Kolb-Archive.digest.vol-os
February 22, 2018 - March 28, 2018
      And prevent a gear collapse.
      For what it=99s worth !
      roy
      On Tuesday, February 20, 2018, Rick Neilsen  wrote:
      > The duty of both steel and aluminum gear legs is to absorb landing
      > stresses by flexing. Aluminum legs flex which is good but don't flex as f
      ar
      > before they stay flexed. Restricting the flexing will transfer the landin
      g
      > loads to the plane where other not so evident damage might occur on a har
      d
      > landing. I don't think you would want brace any Kolb gear leg. There migh
      t
      > a benefit to dampen the spring back on some of the more springy steel gea
      r
      > legs.
      > Rick Neilsen
      > Redrive VW PoweredMKIIIC
      > On Tue, Feb 20, 2018 at 12:32 PM, Dan Breitigam  wrote:
      >> Hi guys,
      >> Regarding the gear leg comments; has anyone tried bracing aluminum gear
      >> legs with cables?  Would it be worth trying?
      >> Thanks.
      >> Kolb Mk III
      >> Geo Metro 1.3L
      >> Chattanooga
      >> http://forums.matronics.com/viewtopic.php?p=478137#478137
      >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/
      >> Navigator?Kolb-List
      >> FORUMS -
      >> eferrer" target="_blank">http://forums.matronics.com
      >> WIKI -
      >> errer" target="_blank">http://wiki.matronics.com
      >> b Site -
      >>           -Matt Dralle, List Admin.
      >> rel="noreferrer" target="_blank">http://www.matronics.com/contributi
      on
Subject: Re: Replacement tail rod...?
Date: Feb 22, 2018
http://www.jackbhart.com/firefly/firefly140.html Jack B. Hart. FF004 Winchester, IN ---------------------------------------- From: "Roy Spangler" <roy.spangler(at)kirtland.edu> Sent: Thursday, February 22, 2018 10:26 AM Subject: Re: Kolb-List: Re: Replacement tail rod...? Cables are a safety for a hard landing at worst they would lessen a bad lan ding And prevent a gear collapse. For what it's worth ! roy On Tuesday, February 20, 2018, Rick Neilsen wrote: The duty of both steel and aluminum gear legs is to absorb landing stresse s by flexing. Aluminum legs flex which is good but don't flex as far before they stay flexed. Restricting the flexing will transfer the landing loads to the plane where other not so evident damage might occur on a hard landin g. I don't think you would want brace any Kolb gear leg. There might a bene fit to dampen the spring back on some of the more springy steel gear legs. Rick Neilsen Redrive VW PoweredMKIIIC On Tue, Feb 20, 2018 at 12:32 PM, Dan Breitigam wrote: Hi guys, Regarding the gear leg comments; has anyone tried bracing aluminum gear leg s with cables? Would it be worth trying? Thanks. -------- Kolb Mk III Geo Metro 1.3L Chattanooga Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478137#478137 -List" rel="noreferrer" target="_blank">http://www.matronics.com/Naviga tor?Kolb-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 22, 2018
Roy, Where are you going to put these cables? The aluminum gear leg is solid, where does the cable go? What size cable are you proposing? 3/32" cable has a breaking strength of 960 lb. That's less than a 2G landing load on a MK III. 1/8" cable has a breaking strength of 2000 lb which is less than a 4G load and will most likely still break. 5/32" cable? Go as big as 3/16"? Now you're beginning to talk some serious weight. In the late '70's some hang glider manufacturers began offering swaged 1/8" cable (breaking strength 2,000 lb) hang straps instead of the 1" tubular nylon strap. Much less drag was the claim. No one had any idea of the loading on that cable, it just seemed like a good idea at the time. I don't know how many pilots died when the cable snapped but an emergency message was put into "Hang Gliding" magazine advising pilots to remove the cable and manufacturers took it off the options list. It seems that a pilot flying through the shear around a thermal could generate the necessary loading to snap it. Whoda thunk that? it's your airplane, do as you like, but do some testing to find out if it would really work as you think. Also give some thought to how you inspect and maintain them. 2 cents worth. Rick Girard <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&ut m_campaign=sig-email&utm_content=webmail> Virus-free. www.avg.com <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&ut m_campaign=sig-email&utm_content=webmail> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Thu, Feb 22, 2018 at 9:22 AM, Roy Spangler wrote: > Cables are a safety for a hard landing at worst they would lessen a bad > landing > And prevent a gear collapse. > > For what it=99s worth ! > > roy > > On Tuesday, February 20, 2018, Rick Neilsen wrote: > >> The duty of both steel and aluminum gear legs is to absorb landing >> stresses by flexing. Aluminum legs flex which is good but don't flex as far >> before they stay flexed. Restricting the flexing will transfer the landi ng >> loads to the plane where other not so evident damage might occur on a ha rd >> landing. I don't think you would want brace any Kolb gear leg. There mig ht >> a benefit to dampen the spring back on some of the more springy steel ge ar >> legs. >> >> Rick Neilsen >> Redrive VW PoweredMKIIIC >> >> On Tue, Feb 20, 2018 at 12:32 PM, Dan Breitigam wrote: >> >>> >>> Hi guys, >>> >>> Regarding the gear leg comments; has anyone tried bracing aluminum gear >>> legs with cables? Would it be worth trying? >>> >>> Thanks. >>> >>> -------- >>> Kolb Mk III >>> Geo Metro 1.3L >>> Chattanooga >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=478137#478137 >>> >>> >>> >>> >>> >>> >>> ========== >>> -List" rel="noreferrer" target="_blank">http://www.matronics.com/ >>> Navigator?Kolb-List >>> ========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contribut ion >>> ========== >>> >>> >>> >>> >> -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Feb 22, 2018
IMHO, and in accordance with what I have learned from engineers, the "spring gear" (steel or aluminum) has the advantage that it is the most simple and lowest parts count for a landing gear that can absorb any sort of impact. It also is often the lowest drag of typical gear systems. The spring gear is often not the lightest way to do it, and it is definitely not the best at absorbing (mitigating) the impact of landing. To actually absorb and mitigate the impact of landing, there needs to be some way of changing how that energy is stored/expended after the first impact.That of course is where the oleo struts, hydraulic fluid, metered orfices, check valves, etc. etc. come into play on more complicated aircraft. The designer(s) and engineer(s) at Kolb made the obvious and correct choice of simplicity and lower cost rather than complexity and higher cost. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Thu, 2/22/18, Roy Spangler wrote: Subject: Re: Kolb-List: Re: Replacement tail rod...? To: "kolb-list(at)matronics.com" Date: Thursday, February 22, 2018, 7:22 AM Cables are a safety for a hard landing at worst they would lessen a bad landingAnd prevent a gear collapse. For what its worth ! roy On Tuesday, February 20, 2018, Rick Neilsen wrote: The duty of both steel and aluminum gear legs is to absorb landing stresses by flexing. Aluminum legs flex which is good but don't flex as far before they stay flexed. Restricting the flexing will transfer the landing loads to the plane where other not so evident damage might occur on a hard landing. I don't think you would want brace any Kolb gear leg. There might a benefit to dampen the spring back on some of the more springy steel gear legs. Rick NeilsenRedrive VW PoweredMKIIIC On Tue, Feb 20, 2018 at 12:32 PM, Dan Breitigam wrote: "Dan Breitigam" Hi guys, Regarding the gear leg comments; has anyone tried bracing aluminum gear legs with cables? Would it be worth trying? Thanks. -------- Kolb Mk III Geo Metro 1.3L Chattanooga Read this topic online here: http://forums.matronics.com/vi ewtopic.php?p=478137#478137 ===== ===== -List" rel="noreferrer" target="_blank">http://www. matronics.com/Navigator?Kolb- List ===== ===== FORUMS - eferrer" target="_blank">http://forums. matronics.com ===== ===== WIKI - errer" target="_blank">http://wiki. matronics.com ===== ===== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www. matronics.com/contribution ===== ===== ________________________________________________________________________________
Subject: Landing Gear Cables
Date: Feb 22, 2018
Seems to me attaching cables to the gear legs defeats the purpose of rod or tubular spring landing gear legs. Spring gear and large low pressure tires take a lot of load off the airframe experienced during hard landings. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Roy Spangler Sent: Thursday, February 22, 2018 9:22 AM Subject: Re: Kolb-List: Re: Replacement tail rod...? Cables are a safety for a hard landing at worst they would lessen a bad landing And prevent a gear collapse. For what it=99s worth ! roy ________________________________________________________________________________
Date: Feb 22, 2018
Jack H's cables will probably prevent spreading the main gear, but effectively kill the suspension. It has been proven over and over again, the 1" 7075 aluminum gear legs are inadequate for the FF, as well as the original Firestar. During taxi to take off for the first time in my FS, the 1" aluminum legs bent before I had a chance to fly. I have to admit my airstrip at that time was not the smoothest, but in my estimation should never have bent those little aluminum legs. To overcome that weakness we need suitable replacements that will perform satisfactorily. This will add weight and Jack H does not want to do that I am sure. I have never been a fan of wire bracing on Kolb main gear legs. Kolbs are prone to nose over because Homer Kolb designed them to carry most of their weight on the main gear and very little on the tail wheel. This gives them the great characteristic of very easy ground handling. Bad enough taxiing on high grass and weeds. Add wires and it is a guarantee you'll put it on its nose, like landing in soy beans. ;-) john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack Hart Sent: Thursday, February 22, 2018 9:59 AM Subject: Re: Kolb-List: Re: Replacement tail rod...? http://www.jackbhart.com/firefly/firefly140.html Jack B. Hart. FF004 Winchester, IN ________________________________________________________________________________
Date: Feb 22, 2018
John, II don't understand your statement. I have pretty much flown from improved strips. The cables are designed to help in the case of a "plop" and do nothing to prevent the gear from flexing or bending front to back. If you drop a wheel into a hole, the leg will bend just as it would before the cable system was installed and protects the fuselage from being damaged. If I recall correctly, the whole works weighed a few ounces. I put up the previous jump to show that cables could be used to keep the gear from spreading, and that no modifications need to be made to the existing structures. $20 spent and the time required to fabricate parts seemed like a good trade off in comparison to straightening and/or installing new legs. http://www.jackbhart.com/firefly/firefly134.html In case you missed it, I put up the above jump so that you can view the analysis that was done to determine if adding cables would be beneficial. The calculations indicated the original leg would start to bend at 1.8 G in a level straight two wheel plop. With the cable system in place and assuming a plop hard enough to cause cable failure, the cable and gear leg system will withstand a 5.2 G plop. Jack B. Hart, FF004 Winchester, IN ---------------------------------------- From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Thursday, February 22, 2018 12:18 PM Subject: RE: Kolb-List: Re: Replacement tail rod...? Jack H's cables will probably prevent spreading the main gear, but effectively kill the suspension. ________________________________________________________________________________
Date: Feb 22, 2018
After bending a couple set of legs I went to Jacks wire bracing but added 4 chevy valve springs (2 per side) in the cables. This has been working well for my lack of gracefull landing talent. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478207#478207 ________________________________________________________________________________
Date: Feb 23, 2018
The addition of VGs does more for landing gracefully than anything short of skill.I have the old spring steel tapered gear legs, and I like them. G.Aman MK3C Jabiru 2200A 1100 hrs > On Feb 22, 2018, at 9:26 PM, west1m wrote: > > > After bending a couple set of legs I went to Jacks wire bracing but added 4 chevy valve springs (2 per side) in the cables. This has been working well for my lack of gracefull landing talent. > > -------- > West1m > Hastings, MN > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478207#478207 > > > > > > > > > ________________________________________________________________________________
Date: Feb 25, 2018
John, I don't understand your statement. The cables are designed to help in the case of a "plop" and do nothing to prevent the gear from flexing or bending front to back and/or inward. If you drop a wheel into a hole, the leg will bend just as it would before the cable system was installed and protects the fuselage from being damaged. If I recall correctly, the whole works weighed a few ounces. I put up the previous jump to show that no modifications need to be made to the existing structures and that cables could be used to keep the gear from spreading. $20 spent and the time required to fabricate parts seemed like a good trade off in comparison to straightening and/or purchasing and installing new legs. http://www.jackbhart.com/firefly/firefly134.html In case you missed it, I put up the above jump so that you can view the analysis that was done to determine if adding cables would be beneficial. These calculations indicated the original leg would start to bend at 1.8 G in a level straight two wheel plop. With the cable system in place and assuming a plop hard enough to cause cable failure, the cable and gear leg system will withstand a 5.2 G plop. Jack B. Hart, FF004 Winchester, IN ---------------------------------------- From: "John Hauck" Sent: Thursday, February 22, 2018 12:18 PM To: kolb-list(at)matronics.com Subject: RE: Kolb-List: Re: Replacement tail rod...? Jack H's cables will probably prevent spreading the main gear, but effectively kill the suspension. ________________________________________________________________________________
Date: Feb 25, 2018
Jack H/Kolbers: By adding cables and restricting outward flex of the gear legs, your modification effectively kills the spring in the direction it is needed most, outward. To me, what you have done is change flexible gear to rigid gear. I went to 1 1/8" 7075 after my initial taxi when I bent the 1" 7075 legs before I got a chance to fly. 1 1/8" didn't hack it either, which proved to me that 7075 rod didn't make good spring gear. Heat treated 4130 has proven much better, although I can bend them too when I try. Spring gear is much easier on the aircraft than rigid. >From the photo of your airplane, it is obvious you landed on the right gear, putting all the load on one leg. I do that too, but on the left leg. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack Hart Sent: Sunday, February 25, 2018 4:59 PM Subject: Kolb-List: Re: Replacement tail rod...? John, I don't understand your statement. The cables are designed to help in the case of a "plop" and do nothing to prevent the gear from flexing or bending front to back and/or inward. If you drop a wheel into a hole, the leg will bend just as it would before the cable system was installed and protects the fuselage from being damaged. If I recall correctly, the whole works weighed a few ounces. I put up the previous jump to show that no modifications need to be made to the existing structures and that cables could be used to keep the gear from spreading. $20 spent and the time required to fabricate parts seemed like a good trade off in comparison to straightening and/or purchasing and installing new legs. http://www.jackbhart.com/firefly/firefly134.html In case you missed it, I put up the above jump so that you can view the analysis that was done to determine if adding cables would be beneficial. These calculations indicated the original leg would start to bend at 1.8 G in a level straight two wheel plop. With the cable system in place and assuming a plop hard enough to cause cable failure, the cable and gear leg system will withstand a 5.2 G plop. Jack B. Hart, FF004 Winchester, IN ---------------------------------------- From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Thursday, February 22, 2018 12:18 PM Subject: RE: Kolb-List: Re: Replacement tail rod...? Jack H's cables will probably prevent spreading the main gear, but effectively kill the suspension. ________________________________________________________________________________
Date: Feb 26, 2018
John, I believe you have it right. The FireFly gear is rigid by design and the aluminum leg bends so easily. If you apply a 330 pound load in any direction at the axle, the leg will bend at just below the fuselage socket. By adding the cable I have, indeed, reduced one degree of flexsure and gained some freedom from plops. As for the photo, it is difficult to tell if it was or was not a level plop. At the time it felt like it was. Both legs had to be straightened. It could be that the right tire broke loose from the asphalt first. Jack B Hart FF004 Winchester, IN ---------------------------------------- From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Sunday, February 25, 2018 7:28 PM Subject: RE: Kolb-List: Re: Replacement tail rod...? Jack H/Kolbers: By adding cables and restricting outward flex of the gear legs, your modification effectively kills the spring in the direction it is needed most, outward. To me, what you have done is change flexible gear to rigid gear. Spring gear is much easier on the aircraft than rigid. >From the photo of your airplane, it is obvious you landed on the right gear, putting all the load on one leg. I do that too, but on the left leg. ________________________________________________________________________________
Date: Feb 26, 2018
To the best of my knowledge, the only aircraft Homer Kolb designed with rigid gear was the Flyer and the Ultrastar. The Firestar was the first to have flexible main gear legs. The gear legs were designed to be flexible, to give the aircraft landing gear some spring suspension to take landing and ground handling loads off the airframe. All Kolb aircraft models from the Firestar on are designed with spring landing gear legs, flexible, not rigid. The rigid gear on my Ultrastar was not forgiving in the least. On my first landing in my unimproved cow pasture airstrip, my roll out took me across a cow path (rut) that took out the main gear, my prop, and the little turned up nose skid of the airframe. Del Cross, who flew a Kolb Flyer at Sun and Fun and Lakeland, upgraded his rigid main gear to 7075 aluminum rod, making them longer to get the nose of the Flyer out of its normal level attitude on the ground. Del was killed when his Flyer crashed some years ago. RIP. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack Hart Sent: Sunday, February 25, 2018 11:11 PM Subject: RE: Kolb-List: Re: Replacement tail rod...? John, I believe you have it right. The FireFly gear is rigid by design and the aluminum leg bends so easily. If you apply a 330 pound load in any direction at the axle, the leg will bend at just below the fuselage socket. By adding the cable I have, indeed, reduced one degree of flexsure and gained some freedom from plops. As for the photo, it is difficult to tell if it was or was not a level plop. At the time it felt like it was. Both legs had to be straightened. It could be that the right tire broke loose from the asphalt first. Jack B Hart FF004 Winchester, IN _____ From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Sunday, February 25, 2018 7:28 PM Subject: RE: Kolb-List: Re: Replacement tail rod...? Jack H/Kolbers: By adding cables and restricting outward flex of the gear legs, your modification effectively kills the spring in the direction it is needed most, outward. To me, what you have done is change flexible gear to rigid gear. Spring gear is much easier on the aircraft than rigid. >From the photo of your airplane, it is obvious you landed on the right gear, putting all the load on one leg. I do that too, but on the left leg. ________________________________________________________________________________
Date: Feb 26, 2018
John, If the below is so, why is it that the FireFly legs bend in a 1.8 G plop? Jack B. Hart FF004 Winchester, IN ---------------------------------------- From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Monday, February 26, 2018 9:06 AM Subject: RE: Kolb-List: Re: Replacement tail rod...? All Kolb aircraft models from the Firestar on are designed with spring landing gear legs, flexible, not rigid. ________________________________________________________________________________
Date: Feb 26, 2018
Springs are flexible to a point. When overstressed they bend or break. That's how my springs work. Isn't that how your springs work? Didn't your gear legs flex to the point you over stressed and bent them? I've flown with a G Meter since my Firestar days. If you sneeze while taxiing, you'll get 2 or 3 Gs very easily. Jack H is wearing me out. I quit. ;-) john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack Hart Sent: Monday, February 26, 2018 9:30 AM Subject: RE: Kolb-List: Re: Replacement tail rod...? John, If the below is so, why is it that the FireFly legs bend in a 1.8 G plop? Jack B. Hart FF004 Winchester, IN _____ From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Monday, February 26, 2018 9:06 AM Subject: RE: Kolb-List: Re: Replacement tail rod...? All Kolb aircraft models from the Firestar on are designed with spring landing gear legs, flexible, not rigid. ________________________________________________________________________________
Date: Feb 26, 2018
After having made numerous landing gears out of fiberglass, carbon fiber, etc.... the world's largest manufacturer of landing gears for light aircraft (Grove) uses 7075-T6 exclusively. Using a direct comparison between MATERIAL PROPERTIES, the 7075 has better stress/strain/yield/weight and all that high brain function engineering stuff I don't understand. But when you put a FIXED CROSS SECTION into the mix, things change. For a given size, thickness, or diameter, then steel starts to show its advantages. A few years ago I took over the FAA "STC" approval for changing the tricycle gear Cessna 172 back into a tailwheel configuration (like the Cessna 170). As part of that process, I learned a whole lot about this stuff, thanks to an old gray engineer who was kind enough to put up with my lack of a formal engineering education. We wanted to replace the steel Cessna main gear legs with aluminum, because the exact steel alloy that Cessna used was a special order from a steel mill. So my engineer did a bunch of calculations, and he figured out that to replace a 13/16" thick spring steel main gear, we needed a 1.25" thick piece of 7075-T6 aluminum... to get the same spring properties, energy absorbtion, and impact capability. How is this relevant to a discussion about Kolb landing gears? Because on a Kolb aircraft the size of the main gear is always limited to the size of the round socket tube that Kolb builds in to the fuselages. With a given size fuselage socket tube, if you want or need a "stronger" main gear than the original 7075 Kolb gear leg, you have no choice but to change materials and use steel. (even carbon fiber wouldn't help you because you would need a 2 inch socket tube to make the gear out of carbon.) So John H made the only upgrade that was legitimately possible, by moving from aluminum to steel. Kolb figured this out at some point when they wanted to build heavier two seat airplanes,a nd they went to hardened steel as well. For the people who are obsessed with weight, or who are on a quest to meet Part 103 weight, then aluminum or carbon is worth pursuing, but to really be able to use those materials you would need to increase the diameter of the socket tube in the fuselage. That would be quite a project ! Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities ________________________________________________________________________________
Subject: oratex covering material
Date: Mar 01, 2018
I was researching Oratex covering for my MK3 Classic, does anyone have any experience with this product? please share... thank you -------- kenw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478330#478330 ________________________________________________________________________________
Subject: Re: oratex covering material
Date: Mar 01, 2018
I used the PolyFiber method but The July, 2014 issue of Kitplanes had a very good article on oratex. Google oratex kitplanes and it should come up. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478333#478333 ________________________________________________________________________________
Date: Mar 01, 2018
I have used this material on R/C model airplanes many times, not yet on a full-size aircraft. Reportedly, Oratex is significantly lighter and easier to use than the other systems (Stits Poly Fiber, Ceconite, etc.). More expensive UNTIL you compare the actual overall cost and time of the older systems. If your time is worth any more than two dollars an hour, Oratex should be a bargain even with the higher initial cost. Remember the "price" of Oratex includes all the dope, silver UV, and color paint. Another very well liked "new" alternative is the Stewart Systems, which is water based and relatively inexpensive. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Thu, 3/1/18, Rex Rodebush wrote: Subject: Kolb-List: Re: oratex covering material To: kolb-list(at)matronics.com Date: Thursday, March 1, 2018, 9:35 AM Rodebush" I used the PolyFiber method but The July, 2014 issue of Kitplanes had a very good article on oratex. Google oratex kitplanes and it should come up. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478333#478333 The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Mar 01, 2018
victorbravo(at)sbcglobal. wrote: > > > . S . N . I . P . > > Another very well liked "new" alternative is the Stewart Systems, which is water based and relatively inexpensive. > > Bill Berle > > . S . N . I . P . > > Direct quote from the Stewart System Web Site: "Our new, breakthrough coatings are not "water-based"-- they're waterborne. " Helped re-covering of an Aeronca Chief and a Piper J3 Cub using the Stewart System. -------- George Alexander FS II R503 E-LSA N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478338#478338 ________________________________________________________________________________
Date: Mar 02, 2018
I am building a Firefly and am going to cover with ORATEX I bought the sample package from the and used it to cover a piece of a rudder that I had laying around the barn it worked great I was using an unmeasured heat gun and got one piece too hot turned a little brown ( it was. Cub yellow) but it was much easier than stitts which I covered my Firestar with 25 years ago there is no Oder from the materials no coating after coating I would suggest you buy the sample kit $25 and experience it yourself if you dont have all the machinery needed to do Stitts you might come out about even using Oratex as the air movers and compressor are not needed you could do it in your house without exposing yourself or your family to all those fumes ! Just my 2cents Chris Davis Sent from my iPhone > On Mar 1, 2018, at 8:31 AM, kenw wrote: > > > I was researching Oratex covering for my MK3 Classic, does anyone have any experience with this product? please share... thank you > > -------- > kenw > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478330#478330 > > > > > > > > > ________________________________________________________________________________
Subject: Ultrastar covering
Date: Mar 05, 2018
For Jeff, do you have any photos of your Ultrastar that you covered. I am p laning on doing the same to mine before I put the fiberglass pod on the nos e. Al, Elkton Mi Get Outlook for Android ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 6 Msgs - 03/01/18
Date: Mar 05, 2018
John, I have had good luck with using the headlight polishing kits that are sold at auto parts stores. The kits are not expensive compared to a new windshield. Try it on the windshield in a small area and see if it helps out. Jack B. Hart FF004 Winchester, IN ---------------------------------------- From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Sunday, March 4, 2018 1:02 PM Subject: RE: Kolb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 Chris D/Kolbers: -----my 1992 MKIII, is in need of a lot of cosmetic TLC, especially the glass. The windshield has started crazing which gives it the diamond glare effect when flying into the sun. ________________________________________________________________________________
Date: Mar 05, 2018
Jack H/Kolbers: Doubt the polishing kit would correct my problem. The failure is in the generic polycarbonate I used last time I replaced windshield and doors. I think if I had stuck with more expensive GE Lexan, I wouldn't be having this problem. Right now I am scratching my head to figure out why this polycarbonate failed. One possibility is a reaction to the last windshield cover I made about 4 or 5 years ago. I found some heavy material, similar to Naugahyde, at a local fabric shop. I was tired of making new covers out of plastic table cloths every year. My thought is there was a chemical reaction from the gassing of the material used to make the material. Maybe not. I don't know. Darn shame though. The surface of the polycarbonate is in great shape. Thanks for the suggestion. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack Hart Sent: Monday, March 05, 2018 10:13 AM Subject: RE: Kolb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 John, I have had good luck with using the headlight polishing kits that are sold at auto parts stores. The kits are not expensive compared to a new windshield. Try it on the windshield in a small area and see if it helps out. Jack B. Hart FF004 Winchester, IN _____ From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Sunday, March 4, 2018 1:02 PM Subject: RE: Kolb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 Chris D/Kolbers: -----my 1992 MKIII, is in need of a lot of cosmetic TLC, especially the glass. The windshield has started crazing which gives it the diamond glare effect when flying into the sun. ________________________________________________________________________________
Date: Mar 05, 2018
Subject: : Kolb-List:Windshield plastic crazing
John H and Kolb List, I'm no expert on the polycarbonates or acrylics, but could this crazing be from internal stress over time? Meaning that when you take a flat sheet and bend it into a curve, then fasten it down into that curved position (the shape of the Kolb nose cone), there is a small stress put into the plastic. Over a long period of time, perhaps the stresses eventually cause the internal cracks or difference in transparency?? This is a wild-a$$ guess on my part. Most "airplane" windshields are thermoformed, heated until the plastic is soft, so perhaps the internal stress is not as much? If this is not a viable explanation, perhaps the previous suggestion of a bad batch of plastic is the likely answer IMHO. Most of the manufacturers have a website or some sort of tech help phone number where you can ask a technical question. They may have seen this problem before and have a useful answer. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Mon, 3/5/18, John Hauck wrote: Subject: RE: Kolb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 To: kolb-list(at)matronics.com Date: Monday, March 5, 2018, 9:11 AM #yiv8117676239 #yiv8117676239 -- _filtered #yiv8117676239 {panose-1:2 4 5 3 5 4 6 3 2 4;} _filtered #yiv8117676239 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #yiv8117676239 {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;} #yiv8117676239 #yiv8117676239 p.yiv8117676239MsoNormal, #yiv8117676239 li.yiv8117676239MsoNormal, #yiv8117676239 div.yiv8117676239MsoNormal {margin:0in;margin-bottom:.0001pt;font-size:12.0pt;} #yiv8117676239 a:link, #yiv8117676239 span.yiv8117676239MsoHyperlink {color:blue;text-decoration:underline;} #yiv8117676239 a:visited, #yiv8117676239 span.yiv8117676239MsoHyperlinkFollowed {color:purple;text-decoration:underline;} #yiv8117676239 p.yiv8117676239MsoAcetate, #yiv8117676239 li.yiv8117676239MsoAcetate, #yiv8117676239 div.yiv8117676239MsoAcetate {margin:0in;margin-bottom:.0001pt;font-size:8.0pt;} #yiv8117676239 span.yiv8117676239BalloonTextChar {} #yiv8117676239 span.yiv8117676239EmailStyle19 {color:#1F497D;} #yiv8117676239 span.yiv8117676239EmailStyle20 {color:#1F497D;} #yiv8117676239 span.yiv8117676239EmailStyle21 {color:#1F497D;} #yiv8117676239 .yiv8117676239MsoChpDefault {} _filtered #yiv8117676239 {margin:1.0in 1.0in 1.0in 1.0in;} #yiv8117676239 div.yiv8117676239WordSection1 {} #yiv8117676239 Jack H/Kolbers: Doubt the polishing kit would correct my problem. The failure is in the generic polycarbonate I used last time I replaced windshield and doors. I think if I had stuck with more expensive GE Lexan, I wouldn't be having this problem. Right now I am scratching my head to figure out why this polycarbonate failed. One possibility is a reaction to the last windshield cover I made about 4 or 5 years ago. I found some heavy material, similar to Naugahyde, at a local fabric shop. I was tired of making new covers out of plastic table cloths every year. My thought is there was a chemical reaction from the gassing of the material used to make the material. Maybe not. I don't know. Darn shame though. The surface of the polycarbonate is in great shape. Thanks for the suggestion. john hmkIIITitus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack Hart Sent: Monday, March 05, 2018 10:13 AM To: kolb-list(at)matronics.com Subject: RE: Kolb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 John, I have had good luck with using the headlight polishing kits that are sold at auto parts stores. The kits are not expensive compared to a new windshield. Try it on the windshield in a small area and see if it helps out.Jack B. Hart FF004Winchester, INFrom: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Sunday, March 4, 2018 1:02 PM To: kolb-list(at)matronics.com Subject: RE: Kolb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 Chris D/Kolbers:-----my 1992 MKIII, is in need of a lot of cosmetic TLC, especially the glass. The windshield has started crazing which gives it the diamond glare effect when flying into the sun. ________________________________________________________________________________
Date: Mar 05, 2018
Stress may very well be the culprit. Takes a lot of pressure to conform 1/8 polycarbonate to the nose pod and upper windshield frame. Doors are 1/16, but not much pressure to bend them to conform. Thanks for the suggestion. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Bill Berle Sent: Monday, March 05, 2018 12:28 PM Subject: RE: Kolb-List:Windshield plastic crazing John H and Kolb List, I'm no expert on the polycarbonates or acrylics, but could this crazing be from internal stress over time? Meaning that when you take a flat sheet and bend it into a curve, then fasten it down into that curved position (the shape of the Kolb nose cone), there is a small stress put into the plastic. Over a long period of time, perhaps the stresses eventually cause the internal cracks or difference in transparency?? This is a wild-a$$ guess on my part. Most "airplane" windshields are thermoformed, heated until the plastic is soft, so perhaps the internal stress is not as much? If this is not a viable explanation, perhaps the previous suggestion of a bad batch of plastic is the likely answer IMHO. Most of the manufacturers have a website or some sort of tech help phone number where you can ask a technical question. They may have seen this problem before and have a useful answer. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Mon, 3/5/18, John Hauck wrote: Subject: RE: Kolb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 To: kolb-list(at)matronics.com Date: Monday, March 5, 2018, 9:11 AM #yiv8117676239 #yiv8117676239 -- _filtered #yiv8117676239 {panose-1:2 4 5 3 5 4 6 3 2 4;} _filtered #yiv8117676239 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #yiv8117676239 {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;} #yiv8117676239 #yiv8117676239 p.yiv8117676239MsoNormal, #yiv8117676239 li.yiv8117676239MsoNormal, #yiv8117676239 div.yiv8117676239MsoNormal {margin:0in;margin-bottom:.0001pt;font-size:12.0pt;} #yiv8117676239 a:link, #yiv8117676239 span.yiv8117676239MsoHyperlink {color:blue;text-decoration:underline;} #yiv8117676239 a:visited, #yiv8117676239 span.yiv8117676239MsoHyperlinkFollowed {color:purple;text-decoration:underline;} #yiv8117676239 p.yiv8117676239MsoAcetate, #yiv8117676239 li.yiv8117676239MsoAcetate, #yiv8117676239 div.yiv8117676239MsoAcetate {margin:0in;margin-bottom:.0001pt;font-size:8.0pt;} #yiv8117676239 span.yiv8117676239BalloonTextChar {} #yiv8117676239 span.yiv8117676239EmailStyle19 {color:#1F497D;} #yiv8117676239 span.yiv8117676239EmailStyle20 {color:#1F497D;} #yiv8117676239 span.yiv8117676239EmailStyle21 {color:#1F497D;} #yiv8117676239 .yiv8117676239MsoChpDefault {} _filtered #yiv8117676239 {margin:1.0in 1.0in 1.0in 1.0in;} #yiv8117676239 div.yiv8117676239WordSection1 {} #yiv8117676239 Jack H/Kolbers: Doubt the polishing kit would correct my problem. The failure is in the generic polycarbonate I used last time I replaced windshield and doors. I think if I had stuck with more expensive GE Lexan, I wouldn't be having this problem. Right now I am scratching my head to figure out why this polycarbonate failed. One possibility is a reaction to the last windshield cover I made about 4 or 5 years ago. I found some heavy material, similar to Naugahyde, at a local fabric shop. I was tired of making new covers out of plastic table cloths every year. My thought is there was a chemical reaction from the gassing of the material used to make the material. Maybe not. I don't know. Darn shame though. The surface of the polycarbonate is in great shape. Thanks for the suggestion. john hmkIIITitus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack Hart Sent: Monday, March 05, 2018 10:13 AM To: kolb-list(at)matronics.com Subject: RE: Kolb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 John, I have had good luck with using the headlight polishing kits that are sold at auto parts stores. The kits are not expensive compared to a new windshield. Try it on the windshield in a small area and see if it helps out. Jack B. Hart FF004 Winchester, IN From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Sunday, March 4, 2018 1:02 PM To: kolb-list(at)matronics.com Subject: RE: Kolb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 Chris D/Kolbers: -----my 1992 MKIII, is in need of a lot of cosmetic TLC, especially the glass. The windshield has started crazing which gives it the diamond glare effect when flying into the sun. ________________________________________________________________________________
Date: Mar 06, 2018
Subject: Re: Ultrastar covering
=C2-hay man wats up=C2- ?wrong=C2- # see you at the Lapeer safety sem inar?=C2-Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair http://michigansportpilotrepair.comLSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022=C2-=C2-=C2-=C2- From: Sharon Bumhoffer <abumhoffer(at)hotmail.com> To: "kolb-list-digest(at)matronics.com" Sent: Monday, March 5, 2018 9:00 AM Subject: Kolb-List: Ultrastar covering For Jeff, do you have any photos of your Ultrastar that you covered. I am planing on doing the same to mine before I put the fiberglass pod on the no se. Al, Elkton Mi Get Outlook for Android ________________________________________________________________________________
Date: Mar 05, 2018
John, One more suggestion. Tooth paste contains a mild abrasive. Take a tube and put some on your finger and rub it on the outer surface over a small area. Just like you are trying to polish the surface. Then clean off the surface with a soft towel and pear through the affected area. If it looks better, further polishing out will be of benefit. I used acrylic head light cover polish on a Monark polycarbonate windshield with good results. Jack B. Hart FF004 Winchester, IN ---------------------------------------- From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Monday, March 5, 2018 12:15 PM Subject: RE: Kolb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 Jack H/Kolbers: Darn shame though. The surface of the polycarbonate is in great shape. ________________________________________________________________________________
Date: Mar 05, 2018
I don't have a surface problem. It is in great shape. I use Plexus religiously to keep my glass clean and protected. My problem is in the glass between the two surfaces. That can't be corrected. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack Hart Sent: Monday, March 05, 2018 7:46 PM Subject: RE: Kolb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 John, One more suggestion. Tooth paste contains a mild abrasive. Take a tube and put some on your finger and rub it on the outer surface over a small area. Just like you are trying to polish the surface. Then clean off the surface with a soft towel and pear through the affected area. If it looks better, further polishing out will be of benefit. I used acrylic head light cover polish on a Monark polycarbonate windshield with good results. Jack B. Hart FF004 Winchester, IN _____ From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Monday, March 5, 2018 12:15 PM Subject: RE: Kolb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 Jack H/Kolbers: Darn shame though. The surface of the polycarbonate is in great shape. ________________________________________________________________________________
Date: Mar 05, 2018
Plain polycarbonate can be crazed by lots of stuff, including gasoline=2E P lexi is much less susceptible=2E Charlie On Mar 5, 2018, 9:31 PM, at 9: 31 PM, John Hauck wrote: >I don't have a surface problem=2E It is in great shape=2E I use Plexus >religiously to keep my glass clean and protected=2E > > > >My problem is in the glass between the two surfaces=2E That can't be >corrected=2E > > > >john h > >mkIII > >Ti tus, Alabama > > > >From: owner-kolb-list-server@matronics=2Ecom >[mailto: owner-kolb-list-server@matronics=2Ecom] On Behalf Of Jack Hart >Sent: Monda y, March 05, 2018 7:46 PM >To: kolb-list@matronics=2Ecom >Subject: RE: Kolb -List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 > > > >John, > > > >One mo re suggestion=2E Tooth paste contains a mild abrasive=2E Take a >tube and >put some on your finger and rub it on the outer surface over a small >are a=2E >Just like you are trying to polish the surface=2E Then clean off the >surface >with a soft towel and pear through the affected area=2E If it l ooks >better, >further polishing out will be of benefit=2E > > > >I used a crylic head light cover polish on a Monark polycarbonate >windshield >with good results=2E > > > >Jack B=2E Hart FF004 > >Winchester, IN > > > > > > > > _____ > >From: "John Hauck" <jhauck@elmore=2Err=2Ecom> >Sent: Mon day, March 5, 2018 12:15 PM >To: kolb-list@matronics=2Ecom >Subject: RE: Ko lb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 > > > >Jack H/Kolbers: > > > >Darn shame though=2E The surface of the polycarbonate is in great s hape=2E > > > ________________________________________________________________________________
Date: Mar 05, 2018
Depends on the type of gasoline. I used to be able to tell which would and which wouldn't damage the glass. Been too long to remember that. Some won't and some will. The types that will are immediate reactions. You watch it and cry. john From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Monday, March 05, 2018 8:42 PM Subject: RE: Kolb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 Plain polycarbonate can be crazed by lots of stuff, including gasoline. Plexi is much less susceptible. Charlie On Mar 5, 2018, at 9:31 PM, John Hauck wrote: I don't have a surface problem. It is in great shape. I use Plexus religiously to keep my glass clean and protected. My problem is in the glass between the two surfaces. That can't be corrected. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack Hart Sent: Monday, March 05, 2018 7:46 PM Subject: RE: Kolb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 John, One more suggestion. Tooth paste contains a mild abrasive. Take a tube and put some on your finger and rub it on the outer surface over a small area. Just like you are trying to polish the surface. Then clean off the surface with a soft towel and pear through the affected area. If it looks better, further polishing out will be of benefit. I used acrylic head light cover polish on a Monark polycarbonate windshield with good results. Jack B. Hart FF004 Winchester, IN _____ From: "John Hauck" <jhauck(at)elmore.rr.com> Sent: Monday, March 5, 2018 12:15 PM Subject: RE: Kolb-List: Re: Kolb-List Digest: 6 Msgs - 03/01/18 Jack H/Kolbers: Darn shame though. The surface of the polycarbonate is in great shape. ________________________________________________________________________________
Date: Mar 06, 2018
Subject: flight video
Well nobody is doing anything so here goes: This is a copy of the blog that I write for friends. My wife passed away the end of Jan this year, and today was her birthday. I bought my plane on Karen's birthday in 1997. I was 54 and right in the middle of "Manopause". This isn't the one where you get the night sweats, no its much worse. This is the one when a man realizes that nothing works anymore, you are well past the best you could ever be, and the general time of life when a man either gets a girl friend, and eventually a divorce or they start molesting kids. Neither had any draw for me. I started thinking about what I would regret the most when I was sitting in my rocker at the old welders home, drooling down my chin and flashing the nurses. There were only two regrets that I could think of, since I had done just about every thing else that I wanted. One was to learn to fly, the other entailed an act best kept secret involving Sofia Loren. Flying seemed the most likely to succeed. So I began to look around and found just what I needed, A Kolb Firestar II. I assure you it was a coincidence of the utmost surprise to find that I had bought it on Karen's birthday, but all in all I considered it a fair trade, since she neither had to bail me out of jail or share me with a mistress. I haven't flown since early October of last year, and the weather has been so shitty that flying was out of the question. Today, her birthday, however was cool but with no wind. First time in almost two months. As you can imagine I have been rattling around this place like a rock in a tin can, with lots of time and nothing much I am interested in doing. I was out in the shop repairing the shroud on a carpet cleaner, when I decided to burn some of the boxes that I have been accumulating. I opened the hangar doors and was surprised to see that it was still nice. So I pulled the plane out thinking that I would just fire it up and get it warmed up a bit. One thing lead to another and the first thing you know I was getting dressed to fly. I did a bunch of touch and goes until I was sure that the engine was going to keep running and I got a bit better, so I went over to the ranch and eventually landed in front of their house. Listen closely to Elsie when she comes to the plane. https://vimeo.com/258896917 There is no password required for this one. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: flight video
Date: Mar 06, 2018
Larry, I always appreciate watching your videos. One of these days I'll get my Twinstar in the air and who knows. I might buzz up your way. Wayne On 3/6/2018 8:03 PM, Larry Cottrell wrote: > Well nobody is doing anything so here goes: This is a copy of the blog > that I write for friends. My wife passed away the end of Jan this > year, and today was her birthday. > > I bought my plane on Karen's birthday in 1997. I was 54 and right in > the middle of "Manopause". This isn't the one where you get the night > sweats, no its much worse. This is the one when a man realizes that > nothing works anymore, you are well past the best you could ever be, > and the general time of life when a man either gets a girl friend, and > eventually a divorce or they start molesting kids. Neither had any > draw for me. I started thinking about what I would regret the most > when I was sitting in my rocker at the old welders home, drooling down > my chin and flashing the nurses. > > > There were only two regrets that I could think of, since I had done > just about every thing else that I wanted. One was to learn to fly, > the other entailed an act best kept secret involving Sofia Loren. > Flying seemed the most likely to succeed. > > > So I began to look around and found just what I needed, A Kolb > Firestar II. I assure you it was a coincidence of the utmost surprise > to find that I had bought it on Karen's birthday, but all in all I > considered it a fair trade, since she neither had to bail me out of > jail or share me with a mistress. > > > I haven't flown since early October of last year, and the weather has > been so shitty that flying was out of the question. Today, her > birthday, however was cool but with no wind. First time in almost two > months. As you can imagine I have been rattling around this place like > a rock in a tin can, with lots of time and nothing much I am > interested in doing. > > > I was out in the shop repairing the shroud on a carpet cleaner, when I > decided to burn some of the boxes that I have been accumulating. I > opened the hangar doors and was surprised to see that it was still > nice. So I pulled the plane out thinking that I would just fire it up > and get it warmed up a bit. One thing lead to another and the first > thing you know I was getting dressed to fly. > > > I did a bunch of touch and goes until I was sure that the engine was > going to keep running and I got a bit better, so I went over to the > ranch and eventually landed in front of their house. Listen closely to > Elsie when she comes to the plane. > > > https://vimeo.com/258896917 There is no password required for this one. > > > Larry > > > -- > /The older I get, the less tolerant I am of those who are intolerant > of others./ > / > / > /If you forward this email, or any part of it, please remove my email > address before sending./ ________________________________________________________________________________
Date: Mar 06, 2018
Come on up. The fly-in is the 8th of Sept. Larry On Tue, Mar 6, 2018 at 8:29 PM, Wayne Schneider wrote: > Larry, > > I always appreciate watching your videos. One of these days I'll get my > Twinstar in the air and who knows. I might buzz up your way. > > Wayne > > On 3/6/2018 8:03 PM, Larry Cottrell wrote: > > Well nobody is doing anything so here goes: This is a copy of the blog > that I write for friends. My wife passed away the end of Jan this year, and > today was her birthday. > > I bought my plane on Karen's birthday in 1997. I was 54 and right in the > middle of "Manopause". This isn't the one where you get the night sweats, > no its much worse. This is the one when a man realizes that nothing works > anymore, you are well past the best you could ever be, and the general time > of life when a man either gets a girl friend, and eventually a divorce or > they start molesting kids. Neither had any draw for me. I started thinking > about what I would regret the most when I was sitting in my rocker at the > old welders home, drooling down my chin and flashing the nurses. > > > There were only two regrets that I could think of, since I had done just > about every thing else that I wanted. One was to learn to fly, the other > entailed an act best kept secret involving Sofia Loren. Flying seemed the > most likely to succeed. > > > So I began to look around and found just what I needed, A Kolb Firestar > II. I assure you it was a coincidence of the utmost surprise to find that I > had bought it on Karen's birthday, but all in all I considered it a fair > trade, since she neither had to bail me out of jail or share me with a > mistress. > > > I haven't flown since early October of last year, and the weather has been > so shitty that flying was out of the question. Today, her birthday, however > was cool but with no wind. First time in almost two months. As you can > imagine I have been rattling around this place like a rock in a tin can, > with lots of time and nothing much I am interested in doing. > > > I was out in the shop repairing the shroud on a carpet cleaner, when I > decided to burn some of the boxes that I have been accumulating. I opened > the hangar doors and was surprised to see that it was still nice. So I > pulled the plane out thinking that I would just fire it up and get it > warmed up a bit. One thing lead to another and the first thing you know I > was getting dressed to fly. > > > I did a bunch of touch and goes until I was sure that the engine was going > to keep running and I got a bit better, so I went over to the ranch and > eventually landed in front of their house. Listen closely to Elsie when she > comes to the plane. > > > https://vimeo.com/258896917 There is no password required for this > one. > > > Larry > > > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Mar 06, 2018
Enjoyed the video very much. It takes me across the continent to my other home. I didn't learn to fly until I was 29, and I thought I was a late bloomer. ;-) Glad you got that little airplane and learned to fly, Larry C. If you hadn't, we would have never crossed paths. There's a whole lot of friends I would never have met if it hadn't been for my little airplane. Been a great ride. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Wayne Schneider Sent: Tuesday, March 06, 2018 9:29 PM Subject: Re: Kolb-List: flight video Larry, I always appreciate watching your videos. One of these days I'll get my Twinstar in the air and who knows. I might buzz up your way. Wayne On 3/6/2018 8:03 PM, Larry Cottrell wrote: Well nobody is doing anything so here goes: This is a copy of the blog that I write for friends. My wife passed away the end of Jan this year, and today was her birthday. I bought my plane on Karen's birthday in 1997. I was 54 and right in the middle of "Manopause". This isn't the one where you get the night sweats, no its much worse. This is the one when a man realizes that nothing works anymore, you are well past the best you could ever be, and the general time of life when a man either gets a girl friend, and eventually a divorce or they start molesting kids. Neither had any draw for me. I started thinking about what I would regret the most when I was sitting in my rocker at the old welders home, drooling down my chin and flashing the nurses. There were only two regrets that I could think of, since I had done just about every thing else that I wanted. One was to learn to fly, the other entailed an act best kept secret involving Sofia Loren. Flying seemed the most likely to succeed. So I began to look around and found just what I needed, A Kolb Firestar II. I assure you it was a coincidence of the utmost surprise to find that I had bought it on Karen's birthday, but all in all I considered it a fair trade, since she neither had to bail me out of jail or share me with a mistress. I haven't flown since early October of last year, and the weather has been so shitty that flying was out of the question. Today, her birthday, however was cool but with no wind. First time in almost two months. As you can imagine I have been rattling around this place like a rock in a tin can, with lots of time and nothing much I am interested in doing. I was out in the shop repairing the shroud on a carpet cleaner, when I decided to burn some of the boxes that I have been accumulating. I opened the hangar doors and was surprised to see that it was still nice. So I pulled the plane out thinking that I would just fire it up and get it warmed up a bit. One thing lead to another and the first thing you know I was getting dressed to fly. I did a bunch of touch and goes until I was sure that the engine was going to keep running and I got a bit better, so I went over to the ranch and eventually landed in front of their house. Listen closely to Elsie when she comes to the plane. https://vimeo.com/258896917 There is no password required for this one. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Mar 07, 2018
That was GREAT! Condolences on your loss Sir. Rick From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Tuesday, March 06, 2018 9:37 PM Subject: Re: Kolb-List: flight video Come on up. The fly-in is the 8th of Sept. Larry On Tue, Mar 6, 2018 at 8:29 PM, Wayne Schneider wrote: Larry, I always appreciate watching your videos. One of these days I'll get my Twinstar in the air and who knows. I might buzz up your way. Wayne On 3/6/2018 8:03 PM, Larry Cottrell wrote: Well nobody is doing anything so here goes: This is a copy of the blog that I write for friends. My wife passed away the end of Jan this year, and today was her birthday. I bought my plane on Karen's birthday in 1997. I was 54 and right in the middle of "Manopause". This isn't the one where you get the night sweats, no its much worse. This is the one when a man realizes that nothing works anymore, you are well past the best you could ever be, and the general time of life when a man either gets a girl friend, and eventually a divorce or they start molesting kids. Neither had any draw for me. I started thinking about what I would regret the most when I was sitting in my rocker at the old welders home, drooling down my chin and flashing the nurses. There were only two regrets that I could think of, since I had done just about every thing else that I wanted. One was to learn to fly, the other entailed an act best kept secret involving Sofia Loren. Flying seemed the most likely to succeed. So I began to look around and found just what I needed, A Kolb Firestar II. I assure you it was a coincidence of the utmost surprise to find that I had bought it on Karen's birthday, but all in all I considered it a fair trade, since she neither had to bail me out of jail or share me with a mistress. I haven't flown since early October of last year, and the weather has been so shitty that flying was out of the question. Today, her birthday, however was cool but with no wind. First time in almost two months. As you can imagine I have been rattling around this place like a rock in a tin can, with lots of time and nothing much I am interested in doing. I was out in the shop repairing the shroud on a carpet cleaner, when I decided to burn some of the boxes that I have been accumulating. I opened the hangar doors and was surprised to see that it was still nice. So I pulled the plane out thinking that I would just fire it up and get it warmed up a bit. One thing lead to another and the first thing you know I was getting dressed to fly. I did a bunch of touch and goes until I was sure that the engine was going to keep running and I got a bit better, so I went over to the ranch and eventually landed in front of their house. Listen closely to Elsie when she comes to the plane. https://vimeo.com/258896917 There is no password required for this one. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Mar 07, 2018
Larry, I am sorry for your loss. Time will help, and I know you are thankful that y ou are able to escape into the world of flight-an escape that only a few have. Enjoyed the video and especially how the kids received you and your aircraft . Sincerely, Lanny Sent from my iPad > On Mar 6, 2018, at 11:05 PM, John Hauck wrote: > > Enjoyed the video very much. It takes me across the continent to my other home. > > I didn't learn to fly until I was 29, and I thought I was a late bloomer. ;-) > > Glad you got that little airplane and learned to fly, Larry C. If you had n't, we would have never crossed paths. There's a whole lot of friends I wo uld never have met if it hadn't been for my little airplane. > > Been a great ride. > > john h > mkIII > Titus, Alabama > > > > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com] On Behalf Of Wayne Schneider > Sent: Tuesday, March 06, 2018 9:29 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: flight video > > Larry, > > I always appreciate watching your videos. One of these days I'll get my T winstar in the air and who knows. I might buzz up your way. > > Wayne > > > On 3/6/2018 8:03 PM, Larry Cottrell wrote: > Well nobody is doing anything so here goes: This is a copy of the blog tha t I write for friends. My wife passed away the end of Jan this year, and tod ay was her birthday. > > I bought my plane on Karen's birthday in 1997. I was 54 and right in the m iddle of "Manopause". This isn't the one where you get the night sweats, no i ts much worse. This is the one when a man realizes that nothing works anymor e, you are well past the best you could ever be, and the general time of lif e when a man either gets a girl friend, and eventually a divorce or they sta rt molesting kids. Neither had any draw for me. I started thinking about wha t I would regret the most when I was sitting in my rocker at the old welders home, drooling down my chin and flashing the nurses. > > There were only two regrets that I could think of, since I had done just a bout every thing else that I wanted. One was to learn to fly, the other enta iled an act best kept secret involving Sofia Loren. Flying seemed the most l ikely to succeed. > > So I began to look around and found just what I needed, A Kolb Firestar II . I assure you it was a coincidence of the utmost surprise to find that I ha d bought it on Karen's birthday, but all in all I considered it a fair trade , since she neither had to bail me out of jail or share me with a mistress. > > I haven't flown since early October of last year, and the weather has been so shitty that flying was out of the question. Today, her birthday, however was cool but with no wind. First time in almost two months. As you can imag ine I have been rattling around this place like a rock in a tin can, with lo ts of time and nothing much I am interested in doing. > > I was out in the shop repairing the shroud on a carpet cleaner, when I dec ided to burn some of the boxes that I have been accumulating. I opened the h angar doors and was surprised to see that it was still nice. So I pulled the plane out thinking that I would just fire it up and get it warmed up a bit. One thing lead to another and the first thing you know I was getting dresse d to fly. > > I did a bunch of touch and goes until I was sure that the engine was going to keep running and I got a bit better, so I went over to the ranch and eve ntually landed in front of their house. Listen closely to Elsie when she com es to the plane. > > https://vimeo.com/258896917 There is no password required for this one. > > Larry > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. > ________________________________________________________________________________
Date: Mar 07, 2018
Larry, I too am sorry to hear of your loss. Hopefully your love of flying can help ease the pain. I really enjoyed the "Blog" and the movie makes me want to get out and fly but it is 15 degrees and snow white here and I haven't seen my plane since Oct either... -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478461#478461 ________________________________________________________________________________
Subject: Firestar airframe wieght
Date: Mar 07, 2018
I am curious as to the weight of the Firestar II without engine and covering. Has anyone weighed the bare airframe? Rick ________________________________________________________________________________
Date: Mar 07, 2018
Larry, just learned about your loss. And just watched your video. Tain=99t easy, as you of course know. I lost my wife 10yrs ago, after 52 years together. You never get over it, but you will get used to it. I sold my Xtra last year, but we ALL appreciate your input to the List and your helpful comments You=99re a good friend and an inspiration to all Kolbers. Doubt we ever meet, but I - and all of us! =94 hold you -- in high regard and are thankful to =9Cknow=9D you. If you=99re ever daft enough to come to Maine (make it autumn!) pls look me up. Fair winds, Russ Kinne > On Mar 7, 2018, at 11:00 AM, west1m wrote: > > > Larry, > > I too am sorry to hear of your loss. Hopefully your love of flying can help ease the pain. > I really enjoyed the "Blog" and the movie makes me want to get out and fly but it is 15 degrees and snow white here and I haven't seen my plane since Oct either... > > -------- > West1m > Hastings, MN > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478461#478461 > > > > > > > > > ________________________________________________________________________________
Date: Mar 07, 2018
Thanks to all of you. Larry On Wed, Mar 7, 2018 at 5:53 PM, Russ Kinne wrote: > Larry, just learned about your loss. And just watched your video. Tain =99t > easy, as you of course know. > I lost my wife 10yrs ago, after 52 years together. You never get over it, > but you *will* get used to it. > I sold my Xtra last year, but we ALL appreciate your input to the List an d > your helpful comments > You=99re a good friend and an inspiration to all Kolbers. Doubt we ever > meet, but I - and all of us! =94 > hold you -- in high regard and are thankful to =9Cknow=9D you . > If you=99re ever daft enough to come to Maine (make it autumn!) pls look me > up. > Fair winds, > Russ Kinne > > > On Mar 7, 2018, at 11:00 AM, west1m wrote: > > > Larry, > > I too am sorry to hear of your loss. Hopefully your love of flying can > help ease the pain. > I really enjoyed the "Blog" and the movie makes me want to get out and > fly but it is 15 degrees and snow white here and I haven't seen my plane > since Oct either... > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478461#478461 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
From: Mark and Diane Bancroft <markanddiane72(at)gmail.com>
Subject: Rotax 503
Date: Mar 08, 2018
Can anyone give me some guidance on maintenance costs and timing for repairs for a Rotax 503? Thanks. Diane ________________________________________________________________________________
Date: Mar 08, 2018
Subject: Re: Rotax 503
You might check the Leading Edge Airfoils website. California Power Systems is another. All Rotax air-cooled 2 cycles are getting a bit expensive to have gone through mainly because of the cost of parts. Also the engines are no longer in production. I really loved my 503 and my 377. Ive moved on to another brand myself. You also might talk to some of the local flyers around your area to see who their using. George Helton Firestar 1986, FS100 Hirth 2702 14GDH Mesick, Michigan Sent from my iPhone > On Mar 8, 2018, at 9:37 AM, Mark and Diane Bancroft wrote: > > > Can anyone give me some guidance on maintenance costs and timing for repairs for a Rotax 503? Thanks. Diane > > > > ________________________________________________________________________________
Date: Mar 09, 2018
Go to the Rotax Owner website and check for certified tech's in your area. They can probably give you the info. you need. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478524#478524 ________________________________________________________________________________
Subject: The Firefly is painted
Date: Mar 10, 2018
Finished painting the Firefly today, put it together, and was hoping to fly it, but then the front started moving in, the wind came up, and having to land with a stiff tailwind seemed like not a good idea. So we took some pictures and put it away. All we have left to do is add the VG's, and some home made strobes that ought to weigh less than 5 ounces. (I'll do a separate post on that after it is done) Best of all, we are still within legal specs for Part 103 - WOOT! Here are the pictures. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478562#478562 Attachments: http://forums.matronics.com//files/p1060591_medium_275.jpg http://forums.matronics.com//files/p1060589_medium_161.jpg http://forums.matronics.com//files/p1060584_medium_153.jpg http://forums.matronics.com//files/p1060596_medium_207.jpg http://forums.matronics.com//files/p1060594_medium_241.jpg http://forums.matronics.com//files/p1060598_medium_544.jpg ________________________________________________________________________________
Date: Mar 10, 2018
Not easy to come under the weight limit. I could never accomplish that. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Saturday, March 10, 2018 5:17 PM Subject: Kolb-List: The Firefly is painted --> Finished painting the Firefly today, put it together, and was hoping to fly it, but then the front started moving in, the wind came up, and having to land with a stiff tailwind seemed like not a good idea. So we took some pictures and put it away. All we have left to do is add the VG's, and some home made strobes that ought to weigh less than 5 ounces. (I'll do a separate post on that after it is done) Best of all, we are still within legal specs for Part 103 - WOOT! Here are the pictures. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478562#478562 Attachments: http://forums.matronics.com//files/p1060591_medium_275.jpg http://forums.matronics.com//files/p1060589_medium_161.jpg http://forums.matronics.com//files/p1060584_medium_153.jpg http://forums.matronics.com//files/p1060596_medium_207.jpg http://forums.matronics.com//files/p1060594_medium_241.jpg http://forums.matronics.com//files/p1060598_medium_544.jpg ________________________________________________________________________________
Subject: EAA Chap 822 Rib BBQ
Date: Mar 10, 2018
Got Miss P'fer out of the hanger, brushed off the big lumps, cleaned the windshield, and flew 11.3 miles from Gantt International Airport to 08A, Wetumpka Airport. Ribs were good, plus I brought home a slab for $10. We always cook too much so we can take some home. Lots of old folks and two airplanes, mine and a Falco based at 08A. My chapter doesn't do a lot of flying. ;-) One of the guys rebuilding a Stinson from the ground up, loaned me some Polytak to repair a finish tape that has pulled loose on the fuselage a foot or so in front of the prop. I'll clean it with MEK, and stick it back together. Then put a new sticker over it. Be good as new. Got to put in an insurance claim for rodent damage again. SOB ate my seats and the foam rubber stick grip, plus a lot of foam I was using in the rear of the fuselage in an attempt to reduce noise. Don't think it helped much. john h mkIII Titus, Alabama ________________________________________________________________________________
Subject: Re: The Firefly is painted
Date: Mar 10, 2018
John Hauck wrote: > Not easy to come under the weight limit. I could never accomplish that. > john h > mkIII > Titus, Alabama-- You are right; it was not easy. That is why we sold the 447 and replaced it with a 277 free air. The 447 weighed 59.1 pounds, the 277; 42.5 pounds. Not having the fan or cooling shroud on the 277 saved a bit more, but not sure how much. We are also using a hand deployed parachute and counting the weight that the FAA allows for that. Since the chute and hardware only weighs 9 pounds and you are allowed to count 24, that gives us another 15 pounds to subtract from the actual weight. Something that is not helping is that we are still using the original wing fabric and paint, plus our repaint. If we stripped the wings and recovered it with Oratex, we could probably make weight w/o having to count the parachute. But right now, we don't care. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478567#478567 ________________________________________________________________________________
Date: Mar 10, 2018
Looking good Richard. Weight is hard to shed easily. Mine still weighs in at about the same weight as when Vince had it. Haven't been able to get anything done on mine since first of the year. I fell on the ice the last of Jan and broke my left ankle. Hopefully spring will be better. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478568#478568 ________________________________________________________________________________
Date: Mar 11, 2018
Really nice job, Richard! And made the 103 weight too! Enjoy, Lanny Sent from my iPad > On Mar 10, 2018, at 6:17 PM, Richard Pike wrote: > > > Finished painting the Firefly today, put it together, and was hoping to fly it, but then the front started moving in, the wind came up, and having to land with a stiff tailwind seemed like not a good idea. So we took some pictures and put it away. All we have left to do is add the VG's, and some home made strobes that ought to weigh less than 5 ounces. (I'll do a separate post on that after it is done) Best of all, we are still within legal specs for Part 103 - WOOT! Here are the pictures. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478562#478562 > > > > > Attachments: > > http://forums.matronics.com//files/p1060591_medium_275.jpg > http://forums.matronics.com//files/p1060589_medium_161.jpg > http://forums.matronics.com//files/p1060584_medium_153.jpg > http://forums.matronics.com//files/p1060596_medium_207.jpg > http://forums.matronics.com//files/p1060594_medium_241.jpg > http://forums.matronics.com//files/p1060598_medium_544.jpg > > > > > > ________________________________________________________________________________
Date: Mar 11, 2018
Beautiful airplane!!! I sure enjoy reading about how you kept the weight down. Outstanding job!!! -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Saturday, March 10, 2018 5:17 PM Subject: Kolb-List: The Firefly is painted --> Finished painting the Firefly today, put it together, and was hoping to fly it, but then the front started moving in, the wind came up, and having to land with a stiff tailwind seemed like not a good idea. So we took some pictures and put it away. All we have left to do is add the VG's, and some home made strobes that ought to weigh less than 5 ounces. (I'll do a separate post on that after it is done) Best of all, we are still within legal specs for Part 103 - WOOT! Here are the pictures. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478562#478562 Attachments: http://forums.matronics.com//files/p1060591_medium_275.jpg http://forums.matronics.com//files/p1060589_medium_161.jpg http://forums.matronics.com//files/p1060584_medium_153.jpg http://forums.matronics.com//files/p1060596_medium_207.jpg http://forums.matronics.com//files/p1060594_medium_241.jpg http://forums.matronics.com//files/p1060598_medium_544.jpg ________________________________________________________________________________
Date: Mar 11, 2018
Its obvious that the Rev likes blue. I do as well. It looks really good. I do have a question about the silencer. I was wondering the reasoning behind installing it vertically rather than horizontal. Clearance perhaps. It looks better on your plane than it ever did on my shelf, what ever the configuration Larry. On Sun, Mar 11, 2018 at 10:12 AM, Rick MacCrone wrote: > > Beautiful airplane!!! I sure enjoy reading about how you kept the weight > down. Outstanding job!!! > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike > Sent: Saturday, March 10, 2018 5:17 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: The Firefly is painted > > --> > > Finished painting the Firefly today, put it together, and was hoping to fly > it, but then the front started moving in, the wind came up, and having to > land with a stiff tailwind seemed like not a good idea. So we took some > pictures and put it away. All we have left to do is add the VG's, and some > home made strobes that ought to weigh less than 5 ounces. (I'll do a > separate post on that after it is done) Best of all, we are still within > legal specs for Part 103 - WOOT! Here are the pictures. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough, being forgiven is wonderful, and God's grace really is > amazing. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478562#478562 > > > Attachments: > > http://forums.matronics.com//files/p1060591_medium_275.jpg > http://forums.matronics.com//files/p1060589_medium_161.jpg > http://forums.matronics.com//files/p1060584_medium_153.jpg > http://forums.matronics.com//files/p1060596_medium_207.jpg > http://forums.matronics.com//files/p1060594_medium_241.jpg > http://forums.matronics.com//files/p1060598_medium_544.jpg > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Mar 11, 2018
lcottrell wrote: > Its obvious that the Rev likes blue. I do as well. It looks really good. I do have a question about the silencer. I was wondering the reasoning behind installing it vertically rather than horizontal. Clearance perhaps. It looks better on your plane than it ever did on my shelf, what ever the configuration. > Larry. > -- It is because the 277 lacks sufficient mounting points to tie the silencer in place at the mag end, so the silencer had to end up with all it's mounting points as close as possible to the PTO end. Picture the silencer in different locations, then look at the engine and the potential silencer mounting points, and there are not many options. Probably could have mounted it down/horizontal with the air filter at the mag end and made it work, but we took the path of least resistance. (Also known as not having to work across the top of the wing while fabricating parts) (I'm not getting any younger/more flexible) -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478578#478578 Attachments: http://forums.matronics.com//files/p1060606_medium_143.jpg http://forums.matronics.com//files/p1060609_medium_155.jpg ________________________________________________________________________________
Date: Mar 11, 2018
Subject: Re: Kolb-List Digest: 5 Msgs - 03/10/18
Dragged my poor ole slingshot out oh hanger yesterday. Had left knee replaced three weeks ago. Gotta be careful. Got in and gave her a good run up to heat the oil and such. Felt good. Gotta replace some gas filters and old gas and weather permitting i will flap my wings and pretend im a bird again. Been over a month. Congrats on your shinny new looking firefly. That 277 really looks small. Have fun. Ted Cowan. Sling shot 912 ul zoom zoom Sent from my iPhone > On Mar 11, 2018, at 1:36 AM, Kolb-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-03-10&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-03-10&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Sat 03/10/18: 5 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 03:17 PM - The Firefly is painted (Richard Pike) > 2. 03:29 PM - Re: The Firefly is painted (John Hauck) > 3. 03:48 PM - EAA Chap 822 Rib BBQ (John Hauck) > 4. 05:04 PM - Re: The Firefly is painted (Richard Pike) > 5. 05:47 PM - Re: The Firefly is painted (japowell) > > > > ________________________________ Message 1 _____________________________________ > > > Subject: Kolb-List: The Firefly is painted > From: "Richard Pike" <thegreybaron(at)charter.net> > > > Finished painting the Firefly today, put it together, and was hoping to fly it, > but then the front started moving in, the wind came up, and having to land with > a stiff tailwind seemed like not a good idea. So we took some pictures and > put it away. All we have left to do is add the VG's, and some home made strobes > that ought to weigh less than 5 ounces. (I'll do a separate post on that after > it is done) Best of all, we are still within legal specs for Part 103 - WOOT! > Here are the pictures. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478562#478562 > > > Attachments: > > http://forums.matronics.com//files/p1060591_medium_275.jpg > http://forums.matronics.com//files/p1060589_medium_161.jpg > http://forums.matronics.com//files/p1060584_medium_153.jpg > http://forums.matronics.com//files/p1060596_medium_207.jpg > http://forums.matronics.com//files/p1060594_medium_241.jpg > http://forums.matronics.com//files/p1060598_medium_544.jpg > > > ________________________________ Message 2 _____________________________________ > > > From: "John Hauck" <jhauck(at)elmore.rr.com> > Subject: RE: Kolb-List: The Firefly is painted > > > Not easy to come under the weight limit. I could never accomplish that. > > john h > mkIII > Titus, Alabama > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike > Sent: Saturday, March 10, 2018 5:17 PM > Subject: Kolb-List: The Firefly is painted > > --> > > Finished painting the Firefly today, put it together, and was hoping to fly > it, but then the front started moving in, the wind came up, and having to > land with a stiff tailwind seemed like not a good idea. So we took some > pictures and put it away. All we have left to do is add the VG's, and some > home made strobes that ought to weigh less than 5 ounces. (I'll do a > separate post on that after it is done) Best of all, we are still within > legal specs for Part 103 - WOOT! Here are the pictures. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough, being forgiven is wonderful, and God's grace really is > amazing. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478562#478562 > > > Attachments: > > http://forums.matronics.com//files/p1060591_medium_275.jpg > http://forums.matronics.com//files/p1060589_medium_161.jpg > http://forums.matronics.com//files/p1060584_medium_153.jpg > http://forums.matronics.com//files/p1060596_medium_207.jpg > http://forums.matronics.com//files/p1060594_medium_241.jpg > http://forums.matronics.com//files/p1060598_medium_544.jpg > > > ________________________________ Message 3 _____________________________________ > > > From: "John Hauck" <jhauck(at)elmore.rr.com> > Subject: Kolb-List: EAA Chap 822 Rib BBQ > > Got Miss P'fer out of the hanger, brushed off the big lumps, cleaned the > windshield, and flew 11.3 miles from Gantt International Airport to 08A, > Wetumpka Airport. > > Ribs were good, plus I brought home a slab for $10. We always cook too much > so we can take some home. > > Lots of old folks and two airplanes, mine and a Falco based at 08A. My > chapter doesn't do a lot of flying. ;-) > > One of the guys rebuilding a Stinson from the ground up, loaned me some > Polytak to repair a finish tape that has pulled loose on the fuselage a foot > or so in front of the prop. I'll clean it with MEK, and stick it back > together. Then put a new sticker over it. Be good as new. > > Got to put in an insurance claim for rodent damage again. SOB ate my seats > and the foam rubber stick grip, plus a lot of foam I was using in the rear > of the fuselage in an attempt to reduce noise. Don't think it helped much. > > john h > mkIII > Titus, Alabama > > ________________________________ Message 4 _____________________________________ > > > Subject: Kolb-List: Re: The Firefly is painted > From: "Richard Pike" <thegreybaron(at)charter.net> > > > > John Hauck wrote: >> Not easy to come under the weight limit. I could never accomplish that. >> john h >> mkIII >> Titus, Alabama-- > > You are right; it was not easy. That is why we sold the 447 and replaced it with > a 277 free air. The 447 weighed 59.1 pounds, the 277; 42.5 pounds. Not having > the fan or cooling shroud on the 277 saved a bit more, but not sure how much. > We are also using a hand deployed parachute and counting the weight that the > FAA allows for that. Since the chute and hardware only weighs 9 pounds and you > are allowed to count 24, that gives us another 15 pounds to subtract from > the actual weight. Something that is not helping is that we are still using the > original wing fabric and paint, plus our repaint. If we stripped the wings and > recovered it with Oratex, we could probably make weight w/o having to count > the parachute. But right now, we don't care. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478567#478567 > > > ________________________________ Message 5 _____________________________________ > > > Subject: Kolb-List: Re: The Firefly is painted > From: "japowell" <japnmjp(at)twc.com> > > > Looking good Richard. Weight is hard to shed easily. Mine still weighs in at > about the same weight as when Vince had it. Haven't been able to get anything > done on mine since first of the year. I fell on the ice the last of Jan and broke > my left ankle. Hopefully spring will be better. > > -------- > Jim P > WAR EAGLE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478568#478568 > > > > > > > > ________________________________________________________________________________
Date: Mar 11, 2018
Subject: blast from the past
Sorting my late wife's desk and found this disc with John Williamson, John Hauck and Gary Haley flying formation. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: blast from the past
Date: Mar 11, 2018
Very cool pic! Lanny Sent from my iPad > On Mar 11, 2018, at 5:35 PM, Larry Cottrell wrot e: > > Sorting my late wife's desk and found this disc with John Williamson, John Hauck and Gary Haley flying formation. > Larry > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. > ________________________________________________________________________________
Date: Mar 11, 2018
[quote="tc1917(at)bellsouth.net"]Dragged my poor ole slingshot out oh hanger yesterday. Had left knee replaced three weeks ago. Gotta be careful. Got in and gave her a good run up to heat the oil and such. Felt good. Gotta replace some gas filters and old gas and weather permitting i will flap my wings and pretend im a bird again. Been over a month. Congrats on your shinny new looking firefly. That 277 really looks small. Have fun. Ted Cowan. Sling shot 912 ul zoom zoom Sent from my iPhone [quote] Thanks Ted! (Get well soon!) Guess what? The 277 IS small! When you line it up on the runway and feed in the power, it feels nothing like the MKIII/582, it just sort of bumbles along and gradually picks up speed, but then it pops off the ground and climbs at about 900' a minute, and I am like "How is this even possible?" It is very similar, and very different all at the same time. I have maybe 6 hours in it so far, looking forward to learning about it. Also, now I need to order some StolSpeed VG's for it. I'll take all the help I can get... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478583#478583 ________________________________________________________________________________
Subject: Re: EAA Chap 822 Rib BBQ
Date: Mar 11, 2018
John Hauck wrote: > Got Miss P'fer out of the hanger, brushed off the big lumps, cleaned the windshield, and flew 11.3 miles from Gantt International Airport to 08A, Wetumpka Airport. > > Ribs were good, plus I brought home a slab for $10. We always cook too much so we can take some home. > Lots of old folks and two airplanes, mine and a Falco based at 08A. My chapter doesn't do a lot of flying. ;-) > One of the guys rebuilding a Stinson from the ground up, loaned me some Polytak to repair a finish tape that has pulled loose on the fuselage a foot or so in front of the prop. I'll clean it with MEK, and stick it back together. Then put a new sticker over it. Be good as new. > Got to put in an insurance claim for rodent damage again. SOB ate my seats and the foam rubber stick grip, plus a lot of foam I was using in the rear of the fuselage in an attempt to reduce noise. Don't think it helped much. > john h > mkIII > Titus, Alabama John, I hear ya on that tape pulling loose on the fuselage ahead of the prop. In my case, it also pulled the fabric away from the diagonal longeron. When I fixed the tape, I also used some GOOP inside on either side of the diagonal to secure the fabric back to it, have not had any more trouble. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478584#478584 ________________________________________________________________________________
Date: Mar 11, 2018
Excellent. Thank you. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478586#478586 ________________________________________________________________________________
Date: Mar 11, 2018
I have a couple fuselage longerons that are concave. I rib stitched those longerons, blind on the inside because the fuel tank was right up close to the longerons. Only rib stitching I have ever done. I'll cement the tape back with Polytak, then slap a big sticker over it. Be like brand new. Of course, the hard part is first, removal of an old sticker that has grown onto the fabric. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Sunday, March 11, 2018 6:43 PM Subject: Kolb-List: Re: EAA Chap 822 Rib BBQ --> John Hauck wrote: > Got Miss P'fer out of the hanger, brushed off the big lumps, cleaned the windshield, and flew 11.3 miles from Gantt International Airport to 08A, Wetumpka Airport. > > Ribs were good, plus I brought home a slab for $10. We always cook too much so we can take some home. > Lots of old folks and two airplanes, mine and a Falco based at 08A. > My chapter doesn't do a lot of flying. ;-) One of the guys rebuilding a Stinson from the ground up, loaned me some Polytak to repair a finish tape that has pulled loose on the fuselage a foot or so in front of the prop. I'll clean it with MEK, and stick it back together. Then put a new sticker over it. Be good as new. > Got to put in an insurance claim for rodent damage again. SOB ate my seats and the foam rubber stick grip, plus a lot of foam I was using in the rear of the fuselage in an attempt to reduce noise. Don't think it helped much. > john h > mkIII > Titus, Alabama John, I hear ya on that tape pulling loose on the fuselage ahead of the prop. In my case, it also pulled the fabric away from the diagonal longeron. When I fixed the tape, I also used some GOOP inside on either side of the diagonal to secure the fabric back to it, have not had any more trouble. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478584#478584 ________________________________________________________________________________
Date: Mar 11, 2018
Wow! Brings back great memories of our first get together on the Alvord Desert, Oregon, 2005, the year before you and Karen moved into the Rock House. At the time, I thought those days would never end. We still have them in our photos and memories. Here's a couple more Karen took that day, 13 years ago. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Sunday, March 11, 2018 4:35 PM Subject: Kolb-List: blast from the past Sorting my late wife's desk and found this disc with John Williamson, John Hauck and Gary Haley flying formation. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Mar 11, 2018
Extremely cool! Thanks John! -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478595#478595 ________________________________________________________________________________
Date: Mar 11, 2018
John Hauck wrote: > I have a couple fuselage longerons that are concave. > -- Did you modify them to fit your gas tank? Inquiring minds want to know... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478596#478596 ________________________________________________________________________________
Date: Mar 11, 2018
We didn't modify them, we fabricated them where there were none in the original plans or fuselage. There was a couple feet of one longeron each side that was from zero to maybe a 1/4" gap and back to zero. I was afraid, if I didn't rib stitch, the fabric would drum and destroy itself, being that close in front of the prop. Rib stitching worked. Oh, and I haven't had any of my stitches loosen up. Still got my fingers crossed. ;-) john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Sunday, March 11, 2018 8:25 PM Subject: Kolb-List: Re: EAA Chap 822 Rib BBQ --> John Hauck wrote: > I have a couple fuselage longerons that are concave. > -- Did you modify them to fit your gas tank? Inquiring minds want to know... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478596#478596 ________________________________________________________________________________
Date: Mar 11, 2018
Awesome pictures! Thanks for posting them -------- 912ul King Kolbra ;fun plane O300 Cessna 172B ;travel plane Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478598#478598 ________________________________________________________________________________
Date: Mar 21, 2018
From: william sullivan <williamtsullivan(at)att.net>
Larry- we were in the process of moving, so I just heard about your loss. Please accept my most sincere condolences. A very nice video. Bill Sullivan -------------------------------------------- On Tue, 3/6/18, Larry Cottrell wrote: Subject: Kolb-List: flight video To: "kolb-list(at)matronics.com" Date: Tuesday, March 6, 2018, 11:03 PM Well nobody is doing anything so here goes: This is a copy of the blog that I write for friends. My wife passed away the end of Jan this year, and today was her birthday. I bought my plane on Karen's birthday in 1997. I was 54 and right in the middle of "Manopause". This isn't the one where you get the night sweats, no its much worse. This is the one when a man realizes that nothing works anymore, you are well past the best you could ever be, and the general time of life when a man either gets a girl friend, and eventually a divorce or they start molesting kids. Neither had any draw for me. I started thinking about what I would regret the most when I was sitting in my rocker at the old welders home, drooling down my chin and flashing the nurses. There were only two regrets that I could think of, since I had done just about every thing else that I wanted. One was to learn to fly, the other entailed an act best kept secret involving Sofia Loren. Flying seemed the most likely to succeed. So I began to look around and found just what I needed, A Kolb Firestar II. I assure you it was a coincidence of the utmost surprise to find that I had bought it on Karen's birthday, but all in all I considered it a fair trade, since she neither had to bail me out of jail or share me with a mistress. I haven't flown since early October of last year, and the weather has been so shitty that flying was out of the question. Today, her birthday, however was cool but with no wind. First time in almost two months. As you can imagine I have been rattling around this place like a rock in a tin can, with lots of time and nothing much I am interested in doing. I was out in the shop repairing the shroud on a carpet cleaner, when I decided to burn some of the boxes that I have been accumulating. I opened the hangar doors and was surprised to see that it was still nice. So I pulled the plane out thinking that I would just fire it up and get it warmed up a bit. One thing lead to another and the first thing you know I was getting dressed to fly. I did a bunch of touch and goes until I was sure that the engine was going to keep running and I got a bit better, so I went over to the ranch and eventually landed in front of their house. Listen closely to Elsie when she comes to the plane. https://vimeo.com/258896917 There is no password required for this one. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Subject: Wing structure upgrades
Date: Mar 21, 2018
Hello to all...... I am nearly at the covering stage for the wings on a Mk3 xtra which were "quick build". What upgrades to the structure have proven successful? Thanks for the info. Mike Cranson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478786#478786 ________________________________________________________________________________
Date: Mar 21, 2018
Thank you very much. Larry On Wed, Mar 21, 2018 at 11:40 AM, william sullivan wrote: > williamtsullivan(at)att.net> > > Larry- we were in the process of moving, so I just heard about your > loss. Please accept my most sincere condolences. A very nice video. > > Bill Sullivan > > > -------------------------------------------- > On Tue, 3/6/18, Larry Cottrell wrote: > > Subject: Kolb-List: flight video > To: "kolb-list(at)matronics.com" > Date: Tuesday, March 6, 2018, 11:03 PM > > Well nobody is doing > anything so here goes: This is a copy of the blog that I > write for friends. My wife passed away the end of Jan this > year, and today was her birthday. > > > I > bought my plane on Karen's birthday in 1997. I was 54 > and right in the middle of "Manopause". This > isn't the one where you get the night sweats, no its > much worse. This is the one when a man realizes that nothing > works anymore, you are well past the best you could ever be, > and the general time of life when a man either gets a girl > friend, and eventually a divorce or they start molesting > kids. Neither had any draw for me. I started thinking about > what I would regret the most when I was sitting in my rocker > at the old welders home, drooling down my chin and flashing > the nurses. > There > were only two regrets that I could think of, since I had > done just about every thing else that I wanted. One was to > learn to fly, the other entailed an act best kept secret > involving Sofia Loren. Flying seemed the most likely to > succeed. > So > I began to look around and found just what I needed, A Kolb > Firestar II. I assure you it was a coincidence of the utmost > surprise to find that I had bought it on Karen's > birthday, but all in all I considered it a fair trade, since > she neither had to bail me out of jail or share me with a > mistress. > I > haven't flown since early October of last year, and the > weather has been so shitty that flying was out of the > question. Today, her birthday, however was cool but with no > wind. First time in almost two months. As you can imagine I > have been rattling around this place like a rock in a tin > can, with lots of time and nothing much I am interested in > doing. > I > was out in the shop repairing the shroud on a carpet > cleaner, when I decided to burn some of the boxes that I > have been accumulating. I opened the hangar doors and was > surprised to see that it was still nice. So I pulled the > plane out thinking that I would just fire it up and get it > warmed up a bit. One thing lead to another and the first > thing you know I was getting dressed to fly. > I > did a bunch of touch and goes until I was sure that the > engine was going to keep running and I got a bit better, so > I went over to the ranch and eventually landed in front of > their house. Listen closely to Elsie when she comes to the > plane. > https://vimeo.com/258896917 > There is no password required for this one. > Larry > > > -- > The > older I get, the less tolerant I am of those who are > intolerant of others. > If you forward this email, or any part of > it, please remove my email address before sending. > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: Wing structure upgrades
Date: Mar 22, 2018
The only things the wings need is a reinforcement of the tip ribs, scroll down to page 21 in this link: http://oh2fly.net/oldpoops/Lexan%20rear%20enclosure.html The only thing the fuselage needs is a brace on either side of the lower rudder post to protect against excess side loads from the tailwheel, here: http://forums.matronics.com/viewtopic.php?t-198&highlight=tail+braces -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478792#478792 ________________________________________________________________________________
Date: Mar 22, 2018
In addition to the outboard rib angles I added a lift handle with extra supports at the wing tip. I also added extra "trusses" on the tailwheel support. See attached pics. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478793#478793 Attachments: http://forums.matronics.com//files/3_27_05_wing_aileron_set_up_2_001_136.jpg ________________________________________________________________________________
Date: Mar 22, 2018
This is the tailwheel supports. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478794#478794 Attachments: http://forums.matronics.com//files/3_12_05_drilling_extra_tailwheel_support1_844.jpg ________________________________________________________________________________
Date: Mar 22, 2018
Thanks for the great suggestions! Will include the outboard rib bracing and tail struts for sure..... has anyone incorporated additional diagonal bracing or a .016 to .020 aluminum leading edge?..... don't want to add weight and complexity unless there is a reasonable upside. Best regards to all who took the time to share ideas & photos, Mike Cranson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478802#478802 ________________________________________________________________________________
Date: Mar 23, 2018
Notice the diagonal braces from the leading edge to the main spar (B inside the triangle): It is not a bad idea to add a backup to them, because if the ribs between the spar and leading edge go out of column, really bad things will happen. I used some 1/2" x 1/2" x1/16" angle from Lowes. Sheeting the leading edge has been tried, it does not help, just adds weight. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478811#478811 Attachments: http://forums.matronics.com//files/p1060614_medium_124.jpg http://forums.matronics.com//files/p1060615_medium_483.jpg ________________________________________________________________________________
Date: Mar 23, 2018
Richard P has that right. The standard 5/16 leading edge braces have a tendency to fail due to vibration and time. They are also vulnerable to failure if your Kolb has a wing strike. Most folks don't realize how much stress the wing experiences from the main spar forward, including me, but that area of the wing is working pretty hard. Homer Kolb told me the sheet metal leading edge actually decreases the Kolb wing's performance. The fabric valleys between ribs enhance performance. I don't know, but I'll take Homer's word for it. john h mkIII Titus, Alabama Notice the diagonal braces from the leading edge to the main spar (B inside the triangle): It is not a bad idea to add a backup to them, because if the ribs between the spar and leading edge go out of column, really bad things will happen. I used some 1/2" x 1/2" x1/16" angle from Lowes. Sheeting the leading edge has been tried, it does not help, just adds weight. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 ________________________________________________________________________________
Date: Mar 23, 2018
Subject: Looking for Kolb owners near me
Would like to find someone with say 300 miles that would allow me to come see their machines. Would love to see it fly. Maybe even fold the wings. Gets in touch: robpen5557(at)gmail.com Thanks Robert Lobdell Waskom, Texas Flying is the second greatest thill known to man. Landing is the first! ________________________________________________________________________________
Date: Mar 23, 2018
Subject: Re: Looking for Kolb owners near me
Glad to see that you made it to the list. Hopefully you will be able to find someone to help you out. Not sure about the three hundred mile limit however. Good luck, Larry On Fri, Mar 23, 2018 at 4:02 PM, Robert Lobdell wrote: > Would like to find someone with say 300 miles that would allow me to come > see their machines. Would love to see it fly. > Maybe even fold the wings. > Gets in touch: robpen5557(at)gmail.com > Thanks > Robert Lobdell > Waskom, Texas > > Flying is the second greatest thill known to man. Landing is the first! > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Mar 23, 2018
Why not drop in to Sun And Fun and see the folks at Kolb, they will have reps there. Larry On Fri, Mar 23, 2018 at 4:02 PM, Robert Lobdell wrote: > Would like to find someone with say 300 miles that would allow me to come > see their machines. Would love to see it fly. > Maybe even fold the wings. > Gets in touch: robpen5557(at)gmail.com > Thanks > Robert Lobdell > Waskom, Texas > > Flying is the second greatest thill known to man. Landing is the first! > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Mar 24, 2018
Richard and John...... Great input regarding the diagonals..... surface contact between 2 round tubes is minimal to begin with.... then asking a 1/8" pulled rivet to exist happily with about 3/8" grip length and reversing loads...... ahhhhh... must be a better form. Will fab up something that improves on existing and add one "V brace" style with concentric contact points to either end. Thanks! Mike Cranson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478842#478842 ________________________________________________________________________________
Subject: Mk3 Xtra Fuel Tank Install....
