Kolb-Archive.digest.vol-np
January 10, 2016 - February 06, 2016
      > below the legal weight limit even 11 ozs. needs to be watched. Weight
      > increases naturally after the initial weighing anyway with radios, GPS,
      > cameras etc.
      > The guy who built my Extra added all sorts of odd little brackets or a bit
      > of stiffening or beefing up wherever he saw what he considered a weak
      > point. All without consulting me  a couple of hundred miles away. This
      > caused all sorts of fancy maths to get her certified as a microlight.
      > Cheers
      > Pat
      > *From:* Charlie England
      > *Sent:* Saturday, January 9, 2016 8:00 PM
      > *To:* kolb-list(at)matronics.com
      > *Subject:* Re: Kolb-List: Weight in one wing...?
      > LRI's are basically angle of attack indicators. I suppose you could argue
      > that you don't need them on an ultralite (type) a/c, but then, we don't
      > know how he intends to use the a/c. US Navy pilots depend on AOA indicators
      > to land on carriers safely, and some 'bush' pilots do, too.
      > As far as balance goes, odds are high that component tolerances and build
      > errors will easily mask an 11 oz weight difference. On a plane with wing
      > tanks, just over 0.1 gallons of fuel difference between tanks would cause
      > that much imbalance.
      > Charlie
      > On 1/9/2016 12:29 PM, Patrick Ladd wrote:
      > I installed a Lift Reserve Indicator probe with a plate>>
      > What the hell is that and why do you need it.Particularly  if you are
      > adding 11 ozs. Totally ignorant. Pat
      > *From:* Nick Cassara
      > *Sent:* Monday, January 4, 2016 7:56 PM
      > *Subject:* Kolb-List: Weight in one wing...?
      > Hello Kolber flyers,
      > I am covering my left wing. I installed a Lift Reserve Indicator probe
      > with a plate, that weights about 11oz, in the next bay out board of the
      > strut mount on my left wing. Should I add an equivalent amount of weight in
      > the right wing for balance?
      > Thanks,
      > Nick Cassara
      > Palmer, AK
      > Kolbra #1 p;      -- Please Support Your Lists This Month (And Get Annual
      > List below to Incentive Gifts href="http://www.matronics.com/contribution"
      > <http://www.matronics.com/contribution>>http://www.matronics.com/cThank
      > you for your generous ;                      -Matt Dralle, List nbsp;
      > Navigator Photoshare, and href
      > "http://www.matronics.com/Navigator?Kolb-List"
      > <http://www.matronics.com/Navigator?Kolb-List>>http://www.matronicp;
      > the Web href="http://forums.matronics.com" >
      > _p;         generous bsp;                    href
      > http://www.matronics.com/c================
Date: Jan 10, 2016
Subject: Re: Horizontal stabilizer seals
I believe what happens is that the air leaking through the slot between the horizontal stabilizer and the boom tube causes the flow to go more vertically over the rudder rather than horizontally. I base this on the results of tuft testing I did on the Mk III's rear fuselage segment as seen in the video I shot of the tests: https://www.youtube.com/watch?v=IG796iiymYw I attached photos of the gap seals to the original post but just in case...... The photo shows the second set of seals with their peel ply covering with the first set of seals all trimmed up and ready to bond to the second set when they are cured and trimmed. This style of construction was only possible because the "plane from hell" had the horizontal stabilizer set on the center line of the tube. Rick On Thu, Jan 7, 2016 at 11:49 PM, wakataka wrote: > > Any idea why sealing the elevator gap had such an effect on the rudder > effectiveness? I wouldn't have expected that. > > I'd love to see a photo of the seals you built. I'm planning to recover m y > Firestar next year and gap seals are one of the things I need to figure o ut > how to install. > > -------- > There is something fascinating about science. One gets such wholesale > returns of conjecture out of such a trifling investment of fact. > > Mark Twain > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=451801#451801 > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Jan 10, 2016
From: william sullivan <williamtsullivan(at)att.net>
Rick- How do you fold it? It looks to be a rigid assembly. Bill Sullivan ________________________________________________________________________________
Date: Jan 10, 2016
Wouldn't the air be going *down* through the tube-stabilizer gap? (Higher pressure on top of the tail.) That would still reduce the rudder's effectiveness, since vertical flow would disrupt horizontal flow across the rudder. On Sun, Jan 10, 2016 at 10:56 AM, Richard Girard wrote: > I believe what happens is that the air leaking through the slot between > the horizontal stabilizer and the boom tube causes the flow to go more > vertically over the rudder rather than horizontally. I base this on the > results of tuft testing I did on the Mk III's rear fuselage segment as se en > in the video I shot of the tests: > > https://www.youtube.com/watch?v=IG796iiymYw > > I attached photos of the gap seals to the original post but just in > case...... The photo shows the second set of seals with their peel ply > covering with the first set of seals all trimmed up and ready to bond to > the second set when they are cured and trimmed. This style of constructio n > was only possible because the "plane from hell" had the horizontal > stabilizer set on the center line of the tube. > > Rick > > > On Thu, Jan 7, 2016 at 11:49 PM, wakataka wrote: > >> >> Any idea why sealing the elevator gap had such an effect on the rudder >> effectiveness? I wouldn't have expected that. >> >> I'd love to see a photo of the seals you built. I'm planning to recover >> my Firestar next year and gap seals are one of the things I need to figu re >> out how to install. >> >> -------- >> There is something fascinating about science. One gets such wholesale >> returns of conjecture out of such a trifling investment of fact. >> >> Mark Twain >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=451801#451801 >> >> >> >> >> >> >> >> ========== >> br> fts!) >> r> > w.buildersbooks.com" rel="noreferrer" target="_blank"> >> www.buildersbooks.com >> rel="noreferrer" target="_blank">http://www.matronics.com/contributi on >> -Matt Dralle, List Admin. >> ========== >> -List" rel="noreferrer" target="_blank"> >> http://www.matronics.com/Navigator?Kolb-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributi on >> ========== >> >> >> >> > > > -- > =9CBlessed are the cracked, for they shall let in the light. =9D Groucho Marx > <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > ________________________________________________________________________________
Date: Jan 10, 2016
Couldn't the seals be attached to the boom tube under the horizontal stab. so it could be folded. Also if properly braced it might take the place of t he upper wire bracing. ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Sunday, January 10, 2016 1:06:25 PM Subject: Re: Kolb-List: Re: Horizontal stabilizer seals Wouldn't the air be going *down* through the tube-stabilizer gap? (Higher p ressure on top of the tail.) That would still reduce the rudder's effective ness, since vertical flow would disrupt horizontal flow across the rudder. On Sun, Jan 10, 2016 at 10:56 AM, Richard Girard < aslsa.rng(at)gmail.com > wr ote: I believe what happens is that the air leaking through the slot between the horizontal stabilizer and the boom tube causes the flow to go more vertica lly over the rudder rather than horizontally. I base this on the results of tuft testing I did on the Mk III's rear fuselage segment as seen in the vi deo I shot of the tests: https://www.youtube.com/watch?v=IG796iiymYw I attached photos of the gap seals to the original post but just in case... ... The photo shows the second set of seals with their peel ply covering wi th the first set of seals all trimmed up and ready to bond to the second se t when they are cured and trimmed. This style of construction was only poss ible because the "plane from hell" had the horizontal stabilizer set on the center line of the tube. Rick On Thu, Jan 7, 2016 at 11:49 PM, wakataka < wakataka(at)charter.net > wrote:
Any idea why sealing the elevator gap had such an effect on the rudder effe ctiveness? I wouldn't have expected that. I'd love to see a photo of the seals you built. I'm planning to recover my Firestar next year and gap seals are one of the things I need to figure out how to install. -------- There is something fascinating about science. One gets such wholesale retur ns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=451801#451801 =========== br> fts!) r> > w.buildersbooks.com " rel="noreferrer" target="_blank"> www.builde rsbooks.com rel="noreferrer" target="_blank"> http://www.matronics.com/contribution -Matt Dralle, List Admin. =========== -List" rel="noreferrer" target="_blank"> http://www.matronics.com/Navig ator?Kolb-List =========== FORUMS - eferrer" target="_blank"> http://forums.matronics.com =========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank"> http://www.matronics.com/contribution =========== -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx
Subject: RE: Kolb-List Digest: 2 Msgs - 01/09/16
Date: Jan 10, 2016
You people act like these are airplanes they are air carts not ment to fly any were but up and around! --- Original Message --- From: "Kolb-List Digest Server" <kolb-list(at)matronics.com> Sent: January 10, 2016 2:14 AM Subject: Kolb-List Digest: 2 Msgs - 01/09/16 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Kolb-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Kolb-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-01-09&Archive=Kolb Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 16-01-09&Archive=Kolb =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Kolb-List Digest Archive --- Total Messages Posted Sat 01/09/16: 2 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 10:29 AM - Re: Weight in one wing...? (Patrick Ladd) 2. 12:00 PM - Re: Weight in one wing...? (Charlie England) ________________________________ Message 1 _____________________________________ From: Patrick Ladd <patrickjladd(at)hotmail.com> Subject: Re: Kolb-List: Weight in one wing...? I installed a Lift Reserve Indicator probe with a plate>> What the hell is that and why do you need it.Particularly if you are adding 11 ozs. Totally ignorant. Pat From: Nick Cassara Sent: Monday, January 4, 2016 7:56 PM Subject: Kolb-List: Weight in one wing...? Hello Kolber flyers, I am covering my left wing. I installed a Lift Reserve Indicator probe with a plate, that weights about 11oz, in the next bay out board of the strut mount on my left wing. Should I add an equivalent amount of weight in the right wing for balance? Thanks, Nick Cassara Palmer, AK Kolbra #1 Prototype ________________________________ Message 2 _____________________________________ Subject: Re: Kolb-List: Weight in one wing...? From: Charlie England <ceengland7(at)gmail.com> LRI's are basically angle of attack indicators. I suppose you could argue that you don't need them on an ultralite (type) a/c, but then, we don't know how he intends to use the a/c. US Navy pilots depend on AOA indicators to land on carriers safely, and some 'bush' pilots do, too. As far as balance goes, odds are high that component tolerances and build errors will easily mask an 11 oz weight difference. On a plane with wing tanks, just over 0.1 gallons of fuel difference between tanks would cause that much imbalance. Charlie On 1/9/2016 12:29 PM, Patrick Ladd wrote: > I installed a Lift Reserve Indicator probe with a plate>> > What the hell is that and why do you need it.Particularly if you are > adding 11 ozs. Totally ignorant. Pat > *From:* Nick Cassara > *Sent:* Monday, January 4, 2016 7:56 PM > *To:* kolb-list(at)matronics.com > *Subject:* Kolb-List: Weight in one wing...? > > Hello Kolber flyers, > > I am covering my left wing. I installed a Lift Reserve Indicator probe > with a plate, that weights about 11oz, in the next bay out board of > the strut mount on my left wing. Should I add an equivalent amount of > weight in the right wing for balance? > > Thanks, > > Nick Cassara > Palmer, AK > > Kolbra #1 p; -- Please Support Your Lists This Month (And Get > Annual List below to Incentive Gifts > href="http://www.matronics.com/contribution">http://www.matronics.com/cThank > you for your generous ; -Matt Dralle, List > nbsp; Navigator Photoshare, and > href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronicp; > the Web href="http://forums.matronics.com">http://forums.matronics.com > _p; generous bsp; > href="http://www.matronics.com/contribution">http://www.matronics.com/c=============== > > ________________________________________________________________________________
Date: Jan 10, 2016
Subject: Re: Aileron trim
Date: Jan 03, 2016 From: Richard Girard --------------------------- < Doubtful it is caused by torque, at least no Kolb I've ever flown has had the tendency. > ------------------------- If you have an engine on an aircraft there will always be a torque component in play as long as the engine is operating under load. For example, a Rotax 912 81 hp engine generates 75.9 ft-lb torque at 4800 rpm. Add a 2.43:1 gear box and the torque at the propeller goes to 184 ft-lb. This means it will take about an 18 lb vertical force at the wing tip to keep the wings level. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jan 10, 2016
>At 11:56 AM 1/10/2016, you wrote: I believe what happens is that the air leaking through the slot between the horizontal stabilizer and the boom tube causes the flow to go more vertically over the rudder rather than horizontally. I base this on the results of tuft testing I did on the Mk III's rear fuselage segment as seen in the video I shot of the tests: > Rick, I believe if you check it out you will find that while you are in level flight the tail has to exert a downward force. This means the air pressure on top of the horizontal stabilizer will be greater than that found on the bottom side. Air will always move from high to low pressure. So, if any air is moving through the gap, it will be down through the gap not up. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jan 10, 2016
What if the tail section is on a few feet from the prop which is generating a very strong rotating column of air directly on the tail section? Air flow over the tail of a Kolb is interesting based on prop wash. I get a pretty good idea of what the air is doing based on crankcase residue being blown from the vent tube and sticking to the tail section. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack B. Hart Sent: Sunday, January 10, 2016 1:56 PM Subject: Re: Kolb-List: Re: Horizontal stabilizer seals --> >At 11:56 AM 1/10/2016, you wrote: I believe what happens is that the air leaking through the slot between the horizontal stabilizer and the boom tube causes the flow to go more vertically over the rudder rather than horizontally. I base this on the results of tuft testing I did on the Mk III's rear fuselage segment as seen in the video I shot of the tests: > Rick, I believe if you check it out you will find that while you are in level flight the tail has to exert a downward force. This means the air pressure on top of the horizontal stabilizer will be greater than that found on the bottom side. Air will always move from high to low pressure. So, if any air is moving through the gap, it will be down through the gap not up. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jan 10, 2016
Keith Callfas: Where did you get your information on Kolbs? Kolbs are definitely airplanes. They have fixed wings, an engine, and fly. I don't know what you mean by up and around. I know a few Kolbs that have flown and are still flying up and around all over the US, Canada, and Alaska. Are you familiar with Kolb aircraft? john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Keith Callfas Sent: Sunday, January 10, 2016 1:29 PM Subject: Kolb-List: RE: Kolb-List Digest: 2 Msgs - 01/09/16 You people act like these are airplanes they are air carts not ment to fly any were but up and around! --- Original Message --- From: "Kolb-List Digest Server" <kolb-list(at)matronics.com> Sent: January 10, 2016 2:14 AM Subject: Kolb-List Digest: 2 Msgs - 01/09/16 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Kolb-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Kolb-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-01-09&Archive=Kolb Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2016-01-09&Archive=Kolb =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Kolb-List Digest Archive --- Total Messages Posted Sat 01/09/16: 2 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 10:29 AM - Re: Weight in one wing...? (Patrick Ladd) 2. 12:00 PM - Re: Weight in one wing...? (Charlie England) ________________________________ Message 1 _____________________________________ From: Patrick Ladd <patrickjladd(at)hotmail.com> Subject: Re: Kolb-List: Weight in one wing...? I installed a Lift Reserve Indicator probe with a plate>> What the hell is that and why do you need it.Particularly if you are adding 11 ozs. Totally ignorant. Pat From: Nick Cassara Sent: Monday, January 4, 2016 7:56 PM Subject: Kolb-List: Weight in one wing...? Hello Kolber flyers, I am covering my left wing. I installed a Lift Reserve Indicator probe with a plate, that weights about 11oz, in the next bay out board of the strut mount on my left wing. Should I add an equivalent amount of weight in the right wing for balance? Thanks, Nick Cassara Palmer, AK Kolbra #1 Prototype ________________________________ Message 2 _____________________________________ Subject: Re: Kolb-List: Weight in one wing...? From: Charlie England <ceengland7(at)gmail.com> LRI's are basically angle of attack indicators. I suppose you could argue that you don't need them on an ultralite (type) a/c, but then, we don't know how he intends to use the a/c. US Navy pilots depend on AOA indicators to land on carriers safely, and some 'bush' pilots do, too. As far as balance goes, odds are high that component tolerances and build errors will easily mask an 11 oz weight difference. On a plane with wing tanks, just over 0.1 gallons of fuel difference between tanks would cause that much imbalance. Charlie On 1/9/2016 12:29 PM, Patrick Ladd wrote: > I installed a Lift Reserve Indicator probe with a plate>> What the > hell is that and why do you need it.Particularly if you are adding 11 > ozs. Totally ignorant. Pat > *From:* Nick Cassara > *Sent:* Monday, January 4, 2016 7:56 PM > *To:* kolb-list(at)matronics.com > *Subject:* Kolb-List: Weight in one wing...? > > Hello Kolber flyers, > > I am covering my left wing. I installed a Lift Reserve Indicator probe > with a plate, that weights about 11oz, in the next bay out board of > the strut mount on my left wing. Should I add an equivalent amount of > weight in the right wing for balance? > > Thanks, > > Nick Cassara > Palmer, AK > > Kolbra #1 p; -- Please Support Your Lists This Month (And Get > Annual List below to Incentive Gifts > href="http://www.matronics.com/contribution">http://www.matronics.com/cThank > you for your generous ; -Matt Dralle, List > nbsp; Navigator Photoshare, and > href="http://www.matronics.com/Navigator?Kolb-List">http://www.matroni > cp; the Web > href="http://forums.matronics.com">http://forums.matronics.com > _p; generous bsp; > href="http://www.matronics.com/contribution">http://www.matronics.com/ > c=============== > > ________________________________________________________________________________
Subject: Re: RE: Kolb-List Digest: 2 Msgs - 01/09/16
Date: Jan 10, 2016
Keith Did you know you were posting to the Kolb list??? Many of our planes fly substantial distances. I was a bit insulted. Rick Neilsen Redrive VW Powered MkIII Sent from my iPhone > On Jan 10, 2016, at 2:28 PM, Keith Callfas wrote: > > > You people act like these are airplanes they are air carts not ment to fly any were but up and around! > > --- Original Message --- > > From: "Kolb-List Digest Server" <kolb-list(at)matronics.com> > Sent: January 10, 2016 2:14 AM > To: "Kolb-List Digest List" > Subject: Kolb-List Digest: 2 Msgs - 01/09/16 > > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-01-09&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 16-01-09&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Sat 01/09/16: 2 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 10:29 AM - Re: Weight in one wing...? (Patrick Ladd) > 2. 12:00 PM - Re: Weight in one wing...? (Charlie England) > > > > ________________________________ Message 1 _____________________________________ > > > From: Patrick Ladd <patrickjladd(at)hotmail.com> > Subject: Re: Kolb-List: Weight in one wing...? > > I installed a Lift Reserve Indicator probe with a plate>> > > What the hell is that and why do you need it.Particularly if you are > adding 11 ozs. Totally ignorant. Pat > > From: Nick Cassara > Sent: Monday, January 4, 2016 7:56 PM > Subject: Kolb-List: Weight in one wing...? > > > Hello Kolber flyers, > > I am covering my left wing. I installed a Lift Reserve Indicator probe > with a plate, that weights about 11oz, in the next bay out board of the > strut mount on my left wing. Should I add an equivalent amount of weight > in the right wing for balance? > > Thanks, > > Nick Cassara > Palmer, AK > > Kolbra #1 Prototype > > > ________________________________ Message 2 _____________________________________ > > > Subject: Re: Kolb-List: Weight in one wing...? > From: Charlie England <ceengland7(at)gmail.com> > > LRI's are basically angle of attack indicators. I suppose you could > argue that you don't need them on an ultralite (type) a/c, but then, we > don't know how he intends to use the a/c. US Navy pilots depend on AOA > indicators to land on carriers safely, and some 'bush' pilots do, too. > > As far as balance goes, odds are high that component tolerances and > build errors will easily mask an 11 oz weight difference. On a plane > with wing tanks, just over 0.1 gallons of fuel difference between tanks > would cause that much imbalance. > > Charlie > >> On 1/9/2016 12:29 PM, Patrick Ladd wrote: >> I installed a Lift Reserve Indicator probe with a plate>> >> What the hell is that and why do you need it.Particularly if you are >> adding 11 ozs. Totally ignorant. Pat >> *From:* Nick Cassara >> *Sent:* Monday, January 4, 2016 7:56 PM >> *To:* kolb-list(at)matronics.com >> *Subject:* Kolb-List: Weight in one wing...? >> >> Hello Kolber flyers, >> >> I am covering my left wing. I installed a Lift Reserve Indicator probe >> with a plate, that weights about 11oz, in the next bay out board of >> the strut mount on my left wing. Should I add an equivalent amount of >> weight in the right wing for balance? >> >> Thanks, >> >> Nick Cassara >> Palmer, AK >> >> Kolbra #1 p; -- Please Support Your Lists This Month (And Get >> Annual List below to Incentive Gifts >> href="http://www.matronics.com/contribution">http://www.matronics.com/cThank >> you for your generous ; -Matt Dralle, List >> nbsp; Navigator Photoshare, and >> href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronicp; >> the Web href="http://forums.matronics.com">http://forums.matronics.com >> _p; generous bsp; >> href="http://www.matronics.com/contribution">http://www.matronics.com/c=============== > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 10, 2016
Keith Nothing personal, but you are VERY uninformed (AKA ignorant) about Kolbs. Do a little research Russ K > On Jan 10, 2016, at 2:28 PM, Keith Callfas wrote: > > > You people act like these are airplanes they are air carts not ment to fly any were but up and around! > > --- Original Message --- > > From: "Kolb-List Digest Server" <kolb-list(at)matronics.com> > Sent: January 10, 2016 2:14 AM > To: "Kolb-List Digest List" > Subject: Kolb-List Digest: 2 Msgs - 01/09/16 > > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-01-09&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 16-01-09&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Sat 01/09/16: 2 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 10:29 AM - Re: Weight in one wing...? (Patrick Ladd) > 2. 12:00 PM - Re: Weight in one wing...? (Charlie England) > > > > ________________________________ Message 1 _____________________________________ > > > From: Patrick Ladd <patrickjladd(at)hotmail.com> > Subject: Re: Kolb-List: Weight in one wing...? > > I installed a Lift Reserve Indicator probe with a plate>> > > What the hell is that and why do you need it.Particularly if you are > adding 11 ozs. Totally ignorant. Pat > > From: Nick Cassara > Sent: Monday, January 4, 2016 7:56 PM > Subject: Kolb-List: Weight in one wing...? > > > Hello Kolber flyers, > > I am covering my left wing. I installed a Lift Reserve Indicator probe > with a plate, that weights about 11oz, in the next bay out board of the > strut mount on my left wing. Should I add an equivalent amount of weight > in the right wing for balance? > > Thanks, > > Nick Cassara > Palmer, AK > > Kolbra #1 Prototype > > > ________________________________ Message 2 _____________________________________ > > > Subject: Re: Kolb-List: Weight in one wing...? > From: Charlie England <ceengland7(at)gmail.com> > > LRI's are basically angle of attack indicators. I suppose you could > argue that you don't need them on an ultralite (type) a/c, but then, we > don't know how he intends to use the a/c. US Navy pilots depend on AOA > indicators to land on carriers safely, and some 'bush' pilots do, too. > > As far as balance goes, odds are high that component tolerances and > build errors will easily mask an 11 oz weight difference. On a plane > with wing tanks, just over 0.1 gallons of fuel difference between tanks > would cause that much imbalance. > > Charlie > > On 1/9/2016 12:29 PM, Patrick Ladd wrote: >> I installed a Lift Reserve Indicator probe with a plate>> >> What the hell is that and why do you need it.Particularly if you are >> adding 11 ozs. Totally ignorant. Pat >> *From:* Nick Cassara >> *Sent:* Monday, January 4, 2016 7:56 PM >> *To:* kolb-list(at)matronics.com >> *Subject:* Kolb-List: Weight in one wing...? >> >> Hello Kolber flyers, >> >> I am covering my left wing. I installed a Lift Reserve Indicator probe >> with a plate, that weights about 11oz, in the next bay out board of >> the strut mount on my left wing. Should I add an equivalent amount of >> weight in the right wing for balance? >> >> Thanks, >> >> Nick Cassara >> Palmer, AK >> >> Kolbra #1 p; -- Please Support Your Lists This Month (And Get >> Annual List below to Incentive Gifts >> href="http://www.matronics.com/contribution">http://www.matronics.com/cThank >> you for your generous ; -Matt Dralle, List >> nbsp; Navigator Photoshare, and >> href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronicp; >> the Web href="http://forums.matronics.com">http://forums.matronics.com >> _p; generous bsp; >> href="http://www.matronics.com/contribution">http://www.matronics.com/c=============== >> >> > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 10, 2016
No they only fly short hops like this: http://www.kolbaircraft.com/johnhauck2.htm > On Jan 10, 2016, at 12:28 , Keith Callfas wrote: > > > You people act like these are airplanes they are air carts not ment to fly any were but up and around! > > --- Original Message --- > > From: "Kolb-List Digest Server" <kolb-list(at)matronics.com> > Sent: January 10, 2016 2:14 AM > To: "Kolb-List Digest List" > Subject: Kolb-List Digest: 2 Msgs - 01/09/16 > > > * > > ======================== > Online Versions of Today's List Digest Archive > ======================== > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&C hapter 16-01-09&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Ch apter 16-01-09&Archive=Kolb > > > ======================== ======================= > EMail Version of Today's List Digest Archive > ======================== ======================= > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Sat 01/09/16: 2 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 10:29 AM - Re: Weight in one wing...? (Patrick Ladd) > 2. 12:00 PM - Re: Weight in one wing...? (Charlie England) > > > > ________________________________ Message 1 _____________________________________ > > > From: Patrick Ladd <patrickjladd(at)hotmail.com> > Subject: Re: Kolb-List: Weight in one wing...? > > I installed a Lift Reserve Indicator probe with a plate>> > > What the hell is that and why do you need it.Particularly if you are > adding 11 ozs. Totally ignorant. Pat > > From: Nick Cassara > Sent: Monday, January 4, 2016 7:56 PM > Subject: Kolb-List: Weight in one wing...? > > > Hello Kolber flyers, > > I am covering my left wing. I installed a Lift Reserve Indicator probe > with a plate, that weights about 11oz, in the next bay out board of the > strut mount on my left wing. Should I add an equivalent amount of weight > in the right wing for balance? > > Thanks, > > Nick Cassara > Palmer, AK > > Kolbra #1 Prototype > > > ________________________________ Message 2 _____________________________________ > > > Subject: Re: Kolb-List: Weight in one wing...? > From: Charlie England <ceengland7(at)gmail.com> > > LRI's are basically angle of attack indicators. I suppose you could > argue that you don't need them on an ultralite (type) a/c, but then, we > don't know how he intends to use the a/c. US Navy pilots depend on AOA > indicators to land on carriers safely, and some 'bush' pilots do, too. > > As far as balance goes, odds are high that component tolerances and > build errors will easily mask an 11 oz weight difference. On a plane > with wing tanks, just over 0.1 gallons of fuel difference between tanks > would cause that much imbalance. > > Charlie > > On 1/9/2016 12:29 PM, Patrick Ladd wrote: >> I installed a Lift Reserve Indicator probe with a plate>> >> What the hell is that and why do you need it.Particularly if you are >> adding 11 ozs. Totally ignorant. Pat >> *From:* Nick Cassara >> *Sent:* Monday, January 4, 2016 7:56 PM >> *To:* kolb-list(at)matronics.com >> *Subject:* Kolb-List: Weight in one wing...? >> >> Hello Kolber flyers, >> >> I am covering my left wing. I installed a Lift Reserve Indicator probe >> with a plate, that weights about 11oz, in the next bay out board of >> the strut mount on my left wing. Should I add an equivalent amount of >> weight in the right wing for balance? >> >> Thanks, >> >> Nick Cassara >> Palmer, AK >> >> Kolbra #1 p; -- Please Support Your Lists This Month (And Get >> Annual List below to Incentive Gifts >> href="http://www.matronics.com/contribution">http://www.matronics.com/cT hank >> you for your generous ; -Matt Dralle, List >> nbsp; Navigator Photoshare, and >> href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronicp ; >> the Web href="http://forums.matronics.com">http://forums.matronics.com >> _p; generous bsp; >> href="http://www.matronics.com/contribution">http://www.matronics.com/c= ============== >> >> > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: RE: Kolb-List Digest: 14 Msgs - 01/10/16
Date: Jan 11, 2016
