Kolb-Archive.digest.vol-oo
June 13, 2017 - August 20, 2017
Date: Jun 13, 2017
Subject: Re: Strange Flying characteristics of new to me Mark III clasic
Jimmy I am posting things on the Kolb e-mail list, but nobody seems to have a direct answer for why the airplane rolls one way and not another. I have three separate ideas for you to try, but I have not tested any of them. First, Use a digital level, measuring at three or four places on each wing, to make sure your airplane is not warped or built improperly. If one wing is twisted only a few degrees, it will answer half of these problems immediately. Tape or clamp the level onto a piece of aluminum angle or a straight edge that is 100% straight. Jack up the tailwheel until the airplane is level by their definition. Measure at the root rib on each side, two ribs on each wing in the middle, and the last tip rib. You are checking to see that ALL of these lines are exactly the same. Second, make 100% sure your airplane is rigged and adjusted to the factory specs. Get this information from Bryan Melbourne if you don't already have it. Basically, forget about anything that anyone else has done, and "zero out" the settings to whatever Kolb says they are supposed to be. Third, make a piece of tube or dowel that fits into or onto the control stick, that allows you to have another 6 or 8 inches of leverage. This can be temporary, but you definitely need to have more control avaiilable than you need to use. Fourth, actually measure and record how much each aileron twists when you move the stick and someone holds the tip of the aileron. What you are looking for is one aileron being more flexible than the other, or one aileron having something loose or cracked, etc. At that time, after you have proven the wings are not twisted, and all four control surfaces are where the factory says they should be,a nd nothing is weak or cracked... THEN go test fly the aircraft again. Test it on the main runway, before the control tower opens. Do short flights at 5 foot altitude, verify that the airplane flies straight and that you have no "pull" or roll to the right or left. You MUST prove to yourself (and your kids) that you have plenty of aileron control authority to roll right and left equally, BEFORE you let yourself get above 5 feet. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Mon, 6/12/17, jonealjr wrote: Subject: Kolb-List: Strange Flying characteristics of new to me Mark III clasic To: kolb-list(at)matronics.com Date: Monday, June 12, 2017, 1:31 PM "jonealjr" PLEASE HELP IF ANYONE HAS EXPERIENCE WITH THIS :) I have a mark III classic w 912 uls Acting odd during taxi needs lots of left rudder to keep on the runway with tail on and off the ground and while flying needs lots of right stick to keep plane level. If you let go of the controls during straight and level flight the plane wants to roll to the left has anyone had similar experiences and or has anybody had any luck with adjusting engine mounts changing the thrust angle to help with aileron trim etc Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470012#470012 The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jun 13, 2017
clasic Jimmy I agree with John H make sure the plane is built to specifications first. Bill I disagree 100%. Kolb airplanes never have control issues if they are built correctly. That being said they are built by builders of all skill levels. So to say it in a more technical way, shit happens. Rick Neilsen Redrive VW Powered MKIIIC On Tue, Jun 13, 2017 at 7:03 PM, Bill Berle wrote: > > That is very helpful, thank you for taking time to respond. > > Over and above the potential causes and fixes for this, another thing I am > getting out of all this discussion is that significant aileron system > issues (control heaviness, asymmetrical loads and high required force) is > not seen as being rare or abnormal for a Kolb. > > As a suggestion, I will advise Jimmy O'Neal to find the original Kolb > rigging and control setup specifications and start by making sure that this > is all set back to the factory specs. That way he will know where he is > starting from. > > I will also advise him to make a proper series of measurements to > determine whether there is a warp, twist, or other "big picture" issue with > the aircraft. > > As far as resolving the high force to actuate the aileron system, does > anyone on the Kolb list know whether the aerobatic style "spades" that were > developed for one Kolb actually solved this problem? It seems like a lot of > effort and modification, but I also know that these spades do work (on > aerobatic aircraft and for a different intended purpose). > > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and > for-profit entities > > -------------------------------------------- > On Tue, 6/13/17, John Hauck wrote: > > Subject: RE: Kolb-List: Re: Strange Flying characteristics of new to me > Mark III clasic > To: kolb-list(at)matronics.com > Date: Tuesday, June 13, 2017, 3:45 PM > > Hauck" > > In my experience it was lack of an > adequate trim tab, if all else was rigged to specs and the > control system had not been changed or modified. > > The aircraft I was flying was much > easier to roll right than left. > > John h > mkIII > Fayetteville, NC > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] > On Behalf Of Bill Berle > Sent: Tuesday, June 13, 2017 6:32 PM > To: kolb-list(at)matronics.com > Subject: RE: Kolb-List: Re: Strange > Flying characteristics of new to me Mark III clasic > > Bill Berle > > John H thank you for your reply, but I > am still left with a specific question: > > If you were test flying someone's Mk 3 > Classic, and you found that it was 2X or 3X as difficult to > roll the aircraft to the right as opposed to rolling it the > left, and if the roll rate to the right was 1/2 as fast as > the roll rate to the left, what would you suspect as the > cause of this condition? > > Bill Berle > www.ezflaphandle.com - safety > & performance upgrade for light aircraft > www.grantstar.net - > winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Tue, 6/13/17, John Hauck > wrote: > > Subject: RE: Kolb-List: Re: Strange > Flying characteristics of new to me Mark III clasic > To: kolb-list(at)matronics.com > Date: Tuesday, June 13, 2017, 3:18 PM > > "John > Hauck" > > If the aircraft was mine and I had > all > those problems, I'd start from > scratch, insure the aircraft was built correctly, had > not been modified (especially the control system), and > everything was rigged as specified in the plans and > instructions. I would insure I was starting my > journey from a standard beginning. > > Once I got it back to standard > configuration, then I would test fly > it, insuring I did the test flight alone, not with a > passenger on board. If I wasn't an experienced > MKIII pilot, I'd find one that was to do my test > flying. He would know what to expect from the > MKIII in flight. > > If I still encountered the same > problems, I'd put the standard (large) > rudder trim tab on temporarily. It can be > attached with Gorilla Tape to test fly. > Sometimes the rudder trim tab will correct adverse > roll problems, when your mind is telling you that it > is aileron or wing incidence problems. > > Always change only one thing at a > time. After each change, test > fly to see what that change has affected. > > I would not change thrust line in any > way, unless it has been > modified. Then I would change it back to what it > should be per the instructions. The thrust lines > on Kolb aircraft, all models, are correct the way they > were designed and fabricated. Incorrect thrust > lines would not affect the aircrafts flight > characteristic as described unless you mounted the > engine backwards. > > I would not try to trim the aircraft > with flap(s). > > Aileron trim tabs are effective for > slight roll problems, not the problems > you all describe. > > I test flew the latest model MKIII > Extra. It demonstrated similar > characteristics. Wanted to fly straight if it was > allowed to roll 10 to 15 degrees to the right. > Was a terrible, unnatural feeling. Took a Hell > of a lot of left stick to fly it straight and level, > but was happy flying rolled right. This flight was > without a rudder trim tab. We installed the > large rudder trim tab, test flew, and the problem was > gone. Hard for me to grasp, but it worked. > > These are my thoughts and > experiences. It is the way I > would do it. I am not recommending anyone else > try this at home. > > John h > Fayetteville, NC > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] > On Behalf Of Bill Berle > Sent: Tuesday, June 13, 2017 5:00 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: Strange > Flying characteristics of new to me > Mark III clasic > > Bill Berle > > One or more Kolbers has pointed to > the > flaps as a possible reason for the > problems we had. This may be the problem... does the > following make sense to the experienced Kolbers??? : > > Let's say that the airplane was not > built perfectly straight, and it > wanted to roll one way (like many homebuilts). > > One owner installed the "adjustable" > U-joint on one side of the fuselage on > this aircraft, hoping to trim out the problem that > way. > > The same owner, or perhaps a > subsequent owner, tried to adjust one of the wing > flaps a little more up or down, still trying to solve > the problem. > > But because the flaps are hinged > directly to the aileron torque tubes, > adjusting the flap will have an unfortunate side > effect of inducing different forces on the ailerons as > well. > > If one flap has been adjusted > downward > (attempt to trim airplane to fly > straight), then when the stick is moved in that > direction the pilot has to use more force, because the > pilot is pushing that FLAP down into the airstream > more than he has to push the other flap. > > Jimmy removed the adjustable U-joint > and replaced it with the standard > U-joint, on advice from the factory. This may have > also taken out HALF of the previous corrective efforts > to trim the airplane. > > Does this make sense to any of you? > Have any of you seen Kolbs where the > owner tried to adjust the flaps in order to correct a > wing issue? > > Bill Berle > www.ezflaphandle.com - safety > & performance upgrade for light > aircraft www.grantstar.net > - winning proposals for non-profit and > for-profit entities > > > The Kolb-List Email Forum - > Navigator to browse > List Un/Subscription, > 7-Day Browse, Chat, FAQ, > - MATRONICS WEB > FORUMS - > via the Web Forums! > - NEW MATRONICS LIST > WIKI - > Email List Wiki! > - List Contribution Web > Site - > support! > > > -Matt Dralle, List > Admin. > > > The Kolb-List Email Forum - > Navigator to browse > List Un/Subscription, > 7-Day Browse, Chat, FAQ, > - MATRONICS WEB FORUMS - > via the Web Forums! > - NEW MATRONICS LIST WIKI - > Email List Wiki! > - List Contribution Web Site - > support! > > -Matt Dralle, List Admin. > > ________________________________________________________________________________
clasic
Date: Jun 13, 2017
On 6/13/2017 2:55 PM, Ralph B wrote: > > Along with the U-joints, there is also the offset fin. This was installed by the builder and I don't see how I would do without it. I've also included a picture of the adjustable rudder trim tab. Between the U-joints, offset fin, and rudder trim tab, the Kolbra can fly hands off in calm air. For pitch trim, the builder installed a motorized bungee windup to move the stick forward or aft. It is controlled with a toggle switch for nose up or down trim. > > Ralph B > > -------- > Ralph B > > Kolb Kolbra 912uls > N20386 > 550 hours Clever ideas, but a couple of questions. 1st, no safety wire on that turnbuckle? 2nd, what's to keep those little shackles on the horizontal stabs from going overcenter & moving the leading edge up instead of down? Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 13, 2017
Jimmy We don't know your airplane so we can only guess what maybe the problem. You have our best suggestions..... Maybe it isn't the airplane? Bill may have some good suggestions but do not follow the 5 foot suggestion. Our Kolbs do not react well in this maneuver. I can't think of a better way to bend a perfectly good Kolb. Rick Neilsen Redrive VW Powered MKIIIC On Tue, Jun 13, 2017 at 7:18 PM, Bill Berle wrote: > > Jimmy I am posting things on the Kolb e-mail list, but nobody seems to > have a direct answer for why the airplane rolls one way and not another. > > I have three separate ideas for you to try, but I have not tested any of > them. > > First, Use a digital level, measuring at three or four places on each > wing, to make sure your airplane is not warped or built improperly. If one > wing is twisted only a few degrees, it will answer half of these problems > immediately. Tape or clamp the level onto a piece of aluminum angle or a > straight edge that is 100% straight. Jack up the tailwheel until the > airplane is level by their definition. Measure at the root rib on each > side, two ribs on each wing in the middle, and the last tip rib. You are > checking to see that ALL of these lines are exactly the same. > > Second, make 100% sure your airplane is rigged and adjusted to the factory > specs. Get this information from Bryan Melbourne if you don't already have > it. Basically, forget about anything that anyone else has done, and "zero > out" the settings to whatever Kolb says they are supposed to be. > > Third, make a piece of tube or dowel that fits into or onto the control > stick, that allows you to have another 6 or 8 inches of leverage. This can > be temporary, but you definitely need to have more control avaiilable than > you need to use. > > Fourth, actually measure and record how much each aileron twists when you > move the stick and someone holds the tip of the aileron. What you are > looking for is one aileron being more flexible than the other, or one > aileron having something loose or cracked, etc. > > At that time, after you have proven the wings are not twisted, and all > four control surfaces are where the factory says they should be,a nd > nothing is weak or cracked... THEN go test fly the aircraft again. Test it > on the main runway, before the control tower opens. Do short flights at 5 > foot altitude, verify that the airplane flies straight and that you have no > "pull" or roll to the right or left. You MUST prove to yourself (and your > kids) that you have plenty of aileron control authority to roll right and > left equally, BEFORE you let yourself get above 5 feet. > > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and > for-profit entities > > -------------------------------------------- > On Mon, 6/12/17, jonealjr wrote: > > Subject: Kolb-List: Strange Flying characteristics of new to me Mark III > clasic > To: kolb-list(at)matronics.com > Date: Monday, June 12, 2017, 1:31 PM > > "jonealjr" > > PLEASE HELP IF ANYONE HAS EXPERIENCE > WITH THIS :) > > I have a mark III classic w 912 uls > Acting odd during taxi needs lots of left rudder to keep on > the runway with tail on and off the ground and while flying > needs lots of right stick to keep plane level. If you let go > of the controls during straight and level flight the plane > wants to roll to the left has anyone had similar experiences > and or has anybody had any luck with adjusting engine mounts > changing the thrust angle to help with aileron trim etc > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470012#470012 > > > The Kolb-List Email Forum - > Navigator to browse > List Un/Subscription, > 7-Day Browse, Chat, FAQ, > - MATRONICS WEB FORUMS - > via the Web Forums! > - NEW MATRONICS LIST WIKI - > Email List Wiki! > - List Contribution Web Site - > support! > > -Matt Dralle, List Admin. > > ________________________________________________________________________________
Date: Jun 13, 2017
https://microsoft-powertoys-image-resizer.en.softonic.com/ -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470077#470077 ________________________________________________________________________________
III clasic
Date: Jun 13, 2017
Kolbs were not designed for aerobatics and fast roll rates at higher speeds. Homer Kolb's idea of the epitome of flight was to fly slowly, just above the stall and just above the tree tops, to be in contact with the ground. His requirement was full aileron control right through the stall. In order to do this, Kolbs have very large ailerons. The Ultrastars and Firestars had full span deep cord ailerons just for that purpose. If one wants quick full aileron throw he must slow down. The faster the airspeed the heavier the aileron. At higher speeds, 80, 90, and higher, the MKIII is still very flyable, but you aren't going to move the ailerons very much very quickly. If you want faster roll rate, slow down. If one is flying fast, gets into severe turbulence, and think they need a lot of aileron input quickly, you ain't gonna get it. Slow down to a comfortable maneuvering speed and your bird will do exactly what you tell it to. You cannot be forceful. There is a lot of leverage in that control stick. If you force it, something might bend or break. At slower speeds my MKIII, and the other two Kolbs I built, will respond quite readily to aileron input. One can easily get full aileron travel. I once complained to Homer Kolb about the heavy ailerons. Homer told me to be gentle and the airplane would do what I wanted it to do. A gentle pilot, in my opinion, is a much better pilot than one that tries to force an airplane to respond. Again, my own opinion. Don't recommend anyone doing like I do, but it works for me. John h mkIII Fayetteville, NC -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Bill Berle Sent: Tuesday, June 13, 2017 7:03 PM Subject: RE: Kolb-List: Re: Strange Flying characteristics of new to me Mark III clasic That is very helpful, thank you for taking time to respond. Over and above the potential causes and fixes for this, another thing I am getting out of all this discussion is that significant aileron system issues (control heaviness, asymmetrical loads and high required force) is not seen as being rare or abnormal for a Kolb. As a suggestion, I will advise Jimmy O'Neal to find the original Kolb rigging and control setup specifications and start by making sure that this is all set back to the factory specs. That way he will know where he is starting from. I will also advise him to make a proper series of measurements to determine whether there is a warp, twist, or other "big picture" issue with the aircraft. As far as resolving the high force to actuate the aileron system, does anyone on the Kolb list know whether the aerobatic style "spades" that were developed for one Kolb actually solved this problem? It seems like a lot of effort and modification, but I also know that these spades do work (on aerobatic aircraft and for a different intended purpose). Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Tue, 6/13/17, John Hauck wrote: Subject: RE: Kolb-List: Re: Strange Flying characteristics of new to me Mark III clasic To: kolb-list(at)matronics.com Date: Tuesday, June 13, 2017, 3:45 PM Hauck" In my experience it was lack of an adequate trim tab, if all else was rigged to specs and the control system had not been changed or modified. The aircraft I was flying was much easier to roll right than left. John h mkIII Fayetteville, NC -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Bill Berle Sent: Tuesday, June 13, 2017 6:32 PM To: kolb-list(at)matronics.com Subject: RE: Kolb-List: Re: Strange Flying characteristics of new to me Mark III clasic Bill Berle John H thank you for your reply, but I am still left with a specific question: If you were test flying someone's Mk 3 Classic, and you found that it was 2X or 3X as difficult to roll the aircraft to the right as opposed to rolling it the left, and if the roll rate to the right was 1/2 as fast as the roll rate to the left, what would you suspect as the cause of this condition? Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Tue, 6/13/17, John Hauck wrote: Subject: RE: Kolb-List: Re: Strange Flying characteristics of new to me Mark III clasic To: kolb-list(at)matronics.com Date: Tuesday, June 13, 2017, 3:18 PM "John Hauck" If the aircraft was mine and I had all those problems, I'd start from scratch, insure the aircraft was built correctly, had not been modified (especially the control system), and everything was rigged as specified in the plans and instructions. I would insure I was starting my journey from a standard beginning. Once I got it back to standard configuration, then I would test fly it, insuring I did the test flight alone, not with a passenger on board. If I wasn't an experienced MKIII pilot, I'd find one that was to do my test flying. He would know what to expect from the MKIII in flight. If I still encountered the same problems, I'd put the standard (large) rudder trim tab on temporarily. It can be attached with Gorilla Tape to test fly. Sometimes the rudder trim tab will correct adverse roll problems, when your mind is telling you that it is aileron or wing incidence problems. Always change only one thing at a time. After each change, test fly to see what that change has affected. I would not change thrust line in any way, unless it has been modified. Then I would change it back to what it should be per the instructions. The thrust lines on Kolb aircraft, all models, are correct the way they were designed and fabricated. Incorrect thrust lines would not affect the aircrafts flight characteristic as described unless you mounted the engine backwards. I would not try to trim the aircraft with flap(s). Aileron trim tabs are effective for slight roll problems, not the problems you all describe. I test flew the latest model MKIII Extra. It demonstrated similar characteristics. Wanted to fly straight if it was allowed to roll 10 to 15 degrees to the right. Was a terrible, unnatural feeling. Took a Hell of a lot of left stick to fly it straight and level, but was happy flying rolled right. This flight was without a rudder trim tab. We installed the large rudder trim tab, test flew, and the problem was gone. Hard for me to grasp, but it worked. These are my thoughts and experiences. It is the way I would do it. I am not recommending anyone else try this at home. John h Fayetteville, NC -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Bill Berle Sent: Tuesday, June 13, 2017 5:00 PM To: kolb-list(at)matronics.com Subject: Re: Kolb-List: Re: Strange Flying characteristics of new to me Mark III clasic Bill Berle One or more Kolbers has pointed to the flaps as a possible reason for the problems we had. This may be the problem... does the following make sense to the experienced Kolbers??? : Let's say that the airplane was not built perfectly straight, and it wanted to roll one way (like many homebuilts). One owner installed the "adjustable" U-joint on one side of the fuselage on this aircraft, hoping to trim out the problem that way. The same owner, or perhaps a subsequent owner, tried to adjust one of the wing flaps a little more up or down, still trying to solve the problem. But because the flaps are hinged directly to the aileron torque tubes, adjusting the flap will have an unfortunate side effect of inducing different forces on the ailerons as well. If one flap has been adjusted downward (attempt to trim airplane to fly straight), then when the stick is moved in that direction the pilot has to use more force, because the pilot is pushing that FLAP down into the airstream more than he has to push the other flap. Jimmy removed the adjustable U-joint and replaced it with the standard U-joint, on advice from the factory. This may have also taken out HALF of the previous corrective efforts to trim the airplane. Does this make sense to any of you? Have any of you seen Kolbs where the owner tried to adjust the flaps in order to correct a wing issue? Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jun 14, 2017
Richard Pike wrote: > https://microsoft-powertoys-image-resizer.en.softonic.com/ Richard, I scaled down the images by 50%. It works much better! Ralph B -------- Ralph B Kolb Kolbra 912uls N20386 550 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470118#470118 ________________________________________________________________________________
Date: Jun 14, 2017
I am currently building a NEW Mark III Classic... If you need any Plans or blue print spec info, let me know. worthken67(at)gmail.com -------- kenw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470121#470121 ________________________________________________________________________________
Date: Jun 14, 2017
Subject: Michigan Kolb Gathering
I'm trying setup a impromptu Kolb gatering in Mighigan There are three of us in the Hart, Cadillac, and Howard City area. Seems like Chris Ambrose was at Houghton Lake. Is Chris still around and flying his Kolb? Anyone else in the area that would like to join us? Time, date, and location flexible. Contact me Off List at: NeilsenRM(at)gmail.com Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Date: Jun 14, 2017
Depending on time frame I may be able to fly up. John h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen Sent: Wednesday, June 14, 2017 3:27 PM Subject: Kolb-List: Michigan Kolb Gathering I'm trying setup a impromptu Kolb gatering in Mighigan There are three of us in the Hart, Cadillac, and Howard City area. Seems like Chris Ambrose was at Houghton Lake. Is Chris still around and flying his Kolb? Anyone else in the area that would like to join us? Time, date, and location flexible. Contact me Off List at: NeilsenRM(at)gmail.com Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Date: Jun 14, 2017
Subject: Re: Michigan Kolb Gathering
That would be very cool, John! Have a great day! > On Jun 14, 2017, at 3:44 PM, John Hauck wrote: > > Depending on time frame I may be able to fly up. > > John h > mkIII > Titus, Alabama > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com] On Behalf Of Rick Neilsen > Sent: Wednesday, June 14, 2017 3:27 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Michigan Kolb Gathering > > I'm trying setup a impromptu Kolb gatering in Mighigan There are three of u s in the Hart, Cadillac, and Howard City area. Seems like Chris Ambrose was a t Houghton Lake. Is Chris still around and flying his Kolb? Anyone else in t he area that would like to join us? Time, date, and location flexible. > > Contact me Off List at: NeilsenRM(at)gmail.com > > Rick Neilsen > Redrive VW Powered MKIIIC > > ________________________________________________________________________________
Date: Jun 14, 2017
I haven=99t done a cross country flight since Sun and Fun 2016. Had thought about flying back to the Rock House in Oregon, but changed my mind on that one. It is 750 air miles to the center of the three towns referenced below. A two day flight for an old fart in a MKIII. Route of flight takes me right over Fort Knox. ;-) Maybe I could RON there and make a withdrawal at the same time. That would help pay for the fuel to get up there and back. Round trip flight is 1500 air miles, 20 hours flight time, and 100 gals of fuel. Works out to 4 days travel time up and back. Doesn=99t count any flying while up there. I=99ll think about it and see what falls out. For now, count me in. John h MKIII Fayetteville, NC From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of George Helton Sent: Wednesday, June 14, 2017 3:49 PM Subject: Re: Kolb-List: Michigan Kolb Gathering That would be very cool, John! Have a great day! On Jun 14, 2017, at 3:44 PM, John Hauck wrote: Depending on time frame I may be able to fly up. John h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen Sent: Wednesday, June 14, 2017 3:27 PM Subject: Kolb-List: Michigan Kolb Gathering I'm trying setup a impromptu Kolb gatering in Mighigan There are three of us in the Hart, Cadillac, and Howard City area. Seems like Chris Ambrose was at Houghton Lake. Is Chris still around and flying his Kolb? Anyone else in the area that would like to join us? Time, date, and location flexible. Contact me Off List at: NeilsenRM(at)gmail.com Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Date: Jun 14, 2017
Subject: Roll problems of the Mk III
Bill, John is right. I had the misfortune to deal with a Mk III C conversion to a III X. It had 29 hours on it and five owners. I think almost all of the posts I made while fixing it make reference to The Plane from Hell. You can read about all I did to bring the aircraft back to trim. At one point I took the rudder trim tab off it. The aircraft became unflyable for all practical purposes. If I could keep enough rudder in it to center a yaw string my right leg was cramped before I reached downwind. I put the factory recommended trim tab back on and it flew like a Mk III again. There is one other thing that will cause problems and that is not covering the lower frame between the wings (the one under the engine). Uncovered, the aircraft will have half the climb rate of one with the lower frame covered. I never flew the aircraft without the lower covering and no rudder trim tab. Rick Girard =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
clas
Date: Jun 14, 2017
Kenw, that;s very generous of you and Im sure everyone on the List appreciates it Where are you scatted? Russ K > On Jun 14, 2017, at 3:04 PM, kenw wrote: > > > I am currently building a NEW Mark III Classic... If you need any Plans or blue print spec info, let me know. > worthken67(at)gmail.com > > -------- > kenw > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470121#470121 > > > > > > > > > ________________________________________________________________________________
Date: Jun 15, 2017
I failed to mention the Kolbra fin offset was built that way due to the powerful 912 engine that spins in the opposite direction of a 2-stroke engine. From the rear of the airplane, it spins in a counterclockwise direction whereas a 2-stroke will spin in a clockwise direction. This makes a difference in how the airplane is trimmed out. When I upgraded to the 912uls 100hp engine, I was very happy have that offset built in as the rudder trim tab would not have been able to hold it without using constant rudder on the pedals. Even then, the airplane would have been flying in a constant yawed condition which I didn't like. Ralph B -------- Ralph B Kolb Kolbra 912uls N20386 550 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470154#470154 ________________________________________________________________________________
clasic
Date: Jun 15, 2017
Don't want to contradict Ralph B, but I have a little different take on the upper vertical stabilizer leading edge offset. I tried for a very long time to get Old Kolb Aircraft to experiment with offsetting the leading edge of the upper vertical stabilizer on the factory MKIII because I had an idea that this would help remedy the adverse yaw problem. However, they never did. At that time I was flying with a rudder trim tab half the length of what I finally discovered solved the yaw problem. The reason I didn't want to experiment on my MKIII was because I didn't want to drill a bunch of holes and screw up my airplane. I had already made a 17,200 mile flight with the slip/skid ball yawed a half ball out, and got tired of looking at it. My MKIII flew great this way, but it just wasn't right. I started out by offsetting the leading edge by 1/2". No observable change. Drilled out the SS rivets and tried 1". Very slight change. Finally I got it pushed over to 1.5" with hardly any difference. Not worth all the effort. On the down side, doing it my way was actually twisting the tail post and bending the leading edge tube of the upper vertical stabilizer which eventually failed. Big job repairing this. When I did I went back to centering the upper vertical stabilizer the way it should be. Then I decided to experiment with the rudder trim tab. I chose to go big and built the first one three rib bays long. Wow! That was an overkill. Since I had attached with duct tape, I snatched it off, cut off a third (one rib bay), stuck it back on and discovered it was perfect. Slip/skid ball centered with my feet on the deck. ;-) I think Mark German modified the tail post on his Kolbra after he saw mine and talked with me. Cannot remember for sure. There is no need to offset the upper vertical stabilizer because an adequate rudder trim tab solves the yaw problem. A much simpler and effective solution. Direction of prop rotation and HP did not make much difference to the yaw problem. I had it with 65, 80, and 100 hp on my MKIII. John h mkIII Fayetteville, NC I failed to mention the Kolbra fin offset was built that way due to the powerful 912 engine that spins in the opposite direction of a 2-stroke engine. From the rear of the airplane, it spins in a counterclockwise direction whereas a 2-stroke will spin in a clockwise direction. This makes a difference in how the airplane is trimmed out. When I upgraded to the 912uls 100hp engine, I was very happy have that offset built in as the rudder trim tab would not have been able to hold it without using constant rudder on the pedals. Even then, the airplane would have been flying in a constant yawed condition which I didn't like. Ralph B -------- Ralph B Kolb Kolbra 912uls N20386 550 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470154#470154 ________________________________________________________________________________
Date: Jun 15, 2017
John, While in flight do you have to hold any rudder at all or are your feet neutral on the pedals with the ball centered? Just wondering ... The reason I say this is if you have to hold any rudder, then your trim tab is not working. I believe Mark German did consult with you and others before offsetting the fin like that. He didn't want to drill out extra holes in the tube, I'm sure, if he didn't have to. As it stands, with my 100hp 912, the only way to keep it from rolling was the offset fin. If I didn't have that, I would probably need a very large trim tab as you have. Ralph B -------- Ralph B Kolb Kolbra 912uls N20386 550 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470159#470159 ________________________________________________________________________________
clasic
Date: Jun 15, 2017
Yes sir, I fly can with my feet off the pedals and on the deck with centered slip/skid ball, as I indicated in my original comment. John h mkIII Fayetteville, NC -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Ralph B Sent: Thursday, June 15, 2017 11:21 AM Subject: Kolb-List: Re: Strange Flying characteristics of new to me Mark III clasic John, While in flight do you have to hold any rudder at all or are your feet neutral on the pedals with the ball centered? Just wondering ... The reason I say this is if you have to hold any rudder, then your trim tab is not working. I believe Mark German did consult with you and others before offsetting the fin like that. He didn't want to drill out extra holes in the tube, I'm sure, if he didn't have to. As it stands, with my 100hp 912, the only way to keep it from rolling was the offset fin. If I didn't have that, I would probably need a very large trim tab as you have. Ralph B -------- Ralph B Kolb Kolbra 912uls N20386 550 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470159#470159 ________________________________________________________________________________
Date: Jun 16, 2017
Subject: Flight to the Great Salt Lake / spiral jetty
This morning my wife and I flew to the spiral jetty, the last time we were there, the water was 1/4 to 1/2 mile from the jetty. 5 years of drought. Winter snow fall was 200 to 250 percent of normal... Spring runoff is about done and the lake is rising ________________________________________________________________________________
Subject: List Contributors
Date: Jun 18, 2017
Greetings Kolb list, I spent the entire day yesterday with Boyd Young at Brigham city airport. I was going to fly my plane I purchased last year. I spend my spare time during the last year patching, repairing and replacing all of the components that needed upgrading. When going over the EIS, it was discovered there were gremlins in the electrical system. I don't think I could've asked for a better person to have with me when going over and repairing this system. I can't help but be impressed with Boyd's knowledge and skill locating the problems and resolving issues. This includes his knowledge of the Kolb Mark III structure and flight characteristics. Over the years I have continually read the posted information on the Kolb list by pilots to include Boyd Young, John Hauck, Richard Pike, Larry Cottrell and the list goes on. This is my third Kolb. The advice provided on the Kolb list has been invaluable when it comes to making tweaks and fixes. This is a THANK YOU to all those contributors on the list that make flying fun and safer for Kolb drivers. Thanks Boyd, Kurt Kolb Mark III 912 UL Sent from my iPhone ________________________________________________________________________________
Subject: Re: List Contributors
Date: Jun 18, 2017
You are very kind. Thank you. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470208#470208 ________________________________________________________________________________
Date: Jun 18, 2017
Than you everyone for ALL the input Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470210#470210 ________________________________________________________________________________
Date: Jun 18, 2017
Subject: Great Salt Lake
Friday's flight to the lakes north west arm. This arm has the most salt concentration and it supports the growth of an algae that is purple in color ________________________________________________________________________________
Date: Jun 18, 2017
Boyd is the real deal that is for sure. He has been helping me a ton. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470213#470213 ________________________________________________________________________________
Date: Jun 19, 2017
Absolutely agree! Boyd has been a very generous contributor to assisting myself and others. All of the Kolb List "wise men" have provided tremendously important and relevant information, even when I was just researching an idea, or trying to figure out why something is done a certain way on the Kolb that seems strange to me as a "certified airplane" guy. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Sun, 6/18/17, K I wrote: Subject: Kolb-List: List Contributors To: "kolb-list(at)matronics.com" Date: Sunday, June 18, 2017, 11:25 AM Greetings Kolb list, I spent the entire day yesterday with Boyd Young at Brigham city airport. I was going to fly my plane I purchased last year. I spend my spare time during the last year patching, repairing and replacing all of the components that needed upgrading. When going over the EIS, it was discovered there were gremlins in the electrical system. I don't think I could've asked for a better person to have with me when going over and repairing this system. I can't help but be impressed with Boyd's knowledge and skill locating the problems and resolving issues. This includes his knowledge of the Kolb Mark III structure and flight characteristics. Over the years I have continually read the posted information on the Kolb list by pilots to include Boyd Young, John Hauck, Richard Pike, Larry Cottrell and the list goes on. This is my third Kolb. The advice provided on the Kolb list has been invaluable when it comes to making tweaks and fixes. This is a THANK YOU to all those contributors on the list that make flying fun and safer for Kolb drivers. Thanks Boyd, Kurt Kolb Mark III 912 UL Sent from my iPhone The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jun 20, 2017
Subject: video
I took a short flight this morning before it got too hot, to check on the water levels of the Owyhee River. I kept some of the visual highlights for a video to share with you. One of the biggest problems with making a video is that our range is naturally fairly short, so it gets a bit repetitious. The other is trying to find some music that might remotely fit the scenes and haven't been used too many times before. I think I have used both of these songs before, but one of them (Thank you ) reminds me of Possum, whose video's inspired me to bore you guy's with some of my own. For some reason Possum no longer posts to this site, and I personally consider that to be a shame. If any of you know what happened to him, I would be anxious to hear of it. Or if any of you know him personally and have contact with him, give him my regards. https://vimeo.com/222426663 password- owyheeflyer Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Subject: Re: video
Date: Jun 20, 2017
Good stuff. Thank you. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470296#470296 ________________________________________________________________________________
Date: Jun 20, 2017
Subject: spoofing??????????
