Kolb-Archive.digest.vol-nu
April 12, 2016 - April 30, 2016
Subject: Re: Alloyed aluminum on our kolbs...
Date: Apr 12, 2016
John Hauck wrote: > > > Kolbers: > > To prevent the rivet from spinning while drilling I made a small tool out of a piece of hack saw blade. I grind a notch in one end, beveling on one edge. Push this under the rivet head as far as possible to lock the rivet. > > > john h > mkIII > Titus, Alabama Yep. Works like a champion. Sharpen the beveled notch edges with a Dremel. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=454917#454917 Attachments: http://forums.matronics.com//files/p1050022_medium_665.jpg ________________________________________________________________________________
Date: Apr 12, 2016
Yep. Works like a champion. Sharpen the beveled notch edges with a Dremel. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 I used the corner of a bench grinder to do mine. The little homemade tools I use for pop rivets in the tin can with my pop rivet gun and snap punch, must be 30 years old. Can't wear them out and they didn't cost anything to start with. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: video
Date: Apr 12, 2016
Thanks for the great video! Marlon -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=454922#454922 ________________________________________________________________________________
Subject: Re: Last Flight 2005
Date: Apr 12, 2016
I have been there a few times by auto, would love to see it from my Firefly. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=454923#454923 ________________________________________________________________________________
Subject: Re: Firestar tail boom length...
Date: Apr 12, 2016
Thanks Bill I have a bunch of 5 inch tubes that I bought Kolb many years ago... lightly dented or scratched...tubes that they could not sell with a kit...but very serviceable otherwise.. Wish I had bought the whole trailer load...!! Off to measure...:-) Herb On 04/12/2016 04:19 PM, Bill Berle wrote: > > 13 feet on the FireStar 2. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Tue, 4/12/16, Herb wrote: > > Subject: Kolb-List: Firestar tail boom length... > To: kolb-list(at)matronics.com > Date: Tuesday, April 12, 2016, 1:26 PM > > Herb > > Could call Bryan...but someone will know....what is the > length of the > tail boom on the Firestar 1? Probably the same on the > II also? Herb > > Lists This Month -- > Some AWESOME FREE Gifts!) > Raiser. Click on > more about > Gifts provided > www.buildersbooks.com > -Matt > Dralle, List Admin. > Forum - > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
From: "Greg Taylor" <gtaylor35918(at)roadrunner.com>
Date: Apr 12, 2016
Good video, Christ has pay the prince for our sins, it is by God's Grace that we are Saved. G od's R iches A t C hrist E xpense -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Tuesday, April 12, 2016 5:28 PM Subject: Kolb-List: Re: Alloyed aluminum on our kolbs... --> John Hauck wrote: > > > Kolbers: > > To prevent the rivet from spinning while drilling I made a small tool out of a piece of hack saw blade. I grind a notch in one end, beveling on one edge. Push this under the rivet head as far as possible to lock the rivet. > > > john h > mkIII > Titus, Alabama Yep. Works like a champion. Sharpen the beveled notch edges with a Dremel. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=454917#454917 Attachments: http://forums.matronics.com//files/p1050022_medium_665.jpg ________________________________________________________________________________
Date: Apr 12, 2016
Herb although it would be a custom, unapproved, unsupported modification, from an aerodynamic point of view it is possible to use a slightly shorter tailboom with a slightly larger size tail to achieve the same "tail volume" as a longer tailboom and a smaller tail. So for example, you can lay out the drawings of the tail surfaces of a stock Firestar, and measure the square foot area. Multiply this by the distance between the center of that tail area and the center of gravity for the whole airplane. You will get a CUBIC foot dimension (sq ft of area times linear ft of tailboom), which is expressed as "Tail volume". If you shorten the tailboom by 6 inches or a foot you can compensate by enlarging the tails proportionately according to that formula, and you SHOULD THEORETICALLY have the same flight characteristics as you would have with the stock design. It never works out exactly the same, but it will likely not be unsafe or dangerous. There are significant common sense limits to this of course. But the point is that if you want to build a Firestar and your longest tube is 12 feet long, you are not "sunk". Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Tue, 4/12/16, Herb wrote: Subject: Re: Kolb-List: Firestar tail boom length... To: kolb-list(at)matronics.com Date: Tuesday, April 12, 2016, 3:05 PM Herb Thanks Bill I have a bunch of 5 inch tubes that I bought Kolb many years ago... lightly dented or scratched...tubes that they could not sell with a kit...but very serviceable otherwise.. Wish I had bought the whole trailer load...!! Off to measure...:-) Herb On 04/12/2016 04:19 PM, Bill Berle wrote: > > 13 feet on the FireStar 2. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Tue, 4/12/16, Herb wrote: > >Subject: Kolb-List: Firestar tail boom length... >To: kolb-list(at)matronics.com >Date: Tuesday, April 12, 2016, 1:26 PM > >Herb > >Could call Bryan...but someone will know....what is the >length of the >tail boom on the Firestar 1? Probably the same on the >II also?Herb > >Lists This Month -- >Some AWESOME FREE Gifts!) >Raiser. Click on >more about >Gifts provided >www.buildersbooks.com > -Matt >Dralle, List Admin. >Forum - > - MATRONICS WEB FORUMS - >List Contribution Web Site - > -Matt >Dralle, List Admin. > > > > > > > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. Lists This Month -- Some AWESOME FREE Gifts!) Raiser. Click on more about Gifts provided www.buildersbooks.com -Matt Dralle, List Admin. Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 12, 2016
"Greg Taylor" Good video, Christ has pay the prince for our sins, it is by God's Grace that we are Saved. ----------------- What's this have to do with Kolbs? Can I post all of my other non-Kolb stuff here too? ________________________________________________________________________________
Date: Apr 12, 2016
I am a foot and a half short...but the fuselage design will not be the same anyhow...The distance from the tail boom H section bolt to the tail is all that concerns me currently..fromdistance from the bolt forward can be worked around safely...Herb On 04/12/2016 05:55 PM, Bill Berle wrote: > > Herb although it would be a custom, unapproved, unsupported modification, from an aerodynamic point of view it is possible to use a slightly shorter tailboom with a slightly larger size tail to achieve the same "tail volume" as a longer tailboom and a smaller tail. > > So for example, you can lay out the drawings of the tail surfaces of a stock Firestar, and measure the square foot area. Multiply this by the distance between the center of that tail area and the center of gravity for the whole airplane. You will get a CUBIC foot dimension (sq ft of area times linear ft of tailboom), which is expressed as "Tail volume". If you shorten the tailboom by 6 inches or a foot you can compensate by enlarging the tails proportionately according to that formula, and you SHOULD THEORETICALLY have the same flight characteristics as you would have with the stock design. It never works out exactly the same, but it will likely not be unsafe or dangerous. > > There are significant common sense limits to this of course. But the point is that if you want to build a Firestar and your longest tube is 12 feet long, you are not "sunk". > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Tue, 4/12/16, Herb wrote: > > Subject: Re: Kolb-List: Firestar tail boom length... > To: kolb-list(at)matronics.com > Date: Tuesday, April 12, 2016, 3:05 PM > > Herb > > Thanks Bill > > I have a bunch of 5 inch tubes that I > bought Kolb many years ago... > lightly dented or scratched...tubes that they could not sell > with a > kit...but very serviceable otherwise.. Wish I had bought the > whole > trailer load...!! > > Off to measure...:-) Herb > > On 04/12/2016 04:19 PM, Bill Berle wrote: > > > > 13 feet on the FireStar 2. > > > > Bill Berle > > www.ezflaphandle.com - safety & performance > upgrade for light aircraft > > www.grantstar.net > - winning proposals for non-profit and > for-profit entities > > > > -------------------------------------------- > > On Tue, 4/12/16, Herb > wrote: > > > > Subject: Kolb-List: Firestar tail boom > length... > > To: kolb-list(at)matronics.com > > Date: Tuesday, April 12, 2016, 1:26 > PM > > > > Herb > > > > Could call Bryan...but someone will > know....what is the > > length of the > > tail boom on the Firestar 1? > Probably the same on the > > II also? Herb > > > > Lists This Month -- > > Some AWESOME FREE Gifts!) > > Raiser. Click on > > more about > > Gifts provided > > www.buildersbooks.com > > > -Matt > > Dralle, List Admin. > > Forum - > > - MATRONICS WEB FORUMS - > > List Contribution Web Site - > > > -Matt > > Dralle, List Admin. > > > > > > > > > > > > > > > > > > -- > Signature text; Fort Marcy Park? Sure...Mr. > Foster...Third red light and turn left. > > > Lists This Month -- > Some AWESOME FREE Gifts!) > Raiser. Click on > more about > Gifts provided > www.buildersbooks.com > -Matt > Dralle, List Admin. > Forum - > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
Date: Apr 12, 2016
A lot of the guys on the list know each other, either from flyins or cross country stints...so the List Gods tend to tollerate small transgressions from time to time.... the general attitude is one of a bit of tolerance and the list Gods generally say..."go forth and sin no more"! :-) Herb On 04/12/2016 06:01 PM, Bill Berle wrote: > > > "Greg Taylor" > > Good video, Christ has pay the prince for our sins, it is by God's Grace that we are Saved. > ----------------- > > What's this have to do with Kolbs? > > Can I post all of my other non-Kolb stuff here too? > > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
Subject: 447 Head bolt torque...
Date: Apr 12, 2016
Already in trouble with the list Gods...forgot to change the subject line...!! Now...to show how forgetful I am...got an email from the guy who bought my Firefly... I told him to be sure to re torque the cyl head nuts/studs.... I think the correct torque is 195 inch lbs. or 17 ft lbs...that correct? They do loosen up ! considerably... I think I also told him that I would change the cooling fan belt...since we have an unknown with it... Herb On 04/12/2016 07:30 PM, Herb wrote: > > A lot of the guys on the list know each other, either from flyins or > cross country stints...so the List Gods tend to tollerate small > transgressions from time to time.... > > the general attitude is one of a bit of tolerance and the list Gods > generally say..."go forth and sin no more"! :-) Herb > > On 04/12/2016 06:01 PM, Bill Berle wrote: >> >> >> "Greg Taylor" >> Good video, Christ has pay the prince for our sins, it is by >> God's Grace that we are Saved. >> ----------------- >> >> What's this have to do with Kolbs? >> >> Can I post all of my other non-Kolb stuff here too? >> >> >> >> > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
Subject: Building an airplane quickly
Date: Apr 12, 2016
Hi Folks, Lots of discussion recently about building and re-building. Attached is a link to a video about building an aircraft that you may find interesting and encouraging. I think the aircraft being built is fashioned after the Kolb Mark III design, so you may get some ideas for shortcuts if you watch closely. Dave Kulp Bethlehem, PA http://safeyoutube.net/w/ZMo ________________________________________________________________________________
Subject: Re: Building an airplane quickly
Date: Apr 13, 2016
Yep! Like the way the Poly Brush goes on....seems they skimped on the poly spray however..:-) Kolbs built in London....the other London!! Subcontracted assemblies included wing manufacture (Mitsubishi Heavy Industries , Japan, central wing box)^[33] horizontal stabilizers (Alenia Aeronautica , Italy; Korea Aerospace Industries , South Korea);^[34] fuselage sections (Global Aeronautica, Italy; Boeing, North Charleston , US; Kawasaki Heavy Industries , Japan; Spirit AeroSystems , Wichita , US; Korean Air , South Korea);^[35] ^[36] ^[37] passenger doors (Latcore , France); cargo doors, access doors, and crew escape door (Saab AB , Sweden); software development (HCL Enterprise India);^[38] floor beams (TAL Manufacturing Solutions Limited , India);^[39] ^[40] wiring (Labinal , France);^[41] wing-tips, flap support fairings, wheel well bulkhead, and longerons (Korean Air, South Korea);^[42] landing gear (Messier-Bugatti-Dowty , UK/France);^[43] ^[44] and power distribution and management systems, air conditioning packs (Hamilton Sundstrand , Connecticut , US).^[41] ^[45] Boeing is considering bringing construction of the 787-9 tail in house; the tail of the 787-8 is currently made by Alenia.^[46] On 04/12/2016 10:51 PM, David Kulp wrote: > > Hi Folks, > > Lots of discussion recently about building and re-building. Attached > is a link to a video about building an aircraft that you may find > interesting and encouraging. I think the aircraft being built is > fashioned after the Kolb Mark III design, so you may get some ideas > for shortcuts if you watch closely. > > Dave Kulp > Bethlehem, PA > > http://safeyoutube.net/w/ZMo > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
Subject: Re: Fourstar
Date: Apr 13, 2016
What a gruesome looking beast. Pat -----Original Message----- From: Herb Sent: Tuesday, April 12, 2016 7:50 PM Subject: Kolb-List: Fourstar Wondering how many have seen this...? Called the Fourstar...one of a kind...Bill Bronson of the St. Louis area designed and built it using Firestar parts... I have enough parts to build it...and the less than 2 gal an hour consumption of my Global engine is desirable... With my memory...may have sent this before...?? Herb ________________________________________________________________________________
Date: Apr 13, 2016
As you say, the stock boom on the Firestar II is 13 feet long as per the plans. When I built my own Firestar II, I wanted a bit more lively performance, so I clipped the wing tips and shortened the tail boom tube to 12 feet. Prior to doing so, I ran my plan past Dennis; who confessed that his Firestar demonstrator airplane was also shortened one foot. 1.5 feet? I wouldn't worry about it! Just do your W&B with extra care and make sure your CG falls within the acceptable range and not TOO nose heavy when loaded with YOU in the airplane. BYW, If there are any defects in your boom tube, install the problem area toward the AFT end, as all the stress is up front where the tube joins the fuselage structure. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=454945#454945 ________________________________________________________________________________
Date: Apr 13, 2016
1.5 feet? I wouldn't worry about it! Just do your W&B with extra care and make sure your CG falls within the acceptable range and not TOO nose heavy when loaded with YOU in the airplane. -------- Jerry King Jerry K/Kolbers: I shortened the tail boom of my MKIII 1 foot initially. The airplane never wanted to settle down in cruise. Was like trying to fly on a ball. Get it on top for a few seconds, then it would fall off in no predetermined direction. Fortunately, or unfortunately, a CGS wooden prop came apart, think a dual K&N air filter went through it, destroying the shortened tail boom. I replaced it with a standard length boom. Problem solved. My idea was... by shortening the tail boom I could get a better three point stance and STOL performance. It didn't work. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: 447 Head bolt torque...
Date: Apr 13, 2016
Greg, why the mini-sermon?? Thats not KOLB-related! > On Apr 12, 2016, at 9:04 PM, Herb wrote: > > > Already in trouble with the list Gods...forgot to change the subject line...!! > > Now...to show how forgetful I am...got an email from the guy who bought my Firefly... > > I told him to be sure to re torque the cyl head nuts/studs.... I think the correct torque is 195 inch lbs. or 17 ft lbs...that correct? > > They do loosen up ! considerably... > > I think I also told him that I would change the cooling fan belt...since we have an unknown with it... Herb > > On 04/12/2016 07:30 PM, Herb wrote: >> >> A lot of the guys on the list know each other, either from flyins or cross country stints...so the List Gods tend to tollerate small transgressions from time to time.... >> >> the general attitude is one of a bit of tolerance and the list Gods generally say..."go forth and sin no more"! :-) Herb >> >> On 04/12/2016 06:01 PM, Bill Berle wrote: >>> >>> >>> "Greg Taylor" >>> Good video, Christ has pay the prince for our sins, it is by God's Grace that we are Saved. >>> ----------------- >>> >>> What's this have to do with Kolbs? >>> >>> Can I post all of my other non-Kolb stuff here too? >>> >>> >>> >>> >> > > -- > Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. > > > > > ________________________________________________________________________________
Date: Apr 13, 2016
Herb, Have your buddy download the Rotax Two Stroke Illustrated Parts Catalog (IPC). Go to Chapter 10 Torques and he'll find ever screw, bolt, stud, and nut with its part no. and chapter where it can be found, size and thread, and everything else you need to know to properly button up a 447, 503, or 582. Rick Girard On Tue, Apr 12, 2016 at 8:04 PM, Herb wrote: > > Already in trouble with the list Gods...forgot to change the subject > line...!! > > Now...to show how forgetful I am...got an email from the guy who bought > my Firefly... > > I told him to be sure to re torque the cyl head nuts/studs.... I think > the correct torque is 195 inch lbs. or 17 ft lbs...that correct? > > They do loosen up ! considerably... > > I think I also told him that I would change the cooling fan > belt...since we have an unknown with it... Herb > > On 04/12/2016 07:30 PM, Herb wrote: > >> >> A lot of the guys on the list know each other, either from flyins or >> cross country stints...so the List Gods tend to tollerate small >> transgressions from time to time.... >> >> the general attitude is one of a bit of tolerance and the list Gods >> generally say..."go forth and sin no more"! :-) Herb >> >> On 04/12/2016 06:01 PM, Bill Berle wrote: >> >>> >>> >>> "Greg Taylor" >>> Good video, Christ has pay the prince for our sins, it is by God's >>> Grace that we are Saved. >>> ----------------- >>> >>> What's this have to do with Kolbs? >>> >>> Can I post all of my other non-Kolb stuff here too? >>> >>> >>> >>> >>> >> > -- > Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and > turn left. > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Subject: Re: video
Date: Apr 13, 2016
Beautiful video and beautiful country. I am envious. Larry, if you don't mind my asking, what part of the country did you spend your RR welder days on? T K Read this topic online here: http://forums.matronics.com/viewtopic.php?p=454955#454955 ________________________________________________________________________________
Date: Apr 13, 2016
Subject: Re: Last Flight 2005/Alodine/Corrosion Prevention
Alodine works better if its used under an epoxy coating. As I believe the Poly Fiber book recommends. One sure way to get your Kolb wing or tail to corrode whether you alodine or not; don't install drain grommets. Once again, as the Poly Fiber book recommends. Tip on Alodine. It doesn't work forever. Look at the product usage and see how many square feet it will convert and protect. The Alumiprep that Spruce sells is good for 100 sq. ft. of coverage per quart. Sounds like a lot until you consider that a single 4 X 8 sheet of aluminum is 96 square feet (both sides). Years ago a fellow in EAA Chapter 1000 (Edwards Air Force Base) noted that you're paying a hell of a lot for water when you buy premixed alodine. He bought the powder from Henkel Technologies and bought his own distilled water. Unfortunately the minimum purchase size was $100 (early 2000's) but he had enough to do something like 4 RV style aluminum airplanes. On the other hand, if you buy quarts from Spruce you won't even get a gallon of premix for $100. So, buy the gallon for $42 and get 4 times as much for 1.5 times greater price. Or better yet, go to your local auto body materials distributor and avoid the hazardous materials fees for shipping. Rick Girard On Tue, Apr 12, 2016 at 7:00 AM, John Hauck wrote: > > Only thing I Alodine on my MKIII is the engine mounts for the 912. I do > not paint them. Initially, I did paint them and had a problem with lose > engine mount bolts when the primer and paint wore between the two surface s. > > Haven't found it necessary to use a corrosion preventive treatment on > alclad aluminum tubing. > > john h > mkIII > Titus, Alabama > > > Started on the stabilizers of my Firestar kit Saturday, got one side cut, > fitted and Clecoed, and was able to start cutting tubes for the second on e. > Does anyone have a recommendation for or againsit using Alodine chemical > conversion as a no-weight corrosion preventive treatment on the aluminum > tails? > > Bill Berle > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Subject: Last Flight 2005/Alodine/Corrosion Prevention
Date: Apr 13, 2016
Rick G/Kolbers: Anything on my MKIII that could possible hold water gets a drain hole at its lowest point when in its 3 point stance. I tried drain grommets on previous Kolb models, but they turned out to be a pain in the butt. Instead of drain grommets I use 50 cent sized patches and a pencil soldering iron. I make a 3/16" drain hole approximately. Works well for me. One drawback down here in the sunny south is mud daubers. Some of them can get inside the drain holes to build mud nest. I discovered that when I pulled fabric to repair wing and aileron 15 years ago. They are nasty. I have to constantly keep a look out for their nest in places on my engine. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: Wednesday, April 13, 2016 12:29 PM Subject: Re: Kolb-List: Last Flight 2005/Alodine/Corrosion Prevention Alodine works better if its used under an epoxy coating. As I believe the Poly Fiber book recommends. One sure way to get your Kolb wing or tail to corrode whether you alodine or not; don't install drain grommets. Once again, as the Poly Fiber book recommends. Tip on Alodine. It doesn't work forever. Look at the product usage and see how many square feet it will convert and protect. The Alumiprep that Spruce sells is good for 100 sq. ft. of coverage per quart. Sounds like a lot until you consider that a single 4 X 8 sheet of aluminum is 96 square feet (both sides). Years ago a fellow in EAA Chapter 1000 (Edwards Air Force Base) noted that you're paying a hell of a lot for water when you buy premixed alodine. He bought the powder from Henkel Technologies and bought his own distilled water. Unfortunately the minimum purchase size was $100 (early 2000's) but he had enough to do something like 4 RV style aluminum airplanes. On the other hand, if you buy quarts from Spruce you won't even get a gallon of premix for $100. So, buy the gallon for $42 and get 4 times as much for 1.5 times greater price. Or better yet, go to your local auto body materials distributor and avoid the hazardous materials fees for shipping. Rick Girard On Tue, Apr 12, 2016 at 7:00 AM, John Hauck wrote: Only thing I Alodine on my MKIII is the engine mounts for the 912. I do not paint them. Initially, I did paint them and had a problem with lose engine mount bolts when the primer and paint wore between the two surfaces. Haven't found it necessary to use a corrosion preventive treatment on alclad aluminum tubing. john h mkIII Titus, Alabama Started on the stabilizers of my Firestar kit Saturday, got one side cut, fitted and Clecoed, and was able to start cutting tubes for the second one. Does anyone have a recommendation for or againsit using Alodine chemical conversion as a no-weight corrosion preventive treatment on the aluminum tails? Bill Berle br> fts!) r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com rel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - eferrer" target="_blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution -- =9CBlessed are the cracked, for they shall let in the light.=9D <http://www.goodreads.com/author/show/43244.Groucho_Marx> Groucho Marx ________________________________________________________________________________
Date: Apr 13, 2016
John, This is a PBI (partially baked idea). I have used it on an LED porch light and it has been holding the mud daubbers at bay for two years now. I just haven't tried it in this manner. When you do your drain grommets, however your method, make the hole, then cover it with small piece of fiberglass screen and place a patch, with hole, over the top to hold the screen insert. You'll have to take some care to keep the screen from filling up with Poly Tone or whatever your final coat is but at least the wasps won't be in your wings or tail feathers. Wish I could do this to keep the little buggers out of my trike wing. Also, don't forget if you leave the locator hole on your prop hub open they'll get in there, too. Rick On Wed, Apr 13, 2016 at 12:44 PM, John Hauck wrote: > Rick G/Kolbers: > > > Anything on my MKIII that could possible hold water gets a drain hole at > its lowest point when in its 3 point stance. I tried drain grommets on > previous Kolb models, but they turned out to be a pain in the butt. > > > Instead of drain grommets I use 50 cent sized patches and a pencil > soldering iron. I make a 3/16" drain hole approximately. Works well for > me. > > > One drawback down here in the sunny south is mud daubers. Some of them > can get inside the drain holes to build mud nest. I discovered that when I > pulled fabric to repair wing and aileron 15 years ago. They are nasty. > > > I have to constantly keep a look out for their nest in places on my engin e. > > > john h > > mkIII > > Titus, Alabama > > > *From:* owner-kolb-list-server(at)matronics.com [mailto: > owner-kolb-list-server(at)matronics.com] *On Behalf Of *Richard Girard > *Sent:* Wednesday, April 13, 2016 12:29 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: Last Flight 2005/Alodine/Corrosion Prevention > > > Alodine works better if its used under an epoxy coating. As I believe the > Poly Fiber book recommends. > > One sure way to get your Kolb wing or tail to corrode whether you alodine > or not; don't install drain grommets. Once again, as the Poly Fiber book > recommends. > > Tip on Alodine. It doesn't work forever. Look at the product usage and se e > how many square feet it will convert and protect. The Alumiprep that Spru ce > sells is good for 100 sq. ft. of coverage per quart. Sounds like a lot > until you consider that a single 4 X 8 sheet of aluminum is 96 square fee t > (both sides). > > Years ago a fellow in EAA Chapter 1000 (Edwards Air Force Base) noted tha t > you're paying a hell of a lot for water when you buy premixed alodine. He > bought the powder from Henkel Technologies and bought his own distilled > water. Unfortunately the minimum purchase size was $100 (early 2000's) bu t > he had enough to do something like 4 RV style aluminum airplanes. On the > other hand, if you buy quarts from Spruce you won't even get a gallon of > premix for $100. > > So, buy the gallon for $42 and get 4 times as much for 1.5 times greater > price. Or better yet, go to your local auto body materials distributor an d > avoid the hazardous materials fees for shipping. > > > Rick Girard > > > On Tue, Apr 12, 2016 at 7:00 AM, John Hauck wrote: > > > Only thing I Alodine on my MKIII is the engine mounts for the 912. I do > not paint them. Initially, I did paint them and had a problem with lose > engine mount bolts when the primer and paint wore between the two surface s. > > Haven't found it necessary to use a corrosion preventive treatment on > alclad aluminum tubing. > > john h > mkIII > Titus, Alabama > > > Started on the stabilizers of my Firestar kit Saturday, got one side cut, > fitted and Clecoed, and was able to start cutting tubes for the second on e. > Does anyone have a recommendation for or againsit using Alodine chemical > conversion as a no-weight corrosion preventive treatment on the aluminum > tails? > > Bill Berle > > > ========== > br> fts!) > r> > w.buildersbooks.com" rel="noreferrer" target="_blank"> > www.buildersbooks.com > rel="noreferrer" target="_blank">http://www.matronics.com/contributio n > -Matt Dralle, List Admin. > ========== > -List" rel="noreferrer" target="_blank"> > http://www.matronics.com/Navigator?Kolb-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contributio n > ========== > > > -- > =9CBlessed are the cracked, for they shall let in the light. =9D Groucho Marx > <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Apr 13, 2016
Has anyone tried small pieces of window screen to cover the drain holes? Regular back door window screen could be cut into little patches and glued over the hole in the fabric at the drain location. Seems to me like it would keep the mud daubers out, let the moisture drain out, and allow air circulation. But we don't have those little critters here as bad as they do in the south so it's not something we have to deal with here as much. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Wed, 4/13/16, John Hauck wrote: Subject: RE: Kolb-List: Last Flight 2005/Alodine/Corrosion Prevention To: kolb-list(at)matronics.com Date: Wednesday, April 13, 2016, 10:44 AM #yiv3134528233 #yiv3134528233 -- _filtered #yiv3134528233 {panose-1:2 4 5 3 5 4 6 3 2 4;} _filtered #yiv3134528233 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #yiv3134528233 {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #yiv3134528233 {font-family:Georgia;panose-1:2 4 5 2 5 4 5 2 3 3;} #yiv3134528233 #yiv3134528233 p.yiv3134528233MsoNormal, #yiv3134528233 li.yiv3134528233MsoNormal, #yiv3134528233 div.yiv3134528233MsoNormal {margin:0in;margin-bottom:.0001pt;font-size:12.0pt;} #yiv3134528233 h1 {margin-right:0in;margin-left:0in;font-size:24.0pt;} #yiv3134528233 a:link, #yiv3134528233 span.yiv3134528233MsoHyperlink {color:blue;text-decoration:underline;} #yiv3134528233 a:visited, #yiv3134528233 span.yiv3134528233MsoHyperlinkFollowed {color:purple;text-decoration:underline;} #yiv3134528233 span.yiv3134528233Heading1Char {color:#365F91;font-weight:bold;} #yiv3134528233 span.yiv3134528233EmailStyle18 {color:#1F497D;} #yiv3134528233 .yiv3134528233MsoChpDefault {} _filtered #yiv3134528233 {margin:1.0in 1.0in 1.0in 1.0in;} #yiv3134528233 div.yiv3134528233WordSection1 {} #yiv3134528233 Rick G/Kolbers: Anything on my MKIII that could possible hold water gets a drain hole at its lowest point when in its 3 point stance. I tried drain grommets on previous Kolb models, but they turned out to be a pain in the butt. Instead of drain grommets I use 50 cent sized patches and a pencil soldering iron. I make a 3/16" drain hole approximately. Works well for me. One drawback down here in the sunny south is mud daubers. Some of them can get inside the drain holes to build mud nest. I discovered that when I pulled fabric to repair wing and aileron 15 years ago. They are nasty. I have to constantly keep a look out for their nest in places on my engine. john hmkIIITitus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: Wednesday, April 13, 2016 12:29 PM To: kolb-list(at)matronics.com Subject: Re: Kolb-List: Last Flight 2005/Alodine/Corrosion Prevention Alodine works better if its used under an epoxy coating. As I believe the Poly Fiber book recommends.One sure way to get your Kolb wing or tail to corrode whether you alodine or not; don't install drain grommets. Once again, as the Poly Fiber book recommends.Tip on Alodine. It doesn't work forever. Look at the product usage and see how many square feet it will convert and protect. The Alumiprep that Spruce sells is good for 100 sq. ft. of coverage per quart. Sounds like a lot until you consider that a single 4 X 8 sheet of aluminum is 96 square feet (both sides).Years ago a fellow in EAA Chapter 1000 (Edwards Air Force Base) noted that you're paying a hell of a lot for water when you buy premixed alodine. He bought the powder from Henkel Technologies and bought his own distilled water. Unfortunately the minimum purchase size was $100 (early 2000's) but he had enough to do something like 4 RV style aluminum airplanes. On the other hand, if you buy quarts from Spruce you won't even get a gallon of premix for $100.So, buy the gallon for $42 and get 4 times as much for 1.5 times greater price. Or better yet, go to your local auto body materials distributor and avoid the hazardous materials fees for shipping. Rick Girard On Tue, Apr 12, 2016 at 7:00 AM, John Hauck wrote:--> Kolb-List message posted by: "John Hauck" Only thing I Alodine on my MKIII is the engine mounts for the 912. I do not paint them. Initially, I did paint them and had a problem with lose engine mount bolts when the primer and paint wore between the two surfaces. Haven't found it necessary to use a corrosion preventive treatment on alclad aluminum tubing. john h mkIII Titus, Alabama Started on the stabilizers of my Firestar kit Saturday, got one side cut, fitted and Clecoed, and was able to start cutting tubes for the second one. Does anyone have a recommendation for or againsit using Alodine chemical conversion as a no-weight corrosion preventive treatment on the aluminum tails? Bill Berle ========== br> fts!) r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com rel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. ========== -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List ========== FORUMS - eferrer" target="_blank">http://forums.matronics.com ========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ========== -- Blessed are the cracked, for they shall let in the light. Groucho Marx ________________________________________________________________________________
Date: Apr 13, 2016
The crush plate and spinner keep bugs out of the centering hole. Open holes in the back of the prop flange get a little dab of silicone seal, because the mud daubers homesteaded there. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: Wednesday, April 13, 2016 1:17 PM Subject: Re: Kolb-List: Last Flight 2005/Alodine/Corrosion Prevention John, This is a PBI (partially baked idea). I have used it on an LED porch light and it has been holding the mud daubbers at bay for two years now. I just haven't tried it in this manner. When you do your drain grommets, however your method, make the hole, then cover it with small piece of fiberglass screen and place a patch, with hole, over the top to hold the screen insert. You'll have to take some care to keep the screen from filling up with Poly Tone or whatever your final coat is but at least the wasps won't be in your wings or tail feathers. Wish I could do this to keep the little buggers out of my trike wing. Also, don't forget if you leave the locator hole on your prop hub open they'll get in there, too. Rick On Wed, Apr 13, 2016 at 12:44 PM, John Hauck wrote: Rick G/Kolbers: Anything on my MKIII that could possible hold water gets a drain hole at its lowest point when in its 3 point stance. I tried drain grommets on previous Kolb models, but they turned out to be a pain in the butt. Instead of drain grommets I use 50 cent sized patches and a pencil soldering iron. I make a 3/16" drain hole approximately. Works well for me. One drawback down here in the sunny south is mud daubers. Some of them can get inside the drain holes to build mud nest. I discovered that when I pulled fabric to repair wing and aileron 15 years ago. They are nasty. I have to constantly keep a look out for their nest in places on my engine. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: Wednesday, April 13, 2016 12:29 PM Subject: Re: Kolb-List: Last Flight 2005/Alodine/Corrosion Prevention Alodine works better if its used under an epoxy coating. As I believe the Poly Fiber book recommends. One sure way to get your Kolb wing or tail to corrode whether you alodine or not; don't install drain grommets. Once again, as the Poly Fiber book recommends. Tip on Alodine. It doesn't work forever. Look at the product usage and see how many square feet it will convert and protect. The Alumiprep that Spruce sells is good for 100 sq. ft. of coverage per quart. Sounds like a lot until you consider that a single 4 X 8 sheet of aluminum is 96 square feet (both sides). Years ago a fellow in EAA Chapter 1000 (Edwards Air Force Base) noted that you're paying a hell of a lot for water when you buy premixed alodine. He bought the powder from Henkel Technologies and bought his own distilled water. Unfortunately the minimum purchase size was $100 (early 2000's) but he had enough to do something like 4 RV style aluminum airplanes. On the other hand, if you buy quarts from Spruce you won't even get a gallon of premix for $100. So, buy the gallon for $42 and get 4 times as much for 1.5 times greater price. Or better yet, go to your local auto body materials distributor and avoid the hazardous materials fees for shipping. Rick Girard On Tue, Apr 12, 2016 at 7:00 AM, John Hauck wrote: Only thing I Alodine on my MKIII is the engine mounts for the 912. I do not paint them. Initially, I did paint them and had a problem with lose engine mount bolts when the primer and paint wore between the two surfaces. Haven't found it necessary to use a corrosion preventive treatment on alclad aluminum tubing. john h mkIII Titus, Alabama Started on the stabilizers of my Firestar kit Saturday, got one side cut, fitted and Clecoed, and was able to start cutting tubes for the second one. Does anyone have a recommendation for or againsit using Alodine chemical conversion as a no-weight corrosion preventive treatment on the aluminum tails? Bill Berle br> fts!) r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com rel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - eferrer" target="_blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution -- =9CBlessed are the cracked, for they shall let in the light.=9D <http://www.goodreads.com/author/show/43244.Groucho_Marx> Groucho Marx -- =9CBlessed are the cracked, for they shall let in the light.=9D <http://www.goodreads.com/author/show/43244.Groucho_Marx> Groucho Marx ________________________________________________________________________________
Date: Apr 13, 2016
Just saw Richard's post similar to my idea... great minds think alike I guess :) You would not need to install the screen during the covering process and spend all the effort to prevent it from getting filled up with Poly-Brush etc. Make a 3/4" round patch with a 1/2" hole in the center. Make the patch out of thin ABS plastic, same as some seaplane grommets. You can probably find pre-cut plastic washers or shims somewhere that are the right size. Cut small circles of window screen that are just UNDER 3/4" diameter. Glue the screen over this hole. You can even paint them now if you know the color of the airplane. Set the patches aside until the airplane is all covered. Then cut the hole with the soldering iron or knife or whatever. Then glue the patches on using Poly-Tak with the screen sandwiched between the patch and the fabric. It will take a couple of hours to make up a dozen of the drain patches, but it will prevent the little critters from damaging your aircraft. Speaking of mud daubers, they LOVE to get into your pitot tube and leave you with no airspeed indication. This is easy to solve, get a short piece of rubber tubing that slips over your pitot tube, and wrap a little piece of window screen material over one end of the rubber, then Ty-Rap (zip-tie) the screen onto the tube. Also make sure you capture a little orange or red streamer, ribbon, etc. with the zip tie as a "remove before flight" warning. Apply some glue (RTV, Shoe-Goo) to stick it all down around the rubber tube,m leaving the screen on the tip of the rubber to allow the pitot tube to "breathe" so your airspeed indicator does not get damaged by moisture or pressure. After the glue dries trim off the excess screen, and you have a safe way to prevent bugs and muyd from getting into the pitot. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Wed, 4/13/16, Richard Girard wrote: Subject: Re: Kolb-List: Last Flight 2005/Alodine/Corrosion Prevention To: "kolb-list(at)matronics.com" Date: Wednesday, April 13, 2016, 11:17 AM John, This is a PBI (partially baked idea). I have used it on an LED porch light and it has been holding the mud daubbers at bay for two years now. I just haven't tried it in this manner.When you do your drain grommets, however your method, make the hole, then cover it with small piece of fiberglass screen and place a patch, with hole, over the top to hold the screen insert. You'll have to take some care to keep the screen from filling up with Poly Tone or whatever your final coat is but at least the wasps won't be in your wings or tail feathers.Wish I could do this to keep the little buggers out of my trike wing.Also, don't forget if you leave the locator hole on your prop hub open they'll get in there, too. Rick On Wed, Apr 13, 2016 at 12:44 PM, John Hauck wrote: Rick G/Kolbers:Anything on my MKIII that could possible hold water gets a drain hole at its lowest point when in its 3 point stance. I tried drain grommets on previous Kolb models, but they turned out to be a pain in the butt.Instead of drain grommets I use 50 cent sized patches and a pencil soldering iron. I make a 3/16" drain hole approximately. Works well for me.One drawback down here in the sunny south is mud daubers. Some of them can get inside the drain holes to build mud nest. I discovered that when I pulled fabric to repair wing and aileron 15 years ago. They are nasty.I have to constantly keep a look out for their nest in places on my engine.john hmkIIITitus, AlabamaFrom: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: Wednesday, April 13, 2016 12:29 PM To: kolb-list(at)matronics.com Subject: Re: Kolb-List: Last Flight 2005/Alodine/Corrosion PreventionAlodine works better if its used under an epoxy coating. As I believe the Poly Fiber book recommends.One sure way to get your Kolb wing or tail to corrode whether you alodine or not; don't install drain grommets. Once again, as the Poly Fiber book recommends.Tip on Alodine. It doesn't work forever. Look at the product usage and see how many square feet it will convert and protect. The Alumiprep that Spruce sells is good for 100 sq. ft. of coverage per quart. Sounds like a lot until you consider that a single 4 X 8 sheet of aluminum is 96 square feet (both sides).Years ago a fellow in EAA Chapter 1000 (Edwards Air Force Base) noted that you're paying a hell of a lot for water when you buy premixed alodine. He bought the powder from Henkel Technologies and bought his own distilled water. Unfortunately the minimum purchase size was $100 (early 2000's) but he had enough to do something like 4 RV style aluminum airplanes. On the other hand, if you buy quarts from Spruce you won't even get a gallon of premix for $100.So, buy the gallon for $42 and get 4 times as much for 1.5 times greater price. Or better yet, go to your local auto body materials distributor and avoid the hazardous materials fees for shipping.Rick GirardOn Tue, Apr 12, 2016 at 7:00 AM, John Hauck "John Hauck" Only thing I Alodine on my MKIII is the engine mounts for the 912. I do not paint them. Initially, I did paint them and had a problem with lose engine mount bolts when the primer and paint wore between the two surfaces. Haven't found it necessary to use a corrosion preventive treatment on alclad aluminum tubing. john h mkIII Titus, Alabama Started on the stabilizers of my Firestar kit Saturday, got one side cut, fitted and Clecoed, and was able to start cutting tubes for the second one. Does anyone have a recommendation for or againsit using Alodine chemical conversion as a no-weight corrosion preventive treatment on the aluminum tails? Bill Berle ========== br> fts!) r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com rel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. ========== -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List ========== FORUMS - eferrer" target="_blank">http://forums.matronics.com ========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ========== -- Blessed are the cracked, for they shall let in the light. Groucho Marx -- Blessed are the cracked, for they shall let in the light. Groucho Marx ________________________________________________________________________________
Subject: : Kolb-List:Corrosion Prevention/drain holes
Date: Apr 13, 2016
John, Interesting about mud daubers. We have them in ND but not too much of a problem. Occasionally find a nest or two in a dark corner of a garage or barn. Maybe because it has been too dry to make mud the last few years. J Sometimes leaf cutter bees can be a problem but again is fairly rare around here. Mice are much more of a threat to all airplanes (and everything else you value). Once a rabbit ate all the ignition wires and some of the wire harness in various places on a company van, but that is another story Drain holes. Usually I would agree that they need to be installed and have followed the plans/FAR=99s on other aircraft I have done. However, for my Firefly I chose to leave them off. At least for now. I did put two holes in the lower outside corners of the fuselage bottom fabric. I used the patch and melt method, quick and easy. In my case the wings and tail surfaces are completely sealed up. The only moisture that can get in would be whatever water vapor could migrate through the fabric and then condense out with temperature changes. That will change as soon as I cut out the inspection holes for the wings. Some (but not all) inspection covers have small vents cut in them that should be sufficient to take care of natural condensation. But other than when I am flying, Serenity sits in a hangar with the wings and tail folded. Having holes at the trailing edge sure won=99t help in that situation. The good side is that small patches and holes are very easy to install in the future because of the Poly Fiber products. Did you put drain holes in the tail and control surfaces? From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck Sent: Wednesday, April 13, 2016 12:44 PM Subject: RE: Kolb-List: Last Flight 2005/Alodine/Corrosion Prevention Rick G/Kolbers: Anything on my MKIII that could possible hold water gets a drain hole at its lowest point when in its 3 point stance. I tried drain grommets on previous Kolb models, but they turned out to be a pain in the butt. Instead of drain grommets I use 50 cent sized patches and a pencil soldering iron. I make a 3/16" drain hole approximately. Works well for me. One drawback down here in the sunny south is mud daubers. Some of them can get inside the drain holes to build mud nest. I discovered that when I pulled fabric to repair wing and aileron 15 years ago. They are nasty. I have to constantly keep a look out for their nest in places on my engine. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Apr 13, 2016
I put drain holes in everything that could collect water. Each rib bay in wings, ailerons, flaps, horizontal stabilizers, elevators, upper and lower vertical stabilizers, and rudder. In my earlier years of flying cross country I experienced considerable rain in flight and while tied down outside. Down here in the SE the humidity is high and some mornings, like a couple recent ones at Lakeland, the MKIII was drenched with dew, inside and out. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Stuart Harner Sent: Wednesday, April 13, 2016 1:54 PM Subject: RE: Kolb-List:Corrosion Prevention/drain holes John, Interesting about mud daubers. We have them in ND but not too much of a problem. Occasionally find a nest or two in a dark corner of a garage or barn. Maybe because it has been too dry to make mud the last few years. J Sometimes leaf cutter bees can be a problem but again is fairly rare around here. Mice are much more of a threat to all airplanes (and everything else you value). Once a rabbit ate all the ignition wires and some of the wire harness in various places on a company van, but that is another story Drain holes. Usually I would agree that they need to be installed and have followed the plans/FAR=99s on other aircraft I have done. However, for my Firefly I chose to leave them off. At least for now. I did put two holes in the lower outside corners of the fuselage bottom fabric. I used the patch and melt method, quick and easy. In my case the wings and tail surfaces are completely sealed up. The only moisture that can get in would be whatever water vapor could migrate through the fabric and then condense out with temperature changes. That will change as soon as I cut out the inspection holes for the wings. Some (but not all) inspection covers have small vents cut in them that should be sufficient to take care of natural condensation. But other than when I am flying, Serenity sits in a hangar with the wings and tail folded. Having holes at the trailing edge sure won=99t help in that situation. The good side is that small patches and holes are very easy to install in the future because of the Poly Fiber products. Did you put drain holes in the tail and control surfaces? ________________________________________________________________________________
Date: Apr 13, 2016
Just to avoid any confusion, alumiprep is needed, but it ain't alodine. Alumiprep is the acid etch used *after* cleaning off all the oils/contaminates, and prior to the alodine process. Alumiprep strips off the oxide layer that's on all untreated aluminum, so the alodine can work on the alloy itself. Small parts can be dipped in the alumiprep, meaning it can be re-used multiple times before it loses its effectiveness. Same applies to alodine, but don't use it outdoors or where sunlight can hit it; sunlight (UV?) degrades it fairly quickly. Good tip on the powder. Even the powder triggers hazmat fees even though it's non-toxic when dry, but still *much* cheaper if you mix yourself. Ask for Iridite powder if you can buy local. Best tip I ever heard was to mix a large batch in a plastic drum or even a black plastic garbage can, if you can seal it up when not in use. If kept away from light, it will remain active for a long time, and timed 'dipping' is a lot easier & more effective than trying to flow it, or mop it on with sponges or rags. Toughest thing to do with large surfaces is keep the entire surface wet (with either chemical) until the 'exposure time' has run and you rinse it off with clean water. One trick is to build a trough with plastic sheet suspended behind/above it, so runoff goes in the trough for re-use. A cheap fountain pump from Harbor Freight rigged to recycle fluid from the trough might last long enough to do the big stuff. Don't forget, both are highly toxic, so use carefully. Full strength alumiprep will eat your concrete floor (I can testify). Alumiprep is a Chromate product, and Chromates are banned in a lot of states due to toxicity. No reason to be terrified of them, but you do need to respect them (eye protection, good gloves, etc). Charlie On Wed, Apr 13, 2016 at 12:29 PM, Richard Girard wrote: > Alodine works better if its used under an epoxy coating. As I believe the > Poly Fiber book recommends. > One sure way to get your Kolb wing or tail to corrode whether you alodine > or not; don't install drain grommets. Once again, as the Poly Fiber book > recommends. > Tip on Alodine. It doesn't work forever. Look at the product usage and see > how many square feet it will convert and protect. The Alumiprep that Spruce > sells is good for 100 sq. ft. of coverage per quart. Sounds like a lot > until you consider that a single 4 X 8 sheet of aluminum is 96 square feet > (both sides). > Years ago a fellow in EAA Chapter 1000 (Edwards Air Force Base) noted that > you're paying a hell of a lot for water when you buy premixed alodine. He > bought the powder from Henkel Technologies and bought his own distilled > water. Unfortunately the minimum purchase size was $100 (early 2000's) but > he had enough to do something like 4 RV style aluminum airplanes. On the > other hand, if you buy quarts from Spruce you won't even get a gallon of > premix for $100. > So, buy the gallon for $42 and get 4 times as much for 1.5 times greater > price. Or better yet, go to your local auto body materials distributor and > avoid the hazardous materials fees for shipping. > > Rick Girard > > On Tue, Apr 12, 2016 at 7:00 AM, John Hauck wrote: > >> >> Only thing I Alodine on my MKIII is the engine mounts for the 912. I do >> not paint them. Initially, I did paint them and had a problem with lose >> engine mount bolts when the primer and paint wore between the two surfaces. >> >> Haven't found it necessary to use a corrosion preventive treatment on >> alclad aluminum tubing. >> >> john h >> mkIII >> Titus, Alabama >> >> >> >> Started on the stabilizers of my Firestar kit Saturday, got one side cut, >> fitted and Clecoed, and was able to start cutting tubes for the second one. >> Does anyone have a recommendation for or againsit using Alodine chemical >> conversion as a no-weight corrosion preventive treatment on the aluminum >> tails? >> >> Bill Berle >> > ________________________________________________________________________________
Date: Apr 13, 2016
Never tried this with fabric, but a common trick in aluminum skin drain holes is to bend up a piece of stainless safety wire so it has a bit of a T shape or horizontal spiral on top, and enough of a zigzag or horizontal spiral on the bottom to keep it from going up through the hole. Vibration while flying makes it 'dance' a bit in the hole. This keeps any dirt/grit from clogging the hole, and will keep insects out, as well. Similar trick, except an inverted J shape, can be used in fuel vents, etc. Minimum airflow blockage, but breaks up the hole enough that mud daubers aren't interested. The crook at the bottom (top) is cut/bent to work like a fish hook when inserted into the tubing. Or just drill through the tubing twice at right angles and cross the opening with an X of safety wire. Obviously, this won't be as effective if you're using 3/8" or larger tubing, without some extra effort. I've used 'proseal' (fuel tank sealant) to 'glue' small sections of aluminum window screen over the -4 A/N fittings (fuel tank vents) on my RV-4 & the -7 I'm building. Charlie On Wed, Apr 13, 2016 at 1:42 PM, John Hauck wrote: > The crush plate and spinner keep bugs out of the centering hole. Open > holes in the back of the prop flange get a little dab of silicone seal, > because the mud daubers homesteaded there. > > > john h > > mkIII > > Titus, Alabama > > > *From:* owner-kolb-list-server(at)matronics.com [mailto: > owner-kolb-list-server(at)matronics.com] *On Behalf Of *Richard Girard > *Sent:* Wednesday, April 13, 2016 1:17 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: Last Flight 2005/Alodine/Corrosion Prevention > > > John, This is a PBI (partially baked idea). I have used it on an LED porc h > light and it has been holding the mud daubbers at bay for two years now. I > just haven't tried it in this manner. > > When you do your drain grommets, however your method, make the hole, then > cover it with small piece of fiberglass screen and place a patch, with > hole, over the top to hold the screen insert. You'll have to take some ca re > to keep the screen from filling up with Poly Tone or whatever your final > coat is but at least the wasps won't be in your wings or tail feathers. > > Wish I could do this to keep the little buggers out of my trike wing. > > Also, don't forget if you leave the locator hole on your prop hub open > they'll get in there, too. > > > Rick > > > On Wed, Apr 13, 2016 at 12:44 PM, John Hauck wrote : > > Rick G/Kolbers: > > > Anything on my MKIII that could possible hold water gets a drain hole at > its lowest point when in its 3 point stance. I tried drain grommets on > previous Kolb models, but they turned out to be a pain in the butt. > > > Instead of drain grommets I use 50 cent sized patches and a pencil > soldering iron. I make a 3/16" drain hole approximately. Works well for > me. > > > One drawback down here in the sunny south is mud daubers. Some of them > can get inside the drain holes to build mud nest. I discovered that when I > pulled fabric to repair wing and aileron 15 years ago. They are nasty. > > > I have to constantly keep a look out for their nest in places on my engin e. > > > john h > > mkIII > > Titus, Alabama > > > *From:* owner-kolb-list-server(at)matronics.com [mailto: > owner-kolb-list-server(at)matronics.com] *On Behalf Of *Richard Girard > *Sent:* Wednesday, April 13, 2016 12:29 PM > *To:* kolb-list(at)matronics.com > *Subject:* Re: Kolb-List: Last Flight 2005/Alodine/Corrosion Prevention > > > Alodine works better if its used under an epoxy coating. As I believe the > Poly Fiber book recommends. > > One sure way to get your Kolb wing or tail to corrode whether you alodine > or not; don't install drain grommets. Once again, as the Poly Fiber book > recommends. > > Tip on Alodine. It doesn't work forever. Look at the product usage and se e > how many square feet it will convert and protect. The Alumiprep that Spru ce > sells is good for 100 sq. ft. of coverage per quart. Sounds like a lot > until you consider that a single 4 X 8 sheet of aluminum is 96 square fee t > (both sides). > > Years ago a fellow in EAA Chapter 1000 (Edwards Air Force Base) noted tha t > you're paying a hell of a lot for water when you buy premixed alodine. He > bought the powder from Henkel Technologies and bought his own distilled > water. Unfortunately the minimum purchase size was $100 (early 2000's) bu t > he had enough to do something like 4 RV style aluminum airplanes. On the > other hand, if you buy quarts from Spruce you won't even get a gallon of > premix for $100. > > So, buy the gallon for $42 and get 4 times as much for 1.5 times greater > price. Or better yet, go to your local auto body materials distributor an d > avoid the hazardous materials fees for shipping. > > > Rick Girard > > > On Tue, Apr 12, 2016 at 7:00 AM, John Hauck wrote: > > > Only thing I Alodine on my MKIII is the engine mounts for the 912. I do > not paint them. Initially, I did paint them and had a problem with lose > engine mount bolts when the primer and paint wore between the two surface s. > > Haven't found it necessary to use a corrosion preventive treatment on > alclad aluminum tubing. > > john h > mkIII > Titus, Alabama > > > Started on the stabilizers of my Firestar kit Saturday, got one side cut, > fitted and Clecoed, and was able to start cutting tubes for the second on e. > Does anyone have a recommendation for or againsit using Alodine chemical > conversion as a no-weight corrosion preventive treatment on the aluminum > tails? > > Bill Berle > > > ========== > br> fts!) > r> > w.buildersbooks.com" rel="noreferrer" target="_blank"> > www.buildersbooks.com > rel="noreferrer" target="_blank">http://www.matronics.com/contributio n > -Matt Dralle, List Admin. > ========== > -List" rel="noreferrer" target="_blank"> > http://www.matronics.com/Navigator?Kolb-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contributio n > ========== > > > -- > =9CBlessed are the cracked, for they shall let in the light. =9D Groucho Marx > <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > > -- > =9CBlessed are the cracked, for they shall let in the light. =9D Groucho Marx > <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > ________________________________________________________________________________
Date: Apr 13, 2016
Dirt might not be an issue in an elevator or even a wing, but I can testify that dirt will clog even an open 1/8" hole in the bottom of a fuselage. I once drained ~5 gallons of water from the tailcone of the Luscombe I was learning to fly in. And that was *after* I'd taken off, flown a few T&Gs, & discovered that I had to hold forward stick to flair for landing. (Water was moving aft, over the bulkheads, after each takeoff. Dirt will likely clog screen very quickly, unless you operate and store the plane in a dust free environment. On my RV-4, I use one of the relatively inexpensive 'flapper' style pitot covers. Weight closes it when at rest, and dynamic air pressure opens it automatically when I start the takeoff roll. I always forget, and it never matters. :-) Charlie On Wed, Apr 13, 2016 at 1:54 PM, Bill Berle wrote: > > Just saw Richard's post similar to my idea... great minds think alike I > guess :) > > You would not need to install the screen during the covering process and > spend all the effort to prevent it from getting filled up with Poly-Brush > etc. > > Make a 3/4" round patch with a 1/2" hole in the center. Make the patch ou t > of thin ABS plastic, same as some seaplane grommets. You can probably fin d > pre-cut plastic washers or shims somewhere that are the right size. Cut > small circles of window screen that are just UNDER 3/4" diameter. Glue th e > screen over this hole. You can even paint them now if you know the color of > the airplane. Set the patches aside until the airplane is all covered. Th en > cut the hole with the soldering iron or knife or whatever. Then glue the > patches on using Poly-Tak with the screen sandwiched between the patch an d > the fabric. > > It will take a couple of hours to make up a dozen of the drain patches, > but it will prevent the little critters from damaging your aircraft. > > Speaking of mud daubers, they LOVE to get into your pitot tube and leave > you with no airspeed indication. This is easy to solve, get a short piece > of rubber tubing that slips over your pitot tube, and wrap a little piece > of window screen material over one end of the rubber, then Ty-Rap (zip-ti e) > the screen onto the tube. Also make sure you capture a little orange or r ed > streamer, ribbon, etc. with the zip tie as a "remove before flight" > warning. Apply some glue (RTV, Shoe-Goo) to stick it all down around the > rubber tube,m leaving the screen on the tip of the rubber to allow the > pitot tube to "breathe" so your airspeed indicator does not get damaged b y > moisture or pressure. After the glue dries trim off the excess screen, an d > you have a safe way to prevent bugs and muyd from getting into the pitot. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and > for-profit entities > > -------------------------------------------- > On Wed, 4/13/16, Richard Girard wrote: > > Subject: Re: Kolb-List: Last Flight 2005/Alodine/Corrosion Prevention > To: "kolb-list(at)matronics.com" > Date: Wednesday, April 13, 2016, 11:17 AM > > John, This > is a PBI (partially baked idea). I have used it on an LED > porch light and it has been holding the mud daubbers at bay > for two years now. I just haven't tried it in this > manner.When you do your drain grommets, however your > method, make the hole, then cover it with small piece of > fiberglass screen and place a patch, with hole, over the top > to hold the screen insert. You'll have to take some care > to keep the screen from filling up with Poly Tone or > whatever your final coat is but at least the wasps won't > be in your wings or tail feathers.Wish I could do > this to keep the little buggers out of my trike > wing.Also, don't forget if you leave the > locator hole on your prop hub open they'll get in there, > too. > Rick > On Wed, Apr 13, 2016 at > 12:44 PM, John Hauck > wrote: > Rick > G/Kolbers: Anything on my MKIII that could > possible hold water gets a drain hole at its lowest point > when in its 3 point stance. I tried drain grommets on > previous Kolb models, but they turned out to be a pain in > the butt. Instead of drain grommets I use 50 > cent sized patches and a pencil soldering iron. I make a > 3/16" drain hole approximately. Works well for > me. One drawback down here in the > sunny south is mud daubers. Some of them can get inside > the drain holes to build mud nest. I discovered that when > I pulled fabric to repair wing and aileron 15 years ago. > They are nasty. I have to constantly keep a look > out for their nest in places on my > engine. john hmkIIITitus, > Alabama From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] > On Behalf Of Richard Girard > Sent: Wednesday, April 13, 2016 12:29 > PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Last Flight > 2005/Alodine/Corrosion > Prevention Alodine works better if its > used under an epoxy coating. As I believe the Poly Fiber > book recommends.One sure way to get your Kolb > wing or tail to corrode whether you alodine or not; > don't install drain grommets. Once again, as the Poly > Fiber book recommends.Tip on Alodine. It > doesn't work forever. Look at the product usage and see > how many square feet it will convert and protect. The > Alumiprep that Spruce sells is good for 100 sq. ft. of > coverage per quart. Sounds like a lot until you consider > that a single 4 X 8 sheet of aluminum is 96 square feet > (both sides). Years ago a fellow in EAA > Chapter 1000 (Edwards Air Force Base) noted that you're > paying a hell of a lot for water when you buy premixed > alodine. He bought the powder from Henkel Technologies and > bought his own distilled water. Unfortunately the minimum > purchase size was $100 (early 2000's) but he had enough > to do something like 4 RV style aluminum airplanes. On the > other hand, if you buy quarts from Spruce you won't even > get a gallon of premix for > $100. So, buy the gallon for $42 > and get 4 times as much for 1.5 times greater price. Or > better yet, go to your local auto body materials distributor > and avoid the hazardous materials fees for > shipping. Rick > Girard On Tue, Apr 12, 2016 at 7:00 > AM, John Hauck > "John Hauck" > > Only thing I Alodine on my > MKIII is the engine mounts for the 912. I do not paint > them. Initially, I did paint them and had a problem with > lose engine mount bolts when the primer and paint wore > between the two surfaces. > > Haven't found it necessary to use a > corrosion preventive treatment on alclad aluminum tubing. > > john h > mkIII > Titus, Alabama > > > Started on the stabilizers of my Firestar kit > Saturday, got one side cut, fitted and Clecoed, and was able > to start cutting tubes for the second one. Does anyone have > a recommendation for or againsit using Alodine chemical > conversion as a no-weight corrosion preventive treatment on > the aluminum tails? > > Bill > Berle > > > ========== > br> > fts!) > r> > w.buildersbooks.com" > rel="noreferrer" target="_blank">www.buildersbooks.com > rel="noreferrer" > target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > ========== > -List" > rel="noreferrer" target="_blank"> > http://www.matronics.com/Navigator?Kolb-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" > target="_blank">http://www.matronics.com/contribution > ========== > > > -- > =9CBlessed are the cracked, for > they shall let in the light.=9D Groucho > Marx > > > -- > > =9CBlessed are > the cracked, for they shall let in the light.=9D Groucho > Marx > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Apr 13, 2016
Good advice Charlie! If I decide to use Alodine on my Kolb project, I figured I could cut a piece of 6 or 8 inch plastic pipe (with caps on the ends) in half lengthwise, and have two troughs for the Alumiprep and Alodine. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Wed, 4/13/16, Charlie England wrote: Subject: Re: Kolb-List: Last Flight 2005/Alodine/Corrosion Prevention To: kolb-list(at)matronics.com Date: Wednesday, April 13, 2016, 1:29 PM Just to avoid any confusion, alumiprep is needed, but it ain't alodine. Alumiprep is the acid etch used *after* cleaning off all the oils/contaminates, and prior to the alodine process. Alumiprep strips off the oxide layer that's on all untreated aluminum, so the alodine can work on the alloy itself. Small parts can be dipped in the alumiprep, meaning it can be re-used multiple times before it loses its effectiveness. Same applies to alodine, but don't use it outdoors or where sunlight can hit it; sunlight (UV?) degrades it fairly quickly. Good tip on the powder. Even the powder triggers hazmat fees even though it's non-toxic when dry, but still *much* cheaper if you mix yourself. Ask for Iridite powder if you can buy local. Best tip I ever heard was to mix a large batch in a plastic drum or even a black plastic garbage can, if you can seal it up when not in use. If kept away from light, it will remain active for a long time, and timed 'dipping' is a lot easier & more effective than trying to flow it, or mop it on with sponges or rags. Toughest thing to do with large surfaces is keep the entire surface wet (with either chemical) until the 'exposure time' has run and you rinse it off with clean water. One trick is to build a trough with plastic sheet suspended behind/above it, so runoff goes in the trough for re-use. A cheap fountain pump from Harbor Freight rigged to recycle fluid from the trough might last long enough to do the big stuff. Don't forget, both are highly toxic, so use carefully. Full strength alumiprep will eat your concrete floor (I can testify). Alumiprep is a Chromate product, and Chromates are banned in a lot of states due to toxicity. No reason to be terrified of them, but you do need to respect them (eye protection, good gloves, etc). Charlie On Wed, Apr 13, 2016 at 12:29 PM, Richard Girard wrote: Alodine works better if its used under an epoxy coating. As I believe the Poly Fiber book recommends.One sure way to get your Kolb wing or tail to corrode whether you alodine or not; don't install drain grommets. Once again, as the Poly Fiber book recommends.Tip on Alodine. It doesn't work forever. Look at the product usage and see how many square feet it will convert and protect. The Alumiprep that Spruce sells is good for 100 sq. ft. of coverage per quart. Sounds like a lot until you consider that a single 4 X 8 sheet of aluminum is 96 square feet (both sides).Years ago a fellow in EAA Chapter 1000 (Edwards Air Force Base) noted that you're paying a hell of a lot for water when you buy premixed alodine. He bought the powder from Henkel Technologies and bought his own distilled water. Unfortunately the minimum purchase size was $100 (early 2000's) but he had enough to do something like 4 RV style aluminum airplanes. On the other hand, if you buy quarts from Spruce you won't even get a gallon of premix for $100.So, buy the gallon for $42 and get 4 times as much for 1.5 times greater price. Or better yet, go to your local auto body materials distributor and avoid the hazardous materials fees for shipping. Rick Girard On Tue, Apr 12, 2016 at 7:00 AM, John Hauck wrote: --> Kolb-List message posted by: "John Hauck" Only thing I Alodine on my MKIII is the engine mounts for the 912. I do not paint them. Initially, I did paint them and had a problem with lose engine mount bolts when the primer and paint wore between the two surfaces. Haven't found it necessary to use a corrosion preventive treatment on alclad aluminum tubing. john h mkIII Titus, Alabama Started on the stabilizers of my Firestar kit Saturday, got one side cut, fitted and Clecoed, and was able to start cutting tubes for the second one. Does anyone have a recommendation for or againsit using Alodine chemical conversion as a no-weight corrosion preventive treatment on the aluminum tails? Bill Berle ________________________________________________________________________________
Date: Apr 13, 2016
Subject: Drain hole 'dancer'
Quick & dirty pic of the drain hole 'dancer' I was trying to describe. Made it in about a minute using needle nose pliers & safety wire pliers. Spiral it into the drain hole; won't come out until you remove it. Charlie ________________________________________________________________________________
Date: Apr 13, 2016
Subject: alodine process
One version of the alodine process (note that the 1st step is 'clean (as recommended).' That would be the clean/degrease/alumiprep (acid etch) process. https://www.pegasusautoracing.com/pdfs/Iridite-Instructions.pdf Charlie ________________________________________________________________________________
Subject: Re: 447 Head bolt torque...
Date: Apr 13, 2016
I did a search..and gound all of the torques...so we are good to go...I will send him the link...Herb On 04/13/2016 11:59 AM, Richard Girard wrote: > Herb, Have your buddy download the Rotax Two Stroke Illustrated Parts > Catalog (IPC). Go to Chapter 10 Torques and he'll find ever screw, > bolt, stud, and nut with its part no. and chapter where it can be > found, size and thread, and everything else you need to know to > properly button up a 447, 503, or 582. > > Rick Girard > > On Tue, Apr 12, 2016 at 8:04 PM, Herb > wrote: > > > > > Already in trouble with the list Gods...forgot to change the > subject line...!! > > Now...to show how forgetful I am...got an email from the guy who > bought my Firefly... > > I told him to be sure to re torque the cyl head nuts/studs.... > I think the correct torque is 195 inch lbs. or 17 ft lbs...that > correct? > > They do loosen up ! considerably... > > I think I also told him that I would change the cooling fan > belt...since we have an unknown with it... Herb > > On 04/12/2016 07:30 PM, Herb wrote: > > > > > A lot of the guys on the list know each other, either from > flyins or cross country stints...so the List Gods tend to > tollerate small transgressions from time to time.... > > the general attitude is one of a bit of tolerance and the > list Gods generally say..."go forth and sin no more"! :-) Herb > > On 04/12/2016 06:01 PM, Bill Berle wrote: > > > > > > "Greg Taylor" > > Good video, Christ has pay the prince for our sins, it > is by God's Grace that we are Saved. > ----------------- > > What's this have to do with Kolbs? > > Can I post all of my other non-Kolb stuff here too? > > > -- > Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red > light and turn left. > > > ========== > br> fts!) > r> > href="http://www.buildersbooks.com" rel="noreferrer" > target="_blank">www.buildersbooks.com > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > ========== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > > -- > > > Blessed are the cracked, for they shall let in the light. Groucho > Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
From: "Greg Taylor" <gtaylor35918(at)roadrunner.com>
Subject: 447 Head bolt torque...
Date: Apr 13, 2016
It's a good message, but I don't want intrude on the list. However for me God is related to everything including flying, its a great way to view his creation. By the way is there any good mark 3's out there for sale? -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Russ Kinne Sent: Wednesday, April 13, 2016 10:58 AM Subject: Re: Kolb-List: 447 Head bolt torque... Greg, why the mini-sermon?? Thats not KOLB-related! > On Apr 12, 2016, at 9:04 PM, Herb wrote: > > > Already in trouble with the list Gods...forgot to change the subject line...!! > > Now...to show how forgetful I am...got an email from the guy who bought my Firefly... > > I told him to be sure to re torque the cyl head nuts/studs.... I think the correct torque is 195 inch lbs. or 17 ft lbs...that correct? > > They do loosen up ! considerably... > > I think I also told him that I would change the cooling fan > belt...since we have an unknown with it... Herb > > On 04/12/2016 07:30 PM, Herb wrote: >> >> A lot of the guys on the list know each other, either from flyins or cross country stints...so the List Gods tend to tollerate small transgressions from time to time.... >> >> the general attitude is one of a bit of tolerance and the list Gods >> generally say..."go forth and sin no more"! :-) Herb >> >> On 04/12/2016 06:01 PM, Bill Berle wrote: >>> --> >>> >>> >>> "Greg Taylor" >>> Good video, Christ has pay the prince for our sins, it is by God's Grace that we are Saved. >>> ----------------- >>> >>> What's this have to do with Kolbs? >>> >>> Can I post all of my other non-Kolb stuff here too? >>> >>> >>> >>> >> > > -- > Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. > > > > > ________________________________________________________________________________
Subject: Firestar tail boom length...
Date: Apr 14, 2016
> and your longest tube is 12 feet long, you are not "sunk". There is a fellow here in Fresno CA who is getting out of the plane business. He has several new boom tubes, wants to sell em. ________________________________________________________________________________
Subject: Re: Firestar tail boom length...
