Kolb-Archive.digest.vol-om
April 03, 2017 - April 26, 2017
      > I usually land a little faster and it has not been a big deal,  but it is
      real..
      > Thanks again for making me think about it and visualize what may be
      happening in real life.
      > In the end , understanding the effects and being ready makes one fly
      safer.
      > Happy landings
      > FrankD
      > N1014S, MkIII Xtra
      > http://forums.matronics.com/viewtopic.php?p=468002#468002
Date: Apr 03, 2017
Subject: Re: : VG's: VG's
""If you are flying a MKIII and hauling a big ass passenger, modify your piloting technique to compensate for the forward cg."" I found that to be correct, when flying a passenger, I come over the fence at 70. Hit the numbers at 65 and maintain power till the wheels touch. I'm going to have to practice more with the vg's, but I'm sure changes are due. Boyd ________________________________________________________________________________
Date: Apr 03, 2017
Me neither John..My Kolbs flew just great...no complaints...Never had to use those wimpy stickums...!! :-) On 04/03/2017 08:15 PM, John Hauck wrote: > > Don't think we have an aircraft design problem, but "maybe" a piloting > problem. > > If you are flying a MKIII and hauling a big ass passenger, modify your > piloting technique to compensate for the forward cg. > > The basic design of the Kolb tail section has never changed, except small > differences in size. > > john h > mkIII > Titus, Alabama > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Hoppy > Sent: Monday, April 03, 2017 7:28 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: : VG's: VG's > > > Interesting conversation all.. > > My problem is considering the tail as aerodynamic...on the Kolbs... > I only see separation as the air hits the leading edge... certainly not an > airfoil in the classical sense and definitely not laminar... More > like a barn door...:-) A symmetrical airfoil is common on most > planes...as in "not flat". Seems to me that an all moving elevator would > work and likely could be much smaller... and could still fold... > > Herb...who talked to an aerodynamicist once... ( he likely could not > spell it either:-) ) > > > On 04/03/2017 06:37 PM, Frankd wrote: >> >> Hello group, >> I have been reading and learning about the topic of Tail Stall.. thank you > all. >> I fly a MkIII Xtra and limit my passengers to 200Lbs or less, because of > the issue with losing elevator authority during flare. >> I did not think "Tail Stall" existed but maybe I am wrong. Technically, > if a stall is where the air separates from the surface of a wing (or tail) > then perhaps that is what is happening when I have a heavy passenger. This > passenger moves the CG forward and this weight shift is offset by the use of > "Up" elevator. >> When landing and decreasing the airspeed the airflow over the elevator in > a full "UP" position could separate from the underside of the elevator and > that would explain why adding more back stick does nothing.. >> All the remedies support this theory:- >> a/ Add a gap seal - keeps the airflow flowing from top of Horz. Stab to > bottom of elevator >> b/ Add VG's to bottom of Horz Stab - keep the air attached to the bottom > of the elevator when the stick is full back thus making the elevator more > effective >> c/ Land faster - the faster airflow over the elevator increases authority > with less back pressure, thus reducing airflow separation. >> d/ move the CG back. Some aircraft have weight boxes in the tail so that > CG is controlled by adding a small weight on a long lever, effectively > offsetting the passenger weight somewhat , reducing the workload on the > elevator and making it more effective with smaller stick movements. (I have > not tried this but am thinking of moving one of my fuel tanks to a back > position when flying passengers to see what happens. ) >> I usually land a little faster and it has not been a big deal, but it is > real.. >> Thanks again for making me think about it and visualize what may be > happening in real life. >> In the end , understanding the effects and being ready makes one fly > safer. >> Happy landings >> FrankD >> N1014S, MkIII Xtra >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=468002#468002 >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Apr 03, 2017
I flew only one passenger in my old MkIII...and he was pretty lite...so I added maybe 10 mph on approach...Herb On 04/03/2017 08:25 PM, B Young wrote: > > ""If you are flying a MKIII and hauling a big ass passenger, modify your > piloting technique to compensate for the forward cg."" > > I found that to be correct, when flying a passenger, I come over the > fence at 70. Hit the numbers at 65 and maintain power till the > wheels touch. I'm going to have to practice more with the vg's, but > I'm sure changes are due. > > Boyd > ________________________________________________________________________________
Date: Apr 03, 2017
Subject: Vgs
For 900 hours I figured I had a good handling plane... I had an expensive lesson at 118 hours, I was too close to the ground to recover... afterwards I modified the way I flew the plane... For years I refused the thought of vgs. After putting them on,,, wish I had done it long long ago. I would say don't knock it till you try it. I truly believe that if I had had vgs on the horizontals, my expensive lesson would have been a non event. Boyd ________________________________________________________________________________
Date: Apr 03, 2017
Subject: Vgs
Should have thought to add,,, if you try vgs and don't like them, I promise to listen and try to learn. At that point let's compare notes. If you reject vgs on principle,,, you are now where I was a few months ago. My position is clear and have backed it up with numbers. If you are apposed, let me see your numbers., Angles, speeds,responsiveness, etc. Boyd ________________________________________________________________________________
Date: Apr 03, 2017
John Hauck wrote: > > Giving a demo flight in my MKIII at Lakeland some years ago, I was able to easily lose all elevator authority, almost without trying. We were out > horsing around, I told my passenger, "Let's try a steep dive to about 85 mph and a hard pull up with full flaps." We had already done the same clean. > To my surprise, when I pulled back on the stick the aircraft continued > straight down until I pulled up the flaps and then back on the stick. A > good demonstration of the flaps stealing air from the tail. > > john h > mkIII > Titus, Alabama > -- I partially agree that the flaps do steal the airflow over the elevators, but I think an even bigger factor is that lowering the flaps moves the center of lift aft. We both know that lowering the flaps on a MKIII Classic requires cranking in substantial amounts of up elevator trim, even when solo. IMO, the effect of the flaps to move the center of lift/pressure aft is at least as significant as what the flaps do to the airflow over the horizontal tail. Unfortunately, it typically all comes together to conspire against us when we least desire it... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468011#468011 ________________________________________________________________________________
Date: Apr 03, 2017
I tested a Mk IIIX to 1280 lb with cement bags in the passenger seat. With seals on the stabilizer to boom tube gap I could hold it in a stall for over 1000 feet and keep the wings level with the rudder. When I released the stick she started flying again. Landing at that weight was a bit like Pete Knight described flying the X15, "it's like milking a nervous mouse, you just don't want to make any sudden moves". Rick Girard On Mon, Apr 3, 2017 at 8:31 PM, Hoppy wrote: > > I flew only one passenger in my old MkIII...and he was pretty lite...so I > added maybe 10 mph on approach...Herb > > > On 04/03/2017 08:25 PM, B Young wrote: > >> >> ""If you are flying a MKIII and hauling a big ass passenger, modify your >> piloting technique to compensate for the forward cg."" >> >> I found that to be correct, when flying a passenger, I come over the >> fence at 70. Hit the numbers at 65 and maintain power till the whe els >> touch. I'm going to have to practice more with the vg's, but I'm sure >> changes are due. >> >> Boyd >> >> =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Apr 03, 2017
Yep, I am well aware of what takes place when the flaps are drooped. Takes a lot more aft stick to keep the nose up. However, in an 85 mph dive, straight down, pull back on the stick and nothing happens, no resistance, to me, sitting in the driver's seat, got the impression there was no air on the elevators. Soon as I pulled up flaps, I got resistance and the nose came right up. I got the same feel and sensation in 1990, when the leading edges of both wings failed. There was no feeling in elevator, rudder, or ailerons. Just like sitting on the ground dead still. At 75 mph I should have had some resistance in the controls, unless they had all gotten blanked out by the two new spoilers on the wings. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Monday, April 03, 2017 9:30 PM Subject: Kolb-List: Re: : VG's: VG's --> John Hauck wrote: > > Giving a demo flight in my MKIII at Lakeland some years ago, I was > able to easily lose all elevator authority, almost without trying. We were out horsing around, I told my passenger, "Let's try a steep dive to about 85 mph and a hard pull up with full flaps." We had already done the same clean. > To my surprise, when I pulled back on the stick the aircraft continued > straight down until I pulled up the flaps and then back on the stick. > A good demonstration of the flaps stealing air from the tail. > > john h > mkIII > Titus, Alabama > -- I partially agree that the flaps do steal the airflow over the elevators, but I think an even bigger factor is that lowering the flaps moves the center of lift aft. We both know that lowering the flaps on a MKIII Classic requires cranking in substantial amounts of up elevator trim, even when solo. IMO, the effect of the flaps to move the center of lift/pressure aft is at least as significant as what the flaps do to the airflow over the horizontal tail. Unfortunately, it typically all comes together to conspire against us when we least desire it... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468011#468011 ________________________________________________________________________________
Subject: VG's, tail stall, angle of attack
Date: Apr 03, 2017
Don't know about Kolbs (yet) but tail stall isn't that uncommon in other a/c. The early Cessna Cardinal required a stabilator redesign due to tail stall. If answers are desired about whether there's a tail stall problem with a particular plane, why not install an angle of attack meter? Doesn't have to be high dollar; just an indicator that has consistent, repeatable readings. The wing always stalls at the same angle of attack. If the plane stalls at some arbitrary angle indication ('x') on your AOA when the plane is lightly loaded, and it stalls at some lower angle (y?) on the same indicator when heavily loaded and/or at a more forward CG, then the tail has stalled instead of the wing. If the plane stalls at the same AOA indication but a higher airspeed, then it's the wing that's stalling. Charlie ________________________________________________________________________________
Date: Apr 03, 2017
Subject: Re: VG's, tail stall, angle of attack
This whole thing is getting blown out of proportion. Boyd's and John's problem concerned weight and CG change, caused by weight. I believe that the original beginning of this thread came about concerning VG's on the wing, but none on the elevator. Perhaps the language or description of the reasoning for why one should also put them on the elevator was inadequate. The "tail stall" that did or did not occur during landing was not a problem in any other configuration other than landings. Even when it did occur upon landing, it was in no way any more than a Hmmm factor of about 1. It was just that I like others before me had learned, that the wing still had lift, with VG's, long after the tail had dropped to the ground. Since this was occurring at 2 feet above the ground, it was not Scary! It certainly is not a design flaw. :-) Merely that you now had a lot more usable lift than you had before the installation of VG's, and you could even out the lift between the wing and the elevator by adding some of the little thingys on the elevator. There! I hope that clears things up a bit. Larry On Mon, Apr 3, 2017 at 9:53 PM, Charlie England wrote: > > Don't know about Kolbs (yet) but tail stall isn't that uncommon in other > a/c. The early Cessna Cardinal required a stabilator redesign due to tail > stall. > > If answers are desired about whether there's a tail stall problem with a > particular plane, why not install an angle of attack meter? Doesn't have to > be high dollar; just an indicator that has consistent, repeatable readings. > > The wing always stalls at the same angle of attack. If the plane stalls at > some arbitrary angle indication ('x') on your AOA when the plane is lightly > loaded, and it stalls at some lower angle (y?) on the same indicator when > heavily loaded and/or at a more forward CG, then the tail has stalled > instead of the wing. If the plane stalls at the same AOA indication but a > higher airspeed, then it's the wing that's stalling. > > Charlie > > -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Apr 04, 2017
Larry C/Kolbers: I didn't fly yesterday, and I forgot what I did day before yesterday. Think I put VGs on the horizontal stabilizer. ;-) My job for many, many years was to fly prospective customers in the MKIII at Lakeland and Oshkosh. I flew all kinds of shapes and sizes in a difficult environment at best, lots of traffic, confined airstrip, wind, and turbulence. Never had a elevator problem. On several occasions I did use extreme vigilance and care flying a few super heavy passengers. Something I should not have done at the time, and something I would not do in the future. One situation the customer would not buy the airplane without a ride first. It was not the best flying MKIII I had ever flown. I was pretty apprehensive about the flight. I agreed to fly him out of Lakeland South where I had a lot more airstrip and less traffic. This guy was what I called a "lopper". When he got in the right seat he lopped over the aileron torque tube in the center of the aircraft. Made it difficult for me to get my hand on the center mounted throttle. This was a short flight, full throttle from take off to landing, one circuit around the pattern. I was not going to take a chance of becoming a lawn dart. I've never flown a Kolb that had an elevator problem, but when I was carrying large passengers I always carried a little extra airspeed until I was back on the ground. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Monday, April 03, 2017 11:54 PM Subject: Re: Kolb-List: VG's, tail stall, angle of attack --> This whole thing is getting blown out of proportion. Boyd's and John's problem concerned weight and CG change, caused by weight. I believe that the original beginning of this thread came about concerning VG's on the wing, but none on the elevator. Perhaps the language or description of the reasoning for why one should also put them on the elevator was inadequate. The "tail stall" that did or did not occur during landing was not a problem in any other configuration other than landings. Even when it did occur upon landing, it was in no way any more than a Hmmm factor of about 1. It was just that I like others before me had learned, that the wing still had lift, with VG's, long after the tail had dropped to the ground. Since this was occurring at 2 feet above the ground, it was not Scary! It certainly is not a design flaw. :-) Merely that you now had a lot more usable lift than you had before the installation of VG's, and you could even out the lift between the wing and the elevator by adding some of the little thingys on the elevator. There! I hope that clears things up a bit. Larry On Mon, Apr 3, 2017 at 9:53 PM, Charlie England wrote: > --> > > Don't know about Kolbs (yet) but tail stall isn't that uncommon in > other a/c. The early Cessna Cardinal required a stabilator redesign > due to tail stall. > > If answers are desired about whether there's a tail stall problem with > a particular plane, why not install an angle of attack meter? Doesn't > have to be high dollar; just an indicator that has consistent, repeatable readings. > > The wing always stalls at the same angle of attack. If the plane > stalls at some arbitrary angle indication ('x') on your AOA when the > plane is lightly loaded, and it stalls at some lower angle (y?) on the > same indicator when heavily loaded and/or at a more forward CG, then > the tail has stalled instead of the wing. If the plane stalls at the > same AOA indication but a higher airspeed, then it's the wing that's stalling. > > Charlie > > -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Subject: Sun and Fun 2017
Date: Apr 04, 2017
Talked to Bryan Melborn yesterday. Kolb Company was set up and ready to go in Lakeland. He has a spot reserved for me and Miss P'fer for the week. Almost ready to go. Don't know why it takes so much stuff to survive a few days at Sun and Fun, but it does. One doesn't have to train to be miserable, so I take all the things I need to be comfortable. I tie down the MKIII in the Kolb display area and put my tent up under the wing. It is super convenient for me. Don't have to go anywhere and all my stuff I need to live is right where I am located. It is 415 sm from Gantt International Airport to Lakeland, about 5.0 hours flight time. I make one fuel stop in Cross City, Florida. That gives me enough gas to fly to Lakeland and return to Cross City to refuel on the way home. They always have free hot dogs and usually cheaper av gas, so I get lunch both ways. Weather is a little iffy when I get down southeast of Tallahassee, Florida. I'm mentally prepared to take my time, find a comfortable place to hang out if I do encounter thunder storms. This is a fun flight, no hurry, and no deadline to make. The air show at Lakeland tends to be aggravating at times. It usually lasts from 1400 to 1700 hours. Can't land during that time frame. Also, the field is Day VFR only which is good until 2011 eastern time today. I can take my time and enjoy my flight. The NOTAM for Paradise City says Day VFR Only. I printed out a copy of the data from the Naval Observatory to back me up if I come into Lakeland as late as 2011 tonight. Also printed out a copy of the Paradise City NOTAM. Usually I get, from the volunteers that run the airfield, no flying after 1900 hours. Got to have my ammo in case they decide to attack me, which they do at times. ;-) Time go. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Apr 04, 2017
We shouldn't get upset because some people like to use correct and accurate terminology when talking about a phenomenon. Charlie, I think your response is brilliant. For those of us who do want to use the correct term to describe what is happening I applaud your insight and I can help with that. I make (and sell) an inexpensive Angle of Attack indicator that dozens of people love. After my last batch of probes and gauges ran out I haven't pushed it but am redesigning the probe for it and can offer it again. There is a link to it on my site ranss7.com New faces will have the needle more or less horizontal with red at the top (high angle) and green at the bottom. And on the subject of VG s on stab, aren't they usually placed just ahead of the hinge line where the air is going to break as it goes over the elevator not up near the leading edge??? If answers are desired about whether there's a tail stall problem with a particular plane, why not install an angle of attack meter? Doesn't have to be high dollar; just an indicator that has consistent, repeatable readings. The wing always stalls at the same angle of attack. If the plane stalls at some arbitrary angle indication ('x') on your AOA when the plane is lightly loaded, and it stalls at some lower angle (y?) on the same indicator when heavily loaded and/or at a more forward CG, then the tail has stalled instead of the wing. If the plane stalls at the same AOA indication but a higher airspeed, then it's the wing that's stalling. Charlie[/quote] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468032#468032 Attachments: http://forums.matronics.com//files/face_black_side_push_143.jpg ________________________________________________________________________________
Date: Apr 04, 2017
=8BI'm shocked!!! John H has put VGs on his airplane! I'm expecting s ome cataclysmic event to follow=8B!!!! Years ago I witnessed and reported on the great VG fly off between John and Richard Pike at a Kolb flyin. It should be in the archives so I won't go back into the details here. But it was a tie. I have some VGs on the sides of my fuselage at the wide point on my doors and they do reduce the noise coming from the rear fuselage. I have plans to someday put VGs on my wings and under my tail but it is a low priority. I have a heavy engine and have put some major beef in the passenger compartment including myself, I don't think anyone lapped but I can't say that the old MKIIIC was ever less than capable of safely committing flight. Also I saw the post about missing Buford, has something happened to him??? Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Date: Apr 04, 2017
We shouldn't get upset because some people like to use correct and accurate terminology when talking about a phenomenon. And on the subject of VG s on stab, aren't they usually placed just ahead of the hinge line where the air is going to break as it goes over the elevator not up near the leading edge??? --------------------------------------------------------------------------------------------------------------------- I suppose that I shouldn't feel a bit chapped, as I volunteered to take the blame for the wandering of this thread.----This is the original: Larry Cottrell Mar 31 (4 days ago) to kolb-list I have to admit that I am quite proud of you. Whether you believe it or not, the ones on the elevator do help t keep the tail flying and will also improve the landings. As I mentioned earlier, without them the tail feathers stall before the wing. --------------------------------------------------------------------------------------------- As far as the VG's are concerned they, to the best of my knowledge, should be placed in front of the hinge line. Apparently they still do quite well in other spots as well. Inaccurately yours, Larry ________________________________________________________________________________
Date: Apr 04, 2017
What some folks might think of as a "tail stall" may just be air separating from the elevator itself. So the entire tail is not technically stalled, but if the air separates from the bottom of the elevator you would very likely see a reduction in control authority. So maybe "elevator stall" is the better way to describe it. The flat cross section tails (no airfoil) would likely be more prone to this, because the airflow forward of the hinge line is not as smooth or organized as it would be on a properly airfoiled tail. But as we know, tens of thousands of Cubs, Taylorcrafts, Aeroncas, Porterfields, and Kolbs are flying safely without an airfoiled tail. The "flat" tail is simply a compromise to make the airplanes easier and/or less costly to build. On a 70-90 MPH airplane it is an easy and worthwhile compromise to make. As a non-Kolb point of reference, I have an old Cessna 172 (1956, first year). Anyone with Cessna 172 time will verify that the airplanes are kind of nose-heavy with the rear seats empty, and that you basically "run out of elevator" when you are trying to do a minimum speed landing with one or two people in the front seats. What happens is that you feel the yoke (stick) hit the control stop, and you can't raise the nose any more, even though you can feel the airplane was willing to slow down a little more. But then I woke up one Christmas morning (in August), and in the middle of the night Santa Claus had installed little plastic VG's on the bottom of my horizontal stabilizer. As I was flying the aircraft directly to the Oklahoma City FAA office to report Santa for breaking the rules, I noticed that I was able to raise the nose of the Cessna just a little bit higher when I wanted to slow the airplane down that last mile an hour on landing. I didn't have any numerical way to measure it, but it was clear that there was a small improvement. By the time I hit the control stop with the yoke all the way back, the nose was a tad higher. Another trick that works in the Cessna is adding a small touch of power at the last 2 or 3 seconds of the flare. This puts a little more prop blast on the elevator and allows you to raise the nose another degree or two higher before "tail stall" / "elevator stall" / "no more control authority". I have not done this on a Kolb, but perhaps some Kolb pilots have tried this. I'd be interested to see if a little prop blast solves or delays the loss of elevator authority at the flare. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities ________________________________________________________________________________
Subject: Sun and Fun 2017 Canceled (for me)
Date: Apr 04, 2017
Hi Folks: Got the airplane pushed out, topped off, and loaded. Come to find out my Hawker Odyssey Battery I bought in 2006 or 2007 decided this morning it was time to die. Started great last time I flew two days ago. I have a new lithium battery jump start that I brought along today for its first flight. Used it before we got off the ground. BTW, we didn't get off the ground. Got it going, ran it 15 minutes while I finished loading. Shut it down, got in and it failed to start. Called Bryan Melborn and canceled out Lakeland this year. By the time I got a replacement it would have been too late to fly today. Thursday is doable, wind is out of the WNW, but there's lots of wind, plus 23 mph. Looks like this will be the first S&F I have missed since my first in 1984. Hopefully, there will be next year. All the preparation didn't hurt a thing. I got the MKIII cleaned up, tuned up, VG'd, and got me back into the swing of aviation again. I'll be ready to fly West come next September. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Apr 04, 2017
Bill With the high thrust line in our Kolbs I don't think adding power while flaring is going to help you raise the nose. The normal advice is to approach with a bit of power then cut the power to assist with flare. As a side note, years ago when I was sorting out my VW I had a reduction drive failure when I was at about 1,000 AGL. My normal landing procedure is approaching with just a bit of power with one notch of flaps cutting power after I settle in. I practiced ahead of time landing with no power with no flaps and found the landing just about the same as some power with one notch. So using what I had practiced I used my flaps like a negative throttle to get me where I wanted to land then raised the flaps for landing. No big deal. The added bonus was that nice landing spot turned out to be a bean field and with no flaps I was able to get the tail down in the beans first. The beans grabbed the tail wires like a carrier arresting cable and I landed with no damage what so ever. Rick Neilsen Redrive VW powered MKIIIC On Tue, Apr 4, 2017 at 1:22 PM, Bill Berle wrote: > > What some folks might think of as a "tail stall" may just be air > separating from the elevator itself. So the entire tail is not technically > stalled, but if the air separates from the bottom of the elevator you would > very likely see a reduction in control authority. So maybe "elevator stall" > is the better way to describe it. > > The flat cross section tails (no airfoil) would likely be more prone to > this, because the airflow forward of the hinge line is not as smooth or > organized as it would be on a properly airfoiled tail. But as we know, tens > of thousands of Cubs, Taylorcrafts, Aeroncas, Porterfields, and Kolbs are > flying safely without an airfoiled tail. The "flat" tail is simply a > compromise to make the airplanes easier and/or less costly to build. On a > 70-90 MPH airplane it is an easy and worthwhile compromise to make. > > As a non-Kolb point of reference, I have an old Cessna 172 (1956, first > year). Anyone with Cessna 172 time will verify that the airplanes are kind > of nose-heavy with the rear seats empty, and that you basically "run out of > elevator" when you are trying to do a minimum speed landing with one or two > people in the front seats. What happens is that you feel the yoke (stick) > hit the control stop, and you can't raise the nose any more, even though > you can feel the airplane was willing to slow down a little more. > > But then I woke up one Christmas morning (in August), and in the middle of > the night Santa Claus had installed little plastic VG's on the bottom of my > horizontal stabilizer. As I was flying the aircraft directly to the > Oklahoma City FAA office to report Santa for breaking the rules, I noticed > that I was able to raise the nose of the Cessna just a little bit higher > when I wanted to slow the airplane down that last mile an hour on landing. > I didn't have any numerical way to measure it, but it was clear that there > was a small improvement. By the time I hit the control stop with the yoke > all the way back, the nose was a tad higher. > > Another trick that works in the Cessna is adding a small touch of power at > the last 2 or 3 seconds of the flare. This puts a little more prop blast on > the elevator and allows you to raise the nose another degree or two higher > before "tail stall" / "elevator stall" / "no more control authority". I > have not done this on a Kolb, but perhaps some Kolb pilots have tried this. > I'd be interested to see if a little prop blast solves or delays the loss > of elevator authority at the flare. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and > for-profit entities > > ________________________________________________________________________________
Date: Apr 04, 2017
Rick N/Kolbers: It'll be alright. Miracles happen every day. The cataclysmic event to follow was my dead battery. Not much of an event, but enough to change my plans. Yes, Richard P and I had a little slow flight competition between our two birds. His with VGs and mine naked as a J- Bird. Rick thinks we tied. Richard claims radio problems. What's that got to do with slow flight? I think I beat him. We'll have to do it again now that I have VGs. Buford has some medical problems. Don't know what, but it is enough to keep him off the List. Yes, I miss ole Buford too. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen Sent: Tuesday, April 04, 2017 10:12 AM Subject: Re: Kolb-List: VG's, tail stall, angle of attack =8BI'm shocked!!! John H has put VGs on his airplane! I'm expecting some cataclysmic event to follow=8B!!!! Years ago I witnessed and reported on the great VG fly off between John and Richard Pike at a Kolb flyin. It should be in the archives so I won't go back into the details here. But it was a tie. I have some VGs on the sides of my fuselage at the wide point on my doors and they do reduce the noise coming from the rear fuselage. I have plans to someday put VGs on my wings and under my tail but it is a low priority. I have a heavy engine and have put some major beef in the passenger compartment including myself, I don't think anyone lapped but I can't say that the old MKIIIC was ever less than capable of safely committing flight. Also I saw the post about missing Buford, has something happened to him??? Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Date: Apr 04, 2017
Subject: Tail stall
Running a 3800 to 4000 creates a sufficient wind flow over the tail to restore authority. As an energy management tool it will give you longer time to find the runway, but also uses more runway. If you have runway to spare, no problem.. if you are trying to get into a 700 ft strip at 4000 msl. You don't need to be leaving any runway behind you. Boyd ________________________________________________________________________________
Date: Apr 04, 2017
Subject: Re: Sun and Fun 2017 Canceled (for me)
I'm sorry to hear of your misfortune John. I'm sure they'll miss ya. I remou nted my little 377 today on my Firestar 1. It's been sealed away since 1990. It'll be ready start next week? George H. Firestar MK1, FS100 14GDH gdhelton(at)gmail.com Mesick, Michigan Have a great day! > On Apr 4, 2017, at 2:05 PM, John Hauck wrote: > > Hi Folks: > > Got the airplane pushed out, topped off, and loaded. Come to find out my H awker Odyssey Battery I bought in 2006 or 2007 decided this morning it was t ime to die. Started great last time I flew two days ago. > > I have a new lithium battery jump start that I brought along today for its first flight. Used it before we got off the ground. BTW, we didn't get of f the ground. Got it going, ran it 15 minutes while I finished loading. Sh ut it down, got in and it failed to start. Called Bryan Melborn and cancele d out Lakeland this year. By the time I got a replacement it would have bee n too late to fly today. > > Thursday is doable, wind is out of the WNW, but there's lots of wind, plus 23 mph. > > Looks like this will be the first S&F I have missed since my first in 1984 . Hopefully, there will be next year. > > All the preparation didn't hurt a thing. I got the MKIII cleaned up, tune d up, VG'd, and got me back into the swing of aviation again. I'll be ready to fly West come next September. > > john h > > mkIII > > Titus, Alabama ________________________________________________________________________________
Date: Apr 05, 2017
Subject: : VG's: VG's
I agree with John, carry a bit more speed on final and a bit more forward pressure on the stick, keep the tail flying longer. I'm confident you will experience better landings. Jim On Apr 3, 2017 9:17 AM, "John Hauck" wrote: > Add a little airspeed when flying healthy passengers. > > > Last thing I would do is add weight to my airplane to counteract > ineffective tail. However, I have added plenty of weight to Miss P'fer for > many other reasons. ;-) > > > john h > > mkIII > > Titus, Alabama > > > *From:* owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list- > server(at)matronics.com] *On Behalf Of *B Young > *Sent:* Monday, April 03, 2017 11:02 AM > *To:* Kolb List > *Subject:* Re: Kolb-List: : VG's: VG's > > > To all, I guess the tail stall may be my ball of wax, let me make one > more stab at it..... > > I have described what I have experienced as tail stall. With some > information received off list, I will make another option available. > > When flying with a passenger, I could only generate enough down force to > slow my mkiii to 15 to 20 MPH above the speed the wing stalls. I've called > this tail stall. I guess to be able to defiantly call it tail stall I > should tuft the bottom of the elevators. Then there would be no > question. > > The alternative possibly could be that the horizontal stabilizer and the > elevators may not be stalling, but it may be that the control surfaces > may be too small to provide the down force necessary. > > Up untill the time I installed vgs I would have said that either > explanation was plausible. As soon as i installed the vgs on the > underside of the horizontal stabilizer,,, I instantly had enough down force > to hold the plane in a level attitude until the wing stalls. That would > indicate to me that the control surfaces were large enough. The vgs have > kept the air attached so that the elevators can work to their potential. > Had the vgs made no difference, I would have decided that the control > surfaces were too small. > > I spent some time at the computer and re did my w&b. Cg limits per the > plan are 25 to 35 percent of wing cord. When experiencing insufficient > down force, my cg calculated to 26.66. within the limits. > > My conclusion is that you eliminate tail stall, there are 3 ways that I > have come up with,,, (maybe 4) 1. Install larger horizontals and > elevators. 2. Install vgs. 3. Limit your passenger's weight. 4. > Add more physical weight to the tail.(thus applying more down force by > gravity in lieu of aero dynamics) > > I understand that men are deep thinkers, and maybe I have over thought > this. Larry stop laughing! > > Boyd > ________________________________________________________________________________
Date: Apr 05, 2017
Subject: Vgs
