actual flight data but in theory it could work. Arduino already has sketches for servos and 10dof sensors since robots have become so prolific, so I'm sure if you put your mind to it, it could be done. I have used arduino circuits in my plane in other capacities such as strobe lights and capacitive fuel indicator with a bargraph. I'm just installing the arduino version fuel indicator now. My analog version worked just fine but I got bored over the winter and had to invent a new one with a larger, brighter display. My circuits for the plane as well as links to my Youtube videos can be found on my web page. http://myplace.frontier.com/~t41pilot/index.html -------- Gregg Kaat 2011 Firefly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439798#439798 ________________________________________________________________________________
Subject: Firefly Serenity web site
Date: Mar 24, 2015
Hi Everybody, Here is a link to my new web site about building a Firefly Quick Build Kit. http://harnerfarm.net/serenity/serenity.html It contains quite a few photos with descriptions from the build process. There were some times that I got so busy building that I forgot to take pictures. Also, there is a complete copy of my builder's log. Under videos there is just the one of my first landing. It appears in several formats and it is kind of hard to see, but it is all I had. Hopefully, as I get back to flying, I will be able to post more videos and flying reports. This is a work in progress so if there is anything you would like to see added, please let me know. Thanks for looking, Stuart -------- "I don't care, I'm still free. You can't take the sky from me" - Josh Wedon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439836#439836 ________________________________________________________________________________
Date: Mar 26, 2015
You gotta go by what your sparkplugs read. Use your gauges for set points. In my limited experience, that spike is a false reading from the way the pipe is tuned. I'm not in any way telling you to stay at that throttle setting. I miss my original firestar when it warms up in MN. Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439909#439909 ________________________________________________________________________________
Subject: Re: Part 103 legal Firestar?
Date: Mar 26, 2015
My original firestar weighed in at 330lbs, ,377with an A box, 5 gal tank, brakes. Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439910#439910 ________________________________________________________________________________
Date: Mar 26, 2015
I can now insert photos of your courtesy cars into the app listings. Feel free to email me your photos, and please be sure to indicate in the title of the email the airport ID and/or city location, and if there is more than one FBO, which one the car is located at. The app has broken 1400 locations nationwide. Thanks, Glenn Email to airportcars101(at)gmail.com -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App. Over 1400 cars nationwide. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439938#439938 ________________________________________________________________________________
Subject: Kolb Mk III Classic for sale
Date: Mar 29, 2015
Hi, Kolb List-ers, I'm offering my 2001 Mk III for sale. It is in excellent condition, comes with many extras, and has always been hangared. It was built by Steven Green- has a Rotax 912ULS 100hp powerplant plus BRS, Mode C Txpdr, Intercom, Handheld, Garmin 396 and ANR headsets. TT 760 hours. If the weather cooperates, it can be seen at S&F this year. I'll hold off placing it on Barnstormers for a week or so, in case one of our own wants to talk about it before I do so. Please contact me off-list. Asking $23,500. Thanks, Dave david.watkins0(at)gmail.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440016#440016 Attachments: http://forums.matronics.com//files/kolb_mk_iii_207.jpg ________________________________________________________________________________
Date: Mar 29, 2015
Subject: Re: Kolb Mk III Classic for sale
thanks but im not looking to buy. =C2-I have fire star, just looking. On Sunday, March 29, 2015 5:34 PM, Watkinsdw wrote: Hi, Kolb List-ers, I'm offering my 2001 Mk III for sale. It is in excellent condition, comes w ith many extras, and has always been hangared. It was built by Steven Green-=C2- has a Rotax 912ULS 100hp powerplant plu s BRS, Mode C Txpdr, Intercom, Handheld, Garmin 396 and ANR headsets. TT 760 hours. If the weather cooperates, it can be seen at S&F this year.=C2- I'll hold off placing it on Barnstormers for a week or so, in case one of o ur own wants to talk about it before I do so. Please contact me off-list. Asking $23,500. Thanks, Dave david.watkins0(at)gmail.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440016#440016 Attachments: http://forums.matronics.com//files/kolb_mk_iii_207.jpg S - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: manual
Date: Apr 01, 2015
I bought a wrecked MK 111 classic that I am rebuilding. I have the original builders manual but it doesn't contain any info about installing and hooking up the controls that are between the seats, like the elevator cables, throttle, and trim. Is there a separate manual for this kind of stuff? Thanks Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440179#440179 ________________________________________________________________________________
Subject: Re: manual
Date: Apr 02, 2015
Yep. I ought to scan it and post it online as a reference, but in the meantime, here's these: -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440186#440186 Attachments: http://forums.matronics.com//files/img057_medium_588.jpg http://forums.matronics.com//files/img056_medium_868.jpg http://forums.matronics.com//files/img053_medium_203.jpg http://forums.matronics.com//files/img054_medium_122.jpg http://forums.matronics.com//files/img055_medium_298.jpg ________________________________________________________________________________
Subject: Re: manual
Date: Apr 02, 2015
Thanks Richard. I think I will call Travis and see if I can get the entire manual. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440223#440223 ________________________________________________________________________________
Subject: Re: manual
Date: Apr 02, 2015
If he doesn't have it, let me know, I will see about getting it posted on my web page. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440224#440224 ________________________________________________________________________________
Date: Apr 03, 2015
Subject: Latex Paint Forum at Sun N Fun
Hi Fellow Kolbers, I will be presenting the Latex Paint forum at this years Sun N Fun flyin in Lakeland, FL. It will be on Tuesday the 21st at noon in classroom 11. I will be flying down from PA with a friend in his Aerotrek and will be helping out at the Aerotrek display also. Hope to meet some of you there. Malcolm Morrison www.wienerdogaero.com ________________________________________________________________________________
Date: Apr 03, 2015
Kolbers: I plan to fly Miss P'fer, my MKIII, to Sun and Fun 2015. If I make it to Lakeland it will be my 32d consecutive visit. The Kolb Gang has graciously offered me and Miss P'fer a corner of their display area to live in for the week. Kolb display is located on the left as you enter the main gate at Paradise City. Hope to see a bunch of you all down there. john h mkIII Titus, Alabama I will be presenting the Latex Paint forum at this years Sun N Fun flyin in Lakeland, FL. It will be on Tuesday the 21st at noon in classroom 11. I will be flying down from PA with a friend in his Aerotrek and will be helping out at the Aerotrek display also. Hope to meet some of you there. Malcolm Morrison www.wienerdogaero.com ________________________________________________________________________________
Subject: Re: manual
Date: Apr 03, 2015
Ok Richard, thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440262#440262 ________________________________________________________________________________
Subject: Re: manual
Date: Apr 03, 2015
Probably be next week, busy right now. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440264#440264 ________________________________________________________________________________
Subject: Re: Latex Paint Forum at Sun N Fun
Date: Apr 04, 2015
Have a good trip John. As a non flyer now I have the next best thing coming up this afternoon. I am booked in for a Simulator flight at a local airfield. A poor substitute but there you go. Pat From: John Hauck Sent: Saturday, April 04, 2015 12:07 AM Subject: RE: Kolb-List: Latex Paint Forum at Sun N Fun Kolbers: I plan to fly Miss P'fer, my MKIII, to Sun and Fun 2015. If I make it to Lakeland it will be my 32d consecutive visit. The Kolb Gang has graciously offered me and Miss P'fer a corner of their display area to live in for the week. Kolb display is located on the left as you enter the main gate at Paradise City. Hope to see a bunch of you all down there. john h mkIII Titus, Alabama I will be presenting the Latex Paint forum at this years Sun N Fun flyin in Lakeland, FL. It will be on Tuesday the 21st at noon in classroom 11. I will be flying down from PA with a friend in his Aerotrek and will be helping out at the Aerotrek display also. Hope to meet some of you there. Malcolm Morrison www.wienerdogaero.com ________________________________________________________________________________
Date: Apr 04, 2015
Patrick: I certainly remember your trip to Sun and Fun, and also to Monument Valley. Those were some very good years. Never thought they would end. john h MKIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Patrick Ladd Sent: Saturday, April 04, 2015 3:43 AM Subject: Re: Kolb-List: Latex Paint Forum at Sun N Fun Have a good trip John. As a non flyer now I have the next best thing coming up this afternoon. I am booked in for a Simulator flight at a local airfield. A poor substitute but there you go. Pat From: John Hauck <mailto:jhauck(at)elmore.rr.com> Sent: Saturday, April 04, 2015 12:07 AM Subject: RE: Kolb-List: Latex Paint Forum at Sun N Fun Kolbers: I plan to fly Miss P'fer, my MKIII, to Sun and Fun 2015. If I make it to Lakeland it will be my 32d consecutive visit. The Kolb Gang has graciously offered me and Miss P'fer a corner of their display area to live in for the week. Kolb display is located on the left as you enter the main gate at Paradise City. Hope to see a bunch of you all down there. john h mkIII Titus, Alabama I will be presenting the Latex Paint forum at this years Sun N Fun flyin in Lakeland, FL. It will be on Tuesday the 21st at noon in classroom 11. I will be flying down from PA with a friend in his Aerotrek and will be helping out at the Aerotrek display also. Hope to meet some of you there. Malcolm Morrison www.wienerdogaero.com href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronic s.com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Apr 05, 2015
John. Terrible news. Went for my simulator flight yesterday in a Piper Arrow. Shot two circuits and missed the blood runway each time and pancaked in a field. Instructors said I was ``a little rusty.` It was disgraceful. I shall have to check out a real plane just to prove to myself that I can still do it. Hanging my head in shame. Pat From: John Hauck Sent: Saturday, April 04, 2015 3:13 PM Subject: RE: Kolb-List: Latex Paint Forum at Sun N Fun Patrick: I certainly remember your trip to Sun and Fun, and also to Monument Valley. Those were some very good years. Never thought they would end. john h MKIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Patrick Ladd Sent: Saturday, April 04, 2015 3:43 AM Subject: Re: Kolb-List: Latex Paint Forum at Sun N Fun Have a good trip John. As a non flyer now I have the next best thing coming up this afternoon. I am booked in for a Simulator flight at a local airfield. A poor substitute but there you go. Pat From: John Hauck Sent: Saturday, April 04, 2015 12:07 AM Subject: RE: Kolb-List: Latex Paint Forum at Sun N Fun Kolbers: I plan to fly Miss P'fer, my MKIII, to Sun and Fun 2015. If I make it to Lakeland it will be my 32d consecutive visit. The Kolb Gang has graciously offered me and Miss P'fer a corner of their display area to live in for the week. Kolb display is located on the left as you enter the main gate at Paradise City. Hope to see a bunch of you all down there. john h mkIII Titus, Alabama I will be presenting the Latex Paint forum at this years Sun N Fun flyin in Lakeland, FL. It will be on Tuesday the 21st at noon in classroom 11. I will be flying down from PA with a friend in his Aerotrek and will be helping out at the Aerotrek display also. Hope to meet some of you there. Malcolm Morrison www.wienerdogaero.com href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronic s.com/Navigator?Kolb-Listhref="http://forums.matronics.com">http://foru ms.matronics.comhref="http://www.matronics.com/contribution">http://www .matronics.com/c - The Kolb-List Email Forum - --> http://www.matronics.com/Navigator?Kolb-List - MATRONICS WEB FORUMS - --> http://forums.matronics.com - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. --> http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Confidence building flight
Date: Apr 05, 2015
Hi everyone, Managed to get out last evening and un-winterize the Firefly. It started on the first pull! Made two fast taxi trips up to flying speed, then took off for real. There was a little wind shear turbulence at 2 to 4 hundred feet, but it was light. Made it around just fine, but got a little high. Used a little slip on final to take care of that and kept some throttle on all the way down. Rounded out the descent and planted it firmly on two wheels with no bounce. So much fun I did it again. Same results. Now it is time to get serious and fly, fly, fly. Happy Easter! S ________________________________________________________________________________
Date: Apr 05, 2015
Subject: Re: Confidence building flight
Way to go Stuart!! Frosty morn down here in Ky... Fred and I will always feel a part of your flying... did you remove the electric start? someone may had said...the engine will break in noticeably in the 40 hour range... Herb ps anyone know anything about installing a VW on a Kolb?? :-) On 04/05/2015 08:09 AM, Stuart Harner wrote: > > Hi everyone, > > Managed to get out last evening and un-winterize the Firefly. It > started on the first pull! > > Made two fast taxi trips up to flying speed, then took off for real. > There was a little wind shear turbulence at 2 to 4 hundred feet, but > it was light. Made it around just fine, but got a little high. Used > a little slip on final to take care of that and kept some throttle on > all the way down. Rounded out the descent and planted it firmly on two > wheels with no bounce. > > So much fun I did it again. Same results. > > Now it is time to get serious and fly, fly, fly. > > Happy Easter! > > S > > * > > > * ________________________________________________________________________________
Date: Apr 05, 2015
Taxi trips to flying speed aren't recommended for new or rusty pilots. Without a aggressive forward stick movement as the throttle is retarded will result in the aircraft lifting off with little power. Herb, yes there are a growing number of VWs on Kolbs. Rick Neilsen Redrive VW powered MKIIIC On Sun, Apr 5, 2015 at 9:40 AM, Herb wrote: > Way to go Stuart!! Frosty morn down here in Ky... Fred and I will always > feel a part of your flying... > > did you remove the electric start? > > someone may had said...the engine will break in noticeably in the 40 > hour range... Herb > > ps anyone know anything about installing a VW on a Kolb?? :-) > > On 04/05/2015 08:09 AM, Stuart Harner wrote: > > Hi everyone, > > > Managed to get out last evening and un-winterize the Firefly. It started > on the first pull! > > > Made two fast taxi trips up to flying speed, then took off for real. > There was a little wind shear turbulence at 2 to 4 hundred feet, but it was > light. Made it around just fine, but got a little high. Used a little > slip on final to take care of that and kept some throttle on all the way > down. Rounded out the descent and planted it firmly on two wheels with no > bounce. > > > So much fun I did it again. Same results. > > > Now it is time to get serious and fly, fly, fly. > > > Happy Easter! > > > S > > > * > > > * > > ________________________________________________________________________________
Date: Apr 05, 2015
No, you kept the started and installed the recoil unit. I start the cold engine by squeezing the bulb until gas gets to carb, then two shots of primer into port on carb, throttle closed, enricher to full. Pull rope, engine starts. Thanks for the great deal on this engine Herb, I really like it. One thing I have found is that if I start it and let it warm up (CHT at 200=B0 +) while standing beside it, I can shut it off, get all strapped in and then start it up again from the seat. This is a nice feature to not be trying to get into a running plane. I tried it cold, but could not get enough pull to get it to start. Better leverage standing up with my left hand on the leading edge. More to come! Stuart From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Herb Sent: Sunday, April 05, 2015 8:40 AM Subject: Re: Kolb-List: Confidence building flight Way to go Stuart!! Frosty morn down here in Ky... Fred and I will always feel a part of your flying... did you remove the electric start? someone may had said...the engine will break in noticeably in the 40 hour range... Herb ps anyone know anything about installing a VW on a Kolb?? :-) On 04/05/2015 08:09 AM, Stuart Harner wrote: Hi everyone, Managed to get out last evening and un-winterize the Firefly. It started on the first pull! Made two fast taxi trips up to flying speed, then took off for real. There was a little wind shear turbulence at 2 to 4 hundred feet, but it was light. Made it around just fine, but got a little high. Used a little slip on final to take care of that and kept some throttle on all the way down. Rounded out the descent and planted it firmly on two wheels with no bounce. So much fun I did it again. Same results. Now it is time to get serious and fly, fly, fly. Happy Easter! S ________________________________________________________________________________
Date: Apr 05, 2015
Rick: How are we doing on VW powered Kolbs, number wise? I was up at the Kolb Co a couple weeks ago. There was a VW powered MKIII in the process of final build. Don't know of any VW powered airplanes, Kolbs or not, in my neck of the woods. Heard there is a VW powered MKIII in Idaho, in the building process. I'm grounded until I get my main gear mounts and legs back from Kolb. Hoping for next week. Only two weeks until time to fly to Lakeland. My how time flies when one is getting older. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen Sent: Sunday, April 05, 2015 9:51 AM Subject: Re: Kolb-List: Confidence building flight Taxi trips to flying speed aren't recommended for new or rusty pilots. Without a aggressive forward stick movement as the throttle is retarded will result in the aircraft lifting off with little power. Herb, yes there are a growing number of VWs on Kolbs. Rick Neilsen Redrive VW powered MKIIIC ________________________________________________________________________________
Date: Apr 05, 2015
Now I am wondering what I did with it??? Forgetful old fart , Herb On 04/05/2015 10:18 AM, Stuart Harner wrote: > > No, you kept the started and installed the recoil unit. > > I start the cold engine by squeezing the bulb until gas gets to carb, > then two shots of primer into port on carb, throttle closed, enricher > to full. Pull rope, engine starts. > > Thanks for the great deal on this engine Herb, I really like it. > > One thing I have found is that if I start it and let it warm up (CHT > at 200 +) while standing beside it, I can shut it off, get all > strapped in and then start it up again from the seat. This is a nice > feature to not be trying to get into a running plane. I tried it cold, > but could not get enough pull to get it to start. Better leverage > standing up with my left hand on the leading edge. > > More to come! > > Stuart > > *From:*owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] *On Behalf Of *Herb > *Sent:* Sunday, April 05, 2015 8:40 AM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: Confidence building flight > > Way to go Stuart!! Frosty morn down here in Ky... Fred and I will > always feel a part of your flying... > > did you remove the electric start? > > someone may had said...the engine will break in noticeably in the 40 > hour range... Herb > > ps anyone know anything about installing a VW on a Kolb?? :-) > > On 04/05/2015 08:09 AM, Stuart Harner wrote: > > Hi everyone, > > Managed to get out last evening and un-winterize the Firefly. It > started on the first pull! > > Made two fast taxi trips up to flying speed, then took off for > real. There was a little wind shear turbulence at 2 to 4 hundred > feet, but it was light. Made it around just fine, but got a little > high. Used a little slip on final to take care of that and kept > some throttle on all the way down. Rounded out the descent and > planted it firmly on two wheels with no bounce. > > So much fun I did it again. Same results. > > Now it is time to get serious and fly, fly, fly. > > Happy Easter! > > S > > * * > > * * > > * * > > * *Matronics List Features Navigator to & Download, 7-Day Browse, Chat, -->http://www.matronic================= > http://forums.matronics.com > <http://www.matronics.com/Navigator?Kolb-List>- List Contribution Web > Site -Matt Dralle, > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * * > * > > > * ________________________________________________________________________________
Date: Apr 05, 2015
Stuart: This is a good point to remember if one is going to do engine off flight with an in air restart. I learned the hard way. Brand new Firestar, 1987. Was thrilled because I could restart from the cockpit. Of course I didn't trying cranking a cold engine while seated. About the second day of flight on the new bird. Climbed to 3,000 feet over a very large hay field. Shut down the engine, glided to 1,500 feet. Pulled the recoil starter. Fired off, easy. That was so much fun I climbed to 5,000 feet, shut down, and glided to 1,000 feet. After several attempts to restart I realized the engine had cooled quickly and it wasn't going to happen. Thank goodness I made a good decision to do my testing over a good forced landing area. Made my first forced landing in my new Firestar. I liked to do engine off flight in my Ultrastar, but when the engine was shut down, or if I killed it horsing around, it was an automatic forced landing. On the ground I had to get out of the aircraft to restart. This meant dealing with 4 point harness and parachute bridal on my Jim Handbury hand deployed parachute. A royal pain in the butt. Happy Easter, everyone! john h mkIII Titus, Alabama One thing I have found is that if I start it and let it warm up (CHT at 200=B0 +) while standing beside it, I can shut it off, get all strapped in and then start it up again from the seat. This is a nice feature to not be trying to get into a running plane. I tried it cold, but could not get enough pull to get it to start. Better leverage standing up with my left hand on the leading edge. More to come! Stuart ________________________________________________________________________________
Date: Apr 06, 2015
Got a Mark3 X-tra close to me that's almost ready to fire up. Roger Sell is the builder owner and should be lighting the fires in the Grea t Planes / Valley Engineering redrive combo this Spring.=F0=9F=91=8D Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA > On Apr 5, 2015, at 11:28 AM, John Hauck wrote: > > Rick: > > How are we doing on VW powered Kolbs, ________________________________________________________________________________
Subject: Better than Seafoam?
