Kolb-Archive.digest.vol-oh
October 23, 2016 - December 19, 2016
      > http://forums.matronics.com//files/img008_162.jpg
      "Masculine republics give way to feminine democracies, and feminine democracies
      give way to tyranny."
      Aristotle
      "Daddy, tell me...why are you going to the pig farm for a reeducation and what
      does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin
      and Mao Zedong"? Mark Twain's GGgranddaughter...
Subject: Re: NEED HELP... Setting wing incidence on a Mk3 Xtra
Date: Oct 23, 2016
here are a few pics of what I'm dealing with... The wing is set at 3.4 degrees and is in contact with the flap tang/flange... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461535#461535 Attachments: http://forums.matronics.com//files/14716218_899158316881130_8794337127641064577_n_259.jpg ________________________________________________________________________________
Date: Oct 23, 2016
here you can see the contact between the flap flange and the wing root when set at the 3.4 degrees... if I move the wing out then I dont have enough room to pin the wing root to the fuselage... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461536#461536 Attachments: http://forums.matronics.com//files/14724609_899158313547797_8819378937121285255_n_516.jpg http://forums.matronics.com//files/14721753_899158320214463_5055405320923361270_n_102.jpg ________________________________________________________________________________
Date: Oct 23, 2016
there is an easy fix for this... If I'm doing this correctly... it looks like the flap rod that goes out to each side could be cut down a little and replaced... but I need to know what I'm doing is right before I go cutting stuff... I did do a search on incidence and it seems the older kolbs with the short landing gear used a different angle of incidence... ok I have the old version, but I have the newer longer curved landing gear... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461538#461538 ________________________________________________________________________________
Date: Oct 23, 2016
New Fuselage and old wings? The root ribs look different...? Herb On 10/23/2016 09:15 AM, dirtracin wrote: > > here are a few pics of what I'm dealing with... The wing is set at 3.4 degrees and is in contact with the flap tang/flange... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461535#461535 > > > Attachments: > > http://forums.matronics.com//files/14716218_899158316881130_8794337127641064577_n_259.jpg > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 23, 2016
Isn't that root rib mounting tab in the wrong location? Been a while and the one I rebuilt was a MkIII C.. Herb On 10/23/2016 09:20 AM, dirtracin wrote: > > here you can see the contact between the flap flange and the wing root when set at the 3.4 degrees... if I move the wing out then I dont have enough room to pin the wing root to the fuselage... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461536#461536 > > > Attachments: > > http://forums.matronics.com//files/14724609_899158313547797_8819378937121285255_n_516.jpg > http://forums.matronics.com//files/14721753_899158320214463_5055405320923361270_n_102.jpg > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 23, 2016
It was bought as an unfinished kit... some of the parts were assembled when i bought it... at some point i think some of the parts where stored outdoors... the fuselage was pretty rusty before i had it powder coated so it looks newer than the wings... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461541#461541 ________________________________________________________________________________
Date: Oct 23, 2016
Looks as if all of the regular kolbers are off doing something else...? Naturally, Bryan at the factory would be glad to help.. I am wondering about the root rib more than anything at the moment...perhaps some pictures with a larger view might help...? Herb On 10/23/2016 10:02 AM, dirtracin wrote: > > It was bought as an unfinished kit... some of the parts were assembled when i bought it... at some point i think some of the parts where stored outdoors... the fuselage was pretty rusty before i had it powder coated so it looks newer than the wings... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461541#461541 > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 23, 2016
lowering the wings has now created a new problem... the gap seal I have cannot work with the wings that low... the leading edge of the wing now sits lower than the upper windshield mount/bar... yet the gap seal I have the leading edge would have to be above the windshield mount/bar... I think I will just call Bryan tomorrow... thanks for responding... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461546#461546 ________________________________________________________________________________
Date: Oct 23, 2016
From: william sullivan <williamtsullivan(at)att.net>
The book says 1.4 degrees, and you say you set it at 3.4 degrees and it won't fit. Why the difference? -------------------------------------------- On Sun, 10/23/16, dirtracin wrote: Subject: Kolb-List: Re: NEED HELP... Setting wing incidence on a Mk3 Xtra To: kolb-list(at)matronics.com Date: Sunday, October 23, 2016, 8:40 AM "dirtracin" I got that info straight from my manual... I do have the 11th Mk3 Xtra.. So there maybe some differences from the newer models... I did set the wings at 3.4 last night which put me inline with the tab on the wing root but now the wing root is in contact with the flap tangs that stick out through the fuselage... And when I moved the wing outward to clear the flap tangs now the wing root tab that mounts to the fuselage is to far out to be pinned to the fuselage... Something is not right!.. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461530#461530 Attachments: http://forums.matronics.com//files/img008_162.jpg Forum - - MATRONICS WEB FORUMS - MATRONICS LIST WIKI - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Oct 23, 2016
If it's an old 3X are the leading edges of the horizontal stabilizer set in the middle of the boom tube or near the top edge? The Mark 3C would have them set near the top edge and the early X's also used this setting. If you mix the "C" setting of the HS with the lower wing incidence of the "X" your airplane will not fly correctly. Rick On Sun, Oct 23, 2016 at 10:58 AM, dirtracin wrote: > > lowering the wings has now created a new problem... the gap seal I have > cannot work with the wings that low... the leading edge of the wing now > sits lower than the upper windshield mount/bar... yet the gap seal I have > the leading edge would have to be above the windshield mount/bar... I thi nk > I will just call Bryan tomorrow... thanks for responding... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461546#461546 > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Oct 23, 2016
Just realized I forgot about the gap cover. Yep, the "C" cover will not work with the "X" (latest) wing incidence setting. Attached are pictures of the one I made for the PfH. Rick PS Found the incidence numbers I used, although setting the motor mount at zero is a PITA, you end up the nose on the ground and the tail in the rafters. :-} 1) with motor mount set at level in BOTH directions, i.e.--0 degrees 2) boom tube should be -6.1 deg (mine was!!) 3) hor. stab should be -4.6 deg 4) dihedral should be 1.6 degrees per wing (I chose 2.7, because my diagonal struts were already made. When repositioning the wings to the new lower position, this has the effect of adding dihedral) 5) main wing should be +3.4 deg, but this has been revised to +2.8 deg After looking at the numbers I began to wonder if you aren't confusing the dihedral setting with the incidence setting. Just a thought. On Sun, Oct 23, 2016 at 4:09 PM, Richard Girard wrote : > Just realized I forgot about the gap cover. Yep, the "C" cover will not > work with the "X" (latest) wing incidence setting. Attached are pictures of > the one I made for the PfH. > > Rick > > PS Found the incidence numbers I used, although setting the motor mount a t > zero is a PITA, you end up the nose on the ground and the tail in the > rafters. :-} After looking at the numbers I began to wonder if you aren't > confusing the dihedral setting with the incidence setting. Just a thought . > > On Sun, Oct 23, 2016 at 3:49 PM, Richard Girard > wrote: > >> If it's an old 3X are the leading edges of the horizontal stabilizer set >> in the middle of the boom tube or near the top edge? >> The Mark 3C would have them set near the top edge and the early X's also >> used this setting. If you mix the "C" setting of the HS with the lower w ing >> incidence of the "X" your airplane will not fly correctly. >> >> Rick >> >> On Sun, Oct 23, 2016 at 10:58 AM, dirtracin wrote : >> >>> >>> lowering the wings has now created a new problem... the gap seal I have >>> cannot work with the wings that low... the leading edge of the wing now >>> sits lower than the upper windshield mount/bar... yet the gap seal I ha ve >>> the leading edge would have to be above the windshield mount/bar... I t hink >>> I will just call Bryan tomorrow... thanks for responding... >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=461546#461546 >>> >>> >>> >>> >>> >>> >>> =========== =========== =========== =========== =========== >>> >>> >>> >>> >> >> >> -- >> =9CBlessed are the cracked, for they shall let in the light. =9D Groucho >> Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> >> >> > > > -- > =9CBlessed are the cracked, for they shall let in the light. =9D Groucho Marx > <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Oct 23, 2016
I have an Xtra that is the same vintage as yours (within 2 numbers). I ordered a MarkIII and then changed it when the Xtra came out. I called Brian in July, 2011 when I started final rigging. The numbers he gave me are very close to Rick's. At Motor mount of 0 degrees, wing is 3.4, boom is -6.1, horiz. stab is -4.8 (I have the larger horiz. stab.). I set my D.H. so the tips are about 2 1/4" high each side. I also have the longer heavy steel legs from Kolb. Be sure to take several readings and average them. Those numbers have worked great for me. I think the u-joints on the wing can be turned upside down and that also Kolb has make some a little different. I don't remember the details or exactly what I had to do to get his numbers. I do remember that it was a lot of hassle going back and forth. Change one thing and you affect everything else. You might call Brian if nothing seems to work. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461554#461554 ________________________________________________________________________________
Date: Oct 24, 2016
If you use a digital level you can set it on the motor mount and "zero"it. Then you can take your readings as the plane is sitting. Also, I taped the level to the bottom of a longer precision level to measure the wing angle on the bottom of every other rib. You may be surprised at the deviation. Just average them and try to make the outboard end of the wings close to the same angle so you have an even stall. The more I think about it I may have turned the back wing u-joints upside down or used some that Kolb made with the holes in a different location. Can't remember, but I do remember that Brian had some suggestions. I think the older "blue" manual had some good tips and suggestions that were not incorporated in the newer one. I could scan the wing set up part and send it to you offline if you want. I could also send you pictures of my front and back wing attachment points if you wish. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461561#461561 ________________________________________________________________________________
Date: Oct 24, 2016
Subject: 7/16 x .028 shims
Kolbers , On my Firefly construction Im told to cut two shims of 4130 7/16 x 028 I believe they will be about 1/8 each or less I dont have any tubing of that size laying around so i called Aircraft Spruce and they dont have a ny either the thinnest wall that they have is .035 so i thought maybe someo ne on the list might be able to send me a little piece by us mail wont cost much for shipping so can anyone help me out?thank u Chris =C2-Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly ________________________________________________________________________________
Date: Oct 24, 2016
Yes Rex... anything you can do will help me out... the manual would be a great start because i have the new manual and it doesn't mach my plane... also my plans are from a classic so its all screwed up... can you measure the distance between the left and right wing roots at the rear by the u joint and where it is pinned to the fuselage... and no i have not tried rotating the u joints... i never gave that a thought... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461564#461564 ________________________________________________________________________________
Subject: Re: 7/16 x .028 shims
Date: Oct 24, 2016
Chris I do not recall them..what is the purpose? Herb On 10/24/2016 09:36 AM, chris davis wrote: > Kolbers , On my Firefly construction Im told to cut two shims of 4130 > 7/16 x 028 I believe they will be about 1/8 each or less I dont have > any tubing of that size laying around so i called Aircraft Spruce and > they dont have any either the thinnest wall that they have is .035 so > i thought maybe someone on the list might be able to send me a little > piece by us mail wont cost much for shipping so can anyone help me > out?thank u Chris > > > Chris Davis > KXP 503 492 hrs > Glider Pilot > Disabled from crash building Firefly -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Subject: Aileron trim and a new video
Date: Oct 24, 2016
Thanks to all for the aileron trim suggestions a few months ago. I made an adjustable trim and then had to add a little bit on the rudder trim for the extra drag. See attached pictures. Also, I made a new video with the camera mounted outside and added some music. I'm flying about 2500'. Would like to go lower but a little nervous as some times no good options for landing if an engine out occurs. Go to utube and type in "flying a kolb over table rock lake" and it should come up. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461566#461566 Attachments: http://forums.matronics.com//files/img_20160927_125540311_176.jpg ________________________________________________________________________________
Subject: Re: Aileron trim and a new video
Date: Oct 24, 2016
Forgot to reduce the size of the picture. Sorry! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461568#461568 ________________________________________________________________________________
Date: Oct 24, 2016
Not bad Rex. The mount seems to be pretty steady. I am surprised that You Tube allowed you to post it. I had some videos on YT and they blocked the video's since I didn't have copywrite permission for the song I used. That is why I went to Vimeo. Larry On Mon, Oct 24, 2016 at 9:40 AM, Rex Rodebush wrote: > > Forgot to reduce the size of the picture. Sorry! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461568#461568 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Oct 24, 2016
"Forgot to reduce the size of the picture. Sorry!" >>>>>>>>>>>>>> my curiosity is getting to me...... the picture of the aileron trim.... can you take another picture from further away... is the trim tab mounted dynamically? does it flex as you move the aileron? or is it fixed? what is the rod that the linkage is mounted to? I have the aileron counter weights on my mkIII.... but they go from the aileron torque tube forward.... Assuming they are dynamic and move as you move the ailerons.. do they reduce some of the stick pressure like a spade would do? and then maybe I am over imagining things here.... boyd young On Mon, Oct 24, 2016 at 9:40 AM, Rex Rodebush wrote: > > Forgot to reduce the size of the picture. Sorry! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461568#461568 > > ________________________________________________________________________________
Date: Oct 24, 2016
Hello Sir, I have one of the early MkIII Xtra's as well. I did change to the new taller steel legs and would advise anyone to do that. Both the Wing and the tail Horizontal incidences need to set correctly and I would certainly call the factory for the latest settings. I don't remember what they are but I did set the Leading edge of the HS too low, per a factory letter for newer models, and this created a dangerous first flight with wayyy too much UP pitch which could have killed me.. I did get a new universal joint from the factory that was much wider then the original and I have a bunch of washers to get the wing incidence correct. This is the trick to getting it all lined up right. The factory reset the wing incidence to reduce the effect of the wide nose during flight. You will have to reset the gap seal and windshield fairing again and maybe make a new one, once all the incidences are set . I remember it took some effort but I eventually used the original fiberglass parts. To summarize:- a/ I'd recommend getting the tall steel legs. There is a left and right and make sure you install them correctly. I had to redo this as its easy to b/ Call the factory, get the new incidences for both the wing and tail and a possible new wide universal bracket. c/ You should not have to cut any of the flap controls, that does not look right. AND we will try to help as well.. Regards FrankD MkIII Xtra, N1014S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461573#461573 ________________________________________________________________________________
Subject: RE: Kolb-List Digest: 3 Msgs - 10/16/16
Date: Oct 24, 2016
> Am I being paranoid? Any thoughts? You will probably be fine without brakes. However, I do have a concern. Consider this; you are going downhill in the rain pulling your trailer. You enter a tight corner, it's tighter than you expected so you put the brakes on. All of the trailer inertia is attempting to turn your PU sideways. You are in prime condition for a nasty jack-knife. I had a close call like this once on dry pavement. ________________________________________________________________________________
Date: Oct 24, 2016
I just got off the phone with Bryan at Kolb and he told me to set it up like the mk3 classic... lol He also said not to set it up with the adjustable u joints... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461580#461580 ________________________________________________________________________________
Date: Oct 24, 2016
Not sure what he meant by adjustable u-joints. The only adjustment I am aware is with washers. ?? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461584#461584 ________________________________________________________________________________
Date: Oct 24, 2016
Larry, I got the music from a web side for "free" music. No copyright problems. I'll see if I can find out where. Rex Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461585#461585 ________________________________________________________________________________
Date: Oct 24, 2016
Boyd, It's a fixed tab mounted to an extension of the aileron counter-balance. I'll send a pix tomorrow. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461586#461586 ________________________________________________________________________________
Date: Oct 24, 2016
Larry, I could not find out where I got the music but google "free music for utube videos" and a bunch of stuff comes up. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461587#461587 ________________________________________________________________________________
Date: Oct 24, 2016
It doesn't matter, I won't be returning to You Tube no matter what. Larry On Mon, Oct 24, 2016 at 3:33 PM, Rex Rodebush wrote: > > Larry, I got the music from a web side for "free" music. No copyright > problems. I'll see if I can find out where. > > Rex > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461585#461585 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Oct 25, 2016
Lovely smooth video. No music unfortunately. I think if I was flying in yo ur area I would choose an amphibian. Stayed many years ago with a guy in La ke Wales and flew a Buccaneer (I think). I have flown a French amphib.also . The amphibian is an exciting change, Easy to fly, the water landings are really not much trouble. I was sent solo after two trips dual. Swimming an d fishing from the plane and the use of deserted beaches for picnics opens up your options plus a lot of places to land if it does suddenly get all qu iet. Pat ________________________________ From: owner-kolb-list-server(at)matronics.com <owner-kolb-list-server@matronic s.com> on behalf of Rex Rodebush Sent: 24 October 2016 16:38:55 Subject: Kolb-List: Aileron trim and a new video Thanks to all for the aileron trim suggestions a few months ago. I made an adjustable trim and then had to add a little bit on the rudder trim for th e extra drag. See attached pictures. Also, I made a new video with the camera mounted outside and added some mus ic. I'm flying about 2500'. Would like to go lower but a little nervous a s some times no good options for landing if an engine out occurs. Go to utube and type in "flying a kolb over table rock lake" and it should come up. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461566#461566 Attachments: http://forums.matronics.com//files/img_20160927_125540311_176.jpg ________________________________________________________________________________
Date: Oct 25, 2016
Pat, I have looked at making it an amphibian. The main concerns I have are that with the extra weight and a full tank it pretty much becomes a single place airplane. Also, you need a paved or very smooth grass runway. You would give up many off field landing areas. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461605#461605 ________________________________________________________________________________
Date: Oct 25, 2016
Herb the shims go on the 3/8 bolt that goes through th H tube so the flapero n arms can swivel freely . Sent from my iPhone > On Oct 24, 2016, at 11:35 AM, Herb wrote: > > Chris > > I do not recall them..what is the purpose? Herb > >> On 10/24/2016 09:36 AM, chris davis wrote: >> Kolbers , On my Firefly construction Im told to cut two shims of 4130 7/1 6 x 028 I believe they will be about 1/8 each or less I dont have any tubing of that size laying around so i called Aircraft Spruce and they dont have a ny either the thinnest wall that they have is .035 so i thought maybe someon e on the list might be able to send me a little piece by us mail wont cost m uch for shipping so can anyone help me out?thank u Chris >> >> >> >> Chris Davis >> KXP 503 492 hrs >> Glider Pilot >> Disabled from crash building Firefly > > -- > "Masculine republics give way to feminine democracies, and feminine democr acies give way to tyranny." > > Aristotle > > "Daddy, tell me...why are you going to the pig farm for a reeducation and w hat does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 25, 2016
Chris Those are short pieces of tubing that fit over the h section through bolt..Just a bit longer than the actuation levers are wide...Herb On 10/25/2016 11:14 AM, chris davis wrote: > Herb the shims go on the 3/8 bolt that goes through th H tube so the > flaperon arms can swivel freely . > > Sent from my iPhone > > On Oct 24, 2016, at 11:35 AM, Herb > wrote: > >> Chris >> >> I do not recall them..what is the purpose? Herb >> >> >> On 10/24/2016 09:36 AM, chris davis wrote: >>> Kolbers , On my Firefly construction Im told to cut two shims of >>> 4130 7/16 x 028 I believe they will be about 1/8 each or less I dont >>> have any tubing of that size laying around so i called Aircraft >>> Spruce and they dont have any either the thinnest wall that they >>> have is .035 so i thought maybe someone on the list might be able to >>> send me a little piece by us mail wont cost much for shipping so can >>> anyone help me out?thank u Chris >>> >>> >>> Chris Davis >>> KXP 503 492 hrs >>> Glider Pilot >>> Disabled from crash building Firefly >> >> -- >> "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." >> >> Aristotle >> >> "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 25, 2016
the holes in the levers should be just large enough to allow the shims to slide freely through.. ..Herb On 10/25/2016 12:36 PM, Herb wrote: > > Chris > > Those are short pieces of tubing that fit over the h section > through bolt..Just a bit longer than the actuation levers are wide...Herb > > > On 10/25/2016 11:14 AM, chris davis wrote: >> Herb the shims go on the 3/8 bolt that goes through th H tube so the >> flaperon arms can swivel freely . >> >> Sent from my iPhone >> >> On Oct 24, 2016, at 11:35 AM, Herb > > wrote: >> >>> Chris >>> >>> I do not recall them..what is the purpose? Herb >>> >>> >>> On 10/24/2016 09:36 AM, chris davis wrote: >>>> Kolbers , On my Firefly construction Im told to cut two shims of >>>> 4130 7/16 x 028 I believe they will be about 1/8 each or less I >>>> dont have any tubing of that size laying around so i called >>>> Aircraft Spruce and they dont have any either the thinnest wall >>>> that they have is .035 so i thought maybe someone on the list might >>>> be able to send me a little piece by us mail wont cost much for >>>> shipping so can anyone help me out?thank u Chris >>>> >>>> >>>> Chris Davis >>>> KXP 503 492 hrs >>>> Glider Pilot >>>> Disabled from crash building Firefly >>> >>> -- >>> "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." >>> >>> Aristotle >>> >>> "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... > > -- > "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." > > Aristotle > > "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 25, 2016
Attached are downsized pictures of the aileron trim attachment, the landing gear and some pictures of my rear u-joints. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461618#461618 Attachments: http://forums.matronics.com//files/img_20161025_120104653_138.jpg http://forums.matronics.com//files/img_20161025_115731040_511.jpg ________________________________________________________________________________
Date: Oct 25, 2016
two pictures did not attach. Hope this works. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461619#461619 ________________________________________________________________________________
Date: Oct 25, 2016
One more time Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461620#461620 Attachments: http://forums.matronics.com//files/img_20161025_120104653_948.jpg http://forums.matronics.com//files/img_20161025_120104653_229.jpg ________________________________________________________________________________
Subject: Kolb Firestar 1...
Date: Oct 25, 2016
I am looking at a 5 rib Firestar 1... Is that a KXP? And what is a KXP? When were they built? And the engine ,447 , shows an ign box under the carb, but the coil is mounted in the location where the dual coils would be mounted for a points ign engine..Single coil, waste spark ... Any info would be appreciated...Herb ________________________________________________________________________________
Date: Oct 25, 2016
Subject: Re: Kolb Firestar 1...
It is my understanding that the KXP came after the 5 rib. I believe it was the first 7 rib firestar. Larry On Tue, Oct 25, 2016 at 5:27 PM, Herb wrote: > > > I am looking at a 5 rib Firestar 1... Is that a KXP? And what is a KXP? > When were they built? > And the engine ,447 , shows an ign box under the carb, but the coil is > mounted in the location where the dual coils would be mounted for a points > ign engine..Single coil, waste spark ... > Any info would be appreciated...Herb > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Oct 25, 2016
Subject: Re: Kolb Firestar 1... Kxp
Kolb web sight has a history page. It explains the timeline and development of the different models. http://www.kolbaircraft.com/history.htm ________________________________________________________________________________
Date: Oct 25, 2016
thanks for the reminder...been there and read that before... :-) Herb On 10/25/2016 06:51 PM, B Young wrote: > > Kolb web sight has a history page. It explains the timeline and > development of the different models. > > http://www.kolbaircraft.com/history.htm > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 25, 2016
If I read it right...the one I am looking at is a KX...per 1990 maybe? Herb On 10/25/2016 06:32 PM, Larry Cottrell wrote: > It is my understanding that the KXP came after the 5 rib. I believe it > was the first 7 rib firestar. > Larry > > On Tue, Oct 25, 2016 at 5:27 PM, Herb > wrote: > > > > > > I am looking at a 5 rib Firestar 1... Is that a KXP? And what is a > KXP? When were they built? > And the engine ,447 , shows an ign box under the carb, but the > coil is mounted in the location where the dual coils would be > mounted for a points ign engine..Single coil, waste spark ... > Any info would be appreciated...Herb > > =================================== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?Kolb-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > > -- > /The older I get, the less tolerant I am of those who are intolerant > of others./ > / > / > /If you forward this email, or any part of it, please remove my email > address before sending./ -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 25, 2016
pre 1990.... Herb On 10/25/2016 08:23 PM, Herb wrote: > > If I read it right...the one I am looking at is a KX...per 1990 > maybe? Herb > > > On 10/25/2016 06:32 PM, Larry Cottrell wrote: >> It is my understanding that the KXP came after the 5 rib. I believe >> it was the first 7 rib firestar. >> Larry >> >> On Tue, Oct 25, 2016 at 5:27 PM, Herb > > wrote: >> >> > >> >> >> I am looking at a 5 rib Firestar 1... Is that a KXP? And what is >> a KXP? When were they built? >> And the engine ,447 , shows an ign box under the carb, but the >> coil is mounted in the location where the dual coils would be >> mounted for a points ign engine..Single coil, waste spark ... >> Any info would be appreciated...Herb >> >> =================================== >> -List" rel="noreferrer" >> target="_blank">http://www.matronics.com/Navigator?Kolb-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" >> target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> >> >> >> -- >> /The older I get, the less tolerant I am of those who are intolerant >> of others./ >> / >> / >> /If you forward this email, or any part of it, please remove my email >> address before sending./ > > -- > "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." > > Aristotle > > "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 25, 2016
Yes herb I know what they are I was just trying to locate a piece of tubing t hat size 7/16 x 028 as I said I don't have any and I call aircraft spruce an d they don't have any 7/16 with a wall that thin 035 was the thinnest wall t hey sell so instead of buying a lot more than I need somewhere else I though t perhaps someone on the list might have a piece they could send me ? Get m y drift? Thanks for the comeback if no one else responds I guess I will look elsewhere or maybe even ask Bryon at KOLB for a piece . Chris Sent from my iPhone > On Oct 25, 2016, at 1:36 PM, Herb wrote: > > Chris > > Those are short pieces of tubing that fit over the h section through bo lt..Just a bit longer than the actuation levers are wide...Herb > >> On 10/25/2016 11:14 AM, chris davis wrote: >> Herb the shims go on the 3/8 bolt that goes through th H tube so the flap eron arms can swivel freely . >> >> Sent from my iPhone >> >> On Oct 24, 2016, at 11:35 AM, Herb wrote: >> >>> Chris >>> >>> I do not recall them..what is the purpose? Herb >>> >>>> On 10/24/2016 09:36 AM, chris davis wrote: >>>> Kolbers , On my Firefly construction Im told to cut two shims of 4130 7 /16 x 028 I believe they will be about 1/8 each or less I dont have any tubi ng of that size laying around so i called Aircraft Spruce and they dont have any either the thinnest wall that they have is .035 so i thought maybe some one on the list might be able to send me a little piece by us mail wont cost much for shipping so can anyone help me out?thank u Chris >>>> >>>> >>>> >>>> Chris Davis >>>> KXP 503 492 hrs >>>> Glider Pilot >>>> Disabled from crash building Firefly >>> >>> -- >>> "Masculine republics give way to feminine democracies, and feminine demo cracies give way to tyranny." >>> >>> Aristotle >>> >>> "Daddy, tell me...why are you going to the pig farm for a reeducation an d what does it mean "A basket of deplorables"? "Are you unreedemable"? And" w ho is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... > > -- > "Masculine republics give way to feminine democracies, and feminine democr acies give way to tyranny." > > Aristotle > > "Daddy, tell me...why are you going to the pig farm for a reeducation and w hat does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 26, 2016
Hi, I think that I would go for a properly designed amphib. rather than try to convert a Kolb. I can`t remember much about the Buccaneer, it was a long ti me ago but I remember it as a roomy side by side cockpit with easy access and good visibility. I think it had wing tip floats for stability when anch ored. They guy I stayed with had a wooden ramp from his land into Lake Wale s. He kept the plane parked on the ramp and when we were aboard he just too k off the brake and we trundled backward into the water. There was some qui ck work with a paddle to float us clear of the trees which surrounded the l ake. He turned into wind and pulled the starter cord and we gently nosed ou t into the lake. When the engine is running you gotta go. We did the checks as we nosed into wind, checked that there were no boats about, opened the throttle and bounced into the air after quite a short take off run. When we returned after a few circuits, and a beat up across the lake flat out at a round ten feet, great fun, we landed and taxied straight out of the water and up his ramp. Unfortunately the next day we could not get the engine sta rted and I never solo`d. I remember he had friends arriving by boat and pla ne from all over the lake , all offering advice, and beer, while we worked in the shade of a big tree. It was a great day and one of the best `hangar flying` days I ever had. The French amphib. I flew was twenty years later. It was designed by a bo at designer with aeronautical experience. Lots of things were operated by t oggles and ropes, just like a small sailing dinghy. The rudder retracted by pulling a toggle. The wheels dropped from their retracted position by pull ing a toggle. All very boaty. The main difference to the Bucanceer was that the main pod was cast in plastic not just fabric beefed up with a sole pl ate. The engine had an electric starter too. Altogether a more up together outfit but as I said it was at least twenty years later and things had mov ed on in the microlight world. I tried to get a flight with a guy who had put a Kolb on floats when I was down in the Keys at one time. Unfortunately, after a long drive to find him he had the plane in bits doing some maintenance. It looked as though it wo uld work OK and I remember seeing Kolbs on floats on you tube at one point but the drag caused by inflatable floats with little streamlining must have been tremendous. I did find a guy down in the Keys who had fitted a weightshift wing and eng ine to a rubber dinghy but although it looked fun I didn`t fancy it for ser ious flying. Your flying area is very attractive. Is the water warm enough to swim in? I should find it very frustrating if it was like San Francisco, where the wa ter looks so attractive but you need a diving suit to get in it. Good luck Pat ________________________________ From: owner-kolb-list-server(at)matronics.com <owner-kolb-list-server@matronic s.com> on behalf of Rex Rodebush Sent: 25 October 2016 15:53:20 Subject: Kolb-List: Re: Aileron trim and a new video Pat, I have looked at making it an amphibian. The main concerns I have ar e that with the extra weight and a full tank it pretty much becomes a singl e place airplane. Also, you need a paved or very smooth grass runway. You would give up many off field landing areas. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461605#461605 ________________________________________________________________________________
Date: Oct 26, 2016
Chris Looking at the plans..it would be hard to tell if it is a piece of tubing or just a flat washer..:-) I think Kolb went to all .035 in the Firefly fuselage to standardize it to all the other models. I will check my stock...and let you know...If not..betting Bryan can send you a couple of pre cut shims...for shipping cost ...Herb On 10/25/2016 10:15 PM, chris davis wrote: > Yes herb I know what they are I was just trying to locate a piece of > tubing that size 7/16 x 028 as I said I don't have any and I call > aircraft spruce and they don't have any 7/16 with a wall that thin 035 > was the thinnest wall they sell so instead of buying a lot more than I > need somewhere else I thought perhaps someone on the list might have a > piece they could send me ? Get my drift? Thanks for the comeback if > no one else responds I guess I will look elsewhere or maybe even ask > Bryon at KOLB for a piece . Chris > > Sent from my iPhone > > On Oct 25, 2016, at 1:36 PM, Herb > wrote: > >> Chris >> >> Those are short pieces of tubing that fit over the h section >> through bolt..Just a bit longer than the actuation levers are >> wide...Herb >> >> >> On 10/25/2016 11:14 AM, chris davis wrote: >>> Herb the shims go on the 3/8 bolt that goes through th H tube so the >>> flaperon arms can swivel freely . >>> >>> Sent from my iPhone >>> >>> On Oct 24, 2016, at 11:35 AM, Herb >> > wrote: >>> >>>> Chris >>>> >>>> I do not recall them..what is the purpose? Herb >>>> >>>> >>>> On 10/24/2016 09:36 AM, chris davis wrote: >>>>> Kolbers , On my Firefly construction Im told to cut two shims of >>>>> 4130 7/16 x 028 I believe they will be about 1/8 each or less I >>>>> dont have any tubing of that size laying around so i called >>>>> Aircraft Spruce and they dont have any either the thinnest wall >>>>> that they have is .035 so i thought maybe someone on the list >>>>> might be able to send me a little piece by us mail wont cost much >>>>> for shipping so can anyone help me out?thank u Chris >>>>> >>>>> >>>>> Chris Davis >>>>> KXP 503 492 hrs >>>>> Glider Pilot >>>>> Disabled from crash building Firefly >>>> >>>> -- >>>> "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." >>>> >>>> Aristotle >>>> >>>> "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... >> >> -- >> "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." >> >> Aristotle >> >> "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 26, 2016
Herb, I guess that I will try Bryan. According to my plans it is a piece of tubing and I have tried to find a washer that only has an outside diameter of 7/16 and would have an inside diameter of 3/8 to no avail so I guess I will try KOLB.Thanks for your input . Chris =C2-Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly On Wednesday, October 26, 2016 9:24 AM, Herb wrote: Chris =C2- Looking at the plans..it would be hard to tell if it is a p iece of tubing or just a flat washer..:-)=C2-=C2-=C2- I think Kolb we nt to all .035 in the Firefly fuselage to standardize it to all the other m odels. I will check my stock...and let you know...If not..betting Bryan can send you a couple of pre cut shims...for shipping cost ...Herb =C2- On 10/25/2016 10:15 PM, chris davis wrote: Yes herb I know what they are I was just trying to locate a piece of tubin g that size 7/16 x 028 as I said I don't have any and I call aircraft spruc e and they don't have any 7/16 with a wall that thin 035 was the thinnest w all they sell so instead of buying a lot more than I need somewhere else I thought perhaps someone on the list might have a piece they could send me =C2-? Get my drift? Thanks for the comeback if no one else responds I gue ss I will look elsewhere or maybe even ask Bryon at KOLB for a piece . Chri s Sent from my iPhone On Oct 25, 2016, at 1:36 PM, Herb wrote: Chris =C2- Those are short pieces of tubing that fit=C2- over the h s ection through bolt..Just a bit longer than the actuation levers are wide.. .Herb On 10/25/2016 11:14 AM, chris davis wrote: Herb the shims go on the 3/8 bolt that goes through th H tube so the flape ron arms can swivel freely .=C2- Sent from my iPhone On Oct 24, 2016, at 11:35 AM, Herb wrote: Chris =C2- I do not recall them..what is the purpose?=C2- Herb On 10/24/2016 09:36 AM, chris davis wrote: Kolbers , On my Firefly construction Im told to cut two shims of 4130 7/1 6 x 028 I believe they will be about 1/8 each or less I dont have any tubin g of that size laying around so i called Aircraft Spruce and they dont have any either the thinnest wall that they have is .035 so i thought maybe so meone on the list might be able to send me a little piece by us mail wont c ost much for shipping so can anyone help me out?thank u Chris =C2- Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly -- "Masculine republics give way to feminine democracies, and feminine democra cies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and w hat does it mean "A basket of deplorables"? "Are you unreedemable"? And" wh o is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... -- "Masculine republics give way to feminine democracies, and feminine democra cies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and w hat does it mean "A basket of deplorables"? "Are you unreedemable"? And" wh o is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... -- "Masculine republics give way to feminine democracies, and feminine democra cies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and w hat does it mean "A basket of deplorables"? "Are you unreedemable"? And" wh o is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 26, 2016
Rex, I missed your point about rough landing fields. Sorry that I cannot help th ere. As I said, the plane in Lake Wales when we flew it went straight from a ramp into the water. The next time I saw it, it was for sale at Sun n Fu n. The French amphib. I flew was from Vance-Meucon airfield to the sea and back. Vance had a single concrete runway on the edge of the town where the factory which built the plane was situated so the use of rough fields did n ot come up. I do remember however that the company was exporting 5 planes t o a missionary outfit in Africa where I would not expect landing strip to b e very good. For what its worth. Pat ________________________________ From: owner-kolb-list-server(at)matronics.com <owner-kolb-list-server@matronic s.com> on behalf of Rex Rodebush Sent: 25 October 2016 15:53:20 Subject: Kolb-List: Re: Aileron trim and a new video Pat, I have looked at making it an amphibian. The main concerns I have ar e that with the extra weight and a full tank it pretty much becomes a singl e place airplane. Also, you need a paved or very smooth grass runway. You would give up many off field landing areas. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461605#461605 ________________________________________________________________________________
Date: Oct 26, 2016
Herb Larry is right the KXP had & rib wings and a stronger drag strut to ma ke the Firestar able to use a 503 Rotax. Chris=C2-=C2-Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly On Tuesday, October 25, 2016 9:36 PM, Herb wrote: pre 1990.... Herb On 10/25/2016 08:23 PM, Herb wrote: If I read it right...the one I am looking at is a KX...per 1990 maybe?=C2 - Herb On 10/25/2016 06:32 PM, Larry Cottrell wrote: It is my understanding that the KXP came after the 5 rib. I believe it was the first 7 rib firestar. Larry On Tue, Oct 25, 2016 at 5:27 PM, Herb wrote: I am looking at a 5 rib Firestar 1... Is that a KXP? And what is a KXP?=C2 - =C2-When were they built? =C2- And the engine ,447 , shows an ign box under the carb, but the coil is mounted in the location where the dual coils would be mounted for a poi nts ign engine..Single coil, waste spark ... =C2- Any info would be appreciated...Herb ==== ==================== ========== = -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navig ator?Kolb-List ==== ==================== ========== = FORUMS - eferrer" target="_blank">http://forums.matronics.com ==== ==================== ========== = WIKI - errer" target="_blank">http://wiki.matronics.com ==== ==================== ========== = b Site - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contr ibutio n ==== ==================== ========== = -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email addr ess before sending. -- "Masculine republics give way to feminine democracies, and feminine democra cies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and w hat does it mean "A basket of deplorables"? "Are you unreedemable"? And" wh o is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... -- "Masculine republics give way to feminine democracies, and feminine democra cies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and w hat does it mean "A basket of deplorables"? "Are you unreedemable"? And" wh o is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 26, 2016