Date: Mar 24, 2018
Dennis at the Kolb facility is making up an aluminum 18 gal. tank for the 3X . I'm not fond of a fill in the interior of a fuselage so am looking for ideas for an exterior fill. Rural nature of use will require fueling from cans at least half the time so underwing location doesn't seem too feasible..... has there been any success mounting one below the engine through the aft flat area of the fuselage or vertically through the center section? At this point the tank and fuselage fittings can be located wherever works best. Mike Cranson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478844#478844 ________________________________________________________________________________
Subject: Re: Mk3 Xtra Fuel Tank Install....
Date: Mar 24, 2018
Mike, see if you can find a pic of John Haucks fuel tank, mounted high inside the fuselage. after 3000+ hours it obviously works Fair winds, Russ K > On Mar 24, 2018, at 1:05 PM, k3x wrote: > > > Dennis at the Kolb facility is making up an aluminum 18 gal. tank for the 3X . I'm not fond of a fill in the interior of a fuselage so am looking for ideas for an exterior fill. Rural nature of use will require fueling from cans at least half the time so underwing location doesn't seem too feasible..... has there been any success mounting one below the engine through the aft flat area of the fuselage or vertically through the center section? At this point the tank and fuselage fittings can be located wherever works best. > Mike Cranson > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478844#478844 > > > > > > > > > ________________________________________________________________________________
Date: Mar 24, 2018
Mike I have a filling system like you have proposed. It is in a higher pressure area so you don't have to be worried about fuel flow issues if the seal gets compromised. I used a boat fuel filler that also has a vent for venting when filling and fuel delivery. I do caution that the angle of the tube back to the tank is low so there can be some burping of fuel if your fill too fast. Using 5 gallon cans is never a problem but filling with a huge airport fuel nozzle takes careful use. Also Lexon doesn't like fuel being spilled on it. I can send a more higher res photo direct if you need it. Rick Neilsen RedriveVW Powered MKIIIC On Sat, Mar 24, 2018 at 1:05 PM, k3x wrote: > > Dennis at the Kolb facility is making up an aluminum 18 gal. tank for the > 3X . I'm not fond of a fill in the interior of a fuselage so am looking > for ideas for an exterior fill. Rural nature of use will require fueling > from cans at least half the time so underwing location doesn't seem too > feasible..... has there been any success mounting one below the engine > through the aft flat area of the fuselage or vertically through the center > section? At this point the tank and fuselage fittings can be located > wherever works best. > Mike Cranson > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478844#478844 > > ________________________________________________________________________________
Date: Mar 24, 2018
I reinforced my bow tips with the standard brace in line with the main spar plus an additional brace at 45 deg forward from the original brace. I used 1/2" .032 6061 tubing plus I installed a sheet aluminum web between the top and bottom tube brace. The web keep the tubes in column. I can now push my wing up by the bow tip until I lift the main gear nearest me. Bow tips built the standard way have a lot of flex and would probably fail it you tried that with them. I also used 1/2" tube braces on the leading edge of the wing. Compressed the tips and used about 4 or 5 rivets to secure on each end. After 3400+ hours they are still hanging on. ;-) john h mkIII SN: M3-011 Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of k3x Sent: Saturday, March 24, 2018 11:46 AM Subject: Kolb-List: Re: Wing structure upgrades Richard and John...... Great input regarding the diagonals..... surface contact between 2 round tubes is minimal to begin with.... then asking a 1/8" pulled rivet to exist happily with about 3/8" grip length and reversing loads...... ahhhhh... must be a better form. Will fab up something that improves on existing and add one "V brace" style with concentric contact points to either end. Thanks! Mike Cranson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478842#478842 ________________________________________________________________________________
Date: Mar 24, 2018
We built an 18 gal aluminum tank for my original Firestar. Made the fuel fill from PVC and chrome plated brass P-Trap. Ran the fill pipe back to the top rear of the fuselage under the engine or to one side of the engine. Can't remember for sure. Last time I flew it was 28 years ago last week. We built a 25 gal aluminum tank for my MKIII. I fill it through the top rear of the center section. Pain in the butt to remove and install center section, but that is a task I seldom am required to do. Used a sight gauge for both Kolbs secured to the rear bulkhead so I could/can easily see the fuel level. Very accurate and fail safe, I hope. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of k3x Sent: Saturday, March 24, 2018 12:05 PM Subject: Kolb-List: Mk3 Xtra Fuel Tank Install.... Dennis at the Kolb facility is making up an aluminum 18 gal. tank for the 3X . I'm not fond of a fill in the interior of a fuselage so am looking for ideas for an exterior fill. Rural nature of use will require fueling from cans at least half the time so underwing location doesn't seem too feasible..... has there been any success mounting one below the engine through the aft flat area of the fuselage or vertically through the center section? At this point the tank and fuselage fittings can be located wherever works best. Mike Cranson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478844#478844 ________________________________________________________________________________
Date: Mar 26, 2018
I have the standard plastic tanks in my Mk 3. It was the bending over that just did me in trying to fuel and after several tries I came up with this. It's mostly PVC pipe with some odds and ends from strategic resources (junk pile). The legs are titanium from a piece of tubing from Boeing Surplus and the fittings are some old hang glider parts. Works well and prevents spills . Rick On Sat, Mar 24, 2018 at 2:35 PM, John Hauck wrote: > > We built an 18 gal aluminum tank for my original Firestar. Made the fuel > fill from PVC and chrome plated brass P-Trap. Ran the fill pipe back to > the > top rear of the fuselage under the engine or to one side of the engine. > Can't remember for sure. Last time I flew it was 28 years ago last week. > > We built a 25 gal aluminum tank for my MKIII. I fill it through the top > rear of the center section. Pain in the butt to remove and install cente r > section, but that is a task I seldom am required to do. > > Used a sight gauge for both Kolbs secured to the rear bulkhead so I > could/can easily see the fuel level. Very accurate and fail safe, I hope . > > john h > mkIII > Titus, Alabama > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of k3x > Sent: Saturday, March 24, 2018 12:05 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Mk3 Xtra Fuel Tank Install.... > > > Dennis at the Kolb facility is making up an aluminum 18 gal. tank for the > 3X > . I'm not fond of a fill in the interior of a fuselage so am looking for > ideas for an exterior fill. Rural nature of use will require fueling fro m > cans at least half the time so underwing location doesn't seem too > feasible..... has there been any success mounting one below the engine > through the aft flat area of the fuselage or vertically through the cente r > section? At this point the tank and fuselage fittings can be located > wherever works best. > Mike Cranson > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478844#478844 > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Mar 26, 2018
rickofudall wrote: > I have the standard plastic tanks in my Mk 3. It was the bending over that > just did me in trying to fuel and after several tries I came up with this. > It's mostly PVC pipe with some odds and ends from strategic resources (junk > pile). The legs are titanium from a piece of tubing from Boeing Surplus and > the fittings are some old hang glider parts. Works well and prevents spills PSSSTT! Rick! The picture! You forgot the picture! Rick! Rick? You OK Bro? Talk to me Rick! -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478877#478877 ________________________________________________________________________________
Date: Mar 27, 2018
That's odd. Both pictures are there in my copy. I shall try again. Rick On Mon, Mar 26, 2018 at 10:28 PM, Richard Pike wrote: > > > rickofudall wrote: > > I have the standard plastic tanks in my Mk 3. It was the bending over > that > > just did me in trying to fuel and after several tries I came up with > this. > > It's mostly PVC pipe with some odds and ends from strategic resources > (junk > > pile). The legs are titanium from a piece of tubing from Boeing Surplus > and > > the fittings are some old hang glider parts. Works well and prevents > spills > > > PSSSTT! Rick! The picture! You forgot the picture! > > Rick! > > Rick? > > You OK Bro? Talk to me Rick! > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough, being forgiven is wonderful, and God's grace really i s > amazing. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478877#478877 > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Mar 27, 2018
I came up with a simple fix to fuel my mkiii. I made an extension to fit my gas can nozzle. With the 5 gal gas can on the ground the extension will go to the bottom of my 16 gal alum tank. I lift the fuel can to my shoulder, grab an exposed alum hinge to eliminate static. Boyd Young ________________________________________________________________________________
Date: Mar 27, 2018
A friend of mine who owned a Pitts S-1 was fueling it from a 5 gal can as I walked past his hanger. This was many years ago. I was amazed at how simple his fueling system was. His fueling system consisted of a plastic 5 gal can and 6 feet of 3/4" ID plastic tubing. The tubing was pushed on to the nozzle of the can. Stick the tube in the fuel tank, lift the can higher than the nozzle and you are home free. On long cross countries I always carried that tube. Now days I carry an Alabama Credit Card which uses the little shaker valve to start siphoning fuel from the gas can. I usually sit the can on a folding ladder, if available, or on top of the engine if all else fails. Since I have gotten older, I usually don't try to save money fueling from 5 gal cans. Lots easier to fill from the 100LL pump. Experimenters come up with unique ideas to accomplish what they need to get done. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: Tuesday, March 27, 2018 8:48 AM Subject: Re: Kolb-List: Re: Mk3 Xtra Fuel Tank Install.... That's odd. Both pictures are there in my copy. I shall try again. Rick On Mon, Mar 26, 2018 at 10:28 PM, Richard Pike wrote: rickofudall wrote: > I have the standard plastic tanks in my Mk 3. It was the bending over that > just did me in trying to fuel and after several tries I came up with this. > It's mostly PVC pipe with some odds and ends from strategic resources (junk > pile). The legs are titanium from a piece of tubing from Boeing Surplus and > the fittings are some old hang glider parts. Works well and prevents spills PSSSTT! Rick! The picture! You forgot the picture! Rick! Rick? You OK Bro? Talk to me Rick! -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478877#478877 -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution -- =9CBlessed are the cracked, for they shall let in the light.=9D <http://www.goodreads.com/author/show/43244.Groucho_Marx> Groucho Marx ________________________________________________________________________________
Date: Mar 27, 2018
Boyd's message popped up right after I hit the send button on my fuel fill system. ;-) Great minds think nearly alike. ;-) john h MKIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of B Young Sent: Tuesday, March 27, 2018 8:59 AM Subject: Re: Kolb-List: Mk3 Xtra Fuel Tank Install.... I came up with a simple fix to fuel my mkiii. I made an extension to fit my gas can nozzle. With the 5 gal gas can on the ground the extension will go to the bottom of my 16 gal alum tank. I lift the fuel can to my shoulder, grab an exposed alum hinge to eliminate static. Boyd Young ________________________________________________________________________________
Date: Mar 28, 2018
Again, thanks to all for the ideas and photos..... generous and well appreciated assistance. Here's the result..... so far. Will try to post a photo or two as the wings progress toward covering. Mike Cranson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478911#478911 Attachments: http://forums.matronics.com//files/dsc02108_173.jpg http://forums.matronics.com//files/dsc02107_996.jpg ________________________________________________________________________________
Date: Mar 28, 2018
On 3/28/2018 8:16 AM, k3x wrote: > > Again, thanks to all for the ideas and photos..... generous and well appreciated assistance. Here's the result..... so far. Will try to post a photo or two as the wings progress toward covering. > Mike Cranson Looks nice, but did you weigh that blue tubing? (How often will you be *re*-wiring your wing?) Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Mar 28, 2018
Mike C, I've attached the Kolb Co modification of the wing rib. You may want to reconsider your current mod. john h mkIII Titus, AL -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of k3x Sent: Wednesday, March 28, 2018 8:17 AM Subject: Kolb-List: Re: Wing structure upgrades Again, thanks to all for the ideas and photos..... generous and well appreciated assistance. Here's the result..... so far. Will try to post a photo or two as the wings progress toward covering. Mike Cranson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478911#478911 Attachments: http://forums.matronics.com//files/dsc02108_173.jpg http://forums.matronics.com//files/dsc02107_996.jpg ________________________________________________________________________________
Date: Mar 28, 2018
How is it possible to have an aircraft workshop that clean ??? Wing construction looks great to me. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Wed, 3/28/18, k3x wrote: Subject: Kolb-List: Re: Wing structure upgrades To: kolb-list(at)matronics.com Date: Wednesday, March 28, 2018, 6:16 AM Again, thanks to all for the ideas and photos..... generous and well appreciated assistance. Here's the result..... so far. Will try to post a photo or two as the wings progress toward covering. Mike Cranson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478911#478911 Attachments: http://forums.matronics.com//files/dsc02108_173.jpg http://forums.matronics.com//files/dsc02107_996.jpg The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Mar 28, 2018
Subject: Firestar / HKS update
Hi Kolbers, greetings from Los Angeles, It's been a while since I updated the list on my progress with the HKS inst allation and airframe repair on my FS2. Progress has been slow but steady. I've designed and fabricated an oil cool er plenum and housing, and have designed and fabricated a center section le ading edge fairing. Both of these components are almost complete, requiring final trimming and some mounting details. The oil cooler plenum creates "updraft" style cooling. It will take air fro m a scoop underneath the wing (high pressure) and run it upwards through th e cooler, and the top of the cooler is flush with the top surface of the wi ng (low pressure). It's mounted on the starboard side of the upper cage. The old center section fairing that came with it would not fit around the H KS engine, since it had been made for the 447 or 503 that came with the air craft..It had been made out of clear plexiglas or lexan, and was nicely con structed, but it weighed 3 or 4 pounds and I have no need for it to be tran sparent since my Firestar will be operated as single seater. I designed a light weight sheet metal replacement, using .016" aluminum and light pop rivets. A wooden form block was made to match the shape o the fo rward wing rib, rib blanks were cut and "notch-relieved", and the metal was hammered around the form to make a left and a right side rib. Another piece of .016 sheet was wrapped around a 7/8 rube to make a leading edge radius (1/25" after "springback". This was assembled on a bench with a whole lot of cleco-ing, drilling and re-cleco-ing. A decision was made to add one extra piece of vertical/spanwise aluminum in order to stiffen the skin against oil-canning. That piece was fabricated and installed, and the entire assembly was finally riveted together. A light coat of Zinc primer w as sprayed where metal would be touching metal. I'm pleased to report that this fairing weighs about half of what the origi nal fairing did. The intent at this stage is for this sheet metal part to be slid into posit ion after the wings are unfolded, and to be retained by the overlap of the skins onto the root ribs of both wings. The original center fairing was hel d on this way using Velcro, but I believe I can use a spring clip or quarte r-turn fastener of some type to make it easier to get on and off. After these photos were taken, I added the recessed part of the scoop to th e underside of the fairing. This will eventually mate up with the oil coole r plenum and the rest of the scoop (which is not done yet). I also made up a "Swiss Muffler" as referenced in the Tony Bingelis EAA boo ks, as an attempt to keep the aircraft as quiet as possible. This muffler i s clamped under the tailboom tube using rubber padded clamps and spacer blo cks. Photos and details of the muffler are available if anyone is intereste d. Bill Berle www.ezflaphandle.com=C2- - safety & performance upgrade for light aircraf t www.grantstar.net =C2- =C2- =C2- =C2- =C2- - winning proposals fo r non-profit and for-profit entities === /9j/4AAQSkZJRgABAQEBXgFeAAD/4TueRXhpZgAATU0AKgAAAAgACwEOAAIAAAAgAAAIngEPAAIA AAAFAAAIvgEQAAIAAAAJAAAIxAESAAMAAAABAAEAAAEyAAIAAAAUAAAIzgITAAMAAAABAAIAAIdp AAQAAAABAAAI4pybAAEAAABAAAA6+pyfAAEAAABAAAA7OsSlAAcAAAAcAAA7euocAAcAAAgMAAAA kgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAACAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAAU09OWQAARFNDLVc4 MzAAADIwMTg6MDM6MDggMTc6MTU6NTYAACKCmgAFAAAAAQAAEoyCnQAFAAAAAQAAEpSIIgADAAAA AQACAACIJwADAAAAAQGQAACQAAAHAAAABDAyMzCQAwACAAAAFAAAEpyQBAACAAAAFAAAErCRAQAH AAAABAECAwCRAgAFAAAAAQAAEsSSBAAFAAAAAQAAEsySBQAFAAAAAQAAEtSSBwADAAAAAQAFAACS CAADAAAAAQAAAACSCQADAAAAAQAfAACSCgAFAAAAAQAAEtySfAAHAAAoAAAAEuSSkQACAAAAAzAw AACSkgACAAAAAzAwAACgAAAHAAAABDAxMDCgAQADAAAAAQABAACgAgAEAAAAAQAAFCCgAwAEAAAA AQAADxigBQAEAAAAAQAAOuSjAAAHAAAAAQMAAACjAQAHAAAAAQEAAACkAQADAAAAAQAAAACkAgAD AAAAAQAAAACkAwADAAAAAQAAAACkBgADAAAAAQAAAACkCAADAAAAAQAAAACkCQADAAAAAQAAAACk CgADAAAAAQAAAADqHAAHAAAIDAAACoDqHQAJAAAAAQAAEGwAAAAAHOoAAAAIAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKAAABLAAA ACEAAAAKMjAxODowMzowOCAxNzoxNTo1NgAyMDE4OjAzOjA4IDE3OjE1OjU2AAAAAAQAAAABAAAA AAAAAAoAAANyAAABAAAAAcIAAABkU09OWSBEU0MgAAAAACggAAAHAAAAAQAAAAAgCgAEAAAAAQAA AAAwAAAHAAABSAAABMawIAACAAAACQAABg6UAAAHAAAAmAAABhiUAQAHAAALEAAABrCUAgAHAAAB hAAAEcCUAwAHAAABkAAAE0SUBAAHAAABqAAAFNSUBQAHAAAF2AAAFnyUBgAHAAAAEAAAHFSUBwAH AAAAQAAAHGSUCAAHAAACvAAAHKSUCQAHAAACWAAAH2CUCgAHAAAAqAAAIbiUCwAHAAABkAAAImCU DAAHAAAAQAAAI/CUDQAHAAAAyAAAJDCUDgAHAAAAEAAAJPiwQAADAAAAAQAAAACwQQADAAAAAQAG AACwQgADAAAAAQAEAACwQwADAAAAAQABAACwRAADAAAAAQABAACwRQADAAAAAQAAAACwRgADAAAA AQAAAACwRwADAAAAAQAAAACwSAAIAAAAAQAAAACwSQADAAAAAQAAAACwSgADAAAAAQAAAACwSwAD AAAAAQACAACwTAAFAAAAAQAAJQiwTQADAAAAAQAAAACwTgADAAAAAQAAAACwTwADAAAAAQABAACw UAADAAAAAQAAAACwUQADAAAAAQAAAACwUgADAAAAAQABAACwUwADAAAAAQAAAACwVAADAAAAAQAA AABNTQBeAQIyMDE4OjAzOjA4IDE3OjE1OjU2ABQgDxgAAAIIAAAAAAAAAAAAAAAAAAAAAAAJVEht MjExMDAwMDAwMDAwAAAAAAA+lPoBAAAAAAAAAAAAAAAAAAAAAAAJAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAU3RhbmRhcmQAANEB AQAAAAAAAQABcGmIlQD/Vf9V/1X/Vf8R/xH/Ef8RAACUsQAAtE4AAAuiAACFqwAAAAAAAAAAAAAA AAAAAAAATCPWAEwwpwBMoAQATOJuAAAAAAAAAAAAAAAAAAAAAABFAJEAAAAIAAgAGwAAAAAAEAAA AAgAACCVioEAAAAAAAAAAAAAAAAglYqBABsACAAIAAAMlwAAfAAAQOzFkkL//X3+56EAeShXKDXs IQEIAACVAAAAzY+K2o8HAAh9AH1KAHwAAJUA4VwAAAE0CO/jkwjEWi5KQQ7NKhYI2KH2DgI2lcQ/ B4ERQYeG0676PMk8PwfEDs8yq0CGWsQA/////wjj3agAcAVwAn6SXKx0m6G87BslGyH+AH08+Q52 BVuXxK59SX1tfW19SX08w0aVfUX2Q6Q8XONglRtzBJWoJIrQeTQAP5U8dn08gcdCIPbpqQDhB2kA vg5pxBJm40BOgYqKSkBp58VqxL4OWYEi6lEAgNMFSSf/////////////////////dkoUaSQBAcQ9 6io+u4GPXU5/YmJiYn/CwsLCYk9FdHRFT2JOwsJlz1QyMlPPZWJ/f3Ruw9QxWFvu9mJiE2Exr7CD 0M9PYmJ0bsPUMVhb7vZiYmXPVDIyU89lf39/Yk9FdHRF9mJOwsJOf2JiYmJ/wsLCwth95EAe2BZW Qr4mKOSgSNfsXe85sTlXXhUFHruFgapqwYc5GtLTRiSXAnnvmte07ODTFOzRGs1HP4dzxcxH5itk rA3Ts12AgZ0FUzAyMNQgCV1xy426b0diOeRdcyB1MEswOM2LXHcMkAf/TILilL41gX6I6gTyMOeB gWx5bLaHrqCkUZsFnmlZtiqKgeztu4UwJgxzalKSy2xiVhWKZIqkBS1pM2mEB4oE6gz1UVMaUeow zRDq2uppBJHqkpVyijde7erBoD4BTRtSG35AE30QfXpAOn1C2E4btUBnGxhAddhKQFdAfV4F2PpA hRtaAUEIXwj9CKEbKV5lXsVADQgsCMsIhQHhG8YbnhscG6MIPwg2AZ4IfRsvCJsbsNi2QFIIDAhF Aa0Ifhs2G10It0DPG6UBhAESAbIBPgH/QFYbagGYGyMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAElSAM13vsDVzV h/pdpPCaJBdpN5IXDKsohALe0ziVaWAA4CfXhte9ILqVXuJnUZmVSLqOR5+7Zbb9DH/THNfx7BqV kNPXTEqKoLahvnIwBZLQgTVs02A/TG/qRXDzMBeBLFFboCIM6+8FGukENQWdiKW+XGqCrA4aNwzF XBEaig67uxldJz00QJl6jU8ArzwIgQDEaRuPcEB9TrZGXlQ4B+reAUBROD9KcMftdn9VsHS3lclp 4eQBAMQItThdCAFFfeob3Q4BAAHrCLcI8hscG5sbVEArQL0BnQiaCH4IN0AWGzkI/EC5QJAITwgk ARcIjUDFGxsI+33jfRoIvwEDCH4buwhdCMYIfBu+G94BsAGuCJgBeAjoCMsIP0DZGyIBrAF+AfoI whsOCJwIPEBgQBABigEQAUIB/xvEQMgbrQgnGxAAAwFiAScBngjNCPABLggrCBUBJwEmATgBmAi9 AbQBfgirCLQB1QFEAOQA6wFMAQEB2wjVCIQB7QFqAD4BDgBmAeUBFQFYAXcBMAEIAK4A3wFgATkB kwhLAbQAnABvAIQA/AHbAZEAZwGeAb8AlABCAHoALgAXAXcB7gCmAZZqflxMXYIvKl0DUfsvI12m 0+vTmtOyamMvcS8raj5dIy8TL/Zdry/s0yLT/mq7XenTOi+ZapVRWtNyXSHTZC9W06xdTF1gXFFs FGw3ttjsw12O0x0v3dNQXfMvM1HqL0NwzLvsURPFYGoVXVwvH6CEoMQMfLs2XdugzF0RajVqD1GU 01sgSrsOuzYoJC8JoA0vkZUQUbbssmoBIPOBYwyO7BLsmKBoUVgMldNykjtRmyguKLG7TiD3IAq+ KmxQoMCIF753DCrXQterkqSSIZJBuwOSgZJoDIqSRgwxu7wMMLsegaO7Krtvu9aBEZIoktaSmbt2 kga7uOzV1y8Mg5Iegea71pLCknWBCYETu1hqIsVvy6TT/Qy1uxO7dgwnkkkogAzZldxH/kw7ksS7 voF3kg6SZJWeoAddjF3lu97sDQyCkk27JpLyDA/vtDnMatRRe+wtla+7XZUTUb5qdCgw4lqH0gfN OX9ccpWooLldqijAByzsK5UKOUcHuxoU8MAHYWxgbEDiXfBqB64ARwAAAIwBC31pfZF9I0DRQL9A ckBRADQIMn3H2EJ9cn0QfRHYxn0CQIVAC33/fcR9FQi1XqMb8kBC2IR9MX1wQD7Y89jA2EoAxwFa XvIBlUBBfZd9hUCgfcsbkQgLANFe5gFkQJ5e2tj5fcxAawCHAG8BswCQQD8BCkCzfWHYkkATG54b 4ggcCAUAWQiNAOx9fwAvAHMBPEB5CIgISwGzAMoBKwBdAFgAnhu+Gw4IHgDaAQABEAhcASkBlwHR AD4AuQi7CDcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAOswAAAAAAAAAAAAAAAAAAAAAAAAAADrMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADYwl5gBFxwe7tjlVtRNqBAXEWHFoeJ VnlwsNc/DJZqbIeYTBA5qO+JtwR5wbsbKEKgEGxhByDvtcX0Gngrw7qUK1AvnS8DDNYwjLsVKAYo 2cUbK4u60Uekak5RS77kIIUwQIhvUbXTF0w075MkzbsbgSUgJHBRMFi7FexhUVQ5611RXYxw6Wmu tgZw+oEZuxKBp+wjUYagSVGrzQSKSoq9iou2/TAGbBFpv7vgoDlcXOp3zXvNwurt6ky2M5KmiOfq pYhqoLkAvgC+AL4AlgDQACEAAwHkCDZ9IdhyXrbnuuqFirVwNeo2VtkFummYts6IibtMKH/XCgH8 AMwA0AAAAL4AvgC+AABKAAAAAAD/xG1GAABtRgAAAPYAAAAAACcA9gAnAAAAAAAAAAAAAAAnAPYA JwBdAD8AAAAAAPYAAABdIJWKgQAAG0MBIC8yAAAAAAC+AVCKrL4JXACgBxsBAE8ATxslQEP+ABsl GyH+AAGKG30AAABb+/3+AP4AAAAAbwAAAHMAAH0gAAA5ewAAbKwAAA5QAAAi3BtGAAABAAEAAAAA AOehGyV9Uv/WGyXYKv/WAAAAAQfmASAAAAC7AIAAADBb5n0AAAAAAAAAAAAAAAAbQwAAG0MAAC1+ qgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbRgTlAKYAANPTP+xYwq4AGwEAZdeaG4wAAFwAkieK RCQAAAAAAAAAAAAAAAAAAABJOf1WQEOVywAASlwOJzpcBBAAKJ60OtPu6kAASsgAAAAAAAAACBsl GyVAQ0CQ/gD+AAAAAAgAAQAWAAAv0AAA1/UAAfz8AAAbJX1L/IsbJX04/IsbJX1w/MkAACdRfz/F ES+VtIHFhwgFDg6hUQCB8Xn4l//////y13532xF5AK8AOtiGhscvEYE0QkkAEQT2l9ddU1YnIBCz 5xtuSgQiEUCX9koESg3hhzrazBFCQEAIlUUE9t2WlrH29zwBlQjCcMKVw5gAOszOzb5pDuYpCDq2 AL7Yphsp7gAKAF0AcBu/RgHpAMcOrRbDQMVmzsdRSwh2AbG2yV0oxLoIDjjhfhTgzJVKAMX3486V UT5K2ACkxZJcwu4HOg4nCL5WBQAAAAAAAGzqZgAAAChwfXBecF5w2HDYACjnoerZAAAAAAAAAABw lIqU/wAAAAAAAAgAAAAAAGlTAAB9AQAAAQAIAF0AAAAA/wAAAHAAlQAAAMwA/wEA+NcBAACjGwAA AAAAXgAAAAAAAAgAAAAAAAAAAAABAAAAAAgAAAAAAAAAAAAAAAAAAA4AAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACKcAhwIYpg cP6KVnD5inyKfXAAiv8I7AAAAEAAAAAAfQAAAAAAAHpplIpSS0tSS0tLS0sAaQBpAGkAigBpAGkA aQBpAGkAxhHGEcYRxhHGEcYRlxGXEcYRAIFAhwD4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAADQAAAAAzWkIAAAAAACSAb2CEVuzTygBAf/+AAAAAAAAAAAAAAAAAAAAAAAAlv8uAAAA AAAAAAAAAQBpRzhHUkeAR4DNAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABKa0prShd9 cG3dbVtt3VZwn/mfO5/553BKNUq0SsbNcJ/Znzufm81wSrRKUEqU53CfEp8SbQQFcEpQSklKUARw bQ5tDm275yRKSUpGSncOJG27bbttrARGSr9KVEq/DkZtrG2HbboERkpUSjlKVFZGbYef621M6iRK OW2kSjlWJG0AbQBKACgkbS1tpEoAUSRKAEoASgDnJEoASgBKAF4kSgBKAEoAfSRKAEoASgDYJEoA SgBKAH0kSgBKAEoAfSRKAEoASgB9JEoASgBKANgkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAA0DgEBAQgAAAAAAAAAtgD+AAAAAABtAAAMFRKVxFaWXQBtAAAAACgSAAC+AEovRwht AAeS3Qi7lgCA4wBVzAHhAAAO4wVKCPbnoQhDAL4AGoi8ALU4tEBwtpXC7EA8SkuWfjpKqA724QiB lQBAAA6raQAkQFHTGuKJABsb7DSWSigoAT0AuILDtkbkgzyIxA44tlW9rgAAcMQIB1LX4cSWIJXp F+NAu0+WSvY9TxAAAB9LSUAvDsfyxNjEAfZdQC9TAMdwdToxllynQEBJG4cAYpYIxEcBVNtAAOE8 +DoOxJVRAAq2ARrj6Q7OgSkozEoansTEKYEA4WJKxAHuhsJKJ4WW17MnL0u2VlW708TjQAGVaUrT 092rvmDwSr72CMlOJwgeztNJOM4bBwBRXQChQOfTSgBL8OFD0T8BfUoodYGubtAA8iCCgSBmOGq2 wlSVgclAQADE51sBj55woeFLcKpYAGzjBwjEk5mVB2R4ol0gNMEgCFFuGrYOhjgOP8SSrMc+aQS2 HpF5vnmnQAj2xA4+VDZJJgEw3AiGzCcxlUGVDkMBCA4HAFg8SgEHOhauL85JgncZfc06OgjHQARw trwDzCmB0wQB2wGBSl1RP7eBrkCV5lFwANM/KIcx+iQ6L1HHUTpCx4aSx7FKOBXFBQAk9iB2x+fi 08Xqx4fnJA4UXg4IhQIbkcWVlhRWAd2RDggkSgTlSmYz6joJsuoOStAIfUtOIA6qAUVRlgkOiLPh IAFYB2IFZkUYaRkAfSpAldOLB0DF4QAI6W5LhtduABsDwAFwRlgIlZbncLy2AHHYzWA/ME8OCAAI 46xRBzDuPZJpWIHqxGuKLcQkAI/dAQBMOs2BBUo6QAbCQHAySc1MQPbidmk0Sc0CMRHbxNN2gT92 6krCgX7E3JbEiHJwn0BAlccAXczBFF9peOqtKepAikxrnhtPQIAnBCxJGmGFcErjCj8IEGx9AAyT GueJ9kI4fYHltvw+S+oolXkBP0l0gbY0XfaBda7sP8nJ41QRnj4wSuQ/xRRwThvjAQCkCDY4zgjh JwA6zLOVfQABygQv2Urj7KAI3TBKAeHNcGrnscIOf+IOqTA8OFh0qMLpwvo/TzxqxECBAZYAMOx5 uyuVj0ZKG0tlcMLe2LrjDjTCSg7Fzz/ElQAnSdu9S9jZTpUkUrcADgCBXTxAgRsH9uGIVAHTgd0b KX32EAFeEAFAPcRwXi9SBy2ywoY/VA4A4744IDy+d6IBR2cBEUkARoHy9kBJx6oBvn/P5+JwwEvE Dg6u8wB1cjFK9gkQQAEAAbY7AAjM4twUbKbTNhXzXspKEcSysj84KJWVC7ZBP7PQDqw9U1A4xEpN GVIOBMcADmJLGQDYlczhxFMBQJVpTgHeCKipGb9ujtzE58QAfgA7qsjyAMQOzEpd7udAMHAAGycA QDoDSr7AABLiJyBYOoNzwKyHwpJOGwEQXdO2SszFCEcAOyi2DlQn7g7ERwETiBV/JFbsVIEA53k4 2AFLlbYIknAI2JWzAsQA4MR9hZU4674vOeFPSsI3sW5Ad7Y/laAe0FHTfSDn5V3u9uezHwABS3gS 1eNVJLrYAtg8LAEODgjJ8A4vAEwbtqVBSsgAWABA4wjcxKpSAEDEU03MkUYAeTjE6gQblu+851Eg WAcZUuNKPwjEGz6VXJUA32LTCNPnB83ELwAASgDh2EeVcABFQDeW7sQAQFQA7lF9kes9dSSlrqJp eicAnfIkDsRAPuMkfT5RJJXj2ECUUVQZkvcZYpMg6MRHN/YqZGqVxFEFv/CBQARAWkoAGokBuxA8 DoEBAAHCWMc4tocE3DizQADEMgECQIoEUkDMQMI0x0okZiCI3QA9Vk5cTn3E08yVVU7ijwDCDrIB QN0AAcLrCAZNXVbEDgBRspVAKJABAABHtpXXuilTAEmWxNi2AEqkngiWrEqslswOgjyWvre+AEov Rwg64cWx3Wm7lvaA4wAGzAHhiEAO4+pKG8QEAM32SrU4XRoI55UkACBwtgBA7EB2AEuWOjpKqA72 4QiBlQBAAA6raQAkQKXTGuKJABsb7DSWzCAoAT0AuILDtkbkgzyIxA44tlW9BzgAcMQIBzjX4cSW IJXpjeNAMjKWSvY947wAAB9LSUAvDsfyxF7EAfZqADlTQMckdToxUlynQEA9G4cAYpYIxAcBVNtA AOE8qK4OxJVRAAq2ARpL6Q7KgSkozEoanjjEKYEA4WI/xAHuhsJKJ7SW18EnL0u2VlW788TjQLaV hkrT092rvh3wzNfQCBlOJwhQzghJOM5eBwABFAChQOcvSgBL8OFD0UoBfUoodbuubtAA8iCwgSA+ OGq2wiCVgXxAwgDE51vjj55w4eHycKpYAGzjBwg0W5mVlWRYol09NMEgCFhuGrYOHlTnP8SSrMc+ aQS2HpF5vnmnQAj2xAc+VDZJJgEw3AiGzCcxeUGV0D4BCA4HQAgHzTnhqs22dhbg3ZUBOoEOGwi2 QHAPlarlXTdpdEpdTEwAXk3M0JZLB7aBIGlHVEEAXbzFPJ4vDmVKYX7EDrsAlqhnF1RW1bbQ1c4O IFOkAT1LBLLbx1RyXWkAKefCTo+VcDuBu8RRxGHhwgBweCBpd0SkPx7EugAAAD9gfVsbTVPCSg5w bsRcx8fNNIGFQE72TPIAgYtWhtchVpCBdVY/Bfhp1wXUadYFA2nDAEz+hvl4+xIAGv6X+XD7hAAA AAAAAAAAAIAFRDAyAC3NJr6SAJNMP6kACOBwAAUbSgDNCEowASQAAAAAAAH///////////////// /////////7xnGrlXNu/k/////////////////////////////////////////////////////xVZ h6BuA+Dkf8S3f8I+uvwn7uL6dG/gp///////////B4putjq8XWpl3Wqr/////1P2R4JODrcNwhlH /m70UTVOqyvmAAAAAAAAAAAAAHxAxHQAAAAAAAAAAAAAAAAAAAAAAAAAANeSiITvg9suG3+5LwAA AAABciCqBEIAAACWG+heMQC+BF/Y5gQB/////+eYAAAAAAAAAAAAAAAAAAAAAAAAW6UCM1uiAktT lLc/U5S3aFOUt2hbogJLJ4riLieK4i5bpQIzW6UCM1ulAjNbpQIzW6UCM1ulAjNTlLc/W6ICUlui AlJTlLdoAP8A/wCwAJUA/wAAAAAAAAAAAAAAAAAAAAAAACfu4voABAAAAAAAAAAAAAAAAHSNAAA6 AwAAP/1bpQIzAAAAAAAAAAAAAAAAAAAAAAAAP/0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD/9 W6VbpVulZQD/AHkA/wBwAP//AAD/AAAA/wABhggAADhuEAJ3bhACzACAAAIAgAgACADYSv0HAND/ zH1g/38AIP4SQPwBIQEAAcYBIQEAAcYbBwEgAADEdFc27+TdifByW6ICUtT3h98AAAAAqgAAAAAA AAAAAAAAAAAAAEAAAACVCEoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADbAAAArAAAANsArACsAABb ov9k/1n/+gDwAJEAaQAcAF08d4wfFH5azmZmxxQ0iFyyPpUBcMA9ZtMnoerng5ZwfcjPUV2VSiB5 toeBB8zBfsMEftu0WAHO4IHJzm9lniWAxXbmAEyVqShKXA4nrl0EEAAoniU60+7qQABKyH4aOhtl AVDM2MQA004H6MNqKcxMRwB8UeorXJUiJH+3q0D2AJlbqBtSAYYB2OYHrrrBDscWQJVA5scAGyhG h50H84CWXdJlVgIAACMAuz/Fx9ihS6SRR0C0CIc5QAoACAAAzL4ACNPM5wB9fySFyVxKShABKQGA 8gikZSBJH1bY08RYDkoHXA4kG8sidMdJOsc8flGVEUBKl5WFsikMXVEOTEovuD/2Q9YWR3UAfrsZ EuJKB8U1XcRDSZrEwWDY09gAzAF35+oAAJUJ9n0OxLqxDoC2lXAszMVHFn6EfZTQ5qLhaX2D00kk 5nmB04ckSflJyIB3INCSP+H2AcTHzgHgBMsAP5aWscc/lhKMe16ePLbH2BqIQAnbWA4iQNvTARsr CLbTzrEiJ6zAACVuDpYHeOd2RlW2zecglHBGwmA9B9OYS10OBAAZB1xNOhMAx8fYOsdJaQG7KgdM gdyHOpU5XMMIPcXdXd0HLxs4CLBv87r/CMa2SjC+3ZVK6pGVMQRYAeauB6bYcK6WaRQATzobBAA0 vfa1lTq/OfaVIMyDlimelvxpUT0nxtMjfx6HzapJ2AEw03AH2D9wBM4OPO7HQqqVBdz0CIE+fuMO 4yDEwl4AYj85NJU7KaEWGwg/BErHfVZ5rxovmQ7EenBdtAZJJIXpxAcA6sQBWE8gGt2etgVSKQAe lX3yAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQEAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADZSBKB2QAAAAAAAAAAAAAAAAAAAAA0 AH202C5eA17z2M9e8A5rBCMEzw4qAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAA4iVtDNvc3XBDNW2wWNaX9pkwWXAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGp0anRcCFwIXAhwlHB7cO+K9YqU AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAUA s8Q8Bxtl0k5KDrRA5ZbCaYeWxJlsQNM8AgChcA5TzWp+b1YBmpoA01kIQCSWSmlJlfu2UbY6Eup7 NsJUq5LOADQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABxk/LwFxPEOeEQBYCACAaQAAAAoA AAAKAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAABAAIABwAAAAQwMTAwAAAAAAAAAAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAA IAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgAAAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAg ACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAAAFByaW50SU0AMDMwMAAAAAIAAgEA AAABAQEAAAD/4QvFaHR0cDovL25zLmFkb2JlLmNvbS94YXAvMS4wLwA8P3hwYWNrZXQgYmVnaW49 J++7vycgaWQ9J1c1TTBNcENlaGlIenJlU3pOVGN6a2M5ZCc/Pg0KPHg6eG1wbWV0YSB4bWxuczp4 PSJhZG9iZTpuczptZXRhLyI+PHJkZjpSREYgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8x OTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj48cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0idXVp ZDpmYWY1YmRkNS1iYTNkLTExZGEtYWQzMS1kMzNkNzUxODJmMWIiIHhtbG5zOnhtcD0iaHR0cDov L25zLmFkb2JlLmNvbS94YXAvMS4wLyI+PHhtcDpDcmVhdGVEYXRlPjIwMTgtMDMtMDhUMTc6MTU6 NTY8L3htcDpDcmVhdGVEYXRlPjwvcmRmOkRlc2NyaXB0aW9uPjxyZGY6RGVzY3JpcHRpb24gcmRm OmFib3V0PSJ1dWlkOmZhZjViZGQ1LWJhM2QtMTFkYS1hZDMxLWQzM2Q3NTE4MmYxYiIgeG1sbnM6 ZGM9Imh0dHA6Ly9wdXJsLm9yZy9kYy9lbGVtZW50cy8xLjEvIi8+PHJkZjpEZXNjcmlwdGlvbiBy ZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxu czpkYz0iaHR0cDovL3B1cmwub3JnL2RjL2VsZW1lbnRzLzEuMS8iPjxkYzp0aXRsZT48cmRmOkFs dCB4bWxuczpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMi PjxyZGY6bGkgeG1sOmxhbmc9IngtZGVmYXVsdCI+DQoJCQkJCTwvcmRmOmxpPjwvcmRmOkFsdD4N CgkJCTwvZGM6dGl0bGU+PGRjOmRlc2NyaXB0aW9uPjxyZGY6QWx0IHhtbG5zOnJkZj0iaHR0cDov L3d3dy53My5vcmcvMTk5OS8wMi8yMi1yZGYtc3ludGF4LW5zIyI+PHJkZjpsaSB4bWw6bGFuZz0i eC1kZWZhdWx0Ij4NCgkJCQkJPC9yZGY6bGk+PC9yZGY6QWx0Pg0KCQkJPC9kYzpkZXNjcmlwdGlv bj48L3JkZjpEZXNjcmlwdGlvbj48L3JkZjpSREY+PC94OnhtcG1ldGE+DQogICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg IAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgIDw/eHBhY2tldCBlbmQ9J3cn Pz7/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRofHh0aHBwgJC4nICIsIxwcKDcpLDAx NDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwhMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAARCAFQAbYDASIAAhEBAxEB/8QAHwAAAQUBAQEB AQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1Fh ByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZ WmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXG x8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAEC AwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHB CSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX 2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDkbfSLOJxthUnHU81djijVkVVA+gp1 v80hpYh+/X61x3OmwmAJSB60+YYDZ/u/0oI/0hv96nXQ+/8A7v8ASpuNbnDRDN/CPWQfzrvo1/fS H6Vw1up/tK3HpIP5130S/O/1q3sVU+ICvCCnhflbjtT9v3OO1Ox8rfSlczGKvyLxTtv74/Snqvyr 9KXGJWJ9KL6ADL+5enxj92PdRUbXtkmYpXbceu0VImo2CRjAkfsBtqrNiJpF/wBJX6U4j5jx2rN1 DUrsxRvBCYzuyA0RbevToOahGtzwgLe2RilY4QFwA3+H40NBua0Q4fj+KnOP3JrF/wCEg8lnV7J2 IbkROrEfhViPxBYTxYfzrdvSeIr+vT9aVmBqKvyL9K43xEP+J6fdB/Kuyt7i3uEHkzRycc7WBrkP EoK62T/sD+VTLY2ofEa/g/8A5Btx/v8A/stb0K/6PH/u1g+DcnTbj/f/APZa6K3H+jxf7tXfRGc/ iZMi/uW/3aIl/dJ/u1Ig/dn6UQj9yn+7QyBUHP4U23H7iP6CpUHP4U23/wCPeP6CgBQOBk0kA+Vv 98/zNSAcD6023GQ3++f50ASMOD9KYg/0rj/nmP51Mw656VGn/H2PTZTAmA4/Gorof6O3rU+OPxqO 5X/RHNHQCUdqa4+T8akRRtGBTZBiM/WgRFF/x+yf7q1Zx/OoIx/pje8Y/nVrH86AZWx+9b6UWn/H sv409hiRj/smktP9Rj3P86YEhHFc74jXOlXYB6bT+orpcdK57xAubC9H+xn9RSexdP40cWmBrso/ vkAf8CQY/nXo33tOz9DXm7ZXWQe6rCf/ABxa9JVR/ZxAzwgP6VNJ7nRi90JqOm/2pp0cPm+Xghs4 zmpJLf7Pp8cSMf3QAB9atwc26fSknQNCynuK0OQpwv5ik8ZIq1Zc261QhbE23GN3b0PcVoWP+o/E 0AT44qGbiWM+4qxjioZxyn1oENP/AB/N7rVkCoHGL1fdasCmBG6/IwqrH/qZFq633TVOIcSCkCJI P9StTr/SobfmIfWpwKYyKfoR7VEvNqfrU8y5wc9BUMX/AB7OPemIli+4KKSLlaKQHltouWY+1OgX MwNSWi8OcdqWBf32a5jYbt/ffiaLv7kjein+VSqv76mXgxbzH/Yb+VIa3OKs+dUts95F/nXfQrln J9a4OwGdXtx/00FegQL8rfWtOhVX4hxX7lO2/KfpTiPmX2FOx8rfSp6mY1V+UUpjDsynuKkVcqPp TlX9430o6CKEulRMpcswIqeK1S2lsZXj82F5QHBPVVxu6fUVYuMi2cjrWRc6qUjjgi3MyfMscQOc 8dTnpx3qXFbFJnS6VZ22palJM14LgBuDHJwv0Hak1qy0mGSXMtq7KpB8wjd9M1zdhHeXUhjkvZLQ GQqYoPv+/wA3T8qr6Vptr9tuEv0MklrK0bh8sX5+U4zjnitFBIV2Wrea2inSMTbomOEYP8y+x/of 8K1pLaUw5inJGOVYAg10Vro1taaUZVtoIVbqqoBmuWu1lMVzBpksMEjEMdwJ/Af3R9BUqzB6Fc6X F5iyrCsU2M/JwG/DpWBqNrd3eqNGq5kVMlZGxnA5wT/KurttQEoFrewm3uNvCseH91PesLX5rSG7 khut8rFMoM42nBxj3/nQ20rMqF73RT8OaylmBDvXbI5DqRz2Gc+1d3bD/RYv90V5Np9l9uuWiTJk EcjqoOMkFTj8RkD616Z4fuo7jTUjViWgJjYE8j0P0IxitGTLVs10H7tvpSQj9zHn+6KkQfIR7UkA /cR/7opECqPmFNhH7hPpUgHSmwD9ylDAVhhM+9Lbjh/9805h8uKW3H+s/wB6gB5HzVGi/wClr/uG rBHzVHj/AEpP90/0pgS7eD9ainGbWT6GrAHB+tRS8wS/SmIkj+4v0okHyNToeYk+gokHytQBXjH+ mAf9M/61ZI4qvGP9LT/rmf51ax1pDISD5n1FMtB+7Yejn+dTEfvBTLUcSD/bNMCXHSsPXFzaXo/6 Yk/yreNZOqRNLDdIoyWhYD64o6Di/eR51cnGqzHphI//AEAV6VED9hP/AFzrzK6IfVrtkPybsD6D IH8q9Msj5umRuP44Q35iopPVnVi1pEvWvNqn0qRx8hplnzaJ9KnZcrgVqcZnKn708dqsWP8AqiPR jSrH+9b/AHaLEYEi+jU2JFrHFQT9FPvVntUFyPkH1pAMkH+lxn1FWMVDKP30BqegY0jg1ViHzuKu VTjH+kP9KAHW33D9asAdqgtujD3qyBTQMY4yoFVoB+6cehq04LBcVWg6yj6UCJIvu/jRSQ9DmigD zq1X92/HY0QL+9qS2H7qT6UQD5ia5bm4wD97+FQ3wxZTn0jb+VWlGZPwqHURt0+5/wCuZpdBx3OK 0pd2t24/2xXoca8MMd/6VwWirnXrYH+//Q16DGv3/wDerR7FVfiAj5x9Kdj5GpzDkfSlx8pzUmQK vC0ya4htQ8kzhVA71XvdTjtCsSAy3DfdjXkmo7TTpLmb7VqOGk6rEPup/iaa21AgeS+1VcQq1vak 8N/G/wBB2p6fYbO5WwiUeYHxIwYDDY6571dv5vIiLZ2rGMj69q4/S725vby+AYR28QaeQKfnZtuB j2/+vQlzPyE3ZHSyzPFqXnS3CeXHIzgqpG5cc9M9hmtrwl4ZN74huL8TeZauFIz/AHgMMT9MY/Ou W8ORSancQxIwMsgcnjhVIz0z0GT+Veu6X5GkaFi3TbEq43D+X1rSSv7qEn1ZleMdQjt4jHFhI41w PevOPD9yuoXWoLKcnIaMjqPX+da3iWaTWmnjiY+XENz4bBPfA/KubsyNC1W4W1V5x5QyHPIyRnmt I0W7QW7IlUUVzPZHXTQK9sIrtBLCcYfup7HPY+9cvqFhC2rGO6llkgjC5mHUA9A3+NaNve3V67G4 lxtX5EQ7VH+PfrUrWouIHQyvGHOGMZGT26kGuutlVajS9pNo5sPmdOrV5KdyxqWgW+naVaanp8iq Ih+8KJklDjJz6jr+dZOkyNpniFmZyY7mQrIf4RnlcfrTF+0adC1o91Nc2QDKV81lx25A7dK7SzTR LrwrDDeEw27RLiT7zRP90njk4KLz3DCuBxcdDt5r6suJ90/SmwD9xH/uisix1i6uViEdkXyDvCtz 6cfkasXt7PYtp8JhePzZFWQyLgBcHJz+FS97BY0wOPz/AJU2EfuV+tPXDJlTkYohH7ofU/1piHED 9aSDrLx/F/QU5h8tJB1l/wB7+goAl70ixk3EeBkAHJPbpVG+1AQrthZd54LHotWoriW00yK5juXu YXLJIfK2sH4xgnggc9R3Fd8MvrSpKpbfY4J5hQhVdNvbc6CLSVksZWWQNcMpMW05XPb61zcN0ZYZ BPG0e47d2OPety11C50q5hsr+NA0mChQ529c598/1pmsTafPDcW0M0LvG5barAkbuo+oOa46tKpR tzdTqo1qda/L0IBCI5zbJIHaNA2c4yMdRTGwVODkH0qtq9zs0rSdQhQmSRfLkZR0ZT+nerds8d9A xTAuFGWQdGHqP60QXNG5cnZlVf8Aj5j/AN0irWOagIxcw8Y4NR3Gr6fakia8iDDqobc35DmpGWWH 7xaZa53S/wC/WNdeJ7RGXyIpZmOCP4Qf6/pWfq+sa5pbgSWiWnnjeu8bjj2J4/Si6HY7Ajis+7+V yx6bSfyrltA8RXb6vHHfXTSJP8gD4ADdsAfl+NdVfZLMFIDeWf5Gn0FbU8tMey7mUnkdfzNeieHG MmiwZySI2H4ZrzvH785JLMuc/jXoXhdv+JJbH2dT+ZxWNL4md2LXuo27D/j0WrOOKraf/wAe+PRi KtgcVucBCB/pIHqKitBiSX61Pj/SU96jg4nlHvTAsVDOMx/jU/eoph+6NAiOUf6g+9T1Xk/1EZ9G qxQMTGe9Vl4uWFW6qMMXY96AFt/9ZIPerNVoP9e4q3QgYxun41Vh4uJB7Vbbp+NVU4u29xTELEMF hxRQnEjUUAcHAuIHohX5iakiX/R3pIR96uQ6CNB+86dqg1T/AJBlz/uGrka/OfYVU1bA0q4P+xR0 HH4jkNCGfENqP9o/yNehRjl8/wB6uC8PjPiO3HoWP/jpr0GIcN9TVvYdX4hrZ3fhVHUL2SLFvbLv uJOAP7vvT9X1BdOtGmI3P91V9SelFjpd9aWpu7uP/SJD+8Zhwuedo/ShaamXkTaZoptozcMplmbm SUj9B7VbjZS7bWB7cGrHhuJLnUpYZS2xY9wGepyK6preKMbI0AB9BTaA861WKVw8awvJuIG1R2JA P6ZrmINC1fSNVW5W2d4c7JDGQ2Yz1OM5z3r1u8s0F2BsBE0TKOOjY4NcnIWEKyNJiNWPydzjHX8a IXjp3FJKSNHwfpqaOJVVgzyuQh/uITnGf88Yq1438TR28EdhaMNsYO7H8TVzp1s28ckwbDYOKwZb e5vojeTk5kOQpHQdv5V1Qioq73MZO+iHQ6zbwwyqIn8yX7znqTjitLwLdm61HVIpIFnluIPlyM/d zxj8f0rl5glsdhQKxrofA2t/2TG0axfPPIB5gbbxgDBxzjNbQhOo/c3RlKUYr3uo+3TZKBtKnJVh jpV9XRAQxC7gcZ/z9aqS3bXV9LM67GkkLEE9M1HqEXmu8ZOQeQPbr/Wvq8Rh3iMOodT5jDYiOGxD