Date: Apr 06, 2015
Cleaning out the rings on the 582, it's been a while, and the lower one was stuck on one side near the locator pin, both pistons. Scraped and scraped, looked pretty good, put the rings back in and was not real happy, Still sticking a little bit on that same side. Went to scrape some carbon off the underside of the head and think about it. Scraped a bit, and then just for the heck of it, shot the head with some PB Blaster. WOW! That stuff dissolves soft carbon like crazy. Let it sit for a while, wiped it off with a paper towel. Went online and researched it, saw some posts where other people had good results, but one post said to keep it away from seals, it can make them swell. Packed the base of the pistons with shop rags, drenched the rings and piston lands with the stuff, letting it sit overnight. Will post again tomorrow. But I did see dissolving carbon running down the sides of the pistons. That would seem to be a good sign. But unlike Seafoam, I really don't see putting this stuff in the gas tank. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440341#440341 ________________________________________________________________________________
Subject: Re: Better than Seafoam?
Date: Apr 06, 2015
PB Blaster is the best liquid wrench I've ever used. Breaks loose unbelievably tough rusted bolts and even galled threads. Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA > On Apr 6, 2015, at 6:20 PM, Richard Pike wrote: > > > Cleaning out the rings on the 582, it's been a while, and the lower one was stuck on one side near the locator pin, both pistons. Scraped and scraped, looked pretty good, put the rings back in and was not real happy, Still sticking a little bit on that same side. Went to scrape some carbon off the underside of the head and think about it. > > Scraped a bit, and then just for the heck of it, shot the head with some PB Blaster. WOW! That stuff dissolves soft carbon like crazy. Let it sit for a while, wiped it off with a paper towel. Went online and researched it, saw some posts where other people had good results, but one post said to keep it away from seals, it can make them swell. > > Packed the base of the pistons with shop rags, drenched the rings and piston lands with the stuff, letting it sit overnight. Will post again tomorrow. But I did see dissolving carbon running down the sides of the pistons. That would seem to be a good sign. > > But unlike Seafoam, I really don't see putting this stuff in the gas tank. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440341#440341 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 06, 2015
Richard: Maybe you can convince the mfg to add wordage to the label, right alongside the statement about fixing leaky toilets. 8>) I agree with Dennis, it's good stuff. rowedenny wrote: > PB Blaster is the best liquid wrench I've ever used. Breaks loose unbelievably tough rusted bolts and even galled threads. > > Dennis "Skid" Rowe > > On Apr 6, 2015, at 6:20 PM, Richard Pike wrote: > > . . . S N I P . . . > > Scraped a bit, and then just for the heck of it, shot the head with some PB Blaster. WOW! That stuff dissolves soft carbon like crazy. Let it sit for a while, wiped it off with a paper towel. Went online and researched it, saw some posts where other people had good results, but one post said to keep it away from seals, it can make them swell. > > . . . S N I P . . . > > But unlike Seafoam, I really don't see putting this stuff in the gas tank. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' > :D -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440348#440348 ________________________________________________________________________________
Subject: 250# pilot to heavy to solo Kolbra?
Date: Apr 06, 2015
I am 6'2" guy that weighs in at 250 to 260 lbs range just wondering if I am to heavy to fly the Kolbra......I have been told that I am to heavy for this machine and the weight and balance would be to nose heavy with me. I am just curious cause I am considering buying one of these machines or something similar and just want your expertise on this issue.. Would I be better off with say a Mark III let me know what you all think about this. Thanks in advance Larry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440352#440352 ________________________________________________________________________________
Subject: Re: 250# pilot to heavy to solo Kolbra?
Date: Apr 07, 2015
HI Larry, I have a MkIII xtra and have never flown a Kolbra but I am 200Lbs and can take another 200Lb passenger in my 80HP Jabiru plane, but it does make the nose a little heavy and I have limited passengers to 200Lbs for my comfort level. If I take a 60Lb person it flys just fine with no noticeble effect, so I would expect a MkIII to fly fine also. I have sat in a Kolbra and I would advise you to try out each model as getting in and out could be the major issue in deciding what model works best for you. If you intend to fly just by yourself I would consider flying from the back seat in a Kolbra for weight and balance considerations but it may not make much difference. Good luck with your search. Frankd N1014S. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440378#440378 ________________________________________________________________________________
Date: Apr 07, 2015
Larry, as far as your up front max weight of 260 lbs, it's not a problem. My wife and I weigh about 400 lbs (total weight of course) ahead of the cg and yes the nose is a little heavy, but I always have enough up elevator to make safe landings. I would recommend the Rotax 912uls (100 hp) for max performance and the added weight aft of the cg to offset your weight if you are concerned about it. I have my weight and balance sheets on file if you are interested. I have made several videos with my wife and I flying the Kolbra. She does all the video from the rear seat and yes you will be able to fly yours from the front. If you would like to see any of these videos they are here on my youtube channel: https://www.youtube.com/user/flyguy8294 Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 28 years flying it Kolbra 912ULS N20386 350 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440383#440383 ________________________________________________________________________________
Date: Apr 07, 2015
Larry, as far as your up front max weight of 260 lbs, it's not a problem. My wife and I weigh about 400 lbs (total weight of course) ahead of the cg and yes the nose is a little heavy, but I always have enough up elevator to make safe landings. I would recommend the Rotax 912uls (100 hp) for max performance and the added weight aft of the cg to offset your weight if you are concerned about it. I have my weight and balance sheets on file if you are interested. I have made several videos with my wife and I flying the Kolbra. She does all the video from the rear seat and yes you will be able to fly yours from the front. If you would like to see any of these videos they are here on my youtube channel: https://www.youtube.com/user/flyguy8294 Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 28 years flying it Kolbra 912ULS N20386 350 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440384#440384 ________________________________________________________________________________
Date: Apr 07, 2015
Had a chance to experiment on some old lawnmower engine cylinder heads Sea foam PB blaster carb cleaner. Not much gets after hard carbon Sent from my iPhone > On Apr 6, 2015, at 8:59 PM, Dennis Rowe wrote: > > > PB Blaster is the best liquid wrench I've ever used. Breaks loose unbelievably tough rusted bolts and even galled threads. > > Dennis "Skid" Rowe > Mk3, Rotax 670, > Leechburg, PA > > > >> On Apr 6, 2015, at 6:20 PM, Richard Pike wrote: >> >> >> Cleaning out the rings on the 582, it's been a while, and the lower one was stuck on one side near the locator pin, both pistons. Scraped and scraped, looked pretty good, put the rings back in and was not real happy, Still sticking a little bit on that same side. Went to scrape some carbon off the underside of the head and think about it. >> >> Scraped a bit, and then just for the heck of it, shot the head with some PB Blaster. WOW! That stuff dissolves soft carbon like crazy. Let it sit for a while, wiped it off with a paper towel. Went online and researched it, saw some posts where other people had good results, but one post said to keep it away from seals, it can make them swell. >> >> Packed the base of the pistons with shop rags, drenched the rings and piston lands with the stuff, letting it sit overnight. Will post again tomorrow. But I did see dissolving carbon running down the sides of the pistons. That would seem to be a good sign. >> >> But unlike Seafoam, I really don't see putting this stuff in the gas tank. >> >> -------- >> Richard Pike >> Kolb MKIII N420P (420ldPoops) >> Kingsport, TN 3TN0 >> There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=440341#440341 >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Apr 07, 2015
Ralph and Franks thanks for the Info and the quick replies... I sure do appreciate you both taking time to give me some info on my concerns.. This is a great forum with a good bunch and lots of knowledge to draw from... Thanks again Larry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440397#440397 ________________________________________________________________________________
Date: Apr 08, 2015
Let it soak the rings & grooves overnight, helped a little. My conclusion: it works great on soft carbon, not as much on hard carbon, still better than nothing. OTOH, Seafoam only has one purpose, and if it doesn't clean the carbon off your pistons and rings, it is pointless. PB Blaster works great on loosening rusted stuff even if it doesn't clean the carbon off the rings as good as I wish. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440442#440442 ________________________________________________________________________________
Subject: MK 111 rebuild
Date: Apr 08, 2015
I have removed the single pedal cable brakes and want to install the Matco hydraulic brakes. Is there any drawings on how and where to install them. I also bought a set of steel gear legs but they don't look like they will fit. The aluminum ones are same size all the way up inside the tubing on the cage but the steel ones have 2 collars around them and are considerably smaller in diameter where they exit the cage. Are they not for a MK 111? Thanks Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440470#440470 ________________________________________________________________________________
Date: Apr 08, 2015
Bob: You can post a photo to this page. Sounds like some gear legs Old Kolb Co came up with after Jim and I started experimenting and using 4130 legs on my Firestar and MKIII. Yes, tapered legs were designed for the MKIII. Doubt they will work on your Kolbra. Call Travis Brown at Kolb Co. He can fix you up with the correct gear legs. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of pipercolt Sent: Wednesday, April 08, 2015 8:33 PM Subject: Kolb-List: MK 111 rebuild I have removed the single pedal cable brakes and want to install the Matco hydraulic brakes. Is there any drawings on how and where to install them. I also bought a set of steel gear legs but they don't look like they will fit. The aluminum ones are same size all the way up inside the tubing on the cage but the steel ones have 2 collars around them and are considerably smaller in diameter where they exit the cage. Are they not for a MK 111? Thanks Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440470#440470 ________________________________________________________________________________
Date: Apr 09, 2015
Richard Pike wrote: > Let it soak the rings & grooves overnight, helped a little. Wonder if anyone uses oven cleaner? -------- GeoB "Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440483#440483 ________________________________________________________________________________
Subject: Re: MK 111 rebuild
Date: Apr 09, 2015
pipercolt wrote: > I have removed the single pedal cable brakes and want to install the Matco hydraulic brakes. Is there any drawings on how and where to install them. I also bought a set of steel gear legs but they don't look like they will fit. The aluminum ones are same size all the way up inside the tubing on the cage but the steel ones have 2 collars around them and are considerably smaller in diameter where they exit the cage. Are they not for a MK 111? > Thanks > Bob If they look like this, then yes, they are for a MKIII. I am using them now. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440486#440486 Attachments: http://forums.matronics.com//files/p1050448_large_130.jpg http://forums.matronics.com//files/p1050449_large_153.jpg ________________________________________________________________________________
From: "KIRBY, DENNIS T GS-13 USAF AFMC AFNWC/EZS" <dennis.kirby.3(at)us.af.mil>
Date: Apr 09, 2015
From: "pipercolt" <bob.pipercolt(at)yahoo.com> I have removed the single pedal cable brakes and want to install the Matco hydraulic brakes. Is there any drawings on how and where to install them. I also bought a set of steel gear legs but they don't look like they will fit. The aluminum ones are same size all the way up inside the tubing on the cage but the steel ones have 2 collars around them and are considerably smaller in diameter where they exit the cage. Are they not for a MK 111? Thanks Bob ________________________________________________________________________________
Date: Apr 09, 2015
"pipercolt" wrote: << I have removed the single pedal cable brakes and want to install the Matco hydraulic brakes. Is there any drawings on how and where to install them. ... >> Thanks Bob Bob - Install your Matco brakes so that the brake unit is positioned in such a way that the filler nipple is pointing upward. That will make filling your brakes with fluid MUCH easier. To keep the nipple clean and free of dirt, I put a little plastic cover on mine - the kind you find at hardware stores called "thread protectors." They come in different sizes & colors. The red one (for a 1/4 inch bolt) is what fits on the filler nipple. Dennis Kirby Mark-3, 300 hrs TT Sandia Park, NM ________________________________________________________________________________
Date: Apr 09, 2015
Hi Guys Thanks for the replies. Yes Dennis, those are the legs that I have. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440493#440493 ________________________________________________________________________________
Subject: Re: Recall: Re: MK 111 rebuild
Date: Apr 09, 2015
KIRBY, DENNIS T GS-13 USAF AFMC AFNWC/EZS would like to recall the message, "Re: MK 111 rebuild". ________________________________________________________________________________
Date: Apr 09, 2015
I also have the tapered spring steel landing gear that Richard posted photos of. Old Kolb developed these gear legs. When Old Kolb built them they welded a tubular extension on the nub at the 31 inch (from Richard's second photo) part of the gear legs. This extension carried the landing load further up into gear socket in the fuselage cage. When I installed these gear legs on my MKIIIC I slipped a 4130 steel tube over the gear legs from the 21 inch measure to app 36 inch measure. The tube is slightly smaller OD than the gear socket ID. I had to grind the nub at the 31 inch measure down a bit to fit in the reinforcing tube. I would have welded on a extension on like Old Kolb did but was afraid of changing the tempering of the gear legs. The gear legs are great, very durable with plenty of travel and spring. They are shorter than the newer tubular gear legs but work well for me. You do have to be careful because the spring in the gear will bounce you back into the air on a bad landing. Rick Neilsen Redrive VW Powered MKIIIC On Thu, Apr 9, 2015 at 7:45 AM, Richard Pike wrote: > > > pipercolt wrote: > > I have removed the single pedal cable brakes and want to install the > Matco hydraulic brakes. Is there any drawings on how and where to install > them. I also bought a set of steel gear legs but they don't look like they > will fit. The aluminum ones are same size all the way up inside the tubing > on the cage but the steel ones have 2 collars around them and are > considerably smaller in diameter where they exit the cage. Are they not for > a MK 111? > > Thanks > > Bob > > > If they look like this, then yes, they are for a MKIII. I am using them > now. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > There are two kinds of people: those who say to God, 'Thy will be done,' > and those to whom God says, 'All right, then, have it your way.' > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440486#440486 > > > Attachments: > > http://forums.matronics.com//files/p1050448_large_130.jpg > http://forums.matronics.com//files/p1050449_large_153.jpg > > ________________________________________________________________________________
Date: Apr 09, 2015
Neil I wonder what the reason was that Old kolb welded on the extension. Thanks to all that have responded. This is a great site. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440544#440544 ________________________________________________________________________________
Date: Apr 09, 2015
Summer 1988, after flying over Niagara Falls the first time in my Kolb Firestar, I had an engine failure and forced landing over the river between Buffalo and Grand Island, NY, in the middle of the Niagara River. Got real busy on short, short final and stalled the Firestar ripping out the gear leg socket and shearing a socket in midsection. Up until this time the instructions called for running the gear leg only halfway into the socket. This put the load at the weakest point where the socket was drilled for securing the leg. Winter 1988, Brother Jim and I completely rebuilt the Firestar fuselage. We decided at this time to run the 4130 gear legs (our design) all the way into the socket until it bottomed out at the intersection, spreading the load throughout the socket. Never sheared another one after that. The extension was an improvement over the old system of insertion only halfway in. Homer Kolb used to tell me I was his best test bed. If it could be broken, I'd probably do just that. Miss those good old days. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of pipercolt Sent: Thursday, April 09, 2015 6:43 PM Subject: Kolb-List: Re: MK 111 rebuild Neil I wonder what the reason was that Old kolb welded on the extension. Thanks to all that have responded. This is a great site. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440544#440544 ________________________________________________________________________________
Date: Apr 10, 2015
Well John, that does make sense. I live just about 50 airmiles South of your unintended landing at the falls. I think I will install them as they are. I fly off a 2000' grass strip and PLAN on any off field landings. Has anyone moved the battery to the nose section of the plane? I know that is a long way to run the positive cable but It sure would help with the CG. Thanks Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440610#440610 ________________________________________________________________________________
Date: Apr 10, 2015
With a steel leg terminating at the midpoint of the gear leg socket, one has effectively constructed a shear at the weakest point of the socket. I haven't paid that much attention to the old solid steel legs. Did not realize they were designed short. Before I would relocate the battery from the CG to the nose I would test fly the airplane. Now that is what I would do if I had an itch to put a heavy battery way up there. Heck, we have had folks haul lead in the nose. Nose down pitch at cruise and full power is the biggest annoyance of a MKIII. Normally, they do not have a CG problem. Adverse pitch down is caused by the high thrust line of the pusher configuration. Can be dealt with by forced trim and aileron adjustment. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of pipercolt Sent: Friday, April 10, 2015 7:02 PM Subject: Kolb-List: Re: MK 111 rebuild Well John, that does make sense. I live just about 50 airmiles South of your unintended landing at the falls. I think I will install them as they are. I fly off a 2000' grass strip and PLAN on any off field landings. Has anyone moved the battery to the nose section of the plane? I know that is a long way to run the positive cable but It sure would help with the CG. Thanks Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440610#440610 = Photoshare, and much much more: = = = ________________________________________________________________________________
Date: Apr 10, 2015
Bob, I'm in the process of overhauling the brake system on a Just Aircraft Highlander with Matco internal caliper brakes. I've not seen it mentioned in the manual but make sure the calipers are mounted such that the airflow carries the brake dust away from the sliders on the caliper. For the internal calipers that's AFT of the axle. Also, the Highlander was experiencing severe pad wear. Worn out in 30 hours. My theory is that the Nylaflow tubing was installed so that it had to have an "S" bend that caused the tubing to act like a spring and keep the fixed pad in constant contact with the disk. The fix, again my theory, is to put a 90 degree steet ell into the caliper pointing toward the center of the aircraft and a 45 degree 1/8 NPT to 1/4 compression fitting (Matco has them: http://www.matcomfg.com/BRASSELBOW45DEGR18NPT14COMPRESSIONWITHINSERT-idv-3584-35.html so that the brake line follows the gear leg all the way to the caliper with minimal bending. Like I said, that's the theory so use at your own discretion. Rick Girard On Fri, Apr 10, 2015 at 7:38 PM, John Hauck wrote: > > With a steel leg terminating at the midpoint of the gear leg > socket, one has effectively constructed a shear at the > weakest point of the socket. > > I haven't paid that much attention to the old solid steel > legs. Did not realize they were designed short. > > Before I would relocate the battery from the CG to the nose > I would test fly the airplane. Now that is what I would do > if I had an itch to put a heavy battery way up there. Heck, > we have had folks haul lead in the nose. > > Nose down pitch at cruise and full power is the biggest > annoyance of a MKIII. Normally, they do not have a CG > problem. Adverse pitch down is caused by the high thrust > line of the pusher configuration. Can be dealt with by > forced trim and aileron adjustment. > > john h > mkIII > Titus, Alabama > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of > pipercolt > Sent: Friday, April 10, 2015 7:02 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: MK 111 rebuild > > > > Well John, that does make sense. I live just about 50 > airmiles South of your unintended landing at the falls. I > think I will install them as they are. I fly off a 2000' > grass strip and PLAN on any off field landings. Has anyone > moved the battery to the nose section of the plane? I know > that is a long way to run the positive cable but It sure > would help with the CG. > Thanks > Bob > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440610#440610 > > > = > Photoshare, and much much more: > = > = > = > > -- Believe those who are seeking the truth, doubt those who find it. -Andre Gide ________________________________________________________________________________