Pat, We are in Southern Missouri just about 10 miles north of Arkansas. The weather is warm and the lake temperature can get into the 80's during summer. No problem swimming. I have a neighbor (a retired airline pilot) that built an early kolb twinstar and put floats on it. He and a fellow pilot flew it on the Mississippi river near St. Louis. The floats were not amphibious. They hauled it back and forth. This was probably 15/20 years ago. I think he gave me a picture of it. I'll see if I can scan and attach it. Rex Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461639#461639 ________________________________________________________________________________
Date: Oct 26, 2016
I went to my tubing stash and did not find anything...Herb On 10/26/2016 09:03 AM, chris davis wrote: > Herb, I guess that I will try Bryan. According to my plans it is a > piece of tubing and I have tried to find a washer that only has an > outside diameter of 7/16 and would have an inside diameter of 3/8 to > no avail so I guess I will try KOLB. > Thanks for your input . Chris > > > Chris Davis > KXP 503 492 hrs > Glider Pilot > Disabled from crash building Firefly > > > On Wednesday, October 26, 2016 9:24 AM, Herb wrote: > > > Chris > Looking at the plans..it would be hard to tell if it is a piece of > tubing or just a flat washer..:-) I think Kolb went to all .035 in > the Firefly fuselage to standardize it to all the other models. I will > check my stock...and let you know...If not..betting Bryan can send you > a couple of pre cut shims...for shipping cost ...Herb > > > On 10/25/2016 10:15 PM, chris davis wrote: >> Yes herb I know what they are I was just trying to locate a piece of >> tubing that size 7/16 x 028 as I said I don't have any and I call >> aircraft spruce and they don't have any 7/16 with a wall that thin >> 035 was the thinnest wall they sell so instead of buying a lot more >> than I need somewhere else I thought perhaps someone on the list >> might have a piece they could send me ? Get my drift? Thanks for the >> comeback if no one else responds I guess I will look elsewhere or >> maybe even ask Bryon at KOLB for a piece . Chris >> >> Sent from my iPhone >> >> On Oct 25, 2016, at 1:36 PM, Herb > > wrote: >> >>> Chris >>> Those are short pieces of tubing that fit over the h section >>> through bolt..Just a bit longer than the actuation levers are >>> wide...Herb >>> >>> On 10/25/2016 11:14 AM, chris davis wrote: >>>> Herb the shims go on the 3/8 bolt that goes through th H tube so >>>> the flaperon arms can swivel freely . >>>> >>>> Sent from my iPhone >>>> >>>> On Oct 24, 2016, at 11:35 AM, Herb >>> > wrote: >>>> >>>>> Chris >>>>> I do not recall them..what is the purpose? Herb >>>>> >>>>> On 10/24/2016 09:36 AM, chris davis wrote: >>>>>> Kolbers , On my Firefly construction Im told to cut two shims of >>>>>> 4130 7/16 x 028 I believe they will be about 1/8 each or less I >>>>>> dont have any tubing of that size laying around so i called >>>>>> Aircraft Spruce and they dont have any either the thinnest wall >>>>>> that they have is .035 so i thought maybe someone on the list >>>>>> might be able to send me a little piece by us mail wont cost much >>>>>> for shipping so can anyone help me out?thank u Chris >>>>>> >>>>>> >>>>>> Chris Davis >>>>>> KXP 503 492 hrs >>>>>> Glider Pilot >>>>>> Disabled from crash building Firefly >>>>> >>>>> -- >>>>> "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." >>>>> >>>>> Aristotle >>>>> >>>>> "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... >>> >>> -- >>> "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." >>> >>> Aristotle >>> >>> "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... > > -- > "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." > > Aristotle > > "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 26, 2016
This one has an odd 447..odd in that I have never seen one with a dual ign coil..and with an ign box below the carbs.. 5 rib wing...so a KX . Likely something from a motorcycle...? I read the history blurb on the Kolb site but could not get a good feel as to the age of a Firestar with the 5 rib wing..Herb On 10/26/2016 09:21 AM, chris davis wrote: > Herb Larry is right the KXP had & rib wings and a stronger drag strut > to make the Firestar able to use a 503 Rotax. Chris > Chris Davis > KXP 503 492 hrs > Glider Pilot > Disabled from crash building Firefly > > > On Tuesday, October 25, 2016 9:36 PM, Herb wrote: > > > pre 1990.... Herb > > On 10/25/2016 08:23 PM, Herb wrote: > If I read it right...the one I am looking at is a KX...per 1990 > maybe? Herb > > On 10/25/2016 06:32 PM, Larry Cottrell wrote: >> It is my understanding that the KXP came after the 5 rib. I believe >> it was the first 7 rib firestar. >> Larry >> >> On Tue, Oct 25, 2016 at 5:27 PM, Herb > > wrote: >> >> > >> >> >> I am looking at a 5 rib Firestar 1... Is that a KXP? And what is >> a KXP? When were they built? >> And the engine ,447 , shows an ign box under the carb, but the >> coil is mounted in the location where the dual coils would be >> mounted for a points ign engine..Single coil, waste spark ... >> Any info would be appreciated...Herb >> >> ==== ============================== = >> -List" rel="noreferrer" >> target="_blank">http://www.matronics.com/Navig ator?Kolb-List >> ==== ============================== = >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> <http://forums.matronics.com/> >> ==== ============================== = >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> <http://wiki.matronics.com/> >> ==== ============================== = >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contr >> ibution >> ==== ============================== = >> >> >> >> >> >> >> -- >> /The older I get, the less tolerant I am of those who are intolerant >> of others./ >> / >> / >> /If you forward this email, or any part of it, please remove my email >> address before sending./ > > -- > "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." > > Aristotle > > "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... > > -- > "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." > > Aristotle > > "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 26, 2016
Chris A bronze bushing might work? ACE hardware for one...Herb On 10/25/2016 10:15 PM, chris davis wrote: > Yes herb I know what they are I was just trying to locate a piece of > tubing that size 7/16 x 028 as I said I don't have any and I call > aircraft spruce and they don't have any 7/16 with a wall that thin 035 > was the thinnest wall they sell so instead of buying a lot more than I > need somewhere else I thought perhaps someone on the list might have a > piece they could send me ? Get my drift? Thanks for the comeback if > no one else responds I guess I will look elsewhere or maybe even ask > Bryon at KOLB for a piece . Chris > > Sent from my iPhone > > On Oct 25, 2016, at 1:36 PM, Herb > wrote: > >> Chris >> >> Those are short pieces of tubing that fit over the h section >> through bolt..Just a bit longer than the actuation levers are >> wide...Herb >> >> >> On 10/25/2016 11:14 AM, chris davis wrote: >>> Herb the shims go on the 3/8 bolt that goes through th H tube so the >>> flaperon arms can swivel freely . >>> >>> Sent from my iPhone >>> >>> On Oct 24, 2016, at 11:35 AM, Herb >> > wrote: >>> >>>> Chris >>>> >>>> I do not recall them..what is the purpose? Herb >>>> >>>> >>>> On 10/24/2016 09:36 AM, chris davis wrote: >>>>> Kolbers , On my Firefly construction Im told to cut two shims of >>>>> 4130 7/16 x 028 I believe they will be about 1/8 each or less I >>>>> dont have any tubing of that size laying around so i called >>>>> Aircraft Spruce and they dont have any either the thinnest wall >>>>> that they have is .035 so i thought maybe someone on the list >>>>> might be able to send me a little piece by us mail wont cost much >>>>> for shipping so can anyone help me out?thank u Chris >>>>> >>>>> >>>>> Chris Davis >>>>> KXP 503 492 hrs >>>>> Glider Pilot >>>>> Disabled from crash building Firefly >>>> >>>> -- >>>> "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." >>>> >>>> Aristotle >>>> >>>> "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... >> >> -- >> "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." >> >> Aristotle >> >> "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 26, 2016
Herb I emailed Kolb and Bryan said he would send me some , thanks for your e ffort ..Chris Sent from my iPhone > On Oct 26, 2016, at 12:09 PM, Herb wrote: > > I went to my tubing stash and did not find anything...Herb > >> On 10/26/2016 09:03 AM, chris davis wrote: >> Herb, I guess that I will try Bryan. According to my plans it is a piece o f tubing and I have tried to find a washer that only has an outside diameter of 7/16 and would have an inside diameter of 3/8 to no avail so I guess I w ill try KOLB. >> Thanks for your input . Chris >> >> >> >> Chris Davis >> KXP 503 492 hrs >> Glider Pilot >> Disabled from crash building Firefly >> >> >> On Wednesday, October 26, 2016 9:24 AM, Herb wrote: >> >> >> Chris >> Looking at the plans..it would be hard to tell if it is a piece of tubi ng or just a flat washer..:-) I think Kolb went to all .035 in the Firefl y fuselage to standardize it to all the other models. I will check my stock. ..and let you know...If not..betting Bryan can send you a couple of pre cut s hims...for shipping cost ...Herb >> >> >>> On 10/25/2016 10:15 PM, chris davis wrote: >>> Yes herb I know what they are I was just trying to locate a piece of tub ing that size 7/16 x 028 as I said I don't have any and I call aircraft spru ce and they don't have any 7/16 with a wall that thin 035 was the thinnest w all they sell so instead of buying a lot more than I need somewhere else I t hought perhaps someone on the list might have a piece they could send me ? G et my drift? Thanks for the comeback if no one else responds I guess I will l ook elsewhere or maybe even ask Bryon at KOLB for a p iece . Chris >>> >>> Sent from my iPhone >>> >>> On Oct 25, 2016, at 1:36 PM, Herb wrote: >>> >>>> Chris >>>> Those are short pieces of tubing that fit over the h section through bolt..Just a bit longer than the actuation levers are wide...Herb >>>> >>>>> On 10/25/2016 11:14 AM, chris davis wrote: >>>>> Herb the shims go on the 3/8 bolt that goes through th H tube so the f laperon arms can swivel freely . >>>>> >>>>> Sent from my iPhone >>>>> >>>>> On Oct 24, 2016, at 11:35 AM, Herb wrote: >>>>> >>>>>> Chris >>>>>> I do not recall them..what is the purpose? Herb >>>>>> >>>>>>> On 10/24/2016 09:36 AM, chris davis wrote: >>>>>>> Kolbers , On my Firefly construction Im told to cut two shims of 413 0 7/16 x 028 I believe they will be about 1/8 each or less I dont have any t ubing of that size laying around so i called Aircraft Spruce and they dont h ave any either the thinnest wall that they have is .035 so i thought maybe s omeone on the list might be able to send me a little piece by us mail wont c ost much for shipping so can anyone help me out?thank u Chris >>>>>>> >>>>>>> >>>>>>> >>>>>>> Chris Davis >>>>>>> KXP 503 492 hrs >>>>>>> Glider Pilot >>>>>>> Disabled from crash building Firefly >>>>>> >>>>>> -- >>>>>> "Masculine republics give way to feminine democracies, and feminine d emocracies give way to tyranny." >>>>>> >>>>>> Aristotle >>>>>> >>>>>> "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? An d" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... >>>> >>>> -- >>>> "Masculine republics give way to feminine democracies, and feminine dem ocracies give way to tyranny." >>>> >>>> Aristotle >>>> >>>> "Daddy, tell me...why are you going to the pig farm for a reeducation a nd what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... >> >> -- >> "Masculine republics give way to feminine democracies, and feminine democ racies give way to tyranny." >> >> Aristotle >> >> "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" w ho is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... >> >> > > -- > "Masculine republics give way to feminine democracies, and feminine democr acies give way to tyranny." > > Aristotle > > "Daddy, tell me...why are you going to the pig farm for a reeducation and w hat does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 26, 2016
The snowmobile engines had a Ducati electronic ignition ignition with a single two-lead coil and a 'black box' that could be mounted in various places. It's a good system. I believe it has an electronic advance built in that makes the engine idle smoother. I know mine idled a lot smoother when I switched it from points to this set up. -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461652#461652 ________________________________________________________________________________
Date: Oct 27, 2016
I have been looking at pics on YouTube and the Buccaneer shown there with t he pilot fitting the wheels while in flight is definitely not the one I fle w. Mine folded the wheels up in a very awkward config which made the plane look like a stork swimming and trying to keep its feet dry. Worked though. Pat ________________________________ From: owner-kolb-list-server(at)matronics.com <owner-kolb-list-server@matronic s.com> on behalf of Rex Rodebush Sent: 26 October 2016 16:34:59 Subject: Kolb-List: Re: Aileron trim and a new video Pat, We are in Southern Missouri just about 10 miles north of Arkansas. The wea ther is warm and the lake temperature can get into the 80's during summer. No problem swimming. I have a neighbor (a retired airline pilot) that built an early kolb twins tar and put floats on it. He and a fellow pilot flew it on the Mississippi river near St. Louis. The floats were not amphibious. They hauled it bac k and forth. This was probably 15/20 years ago. I think he gave me a pict ure of it. I'll see if I can scan and attach it. Rex Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461639#461639 ________________________________________________________________________________
Date: Oct 27, 2016
Your description matches what I am seeing...but I am wondering if the unit can be fired by points or inductive pick up? Herb On 10/26/2016 10:33 PM, wakataka wrote: > > The snowmobile engines had a Ducati electronic ignition ignition with a single two-lead coil and a 'black box' that could be mounted in various places. It's a good system. I believe it has an electronic advance built in that makes the engine idle smoother. I know mine idled a lot smoother when I switched it from points to this set up. > > -------- > There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. > > Mark Twain > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461652#461652 > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 27, 2016
Attached is a pix of the twinstar on floats. It's a pdf file so don't know if it will work. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461660#461660 Attachments: http://forums.matronics.com//files/twinstar_floats_1_180.pdf ________________________________________________________________________________
Date: Oct 27, 2016
From: william sullivan <williamtsullivan(at)att.net>
The pdf file worked with no problem. -------------------------------------------- On Thu, 10/27/16, Rex Rodebush wrote: Subject: Kolb-List: Re: Aileron trim and a new video To: kolb-list(at)matronics.com Date: Thursday, October 27, 2016, 11:22 AM "Rex Rodebush" Attached is a pix of the twinstar on floats. It's a pdf file so don't know if it will work. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461660#461660 Attachments: http://forums.matronics.com//files/twinstar_floats_1_180.pdf Forum - - MATRONICS WEB FORUMS - MATRONICS LIST WIKI - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Second chance chute
Date: Oct 27, 2016
Anyone have an idea as to the age of this BRS? Took it out of a Z Max...and I am pretty sure it has been installed for more than 10 years...Any details also. Herb http://s1248.photobucket.com/user/herbgh/media/IMG_1453_zpsyn4mklxj.jpg.html?sort=3&o=17 ________________________________________________________________________________
Subject: Re: Second chance chute
Date: Oct 27, 2016
Herb - doesnt BRS know?? > On Oct 27, 2016, at 1:18 PM, Herb wrote: > > > > Anyone have an idea as to the age of this BRS? Took it out of a Z Max...and I am pretty sure it has been installed for more than 10 years...Any details also. Herb > > http://s1248.photobucket.com/user/herbgh/media/IMG_1453_zpsyn4mklxj.jpg.html?sort=3&o=17 > > > > ________________________________________________________________________________
Date: Oct 27, 2016
Rex - thanx for pic of the Kolb on floats. But IMHO the Kolb is an IDEAL configuration for a floating-hull seaplane or amphib, with stubby sponsons. Better than floats IMHO. Fair winds, Russ K > On Oct 27, 2016, at 11:22 AM, Rex Rodebush wrote: > > > Attached is a pix of the twinstar on floats. It's a pdf file so don't know if it will work. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461660#461660 > > > > > Attachments: > > http://forums.matronics.com//files/twinstar_floats_1_180.pdf > > > > > > > ________________________________________________________________________________
Date: Oct 27, 2016
I went to their site and could not download the pages...kinda frustrating...but I will give it another try..I know it is an old unit and thought some of you guys might have good input...Herb On 10/27/2016 05:11 PM, Russ Kinne wrote: > > Herb - doesnt BRS know?? > >> On Oct 27, 2016, at 1:18 PM, Herb wrote: >> >> >> >> Anyone have an idea as to the age of this BRS? Took it out of a Z Max...and I am pretty sure it has been installed for more than 10 years...Any details also. Herb >> >> http://s1248.photobucket.com/user/herbgh/media/IMG_1453_zpsyn4mklxj.jpg.html?sort=3&o=17 >> >> >> >> > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 28, 2016
Herb and all Do you guys know somthing I dont? Did BRS =C2-buy Second Cha ntz? I had a Second Chantz on my Firestar and they where about the only com pany that was competing with BRS =C2-So when I was flying there was no su ch thing as a Second Chaniz Brs =C2-they where two companies did they bec ome one? =C2-Just wanted to know if i missed something/ Chris =C2-Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly On Thursday, October 27, 2016 7:22 PM, Herb wrote: I went to their site and could not download the pages...kinda frustrating...but I will give it another try..I know it is an old unit and thought some of you guys might have good input...Herb On 10/27/2016 05:11 PM, Russ Kinne wrote: > > Herb - doesn=99t BRS know?? > >> On Oct 27, 2016, at 1:18 PM, Herb wrote: >> >> >> >> Anyone have an idea as to the age of this BRS?=C2- Took it out of a Z Max...and I am pretty sure it has been installed for more than 10 years...A ny details also.=C2- Herb >> >> http://s1248.photobucket.com/user/herbgh/media/IMG_1453_zpsyn4mklxj.jpg. html?sort=3&o=17 >> >> >> >> > > -- "Masculine republics give way to feminine democracies, and feminine democra cies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and w hat does it mean "A basket of deplorables"? "Are you unreedemable"? And" wh o is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Oct 27, 2016
The one I have is old and made by Second Chante...They are now back in business... Do not know anything about either company...Emails bounce to Second Chantz.. I would like to sell the one I have..but until I get some info..do not know how to price...Herb On 10/27/2016 09:41 PM, chris davis wrote: > Herb and all Do you guys know somthing I dont? Did BRS buy Second > Chantz? I had a Second Chantz on my Firestar and they where about the > only company that was competing with BRS So when I was flying there > was no such thing as a Second Chaniz Brs they where two companies did > they become one? Just wanted to know if i missed something/ Chris > > > Chris Davis > KXP 503 492 hrs > Glider Pilot > Disabled from crash building Firefly > > > On Thursday, October 27, 2016 7:22 PM, Herb wrote: > > > > > > I went to their site and could not download the pages...kinda > frustrating...but I will give it another try..I know it is an old unit > and thought some of you guys might have good input...Herb > > > On 10/27/2016 05:11 PM, Russ Kinne wrote: > > > > > > Herb - doesnt BRS know?? > > > >> On Oct 27, 2016, at 1:18 PM, Herb > wrote: > >> > > > >> > >> > >> Anyone have an idea as to the age of this BRS? Took it out of a Z > Max...and I am pretty sure it has been installed for more than 10 > years...Any details also. Herb > >> > >> > http://s1248.photobucket.com/user/herbgh/media/IMG_1453_zpsyn4mklxj.jpg.html?sort=3&o=17 > >> > >> > >> > >> > > > > > > > > > > > > -- > "Masculine republics give way to feminine democracies, and feminine > democracies give way to tyranny." > > Aristotle > > "Daddy, tell me...why are you going to the pig farm for a reeducation > and what does it mean "A basket of deplorables"? "Are you > unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's > GGgranddaughter... -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 27, 2016
I have one of the last original Second Chantz chutes ever sold, it is on my MKIII. There is a guy at Skydive Kentucky who still has the Second Chantz manuals and can repack it if you need. https://skydivekentucky.com/ -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461676#461676 ________________________________________________________________________________
Date: Oct 27, 2016
Richard did you see the one I have in the link? Look familiar ? The package is designed to fit in the turtle deck of a Z max that I have. The cords wrap around the landing gear.. I am only interested in selling. Just trying to develop some info...and a more than fair price..:-) Herb On 10/27/2016 10:16 PM, Richard Pike wrote: > > I have one of the last original Second Chantz chutes ever sold, it is on my MKIII. There is a guy at Skydive Kentucky who still has the Second Chantz manuals and can repack it if you need. > https://skydivekentucky.com/ > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Would you consider yourself to be a good person? > https://www.youtube.com/watch?v=VWcDXT6pH7A > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461676#461676 > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 27, 2016
The Ducati ignition system has a small inductive 'trigger' mounted behind the flywheel. There are no breaker points. -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461678#461678 ________________________________________________________________________________
Date: Oct 28, 2016
Yours looks smaller than mine. I bought mine when I bought my MKIII kit, it has a physically bigger bag and also a larger nitrogen bottle. Back in the dim recesses of my memory I seem to remember that Second Chantz selling your model, but don't remember anything useful. You got me curious, and I went digging around in my envelope of MKIII receipts. I spent $2050 for my Second Chantz. I also found the receipt from Kolb for my MKIII kit: $7020. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461681#461681 ________________________________________________________________________________
Date: Oct 28, 2016
Yep.. Mini Max...small...likely 600 lbs? I emailed Second Chantz and it bounced...called and got answering machine...We shall see...Not sure if I need to replace the canister and have a repack or just the repack? Herb On 10/28/2016 09:02 AM, Richard Pike wrote: > > Yours looks smaller than mine. I bought mine when I bought my MKIII kit, it has a physically bigger bag and also a larger nitrogen bottle. Back in the dim recesses of my memory I seem to remember that Second Chantz selling your model, but don't remember anything useful. > You got me curious, and I went digging around in my envelope of MKIII receipts. I spent $2050 for my Second Chantz. > I also found the receipt from Kolb for my MKIII kit: $7020. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Would you consider yourself to be a good person? > https://www.youtube.com/watch?v=VWcDXT6pH7A > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461681#461681 > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 28, 2016
Just got a call from Second Chantz...new rocket and repack is 1k...and he gave me instructions on how to remove the pyrotechnic from the rocket... Herb ps...guess I am up for a visit from the gubmint now...:-) On 10/28/2016 09:02 AM, Richard Pike wrote: > > Yours looks smaller than mine. I bought mine when I bought my MKIII kit, it has a physically bigger bag and also a larger nitrogen bottle. Back in the dim recesses of my memory I seem to remember that Second Chantz selling your model, but don't remember anything useful. > You got me curious, and I went digging around in my envelope of MKIII receipts. I spent $2050 for my Second Chantz. > I also found the receipt from Kolb for my MKIII kit: $7020. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Would you consider yourself to be a good person? > https://www.youtube.com/watch?v=VWcDXT6pH7A > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461681#461681 > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Subject: 5 and 6 inch tubing
Date: Oct 29, 2016
Wonder what quantity has to be bought..and what alloy? Cannot be 500 plus dollars for 20 feet! That would be a whole lot of Lettuce !! some one near by..go over and check out the dumpster! :-) Herb http://hastingsirrigation.com/node/13 ________________________________________________________________________________
Date: Oct 29, 2016
Subject: Re: 5 and 6 inch tubing
Herb- I don't see what alloy this stuff is made from, nor do I know what Kolb uses. I bought a new main tube from Kolb a few years ago, and don't recall what I paid. Bill Sullivan -------------------------------------------- On Sat, 10/29/16, Herb wrote: Subject: Kolb-List: 5 and 6 inch tubing To: kolb-list(at)matronics.com Date: Saturday, October 29, 2016, 12:55 PM Herb Wonder what quantity has to be bought..and what alloy? Cannot be 500 plus dollars for 20 feet! That would be a whole lot of Lettuce !! some one near by..go over and check out the dumpster! :-) Herb http://hastingsirrigation.com/node/13 Forum - - MATRONICS WEB FORUMS - MATRONICS LIST WIKI - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Oct 29, 2016
6063 T? as I recall? 20 foot length is over 500 bucks now.. Not sure the alloy of the wing spars...same I am pretty sure..Plenty strong...I am guessing that small quantities can be bought from them or an end user...Herb ps this link will make you guys with bent booms and spars salivate...:-) Herb http://www.mairrigation.com/aluminum-pipe---tubing.html On 10/29/2016 12:51 PM, william sullivan wrote: > > Herb- I don't see what alloy this stuff is made from, nor do I know what Kolb uses. I bought a new main tube from Kolb a few years ago, and don't recall what I paid. > > Bill Sullivan > -------------------------------------------- > On Sat, 10/29/16, Herb wrote: > > Subject: Kolb-List: 5 and 6 inch tubing > To: kolb-list(at)matronics.com > Date: Saturday, October 29, 2016, 12:55 PM > > Herb > > Wonder what quantity has to be bought..and what alloy? > Cannot be 500 > plus dollars for 20 feet! That would be a whole lot of > Lettuce !! > > some one near by..go over and check > out the dumpster! :-) Herb > > > > > > http://hastingsirrigation.com/node/13 > > Forum - > - MATRONICS WEB FORUMS - > MATRONICS LIST WIKI - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 29, 2016
I don't know what alloy it is, but it makes a great one piece hangar/shop door. 10' tall, 30' wide; counterbalanced for manual operation. If your state publishes an agricultural newsletter, look there for deals on used irrigation tubing. Charlie On 10/29/2016 12:51 PM, william sullivan wrote: > > Herb- I don't see what alloy this stuff is made from, nor do I know what Kolb uses. I bought a new main tube from Kolb a few years ago, and don't recall what I paid. > > Bill Sullivan > -------------------------------------------- > On Sat, 10/29/16, Herb wrote: > > Subject: Kolb-List: 5 and 6 inch tubing > To: kolb-list(at)matronics.com > Date: Saturday, October 29, 2016, 12:55 PM > > Herb > > Wonder what quantity has to be bought..and what alloy? > Cannot be 500 > plus dollars for 20 feet! That would be a whole lot of > Lettuce !! > > some one near by..go over and check > out the dumpster! :-) Herb > > ________________________________________________________________________________
Date: Oct 29, 2016
6061-T6 Jim Baker 405 426 5377 -----Original Message----- From: william sullivan <williamtsullivan(at)att.net> Sent: Sat, 29 Oct 2016 13:51 Subject: Re: Kolb-List: 5 and 6 inch tubing Herb- I don't see what alloy this stuff is made from, nor do I know what Kolb uses. I bought a new main tube from Kolb a few years ago, and don't recall what I paid. Bill Sullivan -------------------------------------------- On Sat, 10/29/16, Herb wrote: Subject: Kolb-List: 5 and 6 inch tubing To: kolb-list(at)matronics.com Date: Saturday, October 29, 2016, 12:55 PM Herb Wonder what quantity has to be bought..and what alloy? Cannot be 500 plus dollars for 20 feet! That would be a whole lot of Lettuce !! some one near by..go over and check out the dumpster! :-) Herb http://hastingsirrigation.com/node/13 Forum - - MATRONICS WEB FORUMS - MATRONICS LIST WIKI - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Oct 29, 2016
Betting that it is the same stuff as our spars and boom tubes are made from... Used...scratch and dent? ...might stay away from that...dollar and forty cents a foot.. so new must be on the order of 2 to 3 bucks a foot...!! Herb On 10/29/2016 03:36 PM, Charlie England wrote: > I don't know what alloy it is, but it makes a great one piece > hangar/shop door. 10' tall, 30' wide; counterbalanced for manual > operation. > > If your state publishes an agricultural newsletter, look there for > deals on used irrigation tubing. > > Charlie > > On 10/29/2016 12:51 PM, william sullivan wrote: >> >> >> Herb- I don't see what alloy this stuff is made from, nor do I >> know what Kolb uses. I bought a new main tube from Kolb a few years >> ago, and don't recall what I paid. >> >> Bill Sullivan >> -------------------------------------------- >> On Sat, 10/29/16, Herb wrote: >> >> Subject: Kolb-List: 5 and 6 inch tubing >> To: kolb-list(at)matronics.com >> Date: Saturday, October 29, 2016, 12:55 PM >> Herb >> Wonder what quantity has to be bought..and what alloy? >> Cannot be 500 >> plus dollars for 20 feet! That would be a whole lot of >> Lettuce !! >> some one near by..go over and check >> out the dumpster! :-) Herb >> > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 29, 2016
Very surprised...irrigation tubing does not need to be a quality alloy...I am pretty sure I heard that the spars and boom tubes were 6063 or something near that alloy...Herb On 10/29/2016 04:41 PM, Jim Baker wrote: > > 6061-T6 > > Jim Baker > 405 426 5377 > > -----Original Message----- > From: william sullivan <williamtsullivan(at)att.net> > To: kolb-list(at)matronics.com > Sent: Sat, 29 Oct 2016 13:51 > Subject: Re: Kolb-List: 5 and 6 inch tubing > > > Herb- I don't see what alloy this stuff is made from, nor do I know what Kolb uses. I bought a new main tube from Kolb a few years ago, and don't recall what I paid. > > Bill Sullivan > -------------------------------------------- > On Sat, 10/29/16, Herb wrote: > > Subject: Kolb-List: 5 and 6 inch tubing > To: kolb-list(at)matronics.com > Date: Saturday, October 29, 2016, 12:55 PM > > Herb > > Wonder what quantity has to be bought..and what alloy? > Cannot be 500 > plus dollars for 20 feet! That would be a whole lot of > Lettuce !! > > some one near by..go over and check > out the dumpster! :-) Herb > > > > > > http://hastingsirrigation.com/node/13 > > Forum - > - MATRONICS WEB FORUMS - > MATRONICS LIST WIKI - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 29, 2016
Pretty sure Kolbs are 6061. Center pivot irrigation stuff is generally marine grade 5052-H38 in extra thick wall types. Way too heavy for our applications. Jim Baker 405.426.5377 -----Original Message----- From: Herb <Herbgh(at)nctc.com> Sent: Sat, 29 Oct 2016 19:16 Subject: Re: Kolb-List: 5 and 6 inch tubing Very surprised...irrigation tubing does not need to be a quality alloy...I am pretty sure I heard that the spars and boom tubes were 6063 or something near that alloy...Herb On 10/29/2016 04:41 PM, Jim Baker wrote: > > 6061-T6 > > Jim Baker > 405 426 5377 > > -----Original Message----- > From: william sullivan <williamtsullivan(at)att.net> > To: kolb-list(at)matronics.com > Sent: Sat, 29 Oct 2016 13:51 > Subject: Re: Kolb-List: 5 and 6 inch tubing > > > Herb- I don't see what alloy this stuff is made from, nor do I know what Kolb uses. I bought a new main tube from Kolb a few years ago, and don't recall what I paid. > > Bill Sullivan > -------------------------------------------- > On Sat, 10/29/16, Herb wrote: > > Subject: Kolb-List: 5 and 6 inch tubing > To: kolb-list(at)matronics.com > Date: Saturday, October 29, 2016, 12:55 PM > > Herb > > Wonder what quantity has to be bought..and what alloy? > Cannot be 500 > plus dollars for 20 feet! That would be a whole lot of > Lettuce !! > > some one near by..go over and check > out the dumpster! :-) Herb > > > > > > http://hastingsirrigation.com/node/13 > > Forum - > - MATRONICS WEB FORUMS - > MATRONICS LIST WIKI - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 29, 2016
The sites showed some thin wall stuff... same as Kolb....058 and .051 or 052. as I recall...Kolb uses 6061 T6 tubing exclusively...but I do not think the spars and boom are? 6063 is not as strong...certainly... Herb On 10/29/2016 10:22 PM, jimbaker(at)npacc.net wrote: > > Pretty sure Kolbs are 6061. Center pivot irrigation stuff is generally marine grade 5052-H38 in extra thick wall types. Way too heavy for our applications. > > Jim Baker > 405.426.5377 > > -----Original Message----- > From: Herb <Herbgh(at)nctc.com> > To: kolb-list(at)matronics.com > Sent: Sat, 29 Oct 2016 19:16 > Subject: Re: Kolb-List: 5 and 6 inch tubing > > > Very surprised...irrigation tubing does not need to be a quality > alloy...I am pretty sure I heard that the spars and boom tubes were 6063 > or something near that alloy...Herb > > > On 10/29/2016 04:41 PM, Jim Baker wrote: >> >> 6061-T6 >> >> Jim Baker >> 405 426 5377 >> >> -----Original Message----- >> From: william sullivan <williamtsullivan(at)att.net> >> To: kolb-list(at)matronics.com >> Sent: Sat, 29 Oct 2016 13:51 >> Subject: Re: Kolb-List: 5 and 6 inch tubing >> >> >> Herb- I don't see what alloy this stuff is made from, nor do I know what Kolb uses. I bought a new main tube from Kolb a few years ago, and don't recall what I paid. >> >> Bill Sullivan >> -------------------------------------------- >> On Sat, 10/29/16, Herb wrote: >> >> Subject: Kolb-List: 5 and 6 inch tubing >> To: kolb-list(at)matronics.com >> Date: Saturday, October 29, 2016, 12:55 PM >> >> Herb >> >> Wonder what quantity has to be bought..and what alloy? >> Cannot be 500 >> plus dollars for 20 feet! That would be a whole lot of >> Lettuce !! >> >> some one near by..go over and check >> out the dumpster! :-) Herb >> >> >> >> >> >> http://hastingsirrigation.com/node/13 >> >> Forum - >> - MATRONICS WEB FORUMS - >> MATRONICS LIST WIKI - >> List Contribution Web Site - >> -Matt >> Dralle, List Admin. >> >> >> >> >> >> >> >> >> >> >> >> >> >> -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 30, 2016
SO a irrigation tube or3 would make For a good door beam frame in the pivot and lift =C2-style?=C2-Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.comLSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022=C2-=C2-=C2-=C2- On Sunday, October 30, 2016 12:53 AM, Herb wrote: The sites showed some thin wall stuff...=C2- same as Kolb....058 and .051 or 052.=C2- as I recall...Kolb uses 6061 T6=C2- tubing exclusively...bu t I do not think the spars and boom are? 6063 is not as strong...certainly... Herb On 10/29/2016 10:22 PM, jimbaker(at)npacc.net wrote: > > Pretty sure Kolbs are 6061. Center pivot irrigation stuff is generally ma rine grade 5052-H38 in extra thick wall types. Way too heavy for our applic ations. > > Jim Baker > 405.426.5377 > > -----Original Message----- > From: Herb <Herbgh(at)nctc.com> > To: kolb-list(at)matronics.com > Sent: Sat, 29 Oct 2016 19:16 > Subject: Re: Kolb-List: 5 and 6 inch tubing > > > Very surprised...irrigation tubing does not need to be a quality > alloy...I am pretty sure I heard that the spars and boom tubes were 6063 > or something near that alloy...Herb > > > On 10/29/2016 04:41 PM, Jim Baker wrote: >> >> 6061-T6 >> >> Jim Baker >> 405 426 5377 >> >> -----Original Message----- >> From: william sullivan <williamtsullivan(at)att.net> >> To: kolb-list(at)matronics.com >> Sent: Sat, 29 Oct 2016 13:51 >> Subject: Re: Kolb-List: 5 and 6 inch tubing >> net> >> >>=C2- =C2- Herb- I don't see what alloy this stuff is made from, nor d o I know what Kolb uses.=C2- I bought a new main tube from Kolb a few yea rs ago, and don't recall what I paid. >> >>=C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2 - =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- Bill Sulliva n >> -------------------------------------------- >> On Sat, 10/29/16, Herb wrote: >> >>=C2- =C2- Subject: Kolb-List: 5 and 6 inch tubing >>=C2- =C2- To: kolb-list(at)matronics.com >>=C2- =C2- Date: Saturday, October 29, 2016, 12:55 PM >>=C2- =C2- >>=C2- =C2- Herb >>=C2- =C2- >>=C2- =C2- Wonder what quantity has to be bought..and what alloy? >>=C2- =C2- Cannot be 500 >>=C2- =C2- plus dollars for 20 feet!=C2- That would be a whole lot o f >>=C2- =C2- Lettuce !! >>=C2- =C2- >>=C2- =C2- =C2- some one=C2- near by..go over and check >>=C2- =C2- out the dumpster! :-) Herb >>=C2- =C2- >>=C2- =C2- >>=C2- =C2- >>=C2- =C2- >>=C2- =C2- >>=C2- =C2- http://hastingsirrigation.com/node/13 >>=C2- =C2- >>=C2- =C2- Forum - >>=C2- =C2- =C2- - MATRONICS WEB FORUMS - >>=C2- =C2- MATRONICS LIST WIKI - >>=C2- =C2- List Contribution Web Site - >>=C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- -Matt >>=C2- =C2- Dralle, List Admin. >>=C2- =C2- >>=C2- =C2- >>=C2- =C2- >>=C2- =C2- >> >> >> >> >> >> >> >> >> >> -- "Masculine republics give way to feminine democracies, and feminine democra cies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and w hat does it mean "A basket of deplorables"? "Are you unreedemable"? And" wh o is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Oct 30, 2016
https://en.m.wikipedia.org/wiki/5052_aluminium_alloy If you're looking for strength and weldability, as long as you can verify the alloy series, 5052 should work well in a structural setting. Jim Baker 405 426 5377 -----Original Message----- From: Malcolm Brubaker <brubakermal(at)yahoo.com> Sent: Sun, 30 Oct 2016 6:42 Subject: Re: Kolb-List: 5 and 6 inch tubing ------=_Part_571230_631422605.1477824138294 Content-Type: text/plain; charset=UTF-8 Content-Transfer-Encoding: quoted-printable SO a irrigation tube or3 would make For a good door beam frame in the pivot and lift =C2-style?=C2-Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.comLSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022=C2-=C2-=C2-=C2- On Sunday, October 30, 2016 12:53 AM, Herb wrote: The sites showed some thin wall stuff...=C2- same as Kolb....058 and .051 or 052.=C2- as I recall...Kolb uses 6061 T6=C2- tubing exclusively...bu t I do not think the spars and boom are? 6063 is not as strong...certainly... Herb On 10/29/2016 10:22 PM, jimbaker(at)npacc.net wrote: > > Pretty sure Kolbs are 6061. Center pivot irrigation stuff is generally ma rine grade 5052-H38 in extra thick wall types. Way too heavy for our applic ations. > > Jim Baker > 405.426.5377 > > -----Original Message----- > From: Herb <Herbgh(at)nctc.com> > To: kolb-list(at)matronics.com > Sent: Sat, 29 Oct 2016 19:16 > Subject: Re: Kolb-List: 5 and 6 inch tubing > > > Very surprised...irrigation tubing does not need to be a quality > alloy...I am pretty sure I heard that the spars and boom tubes were 6063 > or something near that alloy...Herb > > > On 10/29/2016 04:41 PM, Jim Baker wrote: >> >> 6061-T6 >> >> Jim Baker >> 405 426 5377 >> >> -----Original Message----- >> From: william sullivan <williamtsullivan(at)att.net> >> To: kolb-list(at)matronics.com >> Sent: Sat, 29 Oct 2016 13:51 >> Subject: Re: Kolb-List: 5 and 6 inch tubing >> net> >> >>=C2- =C2- Herb- I don't see what alloy this stuff is made from, nor d o I know what Kolb uses.=C2- I bought a new main tube from Kolb a few yea rs ago, and don't recall what I paid. >> >>=C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2 - =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- Bill Sulliva n >> -------------------------------------------- >> On Sat, 10/29/16, Herb wrote: >> >>=C2- =C2- Subject: Kolb-List: 5 and 6 inch tubing >>=C2- =C2- To: kolb-list(at)matronics.com >>=C2- =C2- Date: Saturday, October 29, 2016, 12:55 PM >>=C2- =C2- >>=C2- =C2- Herb >>=C2- =C2- >>=C2- =C2- Wonder what quantity has to be bought..and what alloy? >>=C2- =C2- Cannot be 500 >>=C2- =C2- plus dollars for 20 feet!=C2- That would be a whole lot o f >>=C2- =C2- Lettuce !! >>=C2- =C2- >>=C2- =C2- =C2- some one=C2- near by..go over and check >>=C2- =C2- out the dumpster! :-) Herb >>=C2- =C2- >>=C2- =C2- >>=C2- =C2- >>=C2- =C2- >>=C2- =C2- >>=C2- =C2- http://hastingsirrigation.com/node/13 >>=C2- =C2- >>=C2- =C2- Forum - >>=C2- =C2- =C2- - MATRONICS WEB FORUMS - >>=C2- =C2- MATRONICS LIST WIKI - >>=C2- =C2- List Contribution Web Site - >>=C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- -Matt >>=C2- =C2- Dralle, List Admin. >>=C2- =C2- >>=C2- =C2- >>=C2- =C2- >>=C2- =C2- >> >> >> >> >> >> >> >> >> >> -- "Masculine republics give way to feminine democracies, and feminine democra cies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and w hat does it mean "A basket of deplorables"? "Are you unreedemable"? And" wh o is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ------=_Part_571230_631422605.1477824138294 Content-Type: text/html; charset=UTF-8 Content-Transfer-Encoding: quoted-printable
SO a irrigation tube or3 would make For a good door beam frame in the pivot and lift  style?
Malcolm & Jeanne Brubaker < br>Michigan Sport Pilot Repair
L SRM-A, PPC, WS
for Ultralight & Light Sp ort
(989)513-3022
&nb sp;
On Sunday, October 30, 2016 12:53 AM, Herb <Herbgh@nctc .com> wrote:
- -> Kolb-List message posted by: Herb <Herbgh(at)nctc.com>
The s ites showed some thin wall stuff...  same as Kolb....058 and .051
or 052.  as I recall...Kolb uses 6061 T6  tubing exclusively...bu t I do
not think the spars and boom are? 6063 is not as strong...certai nly... Herb
On 10/29/2016 10:22 PM, jimbaker(at)npacc.net wrot e:
> --> Kolb-List message posted by: jimbaker(at)npacc.net
& gt;
> Pretty sure Kolbs are 6061. Center pivot irrigation stuff is ge nerally marine grade 5052-H38 in extra thick wall types. Way too heavy for our applications.
> Jim Baker
> 405.426.5377
Herbgh(at)nctc.com>< br>> To: kolb-list(at)matronics.com
> Sent: Sat, 29 Oc t 2016 19:16
> --> Kolb-List message posted by: Herb <Herbgh(at)nctc.com>
&g t;
> alloy...I am pretty sure I heard that the spars and boom tubes wer e 6063
>> --> Kolb-List messa ge posted by: Jim Baker <jimbaker(at)npacc.net>
&g t;> 6061-T6
>> Jim Baker
>> 405 426 5377williamtsullivan(at)att.net>
>>>> --> Kolb-List message posted by: william sullivan <williamtsullivan(at)att.net>
>>    Herb- I don't see what alloy this stuff is made from, nor do I know what Kolb uses.  I bought a new main tube from Kolb a few years ago, and do n't recall what I paid.
>>                              ;                     &nb sp;         Bill Sullivan
>>    To: kolb-list@matr onics.com
>>    Date: Saturday, October 29, 2016, 12 :55 PM
>>    Cannot be 500
>& gt;    plus dollars for 20 feet!  That would be a whole lot of
>>    Lettuce !!
>> ;      some one  near by..go over and check
>> ;    out the dumpster! :-) Herb
& gt;>
>>    http://hastingsirrigation.com/node/ 13
>>    Forum -
>&g t;      - MATRONICS WEB FORUMS -
>>    M ATRONICS LIST WIKI -
>>    List Contribution Web Site -< br>>>                  - Matt
>>    Dralle, List Admin.
>>  &nbs p;
"Masculine r epublics give way to feminine democracies, and feminine democracies give wa y to tyranny."