l0J5bq1mjcI8UrkHERPJJ9qii0y/it5UsCZ4DAZZ4sgbAMEkD2IHHXisPULZp5fPOVkiiCjacZ2j AP14pkl7Jo1/b6np886200ODtYlmbbtYHPYnP518piMNUw9RQa1Z9hgnDF0pVIPRGxaa4+j2S6nB IkhklKFFbkAD5SR26muit/H6T28Y1zRJTASGWdckKD+lcRpOr2eq2JsbqO3tXgyyXJT76c/I4HBw ehrsLSaGRI7W6jW2uNvyH+CQeoPSsKynSlaS1FHlktGdY0en32n/ANo6LcB49uXj6EfUf1FV7RhJ AG9zkenWuJZ7jwzrMV9akraM224hH3cHg/ga7BZoB5d5bPm2nAJB6r25+h4NZ8qkuaIXadmWzgc+ 9Yd5qm1pIbcg5blvTgUmp6r5rNb2x+UH5pB/IVmIgUdK+gyvKea1autOiPm83zn2d6NB69WSglsb jxXcw3Gn6h4XbR9MZluioco4x5jdSAa4YVMgZRvVsY98GvdxGHVRKztbY+Zw2MlSlJtX5tH3N06f PpyJ9tR3urg7VVzu8tDwWPv6V5BPpmpQXci4ljic9EyAwr1DxRr8tloQv7eTzGt7SOMqOSCzYbP4 Z/MVxsepW07iS3nJhkXgqfu/X0r5TNakk4prU+yypRUHKLumdLZ66tpoC6VND5kCOHSbdl14I5He r9ndeV5M1vNkNyjgYIrz27neG6ENvuuGPZBvGfYiuigvGstHiEreXOpLYHO3OMD6/wCNeNCck1Y9 6jD2kZOS2N3x3fTQeGLi5hYQzCMCT6MQPl+ufwrznSdVimsonmuI42A2tubHIrtLp49fs3tb0ebH MmAwOCMYIHH0rj7XwqbC7kEsUdxARmNs8j6j/PSu+dCam4Na76HPGpB01UT02IzrsUl00cc/7pV3 BhkEEYrTvtQ1TxPpEt/LevMLc7VVuMAdcDtTJ9EW+VFCJEqsOMYBGeeBV6zjsdDjlits5lbcyFsg /X2rrw2V1a0eb4V5nBic1o0ZcnxS7IzvBws473+07qKS4uEJEEWeA3djn9K9Gt7kX0C3O0x79wKH qD0xXn7SpaXDRhBbyFiWCptwav22rzRMNr5+nX8q1llba+LUI5gr/DoZLj9+n+6f5iu78KHdoKD+ 7I2Pz/8Ar1yL2sU0gkhlwQDlG9663weM6YYj2nYH8ADXjyw1ShO00ezPE0q9NODOg07mJx6Maudq p6f/AMtl9HNXexoOdkR4uI/rUcY/0ySnycSRn3po4v39xQBYqOYfumqXvTJB+7b6UxFd/wDj1X2a rHYVWx/obezVZXlB9KAFqpIP9KWrmOaqzcXCH3oASPi5Oe4q2KrdLurNCBjX4U1UB/0pSO61bbkV VZcXSY9KoAPErUUsq7ZT70UgOIQf6M1EI+VjTkH+inFEI+Rq4zoEQfO30qlrXGkz/QfzrRjXLscd BWdr3Gkz/h/OjoVD4kcv4bGfEsQ9N38jXoMeArn3Nef+FhnxKn+638q9BQfu2+pq3sOr8ZyWty79 X01ZTthM5JY9Mj7ua9Kuke50R5I0Zwyow285IBBxXD3UCygq6B1DchlzitX/AISG6sdOg8iPzEA2 sPQ56fr+tY1ZVfZr2SuzNJc3vDtGvG07UlmZGbJ2lRweeK7uFvtESyhGj3DJVhgivNrPU5JNQjl2 bSrgtz2zXod7qcFnEztnkZCqOTXTFNpXWpD0GaqvlR284/5ZyDP4155rIeKW8jiOXhkfMeOSpORj 16/pW3qPjBLpfslvbSgnkmQY79q5jxbc7tSkuYg8ciquD2dcfMM+vT8q1jC25Dl2OYhubuedFljY xq2fmXAbmu8aNShwMr1Uevp/I1yyBrmxa4aIRk4I57AnJ/T9K6m0fdZxbhyFAP4fL/jWrT3MU/es czrtvAYGkaNiVz+A5/rVXT+LRTwArsBg8jGK6bV7dWsLhiu75CSPw5/nXNwMqW0Ssu1mZmUj+IZO f5V2YCfLXVznx0b0HY3rza0y3S5KzjeTjgt3/wA/UdqlucERyA9VH+FU7e9iWwktZywhB3xMVyVb uD7H+lTus0+jxz243IJMLIynaVyM4/KvpqVVQXJLdfij5ytRc5+0hs9/JlOWMO/cEelV9Ms0lM2m 3OGOTJbqckZPYfX+lX+pxnn+dVZbW4mmQ2qMbiM7k21yZph/bUrrdanp5HjPq+IUZfDLRnFa1Zza RduI1KxSce4x1FdD4U8Ty6g6aRfpHNbs4CPMxBh+jDJ/z6Vt3It76NbySzSV0XDxPz84HNczBaww XLXdrCyyMWaSMDhR/s/gelfNSnKrTu9WtD6mrhY08Ra9ovU7LULm30+5ksbiQ3tu6FUZlKsM++MP j2qPTZ71dLWykfESscEdSKhtftNzbIlwSIQdyxn17E1oooUV72VZU4L21da9v8z43O83Sk6GHd7d f8gRQowBUgoXOemfagV9CfJS7jhTgOM44pop4zyATg9R61LMxyOUbcvUVx+veGIJtWhngQWtu8Xm XBj+VThiOAO+B24rrse1Z2sMXkhth2QFvpkkfz/SvKzWmp00ktW9z6Lhyo44iXM/dSbt3fQp6LZu 8cdsJ5I4e4ByQvOBk+lJa2gvJ3A+eJCxRieozwatEGGDy4MtLL+7VR6njOfx/SrlnZ/Y1ETEZJA4 9BXgUVTq4hTjG0Uz6zGqtRo+ylK8mr2M+WJ9NKmziklmk4Pzj5Bjr2AqGDUJ/tIgu02l+E3DAz6Z q1f3MpvJILdDuQ7S56ZHB/lVV9MZlDzOXckHOelfQUsHTpyc0+aT/LsfPV8fUqRVOS5YLp3fctSB +QGx7Cs6Swjjn8xjIVI5CnODWugJTa2Cw/X3qO6ZYIGk8tmYcBV6mnXnJRcWThIx51OJka/NfNd+ ZIqsuwJvRMZAqlDa3dxtkUFQOAT1NaUl3c3DgNabgBymcEVDo1yvmyyoJI4lGAXHG4EYx+tePVxd TC0IXjqe9Sw9LE4iUYPQmaXaUjdPnztPsRXa+DEZbN3YcNMSv04H9P0rhhPFc3fmSSkgOzMQOT16 V2/g+4Nx9qbooddqj+EY6V408TUrz956HqKhSp0vcR0NiMXFwP8Abq9jiqNnxczj1OavZ5pGJBNw UP8AtUj4+35HdadP90fWmyf8fUZ9QaALHemvyjfSnU1uhpgVhzayVPFzEn0qBP8AUyipoP8AVL9K QEpqpdDEiGrZ6VVux900wEP/AB8qasd8elVn/wBahqzjmhAxO1VpeJ4z9KtdqrXAw0Z96Yh8/wDr PqKKJx8yn2ooGcUFxa4PXNJGMI1PP/HuKIx+6Y+9cZ0CRnDP9KzfEHGkzD1K/wA61IlPzVleI/8A kEuOxdaOhVP40c14RGfEn/AGr0OMfuz35P8AOuB8Hp/xULt6RN/MV6BF9z8T/Or6Dq/GY9wDmRhw QaqRzSwiTYQA/GNoJ9iK2LyLczDuy4rlr6W+t1KQ2ku7uyjdn6Yp0t+Uxl3LD3Vva3WWcbWGMjqM /wD16deaot/IWFyWUYVQW6AcCuMuppxIfPV1bOcMCKhEpIz90fXrXfCKijmk2zubOCO5aR5zvjiQ ucHBJ7AH6mn2Sf6GZHd3UE7AzZB5wP6VyFvcTxrxLsU8kZ6+laVnqFw22LcXUEY5obQam3JGptJE X5sofx44/kP++qu296kyPIiBA7Eqozgbjkf+hfpVO3mXGXU46dP8/wCQKqac5a1246YJx9Mf0NN6 oz2kjdnVpUI5KsOVPvj/ABFcfbqxjWN1OYTgHPOeQf1zVvW9au9KtFkgQN8+0lui5yf55/IVlBNX +xyagqDzHfzVVeuOvT/PU1MZqlJSZuqE68XGKudLbWc7qCq7TjILCrV1JdWRAhnMLSAcQsVDY9V6 H+VUtJ1i5uNKhupigbLKyeuD+lXYIZtU1SNoItzng7jwo7k+1deIxk675mcWHwcMOuVEukXGoX93 shW2Eqj5pTAuAPU4wP0rWudQW3V4LUJKcYkmlGN3rjGMCk3QxLJp9gGwuPMkRclzWJrmmx6cqfa7 id5ZFzHCp5Y/5PeuVznN8qZ1rlguZjbdrDfNcCRoFIJdSCyv2G3jOT6H86hislnujcMjKgP7tG6g ds470lpZMzLPchfMAwqKPlQegrTAA4r6PLcpjR/e1fi7dj5rOeIKleP1em/dXUFXAp+KKWvcPk2w xkYpwGKSlFIljqUdKQU8A4zg4HepZIrMztljk1Uvo4jqDOc7gqqefRQKmmuobZMynH0PJqkdVsJX lky4ldiRuXhea8fNqVarTUaXzPq+GKtChUnVr9tPUntIw2rbs5jgjMnI/iPA/wDZq0BD5s64PORg 1Rsf3dk9w5w1zKSP91eB/In8a0lKxQyTkf6tS4JHcDNeZLDypU4U4r1PbeLWIrzqyeuy+RjTOrXE sgGAzFv1qN7hFTluagiS5vVdraMvsZVbHUbs449OK6PTfBYYrNqkhY9fJQ/zNerWzChh42TuzwqO W4jES5p6I5yN576dUtYmdg33uw+pro00dopo0u9rFl3bUJxn0rqUtoba3WGCJI414CqMAVTvlxc2 r+mQa+fxWZ1qrutEfQ4bLaNGNnqcU1lJazXEbci2n8kN3KkBlP5EitBPCNvNaWs7y3EchAYruBBH 07VoeIYxbpLeBQbeeKNZG/uMjYDH2xwfwrWhIfSbRgwI8pP5ClXl7WhFvo2XRj7KvJR6pHmmr2iW uqPGpJ2ykZP0NdT4I4a7Qf7B/nWD4mTbrM/tIP1A/wAa3PBRxdXK+qKf5/415VPSdj3Ky/cJnXwj F9MPYVZ71XTjUn91q0RzXQzziGX/AFf402T/AF0BqSQfu6ZL1gPvSAnpPWnYoxzTArRjMcg9jT7f /UrSQ/ece1La/wCq/E0ATdqr3Q+QVZ7VBdcxj60AQP8A8s2q1Vdx+4j9QKs0IGIaq3XCx/Wrhqvc AGAH0NUIJeVQj0ooPNvGaKAOPIH2dR70Jjyz9aU/6laB/qz9a4joBBkHFZHibjSR7yLWwg4b6Vhe KZ4vsKweYnm7w2wtzjmjoaU7c6MfwcM65Kf+mTfzFd5F/qh71w/g1HTWJi6MMxHqMdxXcxY8sA9h nNX0FV+Mc8SO2GHaoHsUK713ZHQVZRg7FlIIxjrUmPkNKyuZ3OQ8SWiJbNeGJWkQBCHGRj6Vzy6R ZTavYWjB9lzEZC6ttOcE4HbHBrtvENqbjT7mJRyyZX6jkVwFveCMafddXtJdrr6rnOPyJrak24ON yJpXTL974UKXH+hCRogMne4P5UQQzaYVaQ7MEcqNw/xr0J4oJ7FZotu3buVh3Brlbm4W3u73KW3k Sx7Wec4VGGDngE5JGOPWnTnK/KyZxVroojURO2F8onuFO39KZCzwW0LcjzUJBPcB3H9KxnmZ9pVA M8j5Qf5ir0NyfsNgrgyKkO0AnHG9if511XOeS1RpPtvLQ28wDCcbBnjBrOS5utKPl3abowdu8Dp9 fSmqZDI0WZAoOQGNaMXnX8SQMqtIeAxPLL7/AErKpGM1aR24XFVMPK8CS1uLO4kVgFLE8Kw4NdNc Xlxp+mqjJHB9qBw4J3YHBHtWnoGi2NtJFIDZzTLArIUHzRt0bP5D9az/AIjKJLGxhiJN2ZDsUHHy 4+Yk+gO2uGDquuqFPW521cZhn+9qwsupgLrn9mv/AKGd91Iu1VVck89ST/nikhhmluGvL2Uz3T9W PRR6D0FRabpi2ibmJkmI+aQ1pBK+7yzKlhl7SrrP8j4HO88WLl7LDrlgvvYgFPFG2jBr2T5hjqdT aWpJY6nDnimCo7i7htlyW5xwvekwUXJ2RYyqnL9KzrzVhEm2D5iT17cVnXWoTXTYJ2oew71FMBtg HT5Cf1rGVRI9LD4HTmmMkmeZyzsST3qIqzsqpyzMFH1NBzngVuaDpfnXUF48sRjiJcoHDHOOMjtz XPPEQg0m9WepDDScHJLRHQJD5McMI+7FGFye1Z+oK+pBLC2vYbffKFYs2DN3ZR+QHHoazfEiXdzp klxBJcfaIZNymN2BC9+BwfyrjtMXWtT1KK5to7i6mjYYmkPyrj1Y8V4mIzCNWLhA9PCZa6UlObPa oNKtLCzxBEuVIIcgbuvrWz2Fc1Z+ILS5kk0x5kF6kasUDZBPcA+o/lXSDoK8KV76ntrbQR/u1SvS FNuxOADnJq6/3TWHq+p26IIQ2+RQcqO2elOFKdV8sFdkzqwprmm7IqavqLTW1zaW8KmGMjdJu67j ngfhVfStRtdJZEktleCWJd0cZK+WeuQMkZPfpWTNvuJd+FGRg88YGTzVfkde/SvpqGWwnh1Sq6Pr Y+bxOZyjWdSlt5kmuJFeLLqJbyjJKAkROTgcc/l+tX/BbY1OZc9Ys/qK5zUyDgYxgAj863vBj41l x6wH+a18xXhGniHCPQ+voznUwUZy6o7r/mJfVat45rCvdct7PVNro7bAA23Hfn+tTR+JdOfq0if7 yf4ZrN1YXtcx9nK17GpIP3RqKX/VQn3FV/7YsJYyFuU6fxZH86DdwSWy7Jo2w3ZwapSi9mLlaNLt Sd6AfloPWqJKycXDAd6W1+4f96kH/HyaLbgyD0agC12qC4/1NTZqKb/UtTEQtzapU4/1YPtUHW0F Tx8xL9KBjs5qGcfuG+tS1HOP3DfhTENAzbJRS2/zW49jRQBxzHES0oH7nPvSSf6taeP9Qv1riOkI /utgdq8+8UxuniWXzN5E8KmPHQY4P64r0KP/AFb/AErB8Qm2gn029uYPNEM+SucZXHIrSDSepLi3 ojmNBuLmV5IJWO2HARyeR7fStq9a4urR7WSSVkK8kNjA9TXdT2On3MBuvsuzTUQSjaAEkZv7uPvN 9ST16dK5CKC4OoXiyII44xtUA9M4OPwHFJ2ctBa21H6BaRaRGILeV5ASodm/ibqT/wCPD8q6lW/d kn1rk7RvJuZYiVO1wcgY7LWj/wAJVoqRsj38QYHkcmteSUtkTzJbmpfJviLDnArzDXbM6TrIcp/o tydw44B7iu4/4TDQs4N+pU9fkY/0rnvEOr6Pqunz2lrOJZVHmRnaVwR6EgUlTqQfNbQHKMla5INY nsNINiWk8luYZFXcQvUjqKqwwzXyRl7ghTgkKPf/ABxWXpF4t7YPYzAeYvMbHquK1NOkZHKEFQmQ 3tW0bJ3Id7WNDVrKKZG1S2jLbjtukUf6uT+9t7K3Xjocj68/DaxtKx8qUJE2TnoOeRXRwX8sF01x b7TxtdT8yOD1BHocVteHdD0vXLu6SOeVI5E/eWxP7yM/7LHhl9O/qK1b6kJXOS0WZGuJFuUZ9xyp 9K2rXw6txqNvJFLOqFiMKcEAjBxxXbaFonhqyt7mG6lCeUpAbfhnbvz+I4qGwtks47i6TayoP3fP 8RqdwtYzbCNtB1WK2uFbzLhmS3dfuONpOD6HIH1zUOuTm6uIXlRlkVSrKeg59Ocf/qpvi3xPYK9k ZATLaSRy/Kedykenaqcl7NMHVyjqTkMOp989K78lwsnjFWS2/U8vOq8FhnTbtf8AQjzgYHSlBpva nDn6k9AK+2PhiTNOqIGn84zjipZI/qaaWRFJY7cc5NVbvUYbQ8NufsBWDdX81y3zN8o/hHSs5TUT po4WdTXZGpeaxgeXAcgfxH+lZLSu7HexLHuag8wFsA5qWOKS5lEcalmNYSrqKvI9WlhEtIIXzABy cEUy+vREyExvxGNoxjOe/wBK1dG07zdbjt5VWTbcxxexztz/AD/Suj+I+mw32qQG3ZPPSMxyJgjG On9fyrzMZivZpcnU9PCYdVG1PocXDNcMz+Vb+YFwTgjIB5FaekTiz8O6jq0mEN0/lRE91Xj/ANC3 VjXtw9lplvPa5E2Tbyjrn+6fXv8AoK7CfRrBrLTtEv3It7eJd5U4y+OTx2yWrzKEefmrauSTPUxO LlCMMM7KDa/pnKQX7JKj20kispBAVyQT9O9Gt6lq8yJGsk0ULr/q0XYK6K5e00mOSy0CzxGW+aTk k4Azj1PvWVDp9zPcwmZzGsw3ENncOSO/0rjw2HlKMpt/I7MZj4TtGMfmcdIt1YtHNiSJw2VfkHPs a9P8H/EJtSkh03UYXa6Y7UmiXIf/AHh2+vSuHuZJre7lsruMHacMD91h6ivRfAGj6Ra6aby0UvdM SJHkwWQeg9qxnZxuZU5vm5Wdddwm4tmjEjJn+IViS+Hod0RMgYscElK32+6ahm6QH0esdU7o2sno znYdLtzNdwGJSywvtOMYIGQf0/WorDQ/tNrHdSuPLYcBepqXXwUTUT2EJfHrjB/pVzw2wfwrbMOn z4+m9sV3UMTVhh21LW5x1cLSnWV46WOP8WW8drcxpGu1PIB/U1J4UlCa4v8AtRMP5H+lS+OFPnQM O8JH6ms/w9II9Zt2/wBh8/8AfJNeY23Vuz3kksKkjQ1GZ59Umfja7sfoB0rTttLjkt43R3O5Qcms hEFxcKuSCW5IrqfDrhoZLWUASQnofSsMPGMpNzW5lXlKMUovYz5NJcc7+ntVZ7IQxGXgr3A612r2 6NE3HauavMyM1pbj7vzSOeij/P8AnrW86FK2i1MIVql9WU43lAIgeUFeuwninxapqIbCXErYHQnd W1Zaeot0wMLjj396qTWq2WpozHEM/BPYNUPC8tveZaxHNf3Ssmt6hG+5iGb/AGkFWYfEE8bMzQxt uOTjIqa4sylyAOhFRR6aHnmLqMDnntWn1ea2mR7WD3iWl8UJjMlq4/3WzUw1+zniPyyKSO61z5tx cXLC3H7teC3b8KtNppWIsN3AqYxrvazG3R6mxHqtmbYoZgp7ZBq5bXls8KhZ4ycdNwrjGbAXPHOC ewrp7nyoRaQrBBlbaItmBGJYqCeSCe9aUfaTb5laxNSMIrRmopUjgg02XmFx7VRgs4ZeXhjB/wBl dv8ALFaUemQuMBigP915P6tiuj2UjDmiQWeDERzwaK0oNBVM7LqUg9twH9DRT9nIXMjz6UcKvtS5 2wr7GhhnGe1K4/drzXAdQqEeVIa5fxi2bKAY/jP8q6aMfu3965nxjhLa3Hqx/lSZpR+NGf4O1C9f zrZpi8EK5jjlyyoTnkDIrp1iZLYktvd23O2OpNcv4JjJlvW/2V/rXbiL/RwMdq0sr3IqaSaOQ1HV Lawup4p3Cuy5HftVXQbDS7/T4pbiwVmEWXkMjZJ3EevoprG8Q28c3iXUQ2/dwqBV3c7V/Kr+jT6r a2UVtDpzyKVIchtu4HdwePVs/hXVC9rRepzyg7czRcl0rTYL63RLVHWGKYuDnEjIAOefXNReJNHt 7Se3js7WNC7sq7CckbcnPv6Vo25kVt95ZwK5aTJNwchXJJGMfTn2pL68tJ5o5ppRvjffhOhOwKf5 frWrjUloZc0I6nCy77K5SZBjB5PrW017HcQiRGKyNgjB+96j/PvWfrEcJm3WoJjbjaO30qnClxAj JLFKsZPysVIwaycXF2ZakpLQ7HR7tSBaeUSzfdCryfY/4133hzwrq9jqIuzbMLaWF1Zs4K8cHB/p XlkOoXmikXMd0FbACyFMsD3wP8a1pfGD6raQR3Os3kbBNpX7Q6g/UZwP0reFGdTTYynWhDXc6291 /TX1N7XUrxQ0jbQ4Odp/2vb361U8Z6hcaT4bsrOEiKa4kaRzE+RtHTn3yPyrizokF0YkgY7nYAOG znPH0ru9d1K0XUv7FulCWaRIkc6JmS3fH3h/eXGMr7cc9dXgqsGkZRxdKaucZpOnXet6VPtSMKgO 9ihZz6Edu/6Vr6O4bS7dfMEhjURsw9V4rMv9T8SaDc3NiNQNvbsgIlhxidG+6ytjJBpfDcnlvd2j Fz8wmUvnLBuv6j9a9TJ3KFbXZnl5zFToXW61Ohpw600dD7VQvtWhtV2rh5B2B/nX0spKK1Pk4U5V HaKNGSVIEJmYKo9e1Yl7rbMClvlV/vd6ybm8nu23yPn0FVix65rkniOx6tDL0tZ6ssNOC2WJOfWl XzZnWKNGZm4UAZJrQ0vw1faowfYYICM+bIDg/T1ru9H0mLSEdYIYZZAcGRpfnIwOny14+KzOnS0W rPcw+XSn5I4O40W6sLeKe6Xy45MgsGz5Z7bvbNZlnf6jd/utNTywDhpWr03WwHtHMltKqNw6sAyn 8ia8zn1S30GSWCNXmwx2DOMA88/nXhrGVa03zs9b6rClC8UdX4Khd7m28+QySG5Z3fPLYJOf0ruv HiaS3h65unubePUQwdTvAcnIBGM56E15LeTXFp4RhkhkaKaQL8yttPPJ5/OuPAup96bpZDjcQvIx 616OPkk4R7JHm5fG6nPvJnWeGTHqXiWC3wzRh/PkJPGE+YfrgfjXR3FvPqmrXV5LIY7NZPJRc8yl ev4A5rJ8BaZJZG4vG+WS4jCJkdE4JP8AL8q6O5f7W7R27FBCAqH+En0H+PvUtOjhfaXsm9X+AqsX UxFrXstDS8Nm2UXCNj7RsITPZe4Hv61Bcxlry1kHpt/U1hXGqtDcQskEpuXbY23pu7EnsfWt/QLC a61GRJ7pJjbMGkliIKlj0RfYc8+9YTiqNRVF1T0/rozWletS9m+jVmc14s0x5Ylv40B8rIf1x/8A W/rV/wAAX4i1VrZWPk3Me9AexHUfgQwrqtTsVV51Cgq6klD3HeuMtok0y9j1GHCm3mWG4T68o/4j 5T7j3rzKcnbkZ6FaG00epnoahmzsjPpIKnUqybs/KRkGoJ2AgU54DijoWiq4C+IoCedyjIp2ngDT pEUAKssgGO3zGmXLqut2zkjleMmmaTcR/wBmTF3Vf3z9T71tSX7mXqjKo/3sV5M5bxuObQ+qMP1r ndMl8u/t2zjIdc/VCP610fjORJEs9jBiN4OD/u1y9hJClxA052xgE7vT5TiuCo7Tdj2qUb4dI6ew iUXUeOdzDn1yRW5df8S3XoroHEUow/8AI/0NcmNRslYYmzjoVU1N/alvIwUPIzf7pNYQqSjDl5dT OdHmle53eqamtnaEIQ0zj5Bnp71mWqpFp7r5itJJ80j56muYGpwrkbJiR/sf40qarHyFtpfxx/jW ixE+a7iZvDK1kz0K3ntltYw08SnaOriqOqy2VxYyp9ojYgZXa2eRXH/2gzH5bfBxnBcDNNOpTeWW EChe58zp+lN16jVuUFhop3udDBqrCKPzlZnQbSc/eH5VBe6jLcufLDCNiAwBAJFYS6jcnDCOIA/7 RNMfUrleFWLJ6AKc/wA6n2lZqxSowTOqtL+0hVVaGRcDAAAx/Orb63AY2VYHII6kiuKW91BzhY+f aI003OpsW2xzcdcQdP0rRVK7J9hS7nQGQPGyeUp3Hj5un6Vu6kw/te4T/nm3lj/gIA/pXE6S+pXe t2EDiXy2uI1fKYwCwHpXSzXPm6hcS5+/IzfmTXZhud3cznxEYxsonRaZbGePcJNuDjGK2YbOQdJA aytGbFiCe7E1sxS+prp5jkaLkMUgXBxmiqh1aCM7QxYjrtFFVqTZHmLE5+tLKcRLXE3HjTDYVhxx kDrVKXxLdzgYLYxxk8V5/sX1OvnvsegC4iSFg0ig56ZrnvEcH9qLCkEqjYTuLcda5pZ9QuzjfIV7 7FP866HTbGT7GrSSLDgnLTNkn+VKcYxWmpcHNO+waFbjRkmAlErSgDhDgY//AF0k/ixgrLBDJII+ GwOBjrnH+NaKCygGXvA5HZE//XVO81FZbcweX+7zztGNw9zWlBSk9ImdaS3lIyrXVrvVLl1sLOEO 3zM20ZPvk5NNT+1b3UXs55jFswSxPGCSOPyq7FIsMjPDEsbn+IdaeZ5WOSwH0AFdyp1PJHNKdPpd lqPw5pyjNzqEsreinj9KmS10O04jtFkYdGk5/nWcWJ6sT+NJT+rt/FJsh1kvhRrSahalAq2cHHQl MkfSqd7cvdwvH2POMDHtxVYH2pwzmtI4amnsZuvNnK6lLcOjWVxEpbOY2zjv+VU4tEv50kPlRxiP ghzzx1rpNasxcWxkX/WR8g1fsLpW8LSX0mVCKbed1XcyNj5Dj/aAx/wH3rnxCqc2jOrCyorWa0IP B9jMtzZxyZaNbgMGxxnqR9eP1pfEtw/9uXcwIz5u1dwyPTmug0DUI5ToVjGB8jzs5H8RPIP5AisT U9NbVdTuoVnhhbfId0z7V79+a9PB1udOUuiseVjKXJJKP2mUdPuluNMvNKvkEotInurV2XO0A5dR 7Ec47FfesWx1qO01SK5ZnaBVMZO3kKeR9eRXXx2qaZYyWrSx3F0y+SzAEIqnrywGeOPTrWNf6dZY WSVFlkUhcKSFUE4PTriri5Qs6T03RLUZpqqvJla+8UpchlgLInspyazU1CArgh8jp8prQl0WyCna rIeow1aWn2unpo32lWiEiHa7KpJQuMbSTjPQ+2SK1rYvEKSU7akYfD4flfs09DGh3zEKEdVPRmQg Cur0YeHtOKy3Rku7gHONnyD6A/1qm/ly3MjblCcvhzw3t9ap5llPl29ipJznbDvP5muDNK9WNoRZ 35bClNOU0d8vjfSEUgLOB2AQf41Wl8b6cTJstpXBORvAHYe9ciPDmq3Cl/six46mQgfyzWFLuild X+VlJB49K8JqfU9qPseiPQpvFtld20kRspANuTsfAxXH3d/psjrHNZibH3SXAIzT7O2vIlgF25hj vFBj4wQuf6/561VvtPlTxMsTBp13qokcZOMgc1cKTlJXZnUq04xdonUvpEd7b2sUgi8mBleRHzyv Q4x3Gc/hXNT6gml3WyK3igkWMw5KDLL68jv6+9buv3o065tWESOygkbs8VS06SPW9Qil+zBLSzPm bCNwVj0CnqBkZx04Nelmb5sU4J7WPKytxp4T2klvd/ibEX2hbOFEQRyNGGkUZ4UdB/KqM32uaD7K LB4mycTRo6SfmMZ/Gur0eO3OoItzJGHYlyrEDOOgH55rpZrSA5IQDB7VjXqylTVCT0RrgrJus46s 8PaQ6dcNa3yTOrnc3mbmJ966vS9QksyFt5fKDj92yAY+mOldtJodpczsskSFzGCrEZxzXNaxonlb vLi2up5Re/uPeurA4uC/cVvheif6GGOw8pP21FWa6fqZOr6t4hgtzeSSMY4zjcu3kdO1c6l/dSXD tMZNk21X3dHXqPyxXWafewzQSWl5hoyMNx096nudOtdR8JzXFsdzQASJgdV7/p/KubF4T6tWSWqZ 1YfG/WqLTSTW5Vtv7ZnEcKXtwAyZjVpmAKjg4+lSS2GsRxsz3ZfnG0yMf6V0Gmzr4j8NwNE6xahb AbHH8Mi9/oe/1q1p95FqdhIzxiO7hbbPEeqsP6elcrhBu51QrTikv0OJvNO1eDXNNSTc/mNkuCcL g1pyaNcajJctDMFEUpUrjJHP1/ziuo14nMJT75UgY9a57wRFPDfapDLGw2qqvxkBgeB+prpoRg6F RehhVqz9tCV+5z2qaZJp6Ru82/eSMbcYx+NVNOtxdXVtA+druqnHoSBXX+Mol/sy3fGD5+0/kf8A CuT0Z9mo25z92UH8jXnzSVTQ9mlOU8O29zr5vDNvDGnlq4bd1LGtmHwbYgK5jyTyfnb/ABrQu/8A j2B9xz+NaUbny1+ldPu32PKdSfdmG/hCxYkmMc8nk1mt4egV5UWBCB7V2BbmqQ/10oxRp2FzS7mf pvh6z+yoXhiLdyUBrQTQrJY8eVHx/sCpbA/uR9TVsH5SKpSE7mDqWkwiSLYoyfao7fSY0v42YcY/ xrTviTsI7GiTKzQt60czBInFhbgj5aYbG3Bb5epqfdxTGOTRzMVjCsoUg1wOo/1biQD/AHcn+lYU c3z1sTSeTeXj+kEv6oR/MiuWSY7q0i9BHomlNjToRnqM1JfXjx+XBERulOMnsKq2TbLKBT2Qfyqo 8ktxqynACRD8/wDOacXqSzoLezi2fOcnHJHFFVo9RhQAOxBIoquZiseNiW3iz5VnCmefuio2v17h AR6LWQ8jMeWP40Ka66eDitzlnin0NUXryMFBOD71KMd+eazISfNX61pZqa1KMGkiqVSUldj8+lNc /KaBSOMg1NNWY56okX3p2OKjX60/NW9xLYdmlHFNpc8VSJY2WdYuDkkqSPwGaLOczxLLsIYSbQFP Hbn9aZPAJsEsVwCOO4NVniks4sRzBUJ6YxyaqEuWV5bEVIuULR3NO+nkll8xjGPMYb8qMEcCtaC1 iXw7exRwiKOUhZE2j94ARj/HNc/eW8sNyyLJG67Vxliw6Anv61u+GNaSHxDaW2sNHJZO2WymBk8D PsKeIrU5RU4LRNGFLD1k+WUtSto6Q2Gq20iJtC5Xk9OD/jUF9JGzzTJCgdid4kzwScgj14Pt1rT1 27tLfxjNpunRKUEhDSFc5GeQM9ABxn61m3+nT2Mk7ojNHGCoJcneFVTyD6A4yPatVUpSknFWTKVO rCDTd2u5RnuZGLhkhGQc4U8Z+p7VWlnViSwhySeg9ce9PSO0uYfOggSTPXPUdevBppiKKZFjgQjk HBOOnfj0/WuhzinaMNPUwjGTV5VNfQbu/dFwpHOQQq4A/EZ7/wAqfE0gdd4jZN4JG0LnHbpg1GN7 2luZ5CYZdwKp2K9B+eKhNvhMsD8+WOe/+Tmtbwc1FIzamoOXMWrgoCzHKgHI4rt/Cc8UlkqSJGGO WWRmGXyT268VxVzCbd1WFygKK2Oo5UHvVmGxu7i1SURboucFGIwfpXLmNCMoKTaXqaYCvJS5Ur+h 6dcjbBIUA3AcfWvGLa3jub+BXyd8qiTcPVua2TLqNrHsjv7iBTxtcnFZP2O7hcOq78HOVNeFUwla 10rry1PbpYulezdn56HoHibQ5Lz7HdW7AG2HK57ZHSsmKHzdbZiuc8D65FbuleIrTUdN8u5dYblU wyyfLn3Gf5Vm6Zf2lzr0NrA4kkQmR2HIUfX8aWHu68F5ixDXsJvyOW8ZILjWoLUsQrbV4PTLV0ei 6VDpGnGOMMA7mXLHkgcD8M/1rBv4n1DxvHGg3eWykj8M/wBa7fU7iCRQ1vH5akKqrnqF4B+hJJ/G u+cXPEzqvZHmSlyYSnSjuzlNa0e/vrmORMRR4zDJjoc88+lULLXte0YmOaWVVRthDjcmfT0zXq8E EE+nwxMAyhQOD04rOuYTZJJHJCLmyPDI6gjr6V5kpXep69KPJFRRhab8QITcK1/blfl2l4uR9cV0 5vNM1223WlzHJIOVAOGH4Vyl94cspHa5CNPZMCzGL/XQepP99R9Mj3rMl8KXUEa3el3IuYT8yMjY P59D+lS4yt3RpePoWdb0BnvN+3EwIJTcVWUehIrR0e6/0qaO5RI1m/dvBGMIi4xhR6YrBTxHqVsD b3waUL1WUYdf60Jq9tcgMJPKuE/gbjcPrW+GqRlL2dbZ7Psc+IhOMfaUt1v5k+g3M2jeILiwJ53E L7lf8R/St/WEkjC+INN+8o23UX99f8/0rhb7UZJtU+1IQLiEqd3rjGD+WK7u2ux9iS7iGbW7TLJ2 U9CPzqa0HSm7l0pKpFNF6S/t9T/s+4gbdG+MjuDnkH3qxofFxqq+lw39a5K6iPhvU4ZoyX064IcY /hPf8RXU6JLHLe6s8Lh43kEisp4IOTWtBfu6nyMa38Sn8zJ8ar/xJIz6XQ/9BauHsH2Xcbej5/Wu 78ac6E3HSdT/ADH9a87jcpJn/arhqL3z3MK/9naPa7xT9k/H/CrULfuUPsKr3BzZF/Vc4qW1+a1U +39a6DymTk9KrYxcNzjNTZ4FQynFwfcUAPsuIz7NVnd94VTs+kg/2qs55NAMhuR8m70amTn5oWx3 /wAKfNnyj9ahmP7qFvQigEWgw/WkNRRkGPKnIz1p2aAOd1k+XFqT/wDTJUHtl0P9DXIRMWlVQeSQ K6fxYwisbj1kliA+gDk/0rlNN/e6nbL6yL/OtdkI9LRgFUegxUWUjuw2cFxgjtSA0ybaU3tzsO6k mIumSP6gegzRVJi5CtDJtUjoRkUUxHihNCmm560o+te6jyWWoT+9X61pA1lRH94mPWtQfjXLiVqj ehsx4NMkbqMdqcKa4yD64rGnuaz2JFI4p3eoxnAqRTVslMd3oz2pOKOD3ppCbFBJNJIA4IZQR6Gn AUxq1STM3cYMDAA+gFU78lJLeUdmx/hVl92xthw2OKsQRw362b3kbC3Jy5Q5OB69PxrDEyjGPK+p rQi3LmR2urWumahqa6w1zHAZLdCTuAySgyPrkH86w/EF5MklmqyYt7uIq2O54P8AQfpUurLHqPgq N7fA+xyyRgKc4A+Zf0Z/yqPxLALnwlp91GMSW7KQR9MfzArmw0Gpqo3onsViE37q6o5SSGW2l+1W Rw3Vo+zVftpodUgZoQFmA+eI9/pTEIlKsnO5d/HYdz9Kq3tsynzLQhLhG3GQcbj0I+n1r137krLU 4IrnjzS0Zbs9PaUeXLkQqJAi+jbc4/l+VV1B2AMScDAyc4rR0TWY78m3l2x3gPMbD7/096qXVvLb SbZBgHoR0NaUU+dvoY15vl5XoPvMmVD/ANMk/wDQRXW+DZd2mXEJ52yZx9R/9auSusEwt6wp+gx/ StzwjcGO6uIv76BvyP8A9ejMoc2FfkRl8uXErzOqu9Jsr+J4pYRg/wB3isdfCsCF44WOFwRk4NdB HKSxpiOTczewH9a+WjKUdYux9NKEZK0lc5a80CaFGLp5kYHIkUMD+NUvCunG2169uBarDF5DBCGJ zwfXpXW6rcH7EwHcYrO0x8Wd22PuxcnHv/8AXr0MFiKlSuoT1/M8/GUIU6EpQ0Oc0OEt4m1C+kBI DlFGMHAHP9K1NTt5JdMNqjKskzZDHso4x+OM/jUmnI0spmQ4Cozk/XgD9DSanBdP5kkMZYRAZBIO OM/1/WvTq1aao22Tvc46Cc6mmrjaxzieHdbWFZI5FwwyAJCD/KnrF4qtSQrzle4EoI/LNXYdYu4F UN5ir6ZyP1rWtvEMbMRKFcEYI+6f1ryfqMZ/wpJ/mej9ecf4sWvyOXXWvEenXQkRZFcD7pizkd+1 WNP8WSDUN8Cx2d5I2ZraQ7YJz6/9M39+h7479NFc2U1+jNhU2kZk4AzjvVrUPC+k6vEGliUyL9yW M8j8a55UJ0XZpnRGvCqrppnJ+JNcS7ie3udKe1vVwQJDyvPUcdCK5IwidJHMqxtGpYbv4vavTJ9O WK3jsNUg+02SjbHMP9ZF9D+XFZZ8H6fErvKzy2Zbi7iJ/d+0i9v97p9KylDm2ZrGXKjhrKK4kY3P 3owAj+o9DXc+Db9JIbrSrhvlZTJDn14yP6/nUcfhwaYs1uJBJHICUYHOVI4rnIZJLC/jmAw8L5I9 cdRTjJzTjImSUXdHeX9oZrP7FP8Ac+8hPb3FZvhjVF0LVJrG8IEUxCiQnhTzj8Oa6O8khudDtLqM 7twBUj09K49rG31nV5EtptsxgOVZSP3ikYHpyCfyFKneLauE7OzOl8Ynd4buiuMB0bI/3gP615sG yG+v+FdDNq8n/CN32k3oYTIFEZI54dSVP0wa5tT1+o/kKir8SPRwj/dNHtkZMmkRP1zCrf8AjtWb TP2QccY4qnprF/D1o3rax/8AoIq1ZN/oqj2NbHnPclycdKifLTe+P6VYx0qF+J1FAhLXIklHXmrJ Jyar2/FzKPpVkjnNAMgnfMLYFRT82i+xFSyr+6bjtUMoP2P6UATInlxkZzzkfjT8ZxSKNyA57UYI Gc0wOJ8c3ACQRA8mRifwVcfzNc9oLj+2IGc4VcsT6YBNaHjAS3WqqkKPJhSTsGcHOP6VV0Gyu7K+ W6uLKTygpHOB/PFOUkgUW9jWvfEtwLjy7eMRx/3nHJxUFhqk5u445rnZDJIGkLkEEdxUmsXWk3CF 3uIYZgu0F5F45Hoax4bjRmyGv45XHACHbj/Gl7WCQ/ZTOhk1p7ORkgkSWMHAyOn40Vh21xaylkt7 O/lCHBPAH4UVPt49h+yfc48GnCohzUi9K+mSPCbJ4vvr9a1VNZEf31PvWr2rkxS1R0YfZkgpsnrm gHNIXAODWFO9zWdrD16D6U8VEo+UY9KeDzWjRCZJ9KMD0poIPtTqaExegpjU7IxTDnPtWkVqRIbV jTY/PiuoS6jyFZlXuQ3NV8jvmktbuOO7cpK0cpBjZdgbcPzHvWeJpqcbF4eTjI0vBsgmg1XTZDxI scoz2PMTfo5P4VqtLC3hoWc77S6IFz1DBz/gKwNKkt4NbUWTu15d4gVZThAGGOn49c1u6bbC7uQZ 384urJ83TKgYOPxrKjTcYyia1pR5oyZzymNI2t4hgRn5gR3Oe/pUfOcVEP3NzGSfvAwt9R0/kamP XNerRtypnlV2+doZBpkF+8ocbJkmjKSjqoPB/DpVuz1iOa6l0jVgFlRyqSngNg4Gff3pLM7ZLvHU RIw/77qDxJYR3Go3IxtfcSrDt3qGpe1vHsUnH2dp9y7qli9usZUFolXbvx3yev4UmiXIttUiLNgN 8hz79P1xVDQ/EUtgw07WUJgcYSVhnj+orV1PShbqLyxJkg++ADkr/iK1nJVaMoeRhCDpVoz8zs4Z 8yc0n2nbcTD2H9aqWcgkbcDwQCKHJ+1yfQf1r4y7sfYqCbK2pXRCKp70W7FfDV4/Qu4A/Ef/AFqz 9TlzMi+grQKsPC9vGn3ppiP1GP5135VrWk+yPMzj3aSXdk1jCbfS9xJVp5FUHHQDj/P1q3c3b3tl Ndsqq06u5AGO/H6AVT1SURFLOPqke38WGP0z+lWP+XIJ0AQrXVjpqMlDsjjyym5KVTuYdpiSw+YA jPQ/WlTTbae7ClSoKn7px2zUkMDC3YL0z/WrFnDtv1Zs9MfpXAmj1XFmRcabLbXsUcMxIcdDxT3a 80+X+JT1ypx+orduYkOoQNjpkfoarzwO88h4xtI/nW8MTVjopafeYTwtKerjr9xTh8TXGwpKwkTo fMTP6jH8qlsdZe2d5bQ/eOTGp3Kf6/pViHT7ea2ImjRjuPOOeg71hpo8UlxIschQhuO9aOtTn/Eh 92hmqNSH8Of36mjeXVtKiPa/6NLk74WGIyfb+7+HHsOtclqJD38w2MkgILo3UE/oQeoI65rb+y6j BHlXEyA7cNhsdfX6ViX0Nw179p2oISgVlBPB9eaznCgvehLXszSEqz92cfmjY8PaqUtJNPmY+Xnf H/sn/CusltjJbgwAZiAJx1JIBP8ASvNYnMM6uOMGuoGpFtPkhEjs+9JIpFHQgEEfkR+VbUcNHEJ8 rszCriXQfvK6INZhS/SS4+VbmIfvB08xemfqK5dkKsfQmty7Zp4ZQ8qrI6ld+euazHj2YjeQO+OG UcNXNWwlSn7suh3YbGQa5o9eh6xoRD+G7Fj2gUfkMVo6eA1qK4LSfFM8GmRWVvAjmFdpLf8A66sx +ItWSPZH5MK56nk/yrWng61RXhFs56uLo05NTkkd9x+NQS/61DXDPreot9+9I/3eP5VWlvnm/wBb cyOf9pq6Y5Ri5fZt6s5Z5thI/av6I7sXdvDdSGSeNRjuwpkuv6bFz9oDf7orhAwk6Ru/5mrEUE8j YitefpXVDIqn25pHHUz+ivgg3+B0k/ii1KlY4ZH9+39aoSeI7h0McdsAvqaW28OapOnmMkcEf9+Q hRWlY+GI4dStJL28k2F8qQuIyccdev8AKm8twsE+ao2/IzWc4ibXLTSXmZR1XVZE2hhH+n/16py3 V2ykSXEjk9Bmu21nQ5nZriL/AFyqSNw/1gHf64rlJbZUWORH35HzexqIYXDNXijshisQ177szMEs sRw7vg9vSobyws9VURXe/Zn76tyvv71oTRhx061Sa3eJsjpWscPStayG61Te5w0ulQW1w8TJuKMR k55qWOKGMjbEg/CuzGm2F5Jm6ilMhGA0cgT88qc0sng61YZjvJ4iegeEMB+IbP8A47Xk1sO6crHo U6ynG4sHhu1+zRv9rmhYopbGMZI7flRVhdP1uBQkOs2cqgYG/K4H/A1FFZKD7Gl/M80GakB45NRq eKcDxX0J4jJUPzj61rr0rGQ4YfWtcdBXJit0dGH6jxSOvcdqAR0pGYAjJPPpWEL30Np7ajoyCoqQ VFGRtGakHFaNama2H4HpSjPakyaAaaExx9KaePxpc0h5q4ksb35psW1dVsnI+UybT9DT/aoJyVMT jqsqn9cVrHRmUloytqrPY6ha3kR2tG459Cp4rv8ATxt1VZIo2EL3DyLgcBJBuX9CK4zxDCZW1KED 5on81fp1roPDHiCeXQrODy1JjkWIyE8sCf6Dj8KxxPtKdSTpRvzImlJTpRU3ZxZi6vbmO6vIk5KS l4z+ORSArIiup+VwGH41c1lfK1idT13FT+HT9DWbbfIjxHP7tuP908it8FJypK5OLVql/wCtTR0m 2e6vZo1IGYec+xzS6+ANXnA9R/IVFppYavCqkrvR14PXOKfrpH9sXAHQNj8hiqpxn9Zu3pYxqNex djPv7SO8063VxyAwDenOf61Bo2u3fh+b7LdAy2jHoe3uKvZzYRe0j/yWqlxCtxGUcZz0PpXbOin7 y3OWlXcfdlsd5ZXFtJGlzbuHtWGAy/w+xFSyYN0/cFRz+dc14SYQ2L25cRzxSEKxHyyKcHBH4muh UZZjGpV1H7yEnke49RXztfCwruXstJLdH0VDFzoW9o7xezOe1B/9NIz0FdhawKbfTI5B8scZlf6A c/yriLxHbUmXBG44FdvcSeZBNHA2xvKESsR07n8OaWTUpKU7rUzz2rFwhroY0Mv9oajJMRkFjLn9 B/WtQITB16ZqtpVsmm2Ej3kkcbu3JZgBgcD/AB/GorjxNpVuhVJHmYZ4iTP88Vy4lSlVbZ1YFxhR SQsC/uiD/eP86sRD9+tYVr4jgMhSSznRGYkPwe/pWxHfW0mJItzr2IFZ0qFWo7QVzpq4mjSjzVHY kucLPCxOAG/oahnvLRC26ePOOgbNR3ifbUU7pFA4K5xmqH9jwdQnP+0Sa61leLb0icE85wEVrMsR arbICDJ/HnpWYmpwW91I24NkggA81aOhWxGGLH8cUqaFYJ1jyfdjXXHJ8S1q0jz6nEWCi9LshOrO kbBYBgtuG4/X/GudvryeWKYJhGwSoUZrslsbRAAIkx7jNTKtvGCFVVHsK7qeTU0vfd2edU4lbf7u OhwsFtPcxI6QSncAfuHir8GnXu3a1o7emXxj8M11nnwp6fnSHUYIxn5BjvmtqOWQpT5r3Oerntar HljC33mDHpN4R8tvEh7bsfzFE/h29vItktxHFg5VlXJB/MVpyeI7GL711AMe4qm/jOwBIS5ZvZAT Xc1G3K7WOKNfGOXNGLv6DoPCbRuH8+XdjkoMVfTw/H/y0kc/7z4/wrEfxlAXC+VPluhZCB+tQyeK 5t2EtCR6lxWMalDDx5VJJGsqOY4mXNJXfyOoTR9Pj+8EJ9yWqYW1lEPkA/4CtZtml7qNus9vJvjb ukZOD6dasPo2p7QxMw/75Fc8s1wy+038jVZFj5r3rL5lxZIo/uqv41LHqTxHKMFx6VQHh+9MqI5f 5h3kH9Ksjwrcd8fjKxrCWcYZ/ZbNYcNYlb1EjTtPEKwXKzSxCcqePMYnH51pX/iix1G4tZhG0UsT fMThhiueTwo5bDtEB9Sax7nThZ3DxuinHRttcdTMcM3z8juehRyXFRh7P2qs/I7t/EdusgMcjTKh IUEYGD1H/wCvmsjVLNIWW5tyTZ3HzL/snuDXP2cgQ4J+Un8q6TS7mJkk067OLeb7rH/lm/Y11YWd OrS56XTdHLialfCYtQru6ezMZkI4pNoK4NWrq2e1uJLeUYdDj6+9V8YrRo9SElJXRTkUxtkCug0i 7juoRDKB5ijgnuKyXXcOarxu0E25SQQcgisq1NVYW6mlObpyv0OrnsInwdgzRS6ferew56SD7wor xZKcXZnpJpq54KDxxSimg0o619CjxmSKeRWup4HNYy9a2E5UVy4vob4fqSr1pGFJyfakcnjGK5qa 10Np2sPjP7unjrTIz8gFPFadSOg7mlzz1pBS1SJYc0HHWkoPXrVol7CVDdA/ZnPdRn8uam/Go5l3 QOD3U1fQjqaGsgJrNvKfuXFvGre5KD+uaPD9stpaTIsq4jmBIY8gg+lJq2bjSNLmH3zaA591Zsfo BS6eyO00g+7LGjfrW8Yua9DklJQ+f6M2/Gpie8tdiKroMOQPvZyc/rj8K5Qt5d0h7SDY316j+v51 0PjNpDd2kyAbWgSQ+/GK5qYGSIlPvDDKfcciscDFqF33OjHNc1i/aZGqWe3qZNo/EGn6wc6tdenm sP1qG1mU3tjN1XzlbH1p+qEtql0cdZWP05rpgv3/AMjlqP8AcX8xn/LivtIf5D/CoKnX/jyf2kH8 jV+z8M6vqFh9utrJ3ty20PkDJzjj1rsnUjBXk7HDCnKbtFXINHt3uJLpIz84RXX3wSD/ADFalrfZ kK3LMksa4SQdVNamn+GYtCkF7qeqRQuYyvlKNxwcH8enpWTqs1hNcFrQSnsXbAz+FfM16NSriXUw 33n0dGtTpYZQxH3F+2a11aaEuAtxG4Y46EA9RW6YF8rchB2nDDv7GuItpfs1wkqA5B5Oe1dVDfMP LnQ89QfSvfo0ZqPM/i6nzOMxEHLlXw9BL2zgvYGguSAh5Dgcx+4rireHYdkqqr+3f3rr9Yjv7rSt +mRo8gf96ueWX/ZHSvO9fnurW3sp45GWfe7Mh4yowMEfUNXn5iqVtV7x6WTur0a5Tc2x55JCjvRH etYtvRtqdwehrIj1iOe1EjIyOANyNwVpbGwv/EN2qRDZCWxubpXkU5ShJSi7HvVacakXCaujo01+ 0dATMiE9mOMUR63DczNBbs0s4/5ZpG5J/SsG9jtbSK608xj7TBP/AKzBBZcdCOn/AOuuy8E6vFoe lhk0mWSaXJeYFRuGTjknNeus3rWsoo8L+wMKndtmeTrsn+q0W5/7aFV/rVN7jWfN8o2kccmcbGck 5PbAFeo6F4vtNY1htIubCW2naMyR78MsgHXBHcelZ3jLT4rS90/UI1XzLa8iLE5+4WGSfp/jWX9r Vk7T/A6VkuGVuRfectB4Y8U3UojZrOAd2KO239RWjH8O9bkVTPrQ/wBpYLcfzIzXo+mXKGJSHQgj ggjmtJ5wYxhgTntzXnzx+JqfbsehTwGGp7QR4h4h8CX2jaQdRm1WeQRvh4s7QwPfgjH/ANauR+zw OfmiVj6sM17z4rtWvtCvIWiLq0Z4PGeK8IEE9uwjuFKypwwqFWqTXvO5p7OEfhRJDawMxHkxbux2 Cr8CLGu0KBjpgYzVJG2spB6VeBBAI7817GX1ny27Hk5hRu79yUxxyjZIgZT2IrG1bRntUN5YlnRf 9ZD7eoNbS1KH7EV61WhTxENUeNRxFXCz0ZleF/E0mj3QkUmSzlOJI8/qPcV6vHfW2oWSz2syyIec jt/hXjGq6ebCZry3XNu5zLGP4T/eFS6dq1zYkS2s7BTzgHIP9K+YxGFdGpyzPqcPilXpqcD2Rz+8 gP4Vbrg9O8aoxhj1KPyiMHzVBxj1Irt4bmG6hWW3lSSNujIciuadOUHqdMZKS0JCeax7+yW7SUY+ cDg1sGqoH+kN71DV1YtOxxIQxsyHgg1ftZBLHsJ/eJ09xVjU7Ft8k0a9D8wrKjdo3DKcMDwaeExM sLW5lt1ObMcDDHYdwe/T1OkcjVbAf8/1svB/56oO31H8qyQ27mpILhlZJ4WKspzx2NS3yowF9AoW NziWMdEb/A19U4RlFShs9v8AI+RwOMnSqOhW0a0K2O1QSpn61MOfTNNPP1rnejPoFqiKCeWBiY3Z SRjiikdOciilyxerQ+aS0PLRS1ECacCe1UmZtEoPNa8Zyo+lYoJrWif92v0rmxWyNsPuyznNIdp4 J+lMDGhnHeueG5tPYkj6Y9DUlQI3B+tSBvetHuZrYkpc0zOetGeKpCY/PFITyKaWz1FA7VSJY/FN YjGKQtx7VGr7iRnpW0It6mE5WNCNvM8PWBPWN5I/wGD/AFNV9LbZNPb5+6hx9Oop9m2dHmT/AJ53 XH4g/wD1q0NAt9PuLuQzsRdZKBM8FMZz+ZpVcRHDRVSWxl7J1VKKJtbl83StCnc58y12sfcY/wAa wlUINo6DpXT+KrKK30rS0t0IhilZQCc4BGf6VzRwvOQB60YHERq0U4l4qL5yGPKER/8APOVWH+6S D/jW1e20KagZLm5ijieTf82TuXPbFY6zRxztJgOdu0egOetL57ucknJ796qcKs6l4uytYhShGFpa 9TtfEeneFrCznGn37yXTuGSJG3Io9z+fesuHxXqsGkW+mx3G2KBNisq4YjP8/eufU5609TzW8MOn FKp71u5jOu026fu37FpppJmMkrs7HksxyTSg8VAp6VLH1rrjFLRHFOTerJ14H1rUsJyB5RPuKy6l jYqwYHBHNdCOCquZWOit7iS2kEkTFWB9afe6bBraNLZNHZ6p1ztGJPocZB/z7VRilDxhh3/SpQ2H DAkEdOawr4aFZWZnhsVUw8rxZxcmh3suuzSasJN0S+ZNIzfMQMDHPUngCu0hkSGxt/sW4Sfel2Ah WJ6j6DgD2FaRaz1e0NtqnDDCpcKPnX6+oqhrsdxoeiolurckIkqnIx67vevna2X1I1FCPU+wweZU 60Ly3Od8UlLlYppUjju1O0lEwXQ/3vcdj6GmWFzqd3BHbWEUm1F28Dp9T0q/4Y0GTXLyWe8O63TG Rzlm+ua9FtdHhgRYoYwiAYCqMClXhDCvka5pHZTk6q5k7I88Gnap4cEniJp1kvbdDsVzlRnjk9+v QVNb+Or/AFm9WK+2K4iGBCgILDqW3A9eelbfjDTpb66s9LiYKjMGkHqScL/I/pUtv8KtNa6adbm7 jBGCqOMH9Kwm06fPUWrKUm58sdkdj4cvLWayRkZDjg47H0rpozGyfLj8K4/RfDVv4ftvs9oX2Fix LNkk+v6VrLIyZwcVwKTT2Om1y3qMYe2kQ85U14t4y0s26Q3yrwf3bkfp/WvY/PMikMc5GK5fxBpa 3ujXVmRlmUsh9GHIrRS1JseLq/zVet5N6lc9OlZDbkkKtkEcEVZtpvL+bBOBnHrXbhavs6ifQ5cT T9pTaW5tqNyj2o579RUVrcpLGrxsGRhwRU5AzkfjX0FCryyt0Z8/iaKnDm6oQgMpUjIPUYrmL60b SZzIgJspD/37P+FdL0NJJGk0bRyAMjDBB71vicNGvDlZyYTFSw1TmW3UybHUFjUQXCCa3Y5AP8B9 R6fhWrCLvTpBNpN4yZ/5Zk5B/o35Zrmbq0k0qcI2WtXP7tz/AA+xq/Y33l4hlb93ng/3a8Wlywn7 DELToz36spTh9Ywz+R3Wm+OGDiDV7Uwvnb5idPxHb3rore8truTzbaZJEPdT/OvOz84w43gjHPXF Njhkt5vtFjO8Mo/u9/qP8PyqsRlDWtJmeHziMvdqqzPSo1V5JY2GQRXM6lZm0uWGPkbpVfTPFklr JjVoshhjz4hlSf8AP0rpJ/susWW+2lWQYyCprxa+HnHSSsz26NaM9Yu6Odt5hC2W+4eGq/DMEZuA 0TjDL2IrJkRonaNuCDS6ddZLW7np9w/0r0Moxln7Cps9j57iLLXOP1qkveW/oXwnlybT0P3T7UrL g59aeB5mE7j7tJnIweo617OIp2fMjjynHe2h7OfxIhI9KKeQc0Vynsnj4p4BJqRbV8dRTxavj7wr NVodx+zl2GmIqu4/kKvxH5F+lVRDL2YVZjyAB6VnVkpJal04uLJgcUMQeDTQeetB6VlDcqWw9CcH J4zUmeKhjPXJ71JmtHuQth4al3ZNRg4pe9UiWOz2p2ajzzSk4WrS1IewkkmBgUR/dzUMhyeKnQcA V1fDE5t5E9g/7nUI/Rkf+lLb3KW2qQyOiupjYc/h0qOy/wCPy5T/AJ6QZ/I1Vuzie3b3I/SlJJxi 2KN+aSL9xrk8tr9kCJ5avvBI5Has0u8rZdiTTTyxNKOlOMIx+FA5NrUkUc1MtQqakUmtkYSJlPen /SoxUg6VojGRIOlTp0qunJzVhTxwK1j3Oap2JVqUcc1CDUgPGK2RzSL1lLhthPDdK0ATWIp2kFa1 YZfMjDd+9WclSNncnB7Vo2OptCht51861fho2/pWYG4FKOnWs501NWZEJyg+aLOy0iOytIG+y4+y sxYHuhPZh/Wt+AAentXnFney2coeI8Z5U9DXXaZqcU0KtHJtcffhc/qv+FeDjsDJPnWp9RlubRml TqaMzNTZD4+tQ3BAjAHqPnP88V3VsPkwo5Neea/c28HiWyvmLMJI18tlPAKuM5/BjXoNq+3aRXJi Ifu4eh6mGmnUmvMlmXbwRWfMQrVoTsXYk1nXPK158oncmV2nwwxUF228bqY5xmmSnMdQUeKeLrM6 d4knUDEch8xPoev65rOglGR0rtPiPY+bZRXqDLQttb/dP/1/5153BPjvWyd0Sy1DNLpt9JsIaBzu 8s/0rb03VPtcjJ5ewqMnnNYF4I5oEfnKcHBxxXd+HvBdte6BZarbSyWty4bzFlcMko5Ax6dB1rqo 4mcWot6HNVw8ZJyS1KjDnjpTR6GpJkeCZ4X4ZGKn2IpnBOO9fTYerzRPlsXR5JXQksEV1bvBMu5G GCPSuUubaXTrgW83zRtzFJ2Yen1rqwPeob20S8tHhdQSRlT6HsazxmEjXj5l4HGSw87P4WZumaht xBMfl/hY9vY1slcjjrXGDzbaUwTqVkXse/vW1puqbQIJz8v8Lnt7GuHBYx05exrHoY/AKovb0DZD En5u/BPr9fWtC4Emn2sFtYXS2sgPnGSL5kYnjB7gfpzWecH3FIQexxXpVcPCtbm2PLoYqdC/LuTT 61LuX+04BG/QTxco9RxSK8zNG4I6gg0wMyqVGCrdUYZU/UVVewTcZbOY2k5/gPMbf4V4eLyVp89F nu4XOYzXJXR1VpP9oi3dHXhsdjVuUBh5q8N0Ye9cPYeJTpmpG21WI28vQkHKOPUGu0S5SRFkjdXi cZBB4YGu/BV5VoclRe8tz5zMsK8BiFWov3Hqv8hp55ooc/NlBnPvRRLDTvoexRzOhOClJ2Z5gDS5 pg6U4cV4Sse6x26lBpueKUGtUZskFKScGmDNOHT61pEljkPWndB1qJD8xz2qT3rRmaHZHalzTKXv VITHZp2RimA0E4FaR3M5bDR96p1qJRUy1tJmMULbHbqsP/TRGSqt8cLEe6yY/Q1KrbL+1bPSTH5i mamNucdpR/On/wAu/mQv4vyIM8Uo6UzrTh0rREsevFTr79arjOalU8VaZlJE6mpBUI9KkTsa0jqY y0J0681MnTrUAPrUqn8q6InHLUlB/CpFNRKaeOtaIwkiUVZtZdsmwng1UU1IPUVdzNxurGuGFOzV WCTzIwT1HBqcGnY5GraElSxyMjhkYqw6YPSoAacDUtXJsdJby2Gv262mqDZMv+plGBgn+X9a7Cxz BHFbyyBpVQYb++BxmvLQ2DkHpXRaTrwhHlXgMidmzhh7g+teRjMC2rw27Ht5dmns5ctX7zvm5FZ9 1wpqK11ZJlG4Hy2OEl6g+mfQ1JdfMh968CrTlB2kfWUa0Kq5oMyy2WPtTHb5SKaFAZvc0x02KcE9 c1zm5h6vbJeWk9tIPlkUqfxrw+6iksryW3lGHjYqa92ueWbIrzfxn4dlubkX1tjccLIuOvoaun2F La7OSiul+63Q8GrdlrUmm6zayiFriOCRWEbNwR6CoU8O3RPzPt+px/jWpZaIIgrTOd6nI2np6c12 xwdaT+E5pYyjFayO18QQNHerM8fltMoZ03Z2t3571lhgcHuP1qAyySNmWR5Gxjc7FifxNOV/cV7N GEqUVfdHjVpRrSdtmTZGetLnmoc+/FPU4NelBqSujx6kHB2ZX1HT49Qi2P8AK6/ccdVNcu/m2c5t 7hcN2YdGHqK7QYIrM1fTvt1sQoAmTmNv6Vx43BxrR5l8R3ZfjpUJcsn7rK+i67/ZNz5s1vHeQbSv lTchc9xW9Y+IdO1OWO3utJKSSMFWWyYrn32NkfrVLQLTw/Lp4s9Tt2jvudxmuPJB5/hY/KT7Guig 8HWunapb3drcytFGC6xyJnPHZxwfpwa+f9riKT3Z9J7KhVWydynqunf2ZfPbGRZAuCrr3BqiQMHF U9X1XUIdXjOoQ+XHMxCggZCjoc1a3Z+Yc/1r6LB4hVqer1W58zjsK6FXTZ7GTrmntdWmY13NHyIz 0NXfD1+ulSxaJduRI4LxgtkLn+EH06/jVnjP1rjfEWmSW14L2Fm2sc5z901niKcoVFWh03NMPKGI pPC1eux6qG456UVgeGNcGsaePMI+1RDbIPX/AGvxorshOM4qSPnK2GqUajhJbHHL0p+eMVGOlOzX ySZ+k2HZpw681HmnA1qjNkgJzS5pgoPzVpFEyJFOGPFOzmokPJ+lP3dqvqR0H5ozTM0A1aJZJml9 KaDS57VcWZtD1qQGohwaeDVXJsQXLFHicfwyKc/jUusEfveOdwb+VR3gzayY6gZFLrBLxCQfxRA1 vG0oNHPO8akWVs+lKDUe7n604H3qkEiUVIDxUIPNPBq0ZtFgGpVPpVdTxnNSKa1h3Oap2LCn1qVT xUCnmpVPNbJnNJEympAahB5708E9c1aZlJE44pwNQg+9PB5q0zJotQSbH64B61fBrJB4q9byb0we orSJzVY9S1zTgRjFR5paLGRKG5pwbFQg07JpNEtGlZalNaMVDZjYYZTyDXSWurxPbgQqWUfei3ZK fTPauKz61LHK8b70Yqe1ceIwdOstTqwuOrYZ+69DsllSQhkOVPINEhyprKsNSSYiOV9h9cf5/Kr8 5dYsrhtw+Ug8GvmMVgp0JeR9ngcxp4qPZmbezLEu5j7fWsu/i8y1k4+8taElt8/mSnfIOh7D6VFO u6Ij2rkg7Sud8ldWOD7huzDNO9zSKvyOMf6uV48ewPH6YpTX2EJc8FJdT5KceSbi+gxqN2R701ye tRg80MpFpH7HvUgP6VUBxUytlcjt1p05cjFWh7SPmi0hpx9KgR+RVgDd14rqPPtZlW5gS4geKQAq wwa5b7RqWkStaLdzxpnKBXIVvQ46V2Tr3qndWkN1D5c8Ydf5fSuPF4ZV46aM78FjHh5a6pnK3moX l6Y3ubmWYxrsXexbaPQVe0rVvKUQzt8n8Lf3aiu9IntQWizPCO38a/41nAK3Ktxnn2+teC/bYSdz 6K9DGU7bnbCQOAykEHoR3plzCl1A0UgyrDFc7p2ofZpWRtxiPbPT3rfiuY5kyjBh7V7mHxcK8bde x8/icHPDzutu5xky3Oj3rrFI8bEY3KcZFFdTf6dFfKhfhlPBorCeElze69Dtp46m4rnWpzyyMvDA g1IJQeKvOgyTx+NQmGNjygz7V4VNqoro9ud4OzId4pwYdaDbDPBIpvkuOnNdCiZNkoPPtRubJx1p gVxwRSkH0q46MmWpIG+cgU7PrUAyG/Cn57VZJJnHfpRmmZBo+lUiWTA04GolNPBqkQyVTz707PpU W7ilLYFWkQ2LN80Tj1FNvHH9iwydcw7T/Kjdn8ahm58PKDzscr+ta6qMvQxdnKLfcgQ5iQ+qinA1 DC2beM9flFPqoaxuOS1sTA09TUIPpUqVojGROuKkQ1EOnFSA9K2RzyRMpqVWqBSakU960TMJInBz UgPvUAPeng85q0zJonU04GogePxp4NWmYyRMDnrUsUhRwfzquDxTwfSrTMpK5rKc9O9KDz9aq20u 5Np6jpVjPPStNzkkrOw+lzTc0tBI7NOByKj5pQe2OKTQWJQ2PatC1vsBY5mJT1B5rMzkUoJ7ms50 1NWY4uUJXidMy+ejvDlgBkjHIH9RVCQ/L9aqWd/LaNlHO3IOPcVqsYNQt3ki+WcnLZPB/DFfO4zL HF81M+py/OFJKFZ69zz9P+Qnq1v3DJOo9iMH+X61G/rUtyr2XjSDzFKrdRPA2e/cfypHTaSD2OK6 8vm3S5ZboMfBe15o7MqtTPwqVhTSMV2M5ENzxmlR8EYph60nNTboaX1ui2DzxVuBwTg1mo/8Jqyj 7Tn3raE9LM5qtNX5kaLoCMVXdMcCrMEgdQDycUSR8cfhT5u5HJfYpEYGazb3SLe7y4Bim7SL3+vr WuyYqu/6CpnGNRWlqOE505Xi7HJXNvcWJxOmUzgSqOPx9KI5njIaN8e4NdM4DAhgCD1BHWse60dc l7NvKY9UPKn/AAryK+XSi+eiz2sPmUZrlrIlh1gbcTqc+q96KxZmeB/LuIzGw9eh+horn+uYqHus 6Hg8NN8yRpbwTyacrpjDDNVQ/alZuK8ihVdOVz2K1NTVi4qow4bH1p3kMfusDWWLnY20mpkuR2Ne /GKkro8dtxdmXDE46xn8KbsXvkfWiK9kXkPn2q5HqYIAmgjcfSk6b7Aprqyp5GTwQaT7Oc9MVswy 6POP3sckTeqNxV2LRrC5kRbfVo0LsFHnfKBn3rGXu7po1jrs7nPDS5cb3YRqecvTXgjFtGYi5lJ+ fOAv4VvHw7eXBeW3AuY1YqrK3Bx3AqjcWF1DxPbOv1WsKTnVfxWNqijTW1zIKMDgrQCQMVd8pc9C KiaBWPDV3KDONziQ7qaX5qZoCPemfZ27g81rHTczk09hm75cikXMmjXad1kzUnkFe/5ii2jPl30X XeoYYquZSul2ZEouKT7NGdbnFsg9Mj9akB4qKAEQbWGCGNPB96KT9xFTXvMlU5OKnWoEwOTUqmto mEiZTUgNQKakBrRGLJgeakBqAHvTw1WjGRODUgNQKwp4atEzKSJxTw1QgmnqatMxkicHj6U4GoQ1 PBq0zNonjkKOGrSVwwBFZINXLWXgoT06VpFnPVhfUuA5p3GKjBpQeKs57Eg+tLkdKYCO9GenNILD waXNR5pc0WJJOMVJFO0TBkYg1DkUbhSavoFjWdbLWBCl8gMsbh0fOCrdiDWLrekzWVw0n34XOQ6/ 19KlDEcg1p2mpAIIrhQ8Z4ORXJPD8r5oHbQxbS5J7HGnHpUbCup1Pw6JyZ9KBcEZMI6j6VzDgqSr AhgcEHtWd0z0YyTWhXYE9KZnualb3qAnJpGiH7qtRqxi3E8VRzg1prGfKCkf6xTtyMYYdvxrNztK xqoXi2SQShGBIbHpV8SrKOEfHsprNX7OVUjzQccnPSrMBCHENzMv5UpSluEacFoPkGASEf8AFTVV 8c9fyq5Ity/P26T8hVRobkk5u2P1UVKrSW6KeGg9mVW25ph4JxmpXgnJ/wCPrv8A3KaYbkdLkf8A fH/161Va5k8MlsyJ40kA3pu9iM0VN5d1j/XJ/wB80U+Ynk8z/9k /9j/4AAQSkZJRgABAQEBXgFeAAD/4TueRXhpZgAATU0AKgAAAAgACwEOAAIAAAAgAAAIngEPAAIA AAAFAAAIvgEQAAIAAAAJAAAIxAESAAMAAAABAAEAAAEyAAIAAAAUAAAIzgITAAMAAAABAAIAAIdp AAQAAAABAAAI4pybAAEAAABAAAA6+pyfAAEAAABAAAA7OsSlAAcAAAAcAAA7euocAAcAAAgMAAAA kgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAACAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAAU09OWQAARFNDLVc4 MzAAADIwMTg6MDM6MDggMTc6MTY6NDcAACKCmgAFAAAAAQAAEoyCnQAFAAAAAQAAEpSIIgADAAAA AQACAACIJwADAAAAAQGQAACQAAAHAAAABDAyMzCQAwACAAAAFAAAEpyQBAACAAAAFAAAErCRAQAH AAAABAECAwCRAgAFAAAAAQAAEsSSBAAFAAAAAQAAEsySBQAFAAAAAQAAEtSSBwADAAAAAQAFAACS CAADAAAAAQAAAACSCQADAAAAAQAfAACSCgAFAAAAAQAAEtySfAAHAAAoAAAAEuSSkQACAAAAAzAw AACSkgACAAAAAzAwAACgAAAHAAAABDAxMDCgAQADAAAAAQABAACgAgAEAAAAAQAAFCCgAwAEAAAA AQAADxigBQAEAAAAAQAAOuSjAAAHAAAAAQMAAACjAQAHAAAAAQEAAACkAQADAAAAAQAAAACkAgAD AAAAAQAAAACkAwADAAAAAQAAAACkBgADAAAAAQAAAACkCAADAAAAAQAAAACkCQADAAAAAQAAAACk CgADAAAAAQAAAADqHAAHAAAIDAAACoDqHQAJAAAAAQAAEGwAAAAAHOoAAAAIAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKAAABLAAA ACEAAAAKMjAxODowMzowOCAxNzoxNjo0NwAyMDE4OjAzOjA4IDE3OjE2OjQ3AAAAAAQAAAABAAAA AAAAAAoAAANyAAABAAAAAcIAAABkU09OWSBEU0MgAAAAACggAAAHAAAAAQAAAAAgCgAEAAAAAQAA AAAwAAAHAAABSAAABMawIAACAAAACQAABg6UAAAHAAAAmAAABhiUAQAHAAALEAAABrCUAgAHAAAB hAAAEcCUAwAHAAABkAAAE0SUBAAHAAABqAAAFNSUBQAHAAAF2AAAFnyUBgAHAAAAEAAAHFSUBwAH AAAAQAAAHGSUCAAHAAACvAAAHKSUCQAHAAACWAAAH2CUCgAHAAAAqAAAIbiUCwAHAAABkAAAImCU DAAHAAAAQAAAI/CUDQAHAAAAyAAAJDCUDgAHAAAAEAAAJPiwQAADAAAAAQAAAACwQQADAAAAAQAG AACwQgADAAAAAQAEAACwQwADAAAAAQABAACwRAADAAAAAQABAACwRQADAAAAAQAAAACwRgADAAAA AQAAAACwRwADAAAAAQAAAACwSAAIAAAAAQAAAACwSQADAAAAAQAAAACwSgADAAAAAQAAAACwSwAD AAAAAQACAACwTAAFAAAAAQAAJQiwTQADAAAAAQAAAACwTgADAAAAAQAAAACwTwADAAAAAQABAACw UAADAAAAAQAAAACwUQADAAAAAQAAAACwUgADAAAAAQABAACwUwADAAAAAQAAAACwVAADAAAAAQAA AABNTQBeAQIyMDE4OjAzOjA4IDE3OjE2OjQ3ABQgDxgAAAIIAAAAAAAAAAAAAAAAAAAAAAAJVEht MjExMDAwMDAwMDAwAAAAAAA+lPoBAAAAAAAAAAAAAAAAAAAAAAAJAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAU3RhbmRhcmQAANEB AQAAAAAAAQABcGmIlQD/Ef8R/xH/Ef8R/xH/Ef8RAAALPQAAlF4AAAt/AAALoQAAAAAAAAAAAAAA AAAAAAAATLtVAEwvfQBMf/4ATAjQAAAAAAAAAAAAAAAAAAAAAABFAJEAAAAEAAgAGwAAAAAAEAAA AAEAACCVioEAAAAAAAAAAAAAAAAglYqBABsAAQAIAAAwHgAAfAAAQJLLuyX/o32A590A8LuLko2I TgB2AACVAAAAzQWKwY8HAAh9AH1KAQQAAJUA4VwAAAE0CO/jkwjEWi5KQQ7NKhYI2KH2DgI2lcQ/ B4ERQYeG0676PMk8PwfEDs8yq0CGWsQA/////0BFw6gAMAVwAn6SXKx0m6G87BslG1n+AH2D+Q52 BVuXxK59FX1EfUR9FX2Dw0aVfUX2Q6Q8XONglRtzBJWoJIrQeTQAP5U8dn08gcdCIPbpqQDhB2kA vg5pxBJm40BOgYqKSkBp50qHSkIHCH1dAHFpxDzYSjz/////////////////////dkoUaSQBAcQ9 6io+u4GPXcLCTn9iYmJ/TsLCwsJOf2JiYn9OwsLCTmJPRe5FT2JOwk5iRc9Uk1TPRWJOf2XP0MOD w5PP9n9iRUsnX4xfJzhFYmJFOFcx6DFXOEVif/Z0U0EnQVN09n/Cf0/uE0sT7k9/wthpG7sIardR JGBWuhdHs4f9t46R33UHcBW2s4g8u8a7mRpFGkbTpexNOd1gXgSuMC/qkLYGMCySdwKX7IeIEQxf 1yUOTbbwcAmIQoi/BbeI1IF82B0gE4GfvhiKZiAZih/NQeeI6qtR0igPapIwK75xvsZe8ufh6pG2 8CithxjTd4eo73mKTGlMMPa+P9e6MOOITCDwlXlMBAePBDZpXb5P19DXVSCcaQHqobt/UX1RzM14 zflWHWz1MF62/orO5yKK45IpgYUIkwhXCMobTn05fS1APxvDQMwIvAHJAfQIUAj5fZNAqQgMCA0I AAFZCB4IxAELAcAb9gF9CJYIdQjuCOcB2gG7CEZA7BubQMgbpAEvAfYB5gisCIlAk0C7fZUIKAgf CDcIQghICLwBLhvMQPwBDQh2CE0Iygi1CFsBRAhQGw0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABwimktBctwaIEC DJ4wcIjpgVhwuef5VgkF1ohpDHiK280+tqKKEM026lKKiQQsiLi7Y9ipcKMECoor6k9Wqg7Fthwa WdcKvjsgrV6iBH9pLlEcxWTgKJLu15nNtoi6u3Ns8WrhOfsgaDDL1xsEE7bTMDWSl2ynoPLNSAUc tscaig67uxldJz00QJl6jU8ArzwIgQDEaRuPcEB9TrZGXlQ4B+reAUBROD9KcMftdn9VsHS3lclp 4eQBAMQItThdCAFFfeob3Q5e7F6HG7UbA33c2BN9oX1sfSFethv1G+9AxkDGDst94ht4fXV9tX1s QHnYrEBA2NLqmQj02Lsbq30dQAJAsxuwDheBvQSH2DUOVhs9fVIE+jAOu5TsPQTGfehAUA4+ze+2 1L75DC9WMF6RfYEIJl5ABLAFQWnzMB9epxsPGyEAOwCjAbsBRQH7CNMBwAHdAfIAiQAdAM4A/wGO CAEBggA7AawA1QA1ACEADQCFAE0BbgAyANkA8gDJAEIAuABfACIBfgF7ARYBYgB7AFoASADyAdMB GQHhAUMAnQCbAecBBQEBACwAqwHbAaMA1gD6Ac0BMAD8AHgAyAFwAUqgNmwsXaRqti/WL6hREi8n L1bT+lHxu4UHFS+xXUVq4WpHXS5qjFxaXeXTmaBGu7ErvgdSXZVdLi/sak05qNOzxTJ5flyGeVpR o9MLL5pqMdOvXfmV8tPh71+OFyvVAihdbS95atOgkLvdoFpRYi+vag0HV1yuvrfXUNNi05NRli+R 083sfiDTirmKj4pWigYwI12uanhRC9MyKP0gCnDjiipwG7bMiIJd0S+dUZHT8yisgcgg9ZIoiM62 zojakrGS9tPxUdoaIS/IKCwoRLu7DGsMy5KmDO4Mfgw9JEoa/JWlDNDXMNckkgS78YF+kuQMLWoH 4mSSZQyiu5SSuCgikgzXU+xUkiC7GyjSKLIMLbumbIaSpJImKPfTWiioDM+SGJIpoB67kJJqKKDs pQfIL+zswygsiEi7M1wuAqSsaqDF7ItRSShLKPKgYaw53FjjLuOQ3JtH29eaDOMoJCgOakFH4k6f loWWb5aYdc67AShAKJMoroeFOQusIYfNuu91n5E6XGEaXmxtDCkBYABkGxUb/dgoQMVAcEANQGVA 1xtyCOYIggB6QHYOIF5vfa592V4rfQJAuwDjGwNA4huafS99kRtsfdHYrwiL2JgBQwiqQLob2EBR AJtA70DaAFQAMRsI2M7Ydw5iCIUIPAEoAXoBrRvkADYBmwj9BF4BigC1CH8bKQG3CEEAPBuGCJAA P0CPDuvntQSH51F99n3/fQ4bYhvhAAZA/+dmBIEEgQ5RfQsI6RubG80boAFPAU0IEBuw2AbYvkA6 AGgB+AFnG6cAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOsw6zAAAAAAAAAAAAAA6zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABpLIEDUeJduwKiR2pgyOJ6AhO6knVl tvCIYr6gKNiV2uIH4lY5tC87xf4CnOqcaaVwaIjmgUXs38V4bLWBWyix7P3qeLY4tuuII4iKaXPX 05KItpi+ELvlMH+2FIikioQFYc3baUjswGykUWoMFzD+vmnN9834in1piLv9L+Mv1AcGTMtwnGk+ MMO+K9cAvugw8YHzUe4Ho8VD6g+2Db70gZy7I75wacFwprtIlafT4c3xBaZwZwyS1wuIjXBUzeO2 +pIyDOgAAAAAABoAlgAhACEA0QHZQK5Adtiw57wEX+e6VkUFWgWJ7OrsiWlBcHLqMc14iFowNQgH APcAAwC+ABoAAAAAAABKAAAAAAD/xG1GAABtRgAAAPYAAAAAACcA9gAnAAAAAAAAAAAAAAAnAPYA JwBdAD8AAAAAAPYAAABdIJWKgQAAALAADC8yAAAAAACHBavq3rsEXAAo1hsBANsA2xslQEP+ABsl G1n+AOd6CB4AAABb+zX+AP4AAAAAbwAAAHMAAH0gAAAHxwAAG24AAA5QAAADrQijAAABAAEAAAAA AOfdGyV9Uv/WGyXYKv/WAAAAAZXmAAwAAAC7AIAAAIN15n0AAAAAAAAAAAAAAAAAsAAAALAAAC1+ qgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIowHiACgAANPTP+xYwq4AGwEAz76bCBkAAFwAu1rq kSQAAAAAAAAAAAAAAAAAAABJOf0AQEPT3AAASlwOJzpcBBAAKJ60OtPu6kAASsgAQAAAAAAACBsl