The messages that I get back when I post to the kolb list has the heading that the message might be a spoof. Does anyone else get this heading with the messages I post? I am a bit confused as to how to get it across to Gmail that I really am me:-/ Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jun 21, 2017
Subject: Re: spoofing??????????
No spoofing messages here Larry. =C2-Normal format. On Tuesday, June 20, 2017 9:47 PM, Larry Cottrell <lcottrell1020@gmail. com> wrote: The messages that I get back when I post to the kolb list has the heading that the message might be a spoof. Does anyone else get this heading with the messages I post? I am a bit confused as to how to get it across to Gmail that I really am me:-/ Larry -- The older I get, the less tolerant I am of those who are intolerant of othe rs. If you forward this email, or any part of it, please remove my email address before sending. S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jun 21, 2017
Subject: Re: video
Cool video,Larry! I always enjoy them. Nice quality. George H. Firestar, FS100 14GDH Mesick, Michigan gdhelton(at)gmail.com Have a great day! > On Jun 20, 2017, at 8:54 PM, Larry Cottrell wrote: > > > I took a short flight this morning before it got too hot, to check on > the water levels of the Owyhee River. I kept some of the visual > highlights for a video to share with you. One of the biggest problems > with making a video is that our range is naturally fairly short, so it > gets a bit repetitious. The other is trying to find some music that > might remotely fit the scenes and haven't been used too many times > before. I think I have used both of these songs before, but one of > them (Thank you ) reminds me of Possum, whose video's inspired me to > bore you guy's with some of my own. For some reason Possum no longer > posts to this site, and I personally consider that to be a shame. If > any of you know what happened to him, I would be anxious to hear of > it. Or if any of you know him personally and have contact with him, > give him my regards. > > https://vimeo.com/222426663 password- owyheeflyer > > Larry > > -- > The older I get, the less tolerant I am of those who are intolerant of others. > > If you forward this email, or any part of it, please remove my email > address before sending. > > > ________________________________________________________________________________
Subject: video
Date: Jun 21, 2017
Finally got home where I can send an email. Been reading the Kolb List on occasion, but the free WIFI I snagged here and there would not send my email. ;-( I like the video. Brings back a bunch of memories and makes me want to exert the effort to fly back to the Rock House. All I have to do is figure out how to light that fire in my gut to do another long cross country, to take off, point the nose of Miss P'fer NW, and fly until I get there. River looked good. Looks like there ought to be some fish ready to bite. Good eating fish come out of the Owyhee River. Still trying to figure out how to get to the Rock House Flyin in the airplane, and also have time to get back out to do my annual ground trip West. I think I can do it if we get started on or about the first of Sep. We'll see. john h mkIII Titus, Alabama > On Jun 20, 2017, at 8:54 PM, Larry Cottrell wrote: > > --> > > I took a short flight this morning before it got too hot, to check on > the water levels of the Owyhee River > https://vimeo.com/222426663 password- owyheeflyer > > Larry ________________________________________________________________________________
Subject: Re: video
Date: Jun 22, 2017
Thanks for another great video! -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470384#470384 ________________________________________________________________________________
Subject: Show and tell
Date: Jun 22, 2017
Since the list is dead and since I am slowly making progress on the project that I purchased from Rev. Pike back in December, I thought I would post some of the progress. I have rebuilt the wings and fuselage and now have them under paint. I fabricated a set of 4130 gear legs and tundra tires. I am in the process of fabricating a more comfortable seat similar to the one Richard has. I am trying to decide which way to go on the windshield, short or full. I will be installing hydraulic brakes and a trim system. Wings are set at 3* dyhedral and I have a set of fairings for the struts and the gear legs. Progress is slow but I'm having a blast. Richard gave me a lot of tips on building this thing that has really been great. Also, I picked up a chute from Ted in Bama and also a lot of building tips. Trying to decide on the instruments, EIS or analog. Don't know the advantages of either except for the warning light. Any comments or suggestion would be welcome. I have learned a ton from this list and appreciate all the comments, good or bad. Are there any Kolbs in Ohio? I'm in Zanesville. Still trying to figure this picture thing out. Jim in Ohio. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470388#470388 ________________________________________________________________________________
Date: Jun 22, 2017
Subject: Re: Show and tell
My only comment would concern the wind screen. If you get too short on the screen and do not wear a helmet. The wind will hit you somewhere around the chin and if it is a bit cool then you will have problems with snot getting on your glasses. The streaks tend to distort your vision a bit. Roger Hankins met me at a place called Paisley in Eastern Oregon. He had always flown by himself and didn't need or use a radio, so he had always worn a Motorcycle helmet. I insisted on a radio, so to counteract the wind effect he had to resort to breaking the connecting line to some ear plugs and stuffing the plugs up his nose. I thought he looked quite dashing in his little plane with two blue strings hanging out of his nose. The short screen will cost you on speed however. Some where in the area of 5-7 MPH. Just an observation Larry On Thu, Jun 22, 2017 at 5:08 PM, japowell wrote: > > Since the list is dead and since I am slowly making progress on the project that I purchased from Rev. Pike back in December, I thought I would post some of the progress. I have rebuilt the wings and fuselage and now have them under paint. I fabricated a set of 4130 gear legs and tundra tires. I am in the process of fabricating a more comfortable seat similar to the one Richard has. I am trying to decide which way to go on the windshield, short or full. I will be installing hydraulic brakes and a trim system. Wings are set at 3* dyhedral and I have a set of fairings for the struts and the gear legs. > > Progress is slow but I'm having a blast. Richard gave me a lot of tips on building this thing that has really been great. Also, I picked up a chute from Ted in Bama and also a lot of building tips. Trying to decide on the instruments, EIS or analog. Don't know the advantages of either except for the warning light. > > Any comments or suggestion would be welcome. I have learned a ton from this list and appreciate all the comments, good or bad. Are there any Kolbs in Ohio? I'm in Zanesville. > > Still trying to figure this picture thing out. > > Jim in Ohio. > > -------- > Jim P > WAR EAGLE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470388#470388 > > -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jun 22, 2017
Hopefully the pic'swork. If not, sorry Richard I'm trying. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470391#470391 Attachments: http://forums.matronics.com//files/4_138.jpg http://forums.matronics.com//files/3_163.jpg http://forums.matronics.com//files/2_166.jpg http://forums.matronics.com//files/1_133.jpg ________________________________________________________________________________
Subject: Re: Video
Date: Jun 22, 2017
Excellent what a great looking place to fly. Thank you for sharing -------- 2007 Firestar 2 503 N203SD Moster 185 Flattop PPG/Sky K2 Paraglider Trike Buggy Soaring Trike & Northwing Stratus XP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470394#470394 ________________________________________________________________________________
Date: Jun 23, 2017
Subject: Slingshot owners
Hello again everybody, I have learned a lot from everybody here and just wo ndered how many current slingshot owners and flyers are still here other th an Ted C and myself ?=C2- Thanks Mike Stone=C2- SS# 012 ________________________________________________________________________________
Date: Jun 23, 2017
There are 3 or 4 MK 3's in our club near Akron Ohio. We are the North coast lite flyers. Sent from my iPhone > On Jun 22, 2017, at 7:08 PM, japowell wrote: > > > Since the list is dead and since I am slowly making progress on the project that I purchased from Rev. Pike back in December, I thought I would post some of the progress. I have rebuilt the wings and fuselage and now have them under paint. I fabricated a set of 4130 gear legs and tundra tires. I am in the process of fabricating a more comfortable seat similar to the one Richard has. I am trying to decide which way to go on the windshield, short or full. I will be installing hydraulic brakes and a trim system. Wings are set at 3* dyhedral and I have a set of fairings for the struts and the gear legs. > > Progress is slow but I'm having a blast. Richard gave me a lot of tips on building this thing that has really been great. Also, I picked up a chute from Ted in Bama and also a lot of building tips. Trying to decide on the instruments, EIS or analog. Don't know the advantages of either except for the warning light. > > Any comments or suggestion would be welcome. I have learned a ton from this list and appreciate all the comments, good or bad. Are there any Kolbs in Ohio? I'm in Zanesville. > > Still trying to figure this picture thing out. > > Jim in Ohio. > > -------- > Jim P > WAR EAGLE > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470388#470388 > > > > > > > > > ________________________________________________________________________________
Subject: Re: Video
Date: Jun 23, 2017
Thank you very much for sharing this well done vid Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470401#470401 ________________________________________________________________________________
Date: Jun 23, 2017
Looks good! -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470402#470402 ________________________________________________________________________________
Date: Jun 23, 2017
SSB3b3VsZCBnbyBmdWxsLiBIYWQgYSBzaG9ydCBhbmQgcHV0IG9uIGEgZnVsbC4gQSBnb29kIDUg dG8gNyDCoGZhc3Rlci4gQmV0dGVyIG1pbGVhZ2UuIE9ubHkgZG93biBzaWRlIGlzIHBob3RvZ3Jh cGh5LsKgCgoKU2VudCBmcm9tIG15IFZlcml6b24sIFNhbXN1bmcgR2FsYXh5IHNtYXJ0cGhvbmUK LS0tLS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLUZyb206IGphcG93ZWxsIDxqYXBubWpw QHR3Yy5jb20+IERhdGU6IDYvMjIvMTcgIDc6MDggUE0gIChHTVQtMDU6MDApIFRvOiBrb2xiLWxp c3RAbWF0cm9uaWNzLmNvbSBTdWJqZWN0OiBLb2xiLUxpc3Q6IFNob3cgYW5kIHRlbGwgCi0tPiBL b2xiLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJqYXBvd2VsbCIgPGphcG5tanBAdHdjLmNvbT4K ClNpbmNlIHRoZSBsaXN0IGlzIGRlYWQgYW5kIHNpbmNlIEkgYW0gc2xvd2x5IG1ha2luZyBwcm9n cmVzcyBvbiB0aGUgcHJvamVjdCB0aGF0IEkgcHVyY2hhc2VkIGZyb20gUmV2LiBQaWtlIGJhY2sg aW4gRGVjZW1iZXIsIEkgdGhvdWdodCBJIHdvdWxkIHBvc3Qgc29tZSBvZiB0aGUgcHJvZ3Jlc3Mu wqAgSSBoYXZlIHJlYnVpbHQgdGhlIHdpbmdzIGFuZCBmdXNlbGFnZSBhbmQgbm93IGhhdmUgdGhl bSB1bmRlciBwYWludC7CoCBJIGZhYnJpY2F0ZWQgYSBzZXQgb2YgNDEzMCBnZWFyIGxlZ3MgYW5k IHR1bmRyYSB0aXJlcy7CoCBJIGFtIGluIHRoZSBwcm9jZXNzIG9mIGZhYnJpY2F0aW5nIGEgbW9y ZSBjb21mb3J0YWJsZSBzZWF0IHNpbWlsYXIgdG8gdGhlIG9uZSBSaWNoYXJkIGhhcy4gSSBhbSB0 cnlpbmcgdG8gZGVjaWRlIHdoaWNoIHdheSB0byBnbyBvbiB0aGUgd2luZHNoaWVsZCwgc2hvcnQg b3IgZnVsbC7CoCBJIHdpbGwgYmUgaW5zdGFsbGluZyBoeWRyYXVsaWMgYnJha2VzIGFuZCBhIHRy aW0gc3lzdGVtLsKgIFdpbmdzIGFyZSBzZXQgYXQgMyogZHloZWRyYWwgYW5kIEkgaGF2ZSBhIHNl dCBvZiBmYWlyaW5ncyBmb3IgdGhlIHN0cnV0cyBhbmQgdGhlIGdlYXIgbGVncy4KClByb2dyZXNz IGlzIHNsb3cgYnV0IEknbSBoYXZpbmcgYSBibGFzdC4gUmljaGFyZCBnYXZlIG1lIGEgbG90IG9m IHRpcHMgb24gYnVpbGRpbmcgdGhpcyB0aGluZyB0aGF0IGhhcyByZWFsbHkgYmVlbiBncmVhdC7C oCBBbHNvLCBJIHBpY2tlZCB1cCBhIGNodXRlIGZyb20gVGVkIGluIEJhbWEgYW5kIGFsc28gYSBs b3Qgb2YgYnVpbGRpbmcgdGlwcy4gVHJ5aW5nIHRvIGRlY2lkZSBvbiB0aGUgaW5zdHJ1bWVudHMs IEVJUyBvciBhbmFsb2cuwqAgRG9uJ3Qga25vdyB0aGUgYWR2YW50YWdlcyBvZiBlaXRoZXIgZXhj ZXB0IGZvciB0aGUgd2FybmluZyBsaWdodC4gCgpBbnkgY29tbWVudHMgb3Igc3VnZ2VzdGlvbiB3 b3VsZCBiZSB3ZWxjb21lLiBJIGhhdmUgbGVhcm5lZCBhIHRvbiBmcm9tIHRoaXMgbGlzdCBhbmQg YXBwcmVjaWF0ZSBhbGwgdGhlIGNvbW1lbnRzLCBnb29kIG9yIGJhZC7CoCBBcmUgdGhlcmUgYW55 IEtvbGJzIGluIE9oaW8/wqAgSSdtIGluIFphbmVzdmlsbGUuIAoKU3RpbGwgdHJ5aW5nIHRvIGZp Z3VyZSB0aGlzIHBpY3R1cmUgdGhpbmcgb3V0LiAKCkppbSBpbiBPaGlvLgoKLS0tLS0tLS0KSmlt IFAKV0FSIEVBR0xFCgoKCgpSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6CgpodHRwOi8vZm9y dW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTQ3MDM4OCM0NzAzODgKCgoKCgoKXy09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT0KXy09wqDCoMKgwqDCoMKgwqDCoMKgIC0gVGhlIEtvbGItTGlzdCBFbWFpbCBGb3J1bSAtCl8t PSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09 IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8t PSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09 IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPcKgwqAgLS0+IGh0dHA6Ly93 d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0Cl8tPQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQpfLT0gU2FtZSBn cmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyEKXy09Cl8tPcKg wqAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09wqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqAgLSBORVcgTUFUUk9OSUNTIExJU1QgV0lLSSAtCl8tPSBBZGQgc29t ZSBpbmZvIHRvIHRoZSBNYXRyb25pY3MgRW1haWwgTGlzdCBXaWtpIQpfLT3CoMKgIC0tPiBodHRw Oi8vd2lraS5tYXRyb25pY3MuY29tCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAt IExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0KXy09wqAgVGhhbmsgeW91IGZvciB5b3VyIGdl bmVyb3VzIHN1cHBvcnQhCl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqDCoMKgwqDCoMKgwqAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgpfLT3CoMKgIC0t PiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CgoKCg= ________________________________________________________________________________
Date: Jun 23, 2017
blong6826 blong6826(at)sbcglobal.net via matronics.com 9:13 AM (44 minutes ago) to kolb-list I would go full. Had a short and put on a full. A good 5 to 7 faster. Better mileage. Only down side is photography. =================================================================== Try this solution. The only thing is, that I made it with the plane sitting flat. So when it is in flying attitude, the window is a bit tilted. Just decide whether you want the angle to be aligned when sitting or flying. Larry ________________________________________________________________________________
Subject: Re: video
Date: Jun 24, 2017
Thank you very much for sharing well done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470439#470439 ________________________________________________________________________________
Subject: Video
Date: Jun 24, 2017
Off Airport Landing spot near Aqua Dulce, Ca Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470449#470449 ________________________________________________________________________________
Subject: Video Flight to Santa Ynez, Ca
Date: Jun 24, 2017
https://vimeo.com/222986733 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470451#470451 ________________________________________________________________________________
Subject: Re: Great Salt Lake
Date: Jun 24, 2017
Great view , my wife was just in that area a few days ago saying how beautiful it was from the air Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470453#470453 ________________________________________________________________________________
Date: Jun 25, 2017
Subject: chase cam
Here's an interesting video for those who like to video their flights. "Ultralight Airplane Chase Cam Test" http://youtu.be/Sg9gl2upNBI joe ________________________________________________________________________________
Date: Jun 25, 2017
Subject: cmase cam
Sorry! I couldn't get the video to come up by clicking on the https but it came up by going to youtube and searching for ultralight airplane chase cam test joe ________________________________________________________________________________
Date: Jun 25, 2017
Subject: Re: cmase cam
https://www.youtube.com/watch?v=Sq9gI2upNBI This one should do it. The ultimate selfie. I tried to find it on You tube and couldn't but I highlighted it and clicked "search Google" and it came up. Larry On Sun, Jun 25, 2017 at 8:26 AM, wrote: > Sorry! I couldn't get the video to come up by clicking on the https but it > came up by going to youtube and searching for ultralight airplane chase cam > test > > joe -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Subject: Re: chase cam
Date: Jun 25, 2017
At the risk of boring you all, here's a link to a couple of videos on the development of my chase cam. https://youtu.be/Sq9gI2upNBI https://youtu.be/egd30HslaSY Here's one with some detailed instructions about how I made the camera drogue: https://youtu.be/qtj13raGESk Apropos of the Kolb list, here's a couple of chase cam videos featuring my 1985 Kolb Firestar: https://youtu.be/toCBMcCzrzg https://youtu.be/IXhvF7ikoBM I'm using a Drift Ghost S camera with a remote shutter release. It works really well in this application. The early videos in this series were shot using a previous version of the Drift camera, an HD720. I found the range on the HD720 remote wasn't adequate and I could never be sure whether it was turned on. The Ghost S has a two-way remote with LED's that indicate the status of the camera. The remote can also change the mode of the camera from video to single rapid-burst photo. Both of those cameras have a very clever rotating lens that allows for easily correcting for tilt of the camera. It seems to be a good choice for chase cam use. I'm still a rank amature at video editing so please bear with the rough transitions and lack of a music track. I'd rather spend time flying and working on my airplanes than learning video software. -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470465#470465 ________________________________________________________________________________
Date: Jun 26, 2017
Subject: Desert photo flight
http://highdesertflier.blogspot.com/ I made a flight this morning and while it wasn't anything that would lend itself to a video there are several pictures that are worth sharing. I also publish a blog for my friends. You are welcome to check it for the description of this mornings flight and the pictures. If you click on any of the pictures it brings them up to normal size. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jun 27, 2017
Subject: Re: Slingshot owners
My buddy Dave Lewis flys a sweet flying Slingshot with 582 and E gearbox. He's not on the list but I Rep for him here.=F0=9F=98=82 Dennis Rowe > On Jun 22, 2017, at 9:44 PM, mike stone wrote: > > Hello again everybody, I have learned a lot from everybody here and just w ondered how many current slingshot owners and flyers are still here other th an Ted C and myself ? Thanks Mike Stone SS# 012 ________________________________________________________________________________
Date: Jun 28, 2017
where does he live? I am close to Dallas On Tuesday, June 27, 2017 8:28 AM, Dennis Rowe wrote: My buddy Dave Lewis flys a sweet flying Slingshot with 582 and E gearbox.H e's not on the list but I Rep for him here.=F0=9F=98=82 Dennis Rowe On Jun 22, 2017, at 9:44 PM, mike stone wrote: Hello again everybody, I have learned a lot from everybody here and just wo ndered how many current slingshot owners and flyers are still here other th an Ted C and myself ?=C2- Thanks Mike Stone=C2- SS# 012 ________________________________________________________________________________
Date: Jun 28, 2017
Subject: Re: Kolb-List Digest: 2 Msgs - 06/27/17
Ted Cowan here in Alabama 912 80 hp slingshot zoom zoom Sent from my iPhone > On Jun 28, 2017, at 2:03 AM, Kolb-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 17-06-27&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 17-06-27&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Tue 06/27/17: 2 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 06:24 AM - Re: Slingshot owners (Dennis Rowe) > 2. 06:39 PM - Re: Slingshot owners (mike stone) > > > > ________________________________ Message 1 _____________________________________ > > > From: Dennis Rowe <rowedenny(at)windstream.net> > Subject: Re: Kolb-List: Slingshot owners > > My buddy Dave Lewis flys a sweet flying Slingshot with 582 and E gearbox. > He's not on the list but I Rep for him here.=F0=9F=98=82 > > Dennis Rowe > >> On Jun 22, 2017, at 9:44 PM, mike stone wrote: >> >> Hello again everybody, I have learned a lot from everybody here and just w > ondered how many current slingshot owners and flyers are still here other th > an Ted C and myself ? Thanks Mike Stone SS# 012 > > ________________________________ Message 2 _____________________________________ > > > From: mike stone <captanstone(at)yahoo.com> > Subject: Re: Kolb-List: Slingshot owners > > where does he live? I am close to Dallas > > On Tuesday, June 27, 2017 8:28 AM, Dennis Rowe t> wrote: > > > My buddy Dave Lewis flys a sweet flying Slingshot with 582 and E gearbox.H > e's not on the list but I Rep for him here.=F0=9F=98=82 > > Dennis Rowe > On Jun 22, 2017, at 9:44 PM, mike stone wrote: > > > Hello again everybody, I have learned a lot from everybody here and just wo > ndered how many current slingshot owners and flyers are still here other th > an Ted C and myself ?=C2- Thanks Mike Stone=C2- SS# 012 > > > > > > > > > > ________________________________________________________________________________
Subject: "Driving Lesson"
Date: Jun 28, 2017
Took my 13 year old granddaughter for a ride in the MKIII this morning. We had been talking about her getting some flying lessons and she was pretty interested, she asked a lot of questions about the airplane and how it worked. I did the usual this-is-how-it-works thing, and we took off. I got her over the highway that runs to her house and showed her the basics of how to keep a heading and airspeed, she wasn't great, but probably typical. After flying over her house, she was still having trouble figuring out why airspeed was important, so we climbed up 3,000, and I showed her what an approach to a stall was, and then a mild stall. Eyes got big... Then I gave it back to her and we headed back to the strip, she did much better with the headings and airspeeds. One of my better landings, taxied back and shut everything down. She announced with a big grin "Wow; I just had my first driving lesson and it wasn't even in a car!" It was a great day. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470568#470568 ________________________________________________________________________________
Date: Jun 28, 2017
Subject: Re: "Driving Lesson"
atta boy! Larry On Wed, Jun 28, 2017 at 7:58 PM, Richard Pike wrote: > > Took my 13 year old granddaughter for a ride in the MKIII this morning. We had been talking about her getting some flying lessons and she was pretty interested, she asked a lot of questions about the airplane and how it worked. I did the usual this-is-how-it-works thing, and we took off. I got her over the highway that runs to her house and showed her the basics of how to keep a heading and airspeed, she wasn't great, but probably typical. > > After flying over her house, she was still having trouble figuring out why airspeed was important, so we climbed up 3,000, and I showed her what an approach to a stall was, and then a mild stall. Eyes got big... > Then I gave it back to her and we headed back to the strip, she did much better with the headings and airspeeds. > > One of my better landings, taxied back and shut everything down. She announced with a big grin "Wow; I just had my first driving lesson and it wasn't even in a car!" > > It was a great day. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough. Being forgiven is wonderful. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470568#470568 > > -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jun 28, 2017
Good for you, Grand Pa. Always enjoy introducing children for their first flight. They, for the most part, always enjoy it. Maybe not at first until they find out that everything is going to be ok. Then they lighten up and really get into flying. After the first one it is difficult to keep them out of the cockpit. Had a friend's young son and daughter that were not cut out for flight. Both talked big on the ground, but in the air they were devastated. Had to make highly modified circuit and get them on the ground quick. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Wednesday, June 28, 2017 8:59 PM Subject: Kolb-List: "Driving Lesson" --> Took my 13 year old granddaughter for a ride in the MKIII this morning. We had been talking about her getting some flying lessons and she was pretty interested, she asked a lot of questions about the airplane and how it worked. I did the usual this-is-how-it-works thing, and we took off. I got her over the highway that runs to her house and showed her the basics of how to keep a heading and airspeed, she wasn't great, but probably typical. After flying over her house, she was still having trouble figuring out why airspeed was important, so we climbed up 3,000, and I showed her what an approach to a stall was, and then a mild stall. Eyes got big... Then I gave it back to her and we headed back to the strip, she did much better with the headings and airspeeds. One of my better landings, taxied back and shut everything down. She announced with a big grin "Wow; I just had my first driving lesson and it wasn't even in a car!" It was a great day. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470568#470568 ________________________________________________________________________________
Date: Jun 29, 2017
Subject: pictures
The afternoon of my last flight we had quite a bit of wind and a dry Thunder storm that started a range fire. Luckily the BLM fire crew was able to put it out before it got too far along. That is some pretty rough country out there on the ground. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Subject: Just got a Kolb ra
Date: Jul 01, 2017
Hey folks, been looking around here for a bit. Glad I found the list, a little different than the usual forums. But about the only place I can find with any Kolb info. I picked up this Kolbra (King Kolbra?) already pretty much built by a fellow who I believe built it to replace his hurricane damaged Mark III. Brought it back to NC from Arkansas. But it was never registered, all the paper work has been sent it awaiting registration then hopefully a simple inspection followed by an airworthiness. Seems to be a fairly well built little guy, with a 912ul. Has dual inner caliper matco mains (any one have experience on the inner vs outer caliper matco's? And standard bearing vs taper bearings?) So far have fixed some wiring issues, new fuel lines (seperated the tanks front and back by selecter. (Just can't stand the idea that if one of the T'ed off tank lines draws air it's all over.)Thanks and any other info is welcomed! ,Ben -------- 912ul King Kolbra ;fun plane O300 Cessna 172B ;travel plane Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470640#470640 ________________________________________________________________________________
