Kolb-Archive.digest.vol-op
August 20, 2017 - October 29, 2017
      there dash. If you have any pictures, drawings, dimensions or just some
      ideas you might have thought of because you're struggling from same deal. I thank
      anyone who shares with me in advanced.
      http://forums.matronics.com/viewtopic.php?p=472008#472008
Subject: Re: Mark III Classic Dash
Date: Aug 20, 2017
Jonesy, cant help you much. I=99ve sold my Kolb, but had little prob with the standard setup. Except the radio! - that was hard to use Good luck & fair winds, Russ > On Aug 20, 2017, at 4:32 PM, jonealjr wrote: > > > Hi Guys, > > Hope everyone is enjoying there Kolb in one way or another. I am in progress of designing a new aluminum dash for my Mark III Classic, mainly because I have some new avionics but secondly I am sick and tires of not being able to reach the current dash. I would really appreciate any input from others that have improved there dash. If you have any pictures, drawings, dimensions or just some ideas you might have thought of because you're struggling from same deal. I thank anyone who shares with me in advanced. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472008#472008 > > > > > > > > > ________________________________________________________________________________
Date: Aug 20, 2017
I made a stick out of aluminium sized long enough to reach things on my dash. On one end I put a short piece of rubber tubing for turning altimeter knobs and flipping switches. on the other end I cut a slot for turning my keyed ignition switch. Then fashioned a place to mount the stick when I'm not using it. Not real fancy but it works, it is quick and easy. Rick Neilsen Redrive VW Powered MKIIIC On Sun, Aug 20, 2017 at 5:49 PM, Russ Kinne wrote: > Jonesy, cant help you much. I=99ve sold my Kolb, but had little pro b with > the standard setup. > Except the radio! - that was hard to use > Good luck & > fair winds, > Russ > > > On Aug 20, 2017, at 4:32 PM, jonealjr wrote: > > > Hi Guys, > > Hope everyone is enjoying there Kolb in one way or another. I am in > progress of designing a new aluminum dash for my Mark III Classic, mainly > because I have some new avionics but secondly I am sick and tires of not > being able to reach the current dash. I would really appreciate any input > from others that have improved there dash. If you have any pictures, > drawings, dimensions or just some ideas you might have thought of because > you're struggling from same deal. I thank anyone who shares with me in > advanced. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472008#472008 > > ________________________________________________________________________________
Date: Aug 20, 2017
The other option is to make a little console that goes between your legs and then you don't have to reach very far. Does require you to figure out how to put a bunch of small switches in a confined space. Here is my solution: the radio has been replaced with a new one, but essentially it is still the same as in this picture. http://oh2fly.net/oldpoops/pg4.htm -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472013#472013 ________________________________________________________________________________
Date: Aug 20, 2017
I put a 4 x 6 in plastic Box 2 inches deep riveted to the bottom of the Gap seal right behind the windshield BowI run Master switches ignition switches intercom switches avionics switches fuses fuel pump switches starter switch, , and it just right over your hand when you raise it up works great. The altimeter transponder on the dash is still hard to reach... Been thinking about a stick like Rick described, but haven't done it yet. Boyd Young On Aug 20, 2017 2:34 PM, "jonealjr" wrote: Hi Guys, Hope everyone is enjoying there Kolb in one way or another. I am in progress of designing a new aluminum dash for my Mark III Classic, mainly because I have some new avionics but secondly I am sick and tires of not being able to reach the current dash. I would really appreciate any input from others that have improved there dash. If you have any pictures, drawings, dimensions or just some ideas you might have thought of because you're struggling from same deal. I thank anyone who shares with me in advanced. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472008#472008 ________________________________________________________________________________
Date: Aug 20, 2017
Subject: video
https://vimeo.com/230376068 password owyheeflyer I made a trip to the Alvord to see if it was clogged with Californians to view the Solar eclipse tomorrow. Our Hwy (Hwy 95) has been clogged with cars for about a week. Normally in a 5 mile trip to the closest town you might see 10 cars, this last week has been strings as much as a mile long coming from Ca. heading to the path in Oregon and Idaho. The phenomenon has been on Fox news quite a bit here this last week. While the Alvord is not in the path of totality, its pretty close. I first checked "winds aloft" and found that at 6000 feet there was supposed to be a 14 mph wind from the NNW, and since I am SSE from there I knew that I would be better off at low levels. I can pick up about 4 MPH by flying in "ground effects", so I dropped down to the tops of the Sage and started out. I've got a bit left to do before our fly-in so I decided to clear the carbon from the HKS and set it to maximum cruise of 5800 RPM's. I flew for an hour and 24 minutes, a total of 84.5 miles and four gallons of fuel. If you want to change quality of the video click on the "gear" and set your download speed to what you want to see. It is recorded at 1080 P, so the quality is there if you have the speed. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 21, 2017
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Subject: Clear coating sails
I'm putting new dacron sails on my plane, and will be using AeroThane 100 c lear coat to protect the fabric. Does anyone have any experience with using a roller instead of spraying on the AeroThane? I've heard that it is easier, wastes less product, and actua lly covers more evenly. Comments? Arty TrostSandy, Oregon=C2-www.LessonsFromTheEdge.com/uladventure2009.htm "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe t hrough life just to arrive safely at death." ________________________________________________________________________________
Date: Aug 20, 2017
Subject: Re: video
Outstanding video, Larry! I love low level flying. I don't get to do that mu ch up here in Michigan because of the trees. I fly a 377 Rotax so my low lev el trust factor is not like it was over the deserts of SoCal. Would love an H KS. Thanks for another great video. George Have a great day! > On Aug 20, 2017, at 10:57 PM, Larry Cottrell wro te: > > https://vimeo.com/230376068 password owyheeflyer > > I made a trip to the Alvord to see if it was clogged with Californians to v iew the Solar eclipse tomorrow. Our Hwy (Hwy 95) has been clogged with cars f or about a week. Normally in a 5 mile trip to the closest town you might see 10 cars, this last week has been strings as much as a mile long coming from Ca. heading to the path in Oregon and Idaho. The phenomenon has been on Fox news quite a bit here this last week. While the Alvord is not in the path o f totality, its pretty close. > > I first checked "winds aloft" and found that at 6000 feet there was suppos ed to be a 14 mph wind from the NNW, and since I am SSE from there I knew th at I would be better off at low levels. I can pick up about 4 MPH by flying i n "ground effects", so I dropped down to the tops of the Sage and started ou t. > > I've got a bit left to do before our fly-in so I decided to clear the carb on from the HKS and set it to maximum cruise of 5800 RPM's. I flew for an ho ur and 24 minutes, a total of 84.5 miles and four gallons of fuel. > > If you want to change quality of the video click on the "gear" and set you r download speed to what you want to see. It is recorded at 1080 P, so the q uality is there if you have the speed. > > Larry > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Date: Aug 20, 2017
jonealjr wrote: > Hi Guys, > > Hope everyone is enjoying there Kolb in one way or another. I am in progress of designing a aluminum dash for my Mark III Classic, mainly because I have some new avionics but secondly I am sick and tired of not being able to reach the stock dash. I would really appreciate any input from others that have improved there dash. If you have any pictures, drawings, dimensions or just some ideas you might have thought of because you're struggling from same deal. I thank anyone who shares with me in advanced. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472024#472024 ________________________________________________________________________________
Date: Aug 21, 2017
Bring the instrument panel center part back toward you as far as you want, but IMHO do not extend the sides of the fiberglassnose cone rearward. The sides need to be that far forward because you need to get your feet in and out, and extending the sides rearward would prevent that. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Sun, 8/20/17, jonealjr wrote: Subject: Kolb-List: Re: Mark III Classic Dash To: kolb-list(at)matronics.com Date: Sunday, August 20, 2017, 9:40 PM "jonealjr" jonealjr wrote: > Hi Guys, > > Hope everyone is enjoying there Kolb in one way or another. I am in progress of designing a aluminum dash for my Mark III Classic, mainly because I have some new avionics but secondly I am sick and tired of not being able to reach the stock dash. I would really appreciate any input from others that have improved there dash. If you have any pictures, drawings, dimensions or just some ideas you might have thought of because you're struggling from same deal. I thank anyone who shares with me in advanced. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472024#472024 The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Re: video
Date: Aug 21, 2017
Absolutely beautiful country and video. Thanks again Larry for sharing. I just wish I had a wife who was as willing to live away from the populated areas as yours is. Its not that I dislike people, I just dislike most of them. T Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472040#472040 ________________________________________________________________________________
Subject: Re: video
Date: Aug 21, 2017
Thanks for another great video. Watching your flights seems to be the only flying I have been able to do lately. We were in Oregon a couple weeks ago, Smoke from Portland to Crater lake and most of the way back to North Dakota. The whole state was on fire or something, in the afternoon you could not see the far side of Crater Lake for the smoke. We stayed at Diamond lake, the plume of smoke rising from just beyond the lake looked like an erupting volcano. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472049#472049 ________________________________________________________________________________
Date: Aug 21, 2017
Subject: Re: video
Yeah, its been a bit rough this year. Things will begin to get better the closer we get to Sept. Just in case you make the trip again, try for Sept and Oct. Those are the best months for the Coast as well as the interior. Thanks for the comments. Larry On Mon, Aug 21, 2017 at 3:27 PM, west1m wrote: > > Thanks for another great video. Watching your flights seems to be the only > flying I have been able to do lately. > We were in Oregon a couple weeks ago, Smoke from Portland to Crater lake > and most of the way back to North Dakota. > The whole state was on fire or something, in the afternoon you could not > see the far side of Crater Lake for the smoke. We stayed at Diamond lake, > the plume of smoke rising from just beyond the lake looked like an erupting > volcano. > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472049#472049 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: video
Date: Aug 22, 2017
Thank you Larry for another great Video. I have enjoyed each and every one. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472070#472070 ________________________________________________________________________________
Date: Aug 23, 2017
Subject: Wanted: 68" 3-blade Warp Drive prop
I'm looking for a used pusher Warp Drive prop. 68", 3 blade - preferably wi th nickle leading edges, but that's not a requirement. I have a hub - so I'd also consider buying a set of the three blades, if th at's what you have. Arty TrostSandy, Oregon=C2-www.LessonsFromTheEdge.com/uladventure2009.htm "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe t hrough life just to arrive safely at death." ________________________________________________________________________________
Date: Aug 23, 2017
Subject: Wanted: Warp Drive 68", 3 blade, pusher prop
I'm looking for a used pusher Warp Drive prop. 68", 3 blade - preferably wi th nickle leading edges, but that's not a requirement. I have a hub - so I'd also consider buying a set of the three blades, if th at's what you have. Arty TrostSandy, Oregon=C2-=C2-www.LessonsFromTheEdge.com/uladventure20 09.htm "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe through life just to arrive safely at death." ________________________________________________________________________________
Subject: Anybody have a MK 2 ???
Date: Aug 25, 2017
So I just purchased a Kolb MK II and have questions and would like some pictures if anyone is rebuilding one or has older pictures of a build and willing to chat with me, assistance would be greatly appreciated. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472164#472164 ________________________________________________________________________________
Date: Aug 25, 2017
I rebuilt a Kolb Twinstar MK II 2 years ago. Anything specific that you are looking for ? Lee So I just purchased a Kolb MK II and have questions and would like some pictures if anyone is rebuilding one or has older pictures of a build and willing to chat with me, assistance would be greatly appreciated. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472164#472164 ________________________________________________________________________________
Subject: Re: Anybody have a MK 2 ???
Date: Aug 25, 2017
I saw the posted message, and thought "did I post that?". (Likely too many miles of driving and too few flying!). I too just purchased a MK II, and should have a set of manuals on the way probably today. With mine, I have a few fuse issues to resolve, and a friend is going over the 503. Hopefully it won't be too long before I'm in the air with it. Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472171#472171 ________________________________________________________________________________
Subject: Re: Twinstar fuel tank options
Date: Aug 25, 2017
Needing fuel tanks or tank for a recent MK II purchase, I looked at the US Plastics listings. All say "Not for Fuel". Does anyone have experience using these? Or if they are OK to use? Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472172#472172 ________________________________________________________________________________
Date: Aug 25, 2017
Subject: Looking for a used Warp Driver prop
I'm looking for a used pusher Warp Drive prop. 68", 3 blade - preferably wi th nickle leading edges, but that's not a requirement. I have a hub and all the mounting bolts, etc. - so if you have three matchi ng 68" blades, let me know Arty TrostSandy, Oregon=C2-www.LessonsFromTheEdge.com/uladventure2009.htm "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe t hrough life just to arrive safely at death." S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Aug 25, 2017
Thanks for the reply, I am looking for pictures of the main cage structure (drivers compartment) it looks like someone has done some work to it and not sure if structure is missing, not correct or just missing all together, the landing gear has also been changed and not happy with the way the left wheel sits, so pictures of the landing gear would also be helpful. PM me and I would be happy to give my phone # and talk in person. This is my first plane so excited to learn all about it but for my own piece of mind got to make sure everything is right. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472174#472174 ________________________________________________________________________________
Date: Aug 25, 2017
On 8/25/2017 10:56 AM, Jerry-TS-MkII wrote: > > Needing fuel tanks or tank for a recent MK II purchase, I looked at the US Plastics listings. All say "Not for Fuel". Does anyone have experience using these? Or if they are OK to use? > Jerry > The 5 gal tank you buy from Kolb is also 'not for fuel'. It's just a 5 gal chemical jug. That is not just from observation of the product; it's straight from the horse's mouth at Kolb, as of a couple of weeks ago. If you want a truly fuel rated tank, US plastics has those, too. They just cost about 4 times as much. Look for 'CARB' rated tanks on the web site. But all you're really getting for the money is a sticker on the tank. None of the tanks used in experimental a/c are 'approved' for fuel, because the haven't paid to get some gov. official's 'seal of approval'. US Plastics also have all manner of fittings, vented/unvented caps, bushings for the tanks (though those are a bit more expensive than from the aviation suppliers), quick disconnects, etc. But don't just take my advice without doing your own research; it's only worth what you paid for it. :-) Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 25, 2017
Kolb Aircraft. Com They can supply everything you need, including new rubber grommets. We need to support them all we can. I built Twinstar MKII back in the late 80's. Flew it for about 4 years. It was a good airplane. What year is the Kolb you bought? Restoring can be a big job. I just finished restoring a original Firestar. George H. Firestar, FS 100 14GDH Mesick, MI. gdhelton(at)gmail.com Have a great day! > On Aug 25, 2017, at 11:56 AM, Jerry-TS-MkII <12flybellaire(at)gmail.com> wrote: > > > Needing fuel tanks or tank for a recent MK II purchase, I looked at the US Plastics listings. All say "Not for Fuel". Does anyone have experience using these? Or if they are OK to use? > Jerry > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472172#472172 > > > > > > > > > ________________________________________________________________________________
Date: Aug 25, 2017
Go to the fuel tank section of U S Plastics Joe ----- Original Message ----- From: "Jerry-TS-MkII" <12flybellaire(at)gmail.com> Sent: Friday, August 25, 2017 11:56:53 AM Subject: Kolb-List: Re: Twinstar fuel tank options Needing fuel tanks or tank for a recent MK II purchase, I looked at the US Plastics listings. All say "Not for Fuel". Does anyone have experience using these? Or if they are OK to use? Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472172#472172 ________________________________________________________________________________
Date: Aug 25, 2017
Subject: Re: Anybody have a MK 2 =?UTF-8?Q?=3F=3F=3F?
I have a few more photos from several angles if you want to take a look. Let me know. Mark On 08/25/2017 12:29, dansbird wrote: > > Thanks for the reply, I am looking for pictures of the main cage > structure (drivers compartment) it looks like someone has done some > work to it and not sure if structure is missing, not correct or just > missing all together, the landing gear has also been changed and not > happy with the way the left wheel sits, so pictures of the landing > gear would also be helpful. PM me and I would be happy to give my > phone # and talk in person. This is my first plane so excited to > learn > all about it but for my own piece of mind got to make sure everything > is right. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472174#472174 > > ________________________________________________________________________________
Date: Aug 25, 2017
The boating industry seems to have a good supply for fuel rated tanks. My Mark II Twinstar has a 12 gallon tank. ________________________________________________________________________________
Date: Aug 25, 2017
Thanks for the info. My intent is to get this in the air before winter... to do a bit of flying,and find out what it might truly need. So the plastic tank(s) would only be temporary anyway. In looking inside the fuse, I think a inverted saddle tank, that goes under the boom would be ideal. But that also means vinyl ester, or aluminum/tig fabrication.. better for a winter project. Installation would be easy from below, and a "normal" fuel tank filler thru the side of the fabric would also be a nice addition. Something about two tanks sitting right behind my head.. not ideal. I'll do a search for tank installations or option photos asap. jr Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472180#472180 ________________________________________________________________________________
Date: Aug 25, 2017
Modifying a Twinstar is something that shouldn't be done without careful consideration? Mounting fuel under the boom tube could quite dangerous for two reasons. One is a radical shift in the CG of aircraft and the second is possibly rupturing of tank or tanks on bent or broken landing gear situations. The only thing wrong with the present placement behind you is, they're a pain in the rear to refuel. But, their placement is critical to prevent an aft CG situation. This is just my opinion from years of flying a MKII. If you post some pictures of your cage Assy. I'd look them over. I built mine according to the plans provided by Kolb. George Have a great day! > On Aug 25, 2017, at 1:10 PM, Jerry-TS-MkII <12flybellaire(at)gmail.com> wrote: > > > Thanks for the info. My intent is to get this in the air before winter... to do a bit of flying,and find out what it might truly need. So the plastic tank(s) would only be temporary anyway. In looking inside the fuse, I think a inverted saddle tank, that goes under the boom would be ideal. But that also means vinyl ester, or aluminum/tig fabrication.. better for a winter project. Installation would be easy from below, and a "normal" fuel tank filler thru the side of the fabric would also be a nice addition. Something about two tanks sitting right behind my head.. not ideal. I'll do a search for tank installations or option photos asap. jr > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472180#472180 > > > > > > > > > ________________________________________________________________________________
Date: Aug 25, 2017
On Fri, Aug 25, 2017 at 12:10 PM, Jerry-TS-MkII <12flybellaire(at)gmail.com> wrote: > > Thanks for the info. My intent is to get this in the air before winter... > to do a bit of flying,and find out what it might truly need. So the > plastic tank(s) would only be temporary anyway. In looking inside the > fuse, I think a inverted saddle tank, that goes under the boom would be > ideal. But that also means vinyl ester, or aluminum/tig fabrication.. > better for a winter project. Installation would be easy from below, and a > "normal" fuel tank filler thru the side of the fabric would also be a nice > addition. Something about two tanks sitting right behind my head.. not > ideal. I'll do a search for tank installations or option photos asap. jr > > Aluminum/tank sealant/rivets is also a reasonable option. Closed head 'pop' rivets are available, if you don't have bucking equipment. Attached is a pic of the US Plastics 8gal tank I'm fitting. I wish it would fit between the bracing & the boom tube, but it's just a bit too tall. So, it has to sit in the original location of the 5gal tank. I'll try facing the filler forward, and hope I can set up the root fairing so I can peel it off for fueling. If that doesn't work, I'll just turn it around so it's oriented like the original tank. My ideal choice would be a tank that fits under the bracing, sitting on the boom tube just behind the seats, with the filler pointing forward between the seats (original Twinstar with no enclosure). If you don't mind the fueling inconvenience (my big gripe with the stock 'high' location) and intend to bottom-feed from the tanks, two of the US-P 5gal chemical tanks is by far the simplest, and cheapest way to go. Probably under $30 including shipping. Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Aug 25, 2017
My Firestar SS is setup for a pod similar to the MarkIII. I wanted space for an I-Fly and an Amptronic GX-2 so I built one from fiberglass. I'll attach two photos to this message and a couple to the next ----- Original Message ----- From: "jonealjr" <jonealjr(at)gmail.com> Sent: Sunday, August 20, 2017 4:32:18 PM Subject: Kolb-List: Mark III Classic Dash Hi Guys, Hope everyone is enjoying there Kolb in one way or another. I am in progress of designing a new aluminum dash for my Mark III Classic, mainly because I have some new avionics but secondly I am sick and tires of not being able to reach the current dash. I would really appreciate any input from others that have improved there dash. If you have any pictures, drawings, dimensions or just some ideas you might have thought of because you're struggling from same deal. I thank anyone who shares with me in advanced. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472008#472008 ________________________________________________________________________________
Date: Aug 25, 2017
more photos ----- Original Message ----- From: "jonealjr" <jonealjr(at)gmail.com> Sent: Sunday, August 20, 2017 4:32:18 PM Subject: Kolb-List: Mark III Classic Dash Hi Guys, Hope everyone is enjoying there Kolb in one way or another. I am in progress of designing a new aluminum dash for my Mark III Classic, mainly because I have some new avionics but secondly I am sick and tires of not being able to reach the current dash. I would really appreciate any input from others that have improved there dash. If you have any pictures, drawings, dimensions or just some ideas you might have thought of because you're struggling from same deal. I thank anyone who shares with me in advanced. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472008#472008 ________________________________________________________________________________
Date: Aug 25, 2017
I found this for fueling the Firefly. I mix the gas in the can, insert the pump and then lift the can onto a stand sitting next to the fuselage. Then just pump the fuel into the plane, no pouring involved. With 4 AA batteries, it will move 5 gallons of gas in less than 3 minutes. No Spills! https://www.amazon.com/gp/product/B00SBZRKEU/ref=s9_acsd_hps_bw_c_x_1_w Stuart -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of George Helton Sent: Friday, August 25, 2017 12:40 PM Subject: Re: Kolb-List: Re: Twinstar fuel tank options Modifying a Twinstar is something that shouldn't be done without careful consideration? Mounting fuel under the boom tube could quite dangerous for two reasons. One is a radical shift in the CG of aircraft and the second is possibly rupturing of tank or tanks on bent or broken landing gear situations. The only thing wrong with the present placement behind you is, they're a pain in the rear to refuel. But, their placement is critical to prevent an aft CG situation. This is just my opinion from years of flying a MKII. If you post some pictures of your cage Assy. I'd look them over. I built mine according to the plans provided by Kolb. George Have a great day! > On Aug 25, 2017, at 1:10 PM, Jerry-TS-MkII <12flybellaire(at)gmail.com> wrote: > > --> <12flybellaire(at)gmail.com> > > Thanks for the info. My intent is to get this in the air before > winter... to do a bit of flying,and find out what it might truly need. > So the plastic tank(s) would only be temporary anyway. In looking > inside the fuse, I think a inverted saddle tank, that goes under the > boom would be ideal. But that also means vinyl ester, or aluminum/tig > fabrication.. better for a winter project. Installation would be easy > from below, and a "normal" fuel tank filler thru the side of the > fabric would also be a nice addition. Something about two tanks > sitting right behind my head.. not ideal. I'll do a search for tank > installations or option photos asap. jr > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472180#472180 > > > > > > > > > ________________________________________________________________________________
Subject: Firestar 2 checklists
Date: Aug 25, 2017
Hi Guys Can anybody share their preflight/landing & post flight checklist for their firestar thank you Mike -------- 2007 Firestar 2 503 N203SD Moster 185 Flattop PPG/Sky K2 Paraglider Trike Buggy Soaring Trike & Northwing Stratus XP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472197#472197 ________________________________________________________________________________
Subject: Twinstar MK II Items to examine
Date: Aug 26, 2017
Hello to all, I just purchased a Mk II, and thought I would ask a few general questions. It has a 503 DCDI, B box, and 64" Ivo 3 blade prop. Flying it solo, can anyone share Vx for Best climb angle? And what cruise I might expect? One flyer mentioned a benefit of a 2 blade 68" Ivo, to lighten the loads on the B box. Any other input or other prop suggestions? I fully plan to completely examine the plane before it's put back in service, but asking here about any specific known problems that might need extra attention? I have read over many of the posts. I'll be adding bracing on either side of the tail wheel, and examining the fuse tube connection, and checking brace wire and control wire tensions, and the aileron bellcrank support AD. I read about some leading edge tubes with fractures and may have to scope the tubes and main spar. In general it looks good, but not knowing this plane, I'm asking about any other problem areas that others have encountered. Many thanks for any replies. Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472210#472210 ________________________________________________________________________________
Date: Aug 26, 2017
Subject: Re: Twinstar MK II Items to examine
we have a nice mk 2 listed on barnstormers here in Michigan, check it out! =C2-Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.comLSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022=C2-=C2-=C2-=C2- From: Jerry-TS-MkII <12flybellaire(at)gmail.com> To: kolb-list(at)matronics.com Sent: Saturday, August 26, 2017 8:09 AM Subject: Kolb-List: Twinstar MK II Items to examine Hello to all, I just purchased a Mk II, and thought I would ask a few general questions. =C2- It has a 503 DCDI, B box, and 64" Ivo 3 blade prop.=C2- Flying it solo, can anyone share Vx for Best climb angle?=C2- And what cruise I mig ht expect? One flyer mentioned a benefit of a 2 blade 68" Ivo, to lighten the loads on the B box.=C2- Any other input or other prop suggestions? I fully plan to completely examine the plane before it's put back in servic e, but asking here about any specific known problems that might need extra attention?=C2- I have read over many of the posts. I'll be adding bracing on either side of the tail wheel, and examining the fuse tube connection, and checking brace wire and control wire tensions, an d the aileron bellcrank support AD.=C2- I read about some leading edge tu bes with fractures and may have to scope the tubes and main spar.=C2- In general it looks good, but not knowing this plane, I'm asking about any oth er problem areas that others have encountered.=C2- Many thanks for any re plies.=C2- Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472210#472210 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Aug 26, 2017
I ran a 503 single carb on mine. It liked 50 to 52 mph on climb out as I rec all? It's been a lot of years ago. I built Twinstar, TS 205. It came with a wood 68" Tennessee Propeller. Which worked great. I later went to 64" three blade Ivoprop. It worked fine and was very smooth. I do think it climbed be tter with the two blade thou. I don't think there was a lot of difference in the gearbox loading. I changed my gearbox oil every 50 hours and never noti ced any excessive wear. I flew the Twinstar for about four years. It was a g ood unit. A bit sluggish, but it is a two seater after all. George H. Firestar, FS100, 1986 14GDH Mesick, Michigan gdhelton(at)gmail.com Have a great day! > On Aug 26, 2017, at 8:04 AM, Jerry-TS-MkII <12flybellaire(at)gmail.com> wrote : > > > Hello to all, > I just purchased a Mk II, and thought I would ask a few general questions. It has a 503 DCDI, B box, and 64" Ivo 3 blade prop. Flying it solo, can a nyone share Vx for Best climb angle? And what cruise I might expect? > > One flyer mentioned a benefit of a 2 blade 68" Ivo, to lighten the loads o n the B box. Any other input or other prop suggestions? > > I fully plan to completely examine the plane before it's put back in servi ce, but asking here about any specific known problems that might need extra a ttention? I have read over many of the posts. > > I'll be adding bracing on either side of the tail wheel, and examining the fuse tube connection, and checking brace wire and control wire tensions, an d the aileron bellcrank support AD. I read about some leading edge tubes wi th fractures and may have to scope the tubes and main spar. In general it l ooks good, but not knowing this plane, I'm asking about any other problem ar eas that others have encountered. Many thanks for any replies. Jerry > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472210#472210 > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Aug 26, 2017