Date: Apr 11, 2015
<> John, surely the C of G would have been calculated with the battery in position, in flying position before the plane was taken into the air on her first flight. I needed some lead in the nose to bring the C of G between the specified limits on my Xtra. Nothing to do with flying characteristics. If the battery can be moved to produce the correct C of G without adding extra weight somewhere, thats a bonus. Pat -----Original Message----- From: John Hauck Sent: Saturday, April 11, 2015 1:38 AM Subject: RE: Kolb-List: Re: MK 111 rebuild With a steel leg terminating at the midpoint of the gear leg socket, one has effectively constructed a shear at the weakest point of the socket. I haven't paid that much attention to the old solid steel legs. Did not realize they were designed short. Before I would relocate the battery from the CG to the nose I would test fly the airplane. Now that is what I would do if I had an itch to put a heavy battery way up there. Heck, we have had folks haul lead in the nose. Nose down pitch at cruise and full power is the biggest annoyance of a MKIII. Normally, they do not have a CG problem. Adverse pitch down is caused by the high thrust line of the pusher configuration. Can be dealt with by forced trim and aileron adjustment. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of pipercolt Sent: Friday, April 10, 2015 7:02 PM Subject: Kolb-List: Re: MK 111 rebuild Well John, that does make sense. I live just about 50 airmiles South of your unintended landing at the falls. I think I will install them as they are. I fly off a 2000' grass strip and PLAN on any off field landings. Has anyone moved the battery to the nose section of the plane? I know that is a long way to run the positive cable but It sure would help with the CG. Thanks Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440610#440610 = Photoshare, and much much more: = = = ________________________________________________________________________________
Date: Apr 11, 2015
Hi all long time no post from me but still read the list regularly. Like pa t's extra my mk111 classic has lead in the nosecone it is one if the things I am thinking of changing .I figure the battery sits behind the seat at ju st about the cg and if I put it in the nose I can take the same weight of l ead out of there only a few kilos saved but better out the aircraft than in it .people with more experience and knowledge than me are welcome to point out any pitfalls in my thoughts on this Eddie -----Original Message----- From: "Patrick Ladd" <patrickjladd(at)hotmail.com> Sent: =8E11/=8E04/=8E2015 10:31 Subject: Re: Kolb-List: Re: MK 111 rebuild <> John, surely the C of G would have been calculated with the battery in position, in flying position before the plane was taken into the air on her first flight. I needed some lead in the nose to bring the C of G between the specified limits on my Xtra. Nothing to do with flying characteristics. If the battery can be moved to produce the correct C of G without adding extra weight somewhere, thats a bonus. Pat -----Original Message----- From: John Hauck Sent: Saturday, April 11, 2015 1:38 AM Subject: RE: Kolb-List: Re: MK 111 rebuild With a steel leg terminating at the midpoint of the gear leg socket, one has effectively constructed a shear at the weakest point of the socket. I haven't paid that much attention to the old solid steel legs. Did not realize they were designed short. Before I would relocate the battery from the CG to the nose I would test fly the airplane. Now that is what I would do if I had an itch to put a heavy battery way up there. Heck, we have had folks haul lead in the nose. Nose down pitch at cruise and full power is the biggest annoyance of a MKIII. Normally, they do not have a CG problem. Adverse pitch down is caused by the high thrust line of the pusher configuration. Can be dealt with by forced trim and aileron adjustment. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of pipercolt Sent: Friday, April 10, 2015 7:02 PM Subject: Kolb-List: Re: MK 111 rebuild Well John, that does make sense. I live just about 50 airmiles South of your unintended landing at the falls. I think I will install them as they are. I fly off a 2000' grass strip and PLAN on any off field landings. Has anyone moved the battery to the nose section of the plane? I know that is a long way to run the positive cable but It sure would help with the CG. Thanks Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440610#440610 = Photoshare, and much much more: = = = ________________________________________________________________________________
Date: Apr 11, 2015
Hi Eddie. just thoughts. i did some experimentation with battery position (and battery come to that) Find something substantial to fix the battery to, and then do the sums. You need something more than a bit of ply to hold the battery in place in a heavy landing, or maybe even in strong turbulence. Better to maybe move the battery forward to a secure location and then fine balance with a small amount of lead. Incidentally I used a racing motorbike battery (Called a RED TOP over here) It had bags of power whereas my first battery went flat if the engine didn`t catch on the first few turns Incidentally I used sheet lead cut to about 3 or 4 inch squares, put them in a stack and drilled two holes right through. I clamped them together with a metal bar across the top drilled to suit the holes in the lead. With a suitable large plate at the other end and a couple of bolts that was it. You can easily add or subtract a single piece of lead when you get to fine tuning. Cheers Pat From: Eddie Sent: Saturday, April 11, 2015 12:54 PM Subject: RE: Kolb-List: Re: MK 111 rebuild Hi all long time no post from me but still read the list regularly. Like pat's extra my mk111 classic has lead in the nosecone it is one if the things I am thinking of changing .I figure the battery sits behind the seat at just about the cg and if I put it in the nose I can take the same weight of lead out of there only a few kilos saved but better out the aircraft than in it .people with more experience and knowledge than me are welcome to point out any pitfalls in my thoughts on this Eddie ------------------------------------------------------------------------- ------- From: Patrick Ladd Sent: =8E11/=8E04/=8E2015 10:31 Subject: Re: Kolb-List: Re: MK 111 rebuild <> John, surely the C of G would have been calculated with the battery in position, in flying position before the plane was taken into the air on her first flight. I needed some lead in the nose to bring the C of G between the specified limits on my Xtra. Nothing to do with flying characteristics. If the battery can be moved to produce the correct C of G without adding extra weight somewhere, thats a bonus. Pat -----Original Message----- From: John Hauck Sent: Saturday, April 11, 2015 1:38 AM Subject: RE: Kolb-List: Re: MK 111 rebuild With a steel leg terminating at the midpoint of the gear leg socket, one has effectively constructed a shear at the weakest point of the socket. I haven't paid that much attention to the old solid steel legs. Did not realize they were designed short. Before I would relocate the battery from the CG to the nose I would test fly the airplane. Now that is what I would do if I had an itch to put a heavy battery way up there. Heck, we have had folks haul lead in the nose. Nose down pitch at cruise and full power is the biggest annoyance of a MKIII. Normally, they do not have a CG problem. Adverse pitch down is caused by the high thrust line of the pusher configuration. Can be dealt with by forced trim and aileron adjustment. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of pipercolt Sent: Friday, April 10, 2015 7:02 PM Subject: Kolb-List: Re: MK 111 rebuild Well John, that does make sense. I live just about 50 airmiles South of your unintended landing at the falls. I think I will install them as they are. I fly off a 2000' grass strip and PLAN on any off field landings. Has anyone moved the battery to the nose section of the plane? I know that is a long way to run the positive cable but It sure would help with the CG. Thanks Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440610#440610 = Photoshare, and much much mo - MATRONICS WEB FORUMS - ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 3 Mgs - 04/10/15
Date: Apr 11, 2015
I had my battery up front in my mk III for a while then moved it back... it just seemed to fly better with the cg back.... especially with a passenger. boyd >>>>>>>>>>>>>>> Well John, that does make sense. I live just about 50 airmiles South of your unintended landing at the falls. I think I will install them as they are. I fly off a 2000' grass strip and PLAN on any off field landings. Has anyone moved the battery to the nose section of the plane? I know that is a long way to run the positive cable but It sure would help with the CG. Thanks Bob --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com ________________________________________________________________________________
Date: Apr 11, 2015
If John H has a huge tail wheel, 26 gallon of fuel, and a 912S with a three blade 72" warp drive prop all behind his C/G, and his scrawny little butt in front of the C/G and doesn't need his battery in the nose to balance his Mark3, why does any Mark3 need nose ballast? Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA > On Apr 11, 2015, at 10:12 AM, b young wrote: > > > I had my battery up front in my mk III for a while then moved it back... it just seemed to fly better with the cg back.... especially with a passenger. > > boyd > > > > Well John, that does make sense. I live just about 50 airmiles South of your unintended > landing at the falls. I think I will install them as they are. I fly > off a 2000' grass strip and PLAN on any off field landings. Has anyone moved the > battery to the nose section of the plane? I know that is a long way to run > the positive cable but It sure would help with the CG. > Thanks > Bob > > --- > This email has been checked for viruses by Avast antivirus software. > http://www.avast.com > > > > > ________________________________________________________________________________
Subject: Tail Heavy
Date: Apr 11, 2015
=0A =0A Greetings Group=2C=0A =0A After buying an older Mark III that needed a LOT of fixing=2C=0A I finally took it out this year for some Fast Taxi testing and a couple of crow=0A hops. I found it was better to fly the pattern than it was to crow hop it. The one=0A thing I have been having difficulty with is it tends to be tail-heavy at ab out=0A 80mph ias. As I come in for landing=2C I can reduce some of the pressure on the=0A forward stick due to the diminishing air speed. Boyd Y. and I changed the =0A adjustment position of the flaps in hopes this would help it cruse =93hands free=94=0A or relatively stable flight. Currently when I let off the forward pressure on=0A the stick=2C it starts to climb right away. I have read some previous posti ngs by=0A John H. regarding =93nose heavy=94. His writings indicate the Kolb designed to fly=0A as they are and do not require aggressive trimming. =0A =0A If anyone has had a similar experience with the Mark III=0A appearing to fly tail heavy=2C and you have been able to resolve the issue =2C let=0A me know what you did.=0A =0A Thanks=2C=0A =0A Kurt=0A =0A Mark III C=0A =0A Sandy=2C Utah=0A =0A ________________________________________________________________________________
Date: Apr 11, 2015
Subject: Re: Tail Heavy
Kurt There is tail heavy more accurately called beyond the aft CG limits and there is a rigging or trim issue that makes the plane pitch up. You need to know what the problem is before you can resolve the issue. Kolbs have a long fuselage and large tail surfaces so they aren't sensitive to CG (Center of Gravity) changes. Do you know where the CG is for your plane? If you don't you need to know this. My VW powered MKIIC needed the battery in the nose cone to get the CG where it needed to be. Once you have determined that the CG is in the recommended range check that the horizontal stabilizer is mounted according to factory recommendations. I assume you have adjusted the elevator trim lever and maybe the trim spring tension. Reducing the tension will reduce the pitch up condition also assuming it is tight. With every thing else rigged right you get the best performance with the elevator trimmed to set about even with the horizontal stabilizer with a light solo pilot but don't worry about that yet. Check the wing angle of attack for factory recommendations. There is one angle of attack for long gear legs and one for the stock legs with corresponding changes for the horizontal stabilizer. Changes to the flaps and ailerons rigging will have small changes to pitch. I normally like to see flaps and ailerons rigged even with the bottom on the wing. This will give you something to check on. As always worth what you paid for it. Rick Neilsen Redrive VW Powered MKIIIC On Sat, Apr 11, 2015 at 3:31 PM, K I wrote: > > > Greetings Group, > > After buying an older Mark III that needed a LOT of fixing, I finally too k > it out this year for some Fast Taxi testing and a couple of crow hops. I > found it was better to fly the pattern than it was to crow hop it. The on e > thing I have been having difficulty with is it tends to be tail-heavy at > about 80mph ias. As I come in for landing, I can reduce some of the > pressure on the forward stick due to the diminishing air speed. Boyd Y. a nd > I changed the adjustment position of the flaps in hopes this would help i t > cruse =9Chands free=9D or relatively stable flight. Currently when I let off > the forward pressure on the stick, it starts to climb right away. I have > read some previous postings by John H. regarding =9Cnose heavy =9D. His writings > indicate the Kolb designed to fly as they are and do not require aggressi ve > trimming. > > If anyone has had a similar experience with the Mark III appearing to fly > tail heavy, and you have been able to resolve the issue, let me know what > you did. > > Thanks, > > Kurt > > Mark III C > > Sandy, Utah > > * > =========== onics.com/Navigator?Kolb-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Apr 11, 2015
Can someone smarter than me explain adjusting aileron and flaps to eliminate having to push forward on the stick to fly level. (Out of trim feels tall heavy) VS Being tail heavy on the scales.... Boyd Y On Apr 11, 2015 1:33 PM, "K I" wrote: > > > Greetings Group, > > After buying an older Mark III that needed a LOT of fixing, I finally too k > it out this year for some Fast Taxi testing and a couple of crow hops. I > found it was better to fly the pattern than it was to crow hop it. The on e > thing I have been having difficulty with is it tends to be tail-heavy at > about 80mph ias. As I come in for landing, I can reduce some of the > pressure on the forward stick due to the diminishing air speed. Boyd Y. a nd > I changed the adjustment position of the flaps in hopes this would help i t > cruse =9Chands free=9D or relatively stable flight. Currently when I let off > the forward pressure on the stick, it starts to climb right away. I have > read some previous postings by John H. regarding =9Cnose heavy =9D. His writings > indicate the Kolb designed to fly as they are and do not require aggressi ve > trimming. > > If anyone has had a similar experience with the Mark III appearing to fly > tail heavy, and you have been able to resolve the issue, let me know what > you did. > > Thanks, > > Kurt > > Mark III C > > Sandy, Utah > > * > =========== onics.com/Navigator?Kolb-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Subject: Tail Heavy
Date: Apr 11, 2015
During flight, pull the flaps on. That will trim the nose down. If flaps and/or ailerons are reflexed, that pulls the nose up. If flaps and ailerons are trimmed level with the bottom of the wing on the ground, they will be slightly drooped in flight. Air coming over the wings pushed them down. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of B Young Sent: Saturday, April 11, 2015 6:57 PM Subject: Re: Kolb-List: Tail Heavy Can someone smarter than me explain adjusting aileron and flaps to eliminate having to push forward on the stick to fly level. (Out of trim feels tall heavy) VS Being tail heavy on the scales.... Boyd Y On Apr 11, 2015 1:33 PM, "K I" wrote: Greetings Group, After buying an older Mark III that needed a LOT of fixing, I finally took it out this year for some Fast Taxi testing and a couple of crow hops. I found it was better to fly the pattern than it was to crow hop it. The one thing I have been having difficulty with is it tends to be tail-heavy at about 80mph ias. As I come in for landing, I can reduce some of the pressure on the forward stick due to the diminishing air speed. Boyd Y. and I changed the adjustment position of the flaps in hopes this would help it cruse =9Chands free=9D or relatively stable flight. Currently when I let off the forward pressure on the stick, it starts to climb right away. I have read some previous postings by John H. regarding =9Cnose heavy=9D. His writings indicate the Kolb designed to fly as they are and do not require aggressive trimming. If anyone has had a similar experience with the Mark III appearing to fly tail heavy, and you have been able to resolve the issue, let me know what you did. Thanks, Kurt Mark III C Sandy, Utah get="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Rebuilding/modifying my main gear
Date: Apr 11, 2015
Couple weeks ago carried my main gear and gear legs to London, KY, to let the Kolb boys do some work on them. After some hard landings, some extremely hard, a bent a drag strut on the left main gear. Brother Jim suggested adding a 4130 sheet web to help keep the braces in column during my klutzy landings. Even after all these years I still have the ability to screw up pretty badly. Attached are a few before during and after photos of the gear and a few of the Kolb Gang. Brian and Helen met me in Chattanooga, TN, this morning with my new looking main gear. Thanks to all the guys at Kolb for your help. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Apr 11, 2015
Hi All I just looked in my airframe logbook and it says that if it is flown solo, the pilot must weigh at least 195 lbs. That is with the pizza cutter tail wheel. I am removing that one and installing one that weighs about twice as much. I have not run the numbers yet but I am guessing that the pilot will have to be well over 200 lbs to stay within limits. As far as the battery goes, on my snowmobile forum there is a lot of talk of light weight batteries that work well if it isn't real cold out. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440688#440688 ________________________________________________________________________________
Date: Apr 12, 2015
Trimming the ailerons and flaps up or down moves the center of pressure forward or aft on the wing. Droop them, and the center of pressure, (lift) moves back and the airplane becomes more nose heavy. Reflex them up and the center of pressure (lift) moves forward and the airplane becomes more tail heavy. That is why I modified my MKIII flap lever; so I could fine tune trim depending on passenger load. http://oh2fly.net/oldpoops/pg3.htm -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440696#440696 ________________________________________________________________________________
Date: Apr 12, 2015
I got one of those batteries, and it is awesome! Shorai Lithium Iron battery, 14 Amp Hour, 210 CCA, and weighs 1.5 pounds. That's right, 1.5 pounds. With that little weight, you won't have to do a great deal of reinforcing if you move it to the nose. http://oh2fly.net/oldpoops/pg9.htm -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440700#440700 ________________________________________________________________________________
Date: Apr 12, 2015
You'll have more weight in cable than battery if it is relocated to the nose. I think the numbers on a Kolb W&B weigh more than the actual "aft CG" problem. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Sunday, April 12, 2015 9:35 AM Subject: Kolb-List: Re: MK 111 rebuild --> I got one of those batteries, and it is awesome! Shorai Lithium Iron battery, 14 Amp Hour, 210 CCA, and weighs 1.5 pounds. That's right, 1.5 pounds. With that little weight, you won't have to do a great deal of reinforcing if you move it to the nose. http://oh2fly.net/oldpoops/pg9.htm -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440700#440700 ________________________________________________________________________________
Date: Apr 12, 2015
John I figure my battery cables are two-three feet longer attaching to my nose cone mounted battery than they would be if they were attached to the battery behind the seat. What size cables do you use. Figuring three feet of cable weighing more than a 12-14 lb battery, those must be mighty big cables. I also switched to a Lithium Iron battery (another brand also less than 2 lb) last summer. The cables are still less than half the weight of that battery. The two lb. battery and app one pound of cables still helps my weight and balance. Rick Neilsen Redrive VW powered MKIIIC On Sun, Apr 12, 2015 at 10:41 AM, John Hauck wrote: > > You'll have more weight in cable than battery if it is relocated to the > nose. > > I think the numbers on a Kolb W&B weigh more than the actual "aft CG" > problem. > > john h > mkIII > Titus, Alabama > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike > Sent: Sunday, April 12, 2015 9:35 AM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: MK 111 rebuild > > --> > > I got one of those batteries, and it is awesome! Shorai Lithium Iron > battery, 14 Amp Hour, 210 CCA, and weighs 1.5 pounds. > That's right, 1.5 pounds. With that little weight, you won't have to do a > great deal of reinforcing if you move it to the nose. > http://oh2fly.net/oldpoops/pg9.htm > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > There are two kinds of people: those who say to God, 'Thy will be done,' > and > those to whom God says, 'All right, then, have it your way.' > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440700#440700 > > ________________________________________________________________________________