Date: Apr 14, 2016
He should contact Bryan at the factory... the 20 footers they sell go for $500. shipping is getting to be prohibitive...Herb On 04/14/2016 07:31 PM, George Bearden wrote: > >> and your longest tube is 12 feet long, you are not "sunk". > There is a fellow here in Fresno CA who is getting out of the plane > business. He has several new boom tubes, wants to sell em. > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
Date: Apr 14, 2016
Subject: MkIIIC for sale
Over the past few years I've gone through several major life changes, some bad, some good, but the bottom-line is that I can no longer provide the TLC needed for my Kolb and I won't be around long, so I need to sell it quickly, so I'm putting it up at a bargain basement price: MkIIIC -- N# 553RL (certified as an eLSA) 234 hrs TT Airframe, Engine & Prop 100hp Rotax *912ULS* Always hangared 2 six-gallon tanks Electric fuel pump Airspeed gauge EIS with engine info BRS Chute (expired) Intercom Odyssey battery 3-blade *Warp Drive* prop hydraulic disc brakes Thomason stainless steel exhaust Photos: https://www.facebook.com/media/set/?set=a.4298307717.41.500807717&type= 1&l=f368fa4ce6 Video showing the unfolding/folding of this MkIII: http://www.youtube.com/watch?v=uGblkR8cdYE Price: $17,000 This price *includes* a fully enclosed aluminum trailer (see photos). =8B The plane is located near Waller, TX (37XA : Skydive Houston). Full-disclosure issues: I have not flown it much in the past couple of years, so it does need some TLC. Currently, the gap seal needs repair or replacement. The other issue is that the original builder did a sucky job with the hydraulic brake lines, and right when my life fell apart I had just torn up the aluminum floorboard to get at the brake system (he riveted the entire floor!); I never finished the brake repair or replaced the floorboard. Bottom line: the plane flies very well, but without brakes you'll need to land it on grass until you get the brakes repaired. I have flown it and landed on my grass landing strip and used the grass taxiways without any issues with stopping. (To be specific, the discs, pads, lines are all good; it just needs a reservoir to be added, connect the lines and then an air purge. It will also need a new floorboard.) If you are handy and can address these minor issues, this would be a great project. If you aren't into experimental aviation maintenance tasks, then this might not be the plane for you. If I can't sell it in the next 4 weeks, it will go back into hibernation mode until I get back to town (at which time, I will try again to sell it). Please contact me off-list. Contact info: Robert Laird 713-581-4976 rlaird(at)cavediver.com ________________________________________________________________________________
Date: Apr 15, 2016
I need one, what is he asking for them? -------------------------------------------- On Thu, 4/14/16, George Bearden wrote: There is a fellow here in Fresno CA who is getting out of the plane business. He has several new boom tubes, wants to sell em. Lists This Month -- Some AWESOME FREE Gifts!) Raiser. Click on more about Gifts provided www.buildersbooks.com -Matt Dralle, List Admin. Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Re: MkIIIC for sale
Date: Apr 15, 2016
Robert I had a mk IIi many years ago... Wondering about the age of the airframe? Herb On 04/14/2016 08:12 PM, Robert Laird wrote: > Over the past few years I've gone through several major life changes, > some bad, some good, but the bottom-line is that I can no longer > provide the TLC needed for my Kolb and I won't be around long, so I > need to sell it quickly, so I'm putting it up at a bargain basement price: > > MkIIIC -- N# 553RL (certified as an eLSA) > > 234 hrs TT Airframe, Engine & Prop > 100hp Rotax *912ULS* > Always hangared > 2 six-gallon tanks > Electric fuel pump > Airspeed gauge > EIS with engine info > BRS Chute (expired) > Intercom > Odyssey battery > 3-blade *Warp Drive* prop > hydraulic disc brakes > Thomason stainless steel exhaust > > > Photos: > > https://www.facebook.com/media/set/?set=a.4298307717.41.500807717&type=1&l=f368fa4ce6 > > > Video showing the unfolding/folding of this MkIII: > > http://www.youtube.com/watch?v=uGblkR8cdYE > > Price: $17,000 > > This price *_includes_* a fully enclosed aluminum trailer (see photos). > > The plane is located near Waller, TX (37XA : Skydive Houston). > > Full-disclosure issues: > > I have not flown it much in the past couple of years, so it does need > some TLC. Currently, the gap seal needs repair or replacement. The > other issue is that the original builder did a sucky job with the > hydraulic brake lines, and right when my life fell apart I had just > torn up the aluminum floorboard to get at the brake system (he riveted > the entire floor!); I never finished the brake repair or replaced the > floorboard. Bottom line: the plane flies very well, but without brakes > you'll need to land it on grass until you get the brakes repaired. I > have flown it and landed on my grass landing strip and used the grass > taxiways without any issues with stopping. (To be specific, the discs, > pads, lines are all good; it just needs a reservoir to be added, > connect the lines and then an air purge. It will also need a new > floorboard.) > > If you are handy and can address these minor issues, this would be a > great project. If you aren't into experimental aviation maintenance > tasks, then this might not be the plane for you. > > If I can't sell it in the next 4 weeks, it will go back into > hibernation mode until I get back to town (at which time, I will try > again to sell it). > > Please contact me off-list. > > Contact info: > > Robert Laird > 713-581-4976 > rlaird(at)cavediver.com > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
Date: Apr 15, 2016
By the way...I did not see a photo of the trailer..Herb On 04/14/2016 08:12 PM, Robert Laird wrote: > Over the past few years I've gone through several major life changes, > some bad, some good, but the bottom-line is that I can no longer > provide the TLC needed for my Kolb and I won't be around long, so I > need to sell it quickly, so I'm putting it up at a bargain basement price: > > MkIIIC -- N# 553RL (certified as an eLSA) > > 234 hrs TT Airframe, Engine & Prop > 100hp Rotax *912ULS* > Always hangared > 2 six-gallon tanks > Electric fuel pump > Airspeed gauge > EIS with engine info > BRS Chute (expired) > Intercom > Odyssey battery > 3-blade *Warp Drive* prop > hydraulic disc brakes > Thomason stainless steel exhaust > > > Photos: > > https://www.facebook.com/media/set/?set=a.4298307717.41.500807717&type=1&l=f368fa4ce6 > > > Video showing the unfolding/folding of this MkIII: > > http://www.youtube.com/watch?v=uGblkR8cdYE > > Price: $17,000 > > This price *_includes_* a fully enclosed aluminum trailer (see photos). > > The plane is located near Waller, TX (37XA : Skydive Houston). > > Full-disclosure issues: > > I have not flown it much in the past couple of years, so it does need > some TLC. Currently, the gap seal needs repair or replacement. The > other issue is that the original builder did a sucky job with the > hydraulic brake lines, and right when my life fell apart I had just > torn up the aluminum floorboard to get at the brake system (he riveted > the entire floor!); I never finished the brake repair or replaced the > floorboard. Bottom line: the plane flies very well, but without brakes > you'll need to land it on grass until you get the brakes repaired. I > have flown it and landed on my grass landing strip and used the grass > taxiways without any issues with stopping. (To be specific, the discs, > pads, lines are all good; it just needs a reservoir to be added, > connect the lines and then an air purge. It will also need a new > floorboard.) > > If you are handy and can address these minor issues, this would be a > great project. If you aren't into experimental aviation maintenance > tasks, then this might not be the plane for you. > > If I can't sell it in the next 4 weeks, it will go back into > hibernation mode until I get back to town (at which time, I will try > again to sell it). > > Please contact me off-list. > > Contact info: > > Robert Laird > 713-581-4976 > rlaird(at)cavediver.com > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
Date: Apr 15, 2016
Well! Dag nab it....meant to email Robert privately...Herb On 04/14/2016 08:12 PM, Robert Laird wrote: > Over the past few years I've gone through several major life changes, > some bad, some good, but the bottom-line is that I can no longer > provide the TLC needed for my Kolb and I won't be around long, so I > need to sell it quickly, so I'm putting it up at a bargain basement price: > > MkIIIC -- N# 553RL (certified as an eLSA) > > 234 hrs TT Airframe, Engine & Prop > 100hp Rotax *912ULS* > Always hangared > 2 six-gallon tanks > Electric fuel pump > Airspeed gauge > EIS with engine info > BRS Chute (expired) > Intercom > Odyssey battery > 3-blade *Warp Drive* prop > hydraulic disc brakes > Thomason stainless steel exhaust > > > Photos: > > https://www.facebook.com/media/set/?set=a.4298307717.41.500807717&type=1&l=f368fa4ce6 > > > Video showing the unfolding/folding of this MkIII: > > http://www.youtube.com/watch?v=uGblkR8cdYE > > Price: $17,000 > > This price *_includes_* a fully enclosed aluminum trailer (see photos). > > The plane is located near Waller, TX (37XA : Skydive Houston). > > Full-disclosure issues: > > I have not flown it much in the past couple of years, so it does need > some TLC. Currently, the gap seal needs repair or replacement. The > other issue is that the original builder did a sucky job with the > hydraulic brake lines, and right when my life fell apart I had just > torn up the aluminum floorboard to get at the brake system (he riveted > the entire floor!); I never finished the brake repair or replaced the > floorboard. Bottom line: the plane flies very well, but without brakes > you'll need to land it on grass until you get the brakes repaired. I > have flown it and landed on my grass landing strip and used the grass > taxiways without any issues with stopping. (To be specific, the discs, > pads, lines are all good; it just needs a reservoir to be added, > connect the lines and then an air purge. It will also need a new > floorboard.) > > If you are handy and can address these minor issues, this would be a > great project. If you aren't into experimental aviation maintenance > tasks, then this might not be the plane for you. > > If I can't sell it in the next 4 weeks, it will go back into > hibernation mode until I get back to town (at which time, I will try > again to sell it). > > Please contact me off-list. > > Contact info: > > Robert Laird > 713-581-4976 > rlaird(at)cavediver.com > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
Date: Apr 16, 2016
Subject: RE: Kolb-List Digest: 3 Msgs - 04/15/16
V291bGQgeW91IG1pbmQgdG8gdGFrZSBtZSBvZmYgdGhlIGxpc3Q/ClBhdWxAc2lnc29sbnMuY29t wqAKVGhhbmsgeW91wqAKCgpTZW50IHZpYSB0aGUgU2Ftc3VuZyBHYWxheHkgU8KuIDYsIGFuIEFU JlQgNEcgTFRFIHNtYXJ0cGhvbmUtLS0tLS0tLSBPcmlnaW5hbCBtZXNzYWdlIC0tLS0tLS0tCkZy b206IEtvbGItTGlzdCBEaWdlc3QgU2VydmVyIDxrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbT4gCkRh dGU6IDA0LzE2LzIwMTYgIDI6MDMgQU0gIChHTVQtMDY6MDApIApUbzogS29sYi1MaXN0IERpZ2Vz dCBMaXN0IDxrb2xiLWxpc3QtZGlnZXN0QG1hdHJvbmljcy5jb20+IApTdWJqZWN0OiBLb2xiLUxp c3QgRGlnZXN0OiAzIE1zZ3MgLSAwNC8xNS8xNiAKCioKCiA9PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQrCoMKgIE9ubGluZSBWZXJzaW9ucyBvZiBUb2Rh eSdzIExpc3QgRGlnZXN0IEFyY2hpdmUKID09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09CgpUb2RheSdzIGNvbXBsZXRlIEtvbGItTGlzdCBEaWdlc3QgY2Fu IGFsc28gYmUgZm91bmQgaW4gZWl0aGVyIG9mIHRoZSAKdHdvIFdlYiBMaW5rcyBsaXN0ZWQgYmVs b3cuwqAgVGhlIC5odG1sIGZpbGUgaW5jbHVkZXMgdGhlIERpZ2VzdCBmb3JtYXR0ZWQgCmluIEhU TUwgZm9yIHZpZXdpbmcgd2l0aCBhIHdlYiBicm93c2VyIGFuZCBmZWF0dXJlcyBIeXBlcmxpbmtl ZCBJbmRleGVzIAphbmQgTWVzc2FnZSBOYXZpZ2F0aW9uLsKgIFRoZSAudHh0IGZpbGUgaW5jbHVk ZXMgdGhlIHBsYWluIEFTQ0lJIHZlcnNpb24gCm9mIHRoZSBLb2xiLUxpc3QgRGlnZXN0IGFuZCBj YW4gYmUgdmlld2VkIHdpdGggYSBnZW5lcmljIHRleHQgZWRpdG9yIApzdWNoIGFzIE5vdGVwYWQg b3Igd2l0aCBhIHdlYiBicm93c2VyLiAKCkhUTUwgVmVyc2lvbjoKCsKgwqDCoCBodHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vZGlnZXN0L2RpZ2VzdHZpZXcucGhwP1N0eWxlPTgyNzAxJlZpZXc9aHRt bCZDaGFwdGVyPTIwMTYtMDQtMTUmQXJjaGl2ZT1Lb2xiCgpUZXh0IFZlcnNpb246CgrCoMKgwqAg aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2RpZ2VzdC9kaWdlc3R2aWV3LnBocD9TdHlsZT04Mjcw MSZWaWV3PXR4dCZDaGFwdGVyPTIwMTYtMDQtMTUmQXJjaGl2ZT1Lb2xiCgoKID09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQrCoMKgIEVNYWlsIFZlcnNpb24g b2YgVG9kYXkncyBMaXN0IERpZ2VzdCBBcmNoaXZlCiA9PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0KCiAKwqDCoMKgwqDCoMKgwqDCoMKgwqAgLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLQrCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIEtvbGItTGlzdCBE aWdlc3QgQXJjaGl2ZQrCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtLS0KwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoCBUb3RhbCBNZXNzYWdlcyBQb3N0ZWQgRnJpIDA0LzE1LzE2OiAz CsKgwqDCoMKgwqDCoMKgwqDCoMKgIC0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0KIAogClRvZGF5J3MgTWVzc2FnZSBJbmRleDoKLS0tLS0t LS0tLS0tLS0tLS0tLS0tLQogCsKgwqDCoMKgIDEuIDA3OjQ5IEFNIC0gUmU6IE1rSUlJQyBmb3Ig c2FsZcKgIChIZXJiKQrCoMKgwqDCoCAyLiAwNzo0OSBBTSAtIFJlOiBNa0lJSUMgZm9yIHNhbGXC oCAoSGVyYikKwqDCoMKgwqAgMy4gMDc6NTAgQU0gLSBSZTogTWtJSUlDIGZvciBzYWxlwqAgKEhl cmIpCiAKIAogCl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fwqAgTWVzc2FnZSAxwqAg X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXwoKClRpbWU6IDA3OjQ5OjA3IEFN IFBTVCBVUwpTdWJqZWN0OiBSZTogS29sYi1MaXN0OiBNa0lJSUMgZm9yIHNhbGUKRnJvbTogSGVy YiA8SGVyYmdoQG5jdGMuY29tPgoKUm9iZXJ0CgrCoMKgwqAgSSBoYWQgYSBtayBJSWkgbWFueSB5 ZWFycyBhZ28uLi4KCsKgwqAgV29uZGVyaW5nIGFib3V0IHRoZSBhZ2Ugb2YgdGhlIGFpcmZyYW1l P8KgIEhlcmIKCk9uIDA0LzE0LzIwMTYgMDg6MTIgUE0sIFJvYmVydCBMYWlyZCB3cm90ZToKPiBP dmVyIHRoZSBwYXN0IGZldyB5ZWFycyBJJ3ZlIGdvbmUgdGhyb3VnaCBzZXZlcmFsIG1ham9yIGxp ZmUgY2hhbmdlcywgCj4gc29tZSBiYWQsIHNvbWUgZ29vZCwgYnV0IHRoZSBib3R0b20tbGluZSBp cyB0aGF0IEkgY2FuIG5vIGxvbmdlciAKPiBwcm92aWRlIHRoZSBUTEMgbmVlZGVkIGZvciBteSBL b2xiIGFuZCBJIHdvbid0IGJlIGFyb3VuZCBsb25nLCBzbyBJIAo+IG5lZWQgdG8gc2VsbCBpdCBx dWlja2x5LCBzbyBJJ20gcHV0dGluZyBpdCB1cCBhdCBhIGJhcmdhaW4gYmFzZW1lbnQgcHJpY2U6 Cj4KPiBNa0lJSUMgLS0gTiMgNTUzUkzCoCAoY2VydGlmaWVkIGFzIGFuIGVMU0EpCj4KPiAyMzQg aHJzIFRUIEFpcmZyYW1lLCBFbmdpbmUgJiBQcm9wCj4gMTAwaHAgUm90YXggKjkxMlVMUyoKPiBB bHdheXMgaGFuZ2FyZWQKPiAyIHNpeC1nYWxsb24gdGFua3MKPiBFbGVjdHJpYyBmdWVsIHB1bXAK PiBBaXJzcGVlZCBnYXVnZQo+IEVJUyB3aXRoIGVuZ2luZSBpbmZvCj4gQlJTIENodXRlIChleHBp cmVkKQo+IEludGVyY29tCj4gT2R5c3NleSBiYXR0ZXJ5Cj4gMy1ibGFkZSAqV2FycCBEcml2ZSog cHJvcAo+IGh5ZHJhdWxpYyBkaXNjIGJyYWtlcwo+IFRob21hc29uIHN0YWlubGVzcyBzdGVlbCBl eGhhdXN0Cj4KPgo+IFBob3RvczoKPgo+IGh0dHBzOi8vd3d3LmZhY2Vib29rLmNvbS9tZWRpYS9z ZXQvP3NldD1hLjQyOTgzMDc3MTcuNDEuNTAwODA3NzE3JnR5cGU9MSZsPWYzNjhmYTRjZTYKPgo+ Cj4gVmlkZW8gc2hvd2luZyB0aGUgdW5mb2xkaW5nL2ZvbGRpbmcgb2YgdGhpcyBNa0lJSToKPgo+ IGh0dHA6Ly93d3cueW91dHViZS5jb20vd2F0Y2g/dj11R2Jsa1I4Y2RZRQo+Cj4gUHJpY2U6wqAg JDE3LDAwMAo+Cj4gVGhpcyBwcmljZSAqX2luY2x1ZGVzXyogYSBmdWxseSBlbmNsb3NlZCBhbHVt aW51bSB0cmFpbGVyIChzZWUgcGhvdG9zKS4KPgo+IFRoZSBwbGFuZSBpcyBsb2NhdGVkIG5lYXIg V2FsbGVyLCBUWCAoMzdYQSA6IFNreWRpdmUgSG91c3RvbikuCj4KPiBGdWxsLWRpc2Nsb3N1cmUg aXNzdWVzOgo+Cj4gSSBoYXZlIG5vdCBmbG93biBpdCBtdWNoIGluIHRoZSBwYXN0IGNvdXBsZSBv ZiB5ZWFycywgc28gaXQgZG9lcyBuZWVkIAo+IHNvbWUgVExDLsKgIEN1cnJlbnRseSwgdGhlIGdh cCBzZWFsIG5lZWRzIHJlcGFpciBvciByZXBsYWNlbWVudC7CoCBUaGUgCj4gb3RoZXIgaXNzdWUg aXMgdGhhdCB0aGUgb3JpZ2luYWwgYnVpbGRlciBkaWQgYSBzdWNreSBqb2Igd2l0aCB0aGUgCj4g aHlkcmF1bGljIGJyYWtlIGxpbmVzLCBhbmQgcmlnaHQgd2hlbiBteSBsaWZlIGZlbGwgYXBhcnQg SSBoYWQganVzdCAKPiB0b3JuIHVwIHRoZSBhbHVtaW51bSBmbG9vcmJvYXJkIHRvIGdldCBhdCB0 aGUgYnJha2Ugc3lzdGVtIChoZSByaXZldGVkIAo+IHRoZSBlbnRpcmUgZmxvb3IhKTsgSSBuZXZl ciBmaW5pc2hlZCB0aGUgYnJha2UgcmVwYWlyIG9yIHJlcGxhY2VkIHRoZSAKPiBmbG9vcmJvYXJk LiBCb3R0b20gbGluZTogdGhlIHBsYW5lIGZsaWVzIHZlcnkgd2VsbCwgYnV0IHdpdGhvdXQgYnJh a2VzIAo+IHlvdSdsbCBuZWVkIHRvIGxhbmQgaXQgb24gZ3Jhc3MgdW50aWwgeW91IGdldCB0aGUg YnJha2VzIHJlcGFpcmVkLsKgIEkgCj4gaGF2ZSBmbG93biBpdCBhbmQgbGFuZGVkIG9uIG15IGdy YXNzIGxhbmRpbmcgc3RyaXAgYW5kIHVzZWQgdGhlIGdyYXNzIAo+IHRheGl3YXlzIHdpdGhvdXQg YW55IGlzc3VlcyB3aXRoIHN0b3BwaW5nLiAoVG8gYmUgc3BlY2lmaWMsIHRoZSBkaXNjcywgCj4g cGFkcywgbGluZXMgYXJlIGFsbCBnb29kOyBpdCBqdXN0IG5lZWRzIGEgcmVzZXJ2b2lyIHRvIGJl IGFkZGVkLCAKPiBjb25uZWN0IHRoZSBsaW5lcyBhbmQgdGhlbiBhbiBhaXIgcHVyZ2UuwqAgSXQg d2lsbCBhbHNvIG5lZWQgYSBuZXcgCj4gZmxvb3Jib2FyZC4pCj4KPiBJZiB5b3UgYXJlIGhhbmR5 IGFuZCBjYW4gYWRkcmVzcyB0aGVzZSBtaW5vciBpc3N1ZXMsIHRoaXMgd291bGQgYmUgYSAKPiBn cmVhdCBwcm9qZWN0LsKgIElmIHlvdSBhcmVuJ3QgaW50byBleHBlcmltZW50YWwgYXZpYXRpb24g bWFpbnRlbmFuY2UgCj4gdGFza3MsIHRoZW4gdGhpcyBtaWdodCBub3QgYmUgdGhlIHBsYW5lIGZv ciB5b3UuCj4KPiBJZiBJIGNhbid0IHNlbGwgaXQgaW4gdGhlIG5leHQgNCB3ZWVrcywgaXQgd2ls bCBnbyBiYWNrIGludG8gCj4gaGliZXJuYXRpb24gbW9kZSB1bnRpbCBJIGdldCBiYWNrIHRvIHRv d24gKGF0IHdoaWNoIHRpbWUsIEkgd2lsbCB0cnkgCj4gYWdhaW4gdG8gc2VsbCBpdCkuCj4KPiBQ bGVhc2UgY29udGFjdCBtZSBvZmYtbGlzdC4KPgo+IENvbnRhY3QgaW5mbzoKPgo+IFJvYmVydCBM YWlyZAo+IDcxMy01ODEtNDk3Ngo+IHJsYWlyZEBjYXZlZGl2ZXIuY29tIDxtYWlsdG86cmxhaXJk QGNhdmVkaXZlci5jb20+Cj4KPgoKLS0gClNpZ25hdHVyZSB0ZXh0OyBGb3J0IE1hcmN5IFBhcms/ wqAgU3VyZS4uLk1yLiBGb3N0ZXIuLi5UaGlyZCByZWQgbGlnaHQgYW5kIHR1cm4KbGVmdC4KCgpf X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX8KgIE1lc3NhZ2UgMsKgIF9fX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fX18KCgpUaW1lOiAwNzo0OTozMiBBTSBQU1QgVVMKU3Vi amVjdDogUmU6IEtvbGItTGlzdDogTWtJSUlDIGZvciBzYWxlCkZyb206IEhlcmIgPEhlcmJnaEBu Y3RjLmNvbT4KCkJ5IHRoZSB3YXkuLi5JIGRpZCBub3Qgc2VlIGEgcGhvdG8gb2YgdGhlIHRyYWls ZXIuLkhlcmIKCk9uIDA0LzE0LzIwMTYgMDg6MTIgUE0sIFJvYmVydCBMYWlyZCB3cm90ZToKPiBP dmVyIHRoZSBwYXN0IGZldyB5ZWFycyBJJ3ZlIGdvbmUgdGhyb3VnaCBzZXZlcmFsIG1ham9yIGxp ZmUgY2hhbmdlcywgCj4gc29tZSBiYWQsIHNvbWUgZ29vZCwgYnV0IHRoZSBib3R0b20tbGluZSBp cyB0aGF0IEkgY2FuIG5vIGxvbmdlciAKPiBwcm92aWRlIHRoZSBUTEMgbmVlZGVkIGZvciBteSBL b2xiIGFuZCBJIHdvbid0IGJlIGFyb3VuZCBsb25nLCBzbyBJIAo+IG5lZWQgdG8gc2VsbCBpdCBx dWlja2x5LCBzbyBJJ20gcHV0dGluZyBpdCB1cCBhdCBhIGJhcmdhaW4gYmFzZW1lbnQgcHJpY2U6 Cj4KPiBNa0lJSUMgLS0gTiMgNTUzUkzCoCAoY2VydGlmaWVkIGFzIGFuIGVMU0EpCj4KPiAyMzQg aHJzIFRUIEFpcmZyYW1lLCBFbmdpbmUgJiBQcm9wCj4gMTAwaHAgUm90YXggKjkxMlVMUyoKPiBB bHdheXMgaGFuZ2FyZWQKPiAyIHNpeC1nYWxsb24gdGFua3MKPiBFbGVjdHJpYyBmdWVsIHB1bXAK PiBBaXJzcGVlZCBnYXVnZQo+IEVJUyB3aXRoIGVuZ2luZSBpbmZvCj4gQlJTIENodXRlIChleHBp cmVkKQo+IEludGVyY29tCj4gT2R5c3NleSBiYXR0ZXJ5Cj4gMy1ibGFkZSAqV2FycCBEcml2ZSog cHJvcAo+IGh5ZHJhdWxpYyBkaXNjIGJyYWtlcwo+IFRob21hc29uIHN0YWlubGVzcyBzdGVlbCBl eGhhdXN0Cj4KPgo+IFBob3RvczoKPgo+IGh0dHBzOi8vd3d3LmZhY2Vib29rLmNvbS9tZWRpYS9z ZXQvP3NldD1hLjQyOTgzMDc3MTcuNDEuNTAwODA3NzE3JnR5cGU9MSZsPWYzNjhmYTRjZTYKPgo+ Cj4gVmlkZW8gc2hvd2luZyB0aGUgdW5mb2xkaW5nL2ZvbGRpbmcgb2YgdGhpcyBNa0lJSToKPgo+ IGh0dHA6Ly93d3cueW91dHViZS5jb20vd2F0Y2g/dj11R2Jsa1I4Y2RZRQo+Cj4gUHJpY2U6wqAg JDE3LDAwMAo+Cj4gVGhpcyBwcmljZSAqX2luY2x1ZGVzXyogYSBmdWxseSBlbmNsb3NlZCBhbHVt aW51bSB0cmFpbGVyIChzZWUgcGhvdG9zKS4KPgo+IFRoZSBwbGFuZSBpcyBsb2NhdGVkIG5lYXIg V2FsbGVyLCBUWCAoMzdYQSA6IFNreWRpdmUgSG91c3RvbikuCj4KPiBGdWxsLWRpc2Nsb3N1cmUg aXNzdWVzOgo+Cj4gSSBoYXZlIG5vdCBmbG93biBpdCBtdWNoIGluIHRoZSBwYXN0IGNvdXBsZSBv ZiB5ZWFycywgc28gaXQgZG9lcyBuZWVkIAo+IHNvbWUgVExDLsKgIEN1cnJlbnRseSwgdGhlIGdh cCBzZWFsIG5lZWRzIHJlcGFpciBvciByZXBsYWNlbWVudC7CoCBUaGUgCj4gb3RoZXIgaXNzdWUg aXMgdGhhdCB0aGUgb3JpZ2luYWwgYnVpbGRlciBkaWQgYSBzdWNreSBqb2Igd2l0aCB0aGUgCj4g aHlkcmF1bGljIGJyYWtlIGxpbmVzLCBhbmQgcmlnaHQgd2hlbiBteSBsaWZlIGZlbGwgYXBhcnQg SSBoYWQganVzdCAKPiB0b3JuIHVwIHRoZSBhbHVtaW51bSBmbG9vcmJvYXJkIHRvIGdldCBhdCB0 aGUgYnJha2Ugc3lzdGVtIChoZSByaXZldGVkIAo+IHRoZSBlbnRpcmUgZmxvb3IhKTsgSSBuZXZl ciBmaW5pc2hlZCB0aGUgYnJha2UgcmVwYWlyIG9yIHJlcGxhY2VkIHRoZSAKPiBmbG9vcmJvYXJk LiBCb3R0b20gbGluZTogdGhlIHBsYW5lIGZsaWVzIHZlcnkgd2VsbCwgYnV0IHdpdGhvdXQgYnJh a2VzIAo+IHlvdSdsbCBuZWVkIHRvIGxhbmQgaXQgb24gZ3Jhc3MgdW50aWwgeW91IGdldCB0aGUg YnJha2VzIHJlcGFpcmVkLsKgIEkgCj4gaGF2ZSBmbG93biBpdCBhbmQgbGFuZGVkIG9uIG15IGdy YXNzIGxhbmRpbmcgc3RyaXAgYW5kIHVzZWQgdGhlIGdyYXNzIAo+IHRheGl3YXlzIHdpdGhvdXQg YW55IGlzc3VlcyB3aXRoIHN0b3BwaW5nLiAoVG8gYmUgc3BlY2lmaWMsIHRoZSBkaXNjcywgCj4g cGFkcywgbGluZXMgYXJlIGFsbCBnb29kOyBpdCBqdXN0IG5lZWRzIGEgcmVzZXJ2b2lyIHRvIGJl IGFkZGVkLCAKPiBjb25uZWN0IHRoZSBsaW5lcyBhbmQgdGhlbiBhbiBhaXIgcHVyZ2UuwqAgSXQg d2lsbCBhbHNvIG5lZWQgYSBuZXcgCj4gZmxvb3Jib2FyZC4pCj4KPiBJZiB5b3UgYXJlIGhhbmR5 IGFuZCBjYW4gYWRkcmVzcyB0aGVzZSBtaW5vciBpc3N1ZXMsIHRoaXMgd291bGQgYmUgYSAKPiBn cmVhdCBwcm9qZWN0LsKgIElmIHlvdSBhcmVuJ3QgaW50byBleHBlcmltZW50YWwgYXZpYXRpb24g bWFpbnRlbmFuY2UgCj4gdGFza3MsIHRoZW4gdGhpcyBtaWdodCBub3QgYmUgdGhlIHBsYW5lIGZv ciB5b3UuCj4KPiBJZiBJIGNhbid0IHNlbGwgaXQgaW4gdGhlIG5leHQgNCB3ZWVrcywgaXQgd2ls bCBnbyBiYWNrIGludG8gCj4gaGliZXJuYXRpb24gbW9kZSB1bnRpbCBJIGdldCBiYWNrIHRvIHRv d24gKGF0IHdoaWNoIHRpbWUsIEkgd2lsbCB0cnkgCj4gYWdhaW4gdG8gc2VsbCBpdCkuCj4KPiBQ bGVhc2UgY29udGFjdCBtZSBvZmYtbGlzdC4KPgo+IENvbnRhY3QgaW5mbzoKPgo+IFJvYmVydCBM YWlyZAo+IDcxMy01ODEtNDk3Ngo+IHJsYWlyZEBjYXZlZGl2ZXIuY29tIDxtYWlsdG86cmxhaXJk QGNhdmVkaXZlci5jb20+Cj4KPgoKLS0gClNpZ25hdHVyZSB0ZXh0OyBGb3J0IE1hcmN5IFBhcms/ wqAgU3VyZS4uLk1yLiBGb3N0ZXIuLi5UaGlyZCByZWQgbGlnaHQgYW5kIHR1cm4KbGVmdC4KCgpf X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX8KgIE1lc3NhZ2UgM8KgIF9fX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fX18KCgpUaW1lOiAwNzo1MDoyNiBBTSBQU1QgVVMKU3Vi amVjdDogUmU6IEtvbGItTGlzdDogTWtJSUlDIGZvciBzYWxlCkZyb206IEhlcmIgPEhlcmJnaEBu Y3RjLmNvbT4KCldlbGwhIERhZyBuYWIgaXQuLi4ubWVhbnQgdG8gZW1haWwgUm9iZXJ0IHByaXZh dGVseS4uLkhlcmIKCk9uIDA0LzE0LzIwMTYgMDg6MTIgUE0sIFJvYmVydCBMYWlyZCB3cm90ZToK PiBPdmVyIHRoZSBwYXN0IGZldyB5ZWFycyBJJ3ZlIGdvbmUgdGhyb3VnaCBzZXZlcmFsIG1ham9y IGxpZmUgY2hhbmdlcywgCj4gc29tZSBiYWQsIHNvbWUgZ29vZCwgYnV0IHRoZSBib3R0b20tbGlu ZSBpcyB0aGF0IEkgY2FuIG5vIGxvbmdlciAKPiBwcm92aWRlIHRoZSBUTEMgbmVlZGVkIGZvciBt eSBLb2xiIGFuZCBJIHdvbid0IGJlIGFyb3VuZCBsb25nLCBzbyBJIAo+IG5lZWQgdG8gc2VsbCBp dCBxdWlja2x5LCBzbyBJJ20gcHV0dGluZyBpdCB1cCBhdCBhIGJhcmdhaW4gYmFzZW1lbnQgcHJp Y2U6Cj4KPiBNa0lJSUMgLS0gTiMgNTUzUkzCoCAoY2VydGlmaWVkIGFzIGFuIGVMU0EpCj4KPiAy MzQgaHJzIFRUIEFpcmZyYW1lLCBFbmdpbmUgJiBQcm9wCj4gMTAwaHAgUm90YXggKjkxMlVMUyoK PiBBbHdheXMgaGFuZ2FyZWQKPiAyIHNpeC1nYWxsb24gdGFua3MKPiBFbGVjdHJpYyBmdWVsIHB1 bXAKPiBBaXJzcGVlZCBnYXVnZQo+IEVJUyB3aXRoIGVuZ2luZSBpbmZvCj4gQlJTIENodXRlIChl eHBpcmVkKQo+IEludGVyY29tCj4gT2R5c3NleSBiYXR0ZXJ5Cj4gMy1ibGFkZSAqV2FycCBEcml2 ZSogcHJvcAo+IGh5ZHJhdWxpYyBkaXNjIGJyYWtlcwo+IFRob21hc29uIHN0YWlubGVzcyBzdGVl bCBleGhhdXN0Cj4KPgo+IFBob3RvczoKPgo+IGh0dHBzOi8vd3d3LmZhY2Vib29rLmNvbS9tZWRp YS9zZXQvP3NldD1hLjQyOTgzMDc3MTcuNDEuNTAwODA3NzE3JnR5cGU9MSZsPWYzNjhmYTRjZTYK Pgo+Cj4gVmlkZW8gc2hvd2luZyB0aGUgdW5mb2xkaW5nL2ZvbGRpbmcgb2YgdGhpcyBNa0lJSToK Pgo+IGh0dHA6Ly93d3cueW91dHViZS5jb20vd2F0Y2g/dj11R2Jsa1I4Y2RZRQo+Cj4gUHJpY2U6 wqAgJDE3LDAwMAo+Cj4gVGhpcyBwcmljZSAqX2luY2x1ZGVzXyogYSBmdWxseSBlbmNsb3NlZCBh bHVtaW51bSB0cmFpbGVyIChzZWUgcGhvdG9zKS4KPgo+IFRoZSBwbGFuZSBpcyBsb2NhdGVkIG5l YXIgV2FsbGVyLCBUWCAoMzdYQSA6IFNreWRpdmUgSG91c3RvbikuCj4KPiBGdWxsLWRpc2Nsb3N1 cmUgaXNzdWVzOgo+Cj4gSSBoYXZlIG5vdCBmbG93biBpdCBtdWNoIGluIHRoZSBwYXN0IGNvdXBs ZSBvZiB5ZWFycywgc28gaXQgZG9lcyBuZWVkIAo+IHNvbWUgVExDLsKgIEN1cnJlbnRseSwgdGhl IGdhcCBzZWFsIG5lZWRzIHJlcGFpciBvciByZXBsYWNlbWVudC7CoCBUaGUgCj4gb3RoZXIgaXNz dWUgaXMgdGhhdCB0aGUgb3JpZ2luYWwgYnVpbGRlciBkaWQgYSBzdWNreSBqb2Igd2l0aCB0aGUg Cj4gaHlkcmF1bGljIGJyYWtlIGxpbmVzLCBhbmQgcmlnaHQgd2hlbiBteSBsaWZlIGZlbGwgYXBh cnQgSSBoYWQganVzdCAKPiB0b3JuIHVwIHRoZSBhbHVtaW51bSBmbG9vcmJvYXJkIHRvIGdldCBh dCB0aGUgYnJha2Ugc3lzdGVtIChoZSByaXZldGVkIAo+IHRoZSBlbnRpcmUgZmxvb3IhKTsgSSBu ZXZlciBmaW5pc2hlZCB0aGUgYnJha2UgcmVwYWlyIG9yIHJlcGxhY2VkIHRoZSAKPiBmbG9vcmJv YXJkLiBCb3R0b20gbGluZTogdGhlIHBsYW5lIGZsaWVzIHZlcnkgd2VsbCwgYnV0IHdpdGhvdXQg YnJha2VzIAo+IHlvdSdsbCBuZWVkIHRvIGxhbmQgaXQgb24gZ3Jhc3MgdW50aWwgeW91IGdldCB0 aGUgYnJha2VzIHJlcGFpcmVkLsKgIEkgCj4gaGF2ZSBmbG93biBpdCBhbmQgbGFuZGVkIG9uIG15 IGdyYXNzIGxhbmRpbmcgc3RyaXAgYW5kIHVzZWQgdGhlIGdyYXNzIAo+IHRheGl3YXlzIHdpdGhv dXQgYW55IGlzc3VlcyB3aXRoIHN0b3BwaW5nLiAoVG8gYmUgc3BlY2lmaWMsIHRoZSBkaXNjcywg Cj4gcGFkcywgbGluZXMgYXJlIGFsbCBnb29kOyBpdCBqdXN0IG5lZWRzIGEgcmVzZXJ2b2lyIHRv IGJlIGFkZGVkLCAKPiBjb25uZWN0IHRoZSBsaW5lcyBhbmQgdGhlbiBhbiBhaXIgcHVyZ2UuwqAg SXQgd2lsbCBhbHNvIG5lZWQgYSBuZXcgCj4gZmxvb3Jib2FyZC4pCj4KPiBJZiB5b3UgYXJlIGhh bmR5IGFuZCBjYW4gYWRkcmVzcyB0aGVzZSBtaW5vciBpc3N1ZXMsIHRoaXMgd291bGQgYmUgYSAK PiBncmVhdCBwcm9qZWN0LsKgIElmIHlvdSBhcmVuJ3QgaW50byBleHBlcmltZW50YWwgYXZpYXRp b24gbWFpbnRlbmFuY2UgCj4gdGFza3MsIHRoZW4gdGhpcyBtaWdodCBub3QgYmUgdGhlIHBsYW5l IGZvciB5b3UuCj4KPiBJZiBJIGNhbid0IHNlbGwgaXQgaW4gdGhlIG5leHQgNCB3ZWVrcywgaXQg d2lsbCBnbyBiYWNrIGludG8gCj4gaGliZXJuYXRpb24gbW9kZSB1bnRpbCBJIGdldCBiYWNrIHRv IHRvd24gKGF0IHdoaWNoIHRpbWUsIEkgd2lsbCB0cnkgCj4gYWdhaW4gdG8gc2VsbCBpdCkuCj4K PiBQbGVhc2UgY29udGFjdCBtZSBvZmYtbGlzdC4KPgo+IENvbnRhY3QgaW5mbzoKPgo+IFJvYmVy dCBMYWlyZAo+IDcxMy01ODEtNDk3Ngo+IHJsYWlyZEBjYXZlZGl2ZXIuY29tIDxtYWlsdG86cmxh aXJkQGNhdmVkaXZlci5jb20+Cj4KPgoKLS0gClNpZ25hdHVyZSB0ZXh0OyBGb3J0IE1hcmN5IFBh cms/wqAgU3VyZS4uLk1yLiBGb3N0ZXIuLi5UaGlyZCByZWQgbGlnaHQgYW5kIHR1cm4KbGVmdC4K CgogCgoKXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0KXy09Cl8tPcKgwqDCoMKgwqDCoCAtLSBQbGVhc2UgU3VwcG9ydCBZb3VyIExp c3RzIFRoaXMgTW9udGggLS0KXy09wqDCoMKgwqDCoMKgwqDCoMKgwqAgKEFuZCBHZXQgU29tZSBB V0VTT01FIEZSRUUgR2lmdHMhKQpfLT0KXy09wqDCoCBOb3ZlbWJlciBpcyB0aGUgQW5udWFsIExp c3QgRnVuZCBSYWlzZXIuwqAgQ2xpY2sgb24KXy09wqDCoCB0aGUgQ29udHJpYnV0aW9uIGxpbmsg YmVsb3cgdG8gZmluZCBvdXQgbW9yZSBhYm91dApfLT3CoMKgIHRoaXMgeWVhcidzIFRlcnJpZmlj IEZyZWUgSW5jZW50aXZlIEdpZnRzIHByb3ZpZGVkCl8tPcKgwqAgYnk6Cl8tPcKgwqAgCl8tPcKg wqDCoMKgICogVGhlIEJ1aWxkZXIncyBCb29rc3RvcmUgd3d3LmJ1aWxkZXJzYm9va3MuY29tCl8t PQpfLT3CoMKgIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlOgpfLT0KXy09wqDCoCAtLT4gaHR0 cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT0KXy09wqDCoCBUaGFuayB5b3Ug Zm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEKXy09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLU1hdHQgRHJhbGxlLCBMaXN0IEFk bWluLgpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT0KXy09wqDCoMKgwqDCoMKgwqDCoMKgIC0gVGhlIEtvbGItTGlzdCBFbWFp bCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0 byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJz Y3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENo YXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPcKgwqAg LS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0Cl8tPQpfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMg LQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVt cyEKXy09Cl8tPcKgwqAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0K Xy09wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUg LQpfLT3CoCBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEKXy09wqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtTWF0dCBE cmFsbGUsIExpc3QgQWRtaW4uCl8tPcKgwqAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9j b250cmlidXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0KIAogCgoKCg= ________________________________________________________________________________
Subject: ND flying videos
Date: Apr 16, 2016
Hi everyone, Raining here today so had a chance to get some videos from last year posted. No music, just engine and wind noise. http://www.harnerfarm.net/serenity/videos.html New ones are at the bottom of the list. Serenity Landing is a little long and maybe a little boring. It was the end of a nice evening flight. You get to see a little of the countryside around the Mandan, ND airport as well as the grass strip. Dawn Patrol was a friend wanting to get some pictures from his deck. It was a nice warm morning but we forgot his deck faces East! My video came out better than his pictures. Hello! was from my last flight of the year and it was my birthday. I had promised a friend that I would fly up and around their house so their little boy could see it. Problem was, even though it was nice on the ground, anything above about 600' AGL was so rough it was out of my comfort zone. I forced myself to fly in the rough air as I figured I needed the practice. I got as high as I dared and crossed the river where there was a wide sand bar. First time over water! Made it safe and sound but I was not sure about the fuel situation so only made one pass. I sure don't want to run out on final because I was screwing around too long. As it turns out I had a gallon and a half when I got back. This year I plan on experimenting with different camera mounts/locations to try and minimize the "jello" effect. Enjoy, or ignore, your choice! Stuart ________________________________________________________________________________
Date: Apr 16, 2016
Subject: Re: ND flying videos
On Sat, Apr 16, 2016 at 5:12 PM, Stuart Harner wrote: > > This year I plan on experimenting with different camera mounts/locations > to try and minimize the =9Cjello=9D effect. > > > Stuart, Thanks for the videos. I assume that you are using a Virb Elite? I > was a bit surprised at the clarity of them. The last was a lot more like > it. I checked the settings on mine and found that it was set to 1080P- > Ultra zoom- format NTSC. Lens correct was on as well as the stabilizer. > Those setting seem to render a video close to what I see with my naked ey e. > I have checked all over my Firestar and the only place that will give me the least amount of jello and other crap is on the end of the nose pod, and secured as solid as I can get it. I have a screw in pitot tube holder (plastic from AC spruce) I took a piece of alum flat stock, bent half of it 180 degrees and mounted my cradle on it. It just clears the pod. I tried one of the stick on holders and it was not as good as the alum for some reason. The other spot that isn't all that bad is the wing. Of course if you fold it each time , that isn't going to work. You will also find that there is some rpm ranges that will cause jello. For me and the HKS with a Max cruise of 5800 RPM, I find that either 5400 or faster is as smooth as it gets for me. So if you are getting jello, do a flight and mark your RPM's and try different speeds and see which works the best. I think some of the reason the quality is less than I would expect is where the video is uploaded to. Vimeo has a free membership that will give you 5000? MB a week free. The quality is really good, and they don't hassle you if you want to put some music on your video. You tube is impossible for me to deal with. When I am uploading it I make the quality as high as I can get it. Thanks for doing the videos, I like to see other parts of the country, and appreciate the effort that it takes to do a video. I wish others would do more. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: RE: Kolb-List Digest: 4 Msgs - 04/14/16
Date: Apr 16, 2016
> I need one, what is he asking for them? $310. No shipping provided. But Fresno is midway between San Francisco and LA, on hwy 99. GeoB ________________________________________________________________________________
Subject: ND flying videos/camera talk
Date: Apr 16, 2016
Larry, Yes, VIRB Elite and I think I am using the same settings as you. I had it mounted up high next to the enricher lever so that I could see the horizon and instruments as well as my hands on the controls. I used the videos to review each flight for training purposes. For my last flight last fall I dropped it down on the same upright trying to get less vibration. It was a last minute idea before I took off. Waving my arms around really messed that up! The nose cone on Serenity is mounted with screws on the bottom instead of rivets. That might be a place to make a mounting bracket that can be easily removed. Problem is I don=99t have a remote control and I sometimes forget to turn the camera on. Where it is I can reach it when I remember. I also worry about the camera falling out of the cradle and I haven=99t figured out a good way to secure it yet. The VIRB seems to do a pretty good job but it always screws up the sync between the data tracking and the video on the first file. The tracking will always be about a minute ahead of the video so it looks like I am flying and turning while I am still on the ground. After the camera starts a new file at 23+ minutes, the sync is fine. Go figure! I have my own domain name and access to a web server as a benefit of my job. File size is no limit for me, but can be a pain for the viewing public. I need to look into other file types but MP4 gives good compression from the VIRB defaults and most people can view them. .AVI and .MOV work but are larger in size. What file type do you upload to VIMEO? Stuart From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Saturday, April 16, 2016 7:21 PM Subject: Re: Kolb-List: ND flying videos On Sat, Apr 16, 2016 at 5:12 PM, Stuart Harner wrote: This year I plan on experimenting with different camera mounts/locations to try and minimize the =9Cjello=9D effect. Stuart, Thanks for the videos. I assume that you are using a Virb Elite? I was a bit surprised at the clarity of them. The last was a lot more like it. I checked the settings on mine and found that it was set to 1080P- Ultra zoom- format NTSC. Lens correct was on as well as the stabilizer. Those setting seem to render a video close to what I see with my naked eye. I have checked all over my Firestar and the only place that will give me the least amount of jello and other crap is on the end of the nose pod, and secured as solid as I can get it. I have a screw in pitot tube holder (plastic from AC spruce) I took a piece of alum flat stock, bent half of it 180 degrees and mounted my cradle on it. It just clears the pod. I tried one of the stick on holders and it was not as good as the alum for some reason. The other spot that isn't all that bad is the wing. Of course if you fold it each time , that isn't going to work. You will also find that there is some rpm ranges that will cause jello. For me and the HKS with a Max cruise of 5800 RPM, I find that either 5400 or faster is as smooth as it gets for me. So if you are getting jello, do a flight and mark your RPM's and try different speeds and see which works the best. I think some of the reason the quality is less than I would expect is where the video is uploaded to. Vimeo has a free membership that will give you 5000? MB a week free. The quality is really good, and they don't hassle you if you want to put some music on your video. You tube is impossible for me to deal with. When I am uploading it I make the quality as high as I can get it. Thanks for doing the videos, I like to see other parts of the country, and appreciate the effort that it takes to do a video. I wish others would do more. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Apr 16, 2016
Subject: Re: ND flying videos/camera talk
On Sat, Apr 16, 2016 at 10:00 PM, Stuart Harner wrote: > Larry, > > > The nose cone on Serenity is mounted with screws on the bottom instead of > rivets. That might be a place to make a mounting bracket that can be easi ly > removed. Problem is I don=99t have a remote control and I sometimes forget to > turn the camera on. Where it is I can reach it when I remember. I also > worry about the camera falling out of the cradle and I haven=99t fi gured out > a good way to secure it yet. > > > ------------------------------------------------------------------------- ------------------------------------ > I set my camera to record when movement is detected. It works quite well. I just turn it on and when I am moving whether taxiing or flying it is on and recording. When you stop it shuts off, and starts a new file when you begin moving again. The unit also has Wifi so you could theoretically control it with a smart phone. I prefer the record while moving setting. > > ------------------------------------------------------------------------- ---------------------------------- > > > I have my own domain name and access to a web server as a benefit of my > job. File size is no limit for me, but can be a pain for the viewing > public. I need to look into other file types but MP4 gives good compressi on > from the VIRB defaults and most people can view them. .AVI and .MOV work > but are larger in size. What file type do you upload to VIMEO? > > > ------------------------------------------------------------------------ ---------------------------------- > I upload to MP4 at the max quality- 1980 to 1080 @ 30 frames. Something, probably the service that you upload to is cutting the clarity of the video down to the point that it compares to about 280 kb rather than HD. As far as the security of the camera in the cradle goes. I used a safety wire but cut it off since I don't think you could knock it off without a wreck causing it. If you look at the picture of the wing mount you can see the safety wire. It isn't connected in that one but I used a fishing snap swivel to secure it to the mount. I do make my videos differently in that I rough out the video with the program that comes with the Virb. I then save it to a file and upload it to a Cyberlink Power Director program so that I can add music and a narrative. I don't see how that could improve anything, it would be more likely to screw the thing up than help it. Keep it up, Larry > > > -- > > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > > *If you forward this email, or any part of it, please remove my email > address before sending.* > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Apr 17, 2016
Subject: mail list
take me off mail list Gary Hux ghux(at)aol.com ________________________________________________________________________________
Subject: Re: video
Date: Apr 17, 2016
Another great video Larry keep'm coming Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455159#455159 ________________________________________________________________________________
Date: Apr 18, 2016
Subject: A bit of excitement
A neighbor was missing 6 horses and asked me to check the desert surrounding his ranch to see if I could find them. I had intended to go flying today anyway as I wanted to check some areas for nesting Falcons. My other hobby is falconry, and I want to get a new hawk this spring for hunting. No biggie, I can do both. I did find his horses and then proceeded to look for the Falcons. I landed on a Playa lake bed and proceeded to walk to the cliff that I wanted to check. When I returned, I turned on the Master switch, and no fuel pump clicking that I am used to. After checking and not being able to find what was wrong, I decided to start the engine and see if it would run. Keep in mind that I run my fuel line out of the tanks to a selector switch on the side of the pilot compartment. Then through a gascolator, up to a facett fuel pump then on the the pulse pump and to the carbs. about 4 feet lift. It started right up and seemed to have enough power to fly, so I decided to take off, circle the lake bed in case the engine quit. I got it off the ground and began circling, it seemed to be doing alright, but I knew that I wasn't going to be able to get all the fuel that I needed to fly the way that I normally do. I was about 5 miles off the main hwy, but there was a field tht had been cleared of Sage that cut off some of the distance. There was no way that I could get a trailer in there to get the plane out, without the possibility of getting in trouble with the BLM, as the area was listed as a Study area, and they do not want you to be making tracks in there at all. About the time that I decided that it wasn't going to quit the EIS warning light came on. I have the EGT's set for 1330 degrees, as the engine leans out to stop somewhere below 1500. The EGT's were showing 1420 and going up. I quickly throttled back and at 5000 RPM's it began to sink down to 1410. I circled a nother time and it stayed at that temp and I was still flying, so I decided to head to the Hwy, thinking that if worse came to worse I could make an emergency landing there and hope that no one ran me over afterward. Now I am much too impatient to fly at that low a speed, and I wasn't sure that I could maintain altitude at the level, but it did, even though I felt that I was slowly sinking into the ground. I nursed it home, flying over the road and back to my strip with no problem, but I was pretty wet under the arms, and dry in the mouth when I did land. The moral of this story is - Don't rule these pulse pumps out. They work better than you think. Here is a video of the event. https://vimeo.com/163326173 password- owyheeflyer Larry Click here to Reply or Forward -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Apr 19, 2016
Subject: Matronics Web Server Back Online
Dear Listers, The Matronics Web server lost a critical system hard drive yesterday 4/18/2016. I have been working feverishly for the last 24 hours to repair the system and get the Matronics Forums and other web-based resources back online. Email services were not impacted in anyway. back online and all resources were successfully restored from a backup. My apologies for the down time. Matt Dralle Matronics Email and Forum Admin ________________________________________________________________________________
Date: Apr 19, 2016
Subject: Re: Matronics Web Server Back Online
We've never met, but thank you sincerely for the tremendous resource that you have created in the forums, and for keeping it running. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Tue, 4/19/16, Matt Dralle wrote: Subject: Kolb-List: Matronics Web Server Back Online To: kolb-list(at)matronics.com Date: Tuesday, April 19, 2016, 1:43 PM Matt Dralle Dear Listers, The Matronics Web server lost a critical system hard drive yesterday 4/18/2016. I have been working feverishly for the last 24 hours to repair the system and get the Matronics Forums and other web-based resources back online. Email services were not impacted in anyway. 4/19/2016 the system is back online and all resources were successfully restored from a backup. My apologies for the down time. Matt Dralle Matronics Email and Forum Admin Lists This Month -- Some AWESOME FREE Gifts!) Raiser. Click on more about Gifts provided www.buildersbooks.com -Matt Dralle, List Admin. Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 19, 2016
You are very welcome! It is my pleasure! Matt Dralle At 02:04 PM 4/19/2016 Tuesday, you wrote: > >We've never met, but thank you sincerely for the tremendous resource that you have created in the forums, and for keeping it running. > >Bill Berle >www.ezflaphandle.com - safety & performance upgrade for light aircraft >www.grantstar.net - winning proposals for non-profit and for-profit entities > >-------------------------------------------- >On Tue, 4/19/16, Matt Dralle wrote: > > Subject: Kolb-List: Matronics Web Server Back Online > To: kolb-list(at)matronics.com > Date: Tuesday, April 19, 2016, 1:43 PM > > Matt Dralle > > Dear Listers, > > The Matronics Web server lost a critical system hard drive > yesterday 4/18/2016. I have been working feverishly for the > last 24 hours to repair the system and get the Matronics > Forums and other web-based resources back online. > > Email services were not impacted in anyway. > > 4/19/2016 the system is back online and all resources were > successfully restored from a backup. > > My apologies for the down time. > > Matt Dralle > Matronics Email and Forum Admin > > > > > > > Lists This Month -- > Some AWESOME FREE Gifts!) > Raiser. Click on > more about > Gifts provided > www.buildersbooks.com > -Matt > Dralle, List Admin. > Forum - > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > > Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Firefly for sale in Missouri
Date: Apr 20, 2016
http://springfield.craigslist.org/for/5547123378.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455255#455255 ________________________________________________________________________________
Subject: Re: Firefly for sale in Missouri
Date: Apr 20, 2016
it's not mine I just found it on Craigslist Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455256#455256 ________________________________________________________________________________
Date: Apr 20, 2016
Wow, that looks like the converted airstream trailer that John Gilpin had for his firefly. I saw it at the Rock House a few years ago and was impressed. -------- Roger in Oregon 1992 KXP 503 - N1782C Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455272#455272 ________________________________________________________________________________
Date: Apr 20, 2016
Wow, that looks like the converted airstream trailer that John Gilpin had for his firefly. I saw it at the Rock House a few years ago and was impressed. -------- Roger in Oregon 1992 KXP 503 - N1782C Roger H/Kolbers: That's it. Can't be but one of those. See the large caster wheels on the back of the trailer. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Apr 20, 2016
Naturally, trader Herb, called about the firefly...Chatted with the owner for an hour...well...let me rephrase that...I listened for an hour and he talked...:-) anyhow...late 90's Firefly, points ign 447...belt drive with wooden prop... the trailer looked fine....3k for it....6900 for the Firefly...He has two fireflies...the Gilpin one that he is keeping because of the BRS...Herb On 04/20/2016 08:47 PM, R. Hankins wrote: > > Wow, that looks like the converted airstream trailer that John Gilpin had for his firefly. I saw it at the Rock House a few years ago and was impressed. > > -------- > Roger in Oregon > 1992 KXP 503 - N1782C > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=455272#455272 > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
Date: Apr 20, 2016
I checked several times and each time the site was down, and I thought; "I bet Matt is busting his butt trying to get this fixed." Yep. Thanks a bunch for all you do! rp -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455276#455276 ________________________________________________________________________________
Date: Apr 21, 2016
victorbravo(at)sbcglobal. wrote: > We've never met, but thank you sincerely for the tremendous resource that you have created in the forums, and for keeping it running. > > Bill Berle > > . S . N . I . P . > Make sure you remember that when Matt's Fall Contribution Campaign comes around. -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455284#455284 ________________________________________________________________________________
Subject: Once around, It's Spring!
Date: Apr 22, 2016
Just a short video around the field to prove it's spring in Minnesota! It was a bit windy for me to adventure any further. https://vimeo.com/163883484 password KRNH447 -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455350#455350 ________________________________________________________________________________
Date: Apr 22, 2016
Subject: Re: Once around, It's Spring!
Thanks for the video. Send me a picture of where you have the camera mounted when you get a chance. You noticed of course that it camera settled down when you throttled back. It looked a bit like spring there. Yesterday here is SE Oregon it was 86 degrees yesterday, today the winds were 40 MPH. Larry On Fri, Apr 22, 2016 at 4:35 PM, west1m wrote: > > Just a short video around the field to prove it's spring in Minnesota! > It was a bit windy for me to adventure any further. > > https://vimeo.com/163883484 password KRNH447 > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=455350#455350 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Apr 22, 2016
I mounted it on the nose, attached on a plate above the "P" tube -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455352#455352 Attachments: http://forums.matronics.com//files/ffly2_124.jpg http://forums.matronics.com//files/ffly1_569.jpg ________________________________________________________________________________
Date: Apr 22, 2016
Thanks for the pictures, that was fast. Is it "springy"? The more solid it is the better the video. Other wise you will have to figure what RPM gives you less jumpy video. I used a 1x1/8th flat stock about 5 inches long, twisted 180 so that I could use a hole drilled in the side to secure the cradle. Thanks again, Larry On Fri, Apr 22, 2016 at 5:04 PM, west1m wrote: > > I mounted it on the nose, attached on a plate above the "P" tube > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=455352#455352 > > > Attachments: > > http://forums.matronics.com//files/ffly2_124.jpg > http://forums.matronics.com//files/ffly1_569.jpg > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: q
Date: Apr 22, 2016
It is with regret that I=99ve decided to sell my Kolb Xtra. built 2007 (but not by me), N740VP, Rotax 912UL, TT 113 hrs, BRS just repacked, Icom A6. just bench-checked. Insured for $30K but I think 22K is a more accurate value. Enclosed trainer available Plane is in Maine Russ K ________________________________________________________________________________
Subject: Re: q
Date: Apr 22, 2016
> On Apr 22, 2016, at 9:07 PM, Russ Kinne wrote: > > It is with regret that Ive decided to sell my Kolb Xtra. built 2007 (but not by me), N740VP, > Rotax 912UL, TT 113 hrs, BRS just repacked, Icom A6. just bench-checked. > Insured for $30K but I think 22K is a more accurate value. Enclosed trainer available > Plane is in Maine > Russ K > > <_MG_5003 2.jpg> ________________________________________________________________________________
Subject: 10 gal tank...
Date: Apr 22, 2016
anyone have a notion where a 10 gal poly tank can be bought? I will check with Bryan on Monday if need be..Herb ________________________________________________________________________________
Subject: Re: q
Date: Apr 23, 2016
Sorry you are selling Russ. Pretty looking plane. Pat From: Russ Kinne Sent: Saturday, April 23, 2016 2:07 AM Subject: Kolb-List: q It is with regret that I=99ve decided to sell my Kolb Xtra. built 2007 (but not by me), N740VP, Rotax 912UL, TT 113 hrs, BRS just repacked, Icom A6. just bench-checked. Insured for $30K but I think 22K is a more accurate value. Enclosed trainer available Plane is in Maine Russ K ________________________________________________________________________________
Date: Apr 23, 2016
Subject: Re: 10 gal tank...
SGVyYiwgVGFrZSBhIGxvb2sgYXQgdGhlIHRhbmsgdXNlZCBpbiB0aGUgQ2hhbGxlbmdlcnMuIEkg ZG9uJ3QgcmVtZW1iZXIgdGhlDQpzaXplIG9mZiAgaGFuZCBidXQgSSBkbyBrbm93IGl0J3MgYmln Z2VyIHRoYW4gdGhlIDUgZ2FsbG9uIHVzZWQgYnkgS29sYi4NCg0KUmljayBHaXJhcmQNCg0KT24g RnJpLCBBcHIgMjIsIDIwMTYgYXQgODozNyBQTSwgSGVyYiA8SGVyYmdoQG5jdGMuY29tPiB3cm90 ZToNCg0KPiAtLT4gS29sYi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBIZXJiIDxIZXJiZ2hAbmN0 Yy5jb20+DQo+DQo+DQo+DQo+IGFueW9uZSBoYXZlIGEgbm90aW9uIHdoZXJlIGEgMTAgZ2FsIHBv bHkgdGFuayBjYW4gYmUgYm91Z2h0PyAgSSB3aWxsIGNoZWNrDQo+IHdpdGggQnJ5YW4gb24gTW9u ZGF5IGlmIG5lZWQgYmUuLkhlcmINCj4NCj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj4gXy09ICAgICAgICAgIC0gVGhlIEtv bGItTGlzdCBFbWFpbCBGb3J1bSAtDQo+IF8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1 cmVzIE5hdmlnYXRvciB0byBicm93c2UNCj4gXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1 Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQo+IF8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25s b2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCj4gXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNo IG11Y2ggbW9yZToNCj4gXy09DQo+IF8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20v TmF2aWdhdG9yP0tvbGItTGlzdA0KPiBfLT0NCj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj4gXy09ICAgICAgICAgICAgICAg LSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQo+IF8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBh dmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KPiBfLT0NCj4gXy09ICAgLS0+IGh0dHA6Ly9m b3J1bXMubWF0cm9uaWNzLmNvbQ0KPiBfLT0NCj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj4gXy09ICAgICAgICAgICAgICAt IE5FVyBNQVRST05JQ1MgTElTVCBXSUtJIC0NCj4gXy09IEFkZCBzb21lIGluZm8gdG8gdGhlIE1h dHJvbmljcyBFbWFpbCBMaXN0IFdpa2khDQo+IF8tPSAgIC0tPiBodHRwOi8vd2lraS5tYXRyb25p Y3MuY29tDQo+IF8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09DQo+IF8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdl YiBTaXRlIC0NCj4gXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCj4g Xy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWlu Lg0KPiBfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KPiBf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PQ0KPg0KPg0KPg0KPg0KDQoNCi0tIA0K4oCcQmxlc3NlZCBhcmUgdGhlIGNyYWNrZWQsIGZv ciB0aGV5IHNoYWxsIGxldCBpbiB0aGUgbGlnaHQu4oCdICAgR3JvdWNobyBNYXJ4DQo8aHR0cDov L3d3dy5nb29kcmVhZHMuY29tL2F1dGhvci9zaG93LzQzMjQ0Lkdyb3VjaG9fTWFyeD4NCg= ________________________________________________________________________________
Subject: q
Date: Apr 23, 2016
Herb Ive seen catalogs with dozens of tanx in all sizes. Try Macmasters-Carr or a boating dealer. You should be able to get any size you want. If price is no object, get an aluminum one welded up ________________________________________________________________________________
Date: Apr 23, 2016
On 4/22/2016 9:37 PM, Herb wrote: > > > anyone have a notion where a 10 gal poly tank can be bought? I will > check with Bryan on Monday if need be..Herb > You might try Summit Racing near Akron Ohio lots of tanks. Summitracing.com Then type in fuel cells. Many different ways to search for the tank your looking for on the site. Jack Carillon FSII Akron Oh. > > ________________________________________________________________________________
Date: Apr 24, 2016
Jack The tank I need is just a larger version of the 5 gal tank that Kolb uses... I think Bryan at the factory will have them or know where to get same... Herb On 04/23/2016 08:51 PM, Jack wrote: > > On 4/22/2016 9:37 PM, Herb wrote: >> >> >> >> anyone have a notion where a 10 gal poly tank can be bought? I will >> check with Bryan on Monday if need be..Herb >> > You might try Summit Racing near Akron Ohio lots of tanks. > Summitracing.com Then type in fuel cells. Many different ways > to search for the tank your looking for on the site. > > Jack Carillon FSII Akron Oh. >> >> > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
Date: Apr 24, 2016
gonna fit it in a Firefly ! :-) gotta be quite the same material and very lite....Herb On 04/23/2016 02:33 PM, Richard Girard wrote: > Herb, Take a look at the tank used in the Challengers. I don't > remember the size off hand but I do know it's bigger than the 5 > gallon used by Kolb. > > Rick Girard > > On Fri, Apr 22, 2016 at 8:37 PM, Herb > wrote: > > > > > > anyone have a notion where a 10 gal poly tank can be bought? I > will check with Bryan on Monday if need be..Herb > > ========== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > > -- > > > Blessed are the cracked, for they shall let in the light. Groucho > Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
Date: Apr 24, 2016
VGhlIDEwIGdhbGxvbiB0YW5rIGZvciBhIENoYWxsZW5nZXIgaXMgd2hhdCBEb24gRy4gYnVpbHQg dGhlIHNwYWNlIGZvciBpbiB0aGUgRmxhZ0ZseS4gSXQgZml0IGJlYXV0aWZ1bGx5IGJlaGluZCB0 aGUgc2VhdCDCoAoKRGF2ZSBLdWxwCgoKU2VudCBmcm9tIG15IFZlcml6b24gV2lyZWxlc3MgNEcg TFRFIHNtYXJ0cGhvbmUKCjxkaXY+LS0tLS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLTwv ZGl2PjxkaXY+RnJvbTogSGVyYiA8SGVyYmdoQG5jdGMuY29tPiA8L2Rpdj48ZGl2PkRhdGU6MDQv MjQvMjAxNiAgOTozMSBBTSAgKEdNVC0wNTowMCkgPC9kaXY+PGRpdj5Ubzoga29sYi1saXN0QG1h dHJvbmljcy5jb20gPC9kaXY+PGRpdj5TdWJqZWN0OiBSZTogS29sYi1MaXN0OiAxMCBnYWwgdGFu ay4uLiA8L2Rpdj48ZGl2Pgo8L2Rpdj4tLT4gS29sYi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBI ZXJiIDxIZXJiZ2hAbmN0Yy5jb20+CgpKYWNrCgogIFRoZSB0YW5rIEkgbmVlZCBpcyBqdXN0IGEg bGFyZ2VyIHZlcnNpb24gb2YgdGhlIDUgZ2FsIHRhbmsgdGhhdCBLb2xiIAp1c2VzLi4uCgogICBJ IHRoaW5rIEJyeWFuIGF0IHRoZSBmYWN0b3J5IHdpbGwgaGF2ZSB0aGVtIG9yIGtub3cgd2hlcmUg dG8gZ2V0IHNhbWUuLi4KCiAgIEhlcmIKCk9uIDA0LzIzLzIwMTYgMDg6NTEgUE0sIEphY2sgd3Jv dGU6Cj4gLS0+IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogSmFjayA8cGNhcmlsbG9uc3JA bmVvLnJyLmNvbT4KPgo+IE9uIDQvMjIvMjAxNiA5OjM3IFBNLCBIZXJiIHdyb3RlOgo+PiAtLT4g S29sYi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBIZXJiIDxIZXJiZ2hAbmN0Yy5jb20+Cj4+Cj4+ Cj4+Cj4+IGFueW9uZSBoYXZlIGEgbm90aW9uIHdoZXJlIGEgMTAgZ2FsIHBvbHkgdGFuayBjYW4g YmUgYm91Z2h0PyAgSSB3aWxsIAo+PiBjaGVjayB3aXRoIEJyeWFuIG9uIE1vbmRheSBpZiBuZWVk IGJlLi5IZXJiCj4+Cj4gICAgICAgICAgICBZb3UgbWlnaHQgIHRyeSBTdW1taXQgUmFjaW5nIG5l YXIgQWtyb24gT2hpbyBsb3RzIG9mIHRhbmtzLgo+ICAgICAgU3VtbWl0cmFjaW5nLmNvbSAgIFRo ZW4gdHlwZSBpbiBmdWVsIGNlbGxzLiAgTWFueSBkaWZmZXJlbnQgd2F5cyAKPiB0byBzZWFyY2gg Zm9yIHRoZSB0YW5rIHlvdXIgbG9va2luZyBmb3Igb24gdGhlIHNpdGUuCj4KPiAgICBKYWNrIENh cmlsbG9uIEZTSUkgQWtyb24gT2guCj4+Cj4+Cj4KPgo+Cj4KPgoKLS0gClNpZ25hdHVyZSB0ZXh0 OyBGb3J0IE1hcmN5IFBhcms/ICBTdXJlLi4uTXIuIEZvc3Rlci4uLlRoaXJkIHJlZCBsaWdodCBh bmQgdHVybiBsZWZ0LgoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRoZSBLb2xiLUxpc3QgRW1haWwg Rm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8g YnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2Ny aXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0 LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT0gICAtLT4g aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Lb2xiLUxpc3QKXy09Cl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8t PSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQpfLT0gU2FtZSBncmVhdCBj b250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyEKXy09Cl8tPSAgIC0tPiBo dHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAgICAgLSBO RVcgTUFUUk9OSUNTIExJU1QgV0lLSSAtCl8tPSBBZGQgc29tZSBpbmZvIHRvIHRoZSBNYXRyb25p Y3MgRW1haWwgTGlzdCBXaWtpIQpfLT0gICAtLT4gaHR0cDovL3dpa2kubWF0cm9uaWNzLmNvbQpf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAg VGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93 d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KCgoK ________________________________________________________________________________
Date: Apr 24, 2016
I went to their site...Quad Cities...but found no listing for parts....I will call them tomorrow...thanks..Herb On 04/24/2016 10:06 AM, undoctor wrote: > The 10 gallon tank for a Challenger is what Don G. built the space for > in the FlagFly. It fit beautifully behind the seat > > Dave Kulp > > > Sent from my Verizon Wireless 4G LTE smartphone > > > -------- Original message -------- > From: Herb > Date:04/24/2016 9:31 AM (GMT-05:00) > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: 10 gal tank... > > > Jack > > The tank I need is just a larger version of the 5 gal tank that Kolb > uses... > > I think Bryan at the factory will have them or know where to get > same... > > Herb > > On 04/23/2016 08:51 PM, Jack wrote: > > > > On 4/22/2016 9:37 PM, Herb wrote: > >> > >> > >> > >> anyone have a notion where a 10 gal poly tank can be bought? I will > >> check with Bryan on Monday if need be..Herb > >> > > You might try Summit Racing near Akron Ohio lots of tanks. > > Summitracing.com Then type in fuel cells. Many different ways > > to search for the tank your looking for on the site. > > > > Jack Carillon FSII Akron Oh. > >> > >> > > > > > > > > > > > > -- > Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light > and turn left. > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
Date: Apr 24, 2016
Herb I got two 6 gallon tanks from Travis at Kolb a few years ago they are the same as the 5 gallon tanks just taller. At one point the 6 gallon tanks were a bit thinner but the ones I have are the same as the 5 gallon tanks. They are more likely to fit without any modification. Rick Neilsen Redrive VW Powered MKIIIC On Sun, Apr 24, 2016 at 9:31 AM, Herb wrote: > > Jack > > The tank I need is just a larger version of the 5 gal tank that Kolb > uses... > > I think Bryan at the factory will have them or know where to get same... > > Herb > > On 04/23/2016 08:51 PM, Jack wrote: > >> >> On 4/22/2016 9:37 PM, Herb wrote: >> >>> >>> >>> >>> anyone have a notion where a 10 gal poly tank can be bought? I will >>> check with Bryan on Monday if need be..Herb >>> >>> You might try Summit Racing near Akron Ohio lots of tanks. >> Summitracing.com Then type in fuel cells. Many different ways to >> search for the tank your looking for on the site. >> >> Jack Carillon FSII Akron Oh. >> >>> >>> >>> >> >> >> >> >> > -- > Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and > turn left. > > ________________________________________________________________________________
Date: Apr 24, 2016
The tank in Dave's Flag Fly is the one I need...Herb On 04/24/2016 11:45 AM, Rick Neilsen wrote: > Herb > > I got two 6 gallon tanks from Travis at Kolb a few years ago they are > the same as the 5 gallon tanks just taller. At one point the 6 gallon > tanks were a bit thinner but the ones I have are the same as the 5 > gallon tanks. They are more likely to fit without any modification. > > Rick Neilsen > Redrive VW Powered MKIIIC > > On Sun, Apr 24, 2016 at 9:31 AM, Herb > wrote: > > > > > Jack > > The tank I need is just a larger version of the 5 gal tank that > Kolb uses... > > I think Bryan at the factory will have them or know where to get > same... > > Herb > > On 04/23/2016 08:51 PM, Jack wrote: > > > > > On 4/22/2016 9:37 PM, Herb wrote: > > > > > > anyone have a notion where a 10 gal poly tank can be > bought? I will check with Bryan on Monday if need be..Herb > > You might try Summit Racing near Akron Ohio lots > of tanks. > Summitracing.com Then type in fuel cells. Many > different ways to search for the tank your looking for on the > site. > > Jack Carillon FSII Akron Oh. > > > -- > Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red > light and turn left. > > > ========== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
From: "KIRBY, DENNIS T GS-13 USAF AFMC AFNWC/EZS" <dennis.kirby.3(at)us.af.mil>
Subject: Securing Muffler Springs
Date: Apr 25, 2016
Kolb Friends - I'm sharing with you a tip that may prevent you some grief that I encountered recently on my Mark-3. One of my muffler springs broke on a recent flight and departed the engine. Went thru my Powerfin prop and it took a bite-sized chunk out of the leading edge of one prop blade. Damage was beyond repair - cost of a new blade was $250. All 8 springs on my Rotax-912 muffler are safety-wired, per common practice intended at securing the spring when (not if) they break. I always check the safety wire on each muffler spring as part of my preflight. Apparently on this day, one of these safety wires was worn partially through and still appeared secure when I checked it. When the spring broke in flight, the instantaneous energy must have been sufficient to break the already-weakened safety wire, resulting in the spring's departure from the engine. Double failure. So, here's the tip: I will no longer rely on ordinary safety wire to secure my Rotax muffler springs. I've upgraded to 1/16" braided cable to secure these springs. This is bicycle brake cable, available at any bike shop. I use one piece (about 10 inches long) for each pair of springs. The cable ends are joined and secured using a swaged ferrule. Cheap, easy to install, and most of all, WAY more secure than a single strand of .032 safety wire! Constant engine vibration will not wear thru it, as it does on safety wire. Fly safely ... Dennis Kirby Mark-3 / 912ul Sandia Park, NM ________________________________________________________________________________
Date: Apr 25, 2016
Dennis, Very interesting. Thanks for sharing. Makes me want to use the flange/bolt method. Did you use RTV to keep the safety wire from bouncing around and wearing out? I have always done this, but don't like not being able to see the wire and judge its condition. Do you have any pictures of your new method? Question for the group. Do you think the stainless steel springs are better, and would it be a good idea to just replace the springs at say spark plug replacement intervals? Thanks, Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of KIRBY, DENNIS T GS-13 USAF AFMC AFNWC/EZS Sent: Monday, April 25, 2016 1:38 PM Subject: Kolb-List: Securing Muffler Springs --> AFNWC/EZS" Kolb Friends - I'm sharing with you a tip that may prevent you some grief that I encountered recently on my Mark-3. One of my muffler springs broke on a recent flight and departed the engine. Went thru my Powerfin prop and it took a bite-sized chunk out of the leading edge of one prop blade. Damage was beyond repair - cost of a new blade was $250. All 8 springs on my Rotax-912 muffler are safety-wired, per common practice intended at securing the spring when (not if) they break. I always check the safety wire on each muffler spring as part of my preflight. Apparently on this day, one of these safety wires was worn partially through and still appeared secure when I checked it. When the spring broke in flight, the instantaneous energy must have been sufficient to break the already-weakened safety wire, resulting in the spring's departure from the engine. Double failure. So, here's the tip: I will no longer rely on ordinary safety wire to secure my Rotax muffler springs. I've upgraded to 1/16" braided cable to secure these springs. This is bicycle brake cable, available at any bike shop. I use one piece (about 10 inches long) for each pair of springs. The cable ends are joined and secured using a swaged ferrule. Cheap, easy to install, and most of all, WAY more secure than a single strand of .032 safety wire! Constant engine vibration will not wear thru it, as it does on safety wire. Fly safely ... Dennis Kirby Mark-3 / 912ul Sandia Park, NM ________________________________________________________________________________
Date: Apr 25, 2016
Subject: exhaust springs
Dennis fyi... the safety wire on my Springs do not have to be tight, that is the springs job... after putting the springs on, I run the safety wire through the spring. then run a bead of silicone rubber in the spring to encapsulate the wire. the silicone keeps things from vibrating. that is the belt, and for the suspenders.... I install a second piece of safety wire from the center point of one spring to the center point of the next. also silicone on the ends. the second wire is tight enough to pull the two springs very slightly out of column. this out of column should keep things from excessive vibration movement.. should one spring fail, the through ( belt safety) wire should keep it close... should that also fail the ( suspenders) should keep things out of the prop. Boyd Young ________________________________________________________________________________
Date: Apr 25, 2016
Dennis K/Kolbers: Until I went the expensive SS spring route, I had problems with breaking springs. They didn't go through the prop because I use a lot of silicone seal to encapsulate the entire spring from one end to the other, including the hooks. No need for safety wire. I bought a set of SS springs to go with my new Titan exhaust system, some 800 hours ago. The springs are pricey, but they work. Well worth the money. As far as props go. The reason I use WARP Drive props is because I can't find a better one for performance and for durability/reliability. You could have put that spring through a WARP Drive blade and kept on flying. Probably take a little cosmetic work, but not a new blade. Here is the url for the springs: http://jbmindustries.com/SOCKET.html john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of KIRBY, DENNIS T GS-13 USAF AFMC AFNWC/EZS Sent: Monday, April 25, 2016 1:38 PM Subject: Kolb-List: Securing Muffler Springs --> AFNWC/EZS" Kolb Friends - I'm sharing with you a tip that may prevent you some grief that I encountered recently on my Mark-3. One of my muffler springs broke on a recent flight and departed the engine. Went thru my Powerfin prop and it took a bite-sized chunk out of the leading edge of one prop blade. Damage was beyond repair - cost of a new blade was $250. All 8 springs on my Rotax-912 muffler are safety-wired, per common practice intended at securing the spring when (not if) they break. I always check the safety wire on each muffler spring as part of my preflight. Apparently on this day, one of these safety wires was worn partially through and still appeared secure when I checked it. When the spring broke in flight, the instantaneous energy must have been sufficient to break the already-weakened safety wire, resulting in the spring's departure from the engine. Double failure. So, here's the tip: I will no longer rely on ordinary safety wire to secure my Rotax muffler springs. I've upgraded to 1/16" braided cable to secure these springs. This is bicycle brake cable, available at any bike shop. I use one piece (about 10 inches long) for each pair of springs. The cable ends are joined and secured using a swaged ferrule. Cheap, easy to install, and most of all, WAY more secure than a single strand of .032 safety wire! Constant engine vibration will not wear thru it, as it does on safety wire. Fly safely ... Dennis Kirby Mark-3 / 912ul Sandia Park, NM ________________________________________________________________________________
Subject: Re: Securing Muffler Springs
Date: Apr 25, 2016
Silicon? Safety wire? Um - no. How about some 5/16" bolts and springs from Ace hardware? The lugs that the bolts go through are cut off the ends of some big muffler clamps and welded to the pipes. Drill a hole in the end of the bolts and put a cotter pin through them. Replace them every year during condition inspection. Don't know how a 912 exhaust is configured, so it might not work for that application. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455466#455466 Attachments: http://forums.matronics.com//files/exhbolts_143.jpg ________________________________________________________________________________
Date: Apr 26, 2016
I, too switched to SS springs on my 912 ULS with its Titan exhaust. Stainless Steel springs cured the problem of periodic breakage, although I only flew it about 50 hours after the installation before it was sold. It was always a pain when doing pre-flight and noticing that I needed to replace a spring, assuming I missed it on the post-flight inspection. Here's another twist- at one point, I noticed that the tangs on the exhaust system that the springs hooked to showed considerable wear from the vibration, and I had two of them tig welded to build them up as soon as I noticed it. It's worth checking, because that would be another way to lose a spring and the safety wire connection as well. If you use high temp goop on both ends of the spring where it connects to the tang, any wear could go unnoticed. Dave Watkins Pompano Beach, Fl Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455477#455477 ________________________________________________________________________________
Date: Apr 26, 2016
stainless steel springs give an added margin of saftey.From JBM. > On Apr 25, 2016, at 2:38 PM, KIRBY, DENNIS T GS-13 USAF AFMC AFNWC/EZS wrote: > > > Kolb Friends - > > I'm sharing with you a tip that may prevent you some grief that I encountered recently on my Mark-3. One of my muffler springs broke on a recent flight and departed the engine. Went thru my Powerfin prop and it took a bite-sized chunk out of the leading edge of one prop blade. Damage was beyond repair - cost of a new blade was $250. > > All 8 springs on my Rotax-912 muffler are safety-wired, per common practice intended at securing the spring when (not if) they break. I always check the safety wire on each muffler spring as part of my preflight. Apparently on this day, one of these safety wires was worn partially through and still appeared secure when I checked it. When the spring broke in flight, the instantaneous energy must have been sufficient to break the already-weakened safety wire, resulting in the spring's departure from the engine. Double failure. > > So, here's the tip: I will no longer rely on ordinary safety wire to secure my Rotax muffler springs. I've upgraded to 1/16" braided cable to secure these springs. This is bicycle brake cable, available at any bike shop. I use one piece (about 10 inches long) for each pair of springs. The cable ends are joined and secured using a swaged ferrule. Cheap, easy to install, and most of all, WAY more secure than a single strand of .032 safety wire! Constant engine vibration will not wear thru it, as it does on safety wire. > > Fly safely ... > > Dennis Kirby > Mark-3 / 912ul > Sandia Park, NM > > > > > ________________________________________________________________________________
Subject: new to Kolb list
Date: Apr 28, 2016
Hello I am new to the Kolb list and new to the UL airplane too. in my youth i would fly with my dad in his Cessna 150 and also flew it myself some,but always with my dad. that was thirty some years ago and now i am in a position to have my own plane again. i still have my own runway although it needs some repair but that won't be a problem. I have purchased a Kolb Firefly for my first UL and just found this list. any suggestions on how i should go about learning to fly the Firefly? any advice or criticism is welcome. Thanks John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455590#455590 ________________________________________________________________________________
Date: Apr 28, 2016
Subject: Re: new to Kolb list
It is absolutely essential and critical for you to get at least a few hours of flight instruction. Especially since your previous experiences were many years ago.I'm not saying you need 30 or 40 hours of expensive flight training. I'm saying you need a few hours, depending on your previous experience and how fast you pick up the physical feeling, instinct, and understanding of flight principles. If you can find a light-sport / LSA instructor, or an ultralight instructor, you will be better off than if you just went to a regular Cessna or Piper general aviation flight school. Contact the US Ultralight Association USUA, and they will help you find somewhere close. USUA is very focused on safety and making sure you have a safe, enjoyable experience with your aircraft. DO NOT just try to "teach yourself" by being careful and doing it somewhere by yourself. This is nearly guaranteed to damage your aircraft needlessly. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Thu, 4/28/16, flywithme wrote: Subject: Kolb-List: new to Kolb list To: kolb-list(at)matronics.com Date: Thursday, April 28, 2016, 2:29 PM "flywithme" Hello I am new to the Kolb list and new to the UL airplane too. in my youth i would fly with my dad in his Cessna 150 and also flew it myself some,but always with my dad. that was thirty some years ago and now i am in a position to have my own plane again. i still have my own runway although it needs some repair but that won't be a problem. I have purchased a Kolb Firefly for my first UL and just found this list. any suggestions on how i should go about learning to fly the Firefly? any advice or criticism is welcome.ThanksJohn Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455590#455590 Forum - - MATRONICS WEB FORUMS - MATRONICS LIST WIKI - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 28, 2016
Hi John, Welcome to the world of Kolb and this list! You will find a wide range of experiences and advice from this list. Search "first flights" and see what comes up. There are different opinions on how to do a first flight. I would recommend reading all of them. The more you know, the better prepared you will be. Based on what you have posted so far, it would appear that you do not have any formal flight training. That is OK but would indicate that you probably need more experience. Do you have much experience with take offs and landings or just driving around the sky? I LOVE my Firefly! It is a really fun airplane to fly but it is NOT a Cessna 150. I had lots of hours in an Aeronca Chief which is closer to the Firefly than the 150 but it was still a lot different than the Firefly. 250 pounds aircraft weight acts a lot differently than 800 pounds. I would say that based on what you have said so far, some dual time in the lightest tail dragger you can find is essential for you. I would recommend finding someplace that you can take enough lessons to at least solo in a taildragger. They are a completely different machine than a tri-cycle gear. Not bad, just different. There is a reason that the FAA requires a sign off for tailwheel flight. If you can find someone to give you lessons in a two place Kolb go for it! Buy the gas, buy lunch, whatever you have to do to get time in a Kolb, even if not "official" training. After that I would look for any other very light weight (LSA) taildragger. IF not available, a Cub or Champ would be the next closest. Once you can solo one of these, you will have a much better idea of what a Firefly will be like. BUT, not quite, the Firefly is a true ultralight and you need to be ready for the extra light weight. Also a Kolb with a high mounted engine has different inputs than a centerline mounted engine. Again, NOT bad, just different. The advice that Bill gave is spot on. In a way it may be good that you don't have lots of hours in a type of aircraft that is way different. That way you won't have as much to "un-learn" or put another way, you probably don't have any bad habits that need correcting. Do you already have a Firefly? If not, are you going to get a used one or order a new one from the factory? Bryan (owner of Kolb) is a really swell guy and will NOT steer you wrong. If you are still looking, please give him a call at the factory and introduce yourself. You will be glad you did. Please let the rest of us know more about you. Where you live, if you have a Firefly already, what your runway is like, etc. There may be an owner nearby that will help you out. This list is a pretty giving bunch of pilots. Lastly, if you have read this far, Please, Please, Please don't take any of this as "know it all" or "preachy" or "snobbish". I don't like "safety police" myself and will only say that I would rather have a lively discussion on this list than read about you in the "bad" report from the FAA. Your safety is YOUR business, not mine. You asked for advice, so there it is... Offered at the exact price you paid for it. Again, WELCOME, and let's talk more, Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of flywithme Sent: Thursday, April 28, 2016 4:30 PM Subject: Kolb-List: new to Kolb list Hello I am new to the Kolb list and new to the UL airplane too. in my youth i would fly with my dad in his Cessna 150 and also flew it myself some,but always with my dad. that was thirty some years ago and now i am in a position to have my own plane again. i still have my own runway although it needs some repair but that won't be a problem. I have purchased a Kolb Firefly for my first UL and just found this list. any suggestions on how i should go about learning to fly the Firefly? any advice or criticism is welcome. Thanks John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455590#455590 ________________________________________________________________________________
Subject: q
Date: Apr 28, 2016
> > It is with regret that I=99ve decided to sell my Kolb Xtra. built 2007 (but not by me), N740VP, > Rotax 912UL, TT 113 hrs, BRS just repacked, Icom A6. just bench-checked. > Insured for $30K but I think 22K is a more accurate value. Enclosed trailer available > Plane is in Maine > Russ K > > ________________________________________________________________________________
Date: Apr 29, 2016
Thanks for the replies. I already have a firefly but i don't intend to try to fly it until i get some instruction. right now i am trying to evaluate the aircraft and familiarize myself with the whole ultralite concept. i will probably unfold the airplane and do some extensive taxi around the place just to familiarize myself with the feel of such a lite aircraft. i need to familiarize myself with the Rotax engine and all of its different aspects and maintenance needs etc. are there any special needs the firefly has that i should address while i am getting some instruction? i have been going over all of the welds,cables,hoses and wires etc looking for anything that could cause a problem when in the air. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455624#455624 ________________________________________________________________________________
Date: Apr 29, 2016
From: william sullivan <williamtsullivan(at)att.net>
Bookmark this: http://jackbhart.com/firefly/firefly.html Jack Hart is an engineer, and has thoroughly documented his Firefly. Enjoy! Bill Sullivan -------------------------------------------- On Fri, 4/29/16, flywithme wrote: Subject: Kolb-List: Re: new to Kolb list To: kolb-list(at)matronics.com Date: Friday, April 29, 2016, 1:18 PM "flywithme" Thanks for the replies. I already have a firefly but i don't intend to try to fly it until i get some instruction. right now i am trying to evaluate the aircraft and familiarize myself with the whole ultralite concept. i will probably unfold the airplane and do some extensive taxi around the place just to familiarize myself with the feel of such a lite aircraft. i need to familiarize myself with the Rotax engine and all of its different aspects and maintenance needs etc. are there any special needs the firefly has that i should address while i am getting some instruction? i have been going over all of the welds,cables,hoses and wires etc looking for anything that could cause a problem when in the air. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455624#455624 Forum - - MATRONICS WEB FORUMS - MATRONICS LIST WIKI - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 29, 2016
Keep in mind that when you taxi around you ARE flying it. So make sure it and you are both ready for flight. Many people who have "just taxied" ended up in the air. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455627#455627 ________________________________________________________________________________
Date: Apr 29, 2016
The pilot will be the primary "cause of a problem when in the air." Be very careful during your familiarization to taxi exercise. Fast taxi and a gust of wind will have you airborne and committed to flight in the blink of an eye. More than one inexperienced Kolb pilot has found himself in that situation. If it was me, I'd wait for taxi exercises until after I had become qualified to fly the Firefly. My opinion only. john h MKIII-3,400.00 hours airframe 912ULS-800.0 hours engine 6,000.00+ hours Kolb PIC Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of flywithme Sent: Friday, April 29, 2016 12:19 PM Subject: Kolb-List: Re: new to Kolb list Thanks for the replies. I already have a firefly but i don't intend to try to fly it until i get some instruction. right now i am trying to evaluate the aircraft and familiarize myself with the whole ultralite concept. i will probably unfold the airplane and do some extensive taxi around the place just to familiarize myself with the feel of such a lite aircraft. i need to familiarize myself with the Rotax engine and all of its different aspects and maintenance needs etc. are there any special needs the firefly has that i should address while i am getting some instruction? i have been going over all of the welds,cables,hoses and wires etc looking for anything that could cause a problem when in the air. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455624#455624 ________________________________________________________________________________
Date: Apr 29, 2016
Two things that come to mind is that the high mounted engine can cause the Firefly to nose over with just an application of too much power. And with a 447 and gear box it requires left rudder input unlike a "conventional" tail dragger such as a Cub or Champ which require right rudder. For doing engine break-in or other run ups, be sure to have the tail tied down tight, it can nose over on you! -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck Sent: Friday, April 29, 2016 1:48 PM Subject: RE: Kolb-List: Re: new to Kolb list The pilot will be the primary "cause of a problem when in the air." Be very careful during your familiarization to taxi exercise. Fast taxi and a gust of wind will have you airborne and committed to flight in the blink of an eye. More than one inexperienced Kolb pilot has found himself in that situation. If it was me, I'd wait for taxi exercises until after I had become qualified to fly the Firefly. My opinion only. john h MKIII-3,400.00 hours airframe 912ULS-800.0 hours engine 6,000.00+ hours Kolb PIC Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of flywithme Sent: Friday, April 29, 2016 12:19 PM Subject: Kolb-List: Re: new to Kolb list Thanks for the replies. I already have a firefly but i don't intend to try to fly it until i get some instruction. right now i am trying to evaluate the aircraft and familiarize myself with the whole ultralite concept. i will probably unfold the airplane and do some extensive taxi around the place just to familiarize myself with the feel of such a lite aircraft. i need to familiarize myself with the Rotax engine and all of its different aspects and maintenance needs etc. are there any special needs the firefly has that i should address while i am getting some instruction? i have been going over all of the welds,cables,hoses and wires etc looking for anything that could cause a problem when in the air. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455624#455624 ________________________________________________________________________________
Date: Apr 29, 2016
John makes a real good point about taxing and it doesn't need to be a wind gust. You can be taxing along just fine and you cut the power. It can leap into the air with no power. Not good. Then you add power and it will nose down still below flying speed. Again not good and even worse. The high thrust line isn't a problem it is just unique and it takes practice to handle and at low speed it is more exaggerated. Just keep saying add power the plane will pitch down pull the stick back. Reduce power the plane will pitch up push the stick forward. There are two things that will bite you if you aren't really good and ready. The first is fast taxi. Don't do it as a learning tool. The next is a crow hop. Don't do it. One more thing that is unique to all very light planes is the low inertia. Flying a Cessna 150 will not help you in this area. When you come in for a landing in a Kolb you need to fly right down to about one foot before you flair. Kolbs bleed speed away considerably quicker than bigger heaver planes. In a Cessna 150 you will learn to start your flair at 30-50 feet and heaver faster planes even higher. This will work against you when you then fly a kolb. To make things easier while learning landings in a Kolb make you approach faster and with some power. Kolbs need little runway, so a longer landing shouldn't be a problem. Do use a long grass strip for practice. If you do have to add power for a missed approach add power slowly and do it before you get close to the ground. I can't say it too often add power pull back reduce power push forward. Again worth what you paid for it Rick Neilsen Redrive VW Powered MKIIIC On Fri, Apr 29, 2016 at 2:47 PM, John Hauck wrote: > > The pilot will be the primary "cause of a problem when in the air." > > Be very careful during your familiarization to taxi exercise. Fast taxi > and > a gust of wind will have you airborne and committed to flight in the blink > of an eye. More than one inexperienced Kolb pilot has found himself in > that > situation. > > If it was me, I'd wait for taxi exercises until after I had become > qualified > to fly the Firefly. > > My opinion only. > > john h > MKIII-3,400.00 hours airframe > 912ULS-800.0 hours engine > 6,000.00+ hours Kolb PIC > Titus, Alabama > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of flywithme > Sent: Friday, April 29, 2016 12:19 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: new to Kolb list > > > Thanks for the replies. I already have a firefly but i don't intend to try > to fly it until i get some instruction. right now i am trying to evaluate > the aircraft and familiarize myself with the whole ultralite concept. i > will > probably unfold the airplane and do some extensive taxi around the place > just to familiarize myself with the feel of such a lite aircraft. i need to > familiarize myself with the Rotax engine and all of its different aspects > and maintenance needs etc. are there any special needs the firefly has that > i should address while i am getting some instruction? i have been going > over > all of the welds,cables,hoses and wires etc looking for anything that could > cause a problem when in the air. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=455624#455624 > > ________________________________________________________________________________
Date: Apr 29, 2016
Subject: Re: Question about building vertical fin
I have finished constructing the two triangular horizontal stabilizers, and have started on the vertical fin and steel rear fuselage ring. As many of you know by heart, the vertical "spar" tube on the back of the fin is one inch diameter tube. The leading edge is 3/4 inch tube. When I riveted the gusset to one side of this intersection, it "pulled" the 3/4 inch tube over flush with the side of the one inch tube. So when I went to install the gusset on the other side I realized the fin leading edge is no longer on the centerline of the fin. I'm sure this is not a BIG deal in terms of safety, but it's not right from a quality perspective. Is there a known "fix" for this? I don't want to drill out the rivets and goober up the rivet holes, especially since I cannot 100% locate those previous holes if I want to replace the tube. Has anyone else run into this while building the fin? Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities ________________________________________________________________________________
Date: Apr 29, 2016
Hello Newcomer, Welcome.. This is such an important question that I had to give my 2 cents worth. before I flew my Xtra I did two things:- 1/ I got a ride in a KOLB MkIII that was local to give me the sight picture you get from that aircraft... Its unique but I then knew what to expect. 2/ I flew ALOT in a Champ, to get as close experience as I could to a Kolb. It would have been better in a Kolb 2 seat as the inertia loss is still a much bigger factor than the champ, it would have been better in a cub.. Given the above I would suggest contacting the factory to see if they could help in this area. All the previous advise is spot on... we all want you to be successful.. Good luck and let us know how you got on.. FrankD MkIII Xtra N1014S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455649#455649 ________________________________________________________________________________
Date: Apr 29, 2016
QmlsbCwKCkFyZSB5b3UgdXNpbmcgQ2xlY29zIHRvIGhvbGQgdGhlIHBhcnRzIHRvZ2V0aGVyIHBy aW9yIHRvIHBlcm1hbmVudCByaXZldGluZz8KCkppbSBCYWtlcgo0MDUgNDI2IDUzNzcKCi0tLS0t T3JpZ2luYWwgTWVzc2FnZS0tLS0tCkZyb206IEJpbGwgQmVybGUgPHZpY3RvcmJyYXZvQHNiY2ds b2JhbC5uZXQ+ClRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQpTZW50OiBGcmksIDI5IEFwciAy MDE2IDE2OjU2ClN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IFF1ZXN0aW9uIGFib3V0IGJ1aWxkaW5n IHZlcnRpY2FsIGZpbgoKLS0+IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogQmlsbCBCZXJs ZSA8dmljdG9yYnJhdm9Ac2JjZ2xvYmFsLm5ldD4KCkkgaGF2ZSBmaW5pc2hlZCBjb25zdHJ1Y3Rp bmcgdGhlIHR3byB0cmlhbmd1bGFyIGhvcml6b250YWwgc3RhYmlsaXplcnMsIGFuZCBoYXZlIHN0 YXJ0ZWQgb24gdGhlIHZlcnRpY2FsIGZpbiBhbmQgc3RlZWwgcmVhciBmdXNlbGFnZSByaW5nLgoK QXMgbWFueSBvZiB5b3Uga25vdyBieSBoZWFydCwgdGhlIHZlcnRpY2FsICJzcGFyIiB0dWJlIG9u IHRoZSBiYWNrIG9mIHRoZSBmaW4gaXMgb25lIGluY2ggZGlhbWV0ZXIgdHViZS4gVGhlIGxlYWRp bmcgZWRnZSBpcyAzLzQgaW5jaCB0dWJlLiBXaGVuIEkgcml2ZXRlZCB0aGUgZ3Vzc2V0IHRvIG9u ZSBzaWRlIG9mIHRoaXMgaW50ZXJzZWN0aW9uLCBpdCAicHVsbGVkIiB0aGUgMy80IGluY2ggdHVi ZSBvdmVyIGZsdXNoIHdpdGggdGhlIHNpZGUgb2YgdGhlIG9uZSBpbmNoIHR1YmUuIFNvIHdoZW4g SSB3ZW50IHRvIGluc3RhbGwgdGhlIGd1c3NldCBvbiB0aGUgb3RoZXIgc2lkZSBJIHJlYWxpemVk IHRoZSBmaW4gbGVhZGluZyBlZGdlIGlzIG5vIGxvbmdlciBvbiB0aGUgY2VudGVybGluZSBvZiB0 aGUgZmluLiAKCkknbSBzdXJlIHRoaXMgaXMgbm90IGEgQklHIGRlYWwgaW4gdGVybXMgb2Ygc2Fm ZXR5LCBidXQgaXQncyBub3QgcmlnaHQgZnJvbSBhIHF1YWxpdHkgcGVyc3BlY3RpdmUuIElzIHRo ZXJlIGEga25vd24gImZpeCIgZm9yIHRoaXM/IEkgZG9uJ3Qgd2FudCB0byBkcmlsbCBvdXQgdGhl IHJpdmV0cyBhbmQgZ29vYmVyIHVwIHRoZSByaXZldCBob2xlcywgZXNwZWNpYWxseSBzaW5jZSBJ IGNhbm5vdCAxMDAlIGxvY2F0ZSB0aG9zZSBwcmV2aW91cyBob2xlcyBpZiBJIHdhbnQgdG8gcmVw bGFjZSB0aGUgdHViZS4KCkhhcyBhbnlvbmUgZWxzZSBydW4gaW50byB0aGlzIHdoaWxlIGJ1aWxk aW5nIHRoZSBmaW4/CgoKQmlsbCBCZXJsZQp3d3cuZXpmbGFwaGFuZGxlLmNvbSAgLSBzYWZldHkg JiBwZXJmb3JtYW5jZSB1cGdyYWRlIGZvciBsaWdodCBhaXJjcmFmdAp3d3cuZ3JhbnRzdGFyLm5l dCAgICAgICAgICAgLSB3aW5uaW5nIHByb3Bvc2FscyBmb3Igbm9uLXByb2ZpdCBhbmQgZm9yLXBy b2ZpdCBlbnRpdGllcwoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRoZSBLb2xiLUxpc3QgRW1haWwg Rm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8g YnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2Ny aXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0 LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT0gICAtLT4g aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Lb2xiLUxpc3QKXy09Cl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8t PSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQpfLT0gU2FtZSBncmVhdCBj b250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyEKXy09Cl8tPSAgIC0tPiBo dHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAgICAgLSBO RVcgTUFUUk9OSUNTIExJU1QgV0lLSSAtCl8tPSBBZGQgc29tZSBpbmZvIHRvIHRoZSBNYXRyb25p Y3MgRW1haWwgTGlzdCBXaWtpIQpfLT0gICAtLT4gaHR0cDovL3dpa2kubWF0cm9uaWNzLmNvbQpf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAg VGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93 d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KCgoKCg= ________________________________________________________________________________
Subject: Question about building vertical fin
Date: Apr 29, 2016
I believe in the Ultrastar, Firestar, and MKIII (before the days of the MKIIIx) construction manuals black plastic electrical tape can be used as a shim to give the two different size tubes a snug fit. I don't remember there being a "fitting" problem when building the tail section. By all means build you parts with cleco's first. They are much easier to drill out than case hardened mandrels. Would have thought any self respecting engineer would have known that. wink...wink ;-) If I wasn't happy with the fit, I'd drill the rivets and start over. Might as well get practice removing SS rivets now. You'll need that expertise later on for sure. I'll bet you can figure out how to set the new holes to match the ones in the blind tube. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jim Baker Sent: Friday, April 29, 2016 5:12 PM Subject: Re: Kolb-List: Question about building vertical fin Bill, Are you using Clecos to hold the parts together prior to permanent riveting? Jim Baker 405 426 5377 -----Original Message----- From: Bill Berle <victorbravo(at)sbcglobal.net> Sent: Fri, 29 Apr 2016 16:56 Subject: Re: Kolb-List: Question about building vertical fin I have finished constructing the two triangular horizontal stabilizers, and have started on the vertical fin and steel rear fuselage ring. As many of you know by heart, the vertical "spar" tube on the back of the fin is one inch diameter tube. The leading edge is 3/4 inch tube. When I riveted the gusset to one side of this intersection, it "pulled" the 3/4 inch tube over flush with the side of the one inch tube. So when I went to install the gusset on the other side I realized the fin leading edge is no longer on the centerline of the fin. I'm sure this is not a BIG deal in terms of safety, but it's not right from a quality perspective. Is there a known "fix" for this? I don't want to drill out the rivets and goober up the rivet holes, especially since I cannot 100% locate those previous holes if I want to replace the tube. Has anyone else run into this while building the fin? Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities =========== =========== =========== =========== =========== ________________________________________________________________________________
Date: Apr 29, 2016
a sad story in regards to a new Firefly pilot.... about 12 years ago...I got a call from Travis telling me that a guy in Va had bent his cage crow hopping....and that he was coming to the factory to get a new one and that I could have the old cage for travel expenses...So off I went to meet the guy and buy the bent cage... Turns out it was lightly damaged and in much better than the one I had just bent..dropping my Firefly in from 50 or so feet... In meeting the guy...I learned that he was trying to master flying on his own... I thought I did a good job of putting the fear of God in him and he promised to get some air time while in Florida over the next month..... long story short...he made the newspaper in Roanoke,Va... never made it to Fla....Herb On 04/29/2016 01:47 PM, John Hauck wrote: > > The pilot will be the primary "cause of a problem when in the air." > > Be very careful during your familiarization to taxi exercise. Fast taxi and > a gust of wind will have you airborne and committed to flight in the blink > of an eye. More than one inexperienced Kolb pilot has found himself in that > situation. > > If it was me, I'd wait for taxi exercises until after I had become qualified > to fly the Firefly. > > My opinion only. > > john h > MKIII-3,400.00 hours airframe > 912ULS-800.0 hours engine > 6,000.00+ hours Kolb PIC > Titus, Alabama > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of flywithme > Sent: Friday, April 29, 2016 12:19 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: new to Kolb list > > > Thanks for the replies. I already have a firefly but i don't intend to try > to fly it until i get some instruction. right now i am trying to evaluate > the aircraft and familiarize myself with the whole ultralite concept. i will > probably unfold the airplane and do some extensive taxi around the place > just to familiarize myself with the feel of such a lite aircraft. i need to > familiarize myself with the Rotax engine and all of its different aspects > and maintenance needs etc. are there any special needs the firefly has that > i should address while i am getting some instruction? i have been going over > all of the welds,cables,hoses and wires etc looking for anything that could > cause a problem when in the air. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=455624#455624 > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
Date: Apr 29, 2016
Power on stalls are different. My experience is - if the engine is still at climb or full power at the break, the airplane will try and rotate around the center of drag, and you can go REALLY nose down really quickly. If you chop the power at the break, you create a sudden huge amount of drag from the prop which is well above the center of mass and drag UNLESS you also apply down elevator at the same time. My personal technique (experiment at your own risk) is that in a power on stall you chop the power and apply full forward stick at the stall break, the airplane will literally rotate around the center of mass in just a couple seconds, the airspeed falls off to zero, and as it goes to about 30-40 degrees nose low, the airspeed quickly returns, you can neutralize the controls and it is flying again with a very minimal loss of altitude. Once you get really used to your airplane, the so-called "impossible turn" ie; losing the engine right after takeoff and doing a dead stick 180 back to the runway becomes quite feasible. Practice it a couple thousand feet up... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455659#455659 ________________________________________________________________________________
Date: Apr 30, 2016
Putting black electrical tape on would not be the best solution, because we're talking 1/8 inch on both sides of the smaller tube to make it "even" with the larger tube. That's way too much tape I'm guessing. I had been using Clecos extensively, like any self-respecting sheet metal Cessna modification/repair guy :) My error was to do the drill/cleco/rivet operation on one side of the top of the fin, before cleco'ing the other side of the fin. So without any resistance from the other side, the clecos and rivets on the first side just pulled the gusset over tight against the first side. I realized the error just about as the last rivet went pop ! I can easily shim the other side of the fin leading edge tube with a piece of wood, sanded to a taper. That will allow me to continue the structural assembly without weakening or goobering out the holes by having to drill again and enlarge the hole. A wood shim will make it so the leading edge of the fin is perfectly on the centerline of the rest of the fin. As an old washed up free flight model builder, I thankfully have a supply of balsa and spruce sticks :) What I learned from watching this forum (and speaking to a Zenair builder) was the technique of driving out the mandrel first before drilling off the SS rivet.That has allowed me to remove a few rivets without damaging the hole in the tube or wrecking the sheet metal gusset. I was pleasantly surprised by the fact that it was not a big bloody battle to drive out the mandrel. I do have several "hole finder" tools that can match the rivet holes,a nd they work reasonably well, but not perfectly. With blind rivets you lose the big advantage that solid AN rivets give you, which is the rivet truly filling an oblong hole. Thehole for a pop rivet must be better quality. I also notice that the instruction booklet does not specify the rivets, it only says "stainless steel rivets are 3 times stronger than aluminum". A bag of rivets came witht his kit,a nd I have made the assumption that they were supplied by Kolb. Does anyone know this is right or wrong? Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Fri, 4/29/16, John Hauck wrote: Subject: RE: Kolb-List: Question about building vertical fin To: kolb-list(at)matronics.com Date: Friday, April 29, 2016, 3:48 PM I believe in the Ultrastar, Firestar, and MKIII (before the days of the MKIIIx) construction manuals black plastic electrical tape can be used as a shim to give the two different size tubes a snug fit. I don't remember there being a "fitting" problem when building the tail section. By all means build you parts with cleco's first. They are much easier to drill out than case hardened mandrels. Would have thought any self respecting engineer would have known that. wink...wink ;-) If I wasn't happy with the fit, I'd drill the rivets and start over. Might as well get practice removing SS rivets now. You'll need that expertise later on for sure. I'll bet you can figure out how to set the new holes to match the ones in the blind tube. john hmkIIITitus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jim Baker Sent: Friday, April 29, 2016 5:12 PM To: kolb-list(at)matronics.com Subject: Re: Kolb-List: Question about building vertical fin Bill, Are you using Clecos to hold the parts together prior to permanent riveting? Jim Baker 405 426 5377 -----Original Message----- From: Bill Berle <victorbravo(at)sbcglobal.net> To: kolb-list(at)matronics.com Sent: Fri, 29 Apr 2016 16:56 Subject: Re: Kolb-List: Question about building vertical fin--> Kolb-List message posted by: Bill Berle I have finished constructing the two triangular horizontal stabilizers, and have started on the vertical fin and steel rear fuselage ring. As many of you know by heart, the vertical "spar" tube on the back of the fin is one inch diameter tube. The leading edge is 3/4 inch tube. When I riveted the gusset to one side of this intersection, it "pulled" the 3/4 inch tube over flush with the side of the one inch tube. So when I went to install the gusset on the other side I realized the fin leading edge is no longer on the centerline of the fin. I'm sure this is not a BIG deal in terms of safety, but it's not right from a quality perspective. Is there a known "fix" for this? I don't want to drill out the rivets and goober up the rivet holes, especially since I cannot 100% locate those previous holes if I want to replace the tube. Has anyone else run into this while building the fin? Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities ============== href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronic=========== href="http://forums.matronics.com">http://forums.matronics.com =========== href="http://wiki.matronics.com">http://wiki.matronics.com ============ your generous support! p; -Matt Dralle, List Admin. href="http://www.matronics.com/contribution">http://www.matronics.com/contribution ============ ________________________________________________________________________________
Date: Apr 30, 2016
Herb what is the deal with the guy in CA with the tailboom tubes for sale? I sent you an e-mail asking about it and did not hear back from you. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Fri, 4/29/16, Herb wrote: Subject: Re: Kolb-List: Re: new to Kolb list To: kolb-list(at)matronics.com Date: Friday, April 29, 2016, 4:24 PM Herb a sad story in regards to a new Firefly pilot.... about 12 years ago...I got a call from Travis telling me that a guy in Va had bent his cage crow hopping....and that he was coming to the factory to get a new one and that I could have the old cage for travel expenses...So off I went to meet the guy and buy the bent cage... Turns out it was lightly damaged and in much better than the one I had just bent..dropping my Firefly in from 50 or so feet... In meeting the guy...I learned that he was trying to master flying on his own... I thought I did a good job of putting the fear of God in him and he promised to get some air time while in Florida over the next month..... long story short...he made the newspaper in Roanoke,Va... never made it to Fla....Herb On 04/29/2016 01:47 PM, John Hauck wrote: > > The pilot will be the primary "cause of a problem when in the air." > > Be very careful during your familiarization to taxi exercise. Fast taxi and > a gust of wind will have you airborne and committed to flight in the blink > of an eye. More than one inexperienced Kolb pilot has found himself in that > situation. > > If it was me, I'd wait for taxi exercises until after I had become qualified > to fly the Firefly. > > My opinion only. > > john h > MKIII-3,400.00 hours airframe > 912ULS-800.0 hours engine > 6,000.00+ hours Kolb PIC > Titus, Alabama > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of flywithme > Sent: Friday, April 29, 2016 12:19 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: new to Kolb list > > > Thanks for the replies. I already have a firefly but i don't intend to try > to fly it until i get some instruction. right now i am trying to evaluate > the aircraft and familiarize myself with the whole ultralite concept. i will > probably unfold the airplane and do some extensive taxi around the place > just to familiarize myself with the feel of such a lite aircraft. i need to > familiarize myself with the Rotax engine and all of its different aspects > and maintenance needs etc. are there any special needs the firefly has that > i should address while i am getting some instruction? i have been going over > all of the welds,cables,hoses and wires etc looking for anything that could > cause a problem when in the air. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=455624#455624 > > > > > > > > > > > > > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. Forum - - MATRONICS WEB FORUMS - MATRONICS LIST WIKI - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 29, 2016
Are you working on the rear tube of the upper vertical stabilizer to the top of the tail post? If you are, 1/4" slop between tail post and trailing edge is way too much. I think that is what you said, 1/8" space on each side. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Bill Berle Sent: Friday, April 29, 2016 9:26 PM Subject: RE: Kolb-List: Question about building vertical fin Putting black electrical tape on would not be the best solution, because we're talking 1/8 inch on both sides of the smaller tube to make it "even" with the larger tube. That's way too much tape I'm guessing. I had been using Clecos extensively, like any self-respecting sheet metal Cessna modification/repair guy :) My error was to do the drill/cleco/rivet operation on one side of the top of the fin, before cleco'ing the other side of the fin. So without any resistance from the other side, the clecos and rivets on the first side just pulled the gusset over tight against the first side. I realized the error just about as the last rivet went pop ! I can easily shim the other side of the fin leading edge tube with a piece of wood, sanded to a taper. That will allow me to continue the structural assembly without weakening or goobering out the holes by having to drill again and enlarge the hole. A wood shim will make it so the leading edge of the fin is perfectly on the centerline of the rest of the fin. As an old washed up free flight model builder, I thankfully have a supply of balsa and spruce sticks :) What I learned from watching this forum (and speaking to a Zenair builder) was the technique of driving out the mandrel first before drilling off the SS rivet.That has allowed me to remove a few rivets without damaging the hole in the tube or wrecking the sheet metal gusset. I was pleasantly surprised by the fact that it was not a big bloody battle to drive out the mandrel. I do have several "hole finder" tools that can match the rivet holes,a nd they work reasonably well, but not perfectly. With blind rivets you lose the big advantage that solid AN rivets give you, which is the rivet truly filling an oblong hole. Thehole for a pop rivet must be better quality. I also notice that the instruction booklet does not specify the rivets, it only says "stainless steel rivets are 3 times stronger than aluminum". A bag of rivets came witht his kit,a nd I have made the assumption that they were supplied by Kolb. Does anyone know this is right or wrong? Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Fri, 4/29/16, John Hauck wrote: Subject: RE: Kolb-List: Question about building vertical fin To: kolb-list(at)matronics.com Date: Friday, April 29, 2016, 3:48 PM I believe in the Ultrastar, Firestar, and MKIII (before the days of the MKIIIx) construction manuals black plastic electrical tape can be used as a shim to give the two different size tubes a snug fit. I don't remember there being a "fitting" problem when building the tail section. By all means build you parts with cleco's first. They are much easier to drill out than case hardened mandrels. Would have thought any self respecting engineer would have known that. wink...wink ;-) If I wasn't happy with the fit, I'd drill the rivets and start over. Might as well get practice removing SS rivets now. You'll need that expertise later on for sure. I'll bet you can figure out how to set the new holes to match the ones in the blind tube. john hmkIIITitus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jim Baker Sent: Friday, April 29, 2016 5:12 PM To: kolb-list(at)matronics.com Subject: Re: Kolb-List: Question about building vertical fin Bill, Are you using Clecos to hold the parts together prior to permanent riveting? Jim Baker 405 426 5377 -----Original Message----- From: Bill Berle <victorbravo(at)sbcglobal.net> To: kolb-list(at)matronics.com Sent: Fri, 29 Apr 2016 16:56 Subject: Re: Kolb-List: Question about building vertical fin--> Kolb-List message posted by: Bill Berle I have finished constructing the two triangular horizontal stabilizers, and have started on the vertical fin and steel rear fuselage ring. As many of you know by heart, the vertical "spar" tube on the back of the fin is one inch diameter tube. The leading edge is 3/4 inch tube. When I riveted the gusset to one side of this intersection, it "pulled" the 3/4 inch tube over flush with the side of the one inch tube. So when I went to install the gusset on the other side I realized the fin leading edge is no longer on the centerline of the fin. I'm sure this is not a BIG deal in terms of safety, but it's not right from a quality perspective. Is there a known "fix" for this? I don't want to drill out the rivets and goober up the rivet holes, especially since I cannot 100% locate those previous holes if I want to replace the tube. Has anyone else run into this while building the fin? Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities =============== href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronic=========== href="http://forums.matronics.com">http://forums.matronics.com =========== href="http://wiki.matronics.com">http://wiki.matronics.com ============ your generous support! p; -Matt Dralle, List Admin. href="http://www.matronics.com/contribution">http://www.matronics.com/contribution ============ ________________________________________________________________________________
Date: Apr 29, 2016
Thanks very much for the advice! it is much appreciated!! i don't plan on any fast taxi and really glad you all warned me about just popping unexpectedly into the air. i can see with such a lite plane how this can happen very sudden. when the time comes after some instruction i have a 2800 grass runway to practice on. i need to do a search for first flights on this site to read as much as i can on this platform so i will be less surprised by it's characteristics. thanks again and don't be afraid to tell me how it is, Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455665#455665 ________________________________________________________________________________
Date: Apr 29, 2016
I heard about them , same as you, here on the list...someone else posted the info... I am the one with the short "tube"! :-) Herb On 04/29/2016 09:27 PM, Bill Berle wrote: > > Herb what is the deal with the guy in CA with the tailboom tubes for sale? I sent you an e-mail asking about it and did not hear back from you. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Fri, 4/29/16, Herb wrote: > > Subject: Re: Kolb-List: Re: new to Kolb list > To: kolb-list(at)matronics.com > Date: Friday, April 29, 2016, 4:24 PM > > Herb > > a sad story in regards to a new Firefly pilot.... > about 12 years ago...I got a call from > Travis telling me that a guy > in Va had bent his cage crow hopping....and that he was > coming to the > factory to get a new one and that I could have the old cage > for travel > expenses...So off I went to meet the guy and buy the bent > cage... Turns > out it was lightly damaged and in much better than the one I > had just > bent..dropping my Firefly in from 50 or so feet... > > In meeting the guy...I learned that he was > trying to master flying > on his own... > > I thought I did a good job of > putting the fear of God in him and he > promised to get some air time while in Florida over the next > month..... > > long story short...he made the newspaper in > Roanoke,Va... never made > it to Fla....Herb > > On 04/29/2016 01:47 PM, John Hauck wrote: > > > > The pilot will be the primary "cause of a problem when > in the air." > > > > Be very careful during your familiarization to taxi > exercise. Fast taxi and > > a gust of wind will have you airborne and committed to > flight in the blink > > of an eye. More than one inexperienced Kolb pilot > has found himself in that > > situation. > > > > If it was me, I'd wait for taxi exercises until after I > had become qualified > > to fly the Firefly. > > > > My opinion only. > > > > john h > > MKIII-3,400.00 hours airframe > > 912ULS-800.0 hours engine > > 6,000.00+ hours Kolb PIC > > Titus, Alabama > > > > -----Original Message----- > > From: owner-kolb-list-server(at)matronics.com > > [mailto:owner-kolb-list-server(at)matronics.com] > On Behalf Of flywithme > > Sent: Friday, April 29, 2016 12:19 PM > > To: kolb-list(at)matronics.com > > Subject: Kolb-List: Re: new to Kolb list > > > > > > Thanks for the replies. I already have a firefly but i > don't intend to try > > to fly it until i get some instruction. right now i am > trying to evaluate > > the aircraft and familiarize myself with the whole > ultralite concept. i will > > probably unfold the airplane and do some extensive taxi > around the place > > just to familiarize myself with the feel of such a lite > aircraft. i need to > > familiarize myself with the Rotax engine and all of its > different aspects > > and maintenance needs etc. are there any special needs > the firefly has that > > i should address while i am getting some instruction? i > have been going over > > all of the welds,cables,hoses and wires etc looking for > anything that could > > cause a problem when in the air. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=455624#455624 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > Signature text; Fort Marcy Park? Sure...Mr. > Foster...Third red light and turn left. > > > Forum - > - MATRONICS WEB FORUMS - > MATRONICS LIST WIKI - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > > -- Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left. ________________________________________________________________________________
Date: Apr 29, 2016
any chance you could put the tube in a vise and oval it slightly so the transition is less abrupt without weakening anything... Boyd On Apr 29, 2016 2:59 PM, "Bill Berle" wrote: I have finished constructing the two triangular horizontal stabilizers, and have started on the vertical fin and steel rear fuselage ring. As many of you know by heart, the vertical "spar" tube on the back of the fin is one inch diameter tube. The leading edge is 3/4 inch tube. When I riveted the gusset to one side of this intersection, it "pulled" the 3/4 inch tube over flush with the side of the one inch tube. So when I went to install the gusset on the other side I realized the fin leading edge is no longer on the centerline of the fin. I'm sure this is not a BIG deal in terms of safety, but it's not right from a quality perspective. Is there a known "fix" for this? I don't want to drill out the rivets and goober up the rivet holes, especially since I cannot 100% locate those previous holes if I want to replace the tube. Has anyone else run into this while building the fin? Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities ________________________________________________________________________________
Date: Apr 30, 2016
figure out your pounds per square foot of wing loading, and compare that wing loading to your other airplane wing loading experiences. When I built my first Kolb, the UltraStar, three decades ago, the wing loading was about three pounds per square foot. That becomes sort of like flying a kite. Daniel Bindl On Fri, Apr 29, 2016 at 10:58 PM, flywithme wrote: > > Thanks very much for the advice! it is much appreciated!! i don't plan on > any fast taxi and really glad you all warned me about just popping > unexpectedly into the air. i can see with such a lite plane how this can > happen very sudden. when the time comes after some instruction i have a > 2800 grass runway to practice on. i need to do a search for first flights > on this site to read as much as i can on this platform so i will be less > surprised by it's characteristics. thanks again and don't be afraid to tell > me how it is, > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=455665#455665 > > ________________________________________________________________________________
Date: Apr 30, 2016
thanks very much to all of you who have given advice! I have been kicking around the idea of hosting some kind of fly inn of sorts at my farm in Oklahoma. i have a 2000 foot grass runway under repair right now and am located within 50 miles of two interstate highways,the little town i live near has a good hotel too. i think it might be a good way to meet some more lite aircraft people and see some more airplanes and talk face to face with people who actually fly these. what do you think?? should i start another thread? John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455676#455676 ________________________________________________________________________________
Date: Apr 30, 2016
If I may, do yourself a big favor and get an experienced pilot to fly your airplane before you do. No matter how much instruction, you will still be too inexperienced to deal with an emergency should one arise. When you do start flying limit your flying to early mornings and late evenings when there is no convective activity. Get the book, "The Compleat Taildragger Pilot" by Harvey S. Plourde and take his advise about fast taxiing. If you want to know just how badly it can go wrong, review the experience of Scott Thompson. Good luck and safe flying, Rick Girard Rick Girard On Fri, Apr 29, 2016 at 9:58 PM, flywithme wrote: > > Thanks very much for the advice! it is much appreciated!! i don't plan on > any fast taxi and really glad you all warned me about just popping > unexpectedly into the air. i can see with such a lite plane how this can > happen very sudden. when the time comes after some instruction i have a > 2800 grass runway to practice on. i need to do a search for first flights > on this site to read as much as i can on this platform so i will be less > surprised by it's characteristics. thanks again and don't be afraid to te ll > me how it is, > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=455665#455665 > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Apr 30, 2016
Where about in OK? I'm just across the border in KS. Rick On Sat, Apr 30, 2016 at 9:27 AM, flywithme wrote: > > thanks very much to all of you who have given advice! I have been kicking > around the idea of hosting some kind of fly inn of sorts at my farm in > Oklahoma. i have a 2000 foot grass runway under repair right now and am > located within 50 miles of two interstate highways,the little town i live > near has a good hotel too. i think it might be a good way to meet some mo re > lite aircraft people and see some more airplanes and talk face to face wi th > people who actually fly these. what do you think?? should i start another > thread? > > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=455676#455676 > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Apr 30, 2016
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Subject: Whoops! It would help if I added the attachment!