Thanks George! When I had asked about the 3 blade.. the other flyer felt that the 2-blade 68" was more efficient on a 503. I'm more interested in a climb prop, and that usually follows a lower pitch and larger diameter. His experience was regarding the physical loading of the bearings and components in a B box.. ie spinning less mass, which means less stress in general to accelerate the prop, etc. He rebuilds a lot of Rotax engines (mainly for trikes), so he sees more than a typical airplane owner might. My biggest concern was in thinking the 3 blade pusher, right behind the wing might be smoother than 2. But it sounds as thou your Tennessee worked just fine. I may look for 68" Ivo blades once the dust settles. Always good to hear multiple comments that all point towards the same (positive) results. And it would be slightly lighter too. Again, Thanks! jr Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472223#472223 ________________________________________________________________________________
Date: Aug 26, 2017
I think you'll kind that a Twinstar climbs like a homesick angel when solo. Mine did. I like Ivoprops. I flew off a lot of decomposed granite and sand surfaces in Southern California and with the stainless steel leading edges it was pretty much indestructible. I do think my two blade was a better climb prop. I fly off of primarily grass fields these days. So the risk of prop damage is not as great. I should receive my new Tennessee 66X28 prop with composite edges this week. Under $600.00 delivered. My 30 year old Culver wood just doesn't seem to doing the job anymore? I'm not sure what has changed but I'm turned 7100 rpm on takeoff which is to high. I thought it was my tachometer. But, my new one agrees with the old one. Later, George Have a great day! > On Aug 26, 2017, at 5:27 PM, Jerry-TS-MkII <12flybellaire(at)gmail.com> wrote: > > > Thanks George! > When I had asked about the 3 blade.. the other flyer felt that the 2-blade 68" was more efficient on a 503. I'm more interested in a climb prop, and that usually follows a lower pitch and larger diameter. His experience was regarding the physical loading of the bearings and components in a B box.. ie spinning less mass, which means less stress in general to accelerate the prop, etc. He rebuilds a lot of Rotax engines (mainly for trikes), so he sees more than a typical airplane owner might. My biggest concern was in thinking the 3 blade pusher, right behind the wing might be smoother than 2. But it sounds as thou your Tennessee worked just fine. I may look for 68" Ivo blades once the dust settles. Always good to hear multiple comments that all point towards the same (positive) results. And it would be slightly lighter too. Again, Thanks! jr > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472223#472223 > > > > > > > > > ________________________________________________________________________________
Date: Aug 27, 2017
My experience was that the 2 blade climbs better. Also, using Mobil 1 gearbox lube not only keeps the gearbox cooler, when changing the oil during the annual, it comes out looking pretty much the way it looked when it went in with minimal mung on the magnet. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472243#472243 ________________________________________________________________________________
Subject: Re: Firestar 2 checklists
Date: Aug 27, 2017
Here is mine. I'm sure it was originally supplied by someone else and I have modified it. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://sites.google.com/site/kolbfirestar/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472244#472244 Attachments: http://forums.matronics.com//files/n27kf_firestar_checklist_647.docx ________________________________________________________________________________
Date: Aug 27, 2017
Perfect thanks so much I appreciate it. Mike -------- 2007 Firestar 2 503 N203SD Moster 185 Flattop PPG/Sky K2 Paraglider Trike Buggy Soaring Trike & Northwing Stratus XP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472249#472249 ________________________________________________________________________________
Date: Aug 28, 2017
Subject: short video
https://vimeo.com/231334174 password owyheeflyer I had gone out with our local fire district truck to a reported fire last week. After coming back home I couldn't find my Bino's, and of course assumed that I had left them in the fire truck. The truck is kept at one of the ranches South of here about 45 miles away. I decided to fly down there to look for them. I had noticed that he had a hay field that came up to the parking area, so I figured to land there. I discovered after coming home and viewing the video that I needed to point my camera up a bit, and that I had successfully concealed said Bino's inside my own truck. Sigh!. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 28, 2017
Any excuse to fly =F0=9F=98=8A From: Larry Cottrell Sent: Monday, August 28, 2017 9:24 AM Subject: Kolb-List: short video https://vimeo.com/231334174=C2- password =C2- owyheeflyer I had gone out with our local fire district truck to a reported fire last w eek. After coming back home I couldn't find my Bino's, and of course assume d that I had left them in the fire truck. The truck is kept at one of the r anches South of here about 45 miles away. I decided to fly down there to lo ok for them. I had noticed that he had a hay field that came up to the park ing area, so I figured to land there. I discovered after coming home and viewing the video that I needed to point my camera up a bit, and that I had successfully concealed said Bino's insi de my own truck. Sigh!. Larry -- The older I get, the less tolerant I am of those who are intolerant of othe rs. If you forward this email, or any part of it, please remove my email addres s before sending. ________________________________________________________________________________
Subject: Parts needed: Old style Ivo prop adjustment cams
Date: Aug 29, 2017
Hello everyone, Having a OLD STYLE 3 blade Ivo that I hope to use initially on my Twinstar Mk II, it came without the adjustment cams or adjustment shims. This prop doesn't have the large "easy to adjust external screw and lock nut") So it's at 6 degrees as I read the "no-cam" default. Ideally, I need to find/make/buy 3 cams, and a set of shims.. but I can make either if needed. The shims just round plates, of unknown thickness (at this point) that stack in front, or behind the prop blades, to move the 3 cams. Not sure if Ivo will send me any drawings since they are discontinued parts. But apparently they just have a screw (and some Lock-tite) holding them onto the end of the torque rod in the prop blade. If anyone has converted from 3 blade to 2, and has a spare blade w/cam, and would be willing to sell 3, or 1, or send me one cam and shim to duplicate, I'd gladly return with a coupon to your pub of choice, or health-food store, (I find them to be one and the SAME place myself.. but others might not). Someone's junk drawer probably has one (or more). But if like my shop, 3 weeks to find them would be the problem.. LOL. Any productive thoughts, sources, manifest instructions, etc, all welcome! Thanks, Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472321#472321 ________________________________________________________________________________
Date: Aug 29, 2017
Subject: Re: Parts needed: Old style Ivo prop adjustment cams
Jerry, The one that I had the levers that were on the end of the prop and only about an inch long. You adjusted it by the addition of thin washers to increase pitch. More washers more pitch????? At least I think that is the way it goes. I still have some of that stuff, but I need to know for sure what it is that you need. If you can be more specific - pictures- then I may be able to help. Having said all that- If it was me I would just buy a new prop., and I would get a two blade. A 503 on that plane is going to be to "me" marginal at best. A two blade will give you better climb, which to me is more useful than quiet or faster cruise. Your cruise speed is going to be probably a bit less than 60 MPH without some clean up of drag factors any way. Of course every thing that could be considered advice only mirrors what suits me, nothing more. The offer still holds however- I know I have a three inch spacer and several shims and plates. If you can use them, no charge, just postage. Larry On Tue, Aug 29, 2017 at 12:06 PM, Jerry-TS-MkII <12flybellaire(at)gmail.com> wrote: > > Hello everyone, > Having a OLD STYLE 3 blade Ivo that I hope to use initially on my Twinstar > Mk II, it came without the adjustment cams or adjustment shims. This prop > doesn't have the large "easy to adjust external screw and lock nut") So > it's at 6 degrees as I read the "no-cam" default. Ideally, I need to > find/make/buy 3 cams, and a set of shims.. but I can make either if > needed. The shims just round plates, of unknown thickness (at this point) > that stack in front, or behind the prop blades, to move the 3 cams. > > Not sure if Ivo will send me any drawings since they are discontinued > parts. But apparently they just have a screw (and some Lock-tite) holding > them onto the end of the torque rod in the prop blade. If anyone has > converted from 3 blade to 2, and has a spare blade w/cam, and would be > willing to sell 3, or 1, or send me one cam and shim to duplicate, I'd > gladly return with a coupon to your pub of choice, or health-food store, (I > find them to be one and the SAME place myself.. but others might not). > Someone's junk drawer probably has one (or more). But if like my shop, 3 > weeks to find them would be the problem.. LOL. Any productive thoughts, > sources, manifest instructions, etc, all welcome! Thanks, Jerry > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472321#472321 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 29, 2017
I was curious so I went out to the shop to see what I had. If I am correct what you need is the lever on the end of the prop and perhaps the plate and spacer. The blade was on a 447 and still running when I flipped upside down, so I don't think the blade is usable. If any of the rest is of use let me know. Larry 541 586 5030 On Tue, Aug 29, 2017 at 12:06 PM, Jerry-TS-MkII <12flybellaire(at)gmail.com> wrote: > > Hello everyone, > Having a OLD STYLE 3 blade Ivo that I hope to use initially on my Twinstar > Mk II, it came without the adjustment cams or adjustment shims. This prop > doesn't have the large "easy to adjust external screw and lock nut") So > it's at 6 degrees as I read the "no-cam" default. Ideally, I need to > find/make/buy 3 cams, and a set of shims.. but I can make either if > needed. The shims just round plates, of unknown thickness (at this point) > that stack in front, or behind the prop blades, to move the 3 cams. > > Not sure if Ivo will send me any drawings since they are discontinued > parts. But apparently they just have a screw (and some Lock-tite) holding > them onto the end of the torque rod in the prop blade. If anyone has > converted from 3 blade to 2, and has a spare blade w/cam, and would be > willing to sell 3, or 1, or send me one cam and shim to duplicate, I'd > gladly return with a coupon to your pub of choice, or health-food store, (I > find them to be one and the SAME place myself.. but others might not). > Someone's junk drawer probably has one (or more). But if like my shop, 3 > weeks to find them would be the problem.. LOL. Any productive thoughts, > sources, manifest instructions, etc, all welcome! Thanks, Jerry > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472321#472321 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 29, 2017
Larry, Those would be very helpful! My reduction box didn't have the extension, so that, and the plate, and shims (if you have any, I could use). I sent you a PM. (and a text). Get back with me, and I'll send an address. Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472330#472330 ________________________________________________________________________________
Date: Aug 29, 2017
Wish I had posted 2 months ago on the list that I needed a spacer. I bought a new one from Ivo for the FF... Sigh... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472338#472338 ________________________________________________________________________________
Date: Aug 29, 2017
Subject: Head for 503 DCDI
One of the guys here at Cherokee Strip needs a head for the 503 DCDI on the Challenger he's rebuilding. Anyone have one for sale or know of a vendor to go to? Rick Girard -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Subject: Re: Head for 503 DCDI
Date: Aug 29, 2017
On 8/29/2017 9:28 PM, Richard Girard wrote: > One of the guys here at Cherokee Strip needs a head for the 503 DCDI > on the Challenger he's rebuilding. Anyone have one for sale or know of > a vendor to go to? > > Rick Girard > > -- > > > Blessed are the cracked, for they shall let in the light. Groucho > Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > Tried ebay? I *think* I saw one on there just a couple of days ago. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 30, 2017
I hope that the old spacer system works out for you but like Larry said, I would just buy a new prop. There is a reason that they quit making those. My 503 DCDI was a pain to dial in to keep my EGT in check. A full turn is all there is between "to hot" and "acceptable". The EGT temps still run about 1075 in level flight according to my EIS. WOT on climb out gets me about 6550 rpm. If you melt a piston, a new engine will cost you a lot more than a prop. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472353#472353 ________________________________________________________________________________
Date: Aug 30, 2017
I need a Rotax 277 head to convert to dual ignition. Ebay doesn't have one. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472355#472355 ________________________________________________________________________________
Date: Aug 30, 2017
Thanks to all for the good info and Larry is going to help me with his parts. Really a nice feeling to have a supportive group. Something about pilots and sailers, (when I was Hobie sailing).. that really makes a person feel good. I told Larry about helping others build or repair their U/Ls way back when, and teaching 2 of them to fly. I did their test flights too.. to check things out.. and maybe to instill confidence in their aircraft. As for new props.. yes I agree 100%, new and improved would be much better. When I went to Georgia to pick up this Twinstar, the trailer provided was really heavy and with no brakes. Oh, great fun, pulling THAT down the road with all the sun worshipers out to view the eclipse, and basically driving like crazy people. Sorta glad they are ON THE GROUND, and not flying! I had to swap vehicles with a friend.. but in doing so had to pay her lapsed insurance, and then found 2 bad wheel bearings on the drive to my house before the big trip. Doing it myself was only(?) $300 (or the cost of a good used IVO!!). But I knew she was sweating bullets money wise.. so it was helping her, and me.. to have a hearty tow truck. One guy at a rest stop looked at the rig (with no brakes) and then PRAYED for me, cause I hadn't reached the Smokies yet! (Nothing like being puckered with that commentary). But the trip went fine. I just knew it made for an expensive "rental". So Karma may be smiling for helping her out too. My issue is adjusting the pitch of my billfold!! The prop should be more straight forward. And some classic R/C kits will go onto RCGroups to help fund this rework. I have some options now, and will be able to get it in the air.. and make some decisions. Main goal is to do some flying before winter, so I can bring it back home, and do some rework over the winter, knowing more specifically what issues to address more fully. Having looked at numerous other forums on here, some have ZERO activity. So it's really nice to see this group is active, supportive, and very willing to share knowledge and more. I LIKE it!! Pretty excited about doing some flying soon!! Thanks to all for the input and assistance!! Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472358#472358 ________________________________________________________________________________
Subject: Re: short video
Date: Aug 30, 2017
Thank you for posting Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472359#472359 ________________________________________________________________________________
Date: Aug 30, 2017
Subject: gas tank top feed hardware?
Those who are using top feed for your plastic fuel tanks: what pickup tube & tank fittings are you using? I've got the viton bushings, and the steel (?) right-angle inserts for the bushings, sold by LEAF & others. I need to use a tube to get to the bottom of the tank, but I'm having a brain freeze on how to do it. I took a shot at brazing a longer tube into the steel fitting, but either I've lost my skillset or it isn't steel. It *is* highly magnetic, and doesn't look like stainless, but.... Parts sources, and pics, would be welcome. Thanks, Charlie Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Aug 30, 2017
Subject: Re: gas tank top feed hardware?
I don't recall how I managed to secure my extension, but I am sure I had to go to solder to get it done. Here are some pictures of what I use. My theory was that a flexible tube with a weighted filter pickup that could slosh around to where the fuel was no matter the attitude would not be a bad thing. The little filter was from Model airplane fuel pickups. The fuel line being inside the tank has never been a problem and is still flexible and it has been there for some 20 years. On Wed, Aug 30, 2017 at 1:57 PM, Charlie England wrote: > Those who are using top feed for your plastic fuel tanks: what pickup tube > & tank fittings are you using? > > I've got the viton bushings, and the steel (?) right-angle inserts for > the bushings, sold by LEAF & others. I need to use a tube to get to the > bottom of the tank, but I'm having a brain freeze on how to do it. I took a > shot at brazing a longer tube into the steel fitting, but either I've lost > my skillset or it isn't steel. It *is* highly magnetic, and doesn't look > like stainless, but.... > > Parts sources, and pics, would be welcome. > > Thanks, > > Charlie > > > Virus-free. > www.avast.com > > <#m_4566926007430672732_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 30, 2017
I have the 6 gal tanks that Kolb sells and also the pickup tubes. They reach the bottom easily. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472372#472372 ________________________________________________________________________________
Date: Aug 30, 2017
I agree Larry. Flexible fuel line pickups work great. Never had a problem wi th them on my MKII. I do think that the tubing should checked annually. And a fter a short time after initial installation just be sure the tubing used li kes fuel. My Firestar has a custom aluminum tank which is a bottom feeder. Works well t oo. Fuel system has a Facet electric pump and a pulse pump with fuel filters before and after pumps, thanks to information from those on the kolblist. George H. Firestar, FS 100, 1986 Have a great day! > On Aug 30, 2017, at 5:21 PM, Larry Cottrell wrot e: > > I don't recall how I managed to secure my extension, but I am sure I had t o go to solder to get it done. > > Here are some pictures of what I use. My theory was that a flexible tube w ith a weighted filter pickup that could slosh around to where the fuel was n o matter the attitude would not be a bad thing. > > The little filter was from Model airplane fuel pickups. The fuel line bein g inside the tank has never been a problem and is still flexible and it has b een there for some 20 years. > > > >> On Wed, Aug 30, 2017 at 1:57 PM, Charlie England w rote: >> Those who are using top feed for your plastic fuel tanks: what pickup tub e & tank fittings are you using? >> >> I've got the viton bushings, and the steel (?) right-angle inserts for t he bushings, sold by LEAF & others. I need to use a tube to get to the botto m of the tank, but I'm having a brain freeze on how to do it. I took a shot a t brazing a longer tube into the steel fitting, but either I've lost my skil lset or it isn't steel. It *is* highly magnetic, and doesn't look like stain less, but.... >> >> Parts sources, and pics, would be welcome. >> >> Thanks, >> >> Charlie >> >> Virus-free. www.avast.com > > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. > > > ________________________________________________________________________________
Date: Aug 30, 2017
I would strongly recommend Tygon fuel line only. It's resistant to all the fuels, stays flexible, and doesn't expand. On a U/L I used generic clear tubing, with a "tight" press fit inside the cap fitting.. but one day while fueling, it FELL OFF! Use spring clamps on all connections, or large diameter safety wire with a few wraps, then twisted snug. Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472374#472374 ________________________________________________________________________________
Date: Aug 30, 2017
Thanks to all for your responses. Very helpful in clarifying my path forward. What I have in mind is very similar to what Larry showed in the pics. Plan is to use the same blue urethane tubing that's used for the rest of the fuel system. Larry, is your in-tank tubing 1/4" ID, like the feed to the pump(s) and engine? Do you have a link to the fuel filter? All the model filters I've been able to find are for 1/8" ID tubing. I've got some plastic inline filters for 1/4" line that I can adapt, but I'd have to add some weight to hold the filter down. Thanks again, Charlie On 8/30/2017 4:21 PM, Larry Cottrell wrote: > I don't recall how I managed to secure my extension, but I am sure I > had to go to solder to get it done. > > Here are some pictures of what I use. My theory was that a flexible > tube with a weighted filter pickup that could slosh around to where > the fuel was no matter the attitude would not be a bad thing. > > The little filter was from Model airplane fuel pickups. The fuel line > being inside the tank has never been a problem and is still flexible > and it has been there for some 20 years. > > > On Wed, Aug 30, 2017 at 1:57 PM, Charlie England > wrote: > > Those who are using top feed for your plastic fuel tanks: what > pickup tube & tank fittings are you using? > > I've got the viton bushings, and the steel (?) right-angle > inserts for the bushings, sold by LEAF & others. I need to use a > tube to get to the bottom of the tank, but I'm having a brain > freeze on how to do it. I took a shot at brazing a longer tube > into the steel fitting, but either I've lost my skillset or it > isn't steel. It *is* highly magnetic, and doesn't look like > stainless, but.... > > Parts sources, and pics, would be welcome. > > Thanks, > > Charlie > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 30, 2017
https://www.amazon.com/In-Tank-Filter-W-Ball-Check/dp/B0055DOP6C/ref=sr_1_3?ie=UTF8&qid=1504146785&sr=8-3&keywords=in+tank+filters+for here you go. Larry ________________________________________________________________________________
Date: Aug 30, 2017
On 8/30/2017 9:34 PM, Larry Cottrell wrote: > https://www.amazon.com/In-Tank-Filter-W-Ball-Check/dp/B0055DOP6C/ref=sr_1_3?ie=UTF8&qid=1504146785&sr=8-3&keywords=in+tank+filters+for > > > here you go. > Larry Excellent! I failed to use the 'in tank' search term, & all I got was a list of inline versions. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 30, 2017
I stand corrected! All of my Tygon applications were concealed, and it's worked well with alcohol, but apparently not UV protected. I found this link for the blue tubing marketed by Bing, and AS also has the pickups shown by Larry. http://www.aircraftspruce.com/catalog/appages/bingfuel.php Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472382#472382 ________________________________________________________________________________
Date: Aug 31, 2017
Correction to the correction. Tygon has MANY different formulations! Their LP-1100 is UV protected and good for 100% ethanol. However the link doesn't suggest it's use for "fuel submersible" applications. Every chain saw I own does have new Tygon lines, in both fuel and oil tanks. And it was the only thing I had found that would remain flexible in the tank, submerged, and no failures. I'd be curious to know who makes the line for Bing. http://www.processsystems.saint-gobain.com/products/tygon-lp-1100-flexible-fuel-tubing Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472383#472383 ________________________________________________________________________________
Date: Aug 31, 2017
Well, finally gave up on the plumber's flux & went with tried & true electronics stuff. Heated the fitting & dipped it in my tin of paste flux; after that, soldering using rosin core 50/50 was uneventful. In case anyone's wondering, solder apparently can't go bad. That roll of Kester in the pic is my father's. He turned 100 last June. And it's entirely possible that he inherited it from *his* father, but there's no mfgr date on the spool. ________________________________________________________________________________
Subject: I think it's finally an airplane!!!
Date: Sep 01, 2017
Last Dec., I purchased a trailer full of parts from Mr. Pike. Thank you Richard. I have had a ball rebuilding this thing into a sweet little plane. In two weeks I will take it to it's resting place, a t-hanger at a little country airport. I have read all of the archives about this plane and others. I thank you all for all of the information contained on this forum. Without you all, this project would not have been finished. No matter the subject or the model, I have tried to get something useful for my project. I have been to the factory for parts and Helen and Brian are top notch people. They have really come thru when I needed parts or information. Below is a pic of the beast. It started out as Vince Nicely's plane and after the rebuild, I hope I did it justice. I have spoke with him during the build and he is a pleasure to talk with. Thank you Vince. And thank you all on the forum. I hope in the future I can contribute to this list the way you guys do..Thank you all again. My appologies to Richard if the pic is too big. I tried. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472424#472424 Attachments: http://forums.matronics.com//files/finally_wings_158.jpg ________________________________________________________________________________
Date: Sep 01, 2017
Date: Sep 01, 2017
Subject: Re: I think it's finally an airplane!!!
Wow, Jim! Looks pretty sweet! Congrats on your new wings. George H. Firestar, FS100, 1986 Have a great day! > On Sep 1, 2017, at 7:08 PM, japowell wrote: > > > Last Dec., I purchased a trailer full of parts from Mr. Pike. Thank you Richard. I have had a ball rebuilding this thing into a sweet little plane. In two weeks I will take it to it's resting place, a t-hanger at a little country airport. I have read all of the archives about this plane and others. I thank you all for all of the information contained on this forum. Without you all, this project would not have been finished. No matter the subject or the model, I have tried to get something useful for my project. I have been to the factory for parts and Helen and Brian are top notch people. They have really come thru when I needed parts or information. Below is a pic of the beast. It started out as Vince Nicely's plane and after the rebuild, I hope I did it justice. I have spoke with him during the build and he is a pleasure to talk with. Thank you Vince. And thank you all on the forum. I hope in the future I can contribute to this list the way you guys do..Thank yo! > u all again. > > My appologies to Richard if the pic is too big. I tried. > > -------- > Jim P > WAR EAGLE > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472424#472424 > > > > > Attachments: > > http://forums.matronics.com//files/finally_wings_158.jpg > > > > > > ________________________________________________________________________________
Date: Sep 01, 2017
Atta Boy!, you did good! Larry On Fri, Sep 1, 2017 at 5:08 PM, japowell wrote: > > Last Dec., I purchased a trailer full of parts from Mr. Pike. Thank you > Richard. I have had a ball rebuilding this thing into a sweet little > plane. In two weeks I will take it to it's resting place, a t-hanger at a > little country airport. I have read all of the archives about this plane > and others. I thank you all for all of the information contained on this > forum. Without you all, this project would not have been finished. No > matter the subject or the model, I have tried to get something useful for > my project. I have been to the factory for parts and Helen and Brian are > top notch people. They have really come thru when I needed parts or > information. Below is a pic of the beast. It started out as Vince > Nicely's plane and after the rebuild, I hope I did it justice. I have > spoke with him during the build and he is a pleasure to talk with. Thank > you Vince. And thank you all on the forum. I hope in the future I can > contribute to this list the way you guys do..Thank yo! > u all again. > > My appologies to Richard if the pic is too big. I tried. > > -------- > Jim P > WAR EAGLE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472424#472424 > > > Attachments: > > http://forums.matronics.com//files/finally_wings_158.jpg > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Sep 02, 2017
Good job! john h mkIII Spring Creek, Nevada -- japowell wrote: > > Last Dec., I purchased a trailer full of parts from Mr. Pike. Thank you Richard. I have had a ball rebuilding this thing into a sweet little plane. In two weeks I will take it to it's resting place, a t-hanger at a little country airport. I have read all of the archives about this plane and others. I thank you all for all of the information contained on this forum. Without you all, this project would not have been finished. No matter the subject or the model, I have tried to get something useful for my project. I have been to the factory for parts and Helen and Brian are top notch people. They have really come thru when I needed parts or information. Below is a pic of the beast. It started out as Vince Nicely's plane and after the rebuild, I hope I did it justice. I have spoke with him during the build and he is a pleasure to talk with. Thank you Vince. And thank you all on the forum. I hope in the future I can contribute to this list the way you guys do..Thank y o! > u all again. > > My appologies to Richard if the pic is too big. I tried. > > -------- > Jim P > WAR EAGLE > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472424#472424 > > > > > Attachments: > > http://forums.matronics.com//files/finally_wings_158.jpg > > > > > > ________________________________________________________________________________
Date: Sep 02, 2017
-------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472425#472425 ________________________________________________________________________________
Subject: Beautiful plane Jim!
Date: Sep 02, 2017
Jim, You plane looks great! I am wondering if the dihederal in the wings is to the Kolb normal amount for your plane, or did you increase it? Have fun! Nick Cassara Palmer, AK ________________________________________________________________________________
Date: Sep 02, 2017
Date: Sep 02, 2017
Date: Sep 02, 2017
Date: Sep 02, 2017
Date: Sep 02, 2017
Date: Sep 02, 2017
Thanks guys. Without this forum and some good tips and advice from Richard, Vince and Ted, it would not have been possible. I just hope it flies as good as it looks. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472434#472434 ________________________________________________________________________________
Date: Sep 02, 2017
Jim, Beautiful rebuild! You are going to love it. Bill Varnes Kolb FireStar Audubon, NJ In a message dated 9/1/2017 8:56:24 P.M. Eastern Daylight Time, japnmjp(at)twc.com writes: Last Dec., I purchased a trailer full of parts from Mr. Pike. Thank you Richard. I have had a ball rebuilding this thing into a sweet little plane. ________________________________________________________________________________
Subject: Re: Beautiful plane Jim!