Subject: Re: Just got a Kolb ra
Date: Jul 02, 2017
Very nice looking Kolb, looks like you will be having fun in it real soon. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470647#470647 ________________________________________________________________________________
Date: Jul 02, 2017
North East of Pittsburgh PA=F0=9F=98=AC Dennis Rowe > On Jun 27, 2017, at 9:32 PM, mike stone wrote: > > where does he live? I am close to Dallas > > > On Tuesday, June 27, 2017 8:28 AM, Dennis Rowe w rote: > > > My buddy Dave Lewis flys a sweet flying Slingshot with 582 and E gearbox. > He's not on the list but I Rep for him here.=F0=9F=98=82 > > Dennis Rowe > >> On Jun 22, 2017, at 9:44 PM, mike stone wrote: >> >> Hello again everybody, I have learned a lot from everybody here and just w ondered how many current slingshot owners and flyers are still here other th an Ted C and myself ? Thanks Mike Stone SS# 012 > > ________________________________________________________________________________
Date: Jul 03, 2017
Hello Mike stone here with SS #012=C2- I am installing a rotax 670 on min e (118 HP). what engine and prop do you have on your sling shot?=C2- what s cruise speed? Fuel burn? I am trying to make a good cross country SS out of mine.Thanks On Sunday, July 2, 2017 8:08 PM, Dennis Rowe wrote: North East of Pittsburgh PA=F0=9F=98=AC Dennis Rowe On Jun 27, 2017, at 9:32 PM, mike stone wrote: where does he live? I am close to Dallas On Tuesday, June 27, 2017 8:28 AM, Dennis Rowe wrote: My buddy Dave Lewis flys a sweet flying Slingshot with 582 and E gearbox.H e's not on the list but I Rep for him here.=F0=9F=98=82 Dennis Rowe On Jun 22, 2017, at 9:44 PM, mike stone wrote: Hello again everybody, I have learned a lot from everybody here and just wo ndered how many current slingshot owners and flyers are still here other th an Ted C and myself ?=C2- Thanks Mike Stone=C2- SS# 012 ________________________________________________________________________________
Date: Jul 03, 2017
Subject: video
https://vimeo.com/224120539 password owyheeflyer I slipped out this morning before the heat got too bad and the wind too high to check what I had seen from altitude last week. Have a great "Independence Day", Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jul 03, 2017
Subject: Re: video
Fun video, Larry. Have a great day! > On Jul 3, 2017, at 8:30 PM, Larry Cottrell wrote: > > > https://vimeo.com/224120539 password owyheeflyer > > I slipped out this morning before the heat got too bad and the wind > too high to check what I had seen from altitude last week. > > Have a great "Independence Day", > Larry > > -- > The older I get, the less tolerant I am of those who are intolerant of others. > > If you forward this email, or any part of it, please remove my email > address before sending. > > > ________________________________________________________________________________
Date: Jul 05, 2017
Subject: pictures
I clipped a few screen shots of today's flight. They are pretty small, so they should be OK. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Subject: Kolb flyers/owners map
Date: Jul 05, 2017
Made one of these for a T-Bird group when I had one. If folks like/use it could make it a sticky. Is nice to use to see who is around where and to meet the real people local and when on trips. Is pretty simple to use, just mark a location for your aircraft and add some info (standard format description). https://drive.google.com/open?id=14Re-0FZLIQZBxWLt4ABuuS5Glps&usp=sharing -------- 912ul King Kolbra ;fun plane O300 Cessna 172B ;travel plane Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470706#470706 ________________________________________________________________________________
Subject: Re: pictures
Date: Jul 05, 2017
Looks like a awfully nice place to play around! It's all mountains (beautiful but not very friendly), trees, and small fields around here -------- 912ul King Kolbra ;fun plane O300 Cessna 172B ;travel plane Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470707#470707 ________________________________________________________________________________
Subject: Re: Kolb flyers/owners map
Date: Jul 05, 2017
This is a great idea, but for those of us that are elderly, and computerly challenged, could you add some info as to exactly how to do this? I clicked on the link, got myself to Indian Springs Airport (3TN0) and then couldn't figure out what to do next. And meanwhile Google (which shows the airport) is better at confusing things than making them plain, so that's no help... So yeah, great idea, but exactly how to implement it is the problem. Talk us through, Bro... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470714#470714 ________________________________________________________________________________
Date: Jul 05, 2017
I thought we did this once upon a time. I opened it up enlarged it enough to see where I was and clicked on the little lolypop symbol which opened a box where I could enter my info. clicked save and gotter done. Larry On Wed, Jul 5, 2017 at 8:40 PM, Richard Pike wrote: > > This is a great idea, but for those of us that are elderly, and computerly > challenged, could you add some info as to exactly how to do this? I clicked > on the link, got myself to Indian Springs Airport (3TN0) and then couldn't > figure out what to do next. > And meanwhile Google (which shows the airport) is better at confusing > things than making them plain, so that's no help... > So yeah, great idea, but exactly how to implement it is the problem. > > Talk us through, Bro... > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough. Being forgiven is wonderful. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470714#470714 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 05, 2017
Subject: Pictures
Thanks to all who commented about the pictures. Its rather amusing that I got more comments concerning the pictures than I ever get for all the work in producing a video. ? If you guy's would prefer pictures, they are a lot less work, =F0=9F=98=8A Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: I Love all the Videos
Date: Jul 05, 2017
Larry, I enjoy everything you postvideo or stills. I like to superimpose myself in the cockpit in the videos, and enjoy the flight. The still pictures give the eye a chance to tease apart the country and how hostel it is.would not want to have to walk back to the homestead through most of those places! Keep them coming! Nick Cassara Palmer, Alaska 607AK ..90% done. ________________________________________________________________________________
Date: Jul 06, 2017
Subject: Re: Pictures
Good Morning Larry, Thanks for all the great video, and picture, 'sharing'. I have been experimenting with this stuff for the last half century, and your work, with this 'modern' equipment, makes you my recording guru!!! Keep up the good work (sharing). My first home built experiences were the Kolb UltraStar #306 & #307 in 1985, in southern Wisconsin. I am currently in Florida. Your wide open spaces, of the west, are worshiped by many of us, keep the videos and pictures, and, how you harvest those videos and pictures, coming, to those of us not so privileged, to live in your environment. On Wed, Jul 5, 2017 at 11:31 PM, Larry Cottrell wrote: > Thanks to all who commented about the pictures. Its rather amusing that I > got more comments concerning the pictures than I ever get for all the wor k > in producing a video. ? If you guy's would prefer pictures, they are a lo t > less work, =F0=9F=98=8A > Larry > > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > -- Daniel Bindl ________________________________________________________________________________
Date: Jul 06, 2017
I appreciate them both Larry. You do great job on your video productions. I w ish I could do something just close to the quality of yours. George H. Firestar FS100 14GDH Mesick, Mi gdhelton(at)gmail.com Have a great day! > On Jul 5, 2017, at 11:31 PM, Larry Cottrell wrot e: > > Thanks to all who commented about the pictures. Its rather amusing that I g ot more comments concerning the pictures than I ever get for all the work in producing a video. ? If you guy's would prefer pictures, they are a lot les s work, =F0=9F=98=8A > Larry > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Date: Jul 06, 2017
lcottrell wrote: > > > .S . N . I . P . > If you guy's would prefer pictures, they are a lot less work,Larry > .S . N . I . P . > Larry, if you are looking for votes, put me down for the videos. Like someone else had said, it's nice to go along for the ride. Your narratives make them even better. Hopefully most of the viewers appreciate the work you put into them. -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470721#470721 ________________________________________________________________________________
Subject: Pictures
Date: Jul 06, 2017
I find the video inspiring. Today, I was thinking how much work that must be to put together. It is appreciated. From: Larry Cottrell Sent: Wednesday, July 5, 2017 9:33 PM Subject: Kolb-List: Pictures Thanks to all who commented about the pictures. Its rather amusing that I g ot more comments concerning the pictures than I ever get for all the work i n producing a video. ? If you guy's would prefer pictures, they are a lot l ess work,=C2-=F0=9F=98=8A Larry -- The older I get, the less tolerant I am of those who are intolerant of othe rs. If you forward this email, or any part of it, please remove my email addres s before sending. ________________________________________________________________________________
Subject: Pictures
Date: Jul 06, 2017
I agree with Wayne S. Putting video together is a lot work and time. Time Larry C could be doing chores and honey do's. ;-) I enjoy them because that part of the world is completely opposite of my little piece of dirt. I like the West so much I have been going there every year since 2003, sometimes twice a year. I missed the Kolb Unplanned/Unorganized Flyin Monument Valley, UT, in 2010, but made it to the Rock House 3 months after I had a nasty accident on my mountain bike. I still like my home base at hauck's holler, Alabama, but thoroughly enjoy exploring the West. Not the populated areas, but the remote back country. Still tossing around what to do this year for the Rock House Kolb Flyin. Fly or pull the 5th wheel??? Want to do both, but the timing just ain't right. I drug Miss P'fer, my 1992 Kolb MKIII, out of the hanger a couple days ago. First time in 3 months. She was nice and clean the first of April, with brand new John Gilpin STOL Speed Vortex Generators installed. She flew great despite the load of barn dust, bug and bird crap. I got an hour flight time. Shot a bunch of landings at my short strip and at the longer grass strip at Wetumpka Airport, 08A, 11.2 miles away. I enjoy flying with the VGs, after all these years. They make an old rusty pilot look halfway decent on his landings despite my efforts to screw them up. I need to fly more to get back in the groove and really learn about the STOL Speed VGs. Keep the photos and vids coming Larry C. I enjoy them. They bring back memories of the last 12 years me and my buddies have been flying in your neck of the woods. After flying out of Gantt International Airport for the last 33 years, looking at the top of pine trees and flat ground gets boring. Not at the Rock House though. There's always somewhere to go to see something new and exciting. The big plus is getting together with old Kolb friends that met because of Homer Kolb's little airplanes. Had it not been for Homer, I would have missed out on a big part of the long, exciting life I have enjoyed since retiring in 1980, and my good friends from all over the world. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Wayne Schneider Sent: Thursday, July 06, 2017 7:51 AM Subject: RE: Kolb-List: Pictures I find the video inspiring. Today, I was thinking how much work that must be to put together. It is appreciated. From: Larry Cottrell <mailto:lcottrell1020(at)gmail.com> Sent: Wednesday, July 5, 2017 9:33 PM Subject: Kolb-List: Pictures Thanks to all who commented about the pictures. Its rather amusing that I got more comments concerning the pictures than I ever get for all the work in producing a video. ? If you guy's would prefer pictures, they are a lot less work, =F0=9F=98=8A Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jul 06, 2017
Subject: Re: I Love all the Videos
Obviously I enjoy making the videos, It allows me to enjoy them again as well as makes it easier when telling someone about some part of this country. There is no doubt that I am blessed with a great area to fly, and having a Kolb just makes it all that much better. It gives me great pleasure to share my good fortune with all of you. As for having to "walk back", I will take High Desert over muskeg any day. Larry On Thu, Jul 6, 2017 at 1:31 AM, Nick Cassara wrote: > > Larry, > > I enjoy everything you postvideo or stills. I like to superimpos e myself > in the cockpit in the videos, and enjoy the flight. The still pictures > give the eye a chance to tease apart the country and how hostel it > is.would not want to have to walk back to the homestead through most of > those places! > > Keep them coming! > > Nick Cassara > Palmer, Alaska > > 607AK ..90% done. > =========== =========== =========== =========== =========== > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 06, 2017
From: Billy Bob Thornton <woodman1957(at)yahoo.com>
Larry, Please NO!!! I would hope that you never stop your video's.. I know that editing video is much more difficult that uploading pictures but your are one flyer that I keep going back to over and over to watch your video's you just have a way with your commentary and your flying they just go toge ther.. and your voice is soothing to listen to... Even my wife likes your v ideos...I hope you continue your flights and videos as long as you want to. .. safe flying... I fly A PPC but have always been intrigued by the Kolb Fi restar II... almost bought one but seemed to be to small for my lard butt.. :) anotherLarry From: Larry Cottrell <lcottrell1020(at)gmail.com> To: "kolb-list(at)matronics.com" Sent: Wednesday, July 5, 2017 10:34 PM Subject: Kolb-List: Pictures Thanks to all who commented about the pictures. Its rather amusing that I g ot more comments concerning the pictures than I ever get for all the work i n producing a video. ? If you guy's would prefer pictures, they are a lot l ess work,=C2-=F0=9F=98=8ALarry -- The older I get, the less tolerant I am of those who are intolerant of othe rs. If you forward this email, or any part of it, please remove my email addres s before sending. ________________________________________________________________________________
Date: Jul 06, 2017
Subject: Small Kolb gathering, Michigan
I thought I'd post a few pictures from our fly-in breakfast to the Evart Air port in central lower Michigan. It's pretty tough getting Kolb flyers to get together up here. Rick Nielsen, Gregg Kaat and I made this, kind of spur of the moment flight for a Mickey "D's" breakfast in Evart. Rick flew some 65 m iles, MKIII VW, Gregg, 45+ Firefly 447 and I about 30 each way in my Firesta r (original)377. We managed to catch one of those rare beautiful, windless d ays. A little ground fog early. I'm posting these pictures fairly small as not get trouble with our webmaste r. I'm the guy with the camera. So no mugshot. George H. Firestar , FS100 14GDH Mesick, Michigan Have a great day! ________________________________________________________________________________
Date: Jul 07, 2017
Greetings, All, My name is Lanny, and I have been on this list for a few months now, learnin g more about the Kolb airplanes. I presently fly a Challenger II CWS I built, and a single place Loehle Sport Parasol. I built the two place Challenger mostly s o my wife and I could enjoy flying together, but she is so uncomfortable in the b ack seat (And I don't have any experience flying from the back), so I started looking at Kolb Mark threes. We plan to attend Sun N Fun next April so we can try on the Ko lb, get a demo ride perhaps and make a decision about selling the Challenger and get ting a Kolb. That being said, I have enjoyed the pics and videos, Larry's especially, as I am in the mountains of Virginia, and that terrain out West is so different. I enjoy c reating videos from my flight footage, especially when the flight is with a friend a nd particularly a grandchild! Below is a link to one of my YouTube videos in w hich my grandson, Chase, who was 8 at the time, got his first flight in Miss Suns hine my Challenger. If you are interested, I have a number of videos posted on m y YouTube site, just search on YouTube for Miss Sunshine, or PaPaLan publicati ons to find more. Hope you enjoy, Safe flights all, Lanny. https://youtu.be/yDByWwjpZM0 Sent from my iPad > On Jul 6, 2017, at 10:53 AM, John Hauck wrote: > > I agree with Wayne S. Putting video together is a lot work and time. Tim e Larry C could be doing chores and honey do's. ;-) > > I enjoy them because that part of the world is completely opposite of my l ittle piece of dirt. I like the West so much I have been going there every y ear since 2003, sometimes twice a year. I missed the Kolb Unplanned/Unorgan ized Flyin Monument Valley, UT, in 2010, but made it to the Rock House 3 mon ths after I had a nasty accident on my mountain bike. I still like my home b ase at hauck's holler, Alabama, but thoroughly enjoy exploring the West. No t the populated areas, but the remote back country. > > Still tossing around what to do this year for the Rock House Kolb Flyin. Fly or pull the 5th wheel??? Want to do both, but the timing just ain't rig ht. > > I drug Miss P'fer, my 1992 Kolb MKIII, out of the hanger a couple days ago . First time in 3 months. She was nice and clean the first of April, with b rand new John Gilpin STOL Speed Vortex Generators installed. She flew great despite the load of barn dust, bug and bird crap. I got an hour flight tim e. Shot a bunch of landings at my short strip and at the longer grass strip at Wetumpka Airport, 08A, 11.2 miles away. I enjoy flying with the VGs, af ter all these years. They make an old rusty pilot look halfway decent on hi s landings despite my efforts to screw them up. I need to fly more to get b ack in the groove and really learn about the STOL Speed VGs. > > Keep the photos and vids coming Larry C. I enjoy them. They bring back m emories of the last 12 years me and my buddies have been flying in your neck of the woods. After flying out of Gantt International Airport for the last 33 years, looking at the top of pine trees and flat ground gets boring. No t at the Rock House though. There's always somewhere to go to see something new and exciting. The big plus is getting together with old Kolb friends t hat met because of Homer Kolb's little airplanes. Had it not been for Homer , I would have missed out on a big part of the long, exciting life I have en joyed since retiring in 1980, and my good friends from all over the world. > > john h > mkIII > Titus, Alabama > > > > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com] On Behalf Of Wayne Schneider > Sent: Thursday, July 06, 2017 7:51 AM > To: kolb-list(at)matronics.com > Subject: RE: Kolb-List: Pictures > > I find the video inspiring. Today, I was thinking how much work that must be to put together. It is appreciated. > > From: Larry Cottrell > Sent: Wednesday, July 5, 2017 9:33 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Pictures > > Thanks to all who commented about the pictures. Its rather amusing that I g ot more comments concerning the pictures than I ever get for all the work in producing a video. ? If you guy's would prefer pictures, they are a lot les s work, =F0=9F=98=8A > Larry > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. > ________________________________________________________________________________
Date: Jul 07, 2017
Please keep the vidios coming. They offer a rare insite into the places you fly as well as your entertaining naratives . In my part of the world,, we do not have so much of the open spaces you have. Tony South Island New Zealand > On 07 July 2017 at 03:10 Larry Cottrell wrote: > > Obviously I enjoy making the videos, It allows me to enjoy them again as well as makes it easier when telling someone about some part of this co untry. There is no doubt that I am blessed with a great area to fly, and ha ving a Kolb just makes it all that much better. It gives me great pleasure to share my good fortune with all of you. > > As for having to "walk back", I will take High Desert over muskeg any day. > > Larry > > On Thu, Jul 6, 2017 at 1:31 AM, Nick Cassara wrote: > mailto:nickc(at)mtaonline.net > Larry, I enjoy everything you postvideo or stills. I like to superimpose myself in the cockpit in the videos, and enjoy the flight. The still pictu res give the eye a chance to tease apart the country and how hostel it is .would not want to have to walk back to the homestead through most of those places! Keep them coming! Nick Cassara Palmer, Alaska 607AK ..90% done. -List" rel="noreferrer" target="_blank">http://www.matronics.com/Naviga tor?Kolb-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution -- The older I get, the less tolerant I am of those who are intolerant of othe rs. If you forward this email, or any part of it, please remove my email addres s before sending. ________________________________________________________________________________
Subject: Pictures
Date: Jul 07, 2017
Lanny L/Kolbers: Might be a good idea to check with the Kolb Aircraft Co before going to Sun and Fun to get a ride in a Kolb MKIII. Give Bryan Melborn a call to insure they will have a MKIII at Lakeland. Not far from Virginia to London, KY. Might be a good idea to visit the Kolb Factory sooner. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Lanny Lambdin Sent: Friday, July 07, 2017 6:12 AM Subject: Re: Kolb-List: Pictures Greetings, All, My name is Lanny, and I have been on this list for a few months now, learning more about the Kolb airplanes. I presently fly a Challenger II CWS I built, and a single place Loehle Sport Parasol. I built the two place Challenger mostly so my wife and I could enjoy flying together, but she is so uncomfortable in the back seat (And I don't have any experience flying from the back), so I started looking at Kolb Mark threes. We plan to attend Sun N Fun next April so we can try on the Kolb, get a demo ride perhaps and make a decision about selling the Challenger and getting a Kolb. That being said, I have enjoyed the pics and videos, Larry's especially, as I am in the mountains of Virginia, and that terrain out West is so different. I enjoy creating videos from my flight footage, especially when the flight is with a friend and particularly a grandchild! Below is a link to one of my YouTube videos in which my grandson, Chase, who was 8 at the time, got his first flight in Miss Sunshine my Challenger. If you are interested, I have a number of videos posted on my YouTube site, just search on YouTube for Miss Sunshine, or PaPaLan publications to find more. Hope you enjoy, Safe flights all, Lanny. https://youtu.be/yDByWwjpZM0 Sent from my iPad On Jul 6, 2017, at 10:53 AM, John Hauck wrote: I agree with Wayne S. Putting video together is a lot work and time. Time Larry C could be doing chores and honey do's. ;-) I enjoy them because that part of the world is completely opposite of my little piece of dirt. I like the West so much I have been going there every year since 2003, sometimes twice a year. I missed the Kolb Unplanned/Unorganized Flyin Monument Valley, UT, in 2010, but made it to the Rock House 3 months after I had a nasty accident on my mountain bike. I still like my home base at hauck's holler, Alabama, but thoroughly enjoy exploring the West. Not the populated areas, but the remote back country. Still tossing around what to do this year for the Rock House Kolb Flyin. Fly or pull the 5th wheel??? Want to do both, but the timing just ain't right. I drug Miss P'fer, my 1992 Kolb MKIII, out of the hanger a couple days ago. First time in 3 months. She was nice and clean the first of April, with brand new John Gilpin STOL Speed Vortex Generators installed. She flew great despite the load of barn dust, bug and bird crap. I got an hour flight time. Shot a bunch of landings at my short strip and at the longer grass strip at Wetumpka Airport, 08A, 11.2 miles away. I enjoy flying with the VGs, after all these years. They make an old rusty pilot look halfway decent on his landings despite my efforts to screw them up. I need to fly more to get back in the groove and really learn about the STOL Speed VGs. Keep the photos and vids coming Larry C. I enjoy them. They bring back memories of the last 12 years me and my buddies have been flying in your neck of the woods. After flying out of Gantt International Airport for the last 33 years, looking at the top of pine trees and flat ground gets boring. Not at the Rock House though. There's always somewhere to go to see something new and exciting. The big plus is getting together with old Kolb friends that met because of Homer Kolb's little airplanes. Had it not been for Homer, I would have missed out on a big part of the long, exciting life I have enjoyed since retiring in 1980, and my good friends from all over the world. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Wayne Schneider Sent: Thursday, July 06, 2017 7:51 AM Subject: RE: Kolb-List: Pictures I find the video inspiring. Today, I was thinking how much work that must be to put together. It is appreciated. From: Larry Cottrell <mailto:lcottrell1020(at)gmail.com> Sent: Wednesday, July 5, 2017 9:33 PM Subject: Kolb-List: Pictures Thanks to all who commented about the pictures. Its rather amusing that I got more comments concerning the pictures than I ever get for all the work in producing a video. ? If you guy's would prefer pictures, they are a lot less work, =F0=9F=98=8A Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jul 07, 2017
Larry, You are blessed to live in beautiful country. I always check to see if you have posted any new pictures or videos and I really like the way you present them. Thank you very much for all of your efforts. I grew up in a high desert, desolate area and now live in the big city with a million other idiots. I hope to pick up a Kolb and trailer that I can transport back to where I grew up and spend time there seeing all of the beauty before it is too late for me. Again, thanks for the wonderful videos and pictures. TK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470758#470758 ________________________________________________________________________________
Date: Jul 07, 2017
Subject: fuel tank residue ID? Pull-start wimp?