Date: Apr 12, 2015
Hi Neil What size battery cable did you use? Yes Richard, that is the battery I was thinking of. Isn't it funny how many years ago when I was flying corporate we used NiCad batteries and every so often we totally discharged them and then recharged them. How theories have changed. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440726#440726 ________________________________________________________________________________
Date: Apr 12, 2015
Hi Neil What size battery cable did you use? Yes Richard, that is the battery I was thinking of. Isn't it funny how many years ago when I was flying corporate we used NiCad batteries and every so often we totally discharged them and then recharged them. How theories have changed. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440727#440727 ________________________________________________________________________________
Date: Apr 12, 2015
Wellreckon I should have put smiley faces on my post, or some such. Why would someone put the battery in the nose if it is not necessary? Why would someone put a 2 lb bat in the nose and run extra battery cable? Cost more, weighs more, and every inch means a little more voltage drop. Remember, my comments are for myself. I don't care what you all do with your airplanes. I find it amusing that folks add weight to the nose of a Kolb, but bust their ass to try and save a couple washers to reduce weight. ;-) This comment below goes right along with the subject above. Miss P'fer is on her newly overhauled gear. Brian did a super job of straightening the sagging twisted gear legs. She looks and sits like she did when she was new. Still have to put the seats back in, hook up the power pack for the Whelen Strobes, and replace a bunch of tie wraps that got cut to remove and replace the wheels, brakes, and gear legs. Never goes back together easy after it is cut apart and welded, but Dennis did a great job and I was able to get all the bolts back in. Sure feels good. Now I need some good weather to clean her up and do a lot of test flying, for me and the airplane. Forecast rain all week at hauck's holler. Plan to depart to Lakeland Monday, 20 April. Hope to see a bunch of you all down there. BTW: I don't know how much my battery weighs or how big the battery cables are, but I can pick them up with two hands if I grunt a little. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen Sent: Sunday, April 12, 2015 1:23 PM Subject: Re: Kolb-List: Re: MK 111 rebuild John I figure my battery cables are two-three feet longer attaching to my nose cone mounted battery than they would be if they were attached to the battery behind the seat. What size cables do you use. Figuring three feet of cable weighing more than a 12-14 lb battery, those must be mighty big cables. I also switched to a Lithium Iron battery (another brand also less than 2 lb) last summer. The cables are still less than half the weight of that battery. The two lb. battery and app one pound of cables still helps my weight and balance. Rick Neilsen Redrive VW powered MKIIIC On Sun, Apr 12, 2015 at 10:41 AM, John Hauck wrote: You'll have more weight in cable than battery if it is relocated to the nose. I think the numbers on a Kolb W&B weigh more than the actual "aft CG" problem. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Sunday, April 12, 2015 9:35 AM Subject: Kolb-List: Re: MK 111 rebuild --> I got one of those batteries, and it is awesome! Shorai Lithium Iron battery, 14 Amp Hour, 210 CCA, and weighs 1.5 pounds. That's right, 1.5 pounds. With that little weight, you won't have to do a great deal of reinforcing if you move it to the nose. http://oh2fly.net/oldpoops/pg9.htm -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440700#440700 -List" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - _blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 13, 2015
Mark III appearing to fly tail heavy>> Put it on the scales and check your figures. It may feel tail heavy because IT IS Pat From: B Young Sent: Sunday, April 12, 2015 12:56 AM Subject: Re: Kolb-List: Tail Heavy Can someone smarter than me explain adjusting aileron and flaps to eliminate having to push forward on the stick to fly level. (Out of trim feels tall heavy) VS Being tail heavy on the scales.... Boyd Y On Apr 11, 2015 1:33 PM, "K I" wrote: Greetings Group, After buying an older Mark III that needed a LOT of fixing, I finally took it out this year for some Fast Taxi testing and a couple of crow hops. I found it was better to fly the pattern than it was to crow hop it. The one thing I have been having difficulty with is it tends to be tail-heavy at about 80mph ias. As I come in for landing, I can reduce some of the pressure on the forward stick due to the diminishing air speed. Boyd Y. and I changed the adjustment position of the flaps in hopes this would help it cruse =9Chands free=9D or relatively stable flight. Currently when I let off the forward pressure on the stick, it starts to climb right away. I have read some previous postings by John H. regarding =9Cnose heavy=9D. His writings indicate the Kolb designed to fly as they are and do not require aggressive trimming. If anyone has had a similar experience with the Mark III appearing to fly tail heavy, and you have been able to resolve the issue, let me know what you did. Thanks, Kurt Mark III C Sandy, Utah get="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 13, 2015
Hi Larry, I know there are pilots in the States who regularly fly their planes at an all up weight which would be illegal here.Fine if you can get away with it (I suppose) Certainly if you did it here and had a crunch the insurers would not pay out if they could prove (and they can) that you were overweight on take off. In any case why have a plane straining all the time to keep you in the air when one with a bit more load carrying capacity, not to mention room, is available. Incidentally is that 250/260 lbs you mention dripping wet in the bathroom. If so think about the weight of your clothes, boots sandwiches, bottles of water etc. Don`t kid yourself. Cheers. Pat -----Original Message----- From: w0odi Sent: Tuesday, April 07, 2015 3:48 AM Subject: Kolb-List: 250# pilot to heavy to solo Kolbra? I am 6'2" guy that weighs in at 250 to 260 lbs range just wondering if I am to heavy to fly the Kolbra......I have been told that I am to heavy for this machine and the weight and balance would be to nose heavy with me. I am just curious cause I am considering buying one of these machines or something similar and just want your expertise on this issue.. Would I be better off with say a Mark III let me know what you all think about this. Thanks in advance Larry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440352#440352 ________________________________________________________________________________
Date: Apr 13, 2015
That is why I modified my MKIII flap lever; so I could fine tune trim depending on passenger load.>> Hi Richard. On my Challenger there were no separate ailerons and flaps. Both ailerons moved in unison for the trim. Winding them right down, from the cockpit, and they acted as flaps. This also made the nose heavy which suited me fine. If I was distracted on the approach I would rather the plane went faster than slowed up and stalled. With the ailerons `up`they acted as fine trim. A good simple sytem. Pat -----Original Message----- From: Richard Pike Sent: Sunday, April 12, 2015 2:43 PM Subject: Kolb-List: Re: Tail Heavy Trimming the ailerons and flaps up or down moves the center of pressure forward or aft on the wing. Droop them, and the center of pressure, (lift) moves back and the airplane becomes more nose heavy. Reflex them up and the center of pressure (lift) moves forward and the airplane becomes more tail heavy. That is why I modified my MKIII flap lever; so I could fine tune trim depending on passenger load. http://oh2fly.net/oldpoops/pg3.htm -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440696#440696 ________________________________________________________________________________
Date: Apr 13, 2015
pipercolt wrote: > Hi Neil > What size battery cable did you use? Yes Richard, that is the battery I was thinking of. Isn't it funny how many years ago when I was flying corporate we used NiCad batteries and every so often we totally discharged them and then recharged them. How theories have changed. > Bob I had a friend at a car sound system shop sell me some of this at a good price: http://www.americanbassusa.com/categories/power---speaker-wires.htm I have never seen large diameter wire like this before, it uses extremely small fine wires woven together, it is almost as limp as rope. I used 8 gauge, soldered the end fittings on and it seems to work fine. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440770#440770 ________________________________________________________________________________
Date: Apr 13, 2015
On 4/13/2015 8:47 AM, Richard Pike wrote: > > > pipercolt wrote: >> Hi Neil >> What size battery cable did you use? Yes Richard, that is the battery I was thinking of. Isn't it funny how many years ago when I was flying corporate we used NiCad batteries and every so often we totally discharged them and then recharged them. How theories have changed. >> Bob > > I had a friend at a car sound system shop sell me some of this at a good price: http://www.americanbassusa.com/categories/power---speaker-wires.htm > > I have never seen large diameter wire like this before, it uses extremely small fine wires woven together, it is almost as limp as rope. I used 8 gauge, soldered the end fittings on and it seems to work fine. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' > > That's how welding cable is made, with the bonus of having durable insulation that's probably a lot more fire resistant than the stuff on that speaker wire. Very common to see welding cable used for battery/starter wire in big...(sorry, John) heavier homebuilts. Available in various sizes from any local welding supply shop. Charlie ________________________________________________________________________________
Date: Apr 13, 2015
My MKIII must be an antique. I bought battery cable from Aircraft Spruce in 1991. It is aviation grade with a woven fabric chafe guard. Looked for battery cable at Aircraft Spruce before writing this post. They don't have anything that resembles the cable I am using. Guess it is a thing of the past. All they have is what looks like normal 4 and 8 ga cable. Could hand prop the 80 horse 912, although it was still risky and not easy to do because of the sharp edges of the blades. Hand propping the 912ULS is out of the question with higher compression ratio on top of the gear reduction. It is extremely important for me to be able to rely on battery start. Want to make sure I have a system that is going to perform and get stuck out in the boondocks somewhere. On occasion I have failed to turn off the Master Switch and run the battery down. If it gets near depletion the alternator will not pick up the charge. One year at Sun and Fun I had a helper turn on my Master Switch, or I accidentally hit the toggle switch with my toe getting out of the aircraft. I got a jump start to get home, but was not able to get the alternator to pick up the charge. I flew 425 miles with no electrical system. Radio was able to operate on its integral battery. GPS on its batteries. Lost all my electric engine instruments. All was well until I got to Headland, AL, to refuel. No one at the airport to help me. Could not shut the engine down. Was able to get close enough to the gas pump to get a chock with my foot, while I kept the aircraft from rolling away. Refueled hot, which I did most of the time in VN, and made the remainder of the flight back to Gantt IAP without incident. john h mkIII Titus, Alabama That's how welding cable is made, with the bonus of having durable insulation that's probably a lot more fire resistant than the stuff on that speaker wire. Very common to see welding cable used for battery/starter wire in big...(sorry, John) heavier homebuilts. Available in various sizes from any local welding supply shop. Charlie ________________________________________________________________________________
Date: Apr 13, 2015
Pat, My mk 3 with just me in it is at the aft limit of it's CG.If I use 1 notch of flap and higher power setting it will fly about level,but in rough air i t would pitch nose up and then return to level,kind of like riding over a w ake of a boat.With a passenger its perfect.I attached 2 rings to the passe nger floor and I strap in about 30 pounds of lead shot in a thick plastic l iner, then covered with a denim bag.That stops the wallow in rough air and fixes the trim issue.I'll probably get taken to task for using this method but it works.I was going to try raising the horizontal tail leading edge bu t never came up with a clean way to do it. G.Aman MK 3 C Jabiru 2200A 950 hrs -----Original Message----- From: Patrick Ladd <patrickjladd(at)hotmail.com> Sent: Mon, Apr 13, 2015 5:55 am Subject: Re: Kolb-List: Tail Heavy Mark III appearing to fly tail heavy>> Put it on the scales and check your figures. It may feel tail heavy bec ause IT IS Pat From: B Young Sent: Sunday, April 12, 2015 12:56 AM To: kolb-list(at)matronics.com Subject: Re: Kolb-List: Tail Heavy Can someone smarter than me explain adjusting aileron and flaps to eliminat e having to push forward on the stick to fly level. (Out of trim feels tall heavy) VS Being tail heavy on the scales.... Boyd Y On Apr 11, 2015 1:33 PM, "K I" < wrk2win4u(at)msn.com> wrote: Greetings Group, After buying an older Mark III that needed a LOT of fixing, I finally took it out this year for some Fast Taxi testing and a couple of crow hops. I fo und it was better to fly the pattern than it was to crow hop it. The one th ing I have been having difficulty with is it tends to be tail-heavy at abou t 80mph ias. As I come in for landing, I can reduce some of the pressure on the forward stick due to the diminishing air speed. Boyd Y. and I changed the adjustment position of the flaps in hopes this would help it cruse =9Chands free=9D or relatively stable flight. Currently when I let off the forward pressure on the stick, it starts to climb right away. I ha ve read some previous postings by John H. regarding =9Cnose heavy =9D. His writings indicate the Kolb designed to fly as they are and do n ot require aggressive trimming. If anyone has had a similar experience with the Mark III appearing to fly t ail heavy, and you have been able to resolve the issue, let me know what yo u did. Thanks, Kurt Mark III C Sandy, Utah get="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.ma tronics.com _blank">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics .com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums .matronics.com href="http://www.matronics.com/contribution">http://www.ma tronics.com/c = ________________________________________________________________________________
Date: Apr 13, 2015
Hard core John, hard core. Good on ya, do what you have to do. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440809#440809 ________________________________________________________________________________
Date: Apr 13, 2015
Thanks Richard for your last comment about hand propping the 582. I was just about to post that question. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440813#440813 ________________________________________________________________________________
Subject: Re: 250# pilot to heavy to solo Kolbra?
Date: Apr 14, 2015
patrickjladd(at)hotmail.c wrote: > Hi Larry, I know there are pilots in the States who regularly fly their > planes at an all up weight which would be illegal here.Fine if you can get > away with it (I suppose) Certainly if you did it here and had a crunch the > insurers would not pay out if they could prove (and they can) that you were > overweight on take off. In any case why have a plane straining all the time > to keep you in the air when one with a bit more load carrying capacity, not > to mention room, is available. Incidentally is that 250/260 lbs you mention > dripping wet in the bathroom. If so think about the weight of your clothes, > boots sandwiches, bottles of water etc. Don`t kid yourself. Cheers. > Pat > > -- Pat you have to remember that Larry would be flying solo and if he carried a passenger, that person would have to be within the weight limits for the Kolbra W&B. His max weight of 260 lbs is well within the weight limits for the Kolbra. I have 400 lbs and more with me and my wife flying and as you can see in the videos that it flies well. Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 28 years flying it Kolbra 912ULS N20386 350 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440844#440844 ________________________________________________________________________________
Date: Apr 14, 2015
I am the manufacturer of my airplane, a Hauck/Kolb MKIII. I decide on what the limitations are based on experience, design, and testing. Most of us Americans don't like the Feds telling us what we can and cannot do. I can assure you, my MKIII is been thoroughly tested and proven to be more than capable of any limitations I have imposed on it. Ain't it nice to do things your way once in a while, have it all down its Airworthiness Certificate, and all legal and above board. I did a 20 minute test flight this morning. The new gear legs performed great after three TO's and landings. Didn't have time to fly over to Wetumpka Airport and land on pavement, but it sure did nice on grass and cow crap. Yep, it's under the wing and on the horizontal tail. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Ralph B Sent: Tuesday, April 14, 2015 10:38 AM Subject: Kolb-List: Re: 250# pilot to heavy to solo Kolbra? patrickjladd(at)hotmail.c wrote: > Hi Larry, I know there are pilots in the States who regularly fly > their planes at an all up weight which would be illegal here.Fine if > you can get away with it (I suppose) Certainly if you did it here and > had a crunch the insurers would not pay out if they could prove (and > they can) that you were overweight on take off. In any case why have > a plane straining all the time to keep you in the air when one with a > bit more load carrying capacity, not to mention room, is available. > Incidentally is that 250/260 lbs you mention dripping wet in the > bathroom. If so think about the weight of your clothes, boots sandwiches, bottles of water etc. Don`t kid yourself. Cheers. > Pat > > -- Pat you have to remember that Larry would be flying solo and if he carried a passenger, that person would have to be within the weight limits for the Kolbra W&B. His max weight of 260 lbs is well within the weight limits for the Kolbra. I have 400 lbs and more with me and my wife flying and as you can see in the videos that it flies well. Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 28 years flying it Kolbra 912ULS N20386 350 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440844#440844 ________________________________________________________________________________
Date: Apr 14, 2015
John if I ever get one it will be landed in the pasture and will have cow crap on it too...so just slinging a little money on the wings and tail... :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440850#440850 ________________________________________________________________________________
Date: Apr 14, 2015
I do my best landings at my 700 foot grass strip that has difficult approaches, landing NW or SE. Lots of 100 foot hardwoods to get over, then let the bottom drop out, hold 50 mph and grease it in. The opposite direction have to get over a high hedge row and make a 45 degree turn on short, short final. The bigger the airport and the more runway I have, the worst landings I will make. Think it is psychological. My last landing this morning I hit a fresh one. When they have been eating all this new crop green grass, it goes in one in and squirts out the other. When it dries it is like epoxy. We got about 100 head of new cows the last couple days. They haven't learned the routine yet. The old cows were born and raised around my airplane and noisy tractors. They don't pay much attention to any of them except when they want to irritate me. They all love to feed and crap on my airstrip. Will start piling my camping gear in a pile on the living room floor and check off my equipment list. All I got to do now is clean up Miss P'fer and top her off with fuel. Then do a little rain dance so I'll have good weather Monday to fly to Lakeland. It is 425 sm. Normally takes me 5.0 hours flight time, but have done it in 4.0 when I could snag a good tailwind. Hope to see a bunch of you guys down there. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of w0odi Sent: Tuesday, April 14, 2015 3:52 PM Subject: Kolb-List: Re: 250# pilot to heavy to solo Kolbra? John if I ever get one it will be landed in the pasture and will have cow crap on it too...so just slinging a little money on the wings and tail... :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440850#440850 ________________________________________________________________________________
Date: Apr 14, 2015
Subject: Sun N Fun Latex Paint Forum Cancelled
I regret that I will have to cancel the Latex Paint forum for Sun N Fun. My ride from PA had a foot operation and will not be able to go, and going on my own is a little too pricey right now. I will be at Oshkosh and hope to see some of you there on July. Malcolm Morrison www.wienerdogaero.com ________________________________________________________________________________
Date: Apr 15, 2015