So here it is. Arty=C2-www.LessonsFromTheEdge.com/uladventure2009.htm Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe through life just to arrive safely at death." JVBERi0xLjMKJcTl8uXrp/Og0MTGCjQgMCBvYmoKPDwgL0xlbmd0aCA1IDAgUiAvRmlsdGVyIC9G bGF0ZURlY29kZSA+PgpzdHJlYW0KeAG1nfm21NaVxv+vp5DBNnUxFKWhpnTcCWDwGOOBJJ0O6W4M ODiNsWNM0nmgPFK/T/++822pjnQl3bpOet21pNIZ9tnz3meQ7p+Lz4s/Fwf+Noem2O2a4odnxW+L l8Wtu6/K4smrYp3+Xj2h1XpVNX7Wj1252u8O+32xa7arar948m1x52Gxcfu4Pfy2uPXwYblaF2Xx 8OtiWZwVD/9U3HuYBp0At9mtmv16XZ4C8PfFslqX2+L+WXETcMXyxd/Oij8UDz8aH6MsN6tdedgV lxljeXMa6bI8AHCzvxzAb16+mgFZb1bVbl9fDuQMY6v9ToJCwJdg7Jyk6v16tasPl8MQSf36TBpU LL9PwiqL5dMoePxjK75nT88WqU1xe9j4h29eFNXhRiF5z8l4s67/MXJlD5saINLsanWoim1R1qtq LZ081TgSADHdxlGMGMdiaBzltFJs6oOJugS4TCX+cRNfb8Ic16v1elM8fFJst8kVxM20VKsyDP2N K1ffnCanXDerusTX7Dq48+DemoO1Wx3qZpvBEo4UXIQkKvn2tbOiLpaPlnMaVVZb9L08HdtHZzPo 1uVqW0kxOtKFblWfgu71dzAU8L0xi+5mvdrWu102wk9n7qZZVZsmx3Ye1pyv3FarqqpzQc3DmhP6 drPaN2sstMfFbXMKF1e3ztDS5TpdMTp+V0kN6rNFV87gTbFs3HSTqnE7FKExXF39Ruq8S9f9oHyx vJLKr6YrxjAdlupyL4daiZrwFD3OhKc4WtcMZ7qovN0fVk1AQ8PKmgj8ZNFsktXGzVZbt1aLQbwB 0igYSEvPwBp/zWh7TCVdTT32sqBCen4oltdTF1RTluQiFPQmrEQbtsVydVbsiqXr4ec0H8ptvWo2 uyKhHv5mFuE03FRCUW5JS9Z9aGJEWUlJZuHCiDWUQiK4b0wVJIgrm4U0IIinLPTHsq5pgHKICVQ1 qR0U8xsNosK/2/IF5W+6KHrAafiFnh3HhG0w0uB30cwN3Lh6pOEEymArd4iWCeMkQeAaB1Pkxkbe 9Lg2YHk8xHekJmiLUXp88YP7xMBuBm5z2HlgDAcK/bsyqI5b07qywWaqQ3X4JynL0Wx2zWpTnaR8 h2kvv9uvNocDmrY9HdzPpsHt8Zzbqir74KTM25OU+SriQEPQmBJWY8m6SVJltVhehfVU+rFY/ktn x9PML+tmtS0P28DHXobEDeNKYXfMuJqBl8GE0E70CydzE+0EOR6Em5RB7sXVis1HLXQ9Hof66Ohm rkD5aYsmUt35IMEydFegYzTy1ebnbi4hLEwTXu2JO1VZ9wUxRm7nVBNjp3zUUe02h9W2OUntJKiL 4TXNarfNcrbTFOXnBMKb4XzgGmqjMCB3n0oRhe7SIxjoGzyVz+t3XEWpcAXO6l13RNNu1ovEEUrT U7HE/gUgngLOChdwkzYBwNL1gFGzQkkCuRxlVCOD5n6BjDwY4epfE0oBuMNhkfXC7yl6oRUqjJZy peU6KZdKWzyDsh6hKUQItwAUg0SbYOponVQaBkeTymz/BYVHYeCzM1QDZlDdhxlQosO2Mb9a9vWx acUXEo7KLfybNoaGieW63OGVcmWbNwZ4OqW7zQGbqRsC9ungZnxmcyBrP+wIEDk4fNR6k7LEWTxJ AN4KlgS/cBTBiYVmU/21iw3zwz24x1iRdc2OILVaTLGC1M1LK8wUNA/17LEpnbv55txtE0sri+Xf pzl7aFbN7kAWfyG47WpNCnzBSk25jgWFHjh5f4Q3TK0id+3cIZz9JZwNu5JB4XaxSuzIToBQIO1T DWsAmfZpYSBbfiqbw6rc7yGqro9pLhFIKFS7xKq4DdLc5WY1zfqSGc96Ww95NZM2259NibLcbFEN NCOXpLSQ6HkCr+40sAdPwhxDPgADl1OUlcojyENFJMdrXCEvjBScLNX95J5SQJXHFl9pJ09GwL8i Bae01zCakNpoAIVQQKVb151JjxxQQG7ksmhqKHg6IAaWHu323fcC6Ls4IGobLEpEuLqJuzxY19Vg GnkuykxWdPM4dFrIT3ZPouuOnxoPH517g90zrgoEXcYhJ8sggcYvqRLgc70zRRwY/9EcymyRpGxO ysxuENPQflBGIrAS+RGtYO/NlNNDEVMv4SZ7uJ+e3k9CvJOuH6Trhz07GaJHjlHvWV/Yduhd6Jgm ffTRMa3Xq7rNL+YcU3GaY7oIHI4JzTrZMeXgJhxTMfAKc44pBfTMMX00y/DOMbES2bTOWyZf7jH5 xbxvYj437cjlTA5NRd6dE/jTxVkq6zwM4U14pxGGzXinxZx3StmeXAGpDa4AVzJtXlXD9sGBecU/ ieaqIVY3Q3hSktNS5KvYJ6qA88RPYJ8yTAjgQU6JKV+/EFeWTa4+tgPCodLO108oCv+jzgZFrkYv fBe+IVk/NaRzGSScokZWgktvAkGrnrRUnkyhUWyxcvdAuIX5K1omj0Nv0yX1My1MDovlp8kZBcD9 2YJ2pgiPNS2zhqW+ho2WkFmbv+RBdJgXLOdSOVZyynpzGWgisA3J2pEqi5EdrM5zb5jWtZaaprGn pYh1XZMWitU13IU1+fXq2WKaQeWuXm3qbVnkI+O4p1anFuyi5SnUDtVwuoSMdgroyMxzWcQIQoiH +gfp92dJom+CHI0fpDVOZMhvA3F1LO+861aoCQBd/znQu7GiWdsnzZpO7GP03jXoQPk4vyCrntxp rA/Mure7qs+tSbe3UJgYVYAkcDbr9riA4tsiwW0fX+SPm23xAvsiz90v1Do9Py++nsaxi4ybHcvv rcYPMnaJsc3YTwuMk9DCfi4XF3NoUraUr1+4Jnxyvv7BrMq3YXGD7iNLz2kUa/AzIyl7T+WXN+fD Itu6FRPRnL6eepzzNrl6/HmYMW32eK8BOCGaUvYL2TUTFPEQecrOFkGWsrc5dCTWmCh2LDyxxAtT 9sUyT9kjc++6XyplXyw/uB3DBio/PWPX0hsG385KoL/3FHjhrGhngvE5/I4M3UU4CfzP22cLroEY cUsZ/JWYNcQt4+2M621nr5uNtOa4RPb/nbG/nyTpvJ2MPfL6GURZOi5rEvceoj21HqZkPa83VOuj h2rWZEDtWuPARem8xiVd1EXgLumjcnDTEVF45hHxkG8jOPqhDrYg5VJfZGGRdAbleaRwja51zZRe OTq9i+JRYzD+LcWj/q2UAjkwRpGhxMOXKCY9HYQxbmzXV0PpwfqSmSdtUW+nDvz28GTFWMy7Pfiu iaLYnKoi8gpPViGid7TRpB0optWURArgB2a44V8g637C9P1E9Z20+P4w/UZPu8Qi4P7aEI216TRu PaY48yCN7Yjq8TRgmTV5xhIV5kCfi5rwD7k4Yz2dmVebFY77GG4O9WK48DK0I+aCjVZHQL5daxFi INA+gpqydi0e0ChWZ+ADHLcHi/YwVs4vFmy6Xgl0+EL4iWO74mWIdlSP1i6uxBoLgmOwazCHod0N 5ZvmQUUgK7f7TbFJPDi6uvVpUx2W2Nv1/5RgfkgKJ5Ywz+HG6pwU7K5vv0lV8RA38YCG4KiGimGa skRpbB/g1iHmt6qj6fDuAf+NWo8rcL/jSb6fG3wT65HLv4d5p7WcFm0Pr1jCNCoK0VvGg4WCGDBa zPr92MNI6W3gq7VweirGRBwCAEKgTEKTbni8AIqw2nmdJLQYPfR2nIGUrNJkSdH8LrXXaNHSR+Gj bJO5CxQyyV/JuVTxZFdl0/WVCnlH+0DohyY3spOIfn6AMIjdecdZwN3y+Pz7BCvmJj2HZd9gALZt Y5wj5JJHjxIS3gFE/NPaXa8x7B1as8l5NxEfY1Vb9LTTwsn42Bx27MVNpPARHwPe36fBdYvuF4K7 3KJ7D9xEfIx0l+0ZJMZsCE2595fE12fJH/2QfNnfUgnHxBAlcQvZPk61P6aA9DrV/pDWWZ+m3651 L6ILvdz3VXJg7vVdavl9BvmbBO0lJYto/3Ua3S2NieEYvn9/lY3oNi4x/k/OFjgUY+gS93qRYa4R i+WTRNHzeT2qV4c9K/7mbJsX5YsVER86fs6ejlzrtNgQnKYP+7Q1MaagHWAEpcOQEAdBuBmIkBOB VzfLhW+pcMYqOCnYVGyU9PRkOKgmV92gs9RwArLckYT2wE1QM6J2PWo+tZ989lff0ZKOuGKJlJGX ib+Rcn2zQLETFjxwnwDB+kMWEVBGeEXzabY0Ona33/2TZNxw/qGpB9AmmDLUnaGITTEaKl48KxLl 903eHW4QFqSvZunTCtZ2IPbRqepJYm/2nK4pc3ALznYPtUi+8DRwhzU5WAfuHzWx7tREsz2wNJPl NZyrnMjtyIQ6X6hDbugaYR/uklt1arM4FxM4mLfebarCI7UxYcQ3dPCVEzz803i4P1Srerfe9qFN +PDQG+B20f7ta4+ELo434jLzXh6UkuAxbkAV9EAVuQgRm6vrURyolfosJg/Gb8tVUw4xG5N3S+fC dE6cs+d45nonA0kC6iXf5wQUXqMFrGC1ugXmxp8r9HUSOrf1XqJapc7TntOFaXebD7VmHgR3Klsc LMQKYSFFnAadHrbS8bN6u+9TOMmwtCSZFGOcYZztWu0PHRVHhpVk70ONHmFYQ5JLjiv0wT9uJF3a PsB/oiSa7plOLTy47Dq5NxpznIXRF0AzVHOmotxsiAYDuZKuTk2qcma3Bxitl2+DYOKzruSuoIIY wIFZFVcWtKYxqVlNrKtDeQ6TOPjdk8QIwx6dXYfSlLXDC22HM5xu1xvu4gpKkEJMVIOrWl9/g0kB 93hcU0pbmKu20YWdDDWZ5WTDrtZ2DZbn1HZ6apZz8qY8AEPCSa7yAIhV2JBllVJmsEINFFOuilD8 Q6+pdrFUqVUCcO33KDvgMxZAflun138aTkxgCN0Ee2IdTSlHTsE7YMvUBNaBOeMbYSQAFykBafAS Ipozgrtukg3t3pmzTO2Rrjl7SbTK8Orpw9G1FmWyTMBPzQqOZJIJZRO0mfMb3etOeLIvn5vPr7kh KAd7X0lWoYX0FTG8SmIkg4HmN+siJd2kyUjth1Tz3bf0h1tuoZk3Dd3JwL5zO5JtYD52s5Q3LAKC x/mjsfnupe89cO5rON9TD7oB1UMYqxjOPe/SjPFMSaR6xuq7gNBr911w4aXXOgyK+YQU0Q2V+PDw OMclcA5GdCBSQ14XEp6MOe0qmobdI3a6iyaT4Jg+ILeY1oHMlD40DUd7twNoSv1G7Db8Tq4PXyuV h2VQE1RLK6QkCBQZyVAZncKv4wnaZNQ/whI4wyxO3ZkqqSWMp2w2MdwQWeo9+y0t9VOJXLeYmoxu ivxj6lWxOTaTyHWmLtu9GFqpF62OidzM8kcHGOt6u06swofIblKcYzR8CB5iNiXikDMs/nm6uscb iZWRSsW+BydFJaRfAAyeNzwB+pfJbeG87FIpwRyntY/X1ZgOKlEo8UvtqrsUZnzbSzl1R+JS2ckU 8ypNNPcsVDQ588YU+whvRhbVmly6HoIToicm1V4kujPLDNYhm80aUzwd5bdmOMCZupJY3YMmjHmz bJg05T4/lkTupmVZJKsoY2lyJRu6uV2kiMiT4iMt0DP5GUhEHwhQXNEAKQccpdnbboa0KIrGftjY Q7mZ1MsRjmZXAnZFISCuuL0bvpcABVS5ewa/Z0i4SDqfR9lB/BSU6avlE48krY4TJNNKLKe3263J +5LcxqZBwxxrzuyPMZVjTE270tY50dFpa+5EPwonapeoWIb522uG0ww3+cxuIJytIg2yjM7Rre9z x7yzYhLdbgOLvOShR/vMt0+5kWO3y9ZeQE0eu0UIqUq6UfajsbwPLEDafYPWNOcrnSZg8aJoclb1 jHwYZaSlkz6DPcV6zbmTHjhxnteuJl4Pyzn/4ZHZKKGiEGQQxyOWURYPz6GwF9GoUraA9gePlSCQ 0QSMF98cuUbTL3uQH5tdAfoosWm21ZzZqNab83SSnE5NVHI6b6NayBXFAWEwRYKgDa0uARNUgakA bZDoNB4NDm+75Z3HcX73V1TOCfJDxpmSZFMTMQnu5yGz9HiCJK+J3xAE+hKeeIuPUSICxWKxTapd dkRSEj11KK1ayph4iu5f+Sn6SaZ0f8KNEQIm6eM0nzqPULPw1PMIvGY+4so1mcjl1UsYpVlgKD2D MiTGA/QhQ7AFL2QLWiKHijyrFaYUsQinZhBKs4CiJUt48MzQ3KDZv5Ga+ErZ9PpKxRbF9sDEuUdf z4wjQLVUpcXyKeEf2bXjHcds6uWcYgh3yK1PIArOiCZrAIKEQWYNVD5Fjok10n64RRHakppqs8i/ kS4cfe6mT1/DLfEndXwKLzqQHsslqAnjttAFC1WxdBjcbXCYlNTZdZ1+u/YzIqP86cN8iOc4iAGU pwaMljLgjYSOexj5HClNrRjdWBExDGlaV2t8aLXjzcM6Y/6Q5UrjEGXMJ2Y8Mi9q8/r6tgcMfzyW AA/9Awnw6+9zPlhUPXpcHZJ2vSS1kHYjL1f3xSLRTYmlGhGLxNiJZTXnDTd8fqMuq02P2B7nhiQK wYuNYItAhkZwYRLxWa6xpte60aqn+IC5c7LCJeQU6JJ56JIRA3qe9/4tmgWQ21bZ94hiaO4DnjCl UOBo4l6Wg7HwOLZK196iIwgkaIvAQ/gRoKzOfnAXC1YJpN0eaDhxNKU2Xo3RakI+nq3GIMLeXO0R jI5BeLR2fJ3QcudA9oGJfWleG8jLnEVfmCgX5bb5mp1HoHmUvNpoecSXPEwb6tFLbli6ySaX06d7 W++rRei/Eg7wCzAMQ4FOx3rlyj+mwA8KdloqAkNY/D+pLfEHzF0C/pT3egdcmKElrResdXJza8gR sK/TYPBMNfCTYaI1QYsHVkSOI2c1rBKknmA2zZWKXH5fM0wtroyl8kSiXsSYM8JqU642+wE0+a/0 uYH5/AYe3wVVFBSO4XXhNHyDbHIrqOKKQkAoPmWQZ53bp6mQtdLaOZrGd6tG3uY76k2908nfePtu ZNOnt2Yy+TZft2ZSV1V/pXQ8XMcSwHHbp07sITDCjG6VY1rCvEfpt8W78bTmI6GMbCaMzIvfZzwY fieJgFmiVsMtA+ZA08OyC+Mvm9Qkvdl68HryjTzWJSJAlh9M+3lO/vMqM28vduToO1Oas/gbL2MB pFvxQMdY6te8W7ZEJiHfy2Dyy0RlpXtQq/ifFgMoPbiSPpwlos9Vt7rCDU294dqKG14hCjXHA9D1 D7nLfgMiDFSjNL5hXWJ8en0U4D7mjjyuyxUzDCemhD2LV0KblSzdcO7TkuHrOHqzlribK+As3+am 70d9LrPp+xi4nn2cEMhzeF0SdHEkd0x76Vjhh/9GbduczhHjK0rSYrh9s/0NV7fE5cJF932V/JAj m/vGAJHXKpgtlq9jvOduci7FSp7swhTrL2mry/DxebQX9BYT4dyWOAZ6sGP0c3ABdRIPZa6uNzWG 536G+hT1pccYUSYXKPLEjr35iD+RPI200KI1ZJhIpxA5ah45zzlMnokAQqfY59x+56mrA9uxwxSw H32G8ys8w1OjYXl/nzPe2Lgi59m925gbbiBuZuTv5CnSTJHr65dEZ+6uumeiXeQBzFWDdiMT6tpv 0vlit39uzpzHwkBfhjrmHI2ZWwtdqbmhm6Vu6lENpJ245UO53rxRhgWQVykZM+qWZqsoCtkGZQJy 4AbhQW2c+r2I9kbMA+c8joHdwUBfh6R6vPWkj/E6/Th3OOCoH/vePHk9sqownHqgH+WhXgMf6/oU sWOVOrk0PRprS3wMsKmLSqPN7I10Waa0ZGp6U7Jt1fDtgh40Rb2RF8cHuq3s9UsYi6I+JmOUcj7l JpeHZXOLJ9OGk1EL2I4oycTUDrZLrtEZWdOAFABO5Pw+Z48V56L48l1lnGcSp/McGMnDKtKvaj+A prDgD9D1Ak7OAW3pwoH7EAHCmPK0yCpy4PRByCSyMYSHajG7usrWM69a73vkS2RpwnFhHPtG7AZj rFcygNNwHdtSyoLhqAxJeEJH3rTURF8ZCraddUPuEqd7y22rSfR7gVGpf/QwgDS/jdym6xjDBkbS F4cyGgxg/u+LFx5Le7E0Ctguiwdt2lIVRLhKagexgVnQ3CEv+uKhB7ClOfAjeGdADBiBq6wbOmF1 HHpaGY7egjfU8lcG+FzhuUXIoV6gcH/BhCw+WOzfkIDwwEvOI4XWl39KD9/9DQqg8Svmf+YC0sXC zOVpHEsO3hxKvnpR5Tj2TGGImYafdDI7ZiR8bq0P7hKpl/2zSYMiiHDscQkjEzzkydPhVeiV/Dp6 35g1TXzJXt8tuJDS07LMLmuteOl9fFYXnLssPL4v0zv/kmZ1o9aeT0sm964/STrDUb9N4ieHtODh rTlWcVDTH6isBqicMkNavskUb1I/aj66ok9fDiF7ffJiIn9leVdJ2T81RQ+SmVyLqhsu5GULLIUJ ErYDQpD8Pl25uauvj6Iq9uevJE65f8ss9fwYT4QmwkJtk1IAwGmT0tpBpbdHhzR6G/lCGu/eTMT5 ejX9bjeWwVqO1YVrp4ngQtFnJq7mBqY5BAhR0R13det33NpwvG/c7VCP7BtrTgiIt+eo1s4U38/b BNXH1bGx3GhkkeDW/VZUmPOWAZFerZNvTLI2YE0piiwpGJnEEh4/Twxixmy+cBWT8AxtA4mMzgKx WH5EHS7xY27Ap2xajPri7pqPrvSkOOYYTzPvYzDQh3uOU4tTXwKGbIjiVKNo8wNShgENYoGWIJMX gLUXH087mtPEuhxl8JYG7mQ4UhqYEvUEDeqvpKfBV3/eyuwjWhvO8Fs6YrgHDQz4eIFsD4XTLUc/ 4KTX485LrX1huCdMPgUSvQLz9stDajUt0Jq316oGT10dJaCPM6wJVyNbglo160RLNL5mdpt9QRbU B7OZhZhx8IiillDcbMiG2z1LQzRJj0UDpX77rokeb6oSjU/SNizDbZtnLzzT2XU5xGn6jxpYNr3D UTMWmjOgsfjNhoSnF6wwUJcZmRCNG/c0D3NLytsE9zqGQUjL1uRorVSclkKNcv2Aaz1FGNA/GFJ5 0KBIAFvdIWoIG6N+LWMrbSwTwoFa9HU3cJeTAR3DNyFyqtJg+5trralGS7e5lbKzaKLVO2DEMG7Q Y1jUmDfRyQ+pJn0ROA2J3gvSPK8GCLWcDFDmg4efTQ4aPp5R7TkPWyU1mpnjdMqTEJtKCY55FCdS mOuMrI5HHtVlO3LcF4Jjcbr3veKflkXNmNN6tSn1DdU00Mzs/Ig22jKFNsZZ8l7IoQety5tHV56O cPUexzRoTrSt+LLMEPJYLjeMy/O5HP+rYD8C97TDcp8QBBSDkxpyR/OkwmSn0yzXEsZ+XVUmZUxT BgQstLA2xfKSrab6ZGjpXPcsNL7LdyK02KSYUYdyy0r4lvMdAy0ec9XnrOM2rmSSaMxtFHDa+5jP TTHjGcMrOb1w6FA+5n8nbhL13zjByzpd0AeF8VDaBTmkMpymFiBARNtIOFe29UgT2c9Ag7hG46gn L8TutUEDOI5OatvDPZWy8BTgop0cqMBGGzw6DygqnQOuB2RyEfsyR4BurJTaPl0NbqSubZ9ERTZS KPrISlXN957T/yDIxd/LPQeKnlCeekus3utdRQScQ1PiM3LE/AjXSkri894XmCZcVnzj9hE3qL4P jyA0CmXMxM0US5yBw7h44r0nTVrE22TgugaQj+fytQaFAseeDVygoODUKj7fkdUnuEoO7nFY/dui 5B8YxANfYtrtFnqggR66lulZn2UavrfX5U4l5yd5fe/4ckq9mTr/14U/ePgHbB3eoQlwAvNEoZqk XGQhlMA+uAeHpKAojYK6exCWSc3JR6j3b/cjDQCGIYmz9ENMgCJ3SrKac6MHvZzHf+fpETOmXomE 5PkwsZazQ96UJATrPTO/HrgJ/RouicCbwTei/8NqFuoiZkCPsi440H4GWslyuXb+g6LFpx+U4Nhe M327QyFsUYocCkoT5g3TUaZeE1krPmJoemYieyfh2QTnqDt8IKj7JrdiO4tRJ0w8PkU7rDVoAtLn N7qB9Nm45SpGwaE/iCVJk6hHzzAyhVaKMEMeUB7ox+lxJbOmR3T80rwYf8G05F/zrHVQm7f0jt8w kGynz7zAlc53vJXCe0wuweU/wRKc5RnAAzR1k/MAabCihbDi9qkb6hvTyAttF3Fx0z9ZUYdIGXr9 8Cg3+Zx6+2YXVDurYCDeMI3HAVIxVofrDPj/Ah6mxsdU28wd/KWckBjU5MBnlGzHuuuGyagZm4VL 4sYJSnEPFsKRHRTBHzhhBmrAcUk2nBjls5d4xFySk0afPo2KLCYPoTT6RHUzhCfNmN5PyjXjTjuD xIeBu8QOK2NKNFwNQN+hUgyG5pi4Cblp/h6Njs8/7dozNzK6kYNEBD0dUOrMGac09n9L0AuwsM+1 d85/IxDo4FVTjA2VREtE0zSGJa9IV1v+n0g5xHBkO2rEbX6B6BkQROBbUjp4g3vg+o5GRiM/h2FU uskDfSkR/MU36lhcFzPj9hVP1IF32Cq3OwmWIbqrFJ0+HthDshbTG5IkTU328Ao+VB66ehAIyZsz jJZtwMs9O2hp0zsaPnHD6F4ZmluO4Bh4pU/danS8BteWC58Ayz6nw72H17SIjkqkE0jt22lSojSZ HJ2V5Ur0GIwh19hDLRxR+idHlr42nUqwXdrA4Gk8Sr7BseMNX1JL4XHMPjyHG02KOjyWtx6diauT 4bvhwPChA555okuFJ6wS8hAYrHaU4aPoaBEssKjRVYikxG0wFylIugo9AtJv8rDEFiE9mHBxvdut adIKvwEH4SkVBh7dYTBFhu4K0iZYm2MA48HAeEQ3I9KDRCIBbh6CxKGjy/DIsKCRDwpNC4zPtUhJ sO1cYJPONmVYczKqebt7tx3Ck7MdSeFHfMUWImV4UCn70FAQlSzYwlE4hXPUQR1XpfW0p6HcGZxV g7a9s6+2Q0ThuBlIDBcR8Vkr5BmO6f31zY5PLPyTONawc1VXQ3gpPJ1PukY49vR2+5V5kg5oF0Xw BQaKcfAPvt2jjKd2EXouj9qs9R935OxPUogUfX82HXw3+lRVVRPMc3ByTJwWmc4eurTsCRKFAKRs Ic/4nqMPJIHgiyvdzIeliFNmPk3SGtgkrcFuUBDGRFso8lUl3VImKjNtViVCbRqRPcRl+uRmzw/O eUHysTHQHA45hcwvUBDrhwwF/cDNjAQef4Ys6iEcIVQoGBzJ+8OqaSawfZqO4wYTjv56bG0opvMd E8hsBl8JTGotQ2WhJfQaNwcpsa/ktfioee8uKykzqKEsO14k66M26fZCyycjkw7hNfJwFvflKF2+ 9/XDaXGzBb06nAP9kzHVP9zbbDkE9lMwRSZ//OD5+8HioaNRohAr97np+Hcva8D8+c+Ka/0bLRYP 67LeMYflV7VreHHx1ZNzp6v0qhDnlPC5uTnNM0FYtutMk99B1z90Xetr5D3Ack8jedOI831M2Mc9 vJ+uuCp+o4ZYlK/Qzm+XVygrFucUy98ix0d39rSL/4fXWRc1ZCpHFZ78RnjD8tD+krps5viLPB1z EjNYa9Hr8FsWogT4sOUljfT8Ip5TPZbDV8PFPLdPz7NfCe82T/iQTs0/NJg7Jdg5gWTnbTr4+f8B E4RilgplbmRzdHJlYW0KZW5kb2JqCjUgMCBvYmoKODcwNAplbmRvYmoKMiAwIG9iago8PCAvVHlw ZSAvUGFnZSAvUGFyZW50IDMgMCBSIC9SZXNvdXJjZXMgNiAwIFIgL0NvbnRlbnRzIDQgMCBSIC9N ZWRpYUJveCBbMCAwIDYxMiA3OTJdCj4+CmVuZG9iago2IDAgb2JqCjw8IC9Qcm9jU2V0IFsgL1BE RiAvVGV4dCBdIC9Db2xvclNwYWNlIDw8IC9DczEgNyAwIFIgPj4gL0ZvbnQgPDwgL1RUNC4xIDE0 IDAgUgovVFQ3LjAgMTcgMCBSIC9UVDMuMSAxMiAwIFIgL1RUMS4wIDggMCBSIC9UVDguMSAxOSAw IFIgL1RUNi4wIDE2IDAgUiAvVFQ1LjAKMTUgMCBSIC9UVDIuMSAxMCAwIFIgPj4gPj4KZW5kb2Jq CjIwIDAgb2JqCjw8IC9MZW5ndGggMjEgMCBSIC9OIDMgL0FsdGVybmF0ZSAvRGV2aWNlUkdCIC9G aWx0ZXIgL0ZsYXRlRGVjb2RlID4+CnN0cmVhbQp4AZ2Wd1RT2RaHz703vdASIiAl9Bp6CSDSO0gV BFGJSYBQAoaEJnZEBUYUESlWZFTAAUeHImNFFAuDgmLXCfIQUMbBUURF5d2MawnvrTXz3pr9x1nf 2ee319ln733XugBQ/IIEwnRYAYA0oVgU7uvBXBITy8T3AhgQAQ5YAcDhZmYER/hEAtT8vT2ZmahI xrP27i6AZLvbLL9QJnPW/3+RIjdDJAYACkXVNjx+JhflApRTs8UZMv8EyvSVKTKGMTIWoQmirCLj xK9s9qfmK7vJmJcm5KEaWc4ZvDSejLtQ3pol4aOMBKFcmCXgZ6N8B2W9VEmaAOX3KNPT+JxMADAU mV/M5yahbIkyRRQZ7onyAgAIlMQ5vHIOi/k5aJ4AeKZn5IoEiUliphHXmGnl6Mhm+vGzU/liMSuU w03hiHhMz/S0DI4wF4Cvb5ZFASVZbZloke2tHO3tWdbmaPm/2d8eflP9Pch6+1XxJuzPnkGMnlnf bOysL70WAPYkWpsds76VVQC0bQZA5eGsT+8gAPIFALTenPMehmxeksTiDCcLi+zsbHMBn2suK+g3 +5+Cb8q/hjn3mcvu+1Y7phc/gSNJFTNlReWmp6ZLRMzMDA6Xz2T99xD/48A5ac3Jwyycn8AX8YXo VVHolAmEiWi7hTyBWJAuZAqEf9Xhfxg2JwcZfp1rFGh1XwB9hTlQuEkHyG89AEMjAyRuP3oCfetb EDEKyL68aK2Rr3OPMnr+5/ofC1yKbuFMQSJT5vYMj2RyJaIsGaPfhGzBAhKQB3SgCjSBLjACLGAN HIAzcAPeIACEgEgQA5YDLkgCaUAEskE+2AAKQTHYAXaDanAA1IF60AROgjZwBlwEV8ANcAsMgEdA CobBSzAB3oFpCILwEBWiQaqQFqQPmULWEBtaCHlDQVA4FAPFQ4mQEJJA+dAmqBgqg6qhQ1A99CN0 GroIXYP6oAfQIDQG/QF9hBGYAtNhDdgAtoDZsDscCEfCy+BEeBWcBxfA2+FKuBY+DrfCF+Eb8AAs hV/CkwhAyAgD0UZYCBvxREKQWCQBESFrkSKkAqlFmpAOpBu5jUiRceQDBoehYZgYFsYZ44dZjOFi VmHWYkow1ZhjmFZMF+Y2ZhAzgfmCpWLVsaZYJ6w/dgk2EZuNLcRWYI9gW7CXsQPYYew7HA7HwBni HHB+uBhcMm41rgS3D9eMu4Drww3hJvF4vCreFO+CD8Fz8GJ8Ib4Kfxx/Ht+PH8a/J5AJWgRrgg8h liAkbCRUEBoI5wj9hBHCNFGBqE90IoYQecRcYimxjthBvEkcJk6TFEmGJBdSJCmZtIFUSWoiXSY9 Jr0hk8k6ZEdyGFlAXk+uJJ8gXyUPkj9QlCgmFE9KHEVC2U45SrlAeUB5Q6VSDahu1FiqmLqdWk+9 RH1KfS9HkzOX85fjya2Tq5FrleuXeyVPlNeXd5dfLp8nXyF/Sv6m/LgCUcFAwVOBo7BWoUbhtMI9 hUlFmqKVYohimmKJYoPiNcVRJbySgZK3Ek+pQOmw0iWlIRpC06V50ri0TbQ62mXaMB1HN6T705Pp xfQf6L30CWUlZVvlKOUc5Rrls8pSBsIwYPgzUhmljJOMu4yP8zTmuc/jz9s2r2le/7wplfkqbip8 lSKVZpUBlY+qTFVv1RTVnaptqk/UMGomamFq2Wr71S6rjc+nz3eez51fNP/k/IfqsLqJerj6avXD 6j3qkxqaGr4aGRpVGpc0xjUZmm6ayZrlmuc0x7RoWgu1BFrlWue1XjCVme7MVGYls4s5oa2u7act 0T6k3as9rWOos1hno06zzhNdki5bN0G3XLdTd0JPSy9YL1+vUe+hPlGfrZ+kv0e/W3/KwNAg2mCL QZvBqKGKob9hnmGj4WMjqpGr0SqjWqM7xjhjtnGK8T7jWyawiZ1JkkmNyU1T2NTeVGC6z7TPDGvm aCY0qzW7x6Kw3FlZrEbWoDnDPMh8o3mb+SsLPYtYi50W3RZfLO0sUy3rLB9ZKVkFWG206rD6w9rE mmtdY33HhmrjY7POpt3mta2pLd92v+19O5pdsN0Wu067z/YO9iL7JvsxBz2HeIe9DvfYdHYou4R9 1RHr6OG4zvGM4wcneyex00mn351ZzinODc6jCwwX8BfULRhy0XHhuBxykS5kLoxfeHCh1FXbleNa 6/rMTdeN53bEbcTd2D3Z/bj7Kw9LD5FHi8eUp5PnGs8LXoiXr1eRV6+3kvdi72rvpz46Pok+jT4T vna+q30v+GH9Av12+t3z1/Dn+tf7TwQ4BKwJ6AqkBEYEVgc+CzIJEgV1BMPBAcG7gh8v0l8kXNQW AkL8Q3aFPAk1DF0V+nMYLiw0rCbsebhVeH54dwQtYkVEQ8S7SI/I0shHi40WSxZ3RslHxUXVR01F e0WXRUuXWCxZs+RGjFqMIKY9Fh8bFXskdnKp99LdS4fj7OIK4+4uM1yWs+zacrXlqcvPrpBfwVlx Kh4bHx3fEP+JE8Kp5Uyu9F+5d+UE15O7h/uS58Yr543xXfhl/JEEl4SyhNFEl8RdiWNJrkkVSeMC T0G14HWyX/KB5KmUkJSjKTOp0anNaYS0+LTTQiVhirArXTM9J70vwzSjMEO6ymnV7lUTokDRkUwo c1lmu5iO/kz1SIwkmyWDWQuzarLeZ0dln8pRzBHm9OSa5G7LHcnzyft+NWY1d3Vnvnb+hvzBNe5r Dq2F1q5c27lOd13BuuH1vuuPbSBtSNnwy0bLjWUb326K3tRRoFGwvmBos+/mxkK5QlHhvS3OWw5s xWwVbO3dZrOtatuXIl7R9WLL4oriTyXckuvfWX1X+d3M9oTtvaX2pft34HYId9zd6brzWJliWV7Z 0K7gXa3lzPKi8re7V+y+VmFbcWAPaY9kj7QyqLK9Sq9qR9Wn6qTqgRqPmua96nu37Z3ax9vXv99t f9MBjQPFBz4eFBy8f8j3UGutQW3FYdzhrMPP66Lqur9nf19/RO1I8ZHPR4VHpcfCj3XVO9TXN6g3 lDbCjZLGseNxx2/94PVDexOr6VAzo7n4BDghOfHix/gf754MPNl5in2q6Sf9n/a20FqKWqHW3NaJ tqQ2aXtMe9/pgNOdHc4dLT+b/3z0jPaZmrPKZ0vPkc4VnJs5n3d+8kLGhfGLiReHOld0Prq05NKd rrCu3suBl69e8blyqdu9+/xVl6tnrjldO32dfb3thv2N1h67npZf7H5p6bXvbb3pcLP9luOtjr4F fef6Xfsv3va6feWO/50bA4sG+u4uvnv/Xtw96X3e/dEHqQ9eP8x6OP1o/WPs46InCk8qnqo/rf3V +Ndmqb307KDXYM+ziGePhrhDL/+V+a9PwwXPqc8rRrRG6ketR8+M+YzderH0xfDLjJfT44W/Kf62 95XRq59+d/u9Z2LJxPBr0euZP0reqL45+tb2bedk6OTTd2nvpqeK3qu+P/aB/aH7Y/THkensT/hP lZ+NP3d8CfzyeCZtZubf94Tz+wplbmRzdHJlYW0KZW5kb2JqCjIxIDAgb2JqCjI2MTIKZW5kb2Jq CjcgMCBvYmoKWyAvSUNDQmFzZWQgMjAgMCBSIF0KZW5kb2JqCjIzIDAgb2JqCjw8IC9MZW5ndGgg MjQgMCBSIC9GaWx0ZXIgL0ZsYXRlRGVjb2RlID4+CnN0cmVhbQp4AbWdaZPcxpGGv/evgHjOiBqo cTXQtmQuKR4SaUuWNLK9a9oRDtpayys51tZ+2X+/z1uZOAqNqumhvKFQY1BHVt6ZlSiA/yi+LP5R HPmvO7ZF37fFP/9S/Lb4e/HhJz9Wxdsfi33478e3jNqXdWv3+qOvyqE/DkPRt4eyHnZvfyieXhed jffL9Q/Fh9fXVbkvquL62+KiuCyu/1Y8vw6LJsB1fdkO+311DsDfFxf1vjoULy6LK8AVF9//72Xx h+L61fYaVdWVfXXsi9uscXGVRrqqjgDshtsB/O7vP2ZANl1Z90NzO5AZxtZDL0Eh4FswNiepZtiX fXO8HYZI6ptLaVBx8d9BWFVx8Wdv+NP/jOL7y58vd2FM8WQ9+J/ffV/Uxw8KyTsn427f/DRyZQ9d AxBpdl0e6+JQVE1Z76WT5xpHACCmm3EUG8axWxtHnVaKrjkaUbcAt1CJn27i+6EcWrfIfbnfQ9n1 26Ltgjvwi9EzlJUZOxJ/785lgcDvXhZtcXFvIbXd2pkMQ9nv+64u+rCS8ysL/+K++LXbdCbHumz6 /SGGBt5VVWfw3gUnBd4PmoB3dVl0Md4nTrCqcG77Gjkn8XY5T3y5eD8t5wpFgwsrcGI4jvn67S7L EBD/5UMsCV6/ubBrxwUBsGJTXGBSuvna5LDNuKrDtuv6lnLYpZx61bVlM3RNzJ6gQM2Ngrh4cp3h 1KFLQG4PJ5DXIoBTby7ffw0/jkE7xZYvjWOfcukL+Xw1ogdXqEBgJ63Hy506YWc6xtSEhKYjPC4V QqrXnqreBl6PfhaMBZMZwvKsjhryt7XgI1y8CBQ8qn1xgTusdheImrHgzVj7uw9SxwRBGUKSkNK0 NDVMPgy9E7Ow/w0mFyv7F4vT8muafTlsga4arPBm1/IafkAXUoMuhIawoD1QunMO0XQMHaCBnB8h S4KOzYMrh+Lig9ANT2GmtcBrEzATnl3u0qxp66bcN7iTEzlv478jD5pcAPr3mmgIgp/lVKklsToc 9xve4FDvzuDRizeXI/0ZQrquHCZ9nUX8/yAHoQNfTRytmRZSSePW1TCgHkYGOHJZJyjoKW+EYyUs KK4vw9k7gzvi20ICfDg25fGwYN2+S6lws4iOXz0IypvlQLUn8FeHtojW2EJ5gnyBB0lxQPGl7Y9d DE7++HDqndygJ8Bo7UfYihziL4JeuXoRh/E/3lMqAmFOcqBYm995HCo1lJTdgHzBRaZqSip9YN79 S6LwOJuUQavBJ9p8gE+OAUf4/DuzMO47OGvA4wUFY3NN3IP6HLLjY6ut4e8wVsf0K2YBGIexuIQQ sebMc4PvvJgI2GlRZ4mT6MB8ZOlDnV/e6SQ4FmVo3Y1I+ZjyY1syloJP8cbBEPc7h1p2sGum0bFz 5j1mBn0OOxaYj1TjZMgn6V1FUo6tHItDfyz3g6d3iorb3lK7xqB3O3aN6J0SSfPR/CIgYpwWxJm8 BTXTM0QCLnAWwvgbVqIEZfDnYewuhHjIQAmZj7SBBUm02Cib/eGCjtN074gHOeKQjI6MQ5qsJiCa ssfZhRzasl54kBvYos30zBZEOBGB5kD848sdjDCyfhP45Ox6z5hnLCBxINjFjMQbwZYlC+nfwWgf 5pdnYZlPwu91jmP1vi/rrsGBiUIEv6NI8M7+q6725bE64L9ifu3ZjSYC4iyI6//8Nu0Z65rd8Rry u+PZsC3oj4d3wvPVsyfPxOaU0tSK2PUKeB7VHLhZB9tj2S3D2HBWGHuNsigNJfBa6llhj3L0zU4a SIokddIINLFCOYXM5CpOTawZymNHfnkI6JiroCiwr/AbN8kYm/iYNU33+b3HkniBX4cm+726VH4I fnTj1+QDsAlusBxQrd8on+bWGh/ZwBqvABwbjy+CQvLIq24n0Gla6g5v17GbWtJCEWS/38iffTMw 6+uby/i/jEYMqNu8zq3dUgXPB0y0pVI0FD8Udbe431F3me9JRb5HtFN/uP9r8e2JHKfy4KFpy4O7 /M0N7JLiNI0zPDZYAidHIrXIbumnUsR6S29ZPr+/xIftLh6+UfBA/mgxjWyV+RvHNrWQYSjOIHu0 B9mjIeMU8i3TB9rQrvCr/iXA98KYZVnhU+s2gP8W1Gsf1NEw+Iz1wMtmPA2zrcMgEd1YgfaM8h36 kvpkVRzEsIxOTNsSWUXS6fQUBgap8gKaNDkUJjY9+gQXq/xkrEhABCaHWYbcyZMObbPh9OfWOvgt 7BDL2ZLxK6fBRJsuYSCGO8hBXVOxI2QwiEOJpPXBJ0bYLwzXKgZCu0EEbaPusBEUQOVCTL1ThSTU BhLpgIA30ICfcwHEb+3y4jzMwt5c027CLKLxFWvgT19HIlZxdFGC75q6bOu2MaF4VrUVCSZRiPog 4p1qgjG02cL2rcqeVrPcAhdZbLL4w66IvcZxKA5LeNKZbLS2KtzFX3Mxq9pXlKBjwAlEHdx3adWu lKLcClgetWN5Js1rj4+dPHmCaWDZn3yiNfijJfJwQU+lrvnkFC9dqVxg/M5YfCS/pMlP+tAdEdpY /U2wGSPRA54cZ2Z4fVdWy0TjJ7twhfSVCycNwOR+F5nPSuEralB1Q0rSBYQ81dgi8NR+Np5gVQ3V imFfz+BSue554BBnPez1mGXFriaZl02AUaUDWRccIMCQuVhdCy1CifYhRuEIyOrlBnFv1mFD80Ux wg+8xqECSOFnl3rWVrcgU/d67CT0M95kRHqXjT8dFk8wi6DJl2wXLtbltrvj/lwKClegnl8yPVkV jNKOHPJDvLmrwDONecS+GD9813sVKRirSAEfxikG7tlHtBI/yCSvlPaKuUxFE9X64v1LFRF8TdWZ gaOYRJ/fKfBxdzViECG7gKqgv12/b2HTMHR6wnkm18WLpAufTfawL3k6kw4JsxDHCLNhIdNWo1uC Q4o8RjnJ7Te84/OPTadRPxl8kKF4hAxJXVBz2An/vMluEBHVKW9Cz9MJE89xy+HYd8UpdqfFsQ3s et9ORBjVyNt0y/IQ8JYvp8n2G2UwRsNeqGoHYhRZP9ykzXp629p4v918PBEOZHp28OKrMIeUBY6g g2mKm/2hPLZEjIjiyAGu6cxVFxt258SeGNpko/ncH4e1WVwcC1rSfkRbivh6d/HRfwQa41JW6LO9 p1koXPbSFcyAjV7OGn2B7J5N6njr08cVQ68pE2brd7J7oHphDj2Ux5hHBgO3tWT8pqTBpG3kaomI qPBkbnRHoGVgImCanpbmbF1tV7IvM2MV/49N6nHBlAnA/1bEQWrgh66sBq3PrfUhxNLIBodfDxs+ 4qn4Siu4QrH9opb8LfnAoAmyQcQwGf2wtoojeuw2y2LuUB2gdVkG5Gu9CKOfPnzo97Zay0YCkBEo VVZpa78wHMKENPMaMsr6gCUE3v3k3Kkh5d1XK3BydCdubqPKfgefYdYs/kMUN6q9wknK4zQZA50D aF+GLE4wNHtqRUbXlgO/lYXDnWNfE15WKlaFMHyjid9F481Zq0iE7HRBvoqWn3GhSCSqRM92fGv6 Q9m3I1+3yFnzMzjF1K52jm+kgn0uSRkNxULJzfA4aUQpZTLBrSqFM36MnCroPiCJRW9hEX6fXxUn sJSx0mCNKATswiwnsZ/W26m5dHuqLt0Sj8ixnzyuDXF7m+tVoyLubcElswoFWstsl9jJOjaekc94 TsczHslDyWfYBQPghtwJy8BJkXEpaKJK34QOwi1N+DaZlM0gAyY0+iiMDSW0iQYK7wNA76bWMEH3 6Tx0Zrot+Pnljm4MksV9xm+CfPBkCNA6xqGChEuk3VpINAFEbg6C6P3Oy6i6THk2XU8Xoj7ZtXPO hcSYXcKSl5Gk13qWS7Obvi3bDnexhJYP4Uv9ndJsnsHBVExaJyzcqd9V/QMhwJP0toEavOX5SwQi cmaFYInrb7O7hrbeQ07LtmEJbqInLlut+YQ9TvQgWmzupZwwVxRAoWW8nUZJP5Qe/MwePd69uhKt yeOI3X5fVn11g5VGWxnpWMr5zPGfMDN7no0q/galL1F99FIUcMFmnE7pot+x9THNRaSYiwawdVBF n3SAXx+GtOXVbTRmhwJ7E4puk8JjAApradZUFI8azg110zlQuYcNUlbaICf68uWvAz6kCovlXn5p 9vXS0XRK/YJqppHBV/FsiMXBxhir5xGJnaceXUYmEZRAOaAiW+CZfl+hKfDxde6MSUOplXMmgQuZ UDeutsspxxTp2uHAvjwDjkjnNTMhfKOyRfDElo3i3oa+fU0Cj6V89BEKzbUh6nH5FVxBx7hJS0PB qDpwuM9WzqRqI2PCliBFSNVyEKlu+tuAyxhh1TZl16/BJfiyobxPYr6o3IC2iDu787jDad/F+gk5 y6eMGY0pZpI91P6amT0OT8a48Yja5TxBxhj9gTN5n3l+hGwxkQ0CnoHtGS1SNIzBbmwo+wxCo3fY DHtWjy+xeCy+EJyZF40iO0KDDIj9Tc68Xsm6DQVcGSvZ2va39ZIXAMhA+Ao4C20zbJ4hhWRoIZNl CZuHM5wyggg/wx8/Cyc0IUSuCTOjy8DZojbSUHIE7MbWl+diaY0aT/9llxvxNkrTy418T1vgFGha vEq7yHK3XOKGTtjRlWk7DkKSpXY40gWPoSCoZIFESX4y7Lst92YojJZDDY3zDPFo7vS9/riWd8JA baP8bNA552wcO0fHlxxPOaEDV1QjSrYwrKw10lxTFNlzjKuIuBalNmteBYgpy5w9ekfdecvQ3xFc S6V1DBDBcems9+bWbnKwMnQ4BA+IrkhN/irkw2l2HFEdipR10Yb1znLjv8/EIypZtwWXceOc87Hz 6BF2cntn5iCW+Hh2ATuUJrFeha2yqVOCZAkXCqkk5WlwIGFAePqc5ps2T+GkfIRZpEbrsJJL+KuD nqTxusktwKHtKaWseOhc3xJcRgzVQQ/T1thJKW/52Fkn/ZBAsFflpuFooN8Fj0NnPGZsVa6PtHws uOJ4PqMNxy3fhPUjO3kjutJSq+FLX5OzbBrXjfuQ91ATMGSlzBJDQ9VPedFijbzZ5hRDrw01eyUy Izg/cHFb1ssrGnv4JUJJDir9cffmjTHSmXvHn/gbkwmRGqpNg7N6vIlkoeczxGll9fh15UsBfhAJ D/LVGmHwLMfDtuIUWLcfiXanFJxg8oDZ0gk+F9KY8/MXI824QdGMmih0CBnRTMLRmb+EZMfQHCa/ r2zA6xyi2jr23eFWZgtbU2Y7xxJOXE8v+mw5lSm3y8amOUNYwpP7xPOdcYjr+fxYQ2qCBiFiGHLV 7y68ixwJXuFEPfAygJqJmO9t/oDFLMdBvGUEAMkfGIfmwHqUaV6CzArRjE9gvkFEGXsLL+q1bdGu aeQ0/Rk0NlMAwJWABb+qhJo27HT9W8huQQJCwUxbcZSIG1GjAZuNMIaEiWzK2APHxuFktPTYsrag jXUwVKbmhaKecYry6BnHgMLz4Jjm1RaVNCQyrtz4EpiHqHhgW/GxF8V0XOcZiMjzfxH6RRiBKEHA +EF6h50TWAmoIxzrMSrHNpx6WoQtejoMlK4jEebVnkpByora41B2rTK8tUYQ4s/QiP3ToJfyYagk G0G5iUAn1GTeRZmtjbfRqPVPtZ/9sGlt0e6P1O2x8mm4jA9VWIOpWh+R8SuvxQUByLTEVdju43l2 ObehMNwoiWc4ChN8XTTcACrhmdZAYgKrtnBYlL/Rr7TA6j0v8La8v9AuKV0LLKIv4JyS2OT3mmM/ n0uP4L1bEt0MnMxaPIKz+n8+GiOJ7ClF2AqjsBTUBHZhNVgYbE+zq6rrskYf19hkjp9O0ezi/UW8 0Du54/8br4JzziPUoG2dW0fNJ3qaC10nxaAQ2VHHDIU8D9qr3BKRGAlwzoa9rIUepvSh4vWEnjfe YnCJ+O+aMXEM+f08JmRRvTmvtlXzVtli/bM2RQsxrU/01a2O3pISngrmvPd30TfPprBZjBX7xCHx N9nxThZOdjy1mRt/iUlblAkeQLt5xtm20Ebb3+INHeTQ6LKtYwConyiFs1G2po/1DMraSO0YZVPI 6fj7eQClDAy42AW/pGFp3Wk5rtCxt0irzlrCWi6lOi2vVjXUaiNoQXPO2z7nWB0oGlmtpEV+GIMx 6l9BMZEimy+2/cDmoOsi9PLuaEls8iMQ0xnPhg3O9PLAlv3NiSMakmIiAfTIkVHMmadah/HQsrho EZQnz0LFL/bC6QxYJzdSkCseyLORRD7nIyoup+H15SHIewlPGW76GeaEKZ7iA5TZwiu/9sCRqIpM yY0wHy2tTEk5L6qNy6LRphCKacEM05pdIe2Wg9q3ITaT11QEs6pGd5ak5mUMqknO8a5/V3N69xbg csjxrj+nXtsYnASRrtQsBfEapSHpIWMRv/2iPJUjOPJ1bm2q33wVRoa+Gw5W1by5WwXHez7LMjTW vAoztA1haQlOZrF9+nF6fc7fE9s8WaXdEpsD5XKoIO4n+Gv0DodOhqFGZXOoJA5XSuilWLazjJCC cvmTjQizeYvCpjlIPLSmHfwWZirXsxNcxcUfuYXvDkdMnQrCqg6wbFwXjpb9JZMlGccs1GqY4esb MIesWg/rYEGMdyodst85focyWsJpj0Day6lxRVjZMktn87Cu5sBDw2cdTH6WoIdniLxKeMbGwM9e iaK00U+7gKarY9+JrZ2xyBUskmAVsRGbCOe2+0U44KClUQiLqlfiGH0YuUZ2YgFXCUOaZIN8jN0Y aFXdGeDTIpA+19s+Nfh+9zl3cNhg6EQZMB4CCgyuOh8jZSYG+qKdjfWFHHZ+Y0G1q6bqHfEu7+K0 csrH1Toxz8syETj5pPM2gkeoRFsRgbgMCyFfy2GuULbcFWoLwIaXfpTZZMBEbeTGKePLTJ9MZsuU Nuzc4Ah/+2C70SppFWuOfJvo0Ix0uR7n2fRdmkutilgRuNSB+clhBzakuN7ylnFXTeidtQ+ZIBOT PxX18E36DOPhCDdiD3y3GzyE85WL/CGyQCIwHiGhlnIazHQ4Udt4YLHFiTAecTHQV5KGmneizWbl BTHbOg/DF2nS5nZ/HQ3uaFVTL35lJFwc5cOIHMTo9SoR6F0vg07+JnAAZWKO/Xo3pkfTzDMmfhgO K06Qg35CN6C9LUJkRAvvDXPR/SVWKvNYh7YH9MB1RjnyX0Q0RF0glNZnPi1hJfNmwca8OgvzlP7N UmHffRxf5353eHN1gu9VTC/gyI3wulLCoy93ox/jR2GVsRIdg2GUm1G+e7lqkjJlzvqRUIVVtx4s zltqNm967SfzYK5il8VJxBW4hC9cb7huVRKJH8GcnonkW0THgTzuPLrC60xfS9iJM5G8wtDeEhym n9IdvvFRVi26cjZ2O72GmAYnzT4TnNdFMptb1UWGQUn2UickxI3dzoYQH6F9hBqMn1QMt6LEjzwD T/CHoJCkijRhzSind4BNtd+FM3Y0osNyGzbHALAfxsfY3xQI6MYho+K2SJhOlm79ZB4sb6NsFUPI 1pVNK/kf59yIrOrgEbIrCEpDQPqRA/TLs0DkI+98ZT7rRc4U9QGgeiBniNi+5VCC2QdTZLGUUkz+ iZpguSxOpoW4DI8f4FjZhcJfeEk2zy/xDr7DL6hVOHSXLWb+ceQJIQV24byZi/NOe+PqQPHrQC1v id6a2Li2m9kz6Uk0dfghgobG7jeezrjGLom9r9CCNhE/RqLsVQh0zrcG931HEwj1VttPwY24z2Wu 8u6VmDMqiK0Rj0WAWlgZLrxF8cecmUZf6r9oZA0yBXHc0fGRPsSh3Fdo5OiYWtOcZ2vCe0Act1xy XtZ9EmU2OHVHnJrCzPcTv0BXmE09FvktGIGO3mOIIrVQpA2iIC2a6T3fGDR4B0w2YeRKBsCSFvvb 2n0GLkKsvGNLR5AlCboMHQRgiRcrR0nLc1vyBJs0K2cbowbTjTmA9K7vT7jpcXSpd91jLeaCh85x O9ajDmCHGYGpRK0+OMZInyCdom/cEUkBZjA+Q6KikYk6tf5YZ6RMj5jo0HyeQ3uMh/QZWoqtBiOv MHgthW9VqdehWR9SoGfapS3xHElx0ErkADnii3SYqC0iF8fF2py+K6fBLximUaILx82DoA0vJ2uk 0tebadeM8MxrpkGZKJzwdR3AOIOoo28x+MJXPsjxd174lLFT6oXXM244HJkiK6NgafXhhDHf++IF Fz4Bm3/hMihN8PjCJ+Xyw9dQB46YnwPP84A8PM6aNf86eFOKy7aShCWTbELvGfjN8Hj9eHqhR65s Y+e9kaic/wAupAuEwCdBb5+HDTW2Q8vp73UY8x+hl3eEUTv7tZHoCi1oIHN/hY7gru2G7rSmVAOf n9PBXL1oPVG6FS6nLYHUMaUoFQWQIx9kjMHJb513nvt3UIc/HR/hkWrJjqGDRhEFbXYDUTTZL6ff ZXWyD9yZHYXpZElMlbVxwbz4/YONGGcFW+28ES+EValmOLpLJjTm8m2CLJU1baABdPx8ZWvD1QFI U3Z8+1F/v2Yi+LHnleGqYkn0fzE5ngUdYdwGHeY11nTIwqbJrwwsa6WF3SJsPrpTu3R+6nPBOUiF 7xzPhZLMxnIZpD43hhE2oQJBGdugkiiFEOA97bg7WkQqjlCchHcoIIoAn+ixfoPho/DUgLJuooVg xfMJBcy0Fe2XgAhEg0JIYCnNSHOy5rg/dSL0fE36mR9tZFlQAFOQs4xCChuoVky1bvDhb2EC0ZaS gChMsXnWbb+whPY5bWEC1TngWQe8TBPT8JkxvtGKD7DvVWcPfmykbo+BzkogJQIsgFvMFepovvdI sUWPAqHRpRLWY0jizsd0Krpy+9injodKbAnKyGFvZ2CxMdk2E0Tb9v6azWvZtDywi2hb+7eotqX3 rlL+reURCo9LVuASgWHOyyzkUIa4B7FBNJJ+bVIWpSgfFMINiKH/zawAtPkAOKRJb3Sfif2zVfLk bhZl9hHPhN8Bk5Sv8ksQFXolDFhb+RidoC35SZzqkzi5+hTeuJAWoJWSDbbEr0/XJa2F2mk1Ax8M 4tPHWwF8rXgBakpOcwCnDNWMZ5kisa/Dtlz2jeAqSn3LVxXe8UBOmgtU/DvO2/Dx87DST3bRfHH+ cAIu7COSpwunQI++jl8CN/N7aoKHUek3L6vw5mXj+C8UcCMBmAuApoAXT56nZTCeDopEEEn0BBzG lJIo7x3pDdWRz3k8T1TlydcZyLwrvw05fK3vptMSGS2s+LDeccZ5jrdbydXMDHyzfefTX5b7+cbL cuEcWForeTJuB4puwfxcMfdIQUrnoyJw52eJ6bfbNrNETwU9t7P87FPzT3Ab16Uj+7ipRvqN7yKD TLOi1kGBniLHjQY6pTpZT1Xjr4982vRfBY/PNKigHINTgEqfY1gavL/AK3uHI+S6usjF8/AKh09i BMt0isEyJpipAew92MH7Da6fGx9G0sxgh0OI0ON2nqVb+gY0b/KpPom0WVAJHgCyhX4b/n5hHQok izdh0jiHIOXJ3DQhHI0nfmVT5U7f9h7qUUUzfvg8MU8BqeLV+PGjZVve6zxw04GpJThJeaMGO6ch kyc489gQxzLgEwJADBgRfxP6sRfEZGkAf6Mplrzwa8IO0qE6+U2oDpG1MArVYTbpqSU/tCDxCcY4 w9YziLaSzeZDiowlsUSU1oKOsR5J5ihc1rN+wxZMMibMJpVvUNbFknl5WWQqxLVeQdOn75fQ5Ms2 KsQbotisEAeG7PSkYXprcarT3v+BVhgorwY3PRkLMwKHlZrBJCVqcFJ+zT+PSe6M8flApXIAGVeH k/J8Po89lTpj0N53XwkeQNmGa/kH3uzJoE+Zs7+0FFpKNXXP6eYl3/JSEO6pgD4bGF/L7ceK6Ra8 yd2dl/Fx+HV6lSWEqORZmwkwiVP6Pcbtfcr0HiNP7/QRXUvc8+j/Pr1PIcDae4xng8u+9j+9xxiB k7/BT68fIa+zJT193f4gDfqJmhF1UT18ilk0ukUxzPVm4/uiFfIdeD0hQiXPqJAHbvNdT4u6ji8C RuCCnHMPxz1fLfmSa0ohpdbbkNNfbZ40KDo2vz6PzZFAvtO8gTP/Tg7SyGeYSOMxxgrfCb14T/ww 3p10CH+BDNL2Wle1/aNCxqk5+6zO/JAkSQJrkFyx9pfh11r453CCk5p7wQOc3gvjLRqgIxnMek5d 1XxxL8LsDJXY/ufd9Ib1cOS4ewROKnHG26L2ieKUTihWbIPe0Il1Bo/rhjFp0Gyft7A+N/GztM0y Oc/KVErl4TmrKnlCHkjFUzkbjXCUqJE/Y7s+zJM3LIPR7e/CxfO296lIASiEIFM33RK30QhLLkOm GdRDzzcdDVvLU0S7AUQA5Wu22XjfHvCG/HNUpza+wfWNMkMu7LQ9u70T2JHurf2hGJWS4lS8qfQs daxbBEerp6ibpj1ljJj25huPVlOCcWQGogVZ3SOKw3ox2AQXYj+iFENDykdsh6n87TPIEJCSfzlz hmJJnH81jwE2zFYkGTDDZl1r93nkDHTYIFQIRO4ZJoZVNJZHHIDlsQAIkbSAkIF1UHaz7DCAdGuT YUTbIPutSYPo8OmouxIlQ8VJjJAMNzxJccJrwxMj8AQJOmojh8QTFKPJfubSoP8QkO95IM+caNiS EaTIcMtoMLhmHjNPFn5w9R3vWXn4TBXnF6fin31WL349fJWK7lCeu6SU8NosDG7BJmu5y05Mdi6s F8uvv4OswseRt+r072M2uQxs0li9bJMyBR5f8pVyvoMcgZMpnPkvOJi8hTNyMS4iIwjkjd0MFbwK dmgpGdqymUQsUBEenWZ2B4rVfB91BU7BZGN7sPY9yGRM0EUGuo9slHzrWTaEoIy6+E7gQajEmg6S n8iUk1m8g/NEH3UTVBi22DygcdoSMFLAvM+3DX7nSb+PjPYXMiy58Pve6Rg7NN80PHjgeMSDHLr3 OXVOud8FAJzl9DFIV7g+yIcBXvZsqDBnJLsWQO4ztS1azr/ZGEObBHujp94WrDPCqQxk7aS7Lgmp gMvMZT+C8Vbnh3e6fGS9kyCJ6dq3uQRc8j57wfi0gcxehnPX7fg99xCiTvcCKy+j76rdM3dn7tLc KVQHv6OQJApwPMvuvgY/08HZdX5s3hG1mCeZ24QKvpNgHUBOU8I/4ev11EDJ7C95FTS1q5lcF5SE Ayx4a3Gbi4ICKc94EuWP3HqgobOTAYBpGBv+QQ4d7BDDIemqQ0QMEu1pdGv966Ydb7VVC3T1+sfW N7Q2GP8eHAMDocla7N+dmeCMvtmnJdREsY8LqDEYjnpQYxTWxUQo4FczVt0yedo4nQplqB5/IzfG QlyaKj41wrvYcpALquJQdWKV4lMqbEx1gKHj/DFv/G158FxK9uX/Aewca40KZW5kc3RyZWFtCmVu ZG9iagoyNCAwIG9iago4NDk5CmVuZG9iagoyMiAwIG9iago8PCAvVHlwZSAvUGFnZSAvUGFyZW50 IDMgMCBSIC9SZXNvdXJjZXMgMjUgMCBSIC9Db250ZW50cyAyMyAwIFIgL01lZGlhQm94ClswIDAg NjEyIDc5Ml0gPj4KZW5kb2JqCjI1IDAgb2JqCjw8IC9Qcm9jU2V0IFsgL1BERiAvVGV4dCBdIC9D b2xvclNwYWNlIDw8IC9DczEgNyAwIFIgPj4gL0ZvbnQgPDwgL1RUMy4xIDEyIDAgUgovVFQxLjAg OCAwIFIgL1RUOC4xIDE5IDAgUiA+PiA+PgplbmRvYmoKMjcgMCBvYmoKPDwgL0xlbmd0aCAyOCAw IFIgL0ZpbHRlciAvRmxhdGVEZWNvZGUgPj4Kc3RyZWFtCngBvZ19t9zEkYf/n08hHGzfa3yH0dto JsHJYgfCMQHzYkI2a3bjOBDIYpJA9uzut9/n11VqdWvUunNNsofDyFJ3V9d7VVe3dP9WfVz9rTry X3/sqmHoqu+/rD6vvqvefPRDXb34odqF/354Qa/dtunsXv8Y6u1hOB4O1dDtt81h8+Jl9fBp1Vt/ vzx9Wb359Gm93VV19fSr6qK6rJ7+uXrnaZi0AK4ftt1ht6vPAfhv1UWzq/fVu5fVFeCqi2//97L6 onr6eHmOuu63Q30cqpvMcXFVRrqujwDsDzcD+M13P6yAbPttMxzam4FcYWxzGCQoBHwDxq5Jqj3s tkN7vBmGSOqzS2lQdfHXIKy6uvijP3j+91F8X/7xchP6VG/PO3//zbdVc7xfSd5rMu537Y8jV/bQ twCRZjfbY1Ptq7rdNjvp5LnGEQCI6WYc1YJxbObG0ZaVom+PRtQNwCUq8eNNfHfYHjq3yN12V9dN 9fRF1fXBHfjF6DlsazN2JH4HkhB4fVn11cXrl9VQXdwLv7++3HTVxV0si4aHlwzwhp+FAW+FX+tq vz9HQ+h067Ji3E/CsGcXfej208sNLfbMANqvtdrwNxjejp0MyP0mTGs3huG9yw0YPqYvk9y38c8c sf+wpzbo7u6yAlw6w++t3aZ7DdAb+Q2jruyQWvxHu2/RtMBgV5M5Wzf40MjWi9tlNWmbdrtr9jNw yGuHX5/Ly/VvAvzo2cUK6LYTaBQ6xVSgu/1mDro6VYVnl/ckQ/gLx10WV+iG5tRTeHkFtxCmLkhT jXAwudBlhZOHI7j0hKUEv82ck4pGE8EIqxSN2mO9HfoU3IbgJnL3Z2n+L+8YPeiziP3cLu8+u0Rl N1IpqJOiHY0fKLAYQM8vuKB96Jku4k6Z5m6/29bHqD1unq9Mcwzo++Ow3Y0BvW2DjftlJlhRUmLh BO7Qbuv95Dx2uMUzNOY1FAUuoQowAucR+bCZZyKHw3bYDT2OOsxUsKJc9sGKNouZyLHZtsNun0O7 1unhhMhw5PTuPnNfJ2lHl+cu6C4CRtopPSeZVd112yNZjZFzllh/W5ZD3e+23c2grbiYuscPDMf6 Jsh9uobccdufgDO3cq2SXOBUVkDv+wVMr5VjDF7PLXiZq7cAYf9uQsBBykdmR77y9sFXXeftG1K7 fd20mWZd46NWRNGQFDQDPiqq/eijFrz9gksO/l5eBjLwPIpgh/HmDfwwpAXvTA/ItxjL7x/MNd21 i9wWVmogSMyu9tUFjNOzW/bwDqAA8Z71l2NjsmfPuDKbTIRbekbzPjEHAiRZWGTb5EjQxWt1BIN8 jCNhqo+DsMANDBFkMMxNDUGPQrM9IuLgkq2TiAfxY/gFQ/XFio0R5rgBez80oxNI3yaCWbSKMo3w gb8MDx+/H3wawQHALFrot0r65EP3h2mN9U/QYdAD/8cmI8gAPfiFZFIjAFW4BrtoNVOwFKe93CBu 7AGKgJK5vQ6QDIJvZQE3TbOtd+hxSuQ/IIz1++1uTFqXwBGWzNoDyqU4RmJh69x9Ck8yOPQl9Ysr XtTv8+dBzt+bOmA9KM033LSbC3/2x8DXH6wD+lTDX7J3Xb7ksqsu/ieA+Gvo5498rEN6GYTlTd+F OVhUlVleH/f43T0xJhDlIVN+99iW0rmUqOffBi0AZyQPyogdjPn9C/JG662Z1ZwcgbV8FVB8bkO+ phstYA+RPga09Yw1YLjaqOfW5fugYjBAPQz487H/KRLWwcG+gIXVhSMsoJuwAo2zZ51hGkpvEB0B nybDyjp8+fyvRuC1CEUqxC5DCPnx7+fGFU27yfiYkfpfRndEqyzXSVk7VrCTq1xJW1OxfgUlMIsi ily2dKu6EP3w7E/2DKaAtpiBsNE3OXOU70paKoYzLAwITJSw/g6h0gisQH3//k2InotdtwG2zfCU 7swgPZkmclA+bRV04r/pgRs1XA19+zU42JtwikMC03kGKtZBjGaG50iSZ447IhLujvN/LsBwuDlG sX+IeF/5LWILjGC+suBafN+uP2KQElxqj8XlVSq4T1VDAX9YCDHMxO8do8xuPg06tAkEIg36lXHp mppgM5DjJbjMHagWpREDzVjyn11DxtjOoJmnOXGf85oI7tMJMyqMSHceX9ozgo70a/QTEjAtCsfv 0UKwd9M3I7UxZnVmgu4mpMR0pr3MmMm6muN2jCwFUjzhiiyClOGnQS67nSHx3IQVJt5kkjMyHTHr XNflwYnYhfvyqqY+Hrb7lsXiXrhPCla3LFyWSznEx7iqea0LrvoncAk1ez1YqgI9pnc7hJsmffQk KONVyLVsYB8kQraIXHwc5JMZ2GiySazUG5R4IUXSEKZqmZGbDHwXykcG3kbaJG8GfBzKwwDywSko G2GjDS0fYUAOYVr7tyGHIRGz7Qk5EEjZEwMUJ92UFadr90phSXES5s8tSgvUMSXZrKYkU1pYD9v9 KMyllXoU4ZnwKJ4OzaQcS0v1ed0IxS4u1U9y+WmpHmY6a22LEEq+JS7VU2hKzc6sT8aluqW2ZKnS btboKimi5GGRoF/W12XpxhV2yr1MunOerRXxphX2+eA+LbOo7scVdgpOTqvbY/jry09kOxXuZIlY L+sCRVR5AuwSaxHLwt1mbLv3C55q8YPVyqliyerEwkhD5JZhaVgCqpOWkMDdcQFu6ESJ7DV7iplq DMYsQD5pWJYCQsUyRt6T3JSAeGc8pR6HyTfj5CzjNOsp3LJcWza2+sMRl5mqVybY+bJ6TbAthZim b445OEnihut1FBNuorKO+kb1fWAnm3Ptfk/9Ms7lFr2OOgCf/nk5eMTA12PAh9HhCPVyOTS6HpTo rd+FVFLik5zkb82nS07SDgS/9ad7HO2oUuqM+aMkVBH4tX97B0mbZz5M2mnBiGdb3L5Ae9t4a8Px +VIpbyNUaXYH5rgMNhxGC8qXMbQxTLpG/9gx1KsdltSeLo6f9O8UB4JGSp2PDBNu5HKSISoey1CM W05gfiH4MKEP83kDFhvn1d5odswcJUfeaR6545AdQVkloLd747yTbdAcjLPOcPAZHPQoaWsTBWVd 7WuVFBt2ZVPlWtLVMToGnmxKQWFS1oHC0T6NZvJ4i7tWqbI+vCVpQLvIlIKRjugWjvArWpAqGQBa ADv4lcuiH4wzdVTuSXKDjUoN0xaNtJbgskxyADU4sJB/dwY6zBPWhNIIeyZnC7hbCE6YOF6OEcU3 ZrSOQC+7taaHLWE/WOxZCcETu/GoJW43bCvv903N9nICTq6hXJ2LgHENt12Z0BTjni5sAF6xg6Z6 4vRQLIMV0jAukhERQcTT5Y4/FYdodB32xvsYPK7hjjd6V2n/yMUJkE95Z5WD7UAuvdMGeELyusKu cLA9NNtmv//RHHSLZZtt5FlYVYiD7g6dLU55ziQ5D/eDcGXeFha0aG4ijjvexweO/iLr4yPkWeTK A+cttQUpb3TcbjsAyaysu5Ntk9bEPaoQQ4cV24YjtjnTS20gU/4JlfCLKNGG7frcdctpgD1VuT7M vRJTozfRqrRkOHV72HY3BCcEi/A6Vu31HL1CjPaENDXEMQyYi0+kgTpIcHDNTTVRDtpYjCmgeVtw SligMKVxBJoPeQdwbslATYPe5uITmyoExAC1rAzNvuGURsPpm6JA5nQGvEocbNgx2rdzeHCw3qnS u5gqpxz8BOcLWW9ALKRjZbAFPvJL+uMuhss+rF6975qytwTGWkv2G9C35mdYLA5HtvAzcNFTX0ve 6KklWsx3dvsvyA2LUhpAKdNt210tmWXild39ZA5fGgFrFvzUZvRFv0tUkund7dzxpz6T4+aNrpPe tkVRS77QxzkwaSTY+DiHkk90ZUnkqNcKxS7hsr5OzosN3i7JotGvUtE91a97bwhNpoE8CPEb8ELD 7BG2S6nWVEtE0MturLkxzfSBT0xDoZJusjcuPkg9RMfyaqDmcMSh60jYUjrW4x9l35LZcSBv294I 3Hp1hJNa291xjl404zz/mzsIMpJ7zgt0GO/kzCIjmW4sUcsYR5Ysryc9gI2NGXwGgcwCCJIQ7WNH h24dH0TxbKRLDstEZz2sg0kc+ymrGl6DnPpAThFEdFaSJ1xKMooVJ9aU2/68pPE8ePi4fbpR8U87 HKJlBkej7CTekrJOB4MQUmklPFacMmjSrdWKUyyjzk/ElSVY15SOd6zg5zOdc+Dq4l5YzJdOwVLW mCBPm0R1d9bZJsU3PM4XQZ9xGMrsmK7eba4pk3XUDo4crMkoKkjCOCZzKalk3Tfbvm/xQmcI1sG9 swZOGzBzcIqOoU626DUmjaFKtsZxqjEteyA5qoI9dCXHH2HjkX5NnopX+QDnQohlInP4ocR2y9qQ huLue1zwMqxI6W8dfyWXxJ3HLweioAYUH60E3VIWHxaCyATJx3q3Ww7Db4OjYlKbTnW7COohPmpT Oo3dsrvUd5TXzhEg9Dz9KhQ1SvrQdgP575LBLJTX5gVZmByPw8hvwRojR+tBnLGzy/hqv049tWIx 0jlkg/6dQewY3PJR5GQnXQjLE3sdVB1qXBkkrXkpAZmMb923QaPsUin/Mkgc/Rbz39YlivDd0DRR VfY5qD8VykOzIpE548SmkkSOHQfp9IZAd+QMxbwOc22++bAj6MFahWPTKH6DsnHtxBmUVWSR8uAn 0EBYpy56NNZZlFHSDZc1di7AsAGUi324wbJx2WhDKoOb9vXhP0EtEFz3xOaXyEDA0ESnIMv+bamE TeCdbAKHcwtFWTEhzg9zWnDO4JVgFJemaPyzwCoVxQN3QAhNJymEk+FwNVeKCV6B5CI15dkD6wjm OJwHwnNqgxATFf3s394+wKPp2TgxpCIpJVKW0gHIHhkWpD5As+kaB/Q+SNDNL6RlALBfdSgnrZMy Hjhdmexxncms1w0NxAGTLPUzVI0wsjGwchx/DY6xl7Wz+ABRb7fhqMH0yGBNGaCgrUyp4/MOzKWS omdIervDNF5GkdvkxnkXuQnygSGnygjYZTI0NcHw3JRAEU+DhH4TiH8UzmM8ijYoCowtDizj0cPQ byATNswMbNQ3ncQ3zhk+ToyUbmT/EorWeTBu+piHAS+bxRqGUcnTqb239ZgmLXvLSaMGQnl6HGA4 rxYFc903jZ4M2pgf1y33wo33EGrcaXGG3JEuPAd1eUWPBd6xh3909P4GyjvaKEKG4CYdAjcFKXu2 ML/tTjA/mkZ3gwefNFYzIa9s9hzBMUkIs4TQxAAf7ZccNx9+5Y0KAszt5CbQNpBj0y/gXF2oLIEq XTmD5I4Z4EBHaMZelYnp6juaRqVjYRPYo8WxHwCXiG89eox9ou4KzU547vuajo9jYPD92RV2kmid XohKdvZ63kUaBjb9u6B1K+uZWDoIog1BemGnMK7suv6w5Qy9rY+WzhLEjNRi/nJtYALHwjPZe1nx ssAtro+QB16HX2fidHw+tpgLYq/MebZAI2dcCJOsLLscqaXUPt3R3eidxXurmT1nsFttpswg65T3 fKtpnjoRgR+Qr+NMcXQoJYSiQu+jLTzCuRFBPg5B0zrh501zccvHkCmyY45JoOHGCwaLS2iezEM+ 2i6oFTc2HMcHWJsJay2Hy4aSats3/ZwwzoeeEDaxLMqxDRYKKlCgyT80xHpmBn3ihVshPfqxEcPj toUqRpALG0vo/tRGtfg/7mRqEMxNYiTz7e+BV1KPQ2vYr1Q/Jp3GdEt5LEkshX8OKAchJ+vl1TU/ VNiewzN5LUiyXzGmrKndTiXozhFfMe4JcZhTKlZMxkjVJp7rKay4DV90o1ioO7bbjncayedTcOcX P/yNii8CN9BEhInmI3NIQKLEdrl4e4QWIH9CAp2sWYZBZESPGfFMikWH96zNvQNGQ3ccNGAW3+/T NKyU6PQYZ0+vALS6eCcA/W34fTe0K06ZWfH7PMXGELDp7d9HPwCfDnlsxAB/RUtbXqTtW/Qq4efi smgm7eW6ziRtCiLhkIbeB1mS9kJkWHgjexJ3gJfoPfo5d27uAyJknNvvETHMw/3AbwIpv8Q5vBS8 3ahoRA7KnYnLfmUcSFXMVwcbhN0gqVmTjSUrYA3iHbJBcaYA6IVBwsMAyRAqzCGvMzYRqjFbG2q0 GJakPpRhcBj82twGkqIvT9BfqH7TSBSoFQWQtR/2ONlRYnqFXga1wOGFSvULw8owWSIuxXGk6tZ4 eBIsx2eYnq1XYI/Saiws5xJmRhNmJkkkjA4rb4g2RMYWm9ZEND4zgZCjASFVhpFpSvjHvo6CcTtq UZmP3YF35o9s0hkfV/x91M8wV8nhR80ntJ97REK4F+ERjRo5zgye6n9U6M+wpF/ACckEZVPcRNIu Ie1a+0N4ThNSU/bgz+A5o0gnXWplDtZ9z4vI/XCC4VIis2DrHyJSWY5lHOCCNEFanhpjx8pRBjQM WeIFQJK+L0MzFgy+9gSsGYAumqrZYLkIg4dhUekRn3lE1gcMvGz8hUyePw1PHiW/eTY9SxT0cYTu SIU3k8yr+8zog1tUMp5PeHV4kyam8OQhwpb0unfHB3+CEOAvfJd0YB1CgJsIobFtaGv3FlgP0+1R g/KYqTLeGuyJ932BpsX2w92w4vEmnVtz4TEd8RYISITf98IvEuH5n5Lnv0qefx1yWxtl/ZF1WXMb WN42AxIMHFpKmeaeM7N9XqHujjveh0IzTv+19t2TltM/bePOZmnBtOxsrv+gSkvunZYT/mlbYmGi JY5NGT1S0yIInSktIMcdsRTYtTkhBT9Ljqe3pbNMrrjOQwfLuiAvphenUwYu2d6UTo10LaQ/8eB0 Ck0+e3UFZPzC8t5+E4Is8fGTRrJA/KOSWFJguWlb6lg/XJlqhtoroKU352lNZMGMxRZkVb6Ewt8a WCUsZt72235AC963t1H2i+ssc62teUH8uMP3z/RuYeNr7vovfi6bL8W9lu/tHJcgL+zIzFUOFsYd GZ3dxtdAhTigOs10F1jKbd5nfEqaHthpI2En3CJ903g4A6NJ3QXTbnwC66Y1BXwkF6Hb9Vsvn2qK uOfCUkJgWUswWCxiXgP7mBbi1OrCoFdeuKPGk0pkSZGXPcz8MHjPJzHa/h8GLtY9ObSxHcazAMHk z8pm3vENBLgNV8Qc2Iwh7jeS8PQIFYeF3i6L4c6e6XhFWZ9luPLo1Ry/3Zl1WZeXDAlJYYmaGT24 OtphJEQ6ZmThacCeLp51PaGnU8HF9VI5G3ckOpafhU1Dy880XZmaZk+GQknAqVny1ifx7ZuySTaD DjHeDJwQLJk4HyDgC1hzeHKT4c2AxdVs1FpsfC+OwBj5My5b1Xnxmvgy8Qmt4Fd8JfMTX7FbYWOa MHKZu72Pw7YZYL/e0Y2aFMYVSPvk1sPn9o6cdNdg7L4sjfZIltCwuDbdQhrXr7Fx6SXu8RUtjuTV /amq3uzwtCgAdcoR4Zzt7cu1d9HqUOeNBPiS88w3OcYDna8sheBuWQYmBwKDs0bomQxz2cgIkf1e 00bpnHwIZvJMFFTYd7Za9nrMDsroyUgnK4WPqB2T+faz3QgBWlDFOP3JSzec1STc1QTSMP1Zy9AV 5ajZjd/3HavGFJyoobB5xqox7HlgG6i12wsXXA5rRjGXmzFKiqsYH2s0SBSl3FxJGnDBPVzvfWSn jJRJyhYvLBZnALxL5hoNB4VUQOegZJhMy56JcR7o7izhvGFcZjlFXkpo+9Z5lEi8L56sSd3PbVcz dxKsTEBC+HEJLyEEjmmZ7Q/TY+r08XEUo33DV2od/FVsEz/do0ENC6XAAiWCpHsOldRAfcQfLv5Q kYMuOvRBhcUv3kZp6upg24QMYPoyizrOSR147+yURQv53TyU4KHffHapnIVpntrF73j+Dg+I3bJm EBUr0Qm5boQsQqUhl0hR8hWnXPZlXCcDxiem1ls6JZXK0l+cYSL47PYqdoF551d0DVGijGUUdMr/ QOJa6f8UhSWT00vwGQo2uf2a49CUJlLhIaMynYYXKY4h96FFvJzQl0N3LWE0tsso7+HeyQmzuWxe HumsgY+1lmyoPZKWMpMD8N7OQ9Lh0Q9agYmOCr8TJcF18DSd2CbpHLARftfhg+5YWgW3D4EFKTbY na6+BgjAzAXfzRnwmaHccfiano4kNluWZsfnqgYW6ok053l0JsPAjjFaLxUEpmerpQGOINdjaWA+ Yf4hMkx/nG+et8diUqP65v9LRcBmcr1fRxzhlfadxpJABi0sENYOmMbNw/khWVwMXOLX40exOPB5 VIWlTeC+5l15jp9mWL0yjaFiqjOdNwCHDZRkXfMtv8MJuPXUhTJG5NlbcAjDsl+PI48xF7wH+7wy dH9oPRQ/MGZMDjN8aGxb3tDnw1vbrh/6m9BJ/lmis2kGLGMuhZDUrH3MK9IZawLyK+AOOfz+BnII NrdwgCL1Ay62ExN8qS3u5ZboOqYsNhAnVXYeLetmPoFS56QXZOKRM5aWiJwtEzMjiRC/ml7uM1SA aDPWmzRcNNaR/RlIULjn4qOIFNwAbgVZvn24JqQ5fuJcSUjtgQ2LGwGjXFsGxnJcXxnJDCV4Ax2T Wlwhplz8ufJJzzJg4LtrTOhY2+z1lVKba9qyvO6kx7hVf3lPqsRsis1ITQqFWX1AMsNm/3jrjQpA LiMFaUmWkRwFF8b6ehdyLQuMI/hsWnG0J8N13R+tyGwKFpwLaseqzBK4mLBkwW4efGIq1qTwgthe vcpDikiNjBCPIPVvFJykAQbLmuEd9MUW8g3+TZSBtw1ykO1ar09CC0kALLb2/BChd2uszeA8yOZB QJo7noY0WEM+jXUiWQQB+3XAi7PhRAGpMeO3fBZPGeKMg46Ei7KbSIMhGM7TRqU5WeF2KM2uoThg UkkS1EPxo6pB3r7CvfudVDMmkXAItsJ16bHdgIbpPb1AFvRENRdEwCNL46alMX2nDJdenUGxXM5a 7N8dq0s6G3iBFJHLIWdSPer58dhKUL1i/gCRMUY8c60AYzB63WRn0sQiIcIaMlHkGhFePY9SOF3o 86Jo+DBIM0NwaWW+sKQaV+ZaMcF4cUM899ts4awAILaqJ28ok+zS0wf8noeTq/KHMBgK3UONfLYD I9p5qivlrbMzhXqHv93xNcA5PfXusLTsyb5URKBz42JqTPl1PCgW81G4sV/pOS35BVLoZnwHXZB+ nVeJYYc12CN0B+qfGBglLbRbi7gETL8MMnZuDQX53eJrJ50+kn2EsIzYNUe50a5MKbx1jb600hJy 5rqwsE+0oAvjcknho6xxXcf+PB+knmb5UXXHruPteTZMHdwUJ1eOacawgcCPCy7cjOqjsPZU9oKe 6vAt4vuM2zJpPa8lH5pVeczZlspDuos71GeJu+pl1fPtOnY6/P7b6V5f1eMvCKj3Rl/A0N3X1Vcn tj05n46MPH9J98QW5ojBmvEl8DWS6x3lyVpoJnMsJkKR6SnJ81BdcySYg3lIcwQ3fgh49es8mJzt wb4lJ4PxfPTYxPbILmy7q1T+ld199JwrnbBIBRD5KiQs89NJLb/1xq3cD4IHbiL3udPZdXxl8IDT GbFWJXrNDsPuaLDDheVdsxu2R3QpB6egsXpSIgaNc+SmtVDLFwfyOTKU5xqxJjethXac587BgfI5 eycXktrolKaqxNK/fnhxkkc01JbZJ5txK6PkZKtXwaS04te3qI+7ObxISkmskft71xhXIE2Fpx+1 K290XfM++H3Uke8vSzlnYMbxip4o69b6TsqpIUSbREdnx4Na3G6vP6hgOnpWRd/YNIu4eJUunBMX ozih8HIjCSj5t3s803h/0NtJ31bJCH8ib7UgXsxqPLeyVpLiABoHkjxhLJxWMXGE9CJqVvj6/ypg NvmhKJZKLYQserN0WXd2kUcHA8lQ+SW4oxSU5csCiyf9mxSrTK/dQiMuawvhmu827g87DP4fBI6D Pe0cnHxU2O67lme/wORRWRSYfWlWn9Q43rMU/RnRl2yKAyXwibPztGgthWVYxqvsAodsYzAL2v8Q nmBMPLfR2QjrRDGCqYjfdMI2GUYSx0QOLxtHgo94rJeBpdrNuAgW9QoDy+JrORG9IznJ+S0GLRy1 nwuS4PvsQhVjwwJGmdqQNjIxePHk4Zry8JHabQvPTNgrxj7pDh5ltJR5VG4H3jMcuhk4ucQbnn6B ihWO6YuazXyWTOHnJ2u0OioirdLtgTXXDXgAfmVw+IZ2Dk7ybIvfTo/MRZ7y52gb2mTRAOVGxZEj 3/Ar86RrgNEovSpabcqT8JbPCk+oAG6HAwcEM3AFQc6V0g4xlfjT8QemAE3mVsT0BOAKu+NpUX0C he8Y3dgnfxyWl2ZC9/0NCnwO5gPbiaDYO4LgFREE8SgYN1/997+GhG8x34TJ4zz496kp4ow8a4xd 79vLEwiacR+axS51MzSsm01lfak8AuuOityg+RsV6kKRkIeKxCBq/e6cR1syZjP+PYT3Vw0Qph8b 5YQpz+cGmP8JpzURju/M89cFss80L2SxrhpxjaDVBwyCfvsNFUnu4I1cNtzggqLDGk7/it/Wj+qX p/K0kysxhFBLs/W1To01UExxztL3XjqbDXmAZQIsm/JhAKk9ciAbmCf+VrINSmdzND+RzYeDCijc SIi3OUJjTzw7MxquY0+bZfxeEsUB7Yg+UZ0CsqzA4MO1rAEthpcdSsu3s/UndIJMVuJClMRa1h9K ePqTNym0Qoib5+BIOCtnJR90GsIfHDOhSdruNLFYo7hMnV78HPQ5w1Hlri8tiHclnxYX0DWF437c BD2fwM+QnUVwEEdg0lYLAGnFt3kSlEqIYOJ4msVCKk0GIX+x/gN1D6+SaZRlSCgFvR0eWRUo4OGk fDYFtUy0LMUtNkjhrcg4YNko0+qagrPqnPmC24E97qMzfzG364DC9ezuj0vZ/Y2AxU2EmoVPXC1E 2V2boM6T+rLScY6urxs+G2ozrRhVzAdkoytcqMP3jjNwEfHF9WcEjFWVj6EracV1xTiCPqEU64sQ ikwD9QinbUXEEYU12uo9aemBzwDOhWIn0a8VyvZttBIr+gSt50I6LIf3mItceGhSwKUJ72mfRma1 oEorZqdLtlfpw83p4tnLIuZLMvaXTDOZZJqepmHZewYL5/Eb2HDkBa9cYxDxTfPpfw0SJACKfnkO 4ow8Aoub1UIlFXJW2rtRZZfECj15pF9R2VZFwF3bnIh16c9azbNAVPYx0sF7kQuVRaCTg21HjS1V nXWFkUaUrKzlbNTumIIbC40Lte65bEHZN8RN5/CYQblCyEbLeKdd96iU1NP6kHnJQ5NOrtCIK9n1 fD46o1Gmf1KuXUDppwRIpiOlwIlPxmCT8ssCmAbVs+lFDqqLdV5lvOr1R/19pQypdd1fYXzHp9MG Pk86gSvF6MmjrGzJ60hgqxVNZpkypfPk+NbPXHjvrgmm4/2ogbVfNsmrs4CwSXH/mIOTmBdKAwuC 9tDEegUNQ4gevW0t89j0TOqGCuLuy+qmv+yrA6epYPPwMrfVNYuaAi6Vj/HjG4Eoae+ipcYkE4Mq vkoRlmoorlPJri3uPU+C/gKx9CAqwA3fqeG9CnwiJjENtYyHUrX9g+9cKru0nAgfClhLfQghZaap ON/V/IHxOiEzU4WTNGVly42vHJOccEAlhSbtLVfRUqaNH64lS3M94OLBUd/9DpEQAjkpOnYVvXTC 8NVI7JOa+MPgv+CJP72tA4x0Uux0LjISQKFAzbpomhOO+i6JB9942JM+CEGTkG7I5XjXCTulJQph XBax8nGzg/ZGhqMmbwai6Iag3Hb8c7wVHpP9HW/E9SUkOhzjw0ZLP8A5c8iaxQVHHz8ePkWopSAc G7n7xMDlTHaG6WFZrybzoX5CKI0Fj6W3GeYqhv2MbzMkRMNzYQvSxG4IEVu4+N9R8I72NxECxXCQ Y4fhdJANGNkB4pKfjxiZ7WIVWbRKdCxEfA5/+CEP4c4XXMg6fQDKSn/voXBEWTZDUDzlJZkAMWId /6aGz+DIvKQvsU2HkSdNdQwlMWbSHwCli09oM+W4v01HuCTXOV0Mza/tmQ9+hQ+EOxXSPrIyxywg H5mVIFPWj65hc6TnWzz1XD+G4p85TF3FeFBDDINIMQymwA04pDafeWE7suM0QMtbydnEmcfzGBWn C7wu7a9pjU5JMwcnl7e6w2v7OYmeu2aPaiF3EnKcVB1caq4czubxtQVTWwejnhPvA6+J9mxGU3p9 SUxUActvv01uuw13Eox17gob8ZNtU1hLv5Z97iEbYSmb0WImSk2ahSTRU35FwHR5aP2lrgzDgWL2 LvGrEYjDFOOmgaYPszdkAuyNYr96+rgrv5UqM0euVv7QkdJL9B5pGS9vaJKaGD7fcGgoJvMnweH5 jGGnifCCKwwfK4ViOINPyEV7MhOHlds9b1PaTL54X8/Fop6jjp9ZygDBMAHW8IueQd/0GQFbb5v/ NeHBjLzoYwOFqblJutkjg26HieIRPwQfofmYvEZm2OAogYPwnQmA1k1wrIzPZntg09kQGw73ygLq +HtSdaM6YhDQSs0jMsudwvIHf7Qq4M80zuBJDOUPOUfIiOE+CQRhBPr4BX9IhhYohsrwgR5rIYdA A61d9CsfQI9hk/2ixfx7bIHP3OGy3T6mg1gNWsOmBLVUqo1sguIiYAj6Gp/gF+KTnnp6rRM7cVR4 gu9YOrUTnQVV8x7odZIKsM4pvy0XXeS1X5sty7WuIaPnL1yOk/9oydacYz7sTiFKtue9GdoiLyRJ Qi9xYRHx4q+ySZnxjMgKibmya78YnXa3ozs0hADsw/F6K0zgr9hwpGl/MyasZPmqRh/0YY8ZV8WD FYFi5XaqKfwVJ0hAiSGSrNSJ5PK6pbywiHZUHlVVomzU86tcigs+Cc8kxWYMfOGR33iHW0qE7XVK 2gyQ97AbhQ9alMBwyXDI4MFmcLS/IUA0YbonNsTRMhoctN2M3ym2O+9nFIV+m1DogzL9tSgujoPD +MzAGxIGgsQPah1QhioQVATxoZ8zFJ34bWROWSc6zDKsz0cRYpXXFy7wKmMB6uP/A5kmULsKZW5k c3RyZWFtCmVuZG9iagoyOCAwIG9iago5NzY2CmVuZG9iagoyNiAwIG9iago8PCAvVHlwZSAvUGFn ZSAvUGFyZW50IDMgMCBSIC9SZXNvdXJjZXMgMjkgMCBSIC9Db250ZW50cyAyNyAwIFIgL01lZGlh Qm94ClswIDAgNjEyIDc5Ml0gPj4KZW5kb2JqCjI5IDAgb2JqCjw8IC9Qcm9jU2V0IFsgL1BERiAv VGV4dCBdIC9Db2xvclNwYWNlIDw8IC9DczEgNyAwIFIgPj4gL0ZvbnQgPDwgL1RUMy4xIDEyIDAg UgovVFQxLjAgOCAwIFIgL1RUOC4xIDE5IDAgUiA+PiA+PgplbmRvYmoKMzEgMCBvYmoKPDwgL0xl bmd0aCAzMiAwIFIgL0ZpbHRlciAvRmxhdGVEZWNvZGUgPj4Kc3RyZWFtCngBzZ1tk9zGccff76eA aIp3J+ogPC52E1MxKYmSKFm06JPtsqkkKtqWlBKd2MqbfPv8/tONAQaLwe2JSlWKVYsDpqenn6en ZwD+vfiy+Htx5F9/7Iph6Ip//KX4ffG34r0PfqyLVz8WVfj34yugqrLp7F5/DHV5GI6HQzF0+7I5 7F69Lp7cFL3B++XmdfHezU1dVkVd3Py1uCyuipv/KD66CYNm0PVD2R2qqj4H4Z+Ky6aq98XTq+Ia dMXlD/9zVXxd3DxbH6Ou+3Koj0NxlzEur/NE1/URhP3hbgi//9uPGyjbvmyGQ3s3lBuCbQ6DFIWC 7yDYLU21h6oc2uPdKERTX13JgorL/wrKqovLP/uDb/57VN9f/ny1CzDF4yXwP77/oWiO7xbS95aO +6p9M3blD30LEll2Ux6bYl/UbdlUsslznSMgkNDNOYoV59gtnaPLG0XfHo2pO6CbmcSbu3h1KA+d e2RVVhWc3bwquj6EA78YP4eyNmdH42/duypQ+C+uiq64vD/T2m4ZTA6HcqiGvimGMJLLaxP/5duS 1241mBybsh2qfYoNuuu62aB7F4IUdD+4eClyh+LynfD7EPtsi8uLr69gLWkpA4MfzVg7iZN135dH YpRx5jI8g7NMCOuPZT8c6xRdUEm7wZrH3/Imb2P1UK1g3iYU8eTieT1gsoeKeWJuOz8d3aEp9+0S nVR66G/lG5V27RVz3OUno1ZrLJI40uvRDkVb88vL0I6egYU5Qf3LVYHuO7/DFHiGXddYQs0F+/am fwdwN94YHJYvAAd3uLcC9j78VgBUEZGD/1Noaq92EMHkIwwvr7gycEKFtw2B5oSBJ1fFIQJ/fBE4 dN58jC9tYL97d4bCsSYjzfnYXRp0E8ZYlcSHRvSDgJVIDh84Cr/M0yk3u/xkHfOL/bEtj3sPCdJ4 t+rEOzKNefB5CCMIAemgPqSDqiUCbpAOogwiRfZilMszfByVfoYr77L5Q1uX+6E6FglJWzYd7CHn IseOKKUMao+vVIcZh313YtM+XbSz8PprhA9XJtrADgwwi+wLxUYxZSIYm+AU8O5qBwC6yYu+JqPr yGqWdFXn0fUAuq4ZyS8Yiu4w+Gss+X0oc+EXl7/iGWZBZnANTe9e7XQXyGXy4CH6S5EceAiuCy4o 0jEjAKnu7TnoLh0IqVyjc+QhGryDU+TjOYjjlKmIJhqZFhQENKD3d1Dih8Z1bI5mlcIR2z04hHxH syYRH8hHwO+uFWiYjETM207cc277BYdpRx/BafKBHqlblCgucS0bEYd5U+iGrqyGwz61hTWTD5a5 U5b/fX5W6LD0/lx0Nh8He8i5UMe00DZL8jQd3s1UVy3CH7pZuSxNlbvRLv2p62tmCnmRTm6/78pm llTtV+OaVlBzry9dje4DIgCTFgHMPvJ7sy+3Gte3276sdd4hulDgClhvfDsY/egKNgJRX/5I4AAL oUT+FEaNSJQmeWCFIiOl7DF57pxa671/L9Dsgz19Yf1ks6B2yJS9aMHBf4jpMuSyNHQpqJPmD0uZ OUElxRo4243cOhdvILtAlbOzrh+XnvM4KsE5nxGwC8EBMXw6yShvSiyUy2Hf450ypbWseTltbHrT NOV2uOk45SbO/hPxtV25n01wtn7YJZiL29cPbqBcbCpD/bIYMiV+ScYwPiJlbHZ7lOpp/3rehKPy 6KPNSbBvy24Y+mIfiH/zxH0o6441SYLu7MT9t/mYWu9Je1Yxd/uTNGIp5ct3EGUuutZDW+7XMGdS MIWqJAVj/rIpnAybVJcpjAQ8TNw7BYqXphko0ESEU/KQ+dPWXXqETulvfQgBplk1MPUGxetRFRIa ElrQW553DINYBxtWvql+PtTHDMxYc2iifFgG7AJG4UphsSIIV5zkYnzZkHg2TwwV7g293vHhL652 kXuDMhZtKONtQRiZM12wa1D+c2DYfp8GVClFa9SbPET9AvEzE/Vmets3e9LQfecmuhZOFuazmd5O 0YQq2ej8ay4/ZQ4iOmeMrALIHo5kpTN0Wg5UpwvAZZRiAfgC3SBUgjwKJra6iLh8G2xJQ+cDbd1U 5YECaRh7IxTEiXorCaqRc3snZFtyqZsj7p+Sth1WIpGI5fEHwo1IlGIyTyMZbpR3Dju/cYDVy5OO SIpYrZuDfOfXbkS2u8a1uMnLt2n6smpZ5c2Vm7EVTwtZJedMpWlUTmpSbBmZrJjKh07/qUhu46Jn 3IHM83wz0VA5NqZEseqoQ06Z4prJu2fOdfuCOIIymQbzgq8rfLOWz8/HyEiemKv8fkPyNZVSvJRJ c45Ooj8vuf1lyMziYlHSwSiJWtd1sxuTOMv6tOChTdk5oTyslAjwmuyxR1aZtHn3WXrlufEumDuy MVRpGusovLNnbJYcjmmyg4SsNKzDpsGI0aIH+LzQmz3zqvYtTEprgXZplltCb/ZD2eyZ7BN0Co0U W25eraZZczu5jxSIg0gBNhp4c25wWrg3ZhQuEe6OJrjmGRKmXULiwlzGdAzPAcwAvClBjikCF1p2 Pp6NYIMaBQlm6RU9GWqj0/4m7vBcPULKDEUz5CLWwIyWFSJWuDiEPNL6NRP+4vJ5IHsSTF6z0WX7 I/JPKubZ8uxcFR2jwwpCQdBYONKyv7v91Q67tmgrAcI8LABljzwOW3fr6FDBZoGzJutz3xZlyJPB OgSnBBm5g9R7aZFJJ3kXTcmwRpC3gD2s77xbJ/+l3zjo4rHhMUpeG2qt5ehwESB3znNnY3jvEVnK QeiW5WAnpYl062RwI6KLBL3dGFyEMDlJJLZMRDLknJZARAVdzB/5eC64Oacuk+dICoKcKZ9cnAEH ubBhF1IbidJjN72dtnTSDdTJ9Ia+JLbYlpOiAKXFzGYNpmezKZnAI7NvCIJXpMEvdgTHaBqy78MR jwwIkSEE0RMc3qBZ6QMtVwPOXPkhAhSEAZ4xQvSskx2ihqQpVI76BXvVIbsXFTxLJSnYm+k86g+6 oXgUr4QPo5DsvHExBbutq3onBao0KBuHK0AU8CdPSRzGbWEFL0sD5URu/AZg1JjvJkT4CBcpC7I3 xsVVFJRHoi7ckhIEIZ2LzhxB0ZTYNzYUeSggmTNMxgnA6NMn8onK2rDFPZtKs8ylGoYNW0T8pqye CUXTuCLTqCFETVkKVlVh5SGWKG1c92JAZHJPq/ifdfFGSYAqkLQDzHXoG/JbgVp/VnNjvVnytIdf 8ZCBfSxcgKZxQJV00CFSZArSb8TPykyovFeQN0hQyTTaF4DgJl9zcQehTWLvwsQYqHQhoBhQO1/S OpAJrhf27NoAx+Go8wvLKELjx0lKReio18ZxMagyD6sGcd3LriHCpencOihqyNtFR0HhcGCbt1/Y xXaMinbRvAyKQWI4JuKDIH4VjUJyCLsihkeQJtsIDlrjXiYyl3SevimGdj2Vjynjrlia5GNopG9c DrlfmzOZv6FWn2clKEiU+RgL2IZDWgv0womEDA/3xBGEvxfluhL76wNrwL7hHEqgey2hXK4PJMjd uPLQoZ26WDnkUx/r8lgtEWtSOa++3rYthGsLg7iGBWEd8AKDuMf8iWRkfhaAtEOFblWxQTLAWg9E YrrlN8WLvnmGl0+6HQ8uncwkbdOUTcMhoDvJilWanTWIspJs2Lzru7A9+boIeMfbH2a3Q1P8UMyg h2b3Q/Fd8Vc7S7Um9lg66VsVeLf1ecY2yYSPE1DQPOUGYYWQHuTwpce8kPcAI8QkCUhImSg1Sfkk CyHe101TF30YaaNUEvFf/mljCUxFCnQpNpnfebv+HxPasB5ZF3YF4dpDl//VBAymVd0SuWnDwJgf 8En+hk3tUju4g1GHy3Nd72sKDhU2dT7X2Pfofksh1vu+bPcttnU+uj9soONkx+EEHVKs3rxATCVr DfOZBeIXbPKigmcW6iRpPP4h6lImKa1xYcriFwPE9CwYOBxTAHEFDYPBmq3Wi/rQuQO9daVKs/Uj PNDAlMuTTwJWQPNK5bRJ2VU959xGp9lxwPFcsb28goKcgluqLscJ9TTP1HU2P4r+QjL7PlzDeyig w4xNGMRArBoZ8ISxMWRMGyiYJJxGD7b4i30bjOcHyIYGoQheEASrXRV7YijkOGC1fh+GDh+FuGDj 2N9Pw3ODmcjcKYuayAy7ATxJMD7DCnj22ZZO+mpfHjj/dBfPgJacHqb5Pp43VXBhvjpjsv/oES5s 0pS1mnD0aCdOp0e2cPLFj4PZ8ohZyP5AgCDytvmqiyQOTRk6w+NAlv9YPyODzBB9PUqg7AYd0kJH HXT6yu4wB09swY97mHogmukaKB8FXSjvwwWB8mcoGE80wvyRDW2s2N/2a+QlvW10o957/yfJJQO/ CFTqRAi0WJ85XZ+GYb3LnHsM2LgLdGOwMltnr3F4G3W8exLYMXJNQoON9HJcto4oNw5GRNPpDvuS 6SJOqRUnY1esR8eTkkoPLqz8XFEuXLEfS2GCxC8gzE2Ip55PMiM5qHapxCNWg/YRmIErZ3RNAQDX yiCTptkacsQbFi8RBZIAQ4fqeGS4UabwOHJD95tAHhttGo+Yo8sTLRPAKqFzcWoNh+FLKLJw4MBo FHZt8AC1s02IiM0pMjzeydFpNQN9KWszrlkbeAevK134zoQ/feJ4tEiUtSckeZuNW8MgI61Qbu0K prQ7AgKP7jpb0hNDxzafc1YS+cmqSNm6eaK2ZlPxaIjXOO7JpqbxP+cOfuJTWZroCdadkvo0qBs9 bhx+o2h9qHlBoFuQljF4Jy7Wl3SCUsO7QE3VLqlXNGEx4wrpvWA/ePzkAYoLlOJmWo0KT7RhsvYx 3MWsk9mhPxpQJBY7qtogvFei/jW9dsmID0KGkY7oHuOYUnh32wuv2LpXufG+fyXP9n4OmQhsZkUS 2HoQMWfqvMg0d8CZ1vOJz2SE/b70xQfH8quzZsV7rmYEB4GMza+LwwyvDPKyhtE0E4EqbmAnTAH8 YiYYgTzTQh3YUBahyWwESW3EaC2L26YbWN9ERtK1zmJVbLXeXLYQV1FdR7o/hvzMXtldVmUdtc1D N00ha8fUf55VmY101qoMDeUEgYHUHNY/Fgm6kDllj7DN09fl+foHpv93Ca/oF/0TtTAjfrdXXTqh 07KGSeSX6GMpNRlkjquaF2SqI6vtO6DDCrPo9k3ZH6l3Juji8mF1Vy4KaftYDgd+IHTEPFs9rBRl Fic2VAr/VyIKCyHCi5JOZgXcibjC+pejNCZ6VWyshGxQzAw02C+aUbPlXXim1VVByOoZTIQklEga xhPD6h0+NVRPQrummux7Ws2x5/zxyB9+8TMuvKryGDH/v5ecJgLJ2iX4YRA2PoHebGK6CX8ze6ME B1pqV+vfUbvuWFvaXQz57LOZok5KaX3Nub4hBgKPYIkHLu1PZM5LaVXZsQrqV6uP00RUU4Ycy2CK MytbWssdc21pMVXYhKGw8rsgq9+ER/arCZaW9PJeOE72/L6tD2yeYhZCivfxG5uSuDHUccVABGOe Ihygmgks7EJOdj6WJE/2SxpqiPWBw4HdnNFEjkv2QpKQiz1RcO2RmDZPI1tN4quxZ7440YtbsIMr kyTBKb6POOCa9MoEyhNZynF3+U0AQkJwzpwN0LxbACocyHAYPvvFigkT1o39Q3B7h68CVpIjCJgT Y6CoEoN3ULyCQb8Nv7xskk+um15WNByKRCqJlBf5gJ91WX/JrOHFLl5JWqBTgF9fASYJ8eWz757l 545maMr6BPWS0mRJuXlAhC3T4dgeU8YzlC4NDT/69vGzjyVs1IMulJwl2bv8B+WnF+VncRNeKR2K TE43+LMEIUahlN+XxONyQNnBeBgtAX8etb3yQnHXNuEllryyl5ye6VK8csBxu7jet2rRrS71kReA LFBgxshDMsWRSNdNsgiW1QSiJF7zt4E6kKSLmcM/LQN+A5jthoHBbq2N1TAQGsCyWZoRaxzA0T2y 8DYBR2qGZFijzaiyGd8REBihYCypzFmwYOlgNrTzbn3YsIYRb7eOJg4b2HoYqJFnf8+fT/DBLjwY cdFLQzK0IF6tGuD7vpOKtSAYH9cgjFTDZhUtzHbC9rVhs3b2Hk3A1smIJUeawCchhNdDNFgYbpoA loV+be8c26Fo5zaVuPmJjX6fjxp9y2tbd8Mmadw+iXC+LL4NEGZfnbi91eLfMbk9R/xooWn8+lxj erjguZ6GdT028cibUI5rCrh37A6pExoc52sVxNzKTaUAhhO+4RUY0IYYAoR1fuiInYbnSgwYD2Xn ddOwvccOCUEzsL+xZoozZ9D27eLseZV1/F5CouyT2WdLPXE12ra84D+lsv9372aHgc7K8VBqEMNa hctfzZ4jk02tbETOU0evcOVXjrIxphS8kQSTXzIBAsEvtzSsBR+np9HwTIJrCpmWZSNjK/NNzZEG JtkEWWaKnTMWTtQ+htqc3dQoeg3vm+/dcWr0lN4zd+60STfO1fglrs4vcxS+jKeS02k1wmbev5mj khLib/Zrb2d4O8sLvJRITRfOFQNEYEWVhFoOoDsQUZ0Gw/tkS6MNie9hr5RMGl0zVY+nZ2m0OR44 vKS0aYZNKqUImol/ES9Z0wchBkG4vFixa4vylj3GKo418+YzD0wpm2IoxKb5D0FrSwVR5uu5LWsO Qluz5G6ryheLufcsHKN2BWovLItPVAefis1kC7r4Qwu4KnbyTN3isUoswF/QowWKId+ADbkNJIYm ZDo6A7P+MBYU87G82+uFZpa9C03WfFBguVeznHHR5Op040RAJRQblfekBcgkHUMOJBT8PTtPnadv Wq9xNoUvjsTkcm0psUJgpg4sEiHEd4+QKjYhC4Es5UY4mN+5yohuiBXq+R1L458DiG86DllUtmxT 4y9dT6agkzDz9xVuO6Lpp/4ufBBoyw/S8CZOtecMy8kg+YA4TdDvb82oegmlX0O9dthpOVdjJv4+ PjJF6HIKxKjxaoz9iyB8BKygSFoLBJbDPGVRjTxSRRlBb7DOV1I4QLki3/Nernj6LbrEBJ7Y5Zld PmXPAQveHrqtBwo9xCKT+mSgNdX1MzzoV/DPIGIT/m8Zi4/d1CoqJRrenpcx4Nz8OeVJfIgkHslf QzeZiQjM4YvvobE+n/BtpzARM1byFUZAtjpfsuGZ2MMfw9IPD3OzwTiUrwJrK5d0a99aEugXSDcY FAg4KkvHWJ4KLeIqgzRZ9mAf6MoLYBp7Nx4ON0Lt1whwnPNlnEXEl1I2ozkAhSMsz9ZY47rMOhke 3EBBZ7SSqaM9siENiWft60WZlspJVfMCkmlnLQVYeq5IjCchlyu0aD2kSuW46t8ynu0tpBjo5+hC lnh6vnQlzm+cL0W46Ywb5gTFlPQNjSceZMcZdVFr+Z0FLywFi6RIr2wCDaEb26sLZ1s8XADhRZxx LBREW0f5YpzmzQCA9CkGPQOBUjGqEQ47kG3EuZ8bbIc+sh0uYa4CwElO2VQve53L8YYiJX8b1X5s wDFpXDtAzsVuYhIhGihB0hMDmwb3OTQBM9SvjUuXp2HzcQKzYSmaj+bdgZfAWib7uSlkLMs3Ezde vOv4yltbcVJyji0TlFYMK3lBylOWKbbkmZjseVCuPOWtZ06ZLaLUjEA0nF3kkL7tgSKQrIcDPcNY KP06PKYAgONARdwQr/j1GBG+oXWya6HTmt2e0xV8Zw+iz40RzAjrMYfXJ8umXuKT8EO1PbfjHJPp tyhS4GAyc2wQl8IGZUjwiXHlhd/wqbtGnzM0PmbCX9keWUY9ZiIqWsiWwSz4akjmjId2gmo8EmUP VX00SfPbPMc0oBQha44xCCYNtPOI5IeLg9v7gobdujgwDMdhjYSk4WDt6JXRUDW/NnO8YzfWZa7j kx2Vlly04bjKho6XbhA4yc36XUU1iCwoxRcd7NZi2DcmBVhCZA1GipTEM5aNEXNjgkPqs+LoJEzM Yyy1zmffSXbyEMfhleKGYEa3TSn1fNCKk/Dn+IGHINGck9E0V+r91q3JkmWy4zsncWs6Xque7/6t 1IpcmfP19084tG4juSOtxeKIX0EnJweCoh2PSNBFW1mNBxExfpkvciXHI/KBgaScsjLroaXkNpaT kYDLx1hYjjW+dbqCOZHUUhNbkqrHMxLrhK561YxQbDtLKG8acfpiFMEUG3+GM+98rE2nL060u/5d upOPomhlSPT0Cy7MzaJyllct8Z6jRyuqXSugLlWBbX2j7IkB/YL7ETmYU5XnfQIVXDiGo4irxCqE JYLIO+FcCHbBk9+HX/7OE9lWvGWir3Ilat22ko1AoFQ+vPqZoMOfzv2MkMVeZqgNkhsO+x+ZrxOt JiSfVG03QgDfJOOFLJblCTqRHGqHt4aAWDtELGYeUlBI5VGHjt0GrajNt7zg0SdeqXAO8LkmBB5+ yQWQL8Y2vWNBuh/KhihbIA7pIAe/1TKAjphFXn4d1e/w7ZiE4W35bah8mkrCl3jPisgb6OKavZmj +wnqcMm7uHTeGT34nRxatynM+NSl77CmVrIZdUCwQXXhSKrdJGDyVbyU/BCwe65bLUhQ4D2D17TM naH9MBQefwsAKvUx/mB3TwMOA4s2lhLs+CemAo8pzDpTCRHPGJC64WeJ0ejjzrNPiLcyGj6yXJha NhLxKehDe4j5a1tL4/c0CZKzChWrhmWFapEM7wiMp29z5I29rqGnlXenA531tY2jBIyu/OJJoHux b8uHl+3HV1otejkcYkWpN+HX/lZDntSGF2aalmIapM4mwfMKhnuMB5PD/jYGYEKyxU8cYM3rYwVs 85wKdePDwNs9KbH5U40RKwocP44peUD026MBay1phQoybxYW8jhEKt9gElNg8x5k21rjaDKcHjqI Ni5oY0Ej1XkHqh26e9th5KbA/HEaWHT8WuhY4Tp2FUygI8BYqQgYp0ouDYLgXL6wMgR56bcs+yuW /AuJ3fJJhLHejhiQAtMYXMAEvx0rk2vqKaH6j6Be6Ba+oRdSDMbgqWGrRfUV+pGJAS25cJFlw4eg jUWeWVeJUegcMHxzIGiDh15KkpwYykizXoLO72NNJQje12tny4TtTw7F1ffie40yDcYnLRs1DW2a CFmNwzlN5hT2K9IQF0FJZpV2klYRzahVQSZfvEVEkhRBMmDB8jhmA37vJ3kAwsuxdPNnsjjuiPka zrv54CnhrJc1uEPuvb+b5vj5SckaPCmFT3goS7BLqfKWbeoGr9AcB1XeKpOfCBm7OF0LwfrTI4RN nKcCcC9zPE6WLJIx/KFzSX0QOYBS9bqnHwMCyRoh7yocKC7bnmP2zdxOklh1UhH4Pr/A6Fi6HO6I TgTmFiwd7/yyc70gTylKOE24uhSah7/Hj8nlEOwn4wfd4tfXQvKAg9Kosuru8tPgsiKGR+6S7nYz h8tu80WH0+sVXXLyZPXNt/iWkoed5BSgUyEbVkUYr0LX9usk+UXWgK6xYFO8aH8aGLnwt7qsl0wS TAmPme3Rzgc3nC4IL+eaINhaxq4M8bghShBwn4EQA3MSHV3yTJFDFR9RH7e8mWJA670s0nlfL3Un TePAFwq5Ck0NLhTHTgRiQzsnkWtTdBBMHNXZZFjVFIgrCjwuY6fFGB2L73JDYBLuL7CqmcMtsruO T2Ada75EZHaykd1FOw4unEvvWJ6V+/0SHx6ytvSdMrwY6FcSrxnxua8p8cZb8g7UZkkXKdoHbN5C B6iIoIWtWEUX3ZDEM0XwhCqfT/DMKqRxPLoJv/a3FECD9cb6mCJ8KWaPUCX2g+ZRnTQIrJIGBsRw aLFBYrtw2ehGFToEI8qmA2pdosI0aDCinRLcEyjrZz3UkJdec+AFDg5aB+FtLN4mxX+fj4yN7OhO yERcLs5qf2TggyZz0sJC8HQfe7KhqNdenol0ttlvK33rt1+OsW2ncYyxjtv8MRSL0ZypWQei5I3c oQlLIjEc1MyvCMK8DHh6MX1qIebQEWOi48Otl+b4MikrhqE16s/w2t1WSq/T10eOUSbYJO/1pD45 0j5L6tNAs/DVrmZZyX+Rk4yxPbFvWcg0v/F/ray/5neSKMzxffm/bSMswwplbmRzdHJlYW0KZW5k b2JqCjMyIDAgb2JqCjc1MjQKZW5kb2JqCjMwIDAgb2JqCjw8IC9UeXBlIC9QYWdlIC9QYXJlbnQg MyAwIFIgL1Jlc291cmNlcyAzMyAwIFIgL0NvbnRlbnRzIDMxIDAgUiAvTWVkaWFCb3gKWzAgMCA2 MTIgNzkyXSA+PgplbmRvYmoKMzMgMCBvYmoKPDwgL1Byb2NTZXQgWyAvUERGIC9UZXh0IF0gL0Nv bG9yU3BhY2UgPDwgL0NzMSA3IDAgUiA+PiAvRm9udCA8PCAvVFQzLjEgMTIgMCBSCi9UVDEuMCA4 IDAgUiAvVFQ4LjEgMTkgMCBSID4+ID4+CmVuZG9iagozNSAwIG9iago8PCAvTGVuZ3RoIDM2IDAg UiAvRmlsdGVyIC9GbGF0ZURlY29kZSA+PgpzdHJlYW0KeAGtmlmT3cQVgN/1Kxobz9yLPUJqqbUE GxLAFHacuOwaihDGqaTMUiZABZyX/Pt8p8/RetXyDLim6mrUy9m3Pq1f3DP3i+v5C33t2rZ2v37r vnQ/u/c/eV26l69dEf9ev2RVkfta3+Wftsy7tu8619ZN7rvs5U/u40sXdL09Ln9y719elnnhSnf5 nTu4o7v8wT28jEgT4EKb111RlNcB+LU7+KJs3GdHdwE4d/jxf0f3wl0+3sZRliFvy751N8FxuEgT XZY9AEN3M4Cvfn69A7IKuW+76mYgdwTru1YUhYJvINg9TVVdkbdVfzMK0dQXR7Egd/hPVFbpDt/Y wL/+O6jv22+OWVzj/rRe/OurH53v7znR956OQ1H9PnbFH0IFELFsn/feNa6scl+ITV7XOSIAEbo6 h9twjmztHCFtFKHqlakbgJuZxO938aLLu9o8ssiLsvTu8qWrQwwH9lB+urxUZ0fjZ+dXh3ePrnWH 9/ZU1rd5qNrGtb8RC4LDrO6VRxfchA+s+TFj4m97uMuqyZsKJStyU1SCsUyjGMykoliJoqquL98W OAwQkCvqUECB+60VYAY1KuBwme8QGiqDXJZ53xjfAjmqNvNtVK09Vqo9FMg6KYIABV3XLtWZkKjl hT2JNkXeV2twYoP1tWzw7tXh6Cp3sMd5fKkwlUwCexdNsyzc4TExiJik87cGo5UZ4hb7ZYs79PH/ j4+uHjf6Y8ZLd7rDx1VzgLobcwVScSSuiF8ICiIauD8/ZiC6Hal6Fqf/GtHpBmPAdjxScnXxkkVd fuuYpRMhJopQQ3UtM3VlJrl7R0dYaN50a3BiTM2pjtZmSpz49Eu4gfUP9HFfHyDEe58oowjzAjGj GNGSMHyBBhHoBbJEN7JdRyOlbPwzg8QA22hLbMPVMcJWDGcKC4lfsO02G9KCC3hLG9o9/17zd6A4 SflKoCCpfbHy74WvnIDb0UMocb32ZuC+3qHOV3lzQ3A71I0FY9NXy5ATg1m2YNutQg5WUkX9oiJR Ig9Qoft3eMEi8GUsAMcU3WWbFWZZ9FSWvncL/LtYD3eOWUp3JUVBWTdLaGLz1NDr0DxxoykEbj6J 3GDSYouQDjf8/gNuiEm4tfI0/uLUwjNxlyH9DcfMxMBGEYNYb5y3xciExSItjVYs+zQOPVYs4iHE IPLjhc8OVFwCAWtlk1IjnsFW8QzGFLb4E4AWVE/w0tL3XZn7vqqX8tqSPmKFBAk5IEmKv6/zKh4/ mrbPi26WwDZijskfyKP871sMaGAS5gjTwpaEiV65Qxa5hBtTkbw+4BWTuxN3mPgHMLYUmccApQFm 2GHQbS2STkeYsseHy7JzTedzP5Vc1FxiVlt5eRJY2Mn4hJm87xoAR4EZ5DcqIBm7fMFhqlrDSwT9 SQGqWhwgVzFiVReSAicRSc2mc2JryNvEJlaGij7Rh5grb9/r48MYz21hrWMk5rg75ooRyg30rUTk EWp2MKhPAY5J2NsWnVtjc9rV1aAdZ0zbQV3gL7XEl7V9M7aOL5YkRkNAvB9eHYVGxCdSxM1jvCEh juPi3Vi+Pa6OknaJA1fHj/jHWJxtP0pUgWqDepc3gTpgIWLIu7gBm1oebUYBHmPK1RGZCK7xfY/z 4DmwdtSkc845FhZFSEbWOed3LPyJ3tLyneJHUy/8bKOy3rDef0vwJFL8kQf82htH2zqTAy7i098f hQoWPFRJSARR82YFdPK/LUBC66GaqYy9/1QcFIMif8t+93TQ4BoQ6khWoFFAoaA091hWXgQiZTPj fj8W/CFdKPi6lb7KEtoNFGZ+jhNjI8IKDzEzZDmEAHHiaG7T5LhUTA8xnZntifkiBZKkjI7gMrFp ie8SbSL0KKPZmrnhDBSMADjHCgExBWRDtDLqDHEMZWy0UGaThurMCDHqhlTyEUFqIna503ZExwX1 HQNoD1srCces6EWWanyFos17soqqe+eQO/hRdniVVneg8qmvDS0eHoSVVCEVyiYvmxVxWM9Wk2Ej 0L2LuSOdFm9CwYIobfaT09d9HppZdr1eaBlMTOIYip4CDWXFYFOmnkFrpsTkTrF1sx+896KUABxt 3AYNldnLqdInxGZZtuFOp+nvzvBuW43m9+e+JkFksG3sbGJLiNPXkSwz5305+67Lq6ZtXRPlPCvO +ipbJy+LrvVQ9pG8ziEa1Jaa8GQ0i1xxFBwYp+bwbH4rZ29IwgP4TSu+quo8lMWKoEXAW5tW1EPK ZquqzX2zhjcWP5tnmcG3HAw2ol1IX5aLJnhJnjAZ58ZQg8J22GtbDuAVKXMu7wV7SDmjFz8Ssc8e Ld66WsMb2Vs2/taCg737jdgHSpEqATaNW2PM5qKHwKdNRr/JDn+PmteiCzlhAhjCbi6raWWFhtiW 5H1N4WEnl9W0yb2vV+DGZPZGzQ5RepHMhmBgwRrfRMOjas3hh532OqSqwYEtAshs2hCmAIfBN8Ol jATTIpxUjRtlzV2UgbxFUTwgF5cTjE0mPSr1NSYk00lGis6IitDiXQyUobjYHb5iAepfQEOzLDiL JY3uscX6oms7wpSlsxEBwQDMuw7gPYeljr5MM+d77QByGXU9B5jkyA3PIMbfDm5qfRQ1NwqzvMMV QSIejn1c/OkdhINUEDuCoBIZDSBb38oReNuiDZRiEdNOqh/hixovf9jumdDYq9qCuDKHJua0ewEw HrKveQHAcTcvPHdeG2hS6WIkH/GcETgRz8YNAB1FJjjZiMS2WSxx+NKjhwXyLV2PKJFYsi9R0q9u OUMsoInE0hUGcEeJPabZwiGNlMfhAk1TFkkzRh64waj3k9vYko5uoCdueHdO9xMXwE3lN4r53NOd fGvggtwsvD1wnDfCmlkRsj+9FrEoN7KNvTwg14i9xFiHFOi40T9j5Hyvae65FAwJK91yYkm3c6xX okh0CyqNrUTNj+P/ar74ON5NaUPM1ZWSPSUA83dexbssIjK7FrM6REYDKHzxq4D6TWxmQZlcCS4v 4CuCVNGEG/pBMnJUbZ230mxdRY6tK4FJRaMf3B6qA3wAxcALvyIPdHUBs1JVSMXAA3YlWcm5WGXD ykcUvziQFFQIUMpFBu3N1peSfUbQj1nCBpuzlS8YjHji2VEoSjtgoB1WtqNN7gReMpCyuVuCjRko 9Bh2PSuhN/qb6wJHSrChhLKWJkEeIWk5pb8T/8KkHQ8YlP6bFCost0Gp+RHjfLMVdgZDjh7sEukB ysAfrP+mYjYYA1Wx2osVBGie6j6rcPJFM09UEUGrDkadCSKjUlkziAbLCDOs9maiqPXMbbvjqZ2W gK0xfMqD8W8PaQFgYSt0G3QZ1iUp2yX/0CEWoNnsQCmWuVSCydhoMW5zpXOpjQv4m5RnDM0PFQnQ ucEeXE8kku4pTAbaYvnzG+TdDtro4bWwAJf2EPp4q2EIzQpqRH0uhbKwYotIgdghlSBzLJHmGNFU TKEWNRJcRUeAsf3mzrbbBhWIGBsLz20QnuNtyjnikmFkz0OX2pJ5c80A20MXj2TtCM2TpilTGz7G WQpN2imJQnCMF3j1wwfoCMLACNP6v5AH51gQFTPkS8bQIWoJkY30KHk8/Is8M6mGkJvNSW9x2oDh AhyhI3P9X6GiFGDrCKGYWRmJBxjWG7bPIlzxMdHHID/R4oxkfBtabQcSZRohYvryy8RhsUB3ogWW Yf+qe/Y/iiMCJR2QJ/ukIguzmnundh0PB4i69cq10oBc4Up/wZtBBE4HxUp3u+BIN+q8TSgPxqRq R4dQqARcW+bBlmbJ08bzntI7RJZmOWHD5TZyQq2Gaja+MG5Rmx64YDMGAIganIOrLt7MteBBXHKx Gyth2zXcjNAEJANRD3iE+TTXFd/UtDXfBy24XhToa173updVzQd2NwQnBKZK5Yrmd9+vyZNiNB65 39gweI7wRifBcvg/ygUZqzPjEWgGEjIe5ssoEmdQ03yqVuWJP7puR5a15/wZuEFSWU4H0Z3Kee4U X4ESxCjfUFGOQT/ewLdWaRXWoaAb0YYdFc6bEbFlTLsgJXLp+LQ17amFRSDygpbjOoqubQPXDqJP 2BA7xBzFblWaYtjLOUIUK2xMvyeTzHGynKg4G5R7WNuWFsoUoLDIZvZ13U6JPNfFdXpjtDxpxHKb HOY4Fr4zF3y8dae6TgmeLMVBveZb0jk4EXz6dDsneWhxYdhDlkbicjxPXl2UFV/c1A26jij362oC 8uV3sYeY5ID+UFdwi74AF7319HJxw3SW/an31AP114uV4BbonmB4a+mOid6DfIdV1IN6poC+364b a6jn6voaDQy99ebmM0qfzWu48drO4ysxFKD7bSOZmyFlQtdafBnjkDBJNtZAzlqviymredEJHRGM afuvKi4JPF/xnaiirfjYtkh1fuYG9QRq5UQIzZTw4OYMJ1hLHPQJbDNHGuYmWv+3dXAiC4aFX0S1 2ZwuxEAFIPyTbWM8hmeZijeSquQ0ZzWdaF9yaFtwtva667fj6yDfaK7hidFeJ9rdUlULt+QW1YzE MJQFR/zazEMdez48duI5nSbCSrXhRb47IYkAs2T1A0GYctApKlY00mbHijKee9+YTm+jR4wABmEW y0VX+ktLjf8/j8mK0z42QXMQKxAdq91iLORfedEdHEksGfPAncUUMDGW6TwOYzaw0U6Rz2Nq+Xgu zPlY28BJRzrZVxxbyPLNIN+m6xfle/D0yi4l5wkeVvQGYCdXuM/+D+R+l5oKZW5kc3RyZWFtCmVu ZG9iagozNiAwIG9iagozNTQ1CmVuZG9iagozNCAwIG9iago8PCAvVHlwZSAvUGFnZSAvUGFyZW50 IDMgMCBSIC9SZXNvdXJjZXMgMzcgMCBSIC9Db250ZW50cyAzNSAwIFIgL01lZGlhQm94ClswIDAg NjEyIDc5Ml0gPj4KZW5kb2JqCjM3IDAgb2JqCjw8IC9Qcm9jU2V0IFsgL1BERiAvVGV4dCBdIC9D b2xvclNwYWNlIDw8IC9DczEgNyAwIFIgPj4gL0ZvbnQgPDwgL1RUOC4xIDE5IDAgUgovVFQ0LjEg MTQgMCBSIC9UVDMuMSAxMiAwIFIgL1RUMS4wIDggMCBSID4+ID4+CmVuZG9iagozOSAwIG9iago8 PCAvTGVuZ3RoIDQwIDAgUiAvRmlsdGVyIC9GbGF0ZURlY29kZSA+PgpzdHJlYW0KeAGlVMtOwzAQ vOcr5phI1PX6EdtHnhKcqGTEAThUaZCK2tKm5cDfY8epgIpGjZAPjq3NeGdnZzeYYAMXlnYKxig0 NR6xwvhyS6i24O3aViGKM6HSOX4YYtY4a2FUyYTNqiUuPHSK7za/xNh7YhwE/4ocBfwbrn376BE4 bZiynNMpgE/IBacSNwVGAQ754rPAC/zd328QaWbIGQx5Ix8dT5rIBUBthwHOV9seSKmZMFYOg+wp rLAmChUEHlDYPqWk5cxINyzDoNRDETsI+boVi5DPuovpbi9fPSuyNgbnh8HNfAHhzhD17tNYc/k/ utEPWgaQ2NmCOYESJJngsSdPNUcLEIuezIE/zJEdmiPQOmYOLV0iNQDuR0tESoozpUBkWWmhnI0W LjnFyz2p+7qp6vXuY7rImnn8JUVFR3eRv0ACp/HtknD1HuzcM0WyvimiZUhIcbfPLBVK6XbOdFsq lGSUpSnyXHxXavIFymH/PgplbmRzdHJlYW0KZW5kb2JqCjQwIDAgb2JqCjM2NwplbmRvYmoKMzgg MCBvYmoKPDwgL1R5cGUgL1BhZ2UgL1BhcmVudCAzIDAgUiAvUmVzb3VyY2VzIDQxIDAgUiAvQ29u dGVudHMgMzkgMCBSIC9NZWRpYUJveApbMCAwIDYxMiA3OTJdID4+CmVuZG9iago0MSAwIG9iago8 PCAvUHJvY1NldCBbIC9QREYgL1RleHQgL0ltYWdlQiAvSW1hZ2VDIC9JbWFnZUkgXSAvQ29sb3JT cGFjZSA8PCAvQ3MxIDcgMCBSCj4+IC9Gb250IDw8IC9UVDEuMCA4IDAgUiAvVFQzLjEgMTIgMCBS ID4+IC9YT2JqZWN0IDw8IC9JbTEgNDIgMCBSID4+ID4+CmVuZG9iago0MiAwIG9iago8PCAvTGVu Z3RoIDQzIDAgUiAvVHlwZSAvWE9iamVjdCAvU3VidHlwZSAvSW1hZ2UgL1dpZHRoIDU0MSAvSGVp Z2h0IDY1MyAvSW50ZXJwb2xhdGUKdHJ1ZSAvQ29sb3JTcGFjZSA0NCAwIFIgL0JpdHNQZXJDb21w b25lbnQgOCAvRmlsdGVyIC9GbGF0ZURlY29kZSA+PgpzdHJlYW0KeAHsvd2rG9m2L6b/wW/7PRfy IjD0exC++y0gnIYLAZnNfVG8AwGZ8xDkDeYi+3LR2ufBMnSQDYka0jL4yhhkDpaTRtu5WifbxTGF b8rZ1j2mYrR2UhtTcWpBNaurl2vZym+M+VGzPiSv5Y9utz2r3WvVqppzzDF+c9YYc4w5a9R6bQ+L gEXAImARsAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhYBCwC FgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhY BCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImAR sAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXA ImARsAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXAIvDFIBDv+8vnS/9lmkl8FPh73vJFkl2hs3i1 5/n7xrXDPX9vWSomCyT7nvNkPn9iVEH5wF/ty4aSfd8P9sJDlA9XAc791Qv++TKWJbg8rmf/XuBW EqLYS8kbWnGf7i6euEuTf4NHsE3lg8gQRlPgE6JPjPkvwoiYoYN5wxXm50UYH4nL4mccBK7zZHfx dBkc6OsnEkHXsicWAYuAReAzQyBY3D1VuyT/Ne8GpM/3R211pXFnTxub8MlZlKzfjQQESXC5oYvd yorx3dB9cFqTrV06092NcT1+esagELvU9On+0/X64FpdkZK1rtxcHqB8xpuidtmJ3cGVU7UrTryO l7tmK6fAv+At9/PFBa57dvhcX9YU3MFOoYnzo2fEKfNm3ro8FbQP7/eumtfP9h+RaCcUQXNiTywC FgGLwOeFQLxDKvfq/WVwf/ANtOU19yDx7uHk3ODhfDTCyYXpC4jsz+9JBd68x1p07bBC3pnveZPv RMUMmfjZWSK7c33+fM9/cpGtz4XZy3Xy7ByuKwoxN3R2ADV+MGrCYH236z133Wf3R0TwVOdhuj5Y us887/F5pjZaPPPcZ3vRkTeEYr/qxkf3u2RfRs6LOAqut8gw7biZ+yD4MQzEd3uKRUVhzSc7grIz f8Bsg/Ja8Haqdc9dPp+Pb5Hs9TshcJgSJqfqo/tesLd8LEQ7P4HFOZkIihH72yJgEbAIfGYIHHiL x3fnNI2PFnfIOjixNyL7Mlqu1ylZhzOk9tn6tEakdRvCrBxcJ2Nx477z9P70kReo2BHDE8zILrCy pb/T1ZObk8d+ePAWs9K4J8JU6eohqfH2ropaHZLRgR1Rf2ujsNsjX+N873tn+TIMAm8ZFKJV6/XR XfK8ds63qCSkYwaFNSHzIUh50iPb3yGhrpIfJEzeSBii/cvkTKG8kPpK5hRFT8j/IkzYrBxbBMGG /WkRsAhYBD5bBILHZDJq32hNSzpcOBet7+P1Ubh6uV4f3oR6V2aFVT2qiH83PKXzAZEwTNe9ouOw Fl7MJm8FpOpXTtfhgBDNy3O0KA7W2KTV5d/arCT+Q9Lq6t/5/kMZoFM110Ltdx4lMet/Zao0BW9I NhQuj25XmDNhVk43b+z0b50Xsb7m94m0HSoMSK0I3r7zU3FyXBE0g/bEImARsAh8fggkq0dsUy5d W9ByvFa50qwoVQwVer1oVnbm4Tp2aIlExMoEOEJXX9fxqPQgkkveL3cw7d9oVq5e7N4QNuIiImbZ sdGsoEga77uLh9d6N8jBQexO+heysj8mgqc73zuLB2yAiGEcWkbB6vnudwIB7SLJIJgyWGfbd9wQ q/aMQC0LpmEdiiSi+Jhk8pgiSP7sL4uARcAi8PkhEPFCfG3npqcDRDSBv76Et0Ir7BwEE2Kz5lTe CpkYeBAIHyUcK6OVd3mEHE8703ss/t7j9YgLEwSUcmo5cWkRh+kLyt+DWDinWBzCa4b7s8msvKDY VP2W8FDSJVHjlRrFh9D5yjQwWdgdivgZZoWWaSgIFvO6DwXKyLYKs3LGEIqJHt4UKzhsf3ElYhFO ZY7McUVgavaHRcAiYBH4/BAQGhtqfOdi79aF9uiuf5Asvydt375zrUtbni4rFSoDPtKsCM186Xz/ wUgUy2JWQOnFRVbmZ7t3RwNef69duR9gti9WOi6dbt0aje+eowULQV8aLDYQYiH+0umutEqy3Yog 2NH9DlE40751fXDnQpOiZ+fGell+LQQ53dkN4ziK4mglAn3kaxTMigivRex2naqNlqlaW6F1pdwR ewQO/l3of69Ewz4HWOSTiZAjav+wCFgELAKfDQJyyxbpSfGPNeTR7lAGo850H6oFDcjMmlOFsGgf ckfuzj3Xf2QsrTA60fOdllwlgTswWtB2Mjri55dZ/4vmzg8ec8U85eQ5b/26dNMXOwEORuQj0LqP ODhyxUst0fNr7WyH8Nlebm1FLOibSzzzLhXGFU1BnzDlo/u8B+Ds8JnwVoRrI1tVv0J3VxhEFuHq yBHxupOJoIjZ3xYBi4BF4EtBIE2wIJLb31UpeZIcJknuVUGzWBIfxPGB3GZl3ABxXE/KN4wyxz9N Y7D6wagdr90j8I9GP5AEx2vTlrIIWAQsAhYBi4BFwCJgEbAIWAQsAhYBi4BFwCJgEbAIWAQsAhYB i4BFwCLACOh8jyql5AtanE+Q0PFlbGwFwCsqlBOymN2Rkk9mh05fKU7M1JF4B3/zMlBGwZ5ZBCwC FgGLwK8cgXK+RySm9ETOMZVuhUQMHonNV+Ka2D98KvdyokwRifSVKhXYyGejI/7cMan9ykGz7FsE LAIWAYvAJgT4LZKdm5xJEqkmXfd5lOLVEpH6Uu0q5sr+hDI98istB9c4p8rNZW67mtgYjJci9Wvy 4gVJ8Sdvn97Ehb1uEbAIWAQsAp8JAuLlxIInUWlW8LIMW5Mr5ztkdM70nxQgKJsV5Pu6H67FO/jW rBTgsn9aBCwCFoHPEgFhQTjARW9l8hdYqr0ViJ/6u6okvQ5fOApm5XxvRLnCWrvB8gFqWbNSgMv+ aRGwCFgEPksE2KxcuTi4d3147/rg7k1+JX+Dt0IAiNfndYpjnVAFSSz/pr7hIuzLaLk/p2+yXDrX rgipfZZgWqEsAhYBi4BFQATB1EdPJB7CrFzPL52Ie/KWypAcLx+cqe+caVw5035QMCvXvEORCVM4 ONZbsYPNImARsAh8CQjoxI+msMJ2nGqOrg3u7PTvXO7ddSOZJWaLI1MIggk7IlIo2yCYCa89twhY BCwCnzECbCayr3QJSaVZUTkwTaMgbl3XqScNaIRZOT/eS3KLKTGn8ccnL0tfFjPq2lOLgEXAImAR sAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhkCCT7nvNkPn/i +fSB9ZMfh3vIzRgec536MPADf7VvvGJ4ouon507WOAr8PW/5QiSVDFeB778U5yq3pMzfQrcCncul zC3IgWGQCpD75fhHHOw5iye7i2d7aqcZp76UPGyjg2yWx0lfmRU7CZ7pAfrOX0l5owCwIFUms8NZ NIMsi2ZMGTjDXBKbbWzbexYBi8CXikDoPqA3xNW/M13kXzzWkayenK9/Q7lQ4qdc/Q5/I/4tdVXm xku3V+prjyep/hbquJ2+vN3dOTt8ni+5P2orGRt39lK86khvL4ovBTt98dniOyHqJM/PAor6XQFC FbfPL9QVqdrO7WNt+jrcHcjPKwucd2b0cWR3gHavFJLJ5Nmmv46ZvjIrdjI8gwvU9aM9auoFn186 w+hFzh1we27Md9Zrpy8+u8woUWF7WAQsAhaBKgTkV+Z3rs+f7/lPLnJaxQsz+my68Z3fI5yLiTlO 6Fa0H8Y/7pI2vrpL09cDd7p7ew5tTUcaU6r5MKp2XsR33qGvzvSfcnH8yKob9A/XKT40jLuHYfAy EvNnVSEO94NgP7uGkmg7OQjDOGRleKb32PQkEn4p/tzg4XxEOSQvTF9Ezl2cnB8HUNs7LPWp2g4Z VJ+yr2irVObWG5J2vTB+5i/u4eR077FiauPvYH4LJU81bu36L7z5PTbiO26CvDFXT9W+8eKjOHwZ xsrIgkx6AJFD5SaIzcxkAeP9IDRt/lEUvgQOImO/KMZv0GR4ghiIozsKABq8Ht2n/ABX5rCpwUPm 7dKp5vfA1h2APVh/dk/SvfNq4mG3Txvo2VOLgEWgiEAw+w6q4/wE2pWOdPXk5uSxj3CWMDcNmrTH LulP0lfSBvFc/T8jncP/ruz+7dk5nLceoLDLelvcOt1+UPRfEi7Z/OYcafIbMtdWrKqb9Ov3dill /c5Z5RpcdzhAF+9dllaAKMxZ6QkFKBpt/+eCq0unetpsrb0R5VQZLSHhs7OwaINn6+jJGfDceZTG T+mE/+24cTAju3NdvFlfxW20enZ/+pj9mqdQwpzlWIC36efBqAn6lIhSHP589+5iD1gVXpnZmbM1 Xz0Ch4Kfc4MnMI7CXpxpCmfh0unOQ7Kn8TPDabpy04szs6LxXL+83lJo1C5dnspeLjC6x2MAsod8 wk2jaw5uEtsy4X+4IM/lbPsGi/yoQMH+aRGwCFgENAJC34pYkL5IJ1Kj3oP2E1N9MiviYu3K5eG9 m//gXW9jlntpZ/I0+oHtQuNetI6vk87/Zu6/mA+/O9e+5QTGJBzTYaHBnDiYkvaW6bYEWVQ36c9f CK17tv/Qcx6w5oeKO7rNsawLo8eunPbfgq6UJbt3r48e/eOYKJ9u3/WMVQD5fj3UsWii9X283icn pXHHmZPCHM0fYTZ+dvD4PoV65CuT1dxKmOIRi68zhuXQy/1xwO9I3vDIGOQOwfa5wSMpYANoi8zJ N3b9l7sjipvd9A+FvYCz4yyf7ZCZuIq42d7s1un61ZtOIJwmuH6ZWVF4ygwzvV1/9Wyn/c2FwaMS C8RPunqIhs4NH9+F21K/NZ8RIDedJxdg3dq7XOXgJrX7DWwNm0hiwB4WAYuARaASAaHZ5OQcJdKD SERjhGpqVpmVxj2hnZbkAlylFFtZ4UPWP1BBl840b1yfPTcjUZhhi5fQL44fi2AUgi2kn3R1pQ8F fbYFFCzCwf4ItNnLy3Be1MIHR/vpk1mipMMlxWqIjmJRZbI78K3YWIgmWFuKTJKnyRu64UuFuXMG f5J9xLGBW7q1L7yA0928ok6eq0jRN8ar+cKsfKPNCoKEFLLTXBHbh6SuYVaUv3a+d+c8O2XnRnvC XlzkyKTAnIkfefMHO11yH4C2/vJLZv3Rd5kjduVs+86uv8EYpGJ55QqR6jxOY/LjTjfIOUIaAWI0 eES36jfuOk+usfuj3Vu6aw+LgEXAImAgIIIbWIkQ10RWqwuTPRnv4hh7ygsTQl+dpbDPI2EshK7O m5V1GgV3R/cud74R6g6hFd1autKp5kkT8r8rd7Fwb5iVEn35ocVddiKcmF2MutwbwEmDtVmRLoYI 2ZXMCgXBri9hwijkRUGw9ToUSx7gpPUAEgnHDcXEB7k2crs+uMkeEyJUWjR5kmA1/wqiVafrIy+T W5paZbvZgtR27gdHmbFbsxcAsyKgqF0dTR/eHn+PTMt3nZfCrIjqugrbl0vn+7vOgly5arMCg+A9 vj64db4lAmiZactzfniXPS/IzsaLQeYOEh8vE3MP7i/VcXW7cJ+H0P5lEbAIZAi8uMgK5Gz37mhA 6yy0CkCRK/YLaldvLuQEVZuVs0PSyTjEisb53j332VOYA6SLj8U2qsYtd4UgGMVwrqn0vygvthLt zIM4wn8Hyyk1Rwv3YopO1WnhQ9MX2ux0+958do+DYN/tpVCApNnO9R/cH4t18LtYstDKFq0k/J2U 061bd11aqhCHcGHOtO9c69KS0OUFL9OEj4XtE3NyvenrGod4NnGr80me7d662B1d6D/MDIhqrvBb 5A0DsJeH3++0WcM37sIhMthWZmV9wFHEq7fd5/cHZAqh2LPollGFwceSyguHF7MAWlZM4flXXhA5 N3gcrJ7xghSZlSWChI1bPnt2mk9/Ijaqia7Xm75uLKmYGCE3HPRbFMfxS7GnDgv3kOtMbecm9hLY wyJgEbAImAhEz3datErC/66O+CskuL/kD+/i4tmOMBBYW3mOpXmt9pEoXtTa+aflBWFWsJFqdlfo aqrYfaCWqRFeE1uJvhPffKf25ZUbyx/2ZPU8/fwk+epdsZU3fXFNaGZq8ZbL4SouqeNOLyhQBq+q L80fy3q0y2YO1890tSF4yXvArtz2ebNTIji86oDmRm6Hf/9fC6DUz9aDvIbm1ko/sIv7rET4Ekye G9KSE7MtnCw2KxwSTFaPzzP/YPVcj1gV33kRGS91lUhvC2/eOIfyze/FSgoVSxWe6/h2L9tZsTOl iBY7ZdIH1GwmvP8NK02ivyKXtsnBiYNoifc9gdbLXDOxiQ5XMkOmCdkTi4BFwCKgEEjigzg+yC+F rNMEW3xza+6quPqdHsYx62R1gX8fgVS8vWKufPUfPJmnCXYaHxRUd5qA23K7mg4xUJAF91Ar2lZL V/9IJ+AKxxa2s3apO94KYDX4GRFxxp3IG7D574B2VmPxvVjM/m0RsAhYBD57BFzaYPz2twU/exw+ rIC7g++wG/nD0rTULAIWAYvArwIBeq0yjAt+yq+Cc8ukRcAiYBGwCFgELAIWAYuARcAiYBGwCFgE LAIWAYuARcAiYBGwCFgELAIWAYuARcAiYBGwCFgELAIWAYuARcAiYBGwCFgELAIWAYuARcAiYBGw CFgELAIWAYuARcAiYBGwCFgELAIWAYuARcAiYBGwCFgELAIWAYuARcAiYBGwCFgELAIWAYuARcAi YBGwCFgELAIWAYuARcAiYBGwCFgELAIWAYuARcAi8JERSFb+yvicA/70w+S9PhqUhKtVaJDMBIhX fvCpJE5PI2+xWLirdJ0GS2e+cP75+f9VzTbkCSrFWYerAlYnEXAz2QwwfXaiwrrWSU+S0F+F+b4/ iUQnbU6Vj3zPW/FnI9WV6t9ptHSd+Xzh+dlHLKtLlq5uHpOFomL864sfS3yMHPNYhXgsjtPWccpo 5uVJGoe+v9LPXYSms/EMeT/uI1l6RtblvpBl1CAvFyiK9O5/vwuA3No7V3x3Xn/FNWOnVqsttNaM nXqt1qfPuL774XRrtZ6zTv1OveXq0Qx68SLX1ru38P4102kHvNTq7VG4HImz4QVmu0Q7ZnmqEIn7 VMO4cxIBFdl01mkM8OXZykNhqApXFtpycStxXU+34vYgkCHPz9Nl8QAdgAGz9Yi8MUYmeqzRoN/1 zmQDZCaVTHw5Js2bVeexS7ygP+TNk3RoFT2+puA1CsQDFoYEEkdjGBeeRKN0dvpu/ARTNDITpjj1 29RiT/yVLIcQFx/0/GhH6RlZr3mUmd0ty+hB7vJzdUyWglmv2TepVdZTI+E4IFcSeOeKldQ++4uJ 26g1HP2IJm6zVhuIL45DqYRBEOjpa5rAi8HUJ4zEhDaNI9yOSmMyifA1pzQNF3h0Zro2IZmAmiye JqAdlisrwLmx8h/5Wmmq/Sp1WmRSkSjIEvbrtd4iwF1v1Ko1RwBAsC3KC9FiISffMK9H8kY8rNf6 CisuoARMU6qKipCXiYAtzSp9TRd/SLIhnqHunDihA/AS5AphjaHBA+jmoCu1JSjxzxzxTf2leyr2 BrX6MEohRSBFfGuXpUmcZCNA91pFW3nR1mBbjKY4cXqN7lw6IBheWvxMkGjRqNWaQ0d2yGoGzdiZ ATTdIGEnIGY80ijEGMzEZ/xkT+TQy9ogCtN2vUZmq70ULWnxDW6Z/jqOwKd+bIjKpocl0Z2YtVUe OehVfhKjajxV1Y0DTBWo/B1iutBdEMLJckxWpVafBSThctSstSZC1oouQwk8V2rgGmfZc1chtWRB FDclRacEGNnesFHvK8NNhVUZNci9gS6AT8MphVGtbdJFr17vLWR3FXtBsrJeq5FAIDfdOKUn01Q+ 5cGJquBHPb+yd0SHJ+gj3aBsooBehpUaluaA12x9tidyMCv5YsAuzEo4xiMmjnp3SWqXbolj7Cf+ FENVHiNX6gRBxcVUrP8nDFg+WtlcKIErRCYsDebyJnRFPxsSign8jkewdkOPr9Coa09XaFIz0OjP MNpiTGvqQ9HVbr9eH3gFJiXBNBi2FK/1Lr7g6g1l+//FxX8jbzSGD4htmvYsJ+zJ0I36eBmrVpJ5 X3Nd60yWaJ9qmGZFCciT3qaCr4kHmp5fxSqdN8f/LzP/UHECUx657DcJhlqjCCAoDJ0/S0mrQMAE O9eWlBoW0yDujbVQtaGjrBgVNVp5hLmrPsA2bN/buiyco8IUoUQcEc7ri2hdHhsl0dB35BfwceXB jJpCfVh4edS7fmas1pFDttdkeuU6S0RyiL26mBRRN9X6cLXcgRwm/+JfyRNgy2PSecvAY1d9tvJJ CQtDr8Q3uO0/UPTBar07JTZLA8wch//NvxQyGQ+CHDli5BJydIgn8XkFnuI+l5HdUR5gWZmqM6dH syjcgcbGszNuw5iswPe4WWvTSUWXCTKJhyHRphKJh8HIpnyNZ43DEcXHqqo71DOSrvrq6cVz0dT+ IDUjy6gHjXqQnuX1CmGPWnsMmMojSrLnCyvJBMu9IAqZD8KfH2TPMMSZoJX1hsGZf6a4d1w8EB49 pN0ZQaKP0sNFDriMY6ghag6hXEBAU/mcThJXP8pi9OMnHsPVFL5yl7HDFI4eMwx79Ehr6IRhmIQ0 XYTKBRLBHE9h2zest5xsiMeEiqhDXaFh2Z7Q8xjMWs2eqUBUUZClUBqZK2oLxiiCDhfzVcyuwQn0 Oc2uawPRgm40Y1LR8scQUbQS4YGCiUrXEWoKi8AVyZpIChE5WUM2lA4UCPS/aIXEr4s5dTCDioYG U4+Makhqhngd08NYn1E8OxwK+8hkORBBU8feIlTMayKk3jtTn4hRYdaWCjFVuBKEUluaH8VhuppQ f3k0nP0ZgG0tDaWdZ7sh2AbaZNYVA5u7LJm0ZNSIcG6Oq8ZGhWgCookXRJEcIhyQIasE+Yftlhhd QhSyFMooZ8LhTLGHUwURTYZr9b4PpzrZ13ZfdO5mKYiqT5KMcLKCIKI5Rd/klug3YfTRJD07w2VS McDMh0URQQ11xMrgY5igZ1oUBJXFSniqOvRbkaoYYGax0jnb5UGyTgDIwItDPNLNKSQG/1O4LVse 55TKjFfrlMJlZFfQOxjACNtWSq1DH6o75PDmaVWfPKTYw8OThRmJVWVW1OPsDZr1zqCHJ1mEOrew h1kE5pM8G6zgJ8NBPWXcL+2xhzs+xcHpKS4/dxXwEvLNyZwisf15zqZUPVzK/0Iz+S4zB3zG3ed3 RlLXp8uAYi/4sZxhTkGzOxr39RYfPMvoR1RSRmiF5W00Wy36h9EmZ4wCHppswMlVeGaYqSuhI2aq 9U5/5G5aMOTZ0ThIffQ6DAG7UfQI0EGWDmNJDV26pM2KZpKu8rEgPS6jrzynHWAs6fiV5JZnuWCb adKkVx+6lSRwx8N+p83TGATD1eOgS2qRqUpd2Tvp8pO6aI79NMD8qoUYiyKrBjyowF5ORr1Om1cP 4KqbY5IN6CYQim1pjtQDS66BEir19LMvy6l+YbaHwuBIa6tubemyyAG+XUBKEXGYS7E8URgbJdHM thQbS+FQNdq9qcPmVclBGuPYZkXNdVE5w1b08hYpMAGAysWcYzga9Ts05CeY7ijxTW7dfkPM8NE9 GJvNkVcxwKiiWs5QRJQ0xBhMU2s49zwXh+N4FPRUxQp4Im6FMdfpdNrt/nIfZMnfZ34KA8wgXz4l R6zprBBLbNJyJ622tB0PQ5F8wOouU0Rm5NosvWEL6qBW7/kB/CkawBuklhF14pCmfLILzMIUtsoH wYT1V1UwMYApo0OsB21nTz+/ZhPqMVcyKDY0yLiRKCtWfu4q4NXTb3rwcwezV3i4hNRcUHUr05QP V67+Z/kHS50trLMy56ABBuDQW2LcY+wv5s4yFSUZKkayMXWz2+YSiuxogWfVrBjhxjDwndm428KT LCaoFeDCX2n0x3Dfya1gjToRwZZ1SvPKoUdsKG2DwV+HZ20wqSnSeFPDmJ9ZMit6HquHpTjhObOK t8Qrx13ti+EXzsFrszuYLjwPE37S5BkR2ZYQWTz1yo3S9GnGWO+Neg2EglFePUR6BHIwCnsI0IAL 54IfT4WhLFwJgn46lGXUgiu9ynG8t5qVRLNEBHKdiE7f0mW8CjyYQI2wuSSzUhgbFaIp8Q1meWEJ m/KGPVpVhrui77EGaGbRVB4AWXfzGNNaQgOuxc/E2SwFXA402hsMhwP8P0QAmLqpskNNs9KA2+1X DDBzHKpO1OJIxhCNNQ/VFva6QH6N5zpdjfv9wWDQ749906yUBphJrHTOhqxDVpDRCvBYNZu1hhiK FV2WEYggXqPTrjcm/hIGoY1ZD/ksbFYKj5WQOtcd8hmhqYcqjIjcW8zKAH77aERezRATvGNpm0p+ MiHUU6ZBBlll+DA3oL07xnOnblF9/SCg1GAKxUM9nhEm9mT0lS7KORvH7Tm6qK7o5syqn++5gTMJ yU4iB8HQqW1eN4gohgR/wSzJOlY4g6tSUEVOdGOH/CDfmPgrCnOizUFpjszDWGDr6HyBGVDuSMQe LRmLo+ei3pvhUYx9cqlgVbj3Wy6tMdNiDXnWqgmT0GpCkS8Uoxg4ynVm8BXKZsWYn9cGtPqQUniv PhJBsL/R4CG1iSAARdLe6q2Un3rsCKIpGE+DjVENTjpTWG0Ru6awnz9FnIrNisJQjfNNIMiJq6FR BQAkJhHnMMKAtiikLnFvxvnBiuwp1QrV1U+TmB6Xu0w0IH5StBBQiQ055bGxXyGa2ZYgwlfYR+PJ PFmN7AgQN8U6nIetBEnkjCnoPkIMlkHjcRjSugzPJA0QlPjSmXW2SEGmoTXRDYYUg216VWrcw0Bs DOA3YxyCqZGfVAwwcxwqeDVxIK6HX3bRqJLDMyuReTQmelLeNHJm86U5vTMrAgHSnhBRqkS4DPhT 7vksdxmbBkmAdQIeG4yeRVfUolFaJTV1dL47pKQ+PYMdeGVp6NDTk+tcWUYLRRINlmAZ1EiHb2VP BDahZSr4yRBQI8EAma3VIK567jQnIGA+CB7Fp0kpzE2cqx4u4qpFmxWX/Cwj8mDSzPj6XM8IZ/aL hYA8hOiBXcfTLo1DOuodsi+Ev/RwUXY1x6RUHqyvMoDQEc3RErMsHrlGfEz1KVZOpZdLqmKOIcyY K0cyo0T7tfQIRBwFA1IcbbEpKA0wr+GjjsgUrQPmmVSUokmX9B4dzT4v5ZB+NtZWSINJtqHVZ7Ag 4mjNg4R4g2+SLHuKRqsD9rF3OoukyYaUgFxFOsuwVmrvAZrA+gx8JTok2XW64J0AfTdcDCQq9Vab Hk9sXVYY/umhjKqVQdjUFjeiiUeGUA2xyMIFRCnZU9yKwbbcAkGdXu6yrDps1WoKvLCRQ1wsjY20 LJrJtiIVjjukteho0M6K3BG5FGyXR30wk+pRr5bWUbVJzPP0QJikTHzRuRulSJaAvs97pWSjyRKD rTv9ByPopJDJ1kVq7ZFoqDTAzHGoOlFsLWD6pZGDq/ToyeergGeGw5YBFrsAYMjLnVl540xM0uTm CqhHCkQ3NUulLjNqrhO2CTNcCtn6qu3wJakBvtoZorpDSxpNVOeCT9MVxaMgItLqiRBPoofmeN22 gW7Zwl5MoTyIMk7WFfwoMdRI+PM/apBpAYViDm8ZnPL5VcijnwiNFprLjvLDlW2tabYQ71RxSzmE sppf5Bl2j+oNflUAvOU29E3CO22r6mILXrbplkIQSt9mhXlJVAW+5GViKO/V0BbX/JWMgnGGrYpb ZTGK4pQlL1Mtt56v9o5/AQtRk0ApIlaB4YnY0MQ3CcVNV7RSEibXZebdcEHrKrntgOvi2KgSzaQh z7d3E3eL2vusaxubYPU1fZKJr1owB54udvwTWCie6mDY5Spt5fw48GbUqvDM7n60s2KXHaehCqk3 dwfdyYN2nCZUmc3sGehW8KPql0aCukGPe/m5y+4e66xCYxAvx6prC30cBCJvPvdzXbASu3zFhrGP 06il+iEQoK3gOHr61ZsPQfRTpsGhdDNA92GZ/eLw/LDwWWoWgW0IJKHn5S3NttL23i+GQLRaLk+e TeUXY/e9G06i3It0702vSOBLw7Mov/3bImARsAhYBCwCFgGLwK8AgV8isRtnMlws3iWT4fEQTXxs 1V7wSwobKyD1H2f+VGn3ypn6NlZ9yw1KomgcKzN3RXVVxUP13fzV6vSAke942ED0Sx5J9BKpFY1/ L2RmnPdl6jBYvXz3hYLjtn6w51e2gus6ERLRClcv3t6h2xvFu2GLJ7vuXi4YLaoksY9X25Ijg8Ah MRCbV4yb205LEoG42UEbUUWLlVCIxt6lO9Lo5V5wsI1ZdW+5WFSFTmSW2lVpuU/Vs78/JQTeNbHb 8fLOVUiKHVZin5HIZChSRlRky6yoesxL6Yw2ZzL5htwMVlFTCa7S7lVk6quodZxLtM01d2Ab+fZ6 ioftpeTdqlyOCZZdkHXnWPU/VqHDm61Lp2q5f6PlsTTJdo6S5b1Ttau84Xx7wbffDRd3Trd2Ky1U 4t09VbuxV6LhDa9CqAuzF+rO/oXapYt6X5e6epLfR/c7jFJzequ7c3mxb9YNZt+huR03w21vcgNX Lmc5as3i2DB2AonC+a18B31jvKCUkU1Xu6dqO9kbdtkdOjtRd2j23N6lU53HeUrVf1HWkYZ45Scr IN+AqLc5NUR23Z4xApQCjuPF2SakYua0lEY90sqFKtWGgC6XaM5Ix1dxl3Zb6K1V2Tk3hKyAoob6 Sdv5qjLCFbIsonguZWUu71w1ZdVC4TfljGpxPhmQpPeIsf0YqQoXsAQ6W2YOk/z+M73BJVcm10aM DZ3tBd455MRZFTNCLq33Mcq0e3p/Jt3NoQ3JCbQU6RFU6kumUIZIXpYvaIu/5E9szVHIq1PuGpFQ lFLtaUbz+S1RP4d8LlGnbJAy2GTbw+LwZRDsi9aS5EC1e5Qkh6J8mhzibprSnygcRpkSE1d09fUa tY7W6QGlk8S99DAMUF7SEdTUzxfQtztFfXuUxNQWH3SOkzSliTfazc350QQoZ3PyI27uANN0pBsU LaY8h2eGmU4cG3yCbokCkTgC2UhO/g9uty6d7j9lZrB/bj8IXuo9Zv74m1OtXcWqKILNwU/OsKE8 M3imLh0KKIQUUbgvHihsRQIzymBlzAspcqAle+cFUNFTEL+Zt7zO4Ao0/9mxsm/J83PMwK6amFDn Zok3TyaR079yqvNICZL9LkARzL871fg+SgC+HhiZRLo7UD8vNS4cRTT2tI7J2EuifdULXCYTAaOb xgMKqOZCvMiEd+Uy/uhVIJmlVlwsPp4Y4uI5Mut8IedGCjjoUrxYD7nLid3ohQt9tMc8moq5KPn1 IlGoH5XTvqmUa6Cv30vVu9xRbWROnuUbWLJJkREu2wqOST+nmoT+12whZeUPRt65jZQ3dCu941br zJeBUHcRfP54n18gAw/08mABk5STjcu0u3TewGb+Qpl8U3i5Eu9z8hspLcqeV30os0IQUQIB/d5c EW1+8VPig19dTiZWeC8jp46YcmGyp1ohXii3Uj5X5/84/bciiUGZbAF5NCRyORpCJRN6pXtJV9KX 17XLUP8Oj+a8e+lU9wnuRIs7p2pXWDu9vFi7dN07cAc0D5f/2g94pO3fbJNao3/17+jNjOSZ0Ku4 8j//+dFZVf5s/0lOZDQQPlb0iRF1UFtnx4jOHd1uXzrVuIvhCqUqm4BSZe0ReQ9Oq4sXJ6RReUos il399r+/dBpaPQ1gtlTFKxd7I3F+usfSbaBwpi6q7EBwBxNmpjDy9u/3Mtmvu/AXju62L50dKWUu uWe3or3rTkdQs2IgxS5gvBOtmRkmfs2NdwffKMZGEMhk/n//R7hast2z/cdpuifMxKnaH/8rcb1+ x4hdxtcbVPiMsn2O7KPvGJTgMt8lgu3v0V8nlOjgev3S+al2u4SQhyUo1s5gJ+N5QB1tSiS7Y31U kHodP78g0abBgzerMvYe/zOkvr06Wsd7mQite5wgipA83ZQtXpgSGCJDrLLRaF0lhkUqgAp1h1mc PPT7XLIDv4BfhBW/MgyY6NVuvFFYldiNtG5zhBcT+EUtesOxnIvSTMdXkfZNKUyASu890UvoEb24 zikOvFGnw/nfJORsVvIZ4SqyLIoXbKmjVcpK0o30rvdmypv6NPHVy4i1Rqs7dfmp0jxXYEIbQZuc YITAaU3Fm+yb0m9C6Kl8JbPtb+IB11WLCiJpVspo89tzeAeZ9PYSL2jRWz8JEtI2Bpz9LKa8oCMz oWTeUqM3oZFUK8SQfIuQi4mEojLHZhXZMvLGS4hEDQMFKQUEAzTlrt0Sb6HehBpvP9x3Edv5Dipo l5XqNURXQoQ4biBhqTfcOdX8nkfaQ1gEjLS9KeItrMFYzZ7qPoZZgSk5N3wahvsPMddtcwQpeHSu KVphBvhH5KAhqT/FyUUOHEULBF5u3ByC8g3MGdLgEe5eZO1BJq/3dB09RROX5y9BhtXXLbDkjyny c3u5H8f/346Y24ePTtcunR89X68PRk2yUBg3RLx+L95GAfPtGBQuQ7zoyWkWM/FhxUj/43B6V8hm rcn8XfP05JxuJcsHgGUO7HyYhu+E8ifQOo9SsqEwdk/j5CB0YGh25gGm3PuXuaGM+ej/vly/co3D XNEcdvAuiEUOAIFhYrSVtaL2cBDaV66PIdRd4o6wunKxexVuVLI+hOE71XnIypa4HS0PTyaRcHzq V06Lf4x5FRRs2jrU0dynIwyVTCLVHVFJ6uXoxunuQ55svISlMAHnqBoCbofwFk+1HpBoPEnYwQQx fIxuPTciZ9CDOcN4AAzkfau0TvhbPjL0uFWqOzyAMjEvF/6iflCOii4rIqVYhNNRSCOJV8BkMg2l 98q5KP9Kb6PLXGr0Mm4hu6OqCHiVNuMJPEx6vTUYi9ToCnujsMz1VJVlsZw5kPik1ENbKBuJ+/hh UE3S7zhcuYtpv00TDXrnWrFRiQnn94BxJO+Y0ilTYqVaATdFHAsruNlduFOQbg8olR4Syaq7xm/d orS80qyU0RaZP4W7JCFKPH5Lv6Hzg0pnQZAnyrXB3BXZDcUHFlVHUAltVlBMpvgTPFSR3Yy8koVy GzaEc0S2gx9M3ON5NbyDPSjteRDs1K+cb105O3i6nHwjIiHuYIc1KmmzMzUKX7m0jnDlXOsb/GMn 5U7E3sp9fv0ylIbjyoX+925wuE72djo3LnRG59t3YFRB7VTrnucHy+Ue/nne80BGtOJrNMe+ch+T VXp5XOlM8tpgpx4Ke3S2DTqgRgw4MfkOZwawIBDjKWwBdDubJ7I4a57wj3yKgxGF7pNNFAzpLt0P j2KysILC/nx890L7xjmeJJ+DqVIWh1qUR3wdxqt2477z9P4Y6x0ivHd4s3np3CRg08Ck1uwPKsy5 qsE81OBi93LnxrkWO0eNe7AmBBTsNVeUHKomE/97Mr4BIm9Y5Tm627p0Zvj4bgc/n69jsu+n6t9c 6Nw43+HVFgcJ6E4gESwIsB3Nn7rOUwf/Fk/30EFpCYrkObpe9DgPjCu7Vd0hpwSKc/xOgmej/nfn W9+cbcDh3dkNMQIleyGiarD+PJbU134O4TrBrDCS3/H4IqMjHUZ6goycIQSa/C7MBnWnco0a/Hwh p/QhhnwKOFaPhVSBGYBa0wLSQi5KmZKRgSOcFVmZ3ZEVptAzOitggk/z+O5kxOlLzNSgSruCmFR9 VVkWObyfS1mpO3ojZTNxX2ZWOJeL8Z1HOU4EG1gPqczFRwk66sMxXK4OlqWry8hhFMPk9HklMnI4 wXg+K1eymvf6c5pTqfTCSuErs1JC20zRJgsTP0gnskACUM/z8HVep5SQrRQE25arcxvZUs5GjbyS WH4ZBH+SWenLVQB+YDE9hpa7crY7Ot246y8xS//mPB5nmBDWb6dFYW1WoPGa97zlc9d97rlP5s5e yrdkChFaWAmc2YOLLeiNK7vhi5v9O9cGd3f6D/zkYNQQwS7JlP6V+A8xHT2FhF58CeH908JeCL3a f0ZqtnnX9Z7DEu3OHtyeP0/Zd6DZOE1cpadAFoTjXWrqi5sU1bkwe7mJgvA+kiV0NYW3ljCatLLA Wwuat+buXuA/hgpFPFArQM22WN2+0P0OdhOaHL4JisF/uMBuAjMj1mjIFaJZNx0HnvM8SpUrAZtC q+07o9lTP3hB+xmI/0MAxRsAuCJ3hG6UVufr3yfr4Fztm/sLCH7DT9iNgo9JHXHlpoN+wb/HN8e7 y+joRBLtIZRXYydIt1cFBZs26ZrxEAJ0mUSqO0pSh7QIdX740PNfLqkh8nEUe+wSIqzHLt6unOJR LBS4iYkBc0RrcwwyeaHic1GaUz3mN6q7qpmjrv4Zn3B0pbVYRdFyCqXEQTBK1VtII8lTWXZqlMJf 0dcKcrkoTbNSkfaNlV4uDV26RIviE40r+QUThbRqBX+zuoZTQJq/kGqynDlQBGeiLZRVC/nf+CYp vInWzFvFSbxysSzAOe50ksANye5Evr7GkN+53lCGG+JXp9vjEJn2RAoj9fUTwQYvNrXcEMkLYY8p MVTBrJTRrjArHK3CKgvGMjYbkG9iOkQGpFp2bmVjrk7FA8XWCmTLyGcjRFKnz8qIjynzrqEbboRZ 6EuabCNcIxwERGxoRi3WNeT+H8Qc5Pq1MiuseVAddGNSg+2HwqwI5TfH/qU2B2FYP1CoXB/sQVyc 7kVYeA2w9kp7BmgqweGp86OHl+uXztEyNMeveDUhcmnR4e7qUOguaKF19ByqBr4A+w5XhV1eypV0 aUFAkhaUMfXFGTcKNjZQkNsHKDDYfJBw02cGACG+JkI0iICNEDO8CpsgQltaGhGiOUsBN3HQ1Poi wnQholLYIkXMXFQ7uGhbV4+8D16S+C4gx0cyTzqTtz/FSwQeL+2gCvN8E65WjPX6K/fh9GUHLeWw oT9kRwnWZ38dqxUr6qNLHLk7uN+7gihZdCKJpFdF61DGUQEFj4FLt8FhskfrYnCUDIlUd6wLUj8n 689Spy924Jy2TMAPrgm4yPEUWxRYBDI9B1hLwsSAWKJBJe0zPw65vIXarFSpu6odMoaQn/tpshhy Bsd6E/kNG+xilBO7AUAZUcm0UzEXJcGu0tTjaSxldyynoTPXuOu5TxYamfpURjhSlYVUk4WlZGgM nXfuL9nHK/OUN3VnGoz4KxuwLmRg+jNWEVm2zDImoMTZ1OX3W/FnZRnRIPwRzXxvPKN0/+Z+xXSl 90SINSYGk42p/ABlEW0zqaYqDIgclc+v1uyRfckO7jg5gdVXt+bq5OcIPFSQLSOfjRBJnIyRWHtC t9zuqvXW5h2ZkJI0mPBQeN28IwLgFI1RMQcZBIPav4tIvlgiqfPOjuT5WRn/ga59rJabL2H1OXNA wXbwCE3IivIEWv3lDtZwuTmxwrL8gfY1nadIFxW+Nn/BEmT7BM71HwEE8h3E4sKa1BcxmdBKtzBk YFs4WWmAJaFvluR5VlHg9Qvc2+1eoSDS+vA+I4MVdndE3gf+nW3jBGaFwi/nYc7UwV4Gzbf1sYsl mP5TiiuCMTINV1QwB9mVH56VIn8zXx2azCtP7dLpBolMC1u0XMJmnfeDSVUsmyH1K/Ybz9lwIDSU qDgSiiyniMUxyI3v+DNxJ5AIPUu6XShwLRU81iIUa6d/9WxnJHrzTO9hdXegj/JSY3HqGsUM8W/n fAvhUJgVxd6f/yMWjBCERLPeRIlQv7HLcVTuVrKt7DDS2hOOJTK5q82ifEHFjemPkrozNJgo/EX9 9Ce9jsrCSivPKm82xs5xMjNyfjXzUc6BV5H2rZyGriJFW45I4Y9SlkXKEmdsXYY2UckaT0iZGhLy GE+uQQ63j4PJljKEh9pYm+3s1QJuqSnKbEc7Tycng75VeQKyiqvc/YRCf9n0jNkzyZaQz9WGzcVW GcqmLo40Poh5K6+6cLLfabKlOu1Spi3H73SkFN6nd0PAYQGHBDy/K1nBy3EoGFus37e5PACHcXxg dlh2N8Ut0yXJ7mD7WQEE8171eYna+0tE3V1GHg2VLxZ5KkoNZgogaPayqinGzyZARCnegqJydGcV jbMKdWfc/aJOE58+R1ur8wcJa11z69AXhYMVtoDAkj7Lgk+o0BfH3vWgr60ZE5V3JfOR6+1ht0D9 3sa50Udu3ZL/VSBAH6RuTQrm6VfB+S/GZBzSIu+SvrxuD4uAQCAJfff9U30mwaefhTKN940XHm3/ WwQqEKAX2ax+rADGXrIIWAQsAhYBi8Cnj0BFTsjqrIMkSkXhd5YQ02nK24i8jGnkIUGkK79z/84E t1QsSfQhBdnSrrr1MzeHZmUOPfcv/yl8W6i9BI7iuvI3um1lfrEVhX5+6So5sxctAhaBTwMBlRrR 5KYq6yDfjxcI12/ITmcSOMZ5St+ExdEZ/5+00xmrAG16bXzzgS3E2D29tcjmylIifIy+jm8NQxE6 aPEDCaJobm79Qza3pRXjlsqh969/T2+1io0wxu386cbuNorpFKCxi33HvRzFDzgqjBbtqUXAIvDL IhCHlETSWJDK5xVEDknwR4kHQ44vUnpDmR2Stq0iJyTd0zn6OEsi0qwZtSTpRFKouEUA4ANJIIOy uZ1dEpocS5wEss7bKel79+LlFxQsZHrkdpBIE8yGeGuxq75gWJmFEtnq1MSc9jiJZjnxosyjmGWe lFKnhIgWW/KJ3WSKTP6UQCsXzmezzGerUxQ3NYdEdgERFega7dL+NcVEDjdFUf6WcOkkfOq2yqEn E12CmKKGEhlpUVx2N64TH+XUl3QRL/jUewvcF7vQoxQjQef+U6MC5fB6rBpZgjj9pJ1qWVxbN1/o ay6ZB4QGoOj9jJg9swhYBD4+AiFlEhFHo49AUjmjI7+QWMc7knQ02h28HMfHwKH0JuovujRAwhN6 URrvWjhcqylr1Zp0h7JN8rt+tHM1fwu1Mj7geyDLYnYU3pJIlasCIreuyvbhipjpJcVbMHiZQrD6 L/6VPEE2eLOYmd+S89jQxqeIvsxe52TXAXKuIG0pS/SnLPPkfk5qkQlTsUsv1MsZvsquWU7MqAtn NH8IMgDqXfNFxgLIornIVZnuIGFrFOF1UcrBLN4ap5RonVlQxE21yr+TOec2EPh0OLeYuG/k0Lv6 7/itGdoGU+tzLos1vfllvnGjupvTLwhi9FOkvpQEjRSgnDhOF8OowICTo2JTv6xDSig9FTHOiPM/ R+YbT0hSSqyVAKHUEKIlSqFpD4uAReDnQoCTpIl9xSuo0M7sKWxCc+jQPI8/QULZrijHGr/0F9E3 O1ojPKSU5IqSOrJZEUppRXmvOnhdS2SXkrVof1mIN2IayI3Mb+TxK+RM0LiVrmif84S+lJNQpl8z kUtVqkNNCuqEXq5wI0FhzG9k+cRJC5ulKQlkve+H8BL2ydbRq9obs1CyHeyiBKViEG+Ih+CqrSXK GmWp85kwdYcZqeyVvOXEjLq0plmRrU4Xqmguhj3qcNZizimhkn9SwklkeQTbTS95a+ZJ4e4hTyfC iNn7KWhWvTKv8ifzt1om/M45YITB0qypwi4EgYHPp77MSqkUoPBW0PWNGXc9SBmjYmO/YEjArFH+ B5HTrzlOKjN/lgAxep/8KHtYBCwCPw8CmIdzbkbVWlVGRxG4YPdB6Bk6FbaDtWJdrjKQFiX9hlki aOpXv6nwkHOyKTVbvsXZS+iFbhzJEoZCnvPfVRkUFSmEVTBLV5kelW5UmbWIEzlTVRpySxZKTvky D3xkQW636s2Bs4Q668zAg5BIm4DsBNyKfIzEqDgyiHSxcmJGVRj1ZZIHmYWMbwg0sgUIVQY3s+Zg 9SejXqfNbxwhDgkkQKo2i9A1UP1zFN2WeRKkAnc87Hfa7Dbm7LiSN0vLn+IrRoRkNBMGa4Z6nQ7+ n/p4aVJ3bi2X+jITUhOUQTAR0pLGS0q3OTsopgIOLD0sPn/UbBHyBKCU1bMEiNH7Biv21CJgEfjI CPA0klNakZ7x3P/jAVTTRG6qotfZMJ8kKyD1fDYVN5SJTFTLGjJvVpR1MAsbCa9INnGLFWlfmpWs ORa+MoNipmmlvRAUpCo2zYrMeJlp+41ZKNdQnvVmt1NvDPzlGCGlNgXziGSOf+jErHXWk0pMZpcg anO2f503EqsDYZBLicklhXRsVhJ2kQrJOXWhiubIW6FtCtOF58I3odAiuZDtWnMwhu+BToNZIfdh U+ZJzmDW7A5AwCPP07DjWt7MrIjMbN0xUszAYK2TxWjQHwz6/cF8ZZoVwUYZEwWgWFtRcOVQBb+b 8o6SZD52aAwmGIetZSqYKWRDrQBE0tcw2hOLgEXgZ0GAAyAtB6u+Ce2tak3/Us7ouN2sQHe1Rgia pS6+lcbfIxCzUKOW0ipKPVbcouygtd5sie9a0xJDbvJckerQUOzSrIjPxAwWiM+kLr0hTt/eMhQL FetMl1iXAcPV+S0p/yHFv+qU0p/0mCCCfpDzap15UgmCWzxzzutk7CFoTaDml1PE4ujzXuXEjFnf KpoV2ep0oXJzbDI6nL/e51bYrIgQE9jucZSqCjdFk60wqWi4AoRWDnCNm8KWalGMFMeIPqOVO/JO B90y+1cUlSlA87dyZiXa1i8g4vBCCX9MB/1Uyoa6Tza0AIjR+1i5Xy4cM5+W4Mv+tAhYBD4GAvrz UrV6Z4y1T8QSWKOSDmnzIgtpCbmGTlNxmglDZ46aFD3jiDoVpaM5pcURUkrIS2nUIrVsRNFZ7ahF eXkL2s2biBXWJhREXstVZFDMNC1lNuZFk7U/w0q1OBpikYU1nvDF0gWvUKOk8Q3HUhZKXkRgDyXF 0jTskAjKC4mwaIEMkTA7Tgglpmfmw8JUP9vz0GwhyxoUfmHpXISAZF9qmnEpW53ubSNtHa1NkGeR LtRXx8QHJ4VXhUy6sIst/rgYalfgltFcYglLHK0ODDlvnFZ3FW6Zc4o73pAMcm5ZhctLcHJMYsDk TK1OAUqfBjO7Xn6PksDc1i+QZTUFt/pDe6WsnhWAKCmIy5wzy2zbHxYBi8BHRaCcw9BIinislpGH 8L2WRROv2x6I2aRPCj2nlAQHpVSHVYyxJJs4wd5UWWdrsSq6+ppOZKmvVJ5Q2rn8Ddqla+7TNe5m NE+UrY4o8iZug1TF6RbcTtLLCZZXaG7wzkcm5WYSm/slpO15PbEbTdVnydQf+H1MQIwa9tQiYBH4 jBFY8farmkh5OeQto5+xtL8y0cg3xMEbA34B1vlrNTAq6rWjX4AF26RFwCLwq0QgWXHKS/mi5a9S hM+V6WTleSvzfdmfV9Botfz0U1b+vJDY1iwCFgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhYBCwC FgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhY BCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImARsAhYBCwCFgGLgEXAImAR sAh8kghE3isneOPePHR/+CT5s0xZBCwCFgGLwK8JgaPh1weN60fO9WRw+9Xk/tEvlyf514Sa5dUi 8CkjkIRHvv86Ut+3IlaT17jy9q9y/fDaD958EqK9MyfvXFGLnb5eOq8WzjHg0lXWb8K9o8Vu6rh5 2LMC73iGrlzlv3P1boQ+FB3Rehweed6RnzH2Jo5eh6H49yZOj6Z/d9C+/dq9dtD69mhx/aB180SD Kgl9Zz6fL5xVaI7hd5M8q5WEq1VY+BCbvLvlVlb/I5y9c7uAaDFfeKtqccqchivfPErAxis/yGNd vlKm+hGvvC8y//x8FRwXnI8oxmdE+g0e59pvDprZsyyvDMS3ejeLGjuomH4KvfHOnCTvK8Kb5beE Xv33abQZqPydo+kfuMpvf0TF2m+SqZ+/r/5K/aT+u6P806vuVf9+414+qP3xRDq5ktCHogPib9zr LOxX9LN5/TW198NhgwSX//rOG/ePP/bdN861nxxI6/5YP74IqTvq0OfF6g3x9bfWYLHpw6CVkm65 6HTx2TCnsoBLn6nM3QpmvWY/d6Wy4nte3MLSNsrpUnxDvKM+Rb2tMN2LB/RlbePIfwF8HS9wb2E+ +IlTvPK2Nj7s/fdE5r/9t/9drdY3Bfqw7H2B1N54/ODXvtaK8VWXlMCPQ2VWMLcMAswqJTj0ldv0 TRi++cH9sfZbaVaS5E2iCqAc/sz+SvWtN2HwOtCz1uw6ERTVNfGsOjcreDAuggGQkq0kBidQZYVW qFaaE4Eu/PA6jN7EhYoGTcESFyMO0gQUys7F0eh3B81vtSYvNg2hNAWigiP6CaZEfeXwaPL7g9rv joRcKIkmQmWfwl30wqsQ9xQ4VF2d54F6E4XgjbvymmSmQE1/bZlomL1DRAvHGw8zDaaT1TLbRf9i SCjwuXJecE3vh0M9kBIPZvTQ+2GdLn+sffUqYJkhRbp+41w+aN1+vfjjT/NonUDqyxpPTajyJHKg 32sjNxB3I2+MP+kLkvhysTEa8WVmUSCNoyAItF+eMoZRiK/G4XPIKJKGuKvGeRIF+nNySUR3UER8 M9odNOoDN6ESImCXLnr1eq/CosVhqMowC2kMQtkV5gBg4hKzSAzoRsXNGE0rp0mxVMEtUU9j0Cb2 xX1ukC6Hi3qtPleP3WYQVIV1PKzX+q4ah/IyvueMzoJAEDlRDFOjuJLEbrPWcJReBqRaDv4MtKbM RPRffCIQ4dEAxs2PcmeFzTJKvMrOekdkYm9AXzmnYZNN43Tz2xErdnFeui/2L/JNGn9Impg28+NJ j/9vk85vMYHEY/Sq/7WeWCaTJVA6GvxWXvn7WygJlfjGoxl7MtvTGB5NfodpM09N16+hORvfvkmD w5aaoNb/cIQRSJ7CV8IqYb4qptkZ8YFnUPs7xcNXh0voJf+nbLr7W1JQmVkJD9s8MSYPQrQCw6Ha Va7Bm+VtRRC3viZmqmnKiod/vq+J/Njf1YxJVwX0G9erBMyaPvT1cP3hp/pvfuzdPgrF8nRytPRh HN+47PUIVluwUz8cNkXrvzvafwtQR0OgrWQEJ+QjlKg1ME8QkP5wWEdfZ52lxdEnyqz8AAv4k8Pq RXUWe7J6SHydkrIqYa4JwZp77pFU1HsJqGFRPrwPbn8affvT4Porj5VdGr4a33393DuiyEqUzr3j mRX+EnFvkbW2Xjv9eq0xjIIp7ItUpHTecOO1PxUftcYdWCJqF9aB/oCv8/e35Bn/2WX/0cWUnR0Q d9jiy/yjPsRg8YbN7Epr9DefzBmOZs7BD7N6jf4qXUfuSBSjn60RYI1daLO69Awa7Y6iOnBy7KF4 vTsFNJIl+QFoSUxwGy8nhoeRaXgYceGqiA9Ge2N27rjq0KHnPQMhe+LIW+kDMvMwGh3/5T8AZRiR fKP8QerU72VQNuZB6k+AXp+7eb2atGuNkX4SMHLGbcV1vbuM18tRs8YIo2U6b46TUhk87FkLtVqu s6pu5ZmsRmb3IZuVcA5gpugqHBHO64to67AZ/ONID416N3vETdy+1HPSIVgwnf0dKX9opMVlBLrT 0dcHMCukrr96xWPiNQpwgOVo+NuD+h+P4K3s/9OPta8P5zdJS8zzaip2aGrqo4MiaNFkFhyNofou c0gnOmz/5qB917AFMExyepwR17PNiCbth6wHUli05k2a4UsHgcMpeJaVWXk9xeT/D2zO0ldopfsn vvUbaRBRsY5JOOnVH0ekY1878NTI4dpAE6rYwRJA2v8KmJCuC+7/2BRSyOFCdpCVzwYBJQVTT77x bisj9VXS+5ZXqMmIyGgYycvWVgmlpUOTFUD9878nfGhMJ+RmklmpoPZ6jsjbZUKGtLryMaUQxV+q FQLqJzFrVcywQ/TVqxWaCxHLgqmqwLxID38zb9w1PIX4zY+dP/7UJfP0E6vQihpvv0Taryesnios p51rsjhNjvl4w0atNU3DGTTGGJoLfTiHfWljbNKtet/HbHv/n6DR2zxrWkL11QfQ+R5ckr6briao OPFRMZlDY3I4iMxKc0hKmRRRHQrW7dfr+SCYP4bG6S5Jh64QTuvMnkFNdkTAMyL3gdSyN0T1GeZF kQNV2aIxmc66YIriacRek6wPzA9oDZeJYAnjocRtBCi4ujBehvJEdVK2dEXIMvaIpI9mai2wl4Gg nzh4K8rA1Ujrt8jCcKOtoROGYSIJklMjGg0dCEJN+ECvOSKUQQTo4tmMSbQJqwIw2ZkRbOJYTWHx uiv6I+XT+ZqQqc1I4YTopN4irChTIb7srHdGRg2bBDawwXMD6j4Yta3D5m//8X8QpgdabthuidEl RLM/SYfUr7+h5YmvjpL0Ves3iRMejaAtKQj2JnAPh39M2jxB5ZkwKVIxsSFVw5Nkvp5HkrU6ikVQ Yl/DmqS93xyocDQrlmtvlKaiVrRZ0cQVOb5VCLanR879n3p/+LFJftOPhlmhPUW1r35s/Y7+EW9/ 5FYQSiJyshVm+1DMSVJyzdhjqqQpK752ePmp9lXS/5Zn1Io54bsxUBsElBSyCvIsfb3yXk2u/1gH k78na5uG6eTbnzq/5yvsQGl89IkWQbTLvSDBZLIaxipqHIMK0iNMGGDTtx6KDjlW5F/gUDzQLTLN dNAcoO9WYM53jR/RYQcu5Ncq8BUd+VK3EAWezBiFj39KZqWrgztcL5hhNk5GIZxDbQ7idYhfiOew X1BrNFst+gdVybaAYlnQ5ELxSu8Gupsr0jQeZiWmdRTQ4VJL4xYrH62xRWEuJX/As0B18wpFoyaj XqfNy0A0tydtJifnmYMgbQf8iH6jPWGlu05o5j7yZCs8JxdyS25jB9pYIbHqGPEo5luaFQahT0YF R+oJW0M0BQjiOv0ki9Aazj3PxeE4Hof/yEdgha/sVEhXJuo5UkGw1Hdmg1631cRN4b6RyaAmIlj2 pkd2Vh4uWa96iw8qXQNvpNibYz8N4AC2lum6okxZfPa5CO3yrWMiozo9cmDNutE6ptWzRfi2YbMU vl+j3Zs6G1ZIlbBf2m+lQ1KaMI++hQNypLVl+CfS291rrxbe0ewPQp/w/JyfF9bPP01p7p1Miqhy tOQPh4OvDzp/AqSkddVTRrF0hO5ZU7H/ohS+btfogzdLOBTCAcF430vdPV6P+M1Pw9vp0iPHxzQr 5M5cP1p6Ry7+7b5yllofgqSUlNkumJVNNCk+hoMWVvx0djNpQT1+pRehcEejsVFAQYHJ0I8AdlYt