I have two also have well over 100 hours driving ultralight of many kinds t he base for all of Kolb but at best a mark Xtra is a over grown Firestarter they are not mentioned to have glass cockpits rockets bombs or all the stu ff people want to stuff in the wings they are ment to have fun with not to fly to Alaska in sorry but you asked for my 2 cents Sent from my Verizon Wireless 4G LTE smartphone -------- Original message -------- From: Kolb-List Digest Server <kolb-list(at)matronics.com> Date: 01/11/2016 3:04 AM (GMT-06:00) Subject: Kolb-List Digest: 14 Msgs - 01/10/16 * ======================== Online Versions of Today's List Digest Archive ======================== Today's complete Kolb-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Kolb-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=htm l&Chapter 16-01-10&Archive=Kolb Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt &Chapter 16-01-10&Archive=Kolb ======================== ======================= EMail Version of Today's List Digest Archive ======================== ======================= ---------------------------------------------------------- Kolb-List Digest Archive --- Total Messages Posted Sun 01/10/16: 14 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 03:30 AM - Re: Weight in one wing...? (Patrick Ladd) 2. 07:58 AM - Re: Weight in one wing...? (Martin Koxxy) 3. 09:12 AM - Re: Re: Horizontal stabilizer seals (Richard Girard) 4. 09:37 AM - Re: Re: Horizontal stabilizer seals (william sullivan) 5. 10:15 AM - Re: Re: Horizontal stabilizer seals (Charlie England) 6. 11:43 AM - Re: Re: Horizontal stabilizer seals (mojavjoe(at)comcast.n et) 7. 11:44 AM - Re: Kolb-List Digest: 2 Msgs - 01/09/16 (Keith Callfas) 8. 11:47 AM - Re: Re: Aileron trim (Jack B. Hart) 9. 12:11 PM - Re: Re: Horizontal stabilizer seals (Jack B. Hart) 10. 12:59 PM - Re: Re: Horizontal stabilizer seals (John Hauck) 11. 01:07 PM - Re: Re: Kolb-List Digest: 2 Msgs - 01/09/16 (John Hauck ) 12. 01:29 PM - Re: Re: Kolb-List Digest: 2 Msgs - 01/09/16 (Richard Ne ilsen) 13. 05:13 PM - Re: Re: Kolb-List Digest: 2 Msgs - 01/09/16 (kinne russ ) 14. 06:20 PM - Re: Re: Kolb-List Digest: 2 Msgs - 01/09/16 (Bradley Na tion) ________________________________ Message 1 ______________________________ _______ From: Patrick Ladd <patrickjladd(at)hotmail.com> Subject: Re: Kolb-List: Weight in one wing...? Hi Charlie, i suppose what I was asking in a guarded manner was why would anyone in a ultralight, or indeed any light aircraft want an unnecessary complication like this. Still we all pimp our rides to suit ourselves. As far as the extra 11 ozs goes I would have thought that in the fight to keep ultralight below the legal weight limit even 11 ozs. needs to be watched. Weight increases naturally after the initial weighing anyway with radios, GPS, cameras etc. The guy who built my Extra added all sorts of odd little brackets or a bit of stiffening or beefing up wherever he saw what he considered a weak point. All without consulting me a couple of hundred miles away. This caused all sorts of fancy maths to get her certified as a microlight. Cheers Pat From: Charlie England Sent: Saturday, January 9, 2016 8:00 PM Subject: Re: Kolb-List: Weight in one wing...? LRI's are basically angle of attack indicators. I suppose you could argue that you don't need them on an ultralite (type) a/c, but then, we don't know how he intends to use the a/c. US Navy pilots depend on AOA indicators to land on carriers safely, and some 'bush' pilots do, too. As far as balance goes, odds are high that component tolerances and build errors will easily mask an 11 oz weight difference. On a plane with wing tanks, just over 0.1 gallons of fuel difference between tanks would cause that much imbalance. Charlie On 1/9/2016 12:29 PM, Patrick Ladd wrote: I installed a Lift Reserve Indicator probe with a plate>> What the hell is that and why do you need it.Particularly if you are adding 11 ozs. Totally ignorant. Pat From: Nick Cassara Sent: Monday, January 4, 2016 7:56 PM To: kolb-list(at)matronics.com Subject: Kolb-List: Weight in one wing...? mailto:nickc(at)mtaonline.net Hello Kolber flyers, I am covering my left wing. I installed a Lift Reserve Indicator probe with a plate, that weights about 11oz, in the next bay out board of the strut mount on my left wing. Should I add an equivalent amount of weight in the right wing for balance? Thanks, Nick Cassara Palmer, AK Kolbra #1 p; -- Please Support Your Lists This Month (And Get Annual List below to Incentive Gifts href="http://www.matronics.com/contribution">http://www.matronics.com/c Thank you for your generous ; -Matt Dralle, List nbsp; Navigator Photoshare, and href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronic p; the Web href="http://forums.matronics.com">http://forums.matronics.com _p; generous bsp; href="http://www.matronics.com/contribution">http://www.matronics.com/c =============== ________________________________ Message 2 ______________________________ _______ Subject: Re: Kolb-List: Weight in one wing...? From: Martin Koxxy <martinkoxxy(at)gmail.com> Mark Beierle, the designer of the Earthstar line of planes (Thundergull, Gull 2000, Odyssey), makes exactly that point. Ultralights and near-ultralights tend to be flown a lot more by seat-of-the-pants and exterior view clues than by instruments, and the added weight and complication goes contrary to the Ultralight "spirit". That said, while learning to fly my eGull, I would have appreciated an LRI or AOA (angle of attack) indicator to calibrate myself. But now, after only 10 hours, I can tell this calibration process is well under way, and my instrument scans are getting shorter and less frequent, with more attention paid to the sight picture (and traffic in the pattern). Weight: If I had gone through with an AOA instrument, I would have added only a second, angled pitot tube and hose, and my GRT EFIS would have been able to display AOA on the screen - a weight penalty in the 3-4 oz range. On Sun, Jan 10, 2016 at 3:29 AM, Patrick Ladd wrote: > Hi Charlie, > i suppose what I was asking in a guarded manner was why would anyone in a > ultralight, or indeed any light aircraft want an unnecessary complication > like this. Still we all pimp our rides to suit ourselves. As far as the > extra 11 ozs goes I would have thought that in the fight to keep ultralig ht > below the legal weight limit even 11 ozs. needs to be watched. Weight > increases naturally after the initial weighing anyway with radios, GPS, > cameras etc. > The guy who built my Extra added all sorts of odd little brackets or a bi t > of stiffening or beefing up wherever he saw what he considered a weak > point. All without consulting me a couple of hundred miles away. This > caused all sorts of fancy maths to get her certified as a microlight. > Cheers > Pat > > *From:* Charlie England > *Sent:* Saturday, January 9, 2016 8:00 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: Weight in one wing...? > > LRI's are basically angle of attack indicators. I suppose you could argue > that you don't need them on an ultralite (type) a/c, but then, we don't > know how he intends to use the a/c. US Navy pilots depend on AOA indicato rs > to land on carriers safely, and some 'bush' pilots do, too. > > As far as balance goes, odds are high that component tolerances and build > errors will easily mask an 11 oz weight difference. On a plane with wing > tanks, just over 0.1 gallons of fuel difference between tanks would cause > that much imbalance. > > Charlie > > On 1/9/2016 12:29 PM, Patrick Ladd wrote: > > I installed a Lift Reserve Indicator probe with a plate>> > > What the hell is that and why do you need it.Particularly if you are > adding 11 ozs. Totally ignorant. Pat > > *From:* Nick Cassara > *Sent:* Monday, January 4, 2016 7:56 PM > *To:* kolb-list(at)matronics.com > *Subject:* Kolb-List: Weight in one wing...? > > > > Hello Kolber flyers, > > I am covering my left wing. I installed a Lift Reserve Indicator probe > with a plate, that weights about 11oz, in the next bay out board of the > strut mount on my left wing. Should I add an equivalent amount of weight in > the right wing for balance? > > Thanks, > > Nick Cassara > Palmer, AK > > Kolbra #1 p; -- Please Support Your Lists This Month (And Get Annual > List below to Incentive Gifts href="http://www.matronics.com/contributi on" > <http://www.matronics.com/contribution>>http://www.matronics.com/cThank > you for your generous ; -Matt Dralle, List nbsp; > Navigator Photoshare, and href > "http://www.matronics.com/Navigator?Kolb-List" > <http://www.matronics.com/Navigator?Kolb-List>>http://www.matronicp; > the Web href="http://forums.matronics.com" > > http://forums.matronics.com > _p; generous bsp; href > "http://www.matronics.com/contribution" > <http://www.matronics.com/contribution>> > http://www.matronics.com/c=============== > > ________________________________ Message 3 ______________________________ _______ Subject: Re: Kolb-List: Re: Horizontal stabilizer seals From: Richard Girard <aslsa.rng(at)gmail.com> I believe what happens is that the air leaking through the slot between the horizontal stabilizer and the boom tube causes the flow to go more vertically over the rudder rather than horizontally. I base this on the results of tuft testing I did on the Mk III's rear fuselage segment as seen in the video I shot of the tests: https://www.youtube.com/watch?v=IG796iiymYw I attached photos of the gap seals to the original post but just in case...... The photo shows the second set of seals with their peel ply covering with the first set of seals all trimmed up and ready to bond to the second set when they are cured and trimmed. This style of construction was only possible because the "plane from hell" had the horizontal stabilizer set on the center line of the tube. Rick On Thu, Jan 7, 2016 at 11:49 PM, wakataka wrote: > > Any idea why sealing the elevator gap had such an effect on the rudder > effectiveness? I wouldn't have expected that. > > I'd love to see a photo of the seals you built. I'm planning to recover m y > Firestar next year and gap seals are one of the things I need to figure o ut > how to install. > > -------- > There is something fascinating about science. One gets such wholesale > returns of conjecture out of such a trifling investment of fact. > > Mark Twain > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=451801#451801 > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________ Message 4 ______________________________ _______ From: william sullivan <williamtsullivan(at)att.net> Subject: Re: Kolb-List: Re: Horizontal stabilizer seals Rick- How do you fold it? It looks to be a rigid assembly. Bill Sullivan ________________________________ Message 5 ______________________________ _______ Subject: Re: Kolb-List: Re: Horizontal stabilizer seals From: Charlie England <ceengland7(at)gmail.com> Wouldn't the air be going *down* through the tube-stabilizer gap? (Higher pressure on top of the tail.) That would still reduce the rudder's effectiveness, since vertical flow would disrupt horizontal flow across the rudder. On Sun, Jan 10, 2016 at 10:56 AM, Richard Girard wrote: > I believe what happens is that the air leaking through the slot between > the horizontal stabilizer and the boom tube causes the flow to go more > vertically over the rudder rather than horizontally. I base this on the > results of tuft testing I did on the Mk III's rear fuselage segment as se en > in the video I shot of the tests: > > https://www.youtube.com/watch?v=IG796iiymYw > > I attached photos of the gap seals to the original post but just in > case...... The photo shows the second set of seals with their peel ply > covering with the first set of seals all trimmed up and ready to bond to > the second set when they are cured and trimmed. This style of constructio n > was only possible because the "plane from hell" had the horizontal > stabilizer set on the center line of the tube. > > Rick > > > On Thu, Jan 7, 2016 at 11:49 PM, wakataka wrote: > >> >> Any idea why sealing the elevator gap had such an effect on the rudder >> effectiveness? I wouldn't have expected that. >> >> I'd love to see a photo of the seals you built. I'm planning to recover >> my Firestar next year and gap seals are one of the things I need to figu re >> out how to install. >> >> -------- >> There is something fascinating about science. One gets such wholesale >> returns of conjecture out of such a trifling investment of fact. >> >> Mark Twain >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=451801#451801 >> >> >> >> >> >> >> >> ========= >> br> fts!) >> r> > w.buildersbooks.com" rel="noreferrer" target="_blank"> >> www.buildersbooks.com<http://www.buildersbooks.com> >> rel="noreferrer" target="_blank">http://www.matronics.com/contributi on >> -Matt Dralle, List Admin. >> ========= >> -List" rel="noreferrer" target="_blank"> >> http://www.matronics.com/Navigator?Kolb-List >> ========= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributi on >> ========= >> >> >> >> > > > -- > =9CBlessed are the cracked, for they shall let in the light. =9D Groucho Marx > <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > ________________________________ Message 6 ______________________________ _______ From: mojavjoe(at)comcast.net Subject: Re: Kolb-List: Re: Horizontal stabilizer seals Couldn't the seals be attached to the boom tube under the horizontal stab. so it could be folded. Also if properly braced it might take the place of t he upper wire bracing. ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Sunday, January 10, 2016 1:06:25 PM Subject: Re: Kolb-List: Re: Horizontal stabilizer seals Wouldn't the air be going *down* through the tube-stabilizer gap? (Higher p ressure on top of the tail.) That would still reduce the rudder's effective ness, since vertical flow would disrupt horizontal flow across the rudder. On Sun, Jan 10, 2016 at 10:56 AM, Richard Girard < aslsa.rng(at)gmail.com > wr ote: I believe what happens is that the air leaking through the slot between the horizontal stabilizer and the boom tube causes the flow to go more vertica lly over the rudder rather than horizontally. I base this on the results of tuft testing I did on the Mk III's rear fuselage segment as seen in the vi deo I shot of the tests: https://www.youtube.com/watch?v=IG796iiymYw I attached photos of the gap seals to the original post but just in case... ... The photo shows the second set of seals with their peel ply covering wi th the first set of seals all trimmed up and ready to bond to the second se t when they are cured and trimmed. This style of construction was only poss ible because the "plane from hell" had the horizontal stabilizer set on the center line of the tube. Rick On Thu, Jan 7, 2016 at 11:49 PM, wakataka < wakataka(at)charter.net > wrote:
Any idea why sealing the elevator gap had such an effect on the rudder effe ctiveness? I wouldn't have expected that. I'd love to see a photo of the seals you built. I'm planning to recover my Firestar next year and gap seals are one of the things I need to figure out how to install. -------- There is something fascinating about science. One gets such wholesale retur ns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=451801#451801 br> fts!) r> > w.buildersbooks.com " rel="noreferrer" target="_blank"> www.builde rsbooks.com rel="noreferrer" target="_blank"> http://www.matronics.com/contribution -Matt Dralle, List Admin. -List" rel="noreferrer" target="_blank"> http://www.matronics.com/Navig ator?Kolb-List FORUMS - eferrer" target="_blank"> http://forums.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank"> http://www.matronics.com/contribution -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx
________________________________ Message 7 ______________________________ _______ From: Keith Callfas <kkcmax(at)msn.com> Subject: Kolb-List: RE: Kolb-List Digest: 2 Msgs - 01/09/16 You people act like these are airplanes they are air carts not ment to fly any were but up and around! --- Original Message --- From: "Kolb-List Digest Server" <kolb-list(at)matronics.com> Sent: January 10, 2016 2:14 AM Subject: Kolb-List Digest: 2 Msgs - 01/09/16 * ======================== ======================== Online Versions of Today's List Digest Archive ======================== ======================== Today's complete Kolb-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Kolb-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=htm l&Chapter 16-01-09&Archive=Kolb Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt &Chapter 16-01-09&Archive=Kolb ======================== ====================== EMail Version of Today's List Digest Archive ======================== ====================== ---------------------------------------------------------- Kolb-List Digest Archive --- Total Messages Posted Sat 01/09/16: 2 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 10:29 AM - Re: Weight in one wing...? (Patrick Ladd) 2. 12:00 PM - Re: Weight in one wing...? (Charlie England) ________________________________ Message 1 ______________________________ _______ From: Patrick Ladd <patrickjladd(at)hotmail.com> Subject: Re: Kolb-List: Weight in one wing...? I installed a Lift Reserve Indicator probe with a plate>> What the hell is that and why do you need it.Particularly if you are adding 11 ozs. Totally ignorant. Pat From: Nick Cassara Sent: Monday, January 4, 2016 7:56 PM Subject: Kolb-List: Weight in one wing...? Hello Kolber flyers, I am covering my left wing. I installed a Lift Reserve Indicator probe with a plate, that weights about 11oz, in the next bay out board of the strut mount on my left wing. Should I add an equivalent amount of weight in the right wing for balance? Thanks, Nick Cassara Palmer, AK Kolbra #1 Prototype ________________________________ Message 2 ______________________________ _______ Subject: Re: Kolb-List: Weight in one wing...? From: Charlie England <ceengland7(at)gmail.com> LRI's are basically angle of attack indicators. I suppose you could argue that you don't need them on an ultralite (type) a/c, but then, we don't know how he intends to use the a/c. US Navy pilots depend on AOA indicators to land on carriers safely, and some 'bush' pilots do, too. As far as balance goes, odds are high that component tolerances and build errors will easily mask an 11 oz weight difference. On a plane with wing tanks, just over 0.1 gallons of fuel difference between tanks would cause that much imbalance. Charlie On 1/9/2016 12:29 PM, Patrick Ladd wrote: > I installed a Lift Reserve Indicator probe with a plate>> > What the hell is that and why do you need it.Particularly if you are > adding 11 ozs. Totally ignorant. Pat > *From:* Nick Cassara > *Sent:* Monday, January 4, 2016 7:56 PM > *To:* kolb-list(at)matronics.com > *Subject:* Kolb-List: Weight in one wing...? > > Hello Kolber flyers, > > I am covering my left wing. I installed a Lift Reserve Indicator probe > with a plate, that weights about 11oz, in the next bay out board of > the strut mount on my left wing. Should I add an equivalent amount of > weight in the right wing for balance? > > Thanks, > > Nick Cassara > Palmer, AK > > Kolbra #1 p; -- Please Support Your Lists This Month (And Get > Annual List below to Incentive Gifts > href="http://www.matronics.com/contribution">http://www.matronics.com/c Thank > you for your generous ; -Matt Dralle, List > nbsp; Navigator Photoshare, and > href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronic p; > the Web href="http://forums.matronics.com">http://forums.matronics.com > _p; generous bsp; > href="http://www.matronics.com/contribution">http://www.matronics.com/c ============== > > ________________________________ Message 8 ______________________________ _______ From: "Jack B. Hart" <jbhart(at)onlyinternet.net> Subject: Re: Kolb-List: Re: Aileron trim From: Richard Girard --------------------------- < Doubtful it is caused by torque, at least no Kolb I've ever flown has had the tendency. > ------------------------- If you have an engine on an aircraft there will always be a torque component in play as long as the engine is operating under load. For example, a Rotax 912 81 hp engine generates 75.9 ft-lb torque at 4800 rpm. Add a 2.43:1 gear box and the torque at the propeller goes to 184 ft-lb. This means it will take about an 18 lb vertical force at the wing tip to keep the wings level. Jack B. Hart FF004 Winchester, IN ________________________________ Message 9 ______________________________ _______ From: "Jack B. Hart" <jbhart(at)onlyinternet.net> Subject: Re: Kolb-List: Re: Horizontal stabilizer seals >At 11:56 AM 1/10/2016, you wrote: I believe what happens is that the air leaking through the slot between the horizontal stabilizer and the boom tube causes the flow to go more vertically over the rudder rather than horizontally. I base this on the results of tuft testing I did on the Mk III's rear fuselage segment as seen in the video I shot of the tests: > Rick, I believe if you check it out you will find that while you are in level flight the tail has to exert a downward force. This means the air pressure on top of the horizontal stabilizer will be greater than that found on the bottom side. Air will always move from high to low pressure. So, if any air is moving through the gap, it will be down through the gap not up. Jack B. Hart FF004 Winchester, IN ________________________________ Message 10 _____________________________ _______ From: "John Hauck" <jhauck(at)elmore.rr.com> Subject: RE: Kolb-List: Re: Horizontal stabilizer seals What if the tail section is on a few feet from the prop which is generating a very strong rotating column of air directly on the tail section? Air flow over the tail of a Kolb is interesting based on prop wash. I get a pretty good idea of what the air is doing based on crankcase residue being blown from the vent tube and sticking to the tail section. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack B. Hart Sent: Sunday, January 10, 2016 1:56 PM Subject: Re: Kolb-List: Re: Horizontal stabilizer seals --> >At 11:56 AM 1/10/2016, you wrote: I believe what happens is that the air leaking through the slot between the horizontal stabilizer and the boom tube causes the flow to go more vertically over the rudder rather than horizontally. I base this on the results of tuft testing I did on the Mk III's rear fuselage segment as seen in the video I shot of the tests: > Rick, I believe if you check it out you will find that while you are in level flight the tail has to exert a downward force. This means the air pressure on top of the horizontal stabilizer will be greater than that found on the bottom side. Air will always move from high to low pressure. So, if any air is moving through the gap, it will be down through the gap not up. Jack B. Hart FF004 Winchester, IN ________________________________ Message 11 _____________________________ _______ From: "John Hauck" <jhauck(at)elmore.rr.com> Subject: RE: Kolb-List: RE: Kolb-List Digest: 2 Msgs - 01/09/16 Keith Callfas: Where did you get your information on Kolbs? Kolbs are definitely airplanes. They have fixed wings, an engine, and fly. I don't know what you mean by up and around. I know a few Kolbs that have flown and are still flying up and around all over the US, Canada, and Alaska. Are you familiar with Kolb aircraft? john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Keith Callfas Sent: Sunday, January 10, 2016 1:29 PM Subject: Kolb-List: RE: Kolb-List Digest: 2 Msgs - 01/09/16 You people act like these are airplanes they are air carts not ment to fly any were but up and around! --- Original Message --- From: "Kolb-List Digest Server" <kolb-list(at)matronics.com> Sent: January 10, 2016 2:14 AM Subject: Kolb-List Digest: 2 Msgs - 01/09/16 * ======================== ======================== Online Versions of Today's List Digest Archive ======================= Today's complete Kolb-List Digest can also be found in either of the two We b Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Kolb-Lis t Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch apter 16-01-09&Archive=Kolb Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha pter 2016-01-09&Archive=Kolb ======================== ====================== EMail Version of Today's List Digest Archive ===================== ---------------------------------------------------------- Kolb-List Digest Archive --- Total Messages Posted Sat 01/09/16: 2 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 10:29 AM - Re: Weight in one wing...? (Patrick Ladd) 2. 12:00 PM - Re: Weight in one wing...? (Charlie England) ________________________________ Message 1 _____________________________________ From: Patrick Ladd <patrickjladd(at)hotmail.com> Subject: Re: Kolb-List: Weight in one wing...? I installed a Lift Reserve Indicator probe with a plate>> What the hell is that and why do you need it.Particularly if you are addin g 11 ozs. Totally ignorant. Pat From: Nick Cassara Sent: Monday, January 4, 2016 7:56 PM Subject: Kolb-List: Weight in one wing...? Hello Kolber flyers, I am covering my left wing. I installed a Lift Reserve Indicator probe with a plate, that weights about 11oz, in the next bay out board of the strut mount on my left wing. Should I add an equivalent amount of weight in the right wing for balance? Thanks, Nick Cassara Palmer, AK Kolbra #1 Prototype ________________________________ Message 2 _____________________________________ Subject: Re: Kolb-List: Weight in one wing...? From: Charlie England <ceengland7(at)gmail.com> LRI's are basically angle of attack indicators. I suppose you could argue that you don't need them on an ultralite (type) a/c, but then, we don't kno w how he intends to use the a/c. US Navy pilots depend on AOA indicators to land on carriers safely, and some 'bush' pilots do, too. As far as balance goes, odds are high that component tolerances and build errors will easily mask an 11 oz weight difference. On a plane with wing tanks, just over 0.1 gallons of fuel difference between tanks would cause that much imbalance. Charlie On 1/9/2016 12:29 PM, Patrick Ladd wrote: > I installed a Lift Reserve Indicator probe with a plate>> What the > hell is that and why do you need it.Particularly if you are adding 11 > ozs. Totally ignorant. Pat > *From:* Nick Cassara > *Sent:* Monday, January 4, 2016 7:56 PM > *To:* kolb-list(at)matronics.com > *Subject:* Kolb-List: Weight in one wing...? > > Hello Kolber flyers, > > I am covering my left wing. I installed a Lift Reserve Indicator probe > with a plate, that weights about 11oz, in the next bay out board of > the strut mount on my left wing. Should I add an equivalent amount of > weight in the right wing for balance? > > Thanks, > > Nick Cassara > Palmer, AK > > Kolbra #1 p; -- Please Support Your Lists This Month (And Get > Annual List below to Incentive Gifts > href="http://www.matronics.com/contribution">http://www.matronics.com/cTh ank > you for your generous ; -Matt Dralle, List > nbsp; Navigator Photoshare, and > href="http://www.matronics.com/Navigator?Kolb-List">http://www.matroni > cp; the Web > href="http://forums.matronics.com">http://forums.matronics.com > _p; generous bsp; > href="http://www.matronics.com/contribution">http://www.matronics.com/ > c============== > > ________________________________ Message 12 _____________________________ _______ From: Richard Neilsen <neilsenrm(at)gmail.com> Subject: Re: Kolb-List: RE: Kolb-List Digest: 2 Msgs - 01/09/16 Keith Did you know you were posting to the Kolb list??? Many of our planes fly su bstantial distances. I was a bit insulted. Rick Neilsen Redrive VW Powered MkIII Sent from my iPhone > On Jan 10, 2016, at 2:28 PM, Keith Callfas wrote: > > > You people act like these are airplanes they are air carts not ment to fl y any were but up and around! > > --- Original Message --- > > From: "Kolb-List Digest Server" <kolb-list(at)matronics.com> > Sent: January 10, 2016 2:14 AM > To: "Kolb-List Digest List" > Subject: Kolb-List Digest: 2 Msgs - 01/09/16 > > > * > > ======================== ======================== > Online Versions of Today's List Digest Archive > ======================== ======================== > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=ht ml&Chapter 16-01-09&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=tx t&Chapter 16-01-09&Archive=Kolb > > > ======================== ====================== > EMail Version of Today's List Digest Archive > ======================== ====================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Sat 01/09/16: 2 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 10:29 AM - Re: Weight in one wing...? (Patrick Ladd) > 2. 12:00 PM - Re: Weight in one wing...? (Charlie England) > > > ________________________________ Message 1 ____________________________ _________ > > > From: Patrick Ladd <patrickjladd(at)hotmail.com> > Subject: Re: Kolb-List: Weight in one wing...? > > I installed a Lift Reserve Indicator probe with a plate>> > > What the hell is that and why do you need it.Particularly if you are > adding 11 ozs. Totally ignorant. Pat > > From: Nick Cassara > Sent: Monday, January 4, 2016 7:56 PM > Subject: Kolb-List: Weight in one wing...? > > > Hello Kolber flyers, > > I am covering my left wing. I installed a Lift Reserve Indicator probe > with a plate, that weights about 11oz, in the next bay out board of the > strut mount on my left wing. Should I add an equivalent amount of weight > in the right wing for balance? > > Thanks, > > Nick Cassara > Palmer, AK > > Kolbra #1 Prototype > > > ________________________________ Message 2 ____________________________ _________ > > > Subject: Re: Kolb-List: Weight in one wing...? > From: Charlie England <ceengland7(at)gmail.com> > > LRI's are basically angle of attack indicators. I suppose you could > argue that you don't need them on an ultralite (type) a/c, but then, we > don't know how he intends to use the a/c. US Navy pilots depend on AOA > indicators to land on carriers safely, and some 'bush' pilots do, too. > > As far as balance goes, odds are high that component tolerances and > build errors will easily mask an 11 oz weight difference. On a plane > with wing tanks, just over 0.1 gallons of fuel difference between tanks > would cause that much imbalance. > > Charlie > >> On 1/9/2016 12:29 PM, Patrick Ladd wrote: >> I installed a Lift Reserve Indicator probe with a plate>> >> What the hell is that and why do you need it.Particularly if you are >> adding 11 ozs. Totally ignorant. Pat >> *From:* Nick Cassara >> *Sent:* Monday, January 4, 2016 7:56 PM >> *To:* kolb-list(at)matronics.com >> *Subject:* Kolb-List: Weight in one wing...? >> >> Hello Kolber flyers, >> >> I am covering my left wing. I installed a Lift Reserve Indicator probe >> with a plate, that weights about 11oz, in the next bay out board of >> the strut mount on my left wing. Should I add an equivalent amount of >> weight in the right wing for balance? >> >> Thanks, >> >> Nick Cassara >> Palmer, AK >> >> Kolbra #1 p; -- Please Support Your Lists This Month (And Get >> Annual List below to Incentive Gifts >> href="http://www.matronics.com/contribution">http://www.matronics.com/ cThank >> you for your generous ; -Matt Dralle, List >> nbsp; Navigator Photoshare, and >> href="http://www.matronics.com/Navigator?Kolb-List">http://www.matroni cp; >> the Web href="http://forums.matronics.com">http://forums.matronics.com >> _p; generous bsp; >> href="http://www.matronics.com/contribution">http://www.matronics.com/ c============== > > ________________________________ Message 13 _____________________________ _______ Subject: Re: Kolb-List: RE: Kolb-List Digest: 2 Msgs - 01/09/16 From: kinne russ <russk50(at)gmail.com> Keith Nothing personal, but you are VERY uninformed (AKA ignorant) about Kolbs. Do a little research Russ K > On Jan 10, 2016, at 2:28 PM, Keith Callfas wrote: > > > You people act like these are airplanes they are air carts not ment to fl y any were but up and around! > > --- Original Message --- > > From: "Kolb-List Digest Server" <kolb-list(at)matronics.com> > Sent: January 10, 2016 2:14 AM > To: "Kolb-List Digest List" > Subject: Kolb-List Digest: 2 Msgs - 01/09/16 > > > * > > ======================== ======================== > Online Versions of Today's List Digest Archive > ======================== ======================== > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=ht ml&Chapter 16-01-09&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=tx t&Chapter 16-01-09&Archive=Kolb > > > ======================== ====================== > EMail Version of Today's List Digest Archive > ======================== ====================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Sat 01/09/16: 2 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 10:29 AM - Re: Weight in one wing...? (Patrick Ladd) > 2. 12:00 PM - Re: Weight in one wing...? (Charlie England) > > > ________________________________ Message 1 ____________________________ _________ > > > From: Patrick Ladd <patrickjladd(at)hotmail.com> > Subject: Re: Kolb-List: Weight in one wing...? > > I installed a Lift Reserve Indicator probe with a plate>> > > What the hell is that and why do you need it.Particularly if you are > adding 11 ozs. Totally ignorant. Pat > > From: Nick Cassara > Sent: Monday, January 4, 2016 7:56 PM > Subject: Kolb-List: Weight in one wing...? > > > Hello Kolber flyers, > > I am covering my left wing. I installed a Lift Reserve Indicator probe > with a plate, that weights about 11oz, in the next bay out board of the > strut mount on my left wing. Should I add an equivalent amount of weight > in the right wing for balance? > > Thanks, > > Nick Cassara > Palmer, AK > > Kolbra #1 Prototype > > > ________________________________ Message 2 ____________________________ _________ > > > Subject: Re: Kolb-List: Weight in one wing...? > From: Charlie England <ceengland7(at)gmail.com> > > LRI's are basically angle of attack indicators. I suppose you could > argue that you don't need them on an ultralite (type) a/c, but then, we > don't know how he intends to use the a/c. US Navy pilots depend on AOA > indicators to land on carriers safely, and some 'bush' pilots do, too. > > As far as balance goes, odds are high that component tolerances and > build errors will easily mask an 11 oz weight difference. On a plane > with wing tanks, just over 0.1 gallons of fuel difference between tanks > would cause that much imbalance. > > Charlie > > On 1/9/2016 12:29 PM, Patrick Ladd wrote: >> I installed a Lift Reserve Indicator probe with a plate>> >> What the hell is that and why do you need it.Particularly if you are >> adding 11 ozs. Totally ignorant. Pat >> *From:* Nick Cassara >> *Sent:* Monday, January 4, 2016 7:56 PM >> *To:* kolb-list(at)matronics.com >> *Subject:* Kolb-List: Weight in one wing...? >> >> Hello Kolber flyers, >> >> I am covering my left wing. I installed a Lift Reserve Indicator probe >> with a plate, that weights about 11oz, in the next bay out board of >> the strut mount on my left wing. Should I add an equivalent amount of >> weight in the right wing for balance? >> >> Thanks, >> >> Nick Cassara >> Palmer, AK >> >> Kolbra #1 p; -- Please Support Your Lists This Month (And Get >> Annual List below to Incentive Gifts >> href="http://www.matronics.com/contribution">http://www.matronics.com/ cThank >> you for your generous ; -Matt Dralle, List >> nbsp; Navigator Photoshare, and >> href="http://www.matronics.com/Navigator?Kolb-List">http://www.matroni cp; >> the Web href="http://forums.matronics.com">http://forums.matronics.com >> _p; generous bsp; >> href="http://www.matronics.com/contribution">http://www.matronics.com/ c============== >> >> > > ________________________________ Message 14 _____________________________ _______ From: Bradley Nation <nationcap(at)comcast.net> Subject: Re: Kolb-List: RE: Kolb-List Digest: 2 Msgs - 01/09/16 No they only fly short hops like this: http://www.kolbaircraft.com/johnhauck2.htm > On Jan 10, 2016, at 12:28 , Keith Callfas wrote: > > > You people act like these are airplanes they are air carts not ment to fly any were but up and around! > > --- Original Message --- > > From: "Kolb-List Digest Server" <kolb-list(at)matronics.com> > Sent: January 10, 2016 2:14 AM > To: "Kolb-List Digest List" > Subject: Kolb-List Digest: 2 Msgs - 01/09/16 > > > * > > ======================= > Online Versions of Today's List Digest Archive > ======================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&C hapter 16-01-09&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Ch apter 16-01-09&Archive=Kolb > > > ======================= ====================== > EMail Version of Today's List Digest Archive > ======================= ====================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Sat 01/09/16: 2 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 10:29 AM - Re: Weight in one wing...? (Patrick Ladd) > 2. 12:00 PM - Re: Weight in one wing...? (Charlie England) > > > ________________________________ Message 1 _____________________________________ > > > From: Patrick Ladd <patrickjladd(at)hotmail.com> > Subject: Re: Kolb-List: Weight in one wing...? > > I installed a Lift Reserve Indicator probe with a plate>> > > What the hell is that and why do you need it.Particularly if you are > adding 11 ozs. Totally ignorant. Pat > > From: Nick Cassara > Sent: Monday, January 4, 2016 7:56 PM > Subject: Kolb-List: Weight in one wing...? > > > Hello Kolber flyers, > > I am covering my left wing. I installed a Lift Reserve Indicator probe > with a plate, that weights about 11oz, in the next bay out board of the > strut mount on my left wing. Should I add an equivalent amount of weight > in the right wing for balance? > > Thanks, > > Nick Cassara > Palmer, AK > > Kolbra #1 Prototype > > > ________________________________ Message 2 _____________________________________ > > > Subject: Re: Kolb-List: Weight in one wing...? > From: Charlie England <ceengland7(at)gmail.com> > > LRI's are basically angle of attack indicators. I suppose you could > argue that you don't need them on an ultralite (type) a/c, but then, we > don't know how he intends to use the a/c. US Navy pilots depend on AOA > indicators to land on carriers safely, and some 'bush' pilots do, too. > > As far as balance goes, odds are high that component tolerances and > build errors will easily mask an 11 oz weight difference. On a plane > with wing tanks, just over 0.1 gallons of fuel difference between tanks > would cause that much imbalance. > > Charlie > > On 1/9/2016 12:29 PM, Patrick Ladd wrote: >> I installed a Lift Reserve Indicator probe with a plate>> >> What the hell is that and why do you need it.Particularly if you are >> adding 11 ozs. Totally ignorant. Pat >> *From:* Nick Cassara >> *Sent:* Monday, January 4, 2016 7:56 PM >> *To:* kolb-list(at)matronics.com >> *Subject:* Kolb-List: Weight in one wing...? >> >> Hello Kolber flyers, >> >> I am covering my left wing. I installed a Lift Reserve Indicator probe >> with a plate, that weights about 11oz, in the next bay out board of >> the strut mount on my left wing. Should I add an equivalent amount of >> weight in the right wing for balance? >> >> Thanks, >> >> Nick Cassara >> Palmer, AK >> >> Kolbra #1 p; -- Please Support Your Lists This Month (And Get >> Annual List below to Incentive Gifts >> href="http://www.matronics.com/contribution">http://www.matronics.com/cT hank >> you for your generous ; -Matt Dralle, List >> nbsp; Navigator Photoshare, and >> href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronicp ; >> the Web href="http://forums.matronics.com">http://forums.matronics.com >> _p; generous bsp; >> href="http://www.matronics.com/contribution">http://www.matronics.com/c ============= >> >> > > rsbooks.com> ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 14 Msgs - 01/10/16
Date: Jan 11, 2016
No, we didn't ask for your two cents. In your previous post you just sort of popped on, said something annoying (Like the anti-religion goober who was on last fall) because your purpose is simply to stir stuff up. You are nothing but an internet troll. Unlike the rest of us, you have never contributed anything useful to the list, or anything to edify or help anybody on this list, you are simply an annoying pest. Go away and don't come back until you learn some manners and have something useful to contribute. (And the lists's resident (and often unwelcome) pastor shakes the dust off his feet... ) -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=451868#451868 ________________________________________________________________________________
Subject: Re: Weight in one wing...?