Anyone have an idea on the brown goo in this long-unused Twinstar tank? It's about the color and consistency of old-school Permatex gasket sealant, and just about as sticky. A bit of E-free mogas is marinating it now, and it seems to be softening. Old 2stroke oil? Actual mogas residue? Also, need some perspective on a pull start Rotax 503, for someone who's prior 2stroke experience is Lawn Boy & weed eaters. Am I just so over the hill that I can't pull it through more than one compression stroke? With plugs out, it seems to spin ok, but it certainly doesn't free-wheel. It has the gearbox mounted, but no prop. Thanks, Charlie ________________________________________________________________________________
Date: Jul 07, 2017
I put a pin on this map yesterday in Corning California and it's disappeared today. Anybody know what's causing that? Is it possible for anyone who logs in to just delete pins off the map? -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470765#470765 ________________________________________________________________________________
Subject: Re: fuel tank residue ID? Pull-start wimp?
Date: Jul 07, 2017
That junk looks a lot like what you might see in the bottom of a float bowl that's been sitting for a few years. I'd toss that tank and get a new one. Just as old gas turns to varnish, old plastic gets brittle and even though you might be able to clean that tank out, it's likely a lot more prone to cracking than a fuel tank should be. You can definitely get workout with pull start 503, and with no prop mounted there's less 'flywheel' effect so each compression stroke is more noticeable on the pull rope, but it should still be possible to spin the engine through several compression strokes with a good strong pull. Do you have the right amount of rope on the pulley? Are you able to pull it straight out of starter or do you have to pull it at an angle so the rope rubs on the ferrule? If the rope is rubbing on the ferrule it can bind and make it a lot harder to pull. -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470767#470767 ________________________________________________________________________________
Date: Jul 07, 2017
That junk looks a lot like what you might see in the bottom of a float bowl that's been sitting for a few years. I'd toss that tank and get a new one. Just as old gas turns to varnish, old plastic gets brittle and even though you might be able to clean that tank out, it's likely a lot more prone to cracking than a fuel tank should be. You can definitely get workout with pull start 503, and with no prop mounted there's less 'flywheel' effect so each compression stroke is more noticeable on the pull rope, but it should still be possible to spin the engine through several compression strokes with a good strong pull. Do you have the right amount of rope on the pulley? Are you able to pull it straight out of starter or do you have to pull it at an angle so the rope rubs on the ferrule? If the rope is rubbing on the ferrule it can bind and make it a lot harder to pull. -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470768#470768 ________________________________________________________________________________
Date: Jul 07, 2017
Put a prop on it. The small flywheel doesn't have enough inertia to overcome the compression. The nasty stuff in the tank is old gas and oil. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Friday, July 07, 2017 3:05 PM Subject: Kolb-List: fuel tank residue ID? Pull-start wimp? Anyone have an idea on the brown goo in this long-unused Twinstar tank? It's about the color and consistency of old-school Permatex gasket sealant, and just about as sticky. A bit of E-free mogas is marinating it now, and it seems to be softening. Old 2stroke oil? Actual mogas residue? Also, need some perspective on a pull start Rotax 503, for someone who's prior 2stroke experience is Lawn Boy & weed eaters. Am I just so over the hill that I can't pull it through more than one compression stroke? With plugs out, it seems to spin ok, but it certainly doesn't free-wheel. It has the gearbox mounted, but no prop. Thanks, Charlie ________________________________________________________________________________
Date: Jul 07, 2017
Well, there was no visible way for me to put a pin in this map. Whoever designed this mapping system is missing a chromosome for common sense. The only thing that looked like a lollipop did not open up anything that said "put a pin on the map", so I am stumped. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Fri, 7/7/17, wakataka wrote: Subject: Kolb-List: Re: Kolb flyers/owners map To: kolb-list(at)matronics.com Date: Friday, July 7, 2017, 1:47 PM "wakataka" I put a pin on this map yesterday in Corning California and it's disappeared today. Anybody know what's causing that? Is it possible for anyone who logs in to just delete pins off the map? -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470765#470765 The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jul 07, 2017
Maybe it looks like a balloon??? Perhaps I was hungry at the time. :-/ Its just to the left of the hand. Larry On Fri, Jul 7, 2017 at 3:27 PM, Bill Berle wrote: > > Well, there was no visible way for me to put a pin in this map. Whoever > designed this mapping system is missing a chromosome for common sense. > > The only thing that looked like a lollipop did not open up anything that > said "put a pin on the map", so I am stumped. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and > for-profit entities > > -------------------------------------------- > On Fri, 7/7/17, wakataka wrote: > > Subject: Kolb-List: Re: Kolb flyers/owners map > To: kolb-list(at)matronics.com > Date: Friday, July 7, 2017, 1:47 PM > > "wakataka" > > I put a pin on this map yesterday in > Corning California and it's disappeared today. Anybody know > what's causing that? Is it possible for anyone who logs in > to just delete pins off the map? > > -------- > There is something fascinating about > science. One gets such wholesale returns of conjecture out > of such a trifling investment of fact. > > Mark Twain > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470765#470765 > > > The Kolb-List Email Forum - > Navigator to browse > List Un/Subscription, > 7-Day Browse, Chat, FAQ, > - MATRONICS WEB FORUMS - > via the Web Forums! > - NEW MATRONICS LIST WIKI - > Email List Wiki! > - List Contribution Web Site - > support! > > -Matt Dralle, List Admin. > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 07, 2017
All I get is a blank page. Do I have to join something, or what to get this thing to open? john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Friday, July 07, 2017 4:39 PM Subject: Re: Kolb-List: Re: Kolb flyers/owners map Maybe it looks like a balloon??? Perhaps I was hungry at the time. :-/ Its just to the left of the hand. Larry On Fri, Jul 7, 2017 at 3:27 PM, Bill Berle wrote: Well, there was no visible way for me to put a pin in this map. Whoever designed this mapping system is missing a chromosome for common sense. The only thing that looked like a lollipop did not open up anything that said "put a pin on the map", so I am stumped. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Fri, 7/7/17, wakataka wrote: Subject: Kolb-List: Re: Kolb flyers/owners map To: kolb-list(at)matronics.com Date: Friday, July 7, 2017, 1:47 PM "wakataka" I put a pin on this map yesterday in Corning California and it's disappeared today. Anybody know what's causing that? Is it possible for anyone who logs in to just delete pins off the map? -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470765#470765 The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jul 07, 2017
You sure got good info. from that post. Throw the tank away. It not worth tr ying to save it. That's a nasty looking tank. I had a 503 on my Twinstar MKII. They're a bear to pull start. I personally u sed to prop start mine. Full choke, throttle at idle. Make sure both wheels are chocked. Let me stress that' " throttle idle". I still prefer to prop s tart my little 377. Just my thing. If it's been awhile since it was last run adjust idle screw out until the carb slide is completely seated at the butt on then lift the slide up by the throttle cable. Adjust the idle screw in tw o complete turns. You might check the plunger seat on the choke. They tend t o deteriorate if they sit to o many years closed. I speak from past experien ce. Have a great day! > On Jul 7, 2017, at 5:06 PM, John Hauck wrote: > > Put a prop on it. The small flywheel doesn't have enough inertia to overc ome the compression. > > The nasty stuff in the tank is old gas and oil. > > john h > mkIII > Titus, Alabama > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com] On Behalf Of Charlie England > Sent: Friday, July 07, 2017 3:05 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: fuel tank residue ID? Pull-start wimp? > > Anyone have an idea on the brown goo in this long-unused Twinstar tank? It 's about the color and consistency of old-school Permatex gasket sealant, an d just about as sticky. A bit of E-free mogas is marinating it now, and it s eems to be softening. > > Old 2stroke oil? Actual mogas residue? > > Also, need some perspective on a pull start Rotax 503, for someone who's p rior 2stroke experience is Lawn Boy & weed eaters. Am I just so over the hil l that I can't pull it through more than one compression stroke? With plugs o ut, it seems to spin ok, but it certainly doesn't free-wheel. It has the gea rbox mounted, but no prop. > > Thanks, > > Charlie ________________________________________________________________________________
Date: Jul 07, 2017
On Fri, Jul 7, 2017 at 4:03 PM, wakataka wrote: > > That junk looks a lot like what you might see in the bottom of a float > bowl that's been sitting for a few years. I'd toss that tank and get a new > one. Just as old gas turns to varnish, old plastic gets brittle and even > though you might be able to clean that tank out, it's likely a lot more > prone to cracking than a fuel tank should be. > > You can definitely get workout with pull start 503, and with no prop > mounted there's less 'flywheel' effect so each compression stroke is more > noticeable on the pull rope, but it should still be possible to spin the > engine through several compression strokes with a good strong pull. Do you > have the right amount of rope on the pulley? Are you able to pull it > straight out of starter or do you have to pull it at an angle so the rope > rubs on the ferrule? If the rope is rubbing on the ferrule it can bind and > make it a lot harder to pull. > > -------- > There is something fascinating about science. One gets such wholesale > returns of conjecture out of such a trifling investment of fact. > > Mark Twain > > Thank you to John and wakataka. Never thought about the prop as flywheel, when it's on the other end of a reduction drive. I'll get 'er on. The rope goes down & slightly aft to a flex-mounted pulley mounted on the a/c frame, then horizontal through the 'eye' that's welded to the forward frame member, above the pilot's head. There seems to be plenty of rope in the recoil mechanism; I can pull slowly & get 7 or 8 compression strokes before the rope handle is out in front of the rudder pedals. Obviously no way to pull that far in a single pull; just shows there's plenty of rope. Anyone know if the starter/ring gear from a Ski-Doo/Moto-Ski, etc will fit the a/c version of a 503? There are a couple on ebay now at a bit less than oxy-sucking prices. Charlie I'll definitely check the tank for cracking tendencies. It's been sitting for years, but has been inside. ________________________________________________________________________________
Date: Jul 07, 2017
Once I logged in to Google, then it made sense. If you don't have a Google account, then I guess you are out of luck. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470778#470778 ________________________________________________________________________________
Date: Jul 07, 2017
I have a google account so can't really tell what you see if you don't. But once you click link you should see a google satellite view map with locations tagged and a list there of on the left. *To add a location; use the search bar at the top to find your location or general area; then click on the upside down tear drop that is under the search bar, your pointer should turn to a cross when over the map now; click the location you wish to mark; a box should pop up to which you can add your info and picture if you want. In order to allow any one to "edit" the map (add locations/info) I have to leave it open for anyone with the link to view and edit the map. Therefore anyone can add, edit, and delete markers... If a blank marker has been made with no info in the box I usually delete them to keep things neat and clean as sometimes folks make lots of meaningless markers while trying to figure things out. -------- 912ul King Kolbra ;fun plane O300 Cessna 172B ;travel plane Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470782#470782 ________________________________________________________________________________
Date: Jul 08, 2017
Thanks, John. I have talked with Travis several times when they were instal ling a MZ202 for a customer. We shared info as I initially installed one on my C hallenger. It didn't work out for me-that's a long story-but hope it suited the custome rs' needs. I'll give them a call and see what we can work out. Take care, Lanny Sent from my iPad > On Jul 7, 2017, at 9:36 AM, John Hauck wrote: > > Lanny L/Kolbers: > > Might be a good idea to check with the Kolb Aircraft Co before going to Su n and Fun to get a ride in a Kolb MKIII. > > Give Bryan Melborn a call to insure they will have a MKIII at Lakeland. > > Not far from Virginia to London, KY. Might be a good idea to visit the Ko lb Factory sooner. > > john h > mkIII > Titus, Alabama > > > > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com] On Behalf Of Lanny Lambdin > Sent: Friday, July 07, 2017 6:12 AM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Pictures > > Greetings, All, > > My name is Lanny, and I have been on this list for a few months now, learn ing > > more about the Kolb airplanes. I presently fly a Challenger II CWS I buil t, and a > > single place Loehle Sport Parasol. I built the two place Challenger mostl y so my > > wife and I could enjoy flying together, but she is so uncomfortable in the back seat > > (And I don't have any experience flying from the back), so I started looki ng at Kolb > > Mark threes. We plan to attend Sun N Fun next April so we can try on the K olb, get > > a demo ride perhaps and make a decision about selling the Challenger and g etting > > a Kolb. > > That being said, I have enjoyed the pics and videos, Larry's especially, a s I am in the > > mountains of Virginia, and that terrain out West is so different. I enjoy creating > > videos from my flight footage, especially when the flight is with a friend and > > particularly a grandchild! Below is a link to one of my YouTube videos in which > > my grandson, Chase, who was 8 at the time, got his first flight in Miss Su nshine > > my Challenger. If you are interested, I have a number of videos posted on my > > YouTube site, just search on YouTube for Miss Sunshine, or PaPaLan publica tions to > > find more. > > Hope you enjoy, > > Safe flights all, > > Lanny. https://youtu.be/yDByWwjpZM0 > > Sent from my iPad > > On Jul 6, 2017, at 10:53 AM, John Hauck wrote: > > I agree with Wayne S. Putting video together is a lot work and time. Tim e Larry C could be doing chores and honey do's. ;-) > > I enjoy them because that part of the world is completely opposite of my l ittle piece of dirt. I like the West so much I have been going there every y ear since 2003, sometimes twice a year. I missed the Kolb Unplanned/Unorgan ized Flyin Monument Valley, UT, in 2010, but made it to the Rock House 3 mon ths after I had a nasty accident on my mountain bike. I still like my home b ase at hauck's holler, Alabama, but thoroughly enjoy exploring the West. No t the populated areas, but the remote back country. > > Still tossing around what to do this year for the Rock House Kolb Flyin. Fly or pull the 5th wheel??? Want to do both, but the timing just ain't rig ht. > > I drug Miss P'fer, my 1992 Kolb MKIII, out of the hanger a couple days ago . First time in 3 months. She was nice and clean the first of April, with b rand new John Gilpin STOL Speed Vortex Generators installed. She flew great despite the load of barn dust, bug and bird crap. I got an hour flight tim e. Shot a bunch of landings at my short strip and at the longer grass strip at Wetumpka Airport, 08A, 11.2 miles away. I enjoy flying with the VGs, af ter all these years. They make an old rusty pilot look halfway decent on hi s landings despite my efforts to screw them up. I need to fly more to get b ack in the groove and really learn about the STOL Speed VGs. > > Keep the photos and vids coming Larry C. I enjoy them. They bring back m emories of the last 12 years me and my buddies have been flying in your neck of the woods. After flying out of Gantt International Airport for the last 33 years, looking at the top of pine trees and flat ground gets boring. No t at the Rock House though. There's always somewhere to go to see something new and exciting. The big plus is getting together with old Kolb friends t hat met because of Homer Kolb's little airplanes. Had it not been for Homer , I would have missed out on a big part of the long, exciting life I have en joyed since retiring in 1980, and my good friends from all over the world. > > john h > mkIII > Titus, Alabama > > > > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com] On Behalf Of Wayne Schneider > Sent: Thursday, July 06, 2017 7:51 AM > To: kolb-list(at)matronics.com > Subject: RE: Kolb-List: Pictures > > I find the video inspiring. Today, I was thinking how much work that must be to put together. It is appreciated. > > From: Larry Cottrell > Sent: Wednesday, July 5, 2017 9:33 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Pictures > > Thanks to all who commented about the pictures. Its rather amusing that I g ot more comments concerning the pictures than I ever get for all the work in producing a video. ? If you guy's would prefer pictures, they are a lot les s work, =F0=9F=98=8A > Larry > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. > ________________________________________________________________________________
Date: Jul 08, 2017
Lanny; where in Virginia are you at? I'm in Kingsport Tn, maybe I can be of some help. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470785#470785 ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 16 Msgs - 07/07/17
Date: Jul 08, 2017
Greetings Kolbers. I have enjoyed the info and encouragement for many years. I have come to the conclusions I will not finish my KolbMarkIII Extra project. I have decided to offer this project a final time. It has appeared on the barnstormers list a couple of times but I have not wanted to give it away since I have spent over $20K to buy the kits, build them (poli-stits up through color coat done on all surfaces) and then buy the zero time VW 2180 with dual ignition and re-drive, built by Great Plains AViation Supply. If anyone is seriously interested in buying a project that has 95% of all that is needed to complete the building process you can contact me by using my email address, Bgreen(at)bimi.org. Thank you. Bob Kolb Mark III Extra, N830PB project. Sent from my iPad > On Jul 8, 2017, at 3:13 AM, Kolb-List Digest Server wrote: > ________________________________________________________________________________
Date: Jul 08, 2017
Hey, Richard, Thanks for the info/offer! I just googled directions and it would be a 4hr (239 mile) trip for us, as we are in Amherst, Va, about 1/2hr north of Lynchburg. Not bad at all, with the majority of the trip on I 81. Betty, my wife, and I are retired and have really over-scheduled our summer and early fall, so maybe we could arrange something toward the end of Sept. When you get time, I would appreciate info/pics/ videos of your Kolb and the flying you do. You can access videos of me and my planes on my YouTube site: http://www.youtube.com/channel/UCyassx3BGAUc-weOBtcMwtQ Thanks again for the offer, and we shall communicate more soon, Lanny Sent from my iPad > On Jul 8, 2017, at 7:41 AM, Richard Pike wrote: > > > Lanny; where in Virginia are you at? I'm in Kingsport Tn, maybe I can be of some help. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough. Being forgiven is wonderful. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470785#470785 > > > > > > > > > ________________________________________________________________________________
Date: Jul 08, 2017
Subject: flight pictures
Its really been hot and today was supposed to get up to 103 or more. I still wanted to fly for a while, but need to get it done before the heat got up too high. I choose the Alvord because I would have a tailwind coming back. I liked the scenery from the last flight, so I again climbed up to 6000 for the view. The second picture has the only wildlife that I saw on the whole trip. Its hard to see since I am 1000 feet agl, but there is a line of "mustangs" just in front of the plane shadow. The rest is just scenery. Even though there is 11 pictures, none are bigger than 400 k's I flew for 1.5 hours, burning 4 gallons of fuel. Most of the way I used the HACman system to lean the fuel, but when I turned towards home, The air temps at 6500 feet was 77 at 11 AM. I saw that my cht's was running at 320 degrees. I still had 15 degrees to go, but I richened the fuel just to see how much the temps came down and they dropped 16 degrees when running normal without leaning. It was heating up rapidly, and I had no inclination to dodge Dust Devils, so I turned for home. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 08, 2017
If you pull a rotax with the plugs out, make sure you have the ignition primaries grounded. I cranked mine over with the starter and the plugs out, and in that position, the ignition is in the run position. It shorted my coils and they were $700. Respectfully, Dennis Baber baberdk(at)gmail.com Stay Curious ________________________________________________________________________________
Date: Jul 08, 2017
Ouch. I haven't tried to really spin it hard with the rope (not sure I could), and now I know not to try. Thanks for the heads-up. Charlie On Sat, Jul 8, 2017 at 3:13 PM, Denny Baber wrote: > > If you pull a rotax with the plugs out, make sure you have the ignition > primaries grounded. I cranked mine over with the starter and the plugs out, > and in that position, the ignition is in the run position. It shorted my > coils and they were $700. > > Respectfully, > Dennis Baber > baberdk(at)gmail.com > > Stay Curious > ________________________________________________________________________________
Subject: Re: flight pictures
Date: Jul 09, 2017
Larry, that is some rough, but beautiful terrain there. Thanks for sharing . Lanny Sent from my iPad > On Jul 8, 2017, at 3:40 PM, Larry Cottrell wrote : > > Its really been hot and today was supposed to get up to 103 or more. I sti ll wanted to fly for a while, but need to get it done before the heat got up too high. I choose the Alvord because I would have a tailwind coming back. I liked the scenery from the last flight, so I again climbed up to 6000 for t he view. The second picture has the only wildlife that I saw on the whole tr ip. Its hard to see since I am 1000 feet agl, but there is a line of "mustan gs" just in front of the plane shadow. The rest is just scenery. Even though there is 11 pictures, none are bigger than 400 k's > > I flew for 1.5 hours, burning 4 gallons of fuel. Most of the way I used th e HACman system to lean the fuel, but when I turned towards home, The air te mps at 6500 feet was 77 at 11 AM. I saw that my cht's was running at 320 deg rees. I still had 15 degrees to go, but I richened the fuel just to see how m uch the temps came down and they dropped 16 degrees when running normal with out leaning. It was heating up rapidly, and I had no inclination to dodge Du st Devils, so I turned for home. > > Larry > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 09, 2017
Subject: Fly in out west
Are there plans for a flyin this year at the rock house? Is the rock house in the path of the eclipse? Or where is the rock house? This is Mike in Seattle, lurking for many years. FS 2 503 Rotax Cell 206-963-2118 ________________________________________________________________________________
Date: Jul 09, 2017
Subject: Re: Fly in out west
As a matter of fact there are the usual plans for the Rock House fly-in. We will gather Sept 8th until everyone gets tired and goes back home. It rarely last more than a week. https://www.google.com/maps/@42.6713155,-117.8597774,1324m/data=!3m1!1e3?hl=en I will have some gas available, and if more is needed we can go get some. Meals are group affairs, but you should arrive with any speciality items that you may require. The area is a bit remote from what you may be used to. The runway is dirt, and quite smooth. The taxi ways are a bit less so. There is about 2800 feet of smooth runway. The altitude is just under 4000 feet. There are tiedowns and plenty of room for camping. You can either drive in, with or without a plane if you are so inclined. Or even arrive in a "spam can". Our only requirement is an interest in planes and a nice temperament. Grouches will be ejected. Larry Cottrell 541 586 5030 On Sun, Jul 9, 2017 at 8:31 AM, Mike Hale wrote: > > Are there plans for a flyin this year at the rock house? Is the rock > house in the path of the eclipse? > Or where is the rock house? This is Mike in Seattle, lurking for many > years. FS 2 503 Rotax > > Cell 206-963-2118 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 14, 2017
Subject: video
https://vimeo.com/225632176 password - owyheeflyer Local flight to Antelope reservoir. My flight covered 1.25 hours - 89 miles - less than 4 gallons. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 15, 2017
Subject: Re: video
Another beautiful flight Larry, thank you for posting the video. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Fri, 7/14/17, Larry Cottrell wrote: Subject: Kolb-List: video To: "kolb-list(at)matronics.com" Date: Friday, July 14, 2017, 10:43 PM https://vimeo.com/225632176password - owyheeflyer Local flight to Antelope reservoir. My flight covered 1.25 hours - 89 miles - less than 4 gallons. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Subject: video
Date: Jul 15, 2017
Enjoyed the flight. Your videos give me the urge to fly, but I think I will be more comfortable in the 5th wheel. Another couple weeks and I'm out of here. Got a VA apt 2 Aug, then I am free to travel. Take care, john From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Saturday, July 15, 2017 12:44 AM Subject: Kolb-List: video https://vimeo.com/225632176 password - owyheeflyer Local flight to Antelope reservoir. My flight covered 1.25 hours - 89 miles - less than 4 gallons. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jul 15, 2017
Subject: Pictures from last flight
The last pictures I sent to the list were "screen shots" taken from the video footage that was taken on my Virb camera. The were pretty small. My camera remote gives me the option to take pictures while still recording video. I gave it a try yesterday, and the shots are a bit better, but still a pretty small size. The screen shots were about 300 KB while the camera snaps are about 500 KB. Should be small enough that the "Rev" doesn't have to call me out. =F0=9F=98=8A Of course with all photography it is lighting that matters, but it is better than not seeing it at all. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 15, 2017
Subject: Re: video
Another great video, Larry! I really enjoy your video. You posted some great photos of this area too. Keep'em coming! Thanks, George Have a great day! > On Jul 15, 2017, at 11:00 AM, John Hauck wrote: > > Enjoyed the flight. > > Your videos give me the urge to fly, but I think I will be more comfortabl e in the 5th wheel. > > Another couple weeks and I'm out of here. Got a VA apt 2 Aug, then I am f ree to travel. > > Take care, > > john > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com] On Behalf Of Larry Cottrell > Sent: Saturday, July 15, 2017 12:44 AM > To: kolb-list(at)matronics.com > Subject: Kolb-List: video > > https://vimeo.com/225632176 password - owyheeflyer > > Local flight to Antelope reservoir. My flight covered 1.25 hours - 89 mile s - less than 4 gallons. > > Larry > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Date: Jul 15, 2017
Sorry about posting my last to the List. You know how that goes, thinking I am replying to the sender, not realizing it was a Kolb List message. Used to do two trips a year out West, but scheduling has put a crimp in that schedule. Went through the planning stages of flying the MKIII out to the Rock House, fly commercial back to Alabama to get the 5th wheel and RZR. After the flyin, fly the MKIII back to Alabama and fly commercial back to Boise, ID. Sounded like a good idea at first, but....burns up a lot of time and money, plus puts me in a position where I have deadlines to meet. I don't do good with deadlines and appointments. Figured doing the trip on the ground sounded a wee bit better this year. Maybe next year I can fly out in May, fly home, get the 5th wheel and then do my ground trip out West. 13 years ago I flew out to the Kolb Unplanned/Unorganized Monument Valley Flyin, then back to Alabama, reloaded the MKIII and flew to Point Barrow, Kaktovik, Alaska, and Tuktoyaktuk, North West Territory. My what a difference 13 years makes. ;-) Never thought I would be such an old woozie. Gee, I forgot why I was writing this reply. ??? john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Saturday, July 15, 2017 10:07 AM Subject: Kolb-List: Pictures from last flight The last pictures I sent to the list were "screen shots" taken from the video footage that was taken on my Virb camera. The were pretty small. My camera remote gives me the option to take pictures while still recording video. I gave it a try yesterday, and the shots are a bit better, but still a pretty small size. The screen shots were about 300 KB while the camera snaps are about 500 KB. Should be small enough that the "Rev" doesn't have to call me out. =F0=9F=98=8A Of course with all photography it is lighting that matters, but it is better than not seeing it at all. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Subject: Re: Pictures from last flight
Date: Jul 15, 2017
Great pictures. Thanks for all you do. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471032#471032 ________________________________________________________________________________
Date: Jul 15, 2017
You are all most welcome! Larry On Sat, Jul 15, 2017 at 7:10 PM, Richard Pike wrote: > > Great pictures. Thanks for all you do. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough. Being forgiven is wonderful. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471032#471032 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 16, 2017
Great videos and pictures, thanks again. I still have a problem thinking of this landscape in Oregon. All that goes through the mind is green trees and Crater Lake when I think of Oregon. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471041#471041 ________________________________________________________________________________
Subject: Re: Video
Date: Jul 16, 2017
Great Video Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471092#471092 ________________________________________________________________________________
Subject: The FireFly flies! (And it flies EXXCELLENT!)
Date: Jul 18, 2017
Took it to the field of a friend, 3,000' grass strip (!) I flew it twice this morning, took off, climbed to 30', flew it down the runway and landed. Went back this evening to fly it some more, David & I both flew it for a total of 11 times, a bit over 2 hours. Burned 2.5 gallons of gas. The 277 seems to be plenty of power, but IMO it vibrates a bit much. Maybe I am spoiled by 2 cylinder engines... Performance is ideal for an ultralight, cruises at 54 mph at 4900 rpm, climbout at 45 indicated at 7-800 fpm. Should have gone ahead and put the requisite trim tab on the right aileron, and then it would have been trimmed right to start with. Will do that tomorrow. Extremely pleased. https://youtu.be/Rq8NCDpBg1A -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471150#471150 ________________________________________________________________________________
Date: Jul 18, 2017
Subject: Re: The FireFly flies! (And it flies EXXCELLENT!)