Aristotle
"Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplor ables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Tw or?Kolb-List" target="_blank">http://www.matronics.com/Navigator?Kolb-Lis > http://foru               - NEW MATRONICS LIST WIKI --> http://wiki                       tronics.com/contribution" target="_blank">http://www.matronics.com/contri ================
------=_Part_571230_631422605.1477824138294--
------=_Part_571230_631422605.1477824138294-- ________________________________________________________________________________
Date: Oct 30, 2016
Anyone who is suggesting the use of industrial, irrigation, or plumbing parts as a straight-across substitute for the materials thatw ere specified in the original engineering DAMN well better have the engineering ability and qualifications to back it up. The person suggesting 5052 as an equivalent material... can you provide the engineering basis or qualifications for making that statement please? If my suspicions are correct (maybe yes, maybe no), I need to nip this in the bud right here and now. There is no need for any welding on the Kolb spars or fuselage tube, so a "weldable" alloy has no advantage whatsoever. "Durable" is also a very misleading term. Pure aluminium (1100 series) is "durable" because it is highly corrosion resistant. It also has very very little strength, stiffness, and load-carrying ability. So if you build an airplane out of any old "durable" materials, your wing spar could break, but the broken piece would be nice and shiny and rust-free for the funeral. 7075 alloy (develkoped for the B-29 bomber in WW2) is not very resistant to corrosion, but it is the strongest of the normal aluminum alloys. So you have to take better care of it corrosion wise, but you will have a wing spar that can take a LOT more G loads before breaking, and causing the funeral. I don't know about any of you guys, but I've been to way too many !(#*$ funerals in aviation,and if I can prevent one more needless funeral by opening up my great big mouth here then I sure as heck will. An average non-engineer homebuilder (like me) CANNOT make decisions to substitute materials in the majority of cases. There are some of us with some amount of experience, who may have have learned anough from the real engineers to make a few basic decisions conservatively. But not for wing spars and fuselage tailbooms. As a GENERAL rule in aviation, you can USUALLY substitute 2024-T3 for 6061-T6 and have higher strength and equal stiffness. But there are even plenty of exceptions to this, because you cannot weld 2024-T3 very well. So if you are welding, you are usually stuck with the 6061. When you weld it you lose the majority of the stiffness (resistance to bending under load), and you essentially have a casting instead of a heat treated material. You CANNOT substitute 6061 for 2024, you lose strength. I also believe you cannot substitute 5052 for 6061, because you lose strength. You cannot substitute 2024 for 7075, because 7075 is quite a bit stronger/stiffer than even 2024 "airplane" alloy. Again, I am not a trained aircraft structures engineer. But substituting 5052 for 6061 or 6063 alloy SEEMS to be wrong to me. Any real, trained strctural engineers here on this forum can feel free to correct me. ________________________________________________________________________________
Date: Oct 30, 2016
Here's an idea. Call Brian at TNK and order the tubing you want. I know we all want to save money. However, paying a little more to support TNK and get tubing that works seems like a reasonable thing to me. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461745#461745 ________________________________________________________________________________
Date: Oct 30, 2016
U2ltcGx5IHRoaXMuLi4uCgpXYXMgdGhlIHBlcnNvbiBtYWtpbmcgdGhlIGVucXVpcnkgYXNraW5n IGFib3V0IGFsdW1pbnVtIHN1aXRhYmxlIGZvciBhIG5vbi1haXJjcmFmdCBzdHJ1Y3R1cmFsIHVz ZSBvciBub3Q/IEkgZGlkbid0IHNlZSBhbnkgbWVudGlvbiBvZiBhaXJjcmFmdCBzdHJ1Y3R1cmFs IHVzZS4gVGhlcmUgd2FzIG5vIHN1Z2dlc3Rpb24gdGhhdCBhbnkgb3RoZXIgbWF0ZXJpYWwgZ3Jh ZGUgc2hvdWxkIGJlIHVzZWQgYXMgc3VjaC4KCkppbSBCYWtlcgo0MDUgNDI2IDUzNzcKCi0tLS0t T3JpZ2luYWwgTWVzc2FnZS0tLS0tCkZyb206IEJpbGwgQmVybGUgPHZpY3RvcmJyYXZvQHNiY2ds b2JhbC5uZXQ+ClRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQpTZW50OiBTdW4sIDMwIE9jdCAy MDE2IDE2OjU5ClN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IDUgYW5kIDYgaW5jaCB0dWJpbmcKCi0t PiBLb2xiLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IEJpbGwgQmVybGUgPHZpY3RvcmJyYXZvQHNi Y2dsb2JhbC5uZXQ+CgpBbnlvbmUgd2hvIGlzIHN1Z2dlc3RpbmcgdGhlIHVzZSBvZiBpbmR1c3Ry aWFsLCBpcnJpZ2F0aW9uLCBvciBwbHVtYmluZyBwYXJ0cyBhcyBhIHN0cmFpZ2h0LWFjcm9zcyBz dWJzdGl0dXRlIGZvciB0aGUgbWF0ZXJpYWxzIHRoYXR3IGVyZSBzcGVjaWZpZWQgaW4gdGhlIG9y aWdpbmFsIGVuZ2luZWVyaW5nIERBTU4gd2VsbCBiZXR0ZXIgaGF2ZSB0aGUgZW5naW5lZXJpbmcg YWJpbGl0eSBhbmQgcXVhbGlmaWNhdGlvbnMgdG8gYmFjayBpdCB1cC4gCgpUaGUgcGVyc29uIHN1 Z2dlc3RpbmcgNTA1MiBhcyBhbiBlcXVpdmFsZW50IG1hdGVyaWFsLi4uIGNhbiB5b3UgcHJvdmlk ZSB0aGUgZW5naW5lZXJpbmcgYmFzaXMgb3IgcXVhbGlmaWNhdGlvbnMgZm9yIG1ha2luZyB0aGF0 IHN0YXRlbWVudCBwbGVhc2U/IElmIG15IHN1c3BpY2lvbnMgYXJlIGNvcnJlY3QgKG1heWJlIHll cywgbWF5YmUgbm8pLCBJIG5lZWQgdG8gbmlwIHRoaXMgaW4gdGhlIGJ1ZCByaWdodCBoZXJlIGFu ZCBub3cuIAoKVGhlcmUgaXMgbm8gbmVlZCBmb3IgYW55IHdlbGRpbmcgb24gdGhlIEtvbGIgc3Bh cnMgb3IgZnVzZWxhZ2UgdHViZSwgc28gYSAid2VsZGFibGUiIGFsbG95IGhhcyBubyBhZHZhbnRh Z2Ugd2hhdHNvZXZlci4gIkR1cmFibGUiIGlzIGFsc28gYSB2ZXJ5IG1pc2xlYWRpbmcgdGVybS4g UHVyZSBhbHVtaW5pdW0gKDExMDAgc2VyaWVzKSBpcyAiZHVyYWJsZSIgYmVjYXVzZSBpdCBpcyBo aWdobHkgY29ycm9zaW9uIHJlc2lzdGFudC4gSXQgYWxzbyBoYXMgdmVyeSB2ZXJ5IGxpdHRsZSBz dHJlbmd0aCwgc3RpZmZuZXNzLCBhbmQgbG9hZC1jYXJyeWluZyBhYmlsaXR5LiBTbyBpZiB5b3Ug YnVpbGQgYW4gYWlycGxhbmUgb3V0IG9mIGFueSBvbGQgImR1cmFibGUiIG1hdGVyaWFscywgeW91 ciB3aW5nIHNwYXIgY291bGQgYnJlYWssIGJ1dCB0aGUgYnJva2VuIHBpZWNlIHdvdWxkIGJlIG5p Y2UgYW5kIHNoaW55IGFuZCBydXN0LWZyZWUgZm9yIHRoZSBmdW5lcmFsLiA3MDc1IGFsbG95IChk ZXZlbGtvcGVkIGZvciB0aGUgQi0yOSBib21iZXIgaW4gV1cyKSBpcyBub3QgdmVyeSByZXNpc3Rh bnQgdG8gY29ycm9zaW9uLCBidXQgaXQgaXMgdGhlIHN0cm9uZ2VzdCBvZiB0aGUgbm9ybWFsIGFs dW1pbnVtIGFsbG95cy4gU28geW91IGhhdmUgdG8gdGFrZSBiZXR0ZXIgY2FyZSBvZiBpdCBjb3Jy b3Npb24gd2lzZSwgYnV0IHlvdSB3aWxsIGhhdmUgYSB3aW5nIHNwYXIgdGhhdCBjYW4gdGFrZSBh IExPVCBtb3JlIEcgbG9hZHMgYmVmb3JlIGJyZWFraW5nLCBhbmQgY2F1c2luZyB0aGUgZnVuZXJh bC4gSSBkb24ndCBrbm93IGFib3V0IGFueSBvZiB5b3UgZ3V5cywgYnV0IEkndmUgYmVlbiB0byB3 YXkgdG9vIG1hbnkgISgjKiQgZnVuZXJhbHMgaW4gYXZpYXRpb24sYW5kIGlmIEkgY2FuIHByZXZl bnQgb25lIG1vcmUgbmVlZGxlc3MgZnVuZXJhbCBieSBvcGVuaW5nIHVwIG15IGdyZWF0IGJpZyBt b3V0aCBoZXJlIHRoZW4gSSBzdXJlIGFzIGhlY2sgCiB3aWxsLgoKQW4gYXZlcmFnZSBub24tZW5n aW5lZXIgaG9tZWJ1aWxkZXIgKGxpa2UgbWUpIENBTk5PVCBtYWtlIGRlY2lzaW9ucyB0byBzdWJz dGl0dXRlIG1hdGVyaWFscyBpbiB0aGUgbWFqb3JpdHkgb2YgY2FzZXMuIFRoZXJlIGFyZSBzb21l IG9mIHVzIHdpdGggc29tZSBhbW91bnQgb2YgZXhwZXJpZW5jZSwgd2hvIG1heSBoYXZlIGhhdmUg bGVhcm5lZCBhbm91Z2ggZnJvbSB0aGUgcmVhbCBlbmdpbmVlcnMgdG8gbWFrZSBhIGZldyBiYXNp YyBkZWNpc2lvbnMgY29uc2VydmF0aXZlbHkuIEJ1dCBub3QgZm9yIHdpbmcgc3BhcnMgYW5kIGZ1 c2VsYWdlIHRhaWxib29tcy4KCkFzIGEgR0VORVJBTCBydWxlIGluIGF2aWF0aW9uLCB5b3UgY2Fu IFVTVUFMTFkgc3Vic3RpdHV0ZSAyMDI0LVQzIGZvciA2MDYxLVQ2IGFuZCBoYXZlIGhpZ2hlciBz dHJlbmd0aCBhbmQgZXF1YWwgc3RpZmZuZXNzLiBCdXQgdGhlcmUgYXJlIGV2ZW4gcGxlbnR5IG9m IGV4Y2VwdGlvbnMgdG8gdGhpcywgYmVjYXVzZSB5b3UgY2Fubm90IHdlbGQgMjAyNC1UMyB2ZXJ5 IHdlbGwuIFNvIGlmIHlvdSBhcmUgd2VsZGluZywgeW91IGFyZSB1c3VhbGx5IHN0dWNrIHdpdGgg dGhlIDYwNjEuIFdoZW4geW91IHdlbGQgaXQgeW91IGxvc2UgdGhlIG1ham9yaXR5IG9mIHRoZSBz dGlmZm5lc3MgKHJlc2lzdGFuY2UgdG8gYmVuZGluZyB1bmRlciBsb2FkKSwgYW5kIHlvdSBlc3Nl bnRpYWxseSBoYXZlIGEgY2FzdGluZyBpbnN0ZWFkIG9mIGEgaGVhdCB0cmVhdGVkIG1hdGVyaWFs LgoKWW91IENBTk5PVCBzdWJzdGl0dXRlIDYwNjEgZm9yIDIwMjQsIHlvdSBsb3NlIHN0cmVuZ3Ro LiBJIGFsc28gYmVsaWV2ZSB5b3UgY2Fubm90IHN1YnN0aXR1dGUgNTA1MiBmb3IgNjA2MSwgYmVj YXVzZSB5b3UgbG9zZSBzdHJlbmd0aC4gWW91IGNhbm5vdCBzdWJzdGl0dXRlIDIwMjQgZm9yIDcw NzUsIGJlY2F1c2UgNzA3NSBpcyBxdWl0ZSBhIGJpdCBzdHJvbmdlci9zdGlmZmVyIHRoYW4gZXZl biAyMDI0ICJhaXJwbGFuZSIgYWxsb3kuCgpBZ2FpbiwgSSBhbSBub3QgYSB0cmFpbmVkIGFpcmNy YWZ0IHN0cnVjdHVyZXMgZW5naW5lZXIuIEJ1dCBzdWJzdGl0dXRpbmcgNTA1MiBmb3IgNjA2MSBv ciA2MDYzIGFsbG95IFNFRU1TIHRvIGJlIHdyb25nIHRvIG1lLiBBbnkgcmVhbCwgdHJhaW5lZCBz dHJjdHVyYWwgZW5naW5lZXJzIGhlcmUgb24gdGhpcyBmb3J1bSBjYW4gZmVlbCBmcmVlIHRvIGNv cnJlY3QgbWUuCgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgLSBUaGUgS29sYi1MaXN0IEVtYWlsIEZvcnVt IC0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dz ZQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlv biwKXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFR LApfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOgpfLT0KXy09ICAgLS0+IGh0dHA6 Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0Cl8tPQpfLT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAg ICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVu dCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gICAtLT4gaHR0cDov L2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgIC0gTkVXIE1B VFJPTklDUyBMSVNUIFdJS0kgLQpfLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNzIEVt YWlsIExpc3QgV2lraSEKXy09ICAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb20KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0K Xy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQpfLT0gIFRoYW5r IHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT0gICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1h dHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CgoKCgo ________________________________________________________________________________
Date: Oct 30, 2016
Yer wraped around the axle for no reason. The initial conversation was about alum tubing suitable for a hangar/hangar door, not for an aircraft. Geez. Jim Baker 405 426 5377 -----Original Message----- From: Bill Berle <victorbravo(at)sbcglobal.net> Sent: Sun, 30 Oct 2016 16:59 Subject: Re: Kolb-List: 5 and 6 inch tubing Anyone who is suggesting the use of industrial, irrigation, or plumbing parts as a straight-across substitute for the materials thatw ere specified in the original engineering DAMN well better have the engineering ability and qualifications to back it up. The person suggesting 5052 as an equivalent material... can you provide the engineering basis or qualifications for making that statement please? If my suspicions are correct (maybe yes, maybe no), I need to nip this in the bud right here and now. There is no need for any welding on the Kolb spars or fuselage tube, so a "weldable" alloy has no advantage whatsoever. "Durable" is also a very misleading term. Pure aluminium (1100 series) is "durable" because it is highly corrosion resistant. It also has very very little strength, stiffness, and load-carrying ability. So if you build an airplane out of any old "durable" materials, your wing spar could break, but the broken piece would be nice and shiny and rust-free for the funeral. 7075 alloy (develkoped for the B-29 bomber in WW2) is not very resistant to corrosion, but it is the strongest of the normal aluminum alloys. So you have to take better care of it corrosion wise, but you will have a wing spar that can take a LOT more G loads before breaking, and causing the funeral. I don't know about any of you guys, but I've been to way too many !(#*$ funerals in aviation,and if I can prevent one more needless funeral by opening up my great big mouth here then I sure as heck will. An average non-engineer homebuilder (like me) CANNOT make decisions to substitute materials in the majority of cases. There are some of us with some amount of experience, who may have have learned anough from the real engineers to make a few basic decisions conservatively. But not for wing spars and fuselage tailbooms. As a GENERAL rule in aviation, you can USUALLY substitute 2024-T3 for 6061-T6 and have higher strength and equal stiffness. But there are even plenty of exceptions to this, because you cannot weld 2024-T3 very well. So if you are welding, you are usually stuck with the 6061. When you weld it you lose the majority of the stiffness (resistance to bending under load), and you essentially have a casting instead of a heat treated material. You CANNOT substitute 6061 for 2024, you lose strength. I also believe you cannot substitute 5052 for 6061, because you lose strength. You cannot substitute 2024 for 7075, because 7075 is quite a bit stronger/stiffer than even 2024 "airplane" alloy. Again, I am not a trained aircraft structures engineer. But substituting 5052 for 6061 or 6063 alloy SEEMS to be wrong to me. Any real, trained strctural engineers here on this forum can feel free to correct me. ________________________________________________________________________________
Date: Oct 30, 2016
I may have started the discussion...it is a discussion? right? Inquiring minds want to know... Way back in the dark recesses of my brain...I seem to recall that the spars and boom are not 6061 T6.. but 6063...t651 ...from memory..could be and likely am wrong...said so to the list...nothing wrong with that ...right?? Hoping someone would have the answer... I know ...call Bryan.....:-) Not advocating anything except good common sense... and it works this way...I am my own business...operate to always be in the black...and if I send 500+ dollars to anyone..when I could buy for half or less..then my good business sense says to do it... I make charitable contributions because I am in the black......to childrens hospitals and the like. but not to a business..as much as I like that particular business...In the end...a business must stand on its own profit and loss statement...and bottom line... Right??? Herb On 10/30/2016 05:42 PM, Jim Baker wrote: > > Yer wraped around the axle for no reason. The initial conversation was about alum tubing suitable for a hangar/hangar door, not for an aircraft. > > Geez. > > Jim Baker > 405 426 5377 > > -----Original Message----- > From: Bill Berle <victorbravo(at)sbcglobal.net> > To: kolb-list(at)matronics.com > Sent: Sun, 30 Oct 2016 16:59 > Subject: Re: Kolb-List: 5 and 6 inch tubing > > > Anyone who is suggesting the use of industrial, irrigation, or plumbing parts as a straight-across substitute for the materials thatw ere specified in the original engineering DAMN well better have the engineering ability and qualifications to back it up. > > The person suggesting 5052 as an equivalent material... can you provide the engineering basis or qualifications for making that statement please? If my suspicions are correct (maybe yes, maybe no), I need to nip this in the bud right here and now. > > There is no need for any welding on the Kolb spars or fuselage tube, so a "weldable" alloy has no advantage whatsoever. "Durable" is also a very misleading term. Pure aluminium (1100 series) is "durable" because it is highly corrosion resistant. It also has very very little strength, stiffness, and load-carrying ability. So if you build an airplane out of any old "durable" materials, your wing spar could break, but the broken piece would be nice and shiny and rust-free for the funeral. 7075 alloy (develkoped for the B-29 bomber in WW2) is not very resistant to corrosion, but it is the strongest of the normal aluminum alloys. So you have to take better care of it corrosion wise, but you will have a wing spar that can take a LOT more G loads before breaking, and causing the funeral. I don't know about any of you guys, but I've been to way too many !(#*$ funerals in aviation,and if I can prevent one more needless funeral by opening up my great big mouth here then I sure as heck > > will. > > An average non-engineer homebuilder (like me) CANNOT make decisions to substitute materials in the majority of cases. There are some of us with some amount of experience, who may have have learned anough from the real engineers to make a few basic decisions conservatively. But not for wing spars and fuselage tailbooms. > > As a GENERAL rule in aviation, you can USUALLY substitute 2024-T3 for 6061-T6 and have higher strength and equal stiffness. But there are even plenty of exceptions to this, because you cannot weld 2024-T3 very well. So if you are welding, you are usually stuck with the 6061. When you weld it you lose the majority of the stiffness (resistance to bending under load), and you essentially have a casting instead of a heat treated material. > > You CANNOT substitute 6061 for 2024, you lose strength. I also believe you cannot substitute 5052 for 6061, because you lose strength. You cannot substitute 2024 for 7075, because 7075 is quite a bit stronger/stiffer than even 2024 "airplane" alloy. > > Again, I am not a trained aircraft structures engineer. But substituting 5052 for 6061 or 6063 alloy SEEMS to be wrong to me. Any real, trained strctural engineers here on this forum can feel free to correct me. > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 30, 2016
Thanks for posting your comments below, Rex. Folks, the only thing that keeps Kolb Aircraft alive is us few that still support them. They are an extremely small company with shallow pockets. What they have, parts to keep our aging aircraft alive, will disappear if they do not continue to stay in business. Support Kolb Aircraft. Besides, you won't meet finer folks anywhere. john h mkIII El Centro, California ---- Rex Rodebush wrote: > > Here's an idea. Call Brian at TNK and order the tubing you want. I know we all want to save money. However, paying a little more to support TNK and get tubing that works seems like a reasonable thing to me. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461745#461745 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 30, 2016
...I am pretty sure I heard that the spars and boom tubes were 6063 or something near that alloy...Herb Herb/Kolbers: 5 and 6 inch booms and spars are drawn for irrigation pipe. They are 6061 T-6 .058" wall. Biggest problem for Kolb is finding tubes that do not have dents and scratches. That tubing is not handled with kid gloves once it is manufactured. I remember the Kolb Gang going to the factory and going through many, many tubes to find the "good" ones. The 6061 is probably used for circle irrigation systems because of the increased strength required to keep the system together. The "el cheapo" non-spec'd tubing is probably used for systems that are laid out on the ground and not mobile. john h mkIII El Centro, California ________________________________________________________________________________
Date: Oct 30, 2016
Didn't pick up that the tubing was for a garage door. Not sure what a garage door has to do with Kolb aircraft. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461751#461751 ________________________________________________________________________________
Date: Oct 30, 2016
I went to the barn and looked at all of my 5 inch tubes that I bought from Kolb many years back..they had a trailer full of scratch and dents..None had the typical rolled on alloy identification. .Travis explained that they were perfectly good but if they sent a spar or boom to a customer, it had to be perfect...so..I bought quite a few of them.. Stayed away from scratches and bought those with small dents.. dollar a foot...wish I had bought more.. By the way...I have a good set of Firefly spars...I went with single lift struts,ala firestar, on my first Firefly...unfortunately...all the holes are drilled for the ribs...no extra charge...:-) 6061 T6 it is...!! :-) who would have thought...25 or so dollars a foot!! Herb On 10/30/2016 06:50 PM, jhauck(at)elmore.rr.com wrote: > > > ...I am pretty sure I heard that the spars and boom tubes were 6063 or something near that alloy...Herb > > > Herb/Kolbers: > > 5 and 6 inch booms and spars are drawn for irrigation pipe. They are 6061 T-6 .058" wall. > > Biggest problem for Kolb is finding tubes that do not have dents and scratches. That tubing is not handled with kid gloves once it is manufactured. I remember the Kolb Gang going to the factory and going through many, many tubes to find the "good" ones. > > The 6061 is probably used for circle irrigation systems because of the increased strength required to keep the system together. The "el cheapo" non-spec'd tubing is probably used for systems that are laid out on the ground and not mobile. > > > john h > mkIII > El Centro, California > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Oct 30, 2016
On 10/30/2016 7:11 PM, Rex Rodebush wrote: > > Didn't pick up that the tubing was for a garage door. Not sure what a garage door has to do with Kolb aircraft. > > I don't remember what the original subject was, but I doubt it was about garage doors. That was probably my fault. I posted a pic of the hangar door I built using irrigation tubing; intended as a joking response to the question about strength of irrigation tubing. I'd never recommend using used ag products as aircraft structure. But as John pointed out, the irrigation tubing is pretty strong. What does a 30 foot long 6" diameter tube of water weigh? Charlie ________________________________________________________________________________
Date: Oct 30, 2016
365.7 pounds. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Sunday, October 30, 2016 7:59 PM Subject: Re: Kolb-List: Re: 5 and 6 inch tubing On 10/30/2016 7:11 PM, Rex Rodebush wrote: > > Didn't pick up that the tubing was for a garage door. Not sure what a garage door has to do with Kolb aircraft. > > I don't remember what the original subject was, but I doubt it was about garage doors. That was probably my fault. I posted a pic of the hangar door I built using irrigation tubing; intended as a joking response to the question about strength of irrigation tubing. I'd never recommend using used ag products as aircraft structure. But as John pointed out, the irrigation tubing is pretty strong. What does a 30 foot long 6" diameter tube of water weigh? Charlie ________________________________________________________________________________
Subject: RE: Kolb-List Digest: 9 Msgs - 10/29/16
Date: Oct 31, 2016
> Wonder what quantity has to be bought..and what alloy? Cannot be 500 plus dollars for 20 feet! My bud here in Fresno CA went out of business and has lots of various things in his shop. He has several tubes- I think exactly what Kolb used- and he wants to get rid of the stuff. MUCH cheaper than new, yet this has been stored inside since he bought it new. I don't recall what he was asking. I can put ya'll in touch with him if you have any interest. I remember changing the sprinklers on the alfalfa fields at night. Those kind of tubes you had to unlatch each section and carry it to the new location then reassemble. I remember how flexible they seemed. I'm sure things have changed but I sure wouldn't want that on my plane. ________________________________________________________________________________
Date: Oct 31, 2016
I'm sorry. I didn't know that this conversation was regarding hangar doors. I had thought that the discussion was about sources for the 5 and 6 inch diameter tubes used on Kolb spars and fuselage (tailboom) tubes. Being a city boy myself, I have absolutely never seen a hangar that required very thin wall 5 or 6 inch aluminum tubes for the structure, that just happened to be the same materials as what the Kolb aircraft structure uses. I'm genuinely sorry about getting wrapped around the axle if a hangar door was really the subject of the discussion. Any of us who have been around airplanes for a while, and gone to funerals that didn't need to happen, are a little bit trigger-happy about this kind of stuff. I woke up one day and realized that I was the "silly old guy" at the airport who was warning the younger pilots not to do stupid things, and to check stuff two or three times before you fly. It seemed like it was just the day before when I was the smart-ass young pilot, all testosterone and no brains, and laughing at the silly old guys at the airport who were always shaking their finger at me about safety and risk. I could hear all of the old guys roaring with laughter up in the clouds. I would humbly suggest that instead of thin wall 5 or 6 inch aluminum tube, you use galvanized conduit, or square steel tube, for your hangar. A whole lot cheaper, easier to work with, doesn't dent as easily, and the thicker wall materials can have a bolt through them without the bolt hole getting loose in a week. Thin wall aluminum tube is really an incorrect material for a hangar in my opinion. Otherwise you would see all the airport hangars and Butler Buildings and barns made out of it I guess. Bill Yer wraped around the axle for no reason. The initial conversation was about alum tubing suitable for a hangar/hangar door, not for an aircraft. Geez. Jim Baker ________________________________________________________________________________
Date: Oct 31, 2016
Hi Bill, As I said earlier, I have no idea what the original subject was; I might not have ever seen the original post. I get individual emails from the list; I suspect that I don't see some of the posts made directly to the forum version. As far as I know, I'm the one that mentioned hangar doors made from irrigation tubing (intended as a good natured diversion; something that's apparently hard to achieve on this list...). Obviously, steel is a better choice, generally, for hangar doors. But a local farm operation was selling a large quantity of 6"x30' sections for a dollar a foot. That, combined with some old highway signs from the scrap yard for gussets and some rivets (driven where I could reach both sides and 3/16" 'pop' where I couldn't), resulted in a 10'x30' one-piece door with counter weight that was much cheaper than a steel frame and light enough for me to assemble and hang without any outside assistance from man or lifting machine. And if nothing else, it's a great conversation piece when a new visitor arrives and I open the door with a light shove. :-) You're absolutely right that no one should be substituting materials in an a/c without knowing exactly what they are doing. But it's also extremely unlikely that a low volume a/c kit company is having custom seamless tubing extrusions made for spars and/or tail booms. The trick (if one is intent on bypassing the kit company) is to know exactly the specs of the off-the-shelf product the kit company is using. And now, back to our regularly scheduled humorless pokes and jabs programming. (That's a joke, son...) Charlie On 10/31/2016 12:24 PM, Bill Berle wrote: > > I'm sorry. I didn't know that this conversation was regarding hangar doors. I had thought that the discussion was about sources for the 5 and 6 inch diameter tubes used on Kolb spars and fuselage (tailboom) tubes. > > Being a city boy myself, I have absolutely never seen a hangar that required very thin wall 5 or 6 inch aluminum tubes for the structure, that just happened to be the same materials as what the Kolb aircraft structure uses. > > I'm genuinely sorry about getting wrapped around the axle if a hangar door was really the subject of the discussion. Any of us who have been around airplanes for a while, and gone to funerals that didn't need to happen, are a little bit trigger-happy about this kind of stuff. I woke up one day and realized that I was the "silly old guy" at the airport who was warning the younger pilots not to do stupid things, and to check stuff two or three times before you fly. It seemed like it was just the day before when I was the smart-ass young pilot, all testosterone and no brains, and laughing at the silly old guys at the airport who were always shaking their finger at me about safety and risk. I could hear all of the old guys roaring with laughter up in the clouds. > > I would humbly suggest that instead of thin wall 5 or 6 inch aluminum tube, you use galvanized conduit, or square steel tube, for your hangar. A whole lot cheaper, easier to work with, doesn't dent as easily, and the thicker wall materials can have a bolt through them without the bolt hole getting loose in a week. Thin wall aluminum tube is really an incorrect material for a hangar in my opinion. Otherwise you would see all the airport hangars and Butler Buildings and barns made out of it I guess. > > Bill > ________________________________________________________________________________
Date: Oct 31, 2016
Bill/All I thought the discussion was for our Kolb airplanes also, so if it really wasn't there were a bunch of us that thought it was. I support Bill's comments 100%. It's good for the quality of our airplanes, their reputation, and it keeps more people alive. Just buy from Kolb and you will get the right stuff. It is also very important buy from Kolb to keep our factory support alive and well. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Oct 31, 2016 at 1:24 PM, Bill Berle wrote: > > I'm sorry. I didn't know that this conversation was regarding hangar > doors. I had thought that the discussion was about sources for the 5 and 6 > inch diameter tubes used on Kolb spars and fuselage (tailboom) tubes. > > Being a city boy myself, I have absolutely never seen a hangar that > required very thin wall 5 or 6 inch aluminum tubes for the structure, that > just happened to be the same materials as what the Kolb aircraft structure > uses. > > I'm genuinely sorry about getting wrapped around the axle if a hangar door > was really the subject of the discussion. Any of us who have been around > airplanes for a while, and gone to funerals that didn't need to happen, are > a little bit trigger-happy about this kind of stuff. I woke up one day and > realized that I was the "silly old guy" at the airport who was warning the > younger pilots not to do stupid things, and to check stuff two or three > times before you fly. It seemed like it was just the day before when I was > the smart-ass young pilot, all testosterone and no brains, and laughing at > the silly old guys at the airport who were always shaking their finger at > me about safety and risk. I could hear all of the old guys roaring with > laughter up in the clouds. > > I would humbly suggest that instead of thin wall 5 or 6 inch aluminum > tube, you use galvanized conduit, or square steel tube, for your hangar. A > whole lot cheaper, easier to work with, doesn't dent as easily, and the > thicker wall materials can have a bolt through them without the bolt hole > getting loose in a week. Thin wall aluminum tube is really an incorrect > material for a hangar in my opinion. Otherwise you would see all the > airport hangars and Butler Buildings and barns made out of it I guess. > > Bill > > > Yer wraped around the axle for no reason. The initial conversation was > about alum tubing suitable for a hangar/hangar door, not for an aircraft. > > Geez. > > Jim Baker > > ________________________________________________________________________________
Date: Oct 31, 2016
Didn't mean to sound high and mighty. I was confused right along with y'all. At first I thought it was about Kolbs but then got an email off list that asked, so...its OK to use for a door. That, in conjunction with the hangar picture, is where I thought that conversation was headed. Instead, I think I just steered it into the weeds. Apologies to all...... Jim Baker 405 426 5377 -----Original Message----- From: Rick Neilsen <neilsenrm(at)gmail.com> Sent: Mon, 31 Oct 2016 14:45 Subject: Re: Kolb-List: 5 and 6 inch tubing --001a114b05fc958f3505402d9b0d Content-Type: text/plain; charset=UTF-8 Bill/All I thought the discussion was for our Kolb airplanes also, so if it really wasn't there were a bunch of us that thought it was. I support Bill's comments 100%. It's good for the quality of our airplanes, their reputation, and it keeps more people alive. Just buy from Kolb and you will get the right stuff. It is also very important buy from Kolb to keep our factory support alive and well. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Oct 31, 2016 at 1:24 PM, Bill Berle wrote: > > I'm sorry. I didn't know that this conversation was regarding hangar > doors. I had thought that the discussion was about sources for the 5 and 6 > inch diameter tubes used on Kolb spars and fuselage (tailboom) tubes. > > Being a city boy myself, I have absolutely never seen a hangar that > required very thin wall 5 or 6 inch aluminum tubes for the structure, that > just happened to be the same materials as what the Kolb aircraft structure > uses. > > I'm genuinely sorry about getting wrapped around the axle if a hangar door > was really the subject of the discussion. Any of us who have been around > airplanes for a while, and gone to funerals that didn't need to happen, are > a little bit trigger-happy about this kind of stuff. I woke up one day and > realized that I was the "silly old guy" at the airport who was warning the > younger pilots not to do stupid things, and to check stuff two or three > times before you fly. It seemed like it was just the day before when I was > the smart-ass young pilot, all testosterone and no brains, and laughing at > the silly old guys at the airport who were always shaking their finger at > me about safety and risk. I could hear all of the old guys roaring with > laughter up in the clouds. > > I would humbly suggest that instead of thin wall 5 or 6 inch aluminum > tube, you use galvanized conduit, or square steel tube, for your hangar. A > whole lot cheaper, easier to work with, doesn't dent as easily, and the > thicker wall materials can have a bolt through them without the bolt hole > getting loose in a week. Thin wall aluminum tube is really an incorrect > material for a hangar in my opinion. Otherwise you would see all the > airport hangars and Butler Buildings and barns made out of it I guess. > > Bill > > > Yer wraped around the axle for no reason. The initial conversation was > about alum tubing suitable for a hangar/hangar door, not for an aircraft. > > Geez. > > Jim Baker > > --001a114b05fc958f3505402d9b0d Content-Type: text/html; charset=UTF-8 Content-Transfer-Encoding: quoted-printable
Bil l/All
I thought the discu ssion was for our Kolb airplanes also, so if it really wasn't there wer e a bunch of us that thought it was. I support Bill's comments 100%. It 's good for the quality of our airplanes, their reputation, and it keep s more people alive. Just buy from Kolb and you will get the right stuff. I t is also very important buy from Kolb to keep our factory support alive an d well.
Rick Neilsen
On Mon, Oct 31, 2016 at 1:24 PM, Bill Berle <victorbravo@sbcglob al.net> wrote:
--> Kolb- List message posted by: Bill Berle <victorbravo(at)sbcglobal.net>
I'm sorry. I didn't know that this conversation was regarding hanga r doors. I had thought that the discussion was about sources for the 5 and 6 inch diameter tubes used on Kolb spars and fuselage (tailboom) tubes.
Being a city boy myself, I have absolutely never seen a hangar that require d very thin wall 5 or 6 inch aluminum tubes for the structure, that just ha ppened to be the same materials as what the Kolb aircraft structure uses.
I'm genuinely sorry about getting wrapped around the axle if a hangar d oor was really the subject of the discussion. Any of us who have been aroun d airplanes for a while, and gone to funerals that didn't need to happe n, are a little bit trigger-happy about this kind of stuff. I woke up one d ay and realized that I was the "silly old guy" at the airport who was warning the younger pilots not to do stupid things, and to check stuff two or three times before you fly. It seemed like it was just the day befo re when I was the smart-ass young pilot, all testosterone and no brains, an d laughing at the silly old guys at the airport who were always shaking the ir finger at me about safety and risk. I could hear all of the old guys roa ring with laughter up in the clouds.
I would humbly suggest that instead of thin wall 5 or 6 inch aluminum tube, you use galvanized conduit, or square steel tube, for your hangar. A whole lot cheaper, easier to work with, doesn't dent as easily, and the thic ker wall materials can have a bolt through them without the bolt hole getti ng loose in a week. Thin wall aluminum tube is really an incorrect material for a hangar in my opinion. Otherwise you would see all the airport hangar s and Butler Buildings and barns made out of it I guess.
=C2---> Kolb-List message posted by:=C2- Jim Baker <jimbaker(at)npacc.net>
=C2-Yer wraped around the axle for no reason. The initial conversation wa s about alum tubing suitable for a hangar/hangar door, not for an aircraft.
=C2-Geez.
=C2-Jim Baker
-List" rel="noreferrer" target="_blank">http://www.matronics.com/>N avigator?Kolb-List
eferrer" target="_blank">http://forums.matronics.com>
http://wiki.matronics.com>
http://www.matronics.com/>contribu tion
--001a114b05fc958f3505402d9b0d-- --001a114b05fc958f3505402d9b0d-- ________________________________________________________________________________
Date: Nov 01, 2016
Subject: PLEASE READ - Matronics Email List 2016 Fund Raiser During
November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 24 different gifts to choose from! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 02, 2016
Subject: Re: 5 and 6 inch tubing
Amen to supporting Kolb. They give so much to all of us and I take comfort in just knowing they're out there, ready, willing and able to help. When I first got my Mk III it was Travis who helped me solve my landing problems. The funny thing was, Travis isn't a pilot but he picked up so much from all the pilots he talked to that he knew exactly what I was doing wrong. I followed his ideas and my landings improved almost instantly. Where else are we going to get service like that? Rick Girard On Sun, Oct 30, 2016 at 6:40 PM, wrote: > > Thanks for posting your comments below, Rex. > > Folks, the only thing that keeps Kolb Aircraft alive is us few that still > support them. They are an extremely small company with shallow pockets. > What they have, parts to keep our aging aircraft alive, will disappear if > they do not continue to stay in business. > > Support Kolb Aircraft. > > Besides, you won't meet finer folks anywhere. > > john h > mkIII > El Centro, California > > > ---- Rex Rodebush wrote: > > > > Here's an idea. Call Brian at TNK and order the tubing you want. I > know we all want to save money. However, paying a little more to support > TNK and get tubing that works seems like a reasonable thing to me. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=461745#461745 > > > > > > > > > > > > > > > > > > > > > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Nov 03, 2016
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 05, 2016
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2016
Subject: Re: video
Date: Nov 08, 2016
Somewhere along the line I tried to send a pic or two with water. Here is a bit of water over Shell lake, WI as I was on my wayy to Voyager Village. https://www.youtube.com/watch?v=pzdlqdVxAWs -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=462224#462224 ________________________________________________________________________________
Date: Nov 09, 2016
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Subject: Re: video
Date: Nov 10, 2016
Thank You thats a pretty cool place! -------- 2007 Firestar 2 503 N203SD Moster 185 Flattop PPG/Sky K2 Paraglider Trike Buggy Soaring Trike & Northwing Stratus XP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=462341#462341 ________________________________________________________________________________
Date: Nov 11, 2016
Subject: Re: Kolb-List Firestar KXP
Someone had posted on the Kolb List that they were looking for a Firestar 1 or KXP. Herb was that you? I ran across this, may be of interest: https://billings.craigslist.org/for/5864063598.html Kolb firestar KXP E-LSA, Rotax 503, DCDI, 52 HP, Appx. 200 hrs., fresh covering on wings, runs and flies great. Very clean and in good condition. Phone 406-839-0826. NO text. So whoever is looking for the FS1, maybe the Kolb List can make sure that the message gets to him. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Sun, 10/30/16, Herb wrote: Subject: Re: Kolb-List: 5 and 6 inch tubing To: kolb-list(at)matronics.com Date: Sunday, October 30, 2016, 4:21 PM Herb I went to the barn and looked at all of my 5 inch tubes that I bought from Kolb many years back..they had a trailer full of scratch and dents..None had the typical rolled on alloy identification. .Travis explained that they were perfectly good but if they sent a spar or boom to a customer, it had to be perfect...so..I bought quite a few of them.. Stayed away from scratches and bought those with small dents.. dollar a foot...wish I had bought more.. By the way...I have a good set of Firefly spars...I went with single lift struts,ala firestar, on my first Firefly...unfortunately...all the holes are drilled for the ribs...no extra charge...:-) 6061 T6 it is...!! :-) who would have thought...25 or so dollars a foot!! Herb On 10/30/2016 06:50 PM, jhauck(at)elmore.rr.com wrote: > > > > ...I am pretty sure I heard that the spars and boom tubes were 6063 or something near that alloy...Herb > > >Herb/Kolbers: > > 5 and 6 inch booms and spars are drawn for irrigation pipe. They are 6061 T-6 .058" wall. > > Biggest problem for Kolb is finding tubes that do not have dents and scratches. That tubing is not handled with kid gloves once it is manufactured. I remember the Kolb Gang going to the factory and going through many, many tubes to find the "good" ones. > > The 6061 is probably used for circle irrigation systems because of the increased strength required to keep the system together. The "el cheapo" non-spec'd tubing is probably used for systems that are laid out on the ground and not mobile. > > > john h > mkIII > El Centro, California > > > > > > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... Forum - - MATRONICS WEB FORUMS - MATRONICS LIST WIKI - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Nov 11, 2016
Subject: Make Sure You're Listed! List of Contributors Published in
December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 13, 2016
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that ilk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 15, 2016
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 17, 2016
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some point, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 23 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Subject: Win or Loose please donate to the Matronics List Strong...
Date: Nov 18, 2016
Kolbrers, Whether you voted, didnt vote, are worried or pleased please dont forget to donate to the Matronics List Enjoy, Nick Cassara Snow free Palmer, Alaska ________________________________________________________________________________
Subject: Be out noise electronic trouble
Date: Nov 19, 2016
Mobile phone becomes so important in our lives that we don't know how to live without it. It is more than a mobile phone, it is our movie center, our game box, our wallet, our computer, our camera, our music player, actually it is a closer friend of us. It makes us to live easier lives. But at the same time, it pushs us to trouble situations when it becomes more and more popular, so mobile phone jammer (http://www.skybuying.com/category-177-b0.html) comes. Someone may want to know what is a mobile phone jammer. The mobile phone jammer, as a new technology device, is a kind of device that can be used to block the signal of mobile phone from the base station. It could help us to use mobile phones better and better. It gives us a peaceful life in the world of mobile phones. It is a helpful assistant when we don't need to be disturbed by mobile phone noise. Now the mobile phone jammer is widely used in many kinds of places, like meeting room, theater, church, library, government, gas station, examination room, military area and so on. A very good example is, the mobile phone jammer help to solve the problem of cheating in school, which ensures the equity in student exams. When it is installed in church, court, library, meeting room, theater, it can prevent mobile phone from receiving signals, which maintains absolute silence. As is known to us, using mobile phones in the gas station may be dangerous, when mobile phone jammers applied in gas stations, they can block mobile phone signals so as to ensure the safety in the gas station. They are also necessities of government and military field, which can also be seen as the guarantee of military security. First, it comes our universal mobile phone signal jammer. It has compact size that is only slightly bigger than a standard IPOD. With a built-in heat dissipative design, this mini mobile phone jammer will not generate an undue amount of heat. It can run on AC power, battery power or recharging from AC charger (110/220V). It can block the signals in a range of 15 meters. What makes it the best-selling mobile phone jammer? The price maybe also an important factor. It cost you less than 80 dollars, everyone could afford to buy this cheap but perfect mobile phone jammer. On the other hand, we also offer high power mobile phone blocker (http://www.skybuying.com/) and professional mobile phone jammer for special purpose. In the next, we want to introduce you our 70W high power mobile phone jammer with Omni- directional Antenna. It can block all kinds of mobile phone signals. With the AC adapter, it can work continuously with a total output power of 70W. Besides, its built-in cooling fan enables it to have the good heat dissipation. Equipped with Omni-directional Antenna, it can jamming signal from all directions and its jamming range can reach up 1000 meters. Besides of above two mobile phone jammers, we have many other mobile phone jammers also. They have different jamming distance, different functions, different outlook, different weight, different size, they could meet different requirement. If you are interested in the mobile phone jammers, if you have the request, you may want to know more about them. Just come to our website, here you could find all kinds of mobile phone jammers as well as much knowledge about the jammers. As a professional jammer supplier, we provide the most advanced mobile phone jammers at the most reasonable price. But there is one very important thing you should know before you buy a mobile phone jammer, please check the raw of your country, make sure it is legal to buy and use a mobile phone jammer in your place. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=462754#462754 ________________________________________________________________________________
Subject: Re: Be out noise electronic trouble
Date: Nov 19, 2016
THIS NOTHING BUT A SALES PITCH - NOTHING TO DO WITH KOLBS PLEASE GO ELSEWHERE > On Nov 19, 2016, at 11:07 AM, jamlieleven wrote: > > > Mobile phone becomes so important in our lives that we don't know how to live without it. It is more than a mobile phone, it is our movie center, our game box, our wallet, our computer, our camera, our music player, actually it is a closer friend of us. It makes us to live easier lives. But at the same time, it pushs us to trouble situations when it becomes more and more popular, so mobile phone jammer (http://www.skybuying.com/category-177-b0.html) comes. Someone may want to know what is a mobile phone jammer. The mobile phone jammer, as a new technology device, is a kind of device that can be used to block the signal of mobile phone from the base station. It could help us to use mobile phones better and better. It gives us a peaceful life in the world of mobile phones. It is a helpful assistant when we don't need to be disturbed by mobile phone noise. Now the mobile phone jammer is widely used in many kinds of places, like meeting room, theater, church, library, ! > government, gas station, examination room, military area and so on. > > A very good example is, the mobile phone jammer help to solve the problem of cheating in school, which ensures the equity in student exams. When it is installed in church, court, library, meeting room, theater, it can prevent mobile phone from receiving signals, which maintains absolute silence. As is known to us, using mobile phones in the gas station may be dangerous, when mobile phone jammers applied in gas stations, they can block mobile phone signals so as to ensure the safety in the gas station. They are also necessities of government and military field, which can also be seen as the guarantee of military security. > > First, it comes our universal mobile phone signal jammer. It has compact size that is only slightly bigger than a standard IPOD. With a built-in heat dissipative design, this mini mobile phone jammer will not generate an undue amount of heat. It can run on AC power, battery power or recharging from AC charger (110/220V). It can block the signals in a range of 15 meters. What makes it the best-selling mobile phone jammer? The price maybe also an important factor. It cost you less than 80 dollars, everyone could afford to buy this cheap but perfect mobile phone jammer. > > On the other hand, we also offer high power mobile phone blocker (http://www.skybuying.com/) and professional mobile phone jammer for special purpose. In the next, we want to introduce you our 70W high power mobile phone jammer with Omni- directional Antenna. It can block all kinds of mobile phone signals. With the AC adapter, it can work continuously with a total output power of 70W. Besides, its built-in cooling fan enables it to have the good heat dissipation. Equipped with Omni-directional Antenna, it can jamming signal from all directions and its jamming range can reach up 1000 meters. > > Besides of above two mobile phone jammers, we have many other mobile phone jammers also. They have different jamming distance, different functions, different outlook, different weight, different size, they could meet different requirement. If you are interested in the mobile phone jammers, if you have the request, you may want to know more about them. Just come to our website, here you could find all kinds of mobile phone jammers as well as much knowledge about the jammers. As a professional jammer supplier, we provide the most advanced mobile phone jammers at the most reasonable price. But there is one very important thing you should know before you buy a mobile phone jammer, please check the raw of your country, make sure it is legal to buy and use a mobile phone jammer in your place. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=462754#462754 > > > > > > > > > ________________________________________________________________________________
Date: Nov 19, 2016
This post has no place on our list. Matt, can you get this person blocked. Rick Neilsen Redrive VW Powered MKIIIC On Sat, Nov 19, 2016 at 11:07 AM, jamlieleven wrote: > > Mobile phone becomes so important in our lives that we don't know how to > live without it. It is more than a mobile phone, it is our movie center, > our game box, our wallet, our computer, our camera, our music player, > actually it is a closer friend of us. It makes us to live easier lives. > But at the same time, it pushs us to trouble situations when it becomes > more and more popular, so mobile phone jammer ( > http://www.skybuying.com/category-177-b0.html) comes. Someone may want > to know what is a mobile phone jammer. The mobile phone jammer, as a new > technology device, is a kind of device that can be used to block the signal > of mobile phone from the base station. It could help us to use mobile > phones better and better. It gives us a peaceful life in the world of > mobile phones. It is a helpful assistant when we don't need to be > disturbed by mobile phone noise. Now the mobile phone jammer is widely > used in many kinds of places, like meeting room, theater, church, library, ! > government, gas station, examination room, military area and so on. > > A very good example is, the mobile phone jammer help to solve the problem > of cheating in school, which ensures the equity in student exams. When it > is installed in church, court, library, meeting room, theater, it can > prevent mobile phone from receiving signals, which maintains absolute > silence. As is known to us, using mobile phones in the gas station may be > dangerous, when mobile phone jammers applied in gas stations, they can > block mobile phone signals so as to ensure the safety in the gas station. > They are also necessities of government and military field, which can also > be seen as the guarantee of military security. > > First, it comes our universal mobile phone signal jammer. It has compact > size that is only slightly bigger than a standard IPOD. With a built-in > heat dissipative design, this mini mobile phone jammer will not generate an > undue amount of heat. It can run on AC power, battery power or recharging > from AC charger (110/220V). It can block the signals in a range of 15 > meters. What makes it the best-selling mobile phone jammer? The price > maybe also an important factor. It cost you less than 80 dollars, everyone > could afford to buy this cheap but perfect mobile phone jammer. > > On the other hand, we also offer high power mobile phone blocker ( > http://www.skybuying.com/) and professional mobile phone jammer for > special purpose. In the next, we want to introduce you our 70W high power > mobile phone jammer with Omni- directional Antenna. It can block all kinds > of mobile phone signals. With the AC adapter, it can work continuously with > a total output power of 70W. Besides, its built-in cooling fan enables it > to have the good heat dissipation. Equipped with Omni-directional Antenna, > it can jamming signal from all directions and its jamming range can reach > up 1000 meters. > > Besides of above two mobile phone jammers, we have many other mobile phone > jammers also. They have different jamming distance, different functions, > different outlook, different weight, different size, they could meet > different requirement. If you are interested in the mobile phone jammers, > if you have the request, you may want to know more about them. Just come > to our website, here you could find all kinds of mobile phone jammers as > well as much knowledge about the jammers. As a professional jammer > supplier, we provide the most advanced mobile phone jammers at the most > reasonable price. But there is one very important thing you should know > before you buy a mobile phone jammer, please check the raw of your country, > make sure it is legal to buy and use a mobile phone jammer in your place. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=462754#462754 > > ________________________________________________________________________________
Date: Nov 19, 2016
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 21, 2016
Date: Nov 23, 2016
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Subject: Kolb FSII for sale
Date: Nov 25, 2016
Since the list has been pretty quiet for a while (Hiding from Matt while he solicits donations?) I guess it is time to stick my head up and get back in the game... I have acquired a Firestar II that is now for sale. The owner decided that he was no longer capable of committing aviation safely, and for reasons of liability, parted out a perfectly functional FSII. So somebody is going to get themselves a really good basket case/project. So here's the deal: Kolb FSII, NDH, engine is a Rotax 503, dual carb, 418 TT, PTO end cylinder seized at 356 hours, bored to 2nd over. Runs good, B box, 2.58:1, 2 blade Ivo in excellent condition. Wings are good, one LE has a slight indention in the front, should not be a problem. Cage is excellent. Instruments will be included. Nose bowl fairing not included, it is going to our Firefly project. Two damaged nose bowl fairings included, I have figured out how to repair them, but now I don't need to. You can fix them if you wish. Or Bryan will be glad to sell you a new one. Landing gear is straight, includes cable brakes. Previous owner modified the axle/gear leg fittings to make them stronger. (?) Your call. Factory upgrade might be an idea... Boom tube ~ Since the FSII uses the latest quick fold mechanism, we are taking the boom tube and tail assembly from this airplane and grafting it onto our Firefly project. So you will get a Firestar boom tube and tail assembly from an original Firestar. As best we can tell from the plans, there is no difference in the tubing sizes or dimensions of any of these parts. If anyone on the list knows different, I would be glad to be corrected, however, this is how I see it to the best of my knowledge. The original Firestar used the original Kolb tail folding mechanism which is not as convenient as the current mechanism. It would not be terribly difficult to upgrade the tail to incorporate the current tail ring, vertical tail post, and elevator control system into the tail boom and elevators, but that is your call. I do have the elevator actuator/cable attach mechanism which can be included. I do not have the tail ring/vertical stab assembly or the elevator inserts, you would need to get them from Kolb if you wanted to upgrade to the newer system. Or if you don't need to fold the tail on a regular basis, this system will work just fine. By next week I/we (my partner & I) will have migrated the FS boom and tail to the FSII cage, & the FSII boom & tail to the Firefly cage (all the dimensions are identical) and I can post pictures of that, but right now it is a slow night and I am bored, so I'll get things started now with just a few pictures of the wings. $3500 for everything. No N numbers, no registration, this is a pure basket case sale, and the buyer will be signing for a collection of unairworthy parts of unknown description. Everything has been de-skinned, no plumbing, fabric, wiring, Lexan, fuel tanks or cables. (Scrounging is good) You will be buying in effect a KOLB FSII (mostly assembled kit) that needs to be recovered, wired, plumbed, and totally rebuilt, registered, etc. but signing a bill of sale that says you are buying a collection of unairworthy junk. PM me. I need to get this thing out of my carport before the snow gets here. No tire kickers, price is firm. More pictures next week. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463102#463102 Attachments: http://forums.matronics.com//files/p1050422_medium_764.jpg http://forums.matronics.com//files/p1050415_medium_196.jpg http://forums.matronics.com//files/p1050404_medium_917.jpg http://forums.matronics.com//files/p1050397_medium_111.jpg http://forums.matronics.com//files/p1050395_medium_197.jpg ________________________________________________________________________________
Date: Nov 26, 2016
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: Kolb FSII for sale
Date: Nov 26, 2016
Hey Richard Waiting for the fuselage and other pics...Herb On 11/25/2016 09:45 PM, Richard Pike wrote: > > Since the list has been pretty quiet for a while (Hiding from Matt while he solicits donations?) I guess it is time to stick my head up and get back in the game... > > I have acquired a Firestar II that is now for sale. The owner decided that he was no longer capable of committing aviation safely, and for reasons of liability, parted out a perfectly functional FSII. So somebody is going to get themselves a really good basket case/project. > > So here's the deal: Kolb FSII, NDH, engine is a Rotax 503, dual carb, 418 TT, PTO end cylinder seized at 356 hours, bored to 2nd over. Runs good, B box, 2.58:1, 2 blade Ivo in excellent condition. > > Wings are good, one LE has a slight indention in the front, should not be a problem. Cage is excellent. Instruments will be included. Nose bowl fairing not included, it is going to our Firefly project. Two damaged nose bowl fairings included, I have figured out how to repair them, but now I don't need to. You can fix them if you wish. Or Bryan will be glad to sell you a new one. > > Landing gear is straight, includes cable brakes. Previous owner modified the axle/gear leg fittings to make them stronger. (?) Your call. Factory upgrade might be an idea... > > Boom tube ~ Since the FSII uses the latest quick fold mechanism, we are taking the boom tube and tail assembly from this airplane and grafting it onto our Firefly project. So you will get a Firestar boom tube and tail assembly from an original Firestar. As best we can tell from the plans, there is no difference in the tubing sizes or dimensions of any of these parts. If anyone on the list knows different, I would be glad to be corrected, however, this is how I see it to the best of my knowledge. > > The original Firestar used the original Kolb tail folding mechanism which is not as convenient as the current mechanism. It would not be terribly difficult to upgrade the tail to incorporate the current tail ring, vertical tail post, and elevator control system into the tail boom and elevators, but that is your call. I do have the elevator actuator/cable attach mechanism which can be included. I do not have the tail ring/vertical stab assembly or the elevator inserts, you would need to get them from Kolb if you wanted to upgrade to the newer system. > > Or if you don't need to fold the tail on a regular basis, this system will work just fine. > > By next week I/we (my partner & I) will have migrated the FS boom and tail to the FSII cage, & the FSII boom & tail to the Firefly cage (all the dimensions are identical) and I can post pictures of that, but right now it is a slow night and I am bored, so I'll get things started now with just a few pictures of the wings. > > $3500 for everything. No N numbers, no registration, this is a pure basket case sale, and the buyer will be signing for a collection of unairworthy parts of unknown description. Everything has been de-skinned, no plumbing, fabric, wiring, Lexan, fuel tanks or cables. (Scrounging is good) > You will be buying in effect a KOLB FSII (mostly assembled kit) that needs to be recovered, wired, plumbed, and totally rebuilt, registered, etc. but signing a bill of sale that says you are buying a collection of unairworthy junk. > > PM me. I need to get this thing out of my carport before the snow gets here. No tire kickers, price is firm. > > More pictures next week. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Would you consider yourself to be a good person? > https://www.youtube.com/watch?v=VWcDXT6pH7A > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=463102#463102 > > > Attachments: > > http://forums.matronics.com//files/p1050422_medium_764.jpg > http://forums.matronics.com//files/p1050415_medium_196.jpg > http://forums.matronics.com//files/p1050404_medium_917.jpg > http://forums.matronics.com//files/p1050397_medium_111.jpg > http://forums.matronics.com//files/p1050395_medium_197.jpg > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Nov 26, 2016
How about now? -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463194#463194 ________________________________________________________________________________
Date: Nov 26, 2016
Noop No Pics...Herb On 11/26/2016 04:50 PM, Richard Pike wrote: > > How about now? > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Would you consider yourself to be a good person? > https://www.youtube.com/watch?v=VWcDXT6pH7A > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=463194#463194 > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Nov 27, 2016
From: william sullivan <williamtsullivan(at)att.net>
Nothing attached to your e-mail, Richard. The wings photos came through fine, though. -------------------------------------------- On Sat, 11/26/16, Richard Pike wrote: Subject: Kolb-List: Re: Kolb FSII for sale To: kolb-list(at)matronics.com Date: Saturday, November 26, 2016, 5:50 PM "Richard Pike" How about now? -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463194#463194 Lists This Month -- Some AWESOME FREE Gifts!) Raiser. Click on more about Gifts provided www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com www.mypilotstore.com www.mrrace.com -Matt Dralle, List Admin. Forum - - MATRONICS WEB FORUMS - MATRONICS LIST WIKI - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Nov 26, 2016
All the pictures are in the original post from Friday. I edited it. Look there. (I know they are in there because I used my wife's computer to look them up) -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463203#463203 ________________________________________________________________________________
Date: Nov 26, 2016
On 11/26/2016 9:48 PM, Richard Pike wrote: > > All the pictures are in the original post from Friday. I edited it. Look there. (I know they are in there because I used my wife's computer to look them up) > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 Some of us get messages by email. If you edited a forum post, we won't see the edit. ________________________________________________________________________________
Date: Nov 27, 2016
Richard It is the second batch...airframe...etc that has not come through...Herb On 11/26/2016 10:57 PM, Charlie England wrote: > > On 11/26/2016 9:48 PM, Richard Pike wrote: >> >> >> All the pictures are in the original post from Friday. I edited it. >> Look there. (I know they are in there because I used my wife's >> computer to look them up) >> >> -------- >> Richard Pike >> Kolb MKIII N420P (420ldPoops) >> Kingsport, TN 3TN0 ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 7 Msgs - 11/26/16
Date: Nov 27, 2016
SSBoYXZlIGEgbWFyayAyIGZvciBzYWxlIHNvdXRoZXJuICBXaXNjb25zaW4gIGNvbXBsZXRlIHBs YW5lIDUwMyA2MDAwLjAwIHBsYW5lIGNvdWxkIGJlIGZsb3duIGFzIGlzIGNvdWxkIHVzZSB0byBi ZSByZWRvbmUNCg= ________________________________________________________________________________
Date: Nov 27, 2016
Date: Nov 27, 2016
Hi Richard Think I have it this time... The white tail feathers and boom tube and the blue/black fuselage on the gear are what is being sold...plus the wings in the previous pics along with engine and prop...Pretty much sum it up? Herb On 11/25/2016 09:45 PM, Richard Pike wrote: > > Since the list has been pretty quiet for a while (Hiding from Matt while he solicits donations?) I guess it is time to stick my head up and get back in the game... > > I have acquired a Firestar II that is now for sale. The owner decided that he was no longer capable of committing aviation safely, and for reasons of liability, parted out a perfectly functional FSII. So somebody is going to get themselves a really good basket case/project. > > So here's the deal: Kolb FSII, NDH, engine is a Rotax 503, dual carb, 418 TT, PTO end cylinder seized at 356 hours, bored to 2nd over. Runs good, B box, 2.58:1, 2 blade Ivo in excellent condition. > > Wings are good, one LE has a slight indention in the front, should not be a problem. Cage is excellent. Instruments will be included. Nose bowl fairing not included, it is going to our Firefly project. Two damaged nose bowl fairings included, I have figured out how to repair them, but now I don't need to. You can fix them if you wish. Or Bryan will be glad to sell you a new one. > > Landing gear is straight, includes cable brakes. Previous owner modified the axle/gear leg fittings to make them stronger. (?) Your call. Factory upgrade might be an idea... > > Boom tube ~ Since the FSII uses the latest quick fold mechanism, we are taking the boom tube and tail assembly from this airplane and grafting it onto our Firefly project. So you will get a Firestar boom tube and tail assembly from an original Firestar. As best we can tell from the plans, there is no difference in the tubing sizes or dimensions of any of these parts. If anyone on the list knows different, I would be glad to be corrected, however, this is how I see it to the best of my knowledge. > > The original Firestar used the original Kolb tail folding mechanism which is not as convenient as the current mechanism. It would not be terribly difficult to upgrade the tail to incorporate the current tail ring, vertical tail post, and elevator control system into the tail boom and elevators, but that is your call. I do have the elevator actuator/cable attach mechanism which can be included. I do not have the tail ring/vertical stab assembly or the elevator inserts, you would need to get them from Kolb if you wanted to upgrade to the newer system. > > Or if you don't need to fold the tail on a regular basis, this system will work just fine. > > By next week I/we (my partner & I) will have migrated the FS boom and tail to the FSII cage, & the FSII boom & tail to the Firefly cage (all the dimensions are identical) and I can post pictures of that, but right now it is a slow night and I am bored, so I'll get things started now with just a few pictures of the wings. > > $3500 for everything. No N numbers, no registration, this is a pure basket case sale, and the buyer will be signing for a collection of unairworthy parts of unknown description. Everything has been de-skinned, no plumbing, fabric, wiring, Lexan, fuel tanks or cables. (Scrounging is good) > You will be buying in effect a KOLB FSII (mostly assembled kit) that needs to be recovered, wired, plumbed, and totally rebuilt, registered, etc. but signing a bill of sale that says you are buying a collection of unairworthy junk. > > PM me. I need to get this thing out of my carport before the snow gets here. No tire kickers, price is firm. > > More pictures next week. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Would you consider yourself to be a good person? > https://www.youtube.com/watch?v=VWcDXT6pH7A > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=463102#463102 > > > Attachments: > > http://forums.matronics.com//files/p1050422_medium_764.jpg > http://forums.matronics.com//files/p1050415_medium_196.jpg > http://forums.matronics.com//files/p1050404_medium_917.jpg > http://forums.matronics.com//files/p1050397_medium_111.jpg > http://forums.matronics.com//files/p1050395_medium_197.jpg > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Nov 27, 2016
[quote="Herbgh(at)nctc.com"]Hi Richard Think I have it this time... The white tail feathers and boom tube and the blue/black fuselage on the gear are what is being sold...plus the wings in the previous pics along with engine and prop...Pretty much sum it up? Herb On 11/25/2016 09:45 PM, Richard Pike wrote: [quote] You got it. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463295#463295 ________________________________________________________________________________
Date: Nov 27, 2016
yep..got it...Herb On 11/27/2016 05:36 PM, Richard Pike wrote: > > [quote="Herbgh(at)nctc.com"]Hi Richard > > Think I have it this time... > > The white tail feathers and boom tube and the blue/black fuselage on > the gear are what is being sold...plus the wings in the previous pics > along with engine and prop...Pretty much sum it up? Herb > > > On 11/25/2016 09:45 PM, Richard Pike wrote: > [quote] > > You got it. > ________________________________________________________________________________
Date: Nov 28, 2016
Subject: Fund Raiser Behind By 28% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 28%. Please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Date: Nov 28, 2016
I just want to encourage everyone to chip in, to keep Matt's lists alive. I've been around these lists for a very long time, and there's no better run aviation forum out there. The number of times I've gotten help from these lists is uncountable. I've been guilty over the years of not contributing, but as I see so many other clunky, over-moderated, advertising loaded sites, I'm much more motivated to help Matt keep fighting the good fight. I hope y'all will agree, and put your wallets where your mouths are. :-) Matt makes it easy to do; just pick your favorite method & amount. Charlie ________________________________________________________________________________
Subject: cooling fan belts
Date: Nov 29, 2016
List Looking for replacement belts for the cooling fan on a 503 and a 447... I recall that one engine had a belt made by Mitsubishi... the 447 ...size 10x590 . also had Rotax 94_4 B stamped on it.. I also have a ,made in Taiwan, 9.5x650 that may have come off of a 447. Just looking for a local purchase...and would trust anything made by Gates...Herb ________________________________________________________________________________
Date: Nov 29, 2016
Subject: Re: cooling fan belts
Herb I think that if you first match the width, so it fits into the pulley correctly. second match the length so that the belt tightening adjustment is around 1/3 to 1/2 of its travel when taunt. Any automobile belt should provide good service. Maybe someone smarter than I can shed more light on the subject. If because of differences between metric and our standard,. If you can't match the width I would go with the next narrower belt. provided it rides in the pulley on the tapered sides, not the bottom of the groove. A wider belt will ride high in the pulley and have more of a chance to pop out. Boyd List Looking for replacement belts for the cooling fan on a 503 and a 447. ________________________________________________________________________________
Date: Nov 29, 2016
Take the old one to any auto parts store and start comparing. Nothing magic about a belt that drives a tiny fan. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of B Young Sent: Tuesday, November 29, 2016 9:22 AM Subject: Re: Kolb-List: cooling fan belts Herb I think that if you first match the width, so it fits into the pulley correctly. second match the length so that the belt tightening adjustment is around 1/3 to 1/2 of its travel when taunt. Any automobile belt should provide good service. Maybe someone smarter than I can shed more light on the subject. If because of differences between metric and our standard,. If you can't match the width I would go with the next narrower belt. provided it rides in the pulley on the tapered sides, not the bottom of the groove. A wider belt will ride high in the pulley and have more of a chance to pop out. Boyd List Looking for replacement belts for the cooling fan on a 503 and a 447. ________________________________________________________________________________
Date: Nov 29, 2016
Subject: Just Two Days Left! - Still Behind...