Date: Jan 11, 2016
But now, after only 10 hours, I can tell this calibration process is well under way>> Hi Martin, Always interesting how different pilots approach their flying. Some load their planes with every gizmo known to man and some (me) bare minimum No radio even most of the time. After ten hours you shouldn`t need to look at your ASI at all when in cruise. ( Although you may need to check speed on the approach) the picture over the nose should be familiar enough to ignore the ASI. In any case if you stall through lack of attention `So What`. Unless you are near the ground or the plane drops a wing, a stall in a Kolb or similar a/c is a non event. The nose just nods, you lose a bit of height and then she flies again.. Note at what speed you stalled and don`t do it again. Cheers Pat . From: Martin Koxxy Sent: Sunday, January 10, 2016 3:43 PM Subject: Re: Kolb-List: Weight in one wing...? Mark Beierle, the designer of the Earthstar line of planes (Thundergull, Gull 2000, Odyssey), makes exactly that point. Ultralights and near-ultralights tend to be flown a lot more by seat-of-the-pants and exterior view clues than by instruments, and the added weight and complication goes contrary to the Ultralight "spirit". That said, while learning to fly my eGull, I would have appreciated an LRI or AOA (angle of attack) indicator to calibrate myself. But now, after only 10 hours, I can tell this calibration process is well under way, and my instrument scans are getting shorter and less frequent, with more attention paid to the sight picture (and traffic in the pattern). Weight: If I had gone through with an AOA instrument, I would have added only a second, angled pitot tube and hose, and my GRT EFIS would have been able to display AOA on the screen - a weight penalty in the 3-4 oz range. On Sun, Jan 10, 2016 at 3:29 AM, Patrick Ladd wrote: Hi Charlie, i suppose what I was asking in a guarded manner was why would anyone in a ultralight, or indeed any light aircraft want an unnecessary complication like this. Still we all pimp our rides to suit ourselves. As far as the extra 11 ozs goes I would have thought that in the fight to keep ultralight below the legal weight limit even 11 ozs. needs to be watched. Weight increases naturally after the initial weighing anyway with radios, GPS, cameras etc. The guy who built my Extra added all sorts of odd little brackets or a bit of stiffening or beefing up wherever he saw what he considered a weak point. All without consulting me a couple of hundred miles away. This caused all sorts of fancy maths to get her certified as a microlight. Cheers Pat From: Charlie England Sent: Saturday, January 9, 2016 8:00 PM To: kolb-list(at)matronics.com Subject: Re: Kolb-List: Weight in one wing...? LRI's are basically angle of attack indicators. I suppose you could argue that you don't need them on an ultralite (type) a/c, but then, we don't know how he intends to use the a/c. US Navy pilots depend on AOA indicators to land on carriers safely, and some 'bush' pilots do, too. As far as balance goes, odds are high that component tolerances and build errors will easily mask an 11 oz weight difference. On a plane with wing tanks, just over 0.1 gallons of fuel difference between tanks would cause that much imbalance. Charlie On 1/9/2016 12:29 PM, Patrick Ladd wrote: I installed a Lift Reserve Indicator probe with a plate>> What the hell is that and why do you need it.Particularly if you are adding 11 ozs. Totally ignorant. Pat From: Nick Cassara Sent: Monday, January 4, 2016 7:56 PM To: kolb-list(at)matronics.com Subject: Kolb-List: Weight in one wing...? mailto:nickc(at)mtaonline.net Hello Kolber flyers, I am covering my left wing. I installed a Lift Reserve Indicator probe with a plate, that weights about 11oz, in the next bay out board of the strut mount on my left wing. Should I add an equivalent amount of weight in the right wing for balance? Thanks, Nick Cassara Palmer, AK Kolbra #1 p; -- Please Support Your Lists This Month (And Get Annual List below to Incentive Gifts href="http://www.matronics.com/contribution">http://www.matronics.com/c Thank you for your generous ; -Matt Dralle, List nbsp; Navigator Photoshare, and href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronic p; the Web href="http://forums.matronics.com">http://forums.matronics.com _p; generous bsp; href="http://www.matronics.com/contribution">http://www.matronics.com/c ================ ________________________________________________________________________________
Subject: RE: Weight in one wing...?
Date: Jan 11, 2016
> I installed a Lift Reserve Indicator probe with a plate>> I am sorta remembering a DIY AOA meter that was made from mostly plastic tubing. IIRC it would only weigh a few oz. Details escape me, but I have it documented somewhere. ________________________________________________________________________________
Subject: Use of a Kolb...AOA
Date: Jan 12, 2016
Hello Kolb Flyers, Builders, and others After years of being a student of the Kolb aircraft, it is my concussion that the only limits of the Kolb Aircraft are the imaginations of the people building and flying them. As for the use and need for an AOAI live in Alaska, a fifth the size of the United State of America, however there are very few airports, and a lot more gravel bars, alpine meadows, coastal beaches, and rough patches of ice. The modern AOA instruments are very valuable to people who fly the edges." The FAA and the local flight safety organizations have been encouraging the insulation of AOAs to save pilots lives. Moose kill a number of pilots every year, stall spin accidents. Before I retired, I spent many hundreds of hours in the back seat of a Super Cub, identifying and counting wildlife with some of Alaskas best pilots, who have thousands of hour in their planes. I however am not one of Alaska best pilots, and If an AOA can keep me from making a fatal mistake the time to install, and the expense will be well worth it. Nick Cassara Palmer, Alaska 607AK Kolb Kolbra #1 ________________________________________________________________________________
Date: Jan 12, 2016
Subject: Re: Horizontal stabilizer seals
All, the reason I suspect that the flow through the slot is vertical is because I found the effectiveness of the seals while doing stall testing. When I held it in a falling leaf stall the aircraft was descending at over 1000 feet per minute. The elevator was deflected up to its limit. On top of that the greater area of the rudder is above the horizontal stabilizer. As far as propwash is concerned, the Plane from Hell had a 2.62 ratio gearbox so at idle the prop was only spinning at 900 rpm or so. On my airplane the "C" gearbox has 4.00 gears and prop rpm at idle is only 550 (it only turns 1500 at full throttle). I could detect no difference between the two airplanes. I do wish I'd tuft tested the rudder flow, but at the time I was content to get one more thing on that damnable airplane fixed that I just moved on to the next problem. Rick On Sun, Jan 10, 2016 at 2:59 PM, John Hauck wrote: > > What if the tail section is on a few feet from the prop which is generati ng > a very strong rotating column of air directly on the tail section? > > Air flow over the tail of a Kolb is interesting based on prop wash. I ge t > a > pretty good idea of what the air is doing based on crankcase residue bein g > blown from the vent tube and sticking to the tail section. > > john h > mkIII > Titus, Alabama > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack B. Hart > Sent: Sunday, January 10, 2016 1:56 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: Horizontal stabilizer seals > > --> > > >At 11:56 AM 1/10/2016, you wrote: > I believe what happens is that the air leaking through the slot between t he > horizontal stabilizer and the boom tube causes the flow to go more > vertically over the rudder rather than horizontally. I base this on the > results of tuft testing I did on the Mk III's rear fuselage segment as se en > in the video I shot of the tests: > > > > > Rick, > > I believe if you check it out you will find that while you are in level > flight the tail has to exert a downward force. This means the air pressu re > on top of the horizontal stabilizer will be greater than that found on th e > bottom side. Air will always move from high to low pressure. So, if any > air is moving through the gap, it will be down through the gap not up. > > Jack B. Hart FF004 > Winchester, IN > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Jan 12, 2016
Many years ago I made some gaps seals to go between the horizontal stab and the tube of my MKIII. The trick is having something that gets real close to the stab, but still allows the horizontal tail to fold up. Here is what I did: go to Lowes and get some 1/2" by 1/2" by 1/16" aluminum angle. Along the side that you will have next to the stab, you will glue some rubber u-channel from Aircraft Spruce, part # 05-02200 ( https://www.aircraftspruce.com/catalog/appages/uchannel.php?clickkey=429408 ) The stab folds up and down while just barely touching the rubber u-channel. In front of the front hinge, the space is too wide, and you will need to use 3/4" by 3/4" by 1/16" aluminum angle to fill up the gap. Also it was easier to get everything to line up by having the piece in front of the hinge opposite - or upside down - as it attached to the fuselage compared to the section behind the hinge because the stab is not attached parallel to the tube, the front of the stab is higher. This causes the gap to be bigger in front which means you have to spacer out the front of the 1/2" angle away from the fuselage a bit to keep it up against the stab. Which means you have to bend the aluminum angle a bit to keep it at a constant angle against the stab, and you need to fill that space between the tube and the angle with balsa wood or similar to fill the gap and make it look right. Hopefully the pictures will make sense. One other thing - if you put the u-channel on last, don't use Gorilla glue. It sticks great, but it also bubbles out underneath and looks terrible. As you can see. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=451922#451922 Attachments: http://forums.matronics.com//files/left_lower_gapjpg_234.jpg http://forums.matronics.com//files/right_lower_gapjpg_845.jpg http://forums.matronics.com//files/top_right_gapjpg_567.jpg http://forums.matronics.com//files/top_front_gapjpg_595.jpg ________________________________________________________________________________
Date: Jan 12, 2016
Subject: Re: Use of a Kolb...AOA
After reading about this subject quite a few times, I decided to do something about it. I looked on Bing ( Boycotting Google) and found that it was basically a weather vane with a graph. No reason that it could not be duplicated in a manner that Herb would approve of. So below are pictures of what should do the job just as well as one from Sporty's. It is installed where I don't have to be too far from my main landing instrument - ASI, so all that is left is to take a sharpie with me the next time I go flying and find the " Aw shit" position, make a mark on the lexan . Larry On Tue, Jan 12, 2016 at 10:04 AM, Nick Cassara wrote: > > > Before I retired, I spent many hundreds of hours in the back seat of a > Super Cub, identifying and counting wildlife with some of Alaska=99 s best > pilots, who have thousands of hour in their planes. I however am not one of > Alaska best pilots, and If an AOA can keep me from making a fatal mistake > the time to install, and the expense will be well worth it. > > Nick Cassara > Palmer, Alaska > > 607AK Kolb Kolbra #1 > > -- > *The older I get, the less tolerant I am of those who are intolerant.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jan 12, 2016
If nothing else, the price is right. Waiting for a flight/stall report. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Tuesday, January 12, 2016 2:44 PM Subject: Re: Kolb-List: Use of a Kolb...AOA After reading about this subject quite a few times, I decided to do something about it. I looked on Bing ( Boycotting Google) and found that it was basically a weather vane with a graph. No reason that it could not be duplicated in a manner that Herb would approve of. So below are pictures of what should do the job just as well as one from Sporty's. It is installed where I don't have to be too far from my main landing instrument - ASI, so all that is left is to take a sharpie with me the next time I go flying and find the " Aw shit" position, make a mark on the lexan. Larry On Tue, Jan 12, 2016 at 10:04 AM, Nick Cassara wrote: Before I retired, I spent many hundreds of hours in the back seat of a Super Cub, identifying and counting wildlife with some of Alaska=99s best pilots, who have thousands of hour in their planes. I however am not one of Alaska best pilots, and If an AOA can keep me from making a fatal mistake the time to install, and the expense will be well worth it. Nick Cassara Palmer, Alaska 607AK Kolb Kolbra #1 -- The older I get, the less tolerant I am of those who are intolerant. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jan 12, 2016
if John's happy then I am plum tickled to death!! :-) Herb or the other Herb On 01/12/2016 04:05 PM, John Hauck wrote: > > If nothing else, the price is right. > > Waiting for a flight/stall report. > > john h > > mkIII > > Titus, Alabama > > *From:*owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] *On Behalf Of *Larry > Cottrell > *Sent:* Tuesday, January 12, 2016 2:44 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: Use of a Kolb...AOA > > After reading about this subject quite a few times, I decided to do > something about it. I looked on Bing ( Boycotting Google) and found > that it was basically a weather vane with a graph. No reason that it > could not be duplicated in a manner that Herb would approve of. So > below are pictures of what should do the job just as well as one from > Sporty's. > > It is installed where I don't have to be too far from my main landing > instrument - ASI, so all that is left is to take a sharpie with me the > next time I go flying and find the " Aw shit" position, make a mark on > the lexan. > > Larry > > On Tue, Jan 12, 2016 at 10:04 AM, Nick Cassara > wrote: > > > > > > Before I retired, I spent many hundreds of hours in the back seat of a > Super Cub, identifying and counting wildlife with some of Alaskas > best pilots, who have thousands of hour in their planes. I however am > not one of Alaska best pilots, and If an AOA can keep me from making a > fatal mistake the time to install, and the expense will be well worth it. > > Nick Cassara > Palmer, Alaska > > 607AK Kolb Kolbra #1 > > -- > > /The older I get, the less tolerant I am of those who are intolerant./ > > /If you forward this email, or any part of it, please remove my email > address before sending./ > -- Signature text; Add catchy phrase here.. ________________________________________________________________________________
Date: Jan 13, 2016
I've got gap seals on everything but the horiz. stab. to fuselage tube. My M3X flies good it seems to me. What would be the expected improvement if I add the stab. to tube seal? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=451957#451957 ________________________________________________________________________________
Date: Jan 13, 2016
As I said in my first email, you get improved rudder control and the ability to pick up a wing with the rudder during an approach stall. Rick On Wed, Jan 13, 2016 at 1:28 PM, Rex Rodebush wrote: > > I've got gap seals on everything but the horiz. stab. to fuselage tube. > My M3X flies good it seems to me. What would be the expected improvement > if I add the stab. to tube seal? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=451957#451957 > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Jan 13, 2016
Subject: AOA
https://youtu.be/Ubx5S8rzl7s Here is a link with an even cheaper AOA gage that I found on You Tube. I think it is worth watching. I do believe that one could save even more weight and money over the one that I built. Granted mine only cost a bit of my time, a bolt and two pop rivets. This one could be had for the cost of a piece of twine stuck on the side of your lexan. In any case I found it very informative. The weather is being very nice to us by rain and snow, both highly unusual in this part of the country. I may not be able to do any testing on mine before Feb. Larry -- *The older I get, the less tolerant I am of those who are intolerant.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jan 14, 2016
Rex Rodebush wrote: > I've got gap seals on everything but the horiz. stab. to fuselage tube. My M3X flies good it seems to me. What would be the expected improvement if I add the stab. to tube seal? I had two reasons: one is that with a heavy passenger, my MKIII did not have enough elevator authority at max forward CG and minimum airspeeds. The vortex generators on the wings give the ability to fly an approach at 45 mph with a 26 mph stall speed, even with a passenger. But at those speeds and CG conditions, when it comes time to flare, pulling the stick back did not raise the nose, the AOA did not change with elevator movement. However, gap sealing the elevators to the horizontal stab, sealing the stab to the fuslelage, and adding VG's to the underside of the stab gave more control authority in that particular situation, the elevators became more effective. The second is that many years ago I got obsessive about removing all the drag I could, I wanted to be able to cruise at 65 with the lowest possible throttle setting, and any sort of gap like that adds drag. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=451969#451969 ________________________________________________________________________________
Subject: AOA
Date: Jan 14, 2016
Don't know if I can hold my breath in anticipation that long or not. Turning blue at hauck's holler. john h mkIII Titus, Alabama PS: Why not kill two experiments at one time. Stick a piece of yarn on the Lexan and see if it will work. From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Thursday, January 14, 2016 12:04 AM Subject: Kolb-List: AOA https://youtu.be/Ubx5S8rzl7s Here is a link with an even cheaper AOA gage that I found on You Tube. I think it is worth watching. I do believe that one could save even more weight and money over the one that I built. Granted mine only cost a bit of my time, a bolt and two pop rivets. This one could be had for the cost of a piece of twine stuck on the side of your lexan. In any case I found it very informative. The weather is being very nice to us by rain and snow, both highly unusual in this part of the country. I may not be able to do any testing on mine before Feb. Larry -- The older I get, the less tolerant I am of those who are intolerant. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jan 14, 2016
Richard: Did you make one change at a time and test after each change? Where did you place the vg's on the underside of the horizontal stabilizer? I didn't realize how much the flaps stole air from the elevators until I did a little experiment with a 220 lb passenger. I had been demonstrating some aggressive stalls, dives, and pull outs, when I got the idea to try it with full flaps. On my Kolb MKIII that is 40 degrees. Pushed the nose straight down, hit 85 mph, tried to do an abrupt pull out and the aircraft never changed attitude with the stick full back. Got rid of the flaps and she pulled right out. After that experiment I could then understand the possibility of running out of elevator at extremely slow speeds with a heavy passenger on landing. I have decided to install vg's on my MKIII. Now I need to buy some, probably from John Gilpin . Dan Horton, one of my airplane buddies has said he will give me a hand with the install. How far back from the leading edge do you place the front edge of the vg for best all around results. Too cold to play airplane at Gantt International Airport, Alabama. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Thursday, January 14, 2016 6:56 AM Subject: Kolb-List: Re: Horizontal stabilizer seals --> Rex Rodebush wrote: > I've got gap seals on everything but the horiz. stab. to fuselage tube. My M3X flies good it seems to me. What would be the expected improvement if I add the stab. to tube seal? I had two reasons: one is that with a heavy passenger, my MKIII did not have enough elevator authority at max forward CG and minimum airspeeds. The vortex generators on the wings give the ability to fly an approach at 45 mph with a 26 mph stall speed, even with a passenger. But at those speeds and CG conditions, when it comes time to flare, pulling the stick back did not raise the nose, the AOA did not change with elevator movement. However, gap sealing the elevators to the horizontal stab, sealing the stab to the fuslelage, and adding VG's to the underside of the stab gave more control authority in that particular situation, the elevators became more effective. The second is that many years ago I got obsessive about removing all the drag I could, I wanted to be able to cruise at 65 with the lowest possible throttle setting, and any sort of gap like that adds drag. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=451969#451969 ________________________________________________________________________________
Date: Jan 14, 2016
I don't have V.G.'s but was able to do a full stall landing with a 220# passenger. I do have the larger horizontal stabilizer that was called for shortly after the original Xtra came out. That may be a factor. The drag reduction makes good sense so I'll probably go ahead and put the seals on. Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=451974#451974 ________________________________________________________________________________
Date: Jan 14, 2016
John; it's been a while, but as I remember, I put the VG's on the underside of the horizontal stab, test flew it, made a lot of landings, ssaw improvement. Then I put gap seals between the stab & the elevator, same tests, saw more improvement. Then I added the gap seal between the stab and the fuselage, did not notice much difference. The VG's on the underside of the stab are in a straight line; the innermost one has it's back end at 7" aft of the leading edge, measured with the ruler parallel to the boom tube. The outermost one is at the hinge line and 7" from the outboard end. I have no idea if this location is optimum, I had read that 10% of chord is a good rule of thumb, so I put them there, did not experiment with moving them around. Jack Hart has his right behind the leading edge: http://www.jackbhart.com/firefly/firefly62.html This page shows them at a fixed distance ahead of the hinge line http://www.vortex-generators.com/installation-of-vortex-generators.html as does this one http://www.speedcomfly.com/sito-ecommerce/file_info/vortex.pdf If you would like to try several different locations to find the optimum and let us know, I will gladly move mine to a better position! My web pages are now on George Alexander's web site, where I've got some fairly extensive details on how I did the VG thing. Here is the one for the MKIII: http://oh2fly.net/oldpoops/Vortex%20Generators.html Here is the one for the FSII: some of the data overlaps a bit and it is also useful. http://oh2fly.net/oldpoops/FSII%20Vortex%20Generators.html Something you might think of trying, - and I enjoyed doing the process - take your VG's and tape them on and try different measurements. I would use little squares of that aluminum metal duct tape, cut a slot in the middle of the square and poke the VG through, apply to wing, go fly, make notes. Move them to a different spot and do it again. That is how I came to the conclusion as to where they worked best on my airplane. When you hit the sweet spot, you can tell. It is subtle and subjective, but you will know it when it happens. OTOH, if you just took my numbers and used them, you would still like it, but that might not be the ideal setup for Miss P'Fer, and as much work as you have put into the airplane over the years, you ought to go for ideal rather than just better. Besides, once you get involved in the process; slow flying, stalling, moving them to a new spot, flying again, better here, not as good there - it becomes quite intriguing. A Quest for Perfection, very addictive. When you get done, you will find that you now have a different airplane. Kind of like taking Sweet Thing out to dinner, and suddenly realizing that she has somehow lost 50 pounds and become 20 years younger... Enjoy! -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=451979#451979 ________________________________________________________________________________
Date: Jan 14, 2016
John Hauck wrote: > Richard: > > = S = N = I = P > > I have decided to install vg's on my MKIII. > > = S = N = I = P > > Too cold to play airplane at Gantt International Airport, Alabama. > > john h > mkIII > Titus, Alabama > > > > -- Well, without a doubt, someone has hacked his account and posing as John Hauck. Either that or the cold has gotten to him. Based on the quote above about installing VGs on his Kolb MK III one or the other has to be the case. :D :D :D :D HAPPY NEW YEAR Everyone! -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=451981#451981 ________________________________________________________________________________
Date: Jan 14, 2016
John, VG's under the horizontal stabilizer leading edge will give you a little more nose up. If the VG's do not do the job for you with the full flaps, you may want to try them on the wing too. By placing VG's on the wing, they move the wings center of lift toward the tail. Since this effect is over a much greater area and length, it may produce a greater favorable effect than just putting them on the horizontal stabilizer. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 14, 2016
John Hope you=99re not completely blue. It=99s a balmy 17F here now. Dont visit for awhile. Never thought I=99d hear you say VG=99s without cussing. In a day or 2 I=99ll measure where mine are on the Xtra. Put on by the original builder here in Maine. I had to replace those on one wing, gottum from Gilpin. Good stuff, easy to apply. Fair winds, Russ K > On Jan 14, 2016, at 10:06 AM, John Hauck wrote: > > Don't know if I can hold my breath in anticipation that long or not. > > Turning blue at hauck's holler. > > john h > mkIII > Titus, Alabama > > PS: Why not kill two experiments at one time. Stick a piece of yarn on the Lexan and see if it will work. > > > > > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com ] On Behalf Of Larry Cottrell > Sent: Thursday, January 14, 2016 12:04 AM > To: kolb-list(at)matronics.com > Subject: Kolb-List: AOA > > https://youtu.be/Ubx5S8rzl7s > Here is a link with an even cheaper AOA gage that I found on You Tube. I think it is worth watching. I do believe that one could save even more weight and money over the one that I built. Granted mine only cost a bit of my time, a bolt and two pop rivets. This one could be had for the cost of a piece of twine stuck on the side of your lexan. In any case I found it very informative. The weather is being very nice to us by rain and snow, both highly unusual in this part of the country. I may not be able to do any testing on mine before Feb. > Larry > -- > The older I get, the less tolerant I am of those who are intolerant. > > If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jan 14, 2016
Subject: Re: AOA
Larry, A very elegant solution At 01:04 AM 1/14/2016, you wrote: >https://youtu.be/Ubx5S8rzl7s I tried several different things over the years. One worked well but was cumbersome. The other was a yarn tuft on the side of the windshield. I moved it up and down to see where it was the most sensitive. Unfortunately that spot was where I could not see it while looking forward. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jan 14, 2016
Subject: Re: AOA
Thanks for the comments Jack. When the weather clears I will do some testing and see if Firestars react differently to Fire Flys. I will eventually go to the yarn, but I want to try the bigger surface of the alum first. Larry On Thu, Jan 14, 2016 at 7:08 PM, Jack B. Hart wrote: > > Larry, > > A very elegant solution > > At 01:04 AM 1/14/2016, you wrote: > >> https://youtu.be/Ubx5S8rzl7s >> > > I tried several different things over the years. One worked well but > was cumbersome. The other was a yarn tuft on the side of the > windshield. I moved it up and down to see where it was the most > sensitive. Unfortunately that spot was where I could not see it while > looking forward. > > Jack B. Hart FF004 > Winchester, IN > > -- *The older I get, the less tolerant I am of those who are intolerant.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: AOA
Date: Jan 14, 2016
Over the years folks on this List have assumed that I do not like VGs. That assumption was and is entirely incorrect. My stand on VGs has always been, in the past, that I did not need them on my MKIII. Until recently I was a much better pilot than I am now. Two reasons: -Age. -Not flying nearly as much as I used to. I am rusty and will be rusty until I decide I want to fly much more frequently. Flying Larry Cottrell's FSII convinced me that VGs help make a difference landing for old pilots that are rusty as Hell. Why not take advantage of that change/improvement? Never said I did not like VGs. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of kinne russ Sent: Thursday, January 14, 2016 8:04 PM Subject: Re: Kolb-List: AOA John Hope you=99re not completely blue. It=99s a balmy 17F here now. Dont visit for awhile. Never thought I=99d hear you say VG=99s without cussing. In a day or 2 I=99ll measure where mine are on the Xtra. Put on by the original builder here in Maine. I had to replace those on one wing, gottum from Gilpin. Good stuff, easy to apply. Fair winds, Russ K On Jan 14, 2016, at 10:06 AM, John Hauck wrote: Don't know if I can hold my breath in anticipation that long or not. Turning blue at hauck's holler. john h mkIII Titus, Alabama PS: Why not kill two experiments at one time. Stick a piece of yarn on the Lexan and see if it will work. From: <mailto:owner-kolb-list-server(at)matronics.com> owner-kolb-list-server(at)matronics.com [ mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Thursday, January 14, 2016 12:04 AM Subject: Kolb-List: AOA https://youtu.be/Ubx5S8rzl7s Here is a link with an even cheaper AOA gage that I found on You Tube. I think it is worth watching. I do believe that one could save even more weight and money over the one that I built. Granted mine only cost a bit of my time, a bolt and two pop rivets. This one could be had for the cost of a piece of twine stuck on the side of your lexan. In any case I found it very informative. The weather is being very nice to us by rain and snow, both highly unusual in this part of the country. I may not be able to do any testing on mine before Feb. Larry -- The older I get, the less tolerant I am of those who are intolerant. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jan 14, 2016
I plan to eventually install VGs on the wings first. Then I'll work on the tail section. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack B. Hart Sent: Thursday, January 14, 2016 8:02 PM Subject: Re: Kolb-List: Re: Horizontal stabilizer seals --> John, VG's under the horizontal stabilizer leading edge will give you a little more nose up. If the VG's do not do the job for you with the full flaps, you may want to try them on the wing too. By placing VG's on the wing, they move the wings center of lift toward the tail. Since this effect is over a much greater area and length, it may produce a greater favorable effect than just putting them on the horizontal stabilizer. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jan 14, 2016
Thanks for the info. I plan to get started on this as soon as I get some VGs and the weather warms up a bit. john h Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Thursday, January 14, 2016 2:57 PM Subject: Kolb-List: Re: Horizontal stabilizer seals --> John; it's been a while, but as I remember, I put the VG's on the underside of the horizontal stab, test flew it, made a lot of landings, ssaw improvement. Then I put gap seals between the stab & the elevator, same tests, saw more improvement. Then I added the gap seal between the stab and the fuselage, did not notice much difference. The VG's on the underside of the stab are in a straight line; the innermost one has it's back end at 7" aft of the leading edge, measured with the ruler parallel to the boom tube. The outermost one is at the hinge line and 7" from the outboard end. I have no idea if this location is optimum, I had read that 10% of chord is a good rule of thumb, so I put them there, did not experiment with moving them around. Jack Hart has his right behind the leading edge: http://www.jackbhart.com/firefly/firefly62.html This page shows them at a fixed distance ahead of the hinge line http://www.vortex-generators.com/installation-of-vortex-generators.html as does this one http://www.speedcomfly.com/sito-ecommerce/file_info/vortex.pdf If you would like to try several different locations to find the optimum and let us know, I will gladly move mine to a better position! My web pages are now on George Alexander's web site, where I've got some fairly extensive details on how I did the VG thing. Here is the one for the MKIII: http://oh2fly.net/oldpoops/Vortex%20Generators.html Here is the one for the FSII: some of the data overlaps a bit and it is also useful. http://oh2fly.net/oldpoops/FSII%20Vortex%20Generators.html Something you might think of trying, - and I enjoyed doing the process - take your VG's and tape them on and try different measurements. I would use little squares of that aluminum metal duct tape, cut a slot in the middle of the square and poke the VG through, apply to wing, go fly, make notes. Move them to a different spot and do it again. That is how I came to the conclusion as to where they worked best on my airplane. When you hit the sweet spot, you can tell. It is subtle and subjective, but you will know it when it happens. OTOH, if you just took my numbers and used them, you would still like it, but that might not be the ideal setup for Miss P'Fer, and as much work as you have put into the airplane over the years, you ought to go for ideal rather than just better. Besides, once you get involved in the process; slow flying, stalling, moving them to a new spot, flying again, better here, not as good there - it becomes quite intriguing. A Quest for Perfection, very add! ictive. When you get done, you will find that you now have a different airplane. Kind of like taking Sweet Thing out to dinner, and suddenly realizing that she has somehow lost 50 pounds and become 20 years younger... Enjoy! -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=451979#451979 ________________________________________________________________________________