Date: Sep 02, 2017
I did not. Vince had 3* in it when he flew it. If you check the archives, he did a pretty thorough write up about this. Richard thought that the struts I got were the original per plans struts. When I rigged the wings they were at the 3* that Vince originally put in it. After reading all about him trimming the plane, I left it as he flew it. Hope it works out. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472436#472436 ________________________________________________________________________________
Date: Sep 02, 2017
Date: Sep 02, 2017
Subject: Advise on radio and headset
Date: Sep 04, 2017
I would like to get some input and advise on an inexpensive hand held radio and a headset as well. I looked on Ebay but there were way to many choices to pick from and I have no experience with radios at all. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472493#472493 ________________________________________________________________________________
Date: Sep 05, 2017
Subject: Re: Advise on radio and headset
I've flown all over CONUS, Canada, and Alaska, with an ICOM IC-A6 handheld. Sporty's has them for 239.00 dollars. They come with a charger, headset adapter, and some other stuff. I fly with a DRE-6000 ANR headset, the cheapest of the ANRs, but they get the job done. http://www.sportys.com/pilotshop/icom-ic-a6-com-transceiver.html?utm_source=google_shopping&m=simple&utm_medium=cpc&utm_campaign=Radios+%26+Scanners&creative=76141183015954&device=c&matchtype=e john h MKIII Rock House, Burns Junction, Oregon ---- dansbird wrote: > > I would like to get some input and advise on an inexpensive hand held radio and a headset as well. I looked on Ebay but there were way to many choices to pick from and I have no experience with radios at all. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472493#472493 > > > > > > > > > ________________________________________________________________________________
Date: Sep 05, 2017
I have one Sigtronics headset that I have added a headsets inc. noise canceling kit to and another off brand headset that I use for passengers. Nether headset does the job. I have tried all kinds of foam ear plugs, ear buds, etc. under these and nothing worked very. A few years ago I purchased a set of Bose QC 20 ear buds that I wear under my heads sets and they are wonderful. I plug the Bose ear buds into my intercom via a adapter instead of my headsets. I use the headset microphone. I can fly for hours and my ears aren't ringing from the flight noise. I normally fly with both noise canceling systems turned on. I will fly without the Sigtronics noise canceling kit operating but never without the Bose canceling. I use the Bose ear buds for lots of other things also. When I was stuck on a long commercial flight next to a screaming child, I just sat there smiling. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Sep 4, 2017 at 9:49 PM, wrote: > > > I've flown all over CONUS, Canada, and Alaska, with an ICOM IC-A6 handheld. > > Sporty's has them for 239.00 dollars. They come with a charger, headset > adapter, and some other stuff. > > I fly with a DRE-6000 ANR headset, the cheapest of the ANRs, but they get > the job done. > > http://www.sportys.com/pilotshop/icom-ic-a6-com- > transceiver.html?utm_source=google_shopping&m=simple&utm_ > medium=cpc&utm_campaign=Radios+%26+Scanners&creative > 76141183015954&device=c&matchtype=e > > john h > MKIII > Rock House, Burns Junction, Oregon > > > ---- dansbird wrote: > > > > I would like to get some input and advise on an inexpensive hand held > radio and a headset as well. I looked on Ebay but there were way to many > choices to pick from and I have no experience with radios at all. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=472493#472493 > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 05, 2017
i also have sigtronics headsets,,,, the microphone were so sensitive they picked up a lot of background noise..... I called the manufacturer and they told me how to decrease the Mike gain it made a ton of difference... They came at 100 percent, I turned them all the way down... With my hearing the way it is now, I may need to turn it up 5 percent then see the difference. On Sep 5, 2017 10:32 AM, "Rick Neilsen" wrote: > I have one Sigtronics headset that I have added a headsets inc. noise > canceling kit to and another off brand headset that I use for passengers. > Nether headset does the job. I have tried all kinds of foam ear plugs, ear > buds, etc. under these and nothing worked very. A few years ago I purchased > a set of Bose QC 20 ear buds that I wear under my heads sets and they are > wonderful. I plug the Bose ear buds into my intercom via a adapter instead > of my headsets. I use the headset microphone. I can fly for hours and my > ears aren't ringing from the flight noise. I normally fly with both noise > canceling systems turned on. I will fly without the Sigtronics noise > canceling kit operating but never without the Bose canceling. > > I use the Bose ear buds for lots of other things also. When I was stuck on > a long commercial flight next to a screaming child, I just sat there > smiling. > > Rick Neilsen > Redrive VW Powered MKIIIC > > On Mon, Sep 4, 2017 at 9:49 PM, wrote: > >> >> >> I've flown all over CONUS, Canada, and Alaska, with an ICOM IC-A6 >> handheld. >> >> Sporty's has them for 239.00 dollars. They come with a charger, headset >> adapter, and some other stuff. >> >> I fly with a DRE-6000 ANR headset, the cheapest of the ANRs, but they get >> the job done. >> >> http://www.sportys.com/pilotshop/icom-ic-a6-com-transceiver. >> html?utm_source=google_shopping&m=simple&utm_medium >> cpc&utm_campaign=Radios+%26+Scanners&creative=761411830159 >> 54&device=c&matchtype=e >> >> john h >> MKIII >> Rock House, Burns Junction, Oregon >> >> >> >> ---- dansbird wrote: >> > >> > I would like to get some input and advise on an inexpensive hand held >> radio and a headset as well. I looked on Ebay but there were way to many >> choices to pick from and I have no experience with radios at all. >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=472493#472493 >> > >> > >> > >> > >> > >> > >> > >> > >> > >> >> =================================== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/ >> Navigator?Kolb-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> > ________________________________________________________________________________
Date: Sep 05, 2017
Subject: video
One of the guy's attending our fly - in is a former Kolb Firestar owner, who has transitioned to an RV-7 and is still a good friend. His plane is really nice with a great paint job, so he has a "repaint" fund to repair all the damage that he is going to do to it while he is here. We were intending to go to some of the places that we wanted to visit and he, on to get some Spam can fuel, but we both decided that the smoke was just too heavy to enjoy a flight, so we came back here to the Rockhouse. I decided that I would video his landing so that his friends back home would have something to make fun of him over. All of which I might add, probably do not have even a little bit of adventure or the ability to laugh at themselves that Ken has. Apparently the Kolb experience prepares one for adventures such as these. Hope that you enjoy! https://vimeo.com/232524986 password owyheeflyer Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Sep 05, 2017
Subject: Re: video
Cool video!! How do you get your airspeed and heading in the lower left? Some slick iPhone app? Jerry On Tue, Sep 5, 2017 at 3:05 PM, Larry Cottrell wrote: > One of the guy's attending our fly - in is a former Kolb Firestar owner, > who has transitioned to an RV-7 and is still a good friend. His plane is > really nice with a great paint job, so he has a "repaint" fund to repair > all the damage that he is going to do to it while he is here. We were > intending to go to some of the places that we wanted to visit and he, on to > get some Spam can fuel, but we both decided that the smoke was just too > heavy to enjoy a flight, so we came back here to the Rockhouse. I decided > that I would video his landing so that his friends back home would have > something to make fun of him over. All of which I might add, probably do > not have even a little bit of adventure or the ability to laugh at > themselves that Ken has. Apparently the Kolb experience prepares one for > adventures such as these. > > Hope that you enjoy! > > https://vimeo.com/232524986 > > password owyheeflyer > > Larry > > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > ________________________________________________________________________________
Date: Sep 05, 2017
Subject: Re: video
It comes with the Garmin Virb camera. The edit program from Garmin is a bit of a pain, but that is the only way to get the metrix. Larry On Tue, Sep 5, 2017 at 1:15 PM, Jerry Flyer <12flybellaire(at)gmail.com> wrote: > Cool video!! How do you get your airspeed and heading in the lower left? > Some slick iPhone app? > Jerry > > On Tue, Sep 5, 2017 at 3:05 PM, Larry Cottrell > wrote: > >> One of the guy's attending our fly - in is a former Kolb Firestar owner, >> who has transitioned to an RV-7 and is still a good friend. His plane is >> really nice with a great paint job, so he has a "repaint" fund to repair >> all the damage that he is going to do to it while he is here. We were >> intending to go to some of the places that we wanted to visit and he, on to >> get some Spam can fuel, but we both decided that the smoke was just too >> heavy to enjoy a flight, so we came back here to the Rockhouse. I decided >> that I would video his landing so that his friends back home would have >> something to make fun of him over. All of which I might add, probably do >> not have even a little bit of adventure or the ability to laugh at >> themselves that Ken has. Apparently the Kolb experience prepares one for >> adventures such as these. >> >> Hope that you enjoy! >> >> https://vimeo.com/232524986 >> >> password owyheeflyer >> >> Larry >> >> -- >> *The older I get, the less tolerant I am of those who are intolerant of >> others.* >> >> *If you forward this email, or any part of it, please remove my email >> address before sending.* >> > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Sep 05, 2017
Subject: Re: video
That's just so cool... great video Larry and thank you for takaing the time to do these. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Tue, 9/5/17, Larry Cottrell wrote: Subject: Kolb-List: video To: "kolb-list(at)matronics.com" Date: Tuesday, September 5, 2017, 12:05 PM One of the guy's attending our fly - in is a former Kolb Firestar owner, who has transitioned to an RV-7 and is still a good friend. His plane is really nice with a great paint job, so he has a "repaint" fund to repair all the damage that he is going to do to it while he is here. We were intending to go to some of the places that we wanted to visit and he, on to get some Spam can fuel, but we both decided that the smoke was just too heavy to enjoy a flight, so we came back here to the Rockhouse. I decided that I would video his landing so that his friends back home would have something to make fun of him over. All of which I might add, probably do not have even a little bit of adventure or the ability to laugh at themselves that Ken has. Apparently the Kolb experience prepares one for adventures such as these. Hope that you enjoy! https://vimeo.com/232524986 password owyheeflyer Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Subject: Re: video
Date: Sep 05, 2017
Yes thanks for the great videos! The grasshopper lands again made me chuckle. Nice one -------- 912ul King Kolbra ;fun plane O300 Cessna 172B ;travel plane Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472536#472536 ________________________________________________________________________________
Date: Sep 07, 2017
Subject: Powerfin prop for sale
I'm trying to clear out the hangar and I thought there might be a Kolber needing a prop. It's a four blade Powerfin with two blades. One blade has a repair in the outboard three inches where my wire frame bifocals went through the prop. The repair is CA mixed with cotton flox. Flew it about 6 hours total, it had one when the glasses flew off my neck, and replaced it. The other was replaced when some crush damage was found on one side of the blade shank. I was told this is normal for a Powerfin and the shanks of all the blades that came out of the hub showed similar damage during their ten year life. The blades are "F" type, 68" diameter. I ran it on an HKS on my my trike but I tried it on the Mk III with a 582 as a two blade and couldn't really tell much difference from the Warp Drive that it normally runs. $200 + shipping Rick Girard -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Subject: Re: Powerfin prop for sale
Date: Sep 07, 2017
Did you see my PM? I'll try sending a email. THX! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472594#472594 ________________________________________________________________________________
Subject: Interesting wx site
Date: Sep 10, 2017
Not aviation specific, but still might be useful: https://www.ventusky.com/ -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472751#472751 ________________________________________________________________________________
Subject: Re: Interesting wx site
Date: Sep 10, 2017
Richard Pike wrote: > Not aviation specific, but still might be useful: > https://www.ventusky.com/ Very useful for those of us in SW FL. Thanks! -------- George Alexander FS II R503 N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472755#472755 ________________________________________________________________________________
Date: Sep 10, 2017
George Alexander wrote: > > Richard Pike wrote: > > Not aviation specific, but still might be useful: > > https://www.ventusky.com/ > > > Very useful for those of us in SW FL. > Thanks! Yeah, I got if from my brother in Pensacola. He is probably also taking a great interest... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472757#472757 ________________________________________________________________________________
Date: Sep 11, 2017
Subject: 2 stroke oil type?
I'm getting ready to crank the restored Twinstar for the (my) 1st time, and I've been doing some reading on oil requirements for Rotax 2 strokes. The only thing I've been able to find in the Rotax manual is to use either ASTM-CEC or API-TC. The stuff I'm finding at local suppliers seems to call itself TC-W3, but says it's good for TC (says it's good for both water and air cooled 2 strokes). I also read a warning from one engine vendor saying to avoid synthetic 2 stroke oil, claiming that it would run off surfaces easier than 'natural' oil. That's a confusing statement to me, because in the 4 stroke world, it's the opposite. So, is any TC-W3 oil OK for an air cooled Rotax? What about synthetics? I've got 8 oz of Amsoil synthetic begging to be mixed with my gas (premium, alcohol-free auto gas). Thanks, Charlie ________________________________________________________________________________
Subject: Re: Rotax 277 head
Date: Sep 11, 2017
Don't have a head but curious about the 'fly'. How is it turning out, final weight and flying characteristics? Got mine in hanger doing final assembly and rigging. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472776#472776 ________________________________________________________________________________
Date: Sep 11, 2017
Flies excellent. Climb rate is pretty good, somewhere between 5-700'/min, which is surprising given just a 277, but then it is light. Weight is between 260 and 262, we are hoping to get an A&P friend to weigh it soon on his scales and sign off the papers that certify that it qualifies for part 103. We have a hand deployed parachute that weighs 9 pounds, so using the 25 pound leeway the FAA gives you for a parachute, it will "legally" weigh 246 pounds & qualify for Part 103. Initially we had a lot of problems with vibration, have eliminated most of it, still trying to smooth it out some more. We replaced the rubber motor mounts with new ones ($ouch$) but can't tell any improvement in the vibration. Modified the muffler mounts once, will be modifying them again because we are still not completely satisfied with how they are working out. The muffler keeps wanting to hang crooked. If anyone has an old Fisher style muffler that has the long straight expansion cone, and you want to sell it, let me know. Or even just the expansion cone. Also be interested in buying one of those Balance Master mercury rings if someone has one of those for sale. Next step will probably be to add a third blade to the Ivoprop, that ought to help the vibration some. There is going to be a Fly-In at Greenville airport (GCY) this Saturday, we are planning to trailer it down there, put it together, fly it, and trailer it home, so that will be the first real test to see how well it does what we made it to do. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472779#472779 ________________________________________________________________________________
Date: Sep 11, 2017
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Subject: Re: 2 stroke oil type?
Charlie - Your question seems to come up on this - and other lists - every year or tw o. You'll get impassioned responses as any pilots seem to regard their choi ce of oil as sacrosanct. Personally, I used Penzoil Air-Cooled religiously for my 503 except when I was flying long cross countries, since it just wasn't easily available. So I'd drain all the Penzoil and switch to a TC-W3 oil. ANY TC-W3 oil - Walmar t, Auto Zone. it didn't seem to matter at all. Then Penzoil quit making the air-cooled, and I went to a 582, and I had dif ficulty getting the Shell oil that is now recommended - so I went to straig ht TC-W3 oil - again, regardless of brand. I've got over 1000 hours on 582s, and have only used TC-W3. No problems at all.HOWEVER - that's just my personal experience, and you can't extrapolate a conclusion from only one example. Good luck with your decision. Arty TrostSandy, Oregon =C2-www.LessonsFromTheEdge.com/uladventure2009.htm "Life's a daring adven ture or nothing" Helen Keller "I refuse to tip toe through life just to arr ive safely at death." From: Charlie England <ceengland7(at)gmail.com> To: kolb-list(at)matronics.com Sent: Monday, September 11, 2017 5:52 AM Subject: Kolb-List: 2 stroke oil type? I'm getting ready to crank the restored Twinstar for the (my) 1st time, and I've been doing some reading on oil requirements for Rotax 2 strokes. The only thing I've been able to find in the Rotax manual is to use either ASTM -CEC or API-TC. The stuff I'm finding at local suppliers seems to call itse lf TC-W3, but says it's good for TC (says it's good for both water and air cooled 2 strokes).=C2- I also read a warning from one engine vendor saying to avoid synthetic 2 st roke oil, claiming that it would run off surfaces easier than 'natural' oil . That's a confusing statement to me, because in the 4 stroke world, it's t he opposite. So, is any TC-W3 oil OK for an air cooled Rotax? What about synthetics? I'v e got 8 oz of Amsoil synthetic begging to be mixed with my gas (premium, al cohol-free auto gas). Thanks, Charlie ________________________________________________________________________________
Date: Sep 11, 2017
I am afraid that I don't know what oil most are using on their engines ( since the demise of Pennzoil air cooled) but I will warn you that depending on the designation of TW3 to get the proper oil will get you the experience of a de- carbon within 30 days. Hopefully someone will pop up with the best soon. Just be aware that the local oil company will give you more carbon than you want. Larry On Mon, Sep 11, 2017 at 6:47 AM, Charlie England wrote: > I'm getting ready to crank the restored Twinstar for the (my) 1st time, > and I've been doing some reading on oil requirements for Rotax 2 strokes. > The only thing I've been able to find in the Rotax manual is to use either > ASTM-CEC or API-TC. The stuff I'm finding at local suppliers seems to call > itself TC-W3, but says it's good for TC (says it's good for both water and > air cooled 2 strokes). > > I also read a warning from one engine vendor saying to avoid synthetic 2 > stroke oil, claiming that it would run off surfaces easier than 'natural' > oil. That's a confusing statement to me, because in the 4 stroke world, > it's the opposite. > > So, is any TC-W3 oil OK for an air cooled Rotax? What about synthetics? > I've got 8 oz of Amsoil synthetic begging to be mixed with my gas (premium, > alcohol-free auto gas). > > Thanks, > > Charlie > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Sep 11, 2017
We had excellent results with a 503 and 582 burning Wal-mart Two Stroke TCW-3 oil by the gal. When a friend was ready to break in his 503 I gave him two gals of Wal-mart TCW-3 oil which had sat on a shelf at my hose for 15 to 20 years. He burned that, with 87 octane ethanol free gas, and many more gals before he finished his MKIII and powered it with the engine from John Williamson's Kolbra. The FS and 503 were sold to a local who has since flown the same engine with no problems. I don't have a 2 stroke powered airplane anymore, but burn Wal-mart TCW-3 in many two powered machines. You'll get all kinds of answers to the two stroke oil question. I think as long as the two stroke is run hard it will perform well with any two stroke oil. My own personal opinion and experience, of course. john h mkIII Rock House, Oregon ---- Charlie England wrote: > I'm getting ready to crank the restored Twinstar for the (my) 1st time, and > I've been doing some reading on oil requirements for Rotax 2 strokes. The > only thing I've been able to find in the Rotax manual is to use either > ASTM-CEC or API-TC. The stuff I'm finding at local suppliers seems to call > itself TC-W3, but says it's good for TC (says it's good for both water and > air cooled 2 strokes). > > I also read a warning from one engine vendor saying to avoid synthetic 2 > stroke oil, claiming that it would run off surfaces easier than 'natural' > oil. That's a confusing statement to me, because in the 4 stroke world, > it's the opposite. > > So, is any TC-W3 oil OK for an air cooled Rotax? What about synthetics? > I've got 8 oz of Amsoil synthetic begging to be mixed with my gas (premium, > alcohol-free auto gas). > > Thanks, > > Charlie ________________________________________________________________________________
Date: Sep 11, 2017
As you can see, the response about TC-W3 can be interesting. If you really want to get a response, take it to the Rotax forum. Regardless, there is one thing you need to know, NEVER EVER mix API-TC and TC-W3. Especially in oil injection systems. They coagulate when mixed. This isn't an urban myth, I asked the engineers at Shell Oil and they confirmed it. I don't know what happens when you mix them together with gasoline, but I don't do that with mine, either. Rick Girard On Mon, Sep 11, 2017 at 10:40 AM, wrote: > > We had excellent results with a 503 and 582 burning Wal-mart Two Stroke > TCW-3 oil by the gal. > > When a friend was ready to break in his 503 I gave him two gals of > Wal-mart TCW-3 oil which had sat on a shelf at my hose for 15 to 20 years . > He burned that, with 87 octane ethanol free gas, and many more gals befor e > he finished his MKIII and powered it with the engine from John Williamson 's > Kolbra. The FS and 503 were sold to a local who has since flown the same > engine with no problems. > > I don't have a 2 stroke powered airplane anymore, but burn Wal-mart TCW-3 > in many two powered machines. > > You'll get all kinds of answers to the two stroke oil question. I think > as long as the two stroke is run hard it will perform well with any two > stroke oil. My own personal opinion and experience, of course. > > john h > mkIII > Rock House, Oregon > > > ---- Charlie England wrote: > > I'm getting ready to crank the restored Twinstar for the (my) 1st time, > and > > I've been doing some reading on oil requirements for Rotax 2 strokes. T he > > only thing I've been able to find in the Rotax manual is to use either > > ASTM-CEC or API-TC. The stuff I'm finding at local suppliers seems to > call > > itself TC-W3, but says it's good for TC (says it's good for both water > and > > air cooled 2 strokes). > > > > I also read a warning from one engine vendor saying to avoid synthetic 2 > > stroke oil, claiming that it would run off surfaces easier than 'natura l' > > oil. That's a confusing statement to me, because in the 4 stroke world, > > it's the opposite. > > > > So, is any TC-W3 oil OK for an air cooled Rotax? What about synthetics? > > I've got 8 oz of Amsoil synthetic begging to be mixed with my gas > (premium, > > alcohol-free auto gas). > > > > Thanks, > > > > Charlie > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Sep 11, 2017
I thought the 2 stroke oil thing was over. But, it likes to come back from time to time. Any quality "Air Cooled" oil is good. Most are synthetic blends these days. Rotax recommends AV-2. Which is good and available in gallons from Aircraft Spruce. That's just one of many sources. I use Lucas Air Cooled 2 cycle and it is really good. No carbon problems at all. It's also a blend. My little old original 377 loves the stuff. My experience has been find one you like and stick with it. Don't switch around all the time. Mix 50:1 in Rotax engines period. That's just My experience and opinion and we all know what that's worth. George H. Firestar, FS100, 1986 Mesick, Michigan Have a great day! > On Sep 11, 2017, at 8:47 AM, Charlie England wrote: > > I'm getting ready to crank the restored Twinstar for the (my) 1st time, and I've been doing some reading on oil requirements for Rotax 2 strokes. The only thing I've been able to find in the Rotax manual is to use either ASTM-CEC or API-TC. The stuff I'm finding at local suppliers seems to call itself TC-W3, but says it's good for TC (says it's good for both water and air cooled 2 strokes). > > I also read a warning from one engine vendor saying to avoid synthetic 2 stroke oil, claiming that it would run off surfaces easier than 'natural' oil. That's a confusing statement to me, because in the 4 stroke world, it's the opposite. > > So, is any TC-W3 oil OK for an air cooled Rotax? What about synthetics? I've got 8 oz of Amsoil synthetic begging to be mixed with my gas (premium, alcohol-free auto gas). > > Thanks, > > Charlie ________________________________________________________________________________
Date: Sep 11, 2017
Hi George, To be honest, I didn't know there ever was a thing until I started reading on the interwebs. :-) I did know that at some point there was a difference between oil for water cooled vs air cooled two strokes, and that's what prompted the original message. There doesn't seem to be much info from the oil companies on what's different between API-TC & TC-W3. That makes it tempting to assume that the latter is an improved TC, but I try not to assume any more than I have to. Charlie On 9/11/2017 2:00 PM, George Helton wrote: > > I thought the 2 stroke oil thing was over. But, it likes to come back from time to time. > Any quality "Air Cooled" oil is good. Most are synthetic blends these days. Rotax recommends AV-2. Which is good and available in gallons from Aircraft Spruce. That's just one of many sources. I use Lucas Air Cooled 2 cycle and it is really good. No carbon problems at all. It's also a blend. My little old original 377 loves the stuff. My experience has been find one you like and stick with it. Don't switch around all the time. Mix 50:1 in Rotax engines period. That's just My experience and opinion and we all know what that's worth. > George H. > Firestar, FS100, 1986 > Mesick, Michigan > > Have a great day! > >> On Sep 11, 2017, at 8:47 AM, Charlie England wrote: >> >> I'm getting ready to crank the restored Twinstar for the (my) 1st time, and I've been doing some reading on oil requirements for Rotax 2 strokes. The only thing I've been able to find in the Rotax manual is to use either ASTM-CEC or API-TC. The stuff I'm finding at local suppliers seems to call itself TC-W3, but says it's good for TC (says it's good for both water and air cooled 2 strokes). >> >> I also read a warning from one engine vendor saying to avoid synthetic 2 stroke oil, claiming that it would run off surfaces easier than 'natural' oil. That's a confusing statement to me, because in the 4 stroke world, it's the opposite. >> >> So, is any TC-W3 oil OK for an air cooled Rotax? What about synthetics? I've got 8 oz of Amsoil synthetic begging to be mixed with my gas (premium, alcohol-free auto gas). >> >> Thanks, >> >> Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 11, 2017
Charlie, you can drive yourself crazy trying to figure this stuff out. API-TC is the standard that I use for (TC) Two Cycle air cooled engines. API stands for American petroleum institute. W-3 (water cooled generation three) is a outboard motor manufacturers organization standard. Who's right? Beats me!?? Like I said. I'd find a "Air Cooled" 2 cycle oil that you can readily obtain and works well in your engine and stay with it. Always take it easy on your engine for a couple of when changing brands. Most of the engine failures that I have seen over the years were the result of guys all switching to the latest and greatest. Beware of snake oil and unicorn ear wax. I'm smiling... George H. Have a great day! > On Sep 11, 2017, at 4:36 PM, Charlie England wrote: > > > Hi George, > > To be honest, I didn't know there ever was a thing until I started reading on the interwebs. :-) > > I did know that at some point there was a difference between oil for water cooled vs air cooled two strokes, and that's what prompted the original message. There doesn't seem to be much info from the oil companies on what's different between API-TC & TC-W3. That makes it tempting to assume that the latter is an improved TC, but I try not to assume any more than I have to. > > Charlie > >> On 9/11/2017 2:00 PM, George Helton wrote: >> >> I thought the 2 stroke oil thing was over. But, it likes to come back from time to time. >> Any quality "Air Cooled" oil is good. Most are synthetic blends these days. Rotax recommends AV-2. Which is good and available in gallons from Aircraft Spruce. That's just one of many sources. I use Lucas Air Cooled 2 cycle and it is really good. No carbon problems at all. It's also a blend. My little old original 377 loves the stuff. My experience has been find one you like and stick with it. Don't switch around all the time. Mix 50:1 in Rotax engines period. That's just My experience and opinion and we all know what that's worth. >> George H. >> Firestar, FS100, 1986 >> Mesick, Michigan >> >> Have a great day! >> >>> On Sep 11, 2017, at 8:47 AM, Charlie England wrote: >>> >>> I'm getting ready to crank the restored Twinstar for the (my) 1st time, and I've been doing some reading on oil requirements for Rotax 2 strokes. The only thing I've been able to find in the Rotax manual is to use either ASTM-CEC or API-TC. The stuff I'm finding at local suppliers seems to call itself TC-W3, but says it's good for TC (says it's good for both water and air cooled 2 strokes). >>> >>> I also read a warning from one engine vendor saying to avoid synthetic 2 stroke oil, claiming that it would run off surfaces easier than 'natural' oil. That's a confusing statement to me, because in the 4 stroke world, it's the opposite. >>> >>> So, is any TC-W3 oil OK for an air cooled Rotax? What about synthetics? I've got 8 oz of Amsoil synthetic begging to be mixed with my gas (premium, alcohol-free auto gas). >>> >>> Thanks, >>> >>> Charlie > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > > ________________________________________________________________________________
Date: Sep 11, 2017
I won't obsess over it; just didn't want to make an easily avoided mistake. Some of the W3 stuff actually says it meets TC specs too, so I can live (I hope) with that. This plane is dirt simple, even for a Kolb. No battery or starter, original point ignition, minimal instruments; just a before breakfast/after dinner flyer. I do appreciate everyone's insight. If any of us cross paths, I'd be happy to swap rides with you. Right/back seat in your Kolb for back seat in my RV (airborne version). Charlie If the 503 goes to lunch, there will probably be an electric motor in my future. I doubt I'll ever fly this thing more than 30 minutes, or leave sight of the runway, anyway. On 9/11/2017 4:40 PM, George Helton wrote: > > Charlie, you can drive yourself crazy trying to figure this stuff out. API-TC is the standard that I use for (TC) Two Cycle air cooled engines. API stands for American petroleum institute. W-3 (water cooled generation three) is a outboard motor manufacturers organization standard. > Who's right? Beats me!?? Like I said. I'd find a "Air Cooled" 2 cycle oil that you can readily obtain and works well in your engine and stay with it. Always take it easy on your engine for a couple of when changing brands. Most of the engine failures that I have seen over the years were the result of guys all switching to the latest and greatest. Beware of snake oil and unicorn ear wax. I'm smiling... > George H. > > Have a great day! > >> On Sep 11, 2017, at 4:36 PM, Charlie England wrote: >> >> >> Hi George, >> >> To be honest, I didn't know there ever was a thing until I started reading on the interwebs. :-) >> >> I did know that at some point there was a difference between oil for water cooled vs air cooled two strokes, and that's what prompted the original message. There doesn't seem to be much info from the oil companies on what's different between API-TC & TC-W3. That makes it tempting to assume that the latter is an improved TC, but I try not to assume any more than I have to. >> >> Charlie >> >>> On 9/11/2017 2:00 PM, George Helton wrote: >>> >>> I thought the 2 stroke oil thing was over. But, it likes to come back from time to time. >>> Any quality "Air Cooled" oil is good. Most are synthetic blends these days. Rotax recommends AV-2. Which is good and available in gallons from Aircraft Spruce. That's just one of many sources. I use Lucas Air Cooled 2 cycle and it is really good. No carbon problems at all. It's also a blend. My little old original 377 loves the stuff. My experience has been find one you like and stick with it. Don't switch around all the time. Mix 50:1 in Rotax engines period. That's just My experience and opinion and we all know what that's worth. >>> George H. >>> Firestar, FS100, 1986 >>> Mesick, Michigan >>> >>> Have a great day! >>> >>>> On Sep 11, 2017, at 8:47 AM, Charlie England wrote: >>>> >>>> I'm getting ready to crank the restored Twinstar for the (my) 1st time, and I've been doing some reading on oil requirements for Rotax 2 strokes. The only thing I've been able to find in the Rotax manual is to use either ASTM-CEC or API-TC. The stuff I'm finding at local suppliers seems to call itself TC-W3, but says it's good for TC (says it's good for both water and air cooled 2 strokes). >>>> >>>> I also read a warning from one engine vendor saying to avoid synthetic 2 stroke oil, claiming that it would run off surfaces easier than 'natural' oil. That's a confusing statement to me, because in the 4 stroke world, it's the opposite. >>>> >>>> So, is any TC-W3 oil OK for an air cooled Rotax? What about synthetics? I've got 8 oz of Amsoil synthetic begging to be mixed with my gas (premium, alcohol-free auto gas). >>>> >>>> Thanks, >>>> >>>> Charlie >> --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 11, 2017