Clip"""And on the subject of VG s on stab, aren't they usually placed just ahead of the hinge line where the air is going to break as it goes over the elevator not up near the leading edge???"""end clip ............... The instructions from John Gilpen say to install the vgs at 4 inches forward of the elevator hinge. If I had more vg sticky pads, I may have re tested by removed the vgs, and reinstalling them further forward. Then either move them back to the 4 inch location or leave them in the forward position depending on results. My thinking of why to put them further forward was a combination of a couple ideas. 1. In a further forward position, there would be more 'time / distance' for the vortex to develop. 2. Similar concept but a different way to look at it. On the wing we know that the vgs maintain better aileron control. The aileron is 3 1/2 feet back from the vgs. The question in my mind, if the vortexes are adding benefit 3 1/2 plus feet back, why limit it to 4 inches. There is a good chance someone has tested in this manner and that is why 4 inches is the recommendation. If any of you know, please pass on the information. Boyd Young ________________________________________________________________________________
Date: Apr 05, 2017
Subject: tail stall and vg's
Hi all, I've been watching the thread and am glad Big John now likes the vg things. I use homemade ones. In an Experimenter EAA mag from the early nineties John Dresseldoff reported on his work with vg's and a 150 Cessna. He modified the wing tips, the control surfaces, etc and had slow flight down in the mid 20mph range. He had hundreds of vg's on the wing alone.Very interesting article. And no one cared. In the poh of a 1952 170B Cessna I had it was stated no slips with full flaps. Hand written in, so I went looking why. The 170 club had found, after a fatal, that the flaps blanketed the tail with disturbed air and caused the plane to become uncontrollable near the ground. Lawn dart.My 1948 straight wing 170 did not have this issue as it had very small flaps. Loved to slip it did.. I'll see if I can find that Experimenter . Good luck all. ________________________________________________________________________________
Date: Apr 05, 2017
The 170 club had found, after a fatal, that the flaps blanketed the tail with disturbed air and caused the plane to become uncontrollable near the ground. Thanks for that info, Del V. After Boyd Young's post about horizontal stab placement of VGs, I did a Google search. Discovered the reason most military transport aircraft have high tails is to keep them in clean air when flaps are deployed. Makes sense to me. The other reason, that was not mentioned in my search, was loading and off loading through a tail gate. The large flaps on the MKIII are in line with the tail section. Not hard, for me, to believe they'll divert the air off the tail, full flaps, engine at idle power. When it happened to me, at 85 mph, there was no resistance, no feel in the elevators. A discomforting feeling when diving straight down with a fat passenger. ;-) john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Apr 05, 2017
John Hauck wrote: > Rick N/Kolbers: > > It'll be alright. Miracles happen every day. The cataclysmic event to follow was my dead battery. Not much of an event, but enough to change my plans. > > Yes, Richard P and I had a little slow flight competition between our two birds. His with VGs and mine naked as a J- > Bird. Rick thinks we tied. Richard claims radio problems. What's that got to do with slow flight? I think I beat him. We'll have to do it again now that I have VGs. > > Buford has some medical problems. Don't know what, but it is enough to keep him off the List. Yes, I miss ole Buford too. > > john h > mkIII > Titus, Alabama > > > Yes, it was pretty much a tie. When the radio quit (I had knocked one of the plugs loose from the comm box behind the seat where it was plugged in) there was no way for us to coordinate how we were going to do things. I was uncomfortable with getting side by side with even a highly skilled pilot like yourself when we are having a slow fly competition where we are flying side by side as slow as possible, and by definition on the edge of a stall, and not being able to communicate or coordinate with each other. At times I was lower than you and could not see you, and flying next to somebody I can't see or talk to had me thinking "This is insane." Maybe you could see me, and were watching me close, but how could I know that? If I could have known that you were going to stay in a position to watch me and be responsible for any eventuality, that would have sufficed, & I could have focused on flying, but nothing had been arranged. So I was really distracted, & IMO it had a lot to do with everything. It would be fun to do it again, but I suspect that next time you would win hands down. I think the reason for the tie last time is that both of us were using a lot of power and a 100hp MKIII w/o vg's ought to hang on the prop to the point that it can fly just as slow as a lighter 65hp MKIII with vg's. A better test would be two MKIII's of equal engine and prop, one with VG's, one w/o. Hate that you missed S & F, you have always been a fixture at the Kolb tent. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468067#468067 ________________________________________________________________________________
Date: Apr 05, 2017
Nope. 100 hp had nothing to do with the competition except increase the weight of my already fat MKIII, which still had half my gear on board. Wonder how much heavier it was than yours. I was probably turning 3000, nibbling on the stall. As an added note: My 912ULS only produces 95 hp on my airplane because it is propped for 5500 WOT straight and level. To get 100 hp I'd have to prop for 5800 WOT straight and level flight. I can assure you I had you in sight constantly. A little something I learned about flying formation in helicopters many years ago. Besides, I made it clear on the ground I would fly the right side, south, of the airstrip and you would fly the north side. I believe you also suggested this slow flight competition to prove you could whip my ass with your VGs. ;-) There is no better test than the test between me and you, my airplane and your airplane, to see which one could fly the slowest. I beat. ;-) john h mkIII Titus, Alabama - Fly like a butter fly, float like a feather. ;-) -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Wednesday, April 05, 2017 11:09 AM Subject: Kolb-List: Re: VG's, tail stall, angle of attack --> John Hauck wrote: > Rick N/Kolbers: > > It'll be alright. Miracles happen every day. The cataclysmic event to follow was my dead battery. Not much of an event, but enough to change my plans. > > Yes, Richard P and I had a little slow flight competition between our > two birds. His with VGs and mine naked as a J- Bird. Rick thinks we tied. Richard claims radio problems. What's that got to do with slow flight? I think I beat him. We'll have to do it again now that I have VGs. > > Buford has some medical problems. Don't know what, but it is enough to keep him off the List. Yes, I miss ole Buford too. > > john h > mkIII > Titus, Alabama > > > Yes, it was pretty much a tie. When the radio quit (I had knocked one of the plugs loose from the comm box behind the seat where it was plugged in) there was no way for us to coordinate how we were going to do things. I was uncomfortable with getting side by side with even a highly skilled pilot like yourself when we are having a slow fly competition where we are flying side by side as slow as possible, and by definition on the edge of a stall, and not being able to communicate or coordinate with each other. At times I was lower than you and could not see you, and flying next to somebody I can't see or talk to had me thinking "This is insane." Maybe you could see me, and were watching me close, but how could I know that? If I could have known that you were going to stay in a position to watch me and be responsible for any eventuality, that would have sufficed, & I could have focused on flying, but nothing had been arranged. So I was really distracted, & IMO it had a lot to do with everything. It would be fun to do it again, but I suspect that next time you would win hands down. I think the reason for the tie last time is that both of us were using a lot of power and a 100hp MKIII w/o vg's ought to hang on the prop to the point that it can fly just as slow as a lighter 65hp MKIII with vg's. A better test would be two MKIII's of equal engine and prop, one with VG's, one w/o. Hate that you missed S & F, you have always been a fixture at the Kolb tent. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468067#468067 ________________________________________________________________________________
Date: Apr 05, 2017
Subject: Re: tail stall and vg's
I remember that article !!! He had some tubes that were mounted spanwise behind the flaps, and a bunch of other wild stuff. The tubes served as a poor boy double or triple slotted flap like DeHavilland had. Being round tubes it didn't matter what the flap deflection was, they would provide a cambered surface. The article went on to say he was a "unique" guy, or that he was "more determined" than your average airplane modifier or something. It looked like something that NACA would do in the 1950's. I remember that the article said he made very significant reductions in minimum speed, at the cost of cruise speed of course. But I remember thinking that this guy was worth respecting because he pulled out all the stops and went for broke. I would love to see that article again if you can find it. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Wed, 4/5/17, Del Vinal wrote: Subject: Kolb-List: tail stall and vg's To: kolb-list(at)matronics.com Date: Wednesday, April 5, 2017, 8:22 AM Hi all, I've been watching the thread and am glad Big John now likes the vg things. I use homemade ones. In an Experimenter EAA mag from the early nineties John Dresseldoff reported on his work with vg's and a 150 Cessna. He modified the wing tips, the control surfaces, etc and had slow flight down in the mid 20mph range. He had hundreds of vg's on the wing alone.Very interesting article. And no one cared. In the poh of a 1952 170B Cessna I had it was stated no slips with full flaps. Hand written in, so I went looking why. The 170 club had found, after a fatal, that the flaps blanketed the tail with disturbed air and caused the plane to become uncontrollable near the ground. Lawn dart.My 1948 straight wing 170 did not have this issue as it had very small flaps. Loved to slip it did.. I'll see if I can find that Experimenter . Good luck all. ________________________________________________________________________________
Date: Apr 05, 2017
Yep...Bill No wild geese no gosling's!! Guys like Homer and Dennis and Wayne Ison did a fine job of advancing our field of flying,..,. I tell the GA buddies who like to rib me...."just a weed eater that flies!! and you are just a medical from flying one yourselves!" Herb On 04/05/2017 11:54 AM, Bill Berle wrote: > > I remember that article !!! He had some tubes that were mounted spanwise behind the flaps, and a bunch of other wild stuff. > > The tubes served as a poor boy double or triple slotted flap like DeHavilland had. Being round tubes it didn't matter what the flap deflection was, they would provide a cambered surface. > > The article went on to say he was a "unique" guy, or that he was "more determined" than your average airplane modifier or something. It looked like something that NACA would do in the 1950's. I remember that the article said he made very significant reductions in minimum speed, at the cost of cruise speed of course. But I remember thinking that this guy was worth respecting because he pulled out all the stops and went for broke. > > I would love to see that article again if you can find it. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Wed, 4/5/17, Del Vinal wrote: > > Subject: Kolb-List: tail stall and vg's > To: kolb-list(at)matronics.com > Date: Wednesday, April 5, 2017, 8:22 AM > > Hi all, > I've been watching the thread and am glad Big John now > likes the vg things. I use homemade ones. In > an Experimenter EAA mag from the early nineties John > Dresseldoff reported on his work with vg's and a 150 > Cessna. He modified the wing tips, the control surfaces, etc > and had slow flight down in the mid 20mph range. He had > hundreds of vg's on the wing alone.Very interesting > article. And no one cared. In the poh of a > 1952 170B Cessna I had it was stated no slips with full > flaps. Hand written in, so I went looking why. The 170 club > had found, after a fatal, that the flaps blanketed the tail > with disturbed air and caused the plane to become > uncontrollable near the ground. Lawn dart.My 1948 straight > wing 170 did not have this issue as it had very small flaps. > Loved to slip it did.. I'll see if I > can find that Experimenter . Good luck all. > > > ________________________________________________________________________________
Date: Apr 05, 2017
Herb wrote: "just a weed eater that flies!! and you are just a medical from flying one yourselves!" Well I have a confession to make, and everyone here can give me a great big ration of s*** for it with my blessing. Once upon a time I was one of those guys that looked down their noses at "other" kinds of airplanes. I was lucky enough to be a sailplane racer in the 1980's, flying those beautiful gleaming white hand built German gliders with 50 foot wingspans. When I saw "lawn chair" ultralights with their loud 2 stroke engines, or powered parachutes, or even the Cessna 150's that I had learned how to fly in... I thought all that was just so low class. Thankfully, a combination of age, wisdom, education, seeing things from different perspectives... and having life punch me in the face a few times... changed all that. I can't afford one aileron for a racing sailplane these days. As I had posted some months ago, when I first saw a Kolb I thought it was comical looking, and why would anyone design something that looked like that. Years later when I learned more about airplanes and what makes them fly one way or another, I eventually understood what Homer Kolb was trying to accomplish. And eventually I went looking for a Kolb because of the unique combination of features and capabilities it has. So now I'm the guy at the airport who just as soon defends light and ultralight aircraft when my Cessna driver friends rib me about it. I love my old 172, and I would give anything to be back in the cockpit of a racing sailplane, but I try to appreciate every other type of aircraft just as much. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Wed, 4/5/17, Hoppy wrote: Subject: Re: Kolb-List: tail stall and vg's To: kolb-list(at)matronics.com Date: Wednesday, April 5, 2017, 11:27 AM Yep...Bill No wild geese no gosling's!! Guys like Homer and Dennis and Wayne Ison did a fine job of advancing our field of flying,..,. I tell the GA buddies who like to rib me...."just a weed eater that flies!! and you are just a medical from flying one yourselves!" Herb On 04/05/2017 11:54 AM, Bill Berle wrote: > --> Kolb-List message posted by: Bill Berle > > I remember that article !!! He had some tubes that were mounted spanwise behind the flaps, and a bunch of other wild stuff. > > The tubes served as a poor boy double or triple slotted flap like DeHavilland had. Being round tubes it didn't matter what the flap deflection was, they would provide a cambered surface. > > The article went on to say he was a "unique" guy, or that he was "more determined" than your average airplane modifier or something. It looked like something that NACA would do in the 1950's. I remember that the article said he made very significant reductions in minimum speed, at the cost of cruise speed of course. But I remember thinking that this guy was worth respecting because he pulled out all the stops and went for broke. > > I would love to see that article again if you can find it. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Wed, 4/5/17, Del Vinal wrote: > > Subject: Kolb-List: tail stall and vg's > To: kolb-list(at)matronics.com > Date: Wednesday, April 5, 2017, 8:22 AM > > Hi all, > I've been watching the thread and am glad Big John now > likes the vg things. I use homemade ones. In > an Experimenter EAA mag from the early nineties John > Dresseldoff reported on his work with vg's and a 150 > Cessna. He modified the wing tips, the control surfaces, etc > and had slow flight down in the mid 20mph range. He had > hundreds of vg's on the wing alone.Very interesting > article. And no one cared. In the poh of a > 1952 170B Cessna I had it was stated no slips with full > flaps. Hand written in, so I went looking why. The 170 club > had found, after a fatal, that the flaps blanketed the tail > with disturbed air and caused the plane to become > uncontrollable near the ground. Lawn dart.My 1948 straight > wing 170 did not have this issue as it had very small flaps. > Loved to slip it did.. I'll see if I > can find that Experimenter . Good luck all. > > > > > The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Re: Help 503 side mount exhaust Muffler Mounting
Date: Apr 05, 2017
Hey, thanks a lot guys. These photos help. I do not have a photo of how my current exhaust (muffler) was mounted when I bought this plane and it is all apart right now. They way it was mounted was with two isolation mounts (male thread on each side of a rubber block 3/4" in diameter) screwed into two of the head bolt stand-off nuts and the other end attached to a dual band muffler clamp. This setup was very weak and rested against the shroud of the engine. Put bluntly, it was ugly, weak and concerned me thinking it was going to break off and go through the fan. Actually, I scraped a couple photos off a video I made of the walk-around of my Kolb Firestar 1 Video of walk-around here: https://youtu.be/j1gRQWckwdI?list=PL0k9OzgGAsmt12QQbYGeHYg7-pd7ifSMZ See the below 2 attachments Is there some place where I could purchase the aluminum angle pre-drilled for a 503? I will be at Sun-N-Fun this Saturday so I will look around there. Again, thanks for the help guys, Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468081#468081 Attachments: http://forums.matronics.com//files/mufflermount_2_117.png http://forums.matronics.com//files/mufflermount_1_207.png ________________________________________________________________________________
Date: Apr 05, 2017
BILL, MY CONGRATS TO YOU FOR BEING SO HONEST! - and confessing prior faults Fair winds, Russ > On Apr 5, 2017, at 3:14 PM, Bill Berle wrote: > > > Herb wrote: "just a weed eater that flies!! and you are just a medical from flying one yourselves!" > > Well I have a confession to make, and everyone here can give me a great big ration of s*** for it with my blessing. > > Once upon a time I was one of those guys that looked down their noses at "other" kinds of airplanes. I was lucky enough to be a sailplane racer in the 1980's, flying those beautiful gleaming white hand built German gliders with 50 foot wingspans. When I saw "lawn chair" ultralights with their loud 2 stroke engines, or powered parachutes, or even the Cessna 150's that I had learned how to fly in... I thought all that was just so low class. > > Thankfully, a combination of age, wisdom, education, seeing things from different perspectives... and having life punch me in the face a few times... changed all that. I can't afford one aileron for a racing sailplane these days. As I had posted some months ago, when I first saw a Kolb I thought it was comical looking, and why would anyone design something that looked like that. Years later when I learned more about airplanes and what makes them fly one way or another, I eventually understood what Homer Kolb was trying to accomplish. And eventually I went looking for a Kolb because of the unique combination of features and capabilities it has. > > So now I'm the guy at the airport who just as soon defends light and ultralight aircraft when my Cessna driver friends rib me about it. I love my old 172, and I would give anything to be back in the cockpit of a racing sailplane, but I try to appreciate every other type of aircraft just as much. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Wed, 4/5/17, Hoppy wrote: > > Subject: Re: Kolb-List: tail stall and vg's > To: kolb-list(at)matronics.com > Date: Wednesday, April 5, 2017, 11:27 AM > > > > Yep...Bill > > No wild geese no gosling's!! > > Guys like Homer and Dennis and > Wayne Ison did a fine job of advancing > our field of flying,..,. I tell > the GA buddies who like to rib > me...."just a weed eater that flies!! > and you are just a medical from > flying one yourselves!" Herb > > > On 04/05/2017 11:54 AM, Bill Berle > wrote: >> --> Kolb-List message posted > by: Bill Berle >> >> I remember that article !!! He had > some tubes that were mounted spanwise behind the flaps, and > a bunch of other wild stuff. >> >> The tubes served as a poor boy > double or triple slotted flap like DeHavilland had. Being > round tubes it didn't matter what the flap deflection was, > they would provide a cambered surface. >> >> The article went on to say he was > a "unique" guy, or that he was "more determined" than your > average airplane modifier or something. It looked like > something that NACA would do in the 1950's. I remember that > the article said he made very significant reductions in > minimum speed, at the cost of cruise speed of course. But I > remember thinking that this guy was worth respecting because > he pulled out all the stops and went for broke. >> >> I would love to see that article > again if you can find it. >> >> Bill Berle >> www.ezflaphandle.com - > safety & performance upgrade for light aircraft >> www.grantstar.net > - winning proposals for non-profit and > for-profit entities >> >> > -------------------------------------------- >> On Wed, 4/5/17, Del Vinal > wrote: >> >> Subject: Kolb-List: tail > stall and vg's >> To: kolb-list(at)matronics.com >> Date: Wednesday, April 5, > 2017, 8:22 AM >> >> Hi all, >> I've been watching the > thread and am glad Big John now >> likes the vg things. I use > homemade ones. In >> an Experimenter EAA mag > from the early nineties John >> Dresseldoff reported on his > work with vg's and a 150 >> Cessna. He modified the > wing tips, the control surfaces, etc >> and had slow flight down in > the mid 20mph range. He had >> hundreds of vg's on the > wing alone.Very interesting >> article. And no one > cared. In the poh of a >> 1952 170B Cessna I had it > was stated no slips with full >> flaps. Hand written in, so > I went looking why. The 170 club >> had found, after a fatal, > that the flaps blanketed the tail >> with disturbed air and > caused the plane to become >> uncontrollable near the > ground. Lawn dart.My 1948 straight >> wing 170 did not have this > issue as it had very small flaps. >> Loved to slip it > did.. I'll see if I >> can find that Experimenter > . Good luck all. >> > >> >> >> >> > > The Kolb-List Email Forum - > Navigator to browse > List Un/Subscription, > 7-Day Browse, Chat, FAQ, > - MATRONICS WEB FORUMS - > via the Web Forums! > - NEW MATRONICS LIST WIKI - > Email List Wiki! > - List Contribution Web Site - > support! > > -Matt Dralle, List Admin. > > > > > > > > ________________________________________________________________________________
Date: Apr 06, 2017
Subject: Re: Vgs
I don't have any knowledge of his breathing status / health or lack thereof. The vgs on the helmet and bottom of the wing was 100 % for laughs and to lighten up the mood on the list. Boyd Young >clip > Boyd - has Beauford died? I dint hear about it. > If so, why=99d he do that?? End vlip ________________________________________________________________________________
Subject: Re: Vgs
Date: Apr 06, 2017
I realize that; thought it was mildly hilarious! > On Apr 6, 2017, at 9:41 PM, B Young wrote: > > I don't have any knowledge of his breathing status / health or lack thereof. The vgs on the helmet and bottom of the wing was 100 % for laughs and to lighten up the mood on the list. > > Boyd Young > > >clip > > Boyd - has Beauford died? I dint hear about it. > > If so, why=99d he do that?? > End vlip ________________________________________________________________________________
Subject: Re: Vgs
Date: Apr 06, 2017
I am pretty sure that Beauford had a very serious stroke. He was a huge asset to this group. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468111#468111 Attachments: http://forums.matronics.com//files/beauford_2_1_500.jpg http://forums.matronics.com//files/beauford_2_137.jpg ________________________________________________________________________________
Subject: ADS-B Out
Date: Apr 06, 2017
Kolbers, I am wondering if anyone has installed an ADS-B Out, or In and Out, in there Kolb yet? Open Flight Solutions is the most affordable system I have heard of so far. I would appreciate your input. Hopefully John will check it out for us at Fun in the Sun. Thanks, Nick Cassara Palmer, Alaska 607AK ________________________________________________________________________________
Subject: Re: ADS-B Out
Date: Apr 07, 2017
I figure there are guys on the list who are way ahead of me on this application...? I have likely said this before but I am playing with adsb...receive only on a Nexus 7 with a NooElec nesdr t2. I have never taken it outdoors to get signals but seems to work software wise.. I use Avare navigation which is free along with Avare adsb app, also free. Nexus runs android software ...The nexus was 50 bucks at a pawn shop..The dongle (noo elec software defined radio) was 19 bucks.. I think they are available for less..? I find Amazon to be the priciest ..so I usually buy from Ebay...specify free shipping and US location.. Should receive adsb and weather... One possible problem is the drain on the tablet battery...I bought an usb , self powered, extender at an Amazon outlet for 5 bucks...flying, it will require conversion from 12 to 5 volts.. A three terminal regulator and a couple of capacitors work...but likely those devices are available from "big Red" for a few bucks.. Naturally this sort of device and its multiple usages are all over youtube. Some fellows are repackaging the whole kit and caboodle and asking big bucks for them... Hardware is cheap so it is all in the software... Glass cockpits use the same or similar hardware. But want 10k or better for their brew.. and they use much the same hardware... By now there should be total engine management as well as flight instrument replacement software and hardware for a Tablet ...The interface to egt,cht,oil pressure,etc can be made with a 7 dollar micro computer..called the Arduino...for it and the Raspberry Pi (35 bucks) have multiple analog inputs for sensors . The flight instruments (less airspeed) can be accomplished with a device the size of a postage stamp called a 9dof(degrees of freedom) 10 bucks.. it has an altimeter chip,magnetometer,gyro...The Arduino is the size of a credit card.. 7 bucks... Both computers have a serial port that interfaces to the 9DOF. Should be fairly easy to tie the computer to aileron, and elevator trim for some sort of wing leveling to relax the work load on cross countries.. A large three wire , model airplane, servo would work.. Still looking for a Firefly or Firestar re builder... Herb On 04/07/2017 02:03 AM, Nick Cassara wrote: > > Kolbers, > > I am wondering if anyone has installed an ADS-B Out, or In and Out, in there Kolb yet? Open Flight Solutions is the most affordable system I have heard of so far. > I would appreciate your input. Hopefully John will check it out for us at Fun in the Sun. > > Thanks, > > > Nick Cassara > > Palmer, Alaska > > 607AK > > ________________________________________________________________________________
Subject: ADS-B Out
Date: Apr 07, 2017
Nick C/Kolbers: Two problems with your request below. -I didn't make it to S&F. -At Gantt International Airport there is no ADSB requirement. Therefore I have not paid much attention to it. Have no idea what the equipment looks like or what the requirements are for installing and use. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Nick Cassara Sent: Friday, April 07, 2017 2:03 AM Subject: Kolb-List: ADS-B Out Kolbers, I am wondering if anyone has installed an ADS-B Out, or In and Out, in there Kolb yet? Open Flight Solutions is the most affordable system I have heard of so far. I would appreciate your input. Hopefully John will check it out for us at Fun in the Sun. Thanks, Nick Cassara Palmer, Alaska 607AK ________________________________________________________________________________
Date: Apr 07, 2017
Subject: Info. On MZ201/M202
I just thought that I'd start a thread concerning the MZ201 and MZ202 engines. If someone on the Kolb-list might have some experience with these engines mounted and flown on Kolbs. I'm considering an MZ201 for my Firestar MK1. George H. Firestar, #FS100 14GDH gdhelton(at)gmail.com Mesick, Michigan Have a great day! ________________________________________________________________________________
Subject: Re: Info. On MZ201/M202
Date: Apr 07, 2017
Where is Jack Hart when we need him.. ?? http://www.jackbhart.com/firefly/firefly.html Herb On 04/07/2017 08:39 AM, George Helton wrote: > > I just thought that I'd start a thread concerning the MZ201 and MZ202 engines. If someone on the Kolb-list might have some experience with these engines mounted and flown on Kolbs. I'm considering an MZ201 for my Firestar MK1. > George H. > Firestar, #FS100 > 14GDH > gdhelton(at)gmail.com > Mesick, Michigan > > ________________________________________________________________________________
Date: Apr 07, 2017
TmV4dXMgNyB3b24ndCBhbGxvdyB5b3UgdG8gY2hhcmdlIGl0IGFuZCBzZWUgdGhlIGRvbmdsZSBh dCB0aGUgc2FtZSB0aW1lLCB1bmxlc3MgeW91ICdyb290JyBpdC4KCkxvdHMgb2YgaW5mbyBvdXQg dGhlcmU7IEknbGwgdHJ5IHRvIHNlbmQgc29tZSBsaW5rcyB3aGVuIEkgZ2V0IGhvbWUuwqAKCkNo YXJsaWUKKExvYWRpbmcgYSBUd2luc3RhciBwcm9qZWN0IG9uIHRoZSB0cmFpbGVyIHRvZGF5ISAp Cgo8ZGl2Pi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS08L2Rpdj48ZGl2PkZyb206 IEhvcHB5IDxoZXJiZ2hAbmN0Yy5jb20+IDwvZGl2PjxkaXY+RGF0ZTowNC8wNy8yMDE3ICA4OjU4 IEFNICAoR01ULTA1OjAwKSA8L2Rpdj48ZGl2PlRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbSA8 L2Rpdj48ZGl2PlN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IEFEUy1CIE91dCA8L2Rpdj48ZGl2Pgo8 L2Rpdj4tLT4gS29sYi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBIb3BweSA8aGVyYmdoQG5jdGMu Y29tPgoKSSBmaWd1cmUgdGhlcmUgYXJlIGd1eXMgb24gdGhlIGxpc3Qgd2hvIGFyZSB3YXkgYWhl YWQgb2YgbWUgb24gdGhpcyAKYXBwbGljYXRpb24uLi4/CgpJIGhhdmUgbGlrZWx5IHNhaWQgdGhp cyBiZWZvcmUgYnV0IEkgYW0gcGxheWluZyB3aXRoIGFkc2IuLi5yZWNlaXZlIG9ubHkgCm9uIGEg TmV4dXMgNyB3aXRoIGEgTm9vRWxlYyBuZXNkciB0Mi4gICBJIGhhdmUgbmV2ZXIgdGFrZW4gaXQg b3V0ZG9vcnMgCnRvIGdldCBzaWduYWxzIGJ1dCBzZWVtcyB0byB3b3JrIHNvZnR3YXJlIHdpc2Uu LiBJIHVzZSBBdmFyZSBuYXZpZ2F0aW9uIAp3aGljaCBpcyBmcmVlIGFsb25nIHdpdGggQXZhcmUg YWRzYiBhcHAsIGFsc28gZnJlZS4KCiAgIE5leHVzIHJ1bnMgYW5kcm9pZCBzb2Z0d2FyZSAuLi5U aGUgbmV4dXMgd2FzIDUwIGJ1Y2tzIGF0IGEgcGF3biAKc2hvcC4uVGhlIGRvbmdsZSAobm9vIGVs ZWMgc29mdHdhcmUgZGVmaW5lZCByYWRpbykgd2FzIDE5IGJ1Y2tzLi4gSSAKdGhpbmsgdGhleSBh cmUgYXZhaWxhYmxlIGZvciBsZXNzLi4/ICBJIGZpbmQgQW1hem9uIHRvIGJlIHRoZSBwcmljaWVz dCAKLi5zbyBJIHVzdWFsbHkgYnV5IGZyb20gRWJheS4uLnNwZWNpZnkgZnJlZSBzaGlwcGluZyBh bmQgVVMgbG9jYXRpb24uLgoKICAgU2hvdWxkIHJlY2VpdmUgYWRzYiBhbmQgd2VhdGhlci4uLiBP bmUgcG9zc2libGUgcHJvYmxlbSBpcyB0aGUgZHJhaW4gCm9uIHRoZSB0YWJsZXQgYmF0dGVyeS4u LkkgYm91Z2h0IGFuIHVzYiAsIHNlbGYgcG93ZXJlZCwgZXh0ZW5kZXIgYXQgYW4gCkFtYXpvbiBv dXRsZXQgZm9yIDUgYnVja3MuLi5mbHlpbmcsIGl0IHdpbGwgcmVxdWlyZSBjb252ZXJzaW9uIGZy b20gMTIgCnRvIDUgdm9sdHMuLiBBIHRocmVlIHRlcm1pbmFsIHJlZ3VsYXRvciBhbmQgYSBjb3Vw bGUgb2YgY2FwYWNpdG9ycyAKd29yay4uLmJ1dCBsaWtlbHkgdGhvc2UgZGV2aWNlcyBhcmUgYXZh aWxhYmxlIGZyb20gImJpZyBSZWQiIGZvciBhIGZldyAKYnVja3MuLgoKICAgICBOYXR1cmFsbHkg dGhpcyBzb3J0IG9mIGRldmljZSBhbmQgaXRzIG11bHRpcGxlIHVzYWdlcyBhcmUgYWxsIG92ZXIg CnlvdXR1YmUuICBTb21lIGZlbGxvd3MgYXJlIHJlcGFja2FnaW5nIHRoZSB3aG9sZSBraXQgYW5k IGNhYm9vZGxlIGFuZCAKYXNraW5nIGJpZyBidWNrcyBmb3IgdGhlbS4uLiBIYXJkd2FyZSBpcyBj aGVhcCBzbyBpdCBpcyBhbGwgaW4gdGhlIApzb2Z0d2FyZS4uLiBHbGFzcyBjb2NrcGl0cyB1c2Ug dGhlIHNhbWUgb3Igc2ltaWxhciBoYXJkd2FyZS4gQnV0IHdhbnQgCjEwayBvciBiZXR0ZXIgZm9y IHRoZWlyIGJyZXcuLiBhbmQgdGhleSAgdXNlIG11Y2ggdGhlIHNhbWUgaGFyZHdhcmUuLi4KCiAg IEJ5IG5vdyB0aGVyZSBzaG91bGQgYmUgdG90YWwgZW5naW5lIG1hbmFnZW1lbnQgYXMgd2VsbCBh cyBmbGlnaHQgCmluc3RydW1lbnQgcmVwbGFjZW1lbnQgc29mdHdhcmUgYW5kIGhhcmR3YXJlIGZv ciBhIFRhYmxldCAuLi5UaGUgCmludGVyZmFjZSB0byBlZ3QsY2h0LG9pbCBwcmVzc3VyZSxldGMg Y2FuIGJlIG1hZGUgd2l0aCBhIDcgZG9sbGFyIG1pY3JvIApjb21wdXRlci4uY2FsbGVkIHRoZSBB cmR1aW5vLi4uZm9yIGl0IGFuZCB0aGUgUmFzcGJlcnJ5IFBpICgzNSBidWNrcykgCmhhdmUgbXVs dGlwbGUgYW5hbG9nIGlucHV0cyBmb3Igc2Vuc29ycyAuIFRoZSBmbGlnaHQgaW5zdHJ1bWVudHMg KGxlc3MgCmFpcnNwZWVkKSBjYW4gYmUgYWNjb21wbGlzaGVkIHdpdGggYSBkZXZpY2UgdGhlIHNp emUgb2YgYSBwb3N0YWdlIHN0YW1wIApjYWxsZWQgYSA5ZG9mKGRlZ3JlZXMgb2YgZnJlZWRvbSkg MTAgYnVja3MuLiBpdCBoYXMgYW4gYWx0aW1ldGVyIApjaGlwLG1hZ25ldG9tZXRlcixneXJvLi4u VGhlIEFyZHVpbm8gaXMgdGhlIHNpemUgb2YgYSBjcmVkaXQgY2FyZC4uIDcgCmJ1Y2tzLi4uIEJv dGggY29tcHV0ZXJzIGhhdmUgYSBzZXJpYWwgcG9ydCB0aGF0IGludGVyZmFjZXMgdG8gdGhlIDlE T0YuICAKU2hvdWxkIGJlIGZhaXJseSBlYXN5IHRvIHRpZSB0aGUgY29tcHV0ZXIgdG8gYWlsZXJv biwgYW5kIGVsZXZhdG9yIHRyaW0gCmZvciBzb21lIHNvcnQgb2Ygd2luZyBsZXZlbGluZyB0byBy ZWxheCB0aGUgd29yayBsb2FkIG9uIGNyb3NzIApjb3VudHJpZXMuLiBBIGxhcmdlIHRocmVlIHdp cmUgLCBtb2RlbCBhaXJwbGFuZSwgc2Vydm8gd291bGQgd29yay4uCgogICBTdGlsbCBsb29raW5n IGZvciBhIEZpcmVmbHkgb3IgRmlyZXN0YXIgcmUgYnVpbGRlci4uLiBIZXJiCgoKT24gMDQvMDcv MjAxNyAwMjowMyBBTSwgTmljayBDYXNzYXJhIHdyb3RlOgo+IC0tPiBLb2xiLUxpc3QgbWVzc2Fn ZSBwb3N0ZWQgYnk6IE5pY2sgQ2Fzc2FyYSA8bmlja2NAbXRhb25saW5lLm5ldD4KPgo+IEtvbGJl cnMsCj4KPiBJIGFtIHdvbmRlcmluZyBpZiBhbnlvbmUgaGFzIGluc3RhbGxlZCBhbiBBRFMtQiBP dXQsIG9yIEluIGFuZCBPdXQsIGluIHRoZXJlIEtvbGIgeWV0PyBPcGVuIEZsaWdodCBTb2x1dGlv bnMgaXMgdGhlIG1vc3QgYWZmb3JkYWJsZSBzeXN0ZW0gSSBoYXZlIGhlYXJkIG9mIHNvIGZhci4K PiBJIHdvdWxkIGFwcHJlY2lhdGUgeW91ciBpbnB1dC4gSG9wZWZ1bGx5IEpvaG4gd2lsbCBjaGVj ayBpdCBvdXQgZm9yIHVzIGF0IOKAnEZ1biBpbiB0aGUgU3VuLuKAnQo+Cj4gVGhhbmtzLAo+Cj4K PiBOaWNrIENhc3NhcmEKPgo+IFBhbG1lciwgQWxhc2thCj4KPiA2MDdBSwo+Cj4KPgo+CgpfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQpfLT0gICAgICAgICAgLSBUaGUgS29sYi1MaXN0IEVtYWlsIEZvcnVtIC0KXy09IFVzZSB0aGUg TWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQpfLT0gdGhlIG1hbnkg TGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwKXy09IEFyY2hpdmUg U2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLApfLT0gUGhvdG9zaGFy ZSwgYW5kIG11Y2ggbXVjaCBtb3JlOgpfLT0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNz LmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0Cl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgICAtIE1B VFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJs ZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25p Y3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgIC0gTkVXIE1BVFJPTklDUyBMSVNUIFdJ S0kgLQpfLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNzIEVtYWlsIExpc3QgV2lraSEK Xy09ICAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb20KXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAg IC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBn ZW5lcm91cyBzdXBwb3J0IQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBE cmFsbGUsIExpc3QgQWRtaW4uCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29u dHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09CgoKCg= ________________________________________________________________________________
Date: Apr 07, 2017
With the powered usb hub...should not be a large problem...Herb On 04/07/2017 09:11 AM, Charlie England wrote: > Nexus 7 won't allow you to charge it and see the dongle at the same > time, unless you 'root' it. > > Lots of info out there; I'll try to send some links when I get home. > > Charlie > (Loading a Twinstar project on the trailer today! ) > > > -------- Original message -------- > From: Hoppy > Date:04/07/2017 8:58 AM (GMT-05:00) > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: ADS-B Out > > > I figure there are guys on the list who are way ahead of me on this > application...? > > I have likely said this before but I am playing with adsb...receive only > on a Nexus 7 with a NooElec nesdr t2. I have never taken it outdoors > to get signals but seems to work software wise.. I use Avare navigation > which is free along with Avare adsb app, also free. > > Nexus runs android software ...The nexus was 50 bucks at a pawn > shop..The dongle (noo elec software defined radio) was 19 bucks.. I > think they are available for less..? I find Amazon to be the priciest > ..so I usually buy from Ebay...specify free shipping and US location.. > > Should receive adsb and weather... One possible problem is the drain > on the tablet battery...I bought an usb , self powered, extender at an > Amazon outlet for 5 bucks...flying, it will require conversion from 12 > to 5 volts.. A three terminal regulator and a couple of capacitors > work...but likely those devices are available from "big Red" for a few > bucks.. > > Naturally this sort of device and its multiple usages are all over > youtube. Some fellows are repackaging the whole kit and caboodle and > asking big bucks for them... Hardware is cheap so it is all in the > software... Glass cockpits use the same or similar hardware. But want > 10k or better for their brew.. and they use much the same hardware... > > By now there should be total engine management as well as flight > instrument replacement software and hardware for a Tablet ...The > interface to egt,cht,oil pressure,etc can be made with a 7 dollar micro > computer..called the Arduino...for it and the Raspberry Pi (35 bucks) > have multiple analog inputs for sensors . The flight instruments (less > airspeed) can be accomplished with a device the size of a postage stamp > called a 9dof(degrees of freedom) 10 bucks.. it has an altimeter > chip,magnetometer,gyro...The Arduino is the size of a credit card.. 7 > bucks... Both computers have a serial port that interfaces to the 9DOF. > Should be fairly easy to tie the computer to aileron, and elevator trim > for some sort of wing leveling to relax the work load on cross > countries.. A large three wire , model airplane, servo would work.. > > Still looking for a Firefly or Firestar re builder... Herb > > > On 04/07/2017 02:03 AM, Nick Cassara wrote: > > > > Kolbers, > > > > I am wondering if anyone has installed an ADS-B Out, or In and Out, > in there Kolb yet? Open Flight Solutions is the most affordable system > I have heard of so far. > > I would appreciate your input. Hopefully John will check it out for > us at Fun in the Sun. > > > > Thanks, > > > > > > Nick Cassara > > > > Palmer, Alaska > > > > 607AK > > > > > > > > > > ________________________________________________________________________________