Dear Listers, There are just two more days left in this years List Fund Raiser. We are still way behind last year in terms of the number of contributions and total contribution amount. I really want to keep providing these services to the homebuilt community, but it take resources. Since there's no advertising budget or deep pockets to keep the operation a float, its solely your generosity during the Fund Raiser that keeps things going. Please make a Contribution today. If you've been putting off showing your support for the Lists, now is the time to do it! Make a contribution with a Credit Card or though PayPal at that Matronics Contribution web site: http://www.matronics.com/contribution Or, drop a check in the mail: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Kolb Xtra For Sale
Date: Nov 29, 2016
Kolbers- I'm selling my MK 3 Xtra. It's very well equipped with approximately 200hr TT, Rotax 912 80Hp, Warp Drive 3-blade prop,19 gal aluminum gas tank with 1 gal header tank and fuel Filter/water separator, Intercom, Electric trim, EIS, Garmin GNC 250XL NavCom, GTX 327 transponder , New ELT, New Lithium battery, new tires and a never used BRS. It's hangered at Sandia Air Park, New Mexico. Brad Nation 505-306-7831 -------- Brad Nation, Albuquerque, NM MK3 Xtra Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463515#463515 Attachments: http://forums.matronics.com//files/img_1904_628.jpg http://forums.matronics.com//files/img_1906_183.jpg http://forums.matronics.com//files/img_1911_137.jpg http://forums.matronics.com//files/img_1895_758.jpg http://forums.matronics.com//files/img_1914_758.jpg http://forums.matronics.com//files/img_1908_213.jpg ________________________________________________________________________________
Subject: cooling fan belts (Herb)
Date: Nov 30, 2016
> and would trust anything made by Gates... I have had a new Gates fail on me. I have a 1990 Ford F250 diesel. It has several belts. One EOM belt looks thin for its length; it turns several accessories. It had about 75k miles on it. It broke on a trip somewhere at 2 AM. I put a new Gates on there after the EOM belt broke. It only lasted for 2-3 months. I went to all the auto parts places in town, bought a recommended belt from each of them, all different brands. I eye-balled them. The Gates looked like all the rest. The EOM cost about the same as the rest but it was several layers thicker and heftier. Does this mean anything to us? I doubt it except be careful and check everything.. GeoB PS I also have a 1992 diesel Ford and they changed over to serpentine. ________________________________________________________________________________
Subject: Re: cooling fan belts (Herb)
Date: Nov 30, 2016
The belt is 10/590. Mitsubishi...The spec on the CPS web page is 10/6/590. A bit confusing... Could not find a belt of the same size on the net...found a 587 which should work.. I have a 1991 Ford f250..diesel...:-) Runs like a top... Herb On 11/30/2016 04:11 AM, George Bearden wrote: > >> and would trust anything made by Gates... > I have had a new Gates fail on me. > > I have a 1990 Ford F250 diesel. It has several belts. One EOM belt looks > thin for its length; it turns several accessories. It had about 75k miles on > it. It broke on a trip somewhere at 2 AM. I put a new Gates on there after > the EOM belt broke. It only lasted for 2-3 months. I went to all the auto > parts places in town, bought a recommended belt from each of them, all > different brands. I eye-balled them. The Gates looked like all the rest. The > EOM cost about the same as the rest but it was several layers thicker and > heftier. > > Does this mean anything to us? I doubt it except be careful and check > everything.. > > GeoB > > PS I also have a 1992 diesel Ford and they changed over to serpentine. > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Nov 30, 2016
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 53! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Stuart Harner paid me a visit
Date: Nov 30, 2016
Yep..All the way from North Dakota....! Actually Stuart was in the area of Lexington Ky on business and decided to pay me a visit...We had a great time ...topped off by a visit to Pizza Hut....Look out London,Ky...I think he may be headed that way tomorrow... To top it off...he never said anything about the bum 447 I sold him!! :-) Hope you make it home ok...Stuart...little bit of snow in the Dakota's I hear , well actually saw..on his cell phone.. A bit of show and tell...in my home,barn and garage and off we went to lunch... Enjoyed it very much...Herb ________________________________________________________________________________
Date: Dec 02, 2016
Thanks for the hospitality Herb. I had a great time. Herb has more projects squirrelled away than I would want to tackle. :) Kentucky: Pretty countryside Good folks No snow, so I went home. (I know I'm a sick puppy but I never grew up and still enjoy a sled or toboggan ride) Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Herb Sent: Wednesday, November 30, 2016 7:53 PM Subject: Kolb-List: Stuart Harner paid me a visit Yep..All the way from North Dakota....! Actually Stuart was in the area of Lexington Ky on business and decided to pay me a visit...We had a great time ...topped off by a visit to Pizza Hut....Look out London,Ky...I think he may be headed that way tomorrow... To top it off...he never said anything about the bum 447 I sold him!! :-) Hope you make it home ok...Stuart...little bit of snow in the Dakota's I hear , well actually saw..on his cell phone.. A bit of show and tell...in my home,barn and garage and off we went to lunch... Enjoyed it very much...Herb ________________________________________________________________________________
Subject: Re: Stuart Harner paid me a visit
Date: Dec 03, 2016
Looks like you made it home Stuart...good thing Travis was not at the Kolb factory! I could never leave there without him grabbing a few hundred dollars from me ...even though I just went for a visit...:-) Herb On 12/02/2016 10:38 PM, Stuart Harner wrote: > > Thanks for the hospitality Herb. I had a great time. > > Herb has more projects squirrelled away than I would want to tackle. :) > > Kentucky: > Pretty countryside > Good folks > No snow, so I went home. > (I know I'm a sick puppy but I never grew up and still enjoy a sled or > toboggan ride) > > Stuart > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Herb > Sent: Wednesday, November 30, 2016 7:53 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Stuart Harner paid me a visit > > > Yep..All the way from North Dakota....! Actually Stuart was in the area of > Lexington Ky on business and decided to pay me a visit...We had a great time > ...topped off by a visit to Pizza Hut....Look out London,Ky...I think he may > be headed that way tomorrow... > To top it off...he never said anything about the bum 447 I sold him!! > :-) > Hope you make it home ok...Stuart...little bit of snow in the Dakota's I > hear , well actually saw..on his cell phone.. > A bit of show and tell...in my home,barn and garage and off we went to > lunch... > Enjoyed it very much...Herb > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Subject: New tail wheel
Date: Dec 03, 2016
Well, I did manage to buy a new tail wheel and adjustable rear spar bracket for the Firefly. $ well spent at the factory. Breakaway swiveling tail wheel is a really neat design. Better wheel and well built. Probably weights a tiny bit more but won't know the actual numbers until I get them both on the scales. I can't imagine the impact on CG will even be measurable. The new wheel is wider and has larger bearings spaced farther apart. It should reduce twisting/shearing forces on the tail leg/spring bolts. Time will tell. Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Herb Sent: Saturday, December 03, 2016 7:38 AM Subject: Re: Kolb-List: Stuart Harner paid me a visit Looks like you made it home Stuart...good thing Travis was not at the Kolb factory! I could never leave there without him grabbing a few hundred dollars from me ...even though I just went for a visit...:-) Herb ________________________________________________________________________________
Subject: Re: New tail wheel
Date: Dec 03, 2016
My initial response would be "Anything would be better that the stock tailwheel" but then I got to thinking - What if you extended the lever arms off the bottom of the rudder, made them longer, and shortened the arms of the tailwheel bracket a bit? Now the (light) factory tail wheel & assembly would be able to turn tighter, and by so doing, put less stress on the rest of the stock assembly? (Since I am in the process of trying to build a genuine Part 103 legal Firefly, topics such as this are especially interesting to me) -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463664#463664 ________________________________________________________________________________
Date: Dec 04, 2016
Interesting idea but IMHO I don't think that will help you much. What you are proposing will make the tail wheel turn more (theoretically up to 90) but does nothing for the swivel function. The stock tail wheel does a good enough job. In fact it works perfectly on pavement and handles a well-groomed grass strip just fine. I was surprised at how well the Firefly handles on the ground without the use of brakes. The stock wheel also was about the lightest thing you could have on the tail except a skid. The problem with the stock tail wheel is that it does not swivel and it is so narrow that it has a tendency to dig into soft surfaces. The new tail wheel will unlock from the rudder and act as a true caster wheel. If you have differential braking this should allow you to pivot around either main wheel with just a tap of the brakes once you are rolling at least a little bit. It will auto lock back into the straight forward position once you release the brakes and roll a short distance. The other great advantage of a swiveling tail wheel is the ability to push it backwards when maneuvering around in a hangar. With the wings are extended all you have to do is pick up the tail boom and walk. However, with the wings folded your options are limited. In my case, I fold every time and push the Firefly uphill into a narrow opening. Lastly the new tail wheel is about twice as wide as the stock one, which means it should not dig into soft ground as much. Unfortunately it will be next spring before I find out if all of the above is correct. Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Saturday, December 03, 2016 6:20 PM Subject: Kolb-List: Re: New tail wheel --> My initial response would be "Anything would be better that the stock tailwheel" but then I got to thinking - What if you extended the lever arms off the bottom of the rudder, made them longer, and shortened the arms of the tailwheel bracket a bit? Now the (light) factory tail wheel & assembly would be able to turn tighter, and by so doing, put less stress on the rest of the stock assembly? (Since I am in the process of trying to build a genuine Part 103 legal Firefly, topics such as this are especially interesting to me) -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463664#463664 ________________________________________________________________________________
Date: Dec 04, 2016
My tailwheel mods were on an Xtra so don't know how much would be applicable to a Firefly. Had many, many problems with my tailwheel. Finally found the right combination that would give me good control in a crosswind and still be able to release to make a tight turn if needed. Tried many combinations of linkage ratios, springs, and mounts. The tailwheel pivot angle should be vertical or tilted back a few degrees. I had to make a custom mount to achieve that. I also went to a 6" pneumatic wheel. See attached pictures. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463677#463677 Attachments: http://forums.matronics.com//files/img_20150730_140741532_179.jpg http://forums.matronics.com//files/img_20150730_140801233_344.jpg ________________________________________________________________________________
Date: Dec 04, 2016
Rex/All Interesting. Looks to be a bit of work making it work. The solid rubber tail wheel I have makes a pronounced thump going over runway expansion joints. I used the factory optional full swivel tail wheel. The factory setup was easier to mount but not ideal. They supplied light springs which allowed the tail wheel to rotate enough to unlock but also unlocked when I didn't want it to. It looks like Rex had to adjust the ratio to get his to unlock also. The factory optional tail wheel allowed me to drill holes in board to attach the control chains so the tail wheel would unlock. I then installed compression springs. No more unlocking in cross wind taxi. I see Rex left some slack in the control chains. I'm old enough to remember cars that had slop in the steering and never liked it. My tail wheel chains are just short of tight. I can taxie fairly fast on hard surfaces, even turning onto taxiways at speed with confidence. Rick Neilsen Redrive VW Powered MKIIIC On Sun, Dec 4, 2016 at 11:13 AM, Rex Rodebush wrote: > > My tailwheel mods were on an Xtra so don't know how much would be > applicable to a Firefly. > > Had many, many problems with my tailwheel. Finally found the right > combination that would give me good control in a crosswind and still be > able to release to make a tight turn if needed. Tried many combinations of > linkage ratios, springs, and mounts. The tailwheel pivot angle should be > vertical or tilted back a few degrees. I had to make a custom mount to > achieve that. I also went to a 6" pneumatic wheel. See attached pictures. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=463677#463677 > > > Attachments: > > http://forums.matronics.com//files/img_20150730_140741532_179.jpg > http://forums.matronics.com//files/img_20150730_140801233_344.jpg > > ________________________________________________________________________________
Date: Dec 04, 2016
Stuart Send a pic of the tail wheel...and what is the damage for one at Kolb? Herb On 12/04/2016 09:45 AM, Stuart Harner wrote: > > Interesting idea but IMHO I don't think that will help you much. What you > are proposing will make the tail wheel turn more (theoretically up to 90) > but does nothing for the swivel function. > > The stock tail wheel does a good enough job. In fact it works perfectly on > pavement and handles a well-groomed grass strip just fine. I was surprised > at how well the Firefly handles on the ground without the use of brakes. The > stock wheel also was about the lightest thing you could have on the tail > except a skid. > ________________________________________________________________________________
Date: Dec 04, 2016
Rick is correct about the slack connections. I tightened them up after some more tests after the picture was taken. I forgot to mention that. Rex Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463689#463689 ________________________________________________________________________________
Subject: Firefly swivel tailwheel
Date: Dec 04, 2016
Hopefully these are reduced in size enough. $160 from the factory, new heavier springs included. Wheel is 5" in diameter. There was a larger wheel assembly for the larger models. Stuart ________________________________________________________________________________
Subject: Re: Firefly swivel tailwheel
Date: Dec 04, 2016
On 12/4/2016 9:54 PM, Stuart Harner wrote: > Hopefully these are reduced in size enough. > > $160 from the factory, new heavier springs included. > > Wheel is 5" in diameter. There was a larger wheel assembly for the larger > models. > > Stuart If you depend on tailwheel steering, the 1st thing to do is replace those springs with compression style springs. Just sayin'.... ________________________________________________________________________________
Date: Dec 07, 2016
Subject: Re: Kolb-List Digest: 0 Msgs - 12/06/16
2007 BRS 600-CAN-TOP BRS-6 Now is time of year to install. Complete system for kolbs. In boxes never opened, never installed. Must be picked up or delivered. $3000. Make offer. Selling for friend who sold kolb it was going to be installed on. Ted Cowan. Alabama 334 332 3457. tc1917@bellsouth. net Sent from my iPhone > On Dec 7, 2016, at 2:02 AM, Kolb-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-12-06&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 16-12-06&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Tue 12/06/16: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Rotax 670 update
Date: Dec 07, 2016
dennis are you still flying the 670..? ive been researching a purchase. thank you in advance. -------- kenw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463773#463773 ________________________________________________________________________________
Subject: Re: anybody using a Rotax 670 in a Kolb Mk III?
Date: Dec 07, 2016
mike did you ever make the 670 engine decision? researching the 670 as an option... identical airframe thanks ken worth -------- kenw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463774#463774 ________________________________________________________________________________
Subject: Re: Kolb FSII for sale - This is where the pictures are
Date: Dec 09, 2016
Sold. Heading to Ohio. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463801#463801 ________________________________________________________________________________
Date: Dec 09, 2016
Yes, I ran my 690 from 2003 till 2014 on my Mk 3. Fine running smooth engine especially when I converted to 28mm Mikuni carbs. Took it off to replace it with a Rotax 670 in 2014 and would make you a great deal on the whole package with rads mounts and many extra parts. Dennis Rowe > On Dec 7, 2016, at 9:30 PM, kenw wrote: > > > mike did you ever make the 670 engine decision? > researching the 670 as an option... identical airframe > thanks ken worth > > -------- > kenw > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=463774#463774 > > > > > > > > > ________________________________________________________________________________
Date: Dec 09, 2016
If you are asking me, see my previous post. Have it sitting in the basement collecting dust. Dennis Rowe > On Dec 7, 2016, at 9:17 PM, kenw wrote: > > > dennis are you still flying the 670..? > ive been researching a purchase. > thank you in advance. > > -------- > kenw > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=463773#463773 > > > > > > > > > ________________________________________________________________________________
Subject: Kolb Sighting in Florida...well, kinda
Date: Dec 10, 2016
Long time Kolb fan and lurker... I did a double take the other night while watching a rerun of CSI Miami. Attached are a couple screen grabs with Kolb FS in frame. The episode originally aired in late 2011. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463821#463821 Attachments: http://forums.matronics.com//files/kolb_miami_season9_ep22_01_488.png http://forums.matronics.com//files/kolb_miami_season9_ep22_02_117.png http://forums.matronics.com//files/kolb_miami_season9_ep22_03_144.png ________________________________________________________________________________
Date: Dec 10, 2016
Wonder where the airstrip is located, and who owns the FS? john h mkIII Titus, Alabama - Hunkered down next to the fireplace this morning. -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Bolserst Sent: Saturday, December 10, 2016 10:11 AM Subject: Kolb-List: Kolb Sighting in Florida...well, kinda Long time Kolb fan and lurker... I did a double take the other night while watching a rerun of CSI Miami. Attached are a couple screen grabs with Kolb FS in frame. The episode originally aired in late 2011. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463821#463821 Attachments: http://forums.matronics.com//files/kolb_miami_season9_ep22_01_488.png http://forums.matronics.com//files/kolb_miami_season9_ep22_02_117.png http://forums.matronics.com//files/kolb_miami_season9_ep22_03_144.png ________________________________________________________________________________
Subject: Re: Kolb Sighting in Florida...well, kinda
Date: Dec 11, 2016
I was wondering that myself...and did figure it out the location. Although the location is identified in the show as Homestead General south west of Miami, it obviously isn't. The Wiki page for the show mentions nearly all filming is done in CA, not FL. The yellow trainer in the background is a Breese 2 and has the word SCHOOL under the right wing. A bit of searching turned up N18VE. http://www.airport-data.com/aircraft/photo/000535002.html The airport-data page mentions the owner is a member of VCUAS(Ventura County Ultralight Aircraft Society) which is based at the Camarillo airport. They have a separate ultralight area at the south west corner of the airport. Looks like the kolb was positioned just west of the first T-hangar. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463836#463836 Attachments: http://forums.matronics.com//files/camarillo_airport_swcorner_177.png ________________________________________________________________________________
Date: Dec 11, 2016
Thanks for the information. I landed at Homestead for fuel in 1994. Soon after the hurricane that devastated the airport. Took on 20 gallons of fuel. FOB was operating out of an old mobile home and pumping fuel out of an old rusty fuel truck. When I told the FOB where I had flown the past 40 days, he refused to take my money. His airport had been blown away. There was nothing left, yet he wanted to help me complete my flight. I met a lot of people like him on that flight in Alaska, Canada, and CONUS. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Bolserst Sent: Sunday, December 11, 2016 9:47 AM Subject: Kolb-List: Re: Kolb Sighting in Florida...well, kinda I was wondering that myself...and did figure it out the location. Although the location is identified in the show as Homestead General south west of Miami, it obviously isn't. The Wiki page for the show mentions nearly all filming is done in CA, not FL. The yellow trainer in the background is a Breese 2 and has the word SCHOOL under the right wing. A bit of searching turned up N18VE. http://www.airport-data.com/aircraft/photo/000535002.html The airport-data page mentions the owner is a member of VCUAS(Ventura County Ultralight Aircraft Society) which is based at the Camarillo airport. They have a separate ultralight area at the south west corner of the airport. Looks like the kolb was positioned just west of the first T-hangar. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463836#463836 Attachments: http://forums.matronics.com//files/camarillo_airport_swcorner_177.png ________________________________________________________________________________
Date: Dec 11, 2016
Subject: Kolb Twinstar Mark II weight and balance
Gentlemen, I have acquired a Kolb Twinstar Mark II built in 1989. =C2-However, it is missing one important piece of information: the weight & balance and gross weight document. =C2-I intend to weigh the plane and do a complete weigh t and balance workup, but it would really be nice to have some examples to work from. =C2- Could some of you Twinstar Mk II pilots send me images of your W&B or post them here? Thanks, Wayne S. N359RT ________________________________________________________________________________
Date: Dec 12, 2016
Dear John I have picked up your email on Pat's computer. I am sorry to tell you that Pat is terminally ill and is now in a nearby nursing home permanently. I am so sorry to be the bearer of such sad news. He has always enjoyed his association with the Kolb List. I would be grateful if you could circulate the list for me as I am unsure h ow to do this. Both Pat and I have fond memories of meeting you and the others in Monument Valley a few years ago. All the best to you all Wendy Ladd ________________________________ From: owner-kolb-list-server(at)matronics.com <owner-kolb-list-server@matronic s.com> on behalf of John Hauck Sent: 11 December 2016 16:40:06 Subject: RE: Kolb-List: Re: Kolb Sighting in Florida...well, kinda Thanks for the information. I landed at Homestead for fuel in 1994. Soon after the hurricane that devastated the airport. Took on 20 gallons of fuel. FOB was operating out of an old mobile home and pumping fuel out of an old rusty fuel truck. Whe n I told the FOB where I had flown the past 40 days, he refused to take my money. His airport had been blown away. There was nothing left, yet he wanted to help me complete my flight. I met a lot of people like him on that flight in Alaska, Canada, and CONUS. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Bolserst Sent: Sunday, December 11, 2016 9:47 AM Subject: Kolb-List: Re: Kolb Sighting in Florida...well, kinda I was wondering that myself...and did figure it out the location. Although the location is identified in the show as Homestead General south west of Miami, it obviously isn't. The Wiki page for the show mentions nearly all filming is done in CA, not FL. The yellow trainer in the background is a Breese 2 and has the word SCHOOL under the right wing. A bi t of searching turned up N18VE. http://www.airport-data.com/aircraft/photo/000535002.html The airport-data page mentions the owner is a member of VCUAS(Ventura Count y Ultralight Aircraft Society) which is based at the Camarillo airport. They have a separate ultralight area at the south west corner of the airport. Looks like the kolb was positioned just west of the first T-hangar. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463836#463836 Attachments: http://forums.matronics.com//files/camarillo_airport_swcorner_177.png rsbooks.com> m> > ________________________________________________________________________________
Date: Dec 12, 2016
On Mon, Dec 12, 2016 at 10:38 AM, Patrick Ladd wrote: > Dear John > > I have picked up your email on Pat's computer. I am sorry to tell you > that Pat is terminally ill and is now in a nearby nursing home permanentl y. > > I am so sorry to be the bearer of such sad news. He has always enjoyed > his association with the Kolb List. > > I would be grateful if you could circulate the list for me as I am unsure > how to do this. > > Both Pat and I have fond memories of meeting you and the others in > Monument Valley a few years ago. > > All the best to you all > > Wendy Ladd > =8BWendy -- Your posting was sent to the entire Kolb-List, so everyone now knows of Pat's situation. Thank you for letting us know. Our best wishes go with you, and tell Pat to keep his chin up! -- Robert =8B ________________________________________________________________________________
Date: Dec 12, 2016
Wendy: Sorry to hear about Patrick. I wish him well and will keep him in my prayers. Patrick and I go back a long way. He flew with a radio that had flown to Alaska in my MKIII. We met at Monument Valley about 2008. I have a photo of Patrick, John Williamson, and me, standing on the parking pad at MV airstrip. I found and attached the photo. I am going to miss Patrick's banter on the Kolb List. I know Larry Cottrell will miss Patrick's video/audio coaching. ;-) Take care my friend. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Patrick Ladd Sent: Monday, December 12, 2016 10:38 AM Subject: Re: Kolb-List: Re: Kolb Sighting in Florida...well, kinda Dear John I have picked up your email on Pat's computer. I am sorry to tell you that Pat is terminally ill and is now in a nearby nursing home permanently. I am so sorry to be the bearer of such sad news. He has always enjoyed his association with the Kolb List. I would be grateful if you could circulate the list for me as I am unsure how to do this. Both Pat and I have fond memories of meeting you and the others in Monument Valley a few years ago. All the best to you all Wendy Ladd ________________________________________________________________________________
Date: Dec 12, 2016
Subject: Firestar 2 Progress, slow but continuing
If I had not lost my camera, there would be photos attached to this post :) I have more or less finalized the layout and design for mounting my HKS engine on the Firestar. Thanks to two fellow EAA chapter members, I have the engine mounting plate cut, shaped, de-burred, lightened, and semi-smoothed. The engine mount plate is semi-permanently mounted on the Kolb airframe Lord mounts. Putting the correct length bolts in and installing the self-lock nuts instead of the "shop work" plain nuts is the last step. The 3/8" aluminum engine mount plate was designed with a "wing-shaped" extension on the starboard forward corner to serve as the rear mounting for the oil cooler. After much head-scratching and "staring at it", the final position of the oi l cooler was determined, and a rear mounting bracket was fabricated from three pieces of aerospace surplus 2024-T3 extruded angle and (8) AN470AD4 rivets. Since the rear of the cooler is mounted on something that moves, the forward mounting had to provide enough "compliance" movement on all three axes. The forward mount is a standoff with a single central pivot bolt that is retained through two rubber grommets. This standoff mount is attached to the spar carry-through using modified rubber-padded Adel clamps. This flexible mount arrangement prevents the oil cooler itself from flexing, keeps the front of the cooler attached securely to the airframe, but allows movement in any direction and rotational movement on the bolt axis. The oil cooler is about 1.5 x 4 x 13 inches, and mounts lengthwise just inboard of the starboard wing root. The top surface of the cooler is flush with the top of the wing. Ram air will be fed to the cooler from a scoop on the underside of the center section wing cover, travel upwards through the cooler, and exit into the lower pressure airflow above the wing. Because the cooler is located a foot behind the thickest point of the airfoil the "low pressure" area above the wing is not 100% ideal, but it will still be far lower ambient pressure than the underside of the wing. In order to have more of a pressure drop across the cooler, I would have needed to move the cooler forward near the wing leading edge, and this would require a more complex and heavier cantilever mounting system. The engine has been mounted onto the engine mount plate more or less permanently. I went from 1 inch risers under the engine to 2 inch risers. I believe this is how Larry C's engine is mounted. Because I didn't want to raise the engine any higher, there was still a difficult interference problem with the aileron torque tubes and the exhaust pipes. I decided to use the system shown recently on the photographs that were posted on the List.... a Y shaped exhaust with the pipes coming inboard from the cylinders, meeting under the engine, and the main muffler or exhaust pipe traveling vertically down the rear of the steel cage. The large (dry sump) oil tank was another vexing problem that was finally (FINALLY!) resolved to my satisfaction after weeks of head-scratching. A small weldment consisting of two "half-pipe" pieces of steel tube crossed at 90 degrees will allow the tank to mount directly to the Kolb keel tube, keeping it out of the fuel and baggage areas and keeping the oil lines shorter/lighter. This weldment will use large screw type "hose clamps" to hold the tank to the mount,and the mount to the airframe. The HKS installation manual specifies a limited range of "height" where the oil tank can be mounted. Too high above the oil pump and it will flood or drown the oil pump, too low will make the oil pump work too hard to lift the oil out of the tank. While waiting for this oil tank mount to be "finish-welded", I have started on designing and fabricating the ignition component mounting plate, which will be Adel clamped to the keel tube and the port side steel spar carry-through structure.This will keep the ignition coils, electronic controllers, etc.close to the engine and keep it out of the fuel and baggage areas. The repairs to the cockpit longerons (bending them back straight), and the structural doublers to the wing spar pin attach lugs have been completed. Only a couple of squirts of Zinc Chromate on the spar root main doubler plates remain. After that all of the crash damage will have been repaired. Progress is agonizingly slow. But I'm trying to do things right, and extra safe. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Mon, 12/12/16, John Hauck wrote: Subject: RE: Kolb-List: Re: Kolb Sighting in Florida...well, kinda To: kolb-list(at)matronics.com Date: Monday, December 12, 2016, 2:05 PM Wendy: Sorry to hear about Patrick. I wish him well and will keep him in my prayers. Patrick and I go back a long way. He flew with a radio that had flown to Alaska in my MKIII. We met at Monument Valley about 2008. I have a photo of Patrick, John Williamson, and me, standing on the parking pad at MV airstrip. I found and attached the photo. I am going to miss Patrick's banter on the Kolb List. I know Larry Cottrell will miss Patrick's video/audio coaching. ;-) Take care my friend. john hmkIIITitus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Patrick Ladd Sent: Monday, December 12, 2016 10:38 AM To: kolb-list(at)matronics.com Subject: Re: Kolb-List: Re: Kolb Sighting in Florida...well, kinda Dear JohnI have picked up your email on Pat's computer. I am sorry to tell you that Pat is terminally ill and is now in a nearby nursing home permanently.I am so sorry to be the bearer of such sad news. He has always enjoyed his association with the Kolb List.I would be grateful if you could circulate the list for me as I am unsure how to do this.Both Pat and I have fond memories of meeting you and the others in Monument Valley a few years ago.All the best to you allWendy Ladd ________________________________________________________________________________
Subject: Re: Firestar 2 Progress, slow but continuing
Date: Dec 12, 2016
Anybody who can afford an HKS and do all that stuff can afford a camera; so - pictures or you are making it all up. JUST KIDDING! Seriously, looking forward to pictures. Merry Christmas, keep up the good work. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463871#463871 ________________________________________________________________________________
Subject: Airport Courtesy Cars App Closing?