Subject: video
We are right in the middle of our fly-in, and of course I am as busy as a one armed paper hanger, but I managed to squeeze out a video for those who could not attend. The smoke from all the fires that encircle us was pretty bad this year. It has cleared out now, but who knows how long that will last. The smoke cut into our airplanes flying here, and most people attended by driving. That however does not cut into the fun at all. Since I am so much in demand, the sound track on this one is way out of balance, due to my ability to "multi-task" or is it lack. I just didn't have the energy to redo the whole thing. when I found out that I had messed up. This video is of a geothermal hot spot about 40 miles west of us. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Sep 11, 2017
Subject: Fwd: video
---------- Forwarded message ---------- From: Larry Cottrell <lcottrell1020(at)gmail.com> Date: Mon, Sep 11, 2017 at 6:05 PM Subject: video See what I mean by distracted, sigh! We are right in the middle of our fly-in, and of course I am as busy as a one armed paper hanger, but I managed to squeeze out a video for those who could not attend. The smoke from all the fires that encircle us was pretty bad this year. It has cleared out now, but who knows how long that will last. The smoke cut into our airplanes flying here, and most people attended by driving. That however does not cut into the fun at all. Since I am so much in demand, the sound track on this one is way out of balance, due to my ability to "multi-task" or is it lack. I just didn't have the energy to redo the whole thing. when I found out that I had messed up. This video is of a geothermal hot spot about 40 miles west of us. https://vimeo.com/233384168 pass word owyheeflyer Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Sep 12, 2017
The old Rotax 2 cycle 2 cylinder engines use dual point ignition. Point dwell/point gap determines ign timing. Point rubbing blocks wear quicking on occasion, which in turn changes timing. Each cylinder timing is controlled by each set of points. Point ign's caused many engine failures in the old days prior to CDI. Most folks blamed the failures on oil, fuel mixture, spark plugs, etc. I put a lot of hours on my 447 point ign engines in a short period of time on extremely long distance flights for ultralights back in the 1980's. On flights from Alabama to NY I would have to adj points, sometimes replace because the rubbing blocks would wear excessively. On one flight to NY I had to replace both coils that had vibrated to the point of nearly falling out of their mounts. Growing up in the 1940s and 50s I remember most two stroke engines were run on whatever oil was available around the house and farm. Put a lot of miles on a Harley-Davidson 125cc two stroke motorcycle draining motor oil out of used cans and bottles at service stations. Same for outboard marine engines. john h mkIII Rock House, Oregon Early timing caused by point rubbing block wear caused a lot of burned pistons and engine failures. CDI on the newer engines was a blessing. ---- George Helton wrote: > > Charlie, you can drive yourself crazy trying to figure this stuff out. API-TC is the standard that I use for (TC) Two Cycle air cooled engines. API stands for American petroleum institute. W-3 (water cooled generation three) is a outboard motor manufacturers organization standard. > Who's right? Beats me!?? Like I said. I'd find a "Air Cooled" 2 cycle oil that you can readily obtain and works well in your engine and stay with it. Always take it easy on your engine for a couple of when changing brands. Most of the engine failures that I have seen over the years were the result of guys all switching to the latest and greatest. Beware of snake oil and unicorn ear wax. I'm smiling... > George H. > > Have a great day! > > > On Sep 11, 2017, at 4:36 PM, Charlie England wrote: > > > > > > Hi George, > > > > To be honest, I didn't know there ever was a thing until I started reading on the interwebs. :-) > > > > I did know that at some point there was a difference between oil for water cooled vs air cooled two strokes, and that's what prompted the original message. There doesn't seem to be much info from the oil companies on what's different between API-TC & TC-W3. That makes it tempting to assume that the latter is an improved TC, but I try not to assume any more than I have to. > > > > Charlie > > > >> On 9/11/2017 2:00 PM, George Helton wrote: > >> > >> I thought the 2 stroke oil thing was over. But, it likes to come back from time to time. > >> Any quality "Air Cooled" oil is good. Most are synthetic blends these days. Rotax recommends AV-2. Which is good and available in gallons from Aircraft Spruce. That's just one of many sources. I use Lucas Air Cooled 2 cycle and it is really good. No carbon problems at all. It's also a blend. My little old original 377 loves the stuff. My experience has been find one you like and stick with it. Don't switch around all the time. Mix 50:1 in Rotax engines period. That's just My experience and opinion and we all know what that's worth. > >> George H. > >> Firestar, FS100, 1986 > >> Mesick, Michigan > >> > >> Have a great day! > >> > >>> On Sep 11, 2017, at 8:47 AM, Charlie England wrote: > >>> > >>> I'm getting ready to crank the restored Twinstar for the (my) 1st time, and I've been doing some reading on oil requirements for Rotax 2 strokes. The only thing I've been able to find in the Rotax manual is to use either ASTM-CEC or API-TC. The stuff I'm finding at local suppliers seems to call itself TC-W3, but says it's good for TC (says it's good for both water and air cooled 2 strokes). > >>> > >>> I also read a warning from one engine vendor saying to avoid synthetic 2 stroke oil, claiming that it would run off surfaces easier than 'natural' oil. That's a confusing statement to me, because in the 4 stroke world, it's the opposite. > >>> > >>> So, is any TC-W3 oil OK for an air cooled Rotax? What about synthetics? I've got 8 oz of Amsoil synthetic begging to be mixed with my gas (premium, alcohol-free auto gas). > >>> > >>> Thanks, > >>> > >>> Charlie > > > > > > --- > > This email has been checked for viruses by Avast antivirus software. > > https://www.avast.com/antivirus > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 11, 2017
Lots of good stuff on here. Perhaps the best advice was to find something you like and stick with it. Availability counts for a lot. I have been using Phillips Injex 2 stroke oil since 1983 with good results, it is a TC-W3 oil. One summer I used nothing but Pennzoil just to see if it made any difference. Seemed like there were a lot more oily carbon spots on the tail, but aside from that it worked good too. When you find what you like, buy it by the case, it keeps well. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472815#472815 ________________________________________________________________________________
Date: Sep 12, 2017
Subject: Re: Fwd: video
Thanks for another great video, Larry. I went up for breakfast flight to Moo rsetown, Michigan and believe or not our skies are filled with the smoke fro m your fires out west. Visibility is less then 10 miles. Normally it's 25 to 50miles. George H. Firestar, FS100, 1986 Have a great day! > On Sep 11, 2017, at 8:07 PM, Larry Cottrell wrot e: > > > ---------- Forwarded message ---------- > From: Larry Cottrell <lcottrell1020(at)gmail.com> > Date: Mon, Sep 11, 2017 at 6:05 PM > Subject: video > To: "kolb-list(at)matronics.com" > > See what I mean by distracted, sigh! > > We are right in the middle of our fly-in, and of course I am as busy as a o ne armed paper hanger, but I managed to squeeze out a video for those who co uld not attend. The smoke from all the fires that encircle us was pretty bad this year. It has cleared out now, but who knows how long that will last. T he smoke cut into our airplanes flying here, and most people attended by dri ving. That however does not cut into the fun at all. > > Since I am so much in demand, the sound track on this one is way out of ba lance, due to my ability to "multi-task" or is it lack. I just didn't have t he energy to redo the whole thing. when I found out that I had messed up. > > This video is of a geothermal hot spot about 40 miles west of us. > > https://vimeo.com/233384168 pass word owyheeflyer > > Larry > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. > > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Date: Sep 12, 2017
Here in Minnesota there are plenty of snowmobile dealers. So I have been using Polaris two stroke oil, sold in bulk, bring back the one gal jug for a refill. OK that was to keep it about Kolbs. John H. , you touched a nerve! here is the Harley 165CC my dad bought for me back in the mid sixty's. I still have it. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472842#472842 Attachments: http://forums.matronics.com//files/hd_hummer_136.jpg ________________________________________________________________________________
Date: Sep 14, 2017
Subject: videos of my area
While this video isn't from a Kolb, it is of the area around my house. I felt that you might enjoy it. Larry https://vimeo.com/233776389 password owyheeflyer -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Sep 14, 2017
Subject: Re: videos of my area
Beautiful country, Larry. Great video. Have a great day! > On Sep 14, 2017, at 9:58 AM, Larry Cottrell wrot e: > > While this video isn't from a Kolb, it is of the area around my house. I f elt that you might enjoy it. > Larry > > https://vimeo.com/233776389 password owyheeflyer > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Date: Sep 14, 2017
Thanks for another look at your part of the world. Keep them coming. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472879#472879 ________________________________________________________________________________
Date: Sep 15, 2017
Subject: Rotax 912r in oil
Anyone ever have a little white slime in there radiator overflow tank? Doesnt seem like oil. No water in oil. No oil missing. No water missing. Just this smudge of white foam left when water gets sucked back into radiator. All temps normal. Ted cowan. Slingshot 912 ul zoom zoom Sent from my iPhone . ________________________________________________________________________________
Subject: Re: Rotax 912r in oil
Date: Sep 15, 2017
Yes .. Often visible inside radiator cap and tank lip...small amount. Had it with the yellow/green mix. Same with recently installed orange mix antifreeze. Also noted that after removing heater, and changing 5 ft of 1 inch rubber hose to aluminum tube water pressure goes way down during low throttle/descent. No water loss. Bob -----Original Message----- From: Ted Cowan Sent: Friday, September 15, 2017 2:16 AM Subject: Kolb-List: Rotax 912r in oil Anyone ever have a little white slime in there radiator overflow tank? Doesnt seem like oil. No water in oil. No oil missing. No water missing. Just this smudge of white foam left when water gets sucked back into radiator. All temps normal. Ted cowan. Slingshot 912 ul zoom zoom Sent from my iPhone . ________________________________________________________________________________
Subject: Twinstar Mk3 Classic MAUW
Date: Sep 16, 2017
Hi All, I've recently bought a Mk3 Classic, but I'm confused over the max weight. I'm in the UK so it's classified as a "microlight". According to the CAA (Civil Aviation Authority) MAUW is 390Kg (860lbs), the LAA (Light Aircraft Association) who administer the type, its 405Kg (892lbs), and I've seen it on other Kolb sites as 453Kg (1000lbs). The engine is a 582 blue top. Is there a "standard" MAUW for the aircraft on your side of the pond?, or do I "play safe" and use 390Kg.? Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472918#472918 ________________________________________________________________________________
Date: Sep 16, 2017
Subject: Re: Twinstar Mk3 Classic MAUW
As the manufacturer of my Kolb MKIII I placarded my Kolb for 1,200 lbs max gross weight. I have flown my MKIII at that take off weight many times in many different wind and weather conditions over the past 25 years and 3,400.0+ hours. I feel comfortable with the limits I imposed on my aircraft and feel it has been thoroughly tested over the years and hours since the first flight. I believe Kolb Aircraft recommended 1,000.0 lbs max gross weight for the MKIII. I am not sure as I have never seen that figure on an official document. During construction of my MKIII mods were made to increase strength and durability of the aircraft. Although I placarded my MKIII at 1,200.0 lbs, I don't recommend anyone else doing that. john h mkIII Rock House, Oregon ---- normros wrote: > > Hi All, I've recently bought a Mk3 Classic, but I'm confused over the max weight. I'm in the UK so it's classified as a "microlight". According to the CAA (Civil Aviation Authority) MAUW is 390Kg (860lbs), the LAA (Light Aircraft Association) who administer the type, its 405Kg (892lbs), and I've seen it on other Kolb sites as 453Kg (1000lbs). > The engine is a 582 blue top. > Is there a "standard" MAUW for the aircraft on your side of the pond?, or do I "play safe" and use 390Kg.? > > Thanks. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472918#472918 > > > > > > > > > ________________________________________________________________________________
Date: Sep 17, 2017
Thank you for sharing, I hope to be there next year. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472950#472950 ________________________________________________________________________________
Date: Sep 17, 2017
I have to find out when this get together is going to be next year earlier so I can get the time off work to attend... -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472960#472960 ________________________________________________________________________________
Date: Sep 17, 2017
It will be the first weekend after labor day. If something should happen to change it, come on anyhow, we will have more time to fly. Larry On Sun, Sep 17, 2017 at 6:31 PM, west1m wrote: > > I have to find out when this get together is going to be next year earlier > so I can get the time off work to attend... > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472960#472960 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Fuel level calibration
Date: Sep 17, 2017
My Firefly has an EIS panel that I added. To that I have added a fuel level sender. After initial install (I may have had to cut the probe, can't remember) and calibration the EIS Shows full at 200 empty at 0. The 200 seems odd but quite usable. Recently it has lost calibration. I think it shows full at 50% and more. I haven't had time to try and recalibrate yet but my question is, with the power off etc, how does it maintain calibration? Is the calibration maintained in the sender or EIS? anyone else had trouble with this? -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472972#472972 ________________________________________________________________________________
From: "weloveflying" <yourordinarybeing(at)gmail.com>
Date: Sep 18, 2017
You sure have a nice view up there. Great share, thanks for this! :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472975#472975 ________________________________________________________________________________
Date: Sep 18, 2017
Subject: Re: Fuel level calibration
I believe I have a Princeton sender on mine. I called EIS and Sandy, who worked there at that time, told me the setting on the eis to use. Mine registers 5 gallons when full and the alarm is set to go off at 1. Nothing should change when the power is off. Its been so long ago, that of course I cannot remember the setting, so you might call them. I will try to see if I can find the documentation today. Larry On Sun, Sep 17, 2017 at 11:11 PM, west1m wrote: > > My Firefly has an EIS panel that I added. To that I have added a fuel > level sender. After initial install (I may have had to cut the probe, can't > remember) and calibration the EIS Shows full at 200 empty at 0. The 200 > seems odd but quite usable. > Recently it has lost calibration. I think it shows full at 50% and more. > I haven't had time to try and recalibrate yet but my question is, with the > power off etc, how does it maintain calibration? Is the calibration > maintained in the sender or EIS? anyone else had trouble with this? > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472972#472972 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Sep 18, 2017
Subject: Eis fuel calibration
The information is kept in both the sender and the EIS. The sender has a calibration mode so that it knows what voltage to send depending on the fuel level. The EIS has program calibration settings so it knows what to display depending on the voltage it receives They both save their information in flash ( non volitol) memory I have made a large assumption that the fuel sender is a capacitive sender,,, that assumed, there is one thing that you need to know. Ethonol free gasoline has a constant capacitive value,,, 10 percent ethonol gasoline has a capacitive value that can be twice as much. Which may be why a half tank reads full.... If I remember correctly the people who manufactures prinston fuel senders, have a solution to this issue. If switching between the two different fuels. They have a new sender with a button that quickly adjust the scale factor. When you fill the tank with a different ethonol content, you press the button, at that point it assumes that whatever it is reading is at the same level that was programed at the initial setup. If you press it when half full, it assumes that the new fuel has a different capacitive value and it sets that level to read full. if you have done this the eis will show that the level of your fuel is dropping twice as fast as normal. as you approach empty the fuel level showing and the actual fuel level become much closer to the same. so if 5 gal reads 10 .... 1 gal will read 2... .1 gal will read .2and 0 will read 0.. That is what I understood after a phone call to prinston. Boyd Young ________________________________________________________________________________
Date: Sep 18, 2017
Thanks John, I'm waiting to hear back from our LAA, but it looks like you guys can operate at a greater MAUW than we're allowed to. Ross Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472989#472989 ________________________________________________________________________________
Subject: Re: Eis fuel calibration
Date: Sep 18, 2017
I thought you might be on to something with the ethanol gas. I always fill my can at a Kwik Trip with the Ethanol free premium. A new bridge was opened in Stillwater so I went to the airport over the new bridge forcing me to buy fuel at a different station. My plane is an hour away so I could not check the tank but there was about a cup left in the bottom of the can. I checked that fuel with one of the test tube water testers and it shows no water, sooo.. I am back to guessing what changed. I will try to recalibrate when I get a day off work to get out there. If you loo close you can see Randy and his BeLite down by the bridge. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472991#472991 Attachments: http://forums.matronics.com//files/stillwater1_213.jpg ________________________________________________________________________________
Date: Sep 18, 2017
Just a heads-up; same principle applies if you ever fuel with avgas; capacitance changes. (Unfortunately, I've forgotten which direction...) Charlie On Mon, Sep 18, 2017 at 12:59 PM, west1m wrote: > > I thought you might be on to something with the ethanol gas. I always fill > my can at a Kwik Trip with the Ethanol free premium. A new bridge was > opened in Stillwater so I went to the airport over the new bridge forcing > me to buy fuel at a different station. My plane is an hour away so I could > not check the tank but there was about a cup left in the bottom of the can. > I checked that fuel with one of the test tube water testers and it shows no > water, sooo.. I am back to guessing what changed. I will try to recalibrate > when I get a day off work to get out there. > If you loo close you can see Randy and his BeLite down by the bridge. > > -------- > West1m > Hastings, MN > ________________________________________________________________________________
Subject: First flight for a noob
Date: Sep 19, 2017
GCY had a Fly-In last Saturday, David & I flew down. After lunch, an obvious photographer type was taking pictures and asking questions, and you know how it is when your spider-sense tingles? I knew I had a live one... "Would you like to go for a ride?" I said. Instantly, a dozen emotions flew across her face. "I DON"T KNOW!" she replied, obviously terrified. It turned out great. The thermals all took a break for the 20 minutes we flew around the airport, and while not my best landing, it was far from my worst. Which she commented on; "That was not nearly as violent as I was expecting." she said. To which I replied "Yeah, we ought to still be able to use the airplane again." I think she missed what I was trying to say. Anyway, it was a great day, and later, on the way home, the variometer was bouncing between 1600 up and 900 down - she probably wouldn't have liked that ride nearly as much... http://www.greenevillesun.com/news/local_news/fly-in-at-greeneville-greene-county-municipal-airport-drew-all/article_e335f754-7d75-58ab-a0d2-a121b916b761.html -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473016#473016 ________________________________________________________________________________
Subject: Re: First flight for a noob
Date: Sep 20, 2017
Good job Richard. Did you take the 'fly' down or the mk III? -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473028#473028 ________________________________________________________________________________
Date: Sep 20, 2017
I took the MKIII, it's in the article, that was how I was able to give her a ride. David took the AirCam. The Firefly is getting better but I still want to do some more work on the muffler brackets. Also, David was trying to start it last week and the starter rope broke. Whatever kind of rope I put in it was obviously not very good. He was going to go by a boat shop and see if he could find some of the good stuff. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473030#473030 ________________________________________________________________________________
Date: Sep 22, 2017
Official MAUW is 390Kg (860lbs) in the U.K. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473057#473057 ________________________________________________________________________________
Date: Sep 22, 2017
Gracious: With full fuel, I'd barely be able to take my granddaughter. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473058#473058 ________________________________________________________________________________
Subject: Re: Advise on radio and headset
Date: Sep 22, 2017
Hi John Do you use anything other than the stock antenna that came with your Icom? Thx Mike -------- 2007 Firestar 2 503 N203SD Moster 185 Flattop PPG/Sky K2 Paraglider Trike Buggy Soaring Trike & Northwing Stratus XP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473070#473070 ________________________________________________________________________________
Date: Sep 22, 2017
I use a 21" ELT antenna, may be a 24". Can't remember for sure. About 6' of coax cable trimmed for best SWR. The ICOM A6 is also very effective using the rubber ducky antenna. I carry it in the aircraft in case I would have to use the radio outside the aircraft. I have had good luck with ICOM handheld radios. john h mkIII Rock House, Oregon ---- Mcabbage wrote: > > Hi John > Do you use anything other than the stock antenna that came with your Icom? > Thx Mike > > -------- > 2007 Firestar 2 503 N203SD > Moster 185 Flattop PPG/Sky K2 Paraglider > Trike Buggy Soaring Trike & Northwing Stratus XP > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473070#473070 > > > > > > > > > ________________________________________________________________________________
Date: Sep 22, 2017
Thank you John. -------- 2007 Firestar 2 503 N203SD Moster 185 Flattop PPG/Sky K2 Paraglider Trike Buggy Soaring Trike & Northwing Stratus XP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473077#473077 ________________________________________________________________________________
Date: Sep 22, 2017
I believe the correct length for aircraft is 23.5 inches. Larry On Fri, Sep 22, 2017 at 1:52 PM, wrote: > > I use a 21" ELT antenna, may be a 24". Can't remember for sure. > > About 6' of coax cable trimmed for best SWR. > > The ICOM A6 is also very effective using the rubber ducky antenna. I > carry it in the aircraft in case I would have to use the radio outside the > aircraft. > > I have had good luck with ICOM handheld radios. > > john h > mkIII > Rock House, Oregon > > > ---- Mcabbage wrote: > > > > Hi John > > Do you use anything other than the stock antenna that came with your > Icom? > > Thx Mike > > > > -------- > > 2007 Firestar 2 503 N203SD > > Moster 185 Flattop PPG/Sky K2 Paraglider > > Trike Buggy Soaring Trike & Northwing Stratus XP > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=473070#473070 > > > > > > > > > > > > > > > > > > > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Sep 22, 2017
I believe the correct length for aircraft is 23.5 inches. That should give you the best swr match. Larry On Fri, Sep 22, 2017 at 1:52 PM, wrote: > > I use a 21" ELT antenna, may be a 24". Can't remember for sure. > > About 6' of coax cable trimmed for best SWR. > > The ICOM A6 is also very effective using the rubber ducky antenna. I > carry it in the aircraft in case I would have to use the radio outside the > aircraft. > > I have had good luck with ICOM handheld radios. > > john h > mkIII > Rock House, Oregon > > > ---- Mcabbage wrote: > > > > Hi John > > Do you use anything other than the stock antenna that came with your > Icom? > > Thx Mike > > > > -------- > > 2007 Firestar 2 503 N203SD > > Moster 185 Flattop PPG/Sky K2 Paraglider > > Trike Buggy Soaring Trike & Northwing Stratus XP > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=473070#473070 > > > > > > > > > > > > > > > > > > > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Sep 22, 2017
Thank you Larry. Is it best to keep the antenna as far away from the engine as possible? I think I remember reading that somewhere. Does it matter? -------- 2007 Firestar 2 503 N203SD Moster 185 Flattop PPG/Sky K2 Paraglider Trike Buggy Soaring Trike & Northwing Stratus XP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473082#473082 ________________________________________________________________________________
Date: Sep 22, 2017
I think most of us put them on the bottom of the cage, using the frame work to enable us to put in a ground plane to secure it to. Larry On Fri, Sep 22, 2017 at 3:58 PM, Mcabbage wrote: > > Thank you Larry. > > Is it best to keep the antenna as far away from the engine as possible? I > think I remember reading that somewhere. > Does it matter? > > -------- > 2007 Firestar 2 503 N203SD > Moster 185 Flattop PPG/Sky K2 Paraglider > Trike Buggy Soaring Trike & Northwing Stratus XP > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473082#473082 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Sep 22, 2017
Ok I remember seeing a post about that a while back. Will do a search. There was one on my plane before I stripped it of everything to sandblast the frame. I also have pics I took too. Thanks Mike -------- 2007 Firestar 2 503 N203SD Moster 185 Flattop PPG/Sky K2 Paraglider Trike Buggy Soaring Trike & Northwing Stratus XP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473084#473084 ________________________________________________________________________________
Date: Sep 22, 2017
There's a good article describing how to calculate length in a recent issue of Kitplanes. There are several 'correction factors' that should be applied (that shorten the length) after doing the speed of light/wavelength thing. IIRC, final answer for middle of the a/c comm band was closer to 21" BTW, if you're not a subscriber, Kitplanes is a really good resource for DIY homebuilt owner/maintainers. The current editor is a former NASA mission controller/manager who's also built a couple of RV's, a bush plane, and a motor glider. Lots of really good techy how-to stuff in addition to the 'feature' pieces. I've been doing pretty much everything mechanical for over 50 years, and I still learn something from every issue. Charlie On Fri, Sep 22, 2017 at 4:10 PM, Larry Cottrell wrote: > > I believe the correct length for aircraft is 23.5 inches. That should give > you the best swr match. > > Larry > > On Fri, Sep 22, 2017 at 1:52 PM, wrote: > >> >> I use a 21" ELT antenna, may be a 24". Can't remember for sure. >> >> About 6' of coax cable trimmed for best SWR. >> >> The ICOM A6 is also very effective using the rubber ducky antenna. I >> carry it in the aircraft in case I would have to use the radio outside the >> aircraft. >> >> I have had good luck with ICOM handheld radios. >> >> john h >> mkIII >> Rock House, Oregon >> >> >> >> ---- Mcabbage wrote: >> > >> > Hi John >> > Do you use anything other than the stock antenna that came with your >> Icom? >> > Thx Mike >> > >> > -------- >> > 2007 Firestar 2 503 N203SD >> > Moster 185 Flattop PPG/Sky K2 Paraglider >> > Trike Buggy Soaring Trike & Northwing Stratus XP >> > >> > > > ________________________________________________________________________________
Date: Sep 22, 2017
Thanks Charlie will check out he magazine too! -------- 2007 Firestar 2 503 N203SD Moster 185 Flattop PPG/Sky K2 Paraglider Trike Buggy Soaring Trike & Northwing Stratus XP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473086#473086 ________________________________________________________________________________
Date: Sep 22, 2017
The location of the antenna can affect the radiation pattern. If using a whip antenna, think of a doughnut over the wire.. and the signal strength is highest were the doughnut is thickest. Very little signal strength off the end of the antenna.. it's broadside that works. Since we fly horizontally, put the whip near vertical, and in a clear area. A aluminum disk can be placed under the fabric, to help establish a ground plane if needed on fabric airplanes, or the SWR shows high. Since most of your communications will be with a tower, or another nearby plane, range isn't typically a major factor. If the signal is weak.. fly higher. That will have a more profound effect than any other factor, if the install is working. As with any remote antenna, make sure to use low loss foam core coax.. without sharp kinks, and put a SWR meter between the radio and the cable to make sure you don't have excessive standing waves (more likely caused by a short, or a bad antenna, or connector install if done by a individual). ECM, DF, and avionics repairman in Vietnam, 2nd class FCC license state side, and 2 more years avoinics, 2 years general 2-way communication, installs and bench service to component level on all. Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473088#473088 ________________________________________________________________________________
Date: Sep 22, 2017
That sounds about right. john h mkIII Rock House, Oregon ---- Larry Cottrell wrote: > I believe the correct length for aircraft is 23.5 inches. > > Larry > > On Fri, Sep 22, 2017 at 1:52 PM, wrote: > > > > > I use a 21" ELT antenna, may be a 24". Can't remember for sure. > > > > About 6' of coax cable trimmed for best SWR. > > > > The ICOM A6 is also very effective using the rubber ducky antenna. I > > carry it in the aircraft in case I would have to use the radio outside the > > aircraft. > > > > I have had good luck with ICOM handheld radios. > > > > john h > > mkIII > > Rock House, Oregon > > > > > > > > ---- Mcabbage wrote: > > > > > > Hi John > > > Do you use anything other than the stock antenna that came with your > > Icom? > > > Thx Mike > > > > > > -------- > > > 2007 Firestar 2 503 N203SD > > > Moster 185 Flattop PPG/Sky K2 Paraglider > > > Trike Buggy Soaring Trike & Northwing Stratus XP > > > > > > > > > > > > > > > Read this topic online here: > > > > > > http://forums.matronics.com/viewtopic.php?p=473070#473070 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* ________________________________________________________________________________
Date: Sep 22, 2017
Meant to answer this in my previous. My antenna is mounted under the nose cone on a 6 inch diameter aluminum sheet ground plane. The stainless steel whip has a 45 degree bend in it. john h mkIII Rock House, Oregon ---- Mcabbage wrote: > > Thank you Larry. > > Is it best to keep the antenna as far away from the engine as possible? I think I remember reading that somewhere. > Does it matter? > > -------- > 2007 Firestar 2 503 N203SD > Moster 185 Flattop PPG/Sky K2 Paraglider > Trike Buggy Soaring Trike & Northwing Stratus XP > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473082#473082 > > > > > > > > > ________________________________________________________________________________
Date: Sep 23, 2017
Subject: Zanesville Ohio fly in
Remembered that someone on the Kolblist lived near Zanesville Oh. There wil l be a couple of us flying Mark 3s into Zanesville for the fly in tomorrow Sat. 23rd=C2-Gary JindraKolb mark 3 400 hours ________________________________________________________________________________
Date: Sep 22, 2017
Thanks John that is what the previous owner had. I guess I was being lazy and thinking to use a hand held stand alone. That being said I want as good as reasonable communications as possible so its worth the time to re install. Appreciate your help! Mike -------- 2007 Firestar 2 503 N203SD Moster 185 Flattop PPG/Sky K2 Paraglider Trike Buggy Soaring Trike & Northwing Stratus XP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473092#473092 ________________________________________________________________________________
Subject: Re: Zanesville Ohio fly in
Date: Sep 22, 2017
That would be me. I will be there. What time are you flying in? -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473093#473093 ________________________________________________________________________________
Date: Sep 25, 2017
do you have any weekend pics to share.... -------- kenw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473150#473150 ________________________________________________________________________________
Date: Sep 26, 2017
sorry did not take any =C2-Gary Jindra From: kenw <worthken67(at)gmail.com> To: kolb-list(at)matronics.com Sent: Monday, September 25, 2017 2:10 PM Subject: Kolb-List: Re: Zanesville Ohio fly in do you have any weekend pics to share.... -------- kenw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473150#473150 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Major Upgrade to Airport Courtesy Cars Site-Please Read.