Date: Apr 07, 2017
WW91IGNhbiBwb3dlciB0aGUgcmFkaW8gd2l0aCBpdCwgYnV0IHRoZSA3IHdvbid0IGNoYXJnZSB3 aGlsZSBpbiB1c2Igb3RnIG1vZGUuCgo8ZGl2Pi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0t LS0tLS08L2Rpdj48ZGl2PkZyb206IEhvcHB5IDxoZXJiZ2hAbmN0Yy5jb20+IDwvZGl2PjxkaXY+ RGF0ZTowNC8wNy8yMDE3ICAxMDo1MiBBTSAgKEdNVC0wNTowMCkgPC9kaXY+PGRpdj5Ubzoga29s Yi1saXN0QG1hdHJvbmljcy5jb20gPC9kaXY+PGRpdj5TdWJqZWN0OiBSZTogS29sYi1MaXN0OiBB RFMtQiBPdXQgPC9kaXY+PGRpdj4KPC9kaXY+V2l0aCB0aGUgcG93ZXJlZCB1c2IgaHViLi4uc2hv dWxkIG5vdCBiZSBhIGxhcmdlICBwcm9ibGVtLi4uSGVyYiAKCk9uIDA0LzA3LzIwMTcgMDk6MTEg QU0sIENoYXJsaWUgRW5nbGFuZCB3cm90ZToKTmV4dXMgNyB3b24ndCBhbGxvdyB5b3UgdG8gY2hh cmdlIGl0IGFuZCBzZWUgdGhlIGRvbmdsZSBhdCB0aGUgc2FtZSB0aW1lLCB1bmxlc3MgeW91ICdy b290JyBpdC4KCkxvdHMgb2YgaW5mbyBvdXQgdGhlcmU7IEknbGwgdHJ5IHRvIHNlbmQgc29tZSBs aW5rcyB3aGVuIEkgZ2V0IGhvbWUuIAoKQ2hhcmxpZQooTG9hZGluZyBhIFR3aW5zdGFyIHByb2pl Y3Qgb24gdGhlIHRyYWlsZXIgdG9kYXkhICkKCgotLS0tLS0tLSBPcmlnaW5hbCBtZXNzYWdlIC0t LS0tLS0tCkZyb206IEhvcHB5CkRhdGU6MDQvMDcvMjAxNyA4OjU4IEFNIChHTVQtMDU6MDApClRv OiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQpTdWJqZWN0OiBSZTogS29sYi1MaXN0OiBBRFMtQiBP dXQKCi0tPiBLb2xiLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IEhvcHB5IDxoZXJiZ2hAbmN0Yy5j b20+CgpJIGZpZ3VyZSB0aGVyZSBhcmUgZ3V5cyBvbiB0aGUgbGlzdCB3aG8gYXJlIHdheSBhaGVh ZCBvZiBtZSBvbiB0aGlzIAphcHBsaWNhdGlvbi4uLj8KCkkgaGF2ZSBsaWtlbHkgc2FpZCB0aGlz IGJlZm9yZSBidXQgSSBhbSBwbGF5aW5nIHdpdGggYWRzYi4uLnJlY2VpdmUgb25seSAKb24gYSBO ZXh1cyA3IHdpdGggYSBOb29FbGVjIG5lc2RyIHQyLiAgIEkgaGF2ZSBuZXZlciB0YWtlbiBpdCBv dXRkb29ycyAKdG8gZ2V0IHNpZ25hbHMgYnV0IHNlZW1zIHRvIHdvcmsgc29mdHdhcmUgd2lzZS4u IEkgdXNlIEF2YXJlIG5hdmlnYXRpb24gCndoaWNoIGlzIGZyZWUgYWxvbmcgd2l0aCBBdmFyZSBh ZHNiIGFwcCwgYWxzbyBmcmVlLgoKICAgTmV4dXMgcnVucyBhbmRyb2lkIHNvZnR3YXJlIC4uLlRo ZSBuZXh1cyB3YXMgNTAgYnVja3MgYXQgYSBwYXduIApzaG9wLi5UaGUgZG9uZ2xlIChub28gZWxl YyBzb2Z0d2FyZSBkZWZpbmVkIHJhZGlvKSB3YXMgMTkgYnVja3MuLiBJIAp0aGluayB0aGV5IGFy ZSBhdmFpbGFibGUgZm9yIGxlc3MuLj8gIEkgZmluZCBBbWF6b24gdG8gYmUgdGhlIHByaWNpZXN0 IAouLnNvIEkgdXN1YWxseSBidXkgZnJvbSBFYmF5Li4uc3BlY2lmeSBmcmVlIHNoaXBwaW5nIGFu ZCBVUyBsb2NhdGlvbi4uCgogICBTaG91bGQgcmVjZWl2ZSBhZHNiIGFuZCB3ZWF0aGVyLi4uIE9u ZSBwb3NzaWJsZSBwcm9ibGVtIGlzIHRoZSAgICAgICBkcmFpbiAKb24gdGhlIHRhYmxldCBiYXR0 ZXJ5Li4uSSBib3VnaHQgYW4gdXNiICwgc2VsZiBwb3dlcmVkLCBleHRlbmRlciBhdCBhbiAKQW1h em9uIG91dGxldCBmb3IgNSBidWNrcy4uLmZseWluZywgaXQgd2lsbCByZXF1aXJlIGNvbnZlcnNp b24gZnJvbSAxMiAKdG8gNSB2b2x0cy4uIEEgdGhyZWUgdGVybWluYWwgcmVndWxhdG9yIGFuZCBh IGNvdXBsZSBvZiBjYXBhY2l0b3JzIAp3b3JrLi4uYnV0IGxpa2VseSB0aG9zZSBkZXZpY2VzIGFy ZSBhdmFpbGFibGUgZnJvbSAiYmlnIFJlZCIgZm9yIGEgZmV3IApidWNrcy4uCgogICAgIE5hdHVy YWxseSB0aGlzIHNvcnQgb2YgZGV2aWNlIGFuZCBpdHMgbXVsdGlwbGUgdXNhZ2VzIGFyZSBhbGwg b3ZlciAKeW91dHViZS4gIFNvbWUgZmVsbG93cyBhcmUgcmVwYWNrYWdpbmcgdGhlIHdob2xlIGtp dCBhbmQgY2Fib29kbGUgICAgICAgYW5kIAphc2tpbmcgYmlnIGJ1Y2tzIGZvciB0aGVtLi4uIEhh cmR3YXJlIGlzIGNoZWFwIHNvIGl0IGlzIGFsbCBpbiB0aGUgCnNvZnR3YXJlLi4uIEdsYXNzIGNv Y2twaXRzIHVzZSB0aGUgc2FtZSBvciBzaW1pbGFyIGhhcmR3YXJlLiBCdXQgd2FudCAKMTBrIG9y IGJldHRlciBmb3IgdGhlaXIgYnJldy4uIGFuZCB0aGV5ICB1c2UgbXVjaCB0aGUgc2FtZSBoYXJk d2FyZS4uLgoKICAgQnkgbm93IHRoZXJlIHNob3VsZCBiZSB0b3RhbCBlbmdpbmUgbWFuYWdlbWVu dCBhcyB3ZWxsIGFzIGZsaWdodCAKaW5zdHJ1bWVudCByZXBsYWNlbWVudCBzb2Z0d2FyZSBhbmQg aGFyZHdhcmUgZm9yIGEgVGFibGV0IC4uLlRoZSAKaW50ZXJmYWNlIHRvIGVndCxjaHQsb2lsIHBy ZXNzdXJlLGV0YyBjYW4gYmUgbWFkZSB3aXRoIGEgNyBkb2xsYXIgbWljcm8gCmNvbXB1dGVyLi5j YWxsZWQgdGhlIEFyZHVpbm8uLi5mb3IgaXQgYW5kIHRoZSBSYXNwYmVycnkgUGkgKDM1IGJ1Y2tz KSAKaGF2ZSBtdWx0aXBsZSBhbmFsb2cgaW5wdXRzIGZvciBzZW5zb3JzIC4gVGhlIGZsaWdodCBp bnN0cnVtZW50cyAobGVzcyAKYWlyc3BlZWQpIGNhbiBiZSBhY2NvbXBsaXNoZWQgd2l0aCBhIGRl dmljZSB0aGUgc2l6ZSBvZiBhIHBvc3RhZ2Ugc3RhbXAgCmNhbGxlZCBhIDlkb2YoZGVncmVlcyBv ZiBmcmVlZG9tKSAxMCBidWNrcy4uIGl0IGhhcyBhbiBhbHRpbWV0ZXIgCmNoaXAsbWFnbmV0b21l dGVyLGd5cm8uLi5UaGUgQXJkdWlubyBpcyB0aGUgc2l6ZSBvZiBhIGNyZWRpdCBjYXJkLi4gNyAK YnVja3MuLi4gQm90aCBjb21wdXRlcnMgaGF2ZSBhIHNlcmlhbCBwb3J0IHRoYXQgaW50ZXJmYWNl cyB0byB0aGUgOURPRi4gIApTaG91bGQgYmUgZmFpcmx5IGVhc3kgdG8gdGllIHRoZSBjb21wdXRl ciB0byBhaWxlcm9uLCBhbmQgZWxldmF0b3IgdHJpbSAKZm9yIHNvbWUgc29ydCBvZiB3aW5nIGxl dmVsaW5nIHRvIHJlbGF4IHRoZSB3b3JrIGxvYWQgb24gY3Jvc3MgCmNvdW50cmllcy4uIEEgbGFy Z2UgdGhyZWUgd2lyZSAsIG1vZGVsIGFpcnBsYW5lLCBzZXJ2byB3b3VsZCB3b3JrLi4KCiAgIFN0 aWxsIGxvb2tpbmcgZm9yIGEgRmlyZWZseSBvciBGaXJlc3RhciByZSBidWlsZGVyLi4uIEhlcmIK CgpPbiAwNC8wNy8yMDE3IDAyOjAzIEFNLCBOaWNrIENhc3NhcmEgd3JvdGU6Cj4gLS0+IEtvbGIt TGlzdCBtZXNzYWdlIHBvc3RlZCBieTogTmljayBDYXNzYXJhIDxuaWNrY0BtdGFvbmxpbmUubmV0 Pgo+Cj4gS29sYmVycywKPgo+IEkgYW0gd29uZGVyaW5nIGlmIGFueW9uZSBoYXMgaW5zdGFsbGVk IGFuIEFEUy1CIE91dCwgb3IgSW4gYW5kIE91dCwgaW4gdGhlcmUgS29sYiB5ZXQ/IE9wZW4gRmxp Z2h0IFNvbHV0aW9ucyBpcyB0aGUgbW9zdCBhZmZvcmRhYmxlIHN5c3RlbSBJIGhhdmUgaGVhcmQg b2Ygc28gZmFyLgo+IEkgd291bGQgYXBwcmVjaWF0ZSB5b3VyIGlucHV0LiBIb3BlZnVsbHkgSm9o biB3aWxsIGNoZWNrIGl0IG91dCBmb3IgdXMgYXQg4oCcRnVuIGluIHRoZSBTdW4u4oCdCj4KPiBU aGFua3MsCj4KPgo+IE5pY2sgQ2Fzc2FyYQo+Cj4gUGFsbWVyLCBBbGFza2EKPgo+IDYwN0FLCj4K Pgo+Cj4KCgoKCgo ________________________________________________________________________________
Date: Apr 07, 2017
If the Nexus is fully charged...it would be important to use a powered hub ...The discharge on the Nexus would be fairly normal then... Herb On 04/07/2017 11:43 AM, Charlie England wrote: > You can power the radio with it, but the 7 won't charge while in usb > otg mode. > > -------- Original message -------- > From: Hoppy > Date:04/07/2017 10:52 AM (GMT-05:00) > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: ADS-B Out > > With the powered usb hub...should not be a large problem...Herb > > > On 04/07/2017 09:11 AM, Charlie England wrote: >> Nexus 7 won't allow you to charge it and see the dongle at the same >> time, unless you 'root' it. >> >> Lots of info out there; I'll try to send some links when I get home. >> >> Charlie >> (Loading a Twinstar project on the trailer today! ) >> >> >> -------- Original message -------- >> From: Hoppy >> Date:04/07/2017 8:58 AM (GMT-05:00) >> To: kolb-list(at)matronics.com >> Subject: Re: Kolb-List: ADS-B Out >> >> >> I figure there are guys on the list who are way ahead of me on this >> application...? >> >> I have likely said this before but I am playing with adsb...receive only >> on a Nexus 7 with a NooElec nesdr t2. I have never taken it outdoors >> to get signals but seems to work software wise.. I use Avare navigation >> which is free along with Avare adsb app, also free. >> >> Nexus runs android software ...The nexus was 50 bucks at a pawn >> shop..The dongle (noo elec software defined radio) was 19 bucks.. I >> think they are available for less..? I find Amazon to be the priciest >> ..so I usually buy from Ebay...specify free shipping and US location.. >> >> Should receive adsb and weather... One possible problem is the drain >> on the tablet battery...I bought an usb , self powered, extender at an >> Amazon outlet for 5 bucks...flying, it will require conversion from 12 >> to 5 volts.. A three terminal regulator and a couple of capacitors >> work...but likely those devices are available from "big Red" for a few >> bucks.. >> >> Naturally this sort of device and its multiple usages are all over >> youtube. Some fellows are repackaging the whole kit and caboodle and >> asking big bucks for them... Hardware is cheap so it is all in the >> software... Glass cockpits use the same or similar hardware. But want >> 10k or better for their brew.. and they use much the same hardware... >> >> By now there should be total engine management as well as flight >> instrument replacement software and hardware for a Tablet ...The >> interface to egt,cht,oil pressure,etc can be made with a 7 dollar micro >> computer..called the Arduino...for it and the Raspberry Pi (35 bucks) >> have multiple analog inputs for sensors . The flight instruments (less >> airspeed) can be accomplished with a device the size of a postage stamp >> called a 9dof(degrees of freedom) 10 bucks.. it has an altimeter >> chip,magnetometer,gyro...The Arduino is the size of a credit card.. 7 >> bucks... Both computers have a serial port that interfaces to the 9DOF. >> Should be fairly easy to tie the computer to aileron, and elevator trim >> for some sort of wing leveling to relax the work load on cross >> countries.. A large three wire , model airplane, servo would work.. >> >> Still looking for a Firefly or Firestar re builder... Herb >> >> >> On 04/07/2017 02:03 AM, Nick Cassara wrote: >> > >> > Kolbers, >> > >> > I am wondering if anyone has installed an ADS-B Out, or In and Out, >> in there Kolb yet? Open Flight Solutions is the most affordable >> system I have heard of so far. >> > I would appreciate your input. Hopefully John will check it out for >> us at Fun in the Sun. >> > >> > Thanks, >> > >> > >> > Nick Cassara >> > >> > Palmer, Alaska >> > >> > 607AK >> > >> > >> > >> > >> >> >> >> > ________________________________________________________________________________
Date: Apr 07, 2017
VGhhdCdzIHdoYXQgSSd2ZSBiZWVuIGRvaW5nLsKgCgo8ZGl2Pi0tLS0tLS0tIE9yaWdpbmFsIG1l c3NhZ2UgLS0tLS0tLS08L2Rpdj48ZGl2PkZyb206IEhvcHB5IDxoZXJiZ2hAbmN0Yy5jb20+IDwv ZGl2PjxkaXY+RGF0ZTowNC8wNy8yMDE3ICAxOjAxIFBNICAoR01ULTA1OjAwKSA8L2Rpdj48ZGl2 PlRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbSA8L2Rpdj48ZGl2PlN1YmplY3Q6IFJlOiBLb2xi LUxpc3Q6IEFEUy1CIE91dCA8L2Rpdj48ZGl2Pgo8L2Rpdj4gSWYgdGhlIE5leHVzIGlzIGZ1bGx5 IGNoYXJnZWQuLi5pdCB3b3VsZCBiZSBpbXBvcnRhbnQgdG8gdXNlIGEgcG93ZXJlZCBodWIgLi4u VGhlIGRpc2NoYXJnZSBvbiB0aGUgTmV4dXMgd291bGQgYmUgZmFpcmx5IG5vcm1hbCB0aGVuLi4u IEhlcmIgCgpPbiAwNC8wNy8yMDE3IDExOjQzIEFNLCBDaGFybGllIEVuZ2xhbmQgd3JvdGU6Cllv dSBjYW4gcG93ZXIgdGhlIHJhZGlvIHdpdGggaXQsIGJ1dCB0aGUgNyB3b24ndCBjaGFyZ2Ugd2hp bGUgaW4gdXNiIG90ZyBtb2RlLgoKLS0tLS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLQpG cm9tOiBIb3BweQpEYXRlOjA0LzA3LzIwMTcgMTA6NTIgQU0gKEdNVC0wNTowMCkKVG86IGtvbGIt bGlzdEBtYXRyb25pY3MuY29tClN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IEFEUy1CIE91dAoKV2l0 aCB0aGUgcG93ZXJlZCB1c2IgaHViLi4uc2hvdWxkIG5vdCBiZSBhIGxhcmdlICBwcm9ibGVtLi4u SGVyYiAKCk9uIDA0LzA3LzIwMTcgMDk6MTEgQU0sIENoYXJsaWUgRW5nbGFuZCB3cm90ZToKTmV4 dXMgNyB3b24ndCBhbGxvdyB5b3UgdG8gY2hhcmdlIGl0IGFuZCBzZWUgdGhlIGRvbmdsZSBhdCB0 aGUgc2FtZSB0aW1lLCB1bmxlc3MgeW91ICdyb290JyBpdC4gICAgICAgICAKCkxvdHMgb2YgaW5m byBvdXQgdGhlcmU7IEknbGwgdHJ5IHRvIHNlbmQgc29tZSBsaW5rcyB3aGVuIEkgICAgICAgICAg IGdldCBob21lLiAKCkNoYXJsaWUKKExvYWRpbmcgYSBUd2luc3RhciBwcm9qZWN0IG9uIHRoZSB0 cmFpbGVyIHRvZGF5ISApCgoKLS0tLS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLQpGcm9t OiBIb3BweQpEYXRlOjA0LzA3LzIwMTcgODo1OCBBTSAoR01ULTA1OjAwKQpUbzoga29sYi1saXN0 QG1hdHJvbmljcy5jb20KU3ViamVjdDogUmU6IEtvbGItTGlzdDogQURTLUIgT3V0CgotLT4gS29s Yi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBIb3BweSA8aGVyYmdoQG5jdGMuY29tPgoKSSBmaWd1 cmUgdGhlcmUgYXJlIGd1eXMgb24gdGhlIGxpc3Qgd2hvIGFyZSB3YXkgYWhlYWQgb2YgbWUgb24g dGhpcyAKYXBwbGljYXRpb24uLi4/CgpJIGhhdmUgbGlrZWx5IHNhaWQgdGhpcyBiZWZvcmUgYnV0 IEkgYW0gcGxheWluZyB3aXRoIGFkc2IuLi5yZWNlaXZlIG9ubHkgCm9uIGEgTmV4dXMgNyB3aXRo IGEgTm9vRWxlYyBuZXNkciB0Mi4gICBJIGhhdmUgbmV2ZXIgdGFrZW4gaXQgICAgICAgICBvdXRk b29ycyAKdG8gZ2V0IHNpZ25hbHMgYnV0IHNlZW1zIHRvIHdvcmsgc29mdHdhcmUgd2lzZS4uIEkg dXNlIEF2YXJlIG5hdmlnYXRpb24gCndoaWNoIGlzIGZyZWUgYWxvbmcgd2l0aCBBdmFyZSBhZHNi IGFwcCwgYWxzbyBmcmVlLgoKICAgTmV4dXMgcnVucyBhbmRyb2lkIHNvZnR3YXJlIC4uLlRoZSBu ZXh1cyB3YXMgNTAgYnVja3MgYXQgYSBwYXduIApzaG9wLi5UaGUgZG9uZ2xlIChub28gZWxlYyBz b2Z0d2FyZSBkZWZpbmVkIHJhZGlvKSB3YXMgMTkgICAgICAgICBidWNrcy4uIEkgCnRoaW5rIHRo ZXkgYXJlIGF2YWlsYWJsZSBmb3IgbGVzcy4uPyAgSSBmaW5kIEFtYXpvbiB0byBiZSB0aGUgcHJp Y2llc3QgCi4uc28gSSB1c3VhbGx5IGJ1eSBmcm9tIEViYXkuLi5zcGVjaWZ5IGZyZWUgc2hpcHBp bmcgYW5kIFVTIGxvY2F0aW9uLi4KCiAgIFNob3VsZCByZWNlaXZlIGFkc2IgYW5kIHdlYXRoZXIu Li4gT25lIHBvc3NpYmxlIHByb2JsZW0gaXMgdGhlIGRyYWluIApvbiB0aGUgdGFibGV0IGJhdHRl cnkuLi5JIGJvdWdodCBhbiB1c2IgLCBzZWxmIHBvd2VyZWQsIGV4dGVuZGVyIGF0IGFuIApBbWF6 b24gb3V0bGV0IGZvciA1IGJ1Y2tzLi4uZmx5aW5nLCBpdCB3aWxsIHJlcXVpcmUgY29udmVyc2lv biBmcm9tIDEyIAp0byA1IHZvbHRzLi4gQSB0aHJlZSB0ZXJtaW5hbCByZWd1bGF0b3IgYW5kIGEg Y291cGxlIG9mIGNhcGFjaXRvcnMgCndvcmsuLi5idXQgbGlrZWx5IHRob3NlIGRldmljZXMgYXJl IGF2YWlsYWJsZSBmcm9tICJiaWcgUmVkIiBmb3IgYSBmZXcgCmJ1Y2tzLi4KCiAgICAgTmF0dXJh bGx5IHRoaXMgc29ydCBvZiBkZXZpY2UgYW5kIGl0cyBtdWx0aXBsZSB1c2FnZXMgYXJlIGFsbCBv dmVyIAp5b3V0dWJlLiAgU29tZSBmZWxsb3dzIGFyZSByZXBhY2thZ2luZyB0aGUgd2hvbGUga2l0 IGFuZCAgICAgICAgIGNhYm9vZGxlIGFuZCAKYXNraW5nIGJpZyBidWNrcyBmb3IgdGhlbS4uLiBI YXJkd2FyZSBpcyBjaGVhcCBzbyBpdCBpcyBhbGwgaW4gdGhlIApzb2Z0d2FyZS4uLiBHbGFzcyBj b2NrcGl0cyB1c2UgdGhlIHNhbWUgb3Igc2ltaWxhciBoYXJkd2FyZS4gQnV0IHdhbnQgCjEwayBv ciBiZXR0ZXIgZm9yIHRoZWlyIGJyZXcuLiBhbmQgdGhleSAgdXNlIG11Y2ggdGhlIHNhbWUgaGFy ZHdhcmUuLi4KCiAgIEJ5IG5vdyB0aGVyZSBzaG91bGQgYmUgdG90YWwgZW5naW5lIG1hbmFnZW1l bnQgYXMgd2VsbCBhcyBmbGlnaHQgCmluc3RydW1lbnQgcmVwbGFjZW1lbnQgc29mdHdhcmUgYW5k IGhhcmR3YXJlIGZvciBhIFRhYmxldCAuLi5UaGUgCmludGVyZmFjZSB0byBlZ3QsY2h0LG9pbCBw cmVzc3VyZSxldGMgY2FuIGJlIG1hZGUgd2l0aCBhIDcgZG9sbGFyIG1pY3JvIApjb21wdXRlci4u Y2FsbGVkIHRoZSBBcmR1aW5vLi4uZm9yIGl0IGFuZCB0aGUgUmFzcGJlcnJ5IFBpICgzNSBidWNr cykgCmhhdmUgbXVsdGlwbGUgYW5hbG9nIGlucHV0cyBmb3Igc2Vuc29ycyAuIFRoZSBmbGlnaHQg aW5zdHJ1bWVudHMgICAgICAgICAobGVzcyAKYWlyc3BlZWQpIGNhbiBiZSBhY2NvbXBsaXNoZWQg d2l0aCBhIGRldmljZSB0aGUgc2l6ZSBvZiBhIHBvc3RhZ2Ugc3RhbXAgCmNhbGxlZCBhIDlkb2Yo ZGVncmVlcyBvZiBmcmVlZG9tKSAxMCBidWNrcy4uIGl0IGhhcyBhbiBhbHRpbWV0ZXIgCmNoaXAs bWFnbmV0b21ldGVyLGd5cm8uLi5UaGUgQXJkdWlubyBpcyB0aGUgc2l6ZSBvZiBhIGNyZWRpdCBj YXJkLi4gNyAKYnVja3MuLi4gQm90aCBjb21wdXRlcnMgaGF2ZSBhIHNlcmlhbCBwb3J0IHRoYXQg aW50ZXJmYWNlcyB0byB0aGUgOURPRi4gIApTaG91bGQgYmUgZmFpcmx5IGVhc3kgdG8gdGllIHRo ZSBjb21wdXRlciB0byBhaWxlcm9uLCBhbmQgZWxldmF0b3IgdHJpbSAKZm9yIHNvbWUgc29ydCBv ZiB3aW5nIGxldmVsaW5nIHRvIHJlbGF4IHRoZSB3b3JrIGxvYWQgb24gY3Jvc3MgCmNvdW50cmll cy4uIEEgbGFyZ2UgdGhyZWUgd2lyZSAsIG1vZGVsIGFpcnBsYW5lLCBzZXJ2byB3b3VsZCB3b3Jr Li4KCiAgIFN0aWxsIGxvb2tpbmcgZm9yIGEgRmlyZWZseSBvciBGaXJlc3RhciByZSBidWlsZGVy Li4uIEhlcmIKCgpPbiAwNC8wNy8yMDE3IDAyOjAzIEFNLCBOaWNrIENhc3NhcmEgd3JvdGU6Cj4g LS0+IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogTmljayBDYXNzYXJhIDxuaWNrY0BtdGFv bmxpbmUubmV0Pgo+Cj4gS29sYmVycywKPgo+IEkgYW0gd29uZGVyaW5nIGlmIGFueW9uZSBoYXMg aW5zdGFsbGVkIGFuIEFEUy1CIE91dCwgb3IgSW4gYW5kIE91dCwgaW4gdGhlcmUgS29sYiB5ZXQ/ IE9wZW4gRmxpZ2h0IFNvbHV0aW9ucyBpcyB0aGUgbW9zdCBhZmZvcmRhYmxlIHN5c3RlbSBJIGhh dmUgaGVhcmQgb2Ygc28gZmFyLgo+IEkgd291bGQgYXBwcmVjaWF0ZSB5b3VyIGlucHV0LiBIb3Bl ZnVsbHkgSm9obiB3aWxsIGNoZWNrIGl0IG91dCBmb3IgdXMgYXQg4oCcRnVuIGluIHRoZSBTdW4u 4oCdCj4KPiBUaGFua3MsCj4KPgo+IE5pY2sgQ2Fzc2FyYQo+Cj4gUGFsbWVyLCBBbGFza2EKPgo+ IDYwN0FLCj4KPgo+Cj4KCgoKCgoK ________________________________________________________________________________
Date: Apr 08, 2017
Subject: Sun-N-Fun 2017
Just got back from a day and a half at Sun-N-Fun. The weather was super, very unlike Florida for this time of the year. Highs in the mid 70s Friday and today. Last night froze my a.... off. Brian and Helen had to leave for home a few days ago so it was a one man show at the kolb trailer. I looked at the new break away tail wheel and I don't really understand how it works. It looks to me like you have to give it opposite lock to get it to release. In other words if you want it to go full swivel to the left you would apply the left brake and push on the right rudder to the stop. The design is simple and should be reliable just not sure how it works in practice. Please let us know how it really works. Has me scratching my head. There is a beautiful customer Kolbra for sale in front of the Kolb trailer and sounds like they sold a completed Fire Star. Lots of activity. Not the same without John H there. Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Date: Apr 08, 2017
Rick N/Kolbers: I miss being there. S&F has always been a special week for me. Met a lot of folks down there that I only get to see during the air show. First one I have missed since 1984. Oh well, Miss P'fer is ready for the flight to the Rock House in Sep, VGs, brand new Odyssey PC-545, and all. The Odyssey battery that failed, was installed April 2007. I believe I got my money's worth, but I wish it had failed a few weeks earlier or a few weeks later. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen Sent: Saturday, April 08, 2017 2:47 PM Subject: Kolb-List: Sun-N-Fun 2017 Just got back from a day and a half at Sun-N-Fun. The weather was super, very unlike Florida for this time of the year. Highs in the mid 70s Friday and today. Last night froze my a.... off. Brian and Helen had to leave for home a few days ago so it was a one man show at the kolb trailer. I looked at the new break away tail wheel and I don't really understand how it works. It looks to me like you have to give it opposite lock to get it to release. In other words if you want it to go full swivel to the left you would apply the left brake and push on the right rudder to the stop. The design is simple and should be reliable just not sure how it works in practice. Please let us know how it really works. Has me scratching my head. There is a beautiful customer Kolbra for sale in front of the Kolb trailer and sounds like they sold a completed Fire Star. Lots of activity. Not the same without John H there. Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Subject: q
Date: Apr 08, 2017
Tried to email ole Beauford and it bounced. Can someone pls send me his current email address? Greatly appreciated! Russ K ________________________________________________________________________________
Date: Apr 09, 2017
George, This is a great question. =C2-I have an MZ201 (an unusual dual-carb versi on), and was going to use on a scratchbuilt plane, but I became enamored wi th the Kolbs and bought an Ultrastar a couple months ago. =C2-For me, the attraction of the MZ201 was its very light weight. =C2-With redrive, the MZ201 weighs 68 lbs. The MZ201 weight includes the exhaust, carb, redrive, and hand start. The distributor has a neat picture of the 277 and MZ201 on a balance beam, with the 277 clearly heavier than the MZ201. =C2-That sa id, the MZ201 lacks fan cooling and its free air configuration seems unsuit ed for a pusher layout. My Ultrastar has a Cuyuna ULII-02 and with its exha ust, reduction drive, pull start,carb, air cleaner, ignition parts and prop attach flgs, weighs 82 lbs (actual - measured in my garage). =C2-I would love to replace it with the MZ201 but cooling has been a stumbling block.. . =C2-Any ideas you might have for using in in a pusher would be apprecia ted. The MZ202 has fan cooling but the fan cooling system replaces the pull star ter, which necessitates an heavy elec starter. =C2-That, and the gear red rive, raise weight considerably - its more like an 84 lb all up weight. Jeff in Colorado ________________________________________________________________________________
From: Colin Hudson <colin.scott.hudson(at)gmail.com>
Date: Apr 08, 2017
Subject: M3Xtra
Hey Guys, I just listed my Mark3 X-tra on Barnstormers if you know someone who is looking for a nice one. Colin Hudson N424AL > ________________________________________________________________________________
Subject: Blue Bird Flight
Date: Apr 08, 2017
Late this evening I pushed the MKIII out of the hanger. Not an easy job loaded down with 25 gal, 150 lbs, of 91 oct mogas. This was fuel to get me halfway to Lakeland. The MKIII performed well. Great flying weather, no wind and cool. I checked out stall speed, idle power, with this load: 35-36 mph clean. 32 mph 20 deg flaps. 30 mph 40 deg flaps. Shot a dozen landings in all configurations without blowing any of them. I can't take credit for that. I think the VGs are working. Not sure if I have lost any cruise speed or not. If I have, it is very close, if at all. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Apr 08, 2017
Subject: Re: Blue Bird Flight
John, it's good to hear you're up there having some fun. I finished the new b reakaway tailwheel project today. Now I just need some warm weather up here i n northern Michigan so I can finish painting the left wing on the old Firest ar MK1, so I can try it out. George H. Firestar MK1, #FS100 14GDH gdhelton(at)gmail.com Mesick, Michigan Have a great day! > On Apr 8, 2017, at 10:56 PM, John Hauck wrote: > > Late this evening I pushed the MKIII out of the hanger. Not an easy job l oaded down with 25 gal, 150 lbs, of 91 oct mogas. This was fuel to get me h alfway to Lakeland. > > The MKIII performed well. Great flying weather, no wind and cool. > > I checked out stall speed, idle power, with this load: > > 35-36 mph clean. > > 32 mph 20 deg flaps. > > 30 mph 40 deg flaps. > > Shot a dozen landings in all configurations without blowing any of them. I can't take credit for that. I think the VGs are working. > > Not sure if I have lost any cruise speed or not. If I have, it is very cl ose, if at all. > > john h > > mkIII > > Titus, Alabama ________________________________________________________________________________
Date: Apr 08, 2017
Glad that you could get out John. It was a good reward for you, if you know what I mean. I have always found the idea that having the "little bitty thingy ma bobs" on your wing that are designed to reattach the air flow to said wing, being maligned because "they might" slow your plane down a bit, to be a bit of a head scratcher. ( I might still be suffering from inaccurate writing here.) I had always thought that air swirling from being unattached was the culprit, not the solution. Heck, you could be going faster. Just look at it this way. What is the first thing you do when you get in rough weather? You slow down! It could be an improvement built in. Still a bit cranky, Larry On Sat, Apr 8, 2017 at 8:56 PM, John Hauck wrote: > Late this evening I pushed the MKIII out of the hanger. Not an easy job > loaded down with 25 gal, 150 lbs, of 91 oct mogas. > Not sure if I have lost any cruise speed or not. If I have, it is very > close, if at all. > > john h > > mkIII > > Titus, Alabama -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Apr 08, 2017
I think George H has invented a new model Firestar, the MKI. If memory serves me correctly these are the Firestar models. Ya'll correct me if I am wrong. -Firestar -Firestar KXP -Firestar II Don't think there was a MKI, but I know what you are getting at. Folks, not Homer Kolb, decided to call the first FS model the "original" FS, and the "original" MKIII. BTW: You could cut that tail wheel strut in half and still have more strut than you will ever need. Shortening the strut reduces torsional twist, bouncing, bending, and wiggling. Makes tail wheel steering a little tighter. I use a 6" (exposed length) .120" wall heat treated 4130 strut. Works good on Miss P'fer. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of George Helton Sent: Saturday, April 08, 2017 10:19 PM Subject: Re: Kolb-List: Blue Bird Flight John, it's good to hear you're up there having some fun. I finished the new breakaway tailwheel project today. Now I just need some warm weather up here in northern Michigan so I can finish painting the left wing on the old Firestar MK1, so I can try it out. image1.JPG George H. Firestar MK1, #FS100 14GDH gdhelton(at)gmail.com Mesick, Michigan Have a great day! On Apr 8, 2017, at 10:56 PM, John Hauck wrote: Late this evening I pushed the MKIII out of the hanger. Not an easy job loaded down with 25 gal, 150 lbs, of 91 oct mogas. This was fuel to get me halfway to Lakeland. The MKIII performed well. Great flying weather, no wind and cool. I checked out stall speed, idle power, with this load: 35-36 mph clean. 32 mph 20 deg flaps. 30 mph 40 deg flaps. Shot a dozen landings in all configurations without blowing any of them. I can't take credit for that. I think the VGs are working. Not sure if I have lost any cruise speed or not. If I have, it is very close, if at all. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Apr 09, 2017
You're right, John. Original is just to much typing every time. I'll just us e Firestar 1 in the future. I did build a Twinstar Mk II which was the secon d variant of original Twinstar. (open to enclosed cockpit)Which lead to the o riginal MkIII. George H. Firestar 1,(original) #FS100 14GDH gdhelton(at)gmail.com Mesick, Michigan Have a great day! > On Apr 9, 2017, at 12:08 AM, John Hauck wrote: > > I think George H has invented a new model Firestar, the MKI. > > If memory serves me correctly these are the Firestar models. Ya'll correc t me if I am wrong. > > -Firestar > -Firestar KXP > -Firestar II > > Don't think there was a MKI, but I know what you are getting at. Folks, n ot Homer Kolb, decided to call the first FS model the "original" FS, and the "original" MKIII. > > BTW: You could cut that tail wheel strut in half and still have more stru t than you will ever need. Shortening the strut reduces torsional twist, bo uncing, bending, and wiggling. Makes tail wheel steering a little tighter. I use a 6" (exposed length) .120" wall heat treated 4130 strut. Works good on Miss P'fer. > > john h > mkIII > Titus, Alabama > > > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com] On Behalf Of George Helton > Sent: Saturday, April 08, 2017 10:19 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Blue Bird Flight > > John, it's good to hear you're up there having some fun. I finished the ne w breakaway tailwheel project today. Now I just need some warm weather up he re in northern Michigan so I can finish painting the left wing on the old Fi restar MK1, so I can try it out. > > > George H. > Firestar MK1, #FS100 > 14GDH > gdhelton(at)gmail.com > Mesick, Michigan > > > Have a great day! > > On Apr 8, 2017, at 10:56 PM, John Hauck wrote: > > Late this evening I pushed the MKIII out of the hanger. Not an easy job l oaded down with 25 gal, 150 lbs, of 91 oct mogas. This was fuel to get me h alfway to Lakeland. > > The MKIII performed well. Great flying weather, no wind and cool. > > I checked out stall speed, idle power, with this load: > > 35-36 mph clean. > > 32 mph 20 deg flaps. > > 30 mph 40 deg flaps. > > Shot a dozen landings in all configurations without blowing any of them. I can't take credit for that. I think the VGs are working. > > Not sure if I have lost any cruise speed or not. If I have, it is very cl ose, if at all. > > john h > > mkIII > > Titus, Alabama ________________________________________________________________________________
Date: Apr 09, 2017
Subject: New Kolb owner
Hi All, I've just bought myself a 582 blue top Kolb Mk.3 (not the xtra) as I've always fancied one, but here in the U.K. they're like hen's teeth, or very expensive. I'd like some info as I don't have any basic info on the aircraft, just the builders manual, no plans etc, I even don't know if there's a pilots manual. On inspection I found there were no aileron balance rods although the mounts were there. Does anyone know what weight they should be please? Many thanks, Norman ________________________________________________________________________________
Subject: Re: New Kolb owner
Date: Apr 09, 2017
Greetings Norman, welcome to the list. The counterbalances are a solid steel bar 20" long, disconnect the aileron pushrod and slide the bar in and out of the mount until the aileron has a neutral balance. Secure the bar at that point. Here is a little info: http://oh2fly.net/oldpoops/Lexan%20rear%20enclosure.html -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468172#468172 ________________________________________________________________________________
Date: Apr 09, 2017
John, I meant to thank you for tailwheel strut info. Makes sense to me. I'll give shortening it up a bit a try. I just left the length the same as the o riginal fiberglass strut. George H. Firestar 1, #FS100 14GDH gdhelton(at)gmail.com Mesick, Michigan Have a great day! > On Apr 9, 2017, at 12:08 AM, John Hauck wrote: > > I think George H has invented a new model Firestar, the MKI. > > If memory serves me correctly these are the Firestar models. Ya'll correc t me if I am wrong. > > -Firestar > -Firestar KXP > -Firestar II > > Don't think there was a MKI, but I know what you are getting at. Folks, n ot Homer Kolb, decided to call the first FS model the "original" FS, and the "original" MKIII. > > BTW: You could cut that tail wheel strut in half and still have more stru t than you will ever need. Shortening the strut reduces torsional twist, bo uncing, bending, and wiggling. Makes tail wheel steering a little tighter. I use a 6" (exposed length) .120" wall heat treated 4130 strut. Works good on Miss P'fer. > > john h > mkIII > Titus, Alabama > > > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com] On Behalf Of George Helton > Sent: Saturday, April 08, 2017 10:19 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Blue Bird Flight > > John, it's good to hear you're up there having some fun. I finished the ne w breakaway tailwheel project today. Now I just need some warm weather up he re in northern Michigan so I can finish painting the left wing on the old Fi restar MK1, so I can try it out. > > > George H. > Firestar MK1, #FS100 > 14GDH > gdhelton(at)gmail.com > Mesick, Michigan > > > Have a great day! > > On Apr 8, 2017, at 10:56 PM, John Hauck wrote: > > Late this evening I pushed the MKIII out of the hanger. Not an easy job l oaded down with 25 gal, 150 lbs, of 91 oct mogas. This was fuel to get me h alfway to Lakeland. > > The MKIII performed well. Great flying weather, no wind and cool. > > I checked out stall speed, idle power, with this load: > > 35-36 mph clean. > > 32 mph 20 deg flaps. > > 30 mph 40 deg flaps. > > Shot a dozen landings in all configurations without blowing any of them. I can't take credit for that. I think the VGs are working. > > Not sure if I have lost any cruise speed or not. If I have, it is very cl ose, if at all. > > john h > > mkIII > > Titus, Alabama ________________________________________________________________________________
Subject: You've heard of the short wing Pipers,
Date: Apr 09, 2017
How about a short nosed Kolb? ________________________________________________________________________________
Subject: Kolb Twinstar (original version) info request
Date: Apr 09, 2017
OK, now that I've got that short nose Kolb bit out of my system.... I'm now the proud owner of an N-numbered early Kolb Twinstar (restoration project). IIRC, its serial number is in the low 20's range. A little rusty, but we've peeled the fabric on one wing & the aluminum seems to be in good shape, with very little corrosion, considering that it spent its entire past life in central FL. This one's got a Rotax 503 (converted from single to dual carbs, and to free air cooling) that seems to be in great shape. The previous owner is a close friend who was the builder. I trust what he tells me, and he says that it always cooled fine running it free-air with some added ducting. I'll be replacing hardware, 'soft' parts, etc, but don't intend on doing a showplane restoration; just a safe, nice flying 'after supper' flyer. I've got the plans for the plane, but I'm hoping that you experienced Kolbers can share any suggested mods to these early models, that will make them safer/more durable/etc. Is there a published list of any/all service bulletins or recommended updates? For instance, I've seen the advice to add braces to the tailspring stinger. And I know that the later Twinstars have mass balances on at least some of the control surfaces; is it recommended to add them to the early models? This one does not have any mass balances anywhere. Who's recovered one? Any issues when you drilled out the rivets to remove the ailerons, etc for recovering? Any advice will be appreciated. Thanks, Charlie ________________________________________________________________________________
Date: Apr 09, 2017
George H/Kolbers: The two photos will give you an idea what mine looks like. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of George Helton Sent: Sunday, April 09, 2017 3:45 PM Subject: Re: Kolb-List: Blue Bird Flight John, I meant to thank you for tailwheel strut info. Makes sense to me. I'll give shortening it up a bit a try. I just left the length the same as the original fiberglass strut. George H. Firestar 1, #FS100 14GDH gdhelton(at)gmail.com Mesick, Michigan Have a great day! On Apr 9, 2017, at 12:08 AM, John Hauck wrote: I think George H has invented a new model Firestar, the MKI. If memory serves me correctly these are the Firestar models. Ya'll correct me if I am wrong. -Firestar -Firestar KXP -Firestar II Don't think there was a MKI, but I know what you are getting at. Folks, not Homer Kolb, decided to call the first FS model the "original" FS, and the "original" MKIII. BTW: You could cut that tail wheel strut in half and still have more strut than you will ever need. Shortening the strut reduces torsional twist, bouncing, bending, and wiggling. Makes tail wheel steering a little tighter. I use a 6" (exposed length) .120" wall heat treated 4130 strut. Works good on Miss P'fer. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of George Helton Sent: Saturday, April 08, 2017 10:19 PM Subject: Re: Kolb-List: Blue Bird Flight John, it's good to hear you're up there having some fun. I finished the new breakaway tailwheel project today. Now I just need some warm weather up here in northern Michigan so I can finish painting the left wing on the old Firestar MK1, so I can try it out. George H. Firestar MK1, #FS100 14GDH gdhelton(at)gmail.com Mesick, Michigan Have a great day! On Apr 8, 2017, at 10:56 PM, John Hauck wrote: Late this evening I pushed the MKIII out of the hanger. Not an easy job loaded down with 25 gal, 150 lbs, of 91 oct mogas. This was fuel to get me halfway to Lakeland. The MKIII performed well. Great flying weather, no wind and cool. I checked out stall speed, idle power, with this load: 35-36 mph clean. 32 mph 20 deg flaps. 30 mph 40 deg flaps. Shot a dozen landings in all configurations without blowing any of them. I can't take credit for that. I think the VGs are working. Not sure if I have lost any cruise speed or not. If I have, it is very close, if at all. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: You've heard of the short wing Pipers,
Date: Apr 09, 2017
I'm waiting for Mr. Bean to peek over the windshield... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468209#468209 ________________________________________________________________________________
Date: Apr 09, 2017
Charlie E/Kolbers: I have recovered a bunch of them. All that I tore up and a few I didn't. Drilling rivets can be accomplished once you have the mandrels removed. It takes a 1/16" punch, or you can use a pulled mandrel, grind the end flat, hold with vise grips, and knock out with a hammer. The rivet needs to be held to prevent spinning. I grind a V in the end of a hack saw blade with sharp beveled edges. Use that to push up under the rivet to lock it in place while drilling. 4130 airframes should be tube sealed when fabricated. 99% of Kolbs probably have never been tube sealed. Their builders probably never heard of tube sealing. 4130 rusts from inside out if not sealed. That would worry me with an old fuselage, especially a Twinstar. I can't remember exactly what the fuselage looks like other that the root tube that seats and stuff are attached to. This I would make sure is rust free on the inside. I helped Brother Jim rebuild Adriel Heisey's Twinstar, Navajo Nation pilot that shot aerial photos published in Nat Geo and other pubs, that he crashed in a wind storm. It was frightening when we started cutting tubing. Most were rusted well beyond serviceability. Here are photos of his Twinstar: https://uanews.arizona.edu/story/aerial-photos-of-archaeological-sites-on-exhibit-at-state-museum I don't recall anyone flying a free air cooled Rotax on a Kolb successfully. Yours may be an exception. Don't know of any published updates for the Twinstar. It was not a popular model and kits only produced a couple years. Strong lateral bracing of the leading edge of the wing is extremely important to me. Poor/weak lateral bracing can lead to leading edge failure. This causes the Kolb to stop flying immediately. Lower tail post bracing makes it last longer. I don't know a whole lot about the Twinstar. The one Kolb model I never flew. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Sunday, April 09, 2017 4:33 PM Subject: Kolb-List: Kolb Twinstar (original version) info request OK, now that I've got that short nose Kolb bit out of my system.... I'm now the proud owner of an N-numbered early Kolb Twinstar (restoration project). IIRC, its serial number is in the low 20's range. A little rusty, but we've peeled the fabric on one wing & the aluminum seems to be in good shape, with very little corrosion, considering that it spent its entire past life in central FL. This one's got a Rotax 503 (converted from single to dual carbs, and to free air cooling) that seems to be in great shape. The previous owner is a close friend who was the builder. I trust what he tells me, and he says that it always cooled fine running it free-air with some added ducting. I'll be replacing hardware, 'soft' parts, etc, but don't intend on doing a showplane restoration; just a safe, nice flying 'after supper' flyer. I've got the plans for the plane, but I'm hoping that you experienced Kolbers can share any suggested mods to these early models, that will make them safer/more durable/etc. Is there a published list of any/all service bulletins or recommended updates? For instance, I've seen the advice to add braces to the tailspring stinger. And I know that the later Twinstars have mass balances on at least some of the control surfaces; is it recommended to add them to the early models? This one does not have any mass balances anywhere. Who's recovered one? Any issues when you drilled out the rivets to remove the ailerons, etc for recovering? Any advice will be appreciated. Thanks, Charlie ________________________________________________________________________________