Date: Jul 18, 2017
Should have gone ahead and put the requisite trim tab on the right aileron, and then it would have been trimmed right to start with Sorry hit the wrong button.... I have seen a mk 3 that wanted to roll right on first flight,,, one wanted to roll left.... And a third required no trim Boyd Y ________________________________________________________________________________
Date: Jul 19, 2017
Hey Richard, congrats on getting the little bird flying! I liked the 1st flight takeoff video. George Have a great day! > On Jul 18, 2017, at 11:17 PM, Richard Pike wrote: > > > Took it to the field of a friend, 3,000' grass strip (!) I flew it twice this morning, took off, climbed to 30', flew it down the runway and landed. Went back this evening to fly it some more, David & I both flew it for a total of 11 times, a bit over 2 hours. Burned 2.5 gallons of gas. > The 277 seems to be plenty of power, but IMO it vibrates a bit much. Maybe I am spoiled by 2 cylinder engines... > Performance is ideal for an ultralight, cruises at 54 mph at 4900 rpm, climbout at 45 indicated at 7-800 fpm. Should have gone ahead and put the requisite trim tab on the right aileron, and then it would have been trimmed right to start with. Will do that tomorrow. > Extremely pleased. > https://youtu.be/Rq8NCDpBg1A > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough. Being forgiven is wonderful. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471150#471150 > > > > > > > > > ________________________________________________________________________________
Date: Jul 19, 2017
From: william sullivan <williamtsullivan(at)att.net>
It seemed to get up in the air really quickly. Any wind? What was the finished weight? Bill Sullivan Windsor Locks, Ct. -------------------------------------------- On Tue, 7/18/17, Richard Pike wrote: Subject: Kolb-List: The FireFly flies! (And it flies EXXCELLENT!) To: kolb-list(at)matronics.com Date: Tuesday, July 18, 2017, 11:17 PM Pike" Took it to the field of a friend, 3,000' grass strip (!) I flew it twice this morning, took off, climbed to 30', flew it down the runway and landed. Went back this evening to fly it some more, David & I both flew it for a total of 11 times, a bit over 2 hours. Burned 2.5 gallons of gas. The 277 seems to be plenty of power, but IMO it vibrates a bit much. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 ________________________________________________________________________________
Date: Jul 19, 2017
Congratulations on the new Fire Fly. Glad it performed well. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Tuesday, July 18, 2017 10:18 PM Subject: Kolb-List: The FireFly flies! (And it flies EXXCELLENT!) --> Took it to the field of a friend, 3,000' grass strip (!) I flew it twice this morning, took off, climbed to 30', flew it down the runway and landed. Went back this evening to fly it some more, David & I both flew it for a total of 11 times, a bit over 2 hours. Burned 2.5 gallons of gas. The 277 seems to be plenty of power, but IMO it vibrates a bit much. Maybe I am spoiled by 2 cylinder engines... Performance is ideal for an ultralight, cruises at 54 mph at 4900 rpm, climbout at 45 indicated at 7-800 fpm. Should have gone ahead and put the requisite trim tab on the right aileron, and then it would have been trimmed right to start with. Will do that tomorrow. Extremely pleased. https://youtu.be/Rq8NCDpBg1A -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471150#471150 ________________________________________________________________________________
Date: Jul 19, 2017
Subject: relaying information
I received an email from a Northern flyer concerning an accident with his plane. He did not wish to be identified for some reason. This is what I got. Would you mind passing this on to the Kolb group? I'd like to not put my name in with it. I recently wrecked a perfectly good Kolb MK III and would like to pass on a couple of comments. You can see some details of the incident at: http://www.summit107.com/news/east-kootenay-news/plane-crash -near-creston-results-in-two-people-receiving-minor-injuries/ The engine was a beautifully converted Geo 4 cylinder that ran as smooth as silk. This installation might be a little heavier than a 912 and a friend predicted that in an accident the engine would be in our laps. In fact, as you can see from the picture, there was next to no structural failure in the cage/engine mount area in spite of a landing that wiped off the gear, flattened the belly and essentially wrote off the plane. I was the pilot and sustained minor back damage: lots of aches and pains and a minor concussion (some memory loss of the last critical moments) but nothing broken. My friend on the other hand had severe back damage as in a broken back needing pins to fuse several vertebrae.She will recover most function but will not likely be up to her pre-accident capability. It is possible that her damage was caused by impact with the battery which was under her seat. If I ever own another plane like this I would look into some kind of rigid seat pan for back protection Because of the memory loss, I cannot say for sure what happened. There was a power reduction after take-off . I did push the nose down to go under power lines. I did not pull up enough. Don't know why. ----------------------------------------------------------------------------------------------------------------------------------------------------------------- One of the things that we could take away from this incident is that the sling seats can be hazardous to your health. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 19, 2017
How in the world did you find an operating 277? It seemed to do just fine with it. I am considering repainting my plane back to blue again. I'm having a hard time sneaking up on my neighbor next door. Congratulations Larry On Tue, Jul 18, 2017 at 9:17 PM, Richard Pike wrote: > > Took it to the field of a friend, 3,000' grass strip (!) I flew it twice > this morning, took off, climbed to 30', flew it down the runway and landed. > Went back this evening to fly it some more, David & I both flew it for a > total of 11 times, a bit over 2 hours. Burned 2.5 gallons of gas. > The 277 seems to be plenty of power, but IMO it vibrates a bit much. Maybe > I am spoiled by 2 cylinder engines... > Performance is ideal for an ultralight, cruises at 54 mph at 4900 rpm, > climbout at 45 indicated at 7-800 fpm. Should have gone ahead and put the > requisite trim tab on the right aileron, and then it would have been > trimmed right to start with. Will do that tomorrow. > Extremely pleased. > https://youtu.be/Rq8NCDpBg1A > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough. Being forgiven is wonderful. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471150#471150 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 19, 2017
We are still struggling with the weight, our cheesy bathroom scales say it is ~260, it could be legal, but we don't know what it actually weighs. Even with these bogus scales it at least falls within the W&B envelope. Got an A&P friend with real scales, will get him to weigh it. Anyway, it is very close to legal U/L weight and we are not done fiddling with that part yet; we are determined that it is going to end up legal. Flight yesterday was with no wind, it accelerates slower on the flat than the other Kolbs due to the small engine, but once it gets off, it climbs really good because of the light weight. We found a local guy who had purchased a 277 and sent it to Lockwood and had it totally rebuilt, it has a 2.58:1 A box on it, 64" 2 blade Ivoprop. It runs really smooth at cruise power, but vibrates a lot at idle, don't yet know why. Will be putting a trim tab on the right aileron this evening and hoping to fly it to it's permanent home. Nice little 28 mile cross country. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471168#471168 ________________________________________________________________________________
Date: Jul 19, 2017
Very nice. All I can suggest is to re-read Jack Hart's web site for dietary suggestions. Anybody hear from him lately? Bil Sullivan -------------------------------------------- On Wed, 7/19/17, Richard Pike wrote: Subject: Kolb-List: Re: The FireFly flies! (And it flies EXXCELLENT!) To: kolb-list(at)matronics.com Date: Wednesday, July 19, 2017, 1:48 PM Pike" We are still struggling with the weight, our cheesy bathroom scales say it is ~260, it could be legal, but we don't know what it actually weighs. Even with these bogus scales it at least falls within the W&B envelope. ________________________________________________________________________________
Date: Jul 19, 2017
Does it still have the same vibration problem at high idle? At what RPM does it clean up? Over the years I have seen most folks try to slow idle all models of the Rotax, while the engine it trying to eat itself with adverse feedback and gear box chatter. If it was mine, I'd idle it fast enough to get out of the vibrations mode, if that is possible, and still being able to comfortably control the aircraft. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Wednesday, July 19, 2017 12:49 PM Subject: Kolb-List: Re: The FireFly flies! (And it flies EXXCELLENT!) --> We are still struggling with the weight, our cheesy bathroom scales say it is ~260, it could be legal, but we don't know what it actually weighs. Even with these bogus scales it at least falls within the W&B envelope. Got an A&P friend with real scales, will get him to weigh it. Anyway, it is very close to legal U/L weight and we are not done fiddling with that part yet; we are determined that it is going to end up legal. Flight yesterday was with no wind, it accelerates slower on the flat than the other Kolbs due to the small engine, but once it gets off, it climbs really good because of the light weight. We found a local guy who had purchased a 277 and sent it to Lockwood and had it totally rebuilt, it has a 2.58:1 A box on it, 64" 2 blade Ivoprop. It runs really smooth at cruise power, but vibrates a lot at idle, don't yet know why. Will be putting a trim tab on the right aileron this evening and hoping to fly it to it's permanent home. Nice little 28 mile cross country. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471168#471168 ________________________________________________________________________________
Date: Jul 19, 2017
On Wed, 7/19/17, John Hauck wrote: "... while the engine it trying to eat itself with adverse feedback and gear box chatter. If it was mine, I'd idle it fast enough to get out of the vibrations mode, ..." Agree 100%. I have very little experience with 2 stroke engines, but I do know that harmonic vibrations and harsh load reversals are bad for any engine. There is little or no upside to operating any engine in an RPM range that creates bad vicrations. Any experienced pilot will tell you that an airplane will "talk to you" and tell you when it's happy or unhappy. ________________________________________________________________________________
Date: Jul 19, 2017
It cleans up at around 3500. I am wondering if the power pulses of a single and the coupling design of the A & B gearboxes is not going to make for a happy relationship? Years ago I had a 277 on my Hummer with the Maxair belt drive and it was smooth as silk. Might have to look into trying to scrounge up an old belt redrive. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471173#471173 ________________________________________________________________________________
Date: Jul 19, 2017
Q2hlY2sgdGhlIE1NT0kgKE1hc3MgTW9tZW50IG9mIEluZXJ0aWEpIG9mIHlvdXIgcHJvcGVsbGVy LiAgWW91ciBwcm9wZWxsZXIgbWF5IGJlIHRvbyBoZWF2eS4NCg0KRnJvbTogUmljaGFyZCBQaWtl DQpTZW50OiBXZWRuZXNkYXksIEp1bHkgMTksIDIwMTcgMzoyMSBQTQ0KVG86IGtvbGItbGlzdEBt YXRyb25pY3MuY29tDQpTdWJqZWN0OiBLb2xiLUxpc3Q6IFJlOiBUaGUgRmlyZUZseSBmbGllcyEg KEFuZCBpdCBmbGllcyBFWFhDRUxMRU5UISkNCg0KLS0+IEtvbGItTGlzdCBtZXNzYWdlIHBvc3Rl ZCBieTogIlJpY2hhcmQgUGlrZSIgPHRoZWdyZXliYXJvbkBjaGFydGVyLm5ldD4NCg0KSXQgY2xl YW5zIHVwIGF0IGFyb3VuZCAzNTAwLiBJIGFtIHdvbmRlcmluZyBpZiB0aGUgcG93ZXIgcHVsc2Vz IG9mIGEgc2luZ2xlIGFuZCB0aGUgY291cGxpbmcgZGVzaWduIG9mIHRoZSBBICYgQiBnZWFyYm94 ZXMgaXMgbm90IGdvaW5nIHRvIG1ha2UgZm9yIGEgaGFwcHkgcmVsYXRpb25zaGlwPyBZZWFycyBh Z28gSSBoYWQgYSAyNzcgb24gbXkgSHVtbWVyIHdpdGggdGhlIE1heGFpciBiZWx0IGRyaXZlIGFu ZCBpdCB3YXMgc21vb3RoIGFzIHNpbGsuIE1pZ2h0IGhhdmUgdG8gbG9vayBpbnRvIHRyeWluZyB0 byBzY3JvdW5nZSB1cCBhbiBvbGQgYmVsdCByZWRyaXZlLg0KDQotLS0tLS0tLQ0KUmljaGFyZCBQ aWtlDQpLb2xiIE1LSUlJIE40MjBQICg0MjBsZFBvb3BzKQ0KS2luZ3Nwb3J0LCBUTiAzVE4wDQoN CkZvcmdpdmluZyBpcyB0b3VnaC4gQmVpbmcgZm9yZ2l2ZW4gaXMgd29uZGVyZnVsLg0KDQoNCg0K DQpSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6DQoNCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNz LmNvbS92aWV3dG9waWMucGhwP3A9NDcxMTczIzQ3MTE3Mw0KDQoNCg0KDQoNCg0KXy09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8t PSAgICAgICAgICAtIFRoZSBLb2xiLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0 cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55IExp c3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBT ZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFy ZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25p Y3MuY29tL05hdmlnYXRvcj9Lb2xiLUxpc3QNCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAg IC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2 YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAgLSBORVcgTUFUUk9O SUNTIExJU1QgV0lLSSAtDQpfLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNzIEVtYWls IExpc3QgV2lraSENCl8tPSAgIC0tPiBodHRwOi8vd2lraS5tYXRyb25pY3MuY29tDQpfLT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0K Xy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KXy09ICBUaGFu ayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPSAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCl8tPSAgIC0tPiBodHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0KDQo ________________________________________________________________________________
Date: Jul 19, 2017
Prop weight is well within range for an A or B box, it is a new two blade 64" Ivo, so that is minimal, but something is screwy with whatever we are doing. We idled it up to 3,000 minimum and got rid of all the single cylinder/gearbox shake at idle, but then trying to land it was a pain - float and float some more. So idled it back down to 2,200 so you can slow down on approach and then throttle it right back up to 3,000 once you get down and settled. So you only have a few moments of excessive shake. But that is not the problem; the problem is that even when it is running comparitively smoothly @ 3,000 rpm or over, this thing simply vibrates way more than any airplane or U/L I have ever flown, something is not right. The little engine runs fine, flew it a short 30 mile cross country this evening from the big grass strip where we did our test flights to the field where it will be living for the next few months, and the only rpm that doesn't vibrate excessively is right at 5,200, everything else you can feel the vibration all through the airframe. Something Dave pointed out is that when we first got this airplane it had a 447 on it; after we put the airframe back together and ran it up, that engine vibrated excessively just like this one does. I am starting to wonder about our Lord mounts. But right now we are open to all suggestions. Tomorrow I'll post some pictures of the engine/mounts, etc. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471178#471178 ________________________________________________________________________________
Date: Jul 19, 2017
On 7/19/2017 9:06 PM, Richard Pike wrote: > > Prop weight is well within range for an A or B box, it is a new two blade 64" Ivo, so that is minimal, but something is screwy with whatever we are doing. We idled it up to 3,000 minimum and got rid of all the single cylinder/gearbox shake at idle, but then trying to land it was a pain - float and float some more. So idled it back down to 2,200 so you can slow down on approach and then throttle it right back up to 3,000 once you get down and settled. So you only have a few moments of excessive shake. > > But that is not the problem; the problem is that even when it is running comparitively smoothly @ 3,000 rpm or over, this thing simply vibrates way more than any airplane or U/L I have ever flown, something is not right. > > The little engine runs fine, flew it a short 30 mile cross country this evening from the big grass strip where we did our test flights to the field where it will be living for the next few months, and the only rpm that doesn't vibrate excessively is right at 5,200, everything else you can feel the vibration all through the airframe. > > Something Dave pointed out is that when we first got this airplane it had a 447 on it; after we put the airframe back together and ran it up, that engine vibrated excessively just like this one does. I am starting to wonder about our Lord mounts. > > But right now we are open to all suggestions. Tomorrow I'll post some pictures of the engine/mounts, etc. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > Richard, I don't remember seeing many UL/light plane guys talk about prop balance; particularly dynamic balance. But it might be worth a look, especially if an EAA chapter nearby has a dynamic prop balancer for loan or rent (ours does, here in central MS). What you're describing could easily be caused by prop imbalance. It's the nature of the beast that we notice lower frequency vibes, but are not sensitive to higher frequencies. So your vibe may be there all across the rpm spectrum, but you just can't feel it when the engine's running at higher rpm. There's also the issue of resonance. Your particular combination of prop, gearbox, engine, airframe, mount cushions, etc may be near its system resonance in the range they you're able to idle the engine effectively. Any imbalance may be conspiring with a possible resonant freq that's near your idle rpm to give you severe vibes in that range. Without actual data it's just wild speculation, but something to consider. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 19, 2017
Richard - Congratulations on the successful first flight. I had about 100 hours on 277 engines before I went to Kawasaki, mainly to avoid vibration that was tearing up my airframe. The 277 is a really powerful and light weight little engine, but it does vibrate more than any 2 cylinder I've ever flown. I had one of those dynamic prop balancer thingies on mine and it helped just a bit. Not sure it was worth the extra weight, particularly if you are striving to make it legal. One thing you might want to check the spring washers in the gearbox. If spring washers get weak there will be excessive 'give' in the knuckle joint. It can make the engine shake really bad at low RPM. If you're hearing a clacking noise associated with the vibration, suspect your spring washers. There was a service bulletin on the A gearbox. It originally had something like 9 spring washers and it was updated to 12. Same shaft, just more washers packed onto it to tighten up the knuckle joint. B boxes always had the larger number of spring washers. I'll try to attach the service bulletin and the gearbox repair instructions from the CPS catalog. I was able to do the spring washer replacement in a big bench vise using a big socket in place of the special Rotax tool, which is no longer available. If you read the Rotax manuals, they say the spring washers should be replaced something like every 100 hours. Nobody I know does that, but if the spring washers do get weak, it will make your engine shake like crazy, be hard to start, and sometimes hard to get to come off idle. -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471181#471181 Attachments: http://forums.matronics.com//files/gearboxupdateinstructions_389.pdf http://forums.matronics.com//files/gearboxrepair2_704.pdf ________________________________________________________________________________
Date: Jul 20, 2017
Thanks for those instructions Wakataka, the engine and gearbox are a new rebuild from Lockwood, the engine is very easy to start - usually one pull, and it has no problems coming off idle. Nevertheless, we may still need to take the box apart to have a look and those instructions will be necessary. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471191#471191 ________________________________________________________________________________
Date: Jul 20, 2017
I think we found the vibration problem; we think that dummy Pike designed the rubber muffler hangars incorrectly, allowing a harmonic resonance to set up between the engine and the muffler. Will fabricate new rubber hangars this afternoon to replace the ones that got destroyed in only 3.5 hours of flight, and run it up tomorrow so we can watch it close and see what is happening in that area. Thanks for all the helpful suggestions. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471204#471204 ________________________________________________________________________________
Date: Jul 20, 2017
Subject: flight today
I flew to Jordan Craters today so that I could get a video record with a much better camera. I made a video some years ago but the camera only had a resolution of 480 at the best. It is such a striking visual area that I wanted to do it again. The flight was an hour and 36 minutes, burning about 3.25 gallons of fuel. Average speed of 65, which was much better than I expected. I actually got a bit chilly on the way back, which was unusual to say the least. I will upload the video tonight since my upload link is about 1MB . The video unfortunately is about 9 minutes long. I cut as much out as I could, unfortunately there is a lot that is worth seeing, at least I think so. :-/ Here are some of the snapshots of the flight. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 20, 2017
At least the Ultra Bug is in good company while we try and figure out how to make it's shakes go away: -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471215#471215 Attachments: http://forums.matronics.com//files/p1060092_medium_803.jpg ________________________________________________________________________________
Date: Jul 20, 2017
Must of had a sale on blue paint. :-) Larry On Thu, Jul 20, 2017 at 9:16 PM, Richard Pike wrote: > > At least the Ultra Bug is in good company while we try and figure out how > to make it's shakes go away: > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough. Being forgiven is wonderful. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471215#471215 > > > Attachments: > > http://forums.matronics.com//files/p1060092_medium_803.jpg > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 21, 2017
Subject: Flight to Jordan Craters
https://vimeo.com/226399752 password - owyheeflyer Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 21, 2017
It is difficult to grasp how large the Jordan Craters are, how huge the lava spout is, even when standing on it. Must have really been an eye catcher when the lava was flowing. Thanks for sharing. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Thursday, July 20, 2017 8:35 PM Subject: Kolb-List: flight today I flew to Jordan Craters today so that I could get a video record with a much better camera. I made a video some years ago but the camera only had a resolution of 480 at the best. It is such a striking visual area that I wanted to do it again. The flight was an hour and 36 minutes, burning about 3.25 gallons of fuel. Average speed of 65, which was much better than I expected. I actually got a bit chilly on the way back, which was unusual to say the least. I will upload the video tonight since my upload link is about 1MB . The video unfortunately is about 9 minutes long. I cut as much out as I could, unfortunately there is a lot that is worth seeing, at least I think so. :-/ Here are some of the snapshots of the flight. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jul 21, 2017
Subject: Re: flight today
Larry Great pictures, I suspect any mono camera does not fully capture the panorama. We all know piloting one's own aircraft is nearly magical. The chill on your return, that is due to Global Warming. Jim Mk3 Pilot On Fri, Jul 21, 2017 at 5:59 AM, John Hauck wrote: > It is difficult to grasp how large the Jordan Craters are, how huge the > lava spout is, even when standing on it. Must have really been an eye > catcher when the lava was flowing. > > > Thanks for sharing. > > > john h > > mkIII > > Titus, Alabama > > > *From:* owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list- > server(at)matronics.com] *On Behalf Of *Larry Cottrell > *Sent:* Thursday, July 20, 2017 8:35 PM > *To:* kolb-list(at)matronics.com > *Subject:* Kolb-List: flight today > > > I flew to Jordan Craters today so that I could get a video record with a > much better camera. I made a video some years ago but the camera only had a > resolution of 480 at the best. It is such a striking visual area that I > wanted to do it again. The flight was an hour and 36 minutes, burning about > 3.25 gallons of fuel. Average speed of 65, which was much better than I > expected. I actually got a bit chilly on the way back, which was unusual to > say the least. > > > I will upload the video tonight since my upload link is about 1MB . The > video unfortunately is about 9 minutes long. I cut as much out as I could, > unfortunately there is a lot that is worth seeing, at least I think so. :-/ > Here are some of the snapshots of the flight. > > Larry > > > -- > > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > > *If you forward this email, or any part of it, please remove my email > address before sending.* > ________________________________________________________________________________
Date: Jul 21, 2017
Gentlemen: The propeller is by far the larges rotating mass and therefore the largest potential for vibration. From your discussion I am confident your propeller is out of balance. Swap in a known good propeller. I expect your vibration will disappear. Jim Mk3 Pilot On Wed, Jul 19, 2017 at 9:02 PM, Charlie England wrote: > > On 7/19/2017 9:06 PM, Richard Pike wrote: > >> > >> >> Prop weight is well within range for an A or B box, it is a new two blade >> 64" Ivo, so that is minimal, but something is screwy with whatever we are >> doing. We idled it up to 3,000 minimum and got rid of all the single >> cylinder/gearbox shake at idle, but then trying to land it was a pain - >> float and float some more. So idled it back down to 2,200 so you can slow >> down on approach and then throttle it right back up to 3,000 once you get >> down and settled. So you only have a few moments of excessive shake. >> >> But that is not the problem; the problem is that even when it is running >> comparitively smoothly @ 3,000 rpm or over, this thing simply vibrates way >> more than any airplane or U/L I have ever flown, something is not right. >> >> The little engine runs fine, flew it a short 30 mile cross country this >> evening from the big grass strip where we did our test flights to the field >> where it will be living for the next few months, and the only rpm that >> doesn't vibrate excessively is right at 5,200, everything else you can feel >> the vibration all through the airframe. >> >> Something Dave pointed out is that when we first got this airplane it had >> a 447 on it; after we put the airframe back together and ran it up, that >> engine vibrated excessively just like this one does. I am starting to >> wonder about our Lord mounts. >> >> But right now we are open to all suggestions. Tomorrow I'll post some >> pictures of the engine/mounts, etc. >> >> -------- >> Richard Pike >> Kolb MKIII N420P (420ldPoops) >> Kingsport, TN 3TN0 >> >> Richard, > > I don't remember seeing many UL/light plane guys talk about prop balance; > particularly dynamic balance. But it might be worth a look, especially if > an EAA chapter nearby has a dynamic prop balancer for loan or rent (ours > does, here in central MS). > > What you're describing could easily be caused by prop imbalance. It's the > nature of the beast that we notice lower frequency vibes, but are not > sensitive to higher frequencies. So your vibe may be there all across the > rpm spectrum, but you just can't feel it when the engine's running at > higher rpm. > > There's also the issue of resonance. Your particular combination of prop, > gearbox, engine, airframe, mount cushions, etc may be near its system > resonance in the range they you're able to idle the engine effectively. Any > imbalance may be conspiring with a possible resonant freq that's near your > idle rpm to give you severe vibes in that range. > > Without actual data it's just wild speculation, but something to consider. > > Charlie > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: Jul 21, 2017
Problem appears to be resolved. It was in how I had tied the muffler to the head braces via the rubber exhaust hangers. I had them too tight, and it set up a resonant interaction between the engine and the muffler. Consequently - during a 1 hour flight - it broke 3 out of the 4 muffler hangars. These are the exact same hangars I use on my MKIII, and typically they last several years, and then I replace them just as a precaution, not because they are damaged or worn. Ran it a bunch with the new rubber hangars this morning, vibration was about 90% better, flew it a couple times while adjusting the aileron pushrods and resizing the right aileron trim tab, and I think we are about to get it whipped. We would like to change the muffler configuration: if anybody has a Rotax straight exhaust expansion cone (A- "Straight" Exhaust in the attachment) and you want to sell it, let me know.Would also consider a "C" exhaust as in the jpeg. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471238#471238 Attachments: http://forums.matronics.com//files/503exmeasurements_103.jpg ________________________________________________________________________________
Date: Jul 22, 2017
Subject: Re: Flight to Jordan Craters
Great video,Larry! Mighty rugged country. You deal with rock and I deal with to many trees. I took off the 4:00X 6 tires that I had using a went to some slightly larger 6:00X6 turf tires. Kinda smoothes out some of the rougher grass runways we have up here in northern Michigan. Have a great day! George Firestar , FS100 14GDH Mesick, Michigan gdhelton(at)gmail.com > On Jul 21, 2017, at 8:19 AM, Larry Cottrell wrote: > > owyheeflyer ________________________________________________________________________________
Date: Jul 22, 2017
Larry I think I have a nice back yard to fly in but yours is super. Thanks for sharing. Rick Neilsen Redrive VW Powered MKIIIC On Fri, Jul 21, 2017 at 8:19 AM, Larry Cottrell wrote: > https://vimeo.com/226399752 password - owyheeflyer > > Larry > > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > ________________________________________________________________________________
Subject: summer windscreen templet
Date: Jul 23, 2017
Starting to work on the finishing details for my cockpit on the FS II. I am thinking of using the short summer windscreen. Does Kolb or anyone have a pattern for this? Thanks. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471255#471255 ________________________________________________________________________________
Date: Jul 23, 2017
Subject: video
This should be the last video, since I am running out of new places to show you. I am a bit disappointed in this one. It was taken too early in the morning. The sun plays havoc with the sensors in the camera. The Virb editing program has changed and I left out all the metric's gathered by the camera. I started to redo it, but it was so much trouble and time consuming, that I scrapped the idea. The area is magnificent however, and I am amazed at the courage and toughness that some one would have chosen it to "raise a family". My sources tell me that it was a Basque Sheep Herder from Spain that built the ranch and Lived there. https://vimeo.com/226653937 password - owyheeflyer Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: Video
Date: Jul 23, 2017
Another great video. I certainly hope that is not your last one. Your videos are great and I am always looking forward to the next one. Thank You for putting them up. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471260#471260 ________________________________________________________________________________
Subject: Re: Video
Date: Jul 23, 2017
Thank you Larry. Nice way to end a great day. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471261#471261 ________________________________________________________________________________
Date: Jul 23, 2017
Subject: Re: video