GyVAQ0CQ/gD+AAAAAAgAAQAWAAAv0AAA1/UAAfz8AAAbJX1L/OQbJX04/OQbJX1w/K0AACdRfz/F ES+VtIHFhwgFDg6hUQCB8Xn4l//////y13532xF5AK8AOtiGhscvEYE0QkkAEQT2l9ddU1YnIBCz 5xtuSgQiEUCX9koESg3hhzrazBFCQEAIlUUE9t2WlrH29zwBlQjCcMKVw5gAOszOzb5pDuYpCDq2 AL7Yphsp7gAKAF0AcBu/RgHpAMcOrRbDQMVmzsdRSwh2AbG2yV0oxLoIDjjhfhTgzJVKAMX3486V UT5K2ACkxZJcwu4HOg4nCL5WBQAAAAAAAGzqdgAAAChwfXBLcEtwOHA4ACjn3epyAAAAAAAAAABw 2YqU/wAAAAAAAAgAAAAAAGlTAADYAQAAAQAIAF0AAAAA/wAAAAAAlQAAAMwA/1EBR4ZdAAD+GwAA AAAAXgAAAAAAAEU/AAAAAAAAAAABAAAAABsAAAAAAAAAAAAAAAAAAFwBAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB0cDFwknDC cBhw43A5cExw23AAiv8A7AAAAOcAAAAA2AAAAAAAAHpplIpbU1JUU1tSW1MAaQCKAIoAaQDqAIoA aQDqAIoAxhGXEcYRxhFoEcYRxhFoEcYRADDn7QBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAADQACAAAzWkIAAAAAAAMAb2CEVuzTygBAf/+AAAAAAAAAAAAAAAAAAAAAAAAlv8uAAAA AAAAAAAAAQCgR5BHo0e9R0jNAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABt320XbTRe cEq3Si9Kt+dwn6yf6p+szXDaudqG2rnNcJ+In4ifYopw2obac9qGvnCfYp+6n09WcNq92r3acQxw n8SfxJ92iiTacdpxnxoEJJ92n3afegRGn0yfTJ8k50afep+qn2NeRp/vn++fVA5Gn6qfH5+q6iSf VJ9UnwpWJJ8fnx9KAC8kn4CfgEoADCRKAEoASgBeJEoASgBKAA4kSgBKAEoADiRKAEoASgBeJEoA SgBKAOdgSgBKAEoA2CRKAEoASgAEYEoASgBKAF4kAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAA0DgEBAQgAAAAAAAAAtgCUAAAAAABtAACI8xKVlRuWXXxtAAAAAEASAAC+AEovRwht AAeS3Qi7lgCA4wBVzAHhAAAO4wVKCPbn3QhJAAAAACBCACFFoRszcJXC7EA8SkuWfjpKqA724QiB lQBAAA6raQAkQFHTGuKJABsb7DSWSigoAT0AuILDtkbkgzyIxA44tlW9rgAAcMQIB1LX4cSWIJXp F+NAu0+WSvY9TxAAAB9LSUAvDsfyxNjEAfZdQC9TAMdwdToxllynQEBJG4cAYpYIxEcBVNtAAOE8 +DoOxJVRAAq2ARrj6Q7OgSkozEoansTEKYEA4WJKxAHuhsJKJ4WW17MnL0u2VlW708TjQAGVaUrT 092rvmDwSr72CMlOJwgeztNJOM4bBwBRXQChQOfTSgBL8OFD0T8BfUoodYGubtAA8iCCgSBmOGq2 wlSVgclAQADE51sBj55woeFLcKpYAGzjBwjEk5mVB2R4ol0gNMEgCFFuGrYOhjgOP8SSrMc+aQS2 HpF5vnmnQAj2xA4+VDZJJgEw3AiGzCcxlUGVDkMBCA4HAFg8SgEHOhauL85JgncZfc06OgjHQARw trwDzCmB0wQB2wGBSl1RP7eBrkCV5lFwANM/KIcx+iQ6L1HHUTpCx4aSx7FKOBXFBQAk9iB2x+fi 08Xqx4fnJA4UXg4IhQIbkcWVlhRWAd2RDggkSgTlSmYz6joJsuoOStAIfUtOIA6qAUVRlgkOiLPh IAFYB2IFZkUYaRkAfSpAldOLB0DF4QAI6W5LhtduABsDwAFwRlgIlZbncLy2AHHYzWA/ME8OCAAI 46xRBzDuPZJpWIHqxGuKLcQkAI/dAQBMOs2BBUo6QAbCQHAySc1MQPbidmk0Sc0CMRHbxNN2gT92 6krCgX7E3JbEiHJwn0BAlccAXczBFF9peOqtKepAikxrnhtPQIAnBCxJGmGFcErjCj8IEGx9AAyT GueJ9kI4fYHltvw+S+oolXkBP0l0gbY0XfaBda7sP8nJ41QRnj4wSuQ/xRRwThvjAQCkCDY4zgjh JwA6zLOVfQABygQv2Urj7KAI3TBKAeHNcGrnscIOf+IOqTA8OFh0qMLpwvo/TzxqxECBAZYAMOx5 uyuVj0ZKG0tlcMLe2LrjDjTCSg7Fzz/ElQAnSdu9S9jZTpUkUrcADgCBXTxAgRsH9uGIVAHTgd0b KX32EAFeEAFAPcRwXi9SBy2ywoY/VA4A4744IDy+d6IBR2cBEUkARoHy9kBJx6oBvn/P5+JwwEvE Dg6u8wB1cjFK9gkQQAEAAbY7AAjM4twUbKbTNhXzXspKEcSysj84KJWVC7ZBP7PQDqw9U1A4xEpN GVIOBMcADmJLGQDYlczhxFMBQJVpTgHeCKipGb9ujtzE58QAfgA7qsjyAMQOzEpd7udAMHAAGycA QDoDSr7AABLiJyBYOoNzwKyHwpJOGwEQXdO2SszFCEcAOyi2DlQn7g7ERwETiBV/JFbsVIEA53k4 2AFLlbYIknAI2JWzAsQA4MR9hZU4674vOeFPSsI3sW5Ad7Y/laAe0FHTfSDn5V3u9uezHwABS3gS 1eNVJLrYAtg8LAEODgjJ8A4vAEwbtqVBSsgAWABA4wjcxKpSAEDEU03MkUYAeTjE6gQblu+851Eg WAcZUuNKPwjEGz6VXJUA32LTCNPnB83ELwAASgDh2EeVcABFQDeW7sQAQFQA7lF9kes9dSSlrqJp eicAnfIkDsRAPuMkfT5RJJXj2ECUUVQZkvcZYpMg6MRHN/YqZGqVxFEFv/CBQARAWkoAGokBuxA8 DoEBAAHCWMc4tocE3DizQADEMgECQIoEUkDMQMI0x0okZiCI3QA9Vk5cTn3E08yVVU7ijwDCDrIB QN0AAcLrCAZNXVbEDgBRspVAKJABAABHtpXXuilTAEmWxNi2AEqkngiWrEqslswOgjyWvre+AEov Rwg64cWx3Wm7lvaA4wAGzAHhiEAO4+pKG8QEAM32SrU4XRoI55UkACBwtgBA7EB2AEuWOjpKqA72 4QiBlQBAAA6raQAkQKXTGuKJABsb7DSWzCAoAT0AuILDtkbkgzyIxA44tlW9BzgAcMQIBzjX4cSW IJXpjeNAMjKWSvY947wAAB9LSUAvDsfyxF7EAfZqADlTQMckdToxUlynQEA9G4cAYpYIxAcBVNtA AOE8qK4OxJVRAAq2ARpL6Q7KgSkozEoanjjEKYEA4WI/xAHuhsJKJ7SW18EnL0u2VlW788TjQLaV hkrT092rvh3wzNfQCBlOJwhQzghJOM5eBwABFAChQOcvSgBL8OFD0UoBfUoodbuubtAA8iCwgSA+ OGq2wiCVgXxAwgDE51vjj55w4eHycKpYAGzjBwg0W5mVlWRYol09NMEgCFhuGrYOHlTnP8SSrMc+ aQS2HpF5vnmnQAj2xAc+VDZJJgEw3AiGzCcxeUGV0D4BCA4HQAgHzTnhqs22dhbg3ZUBOoEOGwi2 QHAPlarlXTdpdEpdTEwAXk3M0JZLB7aBIGlHVEEAXbzFPJ4vDmVKYX7EDrsAlqhnF1RW1bbQ1c4O IFOkAT1LBLLbx1RyXWkAKefCTo+VcDuBu8RRxGHhwgBweCBpd0SkPx7EugAAAD9gfVsbTVPCSg5w bsRcx8fNNIGFQE72TPIAgYtWhtchVpCBdVY/Bfhp1wXUadYFA2nDAEz+hvl4+xIAGv6X+XD7hAAA AAAAAAAAAIAFRDAyAC3NJr6SAJNMP6kACOBwAAUbSgDNCEowASQAAAAAAAH///////////////// /////////7wV79Opz+8y/////////////////////////////////////////////////////xVq TFZbRmDaf+23BdxIy8tEVe9wUy3gKv//////////B8BbueFlUcx/hlw3vNTFnTiRut1/ggJDTge6 CmKOh1l/Tyv/AAAAAAAAAAAAAMmjvm0AAAAAAAAAAAAAAAAAAAAAAAAAAFZsiLyHdVtbAfwhUwAA AAABi+ydVmwAlgDQG1fYcgAaBJbY5gQB/////+dJAAAAAAAAAAAAAAAAAAAAAAAAS2usoDgirIM4 yKzNOMisijjIrIo4IqyDJ73iiye94otLa6ygS2usoEtrrKBLa6ygS2usoEtrrKA4yKzNOCKsgzgi rIM4yKyKAP8A/wCwAJUA/wAAAAAAAAAAAAAAAAAAAAAAAERV73AABAAAAAAAAAAAAAAAAHWjAAA6 AwAAmCBLa6ygAAAAAAAAAAAAAAAAAAAAAAAAmCAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJgg S2tLa0trZQD/AHkA/wBwAP//AAD/AAAA/wABJQgAAE9LsawRS7GsEQC9AGwAvQgACADYSv0HAND/ zH1g/38AIP4SQPwBuQEAARYBuQEAARYblQAMAAC+banP7zLDS/B6OCKsg9T+hxQAAAAAqgAAAAAA AAAAAAAAAAAAAEAAAACVCEoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADpAAAAfQAAADoAaQB9AAA4 Iv+d/53//ABcACsAiADpAGo8dx+fJRRa9ykpxxQ0iFyyPpUBcMA9ZtMnoerng5ZwfcjPUV2VSiB5 toeBB8zBfsMEftu0WAHO4IHJzm9lniWAxXbmAEyVqShKXA4nrl0EEAAoniU60+7qQABKyH4aOhtl AVDM2MQA004H6MNqKcxMRwB8UeorXJUiJH+3q0D2AJlbqBtSAYYB2OYHrrrBDscWQJVA5scAGyhG h50H84CWXdJlVgIAACMAuz/Fx9ihS6SRR0C0CIc5QAoACAAAzL4ACNPM5wB9fySFyVxKShABKQGA 8gikZSBJH1bY08RYDkoHXA4kG8sidMdJOsc8flGVEUBKl5WFsikMXVEOTEovuD/2Q9YWR3UAfrsZ EuJKB8U1XcRDSZrEwWDY09gAzAF35+oAAJUJ9n0OxLqxDoC2lXAszMVHFn6EfZTQ5qLhaX2D00kk 5nmB04ckSflJyIB3INCSP+H2AcTHzgHgBMsAP5aWscc/lhKMe16ePLbH2BqIQAnbWA4iQNvTARsr CLbTzrEiJ6zAACVuDpYHeOd2RlW2zecglHBGwmA9B9OYS10OBAAZB1xNOhMAx8fYOsdJaQG7KgdM gdyHOpU5XMMIPcXdXd0HLxs4CLBv87r/CMa2SjC+3ZVK6pGVMQRYAeauB6bYcK6WaRQATzobBAA0 vfa1lTq/OfaVIMyDlimelvxpUT0nxtMjfx6HzapJ2AEw03AH2D9wBM4OPO7HQqqVBdz0CIE+fuMO 4yDEwl4AYj85NJU7KaEWGwg/BErHfVZ5rxovmQ7EenBdtAZJJIXpxAcA6sQBWE8gGt2etgVSKQAe lX3yAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQEAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADZSBKB2QAAAAAAAAAAAAAAAAAAAAA0 ABtHG1BAVxsPGxgInUD3fYbYWtgtfRlA9wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAANh92D4Oml6F2N19AF5n51RWZVZu59VeygAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGqnaqdqp2qnaqdqp3DZcKdwGHBM ig+KlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAUA s8Q8Bxtl0k5KDrRA5ZbCaYeWxJlsQNM8AgChcA5TzWp+b1YBmpoA01kIQCSWSmlJlfu2UbY6Eup7 NsJUq5LOADQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABxk/LwFxPEOeEQBYCACAaQAAAAoA AAAKAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAABAAIABwAAAAQwMTAwAAAAAAAAAAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAA IAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgAAAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAg ACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAAAFByaW50SU0AMDMwMAAAAAIAAgEA AAABAQEAAAD/4QvFaHR0cDovL25zLmFkb2JlLmNvbS94YXAvMS4wLwA8P3hwYWNrZXQgYmVnaW49 J++7vycgaWQ9J1c1TTBNcENlaGlIenJlU3pOVGN6a2M5ZCc/Pg0KPHg6eG1wbWV0YSB4bWxuczp4 PSJhZG9iZTpuczptZXRhLyI+PHJkZjpSREYgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8x OTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj48cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0idXVp ZDpmYWY1YmRkNS1iYTNkLTExZGEtYWQzMS1kMzNkNzUxODJmMWIiIHhtbG5zOnhtcD0iaHR0cDov L25zLmFkb2JlLmNvbS94YXAvMS4wLyI+PHhtcDpDcmVhdGVEYXRlPjIwMTgtMDMtMDhUMTc6MTY6 NDc8L3htcDpDcmVhdGVEYXRlPjwvcmRmOkRlc2NyaXB0aW9uPjxyZGY6RGVzY3JpcHRpb24gcmRm OmFib3V0PSJ1dWlkOmZhZjViZGQ1LWJhM2QtMTFkYS1hZDMxLWQzM2Q3NTE4MmYxYiIgeG1sbnM6 ZGM9Imh0dHA6Ly9wdXJsLm9yZy9kYy9lbGVtZW50cy8xLjEvIi8+PHJkZjpEZXNjcmlwdGlvbiBy ZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxu czpkYz0iaHR0cDovL3B1cmwub3JnL2RjL2VsZW1lbnRzLzEuMS8iPjxkYzp0aXRsZT48cmRmOkFs dCB4bWxuczpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMi PjxyZGY6bGkgeG1sOmxhbmc9IngtZGVmYXVsdCI+DQoJCQkJCTwvcmRmOmxpPjwvcmRmOkFsdD4N CgkJCTwvZGM6dGl0bGU+PGRjOmRlc2NyaXB0aW9uPjxyZGY6QWx0IHhtbG5zOnJkZj0iaHR0cDov L3d3dy53My5vcmcvMTk5OS8wMi8yMi1yZGYtc3ludGF4LW5zIyI+PHJkZjpsaSB4bWw6bGFuZz0i eC1kZWZhdWx0Ij4NCgkJCQkJPC9yZGY6bGk+PC9yZGY6QWx0Pg0KCQkJPC9kYzpkZXNjcmlwdGlv bj48L3JkZjpEZXNjcmlwdGlvbj48L3JkZjpSREY+PC94OnhtcG1ldGE+DQogICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg IAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgIDw/eHBhY2tldCBlbmQ9J3cn Pz7/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRofHh0aHBwgJC4nICIsIxwcKDcpLDAx NDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwhMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAARCAFCAcADASIAAhEBAxEB/8QAHwAAAQUBAQEB AQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1Fh ByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZ WmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXG x8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAEC AwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHB CSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX 2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDz3xCpje2nB5BxmuekLrfh4vvB9wxU 11eTzKolz1yM1t+FI7S51FluYUkOARuHp1pX1uKK0sytKRJJHLsADLwMdPWnxA7sjtXrf/CMaTLa MqWcIBXKnbyM15m0H2a8mt5FG6Nyp4r3MBiIzjyLoeZiqUo6sv2bb4SozyKmjjR428z7p4H1qvaH ZLgdOtWJYx5hBB2g5GDXrv3onk/DIzFjlsTJGys9mSGJXrEf7wrbsb6/n3WchhlXYXR8EF06kjnH HPFREeYvlt0IxWc0ZsJPImZhbMd0UqnmFj3Ht618fjKPs67t0PqcPNToxfdGt9nXnNxEM+9ILeJS CbyAY/2hU2mtEymK4RPtEYyTjO8dmB7g1dEaOrOEUKvqK6HmuIcbNmCy6gndIbqohvDFcrNEu+MK +D3AAyfrT9AtJpr6G0hMbLI2VLHAJ9e/Sqg+zG6iIIEkjGNcc8gZ/Cn6kskywfZdQks5YpAryx9Q P0rl+sznT9k3dHSsPCM/aW1K3iS2l0jxBNDMFWbqxByCfWtC28OTa94cu9SguY98EgjKFcsNoBBz n2qv408J3dj9ivLjWbjUI7yMHzpuSCR35NbPwuQ2jX2jytvF7AZU7Auh+YflWrcnTVuhNlzMx9EV 4tiuuNrlR7iuhBrLMRtdTltz/BJkcdjWkOtebiV+8b7nTS+BIZJHlgw61GEV4pI3UMpyGUjgg1YP UUwLy+PWuZrqao801bSZfDesJNBn7HK3yH09VNdXoOsJKm3dlG+VhWrqNnBf2EtvcgeUynn+6fWv NtLuTZX0ibyQp28dD6GuujPmVmYzjZ3PToH+zXnlE/u5DlfrWkfumuTXUfPtozn5o+hrqY5BJAHH RlBqKkbMqDuhn/LJf98Vez8vTpVH/liP94Vc7VkURkcn6VWKE27j3q13P0qMjEDfWmBkXenlmiXG QWDflz/hTW0+9P3JGUegFbXDXQH9xB+v/wCqrBqXCEndoLvozChtHiz5jE8d60dPXbar7k0MMs30 qa0GLdPpVAS9qhn7Yqx2qvL94CgQjD9/EPQVYqDH+l/Ran70IbA96rxcy5qyeFNVojgufRaYBb8s 7epqfvUVuP3ZPqampAMfhCaxoiDM7Hpnmta4O2Bj7Vgu3lWF1L3CN/Kn0BK7OHvnMs5YnPmSZ/XN bHhiHdqgb+4hP9Kw5eZ0H1NdX4Riy1xL7hBUR3PQraUzpbr/AFUa+pFXYxtiUe1U5/muo09K0McV oecMxQ3CE07FRznERoAZbD5S5pYRlmalX5Lb606FcR59aBjqWlpKQiC56Kop5GyAD1qJzuuQPSpZ jkqntSGOiGEHvU46VGOOKf0FAhc1Tu2ywWrnaqBPmXX05oYHhd3axKiuoPB7mrGk6iNNvROYBMQp CqWxg+tRzNE0T7iwK9sVTUF5FVBkk4Fdy7MwPcPB2uDXNJMahYrwbkAxkA9VxnPuPxrh/ETTf20Z Zdu5jhsKFz+VbPgXQtQsLoSyXdrCHwQpkyQRyDW54w8NWt5PcXUV7ELggusKcgnriujA1VSrJvYx xUOenZHGRlSEcdjz9K0Aqny2b7vQ4rKgP7nBPOK0rZvMtyM9gfyr6yGqPmqmjAMCSdpUKcDPepfK SRkEo3Rv8p+hqN/lj3HoenvWdLrK2ymEwuWQ8E9CO1eNmeGbnzxWh7OXV1KnyPdEs0Umm3QtpJCI 0Yi3n/uH+6f9k1eE9xcQSRxkJMn342/z0IqF9US+0drm4sp/LyI2ZQCN2PrntWJp2rCe58lXaOeM 4iaTjcP7rV4jpTjrbQ9RTT0ub2macsE/mtGC3PVicfnWg8d28Lgxg7FJDqvPHc1jDX5TO0X2Ty3X g7pD/LFPv73U4IQHVYd3pkMPrzVUqcqklGG7JnUUI80j0l0Hib4ZwmUF5LfKklufXtUvhI2R0bTt Qs1Ik06f7PPuUBtpwDn8Cv61nfC25+16JqWnyPksvmDJ6kdf60eDJPsPizVdGmyIbyMuuem5euPw J/KtJU3Hmi90Qp3s1szI+JFtcWGrySRMyHBKspI6VwCeIdShV1jupfm/vHP5E17P8SbH7Tpttcgb nC4fHqOD/KvDthRpUI+4eKmcIypqXyCEmptGnaa9qLMC145bPKseK6/Qr6a58yOdgzDDBvUV5rDH MJVbb+73Ak+ldTYaolg5mG4qFPbr6VxVILodMX3NLxHqEktzHo9iczz/AHyP4BXGanaR2msvDASV QBSfU45P51p6RfSefd3bjE8zYMx52j0AqhIha7eUnPViTTppxYpu6LlpdFcL6ivRdPydMgJ6+WP5 V5hpyPd6jHAnV2Ar1T5YLYAfdVQo/lSryS1Y6auOOPJ/EVa7Vneedu0jvnIq19qjPGcV58cZRk9J GzpyRLjrUTcQt9af5qtnDA1FI4WB2J4B5NdMZxktGQ00Og5klfPVsfkMVYPQ/Sq9pzboe7fMfxqy e9UIqYJ8z6VPBxCn0qIfclPtU0XEK/SkPoPqCTmUCp6gPM4+tMQq83T+wqaoEP7+Q1LmgAkOI257 VXU4ikP4VLKf3ZqFyBbH3NAE8HEK08nio04jUe1PoArXrbbZvfisDVW8vQZv9shR+JFbOpNiIKO9 c74kk8vSbePu75/IH/Gh7F0leaORBzdH/ZFd34Th26dv/vyFv6VwUZ+eRvevSNCjEOl26+kYJ/Hn +tKJ1Yp+6kXU+e/PtWhWBHq0EF7IJVYKTw45Fa8F7bXP+qmR/YHn8qfMnscbTRYqvcnO1fU1YFVZ TuuVHpTEST8RqtSqMIB7VDJ80yrU/amAHpTegzTj2qKY4iJoEQQfPMzelSZ3zk9qjg4jZvWpIRwW /CkMsLTvamClosIbK22NjVe2HDOR7CnXT/KF9TT1GyFV/OkwPGJ7aMuy44kXj61ggAOoYcA4Irem VwTET8yjcprAZv33P96vQRyo6rRfEA0u4SKZDLBtATAAK/412d94ps/7J+1RWJlikJQgsAQfevNZ YN8SyIMbOtdJ4W8q8ml0u5wYLlPlJ/hcdCK6aMIyjz9tyZS15X12K1vc9dq4U9vStPT5vm29s/p0 rI8h7S6ktZRiSJipH0q5bNslGfWvqaLTSsfN4iLTZfnDLJ5TscIxwM8ZqpcQrI2cDNal4FCwXDLu WSPHB/iHH+BrOVyR8wwa6VZ9DkTad7ktrfRwaPeadLEzCYh0YEcMKwLzTw58+PIlX071syovUDrV aQ7EY45UZrjnhqaUm9md0MTUcopdCGyuP7RjEbsI7+PhHJx5o/un39DVqXVHlgFrduA6cAlCDx68 08+H9nhu41Sd9s4kAjVe/cmqEFxHq8IinbyrxeElJwJMdj7+hr46FblqudLoz7OrglCnFVtpHYeA tYs9B16JryfbFPwJNx2KD1zXTXOo2mi+JRefa4hasSwdWJWT0x2NeTahdwoi2zReVJHHt3Pxlu+K z4L+4hj8kyM9tnPlscge49K644Z4he2m9zhqSjRfs6eqR9Na7Gl/4Xmkj+dVG9SO6sP/ANR/GvA7 u2/euwHGckEenWu30Dx3nw3/AGPeyCEi3CxTjkOo52n3x0PsK5F2iJkMcjPHuOC3GRWVKDcJxttq Z1HacWyGApFbzKYlPlyZJ/2T0qO/vEbTwiADJ5qmt3suXh3DbIu0k+o6f0rodA8DajqyCa/zZ2nU bh87/QdvxrkaW50JsxYZFisUGQDzmsy4u/MbyolJZjjAHJNeh+JtJ8N2OkDT1fypwQyyL80h9c+1 UNBh8O6eyyRyZm/vyjJ/wFTKrGJSpTauTeFPD7WEIvbsAXEg+Vf7g/xrorhBLbSJnGRwfQ9qrrqt gYwDdRgjtuqfzIZoC0MispHUGudvnepoo8pnwXCyOY3OyZfvJ/Ue1TbvmNUJoRPuEqhtp+U9x9D2 oW1uY/uTyDjo3zD/AB/WvJq5Y2702bxr/wAxoqx25rP1OaZbdIUkbM0qxjHoTz+maje61CAENAkq juuVP9aovqqSajZNPDLDHGzMxYZG7GB0+tZ0cLiKMua2g5VISVjrYLgoANvygYq0syODg8+hrLhn inTfFIrqehU5qUMRjjOazhmFWDtPUqVKL2LR/wBRJU6cRr9Koh32Mqnr61bSUOmBwRwRXq0MVTrP 3dzCVNx3Jc1AP9d9KlGcVCP9Ya6TMIuWkPvUmahg+4x9TUtCBjJvuY96jl/1KD1NOnPApsh5iWmB YHAFLSZwKAcmgDN1FsuFrmPFkmHtYv7qFvz/AP1V0t2d94B71xviybdqbqP4EA/TP9aUtjfDq8zF gXcgA/iP8zXoIujBYvjjaoVa4bT4911bKf7w/Tn+ldVcP+6SP1yxqZS5YORrXXNUUSiZ1C7nYDn1 qRSJOQefY9Kh8hJisWRuLjdz3rSGjOoBUflWFKjzxvezJq1eSVrCw6je233Jyy/3X+YVag14CUPc x49Shz+lZs9rcW0Zbqo9aqR3SunzxEY6kc1fJWh5kKVKXkdla6hbXM5KzLnsDwa0Qa4WJI5huU5F Wo7y6tQPJuGA/uscj9aSxCvaQOg90dgfaq10x2hR1NY8PiNxgXEIP+0h/oasLqlrczriUL6B+K3j Ui9mZOEo7mgflhA9akjGEH51HIQxVQcj2qYdMiqJHClzSdqRjgZpiKz/ALy5A7Cp3POBUFuNzu59 alHMn61IHlUtoQ6Z54wDjrXK3sRt9QkT0bIrvmQvAV43R8j6VyniWEJeRzD/AJaJmu2MtTnsacUS LHDNgGKVcN7HvVSznawv1liOTE+V9xWlo9xH/ZckUiBhLFuXP8LD/wCtn8qxmE6svmRBUOQrDvXV g5Wq8r2ehlX+HmW6Oq1+JbrytZtlOxyEmH91scE/UfyrOHBDdjWvp9/A+lRGYbrd1+y3ijqv9x/8 +lZWzyJZLdm3bGIDDvXuYCo0nSlujzsxpRdqsNn+Zrxn7RpLphd0TCQHvg8EfyqlJH5e35lJZd2A elS6fINxjzwwKmh4zvI28jg17EWeE1Yrk8dahmG6JlA6g1MwOcUzBpVIqSsVTnyyTNnwvdJrWmto px52x9gY8FsVyj6cyxupUh4mwR+oIqORhpmpLdCaSPB3Dyxzmr76jDqcbzFDGVIYMD0bvn618O19 Sryi1c/SHUjmeDi07NFMtDqcP2O+IEoGIpj39AT/AFrnrm3vNMuPJYtjPymtqYSXbyTLGFQH5VA6 ipEmjurf7NdkEdEkPUexrdXgva0tn+B4zTvyVNyCS4Q2ChJF3Im0ncODVca1cxuUm2yIVweOT71V ufDt8rSm3QyrGMlVPOPXHesoTypJiQFiOCr1EqraXLoLkV/ePa/Cb+ErPTjqjzpJdRqGkM4wYj7D +orP1v4kXGoO8GlK0MI/5asMM30HauO0B4S8ZRgSIm830yScA/hWlcadBIRJABE7Dp/Cf8K4JVFG VmejDCVJ01UiUru9W58t3c+YWwcnqareYVY4fpXZ2vhC2udBlQusl3Iu5JFOQjDoB/Ws3yLO78Nt dPCI7mBTHIAP4xxWbUZaomNSpD3TAW8ZON355q7Z3lwZgsbsmQTkHj9KymimQLmJsv8AcyOtbMmh y6RbwSSSYkuQVY9lPXFTyKxq68uqFi8RXUeVE5PPIb/69atv4tvVyXSNseorGm0mZIPPi+YdSjc5 pM6nHBHKbXdDn5iVBIH0PNJ0/MSqwa1idQnjIEYktl/A1X/ti3n1SKdgFhUcr3zmslW05I5vteFd W4AJGR+Aq1BoSX8mLSZtuEbLDswyKHGS6i5qMu6OikvtFuJTIheGQ/8ALSL5Sfr2P41Il6wBMc8d 3Gv935JB+B4P4Viv4Mvo/wDVyBsVQn0TVLTJKMQO4Nc9XDRqfErlx5F8MjpW8SWagJEk8s5O0RrG Rz7k8CtuxgukQyXbJ5jnIROiD0z3+tecGW7twDtcN6+9WBrepIQWmn/Emoo4SnRd4rUcoSn1R6Yo qFf4j6Vwtt4tvouHkLgdQ4zV2LxivPmQ5z6HFdHMZuhNdDrYRiAH1NOxwK5+38X2HlKjpICO4wau w+I9LlIxcbT/ALSmmmiHCS3RfmHzLQy5ukHpVY6laTzKI7iIjI6MKnWVWujgg8etO6JsTvgcDtQO lLleSOaM4jNMRkn574n0NcDr0om1S5b1k2j8Diu8jcCWSQ9ACc15tcsZbguerMWpSOrCrVsv6Su6 /U/3VLf0/rWzJOAzHPAHNZOir++ndugULn/P4VrPGsksMA/5auAfp1NYVXzNQLbtKU2JbQvBHHO/ BkPmH867OIBlU+1YGpRgJGFHABWtqwk8y1hb1UVstJNI5ZaxTYahEptmBA54rn7iCC2t1XgyOM7f T61paxqA3fZ4CCwPzN2H/wBestbYyui5JLHkk9armb0iTypayKyQzyKUtxjPV8fypDBPbkCQsynr musjs0ijCooAAqnqVvvtXAHI5FHs4crVhqcua5zAlb5j5ZVQeDSJOkp+V1JHY8VuWsMc+lMWUbly uaoRaKdrPjrWaoU5JW0NHXmnrqRxXM9uQ0UrJz68Vp2/iOeMBZ41kX1Xg1Q/seeNNyMcelUsyRsU YAn1FRKnUpq6d0VGVOo7NHYQa9YzkAyeWfRxirc88Zt9yOCD3BrgfkZx865HbNWEdox8jEH2NJV2 viQ3QT+FnbQYW3B9ealiGcmuUh1y6hQI4WRR7YNa1pr9o6ASboj7jIrSNWMjGVOUTkI584OccYNc 94mQ+VEw6K3H0Naj5iuVIP7p+OvTPSqmr273GmyjOWiO4Y7ivQ0vc5Cvo0gk00AnBjbBp88sZsGU tllbIGKzNCYvJLb/AN5cge4rUl09pI/9FYksOjjGT3q1JxldCtdEuhzOl4SFV4WUiaJjjenf8e/4 V0HiDS47WCyv7Vw9vPHjcP7w45riEWRco4KupwRXX+Gr1Ly0l8P3jgRXHzWzsf8AVy9h9D0/Kvbi qiksRF6djiTpuDw8t3syrauVkBz1rRuWbLbGwJVG7FZbRSWtw9vKpWSNirA9jWqjqbdHddwQ8j1F e2qicOZangTpuM+V6FU8jnmkZRjINULG6ebULmLEpgBJQyrgirzj0oo1lVjzWsKtRdKVr3KGpQvJ B8kSyEdQazbGJ5JR55ART/q14Fb4z6VSvLFxIsturMzHlFHWvHzfBOcXVhue7kWOp06ipVvhLrrF IgSAcAUy28PW98HuJHwIjlo84BPvUFtcFMpt2nowI5Bqe8tzLaSRiRl8xcEqcV8vRxEqd49Gfb47 AwxEFKO62MldUtYb42qTkop+ST+6fTPcVl6hpZ82SVv4juDDnrVweFVZCY7ouV5Py4qxGXtIhBdq 5gY4DEcr+NdMKsYy8j5udOWz3MW0uTZfuwMLnkjvW1baoH5LcCs3U9Oktf30Z8yFhkMKZp8X21nU Bt6ISu09T2rGrCL1PRwuPlTShLY66w1WW2KyRSkEnp2NMuMyf2i6YC3WJNi9nGM4+vNc/AL2Oz+2 NEWtw20uvIU+/pV+2u/MKqDlie1c3K47HozhQxMeZaM3rPGq6RbxyjFzp8oPTrGSP5f1rotW0O31 KCAzsVMfzAA4J/nj8qxNAsXsGl1e+cW8Ryu2QjGD0LDr9Biti01W2up3Q3PnSn5vmXYuD6dz+lXG CjqzxKju7I4/xBdTxQzJZGeKK0GGfyR5bZI4DEkk1jaZrjGVRNOXZuPmPSuo8ZRSalp0NvGzPKJQ QqjCgYPb8qytF8PTWcySzI3HI2fKfzraM4WuzJxleyMm+FzcX/lQ2zlicAkYz9M4rbt9Ul0+KAxN ieNApx3A6A+veuiTTY57trsxBfKTIXO456c9B3zWYmlXsrXd9bhVSBgqtkduv+cVnUlzu0Sqa5dz e0nxil0Al1A6N/fRSR+VdBI8VxBuVgytXOQ3+LZDK2JMfMB61Xm1SUgiJtnozDislct2N/7BbkI5 jBO/0q62mWcijdAhz7VzcfiAtAiK0TSKckscAmug0vUlvoirYWaPh1HaqTZJTufDmnSqx8oA1zVz 4S+djEcLXcyn5TVZ8eS3rmnzDUpLZnInwTL5Ksk+SR3qtL4Uv4wQqhscjBr0CP7iD6UrH5j6UtH0 L9tUXU8rmsry0baySK3pmmw3d3GflWTI7rmvRpLaOeVi6g49adaWduqsPKXBPpS5Yle3l1szhE12 8jcZnm+hJOPzq0fFN2qYMu4dOVFdnLpFjKh3QLz7Vjar4bsBbEom1s8EUci6Maqxe8Tnm8RHyZYy mWdSoOcYzXPsf3o9hWpf6KbK0+0E5G7AyayEyXY/hSkrHXh+XlbijY0m6tI4JUklVJWfd8xxkYGK 1VaCcjEiN9GrNi8PvJHEwILugbB7Zq5B4ZjX/XKZCeP3SgY/EmsqlC75rmPto7F1VVFyGY47E8VZ s01GcG3svPdPRV4Gf9rtTrbS4LSLMULkD+Hdk/jTJpbpJd/kpFD6sPmP60o0mne5nKonoka0PhG7 O15ry2hf/nmcsR9auxeHpo5FLalart/2P/r1yd14jhjxF95v7sbZJ/Ksm61i8kzshSEHu53N+Vbx pySsjGUle7PR7trKwgMl3rcCgf3FDH8gTXHaj4ysUZ1tBcXQxjLKqiuTuHkkQmQmRs9W6D8OlUWD MOe9bwpd2Zup2NV/Et+XIhKQRk5KIM5+pNdrDrFqLOM7zuZQSvWvMvlA55PtXVabLE9lCd6BsYIy M1nif3cbxRpQXtJWZtT6pcXX7iAiId8feP8AhTrfRHlXMhOD2rOMUZbcOG9QamjubmEYW4lA7fNm uOOIjvI6ZUZfZNZ/D8IiOOMCuWEcsGoyAMTEDjFa7arqO0p9pBU8coKoF5FU52Nk5JI5rZ4inNWZ kqU4u6K09xN57IqYAIANV31gQzGHyUljTjdkgk9+abe3hRHc8OflXHrWGXyeTV0qUOW9ialSV7XN +3dZrNGbG6M7WB9KvAwkGNgCkowM9jXKR3ZQliSRv596sm8/dzxNJjy/miPrXa4XONSMvc2l62Sv GyT9K2tQ1d4TtiI8t8Opxz+BrG1aRLiaGbneUAk9/ep7K4EsSQsAwizgkc4NVYAa8+0z+a3Bbr9a uQgnBHXtVK5hWMsy5Ck5FOgu3C/LEGx6NXr4HF04Q5Jux5+KoSlLmgjpW1O1vrSaTVWuZNXLLHbC IABx0GeOTU2nSyuZLa6geCRSUZJBgg1zwvpimz7DFIpIzuGSPpXV6f4zRh5euWQlRflM4QM6Dtkd SPcEEep6VnRxv1as+XWD/rQurhFiaSU9Jd/8ysUKMR0Peq813DEMSSKCO2efyq7rujG9T+0dGuJb q0bllifeg+hGCP8AdYZ+tZUVvEFjh2gSZxtx1rrnnUX8EfvORZNOL9+X3ER1UM4jtoJJHJwBjGa7 vRLE2Fh9r1DYs5GcDog/xqnoukwWWbmZFBHOT2qfULz7dEVwyxg9CMZrzMTmNWorSdkd9DA06bul qc1rq77tr+3j2xv94dz71DZy+ZjJz6VqzAsoXYWHTAFYDg2d3t2lUblc14049UfU5di7fup/I1t3 kI6Y+R+Rjsaq/wBox6lbLYsreajHa2OD7VbhZZ4cH71VYpPsNwymJSrEHPcGik1sycywrT9rD5mc EmtpGhaIvCfvREcj3Fafh/TdNgvPtKMcu2UH8IP+NaVwYI7oyycBlyrHtmudaRrGd5EI2nllzw30 rR3a5WeRpubug7bPWNS0qTGwksoPQj/9R/SpdO0/R9HlkmjVi0j4ALZ2Z6AGsq2livtSg1KGb50A SRW7r0wfz61p+I/KjS1RArKJg7FfYdaS91lJtq0SnreoalePd6daxw21rE21l6mUnHf6GnLLbR2l qJmhjlhGN64yfy/rzXPaxrFxDqMgurXYZBvTcCCVPQ1n217aSXG65Mqp/sIGP6kVpyua1Jl7jsdw dYtpCAJlJ9qtQTTyZaJMgDqxwK4q01i1iuGZ4XkjVSI8nBz2JrqdKnkvrEahJIEhhlJlGM4QDIA9 ycD8an2L2Quc6jT4ZFjAkaPc6tIyhs8bG2f1P4isIW4gjMjyFd7FuWC55+tXdHuL+7uluJ2dIZC2 1CQqjKnAA64wB/k1of2TpMGnx3byCaY8tuIYe4HP+JrNwUZNMfM2jkJL5C6iKKSTB5IX/HFZl3PN LLsOcZ4Uda37u4Rp3ihOCvzEN1UVnxq9rGWmmU+YxbcW68kf0rehTdSXKkROSirtkdlDKkMimFgC vAIxmodM1+5026WVVO7bsYOM5APH9PyqT+0rFZSr3Me08EBualhurWae3soCJe+SoIC5961xWGdF LrcrDtVU3e1jsLHxDbalbA7Wjk9xwfoavOw+zg8cms2GG1jj+UbcdCT/AFqL+29Ngmlt5boB0XjP IVveuCV0rmsVzSsW77XBHEyaeYp7hRkgsMY/Pmrmn3r39ilxJEYZGHzRkglT+FeZzaVqpuWvLOJZ Ix8/nW8ikfTGf6V1PhW28SXM081jPb/aI/lkt7qPaD3xjqD+A61quSUVysJ0pwb5jqIVZ95VS2B2 FZFxrZhnFnaIr3BzueRtscY9Sf6VoNqWqWLbdb8KzRj+J7NjtI9yueK6bTtJ0PW7FNUtbJ0dl2xy SqC3HH8We4+vFTZohNdThY7K9u3D3F/cXSf3LeArET/vZwfzFJerc6YYrkPKkaHLxyiNkcDrkJkj 6mup1PTp7X95JKXAOOSc1zGsStJGIDgh1INRdX9415na0dCvrOs+F9cjCx3JjdyrMDKEVSARwD9f SoLCx0mI/uPIkbrvaQOf8K831SJol8thgoxRvqKyckdCfzrpdFSRgq0oqx7TPNCFwk6L6lRnH9Kg bUbK3jwbwvgegrx4E+p/OrNlcSW9ykiMeOD+NHsPMXtTvb3xBM7kWvm7f7zjaP1/wrGuLieb5rmZ 5PYHAqITPJ88hyT1J71IcEc85HAqlBRJcmxLa4ZsoqrGvoo6/jVqOPzJUiBHmMQACcdaQKklkWij RZo/mIB6j1qXw88J16xN3EskTyhXBHAB4yab20AvTaBcpZtOhSTaOVTk4rGlU3sbhU/eQgcKOoPo K+jzBpNrozqfKii8sjLNwMj3rw68i0q3uQ1qzSSRggsG+Uj8uahXW49Gc/b6BqE/zNCYl/2+v5Vq waJdmERxwsQOpNaa6rLFZxyO+QeixjJP1rY8P+Ira6E8d0BbsgBUn5g31x0Nbuj7WNotN9tSIV3S ldqy76HJnSr2I8QMMf3TUTG7h4JmBHXqa9Gkv7UophMcrO4G0dcd6kktLaTJaJefauSdBLSSsdkc VJ7anmJv5k4L/gwpr6nK5CbVOepAro9U0u2utS2RIAE61zOspFYytDGQWAwcVmsPB7FvEu1rGbeX PnSYB+VeBU2j2DalqEcAB25y59AKz+tegeGNM+xaeJZBiaYbj7DsK3doqyObfVnnyrlP+BUpX/WZ OM1ALuJcdTj9aia7BHCnrk11HOW9kbBdx7YPtVSJmgmYIwJHAPrVSW7d3+TK/SmAymTdk0AaErys m8uWTkYJOB7U2xuxa3Ucu7Ko2Sp7j0qMqbiHCthhztz1pq2cwK7k2g0gPT9XXTVht7qz2eXOgbAP Tiudwt1qCRw9SCGNUoo7yWJIgGMMYA4NdPo9hBHGskasWbqf8aXNqPl0K9vpd9pE7Xmn3phmI5VM gN+VdDYXFzqcIutSs7PzhjbPHCu8+vOAc+5JqzbWYnlCHnaMt9Kr+I7prK1W2txtaQYyP4RUySep pGpKKsSW/iOwLS2yWk0jxHDSlA6/lkD9KRLt57wpPb26xdQXtpF3D6xsf5Vk6Ha20MgjnkZppugH 0NbNlNDaT7rhA/OM56VztNvQ3VTTUbenTUidLW/gt5nx8s0nygg8YLBSv61h3Hh3W7mNiGt7mLGQ beUSY79q1dUWDVpJJF2LBCvzE9/auesoTDeM9sjR4GQRVP3QjOLd7CWYuLeXyp0ZXTrkcGtPUNPl MKs0LKSMrkV0Gn3Xm2Ms93b2kvljJ+by3I9cDg/lV6LWLS+Y+XPamSMFlVhuU/jn2rDkd7o9RZjz x5HG55lq32+aGK3utlsY1DIWJBkXJqjqqXNnaxwzGN/NXckgPArs9T0wa14kgj1uSRFJ2qEIA56A H0PrXD674O1aw1u4s4beWaBDuil7FO3J711waavc8jEUpU5WtuUtFaWL7fcLK5+zweaAp+8d6rz7 cmt+z1KDU4fkZUnHRW6E+1ZPhe1dtanspsRrPBJBKHONuRwcezYP4Vo6H4f8jULq11KFlmhxtXOO Oef8+tFWUdWyaXMmmjE1xb6S/M19lnbgN1GB71nIcGu+u7dreJorhPtFoP48fMo9/wDGudv9AMcY uLJ/OhbnaOoopzi46BV5nLmkZcWM13tqg07wdatM2xbm48xjtzhcELkfgT+VcbpNg9/qEdvnYM5k Y/wKOWJ+gzXczXMWq+FbyeEbY7e7SOJT2jChVq+pkT6bZpb6ja3TeIIrsM4xEGOQD3rldb1bUrXU p4DIwMblcA9Mdqt24tYUWYhY3U5BAAxWlqMWm3+oXE8Kxz78SFiMnJGSP5/lUcq5xt+6cM+pXcs2 9ncsRtJB6j0qvNNcToN7MwXgA10N3ZhN2xV29AAMYrOksHjXLjaB/e6/lW8J8juiGr6Mz4LSWZht wPcmuk0zS7+y1GB44GkI53ggAg96dpnhXVnKzzWz29sfm3zYUkdcqpwW/AVuTRXkF5G2nRrOFiwY ZjnaR0Ppn2qK1eU3Zs1hT5Vc6C1sblLZbm8kit4hzukcIGHtuIz+ANV9G0LwnI7395q6MqyHZA0v Q/TFcvYtd69LKly8nyJkkrgo3p796jutLutHka88zzLcKN/OCvPWubRSs2aqSUdEelrq+gWmUtop JEzllt4ggb/gTc/kaZB4pggvJngjtrJpMbWa3aRnH+0cnpzXD6fqCXAXDBg3ANb0Fut2Tv28Dj0H 0p8kY6iVafc7Sw1rUNTuo4Eu4ZFfBykSYA9entXo9pFAtqsaKpQDGAK8KXTJLV/tFo8sM6nKvE5U 5/qPY12GjeL9Qt/Jh1NSwI5uUTGDngMBx+IpRsgqTc+n3Hc3Gj20xdxhS3YjIrgPEfhC68xriyjW Tb1iBwT9M8fhXbwa1BcQg+auWB2MhyDVXVNYg03T3muJFWNRj5jwSeBQ6UXqRGUr2R886lpkE11c rczNC5kJePZgoe45rDn0ixijZ4ZpJApwd2B+VdF4k8N3x1u4u5Wj8q5kMqMZCFfJzwQDkVjnRruO T906AjkBJM/+hYrSDVtGKSaeqOeubZ7eQrg47H1FQjcDnn8K6J/7RiXEoUj0liH86jDl8hrCF2Pe NsVpzMmyCBjNGhzxjmrTXEUKZZlwB3PWq8NlfSHZGhiQngdSKtJo9rb/ADXc29v7o5NJtAkzNfU9 ksbRA4BIPuDW++qPAq+VsC7RgBRj64HesLUVi8rzYYxGUfb15IqrNqUjD5EC57nmqUUyW2joZdWv 9QKpLNLL/dVmJH4Cq15etp0gSWNmlI4QjAGa3PBAimtRJIoaUkgtjn/PNUfGFuP7StpNvBUqePQ/ /XrKM1z8pq6bUOYpGad4FDv2yQOgq3osv+n7HAO5SOazXmVQATyeABWnoum3kt7HcNH5USHJ3dT+ FdFK6lzIxnZqzOu0xFbU/lHCgf1P+Fb9xKIoWcnG0Vj6Kpa6mkxxk4P0wP6VNrtx5ViVB+ZziscV JynqaUVaJiG8Fvb3N455z8ufWuDu7l7idpGOSTnNa+vX3CWiHhBlvc1gdTgDk1nBWRTepr+HtOOo aku8Zhj+Z/f0Feig4GBWRoGnDTtNRWGJZPmf6+lSapqL2ce2GMySvwoHY1D95jvY86e0ic9MH2qt NY7UYhug6V0Or6TLpNztc74W+aKQdGFZrKGGexrt0OfU56OPdJgVoJCEC7yMnoB1pJrfbJhOCTXc aJptrBbrk4Yj5pMZJNc9WsqaO/B4KWJbs7JHDtbSRtvQEexGKnimfbleSOoPauu1HTxICQp9jXNT 2nlPkfK47+tKnWUysZgJYd33R0+hzXN3b7reSSFxhXOAYzgHBPIIPJ9a6iys5/J8qDkkkvM3Uk+l cRoWtGxdIZRviDZKYA59Qe9epWGpW17YrNbldnQ44x9aGnc5FaxBI0GhaWzscuepPVmNcVf3cl2+ 1+WJ3qV5xVPxVr8msak0Fq+IIW2g/wB49zWJ/aV5BuCIS+fvCqs7WRNzqLazmE0bpK4YnuOgqXWZ ZntBHFCTLgMzp1wfb865Zdd1PeobEbfw5B5pzzahPJnzdhxztNQoSK5kbKajDbWAt0mDsOSCec+9 P03WIRcSROmN4wGz06//AFq4+aIxyMSnmMOSdxps8724VhbryMjBPT1qvZ6i5tDrbnWpIN0MYPmn 5QMday9OkmjuAZQ0bsdynpnmsq11G48wXAhwy/d5zUsuoXTTK8gKqpzjOcVcqUnA2w2JjSqps9Nu bc38Fn5bgRzR5hDH7rjqgP16fUVrRM+taIXdT9usvlmHcj1/z71zOiXS6h4ZuIQ2Xt3Wdf8AdPyt +u2ul0C8lttXWef7/l7Zwf8AltH/AHvqvU+orkT01PWxVLmhddDzfxZpslpew6takoWwGK9mHQ/j UWgX8s2oRmaV5GK+X85JKjsPpXceLNCmub+40yFSYcebGIwSxXqPy/pXBQTGC4RZYdtzakLIw/jA 6fjitEm6dmeNdc2h100ayrLG33XXB/GuRtrHWLGU+QEnj6MocYP1Brq4LiO8iWeFtyOoINVbALaX k91essVsH2qGbHmN1wPw61hQvFtI2qtOKZRZA0c9uY/sV1coFfcB8y8HAb8q1/DOiTS+H9W0ozQJ czOjxCRsZAPJx16elT3bWF+h3zQfOcnLDH/1qjt9HufstxNYXEVzDAR+5dt2M/3WHIrpU+5g49UX 7L4bm4wl/qa7c5KxRkj9SP5VU1jS00srbxfchJiyQBnByCfwNWdO8UXOnFFuPMhB6R3qEZ/3ZMc/ jWodS0bU70z6pHMluQp2odysw4+8ueMY/KnK+jQkuhx+maTqd/eeZp0RPlgmSZ/uICOdxPA4/Grd 7caJ4YnecBdT1gsWAJxHAfX6+3UexrS8Q+KDdWSaXpkC2dizcKgxvx6kcCuE1TTrxWjeGBX+XafL OSxyeSPpj8qad3qU1yLTUjvde1DUL1Lx5wjqcjaMAfX1/GuksNUD2omVVAbrtGMkVzVr4Y1OdQ06 CBCcjca6G1s7HTLXyrm+iAzk5PI/CicVLRBzyesi9/a6+XI7AjaMnA5NZGpSXWsWMkEcbopwfnXq KsNrWnwkrZ2c10R0bG1TVO71TUpoiSUtYj/BCuWxUxpWd2Jz0MmK3bRnBSRpXOGK9AfpXV6RrENw F+bAJwc9VPvXGPavKpkLOFA4aV9pP4dap208+nXyzwklSeVH8VbOCaM+bU9ltbxSyx7wR16dRTr/ AFhbEFAryTEDaqnBGenr+X8q5LTtZiEIlfcpI+4Rg/l1pLe6huxPLqWpNaqACx8pmds9dvH4c+1Y 8mprF3euhY1HX7uUbzb+TJESUlglHmRk9cjJ44GfpVXVfFmp6paW8TXksjW/OY0xuJH8XY/lW3o2 paLql01jpelNNHEpZ5rkBVRRxnaMk9u4NSx+DLCe4V7m8vJQvIjRgo/l0rSNPTUJyjF+4zznUtf1 h7iK3udsXAKjywvB6Hjg1Ul1K/t5f3jh/QjivaNf8J6NrcltLeRXMDxIIwYmCkjqMkg/5NU5fB3h lQfMsXmVRy0szZ/8dxVcsYqyRm5OTu2eVv4mle2aFogcjHPesV5mbGCR9K2td0WO2125t7UokYfK Rs/KqeQMnrWZLp1zC2GjOMZzTVkTqa2k387Wfk+Y2FOMe1XSGPNYOnSNBOwIPI6Vry3OF54JH5Um tR3K14m6OROm7BFZrRdsVrBZbjAhiZ8/xHgfnVy28PtKw+0OTn+Fela06cnsRKSRY8E3RikliXBw wPHv/wDqrc8S2IvlQl9pRtxIHtVO10xdP1CFoUCK67WC+o5H9a6a4iIuImAO1hjFc0o8mIVzpi+a i7HM6foG0BxGFz/G3JNdDb2a2sTNuJwCSTVtI2GKnmjH2OUd2Qiu+btojjiiHR12WgYjDEDP48/1 rE8T3oSVVLYCDn8a6SAlNPhd+C0SMf8AvkV5l4lv/PvZFB6tXBWV6rOiGkEY1zIXndt27J4J71se F9N+2ah58i5ih+b6t2rCRWlkVEBLMcAetelaTYLp2nxwj72MufU1MnZWKRoZqi0SvqEcmQQFPy+h zVzNVBFvu5GD7WAGAKzAwtJv/tdsdL1Xa0Lf6qXPMZ/wrE1LT7rRrkwXCZjJyki9GFPhmSRAAw3g dK39P1G2ubb+ztVXzLc8JIfvRn/Cu1IwvfU48qskiPkFc8j1robWVrZhnJhPT2qDXPC8um4mgzLb vykicg1t+E4FurZlukwFG07u9c9aCkjtweJlQndFiOX7VGFyNvYmsq/0+NmyV3AGrl9btpVzui5t XOV55FSIyXEeQc15+sHdH1MKlLE07bplHT9Bs7792+8Z/utU19ps+iRuyTTSWrLtZkOJEHv2YVNC 8thcCaHHupHBrdjvrTVLCaB2CTEfcbv9K7qVVSWp89jMBOi7pXR5W9g8bmayuDInscMPqKvaVDJd XOy4BOFLAk46An+lUtVtH0+8keKYq4biMDr75p9hre4/6Tbvx/y1j4I/pWzTtc85bmwIblrlIrgQ SRH5hsOSmRn60EYhIjI3qcAetVNyMhFtdKQxzhhtb8xS2lvtkxPNtQnkLxn8aF5g0XNIsoLjVYo7 yZViJzJ3J9qt6lpW68Zba2do04B28YrS07xToHhu5ie108XU6YYjZ1/4E3P5VU1nxxd6rJPeWdnD ZqzfcY+YQDnoeB29KtQcloQ2kZR02VQdyqnfFQT6Nef2b9ultJltWbb5pU7TVKW41fUW2pLNI3YR jaP0r3bwnZPrnw+h0+d9t5DH5T4PIYdD/Ks6l6bsy4WlqjyvwyX0XUI47z5YJ1KMpPOxhjOP1/Cu ncXdvO0jSjz7Jgoz3Xt9RisbxDYjRC8VyrrcqeFcct7/AE9609Lu4dU0pLskvPaKFmUHl4ux+q9P piuWae/RnuYKspR5ZdC7quuoLa1aYSQ3SxkRuq5Vk7An25FcLLOl3qE23aXVfmwK29S1HTL2IaPe yeWjOGt5u8ZJ6N/sn9KksNItbHUWiubE25jjyZFYFHAycn1GATkHoK1grwuebioKFWy2MDQJn0yC bUL8rHp0jnyogPmkfP8AD6L6moddluNb1FXQCKNY8ICfkAz2qK9vZr25lkiRplPCqVyqqOgA6AVa t9KM2nC7uNQjQk4WFMFh9fT8q15YLVbnMlN6dCvpukSSXaxyyb0HLCAbmx7dq7W21a40mH7JZRR2 EUrhdzSjeTjI3Hr0+grF0+w08RAxLLJLj5pXbGP90D+tdda2dpa6BbsIUDSXGRxk4AxUtJlczjsc 9Okd/JKuoXksmxtuFQuG75Bxg1VOkQwMjWR1MqSTIyqFCj2Hf9K7lJrVWAZolY8gDGT+FUNe1KVb NGtUby0lRpTjqgPIppqOwnJyep5rd3uqJIyrvZQxCsygn8fwNMhu9cM8bx53dV4H0rvYbnRtRtZr q5kt9N/elURzyyjHOOtcnrGowC9aPS7kmAKP3gTaSe+M9qUZNvYGkloyK9OryqH1PV2T5chC2cfQ dqw5v9Z+5dpWY8Fl5JqcRCV975ZieWY81OmIWyigkcZIzWqlYzauVPIvuD5saeo3E4qTyrhjgSn8 BVtRK67dowDu+7TZ5lgAG0jPRmUkE+nFOUrvRAk1uRSwRwQ7p2Yuw+XeSAafZ2l3qCfNuW2XkBiO o64PSrmmaHLdgXF3mOI4PlBm+f3xWpqF7DYQhI4w0uMBDwF+tQ30RS7sriP7NbuVgdyn8KAkD0JN Z+5Xm/eYLN1I6D6Vo2/i4w6Pc2D2qbpkZTMgxuz6j86wI8Ft27inGNtxSlfY734cxRpr93ZeVg3V v8jA85DDI/L+VdXY3FpBdSG+m8tY03BduWY88V5z4f1ltJ1uzuvMKojYfB6oeD+n8q9B1qVJNSaO 1CySTDzFIPCg4JJPpVPbUn0JY9Wk1EFTHsXPyKR90fT+lStaCSEyTXCQopyNwJJ98AVHaWyQQeYT vOSBkdT3JpZy4+c5Ibg571ne7LtY53WfCA1SRrm3+zXYxg+W2XGO+0/N+lco/hqeIk2k0kXP3d4Z fyNd3c2zL+9hOADng8iqbxNcjCBRPn+I4Df/AF678J9XlLlr6I4sW68Y81BXZxf/AAj2oySL5jWi 4OfMXIP5VoW3htYpFlklWWQHOWGQPw6VvGyvFIDGFT7EnH6VBdx3dsYljkjd5H24K4xwT1z7V6UX lEHbmu/meZL+1pq9kvuFWzTzPMmJlY9e1WVeKNfkt4xUDWl0R82oWy/7q5qnc2skUW830ku44AA2 12KWBhrGDOXlx83aVRGg04JyyRnHqtDX7j/lqo/AVjabpZubtmnuJ3j4IXeQB6/0rporWETKEhQY 9FFcFbOsJTlaNG7O+OTYpxTnW3GWmpxSHa65bsyjIP1xVwfaJcgRKqnuTmrqgBcYpruEQnPSvLr5 hCpLmjTSPSoYOdOKjKdzD8Qaium6YxzyF2IPU15PPKZZWZskk10fi/Vvtl+YI2zHHxx3NcsTzXGm 2+ZnXotEb/h222SNfvA8vlDEaqOp9auT+Kb/AM9kWOKJR2IyRUOk+KUsbaO1ltAY0GN0Z5/EGnTQ 6fq92GtLuCANyyzZDFj+n61PX3kDXYktNd1OW9CqoleThYyMCtiTURp+osLn7rjaWXkA96xb7w+2 n2ZvEvAXXHQY6+hrLVmmlHntIUzlpACxIosnsK7Rm3DFEVhweme9Sw6jcKASwf2PBpLm0umH3VdR /dqbS9Fn1KYBVOc/dyAf1ra/KZwjpY7bwvq155XkzWbz2b/fhcZ49RW/LpUMGnyXujMZ7Rydy/xx H0NQaDo9zHBtl2pgbWDOSfyH+NTSpb+EInu4NRCyynDJIwCt7EVEpKRootGZcWzbYVkBw6kkenrm qcunS2yfaLTJQdUP9P8ACtCC9s/EErSaaVjlxhrffkE/7Jq1ps0IleyugRck4EZYAj3x3rKdNNHR QxE6MuaLMWG7im+V/lcdQe1SvaCQZUg1Y8R21ubmFQyxTN1cdcVjv9psiMOJE7EcVySpSjsfQUMy pVFaejC60ZLhgZE3EdDUK6SE425HpirkerNj5v1qwuqxkcqKSqVI9TWWFw1XWyMt9L3RlREoz3x0 qmvh67D/AC3OFzwCtdF/acQ/hpv9rW4PQfnTVaoL+zcL2/Ey4/D0mcvKT9FxV6LQ0RSu0MD1BA5q U63EvRRUbeIVXso/Cl7Wq+pSwWFj9lFyLT3jGI/kX0UYrTsZdT02QyWd5JCzDDFe9c03iYKPvgfj ULeKx/z2A/GjlqSBxwsdLI6zUjqOsqi39ybjYcqXUZU+xxms+x0WXTboXFl8kgzkZJDA8EEdCKwV 8V56S5+hqeLxbgj98M/WnaqlbUI/Vvs2Ib7wU0jmRDJG24sMcge1bENxcR6NPptwfMVwsUbTZPlI f9Y24DdzgDA9TTrbxiq43FSPU1dm8Z6E0eLqESNjpEnP59K0jVrLTc5a2FwtrvT0ZSW7+zaey6VZ i3RMoZmxnHTP+Rmucj0e9tZftDX9sDu+ZS+4ke4p2q+JrS4dlsbJljPeds/oP8a56ScliQAp9u30 71001JrXQ8XExpRf7uVzsEura0DbZ41B545H4E1BdeI4DEsZnuJwmdqBiFGeuK5IsWbLZJ7ECnYP HA5/OtOQ5bm5/wAJFPDciS3giR0PBJ3VWvte1K/BW6unZT/Avyr+Q4qgFYEcEMBkZ44p6xGQgKjF +4A/wppJE6jVJJ6Z9c1Oo4G7gZ7DmlIKfu2RUPQ8c0mQSQM8UwLEdx5MRWOKME/xlct+Z6fhTktZ nCtsID5wegNVkUE/MSAfWmDUJoZCsDo5DEGN4eR+NCQXLFzM6YiRZFZh8jbNwb2q1a2ltat9qvfL eZhkQoCMfXtUek6bd3V4Y7K3EkzckqDhM9/auys/h9q11bCKR4YyWyXWIs35nFJvohpdTmZ9XuZk ZICsYUZ4POKwZnklkYuxbHUk8k17Bp/wegVxJdTzSMeuWAH6f40eLfh1pejeFLu9tY99yroB85+U E4/z9aItIGeM7Cec/L9aduJHAHH61O5ijiaGSEiUHrnGPwqFcvIsaKXZjtVVGST2rQgdbRXd/dw2 dojyTyttRF9a9x0/QZtEsbe3u5PNujGPNkbuR0H0FaHwq+HsOiWn9s6jGG1CYfIp58oen1rZ8UJt uo2x/Fg1nJ3LWhF4MhivrfUreRBIkc+djDI5UHI/Oo9f0n7LLHFF/qXUsqnqDnGKPAkph8S6jan+ ONWx+J/+tXQeKBEi20rlQgZkYk4AyOOfwqUvdG3qebTho2I7elUZYgUMq9uuK1b4xmdvKIK8cg8Z xVMxvt+TuelUmTYqRXiyyqkpw46Me/saq3UnmXJx0TIB/nU2pWDIpkQAY61VDMQC+CwHJx1rtwGG jKr7S2xx46s1T5L7iogd1UcdycVFfOjSd/KXIXPpVkfLCzE/M/A47Vm3Uke/bKcxxrukx6V6WLqa cqOHCUknzM3rG1t4lHlgFdoO4HOauQqDISB0qtYSQS2QktipiwANvQe1WoMhSfU18vNPmd9z34u8 VYmxk4qhqfnGzn8o4bacH0q8DgE1W1D/AI8ZF7v8uPXJxU7FHlc+krK2WeSKQjJ8xcj8xz+lUJ9J u4VL+V5kY/jjO4D646fjXqf9nwzBmdBz7VD/AMI/byZeMsjjoynBrVTIseSFSOtHSvRb7w1JITui jmHqRhvzH9c1z134bVM7GkhI7SDcv5jn9KtSuIr6bZ6hJY+cl0kcZbCxyt8r49jxWsmq6hp42Xum q0Y/jiGP/rVWju7u1tkhurCO6t4hgPCeg98f1rQHiWwMRYO8ZVT+6dPvH2NZO/YpIx8D0qMXN9ZS rLZxgsD3GaSRGcjDMuPSlUSoOZWP1rraTOZOzLv9oeJLyFpZb82yH+FTsJ/KsttLMzmSeZpWPVmP X+ppV1ZYGZbkESL0IHBqCfXUJO2Nm+pxXTRw9K3NOXyMqlWpe0YlmFBYSiS2Z0kXowOMV3Xh7WU1 uZBe2wa/t1JW5AxlemDXmaanLLIP3ahM813Pgni6unPTyxj863rwoSpOUOhnSlWjUSn1Knjqzumv 0upbd/suzakpX5T681j6JosOobpZ5pIoVOAI8gt9D0rtvtmoG6vIXuBJYSnAt3UOPqM9Kmi0tVRA oVM9F9PwrgqYlRgoJI640m5c1yvBHZW9oLWGzLJj+Mlifr0qlf28ceA1iI93RVG0/wCNdJDa28Dc lmkHccbadd3UBYbY1kcDG49q4btvY61JxWjOUt9Ja7LZjKBRkAk5NPk8OQkYDygnpyOP0rq7OKaR w5jwp4yeAR7U65t0RCcBQvc9BXNVqKM7Ir2tW3xMxtP8M6YxXzYS5PXcxouPD1hBMyraR+2RmtEG REOxh5gGVz0zXO694kv7ecK0NunGMLJuf6nsKx5ZzfusTqS6sTWdMiOjyiC3jEiEMMKB9a5F4LO3 UCVE3Y7ryaS61W/unzLeS9c4B2j8hVOQLnIOT1Jr28FVlh6fLJXZxV6Tqyvexca6sktwsFqVfPLF QAaz3VHl37FHHRRgVNBayXDBVwq55dzhR9TSvCsbbTIrnp8vSrqVXN3ZUKagrIhTIyBgACja7dAa mAVR90cdieacEmkIRY3IPOFUniszTmZH5RAwetJsHTirBgKox3ICOoLgH6Y61GNpI3NjnnA5pkjE RR8x59qdtAXPH0FSRxwOWzcwxherSN/QZNRtd28X+oDyyDgtt+X6jPP6UWEPVeOBluwp2XHUsBjP NVPPuXOeE9yaUlvJ2S3K7c5wq5Ofr/8AXp2FcvM0UafNLG5IxjDfL/IfzqTTrNtTumhtRHuWMviS QKOPyqpBp7TD9zaXM59du1fzrTh8P6kxXNvb2wPQyNkn+lbQw1SfwoynXpw+JmdNAWleJgQ0bna6 E9PTFNaRIywZZJGPG4nA/wAa66Hw3JsUSXknTkRJt/U1p2uk29vGyNCZlbqJJev1GCK7qWU4ie6s cNXNsPT63K3hEwWNv/bUd4sk1s8f/EviUbnBwM+pwGP4g/WvUovEyS263CMNjHbtxhgfQg8g+1ch bzJbWphgt4omJ+8gwQPQdq5fxdBcWxttYtScwOolXqP9lsfof+A1VfKZ0qbne9jLD51SrVlSXU9d i8SswCxR+ZMWxsY9vWpNQvp7iwmju7SOa1YDzIwMEDORkEZFcloE1tcTq7rxcQhoie+eSP5VqXt2 mnARKGPmD5FJyVPGQfbGfyrx2rM9lM5ufSNCluzIdGhYnu8kh/8AZgP0rpPC2naSl0xt9KsoJgPk dIvmH0Jyawt+5mOO/atbR5hBdpIHA+YAqe9a2RFzvdIuGTzLUnhGyo9jzVLxFF5jrnoGzT7aYRah G4+7IuPxp2utut94GSOaxki4s5bw9MbX4gwgnCzROh9zwR/Wuw8ZQJLoNx5i7kDKSMZ74/rXAvN9 n8U6VdZwPPA/MEf1Fel68BPpV1H13Qkj8Bn+lENhy3PJ4IwkXlgADPA9K0Y9PZ4kcNjJ4xVPo2PW pobiSKVQGOzPSoZSNXWNASHT5Sjh9kSuzFuck4x+dcVFAWmKvwqn5vpWzfarc6vPLFbHMkTfvELF QB7+o49+9VrmICJzGu1/4s9feurB4uNCbhJ7mGJwNSvD2kVsZczAsxX7o6VlrNHaX3n3DYXucZ7V oP1xWVrcUkloBFGzsXHAGfWu6TU5Wk9GccU4R93obWl+JdH0eCW3iiR7eVt7qIzkmm3fiuxbUtlg wNoiZfCliCR/SufsvDdxdRqZZFgZv4SCSKvReFtQspl+y3NuyMcsWXH19a8mvhsLTm50ZNt7ndRq 15q1RWR1VpeQXtus1vIsiHupzzReKrIhJ+6cgVU0TR49HglRXLtLIZHOMAE9gPSrc/zSIv41zHSM xsiFToMIB+NQkbmA96mPtQISo3ijkXDKDn1FSHPSo3JVWb0FAHPXWiJPdGSDMZXunFUbnw9LMCZY 4pvdxhvzGD+ddXENsWccmkktkuY2jfOw9R61SkKx5qOPpSnkU0H3pwrtRykElnFK250BqD+z4DJn yVI7VfphBBzUTi2tNDbD1Y053krop3Njl1iRPnb7qqOtdl4a0SVbfy5rt7ZnHzsse4EDoP8A6+aZ pGnCd0EIV5nGMk4/Dmuzi0W601hHeFQxHCZzj+lcs6kqdNpM6as41pqVrFCHQZElcGUiLd8pK/MR WrbW0VsvyphuhJ6n8aryxRvcI+51KdgeG+oqVLoC5ELLwwypzXlSryqaIfLYrXlnNcXuIzhWGTk8 CrFtpkNvyw3uO5HH5VN5yedkMCVO1gO2aW7uobWFpZ5FjQdSxpSr1WlBCUVuSjr6Cs3Wr2wsbcve yqFPO3ufoK5XWfHirui0xSSODKw/kK4ie5ub+dprqUyk8nc4H862oYScneWhMppaG9rHjCa8Yx2S mCNeAw+8R9a5uRjIN7sSc80wzxJjARcHt8386b9qiId2l5z9wA5PvgcfrXqwpKKskZN9x3bJ7egp yo8i5SNmA5yBmqjXIwQkXXozHkU17u4ZtzSnP51qok3NKLLbUkZhFkEnnAB71c8zTPshcsi7ASqN J8zkdvlGe/fHTrXOvKzsS7u5PqetTwadeXH+os5G99vH51SpuWyIc0tzSXXQmTbwxwOFI3ohdnOe 5YnH4CobvWLq8VAzykgfMHcBc+wAGKng8N378SzW8A7hnyfyFaEPha0UZmuZ5j3EabB/49zXTTwN afwxMKmLpQ+KRzpmkX/lqi/7opx8+9lyTPcyH6sa7K20WwgxssYiw7ykyZ/DgVpxq6LtVti/3UUK P05r0KWS15fFocNTN6MdtTibfw/qcoyllsHcycY/A8/pWjB4WkY5ub9FB6iBd/5+ldSIQxBYbiO7 HJ/WplSvRp5HTXxu551XPJ/YRgQeFtPQ5aOeY9/MkwD9MVrW+l2tucw20MfuEy35/wD1qvBcU8LX oU8vw9PaJ5tXNMRPqRrH0ySfpxn8BgVKkYT7qhc+gxTgKeK6FCMfhR58605/ExAtSAUgp4xg80Nm DbYoAzRNDFcwSQTIHikUq6nuKUU4VEkpKzJUnGSlHdE2nxadZ6VFYyQzSrFkIzMCcZ47DpVuE6UH zKl3jpwwbH5ms+tXS7C3vfle4VZCeEyB7d68fE4TBUI81RWPdweYZliZclJ3aNex0LS9Vib+z73/ AEgc+TMNprIu7GXTbzy5UKsp/Km39o2l3SmGY7l5Djgg1rXOof23pHnSgC9tvldgPvr615eJwSjB VqLvFnt4LMpVKrw+IjyzRpWsxlt4nP8ACQa1tVQfZDjn5a5rR7hXtgh6jg1v3F2p0jzJGAEa4Y/S vKmtT2YnmnibUIdNNg8rYk+0IVH0YGvaVVLqyjbjEkeM/UV8o+MNYn1TXJJGOEiO2JfQCvozwlrA 1Dwjp8275vLAJ/CklYpu5xbxlZHBHTihQW+VPvtwPb3rRv4RBqF0HG1N7EH2zUECpbo0zkKT0z2H YUlFN2G58qIBbxaZvuFl42/vEIzu/H1qjdTxTxJPbn93IP51HrNw0iNGDztJIrP0rL6dPCM/u5CF z6cMP51WZYWNOEai36nTlGLlUcqb26FPeHZsHOGI+lXbKMSMxPYVVk0V7CSa4glkmWV9zxt/Dnuv +FaNomyAk5BNVVrRlQVtzjjTarPsTwQr5hYnJFWgMVBCMJn1qXdxXno6R4PFVVbfKznp0FTSyBYW PtVVOIRzyeaYE8XLk1NxmoIuE+tSZ4zmmA4nqaqzk7UQfxcmpixwB61Xz5lyT2WgRIegUdqnUYXF QL8zZqU9aAPKlbKinZ71WRucVKrGu/Y5SYGmP9acASeB1pSmeox9auMJS0RDlGO5asdWmsWQqoba cj1revfHmoand2cTRRwRKVV2Xlm/Ht+VcvhEHJ5NQXMg8s+XkEdDXUsuTg+Yw+uPmSR6vG3mAPxk 1X1YLHaG4JYCH5iVGTj2rO8N6kuo6bGS37xRhh71d1y0urnSZktpXim2krjjd7V8f7GUMRyPuezz XhzHOXHj7T4UkW0gcSv1aQcA+pArj9Y8Q3Opys0s8soz8uRtAHsM1Qk027D/AHOTySflx+dPTRpD /rJkHsoLH/D9a+goZdK94xucM8TFbsqG5YAbdqnuRzmmPcSSAhpGIJ6DgVtxaLbLgsJJD6E7R+n+ NaEVlGgHl28MeO4TJ/M5r1KWVVpb6HHPMKUdnc5WG2uJz+5t5H9wpNXE0S/fG8RxZ/vyAfp1rqRC zDDuzAdieKlS3VegFd1PJV9uRx1M2t8KObj8Ok/625z7In9TitGDQrJOsLSH1kf+graWMDtUqoPS u+lleHh0ucNTM60tmUobGOLmOKOM/wCwgH/16tCDd97Lf7xzUwFPFd8KFOOyOCeJqS3Y1IQBgDFS CMUop3Oa2Vkczk2KFFSACminCqRmx4p4qLdTg3NO5DRKKdnnAz0pgNP4oZDHCnimCnA1LIY8GnCo 6cDUkNEgNPFRA04GpaJsSVHBLDb4WYT5U8lU3hhx+vrmng0Vw43AwxcFGbtY7svzCpgpuUFe5Ykv pbuOLzM/IuAT1P1qxps2ydlOSroVI/CqApk43WlymcboXXPplSKUsPClhnSjskXRxVSvjo1pbtm1 pl1FDd4eRY17l2wKh8Q+Jrd4ZbC0mDoxDOw6E+gNeSPo13pkpmt3Mid2A5H1FXNOu7q8nFtFD5sz cL6fU+gr5mlDDu/tZWZ9rVlXulSjcm0y1ik1+S41K2KQbtqmTG3fkHr06V6r4QufLsJIITmNJSAA eMdqzbTQraDS1tXUyjGXYjhiepxVnQDa6QbqN5PLgiIOWPt+teYqsZTaR6lTDzpwUpGnrMivOoKg Hh3JH+f8isXWbzyrWSNVJJGQ23pV8ahY67dmS1llSVI9gif5TwT82OmOfeq9zbMHKzqVb+E46/jX LXm4y0OnDYZVYNs5i1kkmjBJLt05NatnH5EOCACecCka0jtpmeMABucDoDTt3NdNesq0ILsctGE8 NKa7j7h8RH3qIHbEo9qZM4LKuaUkNIqjtWA7lqMYQA04gZqMNS7juoAiuz8qoP4jUZ6hR9KSQmS6 9lFPj+aXPYUdQJxgLSnkYpueaM9T6UxDJGxuPoKhiyqFj1NNnY4VB1c5NP8ARaBk0XTNSd6YBtFL QI8nihkdsqpI7mtvS5NLtFY3KmW5zxxkJVKBlCbRuKHrjvVeQJBlkQDPrXqrBTr3U9I+R51SvGMb R3Ohb+ybgs7K/J54OKZcQ6fLBttc8DqWPFckl/P9paJpGKHkLnitfR5JWLLKu3PQZrOthXQp+1pT k3HuY87btJLUpuGidkb7wODSbCyFjwo4z61PfbGuGcHkjkVJYy28YRb2FnizuAXqa6Z5jJ0lyrUu jhYuV2GmO1vGFQMu+UbXBxg/5xXQ6lPdyQyR3twQ2zhfM5z26VhEx3923kHyEjwVjUdK2rV7KbVF N+52MOXyMceteZTnT+sc03tqdk7uHJAxEgTriphEoHStTV7jTpZNmnqDHG2A+evt7/Ws0HIr7rDV I1KamlY+YxEZU5uLdxygelPAFMFPFdKOVjxUgqMU8VaM2SCnioxTwapGbJKcKYKcKpGbJBTgaYKc KZDHg0oPNNFPFVYkKMHNOAFTwQNcSbIxlsZ60mla7JuMTpT80112OVz0pRVLYzY8U7NMFLSZDJAa XNMp2aViWiRck4AJPtS8gkEEH0NRh9rKTnbnnHpU8lwso2hi4U/KzDBxWbvewculxAadmogaeGPY 4NDRnYsNbTpEJGjZU6ZIqEyxRq5mUshUggd6mgutgUIz+Y2Q6EfKR/Wse9nWW5cRk+Sp4968zH4l UqTjLd7Hs5XgnVrqcdo7mVqd01tas8YwTwM9qo+GJxHe3ErZ37Qcge/P9KsalKLwpZQLuYnk+lbF vpEWh20aMv2i5kG9lzgcV8ViZrY+7pSdP3kbeizG9u2tpWzEyEsXPb2q2+iWk07NCy+UzdA1c+vi SGSKbZp/2YyDb+7fOBnkc/Smx6vBb28jW5fzj93d29f61xxqWdgdfm+I07yS1sbtRaq6yx8eYjlT 7/UfWta21ZruPyLsRyZ+7Ih6n0I7H+dZCQ2SR29zch0Ey7mTOcH+dZP2kyaght1KRiUFR+IqZttt s68LWlGaXQ3LvCTFevofWq+7mnXjHcpY87cfrVYPwSaql8NzXG29q0hpIa546LViDlmaqEb/AHn9 TV634j+taHKWhzQeFJzTQaZcybYT78UCI4jkO/qanhGAT61XU4jUVZHCgUIY+o3OF+tP7VDO+B9B VCK+d9yfRRU0eS2arxcIWPVjVmIYWkgJd1KG5ptIPWgDyyKQRqY4icHqabNIAjF2/Ooy5VTjvVcJ 5kmXGfr2r6B4tQjZLU8r6vzSuyeKNPlkf72OAKsJM6NlCVyMcVEOBj0pc8VySrSkmujN1SihT35p 0cjB4lwCFboRUZNCuI5UY9iO1YtJo0joxdRzFOSh2jp8posrglyhY7XGOtVbxXa4YOWOCSCT2qvF IYpxk8E11YWMYtNoyr3d0jo40Ea4Xip1NQRSCSMNmplNfV07cq5dj5ype+pKKcDTAT1FSPIrtuCb fUetamLQ4U4VGDTgatGbRKDTwaiBp4NUiGiUGng1CDTwapGbRKDTwaiBpwNUiGiYGnA1EDTwaq5D RIDTxLLGG8tyu/AOB6VEDTs0NJ6MlNp3RIpOOeT606owacDVENEgpaZmjNBFiQGlzTM0oNKwrEgN OzTEG443AfWnujRPtb0yCDkEVGl7CsLmlDYNMzQTRYiwt15qpGo+VZBnd7ZxXM+IdWtobhrewLbO