Date: Jan 14, 2016
I'll be alright. ;-) john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of George Alexander Sent: Thursday, January 14, 2016 3:20 PM Subject: Kolb-List: Re: Horizontal stabilizer seals --> John Hauck wrote: > Richard: > > = S = N = I = P > > I have decided to install vg's on my MKIII. > > = S = N = I = P > > Too cold to play airplane at Gantt International Airport, Alabama. > > john h > mkIII > Titus, Alabama > > > > -- Well, without a doubt, someone has hacked his account and posing as John Hauck. Either that or the cold has gotten to him. Based on the quote above about installing VGs on his Kolb MK III one or the other has to be the case. :D :D :D :D HAPPY NEW YEAR Everyone! -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=451981#451981 ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 14, 2016
Keep in mind that to be truly useful, AOA needs some sort of audio in the headset, or to at least be directly in the pilot's normal line of sight while maneuvering. If you're visually fixating on something out to the side, bad things in front can go unnoticed. :-) On 1/14/2016 8:31 PM, Larry Cottrell wrote: > Thanks for the comments Jack. When the weather clears I will do some > testing and see if Firestars react differently to Fire Flys. I will > eventually go to the yarn, but I want to try the bigger surface of the > alum first. > Larry > > On Thu, Jan 14, 2016 at 7:08 PM, Jack B. Hart > wrote: > > > > > Larry, > > A very elegant solution > > At 01:04 AM 1/14/2016, you wrote: > > https://youtu.be/Ubx5S8rzl7s > > > I tried several different things over the years. One worked well but > was cumbersome. The other was a yarn tuft on the side of the > windshield. I moved it up and down to see where it was the most > sensitive. Unfortunately that spot was where I could not see it while > looking forward. > > Jack B. Hart FF004 > Winchester, IN > ________________________________________________________________________________
Date: Jan 14, 2016
I plan to eventually install VGs on the wings first. Then I'll work on the tail section. john h mkIII ---------------------------------------------------------------------------------------------------------------------- Any Kolb will fly better with VG's only on the wings. I flew that way for quite a long time, but I noticed with the increased lift from the wing, that when landing my tail wheel was touching down first. When I would come in to land and I tried to flare, the tail would go right on through to the ground rather than flare with the wings. I finally decided that the wings were blanking much of the air from the elevator. The rest was lost at the steep angle of the elevator in relation to the wind. I installed four VG's on each side of the elevator, on the bottom, right at the hinge point. The result was that I was able to make three point landings much easier, since my tail was still flying. Perhaps there are better places than the hinge line to install VG's, but the ones that I did install have improved the situation tremendously. It only makes sense that if there are VG's on the wings, they will hold the air longer before stalling. The tail with none, will stall before the wing in a landing configuration. FWIW Larry On Thu, Jan 14, 2016 at 8:02 PM, John Hauck wrote: > > I plan to eventually install VGs on the wings first. Then I'll work on the > tail section. > > john h > mkIII > Titus, Alabama > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack B. Hart > Sent: Thursday, January 14, 2016 8:02 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: Horizontal stabilizer seals > > --> > > John, > > VG's under the horizontal stabilizer leading edge will give you a little > more nose up. > > If the VG's do not do the job for you with the full flaps, you may want to > try them on the wing too. By placing VG's on the wing, they move the wings > center of lift toward the tail. Since this effect is over a much greater > area and length, it may produce a greater favorable effect than just > putting > them on the horizontal stabilizer. > > Jack B. Hart FF004 > Winchester, IN > > -- *The older I get, the less tolerant I am of those who are intolerant.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: AOA
Date: Jan 14, 2016
Quick scan, cross check? In a Kolb, any model, I find the ASI works great to prevent stalls. There is very little difference in air speed between a straight and level stall and an accelerated stall. I realize the subject is AOA. Guess I am trying to say I don't think I need one. ;-) john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Thursday, January 14, 2016 9:33 PM Subject: Re: Kolb-List: AOA Keep in mind that to be truly useful, AOA needs some sort of audio in the headset, or to at least be directly in the pilot's normal line of sight while maneuvering. If you're visually fixating on something out to the side, bad things in front can go unnoticed. :-) On 1/14/2016 8:31 PM, Larry Cottrell wrote: Thanks for the comments Jack. When the weather clears I will do some testing and see if Firestars react differently to Fire Flys. I will eventually go to the yarn, but I want to try the bigger surface of the alum first. Larry On Thu, Jan 14, 2016 at 7:08 PM, Jack B. Hart wrote: Larry, A very elegant solution At 01:04 AM 1/14/2016, you wrote: https://youtu.be/Ubx5S8rzl7s I tried several different things over the years. One worked well but was cumbersome. The other was a yarn tuft on the side of the windshield. I moved it up and down to see where it was the most sensitive. Unfortunately that spot was where I could not see it while looking forward. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Jan 14, 2016
Subject: Re: AOA
Charlie England via matronics.com 8:33 PM (11 minutes ago) to kolb-list Keep in mind that to be truly useful, AOA needs some sort of audio in the headset, or to at least be directly in the pilot's normal line of sight while maneuvering. If you're visually fixating on something out to the side, bad things in front can go unnoticed. :-) ------------------------------------------------------------------------------------------------------------------------------ I think where I have it located I will be able to see it with my peripheral vision. It actually would not take all that much to actually make it audible, or with lights, with some contact points at the proper places. However I have to admit that I am most likely too lazy to do so. :-) I still haven't convinced myself that one is needed with a Firestar. I am sure that it would help a novice, but I have bounced, crashed and other unmentionables enough times that I think I have it slammed into my head. I am open to change and if I can land better and slower with one, I will be happy to change. Larry On Thu, Jan 14, 2016 at 8:33 PM, Charlie England wrote: > Keep in mind that to be truly useful, AOA needs some sort of audio in the > headset, or to at least be directly in the pilot's normal line of sight > while maneuvering. If you're visually fixating on something out to the > side, bad things in front can go unnoticed. :-) > > On 1/14/2016 8:31 PM, Larry Cottrell wrote: > > Thanks for the comments Jack. When the weather clears I will do some > testing and see if Firestars react differently to Fire Flys. I will > eventually go to the yarn, but I want to try the bigger surface of the alum > first. > Larry > > On Thu, Jan 14, 2016 at 7:08 PM, Jack B. Hart > wrote: > >> jbhart(at)onlyinternet.net> >> >> Larry, >> >> A very elegant solution >> >> At 01:04 AM 1/14/2016, you wrote: >> >>> >>> https://youtu.be/Ubx5S8rzl7s >>> >> >> I tried several different things over the years. One worked well but >> was cumbersome. The other was a yarn tuft on the side of the >> windshield. I moved it up and down to see where it was the most >> sensitive. Unfortunately that spot was where I could not see it while >> looking forward. >> >> Jack B. Hart FF004 >> Winchester, IN >> > > -- *The older I get, the less tolerant I am of those who are intolerant.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 15, 2016
KISS John. I agree with you. Pat From: John Hauck Sent: Friday, January 15, 2016 3:39 AM Subject: RE: Kolb-List: AOA Quick scan, cross check? In a Kolb, any model, I find the ASI works great to prevent stalls. There is very little difference in air speed between a straight and level stall and an accelerated stall. I realize the subject is AOA. Guess I am trying to say I don't think I need one. ;-) john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Thursday, January 14, 2016 9:33 PM Subject: Re: Kolb-List: AOA Keep in mind that to be truly useful, AOA needs some sort of audio in the headset, or to at least be directly in the pilot's normal line of sight while maneuvering. If you're visually fixating on something out to the side, bad things in front can go unnoticed. :-) On 1/14/2016 8:31 PM, Larry Cottrell wrote: Thanks for the comments Jack. When the weather clears I will do some testing and see if Firestars react differently to Fire Flys. I will eventually go to the yarn, but I want to try the bigger surface of the alum first. Larry On Thu, Jan 14, 2016 at 7:08 PM, Jack B. Hart wrote: Larry, A very elegant solution At 01:04 AM 1/14/2016, you wrote: https://youtu.be/Ubx5S8rzl7s I tried several different things over the years. One worked well but was cumbersome. The other was a yarn tuft on the side of the windshield. I moved it up and down to see where it was the most sensitive. Unfortunately that spot was where I could not see it while looking forward. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Subject: AOA Instruments
Date: Jan 15, 2016
After reading the attached NTSB article, I may have to rethink my attitude toward AOA Instruments. In my early years of flying Kolbs I got pretty aggressive at times. One of my favorite exercises was to impress the crowd with approach and landing right on the edge of stall all the way to the ground. In the Ultrastar and Firestar I could keep the Winter venturi operated ASI, designed for gliders, right on 25 mph, the very edge of stall. If I got a half needle width below 25 the aircraft would start nibbling at the stall. This was great, a lot of fun, until the couple times when the wind stopped blowing. It is a very helpless feeling falling in a stall 20, 30, 50 feet above the ground. While I was typing this I remembered a third incident where I stalled from approximately 50 feet AGL, on takeoff, in my MKIII, loaded to max, cargo and fuel, field elevation 6,539 feet, very high air temp, dust devils (clear air type that one cannot see) in the area at Grants Airport, New Mexico. High, turbulent cross wind. Soon as I started descending in a mush I went full throttle, tried to push the stick forward, although I don't think I did a very good job of it, got blown off the runway center line, and smacked down very hard into the desert sand, bounced back into the air and continued flying. Was lucky I did not do more damage than rearrange the 4130 gear legs on my MKIII. Only my second take off from a high altitude airport since I departed near sea level conditions on my flight to Monument Valley from Alabama, May 2009. My muscle memory had me at sea level, not 6,539 feet MSL. An AOA would probably have prevented the NM stall. I don't know about the first two. Stupid is as stupid does. ;-) john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Jan 16, 2016
Subject: Re: AOA
Larry: If your device works; it would be simple to put a small magenet on the arm and a mag. pickup inside, placed near the point of stall, hooked to an audio device. ----- Original Message ----- From: "Larry Cottrell" <lcottrell1020(at)gmail.com> Sent: Thursday, January 14, 2016 11:01:00 PM Subject: Re: Kolb-List: AOA Charlie England via matronics.com 8:33 PM (11 minutes ago) to kolb-list Keep in mind that to be truly useful, AOA needs some sort of audio in the headset, or to at least be directly in the pilot's normal line of sight while maneuvering. If you're visually fixating on something out to the side, bad things in front can go unnoticed. :-) ------------------------------------------------------------------------------------------------------------------------------ I think where I have it located I will be able to see it with my peripheral vision. It actually would not take all that much to actually make it audible, or with lights, with some contact points at the proper places. However I have to admit that I am most likely too lazy to do so. :-) I still haven't convinced myself that one is needed with a Firestar. I am sure that it would help a novice, but I have bounced, crashed and other unmentionables enough times that I think I have it slammed into my head. I am open to change and if I can land better and slower with one, I will be happy to change. Larry On Thu, Jan 14, 2016 at 8:33 PM, Charlie England < ceengland7(at)gmail.com > wrote: Keep in mind that to be truly useful, AOA needs some sort of audio in the headset, or to at least be directly in the pilot's normal line of sight while maneuvering. If you're visually fixating on something out to the side, bad things in front can go unnoticed. :-) On 1/14/2016 8:31 PM, Larry Cottrell wrote:
Thanks for the comments Jack. When the weather clears I will do some testing and see if Firestars react differently to Fire Flys. I will eventually go to the yarn, but I want to try the bigger surface of the alum first. Larry On Thu, Jan 14, 2016 at 7:08 PM, Jack B. Hart < jbhart(at)onlyinternet.net > wrote:
< https://youtu.be/Ubx5S8rzl7s > https://youtu.be/Ubx5S8rzl7s I tried several different things over the years. One worked well but was cumbersome. The other was a yarn tuft on the side of the windshield. I moved it up and down to see where it was the most sensitive. Unfortunately that spot was where I could not see it while looking forward. Jack B. Hart FF004 Winchester, IN
Date: Jan 15, 2016
Subject: Re: AOA
If the indicating arm is far enough out towards the nose, the air should flow in a straight line. Assuming that it does and its position is discernible to the pilot, you might not need a light or horn. Most of my landings do not have or require any serious movement of the stick until I get within a foot or so of the ground. I would however be interested in any thing that you could find that would make it an audible or visual indicator. Larry On Fri, Jan 15, 2016 at 6:01 PM, wrote: > Larry: > If your device works; it would be simple to put a small magenet on the arm > and a mag. pickup inside, placed near the point of stall, hooked to an > audio device. > > ------------------------------ > *From: *"Larry Cottrell" <lcottrell1020(at)gmail.com> > *To: *"kolb-list" > *Sent: *Thursday, January 14, 2016 11:01:00 PM > *Subject: *Re: Kolb-List: AOA > > Charlie England via > matronics.com > 8:33 PM (11 minutes ago) > to kolb-list > > > Keep in mind that to be truly useful, AOA needs some sort of audio in the > headset, or to at least be directly in the pilot's normal line of sight > while maneuvering. If you're visually fixating on something out to the > side, bad things in front can go unnoticed. :-) > > > ------------------------------------------------------------------------------------------------------------------------------ > > I think where I have it located I will be able to see it with my > peripheral vision. It actually would not take all that much to actually > make it audible, or with lights, with some contact points at the proper > places. However I have to admit that I am most likely too lazy to do so. :-) > > I still haven't convinced myself that one is needed with a Firestar. I am > sure that it would help a novice, but I have bounced, crashed and other > unmentionables enough times that I think I have it slammed into my head. I > am open to change and if I can land better and slower with one, I will be > happy to change. > > Larry > > On Thu, Jan 14, 2016 at 8:33 PM, Charlie England > wrote: > >> Keep in mind that to be truly useful, AOA needs some sort of audio in the >> headset, or to at least be directly in the pilot's normal line of sight >> while maneuvering. If you're visually fixating on something out to the >> side, bad things in front can go unnoticed. :-) >> >> On 1/14/2016 8:31 PM, Larry Cottrell wrote: >> >> Thanks for the comments Jack. When the weather clears I will do some >> testing and see if Firestars react differently to Fire Flys. I will >> eventually go to the yarn, but I want to try the bigger surface of the alum >> first. >> Larry >> >> On Thu, Jan 14, 2016 at 7:08 PM, Jack B. Hart >> wrote: >> >>> jbhart(at)onlyinternet.net> >>> >>> Larry, >>> >>> A very elegant solution >>> >>> At 01:04 AM 1/14/2016, you wrote: >>> >>>> >>>> https://youtu.be/Ubx5S8rzl7s >>>> >>> >>> I tried several different things over the years. One worked well but >>> was cumbersome. The other was a yarn tuft on the side of the >>> windshield. I moved it up and down to see where it was the most >>> sensitive. Unfortunately that spot was where I could not see it while >>> looking forward. >>> >>> Jack B. Hart FF004 >>> Winchester, IN >>> >> >> > > > -- > *The older I get, the less tolerant I am of those who are intolerant.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > -- *The older I get, the less tolerant I am of those who are intolerant.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jan 15, 2016
Subject: Re: AOA
I'm thinking install a micro switch. Install a light on top of the dash. Set the light to come on 5 mph above the stall Boyd On Jan 15, 2016 6:07 PM, wrote: > Larry: > If your device works; it would be simple to put a small magenet on the arm > and a mag. pickup inside, placed near the point of stall, hooked to an > audio device. > > ------------------------------ > *From: *"Larry Cottrell" <lcottrell1020(at)gmail.com> > *To: *"kolb-list" > *Sent: *Thursday, January 14, 2016 11:01:00 PM > *Subject: *Re: Kolb-List: AOA > > Charlie England via > matronics.com > 8:33 PM (11 minutes ago) > to kolb-list > > > Keep in mind that to be truly useful, AOA needs some sort of audio in the > headset, or to at least be directly in the pilot's normal line of sight > while maneuvering. If you're visually fixating on something out to the > side, bad things in front can go unnoticed. :-) > > > ------------------------------------------------------------------------------------------------------------------------------ > > I think where I have it located I will be able to see it with my > peripheral vision. It actually would not take all that much to actually > make it audible, or with lights, with some contact points at the proper > places. However I have to admit that I am most likely too lazy to do so. :-) > > I still haven't convinced myself that one is needed with a Firestar. I am > sure that it would help a novice, but I have bounced, crashed and other > unmentionables enough times that I think I have it slammed into my head. I > am open to change and if I can land better and slower with one, I will be > happy to change. > > Larry > > On Thu, Jan 14, 2016 at 8:33 PM, Charlie England > wrote: > >> Keep in mind that to be truly useful, AOA needs some sort of audio in the >> headset, or to at least be directly in the pilot's normal line of sight >> while maneuvering. If you're visually fixating on something out to the >> side, bad things in front can go unnoticed. :-) >> >> On 1/14/2016 8:31 PM, Larry Cottrell wrote: >> >> Thanks for the comments Jack. When the weather clears I will do some >> testing and see if Firestars react differently to Fire Flys. I will >> eventually go to the yarn, but I want to try the bigger surface of the alum >> first. >> Larry >> >> On Thu, Jan 14, 2016 at 7:08 PM, Jack B. Hart >> wrote: >> >>> jbhart(at)onlyinternet.net> >>> >>> Larry, >>> >>> A very elegant solution >>> >>> At 01:04 AM 1/14/2016, you wrote: >>> >>>> >>>> https://youtu.be/Ubx5S8rzl7s >>>> >>> >>> I tried several different things over the years. One worked well but >>> was cumbersome. The other was a yarn tuft on the side of the >>> windshield. I moved it up and down to see where it was the most >>> sensitive. Unfortunately that spot was where I could not see it while >>> looking forward. >>> >>> Jack B. Hart FF004 >>> Winchester, IN >>> >> >> > > > -- > *The older I get, the less tolerant I am of those who are intolerant.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 15, 2016
Might not be that useful on a Kolb, but the really useful feature of AOA indicators is supposed to be the ability to fly at max lift/drag; not just avoid stall. The AOA lets you do that regardless of weight, since stall speed changes significantly with weight but stall AOA does not. Ideally, a variable light/tone should be helpful. This one has a 'ladder' type display. Wouldn't take much for a HAM radio buddy to build you a voltage to frequency converter for audio. http://www.barkeraircraft.com/AOA_kit.html I hope it's still available; it's been on & off the market a couple of times. Charlie On 1/15/2016 9:49 PM, B Young wrote: > > I'm thinking install a micro switch. Install a light on top of the > dash. Set the light to come on 5 mph above the stall > > Boyd > > On Jan 15, 2016 6:07 PM, > wrote: > > Larry: > If your device works; it would be simple to put a small magenet on > the arm and a mag. pickup inside, placed near the point of stall, > hooked to an audio device. > > ------------------------------------------------------------------------ > *From: *"Larry Cottrell" <lcottrell1020(at)gmail.com > > > *To: *"kolb-list" > > *Sent: *Thursday, January 14, 2016 11:01:00 PM > *Subject: *Re: Kolb-List: AOA > > > Charlie England via > > matronics.com <http://matronics.com> > > > 8:33 PM (11 minutes ago) > > > to kolb-list > > > Keep in mind that to be truly useful, AOA needs some sort of audio > in the headset, or to at least be directly in the pilot's normal > line of sight while maneuvering. If you're visually fixating on > something out to the side, bad things in front can go unnoticed. :-) > > ------------------------------------------------------------------------------------------------------------------------------ > > I think where I have it located I will be able to see it with my > peripheral vision. It actually would not take all that much to > actually make it audible, or with lights, with some contact points > at the proper places. However I have to admit that I am most > likely too lazy to do so. :-) > > I still haven't convinced myself that one is needed with a > Firestar. I am sure that it would help a novice, but I have > bounced, crashed and other unmentionables enough times that I > think I have it slammed into my head. I am open to change and if I > can land better and slower with one, I will be happy to change. > > Larry > > On Thu, Jan 14, 2016 at 8:33 PM, Charlie England > > wrote: > > Keep in mind that to be truly useful, AOA needs some sort of > audio in the headset, or to at least be directly in the > pilot's normal line of sight while maneuvering. If you're > visually fixating on something out to the side, bad things in > front can go unnoticed. :-) > > On 1/14/2016 8:31 PM, Larry Cottrell wrote: > > Thanks for the comments Jack. When the weather clears I > will do some testing and see if Firestars react > differently to Fire Flys. I will eventually go to the > yarn, but I want to try the bigger surface of the alum first. > Larry > > On Thu, Jan 14, 2016 at 7:08 PM, Jack B. Hart > > > wrote: > > > > > Larry, > > A very elegant solution > > At 01:04 AM 1/14/2016, you wrote: > > https://youtu.be/Ubx5S8rzl7s > > > I tried several different things over the years. One > worked well but > was cumbersome. The other was a yarn tuft on the side > of the > windshield. I moved it up and down to see where it > was the most > sensitive. Unfortunately that spot was where I could > not see it while > looking forward. > > Jack B. Hart FF004 > Winchester, IN > > > -- > /The older I get, the less tolerant I am of those who are intolerant./ > / > / > /If you forward this email, or any part of it, please remove my > email address before sending./ > > ________________________________________________________________________________
Date: Jan 15, 2016
Subject: aoa
What I am visualizing is a vane, much like what I have with an arm on the inside of the lexan. Run one wire to the arm. make a "board" with 4 or five wires sticking through the board with a solder lump on the ends. The arm as it moves up and down would make contact with the different wires as it moves, each lighting a different light moving up to the red one. Larry -- *The older I get, the less tolerant I am of those who are intolerant.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: aoa
Date: Jan 15, 2016
On 1/15/2016 10:41 PM, Larry Cottrell wrote: > What I am visualizing is a vane, much like what I have with an arm on > the inside of the lexan. Run one wire to the arm. make a "board" with > 4 or five wires sticking through the board with a solder lump on the > ends. The arm as it moves up and down would make contact with the > different wires as it moves, each lighting a different light moving up > to the red one. > Larry > > -- > /The older I get, the less tolerant I am of those who are intolerant./ > / > / > /If you forward this email, or any part of it, please remove my email > address before sending./ Ships passing in the night.... ________________________________________________________________________________
Date: Jan 15, 2016
Subject: Re: aoa
Ships passing in the night.... I'm betting the other one would be a lot nicer. :-) On Fri, Jan 15, 2016 at 9:46 PM, Charlie England wrote: > On 1/15/2016 10:41 PM, Larry Cottrell wrote: > > What I am visualizing is a vane, much like what I have with an arm on the > inside of the lexan. Run one wire to the arm. make a "board" with 4 or five > wires sticking through the board with a solder lump on the ends. The arm as > it moves up and down would make contact with the different wires as it > moves, each lighting a different light moving up to the red one. > Larry > > -- > *The older I get, the less tolerant I am of those who are intolerant.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > Ships passing in the night.... > -- *The older I get, the less tolerant I am of those who are intolerant.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 16, 2016
Why could you not make an AOA indicator using a fuel gauge assembly? The sender typically uses an arm that changes angle and sends a signal; instead of the wire and float, make a counterbalanced vane that would move in the airflow. Mount the gauge on its side, and now you have a needle that goes up and down at different vane angles. Ideally you take the gauge cover off and instead of empty and full, you paint on angles of attack up to stall. You could try something like this first: http://www.ebay.com/itm/Universal-52mm-2-Car-Fuel-Level-Gauge-Meter-With-Fuel-Sensor-E-1-2-F-Pointer-/401028163857?hash=item5d5f242911:g:sHEAAOSweuxWSo-T&vxp=mtr Looking at the sender unit in this set, if you cut off everything you didn't need, the sender itself would be about 2" across, plus however big your vane is. Once you got that to work, but say you wanted a lighted gauge instead, one that went up and down, you could try something like this: http://www.ebay.com/itm/Universal-Motor-Motorcycle-2-Fuel-Meter-Digital-Display-Fuel-Ratio-Level-Gauge-/201502529749?hash=item2eea7c98d5:g:nr0AAOSwYIhWlint&vxp=mtr Now you have led's that go up and down as your AOA changed. And if you repainted the face and mounted it upside down, you have yellow and red at the top. Then stick the gauge in a little holder that sits on top of your panel so it is in your immediate vision while you are on final: http://www.ebay.com/itm/52Mm-2-Adjustable-Swivel-Dash-Mount-Single-Racing-Gauge-Cup-Holder-Pod-Bracket-/172060327859?hash=item280f983fb3:g:F8IAAOSwGotWlXS6&vxp=mtr Seems to me a fairly simple exercise in making your vane assembly light and responsive, finding the best airflow location, and doing some calibrating. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452018#452018 ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 16, 2016
My first AOA design was to use a small nuclear reactor coupled to a scintillator...hooked to a high voltage shock device in the seat of the plane.... but the engineering would take too long... :-) so how about this...a linear potentiometer hooked to the air vane(some weather protection) ...two leads run to an indicator on the panel... the indicator being a Milli volt meter...in series with another small pot /AA battery to adjust the meter reading . Meter would be over laid with green and red markers... simply adjust the potentiometer on the dash into the red when stalled onset is sensed.. Herb On 01/16/2016 07:37 AM, Richard Pike wrote: > > Why could you not make an AOA indicator using a fuel gauge assembly? The sender typically uses an arm that changes angle and sends a signal; instead of the wire and float, make a counterbalanced vane that would move in the airflow. Mount the gauge on its side, and now you have a needle that goes up and down at different vane angles. Ideally you take the gauge cover off and instead of empty and full, you paint on angles of attack up to stall. > You could try something like this first: > http://www.ebay.com/itm/Universal-52mm-2-Car-Fuel-Level-Gauge-Meter-With-Fuel-Sensor-E-1-2-F-Pointer-/401028163857?hash=item5d5f242911:g:sHEAAOSweuxWSo-T&vxp=mtr > Looking at the sender unit in this set, if you cut off everything you didn't need, the sender itself would be about 2" across, plus however big your vane is. > > Once you got that to work, but say you wanted a lighted gauge instead, one that went up and down, you could try something like this: > http://www.ebay.com/itm/Universal-Motor-Motorcycle-2-Fuel-Meter-Digital-Display-Fuel-Ratio-Level-Gauge-/201502529749?hash=item2eea7c98d5:g:nr0AAOSwYIhWlint&vxp=mtr > Now you have led's that go up and down as your AOA changed. And if you repainted the face and mounted it upside down, you have yellow and red at the top. > > Then stick the gauge in a little holder that sits on top of your panel so it is in your immediate vision while you are on final: > http://www.ebay.com/itm/52Mm-2-Adjustable-Swivel-Dash-Mount-Single-Racing-Gauge-Cup-Holder-Pod-Bracket-/172060327859?hash=item280f983fb3:g:F8IAAOSwGotWlXS6&vxp=mtr > > Seems to me a fairly simple exercise in making your vane assembly light and responsive, finding the best airflow location, and doing some calibrating. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Would you consider yourself to be a good person? > https://www.youtube.com/watch?v=VWcDXT6pH7A > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452018#452018 > > -- Signature text; Add catchy phrase here.. ________________________________________________________________________________
Date: Jan 16, 2016
Subject: Re: AOA
Sounds good, you guy's let me know when you get them finished. It appears that my work is done here. :-) For me however, I don't have room on my panel for another gage, so some form of lights would work the best for me. Hopefully one of us "Kolbers" can come up with something that is worth doing. Larry On Sat, Jan 16, 2016 at 7:13 AM, Herb wrote: > > > so how about this...a linear potentiometer hooked to the air vane(some > weather protection) ...two leads run to an indicator on the panel... the > indicator being a Milli volt meter...in series with another small pot /AA > battery to adjust the meter reading . Meter would be over laid with green > and red markers... simply adjust the potentiometer on the dash into the red > when stalled onset is sensed.. Herb > > On 01/16/2016 07:37 AM, Richard Pike wrote: > >> > >> >> Why could you not make an AOA indicator using a fuel gauge assembly? The >> sender typically uses an arm that changes angle and sends a signal; instead >> of the wire and float, make a counterbalanced vane that would move in the >> airflow. Mount the gauge on its side, and now you have a needle that goes >> up and down at different vane angles. Ideally you take the gauge cover off >> and instead of empty and full, you paint on angles of attack up to stall. >> You could try something like this first: >> >> http://www.ebay.com/itm/Universal-52mm-2-Car-Fuel-Level-Gauge-Meter-With-Fuel-Sensor-E-1-2-F-Pointer-/401028163857?hash=item5d5f242911:g:sHEAAOSweuxWSo-T&vxp=mtr >> Looking at the sender unit in this set, if you cut off everything you >> didn't need, the sender itself would be about 2" across, plus however big >> your vane is. >> >> Once you got that to work, but say you wanted a lighted gauge instead, >> one that went up and down, you could try something like this: >> >> http://www.ebay.com/itm/Universal-Motor-Motorcycle-2-Fuel-Meter-Digital-Display-Fuel-Ratio-Level-Gauge-/201502529749?hash=item2eea7c98d5:g:nr0AAOSwYIhWlint&vxp=mtr >> Now you have led's that go up and down as your AOA changed. And if you >> repainted the face and mounted it upside down, you have yellow and red at >> the top. >> >> Then stick the gauge in a little holder that sits on top of your panel so >> it is in your immediate vision while you are on final: >> >> http://www.ebay.com/itm/52Mm-2-Adjustable-Swivel-Dash-Mount-Single-Racing-Gauge-Cup-Holder-Pod-Bracket-/172060327859?hash=item280f983fb3:g:F8IAAOSwGotWlXS6&vxp=mtr >> >> Seems to me a fairly simple exercise in making your vane assembly light >> and responsive, finding the best airflow location, and doing some >> calibrating. >> >> -------- >> Richard Pike >> Kolb MKIII N420P (420ldPoops) >> Kingsport, TN 3TN0 >> >> Would you consider yourself to be a good person? >> https://www.youtube.com/watch?v=VWcDXT6pH7A >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=452018#452018 >> >> >> >> >> >> >> >> >> >> >> > -- > Signature text; Add catchy phrase here.. > > -- *The older I get, the less tolerant I am of those who are intolerant.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 16, 2016