Date: Dec 14, 2016
IMPORTANT! If you are a user of the app version of Airport Courtesy Cars, please view it for an important message about the possible closure of the app, or view the page here: https://www.airportcourtesycars.com/app-status.html -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Smart Phone App and www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463924#463924 ________________________________________________________________________________
Date: Dec 15, 2016
If I understand this correctly, you mounted your oil cooler to the engine base plate which is setting on Lord mounts, and also to the rear spar carry through? Sounds sketchy at best, I'd let the oil hoses do the flexing and mount the cooler to the airframe only, away from the shaking engine. Dennis Rowe Mk3 Rotax 670 > On Dec 12, 2016, at 6:50 PM, Bill Berle wrote: > > > If I had not lost my camera, there would be photos attached to this post :) > > I have more or less finalized the layout and design for mounting my HKS engine on the Firestar. Thanks to two fellow EAA chapter members, I have the engine mounting plate cut, shaped, de-burred, lightened, and semi-smoothed. The engine mount plate is semi-permanently mounted on the Kolb airframe Lord mounts. Putting the correct length bolts in and installing the self-lock nuts instead of the "shop work" plain nuts is the last step. > > The 3/8" aluminum engine mount plate was designed with a "wing-shaped" extension on the starboard forward corner to serve as the rear mounting for the oil cooler. After much head-scratching and "staring at it", the final position of the oi l cooler was determined, and a rear mounting bracket was fabricated from three pieces of aerospace surplus 2024-T3 extruded angle and (8) AN470AD4 rivets. Since the rear of the cooler is mounted on something that moves, the forward mounting had to provide enough "compliance" movement on all three axes. The forward mount is a standoff with a single central pivot bolt that is retained through two rubber grommets. This standoff mount is attached to the spar carry-through using modified rubber-padded Adel clamps. This flexible mount arrangement prevents the oil cooler itself from flexing, keeps the front of the cooler attached securely to the airframe, but allows movement in any direction and rotational movement on the bolt axis. > > The oil cooler is about 1.5 x 4 x 13 inches, and mounts lengthwise just inboard of the starboard wing root. The top surface of the cooler is flush with the top of the wing. Ram air will be fed to the cooler from a scoop on the underside of the center section wing cover, travel upwards through the cooler, and exit into the lower pressure airflow above the wing. Because the cooler is located a foot behind the thickest point of the airfoil the "low pressure" area above the wing is not 100% ideal, but it will still be far lower ambient pressure than the underside of the wing. In order to have more of a pressure drop across the cooler, I would have needed to move the cooler forward near the wing leading edge, and this would require a more complex and heavier cantilever mounting system. > > The engine has been mounted onto the engine mount plate more or less permanently. I went from 1 inch risers under the engine to 2 inch risers. I believe this is how Larry C's engine is mounted. Because I didn't want to raise the engine any higher, there was still a difficult interference problem with the aileron torque tubes and the exhaust pipes. I decided to use the system shown recently on the photographs that were posted on the List.... a Y shaped exhaust with the pipes coming inboard from the cylinders, meeting under the engine, and the main muffler or exhaust pipe traveling vertically down the rear of the steel cage. > > The large (dry sump) oil tank was another vexing problem that was finally (FINALLY!) resolved to my satisfaction after weeks of head-scratching. A small weldment consisting of two "half-pipe" pieces of steel tube crossed at 90 degrees will allow the tank to mount directly to the Kolb keel tube, keeping it out of the fuel and baggage areas and keeping the oil lines shorter/lighter. This weldment will use large screw type "hose clamps" to hold the tank to the mount,and the mount to the airframe. The HKS installation manual specifies a limited range of "height" where the oil tank can be mounted. Too high above the oil pump and it will flood or drown the oil pump, too low will make the oil pump work too hard to lift the oil out of the tank. > > While waiting for this oil tank mount to be "finish-welded", I have started on designing and fabricating the ignition component mounting plate, which will be Adel clamped to the keel tube and the port side steel spar carry-through structure.This will keep the ignition coils, electronic controllers, etc.close to the engine and keep it out of the fuel and baggage areas. > > The repairs to the cockpit longerons (bending them back straight), and the structural doublers to the wing spar pin attach lugs have been completed. Only a couple of squirts of Zinc Chromate on the spar root main doubler plates remain. After that all of the crash damage will have been repaired. > > Progress is agonizingly slow. But I'm trying to do things right, and extra safe. > > > > > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Mon, 12/12/16, John Hauck wrote: > > Subject: RE: Kolb-List: Re: Kolb Sighting in Florida...well, kinda > To: kolb-list(at)matronics.com > Date: Monday, December 12, 2016, 2:05 PM > > Wendy: Sorry to hear about > Patrick. I wish him well and will keep him in my > prayers. Patrick and I go back a long > way. He flew with a radio that had flown to Alaska in > my MKIII. We met at Monument Valley about 2008. > I have a photo of Patrick, John Williamson, and me, standing > on the parking pad at MV airstrip. I found and > attached the photo. I am going to miss > Patrick's banter on the Kolb List. I know Larry > Cottrell will miss Patrick's video/audio coaching. > ;-) Take care my > friend. john hmkIIITitus, Alabama From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf > Of Patrick Ladd > Sent: Monday, December 12, 2016 10:38 AM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: Kolb Sighting in > Florida...well, kinda Dear JohnI > have picked up your email on Pat's computer. I am > sorry to tell you that Pat is terminally ill and is now in a > nearby nursing home permanently.I > am so sorry to be the bearer of such sad news. He has > always enjoyed his association with the Kolb > List.I would be grateful if you could > circulate the list for me as I am unsure how to do > this.Both Pat and I have fond memories > of meeting you and the others in Monument Valley a few years > ago.All the best to you > allWendy > Ladd > > > > > ________________________________________________________________________________
Date: Dec 15, 2016
That's not quite correct Dennis, I mounted the rear of the oil cooler to the engine mount plate, and the front of the oil cooler to the forward (main) spar carry-trough tube. The front mount has rubber grommets and a pivot bolt, to prevent the cooler from flexing, twisting, or bending. Essentially this design creates a movable mount that is clamped to a fixed part of the airframe. Tonight after work the oil tank mount gets finish-welded and hopefully painted, and mounted to the airframe.. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Thu, 12/15/16, Dennis Rowe wrote: Subject: Re: Kolb-List: Firestar 2 Progress, slow but continuing To: kolb-list(at)matronics.com Date: Thursday, December 15, 2016, 2:13 PM Dennis Rowe If I understand this correctly, you mounted your oil cooler to the engine base plate which is setting on Lord mounts, and also to the rear spar carry through? Sounds sketchy at best, I'd let the oil hoses do the flexing and mount the cooler to the airframe only, away from the shaking engine. Dennis Rowe Mk3 Rotax 670 > On Dec 12, 2016, at 6:50 PM, Bill Berle wrote: > > > If I had not lost my camera, there would be photos attached to this post :) > > I have more or less finalized the layout and design for mounting my HKS engine on the Firestar. Thanks to two fellow EAA chapter members, I have the engine mounting plate cut, shaped, de-burred, lightened, and semi-smoothed. The engine mount plate is semi-permanently mounted on the Kolb airframe Lord mounts. Putting the correct length bolts in and installing the self-lock nuts instead of the "shop work" plain nuts is the last step. > > The 3/8" aluminum engine mount plate was designed with a "wing-shaped" extension on the starboard forward corner to serve as the rear mounting for the oil cooler. After much head-scratching and "staring at it", the final position of the oi l cooler was determined, and a rear mounting bracket was fabricated from three pieces of aerospace surplus 2024-T3 extruded angle and (8) AN470AD4 rivets. Since the rear of the cooler is mounted on something that moves, the forward mounting had to provide enough "compliance" movement on all three axes. The forward mount is a standoff with a single central pivot bolt that is retained through two rubber grommets. This standoff mount is attached to the spar carry-through using modified rubber-padded Adel clamps. This flexible mount arrangement prevents the oil cooler itself from flexing, keeps the front of the cooler attached securely to the airframe, but allows movement in any direction and rotational movement on the bolt axis. > > The oil cooler is about 1.5 x 4 x 13 inches, and mounts lengthwise just inboard of the starboard wing root. The top surface of the cooler is flush with the top of the wing. Ram air will be fed to the cooler from a scoop on the underside of the center section wing cover, travel upwards through the cooler, and exit into the lower pressure airflow above the wing. Because the cooler is located a foot behind the thickest point of the airfoil the "low pressure" area above the wing is not 100% ideal, but it will still be far lower ambient pressure than the underside of the wing. In order to have more of a pressure drop across the cooler, I would have needed to move the cooler forward near the wing leading edge, and this would require a more complex and heavier cantilever mounting system. > > The engine has been mounted onto the engine mount plate more or less permanently. I went from 1 inch risers under the engine to 2 inch risers. I believe this is how Larry C's engine is mounted. Because I didn't want to raise the engine any higher, there was still a difficult interference problem with the aileron torque tubes and the exhaust pipes. I decided to use the system shown recently on the photographs that were posted on the List.... a Y shaped exhaust with the pipes coming inboard from the cylinders, meeting under the engine, and the main muffler or exhaust pipe traveling vertically down the rear of the steel cage. > > The large (dry sump) oil tank was another vexing problem that was finally (FINALLY!) resolved to my satisfaction after weeks of head-scratching. A small weldment consisting of two "half-pipe" pieces of steel tube crossed at 90 degrees will allow the tank to mount directly to the Kolb keel tube, keeping it out of the fuel and baggage areas and keeping the oil lines shorter/lighter. This weldment will use large screw type "hose clamps" to hold the tank to the mount,and the mount to the airframe. The HKS installation manual specifies a limited range of "height" where the oil tank can be mounted. Too high above the oil pump and it will flood or drown the oil pump, too low will make the oil pump work too hard to lift the oil out of the tank. > > While waiting for this oil tank mount to be "finish-welded", I have started on designing and fabricating the ignition component mounting plate, which will be Adel clamped to the keel tube and the port side steel spar carry-through structure.This will keep the ignition coils, electronic controllers, etc.close to the engine and keep it out of the fuel and baggage areas. > > The repairs to the cockpit longerons (bending them back straight), and the structural doublers to the wing spar pin attach lugs have been completed. Only a couple of squirts of Zinc Chromate on the spar root main doubler plates remain. After that all of the crash damage will have been repaired. > > Progress is agonizingly slow. But I'm trying to do things right, and extra safe. > > > > > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Mon, 12/12/16, John Hauck wrote: > > Subject: RE: Kolb-List: Re: Kolb Sighting in Florida...well, kinda > To: kolb-list(at)matronics.com > Date: Monday, December 12, 2016, 2:05 PM > > Wendy: Sorry to hear about > Patrick. I wish him well and will keep him in my > prayers. Patrick and I go back a long > way. He flew with a radio that had flown to Alaska in > my MKIII. We met at Monument Valley about 2008. > I have a photo of Patrick, John Williamson, and me, standing > on the parking pad at MV airstrip. I found and > attached the photo. I am going to miss > Patrick's banter on the Kolb List. I know Larry > Cottrell will miss Patrick's video/audio coaching. > ;-) Take care my > friend. john hmkIIITitus, Alabama From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf > Of Patrick Ladd > Sent: Monday, December 12, 2016 10:38 AM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: Kolb Sighting in > Florida...well, kinda Dear JohnI > have picked up your email on Pat's computer. I am > sorry to tell you that Pat is terminally ill and is now in a > nearby nursing home permanently.I > am so sorry to be the bearer of such sad news. He has > always enjoyed his association with the Kolb > List.I would be grateful if you could > circulate the list for me as I am unsure how to do > this.Both Pat and I have fond memories > of meeting you and the others in Monument Valley a few years > ago.All the best to you > allWendy > Ladd > > > > > Lists This Month -- Some AWESOME FREE Gifts!) Raiser. Click on more about Gifts provided www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com www.mypilotstore.com www.mrrace.com -Matt Dralle, List Admin. Forum - - MATRONICS WEB FORUMS - MATRONICS LIST WIKI - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Dec 15, 2016
From: "brubakermal(at)yahoo.com" <brubakermal(at)yahoo.com>
Subject: 912 install
I am making a list for a install of a 912. fuel lines .wiring plugs. coolen t hoses .clamps . Im installing a Grand Rapids- EIS.- =0A=0ASent from Y ahoo Mail on Android=0A=0A ________________________________________________________________________________
Date: Dec 15, 2016
Recommend mounting cooler to airframe with shock mounts. I used 4 each 582 radiator shock mounts to hang my coolers, coolant and oil, piggy backed, from the rear of the fuselage. My experience mounting accessories to the engine resulted in severe vibration fatigue. I have my doubts the way you are mounting your cooler, engine mount and rubber grommets to the airframe. If you decide to go that route, and I think you have, let us know how it works out after a 100 hours or so. john h mkIII Titus, Al -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Bill Berle Sent: Thursday, December 15, 2016 4:39 PM Subject: Re: Kolb-List: Firestar 2 Progress, slow but continuing That's not quite correct Dennis, I mounted the rear of the oil cooler to the engine mount plate, and the front of the oil cooler to the forward (main) spar carry-trough tube. The front mount has rubber grommets and a pivot bolt, to prevent the cooler from flexing, twisting, or bending. Essentially this design creates a movable mount that is clamped to a fixed part of the airframe. Tonight after work the oil tank mount gets finish-welded and hopefully painted, and mounted to the airframe.. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Thu, 12/15/16, Dennis Rowe wrote: Subject: Re: Kolb-List: Firestar 2 Progress, slow but continuing To: kolb-list(at)matronics.com Date: Thursday, December 15, 2016, 2:13 PM Dennis Rowe If I understand this correctly, you mounted your oil cooler to the engine base plate which is setting on Lord mounts, and also to the rear spar carry through? Sounds sketchy at best, I'd let the oil hoses do the flexing and mount the cooler to the airframe only, away from the shaking engine. Dennis Rowe Mk3 Rotax 670 > On Dec 12, 2016, at 6:50 PM, Bill Berle wrote: > plain nuts is the last step. > > The 3/8" aluminum engine mount plate was designed with a "wing-shaped" extension on the starboard forward corner to serve as the rear mounting for the oil cooler. After much head-scratching and "staring at it", the final position of the oi l cooler was determined, and a rear mounting bracket was fabricated from three pieces of aerospace surplus 2024-T3 extruded angle and (8) AN470AD4 rivets. Since the rear of the cooler is mounted on something that moves, the forward mounting had to provide enough "compliance" movement on all three axes. The forward mount is a standoff with a single central pivot bolt that is retained through two rubber grommets. This standoff mount is attached to the spar carry-through using modified rubber-padded Adel clamps. This flexible mount arrangement prevents the oil cooler itself from flexing, keeps the front of the cooler attached securely to the airframe, but allows movement in any direction and rotational movement on the bolt axis. > > The oil cooler is about 1.5 x 4 x 13 inches, and mounts lengthwise just inboard of the starboard wing root. The top surface of the cooler is flush with the top of the wing. Ram air will be fed to the cooler from a scoop on the underside of the center section wing cover, travel upwards through the cooler, and exit into the lower pressure airflow above the wing. Because the cooler is located a foot behind the thickest point of the airfoil the "low pressure" area above the wing is not 100% ideal, but it will still be far lower ambient pressure than the underside of the wing. In order to have more of a pressure drop across the cooler, I would have needed to move the cooler forward near the wing leading edge, and this would require a more complex and heavier cantilever mounting system. > > The engine has been mounted onto the engine mount plate more or less permanently. I went from 1 inch risers under the engine to 2 inch risers. I believe this is how Larry C's engine is mounted. Because I didn't want to raise the engine any higher, there was still a difficult interference problem with the aileron torque tubes and the exhaust pipes. I decided to use the system shown recently on the photographs that were posted on the List.... a Y shaped exhaust with the pipes coming inboard from the cylinders, meeting under the engine, and the main muffler or exhaust pipe traveling vertically down the rear of the steel cage. > > The large (dry sump) oil tank was another vexing problem that was finally (FINALLY!) resolved to my satisfaction after weeks of head-scratching. A small weldment consisting of two "half-pipe" pieces of steel tube crossed at 90 degrees will allow the tank to mount directly to the Kolb keel tube, keeping it out of the fuel and baggage areas and keeping the oil lines shorter/lighter. This weldment will use large screw type "hose clamps" to hold the tank to the mount,and the mount to the airframe. The HKS installation manual specifies a limited range of "height" where the oil tank can be mounted. Too high above the oil pump and it will flood or drown the oil pump, too low will make the oil pump work too hard to lift the oil out of the tank. > > While waiting for this oil tank mount to be "finish-welded", I have started on designing and fabricating the ignition component mounting plate, which will be Adel clamped to the keel tube and the port side steel spar carry-through structure.This will keep the ignition coils, electronic controllers, etc.close to the engine and keep it out of the fuel and baggage areas. > > The repairs to the cockpit longerons (bending them back straight), and the structural doublers to the wing spar pin attach lugs have been completed. Only a couple of squirts of Zinc Chromate on the spar root main doubler plates remain. After that all of the crash damage will have been repaired. > > Progress is agonizingly slow. But I'm trying to do things right, and extra safe. > > > > > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Mon, 12/12/16, John Hauck wrote: > > Subject: RE: Kolb-List: Re: Kolb Sighting in Florida...well, kinda > To: kolb-list(at)matronics.com > Date: Monday, December 12, 2016, 2:05 PM > > Wendy: Sorry to hear about > Patrick. I wish him well and will keep him in my > prayers. Patrick and I go back a long > way. He flew with a radio that had flown to Alaska in > my MKIII. We met at Monument Valley about 2008. > I have a photo of Patrick, John Williamson, and me, standing > on the parking pad at MV airstrip. I found and > attached the photo. I am going to miss > Patrick's banter on the Kolb List. I know Larry > Cottrell will miss Patrick's video/audio coaching. > ;-) Take care my > friend. john hmkIIITitus, Alabama From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf > Of Patrick Ladd > Sent: Monday, December 12, 2016 10:38 AM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: Kolb Sighting in > Florida...well, kinda Dear JohnI > have picked up your email on Pat's computer. I am > sorry to tell you that Pat is terminally ill and is now in a > nearby nursing home permanently.I > am so sorry to be the bearer of such sad news. He has > always enjoyed his association with the Kolb > List.I would be grateful if you could > circulate the list for me as I am unsure how to do > this.Both Pat and I have fond memories > of meeting you and the others in Monument Valley a few years > ago.All the best to you > allWendy > Ladd > > > > > Lists This Month -- Some AWESOME FREE Gifts!) Raiser. Click on more about Gifts provided www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com www.mypilotstore.com www.mrrace.com -Matt Dralle, List Admin. Forum - - MATRONICS WEB FORUMS - MATRONICS LIST WIKI - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Dec 15, 2016
OK, your first post was 3 days ago and you still don't have any pictures and my feeble mind is having trouble figuring out just exactly what it is you are doing. Do we need to take up a collection and buy you a camera, so you can post pictures? (Appropriately resized of course) [Rolling Eyes] And I say this with a clear conscience, because I spent Monday and Tuesday finishing up the brake disc mounts/spacers for the FF wheels, and yesterday I finished welding up the aileron linkage and lower cage tubes, took pictures, and sent them to my partner for his approval, and have already heard back. C'mon you slacker, post some pictures! [Laughing] -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Would you consider yourself to be a good person? https://www.youtube.com/watch?v=VWcDXT6pH7A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463959#463959 ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 5 Msgs - 12/15/16
Date: Dec 16, 2016
QSA0NDcgd291bGQgYmUgYSBsb3Qgc2ltcGxlciAgIQ0K ________________________________________________________________________________
Date: Dec 16, 2016
OK , So... why don't we get any pictures? -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463967#463967 ________________________________________________________________________________
Date: Dec 16, 2016
John H and Kolbers, I realize full well that the oil cooler installation I described is "outside the box" and not common. You will have to trust me that I did NOT do it this way just to be a smart aleck (although I'm usually guilty of that too). My first idea with the cooler was exactly as John H described... vertically mounted at the rear of the fuselage cage. Would have been easy-peasy. But this created two problems. First it would require longer oil hoses to go back and forth between the cooler and the engine AND the oil tank. The HKS manual specifically suggests keeping the oil lines short. Second, the exhaust will be running through that same area right behind the cage. I wanted to keep any oil leakage or seeping from the cooler away from exhaust components for fire safety. More importantly, mounting the exhaust system directly behind the cooler would impede the outflow of air through the cooler, reducing the effectiveness of the cooler. Nothing would have made me happier than being able to mount the cooler to the airframe only. But the engine mounting structure/configuration of the Kolb was done with the Rotax 2 stroke engine in mind, and adapting another entire class of engine to it creates all sorts of problems. Another recent poster (and a whole lot of previous posts) was 100% right... leaving the 447 on it would have been much easier. But I have a good reason to want a 4 stroke engine, and I have to put my nose to the grindstone and do what it takes to do things right. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities ________________________________________________________________________________
Date: Dec 16, 2016
I don't know that I fully understand the way you have mounted the oil cooler. How about posting some photos. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Bill Berle Sent: Friday, December 16, 2016 3:34 PM Subject: RE: Kolb-List: Firestar 2 Progress, slow but continuing John H and Kolbers, I realize full well that the oil cooler installation I described is "outside the box" and not common. You will have to trust me that I did NOT do it this way just to be a smart aleck (although I'm usually guilty of that too). My first idea with the cooler was exactly as John H described... vertically mounted at the rear of the fuselage cage. Would have been easy-peasy. But this created two problems. First it would require longer oil hoses to go back and forth between the cooler and the engine AND the oil tank. The HKS manual specifically suggests keeping the oil lines short. Second, the exhaust will be running through that same area right behind the cage. I wanted to keep any oil leakage or seeping from the cooler away from exhaust components for fire safety. More importantly, mounting the exhaust system directly behind the cooler would impede the outflow of air through the cooler, reducing the effectiveness of the cooler. Nothing would have made me happier than being able to mount the cooler to the airframe only. But the engine mounting structure/configuration of the Kolb was done with the Rotax 2 stroke engine in mind, and adapting another entire class of engine to it creates all sorts of problems. Another recent poster (and a whole lot of previous posts) was 100% right... leaving the 447 on it would have been much easier. But I have a good reason to want a 4 stroke engine, and I have to put my nose to the grindstone and do what it takes to do things right. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities ________________________________________________________________________________