Date: Oct 01, 2017
If you are a user of the Airport Courtesy Cars site, I would like to inform you of a major upgrade and improvement. Effective mid December, A.C.C.'s will be fully web based, and will continue to be a secure site. Many of you over the past couple of years have asked for these improvements, the biggest user request being the site does not work on certain devices. By converting A.C.C's to a web based site, the advantage is clear, the site will now work on any device. Also, there is no possibility of bugs or crashes like an app. The information will be the same. During this transition period, it is important for you to bookmark the web address on your device so your service remains uninterrupted. For further information, click on the large red banner on the main page of the site, or here: https://www.airportcourtesycars.com/app-update.html -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473213#473213 ________________________________________________________________________________
Date: Oct 01, 2017
I finally got out to the airport to try to calibrate the Westach fuel level probe. Attempting to calibrate while in the tank by filling the tank and draining did not work. I finally took the probe out of the tank and tried to calibrate it by drying off the probe and shaking all the fuel out of the tube. It took two tries but finally worked. Reinstalled and for now all is good again. Flew to Red Wing and back refilling with 100LL in Red Wing and all is still good for now. Looks like we went a week or two early for fall colors but a fun trip anyway. http://west1m.com/September27/index.html -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473238#473238 ________________________________________________________________________________
Date: Oct 01, 2017
Fall colors are still a couple of weeks out here in northern Michigan too. I shot and posted some early fall color video earlier this month and then it warmed up and they stopped changing. My YouTube channel is : curiousgdh George H. Firestar, FS100 14GDH Mesick, Michigan gdhelton(at)gmail.com On Sun, Oct 1, 2017 at 4:16 PM west1m wrote: > > I finally got out to the airport to try to calibrate the Westach fuel > level probe. Attempting to calibrate while in the tank by filling the tank > and draining did not work. I finally took the probe out of the tank and > tried to calibrate it by drying off the probe and shaking all the fuel out > of the tube. It took two tries but finally worked. Reinstalled and for now > all is good again. > Flew to Red Wing and back refilling with 100LL in Red Wing and all is > still good for now. Looks like we went a week or two early for fall colors > but a fun trip anyway. > http://west1m.com/September27/index.html > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473238#473238 > > > -- Have a great day! ________________________________________________________________________________
Date: Oct 02, 2017
Subject: Thinking of selling 2001 FireStar II
Greetings, I own a 2001 FireStar II sitting in my garage since the airport closed down in 2014. I don't really want to sell it but without an airport to fly it out off and I need the space now for my travel trailer. How much are the FireStar II with a 503, electric starter, EIS, BRS, 3 Kuntzleman strobes with nav lights and 3 blade IVO prop going for now a days? I have been out of touch with the Kolb community for too many years but if I decide to sell it I will post it on www.barnstormers.com. Regards, Will Uribe https://youtu.be/FcJt8pkI_9U ________________________________________________________________________________
Date: Oct 02, 2017
Subject: Kolb available?
I have a friend here that is interested in a Kolb. Anyone currently have one for sale? It would be nice if it was reasonable. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: Kolb available?
Date: Oct 03, 2017
SGVhbHRoIGlzc3VlcyBhbW9uZyBvdGhlciB0aGluZ3MgZm9yY2VzIG1lIHRvIHNlbGwgbWluZS4g IEhhdmUgaGltIGNvbnRhY3QgbWUgaWYgaGXigJlzIGludGVyZXN0ZWQuDQoNCk1pa2UgV2VsY2gN CjQzNS02OTUtNzc4OA0KDQpTdC4gR2VvcmdlLCBVdGFoDQoNCg0KDQpPbiBPY3QgMiwgMjAxNywg YXQgNjowOSBQTSwgTGFycnkgQ290dHJlbGwgPGxjb3R0cmVsbDEwMjBAZ21haWwuY29tPG1haWx0 bzpsY290dHJlbGwxMDIwQGdtYWlsLmNvbT4+IHdyb3RlOg0KDQpJIGhhdmUgYSBmcmllbmQgaGVy ZSB0aGF0IGlzIGludGVyZXN0ZWQgaW4gYSBLb2xiLiBBbnlvbmUgY3VycmVudGx5IGhhdmUgb25l IGZvciBzYWxlPyBJdCB3b3VsZCBiZSBuaWNlIGlmIGl0IHdhcyByZWFzb25hYmxlLg0KTGFycnkN Cg0KLS0NClRoZSBvbGRlciBJIGdldCwgdGhlIGxlc3MgdG9sZXJhbnQgSSBhbSBvZiB0aG9zZSB3 aG8gYXJlIGludG9sZXJhbnQgb2Ygb3RoZXJzLg0KDQpJZiB5b3UgZm9yd2FyZCB0aGlzIGVtYWls LCBvciBhbnkgcGFydCBvZiBpdCwgcGxlYXNlIHJlbW92ZSBteSBlbWFpbCBhZGRyZXNzIGJlZm9y ZSBzZW5kaW5nLg0K ________________________________________________________________________________
Subject: Re: Thinking of selling 2001 FireStar II
Date: Oct 03, 2017
The one in the hangar next to me went a couple weeks ago for around $9K, it had been offered for sale all summer. It had a 582. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473285#473285 ________________________________________________________________________________
Date: Oct 03, 2017
Yes. I=99m selling my Xtra. It=99s listed on barnstormers, KOLB MARK III XTRA 912UL 80HP I can send them more information and photos. Brad Nation 505-307-7831 > On Oct 2, 2017, at 18:06 , Larry Cottrell wrote: > > I have a friend here that is interested in a Kolb. Anyone currently have one for sale? It would be nice if it was reasonable. > Larry > > -- > The older I get, the less tolerant I am of those who are intolerant of others. > > If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Oct 03, 2017
Subject: Kenda tires, anyone?
I've got a couple of brand new Kenda 4.00-6 tires that came with the project I'm restoring. Anyone need 'em? Yours for the price of USPS Priority shipping from zip 39209. No other shipping options; I don't want to make a trip to the PO or UPS to ship them. If you want them, email me direct with your shipping info, and I'll email you the shipping cost. You can send the money via paypal 'friends & family' to avoid it costing either of us any fees. Charlie ________________________________________________________________________________
Date: Oct 03, 2017
Subject: video
A friend came back over to fly to some of the areas that were too smoky during our fly-in. Visibility was great, temps were 31 this morning, and winds were up to 12 MPH. I normally don't fly in that kind of winds simply because it is too much work. I decided to go ahead in spite of the winds. It was worth it of course. https://vimeo.com/236684864 password owyheeflyer Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Oct 04, 2017
Subject: Re: video
Thank you, Larry. =C2-These videos inspire me. =C2-My Kolb is still sit ting in my carport and I am soon going to retire. =C2-Then I can get it b ack in the air. =C2-Keep them coming :) Wayne On 10/3/17 10:47:51 PM, Larry Cottrell wrote: A friend came back over to fly to some of the areas that were too smoky dur ing our fly-in. Visibility was great, temps were 31 this morning, and winds were up to 12 MPH. I normally don't fly in that kind of winds simply becau se it is too much work. I decided to go ahead in spite of the winds. It was worth it of course. https://vimeo.com/236684864 [https://vimeo.com/236684864]=C2- =C2-passw ord=C2- =C2-owyheeflyer Larry -- The older I get, the less tolerant I am of those who are intolerant of othe rs. If you forward this email, or any part of it, please remove my email addres s before sending. ________________________________________________________________________________
Date: Oct 04, 2017
That's what I paid for mine back in '14. Not bad considering just what an engine with 20 hrs. would go for.......... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473350#473350 ________________________________________________________________________________
Subject: Re: video
Date: Oct 04, 2017
Very pretty, as usual Larry. New camera? I didn't see the race track with accompanying info. I just got back from 2 wks. in SW Colorado. I would like to fly that area but I wonder how my 503 would do with the 14,000 peaks..... [Shocked] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473351#473351 ________________________________________________________________________________
Date: Oct 04, 2017
Subject: Re: video
No I am still using the Virb, I just didn't run it through the Garmin edit program. It takes almost twice as long to use and load the raw video, so I got lazy and skipped that step. The best thing to do with Mtns that high is to go around at about 100 feet. :-) Nobody can have fun at 14000 feet altitude. Larry On Wed, Oct 4, 2017 at 6:24 PM, woody wrote: > > Very pretty, as usual Larry. New camera? I didn't see the race track with > accompanying info. > I just got back from 2 wks. in SW Colorado. I would like to fly that area > but I wonder how my 503 would do with the 14,000 peaks..... [Shocked] > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473351#473351 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: video
Date: Oct 04, 2017
Thanks for another great flight! Good to see the smoke has left the area. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473355#473355 ________________________________________________________________________________
Subject: Re: video
Date: Oct 05, 2017
I wonder how my 503 would do with the 14,000 peaks..... I got to 13,200 near Telluride in my Firestar with a 503. With lower altitu de jetting so running very rich, so could have done better with proper tuni ng.... Still climbing slowly but me too cold to continue.... JG --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 05, 2017
Subject: wing center gap seal
I need to add the center gap seal to the (1st gen) Twinstar I'm restoring. The project came with a new, uninstalled, fabric seal with a zipper down the middle. I've already recovered and painted (latex house paint) the wings, & failed to mask off any fabric to attach the seal. Looking at the way the seal is made, it appears to wrap around the motor mount at the top rear, and wrap around the leading edge tubes in front and extend back almost to the wing attach/pivot points on the bottom. After a quick look around the interwebs, it would appear that several different other methods have been employed over the years, including a plexi seal offered by Kolb. I also remember comments about using aluminum. So, my questions: How far back must the seal extend on top? Is it worth the trouble to run it back past the front of the motor mount? What about under the leading edge? Does it help to carry it all the way to the wing attach points, or can it simply wrap around the leading edge tubes? For attachment, should it be velcro'd to each wing along its entire length, or is it adequate to simply wrap it around the wing with attachments at the rear and under the leading edge (or at the wing attach)? Thanks for your insight, Charlie ________________________________________________________________________________
Subject: Re: wing center gap seal
Date: Oct 05, 2017
On 10/5/2017 8:56 AM, Charlie England wrote: > I need to add the center gap seal to the (1st gen) Twinstar I'm > restoring. The project came with a new, uninstalled, fabric seal with > a zipper down the middle. I've already recovered and painted (latex > house paint) the wings, & failed to mask off any fabric to attach the > seal. > > Looking at the way the seal is made, it appears to wrap around the > motor mount at the top rear, and wrap around the leading edge tubes in > front and extend back almost to the wing attach/pivot points on the > bottom. > > After a quick look around the interwebs, it would appear that several > different other methods have been employed over the years, including a > plexi seal offered by Kolb. I also remember comments about using > aluminum. > > So, my questions: > How far back must the seal extend on top? Is it worth the trouble to > run it back past the front of the motor mount? What about under the > leading edge? Does it help to carry it all the way to the wing attach > points, or can it simply wrap around the leading edge tubes? > > For attachment, should it be velcro'd to each wing along its entire > length, or is it adequate to simply wrap it around the wing with > attachments at the rear and under the leading edge (or at the wing > attach)? > > Thanks for your insight, > > Charlie And, I forgot to ask; which material gets your vote? --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 05, 2017
I have always used the lexan gap seal and attempted to cover and block as much of the gap area that I can. MIne has a section of alum. bent to go over the leading edge tubes. I use a small bungee cord to keep it up tight against the tubes. the sides are secured to the wings with velcro. Most of the Mark III's make up a "hard" section that slides in between the wings that consists of a couple of ribs that the lexan is secured to. The installation of the HKS presented a problem because of the location of the muffler. Larry On Thu, Oct 5, 2017 at 7:56 AM, Charlie England wrote: > I need to add the center gap seal to the (1st gen) Twinstar I'm restoring. > The project came with a new, uninstalled, fabric seal with a zipper down > the middle. I've already recovered and painted (latex house paint) the > wings, & failed to mask off any fabric to attach the seal. > > Looking at the way the seal is made, it appears to wrap around the motor > mount at the top rear, and wrap around the leading edge tubes in front and > extend back almost to the wing attach/pivot points on the bottom. > > After a quick look around the interwebs, it would appear that several > different other methods have been employed over the years, including a > plexi seal offered by Kolb. I also remember comments about using aluminum. > > So, my questions: > How far back must the seal extend on top? Is it worth the trouble to run > it back past the front of the motor mount? What about under the leading > edge? Does it help to carry it all the way to the wing attach points, or > can it simply wrap around the leading edge tubes? > > For attachment, should it be velcro'd to each wing along its entire > length, or is it adequate to simply wrap it around the wing with > attachments at the rear and under the leading edge (or at the wing attach)? > > Thanks for your insight, > > Charlie > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Oct 06, 2017
I restored my original Firestar earlier this year which originally used the zipper in the middle type gap seal. I talked to Brian at Kolb and he assured me that their new Velcro on gap would work just fine. I took his advice and had Helen at Kolb make me one . It was extremely easy to install and works great. I also built a Twinstar many year ago. This new one would have great on it. That just my experience, I like easy and availability. I=99ll attach a picture George H. Firestar FS 100 14GDH Mesick, Michigan gdhelton(at)gmail.com On Thu, Oct 5, 2017 at 11:41 AM Larry Cottrell wrote: > I have always used the lexan gap seal and attempted to cover and block as > much of the gap area that I can. MIne has a section of alum. bent to go > over the leading edge tubes. I use a small bungee cord to keep it up tigh t > against the tubes. the sides are secured to the wings with velcro. Most o f > the Mark III's make up a "hard" section that slides in between the wings > that consists of a couple of ribs that the lexan is secured to. > > The installation of the HKS presented a problem because of the location o f > the muffler. > > Larry > > On Thu, Oct 5, 2017 at 7:56 AM, Charlie England > wrote: > >> I need to add the center gap seal to the (1st gen) Twinstar I'm >> restoring. The project came with a new, uninstalled, fabric seal with a >> zipper down the middle. I've already recovered and painted (latex house >> paint) the wings, & failed to mask off any fabric to attach the seal. >> >> Looking at the way the seal is made, it appears to wrap around the motor >> mount at the top rear, and wrap around the leading edge tubes in front a nd >> extend back almost to the wing attach/pivot points on the bottom. >> >> After a quick look around the interwebs, it would appear that several >> different other methods have been employed over the years, including a >> plexi seal offered by Kolb. I also remember comments about using aluminu m. >> >> So, my questions: >> How far back must the seal extend on top? Is it worth the trouble to run >> it back past the front of the motor mount? What about under the leading >> edge? Does it help to carry it all the way to the wing attach points, or >> can it simply wrap around the leading edge tubes? >> >> For attachment, should it be velcro'd to each wing along its entire >> length, or is it adequate to simply wrap it around the wing with >> attachments at the rear and under the leading edge (or at the wing attac h)? >> >> Thanks for your insight, >> >> Charlie >> > > > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > -- Have a great day! ________________________________________________________________________________
Date: Oct 05, 2017
Well shucks; more to contemplate. :-) Looks like either option requires velcro, so I'll get a roll of wide stuff on order while I contemplate materials. Thank you for the pic, and the ideas. Charlie On 10/5/2017 7:37 PM, George Helton wrote: > I restored my original Firestar earlier this year which originally > used the zipper in the middle type gap seal. I talked to Brian at Kolb > and he assured me that their new Velcro on gap would work just fine. I > took his advice and had Helen at Kolb make me one . It was extremely > easy to install and works great. I also built a Twinstar many year > ago. This new one would have great on it. That just my experience, I > like easy and availability. Ill attach a picture > George H. > Firestar FS 100 > 14GDH > Mesick, Michigan > gdhelton(at)gmail.com > > > > On Thu, Oct 5, 2017 at 11:41 AM Larry Cottrell > > wrote: > > I have always used the lexan gap seal and attempted to cover and > block as much of the gap area that I can. MIne has a section of > alum. bent to go over the leading edge tubes. I use a small bungee > cord to keep it up tight against the tubes. the sides are secured > to the wings with velcro. Most of the Mark III's make up a "hard" > section that slides in between the wings that consists of a couple > of ribs that the lexan is secured to. > > The installation of the HKS presented a problem because of the > location of the muffler. > > Larry > > On Thu, Oct 5, 2017 at 7:56 AM, Charlie England > > wrote: > > I need to add the center gap seal to the (1st gen) Twinstar > I'm restoring. The project came with a new, uninstalled, > fabric seal with a zipper down the middle. I've already > recovered and painted (latex house paint) the wings, & failed > to mask off any fabric to attach the seal. > > Looking at the way the seal is made, it appears to wrap around > the motor mount at the top rear, and wrap around the leading > edge tubes in front and extend back almost to the wing > attach/pivot points on the bottom. > > After a quick look around the interwebs, it would appear that > several different other methods have been employed over the > years, including a plexi seal offered by Kolb. I also remember > comments about using aluminum. > > So, my questions: > How far back must the seal extend on top? Is it worth the > trouble to run it back past the front of the motor mount? What > about under the leading edge? Does it help to carry it all the > way to the wing attach points, or can it simply wrap around > the leading edge tubes? > > For attachment, should it be velcro'd to each wing along its > entire length, or is it adequate to simply wrap it around the > wing with attachments at the rear and under the leading edge > (or at the wing attach)? > > Thanks for your insight, > > Charlie > > > -- > /The older I get, the less tolerant I am of those who are > intolerant of others./ > / > / > /If you forward this email, or any part of it, please remove my > email address before sending./ > > -- > Have a great day! --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 05, 2017
The one inch will be plenty. When you get ready to take which ever gap seal you decide on, get yourself a couple strips of Lexan and slip it between the two halves, and it comes off nice and easy. Larry On Thu, Oct 5, 2017 at 8:12 PM, Charlie England wrote: > Well shucks; more to contemplate. :-) > > Looks like either option requires velcro, so I'll get a roll of wide > stuff on order while I contemplate materials. > > Thank you for the pic, and the ideas. > > Charlie > > On 10/5/2017 7:37 PM, George Helton wrote: > > I restored my original Firestar earlier this year which originally used > the zipper in the middle type gap seal. I talked to Brian at Kolb and he > assured me that their new Velcro on gap would work just fine. I took his > advice and had Helen at Kolb make me one . It was extremely easy to insta ll > and works great. I also built a Twinstar many year ago. This new one woul d > have great on it. That just my experience, I like easy and availability. > I=99ll attach a picture > George H. > Firestar FS 100 > 14GDH > Mesick, Michigan > gdhelton(at)gmail.com > > > On Thu, Oct 5, 2017 at 11:41 AM Larry Cottrell > wrote: > >> I have always used the lexan gap seal and attempted to cover and block a s >> much of the gap area that I can. MIne has a section of alum. bent to go >> over the leading edge tubes. I use a small bungee cord to keep it up tig ht >> against the tubes. the sides are secured to the wings with velcro. Most of >> the Mark III's make up a "hard" section that slides in between the wings >> that consists of a couple of ribs that the lexan is secured to. >> >> The installation of the HKS presented a problem because of the location >> of the muffler. >> >> Larry >> >> On Thu, Oct 5, 2017 at 7:56 AM, Charlie England >> wrote: >> >>> I need to add the center gap seal to the (1st gen) Twinstar I'm >>> restoring. The project came with a new, uninstalled, fabric seal with a >>> zipper down the middle. I've already recovered and painted (latex house >>> paint) the wings, & failed to mask off any fabric to attach the seal. >>> >>> Looking at the way the seal is made, it appears to wrap around the moto r >>> mount at the top rear, and wrap around the leading edge tubes in front and >>> extend back almost to the wing attach/pivot points on the bottom. >>> >>> After a quick look around the interwebs, it would appear that several >>> different other methods have been employed over the years, including a >>> plexi seal offered by Kolb. I also remember comments about using alumin um. >>> >>> So, my questions: >>> How far back must the seal extend on top? Is it worth the trouble to ru n >>> it back past the front of the motor mount? What about under the leading >>> edge? Does it help to carry it all the way to the wing attach points, o r >>> can it simply wrap around the leading edge tubes? >>> >>> For attachment, should it be velcro'd to each wing along its entire >>> length, or is it adequate to simply wrap it around the wing with >>> attachments at the rear and under the leading edge (or at the wing atta ch)? >>> >>> Thanks for your insight, >>> >>> Charlie >>> >> >> >> >> -- >> *The older I get, the less tolerant I am of those who are intolerant of >> others.* >> >> *If you forward this email, or any part of it, please remove my email >> address before sending.* >> > -- > Have a great day! > > > Virus-free . > www.avast.com > > <#m_-7813683466236448516_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Oct 05, 2017
Great! one inch is easier to get, cheaper, etc. I like the separator idea, too. Charlie On 10/5/2017 9:25 PM, Larry Cottrell wrote: > The one inch will be plenty. When you get ready to take which ever gap > seal you decide on, get yourself a couple strips of Lexan and slip it > between the two halves, and it comes off nice and easy. > > Larry > > > On Thu, Oct 5, 2017 at 8:12 PM, Charlie England > wrote: > > Well shucks; more to contemplate. :-) > > Looks like either option requires velcro, so I'll get a roll of > wide stuff on order while I contemplate materials. > > Thank you for the pic, and the ideas. > > Charlie > > On 10/5/2017 7:37 PM, George Helton wrote: >> I restored my original Firestar earlier this year which >> originally used the zipper in the middle type gap seal. I talked >> to Brian at Kolb and he assured me that their new Velcro on gap >> would work just fine. I took his advice and had Helen at Kolb >> make me one . It was extremely easy to install and works great. I >> also built a Twinstar many year ago. This new one would have >> great on it. That just my experience, I like easy and >> availability. Ill attach a picture >> George H. >> Firestar FS 100 >> 14GDH >> Mesick, Michigan >> gdhelton(at)gmail.com >> >> >> >> On Thu, Oct 5, 2017 at 11:41 AM Larry Cottrell >> > wrote: >> >> I have always used the lexan gap seal and attempted to cover >> and block as much of the gap area that I can. MIne has a >> section of alum. bent to go over the leading edge tubes. I >> use a small bungee cord to keep it up tight against the >> tubes. the sides are secured to the wings with velcro. Most >> of the Mark III's make up a "hard" section that slides in >> between the wings that consists of a couple of ribs that the >> lexan is secured to. >> >> The installation of the HKS presented a problem because of >> the location of the muffler. >> >> Larry >> >> On Thu, Oct 5, 2017 at 7:56 AM, Charlie England >> > wrote: >> >> I need to add the center gap seal to the (1st gen) >> Twinstar I'm restoring. The project came with a new, >> uninstalled, fabric seal with a zipper down the middle. >> I've already recovered and painted (latex house paint) >> the wings, & failed to mask off any fabric to attach the >> seal. >> >> Looking at the way the seal is made, it appears to wrap >> around the motor mount at the top rear, and wrap around >> the leading edge tubes in front and extend back almost to >> the wing attach/pivot points on the bottom. >> >> After a quick look around the interwebs, it would appear >> that several different other methods have been employed >> over the years, including a plexi seal offered by Kolb. I >> also remember comments about using aluminum. >> >> So, my questions: >> How far back must the seal extend on top? Is it worth the >> trouble to run it back past the front of the motor mount? >> What about under the leading edge? Does it help to carry >> it all the way to the wing attach points, or can it >> simply wrap around the leading edge tubes? >> >> For attachment, should it be velcro'd to each wing along >> its entire length, or is it adequate to simply wrap it >> around the wing with attachments at the rear and under >> the leading edge (or at the wing attach)? >> >> Thanks for your insight, >> >> Charlie >> >> >> >> >> -- >> /The older I get, the less tolerant I am of those who are >> intolerant of others./ >> / >> / >> /If you forward this email, or any part of it, please remove >> my email address before sending./ >> >> -- >> Have a great day! > > > > Virus-free. www.avast.com > > > > <#m_-7813683466236448516_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > > > -- > /The older I get, the less tolerant I am of those who are intolerant > of others./ > / > / > /If you forward this email, or any part of it, please remove my email > address before sending./ --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 06, 2017
I went back to an aluminium gap seal after my cloth one shred it self. You can kind of see it coming apart in this screen grab form a video. It was made of the same fabric as Quicksilver sail cloth. The Lexan would be nice as well. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473392#473392 Attachments: http://forums.matronics.com//files/gapseal_195.jpg ________________________________________________________________________________
Date: Oct 05, 2017