actually the voltage indicator bar/leds could be made to work.. I seem to recall the order is red , yellow and green .. Just turn it up side down.. didn't like my first idea?? The stun gun in the seat surely would be spot on??? :-) On 01/16/2016 09:21 AM, Larry Cottrell wrote: > Sounds good, you guy's let me know when you get them finished. It > appears that my work is done here. :-) > > For me however, I don't have room on my panel for another gage, so > some form of lights would work the best for me. Hopefully one of us > "Kolbers" can come up with something that is worth doing. > Larry > > > On Sat, Jan 16, 2016 at 7:13 AM, Herb > wrote: > > > > > > so how about this...a linear potentiometer hooked to the air > vane(some weather protection) ...two leads run to an indicator on > the panel... the indicator being a Milli volt meter...in series > with another small pot /AA battery to adjust the meter reading . > Meter would be over laid with green and red markers... simply > adjust the potentiometer on the dash into the red when stalled > onset is sensed.. Herb > > On 01/16/2016 07:37 AM, Richard Pike wrote: > > > > > Why could you not make an AOA indicator using a fuel gauge > assembly? The sender typically uses an arm that changes angle > and sends a signal; instead of the wire and float, make a > counterbalanced vane that would move in the airflow. Mount the > gauge on its side, and now you have a needle that goes up and > down at different vane angles. Ideally you take the gauge > cover off and instead of empty and full, you paint on angles > of attack up to stall. > You could try something like this first: > http://www.ebay.com/itm/Universal-52mm-2-Car-Fuel-Level-Gauge-Meter-With-Fuel-Sensor-E-1-2-F-Pointer-/401028163857?hash=item5d5f242911:g:sHEAAOSweuxWSo-T&vxp=mtr > Looking at the sender unit in this set, if you cut off > everything you didn't need, the sender itself would be about > 2" across, plus however big your vane is. > > Once you got that to work, but say you wanted a lighted gauge > instead, one that went up and down, you could try something > like this: > http://www.ebay.com/itm/Universal-Motor-Motorcycle-2-Fuel-Meter-Digital-Display-Fuel-Ratio-Level-Gauge-/201502529749?hash=item2eea7c98d5:g:nr0AAOSwYIhWlint&vxp=mtr > Now you have led's that go up and down as your AOA changed. > And if you repainted the face and mounted it upside down, you > have yellow and red at the top. > > Then stick the gauge in a little holder that sits on top of > your panel so it is in your immediate vision while you are on > final: > http://www.ebay.com/itm/52Mm-2-Adjustable-Swivel-Dash-Mount-Single-Racing-Gauge-Cup-Holder-Pod-Bracket-/172060327859?hash=item280f983fb3:g:F8IAAOSwGotWlXS6&vxp=mtr > > Seems to me a fairly simple exercise in making your vane > assembly light and responsive, finding the best airflow > location, and doing some calibrating. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Would you consider yourself to be a good person? > https://www.youtube.com/watch?v=VWcDXT6pH7A > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452018#452018 > > > -- > Signature text; Add catchy phrase here.. > > > ========== > br> fts!) > r> > href="http://www.buildersbooks.com" rel="noreferrer" > target="_blank">www.buildersbooks.com > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > ========== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > > -- > /The older I get, the less tolerant I am of those who are intolerant./ > / > / > /If you forward this email, or any part of it, please remove my email > address before sending./ -- Signature text; Add catchy phrase here.. ________________________________________________________________________________
Date: Jan 16, 2016
Subject: Re: aoa
Moving An arm past a bunch of solder blobs sounds like a bunch of drag and sticking. Let the wind vain turn a pot. (Potentiometer) It seems in the RC world there are progressive led lights that respond to changing voltage. Run 12 v and ground to the sides of the pot. And the center will vary from 0 to 12 volts when the pot is turned. You could limit the travel of the wind vain to limit the possible output voltages, or put resistors in series with the 12 v and or ground terminals of the pot. This would keep the center outlet of the pot voltages within limits of the led light bar voltage indicator. The total resistance value of the pot would be determined in part by the max or min current requirements of the led voltage indicator. IE: a 5 k ohm or a 10, 15, 50 k ohm pot. The greater ohm value of the pot and still be able to drive the led volt indicator will consume the least amount of power. Boyd young ________________________________________________________________________________
Date: Jan 16, 2016
Subject: Re: aoa
I am afraid that I am only " blob " qualified, after all I spent my entire career as a Rail Road welder. Send me pictures of the finished product. :-) Larry On Sat, Jan 16, 2016 at 9:15 AM, B Young wrote: > Moving An arm past a bunch of solder blobs sounds like a bunch of drag and > sticking. > Let the wind vain turn a pot. (Potentiometer) It seems in the RC world > there are progressive led lights that respond to changing voltage. Run 12 > v and ground to the sides of the pot. And the center will vary from 0 to > 12 volts when the pot is turned. You could limit the travel of the wind > vain to limit the possible output voltages, or put resistors in series > with the 12 v and or ground terminals of the pot. This would keep the > center outlet of the pot voltages within limits of the led light bar > voltage indicator. > The total resistance value of the pot would be determined in part by the > max or min current requirements of the led voltage indicator. IE: a 5 k > ohm or a 10, 15, 50 k ohm pot. The greater ohm value of the pot and still > be able to drive the led volt indicator will consume the least amount of > power. > > Boyd young > -- *The older I get, the less tolerant I am of those who are intolerant.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: aoa
Date: Jan 16, 2016
Blobbers are welcome in the Kolb family. john h mkIII Titus, AL From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Saturday, January 16, 2016 10:23 AM Subject: Re: Kolb-List: aoa I am afraid that I am only " blob " qualified, after all I spent my entire career as a Rail Road welder. Send me pictures of the finished product. :-) Larry On Sat, Jan 16, 2016 at 9:15 AM, B Young wrote: Moving An arm past a bunch of solder blobs sounds like a bunch of drag and sticking. Let the wind vain turn a pot. (Potentiometer) It seems in the RC world there are progressive led lights that respond to changing voltage. Run 12 v and ground to the sides of the pot. And the center will vary from 0 to 12 volts when the pot is turned. You could limit the travel of the wind vain to limit the possible output voltages, or put resistors in series with the 12 v and or ground terminals of the pot. This would keep the center outlet of the pot voltages within limits of the led light bar voltage indicator. The total resistance value of the pot would be determined in part by the max or min current requirements of the led voltage indicator. IE: a 5 k ohm or a 10, 15, 50 k ohm pot. The greater ohm value of the pot and still be able to drive the led volt indicator will consume the least amount of power. Boyd young -- The older I get, the less tolerant I am of those who are intolerant. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Subject: Re: aoa
Date: Jan 16, 2016
What I said! Just not as eloquently....:-) On 01/16/2016 10:15 AM, B Young wrote: > > Moving An arm past a bunch of solder blobs sounds like a bunch of drag > and sticking. > Let the wind vain turn a pot. (Potentiometer) It seems in the RC > world there are progressive led lights that respond to changing > voltage. Run 12 v and ground to the sides of the pot. And the > center will vary from 0 to 12 volts when the pot is turned. You > could limit the travel of the wind vain to limit the possible output > voltages, or put resistors in series with the 12 v and or ground > terminals of the pot. This would keep the center outlet of the pot > voltages within limits of the led light bar voltage indicator. > The total resistance value of the pot would be determined in part by > the max or min current requirements of the led voltage indicator. IE: > a 5 k ohm or a 10, 15, 50 k ohm pot. The greater ohm value of the > pot and still be able to drive the led volt indicator will consume the > least amount of power. > > Boyd young > -- Signature text; Add catchy phrase here.. ________________________________________________________________________________
Subject: Re: aoa
Date: Jan 16, 2016
RnJvbSB0aGUgZGVwdGggb2YgbHVya2luZyBtb2RlLCBJIGFtIGluc3BpcmVkIHRvIGNvbW1lbnQu DQoNCkJveWQsICANCiAgVGhlICJtb3ZpbmcgYXJtIiBkb2Vzbid0IHRvdWNoIGFueSBzb2xkZXIg YmxvYnMuICBUaGUgZGV2aWNlIHVzZSBhIG1hZ25ldCBmbHVzaCBtb3VudGVkIG9uIHRoZSB0b3Jw ZWRvLCBhbmQgdGhlIGNpcmN1aXRyeSBkZXRlY3RzIHRoZSBtYWduZXRpc20gKHdpdGhvdXQgYWN0 dWFsbHkgdG91Y2hpbmcgYW55dGhpbmcpLiAgSXQncyBrbm93biBhcyB0aGUgSGFsbCBFZmZlY3Qu ICBJZiBJJ20gY29ycmVjdCwgSSByb3VuZGVkIGFsbCBvZiB0aGUgZWxlY3Ryb25pYyBwYXJ0cyB1 cCBhYm91dCA0IHllYXJzIGFnbyB0byBidWlsZCBhIGZldyBvZiB0aGVzZSBBT0EgaW5kaWNhdG9y cy4NCg0KUmVnYXJkaW5nIHRoZSBzbWFsbCBJQyBjaXJjdWl0IHdpdGggdGhlIDEwIHNlZ21lbnQg cmVkL3llbGxvdy9ncmVlbiBMRURzLCBJIGhhdmUgdHdvIG9mIHRoZW0sIGJ1dCBvbiBteSBBT0Eg c3lzdGVtIEkgZGVjaWRlZCBJIHdhbnRlZCB0aGUgdmlzdWFsIGltcGFjdCBNVUNIIG1vcmUgbm90 aWNlYWJsZSwgc28gSSBidWlsdCBteSBvd24gaW5kaXZpZHVhbCAiMTAgcmVkL3llbGxvdy9ncmVl biBMRURzIiB1c2luZyA1bW0gTEVEcy4NCkJpZ2dlciwgbG9uZ2VyLCBldGMsIGV0Yy4gIChJIGdl dCBteSBBT0EgZnVuY3Rpb24gZnJvbSBteSBEeW5vbiBEMTBBLCB3aGljaCBoYXMgYW4gYXVkaW8g YWxhcm0gdGhhdCBJIGhhdmUgd2lyZWQgaW50byBteSBpbnRlcmNvbSwgdGh1cyBJIGhhdmUgYnJp Z2h0IExFRHMgYW5kIGF1ZGlvIG5vdGlmaWNhdGlvbiBmb3IgYW4gaW1wZW5kaW5nIHN0YWxsLikN Cg0KQWx0aG91Z2ggYW4gQU9BIGluZGljYXRvciBpcyB2ZXJ5IHVzZWZ1bCwgYSBsaWZ0IHJlc2Vy dmUgaW5kaWNhdG9yKExSSSkgaXMgbW9yZSB1c2VmdWwsIGFuZCBtdWNoIGxlc3MsIG9rYXkgc29t ZSBsZXNzLCB0byBidWlsZC4gIFRoZSBMUkkgdXNlcyBhaXIgcHJlc3N1cmUgZGlmZmVyZW50aWFs IHRvIGRldGVybWluZSB3aGVuIGEgd2luZyBpcyBubyBsb25nZXIgZmx5aW5nLiAgVGhlIExSSSBp cyBhbHdheXMgYWNjdXJhdGUgYmVjYXVzZSBpdCBtZWFzdXJlcyB0aGUgcG9pbnQgYXQgd2hpY2gg dGhlIHN0aWxsIGJlZ2lucywgYW5kIGZhY3RvcnMgc3VjaCBhcyB3ZWlnaHQsIHdpbmcgaW5jaWRl bmNlLCB3aGF0ZXZlciwgaGF2ZSBubyBlZmZlY3Qgb24gaXQncyBhY2N1cmFjeS4NCg0KSSBoYXZl IGFscmVhZHkgYnVpbHQgb25lIChhIGNvcHkgb2YgYSBzdG9yZSBib3VnaHQgdW5pdCwgd2hpY2gg SSBhbHNvIGhhdmUpLikuIEkgaGF2ZSB0aGUgZ2FnZXMgYW5kIHN1cHBsaWVzIHRvIGJ1aWxkIDMg bW9yZS4NCg0KTWlrZSBXZWxjaA0KDQpTZW50IGZyb20gbXkgaVBhZA0KDQo+IE9uIEphbiAxNiwg MjAxNiwgYXQgMTA6MTggQU0sIEIgWW91bmcgPGJ5b3VuZ3BsdW1iaW5nQGdtYWlsLmNvbT4gd3Jv dGU6DQo+IA0KPiBNb3ZpbmcgQW4gYXJtIHBhc3QgYSBidW5jaCBvZiBzb2xkZXIgYmxvYnMgc291 bmRzIGxpa2UgYSBidW5jaCBvZiBkcmFnIGFuZCBzdGlja2luZy4NCj4gICBMZXQgdGhlIHdpbmQg dmFpbiB0dXJuIGEgcG90LiAoUG90ZW50aW9tZXRlcikgIEl0IHNlZW1zIGluIHRoZSBSQyB3b3Js ZCB0aGVyZSBhcmUgcHJvZ3Jlc3NpdmUgbGVkIGxpZ2h0cyB0aGF0IHJlc3BvbmQgdG8gY2hhbmdp bmcgdm9sdGFnZS4gICBSdW4gMTIgdiBhbmQgZ3JvdW5kIHRvIHRoZSBzaWRlcyBvZiB0aGUgcG90 LiAgQW5kIHRoZSBjZW50ZXIgd2lsbCB2YXJ5IGZyb20gMCB0byAxMiB2b2x0cyB3aGVuIHRoZSBw b3QgaXMgdHVybmVkLiAgICBZb3UgY291bGQgbGltaXQgdGhlIHRyYXZlbCBvZiB0aGUgd2luZCB2 YWluIHRvIGxpbWl0IHRoZSBwb3NzaWJsZSBvdXRwdXQgdm9sdGFnZXMsICBvciBwdXQgcmVzaXN0 b3JzIGluIHNlcmllcyB3aXRoIHRoZSAxMiB2IGFuZCBvciBncm91bmQgdGVybWluYWxzIG9mICB0 aGUgcG90LiAgVGhpcyB3b3VsZCBrZWVwIHRoZSBjZW50ZXIgb3V0bGV0IG9mIHRoZSBwb3Qgdm9s dGFnZXMgd2l0aGluIGxpbWl0cyBvZiB0aGUgbGVkIGxpZ2h0IGJhciB2b2x0YWdlICBpbmRpY2F0 b3IuDQo+IFRoZSB0b3RhbCByZXNpc3RhbmNlICB2YWx1ZSBvZiB0aGUgcG90IHdvdWxkIGJlIGRl dGVybWluZWQgaW4gcGFydCBieSB0aGUgbWF4IG9yIG1pbiBjdXJyZW50IHJlcXVpcmVtZW50cyBv ZiB0aGUgbGVkIHZvbHRhZ2UgaW5kaWNhdG9yLiAgSUU6IGEgNSBrIG9obSBvciBhIDEwLCAxNSwg NTAgayBvaG0gcG90LiAgIFRoZSBncmVhdGVyIG9obSB2YWx1ZSBvZiB0aGUgcG90IGFuZCBzdGls bCBiZSBhYmxlIHRvIGRyaXZlIHRoZSBsZWQgdm9sdCBpbmRpY2F0b3Igd2lsbCBjb25zdW1lIHRo ZSBsZWFzdCBhbW91bnQgb2YgcG93ZXIuDQo+IA0KPiBCb3lkIHlvdW5nDQo ________________________________________________________________________________
Date: Jan 16, 2016
Subject: Re: AOA
Back to my idea of a magnet and sensor. Instead of one sensor have four or five in an arc, hook each to a light of a different color shining on the wind shield to have a heads up display. ----- Original Message ----- From: "Larry Cottrell" <lcottrell1020(at)gmail.com> Sent: Saturday, January 16, 2016 10:21:00 AM Subject: Re: Kolb-List: Re: AOA Sounds good, you guy's let me know when you get them finished. It appears that my work is done here. :-) For me however, I don't have room on my panel for another gage, so some form of lights would work the best for me. Hopefully one of us "Kolbers" can come up with something that is worth doing. Larry On Sat, Jan 16, 2016 at 7:13 AM, Herb < Herbgh(at)nctc.com > wrote: so how about this...a linear potentiometer hooked to the air vane(some weather protection) ...two leads run to an indicator on the panel... the indicator being a Milli volt meter...in series with another small pot /AA battery to adjust the meter reading . Meter would be over laid with green and red markers... simply adjust the potentiometer on the dash into the red when stalled onset is sensed.. Herb On 01/16/2016 07:37 AM, Richard Pike wrote:
Why could you not make an AOA indicator using a fuel gauge assembly? The sender typically uses an arm that changes angle and sends a signal; instead of the wire and float, make a counterbalanced vane that would move in the airflow. Mount the gauge on its side, and now you have a needle that goes up and down at different vane angles. Ideally you take the gauge cover off and instead of empty and full, you paint on angles of attack up to stall. You could try something like this first: http://www.ebay.com/itm/Universal-52mm-2-Car-Fuel-Level-Gauge-Meter-With-Fuel-Sensor-E-1-2-F-Pointer-/401028163857?hash=item5d5f242911:g:sHEAAOSweuxWSo-T&vxp=mtr Looking at the sender unit in this set, if you cut off everything you didn't need, the sender itself would be about 2" across, plus however big your vane is. Once you got that to work, but say you wanted a lighted gauge instead, one that went up and down, you could try something like this: http://www.ebay.com/itm/Universal-Motor-Motorcycle-2-Fuel-Meter-Digital-Display-Fuel-Ratio-Level-Gauge-/201502529749?hash=item2eea7c98d5:g:nr0AAOSwYIhWlint&vxp=mtr Now you have led's that go up and down as your AOA changed. And if you repainted the face and mounted it upside down, you have yellow and red at the top. Then stick the gauge in a little holder that sits on top of your panel so it is in your immediate vision while you are on final: http://www.ebay.com/itm/52Mm-2-Adjustable-Swivel-Dash-Mount-Single-Racing-Gauge-Cup-Holder-Pod-Bracket-/172060327859?hash=item280f983fb3:g:F8IAAOSwGotWlXS6&vxp=mtr Seems to me a fairly simple exercise in making your vane assembly light and responsive, finding the best airflow location, and doing some calibrating. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452018#452018 -- Signature text; Add catchy phrase here.. =========== br> fts!) r> > href="http://www.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com rel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. =========== -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List =========== FORUMS - eferrer" target="_blank">http://forums.matronics.com =========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ===========
Date: Jan 16, 2016
Subject: Re: AOA
I know all this can be done electronically but I thought maybe it could be done in such a way that any mechanic could clobber one up. ----- Original Message ----- From: mojavjoe(at)comcast.net Sent: Saturday, January 16, 2016 12:51:42 PM Subject: Re: Kolb-List: Re: AOA Back to my idea of a magnet and sensor. Instead of one sensor have four or five in an arc, hook each to a light of a different color shining on the wind shield to have a heads up display. ----- Original Message ----- From: "Larry Cottrell" <lcottrell1020(at)gmail.com> Sent: Saturday, January 16, 2016 10:21:00 AM Subject: Re: Kolb-List: Re: AOA Sounds good, you guy's let me know when you get them finished. It appears that my work is done here. :-) For me however, I don't have room on my panel for another gage, so some form of lights would work the best for me. Hopefully one of us "Kolbers" can come up with something that is worth doing. Larry On Sat, Jan 16, 2016 at 7:13 AM, Herb < Herbgh(at)nctc.com > wrote: so how about this...a linear potentiometer hooked to the air vane(some weather protection) ...two leads run to an indicator on the panel... the indicator being a Milli volt meter...in series with another small pot /AA battery to adjust the meter reading . Meter would be over laid with green and red markers... simply adjust the potentiometer on the dash into the red when stalled onset is sensed.. Herb On 01/16/2016 07:37 AM, Richard Pike wrote:
Subject: Re: AOA
Date: Jan 16, 2016
The cheapest, says frugal Herb, is the 3914 led 10 segment driver...the 10 segment led with green, red and yellow leds...two or three resistors..9 volt battery..or 12 volts if available and three wires going to the vane and pot on the wing or strut... The schematic is here: http://www.eleccircuit.com/the-led-display-voltmeter-in-probe-model/ and the circuit can simplified by removing and combining r2 and 3 into a 100k resistor..removing the two voltage leads...120 v and 1.2 volt range.. The pot will have the slider going to the probe...one end to 12v and the other to gnd.. the vane needs to be set screwed to the pot such that one can trial and error the stall point.. Then again...the 100k resistor or the 909k (100k is ok) could be adjustable and the pot could be accessible in flight... 2 dollar parts on ebay..circuit board can be some perf board with .1 spacing...think that is the spacing?? Herb slow day huh?? :-) On 01/16/2016 12:07 PM, mojavjoe(at)comcast.net wrote: > I know all this can be done electronically but I thought maybe > it could be done in such a way that any mechanic could clobber one up. > > ------------------------------------------------------------------------ > *From: *mojavjoe(at)comcast.net > *To: *"kolb-list" > *Sent: *Saturday, January 16, 2016 12:51:42 PM > *Subject: *Re: Kolb-List: Re: AOA > > Back to my idea of a magnet and sensor. Instead of one sensor have > four or five in an arc, hook each to a light of a different color > shining on the wind shield to have a heads up display. > > ------------------------------------------------------------------------ > *From: *"Larry Cottrell" <lcottrell1020(at)gmail.com> > *To: *"kolb-list" > *Sent: *Saturday, January 16, 2016 10:21:00 AM > *Subject: *Re: Kolb-List: Re: AOA > > Sounds good, you guy's let me know when you get them finished. It > appears that my work is done here. :-) > > For me however, I don't have room on my panel for another gage, so > some form of lights would work the best for me. Hopefully one of us > "Kolbers" can come up with something that is worth doing. > Larry > > > On Sat, Jan 16, 2016 at 7:13 AM, Herb > wrote: > > > > > > so how about this...a linear potentiometer hooked to the air > vane(some weather protection) ...two leads run to an indicator on > the panel... the indicator being a Milli volt meter...in series > with another small pot /AA battery to adjust the meter reading . > Meter would be over laid with green and red markers... simply > adjust the potentiometer on the dash into the red when stalled > onset is sensed.. Herb > > On 01/16/2016 07:37 AM, Richard Pike wrote: > > > > > Why could you not make an AOA indicator using a fuel gauge > assembly? The sender typically uses an arm that changes angle > and sends a signal; instead of the wire and float, make a > counterbalanced vane that would move in the airflow. Mount the > gauge on its side, and now you have a needle that goes up and > down at different vane angles. Ideally you take the gauge > cover off and instead of empty and full, you paint on angles > of attack up to stall. > You could try something like this first: > http://www.ebay.com/itm/Universal-52mm-2-Car-Fuel-Level-Gauge-Meter-With-Fuel-Sensor-E-1-2-F-Pointer-/401028163857?hash=item5d5f242911:g:sHEAAOSweuxWSo-T&vxp=mtr > Looking at the sender unit in this set, if you cut off > everything you didn't need, the sender itself would be about > 2" across, plus however big your vane is. > > Once you got that to work, but say you wanted a lighted gauge > instead, one that went up and down, you could try something > like this: > http://www.ebay.com/itm/Universal-Motor-Motorcycle-2-Fuel-Meter-Digital-Display-Fuel-Ratio-Level-Gauge-/201502529749?hash=item2eea7c98d5:g:nr0AAOSwYIhWlint&vxp=mtr > Now you have led's that go up and down as your AOA changed. > And if you repainted the face and mounted it upside down, you > have yellow and red at the top. > > Then stick the gauge in a little holder that sits on top of > your panel so it is in your immediate vision while you are on > final: > http://www.ebay.com/itm/52Mm-2-Adjustable-Swivel-Dash-Mount-Single-Racing-Gauge-Cup-Holder-Pod-Bracket-/172060327859?hash=item280f983fb3:g:F8IAAOSwGotWlXS6&vxp=mtr > > Seems to me a fairly simple exercise in making your vane > assembly light and responsive, finding the best airflow > location, and doing some calibrating. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Would you consider yourself to be a good person? > https://www.youtube.com/watch?v=VWcDXT6pH7A > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452018#452018 > > > -- > Signature text; Add catchy phrase here.. > > > ========== > br> fts!) > r> > href="http://www.buildersbooks.com" rel="noreferrer" > target="_blank">www.buildersbooks.com > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > ========== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > > -- > /The older I get, the less tolerant I am of those who are intolerant./ > / > / > /If you forward this email, or any part of it, please remove my email > address before sending./ > > -- Signature text; Add catchy phrase here.. ________________________________________________________________________________
Subject: Re: aoa
Date: Jan 16, 2016
Frugal Herb again....in the case of the LRI ..I think a throw away blood pressure gauges could work? On 01/16/2016 11:30 AM, Mike wrote: > From the depth of lurking mode, I am inspired to comment. > > Boyd, > The "moving arm" doesn't touch any solder blobs. The device use a > magnet flush mounted on the torpedo, and the circuitry detects the > magnetism (without actually touching anything). It's known as the > Hall Effect. If I'm correct, I rounded all of the electronic parts up > about 4 years ago to build a few of these AOA indicators. > > Regarding the small IC circuit with the 10 segment red/yellow/green > LEDs, I have two of them, but on my AOA system I decided I wanted the > visual impact MUCH more noticeable, so I built my own individual "10 > red/yellow/green LEDs" using 5mm LEDs. > Bigger, longer, etc, etc. (I get my AOA function from my Dynon D10A, > which has an audio alarm that I have wired into my intercom, thus I > have bright LEDs and audio notification for an impending stall.) > > Although an AOA indicator is very useful, a lift reserve > indicator(LRI) is more useful, and much less, okay some less, to > build. The LRI uses air pressure differential to determine when a > wing is no longer flying. The LRI is always accurate because it > measures the point at which the still begins, and factors such as > weight, wing incidence, whatever, have no effect on it's accuracy. > > I have already built one (a copy of a store bought unit, which I also > have).). I have the gages and supplies to build 3 more. > > Mike Welch > > Sent from my iPad > > On Jan 16, 2016, at 10:18 AM, B Young > wrote: > >> Moving An arm past a bunch of solder blobs sounds like a bunch of >> drag and sticking. >> Let the wind vain turn a pot. (Potentiometer) It seems in the RC >> world there are progressive led lights that respond to changing >> voltage. Run 12 v and ground to the sides of the pot. And the >> center will vary from 0 to 12 volts when the pot is turned. You >> could limit the travel of the wind vain to limit the possible output >> voltages, or put resistors in series with the 12 v and or ground >> terminals of the pot. This would keep the center outlet of the pot >> voltages within limits of the led light bar voltage indicator. >> The total resistance value of the pot would be determined in part by >> the max or min current requirements of the led voltage indicator. >> IE: a 5 k ohm or a 10, 15, 50 k ohm pot. The greater ohm value of >> the pot and still be able to drive the led volt indicator will >> consume the least amount of power. >> >> Boyd young >> -- Signature text; Add catchy phrase here.. ________________________________________________________________________________
Date: Jan 16, 2016
Subject: Lift Reserve Indicator (LRI)
No, a blood pressure gauge would not likely work. At least, I'd doubt it. T he gauge the inventor/seller uses is the Dwyer Minihelic II, model 2-5002. 0 -2" w.c. The commercially sold unit has a new red,yellow,green silk-screene d face. The pitot mast is a nice afternoon project. See the gauge below. Mike Welch http://www.ebay.com/itm/Dwyer-Minihelic-II-Series-5000-Pressure-Gauge-Model- No-2-5002-0-2-w-c-/252075719317?hash=item3ab0e23a95:g:Pp4AAOSw3ydV5KFd Sent from my iPad > On Jan 16, 2016, at 1:12 PM, Herb wrote: > > Frugal Herb again....in the case of the LRI ..I think a throw away blood p ressure gauges could work? > >> On 01/16/2016 11:30 AM, Mike wrote: >> =46rom the depth of lurking mode, I am inspired to comment. >> >> Boyd, >> The "moving arm" doesn't touch any solder blobs. The device use a magn et flush mounted on the torpedo, and the circuitry detects the magnetism (wi thout actually touching anything). It's known as the Hall Effect. If I'm c orrect, I rounded all of the electronic parts up about 4 years ago to build a few of these AOA indicators. >> >> Regarding the small IC circuit with the 10 segment red/yellow/green LEDs, I have two of them, but on my AOA system I decided I wanted the visual impa ct MUCH more noticeable, so I built my own individual "10 red/yellow/green L EDs" using 5mm LEDs. >> Bigger, longer, etc, etc. (I get my AOA function from my Dynon D10A, whi ch has an audio alarm that I have wired into my intercom, thus I have bright LEDs and audio notification for an impending stall.) >> >> Although an AOA indicator is very useful, a lift reserve indicator(LRI) i s more useful, and much less, okay some less, to build. The LRI uses air pr essure differential to determine when a wing is no longer flying. The LRI i s always accurate because it measures the point at which the still begins, a nd factors such as weight, wing incidence, whatever, have no effect on it's a ccuracy. >> >> I have already built one (a copy of a store bought unit, which I also hav e).). I have the gages and supplies to build 3 more. >> >> Mike Welch >> >> Sent from my iPad >> >> On Jan 16, 2016, at 10:18 AM, B Young wrote: >> >>> Moving An arm past a bunch of solder blobs sounds like a bunch of drag a nd sticking. >>> Let the wind vain turn a pot. (Potentiometer) It seems in the RC worl d there are progressive led lights that respond to changing voltage. Run 1 2 v and ground to the sides of the pot. And the center will vary from 0 to 1 2 volts when the pot is turned. You could limit the travel of the wind va in to limit the possible output voltages, or put resistors in series with t he 12 v and or ground terminals of the pot. This would keep the center out let of the pot voltages within limits of the led light bar voltage indicato r. >>> The total resistance value of the pot would be determined in part by th e max or min current requirements of the led voltage indicator. IE: a 5 k o hm or a 10, 15, 50 k ohm pot. The greater ohm value of the pot and still b e able to drive the led volt indicator will consume the least amount of powe r. >>> >>> Boyd young >>> > > -- > Signature text; Add catchy phrase here.. ________________________________________________________________________________
Subject: Re: Lift Reserve Indicator (LRI)
Date: Jan 16, 2016
Yep...2 inches of water(used these gauges with IBM and Storage Tech) is equal to 3.73 mm of mercury...and blood pressure gauges start at 20 mm of hg... not sensitive enough... Herb On 01/16/2016 01:50 PM, Mike wrote: > No, a blood pressure gauge would not likely work. At least, I'd doubt > it. The gauge the inventor/seller uses is the Dwyer Minihelic II, > model 2-5002. 0-2" w.c. The commercially sold unit has a new > red,yellow,green silk-screened face. The pitot mast is a nice > afternoon project. See the gauge below. > > Mike Welch > > http://www.ebay.com/itm/Dwyer-Minihelic-II-Series-5000-Pressure-Gauge-Model-No-2-5002-0-2-w-c-/252075719317?hash=item3ab0e23a95:g:Pp4AAOSw3ydV5KFd > > > Sent from my iPad > > On Jan 16, 2016, at 1:12 PM, Herb > wrote: > >> Frugal Herb again....in the case of the LRI ..I think a throw away >> blood pressure gauges could work? >> >> On 01/16/2016 11:30 AM, Mike wrote: >>> From the depth of lurking mode, I am inspired to comment. >>> >>> Boyd, >>> The "moving arm" doesn't touch any solder blobs. The device use a >>> magnet flush mounted on the torpedo, and the circuitry detects the >>> magnetism (without actually touching anything). It's known as the >>> Hall Effect. If I'm correct, I rounded all of the electronic parts >>> up about 4 years ago to build a few of these AOA indicators. >>> >>> Regarding the small IC circuit with the 10 segment red/yellow/green >>> LEDs, I have two of them, but on my AOA system I decided I wanted >>> the visual impact MUCH more noticeable, so I built my own individual >>> "10 red/yellow/green LEDs" using 5mm LEDs. >>> Bigger, longer, etc, etc. (I get my AOA function from my Dynon >>> D10A, which has an audio alarm that I have wired into my intercom, >>> thus I have bright LEDs and audio notification for an impending stall.) >>> >>> Although an AOA indicator is very useful, a lift reserve >>> indicator(LRI) is more useful, and much less, okay some less, to >>> build. The LRI uses air pressure differential to determine when a >>> wing is no longer flying. The LRI is always accurate because it >>> measures the point at which the still begins, and factors such as >>> weight, wing incidence, whatever, have no effect on it's accuracy. >>> >>> I have already built one (a copy of a store bought unit, which I >>> also have).). I have the gages and supplies to build 3 more. >>> >>> Mike Welch >>> >>> Sent from my iPad >>> >>> On Jan 16, 2016, at 10:18 AM, B Young wrote: >>> >>>> Moving An arm past a bunch of solder blobs sounds like a bunch of >>>> drag and sticking. >>>> Let the wind vain turn a pot. (Potentiometer) It seems in the RC >>>> world there are progressive led lights that respond to changing >>>> voltage. Run 12 v and ground to the sides of the pot. And the >>>> center will vary from 0 to 12 volts when the pot is turned. You >>>> could limit the travel of the wind vain to limit the possible >>>> output voltages, or put resistors in series with the 12 v and or >>>> ground terminals of the pot. This would keep the center outlet of >>>> the pot voltages within limits of the led light bar voltage indicator. >>>> The total resistance value of the pot would be determined in part >>>> by the max or min current requirements of the led voltage >>>> indicator. IE: a 5 k ohm or a 10, 15, 50 k ohm pot. The greater >>>> ohm value of the pot and still be able to drive the led volt >>>> indicator will consume the least amount of power. >>>> >>>> Boyd young >>>> >> >> -- >> Signature text; Add catchy phrase here.. -- Signature text; Add catchy phrase here.. ________________________________________________________________________________
Subject: AOA
Date: Jan 16, 2016
Run one wire to the arm. make a "board" with > 4 or five wires sticking through the board with a solder lump I haven't thought this through.. but simply to enlarge on your idea, try a TPS. Throttle Position Sensor. They come in all shapes and sizes. Basically a rheostat. ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 16, 2016
If you used a pot, or the TPS you could drive the light-bar and/or a sound generator. It could be fancy or simple. You could use a 555 timer, the pot input could change the tone frequency. It isn't a sound chip but the output pulses can drive an earphone or amp or whatever. You can tailor the duty-cycle, the frequency of pulses, etc. there are interactive software tools available free that will tell you what values of caps, resistors and pots to use. And how to wire it. Is really simple. -------- GeoB "Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452044#452044 ________________________________________________________________________________
Subject: aoa
Date: Jan 16, 2016
Mike, How well do your AOA/LRI indicator work? I have never flown an aircraft equipped with either instrument. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Mike Sent: Saturday, January 16, 2016 11:30 AM Subject: Re: Kolb-List: aoa >From the depth of lurking mode, I am inspired to comment. Boyd, The "moving arm" doesn't touch any solder blobs. The device use a magnet flush mounted on the torpedo, and the circuitry detects the magnetism (without actually touching anything). It's known as the Hall Effect. If I'm correct, I rounded all of the electronic parts up about 4 years ago to build a few of these AOA indicators. Regarding the small IC circuit with the 10 segment red/yellow/green LEDs, I have two of them, but on my AOA system I decided I wanted the visual impact MUCH more noticeable, so I built my own individual "10 red/yellow/green LEDs" using 5mm LEDs. Bigger, longer, etc, etc. (I get my AOA function from my Dynon D10A, which has an audio alarm that I have wired into my intercom, thus I have bright LEDs and audio notification for an impending stall.) Although an AOA indicator is very useful, a lift reserve indicator(LRI) is more useful, and much less, okay some less, to build. The LRI uses air pressure differential to determine when a wing is no longer flying. The LRI is always accurate because it measures the point at which the still begins, and factors such as weight, wing incidence, whatever, have no effect on it's accuracy. I have already built one (a copy of a store bought unit, which I also have).). I have the gages and supplies to build 3 more. Mike Welch Sent from my iPad On Jan 16, 2016, at 10:18 AM, B Young wrote: Moving An arm past a bunch of solder blobs sounds like a bunch of drag and sticking. Let the wind vain turn a pot. (Potentiometer) It seems in the RC world there are progressive led lights that respond to changing voltage. Run 12 v and ground to the sides of the pot. And the center will vary from 0 to 12 volts when the pot is turned. You could limit the travel of the wind vain to limit the possible output voltages, or put resistors in series with the 12 v and or ground terminals of the pot. This would keep the center outlet of the pot voltages within limits of the led light bar voltage indicator. The total resistance value of the pot would be determined in part by the max or min current requirements of the led voltage indicator. IE: a 5 k ohm or a 10, 15, 50 k ohm pot. The greater ohm value of the pot and still be able to drive the led volt indicator will consume the least amount of power. Boyd young ________________________________________________________________________________
Date: Jan 16, 2016
Subject: Aoa