Date: Apr 09, 2017
Boyd Young of the list sent me a PM, good question, he said: "Do you do this with or without removing the flap connected? If with the flap, do you remove the flap pushrod? Explain Your answer..." Wish I could, it's been long enough I don't rightly remember. I went out to the hangar just now and disconnected the aileron pushrod, and the aileron went to a neutral position, the counterbalance was pretty much aligned alongside the wingtip. Waggled the flaps and ailerons, and it kept going back to that general position. Which makes sense; where the flaps are attached to the back side of the aileron torque tube, they contribute a little weight to the ailerons, but at a very short moment arm. I'm sure there was some info that came from Kolb, but I no longer have it, and obviously it was not in the original documentation. If I remember correctly (HAH) I raised the tail up so that the bottom of the wing was horizontal, disconnected the ailerons, and slid the weight in and out until the ailerons aligned with the bottom of the wing. Why not call Kolb and ask them? Since they have been including counterbalances in the kits for over 15 years now, they will probably be able to tell you a lot better than any of us could. I do remember that there was a lot of kerfluffle on the Kolb list the year before I installed them, which my airframe log shows as 1999. The list doesn't go back that far, it only goes to 2006, but if you do a search on "Aileron Flutter" you will see a lot of posts about it, it was still a big deal, but no specifics on how to install the counterbalances. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468211#468211 ________________________________________________________________________________
Subject: Re: Kolb Twinstar (original version) info request
Date: Apr 09, 2017
Thanks, John. I wasn't sure about how rugged the tubes would be when driving out mandrels, etc. I use similar tricks on the heavier experimentals I've owned. I've got a spring loaded center punch that I ground to a flat nosed, straight shaft, & use it to punch out driven rivets after drilling the heads. I also use small, flush cutting 'dykes' (diagonal wire cutters) to grab pop rivet heads; same idea as your hack saw 'V'. I will be checking the 4130 pieces for integrity. One trick I was taught that's used on Cubs, Taylorcraft, etc is to wrap the tube with something to protect from scratching & squeeze it with a pair of 'channel lock' pliers. Not a perfect test, but if the tube gives at all, you know you've got a problem. The free air cooling thing I'll be looking at, but he told me that he had added some ducting (haven't seen it all assembled yet) so he may well have added a 'collector' on the input side & an exit duct that ends near the prop for extraction. We'll see. We've pulled the fabric off one side of a wing, & I don't recall seeing lateral bracing of the leading edge ribs. But I wasn't looking for it. Will definitely make sure it has bracing in place before recover. Speaking of which, has anyone wrapped the leading edge ribs with very thin gauge aluminum sheet before covering? It's done on some heavier fabric wing a/c to provide somewhat of a D-cell (lateral bracing) and also provide a smooth, more aerodynamic leading edge (nothing like a little aero cleanup :-) ). I really don't want to stray too far from the original design, but I'm curious about any mods people have been successful with. Thanks, Charlie On 4/9/2017 5:58 PM, John Hauck wrote: > > Charlie E/Kolbers: > > I have recovered a bunch of them. All that I tore up and a few I didn't. > > Drilling rivets can be accomplished once you have the mandrels removed. It takes a 1/16" punch, or you can use a pulled mandrel, grind the end flat, hold with vise grips, and knock out with a hammer. The rivet needs to be held to prevent spinning. I grind a V in the end of a hack saw blade with sharp beveled edges. Use that to push up under the rivet to lock it in place while drilling. > > 4130 airframes should be tube sealed when fabricated. 99% of Kolbs probably have never been tube sealed. Their builders probably never heard of tube sealing. 4130 rusts from inside out if not sealed. That would worry me with an old fuselage, especially a Twinstar. I can't remember exactly what the fuselage looks like other that the root tube that seats and stuff are attached to. This I would make sure is rust free on the inside. > > I helped Brother Jim rebuild Adriel Heisey's Twinstar, Navajo Nation pilot that shot aerial photos published in Nat Geo and other pubs, that he crashed in a wind storm. It was frightening when we started cutting tubing. Most were rusted well beyond serviceability. Here are photos of his Twinstar: > > https://uanews.arizona.edu/story/aerial-photos-of-archaeological-sites-on-exhibit-at-state-museum > > I don't recall anyone flying a free air cooled Rotax on a Kolb successfully. Yours may be an exception. > > Don't know of any published updates for the Twinstar. It was not a popular model and kits only produced a couple years. > > Strong lateral bracing of the leading edge of the wing is extremely important to me. Poor/weak lateral bracing can lead to leading edge failure. This causes the Kolb to stop flying immediately. > > Lower tail post bracing makes it last longer. > > I don't know a whole lot about the Twinstar. The one Kolb model I never flew. > > john h > mkIII > Titus, Alabama > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England > Sent: Sunday, April 09, 2017 4:33 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Kolb Twinstar (original version) info request > > > OK, now that I've got that short nose Kolb bit out of my system.... > > I'm now the proud owner of an N-numbered early Kolb Twinstar (restoration project). IIRC, its serial number is in the low 20's range. > A little rusty, but we've peeled the fabric on one wing & the aluminum seems to be in good shape, with very little corrosion, considering that it spent its entire past life in central FL. > > This one's got a Rotax 503 (converted from single to dual carbs, and to free air cooling) that seems to be in great shape. The previous owner is a close friend who was the builder. I trust what he tells me, and he says that it always cooled fine running it free-air with some added ducting. > > I'll be replacing hardware, 'soft' parts, etc, but don't intend on doing a showplane restoration; just a safe, nice flying 'after supper' flyer. > I've got the plans for the plane, but I'm hoping that you experienced Kolbers can share any suggested mods to these early models, that will make them safer/more durable/etc. Is there a published list of any/all service bulletins or recommended updates? For instance, I've seen the advice to add braces to the tailspring stinger. And I know that the later Twinstars have mass balances on at least some of the control surfaces; is it recommended to add them to the early models? This one does not have any mass balances anywhere. > > Who's recovered one? Any issues when you drilled out the rivets to remove the ailerons, etc for recovering? > > Any advice will be appreciated. > > Thanks, > > Charlie > ________________________________________________________________________________
Date: Apr 09, 2017
" We've pulled the fabric off one side of a wing, & I don't recall seeing lateral bracing of the leading edge ribs. But I wasn't looking for it.' Charlie E/Gents: I didn't say "leading edge ribs", I said "leading edge." Lateral bracing on the leading edge tube keeps the noses of the ribs in column. Weak lateral, or little or no lateral bracing will allow the ribs to come out of column and fail. I know this by experience. Homer Kolb did not wrap the leading edge with alum sheet, and did not recommend doing this. He felt his bow tip design and the valleys between ribs improved slow speed flight and decreased stall speed. Kolbs all use the same airfoil, all models, and have always been great slow speed performers, long before VGs. Homer's idea of flying was low and slow, right down in the tree tops to stay in touch with what was going on down there. He liked to fly with the birds. Thus the large ailerons and high lift wing. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Sunday, April 09, 2017 7:18 PM Subject: Re: Kolb-List: Kolb Twinstar (original version) info request Thanks, John. I wasn't sure about how rugged the tubes would be when driving out mandrels, etc. I use similar tricks on the heavier experimentals I've owned. I've got a spring loaded center punch that I ground to a flat nosed, straight shaft, & use it to punch out driven rivets after drilling the heads. I also use small, flush cutting 'dykes' (diagonal wire cutters) to grab pop rivet heads; same idea as your hack saw 'V'. I will be checking the 4130 pieces for integrity. One trick I was taught that's used on Cubs, Taylorcraft, etc is to wrap the tube with something to protect from scratching & squeeze it with a pair of 'channel lock' pliers. Not a perfect test, but if the tube gives at all, you know you've got a problem. The free air cooling thing I'll be looking at, but he told me that he had added some ducting (haven't seen it all assembled yet) so he may well have added a 'collector' on the input side & an exit duct that ends near the prop for extraction. We'll see. We've pulled the fabric off one side of a wing, & I don't recall seeing lateral bracing of the leading edge ribs. But I wasn't looking for it. Will definitely make sure it has bracing in place before recover. Speaking of which, has anyone wrapped the leading edge ribs with very thin gauge aluminum sheet before covering? It's done on some heavier fabric wing a/c to provide somewhat of a D-cell (lateral bracing) and also provide a smooth, more aerodynamic leading edge (nothing like a little aero cleanup :-) ). I really don't want to stray too far from the original design, but I'm curious about any mods people have been successful with. Thanks, Charlie On 4/9/2017 5:58 PM, John Hauck wrote: > > Charlie E/Kolbers: > > I have recovered a bunch of them. All that I tore up and a few I didn't. > > Drilling rivets can be accomplished once you have the mandrels removed. It takes a 1/16" punch, or you can use a pulled mandrel, grind the end flat, hold with vise grips, and knock out with a hammer. The rivet needs to be held to prevent spinning. I grind a V in the end of a hack saw blade with sharp beveled edges. Use that to push up under the rivet to lock it in place while drilling. > > 4130 airframes should be tube sealed when fabricated. 99% of Kolbs probably have never been tube sealed. Their builders probably never heard of tube sealing. 4130 rusts from inside out if not sealed. That would worry me with an old fuselage, especially a Twinstar. I can't remember exactly what the fuselage looks like other that the root tube that seats and stuff are attached to. This I would make sure is rust free on the inside. > > I helped Brother Jim rebuild Adriel Heisey's Twinstar, Navajo Nation pilot that shot aerial photos published in Nat Geo and other pubs, that he crashed in a wind storm. It was frightening when we started cutting tubing. Most were rusted well beyond serviceability. Here are photos of his Twinstar: > > https://uanews.arizona.edu/story/aerial-photos-of-archaeological-sites > -on-exhibit-at-state-museum > > I don't recall anyone flying a free air cooled Rotax on a Kolb successfully. Yours may be an exception. > > Don't know of any published updates for the Twinstar. It was not a popular model and kits only produced a couple years. > > Strong lateral bracing of the leading edge of the wing is extremely important to me. Poor/weak lateral bracing can lead to leading edge failure. This causes the Kolb to stop flying immediately. > > Lower tail post bracing makes it last longer. > > I don't know a whole lot about the Twinstar. The one Kolb model I never flew. > > john h > mkIII > Titus, Alabama > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie > England > Sent: Sunday, April 09, 2017 4:33 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Kolb Twinstar (original version) info request > > --> > > OK, now that I've got that short nose Kolb bit out of my system.... > > I'm now the proud owner of an N-numbered early Kolb Twinstar (restoration project). IIRC, its serial number is in the low 20's range. > A little rusty, but we've peeled the fabric on one wing & the aluminum seems to be in good shape, with very little corrosion, considering that it spent its entire past life in central FL. > > This one's got a Rotax 503 (converted from single to dual carbs, and to free air cooling) that seems to be in great shape. The previous owner is a close friend who was the builder. I trust what he tells me, and he says that it always cooled fine running it free-air with some added ducting. > > I'll be replacing hardware, 'soft' parts, etc, but don't intend on doing a showplane restoration; just a safe, nice flying 'after supper' flyer. > I've got the plans for the plane, but I'm hoping that you experienced Kolbers can share any suggested mods to these early models, that will make them safer/more durable/etc. Is there a published list of any/all service bulletins or recommended updates? For instance, I've seen the advice to add braces to the tailspring stinger. And I know that the later Twinstars have mass balances on at least some of the control surfaces; is it recommended to add them to the early models? This one does not have any mass balances anywhere. > > Who's recovered one? Any issues when you drilled out the rivets to remove the ailerons, etc for recovering? > > Any advice will be appreciated. > > Thanks, > > Charlie > ________________________________________________________________________________
Date: Apr 09, 2017
I experienced aileron flutter with all three of my Kolbs, US, FS, and MKIII. I made up some counterbalance weights when I was building the MKIII because I had a good idea I would continue to have flutter problems. My weights did more to aggravate flutter than prevent it. First approach into Wetumpka Airport went into flutter, snatching the stick out of my hand. Got it on the ground and removed them. Anything over 80 mph and they would start to flutter. Could not get Kolb Aircraft to believe we had an aileron flutter problem. Miss P'fer was new, flew to Lakeland, Homer's in PA, and OSH. One eye on the ASI and one out of the cockpit. Flew a photo shoot off a Cessna 210 at OSH. He had trouble slowing to 80 and I went into flutter over 80. Getting ready to do my first flight to Alaska. Sun and Fun 1994. Dick Rahill was hauling butt back from South Lakeland to the UL strip with a thunderstorm hot on his tail. Turbulent air, WOT, all the sudden the FSII went into violent aileron flutter. Dick was white as a sheet when he landed. Got his attention. Now they believed me. Less than a week after I returned to Alabama I had a set of FSII aileron counterbalance weights and mounts. I made them work on the MKIII. Never had an inkling of coming anywhere near aileron flutter after installation. They work. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Sunday, April 09, 2017 6:19 PM Subject: Kolb-List: Re: New Kolb owner --> Boyd Young of the list sent me a PM, good question, he said: "Do you do this with or without removing the flap connected? If with the flap, do you remove the flap pushrod? Explain Your answer..." Wish I could, it's been long enough I don't rightly remember. I went out to the hangar just now and disconnected the aileron pushrod, and the aileron went to a neutral position, the counterbalance was pretty much aligned alongside the wingtip. Waggled the flaps and ailerons, and it kept going back to that general position. Which makes sense; where the flaps are attached to the back side of the aileron torque tube, they contribute a little weight to the ailerons, but at a very short moment arm. I'm sure there was some info that came from Kolb, but I no longer have it, and obviously it was not in the original documentation. If I remember correctly (HAH) I raised the tail up so that the bottom of the wing was horizontal, disconnected the ailerons, and slid the weight in and out until the ailerons aligned with the bottom of the wing. Why not call Kolb and ask them? Since they have been including counterbalances in the kits for over 15 years now, they will probably be able to tell you a lot better than any of us could. I do remember that there was a lot of kerfluffle on the Kolb list the year before I installed them, which my airframe log shows as 1999. The list doesn't go back that far, it only goes to 2006, but if you do a search on "Aileron Flutter" you will see a lot of posts about it, it was still a big deal, but no specifics on how to install the counterbalances. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468211#468211 ________________________________________________________________________________
Date: Apr 09, 2017
Yes, you did. Sorry; I've got to adjust to having 3 spars instead of 2. :-) Thank you for the info. Charlie On 4/9/2017 7:57 PM, John Hauck wrote: > > " We've pulled the fabric off one side of a wing, & I don't recall seeing lateral bracing of the leading edge ribs. But I wasn't looking for it.' > > Charlie E/Gents: > > I didn't say "leading edge ribs", I said "leading edge." Lateral bracing on the leading edge tube keeps the noses of the ribs in column. Weak lateral, or little or no lateral bracing will allow the ribs to come out of column and fail. I know this by experience. > > Homer Kolb did not wrap the leading edge with alum sheet, and did not recommend doing this. He felt his bow tip design and the valleys between ribs improved slow speed flight and decreased stall speed. Kolbs all use the same airfoil, all models, and have always been great slow speed performers, long before VGs. Homer's idea of flying was low and slow, right down in the tree tops to stay in touch with what was going on down there. He liked to fly with the birds. Thus the large ailerons and high lift wing. > > john h > mkIII > Titus, Alabama > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England > Sent: Sunday, April 09, 2017 7:18 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Kolb Twinstar (original version) info request > > > Thanks, John. I wasn't sure about how rugged the tubes would be when driving out mandrels, etc. I use similar tricks on the heavier experimentals I've owned. I've got a spring loaded center punch that I ground to a flat nosed, straight shaft, & use it to punch out driven rivets after drilling the heads. I also use small, flush cutting 'dykes' > (diagonal wire cutters) to grab pop rivet heads; same idea as your hack saw 'V'. > I will be checking the 4130 pieces for integrity. One trick I was taught that's used on Cubs, Taylorcraft, etc is to wrap the tube with something to protect from scratching & squeeze it with a pair of 'channel lock' > pliers. Not a perfect test, but if the tube gives at all, you know you've got a problem. > > The free air cooling thing I'll be looking at, but he told me that he had added some ducting (haven't seen it all assembled yet) so he may well have added a 'collector' on the input side & an exit duct that ends near the prop for extraction. We'll see. > > We've pulled the fabric off one side of a wing, & I don't recall seeing lateral bracing of the leading edge ribs. But I wasn't looking for it. > Will definitely make sure it has bracing in place before recover. > Speaking of which, has anyone wrapped the leading edge ribs with very thin gauge aluminum sheet before covering? It's done on some heavier fabric wing a/c to provide somewhat of a D-cell (lateral bracing) and also provide a smooth, more aerodynamic leading edge (nothing like a little aero cleanup :-) ). > > I really don't want to stray too far from the original design, but I'm curious about any mods people have been successful with. > > Thanks, > > Charlie > > On 4/9/2017 5:58 PM, John Hauck wrote: >> >> Charlie E/Kolbers: >> >> I have recovered a bunch of them. All that I tore up and a few I didn't. >> >> Drilling rivets can be accomplished once you have the mandrels removed. It takes a 1/16" punch, or you can use a pulled mandrel, grind the end flat, hold with vise grips, and knock out with a hammer. The rivet needs to be held to prevent spinning. I grind a V in the end of a hack saw blade with sharp beveled edges. Use that to push up under the rivet to lock it in place while drilling. >> >> 4130 airframes should be tube sealed when fabricated. 99% of Kolbs probably have never been tube sealed. Their builders probably never heard of tube sealing. 4130 rusts from inside out if not sealed. That would worry me with an old fuselage, especially a Twinstar. I can't remember exactly what the fuselage looks like other that the root tube that seats and stuff are attached to. This I would make sure is rust free on the inside. >> >> I helped Brother Jim rebuild Adriel Heisey's Twinstar, Navajo Nation pilot that shot aerial photos published in Nat Geo and other pubs, that he crashed in a wind storm. It was frightening when we started cutting tubing. Most were rusted well beyond serviceability. Here are photos of his Twinstar: >> >> https://uanews.arizona.edu/story/aerial-photos-of-archaeological-sites >> -on-exhibit-at-state-museum >> >> I don't recall anyone flying a free air cooled Rotax on a Kolb successfully. Yours may be an exception. >> >> Don't know of any published updates for the Twinstar. It was not a popular model and kits only produced a couple years. >> >> Strong lateral bracing of the leading edge of the wing is extremely important to me. Poor/weak lateral bracing can lead to leading edge failure. This causes the Kolb to stop flying immediately. >> >> Lower tail post bracing makes it last longer. >> >> I don't know a whole lot about the Twinstar. The one Kolb model I never flew. >> >> john h >> mkIII >> Titus, Alabama >> >> >> >> >> -----Original Message----- >> From: owner-kolb-list-server(at)matronics.com >> [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie >> England >> Sent: Sunday, April 09, 2017 4:33 PM >> To: kolb-list(at)matronics.com >> Subject: Kolb-List: Kolb Twinstar (original version) info request >> >> --> >> >> OK, now that I've got that short nose Kolb bit out of my system.... >> >> I'm now the proud owner of an N-numbered early Kolb Twinstar (restoration project). IIRC, its serial number is in the low 20's range. >> A little rusty, but we've peeled the fabric on one wing & the aluminum seems to be in good shape, with very little corrosion, considering that it spent its entire past life in central FL. >> >> This one's got a Rotax 503 (converted from single to dual carbs, and to free air cooling) that seems to be in great shape. The previous owner is a close friend who was the builder. I trust what he tells me, and he says that it always cooled fine running it free-air with some added ducting. >> >> I'll be replacing hardware, 'soft' parts, etc, but don't intend on doing a showplane restoration; just a safe, nice flying 'after supper' flyer. >> I've got the plans for the plane, but I'm hoping that you experienced Kolbers can share any suggested mods to these early models, that will make them safer/more durable/etc. Is there a published list of any/all service bulletins or recommended updates? For instance, I've seen the advice to add braces to the tailspring stinger. And I know that the later Twinstars have mass balances on at least some of the control surfaces; is it recommended to add them to the early models? This one does not have any mass balances anywhere. >> >> Who's recovered one? Any issues when you drilled out the rivets to remove the ailerons, etc for recovering? >> >> Any advice will be appreciated. >> >> Thanks, >> >> Charlie >> > ________________________________________________________________________________
Date: Apr 09, 2017
I don't have that problem since I have never built or flown anything but Kolbs and a few helicopters. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Sunday, April 09, 2017 10:10 PM Subject: Re: Kolb-List: Kolb Twinstar (original version) info request Yes, you did. Sorry; I've got to adjust to having 3 spars instead of 2. :-) Thank you for the info. Charlie On 4/9/2017 7:57 PM, John Hauck wrote: > > " We've pulled the fabric off one side of a wing, & I don't recall seeing lateral bracing of the leading edge ribs. But I wasn't looking for it.' > > Charlie E/Gents: > > I didn't say "leading edge ribs", I said "leading edge." Lateral bracing on the leading edge tube keeps the noses of the ribs in column. Weak lateral, or little or no lateral bracing will allow the ribs to come out of column and fail. I know this by experience. > > Homer Kolb did not wrap the leading edge with alum sheet, and did not recommend doing this. He felt his bow tip design and the valleys between ribs improved slow speed flight and decreased stall speed. Kolbs all use the same airfoil, all models, and have always been great slow speed performers, long before VGs. Homer's idea of flying was low and slow, right down in the tree tops to stay in touch with what was going on down there. He liked to fly with the birds. Thus the large ailerons and high lift wing. > > john h > mkIII > Titus, Alabama > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie > England > Sent: Sunday, April 09, 2017 7:18 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Kolb Twinstar (original version) info request > > --> > > Thanks, John. I wasn't sure about how rugged the tubes would be when driving out mandrels, etc. I use similar tricks on the heavier experimentals I've owned. I've got a spring loaded center punch that I ground to a flat nosed, straight shaft, & use it to punch out driven rivets after drilling the heads. I also use small, flush cutting 'dykes' > (diagonal wire cutters) to grab pop rivet heads; same idea as your hack saw 'V'. > I will be checking the 4130 pieces for integrity. One trick I was taught that's used on Cubs, Taylorcraft, etc is to wrap the tube with something to protect from scratching & squeeze it with a pair of 'channel lock' > pliers. Not a perfect test, but if the tube gives at all, you know you've got a problem. > > The free air cooling thing I'll be looking at, but he told me that he had added some ducting (haven't seen it all assembled yet) so he may well have added a 'collector' on the input side & an exit duct that ends near the prop for extraction. We'll see. > > We've pulled the fabric off one side of a wing, & I don't recall seeing lateral bracing of the leading edge ribs. But I wasn't looking for it. > Will definitely make sure it has bracing in place before recover. > Speaking of which, has anyone wrapped the leading edge ribs with very thin gauge aluminum sheet before covering? It's done on some heavier fabric wing a/c to provide somewhat of a D-cell (lateral bracing) and also provide a smooth, more aerodynamic leading edge (nothing like a little aero cleanup :-) ). > > I really don't want to stray too far from the original design, but I'm curious about any mods people have been successful with. > > Thanks, > > Charlie > > On 4/9/2017 5:58 PM, John Hauck wrote: >> >> Charlie E/Kolbers: >> >> I have recovered a bunch of them. All that I tore up and a few I didn't. >> >> Drilling rivets can be accomplished once you have the mandrels removed. It takes a 1/16" punch, or you can use a pulled mandrel, grind the end flat, hold with vise grips, and knock out with a hammer. The rivet needs to be held to prevent spinning. I grind a V in the end of a hack saw blade with sharp beveled edges. Use that to push up under the rivet to lock it in place while drilling. >> >> 4130 airframes should be tube sealed when fabricated. 99% of Kolbs probably have never been tube sealed. Their builders probably never heard of tube sealing. 4130 rusts from inside out if not sealed. That would worry me with an old fuselage, especially a Twinstar. I can't remember exactly what the fuselage looks like other that the root tube that seats and stuff are attached to. This I would make sure is rust free on the inside. >> >> I helped Brother Jim rebuild Adriel Heisey's Twinstar, Navajo Nation pilot that shot aerial photos published in Nat Geo and other pubs, that he crashed in a wind storm. It was frightening when we started cutting tubing. Most were rusted well beyond serviceability. Here are photos of his Twinstar: >> >> https://uanews.arizona.edu/story/aerial-photos-of-archaeological-site >> s >> -on-exhibit-at-state-museum >> >> I don't recall anyone flying a free air cooled Rotax on a Kolb successfully. Yours may be an exception. >> >> Don't know of any published updates for the Twinstar. It was not a popular model and kits only produced a couple years. >> >> Strong lateral bracing of the leading edge of the wing is extremely important to me. Poor/weak lateral bracing can lead to leading edge failure. This causes the Kolb to stop flying immediately. >> >> Lower tail post bracing makes it last longer. >> >> I don't know a whole lot about the Twinstar. The one Kolb model I never flew. >> >> john h >> mkIII >> Titus, Alabama >> >> >> >> >> -----Original Message----- >> From: owner-kolb-list-server(at)matronics.com >> [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie >> England >> Sent: Sunday, April 09, 2017 4:33 PM >> To: kolb-list(at)matronics.com >> Subject: Kolb-List: Kolb Twinstar (original version) info request >> >> --> >> >> OK, now that I've got that short nose Kolb bit out of my system.... >> >> I'm now the proud owner of an N-numbered early Kolb Twinstar (restoration project). IIRC, its serial number is in the low 20's range. >> A little rusty, but we've peeled the fabric on one wing & the aluminum seems to be in good shape, with very little corrosion, considering that it spent its entire past life in central FL. >> >> This one's got a Rotax 503 (converted from single to dual carbs, and to free air cooling) that seems to be in great shape. The previous owner is a close friend who was the builder. I trust what he tells me, and he says that it always cooled fine running it free-air with some added ducting. >> >> I'll be replacing hardware, 'soft' parts, etc, but don't intend on doing a showplane restoration; just a safe, nice flying 'after supper' flyer. >> I've got the plans for the plane, but I'm hoping that you experienced Kolbers can share any suggested mods to these early models, that will make them safer/more durable/etc. Is there a published list of any/all service bulletins or recommended updates? For instance, I've seen the advice to add braces to the tailspring stinger. And I know that the later Twinstars have mass balances on at least some of the control surfaces; is it recommended to add them to the early models? This one does not have any mass balances anywhere. >> >> Who's recovered one? Any issues when you drilled out the rivets to remove the ailerons, etc for recovering? >> >> Any advice will be appreciated. >> >> Thanks, >> >> Charlie >> > ________________________________________________________________________________
Date: Apr 10, 2017
Subject: Re - New Kolb owner
Many thanks for the info - the link to the "yellow Book" was very informative. Norman ________________________________________________________________________________
Date: Apr 10, 2017
take a snap punch and grind the tip down to be small enough to knock out th e rivet mandrels. Then the rivets will drill straight with out enlarging th e original hole =C2-Gary Jindramark 111c912ul 420 hours From: Charlie England <ceengland7(at)gmail.com> To: kolb-list(at)matronics.com Sent: Sunday, April 9, 2017 5:34 PM Subject: Kolb-List: Kolb Twinstar (original version) info request OK, now that I've got that short nose Kolb bit out of my system.... I'm now the proud owner of an N-numbered early Kolb Twinstar (restoration project). IIRC, its serial number is in the low 20's range. A little rusty, but we've peeled the fabric on one wing & the aluminum seems to be in good shape, with very little corrosion, considering that it spent its entire past life in central FL. This one's got a Rotax 503 (converted from single to dual carbs, and to free air cooling) that seems to be in great shape. The previous owner is a close friend who was the builder. I trust what he=C2- tells me, and he says that it always=C2- cooled fine running it free-air with some added ducting. I'll be replacing hardware, 'soft' parts, etc, but don't intend on doing a showplane restoration; just a safe, nice flying 'after supper' flyer. I've got the plans for the plane, but I'm hoping that you experienced Kolbers can share any suggested mods to these early models, that will make them safer/more durable/etc. Is there a published list of any/all service bulletins or recommended updates? For instance, I've seen the advice to add braces to the tailspring stinger. And I know that the later Twinstars have mass balances on at least some of the control surfaces; is it recommended to add them to the early models? This one does not have any mass balances anywhere. Who's recovered one? Any issues when you drilled out the rivets to remove the ailerons, etc for recovering? Any advice will be appreciated. Thanks, Charlie S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 10, 2017
Thanks, Gary; I've got one modified like that. On Mon, Apr 10, 2017 at 11:01 AM, GARY JINDRA wrote: > take a snap punch and grind the tip down to be small enough to knock out > the rivet mandrels. Then the rivets will drill straight with out enlarging > the original hole > > *Gary Jindra* > mark 111c > 912ul 420 hours > > ------------------------------ > *From:* Charlie England > *To:* kolb-list(at)matronics.com > *Sent:* Sunday, April 9, 2017 5:34 PM > *Subject:* Kolb-List: Kolb Twinstar (original version) info request > > > OK, now that I've got that short nose Kolb bit out of my system.... > > I'm now the proud owner of an N-numbered early Kolb Twinstar > (restoration project). IIRC, its serial number is in the low 20's range. > A little rusty, but we've peeled the fabric on one wing & the aluminum > seems to be in good shape, with very little corrosion, considering that > it spent its entire past life in central FL. > > This one's got a Rotax 503 (converted from single to dual carbs, and to > free air cooling) that seems to be in great shape. The previous owner is > a close friend who was the builder. I trust what he tells me, and he > says that it always cooled fine running it free-air with some added > ducting. > > I'll be replacing hardware, 'soft' parts, etc, but don't intend on doing > a showplane restoration; just a safe, nice flying 'after supper' flyer. > I've got the plans for the plane, but I'm hoping that you experienced > Kolbers can share any suggested mods to these early models, that will > make them safer/more durable/etc. Is there a published list of any/all > service bulletins or recommended updates? For instance, I've seen the > advice to add braces to the tailspring stinger. And I know that the > later Twinstars have mass balances on at least some of the control > surfaces; is it recommended to add them to the early models? This one > does not have any mass balances anywhere. > > Who's recovered one? Any issues when you drilled out the rivets to > remove the ailerons, etc for recovering? > > Any advice will be appreciated. > > Thanks, > http://www.matronics.com/Navigator?Kolb-List > _==================== > http://forums.matronics.com > http://wiki.matro======================= > <http://wiki.matronics.com/> > > ________________________________________________________________________________
Date: Apr 10, 2017
Subject: covering supplier?