Date: Dec 16, 2016
Yeah, I figure I owe the group some photos after getting everyone all riled up again :) I will borrow a camera Saturday if I can't find mine. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Fri, 12/16/16, John Hauck wrote: Subject: RE: Kolb-List: Firestar 2 Progress, slow but continuing To: kolb-list(at)matronics.com Date: Friday, December 16, 2016, 1:49 PM "John Hauck" I don't know that I fully understand the way you have mounted the oil cooler. How about posting some photos. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Bill Berle Sent: Friday, December 16, 2016 3:34 PM To: kolb-list(at)matronics.com Subject: RE: Kolb-List: Firestar 2 Progress, slow but continuing John H and Kolbers, I realize full well that the oil cooler installation I described is "outside the box" and not common. You will have to trust me that I did NOT do it this way just to be a smart aleck (although I'm usually guilty of that too). My first idea with the cooler was exactly as John H described... vertically mounted at the rear of the fuselage cage. Would have been easy-peasy. But this created two problems. First it would require longer oil hoses to go back and forth between the cooler and the engine AND the oil tank. The HKS manual specifically suggests keeping the oil lines short. Second, the exhaust will be running through that same area right behind the cage. I wanted to keep any oil leakage or seeping from the cooler away from exhaust components for fire safety. More importantly, mounting the exhaust system directly behind the cooler would impede the outflow of air through the cooler, reducing the effectiveness of the cooler. Nothing would have made me happier than being able to mount the cooler to the airframe only. But the engine mounting structure/configuration of the Kolb was done with the Rotax 2 stroke engine in mind, and adapting another entire class of engine to it creates all sorts of problems. Another recent poster (and a whole lot of previous posts) was 100% right... leaving the 447 on it would have been much easier. But I have a good reason to want a 4 stroke engine, and I have to put my nose to the grindstone and do what it takes to do things right. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities Lists This Month -- Some AWESOME FREE Gifts!) Raiser. Click on more about Gifts provided www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com www.mypilotstore.com www.mrrace.com -Matt Dralle, List Admin. Forum - - MATRONICS WEB FORUMS - MATRONICS LIST WIKI - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Dec 16, 2016
Subject: Kolb Firestar 2 kit For Sale
This is a reminder for the Kolb group that I have a partially completed Firestar 2 kit project for sale. This can be sold with or without a low time Rotax 447. Had to promise the wife that if I bought a completed Firestar I would sell the kit project that I had been working on. I'd rather keep it and build it (was enjoying the build), but a promise is a promise... especially with a 12 gauge pointed at my head. Sell or trade. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities ________________________________________________________________________________
Subject: Re: Airport Courtesy Cars App Closing?
Date: Dec 18, 2016
I am happy to report that thanks to donations, the site continues. View the donors or add your name by clicking here: https://www.airportcourtesycars.com/thank-you-donors-.html Thanks, Glenn -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Smart Phone App and www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464112#464112 ________________________________________________________________________________
Date: Dec 19, 2016
Trying like hell to attach photos as prmoised.... my e-mail posting keeps getting rejected. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities ________________________________________________________________________________
Date: Dec 19, 2016
Bill A suggestion...I use Photobucket... Its a web site where you can post your pictures for free...and there seems to be no problem with picture size... With that, all you need to do is post the link here buy doing a copy and paste...Herb On 12/19/2016 12:46 AM, Bill Berle wrote: > > Trying like hell to attach photos as prmoised.... my e-mail posting keeps getting rejected. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Dec 19, 2016
Bill Here is my example...Herb http://s1248.photobucket.com/user/herbgh/library/?sort=3&page=1 On 12/19/2016 12:46 AM, Bill Berle wrote: > > Trying like hell to attach photos as prmoised.... my e-mail posting keeps getting rejected. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -- "Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." Aristotle "Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter... ________________________________________________________________________________
Date: Dec 19, 2016
Let's see if we can attach a photo in Alabama. May be a California thing. John Williamson and me at one of the early Kolb Homecomings. john h mkIII Titus, Alabama Trying like hell to attach photos as prmoised.... my e-mail posting keeps getting rejected. Bill Berle ________________________________________________________________________________
Subject: HKS
Date: Dec 19, 2016
Larry Think I said...I have the 80 hour...second gen HKS on a Rans S-14... Wondering if it was a big job to install one on the Firestar? I have two 503's...well actually three..since I have one on the Challenger 2 that was in the pics that you saw... My thought is to move the HKS to the Firestar and install a 503 on the Rans... So...a question....or two..firstly how many brackets and the like were you required to make and two..did you make your own hoses for the dry sump? Herb ________________________________________________________________________________
Date: Dec 19, 2016
Subject: Re: HKS
I didn't have to make any brackets other than for my oil cooler and tank. I think that I got every thing I needed from Jerry @Green sky. The mounting plate has to have a divot in it to accommedate the sump on the HKS, as well as . Jerry had some brackets that he made for the mags and other electrical stuff. I received the hose and fittings from him as well, and every thing worked out well. I left the muffler where he suggested, but changed the oil cooler to the back of the cage. You might check with Berle and see what if any improvements he came up with. I will be glad to furnish you with any pictures you might want and between Bill Berle and myself find something that will fit what you want. Larry On Mon, Dec 19, 2016 at 9:01 AM, Herb wrote: > > Larry > > Think I said...I have the 80 hour...second gen HKS on a Rans S-14... > Wondering if it was a big job to install one on the Firestar? I have two > 503's...well actually three..since I have one on the Challenger 2 that was > in the pics that you saw... My thought is to move the HKS to the Firestar > and install a 503 on the Rans... > > So...a question....or two..firstly how many brackets and the like were > you required to make and two..did you make your own hoses for the dry > sump? Herb > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Dec 19, 2016
Subject: photo test
Bill Berle www.ezflaphandle.com=C2- - safety & performance upgrade for light aircraf t www.grantstar.net =C2- =C2- =C2- =C2- =C2- - winning proposals fo r non-profit and for-profit entities -------------------------------------------- /9j/4Vp7RXhpZgAASUkqAAgAAAANAAABBAABAAAAAAUAAAEBBAABAAAA0AIAAA8BAgAIAAAAqgAA ABABAgAQAAAAsgAAABIBAwABAAAAAQAAABoBBQABAAAAwgAAABsBBQABAAAAygAAACgBAwABAAAA AgAAADEBAgAMAAAA0gAAADIBAgAUAAAA3gAAABMCAwABAAAAAQAAAGmHBAABAAAA8gAAACWIBAAB AAAAThMAAGATAABTQU1TVU5HAFNBTVNVTkctU0dILUk3NDdIAAAAAQAAAEgAAAABAAAASTc0N1VD VUZOSjIAMjAxNjowNzozMCAxOToxMzo1MQAeAJqCBQABAAAAYAIAAJ2CBQABAAAAaAIAACKIAwAB AAAAAwAAACeIAwABAAAAZAAAAACQBwAEAAAAMDIyMAOQAgAUAAAAcAIAAASQAgAUAAAAhAIAAAGR BwAEAAAAAQIDAAGSCgABAAAAmAIAAAKSBQABAAAAoAIAAAOSCgABAAAAqAIAAASSCgABAAAAsAIA AAWSBQABAAAAuAIAAAeSAwABAAAAAgAAAAiSAwABAAAAAAAAAAmSAwABAAAAAAAAAAqSBQABAAAA wAIAAHySBwBiAAAAzhIAAIaSBwAAEAAAyAIAAACgBwAEAAAAMDEwMAGgAwABAAAAAQAAAAKgBAAB AAAAAAUAAAOgBAABAAAA0AIAAAWgBAABAAAAMBMAABeiAwABAAAAAgAAAAGjAwABAAAAAQAAAAKk AwABAAAAAAAAAAOkAwABAAAAAAAAAAakAwABAAAAAAAAACCkAgAGAAAAyBIAAAAAAAABAAAAPAAA ABoAAAAKAAAAMjAxNjowNzozMCAxOToxMzo1MQAyMDE2OjA3OjMwIDE5OjEzOjUxAOgFAAAAAQAA FAEAAGQAAAC0AwAAAAEAAAAAAAAKAAAAFAEAAGQAAAByAQAAZAAAAEFTQ0lJAAAAAAAAAOgFAAC0 AwAAPAAAAHhWNBJ4VjQSeFY0EnhWNBIAAAAAAAABAGAAVgMMAOgE1ggAAAsAAAD//9onHQAAAAAA hAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD9/QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAEMAQQBMAEdERkQwNgAAAABDdXIuR0RGSTAyQ01MADAxODAwMTAwMTUwOTAwMjkw MTA5MDUwMjAxMEQwMTBEMDEwRDA5MEQT7wUAAAEAGBLrJgAAAwAAAABUAFUATgBBAAMA0ALoBXwE TglOBEFDAgAAAAEA/3ABAGOTAQB7Wv//IhIAAODZ//+9SQEAY9z//0gNAAB8Xv//PJQBAAAARkxG TAIAU1ZOIw0BDQkAAAAAAAAFAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAK4AAAABANAC6AV8BDwJTgROBDwJCRUDAIIJSQnp/xAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAABJKj4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAQAAWAIQAAAAAAAAAAAAAAAAAAAAIAOsB/f8NAQoBAAEAATgAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAABKS0pLAgWuBAEAv/gAAHN1AABoiwAAwgsCAAAAAQBChQEAAQAAAADoBQAA fAQAAE4EAAAAAAAAAAAALkMCAAAAAQAPcQEAQUMCAAAAAQD/cAEAY5MBAHta//8iEgAA4Nn//71J AQBj3P//SA0AAHxe//88lAEASktKS1EzAwBRMwMAUTMDADEiAgAxIgIAQSICAEEiAgBBIgIAQSIC AEEiAgBAEQEAMSICAJERAQCREQEAkREBAJERAQAxIgIAMSICADEiAgAxIgIAMSICADEiAgAwEQEA ESICABEiAgCREQEAkREBAJERAQCREQEAkREBAJERAQCREQEAQSICAJERAQCREQEAkREBAJERAQCR EQEAkREBABEiAgARIgIAASICAJERAQARIgIAESICAAKICAACiAgAAogIAFAxAQBBIgIAQSICAJER AQBBIgIAMBEBAJERAQARIgIAASICABEiAgABIgIAAogIAAKICAACiAgAASICAAEiAgAwEQEAkREB AJERAQBBIgIAUTMDAJERAQARIgIAASICAAEiAgACiAgAAogIAAKICAACiAgAAogIAAEiAgAQEQEA EBEBACARAQCREQEAkREBAJERAQCREQEAkREBAAEiAgABIgIAAogIAAKICAACiAgAAogIAAKICAAB IgIAEBEBABEiAgCREQEAkREBAJERAQCREQEAkREBAJERAQABIgIAAogIAAKICAACiAgAAogIAAKI CAACiAgAASICADARAQBQMQEAESICABEiAgCREQEAkREBAJERAQACiAgAAogIAAKICAACiAgAAogI AAKICAACiAgAAogIAAEiAgBAEQEAESICAAEiAgCREQEAkREBAJERAQABIgIAAogIAAKICAACiAgA AogIAAKICAACiAgAAogIAAKICAABIgIAkREBAAKICAACiAgAASICAJERAQCREQEAASICAAKICAAC iAgAAogIAAKICAACiAgAAogIAAKICAACiAgAASICAAEiAgACiAgAAogIAICZCQABIgIAASICAAEi AgACiAgAAogIAAKICAACiAgAAogIAAKICAACiAgAESICAAEiAgABIgIAAogIAAKICACBmQkAgZkJ AAEiAgACiAgAAogIAAKICAACiAgAAogIAAKICAACiAgAASICAAEiAgABIgIAASICAAEiAgCAmQkA gZkJAIGZCQACiAgAAogIAAKICAABIgIAASICAAEiAgABIgIAASICAAEiAgABIgIAESICAAEiAgBw CQkAgZkJAIKZCQCCmQkAgZkJAAEiAgABIgIAASICABEiAgARIgIAASICAAEiAgABIgIAASICABEi AgABIgIAgJkJAIKZCQCCmQkAgpkJAIGZCQABIgIAASICAAEiAgARIgIAASICAAEiAgABIgIAESIC ABEiAgABIgIAASICAICZCQCCmQkAgpkJAIKZCQCBmQkAASICAAEiAgABIgIAASICABEiAgABIgIA ESICABEiAgABIgIAASICAAEiAgBKS0pLEiYCABUAAQD1hQEA8VYCAPP/AAAMYwEAkO4BAAAAAQBK zAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAKxoCAAEAAQCSgwEAAAAAAAAAAAAAAAAA00MCAAkAAQDUcAEAQkMCAAkAAQAccQEAQkMC AAkAAQAccQEAQkMCAAkAAQAccQEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAKQBBRkFGAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQUZBRgMARABHRAEAJAAA AEFGQUYYAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3rBGgAAAAAAU AAQAAwADALAHAAADAFgNAKR4HwBSvA8AKd4HACneBwDuugsA7roLAHfdBeCuuwAANm4BJwEAACcB AAAAAAMBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKQEAACsBAAAtAQAALwEAAM6K RgLfm1cT8N68mlPpAwA0EgcBgxkgCHkZBwGDGSAIeRlHREZJMDIHAAEABwAEAAAAMDEwMAIABAAB AAAAACABAAwABAABAAAAAAAAABAABQABAAAAWgAAAEAABAABAAAAAAAAAFAABAABAAAAAQAAAAAB AwABAAAAAAAAAAAAAAAAAAAAAAAAAAIAAQACAAQAAABSOTgAAgAHAAQAAAAwMTAwAAAAAAEAAAAB AAQAAAACAgAAAAAAAAkAAAEEAAEAAAAAAgAAAQEEAAEAAAAgAQAAAwEDAAEAAAAGAAAAEgEDAAEA AAABAAAAGgEFAAEAAADSEwAAGwEFAAEAAADaEwAAKAEDAAEAAAACAAAAAQIEAAEAAADiEwAAAgIE AAEAAACRRgAAAAAAAEgAAAABAAAASAAAAAEAAAD/2P/bAIQACAYGBwYFCAcHBwkJCAoMFA0MCwsM GRITDxQdGh8eHRocHCAkLicgIiwjHBwoNyksMDE0NDQfJzk9ODI8LjM0MgEJCQkMCwwYDQ0YMiEc ITIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy/8AAEQgB IAIAAwEiAAIRAQMRAf/EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCxAAAgEDAwIEAwUF BAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0 NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKj pKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6AQAD AQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEH YXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZX WFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLD xMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQACEQMRAD8A2FUuOeB6U9UC v07VFHdwbR+8ApwuYSwxIv515h1E5Hyn6VKo+WoPOjI4dfzp6yoEGWHSiwjU0xcyyD1T+oqlqCbL 5TVjTJh9qXB6qf5VW1pwLhCDU9S76G0E8tUIIIFTJIApd2Udqw57uUBCr4GAcVG+oDyHRmyzdDRY VzoftEO3O9cVjeIGRrLIP8Q/rUVtKXtX55U5qHUS0unkde/5U+UFI4+V8uRgcUxckgYFPkH74g05 F5FaozkWUtfcVKLUjoRWlEoKg+1S7F9qZiZYgcdqXypB2NaXlL6Ck8lfSlYLmS6SHswqs0B963TA vv8AnUPkgswyaVjRTsYLwHHWq0lu3rXSPbjFVpLce35UJD9oczJbOKp3ETBzke9dOYkcZAUis2/h WPDYAq1cXMmY4t12glgDSCBNwGc1LLjBOcmo1BP1p3Y7EbRbWI6UJkGrckJeIPtIIquBTTuS9CxE +MYFWo3Y4PSqUeR3FW4hnHIoaC5pWo3MCzcDtW5EoWLIOc1k6dBvY5PQdq1mgZYSFY9Kza1LjsZN wF807RxmoStWkgJb5hkdqbdRlEXArRR6EXKhXj8KYy/zqaCPzMlhwKjmURtxSasNEZXn8aQjp9at xLAcByc9Tiobg26/6sng0rlWdiIdB9aT73PbNRecuVXtmplYY696ZIuOTVedSy7R1PAqxuHzHNVr htsLNntxTW4rmUeXNdLoik2o/wB4mubjXc1dZoseLcD0rWfwkw3NELxTHXad1WQnBpHTKkViaXIc cU0rUyL8uPTigpQIgK9PrUUgwMDqatbelQ7dz57CmhEPlgDFVL1cW7VosvP5VQ1AYtzVIRmSLi0/ AVDYcSj3FWbgYtPwH8qr2YxKv0rVbEdS20Sm4ORnmpFRVU4UUEYn59qaoJcfWp1KRKgAI4p6n5TQ o+YfQUoHyfiKQCOePwqK2HyE+rf0qSQYX8KS1X9yP94mq6CJwMuB9KQDKt9DUir+8H4fyoVf3Z98 UgGbMAf739KeV+6Pan7Pu57k08p8w4/hFAEW394fqBVa4/1TGroX5mPuaq3S4gHHWmgOqPhg44Zq jPhmQHhzVtfEoHBxUi+JYz1xWHKa87M//hHplHyn86f/AGVeFdrKu3H8NaK+IoT1xUq6/bnsKXIH OYraVeLJuj3L+NI2m3b4Mm8kfjXQLrdqewqUataN2FLkDnObaxvHADPJwMDNVnsLtCCQzc+ldeNR sz6U8Xlm3pRyhz3MLTo3G9GUjK9xU/l7rZ1IrZE1ke4p2bNu60uUXMedXNmy3RG00iWzA9K9ENtY v12Gk/s+xP8ACn5VSQN3Oagi/dLx2FSmKujWwtRwNuKd/Ztsw4x+dBFjlymKAMiulbRoG6H9arnw 9DnKsw/GkHKYBWotvzmuhbw9z8srioj4ddST5rHjuKA5TBZapzsE4NdFJ4fuOdsv6VRfw5dF8sQa asHKzAiAZTgY9qztXjLRLt7GuvOgyxj5UJP1qndaDPMAChGO9MLO55+0T96s2kecr3rdn0C8AIFu 5/Cqn9j3cRz5Mg/4CadrlJ2IS8e3YxwemDVB7dhIQoBFaMmnzFvmRs+4p82nSRIrDPTmhRsNu5RS IDGRircaR44IzURgkHY04QvnGKrlIuaumukW4uw5IArpNPuLUMTIhkxjKkcEfXtXMWVs5Zeck9vS up0rTXuJVhiH+83pWkaavcTmTx6UNUvHFnF5cOcjd2pmp+Fby3j3NHuQfxLyK72xsPsMCJDDuHc5 xWyI1KbWUEEcg81pZE3Z4Dd2L2/yklR+VZEoVM/MTXrfjDQooI/PjTET8Y/umvLLyBQ5AHelKKYK TRmyXGOm6qzTk9Fq15BdiAPyp32Rwo+Xoeaz5UVzMprJKcccDoPenrJOf4VqwtuxwUG7B5waRkeN RvjZee9OwEZMhU7gvFMuX/0dV5ycVKWVlcepqK5XlF9qFHUG9BbS3O0ORwTxXV6TFthPHpVPT7JG 8pXGVSME/U81sWIUl9owAcCipsOmifZxQUqbbxQV4rAoqFdsnsaUrz+NLOQoPOCDURu4R1b9Kdgu EgwopgTCY9qZ9qiaVcnCjPJqTz4SP9YvT1p2YhpXnp3FZ2or/o5rS82JmwHUnPrVDUsGAYwapLUT My8XFqKq24wwP0rQvkxbgVVhTH5CtktDO+pdkTDxt6iokX5h9RV2RAbOGQepH6VCqY5+n8xUtFx3 HqvzH2H9KXbiMfWpdnzP9D/KnlP3a/U0rCbKk4wrfSlt4z9nUL7/AM6kuV+RqmtY/wB1GMfw/wBa dtACNDkluoz/ACpwjwg+oqYL8sh+tO8v5V/3v6UguM2cL9D/ADqXZ++x9B+lOEfzKP8AZH86l2/v mPoTSsBUVP3bH2JqlfDaqY61qBP3Df7tZ98pMsa+9NIDLkuSTxmmi4b1q8+k5GVlU1Vk02VBkOp9 qx5kacowXTetO+2MD1qnLHJCm9h8ucVWNyF600DRr/b3H8VOGouP4jWN9pUjrQZwR1oEbq6nJ/eN Srqko/jP51zqTn1p4nI70xHRjVph/EalTV5v7xrBhuAwwasBxtytK47G4uszD+I08a9Mv8VYJciO qss5BxmmhHVr4jlH8R/Opk8TOP4j+dcQbgjvSfaH7ZosB3y+KG/vGpU8Ut/frzz7Q/rSi6f3osB6 Snik/wB+p08U/wC1XmYu39TUqXj560WA9Pj8SA9xUv8AwkKdwK4vS9Ss2TyrhCpP8ankVYvLWeOP zoGE8HXenb6jtRYZ139vQHqFo/tu1PULXnTXrL1yKiOokdzRyiPTBq1k3VRR9u09v4RXmQ1Nv7xp w1RuzGjlC56X52nP6Cjy9Of+4fqK84GqyD+M1Kmry/3zVcoXPQf7P0x+qw/98isXWrbTbZBFBFG0 z+g+6KwotVlYgBjUv725lDZJbpVRgJyLFrbbWCIu5j1xXd+HXsoEEJzHKepcYyazfDNnbhw8simb PyoRXVPpkc4ztyevv+BrbYzRqBCnKEken+FPDr61m21y1k629w2VPCMaj1XUIbKJpP4uwz3pWGQe IW+2WT2qAEtjn05rzLV9GaxjeWUrgjjj6VvXevyHeN7LnuDg1y+v6xJerHGzErGD1pO4KxhjCjgd adM4ig3dzVbzdwz6HpU80ZntcJ1HIA700hXIrJlLNu6E1oBEbgGsFHMZx0NTpdEHrTsK5rtZq4wU U/hUDaSjsD84x+NRRXzetX4b7A5GaLId2X7WMchQdx9qsRaZdeWpUtG3Occ5qGzvYzOh+6c1uyeJ oMMqxhW7EjpWc03sXB2RmfYNSXpPn6pQbTVB/Eh/4DWkvii3VQGRSQOuOtB8Vwdol/Kp5WVzGJPp uqS/8slP0piaFfbRui5781uf8JZGOkQo/wCEuX/nmv5U+Vi5kYcnh++eIKsXOfWppPD9y8YCwYb1 rWHi8D+BR+FOHi8k4+UfhT5WTdGEPDV9jOzBqWPw1cmPEkTbvat2fxJcx26zEBUc4UkYzVVfFcrf dZR70WYXRkv4Xum48ske9MHha9GcRmtf/hJ7xjhduT6c1sW8uozopkuFiZhnbtzWsac3sRKcFucw NBv1sfs5gJO7cGqjJYSxOYnAR/RuPSu5Md4et/8Akn/16oy6Kty5uJrss3clfSrVCfUj20Ohhx6J ebT+5JyKk/sW82qPJbjPaultYJSctcyMn8Par4O3+EH60PDyRLrxOFuNDvXUgQNyakTTbi3jRpIi qqACTXWXFoLlwxlkj4xhGwKr/wBjwN995W/3mzT+ryD28Tl1j/dN9P609I/MHHRM5rpRolrtxh/z pV0W1VCgDgHr81L6tIft4nPCP96B7KKaRhXb/eroBoNnnP7zP++aX+wrTGCHx0+8aPqz7h7eJz4T NuGHcis+aPfqEK46sK7YaTbBQu04HvTBodkJVl8sl15B3Gl9XkP28Tyhnk3YDEUI0pddzkjPeug1 zTorQRvHHjOQawgDu46V5z2O9PUrTrKzMNxIz0qqYpGbBx+VazR5JABJ+lRmAqRnj60lIJLqZbQO OePyqNo3Vc8ce1a0kPFV5Yv3fXtVJkNGdEXckcflUo8z1/Si3X5yKsqo3fjVCC0R5GHB/Kt+1tY2 sm3Lh1b9K1dBsbL7EXlwGbgE9qvXUdobTYqDeBw696zctTRR0MGayh+zxMM88GsO6hKMcDI3YzXS lQ1iwH8BzWHqJZWC7RtPOaqDFZGUyn0puGERkz07U+VsKcVSnleNPLByCM1ZFiX7QccE037Uc96p LOVp4l6DbyaALgun7VKty3cGqSO64z8oPQmrsRuHHytkDuq5pXBInS7cY4rV03XZrOQFWOO49aoe eEiBwM4qK1fNypI6mmpCaO126ZrqZG22uT3A+Un3FYGp6Pdae/72P5D9115U/jViIjjtWvb6nLAg jlUT27DlWGaFNMfKcU2QelN3YrupdLstQQyWOwP3ib+hrn72x+zuUeIK/owxT5rE8pih/erET5PU 0yVQjhGQA461Nax7lAUfMaq4rF+1UEgnNeieENNi2faHG5jwM9hXAQKEI3nb9a7/AML6jEsQjDdD VxZLR2T6La3MYbYI5B0ZRin2sz2kn2a6P+6/rUttdKVHORTNTSO5tCB99eVNXfoTYh1OH7TAVAJY crjrXM+I7O6CJKz5XaAQf4TXaWSMLdDIPnI70zUbWG4tJVkAAZcE0J2Cx4tegKGLTDPoFrCu33sc HI6Zrodat/KkcHjBwRXMT5JwKYiozeW3ByasQ3LRMOOD2pbK1M1wcrwBk1cmscoyqAPcincEhuLO 6GXUBj3pr6XBt3JKfzpsenXfOwB8HFS/YrpI97xOqg4yFNGgWZCmnHOBv/Krtlol9eSBIIy7HoAe TV200a/dkOyRUbo7KQK7LwZaiO+njlIEsI6fpSvYdkcK9pNYztFMjLIhwysMEU25JDK6rww5+tdl 4j0Oa41SWaGPJdiWUH9fxrDn0e6hi/fQSKnXdjpSGjHSCWdN25FHuagdSjFS44rQuLUwws4kYYGf aspsuS3rTimyJOw1pMMRvpweP++ajaL5j9M0wR5PStVAhyJpHyq7Dnmug0rT47e2bUL/AOWFei92 PoPeo9E0ZZF+1XPyW8Q3EkVBrGoTajMBHGyWsXEaY6D1PvQoX0C9tWMvNQk1F3lfCqOEQdFHYCmW UZfcACTTLSEujAdc1p28Atk9WPWtqdBy0Mp1lHVk1tGtuQ55f+VW/t8u4HeciqLPTVLOQqjJNehC nGCscEqkpu5pf2hO+AGJJrZ0+0lZBJOTg8haraTpYQCaYZPYVugYArOcktEaQi92AGKdjNC804Cs GaCBaXbTiKXjFK40hm2gLUgwKTPNK47DQlLspdwppmTsw496Vx2DbijHFMa6hHWVR+NR/bbdjtWR Wb0XmmFjmfEdsWswQOQ1cTtILAdfpXpmrJi0Zh25rhpYE+0kngMea8VrSx60Hrcz3kaJkYAcjmnz ov2Xz2JzxgVYMcR4ZsYpl4sZsiiyA4GQAeaiMDedRctigwLJkDPHFQGCRl6fSpklVItpzmmGcAjL E1soHNcrJp9wH+Vck+lTDTbnOShq9bXsP2mNn+VR1rX/ALQ07HLg/gal3RWhn2V41oojmU7a0lvo 52WNDyePpVeS90tuoU/8BqlC6fbC0fC5yKVgbNiGLHnR9Qc1k6nDvtFbHKnH+fyrfChbnPZgKo3U G6GeMD3FCRNzjZVNUbhSSuO9atxHjNUZ0X5SW2nPpVAigIiFbcuTjj2pwk2Y/dKc+uatyQDyxIGB 3HH0xUX2fcAwbp0pXTGTNHKFjEsG0ABlBB6HmrthcSQQtGhC856Ukkk5VRc8uiKgyMYAHH6U60t3 nZgq8nkdqhlq/QIoXujtVgML1NR7TbXW0/MVPbvWnptlNFM/mqVwuee/NRz28Jumz3OetCkhOI9N QQfwSflVhdUXZtBdc9xjIqoRbQjkL+WarSajGhxHCT74xQknsgu0bEN6+8Mkjhx/Ft/wrX/tWC6i W31WIMp+7JjBH0ri01a8jkDxqFI6fICP1qOa9u7qUyTFnY9ya1imQ2jqLzw6FQ3NoxuoeuE+8v1F Y7XrxDYiBAPQc/nSabrN7YyAox2jtmugaTS9dX98otrsj/WKOD9RWqiiLnPR3LseTzWzpV68TllJ yBVW50a4045ljEkZPyyqcqaZA4QkYxkc89a1UdNDNysd/Y+KnjQBlP51v2+q3M8kUikBOCPevMYZ gCK6TSNYaHZGFDAHgGn7Ni50etx7tg3Yz7UrDKkYrM0rWEv0bzFWJ1OMFhz+FaM0gjt5JMjCqWz+ FZtWLPHfExDXU7L0Ln+dcdJkSZx0NdlqCwSSuXlyp9q5+ewjUu8cmV4A4PBrRIgforBZZJJIwVIw OKtzWhkfKttDHgVXtZriGMImzY395c121r4bnfT4pUukZpFD/cwBwOKzZojjobeSBsEHBYjINb1h Zo9lIkm1lRwqhlPPftTr/Sb2GOQfu5ERSSQcEe9Vb2W4sFWOaMrJj7gX73bdn8KpRb2E5W3L2p3x gthEACw+7g4xjpUnhiC+kW4vIboRSfxbu4PX+VYiPHdhjKxAU8ZUkgVq2uqRpaGCGQlCu0kLjj86 6lhpW0OZ4iKeot1dXd9dtLIdzdMrhc4qFpriM4Eki+wakiuY1dw29lz8uetTfaYiciJiatQto0Q3 fVMzpoftCsrIxDdcCqn9hgj5FlH1FbpkMgG2D8wf6U+OOZmH7jA7kR5/ma6IUI2vY551mna5zh8P 3PVefqMVJaaI63AM+0ID0DA5rrlhT/njOfpsX+hqFrS5ZjsLIueAX6fkKapQegnVktTPv4Z7lY7e 2CpbJ0Ug5Y+pxVH+w7knJwR/uGt4abcv96X/AMeNXrWxSGLbJFHK+fvOCf60OnCK0VwVWcnq7HLr pUkWdqoCepJA/SlOnt/FNCv1eupuLCO5QIY40AOf3a4NQDQ7UdQx/wCBVcJpLsZzV33Od/s6Afev IvwyasWlvaQzZEnmY/2a6CPSLMf8sQfrVhLC1T7sCflRKogjEzf7TijA+Vj9AKBqhb7ttK34VsrD EMYjUfQU8Io7Csbo1uZtq89yCdghA/56Zyf0p04vkO2FEkGOoyP51pAD0p1Q3qUmYypqpHSMfWpo NP1KeT5rmNDjsua0s1NanbOvvWdWTUG47mlGzmkyg+hXflktqBOBnATH9aI9CPymS9mfvjoDW+wy pHqKrocoK8+hXnNO7O+rTjFqyKkumWzRFdgHuKfFo1iqgiLJPPJNWzyKdCcxL+VRiJyUU0x0Ur7G LNYWwc5iU4PcVELa3jO5IUUnuFFaF0MSt+dUmr0qUrxTOCorSaM/U032Uo/2a8/uYG3E5Nej3QDQ uPUYrg73APznAPQCvMsd6djGEbSOsWT161FJp8odhkn0rTiePzV2gexrR3xW0waQZ3DrStYq7OXa xyMd/SoG09xnb0rqLpUdwVTg+gqBo4Io88lu4IouwOTELLOA3HPNXjb/ACZBzVu5t7YQrcGY+azE eVs6Ad81UZw7fuvlNOw7lN0KyD0rRtiRKnuKfcxvJpcZwCUPPrUEL4MbehosK52UZD2tvIeoGKJ4 sTZGMEYqOwYPpzL/AHDmppXBjVxxwKdibnGajCYp5FCnCsRWcrxO22ZBt+vIrsL21iabzCAd4Fcl q1ssM2V4BzxSaKRZj/s8RBWKY64Ld6sRS6YvBaFcevP8hXKSyDjB5qpJO6t94/nWXs79TTnsegfb dNXrcRE+yn/CpBqNmvR2I9ozXna3kgI+bp61Y/tO4JDeaxP1qHRLjNdT0D+0oXjLqk7oOpEXH51j 3V/p5fJjcd+BiucTWboNlZWU46qcVBcXb3B3PkserE8mnGnbcJSXQ2p9QsWQhBKD65rP+1KRzWUW bPelDSdi1bxikYt3L5nY96USse9UwZf9qnq0vq1aJEF5ZT61agnYMMEj3rMV5PVvzqeGV943McVa IsddpviKa3XypP3sR4KOMgirnkaffO80UwtwpDGM8/LxnHvnNcaksivjceD61fgmfJbPQ1aJaOg+ xSbHljnikRFydpORyB0PPepLSWSKUMwOO+PSq+l6paruiuI9ySYyc4Ix6V0i28J0vzLNmuGV8uDy Qn+NXF66kyWmhVOpurErux7d6v2/iK4Fi1tvfDHlR3HFYupSW625a0Yt/eByCtZVneSm4C72yQQM noa2cNTJS0OusYoNS1GG0LhN7EFiOM+38qXxFoQ0ieOISFg43owG3NcWNRuEb/Wv/wB9Grsvii9n shbTyNKqZ8vdyVz79fwrPlfNd7GnMuWy3GyzlSqqpJUnleCfrWzD4h1UQKgmnVExhQ4HHp0rj1mc y53H14qRrubf/rGOepNaqEG9UZOUkjqU8TXwnxcuzRFgSpAJIBzjPFJe64NRlRpYmEgXb8kmB+WP 61zau0qsWY54FSq22TOMnFbQoxvdGUqsmrM3tG8q5vBHINysCPxrq4dNtYxhYVA+lcZo7lLuKQdF YZrvkPFdL0OV6jVtIF6RL+VTLCi9FH5U4U4VF2ABAO1PCigU7pU3ATHtS9qXFFK4wpwFApRUjFIo xS9qKQABzTxTadSY0ApwpopRUlIdS00HmlpDQU+I7XU+9MpwqJbGkHZ3NWqy8bh6Gp0OUU+1QHiZ x9DXk4fSconq1dYpj+1EJ+Uj0NIKIjh2H0NaV1emyKWkirfDDg+1Z8hrTvx8qmspzXZhJc1JM5MR G1RleSMFGHPzdea4q/tt9yY+eCRXcMeKxrma3imYPgHPpXLY6rnHi3kjkICE7W7DNW5o5rgIPJcY 77TWy2o2scoORt2kGmPrlinb9BRYZYtYoXhj81RwgHIrMv8ATkkulILiE8HB70q+IraJSD6k9ap3 fia3kUBR0IPWjlC5OdCiuLaVYoy5Toc9z/8Aqrnv7LusnEMhx04rWtfF0dp5xEYYuMD0qnceI0kd WZZFzywGBn6UkmPQFsLo2u15FiUnox5H6UyDTUeYQzXUMfGd7AgfyqKbxDAkhNujBcD74BOaoTa4 80u9gMjgZGadgOn0tXEktuZsHaRwBzirCpugwzscHmuTTX2t50mjAL7eQemelRt4jujv2lRv64FO xJ0V5tjs/MGNyHkn8q5HUrjzZGYH5R2qKfUbmYENKxB6jPFUHZm60mi4uxXlXOGUfUVBIjEcDmrJ Bpu01NhuzZQMbA9Kcq/7Qq95eeSv6U1rdO64z0IoGkRQ2rvkgjj3qVbNmcBmCLnqSKgYmIhTmrMM LyoGxwfeodzZRgSfZUJxu6d6sJpnylkdWPoTiqrWzf3gMe9LFKYsYmHFLXoRLluTNZzxsAYmUnpn vTf3sf30I/CrsWrbYfJkjV1POejfmP65ojxPKZIy+zuOMfypxb6kNIgSYVOrKeoFMaEtz5atjuOD UYCA4yyH0YVomQ0y4oT0FWIgvcDHpVBdwOAQ30qxHIQDuBGK1iZvQ0ESP+6PyrXtZjaqPJdlLDGA awY5c1q2+dgYnJxitIkNmks1u8RSeLbIRt8wH73Pf1qP+zY4VEyR9OjAk81CGGOaF1F4TmJty9GB 6GtYu5m1Ykaxs+WaMeuSTSxWGnNJtdUQDuckn6Cl3eYVAcIxHGTjpQSsXL4UAcZ9KJR13CMtNipq MNnAubeFtuR854z16CseR88BQAK0NRvIrjbHE27HJIqtDb+aSznbEgy7f0+tdFCndGFWdmEaFAZH 4ToP9o1J5xV+QOQDUE8vmbGUbUAwqjtilkPzL/uiuxJLY5mzZsbxdzbkG5iOg4FegWr+ZBG3qoNe X2TfvPwr0PRpfM0+L2GKJLQh7muOlPFRrUgrIY4U/HFMFPHSpAXtRSdKAaQx1OFMBpwpAh3agUCi kMcKUU0UopDQtGaTpRSKHClNNFL1FSNC04GmUoqWWjSgOYVpsnEwPqKbanMZHoadN1Q+9eP8OIaP V+KkmHakXiYe4oppOHQ++K6Jq8GjOOkkJejMB9qxZDW9MN0LD2rn5jjPtV5dK9O3YyxitK5EzcVy XiBCbzI7qK3TfJ2BqhcrFdXKPLkIvUDqajmRsoSM/R/DkmpNvkJSEdW9fpSav4VlgufLsw0iEZye 341vNqqRoEhUoqjAHaoZNTmnjKqMA96OdFcjOH1bQb3TYkecAB+mGBrn3DDrXpF3bi7wkvIxx7VD F4OtLi2adpHwv3gKaaFynnaAswXvU95GwSI5P3cVtyaXHFOyxg7Aep60x9KnuwCgVUHAz3otfYV7 HMEGm4Oa37vQbi2h80gMvfHasvySGwRRYE7lUoSKesRPaug0nQf7SmWHzUjZvuhh1rqYvh8wO37T GWHUY6Ui1E838hielIbdh1Feo2nhaztmBluLdgOvBbP6VYn+HtrIdy3RXPOBHkD9aSvfVGs4Rirq VzyEwHOMUxoiMDHNdFeaf9mnePurEVmyQlTu7im0ZLVkXlL5QGOQKiFpI8bEKSAeOa0I5EYbXwff FWkIIUYwoqErs0krI5W5hORkcjrUscojiC8itfVrMSQmVOCvJx3rAZgFGTV8pHNoPkuBgjPNVFlK txj8aGBLcUgjbPShRJbJhIW7jPsKvWhYqUEjKfaq0NsW2jBGe9aAiEZULx2osGo8200ZysyuOvBp RI8SbXA+jCpQyxpluvYVQlcyE4NNK5LdizG8RAznd6ipo3YZwDjHGTWYAw6HpWtZWxlh8x246da3 p0nJmU6llqSQHzMEYB7cVftzNEuMqRnoTjFVVintpVlt1bIOVdT0+lWrS2vNQufMmZsFhvZ25P51 q6bjuZqaexNJNlGVtwBXggd/8KhgkVCAxJ56Y4rqPs8b2MsUqxtDn5SuQQfUZzXJ3MPkS4bcB2wK UQZoXU2+0VlAwG5JHT/OKxZ7mWc/M7FR0BPArYhX7TpUwA59O+Rz/IGslLOWWZYkQlmOAMV0cl7G KkPsLdriQgYA6sx6KPU1buZ1LJDFxCh4z1Y+ppXKW8H2WA5Gf3kn98/4Cqco5rriuWNjmk+aQgI8 phn7rZp8p+4f9kUyPbkjnkY5NPn2hIz/ALNEXoS9yWyb9/j2rstD1AxvFalcq7HnPTiuIsT/AKSK 6Kxl8q7t37CQVW8SZLU9BQ1IKhjPFTCsWMcKeKYDTh0qRjqKTNFIY4GnCmClFICQGimilpDHUopm aUGkNDzQKbnikBpDHg0oNMBpwNIaFzRmmZoDc1LRaL1m3LD2qef/AFWfQg1UtWxKPercvMTD2rxs T7uITPUoe9SsNzUbthc+hBpyHKg+1Ryfcb6V1GZZPKkeorm7w7Gf610SNlFPqBXPaiMzSYrLLJWl OI8arxTOVD0jSVS+2xL1cVE+oRdsn8K57M7NCeWcqavWTeYobNc/LfKx+4fxrT0pWuB8pK+2a6Kd NsxnNI3HAKjnpVvSLhA88EnKunT/AD9arLpuVG+XBNVrrGkDzUdXY8AE81v7Oxi6lznbsgPJl1yr FdvQ1b0+4h+zbsgbRyTXO314xupXI2liSeOlVluWjBWN8g9SaFoJq6OkvtYhWIoq7yRjkcVyrNEX LvuxnhF71qGxVrRJS5eQjLIByOazpbCTfmKJ2OMkY6Um7glYtaXqL2F7FcleEYMB9K6tvHiRztNH aHLjHzSZH8vauMFldNGHSBgo6k0LZXZxhcj3FGhV2dT/AMJk7AmO2tY/+2ef51O3iPXru3V7cttP 9yMYxXLR6ZcOoDFQBXQaJPFYy+TLKAnu2MUmxpGaUd5vPugG3N8wOec9+1R3ljaXUuLdyiDqCuD/ ADNXb4rcXytGcwdCQPeori1ZLpzAGaPAwcVm5XjfqO0lojI1LSDp1qk63sUhc42KckVjveT7Rk8Z xmuiv7Ke4tY9sZJz0zyK526s5reT96NvpjmnCSYWfUvQTGW2/eYJOc1zV3CUndPQ1t25faR2Hc1m 3bhrluB6VoTZlOOMlsV00XhSd7ZJ1ljAKhiGyMVj2cP2i8iiHV2C/ma7zWLpLLR2QHazDy1H8/0o AyLS2gktoxNBGg2lhIOOBgdKzNWltmmVbYH5Bguf4qbc3TKixqSAq7azvM+bgZNCjqaVGrWQ45Ay e9Jt3L05q1cX1xqKRCdgfIjCJxjCjoP1otY98qKR3reEOZ2OaUrakllYGf5n4j/n9K141VZFRQAq 8AClyEToBgdqZGcODXpwpKCsedOq5stFA52gYA6mpY7SQTKqkgH1OafYxebIkZONx5NdNDplrgcH PruNY16ijoXRg3qURplytuHEiOB/CCQf8KqPaPchvOgchWBORnb2GfSuiOmPIwKXcq46DdxVdUl0 zUYvtZM6SdH5OPwrCnOXqbziumhmadp4aRjGoEWOT2z/AJz+db/9nWU6MBCsW9Si7TyPUmoLqeMO 32eMRp2A/nVMSH1rt9i5pNaHE8QoSs9RW8IWs5Zbe82OB92Rcg/iK5zVNCvtNmaOeA8AHcvzDB9x XQ+YwOQSDUb3Ew5Erg/7xqoUai3dyJYmm+hxZUpIG7g5p90uIo/Tmty6jV2LsoLHqSOtY+oACJQO MGtHCyJjNSehXsji5Wt1G+X6Vz9mf9JT61vR9MURWhU37x6JayeZBG/95QatL0rJ0WXzdLgJOSF2 /lxWqp4rBlIkFOHSmA8UoNQMeKKaDRQA4mlBplKDRYCQGlJqMGl3ZFTYY7NAao91GaLATBqQGow2 