gZuCfc13tmkN/phsLopHJy1tPuG5SexHcH8686vvDd7b679ku4itw8gUZ6MCcAj2r47NnVVV8+3Q +5yeNFYdKnv19TpfB2niDTJNQmQF3GQT1C+3+fSm3N2LjVFuF+4+AoPYdKu6zqYtyNMt7cRRQp5b SBs78CqMdpHHpa6k5H3gg9sHmvnJPmkerJ3ehlSxLHeSRudi+YeccDPNV1ZWvYrfePmO4kc/KP8A OKta/wCMNLfR3W009PtLAKJv61neDEbV9QMk7BHd1jBUcAfSs50GveM0k3c6y6uZLizQSEfJ/dHX 61nWeReJg9DnpWpLYSvLcRRA4hU7i3bFZNn9wsc5NVy6anXTlyzUjVuZ/NkHOQoxn1qBnxGcH2qH dxTZG4AHeqSSVjSc3OTk+pIpxGq+taKHCgVloczKPSr6Pk00SWt1V7h90iJ+NODcnmq4O6VnPbpQ CLMfzSYqzmqsHQtUwOSTTQEm7mqdxITx3JqZ2wh96pby9zjHCihiLAPQVOOBioI+TUueaAHk4pk0 gSImlzVSdt8ojz7mgDzHcMUuewqqkmKsA5GQa9C1jl3JQaXNRK3al5qRkmRTWGRim5p1UInhME+I 7slccLIOSPY0+78PzMN9uRIAM7kOVOOvvVNwMZpyySxr8kjKGGCAetdFKDlFtPYmc1dKSNGK3msm WG52rIyhgoYGrIrAG/7QJSxLKfWtyN98asO4r3svrOdO0uh42OpJTvEmBp6kZGeRUQpwNekmec0T uUL/ALrO33oBqNSMjPSpH2BvkbctUmQ0OBp4NRA04GrRDRKDTgeaiBpwNNMhonBpwNQg08GquZtE oNPBqIGlBqkyGiYGnZqIGnA1VyGiXNKDUYNOBouS0SA0oNR5pwPGadybD804Gos04GmJokDFXV12 kqejDINO8xmxuxx0xUWadmlyq9xdLEmaXNR5pc0WIsSiUozEx7wVwOSCD60zWtaaS30+O65MMoEc hGSvtn0/wpM1R1a0a8sWSP8A1incn1FcONwkK9GUWtTuwGKlQrRlfTqPvHE1rJMfvebuJ+tc3rOp 3MemCx81ijsSqjoPU/0rRt7q8+zyGWLylaMq5cYCjucfnWHasdV1JU8tRDE25SP7vYV8Dh8JOVbl t1sfa1KqhB1G+hBqGlGDRrdmB3E5b/CtjwrINPuIlHD53kfhWhrUSf2cqkZO4ACudgeT7fLJESTC RwP7oGDXpZrQhB8kexx5fWnVpuT7ndX2oy29vJKFBN5uBOegz2rOjzHGB7VS1LVTdWFvLGMmGMD8 aTTdTS/jI27JF+8vb6146pTlDn6Hqxmr8rNHdTC2ZfpS8c4qHPyu1Z2NixbtuZm96uxtxmqFt8sQ z35q0p+TFMCwX2Rk57VErYjHqajmJIVQeppV5kA9KQy/GdqAU/dhcZ61BuoLevamIdLJgE+lV4jh M92qOdtzAZOWPIzTwT0UZx0ouMuR8Ln1p+eM1AH+UDpTt3OM0xDyQqFjVGN97PL6nAp97Lsi2jqa jU/dX0FSwPJhJircUmRwaoujJ70schBr0nscqNLJzTs1VWbtUoYHvUDJM804GoiecilBpgS9RTlG YzjqKjBqSI4fHrXThpWnZ9TGqrxuOhgkuJVjiUs7dABWzbWT2qLHckLn9KztPvG07UI7lRu2Hlc4 yKku724v7tZ3KhN2RGOmKqhVxFLE2ivcW5jWjGpT16l8BPM2n1xkU50Eb7SfxHSr502J22r8pdcp zxnuK57VZrrS5/LkRWXPWvfp46nOPMeXPBzUuW5pshQ4JxkZGe9P8pgoYjAPTnGaxY9XLqC6H25q 2mtR+T5Tbgmc4x3rWONovTmMpYOsuhpMqkDy8njnHY0mGHVSPrVSDWbZGKhwdwxhqsR3iK4/fDGe Rn+ldMasJbNHPKjOO6Jc04UrzpI2Y+FPY84qRWiaEt8u8Hp6/lWiZi0MBpwNCbGcKRtzxwac6KjF ST+HOapMhoUGnCkWPKllPA68dKAPRl/OqTIaHA08GmiN+wz9Dml2svVSPqKrmRLiyQHinA5NQg05 TiquQ0TAU7OBUe+m7qRNiTdTgeKhzTweKq4miQGlDgMCeRnmoweadweDT3JtqWpkVANoZWH3lY/q KiBqFRt6Z/Ong0RVlZhKzehJmkd9qEntTc1S1K7S2tndzwoyR6+grDF1lRouZthKDrVowOf1y/aG A2QuHkeQ7pC2OB2FXvDlkILXzWGHk5P07VzdpBJqmrgudxZtz/Su2uZEsLFnIxtHAr57L6aXNWmf QZlUdlRh1KurrI4Eu9QkYLBO7e4rjIbmWGdZ0LBwc+laaSu9leX0+9sqVR88AnjH61ip5gA3tuyO D6V5eNkq0/aR6no4Kk6MORm1Nqu66E9sm2NlG+JuhPetbTbu2kjLwKqsTl0xyP8AEVyKPtbnoetT JIYnEkTkEdxWlGNOrT5GXU5oT5kdyZBsyDnNRucRqvdjWRY6qlwojlIjl/Rq1UJe4UEcAd68zEYS dJ36HXSrqat1LqcKB+FWAQe1VQfmqUOApNcpuITunPooqW35YmqiMdjOerGrkB2x59aQE4PNI7YX 600nj61XnfbkZ6UwQ3dvnJ7LVmPrn0qrADtye/NThwFpDLAbnPpQGzyai3fL1pssnlRFvQUCIZJN 90ecqtTx5J6ZqjADt3H7zHJq9EcCkDPMpIvaqkkOD6VtXdnNayFJUI+tU2jzXtuCkro89ScXqZuS tSpJ71LJFVdoyp4rCUGjVSTLAm9qlVgRWduIqaOUjvU2GXh16U8HBBz0qBJMjrUmeOtNNp6BYsvz hh3FW7YWnkZkkk3jqgXr+NUI23xkdxSxviTGetehf95GXc5PsuPY6+yumm0gTL/rIGz9MVX8R2ov 9PE6cnG4VF4bmHnz2rdJFyBV7TvnS406U8xMduf7pp4f3KkqTIrXlBVF0OIjUFAOhHWneWD3q1eW jWl7KmOM8VHtCLvk4HYdzWM6N5uKN41Fy8xALcEhmYDB4qbVLd47sGMAhlBqB2aQ56KOgq/dNuWB gf4MUpU+WcbMFO8XczxcXKDAYqPapY7+7Q581vxp+3NJt9RXbFzW0jnkoveJZj1m5HUgkd+9Wk1t sfPHn8ay9iE9MU7yFboSK0+s14bMyeHoy3ibMfiCJM8EZ68ZqzFqltLyrn/vk1V0rw2ZyJZ87OoX 1rp49LijQKsagD2rmlntWm7WuWsopTV9jOGpQSxiMuu4dyRmnpcbRlH/ACNS3ejwzqQ8QP4Vz9z4 emhJa1mkT/ZJ4ralxCnpOBjUyO3wSOlkuFYKUcH17j9aYJRn5lTB/wBn/CuJludS09sSu689c5Br U0e51DUiwUqyggHp3NelSzWjUWiZw1Mrqw6o6iYJGR8g564yCD6c1GvlMcfMue+c1ztxq93ZSiOe LJIz8xp8evxOvzRsv0NdSx1DZuzOZ4Gvulc6RoUTGXOD0OP8DRsBHE0f0OR/SsSPxDbv/rGI+i4q wmrWb/dnUH34rWNenLaRhLDVY7xNTynzgbT9GBpDHKvVGH4VCNSgmiEYk3EjkEg4PsaRZMH5Wx9D WsZOS0ZlKnyuzRNk9DRmpLa7IZldicDJy+Dj29aVpyzbSysh4yUGcVXNInkRGWwM+lcd4lvy9wLb JwvzOffsPw/rXTX9yLK1klbGU6A9z2FcbDG+oXaxty0jfMT+pr57O68pyjQpnv5LQhCMq1Q3vC1g IrZrl87pOR9KTWWlv79LGHuQXJPA+tdHY20SLHCWEaABc+lVodNWK/kdIxMpLk/N8zHB2gfjilio SpYZU4fMjDTjVxLqz+Rx/iaeC2ZNMsWY28QDOT/E+OtZNtG80GVKkg4255qXV7a7iuZGuYJI2Lc7 1IqlbBml2KcFulePTklOx7sl7tywyspKsCCOuRTVR2fEZGfT1pXaf5fMJYDgH0pB1yKzl+7noWnz RHq+Ww2UcevFbmm6s0bLHcHI6K9V7YxXsWJEDOowcinHS+P3T/8AAW/xr14UpThf4kzzZ1IxlZ6M 6pCGTepyD0IpZW2wn1PFc7Z3t1pbhZULQnr3rdE0V6iyQOCAclT1rycVgHG8obHdQxSl7sx5P3Ez VxXG0AVRjG6fn+GrQI3c15drHcT7/XtVSdtxAHUmnu/y/U4qup3Slj0HApAXFxgAVIE46VDEcZNS q+aQXF2jdVW6Yu6wg9eTVosAM1QibzJ3k7dBQNFgDAxUm8HGOlNB4ORTAB1BpCMe21q3v4hBqKAn GBIOtVL/AEQxqZrY+ZF6rWEkucetaVlqk9qdoYlD1U9K9x07awPP57q0ii8ZBwwwahaLjpXQuttq C7kwkncetZ0lq0MmGU4pqV1Zk2tqjGeH2qBkZK3fsmUErkLHnk1XvFjkkBhi2KB+dc83Hm5Ym8VL luzMSTBqwkvGKiktyDkVFlkPNJpoaaZet5Ns2OxqRztb6Gs9ZMMD6VpeaqyRTMu5c8j1rqjO9N90 YSVpepo6fc/Z9Qt5weNwB+hra1KX7Fr0N0hHlyDD+9VtNvbacGQxbFB4ytO8RKtxpS3MDhwhzla4 XmE3iItwsChaDiS67ajYLlF3DGfrXKOWlbc1dfodyNW0TymOZEG0g/pXMX0Btrl4yMYNe/Us1zo4 ababgyuBxV6WX/iX2/ABB25xWeG5qaR8WIHdXzXBXs7ep207q5Klw8XIbr1z3rS0u1m13UYrS0VD O/VXHAHc5rCDZzW74Ss7y68QQNZzGGSI72lA+6Kiryxg5LRlRcnKzOs1vwBBYadAtvMZL0n5yeh9 eO2KrWHg9ImWSWbew/h24Ga7/auN02XbuzdTSottLwpAPtXlfW6rXLfQ6/YwTvY5k2MsK8KCPao9 204PH1rppbIgZXn6VUlsUkGJY/xFZKRbRgO69Sa5vUfEiwzNDaxJK6Ha25sflXTatot6sJfTmSRh zskOM/Q15f8A2Zd3V7cpN+6uUOSrg8kmumi6Sd6iujOblbQj1K+mvrndMu1uyjoK6rwjA0EEhcYO 8HFYo0tbRllmlMso9uBXTaEx+zSOTklv6GvVwGJhVrclNaI83G6UrsyNf065u7lZYRuVFwR3rB8i RW2tw3oa7WS4aOdlVhjPIIqGSK1vDtlQBuxrHE4uCxMozReGp3oxszkPJk9KQhx1BroLrRJoctAd 6+h61nh/m2sMEcYNbwVOorwYSc4fEjMLsDkEg1ZivJ1GFlYfRqtMiHqoP4VEYIuuPyquSpH4WLng /iRZtb27kIzKxHvzWidTnhT7wOPUVlxOqDAFVru6IOAa6I4itShfmZhKhRqS+EvanqsmopGjIEVO oB+8emf8+9XvDdmCz3Lr/sr/AFrm4HeedIlXLOcCu+tY47CyjViFVRgk0YGMqtV1anQzx81SpKlD qWie2acnHIqJJopkEkTpIg7qcipUxuxXtJ3R4MouLJ3wykMA6Y6MMj8qzJdC0e4mQy2IjbP+sgOx vy6fpWiXbp2PWsfxBqf9m6a7IcTSAonrnua561OlyuU0jooVK3OoQk9TltRgjFxJ9nYSRq5GR3Ge tZTDBNPtJ2I25yc96sOqsh8wAHsRXyE6zu1I+zhQTV4kdtcyWswkjbB6H3FbkOqW9xgOAj98f4Vz nQ4zQVBOf5V34LGSou3RnDicNGqtdzs0VZF+VgwNRrbLE5aPKH/Z6H8K5mC7ubY/IxZfQ1qW2uK2 Flyp969+NelV+LRnkSoVaesdUb8U4z84HPcVZ3ZGay454ZhlWFTKXUZU5FedjMpjV96m7M6sNmMq fu1FoW5n2j6CmJ8sYHc8moHkLDDcc1LG25x6V8/Xwdaj8cT2KWJpVV7rLSfKOakzgYqInkUu7muQ 3G3c+yAgdTwKjgTbGBnr1qrPKZbnaOQtWozg59BSHsizu28UEgjFRbgTSZO4mmI88aN4TzyvY1Ik tNiueNrjK+hpWhBG+I5H92vWp1+kjjnS6xLUcxUgg81sWEhvT5TLuPr6VziPjg1PDeyxSEJ34rWv eULR3IpWUve2NfUbSP7WVhdpFUd+maovHg4IqSKcg5zz3qxlJeuAadGj7ONhVqnO9NjMeLNVpYfa tiSDHI6VVeP1rZwUkZKTRjvCR0qzbkyWzIeq1M8VMjTy5OnB4rOEOWRpKXMh2m3rQSlCxK/3c8V0 VtcR/wBlz2jciQEr+NcnKhiudw6ZrVt5C8ezuOVp8inFwe4m+VqQ7wxqBstU8lzhJDg10HirT90K 3kS8fxEVxFzujuRKvysDmvR9FuV1vRDbvgsy8Z/vV0YeXPB03ujmrrlkqiPPd1SFswsuevNO1C1e yvpIXBBU1LaWNzdlUggdy3AwOtcVV2TT6HXCzs0Vwc7T6ivRPAenXNkk11LHs83G3PXArFg8OT6J fRC7txcSjkIPur9feu203VbW7ZoopF8yM4dR2rhr1nONo7HRTgk7s6FrgSR7cCqUsa53Lw3YipIw M8GpGAx71xm5BHqFxbnDjenr3q/BfWl31YK3oeKzbh0ihaSRgqqMkntXmGv6/LeXw+yO0cMZ+Uqc En1rrwuEniJWiZVaqpq7PWdX22do9wG+UDPFeZXV01zdSTuBuY9quw69d6l4fihuXLMrkMx/iA6V n+WN/P3R8x4rixKdOo6T6CUuew+30ufU5QBlYx95sdK0rG1FnDNCCTscjJrr4NMitdLjFuCQV3ZP Uk81zI6XDYPMrde3NerkatXfoceaJRor1G2+iR6jDJIHZJtxAPUH8KxdQtJtOuvs82N2Mgjoa7fw 7C80QYRlUQn5j/ESaoeNrHIhuNoyuVPrXJjEpVpvzOihC1GPoYml3fnAwSD5h90nvWZ4isVh23MY xk4bFMilMMqMOoNXPEM+7SZMHGQCDVYSs4yQTjzRsc0GPbJJq9Dpd7OA3lbR78VoeGNLMkS3Vwnz NyoPYetdckKqPuiu6rjne0DKGGVryOAn027tlLNHkD0rBncmQ5BBFep36IIzwK5e60+GcnegPvjm snjZS92RoqEY6oz/AAtY+ddNcuBtj4BPrXQ61JGNNuFL4YKNqjuSf8M0WNsljZxQqAAB5j8/kD+v 5CqM6SXlysaqWaQ7sY6KP8mvZ5/YYe3c8Wp+8xHN2KdlYR22m/a/PaFiCd6PjgUlh4kvgcS7ZUz3 GDj8KZr9xCDHYowRI1xx39f1zVCEKq/KQaVPEudnDQ6ZUYyi+fU6oeJbNUzMJI/wyK5LxDq39qX4 KE+REu2MHj6mnXK74Wx25rHk+9WWOxNSUeToVhMJShLnW5LaMROoBxu4rRLBxskG09ielZAJBBHU GtlNs8CsRnIrzqdCNZNdT0ZV5UmmtirLF5Rx1HY1GretTSxlV4Py56VWwy1k6U6ekivaRnqi5DG0 zbEwWxwPWmywkHa6kEdiKhSQqQynBHStu2vFuoMXEay469mH0NaxxsqatJXQvqyqfC7Mx42mgOYZ CPY1o22uPEQsyke4qaTSllTzLSTcM/cbgiqEls6ZWRCG9CK9LD41SX7uXyOKvhGv4kToIdShuADu Bq0CjgFG5964toWjbMbFT7VNDqtzbnDjcvqK7ViotWmrHE8K1rBnaLJIg+YZHrSm4GwkDkDpWLZ6 7HIAN2PUGtRbi2uB/cJHbpXLVwFCtqlbzRtDFVqWj/EitwSSzZyTmro4WojC4GUIYe1JvPRgRXlV 8prU9Yao7qWYU56S0J8/L70jyeWhJOMUwMCeDVS+lPEYPXrXmOEou0lY7VJS1izhzVmAn1oorqIY s/3hUMP+uoortpbI559TSToKsJ1oorqRzMtL9yoJOtFFNbAyu1QP1FFFIaIbj734VNaffWiikv4g 5fAV9R/1rV0vgJm83GT98d6KKvD/AMeRnX/gok8Uop8UwgqCC/II61p6U7Lq1qisQnnqNoPHWiiv Ox3xM0p/DE2/FZI1KTBPauR8Ik/8JDc8npRRXDT/AIZ3y3PUbb7tTHpRRWbLRy3jhmXRcKxGXAOD 1rzE/wCs/Giivp8l/gv1POxfxnXbVXSrTaAOD0FJB98/7poor5TGf71L1Oql0PSrL/kHW3/XMVx8 v/Lx/wBd3/nRRXsZJ/Gl6HLm38JHYeG/+QHb/wDAv5msPxZzA+fUUUVxYj+LP1Z10f4cfRHnj/1q xqXzWSg8jaOD+FFFYUNyTp9KAEC8dq0X6UUVotzQzNQ+7WPJ1/EUUVUP4sfUUv4bLE/+ruP9/wD9 lFWNMUf2lenA+WwUjjpwlFFe9mH8OPzPAofxH8vyPOtY/wCQjJUNkx8zGTiiiuTD/Eeo/wCGaTf6 tvpWNL1FFFa4zoLD9SOtbT/+Pc/71FFYYT+IaYj4CaT7jVQb7tFFaYkiiNWr2mf8fYHtRRXmVfhZ 6FH40b0X+rHtVi5VWsGLAEgcEiiiuTDfxkd2I/gs5qTvVV6KK+pfwnza3KbcS8cVsaa7bR8x/Oii rwPxMnFfAdJaM2RyfzrVkVTbZIBPqRRRXoS3POWxmdz9aqXH/HwPpRRXhZv0PWy7Y//Z /9j/4UhrRXhpZgAATU0AKgAAAAgACwEOAAIAAAAgAAAAkgEPAAIAAAAFAAAAsgEQAAIAAAAJAAAA wgESAAMAAAABAAEAAAEaAAUAAAABAAAA0gEbAAUAAAABAAAA2gEoAAMAAAABAAIAAAEyAAIAAAAU AAAA4gITAAMAAAABAAIAAIdpAAQAAAABAAABEsSlAAcAAAAcAAAA9gAAKvYgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgAFNPTlkAAAAAAAAAAAAAAABEU0MtVzgzMAAAAAAAAAAAAAABXgAA AAEAAAFeAAAAATIwMTg6MDM6MjQgMTY6MDA6MDEAUHJpbnRJTQAwMzAwAAAAAgACAQAAAAEBAQAA AAAegpoABQAAAAEAAAKAgp0ABQAAAAEAAAKIiCIAAwAAAAEAAgAAiCcAAwAAAAEAUAAAkAAABwAA AAQwMjMwkAMAAgAAABQAAAKQkAQAAgAAABQAAAKkkQEABwAAAAQBAgMAkQIABQAAAAEAAAK4kgQA CgAAAAEAAALAkgUABQAAAAEAAALIkgcAAwAAAAEABQAAkggAAwAAAAEAAAAAkgkAAwAAAAEAGAAA kgoABQAAAAEAAALQknwABwAAKAAAAALYoAAABwAAAAQwMTAwoAEAAwAAAAEAAQAAoAIABAAAAAEA AAKAoAMABAAAAAEAAAHgoAUABAAAAAEAACrYowAABwAAAAEDAAAAowEABwAAAAEBAAAApAEAAwAA AAEAAAAApAIAAwAAAAEAAAAApAMAAwAAAAEAAAAApAYAAwAAAAEAAAAApAgAAwAAAAEAAAAApAkA AwAAAAEAAAAApAoAAwAAAAEAAAAAAAAAAAAAAAoAAAPoAAAAIQAAAAoyMDE4OjAzOjI0IDE2OjAw OjAxADIwMTg6MDM6MjQgMTY6MDA6MDEAAAAABAAAAAEAAAAAAAAACgAAA3IAAAEAAAABwgAAAGRT T05ZIERTQyAAAAAAKCAAAAcAAAABAAAAACAKAAQAAAABAAAAADAAAAcAAAFIAAAExrAgAAIAAAAJ AAAGDpQAAAcAAACYAAAGGJQBAAcAAAsQAAAGsJQCAAcAAAGEAAARwJQDAAcAAAGQAAATRJQEAAcA AAGoAAAU1JQFAAcAAAXYAAAWfJQGAAcAAAAQAAAcVJQHAAcAAABAAAAcZJQIAAcAAAK8AAAcpJQJ AAcAAAJYAAAfYJQKAAcAAACoAAAhuJQLAAcAAAGQAAAiYJQMAAcAAABAAAAj8JQNAAcAAADIAAAk MJQOAAcAAAAQAAAk+LBAAAMAAAABAAAAALBBAAMAAAABAAYAALBCAAMAAAABAAQAALBDAAMAAAAB AAEAALBEAAMAAAABAAEAALBFAAMAAAABAAAAALBGAAMAAAABAAAAALBHAAMAAAABAAAAALBIAAgA AAABAAAAALBJAAMAAAABAAAAALBKAAMAAAABAAAAALBLAAMAAAABAAIAALBMAAUAAAABAAAlCLBN AAMAAAABAAAAALBOAAMAAAABAAAAALBPAAMAAAABAAEAALBQAAMAAAABAAAAALBRAAMAAAABAAAA ALBSAAMAAAABAAEAALBTAAMAAAABAAAAALBUAAMAAAABAAAAAE1NAF4BAjIwMTg6MDM6MjQgMTY6 MDA6MDEAAoAB4AAAAggAAAAAAAAAAAAAAAAAAAAAAAlUSG0yMTEwMDAwMDAwMDAAAAAAAD6U+gEA AAAAAAAAAAAAAAAAAAAAAAkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAABTdGFuZGFyZAAA0QEBAAAAAAABAAFwaYiVAP9V/1X/Vf9V /xH/Ef8R/xEAALSKAAALPQAACx0AAAs1AAAAAAAAAAAAAAAAAAAAAABMeagATE66AEzLggBMAksA AAAAAAAAAAAAAAAAAAAAAEUA4wAAAF4ACAAbAAAAAAAAAAAAAQAAIJWKgQAAAAAAAAAAAAAAAAhK AT4AGwAIAAgAAcXzAAB8AABAoD276v//BHYFTAAAvq6Bfddp/5sABZUAAABwAOoRDQcACH1KfUoA AAAAlQDhXQAAATRJ70uTCMRaLkoNDs0qFgjYofYOAh2VxD8HgRFB5mmHrqiyyTw/B8QOzzKrQIZa xEr/////CEwyqACVBXACfrVcrO6boXPsGyXYzABbBHP5DukFW5fErgSDBNsE2wSDBHPDOJVORfZD pDxc42CVG3MElVkkitC6NAA/xzx2fTwOSkIg9umpCOEHaeppDmnEEmbjQE6BzQVKQGnnxWrEvg4K gSKuUQCA0wVJEP//////////////////////////////////////////Dg5WzYqKis1WDg4O6nAw uwy7MHDqDupwu5Xv4O+Vu3DqBTCgtzhbOEegMAWK113cWEpY3F3XigUwoEc4YThHoDAF6nC7le/g 75W7cOoO6nAwuwy7MHDqDg4OVs2KiorNVg4O2H3a2Ex91ATNUQheqwjtCC/YfQR5fULYHn3XfdwF fzn/CEYIAX2ZktTYr0AMcFoFuQXAcGww2UA9CEhwndcUvgbqks14kq5s1Frdx+/Eu1ZzDsG+atc3 aUK2zmxWJPu6FNsK3M27MJV5gczXWiSQgV4oTwzsvhDqCYrLVuZw1OoFMMZH++pebBUoK1YdDmhW PFZV6qrqZCBRGpjYHeyJ5wm2qs3EzXu7w5UbgQPq85UmfR7NQue0ga3YrgQkUetRF1HGza+Bzn31 2DV9teovObheCRsvCHNehVYaDhBA+H1dfbu+q6DMCLgILwSH15x9lEC/cIuKM80/gdeIH0BEGyNp 0L5Ttu7nfwV8bGHTCB/kJb2H/A59VuoMl12/BR6IedPcrF84fW1cjmGBmmxkgSoMK+JFkhZsWShO 1/sF+2kyBR5pVQX4KEOOcwWU03iB0FYL51jq74qxVsoFB4H8YDAENaCuDkyIHc1icMWSoOzEvlzq CcV0fVpwh1begUperM2+L2hdLy8M6o2gPH3h2FR9blYqXP9eFAjrCJVeogSnDoFA5UA9QJm+WCgo CEUByQRovlN9fUDYinIFw+rOu5W2KxvJG762+iBQBb0ObgVJ7CVRSqR2d9ddv9jTVuYM3Vx3VtFp d1HGrC1SNDwHRxzX7ezc1zqSEUwHkltslQxB1+oFRWnCBTZpPQVV7I7LgQVR03O+swTADk1WNQXt VkfNc4F74FIEuWx5XplpROqDimOBhQzbII7qdcXFfX6KTlaUvjTYg83Y0znTC1Er6lagUgAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAC/EXAeV92wRanIM6tOPlQBq0V23XeBR/tPuUecvR2pblQCVAFYO UeNd2i/7LyQvDl3NL6s5R2y0URg5vQwHbMSVO/ApXSHTmNOCkjQoIShWki7XqexIoFnvfmqzL+0H O0f/OZgwhJJlbPaBF2kE0xCVOexXbOoMbiiL1/MwWwzMIMggmlGyoGWgmJW47Kcok9cnaXAwAZLh IPGVMAwnkmns2YEYgcu2N3B4iLWSH2mugf8MVJJUgS8FsXBMBSTNy83Rkg2KPShyKI3sO5Ur11/s BexOlQBRUoj615psXmxUoA4owTCIlQCVAJVp17e76KALkuEoyyh2gXW7c6C8bFrXlmqs00agaTCS DKAoe2yHh5HTFyhhxdDiZC9voK4wVgxH7E6S6YgNbFAHYy98Uak5F7fXoORRINP8Ua8vgJVaBxfF 4VGZJBvwaOwuUamVxJXKXWnThgforH3i9TnY4oVRG1xWxYQvr4eOh4h1vrc2JCN55u8iOSFcWQce 8AC6DUc0ur0rnisRYDPgsAAwAI4ABAA5XngAPQAAAAAAvgg/AHQAxQAIABsBuOcGAAAAAAA42G8A sAAACJsBeAFZGyHYAQAAAAB9IwiDACIAk30YQHEbVAH+G7oBnwHUALVAoQFBALoOlUD4G0DYT4ph CCFAEgiLAPIbHl5IAPUAGgFXACYAiQA3AUkboACrfX7YQADVAEYA8ADXAH8APQG9G5UIrwhSffkA GwjaAO0A8gEKAVkOZw5s2LQBC9j9ACgBrADVQB4AjQiw59Hn/ucuCLsOJgAAAAAAAAAAtrYAAAAA AAAAAAAAAAAOswAAAAAAALe3AAAAAAAADrMAAAAAAAAAAAAAAADT0wAAAAAAAA6ztra2tgAAAAAA AO7fZtOwsAAAAAC2tgAAAAAAAAAADrOHKtvbX/UAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAC2tgAAAAAAAAAAAAAAAA6zAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAH2qfXHYZgXVkqDqrBvaQIZePOet2GAOTF44Dgdw+uwaDskbZw7jIFEEQV4O ipGKUr6X03w5ir5pDrSKzCApIALN2Lakku9qwlcav7uR9Yj9BYa+wIF6110weewJ7+Tj3Ve6jmUM 5rsBvnoMlRpp10coTGx0oHSSe4GLaTO2UHApDL0CwHBPu5m7UwWqVpzNAQWQcCtwyIFjh10Eqr6e itpwIM3UBcqBH2wMgaIglZWKDm7qYwVRiMRWXQWdoEIvjaA7IIO7SghKCAdAE9jZXjEOs+cv2LAE vuoxVovqqIoaihoFpwW6zTrqqA43BBoFulb7XrbYixvoG+gIIwD3ANEAtQADfRoAAEoAAAAAAP/E bUYAAG1GAAAA9gAAAAAAJwD2ACcAAAAAAAAAAAAAACcA9gAnAF0APwAAAAAA9gAAAF0ISgE+AAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAABBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGyUbJdhV2MwAWwBbAAAAAQAAABYAAC/Q AACWRQAA/7YAANhRfUv+3hslXnn/5hslXlH/NQBKJ1F/P8WmL5XigcWHCAUODqGVCIHxefiXAAH/ //LXfnfbEXkArwE6XIaGxy8RgeHOSQARBGWX111TVicgELMOVm5KBCIRQJf2AARKDeGHOtrMEUJA zAiVRQj23ZaWkg73PAHHCMJwxMnDmAA6zM7NvmkO5ikIOrYAvtimG1HuAAoAXZVwG8NGAekAxw4K FsPCxebOx1EyCHYBsbbJXSjCjggOOOF+FOBKlUoAxULjP5VRPkrYCKTFklzC7gc65ycIvkwFAAAA AAAAXgV8AAAAKHB9cC9wL3CVcJUAKAVMitYAAAAAAAAAAHCUipT/AAAAAAAACAAAAAAAaVMAAH0B AAABAAEADgAAAAD9AAAAAACVAAAAzAD/AQD4aOcAAP4bAAAAAABeAAAAAAAAAAAAAAAAAAAAAAEA AAAACAAAAAAAAAAAAAAAAAAAdAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGpwlXDvcOdwgXCOcP+K73DqcACK/wjsAAAACAAA AAB9AAAAAAAAemmUilJSU1JSUlJTUgBpAGkAaQBpAGkAaQBpAGkAaQDGzMYRl8yXzMYRlxGXzJfM xhEAgV6GAP4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANAAAAADNaQgAAAAAADAB vYIRW7NPKAEB//4AAAAAAAAAAAAAAAAAAAAAAACW/y4AAAAAAAAAAAAB/z5H6EdaR7ZHTM0AAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAErYbUNK2OdwbR1tHW1j575txm3Gbc7YcG3/bW9K AARwbbJtP22ABHBtb22cbW9ecG2ZbcZtQgRwbZxtC22cVnBtxm2nbdbNRm20baFttOpGbadts22n DkZtoW3obaHqRm1+bdRtfuokbeif+G3o6iRtr22vSgAwJJ/4n/hKABokSgBKAEoA5yRKAEoASgBe JEoASgBKAA4kSgBKAEoAXiRKAEoASgAOJEoASgBKAEAkSgBKAEoABCRKAEoASgB9JEoASgBKAOdg SgBKAEoA2CQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADQOAQEBAQAAAAAAAAC2 AMdwwnAAAG0AAAAAAGxtlc5dzWCVlWkAafsAAL4ASi9HCJXExZLTCLuWAIDjAAbMAeEAAA7j6koI xAVMQKcISn3RSxQODNKifT9WAEC7QDwAS5Z+OkqoDsThCIGVAEAADqtpACRAUdMa4tUAGxvsNJbM ICgBPQC4gsO2RuQnd4j2Dji2Vb0H4wBwAAgHUtfhxJYglekX40C7T9xK9j1PEAAAH0tJQC8Ox/LE XsQB9l0AOUtAZgB1OjFSXKdAXUnchwBi3AjERwFU3UAA4Tz4rg7ElVEAfgEBGuPpDs6BKSjMShqe xMQpgQBJYj/EAe5JwkontJbXsycvS7ZWVbvzxONAG5WGStPT3au+HfDMvvYIGU4nCB7OCEk4zhsH AFHMAKFA59NKAEvw4YPRPwF9Sup1ga5u0ADyINtHIGY4arbCVJWBfEAAAMTnW+OPnnCh4fJwqlgA bOMHCDhbmZWV8niiXT0/wSAIUW4atg6dVA4/xJKsx8dpBLYekXm+eadACPbEDj5UNkkmATCWCIae JzGVQZUOPgEIDq4AJzxKAQc6Fq4vzkmCdxlAzTo6CMdAZXC22SnMKYHTBAHbAYFKXVE/t4GuQJXm UQAA0z8ohzFvJDovUcdROkLHhpLHsUo4g8XYACSAIHbH51zTxX3Hh+ckDuReDgiuAhuRxQCWFFYB 3ZEEBHBKBOVKIiPqOhQZ6g5K0AhOS04gB6oBRVGWCQ6Is+EgAVgHYthmVhhpPwB9KkCV04sHQEzh cAjpbkuG124AG3nA42lG4wiVlrNwTrYAcdjnYD/gTw4IAAjjrFEHtu49BGlYgerEa8gtxCQANN0B QEw6zYEFSjpA98JAcE9JzUxA9uJ2aTRJzQIxEdvE03aBgHbqSsKBfsTcxMQMcjgfQEBRxwBdQMEU X2l4Dq0p6kBeTGueXk9AgCcELEkaYYUgSuMKPwgQbH0ADJMaPIn2QjhegeW2/D5L6iiVeec/SXSB tjRdT4F1ro4/2clYVBGePjBK5D8HFHBOG+MBAKQINjjOiOEnADrMsyR9AAFCBC/ZSuMooJbdMEoB 4c22ag6xwg5/4g6pMDw4WHSAEOnC+hnNPLzEQIEAlgAwMAO7K5WPRkobS2Vwwt7YNeMONMJKDsXP P8SVDidJw7042LxOlQJSeQAOALtdPECBGwf24YhUAdNw3Rspffa8AV4QAUA9xHBiL1IHv7IQhj9U DgDjvjggPL53ogCBZwERSQBGgfJPQEnHEgG+bs/n4jjK3MQEDq7zAB9yMUr2CRBAtpV9tjvEaVXi 3BRsptM2FYJe7eERxLKyPziBlZULtkE/s9AAJI9TUDjESk0ZUg4ExwAOYksZStiVzOHEkwFAlWlO Ad4bqKmPv26O3MQOxAB+ADuqyPIAxA7MSl3u50AwcAEbJwBAOgNKvsABEuInIFgOB3PArIfCkk4I AaRd07ZKzMVpRwA7KLYOVCfuDsRHPERpFX8kVuxUgQDneTjYAUuVtgiScAjYlbMCJwDgxH2FlTi5 INMv4U9KwumxbkB3AT+V7B7QUdN9ILPwXe72zbMfAAFLJxLV41UkutgC2DwsAQ4OCMnwDi8ATBtw pUFKyABYAEDjCNzEqlIAQJZTssySRgB5OPbqBBuW7y3nUSBYDhnz4wA/CMQbPpVclQDVYtMb0+cH 58QvAABKDuHYR9NwAEVA4ATuwgBAVHDuUX2RuT0aJKWuooh6JwCd8iQOxEA+4+B9Pi8klcRAQO9R ID9sQhlikyDoxEc39iqoapXEAQW/joFABEBaSgAaiQG7ECkOgQEAAUBYxzi2hwTcOLNAAMQyAQJA igRSQMxAwjTHSiRmKIjdAD1WTlxOfcTTzJXMTuKPDsIOsgFAIgABwusIBk1AVsIOAH2yAEAokAEA AEe2J9e6KVMASZbE2LYASqSrCJasSqyWzA6CPJa+t75wSi8kCDrhxbHdCLuW9oDjAAbMfeFTQA7j BUobxAQBzfZKtThdGgjnlSQAIHC2lcLsQHYAS5azoUqoDvbhCIGVAEAADqtpACRAatNd4okAGwHs NJZKICgBPQC4gsO2RuSDPIjEDji2VTIHAQBwAAgHUtfhxJYglemN40AyMpZK9j1PvAABH0tJQC8O x53EXsQB9moAOUsgZnB1OjGxXKfCQOHcBwBilgjERwFU20AA4Tz4hQ7ElVEAfrYBGkvpDkKBKSjM PxqexMQpKADhYj/EAe4IwkonhZbXsycvS7ZWfbvzxONAAZVpStPT3atsYPDM19AIGU4nCB7OCEk4 zhsHAAFAAKFA5y9KAEvw4UPRPwF9Sigfu65u0ADyILBHICI4arbCVJWBj0DCAMTnW+OPnnDh4Utw 4VgAbOMHCDiTmVGV8niiniA0wSAIUW4atg7yVOc/xJKsxz5pBLYekXm+eaVACPbEDidUNkkmATDc CIbMJzHFQZUOQwEIDgddCJV0OeGqzbZ2Fn3dlQEOgQ4bCLZAcA+VquVcN2l0Sl1MTAB9TUrQlksH toEgaUdU0ABdvMU8ni8OZUoMfgDntgCWoWcXOFZkttCzzg4gU6QBPeMAZNspVHJdaQApGBBOj5Vw cYG7xFHEYeHCAHB4IL53RKQ/HsS6AAAAP2B9Wxu8U8JKDnB/xFzHns00oYVATvZM8gCBi1aG1yFW kIF1Vj8F+GnXBdRp1gUDacMATP6G+Xj7EgAa/pf5cPuEAAAAAAAAAAAAgAVEMDIALc0mvpIAk0w/ qQAI4HAABRtKAM0ISjABJAAAAAAAARXvh2axcCRidMwk6NzQkbHdCOJWFROHc/////////////// /xRplUR/rAchFYeHKGHn7132nXnllvErgE6GxbXQneKMFQmHPbGseQjPbe8L3NcjBCfg4q1fF4c/ ///////////FnVueFPBRqX9QXDTUmky7YXEkFWUm76LczI5vxH2HoLEkJPxc3vCNKEHqzgUTl8QA AAAAAABROhuzCIUB/AhKAVgA0efNUTpRPjAOaavnumNJAAAAAADQL5PYNQgjATUBRQGwAAPnL9hv BAH/////BVEAdgAAAAAAAAEAAAAAAAAAAAAn7OIqJzLihic/4iknP+JIJz/iSCcy4oZYI+LTWCPi 01is4pJYI+JRWCPiUVgj4lFYI+JRWCPiUVgj4lFYI+LTWCPi01gj4tMA/wD/ALAAlQD/AAAAAAAA AAAAAAAAAAAAARux3QjiVgAEAAAAAAAAAAAAAAABcwEAdjp6AADa9Vgj4lEAAAAAAAAAAAAAAAAA AAAAAADa9QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA2vVYI1gjWCNlAP8AeQD/AHAA//8AAP8A AAD/AAgACAABAFhu4jlYbuIHAIEA2ACBCAAIANhK/QcA0P/MfWD/fwAg/hJA/AH9AQABqwH9AQAB qwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACqAQC7AAABAAAA1wABAAAAQAAAAJUISgAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEbAAAAiAAGARsAAFgjAEAAiv8SAEEAUgAOACkAu21KX9Ra r1q1pqbHFDTXXPI+lQEAwD3TXCeh6ucnCHB9yM9RXZVKIHl9h4EHzMF+wwQl27QYAc7ggclCImWr JYDFdq4ATJWpKEpcDieuXH4QACieJTrTCepAAErIfho6G2UBUMwFxADTfQe/w2opzExHAHxR6jlc lSKsfyurQPYAmVs0L1IBhgEI5geuuq4OxxZAlUDmxwAbKCeHnQfzgJZd0pZWAgAAIwC7P8XHCKFL pJFHALQIhzlACgAICADMvgAI08znln1u84U+XEpKyQE8AKjyCEaWVNikVtjTxFgOSgdcDiQbyyJ0 x0o6xzx+UQARQEqXlYWyx2FdUQ5MSi+4P/ZD1hZHdQB+uxkStEpHxTVdxENJmsTBYNjH2JXMAXfn 6gAAlQmAfQ7EurEOgLaVgSzMxUdHfoQBlNDmouFpfYPTSQLGeYEIhyRJ+UkMgEkw0JI/4fYAxJVC POAIywA/lpaxxz+WEowTAZ48tsfYQGlACdtYACJA2NMBGysIttPOsSInrMAAJW4Olgd4AXZGfbZ0 5yDvcL3CYD0HZqJLXQ4EAMKVXE1KE0rHx146x0lwAbsqB0yB3Ic6lTlcwwA9xd1d3QcvGzgIsG/z A/4I+rY6ML7dlUrqkZUxBFgB5q4HpthwrpZpFAhPOhsEAOG9DlCVOr859pWszINSKZ6W/GlRPSfG 059/HofNFknYATDTcAfYziQEzup27sdxqpUF3G8IcD5+44HjIMRAXgBiPzkSlTspoRYbCD9+Ssd9 VnmvGi+ZDsR6cF20BkkkhenEBwDqxAHjTyCF3cy2BVIDSh6VAfIBAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAABAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAANlIEoHZAAAAAAAAAAAAAAAAAAAAADQA525W38376lsEJNiVXpznn+dWXtoA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA6vS2 mL50aTYFM+cI6sZwC4q86rcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAXTZ5a+CerB4HSnCUcHtw74r1ipQAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABQCzxDwHG5a7TkoAtEDllsJph5bEmWzY 0zwCANJwDlPNan5vVgGamgDTWQhAJJZKaUmV+7YptjoS6ns2QFSrkkkANAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAHGT/TAXEBgJ4RAL8IADppAAAACgAAAAoAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAAQACAAAABFI5OAAAAgAHAAAA BDAxMDAAAAAAAAoBAwADAAAAAQAGAAABDwACAAAABQAAK3QBEAACAAAACQAAK4QBEgADAAAAAQAB AAABGgAFAAAAAQAAK5QBGwAFAAAAAQAAK5wBKAADAAAAAQACAAABMgACAAAAFAAAK6QCAQAEAAAA AQAAK7gCAgAEAAAAAQAAHKsAAAAAU09OWQAAAAAAAAAAAAAAAERTQy1XODMwAAAAAAAAAAAAAABI AAAAAQAAAEgAAAABMjAxODowMzoyNCAxNjowMDowMQD/2P/bAIQACQYHCAcGCQgHCAoJCQoNFg4N DAwNGxMUEBYgHCIhHxwfHiMoMysjJjAmHh8sPC0wNDY5OTkiKj5DPjdCMzg5NwEJCgoNDA0aDg4a NyQfJDc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3/8AA EQgAeACgAwEhAAIRAQMRAf/EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCxAAAgEDAwIE AwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJico KSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZ mqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6 AQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYS QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQACEQMRAD8A8uNvJnb5 TAem05H4U0fwn+KOs1qWyXHz5AwHHp/Oo3UiPkMxRs9KaQiOcElgo5bk/wAv6VJoy/8AE8tR35/9 BpiN/XAV0nCru85wh9ud3/slcxFaSSukaoWd22gKM5PpTYke3waMbPT7HQk3PBEFmuY2VyuF3Hds 2HBL7mxkE/u17jFfxJcw6VpVxeXDPK06hDC8twFkUghIwCVB+6uTydqZ534HAruRs9EeJ3TTT3Es 02Wkdi7EjuT19qhEbnOFPHp2rvRiIUIYg9vTmhiMj5dowOBQMbkd6kgLeYuxQ5BztYZH40AadxHD p4WWQJLPIP8AVg7Qvvt29Py/nS2Onar4iuMW0LOgbGekcWccfljgZJx3qW7K7Dc6i08N6NoNvFea 1dQzSEhhvOUxlc7U6ucHPORg4ZRWbqvjmUuq6SrRBFCrNKoLAYXhV5CgFTgdMHgCsUnUd3sU9DNF hP8AMDN17ben61ZhivoQqw30yLnkISAfwzW7Se5CbROF1EghtRusH/bP5dahOmSOWczSEsMEnmhR itguwbTVBBeZsgEfw/4U3TLcxaxaqLh5o0ViFLZ2cen40Ow1dmlqZRrWGKaYQqW3KSwGSM+v+9Tv Ddskd/FexTm4NqS4GA6hsEgkD0wTz/d9M1M37rCJ2TXE6C4Z7R1G9PNV7MsFUKNqM23cBwvGf4Aa 4fxPq1tqlwC2pMY4siOJASq5PJHpnA6egHQCuenHW6LlsYEklqQP37M2cnIOPbjFV5JIyu1Zjj0A Iz7/AFrrMyAlP7+fzpjcn7xP407gOit3mfZGCxNb+mafOJvsWlWrXuonAYqMrEScZJPAwSBzxk89 KmUktxpFm68JPpe261u+swsg3DfLICx4/wBnLYzztzioV8YSW8YS0ikhCjaoSXAA9AAOlYte09Ct jnbu4e7nead3kkbqztuPtzUccW8hVySTgADOa2WhJdku/m4Y8dcHrUX2xx0cmkkMDcsxG0sTngE1 EZs/nTAFkY/dUnHtWn4YuWttYjLINr4VgyZ4yD0yPT1oew1ubPi94rt7OSCBki+f5NuOeMnqfb9a 2PCes3mh6W1tZ6IJfOlEssrykFgDwvA6DAPOe/YmspRvGzYk7MXxP4r1W8002MmlQW29djSLIS2C 27/6w7AFgBzXn7pg8qqn61VOKS0E22RtjH8I/Gmn2K1qIb+NORNzAFtoJ5JHSkM7bw34ZudStYpb RxaW0jtGLmVgrO3sOSPrj19CaoazfXegzy6Zp2syPHAxDG2bbEW4zgADnPGcdqxUlKXLYpprU5+6 iu7hTeXUksrOcF5WJZuPU+1RtZOg/eZXHXitE1shWBbNmx2/CrdvYkuET53I24HBBwT647d6UpaF RN9/DxYJl4UJB6W4P9aiTQVChmkDHYT8sSj+hrNTG2uw+TRoyMeZKPlzxtH8hTW0lFBCyTFgeCX6 5HtiquIZp2mxSw7ZQzmN2RiXYZwfTNKunR22rwNbrhBCznJzyAR39yKd9RlPxI5a9gjWQ7fKXcgb gNyOnrgCvb9O07SrHTNPMFvawHybW2nuYoV82CVW3Fi205JK4JP8Sgd+Maz2XcI9zyT4pai2o+Mb vfIJTaqluSBgBlX5wMgcb95/GuQPPat6fwoh7iHAHqT+lJ2/+vVCFGfSuj8Fabpuoaqr67O0Gnwf PKEVi0vooxzg9yOfT1qZu0bjWrOv8deOElt4tN8OoUhRAvneUYvJA4CqDjHA/Ae/Th9E0aa8eSea GSSCDBd1UtGv+8w49utZQi4wv1Lbu7GrfC2k0uaOGUOV54GcYP8AhWL5yTbFCSOY1HPB3N7+g/z2 pU9ipLQXy7mZiWiUD+6Gx+fHvVuAXkYAijhjHoST/hWjsZnaEZGcdDtqrI9rG4V7iJNoI2s4FQhp N7ED3VkI8vcw8jnDg1Xhu7SeQ7HZyBwUiZiB+A9qZXIyCKeOO5uVFrcyfvQ42QnIyoHfGOho1O9S zaG5nsJygDoVLhMg47jd/KgbjbqYWYtX1gGNXEt3KFjjTBwTgAEnHfHPFer311r8Vxe3k13BZ3EE LNJarExwEXYdqMHBGN3zdOvNRW3VyYnkV3Okrm4liMjSElmaYFiT1yKrSzIekK5BwDnIx+VdCTId iLzD0WNMn0FIhllcJGpZm4CqmSfwpiNrw9obXmrQw6zJcabZ53SSm3csR/dXCnk+p4HX2PWeN9R0 630qKx8P2FoFePEs7CPegHAUZ5LYH3vfuTxjP3ppdC46IwtO8LTH7HNetGiXCBo1LAkDPLEcE8n8 Oma6YXkdhZyR2czQNblkLW8bDDIVYsR3OSP4hjjpXRyNN3M+ZPYwJ0/tG4kgeffHG5X91GVDBWwW yecH0OOvrUVuqRpLHCrKInZdv8ufUjn8ax5OVWNOa4rruIYN83uMZ/zk0ds4wPf/AD9KVhE8UluE At9PjwTnMjGTNODEODHptuHzkEW5/nXO6lmdXI2tWzoLWIXNvGXRRkYcY49CPzzVsWYACgZBzk+l bJ3Vzmas7FNbdU1iRCP3cluGDf7rHP8A6EKr+JbJbjRbhhGQVwV+mev+fai5UfiVzmfDvhrU5Ht9 UtYYjDA6yiS4wsDYbGNzEBhkYIFd/rj+IbpZU1e7huI50CSGxglIKDJ27whYcM/RhkMQeKcopyuS tjBn8JwuGNrpcQRerTtcIP1ArAvNOu4LKZItGtJoN3FxDKJCRuzkH72P6dapS1s2KxzspkjkaN7V FdMZVlOcev8An1pokugwZF2FeRhAMVpbuSI91eM2GuZAemN+P0FdHa2dhYXHl3G28vIwrSNc/wCp Z+piAxnpgbsg+g5zVQUUxSvY7e60Lbe3kV1OXvbZ0dpVlwvmMiu3TA27iccdMU3W9Q0i5vHtdQaX T7+0Zws6fNDcKMqDIgPBIAyQenY4wPUxUIwpwcVa6PPw05SqTUnez/zLHgTT7I31nC8dvPEsrp9w EOADyfXr+FaWv2OjS2WuSWmnR2tzAylXiBEYAk2k54XJXoPyziuColFLQ7Yttnn+0bcB+OnI/D+p qtNJHAwd5FjJ7bgAe/T8q5rGnXQ31hUKGIAA7+lToAr5ClsdgM1456jL2lLttnDKAUc5IGMnrn+V XthHCc5bJr0YfCjgn8TKj2Ul1qFi8Cv5Ykkt28sZ3/Lvx9flI/Ae9aNj/ZWoeI7HQJoJknu0LFZd 22MKpcgoTgkhTjt0Jz0NqLYpSSSPUbPRdPtERUt0kZVIMsw3uc9fmPb2HHoBV5URFCIihfQDAroj 7uxk9dweKJ1w8aMPQrmuD+LFnp9r4RvNQhgthfRMiwOYkcgs6hgA3H3c5o5OZruK9jxaDRo7jy4L tr6yuGcxtKXjMYbAI4+UfNnj5+3fPFS58G3zGM206ag0i7lWJvnb/cVsGTofu5HHXg05wnTdpIiN SMle+hn2WmhbhgY2MqHaIwpb5geVIBzn2966ONJYYoryW1ltrqK58pZnUQOzfeB5PHOfmPrjsKum 3BqbNJJNuD9Cgus6ra/aFvzch3yzNKMl2PQkty2cN0/xq3Pb7rZLiCU3UjSnzVSMqv8AvKcAYyWw oAwAPfGtbEyqJRb0WxlTw0acm0rN7jLRLme48qGVlMZ/ifjB9yDxn271tT63rEuh3Gn3l4USOcRm 2igRRsOW/hUFfmAPvz+OHNdWNbWZiBtMS2X7XJcTyNkrEwaQN7+nf8OaVLoLj+yvD8h39HdePyUV cKbl8KbZnUqKOsmkjoEO4DrigHnrhR0+vrXz57BpaMxJnRlI5DsCOmeMfpV9l8wERsQzgZPTivRp 6wRw1NJM0IUb+zo1tgsTWd/A6kd/MPlEemNpP51lfEmwurOXT9bs5JIbmF2gacNtZeNyncOn8Q9O 1bRlrYzcdLmFa/EfxVZIiPqjyRoePNijfd35Yrk/nXQ2Xxmv4xJNqOn2UkK/KFhLxMGPYklv5evp WkmkhJO+pt23xn0QSCDUrG8tJyw/1ZSSPacYbcSpxz6VmfFPxdofiXwmLXRNTadxdRtIixOgYbXw CWAHUA46/L7ZDV3rETaW55o13dpIDZO9nOI87YCV3gMFwfL74AOeh5I6gCW31C+SUSXMdrceSBNI xhIdSXA5ZQrk5YN1NehCbhTcZ6r+v8+5wyjGc+aDs/6/y7Go2vNcanZxvZxSPuiz54LHDIG+Qk71 CntvweeBnFbnjO30a/0OBLlxZeVKALmUSOxBzwSGPt/D26iuXEQ9nKUYbJ7f5GlCTcYy3ujlU0K8 hSCBb6OVJMyBZLlBFhNucO5CN8xHCscDIPStjU7O2int5LBLe9nMBaRraFpFLB3jBG1sDKqrc5wW J+mKiraHZKtKpZydzMe2NlqMEfkxNcKsYDzZKKzKH5xgqQTz6HjtzvWmh6utwryjSYQmAClsHfGM YBI47+v0r2MPStTXurzutf6+Z42IqJzfvPys9P6+RZXQNUMpY615SHtBAqkfQ9P0p7+E5LsbbvxB q7j0WZV/pXVLnfxTfysv82ckORfDBfO7/wAl+Bg2WpWhCw7TI8idVVicHnOBn2p9rPLKWSKwlIXu U2/luNfFKjJ6WPsnNLVs1LBdXYs0enYyoXDOSTjPOce9X10vX5bfJS3tZSMZ8vIX8S39K7adKSVj knOF77jp9KvGsntbzXlgjkKNKqvGNxU5HRcjn3pl2ujOVOo65JclDkI0ryrnGOjsRWvsl1ZHtXa0 UZklz4JtSzNbvcORg7gOe+Oe2aydXk0h5JbZgIEYhvISP7qkA/3eoHem4x2IcpbmbeQaDcyieSZI 9zdSXAbAHy8njAwP5Vpy+XfWZ0iC6tTaQPvFsiKACpHJw2c9i3BOT61astiLvqSv4gt4be504W+2 aJB5dvGsX2dCOcqHBAOCc5GSec5zXP3msK7s15pNjN5eQrPvjOM9D5TKhIz1xmuqSpSpKMLx77tO 2/f+tzkpwnGo5T17W312LFxrdha6vvWCYNENgEkilFYMOQRGG6Ljkk+5xW/rV5o2pWaWc1+1pJGv msHj8zawBypVTlWB55XoD9KmvzKUm9fe9O//AAR0HanCK093/I56znGm3tn9ns4ru3lnDMsN00nn gHIDIpO08hgGHYZHWpmuYLhXhubX7KJEEYVJC0MQBU7tjElSduOxwTw2ayVnLmhH+r/0jd6J6/1b +mQX+nS/2xCYZkVHnlUR4O2MFsqMgdwQo77gegwT6dp9x9psbec/ekjBb69/1zXrYZycG5Lr+h5m J5edKPb9Sxn8akT74P8AWtmzJI4uXxfZWqA22iwAYyC7Ammr43vnC+RBbwK6ll2xDJ/GvnudLY93 lb3CLX9bv13NcSRp2O8AfkKZsvp8tPdO4JxkMxolJrdjSRj6pEi20sqXvnBOSq8Efjn0qjpkC3UK yNMqLj5lbBIP1/D0qJO2xUVdFfWLJ7fULdIZWlWSMscKGIxk54HStfV3t/7WlDxqWMZbORx/D09M Y5z9OlCdtxSV1cp3cLx28UawsqqzFmBIAG1SWyDnA5/l6VL4dM7ahKs6yiJlJAl3EE5HPPGaqLbM 5JIrTvIdbuZo2RZ05QkgdDxjPfgdM/hWX4hjlgmDNkwTMzId+5VPGUB77ScZ6Gt1G8ZNt6bfqRdq SSW/9L9S88b2Z/tGWJF81I5LcSSYEkpQEvgnBC5PPqR6mqkF1Ols2/y5FLiQsXGCeeSQR3J/HNdU 4U3Lli+rf49/RX+Zz0pVFHmn2S/Dt3u7fIdve4IWOOGYyOEUIQQWPYZOST6davbHtQvlTIk8YIPk ONsbAcjI75PPbmuinCne5nUnPaxeEEzpf3dpmdYdrKVmwy7lMm8AdQqpIT26HtXX+Dbw3GkGORtz wSY/A8j9c0YRylGTbutLfiRioqLi0u5ug8U9B6VuzFHnOuWsa6THeI04eYIGDTM2AQTgZNQeHgJm so5UDBo2wCM9BXzLbbR762Zt6b4XAijd9Qldzll2bkXbnPrg9e/9K2LHwrZ3MogLzXDvzsmlO049 QMD1quRy1YlKysit4+8NxaR4fd4YYA2wsSkeSuGXgNnPIz2PAritPNlLpTx2kE7XCKysxORkg9uM 8Y6DtQ47C5rIz9WW5U25nhV5FjO2ME7lX1YA+tX9fglj1Ca4TcMALjHKheeh/wB3GPetEtLMU5LV oyvtrzTSWgAwZDsLqrKmMkkgjGOpJ6jrzg52NAaIXkywrKuVyxd87jxyOB61UdzOWxmXxaPU7gvI PLDkEFcjkevtzWhaXVwNCu4YG8ueFztUgOsiL99WHQjDE5OfucdTXTT5ldR+1+mv5mE7aN9LfjoV b5rCY2zXNnGzywF2khygGMrjHYDb2A44p50yz1Z447SRZMDCoreUVAGWO0naOhJwfU1XuzfKt3+P /ADWK5pbL8CdtPs9LSS2sZbjznGJbgnaehGEGBgcnnqRxwCQa9pp8ccHloZJUjfzVBIOxiMFunsO ue346tQjZbpf1/X4kRcmnLq/6/r5m3pUFxPeGzt3eOfUbQWsTykKu5mETBsA8bGfPTHv0qHw1rH9 kqh2E28wjDlm5Rc43H1wCa3oNRc0u1zKv78Yvzsejbu1SKxNdHU5b6HjMuty3lvGZVll8sfMhbEf HT5R8vA9q3tAyNU0cFVBk80EAYAOxjx+VfNRXvWPoZLlhfudnokwfT4QpL4UL04G3APP1BrP8UnU 7WE6jo7rBNApWSQKPMKHqVb+EDJJ+nbHPda0dDlvrqef3viPU74tBd6ldTxg9JJyynIPvj+dJojq JTGJHRmibcegDEjkH1x/KueWqsaW0ZrPdaJb21u6HzncbLh0Vi0gweSev3scZ6fSrWp2rXV9NIwi AeVuCpJGSf8AaH51pZX0M23bUptpSmOVd8IzjPyPyPT79WNPsBay/IIypQ4IVhjn1ZjRZE3Mm8tv OvriOGKaaSTaGKE7QDjHTj1PPHWlg0W9jniuXVx2CzIGHuCMjjrxjFenSw3Pb2d11v8A1/X3HHUr Wv7Sz6W8i5e+Hbplt7OwCs4LETMGCiIOzLgnqPn5yOqjFVrzRtchkbStL025VmO6Vkjy9xz1OM4j yOB0yMnJAxGJoulJuPZW9LJN/p/wwsNW9rFJ9G7+t20v1+7uPn0nxNplk8l5pswjhXc4UB1VR1JA yBwcnvjnpVKw1RJEuFMDITD8xXkYDAng/T1rljPVRmdkklFyiaC6qscFleQtiOAvFIysRv3dV6Z6 Gqi7ZbIhRu+TAA9QOK9GivaSbb1cWcVW1OCtsmel6PefbNLtLguHZ4lLEf3sc/rmr6ycVpB3SZzz XK2jx+9N2sU8pe2EUmRI0ZDEexIz1AHHQ9K1/D84/tLQmzxuf9UavAjH3loe45Xizo/D939nsb1m fdFBNNlUXLDDsx+vB9Ko6nrsktwGt1kMSxlNskmFJP8AEVUcn8cd8Zrtp0ZTjocs6kYvU5qwfTVv o47+2aeG2t28oOrLk7ty7uxGSw5GPmA7UmjaV9q1aeJZCyhjGHVumc44JHYFuPT3rFwXNZG3M2rs 6+XT9N0WyZ44N8q/MZ5T5jqBnGD/AA5z2x2zmuY17WpdPkWzWOOS4VA0zsxBV2OSuB1AB6/Sumko 04uq1fp95zVW6k1STtfX5L/hzLOv35k8uKOFycfwkg/masSXt2SpleIsOeIhj8Mj3rejXlVu+SNv QyqYeNNpc8vvOi8H3klxZXLXD7isxVOAAAAD0H1NSzyT6jdLHauI0t5fnm+8BjsB3PT2r0sPUnVo qT3f9fkcNaMKEmraLX+vVmvLeMZFxwE5GOoPPP15pbqY3sci3DtMJUEbFmJYqG3AZ68NzW1SjCbv JHmUsRUpq0HYgtlWzimjtwUWZNknzEllx0JJzWRdaVaEyNGmxpF2sy9SM57/AEo+r097F/XK19WV JtPtbmwFlERG8XTkDnHBx36n9ax9Ihlto5IbhGSRXJKt9B/hXiYZunifZrZXR9TjYKeEjWtul952 ngq5zp0tqTzbSsqqeoQ8gn8c10XmcV3Uo2jbtp9x41aXvX76/fqeOB2haSxDtIGOD8oA6fN+INaO jzhL/S1B/wBXIQOe2CK8BfEj3fss6Hw24d9WtycFriQ/gwGD+hrO1nS1tWh2TbpslwkgyRzyRjIH 4n6V1e0cafu+Ri4Jy1K12gwGPO3oNuADxn3PQdTWr4H05EabUnBAUlIgWIBP8TY79Rj8fSs5e9Ln 6lpKKsXNVv43vGMpzDZr9om5HLD7i8+/OPauABe/uZJnRQzuXfHQEnmu6ULQhT7tv/L9Tjg71Zz7 JL/P/wBtL0MUcKgKBu6k0kjZOK3cVFJLT+v+CSm5Ntmt4Otp1t55HBihk24fu2M52/n1/nXTBljQ JEoRFGAo6CuzAQcaEXI8jMqylWcI7fr/AMAZn3pQ2DkGu080eJA3B4qGb7pFA1uZ1rskZ22eY6nY Qe/JI/mK5yyld7iZncsxx+HXoO3Jr5ykrY137v8AU+3xL/2CmltZfhY6Dwvc+RrE0JbC3EQbnuy9 h+Ga60yY6GvTpqzkvP8APX9T5+u17r8v+B+h5KNiyztbnzEUY3hcdelT6Za3QuLebZhYG3Hdxmvn Fpyu3mfR9GjZgWS1kup4ZWRrlgzgHp9D+JpVbqzNlzySeuapdmSS21rJqMxgtlH+0x6KP6e1dDeS Q6NpSQR8JEuBk8t6k/U81rTXNKxFR2icjrMskOmJauSJr5/tE/rt/hGP1z9fWstHVFwoxXqzjaau tkv83+LPOovmg2urf4aL8EhVd3PyAsQCcAZ4HJ/TmtnStEkaTzdRR4lRv9SwwzEevoP1+nWqpx9p U5en9f8AAJxFVUKXN16f1950YPAxgAcADoBSE9q9e1kfNN3d2GaTNIoCajkY4oGZBuW0++MwXfHL 8rjv7Ee4rBs0ZLxtx5Kfn0rwK6cMYpd7f5H1lKr7XAqH8t/8zVt5vs19aXGQAkoViegVuCa7MvXo w0qSXo/0/Q8ev8EX6r9f1P/Z/+IASE1QRgBNTQAqAAAACAADsAAABwAAAAQwMTAwsAEABAAAAAEA AAABsAIABwAAABAAAAAyAAAAACADAAAAAokLAAAAAAAAAAD/2wCEAAIBAQIBAQICAQICAgICAwQD AwICAwUEBAMEBgUHBgYFBgYHCAoIBwcJBwYGCQwJCQoLCwsLBwgMDQwLDQoLCwsBAgICAwIDBQMD BQsHBgcLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLC//A ABEIAeACgAMBIQACEQEDEQH/xAGiAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMC BAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYn KCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeY mZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5 +gEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEG EkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpT VFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4 ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/APxws9Me ycwBk3xZkidxgqemPoc/rWlEiyspkPlsOuORGwA4/wA9a8uTuz1FFxpr5fr/AJEWpaedULNGwllI KvuGN1Y+mWX2eeWy1N2tZFO6FmXo3b3/ACq6b0cTmqLXmZ0vhu8kuLVxcv8AMrFWiYkjePT61b1m 1tNVtiXTYJRsYIxAVuxII/yayl7krl2c42OW02CVUk0+TBubRjNbyKe4OevuK9A0TVU1q3trkzuH ZRnOWI9R74NaVu6/q5km0tRNZ0d9Rsry2EsTq43oHj27T6j8a4+2vZJfD4yG+0aJNvBOT+4Y4Kj0 A5/KiGqsJ6M66zgiM0bs0UkdzGCCSMdOufxrP8beHTeaHJ5ckRltTg8nJB44OPoamD5ZDb02MWxv jeXcFxc8m/tjE5AxiaP+uBiuj07y7qNWXDZbJhebrj3xzVyVlYI9zmviTbDTtasL2DChHH3eSozj BzVjwjJH52p213Esknm+asmduAwJwBV68iaEr3Oh0u4+03AQApEyErzggDvnvwTXB6bcPps/iCC1 J+SVZl3jqFYn+RFFNb/11G3exd1Kdri+iku2kJmhfbtJ4yA2efpXOeJT5vhy3LPuADbeO4kNVBJW Jla1yKyuSujz4BzJbBeRx/rFqjLwtoQTkW8uQB04krVoEHwttvtPj3SI923zruFMkdMyCv1C05Q2 ua0V5D6vdnn/AK6kVCXvF4r4Y/P9DkPGY3eJr0pnAncdfQ4ro/hfGI/CDtggyTs2cDnpXfUbUInm QWrKEmq/2T8P/iJqrEq0FvfkOD12QuB/IV+b/lCfUZ25K7yAQeeK5Z/Eb0Y6AA1zOWyTjJziormB XjgRRl3OWx6VOzVjWxe1yzXT47a1AKsq73J65I6VneQJGCgZJbP4CknZCktdD1f9mv4Jah8bPi94 Y8I+HreSe+8Qahb2ixxKSx8xwD0B9fTHrxX9E/w/8L6V+xj8HLbwF8NZf7Z8T3CReEdJtdHtjPeP cTSLPfXXlRh5EjUK7Z3MFaUttVWBf47P6vv04X7s9TBw5k0db+358UPCf7Gn7PA8GeG00618NeGL E3NxiRZZpLsSF2jIJ2B3lCYLLwc8Yr80P2ONCaS5v/HPxX8QwWmvfEeeXxJrktt50MtrZSuRaWcj KmwJMGZ/LLKGWWMgHYBXk1XaFSEO6j93X5u33m9KN5czXd/f/wAA+1f+CbxHhP4ceNP2kfjBYafb eK/ixHdaf4fe7t2heLw5FcyMLt17GaQDgnPlWlrglXyPl+wu5fjf8d/FnxFv/tWjy64h8J+Amkjd JNF0h4N17rSoYyOYXdFkAOQZABzGDc3GnSlbfb+v+3UZwi51kn0V/wCvmz3r9grw5c+LfFsfx213 QRB4O8Ew6n4S+Emi3IA+zxRvImoa3cDauJJXWRC4GS0tyGXO1x89/tR/E6z/AGsvjjp+q6XcxeI/ CnhHVzaW3hxbFp01vxDISYOGSSKeGENE8gYYxhWHlyHGlBKKk5fZ0/Czf5szqpylFRW+r/r1sj5M /wCCrX7Tt14K8St8Mvg5rAn0oW8ra5r8WPP1y5kmkEnnPsUuo2qoyBkIh2ocqPgi/l8lCkf3m64r 6zKaKp0I93q/vOLEP33/AF5FB12sAvJPGKmc/YYdiFS78lu6+1ew9dDHqVCuSAoBPtUsmLWLH8bd T6U/ICBs7unJ6VMHFqhCDMh6k/w0gIlUs4CgkmpW22a4Tlu5/wAKGFiuZGkOFGT9eKfHGqKMDP0p BuNaRmYLGDzxx/Suxj+Htt4R0xbv4iSyW9zIA0GhQ4+0uCMhpc/6lSDkbhuPZcc1nVnye7Hdlwhz XfRHL3k32q4Y26BAxOEXoPakjjFuDklm9a0WiAbsaZjn9KdJItouB96k+wJXZGls9y+6U4TrSz3S wDbCNzdqLX0JWm46CyYtvuzz12+laujeOdR0BzH4cndY3G2WFzuhdfRkPysPqKicVU0a0Ki3H1L9 3oVnr5N54UQR3khzNo+4llfuYc8sv+zyw9xzV/wD8EdU+I/nvFPbafb2zCOVrpiHBxkjaBnp/wDr qacm/dlui5pLXozrfFH7PWleBvCtzcXd9d3t3FGWUwqsaAhcng5LfmK8xsfDs+tXMq6Pb3V20KmR gqcIg6swHCgdyTitJ+6rmUJKSbN/w9oES3kQtIxqGoE7VTYHiRgf4V6SH6jb14PBr0fwV8JbnX9T c3qfb7o43qxJggb/AKavn5iP7o/GsoR9pJX2RrOXIvM9q8I+B7LwraPezPBPLaxkz6veFY7azQdd uflUD0/WvMPi3+2Pb6L52n/BkfbL0gpL4mvFyqZ6iCMjH/Am/I8Gt5NPRHNFKTV9j541nW7rWdSl vNfup769uGLyTzuXd2Pck1W+dwTcHavoD0qUjWweaWXFsDj++aajCMtktI57A9KHfoIkihkuZVVd 7s2AIo/WvtT9iv8A4In/ABG/aTe01f4rtJ8PvCDxmdry/tnmv54V5Jjtl+ZMjOGmKL6bq4cdjoYG nzy36LuzSlTc2fot8Nvgn+zp/wAE9PhxfWfgDwdY+L9bu4/suo+I/Epju5YJNhJR55FWC3G1kJVd rDJ+UkBq5f4k+GvCnjjRIbz4w+EfCXhyK8SP7BpkGjKsNs5/1b29pHi5utxDrmQxRnhhkAbvko47 FObqc9nLp0sdrpQlbTRbebM7wV4T0Dx3pV3deE/B/h3RdCDLHJ4r13T4JdRvJcHbBHKIhDB0YMkE bS5IJJOc7Gr+Bvgn8BvDlz4m+NNh4LtLa9l8yG81zT4mQLv6Q2ypvuSQoG6RwC0ZYom7neli68Xb ndlsjOpSTdorV9ex+RVxYQajC7At5hUqAuRz/kVVe6VZ2kI+RNqygryV7P8AUV9NTu3bsbVNKC9f yv8A5mjHeNbg/ZERCBgsPmBHrWf4lsH1GRJJCrNBhkZR1GeRTh7krnNL3oWG6fehZkvYUUI5Ec8R H3RnhxXSwRo0LpDCZRIOZHBGxvYinUi0KMtLmFrlmdIuLfULd1M6NtbyyOR2zVvw1d/2Zq0kQfZB fKZos4wj/wAS8/nVtJxv/WhmnZnSWdwLWAmOWNpWIB3L8rA9sVy2p50DxRviVZLa9DRTQj5QQ3BB 6d8GopK7ZVTuS6JBLbWM1ncEsdPfaAOpXqp/KteRWkScTSOUmTOCTyPSqla90VdLQ5Vi0MVwFXa1 nKl3Em3gjow/Q1t2UkSxyRuVRFJdGVfmx2P5GrlHoRHV2KXjK1TVtCZo23SJnAduTxwRWb4ankbW YZWj3LdW4JwOCynmqWsbEvRnUqWikgLjcsZ2tgE8cgfpXF3KsPG2ppCQi3NuT8wPTA6Zohq2EtC4 b17xrBFdVQA/M4BH+rYf1rB8U2rRaCNwTCvIMRrgD5s/1qo6MRU09w2hSebn5bcgMP8AfXrWfdrs htGbdhoJeT/wMVbQLcufBof8XP8ADZfODqtoDx285a/TXRix1LUs9W1a8JP/AG2YVK3ZeL2j8zjv Echk1m6bJ+aWQ/qa6/wDF5PgS0DDHmM7ZHu1ds1ZRPPp9Thvi3qT6N+yF441CJijXSlNw4/11ykZ /MOR+NfCei6YZdEurtiFCfLz/Ezf5Fc09GzenotTPZSiHbkHO3irOgWn9oa9GMjEeM7uBxzn+QqX sUtbBqTSavqM8spLMzbVx6Dj+VT6Fpn2q7LADaDtAx1x/wDXxUTfLEcW2fot/wAEMPhHdW3xs1P4 iXERh/4R2wntdAmEmx7zXpAPIt48RyPuK+Y+VXICdxmv1N/Zk+Ef/CU/td6H4o0a2j0b4YfCfT7u cG0vppRqPiN5pInExBZ5gtzLdsMlCxgj/dgA5+CzSoqmMtvy6fq/w/I9qhFRot9z49/4KceMtY/a m/aD8PfCuyv1abVZI9X17UJ18yJLFGwhYJgnATG0AE5HrXX6V8D/ABn+0n8R/DHwXsJ7e31HxdfP 4s8ZX1gj7bXwzDBHDAsMjgyRPIhYIHYYe5TopXHO9ORW1s36t/0hwS5Xru/wX9M95/bb1fUfiN40 8P8AwZ8Du2nxXskdgx0KMs2g+HoVWOe6QN9xVijO05G8xKBzwMC2/Zd074m2/gjwh8G7+DTrHxlb vbaVqlk3mXGgeFIIUdr65Zx+7ncPKQGi2s11FH5qFyompBpQp9tf8vyX3kUXdzqdH/X+f3G9/wAF FvjfceDfD/g34L/suaZp+m31wn9j6PbTS4ttK0q3jHnXUu77uyFHlbkEiNicsAG+Ovj54vH7Cf7M Wv3mgC1XVJo59M0a2vzC1zp81yWa61G5jVhtvZ3gl2vjAjWLapV4ynUvecKa2k1f06fk18zCNvem 3r/X+d/kfkp8Y/iHqXxO8c6p4k8YuXvdWnkuCpd32b2LbQzlnbknlmLHkkkkk8FK25iZMnPPNfdY SkqVNRXQ8+o7u45YzaR+bMuS2QoNVXyCSec11EPQfF+6BZx8x6D0qNstkHnJoGS7BZqRndKRgDst QCPe4UDk/rQu4XtuTkLZoFBy56n0qu252x1P8qNxjhiNcKcZ9asaDoN54n1FbXRoHmlYEnbjCqvL Mx6KoHJJ4AGTUuSgm3shpX0R1MWrab8MkKeG2g1TWV4OrsoaC0buLdTwzD/noRx/COjVyt5fT6ve SS3csk00zFpJ5WLMxJySSeSfrXPRi5N1Zbv8EXN291BxbptXk9MmmrGZOWJx6V0eZG2gSz+UuyLl vQVGkA375eaWwPcJJnnOyHp6npU8FqluAWwWAyWPalLQe4Sg3a7clY+5PVv8BTWkWJdloMsPQfzp LQXmOjgEX7y/OT6Gus8KfGm/8FafLDptlbzfaTGEecHam1Qg+UYzwB1PWqWstA3RHP478UfEyS6i u7vfBbpJI8SlIIUiXJYueBj69TgV0Pw1+HGqeOdDtbTwsiMtw3mXtysqxqAxXZE7MQG2hQ+0Hq/P I4yq2sOnaC0PcrH9njQ/Bvgtca9o8t+kqm9ji1GCNpLcAh0WRmUA52k8gYBHvS+Kvih4a+EXh+H+ 0bmB4XjV7TQ9HYNLcqRlWduiof7x6jpms6NfmbSWxm1O/vHzx8XPj7rvxVcQ6xMLHSIjmDRLIlYU 9C2Pvt7t05xiuHXc/C/ItdGxajbQXIIxbLub+8egprx7ZP35Lv8A3R0p7gwWNpGwQcf3E6mvqH9j v/gk98T/ANrO7s7yOxTwh4TuFEreJvEatFHJFwd0EWPMnYhgQEGCOc1x4zGU8FTdSf8Aw5pSpOq7 I/R/4JfsbfAn/gn7pi6hp9tB4p8Y6dGJW1nWIfPuknAeQbA2Leyj2IW3ZMxXoFORXSeM/GuteIPC 1vefF/VV8K+HpJmjg0aaWRWvpDHgAQKzXd6wbadxWOEqjEsRkH4erUqY2p7So9X+C1PQjFRjZbfm Z3h7wn4o8Q6Glt8KtJhsNL06QwReLfEjxyXdvI25WeFTGbe1beQmER5wu3cDjJp+IvDHgr9m6+Os /GK+061mls/NbVPGc6L9ofyjjFpkvOXGN3mnr5ZEZOAKhTuly7fixTqNNpPX8j4y/as/4KtJFrss H7Nk97d3cOUHjPVwFeNQRhLSEKojTj+IAHj5Bjn4v+KHxl8R/GTxNLq/xD1W71jUJeDcXTfKo/uq owqj2AAr6nAZdGlarNe8zjqVXbkWx6Jp96nmoAqYcgZTIxnjPSsTxBp8lpd+YrYHoeMqexrop6Ts +qOupG+FjJbKT/FIdpkp0yRY4m8yKTPl7+mMcofcda0vLj8olgSHxwCCBW0lr5nLH8jFltP7A1CR ZAv2e5GG3DIx6VoaJrgtofstwWVohhfKGDKh+6c9/Q/SrkueNzOD5XY0W0j7RGwuwyo5wRjBHt9a 5+WBrfzra3I+02jeZDg/MSD0/KppWkmiqis00dPoBtdR0qG6aMhupHv/AFqj4u0xdSgeS0T92nJ3 Dv8AU1KbUhNX0ZnaVPcfarS9JRFnQ20x5OXHKsR2JroWt/OtQQyAREk8YIB46+nP6VpJJahT1Rkz 2Rt9XgadkIkJt5QeQUf/AOyx+dO0uJoo1glKF4S9qxIJ+42Mj3IK1duaN0JWTLGoQyDTnjuYI41T GXUYbt2rmPD22xvLZpQwRLtoXdwSm1v8inGNouwpPW6OrNsLC4LhFVAdxZXIOR/9fpXOa3ZNJ4xs J5A6rcqyFn5Lccc1MOrQ5O5DqOkOLezMYLkHyw45xgkE8fhWXqtgE8P3JkBZhIw+YcDKg561a3Ju 4rUg0uzD+GZWO3zBbueuMgMtYWoviO2yTkQuDz/tPVtIUNzT+CsYb4qeGUIJB1ey4HBx56V+mGg5 