puBPsmtQ3X+lkFf994fT3SMXATq2dEKT4zHcCpSOH4KY6koOoBWordevur/5sX+TLYVULcRPdiSv BpdfIcYIJ45cG+nWJRP2Q5X9VU1QNSE7/SxgntGEgAFHLP9OIgkml7upiH2hIbjAykiZlY53npLp oDhJdtCV1oSuJB7FU8ZQDx2oZtYPjam7hKaEtlzMHaxZZbZATr+Jjpq4mmZFLuYWLA6VVhUzUnSV DvZfpFlJAs/1/wrTUKu3R9OF58IDorm9bgvN6uUMTSpnVhpwpnx5SzWKViSFxIM7IzX82seMG8Sz Q5VnE1llVtSDqaqwjfNMElJSGRgTBENymsZ5s0LeChTycOIsvRFZE0KAwe+OB/DW5qoJ+g1x4PR5 WZ/AjMBv69fqvVGvgbWq6jJKHNzVAL4vMsqsIBgOAQYTzB/IqL1l2NDCUrB05sMeSQ13haSyByPA +p/mn69hODDD79zFZaExWGUJHciRK+2tiHEo1B0UBeJmFCvjmGSGKsXSQZBWQ0Cc1qZ/TwEfLLJA hXbu48EnjUrRs5CWXQrENR22Aj9RHDh9BdtU/5ZCUohu4Qj+BAq0ZCA0cLx+ja2q1AruRUSzOtSW EAO9P5HIc6zpcBBsM03QetUhUii/ZjsrTRL+VEDhpEpAeHOlcBMtWEN8eD3YMBClE2D+Vfo3giLh uSDvE+NaFEj86pWPGdxWoJglxgdOAcPI5YvUSJ+LBRdlo6Plq0XuQSAxsbk34e5gj+YIsLQo+ie4 gmkom5UKzBkZ/pESzdpvXy2xVWPvtb/3OlkfjeFR/o76KNmDjdOTjawSnaVHiz8dBWL5KX/H+CsN ZpilN3rTACv0CFhAcVG8RdoZLKPjz4bYeRLO8Ud/TpP/lYr/aAWurQPuak3FXoMjwjK92TKJfVor EUEwcmR435dScTAi0PumtWa/qeXQ+jatbrQm98Fch7vYn8L4vd2sUHiqMUCELPZJzJEvgmBOFbcJ gn617iSIY3dCtrbSrKw5pDNY0KPkjokp+A4ZCBmwwnUypZFmRZKVUidjWO7eHOZnNYf5JokIhy7Z jjSYQ14YDaZKYUAcIw5C6nZWU0z22xxkjShk2J6SBkl94QKIfqwoozBH2WJnVdw6FjKaDmg6vOIm +3frsOFavKKkI35ati/+hNwBMWPkBRGxRCsn4clSL47/2MHiCO13lbeAm1LmOCOvofS6AYdHOJ5P IEeHXbXW3/yjcFKOxrACZHoOoF6atNacETf65WgG5c/Far97FSTGevTXP2LtvnPXiKf98Ioj9kzz 71h3QSdL3U4qUUga7pJup3bB0u8QBKuimVUU9kvw8GOf7JE+DIZLAvLmB7EnQZfHyRv/fkKxL/Hv q8MFDGuaDtSye+v34I16IWWty+ss24Fi46gI0qpTFTXiIIQap5ghH2wgctFF7GSQsCBgRasnYPWu vNJEUJGBEiFTpgDZeRtACXPRAH7ylEBJShyyXEG2raL97evCZETWpd0CYtFKE6s8iZZTvepLypvX 4ETJhFbSeeWC/17NMQWVB6tWFZDHXXJt5AyfdEWdol7Qt80Rmd3Im3CIptaEomSzom9pDR/zJrS8 6xRPu6Jerd4Zh+t0MYDqpKPeaoNS34m4LdoDAAUJb2XIDgKWqkX0zNwY0B5Rr8l2q7hdJ34fREGc QmxC1xFdOgxl68+g/8XREIssOuYmyvLPzHXKLhqNaoKI6imR0GoLZgXbEsiW09FsQfoO7TTAwbL0 smUVSRcQMdMoXu/orWcupge8vMWlSmUMToqdVXXrOMhoOmgxXU3BzlhNTrYNG2wn6ChxG92CeydF tL82IPAm/sHYLbyhUMXlBIvmaveRug1SsZxMykup2rmqilT/xp7Y2Ji7bq+VlFqpIIp2T8QJldc7 pSvoiUtlATcUfUNMGhKhGO3KLijZNLuyXWTCJy9OmRrtpv6NdrXe+DerAlDJmyjPFbY0F/islOhY mGc1aVAVGM5unvgsiXHkxa+mQQWPUy6rnXjd9oAWnLHMTREeuc6SFdBn2Nxa6D3oqHyDvIG2VEhT yJ/AiPDyMXa95m9U/BVPup2J8AXIJaGVo40H83RcJjZS0Tfym4JxGbu1s9V/USzB8kpDei66ojwp QFS8zX8fp0xlRdjrEyDDJMIFravwYqwmme9FfZlP0uOOvXy1z/2voz8/Ovrf/vyB//0vIt7yL1/d +9CUPzirXwbB9N+cI6/hv/x3qZI3/Z+++Wk8/8D9roh/KLKv/5+//dLP30rsS+Z19trQ8IY+NmO0 WaC46rGxTV7aprdCMdNu9GZvN0QbKX3oG+Qr4cg7UB+6kS30ToIMb1mHUVGvlW0ha2/9Eggkrz3v Ne0gscengQDysXi+Gb77NNj6VXCRrLCs7C31i4o/D9N4B1O/uXmcFuPAB5d+kF8TOU7Nj1smWXne 6hdVBcdHJlotl0aWoY8LjKVuEbAIWAQsAhYBi8C7I/ALJ46rZhzp5DgdHPLghcXgrahRwfbmwtWN HOsqMvetivvejlXxUyikmAec/upTm9l+CgBZHiwCFoGPgED8CyeOqxQp5nRy8k2l/LvVsnwF2/xa U2XhyjaOdzF2EW5X+/+PV+XTKaWZp9D9r1aKTwdPy4lFwCKwCQEzO5zcQBhlOzqMsyyNnVklvx1E Fce7BEg5VxkgpheJ6J5YfVEVmDv9R74MZeSjnHu53Y8mD8w2VgYpc59qM1e4kDIuB0WhLTMHoLFA RCkHkVePcm6UdwTlhd1AQfCg0hkSC8U0epkjJoFgSikkFbWkFCaJqhyDebLUUIF52vOp8i/RbXtY BCwCFoEPhUApO5wwK//hIZRnm94fo93gMpkPve6EHCylKuWEcj/w+1C0BwS7QPq55K6lnHuk/Fvy Pf0Ik2gkDiqVwRuveP0Wm/zVu1olHsC22gRPjQ4W2CSoCmN3aCnToMavqi2849BUW9KbRAlvDWSp A+X7C5oCXv6SG/hJ2DkMEb+fW6SwnIg3vcBdnTIIpUFGss773hNk4ZC7Q/U70dhoSvKgzuDRXLyc wH9iRykYqMqkV8zgV8k87dWvMI5aJntiEbAIWATeEYGK7HDi/akIWSCQnAE5UGFfSNfjzTBEfwZu XFGllFBOvHdMGx2DWavZU28X4e+4nHOPEsrxC1CcDQ+JgyrKKDUoLUUFD2xWhLLlN6k7fqrMSlXK OIVXZVsQuT7jhIr0rvPQUykHIVAy7VKaXOPNAHrduDHg164pQzjeJhYeTY6CeF9b7FClN3mb47/Q q8UCmYheesZbxsaba0peIxkgZUSUGc75JW4E4ipyDJaz81Uyr+krHOxvi4BFwCLwoRAoZYdTym3W hhOx9IYt5INDmgY/QL5WSpWDV57emlAudMRLzfVOHx/EIPOSHaWce5jcY0Y+i/DiM5KccuKgUhml BpWlKPNAbNfl14X43IllYfYdipkGt/BDbfGr1iiDHBrFlIOFeT5nZIIDo3Pm4e3sCgpUK7cis4CR Vuk3RUrDSCGPdpW8nF5DJQNMAnc87Hfa7AfBtFVl0itn5/urmS9RMS9bzFCwZxYBi4BF4MMgwO8O 57PDKeUWQfE1Ou16Y+Iv8Z2iNnKvks8iXjfOV5FhHyOhHC2swPiMuy0Ek+jLBeog76CQcw92Cias OaCvQXAKi4oySs1KS7GJbVdYsAqzUsw0uIUf1RYVQQxKmRVpFHTKQUmBg4Tt0YJebvA8fADX8Tkv hwoxCQoJOX1dmb8iXjnu6gGt/MtUKpw6dSDMihBBtyKqU1ucoajZHSBboUf50wdxVY5BCprlM/jt 85t1ogc0WSSp6AgPS4phf1kELAIWgQ+DQEV2OGVW1GpFB8pwgcgPtKD4wNAxEsrNKY0cZwTij+Oo 9Kp6pYaWK3TOPZzzOjha4MRBcjUnV0apemlWKtmGvWqNHKSzdOn7OtDhyrWpShkn4dvWFhWRWp2l GFDGy4hWSEpBMHxPCGEx+FhwuwZerLg1KBCqNaaQ0hc/6qN/pmQgSLVH6TcpR3hnljIznBExJAlU BiqRJIr9C+EtctCM7lZk0qvIzlfFfBotYf+M/QgSD/vLImARsAi8JwIV2eFokUJk3ktI87GHElLI hj/oA8V6jIRyhVVsIwpWkXOPRQioAZlcuqIMKWoKTMnNXRU85Jbsm1P69FK2E6ycMk7htqktuXqC XHwinRGnaaVVJjrkt4okjTR0dM65Zo/sC3NbpGAk+mvN+UuIE5WNECv9YvlJf7+PvhrYJApZMsBk qT+91+rA6rTIr6nIMVjKzidzzArWJfN6S4DCwf62CFgELAIfDoGK7HBvI15RpZxQDltkc1+n1kTp Rjkxn77NJ28vU8ED1URiuA2T8I0p497eluCNct4ZFlJcVD+Z+oaWVRmRfNAsVJGqboNcggYlS8zq b8ykV5GdbyvzmkF7YhGwCFgEPgkEOMKDeXDhC9ifBG+fNRMnyaT3WQNhhbMIWAQ+NwR++YRynxui x5bn+Jn0jk3SFrQIWAQsAhYBi4BFwCJgEbAIWAQsAhYBi4BFwCJgEbAIWAQsAhYBi4BFwCJgEbAI WAQsAhYBi4BFwCJgEbAIWAQsAhYBi4BFwCJgEbAIWAQsAhYBi4BFwCJgEbAIWAQsAhYBi4BFwCJg EbAIWAQsAhYBi4BFwCJgEbAIWAQsAhYBi4BFwCJgEbAIWAQsAhYBi4BFwCJgEbAIWAQsAhYBi4BF wCJgEbAIWAQsAhYBi4BFwCJgEbAIfKIIhCs/VB88TKLA9+lruOKIcGvThxZVmdLveGVQKN197wtJ 6K/C7OuI703vXQl8ZDHflS187vjj4v/ujOmayco3j1WkB5wu8pFPMObNY0UPwBbcyrfKVz4yx5L8 +7dbQSEJV6sQX7f+jI5PRUsUIf0MoS6KKP6OB/imo/yC/Hrepc+dT1ZCba/wHfueE1XX23Q1dkBh 8dEGaezii/e9E/K0idf3uP6RxXwLZ6nfqfOH7LNy6azTGODbnPHiw+Nf0VzW8InPYqdBoyw7Bu4x +1PJeOImCxXiQT1rnc4aw3gLbuW+Tj7iIA9mvWbfKXAs/yxzUlmu3F/6ShUFB099b0OLlfR/wYta kK08sJbo50bV8SpupfoBbrL2+pVA/X7iesNmrTVhQ7Jiq1Jrs5VJgymeN/UR4SQMgnDDtDIK6aZ0 a+jrww0npo/DS75wqrwLfWZW4e/IaxlU6bS6xdgb1OrDKE2CIDAdqTSOcCUSl/DRdt0kPm2vOJFl FF+6SZzwLSUCvjefVTfPDZZITHxhOUWr1bCkMUDBPSW62do6iXCTbomG0hSnKTCR7AtZTD7z1NJw Ab04yzltYb9W684DkESrVJWJoiX55zo1OomY2YIG7pnMVzVXQcFASp2Ch5SIhbEhjBwhRKFwmKMC DHInENuyW9daRq6XZ5IumWOGxkDWqGJINBgP67V+0ZYp3LiIkF/2nckwCRMlsdukQS6oZT9NSNFi NoiMEZWjXCFjuujV671F5bBZy1FHnaqfRUM0eVrur+xK1bgFOTXyjBGeiWVwj4tZexWFiz0ICBgx JQ6hIglndORTQLTNpxh/plQYiIWRxDoThKnkwaRL9GShf7xhrTYw++etFZke/UAHG48tBiG40A8R 7jPfhlBmp0si5ZFJTzc98N6wUe+7sthn/StZogs6K8i4mkAzLWZdTN7QncGsQ7M44BjMW2py1+zP 1QhhUFK/l009G/Mg5ZHfcCIfVYYe1Z7C52mOQTD1R7Vae1Wq4k9Qth8yvdWkXWuMfgjmzazF3CPG A0bdqzUXpFqTeV8Xr3UmSzaItbmgqIyjP4WbI4+RK+7JfvXGHXWnNoK2SZx6rS6URuxCW9O0J1nN tKCtoQMxsyYB38STtPhX5EJSdbRGuVnTeu0ONZw1mEhg5A4k7frAK/NZohaPZNstTz2jNDfgY/Dn /7XOGi924YbW5ay80e4odgcOyV5uRfN/nOZQ2ARt6MCckdsrfVsFIPMg+DKmjqylXcW5bLc0Kngg KQwxLqd+JqMblZikUapErDX7izSco/JU+N0RzuuLrBvIW+mrCZNkgHgWliIct5UzU+8u0T3KrMTL iboB2phUaMzopADpEp3EnYtbdE6PQCXlnIyJPxZ/NwdVyic/6gYLdGUZ9vLwMK7sV4xbl+BwigBm wsUjzBSHYoSTRW4D1rJO2NqDY5/7O92sFkpPMdp3B7pLoTnG0doQJCmBWXiyWHcpIYyKPwTZ81fv korKjmikH816FyzntU2bZiI0GOQBoQqdDkrlkblOV31VB+OnumczHj6Xs9RD582i9WrcqnUW6wRR lIaXruedWnO0BI5jzMwG7LjRJK02WmYawYcVaI64Z+Jho1bHs6CeQcTToCRhq2BVarWWj4cLJbrz iiocFZn4MBARBnhnFrh9jN0JNRPMWs2eGJICbu7oxmyFmyEK02inZ60ujAiZQrIC9CCIyB6mB7XW NA1nYGJMOmIdzGFf2tSaPCJYjtaE7Ko36nTGRJAdLrpNzhFNexJ6sgZk4JIlHvyGy49nG4VJn4hG qTwfNIY7U0gMgeBWSAsl7qVku2sTH5wkc5hkHvzEZL3vYx78138o8VlFzeBQkCX1Imbg6hYDVZ/B 0EcUdGqNwGqKKUMdAZZtaByrOSHF2CNN7YNorbVMDBcgz8PECyI12yRu87pRjJ+KUcHF2hOMwPUS w6w+QLdKGVm9FBAujZkEsxWEBYlDDGye2FDrdMTKCMPa0OAkA6F4XtE0qEujQcyIunN1iwRkGNeh g5lY3lspQyo9StAJMeB6i7CSMh6ovIxrCEJ9VHkwJpg44eaKYO/4aQXsimGDhJJOgF8Yt96AptAl ALPqAQXHezQdITEheIVO2NSDmIOFIbvPTG+TWmDGCk8xze0xPNBuukLkhJ8jJUgZTPVkQTMk0y6p BvRqdqiKNBhqQqVEY3R1e6o1AU+wxfQjGrZbUBeGtkl4XNBgQJdJocqdnlY8PjzB6ONBhDaBphBj MmPssz2jQdKdL4F3l7QzqdmBQ1HAERR64rEBb7ToIKPLtkZjkfrObNDrtpp8yzArkdPHbC3wJ/V6 q1Wrj5crFXkoVeHnl2xQhEHbxAw8dKDMcdQ7/ZGb7SCgRkUQDEMHBz8O9AAmgTse9jvtJikJHk4h PQgwByF+Idwhps2NZqtF/4iyEcFISb3TtdZgLLyfkllBYJboGONUjVJqXZoeYkkecLkno16n3SCG ctNadn+ke54shc0ib4VN8LqazzI1o3XVpFK56pYAijnOJudCgVS3ogghWlZkXtHURZiCckBSj61w 1opWa2Zn6bp8tzaYu56Lw/F8Ulfky1YMJOlyKoSVjFS8yGR5zEQOhnAXxgjjGVqdWxE/aArUGs49 wYHjcThSdrpLJgdDVg13zFKE+CFNU+WyI83EcmalClKya82xnwaYh7SWKbzUSsoFGXkwbIqTECd1 uXDJ505cAbvGPxNZ96A+McYtDb++WwbQqE4zz3GAeEOT9HC1TqjuwZkJPJTLRrVQ8RTzc8Fem2Zb nZTB/CsFFtSTVX4kVcUF2XhptcXDmHmxyRKPOY5Guzd1aFqoZpWEBHEuBwPiz3SlqtMrRqbZIkU4 N3UukfysDh9uf6sD5SACBeR7NmFMMBeiwYcR1R4tlp7reZ4znzt+1g80RUEvDSfO0hvRjDLzVrhi o9tptEYuxkC9jcgCBW0qqsgO6o7RbmdOyFKQHGpm3G1BL5vhi1xHi8dhHc5RqNkdTBeeR9NxHlrE dn04xkig+B4PgMbUhRCQwl3MHXNdIkFE13cnIw6lwSrxCBRRGqnQUh9y0oI4HcnScVfhP7Eupb/N sUd/C1e93h6BIRe+SUH/0OCUhNTgl4JU80nzn1qBmnhGhHHlJlGVZ/Lwq6R6NLjKJrSioa1oHKs5 HRukxpVZofAIO33qShkZ5tWAV/IOh2LLQMoQVjJWIlweM6LXJrDdpNWNg+nkwx8aN0BUaw69bKQs UwFpSNPUsYiqVZuV4gBjFdob9RpYK0HrGykL218aDAbD6tSEjs4xO6LOLcAuZTGHhxCBJvJyeICi HiFy+JUBVM3iN6Zpjf64Jz3iCp2wqQfNuRjRowezQi1UPsWSMaql2FaClMHcV/FqbkRO2KhFcaiK pOSVYueJB7xgfdCiyNKZD3uk1shdUZ2CEmKmKuYYQqiq56ji8aHZjWrR+ZLMCvuYcp4PAGVEsTNj uMmXQWgbYx8zREzYBsbzSI4zogS4xZFtPI7ZABAxBAqaYXaDoAEU/AwPd0UVakbuFhhxnArxN0yK 6LHgCLnamUblzI4Wo45VnNAb7NUq5xcTA7TZGPJsh01Pf84rSDJoQ9ToSJeQr7fA6gACC+SURGxJ uXBIsVYimGLmWe/NAELokiyLv6lxDpZoFUNOk4ggV+/whMafwlvKmRUOi9V6MwSNfIrxMrfZ41Pm c58e4SI1ChvWp4Z9BxcwK52p0oHYEZY9EUWzIh7hajQqmS83x+7/gEBLXQol0ISBerY1AURLlhqP nsEDASMPrSLUBfyuGBVGMUVHy1iBSeWYcXjRqhRTEubJUCfgQDW3opAmR9HXEcVLaHIu+poehHpv DgFXc8wN8t1a7jgMX3ZyMVomHMbdTJmAUDIyFO0JMZeGTn7+AyYxGFojBwvhLg3NLjqgDPu63F/6 ihKTWlTjVnj9lQASZ3wkS7FcKMKDFTphew8qMvjNi60ltVD5FOtwhO4dLVoFmKwrBrTMF03Qh0oP yKYVArR6S/0LCANyH1kpiTLcBSK2QP4sJskiCDaFUkJhvpJxgjrlTq96WtngduASoz/R9hcTBANA pNXJKIiDndwebSuiA2h0SEPT0eyRfdEH1qf0HYqQdaYJjXz5xPEqBi8r86JMnwMRFVWYHC/I9kST hQVBsi/qoK5XK6EYdQ2EzpKl3jbQ6uBZkztvefWTFxe47moO5S8P1oeKIi2OYD4hjjqvPmfr0bTm 3eR9CzwkRKHedCkmXXJZH0ZTuEiSZLoYgA066q02Rm4/v0k78iYcdKs1cY8Hv4hNidolPquopSu2 mblQ3oKdrf6fHwg3ygCKzApvn6C1Y+GDl1rRaByzOSypQLWKoyEWWbB+KeSCq4sgE8AxeND0pQIv TGIrRgVPaxXC6HQY7lTK6IZlhCvHjJgvyfXijIXMzmbXMn0bT7voGD7qHbFKK4Y0plWqXxHdJAHN oxJScvxpVUgcZco0dc/LCNB41R6LQYmL0Zfbq89mRfJWa05phW5dhh1LEcXhoa+EZoty3GJWg8h2 JYCGgCFmDVollnXC9h406IjFzaJaqHyKBWNUV/eOFiQugSnNvYZHrPmqlrOK0aQrxyn2dpjrtrAT Y63pGrSaLyfYgmRzQK6qMSxButTpVY8PmTmpJvELTpDiyf5eJ3Fs7trNEMH+O2wjPNFRUYVWxNRu E0GL9iIen/Im7vJ8sRD5S/Iv7EeNzQ3LsKYVcqHQMWUl7mnbcOlIvG57IDYM8DTGcHOyskU+q6jR 1sesBp+hWOHK1j+LrejCx2wOscoiaNgiGue1rSb61pMqwMuVtIzVTObHTLiA7eO15jKhrVdYskow udmNdTdCqmtspqyLYOyJvoUmb+bMiiqCZvJ9X4a9PDzKVxS57DdJV/3QxS5Mqhk3QCWW1mDkeD2Y tVY6O95TnAlSASZdquw4NGZUREsbihGU6hY5dDyJrcZE8l/s9KqRyepkE18lHOyFD4AATUVw5Ja2 PwDZT5TESrhGvJpfG+a3On+iLP8q2aLdgDi00/3rEwKb2mfYkvnLHysKKiF0xJszf3l2fj4OcmuI P1+ztqUPgkCy8rwVbcf5Qo5kRRsglvr1yy9E7J9ZzGi1XMptZj9zy59dc0noeRxx++wke4tAeLvy M0tr8xaBP8LtkybSQYKb4F0jHsdm/72y6PwsHB5blI0F30dGdNpivvBW798RFdmiNnKcu3Gciscp kyO66Y+TY5XS5p6F4/7lP4Vvi2CenHgVmyd/jjamuXv/AUwU1NpOFbPqGhK1LWE7zMkdqnoVkx+U pJcw1IE5Esx3/jUAde89fp94wHyYvtvCcRICoOXKBDMNANqSXqKzRxEBlS3npOm2Ys4lZKJcpPwh /n6fLDoiNdD7K9wPIUeZRpbhirZGqr305XLbrqRL2gqJvRLvvw64JSlWxkHGc3btOBW3lFHDLyNY daYzZZ0UK7mFqf6vf08Yv2W0fpDsWCd+jmiIq5eA8rK//wAWFN4idkKv6eHgdeXGVOxbow2T8tKE 92cK1jzaHqe4xZv1ci0am0/6MpVgXoR3/Ksqd9l2Uu+jKLZTxl3sZ1DL/LQjlO1ITFsgxVH/oLK/ lZtfQwHsb8HQQIIpsW9nY7qtskmmVDlSZ+cS42DVzFg7xgKWMbchRN6a+Ydh25BFx1gWzCjjomwj l6eIJMq2/uZuZWwouVQOLWQEYqEo3Vcu7Vg5ARHzST+OJxFlN0KGLoVGluGKNhgP3IRyM5mzxUJ5 FtdIRkTtUt+Jd5MzMHBZQA5UUAaN6pRKxKtx5DM4qaRY+UReLJoO12meTWZkRQFgjORHFXEDXabI kh5+gq/cQMpYzTJlHQ+rrKaHjbiUCELu/gLfaqigjAkaVZHZsdRQoHRqqrcyirK7NSZ0R7At1tGP /xwVElgZ3MjT7QPYZGnTuaawZTCsKHvS/8/e+7y4smx7fvqLNPa0oKdGo55p0hjUYDBoKuieyDTt at7AgsZdGJqauMCmRjUw1dhUP6x+3CfuQ/AsfK2+D/VDHNA26IIO6Aw00KD8/a4VK35nSlW79j77 Rybn7EplRq5YsWLFz4z4pC5sQLdBOAyy5edWOD/ceKiLdU/be13RJGsjEeP2CQ9ykTPYFWiE6q32 hQKbObmlg+9b8bK1YO69EbeVuBPrpZCdcASNLAmDrEwBfRqGy6d1S91OOQO6O1LWs73u0C0YPQpV w9T/6f/K/h22ucPF38nuEtcAK24rXnwLXlayY5bvs2SZRI6HasMx5fwu2L8g/yBrGyk6sgVmxP0n bocFnZqZPiXUCF6uh7LLfJnKiV7YoR9xwHRRMeorexqbK/0a09Ga3lcBEOGqHFemKCcRxYQrf04F hsoQK2J0CxsYxAhLbqjC1Q77CsesYlhTGlsq/KpsdDQF5uagWLKdgbGgU/o3kZVAS/N6zriM2R0P f/q/lKYVG7A/kW1HPjojbhUqBffDzpcyU5yJI1KW14HRN9nK4rXdFkji//ivZStfCaBzlYs8onQs sYAQGxgHCoKJk7+xkiTIkS2jnX0EBk1CiR98Uo7GcpSg4VhvH9EHyqFq1i8qfTvRqfmHLwKF5cMz R8x12R4o7t1DUSJiyPaQsjhzFTTMcjO6XzxP/XJ6MBgPsmgK641R9Gy/cJCMs5YC21askqXUjrmH NcxmVcv65ooCUcc5hTJ+JSrQu7GCLzQx2AIAZ4MjyLY1Anhlnw53ueLgXdnxqj+7f2kBWxMeAXAM t1WB3gSbqcceBHKV4qGacUz0lsvknzaKjtDqHrbYxei2WGL3E4rCbLkv2WVWpnKi1x//TDBXqrMA iG7u6Dlcldp7RHNyXqO+ALa9BBAFK1yXohqJKGzKY1U5uGMDySLM3SiVGKWgZYQln3fhJNpYV0Eq md5c29wAcxM36AvI6xcYIqGleSpXrIz5j0bHelYWo95Je+wiTMPAyCXlqcYZM3Wl56C7Gq+yVXjO E37M2twWh/2J6LU6AF0UVgPrJri+cuewCS5d914Q5Ih9cyv6uPty8PAXbv5NsXVFOfrP/0XRcGjT PMAq2k1j5vIOXPp2rHbLuUmo8bWKx5Tfcrc68Cm/FcuU0eAG0gkPW0Mfc/bCXXRg0OLUCuyx4uT+ OXGwlF3GHkgGgmupKGrudBUqkG6sgL5oaKMYPdeoyQZw2WvmIDCyN9PvTvJp+LlPzG3El8guxqFG 045rA0rL7Qv+xL26fq5V8VAYIaKmr+KYriL/tFN0nkeo69aru6HAxqabHari4fq3CrvMlamC6CXp ynVGL4XwGVct611X0ksAUTxZXRLJvChf28cpklWLMThRmWAJ+6gSI7PJwYgki+QfyzsfkenP7TCl GuHBOoNLOqWsUtQNClpa1KwEZUyH5e2No4iAzIl2knBLO3wYM3JQ2G5VM8Wel7QIAaNMVMVW/jE1 Ah+0ZiUD0P26BktuPB6PRrdoBikc6LeoUkUlk0KccpuIj5kvSbzXlKP/yK6L27JkFbVqKBOw3iY6 WqkzuKJENp+6InDBGfi87m8FKRrnzIuGZsUL9HFibumwWwHSW9AMXJB6ga1C0rxQswAumH3QF8lB cHGxynBbVXe6BhUoDha5LlVii9YfP+xOLOvoRQC3q66i+rLTmG3q1xs/87+ag6RAhzcRrnyxychJ R95UGv5ThOLxMChUWnidNStxTII7yPhdIYPMl9opOgc408141L953KyB2BkB6Dh+1jmxjF3mUlQQ vf40/9dlU+jViOzg6iLcyjlR3grXpYj+b1wgIxGFasRH7SvbSoxinGxzug+vJwnHLNSoYUDqtW4i OHGuI3KDnJbmKmdHHnPKWK4lzcpNOtvsw0i9TTXsijuB+1UdyTT2JvInXkLFVvYU/lp436xIndkz AN15+3B7O5vNbm85s6iBYwvY40FiZpM9R836fgHVzxa4uF8jAzqBRTn6xz+iWXGNkVWb7MNkdC+n icz3Zr4dFGo982kJCfGWjx5cguiHMZe8TMFlGUsO3J6ZHQZWBMDq4QXi5371/ERYCo8V4EGBJ6DX 3L/1AitZ01isIiUtRpkvTeF4LRVF3Z1oyQuowGCokAh5pag0hNcz9kPh0wCc+EK1IwfT3gSdDkJ+ sjOj5Vj2MfnOtiX0xrwLYVz4Gh4Kd6s4JsnrnN8VhpPmSxcoOjJAxuonOPQcBGyUTxaHCqfIUlQQ vf6BnPwMaeXVsKeYROE3YhIMk2EpJwo35bgyRTUSEYWT4mVjQ8ozC1RitFsar/vXX5SaJ+WY+fmf INY/20JwCskvaWlikJg8RoGmA2cPbmZYe3rcPLNHF3MxfBg2KzJ1YFc85UnnGbJMSRQWUpbPJh9v xVb+Me/JlpVyJwHQRWFtkF60CyFMaRMmBMRvOCMGMpjCvP9L+XhZjn7BEFufCgArZkodqlbxbXwY avH8svYLQIKKyZnPzdJuPpywefH+YokPWG2xephfCOMreJmDwhwdJgMCPd4LxOPyrn9ERuBpw9EK B/vgGL+sbCWPi6JeYDHT21isfOZCgow7Zkf3LhUlHS98oRNH1m0VRUO9dBEVWGtWOHumSMDTlkvC gEI68etRMlMqU77yBT2X3O4PLWC0nP/4t45UgGtwQuK2KtAbPqGHd7ASD4UAdRxTjd+FfHSwfV/V XKDonIiLk67CnsMA+V4GYizYZdRQxvK45RcDkuhlQ34UbfinvmQRNZhk/xRO0YGUF5EVAJEa4VqW EVKUk4g84epQs0ARI4uV40e5qPEnWCy8oPQcs5pY92iN4ITqMUyCoarAUdDSTOc//E1QxnSwOXba dHQvc3outqBnRSVzP9YSBWfMC/CkrD9UvKWwlX/MNdmcBENW+i9CiqoOQBeFZW8KrigO4L7WwYLg WXkStLBJrPbwZYdPE15VjoRXSVvxkPdcJd3Lu2Lp26ht+U4nWvobJ8SfewkVy7tAKE3sm/lD2/3D irM9coxi3rcXyKfPO7c2DOGGM9HliAkOvPT3CshJvcAiU3L8mn8s8na+7FMiXAW114bbqrrTRVSg tL+p90LRzYuvQIYz4kaR+MWdu9Yfk7DaHYUFAi2nuIULOfRGw2B60Q/ksVQTJJ2wes+9+K7jmMjc iYPWosQ1rkyMBkcNofLLomtdOm4l8RY657LS3xK8rtC1KUK4YyIBSUwjSX61xJiE8z+ixZz+WuPJ lYELKzXpjIpLUIRYxtkYZ8ONyP2K6MIjUahw0c7eYqsSQGdSrvxbKlleqYgqyhGfyoxV0r2CoBbf DoE+8Azq2feeW6RSqygVof1qeSa6JZbLjBDdTk9ZJZQovJaK4n35kkZqv5A1WPiW1C1vUt7kdH8b LbCWvUD9W7fELg33/eOY0vR0v66xgLwbybt51zz4VcPInBWXZHf9yy9i9/PymZ8k7Y7OAu+wAAAV y2ZMUIdjeodJv/dHsLmPs/Lf+vGzAei+9fzo9Oss0Fmgs0Bngc4CnQU6C7zdAm/mvL0hivNhNZ/P l9tP200djeFlfT5nz0RB0iY5PoDMaLKv/AtAX3xs2bFvTiD0zY1jAEOmJeHdVRQ47rfbQFBh1Hsb R4BPgrU+lWfefakxFV/Si7CWt8AbQpEo1e9OT+uDx91yeYl95Tz8T/+l0LAQXUlFEeYtF86H9RIf Bp+v3oxuvlYT0FM2SbquffAtyWgJa9E5r7Of/olGb/QhPvrECuZHy/3h5L2d83a1Cc5cVIiVeaN/ hyVcdYiQyboKZXkdqBCvERlrOIolVRZp/vc6+flT5W/Z3B3ix+LS5aE5gUfsasiM45mBfIVhWx7K ePTKmt8acbvtZH1m+K4fl/oPn5oefMN1s0xjKlrwkpVoahDLMphFimXJsEL2iasPAUWWccZXZD35 tLVVNg//Z/+i1DAWxfO3mSg87cGb4RKoAW7tVv9GvuVz3fIkM/vVmuCj9jjCBzevfjBWNT/32Zrf KH5bdA7CWbjB58M5iyjrF3wWSIztLlGX8KNf5Qob4H0I1tOk2pJR/srYbg0UvgzXJs9RYLI4jOL4 6VL5cLxb8IlFHOH9XvIDnXmgF/FiFepRHjCN5bKUDFSYshwZnx4CZLgrawOntmkJKyB8zGbM5Gfh EViuuGTKMhUXI9WOUhavBPYhLIG8kBowWQ2bAQm5ONY+uxxEpWdCrhjo7sgFvnuL40aTT/aIX2Pf ZK6gzzWWcdmkGsQ8T2NXMgdTB5OwKejSQyxLOXqF/4bsoIvmKEJRRLzpHKsRPR5nScifSuBUNwkq kM/f8El3235+xDaPFA0qMZmHWyEK8TABsQb4bSZqKFZe9dTxAnjTB3g9zNGTGNzhM/c8AMFDno+f d1xPaQXMTkNyziiPzh9MEzzcYD2RC/hSD61WXwAmvGJJkBQAD8uyoKkpoaOJvyEQQsKIWFxltFsR KEIDFRLaumpJ9HZ6cp0zOk5mZP+g8AHuDudjqM3kXlq+fHB3kmd3vcKJ/SRkgay4RoxQLCHTZjHG 9smj/xF/J99r1k1/llkl2026vjmFL1rJ73CUMeRNcXxqOb+14Wb2n2Sn4S/oVtu+ANal2L7qbcye IepPKhMOhUtYmAhU+FvOcrQw/KvNis0D6Z1rEJGR/FMlfJbMNoyhmFTrea+YS2CyPUQN6LZhImQB JLRdqF5K/WSLQeHdCineY3RyN38mig3N6pFESp58LjwzWGbxB0cczXmehpesOFgBuvSOgUFcM1Yx RLr6lfWbP8aPK9pKNjvjcX9rcDu3OhX3uUAxc7ZKXIVu0iVwUf3P//vzgp/XOICL7I7+JN736RNy 81cPsg+oEmnIMW8irtXPi5UFyx1Pdl4w8oGwhjSYbGm0zf5yabtcrHdH72O4hu2WxCdGBep/+O// a03F7A//h/JCm61HoTsCju+2G+y7t/G+JcFPCCAKfw7hDjp6zounDqIl9um/dRmmQGBGxDHRhKtM D6Tc9Of0WO7QvPu7F9WzsVkhkM0fslWzUr4YhTtasxuCtMIJW4qQ8tvnXyP2aerezWRRmzCJCZam xA/4V8yiZDyu50df1rrWLMUZ200CpxS+AqO3ORc4vmC2A/e6kPvqas4dHUi2t1CO+aqE954Dpxs9 rnFtjW2QGSDCWsAayzHECoCYuBo2eHGP1xAb3Ljz9zL00kyBTlkZvkhmC8bQbTQ2h5ftby6BFQM6 4ygu75HVlgcSXtmsnAFiGtxvXo8Epm0B6bpBMT2cViikZIZcovy9wTIuFRLFzYzV+Gn9gKxc/ur3 V3r0onOwCujS/AFPt2EVLbslO3QbOPZsogllonQjG/eq6+dxd8/DwTSu8wtnq8RV0U3yLoZ8nghs 0brucDcaglocXA0ES/VwU7WINAprYSrFyoeqOJ40ECkthDV5bQxruUNxbqNfkhzrwJgmLdZDmZWO H3gCJzTgwwdBwduD0nO73eyxGvDM84GAuA06WhbPX1n/K9HUsYAcHEUSLo0OoIKv3O7MGePj6x5t 2Wjzm3eqhtFK4Hwewfsnz61SvrxxZZ9+wVwtKhxSSXUkiIEV7qIGYxstWRDVn22E3tg+Ifof9yx2 POnz3B7MVUq2GwPbJAAMRS4fO1q9FEeZ4/gi4/npHe/P2Dzee9idN2jDRoERgUecYlSm90JmQwSd 8xJNVbqf7e2VCfAEKCp9yPHLarXEAWyTfNXkGkRkaFYQOzBzdwATSq+SZLkymWe0y+yNHNBEBoyS qM5UzF6WqoG+UdUECqszM6AzjiZE6ywjRyk7K0mdN0Z8wo4liJz4GNPwEdfJep08z+8GCk5sxzMW KRWYj/aNzeDeMi6bMD3O4hZVsBbSBRDlnIOVoEvfrLRjFU2mjx1SvWVQtSJ1iuFFlTW+vV9mHy0U AEhwtnpcwI88z6aT4YCjZI4IGGkK+TwRbU23H02fFtmHNszDg6qph58iuGVoefNiFWdlPTsMMach WW9f3axEyfHF0FXXLdZTsPwNzHov2937tyyUlkwaX7gcuJbQ4QQ6WhbPX4RFgA4TDxOiv/ivQHJe dhtU3qNhfzBbrNFIjIH+c3pGlUPZF71VLySLrDf7pVJBhXgQUzW7kwrnSAd4crtxpIzfLtTZIIia ODSrwX9qMcb2iaP/Uc/jUq+ET2tWZM4hZbvFgdWw0qzkOMoMxxfVNebGvhqRAe/N7QM+M+fZGmrq 0nPi2F12qJudpFdjBc1YjiHHpKvg4Mzu6nWISOfG8P5a+DKZ2st6wOsM/eiPV0H0zCfBZH5YmpXM gHGzkgEJScUZzzI4ho8mOtk/o8s4Ag9P5hVl5mSAMRtwRgiEvGuk/NVS6guRL9feMi5TCp7ndv/H QIOx9QPqYEvCd3rTu8fFegXGobCkNMnouLISbsQqWnYHNXz3QxLFRpOvBlBVPEyGHJzK/EkwCwbH wdlqcQlmKtVN8y5yYtRFeE2ATxnfTZkQDFdCBN6xVVV5Kok0hlvGzYqZKJhahbZnh0UsbWvckxEO Hnr5qOKsucEAlqZOkuPN7qrrFuvRZ/rju7u72Qz/8809fcmSGaudNCsCHWUFnxZPNiuWZO9Llhr8 Re3dH0zG/ZvZZg2MzBCAmVt83NOiKysHfTauItTZpFnJyleIpym7dejkpEmz8ugWANKwmEr16Y1j 1IvVKtGHD3H/0Gc6iHvCQB7zn8qL07zbs4CPnxO2W2lDrW8Fcvi65YdKwahf40F5L48rboLCTFhp VuxbS5PwWkVCu7jMkXAtjt0JNE5mjeVocdq7lbhikIHAZeilByFWwpfUQUbYgDGMUuHVcsmReiMx 4MmsJB9EE4xhABJiDenLgt8LuXTwbSzqVclAhN0KwGgI/Dt/NFP+Kil18yd1RKRlSsHz/OQ7lpwE ix2MMy3yzldn8geEbjHJAt6sYRV9Ui27ffWCO1KKuexNJnkWL/C4kXxETKxntYETkTpbJa6KbkXe SZJ1n/7RFRmvYa1ZSSMNQX0qzIa8ldU/1ezQqSrMEUXHDkbtDW6BecTym8UDq33gzUTyEC+sTvLK iXSdJDlmdrvYaD3pNky0E89Ymd2cXrAHY7XZi0uho2XxjDnPvpRFycFnjzj/1ecUBHHoqFj4qtCi cxazn/7BuDZjM4h5qkr58sH1a1wvTI/Yh64YybR8kVyePsPHgFHFyAXtqc8CC0OZzgi1GGP7hOh/ 3DPJCGYbj8GMbTJnXzG0PM8LthttaJ0flGJ9Abp94TyYHkKgLRGF3nzMIH23EqH/uHhGcFI+GE8k LiWXunGuuxKHCqDCkuUYwq3xhtXUdlevhF56+fu1/5zicIwSNcTQI1qr0NdPTEK4TLgVGEPx1XiK CCF9cgoD2kQK6v8XaRzUuPpGJgbIhyRWzgiR1pkK3jw/g/asLx34s4XyV0kpCkWOAzXLCKGUtXrO 87TiWTpYBXT5ahBL1IAFMpT66mGRLtjn8V6hKEIWaiiZvYWXVtQe59/E2cq4KrpF2EMTtH/Qz+8i X24mMv6zO3gBoR7uCpFeTyL1QX0NVi1WLljNUT14M0ndYTlFf84d/dmzzM6dd7oSEDU0Zm9lTi+Y Dpk2v+Uzt/zcJ+3ZZD3JxPBKHbodFij1+Cyp6zy4FzeitF+3AMkGHc2LZ5xkT7uNX69IWyMjFDRh aFfGMkMenEqmDRMjM+7E2YZSm7EQ5RWUqMl/2rPbl1C8UpGmjcYdyXI7nwUEVlvdwiqxgdAb28fH /gOf+GFytvZRk8zlfQXbrWYNweDFN66CvMkD8l4v61XGki6dc/2qhiGnL6LeXXrwlaEv9/uD/Er4 PJnvxhgWBvTaM4qk/vB3PvOkBZRXSWklsmAZf5O6piatOxhWu2bhUMfZUlJIE3OkglwclUh97HZC ty3l827N2fK4arqZ5PD3Dc5WizQIuuKskh0NZpA8tXXhJhkXC2PbvdTscrXZeuGhtjO071XoaKvF GtLTFk/zvUqRkUyuPnFdduPRPBcuqNwcY1WNH+uijLLdBP7XT9lWvwMeetFfX4WPi5FdKRwdxjAx 6e/rYLEqv4uz/S6Rxqn++uffB3T069vlp4oR2+0C6OOrp/y0XzUjK7+6Np8ZYYcxrBnw93WwWKPf xdl+l0jjVH/18+8EOvrV7dJF2Fmgs0Bngc4CnQU6C3QW6CzQWaCzQGeBzgI/ogW+Bkv2WrsVjNNr H/z4cG81C9ioc9Bo341b/gCa65nbM+aLbf4S+HrjOPtXmMzNMiSwuw3SV4zMPYDt3K7MB6Raon4n mfZz/e2tTtJsxejO9dhwLJb4LBD05yY/UvozT1s0abn1mZF2j39BC3wFluy12hvy9NrwXzLcMkIB XI7nvNY1jeNkt93l57BveNzn+udGtvAVMjSI23DRH2WbCq8WgNUzihquMJmbhRy5dNVSTbpPr2cL Bbn7JmM7Z3I+imH7TjLte/3NE3H5vtt4EVnS3vvToMpXYMMRxWcV3gIp/F6dP/s5nxFWHIJEfytc 6s6+iAXaGZ6E6O6j3Vc51liWc9o/0M+xZJVkih9gI0drRSltR35KdQlojDmVdYL2JJc94pyr+hLe stijmRcaoVnREYMq/hOGDeqpqLhHHKuUWz83hax1zpMMsisTjG1iyk5JhGQS7J5gXZXNhZSbEbgI l+cwAf6FYvsDtowkR+DBSjbgniUUoSXwGTmS0FabErjCfh9HTIKYwnpGoE2ix14AoH09vNptNAg7 cbLA1Z/c+DB8lDS77aUjaWWEH3Jj239SfUwQ9xr47dupzrEdzZB4rFlOv5lMq/6RrtyFg0KasnMb MoieIB5oa+Kd2oGIy31zs+WJeSeMIZ8uGHW3936AyyVCuSEfDaosUC/sGmuwg4tJvMYwxLknVyI1 BeUvsxsrIfmYL2d6Iyl6cinXPysIsKClNjqtKNCQasuIAo/s8whaSGGvDH/fWGTEotDfsqxBJUn2 T/LPBYZnfzJxO4H60xfkc4k1XtqGK3YrdQuqsGRl+3POZU2QvLaNyCy9fwCjQY/+BPv+D0LXwRY3 3WmLPbDJdiflLdcIpSibTsxf/S8ezaq4SVwf3DIhVfXWuuCZD/cFIZirZKryb2mKiszz9tbpQsxl TJ2tSnDybajC5cp7YocdTcL2QiY2Hz1ETX7A/Hq2sLcG0z6Z2J65key4b0yg7Q3Hjr+7T5snSwQJ rqg9JaU0E/bShdjrvoR9dsYNcMm78EdYjmNSF7YADE7moDfckL1D0BlpbPmuPat+KNY3Kxl1FqM3 7MAdPirCi5hQcOOz3X+pHMAB/KFk2hwmrJgst/V89wRLSWZxX2ElgyJPgFxhCzg7xFDieC9hbyjA xgpuukQoN+ajF3gNNhwKKQi64snN3GaXDPwRjqW32mxORkfNyHsHf0XQm1tswa4VJUfGpkrKXq4o 0JjqV4dWDsWBm/T1MOpyRiC32/zbVmQKGrNsa3WJftj8klVisdif57wJ2Tp6WMFLCPno3wJaKpBA oD8qWGNnq7N0LMfkZuiWUmkCEtyxIXlRMZxesGtdqghv6ipWV7aKj2/RsskXQ0RmyluuEUoxLoDa 5Kn+qmSqCqu2VA8YbtT8d0uWBcY7ePizMJ2FKkPEnCJHTOGKKUqZZDzCgGzGVrBlChOoSDDhLKG6 8TmcRHUmEzi4h6JAhCGHku3J9qCvYBn45g6B98SM9x7RnJwJSwSFvmpzr4PkI+gZFYKrpvRxtTtE w6WqL0kq3tasvJ4JDno+vG5BUBzPX09zWG51fgVaRDb7V3LT62yprujMxAoBW79Hszq1yyFz5pkY fCPTss7M2M7k3ut8HY08DDCTMoPoCYI0AeIZE3upJwQoMVuBwR1KHKgjmrNlHpUI5TKMNwizj0Qu NP4uF9qgys2Ft4w0isJOpVkZC29cUE7jzbliZAEaT6RXw0pj/PwPsE0BSw+jTq1PSgXaUm2lIC4+ Tkt3qyCQWyLwt6XIlDRmEGzgrsq4bq0xogh+/NMqw9ORMZihGboWkyyP99PxSL5B57f+HVEBoKiw RjY2Dgt4jjtGtea+WnhaB7dRGzdgdQV21Bu47no0xaE43CqhVGYS0Cxa5bxfyVDlZsiD/W7UThX1 KDzqeyMhKOO9vjwlj6V3ryE8x+zW+RQw7aUm1v1bN6bcrJULqzPZm8rzxcu1B8vAckUT6Gal2hPI WKBwjeAq1kvpnVSgyZfe2KwIHn/ysoZTCYeKNcBswXdT9yDd18nDLv0u1TWdNSForVYEkOEDEBWv 8FaME2jNa0mxRt2PehEuvccfVt1m/DKDGHDiGKFaT/q4cOJMrSdpiavkUYFQroQJ0v0MpOVCTnKO oMonp4kk3xVV1LF0gyLSEIM/Y/L77qudcg7MTln0MCC6WBBcPopkZ65CgbZUW0b4HPE62pWSQB6C +OwTNZIiE5do2eo7EzavY1y3qRTE//hn7QxP7+2WFzKoTLHGqExeACDu6aQKLaZPxY7hrsgcDsYq ODzPXH7xH4SpYHUP/MABjtmCTVYss4VQmqst2MyMixuL0vDSHbJvIR23IOj/saqS07hiilImP/Jr Tckib1YqEpxs/EnLhdKPvdHyBKpN9WF9EJM+1gT7wP6K77jiVsXmpoR7sEZwjURZaMxGlmhilwqr 0ELYC2cbTCUMxxjp6GoBzikRwIzeL10HLpHlphfnFKvpDEflZ2hmDxipCX33Cjki19mhBhMWZfp3 D5xU46jWcs3b3F9B7jd7QtqsqMNEooo84nuIGKHcmo/e+P6E38kKJOcYqhw3K9YDtLTkkXqbhxPR 2ZG6ed4XelueWZzUskJx2q2Wm18wWsGXyO+f5qul+0YYZ+FsktyxlwtwdFuqzXrO/n4GLMqjkkDu E2JJDoXIF5mSxqzId33l16aSl/4TnBDFmeFkfY5YA0Ez6MUa1nj1wJcvD6v9Cfl0wGd87LsDVq3h aZdNMss0fcZc2oaTq/kkGIr7iIP11wPHPvz8ygFTCz08QDYyByw6CRbjcKuEUu8VVqg5EseX3lD7 YnwAkbOVwl1df8yFZxrRfmEGAg0l/Pz+z82kX63cLhKepaYdrw5nJTEmUx9SPWYSaGo9fC5IMEEc 7/lRQjGa7z9bAu0p/DXMr6/5fWB/xZeRFpQxJJkZj8iFfkpwjUSFqJt9yVdoZ6yZXu7iVjA8Hp/J 5F7wEMl3TpdImEpu+mdNsYrOCOPk9JQFeo0cClY7SNc0p17jLgah8P+bOxmHWq55m/sMkhmb4Xx7 OKyf4IyJJyAKFMPRI3y/9mBeLgT/myCUW/PRG9+fYORxz75aL8eGIzmqgJkxSj6LcxIp6aIvi2QZ gU4H3ePbx+clnRWdtIqR+Y6sN1xgScKJyx2Hj/8BBskKgiiQsJflSqJAW6otI3xxYEr00FuHFtB6 yIXIDs56JY3ZY5whvk0li/9n+NvO8ISPOf9nXgBhWmKN/5ETRdGBqQAUQ5tl4gtWHJRD/vnrYfXI SSg4KIuWuytB8E+O1ZU6WQdBMsk2evxL/FFR5S3XCKVSNJJiXrJq6TDWHfLqbZ759kGO4Qs/ApWr ZKrib2mKQ00mmPasdnDgT/ptjoqEIN+XC1iP/WuRABEDGk0tzMBRMPesYX49W1gC0/iinraknBjh R/faEqiFi2ZEW8yugxxGcA3Wc/Eic5f3LqkYWiCb8aKN9Qxf2Ruw+oi6CVxa/0jzCWfdw3ttmbCa vvCdA44yN/U6/vVpLHWWMDv0F3wuXJITeS8/11thO0OmvHDv4/0/5Vt21DLoNL8TK/YHIxjFuuui FdTGJzWR4Ic/lLDoSh6VCOUWR2ULq+9WLBcQZwNU2Vyr5slFpKclsttNeWkypFkRN2FinjZwsGpm QVutBvAJl4d9rSjhTb8tBTL2MpYuWFEycHRzqi0jKnhku1UlkGs6WotMTmOWHqZ7a9BeoFT4z/Iv FvD5xXxXpBmhPTT4iuBRkNNqMprpx0KkyXCDhSgEFn4SFBpfic/90LhQuPUxEyGB4vU+diP+KxrE gVpUutIUNHBDmq6UwCXFb8ijC3DVOLk4b0lgHDInuMb3/Pnb9PSPvefkmty8Rudr5Hj9rhHoA8cn m8fp+F7frHEMbmvSoiCtmVbmUQkELsNE0tPT90KV00jRNg2SZsUigUnjEoTLpZEzbasFAWEyr08V YHyZHFMh/ttsWXk4UzV+sum8VCMOeYVKcfDu/DMtsEVfEYe87ndrrt4k8dvB4b5J7S5wZ4HTBm8N MGRV39d1UL+PVT4MqnzaPj9jgV53dBb43S1w2q5Xy9W6sgfpGtW+HRzuNdp2YToLxBY47sX3uWr5 9zx+Pqjy72ntnzzud0KQIqt9FI4pEpmfXhPFNWFyufHvNmTQ2zhdn6tJrNWbzl0SEP+WO+vbUvQm udiSvs1fuF8n3LBUb+vcWnSXkWIW8urkXKf21eKuDHg+7tbrlPIGl9r83g2NaW8OY7+rf0tTv63q cJa/nKfV2D/+4u/jCR+fjm9KojFz3glBitLyJgiVhyBFAi6ftkThBbaEuRwBQnhkkFkmPGWb36/k dH0UnyoocOWZoZkc38l+Xvl0S7BKiry5Wh579Viqe77EvfqwrLyMFKso1h7Lx9mkPZ78riyGjJaB yVpH2eqbh/w9fl+DrStNrVcCbKFdc+cwbXnqy3K7JL37psAVgb+XJ1RU+XEuYcEMlnM878+69gPA oAwY5XBb9goOr2SReCybL2lUZIFJVzZ6u5ycRlygAEHKTBkTpeQtnr8vooRYpJdSxSKBZRibdKgq r6wxHw3eLjqsk1nG3xJbuX3WuOgUMOESLAFM0aS2+D8nIDmhCj46wzIHsXCOX8uIVWAVJSSuJDqv p1+PJJbAMk6s4rOVKlgFbi9BW8hFqW2DYF0ycUCfG5w3d9mZi794XWhjmqzwnMdSaShCyTS9fMhx 1GrIMpeVbiFZ5Ex8U2vpoMyaYk1xAcy1P/4Gm2C1KiJ4G70qijY6lRKRMbsYfe3Yc/F67wH7Ot1O H100y6BpjsTy3XnVgWGLBtSYRJ+ytlokNGLrUieMvZruejjJsu3K8huNvoD4qcP4xYEMlRalqCy7 Wy1T5klgiEptGAm3GoyX4hSxdCALSMoLwMAsDH6mRU8UbtGKz//Eh+zI46vE4eLvLkOQYKgK7MjM x/fpXLLLRaQOM0v8DtEi4AL5ZciD2/lvG1lOiTWIuqFYJRREKSGfuEWePB88/MVFkdOZYqqSqRHW 5SJ5d9yNUlNe+ipT2S3j0tFEE7KhCrTGytxodWLvXngvJfvICmBJcDKT0aX9kePXCqpVQuLa716w MUAPpZyZ0HiZK7bgLbRZWaJ5WXG3wuQZ+/aaYUrg6tz6vOopiMNLtn0fGu1ohbGHEZaO60dbXYy7 1orJkxGW6g+lcCzmVHH4N0OWWVbqloFfQErRZeqoPLBWdvQkWB2JoqJYLSE+rv5f/W8hkWj7r6VX VXy71ZjecvGJgID6dzvZQjWVqFFCAiarPzHDXsGCa0aNIcqStVUpv5EE5GBSJJG9JQ7OOksJ3y/f LODSm+ULy5mVL4IDpdz59fNwAJTTuCzHt+7jQmrmjAPXMqLizFho4B0OxBWUjtgTxo8ryK6UZeET iqPe/o0t+MfPqlam3U/817qy4gAXIUhCy2mgUVktGvVDTLju9mL/bPc8HEzRU8OVfrp/gUuOHS9X 9rKhxZEZg2dur9+jh4cC6KKgJ2R0piBQwxxIKcQmTQ7NN9xNCaBZVfnjerVOWLGmc9LJVwfxtyog Mm77upnJjowjHfUemz6lAO7XaK/7slv8cDfCnoloHkhcugG/VqFaSR71hcS1L6NTHfmv6en27/Dn 4PHlAZWGbKvEpi1soNCtcAXrrGZbLzlykuPjELQzMD0gHI0ItR3es0hKVZY0K7iGnoayTcqMW2G5 bQOyzHuUVkEtMKuqYvW4DBaHPHoHvSps/TAjtxnTGy47kfW9rKPGz/qyqUqa8mNMs0PFgVtRY+w0 ZqwtWjstv9J5a8LWVZ2QY3AtX48cc52eJuC5uu5fnlBuNEshfs5ubnehcgKzcmqVQxu2y0dkgWte XXHmEzsnsznMflqjc3uz/JWlVcog+orYIAZUS7UssxRL0fsFe9uGj+zSrO7HY7ITu6OwgJUOum7f UZ6kOmINedotH+5uxyMBEYvnoL/XRKMy51eHkcrThO8XcEUc/fHt/ZLbDN3O5VSbgij1ekLdNXjY nHdwAG5wtigaFJMtZhrmE3sXBvg6r7SEtigfNDGdrcIMd/wVTrnAIwfDIf9juqrsI6dtwTIKEn1c smM0MewnDmSedJMd3k2Akni7oEDNo1aeldeT6ZWa341rrOy3k4vKTPcKS4putV08EGOhQKSbxScM S3uO5fu6BWg4oV8akh1ySuE+U1S4TNG7nokzoDESlWzwsDtvUF0SwhCOimKNcUk9QMu/g15V8e12 YwYV0zNpIgPvqIE05cxodpBSkxLD2lFj3MiaEvy8tb2TxFHn2LoaWk2V+UQQk5v48kyhNIn85TXH uUL8FHXiodZSlGrllGW5Ddvl43JOjiqlRvDL/Q0vTNnDURcWGVEZdAmpFS4mxFWPV2nl1ftJT9Sq EUIKdnA5VYMg+Uz0buntZi4kExTSmgNF63pcZ7wF2CyeHyZDVD/sugc59rxskOxN7x4X69U9WbPc O0ZX7E/vpzf96Rw/XRStimkYcfsmd0WNo31sizv+62+ZZcJNuyVl4eZpieWiy9VqOQfC4rcKYMoM 0gxTMoGIIhhEL0qzYp+vOqN5xfyPCYT+lehKPZ1MGRPNniADgBCS4XG9wEzZ0zXb2j2zv/xWJpur JYQoaNpuoGzWrLgZj5pwn/CQOmtH7Irr2SLaBGbl1fKOESvWGpc6wDvoVZx8S327zZiRhtkpazAD seJWI2mKXTDkNgcIqAq9rbwDt6LGKtC5mgTWs6oepHlaF6/U0GqaKXH58uqpkPhfy0FeSxzGvpWQ 7ESz6sIr2YLt8rH4wDjJvbr0gfMGA3XhS0DAaQ3w314h55TntK0Vrjgh12jl1ftJTwqEFOygOSU5 nkOQ/EDGO7a3m7c8p7yGjygF6yfMPvG7S0Cao3vJIkLcNz/2xzACQfKP80pGJ8M96V3wEXnFqVGI S+eKeYFODZmnms0J+FqSWgbyTED9BOXPh8XzyzoGG/mq3izjNQxPibu6CSU3w1ZhHzltWSfoa1mb 3PMSfVxmc95xFyVwI4mrEp2XahIsvSIQfXQZX2DyEMAt5ofMVXv8mnu6muless41KZMNhZjTmE5b zi30Jo+743H56ABu/imUV21WqsK9R3n/CeFddRqalSaYValYNS5fBUFtjDKHb6VXPW1L364Z8zL6 LEos7VQjTbHncJEF14Yaq0HnvLUt4xQQ2oCtwzCzCQcnBVkAesAToZRzEux8WL/MMakQjjhfKAp9 RXNv62k8o3Rn5dSV5XOJ7cKExssqXeLuC36ZEb9ySJVVFOyhKeBuv+Tb5Dn7bzYq5CwEmu9K4Qr5 dZ1WwQQ/51mCkHITpPC9mwYIEgqmfPPC137Bat7y4TUf0VBDfWUfv19G++IhSNIdo5AKUUpk8yWj fCYDvxgF+ng1OpMX+BcNw1cqHvB1o5O3FeWPnL25S9932AhrKxDB6GsmrkRQre0L58H0kEJRYR85 bSssI0kY/mHBdy4tNpdOI2NhI1hSrUSgy6MWnpXUmRTr0hvUPpExPHzA2PTJf86rP07ehdZsa+rC /iyJ7hjO8AEmqyVwstFX/bKPPKxukmdZO8m7lQpWS5REo2eZywc44EWX0gwYva1rgFnVFKvEJZWq MzInL91xPb0qeoVtvg1tC2Me6Rzpq0OxQ/jHkuavFKSpa1lwLaixCnSuUgReW7B1TU7IodP2xZcv 9Ju4dJyJ8jPPkrIkXxTiZ82Kf0tVllNflv/0pFgOWLMvq27EsOlHmX3gilfXnBkFB4VAj+nTOi6D 1FaGkGXhiotetFynUSufrz/xSTMzB64CRFfc/2g20yl+nYE1g0c4WnxgkWS6mLeMFssfr4ysqlhF IFlE16kfq+rPS4n+Fk4EdBRfcJcqEbZDhFIZya92+5eopeTh1h8t5KL2SAXD5LsDGsfxcYIX4JLj HCdGbXGhwwXhRfjkQjvMiklKFLsYFx7Icqs0aWGo0revIVMl6aj+qDjJpRJxETXGUpd94rgWN+NJ LJcEajRjanCuy7IeoD6vC7/hFhfKtZg4yQhf8tJboVmMFfSBMWKS/ItvVpWnoyTxxU+489ITQqBr tAqhu7N3WmAtePz+Ld+AdMdPaAF5YQrkFRdv3kyfm6uo99vmw2BW71fhm3vy20GNwTSH1cuLUIu9 mWQq0l5x+qvvPzkvnx0r+v0yPv7Jb1Orj0/n15cIfsNylbrU11eii/F3tcBxtwHubbO7dr/1m5Xt YFZVk30jqLGqbh3Er2qW7mJngc4CnQU6C3QW6CzQWaCzQGeBzgKdBToL/N4WuIpf+vFKfhGCaGNa Sv7qx6foOolfWZNKdF/E8pp449N+wSgkoi8tvzErYc5NfgBNXNEHIYUj3SiqxoVuDpzcqUSX3P/B fjgO9p/+y0b2VBepu2zq4pH3XKgRm3Ft/jJf/fkfC8R3EUOlJBZhfqAL1/BLLbnn5zE4rNlaL7v5 pr8fShD1OFMH7y00MShuceOrX/jKmpTgWXzmG6/Xq1/3+2xjGJ/2C0YhOp6+XBIu2GD94JfMu9Wq WKoA2kBp0iZX9BG83xOuNG/J4vZxfysn19QnxsH+Z/+iNLKm46KpPyS5FWKzAQP/23/132GJdXu1 +P7s/hDtv54QElAzfmnKFFVVYl7uHmvWJ/7b4kdh0trqH2HSCidWlvA1wHsteVzHjm0OV7FkY74x 1xKGNYJ6HnCmDt4rkWha3EJSB8XlDZdGW2Fah7uSD5ChTU3z6G/KTcV6R4r3XGIXMAP8Ok0aAseQ VYsojwXRYAf/3iHN2u2sSz0T+LDfz4KU22LL6NTsY9lqWujf3Cypw9hOEx8FHkpRuhkSNhae53KD MZHwE/Fr6Y5+AyIbY5m5EKNmUz2Vnxx8FSthr8nuSFtLqbOKOnOCww2u2ORLkU9WMzHCTod1wPR4 V3aS6KhIampPKY/U5in5wyz3bvVvVmyz0iFSSfm14kIJVW0ZkkuaL1g1deakPmkQaxxsc6q4/Gtl 4Ewd+4A5NrTK0ssE+CO1mCZAkOx7XzQQtonY7NnmsnNndsTy42i5dqKnSIEVYZ9qLSFmT4zsdfye Tmr80hgcquzfDPvpmbSz5aEMjLXl2oHrz/7m3vfp+hPZKF/YRvY7+w5fI0u24BsLCjVBvH6KwMhL buIl1mzNPcBOHWAeueKRmOUK2rSEu2bg5chD41QUNGC6fTgmT+SllIBfp0ktcAlQrdBZowcfNv/f RTsnG9N6Ch+GnqyTzSZMFPYs97ETFptJw040h2jmbTkyZ8C1wgdsX7zVACVKVwA4aqVoAWolly8a M9l6KWL72OLK42Y0tk2PswWJpYWewrGRsEh1zeya4pZ/LaUaJHVmxeGqK7b4ktm/kXQt4C8u3T/M 0ZtTbOkOLIO7v5tb+pgGja4wdaCUY4+tPxL+MEtEbIq/K0HTsekE29uoLaKIaoBV2ByNDLmVlecF rjmqT/6xyZN9mJu/ehC/PZZEazW1+IBgDGmVgSKiy/R6UxQWU1R4qwTD61GIDVUQ13/6W9mnLwiC J+4WRp6BK6JZxl84Wgp+YWR94vv7t+SX1piiBfbz5EpTLbBwVoUT++nv/yczaQHv9aaSkniZJVvy ja3KYk5xe69AkwyM7PZTCwP5TsD1CyKDHrgHHyEZac5AXhVwV+VCsCwaeNlr7U8qAFtJ0ehxjTBr qM0NYhXAr9O5ErgCUG2KBWTv/X7/awsk2RSVZkVZshl8OFgPYZ3dKohmE/SaO8Mf/1zCoq2ydXlU QemKPoqEDXMGFYp1xT4cIAyFlrxfEJAb88dULPc2HBZo3CXYGXwdcGbaffVw+q0NCu1Tn59YSvW6 aitUW8PhOpO2+JJ6QgvpWurJCdZtEx0G98Xk8x42H21+K+m7FVMHEoIpr6Z45IaA08sUlTSbFfp/ wDtnpSOHCZ9aXS6IOu3RvxvcLTh62bMRBGyhgms2vE+r2MDB1u5QSbRW73U+wE9u7pEmwPSq6TVj VCzWLAEya8Rmq4usIiIjVz/WxsQOwLUIR3PBz40cnvnezkp+qfiwdSAV/nYosJ/mBpXAwgzRHi9Y bjpUuBlNnxbstFcO5shlliy8EqjK2XQyHHAowK9CWFZCpuUmu0nKytMTuW5pkbh9yBxtqlSuFA9b gpdL/SvcVCrmcL6OwieImAzw670rD1wDqDbFIl8NgKdftrOaQmvwBD6M0Yo1ykidK5glotnX/QUD tuYDVtn6PEKdkqJ0GakRsyOrVnM5NaaY12Etz4F+o0JUrCirOvA0SpQ5Q0w1lNEZIB4ysL4Z8hAf u2fH4NJhKdVwPr3IE7OqumKLLzn7t2SicKhedht0mkbD/mC2WKPaGj/HRcBHx+o7NXUcTNVkh1m6 Yfh5WluXjHDylUtHji4vsL25tqdnkM7HY/z/tAFvw0TVGMhxnaOaHKw+afVkm2/0RhboWUy0DqXe MJ5o4FAhVNOrKeW/hcXEi9hNxVGRYDkr9+UfU8llJcYoC/QA0BOQl4zzPYZsap3J3fxXfVzcWOsE y7vCyCGC7+yMqU/5pZIFaek7FNjP469CipM5JU8Biouqk8kpy/Xi5W5KDA++NVKxjuTIRZZshW8c PWj5kjcr0vmZADfJ47gFr9TlaYk21WZF1TYnwfRnBl5WSfG/8OScm+of9+2dVFkZ4NcqEzcTRQWd v1XoxE2x2KKJy3b2Do+IUpasDPllGgS3noUdLS1Fimj2M4AFA/ZP838dSFDOB6yydaaQeZj+6P5p vlqimy0zb2XZdF9LTCnWFWOyi/6gMwzVZsVVmFYLWc5WHFu7QC7TK2aPM7rh3FKqt0ttLfYWX7Ks aclEfBmhP5iM+zezzRrfzRmOOMWLD4MUzvNaMbULFvWY1RRabZZlB/6BWcTBZIbsWnGkxwq2wPZm 2v79/H52O5vd3s5ettKsqFVrDOQKrtk1K4gnExvXGGbqKNUZ0To0K9ZouitsRt2bdJ9ey9CKxSxH GCSWoBt9CwmwjsuI8KAWk0c02WRdnrZzmgYWun/xEyY65kIU/qnCyKbj9/ZXquuUX1ph/xbYzwOz ePy0PlcCh7pdzJXCewFxA0be11Ewl8wbXGTJcg4h4xtLXyVDvOpUA3JfOqjK1+0JZxU9AUzI3Wue VhnI7hFRSXO8BC+XjNaSmyovUt3MjDlMBfDrbplDIlofGLMxvckTy5h8QHC2Ol4RywU7y7j+pgYf 1niHS35wmh/x5OC9gmj2nl04wz+UENq0Btizxh7LyGojUGu+0Kk1K7VcLmtOThL2py+wj9AOs0kw 1/eGOT3MUGuG11ZfhSOWZsdr5xxw7c3gTiyl+jPOTYfDda5Y+pKXpKb4RIOkmehDoCcg8199UhbZ x0NlxRclZXQ1ajGW/GFC4GkT0Q9kcnj6jE/NbfhVSpkEc1aC4Urwb4Ht/aVVWy+KuYC4UxB3Bdcs zQrqE+n1NRnBTB2lOiNaaxGOXctpUkuvs27NYhUJNWJzyB9TKX6Qs+6ocgriqAtjj0CIu1IYOcqw ENV3clbhl5ZM0Rz7+XqeC6+WM6UFKFjnHCT5+4exe33au9FPqS7xO1nUKs0KCwqPRpZslW/s33Dx He2A88MeZ/oHIy1H6g1fdvLFxgYGMjwwgzNn73BRjsUBbCjnMrgA2NJRo2ZFx+MF4JeiqEklcAlQ Rcw5Jjd6kC/0L9lZmhU1MuokBx92ep53oETL0cd7Sv3sbIlo9v5cOEMJi7YqnZkLU1RQupJ8Zll8 VHI5SqazmLS2biUIcclEZPsjEksd8I0a3MILRJ0ajZzBQa0jX0UjvvBWHEzZrKOGhWclgGsfkzux lOrPRFuHw1W/Kn3JS7J0FZnoQ+CETYOMUF7PxFCP5Stmlegqpn41SnlsqMPqkbUeyg17EvJuxSaQ MROF9y16DMew9BCTCdESDsX2tmmbWnXuicEjecmCKaLHiUUwuJWVPL4++Yfck4MR2ELZN0Z9X4LL w/QtBgKqqSMfYJuuH6ou02uCKxarSiiJzSYhtO+WlbyD70/Ahg/FQiUXJsk79/Gdwsghhu/xrMIv TRGdmqgM+4mFcy6xtcDeDimXFW4wSJoVCwfh8SAGl3OCKLXMgiDziotYuJeFalCvijY1dfxfyCcE Vn+XjFa9LjGYNfyj4eQNgF//UJ58pFUu+QDZyVV2poi6nrhjqfSC2+KjoNjOolx8wUvRE9oxz5gs iPwsM7QWisbwuVIP0HD1kp6S5pZ0NIi96nLiS9Un0kysBrl8sWbqtFScVpPRbCOplPkK9x4hFl0p HYXprte2lFY+C7VVgfJWrFhy3k609kEvpbdmMf9wdEIL1ItPFMid7rlsb8oFiG86CiO/6emfNDAW pz6vvlCh/QomLRmtV0b6FQC/iSbfuZ2TtHQ/Pt4CW1lT1sNgD4culfz4SL6wxLcQrb9yern4GcfU dvZ9YUt04n9eC3xxwO/Pa9ou5e+wwGmLj2av1t/x1ru3Ea2/anoP2/V68+aRyjtysXuks0Bngc4C nQU6C3QWeJMF3gIY/LKUPJIAt9FKihodrkhaRaWvBK8rVPnAC81JqKT3A+O9SlQlX96n1fueukrH Nwf62izBMxfxzxfb/OXk9YpXrGdl+XohV4SsZPfblGex3l94uyGaO2WAc9lEXMrDdvOO0ZkzRZGt zSXrClN0Qa61wFsAg1dS8ipRX0Ol45oQzG06fgJX9HB/TtTMxHJNYE2lrwOvi7X58PPGJNTS++Gx VwV6IqjkyzTJl+McGVdd1FEV5S7+DmkxtynUqlA9izAfeMEtsu2P5okdixhagJMV61lZLsR8zoWy GF6rvIv1iEXYCmVqVoNhBrZFjtybXs+2jG2xJm2K/T5vO5wpymzlQmwu+e6OugVyuB+W+GBbUmAY 7oCYq75nT3l0ttgyWpIdx5fEwjBYoI7exO6Q9D5S1h/WBVnEdppQ6WL58bkjCPVvdX6Ti/pshxSC 1TF3TqUE3OfgdVh3RDUu0SNjDRjLHpBKUx/38qTxFg2g3a8YiphHR8bdPikOSRLA1tMcs2UqcdSW BCpXZIFfqMm7LUccnSyb8WHxyyUxDiMrtZwXJUu2GDwQQXUlJ3fM7HbW18Y5DYLsRhyQuT9EC4gJ MFTyZ7qqrJZ3ouL1NtcUpeF9KuUkxQA6PyytkTpbm0AvXsuRWYCXc2Om7hf7wwoUrcG9t1HyYOQY 2AOF9/PPVo4LT8gKo5XlkPCsnJru3L+IHDM/b8E8ggy6AmwnWXUWlLfiDbl2mpcCWIUwFkVhWPzl X5b94aM45VZald5IWpnzDit+b2wHcVu+VKu1NFsZLfqu/dnyxAJmyRdtYtuW7qEKJ9mkl+zfNHa7 +n39bYX7PWx+ecCGXj36k7X3XaaxpDVW9is5Y9RicVslRLgSJksqHXdm2QZw7JUDXMIT50C5bLH0 ajboj6ZYcz+4WyGYbBsXf27B3P3hr2OVYk6g7DtzZsCfJnpkpM+eu8z0uLnFjvBa0tDSNUARWUn6 oz+ZuIX/2AMohSWHW0rqNDxGZHnUjrpZywK/zzfSvDzNoxOOnNtywnMij/IwscX++X9FLpPIZWX1 39wh4TywQSbZTUMqICy1wEYE7LAoyZ/YCXAb2UVz1qmb7H5y0MW32Ry12e7FZ9rgVk0drOE3SUFz sBa9H/7Lf/NP0YHW3gs3+t24LbcoK+0CveiMhorHgvP03W6vKN2JP/y2vhdbcu/JoXgwcozpv3XO PVz9tvHbUvDYC/hpqfWkMFpZboWOfiak0TYzUvlfipIeuxDSKIXuqmZF2BrjLey7BdJhMgco4OYO fZTd8xgnl/KlsVormxXvA8yC4T3ro6KUXVVYvCtUKtVw7zs6a4L7KcPwz0+o0CbMoFfgI3D6EpJG V8x4dOaKrBWTbnBTLClhkjzGjEoXZ6XtsbJYgiqVM3Qkbu7WBw5Sek87QEZxwmalBXOnhWtU4wS6 W5fokV4PiWWyZneb/aXx8/9bSxp6bv0qFDHS5PQEqlr/FvyZwwJD7iFklthJqZwdtrGIeqd2q2ZB lk1e//ikjA4gXen3ItQec4vT+b4SRmoq9aJ/5EyELODnPndpMowIKporAJNMQrY+5jwrdEwH96iu ZVsZUdUsoTcz1ILYrweJSa9VokvzrupOzTaXXfY3M5nTIG+/dy/5Z6YoMYDmh7JR8ZGbQBjj+Hln TltBhpq06G9BQ/0Tv+QylV10hwcUutETuA3QR1JX8QfJX6pd+vavHB0Yz9MMW/UEyE8Lo6VO0ARA f0P+jqCKke52kQR8AKTRK29Go2BX0jXVSaF7XdwCYLOS2Jv/IdKn93x43cKS4/nrCdOqN9jVANCB 7HduzRdGWq/WYg01bjYrgzuyobgHny5ase01hcUnpRK7v/d9ndThfsowrBAOo8QVtEZzRXPgKGw1 lpQw+Yld9CfWGjjYioF7EGelczZPpYukl6ccnwqVCD0UbGZfo3zJbvdWzF1oDT32x8lhilLgYY0e 6dXAAEFjd1dqwD0mzQ3E1G4sub5A+QqfV1IAZpkpJGkYtjGP2qBG7Eg1szpFz4QWGNKCstPrC4BR CIx8RUVA6+Bhc949sKU7v5YqHcRiRsJkMS+RgIhCjcDmN+Ht6GglT7jw4d1UtjmDPIl/Ipdzefdm m5eoyb+P8Im/kfSLoz+cPXBQBd3RiHDTt/oq6roDGs0BmCrOaa9jV0rg5K1fxUWj1FX8wVy9fDB2 jMhEVU9IC+PRpU7HOzeD4ZD/Mf3xVv3PhzT6cuqMJvkZlYK00MGZbweEoV042HBMXviltQlhjuwS zBZ8vXqP1vpSvjRVa7GGGj+VT8tmpZRdU1ii5BSxR/e+n1M2r+gb3T0u1qt7wQyq++kMJOzGWSSs b1+uVsv5ywJViB0VHp0VtKgUaOjGWLRCYfj+QpoVe7lG8BT6rvRqmwRTCqIVZ1bCLYd3V/MiDrTx DIueQvDY/8cPUOutVo/U9i7k5JS3avRIrw/n6yyW0261/L//GlVSnrTwuifMY5fRRQlxrR6uZJni +JkSfR715qASmrIgqiVOMS0wpKWIjv1yDJ360/vpTX/K74CUKikYzeaxX6tIQDzo7axCaDQzdZnw xZT1uCqGc29hXrGncOpk1iCHUXSlzdn2je7n3MyxWi1eXhabT7FBCgyguQ1iJP5r8gACzpjDeRcL 6RyZwEp9WNJQ/7p00Sh1pVn8ldK3hdxl7zJUCDAsTUU+LoxJs9IAHa1hLSMLy6sHRw927abvrTHL 5PDKV0p6lGovdjUbtc9+q9gN5u6HY/TNdBkDJ1QHGAOOOdRqz5fmas3r4FQPHbbgfhXbXlNYvMRK 7P7e93TSDverEA4tcRUene+/Rf6gwauxoNClhElOnGZUOsnKlIIosZByie73/GW5q7cv3l2hgEwf uWalBXOXICJTTmCl1pLPjvQmjztQnB8xJTOI6meZxQWrCu/xTms028OnPzUkTYt8WcWFcVNIiFm1 zJS4WeEEchL1Vvp+i2oW+DGR5WrlbxkduxaCx0eH5FEmayphTFuVaLPoOqHKj4X1Ro+oZOOi6lJq D6rafNyuyFTbcL49HNZPcJ5sEsynRSp5GLbJnRpsXkVNqvb4t4IBZLMifojb7tXwvUwWWaKq7MoK ahVdjpiG+mdW+yOQP/mSBekcP8eeWfqDv1L6duwYHjhZ9YSyMLqxWAt0VOrnFoKoU6wV0uiVr5R0 y3fY10x6Xs+fl9t6kfd5xewSHpf2JOVxTAbSkhKmli/2cEu1ZjpYUD++xgVTtWJb3L1YWExkLXa7 9139bYf7IT9zwqFPXYVHZ9UjZwiTdyu1WDhdbIcnTBZUugoF0VPpfuGLkwIQqgq6cbTTFh9y4sS9 uGMz5u4Pf+PV5py/TJrB7TkfW+PC4TW84DZ75B069qy3DuwmcyaYNRg/8AXBPk8avdQmwXIoYhQd EuLqT7qucGuLTIlEQYE8ak1CQxYk2eS1T0/qPsAeIL9QpkcRJkqChEiQgJ4ISqC0jUYlpeHdirM8 HrYyi7P5HQfXvf5ghKyykQvlR9H5vHubzZlHBWpSVNd/Cgyg90PaQN7eTjnNrnWgOE9F4KlAreKd SIC1koaKflBOYoxSV/pD5Or5g4ljGHDy/5zf2yqcAac1x08neYuRFkYry8REs5zpMZtrEiWd4M3O 3BqH/hAZQhJmHCNVlaUaLZDGoHxZ0qNUi1h2FVqKvOpk/7KhD4s6ZG7Bo1Qq+WKP1TCbzhSmgw/K 4VgGp62UMgl+obB4kZVK1d/73k6wns/WiFZVF/iZjpDz+yVBLg/hfzfEAnZbmFiTwKVMKJApCI29 4HeclCy7twu8TI8s7VYm7R3K6yOl8FhU/W5DFsQPNp3XBaah28KUSECsHs0yPpVW/to8Tsf3Ogl2 wOhv+NjwYbj0ybfavA01KSmMtTa3OeFVoK12S6NHi5do0IBaLSXjKVsunkts/V36dhTcjN7gCWVh tGclEfYj/gsLXJWRTODlMotQWUmP4/rY8zRfEtlJjiV3rvjRYNvsScnwukE+K/Ysmu7n92aBr02P /N7s4/V9CxLQP1Q5OW34dWMdHOJdRrJQqxL8a13iYAqHfiXkUqQdAvSShbr7nQV+cgt09MirHOBt SMBWkce98BH5nfJv5jhtV6ttsh/um1GtU6SzQGeBzgKdBToLdBboLNBZoN0CBZ+tPfgXvfsV0XAV dt9VSfs8c33FBDampkWHJmSfyXqv0ez58Pd8WM3n86V+8D5cvnjWojxe6ZdEx9bwLbF9XEp9JBWK I2hBWCw5X12xdMqLwYkl6k1KmnH2n7bVxZkQWr0eR/wR56Z8JOu9zhCJyE8/nGaZR9D9JhVhik1K iSWMa3cU0KGtF0qCXPejEeh33eMM5dX7emi40wKz7W/mJWIR0bvM9TsksNn63HVW5+8Zsq8pje+D TFY0ORNNgJcwo0DKqoSqXWpWHkuEBJOSEh0bMZ414eHae90jSCjOSoojFkXLsrne2LiLxUP1Cy5R Ff5kPTyueuP8B9l1U64Afp9jN8bXfKPIwfc7Q3MkXJD2oTTL5qi+4zsZvg+LOxwkUBe9lFS0FIYW yIHeBoFrJ6BDXDcEHUCB4nQEOnq6IJ8rYxFpGViyBMRlyvMhp56bfw/qYUFgFQ2XRp0nX9SIxNrK Naz4wFU8m7AQBdF5Iv2jsnY3VaxGUyR50hXKJDCXyIT3CaJi0GuOvYHTOTLrugT6B3kSQyk94w/X kTrJ/RL3lzwe/WBG4A0DoCt+o2KSBGwk0W3p5hLybJyhDjKpMiuZ4iILqU+UD6pwMfPUlsKmOmig OFK9UlE+yJMzD0UUT0Z4EtYlKW5pWK4wL1fYpCC4Ju5xLpWxmD+P4ihl0HFIIDHmH0Ixyd2gXsyu dInSdd1QttHxTE+srzbcJVfhYotxQRdVS9Ei1VLTRBCVGFwOtpc7kZC5nzwdnCH4Db9Yrd4tqxFZ 6PZ6ISSp9Yzryd9Fs8xzAbFGUN/WOL+rmyW+z61sYX+vhprMUWz8vLscIAdaygkLkmO4+INjRaLG 00v4dzCZ2KaVkaznKUCFJsjD3LC1tiQHVtmD0f4CIAH3sXpeGjUZChqulZH4IHv9RJc81bhYshCP 60fbEcBU+j3mmppMsboEA+7FYMO7xU6gQ8b5PxBA5Cnob06gasN/D6gM3NGfIK0l2FP2jFgYrL56 aljTG3kR9/CIJxTpdRAGHwtWRXmfAD3MQyZrrEXwJx02RLaMYdd2rrxPls9l7PfJzYh+9ebJR3pz +8ymuqa8l6Yntp2Tm2r/2jwZ4FOH8Wz1Ipivxiale4BFaQWhN7hlx8Af2AER7C6+Kts8B+ZgwHIy 7DJQKd2GXyfBhir0w0OFLemNAF/KWKYuUdqs/COcre54XtXYOLqv/+/ByMjwm+bYZamJ7Y+4wmYT RnBVuYslePdT9SJn+E9o8BwVnzhTulPVpD5dLSfvoVkWFMq4cEVVTUu0382tCr5P9kY1oiZrMDTs LQW/K0mz+iQyTnov6H+THHhzh6Kwn4PQ03tEc3JeY64C7UUFVBhkuboIdSC2/WYgyoryNTKeV48+ lqLhKlFHyQ/Dg1qqmaKEhcje+PB+Bd33C+zqTUcrNcUKCc5cB5JXew8rzh1uwF8lYZIYLt0XSaIg ocHheFsC7TkpGto8He5GQ+AEfWYhiNunJtYYpbg/ExD+Cqb1lji34wp5Sj0r6bVmxbnECd/7vpmx Lj2t0TO5Wf7q2AIlMjHeZq5K7teEKErb6pQP2sBVSOg5nCtmbPAiwDxj5SNZ/lQMQidnrvVvNxx1 nNVKTV6U2q3iHtyUPXpkVu6ehwPFS2qEH0Bx9NtISRRx5PwjdUfuaLaSqtrErvQUnTbHK43jXKgR vynWS0rNRYJoBn5skNCYg84Z4JpusAylQ+1EL3rmusK91E8svFcdb6dZNuWC1rRxcb5KgW87UAXf J6OVFtRkCUPj3Eu85RlJDhnHQTGaFZ2fwR1xPGUEuYyugAqD0axZqZEDS+Wl+9HLyHhePa+DV68S dZT8oAUStFs+3N2OR9JdlA37ubQ99y848Be9LmlWGhXTIV5qrk9Exxh+8LxSLIkQzCYgmPHbQdpV Nf3elkB7CrW5vILo3YymTwsOQ6rNChJFXB8sYD0EL8CfxJBDzsiRBIUkZBmRNitCtEBAL8RnSixN xiaYVHEtDgI7JQvlgxyrQESH1Iw1nGkcnSofiQqnqZFd/aMXm7wosZv4VeYe+wWthJptfHu/5P76 6MAc1uP9dDwiwkFGvky4bN5HIDRtYmQyFNWCldwJRquyJZ1/smVMndCl1B5vcTyvrjeOuZCgYkv8 ZlQP+OwuS7EXi5PL5e4ooD97nVfkoG9N1P3EWpa00qRx1K3n76BZVnMBX8Bpjef7vFnB94nNtbjD WzgojVGTNRiad6pgA804T3NVd5KmxxwPYV09U4klCDJnqJEDS+WlJsnJeF49f+JduhJ1lPygRXuq NbF74mgedPFRvVlpVMzro8b5xLUFaX2I0nDe4A3s7BEVEaHB8eHT5U+8wEoCw5Ocu8fnau+mfLXL 4QraAkOpOLCnJk3KYpRxQYSekdlp/QqFQNYyIm9WmBzXrJzWi+V2/0dtQEtkojYrS6l3rf7MlY90 sohKM9ZwpqXykahw6m3rT3BPzytGLu0mA4TcPfhiBWDph8kQjUeY2ETR4DQy1hw8zVdLDF3ZBMT2 13htPpBKmlmCwt4HKvzDSL2QHLvortjPFsfzkXkhXklxgAK/aRYTjV1XoSzFXizmfjmpNZnBDCsM 242n5DqxpmFrDjpngEkxWhk96lc+XFfNa4sYfRJC7K1nb6VZNuVC3LFqjfB7ulnB91lmIRklQvBX FlWt1uRjENpvN3JgSDlHwf2njTCCpEPl5xCirHQ5XsYS1ZoMI0A/Gb9Pn1HDHTeckwfeuKJ8jYyn Uw2YUfI6+BJXiTpKvk+OlN881YU0dmDwpS1oKBCkZLSiBeT2RT4u5Oa1Kvo448gMkvCXzkt+ckNR YK8LmdXP5xtRIsz+hUqVHPS2lbj0BZCbG5ErKdgzsobPuPNh/TJPWjYpMuPV4QzaEtSVSTBWCGl6 rbZ3ox5CqpUsul+SBDhnnU+jlcjEM/FQKm3P90E3d58oJFHeZ5bvruhEXGrGihdVlEdNunhZ2doJ leyrHX+C62rwdi8yu1XcA18AwedU2FoKj9EY12wkkN7PpDh6J6d7yJeS9FUOX15E2RqSYxedF9lP aJc6XptxLLF4qIrfrPh8pRTjaTmuK3fKZE7dzyQEZ9BiMnxE8Vw/8XM9qM8jbX2z0gawDVL5Ru4J TgtXlD4XRNGHW2iW7bkQS/4hzgt8X0R4Q6bkqMkaDM2TA8Mw3rh2//Fv3cgd3juQ9w7MSjeWZ/9B +qtFLMGyAehXkgNR/Er2YEnG8+r9oUDD1RKYz19Rl1qqJUVruevqQ2ho6D1MXQxjpjGClYqVEryf R/jBG33JAgnqyeXbvbclkBrrsX8Yc4aFx418hfAq3J8WRhtMOVGHRxMFiRj44HKRXjcd4R1A2yCN f/oEnqef6cqRiZDmX77zg5oDlOVCeacJ/rDtkC+hxBRHZ8aaF5XKHzk5ZfMqKlgqWy5K8Sc4txws HDgqRFF6c/fIPh8Zis9HUBy9PSv8w0g9JEff2Ul4dmBcoji8cl2j1PHajOMTS0ORv5zjN81iKFM+ uyulWG1+ZbnDi9fS/ZyEyBnCag0iNlk8RVvXLtAOBGNK6rI3xSYr/fs2mmV7LqSSv/tf1+D7Sipa BYZmELvIIpVL0d38tIzFh8ByQH8eR92sfEHGa9WlJWofL07iqOPr6TmUbVmrWCiWPnxK3qowsB9c IKCsdpDPLKZP8dd7E1iSCbmWOY61iItrzwK7ONwmYy9klF6/kF4EQohqdKViXJyaBq2ECerYmeRu lqAyKzPlQ+1nYi7+vc6LSvfglSxdGpcEzRSvacGIc7vn4QrT5QFaf2eOd51x2vCbcWzNpdiFKjMr ftyfZznor6cndJn0yhf8Jd4f5eDn5cIXVPSjRX+j+L7rkvldK18mcc35Liwy4oexiuOIdVPsQb/E ZPIi1Fe5cFi9vGy+Xtn8KmnKIjkvn/k56O5AZ6pwvCuMw5EIjnyNfdWeP1gprqbxZ7z4LeL7rs6H 71r5NJVAbSxXjfX1Ybteb37EVSOpEbpf35oF3uV4b8Rv/kCl+FvLvk6fzgKdBToLdBboLNBZILaA oe0+bTdchV/BvsWh/bmx4PDY2xgKXsLnnVyrp4vltN3E8D78/Ai1jcX3RmUaU17KKa80Pvy+GzXa oUl6E7fw9bAha96eTf+at/wOc1RtCUyV7H51Fugs8CEWMF7E+N//r5hXBWjxOhCfZ8H9O4EUNlQm H6Jhg5ACT9cQTi9nCL4jQBD83GrrM5dvehbfdUa7LJArwdO1TBXJRgS9LO6KEBXaoX/qbXBFW2tU Uc97y5sxkl6X6ORtIFNJ4PRiTnvyZxRRd9pZ4CeyQLK2JvxI8XdYwGBdQzuVoCkkDUs3QdrhzmJb OmggPn2cMsG7KIzrWXB+PyyD1MB9uQRh0JH4Vx6fh6cTedxvBwRd8X0mS52LVLa5AUGjP5N4o4Uf wbRmQSLmYvliLAgxo1FeDqZjSgMekCHiI4UWYrlOxtU0ySHvTswy7POtWVAlZ0oaMDRD8xFUCCYh l+67Td9BL3GSBK5Yz9wkXYvpzeRlLx6Vqee9RWPIHRXoQEaoK6POR4czDf6b+VUGMjWts1TbZV2P ejgDiZlQUpNMx9pgI3/ac93fzgI/lQW4zMO+wS27UJ+2YXU3djMIi4+bkmzzNTb1gLAnDQeXeuBw 2yhsqMLlH8SYcMV7xKzTsPz3Nl3LlLDglHB73gV+Xl/2U7iFJU6ISvAbGXD13mp1ybzPxdNBSAn6 C26hzYrvs8r2f2lW8nhPrGZH3ADpdrdxERd3RQF4VwEJeiYnrLDAhrypLKaRNN+8YFlSaoSM+lhC C71hKWFIrmaZHf/8n4h4224Z0ihnNSW5CREtkRyXaIdoPkr25qXMlXSdls/z/TkAS7GZQg+fKGy1 qDkqt5vIcftLErXuv8iJpl6a7xUgljLVLm4kR7e8uSiQfDTHRaZXyKteQHfSWeCnsMCORB7ZCsGd 3Sh9FRYfO2nWC3V7waSLnkPSfDfeTuLAit3bvWCiy+0ZN/sGFhw21GMXW5U0iI1VqYQDd/sLimF1 Px4TmmcHdftMPF0F9GfSORbz3F9XwRBCcsD1PN7zBiEftmBq+h24B6R/tvwENMdYacAHDvHczqyA I1hy63cVD9hAfWRrlUILWWemXM04O1zeWU6F1IWzihGkXk3QfIpzfCTq+fQ06ftNxyKGHZVhyt5s z9w1Uh3viKmo572l6qiwc/9xtTscfoEvadTSTLBZqQAhDR8UEi3UlCxr/F1J/o2SCSGf/bEy06Xn UJIQvJDupLPAj28B6Ug/7M4b1HSjp3ON6FhtVtCVziFpvhKwE87DABXFn333TSsFJ+7XgDaOx+PR 6HZ98nNfDu4Ro/+E3qCkwVTC8fyivfn+cPYg3cYoqz4bT8eppgz0F8RLcp7WO05h4Z81STLa3S3j BVlr+Lhe3Q37Q5JKNjtgxgUCU8j3RnZGIz/keTadDAcctBA1z3gbqY8ltFAnwah2JTss7+xWSF18 VlXyetqhKJzBFRsytyFdFfXMW5octX/HkY288FLSI7b7j3XszE3fyAcetCmpa87l4kS3ZL1OgunI SdpoAo3LTLccTKR2PzoL/FQWwHjl5vZhqhNQNaJjE4Ewh6T5SsBO4mYF3UUevNVfHLYPt7ez2ez2 FlNovmhHzYpxC4We6pqVRMIRu7MPu83y8f4WlUXSSf4IPF0J+gsuIalT7KGkiPgmNiu1eA+oRm/G o/7N42aNGfcReLTjZ9R6pfysWWkC06kRfOCgVQEtDJVbJTsIRBLlZbpSK8ogS8/alEQIlS/tvgO5 5LRDGdJmcMUmjGQ9Xap5op55S9VR/bD6tMI40RBbGDPqlGzBTXXNSry1s5Jqb5jY7M68tUwPlvdP diedBX4yC9hXeCYC96yw+KQ0NRIIg7Ws+vLdY9ejk+oFsy6YiV4SFDjeJK+IraKwrmONNEg4cCLh tMYV/QLg9hnAvoCo+gA8nXsVwr2HG6HSuRZNk+qTaT+1WanGC1PgLpKM1ypzzBFxzdjeXrUk8n2V pUZrB9P5wN74JbTQd6fL7NA3X3zWiKAYnuVwxZoR4nh9vYpEzfChMXKZ0vb9tQJXrGau1yeWn6rn Exq8hZ8OSdGj0eP8mEtv8rg7HpePmOYdIAcrQEhxOQGZmvxaqu2ewtDcmoSoVc0ZpDohiZdZYHLO F6mze1ndSWeBH9wCXF3jcHMy/UOGiBwjaQvwEbuZVI6YQ8D7WpmQqfIYpeuLrh/rUtc/HNwTIYin