Larry, wonderful video as usual! Are you using a Virb Elite? I'm thinking ab out buying one of these. I think the quality of your recording is excellent. I'd like another camera to go along with my GoPro Session 5. Thanks, George Have a great day! > On Jul 23, 2017, at 8:43 PM, Larry Cottrell wrot e: > > This should be the last video, since I am running out of new places to sho w you. I am a bit disappointed in this one. It was taken too early in the mo rning. The sun plays havoc with the sensors in the camera. The Virb editing p rogram has changed and I left out all the metric's gathered by the camera. I started to redo it, but it was so much trouble and time consuming, that I s crapped the idea. > > The area is magnificent however, and I am amazed at the courage and toughn ess that some one would have chosen it to "raise a family". My sources tell m e that it was a Basque Sheep Herder from Spain that built the ranch and Live d there. > > https://vimeo.com/226653937 password - owyheeflyer > > Larry > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Date: Jul 23, 2017
Subject: Re: video
George, I am using a virb Elite. I think it is better than the go pro. I never was able to stabilize a go pro. The battery life is excellent, you can take pictures while recording as well. Right now they are only about $149. on Amazon. Larry On Sun, Jul 23, 2017 at 9:25 PM, George Helton wrote: > Larry, wonderful video as usual! Are you using a Virb Elite? I'm thinking > about buying one of these. I think the quality of your recording is > excellent. I'd like another camera to go along with my GoPro Session 5. > Thanks, George > > Have a great day! > > On Jul 23, 2017, at 8:43 PM, Larry Cottrell > wrote: > > This should be the last video, since I am running out of new places to > show you. I am a bit disappointed in this one. It was taken too early in > the morning. The sun plays havoc with the sensors in the camera. The Virb > editing program has changed and I left out all the metric's gathered by the > camera. I started to redo it, but it was so much trouble and time > consuming, that I scrapped the idea. > > The area is magnificent however, and I am amazed at the courage and > toughness that some one would have chosen it to "raise a family". My > sources tell me that it was a Basque Sheep Herder from Spain that built the > ranch and Lived there. > > https://vimeo.com/226653937 password - owyheeflyer > > Larry > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 24, 2017
Subject: Re: video
Thank you for your for input Larry. I'm going to order one today. The GoPro S ession 5 is very small and works well. But, they are pricey and Virb Elite s eems to have all of the same features for less money. Thank you! George Have a great day! > On Jul 23, 2017, at 11:51 PM, Larry Cottrell wro te: > > George, I am using a virb Elite. I think it is better than the go pro. I n ever was able to stabilize a go pro. The battery life is excellent, you can t ake pictures while recording as well. Right now they are only about $149. on Amazon. > Larry > >> On Sun, Jul 23, 2017 at 9:25 PM, George Helton wrote : >> Larry, wonderful video as usual! Are you using a Virb Elite? I'm thinking about buying one of these. I think the quality of your recording is excelle nt. I'd like another camera to go along with my GoPro Session 5. Thanks, Geo rge >> >> Have a great day! >> >>> On Jul 23, 2017, at 8:43 PM, Larry Cottrell wr ote: >>> >>> This should be the last video, since I am running out of new places to s how you. I am a bit disappointed in this one. It was taken too early in the m orning. The sun plays havoc with the sensors in the camera. The Virb editing program has changed and I left out all the metric's gathered by the camera. I started to redo it, but it was so much trouble and time consuming, that I scrapped the idea. >>> >>> The area is magnificent however, and I am amazed at the courage and toug hness that some one would have chosen it to "raise a family". My sources tel l me that it was a Basque Sheep Herder from Spain that built the ranch and L ived there. >>> >>> https://vimeo.com/226653937 password - owyheeflyer >>> >>> Larry >>> -- >>> The older I get, the less tolerant I am of those who are intolerant of o thers. >>> >>> If you forward this email, or any part of it, please remove my email add ress before sending. > > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Subject: Fun Fest Balloon Rally 2017
Date: Jul 25, 2017
Took a lady from church flying Saturday morning, it was the last day of a week long local event called Fun Fest. She was an enthusiastic photographer, here are some of the ones she took. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471274#471274 Attachments: http://forums.matronics.com//files/funfest17s_medium_204.jpg http://forums.matronics.com//files/funfest17r_medium_162.jpg http://forums.matronics.com//files/funfest17o_medium_202.jpg http://forums.matronics.com//files/funfest17n_medium_454.jpg http://forums.matronics.com//files/funfest17m_medium_517.jpg http://forums.matronics.com//files/funfest17l_medium_930.jpg http://forums.matronics.com//files/funfest17j_medium_195.jpg http://forums.matronics.com//files/funfest17i_medium_156.jpg http://forums.matronics.com//files/funfest17h_medium_558.jpg http://forums.matronics.com//files/funfest17g_medium_159.jpg http://forums.matronics.com//files/funfest17e_medium_117.jpg http://forums.matronics.com//files/funfest17d_medium_197.jpg http://forums.matronics.com//files/funfest17c_medium_358.jpg ________________________________________________________________________________
Date: Jul 25, 2017
I like the Sun Burst Balloon. Enjoyed its smile which put a smile on my face too. john h mkIII Titus, Al -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Tuesday, July 25, 2017 10:04 AM Subject: Kolb-List: Fun Fest Balloon Rally 2017 --> Took a lady from church flying Saturday morning, it was the last day of a week long local event called Fun Fest. She was an enthusiastic photographer, here are some of the ones she took. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471274#471274 Attachments: http://forums.matronics.com//files/funfest17s_medium_204.jpg http://forums.matronics.com//files/funfest17r_medium_162.jpg http://forums.matronics.com//files/funfest17o_medium_202.jpg http://forums.matronics.com//files/funfest17n_medium_454.jpg http://forums.matronics.com//files/funfest17m_medium_517.jpg http://forums.matronics.com//files/funfest17l_medium_930.jpg http://forums.matronics.com//files/funfest17j_medium_195.jpg http://forums.matronics.com//files/funfest17i_medium_156.jpg http://forums.matronics.com//files/funfest17h_medium_558.jpg http://forums.matronics.com//files/funfest17g_medium_159.jpg http://forums.matronics.com//files/funfest17e_medium_117.jpg http://forums.matronics.com//files/funfest17d_medium_197.jpg http://forums.matronics.com//files/funfest17c_medium_358.jpg ________________________________________________________________________________
Subject: Re: Video
Date: Jul 25, 2017
[quote="lcottrell"]This should be the last video, since I am running out of new places to show you. .... Larry, I hope that you make more videos. I really look forward to them and I want to thank you for all you have done so far. I have been curious about your engine that you seem to be having good luck with so far. I think there would be many of us who would like to see a short video of you showing and talking about your engine and aircraft. You are blessed to live in such beautiful county. Thanks again. TK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471276#471276 ________________________________________________________________________________
Subject: Re: Fun Fest Balloon Rally 2017
Date: Jul 25, 2017
John Hauck wrote: > I like the Sun Burst Balloon. Enjoyed its smile which put a smile on my face too. > > john h > mkIII > Titus, Al-- That's the Fun Fest mascot; "Festus." :D -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471279#471279 ________________________________________________________________________________
Date: Jul 25, 2017
Wow, nice pictures! Have a great day! > On Jul 25, 2017, at 11:03 AM, Richard Pike wrote: > > > Took a lady from church flying Saturday morning, it was the last day of a week long local event called Fun Fest. She was an enthusiastic photographer, here are some of the ones she took. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough. Being forgiven is wonderful. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471274#471274 > > > > > Attachments: > > http://forums.matronics.com//files/funfest17s_medium_204.jpg > http://forums.matronics.com//files/funfest17r_medium_162.jpg > http://forums.matronics.com//files/funfest17o_medium_202.jpg > http://forums.matronics.com//files/funfest17n_medium_454.jpg > http://forums.matronics.com//files/funfest17m_medium_517.jpg > http://forums.matronics.com//files/funfest17l_medium_930.jpg > http://forums.matronics.com//files/funfest17j_medium_195.jpg > http://forums.matronics.com//files/funfest17i_medium_156.jpg > http://forums.matronics.com//files/funfest17h_medium_558.jpg > http://forums.matronics.com//files/funfest17g_medium_159.jpg > http://forums.matronics.com//files/funfest17e_medium_117.jpg > http://forums.matronics.com//files/funfest17d_medium_197.jpg > http://forums.matronics.com//files/funfest17c_medium_358.jpg > > > > > > ________________________________________________________________________________
Date: Jul 27, 2017
Subject: Yet another Video
I had thought that I was done, but then the Monsoons from NM and Arizona decide to bend the jet stream our way. This of course brings heat and moisture. The heavy clouds build up static electricity that just has to discharge as it passes over some of the most volatale terrain outside of lower California. We were under "flood watch", but the forecast was for only 30 percent of the area. Well the floods did not arrive, but the lightening did. The area that got the most of it was the area burned over 3 or 4 years ago, and consisting of Cheat Grass. Of course fires soon generate their own wind, and it doesn't take too long before things get interesting. I waited until I was sure that the fire was out and whatever TFR's were in place, were not in effect. The fire consumed about 1700 acres before it was put out. You will notice that at the South end of the fire, further burning was stopped by the application of Fire retardant. They use "crop dusters" first, to drop loads of retardant. It takes time and quite possibly the large tankers are in use at higher priority fires and are not available. You can see quite plainly that they effectively put out the fire on the South end of the mountain. https://vimeo.com/227323102 password owyheeflyer Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 27, 2017
Subject: Re: Yet another Video
I made a mistake on the size of the fire, Rather than 1700 acres correct that to 17000 acres. Larry ________________________________________________________________________________
Date: Jul 28, 2017
That's okay, Larry. It was another well done video. My new virb elite arrive d yesterday. Now it's going be figuring out the software and where to mount i t. Looks like a nice camera. George Have a great day! > On Jul 27, 2017, at 11:40 PM, Larry Cottrell wro te: > > I made a mistake on the size of the fire, Rather than 1700 acres correct t hat to 17000 acres. > Larry ________________________________________________________________________________
Date: Jul 28, 2017
Subject: Virb settings - Yet another video
The settings that I use fits my needs best, and are as follows. video mode 1080P field of view- Ultra Zoom Loop- off Auto Record- When moving Digital Stabilizer- on Lens correction- check Of all the settings on the camera, the "Ultra Zoom" is the most important and gets rid of the fish eye effect. I use Auto record simply because it makes its use "fool proof". I do have a remote, but I am so ingenious that I can still screw it up. With a good Micro SD card it will record up to about 6 hours, and none of us has that much range. You can still activate the camera while the virb is recording with the remote. The camera has Wifi, but its line of sight and not as reliable as a real remote. If you want to see the G Metrix (Speed etc) you will have to use the editing program that comes with the camera. It ( to me) seems to be a bit difficult to use, but then I probably haven't invested the time to learn it. I make a basic cut of what I want to show, then export it to a folder on my computer. I will then import it into Cyberlink editing program and finish it there. If there is any way that I can help you with it don't hesitate to ask. Looking forward to some videos from you. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Kolb Firestar and =?ISO-8859-1?Q?20=99?= container hangar -
possible?
Date: Jul 29, 2017
Hi all, I would like to purchase a FireStar II SS. Love the folding wing capabilities! Can the Kolb FireStar II SS fit and be hangered inside a 20 container? Where I live security is a real issue and she must be stored between flights in a 20 Container. Comparing the dimensions of the container and FireStar II SS we see a small problem with length : Container Mark III Conclusion Height 74 (door) 64 fits Width 76 (door) 610 fits Length 195 interior length 222 -27 http://www.dimensionsinfo.com/20ft-container-size/ What are your thoughts please? Will angling her up let her fit ? Removing nose or rudder? Any one flying from a 20' foot container? Thanking you in advance. Strength for today, Bright Hope for tomorrow Yours Faithfully Paul Dalley Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471341#471341 ________________________________________________________________________________
Subject: Re: Kolb Firestar and =?ISO-8859-1?Q?20=99?= container hangar
- possible?
Date: Jul 29, 2017
According to the Kolb web site, the FSII SS is 22' long. There is no point in removing the nose cone because the rudder pedals & nose wheel will still be out there. You might gain a few inches by making the front of the nose cone quick detach. You would need to shorten the wings a bit as well as make the rudder quick disconnect because when folded, the wing tips typically come back to the end of the rudder. The trailing edges of the elevators are still going to stick bak out there though. Search the archives for info on shortening the tail boom, several people have done that in the past and were not real happy with the results, but I don't remember the details, that is an old topic. It might be possible to shorten it just a little, but from what I remember, not very much or things go wonky. Maybe it would be easier to buy four 8' pieces of scrap steel 2' wide, cut one end of the container off, weld in the 2' wide pieces of steel and make the container longer? A decent welding shop ought to be able to knock that out in a day. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471342#471342 ________________________________________________________________________________
- possible?
Date: Jul 29, 2017
Good morning Richard. Thank you for your detailed reply. Your first hand knowledge is what was needed thank you. Yes if the wings actually come all the way to the back of the rudder, then it looks likes as you say the wings and the tail boom will both have to be shortened, which is unfeasible. I'm a kiwi pilot flying in the South Pacific Island nation of Vanuatu. Oh World War Two fame as Bali High in the Tales of the South Pacific. Carry my fair share of sick of dying and so many of these jungle villages are completely isolated. THe last dead baby we carried was in a battered old suitcase and its heartbreaking. Done some missionary flying up in PNG so on my days off want to help and fly as much as I can. So with nurse girl friend we would like to do aerial drops to the villages etc. There is no infrastructure at all here and certainly no hangars at any of the airports for airplanes. At times shipping containers reach the two ports - so a 20 foot container in the 'captial' and the northern 'town' where i am based and one more sent out on the twice a year boat far north would give me three little hangars across the nation. Had considered modifying a container and will consider that. 40' containers cant be carried by the local barge so that doesnt work either. A folding wing Kolb that could live in a 20' container, purchased in its own portable container would be greatly appreciated around the world . . . Thank you again. Strength for today, Bright hope for tomorrow Yours Faithfully Paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471349#471349 ________________________________________________________________________________
Date: Jul 29, 2017
Subject: Re: Virb settings - Yet another video
Well Larry, I received my virb elite yesterday. I took it out for a flight t his morning. I mounted in the GoPro mount that's on my nose cone of my Fires tar original. I used all of your settings. The camera works great,color, res olution, etc. unfortunately it's weight is a lot more then the GoPro session 5. A half pound verses 2 oz. . Besides wind vibration I'm getting a lot of r esonance vibrations thru the airframe especially at reduced or while reducin g power. I was wondering how you mount your camera because your videos are s o smooth and vibration free. I really like this camera. It's works well. Tha nks, George Have a great day! > On Jul 28, 2017, at 10:44 AM, Larry Cottrell wro te: > > The settings that I use fits my needs best, and are as follows. > video mode 1080P > field of view- Ultra Zoom > Loop- off > Auto Record- When moving > Digital Stabilizer- on > Lens correction- check > > Of all the settings on the camera, the "Ultra Zoom" is the most important and gets rid of the fish eye effect. > > I use Auto record simply because it makes its use "fool proof". I do have a remote, but I am so ingenious that I can still screw it up. With a good Mic ro SD card it will record up to about 6 hours, and none of us has that much r ange. You can still activate the camera while the virb is recording with the remote. The camera has Wifi, but its line of sight and not as reliable as a real remote. > > If you want to see the G Metrix (Speed etc) you will have to use the editi ng program that comes with the camera. It ( to me) seems to be a bit difficu lt to use, but then I probably haven't invested the time to learn it. I make a basic cut of what I want to show, then export it to a folder on my comput er. I will then import it into Cyberlink editing program and finish it there . > > If there is any way that I can help you with it don't hesitate to ask. > > Looking forward to some videos from you. > Larry > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Date: Jul 29, 2017
This is where mine is located. I have tried every where else and this is the only place on my plane that gives me a decent video. I have a pitot tube right through the front of the pod. I think I got it from LEAF and the original attraction is that the pitot tube can be removed. I had one bent at a airshow. By someones spoiled kid of course, so I got this one. The shorter you can keep the connections and extensions the firmer the mount. The other spot would be on the fold hard point on the wing. You can record right side up or upside down in the settings, just no in between. The mount is set up for a drift camera now, you would have to secure the cradle rather than the screw in. If you are fond of selfies the wing would be the way to go. :-) Larry On Sat, Jul 29, 2017 at 7:22 PM, George Helton wrote: > Well Larry, I received my virb elite yesterday. I took it out for a flight > this morning. I mounted in the GoPro mount that's on my nose cone of my > Firestar original. I used all of your settings. The camera works > great,color, resolution, etc. unfortunately it's weight is a lot more then > the GoPro session5. A half pound verses 2 oz. . Besides wind vibration I'm > getting a lot of resonance vibrations thru the airframe especially at > reduced or while reducing power. I was wondering how you mount your camera > because your videos are so smooth and vibration free. I really like this > camera. It's works well. Thanks, George > > Have a great day! > > On Jul 28, 2017, at 10:44 AM, Larry Cottrell > wrote: > > The settings that I use fits my needs best, and are as follows. > video mode 1080P > field of view- Ultra Zoom > Loop- off > Auto Record- When moving > Digital Stabilizer- on > Lens correction- check > > Of all the settings on the camera, the "Ultra Zoom" is the most important > and gets rid of the fish eye effect. > > I use Auto record simply because it makes its use "fool proof". I do have > a remote, but I am so ingenious that I can still screw it up. With a good > Micro SD card it will record up to about 6 hours, and none of us has that > much range. You can still activate the camera while the virb is recording > with the remote. The camera has Wifi, but its line of sight and not as > reliable as a real remote. > > If you want to see the G Metrix (Speed etc) you will have to use the > editing program that comes with the camera. It ( to me) seems to be a bit > difficult to use, but then I probably haven't invested the time to learn > it. I make a basic cut of what I want to show, then export it to a folder > on my computer. I will then import it into Cyberlink editing program and > finish it there. > > If there is any way that I can help you with it don't hesitate to ask. > > Looking forward to some videos from you. > Larry > > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 30, 2017
Subject: Re: Kolb Firestar and 20 ft. container hangar - possible?
The main parameter for the flight characteristics being discussed is called "Tail Volume". This is expressed as area times moment arm, where area is the square footage area of the tail surface in question, and moment arm is the distance between the aircrft center pf gravity and the center of the square footage "area" of the tail. It's like a child's "teeter totter": You can have a heavier person that is close to the pivot point,a nd a ligh ter person that is further away form the pivot point,a nd it can still balance. So ALL OTHER THINGS EQUAL, on a "NORMAL" aircraft, if you need to shorten the tail then you can increase the size (area) of the tail and still achioeve the same "Tail Volume". Let's say that your fin and rudder together add up to ten square feet (no idea if this is what the Kolb fin/rudder area is), and the center of this area is 13 feet from the aircraft's center of gravity (I think the Kolb tailbooms are 13 feet long). The "Tail Volume" of this is a value of 130. If you needed o shorten the tailboom length down to 10 feet (to fit in your container), then in order to achieve the same tail volume (and flight characteristics) you need to increase the size of the fin and rudder until the area is 13 square feet. In THEORY, and according to the textbooks, the airplane SHOULD fly exactly the same as it did with the old tail. Now there are exceptions tot his "theory" and a whole l ot of other things that can affect the actual result. On a Kolb side by side aircraft, the wide fuselage and all those sharp awkward angles behind the widest point, will almost certainly create a bunch of separated and jumbled upa irflow behind it. So if you go really short on the tailboom, like 7 or 8 feet, you will probably have a strange or unsafe flying airplane no matter how large you make the tail. But shortening a 13 foot tailboom down to 11.5 or 12 feet will PROBABLY be just fine if you increase the size of the tail to the corresponding correct area. Before you take a hacksaw to a Kolb tailboom, PLEASE check with a REAL trained aerodynamics guy who can figure out all these numbers, and verify or disprove what I said about the tail volume. Shortening the wings slightly is a l ot easier and a lot lower risk. There are several factory versions of the Kolb with shorter wingspans (and shorter tails) than the Firestar, and those aircraft have been shown to fl y well, safely, etc. Essentially, If you only need to make the airplane a foot or less shorter to fit in the container, then I believe you can consult with a proper trained aero guy, increase the fin/rudder and stabilizer/elevator areas by a small amount, shorten the tailboom, make smaller wingtips,a nd have a safe and reasonable airplane. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Sat, 7/29/17, Richard Pike wrote: Subject: Kolb-List: Re: Kolb Firestar and 20 container hangar - possible? To: kolb-list(at)matronics.com Date: Saturday, July 29, 2017, 7:44 AM Pike" According to the Kolb web site, the FSII SS is 22' long. There is no point in removing the nose cone because the rudder pedals & nose wheel will still be out there. You might gain a few inches by making the front of the nose cone quick detach. You would need to shorten the wings a bit as well as make the rudder quick disconnect because when folded, the wing tips typically come back to the end of the rudder. The trailing edges of the elevators are still going to stick bak out there though. Search the archives for info on shortening the tail boom, several people have done that in the past and were not real happy with the results, but I don't remember the details, that is an old topic. It might be possible to shorten it just a little, but from what I remember, not very much or things go wonky. Maybe it would be easier to buy four 8' pieces of scrap steel 2' wide, cut one end of the container off, weld in the 2' wide pieces of steel and make the container longer? A decent welding shop ought to be able to knock that out in a day. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471342#471342 The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jul 30, 2017
Found the old thread: http://forums.matronics.com/viewtopic.php?t=16762082&highlight=shorter+tail+boom -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471354#471354 ________________________________________________________________________________
Date: Jul 31, 2017
Subject: Twinstar fuel tank options
Got to thinking about replacing my tank (which did actually crack sitting here in the ground) and tried to call Kolb last week but I guess they were gone to OSH. Wondered if I could find it 'online' & found what you see here. On left is a virtually exact replacement, except for the included capped vent on the handle (missing on the original). Less than $13 plus shipping. On the right is an 8 gallon tank from the same vendor. A bit more expensive, but still not bad. Bigger versions got closer to $100, so I didn't order 'samples'; at least not yet. Not to start a 'feeder war', but how many of you are using top feed tanks? I'm looking forward to the re-fueling process, and being able to pull the cap/feed tube & sit the can on the ground seems like a much easier way to fuel the plane. What say the experienced? Charlie Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Jul 31, 2017
Subject: Re: Twinstar fuel tank options
I think this a matter of personal preference. I prefer stationary mounting. I don't enjoy restrapping a heavy tank back in place every time. You must have an original Twinstar. The Twinstar MKII like I built had the fuel tanks (2) mounted behind you with a covered firewall so they really couldn't be removed. In the early days, 1983, ultralighters who flew Phantoms and Avengers use to use top feeders with flexible fuel hose inside the the tank with weighted ends on them for aerobatics and inverted flight . The fuel pickup hose could move from bottom air feeder to top feeder. They also equipped the engines with pumper type carbs for sustained inverted flight. Was never my bag. I just prefer not taken things apart and putting them back together. That's just my input. You know how opinions go. Whatever works for you. George H. Firestar , FS100 14GDH Mesick, Michigan gdhelton(at)gmail.com Have a great day! > On Jul 31, 2017, at 12:42 PM, Charlie England wrote: > > yet. ________________________________________________________________________________
Date: Jul 31, 2017
Well, I tried this mount today. I'll see how it worked as soon as the video f inishes downloading? Have a great day! > On Jul 29, 2017, at 9:46 PM, Larry Cottrell wrot e: > > This is where mine is located. I have tried every where else and this is t he only place on my plane that gives me a decent video. > > I have a pitot tube right through the front of the pod. I think I got it f rom LEAF and the original attraction is that the pitot tube can be removed. I had one bent at a airshow. By someones spoiled kid of course, so I got this one. The shorter you can keep the connections and extensions the firmer the mount. > > The other spot would be on the fold hard point on the wing. You can record right side up or upside down in the settings, just no in between. > > The mount is set up for a drift camera now, you would have to secure the c radle rather than the screw in. If you are fond of selfies the wing would be the way to go. :-) > > Larry > >> On Sat, Jul 29, 2017 at 7:22 PM, George Helton wrote : >> Well Larry, I received my virb elite yesterday. I took it out for a fligh t this morning. I mounted in the GoPro mount that's on my nose cone of my Fi restar original. I used all of your settings. The camera works great,color, r esolution, etc. unfortunately it's weight is a lot more then the GoPro sessi on5. A half pound verses 2 oz. . Besides wind vibration I'm getting a lot of resonance vibrations thru the airframe especially at reduced or while reduc ing power. I was wondering how you mount your camera because your videos are so smooth and vibration free. I really like this camera. It's works well. T hanks, George >> >> Have a great day! >> >>> On Jul 28, 2017, at 10:44 AM, Larry Cottrell w rote: >>> >>> The settings that I use fits my needs best, and are as follows. >>> video mode 1080P >>> field of view- Ultra Zoom >>> Loop- off >>> Auto Record- When moving >>> Digital Stabilizer- on >>> Lens correction- check >>> >>> Of all the settings on the camera, the "Ultra Zoom" is the most importa nt and gets rid of the fish eye effect. >>> >>> I use Auto record simply because it makes its use "fool proof". I do hav e a remote, but I am so ingenious that I can still screw it up. With a good M icro SD card it will record up to about 6 hours, and none of us has that muc h range. You can still activate the camera while the virb is recording with t he remote. The camera has Wifi, but its line of sight and not as reliable as a real remote. >>> >>> If you want to see the G Metrix (Speed etc) you will have to use the edi ting program that comes with the camera. It ( to me) seems to be a bit diffi cult to use, but then I probably haven't invested the time to learn it. I ma ke a basic cut of what I want to show, then export it to a folder on my comp uter. I will then import it into Cyberlink editing program and finish it the re. >>> >>> If there is any way that I can help you with it don't hesitate to ask. >>> >>> Looking forward to some videos from you. >>> Larry >>> >>> -- >>> The older I get, the less tolerant I am of those who are intolerant of o thers. >>> >>> If you forward this email, or any part of it, please remove my email add ress before sending. > > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. > > > ________________________________________________________________________________
Date: Jul 31, 2017
Yep; very early kit=2E Hard to visualize either under-wing or over-the-top fueling, with the fill neck a few inches under the wing=2E It's tempting to mount that 8gal tank on the boom tube, under the engine, if it won't cause cg issues=2E I enjoy acro, but I think I'll control the urge while flying this one=2E :-) Thanks for the insight=2E =81=A3Sent from BlueMail =8B On Jul 31, 2017, 4:10 PM, at 4:10 PM, George Helton wrote: @gmail=2Ecom> > >I think this a matter of personal preference=2E I prefer s tationary >mounting=2E I don't enjoy restrapping a heavy tank back in place every >time=2E You must have an original Twinstar=2E The Twinstar MKII lik e I >built had the fuel tanks (2) mounted behind you with a covered >firew all so they really couldn't be removed=2E >In the early days, 1983, ultral ighters who flew Phantoms and Avengers >use to use top feeders with flexibl e fuel hose inside the the tank with >weighted ends on them for aerobatics and inverted flight =2E The fuel >pickup hose could move from bottom air fe eder to top feeder=2E They also >equipped the engines with pumper type carb s for sustained inverted >flight=2E Was never my bag=2E >I just prefer not taken things apart and putting them back together=2E >That's just my input =2E You know how opinions go=2E Whatever works for you=2E >George H=2E >Fir estar , FS100 >14GDH >Mesick, Michigan >gdhelton@gmail=2Ecom > >Have a gre at day! > >> On Jul 31, 2017, at 12:42 PM, Charlie England >wrote: >> >> yet=2E > ===================== - The Kolb-List Email Forum - s Navigator to browse iption, hotoshare, and much much more: =2Ecom/Navigator?Kolb-List ====================== = - MATRONICS WEB FORUMS - vailable via the Web Forums! =2Ecom =============== MATRONICS LIST WIKI - ! your generous support! ist Admin=2E ======== ________________________________________________________________________________
Subject: Re: Balancing Tundra tires...