N5cMxJMmpXbE88nzmNZrqXiU3y/P9Dh9UlJuZWGeWc4P1Nd7ozjT/AdizHhYPMJP0Jr0Kq1icFOO jueP/tcalNoH7GFva2Qc/wBtaha2soXgFcPMM+vzwp+OK+SIomsPC8EMY2y3Uu4jBxhRj+eK5Km7 XmbwXumM1rLgSOCVLFz6Af5NbGkaULDSpricESyJtC9DluePw/lSK2ZS1JDa79iHCAKBj+Ijn/Cu k8I+FpGaC3tI3luZSqRxoMl5CcAAe7E1zYiXLE0pRTep+9n7FPhDRv2MP2HdJk1Ownh8ReENPbxL KGtIwLzVLvdHYW8b+Yp82SJjIpILbWlVVyVLfQfjDwje/sZ/si22na5NPc3urT6j4v1671MbZZJ5 n8wQy7mYBkBiXAbOVbHfP59Z16s6i1u/10/C56zfs4JP+v60PiL4J+AZdP8ABF/8Wv2kL2E3/wAQ bVfF+rafnEtlosAI0mz81HV0hupHiMu0MNjINnLFfpz9h7wnqP7PX7J/in4w/HQy6b44+MzS+Iby K5HkPpHhm3D/AGO1Dsp8tWU+ZsDDCyR4AMZU3Tn7Sc5LfZem36r7h1UoQSfT+v0f3nn/AIP1Cz8K 6j4r+Jnxru/s9t4l0q21DWb6LUBHDp3h4MgsbOJFRJluL6ZXYjeAFXzQXKGOvWfgZ4mj/Zm/Zk8T fFD46WlxoWu/E61i1u+spVCR6boimRLDTlhVsJKYmSRgFB/fKrAFSRDXtKrfnb5f1b7if4VJLy/r 9Twb4deED4n0/Wvjl8fr/TtKt/EtoHtbS5tklW08OLeL5Fjh4srLc5FyTl+DHuACOW/MT/gqR+1R D+0V8bbnR/A13DL4H8HyfZrO4s5S1vqMscaQG6UbEGwrEqxjYNqKB3r1MBT9tiXPpH/hl9+j9Tlm 3Gmov+v61PjTxBeG+vGJGFXhE9feqVtpu6Fp7nKxoRj/AGj6V9tBckUjge5Bc5mkLHIGeAedopVs mjiE10vynIQepFXeyEQPmTJbnNL5Js+Zh87dEP8ADQ0AwRtNKFQFnPpT5QLAFVJMv8R9PYUJdBlc RtO2MgepPap7exnvpFi06CaZj0WJCxb8BSclHVjim3ZGqngc6dElx40uBp8LDK2ow91J7CPPyfV9 vHIzUOoeKc2j2ehQ/YLF8B4kbdJNjp5j4G7p04A7AVgv33+H8zT4PUytvzfvMg+lSLLgERA8d63s Z36sIsM3zc49KSafIIj6etK3QF5jEKxqTn/gR70g/wBIYB+FHpQ9dRqxZCrAoBOAR1xyaa0in74+ Xrj3qbX1HcY0r3DkJwv609ZBbALAu5/WnboJbjo4gcteHJ7Z6D6UANf/ACxghR/EOv8A9aku499j 6s/Zc/Zm8F3/AMNbe/8Ai/rVxI19Kbk6HDLmCPGVR5UU5L4z97pnpXqEfwD+FGFTT3mVt3CW8R+Y EEY4rz61arGTUY6FRjF7s+Ov2j/AMXwx+LWq6RpFz5mno/mwK0od4425VJMHhwOo+nrXBbieIh04 3N6V3x2QpPQFZYzgAyP/ACp5TIBnP0jWnsK+th6qz8Y8sHoq9TXuX7Ln/BPL4j/tSul34U0W703w 2u5pvE+oW8otlVRkiMhSZHJwoVeCxALKMkc2LxUMHTdSb/4JdOm6krI/Rf8AZ9/4JvfCL9jBdJv/ AIlOfGnjkSmVdNtolvLvaqvuK2pKx2gyFZZpZG2kE5I4Hufi/wAd6jH4XtNT8UeJ7bwTo2pypHFa RXLxzPDuASH7RGPMmdklchbdEjVt4MmCDJ8LXxVTH1PaT+S7HpRhGnHlW35nDeHNQ1fxfYjTfgFp V7Z6HprIYPF3itY2hs8SuqlISxhWZXbIO2ec+ZkgFcHpvFPh3wt+ydYT+MPit4pMt+u4jxJ4slMU zux/exxQKftFzg9Q4AOQBGoAWqjDn0a/4LFOfK9N/wAj5D/as/4LdaBoljc6P+ydoNzfyvCIj4s8 bRo8kDBm/wCPS0RvKhTacDPI/u8Zr89vih8efFXxq1x9S+JWt6nrV27O4l1G4eTyyzZbaGPyjPYY FfUZdl/skqlVe908jz6k7NpM5F7kM37wmRuu3ooqC41IKuJW6fwr0r2rXMdnqfRNp8P47CWN7jxH ocUav8qCWSQg/wB07EP/ANetNvDGk+IRIZNbtIFh+UB4ZW8zkktkL0/X6V4060uZShTf5H0GHhSW CrQnJc142/G/6Gbc/D3R8uq+KNPRDj5mguRsbOA/CcYqXTvhfdag+NK1LR79sf6uzulD55wPLfa3 OM9K2eLcFzVYNLv0PMhQ19yVyvr/AMMNXFrIl5puoJGvBdYXIWuVjge0iKxRk3diSylx/ro+68/5 4rqpVYVov2bTMKkHTlZo39NlXVbSN5pZCX5BQEg+lZ+v6HPb3K3tkp3x/eYjrVRVpWWwpzdkWvDc /wBi1N7TDGG7Bmg2kHaerL2+v51uz26biHCkScFQCDn1IPH/AOuiUWiVqctqFi+l3l1YM5iLp5sB HyjzV+ZfX0/StvRtSfXLSG4ZAFlUCSPb91h1/XNW48xSfLoReK9JW8sTNZFo5ogd3T74PB/PFU9O uU1HUCUAYXcUdypU7f3gwj/jypNVBaWRlJ2Nu3szeTukszqzqQ3Ibn06evvXFanaDTU1e3LsroEn jGRglTz+PSqj2B6o3bJFvtN3SszNOgMc7kYx71meIbFrNrVpA2UkR9w6bScZH5iko2HeyDyjJZh4 JSvlzsADwSMg9Ki12xZtNvImkwGVmxjaCdtPkuJ7GJpKtP4XhRcZa3lAZTz94ZB/KuU1aNoRFuz9 1xyOnzMKbWhVPRm78BITL8aPCCqCf+J1p4IA7faEr9I/Dz8uxGAby7b6/vWrCNtTTFbxX9dDiL5t 3m7epDfrxXda6/2L4fhOm2wYenJQivQqNuSOKOqZ41+3bObH4T+BtIBYG4upLllUfwwwjn85RXgP /CKi5tFacEeREVAB/iYYzn8c/hXNJXNU0VNZ8IRJFDHaEEyukOMAcDLP+Q3VZt9AN9IHRSsakswb gZ5/Lt+dLZDVmyhrfh+JdStII1IkU73aQ9WOMfXkr+Rr6l/4JWfssr+05+194e0m/inOi6O7ajqM 8cZZI7eEbm3vkBAcbQSw+YqAckV5WYVHTozl2TOiguZ27n7f3Pg7T/in8XfBnww8e+GxqWkT2n/C deKJZSWisYYdjQxPKJN7rtdI1j3yZW7kBAVfm8H/AOClf7Q+gfGH486D8Pmv73+ydduP7a1mdI3e K10m1ZZpYJYQC0iXBSRQAVO5k5xxXxWHjyRvfVXf3K/6npVPfaVtG/6/IpaJa6r/AMFAvjdpPw48 O3tu/wAO1v7bxR44iSxhghtdCtRENN0sMiiNGlWNV2AgxiVlOVhNdr/wUR+M2mfHP4y2Pw7u7yKw 8G6Tpcmq+JxpkxthHocG1YLCM52mWeXbGoUEZzxtU1pS9yk2vX59PzX3Cq+9OMf603/Ji/Crw/Z/ tN/EfTdE8S6PY2ehfDjUo/EfxGdLQxJq1x5sr6NoeJkDsVWWLfGwG1VnQgeYgC/tL6sn7cX7Qlp4 YuPP1HwP4Pu7fVNdgguP+Q/qZcrZaMU4Gx2iZ3xwsUD/AHSyGpopRi32X5/5X/AVW7kl5/199vxP kD/gs9+39/wjulD4UfDcRSXt1aSzXniHTZ2hEEk8xa5WPywvmxs3nom/IVJHIUE8flNqGnS6ggtb f5YlOWYdWavqMnw/s6SfV6/18zhryu9zIX4cNd65HaIzKTzIRzsHv745x+Hes3xhEjX32bSwTbWv yhh/Ee7H9a+gXQ5R3hDwR/abPeawyw6fafPI8uQJMH7orK1wx6lqEs1jF5MG7CRD+Ef/AF6paiNK HweNC8PjVNcBSSb/AI9rdl+/2JIPasKDTrjXdREVrG9xcztgKASWNOOrYjp5/BEmhMNL0KF9Q1yZ C9w8IytomMkZ6DjJLHgDmqumeENIsLgDXbiTVJ1bE0enyBLaAf7c+DuPXhBj/arCc5NuEN/yNYJJ c09vzKuo+O2tZXg8M6fpWn2ykgeVarMzj13y727diKbPrOvx6OJtS1O+htJMeXbCZoxJ6EKMAiiO Ggvi1fmN1pdNDCtbK41u/SDT4nmmlOFijGSak1fTBoEwhkdJbnALhOREf7v1ro5ehk5a2DTPDk+o Wj3d2fIs4/vXEnAYj+FfU1SubrzX8uxQ7M4Hq1Ak9RJ4W01dl798/wDLLPT61XjElypY8IvVj0os NO45FMxAj+703N/Sp5HXT8AjdJjOKnd2RV0iJGkny7/Ko6sxpn2kzShLcM56DFVy20RN0OabyFw7 fN3C9qdFKUQOx2qPWpt0Gn3J9Ot5dYnCwB2X+9jP4Yr2LwN8MYPCFrDdeJ7V7vUrggWWjR/MzN2Z wPw4rOb15S4aavqer+C/2dptY1IXnj+NdR1y6UMmmL/qLFOgLdhiuc+Nv7QujfBOG40D4OyRXniJ gYr3xGqgpZ+scHUFs5G7ovuelL3tES+x8zXWpS6neSXF/LJPNKxd5pWJZ2JySSepJ701ZDIcE4A6 habVhk8Qyh2DaPU9TXq/7N/7GXj39p/Vo4vhro7pp28pP4h1U+RYWuACxeZhjgEEhcsB2rmxNeGF puc3ZIuEHUdon6Yfs/8A/BJT4J/sraBZ6p+0DrUfxB8Z3CxmPS/sshso2baS1vbqwaYLuC+bMREd wfC4Ab6HX4p3cXgy9u1fw/4E8OX1tJHpk2n3Ae9vBvwEikWPYF2lz5NpE3zLGWdc18PjMXPG1VOe i6Lt5s9KFNU42X/D+RyXgbw+91o9xc/C5J5LnUrlmn+IHie6jit4ArLEJBZyttWQtGCvm+dOGbcA FVFM/wAQPD/w9/Z91ybxl+0P4uhfVo4U8u+8auZJpXjkMm6C1ZzNLnoPMKKeMQ4OazpRTtb/AIcJ TcX/AFofI37Tf/BemLw5qz2X7HmkbGgtlt4/FfiVFluY3C48y3gULDCRxtwgA5+Wvz2+M/7Rni34 9+LrnXPixrt/rWpXTM7TXkpbbuYsVQdEXJPyqABngV9XluV+y/e1fi7HFVqr4UcLPeF3yxxTJL0I oBJr2lE5nLuRSXckuQnyqfWohGNx3Hcf9qmtNCuXl1Z7jr00mjTkxqZYDwfLONvPBz61N4U8SJqp aONsTRjLbiMsOzVny3VyYz1fY0bx1kV0uUHAxkjhj71zupaqdBvkk+7t+5t/jj7rn1HUUQhdDcrP Q7bwp8YdV0GxD+Fda1GzDgEi2uWVWH06du/0rV1f9o/XI4EvNTsvDmvT23IbXdGtbiTbwD+8ZN/Q etefWyqjWm52tLutDsp42cElo0u5P4P/AGvre4vI7W68D/D9IpVJiSDSvKAf+JSqsB7jArq/+GiN KuIWjPgLwcFbO9DaTFc/9/eB7CsJ5TVUrxryG8bC38NXOYvv2rzpt7NbWvgH4d28sQ8y2kOkBtxH PG5jg4yOP1rctf2srvWILeeHw74L8qcB1Q6HbnHYjOM8Gm8ncvirSfz/AK/EPryW0Eil4p/aWudM 083UXgzwFfCI/M1zocZbb0OCuMfWqWh/tN+HtXkmS5+Hfg3Cqs6HT1ubYlXOH4ExGQ2OmK0WVzhr CvJfj+YljIP4qaNKT4t+C9REkd94DUwyDASDUrheP+BZ5rk1+JXwvtbpIbnwlr+nyW1wUBttaEo2 SDBJ3xdAT0/WqjhcZSVlVT9UP2uGl9ixrzav4GlGy0k8V2LjnfcC2uhnOOg8v+dcf4y0/wAODW4J B4lMTTRNC0d7p0i5yP8AZLiuiEsVTfvwUvR/5mDhQkvdlb1NPwXa6Aug2+PFVrIETZtjtLkLkZHQ oD6deKj8b6Vof9hb5fEbxpCMbjZSEZ3A/Ljk9O9ae1rvan+KE6dNy+MpaFF4ankumh8UF9jLJt/s 2QMwI6Dkj9RWtNp/gp7aaTV9c1uaIqrtHYWEa4JPKZdxg/QEVlOpipR92mk/NlONCL1lcwfDvxA+ F/hxIYdE8P8AiTWWUSDdrmoJAoGO6Qr356N2FYfin48Q2brF4M8LeFNNRd+2Y2X2qUZJ/jmLevpW SwlevriKll2jp97NPbU4ySpR17l74B/GrxNrPxw8G2c+oslrLrFjC1tbwxxIY3uF3rhVHGCfzNfd fh+U/wBkJIvRnuHyv++xrajQhRuoKy/4cyxUm+Vv+tjirqQvkD+Ljr716B8QAE8OCJf4khiCg/3n Vf616M37yOGCsmfPX/BRjxpDo/jbwrpMjKZbXSmnRO2ZpgmfygrzSHUA2lxuRIGKl2LeuPbtWaSd jS3Q5rxR42gs9ShgupA0og3hCc5eVv0IUH/vquus2jtdMhhkkKlkEkjBTnBwcY/EflTmhLQ5jUvF kEnikqh8xtvygHjfkgceuSfwxX7a/wDBD34Jad8Cf2Srrxd8RUith8QFl1C9TUIx+88PWNwiyshU kgSysY8uEB5GRuBPy+fVfZ0lHrJpHdg4Jyv2R7p8Lvi/Fpf7PfxB+N/jm51Jbz4t3NxcWlnqxEq2 Phqy8yOPy42LLGJLhpGADHhYSOATXxh8EtB1Px94k1v41+JrubTBrF0bye3a9itPK0aFswWoUjeW uCqyABSjCJcqQ65+alJJTl1b5f8AL8kejTj71n0V/wCvxPsr4MaTYfsOfsTal46+Md3qC+KvifKf E2ptqDn+0rfTcsdLsmZ+TIFYMUIB3yuhztFeYeEdc8Q/DDxL4ostY+zz+N77U9KvbppIlaW5167T OlaIsbu0RhtHbzGVDu8wtkfMrs5yUaNu/wCX9NfcZxXNUbfT8/6/M7X4meM7z9nP4O+HvB/hO1s7 v4geJ9Skke4uFCxah4ku12Xd+pf/AFdpDh1V22oIYwQAOW8G/aK/aMsP+Cen7Nd0fDd3YT3N7Jew 2twWRZdWuHdo9Q1oFCH3Xcmy3iGNyQQo3+rYNSwlP28oQW8nf5f1dF1Wo8z6LT+vzPyO1nxQfGM1 xq+uzRfa9QkaU5IXGTngdgM4rk9b8b23hmDzbSVZDuKIu4Es/c/Sv0DBU+WP4fceLUn72hatdfWw 0QLazxPLqMYaZ/vMM8/gfpWDb31rq+u2+nxskbSHMrDA8qPqef1rtUbGKvqWPHvjG2n0+HSPD7/8 S2yOPlP+ufux9h1/zxk+BrvTZ3ur3WJgY7EgwwYybiXPT3/z6U3pdsFdl7xFpWueKp11PXbf7Fa3 QzBPqMi2sBX0jaUqG/4DnNbVne+G/hHo6SCdNd126CvtsiUit068yMM/gF565HGeZ1ef3aWvn0R0 Knya1Pu6s43UvHd14wu/sDPBY2TP50lpZgpHxk73JJZ2xnBckjtgVU1/xLEtq9hoBMWnI29sn/XO Bjee9bU6SpKxFSbqSvbQh8P3OnWdq19re24wcQ2ecbz/AHj7D/PpVPVdel8Q6nH9pcBnOyKEH5Il znAz0HNa2IW5ffxPB4ZgaDwtIPOkRRNfHG4NzkIew5/z1qDwuNKeG4v/ABPOzRwn93aKTvuX9M9h 70WuIqeJPF8niS4jRtsNsuFitIuEjHT8/ekfV7TRbXytJCzXR5e6YZC8dFH50rD7Ix451mkL3bNt zyT1Y1Jc6isrIsKYUYABHy/Uik/IaJJdQS3GLLc745nYZ/ADtUVrLFGplvA0jk/LGQefc1SXYV+o 27vZLydftIZU9FXAUUSXnlgixR0XH3sfMaA2GxyLGgOxnlPqOFrS8O+HLrxPfogjlcs21VUHLn0A qJSUdSoRc3Y96+G/wkbwtc29vYWqaj4ilAMdovMdkP77npkete6eAfhhb+D3mvNQuoJ9VRTJf69e MFhsU6nBPAx9frXPFPW+5o3rc8K/aO/bJF7bXXhn4GvNBp8haO+8QOds+odiE7rH19yOOBkH5xaR 2kLTKWOemetdEIuK1Mm7sdtmcj5Pl64Fb/gjwDrvj3Wo7Hwpp091cSdIoh27knpSqTVOLlJlRTkf ev7J37Evwq+HVjaat+0NBrvirXntll/s7yYo9L0+diV2OPN8y52EZPKKx+Xbj5q+rvE/7a0Ezw6V 8I/C0nhvS9Ft1t9NbTora2lSKMYUJIoIgQL5qYEbvtbCuu5hXwGY4mrjarb+Fbf5nr0+ShGyfqcp 4v8A2lLTwv4seb4Z+EpNdurqfzJPEfjK8SeTIkBQmJY9ssgyp82ZnbMaEYwAvRf8NWaR4Sh0rVvF OiXOsa4Ldl1DUdXvllLMy/vF/wBXulBYEBXPlYx+67VxKnJRXd/1+g5VIR1/pHzt+13/AMFm/FOg 2D6J+zf4bsvC++E2sniG/Md7eQIvy+Va5iVLZdu3/VqOo4GBX54/En4q+Kfizr9zqnxE1nUNWv7j DS3V/O8rvgYGWYknAAA9AK+yynBRpwVSbvJ/gedWqXbUTl3EgOCcfh1pjBscHA9q9tdjmvqNKMqj cx5NOVVUZUZND12NIpRV2NKM2eSPpQsXufqaaSSIlLm3PV5db1mdyv8AZU+w8EDH+NY2n+Ftdh1g 3NlbXMKodwJAJx7gGpUOUlNGvLqeuLDIP7Nmk3fxHHH61R1C01zxBZiD+zZg6nh+Bz+dNQY79Sfw 94c8Q6BFsmsp25PyNgYPfnPStLZ4mVgo0pjGRtKmRcMPzp8gotXuc5J8P/EEWpi5t7SW3RJF2gOp Kvnjoa6Jk8UuXIsslhhwzjnH/wCqmo3G9dSDxB4U8R+KobZJLBIpovlWRZRlh70af4K8U+G7VYYr cMpJKl3AwT1/lQk0HMmbMWm+LtU02W1vrC3aORCCxmwRx1AxWLpXwa8T6Rc/aoI4TtDYXzPl2n8K fJYLqKszoU8HeMGgU2llZKpIIJuGJP6Vh6z8DfEus6s89zHax5wCEkP3vyphezNSX4deL1tisb2e 6P5T++f5yO/3aq+Ivgz4n1xLddR+xB+imORj/wCy0NW1EpIl0b4K+J9CUwWktiQxyFkd85/BcVpX nwV8V6nYyRX9xpwibA3DfkZ49KEnYOZXuiKz/Zm1/wAODdb39p+9wrBg7D69PerUnwD8STQNGdRs SrDJXY/+NEdROSvc566/Zl1rSLd7kXMD5z91W5rj/EfgG/8ADjiXU3V0X+4pA5JH86h6pm1NqTR2 /wCyraWurfHbwdEZBDd2mr2sybvuTRrKGZT6MMZHrz6Cvu/w5KG8HQuP47eVx+R/rXFFNNo3xNlZ rzOVjQyXsCLnDSIvGe7Cu98dMZ7uxt1H+tvLeP8AL5v/AGWu2p8WpwxXu2Pn/wDbX+C8fxX+N0t7 JeSwPptlb2iJHg8AGUE+nMh/KvPNH+CF9YoRJr+pRp93aiBu3+6eK5o4hbOLN3G1tSiv7NNhrF8L q4v9SluVK4nQKORgDOVGMYFal78A7yZxM2u6k4kGMM6ruGOn3cYq5VWlfl0Hyxelx/gX9kA+I9et 3a+vUIcEzbGkAAIH8CnOPSv0M8Z/tKePPEP7Olp8PbfUo7fRrzQrXSG/srSbpJUtrQwsEV2TksYl 3Ef7Q4Br5rNpUsROF/s/1+h24eMoKSsdB8bv2lfEXxy+A+m+E73XdOt7CDRrPTo7PSrOO2kt7S2A 8uNS0YK4CYOOMZAqH/hYPi/xZodlpkuvu2i6VPpV/La/Z4nSWG0dPIhIKkGNCnEf3RubAG414UcP S5Uu1/xOh1Zxk9N/0Z6F+1p8YvF/xW8V6RqfiDX3vYND1Oy1OCGW1gMfnxODEdmzaVBwdhBXj2Fc B8H/ABP4u8NfGC18Z6l4lka/sdQ1JIXubaF/Ku7+OQSXSjaAJdpVFk+8ikAEBVAqVKKglbZW/P8A zIhVd7/1/WgnxB+Ifi+1+KMPiaTxA890ljdaTb/araBktoJRmUxRlNqPIgeMuuGKO65wxz8d/t6X Or/tPfEB9e+JWoT6hcjaEVVSGOFQgVUREAVUUKAqgYUZwBk59DLKcIVYytsrGOIqPkPnvUPgVbiM NdG5YKMAea3Ax2rLb4H2MkZeSCZ9pwiu7HNfZQklE85tt6Igj+AV5c5aw0++Ydm+cL+Z4H51dn/Z 9tNNtf8AT9Q0qxunUkyyXTSNjH3cRBz+dTLEwWkfefkaKjL7Wi8yHTvhT4V0+3U6rd3ep3RYBrew hMURTnJM0h3A9OPKOeeRVO4u30Wd08DWVrokanaLiyU/aSO5845cZ77SAeOKmNOeI1qKy7d/Ucpx or3Hd9zLbwbC1vc3esI11cuMIJSWLNjGST1rGl8IsWyqKRgE5HIPpXYoxitDBtt3bEvPBiw5VI1H GWcjr6VSt9Cjyd0aYXqAB1H/AOqlYd3Yhl0tHcssagA46Cny6WkVsp2J8xwTt6U0hN2sRw6UgPzK D+FQXdqJZCVCjnGBRsO4jWqx2+AOTx0qt9mAcnGBRYCJrTMjADpT2hCR4GODSQDUg2N0pnleY2W6 jtQCHyQg7fSmrABkD060Ctc1/Bvga78WarHBpdvJPI/SOMct7+wr6D+F/wAK5NHk+w+Eo459YC4u 9VYZhsE7hT3P6muSpO8rdEdNNcqPXtL0zQ/hH4Qur/Ub0WGnR83mu3JPnXkn9yIdWJ7Y/CvmT9of 9p6/+MDtpHhVJdI8KQN+609Ww90QeJJyDycjIXkD3IzVU4tu7MpHkqafvYYHNW7XQzIQMAMeBmtn KxPKeq/Cb9nOfxW0c+o/u7Y88jrX0p8OPhzZfDXVLG50eGOBkJV2U43Bl6/XivmszxntG6a2O2jS 0udrc+Ix9lmVpojJE8yrskBwN28f1rQGoJBdQtLL/rYzgkj7o4/9mrwpwdjS/QytZ8UxPaQoJVLR 5yv1BFeeePPGZmvLeIytsulkQ5bjJzVUqXPLTzIcr7nzn8W4Pt0FwcbpUuVkLE9nTB/UV5fd2jRy NnHTpX2ODfuHLJFKSHaw3LUEkBC9M/Suu5NrEc0GISDnIOMUsdsxiGwE/QVV7Mf2WP8AscjdI3Oe vFKdOlIGI3P0BquZEWPqj/hHE3Z8sEe4qxpejpazuHXKkc+h9qlPuYdLE03huC3uWKICjDI470DS IY0JEaq6+o5PNPorF3adi8+nR3lsQVUuB1HemQaWp2+Yq7evSmpA3uiDWdMS2lJVF2l0IAHXBrRt tKiF45aNSH+b7v50o9y7tpE8uiolqDGgAVs9OaW+0tZ7ZDsGQQRxnFP5mb1tct2mmxCLhVwcjAFJ Z2IMJj4O3Ixt7c8Vo2yn3H6RYYt9oG7bVhrRvtEgUH5gDjHQ0m9EEWmrEa6VunYBc5weRU1zpyxp C7AhlbJx9Oad29AWjJrnS0M8b7B16getWrrSlWzkUKdo56UX0J9CvfQLfWakjleTgdKI4FVWABJK 8ilGTSHbmRQuI/M0qSPafl9frXBfGbwx9v8AhrqTQQxkxw+YTs5wjBuvXoDWTdiqd+ZNnnv7H9jv /aY8LbI8BJJpDjp8kEjf0r7g0iURfD60YHObNuT3yP8A69c0XdndjYqM7eRz+ixtP4hsYl/juI+v cA13+tp9p8e6PBgn/SzJ/wB8xn/4oV1Sdm/Q44/CeW/EHUDqHxK15/vFbp4+Rn7h2f8AstZC6W0m QUPBJJ9KmD0M3uSadpqW0zoqnrnJ7cVo6Noa6g8asDhWIKHIqalSyZUUm7I9J+Csul6dfPD9oj86 EszY5CYxnJ7dT+VeueEfEWm6ha6UY7xGjivLi3XOVypLjuf9pa+XxbcpOR6FNWiO0eyg8S+FBb3S pIbGSWJS/ODyQR6fe7VBoFjd6T4bMmg6hDvvbSaF7DUMlN0bBxsIIKdD6j2rzqlO7ulqbQnbR7Gh qXi2/wBY+HiNeaSsIEaq1w9/HglDj5R94k4B6CszUvFl3LpF2YLPTVjdre53DUTuDKMZC7Opx/8A rrOSk+hSjC+/4FT4h6ze6laxySrpcEalJFENxJM2Tx3RQODXjvjHw+LgyvIltIG6I5YDI+hFdGFj NSWtkTOVNLa5wes6c1tHvgtbJTg8qglxz0+fNc5q9zqC2pW0nlgKHI+y4i75/hxX0tClB/Fr6nFO tKLajovI5u+0+61K4/0+WaYjnMrlu3vVDVPDSM8W+VSzcHAxgenvXpR5YaRRytt7so3PhiOxjb7N IGbOMEECsaLw4DPItwVVcggtn860U+4JXWpDrNpF5TiylV8KGxjsO9ZK2KyhT50YJBUgjsM9TQp6 DUSHVIEWSMSXMCg8ccYI+tZN7aWUTbLe5iLMxBOQP6+9PnQWKM9paRtILe5iIUAgs4qrfxQkApcQ HBHHmD0p83QOVjGntI5wJ5QYsZxGwJ+lNe60td4CyMT3L0uYEncrX0tm8C/ZGZW7hjn+lUpTG2MH 60uYrlZD8nnE5zx+VSKYthDLk9qXOHKDSqV2hB+feo/IC7t6gg9C3FJzQ1F7CtaYTLEADua6DwJ8 OLzxpqyQadHv3clm4VF7sx7ConWSV0aRhrqfQ3w0+G0NtYtY+EH8iBRt1DxI6gF8dUiz0H+ea9A8 ReJ/D/wP8GRS66Gt7Jsm10uI/wCk6nIOrN6J6k/4A8+hbd9up8pfGf4xav8AGrxGsvia58u1i4tN ItAfJtE6cL/ex1Y8n6AAczpXhyXV9WgsNHinvb24cRxWlpEZJHY9FCryT7Vp7XkWpKhzM+yvCn/B CP43XnwtXxX43g8OeDLeXiHSPFN+Y9RnYjKotrEkj7zyNrANlW4yMVr+Fv8Aghz8VpYZbrxD4i+H ej2dqxjllvL24mZGBwUISAr5gOQY928EHKjjPjPO6MpOCTfa3U6/qiSTbNXwd/wS9+MclxdQeEPG 3hKLSLPeBq0ytDASMqPmePAUnGBnfzkIe/a/GP8A4Jc+LPhL4J/4SP4tfHrRNA8O2zGNtZ1LRmtY 5J1Tc0UKtIJZWwG2rsDNgYXk7cXisPUvJQu/zG48ll1PhH4k/G6+8K+Mr61+GvjK81/SkIVNZn0y OxNySo3kQ7nIXOQNxyQASF6Vzsv7SvjKVdp12+2jgcqMfQY4r1I4OlOK5omEptNpMzrz47eKJ3Z7 jWr5TjGRKV/QVkaz8ZNc1VgLvUr2coSV3TMACeuMVtDCUou6iZuTZmzeNdU1IkXE8sgOM73Y5x07 0xbyd+bhgT6AZrdQUFZEabDzctkdB7YqP7ZJLcbUYKq/ewBQ9yklq2SMFu8k/McHpS6XJ+5Kt/Ac YzgVDeti9HTujUjm3DD5PoBkD/E1K0xICsxz/dA6/gP61OxmkfXa6HHKkbxFXB6FTkN+NVZdFa2n yiEkHoOlWpps4lGzSLEOlB9pYbV75psulCfJQfeGPpVqSLtdWJbfSgioMdunrUq2kcaDzSihTtG7 A5HB/pS9pG+4cr3KniCxRrXepjbBU5DjHFaFtZKUjk3ReW4wCWHJ4yKSqpa3Nn8CViYW9vcRSKs1 q7L1xIpx70CK3a0TdcWgEv3GMi4P09atVEluZ2drCpd6dDGVk1CyUqcH96vGR0/Sk06WyjlcNeWg AycmVM4HfrzVe2TG4NsltNR0uzLA6nYbHbA/fJjJ7HnipoNT0uXUB5mp6byCeZ0A/Dmp9qn1D2co 6MWbXNDt1WR9X0wKeMfaELcf7IJPaornxboc0Dgavp44DANMvQ/19utN1lbcFTa1SAeMvD4tUkk1 W3JbCgxgs2fcYyO1PuviN4eZXj/tIEqO0TYbA7HGKUq8ehXsminF8RfDqWT+bfYySCpifcOnbbSR /FDwtHIEl1DaGA+cW8pAz6/Ln9Kn2yB077GRe/F7wtaJObrUCgTGFMEuZPphcD8cVyXi749eDrvw tfWkdzcSyXEMsIRIGGN6MuSSBxz0z+FS5X2KUJJ3OM/ZDZD+0NoLhQBHBqEhzz0sJz/hX2Vp6vJ8 O7EIPm+xIccd8CsKcmj0MwXNU07FHwjpLnxdpnmLgecW/IGuys/9N+L2nc/LAly/PvsAP6GumUtW zz1sj4/8U/tjQSeJ9Tki0gSl7iUh/PxuO8/N071lyftkzxxSLZ6ZFG0hB3GfcQMdPuetTyspwW5E n7Xuoo26O0gG4YJZy3/stbfhT9q/xFquo21loGmWU9zfSpHbqVZnMjYChRx1JHUd6zqpJXbKhDok fZVz+wF+1x4O8kTfDnQIZ7zVLDR/s8GoW0x+13bIsauY5SFVWkRXLECMsA2Misv4i/s+ftN/Djx3 aeAda0PwXBqd8Lq+Men3iyLaR2y75biZkc7EHHJ6kgDkgV81PG4OV7t6a7HoqhJW1R3fw7/4J1/t a3OseJ7KG9+H2j23h20gub7VtRubl7bz5nKRWsbRQu7TMA7HC7FVPmdSVB83tP2d/wBpO81nU7Nv EHg2LT9J1CeA6ysl0bK48u3825uYW8kM1vEWjjeQqFEkiIMnOIWPwbi5OD8r9fL8w+ryUuVSO4+I X/BPL9pr4X/Ayx8V+LfHvw602xu9N/tT+xLuK8S9iV1VhEyG0P7wgqQN2MHqOceUa3+zx8dvDngk 6t4r8feCNLjNt9olsXD+dFBEhe7ZsxbB9nIaNvn+d12x+ZkE1Tx2ElBTlTetyZUmpOKlsfJuvftl fEkQiG58SO0PRFjtoV+UHg/dz/kVzt1+1V46nc+br1wzMckeXH/8TX0NLC0UrqJ58py2ZmXn7Qni 66bM2uXgx08ran/oIFUJvjJ4nmBMut6l83YTsP5V0qlCOyItcgk+KHiK5bEmtak3rm4f/Gqd1461 eZsNqd+wB7zvyfzrSyTC2g1vGerpBsbVNRAPPli5kx/OqcuuXt1kz3Vw4H8TyMf60watoV2vZGYh Hc54xmknmaNQCSW9jwKHoVYajsRulOF7eppI2aQ9cL6mjULCNJz8mT2z60hbb1PP14FFw8hDubqS P51IkZ4LnCnvU7BuIX2t3wOgpQrNzIdo9PWjYdh4zJ6Kn6mnxM2NtkuAOrmpsGwqulsSIR5kp6v1 x+NABeUHBnk9B91aT3G30Ov8B/C+58XahuuiFhi+eWaTiKBfU+/tXv8A8NvhvBf6akemrLZ+H9wW S6IIuNUb0Xvj0rnc3J+Rq48qOi+LXxk0L4EaXHDewwT6uqA2PhuA/LAP4ZbjHT1C9T7dR8ueJfFv iH40eNRPqT3uoapqEqww21uhkmcs2EijRenJwFUd6pLlV3sRa/Q+y/2O/wDgg38UPjpYW+sfGfy/ hn4an8sxQasA2r6huYZWKzB80Had3zhSRjAbNfpr+yX+w18N/wBiHw7I/wAG9DtdL1e3jkhbx54u gFzrF3NsQusMXKW2WDcff+UgxkDLfKZnmMsU3QpfD+f/AAD0KNNUVzPf8jehl1HVtQuLvw7ZXN7q c0LJca/4ivFeMxsButl4d/LZgr7H8sH/AJ4kgCuY+L0vh34D+Ah4n+PvjOOCCEkI14BawWaPhntr XaFuJGYg4VY41xvzGxNc9CkmrLbb18l5BUquLTW/bt6nwZ+05/wXuufCMraP+x1aCL7Btt4PGGsw 5kWGNTGi2lqxMdtFgKQNoJAXcDgY/Pf45/tOeNv2jfFkut/GnxJqfiHUJGcrLfzFkhDMWKRp9yNM k4VAFHYCvp8FgFTtOa1/I5Z1LJpHAtd7mJY1FLqBxiIce/WvW5TnSdtSvtabmQ/nUsUCpjec+1MG +iJRcKowgA9cUeeGA+Y/hSsZD5ZfJgB/ifp7D1qOO4WJNvX29alK7ubP3Y27k9jdBrhQT14qVSLW 8kDd+Qc4qJK0zSCvRZfglDIcuFHfsP8AGvafgV+wd8Xf2gHtv+FU+AfEV5aXhUxalPZvb2kitjDC RwA45HQnNZVakaa992MttS1Y6oqwAwNKoydqxyMp/MEEEGs/XPiBf+HZwtyb1rd84nMpbGfUcfnm uKEXzaM1drNtaj2+ItzeIPOeeVyoyVkZgeOo5yfy4rM1Xx5qVsVl0gTGZCf3chfAGMHBzWsV3Ycv WxStPi1e3nyvGpGcFRIQN3vzV5fGcjZN6QrEc4UMVP1JpypuGiHGS6jbfxvBqqtbzX62pXhobq1K gk/3WRmx9SAPpV7UtR1TSrNZIvJltz8ovIdskRPpuHf2PNSpckuWelzeVNSpKUd7/wCRzkPxJ1O3 neO+aANA2SBGqmRPb371pr48uZrVir43H5XCqfwrpcbI5IuyOfn+IOr2d9LFNckqf3ke9FBIzyOl bcfjSW8t1Zbh1DDOTjP4CqcEthqXRHP6l4x1O21aaOO9mZJMPE6twB6VZXxlfSr5gu7hgfm2ls49 qfIugN7mNqvifUU1I/6dcsH5X94cA+1JN4ku7lQZ7qdiuMbmJ4rTlWgkyuuuXaSzAXNwNy54kPat q21lp7dGuJZncqMFXI2/WlKC6IDGkv3iuboRyyBRIjqWJzWsupOqRsku49TyePaiSBI527uWa4uQ WyDITx06VkXxLzRgnt6+9WVE9r/ZDdrX4lfbl6WGk6nMx68fZJF59PvV9tfDOzn8ZeD7Oy0EQSX7 aTC8cM7si7g6cEhWI4z/AAmvPlNQi2/62OvGQ5qi9F+p02l/B/XPCniGzvPGFta2ixCVtkUkjZfy 26EooI6/pXKaT4iWz+I2vXpz5ej6FJdM/ZQGkb/2StKFeNaMpI4JwcLJH5qXDebOzt/ESaWO3Z8A A+n412sgvnTJZCiKrYdgg9/Wvtz/AIIn/s1n4zftr6He6jpsN7ongXGuX8t0rtGPII8mLavJaW4M SDHTnsDXlZpW9lh5S7JnVhYc07M/ebw1eWVz4s8Q/EnxlfLcx+BJJ9N0eSVR5Vz4gkiYahcB9q7v JSUwKcbWAL8snHzh8AbXxH8Q/G/iv4rXUcdk2pPBZaJY3Fst2+p2EE5aygjBwqy3N7iQbtyhIozg Btw+BbtS16/hr/wPxPVSvU06f1+p678TLw/s9/AnS/hbo19a2Xj7xNLJqniPUIwpYXlwRJe3ZaMK ZIrOFSiSMoJWGIHBNO+BH7McPiTX7G+8bZsvBPghFli0wrLvvCS7W9nJOTmSSRwLi6TBG58ZAyD0 zXOoU36v+u+7OeLcXKfyX9fgeTfHHXdf/ah+Neq+I0nnTQPCKSCNplUJqlyQqLdqm3aTHKqpEHBR n+bkwlT+V/8AwU5/bIl1/U9b8CeDJtMGkR3KDVL3TFP70wsSmnxvgfuVceZIF+Vpv7wiRz6WCw7r 1oQa0j+ad/zt8jFzUYyl3/r8j4NvbmXULlnkyWY8Ko4FVmgYZwMnua+3ilFWPObuOk0qaK1SaeNl ickIx/iI61AInmb5R/gBTVnqIFiZm8uAFmY4AHUmpr7S5NIk8u+TE2ATH1K55596YWuQmylaEzTK yxk4DkfePtUflPOSIUZgvPAPA9TT0AYqssm2EFmPGV/kKe1sbNyt2p8xTjym6g+9JILklzp0tvEk upgxiQZSM8Mw9cdhUcenz3sDTRoRbxEK0p+6pPQZ9aY2yLlmK2gLerEf5xRFbmSZUhBlkPHyjjPt 60mgFk2wcSHdKe3XFJJuTm4Ow/3e/wCVFrhfQXyio3T4jU9M/eP4U2RmKbkUrGD95u5o5QuHmbhk n5R3JxTmuC6DBxH0z0zQ4jvYWF/NwkAJBOBgdTXf/Dr4bPfq11r0gtLKDl7hhwP9lR/E59Kxquys aU1rdnvHw9+GR1e0thf2bW+mbgbXRlB828P/AD0l9vrVb42ftN23w1LaR8P5ra/8QoDFJewKGttK 7BIh0eUc5J4HvyBhTjd6bF1JNHn3wp+CmheONa/tr9oP4haP4dsbmQS3P+kNfapdFnUt8qBghKlj uc5BAG05r9C/gx+2v+y3+wloEUv7LNpoEuv20Jhm8UahbzX2sysww7Q3DxxpGc91VBj+F+h5MbQl jLU07RW/n5GdPESpP3Y3Z23ib/guL8PIdOmbwpr1o9+0Ahm1K7t7uSbb8uVhEikHdyWUsifKPl4w eVn/AOCwXwjttOk1DxLr8erahHbnEX2G6Z5XcDcgUjaPTG5U46VwUslSai2/66DliqurUdeh8+ft B/8ABfnxFrtmmnfs66FBoEdqHSLXdSxLcKzBFMsUA/dQkhOR84/EZr4X+K/7QHir42+KbnWfifre oa1qNyxZ7m+lLck5IVeijPZQB7V6+Fy2FB33ZPtpW136nHyX7M+Tn8v6VG07EgufevSskSnfca0+ 4kDn3pnmkHkUJFSlfRB5zYODR5rE4zTIsG5zgZqeyjMuXnz5SdR6n0qZWsVGN3qR3dw9xKWwfwFR 4fPAb8qIrlVhzak7kkCSrKrKjnBzwK19at2kEbRg5cADb1+lZ1FaUTegrwkje+GuoeIPB+tR3vgi K/j1GEgpc28AaSI9mUkEqfcYNer6l+0p8dvE6NPqnij4gXCQgsZJr2YBMck9eK83F0KFWXNUtp5m lKcYKxzUHiwafc+Vcj5/4s87/wDaHoa0b6SO/snC7ZYX+Ugn2/SrcOWzMbb3OSe5k8OXRjLfuCcx yNyU9j7GtSx1z7dau6OuF52MeQfWtJRv7xHwnO6ynl3Xn225d/8ArEHQn1FWbPxPiIrcKJDjG49x 71q486QddSlql0JZRLETvXrnuPetLw542uNFDfZJmAbnaeVcd1ZTww+opypqcbNDVRxejLGqHTfF 5EulsmnamDxbynEEw9FY/cPs3HuOlUoJpdFvpLXWYpIJIiD5MwKkZGfywcj61NNtLkluvxQ5xT95 bFTXZEmZXgfds+ZevA9KdpWupDGUZFYA7gT19xW3LzIkj1u7S58uSH70Z4+npUMWpBVZRwucj6Ht TUdBMq39yJEHP3Dx9KYs/GQenY+lOwJu4xZ9kuSTn2PWrtrqRS12kn5eKfKHUqz32+dipxvjwffB qwNXYIAAeOeKHEChNdYkmPct0/Cs5pvMl5/hFDVhwdmkez/sufG2H4DavqOtXNh/arPYtapYOQI5 t00TMshIPylEYcA8kfWv0O/ZU/ab8L+KtEPijwl8MbiW3u8W7T6nqCRpbyx7WPkoFY7VcnaTk/Lz 0xXi4ym5X1snoelWjJcs/I9q1T9o2T4jsIdV8E6HewmNo0afUJo54VfBO2SO3UrkouQPTmvEP2xb HxH8N/hBqF34S8J2B8O3un39nfHRZZLi7smnVhFPJLIqmSBS20qANgOeQOOPC2pVIxT0ucdSPMnI /M+68GLFC7iXAQZOfQda0/CHh22v9WT7QFENogBLEYeQ8/pn9K+ik2kcyRuaxaWtnrcf2UBzaxbw uM7pGOFB9881+2n/AAR58O+Cv2Mv2Qo9Q8TXxtfH3iCRdXvnignb7NwVtIZXSM7UjQyXD4JwQqkH JU+BnFOrXo+zpq93r6bnTRrQovmqOx6f8fP2xvBPxU8B+EfCXws1W+1HwTCUsNT8U2sQdrp+RcXS JC53SOw2gttfEpzzk10Nl/wUm+EngP4naPZ6QNSin0yye40bw/clbZJr17fyRMBnJWCBNihiQcgg 7lxXhvK6vNFW0RosbBKXdnkVl+3H4W0rX9f8R/Fh/NjnjuFP2l4yiacoVoYXZ5FZ1ecyTyoACxhh TDgmuh8df8FQPA3jv4SaJo3wd+x6V4Y1K4jub+5tbyOG8ukI23UzRtt2zOI9i5U4BxznJ6aWVVPa c8jGpjouFo/1c+cf+ClH/BV3wv4P+At18NPgVbTW2s63CFSKQpINJtHiMTuW3EiTyi8cQbcyiaaU sHKk/kjq93b3h8zU2AjXOFz09/rXu5fg5UG3LUzVVVI3tYzUvbTS7W4lWCMXE4226DnYp6u3ofT/ AOtWTYS2ss7GdgViOZB3Y/3RXsRju2ZMn1vxFDql+hnVVjxsgtw2Ai/561S1PWbLTdLe303l5MGe 5fHOP4F9s/nxVKNtAb6iaRrUHh6Bbi1Kvev90uAREPX61nJq9veXjS6g7SqGJcg8u3Xg1SjrcTb2 G6n4m/tW6jQ4SKMbUjX7saj+tSXHikWulvaaapjhlOZGAy82OgJ7Ae1FhXGaf4hOiLv01P8ASCMf aGTcUB/uj196isNTW33TSwvNcsTgzAnYf73uaaQ7ldtRN1eGXU0ml7nPG/2z2pmo6vcXm2PYY4VJ KQrwi/4n602hXuRGeUoRCnA5xmpFvJ1XbZLtP9/Pzfn2pIGMikmhQiJVWTvIeT+HpTEM0UhL7Wc9 GbnFMBPJmMm+Vlb/AHuaJoppWDSvux/CaQhZLd5l3ySEkEfLTodMm1KQLF5jv2CjoKG7asaV2el/ D/4YQafDHf8AigyFGISOGPl53/uRr/M1798P/huzPHe+K47aNrRDLDprMBbadGOfNmPQtgZ/zmvO nPnbbOxRUVZdNzn/AIofGDVfGjz+HfgaLhYrn91eeJACktyO8cPeOP3HJ9u/EaN+xhrFzZiW7l2F ui88fWq9tCirdTlnPXUvv+xXdwoPNnYfUHBqG5/ZBlsoN88h4zwRxWaxab0RHtOp5r45+G3/AAil 2YXIcjrgYrk59O2N6D0Artpz5lcpe8Vp7Rlx1PtUcloYf9aMNxhe/wBa05ugrdWQmAnHFSwWcTHN 4WX+77kUN2ZpGLcSwlrYrkuGPHGM8mgLYgH92xPbilzFezlsxm60AO2Ik8daTzYAhxEM54zihyGq bFt5FncLHCB1JJ7Cm3MvmyhLeMtEnQAdfepbuylDlTASSt9yHpxkKamjF1L8yW7keuw07kcqTLMM V5IAVt3IGDwlaF3YXUGnRzzxPFJGVkG5e2eDXPVlax2YWMW2l2PSdA+KfjTTRFdRpJCLuMMk+IIA 6AcHIWku/iL49+NEdxonhZ7y53DN4IJQI8E4wznA59O/NeVPB0ef2kntudlPEU402uTXa5iaktve pi7/AHbgY3Z+ZG96wX1WeymIMjbc/eDEg+9ejSV1ZnlSbJLrUjqVttmYMp/i4rL89rBvmf5exFbx VtCZO+o9LwTru3g+xNU7if7O+Vxs/lVJEttk0GoJJFkH2IqvPfCB8xHK5/KqSsFicarFLCCx/Wrk XjQJbRWuuoL+yiG2IO2JbcZJxG/YZJ+U5Xk8Z5qKkObbdFwlyvXYm1DR47nT3vfD1w1/ZJzJtG2a 3GcDzUycDp8wyvIGc8VgNeraynacqOR7U4S512fUU48r3J31GNhgnrVYaiN4XqoOAa0SFe4smpRk FR+tV7TUjG5DcgChIltXQ6XU1cHbw3Y+lEeqGND5gySfzosO5HcX32gqEGCuelObUnjUDBO0Y4Bp grleS9czMwzz14pttuI3MDtJwPrQ9hwupI6nQD5ml3CkkZTNfpV+zL8WvC/wf+E0PhDxDpryP4T/ ANHuL8RFUuZn/elhtJJyZD1AxXlYii694o9OvP8AdQR3Y/bg8OafPDF4W0ed3mwqGC1AG4nGDvkH OPbFZ3if9ojW/izfJ4YmtIYtHuxJ9shnRT5kQI+QgAZByQck1hTwPLK89zgc+ZabH5n/ABA16XUt X1CHwva/ZbeS4fykZ87Yt5Krnntiqek6nqGl6cI1hjMgyWZm5LHqele5y33OdN9SbRP7ZTV/tSIs jqQ6KxOAw6EjHau+1X4vfE3xfZPbavrupzQXHySRtdzEOhABQ89CBg1hOEdW2XppdFeytvF1napD YTlERdu0Bumc88802Lwd4vXUpb+W6lN3KCvnkMWCkdBz0/xNYWpx0FdXeg66+G/irXYBFfXdxJCX DlGj+U4GOeecVU1DwH4lskzJf3QSJQoVRjheg+gPP1qlKmNT0sjlNS8H6haXEs13PcyySn55GOS3 41nS+Hri+R1kaZlXj5j3rqg1uiGmiJ9ElZisnm7hxyTnpUcmgJZuViRsMTySeTWtyW7EZ0FPL8wx nfzgn0oj0VGUmWFTt6AigQz+yx08sY+lLLpSxY8tQAe1Fgv2BtMSJMIo3HngUxbQKTkdaAEgttrn IyBTZIMzEnjPpTFcbcwBkGO3tUEkAKgelK4xVgCjpSJGEJ4PFCARohvPHPWkkjDHpSGBtyV6HNOW 3faflOPpSuh8rJEsWdOF7969L+D3h/w5c6XC3irxFY6Nsm3XKT20kssiknhAgO4KEQgMVGXbkd+X EzfJZK5rTjyu7PZvFfxT+E9tqWkSeBtU1JJLBBbNK2nqzAEnM4JbIznkbTgD5RTvhLonjf8Abu+J Efw8/ZZ8Karr00qvOmkWLost0qctPcyMwVVGAeW2g45JxXnU3KlBzq6WOjl53ZdT6c8O/wDBIz9p n4a3mn2UXwatY76/3PAkvibSGbaqEliqzEqMLkZ65UdWXPc+Hf8Agm5+0tf+IrDR7rwV4J06a9t3 uVvbzxFA9ukCBi87tDv2RgoRvPyncpBIYGvFrY+jezbb9P8AOxr9SutWjtbf/gi1+0ZrniCPT7rW vg/p9wIjcXMJv9RlbT4MHbJKVtSvzY4UMWP90bW2/nD+0/8AF7V/hR8Ydf8ACOh+IvD3iu30Wd7Z tf8AD8UotLl14byjIFZlDZXdjBxkEggnbA4iGJqqEU9r6mVXBQjFts8O1fxBfeLb0yamqqp+Yzys I0/Djn8Kwryaxty+QZyOMxkhT7gkA/pX0MZP4YmXs4xVzFuPEGJdtpaxoehJ3E4+ua3vBngW+8XM rLbwxQscbtpy30rWb9kryYRjzadB3jH4fN4be0a6B23Me4Y4G4HBH8qxrDQ477xBaQXm5YpmAyvB rGlW52mdjo8lNvqaXiXwONEvswRPPAj4aNic9eORWtofhjS766gV7IDdJsKsTnJyMH6HFdDl1RxN uSGzeGbNdUMLWcSH50Ax/Fjj9RVbTdGikuHVbeNW2Nj5BwRzTvYhydzLmg/tm+NvYqFRBmVkGM47 Vo21jtUrEuAADwOwoXcup7qt1RZh0phLtYcnB6VreFtM26g0UwxlcgNxWU5aGfVI6LwvoUXm3dq6 5HOBjsRSajbJDo0EBsFvXjLQywyEqpVWyAW65Oe1cFeTl1tsd+Xyaqq2u/5HM+I/BV/oWsQJqINp FfIJZzb/AHbWLeQUUHGSMcfhXVWPxF1fWrWLwv8As76NPZWiDa5sgZLiZjgGWebgLnjJ+UDgdBWV liFGz93r520X+Z21KXsk3PS3TzPPPiBrNja+J72Lwpc3GoaUkrLa3d1EIppIs/KXQEhWx1GT9a5q TVZZCw25X3NenQVoRctzypxfM0kV4r2eFzgkKe1LJeyyg5K4966HYyUJbMiikeFj83HtQZpH4Zh+ VO6KVNhGGTdzgn06ULGzA5c5PtScio0Xs2CweUh+c0ogDDBLUcw1RS0bJ7C5m0m6SbTpZYZY84kj OD6YrUjgsvFRAjMen6kf4Wwttcn+UTHj/YOf4cc5TbT50aRpwa5GzKv9NlsLp4dQgkiliO1o5AVK mmQ2jZ/dRse3etOZtaE+zgtGOOmyDhoGyemVNTQeHL2VP9HtLhlb+7GTmjmaE4xY5PDOotkRWFwQ mAf3ZGKuxfD3XGiLrp1yFHdlx/Ok3bqCaFsPh3rOqyBbazZiV3csBx071Pd/C/WrDYLi22B22DLD rSclsPmt6kll8I9Z1G2EsCQbefvOe1YDaVLp+oeRfJtYE/J7jiqTVnYn4pK5u+GcoZo1GSYmAH4G v0C03S4f7D8QTyJ/rNRmySOvloF/mmK5b2nc6sTdUofP9DC+Hmipf+NtJi28LIZG+gBNdxr9+NEs vFuqxEKdO0efY2cYkYOV/UrWk23Kx5y+FHxBpfhcS3TF/nPUfnWxZeBRczoQpOTjgV0SqJXJsj1b 4TfBBdblXzo+OOte2aJ+y9btYiRli+uK8TFYrlZTi20bWj/sxW7yjfswDksemPSr+ofBXQ9PcGaS 2VEOPMd1C9OO/wBK4XiZSdkaOnzDLz4e+FtFsfN1LWtDh3NjZLdQqQBx3Oepry74oXPgvT1kii1z R8scbRdRnB79DWtGc29iJU3CyR4j4vutAijmSHUtLdl5AW5Q5x6YNchdaloscbY1C0DNyFUE4OPU DFe1TbStYS6mQ2saN9sdpb5AoAIKxucn8qy7zU9Iu5iovtiqxYM8Tc+wwDXUpMlpdyrL4i0qNSnn XDjkbljGPbqRVf8A4SfT7aceV9oYqP4lUc9uM002KxQufEVv9+2WQqxPL4GfeoX8QRurBYjhOck/ /Wo5hW1IE8QCV1RYwcdznpUcuu/OFjiXI44zyad9SuXuMOtOCfkTA7019VlwN6r+PpRzMOUFv5ZE JP3RxwKZ9qdiQDwPapuMZ9pkc4yMe1Hmuz4Q49xRcNBcucKhJZu5/nU7xmGIIrFpG4+g9allJJDA jZ2ISSO9S+Q6xhUyc9yal2KVy4pVdMigjdS29mbcOc4UflxSJa+SNkTKXf65JqWy+Wx13we+B/iL 46+PtM8K/CfTLvW9a1WdIEt7CPc7Mx+oAAGSSSAACSQASP6Kf+CZv7OPhv8A4Jefs1W9jo3hLW9V 8Z6rsGu+JLdLMfaLzKl7GJ2nHl20RVlmkbGBHIXKjaIPns8xSio0r6vX7jswlK95M9wtvjPreh3D B/BvjDWvFHiXzoY7I3mnqRMv3oIgLnKWkS7t0rBDuyCOWjNvTPiRdWkM9tovgjxPf6/qKSXN7qur vpDQy7EZFmk2Xj+XaIGYRxdCVHzMWkL/ACU5KXXR/kjv5OTZ/wDDn5ff8Fh/+CyK6bpPiL4K/sla nIum3lzKPE/jOymT7Rq0pwrW6yxu6bAFCMY2KsFCjCivyG1TxD5tywsIYkbJLXMn7xsn68fkK+ty XCOMOeX2vy7HDi5qPuroY9/qL3H+vkdl6F3JJbHb6ViX999ocpDkD+96V9FGNjgfvOx3vwp+FH/C Q3ltLqgDLJD50cJ6ttcqcj8B+Yr3/wCHXw3jsJJYjEAsbbkUDGAQD/jXl4/EqKcWduHp9Wcz+0j4 CMHg21mt48tY3bxnb/Cki7x/7KK8H1Vf7Pe3nAO6CUE4Pbg1ngKnMkuzO+cL032PW9Q0ZdQhinij DLdwrIDjgn/IFZXjfw2/h3VYtT0hG+zXMcczRoPuHuw/EV6UJW0PEs+hB4gslbVVu7P5kk2XCP2w ef8AGud8aQNZawbDSmDXl3J8hBwI0bufzqovSxVOLbu+mpe07wWPDxSEEO0cg3uRgtngk/nVpvDv kXcYIwclDnmm5kNXuyeXStssZVeTxx+f9KuW2nmHUIZRwCOeOaxYR3LWreJbPwlemeZwzFdvlRkZ LdqrW/iRfEEDWmiJNe3lwwkNrajdtbGMs/AUc+uK4asZNaHqYGEKb9rN2S/E0fiX4M1zxXotpFqd tIdTRREIbBywZjt5Y45G0Enpzzmvoz4X+HrLwT4PttM0a3hgSBPLk8tFUyOBgu2ByxPJJ5NefibQ oKnDu/uDGVvrEvaLS+y/A+VNJ/ZV8T+IJFANtGrqWztJ6HHpVzUv2MNc0+xlmuL2EeUpYqIjz+te 4sVSjpc4XKUlczdK/ZV1G9ZDc3qJGwyGVOcc+/tVjXP2UpdF0ua4N+7+TyVEeM81p9ag3Yi76ieH /wBmGLU5ZFvL6cKoVgYwASCM07Xv2a7HQVt3e9neOSQITlR19OKpYhPYa5mr9h+kfAvw8A/9r36q YnKndcKvHOKrar8MPC+mX7qt9bsoiYj/AEkffHQcHuKr219iuSZqWvgfwItmGu7uy37FLD7T3x6Z rOv/AA/4MhE6w3NrkYKFWZsj8KPatgqc30JNOk8GGzTz0gMoABHkO3OOe1Uor/w1YXURa1DIkj5Z YOqkcdaXNIv2E30NnVvHXhjWtOW2uLO5OxdkdysC7ogOgwW5Uccdu2OlVx4v07wVO7XWnNdRXW2S C5gVPLkXaASD1HPYjI7gHisk3B8vToaSw8pR5ralPWPi7p17Khh0iQBM43Oo3A8Y6cUlt8cl0/T4 47fSYsoMbnl/+tWvNfdg8J3Ofb4q38t5cSRpEqSS7/KYE4XJIG72zjp0xWxd/HHUkQR2sNg0eASx ibuvI+92OfyptJsn2GuplWfxL1W3mVtPeBHClcJFk7c5xzUt5448Q6tZebM87wK2RLHajaGB9dtR sbKhTja7LGgf8Jhf2rLollrdxbtuP+jWjsPfkLXK+JLeaDXoxqUVxDcIxEqXKFWBI6EHoeKqOl7C nGlFab6Gz4F04ar8RNNswu1b66jh2IcAB3AwD+NfeccoT4dXc6tkXd7fyjHGQ8zY/Q1m376+RnjF aMV6/oV/hFZbvGTTKB/otpI+T1GeKw/2mfGh8Gfs4eML62lEV1qd5a2FuSAdzh1ZgAcj7kchrRu9 Q4be6j4rT4s65gBLlFK8ZSCIZ/8AHatQfE7xAkgSLUZgJMA7Qoxx9OOlbSitSUtbn6Zf8EF/+CeO jf8ABQqTxtd/tDeJviFa6Z4dezhtP+EV1BbcmRy7O0rvHISNsZACDduwP4hX3d8cP+CIHwG+F3wL 0TW9K1v4ltqOpagtgbi612eOK5U3nkHzI9m8A8HCnOOQrHivjsTj5e2rJWXIr7ecV+rPWjTSjBNX v/wf8j0v4W/8EOv2abHULu41jw3c38H9i6hqP9kan4m1SWa4i89fIuTsmjyiJ6dfMXPPJ8R+CH/B Mn9nfVhqb3Xw68N6lPqF1qa6dpMuramJYovtltp9n87SOT++W9OenBBJ8s58bE47ELDwqKWrettN LbfedVGEHUlFLZP+vuPdfHv/AATQ/Z9s/wBrjSvB/g74W/D60i8L6PJqFzZS6fbzG/VylrF54kJd 2MlyGHHLqvpX46/8HCuieDPC37b8vhr4I+GtF8L2fhXSobK7tPD2n21nbS3Dyy3AYCBV3ssU0SMz jcGQoSdgY+pgKk3mHLzaRv19f80clVudG76n573cbBlUluvPPYUxo2jU7t2B/Ovt7nlWESDZEA3X OSKh8oqrsDyflHvVLYWwyKLdJ8/RBuOajaPOSPvOaBLTUJjk4HRRgCkmTybcRkjJ+ZiKGPrcdbRi PGRyck/QCmIgRGZskngZ/WkFu41F8w/7I607b57hRyWOMU9gWxPeuiusVrny4hgt/eb+Jvz6ewFR qAoIxnP+c0kPZ2ALtHy8n0py/IuecmgNixawtGhl2E54z0A9s1IsQVS07jc5/h5I+lQ3qzSMdPIk jjW3Qt0P5mnNF5Sl5idx4Hr+FTr1HtsKsIt0LN988DHat34f+ANT+IvjDTdC8G2z3er6rPHbQQp/ fdgqj8WYAepIFTUmoRcnshwu2kfvn/wSo/4J8+Hv+Cb3wvmv/jZbvpfxK8TJ5cviDUVie3s0ABGn 2TNlTczFgreYAVBcYKgef9mWsr+G9msagtuupZk0fTfDthcqUhXDA6fA4Awy+WDNIr7V2tlsxho/ zvGV3iarq/zfgup7MKfsly9DndX8OHTdSK61HZa7r+rQxQQQaTNNaW7xxzHyraFcqkNjbOELuBiX EYw5CLX5x/8ABXr/AILBR/BHw/4h+DP7L2q/a/Fepu9t408d2chYQspaM2Fk3WNQpKtsO1NzgfvH mc54LDvF14wXXfyiv8x1JqELvp+Z+Nmra++oM43nLElnPb/69ZU94Nm0cIO396v0ilBQSR4kpXbZ m3F813JtjJCdMjv7Cu++FnwNu9eRdS1NRFaRFHEDDJkQnGfbrmitUVGN2aUoNs+hvCPg2PSm0WS0 hVFgmnt3K4G7zEDqPX/lmfzr0fRdEFrqQwuQybf++Tj+tfH4qtz3v/Wp6lKFtDL+NnhEal4A1SNF G42zTpx/FCQ/5kHH/Aa+OvEGmmWzkVQQCpHI7qf/AK9dWWVdZeqZ3U4OdKVv66HrPwxx4h+FelXC ljJbFrd8+3T+Vb2t6Ot14QtHcbjbSPAynuD8yj8q9yT5ZHzjjytnmPjCP/hA9EhuWIkt5jLFHbs3 KODnj2wwz/8AXpfB3w/nj09dV1ks17qSMxDD/VgHhP0Ga25klcuN1Cy6nWato4uEjmIAW4iDZx/E ODVTUNP3eXKAcyorjj+Idf1FRzGLM7xBq9locgNzKGbAkWNOW5+nSuYufGF74lnNr4biYDv5XLKM 45boKTblodNGgl789vzNDQ/g+19tuvFdwZCpH+hwnjGeQzdT+GK9P0LSbXw+LQ6Tbw2scfy7YVCj B9axqyT93oZVaspy8jt9Lufs+oxuDxKm0n3HI/ma6LTbwwXDrk/PtfB55HH9K8eqrlRWlzyLTv2i WiAt7DVLzcWbbHDAc8844XNJq/xE1/XUlEc+vTLKu0pHG+MfQAVpDA1r80kfUT/s+GkdTkmh8TX9 1Fb6VJ4imJJP2aPzMce2fequt+DPGc4YPoniOVGBy8okIK98knHavQp0bb2OGpXwlnbYxNP+Gfi3 xDciHTNE1IuPm2n5e+M5JrT1f9m7x1aWzyXuhssagFv9Ji6f99V1RjGPU51iaVrJCeGP2WvGPihJ mgsba28hthW6nAycA8Yzng1p6v8Asc+KdH8kSzaVKZjgCKVzg4zzlRTUo9zP63F6pF7Qf2KNf1W1 WafUtLgVhnZ+8ZlOcY+7/Wrc/wCxZf2lz5c+sWjYUsRHET09PXpR7SMfQzeLe1jRs/2KkNgJx4mZ Sesa2X587/6Vmv8AsnRRa0IrvWZ5rbegfZCqPtJ55yR3qXWiuhP1mcjr3/Y38LJYsBf60zjkN5sY x7Y2VU+H/wCzjolslxaaxJe3lldx5NvPJ8qyqSN4wOGAxyOeorOpVcly7PoRGvK9+hp6z+yz4Ms9 N3Q6bPuDKDL9qlJ69MZ4/wA+9cN8afhV4d+H/gmRPD+hedevN5Ivnkd2jU5YHBOCcZHA/lTpYh1G k9xqb0VzxH+y5LGcG8hKrKokQOMB1Bx0r7A+FXhjQ08Nafc2ujaWspiUiZbVNynHXOM1tVbVkiqs tE0a1npFrpmsrdWdrbQyrdFTJFGqkhxXQ64GvNJnQruDIR+OM5/Sue+5zydmrEXhG0DahdIAFV1i lC/VSD/KvCP21/CsVhqf2qBP3jxRTMwGM7W2fyalTk3JMu/vHmPwatvO+NvhPbkqdTtHPHZZQT+g Nfas8gtfhDo6HrcRhzx13OG/oa6b+8i8a9fvL/wliAj1u4YDKRJED6E143+3trQtPgL4V08Da2r6 tcahgdxEhX/2vV03eZwNaKx8iqueueSOtbunwLc6xCigYyT6/wAOK2q7Dirs/fb/AINnJT8Lf2ct e1NLW7lS8vJbzUDDIAIbaG0nkWQrvHJNzHtBHO1yM/LX3N+2N44nmn+BfhxLK8uv7UuLG+vLBfkc 28ds9xK2xZFbCeUMocIR8pyDtP51iKl5Yteq/FP9D2eTldJ+n6k/hzxna/C34DfEXX9PWS2t9D0L TNDFukqSxo9rDPLKIijswzHKmWJJLLznGa8D/YL0DXvEOr/DzQfErNFZ3urWPii4ureYphbeG41S 5hlidt4QT3dlHtcZGQcDODwzlzww1Nrf8+Z/5m0VyyrT7f5Hqng3xHJ42+OPxP8AEt3H5Fk8yWss 1yAEtktbdpSS4yyjz7uzGVD7iuAuYnI/m/8A+Chfx2k/aJ/af8b+MZkW3/4SLWrqeC3SQusFojFI YlYgEqkaIoyBwK9zJ4qpjZ1F6f19xx1U40VFs+erkhpzgcKOf5/4VFPLkKnUsc8da+4R5TfYjeTa pZevQVFJ8u1c4281SXQTZG7bbcDoX5P0qJcqC34DNULYYQN43fdXk/WkVfNk5JPfmhglc29K8NI8 V2dbmW1l8hmigwGl3AhuVyNvyq3U5HpyM1oJdJG9b2K/m+95bRzpCAAMgEeW+SfqKy5nJtRNeRLd i50hEXdZX7K/zgLqEIYDJGD+6POR7euOasST6FDZH7LYanHO3AMuoQuoPQnAhH86iTqdGvxLjCPY jig0H7KPOn1SCf8AixHHKmf++lNQXUelQxt9mub55OwaBAMe/wA/FNOp1SHyU+rKLskR/i9wcDAp VlC4IGD6HtWrT6mV4rYkmu3uHDzMWb3PSnwy7Pnf8Km3KJy5mT2z7282bhR0z0+tWIHDfv5yAoB2 o3b3qXoUtixptlLqF2iwxySXE7BIYEGSST6etfu1/wAERv8AgmFpf7JPw9k+Kf7R0FpaeMZ0NxB9 t+Z9EttxRZAMj/SHJISMAkEYOHyIfBz3E+yoqlHeWn+Z2YSmnJy7H3lda7YahpX9s/EGGWyUzzR2 XhwAZs2ndmCruG2S8uBKZGdjiNXPO1mabiLzStR0zxwur+B724k126YxWnh2SNbvSoUyoOn2tsWL wW0BRWuJ4dil3AAdlKQfGOXMrL0+S3PUh7u/9N7H50/8FUP+C0GsfDCPXPhv8Bryyh8a3WbPxD42 0a5MsVugQYt7CT5TGy+ZKjYAEZ3bCzF5D+PWu6tJeXUjTuzPIdzyueSa+wyHB+yputJaz/Lojgxk rPki7pfmZN3fbU2DgDtWdLctduFQHB446n2r6WKtqea9XY9d+B/waN5eWt7rsIIfY8cTDIVSSMn3 4NfS/gjwClnaPZtHs4eLjjjnGPwAr5/M8R73Kj0KMdLo1r3RBp+lpM0ZPkXEE4VTyW3bf/Zq7G20 xIrpWA2hSBkeh4/nXzUp834nerXsvIn8T6Kk9irMgkWJwXRu6MCjD8m/SvhnxZpB0XXr2xmGTZ3T xN7jcUr0cu+JrukdmC15jsP2Y5PM0XX9HmJ32ridF9v8iu01K+t9O8P6ut9KkcEUa3AZyAAVOD+J 4r35Sclf5ngV4OFSUPM8n8GeFpPi7q99reth106w/wCPO1bpL820v9B/P6V1GmqfD0H9m36kwrKG tbgnhQ//ACzb05HH5emd5S5Vy9jGo/esumg7xX470zwxoiQX7+ZexSOUt4+WKEA5PYc159f/ABB1 nxkn2XwvaOIomILwD7u7sznhamEXL0No01CPNMl034RG5tRceJr5iWbDW9v0Hfljyc/hXUaTZ6X4 cskjsTbQJtwzFgCSO5JrSb6IwnVc+hdi8ZaVbxN51/aJ3/1i08/F7QLSy2TaknmL/Cis2cH2H0rn lTbvbclQltYtn9o7w3awxH7TPLIpBIjhb+uKlH7XnhqKVNtrq7Bc5Iii6eg/eVyywlSeyNFTe59P 6H8M9MttReaKxh8y3uyoGwDAIxXWN4XgSAhbeNflJGFArjqV5y0uVZaHKaNokUMCzQwqJIZnVnwM 4Jz/AErX1WwNzZSJt+8nYexqlN6tisonG+D9M8qC2lRQGAkjZgPfp+laPjLTDdaFdBuRsJx68Zro Um5a9wlsjN8J2TR5MYI81I2/EDFJ4qtGWK0kfkJOgyPxrWDvouoS0aLGnWhiMiLuI3tj881Fc2G3 WoN4bEisv6f/AF6qMuaPyCXxGfotoZYJ4mB/dSYx9cH+tZuq6UINVfHUxbsHPY1MhxdnY3YLNpLc fL8rDP581iaRZ+RdIAMbZ5Iz+PP9KqUrkxvexsa3bGDTp5IhtKqTyMgjHQjvXF6bplr4+1o6gPMe C3UrHBIuUkJ4Mq+o4KjPYEjIbiJfu5c6+ZpTXMn+B47+1d4cTT9T0i4t0CqySwHaABxgjp+Nevfs /Sf2p8MdLkxkiJVPuRxXXOXuply/hxfqdTfWe17g4Py+VLwPQ4NdFDZCWAYGcjr61hfVmG6KvhOz +z6vAG/jt2Tn1RsfyNee/treGDdeEIJoIwzNHNGz9CAELD/x7FFOVi95Jnz58AYFn+K3h6d13iKK 5mA947eRwfwKivsDxcjWngvQbU/wW8GM9fuGulO0l/XVl452lp1S/I0/A0p034aaxcqOZrjCkf7K k185f8FD9W2674O0UH5dO0cXB9nmkIOfwiWtKL984nskfN6As6gd271v+FlL6pu7Ipb9c/0ret8L Kp/Ej+i//gjD4Bk8I/sbWtv9g1D+0fEGnXkQls5oYSQr2lmq+Ydj58xC6fMxBJABr6V/ap0X/hJ/ 23dO0+S8uNP0rQPDN5DLe2KP9ohWdrO2RY5Vy8bKss0m8YzsUNlCyP8Al0neliKj/mS+/mPdkv3l OK7HH/tvX1xoP/BOq907wrLc2N34/wBb1K3hvHklkS2je8ayjmjCrv8AK8hVmHBAyT0rY/YH+G+n fCTwL4m8QaeHTStC8P3VojyCBJmnu5wFIREVk/0SxsZFbe+9J0BeQx+Y+1KnF1aMHslzf+S8xk5v 2dSXd2/Q88+Pfxsl/ZW/4JieNPE+s3z29/regvLY6feGNZnvL9ssInKuGKpd2MhQHgwy85UtX80v xC1U3OtMvURKAfqeTXucNR551J/1u/8AM5cYuVJf1sc3IWEAb5syEtz3A4qHeRucdF+Xn1719mjz HqRowaQbidqDPFNLF3A/vdcVQhk8nmScduABTWB3hIwWK9hzk0PQOo54BCmLpwhPJQDc2a2zEvgv TFkuI1Gq3ih4onwWtISMiVh2dh90dh83dTWM5Odorr/TOiEVT1e6MbT77yNTimvSXBkVn3ZO5c/N n6iqquqOzdQOFOOvvWqVtjG7Etk3Puk+6mTmlklMknmHAxwB6Yp9Sb6WEHC7m7evc0g5Xe44zx7m mHcXdvQO/Tnr/EaXeV5cEbume/vU2AchITc2eegp5c5/eDA9PahxC5KJWZgHGAv8NXLZnu7lQRuO cKg9aiSsi4u5+u//AARD/wCCYGn+GRZ/GL9qGwhuL1kjuvDfhm9nSJLOH5ZDrF3kHYiKQ0SEZcsh xh4936iavq//AAlL3eoeMm1LR9H8PNFe6dY25R7pnZFMVxMioc3cir+6twreUhLOAwSNPzzNcV9a rycdl7q/U9vD0/ZxSfqY7+IJvH+qJeXdrFLE0s9vYQG63R2sUIJaOGaRTtYbWa7vWYkH5YsyM8i/ nD/wV3/4K/x/DjTNQ+HH7N/iHT9U8U3Vutlr3jbwzIDbW1sYtraZZnGFAJwXTBQApuZi5HPg8JLH VlGOz38or/MupUVKN5dPzPx11PWZ9UuZJ7x3klcnO7NUmupgh2An/ZfBFfpUKahFRWyPElUblcry KLkjzUdCTj90c5P0P+Nd38O/hRcSGW7vEdXtkMyK0LMTsPK4H3eM8mprVfZQbZpTpqb7H0h8JdNt ZtLto4JoBKjyRlCwDAHDDI6/3hXsui6YBdq0gzkRuD17Y/8AZf1r4zGVHzNHqwi4aM0NT8Lm7EkQ doju4kjAyMNuHX3xSW0scFlEspfzFiKMoRnZmXjjAJY5HbNeendqPmXFJq/U0Jr62j09nupFhXYc NP8AIM9R1x7V8a/H3SLS5+LGrxeGLu0umu/3yeXOmAzKGxknH3s9678BdT5ktkzqwcowqNSdkYGi eJrr4OeLDq0+m3c9veW2ySMAqpJHXfgjqK5r4l/FS68ZRRWsdu1vAG3yxq+SwPRScV9Lh1GajJP+ kcWNhatKZo6N8atb0XT0g0bT9MtbdIjBtkSTAQ9vvD0qGb4ia34uims9ORbt3Ubo7WMKDg5HzHOO nY1pKPM9DljRhD95J6HJf8IxrWu6p5U8Z86Xc22RwoOO2e/0rV0vwb4nmQwWF29vEqlvLWd1Xjth a6rKKt0MJ1VN3eo+3+GmsX6yG6vGxGnmEEs27nHc1Pb/AAZu7i1kke5P7sr8qp1B70NxRHtH0Rft fgcwsUkaecsXKsCAABjIq+PgAjwQtvmZnB3ZPfNZSrwjqQ6ku5pRfs9WizxP5Z2sEO1iWHvW1pX7 PWn22qnzIEIJxsYA8Ef/AKqzlikr2Fyyla7PumxtNuq6oqjhJEk4+vP6VryxB4wGAzgjNfNpXlb0 /I6NbnI2ll+61GKQEbJyRg+tXBB5tqOAcqa30u1/Wwndo5fw3pog8+PtHdOo+hrT1XTvP06WPB+Z CPrXUnzSkErqxg+FLZTa2zdcxFffKn/69WPFmmhtFfjlGDdh0IraHut+v6kztpYXTrVTK2QCGCsP oRSavYnzrSQcBJMcjrn/APVTh7r1FJ9EUrDTRbazexkfew316j+gqr4i0wHVLbA/1iuvTP0oa0LS 1sWdNtmexi7nYBzWQ1iIdRuMAfJcRvz/ALQxSk1YlK8in8QryTUymh6O7C4vEJnlj6ww8gn6k/KP xPar/hbQo9LtrJbdQFMHlgKP7pxiqYLVJHlv7V3hqzl8MRy6sJ4o7e6TE9uoOwtlQzKeo57EHn2x Wn+ym0UPgJLF7m3meKRwjwvkOuSeAcH6jqKd3FKPQ6pXlRUrbM9KvNN3XDLtI8yCRRx6c/41p6JE LjToXYHJQHn6Ur21OR7DLO0EGpWzHI2XMkf4OuRWV+0bpKan8OZFYZaN9xzn7oBY/wDoNTHsx6Jx Pkv9nfSGPjnGWD6ba6mhC9yYXix/4/8AnX1h8Uf9HutPhHyiGBeBxjCL/jXZFrmt6mmN1cfRfkaW lRtD8JLCOIjfe3LHHqDIE/kTXyJ+3V4hTWf2ktcigkDRaZFaWKkEcGOBN4/By9a4fWX3/mckzyC3 IadM5wCTn8K6v4d6e2q60ILUFpJWjhQDPJdgv8zWuJdoNjpfErH9L3/BOLRn0L4LfBfSrqDU9O1D W9W0u7k+yXYW3uZvIbVJt8IQls2pYFSwGNxP3QDcHxcE37Z3xX1K9nuZNK0e1WN7+WOSUOYUurtv KVkYMV822IUsBtBGNoUV+WymvYVO0pfrc99wfto26L9C1+3foknhrSfhR4J0Us0/g/Ro9cvNP05L i2Mk8YRXMP2ZHeKSS6u4SFGQRlBksEbR1u81Tw9+xHrGneGp31G7+IXij/hG9E1FblrvzrW0EGiQ M23cqEyW8rMnGGJ3HOa6HGUMReP/AC7jb9P1MLqVGz+1L+vyPiP/AIOKvilbeH/hB4G8A6JHLZ2+ oXX9svp1xA6JBDBb+VbtEWJCL5DRDahA5JIycn8PNUml1TU5XUEtcSE4HXk9P5V9NwvT5aDl3f8A wPzRyZhK8kiLXY/s180UTllgAjH1HX9c1Wu4/s8EUfO777H3P/1q+pjsjzupGYjFbAkENIcj/dFO tdPllt2kjQ7CdnmNwoPuTxVN2V2OMHN2QLbQ22Wkk85o/wCGPhc+mT/hUQunfKxAQpySI/4vqepp JOWr2KbVPRPXubujadD4P06PVdehWe+n/eafp8ygoF/5+ZVPVQfuIeHIycqMPz93PNql/LNfSSSz SsZJJZDlmJOSSe9RT9+Tn8l8v+CKWisRiBppQBgD39KRrUzzBYvoP8a22M9SRIUlnjhZ9kZP3/Ud zSyxxXN8iI3lxM21WPZfU0rAxLmETzhbdX8pTtBVScD1NLNbtO6hIZPKX5Rheg7mnYW2gS27zODH F+6UgbNwGB+dKbOWecPJGFXP3fb0GKQEh06V5A7FMZ5TB5HpSnTJXkDseeuMDn9aALVv4fuJpFMY lZ/RR1P5V6V8CfBviDwf8QNH8QaV4d03WpNLuUuY9P8AEUXnWc8iHKiWLIEi5wSjZVsYYMpKnmxN WEINSdjWlF817H27qP8AwUK/at8faJLb6f4j0DRbK+uFvXNlpMBaVgoEWWlV2CoACq5wGLP99ixw /F/x7/ag+I8FrH4v+MviC3SwMhgXS2WzWEupVyogCDlWZf8AdOOnFfIcuX0LJJtnqzlVcmeUfFGx +J2tW0Y8ZfE7xhq6wQfZ0S41KchIeP3YG/hflXjpwPSvB9a+EVwl/wCWhmuJZGwoI3M7H+tepgMb T2pwsYVqMt5Mof8ACEafpBZr1zqUsRzLFZyCOCLn7rzkYJ4/gyOeGzxVS5v7S0AXT7LTomVUVvIg a43kE5YtMxAYjrs+U9sV9PD3FqtTz35E0uvaIsEMWo6DHLxtEpgaEsxbJYlJhk/w46Adgea9v+DX 7K15481hktLXxF4cszbNcNf2UyXMIDH/AFYjDs+ME/ebouDyc1FT2Fe1J7vaxpz1KK57XXme1/CH 9gXxb4m8fXXhrwr8SvBJs4rZbmPUPEMyW9jNOcbLQyyj5JiWZcPgEo2CcUnxf/Zl+Lf7N2qpY+O/ BtpHHDI4i1LRZjDbXjDlgk8DKkgAI4BI55Ga+ZzHBxpVGovpc9nCV4VoJ1FY5F/jNrujmSPVvDHi G1bCeZLbXTTlSP4l8xX9uM4qvZ/tJaOb/Go6r4n0sq5JMtralgDjOR5R756D8K8p4Vy1jZ9TqcYt WTF8feOPD/xS8C3uk2vjSWOO6j2CO8giRPlYMM/u1J6DoR/SvC/iz8JrL4b6JYXWjayNTugX8827 Ioibgj5VyVGCepNdmCqSofu+W13r+RCpPn95dP8AgnB6N4m1COweS1uZjGhaMwTEmJgcjlc88E// AFqbp15MryQ+ErVmldtzvESVjYejkkj8ya9uNNRdo6dznrSi4809jrNL+D00l0kvijzL1WCyGCPK RkHnkj5j39K7Pw34Ak8Naq0NlbrFFBPjgc+WT8v/AI6RVuaj7qOCc3W17f8ADFvV/hUx1hobtTGy TArIvDJk9R6dQab4c8NPpniZ9O1wlLu3kI3MMCaMnG8f99DI7VLnzKxjy2djd0/wUlnrTQSj5SzR Hj14H9KfpnhaMTT2zryyOOndeR/Wo52LyZPp+hp9guY9vK4kGRnp1q1BYq1g3lqB5bbunY8Vk10B abEy22baNuAoJU/iOKttEQ8UqDO4A+vI61jJpaDl3PpyIeX4g1BScebAG/KtGNd0ak9D79K822t/ JGlrGBHa7b/VEGOcPjHNTWlri1j47AfpWtPS79BtnPWliYdR1NQv3Zkk5681rPaZiI+tdC+Jr0/I TV0c54ftBFEqqOI55I9o/wA+1aOv2Pn6TcqAQTGSMfQ1rB3k79yZq1ino8W+K3bkBoVOfoal1602 2QYA5RgeOuM1cFZ/MUr7Faaz2eJGIXh0B/LH+JqHxJp4H2STHKTKPwIxUxbsVbVDdJsSlmVX+BmH Psa5zxzeJ4dkvJboEBoFdRnl2VsBR7k4FCs4lJL2iXmS/DvwtLHbvqOs7Xvr0+ZKwH3R2QeyjAHr