Anyone using a covering supplier that's better (cheaper, better service, etc) than A/C Spruce? ________________________________________________________________________________
Date: Apr 11, 2017
Subject: Re: covering supplier?
Charlie Use the covering that A/C Spruce refers to as peel ply. Joe ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Monday, April 10, 2017 7:45:01 PM Subject: Kolb-List: covering supplier? Anyone using a covering supplier that's better (cheaper, better service, etc) than A/C Spruce? ________________________________________________________________________________
Date: Apr 10, 2017
Yep..Peel ply... around 5 bucks a yard...1.7 or 2.6. Herb On 04/10/2017 06:45 PM, Charlie England wrote: > Anyone using a covering supplier that's better (cheaper, better > service, etc) than A/C Spruce? ________________________________________________________________________________
Date: Apr 10, 2017
Haven't checked in a while..but think A/C spruce can ship Poly Fiber chemicals with no haz material charge...? Herb On 04/10/2017 09:10 PM, Hoppy wrote: > > Yep..Peel ply... around 5 bucks a yard...1.7 or 2.6. Herb > > > On 04/10/2017 06:45 PM, Charlie England wrote: >> Anyone using a covering supplier that's better (cheaper, better >> service, etc) than A/C Spruce? > > ________________________________________________________________________________
Date: Apr 10, 2017
Thanks; I've heard of using regular polyester fabric. But at roughly a $3 price delta, it's only a $40 spread for all the fabric I'll need. On 4/10/2017 9:10 PM, Hoppy wrote: > > Yep..Peel ply... around 5 bucks a yard...1.7 or 2.6. Herb > > > On 04/10/2017 06:45 PM, Charlie England wrote: >> Anyone using a covering supplier that's better (cheaper, better >> service, etc) than A/C Spruce? > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 10, 2017
Sounds like Spruce is the go-to place, then. My fabric guy (yeah, I've got a fabric guy) is willing to try Stewart System glue, so I think we'll give that a shot. That plus Wienerdog Aero's Latex painting technique, & we should be good to go. :-) Charlie On 4/10/2017 9:15 PM, Hoppy wrote: > > Haven't checked in a while..but think A/C spruce can ship Poly Fiber > chemicals with no haz material charge...? Herb > > > On 04/10/2017 09:10 PM, Hoppy wrote: >> >> Yep..Peel ply... around 5 bucks a yard...1.7 or 2.6. Herb >> >> >> On 04/10/2017 06:45 PM, Charlie England wrote: >>> Anyone using a covering supplier that's better (cheaper, better >>> service, etc) than A/C Spruce? >> --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 11, 2017
Do a little research, the latex may be heavier than some other systems. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Mon, 4/10/17, Charlie England wrote: Subject: Re: Kolb-List: covering supplier? To: kolb-list(at)matronics.com Date: Monday, April 10, 2017, 8:53 PM England Sounds like Spruce is the go-to place, then. My fabric guy (yeah, I've got a fabric guy) is willing to try Stewart System glue, so I think we'll give that a shot. That plus Wienerdog Aero's Latex painting technique, & we should be good to go. :-) Charlie On 4/10/2017 9:15 PM, Hoppy wrote: > --> Kolb-List message posted by: Hoppy > > Haven't checked in a while..but think A/C spruce can ship Poly Fiber > chemicals with no haz material charge...? Herb > > > On 04/10/2017 09:10 PM, Hoppy wrote: >> --> Kolb-List message posted by: Hoppy >> >> Yep..Peel ply... around 5 bucks a yard...1.7 or 2.6. Herb >> >> >> On 04/10/2017 06:45 PM, Charlie England wrote: >>> Anyone using a covering supplier that's better (cheaper, better >>> service, etc) than A/C Spruce? >> --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 11, 2017
This is the reference I've used; he supplies links to other research that he did. http://wienerdogaero.com/Latex.php I'm not paranoid about occasional use of most chemicals, but something cleaner/safer will work just as well, and save a bit of money at the same time, I'll take it. But don't expect mine to look like the results he gets. :-) Charlie On Tue, Apr 11, 2017 at 12:20 AM, Bill Berle wrote: > > Do a little research, the latex may be heavier than some other systems. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and > for-profit entities > > -------------------------------------------- > On Mon, 4/10/17, Charlie England wrote: > > Subject: Re: Kolb-List: covering supplier? > To: kolb-list(at)matronics.com > Date: Monday, April 10, 2017, 8:53 PM > > England > > Sounds like Spruce is the go-to place, > then. > > My fabric guy (yeah, I've got a fabric > guy) is willing to try Stewart > System glue, so I think we'll give that > a shot. That plus Wienerdog > Aero's Latex painting technique, & > we should be good to go. :-) > > Charlie > > On 4/10/2017 9:15 PM, Hoppy wrote: > > --> Kolb-List message posted > by: Hoppy > > > > Haven't checked in a while..but > think A/C spruce can ship Poly Fiber > > chemicals with no haz material > charge...? Herb > > > > > > On 04/10/2017 09:10 PM, Hoppy > wrote: > >> --> Kolb-List message > posted by: Hoppy > >> > >> Yep..Peel ply... around 5 > bucks a yard...1.7 or 2.6. Herb > >> > >> > >> On 04/10/2017 06:45 PM, > Charlie England wrote: > >>> Anyone using a covering > supplier that's better (cheaper, better > >>> service, etc) than A/C > Spruce? > >> > > ________________________________________________________________________________
Date: Apr 11, 2017
Charlie Another tip, buy Fastbond NF Green on Amazon, it's the same adhesive as Stewart at half the price Joe ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Monday, April 10, 2017 11:53:23 PM Subject: Re: Kolb-List: covering supplier? Sounds like Spruce is the go-to place, then. My fabric guy (yeah, I've got a fabric guy) is willing to try Stewart System glue, so I think we'll give that a shot. That plus Wienerdog Aero's Latex painting technique, & we should be good to go. :-) Charlie On 4/10/2017 9:15 PM, Hoppy wrote: > > Haven't checked in a while..but think A/C spruce can ship Poly Fiber > chemicals with no haz material charge...? Herb > > > On 04/10/2017 09:10 PM, Hoppy wrote: >> >> Yep..Peel ply... around 5 bucks a yard...1.7 or 2.6. Herb >> >> >> On 04/10/2017 06:45 PM, Charlie England wrote: >>> Anyone using a covering supplier that's better (cheaper, better >>> service, etc) than A/C Spruce? >> --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 11, 2017
Joe Wondering if Fastbond would work with the Acetone,MEK based Poly Fiber products? I still have a quart of Poly Tac...but might use it for my next project...Herb On 04/11/2017 07:27 AM, mojavjoe(at)comcast.net wrote: > Charlie > > Another tip, buy Fastbond NF Green on Amazon, it's the same adhesive > as Stewart at half the price > > Joe > > ------------------------------------------------------------------------ > *From: *"Charlie England" <ceengland7(at)gmail.com> > *To: *"kolb-list" > *Sent: *Monday, April 10, 2017 11:53:23 PM > *Subject: *Re: Kolb-List: covering supplier? > > > Sounds like Spruce is the go-to place, then. > > My fabric guy (yeah, I've got a fabric guy) is willing to try Stewart > System glue, so I think we'll give that a shot. That plus Wienerdog > Aero's Latex painting technique, & we should be good to go. :-) > > Charlie > > On 4/10/2017 9:15 PM, Hoppy wrote: > > > > Haven't checked in a while..but think A/C spruce can ship Poly Fiber > > chemicals with no haz material charge...? Herb > > > > > > On 04/10/2017 09:10 PM, Hoppy wrote: > >> > >> Yep..Peel ply... around 5 bucks a yard...1.7 or 2.6. Herb > >> > >> > >> On 04/10/2017 06:45 PM, Charlie England wrote: > >>> Anyone using a covering supplier that's better (cheaper, better > >>> service, etc) than A/C Spruce? > >> > > > --- > This email has been checked for viruses by Avast antivirbsp; > -Matt Dralle, List Adm======== > > ________________________________________________________________________________
Date: Apr 11, 2017
On Tue, 4/11/17, wrote: "Fastbond NF Green -- half the price" YEAH, baby :) ________________________________________________________________________________
Date: Apr 11, 2017
What about this price... :) https://www.evroberts.com/3m-24/fastbond-30-nf-green-1120/ Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Tue, 4/11/17, wrote: Subject: Re: Kolb-List: covering supplier? To: "kolb-list" Date: Tuesday, April 11, 2017, 5:27 AM Charlie Another tip,buy Fastbond NF Green on Amazon, it's the same adhesive as Stewartat half the price Joe From: "Charlie England" To: "kolb-list" Sent: Monday, April 10, 2017 11:53:23 PM Subject: Re: Kolb-List: covering supplier? Sounds like Spruce is the go-to place, then. My fabric guy (yeah, I've got a fabric guy) is willing to try Stewart System glue, so I think we'll give that a shot. That plus Wienerdog Aero's Latex painting technique, & we should be good to go. :-) Charlie On 4/10/2017 9:15 PM, Hoppy wrote: > > Haven't checked in a while..but think A/C spruce can ship Poly Fiber > chemicals with no haz material charge...? Herb > > > On 04/10/2017 09:10 PM, Hoppy wrote: >> >> Yep..Peel ply... around 5 bucks a yard...1.7 or 2.6. Herb >> >> >> On 04/10/2017 06:45 PM, Charlie England wrote: >>> Anyone using a covering supplier that's better (cheaper, better >>> service, etc) than A/C Spruce? >> --- This email has been checked for viruses by Avast antivirbsp; -Matt Dralle, List Adm======== ________________________________________________________________________________
Date: Apr 11, 2017
Guess we need to get together on a quantity buy...:-) I will take a quart with free shipping....:-) Herb On 04/11/2017 09:23 AM, Bill Berle wrote: > > What about this price... :) > > https://www.evroberts.com/3m-24/fastbond-30-nf-green-1120/ > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Tue, 4/11/17, wrote: > > Subject: Re: Kolb-List: covering supplier? > To: "kolb-list" > Date: Tuesday, April 11, 2017, 5:27 AM > > Charlie > > Another tip, buy Fastbond NF Green on > Amazon, it's the same adhesive as Stewart at half > the price > > Joe > > From: > "Charlie England" > > To: "kolb-list" > > Sent: Monday, April 10, 2017 11:53:23 PM > Subject: Re: Kolb-List: covering supplier? > > > > Sounds like Spruce is the go-to place, then. > > My fabric guy (yeah, I've got a fabric guy) is > willing to try Stewart > System glue, so I think we'll give that a shot. That > plus Wienerdog > Aero's Latex painting technique, & we should be good > to go. :-) > > Charlie > > On 4/10/2017 9:15 PM, Hoppy wrote: > > > > > Haven't checked in a while..but think A/C spruce > can ship Poly Fiber > > chemicals with no haz material charge...? Herb > > > > > > On 04/10/2017 09:10 PM, Hoppy wrote: > > >> > >> Yep..Peel ply... around 5 bucks a yard...1.7 or > 2.6. Herb > >> > >> > >> On 04/10/2017 06:45 PM, Charlie England wrote: > >>> Anyone using a covering supplier that's > better (cheaper, better > >>> service, etc) than A/C Spruce? > >> > > > --- > This email has been checked for viruses by Avast antivirbsp; > -Matt > Dralle, List Adm======== > > > > > > > ________________________________________________________________________________
Date: Apr 11, 2017
Hey Herb, Looks like I might need to rethink that. Are you talking about this: http://www.aircraftspruce.com/pages/cs/fabric/peelply3.php vs this: http://www.aircraftspruce.com/pages/cs/fabric/polyfiberuncertified.php ? The peel ply doesn't have any thread count or strength specs on the Spruce site, so I can't directly compare. Measurements indicate that I can half-wrap the wing with a 5' width of the peel ply, so the extra foot of Polyfiber would just get cut away, anyway. Thanks, Charlie On Mon, Apr 10, 2017 at 10:17 PM, Charlie England wrote: > Thanks; I've heard of using regular polyester fabric. But at roughly a $3 > price delta, it's only a $40 spread for all the fabric I'll need. > > On 4/10/2017 9:10 PM, Hoppy wrote: > >> >> Yep..Peel ply... around 5 bucks a yard...1.7 or 2.6. Herb >> >> >> On 04/10/2017 06:45 PM, Charlie England wrote: >> >>> Anyone using a covering supplier that's better (cheaper, better service, >>> etc) than A/C Spruce? >>> >> >> > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: Apr 11, 2017
the heavier fabric is much easier to work with imho.. 2.7 peel ply...just need to be careful tautening the fabric on the wings.. Interestingly...the older Challengers had no bottom rib runners...and the fabric just layed across the front and real spar.. root rib to wing tip!! a real flap in the breeze...I can imagine hitting a duck and having a real problem...not so much with a Kolb...Herb On 04/11/2017 11:57 AM, Charlie England wrote: > Hey Herb, > > Looks like I might need to rethink that. Are you talking about this: > http://www.aircraftspruce.com/pages/cs/fabric/peelply3.php > vs this: > http://www.aircraftspruce.com/pages/cs/fabric/polyfiberuncertified.php > > ? > > The peel ply doesn't have any thread count or strength specs on the > Spruce site, so I can't directly compare. Measurements indicate that I > can half-wrap the wing with a 5' width of the peel ply, so the extra > foot of Polyfiber would just get cut away, anyway. > > Thanks, > > Charlie > > > On Mon, Apr 10, 2017 at 10:17 PM, Charlie England > > wrote: > > Thanks; I've heard of using regular polyester fabric. But at > roughly a $3 price delta, it's only a $40 spread for all the > fabric I'll need. > > On 4/10/2017 9:10 PM, Hoppy wrote: > > > > > Yep..Peel ply... around 5 bucks a yard...1.7 or 2.6. Herb > > > On 04/10/2017 06:45 PM, Charlie England wrote: > > Anyone using a covering supplier that's better (cheaper, > better service, etc) than A/C Spruce? > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: Apr 11, 2017
Bill I 'm reusing a pair of wings. I've already recovered one wing using the Stewart system and painted it along the lines of Weiner Dog, except I'm painting art scenes on the wings so more paint than normal. Weighed recovered wing against wing with old poly fiber. The new wing only weighed 3 oz more Joe ----- Original Message ----- From: "Bill Berle" <victorbravo(at)sbcglobal.net> Sent: Tuesday, April 11, 2017 10:23:33 AM Subject: Re: Kolb-List: covering supplier? What about this price... :) https://www.evroberts.com/3m-24/fastbond-30-nf-green-1120/ Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Tue, 4/11/17, wrote: Subject: Re: Kolb-List: covering supplier? Date: Tuesday, April 11, 2017, 5:27 AM Charlie Another tip, buy Fastbond NF Green on Amazon, it's the same adhesive as Stewart at half the price Joe From: "Charlie England" Sent: Monday, April 10, 2017 11:53:23 PM Subject: Re: Kolb-List: covering supplier? Sounds like Spruce is the go-to place, then. My fabric guy (yeah, I've got a fabric guy) is willing to try Stewart System glue, so I think we'll give that a shot. That plus Wienerdog Aero's Latex painting technique, & we should be good to go. :-) Charlie On 4/10/2017 9:15 PM, Hoppy wrote: > > Haven't checked in a while..but think A/C spruce can ship Poly Fiber > chemicals with no haz material charge...? Herb > > > On 04/10/2017 09:10 PM, Hoppy wrote: >> >> Yep..Peel ply... around 5 bucks a yard...1.7 or 2.6. Herb >> >> >> On 04/10/2017 06:45 PM, Charlie England wrote: >>> Anyone using a covering supplier that's better (cheaper, better >>> service, etc) than A/C Spruce? >> --- This email has been checked for viruses by Avast antivirbsp; -Matt Dralle, List Adm========= ________________________________________________________________________________
Date: Apr 11, 2017
Kolbers: I have never been one to mix and match when it came to covering an aircraft. Always used the Stitts/Polyfiber process. I never forget the unforgiving environment us aviators play. Always sad when I think of Steve Whitman and his wife dying because of a covering mix and match mistake. Realize it cost more to use the Polyfiber process, but am also comfortable knowing it'll be there for a long time. My right wing and most of my tail section is 26 year old Stitts process. Left wing is 16 years old. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Apr 11, 2017
I asked Malcom about this at OSH a few years back. He said the weight is almost identical. He can sure put a beautiful finish on fabric! This is the perfect system for those who: Want to work without the "stink" Save money. Have more time than I do.... Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Bill Berle Sent: Tuesday, April 11, 2017 12:21 AM Subject: Re: Kolb-List: covering supplier? Do a little research, the latex may be heavier than some other systems. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Mon, 4/10/17, Charlie England wrote: Subject: Re: Kolb-List: covering supplier? To: kolb-list(at)matronics.com Date: Monday, April 10, 2017, 8:53 PM Sounds like Spruce is the go-to place, then. My fabric guy (yeah, I've got a fabric guy) is willing to try Stewart System glue, so I think we'll give that a shot. That plus Wienerdog Aero's Latex painting technique, & we should be good to go. :-) Charlie On 4/10/2017 9:15 PM, Hoppy wrote: > --> Kolb-List message posted by: Hoppy > > Haven't checked in a while..but think A/C spruce can ship Poly Fiber > chemicals with no haz material charge...? Herb > > > On 04/10/2017 09:10 PM, Hoppy wrote: >> --> Kolb-List message posted by: Hoppy >> >> Yep..Peel ply... around 5 bucks a yard...1.7 or 2.6. Herb >> >> >> On 04/10/2017 06:45 PM, Charlie England wrote: >>> Anyone using a covering supplier that's better (cheaper, better >>> service, etc) than A/C Spruce? >> --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 11, 2017
I appreciate the caution, and I'm not that prone to stray where no one's been before, either. I did order Poly brand cloth (polyester), and the Stewart System glue.Both the latex finishing technique, and the Stewart adhesive have been around for a long time, so I'm comfortable with those decisions. The Steve Whitman story, as I remember it, was that he switched from the old 'dope' and course weave fabric to the newer process. The story I heard was that the dope & course weave allowed you to position the fabric and then just apply dope to the outside, and it soaked through to the ribs. But the new, finer weave fabric & adhesive required applying the adhesive directly to the ribs, positioning the fabric, and then applying additional adhesive over the fabric, because the weave was too tight for the adhesive to easily soak through. Again, as I remember it, he mixed *techniques*; not the actual chemicals. By only applying the adhesive on the outside, only a minimal amount made it through to the ribs. Those with better memories, feel free to correct me if I'm mis-remembering. Charlie On Tue, Apr 11, 2017 at 2:43 PM, John Hauck wrote: > > > Kolbers: > > > I have never been one to mix and match when it came to covering an > aircraft. Always used the Stitts/Polyfiber process. > > > I never forget the unforgiving environment us aviators play. > > > Always sad when I think of Steve Whitman and his wife dying because of a > covering mix and match mistake. > > > Realize it cost more to use the Polyfiber process, but am also comfortable > knowing it'll be there for a long time. My right wing and most of my tail > section is 26 year old Stitts process. Left wing is 16 years old. > > > john h > > mkIII > > Titus, Alabama > ________________________________________________________________________________
Date: Apr 11, 2017
Date: Apr 12, 2017
Hey, Guys, Just to add my 2 cents--I used the Stewart system on my second plane, after using Polyfiber on my first. It was a joy not dealing with MEK. The glue worked great, just be sure to wipe off the excess as you go. Two words of caution: 1-the filler/ uv block coating absorbs moisture and the finish colors "hate" water. The "how to" videos from the company on YouTube suggest using alcohol on the surface to get rid of finger prints before applying the color coats. I did so and when I started spraying color, it splotched and ran like I was spraying oil on water. I thought there must still be oil on the fabric, so I cleaned with alcohol Even more lavishly this time. After allowing to dry(I thought). Sprayed and same result. Called company and they told me that the surface was absorbing the water in the alcohol. Evidently the Eco fill (uv block and fabric filler) is hydrophilic, and the color coats hydrophobic! I had to use alcohol sparingly and dry all surfaces with time in the sun(when available and with heaters to stop the problem. 2-- make sure the paint is mixed to the exact viscosity and make sure your compressed can deliver continuous sufficient pressure. I had to really work not to get orange peel effect. My paint job looks great from 10 or 15' but up close there are areas of silky smooth finish and areas of slight orange peel. Good luck, Lanny Lambdin. P.S. On YouTube is a video- search for: Miss Sunshine Walkaround, to see the results on my plane. Sent from my iPad > On Apr 11, 2017, at 4:33 PM, Stuart Harner wrote: > > > I asked Malcom about this at OSH a few years back. He said the weight is almost identical. He can sure put a beautiful finish on fabric! > > This is the perfect system for those who: > Want to work without the "stink" > Save money. > Have more time than I do.... > > Stuart > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Bill Berle > Sent: Tuesday, April 11, 2017 12:21 AM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: covering supplier? > > > Do a little research, the latex may be heavier than some other systems. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Mon, 4/10/17, Charlie England wrote: > > Subject: Re: Kolb-List: covering supplier? > To: kolb-list(at)matronics.com > Date: Monday, April 10, 2017, 8:53 PM > > > Sounds like Spruce is the go-to place, > then. > > My fabric guy (yeah, I've got a fabric > guy) is willing to try Stewart > System glue, so I think we'll give that a shot. That plus Wienerdog Aero's Latex painting technique, & we should be good to go. :-) > > Charlie > >> On 4/10/2017 9:15 PM, Hoppy wrote: >> --> Kolb-List message posted > by: Hoppy >> >> Haven't checked in a while..but > think A/C spruce can ship Poly Fiber >> chemicals with no haz material > charge...? Herb >> >> >> On 04/10/2017 09:10 PM, Hoppy > wrote: >>> --> Kolb-List message > posted by: Hoppy >>> >>> Yep..Peel ply... around 5 > bucks a yard...1.7 or 2.6. Herb >>> >>> >>> On 04/10/2017 06:45 PM, > Charlie England wrote: >>>> Anyone using a covering > supplier that's better (cheaper, better >>> service, etc) than A/C Spruce? >>> > > > --- > This email has been checked for viruses > by Avast antivirus software. > https://www.avast.com/antivirus > > The Kolb-List Email Forum - > Navigator to browse > List Un/Subscription, > 7-Day Browse, Chat, FAQ, > - MATRONICS WEB FORUMS - > via the Web Forums! > - NEW MATRONICS LIST WIKI - > Email List Wiki! > - List Contribution Web Site - > support! > > -Matt Dralle, List Admin. > > > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 12, 2017
Here are my experiences with Latex which include a re-paint over an auto finish, re-cover of a fuselage and painting a stits type covering. The re-paint was on a fuselage which had some cracking and chipping of an older auto finish from firewall back past trailing edge of a Rans S7. I sanded and filled the crack/chip areas with poly filla (Yup) then had the hardware store do a colour match of some exterior latex paint. Actually these days it is called water based acrylic. Years ago you couldn't sand latex due to its rubbery nature. Not so these days. The result looked great with sort of a low gloss dope type finish. I have kept in touch with the owner of the plane because even I was skeptical of how long it would last. It has been many years now and he is still happy. In addition to acrylic paints, you should also keep clear water base urethane in mind. I recovered my homebuilt 170 fuselage (steel tube/fabric) and used clear urethane as first fill coat on the fabric and then put tapes on with it. It was great to work with. Also used the green hardware store water based contact cement for glue. Then sprayed on gloss acylic latex for finish coats. A buddy who is a long time dope and fabric guy was amazed at how great the tape seams and fill looked. At that time the glossiest acrylic was about as dull as a dope finish but with a lot fewer coats. Next I've done a complete S7 with acrylic using a cheap primer fill coat followed by gloss colour coats. High gloss is not an attribute of acrylic unless you want to do all that buffing but with a product from Home Hardware called Rust coat the finish is the best I've seen. Yes if you need a mirror finish be prepared to work but for a great looking dope or better than polytone, little sanding is required. For years I followed the suggestion from one site to use an airless sprayer. This was mistake, they put out way too much paint even with the fine nozzles. An inexpensive $50 HVLP gun is just fine and with way less likelihood of runs. Peter Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468328#468328 ________________________________________________________________________________
Date: Apr 12, 2017
Subject: Polyester cloth
To badly misquote Gertrude Stein, polyester is polyester is polyester. If you have the same weight fabric regardless of trade names (like Dacron for instance) and it's 100% polyester, its physical characteristics are going to be the same. Where you run into trouble is if any additives, called sizings, are put on the fabric. The first aircraft I covered was an Easyriser back in the mid seventies. Nitrate and butyrate dope over polyester dress sheathing. Worked great but I had to recover one wing and the kit didn't have any spare fabric so I went to the nearest fabric store with a sample. Which is where I learned about dress sheathing. I went home, covered the wing and finished it and moved on. Later I told a buddy this story when he was in need of fabric for his Catto wing project. He went to a different fabric store and the results were terrible. Which is where I learned about sizings. Seems that some manufacturers add a sizing containing silicone. Nothing sticks to it, which is great for slips and petty coats but not so much if you want to add further coatings on top of it. The same applies if you use it for peel ply. The silicone migrates to the composite and you're done for. That's the caveat you should beware of if you go shopping for polyester. Spruce and Wicks have peel ply that is sizing free, the same as Polyfiber, it just doesn't have the stamp. Rick Girard -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Apr 12, 2017
I may have been given incorrect info many years ago. Never did the research on it. I was informed the difference between polyester Dacron for aircraft and for nurses' uniforms was: -Fabric for aircraft, both certified and uncertified was not preshrunk. -Fabric for uniforms/clothing was preshrunk. I was also told that a lubricate was applied to the threads of polyester Dacron during the weaving process to prevent the threads from burning. Threads are extremely small and weaving is extremely tight. I remember the problems I encountered with Stitts or Polyfiber HS90X. Very light weight, but loaded with lubricant. Unknown to me I started shooting dope and have never seen so many fish eyes. The fabric folks told me I needed to scrub the fabric with MEK prior to painting. This lightweight fabric was difficult to work with and vulnerable to punctures during covering. After that one time with HS90X I went back to D-103. The difference in weight was negligible but far greater durability. I can deal with a little extra weight, but I need durability. ;-) john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: Wednesday, April 12, 2017 8:55 AM Subject: Kolb-List: Polyester cloth To badly misquote Gertrude Stein, polyester is polyester is polyester. If you have the same weight fabric regardless of trade names (like Dacron for instance) and it's 100% polyester, its physical characteristics are going to be the same. Where you run into trouble is if any additives, called sizings, are put on the fabric. The first aircraft I covered was an Easyriser back in the mid seventies. Nitrate and butyrate dope over polyester dress sheathing. Worked great but I had to recover one wing and the kit didn't have any spare fabric so I went to the nearest fabric store with a sample. Which is where I learned about dress sheathing. I went home, covered the wing and finished it and moved on. Later I told a buddy this story when he was in need of fabric for his Catto wing project. He went to a different fabric store and the results were terrible. Which is where I learned about sizings. Seems that some manufacturers add a sizing containing silicone. Nothing sticks to it, which is great for slips and petty coats but not so much if you want to add further coatings on top of it. The same applies if you use it for peel ply. The silicone migrates to the composite and you're done for. That's the caveat you should beware of if you go shopping for polyester. Spruce and Wicks have peel ply that is sizing free, the same as Polyfiber, it just doesn't have the stamp. Rick Girard -- =9CBlessed are the cracked, for they shall let in the light.=9D <http://www.goodreads.com/author/show/43244.Groucho_Marx> Groucho Marx ________________________________________________________________________________
Date: Apr 12, 2017
Thanks, Peter. For you guys who've used latex, did you stick with the Glidden Gripper grey primer as shown on the Wienerdog Aero site, or something else? I can get the white primer (and other brands) locally, but will have to order the grey. No polishing for me; I'll be happy if the paint stays on & prevents UV damage. Thanks, Charlie On 4/12/2017 7:57 AM, phcpilot wrote: > > Here are my experiences with Latex which include a re-paint over an auto finish, re-cover of a fuselage and painting a stits type covering. > > The re-paint was on a fuselage which had some cracking and chipping of an older auto finish from firewall back past trailing edge of a Rans S7. I sanded and filled the crack/chip areas with poly filla (Yup) then had the hardware store do a colour match of some exterior latex paint. Actually these days it is called water based acrylic. Years ago you couldn't sand latex due to its rubbery nature. Not so these days. > The result looked great with sort of a low gloss dope type finish. I have kept in touch with the owner of the plane because even I was skeptical of how long it would last. It has been many years now and he is still happy. > > In addition to acrylic paints, you should also keep clear water base urethane in mind. I recovered my homebuilt 170 fuselage (steel tube/fabric) and used clear urethane as first fill coat on the fabric and then put tapes on with it. It was great to work with. Also used the green hardware store water based contact cement for glue. > > Then sprayed on gloss acylic latex for finish coats. A buddy who is a long time dope and fabric guy was amazed at how great the tape seams and fill looked. At that time the glossiest acrylic was about as dull as a dope finish but with a lot fewer coats. > > Next I've done a complete S7 with acrylic using a cheap primer fill coat followed by gloss colour coats. High gloss is not an attribute of acrylic unless you want to do all that buffing but with a product from Home Hardware called Rust coat the finish is the best I've seen. Yes if you need a mirror finish be prepared to work but for a great looking dope or better than polytone, little sanding is required. > > For years I followed the suggestion from one site to use an airless sprayer. This was mistake, they put out way too much paint even with the fine nozzles. An inexpensive $50 HVLP gun is just fine and with way less likelihood of runs. > Peter > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 12, 2017
Hi Joe, Has anyone verified that it's actually the same stuff? It might look, smell, feel, even taste the same, but the TDS for Fastbond reads like plain old contact cement. No mention of using heat to activate it, as described by Stewart. It wouldn't surprise me if it is the same stuff, but I'd like to *know* it's the same stuff. Thanks, Charlie On Tue, Apr 11, 2017 at 7:27 AM, wrote: > Charlie > > Another tip, buy Fastbond NF Green on Amazon, it's the same adhesive as > Stewart at half the price > > Joe > > ------------------------------ > *From: *"Charlie England" <ceengland7(at)gmail.com> > *To: *"kolb-list" > *Sent: *Monday, April 10, 2017 11:53:23 PM > *Subject: *Re: Kolb-List: covering supplier? > > > Sounds like Spruce is the go-to place, then. > > My fabric guy (yeah, I've got a fabric guy) is willing to try Stewart > System glue, so I think we'll give that a shot. That plus Wienerdog > Aero's Latex painting technique, & we should be good to go. :-) > > Charlie > > On 4/10/2017 9:15 PM, Hoppy wrote: > > > > Haven't checked in a while..but think A/C spruce can ship Poly Fiber > > chemicals with no haz material charge...? Herb > > > > > > On 04/10/2017 09:10 PM, Hoppy wrote: > >> > >> Yep..Peel ply... around 5 bucks a yard...1.7 or 2.6. Herb > >> > >> > >> On 04/10/2017 06:45 PM, Charlie England wrote: > >>> Anyone using a covering supplier that's better (cheaper, better > >>> service, etc) than A/C Spruce? > >> > > > --- > This email has been checked for viruses by Avast antivirbsp; > -Matt Dralle, List Adm======== > > ________________________________________________________________________________
Date: Apr 12, 2017
On Mon, Apr 10, 2017 at 8:15 PM, wrote: > Charlie > > Use the covering that A/C Spruce refers to as peel ply. > > Joe > I almost ordered it, but it's only 5' wide & I wasn't sure if that would have enough 'wrap' to do one side of a wing. If I do this sort of thing again, I'll certainly give it a try. Thanks, Charlie ________________________________________________________________________________
Subject: Re: Polyester cloth
Date: Apr 12, 2017
Thanks Rick - good memories. I also recovered an Easy Riser with polyester dress sheath, guess I got lucky. I was so ignorant I didn't know you were supposed to use heat to shrink it; I treated it like a big model airplane and used enough clothespins, small weights and clamps that it was basically pretty tight once the glue dried. Then I brushed a couple coats of nitrate dope on it and it shrank up just like brushing Aero-Gloss on silk. Bought it used from Glen Rinck (who is on the FB U/L list) but since he was heavier than I was, if I hit a thermal under power and the seat unweighted, it would pitch over. Pretty scary. Called Chuck Slusarczyk and told him what I was doing and he gave me all the proper angles and measurements to rig the engine position/thrust line so it wouldn't kill me. From then on it flew just as stable as you could ask for. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468350#468350 ________________________________________________________________________________
Date: Apr 12, 2017
I really miss Chuck Slusarczyk. Never got to fly with him, and I wasn't around the scene in the early UL days, but I met him through the old "usenet" internet forums, and then met him in person once or twice. Great guy, big heart. A model airplane builder and free flighter to boot :) Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Wed, 4/12/17, Richard Pike wrote: Subject: Kolb-List: Re: Polyester cloth To: kolb-list(at)matronics.com Date: Wednesday, April 12, 2017, 2:33 PM Pike" Thanks Rick - good memories. I also recovered an Easy Riser with polyester dress sheath, guess I got lucky. I was so ignorant I didn't know you were supposed to use heat to shrink it; I treated it like a big model airplane and used enough clothespins, small weights and clamps that it was basically pretty tight once the glue dried. Then I brushed a couple coats of nitrate dope on it and it shrank up just like brushing Aero-Gloss on silk. Bought it used from Glen Rinck (who is on the FB U/L list) but since he was heavier than I was, if I hit a thermal under power and the seat unweighted, it would pitch over. Pretty scary. Called Chuck Slusarczyk and told him what I was doing and he gave me all the proper angles and measurements to rig the engine position/thrust line so it wouldn't kill me. From then on it flew just as stable as you could ask for. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468350#468350 The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 12, 2017