Looks good, and relatively simple to do=2E The fabric just looks difficult to keep properly tensioned, so I think I'll try either the plastic or alumi num sheet=2E Is your Lexan standing up ok to fuel exposure? Thanks for bo th the info, and the pics=2E =81=A3Charlie=8B On Oct 5, 2017, 10 :41 AM, at 10:41 AM, Larry Cottrell wrote: >I h ave always used the lexan gap seal and attempted to cover and block >as >mu ch of the gap area that I can=2E MIne has a section of alum=2E bent to go > over the leading edge tubes=2E I use a small bungee cord to keep it up >tig ht >against the tubes=2E the sides are secured to the wings with velcro=2E Most >of >the Mark III's make up a "hard" section that slides in between th e >wings >that consists of a couple of ribs that the lexan is secured to=2E > >The installation of the HKS presented a problem because of the location >of >the muffler=2E > >Larry > >On Thu, Oct 5, 2017 at 7:56 AM, Charlie En gland >wrote: > >> I need to add the center gap se al to the (1st gen) Twinstar I'm >restoring=2E >> The project came with a n ew, uninstalled, fabric seal with a zipper >down >> the middle=2E I've alre ady recovered and painted (latex house paint) >the >> wings, & failed to ma sk off any fabric to attach the seal=2E >> >> Looking at the way the seal i s made, it appears to wrap around the >motor >> mount at the top rear, and wrap around the leading edge tubes in >front and >> extend back almost to t he wing attach/pivot points on the bottom=2E >> >> After a quick look aroun d the interwebs, it would appear that several >> different other methods ha ve been employed over the years, including >a >> plexi seal offered by Kolb =2E I also remember comments about using >aluminum=2E >> >> So, my question s: >> How far back must the seal extend on top? Is it worth the trouble to >run >> it back past the front of the motor mount? What about under the >le ading >> edge? Does it help to carry it all the way to the wing attach poin ts, >or >> can it simply wrap around the leading edge tubes? >> >> For atta chment, should it be velcro'd to each wing along its entire >> length, or i s it adequate to simply wrap it around the wing with >> attachments at the rear and under the leading edge (or at the wing >attach)? >> >> Thanks for your insight, >> >> Charlie >> > > >-- >*The older I get, the less toler ant I am of those who are intolerant of >others=2E* > >*If you forward this email, or any part of it, please remove my email >address before sending =2E* ________________________________________________________________________________
Date: Oct 06, 2017
If you get gas on it, it will be ugly. There is compensation in that my neck is so stiff that I can't see it when I am sitting down and I am old enough to forget that there is a problem quite soon after sitting. Larry On Thu, Oct 5, 2017 at 1:15 PM, Charlie England wrote: > Looks good, and relatively simple to do. The fabric just looks difficult > to keep properly tensioned, so I think I'll try either the plastic or > aluminum sheet. > > Is your Lexan standing up ok to fuel exposure? > > Thanks for both the info, and the pics. > > Charlie > On Oct 5, 2017, at 10:41 AM, Larry Cottrell > wrote: >> >> I have always used the lexan gap seal and attempted to cover and block as >> much of the gap area that I can. MIne has a section of alum. bent to go >> over the leading edge tubes. I use a small bungee cord to keep it up tight >> against the tubes. the sides are secured to the wings with velcro. Most of >> the Mark III's make up a "hard" section that slides in between the wings >> that consists of a couple of ribs that the lexan is secured to. >> >> The installation of the HKS presented a problem because of the location >> of the muffler. >> >> Larry >> >> On Thu, Oct 5, 2017 at 7:56 AM, Charlie England >> wrote: >> >>> I need to add the center gap seal to the (1st gen) Twinstar I'm >>> restoring. The project came with a new, uninstalled, fabric seal with a >>> zipper down the middle. I've already recovered and painted (latex house >>> paint) the wings, & failed to mask off any fabric to attach the seal. >>> >>> Looking at the way the seal is made, it appears to wrap around the motor >>> mount at the top rear, and wrap around the leading edge tubes in front and >>> extend back almost to the wing attach/pivot points on the bottom. >>> >>> After a quick look around the interwebs, it would appear that several >>> different other methods have been employed over the years, including a >>> plexi seal offered by Kolb. I also remember comments about using aluminum. >>> >>> So, my questions: >>> How far back must the seal extend on top? Is it worth the trouble to run >>> it back past the front of the motor mount? What about under the leading >>> edge? Does it help to carry it all the way to the wing attach points, or >>> can it simply wrap around the leading edge tubes? >>> >>> For attachment, should it be velcro'd to each wing along its entire >>> length, or is it adequate to simply wrap it around the wing with >>> attachments at the rear and under the leading edge (or at the wing attach)? >>> >>> Thanks for your insight, >>> >>> Charlie >>> >> >> >> >> -- >> *The older I get, the less tolerant I am of those who are intolerant of >> others.* >> >> *If you forward this email, or any part of it, please remove my email >> address before sending.* >> > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Oct 06, 2017
I hear you=2E Sometimes my wife has to remind me about what I'm working on =2E =81=A3Charlie=8B On Oct 6, 2017, 3:04 PM, at 3:04 PM, Larry Cottrell wrote: >If you get gas on it, it will be ugly=2E There is compensation in that my >neck is so stiff that I can't see it when I am sitting down and I am >old >enough to forget that there is a problem quite soon after sitting=2E >Larry > >On Thu, Oct 5, 2017 at 1:1 5 PM, Charlie England >wrote: > >> Looks good, and relatively simple to do=2E The fabric just looks >difficult >> to keep pro perly tensioned, so I think I'll try either the plastic or >> aluminum shee t=2E >> >> Is your Lexan standing up ok to fuel exposure? >> >> Thanks for both the info, and the pics=2E >> >> Charlie >> On Oct 5, 2017, at 10:41 AM , Larry Cottrell >> wrote: >>> >>> I have alway s used the lexan gap seal and attempted to cover and >block as >>> much of the gap area that I can=2E MIne has a section of alum=2E bent to >go >>> ov er the leading edge tubes=2E I use a small bungee cord to keep it up >tight >>> against the tubes=2E the sides are secured to the wings with velcro=2E >Most of >>> the Mark III's make up a "hard" section that slides in betwee n the >wings >>> that consists of a couple of ribs that the lexan is secure d to=2E >>> >>> The installation of the HKS presented a problem because of the >location >>> of the muffler=2E >>> >>> Larry >>> >>> On Thu, Oct 5, 20 17 at 7:56 AM, Charlie England > >>> wrote: >>> >>> > I need to add the center gap seal to the (1st gen) Twinstar I'm >>>> rest oring=2E The project came with a new, uninstalled, fabric seal >with a >>>> zipper down the middle=2E I've already recovered and painted (latex >house >>>> paint) the wings, & failed to mask off any fabric to attach the >seal =2E >>>> >>>> Looking at the way the seal is made, it appears to wrap aroun d the >motor >>>> mount at the top rear, and wrap around the leading edge t ubes in >front and >>>> extend back almost to the wing attach/pivot points on the bottom=2E >>>> >>>> After a quick look around the interwebs, it woul d appear that >several >>>> different other methods have been employed over the years, >including a >>>> plexi seal offered by Kolb=2E I also remember comments about using >aluminum=2E >>>> >>>> So, my questions: >>>> How far back must the seal extend on top? Is it worth the trouble >to run >>>> it back past the front of the motor mount? What about under the >leading >>>> edge? Does it help to carry it all the way to the wing attach >points, or > >>> can it simply wrap around the leading edge tubes? >>>> >>>> For attachm ent, should it be velcro'd to each wing along its entire >>>> length, or is it adequate to simply wrap it around the wing with >>>> attachments at the rear and under the leading edge (or at the wing >attach)? >>>> >>>> Thanks for your insight, >>>> >>>> Charlie >>>> >>> >>> >>> >>> -- >>> *The older I get, the less tolerant I am of those who are intolerant >of >>> others =2E* >>> >>> *If you forward this email, or any part of it, please remove m y >email >>> address before sending=2E* >>> >> > > >-- >*The older I get, the less tolerant I am of those who are intolerant of >others=2E* > >*If yo u forward this email, or any part of it, please remove my email >address be fore sending=2E* ________________________________________________________________________________
Subject: Slobovia Outernational Pumpkin Drop (yes, it's real)
Date: Oct 07, 2017
A few families here at my home field are hosting our annual Pumpkin Drop on Nov 4 (1st Saturday in November, as always). For any Kolbers close enough to fly (or drive), this is your O-fficial Invite. This is a private party, but you, and your (non-criminal) friends are welcome. :-) Slobovia Outernational (MS71) is about 10 miles north of Jackson MS, just off US Highway 49. You can find us on the Memphis Sectional. If you want to see what it's like, there are a few videos from prior years on youtube. This is very much a family event; we try to get as many kids into planes as we possibly can during the course of the day. Planes usually start arriving around 10:00 AM. We'll be serving Jambalaya at noon (for you LA residents: don't worry; the cooks are LA residents), and we'll start the Pumpkin Bombing competition at 1:30. Come on down & show the big iron how to hit a target from a plane. You must attend the briefing to drop pumpkins, and please bring your own ordinance. You're welcome to camp on the field, if you need to remain overnight. Please see the attached flyer for airport & contact info. If you're driving, Google Maps puts us in the right spot. However, many car GPSs and other mapping software may not. If there's any doubt, don't hesitate to call or email me; my contact info is on the flyer. I hope those of you that are in striking distance can come on up. I'd love to meet in person some of the folks that have helped me out with Kolb info. I'll be the ugly one with the harried look on his face on the red Kawasaki Mule, parking planes. Charlie (1st gen Twinstar almost ready to fly!) --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 08, 2017
Subject: Re: Slobovia Outernational Pumpkin Drop (yes, it's real)
If I am back to hauck's holler and Gantt International Airport by then I'll do my best to make it. john h Pahrump, Nevada ---- Charlie England wrote: > A few families here at my home field are hosting our annual Pumpkin Drop > on Nov 4 (1st Saturday in November, as always). For any Kolbers close > enough to fly (or drive), this is your O-fficial Invite. This is a > private party, but you, and your (non-criminal) friends are welcome. :-) > > Slobovia Outernational (MS71) is about 10 miles north of Jackson MS, > just off US Highway 49. You can find us on the Memphis Sectional. > > If you want to see what it's like, there are a few videos from prior > years on youtube. This is very much a family event; we try to get as > many kids into planes as we possibly can during the course of the day. > > Planes usually start arriving around 10:00 AM. We'll be serving > Jambalaya at noon (for you LA residents: don't worry; the cooks are LA > residents), and we'll start the Pumpkin Bombing competition at 1:30. > Come on down & show the big iron how to hit a target from a plane. You > must attend the briefing to drop pumpkins, and please bring your own > ordinance. You're welcome to camp on the field, if you need to remain > overnight. > > Please see the attached flyer for airport & contact info. If you're > driving, Google Maps puts us in the right spot. However, many car GPSs > and other mapping software may not. If there's any doubt, don't hesitate > to call or email me; my contact info is on the flyer. > > I hope those of you that are in striking distance can come on up. I'd > love to meet in person some of the folks that have helped me out with > Kolb info. I'll be the ugly one with the harried look on his face on the > red Kawasaki Mule, parking planes. > > Charlie > (1st gen Twinstar almost ready to fly!) > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 08, 2017
Subject: CDI conversion
Date: Oct 10, 2017
I don't suppose anyone has CDI parts to convert my 447 to CDI laying around the garage gathering dust? -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473448#473448 ________________________________________________________________________________
Date: Oct 11, 2017
Subject: Re: CDI conversion
Visit a snowmobile salvage yard and buy a junk 377 or447 and use the flywheel Brain box and stator plate plus the part that fits on the shaft , shouldn=99t, cost an arm and a leg ! roy On Tuesday, October 10, 2017, west1m wrote: > > > > I don't suppose anyone has CDI parts to convert my 447 to CDI laying > around the garage gathering dust? > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473448#473448 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Subject: New FS II flyer has Questions
Date: Oct 15, 2017
Hi everyone I'm new to the matronics so a big thank you to the administrator for the nod. I'm soon to fly my 270hr FSII that I've spent the last 11/2 yr going thru replacing fuel lines, fuel tanks, all rubber and misc items you'd expect to need on an plane sitting for 10yrs. I'm now at the point of flying it after getting my flight review in a 46 Champ to get me ready. My question is ... What's everyone using for airspeeds? What kind of surprises shoulld I expect? VNE = 90mph VA = ??? VY = ??? VX = ??? real life Stall speeds The printed info I had says it stalls at 33mph ..rotate at 40mph and use 45 for approach. Thanks for any help...Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473572#473572 ________________________________________________________________________________
Date: Oct 15, 2017
Subject: Re: New FS II flyer has Questions
I made my first flight in my new Kolb Ultrastar 33 years ago this past July. I was a helicopter pilot, not a fixed wing pilot. Actually, I was a rusty helicopter pilot, hadn't flown in 8 years. I read a lot of stick and rudder books to get up to speed on being an airplane pilot. I paid special attention to Homer Kolb's comments about test flying his new Ultrastar. "Take it up to 1000 feet above the ground and check the stall speed." Now you are good to go. You know when the aircraft is going to quit flying, unless you get yourself into an accelerated stall, which is damn near impossible to do in a Kolb. Stalls were my biggest worry coming from a rotary wing world where we didn't pay a whole lot of attention to that terminology. As far as the other "V" speeds, I didn't worry about them much except "maneuver" and VNE. Maneuver speed was anything slow enough to be comfortable in rough air. VNE wasn't a big problem either, but I tried to stay below whatever happened to be the "popular" VNE for whatever Kolb model I was flying. Stall speed is critical. High speeds and rough air don't mix. john h mkIII Palm Desert, California ---- RoHam wrote: > > Hi everyone I'm new to the matronics so a big thank you to the administrator for the nod. > I'm soon to fly my 270hr FSII that I've spent the last 11/2 yr going thru replacing fuel lines, fuel tanks, all rubber and misc items you'd expect to need on an plane sitting for 10yrs. I'm now at the point of flying it after getting my flight review in a 46 Champ to get me ready. > My question is ... What's everyone using for airspeeds? What kind of surprises shoulld I expect? > VNE = 90mph > VA = ??? > VY = ??? > VX = ??? > real life Stall speeds > The printed info I had says it stalls at 33mph ..rotate at 40mph and use 45 for approach. > Thanks for any help...Bob > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473572#473572 > > > > > > > > > ________________________________________________________________________________
Date: Oct 15, 2017
only reliable info for lower speed questions is actual experience in your airplane .take it up and at safe altitude,slow it down until you see what your indicator reads when it stalls > On Oct 15, 2017, at 9:36 AM, RoHam wrote: > > > Hi everyone I'm new to the matronics so a big thank you to the administrator for the nod. > I'm soon to fly my 270hr FSII that I've spent the last 11/2 yr going thru replacing fuel lines, fuel tanks, all rubber and misc items you'd expect to need on an plane sitting for 10yrs. I'm now at the point of flying it after getting my flight review in a 46 Champ to get me ready. > My question is ... What's everyone using for airspeeds? What kind of surprises shoulld I expect? > VNE = 90mph > VA = ??? > VY = ??? > VX = ??? > real life Stall speeds > The printed info I had says it stalls at 33mph ..rotate at 40mph and use 45 for approach. > Thanks for any help...Bob > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473572#473572 > > > > > > > > > ________________________________________________________________________________
Date: Oct 15, 2017
congratulations on finishing your FII. The questions that you have asked has had many attempts to be answered. I am afraid that there are too many variables for a hard and fast answer. With my Firestar in its current configuration I use 50 for climb. Stall speeds can vary as much as 29- to one I flew that stalled at 60? What I am saying is that there is no hard and fast numbers for your plane other than what you yourself discover. Your best plan is to be very conservative and let your plane tell you what it likes. On your take off roll keep a bit of back stick and let it lift off by itself. Get at least a 1000 feet and see what your best climb is by pulling back on the stick. Do check and see what your ASI indicates as a stall speed. There are lots of differences in ASI instruments depending on your pitot tube placement, the difference in cabin pressure, all that influences your indicated speed. While its nice to have an ASI that reads true, the real requirement is that you know what yours reads when the plane quits flying. One of the biggest problems with a kolb is that the design means that when the power is off, it doesn't take all that long before the plane stops forward speed. It takes most people by surprise and is the main cause of bent landing gear. I suggest that you take it to altitude, pull the throttle off, give it some back stick and see how long it takes for the plane to stall. I also suggest that you maintain some power on your landings when you first start. I do my approaches at 50. My plane however stalls at 30 MPH for me. Good luck with your plane, but be very cautious until you know what your operating speeds actually are for your plane. It may fly like the Champ but it will not land like the Champ. It is designed for a totally different mission. Good luck Larry On Sun, Oct 15, 2017 at 7:36 AM, RoHam wrote: > > Hi everyone I'm new to the matronics so a big thank you to the > administrator for the nod. > I'm soon to fly my 270hr FSII that I've spent the last 11/2 yr going thru > replacing fuel lines, fuel tanks, all rubber and misc items you'd expect to > need on an plane sitting for 10yrs. I'm now at the point of flying it after > getting my flight review in a 46 Champ to get me ready. > My question is ... What's everyone using for airspeeds? What kind of > surprises shoulld I expect? > VNE = 90mph > VA = ??? > VY = ??? > VX = ??? > real life Stall speeds > The printed info I had says it stalls at 33mph ..rotate at 40mph and use > 45 for approach. > Thanks for any help...Bob > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473572#473572 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Oct 15, 2017
There's not much to add to John and Larry's comments. Make sure that you know what the stall speed is and keep it 5-10 mph above that when you bring it in. I also flopped around in a Champ before flying my Firestar II. These light aircraft run out of inertia rapidly and will go from flying to falling in 3 seconds or less. Be vigilant. Bring it in with power, 4000 rpm should give you an edge in keeping it under control. FLY IT TO THE GROUND. Do not chop the throttle and expect it to land like that "flying pig", the champ. 8) PS: If you have the aluminum gear legs on your plane, start thinking about building some steel ones. They are a lot more forgiving. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473584#473584 ________________________________________________________________________________
Date: Oct 15, 2017
If anyone wants a set of steel gear legs for the Xtra, I have a pair Id like to sell Russ K > On Oct 15, 2017, at 3:15 PM, woody wrote: > > > There's not much to add to John and Larry's comments. Make sure that you know what the stall speed is and keep it 5-10 mph above that when you bring it in. I also flopped around in a Champ before flying my Firestar II. These light aircraft run out of inertia rapidly and will go from flying to falling in 3 seconds or less. Be vigilant. Bring it in with power, 4000 rpm should give you an edge in keeping it under control. FLY IT TO THE GROUND. Do not chop the throttle and expect it to land like that "flying pig", the champ. 8) > PS: If you have the aluminum gear legs on your plane, start thinking about building some steel ones. They are a lot more forgiving. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473584#473584 > > > > > > > > > ________________________________________________________________________________
Date: Oct 15, 2017
Bob IMHO NO one should fly ANYthing until/unless he knows at least what VNE, VX, VY, and Maneuvering speed are. Go back to ground school before you crash! Who gave you a review without making sure you knew those??? > On Oct 15, 2017, at 9:36 AM, RoHam wrote: > > > Hi everyone I'm new to the matronics so a big thank you to the administrator for the nod. > I'm soon to fly my 270hr FSII that I've spent the last 11/2 yr going thru replacing fuel lines, fuel tanks, all rubber and misc items you'd expect to need on an plane sitting for 10yrs. I'm now at the point of flying it after getting my flight review in a 46 Champ to get me ready. > My question is ... What's everyone using for airspeeds? What kind of surprises shoulld I expect? > VNE = 90mph > VA = ??? > VY = ??? > VX = ??? > real life Stall speeds > The printed info I had says it stalls at 33mph ..rotate at 40mph and use 45 for approach. > Thanks for any help...Bob > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473572#473572 > > > > > > > > > ________________________________________________________________________________
Date: Oct 15, 2017
Thanks to everyone for the info. I pretty much figured it would be a trial of flying it and figuring out. I guess I was looking for some average speeds everyone was using. I understand the vx,vy &va. The question marks were looking to fill in the average speeds. Sorry for the confusion. I'll let you know how I make out. Is everyone converting to steel gear? Will the original aluminum hold up to average landings? Whats the source of these gear? I found a good source for fuel tanks if anyone needs it. Thanks again... Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473593#473593 ________________________________________________________________________________
Subject: Video all local to KCMA
Date: Oct 15, 2017
https://youtu.be/l2r161S-XXk Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473598#473598 ________________________________________________________________________________
Subject: Re: Video all local to KCMA
Date: Oct 15, 2017
My wife said you shouldn't fly low over the cows like that: it will make them stop laying eggs... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473600#473600 ________________________________________________________________________________
Date: Oct 16, 2017
Congratulations Jimmy, GREAT videos! You're having a blast... I owe you a call, will do so tomorrow. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Sun, 10/15/17, Richard Pike wrote: Subject: Kolb-List: Re: Video all local to KCMA To: kolb-list(at)matronics.com Date: Sunday, October 15, 2017, 8:55 PM Pike" My wife said you shouldn't fly low over the cows like that: it will make them stop laying eggs... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473600#473600 The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 11 Msgs - 10/15/17
Date: Oct 16, 2017
Bob For your first flights I highly recommend flying off grass or gravel the first few times, much more forgiving. Also 50 is nifty And fly it all the way to the ground, just roll it on Mike Seattle Cell 206-963-2118 > On Oct 16, 2017, at 12:03 AM, Kolb-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 17-10-15&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 17-10-15&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Sun 10/15/17: 11 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 06:36 AM - New FS II flyer has Questions (RoHam) > 2. 08:41 AM - Re: New FS II flyer has Questions () > 3. 08:50 AM - Re: New FS II flyer has Questions (Gary Aman) > 4. 09:06 AM - Re: New FS II flyer has Questions (Larry Cottrell) > 5. 12:15 PM - Re: New FS II flyer has Questions (woody) > 6. 01:01 PM - Re: Re: New FS II flyer has Questions (Russ Kinne) > 7. 02:50 PM - Re: New FS II flyer has Questions (Russ Kinne) > 8. 03:41 PM - Re: New FS II flyer has Questions (RoHam) > 9. 08:37 PM - Video all local to KCMA (jonealjr) > 10. 08:55 PM - Re: Video all local to KCMA (Richard Pike) > 11. 11:18 PM - Re: Re: Video all local to KCMA (Bill Berle) > > > > ________________________________ Message 1 _____________________________________ > > > Subject: Kolb-List: New FS II flyer has Questions > From: "RoHam" <RoHam903(at)gmail.com> > > > Hi everyone I'm new to the matronics so a big thank you to the administrator for > the nod. > I'm soon to fly my 270hr FSII that I've spent the last 11/2 yr going thru replacing > fuel lines, fuel tanks, all rubber and misc items you'd expect to need on > an plane sitting for 10yrs. I'm now at the point of flying it after getting > my flight review in a 46 Champ to get me ready. > My question is ... What's everyone using for airspeeds? What kind of surprises > shoulld I expect? > VNE = 90mph > VA = ??? > VY = ??? > VX = ??? > real life Stall speeds > The printed info I had says it stalls at 33mph ..rotate at 40mph and use 45 for > approach. > Thanks for any help...Bob > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473572#473572 > > > ________________________________ Message 2 _____________________________________ > > > From: <jhauck(at)elmore.rr.com> > Subject: Re: Kolb-List: New FS II flyer has Questions > > > I made my first flight in my new Kolb Ultrastar 33 years ago this past July. I > was a helicopter pilot, not a fixed wing pilot. Actually, I was a rusty helicopter > pilot, hadn't flown in 8 years. I read a lot of stick and rudder books ________________________________________________________________________________
Date: Oct 16, 2017