Most of us Americans don't like the Feds telling us what we can and cannot do>> No argument there John although the Americans seem to have a more aggressive streak of independence than we do. Trouble is that the more people you have in a small space the more organisation/ interference is need. Boy! Hove we got a lot of people in a small space That cow crap is OK if you pick it up landing.It doesn`t have time to go hard. If you pick it up on takeoff its like concrete when you land. Out with the bucket. You would love our Wx at the moment. Nearly three weeks of more or less wall to wall sunshine and clear skies. Little or no wind.Good viz. Skies are so clear that I have seen the Space Station go over for the last four nights. Pat . -----Original Message----- From: John Hauck Sent: Tuesday, April 14, 2015 8:33 PM Subject: RE: Kolb-List: Re: 250# pilot to heavy to solo Kolbra? I am the manufacturer of my airplane, a Hauck/Kolb MKIII. I decide on what the limitations are based on experience, design, and testing. Most of us Americans don't like the Feds telling us what we can and cannot do. I can assure you, my MKIII is been thoroughly tested and proven to be more than capable of any limitations I have imposed on it. Ain't it nice to do things your way once in a while, have it all down its Airworthiness Certificate, and all legal and above board. I did a 20 minute test flight this morning. The new gear legs performed great after three TO's and landings. Didn't have time to fly over to Wetumpka Airport and land on pavement, but it sure did nice on grass and cow crap. Yep, it's under the wing and on the horizontal tail. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Ralph B Sent: Tuesday, April 14, 2015 10:38 AM Subject: Kolb-List: Re: 250# pilot to heavy to solo Kolbra? patrickjladd(at)hotmail.c wrote: > Hi Larry, I know there are pilots in the States who regularly fly > their planes at an all up weight which would be illegal here.Fine if > you can get away with it (I suppose) Certainly if you did it here and > had a crunch the insurers would not pay out if they could prove (and > they can) that you were overweight on take off. In any case why have > a plane straining all the time to keep you in the air when one with a > bit more load carrying capacity, not to mention room, is available. > Incidentally is that 250/260 lbs you mention dripping wet in the > bathroom. If so think about the weight of your clothes, boots sandwiches, bottles of water etc. Don`t kid yourself. Cheers. > Pat > > -- Pat you have to remember that Larry would be flying solo and if he carried a passenger, that person would have to be within the weight limits for the Kolbra W&B. His max weight of 260 lbs is well within the weight limits for the Kolbra. I have 400 lbs and more with me and my wife flying and as you can see in the videos that it flies well. Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 28 years flying it Kolbra 912ULS N20386 350 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440844#440844 ________________________________________________________________________________
Date: Apr 15, 2015
Date: Apr 15, 2015
Hi Ralph. Rules here are Single seater MTOW 661lbs Two seater 992 lbs MTOW This is properly weighed as for C of G, full fuel etc. Done by test pilot on renewal of annual C of A, but only about every 5 years.(Planes seem to get naturally heavier with time) Plane must stall at MTOW at 40 mph We also have a sort of superlight category which operates under hardly any rules at all except the all up weight.It is so low that it never interested me and the planes look to be a bit of a handful in very moderate conditions. Fun though. There is a very pretty Fokker Eindecker about which is beautiful. Pat Pat you have to remember that Larry would be flying solo and if he carried a passenger, that person would have to be within the weight limits for the Kolbra W&B. His max weight of 260 lbs is well within the weight limits for the Kolbra. I have 400 lbs and more with me and my wife flying and as you can see in the videos that it flies well. Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 1000+ hours 28 years flying it Kolbra 912ULS N20386 350 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440844#440844 ________________________________________________________________________________
Date: Apr 15, 2015
zeprep251(at)aol.com wrote: > Pat, > I was going to try raising the horizontal tail leading edge but never came up with a clean way to do it. > G.Aman MK 3 C Jabiru 2200A 950 hrs > -- Here is a semi-clean way to do it: http://oh2fly.net/oldpoops/FSIIelevatorbracket.html -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440907#440907 ________________________________________________________________________________
Date: Apr 16, 2015
Subject: Tail feathers for a Kolb
Kolbers: I have the tail feathers (rudder, elevators and stabilizers) for a small Kolb of some Sort. It has the small "pizza cutter" tail wheel." Anyone that is interested or might need these can respond to me using BG285P(at)yahoo.com. I have attempted to attach three photos. B Green Kolb MKIIIX w/VW engine project. ________________________________________________________________________________
Date: Apr 16, 2015
Subject: FW: Tail feathers for a Kolb
Hope these come through. Subject: Tail feathers for a Kolb Kolbers: I have the tail feathers (rudder, elevators and stabilizers) for a small Ko lb of some Sort. It has the small "pizza cutter" tail wheel." Anyone that is interes ted or might need these can respond to me using BG285P(at)yahoo.com. I have attempted to attach three photos. B Green Kolb MKIIIX w/VW engine project. ________________________________________________________________________________
Date: Apr 16, 2015
Bob: Photos didn't come through. I have good luck sending photos to the List by copying and pasting to the msg portion of the email. john h mkIII Titus, Alabama Kolbers: I have the tail feathers (rudder, elevators and stabilizers) for a small Kolb of some Sort. It has the small "pizza cutter" tail wheel." Anyone that is interested or might need these can respond to me using BG285P(at)yahoo.com. I have attempted to attach three photos. B Green Kolb MKIIIX w/VW engine project. ________________________________________________________________________________
Subject: Static Port Tuning
Date: Apr 16, 2015
I was a little surprised that during the first flight after replacing my nose cone that my MKIII would only do about 50 knots indicated. I really didn't think that modifying the nose shape should hurt me that much. Checking with GPS told me I was correct and something was off with my airspeed indication. After messing around with it a bit and trying several things it became clear that I had changed the pressure around the static port by modifying the nose. I was about to change the position or put in another port altogether when I came across this article. This will probably be old news to some of you but it was interesting to me. Particularly the part on 'tuning' the static port using a rubber 'O' ring. I tried it and it works great. Took a couple of tries to get it positioned right but I now go just as fast (unfortunately not much if any faster) than I used to. The link is here: http://www.ch601.org/resources/pitot-static/pitot.htm The tuning portion is quoted below and assumes a tube type static port with holes drilled in the sides. "If your airspeed reading is slow, it is because the static port is in a slight high pressure zone. This can be corrected by slipping a small "O" ring over the end of the static tube ahead of the tiny drilled holes (vents, that is). Moving the "O" ring aft on the tube (in very small increments) will increase the airspeed - on the gauge (not for the airplane, amigo . . . sorry). Conversely, moving the "O" ring forward, away from the ports, will decrease the indicated airspeed in much the same manner. Very small changes in the "O" ring position make a noticeable difference in the indications. What happens is that you are attempting to lower the static pressure "felt" by the static ports with the "O" ring interrupting the airflow, thereby causing a slight lowering in air pressure behind (downstream) the ring. The closer the ring is to the ports, the lower the induced pressure. If on the other hand the static-tube port happens to be located in an area of low pressure, moving the ring to a position behind the ports should provide a slight increase in the pressure felt by the static ports with results opposite to that described above. Because a rubber "O" ring will deteriorate, it should be replaced with a metal ring having identical dimensions after the proper location is determined. A dab of paint or epoxy should hold it in place." Thanks, Allan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440927#440927 ________________________________________________________________________________
Date: Apr 16, 2015
Subject: Re: Static Port Tuning
Your tuning is very interesting. Another thing that you might do is to cut your pitot tube at about a 45 degree angle. That matched my speed to the actual speed reading, it also keeps it from being blanked out by angle of attack. Larry On Thu, Apr 16, 2015 at 1:49 PM, Larlaeb wrote: > > I was a little surprised that during the first flight after replacing my > nose cone that my MKIII would only do about 50 knots indicated. I really > didn't think that modifying the nose shape should hurt me that much. > Checking with GPS told me I was correct and something was off with my > airspeed indication. After messing around with it a bit and trying several > things it became clear that I had changed the pressure around the static > port by modifying the nose. I was about to change the position or put in > another port altogether when I came across this article. This will > probably be old news to some of you but it was interesting to me. > Particularly the part on 'tuning' the static port using a rubber 'O' ring. > I tried it and it works great. Took a couple of tries to get it positioned > right but I now go just as fast (unfortunately not much if any faster) than > I used to. > > The link is here: > > http://www.ch601.org/resources/pitot-static/pitot.htm > > The tuning portion is quoted below and assumes a tube type static port > with holes drilled in the sides. > > "If your airspeed reading is slow, it is because the static port is in a > slight high pressure zone. This can be corrected by slipping a small "O" > ring over the end of the static tube ahead of the tiny drilled holes > (vents, that is). > > Moving the "O" ring aft on the tube (in very small increments) will > increase the airspeed - on the gauge (not for the airplane, amigo . . . > sorry). Conversely, moving the "O" ring forward, away from the ports, will > decrease the indicated airspeed in much the same manner. Very small changes > in the "O" ring position make a noticeable difference in the indications. > > What happens is that you are attempting to lower the static pressure > "felt" by the static ports with the "O" ring interrupting the airflow, > thereby causing a slight lowering in air pressure behind (downstream) the > ring. > > The closer the ring is to the ports, the lower the induced pressure. > > If on the other hand the static-tube port happens to be located in an area > of low pressure, moving the ring to a position behind the ports should > provide a slight increase in the pressure felt by the static ports with > results opposite to that described above. > > Because a rubber "O" ring will deteriorate, it should be replaced with a > metal ring having identical dimensions after the proper location is > determined. A dab of paint or epoxy should hold it in place." > > Thanks, > Allan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440927#440927 > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Apr 16, 2015
Putting the angle on the front of the pitot tube is something I had already read about from you and others on the forum and I've had that in place for a good while now. Good stuff. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440932#440932 ________________________________________________________________________________
Date: Apr 16, 2015
I did a similar thing in wrapping black tape around the static tube just aft of the static holes to create a higher pressure zone over the static port. Do not archive Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA > On Apr 16, 2015, at 3:49 PM, Larlaeb wrote: > > > I was a little surprised that during the first flight after replacing my nose cone that my MKIII would only do about 50 knots indicated. I really didn't think that modifying the nose shape should hurt me that much. Checking with GPS told me I was correct and something was off with my airspeed indication. After messing around with it a bit and trying several things it became clear that I had changed the pressure around the static port by modifying the nose. I was about to change the position or put in another port altogether when I came across this article. This will probably be old news to some of you but it was interesting to me. Particularly the part on 'tuning' the static port using a rubber 'O' ring. I tried it and it works great. Took a couple of tries to get it positioned right but I now go just as fast (unfortunately not much if any faster) than I used to. > > The link is here: > > http://www.ch601.org/resources/pitot-static/pitot.htm > > The tuning portion is quoted below and assumes a tube type static port with holes drilled in the sides. > > "If your airspeed reading is slow, it is because the static port is in a slight high pressure zone. This can be corrected by slipping a small "O" ring over the end of the static tube ahead of the tiny drilled holes (vents, that is). > > Moving the "O" ring aft on the tube (in very small increments) will increase the airspeed - on the gauge (not for the airplane, amigo . . . sorry). Conversely, moving the "O" ring forward, away from the ports, will decrease the indicated airspeed in much the same manner. Very small changes in the "O" ring position make a noticeable difference in the indications. > > What happens is that you are attempting to lower the static pressure "felt" by the static ports with the "O" ring interrupting the airflow, thereby causing a slight lowering in air pressure behind (downstream) the ring. > > The closer the ring is to the ports, the lower the induced pressure. > > If on the other hand the static-tube port happens to be located in an area of low pressure, moving the ring to a position behind the ports should provide a slight increase in the pressure felt by the static ports with results opposite to that described above. > > Because a rubber "O" ring will deteriorate, it should be replaced with a metal ring having identical dimensions after the proper location is determined. A dab of paint or epoxy should hold it in place." > > Thanks, > Allan > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440927#440927 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 17, 2015
Subject: Re: Kolb-List Digest: 7 Msgs - 04/16/15
VGhlIHRhaWwgZmVhdGhlcnMgaGF2ZSBiZWVuIHNwb2tlbiBmb3Igbm93LiAgVGhhbmtzLg0KQkdy ZWVuDQpta0lJSVgNCg= ________________________________________________________________________________
Date: Apr 17, 2015
Larry.. I am guessing that cutting your pitot at a 45 lowers your indicated airspeed? and to keep from being blanked out by angle of attack... again I assume the top is left long and the bottom is shortened. boyd >>>>>>>>>>>> Your tuning is very interesting. Another thing that you might do is to cut your pitot tube at about a 45 degree angle. That matched my speed to the actual speed reading, it also keeps it from being blanked out by angle of attack. Larry --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com ________________________________________________________________________________
Date: Apr 17, 2015
On Fri, Apr 17, 2015 at 8:04 AM, b young wrote: > > Larry.. I am guessing that cutting your pitot at a 45 lowers your > indicated airspeed? and to keep from being blanked out by angle of > attack... again I assume the top is left long and the bottom is shortened. > > boyd > > >>>>>>>>>>>>> Actually the speed was reading too slow by about 5MPH. After > cutting a bit at a time, the speed began matching my GPS readings, and yes > although I am generally too busy to watch the ASI on landing, it does not > now get blanked out. I would "assume" that the angled cut allows more air > pressure to get it into the tube, thus showing a faster speed on the ASI. > Larry -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Parts needed
Date: Apr 17, 2015
Does anyone by chance have a 5 inch spar tube unused , for my original twinstar? I also need gear legs .Any help or advise appreciated Reply offline ________________________________________________________________________________
Subject: RE: Kolb-List Digest: 4 Msgs - 04/17/15
Date: Apr 18, 2015
> Larry.. I am guessing that cutting your pitot at a 45 lowers your > indicated airspeed? I am wondering if these various fixes yield a linear response? ________________________________________________________________________________
Subject: tube
Date: Apr 18, 2015
> Does anyone by chance have a 5 inch spar tube unused I don't know fer sure about the diameter, but an old aviator I know has a large new tube in his rafters he wants to sell. I will email this msg to him, see if he responds. ________________________________________________________________________________
Subject: Steam gauge brass insert fix
Date: Apr 18, 2015
For those of you still using steam gauges, especially the ones like in the picture below, you might save yourself a lot of grief if - before you install them - you mix up a little JB Quick and carefully dab it around the outside of the 4 brass inserts that hold the gauge together, that are threaded for the retaining screws. You want to bond the insert tightly to the gauge w/o getting any epoxy on the threads. Obviously you do this on the back side. Because after 18 years, that brass insert might corrode and cleave itself tightly to the screw, and then when you try and remove the screw, instead of the screw coming out, the insert spins in the gauge. Which results in fighting with it for over an hour while in a position way too awkward for an old man. Guess how I know this? -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440976#440976 Attachments: http://forums.matronics.com//files/westach_small_203.jpg ________________________________________________________________________________
Date: Apr 18, 2015
Good advice Richard. Also, a drop of oil on the threads, or better yet a tiny amount of anti-seize compound will help stop galvanic action between the dissimilar metals of the screw and nut. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Saturday, April 18, 2015 1:11 PM Subject: Kolb-List: Steam gauge brass insert fix --> For those of you still using steam gauges, especially the ones like in the picture below, you might save yourself a lot of grief if - before you install them - you mix up a little JB Quick and carefully dab it around the outside of the 4 brass inserts that hold the gauge together, that are threaded for the retaining screws. You want to bond the insert tightly to the gauge w/o getting any epoxy on the threads. Obviously you do this on the back side. Because after 18 years, that brass insert might corrode and cleave itself tightly to the screw, and then when you try and remove the screw, instead of the screw coming out, the insert spins in the gauge. Which results in fighting with it for over an hour while in a position way too awkward for an old man. Guess how I know this? -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440976#440976 Attachments: http://forums.matronics.com//files/westach_small_203.jpg ________________________________________________________________________________
Subject: RE: Tubes
Date: Apr 19, 2015
> Does anyone by chance have a 5 inch spar tube unused GeoB's friend: "George, I have 3 20 foot 5" tubes all for sale. feel free to give my phone numbers to interested party. Tubes would have to be picked up in Fresno, freight may be costly." GeoB: "Email me for phone numbers gab16(at)sbcglobal.net ________________________________________________________________________________
Date: Apr 19, 2015
Subject: 5 inch spar tube price per foot...
I have a 5 inch boom tube for Kolbs... wondering what Travis gets a foot.. ? Thanks to Bob Green for the Firestar Tail feathers.... Now have a set of rebuilt Firestar wings, thanks to Bro Pike... ...and Tail feathers....looking for a re build able fuselage..preferably single seater...but will take a two seater.. have a 447 for the project...and looking to trade a c box that has new bearings and seals but still needs some small parts..to trade for a good b box...2.58 preferred... By the way Bob , down in the Chattanooga area has done a super job on his MkIII extra... excellent fabric work on the wings...git er dun ...Bob!! :-) ________________________________________________________________________________
Date: Apr 19, 2015
Subject: Re: 5 inch spar tube price per foot...
On Sun, Apr 19, 2015 at 7:13 PM, Herb wrote: > > I have a 5 inch boom tube for Kolbs... wondering what Travis gets a > foot.. ? > > > Thanks to Bob Green for the Firestar Tail feathers.... Now have a set of > rebuilt Firestar wings, thanks to Bro Pike... ...and Tail > feathers....looking for a re build able fuselage..preferably single > seater...but will take a two seater.. > > have a 447 for the project...and looking to trade a c box that has new > bearings and seals but still needs some small parts..to trade for a good b > box...2.58 preferred... > > > By the way Bob , down in the Chattanooga area has done a super job on > his MkIII extra... excellent fabric work on the wings...git er dun > ...Bob!! :-) > > Are you sure that you wouldn't like a nice 503 to go on it instead? I just > happen to have one. > Larry > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Apr 19, 2015
Could get interested in the engine you replaced the 503 with!! :-) How is the HKS working out? Herb On 04/19/2015 09:17 PM, Larry Cottrell wrote: > > > On Sun, Apr 19, 2015 at 7:13 PM, Herb > wrote: > > > > > I have a 5 inch boom tube for Kolbs... wondering what Travis > gets a foot.. ? > > > Thanks to Bob Green for the Firestar Tail feathers.... Now have > a set of rebuilt Firestar wings, thanks to Bro Pike... ...and Tail > feathers....looking for a re build able fuselage..preferably > single seater...but will take a two seater.. > > have a 447 for the project...and looking to trade a c box that > has new bearings and seals but still needs some small parts..to > trade for a good b box...2.58 preferred... > > > By the way Bob , down in the Chattanooga area has done a super > job on his MkIII extra... excellent fabric work on the wings...git > er dun ...Bob!! :-) > > Are you sure that you wouldn't like a nice 503 to go on it > instead? I just happen to have one. > > Larry > > > ========== > -List" target="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > FORUMS - > _blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > target="_blank">http://www.matronics.com/contribution > ========== > > > -- > /If you forward this email, or any part of it, please remove my email > address before sending./ > * > > > * ________________________________________________________________________________
Date: Apr 19, 2015
On Sun, Apr 19, 2015 at 9:03 PM, Herb wrote: > Could get interested in the engine you replaced the 503 with!! :-) How > is the HKS working out? Herb > > >> The HKS is running well, especially now that I have done a little stream lining, or actually vortex minimizing. I am getting in the low to mid 70's with it. You too can run one for about 11 or 12 K :-) I decided to go for the long haul. It should be the last engine that I have to buy. Larry > >> > > > -- > *If you forward this email, or any part of it, please remove my email > address before sending.* > > > * > > > * > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Sun and Fun 2015