Subject: ANOTHER Wheel and Tire Mystery
Well Kolbers, it's like this... My Firestar has Azusa Tri-Star 6 inch aluminum wheels on it. I want to keep the Azusa wheels because I can change a tire out in the field without having to have a big hydraulic tire changing machine (and Mariachi music in the background). I just bought a beautiful set of Tracy O'Brien hydraulic brakes for it. I want to use the Desser Tire Co.'s new 21 inch 8.00 x 6 "oversize tundra" tires. With the long gear legs and the big tires, I'll need an oxygen bottle to climb into the seat :) Boyd was kind enough to relate a story to me, about these tires not seating correctly on the wheel. Apparently he had a set of these tires that he could spin by hand on the wheel. That ain't right in my book either. So I called Desser tire Co. I asked the guy whether these tires should spin on the wheel. He said yes they do spin until you put air in them, and then you can't spin them. But this does NOT match my experience with putting wheels and tires together on my Cessna 172. Then I said I was putting these tires on Azusa wheels. He called me back 30 minutes later, said he went and checked with someone in the engineering department, and that yes they did have problems with Azusa wheels because they were too "flimsy". I asked what that had to do with their tire fitting on a 6 inch wheel. He said that the Azusa wheels were "not built to spec" and that's why they had problems. Put these tires on Matco wheels and there's no problem. That still didn't sound completely legit to me. Thousands of ultralights and light airplanes have flown on Azusa wheels for many years. And other "6 inch" tires seem to work just fine. So now I'm confused (again???) as to whether the Desser tires are the problem or the Azusa wheels are the problem. Question 1 - Have other Kolbers with Azusa wheels had problems with the wheels not "seating" on the tires, and hav ing the tires spin under braking? Question 2 - Has anyone had problems with the Desser 21-8.00 x 6 oversize tundra tires on any other TWO-PIECE wheels? Question 3 - Is there a known, good, light weight, off-road alternative tire to the Desser 21 inch tire for someone who wants large diameter tires? I have read on the Kolb list months ago about how SOME of the Carlisle tires are way out of balance, and how some golf cart tires work well and some don't, etc. After the money I invested in the O'Brien brakes,a nd the money I would have to spend to get different wheels and axles... I would PREFER to keep the Azusa wheels I have. With ALL due respect to those selling or flying with one piece wheels I am NOT interested in one piece "spun" wheels. There are no tire shops at the places where I plan to land my Kolb :) Anyone with experience or knowledge on this particular problem using Azusa wheels , I'm all ears! Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Wed, 4/12/17, Richard Pike wrote: Subject: Kolb-List: Re: Polyester cloth To: kolb-list(at)matronics.com Date: Wednesday, April 12, 2017, 2:33 PM Pike" Thanks Rick - good memories. I also recovered an Easy Riser with polyester dress sheath, guess I got lucky. I was so ignorant I didn't know you were supposed to use heat to shrink it; I treated it like a big model airplane and used enough clothespins, small weights and clamps that it was basically pretty tight once the glue dried. Then I brushed a couple coats of nitrate dope on it and it shrank up just like brushing Aero-Gloss on silk. Bought it used from Glen Rinck (who is on the FB U/L list) but since he was heavier than I was, if I hit a thermal under power and the seat unweighted, it would pitch over. Pretty scary. Called Chuck Slusarczyk and told him what I was doing and he gave me all the proper angles and measurements to rig the engine position/thrust line so it wouldn't kill me. From then on it flew just as stable as you could ask for. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468350#468350 The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Re: ANOTHER Wheel and Tire Mystery
Date: Apr 12, 2017
Hi Bill, I can't directly address your specific components, but in 'off-roading' (both automotive and aircraft), it's fairly common to run screws through the rims into the beads of the tires. When running very low pressures, it is possible to spin the tire on the rim, or even unseat the bead, if there's significant side load on the tire. I've even done it in a golf cart, when I got lazy & let the tire pressure get too low. Charlie On 4/12/2017 6:25 PM, Bill Berle wrote: > > Well Kolbers, it's like this... > > My Firestar has Azusa Tri-Star 6 inch aluminum wheels on it. I want to keep the Azusa wheels because I can change a tire out in the field without having to have a big hydraulic tire changing machine (and Mariachi music in the background). > > I just bought a beautiful set of Tracy O'Brien hydraulic brakes for it. I want to use the Desser Tire Co.'s new 21 inch 8.00 x 6 "oversize tundra" tires. With the long gear legs and the big tires, I'll need an oxygen bottle to climb into the seat :) > > Boyd was kind enough to relate a story to me, about these tires not seating correctly on the wheel. Apparently he had a set of these tires that he could spin by hand on the wheel. That ain't right in my book either. > > So I called Desser tire Co. I asked the guy whether these tires should spin on the wheel. He said yes they do spin until you put air in them, and then you can't spin them. But this does NOT match my experience with putting wheels and tires together on my Cessna 172. Then I said I was putting these tires on Azusa wheels. He called me back 30 minutes later, said he went and checked with someone in the engineering department, and that yes they did have problems with Azusa wheels because they were too "flimsy". I asked what that had to do with their tire fitting on a 6 inch wheel. He said that the Azusa wheels were "not built to spec" and that's why they had problems. Put these tires on Matco wheels and there's no problem. > > That still didn't sound completely legit to me. Thousands of ultralights and light airplanes have flown on Azusa wheels for many years. And other "6 inch" tires seem to work just fine. > > So now I'm confused (again???) as to whether the Desser tires are the problem or the Azusa wheels are the problem. > > Question 1 - Have other Kolbers with Azusa wheels had problems with the wheels not "seating" on the tires, and hav ing the tires spin under braking? > > Question 2 - Has anyone had problems with the Desser 21-8.00 x 6 oversize tundra tires on any other TWO-PIECE wheels? > > Question 3 - Is there a known, good, light weight, off-road alternative tire to the Desser 21 inch tire for someone who wants large diameter tires? I have read on the Kolb list months ago about how SOME of the Carlisle tires are way out of balance, and how some golf cart tires work well and some don't, etc. > > After the money I invested in the O'Brien brakes,a nd the money I would have to spend to get different wheels and axles... I would PREFER to keep the Azusa wheels I have. > > With ALL due respect to those selling or flying with one piece wheels I am NOT interested in one piece "spun" wheels. There are no tire shops at the places where I plan to land my Kolb :) > > Anyone with experience or knowledge on this particular problem using Azusa wheels , I'm all ears! > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Wed, 4/12/17, Richard Pike wrote: > > Subject: Kolb-List: Re: Polyester cloth > To: kolb-list(at)matronics.com > Date: Wednesday, April 12, 2017, 2:33 PM > > Pike" > > Thanks Rick - good memories. I also > recovered an Easy Riser with polyester dress sheath, guess I > got lucky. I was so ignorant I didn't know you were supposed > to use heat to shrink it; I treated it like a big model > airplane and used enough clothespins, small weights and > clamps that it was basically pretty tight once the glue > dried. Then I brushed a couple coats of nitrate dope on it > and it shrank up just like brushing Aero-Gloss on silk. > > Bought it used from Glen Rinck (who is > on the FB U/L list) but since he was heavier than I was, if > I hit a thermal under power and the seat unweighted, it > would pitch over. Pretty scary. Called Chuck Slusarczyk and > told him what I was doing and he gave me all the proper > angles and measurements to rig the engine position/thrust > line so it wouldn't kill me. From then on it flew just as > stable as you could ask for. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 12, 2017
I too have the new tundra tires waiting to be mounted, but what I am waiting on is a new set of rims from Matco. I currently have Matco hyd. brakes on the plane, and thought that I would keep my current 800X6 tires in reserve for a reason that escapes me at the moment. So I popped for the new "heavier" spun Matco wheels, that are on back order, for about three weeks now.. I have the 5 inch O'Brian mech brakes that I had set up with hand brakes prior to changing to the Hydraulic ones. For what it is worth I think the hand brakes are better. No much, but a hell of a lot less hassle. I tried to run the 800x6 tires with fairly low air pressure - 6-8 lbs, and spun a tire, shearing off the air nipple. So I got some tire screws and drilled 6 holes in the rims both sides and screwed the rims to the tire. 6 per side. It worked fine. I just went out and took an Azuza rim apart and stuck it in the Tundra 850x6 tire. If you push it so that the ribs that you can see on the rim engage, it does snap in and you cannot "easily" turn it. I do not trust it to not spin however, so if I use these rims again, I will screw them to the tire. If I do decide to wait for Matco to finally produce the rims that I have already paid for, I will also screw them to the rim as well rather than take a chance on spinning them. The attachments are of the 800x6 air tracks with 6 lbs of air and screws. The other is of the "ribs" in an Azuza rim that is apparently designed to keep the tire from spinning. The screws are from JEGs and are designated for the purpose of screwing the tire to the rim. Therefore they cost a lot more than a regular sheet metal 3/4 in screw. The holes in the rim are small enough for the screw to cut threads. Just in case you decide to go with the regular screws. You get to make your own decision. Larry On Wed, Apr 12, 2017 at 5:25 PM, Bill Berle wro te: > > So I called Desser tire Co. I asked the guy whether these tires should sp in on the wheel. He said yes they do spin until you put air in them, and th en you can't spin them. But this does NOT match my experience with putting wheels and tires together on my Cessna 172. Then I said I was putting thes e tires on Azusa wheels. He called me back 30 minutes later, said he went a nd checked with someone in the engineering department, and that yes they di d have problems with Azusa wheels because they were too "flimsy". I asked w hat that had to do with their tire fitting on a 6 inch wheel. He said that the Azusa wheels were "not built to spec" and that's why they had problems. Put these tires on Matco wheels and there's no problem. -- The older I get, the less tolerant I am of those who are intolerant of othe rs. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Apr 12, 2017
Bill I read your discussion regarding Tundra tires. My thoughts are that light aircraft tires need to be tubeless. The advantage is one can run low tire pressure and not rip the valve stem out of the tube accelerating the tire and wheel upon landing. To my knowledge no tubeless system exist, and this is an opportunity for an enterprising individual to design and market a tubeless system. I fly a Kolb Mk3/ Rotax 582 Jim On Wed, Apr 12, 2017 at 5:33 PM, Larry Cottrell wrote: > I too have the new tundra tires waiting to be mounted, but what I am > waiting on is a new set of rims from Matco. I currently have Matco > hyd. brakes on the plane, and thought that I would keep my current > 800X6 tires in reserve for a reason that escapes me at the moment. So > I popped for the new "heavier" spun Matco wheels, that are on back > order, for about three weeks now.. > > I have the 5 inch O'Brian mech brakes that I had set up with hand > brakes prior to changing to the Hydraulic ones. For what it is worth I > think the hand brakes are better. No much, but a hell of a lot less > hassle. > > I tried to run the 800x6 tires with fairly low air pressure - 6-8 lbs, > and spun a tire, shearing off the air nipple. So I got some tire > screws and drilled 6 holes in the rims both sides and screwed the rims > to the tire. 6 per side. It worked fine. > > I just went out and took an Azuza rim apart and stuck it in the Tundra > 850x6 tire. If you push it so that the ribs that you can see on the > rim engage, it does snap in and you cannot "easily" turn it. I do not > trust it to not spin however, so if I use these rims again, I will > screw them to the tire. If I do decide to wait for Matco to finally > produce the rims that I have already paid for, I will also screw them > to the rim as well rather than take a chance on spinning them. > > The attachments are of the 800x6 air tracks with 6 lbs of air and screws. > > The other is of the "ribs" in an Azuza rim that is apparently designed > to keep the tire from spinning. > > The screws are from JEGs and are designated for the purpose of > screwing the tire to the rim. Therefore they cost a lot more than a > regular sheet metal 3/4 in screw. The holes in the rim are small > enough for the screw to cut threads. Just in case you decide to go > with the regular screws. > > You get to make your own decision. > Larry > > > On Wed, Apr 12, 2017 at 5:25 PM, Bill Berle > wrote: > > > > So I called Desser tire Co. I asked the guy whether these tires should > spin on the wheel. He said yes they do spin until you put air in them, and > then you can't spin them. But this does NOT match my experience with > putting wheels and tires together on my Cessna 172. Then I said I was > putting these tires on Azusa wheels. He called me back 30 minutes later, > said he went and checked with someone in the engineering department, and > that yes they did have problems with Azusa wheels because they were too > "flimsy". I asked what that had to do with their tire fitting on a 6 inch > wheel. He said that the Azusa wheels were "not built to spec" and that's > why they had problems. Put these tires on Matco wheels and there's no > problem. > > > -- > The older I get, the less tolerant I am of those who are intolerant of > others. > > If you forward this email, or any part of it, please remove my email > address before sending. > ________________________________________________________________________________
Date: Apr 13, 2017
Charlie My two cents again; I used white Gripper but any good acrylic primmer will do and you can tint it toward your top coat. As I'm painting scenes on my wings and fuselage I can't do the sanding described by Wiener Dog so I'm spraying on a high gloss clear coat. The product I've settled on is Rustolem acrylic gloss clear. Joe ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Wednesday, April 12, 2017 11:03:16 AM Subject: Re: Kolb-List: Re: covering supplier? Thanks, Peter. For you guys who've used latex, did you stick with the Glidden Gripper grey primer as shown on the Wienerdog Aero site, or something else? I can get the white primer (and other brands) locally, but will have to order the grey. No polishing for me; I'll be happy if the paint stays on & prevents UV damage. Thanks, Charlie On 4/12/2017 7:57 AM, phcpilot wrote: > > Here are my experiences with Latex which include a re-paint over an auto finish, re-cover of a fuselage and painting a stits type covering. > > The re-paint was on a fuselage which had some cracking and chipping of an older auto finish from firewall back past trailing edge of a Rans S7. I sanded and filled the crack/chip areas with poly filla (Yup) then had the hardware store do a colour match of some exterior latex paint. Actually these days it is called water based acrylic. Years ago you couldn't sand latex due to its rubbery nature. Not so these days. > The result looked great with sort of a low gloss dope type finish. I have kept in touch with the owner of the plane because even I was skeptical of how long it would last. It has been many years now and he is still happy. > > In addition to acrylic paints, you should also keep clear water base urethane in mind. I recovered my homebuilt 170 fuselage (steel tube/fabric) and used clear urethane as first fill coat on the fabric and then put tapes on with it. It was great to work with. Also used the green hardware store water based contact cement for glue. > > Then sprayed on gloss acylic latex for finish coats. A buddy who is a long time dope and fabric guy was amazed at how great the tape seams and fill looked. At that time the glossiest acrylic was about as dull as a dope finish but with a lot fewer coats. > > Next I've done a complete S7 with acrylic using a cheap primer fill coat followed by gloss colour coats. High gloss is not an attribute of acrylic unless you want to do all that buffing but with a product from Home Hardware called Rust coat the finish is the best I've seen. Yes if you need a mirror finish be prepared to work but for a great looking dope or better than polytone, little sanding is required. > > For years I followed the suggestion from one site to use an airless sprayer. This was mistake, they put out way too much paint even with the fine nozzles. An inexpensive $50 HVLP gun is just fine and with way less likelihood of runs. > Peter > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 13, 2017
Thanks Joe; that's good news. I'll just use a good quality primer & quit worrying about it. Will a gallon take care of both wings (the multiple coats required)? On Thu, Apr 13, 2017 at 7:06 AM, wrote: > Charlie > > My two cents again; I used white Gripper but any good acrylic primmer > will do and you can tint it toward your top coat. As I'm painting scenes > on my wings and fuselage I can't do the sanding described by Wiener Dog so > I'm spraying on a high gloss clear coat. The product I've settled on is > Rustolem acrylic gloss clear. > > Joe > > ------------------------------ > *From: *"Charlie England" <ceengland7(at)gmail.com> > *To: *"kolb-list" > *Sent: *Wednesday, April 12, 2017 11:03:16 AM > *Subject: *Re: Kolb-List: Re: covering supplier? > > > Thanks, Peter. > > For you guys who've used latex, did you stick with the Glidden Gripper > grey primer as shown on the Wienerdog Aero site, or something else? I > can get the white primer (and other brands) locally, but will have to > order the grey. > > No polishing for me; I'll be happy if the paint stays on & prevents UV > damage. > > Thanks, > > Charlie > > On 4/12/2017 7:57 AM, phcpilot wrote: > > > > Here are my experiences with Latex which include a re-paint over an auto > finish, re-cover of a fuselage and painting a stits type covering. > > > > The re-paint was on a fuselage which had some cracking and chipping of > an older auto finish from firewall back past trailing edge of a Rans S7. I > sanded and filled the crack/chip areas with poly filla (Yup) then had the > hardware store do a colour match of some exterior latex paint. Actually > these days it is called water based acrylic. Years ago you couldn't sand > latex due to its rubbery nature. Not so these days. > > The result looked great with sort of a low gloss dope type finish. I > have kept in touch with the owner of the plane because even I was skeptical > of how long it would last. It has been many years now and he is still happy. > > > > In addition to acrylic paints, you should also keep clear water base > urethane in mind. I recovered my homebuilt 170 fuselage (steel tube/fabric) > and used clear urethane as first fill coat on the fabric and then put tapes > on with it. It was great to work with. Also used the green hardware store > water based contact cement for glue. > > > > Then sprayed on gloss acylic latex for finish coats. A buddy who is a > long time dope and fabric guy was amazed at how great the tape seams and > fill looked. At that time the glossiest acrylic was about as dull as a dope > finish but with a lot fewer coats. > > > > Next I've done a complete S7 with acrylic using a cheap primer fill coat > followed by gloss colour coats. High gloss is not an attribute of acrylic > unless you want to do all that buffing but with a product from Home > Hardware called Rust coat the finish is the best I've seen. Yes if you need > a mirror finish be prepared to work but for a great looking dope or better > than polytone, little sanding is required. > > > > For years I followed the suggestion from one site to use an airless > sprayer. This was mistake, they put out way too much paint even with the > fine nozzles. An inexpensive $50 HVLP gun is just fine and with way less > likelihood of runs. > > Peter > > > > > --- > This email has been checked for viruses by Avast antivirus softwarebsp; > - MATRONICS WEB FORUMS - > ==== > > ________________________________________________________________________________
Date: Apr 13, 2017
Subject: Leading edge bracing; was: Kolb Twinstar (original version)
info request John, You mentioned leading edge bracing. This is all I see in the Twinstar I'm restoring. There's nothing along the rest of the leading edge that triangulates/ braces the leading edge. Would you consider this adequate? It's easy to add now, with the cover coming off. Thanks, Charlie Thanks, John. I wasn't sure about how rugged the tubes would be when driving out mandrels, etc. I use similar tricks on the heavier experimentals I've owned. I've got a spring loaded center punch that I ground to a flat nosed, straight shaft, & use it to punch out driven rivets after drilling the heads. I also use small, flush cutting 'dykes' (diagonal wire cutters) to grab pop rivet heads On 4/9/2017 5:58 PM, John Hauck wrote: Charlie E/Kolbers: I have recovered a bunch of them. All that I tore up and a few I didn't. Drilling rivets can be accomplished once you have the mandrels removed. It takes a 1/16" punch, or you can use a pulled mandrel, grind the end flat, hold with vise grips, and knock out with a hammer. The rivet needs to be held to prevent spinning. I grind a V in the end of a hack saw blade with sharp beveled edges. Use that to push up under the rivet to lock it in place while drilling. 4130 airframes should be tube sealed when fabricated. 99% of Kolbs probably have never been tube sealed. Their builders probably never heard of tube sealing. 4130 rusts from inside out if not sealed. That would worry me with an old fuselage, especially a Twinstar. I can't remember exactly what the fuselage looks like other that the root tube that seats and stuff are attached to. This I would make sure is rust free on the inside. I helped Brother Jim rebuild Adriel Heisey's Twinstar, Navajo Nation pilot that shot aerial photos published in Nat Geo and other pubs, that he crashed in a wind storm. It was frightening when we started cutting tubing. Most were rusted well beyond serviceability. Here are photos of his Twinstar: https://uanews.arizona.edu/story/aerial-photos-of-archaeological-sites-on-exhibit-at-state-museum I don't recall anyone flying a free air cooled Rotax on a Kolb successfully. Yours may be an exception. Don't know of any published updates for the Twinstar. It was not a popular model and kits only produced a couple years. Strong lateral bracing of the leading edge of the wing is extremely important to me. Poor/weak lateral bracing can lead to leading edge failure. This causes the Kolb to stop flying immediately. Lower tail post bracing makes it last longer. I don't know a whole lot about the Twinstar. The one Kolb model I never flew. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com ] On Behalf Of Charlie England Sent: Sunday, April 09, 2017 4:33 PM Subject: Kolb-List: Kolb Twinstar (original version) info request OK, now that I've got that short nose Kolb bit out of my system.... I'm now the proud owner of an N-numbered early Kolb Twinstar (restoration project). IIRC, its serial number is in the low 20's range. A little rusty, but we've peeled the fabric on one wing & the aluminum seems to be in good shape, with very little corrosion, considering that it spent its entire past life in central FL. This one's got a Rotax 503 (converted from single to dual carbs, and to free air cooling) that seems to be in great shape. The previous owner is a close friend who was the builder. I trust what he tells me, and he says that it always cooled fine running it free-air with some added ducting. I'll be replacing hardware, 'soft' parts, etc, but don't intend on doing a showplane restoration; just a safe, nice flying 'after supper' flyer. I've got the plans for the plane, but I'm hoping that you experienced Kolbers can share any suggested mods to these early models, that will make them safer/more durable/etc. Is there a published list of any/all service bulletins or recommended updates? For instance, I've seen the advice to add braces to the tailspring stinger. And I know that the later Twinstars have mass balances on at least some of the control surfaces; is it recommended to add them to the early models? This one does not have any mass balances anywhere. Who's recovered one? Any issues when you drilled out the rivets to remove the ailerons, etc for recovering? Any advice will be appreciated. Thanks, Charlie ________________________________________________________________________________
Subject: Re: Leading edge bracing; was: Kolb Twinstar (original version)
Date: Apr 13, 2017
I'm not John, but if you scroll down to page 21 in the MKIII Yellow Book, you will see what Kolb though to be a very useful reinforcement. http://oh2fly.net/oldpoops/Lexan%20rear%20enclosure.html -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468375#468375 ________________________________________________________________________________
Date: Apr 14, 2017
version) Good Evening I built 2 new wings for my MK111. I did not run the reinforcing tape betwee n the=C2- ribs forward of the spar. Was I suppose to?. I did run the tape between each rib about half way back of the spar.ThanksBob On Thursday, April 13, 2017 10:23 PM, Richard Pike wrote: I'm not John, but if you scroll down to page 21 in the MKIII Yellow Book, y ou will see what Kolb though to be a very useful reinforcement. http://oh2fly.net/oldpoops/Lexan%20rear%20enclosure.html -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468375#468375 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: bracing
Date: Apr 13, 2017
I built 2 new wings for my MK111. I did not run reinforcing tape between each rib forward of the spar. Was I suppose to? I did run the tape between each rib about half way back from the spar. Thanks Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468378#468378 ________________________________________________________________________________
Subject: Finally spring time
Date: Apr 14, 2017
It's finally warm enough to go outside for more than a fast run to my car. We went over to New Richmond, WI to see if our ultralights were still there, first time since November for me. There was some snow on the ground from the night before but it was gone by the time we went out and bought a new tube for Randy's BeLite and installed it. Once his tire was repaired and I had reinstalled the battery and fuel tank on my Firefly it was warm enough for a short flight. We had a short but fun flight around KRNH. https://www.youtube.com/watch?v=7d6BjRHi7WI -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468399#468399 ________________________________________________________________________________
Date: Apr 14, 2017
Subject: Re: Finally spring time
Nice solid video's. Thanks, Larry On Fri, Apr 14, 2017 at 4:19 PM, west1m wrote: > > It's finally warm enough to go outside for more than a fast run to my car. > We went over to New Richmond, WI to see if our ultralights were still there, first time since November for me. There was some snow on the ground from the night before but it was gone by the time we went out and bought a new tube for Randy's BeLite and installed it. Once his tire was repaired and I had reinstalled the battery and fuel tank on my Firefly it was warm enough for a short flight. We had a short but fun flight around KRNH. > https://www.youtube.com/watch?v=7d6BjRHi7WI > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=468399#468399 > > -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Apr 15, 2017
Subject: Re: Finally spring time/vg article
I have found that Sport Aviation mag,with the vg article in it. I think I would have to mail it to someone with the knowledge of how to share it easily. Any volunteers? ________________________________________________________________________________
Date: Apr 15, 2017
Subject: Baby's got some new shoes
I finally got my new rims from Matco. They had been on back order for almost a month, at least it seems that way. I had already ordered the 8.50 X 6 tundra tires and tubes. Today dawned cold, 22 degrees but calm for a change. It eventually warmed up to 44 degrees and I went to the hanger to start my tire mounting. I drilled 6 holes in the rims to screw the tires to the rims. The tires fit tight enough that it takes about 20 lbs of air to make them pop out on the rims. That is unlike the Azusa rims that depend on small flanges on the inside of the rims to keep them from spinning. Since I want to run 5 lbs or less I am still not going to take a chance on shearing off the valve stem, thus 6 screws per side. Before I changed from the 8.00 X6 tires, I rolled the plane out and flew all four corners of the compass with a vid camera to monitor my airspeed. The speed averaged out to be about 66 MPH indicated. The same on the ground speed depending on with or against the wind. There was little wind, and my ASI and Ground speed are really close under those conditions. I drilled and cut threads in the rims, and then mounted the tires. Since the 8.00 x 6 tires are on Matco rims as well, I just changed the three bolts that held the bearings in the other tires and changed them to the new tundras. The wind was still holding its breath, so I rolled the plane back out to check the difference. It seems to roll better with the tundra's on it. I taxiied to the other end of the runway, and began my take off. I cannot be sure, but the tires with 5 lbs of air, seemed to bounce a bit on take off, but I could not be sure. When I pulled back on the stick it flew quickly. I tend to push the stick forward to pick up speed, so it could have been trying to fly, while I was pushing it back on the ground. I will be doing a lot more testing when the weather again cooperates. My take off seemed to be quite a bit shorter than normal. In essence there was no indication that my air speed suffered at all. It was quite turbulent so I only made a circuit and half. While I seemed to bounce a bit on take off, I bounced not at all on landing. The tires at 5 lbs are really nice. They appear to not need balancing, unlike the 8.00X6's. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Apr 15, 2017
Larry, Are you using tubes in these tires? If so, how do you keep the screws from puncturing the tubes? Just curious as I am happy with my Black Max brakes, tubeless tires and aluminum wheels on my Firefly. Apples and oranges, I know.... Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Saturday, April 15, 2017 6:47 PM Subject: Kolb-List: Baby's got some new shoes I finally got my new rims from Matco. They had been on back order for almost a month, at least it seems that way. I had already ordered the 8.50 X 6 tundra tires and tubes. Today dawned cold, 22 degrees but calm for a change. It eventually warmed up to 44 degrees and I went to the hanger to start my tire mounting. I drilled 6 holes in the rims to screw the tires to the rims. The tires fit tight enough that it takes about 20 lbs of air to make them pop out on the rims. That is unlike the Azusa rims that depend on small flanges on the inside of the rims to keep them from spinning. Since I want to run 5 lbs or less I am still not going to take a chance on shearing off the valve stem, thus 6 screws per side. Before I changed from the 8.00 X6 tires, I rolled the plane out and flew all four corners of the compass with a vid camera to monitor my airspeed. The speed averaged out to be about 66 MPH indicated. The same on the ground speed depending on with or against the wind. There was little wind, and my ASI and Ground speed are really close under those conditions. I drilled and cut threads in the rims, and then mounted the tires. Since the 8.00 x 6 tires are on Matco rims as well, I just changed the three bolts that held the bearings in the other tires and changed them to the new tundras. The wind was still holding its breath, so I rolled the plane back out to check the difference. It seems to roll better with the tundra's on it. I taxiied to the other end of the runway, and began my take off. I cannot be sure, but the tires with 5 lbs of air, seemed to bounce a bit on take off, but I could not be sure. When I pulled back on the stick it flew quickly. I tend to push the stick forward to pick up speed, so it could have been trying to fly, while I was pushing it back on the ground. I will be doing a lot more testing when the weather again cooperates. My take off seemed to be quite a bit shorter than normal. In essence there was no indication that my air speed suffered at all. It was quite turbulent so I only made a circuit and half. While I seemed to bounce a bit on take off, I bounced not at all on landing. The tires at 5 lbs are really nice. They appear to not need balancing, unlike the 8.00X6's. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Apr 15, 2017
Subject: Re: Baby's got some new shoes
You wrote: Are you using tubes in these tires? If so, how do you keep the screws from puncturing the tubes? Yes these are tube type tires. The screws don't go all the way through the inside rim of the tire. The screws are 3/4, so I put a washer on them and they are just right for length that way. Larry ________________________________________________________________________________
Date: Apr 15, 2017
Subject: Matronics Internet Connectivity Upgrades April 17-18 2017
Dear Matronics Email List an/or Forum User, The Matronics Internet connectivity will be upgraded on April 17 through April 18, 2017. During the upgrade connections to the Matronics and AeroElectric web servers may be unavailable. Additionally, Matronics Email List email will not be redistributed. Internet Connectivity bandwidth will be significantly increased by a factor of 7X for downloads and 50X for uploads, which represents a significant increase in performance. Reliability should also increase in terms. I will send out a follow up message when the upgrade has been completed. Best Regards, Matt Dralle Matronics Email List and Forum Admin. Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Apr 15, 2017
Subject: Baby has new shoes