I could imagine a group of Reed switches laid side to side with a 50 percent offset. One set on either side of the magnet. Pending on the physical sizes of the switches would determine the accuracy / resolution of the devise. .. A pots accuracy may depend on the size of the wire , and the tolerance in the led light bar. A 10 segment led bar set at 1 volt per segment, or a 10 segment bar at a quarter volt per segment. Big difference. Boyd ________________________________________________________________________________
Date: Jan 17, 2016
Subject: Making videos
When I finally saved up enough to replace my POS Dell laptop I bought an Acer with Windows 10 already installed and was delighted to find that Movie Maker is back. I've made camera mounts for my trike and for Christmas I went looking through Amazon for the latest offerings in action cams. It's amazing what's out there but, as always, money is tight when it comes to toys. I found some good reviews for a GoPro clone marketed by Peyou US Ltd. http://smile.amazon.com/gp/product/B00X5LM4NW?keywords=sj4000%20camera&qi d=1453065702&ref_=sr_ph&sr=1 I'm having an issue that I can't decide is a camera or a mount issue. I've put two short clips on You Tube so the engineer I'm working with can see what is very hard to describe. In the first: https://youtu.be/wQQQHRxujO8 you can see the problem. If I decide to make a video called "Kanandreas, Richter 11.0" I've got the special effects nailed. But when I throttle back for landing everything smooths out: https://youtu.be/t2z0roXMUBI So, there's certainly fuel for hope that it can be ironed out. On my end I'm going to isolate the camera on a block of Sorbothane and add a lead weight as an inertial damper. The best part is that these little action cams are $54 on Amazon. Add two 32 gigabyte micro SD cards and the tab comes to a little over $80. Disclaimer, I neither own stock nor am I in any way connected to Peyou US Ltd. I just bought a couple of their cameras. I know everyone enjoys Larry C's videos so I thought I'd pass along what I've found in my latest delve into videos. Rick Girard PS I tried them out for stills, too. It has a bit of a fisheye look (the camera is claimed to have a 170 degree field of view) but it's better than most phones can do. -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Jan 17, 2016
Subject: Re: Making videos
you can see the problem. If I decide to make a video called "Kanandreas, Richter 11.0" I've got the special effects nailed. But when I throttle back for landing everything smooths out: ====== For me padding did not solve the harmonics problem. The best that I found was off the nose pod as solid as I could make it. You still get a bit during throttle down, but better every where else. I also found that mine settled down at different speeds, best was the high end of the throttle range. Your best bet is to find the spot on the plane where the vibration is the least. Good luck Larry On Sun, Jan 17, 2016 at 2:28 PM, Richard Girard wrote : > When I finally saved up enough to replace my POS Dell laptop I bought an > Acer with Windows 10 already installed and was delighted to find that Mov ie > Maker is back. I've made camera mounts for my trike and for Christmas I > went looking through Amazon for the latest offerings in action cams. It's > amazing what's out there but, as always, money is tight when it comes to > toys. I found some good reviews for a GoPro clone marketed by Peyou US Lt d. > > > http://smile.amazon.com/gp/product/B00X5LM4NW?keywords=sj4000%20camera& qid=1453065702&ref_=sr_ph&sr=1 > > I'm having an issue that I can't decide is a camera or a mount issue. I'v e > put two short clips on You Tube so the engineer I'm working with can see > what is very hard to describe. In the first: > > https://youtu.be/wQQQHRxujO8 > > you can see the problem. If I decide to make a video called "Kanandreas, > Richter 11.0" I've got the special effects nailed. > But when I throttle back for landing everything smooths out: > > https://youtu.be/t2z0roXMUBI > > So, there's certainly fuel for hope that it can be ironed out. On my end > I'm going to isolate the camera on a block of Sorbothane and add a lead > weight as an inertial damper. > The best part is that these little action cams are $54 on Amazon. Add two > 32 gigabyte micro SD cards and the tab comes to a little over $80. > Disclaimer, I neither own stock nor am I in any way connected to Peyou US > Ltd. I just bought a couple of their cameras. > I know everyone enjoys Larry C's videos so I thought I'd pass along what > I've found in my latest delve into videos. > > Rick Girard > > PS I tried them out for stills, too. It has a bit of a fisheye look (the > camera is claimed to have a 170 degree field of view) but it's better tha n > most phones can do. > -- > =9CBlessed are the cracked, for they shall let in the light. =9D Groucho Marx > <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > -- *The older I get, the less tolerant I am of those who are intolerant.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jan 18, 2016
Subject: tires
Our bitter weather has moved Eastward, so I got the tires fixed today. I put some washers under these screws just as a precaution in case the screw might be a bit long. I have 6 lbs of air in them. I anticipate that they will be a bit better when landing in our outback, as well as not ripping off the valve stems. Larry -- *The older I get, the less tolerant I am of those who are intolerant.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: tires
Date: Jan 18, 2016
That looks good. I don't think you have a slippage problem now, unless you try really hard. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Monday, January 18, 2016 1:49 PM Subject: Kolb-List: tires Our bitter weather has moved Eastward, so I got the tires fixed today. I put some washers under these screws just as a precaution in case the screw might be a bit long. I have 6 lbs of air in them. I anticipate that they will be a bit better when landing in our outback, as well as not ripping off the valve stems. Larry -- The older I get, the less tolerant I am of those who are intolerant. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jan 18, 2016
Subject: Re: tires
How much air do you think I should have. I now have 6 pounds in them and they don't appear to be too low. Perhaps I should put my fat ass in there to see how much they squat? Larry On Mon, Jan 18, 2016 at 2:47 PM, John Hauck wrote: > That looks good. I don't think you have a slippage problem now, unless > you try really hard. > > > john h > > mkIII > > Titus, Alabama > > > *From:* owner-kolb-list-server(at)matronics.com [mailto: > owner-kolb-list-server(at)matronics.com] *On Behalf Of *Larry Cottrell > *Sent:* Monday, January 18, 2016 1:49 PM > *To:* kolb-list(at)matronics.com > *Subject:* Kolb-List: tires > > > Our bitter weather has moved Eastward, so I got the tires fixed today. I > put some washers under these screws just as a precaution in case the screw > might be a bit long. I have 6 lbs of air in them. I anticipate that they > will be a bit better when landing in our outback, as well as not ripping > off the valve stems. > > Larry > > > -- > > *The older I get, the less tolerant I am of those who are intolerant.* > > > *If you forward this email, or any part of it, please remove my email > address before sending.* > -- *The older I get, the less tolerant I am of those who are intolerant.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jan 18, 2016
Subject: Re: tires
Larry, When I put the Nerf tires on the Mk III I ran 6 to 8 lb. Seems like you're in the ballpark. Rick On Mon, Jan 18, 2016 at 5:14 PM, Larry Cottrell wrote: > How much air do you think I should have. I now have 6 pounds in them and > they don't appear to be too low. Perhaps I should put my fat ass in there > to see how much they squat? > Larry > > On Mon, Jan 18, 2016 at 2:47 PM, John Hauck wrote: > >> That looks good. I don't think you have a slippage problem now, unless >> you try really hard. >> >> >> >> john h >> >> mkIII >> >> Titus, Alabama >> >> >> >> >> >> >> >> >> >> *From:* owner-kolb-list-server(at)matronics.com [mailto: >> owner-kolb-list-server(at)matronics.com] *On Behalf Of *Larry Cottrell >> *Sent:* Monday, January 18, 2016 1:49 PM >> *To:* kolb-list(at)matronics.com >> *Subject:* Kolb-List: tires >> >> >> >> Our bitter weather has moved Eastward, so I got the tires fixed today. I >> put some washers under these screws just as a precaution in case the scr ew >> might be a bit long. I have 6 lbs of air in them. I anticipate that they >> will be a bit better when landing in our outback, as well as not ripping >> off the valve stems. >> >> Larry >> >> >> >> -- >> >> *The older I get, the less tolerant I am of those who are intolerant.* >> >> >> >> *If you forward this email, or any part of it, please remove my email >> address before sending.* >> > > > -- > *The older I get, the less tolerant I am of those who are intolerant.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Subject: tires
Date: Jan 18, 2016
I run 6-8 psi when I am doing "real" flying. 10-15 psi when I will be flying in and out of paved strips. Higher psi works much better on dry pavement for me. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Monday, January 18, 2016 5:15 PM Subject: Re: Kolb-List: tires How much air do you think I should have. I now have 6 pounds in them and they don't appear to be too low. Perhaps I should put my fat ass in there to see how much they squat? Larry On Mon, Jan 18, 2016 at 2:47 PM, John Hauck wrote: That looks good. I don't think you have a slippage problem now, unless you try really hard. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Monday, January 18, 2016 1:49 PM Subject: Kolb-List: tires Our bitter weather has moved Eastward, so I got the tires fixed today. I put some washers under these screws just as a precaution in case the screw might be a bit long. I have 6 lbs of air in them. I anticipate that they will be a bit better when landing in our outback, as well as not ripping off the valve stems. Larry -- The older I get, the less tolerant I am of those who are intolerant. If you forward this email, or any part of it, please remove my email address before sending. -- The older I get, the less tolerant I am of those who are intolerant. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jan 19, 2016
Subject: Re: tires
I read somewhere that airplane tires should compress so that the edge of the tread touches the ground when loaded. This relates to airplane tires that have the distinctive simple circumferential treads. Hope this helps Pierre ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 19, 2016
Repairing the wiring harness from the mags turned out to be really easy, ought to have the engine back on the airplane fairly soon, so I bit the bullet and ordered the three items linked here on ebay. If/when I come up with something worth looking at, I'll post it on the list. If it turns out to be useless, or a waste of time, I'll post that too. Richard Pike wrote: > Why could you not make an AOA indicator using a fuel gauge assembly? The sender typically uses an arm that changes angle and sends a signal; instead of the wire and float, make a counterbalanced vane that would move in the airflow. Mount the gauge on its side, and now you have a needle that goes up and down at different vane angles. Ideally you take the gauge cover off and instead of empty and full, you paint on angles of attack up to stall. > You could try something like this first: > http://www.ebay.com/itm/Universal-52mm-2-Car-Fuel-Level-Gauge-Meter-With-Fuel-Sensor-E-1-2-F-Pointer-/401028163857?hash=item5d5f242911:g:sHEAAOSweuxWSo-T&vxp=mtr > Looking at the sender unit in this set, if you cut off everything you didn't need, the sender itself would be about 2" across, plus however big your vane is. > > Once you got that to work, but say you wanted a lighted gauge instead, one that went up and down, you could try something like this: > http://www.ebay.com/itm/Universal-Motor-Motorcycle-2-Fuel-Meter-Digital-Display-Fuel-Ratio-Level-Gauge-/201502529749?hash=item2eea7c98d5:g:nr0AAOSwYIhWlint&vxp=mtr > Now you have led's that go up and down as your AOA changed. And if you repainted the face and mounted it upside down, you have yellow and red at the top. > > Then stick the gauge in a little holder that sits on top of your panel so it is in your immediate vision while you are on final: > http://www.ebay.com/itm/52Mm-2-Adjustable-Swivel-Dash-Mount-Single-Racing-Gauge-Cup-Holder-Pod-Bracket-/172060327859?hash=item280f983fb3:g:F8IAAOSwGotWlXS6&vxp=mtr > > Seems to me a fairly simple exercise in making your vane assembly light and responsive, finding the best airflow location, and doing some calibrating. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452113#452113 ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 20, 2016
When climbing, in the pattern or on final I always keep an eye on the airspeed. An AOA gage would just be another item to keep an eye on; unless it has an audio warning. Then it would be very valuable. Without an audio warning I don't see the point. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452131#452131 ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 20, 2016
On 1/20/2016 9:48 AM, Rex Rodebush wrote: > > When climbing, in the pattern or on final I always keep an eye on the airspeed. An AOA gage would just be another item to keep an eye on; unless it has an audio warning. Then it would be very valuable. Without an audio warning I don't see the point. > This might not be totally applicable to Kolbs due to their (relatively) narrow speed range, but in the wider aviation world, you'd ignore airspeed & monitor AOA. Reason is that 1G stall speed can change quite a bit with gross weight, but angle of attack does not. Same applies to optimum best angle and best rate in climb. With the right kind of audio feedback, you wouldn't need to look in the cockpit at all. You could devote all your attention to traffic, etc. The toughest approach for landing is likely an aircraft carrier; Navy & Marine a/c use AOA for approaches. Charlie ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 20, 2016
There are 5/12 volt buzzers out there.. EBAY....and one could tap off of the the output to the first red led in the schematic , whose link I posted.. Herb On 01/20/2016 10:50 AM, Charlie England wrote: > > On 1/20/2016 9:48 AM, Rex Rodebush wrote: >> >> When climbing, in the pattern or on final I always keep an eye on the >> airspeed. An AOA gage would just be another item to keep an eye on; >> unless it has an audio warning. Then it would be very valuable. >> Without an audio warning I don't see the point. >> > This might not be totally applicable to Kolbs due to their > (relatively) narrow speed range, but in the wider aviation world, > you'd ignore airspeed & monitor AOA. Reason is that 1G stall speed can > change quite a bit with gross weight, but angle of attack does not. > Same applies to optimum best angle and best rate in climb. > > With the right kind of audio feedback, you wouldn't need to look in > the cockpit at all. You could devote all your attention to traffic, etc. > > The toughest approach for landing is likely an aircraft carrier; Navy > & Marine a/c use AOA for approaches. > > Charlie > > -- Signature text; Im reminded of the Words of Martin Niemoller: "First they came for the Socialists, and I did not speak out Because I was not a Socialist. Then they came for the Trade Unionists, and I did not speak out Because I was not a Trade Unionist. Then they came for the Jews, and I did not speak out Because I was not a Jew. Then they came for meand there was no one left to speak for me." ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 20, 2016
On 1/20/2016 11:07 AM, Herb wrote: > > There are 5/12 volt buzzers out there.. EBAY....and one could tap off > of the the output to the first red led in the schematic , whose link I > posted.. Herb > > On 01/20/2016 10:50 AM, Charlie England wrote: >> >> On 1/20/2016 9:48 AM, Rex Rodebush wrote: >>> >>> When climbing, in the pattern or on final I always keep an eye on >>> the airspeed. An AOA gage would just be another item to keep an eye >>> on; unless it has an audio warning. Then it would be very >>> valuable. Without an audio warning I don't see the point. >>> >> This might not be totally applicable to Kolbs due to their >> (relatively) narrow speed range, but in the wider aviation world, >> you'd ignore airspeed & monitor AOA. Reason is that 1G stall speed >> can change quite a bit with gross weight, but angle of attack does >> not. Same applies to optimum best angle and best rate in climb. >> >> With the right kind of audio feedback, you wouldn't need to look in >> the cockpit at all. You could devote all your attention to traffic, etc. >> >> The toughest approach for landing is likely an aircraft carrier; Navy >> & Marine a/c use AOA for approaches. >> >> Charlie >> >> >> >> > Herb, That could work (as long as you don't expect the LED current to drive a buzzer), but you'd basically have just a stall warning horn. Might as well just have a tabbed switch, like a Cessna. With a proper voltage controlled oscillator, you can have a varying pitch tone (even configured to beep at different speeds and intensity) so that with practice, you can actually *hear* best angle, best climb, approach, impending stall, etc, all tied to AOA meaning it would work at any loading of the plane. Those who are really interested might want to spend some time with Google & read up on what AOA can do, and how it works. Charlie ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 20, 2016
The current driving the led would not , by itself, operate the buzzer....would require a Transistor..resistor or two..Herb On 01/20/2016 11:34 AM, Charlie England wrote: > > On 1/20/2016 11:07 AM, Herb wrote: >> >> There are 5/12 volt buzzers out there.. EBAY....and one could tap >> off of the the output to the first red led in the schematic , whose >> link I posted.. Herb >> >> On 01/20/2016 10:50 AM, Charlie England wrote: >>> >>> On 1/20/2016 9:48 AM, Rex Rodebush wrote: >>>> >>>> When climbing, in the pattern or on final I always keep an eye on >>>> the airspeed. An AOA gage would just be another item to keep an >>>> eye on; unless it has an audio warning. Then it would be very >>>> valuable. Without an audio warning I don't see the point. >>>> >>> This might not be totally applicable to Kolbs due to their >>> (relatively) narrow speed range, but in the wider aviation world, >>> you'd ignore airspeed & monitor AOA. Reason is that 1G stall speed >>> can change quite a bit with gross weight, but angle of attack does >>> not. Same applies to optimum best angle and best rate in climb. >>> >>> With the right kind of audio feedback, you wouldn't need to look in >>> the cockpit at all. You could devote all your attention to traffic, >>> etc. >>> >>> The toughest approach for landing is likely an aircraft carrier; >>> Navy & Marine a/c use AOA for approaches. >>> >>> Charlie >>> >>> >>> >>> >> > Herb, > > That could work (as long as you don't expect the LED current to drive > a buzzer), but you'd basically have just a stall warning horn. Might > as well just have a tabbed switch, like a Cessna. > > With a proper voltage controlled oscillator, you can have a varying > pitch tone (even configured to beep at different speeds and intensity) > so that with practice, you can actually *hear* best angle, best climb, > approach, impending stall, etc, all tied to AOA meaning it would work > at any loading of the plane. > > Those who are really interested might want to spend some time with > Google & read up on what AOA can do, and how it works. > > Charlie > > -- Signature text; Im reminded of the Words of Martin Niemoller: "First they came for the Socialists, and I did not speak out Because I was not a Socialist. Then they came for the Trade Unionists, and I did not speak out Because I was not a Trade Unionist. Then they came for the Jews, and I did not speak out Because I was not a Jew. Then they came for meand there was no one left to speak for me." ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 20, 2016
How would one compute the speed range of my mkIII and a Cessna 172? and compare the results? Never flown with an AOA. I think it would be interesting to play with to learn what it does and how it would improve me and my MKIII's flying. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Wednesday, January 20, 2016 10:51 AM Subject: Re: Kolb-List: Re: AOA On 1/20/2016 9:48 AM, Rex Rodebush wrote: > > When climbing, in the pattern or on final I always keep an eye on the airspeed. An AOA gage would just be another item to keep an eye on; unless it has an audio warning. Then it would be very valuable. Without an audio warning I don't see the point. > This might not be totally applicable to Kolbs due to their (relatively) narrow speed range, but in the wider aviation world, you'd ignore airspeed & monitor AOA. Reason is that 1G stall speed can change quite a bit with gross weight, but angle of attack does not. Same applies to optimum best angle and best rate in climb. With the right kind of audio feedback, you wouldn't need to look in the cockpit at all. You could devote all your attention to traffic, etc. The toughest approach for landing is likely an aircraft carrier; Navy & Marine a/c use AOA for approaches. Charlie ________________________________________________________________________________
Subject: Fw: America's new toy!!
Date: Jan 21, 2016
All you pilots worrying about taking pics of your flights, vibration and stuff. Get a load of this. Pat .nz Subject: Fw: Fwd: FW: America's new toy!! OMG!!! what ever next! want for Xmas is Lily!!!! America 's new toy. A much more advanced Drone!!! Throw and Shoot Camera. 20 minutes of overhead tracking photography. Just throw it into the air. They are selling at $495 to $699. Amazing what there is on the horizon. Golfers, you can just throw this camera into the air before you tee-off, and it will record ALL of your great shots. This technology is bordering on science fiction. It will revolutionize the movie and TV industry and with this equipment, home videos will be more fun to watch. Lily is the world's first throw-and-shoot camera. It lets anyone create cinematic footage previously reserved for professional filmmakers. Lily is waterproof, ultra-portable, and shoots stunning HD pictures and videos. Click: https://www.youtube.com/embed/4vGcH0Bk3hg?rel=0 ------------------------------------------------------------------------- - . ________________________________________________________________________________
Subject: Re: Fw: America's new toy!!
Date: Jan 21, 2016
I bought one of the 9 dof circuit boards...about the size of a quarter , that contains the 3 axis gyro, 3 axis magnetometer and 3 axis Accelerometer as well as a barometer .... Similar to the device that would be in this gilded Lilly... Thinking that I would have some fun with the 7 dollar device.... I sat down to learn the C language so I could program some of the equally small processor boards that I bought... dozed off ,,,end of story...:-) Herb On 01/21/2016 05:02 AM, Patrick Ladd wrote: > All you pilots worrying about taking pics of your flights, vibration > and stuff. Get a load of this. Pat > .nz > *Subject:* Fw: Fwd: FW: America's new toy!! > > > OMG!!! what ever next! > > want for Xmas is Lily!!!! > America 's new toy. A much more advanced Drone!!! > Throw and Shoot Camera. > 20 minutes of overhead tracking photography. > Just throw it into the air. They are selling at > $495 to $699. Amazing what there is on the horizon. > Golfers, you can just throw this camera into the air > before you tee-off, and it will record ALL of your > great shots. > This technology is bordering on science fiction. It > will revolutionize the movie and TV industry and > with this equipment, home videos will be more fun to watch. > Lily is the world's first throw-and-shoot camera. It > lets anyone create cinematic footage previously > reserved for professional filmmakers. > Lily is waterproof, ultra-portable, and shoots > stunning HD pictures and videos. > Click: https://www.youtube.com/embed/4vGcH0Bk3hg?rel=0 > > > ------------------------------------------------------------------------ > > > > . > > > > -- Signature text; Im reminded of the Words of Martin Niemoller: "First they came for the Socialists, and I did not speak out Because I was not a Socialist. Then they came for the Trade Unionists, and I did not speak out Because I was not a Trade Unionist. Then they came for the Jews, and I did not speak out Because I was not a Jew. Then they came for meand there was no one left to speak for me." ________________________________________________________________________________
Date: Jan 21, 2016
yeah, i could see that might slow you down. Just imagine having this thing fly a circuit round filming you while you are flying, follow you into a .tight landing spot. Maybe even fly back to you in the cockpit Like calling a hawk back to your wrist. Wow! Bet the FAA would have conniptions. Pat From: Herb Sent: Thursday, January 21, 2016 2:21 PM Subject: Re: Kolb-List: Fw: America's new toy!! I bought one of the 9 dof circuit boards...about the size of a quarter , that contains the 3 axis gyro, 3 axis magnetometer and 3 axis Accelerometer as well as a barometer .... Similar to the device that would be in this gilded Lilly... Thinking that I would have some fun with the 7 dollar device.... I sat down to learn the C language so I could program some of the equally small processor boards that I bought... dozed off ,,,end of story...:-) Herb On 01/21/2016 05:02 AM, Patrick Ladd wrote: All you pilots worrying about taking pics of your flights, vibration and stuff. Get a load of this. Pat .nz Subject: Fw: Fwd: FW: America's new toy!! OMG!!! what ever next! want for Xmas is Lily!!!! America 's new toy. A much more advanced Drone!!! Throw and Shoot Camera. 20 minutes of overhead tracking photography. Just throw it into the air. They are selling at $495 to $699. Amazing what there is on the horizon. Golfers, you can just throw this camera into the air before you tee-off, and it will record ALL of your great shots. This technology is bordering on science fiction. It will revolutionize the movie and TV industry and with this equipment, home videos will be more fun to watch. Lily is the world's first throw-and-shoot camera. It lets anyone create cinematic footage previously reserved for professional filmmakers. Lily is waterproof, ultra-portable, and shoots stunning HD pictures and videos. Click: https://www.youtube.com/embed/4vGcH0Bk3hg?rel=0 ------------------------------------------------------------------------ . -- Signature text; Im reminded of the Words of Martin Niemoller: "First they came for the Socialists, and I did not speak out=94 Because I was not a Socialist. Then they came for the Trade Unionists, and I did not speak out=94 Because I was not a Trade Unionist. Then they came for the Jews, and I did not speak out=94 Because I was not a Jew. Then they came for me=94and there was no one left to speak for me." ________________________________________________________________________________
Date: Jan 21, 2016
My idea, since I have never really grown up :-) , was to try an auto pilot trim system on my Firefly....on very calm days that is.... since I doze off each time I try to learn something new at age 72, guess it is on the back burner!! Herb On 01/21/2016 09:13 AM, Patrick Ladd wrote: > yeah, i could see that might slow you down. Just imagine having this > thing fly a circuit round filming you while you are flying, follow you > into a .tight landing spot. Maybe even fly back to you in the cockpit > Like calling a hawk back to your wrist. Wow! Bet the FAA would have > conniptions. > Pat > *From:* Herb > *Sent:* Thursday, January 21, 2016 2:21 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: Fw: America's new toy!! > I bought one of the 9 dof circuit boards...about the size of a > quarter , that contains the 3 axis gyro, 3 axis magnetometer and 3 > axis Accelerometer as well as a barometer .... Similar to the device > that would be in this gilded Lilly... > > Thinking that I would have some fun with the 7 dollar device.... I sat > down to learn the C language so I could program some of the equally > small processor boards that I bought... dozed off ,,,end of > story...:-) Herb > > On 01/21/2016 05:02 AM, Patrick Ladd wrote: >> All you pilots worrying about taking pics of your flights, vibration >> and stuff. Get a load of this. Pat >> .nz >> *Subject:* Fw: Fwd: FW: America's new toy!! >> >> >> OMG!!! what ever next! >> >> want for Xmas is Lily!!!! >> America 's new toy. A much more advanced Drone!!! >> Throw and Shoot Camera. >> 20 minutes of overhead tracking photography. >> Just throw it into the air. They are selling at >> $495 to $699. Amazing what there is on the horizon. >> Golfers, you can just throw this camera into the air >> before you tee-off, and it will record ALL of your >> great shots. >> This technology is bordering on science fiction. It >> will revolutionize the movie and TV industry and >> with this equipment, home videos will be more fun to watch. >> Lily is the world's first throw-and-shoot camera. It >> lets anyone create cinematic footage previously >> reserved for professional filmmakers. >> Lily is waterproof, ultra-portable, and shoots >> stunning HD pictures and videos. >> Click: https://www.youtube.com/embed/4vGcH0Bk3hg?rel=0 >> >> >> >> >> >> ------------------------------------------------------------------------ >> >> >> >> . >> >> >> >> >> > > -- > Signature text; Im reminded of the Words of Martin Niemoller: > > "First they came for the Socialists, and I did not speak out > Because I was not a Socialist. > > Then they came for the Trade Unionists, and I did not speak out > Because I was not a Trade Unionist. > > Then they came for the Jews, and I did not speak out > Because I was not a Jew. > > Then they came for meand there was no one left to speak for me." > > -- Signature text; Im reminded of the Words of Martin Niemoller: "First they came for the Socialists, and I did not speak out Because I was not a Socialist. Then they came for the Trade Unionists, and I did not speak out Because I was not a Trade Unionist. Then they came for the Jews, and I did not speak out Because I was not a Jew. Then they came for meand there was no one left to speak for me." ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 21, 2016
I've got maybe 5 hrs in a 172, & none in a Kolb, so maybe you can help. My RV-4 stalls in the low 50's (mph) and best rate of climb is actually a rather wide range instead of a single number; from around 110 mph up to around 130 mph, due to the fixed pitch prop & the low aspect ratio 'hershey bar' wing. (Drag goes up rather quickly as the plane slows down due to induced drag, & the highly pitched cruise prop loses efficiency at lower airspeeds and limits engine power at lower rpm so best rate is almost the same from 110 to 130.) Best angle of climb is around 85 mph. Point is, the actual mph spread between best rate & stall is around 55 mph. The spread between best angle and stall is around 30 mph. What are the spreads for your Kolb? If the actual mph spreads are closer (percentages might be the same, or even better; I don't know), then an accurate AOA might be *more* useful in a Kolb than something like an RV, with large speed spreads. Charlie On 1/20/2016 3:48 PM, John Hauck wrote: > > How would one compute the speed range of my mkIII and a Cessna 172? and > compare the results? > > Never flown with an AOA. I think it would be interesting to play with to > learn what it does and how it would improve me and my MKIII's flying. > > john h > mkIII > Titus, Alabama > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England > Sent: Wednesday, January 20, 2016 10:51 AM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: AOA > > > On 1/20/2016 9:48 AM, Rex Rodebush wrote: >> >> When climbing, in the pattern or on final I always keep an eye on the > airspeed. An AOA gage would just be another item to keep an eye on; unless > it has an audio warning. Then it would be very valuable. Without an audio > warning I don't see the point. > This might not be totally applicable to Kolbs due to their (relatively) > narrow speed range, but in the wider aviation world, you'd ignore airspeed & > monitor AOA. Reason is that 1G stall speed can change quite a bit with gross > weight, but angle of attack does not. Same applies to optimum best angle and > best rate in climb. > > With the right kind of audio feedback, you wouldn't need to look in the > cockpit at all. You could devote all your attention to traffic, etc. > > The toughest approach for landing is likely an aircraft carrier; Navy & > Marine a/c use AOA for approaches. > > Charlie > ________________________________________________________________________________
Date: Jan 21, 2016
Here you go, Herb. All you have to do is stay awake long enough to install it. http://www.trutrakap.com/product/eco/ On 1/21/2016 10:00 AM, Herb wrote: > My idea, since I have never really grown up :-) , was to try an auto > pilot trim system on my Firefly....on very calm days that is.... since > I doze off each time I try to learn something new at age 72, guess it > is on the back burner!! Herb > > On 01/21/2016 09:13 AM, Patrick Ladd wrote: >> yeah, i could see that might slow you down. Just imagine having this >> thing fly a circuit round filming you while you are flying, follow >> you into a .tight landing spot. Maybe even fly back to you in the >> cockpit Like calling a hawk back to your wrist. Wow! Bet the FAA >> would have conniptions. >> Pat >> *From:* Herb >> *Sent:* Thursday, January 21, 2016 2:21 PM >> *To:* kolb-list(at)matronics.com >> *Subject:* Re: Kolb-List: Fw: America's new toy!! >> I bought one of the 9 dof circuit boards...about the size of a >> quarter , that contains the 3 axis gyro, 3 axis magnetometer and 3 >> axis Accelerometer as well as a barometer .... Similar to the device >> that would be in this gilded Lilly... >> >> Thinking that I would have some fun with the 7 dollar device.... I >> sat down to learn the C language so I could program some of the >> equally small processor boards that I bought... dozed off ,,,end of >> story...:-) Herb >> >> On 01/21/2016 05:02 AM, Patrick Ladd wrote: >>> All you pilots worrying about taking pics of your flights, vibration >>> and stuff. Get a load of this. Pat >>> .nz >>> *Subject:* Fw: Fwd: FW: America's new toy!! >>> >>> >>> OMG!!! what ever next! >>> >>> want for Xmas is Lily!!!! >>> America 's new toy. A much more advanced Drone!!! >>> Throw and Shoot Camera. >>> 20 minutes of overhead tracking photography. >>> Just throw it into the air. They are selling at >>> $495 to $699. Amazing what there is on the horizon. >>> Golfers, you can just throw this camera into the air >>> before you tee-off, and it will record ALL of your >>> great shots. >>> This technology is bordering on science fiction. It >>> will revolutionize the movie and TV industry and >>> with this equipment, home videos will be more fun to watch. >>> Lily is the world's first throw-and-shoot camera. It >>> lets anyone create cinematic footage previously >>> reserved for professional filmmakers. >>> Lily is waterproof, ultra-portable, and shoots >>> stunning HD pictures and videos. >>> Click: https://www.youtube.com/embed/4vGcH0Bk3hg?rel=0 >>> >>> >>> >>> >>> >>> ------------------------------------------------------------------------ >>> >>> >>> >>> . >>> >>> >>> >>> >>> >> >> -- >> Signature text; Im reminded of the Words of Martin Niemoller: >> >> "First they came for the Socialists, and I did not speak out >> Because I was not a Socialist. >> >> Then they came for the Trade Unionists, and I did not speak out >> Because I was not a Trade Unionist. >> >> Then they came for the Jews, and I did not speak out >> Because I was not a Jew. >> >> Then they came for meand there was no one left to speak for me." >> >> > > -- > Signature text; Im reminded of the Words of Martin Niemoller: > > "First they came for the Socialists, and I did not speak out > Because I was not a Socialist. > > Then they came for the Trade Unionists, and I did not speak out > Because I was not a Trade Unionist. > > Then they came for the Jews, and I did not speak out > Because I was not a Jew. > > Then they came for meand there was no one left to speak for me." > > ________________________________________________________________________________