Date: Jul 31, 2017
> > Hello Kolbers, > > A few weeks back I finished a project, with Larry and Boyds help, and I promised to share it with the List. > So here goes. > > I had never thought of balancing the tires on my plane, and if I had not bought the Desser 8.50 x 6 inch tires, I am not sure it would matter. > As you probably remember Larry posted another example of his homestead creativity, where he melted down what looked like about a 1/2 pound of .357 lead wad cutter, poured them into appropriately sized molds to balance each wheel, then when they cooled he hot glued these custom weights to his rims and balanced his tundra tires. > > Larry and Boyd said the better way to balance a tire is out at the tread" rather than at the center, and encouraged me to try it. I discovered that the front bias ply tires of tractor trailer rigs are in fact balanced using leaded patch stuck on the inside of the tire. > These leaded patches are of a scale way beyond what I needed. I found however that regular radial truck tire patches were heavy enough. > > I balanced my tires by spinning them on a dowel to find the light spots. By taping 1/4 oz, lead car tire weights, to the outside of my Tundra tires tread I determined that it only required 1 3/4 oz of lead to balance my first tire, verses 5 oz taped on the rim. The other tire required 6 oz on the rim and 2 oz on the tread. > > I then mounted radial tire patches to the appropriate locations on the inside of the tires to balance the tires. The first tire was balanced with one patch glued to the inside of the tire. The second tire required two patches trimmed down and mated together to form one slightly elongated patch. Ideally the patches would be mounted to the tubes, but I did not think I was a good enough Tire technician to pull that off. Putting the tubes in and out of the tires was the hardest part of the whole project for me, and I felt it unlikely that I would get the patches in the correct position on the tubes. > > Time will tell how this approach works out. > > For what it is worth, > > Nick Cassara > Palmer, Alaska > > Kolb Kolbra Prototype about 90% done > ________________________________________________________________________________
Date: Jul 31, 2017
Date: Jul 31, 2017
Date: Jul 31, 2017
Date: Jul 31, 2017
Date: Jul 31, 2017
Sounds like a great idea. I didn't know about farm tractors and semi-trucks using this method. A lot less weight to get the job done. Boy, those tires would look good on Miss P'fer. ;-) Your post reminded me of delivering some 800X6 tires and tubes from Palmer, AK, to the Rock House in Oregon a couple years ago. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Nick Cassara Sent: Monday, July 31, 2017 8:28 PM Subject: Kolb-List: Re: Balancing Tundra tires... > > Hello Kolbers, > > A few weeks back I finished a project, with Larry and Boyds help, and I promised to share it with the List. > So here goes. > > I had never thought of balancing the tires on my plane, and if I had not bought the Desser 8.50 x 6 inch tires, I am not sure it would matter. > As you probably remember Larry posted another example of his homestead creativity, where he melted down what looked like about a 1/2 pound of .357 lead wad cutter, poured them into appropriately sized molds to balance each wheel, then when they cooled he hot glued these custom weights to his rims and balanced his tundra tires. > > Larry and Boyd said the better way to balance a tire is out at the tread" rather than at the center, and encouraged me to try it. I discovered that the front bias ply tires of tractor trailer rigs are in fact balanced using leaded patch stuck on the inside of the tire. > These leaded patches are of a scale way beyond what I needed. I found however that regular radial truck tire patches were heavy enough. > > I balanced my tires by spinning them on a dowel to find the light spots. By taping 1/4 oz, lead car tire weights, to the outside of my Tundra tires tread I determined that it only required 1 3/4 oz of lead to balance my first tire, verses 5 oz taped on the rim. The other tire required 6 oz on the rim and 2 oz on the tread. > > I then mounted radial tire patches to the appropriate locations on the inside of the tires to balance the tires. The first tire was balanced with one patch glued to the inside of the tire. The second tire required two patches trimmed down and mated together to form one slightly elongated patch. Ideally the patches would be mounted to the tubes, but I did not think I was a good enough Tire technician to pull that off. Putting the tubes in and out of the tires was the hardest part of the whole project for me, and I felt it unlikely that I would get the patches in the correct position on the tubes. > > Time will tell how this approach works out. > > For what it is worth, > > Nick Cassara > Palmer, Alaska > > Kolb Kolbra Prototype about 90% done > --- This email has been checked for viruses by AVG. http://www.avg.com ________________________________________________________________________________
Date: Jul 31, 2017
Date: Jul 31, 2017
Date: Jul 31, 2017
Date: Aug 01, 2017
Nick, I've been using balancing beads in my cycle tires for years. Same idea, balancing at outer circumference, but there's no user adjustment. As soon as the wheel spins the beads position themselves to balance the wheel perfectly. Got 15K miles on the last front tire on my BMW K1600GTL. Coming on 30K now with some tread remaining. I've never had a problem but I do remind the techy to be careful not to splash tire lube inside. I buy "large" quantities online and weigh out 2 oz. on a postal scale each time. FWIW. Dave Kulp no Kolb except by blood Sent with AquaMail for Android http://www.aqua-mail.com On July 31, 2017 9:31:12 PM Nick Cassara wrote: > > >> >> Hello Kolbers, >> >> A few weeks back I finished a project, with Larry and Boyds help, and I >> promised to share it with the List. >> So here goes. >> >> I had never thought of balancing the tires on my plane, and if I had not >> bought the Desser 8.50 x 6 inch tires, I am not sure it would matter. >> As you probably remember Larry posted another example of his homestead >> creativity, where he melted down what looked like about a 1/2 pound of .357 >> lead wad cutter, poured them into appropriately sized molds to balance each >> wheel, then when they cooled he hot glued these custom weights to his rims >> and balanced his tundra tires. >> >> Larry and Boyd said the better way to balance a tire is out at the tread" >> rather than at the center, and encouraged me to try it. I discovered that >> the front bias ply tires of tractor trailer rigs are in fact balanced using >> leaded patch stuck on the inside of the tire. >> These leaded patches are of a scale way beyond what I needed. I found >> however that regular radial truck tire patches were heavy enough. >> >> I balanced my tires by spinning them on a dowel to find the light spots. By >> taping 1/4 oz, lead car tire weights, to the outside of my Tundra tires >> tread I determined that it only required 1 3/4 oz of lead to balance my >> first tire, verses 5 oz taped on the rim. The other tire required 6 oz on >> the rim and 2 oz on the tread. >> >> I then mounted radial tire patches to the appropriate locations on the >> inside of the tires to balance the tires. The first tire was balanced with >> one patch glued to the inside of the tire. The second tire required two >> patches trimmed down and mated together to form one slightly elongated >> patch. Ideally the patches would be mounted to the tubes, but I did not >> think I was a good enough Tire technician to pull that off. Putting the >> tubes in and out of the tires was the hardest part of the whole project for >> me, and I felt it unlikely that I would get the patches in the correct >> position on the tubes. >> >> Time will tell how this approach works out. >> >> For what it is worth, >> >> Nick Cassara >> Palmer, Alaska >> >> Kolb Kolbra Prototype about 90% done >> > > ________________________________________________________________________________
Date: Aug 01, 2017
David and Kolb enthusiast >From my research,,, and I did suggest to Larry that he try them.... The tire beads do work,,, but they don't start until you reach around 30 mph. From the time I go from 30 to when my wheels are off the ground is of a short enough duration,, that I no longer think the beads have a chance to position themselves.... This was noted by another mkiii driver. Dyna beads list aircraft, generically, on their web sight,, but do not have a page showing how many beads to use... Too many sizes and weights. When I sent an email on their contact page they were good to reply, when supplied with wheel weights and dimensions, they made suggestions of how many beads to use. I currently have a set on my desk, but I am now to gun-shy to try. Boyd Young On Aug 1, 2017 7:01 AM, "David Kulp" wrote: > > Nick, I've been using balancing beads in my cycle tires for years. Same > idea, balancing at outer circumference, but there's no user adjustment. As > soon as the wheel spins the beads position themselves to balance the whee l > perfectly. Got 15K miles on the last front tire on my BMW K1600GTL. Comin g > on 30K now with some tread remaining. > > I've never had a problem but I do remind the techy to be careful not to > splash tire lube inside. I buy "large" quantities online and weigh out 2 > oz. on a postal scale each time. > > FWIW. > Dave Kulp > > no Kolb except by blood=F0=9F=98' > > Sent with AquaMail for Android > http://www.aqua-mail.com > > > On July 31, 2017 9:31:12 PM Nick Cassara wrote: > >> >> >> >>> Hello Kolbers, >>> >>> A few weeks back I finished a project, with Larry and Boyd=99s he lp, and I >>> promised to share it with the =9CList=9D. >>> So here goes. >>> >>> I had never thought of balancing the tires on my plane, and if I had no t >>> bought the Desser 8.50 x 6 inch tires, I am not sure it would matter. >>> As you probably remember Larry posted another example of his homestead >>> creativity, where he melted down what looked like about a 1/2 pound of .357 >>> lead wad cutter, poured them into appropriately sized molds to balance each >>> wheel, then when they cooled he hot glued these custom weights to his r ims >>> and balanced his tundra tires. >>> >>> Larry and Boyd said the better way to balance a tire =9Cis out at the >>> tread" rather than at the center, and encouraged me to try it. I discov ered >>> that the front bias ply tires of tractor trailer rigs are in fact balan ced >>> using =9Cleaded patch=9D stuck on the inside of the tire. >>> These leaded patches are of a scale way beyond what I needed. I found >>> however that regular radial truck tire patches were heavy enough. >>> >>> I balanced my tires by spinning them on a dowel to find the light spots . >>> By taping 1/4 oz, lead car tire weights, to the outside of my Tundra ti res >>> =9Ctread=9D I determined that it only required 1 3/4 oz of lead to balance my >>> first tire, verses 5 oz taped on the rim. The other tire required 6 oz on >>> the rim and 2 oz on the tread. >>> >>> I then mounted radial tire patches to the appropriate locations on the >>> inside of the tires to balance the tires. The first tire was balanced w ith >>> one patch glued to the inside of the tire. The second tire required two >>> patches trimmed down and mated together to form one slightly elongated >>> patch. Ideally the patches would be mounted to the tubes, but I did not >>> think I was a good enough Tire technician to pull that off. Putting the >>> tubes in and out of the tires was the hardest part of the whole project for >>> me, and I felt it unlikely that I would get the patches in the correct >>> position on the tubes. >>> >>> Time will tell how this approach works out. >>> >>> For what it is worth, >>> >>> Nick Cassara >>> Palmer, Alaska >>> >>> Kolb Kolbra Prototype about 90% done >>> >>> >> >> >> >> >> >> > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Aug 01, 2017
Nick, I've been using balancing beads in my cycle tires for years. Same idea, balancing at outer circumference, but there's no user adjustment. As soon as the wheel spins the beads position themselves to balance the wheel perfectly. Got 15K miles on the last front tire on my BMW K1600GTL. Coming on 30K now with some tread remaining. --------------------------------------------------------------------------------------------------------------------- The first thing I tried was balancing beads. I ordered some from O'Reilly's but could never get any of them in the tube. The tubes for these Tundra tires has an opening so small I could never get anything in them. I tried every method on You tube, and as far as I know never got a single bead in the tube. That's when I gave up and made my own weights. The beads were very small, but not small enough to get them aywhere but the floor. Larry ________________________________________________________________________________
Date: Aug 01, 2017
Hey Boyd, Thanks for the input. I have never been able to tell at what speed they balance, I think because as soon as the wheel begins to show a need for balance the beads position themselves to eliminate the need. I believe 30K miles on just two front tires supports my trust in them. I personally wouldn't hesitate to use them in an airplane if I had one. Dave Sent with AquaMail for Android http://www.aqua-mail.com On August 1, 2017 9:29:47 AM B Young wrote: > David and Kolb enthusiast > >>From my research,,, and I did suggest to Larry that he try them.... > The tire beads do work,,, but they don't start until you reach around 30 > mph. From the time I go from 30 to when my wheels are off the ground is > of a short enough duration,, that I no longer think the beads have a > chance to position themselves.... This was noted by another mkiii > driver. > Dyna beads list aircraft, generically, on their web sight,, but do not > have a page showing how many beads to use... Too many sizes and weights. > When I sent an email on their contact page they were good to reply, when > supplied with wheel weights and dimensions, they made suggestions of how > many beads to use. I currently have a set on my desk, but I am now to > gun-shy to try. > > Boyd Young > > On Aug 1, 2017 7:01 AM, "David Kulp" wrote: > >> >> Nick, I've been using balancing beads in my cycle tires for years. Same >> idea, balancing at outer circumference, but there's no user adjustment. As >> soon as the wheel spins the beads position themselves to balance the wheel >> perfectly. Got 15K miles on the last front tire on my BMW K1600GTL. Coming >> on 30K now with some tread remaining. >> >> I've never had a problem but I do remind the techy to be careful not to >> splash tire lube inside. I buy "large" quantities online and weigh out 2 >> oz. on a postal scale each time. >> >> FWIW. >> Dave Kulp >> >> no Kolb except by blood >> >> Sent with AquaMail for Android >> http://www.aqua-mail.com >> >> >> On July 31, 2017 9:31:12 PM Nick Cassara wrote: >> >>> >>> >>> >>>> Hello Kolbers, >>>> >>>> A few weeks back I finished a project, with Larry and Boyds help, and I >>>> promised to share it with the List. >>>> So here goes. >>>> >>>> I had never thought of balancing the tires on my plane, and if I had not >>>> bought the Desser 8.50 x 6 inch tires, I am not sure it would matter. >>>> As you probably remember Larry posted another example of his homestead >>>> creativity, where he melted down what looked like about a 1/2 pound of .357 >>>> lead wad cutter, poured them into appropriately sized molds to balance each >>>> wheel, then when they cooled he hot glued these custom weights to his rims >>>> and balanced his tundra tires. >>>> >>>> Larry and Boyd said the better way to balance a tire is out at the >>>> tread" rather than at the center, and encouraged me to try it. I discovered >>>> that the front bias ply tires of tractor trailer rigs are in fact balanced >>>> using leaded patch stuck on the inside of the tire. >>>> These leaded patches are of a scale way beyond what I needed. I found >>>> however that regular radial truck tire patches were heavy enough. >>>> >>>> I balanced my tires by spinning them on a dowel to find the light spots. >>>> By taping 1/4 oz, lead car tire weights, to the outside of my Tundra tires >>>> tread I determined that it only required 1 3/4 oz of lead to balance my >>>> first tire, verses 5 oz taped on the rim. The other tire required 6 oz on >>>> the rim and 2 oz on the tread. >>>> >>>> I then mounted radial tire patches to the appropriate locations on the >>>> inside of the tires to balance the tires. The first tire was balanced with >>>> one patch glued to the inside of the tire. The second tire required two >>>> patches trimmed down and mated together to form one slightly elongated >>>> patch. Ideally the patches would be mounted to the tubes, but I did not >>>> think I was a good enough Tire technician to pull that off. Putting the >>>> tubes in and out of the tires was the hardest part of the whole project for >>>> me, and I felt it unlikely that I would get the patches in the correct >>>> position on the tubes. >>>> >>>> Time will tell how this approach works out. >>>> >>>> For what it is worth, >>>> >>>> Nick Cassara >>>> Palmer, Alaska >>>> >>>> Kolb Kolbra Prototype about 90% done >>>> >>>> >>> >>> >>> >>> >>> >>> >> > =========== > =========== > =========== > =========== > =========== >> >> >> >> ________________________________________________________________________________
Subject: Sorry about the duplicate messages
Date: Aug 01, 2017
Kolbers, Sorry about the duplicate messagesnot only did your have the option of reading my post eight times, but I received a message that my post was undeliverable.amazing what my ignorance is capable some times! Nick Cassara ________________________________________________________________________________
Date: Aug 01, 2017
Date: Aug 01, 2017
Subject: Re: Sorry about the duplicate messages
Perhaps your inexperience is just due to the fact that you don't post often enough. Larry On Tue, Aug 1, 2017 at 9:09 AM, Nick Cassara wrote: > > Kolbers, > > Sorry about the duplicate messagesnot only did your have the opt ion of > reading my post eight times, but I received a message that my post was > undeliverable.amazing what my ignorance is capable some times! > > Nick Cassara > > =========== =========== =========== =========== =========== > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 01, 2017
Date: Aug 01, 2017
Date: Aug 01, 2017
Date: Aug 01, 2017
Nick, I too use the beads in my motorcycle tires with great success. So much so I put them in my Ford Explorer at last tire change. I wouldn't hesitate to try them in the Firefly tires if the need ever arises. The question of when they "kick in" is a bit tricky for me to figure out. Your tire would be turning faster than a motorcycle tire so the centripetal force would be greater, but the distance from the axle would be shorter so that may negate the increased rotational speed. As for getting the beads into the tires. Are you using tubes? If not, seat the tire, then deflate and break one bead. Push it down and pour the beads in. If you have a tube the valve stem should be the same size as any other tire. Take the core out and put a short piece of 1/4" hose on the stem. Put the beads in a small squeeze bottle that has a spout on it. Insert spout into hose and squeeze gently. If the beads bind up in the tube gently tap the valve stem with a screwdriver or something and they will flow in. Remember, just go slow. Make sure that there is no left over lube in the tire as it will cause the beads to clump together. Hope this helps, Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Nick Cassara Sent: Monday, July 31, 2017 8:28 PM Subject: Kolb-List: Re: Balancing Tundra tires... > > Hello Kolbers, > > A few weeks back I finished a project, with Larry and Boyds help, and I promised to share it with the List. > So here goes. > > I had never thought of balancing the tires on my plane, and if I had not bought the Desser 8.50 x 6 inch tires, I am not sure it would matter. > As you probably remember Larry posted another example of his homestead creativity, where he melted down what looked like about a 1/2 pound of .357 lead wad cutter, poured them into appropriately sized molds to balance each wheel, then when they cooled he hot glued these custom weights to his rims and balanced his tundra tires. > > Larry and Boyd said the better way to balance a tire is out at the tread" rather than at the center, and encouraged me to try it. I discovered that the front bias ply tires of tractor trailer rigs are in fact balanced using leaded patch stuck on the inside of the tire. > These leaded patches are of a scale way beyond what I needed. I found however that regular radial truck tire patches were heavy enough. > > I balanced my tires by spinning them on a dowel to find the light spots. By taping 1/4 oz, lead car tire weights, to the outside of my Tundra tires tread I determined that it only required 1 3/4 oz of lead to balance my first tire, verses 5 oz taped on the rim. The other tire required 6 oz on the rim and 2 oz on the tread. > > I then mounted radial tire patches to the appropriate locations on the inside of the tires to balance the tires. The first tire was balanced with one patch glued to the inside of the tire. The second tire required two patches trimmed down and mated together to form one slightly elongated patch. Ideally the patches would be mounted to the tubes, but I did not think I was a good enough Tire technician to pull that off. Putting the tubes in and out of the tires was the hardest part of the whole project for me, and I felt it unlikely that I would get the patches in the correct position on the tubes. > > Time will tell how this approach works out. > > For what it is worth, > > Nick Cassara > Palmer, Alaska > > Kolb Kolbra Prototype about 90% done > ________________________________________________________________________________
Date: Aug 01, 2017
Date: Aug 01, 2017
On Tue, Aug 1, 2017 at 10:51 AM, Stuart Harner wrote: > > > As for getting the beads into the tires. Are you using tubes? If not, seat > the tire, then deflate and break one bead. Push it down and pour the beads > in. If you have a tube the valve stem should be the same size as any other > tire. Take the core out and put a short piece of 1/4" hose on the stem. Put > the beads in a small squeeze bottle that has a spout on it. Insert spout > into hose and squeeze gently. If the beads bind up in the tube gently tap > the valve stem with a screwdriver or something and they will flow in. > Remember, just go slow. > > Make sure that there is no left over lube in the tire as it will cause the > beads to clump together. > > Hope this helps, > > Stuart > > ---------------------------------------------------------------------------------------------------------------------- > I decided that the tube for the tundra's was a special tube and perhaps > the opening under the valve stem was different from other tires. In any > case I used fuel line to fit over the stem. (valve stem removed of course) > tried to tap them into the tube. Nope balled up! Then saw a you tube video > of blowing them in with a short burst of air, air- Nope, balled up, or blew > back out when the air hose was removed. Tried three different times, and > only got them on the floor. At that point I started melting lead. > Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 01, 2017
The day before I departed Alabama to fly to Sherman, TX, to meet my Kolb bu ddies flying in from Texas and LA, I decided to Slime my main gear tubes. The year prior, 2008, several Kolbs had tire problems. I knew if I got in that situation I would be SOL. Takes an act of God to get break the beads and remove the tubes to repair or replace, if one has a replacement. I dec ided to Slime them. That would take care of the little problems that might crop up. Took off the next morning for our rendezvous at Sherman, TX. Soon as I sta rted rolling good on takeoff I knew I had made a bad mistake. Thought the main gear was going to shake the MKIII to pieces. I lived with this super shake to Monument Valley, UT, Rock House, OR, and all the way back to Alaba ma. I dreaded taking off and landing. I think a flat tire would have been easier to live with. Needless to say I changed out the tubes soon as I got back home. No more S lime in my airplane tires! I can live with a little tire bounce. Hit the brakes soon after breaking ground and it is gone. Don't notice it landing because I am bouncing anyhow. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@m atronics.com] On Behalf Of Larry Cottrell Sent: Tuesday, August 01, 2017 12:26 PM Subject: Re: Kolb-List: Re: Balancing Tundra tires... On Tue, Aug 1, 2017 at 10:51 AM, Stuart Harner wrot e: As for getting the beads into the tires. Are you using tubes? If not, seat the tire, then deflate and break one bead. Push it down and pour the beads in. If you have a tube the valve stem should be the same size as any other tire. Take the core out and put a short piece of 1/4" hose on the stem. Put the beads in a small squeeze bottle that has a spout on it. Insert spout i nto hose and squeeze gently. If the beads bind up in the tube gently tap th e valve stem with a screwdriver or something and they will flow in. Remembe r, just go slow. Make sure that there is no left over lube in the tire as it will cause the beads to clump together. Hope this helps, Stuart --------------------------------------------------------------------------- ------------------------------------------- I decided that the tube for the tundra's was a special tube and perhaps the opening under the valve stem was different from other tires. In any case I used fuel line to fit over the stem. (valve stem removed of course) tried to tap them into the tube. Nope balled up! Then saw a you tube video of blo wing them in with a short burst of air, air- Nope, balled up, or blew back out when the air hose was removed. Tried three different times, and only go t them on the floor. At that point I started melting lead. Larry -- The older I get, the less tolerant I am of those who are intolerant of othe rs. If you forward this email, or any part of it, please remove my email addres s before sending. --- This email has been checked for viruses by AVG. http://www.avg.com ________________________________________________________________________________
Date: Aug 01, 2017
Date: Aug 01, 2017
Larry, the Dyna Beads I bought had a device to get them in the valve stem shipped with them. Never had to use it since my scoot has tubeless tires. Just put 2 oz in a baggie and he pours them in. Sent with AquaMail for Android http://www.aqua-mail.com On August 1, 2017 9:40:53 AM Larry Cottrell wrote: > > Nick, I've been using balancing beads in my cycle tires for years. Same > idea, balancing at outer circumference, but there's no user adjustment. As > soon as the wheel spins the beads position themselves to balance the wheel > perfectly. Got 15K miles on the last front tire on my BMW K1600GTL. Coming > on 30K now with some tread remaining. > --------------------------------------------------------------------------------------------------------------------- > > The first thing I tried was balancing beads. I ordered some from O'Reilly's > but could never get any of them in the tube. The tubes for these Tundra > tires has an opening so small I could never get anything in them. I tried > every method on You tube, and as far as I know never got a single bead in > the tube. That's when I gave up and made my own weights. > > The beads were very small, but not small enough to get them aywhere but the > floor. > > Larry ________________________________________________________________________________
Date: Aug 01, 2017
Date: Aug 02, 2017
Well Larry this setup seems to help the jitters some. I think a lot of probl ems are related to harmonic vibrations caused by running a two blade prop. W hen changing power settings. I'm going to try a wing mount next. I may try reinforcing under the nose pod where the camera sits too. Thanks for your help, George Have a great day! > On Jul 29, 2017, at 9:46 PM, Larry Cottrell wrot e: > > This is where mine is located. I have tried every where else and this is t he only place on my plane that gives me a decent video. > > I have a pitot tube right through the front of the pod. I think I got it f rom LEAF and the original attraction is that the pitot tube can be removed. I had one bent at a airshow. By someones spoiled kid of course, so I got this one. The shorter you can keep the connections and extensions the firmer the mount. > > The other spot would be on the fold hard point on the wing. You can record right side up or upside down in the settings, just no in between. > > The mount is set up for a drift camera now, you would have to secure the c radle rather than the screw in. If you are fond of selfies the wing would be the way to go. :-) > > Larry > >> On Sat, Jul 29, 2017 at 7:22 PM, George Helton wrote : >> Well Larry, I received my virb elite yesterday. I took it out for a fligh t this morning. I mounted in the GoPro mount that's on my nose cone of my Fi restar original. I used all of your settings. The camera works great,color, r esolution, etc. unfortunately it's weight is a lot more then the GoPro sessi on5. A half pound verses 2 oz. . Besides wind vibration I'm getting a lot of resonance vibrations thru the airframe especially at reduced or while reduc ing power. I was wondering how you mount your camera because your videos are so smooth and vibration free. I really like this camera. It's works well. T hanks, George >> >> Have a great day! >> >>> On Jul 28, 2017, at 10:44 AM, Larry Cottrell w rote: >>> >>> The settings that I use fits my needs best, and are as follows. >>> video mode 1080P >>> field of view- Ultra Zoom >>> Loop- off >>> Auto Record- When moving >>> Digital Stabilizer- on >>> Lens correction- check >>> >>> Of all the settings on the camera, the "Ultra Zoom" is the most importa nt and gets rid of the fish eye effect. >>> >>> I use Auto record simply because it makes its use "fool proof". I do hav e a remote, but I am so ingenious that I can still screw it up. With a good M icro SD card it will record up to about 6 hours, and none of us has that muc h range. You can still activate the camera while the virb is recording with t he remote. The camera has Wifi, but its line of sight and not as reliable as a real remote. >>> >>> If you want to see the G Metrix (Speed etc) you will have to use the edi ting program that comes with the camera. It ( to me) seems to be a bit diffi cult to use, but then I probably haven't invested the time to learn it. I ma ke a basic cut of what I want to show, then export it to a folder on my comp uter. I will then import it into Cyberlink editing program and finish it the re. >>> >>> If there is any way that I can help you with it don't hesitate to ask. >>> >>> Looking forward to some videos from you. >>> Larry >>> >>> -- >>> The older I get, the less tolerant I am of those who are intolerant of o thers. >>> >>> If you forward this email, or any part of it, please remove my email add ress before sending. > > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. > > > ________________________________________________________________________________
Subject: Water for balance, anyone?