KTdSsVclDU7dUANG7FFhpkpak3VCHyaXdzUtFJlyGTEifUVpnkEVgCTDj61thxtzXi5muWUZHqYJ 3i0RRv8AuhTdwYketVhMNpUdmNMMuDnNdNiDQgbMC+wxWLfShLmQ+9X7eU/Zxz3P865vWbsRfaJC eFBrmy7/AHmp/XUvFr91E5qDRZJlBjUkeuKm/sPYPnKlvRc10SXEfUOuD6k/ypzXkSfd2nnstbJR BtnOvoEl0AyBUx696emmyaeQTIpP+ySMVsT67HGDuQEjoFNYN3qMt3IWdsDPAFdNOk5bGE6ijuW/ PfO3eCe+TmsnU5W8phuHAzxVi3aL5llHDDBx1qK7uLKzZ4HidmHB461dWm4dBU6in1ObaSOSUPNz 2I9alXRpJgHjygboCM8VJcXVm7graHj3xV2DU55YWJRY4gO3WuSTa1sdEUilBYXFvKczFcHHB5Na 0S3Sj5Fk5GCS2MisKbUbkSkxHYOg4FVzeXsxx50rE9gTU2mx3ijpZEmjTfIF298NzTo2gMfmNIFQ dyKwYdJ1K5ORbzkepU10Wl6HM1vPFdSRwkISFdhzVKLS1FdX0K76lp0Q/wBa7/7q1m3GrWBkVo7Z y4IOWPWrq2UVjHOrXNs/mLtZRHvOPYkcH3rLvbSytdyhp2mxlSVAXnnPr0pez7sfP5Dn8Ssq7YrV FHuc1Tl8SX7D5Si/RaalzbwR5ls1nkJ4Z2IA/AUyXXJliKwWlrCMYykIP6nNCpRD2jKsur3s7Ye5 cD2OP5VC8jSHBkdmA5LGqDPznpVpXSO1YZ/eEZNPlS2BNvcknugiiKLlu/tVCQEyjI5NNgkVZGz1 zVxWjbHShKwN3KkUz286yISGVgQfpWrq19PeXSTSTeYjIGUDovtVV1gI5xn6VXbCjYDz39varRDL upatc6vKstz5e5RjKIFz9cUWentdRTyCRESFN7Fj19APc1CkC/ZRJyzseMMMLj196RZXCGNeFYgn 1NXbsTfuSQ7VWTcD0wCKtWA/eFvQVWkxGgi6sfmb/CrloNkOfXmuzDxvI5q8rRLkknRadCcutU9+ 581ZhbDr9a72cNrI1NPfF3D7HFdTFKRjmuKgvFS9QoCwz2rpLa9ilIUH5v7pHNcFeDlLQ6qUuWOp 0ENxtUsTVS6uTMwJ7dPaq3mEDGaYWrqw+H5dWceIxN9Ig7ZqPNBOTTSa7Ejgchd1RueKCaYTxVWI Ktx0rFv/APUn/eFbM/Sse95hf8D+tZy2OmjuUbT/AI+E+tb0R5rAtjidPrW5GamC0N6j1Ox8NSZs GTukhreU8VyvhmTE1xH6gN/n866hTWElqWtiUGlBqMNRuqLDJQaM8VGGo3cUrAP3UZpm6jNOwEoa l3cVBuxSebSsO5NmjdUW7IpofPFOwrkpekEmars+DTBLjvT5BcxcL4pjvg1Va4zUTTkmhQDnRcEo BpGuPmyKomSmGSnyIamX1nyw+tbvm/IK5eA75kUdzW1cTiOFmz0FfP5wrzhBbns5d8EpMiSXO4+r GkeXAJz0qkJtiAU0S72Az8o5NbTkoK76CjFydkafnCC2BY8AZNcJ4j1H90YgfmkOT9K0tc12OKMx owJ9PWuFubuSaQu5yT7VjgqbpxlOW8jXENSkktkalvqmoXOCCqL64q8txNt+aVmPvVNF6AcVKinP Br2KeDXVHm1MV2JiSx5OaMHNKAakVCegrthTUThqVWwjXkVoXWkQ6nKj+d82Ah2r1wOv5VDFCFAJ 61dF4kMhmkTgDooqa0E0XQk09Si3hywhiMkrSsMcYwMnHHrUthpEEsTb4tygfKpBx+lVtS1yOSIM kZSMdFPUmqMnjOdEEcMESKowOprymlKV+x6idka+r6bbQ6VcmO2jQqoIYLz94d+vSuKtria0uN9u 5R8YyPSrl74q1C8gaB5AIm4KhRzVbS4DeXkcfqefYUSsOKZ1Ok2s15bG4vriZg2dg3mui0nSIgu6 WHr0OcZFR6ZbrLKIwP3cQAArpI9q4WuZs1Rh6l4egurdljhRJF5UgYz7GsHxLoqxW1jN5JPmWwXg fxKSD+mK79sYqO9hgvtLkiuJWiWH5ldTgjPUVNxpHiSW8xcpDCJGxkgjoKjuYLh42Saa1hU9VLjP 5CtHxBZ/Y2Gxsq+efoa5aUMc9a2RBA8KpKyqwcLwGHQ0JCGOCeaeseBuJFCTFOU+8fUVLKRFPp0h BYL0HWqA3Lxk1uxzSyJgxJj+8FxiqJgR7k4Hy5pIbViBFZFDnq33R/WppLSWK2jnkAVJPuZIyw9c dccdabMqxS8HoPSo5biSeQvI7Ox6ljmtIozbELvgY4HQCrMI2KZWxweAe5qGFGkfbwAf0qWRskBf urwBWiRLAEs2Sck1oBtsYHtiqEQy49Ktk9OQa7sOrK5x1nfQkQ1ZjzkVVjHNX7aFpXVUXJJrpSuc zdhunIzXUYUEnd0FdhFGsYzgbsdao2NklmnGDIfvN/QVfXpVwpJO5z1sQ37qH5pCeKKYTzWqRxt3 DNITRnimk00AhNRuacTUTnigSK8x4rKuuY3H+z/UVoyniqTpuY/7p/lUSOqkZsCMJUOO9bMZ6Vl7 sSKPetFDUxNampvaBL5epqOzoV/r/SuvVq4PTZfL1C2f/bAP412yvWU1qWnoWM0bqi3UBs1NguSb 6TzKhd8HFReZTUCXKxdVs0b+aqpcBTk1G1xzkUcjDnVi7I22oDJzVZpy3WmeZVqBLmXhcBR9ajac 1U8zmml6ORC52WGlJppkqAye9MMlPQLsnMlNL1CX7UmSxOO1Q3YtRbJWkphl5qvJJsPzcH0NVzdI GwzcD0rKdRRV2bU6Tk7I3NNOXMrdF6UX2oozbdw2KeT6msOTVJWj8uFdifrVJleX7xJrxJwdSt7W XyPZi1TpKnH5mhc63HHwu5z/ALNZV1rtxKGSM+Uh/M/jT/s1IbAN2q3FMUZ8uxi743m/esTnvmku /KjxsHUVqPo4fpwahn0aZ1GBnAxRYOY6A6bHMm+2bJ7oetVxaspKlSCPUVrR2u8ebA2G9BUpdW+S 4TDDowFevTrNaM8ypRUtUZaW3rVhYwvap5YvLxggqehFVJJCD1rqUk1ocbg4vUmJUCqd3Mqx+54p WkwvJrNmk818Z4rCtNqNluzejC7uzD1O6LSbB0WshpMmtLV0C3JIzggGsg9a86UeTQ9KD5tSZWJP HNaenXE1pMsyAjHtWdahiQQhOPStmITNHhLdVX1xWDl3OuFCctYo7rw/qKNOctgSDjPr6V1KEhyQ wwexrzDTr1zH/qkVY/7owTW/p/iCU4WZwi9t65NZuIuV3sdr5yBTkjjqa5PVtbikuU+yTskgyjY5 Dg+3THWo7rVvtt1FarP+6Y4fjbmm61otrYfZpony7HBA7ccd60pw11M5tpHHanqFo9yxaJ5McY3b R+lY8moDBWO2gQHjldx/WproR+Y3yE89zVYeWGxtUH3Ga2lEzTK13F5cxRB1VT+JAzUCIc4Irpzp X9o2omhH74KOAOoH9am0jwle6lOFERjQfedxgCsSznooHdGIJCqMn0qtMjLKzLjk8YGK9cHgC3Oj SGGR2mHzJkAB8f49q4G/0goSFJDDgr6VSUXsTdnMupIJbqajjTPatKW02gA8nPemxweQ3ngnIPyD HeqURXIynkRlMfOfve3tUGKsOp28nJPJNRBea1jEiTJrZOCxHtU7JlAfeljTagFXraze5ZY0Xnue wr0acLKxw1Ja3IrK2e4cKi5J/SumtLRLWPC8sfvN6060tI7SLZGOT95u5qyBXRGNjz6tW+iBRini m5oJqzn3HE8Uyms46UwyelAJEmaaTURkNRMx9aVx8rJWkA71BJJUcsyRrlmA+tZ018rj5CceopOV jSFJsmublY+p59Kpm6KyFFAOQQePaqkjgtkDB9TzTBK6kbTgisJzudtOmoiiQlwfQ1rRyngbQR27 VjDrWpEeB9KdN3HUVi8km1lYcYIIrtopsgGuGgjM0ixrgFjgZrrInKoAeoGKtq5g5WRqvKPLGDzU Qn2tmqXmk96aZKFAzdQuNNuOTUZkqAycCm+ZTSE22TGT3pDJVffzSNJTDUseZxSeZwaqmXim+Zha lspIs+ZzR5mTVUSgDJNAnAXPU1nKaRrGm2W1y5+lTW9rNcybIo3kbsFXNamg2+nCxWfUFdpnclIs /wAPYkD8as3Piadd9vpdisaqSu7bgcVw1MZraJ308HpeQy28LzhfMvJo7dO+eWA/l+tWZJtF0e3e aCD7VImPmfnn+VYjLql8265kLH0z0qdtOd7N45m2KSDnI7VwVMTJuzZ308NGKukc9qd/Lqd9JcyY Bf8AhHQDoBVIJVuWNI5mUOGAJAPrTljDDjn6VpzXRnazKyxH0qZIqspFUqxgVDYyFI/apQgHYVJt oxSGIEHHFO2j0pdtLikMbGxi5RiDVlbuOYbJ1AP94VmNMKhaf3r2Z0r6o8uFW2jNeSBkhba29OoI 7VjTPg1Zs7yVSQrZA7GnzpBfRs8WFlA5X1rKFT2btI1nT9orxMiWbIIzVcNjk9aSZwrbSeR1qAv3 zTpzjUnzNhOEoQskRajb/atpBVcZ5NURpUan55D+C1qo4JGRmkkuoRwXAxVVYQ6l0ZT2RSjgjgI2 ZwfU5q8rnbyc1TkmjdxsxU6n5M14WJsqmh9nlqboK5djcLYySHPXFVEnXzBtPeqMl7JzEMlc9BTY pHMgyDW90obnmQp/7QtOptwTH+0oh2yK6vX8mOA46bT09mrj7ZSLnzCwGAMZroTLNdQfPIWAHRRS jU2IxGGXPK7scFduzuctxmqYTJyK1NVtIbdIykzNK2fMjKY2c8DPfjmsmPIf2rXc4XGxu6HqRs5Q j/dzwa7yx1WOT5Q7AOAGyeAPavMI3JYcV2+jObdQvBYgdRVeyurmTkk7Hepq8UcAJxtA7Vw/iZLG 9mae23JKfvDb8p9/atcSzNxuxx6Vh3Gk3Go6p5JmMUckm3cVwoGepqIwsxtnKPp7SttEgJPpzV9P C00zDJZFVeNyGt290CHS9TSKzlM0SFS8hx17jirbTOFOOnrmt4xb2MpSS3ORl8Nsi3BcspjjDLkc Mc4xWP8AYCkhV3RSvvn+VdxeMLm2eFpAobAO0ZOAc1W8m3EKxeXvAGMt3/Kumlh6l7swqYqklZbn OW1gbmTZEwIHLNjha6K2t47aIRx/iT1JpVComyNFRfRRiivQjGyPKrVebYl3AUhkA7VHSZqznsPM p9KaXJppppNK5SiLuzSE0wtgVVuL1IUJHzMO2ahyS1ZrCm5OyLTOAOTVG4vdoIj5PrWdJftKfnyP YUizxHq1cs8TbRHbTwvWRWlmeV9zsSaWEfuVpkgBkbZyO1SxjbCoPXFOM+YqUbaDWFRGnu4Heoi2 TwKmU0iowbHDrWnD9xfpWUoJrTh/1a/SrozT2IrQaWpoWRxcx/7wrpA/FczZ/wDHxH/vCt/fxXQj imiwGpN9QB6b5nNO5CiWGemh+CarPMKjknCjGahyLUC35nNRtLzVB7sKOvNVmupD90Y9zWcqqRvG hJmm9wB3qrJqCDoc/Ss9hI/Uk03yz6VzTr9jphh0ty0b1nPoK0rGZcjDuvTcVbP6ViY29a19PuUt 7PKY8x3OFHUfWuSpKUup20+WPQ6uwRWiS484GMHktx0p1xrOnWxb5/MbPROa5RVmdQrOxX0zxUyW eeorj9lrds6vaq2iNL/hKWe4CxxpFFzkt8xpkt5LetvkJwRwvYVDHZRhs7Bn6VYEQHarUIrYzdST I/LU9QKeqKvRcU7ZShSCKZABeOlOC47UoBp4oGIBxRinikPPSkMAAaXAFIFoxigDn2mqFpfU1B5o PekEp5VQORgk17tWoqaueRSpObLtjcBpHAPQUywnb7cVJ71WsWRJiF545PrUlmQL3cO7V5NSq5u5 6kKairDdVUR3j4XrzVJDnPGK19UjBuFb1UVRMJEe7HU4Fc9SryLRnXTo3RFESrgkZA9apvHBnOGJ 781oyWUzWxmXkZ6VSETMOnNKeMczroYGEdSsAikbVI+pzVpX+TFMe3bjnFSJGMAbufSuSbcme3Qc acLIaluXJIGc1ahsC2MnHNT2qlMKigk8ZboK3bWytkg3zsoYjr1P4CtYq551atyy0RT063iknCnH ynFdlBaxC2w2MYrjLoC3dXtAV553d6mTVLtotrzbR7CtOZR0OV4epWfMhfEel2tzMpQlSBg7RnNc 5/Y9qp/1kp/AVvrKGOTJuPr1qCVUZsqTknuMCuihWhe0jOtl9a14Gfb2Npbyq4EjFeRuxitQXq5H ytkd881TIoFevCEWtEeBUlJPU0v7SbH8f/fVRm9cn7hP1Y1SHFOFUqUexhKrLuWTcyH+6v0FQs7O ckk/Wm0taxikc85tgKcKSnDpWhg9RMUUuRTS4FK4lEMU08U1rqNOrKPxqtLqMeMKcn2FS5pbmsaM nsi2QPL3bh1xjPNUpbyOMc5B9O5qaezuIdMXUAMRO2xT6mufk3FiTya56mIUdjqpYW/xEl1qEsuQ vyr6CqbSllAxjjBx3p5Q0wJzg9a4alZy3O+FJRVkMwabg1P5dKI65+c2URiyMqAKoHvTTufqTU4i 9qcI8Cq9tK1iVTV72KvlGlEdWtlAT2qedsrlIVSrsX3B9KiEfNWUjYIMgiuzCvU5sQvdLdiP9JU+ nNabS+9ZsGIlJ6E07zznjmux1Etzh9k5bIvtKAMZqI3AUZJ5qoWkf2pViJ6iueWJXQ3hhe457kn7 oOaiy7nkmrKwH0qRYGyD2+lc8q7Z0RoxRUWIntU6QdOKtrCOhGKnSDFZOdzVRKi22e1TLaA9hVxY 8GpFXFRzFWKX9nxOPmUVPDYRRfdXn86sge1PFS2xjEiA7VKqYFFOFSMAKXAopRQMMCl2iiigBcUA DvxSgUoGelIEG0noQaTYw7GnbakRXzxmgehF34FSLDvPzLVhUUDLAE0kkqRDJI+lAHmv2j3pZJwi eWOp5b/CsK0lYvvZiQop8c7ySvKx4FdOJxHO7dEZUMPyo2BcmJvlxkDB+tS2FwVu1/2m5rEtbjdO d3IPPNaVtve6VkAyTnjpXnynY9WlTi4bHVXUQuJYxnAC5Y+gqpcY4fGEHCD+tPjnTyzub92OXb+8 fQVVkla4k3HhegA7CuKdRzl5HTQot6Flb0hAEiHA71Tc7iflx7U8EqMcAe9RHZjmQ/8AAaatHY9O lh30Q14tw4HP1pgix0IBqXzEAwFJ+ppvmnsAPoKfPY6o4ZtWY6MyofuZHrVtb59gUDb7mqJcnqSa QGn7drYP7Opt3ZdedWxklse1NM4/hQA1VDUoNQ6jZ1Qw8IrRE3nMR1wPakV8sKhLUgaqhPUqVNWL pIpu9R3Fc7PPLvI3t19apySyH+I/nX0NLFpLY/P8TgXzPU6wzxjq6j8aU3EY6sK5BZm7mp1upAuA 7AVr9c7I4Xgl1Z0r3sEeNzgZqP8AtO3zwSfwrnfMZz3J96mjUgU/rbI+pQNs6nH2VjTG1RsfKg/E 1nCMmpBGah4uRSwdNdCZ7+dh1x9BUDTyN1dj+NO8s0nl1jLESfU1jQitkMyTTljDEU8JUsaYIrL2 rNORHVon2nwE6d4J1b+n9a46SLnpXaaJ+98O6pB6Rh8fQg/0rl5Y+TUykOMTOMQprRZXj8KumLNJ 5NZ3LsVVjyAcdaeIanjiwi/SpViNTcZVEVHk1dEVPEXtRcCh5HtSiH2rQEPtSiCncVigIfarTO8i IhAAUDoOtWBBT1h9q2hVlFWRnKmm7sprET1qZIKtpB04qdIcdqTm2HKkVUt+elTpbj0q0sYHUVIF xU8w7EC24p4hxUoGen8qePSlcClNbvIQVI+lNSK5UjBOPrV/AFLTuAyMHaNw59qk20ClxxSAMfWl FGDS0DHCjjNNpaQDxRTRSigB2aXFIO3NPAzxQAqqalVM0Ig71IFOOMY96BgqADJFSBgqdcfWoZZh EvT8qoPcmQ4zgelFgLM151VPzqozM3Jpoznjmlxj607CueWW4JgAHepYrZ2XykGWY9BUcLMkQK9V 5FSNNJKu8vh2PUcVyybOyKROmltCN0sqqf7oPNXLeQRLsU9eprKSTYMA59TUiS7iVB6dawneWh2U Y3Naa6Z9oQ4Reg9anWdyoG7H0qgPK+yjlvMz07YqWN8qKwasfQYalFLQtFiepo3VEHpd1Rc74xJc 0ZqMNxS5pXLSJM0ZqPNGaB2JM0uaizS0DsPzRmm0tVHcmS0Mq4H7xvrVYpmr88eJCexNRiP2r0ac tD5DFx99lMQZ7VMlt7VcSAntVuK1J7V0Js82SKMdv7Vbjt/atOHTpGGQhI9cVq2mg3E5ASFvqRgV SuzF2OfS2PpUotT6V3lr4RjEIe5nVTnG1RnFW5fCNqNojnIz3YU7Cuebm2I7UwwY7V2uqeG3sxvj Pmxd2A6H3rAltCvak0FzI8r2p6pirbQYpgjxUjN7wwN7Xlv/AM9bdgB+FYEsfzHit3ww/la3AD0Y lTWddw+XcyJ3ViKb2JW5m+XSMnGPXirOwCkVNx3du1QURhAOgp4QVIFGelPCCgCIJT1SpAlSKgoA hCe1SLHntUoSngUCIxGPSniP2qQCnCmgGqmDUgX1oAzT8cUyRAopdvHSj86UUALxRxSUtAgzS5pR 0owDQMB7UtA4ozQAvSjikzSigBRS8+lAp2KAEAPpTwvpSohNTogUZxQBDHb8kiplhx3x+FSNgL2q CWcIMLgmgCf5UGSarzXm3iMfjVR5i5yxIphJbgU7BcUuXOSetLsyOabj0604CgQmCvC8+1O3eoNK KXBoGeTIWUcHFGSe5pcUtczSO1CKuTj1q08XlTkYwfeq6nFSyTeYwY53Y5JOc1m0dVHckM2AFxVq FvkFZx5xir0B+TFctRWPo8JNvcsg07dUYpc1keiiUNS5qIU4UiiTNLmoxTgaBjgacKZSimIeKcKY KetNES2K8qkSmprWza4lVI1yzHAFNlX95+FaWj5W9jYdRXpUVdHyOO0nI2bTwm/lLJPKq57KMkVs 6X4ct47j95iQEgICOn1qS1uM22Cec45rpNJsiIxK/JPSutJI8eUmymliZLpY8D7ODhkUYroba3to LfyzGAo6ZGao/Zza34c5Eb/pV2Zi0RCD8aGzMYpjEuxVBjPTipzCuAAMg062tkeHIOTnBINTFfLG GUsR3FK4yubZJVeKRAwIweOornZPDVruZZNygH7wPWugS4k+1Heu1CuFz60l00My7C+G65HUU0wZ 5rrmmwWd40VvJvQD8j6VhsmDXb31tZ2Um2OZZi/qcstcW8iOxwefSlIpRb2J9Lk8nUreTptkFSa5 H5erXS9P3rEfic1kyXflthD8wOc+lNlvJbmVpp5C8jHkml0FYe2WO3t3NSKKhWTge9PMwUZIyKgZ KBTgKijmV+hx7VKOfrQA8CpFWmjGPSnCmIeB0pQBTVNPFMQ4KCOtH4UDp6UtACinCminYoEFKM0C lFAAKWgUUAL2pM54paXigBKWgA0Y596AF/CndqAp4qQKO9ACKu4elSquO2aMAAc01pkXvk0DJckc AfpSPOAPeqj3JJ+XpULSEiiwizLcMy9cVXyScmo9xPWnjpTsIAvrThwaMDFGQKAAdfenZpueKM88 UDHj2pxc7Apxj6UwD1NOVSTwM0AeU4pMU7FG2uZnchtKKXbSgVDOmluKtW4OhFVlFWIOuK5qiPew b1LI6UZ5popa5z1kPHSnCowadQUPzSg0wUoNAx4pwpgpwoJJBT1qMVItWiJbDZfvD6VpaQha4AHX FZ0vVfpWnojYuDggfL3716VHZHyeYK1SR1llcQjyvlbavJz3rsNIu1uDmNjsXsRXFabbfdB6Z712 mk2wt7QBR987q6LnjNF6e5guC1uxw/8ACfem2UyyRtGfvrxWXqcognBAwQPlOO9N0ySSSff36k+l F9CbG5aziOd4R1xmrJb15rIhidrozF8KrdfWrFxqNvbKSZVLeg5oBRb2LUoVxgrxWfP5NvC4VlT1 YnpWTe+JGwRCmCf4jXJajq8jyFJpGL5+7TuaxovroVNSYRXrSQSMVU9WOS3rWBLMfNYouMnOTUt9 dSndsOAOnGSapFic56nrQ22U0o6IQtjk0LLn6VESWYKKVI3llWNBkk4A9agyHPcP0U4HrUDSkfeJ P410Vpp8MDqhj8+b+I4+VafdtApWGaKMqw7DkD1pXCxzsdwVOVY/Stu0nE0QPcdaw7y1+yXZjByv UfStDTCfMZe2KYma46U8CmoeKk/nTJDbTsYpvPFO6daAFpwxTOtPUetADgBS9KTPFOxmkAgNLkAZ JxVeS5Ckqg3N6Cs6WaZ5PnPA7dqpK4G0rI4yrAj2pcZrFFwyYI+UDuOKvW927D51yB3FHKBdApwF JHh1DLnB9qlC8c1IDACacFNPAAFDyqox1NADhwPeozNgdi3fHSoJLhm78egqDJPSnYRK87MTzioy 3PNN4FKFLdaaQhQc9BS7fWnAAY9fagcdeaAG7PahAV6nIp3J4BpccUAANL2pQKXH0oGNAyfanYIo HFKMHoaAFHriniQ4FNIGBxin4AUGgD//2f/bAIQAAQEBAQEBAQEBAQEBAQICAwICAgICBAMDAgMF BAUFBQQEBAUGBwYFBQcGBAQGCQYHCAgICAgFBgkKCQgKBwgICAEBAQECAgIEAgIECAUEBQgICAgI CAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgI/8AAEQgC0AUAAwEh AAIRAQMRAf/EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCxAAAgEDAwIEAwUFBAQAAAF9 AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6 Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ip qrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6AQADAQEBAQEB AQEBAAAAAAAAAQIDBAUGBwgJCgsRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKB CBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2Rl ZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJ ytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQACEQMRAD8A+yUn3wD95wAP8/nVK81W CDbEG3yH5VVf4j+FfyxLRn7FVnrYrQ6ZNfXRmvyTEeBGD8qiprmxFvqNv5SEKSBnHI9q6FWdiWdt DGiJvw+7IO0jtV0xBiiqSSeRx+lRKr0YtOg+GNN0ysCf7pPUVT0aMLczAqG5JHtUpopOzOxgXaAA D9SeKdOh7EMuc8ClOV1odaqaE1zH8ltJjYuAMelfSHwLLNP4st/LaZX0h5FTI+cpLG2OfpXDXlpY 78FWaOu1S8tfIcy6dcxnGclOPwr4p+K9tA95fS24eNS4baVx9f61zYaWo8VK7OL8BpGmvaYJ/MEa zKOV5Iz1r7w8PWtsL5YxDKyD5skYFd9SrocbXc7DU4LU3SMkiYwp6iu/06S1NnFM7JGMfxEDFc3t X0N4aDLl4r6aO0gYFc8sCK6uK3to40QFBwB1FT7Vo1VQfMttFEXDK2MYxTXtbR8kvERx9aTqgp9z Pu7S0UFlc5B9K8d8eWts1mjAnzFnjP3P9oVzynqbU5dT8sv2j1K/E7x4oV4x/al183t5jcV8b3yw uLgzEeZnAOeQK9vAtnFj5+7ocJdDTJBOBHGeTuwgrCitrVYgpVdwJxlcAjPevpqNZpWZ8LXUm7lh UsdxaUoJB6jrTgNPE6tvQuRwAvU10KbZ5WJujRt7GzdVJTeu7I471qQQQRkHypAASfu1rqzzVPua kVtA7FQkgJ5BC96044Ps+SICpJz05rdt8pbkacSBFDfZm3euBWhEu7MuyQNzkYANec4O5VOrY0oP M2KRB/Fu9KuRNKSGjRVQZ79PasZxOyGJaLSzzKh2ou489efzoF3OzoUQBcYGT0rCa0OpYoDfXodf lRFJwT1wPpXMXPiPWFeaNYFeNM89j9K46rPWwdVvQ5DVdb1C/SNXhZwpOMA8Vy93cTqFG0kgdT1x 71nE+jo19LGLPLKpUFmCsc4NZ81wwD4kaMg8A84+v61VjZVTKuLl9jL5h3HrXPXUsysPmBxwW7/j TjHocs5t6HNX0sozhndCvbFczdyzIoaSRndj1xjivUw+h5lWm2zm7l5Pm3Rgvn14b61hTzMQF2KV JyRXqwq9CFotSfSiR/a0W94laxmK5xg4AP58V5pcu3zhFVhnhuh/WtKc7s5MRKy0OWuVVpWVmLED nFZTWxlYxKH3AZrvp9zx5S1D+yr2VgzIwUeoxiiSweInldo+9zXRKt0DlZCumTsJJQyg471ei0LU JULpbll279/r9KqFUFB9CvJZXNogjljdH9h1qFfMRzndtIxW/texpzWNCIhUKLt9QSe9aNm7s3yI +zOetZuV9zKepuWsqMpDHbjg49q6qxgeTaygKgGeD1qJ13axzxp3Z3WnpEsBnQLvD9cdMCuutrpd kL72O7IPoK86pUbZ6lJ2Vkbct0kXlBeVGCa0dK1UW1zG8jMEz3rkqLuaRqpaHVW/iBIJCsZbYSe/ X8a2bDW7m4nMECsWkbYox1FcklY0jXu7Hu+gWb2lnCGCvIfvEj9K9e8Naa1zJFM4IiT73+17V5Ne Vj1sO9DubpVaExgDG3HTjFfL/jzwvb2ty17HAUR2OQOimtsFVdycZTTR5bc26RW6fL8+/HHpiq7o jW0ZHZ+uPavehI8OU0tynMqC0XJGwyYHrVeUFrGQpuL+YBnA6YonNl08QkVY4z9ivJGBXLKD9apW 0Qb7ZsJK+X82ayNale5DYLi4YK3JU5HriqkEf+mKjMcE4zWsHoZSq3VinPEi3TxpuIWTvkZqC+id bqQ7ARwM4+9VxnYUdNhl3GypbEkqwHanG2j+yRliM+Z2P+faqU0jSPvMfHFt+0sxP+rx7E1n2iN5 iBRkA4//AFU1UNJVGtB0SbGuH3KPnPWrl4rLPbcNtMY6kc1lKSJnUurMtjyk059g2sZNrYHamxyp BulnfhVb+LFVGo+hMZWVkY9rD9rK3l0rLCpPloR6HqfetXUI4nuIBlRhOmOTV+0MyeGHzLO8Khtq gdKpXyf6AEG9UZdvH06Ghz7FIxdS2rAhXfuEQ/PFeL+Lon/0cswCtnCjse1d2EbvY5ajPOdebZax xMfndmZuecDj+prkY0KMCArj37V9hgdEfO4yTub1j8zrHtKuO2eRX6Afs0zRpod9bKrGX7QGL7Rj AAHWsszl7hpl7SmfUHhqNpLe5nXKs9zL909g5A/QCu2COI4zg7scc18FUS5tD7inVfKWoo3KS7lU HGCaijttxQbjzgdK2jLoZNnM6hZKzXEUwJRsp0zntS6LK7WgsplUTwHyzn+LHQ/kRVtkQ3OhaAiO IZHUkn0p4TbBc4yR61HPY0dToU4YnPQb4u49ajEG1h8yqncY6mtVUZyTqFA2ymRtx35bBxxSTQCO UkGNsDjB6VSmc0tyO+h3y2wdHAIyfReKiuLf9zGqg7yMnjir5rD5tLFB4H+yKrglt3BHUVgX3NoF CqDuwW9q6KdQ5lozD0ywEsF5fTDG9gkZJ52D/wCv/StaO2VbeYAHZgYx/WuuFXsY15X3KItgbWcH qRyF7CstrQLZXOFVYwMduvtWntjn9mfPXxKjWKFVD712kYPeuE8C2m2w1FmBkYkBcHofwr06Uvdu czep12pwQf2JOmwDnnjORivmfXkSO6aNHZcHAHevSwdQyryaLelIFEM7CXzMg/exnFfVXhpY8ae8 alMgYOM7T/nNZ416iwzuR/EDTZ7meKGNdjSNyw6+1eYW/hiS4uLmAzyPEpCkjpn6UqVXlVzsudI3 gu1SxlmKyfaB8o+bOPfFdFpvhKwWCKT7JE8o6lzknOM9adTGOWhcJJG5NotjZ30HlW8EaBOFCgYq 9pmmQG5CxwxxqAT0xWHt2bTxDeho2NpDEs0qINpc++T64rZvEzo8bIquxfIGOnPWuWVZ3IjUd9S7 b7NieSAG4HP86dqW9dQstqhG28jGcHFZyncVSTNC0mLON53IQSCRiufik2Tag21Q7P271pS3sZNn DeKnEsLRgM7YBPoB+tM+GyuNYjChiyKzZx7GvW9o+Sw4SR6TYO5fVpFCuTLx/n8K3LVW+zagzE8p nDdj7V5cp6hdmTpqOlkAV2EuSB+PWtV1Eeg3YYHcxH3ecHNbc7sTHRlG0VI7FEfeD5Y9Tk+9aOok R+H9pVisjlhgcjGKzi9bm8qytYw3j8tFeMsW+79c960tYj2eHLOPeFZ2HGcE81pLU86S1uTRwH7N CjBxKijoPzrT8QJEPDVkGSR2bAHbd9fzFJRSOmlKxmlHREAVkfaAMnGK1NXiEHhYMACGPIx1/Crj PsW5XM22tSsVsoCiTbnaT0A9q1LmMW2jXGQ2OWwelP2nQUZNHMQLHBZW4SQKO2V615p43O6wwNz/ ADEhj/DxXfhJak1NVY/UeC7nvlhisFLE/fcjA/D8q6fTdDgt1edw1zdkjJbqK/nCpJI/TOS25urb Djfkc9u1UtVQ+ZHIAz88k8URl0RyTbRvQBvLjcqd2B+I9avqH3oc7l5A49Kbk7iv3JIF/fSMM88n ArP09c6pcgBVTocd6nVl37HZxHIPmDA9RUskYELYZdw9utZSh2NkyaWLzLGIFSQCDwetfSn7Oyxz eM4rZn8tZ9OvIuf4v9HdgPzVfyrixadtD0MHM9h1LT42ikSRCAFPbvXw18Z7BFvp1ACxsoycfz/K ubCSdzor7njvhMJFq1kwm4WVW57jPSv060fSrQ21s4ijEZQHgdc11YiVkEFoZOvaBEt5FKoKIyjo eKzjbylRCj4gToPesISFJ2O68PafCsSv5iecSM5/pXWPGiPF869fzrOpJ7ERsMdkkgmdpo8DPAOK urLYFI3eaOMYzgmpu9hRdjJur7TQ7K17AcnoGGa808b6hpz2ckUU0TTEjYD3IrN05dTojUVj8qP2 kePid4/+fKjVLofU+YR/9avgbxVc3EW9Ih5cjN1r6LLNtTmxTTRwVvPIyyjMruMkkDhs05llLqQz e4PrX0VM+UxC10E2uzSKxfdnv3rR0+08y/sgynZuAbJ9+1ddN2PJxkFynvFr4cs5EGBJ0wCoxitm DwrAisQjMcjqOTWqmz597luPwhLwFkVCecbelSHwpO7KVlicAZxjGDTlV0sS79A/4Ry+OMGM4z25 +op6+Hr5m6gD0xWadyVPuPTR71AFVZd2cZwDinNpl9EjZjbaTngcGsZbmymVvsd5z5gkQAcYHJ+t V5raWNSf32e/as3E2pzMO7nuiCgeQKQfwqr9mJiQkg8dxXDWhc+gwlUyPszLKHaPamMbfbPas+e0 WSaRfLGACS2ciuaMbHvUqqtYbNpsDLzEihQTj1rn30aAy4MaFG5HFM6HURl32h2rO223jR8Z4HWs i78PWjRExRtnBA5xit0ZKZy114XhYkEspHofvfWuYvvCQZ8RuSrHq3JA/DiuinMxu7nPaj4PnjCB LkOmeQV6VyV14Uvl8xlaN07gnp71305IJ7albS9GuFvGQxFwYpE4HqpryzVNOuoneIxDOT6HPPrW 9F6nBiUrHLy27QSSAjbzt5Fb3hzQ4rhvOmY9eM/WvQqT5UefCmrnby+GrdiMtvc+p5x71iXPh23W dQqoVZScYFcUcU7nTOgU7vw/GsbxxhBKeBg43VZ023iRDBNGUYDB46YrojXuZKnY57W7EWc7XRWZ omOVG3isj7HFdq08a/L7jkV105nPOJnXlksYDqOe+KLQupYRpj3HcV1xlfQw2Nm0RICvmfc7n0Nd LaXUduQA7bccc/erCpHoKKV9Tet9TfyjGh6t9cVrw6hemNcBgueMdK5nA3jPojo4FvZXRpS6u2Po K6aztGNwivM552n6VhViUo6XOr0yzgLvuLSLjGCT8pFexeDtLSMQ3DR8sMDIyF9zXDXdjShH3j3b Q7SC8njtEnXzRgc9K91sLOK0hEcKYiUdf73rmvCxEnsfQUo6KxDc7VGV9+p6V4T8R9QPkNp8BSSV jl1ByQvbj/PSt8DHXUnGStE8HuG2WgLjDh6qYM9oibdh355719LGOmh8vUldiSRhLUBgw+cYAqqY H+xXLBii7gemTSce5VMrRqXspwhbPGcDrTbZPLF4FHzGM/lUuBo3cqWVrtk34UkKRg1UhjPn27Ec 7gOnX607WRdkilPGRdlQ/WQ89xTLtHS7l5K4x1HtWat1Dn7le8RQtvgFpPLJ9hVc710yMK3zGUg1 rylxl2J4ow0VwTIR8mOecVl2K/6UgZgEzwSMDpTSsNsNqkTMRvAJPrzV+8XzJLYNlMRgVly3JlG4 kkwhsS7Fg3metZunKNWvDIyFIFLFQRjefXr0rSKtoZyVtC6kRkZgygIpIAB+9zWhqEbefAm4KdoO 1aZMCW2+Sxu1wA2azbvCWLsxIG098VNnc25tDEvkEoRJAxTYACT0FeW+KYJLu7tItpxv44/XjmvU wfxGU56HiOvShbwnJAC4257VhxjcwwpyT1PpX2eDjofMYuScrI3rBEDoyl2lJ5wO31r7+/Zztmi0 K5nfhTI5AB6cL1H41z5sv3bN8t+LU+sfDlvJBpNnuQhnUMy9cZ5rr/KLiFAzBlAIyOa+DktT7CnK yL8UbbJcA5yNxzkYplsoWRB9088kdaS0HzGZdwb96qdpByMVzLZsdbjOdsM4CHPdwOD+Wa3Rz8zO u2/uYQU69eOlTiEG2lXaFfgdKylFom5SjRj5nzF1C46VBCcKgZnwDjp1FaQ2MpkLwfvyu07c5Wh4 kV5IyrEg9elUQ2U72PdOpUsECgc88UskY2QLncmDj/CqjuTfoZ1zGiWiJv2ZbH1FcPq6ebElnFJt aeTYOOi+v5V0wdjOUOp0UVlHb6cLdAU24XAH5VW8vFrOsnyDjnHXtVKZlNoqNGiW1zsADcAnHNY0 8WbKYIX27uR2NaQWupifO3xNjRvNjVS+E5yOM1yPgi3WPQ79cxq3mgdfu/8A6696m/csczp6m3qq hNHchjndgk+lfMuvBhfsDtaXk89zXp4JHFiGWLWI/ZYUDBgCGJA4619Q+E5A9jYyKSwTHX+IU8bG wYdanWeNbcxmzlVsHaCOOQa4rSlUTXe1CTv+8Rwfz/CvMu+h2Sl0R1R2PpNwyBXcOBkn8cGn20pb C4kU5H41mpa6lFnVHI1KEuGRdnzED16Z+tSaXIUnunEJ+SPHI+99KUpCvbcTT2ZrN3BO53bA6AHN a93HLFpNmgfDGTnGKleY0+qJ4JIzPGmzdggYHrU+qMjansDZdVGCR0+lXAbfcn08ulwjF90IB2qc VjgHZdSg43SkqM4z7cVpCPvESkrHnPiWVwnBAcHGD3FbvwuRF1K4mCo5RHyD06da7Ki90xhJvc7n TPljvZd+xWmOMmtmPzBp2oHev2ckjnIYHFefJam6TRU0/C2cLsoJKnO4cAc1q6lGsPh9EAbe7YLY 5U+orQUZdzOjjCwRqvznABz3rZ8QR7tN0+KKN0VgM7QOBkZqorUly6FGS32wmSRGBA56/lWl4kto I9L0e3eFYydrDnrmtZOxEV3I5otpCxI5bAByOnFa/iSLydN0u2dFDtjnHf3NY81zWOmhnzWwC7Vk ZOgJ6jrVzxRF9n0TTItxKsVwRzRGWtkU+5FbxS7AsyjIQEMpxn8vrVjW0jg0GEkszkkYPIFW3roK LuctLG0ccKOTO2M4x7V5L42AOxXU5DZGD97Felhl2MuZ81kfrV4etYxbQpGCnOclc5rskjO4/cYd selfzY5Xep+o1Z3HsEVM4beP0qrrf72CBkyvOeRXTTOLmWxpWZQxKC53Fc9K01IZVVlAAwRnipe5 QJzcBAu3dnrWWuyDVWHz5J6Y4FagdjAS2A5XbU8hVA3XHHSspG0GSxkHTwMlRnt/WvoX9ni4j/4W H4MR5GUS3Qt8c8eYrJ/7PXBi3aLO7B72PorVI+Z1BJILDOK+HPjVCEuiWQ4MZ3ccHGf/AK1cWEd2 ddfc+aNBu0S9TcBkPnI+tfqH4a1yF9G0yWSQLmBDk9uK3xI6a0E13xHZI5tVkiklGDnPQe1YEV95 trc3XnIiLwOetYxi0jKbNLRPESRyRxI4KlsdelcB8RvHmr6Vqr2UN20dvtDLjHQ+9bYaN3qZTm0t Dz7Q/Huqy6vZxzXs8tuW2YL8V6D4h1u5WCRkkbAYdD1yK9WVFdEcNSq2Ymg688VzC0rbgWxye1bO uyPdT27AIW8wbQv19a5q9IvDyfU/Ob9p0z2/xa+IlvKyu/8Aa13jj7v71uPc8V8F+Lt2ZWDb2XsK 7MFGx21FeJwdrE4QqAgbuvt7VaEXQg5wcV7tNM+WxaaZMkO1yODg54PQVv6Vao91Au/Pzj5u45rq gjy6/vR1PqrTfCm6BZVu75QUwPmBA9+RXRQ+FpmUGO+meUY6qMfj+lW2eJVproakfhi/EivJdoy9 OIsZH507+w9VDDy2tGwedykVooXRzWfclj0bURy0Vu/f5WPX06VAbK/V3MlijKPukOMn8KxcXsiX S0FS2nRHb7DdY6c4yD+dMSN1yr2d6px1C5FZSgybNMST7K5X93LGcY+aMjFQ7dObIMqe/GM1lJNb m0ZGbLpmkSoT5VtIxG0jgcf4VAND00kxiGFhnHbms5bHfQxVjKl8J2DgOUZFUnAB6VyzeHLSTUry 2j3jaFJA6YP/AOqsI09T04ZhoOn8JxMrKJpEYdNwHPasJ/CG3DLIxXGMelV7M6I5l3Mq78HzyN+7 de49KxX8K3Y3gCM4BBBPWm4FxzBGBd+F71SzFOnoelc7d+H75i5NsxYkcgZ4oUWaRxibMW+0W+VH UwykcHletctNo8y7h9nbcT36VsnY0eJvuYVrp72uqQyiJ1b5gCejZBH9a8g1rSWa6kk8s7efx/Ku uhJp6nPUqXOOm0E3fmK5WJSfTOferK6da6XCot72aQr2x+ZrtqVdLEU6HmYlzfXwkJjmdH/n7ms2 bUr1kkLTOXGAO3HrWEIa3NZSsUZL6VrhW853IGSc1q6RfbZSJhv3cZJzu962WmxpGaOtv7FL61ZM mQ4O0EcE47V5OWurKaZUOwBiGGK7cPPocWJ3uDOXwWIYUJGWLMmMd+Rx/wDXruhuefPUuxlgvz4P zZz6Vo2cKAu+xuevpVuJEZW0Z1NisPkyMqqmCMdya6GBgtvaYAUliPr/AJxXJPcuNTU6r7UgSFmB TgEdyK6C0k3zA5AO8D61jKJ0dDp9LkYXBjLndz3r1LwhfzSE2bc5yRg/pXBXp6FUKjTPZdGivYJU kYMY+NuOoNe8aPrC3NmDKTFIvBB45rxK9M+ioT0IdS1e3SJn3AEDJwK+Zb3V0vr/AFS/lHmPITGh z0UcCuzAUG9TDHVFy6nG3cTSBoo1DqG7mmQ2srosKwncG7dM19BFWPmJStI2v7KddNu5Z03Shdyj GNvOK5V02WMjEc7xwOlOxoqxnfa4IrWeJnxIWGB3aqEN95X2hPIZ2cFQSMc1E49TT2i6FaC+NszG WGQrzSWt3G9xCOEXcM5HJrPldjRVLIrSFWvmYKApkx+tOvMPcygEZHr6AVmodyoxuMvbZh9k5TYY +Tjp7CofJ8uyjAUmPzDz1xVNF8g9IisVwB08s9cYrJs8+coOeSM+1OKtuFmNQJvmChtgYggdBU98 AZoGDHIj5x0PtWbjqJpmLK8l5biJMx2yy/MRzvPpW/puPtLmNFSNUOM9TWhLkkhkERzgDHXqeetX 9TUfaoCAoyvA7isXLUzi7j4VC2N0GIPOOO9Zt8AlrKjDdkcKfStE7scJK5gX7bvJUlRGEXPPA47V yqy21jeX2pXsfmww6ddtHn/ns0TJGc+zup/CvVwcXzCqxdj5V1BvPuHfad+4n5u4psf71wMYTnmv tsIrLQ+TrytI6nS41aaPCkAYHvX3/wDBEfZPCrOActHIwyeG5xXDm+kNT1MqS5j7D0u3aOzghCqA qKBjp0reeMLsBOTivhpLU+smrF6O3KwTnHHA9KhgtwroGfOAST/Ss1HW7M27FeS3GJMBm9wK5DXL B9zKA3nLh4zjkMOa2jLoZSOg0+WO+0+zmBOWXJz2q+IQkLhnJ57UpbklWK3dy6/MgA6jvUEEH79F G/aD6CrgtDBkLQfvTI78iQEDGMe9LMpM8gByuaTdmXFaEF9FtmhPy7QuOlV54CkEJcAKoyDVp9jF xW5z+pnfZomTk5OR2/Cud022a4Zr5jmNW8qMY9OrD8ePwrppruYyOl8j/QSZVAUsdvrVR/L+xPty r7sHPcfWtNL2MpNdDLe2UWlyXA+8Ky7hVGnT7T8wITGK2puzIPmL4n7g52t8rJhsE54rE8JwlfDs xWTYnnjIx9734r2qb9055PXU1vEYC6QFRsgsTgr3r5d1kK147NuMmTgDoDXp4LuefXldmjArNaR7 SoU4+h/Cvo7wKXl0a3ZmQOpwfpWuM8jOldana+Jc3Gn20xBdl4B/+tXGac6eXLJvYP5nKk+gFeUz sjO51MrbtEUyEDMuBjgH/INU01KKK6WKI7/IG9uw9qycuh0J3JjfjVJzewl2VwcfKOBW7pERji1G SVm27Bgg9DUBKn3KVszNaQKdw5J6cNyetbepwv8AYdOUkBiRkU4rUUdtB1vCzXUAwFwwwtS6kGGq 3JlCggdjnaPStzKT7l7TVJ+0sV+5GSOcZrnpJCqhUAbLHAxjBFKD1FoeeeKAsIRWIIySwPPNdp8M Y90OsXSqhH2cqAxHGf5V2STsOMep1WmAPaKcAnzDk9MmtmQbNBu9xALPt9a5Wg8hLWDZawr8+0Jn 9Ku62rNoumRwKV3sBubsM/8A1qEhW6FdbV5AiB1icKB15zntWv4iXauk2jn5igOP8/SmtGGxDexk QFMyhDtUkfyqx4jNu0uhQwyRSIpAxnJP405O41BXLKJi6YqilNwBGTkn2rU8Yxob/RIiEYYHG3rj /IqOWxqrdCm0UMkrJENwBH3hgfT+VN8XDP8AY9uo3MNvysew7Vaj3G3YimiBBXZ5bbQMjOM/0pni iIrb6dCHz04yRxT5tTklJmZNHJGsR8s72QnpkgdO9eKeNwWureInYMdccnknHH1rvwsrMqk7y1P1 z8OtEtsSQrMpx7jFdVCVLvhNr9etfzk4q5+mSl0LLhWBJbpweOtZOpyB7E8qxUgH3HtXVSMpW6mh pzK1pAB84IHU5IrV4MPzAoAfpx9atq70K9CLd5MyfP8Ahj3rPmfZq0blQu7jkUuRmfM72Oujba6j KHI6Y6GrDMAGDqenHoK55RsbKVhkEpeylU7hICRj+9XrXwd1AWfjPwXPuKKmqW5ODjH71a5MTTuj swknc+vNQJSW6VmU4kZevua+MvjjGEeIsV27WXqOfevPw0bOx6GJPiiC5EF+yDDAMTyc1916Zrc4 8E6FLFcOj/Z1TnjgcY/SuyokZKdkeLeINc1e1uzK11M67uGzyP8A61SWHinVLrTpLWFpIwx5Yk4B 75rtjBcp5067Z6j4D1fULQst3cW8qBlI3NzWT8YtZjkvdPuUdX/dlTt571zqNpGjqXWp47p+rlb2 3YSMmGDZz1Ir6jvooptBkuoXJkeMSf5zXoHGeXieeG6jk8wIgIwc13GrXkzaX5iMQ23KkHoe1RUH GVj4E+Oq3U2swatlp5LiM+ZI2TucEg5PryD+NfFPiuKYK54Rs5OcfN+Fb4WOp6Kk+U4O0wTuZlV8 EfStQW/3MAFRk/T/ADmvcpHzmJfvNlhIvM+QnAx1yeK3tNt9skeU3bWAUjOc+tdUYHjYln25oMLS WNocOPkXt04//XXXw2PI3A7OOnGaybSZ41QvrCjOYlYnHJ47VOtqo3EBgM55rRPoc0pD0tM9iG7U kloCSxXk9CB0pFORV+yKScluv60w2Y3HJO3HQ0Exkxh08MGUqPUAD9ai/syJN2UTJOORyaycWPnR DJotqwwIIgvugrPk0CwOD9miIXsFqGu5rGVjHn8O2bsSI5Vb0VyP5GuNg0JF1u9g8yfJjVh8xO3B xVqEWtjWMzQn8N4xsubkYGTyDn8cVTXw5eRqfLu3CnB+ZBxUeziXzszJ9Ivllc+cjqe7R4P86wrn StTRWZPs84445G2qVBPYmdZmNc2OoIQJLGOVh/dfj8qxp4riNhv02UsSeQ64FbRw5KxPUwJi67w9 rOGBIxgH+RrHuTAvl+bb3OV+9+5P86v6v2Lji5swJRpbSKJAsa7s/PGRg+nSvPvEFjoTJdiKSyJA YYyB83pTVCS6HRSxMm9T5yvLaPzBlG+UkA54xWBcxkthwR/7NWlj3adT3bnPy2oZTIGCYB/GuLuJ RJO7FWbbjqcUIxcm2SRxBQkhHOc7T396uICEIjj2YPUGr5WzqhFWueiaHOLm1QHapUgMD2NYXirS gjtexKux+JOBx7n8qVB2lYzrw0uefGPygQN2Mg8ip1jSIIWO4Edq9mLR485W0LCxquCC7K3btmtK 2bbg5bcTt6fhWyRia9tK8eVViQeoPBx7V0dpNuhjhACsOfbFZVKY0zp4mby7Y7PkZQRXSxKftUTY bHHI7fWuaZqqrOq02NzckbdwBPQZzX0b8M/C0Gp2k2oO9xBOHKjBHp3GK4sTa2p1YWHNI9o03wnq giER1NjuPXy+35129rpOqWwWMmKVMYLkYrxJ2vofQQpciOK8bWOpW9oyWwVvMBVuSDivnu6tJ7Ql CQJQcc172X0rRueVjptm5penLKI5JFBPOeK6+LTlChljVe3PUn2rrnGzPJ5l1KurQGHRdQjk6eXg dq8Iu5pUt5oy5SLdn3P412YejdWMqkuxiW9xbvJtjdd3QDrXceG9KW9leaQMYwehHIrlxtFxjdGu Hs3Y6DUvD0WP3caswBHI6V5nqeji1dngTYRzkda8uhU6M9R0rIwUk23EbZ2/NkhuprstJ0h9Tu3a XaLJTlsfxY7VtVkkroUKetj0V/DWlajGkE0Jh24ClRgqBXVyfC/w+LdYx9pK8scuDyfwrzZYto9v DZfCS1OE1HwX4Wd7iFNXurZkOGVRk9e/avH9R06LTtbeytZxPCoGxjjlcZrpoV+Y58fgIwV4nPbx GZMtn5ieO/sKq6nci7umt7eRRGsY8xkPK57V1qNzyY6rU0IlhGmRrDgL5oBC8GtrSEjDykop2qT+ NLyM5KxEq7HLBVwT3NTasu28VlYFigIH92s5R1Oclg40y83qRyOc9KyLksbZxnDAdf6VaRUHZ6GR eB/LBYIyNGPunv615v4x323hrULh5jESUtwBwWyS3/sletlyvNIMRJ8p83+YSCcliePrVy2XzJUA BPse/wBa+6w8bI+WxG7O10Wz3ukYGHzjJFfoJ8J9MMXh7SrYsNkromAecFxXmZz8B6eTx94+xrWH COSoCKAMYrUa12pE2CgxxXwknqfV1i6sCC3fIJDHr6U2GJQVBTevOPc1JlzldoiodsH7w+hrF1q0 MkyuqjgVcEQ2ZGjQ/Ybi50wE+Vnz4+wCnqB9Dn8668QJ9jkYsACSPrxTqAV7eDhwp3jGDjNQRw5l Xy0OcngjrSjcwZRWNmmKE7QDjHrStH+/aNQd2fzNaONxqTRHeR4mxkHC8/LVO9h2xRluQV604roR PU4XWt4ghjgVnnkby19s9/wGTWvDYJaadbwxZCDgZ/i+ldPKcfKx1zH/AMS+Ms2PnwR6nNZ0tttt idjMpccev0q4IHEgnhIspBhd2RgN3rBvC66c2VGPMB6ela07tmUnY+V/iW26STDZJwuWHQVX8H2j xeHQWIbEp69fbNe9TXu2Zzzi3qX/ABS23S4T5YOQTk/096+U9U8qW8nZAyMH5Oeterg3oefWSvob zQoIYGGMkZxnpxXvvgFV+wRqqsse0cEdT61WJ2JpnZeIGdtHgKFgEJZj6cVzOmwqtruLb2Zz1Oce 1ebKBsn2NzUgItJ06Mqg3PkDBP51z1naGfVNQVSFzATnOB6dOtc8421OrDxbepd8MACxWFiCysy5 B75rv9PRjpeoyE7VUBWxz9P61nHU7K6sUreNhbwqcOoXK8dfetrVYpUi0lNwAwedvOevP61bTRyS 01RYsEMlxZuyjPmDsO1V7mMS6tehl3YySAetaR8zGpIt2cbmHUNi8bcEsfu1zwi22ajccbtxz3P+ NXTjroRqjzfxQH8wqfkHVV55HtXonw4VYtC1ONiyOybDtGcDPrXbJPlNYps6vTrIRafC6KzqXOWx 0/xrdu4hH4bWVVYM0hCgHp/niuFlpIrLGwjCsJApjzkA/wCRWn4htybHR40d2GQM5xxnrQmZNMrx wD7RGh8zO4AEDP8AnpWr4qt2k1fTkKuhVAWGevH/AOulKQ3G6K01vPLFEiL8juON3T3qxqmnJb6t plswRn4O3PODnn/PpWsZMDXgtws8BIILS+nYd6veMI9/ibT4UGI0j3ZI6nHSoktTa9is8QkeIE4f fjp2qr4tAk8R6daqwOzAyRjdxng1JhUqa6CSBJJEjZSiqe3Rsc/nUXiqFFu9Nhw/8LcHI9frRF+9 YaelyhdxblkIGQB1b6f/AF6+f/Fx230yY8xVXIUY+XivRoCpr3j7w0T4sixA/wBDadDkn58Efn71 2sXxq0sEGa3ni6DIx3r8FeBb2P12WBla9zSb4xaE0QDC4Ruc/LnP4g/jUU3xU0Ke1EXnyrIeBuUj J9KFhJI4auHa0NTSviZokVusElyY5hjgAnArqIPiR4dkQJ9vi4JPQ/1o+rSJjQnYsS+OdFZVkF/b HsDuwMfSoLnxZYXV7bulzC6njO4EU5QkkcsoyTOyHiG1+XLoCMfdPWqV342skZo0YzFQd2P61y76 MtTLmh+I4LsXJaRFZhxnsPWvR/AuvRW+qWVw0x/dXUcm4c4wwPQc9q48QtDvwj1sffHiy7sLPX9c szMm1LyVV+bkDcef5V8YfG29tLmGHywGILhs8Fa82hF8x24uWh8GS3eNQn2kqvmH5s5PWvtvwfcp dfDfTdzeY6REZz0Ic4r0ZGMNYnB6tcRuMuFZu3H865j+2Ug3R7xG4OMVtHY86poyCfxdLaYV7g88 ZHSuSv8AxeNQuREZjIFyAGPP+eK6KaRFSpoaFheBpI5MtycHuK+wvClydT8LWsZZT+78vnquK3dM ypyR5RfNJC7hl5DHp2wa9F05m1LR4SzbiV24I6EUnTKjufKXxj0XzdIvXILy204fgdFYYP6hfzr4 D8W2GEldS4fHp0rooRsemppwPLrHfFcMjA7D0zz0rpPkCqmwDJORivTpxZ4GInZstxw7gqAcr1ro NPjdT5iZbocE9feuuDPFxLvqj7G8JXudJsGaGdm8sDcBkNjv+ld9Dcu5CiCQjHpWTk7njVdy8tzu AJt7nHrsp63SL8rWs/uStUYy8xYbqLnakm7PXFWozBJnDjd06c0EprYQxR/dQMeeRQYYuNwz6cUm 7FRt0F8hSCAW9PrSyQAg/J36YpmbST1Kk8eQduRVR4C2R6cfWolArm6Iz7iB/X5ugrjPKH9v8xg5 iIJxnpiqUehZvtbbkBJwx446moWh24DBsiocdbDMm5tkY4ZTu+lY81sFDFgFT+daw0Jkc5ewFN0i BOmOnNc3dRYQyBSJPQ963JhC7szx+18US3GtnTpreBVLMAR1B56flXTywQHcW3fl0rppwNKkeUx7 