Date: Jan 21, 2016
That sort of fits in with my thesis..which is...."amazing what can be done with 50 bucks worth of electronics...and a smidge of programming....". :-) Its all in the software... which I avoided like the plague when in the Computer business...in the 60's thru 80's.. $999 !! Herb ps They or someone else has a demo on You tube.. On 01/21/2016 10:47 AM, Charlie England wrote: > Here you go, Herb. All you have to do is stay awake long enough to > install it. > http://www.trutrakap.com/product/eco/ > > > On 1/21/2016 10:00 AM, Herb wrote: >> My idea, since I have never really grown up :-) , was to try an auto >> pilot trim system on my Firefly....on very calm days that is.... >> since I doze off each time I try to learn something new at age 72, >> guess it is on the back burner!! Herb >> >> On 01/21/2016 09:13 AM, Patrick Ladd wrote: >>> yeah, i could see that might slow you down. Just imagine having this >>> thing fly a circuit round filming you while you are flying, follow >>> you into a .tight landing spot. Maybe even fly back to you in the >>> cockpit Like calling a hawk back to your wrist. Wow! Bet the FAA >>> would have conniptions. >>> Pat >>> *From:* Herb >>> *Sent:* Thursday, January 21, 2016 2:21 PM >>> *To:* kolb-list(at)matronics.com >>> *Subject:* Re: Kolb-List: Fw: America's new toy!! >>> I bought one of the 9 dof circuit boards...about the size of a >>> quarter , that contains the 3 axis gyro, 3 axis magnetometer and 3 >>> axis Accelerometer as well as a barometer .... Similar to the >>> device that would be in this gilded Lilly... >>> >>> Thinking that I would have some fun with the 7 dollar device.... I >>> sat down to learn the C language so I could program some of the >>> equally small processor boards that I bought... dozed off ,,,end >>> of story...:-) Herb >>> >>> On 01/21/2016 05:02 AM, Patrick Ladd wrote: >>>> All you pilots worrying about taking pics of your flights, >>>> vibration and stuff. Get a load of this. Pat >>>> .nz >>>> *Subject:* Fw: Fwd: FW: America's new toy!! >>>> >>>> >>>> OMG!!! what ever next! >>>> >>>> want for Xmas is Lily!!!! >>>> America 's new toy. A much more advanced Drone!!! >>>> Throw and Shoot Camera. >>>> 20 minutes of overhead tracking photography. >>>> Just throw it into the air. They are selling at >>>> $495 to $699. Amazing what there is on the horizon. >>>> Golfers, you can just throw this camera into the air >>>> before you tee-off, and it will record ALL of your >>>> great shots. >>>> This technology is bordering on science fiction. It >>>> will revolutionize the movie and TV industry and >>>> with this equipment, home videos will be more fun to watch. >>>> Lily is the world's first throw-and-shoot camera. It >>>> lets anyone create cinematic footage previously >>>> reserved for professional filmmakers. >>>> Lily is waterproof, ultra-portable, and shoots >>>> stunning HD pictures and videos. >>>> Click: https://www.youtube.com/embed/4vGcH0Bk3hg?rel=0 >>>> >>>> >>>> >>>> >>>> >>>> ------------------------------------------------------------------------ >>>> >>>> >>>> >>>> . >>>> >>>> >>>> >>>> >>>> >>> >>> -- >>> Signature text; Im reminded of the Words of Martin Niemoller: >>> >>> "First they came for the Socialists, and I did not speak out >>> Because I was not a Socialist. >>> >>> Then they came for the Trade Unionists, and I did not speak out >>> Because I was not a Trade Unionist. >>> >>> Then they came for the Jews, and I did not speak out >>> Because I was not a Jew. >>> >>> Then they came for meand there was no one left to speak for me." >>> >>> >> >> -- >> Signature text; Im reminded of the Words of Martin Niemoller: >> >> "First they came for the Socialists, and I did not speak out >> Because I was not a Socialist. >> >> Then they came for the Trade Unionists, and I did not speak out >> Because I was not a Trade Unionist. >> >> Then they came for the Jews, and I did not speak out >> Because I was not a Jew. >> >> Then they came for meand there was no one left to speak for me." >> >> > -- Signature text; Im reminded of the Words of Martin Niemoller: "First they came for the Socialists, and I did not speak out Because I was not a Socialist. Then they came for the Trade Unionists, and I did not speak out Because I was not a Trade Unionist. Then they came for the Jews, and I did not speak out Because I was not a Jew. Then they came for meand there was no one left to speak for me." ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 21, 2016
Stall on my MKIII is 30 mph (power off in ground effect), about 33 (out of ground effect) best angle 50 mph, best rate 60 with a spread of 17/37 mph. Pretty close. On a good day it will climb at or a tad below stall speed. This is a unique capability of all models of Kolb aircraft. Full throttle, stick back to the stop, they will continue to climb, prop going in and out of cavitation, aircraft doing a shallow porpoise maneuver, nose feels like it is straight up. Must sound strange to those on the ground. Kolbs are different animals. john h mkIII Titus, Alabama - Cold, wet, gray at hauck's holler, but not nearly as bad as my friends further north. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Thursday, January 21, 2016 10:43 AM Subject: Re: Kolb-List: Re: AOA I've got maybe 5 hrs in a 172, & none in a Kolb, so maybe you can help. My RV-4 stalls in the low 50's (mph) and best rate of climb is actually a rather wide range instead of a single number; from around 110 mph up to around 130 mph, due to the fixed pitch prop & the low aspect ratio 'hershey bar' wing. (Drag goes up rather quickly as the plane slows down due to induced drag, & the highly pitched cruise prop loses efficiency at lower airspeeds and limits engine power at lower rpm so best rate is almost the same from 110 to 130.) Best angle of climb is around 85 mph. Point is, the actual mph spread between best rate & stall is around 55 mph. The spread between best angle and stall is around 30 mph. What are the spreads for your Kolb? If the actual mph spreads are closer (percentages might be the same, or even better; I don't know), then an accurate AOA might be *more* useful in a Kolb than something like an RV, with large speed spreads. Charlie On 1/20/2016 3:48 PM, John Hauck wrote: > > How would one compute the speed range of my mkIII and a Cessna 172? > and compare the results? > > Never flown with an AOA. I think it would be interesting to play with > to learn what it does and how it would improve me and my MKIII's flying. > > john h > mkIII > Titus, Alabama > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie > England > Sent: Wednesday, January 20, 2016 10:51 AM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: AOA > > --> > > On 1/20/2016 9:48 AM, Rex Rodebush wrote: >> --> >> >> When climbing, in the pattern or on final I always keep an eye on the > airspeed. An AOA gage would just be another item to keep an eye on; > unless it has an audio warning. Then it would be very valuable. > Without an audio warning I don't see the point. > This might not be totally applicable to Kolbs due to their > (relatively) narrow speed range, but in the wider aviation world, > you'd ignore airspeed & monitor AOA. Reason is that 1G stall speed can > change quite a bit with gross weight, but angle of attack does not. > Same applies to optimum best angle and best rate in climb. > > With the right kind of audio feedback, you wouldn't need to look in > the cockpit at all. You could devote all your attention to traffic, etc. > > The toughest approach for landing is likely an aircraft carrier; Navy > & Marine a/c use AOA for approaches. > > Charlie > ________________________________________________________________________________
Subject: A question of Battery type
Date: Jan 21, 2016
Kolbers, In a few months I will be needing to buy a battery for my Kolbra.so, I am wondering where we stand in the debate between Lead acid and Lithium. Thank you as always for your insights! Nick Cassara Palmer, AK PAAQ ________________________________________________________________________________
Date: Jan 21, 2016
Nick C: I use, and have used for many years, an AGM lead acid battery. Works well for me. Is very reliable and serviceable for many years. Keep mine charged with a small solar charger that has a conditioner/maintainer capability. http://www.batterymart.com/p-odyssey-pc680-battery.html Guess I am a tad old fashioned. I'll let others test fly the lithium batteries until they are refined enough I know they won't burst into flames while I am 90 miles from nowhere. ;-) john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Nick Cassara Sent: Thursday, January 21, 2016 6:36 PM Subject: Kolb-List: A question of Battery type Kolbers, In a few months I will be needing to buy a battery for my Kolbra.so, I am wondering where we stand in the debate between Lead acid and Lithium. Thank you as always for your insights! Nick Cassara Palmer, AK PAAQ ________________________________________________________________________________
Date: Jan 21, 2016
Subject: Re: A question of Battery type
That is a good question. Wish I knew the answer. Lithium has overcharging or uneven charging issues, Good side, it is very light....while lead acid is heavier, no charging issues. I use the recombinant gas technology. It is more like lead acid but can't spill. I have taken apart a ups(uninterruptible power supply) found a crack from the top right corner across every cell to the lower left corner, zero leakage or damage to the ups. My last one lasted 9 years, it was still starting the plane, but I could tell it was turning a bit slower. Mine is a 17 amp hour out of a harbor frt jump start. Buying the jump start was cheaper than buying the battery from Arizona battery. The one that lasted 9 years was a replacement battery for my jump start... But I don't think you can get it as a replacement part ant longer. It was only 15 dollars but took 3 months to get here. Good luck My answer is worth what you paid,, and I am sure someone else will have another opinion. Boyd Young On Jan 21, 2016 5:40 PM, "Nick Cassara" wrote: > > Kolbers, > > In a few months I will be needing to buy a battery for my Kolbra .so, I am > wondering where we stand in the debate between Lead acid and Lithium. > Thank you as always for your insights! > > Nick Cassara > Palmer, AK > PAAQ > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jan 21, 2016
I'm still a little leery, too, from a safety standpoint. Even without the safety concerns, it's really hard to go from a ~$40 battery to a ~$200 battery to save maybe 10 lbs, unless weight is *really* critical. Charlie On 1/21/2016 6:49 PM, John Hauck wrote: > > Nick C: > > I use, and have used for many years, an AGM lead acid battery. Works well for me. Is very reliable and serviceable for many years. Keep mine charged with a small solar charger that has a conditioner/maintainer capability. > > http://www.batterymart.com/p-odyssey-pc680-battery.html > > Guess I am a tad old fashioned. I'll let others test fly the lithium batteries until they are refined enough I know they won't burst into flames while I am 90 miles from nowhere. ;-) > > john h > mkIII > Titus, Alabama > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Nick Cassara > Sent: Thursday, January 21, 2016 6:36 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: A question of Battery type > > > Kolbers, > > In a few months I will be needing to buy a battery for my Kolbra.so, I am wondering where we stand in the debate between Lead acid and Lithium. > Thank you as always for your insights! > > Nick Cassara > Palmer, AK > PAAQ > > ________________________________________________________________________________
Date: Jan 21, 2016
Nick, It bothers me that the Li sellers like to talk about Pb equivalence rather than capacity. I've belonged to the AeroElectric Connection here on the Matronics Forums and so far no one has been able to say that they've tested an Li battery for capacity and had it equal an AGM lead acid battery. On average when the Li battery is subjected to a constant discharge, like when you lose an alternator, it has about 1/4 the capacity to keep things running. I don't recall what engine you're going to run on the Kolbra but if it's electrically dependant, ie doesn't have mags or dedicated ignition coils this lack of capacity is critical to safety of flight. And as for the weight, if it's that critical there are other ways to lose 10 lb. :-} Rick Girard PS when it comes to lead acid AGM, SLA, RG (in order Advanced Glass Mat, Starved Lead Acid, Recombinant Gas) are all names for the same kind of battery construction. Right now they are the pinnacle of lead acid batteries but as John notes you don't need to spend $100+ on a brand like Oddysey. I use the cheapest I can find, usually the type used for Uninterruptable power supplies. The $37 battery I put in my trike 8 years ago is still running strong. If you want to be safe, figure on a 2 year life, change it out and use the old battery for a motorcycle, snowmobile, emergency radio power supply, etc. That's only $20 a year to ensure you always have a top notch battery in your airplane. On Thu, Jan 21, 2016 at 7:12 PM, Charlie England wrote: > > I'm still a little leery, too, from a safety standpoint. > > Even without the safety concerns, it's really hard to go from a ~$40 > battery to a ~$200 battery to save maybe 10 lbs, unless weight is *really * > critical. > > Charlie > > On 1/21/2016 6:49 PM, John Hauck wrote: > >> >> Nick C: >> >> I use, and have used for many years, an AGM lead acid battery. Works >> well for me. Is very reliable and serviceable for many years. Keep min e >> charged with a small solar charger that has a conditioner/maintainer >> capability. >> >> http://www.batterymart.com/p-odyssey-pc680-battery.html >> >> Guess I am a tad old fashioned. I'll let others test fly the lithium >> batteries until they are refined enough I know they won't burst into fla mes >> while I am 90 miles from nowhere. ;-) >> >> john h >> mkIII >> Titus, Alabama >> >> >> >> >> -----Original Message----- >> From: owner-kolb-list-server(at)matronics.com [mailto: >> owner-kolb-list-server(at)matronics.com] On Behalf Of Nick Cassara >> Sent: Thursday, January 21, 2016 6:36 PM >> To: kolb-list(at)matronics.com >> Subject: Kolb-List: A question of Battery type >> >> >> Kolbers, >> >> In a few months I will be needing to buy a battery for my Kolbra .so, I >> am wondering where we stand in the debate between Lead acid and Lithium. >> Thank you as always for your insights! >> >> Nick Cassara >> Palmer, AK >> PAAQ >> >> >> > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Jan 21, 2016
http://www.arizonabattery.com/?page=shop/flypage&product_id=58&category _id=b291dca6cea297f2a41f49052a63d38d& This is the one that I use and have a cheap float charger that I keep on it when I am not using. It has been in service for three years so far. The problem is if they are regularly discharged, the float takes care of that. Larry On Thu, Jan 21, 2016 at 5:35 PM, Nick Cassara wrote: > > Kolbers, > > In a few months I will be needing to buy a battery for my Kolbra .so, I am > wondering where we stand in the debate between Lead acid and Lithium. > Thank you as always for your insights! > > Nick Cassara > Palmer, AK > PAAQ > =========== =========== =========== =========== =========== > > -- *The older I get, the less tolerant I am of those who are intolerant.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jan 21, 2016
Spend 99.00. Replace the battery in 8 years. 12.00 and change a year. The url I posted is also offers free shipping. That is a 16 amp bat. Works well on a 912uls. On the other hand, I have the same capacity AGM battery powering the 5.5 kw Onan Generator in the back of my truck. Think it may be a Power Sonic, or some no-name brand Absorbed Glass Mat battery. It was cheaper, bought it locally, lives unprotected from the elements, 24/7. Cannot remember how many years I have been using that one. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: Thursday, January 21, 2016 8:57 PM Subject: Re: Kolb-List: A question of Battery type Nick, It bothers me that the Li sellers like to talk about Pb equivalence rather than capacity. I've belonged to the AeroElectric Connection here on the Matronics Forums and so far no one has been able to say that they've tested an Li battery for capacity and had it equal an AGM lead acid battery. On average when the Li battery is subjected to a constant discharge, like when you lose an alternator, it has about 1/4 the capacity to keep things running. I don't recall what engine you're going to run on the Kolbra but if it's electrically dependant, ie doesn't have mags or dedicated ignition coils this lack of capacity is critical to safety of flight. And as for the weight, if it's that critical there are other ways to lose 10 lb. :-} Rick Girard PS when it comes to lead acid AGM, SLA, RG (in order Advanced Glass Mat, Starved Lead Acid, Recombinant Gas) are all names for the same kind of battery construction. Right now they are the pinnacle of lead acid batteries but as John notes you don't need to spend $100+ on a brand like Oddysey. I use the cheapest I can find, usually the type used for Uninterruptable power supplies. The $37 battery I put in my trike 8 years ago is still running strong. If you want to be safe, figure on a 2 year life, change it out and use the old battery for a motorcycle, snowmobile, emergency radio power supply, etc. That's only $20 a year to ensure you always have a top notch battery in your airplane. On Thu, Jan 21, 2016 at 7:12 PM, Charlie England wrote: I'm still a little leery, too, from a safety standpoint. Even without the safety concerns, it's really hard to go from a ~$40 battery to a ~$200 battery to save maybe 10 lbs, unless weight is *really* critical. Charlie On 1/21/2016 6:49 PM, John Hauck wrote: Nick C: I use, and have used for many years, an AGM lead acid battery. Works well for me. Is very reliable and serviceable for many years. Keep mine charged with a small solar charger that has a conditioner/maintainer capability. http://www.batterymart.com/p-odyssey-pc680-battery.html Guess I am a tad old fashioned. I'll let others test fly the lithium batteries until they are refined enough I know they won't burst into flames while I am 90 miles from nowhere. ;-) john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Nick Cassara Sent: Thursday, January 21, 2016 6:36 PM Subject: Kolb-List: A question of Battery type Kolbers, In a few months I will be needing to buy a battery for my Kolbra.so, I am wondering where we stand in the debate between Lead acid and Lithium. Thank you as always for your insights! Nick Cassara Palmer, AK PAAQ br> fts!) r> > href="http://www.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com rel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - eferrer" target="_blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution -- =9CBlessed are the cracked, for they shall let in the light.=9D <http://www.goodreads.com/author/show/43244.Groucho_Marx> Groucho Marx ________________________________________________________________________________
Date: Jan 21, 2016
Good price for an AGM battery, but the want 24.80 to mail it to hauck's holler. ;-) john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Thursday, January 21, 2016 9:34 PM Subject: Re: Kolb-List: A question of Battery type http://www.arizonabattery.com/?page=shop/flypage <http://www.arizonabattery.com/?page=shop/flypage&product_id=58&categ ory_id=b291dca6cea297f2a41f49052a63d38d&> &product_id=58&category_id=b291dca6cea297f2a41f49052a63d38d& This is the one that I use and have a cheap float charger that I keep on it when I am not using. It has been in service for three years so far. The problem is if they are regularly discharged, the float takes care of that. Larry On Thu, Jan 21, 2016 at 5:35 PM, Nick Cassara wrote: Kolbers, In a few months I will be needing to buy a battery for my Kolbra.so, I am wondering where we stand in the debate between Lead acid and Lithium. Thank you as always for your insights! Nick Cassara Palmer, AK PAAQ br> fts!) r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com rel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - eferrer" target="_blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution -- The older I get, the less tolerant I am of those who are intolerant. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jan 22, 2016
I use an Odyssey PC625 for my 912S. Have had it for about 5 years. Last year after setting for 5 months during winter it would not turn the engine fast enough to start. Charged it up and now keep it on a battery maintainer. So far so good. It weighs 13.2 lbs. and I moved it to the front to help my weight and balance. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452194#452194 ________________________________________________________________________________
Date: Jan 23, 2016
Recently replaced mine with a AutoCraft Lithium, LFP-7, it=99s the sa me one, that Bryan Melborn is putting in his builds, except it is the large r size. So far so good. Brad YellowBird1 ----- Original Message ----- From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Thursday, January 21, 2016 8:41:28 PM Subject: RE: Kolb-List: A question of Battery type Good price for an AGM battery, but the want 24.80 to mail it to hauck's hol ler. ;-) john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@m atronics.com] On Behalf Of Larry Cottrell Sent: Thursday, January 21, 2016 9:34 PM Subject: Re: Kolb-List: A question of Battery type http://www.arizonabattery.com/?page=shop/flypage&product_id=58&category _id=b291dca6cea297f2a41f49052a63d38d& This is the one that I use and have a cheap float charger that I keep on it when I am not using. It has been in service for three years so far. The pr oblem is if they are regularly discharged, the float takes care of that. Larry On Thu, Jan 21, 2016 at 5:35 PM, Nick Cassara < nickc(at)mtaonline.net > wrote : Kolbers, In a few months I will be needing to buy a battery for my Kolbra.s o, I am wondering where we stand in the debate between Lead acid and Lithiu m. Thank you as always for your insights! Nick Cassara Palmer, AK PAAQ =========== br> fts!) r> > w.buildersbooks.com" rel="noreferrer" target="_blank"> www.builder sbooks.com rel="noreferrer" target="_blank"> http://www.matronics.com/contribution -Matt Dralle, List Admin. =========== -List" rel="noreferrer" target="_blank"> http://www.matronics.com/Navig ator?Kolb-List =========== FORUMS - eferrer" target="_blank"> http://forums.matronics.com =========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank"> http://www.matronics.com/contribution =========== -- The older I get, the less tolerant I am of those who are intolerant. If you forward this email, or any part of it, please remove my email addres s before sending. ________________________________________________________________________________
Date: Jan 23, 2016
Subject: Snowmageddon
Okay, I hate all the hype and that name in particular but it is a powerful storm. I hope all you out there in it are safe and warm and able to ride it out. I know it's a little early to think about it but there could be some great ski flying after the storm has passed. Good luck all. Rick Girard -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Jan 25, 2016
I replaced my lead acid battery with a Areovoltz 8 cell lithium FE battery about 18 months ago. I had been using a cheep 12 AH lawn mower battery that weighed app 13 lbs. The lead acid battery was marginal at best. On a cold morning or after few starts without any charging it would fail to power my ignition system. Maybe I should have used a bigger battery but I don't like weight. The new Areovolts battery is a 15 AH equivalent and weighs 1.8 lbs. Last spring when I got back from 6 months in Florida I tried to run the battery down with six 5-8 second cranks with the ignition off and with a cool down between each crank. I gave up not wanting to wear out my starter. I then started the engine perfectly. I then hooked up a balance charger and found the cells were within .02 volts of each other. The balance charger couldn't improve on the already good balance. I hear discussions about the AH equivalent rating but from what I have experienced my old lead acid battery would drop below the necessary voltage for my electronic ignition well before the lithium battery would quit. I also have a alternator that bolts to the flywheel and accessory case so there are no moving parts other than the engine. If you have to have more reserve power get a larger lithium and you will still save considerable weight. The lithium FE batteries don't catch on fire like the older lithium batteries did. My lithium FE battery doesn't need to be kept on a battery maintainer like the old lead acid batteries did. After sitting idle in the hanger all winter there is no measurable loss of power. I will continue to report on my ongoing test. Rick Neilsen Redrive VW Powered MKIIIC On Fri, Jan 22, 2016 at 7:06 PM, wrote: > Recently replaced mine with a AutoCraft Lithium, LFP-7, it=99s the same one, > that Bryan Melborn is putting in his builds, except it is the larger size . > So far so good. > > Brad > YellowBird1 > > ------------------------------ > *From: *"John Hauck" <jhauck(at)elmore.rr.com> > *To: *"kolb-list" > *Sent: *Thursday, January 21, 2016 8:41:28 PM > *Subject: *RE: Kolb-List: A question of Battery type > > > Good price for an AGM battery, but the want 24.80 to mail it to hauck's > holler. ;-) > > > john h > > mkIII > > Titus, Alabama > > > *From:* owner-kolb-list-server(at)matronics.com [mailto: > owner-kolb-list-server(at)matronics.com] *On Behalf Of *Larry Cottrell > *Sent:* Thursday, January 21, 2016 9:34 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: A question of Battery type > > > http://www.arizonabattery.com/?page=shop/flypage&product_id=58&catego ry_id=b291dca6cea297f2a41f49052a63d38d& > > > This is the one that I use and have a cheap float charger that I keep on > it when I am not using. It has been in service for three years so far. Th e > problem is if they are regularly discharged, the float takes care of that . > > Larry > > > On Thu, Jan 21, 2016 at 5:35 PM, Nick Cassara wrote : > > > Kolbers, > > In a few months I will be needing to buy a battery for my Kolbra .so, I am > wondering where we stand in the debate between Lead acid and Lithium. > Thank you as always for your insights! > > Nick Cassara > Palmer, AK > PAAQ > > ========== > br> fts!) > r> > w.buildersbooks.com" rel="noreferrer" target="_blank"> > www.buildersbooks.com > rel="noreferrer" target="_blank">http://www.matronics.com/contributio n > -Matt Dralle, List Admin. > ========== > -List" rel="noreferrer" target="_blank"> > http://www.matronics.com/Navigator?Kolb-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contributio n > ========== > > > -- > > *The older I get, the less tolerant I am of those who are intolerant.* > > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > ________________________________________________________________________________
Subject: Re: Snowmageddon
Date: Jan 26, 2016
=9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx>> Great. New one to me. We have the remains of your snowstorm due here as rain. UK is hardly afloat as it is. All field are saturated and are overflowing onto the roads, rivers are full. Some poor blighters have been flooded three times since the New Year already Fingers crossed. Pat From: Richard Girard Sent: Saturday, January 23, 2016 10:19 PM Subject: Kolb-List: Snowmageddon Okay, I hate all the hype and that name in particular but it is a powerful storm. I hope all you out there in it are safe and warm and able to ride it out. I know it's a little early to think about it but there could be some great ski flying after the storm has passed. Good luck all. Rick Girard -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx ________________________________________________________________________________
Date: Jan 26, 2016
Groucho also said " I do not want to be a member of any group that would have me as a member". :-) Herb who is not leaving!! On 01/26/2016 09:36 AM, Patrick Ladd wrote: > > > Blessed are the cracked, for they shall let in the light. Groucho > Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx>>> > Great. New one to me. We have the remains of your snowstorm due > here as rain. UK is hardly afloat as it is. All field are saturated > and are overflowing onto the roads, rivers are full. Some poor > blighters have been flooded three times since the New Year already > Fingers crossed. Pat > > *From:* Richard Girard > *Sent:* Saturday, January 23, 2016 10:19 PM > *To:* kolb-list(at)matronics.com > *Subject:* Kolb-List: Snowmageddon > Okay, I hate all the hype and that name in particular but it is a > powerful storm. I hope all you out there in it are safe and warm and > able to ride it out. I know it's a little early to think about it but > there could be some great ski flying after the storm has passed. Good > luck all. > Rick Girard > -- > > > Blessed are the cracked, for they shall let in the light. Groucho > Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > -- Signature text; ________________________________________________________________________________
Date: Jan 26, 2016
Pat If a clever chap iike you can find a way to ship all that water to Calif, you=99ll be a hero for life! Here in Maine we dint get any of the recent storm; but I feel for the poor folk down south. They dont have warm clothes, and most towns have never even heard of snowplow. Tough duty. Lily sounds like great fun if you have a spare $500 to spend. I=99ll skip for now. Next year they=99ll be $300, eventually $29.95 fresh from Hijng Kong. And the newer model will start at $500. But I did just buy a tiny video camera to play with. When I think of the clumsy stuff we mounted on telephone poles & put into mailboxes - wow, wish we=99d had tiny things like this. What clever beasties we humans are!! =94 I only hope don=99t drown in our own (glowing) garbage. Plan to sell my Xtra. It just doesn=99t do what I=99d hoped it would, photographically speaking. Will likely get a Cessna 140 or some such. Don=99t really need 4 seats, and I do know Cessnas a little. Put 2700 hrs on my 170; 6 coast-coast flights, banner towing, whale surveys, swordfish spotting, even Sasquatch research! =94 lots of photography. It do add up. That plane is now in Fairbanks AK; she=99s a good bush plane for up there. The 140 should work for me and tho they=99re all 60+ yrs old, they built them right. No worries there.. Depressing to think we have 10 more months of the political Yakking. Trump sounds good to me; we need someone who=99s not afraid of saying NO to some people. Hope all=99s well with you guys, and all the best in 2016. And onwards! Russ > On Jan 26, 2016, at 10:36 AM, Patrick Ladd wrote: > > =9CBlessed are the cracked, for they shall let in the light. =9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx>>> Great. New one to me. We have the remains of your snowstorm due here as rain. UK is hardly afloat as it is. All field are saturated and are overflowing onto the roads, rivers are full. Some poor blighters have been flooded three times since the New Year already Fingers crossed. Pat > From: Richard Girard <mailto:aslsa.rng(at)gmail.com> > Sent: Saturday, January 23, 2016 10:19 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Snowmageddon > > Okay, I hate all the hype and that name in particular but it is a powerful storm. I hope all you out there in it are safe and warm and able to ride it out. I know it's a little early to think about it but there could be some great ski flying after the storm has passed. Good luck all. > > Rick Girard > > -- > =9CBlessed are the cracked, for they shall let in the light. =9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> > ________________________________________________________________________________
Date: Jan 26, 2016
And yet, there it is..... On 1/26/2016 5:08 PM, kinne russ wrote: > Depressing to think we have 10 more months of the political Yakking. > Trump sounds good to me; we need someone whos not afraid of saying NO > to some people. > > Russ > >> On Jan 26, 2016, at 10:36 AM, Patrick Ladd > > wrote: >> > > >> Blessed are the cracked, for they shall let in the light. Groucho >> Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx>>> >> Great. New one to me. We have the remains of your snowstorm due >> here as rain. UK is hardly afloat as it is. All field are saturated >> and are overflowing onto the roads, rivers are full. Some poor >> blighters have been flooded three times since the New Year already >> Fingers crossed. Pat >> >> *From:* Richard Girard >> *Sent:* Saturday, January 23, 2016 10:19 PM >> *To:* kolb-list(at)matronics.com >> *Subject:* Kolb-List: Snowmageddon >> Okay, I hate all the hype and that name in particular but it is a >> powerful storm. I hope all you out there in it are safe and warm and >> able to ride it out. I know it's a little early to think about it but >> there could be some great ski flying after the storm has passed. Good >> luck all. >> Rick Girard >> -- >> >> >> Blessed are the cracked, for they shall let in the light. Groucho >> Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> >> >> > ________________________________________________________________________________