Date: Aug 02, 2017
I have had my 4x4 Suzuki Samurai for over twenty years. I have been modifying it for all of that time. It was my daily driver for many years. I have a set of tires and wheels for the street and a set for off-road. Or F'road. Froad. I'm a froader. :-) I change my 4x4 tires all the time it seems. I trade for different ones, my 4x4 buds and I like to try different ones for different terrain and regions. In years past I have tried a number of ways to balance big heavy tires. Off-road it isn't an issue of course, but sometimes I drive hundreds of miles to my destination. After all that, no- I have no special insight. I have tried beads and they are OK. I remember putting some into an inner-tube but forget the other details. I used them in tubeless tires too just fine. Then I got lazy. With big knobby meats in sharp rocks you might lose 1/2 a lug or more, or the tire can have striations all around the circumference. So sometimes on the way home it gets bumpy. I started using 2-4 ounces of water in my off-road tires when needed. I had aluminum wheels. Now I use steel wheels and no longer use water. Might be OK, just haven't tried it. Water works about the same as beads IN MY OPINION but I have tried no special objective measurements to determine that, it's all seat of the pants. ________________________________________________________________________________
Subject: Gap seal
Date: Aug 08, 2017
Hi to all. A buddy is looking for ideas as to the best way/method to install gap seals on his Firestar2 Thanks in advance for any help. Mike -------- 2007 Firestar 2 503 N203SD Moster 185 Flattop PPG/Sky K2 Paraglider Trike Buggy Soaring Trike & Northwing Stratus XP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471635#471635 ________________________________________________________________________________
Date: Aug 08, 2017
Subject: Re: Gap seal
Ideas to install gap seal. I have a vls brs. The tray for the brs is mounted to the motor mount tube... I've riveted a 7/8 tube to the brs mounting plate... As I built ribs for the gap seal they were built in a manner that I could rivet an internal brace to the 7/8 tube... Then built a faring between the top of the windshield and bottom of the gap seal, riveting in place.... The sides of the gap seal are 1/4 to 3/8 inches from the wings.. I can fold the wings without removing the gap seal. Boyd Young ________________________________________________________________________________
Date: Aug 08, 2017
It would appear that Boyd and I are the only ones awake today. I purposely waited for someone smarter than myself to give you guidance. I suppose he is out flying. I have seen three ways to do a gap seal. One is using the fabric that Kolb gives you. It works, but I never liked it. The Mark III's all seem to build a solid gap seal such as described by Boyd. It works well, but I was either never smart enough to build one or too lazy. I couldn't say for sure which. It works well The method that I used for my Firestar II is a bent tin front secured to a piece of lexan with a cut out for a motor or any thing else in the way such as my muffler. It is secured to the wings with velcro. When you take it off, just slide a towel or a piece of lexan or cardboard between the two pieces of velcro and lift it off.. Larry On Tue, Aug 8, 2017 at 4:59 PM, Mcabbage wrote: > > Hi to all. > A buddy is looking for ideas as to the best way/method to install gap > seals on his Firestar2 > Thanks in advance for any help. > Mike > > -------- > 2007 Firestar 2 503 N203SD > Moster 185 Flattop PPG/Sky K2 Paraglider > Trike Buggy Soaring Trike & Northwing Stratus XP > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471635#471635 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 08, 2017
Call Helen at Kolb Aircraft. She will make you a fabric gap that is held in p lace with super 2" wide Velcro. They work great. They hold up well. I had th e old zipper type originally and these work and hold up just as well or bett er. George H. Firestar, FS# 100 14GDH Mesick, Michigan Have a great day! > On Aug 8, 2017, at 6:59 PM, Mcabbage wrote: > > > Hi to all. > A buddy is looking for ideas as to the best way/method to install gap seal s on his Firestar2 > Thanks in advance for any help. > Mike > > -------- > 2007 Firestar 2 503 N203SD > Moster 185 Flattop PPG/Sky K2 Paraglider > Trike Buggy Soaring Trike & Northwing Stratus XP > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471635#471635 > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 4 Msgs - 08/08/17
Date: Aug 09, 2017
Matt, thanks for the great service through the years. Please remove my nam e and email from the list. I have sold my MarkIII Extra and will no longer be building or flying a Kol b. Thank you again. Thanks to all the Kolbers too. Bob Green ________________________________________________________________________________
Date: Aug 10, 2017
Thanks guys I'm sorry I wasn't more clear in my post. I was looking for info on sealing the gap between the wing and airilons. My friend said some folks are using some kind of new strechy material that is easier to remove if needed. Thanks Mike -------- 2007 Firestar 2 503 N203SD Moster 185 Flattop PPG/Sky K2 Paraglider Trike Buggy Soaring Trike & Northwing Stratus XP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471716#471716 ________________________________________________________________________________
Date: Aug 10, 2017
Oh. You want packaging tape. Check the archives, tons of entries. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471724#471724 ________________________________________________________________________________
Date: Aug 10, 2017
I guess some use book binding tape? I did mine per Kolbs plans using 2" Stitts polyfiber tape and polybrush. It has lasted since 1986. Still looks great! Do you want fast and easy or quality? Have a great day! George H. > On Aug 10, 2017, at 2:35 PM, Mcabbage wrote: > > > Thanks guys > I'm sorry I wasn't more clear in my post. > I was looking for info on sealing the gap between the > wing and airilons. My friend said some folks are using > some kind of new strechy material that is easier to remove > if needed. > Thanks Mike > > -------- > 2007 Firestar 2 503 N203SD > Moster 185 Flattop PPG/Sky K2 Paraglider > Trike Buggy Soaring Trike & Northwing Stratus XP > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471716#471716 > > > > > > > > > ________________________________________________________________________________
Date: Aug 10, 2017
UGVyIGtvbGIgaWYgZ29pbmcgdGhlIGZhc3Qgd2F5CgoKU2VudCBmcm9tIG15IFNhbXN1bmcgR2Fs YXh5IHNtYXJ0cGhvbmUuCi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS1Gcm9tOiBS aWNoYXJkIFBpa2UgPHRoZWdyZXliYXJvbkBjaGFydGVyLm5ldD4gRGF0ZTogOC8xMC8xNyAgNzoy MyBQTSAgKEdNVC0wNTowMCkgVG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29tIFN1YmplY3Q6IEtv bGItTGlzdDogUmU6IEdhcCBzZWFsIAotLT4gS29sYi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAi UmljaGFyZCBQaWtlIiA8dGhlZ3JleWJhcm9uQGNoYXJ0ZXIubmV0PgoKT2guwqAgWW91IHdhbnQg cGFja2FnaW5nIHRhcGUuIENoZWNrIHRoZSBhcmNoaXZlcywgdG9ucyBvZiBlbnRyaWVzLgoKLS0t LS0tLS0KUmljaGFyZCBQaWtlCktvbGIgTUtJSUkgTjQyMFAgKDQyMGxkUG9vcHMpCktpbmdzcG9y dCwgVE4gM1ROMAoKRm9yZ2l2aW5nIGlzIHRvdWdoLiBCZWluZyBmb3JnaXZlbiBpcyB3b25kZXJm dWwuCgoKCgpSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6CgpodHRwOi8vZm9ydW1zLm1hdHJv bmljcy5jb20vdmlld3RvcGljLnBocD9wPTQ3MTcyNCM0NzE3MjQKCgoKCgoKXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09wqDC oMKgwqDCoMKgwqDCoMKgIC0gVGhlIEtvbGItTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhl IE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55 IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZl IFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hh cmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPcKgwqAgLS0+IGh0dHA6Ly93d3cubWF0cm9u aWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0Cl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqDCoMKgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQpfLT0gU2FtZSBncmVhdCBjb250 ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyEKXy09Cl8tPcKgwqAgLS0+IGh0 dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09wqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqAgLSBORVcgTUFUUk9OSUNTIExJU1QgV0lLSSAtCl8tPSBBZGQgc29tZSBpbmZvIHRv IHRoZSBNYXRyb25pY3MgRW1haWwgTGlzdCBXaWtpIQpfLT3CoMKgIC0tPiBodHRwOi8vd2lraS5t YXRyb25pY3MuY29tCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtIExpc3QgQ29u dHJpYnV0aW9uIFdlYiBTaXRlIC0KXy09wqAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1 cHBvcnQhCl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgpfLT3CoMKgIC0tPiBodHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CgoKCg= ________________________________________________________________________________
Date: Aug 10, 2017
CgpXb3JrcyBncmVhdApTZW50IGZyb20gbXkgU2Ftc3VuZyBHYWxheHkgc21hcnRwaG9uZS4KLS0t LS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLUZyb206IFJpY2hhcmQgUGlrZSA8dGhlZ3Jl eWJhcm9uQGNoYXJ0ZXIubmV0PiBEYXRlOiA4LzEwLzE3ICA3OjIzIFBNICAoR01ULTA1OjAwKSBU bzoga29sYi1saXN0QG1hdHJvbmljcy5jb20gU3ViamVjdDogS29sYi1MaXN0OiBSZTogR2FwIHNl YWwgCi0tPiBLb2xiLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJSaWNoYXJkIFBpa2UiIDx0aGVn cmV5YmFyb25AY2hhcnRlci5uZXQ+CgpPaC7CoCBZb3Ugd2FudCBwYWNrYWdpbmcgdGFwZS4gQ2hl Y2sgdGhlIGFyY2hpdmVzLCB0b25zIG9mIGVudHJpZXMuCgotLS0tLS0tLQpSaWNoYXJkIFBpa2UK S29sYiBNS0lJSSBONDIwUCAoNDIwbGRQb29wcykKS2luZ3Nwb3J0LCBUTiAzVE4wCgpGb3JnaXZp bmcgaXMgdG91Z2guIEJlaW5nIGZvcmdpdmVuIGlzIHdvbmRlcmZ1bC4KCgoKClJlYWQgdGhpcyB0 b3BpYyBvbmxpbmUgaGVyZToKCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMu cGhwP3A9NDcxNzI0IzQ3MTcyNAoKCgoKCgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDCoMKgwqDCoMKgwqAgLSBU aGUgS29sYi1MaXN0IEVtYWlsIEZvcnVtIC0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVh dHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3Vj aCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwKXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQs IDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLApfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBt b3JlOgpfLT0KXy09wqDCoCAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9L b2xiLUxpc3QKXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLSBNQVRS T05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUg dmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0KXy09wqDCoCAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25p Y3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtIE5FVyBNQVRS T05JQ1MgTElTVCBXSUtJIC0KXy09IEFkZCBzb21lIGluZm8gdG8gdGhlIE1hdHJvbmljcyBFbWFp bCBMaXN0IFdpa2khCl8tPcKgwqAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb20KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0K Xy09wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUg LQpfLT3CoCBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEKXy09wqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtTWF0dCBE cmFsbGUsIExpc3QgQWRtaW4uCl8tPcKgwqAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9j b250cmlidXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0KCgoK ________________________________________________________________________________
Date: Aug 11, 2017
Brian Carpenter has come up with a great way to make gap seals from foam pool noodles. He pulls the noodles through a heated die. https://electricmotorglider.com/2017/07/15/57-80-10-large-gap-seal/ The resulting foam shape fits snugly between the aileron tube and the trailing edge of the wing and completely fills in the profile of the wing shape between the trailing edge and the aileron. -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471770#471770 ________________________________________________________________________________
Date: Aug 11, 2017
Air-Tech Inc Ultralights sells a 10 gallon fuel tank. I purchased and installed two tanks on my Kolb Mk3 and am very happy with the now 20 gallon fuel capacity. https://www.air-techinc.com/product_detail.php?pid=1079 Jim On Mon, Jul 31, 2017 at 3:12 PM, Charlie England wrote: > Yep; very early kit. Hard to visualize either under-wing or over-the-top > fueling, with the fill neck a few inches under the wing. It's tempting to > mount that 8gal tank on the boom tube, under the engine, if it won't caus e > cg issues. > > I enjoy acro, but I think I'll control the urge while flying this one. :- ) > > Thanks for the insight. > > Sent from BlueMail <http://www.bluemail.me/r?b=10215> > On Jul 31, 2017, at 4:10 PM, George Helton wrote: >> >> >> I think this a matter of personal preference. I prefer stationary mounti ng. I don't enjoy restrapping a heavy tank back in place every time. You mu st have an original Twinstar. The Twinstar MKII like I built had the fuel t anks (2) mounted behind you with a covered firewall so they really couldn' t be removed. >> In the early days, 1983, ultralighters who flew Phantoms and Avengers us e to use top feeders with flexible fuel hose inside the the tank with weigh ted ends on them for aerobatics and inverted flight . The fuel pickup hose could move from bottom air feeder to top feeder. They also equipped the eng ines with pumper type carbs for sustained inverted flight. Was never my bag . >> I just prefer not taken things apart and putting them back together. Tha t's just my input. You know how opinions go. Whatever works for you. >> George H. >> Firestar , FS100 >> 14GDH >> Mesick, Michigan >> gdhelton(at)gmail.com >> >> Have a great day! >> >> On Jul 31, 2017, at 12:42 PM, Charlie England wr ote: >>> >>> yet. >>> >> >> ------------------------------ >> >> ________________________________________________________________________________
Date: Aug 12, 2017
Pretty interesting. Thank you guys. -------- 2007 Firestar 2 503 N203SD Moster 185 Flattop PPG/Sky K2 Paraglider Trike Buggy Soaring Trike & Northwing Stratus XP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471780#471780 ________________________________________________________________________________
Date: Aug 12, 2017
I tried making the noodle gap seals but because of the way Kolb ailerons are hinged they pop out. Joe ----- Original Message ----- From: "wakataka" <wakataka(at)charter.net> Sent: Friday, August 11, 2017 9:22:48 PM Subject: Kolb-List: Re: Gap seal Brian Carpenter has come up with a great way to make gap seals from foam pool noodles. He pulls the noodles through a heated die. https://electricmotorglider.com/2017/07/15/57-80-10-large-gap-seal/ The resulting foam shape fits snugly between the aileron tube and the trailing edge of the wing and completely fills in the profile of the wing shape between the trailing edge and the aileron. -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471770#471770 ________________________________________________________________________________
Date: Aug 12, 2017
They *look* like they would cause significantly increased control system drag, due to friction between/among the fixed & moving surfaces and the noodle. I guess that in some a/c designs, it might not be noticeable. On Sat, Aug 12, 2017 at 7:28 AM, wrote: > I tried making the noodle gap seals but because of the way Kolb ailerons > are hinged they pop out. > > Joe > > ------------------------------ > *From: *"wakataka" <wakataka(at)charter.net> > *To: *"kolb-list" > *Sent: *Friday, August 11, 2017 9:22:48 PM > *Subject: *Kolb-List: Re: Gap seal > > > Brian Carpenter has come up with a great way to make gap seals from foam > pool noodles. He pulls the noodles through a heated die. > > https://electricmotorglider.com/2017/07/15/57-80-10-large-gap-seal/ > > The resulting foam shape fits snugly between the aileron tube and the > trailing edge of the wing and completely fills in the profile of the wing > shape between the trailing edge and the aileron. > > -------- > There is something fascinating about science. One gets such wholesale > returns of conjecture out of such a trifling investment of fact. > > Mark Twain > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471770#471770 > > ________________________________________________________________________________
Date: Aug 12, 2017
Looks really nice, but they are quite proud of it. If you could have settled for 16 gal, you could have bought 2 ea 8 gal tanks for half what one of the Air-Tech 10 gal tanks costs ($30 each). US Plastic also has a 20 gal tank for ~$160. https://www.usplastic.com/catalog/item.aspx?itemid=23334&catid=934 Charlie On Fri, Aug 11, 2017 at 8:55 PM, Jim Thomson wrote: > Air-Tech Inc Ultralights sells a 10 gallon fuel tank. I purchased and > installed two tanks on my Kolb Mk3 and am very happy with the now 20 gall on > fuel capacity. > > https://www.air-techinc.com/product_detail.php?pid=1079 > > Jim > > On Mon, Jul 31, 2017 at 3:12 PM, Charlie England > wrote: > >> Yep; very early kit. Hard to visualize either under-wing or over-the-top >> fueling, with the fill neck a few inches under the wing. It's tempting t o >> mount that 8gal tank on the boom tube, under the engine, if it won't cau se >> cg issues. >> >> I enjoy acro, but I think I'll control the urge while flying this one. : -) >> >> Thanks for the insight. >> >> Sent from BlueMail <http://www.bluemail.me/r?b=10215> >> On Jul 31, 2017, at 4:10 PM, George Helton wrote: >>> >>> >>> I think this a matter of personal preference. I prefer stationary mount ing. I don't enjoy restrapping a heavy tank back in place every time. You m ust have an original Twinstar. The Twinstar MKII like I built had the fuel tanks (2) mounted behind you with a covered firewall so they really couldn 't be removed. >>> In the early days, 1983, ultralighters who flew Phantoms and Avengers u se to use top feeders with flexible fuel hose inside the the tank with weig hted ends on them for aerobatics and inverted flight . The fuel pickup hose could move from bottom air feeder to top feeder. They also equipped the en gines with pumper type carbs for sustained inverted flight. Was never my ba g. >>> I just prefer not taken things apart and putting them back together. Th at's just my input. You know how opinions go. Whatever works for you. >>> George H. >>> Firestar , FS100 >>> 14GDH >>> Mesick, Michigan >>> gdhelton(at)gmail.com >>> >>> Have a great day! >>> >>> On Jul 31, 2017, at 12:42 PM, Charlie England w rote: >>>> >>>> yet. >>>> >>> >>> ------------------------------ >>> >>> > ________________________________________________________________________________
Date: Aug 12, 2017
Subject: elevator & aileron deflection angles?
I'm setting up the rigging on this (original) Twinstar restoration, & can't find anything in my plans that details elevator (or aileron) deflection. Does the Twinstar have more-or-less symmetrical control surface up/down deflection? Thanks, Charlie ________________________________________________________________________________
Subject: Re: elevator & aileron deflection angles?
Date: Aug 12, 2017
35 degrees up and down. It's on page 4. http://oh2fly.net/oldpoops/Lexan%20rear%20enclosure.html -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471786#471786 ________________________________________________________________________________
Date: Aug 12, 2017
On Sat, Aug 12, 2017 at 9:07 AM, Richard Pike wrote: > > 35 degrees up and down. It's on page 4. > http://oh2fly.net/oldpoops/Lexan%20rear%20enclosure.html > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > > My plans set apparently came with the plane (very old), & my sheet 4 is a drawing of the front cage. I can't get your page to load right now, but the fact that they are symmetrical up/down is what I need to know. Many thanks, Charlie ________________________________________________________________________________
From: "Michael Adams" <altojazz35(at)earthlink.net>
Subject: Model Firestar
Date: Aug 13, 2017
Thought some of you might think this is interesting... https://www.youtube.com/watch?v=zaZBeHtTVyQ ________________________________________________________________________________
Subject: Sail Repair tape for Gap Seal...
Date: Aug 13, 2017
Hello Kolbers, I do remember someone suggesting the use of Sail Repair Tape for creating gap seals. I saw the tape a West Marine, and have been thinking I would try it when that day shows up. Enjoy, Nick Cassara Palmer, Alaska 90% done on the my Firestar lll, Prototype Kolbra, MarkIII Classic, Extra" ________________________________________________________________________________
Date: Aug 13, 2017
Subject: Re: Model Firestar
Fantastic video, any chance I could get more information on the model building, and flying. Where was the location of this video? When? Who? My first homebuilding experience, was the UltraStar, back in 1985, in southern Wisconsin. I am currently in Florida, and I am involved with a FireFly. On Sun, Aug 13, 2017 at 11:50 AM, Michael Adams wrote: > > > > Thought some of you might think this is interesting... > > https://www.youtube.com/watch?v=zaZBeHtTVyQ > > -- Daniel Bindl ________________________________________________________________________________
Date: Aug 14, 2017
Michael, congratulations on a beautiful model of your family aircraft! 'bout time there was an R/C Kolb! I have a humble suggestion for the model. It looks like an electric motor has been installed where a gas engine was originally designed tot be. IMHO There needs to be a streamlined cover over the engine and wing center section. Even on the video you can hear the propeller beating against the dead and separated air on the top center section of the wing. Also put small vortex generators above the leading edges of the wings within the diameter of the propeller to guarantee attached airflow into the prop. That buzzing noise is telling you that the propeller is not making smooth strong thrust. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Sun, 8/13/17, Michael Adams wrote: Subject: Kolb-List: Model Firestar To: kolb-list(at)matronics.com Date: Sunday, August 13, 2017, 8:50 AM Adams" Thought some of you might think this is interesting... https://www.youtube.com/watch?v=zaZBeHtTVyQ The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Re: Sail Repair tape for Gap Seal...
Date: Aug 14, 2017
Seems like great idea. Ive used it on my hang glider and paraglider sails before it stuck on there really well. thx -------- 2007 Firestar 2 503 N203SD Moster 185 Flattop PPG/Sky K2 Paraglider Trike Buggy Soaring Trike & Northwing Stratus XP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471844#471844 ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 2 Msgs - 08/14/17
Date: Aug 15, 2017
Good points.... we are still in the testing phase The wing does have a gap cover that covers a lot more than the real Firestar. Can't cover the motor since they really like to have open air flow. Heat. The airplane has way more thrust than needed. I was testing some 3 cells which the motor is not rated for. The motor suggests 4 to 6 cells. The motor is much more efficient with 4 cells and can take off easily with a little over 1/2 throttle. The 3 cell required full throttle. This model could easily aero tow a large glider with 4 cells. Can't imagine what 6 cells would do. My dad immediately thought the prop was the wrong fit for the airplane due to the sound of the prop/motor but I'm not sold on that idea just yet. The motor may have an issue that could be mimicking stalled prop tips sounds. Would take too long to explain but you'll just have to trust me on this. I have some things to do to the airplane before any more flying can take place. I'll post videos as the flight test continue. A good thing is the model didn't require VG's on the horizontal stab. My big Firestar fly's much better with them and there was no indication of elevator stall on the model. From: Bill Berle <victorbravo(at)sbcglobal.net> Subject: Re: Kolb-List: Model Firestar Michael, congratulations on a beautiful model of your family aircraft! 'bout time there was an R/C Kolb! I have a humble suggestion for the model. It looks like an electric motor has been installed where a gas engine was originally designed tot be. IMHO There needs to be a streamlined cover over the engine and wing center section. Even on the video you can hear the propeller beating against the dead and separated air on the top center section of the wing. Also put small vortex generators above the leading edges of the wings within the diameter of the propeller to guarantee attached airflow into the prop. That buzzing noise is telling you that the propeller is not making smooth strong thrust. ________________________________________________________________________________
Date: Aug 15, 2017
Subject: rubber grommet for gas tanks
Hi....where can I can I get the rubber grommet's for the bottom of the 5 gal plastic gas tanks on my kolb firestar ll... and maybe also new tanks ? thanks Jim Swan.... ________________________________________________________________________________
Subject: Re: rubber grommet for gas tanks
Date: Aug 15, 2017
Are these the same thing? I used them on my Quicksilver. https://www.air-techinc.com/product_detail.php?pid=1087 -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471883#471883 ________________________________________________________________________________
Date: Aug 15, 2017
Yep! Larry On Tue, Aug 15, 2017 at 11:11 AM, west1m wrote: > > Are these the same thing? I used them on my Quicksilver. > https://www.air-techinc.com/product_detail.php?pid=1087 > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471883#471883 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 15, 2017
jimswan wrote: > Hi....where can I can I get the rubber grommet's for the bottom of the 5 gal plastic gas tanks on my kolb firestar ll... and maybe also new tanks ? thanks Jim Swan.... Jim: Kolb should have both the grommets and tanks. -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471886#471886 ________________________________________________________________________________
Date: Aug 15, 2017
Jbm has them, couple days to you Sent from my iPhone > On Aug 15, 2017, at 2:38 PM, Larry Cottrell wrot e: > > Yep! > Larry > >> On Tue, Aug 15, 2017 at 11:11 AM, west1m wrote: >> >> Are these the same thing? I used them on my Quicksilver. >> https://www.air-techinc.com/product_detail.php?pid=1087 >> >> -------- >> West1m >> Hastings, MN >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=471883#471883 >> >> >> >> >> >> >> ========================= >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?Kolb-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= > > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Date: Aug 16, 2017
Subject: Rock House Fly-in
The time for the Rock House Fly-in is near, and I would like to extend an invitation to all Kolb flyers and even wanna be Kolb Flyers to join us for our annual get together. Our core group is about 14 participants who join together to enjoy flying in the Deserts of Eastern Oregon and each others company. It is totally unorganized and therefore fun. Plenty of Desert to camp in and explore. Meals so far have been communal and supplied by me. There will be a limited amount of non ethanol 91 oct. gasoline available, we can go get more if needed. 42 40.419 N 117 51.198 W will get you here. Runway is 2800 feet of natural desert soil, with no obstructions at either end of the runway. Freguency will be 123.450 Arrivals should be around Sept 8th, with the core group and any others that are not usefully employed lasting most of the following week. It is mostly unoccupied High Desert, so come prepared for any emergency. Bring your own gas if possible. RSVP Larry Cottrell 541 586 5030 -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 16, 2017
JMB industries Dennis Rowe > On Aug 15, 2017, at 9:54 AM, James Swan wrote: > > Hi....where can I can I get the rubber grommet's for the bottom of the 5 g al plastic gas tanks on my kolb firestar ll... and maybe also new tanks ? thanks Jim Swan.... ________________________________________________________________________________
Subject: Kolb MK II info
Date: Aug 18, 2017
Greetings all, I am new to the site and am looking at a Kolb to purchase, I am looking at a MK II and am curious as to what years they were built. Any tips would be helpful as to what I should look at. I am a field engineer so I have mechanical background and abilities but anything specific to these planes would be welcomed. Any info would be helpful or if anyone would be willing to chat with me about their experiences with this model I would be happy to give a call. dansbird New Member Posts: 1 Joined: Wed Aug 16, 2017 7:15 pm Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471973#471973 ________________________________________________________________________________
Subject: Mark III Classic Dash
Date: Aug 20, 2017
Hi Guys, Hope everyone is enjoying there Kolb in one way or another. I am in progress of designing a new aluminum dash for my Mark III Classic, mainly because I have some new avionics but secondly I am sick and tires of not being able to reach the current dash. I would really appreciate any input from others that have improved
June 13, 2017 - August 20, 2017
Kolb-Archive.digest.vol-oo