jPetWxtfKjiUDiG4kj5HqM1TdyJS97Q8+/ao0A3vwu1cIMmKNZhgdNjBv6Vx37FIi1LS9YsL6JZU SZZAkgyPmUcj8q0a9yx2QXNh5Ps0e4XfhjyLiAWVzd24aTaSsgfAIxx5gYCjRdDv0s1SLUn/AHTl dssCHGDjsBWW5zX0d0S/2bewTzmS6hYRvFIP9Hwck4/vVJ8RvDdxqngy6jvZYplkXbiOIoRn5cg5 OODWTVRSdmaRdN2bR8ufBq1sofid4kh063mgIhVj5sofcZ54Og2jH3iO9fQPxWH2nVJnBIaJNqoo 7AYz+ldUG9HLf/gIWLs2uXt+rOghsvs0Hg7Tzw22ORlx1G1mzj6ha/Pb4ray3jL4o+I9VCkDUNTu p1HorSsQPwGK7sJ39DjqaSaMi1057iVVTliDwPr/APWr0D4KeG7jVfFunWGlpJJf3uoW9vBFEMu8 jOAgUdyTRjZKNJlUI3kj+s39njwH4Y+HHiXQ7Xw1aNaN4e0TVtShFmwKRRWyQWC28kiLiQbprnvl niVvm2ZHyT8DNPsPjF4k1V9Jit5bzx/47W2nl/dnNnFepBuk3MGVvskFyUePcxd0ViBI4H5lOHNh YRXWb/FI9yE37abf8v6h+1Z8arzxD/wUS1m+0jUre10nwjbxG6ld5UikiiWfU3ikAfHzDTrZOhJN wi7DkFfdfi14Sg8PX/wq8CvewWtz4N8OPrN9JdwrIH1KdFskYtIyhZX1DVIpdxGflYYBOa3d+evV 6NJfNq/6GX2KUeqbf4n4gf8ABcP9p4fG39sDxDplvqGpyaf4MhOh2lrqkislpskYOkIX7qZ6Z+b+ 9mvhK30949etPs9nc3SsSwWGNiCR07exr7bJKTp4aN+v/D/qedi5LmILnwjqbMZhpWosnmEyu1s6 qvc5JFXtQ8B3V5I9zceXGJm+SKOSMsV6DBLBeAO5H0r1XUUWktTKFFyXNLRDLvw3eynOm2FsrQIF D3V1DLjCj+Hdt6nPINQQeCdR11IzqFzbwbfk3TLMVHOf4Izxz2qoq9nIUqijdQWg28+Gtxp7CP7Z a3aZ3NLZq64B9pRGavaZ8OINLtxqF9LJcxDJitJ444xcSjPykiRsxrwWPU/dGM7gVKiS03MYRcpF LVdAOr3M11qVzJcXdw4aTfIc/gBFgDsADgcccVD/AMIbBFMWSO55GMF9wIHb7q04yjBKK6A05O9h 8nhSGJ/ktCxOQrsWzj04fH6dqZP4UNuY8QqN5K9QSPzyaftESovcml8HizVRwSwHCnB+h4qS68Jm ygU28hxL95Ax/wAmj2iKUWVbvREto1/eJlh8wJHHOKZNp9rBGD5yBsZIyOKOZsrkSIpri0jICTDj qc9abJqdhtGHOR6Ch3YrK41tescKCCwX0GKmh8XWaEFbbcV9T3qbNhZJn2F/wT6/4JsfFX9uvwdr Hif4UWHhrRdA0dzBb6p4wuLi2j1e9Vd7Wdn5cMhklCDcxYLGijLuoBI+sPBX/BGL4ki6uH1D4k/D Wy0fTZYUm1azstQmjEZOZZ1MyRAxog+UsVLtxhVIc/KZnj6UakqbTbWnbU9TD0HbmvY6n4cf8EoN Z1H7P/wknxc1Ozs1uZrY6dYeFI4LgAT+VbwM7SusVxMp83y8N5EW1pvLygb4t/4KTeKvBn7PfiVP BP7P/jrxx4n8U2EhGv6nqU1pHYafOMh7OBYYleVkb5WkLKMqcIM8cGA5MZiFGENL/gv+DodFf92n J7/qz491P4q+INaJGoazqU0ONrCS4dt/tjPSukvNQj+F/h7zPE5ln1fUoiXsPNKssTDIjdhyi4I3 4IZjlBt2sT95hMLSpapWS/M8WtUlLTuec634l1PxpfIk0h2KcRWkA2RRD/ZUcD69T3JNepfCP4L/ AGae0ufEFt5jT/N+9bIG18MMdhgrWONxHs4GlCnd2Pa7L9lux+Js+nWOoTSWsEUmGFqB5soHBVSR x7nB6dDX6Lfszfsr6bovhO0FwdSEax7IrWwtXkeQgd3bIye/Fehw1QVSDr1POxy5xXcVGjBep3Wh +EdWHizVPDKfDrW5PDmtaa1jc6jewxMoQ3VtMAS7ptbMRAaMMRu7civJfAniTSvgZ4813wT42fUp dE8aaLf2h05rNrlY7+Ml7aRBCzqJY3EREjlPmkdPusS0ZjhqFerGUXy8ujfRrqh4SrUpU2t29bea 2/I8duLGGaDcyq219pOOoPP8xXO614D029nja7tIHE4bduQfeBr85u4N2Z7q97Q8o+LfhT4a+Are X/hIEtBdFd8dpYBTNg9jjhf+BEV83eJteg8RSvHoccqQt+7tt0u4uAfuMT29+g+le1hJTrayOqnC VOHtJOyX4mT4d8Kwa/4vsrHxE0scM+8PFD8myTBO39MV9FeCPAui6V4LsG060hVoWkgkYgZYqcZP 5H869aUvdsjz8ZdST6WTOq1DTYZNE0+WCNVKo1u2B02njP4Vl6lEJdQV8f6+2iLf767oz+iA/jXP 2scy0Ul5fqWfE0H2pLW4I4uoAD6714P9Kx/iHoI1/wCyXtqxhuZYVkiuF4Kyrwf/AK9OMrMyk7bb lez8QHVrhXvE8i+VFaWEDgsP4kPdTj8Oh6VqXu221dZ0HyPtlH0PX+tJqzsN2ixVg+x6y0ZztLGP 8G/yKbplp5N09vIRg7oyTxyO9Q3YzjtYW1iDwyoQSQu7j1FSwfvtNOSMxnPHoRWbVzSPc+oWgA8W DHHmwMtWdPUvZIR6dq4eXX5GnTQzxb/8T68Vh/rrcnH+fpTtLj3W4BHAPb61ot9ey/UVzLlstuv6 guPv24cfUVbSAsisoyWH9K2jo/khrRGJY2JinvQesd0H9c7v/wBdalzY+dA644ZSP6VoklJia2sZ Og2u3T7Tk5TfGc+oNX9Vsd+nSgA8c59KtWjJifS7Kv2MS3VrKBw8S/jx/wDWqPxLZA6WWUZMTK3T 0NSl+oX0uRWVqI3uFcjh8/gRmuB1uz/4T74gxmOMNY6eJIY3OcST4IZh7LyB77vSph8Bcb81zvNB tM6Tb7RgbVBHTHFQmwKNdDH+rmjkGe2RitErxuTez0MP4u+Gv7Z8JajbsM+fayJz05Uivnv9iTVR D48vbViP39urYIP3lbb/AFFVa8Dtw9nh6ifl+Z9W31mBAH/55urdPQ0tpYCK8u0UHPmFsf7wBqLn DrbQiv7MfapFA5lt2AHqVINX76L+0fDdwig7niYjA74yP6UKItVofLnw28I2y/HrWluNS07SEmFq scmqSrHHN5dyW8sMxADMIUAycZIr6507TPhVHox/4Wp468E2mqPE7pbS38FwFzI7fOQSuR8pwpLc nAzWWJc5Llpq70/I6Z73a0PJPjR8e/hx4R8TQahpHjPTtcngt7iKztdChnkgwIPlMjFVKEsoVVx/ FyRivj2z8I+FfFF6BpGpatojS7i66rafaoN5yeJkKuATgDMZx1LV30XWox5uX5dfl/kcyUZ6N2ZZ j+BNx4eLz3Yvrq2kYKt7amFoDyT8rozj8Dgj0rqvg9o0/wAOviRoniLw9b3VzqGg6hBf28Ms7COR 4ZA6btiK3UD7rA+hBrSvVp4im1fRpoUYzpTWmqP0L8Lf8FnP2jdF0W8tvBOh+GNOsbuxmsSn2KaY BZbgzs/7yYguCzKDj7pxjgY8n+GX7U3x++GmsaPe/D6+s9Mk0W8a+t1S2jYLM6XCFyshYMQt5cAZ B27+MYXHzH1PA048rk9DujVqSle2+5S1Dx38dfiL4h1K61nxddRTa1eNe3ixGNI5ZSnl5ZQnI2fL t+7gnjk1a+LXxU+M/i7xHPqvxT+LOsX+syRLDMyXbtNIiusqqyxgEgPGjAYwCoPUCrTwVPRQvqJR rTdk9tj5+1vwFqWoatNc6rdX888sheW7laQNMxz8x5JJJPcVm33g+Qui3DPOycBpojIUHoA2R+le zTxXMlGPuoxdONF3fvS/Bf5mbrHh63iwtxLLuB2gS7FGepAz+HArPurSytNykOZkXdv80tgY6/Ln gV1Qm0kooynGVSXNJmNf6vYxQfNd2SrIeJGLtzxxmqCappyytAuo27SZK7IhncfQHuf51t78kRbl uJfanofhljJrtyLm6AyunruDKf8ApqcHbj+797/d61haz8R7HUblpChZlUBRFwiLjhVGBgD0qYU5 VHzPbp/mVKUIK19TPj+IcCvmC2JK5JyePzpP+Fhi5ZxBaKCuWKl+3t710ey7mXNGWi3Kn/CxrqZJ PJjt4hEu4kjJbsByeTmqt34l1C40mK9llCQzSyxIqnnfGEY/+jBVciRne5nf8JNeTQu89xIAOgz1 P+TUH9r3LwF5pZMnhBuP4mtFFLZCvcia7mMeZXdmboD2FF5vSQqCdzYOPTPOKHuUleLfmiJ1Y/u0 JLdzmk8vJIXOPWmQtyWKLd93gdPevqv/AIJif8E1vEH7e/xPkxDeWfgnw+0cmta3bRlny+fKtIBg 7riZl2qAGI5YK5Cxv5+Y4tYKhKq+m3r0OjD0vazUT+gb4Q/By1+HHwy0jwh4XSPRvDXhWJLGeytB CYrW0hdJJdPgcFSEYAyXd0Xdi7skbSSnKafjTD+HYdV8WahJaWGnPDcx2MVn5cl5t3mMrCdojZR/ x7xBmFugWaQvI1fmlRzk99X+b3fyPdUl8v06fefmJ/wVF/4KaD9nK/8AFHhT9nfXSnjvV9Uul1DU dGWSO28NWvlCBrS1dwsn2tyu6WTHUD5mY/J+Rmp6zPrV9NcanK8ssrl5JZGJaRickknk819nw7g1 SpOu/tbf4Vt9+7ODHzfNydv1Ou+GXgZri0tfFeoR21/pmm36pLoqOfPlVAJCWBAXy2GV4bcWwMDI asLxRJd/E7xbM+nPdXrTXUrC4u/v7GYfPIRwO2a+sty0uZ9/y/4c8tPnnboe2fBP4CWmg3FtJcRG 4luVG6eYA43bkZV9BkH35616xpHgUraQbY8vBOAwUf31K4/76UV8ljsS6s7I9ajTUNWe1fs1eOtY +B3xsttft4tEgs1tHtPN16VxbxtIqlpZPL+cBCO3J59a+gk/ak1v4g+MbC01r4mx+HtNmjuvOh+H 9ssf2jyZxGktvNLD5vlurZBJDcHpX2OAVTCYKNK9n/nqeJieXE4hzavY6jQ7L4a+ITYS+I7rXtf8 S3Ml7d2h1TxLdXFzPBbXskP2t4mk2r80YTaQQWjkIypwPl34t+NZ/gB4wmm8C+FPFeoaHp+vQ2lh JYwCcefNbrOETfJulwysScBfnVc5zjjxdGdeEqdN6u2/9eR0UalmnLbW35HG+J/2kPBvhufxFbQ6 k97Jo13Jatb20TM8rRyEK6nG0owGQ+cEY+leEePv2n/FnxZgmg+HFjLp+lwSANdxE7l3fL80vv6I O9fMf2XOFeUamiTZ72FnTVL29Tbou7KPhf8AZlk1fR01bxtcSytJ5zzte5WCLaNwbGcnjOd2a6T4 NfsrWUeoy3/iG43PcTNbCzuk2pZqcOhbGf4CMjHByOa7XXjC1Olv/SMKledeUqk9u3ZHb/G34OQ/ s/fBTWPEugeHodXW7vrf7Zrl9aJmwgd9qGHfkoT32HdudSx+6o53wlaGXStVgi+cRGO8i9NrAK2P ++c16uMwqwKhSb6b93c81V3iY+1fpbtaxq6dcfafDd3DL96CVJhn0PBqhesJo7fkL5byLgHk7wrA fhsc150tCoNpu/Z/ky6iC68MyAjDWk+for//AF81DOguvC2VBZ7G4IJx0RxkfrQly6makmtTC8Qa C+o6DBe6P+6v9PmYI46MrDO1vUE8Y/qBT9I1ddd8O28xUxTQM0E8D/ejcc4+mDwe4oeqv2KS5dOx e1OQv9mmU/NLGB/wNTj/AAo1JvK1NZxysqrKvHfjP8qz5eopWY6Xbb6xnojEHPHRh/8AXpLEbLqa D+8GUA9yOQam1lcaPqm8i2+INPZurFkPHTIqfToNsLxtjKsynI/2q4u39dSrdCGW22+JbcnPzoy/ Wo9Lg2oVPVTjOPSqjpJf11LepXurLb4phHAE8Lpx/n3qWwtP9FQt1AH+Fb6OXyJ6GTPY+VqWpAjG USQA47Y/wrWSDfGCoz7CmtZW9B/CjFsLQRxTImMRXZ69g3/661Z7HzrZkHzZU/yrSWrbJSWxmR24 GnWbMOm5Ppg0us2fm6POuMkqTS+0wtocf4w1mWKOKx0NiNQ1eNFjdf8Alko4klP+6Dx6sVFaNl4W h8MaVp0Vuu1YHRck5OCMdaSdk7G0lZK3U1dChjisyjso2SOvOB0aqWreIdL0i8uRqGpWECyW+d0t wi/MrdOT1pwSUDPklKWiMPxb8U/CcNgPP8RaPkDBC3SMwz7A9K+Ufgt4u07wB8bpLqW4C6V9puIT dRAspQtuU8Ak5wPzrT4onp4PDTUKikrXVl5n0nqf7WngKOykjh1C6uXZcAQ2sgySOPvAVlN+2z4T sr6R47LV7neqA7IUHzKMHq3SocrIVLJsRV3VjO1T9t7Rru8hbTNCvSqbgTcTIuQRjGAD/OspP25J 7S222uh2yLGCuZbkknA4PCio5vI7HkMoJOUz50+LfxHb4ieJDcSwQxMyPu8gnaOF9f8Acz+JrhY1 EuoZmcKhc8k4r0sPHljY4cZTVJOF9v8AJf5nUQXenW8QU3FowTuJEz/9etvT/Hmj6VbKklxEWwTl VY/hwDVuE2eUpRudD4Y+Pum+FAJNFuLvzZDtaO1VlJHo2QAR14yeK9V+AvxA1b40eOIdD+GPw61j xP4guV3Q2vh62KzzKCAWMS5AUZGSE78mvKx2GcYyquXL3OzDyc2oJXPrnxL+yx8a/Afwa07xe3w9 t4dH1HUH0lLe91W0N4b1JjA8SwwySM2Jh5fO0l8DGSBWF4c/Z9+M3jLwZ4i1d2+G3hO18OR2s1xB ruseZd3EU0bSDyEiV1baFXfkgoXUHnIHzMKlDnUJt3evyO6VPli5LWx3XwF/4Je/GD423Os3PiHx h4L03TNG0a51OS8nS7mjVY5EtvJlt8RYd5DdIoePO61kPAMZbzX9oL9nDxF8F/2N5PiBf/FbT4PI 8mCy8KaLoEMSzyyyq0MaTmY5RrSSO44TKrIqkd6unWoTcUou0nZE1ee8orSx+fniT9ozxbqaTi71 mXqVCpGik4IxyB7t+Vc34m+IuvP5EV7qV2WWGOU7XZMl1Dg/kwH4Z719tRwlOCVonk+1avrr0MCX xTqc9qY5b67aIkkxGRiufXGaXTfD+r+IYml061vbiNPvzRxkog9WboB7k11y5aau9Ec6Uqj7kj+H 7fTYv+Kj1KHdwfs2mstzIQQTksp8sDjB+csCR8p5wDxB9m0yePwzbiwAKlrjdvuXQhlOZcDaPmwQ gUEEZB4qNaur+H8zaFoO3Wz/ACMQRYU5J+alEWxcHqeuK6EjmYog8pCMYzycUrQ+UAq53HkkevpR YXXQjuoN5VYh1ODjue9aV2iyeCtNiiBHlX94d3qDHb8/oamXQt6NryMl0FxNs+7FF1Pt/wDXpm4T yF5BiNOFX+QqiNwDZJll6nhR7+tTSLssopTne2U+nof1qWrGtNXUr/1sQMhC7Vxubqf6U5Iv4V6d c4o2IPoH/gnh+wP4l/b3+OFv4d8LONK0DT9l1r/iq6iZ7XRbAH55nA5d8BtkYILEHJVVd1/ol+BH wj8K/sjfBfwz4M+Fen6boFjpsSpbQX0qi5a4uU+fzJTsL6ncRyuGYgfZ4GZQYVb5/i+I8W6tVUI6 qOr9eiPVwdPlhfq/y6mD44/aC8DeCvEUNl4m8V+F9Anv5jHD/at5FAskcEQ/0kRyyKzRJgeQp5P+ uCFQtfE3/BVn/grX4a+EXgq58E/sv+JLPXvG2oRC3l8Q+HrvzofDlo2yUrbXkcjie9mdnMk6uSoy vBJz4WFwNXFVFGzte1//AEp/ods6kYK/z/yPyPPwx8aeObbz7Pw34kv5LyYvE8VhO6yZB3Hdtwe3 f1rj/GXhfVPAWvT6X4xsbvTNRtghlsr2MxyR7lDLlTyMqQfoRX6RQdOH7qL2PHrtztLy1+9nonwU 0bUtR8NSQWLiGG+n2EyAglUkhDYx1y7p+Kmvpfw5/wAEwvF3w18XvJ4TjTX9D/s8GXVYmWJzOdwZ fKZt3HB4yCMc54r08VhqlXDL2a6M4qVWNOraT3Z2Xw/8NaO9ithrkOr6Xe2jOsd2sSTQySkgrG6A h4zkEZIIGDkjrX0z8BfhFoVjpk876db6hfTByxvkEqtzkAK3yj8s+9ePleWUcVJVVK7juuzOrHYq dBOHR/kavjLwn4Vk8CTx3Jt1bULeeR44IEH2e4jgaRHUIAVX5CpHQA5PTNeJfB3wLB40+MXirw/K sYvLfwfG+lTLMYliuZjFKjFxjb+8n57AA5yOv0PuyhBN6rc8+SanOysuhr+BvE/iDwN4zttU8Jap 4a03wVLq+mXSXmsXoRbu+KJG0bRqTL9/zOeFO1+QSxHZ/H34gP8ACPS7K/tJI9Zn1e7ubS70i+sk Z7i1MQWK4h81B5vl7wrLDIoDQn5iJSREKqptrfdI0lRclpp5/K3/AASf9sH9gT4e+BP2a9I+J/wq vdH1DXNf8daRpM/iawWaMXVje2r23lGPzjBHGlzCW+WIMxzuYjivjvwx4p0rIhfSoEluNiYtkUhg G+V9qMQoB759eK5q9ONekl11uzoo1JJ3f3eZ3qahH4ugt49N/cWChb2USMD+8SQqsKsMBvmQnjBI VBj58Vp+Gdov5bq0jZ9xUgMMxllDBSBnluRz0xjr1Hn5Jkcni1Kfww/G+q/DUMwxyjRcVu/+G/Q8 Y/bq1bVB4Qs9JtdR1E6UkjvcWUlzI8UlyRuDbWJGVAIHHGT60fs16yus6VoL3T7hf2cljKT3dRjn 8Ub86zzPEPEV6jW0XZfI7KdHkwVK2jd7/mdNpmm+TrMttINvnI8LAjPP+QaxCwiu4UmUszSLEozj Dv8Auwfw8w1yr3kzOK5pJXL/AIbk+0S3NsSf9KhZQD/eX5h/WnaCwuo722XB+1W5x0/1iHI/r+VF lsZ8lnp0KujH7TbXcA/jh3hQOrIc/wAs1zup6PKq3F/og/0mGNXlgU8XEanlSOmfQ9uexIIlvcV9 bmno1/Fr/hUTWZOIZeQ3BTcMFSOxDA5qzcRGfRraXB3QO0Rx3U8ilypaDsloF/b7rK2mXlghjJHq vSm3UxhvoLheBKqv+I4IrNRvuGl9D6z12Lyp7OQ/KEmXnp1qe2miju7tZZUXbM33mHfB/rXBdJL5 miTlsZ2ueKtH0vU7R77VNOiMUh3GS4Rdo6HPPFZS/Fjwppjzm78R6Qv7xv8Al5Q9+wB5p+0jdXN6 eFrS0jB/cYmvftGeB7XVbKZfENk4gYh/JV32g9+FrNuf2u/Amkxui6hc3A3OV+z2khBG44+8B+tP 2qVrHZTyfFTXw2OY1n9tTwkmpTS2NlrcyvC0WDBGu454P+s6frVW5/by0q2tF/s/w/qE7Y5+0TpH 29g1UqlndHZS4erSXvtI5a6/brZbq5Nn4fijS4Ktie7J2suP9jvVC7/4KD6yYyLPSdGhOMYkd2z/ AOPCrUpN6HSuH4R+Koc9cftveKp9kdi2lRYYsoity5ye3JP8qrXP7T/xG1G2Eq3d2IZCV3waeoT8 9lW4zV2aLL8DT91yuZ+jeIviDrerrPBD4nacjyopI4ZUO1STgcDjOTWhqfgH4ra7aGZ7LxHLAjcr c3YQgg9QHcH8cYpezalZsj22CoJNRuyDRv2V/iT4nuHFzY/ZG3BZP7Sv1yAwzuO0sSPpz7Vq3P7B Pjpr2KH7Z4cBmyA5uZ2zgZ/55VqoK9mxSzbD04+5DUv2X7AGtTacZdX8RafbseBHbWjyj0OSWWvL fEHwibwN8Qn8O3l+0g8+AG+ihEbFZNvzBSTjHPc9Kd1FNIilmDxtRpq1k2vVH0boH/BP3wrc2ccl 5q/iKTeFYFZoUGMcjiPp+X1rR0f9hTwVaS2r341a7WUupSW9ZcFTx93HbHeleyeh59TNK83o7HS/ 8Mc/DvTY1aLw7CymSPeZri4kyAwz95zjPtitzTv2bPBGiQ3UVl4Y0bKM6fvLVHJU9M7s54xScm7H I8VVnvI+V/2r/g9ongeG8vNNtls5HdUTqQqrhQif3V2uvHTivl7U1VwRK0iqCSTGAT1+ortwkpSu 3/Wg6i/crm8yvHPZxghobiZh0LShR+Ix/WpoNQEMafZ7eAEc5dd//oWR+ld3LJ7s8/nhHZFi31a6 kgkQTOiOTmOP5V/IcV+lX/BurI/w8/aT8U+NpHgS30LRrSydry5ihgcz30U3lOJCN5dLWRVABw21 iVA3V4uftUcFUkv61SOzBN1aqUnofrT8fdO174o/CT4B6L4f1UWep69Y3Hi+Sby4LWWNJ0mvoZPJ SQ7pkaSBmEZk5iZsMMtXNfHDw/Y2n7AU9vp6TxXnxQ8a3UiXms3hM0aWbwaUZpJg7OEEGnM4KtvW PHAbJHxMYqpJ1JbwhFr1sl+TZ2uXLFRXWTOW+A3hGSH9hnx3qehg6NrHinXtO8I2U+l6pdxCR1RJ pGkXzvLYJd6g0ZQqB+5ddik7a+JP+C6vgTTv2dE8E+FrS61DUrSS1mvVs59QGxLeNY4bcrGjHYfL QIcgjdG5BJLGtsDDmrUILR6/rqOtUs6jex+X9zrujh5Fj8PQys5yDdXc7bP++CueTT9Z8Twq9pdQ aHoiyS26LnFzKE8smMArLKy52ovY8EV+hqhU0vU+5HiOpDpEpP4+1OLadN/s+yk7TafYW8D4H+2i Bh+dZGsatfa5Iv8Aa95dXb9N1zKzkAfUn0raNCMHfd+ZM6smrLRFNrfcQtT6TGs1zJE5wksTg49h uX/x4LWknowpK9SK7spqgdycfKuSaYmHcu/3U5PuewqtjJBHL1lYZVT+ZprSk/vMHBOAfei9gCTd HbBmBDPnHqB6/jWrpeh3OsaVJaW4keVN0qQKOmQM/oq/pUTnyq5oldmHcWxX90hAGRvc9M1ONElk gSXy5VtCCwuNp2vjg4OMdeKpsmzZHb2DXc+I1aQjCpEoJJPYAV7F8LP2LPFHxR0HR7zT77Q7S11p pZN15O4azSPA3S7UIXduG1c5PGcVjWqxpK8i6ald2PU9K/4JVFbt4df+IeiW8m3cqWlsZZG/4C0i cfTNdLof/BMPwXbWKP4i8aazcyRE+d9hsQgPqAuHI+vNedPMn0RvGh3PYPhl8MdC+A/gvUvDXw+8 dfETT/DmsSNcXuk2euCxgupCixkyGIRO42KBtclRzxkmoPF+m+B/Eml28fj281vxObQbbc+KPE1/ eCJS2dqgyuoXOTgDGa8yUryc7K78jpipLRGZL4k+GPh7VTdR6D4Xt7lVGLj7ArOewO5lXP8AOqd7 +114f8GW7roU2l2aseW061ijJ7cjec/lRyTnorjuluzkfH37fqNZSL4d1e637doW2jUcnjPzQ4/W vnePw5q/7TvxlXUks76+tlmtYr+/nkyUgX5A0jtkBjGhwMn7pxmvSy/DShPma1MqtSEVY9cfw/be EPjnLpl1qEl3BLb27W81y28CZpYHCfKoVRviKk4Hue9ftN4r8c6H8A/AdifiXrV9c6hrEZFl4W0K 3E13c7U3MNsY+XGR1bHPJAzj9KwdOMqbdR2ikr/cfI4uq+aKhHXW33n52fG79pHwX4i8aeIrf4X6 emnazbIs2p2WvabJFcGJZEd7iAl3VCEDdwSGYY5r079nTxrJqMsJgLGKRQMDse/6fyrwssVKOKnG l1/zZ6ONUnRjKe6/4Bxf/BQ7w1q3w78Ox+M/CNxdpZWyyQ6hb2pJXyZQQzbcepPfo/YISfB/2cx4 08YeHviD4ol0+7F54h8N3k9is7tGYtKjiETTIdwJCq8WCO4U4PbLFU3Rqyhbr+ZtCftaSkenfs9a 7Lrf7IGv6N4ltobhbDxNDqFvcT2oUH7TbxwlFLIoODasxKKBufIOTmqHxp8WXXwV+G13rOlp4xLa VPp9zKL67hMVmkshjmtIjvfdCRKRgLHuDcqNoxmqN2r6aFe2SVlrdpfgj59/aW/bd8QfEC803wv8 IfFF+ng25v7TVl8KJcubW2voCRE5DbUGCXfachC5+bniDS/Gmr2dk63ms3sFvHjg3M/lLjIOAlwU 9OB1/M1FlG0I69EThp1J01KorPW/+fz3PoT9hXwhpPxg+Imh6P8AEWBl8JXf9oEWtrGLQ3U32Fyk /wC7x5cAdImPdgrFjtO09JpOlf8ACPWa3OoyeVbLIsUTsmN5ZgqZH1Ir0MBVVqtWL92kmvXSLuZY qm24U2rym1+qt+R4b+03pDa74Iv/ADQzy2+2QvnJ3K2HOevQmvNf2Y/ETafoU8LN+80a+S4AbtET k/ykr4XDTcoyb3ufUSt7Cy6NHufiiL+z/FUk8K7laRbhT/snn/GsLx1oTRXl6lm4RyWMchGdpIyG 59M/pXQnax5fNy7LYrWc6Weq297bBhFKUuEz18twDz+DVb8saH4sUHOyO4HfPyNx/JqqzYSajLl6 DY7X+xfFhRyAiz7TnP3GP+DCm2Nn9g8RPbzcRu7wHPo3A/XFVLaxEtbHOJp83hbWLqTTI2kguUZb mzQYJZeQ6j+8MdO449K2vD08eraRcpZurxyRLOhT1U/4UrWZT1Vx9onn6Rcxvn90yyj6dDUdzF5u iI69beQqcDoG5H61m420I0i2ctqWk/FPWYybrS/F0yp82Lu5ZeT3AZ6NH+DfxK1q6dZtAnSRcZ+3 38aHnnP3ia8+GB0tKWp9ss2wuHdqUDei/ZZ+IV3gyQaBbkYG2a8kY/8AjqHkVf0r9i7xbq9zcQa5 qeh2UkBHEMUs3X67RVLBxjq2RU4jVnyQ1LVx+wHrEDhpPF8QDkLti03aAT/20NaXh/8AYBtjcXUP ifxPrEzQtt/0GKKEHgHPzK/rW/s6a0see8+xD2NqL9gXwvFc20Ump+I38wkM0l1GM4HtHxW14b/Y t8DNp0f9qaRcXU8e9HknvJ/3pDEbmAYAHjHGKpcsdIo5p5niKzvKRZj/AGNfAUN9NHF4btHZLZmj 815XwwPU7mOenfNdPo3wI8KWtvA9j4Y0CJiow0enwjGfotX7V7HLPE1JbyZpW3w30vS7a4k03TLG 3eCWN99tbojYzjsPesbxFpZ8e+I10q0ybKyZZLuQdJJPvJF744Y/8BHc1EpdCINtt9jorPwslraW XloALW7eLIHZlI/pWjqnh8S2E6hD9049jipu7md9As9IB1ONwv8Ax820bcdCRwT/ACqa80ow3VlJ g/JOoJPoeP6007XBu6Ek8PAW9zHgkRyuP1z/AFr42/bD0I+HvjBBcxJj7RaI4P8AtRyH+hFKTSiz 08mjzYmK7pr70fX3w5sf7T8IWE0fzB4lII78Vfbw6yWwOCfJvMfQOKN0meY1ysu6l4Skm02YIDnY fzxkfyqOTwzJLcTsX2hoo5iScAZXk/pRzah3Pmb9qz4eS694dvNVubV7jT9jPDGyhiFETMJsEcFj CuB6EdMkV8PeIfCt94Z0NrvWYlFvfjy4/LcE54YHODjpn3GRXTg6sVLlb3eh6E6EqlGUorSC1/r5 nLog5AqaGPAUDpXtHhluwiy6L/eYdfrX67/8EEvhddeKP2dviVNa6rf6UNV17TLaJtGeJb24mt4J DDsLEsqJPdQByE48xTvXGa+X4qqcuCkn1t+a/wAj08sTdVPsfqd+0b468NeBv2nvElprDvb2nwz8 DW1ravLHE9vCWRpRM5JEu5Y7N067dshJIZUI+cv+Cgb/ANlv8Cfhr4nu28jwx4cs7zWbTS5Vge4u LgQ293L5siu0W03083c4j74NfHVZOnWrKPRcv4I7qSUo07+v5nb+GGOmad8M/CMVzcXccsdz8Rbp ruZhPDdX8a30MTsrgq8DXlm24ghtuzOW4/FX/grT8f5Pjf8Ata+JprLUhqmk6HImh6a9vM0kC29t 8rGElm+RpBI3BwS5PevXyOn7XFRlLeMV/X3HNi3y03bq2z5U8p2t5pSrZJWNRj8T/KrGl20mpafL btlZGf8A0bcPlD4+ZT6bgFGfULnAJI+8bPIjHoVY9CvDbyt9nm8zf5O3YcqQfmB984FbmlfAjxpr ZVNK8J+JLqacDy0h0ydiyn+IYXkGk60Fuw5WdJof7FHxW1qxkksPAXijLMI/9IsXhKj6OARzjtXX eGP+CbPxjms5gvhJ7OeYDbNd39qu0AjpiUkE89R29cVlLE07Wua0oyjJS7G5B/wSa+KVzYu14nhr S1aRndL3UskKOnMaOMYyeteAeMPhPrPhDxLqehXttFJdaPeXFnPJFMgR5IpDGxUsQSuV446GnRxE ahFWHJK/QzIvBOoXNmFZIYPLB4kYnJz1+UGr9p8NbvU7eMmdEj27QYonY5xngHb1PvW/OluZtWJb v4cvasDey3LMQGGyEL7KOrdf6H0rRh+H+pJYqGlu4VkkMgVZFU4O3IbAyc7AeuBgccZrKUo9TV3s kv61AfCYw26QXJRo2bzDmWTGenIBxnHfHSr1p8Ov7NvAbGRbdRxugXBwevJ5I+pqXWuTGLXUkk8M C0YrJc+XGONsQWLdxjnAGeK9F8G/HG38B6W0Ng9paPIqAzmSFiwWML/FGSAWDHGcDdgDiuavB17L sbwl7G5pyftn+Ygi1XxBaxx54Nqs25R/wBsfpRL+2T4RtLQnVtT1nVJMnCLBuB5PQuf61xTwdZaU 4mqxGnvHOat+2x4XjaQ6RomsTZ+750qRkn0JBPH51yOtftim9nf+zPD6JG+fluboyFc++0VUMrry b9pMl4mPRXZx2sfHzVNVzstNPgGTgxRsT/48xrnL/wAf6neqfNmAB4wiACvTo4KNPzOeVVvRHo3w g/Zq134qy6f/AG5rUehrrCSPYxzRtLJOqHG4qMbEJyqsThmG0Zwce4/s8fsZ+I7K6vp9K8QrcaFY XVpca5b6W0yXN3YpISyISqlSYxNyr9Soz6essNy25fi7HNOstedaH0n/AMFA/wBnjwx+yL4s8FaD 4G0WKzvNB0+e01TxH80k160jPNskw2xyonI8zaWICksMbEsaT8bPFfxKOi3/AIY1LWPGfjG90lJX gkkis/s9tHb+bIPPPChEQucJztween2GR5Pi8858Jh9oq8m+0V+p83nOa4bKIwxNfq7L1b/r5Hgn iTWvHXm+JU1Twtqdtaa4LjypWhtLm5RcEhWmSbfjllXK9MdsAew/sgfFw6N4geLXoLm2FvdbfLu4 JIiY2wysAyjjkrjnlT2Iz15jwVmWQJV6tJqK1bt6btabX3OPLuL8szxOjQrJyl0vr16PU/UXwV+y boX7RnwgmurRo7u3vYDHPb4VxyMDIORn2PGOoNfnX8d/gZ8Sv+CdHx6bUNftLnxJ8O7nQ73QrBWT alhazoq+X8qlii7YwFY5G05PO5+HNKEZxjiaavbRr8j0ssr6zwtR26r9TwqT9pPSPh/8NbWy1829 3OYoxcafDO8QWRWyrqyg/dJJxjnJ6da9E/ap+PXhb9of9lXxH4b8ISW+najqdha30jagRAYEtpIZ 2fZy7I0TKylA24BsE4OPn8XVhTbnP+VX+R6mHpOVorbmb/E+TvhJ+zho+meHNE1Lw3q994m8T+Jp Hh0rQdAjVJ22yPE7OHDNGmUblguV54GSPe/Cf7GbeD/EVvB8Rdc8ManqkipGuiQXDyx2Ny/3kY7C jyDByckDY56AGvG9niKtOpOMbPZeS7npKUIzjTk9GejW/gXULLxykukSoz+WInFhIdq7kMcilwMb Sh2nGcgkYPNfffwD/wCCR+jfHj4O6VqXj3Xr23bUIIry2XScL9lZgGQ5bIZh8p6DrXs5Tlk6GX1a eI0UnfTrsjysXjU8XTnS1a7/ADZn/FP/AIIDaPeT3NlP4s8UTNqsFxcIulaRb3axKhVX8wPcRHBM yY2bjw3HSvzF8J/8EuvjN8JPjfL4b8W+GPJutXgdYbYXKN5+05DDB6Y3dcda8yHDrk5LDO6fc9eG bUqVCSraN2/C57b45/4J2fGvw18M7bXfGPgDXLaDSrYxahJ5as0Sx/xlQSxXGTkDFeM+ILT7TY2M 8gOZYPKfP95DtOa4MXl9XBtOfXs7mdKtGsm4mHJZ+dotpIQAyGW2YDjbsc7R/wB8Mv5VY8R2pvba zuiCGuINpYf31+U1yxdnoXU+LQZ4rVZ57O7QEC9t1YkD+NeD/Sm+IzuvLe8hPM8STDj+IAZH5irl GzJ0I9WC2XiiO4Qfupik2OuVbr9eprDljX4a+NpJWz/ZM0xE6npbh+PM/wB3kbh+PrmeW/3DjK2l zZ0uNYdYeBSGil8yIMDwVI4P6Cm6ZGZftlrJwXjYgZ/jQ5/xqG9bk+p9I6pqui2kRFzqenI3UB7h ASc/Wq03xC8L2mrCV9Z091lgTLRSeZyCRj5c815TxMIxvzHoww1STsosq6l8b/CVlDmLUGkKHG2G CQ5I98YrIn/aZ8PRa5NPb21+6SRquGEaksOCfvdK56mZ01tqdtLKa8tXoUtY/aqsJYFTT9NYtkNu mmAwfwBz+dZ11+1Y5vZ5rbS4VMwXIZ2YZC4z2rCWaX0jE7KeRtL95P7jK1L9qrW5Z4pbHT7IeUdy q8bHPH+90rLb9qXxVAJPs8dim5y5zGOMnJxk+tTHHTktdDV5XTjtdnpn7NHxT1X4karjxitrvCus b28ZUshyPm5IJ+mPpXrvh/Sg2nRh1+ZMqRnOCDjtXp0q3tIp+v5ng4il7GpKKMbx9fnw9aXUNknm 3d9F5VtCP4pMZBPsoBYnsAan+G/gdNE0GMvmSWbMjzNjc7scsx9yTmrerI2h6s0pdGC2l4pGPJni lGR6mr8mlbgcrkEelU2ZmbZacdulsw/hlhOfY5H8qu61pZWwdkAymH/Ig/0oiw6EraaDqV6g6OEk Hvlf/rV8l/t8+GBa6loV8iZHmS27cf3lyOfwpTVos9LKHy4yn6nvf7KF4de+CGgyA5ZLZEY56FRg /qDXe3enYtr8H+FYpxj1U4NEdjjxC5ask+jf5mqbJTBnGQynHpzXKXMH/CW6xa6VEf8AREt8ai4H 39rfLbZ/2gcsP7nB+/mk3pYVNa37Gb+0H4NXUPAl+uxWSSBSVHHypIob/wAdJr8yPidpLn4XJBcZ aTT5lhYH+FkYxt+opU/drwt3X6ns5Y+bD4iL6wf4WPLX0s24zKNo56/T/wCtVuXRhZWqTTEbPlPP vX0rkfMXQogjsrSGVivzAMeegNfbv/BPP/grXD+wp8I20bTPA8Pim+k1uPWWludTkgjlRZbabyDG sbZ3PZw854G7jJBHj5vlrzOlGneyUr/dc6sJiVh23a90b3xN/wCC0Hxi+Nl14w1XVvBNl/afjVfI vLyzsr8JHbbJ0EKoJNvK3MgJbPGPQEdl8Ff2/Pid+2J8SvFOtftW67eWF4bUTfadD0G2afymZrRr VYvIkAj8u9ZeEDYwd/y5rzK2RUYQqS5ruVv0NaeJd4rblT/U+gdR+I83iHUtbvte8cfE/XJNfCma a4T7Izouzbb280cEMkEAEaDyFdIvkT5PlXHi13+yn8FdFu4bqX4f6hdThzM73+uH7xOSHje7Ctz1 +U96KEFhm3T0crX+RdSTqJRa0Rqt4H+EnhyCTyfAfw6iNxl9l/Pb3AHbp5cgRvYfjVqL4jfD/wAK mG40XSvh9p81uSsTWViTLDgYJDLCox06EVu5znu2QkluVJ/2pNB0zUzcafq2mLNjLG3sJtj8f3DI Bnnr1/WqF3+29Y/vDFql9L2EdtZQLtxnkFt365ohQkruwSkt2Zz/ALasciM0dzrt0V6PM8EOeOmI 4gPWuT1f9sCPzJbh7TUw8gKsl5rt08RHqIjIEH/fIrT6vJ9TJ1I9jhfGf7XiazalL2Hw0yxAlf7X L3TqD2+eQ8cHivDtV+I/h19b1G51fULO4m1CQzyTqA2ZGJLHgcEnmu3D4eVO9jKpWU+hiar8XtF0 61xps0axOWHlm2Yuw4O4dMAnPWslPjxbRxRW1paSNtY7Wb5QDu44BrpjQlJamcpIz7745/Y9XmMO mxySoTF57uc7Aeg449f/ANQrMuPjtqszjyYbVAvOCpOf1rZUF1ZDkZt98XNcvnP+leWOm2JQAKzL vxlq142J766Yn/poQKuNKK6Ccmyjc6hcXTE3E0sh/vO5JqB2Zwckn61ewXfUYF2nP5k0hXpn8BT6 kigYH9fSlGE45NDGtDV8FeCtW+I/ia10fwTZTX+o3jbYraIcn1JJ4VR1JJAA619s+HP+CZvinwX8 Dbyb4lFr7QLSFtRdYLd/ITUmKwW0YkGGwXkwS2A2eldWGw8q7stuplVrKlvufRPxl0X4N/Az4Q+H 7zwd4ottd8V6WljcS2zRhIAYTGUtTg7iFEaqfcHNY37Nnj3V/hL4z+Ir2+m6be6P40t38NWt1bXC Zs7i9uBJDNGATtCwQ3Kg9iw9jX2WWYOGJxdqC0XLdvprY+exmJdDD3rbvmsu+h2HwB/Z2f8A4KNf 8FAfEngW/wDFRTwtDruu3q6tKHvEuGSBXCqgkQDKxjnI4foa5j4U/C6PwL8YNe0yOSN4dEvtU0qL YD80cRmjXjJ/hjHfvX6jwFL/AIWa1KCSioq6824XPzXxCdsli5NuV3r5WnY+lde+B+k3NkzSwxLL OM4OAcnGcA187fFP4UP4c8QzrpaSsYuWeMH7pIHP4kfpX6rF0c0jXwddpxacX5XX+TPx2oq2USw+ Nw6fNdNWW9n09GtT3b9iL9uTxV+xt4o0iw+Iyuuma9ax3loszqyXdm7MFfgnY3yn5Tg4wcYINfp3 4S8a/Cb9uD4fzaT4zOk3K6oh82ynAjQ7s4KEk7XAOM55xnviv5VzKMsrxFXCt8yg3F+dna5/VOBa zChRxaXK5pSXldXsfmt+3f8A8G8UvwV1HUPEfwQTUda8F3HmSTWGkx2/2qzB5PmMYmfywecq2zAI IQYz8L/FCfwx+zymp+Hfhd4PEWv69Yf2fe32ro7xW9pIAmAz/f3gdyQcEnPSvlp4aNWpKcpe526v yPo41JKKSWr38ib4Q6JZ/Djw+ln8PLq2N14kmTSb7XEBW5uI2dSIof8AnnFtBO1cA7RknAr6atPh NYxePPE1jawLFp2halJp9pbqMYhiJRC/95sFiSfU+te7gKVOrBRiu36/5Hl4ypOm235/p/mdIvhS G0VFs41XysY8sYGPYdK/VT9guWMfs/eGgxVj/Z0BUDA2/uwB+letjo8mFml5HmYV81aL9fyZ6r44 1KLR9f0uSYYZrO9KtGcFQJLfP8xXyD8V7a31f9tbwJLu8yVEvRg+g3MB+orxsodqr/rqepmH8NfP 8mfbMsCJqPk6igmidP8AVvj5R3H0Iz+VfzNeK7ZXOrRRgAWGoSEeyMxH5ZFfO4/+FZd/8z18NpFv 0Oe0+zE+k6tCQN0E8N4BnosieW36x0gt/tfhORWzuspwwHorjH8814yWp0Vm7/JFe6g+2+EBtB3a fc4yeojkGf55/KoZYvtPhaB8sWtJWjI/2W5H61ra2pg5tX0K+rR/adBsZsZMe+3cn25X9KZ4kg+3 WtpO5LLcQBXJ4y6/Kf6UuXlSB6HPXLN4F1+1O5m0u+WOa3k/595Cf9Wf9kkAD0zjpjHQ6nt0zxSk pP7t3WTK/wBxuv8AM1k03v1Rdr7nIrJOwyCceoNTwtPICDuAGDkk18NKEe599GUnokS/YpGIMj8j gqKmg0/e+JFYhR2NTKStobxjrqObTUblBzkct6dMVLHpoUYAUNnHT3rN1C4oX7P5QDMBgd6z7wvI 4CgAN1J49qul7zuzOtJKNluev/spt/Zvi63VXyGymMjH3s/1r6d0BEtY70XB2rDPIfnIwAfm/rXu 4KXPRuujf5nzOZx5cQ+1l+Rz/hHSz4/8YNrM4P2No5LeyVhj90esv/AyMj/ZC+prsvDenj+y4Vxn bhTkdwMV2RZwVHbTtoJe6Vta+TGTJalgPdTVuysRc2cUmOHUH9KdrMjYoPpYgtgTjMF90x2cY/rW ld6OJbOVCMl1IwPcUr7kle0sg99buRnzrRCSR1KnBr50/wCCgnhoS/DtLpVJNldwydOgztP86UtY tHflj5MVSf8AeX5nSfsA3/8AaHwgNu2C1ndSpz6Ft/8AJq9vubJftTx4/wCPm3ljH1HIqacuaKHm kPZ4uqv7z/MyNU1uS20ezj0xVk1G9Ajt4n5AbHzSNj+FRyenYdSKk8MeHl0K0soUZ5GivJVknkA3 StICxdscZJ/AdBwKe+rOP4V6ml8WPDn9p+DLmGFfmnhnt8+m+NgP1Ar8u/izoUbax4ksJ1d4mvGn 2RkKzCULPgEg4+/6Vm9KkPU9jJ37taPeLOIb4a21yFW50tnUtlVuLpyQOw+QrW+/wmtkhJGmafGX I+9JLPgem2UsMfhX0Htex86oI1tL+Fap5f2a209GbnMFnEhXt1C+9fR/wR/4JpfE/wCMmji68L6F 4llsZFEy3E+bS1l5x8skxSM9R0P8jXNWxFlZLUuFPm6n0b8PP+DfnxBrTJceN9Y0Wzt5CDJLZtNe TABiGIG1UZsYIHmYIJyQRiuyb/giv4f+GOhS3Wsa5rMlyFjdH0xRbJvXllfBYuucFeV2kKSCQMcS xUJNRnL5I6J0JRTaRmaN+x54IivbkXzate20ysLa1vdcDXAcAnBCKpA+U/eGM9zWvafsNfDXT9bh ttZsden+2oHh+06gWU567dignGfUmtZ1KSlZL7xRpzlqXNZ/YG+GcMRi/sB4C+QJF1C7LfrJj9K4 D/hgD4aW0kwKeIGVshUi1BFCE98GJmP5/jS+tw/l0F7KXU868V/8E8vDVxaPD4f8Ua/pt48v/H1N Hb3ESR918rajM3TnzAPavNvHP/BKTxfNorzfDP4o2Vzdmdl+w6zpTWcX2fBIcTRvKxkJAGzywvOd /FdMMTQ+1dGTpyPHPin/AMEwfj/4TlH9jT6d4stmtkme48PawsaI2wu0JjufIkaRNuDtRlZiAjOT Xzv8TPgR8Rvhm7H4o+GfFOlLyPP1KzmWM4IHDkbTyQOD14r0aTpTV6bTMJRcTgp4nJAJb3yagMWc g9BWxCWolzM90d85zt+VQBwBTChSMFc724H0pWsrA22y7r9ntezmiiEUd1bRuuGzuKjynY+mXjc4 qkEzyOB0xSWqQ2BhKADGWboKTymycdupoYegGAqmWH0oEALBWYKe59BS3EJ5HmZCZbHAVRz9aUaf JJ9yOQk9SRincTJE0eZm5j2gdAx/wp39iSFCGIB6k4pcxcY3P03/AOCY/wCzh4Y/Z/8AhJ/wn/xZ EJvrxIp5BMpJIcjyLVRjPJKkgDljzwBjL/av/wCCguufHz4uaNoHhc/Y/C9lrFjHcWlowWJ5FmDR ptPDHK5OeOK9ilU9jShHvr97PPlS560pPp+h5F+zl8IbvwddnxNBqVhrmoXcd3bSWd5C7jSnSQ7g yyLh5NqK2UJUB8btwKj2/SPhtH8Q/iV8LdJ1CK3ey8R+KrS2vLaE4iKyzW1uUcDJICyyfKT/ABe5 rpyrFyp15Xk+Rv3kutiMZh41ox0XMlo/Xqfev/BOL9jzS/2Tf+CiXh+08C2qC+1vRtav7jUmBzdJ 52pRQnbvIH7mKNTnHzKTjvXy54X1H+3/ANozxpeMgjabxBrLMiZx/rbkDjsTz3r9i8NJe1zfE1bW uou3rKJ+SeJq5Mppwvtf8IyPp3WbbTrm4tp762Fxc2iMIJMHKbgAfbsPyrz/AOKfhGbSfDuq+Jvs 0t21lGJzp8d8bPzghyP3ojk2kZLD5D8ypngEH9DzvJPr2ExVKg+SpWtr/ei1b8kn5H5xkud/U8Vh J1lz06F3bfRp3/Nv1PC/2uvBmqWPxM8I+GpfD+t6sLLwpo1nYXmlzKtuJX02K+mLIWLZEtzL8/BO QOTgDjfht+1d4k/Z11GGPXr2RLNpBCsrSBXjcE/K65znhsEddp9K/lnHVK2GxdSnW1d3d+f/AAT+ o6Kp1cNCVLRWVl5H37+yp/wWnv8Aw7pMNhqd8moW6Kqql3LuIzgLhm6jnGDW/wDtMfEL4Oftm+HL +TX/AAppuja2ytM+pWEUf2a6cDK/aIWVkZzk/MVJzXBK0al18L3OiE5KPmj5M8R/BfT1tvCqaRa2 yJY+J7K0WaKJIshhbyqCi5xgSOv3sADgDJr0yXTAvxO+IMhwyyeIr9sNgcGQ819NldKNNabXX4XP GzGTlv8A1exg+IdYTSLW8uHief7IpYwQcuQM8Ae4r9Hv+CcPj608afC7QrTTzFPZJo1k6ahAU2yT NFuliwG3qYG/dMJFBLHcAAcDbN6zhT5F1MstoKUud9DyL/gvp4V+Ivi34f8Awvh/Ztvf7Nuo9fli vL97kQRQQNbZUyH723KfwhmyBwa8S+APxD8T+FfiX4H1/wCP19p14fDNvPBdSaVcSTyzgpjz/wB6 iDAwA25h1GM9B8PTzylgczpYRu8p209ZW/r0PexOGVbCuXZP9T9QvBXxs8N/Fnwnp/iXwref8S24 IjeSfCGJh/C/JAPI7kcjrmv5y9d0mez+JHiTTNQhlgmea5iaCdCrq6yEgFTyD161tj4OMZJ9/wDM 0oO9P7jmPDClvGDWsi/LqtjLCz4zl4yHQf8Aj7/lTvDsHn3F5ZSEH7TbunA/jX5gf0avIUbXZvUe ny/Vlbw5AbyLULPqbq2Yrn++h3D+ZqtoCm5sr+3IOZIfNX/eQ5/l/KrW/oZp8rsQWUf2zQb+EjmP ZcIBxjB2sfyxTUhF54TkVQWaymDZ7bXH+OaViOa92Udd0+LWPBUK3SCRIJXhdXGflYbhXOtqFzpd pY2WvMWUK1va3bDl1U8Rt/tAE49R7g1HJexcJN6LYtQ2l6wIj0XUmB558tB/484q/J4R1u3tEnXS WWN8EeZcxAqM9wCT+lfnDqU4uzmfpUaMk/hCDw9rzH5LCxXdwfMumJHvwn9a09N8C69d5QyaZArj nAkkOR+VZVMTQj1bOiOFqSd5aGhbfCDVpflutTs1Xt5Nm2R+ch/lVqD4E3U//Hxrt2D/ANMoIVH6 qa5nmFOOqh+Jt9Wb+1+BatP2arfUNRji1TVNZuIW4fbMsWznr8ir+VdZ4p/Zf8Habf3a6FYXE8Nt NsU3l3NOSAAMklsHPJ/GlPNJuH7tJamP1aEaiU9UU9B8M23gX4meHbiwhjgt/OaEpHwPmXj9a9t8 T3b+JvFc+gaSWEE6RXN9Ih5ELLgRj/acqR7KG9RX0uSVHUw127u7Pnc8ioYpPpy3PQ9H0qPSVtFi VV2MowoAA4xj6VNolv5BuYsYMU0ilT2+Y/417NrNHz3xXJpLdX1mFWBVZkkQ49xxUXhiPfo0G4f6 sFCPcHH9KT0dhblfUYv9F1MY5URTjH+yef5VppHviBXoQPxoAzbdfLTTdw5RpoSfpzivKP20fDp1 f4Qa2ijcwt2kUe64b+lOXU3w8uSrCXZo85/4Ju63vttcsCeA0VwFzn7yYP8A6DX0v4m1iDw+lve3 xIigkAbapLMWG0KAOSSSAAOpIrGi/cR6Gdw/2+ol3/NGX8O9AmuDNqGuKReyM8QgzkWkIbIiB9c4 LHufYDHUT2AgiuWxzFJbz8dhuwT+la7K7PLnq7J6F7xhE39hHysYV0Zs+gYE/wAq/M39pbQDoXxV 1S0t0xiLYMj7zRyyRZ/JFrKTSkm/61X+R6uTa1uXun+TPH/h1r/jn4z+O7fw78HfC1zr+t3beXb6 XptvJczsw6nC44GMknAAySa/RL9mX/gif488SPb6h+2V4u07wXbyqn/FK+FRFd6gvtJcOWgib2Tz gfY19DVpwoR5nqeDF3Z99fD34C/s5/sFeGbXVPElp4e0aSHZINa8UuLzU7h1JIkQuCynOOIgiZAO MipPFX/BUPRfGsE9n+y34C+Ifi26jdU/tQ2KWNlNu5/dyzcOMZyF5GQe4r5ivWq4qbjHRI9WCp0I 3lucHe/H/wDah8bagYNG8PeBfBmnTR/Jc6tez317FIG6GNTsPyk5Gewq34V+FP7R/wAUNTSD4hfF +60/S5Q6yW/h/wAPWyKSQArK0+8jGf4Rz611Uspi3dq5hUzHSy2OL8Yf8EtvG+reKhqPhf4ifE3X Y4mVG1izntra3tZYdQliuUmKoBlVYMqADLM5BO0iuT8RfsdfELWtH8HSeH/GnxMnivYoL97lb0D7 OnlhljDGLYASeQWzgcDvXpRwK5ouS2OR4xpaM6fXP2KPGviOL7Jc/Ev4kRLJECXW+gLI4OcDMJ5z 19Rn1zUU/wDwTe8cyWEj6T8WfGSSyJhZLy2tJyPcjy1J7dxXn4nBum0oLQuGLcrpswvFX7EHxx0C xmbw14u8Ka2yRsYV1vSpLcu2DjdJCxI5x0U49DWNL4G+PHg3RhJ4q+H+ma6bWLLS+FtVUtKwXJxH Ns69gDXm13KlFXvv/Xn+ZtGopvVHM3n7UD+HrBP+Ft+EvGfhKUIC6appErRJxnmVARjmneDf2oPC HxDtFk8J69p91Fcbh5Zl2krypBVsEZBYfjWaxE6N503onui+WNTRGL8Qv2dfhn8XIHbxT4K8M6gr g7r2ytFt7gk5+ZpodkpIJyMsRhQDlRtr5l+Of7Efwl8F3EyeHNM1DT5bhmaLZfPcxW2FYYEch3MM mM4aQ8K4/iBT3ctzKpinyS+/qjkrQVL3mjwr4pfsvRanpxX4eahoMrRys0VrdxLplxJgqMljmAKV OfmmAGxx1K7/AAM+Fr8Xbo1hchwdoLoQv1yeMe/SvoXRdGK5pXuc3PGo/dWxqw+Ab/UPD0DRwMs0 c0sbtK4KBMKY8bck5bzOg9KI/hdqjlfNWNQpC7UDEn35AH65rDnSuhNFl/hLeRSAyzMzsDldgTA+ uTUkfwo2DLOxxyySSZDfkBjtSdVW0KUGx3/CtoiwOEXPSMZIH/fRNR3XhnT9PceZLBHjrkqtTKo+ w+XuUbu80izLZuoif9nLY/Ks248T6fECIjJJz2WqipSE7LYqy+MYRxDbsx/2jiuk+HHhm/8AHHib TbZ4Etra6vLaCRmBL7JWwCB6YzVuPKtRKXY/RL9pLxBd+GvgNZ2miXBgjWKWe42SlAOiIAo6nhvz NfCPhnXNfOsQXOhWn2ezs5YNRea8zvuWhf5nQkc5bf09xnitq3NGacnorJfJJhTcJU7Ld3b+9nvM HijQ9N8KNpul2upa/d6JNquoyrpsJby4lu5pHZ5N42hVIHIOQT6DPsf/AATU8a+I/wBoL9rj4UWq nR9K0nTfE8F7beHfs4+1zw2kiX9zIzgKT+7gfDNk/LjtXr04SdWc6abSfRadm32/4Y47qMYe1fbq frT8EfFVjef8FSvBw0ISTxN4KuJLWYEBXjkk1GUN82AQVkUjBPWvzv8AAl9HefHLxdNp0TRW82va vIqv8xU77ogHnntX7D4VTlPMq19PdgvulE/IPFWKhlaXnL/0iZ9U2c8aWsbOdw25+Yda4z46ePLb T/hrqttMMG9hktkBPBLKRn6jrX7b7CVerGMe/wCp+JwxUMNQlOXSP6Hmnxq8eHU9L+GHiW2kG/W/ CMMMpbjF3ZSGxlA98Wsf4Gvhz9s7WNb8N+MJr3wleRx2GvNFEdK2B5JpF28IpBxyF+ZSOg9s/wAu cb5cqWYYmmvszl/6Uz+ouFMb9ay/Czl9qnH8jz/4Y6x4i8MTyQajqUwljKyMDhghY/dHsMn/APVX odr+1t4y8P38Gk6daXupSzhQEs3bL56cDqcjvXxTvGnzPqfVKKlKx9KfDH9riDUNI+GOh6/DImra t4vsLm7NyFVIiJYYgoyNwwiJkk7cq3Fe/wDib4gWth8cPH+nXFzbRX9v4o1AvaSuFcr5pGAOM819 FlVVKCjfa36nk5lTvqut/wALGbrWoO928uFVPvBeeff881+nf7C17a6J+zj4duNTdYhNbWw3RLuY yOihQAPXcPzr0MytKhJL5fecWDvGqv66Hzj/AMFQPHPif4mQ3WmeA7+10zT7JopItS1ZxBa2845B ldioAOGyMg43V8I+HLH4jfFjUp/BXieey1XXnVra1t/h68l8LgMy7280Y3R7RnzEBUHGWAya/PMy ySOIzbB5hTlyugtV3V7/AKux9JQq3w1SjJfE9D9Zv2M/2Utb+B37Jdt4X+JGoBNbvbmbUJ4t4dLJ pCuyAsjDIRVUMVfht21uA1fjF+0r8RZvGH7SGp6tqNpb2AglgtEt4HkkxBBEsCF5JCXkcog3Oxyx yfauzGVueDst2awjypr0R5z4phPh7xfY3MbFRZagrcHGUdWXH47xV3Urb/hHPGzSJxEs6yZHI2Ny f0JryktS/itd9yA2o8O+NuQfKhuBkdB5bcf+gtVWOzHh3xw0b4WNbgp8xH+rY4Ht0YVaWrM+qZlv rel+EfE09r4j1CztYiZIJPPlVflYcdT7CuRg+O/hLQnvbe+1i3MMsTr+5VpAXXlfug9/50Ow1TnL ZfgczdftY+GdM0y9tIY768E4Vo3ijCqHU8E7iDyPauS1/wDaVfxd4buNK0Xw5cXC+YLmKcFmeBlG Nw2rx+dSm0dMcK1rJ2PrcaGrRjylPIHbjpVz+xojY+WtugbjkLjn1r8QdV2sj9Z5dRYPDSoiFCvP JAHIrS03Q9ksYAGAce9TKq5Ms2k0Ta4JHPTpUsOlbcg9sfjWfN0FfuTWtmVuRyV3AgE9uP8A61dV o2kf2n4MDbldpOPlxkMVHLD+VXDVNHPV0aZ5N8VGbRNHguoyrXMNzE0SMcbpA4AX+de1fCLwo+k3 0FxqLGW81C0Wa5uMH95LnBx7AEADsABX2nDd3h3fufNcRJKpHu1+p6Ldx7Y1P90hunHBos4/K17U I+cM4kGfQqK+gl3PmerJr1fLu7Rz/DMv68VFoUXlC7hxjyriQenfI/mKXzC7sJe22dQmjAYm4tJE /EcipNFbztMt3H8SDOPpTvZi9CncL5UL7h/qL1G+gcf/AF65r456L/a/gu/hZQyzQOhGB3UimnqU t7o+S/2C/EQ8N/FS5sruRYo7mzcNvO3DRPj8MAk/hX1np0Uvj54tXihuJ7K3bfp9vFGzmXa3z3JA B7Ahf7qlifvYHPSkoxs2e7ncbYuU11S/FG1pvi/R9G0zVNUn1LTTbxXRUW4vrdbqViBnZA7iVkzx vC7OvzVmeIvj14YtopTZ6jHdPPaqr20EM3mRuX5T5kCM6jJ4bYezmlUxVOK3PJhg6smtBL34yy+K /Ct4PC2kajPIi+X5L2z7nLHCFAu7Oe+QNvHLVxdj/wAEzde/aY8bp4v+KBv/AAX4ZZn3Q3dqRqF6 zAM0cCMAMAqf3zLtJkG1XKuAYWSxlRJbLU66beWP2r18j6O+BWvfCn9hLwyvh74HeGZdQ8QavMyx +EPClq13q+qShyN91INzqA2cGU4XPCquK+j/AIH/ALEfxz/actG8Q/FyfS/gnpl9Oz22mWMZ1HxC LUgFd8kn7m2fkj5QWHf0rsq1KmMryowdv8v6+889ctKPPLc9U8L/APBF34V+A9bk1PS9IuNf166f zrrxP4uvJL+8nkIALZkJVAcdEVRXoek/sBaVpl0rWdzFaxLj93FHkjHbtxxXs4PBU6PvTV2efiKs 6r0Oy0X9jvwlpjq95HNdSL3chQT/AJ967rTfhnoWleX9k022zEAql1zgD616LqL7Ksc0aNt3cydA +EvhzQPHWrXWlWEEc2oWqCaEJlRm4nmdhxwWkndiM9T0FTWfwK8Kabo9np+maNa2tnYQx29vBACo ijjUKig5zwFA/CrqVXK10tkJUlrZjj8EfC7TLI+kwNIvR2JJ/nU4+EPhxV2rpVsB6YrGfLU3iUqV upna38AfDmsoQbTyWxjdGf6HiuN1X9j/AExkcabMNrHOx1xj8q8/EYCFeNjaM5QdzhvGf7FqXtk0 Zht7nA4DLnP4GvAvir/wS28G+OImHjbwPpF1Ll8TG1VHAyeQ64OTz0Pevk8flU4R92+nY7aVaMnq fM/ij/gi34W8G2V3P8GfEfxC8ITRM7pp9nqRu7WQ8HBjulkJHBHDD72TnAr87P2nfh1qvgz4ta14 R+MevS6TrXhddQ86+voIYbeRoI0mESr5xcyuktuQEDEmXAX5GNevw7UdeUnVilLXbS//AAdScYtL LY8CuPEVuumkeItWsQJOTC84GVz6deeuKx5viL4U0ViovYH+UfLbQlwPbIGP1r28TOVabUdlsctK PItepV/4XVow07UItKgnmSJY7jJRU3kOI8Lnn/lqSeOi57VzV58c9zN9g0zgZ/1snT8hWSoN7sty srIwtR+NmrTs3kQ2kK4P8BbH4k1h33xO1y5UhrsxhskLEir/AE9q2hQikJy7GVqXiK/vGxPeXLrg HaZDgZHIxWa5aQneSx9zW0YqOxLk2N8vnn9aVYy3QfjT2Fqza0awhsJIbjVx8mVZYGHzSrnBOO/Q 167+z9d6pe/E/wAOyfZorKxjlEcjXON1wYyXwBjIIDL6cDrzWEnrdmy0R9L/ALR2uXPi7wvfWEJM UEItEVicAo285ye2Sw/CvOv2qv2Y/Ef7Jt5p1r49nt73Q9Ws2/svXtFkbyLh2OXjMm0HI3k7TwVI OeuPo8LhoVcRTqVfgV2/y/A4XU5Kcope9pb13/K5T0XTJfD15JfafPbwDUrN7eeKxkV1ZHVQxAKK VV+eMcZ64xXuP7G/x/H7LfxSPjDwxaQ3msaToeorpvmyhBDcPB5Syn5TuA3n5eNwOMjNfq/BWXYf F5bjXTdvaynFN9E4xt9zbPzzirGV6ONw3MtIJOy62cr/AH2MH4rft7eLvjP458N6n4auJNHvPBvh uz8OLNeWdq4+0W0LKqqBuBRlBG4/Mcn1ra+Cnx60f4ceLorj4veIbOyl1Jbmd57hQhlnljkOVRMl QXcjhcDPXivU8P8ACxyerUx+MkoRjFJ320qWv/5KeD4hynm+FWCwkXKcnJq3nC//ALcj6d1n9rLw nrGnpF4f8aeH/OjkKiKPUIfMlUZIRVLZ3npjr64rkfHfjlPGt1DYzahE5UjfskV9mR3wefTOK/as BnWCqVn7CUZxUXNSUlq7/D69T+fsfkWYQw6+sKUJOag4uL0jZXl6X0OX/bC+P3gn4Wfsw+EfC3hi 6vte8Y6ffvrtkkTQutjpt2ipeQTsnzW3+mQKRHIPM/eMHCHAPyq+jeMvi34k03xdfR6LavcEQ2Nn qDzbYUIIDhApwG5OSSTnPQiv5J4kzmecYyrXlT5ZTbk121vY/sHIMphk+Do4aM+aNOKin3srXMHV 49e0rx6YNSg0t7xkjG63MiQsVwoPKZPK8nHJzW/pNx4h8LajFqCadoU16gheP95ISrJJ5iHDLtyG UHn24NfLzcJJqS08j6CLa2Znal8Qdbu9Yt7rxBorGW3+WK5aVcK2Q2QexyAc+p969Rb4ueJPjVqm p+I9b06wvNVso4ZLyaS/eK4ugoKtOQFIc8KWPBzzj71b4apSvyxuZV4yaux+j/tB+L/DqkaQ3lQg ZRJ9TaWED0CvCT69+9e5/Af/AIKG/Eb4rXWi+DviF8WtR8HaDYzxQRDw9YoHhhDAFvtCSQkFQM8l unSvTji+aHIvxON0FGfPI+1/hN+xd8B/FCXOpfGT4n6z8R7+Wa1CSX3iJbISwhiZkKWrJOSRu+9I eo285z9i+HNZ+G3gn4TXOnfs+eHfDPg7T5Gg1A2el20dnFqTOV3GfEYbzAU2sHBOwqT3VfCrV51Z e9p5HrQhGK0NdfidBpljrOp+L7+y0/S7MSRXNxP5aQwRLEWch0bhQccMAcgfLyDX87/x0/aY8Hy+ N7280i/l1CJ5p932SNhlRK2xgX2hsqQRjNcNfSmdVKhKtdRPOPH37Yul+Ibe2Gl6VeNKPILPO6qH eJw3AG7rjH41Po3xq8S/HzUYtHh0OfS4L+wurOPU4kl/eTrbyGJQ5wqszhFz/tdq4k7vQ2qYVUYP mlqrs466v/i3qOj2UUCf2dYxwLawO/kK3lxARgE8vkDjJ5Pqah1v4J/EDxRHbXPizxRPcPfR+ZhJ pZSP4dpHAyOnFaqnLqRKpQp/Arl23/Yred4nu9V1C7MsSu7BRHtcjlecmuz0z9inQYtUSSO1uZ4E ZW8m7kdi2MZBwQOeaIxWyVyJYqW+yO68Kfsp6HoOoLcabpFukyNuRzGDsJzwM133hf4C29o4NhYp EVGCY4QvHvWkcNUqaWsjjqYnXudDYWaTRHAyemcVaj0qIngZPoR7V/P+zZ+zFhbOKJcDbj3xSxtF AVOQBnkk+9C2H5mskaOpIH3e4FQTzRwSrxIS2eNrYqlexKXQms5dtxGzIxXI4bGMfjXUxXKWUEiR CRFlRWxwFBBIPb6Va0ujKsr2PDPFs7eMNbvriQq+nWLTJZgDiRwDmX3APCn6nuK+lPh9ef2n4e8O XqZIngaM/ioYD9DX2XD87RnBdLfrc+f4ljrSl6/odneQf6K4781UT5fEIK8m4t43/EZB/pX0b8z5 NotazERY7iOUKtx7HNR2cfla9qC8YYpKPxT/AOtS31K8iS5j26rZO+cb2jP/AAJf/rVD4ahK6f5b n5oJHQ+2GIoJTKfiVZYbLVRanDmBJV46FT1/lWx8M9J1n4yfCz+1r/V9JsYZJnC6dD4c06Y2z28j xArNOjy5bbk/NznnNY1uZ6R0ubUlDVzVz4U+Hngo237cmpeFry/vZba91LULKWS0uBbNeI6NKkUh TChWkVAVxjjpX3J8OPgR8MfE0pGq2F8NUdiJbPWb6fzDKvDEfPhyCCMj05Arn+rRq79D3s0xcoSp uKteK/yPU9I/Zp8DaXl4PC+jPuwc3Fqk3TofnBrYtPCOjaW7DTdN0+BmwCbe2RM4+g+tXChCOiR4 s8TUnvI+gfhL8DNI0LwsvjX46NaaZ4btITNbWkwCPfMBu8yTPSIDov8AH14UfN4nLd/EX/gph4/u dK/ZNhPhHwFYSNb3PxK1GIr9pT7rR2CjO75cjzMbemN3OKqVPZThCG709W/8iErxbl/wx9zfsafs B+Av2HPh/Jpnwl01brWLt2uL/wAT6sqTahqFwwAZpJ9u7bwML0Fe2RSSfaWR0xGqg789TX1uHw8K UX/N1fc8yrUc35FfQdUOsaeZmCj95Ig2ZwQrkA889qu10VI8knHsZQlzxUu4UVBQxd32h87du1QM dc5Oc/p+tPpgFFIAooAbLEJUIb86q3+jQ31uUkQEHtjrUzgpqzFbsee/FL4XwS6XPdNAhjhjLHZ1 4BJ/l+tfyV/8FBviD/wvH9sbx5c+OLrVrWEa/exi5tIRcmSGKXyImVGlRR+5hjzg/MV5NebhsL9X xcvZ/wAv5v8A4Bu5uVOz7/oeeeHP2bfCnjfUYovC3xDs7AyERuPF+mz2LxkvtzmEzxFcc58we4Fe x/Bf/gkDf/GbxfZaXoXxN8ASw3kkcYn0ueS6kUsSCzRkJgDHryMn2rfE4irhU5Spuy6rY8bEZlLD N89N/I7T4wf8EBfjX8FLq51PwRbaT490YRyRebo8gjvEjkhKGRrSQhsqzHCxs7cA46gfFviz4S+J fA2sXGm+MPDevaXfWkTTzWOoWE0MscS8tIyMoIUep4xWWCx0catNH2OvCY2njI3i9eqOUuoCQgET YfkZ784qCTSJJTLtCAj0O7dzjAx+fpXoXS3O5UpPoa8HwuuBDFL4luItIh8sMBdIxllUscbIx8xP B64HvU3/AAiOiQrIbGHVL4IM+dO6QqBnGSihj3A+9/hWPtnL4dinSS3C2021QoLXSLNmw0iPL5rZ C5J4L4I+U8EUX/h2XVUjlSyhswTjMCMgTGDuOc/3hz70nJ9WC02PW/g1+yFqPjL4O694z0ibRZLT RZTY3aXlztuI5GKMki7h5aoD1cuvG7rg1Y1P4t6b8Ibhx4BtBr2sLIZW1q8t/MtImlRdwgt2HOQo w8vJHPloaulaUlOW35iqRaVj6Q+BXib4jeMvhxY61D4f1+/tb87ZP7GvjZzMv3N0cUSxpxxgKwI9 q7mP4nWv7S2va78DPizFdDThYNJaXXiuCS2vNMvkBMLRySrvZgcr8/UZXcU4P0+Lrww0IScXZrX5 9jysNz1FOCktHf7r2/M8p8P+CpPgbfN4N8fQ2LyWsRWcxSJMlweVMm9Sc5YHg8j8qx9c+Hkfg5tT my72c9i8+nXnSSBtwBUN1V145HUYNer4a51bMJ5fWbdOvtfutfldfofR+InDtKtkFHNcHFKdGydu qe/3P9TxnTdSjsLLXDK4Ba8jnEhPPyyruA7btpOM8Z61B4f8e6v49+JGn6R4QspN0skipDC215CI yWZm69FOSew5r0eJMxqVXSwFN+63r53nK1/S58DlGChT9pipr3lt5e7G/wCR6Dr2g6rYXcg8fyaT pbCFWa38U2caXMoOfnjZFkRkyCN24Hg8cjPF6tr+j6Hsi1PTfDNxLOxTztHuN3mk8Bto+716Dpzi vnpUfYrmhOzXZtM9ZP2mko6PurnoX7Ff7Nth+0b8eNU0XXjq1po91ZakLSJJAjNcQWzvaQzHBAj8 4RbuOeAMZyO1+IWk614S8datoYt9YttT0G5Ai0k6cxWWHCeVluGRs+ZuyOAExwxI8nG4x0o/FeTb 3ettNf67HVRpRb2sklbtc4rxfdMvjuy1HXbWe3KPtaCdtpCRyB3weQBlzyAec8HFbWiatBrVsu5I kYBVdTk8jIznnI6ngHuMEgbspzS+ZcVZaj9Z0myaTyrxgscnAm4xz3+nrz/UtxKz3/gPxzHLaXNt axwMfOW7ZfmhIwylerZB6Y57460k+Vppj0sy7qeteEfGOkyxabdXFhfQ3RlgmmL/AGYRZJZHVeSO mDg5OR25zZfDnnoj2Gv6FOcAhFuHtyPTh0UA124aUXUlr6f16mNdNxTt6lrTdK8YW04bw1eTylcb YtN1BJW3euFcn9K9m/Zw8HfHbxprWmjw5qWp6Fp1/frp6axrMskdsk5PKswychQWwRkgcZ4z6lSv h6cb1kv8+xwwpVJytSui1/wUf8cfGr4F/FS8+B/xS8T6tqsMcdu2sNp6PsuopCWXy2OSYTHsbJAJ OcjivLtB/Z48PnwjNFPpsVzqcU8aRNPlmlg8sLgKTjIIJJxyfyr5SWKjjHzKPLHoj6OrSlgoRjGV 3Ld/cRfDz9lzWdLivoWhs0tbmEwo8a7pFcEqr4xgHaTnB64r2XQPh5qOmQ20cKSRvaXIuopVXlHG Pw6jNONKd7xjoc1atGbTkzYsPgpcX6Is9qzoHZ1GBhWbkkegrrNF+AJjCia1IAO35RnGe/0zXZSw U6kvfOKWIUF7pu2/wWj0/H2hURc9TWlH4V8P+H03alPBleeoGa9engYwRwTxEm7GH4k+MHhHwgji SeyQpkndgn6V5d45/bs8M6PuW1nilPTOcAVrUVKirvcVOM6p2dpbGN22Ku0HjPSrSqVhw2Oh5wf1 r+VuXRI/fWPtbP7TsBdvl5AB4NTrp67CCqMAej84+mabV3YSfKjRtYlRCFyelRXcaM4LZ+Xnijl0 BPUI2AXDg8YAYkZI9aq+OtWm1JrHR9OldbjUQRJMhwYLb+Ns9ifuj3Oe1OPxX7akTSk12MHx1p0P h61S2s4TsaIJDCiErx8oH0GBXq/7P1+bj4O6O05LPY3KxM30JSvrOHGuWXc+f4jvKMG+jPWXhEkB Cng1mSDyrvTJGHVJYSfcEEfpmvqbXR8iaGow+fp8o5PyNVS2UvrFu5z/AKRZoTkdSpwf5im/dFfW xNrCmO3jlI/1ciOMfUCjTYvK1fUouwmLj6MAaLXF1GaxZh74Icf6TbzRc+uARWH8BfEd7eeF9a8J eF2miuUvpZZ75FIWyt5UVtyE8GVmLhR2OWIwAGmqr2ZtTe6PlH4v6MnwN/bUtL/TYykMF1p9+iyB j8isEYHALNkIcnljnua+49T8QaJ4hSW8k8P2t75uDOkN1EyyOqjD7JGSSKRQcblG7AAIbgCKatOV j2c2tOhhp94/kanwh+PmneJfE0mg2ltqoWNcQtqsbK6SAgGEu338g5VjyRnPbK/tM/tLaf8AATRD HmFNXuI2kRX2stpH081x0J/uqfqeMBuqhRvU123PAqSVj5//AGV/+Cm95+2/+3R8Ovgz+0zrt9qH w01vUDpsj31y3mT3bK32WJ2HLxyTCOIoxx+8yTgFT/Qn4Q8G6X4B8O2mk+DrG207TrKNYobS0jCJ GgGAABXpUMvhSq+2ertp5dzOrVcopLqadFeicwiRrECI1CgknCjHJpab1BKwUxoyZ1YH5VBG33OO f50J2Jkm1oUIJ54hel382VZwioiZ2LtVgD68HP44q7NdeVcJHsdtwJLgcKB6/wCFaygm9P60MY1J RXvLt+bJFYMoKnIPINIZVDlSw3KNxBPQetZWZvdIdRSGFFAHNfGPxVB4H+FfiHVtRUvBp+n3M8iD OWVYmJAxzniv4tfiX8dZvFXjzWNS1mxt2uNQvJ55W3EEs7ljzj1JqKclKrKPVJfqXZ8pl6V8Xks5 uLKbZjGwXZC/yr7F/wCCUlve+J/jDL45n0fUbvw34Vimtry4gkWXyp7y2lgXKkchY2kY88FV9avN swpYTL63P1i19+i/M83HQtTcm9F+pJo//BQv4vfDv476vD+zD4z1vWvDOq+Jby30XQb8DUIpbV7t 1to4klDGNWxjEe3GR619har/AMFJLnQ/G8HgT9vz4S6bL4rtIS8cWnxw3W6GdGjZrdJC2VeJpFbb LyNykYJx89VyqcKNKthny1FFO3e3U4XlnPadKXLOy/I4HUv+Cdn7K3xS8QTQ/DjV7z4ceIpmVR4c 8VW7NHE5XdtEN2FlLMGB4mI9B6eZ/GT/AIIzfFn4YaFNN8GtJ0HxnaoAUvPDkifaYlzjIt5ArF/9 3fjt7c9LHVX+7xKcZHo0M1qUpKnjoOLez6M+Dvil8J9f8A+J7jTfHWn6lp+ooWaa31SF45hICQQw cbgcZ/Ss+x0jFiJ8jzpyUkhMeAV2htw7ffUDFer7VOCa2PYh77umWWge1sBFHHCQkpy0iDIiO1sA 9cEmQH2oOmzRG1064kaae+khDQhsiJB/D1z93Gff6URldGklc9M8H+M7/Rvh3qHg7Q4If7PvZllv JLtg8cxSVnC7UAOAWPO89/oOt+EHwh+GGl77z4vX+rZLLiLS7aIWrEdi9wwRQMEdwe2CK+myzA0+ XnqdDxcZiaivGCNHxH+1n4fs9Tg8Jfs629/5zyItpF4kvIIIBG0ZkL4RERfkwcsQc4GM8Dn5P244 bL4iLp8enW39oyTKtx4i1e/+zW6yAYG7y45XMYJ69ce1dtTEU3p2dlr+PorGFOlKN/Pc6qbxXcft AeIPK1e70HVPFLyO8WpeGNfhvri6kIGd0EwieYYGcJuY9u9c7q3iXdpN34Y1iG8g8SWqlZcgRq2x AZF8tlEv3eTvIYH+EbcCacvqeLp4mhJOScdV0s/O3z9D6PLKn9qYSWV4ptQalyrvJrRaXT62Xdnz 1fXyWmh3d41ysitewRuhUjYCJySc92wp9torF8K/EePwxrU1zAbxC0ckX2iwm8iZVkGxtj4OMoWU 8HhiO9GYV5Trqbeq/Rs8LD0uSDjb+rHb+Fv2ztf8AGaz8Jvc3+lXBjZ9M8TSjUhvXIG3coAHtiq3 i3XYPBdzP4q8VadYWfifVxu03w5aRrHFpqsAPtUsa4CMeqpgepHSuCnC03U6I1m27I+8/CHhyT9k v/glT4I8caRczLq3xBvbldU1GFVNwWSeZBFuOCEX7OQASRuLNjOMfRH7F9x+y98Of2e9M8SePHs9 c+LWr3S3CW3jP59NkicfdcOPKCnJDGQEj+Ha+0jxfrMFWrzmuZrT8E/+COWDlO8r2Vr/AInxV/wU a1vw1f8AxUj1v4E2VgPC2pSyxTyaK8kllbanvKz2ke8b1iCpGYwxO4hmVsbdvg+jaldaXcGXR5JD Gx5t2JJ5x0x6+2OcY5KVrh6k61KLlv8A1+lj0sZgJ4GcI1F8UVJeaavc6pvF11oyRtqzW7xXIWSG NtxkZTnoqglWyD6A9RxsIwte+I0Gq3EQ1Dy1hjX5NNs2VlkcZK+aVcsSfTPPpTqOU3yo5YqKWpo2 WgQapdG8KxXnnwxE2NvCLXyZCPmjwpBbaxxuzzxzxXpkP7GF5rXgyPV9SE1q1xhotPimeR/K2Ft+ CeDwMLuz/KlSVSb06GkuWNrnMt8A9DsrAR3x1CVEmErlH8oyAHOwlfnC8dmz716/8FPjh4k8NeFL nwjb6vef8I1pernVNO0Qqghtbkp8xRtu/BDjK7iuTuxnmropYurCNRu0Wn8zOrUeHjNw3a/A9N/b 7+LS/GH4vaT4l1ORUurzw5pqXUzHG+SNDFk++2NetfNguYdS1K4l0+3E6WwJ+0IAWUdz7DnrSq0n Go0tg9pzxTZBouoXVjrMLLI8AnlVFNjM8cibjwcqfXGc19P/ALOfxDivbXXtP+Jk1vdT6NKixX+x EZwy5ZJAuAWU4GQBkMK78vqyjWjTbumceLpJwclujR1v9p7wr4Tt5UaW33QuwQnkkA8f/r74rwX4 kftsabF4uW/HiLUvs1tHtj0u0mMcPmFmO5wmN3BAw2R8tfQVqkKadmeZThKbTSPM/Hv/AAUovbje