Date: Apr 21, 2015
Hi Folks: Out the door and heading to the airstrip. Hope to be off the ground by 0630 CT. Should arrive KLAL before 1400 ET, which is when the field closes for the daily air show. If I don't make it by 1400, I'll have to wait until after 1730 ET to land at Paradise City. I've done that before. Got about 415 sm and 5.0 flight hours. Miss P'fer is already fueled and loaded. Did that last night. Expected temps in the low 60's this morning, but got low 50's with the temps going down instead of up. It has dropped 3 or 4 degrees since I got up at 0400. Route of flight Titus, AL to Blakely, GA, to Cross City, FL, and Lakeland, FL. Hope to see some of you down there. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Apr 21, 2015
Subject: Re: Sun and Fun 2015
Fair winds John have a safe trip Chris=0A=0ASent from Yahoo Mail on Android =0A=0AFrom:"John Hauck" =0ADate:Tue, Apr 21, 2015 at 6:59 AM=0ASubject:Kolb-List: Sun and Fun 2015=0A=0A--> Kolb-List message po sted by: "John Hauck" =0A=0AHi Folks:=0A=0AOut the do or and heading to the airstrip.- Hope to be off the ground by 0630=0ACT. - Should arrive KLAL before 1400 ET, which is when the field closes for =0Athe daily air show.- If I don't make it by 1400, I'll have to wait unt il=0Aafter 1730 ET to land at Paradise City.- I've done that before.=0A =0AGot about 415 sm and 5.0 flight hours.=0A=0AMiss P'fer is already fueled and loaded.- Did that last night.=0A=0AExpected temps in the low 60's th is morning, but got low 50's with the temps=0Agoing down instead of up.- It has dropped 3 or 4 degrees since I got up at=0A0400.=0A=0ARoute of fligh t Titus, AL to Blakely, GA, to Cross City, FL, and Lakeland,=0AFL.=0A=0AHop e to see some of you down there.=0A=0Ajohn h=0AmkIII=0ATitus, Alabama=0A=0A ==============0A=0A=0A=0A ________________________________________________________________________________
Date: Apr 21, 2015
On Tue, Apr 21, 2015 at 5:55 AM, John Hauck wrote: > > Hi Folks: > > Out the door and heading to the airstrip. Hope to be off the ground by > 0630 > CT. Should arrive KLAL before 1400 ET, which is when the field closes for > the daily air show. If I don't make it by 1400, I'll have to wait until > after 1730 ET to land at Paradise City. I've done that before. > > Got about 415 sm and 5.0 flight hours. > > Miss P'fer is already fueled and loaded. Did that last night. > > Expected temps in the low 60's this morning, but got low 50's with the > temps > going down instead of up. It has dropped 3 or 4 degrees since I got up at > 0400. > > Route of flight Titus, AL to Blakely, GA, to Cross City, FL, and Lakeland, > FL. > > Hope to see some of you down there. > > john h > mkIII > Titus, Alabama > > I wish, but it's not happening for me this year. Charlie ________________________________________________________________________________
Date: Apr 21, 2015
Hi Folks: Miss P'fer got 18.1 gal 100LL and I got two free hot dogs at Cross City, FL. 3.4 hours from Gantt IAP is pretty good in a fat ultralight. I'll be at Lakeland in about 1.5 hours. Brian Milborn said the crowd was down, but that is not unusual the first day. Normally I have to wait to get fuel here at Cross City. One airplane here when I landed. Weather is great. I have had a ground speed from 88 to 105 mph. I love a tailwind. If nothing happens, I'll make KLAL before the airshow begins at 1400 ET. john h mkIII Cross City, Florida ---- John Hauck wrote: > > Hi Folks: > > Out the door and heading to the airstrip. Hope to be off the ground by 0630 > CT. Should arrive KLAL before 1400 ET, which is when the field closes for > the daily air show. If I don't make it by 1400, I'll have to wait until > after 1730 ET to land at Paradise City. I've done that before. > > Got about 415 sm and 5.0 flight hours. > > Miss P'fer is already fueled and loaded. Did that last night. > > Expected temps in the low 60's this morning, but got low 50's with the temps > going down instead of up. It has dropped 3 or 4 degrees since I got up at > 0400. > > Route of flight Titus, AL to Blakely, GA, to Cross City, FL, and Lakeland, > FL. > > Hope to see some of you down there. > > john h > mkIII > Titus, Alabama > > > > > ________________________________________________________________________________
Subject: Rebuild parts
Date: Apr 21, 2015
I=99ve had good help finding needed materials for my wing rebuild so far. I thought I=99d try the list for a couple of more requests. Anybody have enough fabric left from other jobs to cover the wing and aleron of a twinstar? Need about 30 ft of 72 inch light 1.7 ceconite . Also need 12 ft. of leading edge 1 1/2 in. .028 tube and and 12 ft of trailing edge 1 1/4 .028 tube.Thanks for checking. Jerry ________________________________________________________________________________
Subject: Fwd: Kolb-List Digest: 0 Msgs - 04/22/15
Date: Apr 23, 2015
List Can someone tell me where I can buy the little fuel fillers that fit over then intake fuel line, inside the fuel tank? Called finger-filters sometimes? Id appreciate that Russ K ________________________________________________________________________________
Subject: Re: Fwd: Kolb-List Digest: 0 Msgs - 04/22/15
Date: Apr 23, 2015
Aircraft Spruce has them Dennis "Skid" Rowe Mk3, Rotax 670, Leechburg, PA > On Apr 23, 2015, at 10:42 AM, kinne russ wrote: > > > > List > Can someone tell me where I can buy the little fuel fillers that fit over then intake fuel line, inside the fuel tank? > Called finger-filters sometimes? > Id appreciate that > Russ K > > > > ________________________________________________________________________________
Date: Apr 23, 2015
Russ, If there is a hobby shop any where near you, check and see if they have them. I used to use them for the fuel tanks for my radio controlled models. Larry On Thu, Apr 23, 2015 at 8:42 AM, kinne russ wrote: > > > List > Can someone tell me where I can buy the little fuel fillers that fit over > then intake fuel line, inside the fuel tank? > Called =98finger-filters=99 sometimes? > I=99d appreciate that > Russ K > =========== =========== =========== =========== > > -- *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: second chantz chutes
Date: Apr 24, 2015
Anyone used them in recent years? I cant find anything on the internet except some 5 year old posts on a website. Difficult to reach them via phone as well. Just wondering... -------- 1984 kolb ultrstar Former 1997 kolb firestat Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441227#441227 ________________________________________________________________________________
Date: Apr 24, 2015
Subject: Kolb Firestar parts
Kolbers and Kolbettes.... with the collection of Free Firestar parts...I now have a good , rebuilt set of wings...and Tail feathers...so...need a repairable Fuselage...Herb ________________________________________________________________________________
Subject: Firefly/447 RPM question
Date: Apr 24, 2015
Guys, Here is a question for those that have a Firefly with a Rotax 447. Assuming a properly dialed in propeller with a static full throttle output of 6300 RPM, what do you usually see at straight and level cruise RPM and speed? For that matter, if you have any information of what airspeeds to expect at different throttle settings (straight and level) I would appreciate knowing what others are seeing. I have been up a for a couple of short flights this spring and it seems to me that a comfortable airspeed is between 55 and 60 indicated, but that seems to be in the 4800 RPM range which is still giving me high EGT's. I moved the needle clip down (more rich) one notch and that helped a lot. Now when I get a warning at mid-range, I just add a little "choke" to take care of it. I expect this problem to go away with warmer temps, but may have to fuss with the pitch a little. I need MUCH more time in the air to sort this stuff all out, but the weather has not been cooperating very well. Any numbers you can give me for comparison/starting points would be appreciated. Thanks, Stuart ________________________________________________________________________________
Subject: Re: Firefly/447 RPM question
Date: Apr 24, 2015
It all depends on what size prop you have. And the drag of your craft. I find 4800rpms to be just about the hot spot for my EGTs also. 4600-4800. I try to stay out of that range. I usually cruise around about 5500-5800rpm which provides 53-58mph airspeed. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441248#441248 ________________________________________________________________________________
Date: Apr 24, 2015
Remember also...Stuart,,,that engine is not broken in...rings will seat in the 40+ hour range..temps usually drop...cht and egt... I cruised in the 5600 range and saw high 50's to low 60's using a three blade IVO..Herb On 04/24/2015 02:42 PM, olendorf wrote: > > It all depends on what size prop you have. And the drag of your craft. > I find 4800rpms to be just about the hot spot for my EGTs also. 4600-4800. I try to stay out of that range. I usually cruise around about 5500-5800rpm which provides 53-58mph airspeed. > > -------- > Scott Olendorf > Original Firestar, Rotax 447, Powerfin prop > Schenectady, NY > http://sites.google.com/site/kolbfirestar/ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=441248#441248 > > ________________________________________________________________________________
Date: Apr 24, 2015
Thanks Scott. I have a 3 blade 60" Warp Drive at 7.5 of pitch. The amount of drag is a little harder to figure. I have the short windshield, double struts, and the larger wheels with brakes. Less pitch will give more RPM but less thrust so that may be the way to go. There is no shortage of thrust, that's for sure! I need to go back and review to see if less pitch increases EGT or if I need a little more. I have had it up to 70 IAS in a descent and that seemed "uncomfortable" to me. Maybe I am just not used to it yet, but I really like the way it "feels" between 55 and 60. Someone else said "climb at 50, cruise at 50 and approach at 50" or something like that. So far that seems to fit. I didn't build it to travel with anyway. Your Firestar is slightly larger than the Firefly but if you have a full enclosure it may have about the same amount of drag as I do. Thanks again, Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of olendorf Sent: Friday, April 24, 2015 2:43 PM Subject: Kolb-List: Re: Firefly/447 RPM question It all depends on what size prop you have. And the drag of your craft. I find 4800rpms to be just about the hot spot for my EGTs also. 4600-4800. I try to stay out of that range. I usually cruise around about 5500-5800rpm which provides 53-58mph airspeed. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441248#441248 ________________________________________________________________________________
Date: Apr 24, 2015
Thanks Herb, Sounds like a mandate to go fly! Tiny Tack is currently showing 19, halfway there. The darned wind comes up with the sun and temps these days. I am sure after some time aloft, I will be able to handle more adverse conditions but at this stage of the game I don't need any more to deal with, so will wait. When you are a little kid at heart, waiting is sooooo HARD to do! Patience was my dad's virtue, not mine. GRRRR! I sure like the power (thrust) I am getting with the 447. Sometimes I wonder if it is overkill for the Firefly. Better to have it and not need it than need it and not have it. (True of most things in life) Thanks again, Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Herb Sent: Friday, April 24, 2015 5:18 PM Subject: Re: Kolb-List: Re: Firefly/447 RPM question Remember also...Stuart,,,that engine is not broken in...rings will seat in the 40+ hour range..temps usually drop...cht and egt... I cruised in the 5600 range and saw high 50's to low 60's using a three blade IVO..Herb On 04/24/2015 02:42 PM, olendorf wrote: > > It all depends on what size prop you have. And the drag of your craft. > I find 4800rpms to be just about the hot spot for my EGTs also. 4600-4800. I try to stay out of that range. I usually cruise around about 5500-5800rpm which provides 53-58mph airspeed. > > -------- > Scott Olendorf > Original Firestar, Rotax 447, Powerfin prop Schenectady, NY > http://sites.google.com/site/kolbfirestar/ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=441248#441248 > > ________________________________________________________________________________
Date: Apr 24, 2015
I bought the low time Firefly in Conn...pictures only...one of those impulse things....! January...no way to get it....then had buyers remorse...not because of the nice looking plane or nice trailer...just taking my ole bones on a 2000 mile round trip....so I sold...it.... :-) Hope to get back in the air before too long...Firestar this time maybe.? More local too! :-) 447 engine...not the 503 I hope...or a Firestar with no engine...for I have another 447...older model... single seater..project would be good...damaged cage ok..if not too bad... Herb On 04/24/2015 07:22 PM, Stuart Harner wrote: > > Thanks Herb, > > Sounds like a mandate to go fly! Tiny Tack is currently showing 19, halfway > there. > > The darned wind comes up with the sun and temps these days. I am sure after > some time aloft, I will be able to handle more adverse conditions but at > this stage of the game I don't need any more to deal with, so will wait. > > When you are a little kid at heart, waiting is sooooo HARD to do! > > Patience was my dad's virtue, not mine. GRRRR! > > I sure like the power (thrust) I am getting with the 447. Sometimes I wonder > if it is overkill for the Firefly. Better to have it and not need it than > need it and not have it. (True of most things in life) > > Thanks again, > > Stuart > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Herb > Sent: Friday, April 24, 2015 5:18 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: Firefly/447 RPM question > > > Remember also...Stuart,,,that engine is not broken in...rings will seat in > the 40+ hour range..temps usually drop...cht and egt... > > I cruised in the 5600 range and saw high 50's to low 60's using a three > blade IVO..Herb > > On 04/24/2015 02:42 PM, olendorf wrote: >> >> It all depends on what size prop you have. And the drag of your craft. >> I find 4800rpms to be just about the hot spot for my EGTs also. > 4600-4800. I try to stay out of that range. I usually cruise around about > 5500-5800rpm which provides 53-58mph airspeed. >> -------- >> Scott Olendorf >> Original Firestar, Rotax 447, Powerfin prop Schenectady, NY >> http://sites.google.com/site/kolbfirestar/ >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=441248#441248 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Apr 24, 2015
Herb Dunno if this is of any help to you but I have an open trailer, set up for a Kolb, that you can borrow anytime you need it but its in MAINE! Prolly 5-6 hrs north of CT. But youre welcome to use it Fair winds, Russ K > On Apr 24, 2015, at 8:43 PM, Herb wrote: > > > I bought the low time Firefly in Conn...pictures only...one of those impulse things....! January...no way to get it....then had buyers remorse...not because of the nice looking plane or nice trailer...just taking my ole bones on a 2000 mile round trip....so I sold...it.... :-) > > Hope to get back in the air before too long...Firestar this time maybe.? More local too! :-) 447 engine...not the 503 I hope...or a Firestar with no engine...for I have another 447...older model... single seater..project would be good...damaged cage ok..if not too bad... > > Herb > > On 04/24/2015 07:22 PM, Stuart Harner wrote: >> >> Thanks Herb, >> >> Sounds like a mandate to go fly! Tiny Tack is currently showing 19, halfway >> there. >> >> The darned wind comes up with the sun and temps these days. I am sure after >> some time aloft, I will be able to handle more adverse conditions but at >> this stage of the game I don't need any more to deal with, so will wait. >> >> When you are a little kid at heart, waiting is sooooo HARD to do! >> >> Patience was my dad's virtue, not mine. GRRRR! >> >> I sure like the power (thrust) I am getting with the 447. Sometimes I wonder >> if it is overkill for the Firefly. Better to have it and not need it than >> need it and not have it. (True of most things in life) >> >> Thanks again, >> >> Stuart >> >> -----Original Message----- >> From: owner-kolb-list-server(at)matronics.com >> [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Herb >> Sent: Friday, April 24, 2015 5:18 PM >> To: kolb-list(at)matronics.com >> Subject: Re: Kolb-List: Re: Firefly/447 RPM question >> >> >> Remember also...Stuart,,,that engine is not broken in...rings will seat in >> the 40+ hour range..temps usually drop...cht and egt... >> >> I cruised in the 5600 range and saw high 50's to low 60's using a three >> blade IVO..Herb >> >> On 04/24/2015 02:42 PM, olendorf wrote: >>> >>> It all depends on what size prop you have. And the drag of your craft. >>> I find 4800rpms to be just about the hot spot for my EGTs also. >> 4600-4800. I try to stay out of that range. I usually cruise around about >> 5500-5800rpm which provides 53-58mph airspeed. >>> -------- >>> Scott Olendorf >>> Original Firestar, Rotax 447, Powerfin prop Schenectady, NY >>> http://sites.google.com/site/kolbfirestar/ >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=441248#441248 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Apr 24, 2015
Maine? Isn't that near Greenland?? :-) Thanks for the offer...One more plane and I am out of the business for a while...Herb On 04/24/2015 08:13 PM, kinne russ wrote: > > Herb > Dunno if this is of any help to you but I have an open trailer, set up for a Kolb, that you can borrow anytime you need it but its in MAINE! > Prolly 5-6 hrs north of CT. But youre welcome to use it > Fair winds, > Russ K > > >> On Apr 24, 2015, at 8:43 PM, Herb wrote: >> >> >> I bought the low time Firefly in Conn...pictures only...one of those impulse things....! January...no way to get it....then had buyers remorse...not because of the nice looking plane or nice trailer...just taking my ole bones on a 2000 mile round trip....so I sold...it.... :-) >> >> Hope to get back in the air before too long...Firestar this time maybe.? More local too! :-) 447 engine...not the 503 I hope...or a Firestar with no engine...for I have another 447...older model... single seater..project would be good...damaged cage ok..if not too bad... >> >> Herb >> >> On 04/24/2015 07:22 PM, Stuart Harner wrote: >>> >>> Thanks Herb, >>> >>> Sounds like a mandate to go fly! Tiny Tack is currently showing 19, halfway >>> there. >>> >>> The darned wind comes up with the sun and temps these days. I am sure after >>> some time aloft, I will be able to handle more adverse conditions but at >>> this stage of the game I don't need any more to deal with, so will wait. >>> >>> When you are a little kid at heart, waiting is sooooo HARD to do! >>> >>> Patience was my dad's virtue, not mine. GRRRR! >>> >>> I sure like the power (thrust) I am getting with the 447. Sometimes I wonder >>> if it is overkill for the Firefly. Better to have it and not need it than >>> need it and not have it. (True of most things in life) >>> >>> Thanks again, >>> >>> Stuart >>> >>> -----Original Message----- >>> From: owner-kolb-list-server(at)matronics.com >>> [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Herb >>> Sent: Friday, April 24, 2015 5:18 PM >>> To: kolb-list(at)matronics.com >>> Subject: Re: Kolb-List: Re: Firefly/447 RPM question >>> >>> >>> Remember also...Stuart,,,that engine is not broken in...rings will seat in >>> the 40+ hour range..temps usually drop...cht and egt... >>> >>> I cruised in the 5600 range and saw high 50's to low 60's using a three >>> blade IVO..Herb >>> >>> On 04/24/2015 02:42 PM, olendorf wrote: >>>> >>>> It all depends on what size prop you have. And the drag of your craft. >>>> I find 4800rpms to be just about the hot spot for my EGTs also. >>> 4600-4800. I try to stay out of that range. I usually cruise around about >>> 5500-5800rpm which provides 53-58mph airspeed. >>>> -------- >>>> Scott Olendorf >>>> Original Firestar, Rotax 447, Powerfin prop Schenectady, NY >>>> http://sites.google.com/site/kolbfirestar/ >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=441248#441248 >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> > > ________________________________________________________________________________
Date: Apr 24, 2015