https://vimeo.com/213383013 password - owyheeflyer A short video with the new tires. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Apr 16, 2017
Subject: Mk3 C Clevis Pins
Hi again, could someone tell me the correct clevis pin sizes (ms20392 - xxxx), for the Kolb Twinstar Mk3 C please. The current pins fitted bear no resemblance to the "picking list" I have, which gives, (I presume I've got the correct ones), Aileron & flaps - AN394-25 (3C25); wing strut top - AN395-17 (4C17); wing strut at fuselage - AN395-29 (4C29); main wing - AN395-41 (4C41); elevator bottom wires (not a through bolt but a mount on each side), AN393-17 (2C17). The only pin I could find in "The Yellow Book" was the aileron, AN394-29. The pins currently fitted are all 3C (1/4") instead of 5/16". I'm a new owner and I want to change all the clevis pins. Any help will be appreciated. Norman ________________________________________________________________________________
Date: Apr 16, 2017
Subject: New Break-away Tail Wheel
Date: Apr 16, 2017
Gentlemen, I bought a new breakaway tail wheel from Kolb at Sun N Fun this year. Attempting to replace my original wheel, It appears like the original is JB Welded to the solid aluminum tail rod. What is the recommended procedure for removing the original tail wheel assembly? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468520#468520 ________________________________________________________________________________
Date: Apr 16, 2017
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: New Break-away Tail Wheel
If it's aluminum, heat from a propane torch will break the bond. A wet rag wrapped around the aluminum will keep the heat from traveling up to the tail skeg. Maybe try to twist a bit while heating, so you know when it lets go. It shouldn't take much heat. Or, as suggested earlier this week, cut it off to shorten it a bit. Bill Sullivan Gentlemen, I bought a new breakaway tail wheel from Kolb at Sun N Fun this year. Attempting to replace my original wheel, It appears like the original is JB Welded to the solid aluminum tail rod. What is the recommended procedure for removing the original tail wheel assembly? ________________________________________________________________________________
Date: Apr 16, 2017
Subject: Re: Mk3 C Clevis Pins
Norman wrote "Hi again, could someone tell me the correct clevis pin sizes (ms20392 - xxxx), for the Kolb Twinstar Mk3 C please" My plans says an395-17 for lift strut attach point to wing An 395-29 for lift strut to cage An394 - 29 flap arm attach and aileron linkage Forward wing attachment an395-45 Wing attach at universal joint are 5/16 bolts Note: AN 39 indicates the style the "5" in an395 is the diameter in 16ths the "dash number# is the length. All clevis pins can be replaced with bolts and locknuts if you don't fold the wings. Disclaimer....... Some of the clevis pins as noted by the plans were very slightly too short. In my humble opinion. If it were me,,, I would measure the distance to be spanned add the thickness of the washers you want to use. Plus a tiny bit so it is not to hard to get together. Boyd Young ________________________________________________________________________________
Date: Apr 16, 2017
Norman- call Aircraft Spruce and get their catalog. Gull of information about sizes, hardness, and strange stuff. Great reference book. Bill Sullivan -------------------------------------------- On Sun, 4/16/17, Norman wrote: Subject: Kolb-List: Mk3 C Clevis Pins To: "Kolb List Posting" Date: Sunday, April 16, 2017, 7:54 AM Hi again, could someone tell me the correct clevis pin sizes (ms20392 - xxxx), for the Kolb Twinstar Mk3 C please. ________________________________________________________________________________
Date: Apr 16, 2017
A propane torch should do the trick. Just heat it lightly all the way around. It will break loose.Keep wet cloth with around to keep to much heat from transferring to the tail post. Have a great day! > On Apr 16, 2017, at 9:52 AM, KJ4CTZ wrote: > > > Gentlemen, > > I bought a new breakaway tail wheel from Kolb at Sun N Fun this year. Attempting to replace my original wheel, It appears like the original is JB Welded to the solid aluminum tail rod. > > What is the recommended procedure for removing the original tail wheel assembly? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=468520#468520 > > > > > > > > > ________________________________________________________________________________
Date: Apr 16, 2017
Thanks guys, I will try mild heat first. If no success I will cut off and put new assembly on. Should it also be JB Welded back on? I assume so but open to suggestions. This forum is great and I appreciate everyone's comments. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468526#468526 ________________________________________________________________________________
Date: Apr 16, 2017
I re-mounted my tail wheel on a very early Firestar because it was crooked. I had the fiberglass rod. I used a 1/4" bolt through it. I was a truck equipment mechanic, so I have a tendency to overdo things a bit. Bill Sullivan -------------------------------------------- On Sun, 4/16/17, KJ4CTZ wrote: Subject: Kolb-List: Re: New Break-away Tail Wheel To: kolb-list(at)matronics.com Date: Sunday, April 16, 2017, 11:57 AM Thanks guys, I will try mild heat first. If no success I will cut off and put new assembly on. Should it also be JB Welded back on? I assume so but open to suggestions. ________________________________________________________________________________
Date: Apr 16, 2017
Subject: Fwd: another video and flight
------ Subject: another video and flight The weather was still nice this morning so I put on a lot of clothes and took off. video- https://vimeo.com/213440748 password owyheeflyer Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
info request
Date: Apr 16, 2017
Actually, the two 5/16" tubes are fabric braces to keep the fabric from pulling the aluminum rib nose inward. There is no lateral bracing of the leading edge tube except a long 5/16 alum tube that is in compression. The bow tip doesn't do much for lateral bracing of the leading edge tube. That's all you have to keep the rib noses in column. Once they get pulled out of column, they will probably fail. The small 5/16 tubes are flattened, bent, and riveted. They tend to break at this point from vibration with not a whole lot of time on them. I used two 1/2" alum tubes, one inboard and one outboard, diagonally working with each other, attached to the leading edge tube and the main spare. Wish I had a photo of my wing handy. If I can find one I will share it. I may be overly cautious, but it makes me feel more comfortable, especially when I get caught in extremely rough air. Sorry for the delay in responding. Just got home from a 4 day trip. If you need more info, call me. 334-567-6280 john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Thursday, April 13, 2017 11:05 AM Subject: Kolb-List: Leading edge bracing; was: Kolb Twinstar (original version) info request John, You mentioned leading edge bracing. This is all I see in the Twinstar I'm restoring. There's nothing along the rest of the leading edge that triangulates/ braces the leading edge. Would you consider this adequate? It's easy to add now, with the cover coming off. Thanks, Charlie Thanks, John. I wasn't sure about how rugged the tubes would be when driving out mandrels, etc. I use similar tricks on the heavier experimentals I've owned. I've got a spring loaded center punch that I ground to a flat nosed, straight shaft, & use it to punch out driven rivets after drilling the heads. I also use small, flush cutting 'dykes' (diagonal wire cutters) to grab pop rivet heads On 4/9/2017 5:58 PM, John Hauck wrote: Charlie E/Kolbers: I have recovered a bunch of them. All that I tore up and a few I didn't. Drilling rivets can be accomplished once you have the mandrels removed. It takes a 1/16" punch, or you can use a pulled mandrel, grind the end flat, hold with vise grips, and knock out with a hammer. The rivet needs to be held to prevent spinning. I grind a V in the end of a hack saw blade with sharp beveled edges. Use that to push up under the rivet to lock it in place while drilling. 4130 airframes should be tube sealed when fabricated. 99% of Kolbs probably have never been tube sealed. Their builders probably never heard of tube sealing. 4130 rusts from inside out if not sealed. That would worry me with an old fuselage, especially a Twinstar. I can't remember exactly what the fuselage looks like other that the root tube that seats and stuff are attached to. This I would make sure is rust free on the inside. I helped Brother Jim rebuild Adriel Heisey's Twinstar, Navajo Nation pilot that shot aerial photos published in Nat Geo and other pubs, that he crashed in a wind storm. It was frightening when we started cutting tubing. Most were rusted well beyond serviceability. Here are photos of his Twinstar: https://uanews.arizona.edu/story/aerial-photos-of-archaeological-sites-on -exhibit-at-state-museum I don't recall anyone flying a free air cooled Rotax on a Kolb successfully. Yours may be an exception. Don't know of any published updates for the Twinstar. It was not a popular model and kits only produced a couple years. Strong lateral bracing of the leading edge of the wing is extremely important to me. Poor/weak lateral bracing can lead to leading edge failure. This causes the Kolb to stop flying immediately. Lower tail post bracing makes it last longer. I don't know a whole lot about the Twinstar. The one Kolb model I never flew. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Sunday, April 09, 2017 4:33 PM Subject: Kolb-List: Kolb Twinstar (original version) info request OK, now that I've got that short nose Kolb bit out of my system.... I'm now the proud owner of an N-numbered early Kolb Twinstar (restoration project). IIRC, its serial number is in the low 20's range. A little rusty, but we've peeled the fabric on one wing & the aluminum seems to be in good shape, with very little corrosion, considering that it spent its entire past life in central FL. This one's got a Rotax 503 (converted from single to dual carbs, and to free air cooling) that seems to be in great shape. The previous owner is a close friend who was the builder. I trust what he tells me, and he says that it always cooled fine running it free-air with some added ducting. I'll be replacing hardware, 'soft' parts, etc, but don't intend on doing a showplane restoration; just a safe, nice flying 'after supper' flyer. I've got the plans for the plane, but I'm hoping that you experienced Kolbers can share any suggested mods to these early models, that will make them safer/more durable/etc. Is there a published list of any/all service bulletins or recommended updates? For instance, I've seen the advice to add braces to the tailspring stinger. And I know that the later Twinstars have mass balances on at least some of the control surfaces; is it recommended to add them to the early models? This one does not have any mass balances anywhere. Who's recovered one? Any issues when you drilled out the rivets to remove the ailerons, etc for recovering? Any advice will be appreciated. Thanks, Charlie ________________________________________________________________________________
version)
Date: Apr 16, 2017
In addition to modifying and additional lateral bracing of the wing's leading edge, I also reinforced my ribs. Makes for an extremely stiff wing. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Thursday, April 13, 2017 9:18 PM Subject: Kolb-List: Re: Leading edge bracing; was: Kolb Twinstar (original version) --> I'm not John, but if you scroll down to page 21 in the MKIII Yellow Book, you will see what Kolb though to be a very useful reinforcement. http://oh2fly.net/oldpoops/Lexan%20rear%20enclosure.html -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468375#468375 ________________________________________________________________________________
Date: Apr 16, 2017
Subject: Re: Fwd: another video and flight
I like the video. Especially the short approach to the landing.. observation way to many dreaded 3 mile finals. Boyd On Apr 16, 2017 4:02 PM, "Larry Cottrell" wrote: > > ------ > Subject: another video and flight > > > The weather was still nice this morning so I put on a lot of clothes > and took off. > > video- https://vimeo.com/213440748 password owyheeflyer > > > Larry > > -- > The older I get, the less tolerant I am of those who are intolerant of > others. > > If you forward this email, or any part of it, please remove my email > address before sending. > > > -- > The older I get, the less tolerant I am of those who are intolerant of > others. > > If you forward this email, or any part of it, please remove my email > address before sending. > > ________________________________________________________________________________
Date: Apr 16, 2017
Sounds good. Reckon sitting more nose high helped with your takeoff? john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Saturday, April 15, 2017 6:47 PM Subject: Kolb-List: Baby's got some new shoes I finally got my new rims from Matco. They had been on back order for almost a month, at least it seems that way. I had already ordered the 8.50 X 6 tundra tires and tubes. Today dawned cold, 22 degrees but calm for a change. It eventually warmed up to 44 degrees and I went to the hanger to start my tire mounting. I drilled 6 holes in the rims to screw the tires to the rims. The tires fit tight enough that it takes about 20 lbs of air to make them pop out on the rims. That is unlike the Azusa rims that depend on small flanges on the inside of the rims to keep them from spinning. Since I want to run 5 lbs or less I am still not going to take a chance on shearing off the valve stem, thus 6 screws per side. Before I changed from the 8.00 X6 tires, I rolled the plane out and flew all four corners of the compass with a vid camera to monitor my airspeed. The speed averaged out to be about 66 MPH indicated. The same on the ground speed depending on with or against the wind. There was little wind, and my ASI and Ground speed are really close under those conditions. I drilled and cut threads in the rims, and then mounted the tires. Since the 8.00 x 6 tires are on Matco rims as well, I just changed the three bolts that held the bearings in the other tires and changed them to the new tundras. The wind was still holding its breath, so I rolled the plane back out to check the difference. It seems to roll better with the tundra's on it. I taxiied to the other end of the runway, and began my take off. I cannot be sure, but the tires with 5 lbs of air, seemed to bounce a bit on take off, but I could not be sure. When I pulled back on the stick it flew quickly. I tend to push the stick forward to pick up speed, so it could have been trying to fly, while I was pushing it back on the ground. I will be doing a lot more testing when the weather again cooperates. My take off seemed to be quite a bit shorter than normal. In essence there was no indication that my air speed suffered at all. It was quite turbulent so I only made a circuit and half. While I seemed to bounce a bit on take off, I bounced not at all on landing. The tires at 5 lbs are really nice. They appear to not need balancing, unlike the 8.00X6's. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
info request
Date: Apr 16, 2017
I left out the fact that the fabric braces are on the nose of the inboard rib. Aft is 4130 and nose is alum tubing. john h From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck Sent: Sunday, April 16, 2017 5:36 PM Subject: RE: Kolb-List: Leading edge bracing; was: Kolb Twinstar (original version) info request Actually, the two 5/16" tubes are fabric braces to keep the fabric from pulling the aluminum rib nose inward. There is no lateral bracing of the leading edge tube except a long 5/16 alum tube that is in compression. The bow tip doesn't do much for lateral bracing of the leading edge tube. That's all you have to keep the rib noses in column. Once they get pulled out of column, they will probably fail. The small 5/16 tubes are flattened, bent, and riveted. They tend to break at this point from vibration with not a whole lot of time on them. I used two 1/2" alum tubes, one inboard and one outboard, diagonally working with each other, attached to the leading edge tube and the main spare. Wish I had a photo of my wing handy. If I can find one I will share it. I may be overly cautious, but it makes me feel more comfortable, especially when I get caught in extremely rough air. Sorry for the delay in responding. Just got home from a 4 day trip. If you need more info, call me. 334-567-6280 john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Thursday, April 13, 2017 11:05 AM Subject: Kolb-List: Leading edge bracing; was: Kolb Twinstar (original version) info request John, You mentioned leading edge bracing. This is all I see in the Twinstar I'm restoring. There's nothing along the rest of the leading edge that triangulates/ braces the leading edge. Would you consider this adequate? It's easy to add now, with the cover coming off. Thanks, Charlie Thanks, John. I wasn't sure about how rugged the tubes would be when driving out mandrels, etc. I use similar tricks on the heavier experimentals I've owned. I've got a spring loaded center punch that I ground to a flat nosed, straight shaft, & use it to punch out driven rivets after drilling the heads. I also use small, flush cutting 'dykes' (diagonal wire cutters) to grab pop rivet heads On 4/9/2017 5:58 PM, John Hauck wrote: Charlie E/Kolbers: I have recovered a bunch of them. All that I tore up and a few I didn't. Drilling rivets can be accomplished once you have the mandrels removed. It takes a 1/16" punch, or you can use a pulled mandrel, grind the end flat, hold with vise grips, and knock out with a hammer. The rivet needs to be held to prevent spinning. I grind a V in the end of a hack saw blade with sharp beveled edges. Use that to push up under the rivet to lock it in place while drilling. 4130 airframes should be tube sealed when fabricated. 99% of Kolbs probably have never been tube sealed. Their builders probably never heard of tube sealing. 4130 rusts from inside out if not sealed. That would worry me with an old fuselage, especially a Twinstar. I can't remember exactly what the fuselage looks like other that the root tube that seats and stuff are attached to. This I would make sure is rust free on the inside. I helped Brother Jim rebuild Adriel Heisey's Twinstar, Navajo Nation pilot that shot aerial photos published in Nat Geo and other pubs, that he crashed in a wind storm. It was frightening when we started cutting tubing. Most were rusted well beyond serviceability. Here are photos of his Twinstar: https://uanews.arizona.edu/story/aerial-photos-of-archaeological-sites-on -exhibit-at-state-museum I don't recall anyone flying a free air cooled Rotax on a Kolb successfully. Yours may be an exception. Don't know of any published updates for the Twinstar. It was not a popular model and kits only produced a couple years. Strong lateral bracing of the leading edge of the wing is extremely important to me. Poor/weak lateral bracing can lead to leading edge failure. This causes the Kolb to stop flying immediately. Lower tail post bracing makes it last longer. I don't know a whole lot about the Twinstar. The one Kolb model I never flew. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Sunday, April 09, 2017 4:33 PM Subject: Kolb-List: Kolb Twinstar (original version) info request OK, now that I've got that short nose Kolb bit out of my system.... I'm now the proud owner of an N-numbered early Kolb Twinstar (restoration project). IIRC, its serial number is in the low 20's range. A little rusty, but we've peeled the fabric on one wing & the aluminum seems to be in good shape, with very little corrosion, considering that it spent its entire past life in central FL. This one's got a Rotax 503 (converted from single to dual carbs, and to free air cooling) that seems to be in great shape. The previous owner is a close friend who was the builder. I trust what he tells me, and he says that it always cooled fine running it free-air with some added ducting. I'll be replacing hardware, 'soft' parts, etc, but don't intend on doing a showplane restoration; just a safe, nice flying 'after supper' flyer. I've got the plans for the plane, but I'm hoping that you experienced Kolbers can share any suggested mods to these early models, that will make them safer/more durable/etc. Is there a published list of any/all service bulletins or recommended updates? For instance, I've seen the advice to add braces to the tailspring stinger. And I know that the later Twinstars have mass balances on at least some of the control surfaces; is it recommended to add them to the early models? This one does not have any mass balances anywhere. Who's recovered one? Any issues when you drilled out the rivets to remove the ailerons, etc for recovering? Any advice will be appreciated. Thanks, Charlie ________________________________________________________________________________
Date: Apr 16, 2017
On Sun, Apr 16, 2017 at 5:27 PM, John Hauck wrote: > > Sounds good. > > Reckon sitting more nose high helped with your takeoff? I think that it did, seems a lot shorter. I just went back and looked at the video and as near as I can tell I lifted off at 34 MPH indicated. Stall is 29-30 . With the taller tires it is sitting at the angle that it is when it actually stalls, so it would appear to be at optimum attitude. I am experiencing some bouncing at the same time that it wants to fly. Not sure if it is dribbling or, starting to bounce. Need more take off's to tell. Actually an observer would be just the thing. Larry ________________________________________________________________________________
Date: Apr 16, 2017
Hey, Larry, you got an interesting problem. Id be gad to observe & photograph your TOs Just pay my travel from Maine! Fair winds, Russ K > On Apr 16, 2017, at 7:53 PM, Larry Cottrell wrote: > > > On Sun, Apr 16, 2017 at 5:27 PM, John Hauck wrote: >> >> Sounds good. >> >> Reckon sitting more nose high helped with your takeoff? > > > I think that it did, seems a lot shorter. I just went back and looked > at the video and as near as I can tell I lifted off at 34 MPH > indicated. Stall is 29-30 . With the taller tires it is sitting at the > angle that it is when it actually stalls, so it would appear to be at > optimum attitude. > > I am experiencing some bouncing at the same time that it wants to fly. > Not sure if it is dribbling or, starting to bounce. Need more take > off's to tell. Actually an observer would be just the thing. > > Larry > > > ________________________________________________________________________________
Date: Apr 16, 2017
Hey, Larry, you got an interesting problem. Id be gad to observe & photograph your TOs Just pay my travel from Maine! Fair winds, Russ K Sounds good, but after buying all those rims, tires and tubes, my slush fund is a bit under the weather. However if you toss your stuff in your plane and start out now, you could be here in a week or two. Larry ________________________________________________________________________________
Date: Apr 16, 2017
Would love to fly out to you but I=99m plane-less at the mo. Have made 6 coast-coast trips in Cessnas, GREAT fun & would love to do another. I=99ll work on the Lotto Good luck, Russ > On Apr 16, 2017, at 8:15 PM, Larry Cottrell wrote: > > > > Hey, Larry, you got an interesting problem. I=99d be gad to observe & > photograph your TO=99s > Just pay my travel from Maine! > Fair winds, > Russ K > > Sounds good, but after buying all those rims, tires and tubes, my > slush fund is a bit under the weather. However if you toss your stuff > in your plane and start out now, you could be here in a week or two. > Larry > > > > ________________________________________________________________________________
Date: Apr 16, 2017
Maybe you are trying to make the airplane fly too soon. Keep the nose down until you get well stall, then pull the nose up. It gets light, but not light enough to fly. 5 psi in big tires have a lot of reflex. Just the thoughts of a guy that has never flown anything bigger than an 8x6, which seemed huge for a short time after upsizing from 6x6. Now they are just regular tires. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Sunday, April 16, 2017 6:53 PM Subject: Re: Kolb-List: Baby's got some new shoes --> On Sun, Apr 16, 2017 at 5:27 PM, John Hauck wrote: > > Sounds good. > > Reckon sitting more nose high helped with your takeoff? I think that it did, seems a lot shorter. I just went back and looked at the video and as near as I can tell I lifted off at 34 MPH indicated. Stall is 29-30 . With the taller tires it is sitting at the angle that it is when it actually stalls, so it would appear to be at optimum attitude. I am experiencing some bouncing at the same time that it wants to fly. Not sure if it is dribbling or, starting to bounce. Need more take off's to tell. Actually an observer would be just the thing. Larry ________________________________________________________________________________
info request
Date: Apr 16, 2017
You're right about the little tubes cracking. One of my wing leading edge tubes had some corrosion & a big crack about half way around it near the root rib. After drilling it free, the diagonal tube tying it to the main spar showed cracks in the bends on both ends. I'll be adding new diagonals, either of larger aluminum, or some 4130 tubes the same size. (Easier to form safely, by using a little heat.) Thanks for the addtl info. You may well get a call from me before this project is finished. :-) Charlie On 4/16/2017 5:35 PM, John Hauck wrote: > > Actually, the two 5/16" tubes are fabric braces to keep the fabric > from pulling the aluminum rib nose inward. There is no lateral > bracing of the leading edge tube except a long 5/16 alum tube that is > in compression. > > The bow tip doesn't do much for lateral bracing of the leading edge > tube. That's all you have to keep the rib noses in column. Once they > get pulled out of column, they will probably fail. > > The small 5/16 tubes are flattened, bent, and riveted. They tend to > break at this point from vibration with not a whole lot of time on them. > > I used two 1/2" alum tubes, one inboard and one outboard, diagonally > working with each other, attached to the leading edge tube and the > main spare. Wish I had a photo of my wing handy. If I can find one I > will share it. > > I may be overly cautious, but it makes me feel more comfortable, > especially when I get caught in extremely rough air. > > Sorry for the delay in responding. Just got home from a 4 day trip. > > If you need more info, call me. 334-567-6280 > > john h > > mkIII > > Titus, Alabama > > *From:*owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] *On Behalf Of *Charlie > England > *Sent:* Thursday, April 13, 2017 11:05 AM > *To:* kolb-list(at)matronics.com > *Subject:* Kolb-List: Leading edge bracing; was: Kolb Twinstar > (original version) info request > > John, > > You mentioned leading edge bracing. This is all I see in the Twinstar > I'm restoring. There's nothing along the rest of the leading edge that > triangulates/ braces the leading edge. > > Would you consider this adequate? It's easy to add now, with the cover > coming off. > > Thanks, > > Charlie > > Thanks, John. I wasn't sure about how rugged the tubes would be when > driving out mandrels, etc. I use similar tricks on the heavier > experimentals I've owned. I've got a spring loaded center punch that I > ground to a flat nosed, straight shaft, & use it to punch out driven > rivets after drilling the heads. I also use small, flush cutting > 'dykes' (diagonal wire cutters) to grab pop rivet heads > > On 4/9/2017 5:58 PM, John Hauck wrote: > > > Charlie E/Kolbers: > > I have recovered a bunch of them. All that I tore up and a few I didn't. > > Drilling rivets can be accomplished once you have the mandrels removed. It takes a 1/16" punch, or you can use a pulled mandrel, grind the end flat, hold with vise grips, and knock out with a hammer. The rivet needs to be held to prevent spinning. I grind a V in the end of a hack saw blade with sharp beveled edges. Use that to push up under the rivet to lock it in place while drilling. > > 4130 airframes should be tube sealed when fabricated. 99% of Kolbs probably have never been tube sealed. Their builders probably never heard of tube sealing. 4130 rusts from inside out if not sealed. That would worry me with an old fuselage, especially a Twinstar. I can't remember exactly what the fuselage looks like other that the root tube that seats and stuff are attached to. This I would make sure is rust free on the inside. > > I helped Brother Jim rebuild Adriel Heisey's Twinstar, Navajo Nation pilot that shot aerial photos published in Nat Geo and other pubs, that he crashed in a wind storm. It was frightening when we started cutting tubing. Most were rusted well beyond serviceability. Here are photos of his Twinstar: > > https://uanews.arizona.edu/story/aerial-photos-of-archaeological-sites-on-exhibit-at-state-museum > > I don't recall anyone flying a free air cooled Rotax on a Kolb successfully. Yours may be an exception. > > Don't know of any published updates for the Twinstar. It was not a popular model and kits only produced a couple years. > > Strong lateral bracing of the leading edge of the wing is extremely important to me. Poor/weak lateral bracing can lead to leading edge failure. This causes the Kolb to stop flying immediately. > > Lower tail post bracing makes it last longer. > > I don't know a whole lot about the Twinstar. The one Kolb model I never flew. > > john h > > mkIII > > Titus, Alabama > > -----Original Message----- > > From:owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England > > Sent: Sunday, April 09, 2017 4:33 PM > > To:kolb-list(at)matronics.com > > Subject: Kolb-List: Kolb Twinstar (original version) info request > > > OK, now that I've got that short nose Kolb bit out of my system.... > > I'm now the proud owner of an N-numbered early Kolb Twinstar (restoration project). IIRC, its serial number is in the low 20's range. > > A little rusty, but we've peeled the fabric on one wing & the aluminum seems to be in good shape, with very little corrosion, considering that it spent its entire past life in central FL. > > This one's got a Rotax 503 (converted from single to dual carbs, and to free air cooling) that seems to be in great shape. The previous owner is a close friend who was the builder. I trust what he tells me, and he says that it always cooled fine running it free-air with some added ducting. > > I'll be replacing hardware, 'soft' parts, etc, but don't intend on doing a showplane restoration; just a safe, nice flying 'after supper' flyer. > > I've got the plans for the plane, but I'm hoping that you experienced Kolbers can share any suggested mods to these early models, that will make them safer/more durable/etc. Is there a published list of any/all service bulletins or recommended updates? For instance, I've seen the advice to add braces to the tailspring stinger. And I know that the later Twinstars have mass balances on at least some of the control surfaces; is it recommended to add them to the early models? This one does not have any mass balances anywhere. > > Who's recovered one? Any issues when you drilled out the rivets to remove the ailerons, etc for recovering? > > Any advice will be appreciated. > > Thanks, > > Charlie > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
version)
Date: Apr 16, 2017
Thanks, Richard; I'll look at doing that mod, as well. BTW, my plans just mention '1/8 x 1/8 pop rivets'. What's the rivet of choice? Just a typical 18-8 stainless, or 304 stainless? the 316 stainless are pricey enough that enough to do the whole plane might cost as much as the whole kit. :-) Charlie On 4/13/2017 9:17 PM, Richard Pike wrote: > > I'm not John, but if you scroll down to page 21 in the MKIII Yellow Book, you will see what Kolb though to be a very useful reinforcement. > http://oh2fly.net/oldpoops/Lexan%20rear%20enclosure.html > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough. Being forgiven is wonderful. > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 16, 2017
I'm tired and can't type. I meant to say "keep the nose down until you get well "above" stall." john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck Sent: Sunday, April 16, 2017 7:51 PM Subject: RE: Kolb-List: Baby's got some new shoes Maybe you are trying to make the airplane fly too soon. Keep the nose down until you get well stall, then pull the nose up. It gets light, but not light enough to fly. 5 psi in big tires have a lot of reflex. Just the thoughts of a guy that has never flown anything bigger than an 8x6, which seemed huge for a short time after upsizing from 6x6. Now they are just regular tires. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Sunday, April 16, 2017 6:53 PM Subject: Re: Kolb-List: Baby's got some new shoes --> On Sun, Apr 16, 2017 at 5:27 PM, John Hauck wrote: > > Sounds good. > > Reckon sitting more nose high helped with your takeoff? I think that it did, seems a lot shorter. I just went back and looked at the video and as near as I can tell I lifted off at 34 MPH indicated. Stall is 29-30 . With the taller tires it is sitting at the angle that it is when it actually stalls, so it would appear to be at optimum attitude. I am experiencing some bouncing at the same time that it wants to fly. Not sure if it is dribbling or, starting to bounce. Need more take off's to tell. Actually an observer would be just the thing. Larry ________________________________________________________________________________
Date: Apr 16, 2017
Maybe you are trying to make the airplane fly too soon. Keep the nose down until you get well stall, then pull the nose up. --------------------------------------------------------------------------------------------------------------------------- Actually it was the "bouncing" that prompted me to pull it up. Something similar happened on the first take off, so I was prepared for it. Just don't know what causes it. I am wondering if a bit more air might clear it up. The first time I can fly, I will set another camera up to film the take off as it happens from in front. It is nothing more than a curious occurrence. Larry ________________________________________________________________________________
Date: Apr 16, 2017
Heat will definitely break JB weld loose. I actually just replaced the tailw heel on my Firestar 1 with the new Kolb breakaway unit. I had drill out the f iberglass tail strut which was a real pain, but JB had failed at tailwheel a ssembly. So I installed a new T7075 tail strut. I just locked it into lower vertical stabilizer with a single bolt at both ends. Here's a couple of pic tures. I did coat the inside of both end with a liberal amount of white silicon to s eal out moisture. George H. Firestar 1, #FS100 14GDH Mesick, MI Have a great day! > On Apr 16, 2017, at 11:57 AM, KJ4CTZ wrote: > > > Thanks guys, > > I will try mild heat first. If no success I will cut off and put new assem bly on. > > Should it also be JB Welded back on? I assume so but open to suggestions. > > This forum is great and I appreciate everyone's comments. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=468526#468526 > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Apr 17, 2017