SQjkcfO0jjuHsKwHA9r8BiqoicxSIPjgVqbtKxKijw/2+f1Ef1yHhZRq0OmEP0pHNBnn+cy9P+kP R1A+WT/MZmUQjVao2z0SVYsXtsDrAuWa7tlTH8owoSKfVaJxv2E0vBFwyvXIxcObmBNrPFoVhw9s CvM7g05j2uwFHXzUezQ+DmsH3ZVIDuCVGKUicxZHW9PrJX4E7RCzaGZHz94sM7c5XUE9r5b3Fk5W ZY4qZnHkQHwGUsaxvT4/WOJYxzk3FWmUQMqllDgqWRPiZh5FZEKuXVn7lRXDMdI6hGN48udfYjK/ l9KddBb4GSxw5DtomzFwCS7xbhcJhI2mkmoNxQ2Ut2SY0vgAbyQUwSYJNYqgSi31r8bGJcDJHEsI xTvypetw6YqzK+OFpMvyo/XJV8TsRFahha2PO0hlaIai0JeV1MBttEOREcnEaZK56a3il1OvuO4u NBj8+DgZP2oHhmtR3AeL8Yy4TJLl0C8Tfm2q7bGKDhe0tie7v50FfkQLbDlzwVVWedH6wMS+bStc LeLPl1CT2l2LLHAFPzAK/e2fyhcbMVThsPdm+vwF3fvbt0WnYWeBr2yB037VjDf8IF3O2Nb3eeX6 8yV8UFI6Md+PBY67zQrszp3fYvT9qN5p2lmgs0Bngc4CnQU6C3QW6CzQWaCzQGeBzgKdBToLdBbo LNBZoLNAZ4HOAp0FOgt0Fugs0Fmgs0Bngc4CnQU6C3QW6CzQWaCzQGeBzgKdBToLdBboLNBZoLNA Z4HOAp0FOgt0Fugs0Fmgs0Bngc4CnQU6C3QW6CzQWaCzQGeBzgKdBToLdBboLNBZoLNAZ4HOAp0F Ogt0Fugs0Fmgs0Bngc4CnQU6C3QW6CzQWaCzQGeBzgKdBToLdBboLNBZ4Me0wGm72bwbXr/f4tnr v9D1bVjwtN/u+KlFp7z9/EjlSpmn/Wa7v9pSx+1md/0HBRDbZrvbbbf7i19LM8Us44qILMBHWaNd t/NutVjzE8xf7jgfkd0ZIf+0277BvB+u2367PdRzt8iOEDfKaa5zs5zw2OeewW8Z73m9WF7vvvVI iyIA37jssXVZ3dVv2gLH5YxfO5ot36Xl8RaflV9kZfZdkr7iQ8cFPnE+Pbw65Y9LfBH4Nvsc8meq Y1EEMRrLBUudN+M+v12LD80jU+ZX68RPqPdGI/xzuwhR1s5MMcu4IiILcH4ewymu1qAWl15r0+20 wsdJ+dXmL3Ds57f9IT9Rt5r1e8OnOIbT+g4fI15f3cbHz37E+R7fz5vUSs0JnzbujbZRHD4V5+0j imn44DXDNMqJBHzuqXwvG1/YPD8OPrekl0WAJW/6vprnc9PVPf8lLXB+QmXET36P4lJ23O93+0O1 2J2Ph91ud3C9Yv0G/T58vhcfbbXH/FnyCD9gHDpqPnhLjEj+CQ85sfwqrBrEP+vkB6n+vl3yQSnq /Ho67PaoylT5Az+D3pvFVdtZvjh8PMAIdhmXzvhg7n5/dDKPe5jBdd+ok6VaPinso6AmJ8g5nI4r VGU+lhOe3hcdVnyiHTnxDKn81DI+wn6GrdNg9QdXs5v+5OF+1HOfsH/Ft8/0Qf12sqSf2h/Oadr9 x+7VZKqupHqPDsPkZWfXk3jVPkyX2odq7uJxUpybhW4m8vX0OOzd3K30N7TLhFB+LBYf80VQ6q+N M1WKTUgB7hbCHSG8z0b29DDojZ+3ZwS33IQR1KomMtyiMueji1dv85IdomXIkTOdgddMsoZLNeE1 cVE/JXBiRkjQk6ba/HTzMOwNH4MrhVS87l4myN3jK5NhwYMcMVVZYCO/ly9dN6mXqYGwCAkjIaWr u5te/w7FAPnYm85VQvhXs82S82qegZyISkS1CFAGvnZ9M1sw9tKALYVLohfL+fFT5OFyF7pDh9gn xZ1ooqisJl7N5+glWYkTcd0/b7LAccF6bLtBr8HqkMM9epB69Ccb82CRenq5Hdi9Hr4XjsKLnuDt H5d44m4F10MjhW7gAx46b+6l31U8sn+BhKetFJ0DzvvzQ0uMLjEoUr0JXfowR22HR3C6wzVEunmC 7u64X0bTKedNk1Z/Wt5KSRHll5VmBd5uInv9yROSo2M6uXh7OO/uIhMh3ev7gRY9qMXzwcNfXBSv yxAUnU0Wz/PuxT89uH2J6xA8Ksdw9esyGLoHU7PubX4Q6t2NH9brxwlz4by9Der3Bqi32Ui5498/ /as47WWzchTN//bOxT9bIrm5wrF9BpOJqTpa01vy3Ex0w307pJ0dbeTnNs7EFXL3NJ95I908bWC2 1wVHZO4YTKYcmvGQSE+bqU/h6B7PL8wp7ld/gp/4Y/zICOFOfQ7PNxg19AfuyfETb+0XaP3l6A8Q QzJe28+9ToMZR4U+FjwwmEmVW2iCfIvSMkb+0MK928Pr6XlqloMn03VZfKxjAPFB/v3quIgzdYj2 xcs5PJgtev3pJvYnRuR6Mms0rr3ZoaJeqUZk6tEjGjqdyjjMYdOZtuhUDjm9RBm3Y0izSzGh3eQY zKU4lkVAH8e/K/N4hO9P9PPQ+yg5Ewxky8J1es3DxB7+8J//FJyhd/Oyo0USHaSVLL0aV3x+DG7n kSG9vt3JVRbYsL94j6BbeI9YW+YHtN4+3I2GD/EExQl1Xf9FXGX3jBKJouFqZimnqPq2aFV6vSHK 5xqdnMkLsrt4RPqoMufGvtng4VfOSDTEaIkQd53Ab+naWtj3mBMYbT4946cquXvBvVFcrJq0suFJ Y7PCHtqAxQTlBDXJ3VrHGv3H1e5wOFLt3lQaXJRoxPl0PugoAw/socR0vtcoDpy46D0y6OlpglEh mhV2ntFDY8qObDvupS7mTxys/28WqDJot97oASZ93TypqVsflKf1HxbDmxkL02mNGpV1gkgb3i32 +/1f3NDMpT3EaBIy40BKqTDtc3MHR8AUDROIJJzX0BJtUJv/WBTyl1Wo1O34deDUzxPnfpa3N/3b JXvmPVRKLNnMVfYoDoizd3OL4ZM0an1alebC/MyJnZkxW3/tbNCkzBHcgoovqOVGD5xp4dwnxy8H VuuYg5Jbw3vekq74Qp7qTZ7ZvqyYtZIX+CHHBoaQMvK6eYDIzfnA3sfoAX5yWDAFm3NFk8MCsWnl Jr6xONB64+ffNg/9HlsZHItpX0zBntJML2mUPhWWfNhIJ8qQRJVzlmnMRw4rKT9uB8+7J2i1hhWP C2h6t9qXhjpV1DjS1L3bzRFTBPQTVckcQzXDv0c4mrbF3trSVeg/b5EVe/GRlczdZUXASxCzD+5Z o+wXWha2VHEi04DSR0UdUhSuSpjIw//0yLZZ7MqEwLCmA66dXtDkNBRDztaOOGv6unseDrSAB1W7 s6stsIfPwPHu7u9vx/QkKaqsH3DcjKZPC5av+Djtlg93t+ORdEiYO652Ytnp3+02j/3+EO3Tw3p7 h1HMkhVz8QjKIGsK92oDHZpTW4wu9vMaXvey29z2+6NhH33FNRrE8bN7MTQYDvkftJaaxDRu0soK SGOzgspt9Kgz3CeUnQE6i6iN+3dScUnTNpV2gS0DO4ToeUKdwcPmvEOFM0RB1ig+Rd1FqQ1mR3mb AOsOedDmce80VPK+fXHVyKUHLcn4yyp54tTjBNQtmxXE9Cz9gSztIUaTUATg649MYVTs2iJIYPQu cLgZxatyE8FPK2TXk/Qk8Uuazl5/eLvYouxT1FCGFbi1Z3rQzV4hCY8yyJ2jEpZXSKc1R8QbHdn1 h+PxaDRGpcRXAOIYU6RYnI0nGAugvkE/CXUsWpyXg/NDuSXZd7/esgV3HfIzezv6IB/msX9hhiHH XqTzIlZ90mlCkTn/xM4AkhFrQvXNW0QKm2mm7rx/eZhB5aEMl4b3K185SzD+41Oh5nqQ5PNlRx9j EJODFoex9kazp/yNvnjR8iyjHsytSTcmU6+ihmSNmlrcY7ASv5f2MRmt4Nn54/10POIkOudsxe2p Gw+0evA9LSB6xRUBuav/xAVNM33JxKASseIhw7qscFXCRB6OjN4snmfTiRp2gIY2LoZrmfGuFcM9 +wY4+uPb+2Vuykjp7rTVAuiowIjT2d3dDP/fYSTd59wpZ0vXi5e7KUsoi6E/pHc3mMye5qvVM+cR fLMibn8zGd+g74dM7/Pt8ZDeWHmE2Q7Rs0dkImvgthh91Jwf6A8m4/7NbLNGN2+ICNDhlHJ387Rc r5bL1Wo5f1n4yVY+ygJS0SqrOe1niCz29vsbdGE2cRiOmFBXyyG1FsuaNGHT++mN2DBuVrTWhS7O n1FsRvdzaLxarRYvL4uN1MoqTuqBBeymJ1IaXdRS2BsfDLqz6+vVYzfYNSs3+vrdEnLlaAW1F+v/ LF42K2IBk4boTWCL/0RKagL1BfRxt8G6qONuOeNkDsatKkqrotcX1PTThbQgY6lWOdbQVSJb9ksf TrRV/2GB/Md/Lw8Pj+sD2gS+UEGE7ILK9CmG0pCESUK8LUC7y1FPcQtXNF14cCUS6J56HHfrzR5T 7y/3aCfoEjIuc+0Opqgos6IJX1Fp/womWi1WB6zK4BD1Vw55B9OX5Xq3YWsFxUIjYnH6VJw4pTzW kTgnA9lOiZz/5y+b1Xp/Om7mlGe9dHsew0CEfUCFLZ2Kinq/lWpIXLQPj9NyPJYOvJorebfC0Uqv P7pHdbDkcgKMDSN/4KDSmpW0CKhk+RcFbfysUZ0wskBry6Eo5m1DgWYNkRWuShgpL+rhG3gFPOTu cbFe4W0j+j8665g0bTWvlhcraJEeJkP1w0jR7vRqC7B6HD764NItHCz+DrUfOx7sNMoQ0geQ3NGG QCZ/otEKmgYOXllezlJsUQieOfhmPyF7hPIW8vJC+5ziimmM5/0iayDQQMn8V18KlEQVmq3bF44s tmjpEBfq5HA0aJVOBMVlQR9FR0vnkY6bZ3jY/QaTYNIoyG3WZr0R3jngbQf7VpJStJWoLnDIlJeV L3mRNFug4BwecdtG373JEwyMvh7qk2TSg5MV/Sc0NFJMOIdDG2rU7J02Pqh6q3rMieF8ezisn/CE ToK5uTVWbSrNWoEoIpURBxg/oVBX4pVBEAdEFpinfMvmXlSlualys3+jeLkcqH/HxvU4hwHvVp/E /Jzc3smbjrvlgXWFvLPzYw0Ex0Tszcy9ObrnG5njM5rUPlp51ngy00gfdhUX84Jt6xo1KV+LV25J h3ww3x22C741QNvhtRZP7j1zeMVRDyr2DXMUE4BoeTncxpBWcq2XakIle9MXyBGfn+z2mLbFgi7O +2njuOC7TFqMXidNoUXqU/HqGlDe4FBugploJ2cH8dr328/h/64CNwnnF0y90gdk9EqbZ+pV1GBc wyekE8dhs5ivZDwnrzIxu2uS3XhzLGPgzROirjcr6FhCgbQIBBlsu/tT9BbwihSKPmxOMmBE4WLk bPIww4zTtHBVwsTuxN4CDa7vSvhuUabRps+Yy97wVWdDMWQHZiRTqaIzxmvnw3q+iKfVg+bdWd0C pzUMfJv4yRrFZfK8fBjTFXncTOKJXhQf/y5sOMbTWAprUx+oATgJLlW9jLWd5MojVOe8fYJ4eJHo ts9jPC2hQb68VuaHOSWu5XrsPH/7ggLqjtncdbJ8kqtasTKUoRZKqKsJbeSuD9Lb7RjJ3Ls8whfu chweJzIdgjCDW5cIdOdmKCNulsCieN2+oGG1Q6Z80WZ6Aw+mbF/Ccd6iXkQlu9hznOWaFfSuRb22 B4MInJ3md8hJiBmMIIWjlVhaknbUhD4ilWGan+eyPAP2KeNFd5G1KOo4Z0mewpgysV/kpsrN/uWs kVsuW8o/bZ99Btw+rfEohl1sQRijG2vgVBsyXFyzWpMDHssa6fQsGTT7wwJu+sipfj9dyXqeE4/i /3aLTS2fez0+yWv0vpSA5LWX3WI0/fFyf3pGLg5kHpMFxeVjoQkrTEvL8GV7YvMkublET1qOwQgn aFY4ERc3ZCEVSzR3Lvk6eMTkoZeT+L/0r5gOO9ix11IpV0r1CjVoapuYlR6FzOBJ32as88ImOyxF 6A/haDJ7QH9wxQR9D13mVxYBkyBDwp6rbcby/otZ4NeAwM6SKwgfF65KmMjDsZDASdTskZduh9Wj ltgBFGWzgk5dXgyzl/hwGulLZC211707ebMFzkccWufnz/KGdmXyO42/y0fkVW8ycZ3GuL/tD/Jm pVE8bpwa1W17qvEeCqOsfsGy5sYwqcKNwXgDa6oLQaJx1Y5Y1Vq97qJoftAF2DxOx9IUor+H/q9/ SeFuv+UPVm364Bfj9SFxcoVxOCVl/Qo+WsinjBB9LL16XhjZL0SvBq9dxJqo8YM0S8cVRivunUIc kpE4peT9+AoKxot4JWyhiSauzFQJWF6OI8Rq2CtsEKmVPHzeorlNm6qKN16hBtcSJEMViwaJb3dX F7BiExPhNErs0JSg8Iw+1eQg5zRTTqvJaKajDpkiw+y9O0qvQ4KiFcgWrvv7rVvgiLcVOKZhT0Sh MXqrz6vEz4ogX/QCp+7s7ckXjehLCD9tuPys15f3qL1JOiv4JSJ8p0zM2YzcC+93Svjwx+RdMExH +01kvXFjFMU20saQv9MNGV+wZx7NW71PlTPWSOi00vue/wae2mImBYcWCVnL/Q0o1anwoRY4bNd4 +/mhIj9YmO2W+2CxX0/ccc8lAWuZ/fl6sb4tpvNxu46XK7zt6S8VGqCX9XqdbLOsRxVvS6yH+J2v nvarVbw94N3qnLAqwHfv3y3l937wtJUikeyQ/L116uLvLNBZoLNAZ4HOAp0FLliAEDl/eOZbC+zu gryLt9vJcrgLJS4K+bwAZerKK60xGC6vUVsL0CrlqptGg2wN/BHRNaalNeYvd/Nb0+fLpfQqyTCH kFHLwFd5iHvsjX5eRnbhyheT35z8Ro3cI6ZSIQEXvvawxcoposZ6+kbNv/8bbvZVZh31nwlWVH7J SeN2spwAIN0+vi9lXVnCmiwGOL0N6uhxeU3aSgBwLD//MBpkqySvT2uoCzclX76M5T0884IKyW2+ 20q2ECZ37ceHwTBN4Df61+CfpXreQ64wRen5pbzPufLF6g1L/hVpNP3dI6aSlpG4w9peEZmYj/zr yyl9O18H/pER/e6yZK2m2yWHhRVCqxitf8Pi9sCsSHluVDnhRkoaFKMXU90a2I/cIZWT5SKEo0AQ 8aJeAX9nggRToY0AQKx5Kshy3rypeidC8PQe9n0Cpcfl0G3p9XKIqouIkaYt78dkRV2KDKRjgkn0 UqKTVDHecHZzqQ6Lt3GrTGCmTySYp0nGRUZOg5FIif032DHhtwGWeVfqGadXBSbR6eIoNe9+jhfg hGeWR7RcJyzcwcWz7KSbLU9ClYyfTI2QwDATtbGQKFqtiJU9GnkSBtbmijtYIOq38sGw8sprlT8Y lgpZkCYLp+hCifE1QZiKZqn1eEljdI4grpYkIfcQZwpoE6XbdNMngbswzxfhUapdAPvTnC8aotSW 16OdI44Mq6mF8il2MjHmpbhEsoJhk+zm9ZZn1WKmEouksdH4IJcrFxWRXK8nTW5dRarMyp1/MKo3 ZKuO36ogIX6sf7RZWVm5FVrFAJBDa1YKnhuIOjlqEugkLBR1x72sMm9kP2LnMvflukPJctGI6fav uQ9hoXvKLJRbkHNcP9padNwJrQAz5BxhBo0s5zMqV+/E7RLcDpwI1O17ZXq9mBRVJ+vel6ptSVbk xgp/OLBVEGRnuWIV29q+jFoCE3Se6GOCYZCchBkbOQyjIiIlbAvGBSSUeVfomZMksVE1YwPGOfjP /4maQjY0BRV5JttmBQIvW5510yJ3vk8X8b6h3lDgbIURfBiAyDK1hYXVU3jdK7lY7DtlYaCA7Omg en3ZEUOdZB9cykFNPPyOO1uPqKTcxyDoTuQFVS1cogt9jIxUEKYV62Ebjmy0FMOBg4Td90pGLUuf 8xBvin/5b/4pesK6Goa7Gm/uQxtpnl9kKNMdHy35UtXWPSt1OEAxJ67Nxva3rdgkx07GscOYrXE5 wZr8mH2qN1qedRZrblbKiqgtaXCVGBir7MTNk21dw9awZ9q5KHe4ljwo5bRs41w6f5Q/0qz0bh+e cDw+yL73oaIwWPE28Nwy1CRJGkPBZ63ux1j0L5t/G9mPBPqlZDnRwSEcPcAKbc+IeGSUL8IXQG9C FU5oEjrthKYmzYrsv07IclH+FOo5T+NAQAUKsbYhvSbIUHXwHU+MJCUPPfySrKiNtdL2oLYHv5sw /VtRrGByukqjTGBVHy+/JGH+ypbOGdkHEzDsLXeNH1foGXCfDjduZ3mX61mmt8FPekq2FLJKkl9e AfQHsFfxYQtKpTTE42dkLxaCYk8l68nBHWpwqedZb5dGYPUuu1lranMR+0C4Q9y6jj3jlaTJrvb+ 7YZDVutaKas/4qD+JrBQ3cyycRiHaBQZKq6KhdlEpuhCKpMiTCvWky3hugiWG/NBw9bONjeuZqXP LOBNIVuGH7lDg0XGuChicqdqnqEhO/xZc75UtPVPUf7g8QVgpZ5SL7Rol9jJxJi/NfqAF2z1sE+s 3WnW0z0ScicfrZQVUUvSrLhhFs2TKmnewd0ChgYrg1tB0bchFCAh0J4qpNkYTGEJ+bH+Sr73bgBp BKZxMJzev3CuwvKiwnPDzRw1eSYRFEd/OHsgcVa7bZRZYz/GrC1W7MraMoQj+nKciqECrqvpOFpC 73edT5KdsmoqJ8tFuZSr51K3ZxQOpnd2O9Cr6VVRstnWbaHyuDzTluAOHJ7MSZe2FEnTU31nUShW sa0vR3kCq/r4VBNyYy8mNOQvkUrVYAJvBDoJpU/8IeRdoWfBBa3YTXJQyZbenXy88ckzMCGP69Xd UACl080OoA+ifmhbqdujx3Mj+GalpjaaI2zgQ5bt8YcghUrSNBb2VeIj46DKg7bP+gzcJXxP80Wm 6q2wxJnupZXowtj/FWFaWo+Zlc69W71alj7vIf6EtCIOvg7oIaTbOZ2qRYZ6daOTxnwhfSLjQNpj J7K+edjYWWziSo3OstaM+doUl8n19bBPo7/T+KyzWJw72SRYxJLViqjMCD+uT4qbkiqPrEAMlCo2 v11Uyh3fo+T1hkrzwkNifpQz7Vf7STCXLMsLDtgz5luNG3nCV702y8d7mR27ufvE8tvIfizJcr7I IHarqJFlruEw9yBE17UCr+jeJM2KbJtNyHJx/mTqHTV1e5JmlQeLd0r6bqWSXhMknpDj8py2mAVP yZyVFJmc+G+uWMW2rhyVCazq44XTvW0vp5IwpaZy7u2DESNtwZRIKaU+z7tczyK9FbuJkQUrZ70U zhFUDn7C42Y86t88btaAYo6AwuWYxTwBZ+aNpRGsWVFCY662QE76dw8o10SOVJNmOZgqlnJQY1PD VbRZQUXkANfuiq/6MlHY25KgC5NmRRCmpfV+49jNSI/H7WK5/VVHK80e4k2B6CWlkwdwhMbkYoXD LFlkaAjiz1ryJa8T/DOCpp89gUDj9vWXBaFmTPC66j7gBZscLQ7Smtu9pmet3nA1iUmwx+Bg1yEu 9QFVWyO2jm7ULwVLSr5GVyl3bFbyegPcqrEi2oI6P9SZNiuu+PuUmfuVPLdfaaWUGym8+qmQuLZk 6t0exPmb2I+c3EjJcnGOu769KQCN7O6JG/MnjztUIY/ofg4wK+IP4dCmZDl/r1TPCSfsqD99gRgB FrGdKtPrZ0aquDzVVjRMyIqmM5Wwigs97ZdVvEa0UOyX0rY2s1FJYCu+ryRhunrJm0VOpKIeg6gL OBKgVDIJxk+TJHn3G79HEOevtFBJeit2i3JQvvQh8EzMeWVGgBpSF6Hmx3zXXKCItwu+GQijPBNV MYLYhzDMBpfj3nD2nYU1XQtjuZPaJeWg6gybsObOS36BhS+JqMzwEc4jiC2+uIkz3Ysr0YWcBJNP 4XiEaYP1lM2IkQUGB/c6CSYfWUhLn3mINivCBUXkBLbgyD/lrJY85Bl6eEu+VLT1qRX5K8y+sXrF ZN05tokztUxFZsZs8gEv2OSwWbE02s0G/3GPmPOYBHsKDlZURG1Jq5Aqj8jJ/vQZPoCsROUEAHVZ 7uCZyIgMswl8JajloW4JSv0gZ9KsaBURpYg5pcOBgvlW40ZGb0L78kITFTXnUvTI2I/ybpGFHYeS 5ZjjxqaD7wkDsOQiov7Z6GIBQZIkOlfJcj49uXrmaZgRdWN2ShxKO1Wk10txrY8qjmaNr3Kctnhh 7cGRQuaMU4TqUQCJR1rEJqZUaqFYI8azmsAWfB9KdkbCjFWK0gSosssL/FEKbpl3uZ5FelGwcjZg xP0DVNTBMzF3VBgB+UoasIxQhFA91E6O2TaMVmpGCDDMUm0kU7770BfmMBNdhpHGy33gIDJLxkF9 3TyjN6XHjb4XOPnXtURN0nmqFi7RheL/TpYiTCvWw8KJEOPwZSf0bNApK6XPv+UJpkBCJJYp30zF h3l+kaFvyJeqti4Sk+/ydCivhKxosyDI16WjpDljNvmA111si7F2kka7W/cf94hVZSbBHnImSiqi tqShRFVIlXN4rh4jeclSljvEV5bTZMgWNPq5zkrmW8mNFJSiW/Jo1glIPrsS/lJmeEkarjefHR8n +MQx6nK8w8WkcfKtLl6MlhryZ3ZIGmrdg3Q9pjxVpjcIE73Dz+jsIlkx1JPRU6XdKrbV8NUENuuD hy6qFATnM1RF3hUGLIW32Y0rxmn+uhFUj2v+rRkBWWiPFmrbjejvNWH0k5cJB7XMKTVwJLnplD7m V/3CAlWEacV6hc01gkYPgULOFPxCZcNCEVMyFf7WfKloa4Kv+pvGftUjFsjSaL8/7y8VSSuietKa SZVldpRFQ5zHe+nnadw9/aEWkBdqoCdiuNm7mcpyvg+V/4WFnZfPvtf8haP6dsV/F0a4goP6GRaW ufbK+OgzRKaPcsiAIxnOpyHKX99FvpRqf80rHanya1r7q8aFbwiCnrjZ/cBrKL6qPbvIqhb4ohzU L48wPW1Xqy02uHbHB1ugI1V+sEE7cZ0FOgt0Fugs0Fmgs0Bngc4CnQU6C3QW6CzQWaCzQGeBzgKd BToLdBboLNBZoLNAZ4HOAp0FOgt0Fugs0Fng/2fv/V5dS651Mf0P/db/QV5EDB3yGuE0gZAgHEOe ZJr7Io4hD3L6IegYmkTtcKPu82A1cVCbXGQOZ5lc1BjU5B4110ftHO0TW1wjfK7MsXKNbkfboI4j O9owN2vPvfdcaynfGFWjZtWsmnNprb16/+qadO81NWf9GOOrUTXq5zcjAhGBiEBEICIQEYgIRAQi AhGBiEBEICIQEYgIRAQiAhGBiEBEICIQEYgIRAQiAhGBiEBEICIQEYgIRAQiAhGBiEBEICIQEYgI RAQiAhGBiEBEICIQEYgIRAQiAhGBiEBEICIQEYgIRAQiAl8rBPbbzV4+L5Pii/Sbnfw6HvCq8GGu U6FJtpwOJw6Cbv0zj53ut/bnd/MXL+WdJy0ebPf8QbGXUt6CUOl+M5/NV9sTBBZNn1/BSY4FmV/Q T89QX4Acz0mGk2z4+ZROdljN5/PltpzK/8aYnKTdMdutF7P5YnvLVu5ZjOPGGj1LZs89Ln1stHm2 VvnO+APYY128W3xPs7e41ZdNkjk+IzRPEnyolVJIFvwzVy5Z4lPX/ROauTzKtXe7aa/ZX1wb7BYB kgVw6QEIkwV9icn9fPAtktVRsk2n3loaX377hEpiZmv1XdSOlHJJOHosmpqCU+WYKy4BKtK42auv whJuJoEd2jNU++Wz3xv7CSRlzEDXnUCQu31EVfA6G75Z6RgVbiZoNunQV8fqbfqKd/i6ebmcol26 HqmM57dq5MKinvj05hqdmPBLEoy+ed0acz9hy16l1ub2J9tN8A1G9VVxfGl6v9vtD4W2jz6lqrXA rXQ1+C5F8PQoX9nOv3CtgydL+nj9IUs4WI5Elhx2u10xH37Pr5zBkxs4m/fq9d5cpFBx8KFbnTi+ Vcu36g+pczDvVBDra7a5NioaRnE0NsmzwBda64NlSs+9ryVluPC13/0+0eAkyGy3F0EoM7w0EbP9 HJ/TnuJ9MWIAczcppUtGunB3C9+HQrJaYfnD6ddne/37gKyhjCWNglE/0ZpKwR1VOeaKH3UASs3F 3zxxEte5yh+CBuqTnLoJoS+M1+gb5bkBWfd+oUtKlD3jWsC/wiYpqpbZ0t/JggwVH1XMYIWetVNs X0hfo1xCjkFwa4O2YGRRbPlzM9CYq2RcG1CZoQhQuawSzHN0MYHx4hVg2h/sBjsD/EBtNWzU+85H Kn1dpHQoh0Jx+4kbFagMcvFs0LSkrhnv+/Vab77T7+TPSeXi6stRA9oVJJccjqtRq9Y0vsyD2q3F KnF8ODtT+JtUPGT4jZsaLKcQ0WkSC4GtpF/Z23Q9rNU6W8i/Hddq3fm0i29gwxx30w5uqDHdzVrk 1Olq9meWvWzwfLiiIPhwNsY8iJVt0AFob9NFvdZYJMmgXusvD0cHQ0IqWSFTc7UpjeNxM0H/SV+j pbSD9Oa4OuMODb8cIUEvcLo5UzGbg7ymJBhU1EkFXMt+vT5YsSSSB8ZLs9yYUxKpTTikqyYQmdIr xEKPTqWzt7IgX2yu1shuyslj6qt/OO7P2nAafNW7axLlAFs2TzZpMtIptRa/zCN+uZnwd2MpYKPP n1fOdkMrIiFGqJqr3u2qQUmt3rPLSA9V6BO0h00vj9CY7agk12MDbP1snQhipuCoHP/+H3NsJUCg sPwyQvqFC+7YkngCg9ENFxlMfcFFRVnUAF2g0E1qhyX3M1VaNv5ZuU0e01k/L7XOeI3UijKnyzwE bGC8MjnSTUhIXyMTBRXHpNbszx9a9uPJn5vB6oGqO8fUswE2rabYU3PuVJGjl+ZxOTD5w7TPyEqz bV9KAOnYlQUvfV2MW/Hrppd4rsK/+iksta+k247btcYIBa0vz4xNVWpYNfeUcvH1DWrnS64k0UMV mFBj6Fc3txZr2QutFrdDgYoQKDi3uaOI0iSWtq4C2Kv6N6NWdHo4bs9atc78mGLeo7HKjrMOPDmq XnrWrDUGPLmUUKUbrXMbwaQZtdVHmi6r1VobNFPDRq07E9BM64QGEF4mR4gLqDHdIqlk3KpRr2k/ RRJo2RBoN4N/aW9yB3ZAQ9MaU5O/GnU6Z6tgYHIc7iSYqRQUEeML5MLtRpubFM6ltTLacIt0tj1m 5GfJr8AFQI7BMjHpmCyoLjSH5Hj2MwzfPdXq49XucEi25G67JLfyvN0ZO/E6D7oPw3aL9BUDY0xU xD/AHTeHCwCAHiAwh2veoHRqvQ1JezhDqu1JpnQBGseUphHqfchzWBBUVhHlBrxBBdd9swSlhNHW 8UADpSF78AUa/ObZn/TYoVhwRnENRaCwvDIirYsXesiQgdq3ZAl9hutUJygg0BstQ0WC1IJ1JjA3 KAwVHPwrbLJZ06M26jKR5/KyyCFFc6HCUCb6CghJff6CRhKa+yTtMZXYbtpqUtkJjCH5TeL65uDb gLIQrjV7ZNsYoujNFUhTyYbmPdti5oFQWgM42AkMK1lBPbslR0K+LuXFrQPbiRtLxlwqfNeYKjBp oXpoStCAGSMMW7jRBLGK9T1QLgF9A9oFDDXPh9sEtGylUKtabCJYrVbKNXsWaojKUlPNnUTUpVzV upp8X80bUq07W6Pd6tJcCZXpYEFzkyPUhHTFfeRGiy7q6LCv0YpSI1Yf7jbjer0F53C23g6d4Umx dTL4sLnqtZXDnBrvP3Anv9Fsteg/5GO3FdlM9bPrrcHZHNNFqi9RCEwTU+6gXhooyta4FTSoc+Xg slXB2U3bcF7r1bDF2vQ2O7iM1hrZ6YaOunMqC7pRnSvTGohuFLhOwz1cSxrUIDHBDk1ZukZ1xtVo 9yYLbhglhTxiQsOQCY8mlD+CuySQZCac+/ODg0RERqRdiTx5ZcdQcjEd9LqtJpcj/CXpReMCc4mm xYIziqsAXwYKq1hGJk37ZtlvtLl7AG+HFq45WukcLV1EhsoE4W7Ho16n3aC+O6at8kxKbRJZ7pZn w36nzR1+Gol7WVhipFzoe3iXdqfTaXeHc/hxYzAiJDxFUSMjyn6hhp/1Tn+05I0wBkbqLhTkN4mr my8DNkCZ1jFhSBdcQMHa/TR9K7WtiCaN3fri66LUDBU314WCyRkVuBNFHc4D+orNvOd2PNoCaDM2 U+UGuBPKhUDwMLQTV9oFGwqTjy6OUHVjqHUtNuFNoeMJ99/6gVarrOBoppcuFVFX3n1V68rBX+F/ NpipaXVQZdTSFQ1vm3AmHepu8IxQezRfr5ar1Woxmy02VjtEbxvdTqM1WqIJrbcx48P9f21gxdbJ YGQX0J42Cii30pgskQ8yWs5nC3s1IsWay2Y5HvEsBgat1KwVA+d1VrIho5JJMLgManhJMHFY9j1H IQfX6LTrjfFmjTrXRqNFY5YSt6KqZF6VdK62ahAJo45VrhN8FE0HY/vJsEcjPAxXdLOPhShux8j2 2M5l40SG0Rz6pVRlpBE4LMgR224l192Tx7gVGq3ANQ3Hi/VqxGjw0Kmr5wGT7WK5faBlKBacSV8J GcS/UEaqEmlQ5I/TcDVq7fFGa81iq30Lqj1H9PIEqadKS7yT+WqJmVtnIMwWG7LJ/YymfboDRFph ppfb52IWFnpKsP12Puj3B4P+YDRLQ0L6GomuaPcwZw5PftZtIWcaogqMIflV1uiOqBtunQo2kFsI T1i5TiGQpmQnaSZHMhyxokW1W7FKJ1jcfuLGktmEUUO7Z2hJOrMcEOVWRABtxkcxNivcteWSHAP6 +tqxWyk2FCYfrUKoutlQm/D2w9JW6wH1ByoKTkU0bgWGXNq6moxfzRseI6N26mUIHuupWSDoQ2OZ WneCao7eARAbqIUQrSmvqtDMWMZrExQLvkiaMjEYq7aqeGo4OcEUULZD00uTV1zr+zNe5EGtt2dy sjVEUIt6WzV9EQqMGQa0U5bPUw11a3nIUp7lpiE/j6ZbPL+0pEUOdp1aFxIbGeEhWtp5l/rB/QXN EBtzMlnI8NloapLIA+PRliZS2jwHe6BJrPaE223Vu070TBTNGNQnm4PJBRnSq94UmCebKTDHAhbN UVNS8Es7GgMBZwvVQB03EkkwEh7zkyhHRgPujosJI1Ooi347Wr5RxSSYwlYL6eP/0CsjGhzNVu42 cppmaQwwDoNewBfDYZ0g91649PdULDBFv9BzjdTiFxXNZgJTcd2Kmm/0bJL7xjT2RIeRZhGDWQhW CMQtku5h6px9IdXEkauRDnykaWSUOI1baaaUmhptP5xOZ+rKL2Zg6o5vA5aFGA8luYXS9K2Uuxad 1SHL9gvCQA03JI3S0vGLO1XDf54bN6AZFShBvf9nxNPakgPWbz0z9t2KX/QmC1MuIX0D2oUkN8JI rQlUNxtqE95utXTlDaQfTA3z6g3V3OmIWqPq1tXk/IrekA1QO6MunvjqyXI2LLBDTSxdzR75F/vK Vyh45aWv1hE1aLKhiJprp+5rz6USbQ3UjubtTE0a0NOBuzPEWnerD6kZPPqBkxWvLPPOAS0hfBb7 CbSYmPigBUp2HHWtDhe0rcwxJavnEcqehgctNbtCNsadW5PFLwcNPRloGbxKiQNrB41KMOlqCWr1 DvuX/ZlBs9Hl/Q7bHslT//xX+dgKHhyCqKvNThCN4bhLk1d0Nfu0yEI1S6OKBkQ3ESSPtWAEmURC LHGaYqTpzA61eJsppjzV1ZrtuJEnTfOCU9M+RnHyOwyFj79XRgkVp0zcKXDM+izetEe0ucJga1Zp qXSaBKCXoEoD/2bzAXwPXfVWG/j23W3wJTa5NjsWWh1Ep03dxSwsSMlEWVOTK258IX2NTPjCaizQ Fhj/+u98+TNtBos9SpCK1bcB27SoxE2FpSwDmKDZ9Kz0MBbzA8w0WLYuXxdTOn5xBxI3KnAbwan1 9Fg4z8UzY+5E0cYe6zqhXAL6Uh3xtPMlN/mw2yUjrIbahHdarWZpqxVKzdqhpCJKk1jdupqsX9eb NEmSlLp6d3llSBW1zb44H/uBuafA1sZQeu4Fpn18JoK+QbxccG5j0Z5kxaSKsUp/h7IoDcwvWHBH TeTuKh5O1Ifci1ids/cWuyNzLORtAFh5Zf8NyBjA3y6jvOWRdPCE3R+KRB7Zf33xymXjXaxeYdup he59SDFVZcsciuQ+c4W8RiPak+xst+WtppRgSP4AxAGBXXHsX6E07ff6njQI4X+dLl5xh9KWGkhr 067jy0OfZMYnlEtQ35B2p0h+vBZqM6nuVaJA+nZq5RE1Jhz/xsacAxrvXiwCafFg5osV57XOPVtO p3rfgejJe4fzHeDy+BX++zppdGe6UOcNl7OV4hUuYxHdbH2XB6f+vXXEUzOI4V4wAjgtZbhqXrAo X8PscWAzeNb11YXiddLo7nRJt6vVtnBQ9dUtYyM5AJJjvObZSTe3jnhS6jFQRCAiEBGICEQEIgLX IyDMhNeHfJYQp9HH+Tmk2w1d2636S/cgv7htan76VU90LvjDe6I8oF56xjlDA2huqtR9oe8EZCPE rYv4BuScJjO+uXWObjIn/XrWvKDk1t7Ff1KmX32gQI24laaBdK4VHuS629MnM15SAK/V8rkEuCVB nC2bMBPaz76C+1Po4wLZ8r50muu1Luw8oZlkd59SIO4zP2KWStC/0IEB7LDiPK1NLy8745yhAfxf /zc+xlnFBwisbm9L2bSDxfzCNsOboa9AtsA9KvBvlgppcQNyTk48F/75GJXS6BnzYrh6Nlw3BuqU CDc1idDq523K8RaMndma9xfKSa7rtPPt7boYX6P32A6HrYZEdciXywKX48A0dLQwoTZjuextsh+V g9tkhrSbw2w94n0beYq0F8ZsftD32MWBAKeQ47kCEE0jmgMjnpVLfotTA/YJMux7wQFJjy7SpX1D ui7jXBCfNN9sRkqqLJVKTM2Y0UZNOmbrAEXBaHETK5vEXucuOrhi5ErQFiKLvVC9cJ8wFsQJSWyf uIiL0uZ/LEBnp417V0FDA2huCsHvijZzD4fblT3tKg+lh81LqZ7bBkZwwIpwxnR/UGc5VTsJu0PB KfApDBlazsmpdSCm0x3Zs3qvn9J2UxDCGHLOAlwsVcHScuFLjKqAKuVk042qnF3ktTQVplWSl2sM Ohn9R+miqrDarkyHuhQIErKgLz/20rzWCE1qpzUvFJwLMaVzCrxtHkBL1VPlSFXLNBiq3DmXIG6o Wtr+lRmp6pBHF/msv3ymgLa3D8xu55K4WCpBdeX9xtbJJjR2UvdJGxHWx5Of2DXSEuI1ueXDqtSN b60eemSGlo6wYdXZByeDtau8xpyQcuwxK5IZHpjlA4clcQoBBzHyozFIOUzcJ6c8kFk5OZ4nAJ0O M+JZUju3VA3lhC9e2Lv0ay0iqiocNIDQfCZOJRzkjdTpE09Ad44fhzlaR0X5tcMzHGNcEtvmwrgV +mWMFhH0AUyVBU7r0BE5XwydDb8yAIG9EBIGeO0Ic3M0p92RCAM+2ulDZxKng5b6OAgSoDM1BqL/ 6L/+T5SI7gG6k2gz9wGq0iIDp8kor9Eh5kOMhszZE5wvI7ZMvemIpPsX/+qvADkwmROdIpgYMwW+ HQbBukwmlqzHaEDksg5VyVBFbWQyB1UQUh2Y8i3NFt7cU8psVD6qMBOXbhQlUATEFEqFafl5+cZg 0sFNkVbU4T8kuBDG19dPUx2nVdApIyy32FObF7c4aAuZXfV+wZWIKb/0iTC6pxNqpbhx80LFyumU 8nNa+NDJROZuwsEvZnLT1b8Yd5lXEj5Ua5LgQ68TdQbvQFSB4FXwq5uNsGLNNQm8Vjd8lAP4h1jg ckXpBG69v0Gn8A//OyzK5YTUbiVAZng8EochWJHgVBpDZ8Qt+SIPaXUD/HUn0sfl4lkdmlx6vgu4 FYcukuyqQKrJHZJS3kiTPptuF9rRGUrq7STHPUhFiC1THbkSBcX/mpjsVhSb7pa4BXDqPyCGCa6O adMYRLMXlvHa1Wlr74EY/1qjFdwRsZUQlUEFn2fQAAwNoLkxshxPo83c+6j6DJwwgaLDJb9fZHEM GBgDCNqE/X7PRzV7Y6r1LXahOREcXKviF13jvGt9AJJJZMfIKOJfy61AP7HMjDi9a2crMtuNMD+E LC0Xnpp6x6gCqD4kLlOHbjQEiMa5yrSKeQWMIS+tAK0oHf1WxJVAA2dMQvoG0vSMsMpiDZiVzQuN 4lVx7BckFbkD8nq66ulzi6wCkxPsUc96830FbiZflU4JP2cOj+KMnaNqEY9ZTY1V/bgKojGfRp6A iEOYSTihlHiWmLiAlIXXC1Q3j0XTEuG1upVKRE2irDUIC1yuKLXJRFasexEuzaOpVkUyQ46/A2sI +n4wFeeSfClNPUcU4K+zpaqgjzPiOVm4PwpuhaPwGQolSYj2jQSr4I006TPdxGy3wTRbu1VvDhZr WBif1leZioIGKIlJWQv1Jd8vQmJI6GORvbCcJY/BVtnRrfZuPHh0y86kXU0DqKfv0He1qBdPoM0M UZUGGDhDbsWh22JeSvjHAlumGolwU6MaIlga2vW10kqXOAGrGwpNOJaAfF4/AWEDvgDhGKeyB93R FSpOISZls6GKYF15sRaNKgmh6tGNhgCR5KtNS7GvKIFDJIeSiqpiogs/tW2bzQMrgBjnShilbyjN ohGGitjka5p3uyIXmxcuIM2jRYTqyq1YVU/PM1C73TzbZDvwaRAPTxVuphCpCuupKnQJ7PmKXEgM 5YhcqdYdDIcDIr1oDh0KCIRUcZXkqiUz5HUmHWY5Q/eSl1Dne8az5lY3j93URH7NbhT+Kdu/zBEJ C1yuqq6h2q0U2Nt0tWJOHofMkOIfiNodl5qEyVPkfAvsgiYXY40n0sflEfMMineFMPlPhcCemKYK tG/iDigphKdZPIc30mQBbrR6s9upNwab9Rl6XuDcVIwiKhdJJ29/dEwLBFa5Drfii2GywYytw174 B2owy3nt8qUcLQa1G4Wyy9Omil80ACOwvklt6sVTaDOZu6mAaghJlb6qr1okx60w82HAwBSAHI9B 7kzGUEOvjCitjS0hXV0Q3BIKbvhES5lbwZSm28wmHhkXCZsLr3PEM2VUyq0UUS3SjYYAoXT5usa0 KIzKK8ROqZKgIDREksVoh1aUgiixnVN7llsRoDTradEIv6y0WCVbdfPCQ84zNX1kuxVh/TWoMj11 b9Rr4IN9SuzSKin4S9XL1aS74kVT1g12KuRYiHCJ2AL9uDZEvltBrwezMoMxahkzn4eqW5FFsyjJ 6/JbCOJCLHC5jqZkQ5yQus2h0XGBzPB4wExGrTdd0xyCO2DhBsdhF9Sdaoe/jlsSlxwvQO9mV/YM H25fugyHSo1cBf6temh0qy2QxvIFUk3brnzeSJqMlovX+8APCeHJtGBXK14v1/1AWbIvTvWoOZwR Pq2SMfUlKn5ADMnEZy98QHOTLimlJXPRrYTKzqRdTQOoizgPrZvoa2kzA+qEkKT0OxNahDMXTTe5 LI4BA5PWA7FI8TqtrdC3MHjGVRdxIQw1VukIZtkd7/DhsrFvmXDW7Gh4EoPp6bIl0VNSmRasiKXN hfeMKoCqTzcaAsTAcKw2LQqnFUx8Y8hToTBBWlEKopUK6BtI06PQfOhXnDzfk5oXMhJ8fg69g+0M rlxGK+JWclSxr4wqFz7mQrWrCjcpdKs6iJrZYTGdrWWTEtLhya6G6uKS5IwVJtkCcXkBhdlZwT9G Zub0hNScP7o16sNPfkt1GiMryfCqXzlBnM8Cl+vGJatpNzz2Nt18+WSG/8SEpfxVqYQpfPVamErX rF4ZdkGY9ynkeJ4AMotO6SboK2CokIsud5j3tofAfl4+7ZtqqcRyfN5ISZqypYUMHqFkzFc5US2k yoXTCe8EgyuTqznZUFa+GCabwtooqlaI145aV5aZyoU/30nfb1K6+9CZxDGwLLJZ5jSA1Lw4mw0o 2om0mT5VqY9kNuePHthZ2EvSipfSN7DUIYeU6Q5mPcV3vnQRB8OkG/WtyDp9ssWlGZEWCRpaVJwN tchiVwSBLhfeN6oQqh5uAUpSSRt/K02LwonAvjFYqdi6GFpR3SpCqQZPcfv6+mmGjNAvYsn5tOYF uejdIlQeLV5bMWZM7sB85ok+20GrY+ryDUnyFUzsKkxqgp8zWaLIhxa1Mu2LACW4RFVrkfqrdvJl DR1XOz5TZc03i3VkxQZ/xl4Pj/zqZi3iK9Zcbq9k9SEX4XW4yznuTmKBI5UD7Gr02CXioyfV12nh b00fV5158G017RsT4PE4JBj5tg9pQ6wbt1wM2mgpuxd1HJvXzk0m+Kuk7DjsyQagU/bC57Zk5+2r 4yMJxewoaEwCvJSnGYydTug+GXexUYJ9L3XR5RM8oaCY8wG8hdLxAxaELwTwUCKyU5duVOXjIFBI 5MSfVcZwii6hMF6aASP0i1gEzk3C11rC4C+leS3OVnh96xuSH+aOn1CW4ZLa017QHm3ozC8GJv9J igJPo6ntNO1Q8T4iEBG4cwTujPkwJBmv9tbqDQwxa43eNNxGhCLGZxGBEgQSmlmFU3GPX5UENo8D jKzmXbyJCEQE7haBu2M+DMuV7Db45OlmJxMq4VDxaUTgVAQO2/V6445UTo0aw0UEIgIRgYhARCAi cAICz4c5DbRxNumi/DTy4cGL5jW4DUmdkd+6uat0rCSvv5VMPWBN1ADC5YFNrOdyI8IHMtOvPK7O QNCvBVFkQO9X7dFzJy+FmaNxqYbpZsbDbWZK1Qdj3grrrc7zdXwrXHDPh3ouYdo4fWJocVB0bXZJ M5/kC/3S0y1I6oJ2Ienspr1maGdaMNKzPpRMfWBNyj7CFYFNrOdxI8IH8tKcnB5Xpx9U2Fc67hd1 /YDy5JUkihThT/srddwKnWttPbz+9u6MOWcx/dkzs4xeLzeHuJ6r9obGw8dYmlP6cnf/8LLTxp4I 0t0Ew9Y+bLcD1aTaiXct9Ryzr+VUez6RGotFmzq0fLiVTQ90x7Rx8OzY+4rdpJSp7E5X4Xn/zyIF f5zbryghlFORilR4WirZbSGMcZJmBhpG5hik2LRNJVNMdCoxIanDUzwgQQ6234PueIJXxG5ZuFwS OUV2lxE5QI/4u9TlK+KzDkrYo02r6G6UyWG1w2CHnmLYs4EtoOEjHAgspWckKdxcp4WPKiUQsha7 7IQekDNz9NL7RbXZlEFBWbyORJEVhJM5qrm1F+3W1HHGVf2T02Pyb7sUrFC4dVglXWOmY50wN/29 rtwiOZap9SY5p0CPhry0UhLUTc0k+tC0I3lGqKKqXrmSEPOs0FRy7lRnISVOQpkjBsFKVzAe18g5 W+bDNHWZuVxasxkasf6BTBQ71alxcT5WV5At0OAoLagIDkofbBUz7SeVgI+lAfXlvMm54Ba/xjlc c2nqOWuXtWKVpD3kKlCIc1J0zHByWZ2YwBlhHAsAKRxOoI5wiv2fsL+HtoLr43V2g6Yir0AiJ1e9 q7bolBPKoRndTrVAOK42xHGVdKYOJHAiim7LyIxnzS6doeWrvU7VSSj9G+IRDSRxYNKBLNohby6P 9xJvHOZMnOU8U0e1KA6RyHE6f/+PIJqgq0k8G74iPutgjmGBVjFAtRegXtTCC7ABNHyEJXCAGU+k sf9erwWfL1N6419GFWdAJjj/ri9mKPXKTpAvoZREoWiz2YDFo9ZXi6N0jLcx0m5QepvAG8Rsdom8 0kSR5YST+5C1F+w2r+PqiC7K0pwJArenTyZpCrvAKvlwkxszzhBJYaLigamV9kHJx+vJ+7cnW5OO X6BGAMNiCkkKJ2LQeiv+E87ov4IhUYp8jLoz3eGWjsf2Fp4kdqz+IdsS8yhfdEKJqmFJpbON51Ck XVVnJFU65lgKhOl0xrvNuDNYIICFe60zXkHCgGwOw6dqcOikqrn62EgWYq3MwXwl7vJzQ0TyZlPP BZkJ4fHLOSdzhVERmENsq46cb8C6g4jdmbRg5W6FOFJG1GLsFyim0TqtIpTj49KNAXP5rmHzjeUD FK7m7thN0c4T+QbJ3BgiTd5VXhvDnWTEZwVLVgdsWeuUPCBYAgQQisWS8BEnOtpADTuf+wYXBrE9 KEYmrbRHIifpwPjVqVtfkQBbo0AYoFX0qPYCYSRTjTOZuoeGh7AOHGDGE2msv6doEUA1kDgddS+U nTreXq6XNht1QnAMfg0mjVSNjJZREAgRJ7IlKMbUvAMoaarG9qUkiiwlnHwYKl/Pbo1JW8VotA6Q SZpg1G63+QizpjallpyNmVwVDpxSSDJLqh07cn58ZIPKmmkKJKFAgaLgUDmpG2ckobP2pVyv+39E T+Jsi4rLvd/OFBmjmzJYfulLwuanaSp9rtqKSmeAChBjKkIMJjXVfRjRTv/lAO0z8iZgzuOWJ4BS oGqoiOM1Iu5m0AlkDh5rZSGvl/+nVENqW4RWkY8SK+q5AlUaEyCUck7m2jJ7zxB+vF5vtWr1s/XW nfXStiReJo9oM0EhSmu8qSKUYzKHvvv5p3S3PBv2O21mtGZ2BYxW8GkV5MHZKZanwCwcyawHs2q0 omMZY+NOoz6/zxDZa0AeiZwAS7kzK1RAEY91MAcCPbzFdNDrtprUl+FeVpFqj4aAhTCSqQE2gEa/ 0R6rnmSqEFaBv6wkojSCnaKFyR2xFKp/8BM/EBGHU3YifLlepgmiUTD1W4hvtmk64SSkJBIgTlSM Xmy9Rh2rWVO2zWUqiQQIEr0iCwBiUr8jokg0puhiBblMA+Ur1m6gyG+MYKYxD7GVmlBFVklD84IQ mDAaj3qdNrEUKJoCHkec7TAt0cRYxcwUcWqeoco0eI5/iLKSDEkapWlbEde3uEXpbXYgnyfqLV8S O5ZdgoqrFn1CGB6uRrs3WbBnNApXlTuNKRSpqQnu3EhcPMzpwjyU/KrBs2fCNyuMpgXWSiejV+KH QoOmg/JlDtUScsUsMhOaRjL4NteYGTO6nUZrtES9q7dBvkiUSpJLlVuRzmeKbhe5lQqOR8Xtpt1K ul4st1/8axrqdgeT+WpFdPBEXprLnOsYEGBPbmPApSxuRZEEisEsQG4qtIG4N/O0SusiiZzEMrmH FKGJ1/ViNuzRqK5lrTJTBw+dv+F4sV6NqAml5q5AtRcII5lqnJmVqIhGv1FAWAVmt1Is7rxA5e4U LaSUKY5Cld2Km3jKvHx22e3/TT5aKeiu9TJuRU10dM8wUdmZiWj81yDAxynRG6ZLaqspC/WY/1Vp 0vJZ/lYSCdFvFossBIhJ/m6IIqFAmMs0WL7Sjcm9iVLH6WSL1uxWimSSufiY8EfP5azbQq0iMn+B iCfW8K1QVLMlPh+gxyaoQI3+GdcSDbxKKWCoxq/pG/C0BSgrbUM6oDAanXa9Md6sUfnacGg0ZglI YsfyuWoBZlmlM4gFyp0xdDuwBia+EZvBDxHgGtmsBkd4HigRvndZK92cXoVfwgUnUJDM2nh8qjSb ai/01lKYV1VoFitL1XQis+5ILoFWXcWlSdd6D2ymyWYCU8Y0ZhWh3JFYVRXX4n5Jo+PPfoERB/dh jgdiB+TRihp8IX3JnW4V66Mak07A44GPWKFE0XqLeZhY5gnP/7Tm28NhPUHv0ZkE4/5kb05Tvls1 +SbpqJkEVDNfEZ91UIGAfylWkbcTFcKh2guEkUyVpl9S0+qh4SGsYQkVaHZYz+bUJTTXKVoEUA0k Xiy7OXHwskP3ddd66VJjYbboBOAaWeRO9FwQUFO4rwlRJM3f0spUgcuUdyJ55UtuhcfUBgqp46YQ lf0zt2dCZu+ylZpgHqtkpo1ZL3DQXPVmQvPBmATDla7VgkvXWlah5wFDlQpoSRJgJbUqLJUsL150 UMfm+NYJhrr4rE5IEjsWezSHq5bfuhSpJCNfgliAd1deSVDvrxWAu9yDJCwbrTUUGhzohXVh1DLm myXyZFz0pSrDWunl9rI/EC64z3+Vc7uhRVXUcz5Vmj3547+1lZV5QhgO2UOfP31IZUojCGsOSr6G oOLyWh7ZDK7OmZplKieUQ0O7X1C3nq/eZA3LNivdrQ6mY1sgJoWXbNLXrNit6OxIAHxvixtAid8c EDm3mAfHoglP8wR38yHnVm+2MQ8sIxclubUkzSRykk6y4oVO2rfgK+KzDqrEaLFPo1BrtmBfnYnq bNpUe4EweaaMcwgNH2EplAAzHtdBIYfXol2vRQDVEO2eV3barQT14s9waLNRgrAiPXLk9iUI4JlP nGhbr0R6NYgiw4STofIN2K3UcdX4s+K51pinMTWozY2bIFP8UCksUIz5r/9ugMpFV72FqqA/AwHv hx6B093itAIFmrOY2pIUKSvZMg1LcMokrhihKCfb4rFDNvckcWOBaljXJPzhCYHSSmfVdI92lXyE 9p4GH+fGCkD2T+1MUDZeG1LYSYMDAM33XMnj8FVgrXTyejV+0HbQckk9qjQnaPVbJ+jpP5jLzRGJ 6dlUyxpIBkLka7AwfvdnIII8on4Fk5SesolvM+51RsrTEeE/JugkGfnrksjJUzi/HGBfkVL+vVNo FU8IE0TDR1ikdQo0xeafnDBWgpBClGr+G0/wQJ6Uo+pFg6sOFtb1etEWC9l6ZAvi3peVSDGUo4v7 0lFNvbKV1U8CmhWSOelnsLCqY54WxTJBSQ47V+W2osoglMsBKSnRi0K7kSzhbGRKzaTNN5UFakvC QDp1300o8CsgiRuKMs91pXd+CboxTg3jxyo8KcgWqBrcEULvFyLZaodYKwtpx58vKQL2d3muFTHd 0FdoQVDIvZ8uNpS99tdhNZsxXf+NNL0RqjdKWQemmojLJbS/TUIxzp0hsKUPkGAXsPPxiztL/XVJ KFA10gVgm+sxitLzdqyVrwtGr4EeIDR0z11eo1Oyx/chV+vt18ClXINE1eubolqVVvBdul2ttvoc XjBAfPjcEUj3q9XNuyDPXcwXnGGgatDp8kJ7ElkrX3AxxewjAhGBiEBE4KVC4A4YJjNQuB1SMK2V 9OHvIIu7hEzoCu+QGu5mSYkAd6hUhQAVr24qwB0mddOsbxMeFIDL+XyObedEtnPtVa1d9dtrE3/l Ajy7vhUpVLx65YCKAgcQuAuGSSYAnE4w3e3OEOrs7iKLgOSVjyqY9ISu8A6p4QKzoxXSiQChILek 8ruepNHJ7La5+JPATrIv1Y81bXylhTBehal11ZHwChGr7aEC4Yo0q18FGCCrItys1G6YuGQsFaca DQld9bcCsVDiN9OuKuP47sUjoDbjXc8wme+UwtYG3rCQ87n9ic6ATHGUI7wB75osZPsDdmsADpxU upba0eWsY3lwwkko7xhTl7+Ozj8ZTjzZpGrtRD1aXH6mSIq5kNIZ0cGJwBSS801pB3VA9wLHo6Qs AvBvN4xL5XcsIQAkIj3soCJOO9n/ZpM0umSYpGaBAa+QC8mhkkyIRtNdO2Tg9AaVEsQUuDqMIsYr FgdlgUllgIdglinZ5SJC5LSfhLb9lYQQUyWlHLqIG6Qr3+lb087UljoOgPwpWX/8ooGi7M1LhoWm vpNMI3y6leZSOeZnPRaWV/XI1Q7brfDYtrdAqeVp8Z1Nn8isiUQhq8LYxsx7k0xUqc76gVScgNmo ECXofQU2aUSMN68cAs4Rg5pmmPQ4+hJUUpC6kXbEB0jnQPnID/UHa7V/jo23s91u1O7iHL1/hbII UCCeRO0YIFdUm4JIDkMBxyca6AlYv7Bnnu7U1SJOPHUQUu1RX4JTeUUBulPrCFdlLhSYu77JeixH S/CssCspoKAgIwJ4rJi0m5cvULX4tHsSXSHP1DQUGEWmCoX9mkWsR++GK6iJXfHmAgOenYtJE4cd TJh6l8/I4HyoPpqAPn93BW/DbsVFzKOdpDD6MsWBXJZ5WkiNTiJ45aL0Mvv32x2Re4BTbyGmSiN8 6IZAbvTGG+0l0816g+5ABa1iAagBH7MysNT/6m9uR0DqqynS8hFsgorYJ6xDT8zpasGIELC3YKlJ UvhboE+0En+4MSe5cBBvBnKVMqJOm4Lyl78Q+ElERZz4nG3S0i7evmIIcJvvMEyGOPqsDja3LeRW 6Oy85nOr1tnPgquwR4GIoyDXUTvSmdnmiPvTfDqYD8XD/nFGde/spjBNN9UvlxNPXpEizfHsDK6h P7N8ClqwklzaTAdHXV86ykGYtPiU5X5BJ2ets2bUAvscj4JSLoAfBueR+Yh0gHZPomvkFSkoMKOz G1IoATJMRWTnMOAZwkCTJHMwNuFzMVykowfDNZox/O1tqJ/AfAVgefIQ82knVeNcKA5lUWPaJZTO 0MYR9YFfLqLXLgNJDXwTY5sRAQ/OjAeYKnPhg3eH1VgcXL3dG61pnFRFq6gkV5TXW+Rao8PORDeq qCkfaGKZGxKQBtTMpZVSC2hHHJLYq7tGYLG3QKmZpAL0iZJ4wJjp0H0tTNRpdbpIAMdsnrdNGu3i zSuHgJqhUoMMRVfCwxA5WK3JlFRLyM25mKsdsVprO6TKAuFPocgLUTt6nHUkj08BJ003ciqyvcmr lNpPupjgxVUhnMuMes3CI8f56pNfWeAErq+gZCEClIGAw/sh2j2JjuZXMRXQA7RyRE0mhRJATF4h sGHAQye8QGhmM3zCEYOUgMhCeppXkzfbE1taAbEAy2KoOFR0th6wIAj1XLFclF7qSHVub+pcvBoa N5qtFv2HMhMOJQNK+AabSVaz8ZAYrWrt9Z/IVCZwW3QxWaX9eTWSXBj/+B79BAJKUVMKjPzEoaMM YG4L46mZv5Q0A9rtSVTH3jDi80rNSsqjT5TEoWmRj1TpHiTqtNyKItJBFtpsnrtN5trFu1cNAWqj 5ENaym6dAzviVtAz17S3wtpnR6xW2g6pqwYzRBUpEE2tkRrhUzsyw49LwMiBPQo40y7xbIDDiSet OnfjBxOaEWi75+XLclHjEa0ORz8jthdUXM+thBQUlESAUBiND7MJtUdzOiOzWi1ms8Um5+4L4FmO mPE4yN1E9Bsox600CJAg2x5adBsxpEMTbZASYi7nswUI4NAeNgrFoSxKuxVtb3655OJBUtgbs6br tpQbXpepUi8aCKju32w3JWpTE4aMtja49wv8K2fAiZHMOaSvJFcdLLonz5UDJQj7T3wrtWQJqJm/ VWmC04fonV3tHhKMjr1VuxVa5HM5SyXxgDHTkBQ5hog6tVsB8aMnwHO3yRyoePeqIWCaGgiuqwxP OBQ5+sD10xqjZeANNtRu2BFtpX1yQjukyoLbmesp8nxqxwBnnWX/lhjUdBOTHteFDvNZCyeetOoc cYWZEWpAMSNn2qAQM56Vi6hDcwL13gyYbGdgdHQmwYIKinhagGAYTeV3DNDuSXQHeV1kIp6PmNM+ UGPClM4ozfY4d1Q86gGXEzryyQYNcm0Ehk9a5sZnhvCZvR3IKWtgCvUQ82knVRjVHhqB+ZMctd50 nSYbWmPB8DBQLrZeRbcCHmQzV8kzVC36Zs5hPV/IOnyeGd9la+RT74zW2GGRHBZjTGrV8Y1rmtMq oVUEUNCyNQLjX8aMf12wjflOxAy3DbABzI0wITXNS6b5qk/QYfC1e+C16hDGlBrI1GYLy2AVdC59 otBLBqoMSVBC1MluhSuOJYA2m+dkk1XFmmMX715qBKiR5CVUSIkqoxgmfY6+fK2TiA9baDfsiLaG 3OrKHBq/sEPqLE6kyPOoHQOcdVRznSad8zT8dXuPie4PuicsTTFG+dSCtugTluqqzoXVocYZ0xt6 UojoXAiT/AopKG+lzQyFESq/s4f7Iu2eRHeQJzyttRXoUiTDtPChRS5m2jS5GJXNJgeaLRLes3EX vXu+mn1aZAkg5tFOWtkZgXFjVjqaaLtp1jHIwmdMkSAa0i4B+nSamq/zeU3VIMh2jnaO8I/4GINc 9eGcls9QZGW0isqtSPjmhM+LsxNxprzgaJqjNWVkoVHEPJcjoKb1cgsOeTWhV9TOgtHYW15q6RLx 3M38Hn2i0Ev+fB7mLA0TdaJc+OOq/V/+g6lWxmzgzYS1sdbsTWx7L9bxZ7DJP9lfNMjBinevBQIB jj6iZ7tWN9qyEiIn9CNeS5EXpnas5Kyzc8HWSfWTd1TmgxE7TOn9qbm4uzXd5K5VEMEDYYTKD29v SrsXRsyVSv+ycsETtJZMPIuPaDuhT2Lku5ZlMV112wM1ruA5GXLKuG5eLtfm5AiPH9g5jqtQ9gHM rXiIUQhvvQzcXot5pZp2MZygnQ4OouCm61ZIMK+wJPGAMVcRdULggJ7yiKW8AULX4iMJk0EUqCvz V/Hu643A7cgJg5h9Dakdgzic/vDWiHEPUZEzn57b6SG39LEQDFN4+DBc8taH02O/3CFvjfnt1Uq3 02m+cHTjdGichauwJf7GyZwY4QXgc6JkMdjXFoFI7XjTor8VYjiraM4A3jTD08KnW+botI83nhbx VQh1K8xfnGLPnajzFcPnxZVMzDkiEBGICEQEIgIRgYhARCAiEBGICEQEIgIRgYhARCAiEBGICEQE IgIRgYhARCAiEBGICEQEIgIRgYhARCAiEBGICEQEIgIRgYhARCAiEBGICEQEIgIRgYhARCAiEBGI CEQEIgIRgYhARCAiEBGICEQEIgIRgYhARCAiEBGICEQEIgIRgYhARCAiEBGICEQEIgIRgYhARCAi EBGICEQEIgIRgYjAa48AvvS5xCfT56vNTb+FkWw3u6qv/gh0+Nj2xgl5akRJ4MS/X1GynHu63+6u /5DZiYLqYNlhNZ/Pl//07x1wrDQCmT67jn4K/hNLhme6vU3KUHoJWBbL7TPz9e+3m316g89O3VzX 2yjo5BIoYuc9flxuNxcb57/LQ3q1v3+5f+gETfeXO/eJ85p/ZIeL+b1seT8QXQd+eLnZXbkRvcCB MG6Ml+bXNZhkF8vl5VdqIC8NEs9TkMPqjD+vVG/wZ5bqHfpm/XVXNu3gc4L49vAcHwTyP1TnR5/h c+K12hl9vJavkyP6SeVPsk2n3lpKkvT8TpLNM3DukgV06JV95dYJejzupr1mf1F46P3MJh2Cpf7P CJ0gjMkSn8DqOyWSLsoCe+mXPPBTuHvcjIXcWNr1hG0F9kjY1LqTTYka/mPJ9Ghukj7KbHFiofkJ VjyRLJ4ZukARF7N9+KTx5nnN+e/RYHnRf/O859jY1eL757X3Cx7BTSx72uF02j/JusXoOmSyQF6Z Y3PHi54bOLnnh3Ezell+XYNJtnpUe/vCbkNeFsFfZTkOc1Te5nCh3DW+O4eK3JnujvhQqXhwucXH SDN82XS/P2THPWprd7bDZ113u70ukyzd40ewe5ku6Rvm9Vq9OxOwdMSMvjOaHfb0fSe+PyaH/W7v 2HSCdHd7LQ4CKSmSFJ8mh0OcyhtOOZcnSw6IFf6CLLSgJKFI4aLvnmYpRRRDs7TGcwiGzzEbaOiz tqI9Zbc76Pyyea9e780l/TJk8PXYWm/uwgjfaOlLXwmv6a/0KvDTBGA2Fg5CpAUwtPRVxZfhkYjE mnLxhVI4DbejowiQQqKQdn/wpDEWQt8ixIcIM8LUsQ0nKRZO/XOAwmxa9HM9xsfnW+qDxQCbNHQS KWhtzNLcJMN6rb/UbsUG1sqRbn1r4Sc7NzdbAJNFDh3ScbMoLwXL/JwiLohV+Jku0QaaBv9i8Pb5 YHmVHi734jfpXkYryeFyt78SE5SU9o/rbz4mkzteHXaXUj2u9jsE1mGcXDK8QiIXw7fP+/b3Q1NK XEXIcL/D6EmysP+6r9RHhSFkQTASdXdVSCDLrkxFk1qGNsJodLXH0EwUTFPzHIWZR4QsBhM2V9L0 IBABhOVH582fKokdEJAIQZeRYIISB3M1UjEpR5E+yyXJxVAKqnQQwARGdPtep/bK/zksyD+Qkcm1 XS7WuyTBZ2jrQ9VYLPv1+mB11N8qpQ7k//T+f0l/0N798l/XuYnLdjM4DnU1+6Y51Ynuph2ktt2M 4Vt0e5guVER8RV3FQhbmHk/q3QmVU7YbtnSyeLTC8GiJVkddvf9ZZ9laSZEeJdnVGQ8DOOBIWhUl zWE5khTQYo2kQtLLZDXMX9XaFM/S+l9M/kdocdhNEGamqiDdN5ZJOusb7Wud8TrdnKl0moMlkDEa NPszu5avhjpW469+otA4HvdnbR47In69u4a+4laS9Vhe4J37xdhs09Mo4lVjtstssfFIdfirUjgB t3QzMZk0+lNAvhzkWtfaZzaSRrXBL39hBQI4Ky7VUkxQCANg0RtvdNci3aw3qI4BGD2tTab/3V/+ 59Aa12D5B6TGbqUIrDIG9a9vLZuJ+k4yJTLirySjx2XUbw0XJi9TBXxbDZaCb36miG2RwvdOg4+m /tv5EKb1EzTyV8sPz+sf4+bi7F3z6oll/yYKDXYGb53TgHr/pP2WDlz//gXqvMklu//YGiUhSi5V ihENO7jd549kGPWofy8PAGE2n1qvPmPxPjqvGZm/nXElupi8b4kqrg3RVx+f1757iRRTDCjeTNHX hV79t2iAlm0swd5+ussuxu+c1z6kwJgwHH/3vEFoqCvHZGCyfvO8/VMVIOu//Wh8H2X3pCWDwRwE eYLc1ZDZUfZzyQHN1AYSPlnBW2VP22/CT1Him5+w/OnTfp5vOl4f959D36dbbgkOuH8rs2tOnugr fEctubgPWw3b1FeDRh0dFR5xoELt9+jJU92n2kqtLnkKuJ5ae0yt+27aavbMXBenST3G9gRWkSJW 64znNCTiaggB+hsMgdKM7pvczidLNMVDap7xV6V2OEO/tT15QC1/fbzaHdBDlkRyyfWTA5xla7zF 89Wo0zmjpkyuZNSsdZSRHDDYqdvdfnYrjekWeqQTZIexlaX1n3QLn4wg5tkaCZLArUlGYerK0ZAD rfVhJuSLqc6mZxhaDHimgkYZtdGaQJKLeuY2jFvOleQ+ZkoAKQjCsDUiRfYLICDemRPaoEvfHKE9 QJtMcKL6s9ht2LDq8NcHB7wqT0GQrMDtgLJTo1oMEqEIxFblhYYg28K9Okgq76BUQ+A2F8GGpvwA TjUmx8NqLA14vd0brWlMGYgS0NqYpXfjA8vIqX88rfc0Zj+DU4c5z+Bf2pssRaE3BtRfStfoMzSW abEK+LbKhoFq4ZSCb35SxJZEZbemwecA5COaH1NbSi3VWxjFXK3Qbn90dTw8rr1JrSXa4dG7qWP/ 9OoxOxoa7PSXl5Pvnte+zw0yN4ndz2EMakx0Mfr2ef1DWndIVikSdNyKhEE73/6EWtHdZ4+a71uz SQcMix4N2fL399DqIlP2FG89pfq1x7Teo+HquP8MbeyTNQ0fLmfwL9+94OYWP3Vbjcqwhn9587zz GUbkLPzDCziOpnIcPD0IwZIFNew0rKV8lQ+iRMg9KUx4wNX8CWm6/VTBBTEe194ir3QGr6SEPzyB X2h/yiC8SV4AGCK7OlBNnzQBgq7LlJ1Vl59iRhF97+N9AHVee+cCsTC+02C+9ZS95eUUvv5DSqel waR8lQ8iSV+fi+rCyW4FlX2qexPFOrVfoIHEVe/0R0t3DT/j7n0DL0YD6rfX+5SGeAT4NRoK8bXs N9rsC/Aata85Ws1Rp2X2mAZQtcEf0LbXh7BLuiQR9ct6ks1U973eGpzNnUkyBEKzOB71Om1eSnK6 /XYF53Fc/0BZaK3N2z0tFGFiao8/1HJCkN3ybNjvtJs0oGjQKI/0Il+84qFKo0UXNZbNERmqXDJF I4osafxS58AcutYnfZEXizFWPZxs5U2CZZvFdNDrtpqcBbsV3ClPl56SghagHLeEcJhgHEQXuTw4 TS477sGK/KIX/hYtBI9EkmpMVBrZfruajYctArS9fhCM4mltMvVufGCtHmJRazUibjRbLfqPTHZx 2JBHxGJifhUV9G1VGY9TCojumZ+xqzztsjtp8NV7NQlG9/JcmtDsae9taorr7zw+u+euRz98gkkw y63w+OWtR6136D9qEj+8ktQyaz0l62FoY49WtFu5XKDRRqy30v5PLuyKnyDAm2ixWVR2WP0FiUft M11qVo3moOCwmu/wf5SOmeJDGPT8H43XF8N3zlvvnNffv9jBe77Dfie7WHz2uPf9R01Sk/0dZ4GW 5AA/9W3Lu1luhecMKW9RkJ0auVRbUxrdwDVTmDeVO9Co8qAJYzTGivO16vLVgsaJl5tPgPmj2ltP 1vcNzle75ZPhh2mbxywNGkteLeBAv391fEhecq6bVBLsdbm4pjfzSaRjNoafwWI85prE3UzRhuiW ChM+SnNVp6zxAi2soG0761JDUJ9blZYHRJ3hcDgY4H9ajR1iMksaIt38cqqOW2mgm7ehqirGfFjg B7sVs9agEtE+hpOQZFOsdGyW4xFPTnE7LyVGo5VavT2azFdLa1KOX9sVXPkObhm01vnbFA17fXgG N9ehkcV+Bp2b3QGSXE27AMt2K9RXH83Xq+VqtcJmu8XGgsa0fiI2YdUcrhAawZfz2QINqnYrSOes xK1Qvx3udzherFcjq7DUQEyLzeOXshRMcZTixm5F+zU2ksaQJi3JdeIS+RlF9Y9nIdTnVboAvVJM st0Ug6pV3mVdwZ0NfvkPfpSA1hpPwC+5C8I+sCYHEt+1li9porUxWebFsE83gJj2qNCVrrFFLXnA A/bckn1bVcbjlMIxYH65XXHqVf+Y9pADqeEG3cpzcSvHK0zmb5ZPRh+Sp+CmTJJ9SGsrtltBY9v8 +GK9uljiv3tPF2uTGjW2UvvK3AqWGi93m2z607SFmTRrPofdyhNlsceM+ufDlREPwijh2a28/XS5 xnasi9Uymy1sJ3g1f/+88W5af/vJZv24/lbafpvHLDx8QIM8/CRbr2hwwcMoTur7TzDT1flclKW/ JlMfrsvJu+ddmrizNeU2X7kVvYxlu5V0dA9yXqxW2ezzzK7L5HTeTjtvPxotyVO3MQZ8h7wbT3k9 6n70dL66mH5fe9Vsg0HN4zFcqvKStryvx/0O01e1Zn+1S7BUvTijZn+0TtjUW8tDlvKiCXZ9uU0H VdvOZI1hvpoEm6Ez1+bVkP0MKUj7gwKj+tjVSxFUgHBbCGki5k2TmlNqDNDBSTZoW2qjTbqlBhNr HDS3Th35zlQ3swr7ZIEpn4lTuCzPYY2wvBR+3MqslC4t8ghIhnoIG9px5MwmqUmwCWY/kJ3MJikF Ed6u/liRh5qNITWqPIxqramd4pk6NVrhWUE14YO1DbRH6KVSCwmXml+q9cvnErc0TcRrOkiKgRJ9 aRao3psh8nYGd+aITTOQvBdCrXDBL9mFJWJXpaDDV+Cmptd6UwiA0oEi6Bvw7CjPCYgZ5Jpxe25b CF7xKAA+lyQpxSRbQ+96Z7TGXoPksBijjDBYCEQJaG0ydW8wovSBzd1K5lkL9xP6M+oybNFPqLXW KXe3WP39khbg5odiFfBt1Rg56W651IL5SQFlm/lsWb2DXdyHwpnbSY2/mrbSDWC2hjdR6/Iy8aJi 4N+CW1lQ04qpJ+rsHGh9Qc//UItKkz+1dy9oh86ibBKM9pW1P6UBCLef4kcoI9q91uMllc1nkAdL D6aFx2vdyHOsxzOar7tEq6uaYvxQFw8ZIAMNKLq0APR4QTWXVlgwv4SLFztoMo0uNQGlp9T4Cf1j MvXgImf3mHcJ0nIMgUDtDGa6yHlZUEsKNAl23lXK8rQeLaaYi4dLNDOW8VyfmrXj1S7tO3h6TVx8 Bm8Oj3/9ZlGT/qt2c1j2UM31VR9Mee0j28l6bB0zO1h6xhSGNfeSzXkc0P/lL1SrW1hRNQMIbqit JXXYLk2XNZd77Y/0wg1jZpZBIUt7pEbch3EXbRhfzT6WbKgOyjAKc/rculuz+tK+WUuu9eGCFvvk yuY8FYcU66029O5bu0+dJfvmgLpaltacNY1EcPGifH2qxvjp2qyYtzpoFGnPc7LiVfvm2cP9okMu iK5mj/yLddFSiFqAEOeVTLpSGPUOOpUmU3glJE1XHbN3LXtJCKvAJgeaO+tM0pDYFSkYN1SOG7lF GhTx1eatg+gS6Dk9gd1SzVgIBhraCRK8PJTLqjAht2W2LUDb4Zyadz9KQOujZLrca/tc/kF2ghWB tURFBwMDYXVpa9nOYKX6GvC+KQhg1O9NMJMpeUkVgGkXbDVkPAHzkyJOKMvqdobaunyGB+3kIzUP I20gNYA8y2Stg7/1xLF/au3NaIWjP3zalTXlOpxIPvYhR9OR1XzMNfF6osZNclQNO7WQCND/nPyL ufb3eKGBXqW8yMLi0SwQLhKe3cHlTE2jUTDlCk0CEIUGI7SqcrzEyAXtM9efqyVWwyk85rsewXl1 uKlHmrSH4X1eJ8rTyDEpwHWwtxYfnnS5nUeazQ9plMGjDzUjZ1Ig91pX+b75qKczNTnx2hCPUHik pme30rXZXfCogxUcDoA4tL6DxSDTUppkXqsbbJvFlXfhWDl3L21RX2y9dR/hAa5CGm6Qyl9opmhY hDkJN+GMRHMf5enQluD8l33HKgXfkaChWGbq7xZakIiFzCzRCN3ia1tW554FD+rLgjth5Qc2+56U fnkKkhLtoPYswby8iR5IKaiFTqwakzRkkMUoIa1NpubGCF8OLLyErzXnZiLzDR7ZMAeyAECltqrT Qqyg+blZPfMvbGRN7O50ZYLpw6sysWlDbGVc3l6bb6Z1w0IGa+uv+y7/RaI6Lil/VXJnbz/WQVJa i9Ejl5JYzuOsqDJkKAPBikii2kZgvSq79UG4nGMFp+gBy6LH58+CAK3Jy1zus6Rz67g8nUX7uOIV EYgIvEoI0OiJBi9qOPNyS64Ptz6mc3/x+soRSA+Fs25feY7FDCCBexKzGCD+jghEBF5GBNLL1eqS 9qK/AtfVdn1xY5qsV0CvKGJEICIQEYgIRAReaQTAlXd5wwnJG+h7DZucTsmjy7tBDiVBA4R7kkvF q5LE6HEgVkVo65VEPA0KK+KtbtP9xfb57LcXvW4lJkcKpKDLSLC6pXFK9NuLhn1K+002u3exfWhu niW1O4h7askGUL1F7lJZrKiCqi4U+WmFKLkFheZy8RRgxoFACUIv2+PL6fuPqveoXCMxH/yx9lxd E/yGr69hk5PUinR58vz2f0OkfJrBr+IVdq3XZUNIIe9QrEKQ8E8i0yB6wBOh8BIBA+Hbj5fXrPAa M7haYltONaWhl8ONHhiIbg2IyS6Ugioj1gKnniuMswoWiW5yuvlNtlZ7pdK//lt9Y++2KqRnMCk8 v5OfkvipJSv29oyZl7Nl6kI5EeSr1U95Y9hbjxq8da3DB/9PE85Y9UnBBaiTAn+9AxU51vJhhSJt y+gwVM8h/MkBs8jfsJ2Gn/ssbfnZXgRws6MYxBpn6PLwO0xeV87nVskmh+SQI7aj2HR5xRxJClyQ HIRaTIWnHtAuF+xmf2jEc4RXGz6T7Mqi2tMMfvpVildmI41+tb+HKvC0ePif8zP7NvmXQ6ZHspGE Re47lu2K9jTy6S0NRXlgyIN0dElpJZnF4s3UrCEGqf9A8ydmoHeKcjE5+3zCEXV2BJ3F8oe8HTBt qA1EIYSN0BZNnzJUwqdYgqEUVEGQFkR14hhnnjjdgdzDggVQo6DFUCU6hcNWn6Oe1w9SEVIYvty3 pCYze5gbDhQ2ToOJSqkMarylV8LBGAyc79AT3CTx0pJV6eDfgr3xc7scr7CpTENhVVjKMWCTdJYk zJapC8UG2YhQvDnQKRJNFIOy2BIhTM7fUgCqSDiZW7VK1q10/EyloJQSoIoyFHLxEUbDghSS/eUJ m82Kib9yvwMca+j3agoF5jH48HKjegIuKZBoapjc8ICOKTEpJe/K0Bu8maXNHMLyeO3UISy1Cx0k b7A+h8/N8mXlfG4XhmHPZ5ML0OXxsS87R6MLsdtpsfUZMWqU9JMn/9cXdF7MRMQWeustWTLzKGoG P/eV2sTOrz6nQ1WUSGjAQrHYO3hkesW8mNbsav2JJTBtg9HF4eauiPLcwPoEsVKdN/yTVDjR4LAU Wkceriwz0Ae+NDLgDKQqZ52VePMJ0zMKrjikICcjEEWx/AUML4f60X8qED3IHxqEJVlrlEGdZ0WK VVWCJgVVRtJkGeOUhOWvDYt1VuLNc8XrSF7pY4QFXSH2IBEIjunyeT1JCn+vCtSLMlQ5r/1nYmMo wTLjfGibTVkZIRfnlTpNb9NOUoH6uOWJZ7+2AdQla5RwTYi3XXnlSOxYfHT9ivbQqnP3O4zFnvz6 H0RNKlxlkwZhPNGo6rqsC0XKyIgQuCHiFE1rpt9eLhcX/N0ZBw025oIpOo2bX+mA5xjHRZU1gpLl /7FLwYji5eIjzFTJOh0MkF/zq4RjTbc5pkzJX5RMgpkwQIrPsdJ5fNiPy9KmjcTntbsiHjlleziF +g5I5yivMHndsYzPzchA4xGXTc6ny/NzNGXMreXbTIVHe+CFKY46Qpf7fQlWbyoqvws6rUwG44PA x4ffBZeR9cpp1Y0ADB29CpDphVAF79Aj5p+8XABGiqihCARm6j8OzC1kQQBpWrfkp56saJM1cU24 vs+YgQUUEa3TYYEKzkAk5ZdLCbmfgtrQUmlbYrJEg7DAZY0ySF+lPuHgl2CwjMRsRHdJ1/prXlHD q2lsDzTE0FDX338CxqraO0zGW0VFiKOFPvWiKW5zU2GcJsyxqow8kslA4ABuJvFAyeZwUMSCvfmV QpGooCIQIwp1VB4e9zCq71489JsFPsAYZsvUyEsZ5UL4d1StmLe5+Cqge8gUpXELVDoqa91HonPx oIUUS8vzCuQSQJiBfevJanflDtjzdF6juxKONd3mmDLV7WFIcRMGL61m02VpE8oI7pwUeO309PKj 9vtPF3TAv5S8Dv29Ej43IwMJwARBpprYCmpeo7SYo1HLpIMn3AVStHtaFzspi4+uBCsyP+HNk3sL n0KrLiLkRuuR6dErF1V+ouky+GtEBbfiEOXxEoN6wjQXBQGkFhP1n/SmJE0RTsoX4NBp7vy4NLoc 1ZyB1eVigakVNMWX36hMac7KXEpmXg8S3EpKMFxGEtj4DpOyubFeYTQy/snjzncf0TlrHhjK2PbR cE0RAlSE//i0/27aeTdtv/v03/6Kis+lXsy1E/nBN6YWWUx1MKKYwAx1WRkVSSZDgQO45Yl7JesK 8GbB3gKVgqljnu42xOLVeguUv8Rar+lQXANWLYZbYQuFIj9zKfw7cm1ijfbbkO5sw26OulZSzGKl 49wFapW0KSnJKZRLAGFKKiSkJPNa/SWrkBOINscaTUZZFdlCvqg+oSpwUQ8fRWYhL1ahqyelU+C1 w4zrfnex+PxJD7Q8TBBRRl6HnEv43CSXvN0zMtgKCl2el6PoZNLBg8sZ+uqacU6dsbKTsrFCY47L xNVYMQgKRhaGXIz9qri4oWQQ6JiOySXTk1d5XvSkWM21GIHA9NEKoWzC5yGCbuUht/BSj6rdirTw SimuXKWcgVpxiC6ClYGpj7OpYDBCCZ9rrYCif6lPmDL9+1FENaWA13YJBstIAlu+I09c3Zn2gaeJ 6t99Mrl3sUTfm9Dj6O8+Hb+PwQv5a3YrLhXhl9noo8eDjx73P3r6T+RWBH9NvZhrl6tZapw6cKpo pkrLqEAyeUl8vIXAAdzyxGlmT/vuvNQUGCSkqCCAB8qRvjny1qPuu+eNjy7WmD9/B4QnRL2V6+hV FqQvbwuFIj+LBWP/5jA5pw28A01WY8kmoLvUQStHo6Zf6XjwqL4acDwm9/GlZgOUESCUSwDhUxQx ab7qNyGONWp/mPxtT6XD3Gj5xNRh/XTOfTPRnOF6ByxtV4r2rdKt+Lx22iSoZdafTignr0OYEj43 qQtsIQ75HpuKQ5fn5yiqwNp5CgVff8CMMbiGXF1CWKGiSU+Y+vlUH7UMXAcfjSBMdjHCPAkZp35F 34Z46ykxZKJ39LmaBNYySOUiwAtkevIKIcVEmfuuR0RMlzO0HqatC/Gvgl4JGnU/uUzwuQp4zG+r llZ0p/YzBdUVz2UxNRM+QiEsrBLImIEIQC90razkDPTLpRpM/nwGQ2RrLQiLOLyW16I9PxcTaPQ2 LS1VliD7vryMRAvjVrzi4FE2waJcBjOUqry0W6nT2gr1pqiaVFMRBqgXTVtqbiqMM8ekoox8kslQ YCpHFzeTuGBilayBWyno2lugHGGNxN+lPlJMVL16KtUuyvIKKwLoQpGfmERcZzybkYuT3+1gvcTl hfWU9JCdwRiYcDKoO3q2aj5f5DFWXVLp4BOxIIVhID408JOrvPJK9sFcPIRzRSTea/3X41hDJTVr fFRY/IEAtX+v+dNLsgfp/Chcst1jvQb9FuYH6NsHPKbI+4fEfWcmGz1eO3zQx9DZNfjjdO66pzXp QfkF+dyoyBTDXoFNjryVT5fn5agUoeYabkUtz0Hxj4ij29KFkqrio/vYkYGMVpKqffvphuZq0LoS uR92EdBECsYvtLTnfI5cTN1aIBYyPUsSo++RP5BEMtexavyOtHVwK0Sj5xYBdNnokqJNmLzeKoqj 1mT8DTtasp/CQynJ31aLLCaU3sapzECGqKQUfzGngjNQK46ERMFqMHOI9rYiGuFcHrMIjg92aPWr SpDK17ITgTE3zmJx5LDsswH6BgxL67vU71rgo1Ta6kDNjCe08lJJRYjCUhNcSEdRL+Zo5LCUGmeO CYa95WVkbZzQJJN+4HzzgOBmEn/6q3zywZSsAdy3t0A5IjR/VIvJgTPmivyUUgjZpG8YgqouFPnp jtFygeTusJRWiGrWY8WXixrnARXKkbckwapDDJZWCu88xQdl8sorWYdy8RFmRfS8cR7z9b7zOdZ8 JjfM2mRH2g7EFbOIR76rsPgm8NvntSsKQFsTb8rnFsjIPPLp8oo5UlAzoVeVdSiiyce/oa2ngYv3 wRpHEwhALX2VGHkUaxtn/tC/e/ik+676DB8PSWTdxw5odkVWsBSyGdiR3PsbcgZWgakhctP3f4Ew MEf4pBL005AneZsjT+ivgYU+mE573qov4hXMt+gXw9Lba9MohcXCpLKMbExIgkBgBzeW0kq8KLX9 O2RvpQLbEb/6e2pYcmPQ+QV09yQxVh2sdMUUQkAVwyALH2Ev3/iAEbhafa463q8lHs406fPQMLuY fmZ/t+grzVNv5mwQAfgj/hDGV5rdC0n82UrwuRbHC8EnZhoRiAg8bwTMscrnnfFzyu9qt6GPAO5e X5Lm170En5OhxGwiAhGBiEBEICIQEYgIRAROQwCMcxcb57/LA+9+Pi36Vx8qvdzY303Az/XFamPP n9MYAazd+5DYyZ5f2RPCGaWwvl/Yq3ALRQI8frdI5WZR7oaBEOsZp6G6vgyBqkUGUUaOeQWq2eV6 8XS+uCx+xa5E89PJD90EpDjuCiI3df9XFWnk85LBl+oFPRHwX1D2X7dsX3bmNP3JG9mbRFtxaLPZ S3PxKWPZGpeuzFYfOutNXxTNnvIOq3Pa+vVmyofcjeyGH4+V4n3R2DKH3apqx1H9w2dcdrl7ak0j etnNXTEQ0hn8KlQzxQbDG+r0PoSiSHSqXXbZVaF6teYv2Na/m502NXgi+WFRHGzPwA7V3uKY0MFt tUnPD3OHT6rkvKNiUtLejKrxDjW8SVIvoC7cRLzXLazLnGZTxtFOBtqyknMbXh0sQkjeEsNP7J52 OXmgAk4RspluISWC81/7q4fYY2OgxVaT/Id+mu/ANMGcvMoJ7lR4l+KvlPbNC4bYinnSk+iY3tdb o3kPNgJe4jSx/pAomG9xznRxPHyONkQdguPN/O9anoI8Js4gk3yKI2Kd8tF+xRW2I5LDMdEOOFcR QOqsU6k5jBB0pA542tSaeSLMl0hoqwOZpgi0gkUE8nJR4T2r0CmHGAhNptV2ZYLRzSmocquovgOe 4YBAm751XriItIfoB1d4Xo0qnSpq/kTGhkX1fXpA2ikqBwaJd9Ein1SQXlccyGJP2XEN8q2L6hQv fgVqQTE7LjPPPimFQ8q75fXBxhycUDGFSodwcATws0bmRJz40BCQ0t5FbUViXbCWCqZWSyyO6GZa bZkc1+PkdIuPwhTqgt22qPuihEzUmdPDUhpU6VzqTnoarzIEcoq5i9QjgaSWXHrOtbfSLp2Cp/96 nyM5bMXUP/Gk+ylXk10FE+OTzQPdb+dENGOYSeSfNdE7xYFBXHTAqmGqOT/CPwW3cjrB3eqhTwDI x+KUatIlRuNjDkGgOep/Bo04mOFIBO2eCMN/8fZR+yfZ9H2z4/pqu7qgQ4500elj6pqCQGBF4CA1 ao6+C2YwuYgd9/FaTeLQWUWwJ/GBLM2uSQg7rNFpCEAjnqFwvP8Yxx5VSXkjO5cqkA625OU4WIUQ +NBQKJBsYR7Ro5useyLGKykuylxCTbQloJyEKndFOAYOJQFni4+Un/IA5NuPO2AOoYFtBap6qAK4 Gh9fhg3AsxNxK9bZIk2TWKAx5ErhFQf5RD64Sqc7TfFp67oghjEBR04GKWz87IL26aTAZ5lVdPwb KqbqWo9j0TTBW5K1krOlBAbUtA1PZPat5cnmD0/azFoPBUEqS2fK5HKaGp1ptWWCXDpvbRo8rnfP u1HSPs0sga+31utNg1bW6KhYp340FVh+iA/9Q6buFKHj33IEpLn2SSBV9WeOvpT63piTgYERWSh1 pxV5IFUcPgv2ZJ36pHMqBYs8kDku4Dim76opDkqk/uEFRit/+j/hwp5s0ObS3EVOam0EFznVAz8v rmLfhzzUntsEd1mAAJA7cgXatwAToArGvIV7Gllw19dIpG6cvqu8U7RmzlnChOfH+nYDSAe+NJs3 14h0ep+qklB6MiOB1dskBEIAXketKULhL+vosk3mRZAq0kgePfEpSxyNtLVj2cI8oj4DocnULylt V+M1whAHQugYlJ2vSaqAKpcOlzV6DvaFeV0ygAMNWJiYqApV1UEizEsNoEAPKLIFyCdVpaDe0fZT 1Xz5TKesvuJDwMnNtxzrUqSFdHI2fdp7WxFciGaB7AL2qVNAXyV92n2rmIJHFFla67l05OhxadYK GfIgbLSCDIlsW4tmap2gX6qIUJgrQ5FIKPW4bVddTcmUWxjVOIQsk+2KCc+P91Hc6fQLcIHqsb9p kWAAaiaZax+f1EYlso4JY9TJWes2is/LqzlVFgOdQI+6U8oj/q1CQJrrEAlkXgRkJGpFw4Tvv63p mJjSAbymun/OmXFPQBeZ0Bser3bLJ8MP0zb30BQnDCVL0xTwBswntjoe8K0Em96HX+IfyVf9DuRV SnBHXDToHz5qvfOoxUc2Rmuyf+lW6QzYFAtMgBxMN+zUYgh5mshEf+2qpJ6rY7lOJ3wPthbdoXXi 5qd6lSs86MrIgajiFHqbYQB5pUnwsZERDjTJM8Q2ySXLRVCGgEz42A2FQ2JJWRepoiRLGbXxb98q fPRURP95AFU6gLZ/SoffiR1aroxorsE0C5NCc9clZptqVPXbMvULdmKXuEc+yWBeVxxSUr51aXwU Vmtrqk3p5mV3TQoyqtLIhIqppNbLUVkh/jqGs7a5Rklru9R8awnkpSVTtbuYKYNZapn8aQOGWiVC R/iL1TxQFwT8XFqGRdszjR/ffATmAfoPqUGkInWnETneVCGgcMboAy18gQTSKgJtJEhIHl7YbqVB qwBUiNLw2kyMerTLnFGPuh89na+IcV04NPIoVKbff4Kl2M7nAYElX/UqkBc5piDBHdmbSwDodMJ1 XqqHs1XNk2YCDFQTTzI7DF5ejGiq8Mkiny/DzBLZauj44dXhQHz7m/tXGY0UQHZBOIPrlS/93Rb1 A/9WAyj42MgU3QpXPWE71GyTeckGEUChSLtayiNKWVe6lZBV5MQy4raMori5BlUQ043vwV/QRSvg 