Bob For your first flights I highly recommend flying off grass or gravel the first few times, much more forgiving. Also 50 is nifty And fly it all the way to the ground, just roll it on Mike Seattle Cell 206-963-2118 > On Oct 16, 2017, at 12:03 AM, Kolb-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 17-10-15&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 17-10-15&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Sun 10/15/17: 11 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 06:36 AM - New FS II flyer has Questions (RoHam) > 2. 08:41 AM - Re: New FS II flyer has Questions () > 3. 08:50 AM - Re: New FS II flyer has Questions (Gary Aman) > 4. 09:06 AM - Re: New FS II flyer has Questions (Larry Cottrell) > 5. 12:15 PM - Re: New FS II flyer has Questions (woody) > 6. 01:01 PM - Re: Re: New FS II flyer has Questions (Russ Kinne) > 7. 02:50 PM - Re: New FS II flyer has Questions (Russ Kinne) > 8. 03:41 PM - Re: New FS II flyer has Questions (RoHam) > 9. 08:37 PM - Video all local to KCMA (jonealjr) > 10. 08:55 PM - Re: Video all local to KCMA (Richard Pike) > 11. 11:18 PM - Re: Re: Video all local to KCMA (Bill Berle) > > > > ________________________________ Message 1 _____________________________________ > > > Subject: Kolb-List: New FS II flyer has Questions > From: "RoHam" <RoHam903(at)gmail.com> > > > Hi everyone I'm new to the matronics so a big thank you to the administrator for > the nod. > I'm soon to fly my 270hr FSII that I've spent the last 11/2 yr going thru replacing > fuel lines, fuel tanks, all rubber and misc items you'd expect to need on > an plane sitting for 10yrs. I'm now at the point of flying it after getting > my flight review in a 46 Champ to get me ready. > My question is ... What's everyone using for airspeeds? What kind of surprises > shoulld I expect? > VNE = 90mph > VA = ??? > VY = ??? > VX = ??? > real life Stall speeds > The printed info I had says it stalls at 33mph ..rotate at 40mph and use 45 for > approach. > Thanks for any help...Bob > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473572#473572 > > > ________________________________ Message 2 _____________________________________ > > > From: <jhauck(at)elmore.rr.com> > Subject: Re: Kolb-List: New FS II flyer has Questions > > > I made my first flight in my new Kolb Ultrastar 33 years ago this past July. I > was a helicopter pilot, not a fixed wing pilot. Actually, I was a rusty helicopter > pilot, hadn't flown in 8 years. I read a lot of stick and rudder books > to get up to speed on being an airplane pilot. I paid special attention to Homer > Kolb's comments about test flying his new Ultrastar. "Take it up to 1000 > feet above the ground and check the stall speed." Now you are good to go. You > know when the aircraft is going to quit flying, unless you get yourself into > an accelerated stall, which is damn near impossible to do in a Kolb. Stalls > were my biggest worry coming from a rotary wing world where we didn't pay a whole > lot of attention to that terminology. > > As far as the other "V" speeds, I didn't worry about them much except "maneuver" > and VNE. Maneuver speed was anything slow enough to be comfortable in rough > air. VNE wasn't a big problem either, but I tried to stay below whatever happened > to be the "popular" VNE for whatever Kolb model I was flying. > > Stall speed is critical. > > High speeds and rough air don't mix. > > john h > mkIII > Palm Desert, California > > > ---- RoHam wrote: >> >> Hi everyone I'm new to the matronics so a big thank you to the administrator > for the nod. >> I'm soon to fly my 270hr FSII that I've spent the last 11/2 yr going thru replacing > fuel lines, fuel tanks, all rubber and misc items you'd expect to need > on an plane sitting for 10yrs. I'm now at the point of flying it after getting > my flight review in a 46 Champ to get me ready. >> My question is ... What's everyone using for airspeeds? What kind of surprises > shoulld I expect? >> VNE = 90mph >> VA = ??? >> VY = ??? >> VX = ??? >> real life Stall speeds >> The printed info I had says it stalls at 33mph ..rotate at 40mph and use 45 > for approach. >> Thanks for any help...Bob >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=473572#473572 >> >> >> >> >> >> >> >> >> > > > ________________________________ Message 3 _____________________________________ > > > Subject: Re: Kolb-List: New FS II flyer has Questions > From: Gary Aman <zeprep251(at)aol.com> > > > only reliable info for lower speed questions is actual experience in your airplane > .take it up and at safe altitude,slow it down until you see what your indicator > reads when it stalls >> On Oct 15, 2017, at 9:36 AM, RoHam wrote: >> >> >> Hi everyone I'm new to the matronics so a big thank you to the administrator > for the nod. >> I'm soon to fly my 270hr FSII that I've spent the last 11/2 yr going thru replacing > fuel lines, fuel tanks, all rubber and misc items you'd expect to need > on an plane sitting for 10yrs. I'm now at the point of flying it after getting > my flight review in a 46 Champ to get me ready. >> My question is ... What's everyone using for airspeeds? What kind of surprises > shoulld I expect? >> VNE = 90mph >> VA = ??? >> VY = ??? >> VX = ??? >> real life Stall speeds >> The printed info I had says it stalls at 33mph ..rotate at 40mph and use 45 > for approach. >> Thanks for any help...Bob >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=473572#473572 >> >> >> >> >> >> >> >> >> > > > ________________________________ Message 4 _____________________________________ > > > From: Larry Cottrell <lcottrell1020(at)gmail.com> > Subject: Re: Kolb-List: New FS II flyer has Questions > > congratulations on finishing your FII. The questions that you have asked > has had many attempts to be answered. I am afraid that there are too many > variables for a hard and fast answer. > > With my Firestar in its current configuration I use 50 for climb. Stall > speeds can vary as much as 29- to one I flew that stalled at 60? What I am > saying is that there is no hard and fast numbers for your plane other than > what you yourself discover. > > Your best plan is to be very conservative and let your plane tell you what > it likes. On your take off roll keep a bit of back stick and let it lift > off by itself. Get at least a 1000 feet and see what your best climb is by > pulling back on the stick. Do check pilot. I paid special attention to Homer > Kolb's comments about test flying his new Ultrastar. "Take it up to 1000 > feet above the ground and check the stall speed." Now you are good to go. You > know when the aircraft is going to quit flying, unless you get yourself into > an accelerated stall, which is damn near impossible to do in a Kolb. Stalls > were my biggest worry coming from a rotary wing world where we didn't pay a whole > lot of attention to that terminology. > > As far as the other "V" speeds, I didn't worry about them much except "maneuver" > and VNE. Maneuver speed was anything slow enough to be comfortable in rough > air. VNE wasn't a big problem either, but I tried to stay below whatever happened > to be the "popular" VNE for whatever Kolb model I was flying. > > Stall speed is critical. > > High speeds and rough air don't mix. > > john h > mkIII > Palm Desert, California > > > ---- RoHam wrote: >> >> Hi everyone I'm new to the matronics so a big thank you to the administrator > for the nod. >> I'm soon to fly my 270hr FSII that I've spent the last 11/2 yr going thru replacing > fuel lines, fuel tanks, all rubber and misc items you'd expect to need > on an plane sitting for 10yrs. I'm now at the point of flying it after getting > my flight review in a 46 Champ to get me ready. >> My question is ... What's everyone using for airspeeds? What kind of surprises > shoulld I expect? >> VNE = 90mph >> VA = ??? >> VY = ??? >> VX = ??? >> real life Stall speeds >> The printed info I had says it stalls at 33mph ..rotate at 40mph and use 45 > for approach. >> Thanks for any help...Bob >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=473572#473572 >> >> >> >> >> >> >> >> >> > > > ________________________________ Message 3 _____________________________________ > > > Subject: Re: Kolb-List: New FS II flyer has Questions > From: Gary Aman <zeprep251(at)aol.com> > > > only reliable info for lower speed questions is actual experience in your airplane > .take it up and at safe altitude,slow it down until you see what your indicator > reads when it stalls >> On Oct 15, 2017, at 9:36 AM, RoHam wrote: >> >> >> Hi everyone I'm new to the matronics so a big thank you to the administrator > for the nod. >> I'm soon to fly my 270hr FSII that I've spent the last 11/2 yr going thru replacing > fuel lines, fuel tanks, all rubber and misc items you'd expect to need > on an plane sitting for 10yrs. I'm now at the point of flying it after getting > my flight review in a 46 Champ to get me ready. >> My question is ... What's everyone using for airspeeds? What kind of surprises > shoulld I expect? >> VNE = 90mph >> VA = ??? >> VY = ??? >> VX = ??? >> real life Stall speeds >> The printed info I had says it stalls at 33mph ..rotate at 40mph and use 45 > for approach. >> Thanks for any help...Bob >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=473572#473572 >> >> >> >> >> >> >> >> >> > > > ________________________________ Message 4 _____________________________________ > > > From: Larry Cottrell <lcottrell1020(at)gmail.com> > Subject: Re: Kolb-List: New FS II flyer has Questions > > congratulations on finishing your FII. The questions that you have asked > has had many attempts to be answered. I am afraid that there are too many > variables for a hard and fast answer. > > With my Firestar in its current configuration I use 50 for climb. Stall > speeds can vary as much as 29- to one I flew that stalled at 60? What I am > saying is that there is no hard and fast numbers for your plane other than > what you yourself discover. > > Your best plan is to be very conservative and let your plane tell you what > it likes. On your take off roll keep a bit of back stick and let it lift > off by itself. Get at least a 1000 feet and see what your best climb is by > pulling back on the stick. Do check and see what your ASI indicates as a > stall speed. There are lots of differences in ASI instruments depending on > your pitot tube placement, the difference in cabin pressure, all that > influences your indicated speed. > > While its nice to have an ASI that reads true, the real requirement is that > you know what yours reads when the plane quits flying. One of the biggest > problems with a kolb is that the design means that when the power is off, > it doesn't take all that long before the plane stops forward speed. It > takes most people by surprise and is the main cause of bent landing gear. I > suggest that you take it to altitude, pull the throttle off, give it some > back stick and see how long it takes for the plane to stall. > > I also suggest that you maintain some power on your landings when you first > start. I do my approaches at 50. My plane however stalls at 30 MPH for me. > > Good luck with your plane, but be very cautious until you know what your > operating speeds actually are for your plane. It may fly like the Champ but > it will not land like the Champ. It is designed for a totally different > mission. > > Good luck > > Larry > >> On Sun, Oct 15, 2017 at 7:36 AM, RoHam wrote: >> >> >> Hi everyone I'm new to the matronics so a big thank you to the >> administrator for the nod. >> I'm soon to fly my 270hr FSII that I've spent the last 11/2 yr going thru >> replacing fuel lines, fuel tanks, all rubber and misc items you'd expect to >> need on an plane sitting for 10yrs. I'm now at the point of flying it after >> getting my flight review in a 46 Champ to get me ready. >> My question is ... What's everyone using for airspeeds? What kind of >> surprises shoulld I expect? >> VNE = 90mph >> VA = ??? >> VY = ??? >> VX = ??? >> real life Stall speeds >> The printed info I had says it stalls at 33mph ..rotate at 40mph and use >> 45 for approach. >> Thanks for any help...Bob >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=473572#473572 >> >> > > > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > ________________________________ Message 5 _____________________________________ > > > Subject: Kolb-List: Re: New FS II flyer has Questions > From: "woody" <n3022.176(at)gmail.com> > > > There's not much to add to John and Larry's comments. Make sure that you know what > the stall speed is and keep it 5-10 mph above that when you bring it in. I > also flopped around in a Champ before flying my Firestar II. These light aircraft > run out of inertia rapidly and will go from flying to falling in 3 seconds > or less. Be vigilant. Bring it in with power, 4000 rpm should give you an edge > in keeping it under control. FLY IT TO THE GROUND. Do not chop the throttle > and expect it to land like that "flying pig", the champ. 8) > PS: If you have the aluminum gear legs on your plane, start thinking about building > some steel ones. They are a lot more forgiving. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473584#473584 > > > ________________________________ Message 6 _____________________________________ > > > Subject: Re: Kolb-List: Re: New FS II flyer has Questions > From: Russ Kinne <russk50(at)gmail.com> > > > If anyone wants a set of steel gear legs for the Xtra, I have a pair Id like to > sell > > Russ K >> On Oct 15, 2017, at 3:15 PM, woody wrote: >> >> >> There's not much to add to John and Larry's comments. Make sure that you know > what the stall speed is and keep it 5-10 mph above that when you bring it in. > I also flopped around in a Champ before flying my Firestar II. These light aircraft > run out of inertia rapidly and will go from flying to falling in 3 seconds > or less. Be vigilant. Bring it in with power, 4000 rpm should give you an > edge in keeping it under coand see what your ASI indicates as a > stall speed. There are lots of differences in ASI instruments depending on > your pitot tube placement, the difference in cabin pressure, all that > influences your indicated speed. > > While its nice to have an ASI that reads true, the real requirement is that > you know what yours reads when the plane quits flying. One of the biggest > problems with a kolb is that the design means that when the power is off, > it doesn't take all that long before the plane stops forward speed. It > takes most people by surprise and is the main cause of bent landing gear. I > suggest that you take it to altitude, pull the throttle off, give it some > back stick and see how long it takes for the plane to stall. > > I also suggest that you maintain some power on your landings when you first > start. I do my approaches at 50. My plane however stalls at 30 MPH for me. > > Good luck with your plane, but be very cautious until you know what your > operating speeds actually are for your plane. It may fly like the Champ but > it will not land like the Champ. It is designed for a totally different > mission. > > Good luck > > Larry > >> On Sun, Oct 15, 2017 at 7:36 AM, RoHam wrote: >> >> >> Hi everyone I'm new to the matronics so a big thank you to the >> administrator for the nod. >> I'm soon to fly my 270hr FSII that I've spent the last 11/2 yr going thru >> replacing fuel lines, fuel tanks, all rubber and misc items you'd expect to >> need on an plane sitting for 10yrs. I'm now at the point of flying it after >> getting my flight review in a 46 Champ to get me ready. >> My question is ... What's everyone using for airspeeds? What kind of >> surprises shoulld I expect? >> VNE = 90mph >> VA = ??? >> VY = ??? >> VX = ??? >> real life Stall speeds >> The printed info I had says it stalls at 33mph ..rotate at 40mph and use >> 45 for approach. >> Thanks for any help...Bob >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=473572#473572 >> >> > > > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > ________________________________ Message 5 _____________________________________ > > > Subject: Kolb-List: Re: New FS II flyer has Questions > From: "woody" <n3022.176(at)gmail.com> > > > There's not much to add to John and Larry's comments. Make sure that you know what > the stall speed is and keep it 5-10 mph above that when you bring it in. I > also flopped around in a Champ before flying my Firestar II. These light aircraft > run out of inertia rapidly and will go from flying to falling in 3 seconds > or less. Be vigilant. Bring it in with power, 4000 rpm should give you an edge > in keeping it under control. FLY IT TO THE GROUND. Do not chop the throttle > and expect it to land like that "flying pig", the champ. 8) > PS: If you have the aluminum gear legs on your plane, start thinking about building > some steel ones. They are a lot more forgiving. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473584#473584 > > > ________________________________ Message 6 _____________________________________ > > > Subject: Re: Kolb-List: Re: New FS II flyer has Questions > From: Russ Kinne <russk50(at)gmail.com> > > > If anyone wants a set of steel gear legs for the Xtra, I have a pair Id like to > sell > > Russ K >> On Oct 15, 2017, at 3:15 PM, woody wrote: >> >> >> There's not much to add to John and Larry's comments. Make sure that you know > what the stall speed is and keep it 5-10 mph above that when you bring it in. > I also flopped around in a Champ before flying my Firestar II. These light aircraft > run out of inertia rapidly and will go from flying to falling in 3 seconds > or less. Be vigilant. Bring it in with power, 4000 rpm should give you an > edge in keeping it under control. FLY IT TO THE GROUND. Do not chop the throttle > and expect it to land like that "flying pig", the champ. 8) >> PS: If you have the aluminum gear legs on your plane, start thinking about building > some steel ones. They are a lot more forgiving. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=473584#473584 >> >> >> >> >> >> >> >> >> > > > ________________________________ Message 7 _____________________________________ > > > Subject: Re: Kolb-List: New FS II flyer has Questions > From: Russ Kinne <russk50(at)gmail.com> > > > Bob > IMHO NO one should fly ANYthing until/unless he knows at least what VNE, VX, VY, > and Maneuvering speed are. > Go back to ground school before you crash! Who gave you a review without making > sure you knew those??? > >> On Oct 15, 2017, at 9:36 AM, RoHam wrote: >> >> >> Hi everyone I'm new to the matronics so a big thank you to the administrator > for the nod. >> I'm soon to fly my 270hr FSII that I've spent the last 11/2 yr going thru replacing > fuel lines, fuel tanks, all rubber and misc items you'd expect to need > on an plane sitting for 10yrs. I'm now at the point of flying it after getting > my flight review in a 46 Champ to get me ready. >> My question is ... What's everyone using for airspeeds? What kind of surprises > shoulld I expect? >> VNE = 90mph >> VA = ??? >> VY = ??? >> VX = ??? >> real life Stall speeds >> The printed info I had says it stalls at 33mph ..rotate at 40mph and use 45 > for approach. >> Thanks for any help...Bob >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=473572#473572 >> >> >> >> >> >> >> >> >> > > > ________________________________ Message 8 _____________________________________ > > > Subject: Kolb-List: Re: New FS II flyer has Questions > From: "RoHam" <RoHam903(at)gmail.com> > > > Thanks to everyone for the info. I pretty much figured it would be a trial of flying > it and figuring out. I guess I was looking for some average speeds everyone > was using. I understand the vx,vy &va. The question marks were looking to > fill in the average speeds. Sorry for the confusion. I'll let you know how I > make out. Is everyone converting to steel gear? Will the original aluminum hold > up to average landings? Whats the source of these gear? I found a good source > for fuel tanks if anyone needs it. Thanks again... Bob > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473593#473593 > > > ________________________________ Message 9 _____________________________________ > > > Subject: Kolb-List: Video all local to KCMA > From: "jonealjr" <jonealjr(at)gmail.com> > > > https://youtu.be/l2r161S-XXk > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473598#473598 > > > ________________________________ Message 10 ____________________________________ > > > Subject: Kolb-List: Re: Video all local to KCMA > From: "Richard Pike" <thegreybaron(at)charter.net> > > > My wife said you shouldn't fly low over the cows like that: it will make them stop > laying eggs... > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough. Being forgiven is wonderful. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473600#473600 > > > ________________________________ Message 11 ____________________________________ > > > From: Bill Berle <victorbravo(at)sbcglobal.net> > Subject: Re: Kolb-List: Re: Video all local to KCMA > > > Congratulations Jimmy, GREAT videos! You're having a blast... > > I owe you a call, will do so tomorrow. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > ---------------------------ntrol. FLY IT TO THE GROUND. Do not chop the throttle > and expect it to land like that "flying pig", the champ. 8) >> PS: If you have the aluminum gear legs on your plane, start thinking about building > some steel ones. They are a lot more forgiving. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=473584#473584 >> >> >> >> >> >> >> >> >> > > > ________________________________ Message 7 _____________________________________ > > > Subject: Re: Kolb-List: New FS II flyer has Questions > From: Russ Kinne <russk50(at)gmail.com> > > > Bob > IMHO NO one should fly ANYthing until/unless he knows at least what VNE, VX, VY, > and Maneuvering speed are. > Go back to ground school before you crash! Who gave you a review without making > sure you knew those??? > >> On Oct 15, 2017, at 9:36 AM, RoHam wrote: >> >> >> Hi everyone I'm new to the matronics so a big thank you to the administrator > for the nod. >> I'm soon to fly my 270hr FSII that I've spent the last 11/2 yr going thru replacing > fuel lines, fuel tanks, all rubber and misc items you'd expect to need > on an plane sitting for 10yrs. I'm now at the point of flying it after getting > my flight review in a 46 Champ to get me ready. >> My question is ... What's everyone using for airspeeds? What kind of surprises > shoulld I expect? >> VNE = 90mph >> VA = ??? >> VY = ??? >> VX = ??? >> real life Stall speeds >> The printed info I had says it stalls at 33mph ..rotate at 40mph and use 45 > for approach. >> Thanks for any help...Bob >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=473572#473572 >> >> >> >> >> >> >> >> >> > > > ________________________________ Message 8 _____________________________________ > > > Subject: Kolb-List: Re: New FS II flyer has Questions > From: "RoHam" <RoHam903(at)gmail.com> > > > Thanks to everyone for the info. I pretty much figured it would be a trial of flying > it and figuring out. I guess I was looking for some average speeds everyone > was using. I understand the vx,vy &va. The question marks were looking to > fill in the average speeds. Sorry for the confusion. I'll let you know how I > make out. Is everyone converting to steel gear? Will the original aluminum hold > up to average landings? Whats the source of these gear? I found a good source > for fuel tanks if anyone needs it. Thanks again... Bob > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473593#473593 > > > ________________________________ Message 9 _____________________________________ > > > Subject: Kolb-List: Video all local to KCMA > From: "jonealjr" <jonealjr(at)gmail.com> > > > https://youtu.be/l2r161S-XXk > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473598#473598 > > > ________________________________ Message 10 ____________________________________ > > > Subject: Kolb-List: Re: Video all local to KCMA > From: "Richard Pike" <thegreybaron(at)charter.net> > > > My wife said you shouldn't fly low over the cows like that: it will make them stop > laying eggs... > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough. Being forgiven is wonderful. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473600#473600 > > > ________________________________ Message 11 ____________________________________ > > > From: Bill Berle <victorbravo(at)sbcglobal.net> > Subject: Re: Kolb-List: Re: Video all local to KCMA > > > Congratulations Jimmy, GREAT videos! You're having a blast... > > I owe you a call, will do so tomorrow. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Sun, 10/15/17, Richard Pike wrote: > > Subject: Kolb-List: Re: Video all local to KCMA > To: kolb-list(at)matronics.com > Date: Sunday, October 15, 2017, 8:55 PM > > Pike" > > My wife said you shouldn't fly low over > the cows like that: it will make them stop laying eggs... > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough. Being forgiven is > wonderful. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473600#473600 > > > The Kolb-List Email Forum - > Navigator to browse > List Un/Subscription, > 7-Day Browse, Chat, FAQ, > - MATRONICS WEB FORUMS - > via the Web Forums! > - NEW MATRONICS LIST WIKI - > Email List Wiki! > - List Contribution Web Site - > support! > > -Matt Dralle, List Admin. > > > > > > > > ----------------- > On Sun, 10/15/17, Richard Pike wrote: > > Subject: Kolb-List: Re: Video all local to KCMA > To: kolb-list(at)matronics.com > Date: Sunday, October 15, 2017, 8:55 PM > > Pike" > > My wife said you shouldn't fly low over > the cows like that: it will make them stop laying eggs... > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough. Being forgiven is > wonderful. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473600#473600 > > > The Kolb-List Email Forum - > Navigator to browse > List Un/Subscription, > 7-Day Browse, Chat, FAQ, > - MATRONICS WEB FORUMS - > via the Web Forums! > - NEW MATRONICS LIST WIKI - > Email List Wiki! > - List Contribution Web Site - > support! > > -Matt Dralle, List Admin. > > > > > > > > ________________________________________________________________________________
Date: Oct 16, 2017
Nice thx for sharing -------- 2007 Firestar 2 503 N203SD Moster 185 Flattop PPG/Sky K2 Paraglider Trike Buggy Soaring Trike & Northwing Stratus XP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473624#473624 ________________________________________________________________________________
Date: Oct 16, 2017
It looks like you have made the Go Pro work for you. It was nice and steady, all in all one of the better video's posted. Where was it shot? Is this a different ( newer model) Go Pro? One thing you should remember however and that is, videos can be entertaining, but evidence as well. You may have heard of Steve Henry. A Nampa Idaho pilot of a Highlander. Google him or search You Tube. Any way he posted some videos of flying in the Owyhee country. I think he buzzed some feral horses. BLM fined him at least $1000.00 for it. They saw the video as well. I myself found a bullet hole just outside the prop area in my wing covering, after doing repeated touch and goes at a rural airport in a small town of S Oregon. I guess the people that lived in the area bordering the airport were not as amused as I was. fwiw, Larry On Sun, Oct 15, 2017 at 9:37 PM, jonealjr wrote: > > https://youtu.be/l2r161S-XXk > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473598#473598 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Oct 17, 2017
Yes Larry, I agree with you on everything. We were flying is Ojai, Ca all within 30 min or so from my home airport. I do NOT fly near horses because the spook way to easy and my wife is a horse trainer so I know the deal. Cows are a bit different. We don't buzz cows very often that day we were doing some low flight and at the end of the field there they were. As far as the area we fly there often thankfully without too many issues. I can not take any credit for the Go Pro work only the flying :D the Go Pro was mounted on the right gear leg & all the photo/video credit goes to my cousin Chris Jancich. I hope to make it up to see you in 2018 and I look forward to any and all of your videos. -------- Mark III Classic 912ULS Go fast & always take chances / Minimize your regrets with age Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473644#473644 ________________________________________________________________________________
Subject: Kolbra w&b question / lookover
Date: Oct 17, 2017
Weighed the kolbra the other day while getting some things finshed up. Seems to come out rather tail heavy, what your thoughts? Battery is by front fuel tank, plan to move into nose cone and check again but think that will be enough. Where does other kolbra fliers have their battery etc? Numbers: Book CG 11.6in - 20.3in from LE No fuel With oil and water Tail. 90.65 Right. 254.9 Left. 245.5 Total empty weight wengine fluids 591.05lbs Leading edge= datum = 0 ARM WEIGHT MOMENT Main axle -1 500.5lbs -500.5 Front seat 22 160lbs 3520 Rear seat -9 0lbs adding passenger puts it in the rear of the envelope Front tank -30 30lbs -900 Tail wheel -206 90.65lbs -18673.9 811.15 / -17754.4 = -21.888 CG Of course its been awhile since I've been into doing the math side so could just be numbers put together wrong, but it sounds about right a bit tail heavy? -------- 912ul King Kolbra ;fun plane O300 Cessna 172B ;travel plane Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473652#473652 ________________________________________________________________________________
Date: Oct 19, 2017
Your aluminum gear legs will hold up just fine until you drop it in. You should do your first flights in the mornings or evenings when the winds are less bumpy than during the day. I have a Firestar II with added Stolspeed VG's, they have made quite a difference in the way it handles when close to stall. Mine stalls at 28 indicated, down from 35 and it just mushes now. I also fly another Firestar II that has just gotten it's air worthiness cert. It flies the same but the landing are quite different. It stalls at 36 indicated, and it stalls abruptly. At altitude it sounds like the prop is starting to lose its grip and bang, the nose drops quickly. This is where you practice, practice, practice. !000' up is the only place to learn how the plane acts when it stalls. Down on the runway, stalls get expensive real fast. This second Firestar has gone thru the latter. But with a new wing and aileron, landing gear and some really good workmanship, she is back in the air. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473675#473675 ________________________________________________________________________________
Subject: Re: Kolbra w&b question / lookover
Date: Oct 19, 2017
Here are the weight and balance sheets for my Kolbra (see attachments). I have lots of flying videos (over 100) of the Kolbra. You can see them here: https://www.youtube.com/user/flyguy8294 -------- Ralph B Kolb Kolbra 912uls N20386 550 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473691#473691 Attachments: http://forums.matronics.com//files/n20386_weight_and_balance_loaded_211.xls http://forums.matronics.com//files/n20386_faa_weight_and_balance_submit_192.xls ________________________________________________________________________________
Date: Oct 19, 2017
Hey thanks! Looks like the weights are very close, I guess with the 912 vs the 582 it was designed for it is just gonna be toward the back... I'll weigh it again and double check all my arms maybe, noticed your mains were 1.8in where as mine are -1 which would make a difference. Where is your battery located, and how did you go about mounting it there? Thanks for the w&b sheets and I'm already subscribed, not much out there really on the kolbra... -------- 912ul King Kolbra ;fun plane O300 Cessna 172B ;travel plane Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473700#473700 ________________________________________________________________________________
Date: Oct 19, 2017
I'm using an Odyssey PC680 battery and it's located in back of the passenger seat. There really isn't much info on the Kolbra. I don't think many were built. -------- Ralph B Kolb Kolbra 912uls N20386 550 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473701#473701 ________________________________________________________________________________
Subject: Kolbra's...