SGkgU3R1YXJ0LApUaGUgNDQ3IG9uIG15IEZpcmVGbHkgd2FzIHNldCBmb3IgNjIwMCBSUE1zIHNy YXRpYy4gQXQgNDgwMCBSUE1zIEkgZmVsdCBsaWtlIEkgd2FzIHBsb3dpbmcgdGhyb3VnaCB0aGUg YWlyLiBOb3Qgd3VpdGUgc2xvdyBmbHlpbmcgYnV0IGNsb3NlIHRvIGl0LiBXaGVuIEkgY3J1aXNl ZCBhdCA1MjAwIG15IGFpciBzcGVlZCB3YXMgNjUgLSA3MCBtcGggYW5kIGl0IGZlbHQgZ29vZCB0 aGVyZS7CoAoKVGhlIGFpciBzdHJpcCB3aGVyZSBJIGhhbmdhcmVkIG15IEZGIHdhc24ndCB0aGUg ZWFzaWVzdCBwbGFjZSB0byBsYW5kLiBZb3UgaGFkIHRvIGNsZWFyIHBvd2VyIGxpbmVzIHRoZW4g ZHJvcCBkb3duIGludG8gYSBndWxseSBiZXR3ZWVuIHRyZWVzIGFuZCBsYW5kIHVwaGlsbC4gSSBv ZnRlbiByYW4gZmluYWwgYmV0d2VlbiA2NSBhbmQgNzAgbXBoIGJlY2F1c2UgaGFuZGxpbmcgYW5k IGNvbnRyb2wgd2FzIGV4Y2VsbGVudCBhdCB0aGF0IHNwZWVkLiBKdXN0IHVzZSBjYXV0aW9uIGRy b3BwaW5nIHlvdXIgZmxhcGVyb25zIG92ZXIgNjUgbXBoLsKgCgpJZiBpdCB3b3VsZCBkbyB5b3Ug YW55IGdvb2QgSSBoYXZlIHNvbWUgdmlkZW9zIG9uIHlvdXR1YmUgdGFrZW4gd2l0aCBhICJoYXQg Y2FtIiB3aGVyZSB5b3UgY2FuIHNlZSBteSBhc2kgYW5kIHZzaS4gV2hlbiBJIGxvb2sgYXQgdGhl bSBJIGNhbiBmZWVsIHRoZSBzcGVlZCBhbmQgY29udHJvbCBpbnB1dHMuIE1heWJlIGl0IHdvdWxk bid0IHdvcmsgZm9yIHlvdSBidXQgaWYgeW91IHdhbnQgdG8gY2hlY2sgdGhlbSBvdXQgZ28gdG8g wqAgeW91dHViZS5jb20vdW5kb2N0b3IKCkZhaXIgd2luZHMgYW5kIGJsdWUgc2tpZXMuIEkgc3Vy ZSBkbyBtaXNzIG15IGJlbG92ZWQgRkYuwqAKCkRhdmUgS3VscApCZXRobGVoZW0sIFBBCgoKU2Vu dCBmcm9tIG15IFZlcml6b24gV2lyZWxlc3MgNEcgTFRFIHNtYXJ0cGhvbmUKCjxkaXY+LS0tLS0t LS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLTwvZGl2PjxkaXY+RnJvbTogU3R1YXJ0IEhhcm5l ciA8c3R1YXJ0QGhhcm5lcmZhcm0ubmV0PiA8L2Rpdj48ZGl2PkRhdGU6MDQvMjQvMjAxNSAgNjoz OCBQTSAgKEdNVC0wNTowMCkgPC9kaXY+PGRpdj5Ubzoga29sYi1saXN0QG1hdHJvbmljcy5jb20g PC9kaXY+PGRpdj5TdWJqZWN0OiBSRTogS29sYi1MaXN0OiBSZTogRmlyZWZseS80NDcgUlBNIHF1 ZXN0aW9uIDwvZGl2PjxkaXY+CjwvZGl2Pi0tPiBLb2xiLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6 ICJTdHVhcnQgSGFybmVyIiA8c3R1YXJ0QGhhcm5lcmZhcm0ubmV0PgoKVGhhbmtzIFNjb3R0LiBJ IGhhdmUgYSAzIGJsYWRlIDYwIiBXYXJwIERyaXZlIGF0IDcuNcKwIG9mIHBpdGNoLiBUaGUgYW1v dW50Cm9mIGRyYWcgaXMgYSBsaXR0bGUgaGFyZGVyIHRvIGZpZ3VyZS4gSSBoYXZlIHRoZSBzaG9y dCB3aW5kc2hpZWxkLCBkb3VibGUKc3RydXRzLCBhbmQgdGhlIGxhcmdlciB3aGVlbHMgd2l0aCBi cmFrZXMuCgpMZXNzIHBpdGNoIHdpbGwgZ2l2ZSBtb3JlIFJQTSBidXQgbGVzcyB0aHJ1c3Qgc28g dGhhdCBtYXkgYmUgdGhlIHdheSB0byBnby4KVGhlcmUgaXMgbm8gc2hvcnRhZ2Ugb2YgdGhydXN0 LCB0aGF0J3MgZm9yIHN1cmUhCgpJIG5lZWQgdG8gZ28gYmFjayBhbmQgcmV2aWV3IHRvIHNlZSBp ZiBsZXNzIHBpdGNoIGluY3JlYXNlcyBFR1Qgb3IgaWYgSSBuZWVkCmEgbGl0dGxlIG1vcmUuIAoK SSBoYXZlIGhhZCBpdCB1cCB0byA3MCBJQVMgaW4gYSBkZXNjZW50IGFuZCB0aGF0IHNlZW1lZCAi dW5jb21mb3J0YWJsZSIgdG8KbWUuICBNYXliZSBJIGFtIGp1c3Qgbm90IHVzZWQgdG8gaXQgeWV0 LCBidXQgSSByZWFsbHkgbGlrZSB0aGUgd2F5IGl0CiJmZWVscyIgYmV0d2VlbiA1NSBhbmQgNjAu CgpTb21lb25lIGVsc2Ugc2FpZCAiY2xpbWIgYXQgNTAsIGNydWlzZSBhdCA1MCBhbmQgYXBwcm9h Y2ggYXQgNTAiIG9yCnNvbWV0aGluZyBsaWtlIHRoYXQuICBTbyBmYXIgdGhhdCBzZWVtcyB0byBm aXQuICBJIGRpZG4ndCBidWlsZCBpdCB0byB0cmF2ZWwKd2l0aCBhbnl3YXkuCgpZb3VyIEZpcmVz dGFyIGlzIHNsaWdodGx5IGxhcmdlciB0aGFuIHRoZSBGaXJlZmx5IGJ1dCBpZiB5b3UgaGF2ZSBh IGZ1bGwKZW5jbG9zdXJlIGl0IG1heSBoYXZlIGFib3V0IHRoZSBzYW1lIGFtb3VudCBvZiBkcmFn IGFzIEkgZG8uCgpUaGFua3MgYWdhaW4sCgpTdHVhcnQKCgoKLS0tLS1PcmlnaW5hbCBNZXNzYWdl LS0tLS0KRnJvbTogb3duZXIta29sYi1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tClttYWlsdG86 b3duZXIta29sYi1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2Ygb2xlbmRv cmYKU2VudDogRnJpZGF5LCBBcHJpbCAyNCwgMjAxNSAyOjQzIFBNClRvOiBrb2xiLWxpc3RAbWF0 cm9uaWNzLmNvbQpTdWJqZWN0OiBLb2xiLUxpc3Q6IFJlOiBGaXJlZmx5LzQ0NyBSUE0gcXVlc3Rp b24KCi0tPiBLb2xiLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJvbGVuZG9yZiIgPG9sZW5kb3Jm QGdtYWlsLmNvbT4KCkl0IGFsbCBkZXBlbmRzIG9uIHdoYXQgc2l6ZSBwcm9wIHlvdSBoYXZlLiAg QW5kIHRoZSBkcmFnIG9mIHlvdXIgY3JhZnQuCkkgZmluZCA0ODAwcnBtcyB0byBiZSBqdXN0IGFi b3V0IHRoZSBob3Qgc3BvdCBmb3IgbXkgRUdUcyBhbHNvLiAgNDYwMC00ODAwLgpJIHRyeSB0byBz dGF5IG91dCBvZiB0aGF0IHJhbmdlLiAgSSB1c3VhbGx5IGNydWlzZSBhcm91bmQgYWJvdXQgNTUw MC01ODAwcnBtCndoaWNoIHByb3ZpZGVzIDUzLTU4bXBoIGFpcnNwZWVkLgoKLS0tLS0tLS0KU2Nv dHQgT2xlbmRvcmYKT3JpZ2luYWwgRmlyZXN0YXIsIFJvdGF4IDQ0NywgUG93ZXJmaW4gcHJvcCBT Y2hlbmVjdGFkeSwgTlkKaHR0cDovL3NpdGVzLmdvb2dsZS5jb20vc2l0ZS9rb2xiZmlyZXN0YXIv CgoKCgpSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6CgpodHRwOi8vZm9ydW1zLm1hdHJvbmlj cy5jb20vdmlld3RvcGljLnBocD9wPTQ0MTI0OCM0NDEyNDgKCgoKCgoKCgoKCgoKCl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8t PSAgICAgICAgICAtIFRoZSBLb2xiLUxpc3QgRW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRy b25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0 IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFy Y2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBh bmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29t L05hdmlnYXRvcj9Lb2xiLUxpc3QKXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9O SUNTIFdFQiBGT1JVTVMgLQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZp YSB0aGUgV2ViIEZvcnVtcyEKXy09Cl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5j b20KXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09Cl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRl IC0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEKXy09ICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgpfLT0gICAtLT4g aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQoKCgo ________________________________________________________________________________
Date: Apr 24, 2015
Hi Dave, Thanks, I will check out your videos. I have been considering getting a sports cam to record my flights so I can review them later. My hope is to be able to learn things that I was too busy to notice when in the air. Did you find video useful in that way? One of the many things I need to do is get some time aloft with my phone where I can see the GPS speedometer readout. by flying different routes and then again in reverse, I hope to get an idea at to the accuracy of the ASI. -------- "I don't care, I'm still free. You can't take the sky from me" - Josh Wedon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441273#441273 ________________________________________________________________________________
Date: Apr 25, 2015
stuart(at)harnerfarm.net wrote: > > ... > Less pitch will give more RPM but less thrust so that may be the way to go. > There is no shortage of thrust, that's for sure! > > I need to go back and review to see if less pitch increases EGT or if I need > a little more. > ..... > Stuart > > -- Less pitch will actually increase your EGT. You can try this test. Fly straight and level watch EGT. Push nose down to unload prop a little, simulating less pitch. Watch which way EGT goes. It will go up. That's also your danger zone while decending at lower throttle you will be in that hot zone of 4500 rpm already, then with the added unloading of the prop during decent, you will see your EGT spike. I will either throttle back more to get out of the zone or decend with more power. Depends on my approach. The ideal situation would be to get a jet needle with a different curve that didn't lean out at 4500rpm but so far I haven't found one. There was talk about one on this forum a few years back. I bought it and it was way too thick so I am back to stock. I think the 3 blade on a Firefly is perfect. Lots of climb performance but less top speed. Like you found the top speed isn't as much fun anyway. Seems uncomfortable. It's much more comfortable in an enclosed cockpit where the wind, noise and buffetting are reduced but whats the fun in that? -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441279#441279 ________________________________________________________________________________
Subject: Re: second chantz chutes
Date: Apr 25, 2015
I think they may be belly up. I have an old 2nd Chantz in my MKIII, it uses one of the compressed nitrogen launchers which is still in the green, so I keep toting it around. I have sent the canopy off to Skydive Kentucky and had them air it out, check it and repack it a time or two. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441286#441286 ________________________________________________________________________________
Date: Apr 25, 2015
If you have not seen this before, or if trying to figure out jetting and prop load seems non-intuitive, maybe this will help: http://oh2fly.net/oldpoops/pg11.htm -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441288#441288 ________________________________________________________________________________
Date: Apr 25, 2015
Ha! Yes, that is where I saw it before. Just could not remember the details. Thanks for the link. There are lots of other sources too, some I have read, some not. This one is nice and concise with pictures even! More flying, less thinking. Thanks, Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Saturday, April 25, 2015 9:48 AM Subject: Kolb-List: Re: Firefly/447 RPM question --> If you have not seen this before, or if trying to figure out jetting and prop load seems non-intuitive, maybe this will help: http://oh2fly.net/oldpoops/pg11.htm -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441288#441288 ________________________________________________________________________________
Date: Apr 25, 2015
That is exactly where it happens, powered back for descent. I guess that makes sense, energy not used by the prop gets dumped overboard in the exhaust. In any case, either getting out of the mid-range or adding a little "choke" fixes it. I get nice even temps on both cylinders everywhere but mid-range. The clip was in the top slot and I dropped it to the second which is actually the recommended starting point. At this point I think it is dialed in fairly close and I don't want to make any more changes until I can get some more hours on the engine, heck it is still new. Also I have yet to fly it at temps above 70, so I expect things to change some as the weather warms. Probably the best thing to do would be quit thinking about flying and start actually flying. Not today though, cool, cloudy and windy. :( Thanks again, Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of olendorf Sent: Saturday, April 25, 2015 6:56 AM Subject: Kolb-List: Re: Firefly/447 RPM question stuart(at)harnerfarm.net wrote: > > ... > Less pitch will give more RPM but less thrust so that may be the way to go. > There is no shortage of thrust, that's for sure! > > I need to go back and review to see if less pitch increases EGT or if > I need a little more. > ..... > Stuart > > -- Less pitch will actually increase your EGT. You can try this test. Fly straight and level watch EGT. Push nose down to unload prop a little, simulating less pitch. Watch which way EGT goes. It will go up. That's also your danger zone while decending at lower throttle you will be in that hot zone of 4500 rpm already, then with the added unloading of the prop during decent, you will see your EGT spike. I will either throttle back more to get out of the zone or decend with more power. Depends on my approach. The ideal situation would be to get a jet needle with a different curve that didn't lean out at 4500rpm but so far I haven't found one. There was talk about one on this forum a few years back. I bought it and it was way too thick so I am back to stock. I think the 3 blade on a Firefly is perfect. Lots of climb performance but less top speed. Like you found the top speed isn't as much fun anyway. Seems uncomfortable. It's much more comfortable in an enclosed cockpit where the wind, noise and buffetting are reduced but whats the fun in that? -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441279#441279 ________________________________________________________________________________
Date: Apr 26, 2015
Yes, Second Chantz is back in business. He was out of business for 15 years because BRS paid him out to not produce for that time..... So John Dunham, the originator of Second Chance, is now back in business in Carson City, NV. john(at)secondchantz.com Ph 775.315.0133. Last July I took my much out-of-date Second Chantz to him and had it repacked and a new rocket motor added. He reckoned he would have been the one who originally packed that chute 22 years ago! Very friendly and conscientious service; I have confidence in his experience and integrity. JG ________________________________________________________________________________
Subject: N58SG Sold
Date: Apr 27, 2015
Hi, Gang, After a great visit with the Kolb folks and John Hauck at S&F, I returned to Pompano, and met with a real gentleman who flew down from Minnesota to look at my Steven Green MK III. He bought her on the spot, after a test flight with me at 190, him at 220 and 10 gallons of fuel. She flew great, and sweetly, as is her style, when I'm lucky! He has a 2005 Firestar with a recently rebuilt 503 that he will be selling. If anyone is in the market, contact me off-list, and I'll give you his contact info. Thanks for the community over the years. I'll still be listening in, but I'm out of the ownership business for now. Dave Watkins Mark III Classic Pompano Beach, FL 954-608-5423 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441364#441364 ________________________________________________________________________________
Subject: Re: N58SG Sold
Date: Apr 27, 2015
Oops, meant to say, "Landed Sweetly!" Should have previewed before posting... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441365#441365 ________________________________________________________________________________
Date: Apr 27, 2015
I just started flying my Firefly. It was running very hot 1200+ ish. 66' 30 pitch wooden prop. the prop is a bit under pitched as I can over rev it. However, I saw a chart in Leading edge catalog that shows a 155 main jet for a 447 with a silencer or a 165 jet with out. I only have a K&N type filter. I switched to a 162 jet and a moved the needle to the middle rich position and problem solved, low 1000 temps. I will likely put the needle back to the middle lean position. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441368#441368 ________________________________________________________________________________
Date: Apr 27, 2015
I read an article a few years back from the guy that developed the EGT system. He said that he was against the idea that there be any number markings on the gage. The only information that was important is that the pilot can see quickly that the engine has been leaned too much. The result is a much quicker swing of the EGT than the CHT when leaning in flight. That is also how it is explained during my private pilot training. So all this talk about adjusting the prop to get a specific EGT number just sounds funny. I fail to understand how a engine is better when the heat of the exhaust is captured more by the engine. By all means get the prop loading right. Make sure the CHT temps are in line and the spark plugs read correctly (these are the important things). Again the EGT will tell you quickly when you have leaned the mixture too much. As always worth what you paid of it. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Apr 27, 2015 at 8:53 AM, west1m wrote: > > I just started flying my Firefly. It was running very hot 1200+ ish. > 66' 30 pitch wooden prop. the prop is a bit under pitched as I can over > rev it. > However, I saw a chart in Leading edge catalog that shows a 155 main jet > for a 447 with a silencer or a 165 jet with out. I only have a K&N type > filter. > I switched to a 162 jet and a moved the needle to the middle rich > position and problem solved, low 1000 temps. I will likely put the needle > back to the middle lean position. > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=441368#441368 > > ________________________________________________________________________________
Date: Apr 27, 2015
Aluminum melts at 1221F. Rotax two stroke EGT redline is 1200. That's close to the melting point. Instruments are not precision. A tiny hot spot will melt a speck of the piston ring groove, enough to cause rings to stick and blow by, then seizure. I am a fan of the four stroke. They aren't as critical to tune as the two stroke. They run well for me right out of the box. Prop loading is not critical. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen Sent: Monday, April 27, 2015 9:50 AM Subject: Re: Kolb-List: Re: Firefly/447 RPM question I read an article a few years back from the guy that developed the EGT system. He said that he was against the idea that there be any number markings on the gage. The only information that was important is that the pilot can see quickly that the engine has been leaned too much. The result is a much quicker swing of the EGT than the CHT when leaning in flight. That is also how it is explained during my private pilot training. So all this talk about adjusting the prop to get a specific EGT number just sounds funny. I fail to understand how a engine is better when the heat of the exhaust is captured more by the engine. By all means get the prop loading right. Make sure the CHT temps are in line and the spark plugs read correctly (these are the important things). Again the EGT will tell you quickly when you have leaned the mixture too much. As always worth what you paid of it. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Apr 27, 2015 at 8:53 AM, west1m wrote: I just started flying my Firefly. It was running very hot 1200+ ish. 66' 30 pitch wooden prop. the prop is a bit under pitched as I can over rev it. However, I saw a chart in Leading edge catalog that shows a 155 main jet for a 447 with a silencer or a 165 jet with out. I only have a K&N type filter. I switched to a 162 jet and a moved the needle to the middle rich position and problem solved, low 1000 temps. I will likely put the needle back to the middle lean position. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441368#441368 -List" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - _blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 27, 2015
Not knowing a great deal about 2 stroke engines, I think the EGT limits are to keep the exhaust ports from burning out. EGT is an indication of whether or not the combustion is taking place mostly in the cylinder or if it is spilling out into the exhaust. A charge of gas that is still burning when the piston goes past the exhaust port would kind of act like a cutting torch on the edges of the port. On my 447 the only leaning is done with the clip on the needle (or swapping needles and or jets). You can make the mixture more rich by adding =9Cchoke=9D, which is what I have done on a couple of occasions. Of course, the ideal is to get the engine to operate properly though the entire RPM range so you don=99t have to fiddle with things like the enricher while in the landing circuit. I don=99t have anything against using the enricher when needed, and indeed that may be the best solution for me. Maybe it will become part of my descent and landing procedure. Kind of like adding carb heat and going full rich when flying my old Cherokee. If that becomes the case, I may relocate the enricher lever to be down by the throttle so I am not reaching around blindly for a lever I can=99t see. >From what I can gather, prop loading/engine mixtures is more sensitive on little two strokes like the 447 and changes quite readily with temp and altitude. Trying to fly in 3 seasons may cause me to have to adjust things several times a year. In any case, weather forecast is for flying conditions tomorrow. Hopefully they are right this time, I am anxious to get back up and do some more experimenting. Stuart From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen Sent: Monday, April 27, 2015 9:50 AM Subject: Re: Kolb-List: Re: Firefly/447 RPM question I read an article a few years back from the guy that developed the EGT system. He said that he was against the idea that there be any number markings on the gage. The only information that was important is that the pilot can see quickly that the engine has been leaned too much. The result is a much quicker swing of the EGT than the CHT when leaning in flight. That is also how it is explained during my private pilot training. So all this talk about adjusting the prop to get a specific EGT number just sounds funny. I fail to understand how a engine is better when the heat of the exhaust is captured more by the engine. By all means get the prop loading right. Make sure the CHT temps are in line and the spark plugs read correctly (these are the important things). Again the EGT will tell you quickly when you have leaned the mixture too much. As always worth what you paid of it. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Apr 27, 2015 at 8:53 AM, west1m wrote: I just started flying my Firefly. It was running very hot 1200+ ish. 66' 30 pitch wooden prop. the prop is a bit under pitched as I can over rev it. However, I saw a chart in Leading edge catalog that shows a 155 main jet for a 447 with a silencer or a 165 jet with out. I only have a K&N type filter. I switched to a 162 jet and a moved the needle to the middle rich position and problem solved, low 1000 temps. I will likely put the needle back to the middle lean position. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441368#441368 -List" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - _blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 27, 2015
remember also...Stuart...the engine is on the main jet from somewhere beyond 65 to 75 % throttle opening...before that you are on the needle jet and needle..... Herb On 04/27/2015 11:02 AM, Stuart Harner wrote: > > Not knowing a great deal about 2 stroke engines, I think the EGT > limits are to keep the exhaust ports from burning out. EGT is an > indication of whether or not the combustion is taking place mostly in > the cylinder or if it is spilling out into the exhaust. A charge of > gas that is still burning when the piston goes past the exhaust port > would kind of act like a cutting torch on the edges of the port. > > On my 447 the only leaning is done with the clip on the needle (or > swapping needles and or jets). You can make the mixture more rich by > adding choke, which is what I have done on a couple of occasions. > Of course, the ideal is to get the engine to operate properly though > the entire RPM range so you dont have to fiddle with things like the > enricher while in the landing circuit. > > I dont have anything against using the enricher when needed, and > indeed that may be the best solution for me. Maybe it will become > part of my descent and landing procedure. Kind of like adding carb > heat and going full rich when flying my old Cherokee. If that becomes > the case, I may relocate the enricher lever to be down by the throttle > so I am not reaching around blindly for a lever I cant see. > > From what I can gather, prop loading/engine mixtures is more sensitive > on little two strokes like the 447 and changes quite readily with temp > and altitude. Trying to fly in 3 seasons may cause me to have to > adjust things several times a year. > > In any case, weather forecast is for flying conditions tomorrow. > Hopefully they are right this time, I am anxious to get back up and do > some more experimenting. > > Stuart > > *From:*owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] *On Behalf Of *Rick Neilsen > *Sent:* Monday, April 27, 2015 9:50 AM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: Re: Firefly/447 RPM question > > I read an article a few years back from the guy that developed the EGT > system. He said that he was against the idea that there be any number > markings on the gage. The only information that was important is that > the pilot can see quickly that the engine has been leaned too much. > The result is a much quicker swing of the EGT than the CHT when > leaning in flight. That is also how it is explained during my private > pilot training. > > So all this talk about adjusting the prop to get a specific EGT number > just sounds funny. I fail to understand how a engine is better when > the heat of the exhaust is captured more by the engine. > > By all means get the prop loading right. Make sure the CHT temps are > in line and the spark plugs read correctly (these are the important > things). Again the EGT will tell you quickly when you have leaned the > mixture too much. > > As always worth what you paid of it. > > Rick Neilsen > > Redrive VW Powered MKIIIC > > On Mon, Apr 27, 2015 at 8:53 AM, west1m > wrote: > > > > > I just started flying my Firefly. It was running very hot 1200+ ish. > 66' 30 pitch wooden prop. the prop is a bit under pitched as I can > over rev it. > However, I saw a chart in Leading edge catalog that shows a 155 main > jet for a 447 with a silencer or a 165 jet with out. I only have a K&N > type filter. > I switched to a 162 jet and a moved the needle to the middle rich > position and problem solved, low 1000 temps. I will likely put the > needle back to the middle lean position. > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=441368#441368 > > > ========== > -List" target="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > FORUMS - > _blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > target="_blank">http://www.matronics.com/contribution > ========== > > > * * > * * > ** > ** > ** > ** > ** > *http://www.matronics.com/Navigator?Kolb-List* > ** > ** > *http://forums.matronics.com* > ** > ** > ** > ** > *http://www.matronics.com/contribution* > ** > * * > * > > > * ________________________________________________________________________________