0iLRbxp0APD8v8bHRGlehqpxOkH1Cy0zpW9k4wlkl3wyB7OiOOSVraOKqKdlnFz4B/0TyO5mKYSK ifIN1HrBk6Lg/qSsISLNGISsRbUAgbyMcjoj/i33OZihouEhknYrV7vVxT/Rx1wK1TxQFyjxtx0e XfWEZ+R4xqNIl1qg7tRWZySPN0EEhDnNJ4E0HgTx8iLmUqA5efTeG8SadbWhb7FhWjJAOieBkQJX mXe4V4nvqgiDJaxa2hxma6fWILyxx0oKqQXywsMgwV2IANCuj4JKgAnQDpYjIBHUXzsMzxDCwy4v sYa+3dBG6IQ7Ua2PMdF3ub1/qb7/rknzMvokEK8LMHshc61vsCuJJ0a4KuWfa6wCkKetBB+fWtOS N8A2aelVhsC1PKIBxkuTaaCkRFSEsdEzUQrPA6jyRgjNhyk0njkVIdH+YBYILGf6k6ZX5agiL0Gg TH1rHpJF1DKzj05d8klO6rriEPVt3bUMvHPj8XR9lWwMy6uGJZRdIAVF+EnUiLzq5Ix2A8VUUuv1 3CxTpL578ZA7Zq6mTtbAmT+QxA9LrSWQl9ZNdVbdTM3HiShMoGh4Iv2d7IBvudKnBB5Nfk+1SS3y qincFShV0cdzaGYVZajDoyvFQfn4dKkP1/BWbGlHmbrPLuYuPSzFjJeLQM6c5pFAkiXreUiYvd7W S6Wg1lbMaiM6CarbUMXEiNI3S8mPOpi44EQctwJXhTTfVwv3rpTK8OzJMS8vRAgS3OG5RwBI9i/d qjwjjwnQDkYIlK2t6NWBNF+RVL1l+gqJxXzIg3R4ZNMpxddRYbTcrwYroBrgZNlQtkYUvsddAiBx V+LKa4dPrZmr6LNN6gZNBfEQAJOzMPhV8IgCYfrqKykijJdWll5JWXbFCBfbbcS1ngdQRYALoqNX 0H1bfYnSoGqyNmsr5GLKUM3dCmlh9ocrKkjbAEyyIlvmk0+SkVxbHFJSduLGuq5WnygkaRLGcQqB 7IIpMJe1QgaTge7Wl0Ax+bWexp5qPzxtkgebN9AL02zqSTBDQHpVaS3wDk+70mjU0dobRLVbcTM1 7p6DeUXDqcmuoc5PqdHwqjn7VtkkANdzxst5BR5dyxqRxuWM5sHUf8qbWIv4irqT6WFlAdTSId4W ELCY03wSyEJY+UkVgVZb0DOUR+pvJelcJc8efZAx2HS7GVi/KvOywtEtZe3vWy4EUsHyiXrv9d0/ yPC1uOLIurwUKgG0hMO6Q6Fc6OUJbJNBBCDP9Zhgo2YgSy3TTUrKUqPyFjo626orA+NlOap2zFMR VnFOI58kpsdybPLcce6p/ZFaJ+KetudwT8+u9IPpoWKykWGvR9NEBc7G6qwNVaPCucJa7LyM5mWZ mgB8EygaL7VANffBD/JJ5nl5dKlIoYBGHjje3SUCF/18JeUO0iW7QifB3Zt6B+nGJBwEeDyIbvDr zDbpKPyK/bhPzPzoV/PykBqFPW8N7vSk5KnCv5BMTxUuhnt+CODI1UkdsFMlSi9Bb4KZ0nh9xQi8 /myTXzGAX3Hy6eV6dbFan8okc/fS8PHku0+2OsUXkmm1SPFtRCAiEBGICEQEIgIRgYhARCAiEBGI CEQEIgIRgYhARCAiEBGICEQEIgIRgYhARCAiEBGICEQEIgIRgYhARCAiEBGICEQEIgIRgYhARCAi EBGICEQEIgIRgYhARCAiEBGICEQEIgIRgYhARCAiEBGICEQEIgIRgYhARCAiEBGICEQEIgIRgYhA RCAiEBGICEQEIgIRgYhARCAiEBGICEQEIgIRgYjA3SJwfn/zR/WJoXS/uzf77Wp7nmeQJav5b+8t //jldrdPL/Lncpfu/3h/b4WX59f8TR/c350cK32w2T64EWO+VuTffVmaiy/AzXO5Rkf3tQAFtP98 yged3NjxV0QgIhAReHUQSH73Ru29ewm+LHr/L2rv4f57Z/dF+otPO/TkG+2/fb/23vsLBCpei+57 b/R+V3x63e9k8Tdv1P6l/dHRQIxs9736j5b4GvzyX14f2I4vivw3/8OPyyJymj+z9VFPrhHJzuWG 98seA5X8VqN9UvSLzzoffLQ82f+elGYMFBGICEQEvmIE0t9/s/YBPEa2/+03aj+YqQ+q6zwffFB/ 7/35n4/H84/r732wTLL0ST5qyJ7gE77p4c/7BKOYC/6c78V+9+cD/ZQrO9/t/pwgTmZFxMs02fEY J8ue4Fey//P+UGw8WZ73PttfJKtP36j/7SF7opMyaScJnhy8rn+uiOTCMZ5Atv2BssNFadY+VW4l PTzYHZ4kq781T1QY9W+yf7DbkwZyOenwQ/dJdpFlxyx5sE9UXheH/Z/xdbLV8INv9H9/PEKLBxC5 TPEDsts9kPwefFB77y9nwF9dbkZIhBAwgSWU+pudQ99c8qJUxaRSu2TdlOKviEBEICJwMwSUWzno ocobtR8upRO/Gv4QXWv8983Bbz8it/L/jhrvfXP4BadPjuYvJn9cDn7wRv93R0qEQqr//nKyQ5hk fe8b8uQN9lxGsGT5M3gK5LMc6CwoYvsX1mDhfNRUqf1o8Ws0+CbxH97bk9vaTDCE0Q9HywcmZTPm giL35jqXbPeb70jgb/V/Ax9h3Mpy+COTzhsNEsm6HnzcknwbP7sPH7r5lVHzm/1fwzv4T5IlHJaK 9bND9scPGjoFQPGtwe+P6e++wVAEFM9270tgwDXbXRj8P4JD91RYnY0ko/dGpsxY+sPy5+bVG62f A1Vbqr2X1JFHrO+7iVg4xNuIQEQgInATBGS0wq6Bhi3WlXxUo0EKRivsVpLdjCavaECz/7XyFKsB d8LT33+r9t5fjGn2bD3+8Rv1Tw/HBFG+MyIfxK2ck7Jp1dGHf6P5cySYbX/1Ru0HTu4iGI8jPvhs i87/A6RJfo1yf++naxrg7GbwLz/eWMMJo4jk8uSnTXhGnqlLSM7RGmMTGq0ctveQzicbpPzk0+4P Cm5lcwaP8zdrGg398S8xNzi9j9y/Nfwdjb32v0U6Hyy/9J4kLO0PPln9+XA4X49++Eb9ZztyY198 j7wz3IoeG/qKb4Bb8+cM//nHjfe+gcACO8TzVPj/MJD5zviPEG41Gn3vTPl6/MJFHvl77NmPBxqB AlVLqgdeUlD/fL26Hz/4rOCL/0YEIgLPioA0dKbFsxLUc195+5Z+geb0p7uLDRrM9q/QXi7FraAb rybQUjW/lKBbrp+gWf5eYbQic1AUndpP9Pt1e5vnLk/IBdT/Vs11sRf7nep7f7P5o+/QfxgOlPkj nulKv+Chygffaf3oO60P4Ee+Nbqv3MqXGDSZqTARyQiAgRhPW8mDhEZkn+7UFN/Fp+33vtH7u+KT /u9sae+p9RRO4F6PUxOlQopfbBa//qj3N99pspC2Wwmo8MWsR8HeqP/oo7Pf7m2viuyyB/fGP3+/ 8+Nv1gEODT9zqQJJmaU00TT+jQhEBCICz4KANHSBhj3vLevRCvKZdd/7Zv8X7/NSC35abkWPR1SL nXDz9clWNcK771S4FVpxKHcrWLK3GnyVHbuVDz5d3l8tf79a/f7e7HdOuyoaGUngCv9i9Nv1CoG/ WMx+s9hgTEEeh93Kz9TMm/aGJIq+lv3craS7L5b/9h/hRESji09a733zh39ffDL8wpZ2AbeitDse F75bcRWn0Qr2RQzvLdZfjOCzcrdyfmRvXlAhxcLK5vefjH4G7dxxFs8f1n88mvx2tcRwjMollyqU lGgc/0YEIgIRgbtAQBrhE91Kulbz9n+j+rhq+GDHlRbsCRZi3uje2yXnyzGmzn5oT3BJmKOODj2M GEan5HffrP3gU3EBanJOe7H9bzAU+mBGU0D3p0j8RzxVJTElKcmFZpDe6P4KKWDyCo7go9W5frX/ DVryjxZYE08+wZ43d21lN8XixY8Wh4tjSgtP35lsaW6q92ukk2x+jXQ+Xv3ZeyIpsyzsKUarw0W2 /x1ScCbBaJTH83IiLbzYG93fIB6WUeApvkVrWOTNvzfBqo6nwm/+HcLwbgogADm1c6Rs2XF8b0rr TZsJwHHdip/U6hxr/4vpb9a8aEUpxCsiEBGICDwLArQswgMNad+sxGiSX62tqJ1g/Iq2h1ELyRfa ecwpcVNmjVbqvMkq3X3Ay+7faPzA3gmAeNSqcxgdHY/83LM/YkyECa7Pf0WTYMqtwA19c0DrCPdn ZmX8vY9or5p1SVImF7Tq36Ok6L9v9ci/mFf3Z5gH069kacMkdf5plyeasMW68wtaANr/Vu3BRpS/ kEWWwhNO2Sz9w1tBd0offvA72LktsvmKYwUKYTjwD78Dj9z5VXq8uNenLQ20B89Twdq08IOPyTOa 6+LeQO9D+Ebrx/A+KBhbKj8pLNkj6495rcqkEm8iAhGBiMBzQiD5PZYqZC6oIs/zT7qjT1RLRSvs 7vJHRTznFfYtW9uVnVf48SRJztWaS/FN6HeanCehE53Y/JzozcCBaFl6XnhLmbprGf4TOyHsJU5P lDK7SD0JsanbpFZUgSQ/d2XRYRGrEjps8S5Bw2QWbyICEYGIwK0Q+De//MM//B//94n//ey//1+o O/1fTD4/Icrov/0Qgf+D//Cf49//+J9NT4lyohgx2FeEQJI8vpURxUgRgYhAROC2CKQPVqudmo86 JQmc1lstv9jcIMYpqcYwEYGIQEQgIhARiAhEBCICEYGIwNcDgXS/2Wytuf90u9mWjEfS7dbeyZts 1qv1hk776euwWVlRD7vNarXe50lnh725/LN3yHe9Wm30iyzJg1I0CZ8ij9Vmp4/jp3tIVCIsy4Rk bO0O2401dEKOu1w6UeKIfbv242QPsdYbW3FXVIp4WC42kkCpmsl2Y6EhwfGXswgokuy3VoTDlvFR EnOpVWluJf/8bkmq/NruTKlRKVjSAkBAQYazRxkIVQ1+okDxE3pbaKjAWokUViWlj+Ccjn6VJbv1 2s6FkrNLX4fDn0IRY2dfwZKP2Wa55CJPt+s1jNyzk0JdyNOOdxGBiECyHNRqtdZopaFIFvVarR/i 8ViftWq1ut4nnKw6iKau1git/HY+PRs0a83BdLo4HLM57hEaadXq4zW3KIc5/dKXpKNyTXVqHKAx 2aTJsi8h1d/6HGns55RojUI1hwtEpVA9uim9dhMEniqis2zTpug99StdD2u1xqrYXuwGjTzNwxJh tBrIkihpPFGz3XJyBjna09l0hZaoRM10O4XcfWDjXsnqjLJQSg1sXQ4DRNDapdMexOJAtcZslyl8 7D3bbqov5peyJVZH/mkNgXZRWmVjBEVCOtb7qkQg9LJHKq9HUHag3JBKszFYKpUWCNCaqPvCK4W8 CQlfP0QyjWER8aNTxNgUWLBkSjxbNWqN5cNNj2yNr0Z/m/efjk5dUNLEfyMCEQFBIFlxy1mrjVW1 SZdougfLYl3MtmOuXU3lcOZUu8dUz7IVwo/W6Xau02n0xruHCwQ+21CTvejX0eLiJlnBfw1UuhnY GK1rO4bDUq19Nu2gmUHrmqV0EQ9XF23DYI4nE3iFzgQxsw2Eqc8PcCt1DmylVbzdQ9LunNqtdK0b 8CkPsNajplZBoiSbKeTA1RyqRiwhx6Pu0xVeDVeJL2q2X3RU41PvzHdpUM31GFLQ5QGboOlrKG/C /ghIKnFWEI9yJ3efUhk1lRMBCPX+Ml2P8MTziaLJC/rLttQA6bS6lCcdLLG9mYDMuyq5jSWsZd6r WQ0a0I6NranSWXD/RLzDAf67OyP3zvZQrzUAfXst1rSfEc7K8DZjmIs2VyUP/vWK+OhbMgVDX6t5 9u8nKPMuZ7aDEfakS1CoCybxeBMRiAgoBKgZrHeHXVRP7jSmS+opFt3KlqrV+KxZa3DjdoCH6M/X q/lkMlvoeZodeuPNTrPWHm9R5TFxxXX9MIab6MEpHNejFjI6Gw0Ho8nG9VrJlma/lDzUHbUGIBRL V23q2cowKoEAqOaHxaBjxlklJbpAj5MFQJPV6E/P2nAmJCGUYVHzaOtRpztezPrUsvHTDBsONnqK Zos+LbWQAVH3GOC02hipnUHlkJrJqN2ZrNcI1i8Cu0c7OdCuJEUnXSmovEavU1d97yUa28F8t56P x1M9zYhBU3uk+vO5Ai/6TrmPlTTyx/0MjTx8se9WxMbIqzY75MxVr4Y0JfAJ7SF5TeoVDOfTZq0+ g4HQMIdvoCkPeabbDQKIo8FT7nvUh7v9HFn0uDtho+IVcciSqS/UgJFk6eGQkI9EzwEiovQ5qUJd sJOP9xGBiAAhwG5lmGRrVJzmcA3mQn+0MkfLTCOONXrW5Fa4t4mmoE6NKU1icI8OlRCM8AfDVM99 bLyuDVaIw/Udo43BoIMKX2vTM+/aL+Au0J6I1+GMZOKIeoxq3AGph+RiJJiXjv3gsKCWOz2m8EqQ ZI/ufhOzKBvoO7HWhUwU1WE2P/kmnZLb7cIbmcsWFZpDQda8Qs2gzPRQTehluxmA6U63GIyhnw3t NqOmcnBq5EJwt2hcNOZhoJHk5blh91GrN1u42m1yFrVmHxhXuBUUynC9n6Foa32AKOBnU5TSaHNM 4Jha2yM53O78kK5QlBQM1wYj3MYIN1vMzdaHuTUlS84YpjY1/o0iWJfkUmbJ8GV1YxurIdk4LFbR mRbrgpVsvI0IRAQUAmrSBrXyMEedrU2Wc7Rp9mgFIwLMYMz3WbanxZEpVi8Tmihrn604BepYhlv4 DLRV+9kAtbyDKom11q1ewqUuemeqpjLycthMSYDuxKx9H3eYEav1JJw9ERFsovOknDvq1jYXW3Rf eV6FVlvaC1rRUPMbTlj8kA6zeY4BF/RuYkXDPPJFNa/K1VSjraIrPCwxnZVfgyW3sc0zlAjNH3Zn 6C5TyyYLENSsdWYmu5fqht1HfTCeziY0yDQI+24F9sM2ozBJMZWK8K2zFRyo8qRU9K3xetrFv9CR Ziy70/lQv8UohhZlau3haNTnbortanfkpdoymxhAKC/ioCXvp0ZyRIYVH3arfoPmZgN1IZB8fBQR +LojYNwKKtBULxLUhtZAAHUwb/XoDgMWmuKW+ah0hIGDTDsrNLPDejKmNXa6kjmtg2A4NJ+ttVuh zmfrDCOj/FqO4M1qw4VZvMWrlCbdeHGBw1ETJPPbJIDc54mU3NFMSwvTc80RmmhQ6aNhbiJlnhnz o+RtDt5lvLxb69hjq5CoJpkKNcNuBSMdbHSjjVIZNZW9xRfcYFqQN4ZzPOpqV7LFkkFdL2ebXF+S G+U+9CTYngZfetmIZlatTRopbQthvuscEx5U1pq00sQzkPspugHtBhbTaIyYbtANaML1YEpNftZ6 g+FwgP+HbUyNWaWZ0rxuFURWEQcseTfp1Ls0bbtfTScL3alZoQjqg18E6sJLgn0UIyLwEiFguRXU Xuo04rJHK3rxPKXRCir9nJdSqD/YGNL8xmaCJmKk9noZtQ40qd6fo0pmS704QsvfaCPQsB9WtPpP a9PZYTGdrff4Q+OUzni53++22HGq5tF4Xk41Iyph6r03BnA8OxpYNVxXZvIO3KhJpNZYj4Ooww/x SuJbbQ7tH0BG0/WO5aLdvmFR8zxDauq3eRMKWDbz2ZJOidISj1r62UyAKS0xy2aFDPqitcQYiZvr 2mSDdzta4s9dbZ7xy3DHtqRW30ic7YTgo3EET+vVO2fbQ5IctmOaUaQBLDRDay1DXd2raepNXzSk RYdE7+I7bqnbUWupMYhaZzcqqwGe2cDgmLQJZN1YRQxG7oIlHzC7pnosvD2DZ2vTDY1WIJgqG7cu WAnH24hARIAQoDpode14mO+6FYMT9Tml0Ug3aocOqnp7pBa4TTi6WcneJzSVcBd4YjbhIEpXTaAl S7QvmFofo7tpXXpzF2eXbx+iJNao3erqz+yFDsqx4uIV8NpEdoiyjnpjlR/Ln3g3ovUXX4ZFtVIJ qKnf0sSdLPvSlgM4NrzBdik1d48mdOQM1mjmx2weWPBojiRpOjtdrZxf/K0aU5jmHT0I6lPwFt9k PRE1SYeJ7oe4k5npCr5D3MpxgaGBTP3B/9LyVntM482U1gH79nJ8ukZEWpbiq2DSPi55EVNqriXT zkbZzJbtRjJ+r7UGTtfJrgt+BvFJRCAicFsEsHbCO2VK4vNOmnxBgkJlid5cUxLlhMfo7/JBuhOC vrAgN1UT4auAVHrQJP/1oV6YzqdkTAbzUqpgWXJWkPCllfkUwGOYiEBEICIQEYgIRAQiAhGBiEBE ICIQEYgIRAQiAhGBiEBEICIQEYgIRAQiAhGBiEBEICIQEYgIRAQiAhGBiEBEICIQEYgIRAQiAhGB iEBEICIQEYgIRAQiAhGBiEBEICIQEYgIRAQiAhGBiEBEICIQEfj/2Xu7XjeONE2Q/0H/oC8WmBui dN3YC7YvZwGWbvaKBnZuCF8M0NRcNetCaByrt5vawZbphRq0sbUEtn2MNeh1D4UpH3e7Wa6huspc u7meTlWLVVqWhscA3Vq2kAdIQ5sj5JG4z/PGR0ZmBnmOPqxSyZGQDpPJiDfeeCLifePzyYBAQCAg EBAICAQEAgIBgYBAQCAgEBAICAQEAgIBgYBAQCAgEBAICAQEAgIBgYBAQCAgEBAICAQEAgIBgYBA QCAgEBAICAQEAgIBgYBAQGAfAunJcrnW/1b3/S9ZSk+O1w88QnY99wTd8Qipr07wqq90c+9440ti R7zy42fXpCzR832zWvLFw6UrS/Eyen3FfNP687sSvIG5kt4TiX92CaXkdgvMEoPCJo5xG/N1ybyR i48871/bRLNFDARXS3ut1knx3W8lDdTXQhSJu+Hb3Yx6+JnvdOaVLOfROimGX0EX9esL/2s0ZMLZ cj7fSGah3nw6nc7mq+en2AvLcpasF1G03GjAF9Mp3o995gX1Cq0p3SxX8ZmxfAFcSH2/v/BnkrVz QPDCFXthCSbzGxdqV9x/b0/vl1JPZu9dqH1QLfJdz0vR93xN5h9cqH0EybPulQsHt/eE9P+UrS/X r8/T7bNr4pdfeJq/Kdh9vBzJW9b5PmBcvSpKbuBz3WfLTr2FTCFXkDg9s3ra8FXp55RQjbjrSTLV KlUSTeby8nmCoK76NInxqnr3Uu+Iz2XH03qtPo23eLm8GwxvHp6c5U4rUWq9eWwRS+YHKAtBLhu3 ap3Jphq+o958nWvzQu5Sp0yzCG/xRkEvxl1mv95QKHTHS6iyPjpoymupfWplR52GeYG173d59oxZ 3qtAnuhmNhDl+aczWuCH1bhdawzPdNssogO+d1tdqsiepvm4kBppz/B5Lmz3yy9lbX/gV/LXJPr4 Qu2aeWX8g5uD6/g6Q+lmp1mGlwSfbJKH2zRZbx5k6UPnbb+naXqqngOWLHuIv8nm/iZ2RxynMZ/g p9Nq9zONT9bxQ0n9Bpp/Gt/fJKcISbHZg81G91ghc73mcMZeeCnsen1f/Zxtbl2sXflkk2siwR5u 1ipd+YaM4BNZWJ84+kPbk7VJhb+nD91UJGbpTzKAFejPS0+n3XpjEMnDDFfp1y164ut1sW9ceJKl Vil9m21gbGtH6MXyhenNeZLFZQmFRPLw8hijAgTX8LmvXE/TxCSVIMhadZMLovAF7z/Gb6bLjBcd mzjISQpTkSIiPkqJihQGYG7SJaxkoz+lNHmGz2kPeeoui/BMuwhG6Aovl8/WgyZeYq8NTlEfSUf+ FKLYxya/fJ19rS9uZQkbN0voueq9vOwWow6soNYH4yziweEVLl0MSqZ8UcWaxhvgKiEIkTukKuKZ CWQZZMZuII7m4jSZN0UfyEnm/VrzMNvG0LU7WasEF+yltJZZNj2o1w+mFrBCsW43cOE2yi6I9mWZ rdWtA26m1X1JgUKlVarK3xXU7R5R+XhKVy5+YYMKMIgEKydo6bZUgk6RMWBRPT7R2dwLKcPpimpu DYK2nVXhkiemyRSxFSkiVLULkzoqNp5CyU1hgiJDHUE1igaFymaFfH9uim6FUF2rXfnR5L4zivno 6/lHF+of/8PwLfxVdWWB++Zn/yLP8WTefysf77Q/Y9XK7l1r5IOgS4O7LqRzOi/za4My5/2rF3q3 t+md18zz95eb99tXdbD6ewtJeDEamohX31/cHzaVkOuzX1JDBEmXn1sJr/W+RNlLRt6C95GIb93c MI/Dlkm9/t6SgW7j1zeNc3VVde69biVBh7xxMBgO+odHHGG4V7aeNNmJ49Xs0USky7Htlzd6Rxhm waToPnw6Q9d9liRDHacVncAE5VdnFLnCzb0T/tvlgZVea0zWyjE15viMhhDUPVptt5vDthlC1LsK VSNquxzDMuhrON9gkgbGV1n4CTvUvQ2VhJV2Ei3lebtdDFtISltJEZ2tx4h8uCgGpQuojaEkS79R F/+iNJnBoopbKetjFVVRHDehf6m4lXQ5rDUGUsEKSayZnzbcSjwnMvpqDTHgGaLzoPsJyaBea49X bre/2e2aQmkzQ3CCyK666l2aUsmXeVRTQ49kMTKg4xd0FajvrNdojVAiqgqNzCRSulwsN78+VBKa 6MZk5WKN4Hfl6s/jMyByULVZ9ums6h61klFn75tlrgCqsc1iszcxdpqB0whDlYPFenk0Gk/mbEnq WqASNw/tV/O48CluJR+txHCyuidQraLppGdQN2MiL6RMIFtCW3FqGYZNSo0M1aDWBtZVuKJD1HF9 Deexi61R15P6vJ/rU2sfisVb9UzrQ1mz4L7HV8WtPHinceVi77Y8v/phdD+OHyQRJspuJLEaGgCs kzdhhKcn+jl6m4NrF5qfwmBnq88v1K6ic0i/07hBm5Ee/6h25bX+HYtxtroJG/7hEqOYhze6Vy+I W4n61y727sCtXKpdeX1we7M5+c343Qu1944Z7fRG+8qF7ldbUeCd+QkezfpI8bOUbugakjOaJG/X r1wa3EayGMhAFIZhKiOfrJDcCbL22uBuusAA7epNVoXknfb19xcYYT1YRMe6t8oUvZfPrSS0jehe 9vsHtBudsduU5uiit0d8sj5qNQ+WKSeFmoOZqDdFvezNv4bh4uwNLmMS3RuEactczXKMyr9jhs1E 5HRccygWi6rWUbH5U3M0OYRuvQlalUxQ1Lq820qj6054q67NEXJwKJ5mPYF/odVNF7S6B326F+un AHiupImtP1O6wh6Hu/aShDpH9ru6UeZLhYvQSJu98dEY17DHScUOPKBPHyskyq05guMSW22gsF1f WInmcIFYYi4aLV7tdouF1h6i4dM/dmTSCb1tcetbMb8H7H1QAY500PmEp8GTzZQTfSO4k2wBRGjV D2HDULIIHR9C8fY4EwTaMh3EoUe9D1eFUm4NI4rklBFl4vagVldeNY5G1iC1D4ZYbMLPqDzat1aL VTwRq80ZEKEoqlneenVGDkUrNCVt3o0C6SHGV32x/xxq1YZO9yChW+HVatPzNAfaloq7KXQtkKPS VSlBxgcwnEMrVVFCWp+wSNCSVEPwQqpTQJdBeikcSXHoh64OShBV3QNXjBIV576Nhh2ZF6WX101S yfOkLlWiORSLhy4TeoOweBxj0+IlEVSsTmto5b4fH1W3MqTtvUNDXf+YzYU4iVvZPvywdeXS4Tpb f3ahdn2R2efobV67qByHsfMTrJV09VqJdhkGzwRjHDgp+ZpqySJB3ArGGp9I/ZkPMAK6+nrrOv7J AOSjrxmYCzH5ZZLTGiYc7NxYYzINF52R+EdkRCcH9yfO6/iyDF5ea39wY+Z2q3PBvjvjVtJFr9Pu dDrtdm+RZtjuoPxRthqpCmbjbmZoobjqnd5wjsUC8UHKkiirXu/9TOqwgGFMYm6x7RN2C21fzoo3 N3mwbDk76h90W01aKfaX0rnuZ0qPHRHm7OjWxbqKbXVcFedk0ByarRb/UW1lZyKOPvREh1c3owc/ pdUfFDClua4d5j1ZHVzMl3aUjs1vttrd0ZSzU7v0UfHR1611DhdLrBWra8H5CQOFsY00ESppeq5W fzKdjAZo9E6rx3TeaHjQaTfYLVC+KULuUc2XMBRwE3owRYPp6EyzBuPDiR+zQCCOsh9Th5qygbrU 5MloBUkodggXA04T5xrebLOKoFyLanAc5ExhVYrVuJWzIPJneYfOFbeipg3TSKqQck9Sr8RNq1IQ t1IfS9bkvqlH7Myyrj8qZPUvS7A7Xm/WK87GbSJ0nOqct/RW0XQ9Pxyg2TUJDyqzF1KTRjzr1eqD 9XJUR02v1Q8XK1VYPriyiRrh11v9w6nMC1fcCqpVKXWnStgq56LKCczqUNqo93341G5F+Q9kWMYL b8/NCEUgMG5lG88w1/TB8ODaxYNb+MU+p1uBU5DoavgwO8Cklh6h4F7/qqTRrWjv4HMreqEHMi80 P44Wd+fzu9H81mR2/C1HGe9pk5Xcm83vZcqtwGAr9yRu5cOVditwghibWCWRuNHzFEs2i9lX7xxg QHTl9UMZEolue/8Yt5KtDnu9fr/f6x3++p+Xk4mZO6s2JS6swNIfdmks6tOvaXC0edlmoxbaxwwV vs2ZEBoc3WOknMYMJaJuxOcYO+lT0IRXmwcOBqPZIhqym0y3AgvZHyMppIJeG40V+oTRIprPo2g+ nczQO9CXNLrGeJ7/ploZO+HQvnvEkFYlk6iJrT6lZ6tnkPQvKxlnSU+hENYx0WJCnekaFW6HPlpI ad5MPzXqabgSeLSOgFtIQoZ+alJOZvPq7eF4Gs3RK9CmFd3dRu8Q40/Va7UW3ikFbXxkPUF30eMZ fIxyK0UTLaVwWHQr63Gn3pXlp/URhjKRLQZWA46DbKKeYtVuJTk/RE6Wt7t0Vh7BdmC0AimdbHs4 RbWA/55NJrNl3rNTrkQrT/CNK2FfQoNQKHXni82geuamW66imwnaT7PbRylFRxyKwK3Q9RchzWVT 50a302gN53BS9TamfVsRu3XoOJVreIpFk+V8NJRZNva+VMmqbq+IrKau3IpyHKbKsfCNK5FZXF0r cq2+T3fiVq58GN1br+4to1tvckHkA5hu1xrn99h5Jf18mcLKw8h4RMYmZvhwzCms6zdXSbz4HJNR 7iTYdvMVjPnbM+w3Sz7sXHEmwdTaCie1cB2PsYzyrswPJe9jKaT9uTgRFfF0cnDlQv3TNLn9Wu3q jSVmutR4SmbwDr6EgGT5JUYu70QF/6jcigR+S5yBhMc4K0tmR18tsPS/7zIzS26YzQQmtzcFYNmM 0zLaiKkgE/SL2zItJsFGqxPOTR0ciXpHsB6YAeZEWWuEJ7IdqEGtkhlCjdF4TY2FNGkR7Mtl8WIy zX0BEzLhKUomtdSaDryHkhDp5VRMI2Ri5NuCasz5G+mNK2230nz0XBkab62FPvNSZnbmyym05Rqx VckkquOqj2wBkaW1Wmpl1t/dwGpaXnUSShZmjz5WQt7XXemLWwmMesr+38WegPaRilJMAotrKLeD tdjMzhGd3pLbsbQlVFN/ZipG7SjgLFDVray4wg48sbuFOw0weYdJsMqEEr1t/WCC4ltNMOmCVNip 0GtqAlq9M1xghT+JZyOoUcckInFrj2DBPcUqpq8zXmS+IrMQ+bMMHTw603dI0W+IjFqN0gpQeQwr WPc2rAZ9dy0+w44IPU8bsaqo+VUFFIai2XI6mZud3lYxdVNUL8e2WkVPuMmwJZVeZhqpXhVSV7zM u3K+LpNqJuWC36twfbtA5g7YfrcrM72GES6xNfJkEFpKPa8StsqJ9+9EcZZtZgAiTILByNt/lzof q2Vc2l6zQC/3eh6Jq/P1G6q/Yp/DXF8aSp/fuBWsm9wccCxwof7WG80rr5mRiyqr4wkGLCbR5qeo sVpCeveSrJVIsAc3umYnQB2LaXy2PLIRr0/WD7Ex4M065Fz92ed6pgtLKm8YyW/IIoubEbg/jF+w yPJ+x2wGaLzHVpLcvggfxEWWPRfdSlNmyN1A0QjdFHU1j4r79UtrnRh/oGGiyqmrLYss+SJ+E7NS LbrUbIV+Mm3LxkyY0KAN1BSBWLbiIosJ/+l0yHi8KIsLPbmJS2lLWlhFTcZ2zbneUaja7KwmataO IvpTzHZytaUvCyUrWt3mfGNspklU9QG0BEnODN7UM66Aq4GSTcUEZrdcjd1k9dbTuyvp40qozsxz JYKdWLoGolTvf9Tm1mIVC/NshXmJzQSpt0e/nvbpYHDVW22aVr0qtIFNtZYBBlCVuxKLIkKBYJgp W3zjUReS5Gr2ONUnXWUFiw2PcjfJYLKtNYtZsnaHR7I8stsooMhgygFWEsmiefPwn+eVYuXOOijL wdReiLxZxqC1ojPWnszKdZ0DA65xWAW+3cw6tmId0L+4F5bOTf4bI7MFZIEuSwurityR4u1UQEKp 0C1WSLlcRdOF3YvS6gBIbr8vQ1pUSxYHOUJBh4zFOtXVoAqXs4hfH3BKPMdWZ9OXulSJBQPkTSwe GZiAVutQftUiwsfzQWA5+uDyUE2CJVgof32kuqWO8Oxhgq3LZ11Z+qAcjBEf2L4E9yRn5VEGAqRO CG8iWVKR7A13nodZGhf2krpxsF1Ttt06z5Ik37Yrj7FputgqsEmyuldZgqbYosNV4NJlwnNH71k5 R8tJqUJJhPm67zcTRn2aRItPz/9ttmMgU5Rwfn2K8ZDNMs7lAOo7S6iEdsI1KTNd6Y/lPmX57cTT BpR09DeqZn9QN9gAjqtQeBZgX7FCnJHwNBB5dK6mYhWA+WQWC9qZ1PGJmSRX8xWG6cPKapoT/uzb ahX1pe9CerZME6IClyTm5s3BVkfypW7kOZ+E0BaL8/z7dvvFL7/++5//l+f+72eHY45H/uDP/xXH Du++/zfPP4nnrjME/tf/6laul7EuxNFkUhwTvYxanlMn9vT06vY5Y7yAYCseaeFIJpiHp0N7iQm+ 1uhlb0hPl7cQ63eOQHKyiO5Ei3uhef7Oi+KlVSBZLfRGupdHxXQDJpLS6PHl0e7l1yReLs7iSHj5 MxE0DAgEBAICAYGAQEDgVUQADGvlXR9gM7CX57hhiaTufKBoZjnQEwq74PkifSeh9nHcgTlvOplG q2fr9mLj1xybOqcg8nvCHOzTTYnayfVnylEjbL5aBfDAEkMuwb5pqF5sgHPf7FNyD4C7FDt3uhIw iyOwO87VLtXzRU02OCezMpyKxTg4wbSIFqsnG5sbbH9XlRnpl7NDykc/sU8xv9/ZN4OJN4E9taIU HmQ5qJy2OGLU2dw6pU9O4rqvrmIdb72YTaazlbvEVFLoe/W1whn41Ll3+P2MDDkKx5lqXmZPu/mx SlJnftn7qdkOE2w6LFMX7o1X/PE5EMpZYsOiZPmWLdSOr87//jeaN9ITKH/kpfWLI56OB24NOapX 73Af8lmXyZflhNwdoUSIZ7n+khk2fR3gbLhCuFqs2AZDvZzrKWkb95AEWgA9O2p2KrY7r9VfMp6n AbhtxUtQDVB+ondGSa5xIKL4c6JO94jE3vkdVQnqoswzv5myPjPg7gClOoCAthrsjvTd/lKtb3l6 tlacp1kJZZBsHofV50Zo1GrVOUsX5DrgPrHK5W2JDLWXtVXvSK+3wZsaLiCAfXqwXSQ2FKJE8uGZ PSouux02OORrcPmXAgEdtwhqVh8NrXqikK7QMHpJ6nTEveR+iu1QH3NWEc6ij9NinY+crC/PjWUZ dKDA1g7EqnDKiaR8byG+FqAQVEk3kcPrpI3bIm9eidZPgsY8I6CYXih9xb2+HXL6Ofqae4GLA8Mk s/nSnJCU5aG75GPPDk9VfGksnIoa4Wqxlk4cFGgbBasSj2Uxs0wa+S/xLsrT/I8FUD0qlq9XMRd/ QGRMhoOWW4VxhgHb0NSBBVHHJdhkU4CKgqdVKcU2X54wRVmQ0EZOGJkfeaxbDtyBZgDbzUsbqvdV 5iLUSl6VZRFgWSZMkyY+bVnzWREiJ5T85nJpym8eUkRyaYILk3wsckKqCEJVvjyxDI2UukNP/lSK vqdZFeubW6yqNe1rVkwpv0CPU+vK1uJ0oSjO6kfCQUeiFbOpQCumRxmlluikzsa+k/eVTBSaN4nJ F0tQqqBU+NyE5kq+knc5Z+Dsl/bMQi8us9udYJd+S45pY9M7mhDsW+lQBhAr1gfCRdbBevcQPIxD Hu9zr10kdSqM2x8uk/sZtkNL3ePsPK+RINHZhA9TrE+8uGkjQE7W9zWyXSR7VGcP2bnBhvfPqpxy VpRxK2UoTJ+qVvvXf/qvlRzZQq8jlpnruGdYLpeeTiyVS+6xXc1nC4ziNSMlZVlaLQvXf/Pf63FE /5d/q445q6ORWr7QXVr1xa14uP4otm6PG8fVYqVbcQ7F7+Mw3JYzS7V9vItWK97kAJJNxR6pQC7k ZIE+4W4Vy8/+wNyDwHMv2aBKyFYAHE6pyBcuAoHMzSasrrI9cqRReCaN0nJikUfmcQFVuCt1r/7a 0oHIUmUuQQ1PUSECjeXkptKm627atVnAkfxqFqwCFS5NwOshRZy7HGvqOKQZkwKEczSxnXoSE3Mo xpQgEOa5G30pqkajsS3WJ2xWJr7zidPuqixQKKgYGFEK/VeGA55CbVGunG5LREfOjslbA3UkyigM A+jwvprDs6h8g3gv9WiVwshR9tW6NbZRein1UbTGEYwqaSH53+S4hDBfNaNUaDqKBHS2PhiA9FnX Tr/fYQm13eO5khyLqURSp+JGu8n9zPkjQ91zLvo4o1H+aaLLuTbNLOeDgpoUOeVyGTq8BwqjJLq2 5vygjcYjeyXevJxX0IaiLaJtr1yOQAs4laz3lhwAnGhva4Kpw9rsu2u6y1xg9UShOQenRp1l621j ikE7L4dhJbMca7TKvItWtrkx+kt9qx1G7JQs9dn/kmJVAs94J9mgEY/eETKJcvfJFyJBjWexgymU zqy1HYeiU1yJooWEeDkkXjhYtKcymxLUOaqyLMp0DV9JA4UHbZyxc2uEjuXNgsmoh0uzSoqoJIzk MOe4i/4IK15eqb7+j8hxkYO0zNC4R0+venualcHkCZuVybD7KX2zPsgX0ChADrCBEWuOUY9wKInU fPtaYkoi676wjnOk05gLnfgu3lfbQ/PSeMKDwjFhjdkMoV0dX9F7035ZmvWByXiF3U5oEo9idMZA bTDBUWI5NVwgoDP1IQcKbDsrvVDPAbvM4ehflRfzkNTJ79If5oSDyFSHys2sl1bY2BYPQWKVPi5X ydzp6EhB7LC0Vh8UVhOvgyBNx8YDRR7YyDTp8tPPXGcIhVRI1s9zuxVRMpKIJl8m3TLdpZIuf9mv 9nH9mXI0CFfmNnfRNrpsezKSonUtZ5aKmZOGlnfR0UrfGv2FtcawCmjatKJiHgLP2S6yQScdM5PG +lOSXyAQc6LwFsfiVjOyOrscNcTfFB8LTsyyjWirULUyl6D2sCympErG1WgfjGdkdXMug4MvC3kw zCcWuTTdYlKkiKqwlMdyubnUYE2KoMRBWmliu/X0laBCWNanTEFbhTUmPguzv1lZCflNAsL/5myF +WThwORqS3tG+gI9D1CunJbsS/oPPZcwwtHTQmQTshXAxVY3AanweonHRnjlbxRcZGtUfVRm2Mdu lx3B1fc5mmWD8hHQuRIEtmwxnSiWb1gXeH+X0EDcSjNSnUHqUFjQt8XkyCwZTLdNnUkfVy1FFR0t iealRPboJCr1v8gpl8tS0JFipcLFp36CeANvHms/c50JJ1UXo0LzXagpDde95v2w1dvClXtJq0CJ 7tKZinRiMRUrzWTfIOxUDKUNI5pJsDM4DKuZ3U8SaLNr9Je2WTL7RcXErZgT8YrAE2RoZEepkg1a 8Qao2CffKfQ8QhYdjWYyM49ZJKyzuNtF6KA7RypsxG5KPrWIhxZnAyyeFbNgviJkmWWRq1DcZDQ4 4Jqz24KMEBBOostWgsjq7eHSrJIiuhJsNcjVPhdD4049XeGWT9UKzz2FUVmj5LMweeBqszLRi58J xvGtDl67oN5WucasWBM1Q81SViunLSxZ4jfv30wXeBn05osK1VuelM3OThpP5bPzGK/6neEMdOq8 l90Ofke9W0HRnnOIWiKgcyUIagkjyCtI8EYJ3PJNDVk8O5osuEPAT1Kn4LaDSkembommapmv56KP w+BrgheaO2XJ6IpQjtNERbJHJ1G1ri1Wwhi6XIh+4oHCKImmb3gjTTRpZWXmOjVV5Zh8hF5DL7yF BGqDG2Z2iN1ZAFA79DIrYN5bNvky2lboLvNZHdsWlGo21+ZGI2y+mgzYpqcfGNpGH4fheUkCQc83 mRV2tRr91TsyQFAGYz7ndiusUpUUo+koEXgiMN/aQcSKZIN5JrQQn/zcEeTBpfuB1wPAz8eLcmXm y8Jq9SPsZhXWF/veRhV9T2U22GplPCyL9OlC1w8FkE3ZM2C0YiwhnBTqtgJEJogY5xKXpocUUahQ +2TEArEV1wjQVPLqcY4m9vUePWWauliC+5qVweR8zcraE5Pj0meE1XlUGr0uDPZmbq5UzG97WyL7 J6pSbeY0Y9Nv8tlsy/tq07JY+Wg884g2/Kt/YzgDf/Y5J8GU5cUyn2xtBZyGtJBAcJeL7S/BEhhm tVpTCOhYH+SNCRY0cOjJXBnk1Lrq1eHJHJIHMkXsJalTcVFMO8n9tMExc2KwZkWCREhwVhgVfVyC xon+pVUMZseS9eULvobsUTKioRBNFoxoDZ2VYogNq1DkgQ28OSWjj7nO0vrloxOkEs8P2CbUVe8f 6TkQuwBqWQHFcKktryZfv/xMda5K656ufCcWs2SLz9yYaaJKsWJtxc75MKambfRxGPoyi1kZXSvq wruIOpeyVkxdt++gvTxCb1xdDVlkKSsGgeJDGEYReEKpXWSDVJgXrbRaU6vIV0ZP4akC82+6yl+S 2BnyxQVwIqYyg79aq1DdB76nMpeghsQyyyIW8W0za8jbJ3ONTFnjbWJliGygzMel6SFFlH0IGmW1 qcmtHudoYnv0xKJYqQTps9Tr1fKWYlQ2mGDfV9nC5IFts/rGFoGJX/xU6+lqsh2/xHwFUlM3Rl/l tC0RBJu2Uh2MF2r8axhENe+rTcrBqkLjKQPnvPnbOK/+jcMoZzNb5Z2zPzk3ewnoVDjs4IvNnmUn pr4tkdRVA5zzyRn0cXk1duRh55/5RuI9c/+Un7uh8MDrYa7zhKImQoNXOWS1t3ScfKm84AGufJzy lDk8X7Qqh6Ens9wa7SqE7b7NglsppVUhAyz9jq++VKqhdjw5h3yJua8yiwxbo3YkdI7HVTlVSK2Y vKx3Z0GwLpc+a1BJWUooPbLp4OaMJoYQe/RU9bishCt+x/0TNasdMvY99lQbpyUSkSdXeh8O+3QJ v/1+IZDNj9SO9d8vtb832mI355FeZ/ve5DlkNCAQEAgIBAQCAgGBgEBAICAQEAgIBAQCAgGBF4sA uNvyC7RzeiaxyCaI3UhGKxLBxdhNCOK2wjxsVqBiA7Hbyjn9U5AmyYEmAnwnecrqrshxh6TyAGCx tDpQF5DFgWrSaIXvbmCH/7DwWMQdf313sShSQFKTnJUuF5rfFXKXP37yO8HP0RsS+OislZ3zhHGU QfAiheDz0B8oSQFVhDsJf6e3FRCeUpOKnOeltdZnj3zPT89aNKjhwrn6RHKeKPDzgsfI8YBgfnr6 z0D2+PTYPfeY6qyT2QLCzy4343HvYvFqjIU5QhHBbVbcY3nocOqtcayl1ubbUnHJ67ntmSNIw66b 0gXSjGrS6iC/koG/WGcvxmpOjCtTce1rYX2Ba8J/6Ev6z/9XZM6JG1M9EC/YhKs352BurEbyPvGQ +2lqR29w/dBwEuKs/EGzeCzCG62cyl6iPK+E6kNLQij6utvqqmG/kydWASv96TSxYFo5z+tG6bOH LNHz07MWjeFcPY8cyyt7nsDPC5SKnGo5VoLsf+Dh2Hx6skeLyf40w69PgoCcRrG8eVnEowHtRab2 cJouNIhuwMEh1ozb/8hEx3eU1xV5C5Oj9dY7BrHhlIeCuPsVbEUFXZxdo4zDgzA26UJA9cXZtgdX leuAL2O8/Ju8vlBVR4QPcne9lvgP862JEnwzgYY1RdEj2/jV0YCCDsJBZ0dvLnNjsl7L0Ak7RhDD MAmCX/E8m0YKmVIJar5BKwm8goJ8Rv5DPUbTYXZT4WndPRSC/IXI+4jyeIgNipt3FuzIS4mEUHTR uCumPncg6TKUAh3BhJR9cQUdlVoChsMi1XxZAiJCz018InVPVSls0QEVotFElwRTcVXBexfcktIQ AQ3FpcnvZ7MjKoHYJeXobzdRqezbRJU+po1IekWE2R2qgzkKipmhdqFRONyGVtvKTTFRs9O+ICeP 49IeCoGn8Mruqg9FxtQS/WyxReRJ+MuxmHFXlMLHLcdcFu+KIGDLmmnj5rbAsaniWrJHUcalCS1L ozCUk2mtOSZKUPj7PBBQtj2yBUfKaBzu5miln5/xTkegBCu4FRxWwAG9jh6ekBVBMRexzHBSsjVa RPA0reKbW4s1X7uV4oSQmyd6CnOaG89BHKeZl8jJUDtaLclQOsEZLl6lwDn/ofq5mLQ4Jqg8WG9I FHwgNKcqoPprz4bA+5CsUvNblmgSG9iOLuOmJvSRq1mR5Erlfcn94QmPZcmJIfykxaAMul1zZoWs hirMxiGlLB1IYQH6KASZJC45226FK6K8KgmhNy8+EkJ9kFx8t5JaJ2dUmaGUtEt5lnAMzRSWUsrN b707ZkXYK+EnP/33OPOEnE57kAqoszmqKaplMZXumAd8ioSWLCl7GcD3sCOWSQgzYVkHJTUv3qM7 VA6DX5Q+1q14ENZnihVowpJnaqanQCW14p9qovoopYBQyCZ7YvbYWB1nXnJe2UgYrkr1oaqAmhOQ YL2/d+giS/St1XL0ZJxH9dXVk7OThXK0ecwPkQFisIY6rYPw9uowCC7Hporokj1+ZhoRQvqkQQ23 tTqY7DZEVr1wc04ExLbXeodjXKNDKZLWIcwYKX7rzVar1W63pRjqI3WGUY9WYAEWqLOKGUl5EO2a eGK3PkUZxTz8q1uiLv7CgVOVtKls/By4JDxk8APrQm98RN2GPR5O6hzRj/Fl2Y0hblYOcdYu/kOV sqfRyYFopto5Mk5Vh4XqOL4lZKfbaNjhZJpu+2Q1VDSJ0nDErdBQyAnr7QaOtDGIrBTvjcetGEgJ Y2MA07WZ8vjYCO4kIyUUBn3WUrFl0b/TdzeKVJ9VCsFcAXErRaI8NqiOWOAtX4tD8hwpkUJe/CSE amAoL9MZCGX0DBWnefhP6HxoenCOXhXVDOpRe7SAJvn5RKMW89scstcqZTFYpFWOUyAPCYqp718A VP1gRFvZmomF10M/lTtJZcEOELjIPCVlkpWDn7X+hj2oHSyOFFiiA+XwvCkvf5HaPs48YfQ5SlNY uxBu8Dz+NuE5bvAC6arlKVCrcH7jSXSnW/HSHmoGEoWYnFAW+h1wv3gUUPVB6Ge/LreIXCchpSyU 47/sqlqKyZb4FMvRCPOwhhowGcSM9E2WTTTzEydmWTqaJnSD1qpeLYEhCWoRTr9Wa7jB35EVbp8Z AWXbG3QgrWazdTCcCIcGzUKrP5pMxj1MN3G+SJtet5Q510Uq1w3GLYoPAeosYOoxiOgPBn0SJTQH zmll0zFTWqsiPpxFeOMerzl5StwMOZ6i2Wp3R1OlBGsLbNVgOOwJM7Iwr4oPavUn08loQHI+Z+lE RBaTVqmoEQ2Md+WqMumJQ/yGoyTjKFcd8EzSFOfcAqjS7kRcRSwf7HEr/EnYOQRkxfLknCiXt2Do 6D4iPpfmTlEI5go42bekT3x9RZGEsJoXIbjg2zdw2YhKB0dJm06FoZTp1vU5R00UaQOj89nQbGyg jCNvEzyyVwLmbRhL1VUUbnNAP4XLoMExkSoXraSMZ0slpaLgr2jeT3azIyJMlYRQhueAQmq7zO5W wzjICGhehGs9hWfMAuvHqmi8hKVWY+emkqixsU4Rq+BufVDlqNNC8k5gjZivRkl9UPSzlRbhqOQp R2/GDZNttRy1MB9rqC4sCbHHreiaoKqEmuLYJc0wgejW6kDh5CncPhMCUsQNOwlmZLGumkmwnPQJ v7qlnHFOpjMjoauZDduu4WIa4lToWDiR0zEeqVCZRZRMuBU8iUlfPllVnEkw9Zt6J8IBpeP/AE6v LsRxbmCX/1BL9FUeNihTxwoJQ9ME7Mvz0bCHDJAiSUWXtm9YDUGvbdyKevuVtXIlWcWvtv7bxxZS +5N9ArxRENLLwuCdlkqH8RHxVSkEbRKuGTHCZfiPlyOOp9EcGzD8eRFzpGkMS25FuNDNG2FA6ztf /RojBcwoDkazRTTkoEF1xQ2JKDE096JZwRw1+PYrD8epIK9GsaJ5ZzyCNdZDCYOGOH0x1jp3YiRL JWXRMAhw9t/P4ugjIRT6jvrgEN12qe2+MEofI/8MhJWfsm4FNa09nC7Qu4oivGd6VnpBkdLek+he t2J4lWNWDuPC0I9ymoNFrKqAyQjTLrcIiybqpNs9YDn+I4m4dlctEVsoRy3MxxqqVqOUI8a2IOl3 qSyrZzqqbTv2BkNgdDZMHdAcpG6OCpXH07d0chhunxAB5VaKk08QYeqqkqbfVMhxh1sumCxSE5lN M/OjpdkyYu11Vi6cyiyi4FZqh/PVemWudWGJP68hSg35yz5Ya2QfSNsk028xcMEVMnAxaRW9mBcr kvN7aBbq1YGrI4x9eqabRx5mbJVbgzV2BP9JciFXiNEhw2vs5zv2DKPHRcbkjc40Vg6tBOmMcSBv n9iCsE8MKSWnLEpUnx4KQZsnJ/syYY6+OomXSySENhXE03nxkRBqPaVwhZ8QXVmYkeEvQY7Z5YtI MEsP4awVMtmCKSz0HeZ8H5XTx1DzFY0+WIHBHYdh4HCZMncVCXreRsFS55w8aSRl556jCd0iLpMF T0nxZ7lUmG/QqdjB4ijOtEwHiqiKqLAhA3BvGKWP1sGPMOp8Y8x1qDUqAuczddF4CpSsWEUGTl+i pqk6Rayy6aE9tMSnTmBdH2QSrFSjDJi+FqHSkL+cd3LL8Z++3F+1KLZYjkYYJ0lKrKGiQwsvxkml UsksBLOseGJNRFNdbb3lD7uk6dG3ruEWE4yUdzdbm1C4OQ8C4giq+6DM9hIjYkliU76yU6qELhf8 uBrDuuquI77KMr67VJHxzUtNLNbIxcosLz5Q35Yjzma5l7wpTIXFX2mkzhwaHqVc0Om56+Ip3xrf PVphxqwwAZXzH6rECkmrJEp5UQ/V3zJZpW2G6VIGMHjBPHQnbqqNqJ4TFJa1lYTLk7LDwZWp7ksv z0IzsWqgnu8i2LRhXCo8y0GoqD7h5UfmEZSzpKBM1+G7Y4lzjOYhIfTlBUyeXOjRlyydiJ4LSHUo BFvY+431JlOghqFU3Ao3BfISc6pQkL8yyal+QkedBe2TQIr73GWo0WXCBRcsDGlNCrkzI9BKSdmU DZi72RF9JISILiNl/eJaVMUD9DHkanW43DOXvg32Qxr5XoTZldJXq88d+oSIGfQyKwK5AlWaJ1HT VI0cm03Wh65Rsdnj+QDL0Mi3OVhUNXFiVQG3PpRbhJNMpRy9GacrUc3E4APDr8vRCsPkGUe8cmnW UPhfFDavOhZ55Q2qOcemjWhthb3BT1Vpbo50a7WYJPuarU0o3AQEngkBD3dfMup21NYFIVQvTOk8 U1pPFBk7Ls3MYZWIz0MhuFu4l4TQE3wPCWEJJSZvlIMgccewtyDfc57qFOAUpPOJvbtOmiUJzi9P cnvektrDCughIaxocGYYP8K78SwWqJ+B88xEXTUrGXRqjxvO3BcVME/VZ6mszY/ecvRn3ETZ/1nN IFJ2qxWiQ/5+IfbXqjT7k7k5AxMTLHwGBL4TBOT9fRiqsBPYOOAGyHDtQyCdAahCf9sJLa+fKo5G nV+f8fZVKKnfEwbO77Qcn7EahOgBgd8LBJL1Esuqy+Iy0O+F5r8LJXkwbZfzxSlLUPh8d1coqe8O W1fyd12OblrhPiAQEAgIBAQCAgGBgEBAICAQEAgIBAQCAgGBgEBAICAQEAgIBAQCAgGBgEBAICAQ EAgIBAQCAgGBgEBAICAQEAgIBAQCAgGBgEBAICAQEAgIBAQCAgGBgEBAICAQEAgIBAQCAgGBgEBA ICAQEAgIBAQCAgGBgEBAICAQEAgIBAQCAgGBgEBAICAQEAgIBAQCAgGBgEBAICAQEAgIBAQCAgGB gEBA4PcegXQTzaaTyTRaFd78+xzzlW5Wq50s6c8xHYhK16u1l3P9Bepwdo6AxzmZ4fHa9dXvhoo/ WS39SJ6dvVc3xO+uOPZh+mK1Sl/uirHTAmxWyxdkhCpW6MUW0L6q8mJ+W0/Vu1DrTb5Lt9bsfScv qJrhjefd6QvIUbpAdpqL6vsIt9sXpkM5m8m8XWuql+eanzZ4kXN3ts+Jb6a9emsE/xjh7d2tsYm4 6xOveG4cuG9k3hXw3M9TvvC9vTp3+Jc74NPh44l1vuJ4MWDk6p1LK089fBo9s9UIL7LDez9fzmu3 BdjQCO1tdM8rR1aHJ2zFzyv937GcJBrClXQO58oMq7elK+vkvEHW3GasSXhxT/kNTPDE6/Umf7Vs Ji/GzfAw1q8LTWAau9NvUudtoUZojoCIWVsxSgpEF3r15bQYPWby2kRn+YuF8BqpNVQwHkbpsMnT 2yo1E8RlGI/kLGYW+Jt61a+js3tbyr4RZfReT1md107CQBEgKsWKStpAyahVq/dmCHnYrHWOVlm6 AcT2Z62tSWIbz/DSysOFE4CvZjVZ572yAoKJwYoZywM5t5LM8rBVa42UiCwBEsWRi4LLKMDIbmom WrFiaPWhjA2ba1DG39HHvBhWFQMqoK0kzIIkfEY9cfEpaq51Uh+ln9xYRvd9xZGrBY0RAWWm6zOr iMEKP3jw1PLLlYePy8iYoLl656ok1XqYQ4w7UyamquxUcj3p1prDhLlz+/6F5lZ8fTSlK6Wlqfh6 U2JbkCRasg66J+OARLSFNGWLBM+NrnS5BRDLYC1AgjbSmMUpq0peUlt+RzHZVEUTQu40NymB3DTp AnBAy5GUCm2s0Fmt2JTkq/XJ2ljrTtxMTbvKmi3btdpQzFTCXusBqsKsx+EMr3beeY7nh+Yp3FME UeKpazL0QdDGFDHTCOmMf/sFQk5UnVqP8dvROrcuqzFsr76GUbzNqIC9DvEE7iPK0+qOFlQ7XR7w JcC86p0xqgaqfL0/3yZRx6pV7y7xg9LBSVHpKVGb/9dXFclJ1NUSGq06mhGS82DiUWkzbYlQ/Gn2 Z0mkBoM1eXU7VcaVyLta42182DZa1g+WORgysBIhw+ifukYaPjujJaJvZlomk+hNsmyhsar3rPOS JPrKzSxYzP04WVisaq2BIOHJkSiIP9kYQyzmOpv28wxNJFpZgW3cq9V6c5Ua+4St0dKDjBZNyY0B qwqKFHWrebjw1CLWuq7qBKBOQjrwxxCvJoD1dVrQ7hz1xMWnWDpaI/koZ8qNlYdbVYvDozyHzOaq t7ttXUcHVNuDZy6+ol5VuA5cUM+jVSk7J556mLBhcxQtdqDO2hLPUJKd1V4lZz3T5JDFFvwLKnS5 uS0GjVr7SKka4b4+SJymWmsPlRmwGVe2RTeG1iE1qRgWGxiFzpqgr3r3QH+rH3A+RFuASuNKF+xC m6shI/v06ABNQ1+DOasb5zTM1exTYNk0GT0yGrE2m208heY9GQcdoSn2ZkoHK8rbio2YV+5TLG3e QiV/qAN1NOHNkR3nLoZN+JFsm6B2ALJlkph+DaoTO8ndI9q6eI6m1Fpk2+UhjdyILonW5gD9g+Wh 4M9qLMYnQ1e8JnXAYErz0h5zxmXeowLZGgrUumNKRhlBCmo8asDBhIZTPMIBKgF/akoVZfj6LBH7 NosXw3a9C51xrVHnHB34SF1Gz03y9X+qSE6poVTvhPmqDaLEg4lPpSVsOBoR0tC5Tgd1DjdMsvxk Q+scZQnf9j5ihmiKCwXBiors4JcJamz7kK99n9G6zrbZ6qBe70uriCfIXB8tdEVLLQ2c4nmpOo/i UGU0iDY2R6pV9uaxJ0cqMv+ukVo/SjYcarWUFUczYd3wKTA9qCtPsT6CSt21Dxkrm3UMBcrMIZHO yl+L7FhJ1yKEBlx1eOo072ues55YfCqlY5TyZcrGMoF8xeFXHk2gPkZvRoqvNYzQFoBje7z04JlL R5UpVp4TT/uywXP1zlVJqvUwQc3sRemWk1po7oN0yzBohnuVjGkHGj1UaDVNuki31eYmfVHp1YjJ PVyeoIbWpOOnqtYQ0fJLbEujj6Yg3aHOcm/GUW/ZKIhqAuOEHhsixqiobHfaAqDalxqXtPf6uGiX 0DTRsnHN2KjQyuI+ctc+RJuKZ7RJy6xsmnKt0zn8JSZ66ENphxbbBFW0Po2NDntacS7llbsTWPTw QWeO5hRzLzEdLe0V7BOetA6Xqrc/Wjldam0WerrjkUUAeZawLyoFhGoH2GtHm0zV/3SbwZW3MURZ otvQLM3NLsfsctRbvdmKxcyKLd0n3M8xSmqPpZRrzXan3W53OqhM9dmGg6BDt5efzGCNkaN0PR/2 uu1WSxaM2DMxOjBLckmfuY+aqepPUfI3kFMb0+ADAJUvBCtj4lEJum8mrGSoZRPRLFvAQR1yvGQv dg7Rn0fKA2QAdbc/Lk4woXGhStNvSqK8YUG0URAYPmyX09FBh5lj5MYA+KvekU2ANwS/gTpPrTGX JWUxEUH4jfZkHldzlEvQLSJFotSwQ9gxapN5OY8C7Ht04SmWyCyqjx8ZI11MB4wYPX53shHn4qlF MlbStQiaO1AYQeesJ4mDT6l0ckmeTFVRdXTQxbFLeeVkpRzV/OeatQfO3YdnrkVRPZ/wPKxVr6oV ApUriacebuf9RnM4O+rWm71eqzVcsT/fRlPfp6T0RQ/FDthGWm1u2xjdoSYqK0eanSNUaFbWeov1 qEMI0NPLc6JkSnNRMu+yv1GqEnlwehBpHVvJ1FAaF60EVm+NBag0LtXe2T2zdmmbbSaHfWgEMwGV 6P2lmeiGL6KmybZkmnI9qHZzvomQHwhoDedYDmVv2eiwvxXncl6xO5lAQLu22crYwebcVwSfLf1J VXDoq6f0BaUFAvRSmqrbCQmCYWuR6l4unsioEwPqvFFHg2ajN4Js+innStZL7ItK1vM+J4Xg7jnh Vhebj1BsPr05mgAmleYRr+nR4WgSianUS4fpZjGLVt9ypI+u8hS1pD0YR8v1gt6qgwpr26BJlnqq LtMZkmUOEBhVMfFETNaL5QbrIJMhxNfao6WsbwIWkyw/OYQf/upfltFikybLKdYw6IWk06SDLeBv 0BiVS9VbHVaIhYJYss03hkez5XrFmBz0md6Rjq0+YqxnHRzCgcCz09khEbQRuThxBLdSzZEVYFoE F6Q6o9kiAvDzo9HhZBH7FMAsSB+dxsmwBdWQVw8yVrSMpOqN3tGQ/Q9otKsWcYRIx6qmZaR3oeqk I+pc9cTiUykdK8mXKQ+q2nYxmi6OXcpjoIdAaljK4PEUpTZLPHjyV3VV1PMJN4Ftps5XSXz1EMUE u4g61IrW806ze8ABIhrmPiXFDrBB4eLMFacRPM1NeqHNyRzjIDZnMdf1wxkqEf5NDg9HC7vmiR9p Wwoy92Zc1QROT6lMYbwFnVHRO0frVFmALKk0rqpdStl8mgeT+WK9ZFeQVo6zl6oXB+eAite9UzFN zLm+OFaqozONyYhZv9Hq4BbWVOuAir27FRsJr+YnwACy42iNJbbVfIQv9YNJhu4KAO/iZoOmjwCY A1nBmrXUtFIOxYpGu8s6Fke4Y1eWvVw0H4bhmm/zMHXqv5pQQpTClBDaBXofdfa6twlaH8r3G45t ZaVA5tZq41UqXTKpezG7B6z/0snhAlAmc8u92QIptkbiXGQ0lK04Ddwq6KC1p556xOSTzHEWV8Cx HgG7zOUnDybViNIPV2tG7M2i0cl8Qi/33EheTzCyr65GHxtZPHB6b6yujT46/5wcQGOhzvQLDRQE LVuHy2HJgnMXPYzEOA9TR5NisPzKJrI4JHIQmuMvWdNPjpglIOnJkY1t7KFafTtCCa+nGEBx7OlR ANF0N7s+ln5sFRkrmTdphPqF61DcracWqf4e/POac4Bwz6nYjS4yW7hkDuTMemLwqZaOFebJlIll w3iLw6O89iCIZ4elam4H9sqDp5VfVc8jPA9tC/1clcRTD1loaHioaRFMoBo3i7/YpyTtABs1Llpy dErFipaaG38dogmhhnOqCkiwQXHNdCvVr65mQvgLrorM9b6MGw+CiNw8oCacZdiCuRRlATIZCBca l2uXYN3ELnFGQAZNM3SHxMotR2iUMoGfLnDXHEYV0ySmTdRW9QHhD2HOlpwqV4s7Rod9rVgLeGU/ 4nFPNXGgUusMp8o2LcfsbONq0ryzDmDuUU9KFKBYYxFDhWx0D9HmpZerR6/Trsy3J6hR0mNBRFmp pyUsXtlmZlfYmwfjRMxOmzNdvPoT5YU2doG71TtSpTsfshrgqreHEIp5fVFyjV6YXI12i0Oj1NVB kqaeZpINzasi2V1XxZQwx1ZVTHwRk7FdBKx35pssVsvrMvRQmab1kKRXExpqdZk8qiApdgvjef+X M5TNaCW9Ma7ysyDS5VghXm8wk1yRSdWSfXlekUMGdESNt4lGukwB1lR8kC9HWgG0PAy18CVbT0z9 qA9mdHAeBfiUnqLBrWvqqkJqfuEnLSFgNTOq5VqEbgobOq56S++XoN1gV7BwnbOe5PiUS8dK82Qq j2VCpZzPLBUH6vTuJsDejhoRc2Aoe2OqeBrp+KyqVxaeB7bqnXi0qmanWg+ZHvv2DaIqSKoNIXi+ R0mMUMQNMQrq35hbOCrNTbScsksnfU75ujAmpdboygYceSp/vDJLqOahdSmw7qCGc7FPxr+o6lhJ NBZgW2pcHruE6NJpRi1rttEFROc5O4IZasJk8Gp0xzAyZdOU68E7dstlnkF8q66fRod9rbgo5hX9 lqVJki+DqkwWtwjuyzgjp8ZC7AuYzWDuG7Kc7Qtm5chcHE9MZBXBNowVQD19qfuf2miVG5/kTI2D BmYOy4uJJ6I8sik4mw/tM3MjyBvDbx7Kp92TWXiqvjBWKZLacemElRGccg35U2JViOjNUR5e31Ug 9ihQiQTDs6NiJAvMtZZ9RDVwtU6W0niSepLjsxNyT6byWKWkS1+rypcCFL9W8HR+rqq3W/he9SrZ 2VcPHQXM7T4lTZj881zNraJSHt93tzvjvtDVZ1UoK2FEI2u7ZOcM+2FlqJ5ak1Jzq6QfHjwbArJh BsbE3VS8S+IKfeU6lnRfgovDq3ppd8FLoNYZKkjfDP2tQal3f0a0F/GzTFthWkv2Hjxjgi9RPXnG nIToLwMCsnnMrD++DAoFHc5EIF1F4IaxHYN94XH4qHDgbV/Y7/i3NLYHLb/jlJ6reLDxRNxJ+RJe 2J4RLZ+Pu3uJ6slLCHRQ6YkRKB3wfOL4IUJAICAQEAgIBAQCAi8GgfOzIO7UJ4vn0+l0/pJ2mHeq 7fyAnnCF4HEnhV18bt5IJ4Vz3j4j3+NTRn+6OvBSkXmeE98QLCAQEPjuETibBfEsHbChQvZSNH/8 fzxv/sOzkvb8btnePL/tfhThwEaR4FH2tHtJLHkMRJ1T2C3vKX95Rr7Hp43+lHWARy9fCKHoU6IZ ogUEAgIvBgGhUXPYIzULYonWT5G5mWV0H0mjZdKTrY9kyMmp8Pw5kZRzAjdn+4W5rdK+VZ9QdoVB URQUTkLL9qZ1KO594nYX9QMJ53IORm7dLxE8Gvo4SY/Ui4YTT50oETFVCsFSHrUS6kMhn2/BK6Iq YVy+R1DokRPPXZ4qSyjz5rnRbdJebr0iy5+pA7LFjqx7UrguoZ9IK7ALYr8qXLE6WrIv11aPcBMQ CAi8igiU+OhgseRMFg6euLR+sUM2SAodl6TxF3/Pc0DqUrSH5pjDaz9UTx3+QxfCCoGbh/aQvV9z Kdq36hOeWFQbzRHSMChytCSnO/7dGzr+UFH/8OjreUjwPNx95py+e6SFaMjRPyDmPm8qSsZKHnMA qkx6LqrYgS8XGSfkJE7qFEFjvORqvMvl2CNVWpU3z0a36VbDaAZRffpI06DhjEwv3kvoV2UXtAcZ 9uTa6hFuAgIBgVcTAR+9njpeDbIcGmah9duQxKAhdpL7unEuNSdpjH9TpT00ZtbDf+jAWCFw85Bb +mjf4EEKRHByVFyMocOgmCufaW6rPOVzkeBVufsMV4BwiRTQmKs+epWSUeh5Xf5MRwkPhWCOan4m RTNO8DRxrTkV5m8ejMZEkz6/toDMiGfyhydLkDCXePNywgqVNDg/K2HkZKLL8pcZJsx9hH4edkFD KFop2Tzb4S4gEBB49REo89EZuglxDeCa4EWTVuBiykka8WtFgvBByYFi070XKZU/JQI3SbFEbknC hwLt28b/xBy+dhkUtfJygkPfaxXOQYLnZN8QPBr6uAoaJKnoHP2GVC3weCVKxiJ/psXARyFYQNWo CoYZsHeSJUPImvhY4va/JlOZQ9GG0U2VN6/iUj1hKix/GIwqJsx9hH4YGu0m8yyVrM11uAkIBARe eQR89HrCgrhISZGkXYkQ7oFEnVcSzaI4y0kafRJSMbM4Iu9h6rOQVrklq7SHVdq331aI4NY+BkVH +ZztzSYtczVnkOBRQpHg0dDHVdBQVBLLf8GQpUTJWM2j1cHHpJejaoMZn8g1C/M2ky258A9mJE1S bEigVJrPlvG3Vd48E93K83HrVVj+0FNACqAcERj9hH5edkHVi9iTa6tHuAkIBAReVQRoN0qkhXom SkjkDHMXt3UdkNtQeCnJD2xJGj0SLP+2w9QXL2fTReEEXIXATd4GUiS3rNK+VZ/4GBRd5S3bm1uG Z5Lgebj7DH0cSYdcNI75rgrwbnnY+Sp5zI8nepj0HFStrmpCEt4cy0GN/hQjkrUwjA3msSyBkbFT vdDzcPnPVd48E93K4/RUiVuvyvJnmDAJo2K5rBL6+dgFdS+imussXkxnivLWahJuAgIBgVcTgSof nWZBLNL6JcuxJm6stSYrsDbmJI1VCVu+TkvoDS0VXpoOsR5cmEbzELhVaA+rtG/VJyyXMoNiQXnD 9qZHW7oczyDB8zEKGvq4bQUN8EaS5azKzreXpK5MIeiiamobl40UqVe6OjJFUOuNuZ4CsjL7zkb1 oswKb14e3Qiscutxvb7EHKjrwF5CPw+7oCHzrObabAKxWoSbgEBA4JVG4Lzkb+Ra07uTSnjsk6Co 8DLw8ao3cpailgjcilt/q7Rv1SdGHrcJ633C5lH+ueenPNC+XOShzN0uNKhHCaVSHo0Efu75yQ1m 7sG7ma/lq4fMtpNekTfPxCt+nidMMcbOb8XEC8GeMGuFuOFLQCAgEBA4AwEMacZ4S+ETXlXat+qT JxQZggcEAgIBgYDA9xiBKu1b9cn3GJ6Q9YBAQCAgEBAICAQEAgIBgYBAQCAgEBAICAQEAgIBgYBA QCAgEBAICAQEAgIBgYBAQCAgEBAICAQEAgIBgYBAQCAgEBAICAQEAgIBgYBAQCAgEBAICAQEAgIB gYBAQCAgEBAICAQEAgIBgYBAQCAgEBAICAQEAgIBgYBAQCAgEBAICAQEAgIBgYBAQCAgEBAICAQE AgIBgYBAQCAgEBAICAQEAgIBgYBAQCAg8PuBQLpautcq3vkurBeVn3SzWucv5y2lmm6W08k0Wu0M UAr/ZF/3Jv1kokzozWq5cd+zZZ6/8p8oxU16arL58Hh5vFw/MF+dz/TkWJ4XwzsBirfJ6u5kcmux eVh8jG9IYr1cro9X9/BX/XMUqAR/wgfp5t58euvm7M5xXE3aynpwvLyPBmTyor/an5/pJl7Povvb 9GS5vJfXfnxdAOct1DveFOHNkggKz+890XuOkvhks5F/cbLZJFJzT2P1hH+LL/JLTo6dgkjW6yg6 Xse60KGSLYjjdR4x29ydRSfPBEWI/JIjwNfNF65+8eW8L179ZNbF+4ljb8LZoi3Kdg7lrbveME/x MFt26q15ut2X9FOIZZSkZ94d/5QCnn80vLi50Z/nlmlvCk8U2JX04FrtypszlcrDG92rF2pX3l8U 7Z4ET+YfXKh9lGzd8K6cwn08/xhyLjUp7cbK+iwl6M5rtSt47v67dt5sFlKpflmM36PY+jWVxI/G 62oYPkluI9jNxOQluSVf/WGf8OnDYePKG+N7yfwjyNS4JnfeoFYfHKfbWffKhYPbeO/15fp11OTt 9vRGh1BcbH96zpIWfZK36wUAWYLxrYs5qld10gwtgZGoXPPhu0hO/Xt7Sq8x71+zT3hTH2rTQoFX b/pbuBIW/v6eI5DOG7WGU1Xy7CSb9Xq90V2dDNc2k/5LHoLP8N7cGMFkiJMhRrE7g7durTdm/CPB szjv8RR+zcVC4IZNAS8gxl+osYl1y8g203qtPtnosAUNt3jbr1IxFmX3KoacMHOxyp2IrR0hryZp SaConpvZnf0/9YZlRoz1CCUZ1Gs946mzBFjhJ60/P4qayJNiunxUfcKn6kKZ2IzIk2Jgj9obeLru RBtGrVLel4QMV4IbGLnbmXOtTf7x4J36lWtz+BHlU6594niBZHN/vT5RspLoxoXaDbgVCZ9k6UNn bHea5uMdip71rl7o3sLN27nPypNUd/Pe1Yu9O8WnDzfr+xs7yshOpTKfbJKHWQbfxN54kj7EPxsL ajhZTZDcjyb31a+LEezn9SV+zk6tqlkm4VO4tmuzROcFeUc20wyScw+YmlTwAun1+n6c6J8gAfKB zCb2ON80gj/9ABU/4c01Og7lU1ofq9aQxvc3yWm2oQv4ZAOZJ9fqV96cap11WrrinabIuM4qEM5z jWdQQ56c3gTUtfeQTVVAygkIXDpmNHwLzuK1wV35fu9y7crlCb3JAs8bnyKpqH/NFkQWH19rXLnQ 1D4OP104YDmG69VEQNyKdG+c/GXrQcsMYerdKNkm87753rO9DHlYr6sfGu1OUwfpz1jT8Z5hOw5q 9I5QzeZ9/aDej7L1xKbQ7E1MJacOybxXqw/gSOZ9IxGC24exGarUas15XNZwy4zo6yfjf1+r7VQs ng9NwFqtNYy3yVCn05r9UiddVV4y29SZrTWnxrU5qCHPuQ5IokfTnfSNW1mOD2y6wznjVzRBZ3Ni 89zsTWm6dgOFuZa8mBq9FbxiBfOq2tFAp9CffzPp2dRqndECKqWrIwtjazBzAsfJDPrvGEUWUFBf HqDf+050f3KALuv1m2trV0/eb3OsId3X9xaoWsatIDwGF8vRdQxeFLrHMOBioKx4NVp5o4Mwb92k 8fRc6CRba4afs/VXr5te9KXeV4A0mcORqX71R5+ZHvXFP/sbPNQjoPirC4XuNPPy2sHNpZ5leoh5 J/hhDhzqH6seD31Z/+7WuBWVl216+2Lt2i9+8zkk677QGvfI5cNJjzZZ/bs8Ooae837+5EL7M9vK JIcPP2xeuTRkMHEr12eruz9C9E4ebN6/eqH31bCpZF7/P/8XLe21/p3ocGjTemd2nyMajGJ6HGVM MMYxaEtC+k9GPTG6pMdZDK9fqL/3/vDjt4efL41a6eJTFMGbnauQL3Huv1m78gYz8pAl3vpM2nux IJafAVXVg83WNxE9QqBwvZIIpPPcssDqNYdoJstDmPyDJQs9PsSsU3t8Eg1gqEfROjYDB/yWyMOj dbaNOZPWGkZoxEfdWr03Q0SY0+ZgRsO4mSIJ9NijQQO/LTcYvnx72Kw1+gjGRo5fh4u8hiURXFgf ajB8cwgLk63GSJ0V0oytqhpmkhFYws1m8y/7FKMT6YyXTDrm2McVa5L2KK8zu4KeG+jVGCCzlUt0 aIt9Xk9ghFtRatzK5gjoHsKMbrfyU3uZeTSZ9+q19ohYrI9aTRRBugcoAaEryK0wb9g5ul3F3Ke2 UYna6qHf+qiDIoq36RBZ69OdpYvDWq0xt/qjFJJ1tEBhn/N6YEzclQvtmzbW8Rhd/fdoHzFL075y oftVya1gHgkTTR8u4TI4x3L5SPe3VarHU+0RZBzk16ToVh6+37zyWl8mapI7l2pXhouHYpmvfhjd j+MH0eDahfpHy81JnP5/H7YQkkZyeXj9QpOG0V5xdNPMsF194+DThSwfGM0ZSvfMy25FD14wf3Xp kJlmcq3PsxSaXFWOZn0Em/8RrDV/an4qtR0m3Z1rAvQcC0BzSBDltT96U0YHTL6sAB5whAUHlq1g wK+8j64h8nWEqbzrqDDiFK682UfSVye5x6ccuaRoOl/m9xiJ9G9cxnCj9i4lZWtMvrEPMHzLevDl Ye4W34444CoWBKqUQkMlkWCOFBLUl/D3VUNAOtj9yTya45pFS/YTp+yWis2n1ceUSf9rmPr6wG1o CEYjLMMK3EqfnJUk6jfqvTmiwdGMtRHKxm36GoxWME4hgGkkQ5VGixd7x83hgs/lMrado5t6f85n xpvYm6qGsWTkSLq5+xSDNPi50fCg025w7NFk1TbyddI+5UUmnR0u+DvmsXpRTn2qAmWRzC5qG66G e41mq8V/SFfcWUWTzUyNCuud3nC+RvvfB9S8Xy+ocV61jVtBvtfzw0Gv05ZRWGOQYI2JHQCVAZW9 PHA1u3ufiFupvzeZ3bzIfqyec5sPYHyuvt66jn9iqD/6ujhaUe6GPf/4y1KHNp7Rp7wzvf1OC9Mp H1zDqKfzpXVYVpmCNUvvylDlmqTIqX70+ekO6h+ryszASEuueIZVnvditcojqwNWptycbrBbYPTx 61x9eBfG+dxuZbuZwJ5jou8EQwxlS9P1nfcHH11uvwVwLjQ45BFNpOdfML+ScsJRj5pSUG7lUu/z CdcytG9CIJ3rPK6eiJOhGd0Wr+yuzNHxNsIYBDN7Ra/NH3DJYsr7Sz05hnnbY70KfwJfcPno/+UY p/kZdJY5ya+IpES5dnScZsnNASQPMXtWKAiEyXXDFztPiPtwvXIIiEUtTYLRaBuzGXPqQ9yKjCDc /Fv7D7diVxDoC4xbGWFehlc2arF7r3/CgzSCZW0Pp4toHkXRbDKZ2dG18laSlhMe5loWgIz9r2oo bqWhLOI+xdSUV709HE+j+Qgd8ny0QkMhAyWxzyXlHZni7ww+kkHzR9yKGuaLq4LvcN1KYzxHjpHl +XQy28hopVbSJMO6xnJ2dNhtwefVp9/sAwpDG+tW0nU0/8fP4KHPobZSKYGxQxrNbh9IRBxk9uFW MDY1q/npYjZfJSe2w2Ayec5PZTfYa12OOAnzoZgpmJoLzY+jxd35/G40vzWZHZ+U3Qq6JHAf772P SaHOV25imGiCH+GT9Bi9d8h8u+ABddiCNUvvXoJTG95aRHei6O5s8tVsmbjuoBBYOuFvj5D69YXj rrL1lxdr1yP7hMaZSVNPMwn2SfvKRYx0tOXkpBndhzWkVOPqO4dYbZeZrM1X8CaXujduTO9GGEHU 4XEcI2xj2cyLW1H1StyKcjHJO5jyqn+kHLbOiIpLQ691kCX+qlt58D6GipgK63r88vGYAyjpoEHO 6WL6lRqdYYILw67XDxfIHeLm/xoff8ONBO/KIFQ5L462CthikD+F175uJr6CW7Gl+yreGEPt5m01 4szXHAvaWGSBA+gcnZiJKTeYY2krbgWOBh33gyO0l2TJ6fpBhA677eRzbqfWHeNXdNjxa18G6Uq4 FSsDHxk0WSXNTVVDTIJp1+M4Jo+/E4/WkVHNcoypI3Er3A5XHy9jk7RHefMTddQZyTYzegcHEjMR h2fzIQZkHcx0iVmOlQ3vTVYIvYINr7UWJ3QZJU0mGC20x7QKmwmGNKMVZwt3ASUzV60ZiinlBrnW +J+qmHvUlqFlZ7w44Ti0JfZTpjoxWpEOgCq1zRzTnrVpTP0RGDnK4sV0xpXq813GtDL0g/cxvpD1 XzFZ78oWhoQP259X3cp2e48LB5z2KSxeywTaWzfXDzEd96ZYtjeGt9Wgw1WpaM04CXah+7nUtFt0 B9GDnW4F3W9ZalHrDrnM7BhDnoudT7Gigms2wtDj6gxrcnSI1+fxabr+Cs6LE2i73Mp2e/OAK0qv DTgeEVOvPFdC8y6jFZlGk8m6qlvZnrxJR0Y0lFvRXZeYOXqtx7VvHZ1TiFdvLJFdg/8Gg74rb3Pt /nR+yM0GMOxL3rw7XzK63Ypg80v3LSsv8uTBOyiLzufAGTOBUigPua2CWxpOMVq5eHCLVUJGK5LK dsFeBKfauC7f+Xy9uY8t3/PJx/CkZiEGEdS0XqF8rQLh5vceAbHGlU5fPOpybopXs4dFFlonPd+V 59h5SLcCx4HfFsOm6kLDX8DWqastiyx6fkwEwCR37Pr3Af2LvUQsp5tgvfXkmHUZ9mZb1lBGQHpL 217Fsmlfbxaot9qw2T0YiGx1QGXqP/sc2WTSVeUdmZzo49pKOkckPeWltBe3YvcKjLmSkjvc1URN cBGS/hR9TI8mpQV6tOU9QEH42BRTvXPIafkK5h61ka6s1Pd+OTswhdzqABNusUZyttQOxgsqqQLP Y5kOzTds2PLaccPuqLKEDJDcpmXuYvTx4EbXTMLLjlMaZ3bXC93XiHNlH+iJszyBk/c7es/qxc7H kzG32n5SWRpAXDvhj6jZ5vZl07u+dED/IinqpXa9JmKSyFayVG3mf8xjdI2+fMMIgU95Z3qPP2X3 39ZL5Fcv1a9cErdyyd0J5jiIVBastbbp8Ztcp+C/17n9gFuC4Q3VorzxTTZx3NA5qtUZcSucglPX ekIQ3pmjzybRs3vicDFYePBOQ0+4LY8YRv5dwyILBl+4f1s80zE3Tr9VbP4PuJPZTFoiFeTd7nn4 0aGeMFSpY9OXgfo0GmEwolK5+v6cW8IizobpbAK0N4e3jNZocGHJXkH4vfuLTYlJYivCU2afInZ3 cNP9P5+V5lNriL3Ilb2ynt2zZ2m36dWbJbeCERONc1LYsOvkQ3LsfPdrAvWKqO0BKiuL3J6lNpNH ukoLb2CIdNO3gR3Fn+k2Sx8kSWFfa1HcQ6zmm52rxV8wAZYgrt4Dljkbd8vhit8Z6xyBN1NYYO7j 9V4p1X5Qqs7Ii4uVN6L3IUSdP2K6xM6rYcXPegVj23Nljxw2OVc090be8fA0ic9hDGRzcgkfr8DZ ATaB6wMv3gDhYUDge4oANuMe5TPuBCGdYSRScDTfU2ieIdvs4aOLW+pCP4PA80ZlLx296zfN+ZTz xntB4U6xUe11ZxDxgpL9LpLZYP+23oHwXYgPMgMCrxYCPOz5rAO8VwuRJ8/Nw+Portl69OSxnyFG vDpeLDl785Je6f2XWr1zo5Yl9xarsKpybrxCwIBAQCAgEBAICHzvEcCW1puTW9Fz7j9o3j/DNXev wFjyQjAH3Z9JXRgIyYm3m/rPEB46qu0KzKy5YxIPy58jZc/tuSM+iGZ3sNbsy5EWH6/WLukfnyYn C3T7C/SDD48XdxfL+3r2OzuZTe/uHlshMHrvJE60V5bch0xz2Fwep8kST3ZRg4oO6GO78+0YFEQ4 V+vIFYpCqOpfbcG5CRAYuoBjfaWaaFUs4GVEsxBjc3Fu2G2MJ77x6Lx9sHTBp8jT9fI4WtxzkNAJ YW1O8z1uEhDLWIIXn1hEQYU0ZaoFmI9KHcCqmZG8V6yv4Ch0B9GlSc/51A1qVyNyQp7r1sjxtNNz xQ+BXigC2THZ6nDKSU4BP7ek5ay0sw/Ef8TAl9zpJ51r+Q4iX4jzPeMGS1cBbuPcTf1nCA8d2ami DXSeyK2i/nC2ShqWv3LAwvf10QeXKmuUmh6wENDzhRtrGyBT8uVIBZcdsNjBa5d0k+gzyTs3tV5S Z8wzvSkX+zxJTkhDL3t+xrKpqZSsCUwhjY8k8HYzAxsV4kptEb6R7eYWNtZikw9TGZRXYBXRyoU6 f8VZFdHt4SfkcrlCHWrX5Hz3qaIxuShi3xgWNhrB8N4UShP59eqHar+xJ9Gq2O0xT5RrbXVEk8d5 T1gZzdfn/enTObl7mVmWf61P5XCiPjkiSmqErSbc4mvDMxc82DLry8YqAcol7YzACSDn9G10deOp A9huZ3agQb4smnu09RWclr2L6LKUNL7qBqW5N6u/P+ETI8fTTp9QUgj+AhAQbjo5q+vw76l0XT5A sOrRDqXoV55I5+qU3H15P7Cy+cTZWlnIRfYAEXM+Sles7tHyJG++l74UHrIyhzaQJH55F7dID1jY sGp0EOo/88XNoHuWYYtEQQlOrg/QBprQ+hO8FlcvNNDq312YLrhi+YMNJC+ixOUvrp4wj9j6Ijv8 c25DElsqDIkeNnQZbEspkijjQ/I0enPEwHLQ7CpstTkeSOuhGUvkQAF4P0gACNYUasZTJGovq+zz NKfYnGSPx7BUykndxxESISK+BzXUoeyY59pwwk5RfHwOkdkS+0VLnLQ876COaWzlqPs70QPhS3xL QYq9XtybSvYtlTuVi6FyYVoX8ezquDcPdLdxFtKTqEesYheZcaGE5/rlYIjNHw+29O+kALzIi+rW B5YmsWI9V4OFND5RDKhGjlMPzSN+enTGoZUrF1rCYJPxeCaKI55hy5k6G6jYtGyPQGSBxBIHQ8CK FGED2JUhdwUrki4uScjZH9l9nd4bdrTXLtdT8SClOrBl9+PqDbUlW9q7T1tPwYlO/JMfxiwSXUqA AiC6QRk7UGib2DBGbAsXBmgg3nQ3UBaKw8gptNOCgPDlpUHADFWw8eamYVuixcjukx9D9Zfq7+E8 inTRabj4sPHuZb1dH7vf2XITsl58YFjoJHdSDUqH9+M524j+J302ESv8FXwO8kDsddeHGmAhq+FB G4hWqSRc6t3KuKVkHz1gmTlKqP/ErO0iPNwmC5KNGD0r+5F43vnKJ6s1jqdZ3ycsf7fluIGO+Fe/ /NLV81ueWeBPONoAm6buwRmiIkpTtSmqo4J5DbGcUXAHcna7utbJQw2vj46Fb+qmOH265reFQkqd jAYOmgtRBM/FytmQJd4tBIGPi2UDMA594MwCBo+KQXexXn8y+nxCWhlcrj4PKpTCp+vozlJ3PHj2 DULEnt9aL259OPpSTbpiVm0+u6tqTsrThe8Wz1uSW1gsUPJh5wr8sjdRj1geizAn5WXfkds9sHWM BaHGDpUK75YmPOaPujg/yDK6eECyyip9peCq/lR1Fnqu6XE0/fzG5LaazeN4RKiYEYfHBv10vmRF uyiDTRkmmA3GPOHIY+xoPq+1P50dfaCGM44OuPXUga0cjXxz+Onb/Y8n+o0nVW09BWclS131EF1W ASm6FY6LzY5x9o7A8G9l4kZOUKomcFUGYuXmac/yBLfi4vby3ufdAExxaP49Uu3VPhCqSTkFzKPQ /JWHuWIyAb7OyYrTT7qaBxXGIVoUZ3dJpmdNpSLEJknUZfWiCnahpV0osSuMOE7YwSbJtjJW6Hx5 wrMxtsVyrr98vQkNH+6mB3xAagulA+cNrvPMl8nsHsJD1HnJnZrzKY9WyK/b+BSleQyIDHGHPlIn WX59cBtz15+X9dzSqsskmMNteKoiqh7gJwSB5zXAvujWFue8ni9HCEqzeZWgkERLMeWy5apZKbR3 nqQ+uiejFTX3lQx5svuGMuZwbeZEm5ss7435pam3vu/1NqdiLvG0OAcyP9LcWTtHUsjUJ3zZCukl FZX6hfr1N1rsYys6F51qchejoYtyYLykh3g0FqUQGHoSrYql8ZGJI4oyhW7FMl9qUk6gg32uVnhh g7zyBk//PeSLS4QjRQ0xFqmHvtIKVzcFnU1buNh6l41CREmx6mlDGX3o4nDlFNhO5Ayjmvtaklwl 7/CIO+YsWfHy1AE1hfVa56NrciJV9QkRq6BtLiUvOPvMVgMUh0N06QGk6FZAr/qePhBE11ZsVjKg fkdOUJLloPnZbyp8pLYQg1uxZfFS35hGJy1R8+9xzG7eziNV8Qb5ALUVzfuojsWrZJFir7w9uRPN 78zntyO1bzM7uTn69M3Ou6/RzrNduM0f9lbsm3Ur6BSWw2+EbBBW9HLv0/ma01+76QE5EfT64Kso ggJ3ZugSo5dpMruT8FDUlhknpI75imL9357Ies277ww/vSbHvS3PFTWXuJ/IUbqqnuxRy0tApGut VxDUQ7eliOEyDE4E9eGHbdhwFd6XI/T02Ae48qP+x+/0P7ioDT4o952BIUcK4GW5hxdwIKT+1/hY uRUUIhhUKuXHBzjoF6/v4jUZcIhiT64q3ni5f2ue2vkxhFVu5f4nveEbneHl9vCGPqiOUQY8yFuK Jpf2vK7JpkhmYii/1JhIDxzS42uddy93hm+0P9JnyXmU72TClQUQGFYTBUlzWSxHwbvdihRBgdSx WuFjU1WQN9ZzYTbW9Wfjoa8kXu7l6nzCLpZ4KITgwA10YbY+4BGdWuPjzfJz4Ha58+6PBkKHAgIu ci+LnpSsF0FMCeZuxak/D138fXUgWS41IzS7N1ywk8vVVgaHmIFwC06Fwl/lVspEl7v4PMGuaWEU crb316cgPUZ9y5xS/ocvMUp167zMWxb5SG1xOJm1SoWblw8BU+5uebGVmRchid0Wt0IKVlx5v9Rt GuWMidjiJJiitH13OL4VzTFHQYvtJmqkWbflCS8LFuvZ0Wc/YndXJvN30APqUY8QdOe6mcwiLT/h oXQs31cvnKq4FeHfuPImDfiNdwYfg81DpmUMpZ7KsmqoXFgp6GlyZwKLTuqhC4KiunWmE7GBwdoW QaaUIxkyvNaFPjfeHnz8NnuhJI9NY2744dtpM7pCLo7AR2xO1qv1OnlIk2JmXehWNAV6jtMm+vIG XswhV9S/ChP9NceVb+nDn8wp6UG0ZAYjz/mbs/s3hzeu9W9c692YYPAFbhMuEGNlQElC3jHzo8di fJeKWP50+Tm84WsHX8rEGpzZvfd7H71NIZ/9+p+Pb4xu6djcbnEVL16sJAoTXRYbk4PFaFt5tYct C9vNqFZ4a8egejn8xkNfqXMI9eOqzooEXs1ePhyChXIGTp0cdiLcu52ubr3NjH/09lA4gWW6Vfdw KJ2zVev1veUqSZg7Mlmqy6k/D138q3UgXty6ad72uwEhf/3GxqMt8lAuOJ2SdisVoss9fJ6mxUEC eI9f630Gbhmq7pTyP/1nVC2z2yS5N5vf+6LSPDF4VNzLTmatUuHm5UPAV15s8mCiAxs25pwxldT5 0vABQn+PW0FTujkrvonDiM0zLHXv8hHXYpZkItrnVi6PjzNf+AmmI9pkvZOZH73U66cHzCfTchWs GdlNeMjhPObP0WSPybZUGK3Q+LRuWnHiAvgqIvZmMcHlZLmqp5q+g7/IbZTqBuuBwLUb2OYEtDE0 yDuoTMqZpFIO11gT0UN6j86BZerAdwKSX1Ech0DNnm08BeaczlLTYm8a4netvM2V3BzzXVrv0h2k a45WoJK4b9XljkhUyEktLqM3bmB8tibnyTWQqzkXHSIefrK4v1nfO17ew5qC6uveWOqccs4zkZ5/ 62O88WS9une8KmxFVgv61xRNIoncaXyqiXrEirfVU1hgcccrThzN8iybIqtWeGvHEC8vMh2elaRE X5mLl00IJZ3JJN/4GC0kER8KCk0hY7nKmc/kDlav7DqdlSPLjsbY4ml6B84X2x5g2odY93TeCLDD 0p5W64C8EgXcmJDGoSuHzx5tPQWXayXvpkQnhVdOdOkBRGtlEEZw9ZIXVXMkvvkjlfZtdmNOJ2hi 9U9/w1m+Ah+pLY4dmTWiwudLgoApd5aXWSxA1f2wq1eWLzQ/EqpJ+yvdilRvvl1UTezIRFlhGKts rO1QSV4xiud0Df6pSWaYbDdRNHZZW8HbTrlqf21+Ug1fWhlU/dsd9IC5+8uRNpmFc9xBeAhmwlua