Date: Oct 21, 2017
Kolbers, I do not know for sure, but I think there were nineteen Kolbras built. There is probably someone on the list who knows the true number. Mine is the Prototype. but is really more of a Firestar III, than a Kolbra. Nick Cassara Palmer, Alaska 607AK .will be finished this winter:) ________________________________________________________________________________
Date: Oct 21, 2017
Date: Oct 21, 2017
Date: Oct 21, 2017
Date: Oct 21, 2017
Date: Oct 21, 2017
Date: Oct 21, 2017
Date: Oct 21, 2017
Date: Oct 22, 2017
Subject: Twinstar Mk I weight & balance?
Getting ready to weigh the Twinstar. Anyone have a clue what part of the airframe can be leveled, to put it in flight attitude? On this one, leveling the top tube gives about 5 degrees positive AOA on the bottom of the airfoil. Does this sound about right for doing W&B? Was there ever a preferred datum point on these old planes? Thanks, Charlie ________________________________________________________________________________
Date: Oct 22, 2017
Subject: Re: Twinstar Mk I weight & balance?
Charlie, I=99m pretty sure the wings leading edge is the preferred da tum. On a level surface the bottom of the wing should be set 8 or 9 degrees by raising or lowering the tail. It=99s looking pretty nice in your pict ure. George H. Firestar, FS100 Mesick, Michigan gdhelton(at)gmail.com On Sun, Oct 22, 2017 at 4:10 PM Charlie England wrote: > Getting ready to weigh the Twinstar. Anyone have a clue what part of the > airframe can be leveled, to put it in flight attitude? On this one, > leveling the top tube gives about 5 degrees positive AOA on the bottom of > the airfoil. Does this sound about right for doing W&B? Was there ever a > preferred datum point on these old planes? > > Thanks, > > Charlie > -- Have a great day! ________________________________________________________________________________
Date: Oct 22, 2017
Thanks, George; I appreciate it. My a&p buddy was guessing at 2-3 degrees of actual angle of attack, so I'll need to adjust a bit. On Sun, Oct 22, 2017 at 3:28 PM, George Helton wrote: > Charlie, I=99m pretty sure the wings leading edge is the preferred datum. On > a level surface the bottom of the wing should be set 8 or 9 degrees by > raising or lowering the tail. It=99s looking pretty nice in your pi cture. > George H. > Firestar, FS100 > Mesick, Michigan > gdhelton(at)gmail.com > > On Sun, Oct 22, 2017 at 4:10 PM Charlie England > wrote: > >> Getting ready to weigh the Twinstar. Anyone have a clue what part of the >> airframe can be leveled, to put it in flight attitude? On this one, >> leveling the top tube gives about 5 degrees positive AOA on the bottom o f >> the airfoil. Does this sound about right for doing W&B? Was there ever a >> preferred datum point on these old planes? >> >> Thanks, >> >> Charlie >> > -- > Have a great day! > ________________________________________________________________________________
Subject: Re: Kolb available?
Date: Oct 24, 2017
Mike Welch wrote: > Health issues among other things forces me to sell mine. Have him contact me if hes interested. > > > Mike Welch > 435-695-7788 > > > St. George, Utah > > > > > > On Oct 2, 2017, at 6:09 PM, Larry Cottrell wrote: > > > > > I have a friend here that is interested in a Kolb. Anyone currently have one for sale? It would be nice if it was reasonable. Larry > > > > -- > > The older I get, the less tolerant I am of those who are intolerant of others. > > > > > > If you forward this email, or any part of it, please remove my email address before sending. > > > > I have a Mark lll Extra factory built with a 912 80 hp. if you are interested > > Rick 361-229-6061 > > bmwz343(at)aol.com > > Chuckey Tn > > > > > > > > > > > > > > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473848#473848 ________________________________________________________________________________
Subject: Re: Kolbra's...
Date: Oct 24, 2017
Yeah I haven't been able to find much on the kolbra's. I have #15, I believe it is the king kolbra model because of the wider nose? From what I can gather there was kolbras, and king kolbras same but with wider nose, but not really sure. I really like the overall design though. Good luck on the build! -------- 912ul King Kolbra ;fun plane O300 Cessna 172B ;travel plane Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473850#473850 ________________________________________________________________________________
Date: Oct 25, 2017
The Kolbra is nothing more than an oversized Firestar with a big engine. It just flies faster and can run circles around any Firestar. I'm surprised there aren't more out there as it's a great flying airplane. -------- Ralph B Kolb Kolbra 912uls N20386 550 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473858#473858 Attachments: http://forums.matronics.com//files/kolbra_727.jpg ________________________________________________________________________________
Date: Oct 25, 2017
Charlie, Set the horizontal stabilizer level. As for datum, it doesn't matter as long as you're consistent with your measuring and you don't get minus and plus measurements if your datum is somewhere in the middle of the plane. I use a point 20 inches in front of the nose, that way all numbers are positive. You could just as easily make it 20 inches aft of the tail. It doesn't matter. Rick Girard <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&ut m_campaign=sig-email&utm_content=webmail> Virus-free. www.avg.com <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&ut m_campaign=sig-email&utm_content=webmail> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Sun, Oct 22, 2017 at 4:01 PM, Charlie England wrote: > Thanks, George; I appreciate it. > > My a&p buddy was guessing at 2-3 degrees of actual angle of attack, so > I'll need to adjust a bit. > > > On Sun, Oct 22, 2017 at 3:28 PM, George Helton wrote : > >> Charlie, I=99m pretty sure the wings leading edge is the preferred datum. >> On a level surface the bottom of the wing should be set 8 or 9 degrees b y >> raising or lowering the tail. It=99s looking pretty nice in your p icture. >> George H. >> Firestar, FS100 >> Mesick, Michigan >> gdhelton(at)gmail.com >> >> On Sun, Oct 22, 2017 at 4:10 PM Charlie England >> wrote: >> >>> Getting ready to weigh the Twinstar. Anyone have a clue what part of th e >>> airframe can be leveled, to put it in flight attitude? On this one, >>> leveling the top tube gives about 5 degrees positive AOA on the bottom of >>> the airfoil. Does this sound about right for doing W&B? Was there ever a >>> preferred datum point on these old planes? >>> >>> Thanks, >>> >>> Charlie >>> >> -- >> Have a great day! >> > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Oct 26, 2017
Subject: Re: Kolb-List Digest: 2 Msgs - 10/24/17
I have a firestar 2 with less than 50 hrs. tt. 503, dual carb , ele. Start. Asking 9,000. You can call me @ 402-5476406 Sent from Yahoo Mail on Android On Wed, Oct 25, 2017 at 2:18 AM, Kolb-List Digest Server wrote: * ======================== =C2- Online Versions of Today's List Digest Archive ======================== Today's complete Kolb-List Digest can also be found in either of the two Web Links listed below.=C2- The .html file includes the Digest format ted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation.=C2- The .txt file includes the plain ASCII versio n of the Kolb-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: =C2- =C2- http://www.matronics.com/digest/digestview.php?Style=82701& View=html&Chapter 17-10-24&Archive=Kolb Text Version: =C2- =C2- http://www.matronics.com/digest/digestview.php?Style=82701& View=txt&Chapter 17-10-24&Archive=Kolb ======================== ======================= =C2- EMail Version of Today's List Digest Archive ======================== ======================= =C2- =C2- =C2- =C2- =C2- ---------------------------------------- ------------------ =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2 - =C2- =C2- Kolb-List Digest Archive =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2 - =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- --- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- Total Messages Posted Tue 10/24/17: 2 =C2- =C2- =C2- =C2- =C2- ---------------------------------------- ------------------ Today's Message Index: ---------------------- =C2- =C2- 1. 05:01 PM - Re: Kolb available?=C2- (Bmwz343) =C2- =C2- 2. 05:59 PM - Re: Kolbra's...=C2- (3benny3) ________________________________=C2- Message 1=C2- ____________________ _________________ Subject: Kolb-List: Re: Kolb available? From: "Bmwz343" <Bmwz343(at)aol.com> Mike Welch wrote: > Health issues among other things forces me to sell mine. Have him contact me if hes interested. >=C2- >=C2- >=C2- Mike Welch >=C2- 435-695-7788 >=C2- >=C2- >=C2- St. George, Utah >=C2- >=C2- >=C2- >=C2- >=C2- >=C2- On Oct 2, 2017, at 6:09 PM, Larry Cottrell=C2- wrote: >=C2- >=C2- >=C2- > >=C2- I have a friend here that is interested in a Kolb. Anyone current ly have one for sale? It would be nice if it was reasonable. Larry > >=C2- > >=C2- -- > >=C2- =C2- =C2- =C2- The older I get, the less tolerant I am of t hose who are intolerant of others. > >=C2- > >=C2- > >=C2- If you forward this email, or any part of it, please remove my em ail address before sending. > >=C2- > >=C2- I have a Mark lll Extra factory built with a 912 80 hp. if you ar e interested > > Rick=C2- 361-229-6061 > > bmwz343(at)aol.com > > Chuckey Tn > >=C2- > >=C2- > >=C2- > >=C2- > >=C2- > >=C2- > >=C2- > >=C2- > >=C2- > >=C2- > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473848#473848 ________________________________=C2- Message 2=C2- ____________________ _________________ Subject: Kolb-List: Re: Kolbra's... From: "3benny3" <the3benny3(at)gmail.com> Yeah I haven't been able to find much on the kolbra's. I have #15, I believ e it is the king kolbra model because of the wider nose? From what I can gather there was kolbras, and king kolbras same but with wider nose, but not really sure . I really like the overall design though. Good luck on the build! -------- 912ul King Kolbra ;fun plane O300 Cessna 172B ;travel plane Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473850#473850 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Mark III Extra
Date: Oct 27, 2017
I am selling my Mark III extra factory built if one knows someone please let me know. 361-229-6061 chuckey TN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473901#473901 ________________________________________________________________________________
Date: Oct 27, 2017
I am selling my Mark III extra factory built if one knows someone please let me know. 361-229-6061 chuckey TN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473898#473898 ________________________________________________________________________________
Date: Oct 27, 2017
I am selling my Mark III extra factory built if one knows someone please let me know. 361-229-6061 chuckey TN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473899#473899 ________________________________________________________________________________
Date: Oct 27, 2017
I am selling my Mark III extra factory built if one knows someone please let me know. 361-229-6061 chuckey TN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473900#473900 ________________________________________________________________________________
Subject: First Flights Completed!
Date: Oct 29, 2017
Hi Everyone. Last weekend yielded the best weather I could have hoped for, warm,sunny and no winds to speak of. I took my FSII to nearby SFZ where from the Airport manager on down the line could not have been more friendly and welcoming. They set the stage for what was a great experience. I got things together, taxied out to the 5000' runway added power and off I went. I planned using 55mph for climbout and was amazed at how quicly it accelerated and climbed at that speed. Iflew around to get a feel for slow speed handling and found it stalled at 40mph dropping the right wing. Using flaps (yes my FSII has flaps) yeilded only slightly slower (38)stall with a more pronounced wing drop. Flaps were not used for remainder of flights. Landing approach was done at 55mph which setup a reasonable decent. Reaching around 50" I added power to arrest decent, with a flare around 10' settle to runway and BAM! right up on my nose. [Rolling Eyes] Lesson learned is make sure you put your size 10 heels in front of the heel brakes, not in front where comfort dictates. No real damage other than to pride and bent antena and road rash on cowl. As of yesterday I've put in 8 hrs of time with a mix of landings from dropping in and respectable. the gear may have suffer from some. Any way to straightren aluminum gear? Whats the options and possible vendors? ...Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473932#473932 ________________________________________________________________________________
Date: Oct 29, 2017
Subject: Re: First Flights Completed!
""Lesson learned is make sure you put your size 10 heels ! in front of the heel brakes, not in front where comfort dictates."" If your heals are hitting the brakes at the same time your toes are on the rudder pedals....... Here is an idea to think on,,,, only an idea.... If you shorten the rudder cables it should bring the top of the rudder pedals closer to you / or more over the top of the brakes. Now in order to hit the brakes you will have to pull your toes back towards you in order to reach the brakes with your heals... So if an event requires you need both, you won't have to lift your heals over the pedals waisting time... Or on the other side of things you could reposition the brakes further forward... Either way the geometry would be the same. The choice may depend on the legnth of your legs and which is more comfortable. Just think on it. Boyd Young On Oct 29, 2017 9:37 AM, "RoHam" wrote: > > Hi Everyone. > Last weekend yielded the best weather I could have hoped for, warm,sunny > and no winds to speak of. I took my FSII to nearby SFZ where from the > Airport manager on down the line could not have been more friendly and > welcoming. They set the stage for what was a great experience. I got things > together, taxied out to the 5000' runway added power and off I went. I > planned using 55mph for climbout and was amazed at how quicly it > accelerated and climbed at that speed. Iflew around to get a feel for slow > speed handling and found it stalled at 40mph dropping the right wing. Using > flaps (yes my FSII has flaps) yeilded only slightly slower (38)stall with a > more pronounced wing drop. Flaps were not used for remainder of flights. > Landing approach was done at 55mph which setup a reasonable decent. > Reaching around 50" I added power to arrest decent, with a flare around > 10' settle to runway and BAM! right up on my nose. [Rolling Eyes] Lesson > learned is make sure you put your size 10 heels ! > in front of the heel brakes, not in front where comfort dictates. No > real damage other than to pride and bent antena and road rash on cowl. As > of yesterday I've put in 8 hrs of time with a mix of landings from dropping > in and respectable. the gear may have suffer from some. Any way to > straightren aluminum gear? Whats the options and possible vendors? ...Bob > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473932#473932 > > ________________________________________________________________________________
Date: Oct 29, 2017
From: william sullivan <williamtsullivan(at)att.net>
The gear can be straightened. Most people use a cheap hydraulic press (Harbor Freight) or a home made jug with a hydraulic jack. Some guys get a set of spare legs from Kolb. Others have made steel legs, but if you are still learning, the aluminum ones put less shock on the airframe in case of a goof. Bill Sullivan Windsor Locks, Ct. -------------------------------------------- On Sun, 10/29/17, RoHam wrote: Subject: Kolb-List: First Flights Completed! No real damage other than to pride and bent antena and road rash on cowl. As of yesterday I've put in 8 hrs of time with a mix of landings from dropping in and respectable. the gear may have suffer from some. Any way to straightren aluminum gear? Whats the options and possible vendors? ...Bob ________________________________________________________________________________
Date: Oct 29, 2017
Wait until Harbor Freight puts this on sale, fix it yourself. https://www.harborfreight.com/12-ton-hydraulic-pipe-bender-62539.html In the meanwhile, take the leg to any machine shop, they can straighten it for about $20 if it is not badly bent. Attached is my collection of old Firestar/FSII gear legs. The top set is from the original Firestar from which we built the FF clone, and I would consider them un-straightenable. The next 3 down all have slight bends and could easily be fixed with a press in just a few minutes. The bottom one is unbent. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough. Being forgiven is wonderful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473937#473937 Attachments: http://forums.matronics.com//files/p1060418_medium_140.jpg ________________________________________________________________________________
Subject: Re: First Flights Completed! (gear leg question)
Date: Oct 29, 2017
Looking at Richard's pics of gear legs; has anyone ever made a set of steel legs that don't have any taper? In the RV-x world, the Harmon Rockets use titanium legs with no taper, but supposedly, titanium's flexing characteristics are different enough from steel that they can get away with no taper. Making an axle adapter to fit the fatter leg cross section wouldn't be that big a deal, but I'm not sure about transferring extra impulse load directly into the gear sockets if using non-tapered gear. Thanks, Charlie On 10/29/2017 12:52 PM, Richard Pike wrote: > > Wait until Harbor Freight puts this on sale, fix it yourself. > https://www.harborfreight.com/12-ton-hydraulic-pipe-bender-62539.html > In the meanwhile, take the leg to any machine shop, they can straighten it for about $20 if it is not badly bent. > > Attached is my collection of old Firestar/FSII gear legs. The top set is from the original Firestar from which we built the FF clone, and I would consider them un-straightenable. The next 3 down all have slight bends and could easily be fixed with a press in just a few minutes. The bottom one is unbent. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough. Being forgiven is wonderful. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473937#473937 > > > Attachments: > > http://forums.matronics.com//files/p1060418_medium_140.jpg > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 29, 2017
Hello to fellow Kolb owners. Name is John from Northern California, just completed a FS ll and have been reading all your great comments about building and flying for about 2 yrs. while finishing my project. I'll be asking for lots of advice. Listening in on the gear leg issue...I was wondering if any sort of bungee cord arrangement like those found on bush planes could absorb some hard landings, maybe a spring steel leg? ( Maybe steal the front shock struts off my wife's car) Sent from my iP > On Oct 29, 2017, at 12:29 PM, Charlie England wrote: > > > Looking at Richard's pics of gear legs; has anyone ever made a set of steel legs that don't have any taper? In the RV-x world, the Harmon Rockets use titanium legs with no taper, but supposedly, titanium's flexing characteristics are different enough from steel that they can get away with no taper. Making an axle adapter to fit the fatter leg cross section wouldn't be that big a deal, but I'm not sure about transferring extra impulse load directly into the gear sockets if using non-tapered gear. > > Thanks, > > Charlie > >> On 10/29/2017 12:52 PM, Richard Pike wrote: >> >> Wait until Harbor Freight puts this on sale, fix it yourself. >> https://www.harborfreight.com/12-ton-hydraulic-pipe-bender-62539.html >> In the meanwhile, take the leg to any machine shop, they can straighten it for about $20 if it is not badly bent. >> >> Attached is my collection of old Firestar/FSII gear legs. The top set is from the original Firestar from which we built the FF clone, and I would consider them un-straightenable. The next 3 down all have slight bends and could easily be fixed with a press in just a few minutes. The bottom one is unbent. >> >> -------- >> Richard Pike >> Kolb MKIII N420P (420ldPoops) >> Kingsport, TN 3TN0 >> >> Forgiving is tough. Being forgiven is wonderful. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=473937#473937 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/p1060418_medium_140.jpg >> > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > > ________________________________________________________________________________
Date: Oct 29, 2017
Yes, sir. We have been flying Kolbs off heat treated 4130 steel legs for more than 30 years. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of jpfitt Sent: Sunday, October 29, 2017 2:58 PM Subject: Re: Kolb-List: Re: First Flights Completed! (gear leg question) Hello to fellow Kolb owners. Name is John from Northern California, just completed a FS ll and have been reading all your great comments about building and flying for about 2 yrs. while finishing my project. I'll be asking for lots of advice. Listening in on the gear leg issue...I was wondering if any sort of bungee cord arrangement like those found on bush planes could absorb some hard landings, maybe a spring steel leg? ( Maybe steal the front shock struts off my wife's car) Sent from my iP > On Oct 29, 2017, at 12:29 PM, Charlie England wrote: > > --> > > Looking at Richard's pics of gear legs; has anyone ever made a set of steel legs that don't have any taper? In the RV-x world, the Harmon Rockets use titanium legs with no taper, but supposedly, titanium's flexing characteristics are different enough from steel that they can get away with no taper. Making an axle adapter to fit the fatter leg cross section wouldn't be that big a deal, but I'm not sure about transferring extra impulse load directly into the gear sockets if using non-tapered gear. > > Thanks, > > Charlie > >> On 10/29/2017 12:52 PM, Richard Pike wrote: >> --> >> >> Wait until Harbor Freight puts this on sale, fix it yourself. >> https://www.harborfreight.com/12-ton-hydraulic-pipe-bender-62539.html >> In the meanwhile, take the leg to any machine shop, they can straighten it for about $20 if it is not badly bent. >> >> Attached is my collection of old Firestar/FSII gear legs. The top set is from the original Firestar from which we built the FF clone, and I would consider them un-straightenable. The next 3 down all have slight bends and could easily be fixed with a press in just a few minutes. The bottom one is unbent. >> >> -------- >> Richard Pike >> Kolb MKIII N420P (420ldPoops) >> Kingsport, TN 3TN0 >> >> Forgiving is tough. Being forgiven is wonderful. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=473937#473937 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/p1060418_medium_140.jpg >> > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > > --- This email has been checked for viruses by AVG. http://www.avg.com ________________________________________________________________________________
Date: Oct 29, 2017
-----Original Message----- From: John Hauck [mailto:jhauck(at)elmore.rr.com] Sent: Sunday, October 29, 2017 3:39 PM Subject: FW: Kolb-List: Re: First Flights Completed! (gear leg question) Subject: RE: Kolb-List: Re: First Flights Completed! (gear leg question) To answer Charlies's question, yes, there are a lot of straight 4130 Kolb g ear legs out there. My Brother Jim and I fabricated a set of non-tapered 4130 legs for my origi nal Firestar in 1987. That is all I have flown on since. In fact, we used parts of the FS legs to build legs for my current MKIII in 1991. Don't know of any other Kolbs with steel legs back then. Homer and Dennis were interested at the time. Just another trick Jim and John Hauck came up with. ;-) Old Kolb designed a tapered solid 4130 leg that was not near t he performer ours was/is. New Kolb came up with non-tapered legs with a be nd to get the nose of the Kolbs higher and in a better 3 point stance. John Bickham designed and built the first set of non-tapered 4130 legs with bend for his MKIII, before New Kolb copied his design, or should I say ca me up with legs just like John B's. ;-) Should be lots of info on the steel legs in the Kolb List Archives. I'll see if I can find a photo of the FS and MKIII legs and attach. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@m atronics.com] On Behalf Of Charlie England Sent: Sunday, October 29, 2017 2:29 PM Subject: Re: Kolb-List: Re: First Flights Completed! (gear leg question) Looking at Richard's pics of gear legs; has anyone ever made a set of steel legs that don't have any taper? In the RV-x world, the Harmon Rockets use titanium legs with no taper, but supposedly, titanium's flexing characteris tics are different enough from steel that they can get away with no taper. Making an axle adapter to fit the fatter leg cross section wouldn't be that big a deal, but I'm not sure about transferring extra impulse load directl y into the gear sockets if using non-tapered gear. Thanks, Charlie On 10/29/2017 12:52 PM, Richard Pike wrote: > --> > > Wait until Harbor Freight puts this on sale, fix it yourself. > https://www.harborfreight.com/12-ton-hydraulic-pipe-bender-62539.html > In the meanwhile, take the leg to any machine shop, they can straighten i t for about $20 if it is not badly bent. > > Attached is my collection of old Firestar/FSII gear legs. The top set is from the original Firestar from which we built the FF clone, and I would co nsider them un-straightenable. The next 3 down all have slight bends and co uld easily be fixed with a press in just a few minutes. The bottom one is u nbent. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough. Being forgiven is wonderful. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473937#473937 > > > Attachments: > > http://forums.matronics.com//files/p1060418_medium_140.jpg > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus --- This email has been checked for viruses by AVG. http://www.avg.com ________________________________________________________________________________
Date: Oct 29, 2017
....So the aluminum legs will sooner or later become a lost cause? Sent from my iPad > On Oct 29, 2017, at 1:33 PM, John Hauck wrote: > > > Yes, sir. We have been flying Kolbs off heat treated 4130 steel legs for > more than 30 years. > > john h > mkIII > Titus, Alabama > > > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of jpfitt > Sent: Sunday, October 29, 2017 2:58 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: First Flights Completed! (gear leg question) > > > Hello to fellow Kolb owners. Name is John from Northern California, just > completed a FS ll and have been reading all your great comments about > building and flying for about 2 yrs. while finishing my project. I'll be > asking for lots of advice. > Listening in on the gear leg issue...I was wondering if any sort of bungee > cord arrangement like those found on bush planes could absorb some hard > landings, maybe a spring steel leg? ( Maybe steal the front shock struts off > my wife's car) > > Sent from my iP > >> On Oct 29, 2017, at 12:29 PM, Charlie England > wrote: >> >> --> >> >> Looking at Richard's pics of gear legs; has anyone ever made a set of > steel legs that don't have any taper? In the RV-x world, the Harmon Rockets > use titanium legs with no taper, but supposedly, titanium's flexing > characteristics are different enough from steel that they can get away with > no taper. Making an axle adapter to fit the fatter leg cross section > wouldn't be that big a deal, but I'm not sure about transferring extra > impulse load directly into the gear sockets if using non-tapered gear. >> >> Thanks, >> >> Charlie >> >>> On 10/29/2017 12:52 PM, Richard Pike wrote: >>> --> >>> >>> Wait until Harbor Freight puts this on sale, fix it yourself. >>> https://www.harborfreight.com/12-ton-hydraulic-pipe-bender-62539.html >>> In the meanwhile, take the leg to any machine shop, they can straighten > it for about $20 if it is not badly bent. >>> >>> Attached is my collection of old Firestar/FSII gear legs. The top set is > from the original Firestar from which we built the FF clone, and I would > consider them un-straightenable. The next 3 down all have slight bends and > could easily be fixed with a press in just a few minutes. The bottom one is > unbent. >>> >>> -------- >>> Richard Pike >>> Kolb MKIII N420P (420ldPoops) >>> Kingsport, TN 3TN0 >>> >>> Forgiving is tough. Being forgiven is wonderful. >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=473937#473937 >>> >>> >>> >>> >>> Attachments: >>> >>> http://forums.matronics.com//files/p1060418_medium_140.jpg >>> >> >> >> --- >> This email has been checked for viruses by Avast antivirus software. >> https://www.avast.com/antivirus >> >> >> >> > > > > > > > --- > This email has been checked for viruses by AVG. > http://www.avg.com > > > > ________________________________________________________________________________
Subject: Twinstar MKII
Date: Oct 29, 2017
Good afternoon Kolbers. I have a Twinstar MKII that I am redoing and looking for some pointers on the aft cage tubing bending and fastening. I have scoured the build manual and plans and photo build manual and don't find any details on the shape to bend the tubing to. Riveting and gusseting is described but nothing on shaping. Any and all input will be greatly appreciated. Thanks in advance. -------- Mark Twinstar MKII Great Bend, PA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473945#473945 ________________________________________________________________________________
Date: Oct 29, 2017
I think so. The reason we "lost" 7075 alum legs 30 years ago. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of jpfitt Sent: Sunday, October 29, 2017 3:48 PM Subject: Re: Kolb-List: Re: First Flights Completed! (gear leg question) ....So the aluminum legs will sooner or later become a lost cause? Sent from my iPad > On Oct 29, 2017, at 1:33 PM, John Hauck wrote:
August 20, 2017 - October 29, 2017
Kolb-Archive.digest.vol-op