Wow ! Now I'm suffering from "Tire Envy" ! The airplane looks mighty serious with those tires. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Sun, 4/16/17, Larry Cottrell wrote: Subject: Re: Kolb-List: Baby's got some new shoes To: "kolb-list(at)matronics.com" Date: Sunday, April 16, 2017, 6:15 PM Cottrell "John Hauck" Maybe you are trying to make the airplane fly too soon. Keep the nose down until you get well stall, then pull the nose up. --------------------------------------------------------------------------------------------------------------------------- Actually it was the "bouncing" that prompted me to pull it up. Something similar happened on the first take off, so I was prepared for it. Just don't know what causes it. I am wondering if a bit more air might clear it up. The first time I can fly, I will set another camera up to film the take off as it happens from in front. It is nothing more than a curious occurrence. Larry The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 17, 2017
Here is a PDF of the VG vortex generator article. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468572#468572 Attachments: http://forums.matronics.com//files/article_13498_181.pdf ________________________________________________________________________________
Date: Apr 17, 2017
Subject: Re: Matronics Internet Connectivity Upgrades April 17-18 2017
Matt I'm a retired network engineer. I know what it takes to do what you do. Super job! Thanks Rick Neilsen On Sat, Apr 15, 2017 at 10:10 PM, Matt Dralle wrote: > > > Dear Matronics Email List an/or Forum User, > > The Matronics Internet connectivity will be upgraded on April 17 through > April 18, 2017. During the upgrade connections to the Matronics and > AeroElectric web servers may be unavailable. Additionally, Matronics Email > List email will not be redistributed. > > Internet Connectivity bandwidth will be significantly increased by a > factor of 7X for downloads and 50X for uploads, which represents a > significant increase in performance. Reliability should also increase in > terms. > > I will send out a follow up message when the upgrade has been completed. > > Best Regards, > > Matt Dralle > Matronics Email List and Forum Admin. > > > Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 > 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email > http://www.matronics.com/ WWW | Featuring Products For Aircraft > > ________________________________________________________________________________
Subject: Re: ANOTHER Wheel and Tire Mystery
Date: Apr 18, 2017
> " Is there a known, good, light weight, off-road alternative tire" I am a total nube and know nuthin, however I read somewhere that a fella went to a GA shop and asked for old tires. He found some large ones that were not safe for GA but worked fine for light weight ultralights. ________________________________________________________________________________
Subject: RE: On MZ201/M202
Date: Apr 18, 2017
> I just thought that I'd start a thread concerning the MZ201 and MZ202 engines. I am interested in this topic. I have a FS I that needs recovering. I have a low hours 503 that came with it but I play with the idea of using my new-new MZ202 on it. I have no idea how that would work out. I am a total nube. ________________________________________________________________________________
Date: Apr 18, 2017
Subject: Re: RE: On MZ201/M202
George- This is Jack Hart's "Firefly Slide Show". Probably the best info on taking off weight and adapting engines. I don't know why Jack hasn't been posting on the List lately, but Bookmark this site and read all of it. Very clear reading. He shows info on an MZ34, so a lot of mounting ideas may be similar. No matter what, it is a very informative site. http://www.jackbhart.com/firefly/firefly.html Bill Sullivan -------------------------------------------- On Tue, 4/18/17, George Bearden wrote: Subject: Kolb-List: RE: On MZ201/M202 To: kolb-list(at)matronics.com Date: Tuesday, April 18, 2017, 6:11 AM Bearden" > I just thought that I'd start a thread concerning the MZ201 and MZ202 engines. I am interested in this topic. I have a FS I that needs recovering. I have a low hours 503 that came with it but I play with the idea of using my new-new MZ202 on it. I have no idea how that would work out. I am a total nube. ________________________________________________________________________________
Date: Apr 18, 2017
Are you the same George "Chip" Bearden that flew contest sailplanes? Bill Berle (Contest # VB back in a previous century) -------------------------------------------- On Tue, 4/18/17, George Bearden wrote: Subject: Kolb-List: Re: ANOTHER Wheel and Tire Mystery To: kolb-list(at)matronics.com Date: Tuesday, April 18, 2017, 2:25 AM Bearden" > " Is there a known, good, light weight, off-road alternative tire" I am a total nube and know nuthin, however I read somewhere that a fella went to a GA shop and asked for old tires. He found some large ones that were not safe for GA but worked fine for light weight ultralights. The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 19, 2017
Subject: spiral jetty video
this is a remake of a video that i did a couple years ago.. i've done it with a different video editor that will go to full screen. it is 5 min long, enjoy https://vimeo.com/213943022 boyd young ________________________________________________________________________________
Date: Apr 20, 2017
Subject: Re: spiral jetty video
Private video, need password. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Wed, 4/19/17, B Young wrote: Subject: Kolb-List: spiral jetty video To: "Kolb List" Date: Wednesday, April 19, 2017, 8:34 PM this is a remake of a video that i did a couple years ago.. i've done it with a different video editor that will go to full screen. it is 5 min long, enjoy https://vimeo.com/213943022 boyd young ________________________________________________________________________________
Date: Apr 20, 2017
My biggest apologies the pass word is beekeeper Boyd Young PS I've made bigger mistakes On Apr 20, 2017 12:24 AM, "Bill Berle" wrote: > > Private video, need password. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and > for-profit entities > > -------------------------------------------- > On Wed, 4/19/17, B Young wrote: > > Subject: Kolb-List: spiral jetty video > To: "Kolb List" > Date: Wednesday, April 19, 2017, 8:34 PM > > this is a remake of a > video that i did a couple years ago.. i've done it > with a different video editor that will go to full screen. > it is 5 min long, enjoy > https://vimeo.com/213943022 > > boyd young > > ________________________________________________________________________________
Date: Apr 20, 2017
Ok all in one email https://vimeo.com/213943022 Password beekeeper boyd young On Apr 20, 2017 12:24 AM, "Bill Berle" wrote: > > Private video, need password. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and > for-profit entities > > -------------------------------------------- > On Wed, 4/19/17, B Young wrote: > > Subject: Kolb-List: spiral jetty video > To: "Kolb List" > Date: Wednesday, April 19, 2017, 8:34 PM > > this is a remake of a > video that i did a couple years ago.. i've done it > with a different video editor that will go to full screen. > it is 5 min long, enjoy > https://vimeo.com/213943022 > > boyd young > > ________________________________________________________________________________
Date: Apr 20, 2017
Hey Boyd, Larry's password doesn't work. Help me out, I want to watch it. Sent with AquaMail for Android http://www.aqua-mail.com On April 19, 2017 11:38:11 PM B Young wrote: > this is a remake of a video that i did a couple years ago.. i've done it > with a different video editor that will go to full screen. it is 5 min > long, enjoy > > https://vimeo.com/213943022 > > boyd young ________________________________________________________________________________
Date: Apr 20, 2017
Thanks!! Sent with AquaMail for Android http://www.aqua-mail.com On April 20, 2017 10:18:21 AM B Young wrote: > Ok all in one email > > https://vimeo.com/213943022 > > Password beekeeper > > boyd young > > On Apr 20, 2017 12:24 AM, "Bill Berle" wrote: > >> >> Private video, need password. >> >> Bill Berle >> www.ezflaphandle.com - safety & performance upgrade for light aircraft >> www.grantstar.net - winning proposals for non-profit and >> for-profit entities >> >> -------------------------------------------- >> On Wed, 4/19/17, B Young wrote: >> >> Subject: Kolb-List: spiral jetty video >> To: "Kolb List" >> Date: Wednesday, April 19, 2017, 8:34 PM >> >> this is a remake of a >> video that i did a couple years ago.. i've done it >> with a different video editor that will go to full screen. >> it is 5 min long, enjoy >> https://vimeo.com/213943022 >> >> boyd young >> >> >> >> >> ________________________________________________________________________________
Date: Apr 20, 2017
Mistakes???? I thought that I held the worldwide patent and ownership of the entire concept! Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Thu, 4/20/17, B Young wrote: Subject: Re: Kolb-List: spiral jetty video To: "Kolb List" Date: Thursday, April 20, 2017, 7:14 AM Ok all in one email https://vimeo.com/213943022 Password beekeeper boyd young On Apr 20, 2017 12:24 AM, "Bill Berle" wrote: Bill Berle Private video, need password. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities ------------------------------ -------------- On Wed, 4/19/17, B Young wrote: Subject: Kolb-List: spiral jetty video To: "Kolb List" Date: Wednesday, April 19, 2017, 8:34 PM this is a remake of a video that i did a couple years ago.. i've done it with a different video editor that will go to full screen. it is 5 min long, enjoy https://vimeo.com/213943022 boyd young ==== ============================== = -List" rel="noreferrer" target="_blank">http://www.matronics.com/ Navigator?Kolb-List ==== ============================== = FORUMS - eferrer" target="_blank">http://forums.matronics.com ==== ============================== = WIKI - errer" target="_blank">http://wiki.matronics.com ==== ============================== = b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/ contribution ==== ============================== = ________________________________________________________________________________
Subject: Air start cart...MA-1A
Date: Apr 21, 2017
Off subject...but first ..heck of a deal in Salton California...Kolb Firestar 1 with trailer and wrecked Firestar...5k for all... Just too far away for me...Came on Barnstormers yesterday...likely gone by now..! off Subject....for you Viet Nam guys and some others.... Anyone familiar with the Air Start Cart ...model MA-1A . pn 370400 I have one by trade...hasn't been run in 7 or so years...good oil supply...will add jet A and two 12 volt batteries later today...Not a keeper...will advertise it on Barnstormers and possibly EBAY... Turbine is an Garrett/Air Research GTCE85-15-1. Sn 36P-355 PN 376490... I heard it run back in 2010...there bouts...Sitting in the dry ....til I tarped it last fall ... Any info appreciated...Herb On 04/20/2017 11:47 AM, Bill Berle wrote: > > Mistakes???? I thought that I held the worldwide patent and ownership of the entire concept! > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Thu, 4/20/17, B Young wrote: > > Subject: Re: Kolb-List: spiral jetty video > To: "Kolb List" > Date: Thursday, April 20, 2017, 7:14 AM > > Ok all in one email > > https://vimeo.com/213943022 > Password beekeeper > > boyd young > > On Apr 20, 2017 12:24 > AM, "Bill Berle" > wrote: > Bill Berle > > > > Private video, need password. > > > > Bill Berle > > www.ezflaphandle.com > - safety & performance upgrade for light aircraft > > www.grantstar.net > - winning proposals for non-profit and for-profit > entities > > > > ------------------------------ -------------- > > On Wed, 4/19/17, B Young > wrote: > > > > Subject: Kolb-List: spiral jetty video > > To: "Kolb List" > > Date: Wednesday, April 19, 2017, 8:34 PM > > > > this is a remake of a > > video that i did a couple years ago.. i've done it > > with a different video editor that will go to full > screen. > > it is 5 min long, enjoy > > https://vimeo.com/213943022 > > > > boyd young > > > > ==== ============================== = > > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/ > Navigator?Kolb-List > > ==== ============================== = > > FORUMS - > > eferrer" > target="_blank">http://forums.matronics.com > > ==== ============================== = > > WIKI - > > errer" > target="_blank">http://wiki.matronics.com > > ==== ============================== = > > b Site - > > -Matt Dralle, List Admin. > > rel="noreferrer" > target="_blank">http://www.matronics.com/ > contribution > > ==== ============================== = > > > > > > > > > > ________________________________________________________________________________
Date: Apr 21, 2017
Subject: Re: Air start cart...MA-1A
Yeah, if it's what I think you're talking about? We used them for ground power and air starting of the engines (J-79)on the F-4 Phantoms when I was Crew Chief in U.S. Air Force. Engine oil should be MIL-L-7808 as I recall. Fuel was JP4. George H. Firestar 1, #FS100 14GDH Mesick, Michigan gdhelton(at)gmail.com Have a great day! > On Apr 21, 2017, at 11:46 AM, Hoppy wrote: > > > Off subject...but first ..heck of a deal in Salton California...Kolb Firestar 1 with trailer and wrecked Firestar...5k for all... Just too far away for me...Came on Barnstormers yesterday...likely gone by now..! > > off Subject....for you Viet Nam guys and some others.... > > Anyone familiar with the Air Start Cart ...model MA-1A . pn 370400 > > I have one by trade...hasn't been run in 7 or so years...good oil supply...will add jet A and two 12 volt batteries later today...Not a keeper...will advertise it on Barnstormers and possibly EBAY... Turbine is an Garrett/Air Research GTCE85-15-1. Sn 36P-355 PN 376490... > > I heard it run back in 2010...there bouts...Sitting in the dry ....til I tarped it last fall ... Any info appreciated...Herb > > >> On 04/20/2017 11:47 AM, Bill Berle wrote: >> >> Mistakes???? I thought that I held the worldwide patent and ownership of the entire concept! >> >> Bill Berle >> www.ezflaphandle.com - safety & performance upgrade for light aircraft >> www.grantstar.net - winning proposals for non-profit and for-profit entities >> >> -------------------------------------------- >> On Thu, 4/20/17, B Young wrote: >> >> Subject: Re: Kolb-List: spiral jetty video >> To: "Kolb List" >> Date: Thursday, April 20, 2017, 7:14 AM >> Ok all in one email >> https://vimeo.com/213943022 >> Password beekeeper >> boyd young >> On Apr 20, 2017 12:24 >> AM, "Bill Berle" >> wrote: >> Bill Berle >> Private video, need password. >> Bill Berle >> www.ezflaphandle.com >> - safety & performance upgrade for light aircraft >> www.grantstar.net >> - winning proposals for non-profit and for-profit >> entities >> ------------------------------ -------------- >> On Wed, 4/19/17, B Young >> wrote: >> Subject: Kolb-List: spiral jetty video >> To: "Kolb List" >> Date: Wednesday, April 19, 2017, 8:34 PM >> this is a remake of a >> video that i did a couple years ago.. i've done it >> with a different video editor that will go to full >> screen. >> it is 5 min long, enjoy >> https://vimeo.com/213943022 >> boyd young >> ==== ============================== = >> -List" rel="noreferrer" >> target="_blank">http://www.matronics.com/ >> Navigator?Kolb-List >> ==== ============================== = >> FORUMS - >> eferrer" >> target="_blank">http://forums.matronics.com >> ==== ============================== = >> WIKI - >> errer" >> target="_blank">http://wiki.matronics.com >> ==== ============================== = >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" >> target="_blank">http://www.matronics.com/ >> contribution >> ==== ============================== = >> >> >> >> > > > > ________________________________________________________________________________
Date: Apr 21, 2017
Don't guess the list monsters will scream about one picture...:-) Herb On 04/21/2017 12:37 PM, George Helton wrote: > > Yeah, if it's what I think you're talking about? We used them for ground power and air starting of the engines (J-79)on the F-4 Phantoms when I was Crew Chief in U.S. Air Force. Engine oil should be MIL-L-7808 as I recall. Fuel was JP4. > > George H. > Firestar 1, #FS100 > 14GDH > Mesick, Michigan > gdhelton(at)gmail.com > > Have a great day! > >> On Apr 21, 2017, at 11:46 AM, Hoppy wrote: >> >> >> Off subject...but first ..heck of a deal in Salton California...Kolb Firestar 1 with trailer and wrecked Firestar...5k for all... Just too far away for me...Came on Barnstormers yesterday...likely gone by now..! >> >> off Subject....for you Viet Nam guys and some others.... >> >> Anyone familiar with the Air Start Cart ...model MA-1A . pn 370400 >> >> I have one by trade...hasn't been run in 7 or so years...good oil supply...will add jet A and two 12 volt batteries later today...Not a keeper...will advertise it on Barnstormers and possibly EBAY... Turbine is an Garrett/Air Research GTCE85-15-1. Sn 36P-355 PN 376490... >> >> I heard it run back in 2010...there bouts...Sitting in the dry ....til I tarped it last fall ... Any info appreciated...Herb >> >> >>> On 04/20/2017 11:47 AM, Bill Berle wrote: >>> >>> Mistakes???? I thought that I held the worldwide patent and ownership of the entire concept! >>> >>> Bill Berle >>> www.ezflaphandle.com - safety & performance upgrade for light aircraft >>> www.grantstar.net - winning proposals for non-profit and for-profit entities >>> >>> -------------------------------------------- >>> On Thu, 4/20/17, B Young wrote: >>> >>> Subject: Re: Kolb-List: spiral jetty video >>> To: "Kolb List" >>> Date: Thursday, April 20, 2017, 7:14 AM >>> Ok all in one email >>> https://vimeo.com/213943022 >>> Password beekeeper >>> boyd young >>> On Apr 20, 2017 12:24 >>> AM, "Bill Berle" >>> wrote: >>> Bill Berle >>> Private video, need password. >>> Bill Berle >>> www.ezflaphandle.com >>> - safety & performance upgrade for light aircraft >>> www.grantstar.net >>> - winning proposals for non-profit and for-profit >>> entities >>> ------------------------------ -------------- >>> On Wed, 4/19/17, B Young >>> wrote: >>> Subject: Kolb-List: spiral jetty video >>> To: "Kolb List" >>> Date: Wednesday, April 19, 2017, 8:34 PM >>> this is a remake of a >>> video that i did a couple years ago.. i've done it >>> with a different video editor that will go to full >>> screen. >>> it is 5 min long, enjoy >>> https://vimeo.com/213943022 >>> boyd young >>> ==== ============================== = >>> -List" rel="noreferrer" >>> target="_blank">http://www.matronics.com/ >>> Navigator?Kolb-List >>> ==== ============================== = >>> FORUMS - >>> eferrer" >>> target="_blank">http://forums.matronics.com >>> ==== ============================== = >>> WIKI - >>> errer" >>> target="_blank">http://wiki.matronics.com >>> ==== ============================== = >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" >>> target="_blank">http://www.matronics.com/ >>> contribution >>> ==== ============================== = >>> >>> >>> >>> >> >> >> > > ________________________________________________________________________________
Date: Apr 21, 2017
What's wrong with a kerosene burning Kolb? On Fri, Apr 21, 2017 at 1:03 PM, Hoppy wrote: > Don't guess the list monsters will scream about one picture...:-) Herb > > > On 04/21/2017 12:37 PM, George Helton wrote: > >> >> Yeah, if it's what I think you're talking about? We used them for ground >> power and air starting of the engines (J-79)on the F-4 Phantoms when I was >> Crew Chief in U.S. Air Force. Engine oil should be MIL-L-7808 as I recall. >> Fuel was JP4. >> >> George H. >> Firestar 1, #FS100 >> 14GDH >> Mesick, Michigan >> gdhelton(at)gmail.com >> >> Have a great day! >> >> On Apr 21, 2017, at 11:46 AM, Hoppy wrote: >>> >>> >>> Off subject...but first ..heck of a deal in Salton California...Kolb >>> Firestar 1 with trailer and wrecked Firestar...5k for all... Just too far >>> away for me...Came on Barnstormers yesterday...likely gone by now..! >>> >>> off Subject....for you Viet Nam guys and some others.... >>> >>> Anyone familiar with the Air Start Cart ...model MA-1A . pn 370400 >>> >>> I have one by trade...hasn't been run in 7 or so years...good oil >>> supply...will add jet A and two 12 volt batteries later today...Not a >>> keeper...will advertise it on Barnstormers and possibly EBAY... Turbine is >>> an Garrett/Air Research GTCE85-15-1. Sn 36P-355 PN 376490... >>> >>> I heard it run back in 2010...there bouts...Sitting in the dry ....til >>> I tarped it last fall ... Any info appreciated...Herb >>> >>> >>> On 04/20/2017 11:47 AM, Bill Berle wrote: >>>> >>>> Mistakes???? I thought that I held the worldwide patent and ownership >>>> of the entire concept! >>>> >>>> Bill Berle >>>> www.ezflaphandle.com - safety & performance upgrade for light aircraft >>>> www.grantstar.net - winning proposals for non-profit and >>>> for-profit entities >>>> >>>> -------------------------------------------- >>>> On Thu, 4/20/17, B Young wrote: >>>> >>>> Subject: Re: Kolb-List: spiral jetty video >>>> To: "Kolb List" >>>> Date: Thursday, April 20, 2017, 7:14 AM >>>> Ok all in one email >>>> https://vimeo.com/213943022 >>>> Password beekeeper >>>> boyd young >>>> On Apr 20, 2017 12:24 >>>> AM, "Bill Berle" >>>> wrote: >>>> Bill Berle >>>> Private video, need password. >>>> Bill Berle >>>> www.ezflaphandle.com >>>> - safety & performance upgrade for light aircraft >>>> www.grantstar.net >>>> - winning proposals for non-profit and for-profit >>>> entities >>>> ------------------------------ -------------- >>>> On Wed, 4/19/17, B Young >>>> wrote: >>>> Subject: Kolb-List: spiral jetty video >>>> To: "Kolb List" >>>> Date: Wednesday, April 19, 2017, 8:34 PM >>>> this is a remake of a >>>> video that i did a couple years ago.. i've done it >>>> with a different video editor that will go to full >>>> screen. >>>> it is 5 min long, enjoy >>>> https://vimeo.com/213943022 >>>> boyd young >>>> ==== ============================== = >>>> -List" rel="noreferrer" >>>> target="_blank">http://www.matronics.com/ >>>> Navigator?Kolb-List >>>> ==== ============================== = >>>> FORUMS - >>>> eferrer" >>>> target="_blank">http://forums.matronics.com >>>> ==== ============================== = >>>> WIKI - >>>> errer" >>>> target="_blank">http://wiki.matronics.com >>>> ==== ============================== = >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> rel="noreferrer" >>>> target="_blank">http://www.matronics.com/ >>>> contribution >>>> ==== ============================== = >>>> >>>> >>>> >>>> >>> >>> >>> >> >> >> > ________________________________________________________________________________
Date: Apr 21, 2017
Subject: Tundra tires
I believe that I mentioned in my earlier post concerning the tundra tires, that I had some dribble in my right tire when taking off. I considered that it might be because I only had 5 pounds of air in the tires. I aired the tires up to 7 lbs. just in case that was what was going on. I finally caught a bit of a break in the weather, so I decided to set up some cameras at differing angles to see if I could figure out what is going on. I of course checked the tires and gear leg to make sure that the problem was not with them. Every thing seemed snug and normal. I collected all the video and slapped together a short video, and was able to see the effects but not the reason. I have however come to a conclusion that satisfies me, correct or not. The dribble only occurs on take off and it comes at the last few seconds that the plane is still on the ground but getting lighter. The forward speed is around 40 MPH. It only occurs on take off. My landing was a wheel landing and I touched down at about 48 MPH and it did not bounce or dribble at all. While odd, it appears that I might have a somewhat useful aspect to it. I know when the wheel dribbles, I am at take off speed, and the plane is light enough to fly. :-) The video for what it is worth will be out later this evening. Any comments or thoughts will be entertained. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Apr 21, 2017
Subject: video- tundra tire
https://vimeo.com/214265452 password owyheeflyer Here is the video. You can determine your download speed by clicking on the HD in the lower right corner. It defaults to "Auto" Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Apr 22, 2017
Boyd, nicely done with some interesting history too. Lanny Sent from my iPad > On Apr 20, 2017, at 10:12 AM, B Young wrote: > > My biggest apologies the pass word is > > beekeeper > > Boyd Young > > PS I've made bigger mistakes > >> On Apr 20, 2017 12:24 AM, "Bill Berle" wrote: >> >> Private video, need password. >> >> Bill Berle >> www.ezflaphandle.com - safety & performance upgrade for light aircraft >> www.grantstar.net - winning proposals for non-profit and for-pr ofit entities >> >> -------------------------------------------- >> On Wed, 4/19/17, B Young wrote: >> >> Subject: Kolb-List: spiral jetty video >> To: "Kolb List" >> Date: Wednesday, April 19, 2017, 8:34 PM >> >> this is a remake of a >> video that i did a couple years ago.. i've done it >> with a different video editor that will go to full screen. >> it is 5 min long, enjoy >> https://vimeo.com/213943022 >> >> boyd young >> >> ========================= >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?Kolb-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= >> >> >> ________________________________________________________________________________
Subject: Re: New Break-away Tail Wheel
Date: Apr 22, 2017
Thanks guys, I applied a little heat with a propane torch and used a very large crecent wrench to twist off the old tailwheel. Worked like a charm. Thanks for the help, Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468682#468682 ________________________________________________________________________________
Date: Apr 24, 2017
Subject: Re: video- tundra tire
I had the same problem with my Twinstar MK II many year ago Larry. Never did find a solution for it. I just got so I'd touch the brakes a bit just as I broke ground. Nice video! George H. Firestar 1, #FS100 14GDH gdhelton@ gmail.com Mesick, MI. Have a great day! > On Apr 22, 2017, at 12:15 AM, Larry Cottrell wrote: > > > https://vimeo.com/214265452 password owyheeflyer > > Here is the video. You can determine your download speed by clicking > on the HD in the lower right corner. It defaults to "Auto" > > Larry > > -- > The older I get, the less tolerant I am of those who are intolerant of others. > > If you forward this email, or any part of it, please remove my email > address before sending. > > > ________________________________________________________________________________
Date: Apr 24, 2017
Thanks for the comments. I have decided that it going to be my cue as to when to rotate. I just wonder why it is only one tire? Larry On Mon, Apr 24, 2017 at 6:02 PM, George Helton wrote: > > I had the same problem with my Twinstar MK II many year ago Larry. Never did find a solution for it. I just got so I'd touch the brakes a bit just as I broke ground. Nice video! > > George H. > Firestar 1, #FS100 > 14GDH > gdhelton@ gmail.com > Mesick, MI. > Have a great day! > >> On Apr 22, 2017, at 12:15 AM, Larry Cottrell wrote: >> >> >> https://vimeo.com/214265452 password owyheeflyer >> >> Here is the video. You can determine your download speed by clicking >> on the HD in the lower right corner. It defaults to "Auto" >> >> Larry >> >> -- >> The older I get, the less tolerant I am of those who are intolerant of others. >> >> If you forward this email, or any part of it, please remove my email >> address before sending. >> >> >> > > -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Apr 24, 2017
The one that doesn't bounce is the one that is better balanced. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Monday, April 24, 2017 7:25 PM Subject: Re: Kolb-List: video- tundra tire --> Thanks for the comments. I have decided that it going to be my cue as to when to rotate. I just wonder why it is only one tire? Larry On Mon, Apr 24, 2017 at 6:02 PM, George Helton wrote: > > I had the same problem with my Twinstar MK II many year ago Larry. Never did find a solution for it. I just got so I'd touch the brakes a bit just as I broke ground. Nice video! > > George H. > Firestar 1, #FS100 > 14GDH > gdhelton@ gmail.com > Mesick, MI. > Have a great day! > >> On Apr 22, 2017, at 12:15 AM, Larry Cottrell wrote: >> >> --> >> >> https://vimeo.com/214265452 password owyheeflyer >> >> Here is the video. You can determine your download speed by clicking >> on the HD in the lower right corner. It defaults to "Auto" >> >> Larry >> >> -- >> The older I get, the less tolerant I am of those who are intolerant of others. >> >> If you forward this email, or any part of it, please remove my email >> address before sending. >> >> >> > > -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Apr 24, 2017
Kinda what I was thinking. Easy to test; swap sides with the wheels & go fly. Charlie On 4/24/2017 7:36 PM, John Hauck wrote: > > The one that doesn't bounce is the one that is better balanced. > > john h > mkIII > Titus, Alabama > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell > Sent: Monday, April 24, 2017 7:25 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: video- tundra tire > > --> > > Thanks for the comments. I have decided that it going to be my cue as to when to rotate. I just wonder why it is only one tire? > > Larry > > On Mon, Apr 24, 2017 at 6:02 PM, George Helton wrote: >> >> I had the same problem with my Twinstar MK II many year ago Larry. Never did find a solution for it. I just got so I'd touch the brakes a bit just as I broke ground. Nice video! >> >> George H. >> Firestar 1, #FS100 >> 14GDH >> gdhelton@ gmail.com >> Mesick, MI. >> Have a great day! >> >>> On Apr 22, 2017, at 12:15 AM, Larry Cottrell wrote: >>> >>> --> >>> >>> https://vimeo.com/214265452 password owyheeflyer >>> >>> Here is the video. You can determine your download speed by clicking >>> on the HD in the lower right corner. It defaults to "Auto" >>> >>> Larry >>> --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 24, 2017
Big wide tires often need two plane balancing just like a car. Static balance often inadequate particularly on a lightly sprung support system..... Bob -----Original Message----- From: Charlie England Sent: Monday, April 24, 2017 7:33 PM Subject: Re: Kolb-List: video- tundra tire Kinda what I was thinking. Easy to test; swap sides with the wheels & go fly. Charlie On 4/24/2017 7:36 PM, John Hauck wrote: > > The one that doesn't bounce is the one that is better balanced. > > john h > mkIII > Titus, Alabama > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell > Sent: Monday, April 24, 2017 7:25 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: video- tundra tire > > --> > > Thanks for the comments. I have decided that it going to be my cue as to > when to rotate. I just wonder why it is only one tire? > > Larry > > On Mon, Apr 24, 2017 at 6:02 PM, George Helton wrote: >> >> I had the same problem with my Twinstar MK II many year ago Larry. Never >> did find a solution for it. I just got so I'd touch the brakes a bit just >> as I broke ground. Nice video! >> >> George H. >> Firestar 1, #FS100 >> 14GDH >> gdhelton@ gmail.com >> Mesick, MI. >> Have a great day! >> >>> On Apr 22, 2017, at 12:15 AM, Larry Cottrell >>> wrote: >>> >>> --> >>> >>> https://vimeo.com/214265452 password owyheeflyer >>> >>> Here is the video. You can determine your download speed by clicking >>> on the HD in the lower right corner. It defaults to "Auto" >>> >>> Larry >>> --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Valley Forge Plans
Date: Apr 25, 2017
Hey anybody have a set of Firestar II plans from the original Valley Forge,PA days that you'd like to sell .... bought a 1995 early serial # and would like to have the older drawings to go along with my rebuild... :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468792#468792 ________________________________________________________________________________
Date: Apr 26, 2017
Subject: aileron gap seal: when?
For you Twinstar builders/restorers, how/when do you install gap seals? My 1st gen plans say to install the seals before installing the hinges. I'm planning on using the latex finishing method, and I've used the Stewart water based glue for covering. Do you pre-shrink the gap seal fabric and glue it on after the rest of the finish work (final paint), then repaint after attaching the gap seal? Thanks, Charlie ________________________________________________________________________________
Date: Apr 26, 2017
Charlie E/Kolbers: Haven't covered a wing in 17 years, so if I am wrong someone will promptly correct me please. ;-) After you shoot the last coat of Polybrush (sealer), the gap seal is cemented to wing and aileron. I think I used 3" finishing tape and it is not shrunk. Use a small needle soldering iron to burn out the rivet holes. Hinges are riveted after finish painting. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Wednesday, April 26, 2017 8:47 AM Subject: Kolb-List: aileron gap seal: when? For you Twinstar builders/restorers, how/when do you install gap seals? My 1st gen plans say to install the seals before installing the hinges. I'm planning on using the latex finishing method, and I've used the Stewart water based glue for covering. Do you pre-shrink the gap seal fabric and glue it on after the rest of the finish work (final paint), then repaint after attaching the gap seal? Thanks, Charlie ________________________________________________________________________________
Date: Apr 26, 2017
Subject: recovering slingshot wing
is it acceptable to leave the rivet ends in the 5/16 tubing to rattle around ,or remove rib tops and bottoms ???? ________________________________________________________________________________
Subject: Re: recovering slingshot wing
Date: Apr 26, 2017
It must be acceptable; all of them do. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468833#468833 ________________________________________________________________________________
Subject: Re: aileron gap seal: when?
Date: Apr 26, 2017
Hi John, Thanks for the info. Your description is how I'm reading the plans. But I'm not sure how to manage a 12' aileron (flaperon) and a 15' wing when I'll need to flip the assembly numerous times while applying multiple finish coats, and keep the two components aligned well enough to avoid peeling off the gap seal from at least one side. Charlie On 4/26/2017 9:18 AM, John Hauck wrote: > > Charlie E/Kolbers: > > Haven't covered a wing in 17 years, so if I am wrong someone will > promptly correct me please. ;-) > > After you shoot the last coat of Polybrush (sealer), the gap seal is > cemented to wing and aileron. I think I used 3" finishing tape and it > is not shrunk. > > Use a small needle soldering iron to burn out the rivet holes. > > Hinges are riveted after finish painting. > > john h > > mkIII > > Titus, Alabama > > *From:*owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] *On Behalf Of *Charlie > England > *Sent:* Wednesday, April 26, 2017 8:47 AM > *To:* kolb-list(at)matronics.com > *Subject:* Kolb-List: aileron gap seal: when? > > For you Twinstar builders/restorers, how/when do you install gap seals? > > My 1st gen plans say to install the seals before installing the > hinges. I'm planning on using the latex finishing method, and I've > used the Stewart water based glue for covering. Do you pre-shrink the > gap seal fabric and glue it on after the rest of the finish work > (final paint), then repaint after attaching the gap seal? > > Thanks, > > Charlie > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
April 03, 2017 - April 26, 2017
Kolb-Archive.digest.vol-om