Date: Apr 27, 2015
Absolutely. I am shooting for high 1100=99s EGT and mid 300=99s for CHT. I think the 2 stroke is a fine line dance between shock cooling and burning up. Carefully monitored and well maintained the little Rotax would seem to be capable of going beyond what the factory says it will, but make any mistakes and you are looking for a place to land! The Rotax guy from LEAF told us at OSH that 1250=C2=B0 was the absolute top red line limit. Since my manual has no listing for max EGT, I will defer to the factory certified guy. Consequently, I have my EIS limit set to 1225=C2=B0. If I could find a viable 4 stroke to put on a Firefly and keep it Part 103, I would buy it in a heartbeat. Of course, 2 HP from every cubic inch of displacement on .01 GPH is every pilots wet dream, right? Now where did I leave that box of di-lithium crystals and that bottle of anti-matter? Anyway, I think there may be a future in electric motors for the Firefly. They are getting close to having reliable long lasing batteries. The motors and controllers already exist. If you can get a battery that will run a 30 HP motor for an hour with some left in reserve that does not cost $45K and weigh 100#, we will be in business. Stuart From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck Sent: Monday, April 27, 2015 10:06 AM Subject: RE: Kolb-List: Re: Firefly/447 RPM question Aluminum melts at 1221F. Rotax two stroke EGT redline is 1200. That's close to the melting point. Instruments are not precision. A tiny hot spot will melt a speck of the piston ring groove, enough to cause rings to stick and blow by, then seizure. I am a fan of the four stroke. They aren't as critical to tune as the two stroke. They run well for me right out of the box. Prop loading is not critical. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen Sent: Monday, April 27, 2015 9:50 AM Subject: Re: Kolb-List: Re: Firefly/447 RPM question I read an article a few years back from the guy that developed the EGT system. He said that he was against the idea that there be any number markings on the gage. The only information that was important is that the pilot can see quickly that the engine has been leaned too much. The result is a much quicker swing of the EGT than the CHT when leaning in flight. That is also how it is explained during my private pilot training. So all this talk about adjusting the prop to get a specific EGT number just sounds funny. I fail to understand how a engine is better when the heat of the exhaust is captured more by the engine. By all means get the prop loading right. Make sure the CHT temps are in line and the spark plugs read correctly (these are the important things). Again the EGT will tell you quickly when you have leaned the mixture too much. As always worth what you paid of it. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Apr 27, 2015 at 8:53 AM, west1m wrote: I just started flying my Firefly. It was running very hot 1200+ ish. 66' 30 pitch wooden prop. the prop is a bit under pitched as I can over rev it. However, I saw a chart in Leading edge catalog that shows a 155 main jet for a 447 with a silencer or a 165 jet with out. I only have a K&N type filter. I switched to a 162 jet and a moved the needle to the middle rich position and problem solved, low 1000 temps. I will likely put the needle back to the middle lean position. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441368#441368 -List" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - _blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution - The Kolb-List Email Forum - --> http://www.matronics.com/Navigator?Kolb-List - MATRONICS WEB FORUMS - --> http://forums.matronics.com - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. --> http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 27, 2015
I don't seem to be able to copy the page out of the two stroke manual, but MAX EGT is 1200F. Normal EGT is 860F to 1000F. That is on page 10-1. MAX CHT is 500F. Normal is 374-446F. Seems to me if you operate the 447 at 1200F and have your warning light set at 1225F, you will be well over the red line before you know it. I cannot remember how far downstream the EGT probe is located, but it is a significant distance from the edge of the exhaust port. Seems to me, as an uneducated hobbyist, the exhaust will be cooler at the probe. Again, ultralight instruments are far from precision instruments. I did pretty good with my two stroke engines flying them as they were set up at the factory. The idea is to prop to the engine, not tune the engine to the prop. Most two stroke engine failures are the result of operators chasing their tail, trying to reinvent the wheel. Here's the URL for the Rotax Two Stroke Manual. I assume it is the current version: http://www.rotax-aircraft-engines.com/portaldata/5/dokus/d04495.pdf The above is my opinion only. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Stuart Harner Sent: Monday, April 27, 2015 11:24 AM Subject: RE: Kolb-List: Re: Firefly/447 RPM question Absolutely. I am shooting for high 1100=99s EGT and mid 300=99s for CHT. I think the 2 stroke is a fine line dance between shock cooling and burning up. Carefully monitored and well maintained the little Rotax would seem to be capable of going beyond what the factory says it will, but make any mistakes and you are looking for a place to land! The Rotax guy from LEAF told us at OSH that 1250=C2=B0 was the absolute top red line limit. Since my manual has no listing for max EGT, I will defer to the factory certified guy. Consequently, I have my EIS limit set to 1225=C2=B0. If I could find a viable 4 stroke to put on a Firefly and keep it Part 103, I would buy it in a heartbeat. Of course, 2 HP from every cubic inch of displacement on .01 GPH is every pilots wet dream, right? Now where did I leave that box of di-lithium crystals and that bottle of anti-matter? Anyway, I think there may be a future in electric motors for the Firefly. They are getting close to having reliable long lasing batteries. The motors and controllers already exist. If you can get a battery that will run a 30 HP motor for an hour with some left in reserve that does not cost $45K and weigh 100#, we will be in business. Stuart From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck Sent: Monday, April 27, 2015 10:06 AM Subject: RE: Kolb-List: Re: Firefly/447 RPM question Aluminum melts at 1221F. Rotax two stroke EGT redline is 1200. That's close to the melting point. Instruments are not precision. A tiny hot spot will melt a speck of the piston ring groove, enough to cause rings to stick and blow by, then seizure. I am a fan of the four stroke. They aren't as critical to tune as the two stroke. They run well for me right out of the box. Prop loading is not critical. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen Sent: Monday, April 27, 2015 9:50 AM Subject: Re: Kolb-List: Re: Firefly/447 RPM question I read an article a few years back from the guy that developed the EGT system. He said that he was against the idea that there be any number markings on the gage. The only information that was important is that the pilot can see quickly that the engine has been leaned too much. The result is a much quicker swing of the EGT than the CHT when leaning in flight. That is also how it is explained during my private pilot training. So all this talk about adjusting the prop to get a specific EGT number just sounds funny. I fail to understand how a engine is better when the heat of the exhaust is captured more by the engine. By all means get the prop loading right. Make sure the CHT temps are in line and the spark plugs read correctly (these are the important things). Again the EGT will tell you quickly when you have leaned the mixture too much. As always worth what you paid of it. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Apr 27, 2015 at 8:53 AM, west1m wrote: I just started flying my Firefly. It was running very hot 1200+ ish. 66' 30 pitch wooden prop. the prop is a bit under pitched as I can over rev it. However, I saw a chart in Leading edge catalog that shows a 155 main jet for a 447 with a silencer or a 165 jet with out. I only have a K&N type filter. I switched to a 162 jet and a moved the needle to the middle rich position and problem solved, low 1000 temps. I will likely put the needle back to the middle lean position. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441368#441368 -List" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - _blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution - The Kolb-List Email Forum - --> http://www.matronics.com/Navigator?Kolb-List - MATRONICS WEB FORUMS - --> http://forums.matronics.com - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. --> http://www.matronics.com/contribution http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 27, 2015
Ah-Ha! Good find John. Thanks for the link. My manual is older, and has this info: I will be downloading and using the new version from here on out. EIS limits will be adjusted down to 1200=C2=B0. It is also interesting to see that it is acceptable to be in the high 800=99s in normal operation. My understanding was that it should be at least 1000=C2=B0. Strange, I had asked this question at OSH specifically since it was not in my manual. Based on the higher CHT temps, the slightly higher 1250=C2=B0 EGT seemed to be in line that the 447 ran slightly hotter than the 503. HMM, makes me wonder about other things said there Most of the time I am seeing 1150 =93 1190, but on a couple of occasions I have seen it spike into the 1200+ range, which I quickly got out of by changing throttle settings or adding =9Cchoke=9D. While I don=99t think any damage was done, there certainly is no reason to push destructive temperatures. The probe bosses were welded in by Rotax. I don=99t remember the dimensions off the top of my head, but I did measure to see that they matched the instructions of where to drill if there were no bosses. If memory serves me the hot spot may well be farther downstream than the port opening itself. From welding class days the hot spot of the flame is not at the tip but at the point of the lighter blue flame in the middle. Since I can=99t see inside the exhaust, I can only imagine that this MAY be the case. I am going to read this updated version to see what other changes there were. That may shed more light on what steps to take next. The learning curve never ends. Thanks, Stuart From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck Sent: Monday, April 27, 2015 12:22 PM Subject: RE: Kolb-List: Re: Firefly/447 RPM question I don't seem to be able to copy the page out of the two stroke manual, but MAX EGT is 1200F. Normal EGT is 860F to 1000F. That is on page 10-1. MAX CHT is 500F. Normal is 374-446F. Seems to me if you operate the 447 at 1200F and have your warning light set at 1225F, you will be well over the red line before you know it. I cannot remember how far downstream the EGT probe is located, but it is a significant distance from the edge of the exhaust port. Seems to me, as an uneducated hobbyist, the exhaust will be cooler at the probe. Again, ultralight instruments are far from precision instruments. I did pretty good with my two stroke engines flying them as they were set up at the factory. The idea is to prop to the engine, not tune the engine to the prop. Most two stroke engine failures are the result of operators chasing their tail, trying to reinvent the wheel. Here's the URL for the Rotax Two Stroke Manual. I assume it is the current version: http://www.rotax-aircraft-engines.com/portaldata/5/dokus/d04495.pdf The above is my opinion only. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Stuart Harner Sent: Monday, April 27, 2015 11:24 AM Subject: RE: Kolb-List: Re: Firefly/447 RPM question Absolutely. I am shooting for high 1100=99s EGT and mid 300=99s for CHT. I think the 2 stroke is a fine line dance between shock cooling and burning up. Carefully monitored and well maintained the little Rotax would seem to be capable of going beyond what the factory says it will, but make any mistakes and you are looking for a place to land! The Rotax guy from LEAF told us at OSH that 1250=C2=B0 was the absolute top red line limit. Since my manual has no listing for max EGT, I will defer to the factory certified guy. Consequently, I have my EIS limit set to 1225=C2=B0. If I could find a viable 4 stroke to put on a Firefly and keep it Part 103, I would buy it in a heartbeat. Of course, 2 HP from every cubic inch of displacement on .01 GPH is every pilots wet dream, right? Now where did I leave that box of di-lithium crystals and that bottle of anti-matter? Anyway, I think there may be a future in electric motors for the Firefly. They are getting close to having reliable long lasing batteries. The motors and controllers already exist. If you can get a battery that will run a 30 HP motor for an hour with some left in reserve that does not cost $45K and weigh 100#, we will be in business. Stuart From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck Sent: Monday, April 27, 2015 10:06 AM Subject: RE: Kolb-List: Re: Firefly/447 RPM question Aluminum melts at 1221F. Rotax two stroke EGT redline is 1200. That's close to the melting point. Instruments are not precision. A tiny hot spot will melt a speck of the piston ring groove, enough to cause rings to stick and blow by, then seizure. I am a fan of the four stroke. They aren't as critical to tune as the two stroke. They run well for me right out of the box. Prop loading is not critical. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen Sent: Monday, April 27, 2015 9:50 AM Subject: Re: Kolb-List: Re: Firefly/447 RPM question I read an article a few years back from the guy that developed the EGT system. He said that he was against the idea that there be any number markings on the gage. The only information that was important is that the pilot can see quickly that the engine has been leaned too much. The result is a much quicker swing of the EGT than the CHT when leaning in flight. That is also how it is explained during my private pilot training. So all this talk about adjusting the prop to get a specific EGT number just sounds funny. I fail to understand how a engine is better when the heat of the exhaust is captured more by the engine. By all means get the prop loading right. Make sure the CHT temps are in line and the spark plugs read correctly (these are the important things). Again the EGT will tell you quickly when you have leaned the mixture too much. As always worth what you paid of it. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Apr 27, 2015 at 8:53 AM, west1m wrote: I just started flying my Firefly. It was running very hot 1200+ ish. 66' 30 pitch wooden prop. the prop is a bit under pitched as I can over rev it. However, I saw a chart in Leading edge catalog that shows a 155 main jet for a 447 with a silencer or a 165 jet with out. I only have a K&N type filter. I switched to a 162 jet and a moved the needle to the middle rich position and problem solved, low 1000 temps. I will likely put the needle back to the middle lean position. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441368#441368 -List" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - _blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution - The Kolb-List Email Forum - --> http://www.matronics.com/Navigator?Kolb-List - MATRONICS WEB FORUMS - --> http://forums.matronics.com - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. --> http://www.matronics.com/contribution http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com http://www.matronics.com/contribution - The Kolb-List Email Forum - --> http://www.matronics.com/Navigator?Kolb-List - MATRONICS WEB FORUMS - --> http://forums.matronics.com - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. --> http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 27, 2015
Rick, I agree with you on 4 stroke engines.But I always considered cht , on a 2 stroke to be a indication more of load than mixture.If i was under propped it was like running in second gear, lots of revs but not much load.no load makes the 2 stroke lean out which ups the egt but keeps the head cooler.In my opinion,you need to prop the engine for the operating rpm then adjust the mixture for the amount of load at that rpm.My 503 ,prop set for 6100, on takeoff gave about 1000 degrees at full throttle climb out and less than 1200 at 5500 cruise.But the firestar was so clean the throttle was around half open at that rpm.At 5700 the egts got close to 1200 and 75 mph cruise but the head temps were always well under the limits G.Aman 750 hrs on the Firestar 503 dcdi oil injected -----Original Message----- From: Rick Neilsen <neilsenrm(at)gmail.com> Sent: Mon, Apr 27, 2015 10:50 am Subject: Re: Kolb-List: Re: Firefly/447 RPM question I read an article a few years back from the guy that developed the EGT system. He said that he was against the idea that there be any number markings on the gage. The only information that was important is that the pilot can see quickly that the engine has been leaned too much. The result is a much quicker swing of the EGT than the CHT when leaning in flight. That is also how it is explained during my private pilot training. So all this talk about adjusting the prop to get a specific EGT number just sounds funny. I fail to understand how a engine is better when the heat of the exhaust is captured more by the engine. By all means get the prop loading right. Make sure the CHT temps are in line and the spark plugs read correctly (these are the important things). Again the EGT will tell you quickly when you have leaned the mixture too much. As always worth what you paid of it. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Apr 27, 2015 at 8:53 AM, west1m wrote: I just started flying my Firefly. It was running very hot 1200+ ish. 66' 30 pitch wooden prop. the prop is a bit under pitched as I can over rev it. However, I saw a chart in Leading edge catalog that shows a 155 main jet for a 447 with a silencer or a 165 jet with out. I only have a K&N type filter. I switched to a 162 jet and a moved the needle to the middle rich position and problem solved, low 1000 temps. I will likely put the needle back to the middle lean position. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441368#441368 =========== -List" target="_blank">http://www.matronics.com/Navigator?Kolb-List =========== FORUMS - _blank">http://forums.matronics.com =========== b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution =========== ________________________________________________________________________________
Subject: Re: Firefly/447 RPM question
Date: Apr 27, 2015
[quote="John Hauck"] The idea is to prop to the engine, not tune the engine to the prop. Most two stroke engine failures are the result of operators chasing their tail, trying to reinvent the wheel. john h mkIII Titus, Alabama [quote] This. Jet it the way the book says, and then fiddle with the prop pitch until the numbers are happy. Did a 150 hour carbon cleanout of the 582 top end last week, flew Friday, climbout turning 6300, EGT 1,000. Cruising at 5,300 to 5,600 rpm gave consistent matching EGT's of 1050 to 1100. No problem with high EGT's on descent because you adjust the throttle a bit and they stay around 1000. Checked the plugs after landing, they are a medium brown. Hope to fly again tomorrow with a passenger, will give an update and maybe a photo of the plugs. The plugs verify if the temperatures are acceptable, and if the EGT is close to accurate. From then on, the EGT gauge is mostly to warn you anomalies. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441420#441420 ________________________________________________________________________________
Date: Apr 27, 2015
Shouldn't the plug check be done at the power setting that you want to check, e.g., cruise, WOT, etc? If the plugs are checked after landing and taxi back to the hanger, does that not give you an indication for low speed, low power settings? john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Monday, April 27, 2015 9:54 PM Subject: Kolb-List: Re: Firefly/447 RPM question --> [quote="John Hauck"] The idea is to prop to the engine, not tune the engine to the prop. Most two stroke engine failures are the result of operators chasing their tail, trying to reinvent the wheel. john h mkIII Titus, Alabama [quote] This. Jet it the way the book says, and then fiddle with the prop pitch until the numbers are happy. Did a 150 hour carbon cleanout of the 582 top end last week, flew Friday, climbout turning 6300, EGT 1,000. Cruising at 5,300 to 5,600 rpm gave consistent matching EGT's of 1050 to 1100. No problem with high EGT's on descent because you adjust the throttle a bit and they stay around 1000. Checked the plugs after landing, they are a medium brown. Hope to fly again tomorrow with a passenger, will give an update and maybe a photo of the plugs. The plugs verify if the temperatures are acceptable, and if the EGT is close to accurate. From then on, the EGT gauge is mostly to warn you anomalies. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441420#441420 ________________________________________________________________________________
Date: Apr 28, 2015
John Hauck wrote: > Shouldn't the plug check be done at the power setting that you want to > check, e.g., cruise, WOT, etc? > > If the plugs are checked after landing and taxi back to the hanger, does > that not give you an indication for low speed, low power settings? > > john h > mkIII > Titus, Alabama > > -- I have always heard that, but years ago when I was building dirt bikes - 2 stroke - I would check the plugs after a plain "ride," and then do a run at a specific speed or load to check the jetting, and I couldn't see the difference. Perhaps an expert with a magnifying glass could, but in my laymans experience, the plugs sort of were what they were. For instance, putting in brand new plugs, going out and doing a test, and then pulling them and looking at them, there was not enough accumulation to tell much of anything. Maybe I was just doing something wrong, or maybe I am missing something. I would be glad to hear from somebody who is actually real good at that particular skill. Since I run at cruise power & 1,000' AGL 95% of the time, and then just pull it back on final, and then a fast idle downhill to taxi to the hangar, I am thinking that I am not going to alter the appearance of the plugs all that much from their normal state by that last 3 minutes of run time. But I could be wrong. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441434#441434 ________________________________________________________________________________
March 10, 2015 - April 28, 2015
Kolb-Archive.digest.vol-nk