i13OmCNwO4cV574p063237SwK7AHgqMdO1ay7Cp1NT421bVEWeRViIUMQOwHXrXNzaxagtnczdOl c7pH01CV4mPd6vHJEyLEwzkdAOa4wjFyScq+QCAKuNId0i/bKzM25SEwRzn+dbUVrJLhY4WcBcjA 60noehTldaHaeGfDuqz3KyCEm3P32YY212Wp+H5fIe3lUPEwJz61zRnaViqmHkldnh2r6fNY3DwM vAbAyMcVjpE2QjkFB3PpXt0XdHz2IVmaEWxkA8lnVT6dquKIGf54Js7uzVur9DJRubFvJYqwH2Ry c9S1blvdWiOFNnFvz1LGlOLJkrHYaff252q1iny/yzXa2VxasYX+xRuD2ycAetclSnYuM7HeaU1q HXEBTsSDxX1X8LYIk0fcFkVXlbHuOOf5V5eMjod+BfvHudjbK2Aw4/lXTR2z8KVHA9OK8uFN3Peq T0sch4s0tZVhBAU4Pavn7WdEgu9TEVujzEEjcBgZr7DLcO3E+fxtTuWrLQntn8kgq45PHaupi09k RSEHSuqtQszzkZOr6Q8mmXwYFsI2MCvm/VNI8yVkyvldceldeEp6GVWOlzjorBl1NfLUR5fbgDiv d9EsEsrJPMUiQjNc+a07QNMDK8izczW8ERUE8988ivLdekRgy+cmfT+7XzFONme/N6Hm95HK5Jyz AcE46V6Dp+vJpunwQRwRh0QKCD94+9Ti5LoVh6fNI0bbxvdLcqIbYOxAABJPP0xXUap8TPEehyRR 6tp1hZlkDBHVlbBHBPPHY15vJGSPpMNFxVzyzUvG73s013GIS7kk4JwDXneqeIHnvDcGSOKbG3I6 EY7104SHKzkzGopKxyFzrExcKlw7K3BwMVialqF7YyQ28clzGGUk4XbnmvcpwufLVG47Hd6bqVqd Jto8MZtwZ2JNdFp+pxW7yCVlKsrEZ5IrKppoTFSaHxXkJ2HeM7j1PvUt/qEclzEUkR024JzjHtWB Ps2X4rxFsLoNIruRkA9xXMX+q2y3S2e4iRlyoTp+JrSNNsIxZLcoJI253LtHGeRXhfxP1ONoLLTI 41DrK8jsDzjACj/0I17GVw9848a2onjKjDFWG9s+lbmmwESAhWLds/yr76lDTU+anLU9c8NaXlg8 ilpDjnpt9q+7/hVE3n+FrcvxvDEkZ24yf6V4meK0D3cnlqfXFvA2Gyylc+hrWaDBjByRgdq+CktT 6Woy6kaLbyPtPmZ7j2qC2iy5JBPB7dKSRj6DGgKkA4JB9Peq17bo3mIp3t9eBVQ3CO2pyOqR/ZH0 ++AYtGwV+cZU8E/yNdd5Hm2TkDIVvX71aNEyfREdvCSkvGw4yeMVFDB+9Tgsozn2FKGxkU47cNcn 5ECk4GR1qEQOHbC8k8jPT6VQ79CG9X/SgWcjjoR96sfXm2RxAo2/px2/zzVRM5SscpBbG/vRc5/0 eAGNBjgseprpprUrFbDCgEdSP5Vp7V7GF2VbuECyjVGTlsjOapXEBFiuA45ycf0ramZyvszOuLVR ZoWGF3H6msHU4zHpyiNmU5+U+tdNFe8S0fJXxK2I8yMcbiQW9D61b8MI48L2jORtaRuxy31r21sc UpDfGRSLS4XjGxgmQa+VdQRpboyA7DvwQeor1sBHqeTXeuhtzxkR2m9WMmBtHY9uK978EPslitZF ypiBC4ORn0/GtsUrlUL9T0nU4N2h3EaRujA+nXmvOrJdkbpkuM464INefy6G8nZnSamkklppqdh8 w296p6SsX9rsnmcPERgDP1PX/Oa5KkNDtwr94l8MWibNSV1dNkzZwOvPWustnkbSdVG144dwGV7k 9v51jDc7cSrMltFgEECIgVVVQOOVPpW3rQmNzp8bKR8gJAGD681pY5Z7FnRox9sjjjB+8TyM4qvI sbajqEjsV+bkAYwRmqMJW6lqxwLLU2JVVwOvXFYE6osMYBRvl3EZIralEhcrPKPE7brhS4Ctk8qe teseCItnhfVZPLC7tqK2eOhzx+P8q7qlO0bnRCR1NqoSwtERto2bsqMD8PetTU4ZIfD2nqUcb5M8 H7wzXnSjczk30EkiciJFbGOGGOf89K0/Elukc2j2jO23CnB43EDpUNWGiaO0jNzAiYQbgQT0UVW8 Qxeb4oSBJidiY/DH/wBeqjG4SXY2LW2kN7ZJLG5YyhunHXFJr9s3/CZtGXICJjB/A9PpVppaEt2N rSbYyajYxkv5TSZzgdj6VY8S2Xn+LJoxGriNAAuMHjis5PUrmuivbWkwvbUun7rzCW4yRyMVla5G s/iyNlVmZQccZwemPpTST2M4QuXjbDfBlQC0nBxwPwFUPEcbS63aiFgVByRnpx+lQoamktNytqcM YgmY/eOM7hj8K+a9atZ7zWrlRGX3YI6gj/8AVXpYVGMZtS0PpGLwvqgj2/Yrh8KcjuKjOg6pGwH2 K7WInBBQnj6V+QxpNbn7XUx8Niu2l6iPMBtp/lBIwpyBUKwXaACZZUwe46+9Q6VzgnXjJkqR3Sb1 ieUuc4PPerlvZ6o6LII5mjz6cE1SpjjVS0N+307WWQ4jmXPTcMV3Hhex/wCJnapqki2uZON7fL+P 61yYhaaHJVkj2W61LQNMZ7M30Zm/2ef5V554svJLaeBdNZm8wFmwckgnj+teWqM+qOeNrlW+1DUo 9FtNRgSeF1zG5BIwR3/HisrTvG+taeFMV5cqckk7s/n+Qrenhk/iPUwko9T1eL9ojx/cKn2vXZbm Vc/PNEsjP7liMsfrWJ4p+LXizxVCg1WS3Z1JIaC1SIn6hAM1UsDTWqNK+ux5fbXd4Zy7GVuc5wef qK+gvCv7QOqeFPDn/CMTeFfDOrxZfbPPHOsoB5IJSVRxzjiuaWDUti6PKlY4HU/ihq8vmFVhiGdx ABwvpXJSfEHUXZxujLDJ+72FbQwUUrM4cTSV7mPL47vZs70XPYnPHrU+k60018sxCoNwIwa1+rJb HjVJO9ke06ZI3ytHIzc59fSvsP4Q3JudDu7VmDNFIPqcj/8AXUyjoZwm7mD4mtTFqd2pH3XJA9jz XWeDZRJamF2O5H6jtWfLpc6Ys88+I+ii4utTs1QMl1bvHyf4sbgfzUV+bPjHTGRLoMGypKkEdDmt aO9j0aesbHha2LpelN2SDkg10C2e3aJAzENuyB+lezTV9D5/F6M07a0ZpJGXdgd2GK37Gzb5nZHB 9Oma3jGx5VeWh9e+ALRJdCsC0R27cDjHOa9QtbBcHl+D2rlk/ePKqGj/AGe5VSr7VxUZtGUOOGUd /WtVG5hPYhe3O4Dy2VT3AwPxqKS0jfIdEdQc9OnvWnszJOwzyJIlbyySq9j2HtT4libDxuWfoVIx WLjc3ROsTEt83y9celK0WWyScE9arlsZzRTlt2BAyRz3qE2wAwT/AI0EvYpXMeUUhc1xkkbRavBj dtORjHTilKPcqEuhv+UwKcndVaWLG84y49RSSBp3sUXBVG3Aq+OeOhrCuiCoDKH59OlaKLK5kc7d LwyrlfqOtczqeFhmyfL+Ut04rRu25pTep4lJ4RW1u4dYW7eS5EpkYLjaoJ45z9eMdhXbqiskc0ag gj73rW9GpdmmK2M+e2znbg9CQRXD+K7MCG6BUeZtPX6V1HNT7n5465KYbq5H2fewY45xxn1riXuk IkZreMuOgORgVt7Lse3QrtKzMv7Ugb5YI9xbg5psCl7tyyg9wD2NS6bW50Oqnod/4W02G7upvte1 0CjaoHQ5716RHYJZskcMEbLkkAc5Oa8rFSsz2cGr6npOhrE9gqldkoJztHT8K0LywWWGTzB/Dg8c mvNhNqVzvry908N8baIUQMke90GffGa8pWBJWChgG9/5V9ThZ3ifLYqHvFxbcKAGIU7sDjrXSafp gmVGnUuAcqO4HaumTsc50MGlRR7QqAHOeBnmt610VGLO0KHHQ49TWTqMmUTp7Hw+siDzIzu69K6X +xbSzhEszCFQO44NZSqNhypbliyvLWORVhVnBI+dq+0PhUhPh+zbBKsxP61y4qn7p04WVnoe8afH tYZbJPGK7/SNMe8nhhTBZ22jPFcOGpc0uU9CpVa3PrLwx+zZp3jbR44Le9ivNQYbiyIGUYHKjvge teJfE79ly8+HDnUrqERRcYB5De6nuORx1FfoGX4WUEkc9SpRrQknpJarzPnDxDoNlK9rJZpsmX5X wv3qpW3hS7eOX5QccdM16NXAJ6nzft7GbqXh97e1uIZI3GY2X15r5y1zw1NbySM0DhScdODRhMHb cwr4nojgv7KjtNRFxLGfkz2P4VS1PxFe26NHBAQvTLDOazxmW87s9isNiVHY851TxPr08jKjyYxj hOntXKre640jicSMGOdx4215uLyynGPuo9ahjJN6lO5udQ3qIxsPQZq4+qKsCRC3Lv0JJxk+1fK4 nBN6I9nD4tR3KieJ72xaOe1UR3CNuDKTkEelc3qWtX2oSGW7uZ5WbLc8kn3qKWXNbndLNEtEYMt1 MUIad48DPB6fhWVJOXAV5GdM8Zr0qeBS0PJxOOctBtjq40u+iv1MTqhyFfOM9s0a74qm8TanBOxt bfy124jHHXPPWvRpYVbnmzxfQ3rDWdKW3gSW9hWUcHLbSCKu/wBrWGSq3ETHPB3dawq4OT2REcT2 Zb+2W/zFbmB88HDd6Y1wrBNpUNzznpXIsG76o0WMZWnnO3KzSlScglq5SKUJr1o7ySFjknOcDr/X FddHDpLYbxDluem6hfNFtgZjvCgZXvxXzh4ymeTWLncG3g4ORg/iK7svo+/ocmMq+6cbEoZ1lDOM 9RivR/DmmrO/mSErg7gT0FfX042R83OV2e0aTZRB4Rhccc4/Svtj4UWP/E60WN0O0b2XJ6kRnp+J FfP587QufR5K9WfV1nbKEPAL5x/+qtV7fcyYRuccfh0r4V6s+gm11LTW2bZ1wNoPcdaighHzHawY A9OlJonm00GLCG6Lh81DcwIJHGA4704+RPP3MDVdPUqtu43IykcUzQ5zcaW8Dt/pEEjQyFjk5B4P 4jBrYq6S0NmKPcHAxx196ihjxMNqL6+3SgxKiR75RgYTeT9Kg8k+eWzht3Pv+FBPMinqUWbpjjnO a4vxBK8eJIwXlOEjXrknjn2q4IxnLqa8WmfZbGwt0UJtQbzuzuPc1NdptggRFLLtrZIFtcq3dv5V nbFmJPcDvVWW2zawkM4yelac3cyerM69tVTT1bOzLED3NcrqUbCxjDABmJAJ7V10Xd2REtD5D+Jk aPPcDau7fgY6HB5re8NwvH4d0zdtQMWODyTya9yEfd1OCp5GZ48jdrVOJAmzbjbwf/1V8r3MfmXz CMlRux6E17GCjoeVV0ep0V1Fma2UtyDnIr1zwrctBrNtCSQWhVRnqT3J9PWqxdO6HSlY99jtYrrS 9RV2lXKk8A15BFEkc8+5i67sYxXnw7G8l1Oh1RFjXTVz1XBHt15qhpy+XrNouDsbOBjHbrn8KxrN W0OrAy96xteF7cDU/EVsN/8ArSVyDgf5zXWSRmDw3cyJsJefA44OP85rihuepi0Ja2gCRqEAyQem c1ra9HLFqljESNvlZO7iuhwZ5kpGloFuDfGQvhQpJwvFYscDST3u5mK+YRnGOP8AGnCLuYudzSkg MehXjKN6E9cDI/zzXPyRhbSCRyuAv44rem9RHj3iMGW6YYzwM7Mcf/X617T4dtjb+A7iXYXZ5Qmf Tgf4mu6o1y2NoPQ1JpI7W0t/NJj2phSByT6gVs32oRXOk6RADI024Lg9CD3rhcDFVXexpw2rtPAu ECMVFaPiW1ebXNMhUqipGFG76dvSs2r6HTbQuaXpks19bKHLEyYJ/Gq15bxyeLLzexkYKfmznHTg 0NdCYp9TrtGtI5NY0gSRyeX5h6jnFU7mDPjK+2xjaoI5HbNZ8rMpM6Xw7p+/VbUEb/mJxnrz3rP1 ALN4v1UbJECgAkcj6VDNItbGpptsrX1sqnDK277vX6/lXKrGJ/F2obgQYxtwSAOvtSiyr2OgsbQS XVuwYN82WOOcZ/8A1Vzup20c3i1wqqyBDzxx+H5VcdzOaZmeILNkhmlhAYDIPOcfWvm97u1g1S7d 7iSJQzeo5x2/Gu+hFy0Rnsz95F+CemqVb+zLdXOc7V61Wl+Cdiw2rZgs33s8/jX5ZB3XvH6Appbm TP8AAuzlVlNvsOTzt6/55rnrj9nTTHZyLeUtjsBgGs5vS0TSNRvqUm/Z6tYmRo7OJG4OSu4/rVaf 4EyKAFJiXrhUH51hyvqbU5NdTIvvgNqD+cI5CnA27g1cZefs6a23lGK6hGDyWVhxVwsctZykzN/4 Z+8SxyPKZ4nbPyklsn9K6XTvhh4s06RWm0i1u+Au529PSipCMtgoylHYu6z4I8U65YXGn3WjxRW/ BAhIHQ9etebSfBfVIiFXSrqRGGCu8cn8BWccP0N5YiS1KjfCvXLfCQaPIgAH3s/44rd03wJNGkg1 DRr5ph3jHTtmoqYaRccd3LZ8GWCod2mawBx90DiqLeDdLfIFtfIPu5ZQcmueWGcegv7SakTxfDbT LxJFjM6yKADuXoPesbU/hQo8zyncAfxbauEbblSx19zjrz4ayx5YM65ABO3Ncyvh6+sbqNY4hlG+ YmtZLTQ8+rNXPadLtZfLtpFRjxzxyK+qfgyzw3d9ayHG9AfyrnlEmDOp8c6Y8WoiZVJ3rz9RUPg5 NsksQJGV3fiKz9lpY1pydyt43s3VobxlDyDn/P518HfFPwq9jr2rRpGWidi6knjaeR+hrXD07Ox6 NOdkfMMejk3S7lfAbuME810S6VIUxsLdO1e3TpX2PExUrssDS2GV2AKM8YretNLcgKsfBxntWkqd lY8mqmz6p+HkHlaNbJsUsrFeR15r1aCHIU5CjOM4riktTzJ9jRS1ZiFOGA7+tSSWzjDOOvA4rSMb GbRVksQFIIBBz1FZsltgDaTj+dUYtWK5hwRxhjVF41il84Equf3m3v7is5R6ju0aMMSthl64OOP5 06RNvAOWHP41AmynLEhKnPPf61HLCpwAvTmqjHUqLMxodykZfdziuOvIf+JjbOpLfvsHHfjt+VaS ehKZveUVxtLDB6YqGSLOQQQ9RAbkzOmg2A5JJ4HPasK5iQYYEE89ulaaknJalGkMZl3ZXJOc9K81 1fXIBHcwRKspCEhsZ3Gt6dLm3GpW1PK7XVJJnMckjbcbMZ4r0bTFE9lE2TkDGcV0yw6jqhOrfQbc QDpuIfPGK4jxXADHOxBLGPAPPJxVR3NKaPzs8U6ROt/cK8PlHexUfjXBTaJdsGT7M24nqx4J/wA4 r042sd1O5nDSbqMoWSMRqeferEen+TdIN5+Ybhz146D8qwqxR0R3Ou0uOSG6hKhx84JwcAj3r36H TraKIyQwbgDnLeleBi1qfRYOfQvadqsUcqOwt4IiMYBx2rf823mUss0WMZzuzmvMjB3sjvqvQ5TV bFbl13CKWI5DcdiK8B1vwvPpmoSLBAxiYll/2RX0mBkkrM8XF076oow6Bq1ypYJKUBwCTXeadZyQ wpHcxbH45U9q9Co10PKUO50UWnwNs2XBTs24YIrqNMsY4Xz5gmTtz0/CuOo+htfod5ptsily4GFz z7Vbu7KO/RUaBZo/vAkVnSvfUTiramUmhpFIDEAoDDKnrivsL4fzWemeHNKiluIol2bvnIHBY10Y mDcbJBh9Hc9s03ULNlWUTJNHj+Eg9K9S8BfE7wRouprb+ItAudZgZgsjQ3ARo4++wEYz17itsmy1 zlqjTE4zk1R9KWHxi0LwR47stY+DF7rVvoCRxvINQQDzmYZeJ0HBUZxnrnkHoam/aD+P2p/GnUNM gh05NE0OzjK29mkm8CRgPMkdsDcxIGOOFAHqT+j4bA8isfO4rHe0lzWseL+Cfhhq/jnV7ex0ix8+ RnAZ2HC19gJ+wz4muLUNa6lpBuNmdpZ1Ab0J2muyVCOzODnfU+ffiL+y38QvBu99Z8O3SWvO25TE kbf8CGRn2PNfLfiH4ZXKeZ51tv7HcK1jhVa6OSpPXU8b1/4d20NpeS+S9vNgbUOTu+hr5+vfDwiu JA0ROCSoIxmuCvRN6daxxOpaYkJbCjPXn+EVwWoiCMMWeOPbwfSvGxdLQ9OhirHD6hqFlAWJlj9s HiuPu/EFqvzKJC+TxtrxHhm2ehHEXOXvPEaRblFu+3tluc1ydz4pui7BY1Vs9+Qfwrojg7kTxRh3 GvXzEMrbRnBwMYrKudSvJfuzS4PYt1raOEOeWIM/7RO5KeYM5+v5VsaNG7SOSGU89+CMV2KgkjD2 nMVbyzmkunaKOTljyM8/SprbSdSl3LbpKWAOeDzXRGyVi9baFq20vVJG3kyINwXGTyelbq6JqtnI F/tG556fMfl+lRLkS2NKULnQwaDqP2AXbaheEKwUfN7f5/KqUcUkGqWyzzzTDgZrza3K9kdCjZ6n o8+pNZ6g140as8ZWQKwBBxzz7V8++LdZn8ReJdc1+8ZWnu7ua5fA+Xc7E4AHQDOAB2rfLqXvXMMw qrlsUdPs/tFzBHEoOTgD0NfQGm+GG0uZrScAuioWB/hYjJH4GvpYQVj5p7nouiWOJ4Y1Vnk8wcNX 2f8ADCB18UW/y7Ejjf5QehI/+sa+W4i+FI+tyDW59Q20QCIyBlI568VrvCAYzk4wM5HtXwy0Z9DP fUsfZ1aCUADy9x69elQw2xDSfMcbeaqUdTn5uwwQlmU7F6446U2eBTLNkgt6dqcYdxMzNXtDJBFg NkDiuRihGn3yuxfybvCnnjeOmB6kfyrSxLR1sEQKTE4C/TkVHAgeR1IH3eoHNIzvbQrW8Q89h/qx zjNReU63DN8jZOODVRWpNuxjazL5M7jcCW42kcjNch9me91hyozbW3GP70hGf0BH51slYymzrLqL EluvcKBn0qtfW7BYMKFJXJye/pVw3Ep2KmoIy2doQvyjOQDyKguIl/s632El+SSDW9hcxj30G61j 2725JOa53WYv9FtFMfYkkdveumhuYzZ8cfEmIR3hVB8+4jOegye1dfo0G7QNGjwrEISGHqfSvdhL 3bM4qjMTx9FtgxKZApXHBPHFfJssG7URydvmEcdDXsYGKtc8qta51UtsRcWqN5oYbQOf616ZpMaw 69F5pV1UL+HTitsTHQcNz6Y8OW/2yO4R4xtaPK+p4714xeWYttau4UZ3XcQuDz1ryYxNZRfQ6HWI UE+nICpYRDK9SxxzWVaHydY0sTR4jZiOR+lY1qemh24G/MbOmx+V4l1y2DLGxUSYyeB/kV191GYv DUICthp+o6GuCnF3PXxjsieCJme32AfeQDB6GrutxedrhDFZNkeEx2x6/nXVJ2Z4k3fY3fDluvnz sAu5Y2baTx0rlreLIlYd5GPC4yfaqhdkxVjSv0KaA+1l81n5GPesW6TdAEkhTbtHat4w1CU7aHku oWvn6jMWVlGR26D3r2y2szB8P7NCMRvccHvxgV0VI6Ci2yzqOhzah5LRvNsVQq//AF6szaUbfUNE gnTEaAdT94j1rBPoHNbc7y2tmnvbaNVRNzqMke/ap9aiabxS0ZXLpF9Ao6VhOVmbOpobWi2iSalb xkkLyTiueS0MnibVWjTbEh4PQsc1Kl0ZB3fhezFxr9oJANyqzAE9PesmGLzfEmvyuNrA7Rn6/wD6 utJS1E3ZHaeErVW1pCzMWRScA47fr/8Aqrmlj3a/rr427n2hs5yOc/Spmwi+p0Wg22/VEhSJzGil ifU4/wAK4+1tBc+ItXuny65I3EDjGetKnruXa7Ov0q1h/tC0ABUpyC3OfrXJ3Flu8U6lJtRGThsZ 65pJFylY5vxEoEMmSIjg5OeD718p6iY31OeNUj2s/Ge9evg01sZw956H9Z0enWDEDYhxwOKm/sax LEqieua/L/Yn1ft0NbQLRiRsXgjoKjbw5ag52oT9Oa5pUWJYixVPhq2JI2bj9OhqCTwtbHG6BHYd PrUeyZssSRjwlbnO6MAgc4HFRHwZaO/MYB9AKfsWR9ZY1vAts3y+WD6gion8BwsQCg29OlZqnY0+ sMgb4fQHKCBdnbjpVNvhrASw+zKVwe3Sj2VtglimyvJ8NUbAFurL7L0qtJ8LbVsf6MAehOOTTszN Vu5Tf4X2uGQWS4z2FUZPhVYHAFlCvU8p0pI19rErv8KrMbsWUIXvheT+NU5PhLbSbs2gbsWx+lEt dx+1iZVz8GNOnyr6ertjoRj9a5a7/Z30KeQSNp5D54IJ+X260o27GjlAWH4D2MWFSKcIAQvNdL4f +GD+Hr1bu1WR5MkYzkfjWVWGmiMeaPQ6HWfC95qyRiSEo65HyjrWDp/gi702Y3CI78FeRjINYRpN jjUaegus+FrvULZoWgkBx614b42+Deqa9LFLAgDrCI5GI+8R3rajT11N/b2Wh4FffsyeJVnaaOO2 ki3ZxkjPP0pJPgB4jUuI7JG49f8APvXrUnFdTjnGUii3wO8TwZc6Y5A/u49PSlPwh8RQbf8AiU3b djhM5+tbNpo5KtCXQ9e8D+DNQs9PeC7tJkdX6bCOK9Kj0C4CsohdEHXI6+9csqep5k6LW5MuiToB 8hDdOmKG0eccyK28A446VSgjBxZUk0t1IZlyOCPrWRLpkqkSbNpz2HTPenZMzlG5iXNjOrMdjk9R xxj1rmNVnbTIzuQuBztHespKwKPQx7PxLEiiPyZlHbJ7elb8Gq202X2H5u2OVrK6Rp7G+wyTULUb dmB1H1pv220+Xfld3K54zR7QSpNEc81vEoZnCg8DFcbqUkEVzASxz5oODwRUud9CfYs3llgMBnjP 7nOCfeqcl3aq+zzE3H36VUH0IlTsZ7yQFnG5ffJrGuiojkfzAAM85rqjsRY8T8Sam905iiaZIBkY 6Z9681vo3lEyR/Mc446k130o21MpRZTi8PXDRNMI1gyQWLkKqj616BoVhMLHyY5LS4AYrmOTcAPe qqVE1YpUXuXbuwk24RVRh7ferjtespmty7/ORHzxxxXObQXU+NvE+lDU7mRpoyCpO0L1IzXDz+GY GUuYJN5XruP54reFW2h6uHt1MSfw5CqAC1OexPeuMNlJHOTKhQxkqAw6YrdO6NeWzujStElDruKq ThhivZvCutW3nLHf3KuhGPnNeXiqD6Hp0KhD4uj0tW8ywZcP/dYcV5NezXUUoVJ7iM/571phKD6o vEYpo3/DeuyReet280uw5UMec+1al3dPezeeV3hmxz29q3lSszldfmRoobeCBDuRUH8PfNRtPYLI JEfe+eAAc4P6UuWRhUdh7XlsNu8M5HPNNjvVUuY0Ze/XqK2hSfU5pTLsGsXcUcqieZF6HB4bPrXR 2nifVIkjgDmRF4UY6fjXbSwaZDrJI2rbUbqdxJNMxk9RxXqWlakuoWMOnliknBjkJ+63936HmvTo Yaxk8QraHougreaXHvlmlF0eAgbhRXsvg7RbjU7lbqXeq53HIr6TL8Mt7HlV672Po2xiFtGkUKgn v7V6L4M8E6p4v1W10uwgkkkdwHYD7oJ/nXtxXQ8+UuiP12+CXwVtfBun2aC3CXIC7mxyW7k19k6P oKqioEBOB2qKkexCbR2R8G2upW7293axTwuu10dQysPQg9a+KPjd+xPpuqpe+IPA1mLS42l5LEfc f3j9D7dK2oT5dwqLm2PyX+IXwfk06a4sr7TprWaNipDKRyOxFfC3xR+G15pUU13aQ4QH5gB39a6K tJS1OLmaZ8ZeJbW6ilkEgfjPU9K8Q1cTMR5ke5M5xjmvHr4c7aFTuedapNtdkSBiM7VyDxXGXMbN vfy5A2TncO1ePKjZnoKbtoYlzCzMp8qTfjjPHFYstjcOV28HdtIA61MY9Rxky3F4aeeKfMmxUGW4 xmobfw9EZ0Sbd/8Aqp862sb8rJ10q1TDPFkZ4745rXu7C3tr63hihWP5AeB6+tZSmXGKNOTTnXT7 aVUUo0hAJxW3oemRym8LKwcRFuP51jKTN4w01IraBE8uMoFycfr6Vo6zam21GRNpEexTnHANZOTN qasTfZ1XQp3y+8yjtwa4+BUk16Bdw25HBHT8KkmUtbGz4kfbbak20YIK5z6jFeEtHuLlBj5scnrX oZfDU83Hs9o+Dvg9vEPjTR7OWLz4BJ58gAz8i8nP+e9e4a3bJL4o1SRUREacjA6fhXvRVjxZRZ2n g/RHu9XsIY0aRvOXAHU/5ANfXHgG0ks/Ft7HcwvBIrBDGybcfKT/AFFfJ8S20R9nw7D3XI+irZco BztJxwK1JIiX4UgcdR1r4mUD2Ks9Sy0QitWON2Ce1RQqQZGUcAcVZiNiX50LKSc4PGKr3MDmV3Zi V7mhiZHexglQqneFzXE+ILY/2cTFHunicTRj0ZT/APrH41SQm7GxpsgvdOWdQ+xlDZ7mn2kbh5gT kbTjjrSMJS1K9tEROpkDEg8en41HGoE4Ctkbz3pqLY1Kxw/iW623Fy8YR3X5EGfvN0A/Mirlnp32 C2gWSQPcsN0rEffY9T/OuuEdNTCXmaV5ErNGwf5QoGKrXkQYwKhVRtHWqUbEkepRJElkNzb88t+A rPv4z5MG0GMkde2PWui6BmZfIEt4FyQeTgDrXO69E6W1s2cMyEnHWtqO5jKWh8XfE0f6U25eNwzj 6/zr0PS7fGk6DEgOPJBIPTPU8V7sV7pwzl0OT+I8Yy6Nlfk7duK+VIrb/iaRiNWcGTHI7Zr3cvS5 dDx67tI6swbtWiRmblgR+GK9KtIzFqjsxGxcZI6k1piY30Li+59N+AX+0zQxJ9wgnaT+leceMNMS w8TTwhQh8zbgdq8Zxs7HZzJog1qPOr2aAIJRAOAegA5/mKxFgkXUdNkC7v3q5zztHtROOl2b4ab5 zpYrMxeOZ1XcfMgDEE9R0/wrtNZtFi0TT4NzIWnL4JPcnivNpv3j1MZtqWNMj33VvHtDjeAuP8at Xkfm69djlUAxgLyMda7PZnkm3odtsTUn/eDEDHpzmuSt490W5gyqWY4B56//AFqIxZlzGxqFsqaJ aKEf5nHUZx+dc3q0BiDKUXbgAYJya3gtQmeOagrNqEyIxiy/GO4r6MWJo/Bnh2AxjynlJ445zzW9 VWRpTjpc7FbbcsCDdGAwGB0H0q/4ktEPiHTApUsIwcbRyQP1rhW42aelwbtUtrdwZH8z+EY5zVO4 R28WajiNk2gryfmH0qJLUl7HR+H7UR35kI3bBuAXPTniuUs8jU9au3Ylt45HGeT71lGN2VE9D8Jx xtrNxdBT8lu7ZHbp/wDWrm9JWW4udduAp3eaQCvde2aPZsmR6T4IgL6heSsBtWM9F61wllGkl5rM 2/CtO3OeOtOMe5MGjtvDdov2m/nDNtjhbaR06cZ/lXBaHE91qGszSyADzCAAD1rK1jp5j0PQ7U/2 kArOyCM/Mx7gelcFBG9xrutzghE37S3oRz0q4IJWOQ8XxhbWVSfnCH5sY3cV8rNamW+COVCs+MY9 +te3htrkYd2lY/oUsfjPGM/6WxQc5z1rbh+NMPT7Yu3HY9DXwM6N9kempvZGhH8Z4MHN4NuQc56+ 1ai/GaDc5+0ocYxk9KzlhH1FGo0X4vi7a8F7hNp68jrV2D4q2xKlpodp5HPX9a554Zroaqb6GpB8 UrGdSdydu9acfxMsZAqh1LLk8d6h0HsX7Q0k+IumuSN0JOM//Wq5H4/0ts/Mobr71n9XIdY04vGu mSLuZ09qvp4u01txMqAADuKXshe2LkXinSiD++i2nnAI5q1/wkWlsqlXXGD0I/OsvZamirjo9a0p +TKvNPXUtLOCxRvbHWm6BHt9SwLnS2IAKMD2FWFXTWQKpVewwetTKibKuItrYnncj/0p66dp8rEk KB7HpWfsrFKt0Jm0rTyAdqHnGakbRLFgP3aL9B1olTZftCL/AIRuxbkKo/nTW8M2OQQuDjHNZOkx xqFf/hFbJs/IC3rVZ/Blq2V8rJJ7il7Jle1KcngO2ZgvlxjA/u1Vb4fW7IcRxbj14q4waNvasqN8 OrVgo8qPGcHiom+HFopGIoyw9qqwnUZIvw9gyCsUfsMVPH4BQcGG3PPdQa5pXvuCknuWP+FfRS5D WdpIvT/VDrUTfDi2bOdNtCG6/IeaJ1JLY2jTg90U5/hppTE79GgycDIB61jXPwm0ZxgaZg9wGIxW XtZhLD0nujAu/g1o024fYp0GeNr9a47Vv2e9Bv1KsupRgf3WH68VUcTJaNGEsvpdDjZv2Y9HU74L 7Uk25AygbFZ0n7NyDzBDqsqhuCDFzipnX8i4YKGxnTfs53keBFqNuwAK/PGe49fyribj9mfxOWJh 1TTePVmB/DiqVaFtSamCV9GZ8v7NfjkuvlzWc/OD+/x/OsWb9nH4gx3kbrZfaYUYZCSA5Gee9Lmp 9xxy9m7qnwg8XwBrZNMnMWAdij734H6V5l4i+D/i1mYjQNTSRefuHvVUpWIq5e+h5/efDbxTb7BJ pupKTjrE3GPeuI1LwrrNiZo3g1HyTyVKkbj/AIV61GaloefiMJKK0RxV3oF437y7W4WLoFROSfSt XT/AOuXYX7FYrplu7fNLONzsPb09a6Z1OVGGHwzlKzR09t8ILVnWbUprjUJBy2eFrfvfBthp1rAd P09LZCcMEGN31rzo41ydjqxeGUInO3OjSYBZCBg9RXL6z4fmls2QrtJQgYH3utdiPIg23Y+eb74Q 6xe/6VbCGRHUnJyP6V5Pqfha6s5ZLWWMCVGwwHQ49KISTdj2aOGcY3ZyOqaLNEheNCCMkHrXnNxo LyysxQohy2M45/z2r0aMTCU9SlHorRM+EcN7dKv2ekusqEq20fLxVzhc3pVDZudJiNqU8o7t3GD1 A/rXMz6S7OI0hK/3jjpRThYdepcv6Z4cln1GOBQGdsDngc16D4n+Hz2UME1kZFdF+cH1pO3NYzi/ dPLY9PnjkYSSfKD8wx1+tWhbIig5YdCK6VRMva9BjpGmCyl2HX1zmrG18kxoxXHBIxmtI0DnlPqS ASsoQqV4HJq5A1y+Yyy5HHA616WHpHFWqM6bTYrptoAdueff8q9q8K6JLbQR6ndJIsTNiJWBw5HW vVp0EYe0Pd/CHh+41aeOWdZCcggY4619SaJpUOmQIgQiXA+or26FPlRx1ZdT1Dwh4X1HW763sbO3 ea7lfC4/hGepr9e/gJ8DrHwRpdtd3FurazKAxLLyme5966XpoZwa3PrD+2PDvhiNhqWoQwTJH5pj HzPtyBkKOSM16t4J8ReG9fljhsbsPMY1kCshXIYZHXvjtSlTla5m5pux66qqnCjFLXNsaU9z5N/a M/Z40r4kaRd65o9nFD4jiQs6quPtQA/9CH61+EXxL8Irp1xqGj6vbbpVLIwZeo6V30quljGtS6o/ MT4oeBk0rVLm3SPfbsSY8DqO1fLOr6RDBcskiRhlODntXFiGVRPJdZs7dJ5CSMluFA6ivO9VwHkV It6egHNePUi3ueiZUenHVZIjh4hCp5Ydcc4/Kq39kLvlKEs/mAA+nHSueU7aG8aRuWNjiw1fKtI3 lD/gOKy9Nsne8hSQsynOOOnFQa3toMk00NtzwN57c9f0qTXrcQ6nAqBy3lAnnp/nis73KlKxoTqW 0PTo8ZRpjgjt+NbPh8JGuolsoPs7AE+tZTTNo1DHs442ktXDEtuAwT79a2dd4v3ZHDRhUxz1OKyc WWncsq0J8OTQg7i0wP8A9b26Vxun2qv4ksozEF+Uk46dDyaumg5dRPFTBrG8LOEO4D2NeRwRZkKk EpnPAB/Svay+meZjtdD7h/Zc8OQx2XivxRdArHBCtuhzjk5ZsD6Kv513nw58K2vi3xPcpd7mtQzS yYPO3OAK9WSstDz6SV9T7DuPD2k+H9EnbT9PtbJEUkFV5/E9ay/Ai3LauJ5Y43aWYvv35JGCOfyr 4TiGWup95k8FyaH0JZwEAhSCQfyrTlg/fD1x69K+WNaq1JZYz9lYY6MahgjwGHzbtuKDjfmLHDmQ FWGcgf8A6qqzIBO6liMHA96dwTsQagVV1CnsK5rWoQtlCynhmOcd6qMbmcql3oc/4bkaCPU9Mlc5 STfHkjlG54+hyPwFdHbPiSXkgBD+NaKNir6ale1b94zIcgAnismSWNWHzeXk9quMQ0Z56L6x1LxF bxeerJE5k2vx5knTp7cn8q767UNPG5Xb3PHSur2bsYtjb/CXKBQFYAHniq+pfJNGWTACjp2P0qVF ksi1XKNbqwLfJwccCquoFVt7RNrFzHgHHFXGkyVIytRUpDbh13gJ+dc/4hi8u3t87yvlktz04rrp QszKXkfFXxFeR74GFPl8wA5P1r1bT7SZLXRdp2MIUOPTgcV7sF7tjhkzgPiUFWefzM529cdeK+aL KAPq8ACsAX6kcgV7uB+E8ivL3tTqI7UzavbxqWVlcbdw68jvXfRRBb68JQCQHB4xnmtKw4O6sfS3 wvjhmuLBuBIxI78DFZfxT0s2nilSisHbaSdo5FePy+9Y7FH3dDhtUgzrki7Sq+WFBIycVmXMRje3 mJk4lX5R2HPP6VdVaWKwj96x01/FIPGekXjyE+ZbELjjFd14lgItdDVt+1nJIxnNeXGOuh7GId4l rSYA99ar5bKN+V9sd6gvV3a7qZG5NpHJ4BNdaR41zrNEtsadrDOSx8nGK4+xt3WBcje244z2qo26 kTbNPWYWXSdNjdmz5gI461y+rwvsLOo+UYwo61vTMm2eMSQBtY2lXdS4PPTNfVl9aCDQfB0BTKMu 8AHPU5zit8RsdtN+6b1tblrqAAO+ZB/wGptYRT4uSNt2+OI4OPuj0/I15vLrcSqG/ocG/V7fYJDt y24/w8H/AArnIl363rcqq2N+3JOSPpWT3Ibudz4etpBPcygbgsBJOOcf41x+iWo/4mLqDtaY8g81 MVY1iekeE7TZcaxOOFW2PtgY/wDrVyfh2DZDqM0iH552/i689KfL1FKR6r4PglWLWZpE2KIyMY5J /wA5rznRot1pdyPGgYzuvTqM4/xp2MkjutBtEFprT7sMsR4yee1cJoMbyR3rZCv55PQHdzj+lYJN nRfod5oEDq+oOylVVCSenIrzPS498mrzEo8bStkFugAxWlOJg5M4jx1/yDJzGzKqqcEHFfOWhxeb qlojJu/eZOcg5zXr00+XQ0w2kj60j+I10gRDKFGMjnOD9PzpIPipPvKvJL3PLfer4uD1PXi7LUtL 8X51ZE+2GNQTxnrj15q+PjDOBvacyHODtbHFdM4poVkakfxhnj8qMzl16/e6VbPxnljcnz5dvHU/ d+lYuDE5djdtfjM6Kx+0Sbjwfm7g1s2/xpII3XMyZU7sHgHrWMk9jWMbo1I/jUyuxW9k2/73t6Vs QfGqQbkW+I9yc5ocV1M5xN+0+M9xsH+msXU8/NWpB8apF2KLvk4Jy2SxrPkh2Jijdg+NbpgPcjZu AODyD9a24/jaGxi4JB46/pU/V4vYehpw/GXOGMoU9NpbrWmnxoO5QbgBgccNzQ6CRJq2/wAZgylj c/7JO+taD4yrkD7Q+4jsaxdIDUi+My9BdHbjJ+ate2+MiAIxuWwMc5qPYvoVA3IfjJGcEXIXnAGc ZrWj+MsO4BrtNpOPvU/qzRo7mpB8YbbawNynbHPU1pwfFy1YoGnj/Oh4dkNyNSH4q2XadH59a1If ijYuqkzISOPv9Ky+rvsUqjRej+JFg+7DqccdauxfECwKLllYn/a70OiV7ZlhPHemuoO8Ic+tW4/G mnSEEOM9CDUOiHt2XF8V6c3WToR0q1D4n0132idc/UVk6BUaxpxeI9NXKCdMj3rUt/EFm6g74to9 +lZzwyNfbl5NZ02Qhj5eR64qX7ZpUhIYxfN0ORk1yywzNI4hi7dLboyeg6Uz7JprZz5Y7/Wp+rFu uyA6Tp5UkEDnpTG8P2brlVXg+lZyoBHF2IpfDNo5BYI546iqz+FLP5h5aNnjpWToGyrrcqf8Ijb8 J5aYz6c1Uk8HIGYrGfwqfYm/tjMuPBEbtgq3T15FY8vg0szQbnZ8dz1FNURe18zNn8AGRAhXf3PH Q1y118LIZXO+zjc98qK3pqS2MqkrnI33wY0yXPnaTayY65iBHH4VjT/BvSwcnTofpsAxXTKUmrMx jOzMm4+C+nFmZbJF49+K5+/+BdndIEWKTapzwehpUqcU9Qr2krSOUu/2e7RslUmH61yuofs8mQYR plXGFyAa7eZbHnRwkU7mF/woe9sbJbKNVdACMleteC+Jv2TNU1G8vLy3nVPMfdtMf3f1opRjF3PS veNkeY6n+x54lYMIJ7TaODuVgTn04rzu6/Y58bW7/LaW06EnBDZwPyr06NaGxwTwjbucjd/sq/EC 1zImib+MfKwO6sK5/Zx8cWyGRvDd6eQD5aZzmuxSg9mWsPJGJqHwU8U26Ju0DVXGc8QE4HT09q5a b4Wa5FK6y6PfKFbvCRjHY8VXs0ZSpTO18J/DW4g1IPd2UyGNQ4G3G013et+CtyMRDLvAwFIzXFKP vnRGDUdT538R+A2W+k8q22grkHHfvXLv4LmRirLJjHI28n8a9iktDzp3M+XwpKkjQrG5OAas23hk shWWNoyo/PNdSpnPz9yOTw7LAzoclRypxWlZ6CpwWgLkelb01bYxkrnp/g3R9Is7+DUtasmurJMs kQH35AMru/2d2M+1eqaNp974gvpZ50DebK0hVVARWJycKOFHsK9jBwb1ZhiKkYqyPqPw1oUGk2aS bU8zGAPSvUfD2k3Go3MEMEDTzuwVVz1r2YwZ5jqXP1a/Zx+B0OhWsGt6taJPqb4Zdw+7xx+Ffobo GghQvy5Y+1Sywn+DujSSXWpNY3d88jPIweZiRuBDAc9OenavRPA/gXStFWLUorKS1n/5ZoxOUGAv T6AVcq8rWY40472PTqK5C4BX5Dft+/CODTpU8daRbrDaXTmO4CDAjmwTn6MAfxBrSk9bDqbH4E/F lHkRyEDSqxAJ/hFfEXiO3kE7EqrPyc5q68UctN6nlE+nfaLqYOVRVPzMT0rzXWdPhSR41LP824t6 15FRdj0Iy6E+lWV7KTHYWvn54fPArsLXwFLMkst7cW9ruIO1ATj3rl+rtu52xr2VjUt/A+mwwT2y anKwkTbu2f8A16xbvwWujIlxa3UF5Lgj5gQR9O1arDj9vE5K1uNJe6eC/wBLS4KttZVYoyn1yK7F fh54U1rddQalqllO427ZNsgUfXg+lU8LoHtovQyLn4RaqYzHp2r2t6qtlF3bOM9geAenest/ht4i 01Lh7+21JbeNTteNQ4Jx6jNclSm07WOmkk9mcDJaQW8w8+5vYVX7wHH4Cs27ns2uF+yTXaxns757 densamNO/Q3u4m3p2rWcGnSWoW5eRX3s7cjHoK0fDxW41xZFB8sRsTkdDim6djndTWxk+N40gt2i VEDGTp3PGK81sIFllWPB8wdCK9XAp2PKxmrP0C+Hduvh74NlASl7dySPz/3yD19F/WvoD4O+H4tF 0WS+uI9lxcsCeBkKOg/PNdtV6HFTjZno/j2+a28LXIQ/vPlAzj+8Kwvh9I8Wo28QJAymcdckc18H niuz7zKHaB9Q2ysEUAHdj2rReHMjKCA3FfMNWOipK7JpLcNbA4JUMajjiVRJ1ZgOAB71pGKaOWS1 IYYyJ0CkD5ueOtUrpB57AoMZ6ij2Zm5GPrkiQ7TjgjGT3rg9b1mFdMhAcouTycZBrenSb2MW7Hmd 54mSwe31VGO0ERScclTx+hwaqXfxQuIGYWtpEyMNoZ3IwPpXbTwV9w509zEn+J+qWwcw+RuI/un9 Oa5ufxxreoXkK/bPLQMOIxgH8evrXZTwcVuQ6nYzbXXo9G1iPVb13kto5d21fvNk+vrXo8nxf0Se UMlpfEZz2JP4ZraWDb2IUy3c/Fbw3c3AZUv4lGPvIOf1+tSz/FDwpLcAJcT9FByh4qf7NqClU6jd Z+IvhyQx/ZtVhPycNIrKoPp0z+lZ9j8R7DVJRbzlLYRkxo+/crj+9zggH3rT6jNLVEc6Oivtb0tl tDDqVnOdg+5Irbc+v+e9Z/iO+tJI4fKuVJ8vtjriinQknqhSqJHxn43QzasvloXQODz3+le3WkSN /ZiZDgRRjI/h4H/169qK0POlU10PLviPFukuV3KowSMjoa+dtOgdNWgYLvGfTNezg4+6eTiKtmdZ psTPr8LSp8m8NgDk8/0rr/Lb7TqPlKv38Ak9qupTLjWVj2/4UX4XVNPiYAqkwB/PtXq3x10b7Lf6 dfqoUOoPKjt/kV5M1adjti04nz9MRNqNxcKzM5UDJ5x9adcWanTrudkkfEiL1GevXNXUpuxGHfva mnrMTx634RuQHCOpXhgOOP8AGu98QbAdFiUlTkscd68z2euh79b4TU0GLzNVtCMlQScAdcVSa3WX U9VmCFt83/fP41rys8V+R1mnwNb6Hrm4KNyhc4/ma5eCB4reNiTtI6A/qauMO5jORpa/BmDRlLOz 55xwfpXJa5FIFYYbaBzu712Uqepnzo8bihEmsBGJ2iTJx/DX1jq9iUPg63f5mjtEbnHpmta8NLHX GehvaTam51K0AUnMnOAOeaq6lGp8WagdoKqNpPp7fpXBy2I5zrPDEBOp527VEZbnvx/+uuP0uAyX 2tFhvkM/JHp9fzqHFC50eh6RDi21icI3lCEjI5I4rlPDdofstxJg/PKxA6kc9c/0rmcddDVy0seh eGbRUsfFUxLkLEF4x1wa5fw9Bt05A6q5MxIOOnJqoxIuepaLbeXoOtTsAgKH8a8/0a3dtPjlYY3S FhjuMmiVLQq51ttA0Ph7X5iN+5SOPvY7VxfhyErpEbuCkrMe2MZJ/wAaxjGxq9tTt9HjCWGtTBPm 2nqfuivOdNtAbS7eNATJIxIz3zW1NHPLY8o+IYItZ4oS8K/cwMV474ZsvtGvWEag+d5oBzjDHP5V 6kVaJvg171yXU9USFZXDGMD7vucf/XrjLnXZofLjO7A5yG5UHHFfCRdz16iKP/CRtFJIsU4IC7VU dB75781ZtvEUjAMZHjRucDpWsp6EIsxeKpEchZyfmI2Mf0NSt4nkl+Zd6AHJUmojUYi1H4mk+UM7 bFzuY84FXIPFssamQSZQngj0FZ1OxvfQtL4pYPgXBfjOD2q6ni6dSuJ8ECp5zlnJ3NeLxrcfdFyw x6t7dKsr47uI9mbiT8D+FXpexrCehZT4g3YwPtDPk9Celaa/EO5Cxt9oXaPmwOprRBZN6GhF8TLt WEguSQP4cnC/Xpn/AOtWpH8TLhSNk+Qck88D+VTJaDcGX4/izOMoZ8lemDgVqt8WZ4iFWcsQMdeP rWSj0K5Uty9b/FqckKJivcn146VrxfGKdRg3B55wW9//AK1X7MFa+hpw/GN3GDcMWztOG6cfyrWt fi/udkNyQykLnpRKVtAlLsakXxgaNVZLsEjqf6GtSL4wKAjfaXHTABzxVqXUUpGxF8XiHUpeuo7E Hr+FbUHxeeMDF0+M9AcVMqouZtGpF8Znwc3u3nu1a0fxldkB+2ueeobg1WnYV9LGnB8a9uEW7zgd GYc1pxfGmXAIu/nLY4fOKy9khM2YfjTKqAm8OAeRnFacHxoIbP2jDfXiolTXQRsw/GbcF23S5B5+ atu3+NDBlDXXy+oNQqSLUDeg+NajB+0jjqM/rWvH8Z4uP9M3NnseAKhULlcnmaEHxoTAIuwT3+bG K1YvjShUbrvj69accP3BX2NSL41Rtt/0tfz6VrwfGiP5f9M3kdeaJYRdg942IfjLAcZukIzjr3rY t/i9akEeejE9eeRXLLCjjUsaEHxXtpOWnjx7titSP4oWbKoZ42Xj+Ks/qoe1vuaQ+I+nuACYm/Gq zeO9Me9hOVwAQeRS+rmsah0Fp4y0hlO5Y+avr4n0KQEkpycY4o+rjdUcdb0KUgMVXP5VH9q0GX5g 8eM46c0ewD2ncYbfQyGCzoGHPNUfsGlygokse4N+FKNEpTTKp0WxZW+eHOeMNVOfw5aNhMwt9DVq Bm5FF/ClnKxBRJB06VXk8BW0jg+Smz6ciolA2hMo3Pw5tTk+Sm7pytYU3wzhLf8AHugX2FaRVkbu oZs3wugxtNuCc9cCseb4SW74ItEPPTANDT6EOp2Ma6+D1pJktZR7fZOtYF58GtOlZjJp8D5HOV71 pGUuhEqrRjt8EdIUNnS7bn1Ss2f4H+H3BR/D+nOo4yUxSdSXRgq5y95+zZ8PLze114K0p2Py5XI4 rl5/2TPhpOWU+EWTnPyzMOcY4zW0MwrI05otanP3v7G/w4uPNP8AY+pwbhjKucD9a469/Yl8CyuW t7rXLXA7opB5/T/61dsM1nbUwnh4HGah+w5ojGRYfEl1H0IMluDtPvgdP/r14X8Sv2atM+GmnPqE /iyyvZHkCR2qwsskg7nJPSvXwOZe0ly2OKth4JXR4jp+izX1wsEcQSEMFAHSvo/wp4et9JtUeRcv 156n8K+2wtOyPmsS9T0nSrY3k8W2NvLzgD+8fSv0x/Zr+BJJtfEeuWn79sGKMj7orrlLoYU6dz9S /C/h5LaKJEjAAHQCvRLx9X0i3t7nTtIbUo1bM6q2GVPVR3rNBNM7Xw74nsNchRrKeCLaCssUp2yx v6bfSujtLpJ/Mj8zzJo2KvhCoz+NZTXU3pxsi3RWY4DXdY1ZmOFFfJ/7SFjZeK/hv430m4RZGNjL LFkZPmopdMfiuPxq4bjlsfy4/ErSjPNeIis3JHTuK+OvEvh5nlcNEPNweg6VdaehjCJyXinw5p+h WdvYNaK19NarLK2/mJ2G4fkCAR9a+e59HllYIojXJA5Ukk15cnqd3Kjt9J0yHT4D5Z3Sr94kdxTo Z3mcuAdhOfXNa0otmEpW0N2CxQqzY+U/nWfqsFvAhDDjHc4/CuqMOgoyufPuqpFbawzkffwTg8Zz 6/SvZvCNgt3bhIz1wf8A9VbKApVEjs49GuImJAO7gDFXFTULVmAaVW/TArKWHiyqdaxlXFnYT7pL /S7K9RjuPnQhivvz0qjL4S8GXwJuNFtrZzwTF/TORXNUwz+yenRzC2jM2b4V+HZ45PseoJAx+6sk PH4kHmvOtT+HXibR7m7fTYzdodoQwfMSO/FcqoN7nRUrRlqjyzxDpOuSRodRsru2m3HAeEqeOvWs DQtGkubuCJFfzdwHKjJOelenhqVtDxMZdao/RiPQPL0fwpoIRUREjVto9AM+2eTX0LoemRW1vCi5 WPaBz/hTq7HLQlqcz8ULlU0jTLUt5e+5Cn1IAJ4/IVmx3V94fsNS1XSYY7q4jRJFLj5Y+erY+tfF 5pT5pan6DlCfJdnQ6b8d7y3hjW90a3uXAwzxzbcn6YNdBF+0JpZZnm0S7iIOBiQH9cc15Usuvsds 6GtzbT9oLwsUVJbLVVJbjCqQPrzWlafHDwa+7e17ErEZ3R9PyNJ5bJHNLDMu23xi8Eu5H2912kn5 4mz/ACqY/E7wddOTHrFug/2sgk/jWTwM+hhKlLYwfEfjLw9dqzQavYyMBziUYxXjXiPX7H7DZLHf Qth2Pyv0+tdeHwk09UcNeMonlWqao9xZXcEUytE3YGqdmkgs7czkmQqM4Ga9JUXHVnHCo72ZLKjs Mhcj8sVLp9lILu0Lfd3g4HpmiO43MoeNrURaXeYd42Zh07c1zvw30dNY1CWyu5rhoxGXBDc545r1 6MFyXPPqVnz2TPXdQ+FrSxu9td+cVb5UkHQ/7wryi/0OXT5biGYSI6Nhscg89c1VKd9jWre12ZMt ndZOCrkDgE8gUsKSiRQYxkdT6f5xXQ4nOsRYsq7qAQWc44A7VtWejatqUcckFtdzswyQqE8dM1HL YTrc2xSvPDd/G5M9ncbs4y6EYpsNtqEcLxxzzw4HBDHIq4RTM5xkkc/qOi6jeo6XF48hIIO4ZwDX EQeDZrC4SQF2jUnjv9a9SlUVrHmVoNu7NfQ9JeLWIJblAq78559a3WtnP26ZVO3f271XLzML2Ru/ Di7kTxDCXJQeYMj15r7j+OGlrd+DdB1RVj3NGoPqeOlefXo2qI7cPP3dT4xs7V2e8mdQcYHHb2rd uLPPhnUXO7O9TnHIwaupDQKNT39Sv4gCrp3hS9C+bGJQnXvt+n1/KuoZZ7mfSQ6FW5IJycf55rg9 nrc9mtVfJod14YsXOojzEPCnaTjHes22tn82/Cb8GbPTGTWnL0PLVTQ7JbTHhLUWCt8zhckcmudg skCQ/IU2qB06iiMbaIxlJvcveIrFjdaKE3BQmduDge9cZrtqRbsEALctgnGa6KMCL2PHtEtHk1q3 8xcuX5x65r6/8S2pbXNAhZs7LVBjHAIXpVYmJ1qXumxolgj6rZNCCiqx+UD71YkUAbX9elwzgEYw OhyTk/WuDl0MZTsdr4cgiWS+n8sbltz1HTjpXI6FCpTUJGiC5mYE+tYchUKi6nfWlt5eha7JuVQy 4J9vT9a5jQbZk0lCiLncThh05pRg2bOSsd1pdssfhbXbpV+Z8jgdeMf5xWHodrt0m0iKBW5PAzj6 0pRsTBnoCwvaeDNWkIPIPJGN2B0/WuJ0qB10mwUJjK7iTxkEelUoaFylY6C6VLfwZqZIG5jjOcY+ lc9o1hMdHsfkRztyxz1/OiMNCkzro7byfC+rSsW3bc5I4z6/rXn2iWM39jWrPGVkY7uOvJqY7kST PFPibH5dtciMLuJ+XcPu/SuG+GulG88W6VCQAWnj6465AB59+K7do3OvBvofOd94oNzGUlRvMPGM /ex3/lXJXeps6yFpHRS20tn1r4KOjPWktDNF7PKQQ53Lxlh0FaC6m8v7uJyrf3vX6Yqpip2JTfZ2 gkq2ASRUJ1A5dFdT8wJBOMj/ACKx5+hp7NX0Li60DmNVc5yGK8ZHSrQ1SLaux2c5wOgxiqLnRZUv NbdMTKyomRz6e9Jaa9I28rLIrcc57inynDURbGtvE+5pSm7HPc09tecIoD/LnJz6YosKKdhRr21V Czbuchd3TtV1tfdvmWSQKDjr1rSEepVOLLKa9OjZLkHPAz1/GpW8RTMyKZCilsDaacpGqbReXXWC cShh0Y+hzVlPEE+4De79hkdR71nGVhSlcuweIpAB5bvvH4DNTr4im3FSzqpx19apz7C3L58RTI21 ZiyY5x2qZfFMq7sSNImfXvU7sVyePxVMXzE3QfxN1q/F4snVnVJsL75rSMbGcos6GHxLOrLvmLZ+ ULmtH/hKZQu3zpd27qf4f1olG5vFpIcniy4ICrOxIwC3Y1aHjK7VVUXLnHPDUoy6GTkgj8bzgIRJ I+D19Ks/8LAuVwouQNp960aLUtCdPiZebhtkOOmM9v61ch+KFzB5n+lF/ox5/Cs3Ak0Ivi3dLg+e UQDpn/PtW3H8Xp8rILgHnHXpSdM3hJPRmlH8YLs4P2jIzj3FakXxhnVox5+focYqoxsKTfQ1rf4y 7tyeeTg46j5q1YvjMSoH2iQjODg0O/QUbsuw/GT73l3kjY5zn+lblp8X2QsftZ5wVIaqV+o+VmrB 8Z41cbb3uAQxyK2I/jAgYsLzHzbfvdfpzWcXqZ8utjah+M+doF4CmcDk5FbMXxpwBi6bGT3puN2V KPU1I/jTcrkG8Pr16e9b1j8Y25ma7BbOOvOPzpSpLoQdNa/GNlVSLvLdNua2YfjEduWu2x6bvzqP ZDcmaUXxjwM/aXyO+7oKtw/GR8h/tbhc/wB7mq9kNvSxqRfGcEAi6brzyav/APC5c8C6ZRnrnml7 Im5Yi+MjDK/bHk9yaur8aEyAbgOwwD8/FTKkxFu2+MYVg32kKCexrbh+Ng5/0v65aj6vfoaQkzTj +NsY2/6WG7H5qvx/GeJtu6cODyMkc0vqhTqNF5PjJaSbQZIGJ7ccVai+LWn8BjCTSeFsJVC7F8Ud
October 23, 2016 - December 19, 2016
Kolb-Archive.digest.vol-oh