Subject: Gap seals
Date: Jan 26, 2016
Hi all, I've bee slowly and intermittently working on my mk3xtra and have wondered about using the aluminum hinge that attaches the flaperon to the trailing edge of the wing going the the whole distance from inboard to outboard. Does anyone think this would eliminate the need for the 3m tape supplied in the kit ? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452324#452324 ________________________________________________________________________________
Date: Jan 26, 2016
Subject: Re: Gap seals
It's your experiment, but either fabric or tape gap seals are less expensive than all that hinge (which is NOT intended to attach control surfaces by the way) and decreases the number of holes in the rear wing spars and the leading edge of the control surfaces. My two cents. Rick Girard Before someone starts in, look up the specs for MS20257 rolled hinge and MS20001 Extruded (structural) Hinge. Just sayin' On Tue, Jan 26, 2016 at 5:49 PM, Flylawnchairs wrote: > > > Hi all, I've bee slowly and intermittently working on my mk3xtra and have > wondered about using the aluminum hinge that attaches the flaperon to the > trailing edge of the wing going the the whole distance from inboard to > outboard. Does anyone think this would eliminate the need for the 3m tape > supplied in the kit ? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452324#452324 > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Jan 26, 2016
List, I apologise. Meant that email to go to Pat alone. But WTH, praps the List agrees with me. Russ > On Jan 26, 2016, at 6:35 PM, Charlie England > wrote: > > And yet, there it is..... > > On 1/26/2016 5:08 PM, kinne russ wrote: >> Depressing to think we have 10 more months of the political Yakking. Trump sounds good to me; we need someone who=99s not afraid of saying NO to some people. >> >> Russ >> >>> On Jan 26, 2016, at 10:36 AM, Patrick Ladd > wrote: >>> >> >> >>> =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx>>> Great. New one to me. We have the remains of your snowstorm due here as rain. UK is hardly afloat as it is. All field are saturated and are overflowing onto the roads, rivers are full. Some poor blighters have been flooded three times since the New Year already Fingers crossed. Pat >>> From: Richard Girard <mailto:aslsa.rng(at)gmail.com> >>> Sent: Saturday, January 23, 2016 10:19 PM >>> To: kolb-list(at)matronics.com >>> Subject: Kolb-List: Snowmageddon >>> >>> Okay, I hate all the hype and that name in particular but it is a powerful storm. I hope all you out there in it are safe and warm and able to ride it out. I know it's a little early to think about it but there could be some great ski flying after the storm has passed. Good luck all. >>> >>> Rick Girard >>> >>> -- >>> =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> >>> >> > ________________________________________________________________________________
Subject: Gap seals
Date: Jan 26, 2016
Doesn't take much hinge to hang an aileron and flap. Piano hinges may not have been designed for control surface hinges, but they have served us, in the Kolb world, well. The trailing edge of the wing and the leading edge of the flap and aileron flex quite a bit in flight. Never tried to see if I could actually see them flex in flight, but it can be done on the ground. Full span hinges will begin binding as soon as they begin getting out of column. Would it be a problem? I don't know. Is there enough flex in the wing and control surfaces to bind up a full span hinge? I don't know that either. Best go by the plans on size and number of hinges, in my humble opinion. I have Polyester Dacron fabric seals that were installed on my MKIII in 1992. They are still serviceable after 24 years and 3,300+ hours. Takes a little longer and is a little more difficult to go this route, but the end result produces the best gap seal. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: Tuesday, January 26, 2016 6:17 PM Subject: Re: Kolb-List: Gap seals It's your experiment, but either fabric or tape gap seals are less expensive than all that hinge (which is NOT intended to attach control surfaces by the way) and decreases the number of holes in the rear wing spars and the leading edge of the control surfaces. My two cents. Rick Girard Before someone starts in, look up the specs for MS20257 rolled hinge and MS20001 Extruded (structural) Hinge. Just sayin' On Tue, Jan 26, 2016 at 5:49 PM, Flylawnchairs wrote: Hi all, I've bee slowly and intermittently working on my mk3xtra and have wondered about using the aluminum hinge that attaches the flaperon to the trailing edge of the wing going the the whole distance from inboard to outboard. Does anyone think this would eliminate the need for the 3m tape supplied in the kit ? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452324#452324 br> fts!) r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com rel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - eferrer" target="_blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution -- =9CBlessed are the cracked, for they shall let in the light.=9D <http://www.goodreads.com/author/show/43244.Groucho_Marx> Groucho Marx ________________________________________________________________________________
Date: Jan 26, 2016
Rick mentions a question worth asking about extra holes in the spar. Having said that, the 2 seat RV's use full length piano hinge for the flaps. IIRC, some of the Zenith products use them for aileron hinges. FWIW, Charlie On 1/26/2016 7:04 PM, John Hauck wrote: > > Doesn't take much hinge to hang an aileron and flap. > > Piano hinges may not have been designed for control surface hinges, > but they have served us, in the Kolb world, well. > > The trailing edge of the wing and the leading edge of the flap and > aileron flex quite a bit in flight. Never tried to see if I could > actually see them flex in flight, but it can be done on the ground. > > Full span hinges will begin binding as soon as they begin getting out > of column. Would it be a problem? I don't know. Is there enough > flex in the wing and control surfaces to bind up a full span hinge? I > don't know that either. > > Best go by the plans on size and number of hinges, in my humble opinion. > > I have Polyester Dacron fabric seals that were installed on my MKIII > in 1992. They are still serviceable after 24 years and 3,300+ hours. > Takes a little longer and is a little more difficult to go this route, > but the end result produces the best gap seal. > > john h > > mkIII > > Titus, Alabama > > *From:*owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] *On Behalf Of *Richard > Girard > *Sent:* Tuesday, January 26, 2016 6:17 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: Gap seals > > It's your experiment, but either fabric or tape gap seals are less > expensive than all that hinge (which is NOT intended to attach control > surfaces by the way) and decreases the number of holes in the rear > wing spars and the leading edge of the control surfaces. My two cents. > > Rick Girard > > Before someone starts in, look up the specs for MS20257 rolled hinge > and MS20001 Extruded (structural) Hinge. Just sayin' > > On Tue, Jan 26, 2016 at 5:49 PM, Flylawnchairs > > wrote: > > > > > Hi all, I've bee slowly and intermittently working on my mk3xtra and > have wondered about using the aluminum hinge that attaches the > flaperon to the trailing edge of the wing going the the whole distance > from inboard to outboard. Does anyone think this would eliminate the > need for the 3m tape supplied in the kit ? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452324#452324 > ________________________________________________________________________________
Date: Jan 26, 2016
I think that if I were to use full length hinges, I would install them in such a way that they never go straight even at full deflection of the control surfaces. that way they can't lock up on you. Boyd Young ________________________________________________________________________________
Date: Jan 27, 2016
I don't. I won't go into politics because this isn't the place for it. I may express my Kolb opinions, or in the case of the Snowmageddon comment was as far out of bounds as I'll go. Rick On Tue, Jan 26, 2016 at 6:47 PM, kinne russ wrote: > List, I apologise. Meant that email to go to Pat alone. > But WTH, praps the List agrees with me. > Russ > > > On Jan 26, 2016, at 6:35 PM, Charlie England wrote : > > And yet, there it is..... > > On 1/26/2016 5:08 PM, kinne russ wrote: > > Depressing to think we have 10 more months of the political Yakking. Trum p > sounds good to me; we need someone who=99s not afraid of saying NO to some > people. > > Russ > > On Jan 26, 2016, at 10:36 AM, Patrick Ladd > wrote: > > > =9CBlessed are the cracked, for they shall let in the light. =9D Groucho Marx > <http://www.goodreads.com/author/show/43244.Groucho_Marx>>> Great. New > one to me. We have the remains of your snowstorm due here as rain. UK is > hardly afloat as it is. All field are saturated and are overflowing onto > the roads, rivers are full. Some poor blighters have been flooded three > times since the New Year already Fingers crossed. Pat > *From:* Richard Girard > *Sent:* Saturday, January 23, 2016 10:19 PM > *To:* kolb-list(at)matronics.com > *Subject:* Kolb-List: Snowmageddon > > Okay, I hate all the hype and that name in particular but it is a powerfu l > storm. I hope all you out there in it are safe and warm and able to ride it > out. I know it's a little early to think about it but there could be some > great ski flying after the storm has passed. Good luck all. > > Rick Girard > > -- > =9CBlessed are the cracked, for they shall let in the light. =9D Groucho Marx > <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Jan 27, 2016
Yes, I knew that one. It was `The cracked shall let in the light` that was new. Pat From: Herb Sent: Tuesday, January 26, 2016 4:07 PM Subject: Re: Kolb-List: Snowmageddon Groucho also said " I do not want to be a member of any group that would have me as a member". :-) Herb who is not leaving!! On 01/26/2016 09:36 AM, Patrick Ladd wrote: =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx>> Great. New one to me. We have the remains of your snowstorm due here as rain. UK is hardly afloat as it is. All field are saturated and are overflowing onto the roads, rivers are full. Some poor blighters have been flooded three times since the New Year already Fingers crossed. Pat From: Richard Girard Sent: Saturday, January 23, 2016 10:19 PM To: kolb-list(at)matronics.com Subject: Kolb-List: Snowmageddon Okay, I hate all the hype and that name in particular but it is a powerful storm. I hope all you out there in it are safe and warm and able to ride it out. I know it's a little early to think about it but there could be some great ski flying after the storm has passed. Good luck all. Rick Girard -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx -- Signature text; ________________________________________________________________________________
Date: Jan 27, 2016
Thanks for the input guys, think I'll just use the required amount of hinge and call it good. Even though all that flexing really bothers me, I think John has a point about it working fine for 3300 hours. Cheers, Gene Wilson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452355#452355 ________________________________________________________________________________
Date: Jan 27, 2016
Probably didn't make myself clear, as usual. Any flexing is not noticeable. My description would have fit a Challenger wing much better than Homer Kolb's wing. Do not let the minute flex bother you. john h Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Flylawnchairs Sent: Wednesday, January 27, 2016 11:03 AM Subject: Kolb-List: Re: Gap seals --> Thanks for the input guys, think I'll just use the required amount of hinge and call it good. Even though all that flexing really bothers me, I think John has a point about it working fine for 3300 hours. Cheers, Gene Wilson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452355#452355 ________________________________________________________________________________
Date: Jan 27, 2016
Subject: Re: Kolb-List Digest: 1 Msgs - 01/25/16
Ben gone a while ... this is a test post :-) -----Original Message----- From: Kolb-List Digest Server <kolb-list(at)matronics.com> Sent: Tue, Jan 26, 2016 3:11 am Subject: Kolb-List Digest: 1 Msgs - 01/25/16 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Kolb-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Kolb-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-01-25&Archive=Kolb Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 16-01-25&Archive=Kolb =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Kolb-List Digest Archive --- Total Messages Posted Mon 01/25/16: 1 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 11:04 AM - Re: A question of Battery type (Rick Neilsen) ________________________________ Message 1 _____________________________________ Subject: Re: Kolb-List: A question of Battery type From: Rick Neilsen <neilsenrm(at)gmail.com> I replaced my lead acid battery with a Areovoltz 8 cell lithium FE battery about 18 months ago. I had been using a cheep 12 AH lawn mower battery that weighed app 13 lbs. The lead acid battery was marginal at best. On a cold morning or after few starts without any charging it would fail to power my ignition system. Maybe I should have used a bigger battery but I don't like weight. The new Areovolts battery is a 15 AH equivalent and weighs 1.8 lbs. Last spring when I got back from 6 months in Florida I tried to run the battery down with six 5-8 second cranks with the ignition off and with a cool down between each crank. I gave up not wanting to wear out my starter. I then started the engine perfectly. I then hooked up a balance charger and found the cells were within .02 volts of each other. The balance charger couldn't improve on the already good balance. I hear discussions about the AH equivalent rating but from what I have experienced my old lead acid battery would drop below the necessary voltage for my electronic ignition well before the lithium battery would quit. I also have a alternator that bolts to the flywheel and accessory case so there are no moving parts other than the engine. If you have to have more reserve power get a larger lithium and you will still save considerable weight. The lithium FE batteries don't catch on fire like the older lithium batteries did. My lithium FE battery doesn't need to be kept on a battery maintainer like the old lead acid batteries did. After sitting idle in the hanger all winter there is no measurable loss of power. I will continue to report on my ongoing test. Rick Neilsen Redrive VW Powered MKIIIC On Fri, Jan 22, 2016 at 7:06 PM, wrote: > Recently replaced mine with a AutoCraft Lithium, LFP-7, it=99s the same one, > that Bryan Melborn is putting in his builds, except it is the larger size .. > So far so good. > > Brad > YellowBird1 > > ------------------------------ > *From: *"John Hauck" <jhauck(at)elmore.rr.com> > *To: *"kolb-list" > *Sent: *Thursday, January 21, 2016 8:41:28 PM > *Subject: *RE: Kolb-List: A question of Battery type > > > Good price for an AGM battery, but the want 24.80 to mail it to hauck's > holler. ;-) > > > john h > > mkIII > > Titus, Alabama > > > *From:* owner-kolb-list-server(at)matronics.com [mailto: > owner-kolb-list-server(at)matronics.com] *On Behalf Of *Larry Cottrell > *Sent:* Thursday, January 21, 2016 9:34 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: A question of Battery type > > > http://www.arizonabattery.com/?page=shop/flypage&product_id=58&catego ry_id=b291dca6cea297f2a41f49052a63d38d& > > > This is the one that I use and have a cheap float charger that I keep on > it when I am not using. It has been in service for three years so far. Th e > problem is if they are regularly discharged, the float takes care of that .. > > Larry > > > On Thu, Jan 21, 2016 at 5:35 PM, Nick Cassara wrote : > > > Kolbers, > > In a few months I will be needing to buy a battery for my Kolbra .so, I am > wondering where we stand in the debate between Lead acid and Lithium. > Thank you as always for your insights! > > Nick Cassara > Palmer, AK > PAAQ > > ========= > br> fts!) > r> > w.buildersbooks.com" rel="noreferrer" target="_blank"> > www.buildersbooks.com > rel="noreferrer" target="_blank">http://www.matronics.com/contributio n > -Matt Dralle, List Admin. > ========= > -List" rel="noreferrer" target="_blank"> > http://www.matronics.com/Navigator?Kolb-List > ========= > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========= > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contributio n > ========= > > > -- > > *The older I get, the less tolerant I am of those who are intolerant.* > > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > ________________________________________________________________________________
Date: Jan 28, 2016
I got a new lithium battery for Christmas from my kids.For my Kolb Firefly. Here's the link I sent them.Not sure how safe it is but losing 10 LB sound ed great. My 6 year old lead acid was dying.=C2-Amazon.com: YT12B-BS Lith ium Ion Sealed Battery 12V 280 CCA - Ducati Monster Hypermotard Multistrada Street Fighter (#5): Automotive | =C2- | | =C2- | | =C2- | =C2- | =C2- | =C2- | =C2- | | Amazon.com: YT12B-BS Lithium Ion Sealed Battery 12V...Dimensions: L: 150 x H: 64 x W: 92 (mm) Battery weight: 1.1 lbs Voltage: 12v CCA: 280 Get impr oved performance and exceptional cranking power with this lithium io... | | | | View on www.amazon.com | Preview by Yahoo | | | | =C2- | On Monday, January 25, 2016 2:13 PM, Rick Neilsen wrote: I replaced my lead acid battery with a Areovoltz 8 cell lithium FE battery about 18 months ago. I had been using a cheep 12 AH lawn mower battery tha t weighed app 13 lbs. The lead acid battery was marginal at best. On a cold morning or after few starts without any charging it would fail to power my ignition system. Maybe I should have used a bigger battery but I don't lik e weight.=C2- The new Areovolts battery is a 15 AH equivalent and weighs 1.8 lbs. Last sp ring when I got back from 6 months in Florida I tried to run the battery do wn with six 5-8 second cranks with the ignition off and with a cool down be tween each crank. I gave up not wanting to wear out my starter. I then star ted the engine perfectly. I then hooked up a balance charger and found the cells were within .02 volts of each other. The balance charger couldn't imp rove on the already good balance. =C2- I hear discussions about the AH equivalent rating but from what I have expe rienced my old lead acid battery would drop below the necessary voltage for my electronic ignition well before the lithium battery would quit. I also have a alternator that bolts to the flywheel and accessory case so there ar e no moving parts other than the engine. If you have to have more reserve p ower get a larger lithium and you will still save considerable weight. The lithium FE batteries don't catch on fire like the older lithium batteri es did. My lithium FE battery doesn't =C2-need to be kept on a battery ma intainer like the old lead acid batteries did. After sitting idle in the ha nger all winter there is no measurable loss of power.=C2- I will continue to report on my ongoing test. Rick NeilsenRedrive VW Powered MKIIIC On Fri, Jan 22, 2016 at 7:06 PM, wrote: Recently replaced mine with a AutoCraft Lithium, LFP-7, it=99s the sa me one, that Bryan Melborn is putting in his builds, except it is the large r size. So far so good. BradYellowBird1 From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Thursday, January 21, 2016 8:41:28 PM Subject: RE: Kolb-List: A question of Battery type Good price for an AGM battery, but the want 24.80 to mail it to hauck's hol ler.=C2- ;-)=C2-john hmkIIITitus, Alabama=C2-=C2-=C2-=C2-From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@matroni cs.com] On Behalf Of Larry Cottrell Sent: Thursday, January 21, 2016 9:34 PM Subject: Re: Kolb-List: A question of Battery type=C2-http://www.arizonab attery.com/?page=shop/flypage&product_id=58&category_id=b291dca6cea29 7f2a41f49052a63d38d&=C2-This is the one that I use and have a cheap float charger that I =C2-keep on it when I am not using. It has been in servic e for three years so far. The problem is if they are regularly discharged, the float takes care of that.Larry=C2-=C2-On Thu, Jan 21, 2016 at 5:35 PM, Nick Cassara wrote:--> Kolb-List message posted b y: Nick Cassara Kolbers, In a few months I will be needing to buy a battery for my Kolbra.s o, I am wondering where we stand in the debate between Lead acid and Lithiu m. Thank you as always for your insights! Nick Cassara Palmer, AK PAAQ br> fts!) r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.builders books.com rel="noreferrer" target="_blank">http://www.matronics.com/contribution =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. -List" rel="noreferrer" target="_blank">http://www.matronics.com/Naviga tor?Kolb-List FORUMS - eferrer" target="_blank">http://forums.matronics.com b Site - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution =C2---The older I get, the less tolerant I am of those who are intolerant .=C2-If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jan 27, 2016
I think all the Kolbs have a solid hinge at the root, and piano hinges along the rest of the wing, and typically the tips have a bit of flex from the piano hinges. If you want the aileron tip end to be solid with no flex: you know those stainless L hinges that are used to secure the leading edge of the horizontal stab? Buy 8 extra stainless L hinges and use them as tip aileron hinges and the flex will go away. http://oh2fly.net/oldpoops/pg8.htm -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452377#452377 ________________________________________________________________________________
Date: Jan 27, 2016
Note that it says 'lithium *ion*'. If you ever offer me a ride, please remember to tell me about your battery. :-) Seriously, the ones that have a (limited) good record in a/c lithium iron phosphate, like Rick described. If yours is really lithium ion (as used in RC model planes, etc), tread carefully. For reference, EarthX makes lithium FE batteries intended to be direct replacements for Odyssey PC680 batteries. They actually publish discharge curves for their batteries showing similar total energy to the 680, a true 12 AH battery. The EarthX weighs 4.1 lbs; the YT12B weighs 1.1 lbs. For me, these data points indicate a couple (three, actually) of things. First, the YT12B probably *is* a lithium ion battery. Second, it's probably rated as a 12 AH equivalent, *only for starting*, meaning that if you need endurance from the battery in the case of an alternator failure, you may not have it. Last, there's significantly greater fire risk from the YT12B. But those are just my opinions; worth what you paid... Charlie PS: I'm not advocating for EarthX; it's taken them a long time to publish useful info & their technical spokesperson has often seemed to lack technical knowledge in previous exchanges. On 1/27/2016 7:01 PM, William Long wrote: > I got a new lithium battery for Christmas from my kids.For my Kolb > Firefly. Here's the link I sent them. > Not sure how safe it is but losing 10 LB sounded great. My 6 year old > lead acid was dying. > Amazon.com: YT12B-BS Lithium Ion Sealed Battery 12V 280 CCA - Ducati > Monster Hypermotard Multistrada Street Fighter (#5): Automotive > <http://www.amazon.com/dp/B017DY70RQ/ref=dra_a_rv_mr_hn_xx_P1250_1000?tag=dradisplay-20&ascsubtag=8c987a3d56d7e7185d64c9e92cd3d206_S> > > image > <http://www.amazon.com/dp/B017DY70RQ/ref=dra_a_rv_mr_hn_xx_P1250_1000?tag=dradisplay-20&ascsubtag=8c987a3d56d7e7185d64c9e92cd3d206_S> > > > > > > Amazon.com: YT12B-BS Lithium Ion Sealed Battery 12V... > <http://www.amazon.com/dp/B017DY70RQ/ref=dra_a_rv_mr_hn_xx_P1250_1000?tag=dradisplay-20&ascsubtag=8c987a3d56d7e7185d64c9e92cd3d206_S> > > Dimensions: L: 150 x H: 64 x W: 92 (mm) Battery weight: 1.1 lbs > Voltage: 12v CCA: 280 Get improved performance and exceptional > cranking power with this lithium io... > > View on www.amazon.com > <http://www.amazon.com/dp/B017DY70RQ/ref=dra_a_rv_mr_hn_xx_P1250_1000?tag=dradisplay-20&ascsubtag=8c987a3d56d7e7185d64c9e92cd3d206_S> > > Preview by Yahoo > > > On Monday, January 25, 2016 2:13 PM, Rick Neilsen > wrote: > > > I replaced my lead acid battery with a Areovoltz 8 cell lithium FE > battery about 18 months ago. I had been using a cheep 12 AH lawn mower > battery that weighed app 13 lbs. The lead acid battery was marginal at > best. On a cold morning or after few starts without any charging it > would fail to power my ignition system. Maybe I should have used a > bigger battery but I don't like weight. > > The new Areovolts battery is a 15 AH equivalent and weighs 1.8 lbs. > Last spring when I got back from 6 months in Florida I tried to run > the battery down with six 5-8 second cranks with the ignition off and > with a cool down between each crank. I gave up not wanting to wear out > my starter. I then started the engine perfectly. I then hooked up a > balance charger and found the cells were within .02 volts of each > other. The balance charger couldn't improve on the already good balance. > > I hear discussions about the AH equivalent rating but from what I have > experienced my old lead acid battery would drop below the necessary > voltage for my electronic ignition well before the lithium battery > would quit. I also have a alternator that bolts to the flywheel and > accessory case so there are no moving parts other than the engine. If > you have to have more reserve power get a larger lithium and you will > still save considerable weight. > > The lithium FE batteries don't catch on fire like the older lithium > batteries did. My lithium FE battery doesn't need to be kept on a > battery maintainer like the old lead acid batteries did. After sitting > idle in the hanger all winter there is no measurable loss of power. > > I will continue to report on my ongoing test. > > Rick Neilsen > Redrive VW Powered MKIIIC > > > On Fri, Jan 22, 2016 at 7:06 PM, > wrote: > > Recently replaced mine with a AutoCraft Lithium, LFP-7, its the > same one, that Bryan Melborn is putting in his builds, except it > is the larger size. So far so good. > > Brad > YellowBird1 > > ------------------------------------------------------------------------ > *From: *"John Hauck" <jhauck(at)elmore.rr.com > > > *To: *"kolb-list" > > *Sent: *Thursday, January 21, 2016 8:41:28 PM > *Subject: *RE: Kolb-List: A question of Battery type > > > Good price for an AGM battery, but the want 24.80 to mail it to > hauck's holler. ;-) > john h > mkIII > Titus, Alabama > *From:*owner-kolb-list-server(at)matronics.com > > [mailto:owner-kolb-list-server(at)matronics.com > ] *On Behalf Of > *Larry Cottrell > *Sent:* Thursday, January 21, 2016 9:34 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: A question of Battery type > http://www.arizonabattery.com/?page=shop/flypage&product_id=58&category_id=b291dca6cea297f2a41f49052a63d38d& > This is the one that I use and have a cheap float charger that I > keep on it when I am not using. It has been in service for three > years so far. The problem is if they are regularly discharged, the > float takes care of that. > Larry > On Thu, Jan 21, 2016 at 5:35 PM, Nick Cassara > wrote: > > > > Kolbers, > > In a few months I will be needing to buy a battery for my > Kolbra.so, I am wondering where we stand in the debate between > Lead acid and Lithium. > Thank you as always for your insights! > > Nick Cassara > Palmer, AK > PAAQ > > ========== > br> fts!) > r> > w.buildersbooks.com <http://w.buildersbooks.com/>" > rel="noreferrer" target="_blank">www.buildersbooks.com > <http://www.buildersbooks.com/> > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > ========== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > <http://forums.matronics.com/> > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > > -- > /The older I get, the less tolerant I am of those who are intolerant./ > /If you forward this email, or any part of it, please remove my > email address before sending./ > > ________________________________________________________________________________
Date: Jan 28, 2016
While my Firestar doesn't have flaps, my ailerons have hinge the length of the aileron, not however from the inside edge of the aileron to the wing root and I think this a very good gap seal. ----- Original Message ----- From: "Flylawnchairs" <Flylawnchairs(at)gmail.com> Sent: Tuesday, January 26, 2016 6:49:20 PM Subject: Kolb-List: Gap seals Hi all, I've bee slowly and intermittently working on my mk3xtra and have wondered about using the aluminum hinge that attaches the flaperon to the trailing edge of the wing going the the whole distance from inboard to outboard. Does anyone think this would eliminate the need for the 3m tape supplied in the kit ? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452324#452324 ________________________________________________________________________________
Date: Jan 28, 2016
William I have been using a Areovoltz battery in my MKIIIC it is a Lithium Iron Phosphate battery. Lithium Ion batteries have a history of not tolerating low or high voltages very well and doing bad things. If we believe the literature on Lithium Iron Phosphate batteries these low or high voltages are much better tolerated, at the very least they aren't supposed to catch on fire. What I do know is my battery looks to be very well made, extreemly light, very powerful, and doesn't loose any measurable power with 6 months in storage. As always worth what you paid for it. Rick Neilsen Redrive VW Powered MKIIIC On Wed, Jan 27, 2016 at 10:42 PM, Charlie England wrote: > Note that it says 'lithium *ion*'. If you ever offer me a ride, please > remember to tell me about your battery. > :-) > > Seriously, the ones that have a (limited) good record in a/c lithium iron > phosphate, like Rick described. If yours is really lithium ion (as used i n > RC model planes, etc), tread carefully. > > For reference, EarthX makes lithium FE batteries intended to be direct > replacements for Odyssey PC680 batteries. They actually publish discharge > curves for their batteries showing similar total energy to the 680, a tru e > 12 AH battery. The EarthX weighs 4.1 lbs; the YT12B weighs 1.1 lbs. > > For me, these data points indicate a couple (three, actually) of things. > First, the YT12B probably *is* a lithium ion battery. Second, it's probab ly > rated as a 12 AH equivalent, *only for starting*, meaning that if you nee d > endurance from the battery in the case of an alternator failure, you may > not have it. Last, there's significantly greater fire risk from the YT12B . > > But those are just my opinions; worth what you paid... > > Charlie > PS: I'm not advocating for EarthX; it's taken them a long time to publish > useful info & their technical spokesperson has often seemed to lack > technical knowledge in previous exchanges. > > > On 1/27/2016 7:01 PM, William Long wrote: > > I got a new lithium battery for Christmas from my kids.For my Kolb > Firefly. Here's the link I sent them. > Not sure how safe it is but losing 10 LB sounded great. My 6 year old lea d > acid was dying. > Amazon.com: YT12B-BS Lithium Ion Sealed Battery 12V 280 CCA - Ducati > Monster Hypermotard Multistrada Street Fighter (#5): Automotive > <http://www.amazon.com/dp/B017DY70RQ/ref=dra_a_rv_mr_hn_xx_P1250_1000?t ag=dradisplay-20&ascsubtag=8c987a3d56d7e7185d64c9e92cd3d206_S> > > > [image: image] > <http://www.amazon.com/dp/B017DY70RQ/ref=dra_a_rv_mr_hn_xx_P1250_1000?t ag=dradisplay-20&ascsubtag=8c987a3d56d7e7185d64c9e92cd3d206_S> > > > Amazon.com: YT12B-BS Lithium Ion Sealed Battery 12V... > <http://www.amazon.com/dp/B017DY70RQ/ref=dra_a_rv_mr_hn_xx_P1250_1000?t ag=dradisplay-20&ascsubtag=8c987a3d56d7e7185d64c9e92cd3d206_S> > Dimensions: L: 150 x H: 64 x W: 92 (mm) Battery weight: 1.1 lbs Voltage: > 12v CCA: 280 Get improved performance and exceptional cranking power with > this lithium io... > > View on www.amazon.com > <http://www.amazon.com/dp/B017DY70RQ/ref=dra_a_rv_mr_hn_xx_P1250_1000?t ag=dradisplay-20&ascsubtag=8c987a3d56d7e7185d64c9e92cd3d206_S> > Preview by Yahoo > > > On Monday, January 25, 2016 2:13 PM, Rick Neilsen > wrote: > > > I replaced my lead acid battery with a Areovoltz 8 cell lithium FE batter y > about 18 months ago. I had been using a cheep 12 AH lawn mower battery th at > weighed app 13 lbs. The lead acid battery was marginal at best. On a cold > morning or after few starts without any charging it would fail to power m y > ignition system. Maybe I should have used a bigger battery but I don't li ke > weight. > > The new Areovolts battery is a 15 AH equivalent and weighs 1.8 lbs. Last > spring when I got back from 6 months in Florida I tried to run the batter y > down with six 5-8 second cranks with the ignition off and with a cool dow n > between each crank. I gave up not wanting to wear out my starter. I then > started the engine perfectly. I then hooked up a balance charger and foun d > the cells were within .02 volts of each other. The balance charger couldn 't > improve on the already good balance. > > I hear discussions about the AH equivalent rating but from what I have > experienced my old lead acid battery would drop below the necessary volta ge > for my electronic ignition well before the lithium battery would quit. I > also have a alternator that bolts to the flywheel and accessory case so > there are no moving parts other than the engine. If you have to have more > reserve power get a larger lithium and you will still save considerable > weight. > > The lithium FE batteries don't catch on fire like the older lithium > batteries did. My lithium FE battery doesn't need to be kept on a batter y > maintainer like the old lead acid batteries did. After sitting idle in th e > hanger all winter there is no measurable loss of power. > > I will continue to report on my ongoing test. > > Rick Neilsen > Redrive VW Powered MKIIIC > > > On Fri, Jan 22, 2016 at 7:06 PM, < > nationcap(at)comcast.net> wrote: > > Recently replaced mine with a AutoCraft Lithium, LFP-7, it=99s the same one, > that Bryan Melborn is putting in his builds, except it is the larger size . > So far so good. > > Brad > YellowBird1 > > ------------------------------ > *From: *"John Hauck" < <jhauck(at)elmore.rr.com>jhauck(at)elmore.rr.com> > *To: *"kolb-list" < kolb-list(at)matronics.com> > *Sent: *Thursday, January 21, 2016 8:41:28 PM > *Subject: *RE: Kolb-List: A question of Battery type > > > Good price for an AGM battery, but the want 24.80 to mail it to hauck's > holler. ;-) > > john h > mkIII > Titus, Alabama > >
January 10, 2016 - February 06, 2016
Kolb-Archive.digest.vol-np