WK9+DXTougVBREoa22vGGlNmyr3ZWLaA2eHGKvpB7Yaqeurdns3P/sHMhkGAiqisop7caN4obIWC /+SktMLWkyPaK8fCqAUvzE6frOyegatD2VZBn2W2Ybzel/4w88CFXeti+EBd2X29xQjl1bohLx/j Zgb4LNHzmt6ym8ibZOXhtUlhERYVADM/OlMqAKE8ndk3nje5qzaRd9M7wQp+HLo4BIZvfSjT71tP omWxiBhHn8EOi+R3Z8X3SOryQqC8PpQrvFuarJn5JBi3b1XpKxVs6q9H53RtSCnB0q/mtU5nA7MN oHOz0FcQKdI0Cism0SFqguSo8YEqEZVcNaR6nvrqwNC+mrP9qeoIlrX1F5wSqToG71aJLquAaK0o zZYp34PsTOtpmfhwyDCvTzi5XW6eUp0oZ1dmc1nh7uVGICOnH9cvnuNFSu0qD14lAQRTz3zhuffS fcX5fnrAiuz8wW7CQ9nemQd8uruynpjB874KXhYCSKjrZspJUlGIP0VBgB7wgZ5ZMuJKjIvSgXS6 xCaY+hRSx1K6DyHT7fkjpJessiip8I1LNk9Ur7KHeI3jmYl6xGLJoBKxoErxy5NW+BKYBWE+nSV8 MdQZlJuFwPzypNBtd9SBEv4+bStpn/1gHyCILeMyZ1qvKJDrO4VS3t08ixHDt4DAc0bgJacHPFdu PWO9YjwOWPKBZPG3Z/rG4c+PnBfXPpOwEDkgsBuBY3mVm97GuTtY+CUg8DIg8LLTA54HoxTL69XT KG7M0+PomDvZnvMFOpF7z1/qc1YyiHslEEhPwNhTnet7JfIWMhEQCAgEBAICAYGAwHeLgKaa/M03 x2v2mXcT8Rm2t/OrU6EE9DLdKXnJZj2bfjXB28bRq3niPvST63b+XPzuQn69fMzFkfTx18LtkW4e f73rFVNPouS3m8dfTB/9fPLoi+jxt08M9VZr9SQphrABgYDA9wgBw9/yb//sf8OOI4xSd/IfGrY3 Fxwvg6IO4KEErDLdSVjs7ZET8a+1hmDJUNuNrh0VWZLcVKv3Pt2qoZ7uyTdHp63eo6eL+0yxkkc/ qGW/SLbfzk9/UDv9drv9opv94ODZNEke/7iZQewPW6d/2j39YY33Pz56/AR6Gq2eIEoIGhAICHyf ELBUk9y5JwceDf8hUMAJrPubGHuBTtml5W5MnIA4jUEyyYcMkDMoghlPHvEPqeQ8lIAepjuG5rnp iwdfcisUXsPKJ9vjGQ+JX1M7Y/G9SjiJfSWb++Bm1InmO0UlvvmT4DREgU6wwIZ3Fn+mlvKLg+yP Dh7Z3G3Wjzf2gAaOgeBf8niDA14S4mTz+Nt0i3/2yrAfVb5kyfab9eMTZ35ZPbHjBfMeYIbmffoY Zv8LuJVIu5U0loSMQIbDyUctfQvFvtnotPDBxylTdGj9Hv9pjXmBh0pxPpLxt1/P6Lx+PDOeJSvK kTAY3UCOSsdqJb/kfxjGpi6Py0DhodLH/upAkQsKdwGBgMDvNQJmqIIjyTc/126FZ5ZxuA9cHw6H NvlDihvaL4/uqlPnsP+X+rcqVHIrnIY2TI+Gh9DDdMezGzithp3qPOQl2/Jx3ACnC+MFzt7yvEaB g2IfMaDdHq+K5MQe01DU7jjNbY5d4LQvz3TLibOd/JlKSrqk1cW/Vv9xtn7Ulnt+7dHRyDiCv2I0 Me2rm+yP/oxRfroSATHvfxFvf97Tv+Lrn4xow391CGehH/7VHCb30R+JE8FPanhyUnErXyGJ3qOf 1LO2SEDIH0Pa0eOTuVaSAluPcOJUKQaBKolfyNQZo7c42PmrllEVXqb36GRBt4VYVTnb7PFPTOAf 1E9/Rd//+IdGT4iSywnTOP0anm75CGFU0j/sPQLUBX0ap38iIyYE+Evrzoys8BkQCAj83iNg+vl2 tCJnkO+QmbBxgwem0mOMJniISdyKOmctZHe0+ZZBsUIl56EE9DHd4VAGaRJ5CL1GIsRs/SXcyuUx jtweC12Dh3DSSwyouB1scUiY9+Tc1j3of/noGG4O7IvIEAZoOKkHBgk5h7iTP9OK+qpH24uvHzSz H/ZlDip53Kplf7VQ44jsr6PHJ/H2V4MMhve3m8d4c8BftxCSvuO3h9kPmo/SlOF/LrYdU2rKhsMj KO/wq+Hpnxw+ds21Hp4YA25HK7/qQ5PHX49PkRC8QLaiN/lVuv2rZvYnYxluxNo3SZTsb+naHv+k kf1wgF8f/wkcXLpFdqAAjD+8JPyORNSeoiqH+tdOfysDmw/a2Q/ajzKjlcVHhfk1w3A0BDf3l/Ws NaDbzTaPkPEfzzVQf4t5zZgepz2ktn/b1cBaUeEmIBAQeBUQqLgVDB9wdp7Ht7uaYVU5GpkE0yMC S5qqAhMH4VrJqeRkakve04HfzPHwrMJ0x7d9vbdOeeJPB1Zylni9yF3OucFYVQgn9xMDqkJxOE/k QUJWE/2miS0n6IQ+MacOsGMrnVklRf6ikw9jDrOvhirtVoZ/sOet4WNa7/qpGN0tg4krQaSTWe47 /mJKE5quH38wOP2TdsYRRIMLJT8/kP58PfvLw0cbuu98FLDLrWhNEob8WzgyjD464uayx78YPfqL zukP65QJ6hmlGFLBBX9H/RPY89NvUjqXv5jJD+LsPljingJ58L4iBxOAdjWnNIYSEfyjtbLfRb2f mpWxnyLLvUeuPnA6cDS4lJe08cJNQCAg8IogsMOtzEAwa9gmcU+SFhMSGbdDm9ytlKjkhJLLuBXF Q5hUme7i5PYlvGIpvat48gmpvCkDpo7viiIVoYdwcj8xoCoXGUZp9td0fXf+j/8ZbsWc8D0lnf7g rs1F7vhcAiglyJpNMcJ/PHz06+jxr6LHX2Ab1TJf9UDYgnXNHv8xZnhGnOb6NVzGhuOCVvf0p9PH v8JopU63gtWNb5aP/3p4iv48HY24FUWqkqrFFONotJdxkvjbNiblHsFB/CSilhhlQOZfjR/9SmbD 3OWYXLHkUUtSgSYIwEsGO7+FE5xqlapy6FbgkuTSvtJopR7ir4zmdBh4z6/+kU7qr9Uc4FYGbgPx v7LrAOExiafcSgExKy7cBAQCAr/vCBhnYW2sdNdvyxtJrt9cwRd8jikjNQlmJ5pkVYKERZZBETCU qOSqlIAepjum/laU8AV5rw/vxJvbGLZgKWQmS/aknfcRTu4hBrSkl/L2q+szsGUKc9fr4xVZHGVj QLL8Ei4GtGY2y2e4FcwatblggUmwH3S53o25HVjOv4x2uxXs2pKlFjV7plYW6F8gBFNJMO8Zp8XU QOZrNS0mbuvHE9jnx1z7MI7G9RHSvefwRBwNp6e+Ie4Uhakn3P4W82PFVX481NZb3MGvksd/IXNQ Jxt6JaTyhSzZ/zUcuU/O1/SMp19huhOLLMh+x5kEy7ZfHD369WYr03rZFwiT0pm2x5x2UxsDvpVF Fvg+6xmhT3ArACFcAYFXGQHXrQhROQYg8kbahzcVFV79rTfw3geOVnIqRa5KSGDLoCgTQUUquSol IAgMy0x35D59/fAYzK4w9dg58PbwI7m5fiNaL2a3j5OHVcJJjJZKTJiy7iNMdHNQ6WpixhuGLfNi 5zMsa2BJBcyQalfAG7LIQrdiXiJT5c+0hf5t9Ai2Gksk38IUyywTvrZkP5U7t1Oa0lELHzLFRHv7 Fw2Z8oLV7cg8VapdACVj0CEr13YR/4+QSpPjF/gL7VZkgAMHgZk3UUy8A1Zk5PqFuDDI+aMWxz4/ nokZlyj4HYrJ2grdYvvwsTL1CPyXQ73B+KfR41/PHn2dbKtyEP2vsatZlIRKXGQxWm2Txxj4/GRB DX5qwvxR55FA/Qj+RcX6Y1lkcYGCW1GDrF8PZXaOAsIVEAgIvPoILEcfXNZUqwnfhzUyc+XVrFsG RR+VXJWHkHx0DtMd1uhh6t8Y3o7xInhzpfG990mrPpQ3VOJ9Uh6CyvMQA1bZ6kBn52y4Nemd+YkF bhlrICAmr9z9w7uibjCzVDuVVXod5Fvs6TVC9KNsi4eFZ9hGJR56l9hdz7GNuSy8EhRr9DD1mMfD pgJ7YdPyB/R0el3eKwcboaHn/gsRS2E8+d0vIvwaEAgIvBIIfPHLr//+5/+l+u9nh2N27P/gz/8V e/jvvv83njBurI/+9C8Z/r8b/8wnzQ1Zvf9P/+Hn/8MfyjjiD/688Yf/k6R4pfFvxv/x785ItCrq eT357f+jX2L14NvHX/78if/9jz9gX/3f/c+PniLudxpl9h9O/+0fyjjiD7JLf5j9tzKmuPRvTv/u 7544j89Lz8X/rcdcr0R7CpkICAQE9iKQnCyiO9HintO3/f/buUMVAGEgDMDv/3AWEWaYw2hysGIb YrMMBMMEv3wH//GFgyvX7n/9Su4oOYY0DinEbX8U2R6mdyWvdY7f3ZZHqUuo03ANeb9cerPJJ0CA AAECBAgQIECAAAECBAgQIECAAAECBAgQIECAAAECBAgQIECAAAECBAgQIECAAAECBAgQIECAAAEC BAgQIECAAAECBAgQIECAAAECBAgQIECAAAECBAgQIECAAAECBAgQIECAAAECBAgQIECAAAECBAgQ IECAAAECBAgQIECAAAECBAgQIECAAAECBAgQIECAAAECBAgQIECAAAECBAgQIECAAAECBAgQIECA AAECBAgQIECAAAECBAgQIECAAAECBAgQIECAAAECBAgQIECAAAECBAgQIECAAAECBAgQIECAAAEC BAgQIPA7gROpB8nLCmVuZHN0cmVhbQplbmRvYmoKNDMgMCBvYmoKMTE2NDI0CmVuZG9iago0NSAw IG9iago8PCAvTGVuZ3RoIDQ2IDAgUiAvTiAzIC9BbHRlcm5hdGUgL0RldmljZVJHQiAvRmlsdGVy IC9GbGF0ZURlY29kZSA+PgpzdHJlYW0KeAGFVd9v21QUPolvUqQWPyBYR4eKxa9VU1u5GxqtxgZJ k6XtShal6dgqJOQ6N4mpGwfb6baqT3uBNwb8AUDZAw9IPCENBmJ72fbAtElThyqqSUh76MQPISbt BVXhu3ZiJ1PEXPX6yznfOec7517bRD1fabWaGVWIlquunc8klZOnFpSeTYrSs9RLA9Sr6U4tkcvN Ei7BFffO6+EdigjL7ZHu/k72I796i9zRiSJPwG4VHX0Z+AxRzNRrtksUvwf7+Gm3BtzzHPDTNgQC qwKXfZwSeNHHJz1OIT8JjtAq6xWtCLwGPLzYZi+3YV8DGMiT4VVuG7oiZpGzrZJhcs/hL49xtzH/ Dy6bdfTsXYNY+5yluWO4D4neK/ZUvok/17X0HPBLsF+vuUlhfwX4j/rSfAJ4H1H0qZJ9dN7nR19f rRTeBt4Fe9FwpwtN+2p1MXscGLHR9SXrmMgjONd1ZxKzpBeA71b4tNhj6JGoyFNp4GHgwUp9qplf mnFW5oTdy7NamcwCI49kv6fN5IAHgD+0rbyoBc3SOjczohbyS1drbq6pQdqumllRC/0ymTtej8gp bbuVwpQfyw66dqEZyxZKxtHpJn+tZnpnEdrYBbueF9qQn93S7HQGGHnYP7w6L+YGHNtd1FJitqPA R+hERCNOFi1i1alKO6RQnjKUxL1GNjwlMsiEhcPLYTEiT9ISbN15OY/jx4SMshe9LaJRpTvHr3C/ ybFYP1PZAfwfYrPsMBtnE6SwN9ib7AhLwTrBDgUKcm06FSrTfSj187xPdVQWOk5Q8vxAfSiIUc7Z 7xr6zY/+hpqwSyv0I0/QMTRb7RMgBxNodTfSPqdraz/sDjzKBrv4zu2+a2t0/HHzjd2Lbcc2sG7G tsL42K+xLfxtUgI7YHqKlqHK8HbCCXgjHT1cAdMlDetv4FnQ2lLasaOl6vmB0CMmwT/IPszSueHQ qv6i/qluqF+oF9TfO2qEGTumJH0qfSv9KH0nfS/9TIp0Wboi/SRdlb6RLgU5u++9nyXYe69fYRPd il1o1WufNSdTTsp75BfllPy8/LI8G7AUuV8ek6fkvfDsCfbNDP0dvRh0CrNqTbV7LfEEGDQPJQad BtfGVMWEq3QWWdufk6ZSNsjG2PQjp3ZcnOWWing6noonSInvi0/Ex+IzAreevPhe+CawpgP1/pMT MDo64G0sTCXIM+KdOnFWRfQKdJvQzV1+Bt8OokmrdtY2yhVX2a+qrykJfMq4Ml3VR4cVzTQVz+Uo Nne4vcKLoyS+gyKO6EHe+75Fdt0Mbe5bRIf/wjvrVmhbqBN97RD1vxrahvBOfOYzoosH9bq94uej SOQGkVM6sN/7HelL4t10t9F4gPdVzydEOx83Gv+uNxo7XyL/FtFl8z9ZAHF4CmVuZHN0cmVhbQpl bmRvYmoKNDYgMCBvYmoKMTA0NwplbmRvYmoKNDQgMCBvYmoKWyAvSUNDQmFzZWQgNDUgMCBSIF0K ZW5kb2JqCjMgMCBvYmoKPDwgL1R5cGUgL1BhZ2VzIC9NZWRpYUJveCBbMCAwIDYxMiA3OTJdIC9D b3VudCA2IC9LaWRzIFsgMiAwIFIgMjIgMCBSIDI2IDAgUgozMCAwIFIgMzQgMCBSIDM4IDAgUiBd ID4+CmVuZG9iago0NyAwIG9iago8PCAvVHlwZSAvQ2F0YWxvZyAvUGFnZXMgMyAwIFIgPj4KZW5k b2JqCjE0IDAgb2JqCjw8IC9UeXBlIC9Gb250IC9TdWJ0eXBlIC9UcnVlVHlwZSAvQmFzZUZvbnQg L09NQ0FKTCtQYWxhdGlub0xpbm90eXBlLUl0YWxpYwovRm9udERlc2NyaXB0b3IgNDggMCBSIC9U b1VuaWNvZGUgNDkgMCBSIC9GaXJzdENoYXIgMzMgL0xhc3RDaGFyIDUyIC9XaWR0aHMKWyA2MTEg NTAwIDM4OSA5NDQgNDQ0IDU1NiA1MDAgMzg5IDI3OCA1MDAgNDA3IDY4MyA1MDAgNDQ0IDI1MCA3 NzggMjc4IDMzMwoyNTAgMzg5IF0gPj4KZW5kb2JqCjQ5IDAgb2JqCjw8IC9MZW5ndGggNTAgMCBS IC9GaWx0ZXIgL0ZsYXRlRGVjb2RlID4+CnN0cmVhbQp4AV2Sy26DMBBF9/4KL9NFhIE8JYRUpYrE og+V9gOMPaRIxViGLPj73nFoKnVxFsfzsMd2cqqeKtdNMnkLg6lpkm3nbKBxuAZDsqFL50SaSduZ abG4ZnrtRYLieh4n6ivXDrIohJTJO0rGKcxy9WiHhh547TVYCp27yNXnqY4r9dX7b+rJTVKJspSW WrR71v5F9ySTWLquLOLdNK9R9ZfxMXuSOBEq0tuRzGBp9NpQ0O5ColCqLM7nUpCz/0JLQdOaLx1E keclkjMlldIq5i+R9Hjr3LRLyywtC0ap7aYURZZBgVK7Ayv6MNAt6wYKkLxn3UIBoinrDgqgxLqH AmjsfIACpfYZR49QgOiRVUMBNHZuoACac9RAgVIbTFNkFgrQKtYSFCC55WgLBZifj5HjzhhELStm ZTKVcm2OWRm04kPmGI6BYl9c8+898Y3zz7i/pLmGgEeM3ye+L79b5+j+w/zguUHkB8kstgcKZW5k c3RyZWFtCmVuZG9iago1MCAwIG9iagozNjMKZW5kb2JqCjQ4IDAgb2JqCjw8IC9UeXBlIC9Gb250 RGVzY3JpcHRvciAvRm9udE5hbWUgL09NQ0FKTCtQYWxhdGlub0xpbm90eXBlLUl0YWxpYyAvRmxh Z3MKNjggL0ZvbnRCQm94IFstMTYyIC0yOTEgMTI0OCAxMDUyXSAvSXRhbGljQW5nbGUgLTUgL0Fz Y2VudCAxMDUwIC9EZXNjZW50IC0yOTkKL0NhcEhlaWdodCA3MTYgL1N0ZW1WIDc5IC9YSGVpZ2h0 IDUxOSAvU3RlbUggNDAgL0F2Z1dpZHRoIDQwMSAvTWF4V2lkdGggMTI4OQovRm9udEZpbGUyIDUx IDAgUiA+PgplbmRvYmoKNTEgMCBvYmoKPDwgL0xlbmd0aCA1MiAwIFIgL0xlbmd0aDEgMTc1OTYg L0ZpbHRlciAvRmxhdGVEZWNvZGUgPj4Kc3RyZWFtCngBdXwJYBTHlWi9rp77vk9pLs0hjaQZaTSt GV3TOhlxSZjDAluWOM0tgblsDMjBIFvYAccYO1kn4ByQ4HU8gA/YxIZsWGJv4jWb7xDH2Q141/F6 Y/PhZzfE+UTSf9UjWLzZ39N1v66qrnp3tbRp4+blRENGCCXJpesWDxPpsl3BRFy6ZZNfKhJNByHU u2L4/nXFsn6QEEXF/WsfXFEs22cSUt2ycvniZcUy+TOmwkqsKJahDtOyles2bSuWbU9gOm/t0NKp drsfy5XrFm+bGp/8E5b96xevW44pXh0MPjm8cflUO/QRovoUsPKTF2+yhGhZhFdTMSGTeBHWYiP7 iJF8l6gIh2mCzCdE9orqU3xfTmqXETLy+cOHBgxNf1B6lNLTL9Uue5tl3lKdODbx6vhfq8aVaxCa 9VC8sF/livG/IkTdM/HqhFc1TkyETu6aamWJTWybB+QZ+BacgovAq8ENFVAP50AGpdAFRAWUmFs7 twXEjm2By1fsDu97v8Bo+8N2j7g9EsuKD0ei2dOT58TJh93BrLjd4cIqgyW7/WHXP/4cAbdsxWjd MEa+odwQR4aMQ4mh5JA4NDA0NKTYP/Tu0JWh60P8rrX713K+tbm1u9ZSw1rf2gRme9YeWCsnmD27 dnItv3aI9bF+13rOtz6xPoeZ/etlyfXA8vvXn13P+9Yk1uTW7FojZc6ueXfNlTWyNevtnjXrd210 b9pstXnvX42RYVXPqqFV1LcqsSq3anIV71sxtGL/isMrXl4hM6zwrehZQQ0rYPLWPbQCDAhwYAVd sQofXr7S6ulZObByaCXtWQ5Dy3ctP7ySLl+5Z4PbJaofsD/U7go8iOE0bDz5ZpPvNIRe393re3R3 1nek1QklpIDhHIaLGK5gkJHDGL+M4SwGSkbAg1t9GFwEJs+dejcQyp4Gt6h5yuz7+Kmo77dPpbDL 3SefdvnOwAjsFDMO39efJr6DGL6C4amnRd/vno76nn6G+L6K4TkMhzD0Pjf43PBzI8/xuM2Hj7x8 hEu0muEJksMwgIESP+wjIoYCBkp2wSgOPwJjJ+212TOT52DslMWWJa3LYYwYMYgYejEMYhjGgJBE gZN+HF/kcXyRx8m7GC5juIZhEoOCGDD2YUhgyGEYwCDD2lGsHcXaUawdxdpRrB2EXdjvLux3F87G ADsRZifC7ESYnQizE1t3EjmOuB1H3I4jbscRt+OI23HE7djSg/EAhiEMuzDsxyDDXrZjL9uxl+2i gZI3jW8m3xTf7H3zwJty8TTMfd3szop/wiVnr9xyMll894aTwahU0yiqMCfezLVmB1oNsAU734Kd b8HOt+BUtuBUtuBUtuBUtog6pf+z5GfiZ0c+K3wmS7bWwELc1hzyAhbPwbgAaUSENCJCGhEhTa5j kGGXVfh4FVJvDmOGCJXYbSV2W4n1lfiGlQjlh3KSxMDh2sTwrWL4VjHRSo8cLBw8d/DiQX7w4PDB kYMHDvKGH0IAAQIIEHiFjrwJl1sdWLqGYRIDxQECOEAABwjgAAHCY40fa/xY48cav2jmD994+cbZ G3TgxtCNXTf23+BJqxF6ERF6cSK9OJFeRIheRIheXPgrGF+HXtHODfxs6GccecP4RvIN8Y3eN0be OPCGwngacqfKKrO42k2nalLF1FdWTM02lg6IBrs76/80+an46ZFPC5/KBpBu6nBh6vB1X4YkziuJ 80riUiRxtpNQQwDH5hFpeEQLHpGGF9X84c9f/vzs5+9+zv8QlkCIuHARBk7u8SD1OE4+3YhJbzHp ObmDUemMk++UY9J58sMuTNpPPrIMk+aTu1O+H0IjNJByfL7m5DthrE2efCeASeLkO82YVLPkhxCH CuJDmPDJR2uxdtPJ3SwpLSb6k3tKsaQVgziBtzD/jWfNvv/cUerbieHwPnhyNOZ7Yh/1je1j/W8T PfuafPtGm3yPYyfijnhVVnwEo4cehUcffegH0EwAmqFZtDywG3bv3rsP9u3bvQN27BjZEcSnQycf 7cXEKR58pNe34xHB98iuJt+uPXHfR3vMvn/FUMDwMobH9hDf3kcrfKN7kD3tqfDt3lPjC+6pqcmK e4IhjHA3PPU2p2CzpW3mOpshZdPW2lQ1NnnSRhM2Um2LRA2xqKEibqiMG4IhfVnIUOrT+32GpEN0 9DoGHTxxDDtGHAccRxwFh/yK47qDu47IZ8TtMmIsYhjBUMBwDoMMkdKMbdfAgLEBFiAFLBDDnHFc HO8dp4Xxc+MXx6+MXx+XJaWawfHh8ZHxA+NHxpWDp8EkqsEgS8hysh4ZbrkZO1mA26ERd8prfQaj SavV6bUqtUYrVyi1chr1EeC0fgJDOBa1+Cgv0w5ah60j1gNW3mj1W5NW0dprlQ3VgKHGV5OoydUM 1MgMGshpBjTcRQo5epi+SycpbzBAzjBguGagHijRORVunYKv9dmMDp2Zt+rsp8F+staHaG/DxHIa rJjwp8EiWmt9nkacWkOtj2ZrfSRT6+tNneBI20mHCR7zF4JzxkLbCuJd206o/Y+dNpL5205w0Fag 3kAACuYZZMa8toIFMJ3bVkjFZ5yGA3cVauMzCqree/pOAHx5IdYWuMdOA5lX4B87zWFibl90T99p cLHmPZ4TMsDGwozBPU8+uTBeUlg2Y25fYaRkYaGWZQ6ULCTxO68HNkm/BzZvjscf2HSrZdMDD7Bq drEGdp2IRToLFZ2LC5Wdgx3FqmIMdxaK+RmFwFwMcxb1ndixo7PgGuxY2Olc1bFJimYUktiYZI27 d/9X42bWWIxudTg18q3if6UP4Kw2PSCVcZKbN7HpSrPdjO+xWSoUgW8VH0BgBrR50xffHt8ZH0RY fImCs1CGq86WAaFZJ6zL4ppgFRawhVXcXiU2xgkV253kXW0zCk13zSgYeu8puENYeAsLAha0oTbc vzjC2O8qyLCAm4qNfWeInCdtJxSk7QxRs5yGtHngBCF244kuMnyCdLUUxE5SaO0saOIFNT6oCbWR XM4ZNzbBlkTG2d8v1xbkWK8ItS2ME9k5ZJpENkL8pF82E2NCv0uc5H76jwTVUnocudijhEz+cvIx jD+cRB148goh4z9B1i5dkweK6f8Yf0q6CIF3se3tyaeLELK/l+2g3+Eyt+F/QX+HGikhq+EPt+v+ 50wX2U+ex8CuLjKPLCGoSd9x/YLUE9lkfPKtyZugIIuIbOJPk0cnb3JZ7viUfls6+S9T8LnJH5HX yVewv+PkMMIeIU9hz7vxXR8h30Kt+3myh/wVGUCNW8SRdpIesozMxPI2spI0k4dw/F34zAUyjJAn Jx8ie0kj6ucZUoESfQFqNz8hSXI/EchZ8k+wbuJpMpMvuWOmUhZegpfIKim7nzRI6V3kLuxxH87D TQZxpHaSmnoqNwU3VZSSNpzdCGplvyUHyEX8rSH3YX2KZEkeXKgwzsHfarKVjJAv45uuwt9cfOIA 2Tz5OnmCLOT6EfZR8ji9j9xLlpLvk23cI9wjpIybQ7oQEzbi7FdxJVwf+TkXJe7Jj4lz8hPSTf6W vED+mbxGCXmafBXX7EmyHn+H0HgZw/m+iPk8rtMQGeMO43zmY5iHb1eLu9VI+kkcc+2kl8zAt3wK 17ZTuYJU4DxfnPw3fI9luK513Bvcj7CtljyAff4Dln9PjWQzGVHcy1XCpYmDsJZUohGzmtTgSF+b /GzyM9yVHtIPn2B8L6lGrNiGIy3D9d9P5sl+xB9EFayffAlb5/D7yEv4ZiJiSguZLlsiq5VV8Zdx 1D34tr3kHoVdEVbMkl+SbZHdPekTc/NmzZwxvTs/rashK6TrUrU1yUR1VWW8ojwWjYQDfl9pidfj djkddpvVYjYZDXqdVqNWKRVyGU85wHkWnO19nasLrvbBQleoI2T0F7pmX5+VKBCzJxAypRZWFUEK sniBWGYUrL19J4iYWViQx7/QPrtAw8bfB/CxWR5/Z4EP4x2avnhZIXZXXyBk/LnndvtC7LLgbu8L BDwFLox3NzbhPX2xf1nB2Iv12CDVdBdIbx8Lpyf/JYOVxkxgoadA7uorlGLx9OR1LOP1lzM8gzzg 3BfmOBvGkPu42jsKxIoc6F8KxMaArmdIgTQVYih4wkbMYVfOAkkUwPr7AlgKYJuFL/SF/tlTVzL/ /e07l60OdS5bhau4bPC/1vF6cRUD/jH/2F19ppQngPPF3k5o1O2h9uXqqkpyQq3BrAZzuPrDJ6Cr BaQM19XZgLJVqcO1MrPZdbKwuiDuG8RMqAMXCVss/9WC1uwTdzYRfKwIRBBMykFB3l5QSOP6VxXE xQWyz3+i8tzYEyislwzGtctCyxbf21egi3GOJwgNd66cV/DO6F2EVTg8hsGVfrarHVLE9sjfudI/ hmUGO4hxqIPt7Rfql61cPsiwAQZDHdimau8bDZzzoGTvG+0smOKFafj4tIc+8tAxlJJ+VhwbG/UX jszpu7M1wGBwq51Vlf6xzhCOhp11rm5j+5W4tT8SznUvYxux2F8YWbIaVwrvxU/cQu7AmLHQdSOA 24AbceupqaVdNriavcZqfJLHxD+2b7n0mk9Ir4Uo6e9c3cECexARnMxHwlnU17ky1Ilrua84IC4G Zmj4vz8bCBRccfbg2Fgnm9/iZThztip4u1A8t/dNFRDtPXHASbcXxHlSQuZJ648jios7Fk5VTQFg C497UBBRC1nIXgpHmHFXXzs2d4YWdzB0u7NmcKoGQTpvNbLZhrqxh4J/qZ+RVggfzrBoeYaMLc1I axVYCFWVM3pvP9UV6hocG+sK+bvGBscWn54cWRLyG0NjJ2bMGBvuHMRukGoB6/9mn6fQ9cTCgnFw JTTgzjEk6kLq5cJd/pWLsYB3LhTAQUw40WIzPvo/NxNEXURgJJUx42e4elrkIB5/F5sz4wSMOzDi wtHn9yFCL8W+O5dJESI66oech6E8XRjuXDV36k08ARxLIizGp+ZM1WIngQAjhn2nRbIEC4WROX3F sp8s8ZwkYiKOGzHIWs7darHNZy0jt1puPz4Ywk1h6un/HzmR695GzDFTyOzPJqQpFDe0YGnvox4O a1iO81CWU8eRTzcVHHHMc2H2+sjCxowh/8VQwRgvyNr7znmaFvqNJuRebOvmhmagUso2E5+eKvk7 x24jRLG9wLUXYf6/cPP6/vKpW73Ou9V/VWXxh+yr7UQIHptzQoTH5i7qO2MkxP/YvL6THHDtg20L T5RhW98ZPyGiVMvdrmUwflYiMxg+n+SUUpPnjIjeRAmWlyqk8lK0CaS6IhDWAVmK1oNUZ5TgmIwg RL538k/8R+TriifJKvokCdNW0oGKZYqWkDBa5b/AvJvLkpnyLGnhHyCdCBPFtjQGJ3ecrEWYaxxK dYQ5L9tKkphnF+CPXVrUN2sxDRAr1iixxKGzQoNWog59mwrUYS3EiFAmoiZmYkAovfTcEXiUu8D3 yEzyryqGla+rX9R8oO80dhn/wfS2+UOr1/ao7SXbBw6fw0f4yT9NXpU/Ru8hs1GDu4+gdxgU8ls/ h8KhCNVHFYpoPcbRekd9VB61s9pofdTA3a6MRKd+ivqwUO+wO+x4O+z1Qr0A+FxU4XBAXShos6Zq o9ZQkOkU8sd4cf/078x5o265YvXOpb4y811Cla+malGNf8H962YFXXbbGWG6K+7pMXo8QqvLXjF0 xFPWUxKPlfXcO+cZD8DK02Vqt2tWxJU4v979t2vHTyFYJCjcN/ErZmk4TXjR2rwzW9JVeU8gS9c/ KJtTq/LkdR1lvKBaoJqz2agIBvJGQRbT2yJ8g9EVVQkluS53oyOddNU5bdqyWf4GvTkWqLIZXXoL nwtN/B9NpCqvW1QF1vLymM9sZpb61yc/lzXK9pA6KBENRAD/ty+XXCvhSvZ6wIOulFfCum8bzZgR V6gTL1TAC4oKhZrGlBUgD4NMDY+H4Xm81SCEQVBDsgKSCqgIhx9RK6xqtUKtrgjT6QoQFXBVASoF KIy+srzC6HBjpDfn/YqkYlAxrBhRFBTnFBcVSgVzQbc6S/ME648oKFEcUFxRXFfwOUWPgvMpEopd CirNwddjAINBXX20hh4lNcfJ8ZQ5/LT6afdxy3EHJbmPP756FSPjVeNVUyrR32QyZ7OQ2LCxf0O8 H9e3Hy9HKjFaHdfvMJ4HVuzv34BXXAJ0Gj/C3/ilq8bxDZf6r9Yk+2WIQy3UbK73yxWKUFSoZ3gi C9fWO6bKkUhArqByzma1OxwKRSQUBKuCV26LG8zz+uwTr82vUMWUPk7dbayDb8IfVY0qt1sdUwIH /om/UgfatLNiTyt51XfvP6RUVipUJmsOvs05/t7/llI5IaplAEqVXL3k1yqVaRWarT+YeLJ9wl7j cctUcaUS93HV5HWlT3aAtML3xBZDe669p53ez0FWhFgjPIZ3JVTEYSz+tfgHcWq1OokWVFqtQhRA EJrQ/aelyWTcG7QHGnALfnNqKhUrzKXCPd413u1eOk+xTLFJQdVeUFO8FV6n90tUYaVUEWGPtU49 xlJxv9kmrIlsj+yL0GWtm1ofbaW+ANgjYG+FSCDwpdYWa2vA39piJ+ArgUBJIFTyCCXYFXG2gDMK 8Wj0kZYma0tLUwuNNwUUTkV1lKNmylGuBfpaoCUebYq0tlBS4lU4tW2BQHubtyQSbW1N2Y6ajxs1 R/XHjTRzNH08hehxPEX5J0nuxlXjjavF2Hg+kWhKNAFutSthcmQT/f2JfmIyO7KjsmrnLYwYxayy iByjSszLinm0WRBL4nEGOis+qt9xHgbuY7iDdWBKORNYYhiHQcqckHPt89ADEJi8ckLdTeILEZk2 IDziG9gdFqHeYk7XRaKIXvYUYpNCIUc0ohziWCRK5ZTKFaEIpdXcFyDQcrGAuZ5f6or+vqR728vh LQqZauBLq0QFr5oRznzzW6sql7lU3ivhv7k4EFlOI80WZ+AuxK65+78yB5PliRYfhM4vkB3Y9JU/ 72w9Awn4m1qjh1NWqBQKZVzJhUcndk6snxh/Zlf1OjqrY+K5iXWnh5+HQS7zyr0GBiGTqSqUnKf1 nvHvT/ySq4cdF5Cbhyefpj28jMTQmm0gjVz/GaKdfO9UsEzQnZ58T8xj5qMMyO2gNjT7mhPNPc0D zbuazzZfblZaaLOo0gpCzFmSn6n/a/3P9P+k/7NeNtA8hBCUgTPgs83XmuX6EEp38XV3SV6uW6Dj 5PXAC+Ci+krs/gcG+E8D3NDDt/VwNAhCoCvAdfpB4Z/m5wxUHwwEBH3QYhEAguhGzGRl5SqNVkV5 VbC8lA+7neXpeMztLi1/tRTUeFNVMJAU1OWgVgRBrwpCdxBmqECnwvGCpaWj5SrkpKrS8qBWo1KJ KrXQpCpPX1OBQeVTJVQDqpdV76rkBhXo8fht7gEVqFS16NwVay6awGgSTRyml03QYwKD6bDprIka qKlJVVecjDQvnA93LCbGGFe0afVCLBa+KfL2dDBY1pAOmq0NuLC/OYVvhenvxYDZKqSdVqvwbvpy +lqaGtJgo+mb6Iv3eJxud9wZZ7Sp8pY2xPV+v8BKp1ylmMLaE04jyV1FFEYyYESBeJxzz7qKuMzw GqudrFibiBO30zjrKgIhteAdR2ODASFf3TjrQ0T7+/C3YaNECqmUKTWqZ1TCKIcRSb/UHJfy0jiM 297qCsnRkWUDx+M1ySlw9kgRvD+O/SLnZg0Eu4rHww6FnAljIcdF5TzLmVtoqtaBHNnAyeVMWgv1 FPmwQk+RKWPJXB+lNK/gfz6zVqdzGeTPTIzXdbXel92zadrdS0Q7jVa7PNUeU6b7yMy+7qytsrfW Yin7+VOJOWfOe7Svir6B7JpG+t57L64B4yfd99WWRcyG0eNLV/9bRaw0wz0U8hjn/PPN6fX+vwVy aeLml5ke1DH5G1pG3yHloBAfWaWDLvMC8wozDQdAFrAFuKwcYvKMnOuTgyEOGhL3x6/EKUsG48Px kfjFuFxP/UFvoEEWWB7YHKBqf8AVYsdGvSg3nN8RLQO2/TaO2Py2pK3XNmw7YpMTm9E2aBuxHcDC OdtF23WbCt/fFtqtVDIsilQlBYNySMmVUmWFcgUkAzDgAIfDyB3DWapoeXnkOZnoOz35iaguCQi+ 54wyuxFxI2e8OrX3tWzDmVBFllfc/TgYce+LiNB/wX31Qn9tLW5s9r7+qZ3cwBhkP0Em2c92Dbct kq5r4eoFAferKEDT6KqJ4GZJApTtHHdJQx/8af/2nZXT58xZt61+yTRaYlD6lODsq1+1Y+mSWbmx h973apev++qhe9/92qJUR0WNbutDSmW7VR8oK103cWbHjg0Ni1DjTE3+ln4oO0vqyDSuQWz7LoUy /iDPne0G0g1+Fovd57qvdPO695tA0+Hp4AzKdqBudjupB6lMuOSBd7vB0L2/m1NTFyObYEhwT6VS GYFYWfwuZlSd3Z2cXuUGr7wcqqlXj3TqYdE1Pej1skQN7KrZX8PVvFDhdJnrY8MuGHGBzIEH9OqY y5ku5yscH8ngIwcIsgWyo7ILMv4jgI8qQAMe+ClQDZU53XHBwaL3sbbCU/HTClYLMFrhsFZUOKBC 5sg7KtIJB+xynHVwBsdhjAie4Vx3UBPFtroWxoccftHgB0OvH4jf7xf9vf4DfpmD+hme2K12wc/m VxFNFudmOKYVtawpqdELWq36pmi2twZDZQ3vtl5uvdZKDa3IbVpveu3JYykxJepNQipF0vXl0XpE plPuUqEe+cwrUSOzDXK1yGyICRmERPBFppIrspu/YDXIFczsRv1NIv+N9/VLTGgK+yR+g5IXmc2d vKbIKhgD6WeMBTmNI4sYeEu/m/VR/wYmphmzIYjQ7McYHeMvDLGlBBkNSPwMOwGHJIwlvlKPGt4U FgtoUxDEZ0ToIvuxMEQOMWktMOaj5yXeg6iO5bdciaYtXgXnjTyoUdP+VyI2T0lUtnbiF/NKK9yZ BfO/fL/QsL5O6YvNU1LlDzbet6xlVjTXFLA7Il2rv1thkZ21XJj4cPxnB5os1uQgdejmPFBVFX7m W/DaxETFcMt8UP5oyWCFCxIRt90MSpeqdPylGk9sz49+cLdQUdnx0SONpCiluc9RSpegnC5H33dY dKjlFXJOr46CKVkpVnKGykQl56QodT4RExqtsNQPK3x7fVzW8riFk/vt/oifyq12a8S6wsrrSu1B Zwme9fmA00MQ8ep1k0hMEKAmhiwqT6mAJYtUOqUz5lntq2qNYDI5GQ5WG5VwUQkG5WHlWSU1KLvU C9Rc6feJPWkX7cP2EfsBu9xM7XY9zx0rEUtYl2qVRigp8TzHi2jn/+aUw9XAUlHlDgthPW/XS9zq HZRZEpbcKbMkztUPqJj1b0BhhQdBuM3SXkug5++bYlyIEpK0mpI9DDeK0qa4zVyqFn3HqKcpEBuY 1gYtHNv0oFxuodw3NdyNFzObsnPnHn2ma+bgvf95PGHtzY++MZFb9cZyIVKx4e73zlxy6S42b1y4 AzyjW7t7p815/KGoZlBctPoggGXOaJdQlxyBHIoQOvmL8Z/Qa/Q8nlM0kZnwitixPATLg/C9ujN1 3DcbTzZy00ygFLXG/NH219q573Wd6eJOz3hrBnehHS6UQG72tdkcmW2czak2RWFrGyhDqNXwqCyc Kg0JudOTH4txlV4YCcFIEJa0w8pmKJWR5nyrDU9RwWBFBmhleo3VavoOWgp4mi6qPUc8QDy4v+hu PneqOilIqbNUSkWtzS54PBF1EmbQJDvnVhM17lmFxZ5Xi/YSQS0aDIJaXZnf+24EhiNAIsZIb4Sq aMTP5Vv3IvqxLTbbHQKpNFYeqKSqSlkQTDTI5mrS6QXSLOuwuQ6ZcEomQ+o0fgSiKRVlIJMZmpM1 HVh+tdyzuQEaMHfCwJSajTkUVsg+Ev2pq6ZsIpUwXpWkU5yRPQowhgFFpSablXQZSbghJ4ijVEOQ okpS5DxYszFViyoK4w/YwrhSNst4DKIMYhyrBcYyihczMzdsCCNvEOpvCT2UeOhjYPahgiGRhELo cLBZUYVhgIJF0lWmpKFFzwxKlIeSeIzCiqrmmSXmrU90bP7O4r9u35TljR5XqIo/8/VM4zML0hMf Xfr+6/nz4uJ7t22KzW3atHP5/Odav75jwZO9wbrmkoTD2dPG7Xj47pfW9Q5zGtkyjve7v/zbeDoc ad/etTr5yOlHh1pHHuZq79/8wVjHvXX/MN5mG9zYsmxDsr8+lK+pRn3GPfkh/SHKUpGGxMZD5SBY IVIJvW1gaEu0XWujhrbLbVybaLblVTwqE6CuqwC+AraKIIujKiuLg4wHHUXN871T8YRQPpVWTKVS ParxUj2mUv1UWfTbbIKs0mwR0Bhu6pSBmm/gj/NUTRvocYoIJGc2xhafX7hQBQn8FoCTJSnPUUjE KJUluMRZGZythLM8nKXAy5KKWHlFvFJWE0FQOR9Iivi1A9fLVCE9aTY2c83NgqBoStUG9CEtHzED 4akiGXPoo3pOob9bf79+q/6Xetkf9XBJCygWr4tXvL78Vi08q31dyz0bgqNa+IUWNmtBjXcIVFuS 0JWCLSn4DsBRAaYJcEwAexLsKfxUD9wCKJMIqtePBkLWQCD0fhLeB9iKtwArk6BAxkAhmRxNCdZU StCG9AEQkqnWQCjdmhLSJAB+QwByQwEYChwOvByghkBPYCiwP3A2cC0wGVAYaKA1UJcSQ+VCIgWG VCI1kBpK7U8dTp1NYWNKxMmnWlN1f/nKzmM2kdjAR22MMI1qPX5MkrQhBzTfFD32CJPt3oDAUrEM N+dg5NuRVyL0fARGIgciRyI0clOBIr8phwpBPsdORHPIkd8xpZAwmW1RlPa5FKtl5FOkRCQrE4p8 NDGY4GeCnnFqBL9lbhTFtST1/0LyM5pjxjuzOqYokVnbGxhZoqGCUXwDs1EY8d4ximS8S6b7BklX YBEDYaRckzQqlE2SDgHoMOgvUjp2yFQGdkmUj31vZCPGmaJLNkgqg0Mow7WyWRW3Fds7dYd6JGtk BMgFmNMS76jZwuqmFAj4e1fFc4ozEJrlKvXF+k1K+1xRreXmvhuwe+S+bGPM421e1PVQ0G0PP2TS PTsroPRUzlPyCiRRy8nxOP8fL4ZcZQ8/P7E2ZjIICerWdOyujrh9ez//fbpMVzq75ft9XSsvuJR6 rhk+/FnYbbNKSgP6aGdOPs25ZV9HX20NqYUfi/dkIuB0wJ/s0GWAuyvgmAXyDlBVQjee6taBrw5y dT11++tojVZP40QHBp/usu6ajup0cW+JjzoVpWAuLXXGnHEbX+2OkX8ViRzcFM00J7Ncv+9wNPw6 9mnsZoz+2vmp86aTqmKuGKdyupzca7ELMW5B/Eacs8dfi1+IfxznF9hu2LjXbBdsH9vovyNOxOET Gzht22yf2OgnTnDirbS58jbb39m4u21/tHEKW9T2ug09SDanczQWt8ZicVvcGUvF4ulrMTDEBmJD sV2xszGZhcZidaMrlanYcpKK1U3NV/URoWCklC8t8R3zil5GCSE0x71et06rP1Yj1oiI+jUiiqea mmr3zVD1s6aQ3VQ0myQH5C1tBDEO9Y6iZpLN5hCp0ZZG7fQ2ZjMf0n8zm9HsReQtojCmmLntaEKb fAopmbeJIaxkgmOGeZmKD6HDqn/jBqhDW4sJHJQyEJUsLyZ9ULowr5NDoeeK4qdeQHcUajIKC9zT ngxWtCRCiYmbavrY0xXlttg6b3yDWsN1HczZSoMuc2u9w+AdHpA50nMqosL85PjnDt2SnkbP0kMT a6fH5lO3VljmqQtV3Z/7BPiSoKH1z99nVnHL5BXZB6jTzKUfnyGtqLqVoDeiNChFZrNgD5rtWHS7 MYeRKNlZZcLsqVQqIwQriw7MoAuxwgZuG+xtB1Xr462cnZYyWIu9gdmxp8xSijZbsMHBnpk02xoW ivDvIozPht/h3QOTJXB4Psh8nT5O5uh0cCp5G8h6wdEWbZvWRu29kd6uXkrmQ3L+ufncu/Ph8vzJ +Rw+YZg/NH8/5nn1+154Hx+IRCNceRm83QtXDFBfAskIZEuhxNNus84pbbHPjFdW0/DZKvBXJau4 ZBWg/q5BkpGJul7dsI5e1oFOJ8uEG0K8vzbfXjLdK3N2cXNQOTCS2KoQ9DWsbOC6wgvCK8KvhfnO hvkNXFloXogTQl2h10LUEZoW4kZDEA6FRhsy1oaGTFf7gvYVqBnyh9phq3fU+6yXbhV/iBnujBd+ 6v21l/ub6fD30z+Y/rvpNNYN73eDMh/Lr8zTt/LgbW8fzU+35vPTp825ew53t/V+K7fVOmrllNa3 rO9bqUYlc8n+JKMOOsdqHZVxVpmMCzWEM97p7XmrbA43L9OQnpefnp7HydIkb8xfz9Mams9nuIzY 2ioYMlCGoeFyBgyZnsxQZlfm5czljNyH2cOZaxn+YgaMmeEMRzJihlNlCHeR41C9ZrSX0ejz2H3d vHzdPK7uf14uRpgFDeDnfnqqUVZVVh+Li6hfoAhDwjXEfXHOT+Oxm7Vii4RXwQaWiibEDdJibPG3 4FxbbvrFmVOtLBVD2Doy88DMIzPpzJtO5bPGaV3QYbvLVmvvshO73+g0Sq6SnHTVmlLs9AF9YUVy R1qfyo5fYPlbTMB4CUv9V5EzSAKHCZ1bDIEJPaRrpPgNaPQyRRUFkuRnYQyDMYpbvy/42Zicuy0B JdbBOAH+GJQkFrFduiTmcWvcogC8xUU2sIxkorNB8cYH0IWDrjnGgdik2A8vHA3rpSMUyVcoqcZY c1s2xuMOZDhmSdShhMN8qhZ5D2WSkfGgYkolVoSq8X/jRago66kkGSXGpOc4hXyNoaG03lGir5+p VdOrsyo12TEou7fGWrMfOhfVLJ1ZYqzvU2to1dd73SVBlbNswKp1b31+aUekut/Qs6CkZON3lov6 2VbTxfUg+15pnbeGtxteqrV0T/zh/P+qqtj4jz95r7Zj4qmJf28sd+d4l65sTSgeLEncPQIHs2aT +LXnf/drhU0LXjg1O547+fOJ92dokat1Tn7I2+lZ0kY78Xs/xJYSi6XhqA46GqGjCeaxe1MT959u QM+QiqK3CDmTuYEZT+IWxKtjQTjWAs8FYEsz7O+AwQ7wd4gd3GkOTtehpKygXLq5s5nLOrodXNbZ 7WQnBKH6EOWbrc1lzVT9mg/kTgb7qgfkDvxoNudw2m1ya6u6EczKxnwjZw03gqEFbAk3GFxgp40M tWtSgpRWJ6RUzKL95hLdAcHtyribGmnaGo1V0KC/HEi5sZzTlZcHlSoNntSoR9Qcnr+Bg6rRJ5Zu RQPtE7EPjfEtwb1B7lDwQvBS8OMgfygFLwZ/EOReTP0ghRFcCFwKcOkgpAMgDywIrAgcCrAquSWS XpDemz6U5tcGHg5wa9MPpzlXoDzAqQQcQmDU50UlQZ2G/5sG9OOPplPWdDr1egvIc5dyHJqy18U5 nkC+j1vJbePoUesNK6e2wu+s8O/stOoDip47UOmseNCFRm0OGRbl8MCJC6SDKSvNce2pdLqdo+lk CoZTQFLJFKdKScxGp9LnCXeEO8dRf5H91Lm8eXygrp2rSwXTAV4Zdos+fwMum7fB4XThIWCOMo5d HquIiiRqjHIqGsV9fh0dZ9Ewui9OQ79oOaI8p0RXo0/J6ahSHr5ZLWbYW/oZj8kcyBzJ0MxNLy+H j+Qgf9bYCtXIYry3GExtrfFq/wbGXYps5DYTMV6QbFNW+06RpUjcRDrdkpQMyeXBmErRSV9kIF9g HxJxM+pGNfkOjlG0eSWCn9IsEELiDUXX7y39A7ueYmTIPVK3lWNkE6gb34cMhPEbxjSKXETKFDkJ 44+MF+LcNvYj0yiqIoxjMMe+pEQrHC1F70uRXXyBW0j8AZ39TJ3eomtd7glvxrOd2NDacqPXFlBX Kqa//7FQWtrZ7wmMajS05Uje6Svxp7ojnjLx4PZON+/pdJl+wim7oj3Ubiid2aiL2qr2hF/jHvzN pnBJ58QfJp7PhQdRqald5Y/7Q8/8BFxi2lQ6+uqpDfpnNOhZi+L5Vyd61vSkFL/A9ZPDosYa9AcE G4vQdfUb0YKZLuUW5V4lVeFxkA2xkbL6Tl9AUAcx6g2CIQha526DAhKKnII7oACiQP+HIqhYxWOT 2rA7R/DD+CGCHnz8smIFWJ7ReJ/hNXZEOOalRz/9lJE060MmMYpueXY6U5PEtUUcYEtMGHe21JmL xgnHfA+ReqsdPQ2SKwuZLgc0+iXQ7Nr0jWcm/rxj7sPZI8EFubZli8or7mr42gFoOQOOs9Bw5skX vzvx3cKsPRsXLG/uevPTpfesz0zshxvouwKSnvwXaqRvkzB8SXzja35osHzNwnVbQG4B6xb/Xv8h PzWYQWdGguScDpfwNge7okCiyagYvRjlbcF0kNsbhIV+OBuEsxY4awZLqdcz4HrZxSVdkHSJLs6l USkpP6g+oD6ipofVL6s5tZo3m8q4EE/lJPZaCAQTyE0fm7gulh4ycaoIDwu5VRz3gQk+QC+F6U9Y xy/kMfoTz2loyNRlGuU5K89zJj7ERTg+LfGBZnSUHeBAwaEljrV1xRE0x5Sikin+RAnXlZBTglIp 93i9rtJv2OXP6qHMRux2o+STzOWQaI1XU7UJFNt45rxhinYleV/cJ7Y9jCIlTzZ+57PD89DC4tkZ E7Ub8ByFCd0plR+lMlJeP5PTCWy7UIv0hlAon1H5Z2Bsp1EOMyc2fu1wBzmxcxeblTJSko5fpmTs VnPXfc7Sx1CmLvy76lh3/8meqNnMGyx4tu7t2TS/Lra8VP9b+I9pVYuQPqZtqW2YeP1bH6aUmvpv yGPVT5z4+Y8cTLt3Tv6Se4P+hDTCmLilgqF+OYvqWSSwyNAMxuZkM3faClYjvGIE3mA1cK8Y4JgB nq05VsPJamw13Ks1IEvYEtyrCZAlbUnOlgwnX03SrmrIGqE+DYcMwCetSU5pcVrQdx13xyviqLPF 96LfmMnU5yuSQs7eYx+yX7NP2mV2O1mu26zbgybpXiEFH6dATPWmrqdoEg8rCimaSpWWHQ2gywQm S8FYCqR0sHSk9EoprymVy46KHDfMqA5C+Fer+DUxbzSZLbwyEorJqTIk2p3CUGhXaH+IGkK+UCJ0 NsSHmL8jFCrBb0LP0YsUr8ZG5TPZ2DOerN1zi1LRDZPoN76Drg+GDEU1C3fTkZ3ChlRCOnTFXd+w IZWQPmTZgGcYcHUjIhAyX8lZwjaZMU3UzNhuMwwBjDDPcAW3nrHgevxgJeWw3abvaDVlJ3DS/hu4 ULQuijjAvNmOUjws1dNQMOoMyZVB5aI1yUVNZa7GhYumd5XnHt7Tu2UOb5JplT4V7dp638aZqwd6 O6Lxnq8M55YPOb4xqFS+MMtff0/C3xQ2Gm1182ra1w3igVFDYlipbMzMWjezJW/UWxMzEpk1ixaX pRm+rJ28zO2X2UkcPhVrfFUDVVxvFRC0jy5W4alWSOexTC+brgnhJ9u8s0yrs1h5m9GEOr3BoAn4 pbOqoD8o+Jmb2u/nSJyGASpR9eIllxmUOeWOWBlzMjB9bEUYbE6w2aDbCSucqDF97OTk6EbgEOK6 2OL25z8pg/vLQFH2etlPyn5Zxi/SgEMDCg1yamdZ2ajGZtVobE5bmaZSY0snNUA0Rs0VzXUNr6Ma RDtU6QSWoltdIyBMHY5u8fk8fw6hT8+k14fQN6LS6RxyIBwaJPjSJcwbek40IHw8Hr0pt9mcDrnd QRI5lJ7MV32HX4wJ9CzK7qZUAj1oUiNzZTMmX+TrTCDfYh9Th+6SrEZHdFHfR9aRlfR8xBomvB1Z 6cBdesqZwCJ6t1itEZmPqLJYTDqdQauxKfRNSvx57qga1Z9DBebcwiKky+MpDYWCZU50kymb9Azy dtUog9OfW0gSeBWP9qVz4CmXQ71gUbDTMkxR+0fhjUiKaTA6ZRDUc2UaGv3RfF8JImXztxRUuabV ElhT64wqqqu8S8vVjvCrQxFLbnboNw5tcF9CqG18rgCdvNKE9NkHUOUxf7Xkt1SvXCIb/3SgOpD1 EDxXuTb+Y/pvKKs78e8IpsGEeNwUxG+WjCzqZs6ct42wtwX2qoFvBk8qnmpMUUO3r/taN7278Vgj h0fHC0zQbYKuugV1XI2x1sDrK9N6LXpmA37q7gkOBLlg0I1/XUAFi7ZJyPKZ1lhGOJ8FFd4CNBlV 2vzb6DlmqQFdUGgTNGWzo4LWKghaXawkxuncJW5OJ4uBzI2fm8TDCQL49wl7O2Ls2MzqFt2iwy24 RYsdI4NZcLsr2dmbHb/2AAOVWOBOdI4k8RCNI8gTe+2DeJomU1F7VmjS5rVCWiuirq8VTRbBp+3R ckNaYB+FUWyrK85b0yzNm+AhOjBvPiieaRWymWAgdAxPi0W0o/3+kkQQHfT7E4cTLydo4qal5Nlw q8dizxjDjMkVFRJUUu845sVTltSFBOI1oiBiOMO2OyUgsyGn0BEBEKExlvgc+s2wRcomrjLTFDEZ 25j9iZ/xTTl78eM+ZIFIEre6lZCdiUgj4jD75IudAiNTZCKS8UqJPVL8ZkQ6Zmmh9fWM+eFBTNEN i46wosHKtE9ESMZAecRVPAzGE9Oizwws2qU2bl4y0jPjvlllwY6N6/PeiqTeabI5utI6Db08rTSk 9pnshpq1a+cngx1z7bV7O+55+NtPtU27n7trcmJvu8KozXdHF733hz07Vu7cWHn/zOiDv35hbqq6 nHcafliX71g/8dcbYxXO1S/8beFJtde6bKL+04n/c/nb7QvzBtlXil+arJ7839BCPkSPbUS0ydG9 in/LJBI8FiGUHcXTj1QkcUszRKFSk6y/wyG4uqumOtEmxGsW1femKxv68H8aADlPX+Aysv14gFcu ovcbP/lSY60aqFIho6dhA8n984Va46W/S0Ei9Q6TZKmapCUqoKBhy6N4zzhNKDXuK7ete5W+oF87 skOMmDyf/ZwhU3LykmwafwXn1wPfEF/Y0ri38ULjpUb+QvZSlns7Cd9TwffU8NU0fDUAX/X/ys9t mX1h9qXZ9LXmC82XmukPMvCrDOwNwLd0P8bvv3RduhW613R8lxa6M29nuLKmuqZHm6i8yd60oGlF 05Ym2aoeON8DP+2Cn+ahe/oMGvTGZsyYOb3bFXUhUuvLg/n4dPzKLba3HPzlyXKxfLj8QPmRcrk/ nkSfUZE/O42WvF/STIejB6JHonJ/PpkX8zTPmLcVG+Pl5U9E89ZoeTSaL58ez+PR5CzRSPRJfUF/ Uc+r9MrWJ3x4KjlLTBuUYKXKhMXS8WN0Josqq5DwgsHr8172Um8Q/0ir5ceyaDQWm/XjoeCu4P4g DQo/1pDE+G/6r7J1TmB83nj+tv6IwgCkk+3EVeN76FBm6iV+sVj8jhHJgVGERA9TrP8CI4Ud55Xn i3oktuLhJcZ4FTUISV8sVoRxJ+UBP0FfdqCWoGZQRHn86EEuUYkZ7TK7ox43vEgc7JyyLBTkWQlp RQCJYlDXYBYFv02ppe9M/NvE5xMvwfeg7o/Q3jW8p6Ppbk5TtX7WyhW/OBZHtUG3WuO+pyoqbumZ +OTtb0386uiDn35z7Mb4pcb6YH2mKZGtX3nodaXD9T2YDRQi8PTEf/zzmpMHprfldFZu5qyxrd+H uD3i63JoFk/c01BTs/6dkX/91bGJ//Xac38cWwJfX7OotH33T7ONMyau4FkUw3P2FTS75Gi1kZ5Z 7a3TZ8Z7F69dvGnV+qGZGDY9OLy8qnvT4rWrlv4/0iKVJAplbmRzdHJlYW0KZW5kb2JqCjUyIDAg b2JqCjEzMjg0CmVuZG9iagoxNSAwIG9iago8PCAvVHlwZSAvRm9udCAvU3VidHlwZSAvVHJ1ZVR5 cGUgL0Jhc2VGb250IC9FUVBTVEErU3ltYm9sIC9Gb250RGVzY3JpcHRvcgo1MyAwIFIgL0VuY29k aW5nIC9NYWNSb21hbkVuY29kaW5nIC9GaXJzdENoYXIgMTY1IC9MYXN0Q2hhciAxNjUgL1dpZHRo cyBbCjQ2MCBdID4+CmVuZG9iago1MyAwIG9iago8PCAvVHlwZSAvRm9udERlc2NyaXB0b3IgL0Zv bnROYW1lIC9FUVBTVEErU3ltYm9sIC9GbGFncyAzMiAvRm9udEJCb3ggWy0xNjcgLTI5OSAxMDk0 IDgyN10KL0l0YWxpY0FuZ2xlIDAgL0FzY2VudCA3MDEgL0Rlc2NlbnQgLTI5OSAvQ2FwSGVpZ2h0 IDYyMyAvU3RlbVYgMTAzIC9YSGVpZ2h0CjQ2NyAvU3RlbUggMzggL0F2Z1dpZHRoIDU3MiAvTWF4 V2lkdGggMTA0MiAvRm9udEZpbGUyIDU0IDAgUiA+PgplbmRvYmoKNTQgMCBvYmoKPDwgL0xlbmd0 aCA1NSAwIFIgL0xlbmd0aDEgMzcwNCAvRmlsdGVyIC9GbGF0ZURlY29kZSA+PgpzdHJlYW0KeAG9 l2t4FNUZx//nzM5sIklYLoK6puwawzVpgIDITTaYRGwshgTpLtJwS0KwRCIBJKSUxZgCi3ijpSlN qVhKLdK4AsWVWpo8tILl4gUqvVAtVYq0FK1FyoMh2/f8d+UDT/utj7OZ33lv5z3vnDMzZ7J40ZIq pCEMC4G5tbPrwCN9jTQ3zV262JfQU2sA3ae6bl5tQu8WFh3zFjRUJ/T0HdI+WlM1uzKho1Pa22rE kNDVCGlvraldvCyhp4elTVmwcG7Sn75VdKd29rLk+Dgpuu/B2bVV0sqRERT46hbWL6aKjKHSDqxb VJWMV+JP8RjfuEQA4nJAiaKxHC4aNTwIoAfg/kBiFX8wMUff+XDUzO7jPlE9Uhi45ciasBFezTs7 vmv7ldaUdmezqA7zGYf0sVuvtMqY07q2f3oyZdVVj/GaQ8fgHlIQ12FlowuWcpEWVoisKSsShoiT XeQVspP8lLxMXiL/TV4kPyEvkP8iPyb/SX5EfkieJ/9BniP/LjVa+Bvls/gAlbBxlpqRLZyh/Ffy NPk++R75F/IU+S75DnmS/CP5B/L35O/IE+TbeBSZMtrbyJJx3qLtLZFdeJPyG0kay+uUj5KHyUM4 KL1+Q/k18iB5gHyVtf+a8q/I/WQH+UtyH/kL8hXy5+RevIx7pa69CS3+hoxvLBZieAkZ4omhD7Ww eF7CHrkfbHosYUBsxmLhZxgu3I1HYBXEsQvPIF/idmGGWHcxbidHeJG1RvGCjGgjStsLaMNS0YzN EpqR2pIZjMcSzYz0PEpE3s4+PyGfI3/MnNswRrw/oryV9h9y9Gdp2ZLMtwUTJGoL85kaLfyA/Taj QOTvy8pYaGXv73G0TZS/S7aY+xjfwe3CjbR8m/wWM2yg92nyKY75JL1P4LLEP86Y9fQ+Rq7jmkYY s5Zcg4ESuSb+kVzralq+STYn751m3CF+cx9ZaJKZNjPcxIgmrpuxWFgl83dSPKvoWYV2yRbGSjwm NuOxhGaGV+Ib8tqw6bGEZoaNxTyt5un8Otko7xET1ZjQOI6xWGigZRn5MLmUV71E1t/0r8ciFEnP +oTGnsZi4SHUcfUfoqcOC7n6xmaJx9S2EA+iv/Q1HktoajMWC19jnxpyHllFziVnkhXkV8kZ5P2Y LrXZuJ+akS2EKAfJr5DTyPvIqWQ5V6qMcil5LzmZ/DJ5D1lCTor/WSq9i/mLaSnkM34n5YlkARng 1UygfAc5nhxHjiXHkKNxp1R7O+VR5AgynxxODsMIiRlKOY/8IplL5mCSeIdQHkwOIgdigNyVttx1 Zr2MbElVRs4mb0V3kbPgFd4id7wFP+0+3CdyP8Z/gZZMyjeT3oLEfXATZ+FGjn0Do/qSfcjrk/TI fPWW3Slb6uhNWy/0lCfPRi+O2DPpMzaLsiX7manRIz+XVGiergxa0sk0sht5HZlKppBujJR4B0eF Ni3co0QzOTWfLbNjumRvM3fJLLn6WWINIx1PyvmMnFE52+V0Q6l7mter+iGfy4HPZZT/6yCZOI8j GIvVeq28d6ehAxXqHHaqDVincrFWvGPl3b4TB+QchVzMsrZJTCeOya5zTM/AIdGqMUzfKO1kTJWo Vq11JpagQ21Eh87QE9QObNataqWszHT0cw2QyAsIWrtRi3z9HCpcD+hmN1Cvn8US5ZG3UYWeqCen arS4LmKUXSx7xCuyotusWn3GXYFCdUmy1+BPOIWRehTmYL2eI5XuU8fUHnVCvafL8LrarzrVEXsS f+ZbsC/O2x3Yo73ybtsjuhcTLFfSP0n0fhgk9ZuzWm2wD6nNcv2lcvXnMQyb8JTYN9mTpIphVgty Lalcvkq+JL9BVotY8u0mkffjCZTZxzBdtWKJs0LmSnzWHrUT+VaL3aQOUG+R0Xqq004mRrv8eoBT ITvJWTuqx+sTeBhN+qJE7sa79nq9Teajp92qm9ScxJxgsl2GdfZ69JaZ8Us7Q1akn30BZWqvzoXH 2qa2fzY39mv6jE5zilFpn1Pn1SUnz8lWO+1LGmhSHc5IjFedTr7a54x2MmQ2m2Qe9zU2r4zLrjUU g4GA27FdllbI8XmiOvvuymhgStB3MOTPzblG9XncvihKo+kNvlg8Xhp0ee1Q1L45amWnRF3ZWaf+ l/NUbk5JadAXU+6iwmTaolmFYiwPygjyZ8wyXFFhrny05pTE4JQGX1Tq8VBMxZtjKMx82XzYzKwQ d0qOz1c0vzCqZomSmiOGwX6RrsvxFUsdxWXBrJAv4ovcXRnxFftqZldKYWzFURUJ5UmJ5cH5wqlB fzQQ8l4Vq0KhMZKnm8kjXSQ8EpIMDyQzSEtT3hUJSssp8UWt/qXBKcFouNAbDRSGvH6/ryjaXhqM thd6/aGQRKVfrVQqXjH/hmTNGVJz+mDxd09kkTkIeKMIRSImZ3kwyx8NRyLeiFxHUo+h/RqDwrWG QNIQg8khM1EUU+FSSSZNlt9rDFn+LL/UGTKT7DFzXySV+kO5riOottrk2Tf/VZj/VyD/jTlyQr7g PrNAdp2JYtGo7troqra3yvvYjb6BVBcclWJrF/IOnzw8DJ7jh48fHtqrh79Htr+Hv9qFznrL23m6 a6M749LHi5xBJrtCm3pTd7r86IZegRTrt6lpTgnSPMffN/3PDe014rb84X2u7+1k3dK/ra1x+fM/ Xd64Q19uaNvR2NgmZcqNbY6uHfIU/rfD+FfToWT/SlyRI3sEiqaUlk8tGFLeUDtn4QL8B48xI7IK ZW5kc3RyZWFtCmVuZG9iago1NSAwIG9iagoyMDU0CmVuZG9iagoxMiAwIG9iago8PCAvVHlwZSAv Rm9udCAvU3VidHlwZSAvVHJ1ZVR5cGUgL0Jhc2VGb250IC9BT0RQRFUrUGFsYXRpbm9MaW5vdHlw ZS1Sb21hbgovRm9udERlc2NyaXB0b3IgNTYgMCBSIC9Ub1VuaWNvZGUgNTcgMCBSIC9GaXJzdENo YXIgMzMgL0xhc3RDaGFyIDExMiAvV2lkdGhzClsgNzA5IDU0NiA4ODMgNjAxIDI5MSAyOTEgNDc5 IDYxMSAyNTAgNTUzIDU1NiA3NzggMzk1IDMyNiAyNTAgNjExIDU1NiA1ODIKODM0IDUwMCA0MjQg MzMzIDYwMyA1NjUgNjExIDMzMyA2ODMgMzM3IDU4MiAyNTAgNDQ0IDc4NiA1MDAgNTI1IDUwMCA1 MDAgNjEzCjMzMyA1MDAgNTAwIDMzMyA1MDAgMTAwMCA5NDYgODMyIDY2OCA1NTYgMzIwIDgzMSA1 NTYgNzI2IDUwMCA2MDQgMjUwIDEwMDAKNDQ0IDY2NyAyNzggMjM0IDUwMCA3MjIgNzc4IDY2NyA3 NjMgNjExIDc4NiA3NzQgNTAwIDI1MCA1MDAgNTAwIDUwMCA1MDAgMzMzCjUwMCA1MDAgNTYwIDUx NiA3NzggMjc4IF0gPj4KZW5kb2JqCjU3IDAgb2JqCjw8IC9MZW5ndGggNTggMCBSIC9GaWx0ZXIg L0ZsYXRlRGVjb2RlID4+CnN0cmVhbQp4AV2Vy27bMBBF9/oKLtNFYFoUpQQQBBQpAnjRB+r2A2SJ SgTUsiArC/99z504aZHFMXDFGXLu8OHNw+7LbhpXt/mxnLp9Wt0wTv2SzqeXpUvukJ7GKdvmrh+7 9arsW3ds52xD8v5yXtNxNw0nV9eZc5ufpJzX5eJuPvenQ/qkb9+XPi3j9ORufj/s7cv+ZZ7/pGOa VuezpnF9Gpjuazt/a4/JbSz1dtczPq6XW7L+Rfy6zMlRERnb15K6U5/Oc9ulpZ2eUlZ739SPj02W pv7D0DXhMHTP7ZLV+X1DcO6d9623+OvIh7jQWlyvuN7lfuv1s/0/I/rXWg7DtYh829TC+yI0LJUj wftykAxIQPaSBRK8r6ijziMSGL2XLJGA7CQrJCCj5B0SkIUktQpkLnlAAjPbVB0SqIry67xHAqMW nJCAtKkGJNCiRHCgrYJclREwJ1joIIk5gbRgzAUzWFUaxZxgVOsGzAkWUnMC5gSjpSTmgjmqZDCw S4J1TeImmKNCvQq4EYzKYMCNYKo7SdwILFjNuAnmqNS6TGCQq02hJYb3+ELiRngfLRg3bCWSJjCK G4FUVZRmEKzWFbgRrKsyChwJgtWNAnMCaTNjjuIVLAsFuycY1aYUeBXMbLl4pf/IQieHHwNpC+G1 ML/RcvGKNYJL5Ub8ChaS34hfQa62jAwDqV3AtIHU/mLLoCoVGfErqOrt5rwe/Lz8cBEibRAktkqk DSL3HGkkbRCMWkm0IVor+GWUNghum0naEK0VpU1FG6K1ojJJK6JtPcuRSxsEZk3ShmitYMKsLmmD wJ06w6k0kOobV8fAnU4Ch8VgVJvLPTOY2SRt4CbKghrFETaQWpfGG0gLxisnU8HaL+63gUGdBGwZ LGRF4pUrL/s6vTwVBrfGqsIcd42pKpsKc7wtSPYlq3lIDIokmKfw7WXSq6jX+/217V6WhYfWnnh7 g/W2jlN6/xeYT7MmMP4Ci0GICAplbmRzdHJlYW0KZW5kb2JqCjU4IDAgb2JqCjczNwplbmRvYmoK NTYgMCBvYmoKPDwgL1R5cGUgL0ZvbnREZXNjcmlwdG9yIC9Gb250TmFtZSAvQU9EUERVK1BhbGF0 aW5vTGlub3R5cGUtUm9tYW4gL0ZsYWdzIDQKL0ZvbnRCQm94IFstMTcwIC0yOTIgMTQxOSAxMDQ5 XSAvSXRhbGljQW5nbGUgMCAvQXNjZW50IDEwNTAgL0Rlc2NlbnQgLTI5OQovQ2FwSGVpZ2h0IDcx NiAvU3RlbVYgOTQgL1hIZWlnaHQgNTE5IC9TdGVtSCA0MiAvQXZnV2lkdGggNDQ1IC9NYXhXaWR0 aCAxMzk3Ci9Gb250RmlsZTIgNTkgMCBSID4+CmVuZG9iago1OSAwIG9iago8PCAvTGVuZ3RoIDYw IDAgUiAvTGVuZ3RoMSA2MjM2NCAvRmlsdGVyIC9GbGF0ZURlY29kZSA+PgpzdHJlYW0KeAGUfAl4 lNW5/3nPN3smmX1LMpktk22yTCbrTELyhZCQEJZAANkiAQFBBMKirQsSVERRK1il1ltrWIxbvYyJ Itha6C3azRauRW+1C9Baim2paaterSX5/843E8Qu93n+kznnPfs53/ne7bznnWzZdMNKlsEGmMSi 16xb1s+Uj68e4Mg1N27xp/LWnzGm+tOq/mvXpfKu7zOmKbr2+ptWpfL+Rxh7443VK5etSOXZ3wFr V6MgladqwPzV67Z8MZX3jjJGHddvuCZd70OeDa1b9sX0/OwXyPvXL1u3MtX+r9cDRvs3rUzX0wLG LFs/n9eZRdvGVAc2jg8jZOawF5iZDTE944AVbB5j+lmWrXheUurVjG39cAVbamr8UJejU3o/F5uB 52Ps+/rnvzl28NKzGYt14jnFCKkPxtWtuvQfjGWUjR0cO5ixWBkpXamAObJ17pmzTlfu6TcR3XKr M+eWWz1H+LLhDV7fEd43fL0AHcMbggBTh68HIPXw+gCASp63NuD77zfQ7cYvIFrXj+j6DYh815Np A61d78yZtZ4OrT+2nlesH1x/cr3UvHbD2m1rpffXjq/lvrUVa5vXLkWJunntA2uPrT2zVrV2/bZN 2Ufo18OrxTznhlcCjB8fOT9zZhxQzvotEl85/+R5/pXfPvlbfoRPURry1uFVfixvsrx5TdB3fkfE 91uET3cEfB+sKvRtucHuyL32OkQVa5rXcP+q6Cq+ag2yK1fbcw6tPrOaV6xuXs0fWP346mOrpebV 768eXy3JK+vq4mzlrJVLVz6+cnCl+tBKMq2kfiT5ytU7NmZ7NjtvbvUEbkI4wm8YkWp9FS2FfAvb gMBZBeLmdGozm8U3o0zExHyImxGWIkhotwk9Nik9NqF8E3sfYRxBxfNGDtX6NrRU8X72AMIhhJMI KmZCTEzm61k3Qh9CP4KKMcRmBD9CVCkx8XWYdh07jiCx3YiTCO8rOR/iZoSlIsevH5ECPlOLia/F ZGuxHh/iZoQNCO8jqDBh93BxSfwIXzKsKvAdHT/OS4cLiuOphCsnndBb4y0G2khXswjzUSVF2VXM N36c6oc7p4kmVDPc0akkosMdHelEa2s60dgYP0odNHX4Kt/7LW5qwHMupansJMIogsRkDEjMjHgA IYlwHGEUQT0+OvLkkiVAk1+NPLlosUCXkSdv25GCtQnACyND0Rjg6ZGhnh6lfKj/BgFfGOqeE2dY 9qsYe5AuYtyLGPcik+j08NZaIOJPh/fkAvz38LZy31FK0nPDeT75CD07fNViZeXPjuARlAJ5crog kYhvwCM8y7YhnEQ4g6DC4zyLSWYhPoVwFmEUQYVpn2GEJSe3KEuSyw4h0Z8cSO5OSv2HBg7tPiQt TW5Ibks+kFSdTY4m+dlDo4d48pDbd2iHG0t7fPjbLQCPpcCjw68IAv3qS6+0+175drtPfpluZd10 q2zm3cco+m3523zg2KljZ49J36KH6SHWgnf10MjJQt/jLVn0JXYI4RiCxDYg3obwgMiBAEMv4rnk FwdePHNY8r/YfJj3Hz52+Ozh8cMq/+Ho4b7Dgy+qZGzkvawfYRDhFAJwh+4dbmhQdube4cmT40fo ATnjVJ3v1Mk6349fr1No/PXmZuWlvG62CCjbX7e54+bX5dd5FNHJ18dfV1n7W8xUh1dfx3YjSMyP OIogI3Qj9FHdi+rHHz30KD9Cm0bMNqB0iM8FMs8FSr+PeFxJHUJ8DOEkwhkEFZ9LI6wdm7AeiDsD cDlgI+AGSrBqwP5hbTXe/Fq6ejhbvPmrxeO0tFMvdbNs1E+mGlYKWEuygvhNVMUmIT8f0As4F1DU twHaAaekYSdgLfJdgHmAM6haWUcD5gXhUIIqFBgDhot8mqAwTjVrRn5KGlZR9chCn7X/W7yMDSDs 5mUvSKOP0O6WDDqBF3ECOH0COH0CL+QEU9OJkW25PtZi4wmwjARYRgJdEnhTjMdREkdJHCVxbE2C x+XMPF9yz/E9p/ZIX3nYB8QyHz4Q8H19D3gueeXSPVbfpYcrfLMayd94ppEnG0818kaT1ffQl5nv wS8HfHsAv/ww8+19OE/wDRofntSs4ML4cM9c4ML48A4QGV+j0BpfPXxvFXLXpsCqEeSw4e8Nr1ih 9HlvGEQuRnlveMGCVGJk1ixBfO8Nz5iRrpkyJV0DXBM1I8At1uKg97AV72EL3gPuzELch/A+wigC nh3xNoTd9J5skNjddPbu0bv52ZYw7UeL/UChQ4iPIZxEOIMg+uwH9u0Hvu8HXu5H3/1MjXH3Y6ZU j33osQ899oHNLh25ownbbqU/gQn0KfEpJY4i3o0wiJBEUPHYMOhaPOfrad7y+kjqYV4fAQmeaSml 1zFGM+JtCFyJx5XUcdqJmscRH0LgoOG7UHsXaPguPPbjiA8hcCzrLixLpC6X0a/oN3JGrc/8KiVf pd0nSBCi/oTcEj+xw+uLvsznQwzMlzN59Hfy77p/1/e7/t+pl4Leb8ckt2OS25UJbscEt7/Ilx7c cBB0+MQw5DAehMvDuSHxWnjzCBLHXuHNWCajYUY8OLw1inceSAH/CHKDr9Cn2IpPsTyZPhq54Ubx Ij8a7gbC8JzhHQVobkoBVwqohu+YjkKHyH2LW7mFFYDwjalKQwroUsAyfAdQDKNtm+w7ymXePJzv 62vxYUH9CAMIQjQ3QwA2Y3oTYlEHpYyOYklHQUdHgURH8fqjiGUETkeHdwgRMTp8RwfAH1LgncPb qnxP7/AIBieblgALTy2hn22L+e67RzDt0PA9pQAlw/fkAERSIHj4nphvF8IRKhq51wp0iZAVE1mx v1Ys7BDiUQSOJbiUHXRhYS7wQhdaubAcFzDwOOJRBA40cwE7XcBOF9DLhUWLmMg2DBoWCGYSCCbE nwk81AQ0MWFkE9rJ5J6gOvcE1blHIDtZS4DcmMyN3XBjKjc6uDHpbsSDCFA+EZsRZiF0I/QhqIEk qdbilZpGQNDdLRbMNIrAsX4TpKMJjUwYNlWqxvLY8A0QiQAHapXl7hV5se69w2m9Ye/IokUCO/aO zFAYwd6RaV2pvCzHt7V4aS+2qRnxGYRRBImZEM9C6EboQxCEvBdT71W29TcQzL9hHOJ4v5gb8EAa 7k9rDgfScD+WIN7tNQeQOHOA+vb3Hejf339gYP/AAc3ggeSB4wdOHVCx/YP7k/uP7z+1Xx39q/xX 7t8X3Sfvk/yD0UF5UDLvS+47vk/q3zewb/e+wX0q82By8Pig1D84MLh7cHBQ9bcdZb537xBqyPlh JI/w6PCObIBOOQPwPYSPtonaUnnXPUHf/eCl9yLcg3D99lu337/90e3Pbv/mds32bXW+rQjytu7u uLwVuChva22Lb9i2bRs/ue3Mtve3Sf+x89mdfO3OW3beu/PoTtW2HVHfToxy5x11vjt2NPnkHatX x+UdCxYjEhx3x+TW+KEdx3ac3HFmx/s71KYdvh186Y7xHfzxHWQ+wtuHawKmb/E2VsMCIPr24ZYW hfrbBTOWj/A2uWD69LgFCnROncNd63DUOKzVDlOVwxhz6CsdmqhDqnCwcof/Zb4QLGLhsAUkw7uG LXaAaSMWk293S5DPhEo7U2APYhmhG6EfQajJ00HE01H3PuJxJSXyzQgbEA4hqLCwacNut7KwacNO p5LomijpkvUoki0eT5y9wpsgGJsEVvCmkcKIeISGEZNFwEkjeXkKHBa6C28ZVhdhjZOG1VaAxmG1 WHjDCADaNo5gOgHl+8rL47La6YsXFJqKCk0lEVNpxBQMZeWHTHm+LL/PZDJbjMbMLKPekGHUaHVG 7IJRIxX6/Iw2AKMlm++Ujc6oSFKpjackapYel05K45Jqt4lMJmo2LTW9b5JMHp+nwtPsmeVZ6tG8 7xn38BzyZrq12ZlaVcznMLsyrSp7pvMILRmO+cxHaDGA7QgtAlAdoYWyPebLaYj5TImYT4rHfKw+ 5uuuep6zycMuC93tTwZn7wp9MSnP+eLzBv/dR8xs3hef5zQ5KeUGApS0drGuuZOTNgLsmZysinQd kfxzkrFIV1LfvXjB80RfWojSJL8bBD43qbr7CAewti5avOAIeUT1jpzn1YTKZFffjvvvXxjxJld0 9SxIDngXJmMisdu7kEWu/Gy5YbP4RrZsiSC+4vN8UUFbsqRtWbK0rW/KFeWRSKrZ5s1bNm9G+ec6 iXaEAW+Y6LBly5ZU+spm6IlydE/XRZCaSEbEMtJZ9BQpsbz0J53AijdfniJVJZaitENrPEtEdBIT iLmUpspsYmKl8B96R9KbMrEi0Tdyw5YbWhcIeVU9srQPOEjVw52zBMajIMerFIw0TIpXHIVSScqA CyfW+U8Qs4vlpMabPtK/UXSfPtLekYJdCgOeLoSFKB+OJ5R5po/ghGcCR54O3XU6JMh08GIREzhy qqwCsBlByNbpWCsIFeF9hHEEdXonsZ6FV+xiai+wS2Iv0mvFxojXplSli67ogV373DOlHmczPhhD 2dEIRSJJd7IeiJt6bWJwDPgZLkwkxZrERivoc8Woz+sFolfOmdyVbJzTlTR1L05mh5D5PjK1yBhD kyMwwah/IOww6q0sny1XX4PjApMeYz7ELzA34meYn93E2Pgvxp9DfFa0Hf8lY5e+zzQi/f//Uf9Q vVV6gtdLN0z0FbaklD1pouTfwCL2JPs2gvi0wl7V+g/tXmBTmGF8+vi3xj9if2NRpDXjp8Y/4nP5 8JUtVYelB1nT+H+xn7JnMd5idpytAkxi5AgbZN3sG+xF9p/s6+wJ9Cpjw7CErWU9bBrmu5ktYwM4 Ig2ybWw1ZtvOFrHv4e8p/MloLbM4fcQevmK299n77LfsMLexuezb45OvqGFsCzSjp9hZto89ytZA fVnFHMzMvsjuxuhreC+/nsXYNaxX6bM+1ZN/h51hT0lJNp1OShvTM2nZLsV6d46dY+ux8gdweJyK +Zayr+AYeAtbx57H3xxWhWe5i32J3scTPoZnaGf3sj48ZxdK69lfxrPwNG04qs+l5diJpewG1kk/ R59f0S/Yj8jC7mAb6S/0A3qRHWZhtoN9h/6MUe/EUfAYG2ILMO989gV2mn2JfRWjfwMjzOJevoC3 8Ub03YIx57HlrATHi1weVS1TbcZ+RtE7yjpwzN2Lv03sHfYG8O16too49iTEvjB+DwuO/4p2o245 nmQRK2fZ4+eZe/zC+C3Yqzh6rlZGn4y6dtbGlmOv57MHMcYGdhsvUfezB6Vf4vl3jTnwlrZiVdOx K3PYGN74buz1bVjZ1/h+fhC7vQdSOcYfZIXIcbTrYddh16awBmjz3Ww+HcMJ9SibyV5Dz0XoF8AM KjaHr8Ya1mJPd+AJW9k6/ia7wDaze1gCI6xiC9U/ZpsoQHupB3jZApvtbThOlylv/VHs8TX0X6TD u9sGQ2uUjuP5Z7B5PI+XsBWsC6aBx7CGO4FFL+KdvoD9qmMv0hj7/biT/QdrHlexb463sfvwBsvZ flrPJtOL0ib2feD1E/QcVn6Y/4R2wjCwno7gvXWyAHDuu3hfX6EcPNNRPO2X+afYxUNY6WyMfoCt xNPdB9yaz25kI8CfI8CRu0ANX8OePo38nexqtFhFh0jC034fGPk7fjvW3EhfAd5NoUmYdRrbiSed jP4HMDJaAyOuZ7OwQy0o+4lmisam2T5+Lz1Od6v/PP40mztulgal/2LLx7/OHlbdq3pQo1X/QHVs /I/AjU7g89eBDV3A7na2TXW96ivj/eovw9bcjfVcO/5VNn/8GRyDIljpIaznR2yp6kP1G6r68e+S Tnp//G4NV0U0kvrL4+BrcnTutM6Oqe0NiXhtVawyWlFeVhopKS4sCAf8vjxvbk62x+102G1Wiykr 05ihk3gpJd2tC2YmpbD5L4Eks87I8bclVWF8Q9OWrUgWzVkQCJnfyLlcv3BhWWkyu3VBIJCT5GF8 O1GF77Rl/hVJczfKUaGUdCZZ9wIRjoz/uh6F5vrAwpwkm7MgmYfskfFR5PEpS62gbcV1obYVa5Ke 1hV9fcn20JSQ2Z9sH63AknICAf8u/645CyxVSIoeDA36n6f2JlISvL0tAbVJl4mlWaHxhNtEuC4p 39uHRGgK1oQa22c1OFbcd2UVQ7dUI4ZmSsq/JikvS7J7/c+XHt91H5Sv5X0R44rQimVLFiSlZVjD 80wKt62em8zt6l6EIsyJ0LfaL3ZuihKJffC3rfbvQl607UMcmiL273PlK1av7BM7Tn2hKajTty7Y GTieA01twc62pCWSnIruU29+N0fa1eZe4xfZXbt2+pODsxdcWRsQbbCd7rJS/662EGbDYG3XTU5v r5hAFe5cIfZ4mT85sPw67Ay+y+7Djiv7HdhlTrZ/FMAOY48neqW3ckXfdeIJrkNPFYB/170rkQhN uU95Irxxf9t1U0QQHYE/bB6QatGCttWhNmzjvakJsQ9ISOF/7BsIJD0R0XHXrjaxvmUrsOjUelEh sDOdAVblRAiLbk3KcxXA5ipbjxnlZVMWpovSDVCjwvYn5b4pCxeKh8IMXXMWtKK6LbRsisCkK0v6 0iVo0jZRKVYb6sQISf81foG5IXSuF9HKerbrmnplrwILqay0q/tyr/ZQe9+uXe0hf/uuvl3LjowP LA/5zaFdz3d17epv68MwIApC+cv35iTb71uYNPetpgRemsCfdhAHD7f7Vy9DBt/mUACTWLDQVDW6 /uvqXeY/Ys+MIMscf7tYqSAvQXKCWjDnvAXA4GswYtsKJQJmQ8HnOQLHpYXhtjU96fXnBDCDQj6C +GenSzFIICCw/94jMluOTHJg9oJU3s+W5wwzuSKC7e8TNccnahzzRM3ARM3l7n0hvApxvvj3KAny v4yOuywhqz9eoSwh9RqTttYFUg5HiUjxHAmprp5Q1+xFC8Qr+Sznb9t1+bWm6pO8NdXmc+1E6eW2 n6u5XIoZ5n7W5p/mmzsxM3YP384VyeNz8Q7+UJ90pJckjnXPh+ju2c/LdHfPogVHcU/pv3vugmFO vLVv8sLn81G34KgfPFwp5ZdLRRu/yEFcAjuHuU6pyjkqMzagtFUpBUr+GpznlLJUI5QRuwYnP6XM rLQTPFfVyZo1cRZS/Yblqr/BpmoqWR7SndBayjU5TNY8xaqgV1bxZ8YvqE+yKtSFtXtYgWaIVWqm sajqTVYloHoBK1FVMVn1O1aI8fLU32MOaLsu9XymQciH7WeOat3476X7WTfGmCuhH3+GVWKeqaqn mIHPZRE6M34c+SDSpVozK0C5UXU1m6I6yYpVt7BZUjGrlVawafxrrFz1U2ZW7WB5mm8wryqA8Tcj jztlhCaErQhBhDCCEcGP0I5wNYKMUI0QxzqXwIp2N2fjf0lBZc1nsMZFPM7ux/puQpiGdJkI6LNZ 9FN/AVd/u6EjPaOUQYVSPlBrFGjEmeEZpAKQ2xIrgk5VzILQJPNw6pjNcqB/EWR4GZOZEaeRQuiF 2eLaAnpNBcx3s6Bh6NG3heUyE8w6NugscWaHxtEAjagDFxkulomDhBUnlpksC3NlQM8zQweZAq3Q DY0kBD3KCQ3Hw7RYmoWpWBP0lwQ0p0asyAD9Yjq000po4e3KemfzR1Q71C9r/ld3rf7Lhg+Ns4wf Zz5q7reU2srtjzmLXR2eqpx1uR953/RZ/fcFD4VO5Y8WbS5ZVFpWnh+1V26vzqydVldZn98wveGv TSvkxyaHp2xuXzL1ic6/deVM/9LMA7MTPXzu6flN839ylbwgvLB24eii7yy+a0lh741Xz1i6etnU Zbcu+9nyxPLXr1m5YsGKb60YWzlz5ZFV2lV1q65Z/fLqj9bMX4MP1gnjImtVZajq8CSMCmtrqkNB jcPurIohWXBlurDOaXXYWSjIaqqh+0DL0YSCBRNp+k12c1dd8/Kuq2/62oabn/vVwefOvXSg8KVf jZ1947/H/vc3jz3405HbNu28fkHLDPp5xFk2Y+7k1msHem/4+gu3PfmL8ZeH3g53Fo198tLbYz8i 1Q8fv3DskTuG79sw79aZiT7sc2j8hEYPKoniDVSzGukXclGV225PaKooI7OKeiZV0cUquqXq0yqe UfWjKm4zVlFeVZErp8N8ZPzdkXBhwpSGWWmYmYZGQFmPBpVmtzuB3McjGBe1oyMORyJDQKstYUhD /ZHxP4q8Lg216XJNGqrTUPSTGzyeRIY7NxeR05mwiPWaU5HXmzC5rdZElohMbrsXKUSZIjKKCP0v jABiXgViXgViXgViXgViXgVi3gvyx+igKaRWQ4xuju2KcU2MDMUx0sXqYwtikvnJStJWkltTSa2r Ks9X8hsqSV/pqeSGojDdnU+rQ2QI/T7EjfpgcZBbMwLUimDL8FPrj/z0lIl2ZlEki/SZdFPmPZlH M6UvZJI2kwwlJirJopJMeslIJUaKG6nWSB8ZSWPcaxwyHja+ZVRnlBgXGa8z3mx81PiM8WWjdl7G yoyHM57IeDFDrTPQ9w0/M/Av6EmjI4te59HxPL2WWhdq12j5Ig2Z6/rq+uukmorqjFCsKphfWRWu csjYQIcd++lwu9wJh3h4q9hJxywHf9xBfQ5yOEzi9mckJyeh3AJ5XK5EkvDR5vjRL8eNl53jRiG0 5AuyE52fzaFtOY/nnMmRWI45h+fkBEvF5qKJgHIDevWXUqmsN9SWloa14aCpSp0hxUKV/nBBonKJ P5/y8zMqbF6v5MzOLiuRhsrYuQq3tcJqzICLhVxYU1NVXb0rSCuCDwW5M0jBusXhtWEerh2oOlXF B0VUVVVXa7HGPRW9G63xXnx7e6vcFZaqCtbc2Nxs/qjxUqM5/YdmFb0XI1Uxi9UVT1ZA1sv2DK32 9nCVPRyuMppM24NV9mCwamdWeUS91XwC0K0kFpIFY0Z6IxGMiwmEwUek0vmNIm/WNjbiy8w/Mf+k Mkq9Gzde3Sv+ens39gJs3LRxI8pQCNC7SRRN/G3qRWmqAIlNSAOIIf/vD4uIATCaABFXYU1dE6+r o9q6KnLlSS6XQ1sQ0mhRXAuWVCgFJMGfUsVBCkg2qVSv7ywJxNaQecb0Fno27mnxhGWd7rp5Q0M6 XX991i2XXlnnrV2n121ftp4W0N8+jbp0umodZRZe/y5f/eKLf7ffFb/LnUko06tViLkpx5lPleOs ze9xi2IdL+aLqeuTDyF5csc/Vt2q3glu1MS6JJJva7XTovpH67nKRSr3CTcvycig5mcz6C4DFVip 3XqX9bxVcra2t55vlZxT6N0aUtXk11TXSMbamtdquKZ6qPpw9WvVqnp3tre23m2211rlYChhLQEH sbnd2QmrwHNrUXZuYmE7PdpOhvbs9pL2R9ufaVdntgr0fNqYVZtRR958O+GrMVGeYSr1ZE99dCr3 mKmtdWXrDa1SuJXaPKR2r3RztdvhDrs/dKvusX3Vxu/J+GoGv9FFTtd81yrXjS5VtW2K7QXbCdtp m3q2dZmVf8f639ZzVukF6wdWbrCWWHmmwUI9L1t+aHnHIr1qojezfpvFVUaaYpxrXGGUauvpHgPd U0+qDHvGCxknMlSGuJkOG14zcHC0U3JWuKijfwZ1zyDTDLLliysoz4YbOvID53zNLdM6KqsaE2xI Oqc2m6s6EoKVOkFjxgQligpjHYkl+nPqFjNKWo6M/0w2ooi3UMuSnHO+KrEV5YXlQi7IVUtYB63o 6yDWMdrBWYe/I9rR16EydHT41JLP2tjcZf5dLdUeGT87ku1NAI6OuD0CQgK4APka2WvKxFVeJk31 Z0YzuZxJmW1t89r41DZytlFbuieg0hPwY7kQXdu2MkfSccohmR1RR59jwKFycL/VkTjDKQpV9K/B osou0RdCR0DZXRFNdJkxdxdef6Jrm6noUBFfWkRF4AOXBOE0ml9/d+OmyOnejReR27Rx02lBWleD /iOR3pilqoo1N4MfCMpEISjI/MFFUB1i0Dk4xaQKt/mji5aq1J/5ox9HQNWCNiOC4jZt2sg2bgId iyEVEgdtg75TJJ4mYTG2WAo+CgtAE6xD6bGx1wbKhLpQJ3QCoRRo8ySHPUsKBQuhPqTI1lpjKawu lwoprVaICo3DJnJCywgEtZZ8ne7Z3tBfZoZ2fr1v8IXr71vVULT2kcdvdH9xR8aUa3S6hDWDVFqz N0Q5seaT+5t2bOqdquczZj+wf8aBsT+XNavbtDEtyLT2nqs2fLvYUDDrtp6Wu+68ukQt6XQBQ7ad
April 12, 2016 - April 30, 2016
Kolb-Archive.digest.vol-nu