uil8erHNeO+MP2yvE3id2Au5VBJ6Hn61x1ce9onXTwai05Hn3iD4j6t4ikBury+lJzu8xzg1NpPw 11bXtLN48scduWCkuxZuRkHFeXOrKo9WdigoLY/UTTUzKA/3cjP0roINOhBHyZH1r+do6JH7BJ8p BfKlq5IVVHXpVNZFWQfK2JSFO3+dUl3Ki7u5at5NkIyNoHB9qpXn2i6uAtiNm443OOD9fSnYa925 ZutEvdN0W51C/Rfs1rGzSzKpKnHRQ3TcegHUkgCrHgjwJdafpEup+LDHFqN2yyG2Mi70ULlEXGfl UEZ9TuNXyctNt9f6/wAjKdaKWhd8Q+Ck8TW8Uv22OFYiUQsj7m9WXIxjitn4HaQ+geENd0/zhObO 5MoY46bt5H869/hr3a0o+X6ni5/UUqEfJ/5nsMIzApOCCB0rL1AeXbW7DnyLwjHsykV9py6Hxt1d Gv5WYDx1HesmBdn9kuf4TPAc+3P9KLCRe1eMvpU20EkITx7VFbuf7ekck4uLaGTOOpAINNoG7GP4 98RSWWpaZa6MI5NTuJtsSOCUiQja0smOQoyOONxwB1yO1/Yn/Z9v7ufxJNosTXplvDFczSMiMZEA PmNnA+YSkADoEwBgCqjTdR2RTn7OGp81/wDBXL4Fah8Kfi74Z1a/MO3VbS4t1eBi2HhdXGcqO0n8 6/RX4Ofs66f8Qvhf4f1m7vxPBqWnWt1GVjB4eJWHLexq6WDftpxb7HqY/EKWX4WS/vL8TK1D9izw 7Z6zqkt0ur6pDLOl6ZWuwmG2svlqYirKnK9eyj61+VX/AAVs8RX3g347eK7PUvtcNrBqM8Fpb3Mj u32ZCPs2SxLEeSYyCxyRj617EcPCklJb6fkfPRlKej2PhTwL4z1Hwz8QNO1vwxcz2ep6ddx3dreW 7bXgmjcOjqexVgCDX9mP7Ev7R9p+11+yZ4A+I+kbB/wlWjwXVzFGcrBeKPLuoQcDIS4SVM99ua6e hUlZHqVFIgKKACigCOCIxvKWOd75H0wB/SpCoPUZ+tNvUSWgdKrvpsT332hhmXaEBPYZz0/z0FVC bhexM6ana/Qjuba6ElzJazg70URQuo2owzk5685H5UXLT/2naLFv8r5zKwGVPy8A+nPP/wCutE4S 6dH+X+Znacb69V+f+Qy51ZrO7KThNrOqpzgnOBz36nsCKh0TxZDrl9fW8COsljcvbOCDglVU7s4x /EOM5qnQvFyWyQe2tJRe580f8Faf2h7H4YfsJ+Mr+wulhkvra5s0uGXPlFI3kk+U4ySkTADIznIr +Wzwr4f8F6744MPxC1K5t9DWdjmC0R5JY93yhTuYLwTyQSPQ54+n4R4Zw+c1qn1mqqdpxT6vltrb 5s+e4gzzE5ZScsLR9o3BuKvZc3RM+7PCv7PH7GXxt0GzstH0uLwvqHkrEt9HeP5pwM7384OhJJPJ T0zgDA8R/Z3+Gepv4n8a+HP2QtR+wSeK2uPDa6sFlhhn02WOYvJOkcbYJjRQrbCUeRSpB5r7/jLg PLqX1ahhEn7Z8id/deqSfk7tXPgOEuM8dmFPGSzOLSoR55Ra95fFJrzVk7Ml/wCGBfjZ+yRfacvh zwDrup3DYaPXdFvYLo2MiGNxL+5dmUhsYJVehI6HHtX7Pvivxvof7Uvh745/tl3eoX/izS9PvdL8 OeHJrMtq3iCNLae0aSO2iVRFbgPOgnlJMjh2SOTy5CnwmM4fxGUz/wBog1GMb36P0fqfoWDzrC5p C+HmnJtq3Veq9Cz4y/4KKeDP2rvijEknw0e28QakLe2iupNThS6vlhmwipcNBNF5igkExrCy5IwQ qsOr/at+OUv7EF1p9l8F9Z1MePGeMeItTi165utOs5HwEtjDcPJDc3AVDG8hQHfgLhvlrycRhnm9 RYetFeyum0tLJdU++u/U68Z7Cnh4Krdz+GMpXer0svuW2yR0Xgb/AIKVfD39pXQfD3h/9vr4Z6Xq kmpiRf8AhIYrOGa0sGxInmPJKQ8DNsfhGLDcuQA656/xn/wSv+Df7V9jZa3+zT4msWt7HfMNKtJ4 1GWYMqtIqNJF86/xxsxG71Jr4epCrkkpPl56Mtr7ry9V9zKwOLWUY6ksS+ejGUW0nvG6bt/iV7Hw d+2J+wvf/sk+Gb0a18GPHNkIX8yLxrY6qms2EqK/zlvIiHkB1ZhiUof9k18ofC3xZofiXxNqVz4j Y6Z9gspZLRmUu0lwSFRMgZIILHnHr2r7nKMXgcVk8qVSC5nO6fVLTrv3Pq+LMZl2LzCliMiuqPs0 mn/Nd30+439L8WSW19bNaCGWAgSn7REHDNu3YKH+X4V7H4S/YJ8SftZWSXPg3VbLT5FiHyXNxIU3 k5OVI+UdSTn0xnNbUsI60XCkfL1cQqDUpmDL/wAEgfinqPxDsV+Jmki1tGVIZtRsr+1YFI1VEYIh ZhhQoxtGcZJHJr6b/Z8/Y68D/saR6lq/jLw9D4ku9WjTcniK2iuo7KIE7lhV0PJDc5JJCAZHOeSl hHCs4Vlbf7zWpiFUpqVN3v8A5nm3/BSz4K/DvxX4X0nxD8KtF0TQbu4TzBqOg26WySttyAyR4Vug 5xkYIBrx39kP9oLW7X4hxTfGhLXxBZWNtJYxnWAs0piaFYSqM2WydkLGQnOIwq4DNXiV67w1GpNL WzX6I+u4XwEsyzbC0ea3vxbfkmm/yPXvjF+wJ4K/aG8Otffs363DoeoXsrPLoN4fkchM8DIVQWZ8 be38Jr5d+JH/AATW+J3w0klFxoseoJEdpks5QTtx1Cvhj+Argwub/WIr2nxd+597xX4b4jD4idbA RvB68vVenddi/PdR/s5fB7Q7Hxl4O0KXxG9w9zFdrZg3igkNma5k3DcoOFjQADgsp/i8u8TarD8W virNqtvo7aPa3TxsNNNxcXjPIABgyPlmLv8AQZbAwK9qVWPIox9Wfk9XDVcPUlGrFpro9D6n+C/x +vPE/wAI9M+GPx11DUbrQbvUmNlFaQmafRWMce12iZlUxSbWOEYENHITne2fdNR/Zl+Gnhnw3c+H rTxR4p1vW7S5a2+zxWyWlpYBSPMV5Hd5GZW3JsQBSRkORjd8riqdaliHOktJu/o1v96N+T28UpSs kjC8O/Ci2+Fi3tnpdja3+kaiqW2paLqZaaz1OI8kOiMCMEnZIvlzIwJRlbDHzHxT8E7LS7K38QfD RZLjwzqck6RjVnVm0maPiezuZNoR3QsMM21ZEdX2gu8ae3TqqSt2CblNLnd7aL07GF4P+FfiT4iS ahL4M0m71Bbd9lzqELJJNLu27TvQtwdwwEHPbjmua8Z6e3hPW9P0e00+31TU9RZlVjGBAhO0gk/f c5OOq9OprD2sZydNbr/K4Km1G7Ppr9n/APZ+0/xN8CtM8RX1qsetWkMiyRWkkUfmzmYqW8okbRs2 gcZ45r1L4azXU+namnjG2ubS0sIZnkuXtpGihjByxZowwVFjJ+bGAF6130Iezbd9GYylz6Lc4L4v fB6x8YaINX+GfijQdTuA4We3024BkbdnaXVgMZxjeDjOA2M5ryK11iPwjsg1x2txPqEltLIV+ZD9 nXqME8Oq5HWujAUE8XCPRtL7zkxkpQoTklrY2vjZ4g0nxt4ptfD+l6nb3V+ukwEADKtJukLBcjqA yg++a4PT/hdeeFNOlubq9+zqBslZztXaT6fUClmSdGvKNh4RqdJSvv8A5nN3XiyDw9qYbRjI0xPF 1ISQp7lF6fia2vFGuXt6+rWnh27mtG16IX1pcIx+abHzK3rk5HtxWdCnJVIy6jqONm29DwV/Bnj3 xjcyx21nq13LG5jdPLkC7s44JAU89wa3vDf7G/jbWNThTxPY3VtA7qshgjed1BxyCo2cd/mxXu4P IcyzOXJQoyl8meRjc/y3LI81evGPq0ei+F/2ANSt9ajTUtJ1DUrUybS5dIwyc/NjduHaur8Mf8E9 vFUmoSJoPhuC3t/nTzZf3jSAjHYMfTrivr8N4XZ5Xjf2PL/iaR8XivFfh/Dy5frHN/hTZo+GP+CS vxEvTLJd2qBpQyhIoJWUc8HJUfyr0HQv+COnxGGlvDDd+TFcBfNWSxBKkHgq3nAA9Oor1sP4RYqm +bFYqEPRtnkV/GLB1fdwmEqT+Vkd5aTtGxC7dwxwTW3BrDbCCiqR9a/hlaH9hTitmytf6m8ikbPM lboiDGaoPbXki5Zo05yEVcj6Zq+hUVypFnTFeC2Kz7sj+Jq1tG1b+y2mfYWMoAALYxVX1Ca5lZGF qXjK88beKUtYJHXStGcM6CRmWW64IHXonX/eI9K1b/VmhjeQGRpWURsSxOF9s1VW/NFP+upm6PLH zLHiDVk+wmC0l8pwgZVTcMfSp/2Z9QmuvEHiixv5JJDIm5N7EnDIf8DXscO/7015M8rOoJ4Ju3VH vPh0/adEtpF6tECfriodai26denHELwS5/4Fz/OvvOXQ+H6mpafNbAj0FZFzGIbQFutvqAPToH4/ rQF9TXlgEkDhxjcCOfQiuR17xR/Yq6S9vE1zd3UclrBaKcGR1YHn0UDJJxwPwBT0QRV2PsvC76bp 813qL/adQmkSW4u9uM7TwqjnaijIUZPcnJJJ+qv+CeN7Fba98RdEkXMs0dhq8XoEjd4JPzN3F/3z XThPdqIis+ZM8M/4L0+DhefBnwtrUMWH0vXFhLqvSOeCQH/x5Er3H/gnd4/Xxt+w54CmlcO9ppa2 RBnKHNs7W5OM9vLHXiuuK5cW79Yr8z0JR9plNJrdVJL71c9V1b4l6WrW2n6a8d5cX0gR44mMogXI 3fKoPzc9PUgntn8/P+C0v7JWgfGfxnpGras17pR1GBIo9askyYmX5G82J8CZAAmBuRsufnIAA63O Cajc8SKlufmD4Y+EngDRbh4Ne8R+JUvYGaOVLTQLeWPepwdrteqxGR12rn2r9sv+CZn/AAW//Zz/ AGQv2PvBPwt1q4+IJuPDFrcefq15olukU8891LcvsWO6kYKGmKrnsBmuinQk29TadSLSifWPw/8A +C9X7L/jy1R5vH8+hzSPsW11vR71W/3i8Uckaj6uPevYvAn/AAUL+BnxKVP+EO+LPgK4kkLBba41 iC2nbb1PlSsr498Ypum0Yqaelz1rStas9dtEuNDu7a8gkUMs9pKsiMpGQQVJBBHNWazKCigCKzm8 +EnAGHdeCT0Yj+lS02rMS2CikMKKAAgHqKgj0u3huWmhhRJXYszoMFmIxk+vAHWrU3FWJcE9Wfn5 /wAHJsejeC/+CVHjCaBY7TU5ruxtbARgbpXmuVSUZIJ5iaXJyPr2r+XCxmvoNUjtY42nupnRIbeM hmdmIAAA75PSvcyTMZYV1JN6uWv3I48Xgo11GCR9R/AH9nHxPrvizWNE1S503+0NK08T+XKvm2sV w0katayu235hFI2SjYVgOSRWve6X4n+FuqeJrn4aLZeHbrQ7I3VxpXh68vbpYhFC00hVrmSQ48uJ pG+cgbBggDFdmX8YSjmFGtq4QknFPVaNNaebOXNMgw88FisJXaVRp03bRtNWevldo3fgd/wV8+KH h62lW+1uHWLe2jVxHqcaTY+YLhgSGUHPUEc4GOa9x8Gf8FnNL8cWoT45fDex1KDBTz7RBIFVgVb5 ZN+M5Pp3r95wPFeVcQc+HrxSez0vF302f6H4TjeCc0yKUcRgqrl2u7S77rf5mhJ4i/ZF/aEuLF5R q3gHVbefzkuNNuJbXymySFVSXiABbIxECMYztyDu+Nf+Cb3g/wDaK8Oa1F4P+Ktvr7aiqmxiM0Vs 0EvnK5llKBjIQN2AIkG7HGDgeVnfAFLHc+JyuajKSs7axtp03R0YTj/GYOlDA5pSvyzUouSs01fr s9G/wONf/gm94p+EXhG8HxG8C6n8TXtJI4NKTStZkt4YrWRmeWWRbaSCd5I5GG1QCCHkByArJk/s +fD/AF74b6d8R9S8L/Bzx7qMmkaSJtH1tb/UNCvvDl/sO6dVlnmZlVSHOX2sA4wA+K/Gcy4WxeUy nTxVJzhd69LPXX53P13LuJcHn8JcrjC3LGMerShFX/NfI9C/Zp/4LG+PLX4p6T8PPiMuh+PZr3Yj SNdBbpS3OPMihC/KobO9WYgAk8k16p8bvgV+x7+1H8UdY8PeMYNB8FeO4bxojqCxx6TPeOqiYSxy keTMWjZGBcF9rAEDBA/Pcyy6vlUlVwkt+n3bnbDD1cM3UoaxX/BPm/49f8EHPG3w61I6p8CdasfF ukRFmTTrsi1uyh5AU8xv25JTNerfsjfs0+OvDfwy1CG48FeMF1C0Vwbe20O4uo45gp2FhEu3ZuyT 83PJ74r6vhPiChjqnsqj5anZ/ocWMxCxENFr2Oh/Zn8ceMPF/wAX9M0vxdoWs6xFdmSGS00CwMjp IInYskaM7sAFzwTgbj0Bz7T+1H8BLjXPhbqok8P63ZPbW5Ci90+eDaSpKqzSKNpzjr3P1r6PPJqm rt+8bZYnJ2Wx+Ln7VOq+MvAAj8NeMIZYLe2mLKjKcqO+D/vbvyr5t1HxLdafrs0mnzTR+XIsismQ G+UDtXyFSUa0JW2kfW4OtPB1o1Yuzie1+C/jT4z8EaXomo2lrd3lpqt1dWltdQsFLSWwi80DngL5 ykk4GCOete7+DP8AgoDqkWnSQ32qw38ELmKRJD5iBgBnGRg9eoyOuDXhZpkLwrdSg/d0/FXP27hH xNWY8uEzCneavZrsix4s+L/h/wCN3g3UbLxGLCOya3llmdwu2IKpbeM8hhjIxznGK8i/Z7+DWtfG CeTT/hIhgmPlhNVmmEJidHWSNozjdlWRSOnStsho1ZuVOfkfP+LGJwFWeGxOE1clK9vK1r+e59ca 3+zJ4ovvA2rWo0++tP8AhHNNfVpdUn1BLoFNOj+0DfmIEMwyu4Md3mgEDbz4pffs0+Jtc0K51nT9 H129v9RlN3DdYBS4SRt29pC24kgk5PUmvRxODdKF+l/0R+V0qyml6HOxeCPib4bvoUv9J8TWqKQM RySMODjnaeAK938GeHxF4AvvD1zKjWup2Mt0yyZEsd/CjzrMV4IdtssX0nPtWMUoLYqT5m/I8f1f xDcfBawsrTwYbr7Zqcrny0ldvMTOXB9Qd3T3NZPxa/tCLQdH8S+JohYSX6kWd5ZHa2UkJIj5zvyB k9goOeadOmue/UjmfKO/Z8+C83xD8Qxx/wBoeJlDqZZDb37iVlx9/aeoJ4x159K+v/gD8Gp/AOiz W40PxFrUqSSMJtSndllWVApDDlTwCuCDgc4G41+k5N4d5pnNOFdJRpy6yffb7z8/zvxGyrIqk8PN uVSPSKvtv91hPAP7IHjvwb8SbzV/h4LvS9H1i4mubnw7cQpNbuXb+EEpsxz05xjoKW6/4Jd3HjTT 4I/FUuvmWKd7x57a8trXdcuxZ5CDDJwSTgDGBge5+3wnhLDDcs8Ti4pp9EfC4nxili244XAya89B NL/4JF6FpfjKHXZtVlgvLVtyS6hqobauOhO1Aep/hAr0XUf2M/AU2nS2vjbXfDk+cEn7QXKsPYSY /Svcj4f5BBqc3KrNa+TPAqeIPEeIuowhRp9LvVGVb/so/A7w6m3UdT0adgQx2Wiuc57FlNaS+HPg T4eRMyzz+TwoigVcew6YFfX4PKcvwdvquBimurR8Zjs1zHGt/XMxk12iPf4wfBPw4B9i0W9u2Unm Z1A/LJqK2/bJ+EWgrO0vhi3gMcLG3y8bBpsfLvzjC+pGT7V6VWti6cHyyjD0PMw+EwNWa5oTqvu7 nM6n/wAFQfCvh5C2kaN4Wt9udpkO/H4AiuN8Tf8ABZ6x0WbamoaBZ5yRHFbqT14POeK8nGZngaGu LxV/me9gMlzKvpg8Eor0OD8R/wDBcp4tyW/iOVQQcCxtcYPPcLXAeI/+C2Wo3+8Q6l4juieOH2Aj v/FXyuL44yHCX5U5v7z67B8BcQYr+JUUF8ke22LBWBcDJ7n1q3Jwo8ruP8k1/nWlZn922JIIxENx ILnrxzU8jZj+QNx+VVFWJb0sQmcqWH3sEdT74rM8Y63Pp1gkGlBTqF+5ht16hTjLSH2Vcn8h3rSM eZpMqK6knh3Qk8P6dDbWxLIigl2OS7Z+Zie5J5PvWrHbi9uEjflCwDLnrniolLmk2wbvco+KTHap CFYzHyxGqqeMjIAqz+zZdto/xkaG7Zi1/bEtnoCrYwPwavayK0MVFep5mbrmwMvL/M+j/BgYaJHG f+WLvEeP7rEVLqVuJoryLBBktGwvuORX36Wh8BPXUsaPILixhkznegPX1+lUdYh22uqBSRtSOdcD +6Rn+VKwSsmL4k8TQeH9I82bfI8pVILaHBe4kP3UQHqT69AASSACa5Tw14dnjuYtS10B9Ra9aJlQ lktonBKwpnHAPU4BY89MADWtuxS01O/vbEf2POigZZG5HrXpv7E3iabRf2i7GOB0SHxFoF5a3DMo YsscDXKge5ltoquD5Hczcb6Dv+Cu/h9vFn7GniczHfNp62t+pUdGinQseBj7u4V4r/wS8+Iqt+yL LZSWq3LeH9Yv1DNceUEjdI5sHnuZX/Wrk3VxMIt7qx6bqfV8nnJfZqJ/erH11ofgPS9L+KkKWUks SR2011GnnhsMyq6rwMnByfwrjP25vD9t8Uvhlead4bcXGq6DDNfeSGGYyHVoww9CNxx6JWlN/vI3 PJl8DPwn+OmnxeD/AIyaxHbgJa3c32mPC4ADjdj171RF2dWsLeJFtg8BYpcRKQ7g4wH5wQMHHGeT 14x7vNbVHNZJXZbhaSw09lukuPtTSArcQzfu9mDlSmM5PHIPHPBrR0PVcwT7ru5EqL+6RBvEjZ5U nI28c961T9orxM2oyR1Xw9+NPirwJrcE3gTxJrvh2/jYtFd2F5JaurEbdwdXBBxxkHp7V9GfB7/g rf8AtR/DiFIPA/xV1/VEuSpjg18Rao+SoVQv2pJGXt8oIGecZrojCNRWluZc0qe2x9HeBP8Ag5c+ O/gnZF8U/AvgzxHHHuWSaCKaznLAAc7JCo5BJGzknAxXuXwx/wCDrX4cavMkXxd+HHifQmLFWm0e 8gvlX5gBlXER6ZJxnpjmuerQjHWLOinUU99D6i+Bn/Ba/wDZw+K+nQDTfHdzpE11M+2HxVY3EDK0 krEKZQrRBRnj58Ku0EjpX0R8O/2iPAPxcfZ8LfGvhXxDKCAbfR9Ut7iVCQWAZEYspwCcEA4BrnqT U5ya7suFOVOCTOyoqBhRQAUUAfln/wAHR+rWusfAn4XeEpiXvNa8SSTQW+1mWRorZyu9FBdk3lAd vI3Z5xivwF1LwHb/AAC/aTtU1tDJ/Zmq288sl2qAooSKfIAJVc+Z6kjgZpuknSlyy96Ttb5f8BHb ls1DExlNe7Gz/FL9Wz2vwb8U/Efw3+Keuat4A0y18Y6HrW7fFYalbRFVZyYpJBI29TtABUgZOeeB WH8V/HXiDw/rWu2VpaQ6be+M9NmH2iciZbeK4tpbSWBpUBTdskfoflyvQk15uTqOYYinhYP3pNJ7 6bLU24ryHFZc6+YTX7pO901rd307lbwP8HtL+AX/AATn8X+K/ijC9xq3jzWbfQtJeydnEYtAbuWO ZTgBSTZuD82Q4I6Ajzj4a/H7wv4c/Z+8YeGNR8OtN4l8QXenSWGvJOVTTYIGdpVEYxuLkqPmJUDJ xnBH6RTwVahVnSjLllzU3fyXLKS/rqj4l4qniaUarV42mrffFP8AD8TlpPEbRyFJy2U4PzHj9TWv 4b+JWpaDMj+GdVu7KReQYJChJ/A81+r4DNJQanGXK/I+Fx2WU60XCtBTj2aPYfhl/wAFK/jF8JLq 0t9C8UXl3CXBS2uTvRsdMr0b8Qa+xvg5/wAFYPiRqn7MusfEv4heFtA1fwjpWpjRdRuA8aT+bJGh x5KkZjYSqM7SCdw5wceviOLsEn7LNad7tLmjvrorrZnyc+BcTTXt8lq8trvklrHTs918jb/Zf/b7 /Zm/4WpZeOtB+FWl+FPFWmQPCdW0PSI0hEchUu0sUarE5+UDe6llGQGAJFZH7Yvwz+EH7UTeK/iF 8FPHdlL4quVe+XwnJEsEN9Ishl+zKRtC5X5FDZ7KW2k152deHOEzdPE5e1JtXXLo7+cX+lzXKfEP F5JOOGzeDhZ2d/ejbykvydj5m8HftqfFX9jTwDa638KvF11BbzXiQHwZf4utOhRwCyiNiyDmIjdE FOGOGGa+9P2Of+CuGq/GXwrDdfEzwj/Z+qLG4m1LwbOQB8pziGRwy5HYSHOcAV/L+YcM1q85ewXJ Xp3XzW/zufsuMjSxEPbQ0Utb90z6G/Zw0XT9E+JWj+PPgJqSSTwG5f7DqJnVJkkR43WSF2VyFZuA p2hlXrgV9Et+3T8TvB1sj+IvCGgazEkh8yTSRcQMYx2CMzkHrz830rnwvEdfFc2GzNWqU9Obv6+f mY5dWjh6nJJ7n58/8F0P2mvA/wC0t8K9Hg8c/D9dC8S2t2Y21ZTFMTGQSVLbEkGCQe/U/j+Wvjb9 iux0/wCCGseOvA3ieK4t7a/+wDw7Dai4uiFsBdz3G1fnWKJNxZiuFAySOcddCLnFpbN6H10pxjFO 97HDw/Cy68Z/CkWEPim10E2Fxef8SXVnYOiFkDTZXIjMkuVKkDhYiS2Vxi/BzwR4Xupjo/jXWNT0 zVlukhkax8uWCaLcAzqT3C5IIOOMYrrxlaWJ91rRbBl2IeBqKtSfva/idF8dP2fo/h7qunHw3dam 2latETGLxfmZlPJIUfMMBTjHUGt/wnZeIfhPokV54X1x9LlkwCPL24yM5B5PTk8cDPWqov2XwkYv ETxkuaqz7F/Zz8d+M4/2BfGWueLJ/wC1Ne+K+uWXw78LWsbtveFSl5qc2W4IkP2K2LZwDKQcc49X /bz+APxX/wCCTvwg8CanrHivRvE/h/xBGLSOJI2geyljiU+WysWDDaQAwPODwK7cVeVCEmtP8zlp x5ZuCe93+R8y23/BT3W43iXxDokUxYBgrKp8zB6/Ng84xmtnVv28D8WpbbTn8MW+n+cshknMCrIF WNnYjBz90GuOMFJWLmuR3exzP7EXh6z/AGk7i90j4sIbrRId91ZwSyeWUmZQsgVxgkEKvy5xxnvX PfHiwvNG+P8AqlpNDor+A7aCCy0vVNcHzJZqkbmO1+XMnz/KfKBYjluMmu6GFTUZpbnNKulOUb7G h8D/AIhWvwi+L2lXi3Qh8hnifjBZGiIb5e/HPt17V9AeK/21PFL+MzH4C0/Wrm3tUkhhu4bEbXyU 3nft2jlByT0Ax61/TNHFYPL8NRp4ipZRtG1+qS/I/m7GYLH5li6tTC0ruScr2Wzbt955f4l/4Kbe KUku7C61HVY57VXWSXzo0G6IfPtYEqSOSQMj5e/Q+caB/wAFMtd+IesS2mkyaptgiMst5qV0wiRU HDdSQScDgc/hx4NfjHJaL5Izc5LTRdX6+n4ns4fgvO67vJKmt99lr2+75HDa/wD8FDfEFxrEtrYW 4mUTeULjzmZG5wW6DivbfgxeXXx98IyX+heKJ2voFf7RosNqI512naZYmZm82PPXABHGeoJ5a3ia pylSwlHXpfqdNLwop00quLrtrr5Hmfxl1zxV4B1hYk1a/uIn5jcIiseeRwv3hx+ftXnFxrnj7xJ9 qj0WPX7qdACkcEEzE+2FHXivma3H+dY5qNBWv2Vz6nC+H+R4CPPVV7d2bOi/Dz4i+KdKt75fC/iB L2F1imsrtJI1mB6SKJCMHjkHHY1H8Sv+CfvxJ8fvHeeGNMks52A82yuL1BG302swBH6/Xry0cDxV naalCfz0X6G9bNeFchaftKa9LN/hc0fBH/BJH4oa1pcVtrep6Zpy5Zh5bTzFSwGVK+WFPQchjXW6 d/wQt8Vaxbp/b3ijEyt9210tmXb3+ZpFIP8AwGuyh4XZxVmnipqHq7nnVvFfJqVOX1SLnbsrHfeF /wDg34s5HV/EOu69PE4/1dq0ETKf94o46+1eleG/+CAHgjTLRE1I6nqMwO4y3d+ykjP3SI1Qfpmv oKfhrl2Hs8RiHLvY8CfiZmeLTWGwqj6mLZXOZlwQB61rJchem73PNfwJFbH9rPclimDZBBHPBIq0 v71Rt6dM4qlvohJ9SC7VLWN5LohIlG5mY4Cgd6wPDFq/iPUpdbu8KJl8qxRuqW+c7j7ufmPttHat afupv+tQSSWhvTSmNVVyS4znb60+OTahIPzDnHQ1la2wLUxPDukfJc6nMGZBcPbqWz94AE4/MVb8 G6kmkfGrQZ3JHms8J565AIz27V6+Ve5i6f3HBjVzYOovJn1B4XPz6hGoO2O4Yj6MA39a0JIf+JlE COJN8Z3H1HrX6Ik0fnfNqVPCeV0iJWOChKfkcVR8Za7a+H3mk1F9iT2skQVAWeWT+FFUcsxPAAoV 1qF23Yx/AOjXWupb6t4kCm8kh2wW4OUsoyOVB7ucfM3foOBzvXtotrY6gMcxSQXAP0IBpKN1qVUe tl0OijQPF8vRhzx6itH4B63/AMIt8Yvh7qMz7Y7PWIYJiTjMX2hRIDnsULCnLREw1Z9J/tp/B3Uf G3wD8a6Rqq6ZY/atJvoD9susEv5bEYAUjO4cc18E/wDBCzT9J8ez/ETw543mu1iVNOvIrezhLuxL PC5VgDs5Eak99wrnlW5KtOcd1c9rDUVXy3E0pLS8X+Z+gPxP8Fw6R4mstX0jw3JfLJEQl3rN4EjV l/dhimW5AZf4fyrc+FPh7zrLWdG1Q6fbyXcf+kxWcOGmV7hrd1dm64AbnA5NVKbe7PLUUuh+Dn/B Tv4A3Pwp/ay1/wAOOokS3nnW3lxtEiCVuV9uTgegFeM2PwM8QaTHDNA2RIoYICMrnnkEgdBX0vPz K/Q4Uk4a7jtQtNUsY/K1K0l3gZ3KuBjHWsdzMXLBZYjnH2jlSD9a3oRUXZMwdPlvc6HTNXvrTS9+ qQpf2vQyxMu9fqp5P4Uah4wskts6BqQsrgYxFJuAH4ciurl5WZ7aLYXwp4u1HxBqQtNY1CWKzhzL c3dramUQxfxSHy1Pr1YYyee9W/Bvhqx8bX8+rzDZbLORDawkMoX0bjk15eYYp0INrod+Bw6rTUZH pGgWGoeLdVtNH8DWJmuyp+SH5VVVLEyMTwihcZJOMjPfFYPiq+0JvErW83it5dTtx5b3mhAmMOCR t35G8D+9jntnrXgYfFyjNyWp7VehFxUT0eX9vn43/sf+FrW++GXxP8f3Whuy7JINauGtIJCmzbLb k7RwAASMdMHIr1P4Of8AB0n+0h4QhNx4tuPDnjGwgIWQ6zo8cewMwIy9t5RBwCBnPUkgnBr38JUW JhzyPGxEfZS5T6m+D/8Awd12F75Mfxp+FaISQJLvw3qpHc5IilQ9scb/AF57V9TfB7/g5R/Zm+Jv lp4q1fxH4NlYfO2u6W80SHbn71sZWIz8o+UcjkAc10+wdro5+dXsfT/wq/b/APgl8bbe3f4Y/FTw PqUl3J5UVm2rQwXTvu2hRbylZcluB8vPGM165b3Ed3CslrIksbjKyRkMrD1BFYuLjuWfjz/wc1fF jxb4U+OHwk0L4OWGn6trGq6Nq5isL3apVQ8bSyKzMoz5aHgMCcHg9K/ET9oDxBqXjvxFDretW019 qN4u3WYJbZI4YZ4sRpFGMErtjUDceT04xTw1ONepGjKVnJ6fewljv7PtVcbqzVnszN+DmvWVj8Rt Ht9c0/7DbXMwt/ti4UW8jcRuMf7e38M13XifxFf+EfGc3wx8e2+qXVlrM/23TLO3hhuBd3Mq+XCW 3sGVDMgDdfuBtrkIR9F9WWBxNXDYOk71YQXM0rxfMk3fpzNv52PJWdvEVoTxtS9GHNLkTfLom0rP srN/M+uP2hvCfgm1/wCCXvwf1jwv4hsorLxBrniiSKx19GK6qbL7LpoVCFKR4SzTG4qDvBznNfBe t/CHw54ikE/hu8j0u4lyRbJcxzQsc44wSU5PAbGewxX2mFpxzaeKpytFwnLklf4ld6edrbnydVzy mhhasLyU4R54dmktV663RJpX7P8AZtItvd+MrHQr4gFR4js7hLWZ+fkjuIBMM/dwZFQdckYrp/id +xn8TfBXh6XxJremWHifw+NgHibwrq1pqltMTgYUQyNJwx2nKD5s9awhiZYev7KvFqUbr+u53+zh iKPtqErxl/XyMr9nr4e614i+KMsem6JqElxpekXl8ttcwuh+aB445MMASu9geOu0+hrX+G0HhG9+ CfjG81q+tbTWtIghtotJujLvuGeObe8eAY8hlH3sEdutcOZZnGXtnD3n+7Vu15rU6MLg5x9nfRe8 /wAGe5/8EvNY0TSl8TahcWGn6mLCxeNY72a4WMPLEIxKEjYK0kZJdQ3BPU4wK+Q9Y+JNn4h1rxJP 4VnmtzNNLc2u9yJRmbCqCMfwsSfXHavreIMwx2RYChmGGrXp12lTS+zyJqevW7afyPlMgw+XZ3me My7E07VKCvO+vNz2dNa7WSZ6t8QdIu9c/Zi8P3/ii4lknvLqykkluDudz5EmGJ6nIH619Df8E6tR XT7eazt0J8xtwkdRj7h6njg475x1BGcV+e5PVni8ROvVd5Sbbfm9z7TG0o4eiqVNWitF5JaJH3R4 b+O+r6PptjpulWulJbW0aRHy43LSDLZYkMASTkkgYzzXrHgb9q/VtP8AKXUtOa4i3bQgmIXaBnPO T3PT0/CvmeJuGKTc6ql7zbfzZx4HCLFddTmf2oPj/wDs/fGZINA/bD8Py6RFe4Sx8RSxOu2TcAoE 0GZIzux8rgoe+cGvHPi9/wAEyU8PfAnxcv7IV/aeK7TxDo91ZRW8Etul7emWNoxvuiwjkRd7NsBX JyAvPPxuV46tlUvZ4hXgno+x6SqVMHL2Vf4e58EfEL4deND48gN/o9xYeKLk3kOpeFLy3ktZHiub p5Hik80IgwZ5XTDMPlBJUhc/Xtn/AMG9Xi3x9+ynH4u0C3u9S8eR6VDcaZ4XmsdMjld2YE263pvc DZudlZwBhcccCvuqVJVqcqsdYrbz2OuFXkqKKfxO/ofH3x1sfEXgu68O+EfjVot34U8Y+GryWO8i 1hQohYowjbIyGQSpyV3Dg9asfEn43eCPHnw/Ww0PRNcfX5/MCy6xDZEwudsY3tCijG1QRhDyAWYk k1mqSlFW26nW52dux9Y69ZaR8I/2hfgH8Edbi1G1f4WeFrO6NnYeUsaeKtVYajdvLwzbAJreM7fm zCRX1t/wX51LXtE+F/gCL4jx6cz28c726aJbTXSyYiywbft2PwMMfl9SOK9CvBOl7N7J/kjni2qy a7fmz89vClra23h0QeK9CsPtkpPz4yNpGQdg+64ORje44znnFcn4h1zT4/iz4b8O6Hp/h+11/wAS XR0ewt5bSEzG6u4zbQkq4ZtpeUcvhCMjJ6Vw4eEIWsbTU6unc+lv+CNn7Kun/tD6Dfa34g1DULZf CF3eHTv7Ighs47krfSxIHSFFQbgoJAABbJ6nNfCn7WGkDU/+Cl3jbT7p2dLHV3iFvIxIUIMsOepJ BJPcsSa9mnhnNUqalrOSt99jy5yjSlWqtfAn+RtePvG0+j2aWmnwrHcSXAitndATvxl357KM/U4F dD8Jv2QNY+PHjK4X4feLr3S7WxC3EdjbRqm6FiWw5JUMyklScHOBxzgfr+bZBUzqcqWGahablJv+ 87X9eWCt6n5JlWf08hoxr4lOd4RjFL+6k7enNN/cel3n/BH/APtjWrwazf6munXIKrYQzJ+5Bbd/ rCDk4ABIA3ck8mt7wl/wRh8JaNpptWW+aKVsz+bqDhrkDorlNpA6/dx1NThPC/LMLaVfFyk93ZJf 5nNiPFTN8U2sPgowWy5m3/kdf4N/4JAfDbwmjCDSrPDt/wAvMk9wduQQN0jseMV6f4K/YO8J+Cli /wCEbtrTTvJ3FW063SIqxyGIIwcnJz9a9/A8NZBlluWj7Sa6u/8AmeFj+JeJM1upV1Sg+kUv8jrL X9lDw1bOWvDI78sS3G455z61bg+BHhvTiAtrGSvTcck/WvoIYyhhv92w8YeiR83PK8Ri/wDe8VOf k2zX0r4Z+HrLHl2MDds7c1pN4T0swSJHYgK425iRozj2Iww+oIIqamaYmeilb0NaOR4Ki7uF35l2 CzjhAFvZYOONiqP51YWVxhfJ27sEgkYFebXxNRpc0mz2cNg6MW3CKRp2EUroNwjGD1JPNXbeKWKQ 7pUI7cH/ABrhqO6O+kmnoj8vYLhV/DqBW6qFk+UnHWv8449mf3fJ7ImsyGcjPzDsavo3lRnCnjsO 9auJLZyfifUX8X6umjWgb7JCVkv5OxHVYfqcZPt9a6FFW2QGMBVUbRtq6vu2ivX7/wDgDfu6Fe8l C4B4OR0qS1kEjjdk59qzd1oV0N208KNL4MjSN1R/Ne6KJ82AxYAH3O2uDuZdninQZC2JorkEv6kc 9O3Ga9LBxcMTTfmjgq60KifaX5M+tfC/Gr3g6ieGGYH6qR/Ste+GySBznCSIT9Ohr9MUbH5y3oYk 3iC38MWuoPqblEguXAA5ZiTlVUDkkkgADqayNK0a61zxPY6v4lUpKHeO1sMhls0YY5I4MpHU9B90 dy0tFrRXOk8FWn2bTPKYfNBJJGc9iGIxUupW2+a8i5zPZP8AiynNNK+hm3ua2hSC70u3lXkSRo2R 34rMlV7NXMJZHtNRUq442b14P5mhq6HfXQ/STx1oOkeLLMarFaW8qa1BDfb2VSWWZDMevqCv51+R 3/BIidvg/wD8FFPiB4SuSYvM0/WtPSIcbprO8SdOPZYXrzK61i/M+gyuV8PiYf3U/uf/AAT9UvGv gnUtW8RWE1sVurW1+2JFAxACbJY2G7nnpWzb/D06Hquo6k1xPJPPI5aGNUVMG+34BxnI39zziulx ueNc/Pb/AILbf8E3/G3xz1i1+IPwF0W51y/s7mZr3T9OCveBFYx7hH/y1HEfyrls7uDnj8yNesfi H4DkaP4j+E/F9jJChCrqGiywocHB6opAwG556fjXq0pe15XF2aVjmuopxkjF0zxSnibUJVtJit2s aZSUGHaN6r1w397PPYHvjPLan8ONZ0e8m1K5vbH7HLci3MzMPLEzI0giDnq21ScdcDOK0nUU7wv7 x6uHl7FwrTj+7Wmquv61MLxNDrNheIY/9UykgqEkRvoD9R+Y9a5PUtWd5SZlgVs4JSEIc/hxXp4C 81GE2cGZypSqylRVl0sb17ra+BPhUsVm4Gp+J2Z5p0mO+OxRsCJlB2jfIu7kZwowcEg6/wCzh4lu 9Vun8P6VDJcT3T+bH5a8Jxhix7DAHP8AjXnY+n7TD1H1Wv3F4Ooo1o+Z7x+1NZ3H7OP7Dup3uhTs uueMdYttGudQiyrpbLE07xowIKq2xVPXIJz2x8I+GPFl1ZanHJ5r/eHU152WUlKg5Pds3xdZutvs fdP7L1hD8cfh3N4f8Qp50Opr9lfPJAcbc89weQexwe1fDnipX8PajNbRTEhJCGVG+VipIB+vX866 stbTnHszmxtm0w0b4iX+mWl1bWc+yK8QRSqwB3KGDDr05UcjnqOhNbWg/EaTTFlWW2huDKhjBuN4 8kk/fXaw5+uRz0r2IycXY89pPU2fDnxJltLwveTXfl7G2/ZZQrBsfKeQeM4yPTvXr3wD/bR+Mng3 XrXTP2fvF/j201O7fZb6b4VvrtZZ327AFihOWO04HB9q2UuZWZEXybH01+0tqH7S2o+JvhD44/bt MeuG81lPD+kz60Ee+0V7tesjQBOWjSTaju6ghtyBq+dPiZ4+tIvjT4nb/Q7i3fVLkNGhBUqJCuc8 5yACc9668FkEM5qTw8pcklHmjLtJNW/U8bPMc6dCMkr+9ZrytqYPxl17w94o+HSW/hiHRdJ1k3ED Jczv9nZtrBsK+dgPA5O0da9m+Mfh1vEHwF0T4q+JdFkg8beCdPfR72CNUJWaUiK3vw6khkQyGeOR NyuWVgShzX3PCeNqxrYvBZlFe3p01UT/AJvYz51y+Ula6Pz7iGKlTwdWi7KdSVJr+7Wh7Nt/4WdZ 4D+HcPxm/wCCK3gW58aXDWmmeAfiRrmhae6rubZeWNtfnI4yPMMuT7LxXz/d/staZfKDoPiKzViP uXKOhB9DwanhulKvhFJxvq/8/wBT6LiHGRw2L5OZLRf5foVW+DHirw/asllLpetWqfethcIePYMc g/So9E1TUPA2o+Zpx1PwvfH5TtkeJJP9kSKcMDjoevpX0FXCU8wShXVpLZ7P0PDpYyWCbnhn7r3j v80vzPQP2U/gtFqHwi/aW8Y2F5d22qeEPDWmTWwKRTLcXOoavbWr+bvV2YeW7ldpBDEHPGD89ad+ z9qNnbeN4riEumi29kZZJRlkuLm4jWJPcupdgOuAT2r8jxWDnTxOMdNu0Jxj96ufpmHxkJ0MLzbz i5fc0v8AI+jf2UPAt38LPgj47fzP9LFtdTiRznY62xKgnHqtfNsXwPXwt8LD4g0iS4nj1FEDCZB+ 6IklQqGHUFk/8dr9S49wtTLuGsgwtVWkoVW15uUT8p4GzGGacVcQ4uG0p0EvSMGi7B8Vda8UeE9L 8M6wUaysJE+y+XHtcMi7Fy3fggflX3V+wX4JXTfCZvViPnFm8xwfung9PQjH0yPWviMjhaTSP0XM 3aB9DWN61tcyMY94GeTn5seh6f8A1q7vwgiiBJXcIrkyBRgmTkD27H06VPEr5Y2Hk3vHy/8A8FLr mOxgs4iU3TStK2FUlHXvkD145z0yOpNfEvhb9uj4tfBD4lXE/wALPiBqekf2PJLEttFcST28wTcz HyHVoXQkFvmU+o5r4+hgo4qjySV09z2MWouTU10Pur4c/wDBYLwZ8efB6aN/wUC8IaRPHNIIYPE/ hrzIXRmchCqbxLA4wp8yCcEnOEXFeoaT8B77x8bvUf2Jv2n/AB/qNnpYaNvC3/CWXtzdWky/8stw u4jHgjAWVBj+8etYYrBYrhCcPay5sNOzdtXFO/T5HzFHGuhKThHmir/p/mcH8Hv2rPil+yF4i8Y3 vxejtPF2oCQJ5HxY8P3tzFM8kiAMboShnyxwJU88DPcHjvvgp+258Nv2q/2y/C/w/wDil+zN8I7f UdelFq+p6MkAjgkaL7S17sa2DMVjUnaxHTBNfSfVaFWlTxGHrKcJuyt+p6uEzP6y5KUOVpX33Mg/ 8FVv2M/G/wC0XceO/G3wP8W2vj67vmuZvEWm6vJcNPMrg7/KadI+iDjYABx0r3b/AIK0/tm/An46 T+EfDH7ZN18ZPh1f2VudX01Y9IisZJreXdHlw8UhaMmNuQo5U81lV5+ZQb6s742i33SsfFl9oH7O PiO3eD4WftQeMtGkdCiv4gtjIkcZGNozDbgHHH3zXGfs5/sp+Evhx+1Vo+u+BPjB4K8d2f8AakF/ Z6ddDyrv7TE++OWPZcs5mDgFQRhmAzxkF1MK5L3RQr8r1P0E/wCCf3i7RP2HPh/4zuvG93pl/baz 4gumsbXSbqPdGZLuS6SKcSFTEQsmO4zn61+dfxbtPBPxF+PPjbxzodlqMPiLWNVuL2LUZbvdavE2 5Wj8jYCpJKENuwApGCW3D7/hTIHm2LoScrKkoy/FO33JnwvF+ff2ThMRHlv7Vyj+DV/vaPnzxa89 78QLXV/EXinSrSSwhEy6KVfM0LJvYAnjcwYgZ6EDPSvqz9hr4t2vhf4rWcBYNHqwSCN8DG4uCvf1 /n09P0LhDMZ4zF46lVaumrW8k4/+2p/M/P8AjXLIYLCYKpRTtZ3v5tS/V/cfoTdWrxJC8c8jpIAA zBAcHGP4feiSPywv7+VvchR/ICvXppu92eDUtpZbkTQbpB80jL6byDmrVqkccZEivkHpvJzUQT5u Zs2nJciSViwZol4CLknGdvWljZXU9MHOeMVvzW2OTlvoxfNESktgAHHA5NK97lQAXOR6VjUqqJ00 qDlYZ55ZyqkjHOWp4ZlXK9K56knKNzqpQ5J2LemagUnKsc7ge9bFvJt/1v5VyuV3ZHWocurPyxiO Bu7mums5RJbxnP3h26niv87r31P7nmtVc6bwRpQlvnOowypbtG2Z3TCg9vmPFZvxQjufCcUg0pWv ZrhxBaiJTiSVgSBxkYA5PPAFdMafNyo4/apVeVvQwfDHg+60rSlgEM093M/mTz7DullY/Mx/XHoM Vu/8IxfhBGLdzjj5iAPx7CpcJVZOSW5tKrGL1ZHc+Go7ZS2p6lp1q3BMTzLu6+mas+HNGs9QA8i4 lnUcbreCWQH8VU1Tw8u5lLFRS0O90qEDTZE/s6WFBBGhupUCtKQxAO1skcY646GuV+Jmn22j+H4n jEMDLKhUAgc5I4AFdsVy1I20tY89NzhLzuez+Brv7Q+lTJj/AEmw25GOSpH+JrT8b65b+HvDs9zf SbFhVTgDczNnAVQOWJJAAHU1+lrqfBaydkcp4Z0S88S+ObrUfE0XlygJLbaeH3pZhlwWJ6GUjgsM gchTgkt219ZCwtoZF4aGZHyR05xUxXcc5K6sSaTEYdU1ONf4LkuAP7rAGp7u2Mer2TSAbHaSFsj+ 8vAq0rE7kng/Z/wjtursqlAY+T3Ukf0rmvHPxF0HwjLqY8R61pdkWSCVftd1HHlkbkfMeuB0odor VlQjKo7RVz6Yvv8Agrp8B/hz8BfCkOr+NLG9vrHRLexltNL33LxyQqkAUrHlslIyQcYwRyOa/MnQ /wBszwn4D/4Kcaz8YvAZuNY8EDVry7mS0Qx3BhvLV4pcRSbThXlOScDIHPINeZWScU0+p9PlODqw 9t7WDipQaV+7asfWvif/AIOO9JTRHXwV4CuJ3aGYfadTvkhVZHI3N5YR8rtH97r7V5b4i/4OEfil 4+1KW3+E/hfQxul+0pb2dpd6jMqgqT918FN4B+4MZArN4py0hG5ceHfZ64mqo+hwfiT9vD9rz4uW MoNz4utLO6keDEFla6W+JW3sFLCOXBPcH2zWBP8AB34/fHLTftPjfxHdnEhUw+J/EFxO0RT5duxA 6g4GBg4xWkaeJq9behrGtlOXq6XPJfM8k+Jv7KHjPwTb2+pat9kup7a+NrJb6bG7uy8vvjOcsmEU ElQQWx9eU+KP7Mnin4peFbfTdD0W9gC3q3N3LJdFFmUoERlhdhGWiBlO7O4iUjsKunTqUKsNL2DF Y3D4/B1rNRvJNL0S2Oy+A/8AwTyj+HE942o+brH2yMR4u41byiD95Bg4zn1B4Wq8H/BKrxb4juom 1LxfcRW6RhFiOnicptztAZmX5eTxjrk8nmvbwc8ROUp1IWvsj4/EOlB8sJXsej6b/wAEm7bVIUOr 6lqVzcJHGhlkt7VUOxAuSixg44BOCCeTnJJNP4efALRv2frnUbWxEMt0s8kU9+IRGZdjEKAMnaox gDJ9TXLndSrRoqG3M7fqdGW8tWo3/KWPifp/hz48fDbUvBHji7hsoL7E1jqUmCLG8T7knPY/dbvt J5AyR8PeN/2FviT4C8XGxj8NX+r2xKvBq2iRm5tbiIkhZFkXoDjOGwcY45FYZdXUIezkbYum+fmX U+lfC15cfsS/s/Tan40tLmLxNqlu0WnaYUPmW8rxsqTy8fIqkE4PJI2jo2PhPU51a4drmJssSSTn k/jXpYKk4qU9rnHiJqTS7GawUy5jGP0rQsZ7iaVIbeB53chVjj+ZmJ6ADkmux3uc+61PtX9jX/gj b4u+OTWeu/tCXrfDbwvKRItrcqJNWvIwxBC25I+z5wfmmweVYRspBr9Xf2aPAvwQ/Yf8MLYfAjwv ptvf+UI7nxHqH+lale8DcZLh+Qp258tNsYPRRXq4WgoLnmefiKvN7kTzX/gqn8ZNN/aO/Yz8W6Bp DxW2r6akWtaRe267ZrW9spBOrxFcFXaNZYwe3mGvwy8K+EdW8S39uNIjvL+5u5fLEFuGkllcnGAB kkk1rWrOhONaD7J/mZ0KSqRdOaPtD4Uf8EZfEOk/s0eM/jb+2dr0Xw78IeGtONzo/hnWdw1LX74h hBaNDkSWqyuqAFlLskm9VC4evsf9lH9ojwt4S+GHg/Sfjf4T0u702/0uDSbo29vDNY3VqUEcBaGT 7irHsTGWGCT3wMcuw2L44xuYQydunWwtXljNtpTg01KPlbq+qsfI8XKGW4XC1K79xq/KltJa3/K3 nc+h7vwP+zj8VfgrrPw78O2LeH/DkHiSG+u9L0m1vNPgtdXltGWOUFU8lQ9vA3I/d4HOGPPg+rf8 Em/hB451m8s/gb8XJYNThk8qXT3urPUjay43+W8cZjkUhP4WO7HOcVnlnFWd8HYmpleNoXnT1kra 2sle66Oy1PEqxp59Sp4pyupJWa6q7f5nFeMv+CJ/xM0SQt8PvFvhTWo+MfbxPZSdT2CSjpjvz6d6 8V+I3/BPr4+eBdEeTxP8N9S1XT2kEJ/sG6tdSkZmzjEEEjzYwOW2YGRkg1+kZd4oZTjVy4qDg/S6 PHnw7VTvRqHzd4r134jfsz6H4r0rxv4U8W+Dx42v9Nln0rXNGu7KSaytHLwyYkRSUeYLtIPLRn0q gP2n73R/g/qWneKyks/inxPBruuzzEm4uJLSN47S2XOWZYzNcM2OMuA3KivhMRjsPi8VVqU37tSs pv8Awxen3r8j9WweGqU8LTs7uFPkXbmaV/xR9AfDnUovE37GfifX4mTS7bUojAHuZFGxZZlt8Epn BIY/LyQTt6157H4PuIPhxpPhWz17RdR0fUJtsk0Goxia3cCS4A8h23beXxlRlm4JLYH6f4rYiGPW Txpu0VRUrP8AvO6/I/LvCrATwdfOatXVvEOOn9yMV+ZB8Pv2U49evNUitLe7iuNBja8+3Tg7Zowp JUrjGRt9h8y56jP2Z+yjs0v4cW6wndHISTkAkBsDapJOORk9M549vi8qoexfNff9D9KzGtzq1tj0 zSne41pbM7SuVwSFBdjjv/3z+ldzpkyW0QkCDKZG7aDjnjHH8WOvv9K8ziWVjryVWVz5A/4KO+Lm 1HToLKCK1kaXBWbyykkO3OAAABkgnIJbjb0PLfnbP8NtTk8c3KX0Biinl2iZ/unzpFiB/AyjNeTl FKUqUmuiv8rno46pGNWKb30Oe1rw34gvJoRq8FzLbWuBFbx8LGBxnHdjjr1r3HwLP4v+AHhbSPGo 8FfEfw5p9yd1n4uOmXFrBOxzkxXR2q3IPIPY+la5tTrKb+ux+KyV9rbWMMJGlWpONCzS3+Z9OeAv +Cofj/QUsdF/ar8Mab8QPCGpXSWy/wBsxRxahp7dEYyKCrHPO5gXBH3genrP7HHwt+BI/bY0Txx8 E/EWueFvEHhy6uJdU+Hvikl5HSe3ltWNtNK2WP78MMSSZ4GFzXzGMyvG8IYiE1B+xlaTj2u919x4 9OrSXPXwj5oXcWu3p958x/Dz/gmd8T/Dfxzk8N+KtN0bS0mS7uIfEPieBzYzCOJpFjjnt5fmdyoX Z95d2WGAa5OT/goNpegCaz+KvwB0HxDe6QosRqT6zcMkITIIRmWUFTnONxX06162HxkMfHnw75ov +tT3qdWnXj7RS3Nr4b+GvEv7TnwK+JfjL4J6JoPhjw/4fsBqOr+E0uLjy5bdJI40O8W4jkZpJHwu /jY+4KCC3zto/wAMtW8Y63aajp9xa6NNC6SQnSkIKODlWByOQcGvp8jyevn9X2NKXKo7s8zNc0pZ NS9pNXb2Po79vS08J2/7XfiDxDf+RpJ8Uiy1iyimuSsZ+02cU6sEyFx8wB4x+PNZuleIpbL4bXN5 rckCXQgbLxsNrYVjlT+ANfqnCeGp5XiY0qMk24vn11TXw6eep+acZ1Z5ph5SqR0TXJpumve+7Q+W PCniOHxNa6ks8Qt7qc7PMWRmc7+GK54A659s9q+pfgxrf9gafoV9YzmZ7Iwnz+uWjIDH81Oa8/w+ xVKrmNSUVaU4tv5SX+Z2+IeHnHLoRltGSS+cX/kfrv4D16Pxd4B0y9tZDi4t0YOTntwfyIrQu4iz qQQoxyRX39Rck5LzZ+b0n7SnBrsgtolViMZPT61MIiGAGcA9uKmPUubuPkiGzB6+46mo4xsfGOBx k0cxSgNnxcqVTOf0qSBcx4P3lAwa5mnNs601TikSx8ZBXPvilkBTk8KexqJXUS4pOasNsZdr74sE 56Dtz1roI3eXCxjr6j9a4b22O1LufmFpf2CVlCWuo3BOOXgZVPPqcCvXfCogg0W2XTtLcz7ASzeT GuckY3jc36Gv8/sLBJtz/wAz+0cVXnNK2xu6brOo2VwJdSh8N2FkI3Elxqga9ZRkZ4by1GAD7fWs CyV9av4vGPiHVpbfRtslrptvp9j5SxxkjMu0hlVpNoIx/Bt55Ir0ZRV+fZJW+88+Cl16nO6/8XtH XVJtP0JNRusENJM6ogHbGBjnn0qlB4ss0RlXSopWOV3XjGTr7GuarVUGlbod9PDOau3qWF+JE8Fq IdLg0+2CtwLeEYB/UVu+FoNU1+9U3+p3NiLk5j2QFTMMclcYGM1m6kqrXQ1lThRjtc73TZ9P8PaP FHe3Gq3UZeRJbq4UspJwUGceu78q8h/aK+MHhzSNE8ieeG9fcu1CmDDIGBGd/fr06V18yk4xi7vQ 89O0pX0R6H4I+LWi+DPht4c1PxlqEGmpbQuJVuztkRTHn7v3ieOgGc8YrMu/2jvBd/qP9p+MvEFj uCyfY9OtWNwLNTxvcxbgZiDyckKDgd2b9HlUjFe87HxtHCVa8n7ONynP+3Z4K8Pays2nJqmoL9mS KT7PbhAXB4xvKk/lWB41/wCClVpPZyQ6H4bdFYAC41C7VMc9SFU/zrlnjYQulqz2aHDGIq61Xynn eo/8FGvF2q65ND4Wj0GC5vtgWO0ja5f5QR0ycnv92s3V/j/8cvH7qlpB4raJWDxz22lNZxlicDEv loD+JrneIxFX4FY9SGVZZgP94nzP1/RFfTPgZ8bviibiPVBdWUUMm1z4h1XABxuPyozkflTdQ/YB 8U3d6kfinxl4etEIdiLUyT429FOdvJ4qqeBqSadR3Mq+e4XDR5MJD52sdB4d/wCCfPhBdHhk8VeL 9evLwJua1sLdYk3EDgFkb9WrBX9g66tvEd1F4RnaPw87xSJBeO8ksxDfMrgYGME45/AV1/UHyWhu cdLiWVSo3iPhs7W79GfTPgn4Y6L4UtI4/DHw80C1nQAC4FvHn3P3AfXvXUaB4E163jt20izsrNrY NGrQ2+CUc7iDk46+1enRy62yPma+OlVd5zbZ0EXwj8U68ijUL+6IXDBbdAmCOh+QCtnS/wBlPUdT kI1U6nOrncdzMcsecnP869Cll+vvM4JYmy0Ol0X9iaV2Utp7n08xgK7DQv2KzEwD2kKccEjPTrXb TwMVsjCWJk92dlpP7IVnZxj7XJEmOT8qg/rW7Z/s9eHdMGb6aE4/vuK7oYaKOZ1Xc+Pf2ytC0/S/ jN4gi0iaVVsbKEae0TuPJkECyGWPHCsHccjB4HJ6V8meJPBvjfxdf3Lm58O3SSzSl7y7ub1Jnbec ltrFdxOc4HUmvIqYenjMTOlUjzKNrJ6dDuqVqmEwtKpTlZyvf5M5rU/gV4jlyup6R4fuUP3pY9Vu l5xjgYB61a8EfB3XPD1tZ3PhKNEvba6eR7dtVuHtcoFIDRuSkoJxlXQrwQQQaqWWUoK3srejOWGY 15O7qfge8XP7Z37RGnadFZQ31n9jt1EUdvYnToY0QLjAH2fCp0GAOPevKPHmpa58VwIfiJ4C8Dal Msis1/eaVpUlwyrIG8kSLACEbJHGPvZrvm24JSp6HMqsuZuMtTyrxN+ydo2vaiWh+D9tbMx3M9jr rW6klufl3kAYPAUAD8K7D4M/CCH4CSz6t4I+GUWk6ptYxarcaxFfT25xwYmkjl8vrj5cZzyaxp0q atLkdzR4uq3yqSO41j4+/EKxslRNH1zWi65e4spYAM5yUwIxkr0JGM4ziqFh8WfEWtLL/wAJF4S8 cpt67PLHPtzz1rZSjNXV7Ee1nDR2Of1CbUdatZr3U9I8Y/YGcQDTdqtcZYElmAGNuB6jqKyP2fPA Xhb9nvxiNX8L+FPiVJMrOFW/sIpI1DqvTDqRtZQQc9etJqnBWbd73+66Gq1W97L/AIdH0B4z/a/1 H4x29jZeLNK1iWWKKG1+x6raBFuFiY7XMSyMnmYbAKgcAcVoal+zI3xL8OWx0DxDDZWcqJJFDYxi WHDAEbGODtwe2OPSv2nw0qYavl1TC4amo1Ibz6ycr6vr0t10R+MeIH1jL8xp4ytUcqdTRQ6JRSul r53+Z3fhr4VT6r4a8S6JfahczavL4dUpe2sn2TN7YTQ3Yu1YvhZFtY7wA7uPM54r5Z+JP7IPgDxt 4quyPGaWvirU55XeaPURdIJ2y2+eVvkUE9T5pJxgAkgH3swyKjHH1sdXs5uEbtpfClZpddXF7s8b I+IKscLRwuHp3ipTit7p83Mr+imr2XT5ninij41/Fb9kjxY2jfDr4xajfrbgO58NazPdWKMTnad4 8tm4GcAjnBPUD0j4V/8ABcb49eCWRfFWoaR4nswdofWdLiQlg24/vIfLOccd8DHGea/N+L+EcpeV yzONJwk0mre7u+q/4B+scP0Kmb5jDL21duzat08z6D8C/wDBxDPHZp/wtL4f6VPjHmy6NqDwKBnl ljlWT+Htu69xVzU/+Cpv7GXx+uo7L4/fChY7iRQ5utU8L2dyqDeSMTRN5vOSxwoHJ65r8IwWCxWJ rezwl3Jn6LxJwNieGKKxNPEKUO20vu2Z6Pqnwc/Yu+NfwNk8JeC/FWn+DfCmsNG6smoT6ZHuEvng I1+u1SWUnbjnHAr5H/ap/wCCOv7P/wALvBc/in4b/tEwrC+2KDRoBa6xPdMRzsEMqHG3qWwoJ5YZ AP12e55n1SWEwWaYf3qcYwg3Hlbivh12aXc/NOG6mFy6WIlhPe9rUlKet/ffxej02PJ/2W/hBrfw yh121+GPxT8JXY8VW32G50jWL6TSSbfaxw73ara8bjgJOzbiDwATX21+zR+y58T9P8I21no3hN9U vrp1+yOl5bfZbqTJ3H7XvMIwEk53YJwoyxAPs4DExy+q6OJfJLz2fo9mfR4qqsRrHZnu3hr9hr4x eDri7vfiN4b0zTrWNFkGNQt5GhO751ZjKE4UE8DnrnjFW9K+Fmv3MDRabo2sXklyH+zrpkT3BkVQ Mt+7ByASCT0GRyM0ZnhqmZUp18OuaMFd7bb6d9Lu3ZN9DqweKo4CcKNV2c3Zeu3y1sr92luz4d/4 KG+H5dL+IGlQaxb3VrMrqJfOgljKLv6FXGQR36f1r5S13x7o3iDxFZG0FmLHQ53j1CZDtKnh03e5 eDHrlqrhudGnhq0akknJJL/wNX/DUnPadadejKmrqLbf/gLt+J2V38cdC8U6DdWTzQuZ4XiSSSRZ BHuUjPzAkfhzX034h8WaT4N/4JV2OveJ9V0Oz1a71NNO0XwxeQTNca3AjKpuYdyCKVPNlIZCwwIz k8gV6HiVkqxaw1XBVE07rR3s7xd/wZ7Hg3xhDIIYzDZph3JycJK6W0VJNa+p8+ftLfH/AMOeK/AN vp9tp+iQ3dxqVmIp7a0ET8SAkEqTxgHPFfUPhT4l/DX9qv8A4KG/HXxB4c8J2knhS2+Hl9BaW3he zuPssurf2fFHbW6BV3CWWaGQKmMswbaDivU45i8JiKUOZTcaave3d2X4P7z4bge2Jw1Zzhyc05W3 7R11+X3Fb9lz/gqwurfB29l/aL0nUdUufDN4vh+y1rTpxv1eKOMyyLewMDiWGBXbz4+XACyKcbxg +KvBnwO+MWlat4lvbK4+G93qEltC+oQAXOmXUjl1iYLDuRNwBycRjAGTkED8ydafDGbRxmW0+aLf v038M907dna59Bi+GMRmOW1sVhZW5LcyW6vZqVu19B37L37FV38Evgj8WNG8PpoXjBPH1pc2Gn63 oWpfuDZsDtidVP7wCTLFF3ZIG3ccCvk2z+GyfC61a1vtY0zU5rGU2k8djDfQmKYLhl3XFvECykrl RkjjIwQa/UPD3NsLiq9TEYaOk3ZrrG7duZdLHx3EVSWYYSMJS1ilv3S1sP8A+CrPg+JvA3wZ8X2G JNQudATQrxJJEbK2sMDW7AD5iTHKcsSf4e+c+I63+z/8QPC/wk07xBfva2mg62WgCQXbbgATkSIO COD0zXyGeZlUwOY1qkZuL5paq60TsfqPDXDdbPsDCNGmpKEYtptbtN/jZnn3hnSpdKXU7lmLLpuW JAwDJkKo/wC+j+lfQf7Mmote/COxWdmZoZZ0Jbqf3hf/ANmr63w4qunm0Y94yX6/ofAeIVNTymcr bSj/AJfqfqx+wH41fxn8B7O3kmV5dOzEQ3JAU4x/3yV/Kva5kBjOw9CenPvX7HjI/vpfefjWCf7q K+X4iRNhhk9e9Tl9xGAfx9awRuxskh425/EUKqg5bnr74qG+5pFdh7IquTHyRSGRYzhSOcmoUrGj jfRjo28x8bhk9h2p9xaNdRgK2MevXrWM480WkbwkoyTZX+xm0PyEeua6PTctaxyAjBUE+lcCg4Oz O6U+ezR+Uvhf402/ia3LaVcplsYR0AZa62x8a6g9mEkvZ1WM8KjbQO/av4BnQqYKfLLRn9pwdKvG 8dTD8R+JT4mv00n7Q/lYEl3IzZAj7Rderd/b616Lq3xJ8PXHwve3vtY023uoocRxXNwqjevTAz7f WuuF3Dllu9SK0PhcVseOQ/F/wz4et/Ke++0SgZeWGF3MjepYDGT9aytX/ac0eKPdp9vdyYPBYqmf 1J/Sqhl9avLmasdkKcnpFHO6l+1bdfvDoOmW8GSQjXbmTB9wNua1l/ar8T6rpdjajUrS0e2Taklm oMmOpA3lsfgK9WhlMI6TbYVaHKr1ZJFbxz4v8Ta08MS6j4q1JZYxOIozcMAeAWIT5V5PfGM1K37O /jeHThqGreFZbV8hhNql1CsjMcbdo3M24k9Aua9ahl6i704/M8uOYYKlTXtGnJ7ouQfsmeM9Z1cS a/f+G7aFHRfKmuZLlo8jliqABtvcBq77SP2MdMW4U+IvGV/dcY2aFpAgHT+9KX7+1elHASqfEzzK 3EkKF1h4HSeH/wBj3wnbTQyaja+JdagVm8231G88lJSenEIXp37V3mm/s8aDDDt8P/D3QIiQV86/ gNy/1y/SvRo5YtNLnz+Kz3EV7807LyOp8N/B7VtKnt28M6fp2lGGEQ4sLNFBTOcnIOTXU2nwQ8S6 4ireXt86nnbH8o6+gr06WXO1noeLUxSfmbmj/sh6lqcm64jupSxyzSkkk46nPWus0H9iScjMlrz7 jI/lXbTwEd2c88Szr9F/Yn8nHnRqpH8Wz3rq9K/ZDsLbJn2j6lRXdTwaitjmlXbNi1/Z80HSSTcP bY/2nB/+sK1LPwp4S0JP9IazJHBwAwxXQoQiZ80mSz+P/CGgqSGgO3v8orH1H9qbw1ovEDW5A4zk Z9qPaQjsHs5M5bWv26dKsCwszGMZwcVxHiL/AIKGpDu+zyhf+BDOOayliEaKjc4DxL/wUTmKuUvI 1HTl/wD69ec+J/8AgovMxbGpEDn/AFZHNYzxXY1jRvuZekeKJvjJpmpeKJpJJlntJB57Nwoz5ODz 6p7/AE71ymlxG3ikUnAeSU5Az1Yn+dceFfNiaku9vyLx7Tw1OPa/5k15DEpJnkI4wW464qj4YUJb f6MWfNxN07/d5r0Km1jzKd0al35sluRABhs54PJHU/mK56GyZdUjBDbcOyuR3Aq539m7voZw92a0 OnWz+2WyGRyCOcgVQ1ZlstGncrJgqQQeDj1xRTlZJDmveuZOlePtP0K7isNRF0sgAfNvbSzKMjdh jGrbTg98Z7Vo3HxIuLiEjSND1CQAHbNKY4kY5OOp3AHjkrkZ6dq5Fi1SXKtX5HTKjzycnp6mLoev +INVS9+y2dlptys8OZJZnuowpVi21QsZVsKgySQctx0xe1DSvE+q+Y9/4jks1k+UQaTbRxKF9hL5 hznvn6AUOVWq9NCrU4LXUwNRs9T0vxnos82rX10Y7uFj57Lh8TgsCFUDkEjp0OMcAV5t4P8A+CoN 3+zZquu+FPEnhX/hJrfR9Tu4rG8h1L7G8VsJGKRMPJkDbPuqV2gKFGDjJ+m4V4klwriXVmueM1Zr 8n8mfOcScNQ4qwyoJ8koO6f4NfNfkes/CH/gowPj/rWmC58Iw+HdO1hJ7Rb06x9sJdi0XlyxfZ4h sf5lPznIODXxF8W/EnxI8AeJbvQviVpVxdRaFLLZx3VrHLFEyCRm3hgCuGzu7cMK/S8Rx1TxGCp5 vSpe6pulJS30XNH85HxGUcGf2bmFXKatX3pQVWLS7ycJflE5a5+IGja0nn+IEvNLkIRGhhtw8Q2o FJDb92SRk/L1J+lZc6aT4iJj0rX0hCFmjZgVJ4JAKHnJwB7E9cVGZZvl3F+AngZz9m5Jb907ry8j 6jK8LjuFcXDGUo8/L2+4d4f+Htz4kvJVsJfOW2XcWuZQqtnouThcnoPwrGsYtP8ADl3I+qiO2csQ Y2B3DB6bevFfKZZgsnyXGVMO5a4ezk+7ktPXc9nM88zHiFOUm257LsfTP7QFnFo3wa8H6ZdXNvbQ lUlMsxKqzJCcDpkkhjgY/KvNPF/xCm8J+FoJ7CCzlVJZI2jwEYoAvlsD1Yn58+mB619Z4nRo1Z06 UZWlRpRdu9/Z2/N/cfC+GfOsPUrSjf2tapr5qU//AJFGV4V+JLa1pkduluY5Z5c/NGWD5BGMhhxj +Veu/C+x+LPwYsbjxJ8JNf8AEOh2lvska40G/lQYZlAJjiYsw6ZyNoAO44Br8khUji6XJWXOvPt2 P1GpRjTbS0T/AD7n2n+wN/wUr+O3xQ1rUvBPxI1XS/GmbXy0vNXhSSKNGXBE00BjZyURgSzNncSQ eDXsvjr/AIK4eCv2LvHek+HPi94V8S6Y8Fmrf2j4Q1VLuGAuwjlSOFmVUjPllgBI2cgZJ3NXznE+ EqYCGFw2V15Q+sQnKzs1pzQdnurrmR83R5sTj69C9pU2l+EZ/J3szN+KP7Xvwd/4KBaxb678LviD 4It9W0+2hjbQviZplxbQuBMkipNNI4hKMw2MqMTjceVHPP33/BOzTvjj8dL7xR8TvBvgT/hCdUsb sXEfgOdrmLVJmcNC0jKFJkRJXCyRqGwkZ3F+a8XLsyll1NYbHQcbac262PppYqcbRqxtbrunsfPH 7fXwe/Zj/Zp8Cy2Xhj4beKn8RAhftV1puuwQxxlcSNHLM8SsyAjG5mHTIbpXwh8W9R0DWfEmg6R8 OtR1R9HgS3CrqmtDUks5J3BkMYFvCsJCsm5AXwwPznovvTxUpTpqnK8Gt0z28JSw+Iwk6rmvaJ7W 3Wmqf6fM43wxpFnc+Kz/AMJDfTmwtGeTzpZX4VF3YGMnJxgY5yRXuf7LesP8F/ita6p8I9VGtarP JbeVorTXxS8ma1d2LJCY2dkckL83G4gjJxXfUlPE3dWo+Z6X622OGmoYdpwguVa26dzM+JGqweJ/ FmpG61qa1smubm6jtLCRVSzunWNZvNUrubmV02kjYq4JOc1ofsoftz/EX4GeF9U8K+F761vNA1uW C4k0q6twyrcQFvKkLKvmbV3NwHAGSRgnNTKLVCFJPmad79fhtc1jiJQnVlH3VNWaWzXMpW+9I9E8 C/tx65HoEXhrwHp+n6V4ou7triTxRocxjjuJXmZ2eaMD94Rv8vDsV2onyk7i3pHgz486D+0lqOs6 F8fPDUF7r2hwo1nrmioLe5v1RAbrGDtMgI8xVGFddwA3BQ/oZNwvjKUHmmBqezrKTs/sySSupLqj 43iWphq9X2cY8r5dfNt6HN/t7fs9XvxhsrPT/hTqFhqV/wCFIdMih8PyTJFcxQrp6QvId2AzyJb2 z/LgHEmOgFZWj+EdR/aY/ZEsdI8G63Dpep+BdK1XVfEXhXxDFBHdTGwMPni22WwKuEmnlKNIMxxM W+YDPDi8fHiTFOFenyVkveT9Fdrum9T6LhTOsZktJUcLV5Hdcy7pc1t+1z5l1rwM9n+z74l12D5k n8SQWLMo4Hy3EhH/AKD37V9e/DL9jqa7/Zq8H6x8BdJudYkg8Kf8JL4qME6ubNNqO9wyswO0b9pC A7QgJHOT9VwbiqWX5jDEVnyxSf46HhcX4epjctnSpK7bX4anvv8AwS+8WGx17VdFu5CFulSaJM/V Tx9StfaMsSxxuCPfk57/AOfyr90xzvUTXVI/C8DHlhJPdNlEytGcAZIPpSzXDCQAnKnvjpXn1J8i PSpU1N2ZJBPhd28Y6jOKDdbiFxk/SsnU5dWbQpJ6IhivTLPtKlVA5yCP896b5waXEgbI4rllV5ju hR5S2vIH2fduYY56U5fMhUANJuIxxzmpk5WuhJRvZhMkroDIxIXkj8a6Dw1J51kFJP7s4rFN8ybN Gvdsj8KfgBqEksuuWETkSWFvJJbPKSxU+SZRyf8Aaj/XHerMPjrxH4mjQWt7qUiSts8+1jkEbH0D KAufbrX8eYzBQxE41JLoj+wMqqU6Mq0KkrJS0JNM+EvxA8TvcXFroWrtHK2V+3TRQcAY3HzXBya7 XQP2MfFutW8EviPUNB0vzQD5LXEs8iezLHGRn8a6oZbd3WhNXiHDUUlCLbOmtf2EJZgRqHimZsj7 tlppBB7cu/64/Cu18EfsKeFbGzjHia08R69cHqbq9FvGD7CFFOOvUmu2lliZ5lfiqvJv2aUTstH/ AGMvCsErtYeCdLy67c3pluWXp8w8xzz+FemeEfgrqOhWS2vhmysdNhC7dthYQxsRjHLBc/rXp0cu tpY+cxOZ1K7bqSbN60/Zk1TX5TLqCXlwzjaxYMdw6Y+nFdVpH7G99eMpltJGJ5zIetejTy5HnyxR 1/h/9iSaQL5lqi+xGTXa6J+xKsagyQBOv8GMfnXXTwUV0MJ4hvqdfon7KGm6cmbs2+VzxIVxn1ro Lb4MeGNMUG6ntl244XpkV206Kgc8p8xZFn4N0dT5jwN0J+UDP1FVrr4r+DfDyfu/s+VPcqK091EW Zi6t+1z4W0ZD9lNoAv8AdIbn0rk9d/b60mxDi1eMHtgD+tRKuolqk2cN4j/4KLQx7xDKuBwDux+P Fef+Jf8Ago0+W2XYA+v41zyxhrHDnn3ij/goq0m8C/xnptNcDr3/AAUEuLqVlS9lY7WP3z2BP9K5 XiZPVG6opHD65+3Jf3Sv5UjNu9Xrk9R/a41rUWYrOoHXO4nj8KydRtXZagloc1rP7R2r3CvJ9ukI XBbaOBnjmuQ1n9oC7ZHlu79yoYLtMnOT6DOT0qLtsq3bc52X4zzanIoimkYM5VggZmUcc9gfpntW Rd/FRkufLu/tLSBX3xZVNpAO3BJPfGR1PQUk7lqGup97/sZlL39j2yvbxbhFu4GDMJCq72v5Vw47 8KeAPQ/X4Y8X/Fjx5Fr13J/wkmtLsmkWI+e4yoOACeN3AHXNEOaMpNPsc9bl5Ypq+r/QzpPjr8Ro tNeceJ9UZSdmxpz0GDnB6jmux8S/F7xjZ/CvwM+l+JNQsn1A6ncX1yrYZlEyIg7HgL29af1ipG7v /WhDoU20rHEx/tj/ABO8LbRp3iyN0dnCrciO5OAcc+YpPp7V3Hwh/ay+IHjafX5vE+vWUzaVoOq3 8Sx6faqRJFakx8iMHhiGxn+HkYojjKtrX0G8LS3seaS/t0fE+C1SZPEUrsSc4hiVQc8cAY9D0pJf +CiHxQubY291rFtKjjBzY24JH12Zqo4upHW4SwdNnbfHf9t34hfCL4ny6R4bvdP8i3stOlIm021k PmS2UUjnJjJxukJx0rE8O/8ABSH4m390kN3c6ZInQ/8AEvtl2gnr9wZP1NL6zKDukhLCwkj6I/ZU +J3i74+/D/VrrU9StrC9g1OKAXVraQr5kaxszAqFUZJkXkD+Ee9emXmheLraZAviqReuIjYQlT9c 8+neuiFapVSaSOWpSp0243MufUvEGkeJtOHimTR9SglnjUO1nLDNCS6gOCk2zOcH5kIr4N/aKvkb 43+LYQjK8OoXCs7j5WIc5xj+tTXcpJcysb4Oym+V9DY+DvjjU9H8NNpKwyJKjC5iu1PEKyBWAXHc PuPtkV9A/Eb4lX158ONH8ZeHdNtr6SUiw1X7RfR2qWtygADlnzkN+f3fWv0/JuH1i+C8XUjLmlN+ 0S7ezdn98eY+NznHLCcS4SUlZK9Nvvzq6/8AJkjzCb4haZ8Syy+IPCOk6gdu2T7BDPczDkj7wijH 4hu/Ws3VP2WtD8ZwH+xPC+peH5W+YXT6sqochuDERMQM44yOmBjmvyb2lfCW5p+72Z98uSre0dTi 76Ffgd4d1PSbCSHUS08i+dcK4DMBhsKDnGFx+Ga801LVE1S5luL2ytS9zk5g3gqxPpn+eetezjsB TwmIhUlUd6sITafdq1vuR4uXRlVlVqxWik4r5H1d+2nLb6l8GtFlnklg+yw2crm3wWUurqVxnpnb +dfMXjJ4b+IzRXF3tnUywRyqgXsG3YbIO4NxzxtPev0fxXjfOKU72TpQWnez/VHwnhTeGU1ab+zW q/jK/wCplal4c1zwpo+n3msWN9Z2+qxmezmubd0S5iBK74mPDrlWGRkZB9K2Ph/418W3uuWel+Cp 7832oTJDBHayPGzux2gbgRgc8nOAOvFfmWFhUq1Iwh8TaSXqfplepClBzn8KTbfkj79+KfxZn/4J w/s86Fp9hctrHxO8VPDc3VxeyNJIkW4NJvJO8bxhRk5ClRyK+efjv/wUy8U/Gn4iXdz8SvCegS2i QwWcHh+6tmZbCONcFEkyH+ZyzncT8zEjAr6rxcyPD0cfgMBQny1MJS5W13k038uv/bx+Y+HCqZ5Q xOdVW0sRUlKP+FWS+63L/wBumZJ8eNP8M+Hf7HXwhH4Ys9YmS9W/tZUuVicgbWVtnmKoA+7uOOeO TWVefEbxj8FfE9jqXwf8R6tpt/qMS3kNz4Z1OUSgbs/OY2DKysPunuM9q/P8FSqVITjiLS2+fyP1 Cc/ZxhQqK71176Lf0semeCv+CzP7RHw/sGstY8SNr1kzKXt/FelwXryEDHM0ied6EgScnk5rstE/ 4KBeAfj5OJfj9+zd8MLp4sGbUvC1zLoVzIdhy4dfMkYk5YkEqPQcGsY8Ne1rqGDk6cm9O33HDWw1 OlB1acuVrt/kcj8RtG/ZE8XX5k0fUPid8Prq6VSYrKS31rT7aUkbgQ7C4KKoPJYsSenGKwvBHwA8 H6T8SdOuv2cf2jPBo1G2cta3+t2t5oNxCpGHIkuV+yqQuVAeZN29unWuqvhsxyfEOjX5anLb3ov9 BYbEVq1JTlC6fyfzR13g79jzS/DHiC/l8Fa/b/Erxhp9ld6jZ6b4bvbPWYZpkJKytb2rzFyXCZSQ lWzkhhXPaJq2g+LJ721+LvwQ0SLUrWNhNNpc2paORMCABJEsnlp8xAO1FAz0619Tl9KjXoycdW07 p6PbYwrVqqmm1yq6sSeF4/DGj+P7C40vwfY+E7a0RnkS01afU2d9vyI5fIGGxwvqc1N4d+LPiZb9 J7+aG0bSL2ObTb2whit5onj+ZX+UBiQSuCeOMDkGv0nD5DKthsDWjNxdKo5OK2lFq1peSt958Hjs zUcViqbSanBJN9Gn0+89+/aD+MF1oXjEXGk2fhO702+ihktZ5LEMl/DLZQs+0tB5rCIzIv7x1O0A cY21558MtXvNX+IENkW07TNYuphF/bvneTBJBqVuYHt5/MYoVSCVlZzxslPHyg18xlPCkaWNnmGL henTjL1fut2/B/M9nNc2j9XhTwztWlaz7XlFP/0pD/HXwf0b4e/DLxb4P8Tabaaj4dtdXPiS6bTL mQyST2ljcyNFFIDlY3SRsggtuVcEYZTr/sE6f4j+J3wM1668EahFp+mzWMekxaP/AKTAJLETGN4D NDOkm08kgsQ5zvDA19LhMiy7NcNTng6f8aNRq/RQa0X/AG89+x4GM4gxuW16kMbO8aMqUXb7TqJt t+kVt3Oq/ZNuLr4e/FrSJ7p0jMkywv5Mu9VDjCjcQM4JXt2r9JZ7fz4I5oACkihwB3BH/wBev0DH KXsKFSSs7an57gZxeJxNODuubQyWyHPJIGRt+hptu/mzgkZXptPevKlU0R60YK7XYcsvlEhgoxnr 0p0Ey7MynLdTxgVhOd9GdMIW1RJPFvAAIBbjgZzxVY/uZCIyWPueRWco63NqctLF2G8UyjhcHPI7 AVYi1KEr9wg/Tiqc0lZmfs23oSfa47lCIWY4BPQ1c8OXmyeRXJK4BBHTFZSadrFxTV7nwp4F/YK0 vQ7x38PaJBFLMMSOqs7OMY5yTngn869U8N/sX3FxawRPEIo7fiKAxMBF2+UYwPwr+ZaWX3SX9aH9 CVMbKUnO+rO58O/sVBI83Kuc85RACK7DRv2K7c42278Y5f1r1qWAS3OCpiGzp9N/Y1tYEG1QhHYo AK6XSv2XtD0/i7eFTjnzGArshhYxMJV2zetPg/4S0bJuZbTdjvzmrccngzw6mWMBI/uhQK6FSUTP nbKd98cfCGhMfKW2+UcbmGeK5/WP2xvDum4+zC1BXgFBmplKMSoxbOS1z9v+zs0YWsqIF9NorhvE f/BRZURxDe/gWxUPERtYpUm3c8+8Qf8ABRGWZZDbXUjN1OwdR/8Arrhdd/b61G5LCG8uMDjC8VhK u2zVUUtzjdd/bI1W83bZ7jngFm4Ncnqv7TusXRbEsnU9Cay9o3uy+VIwNQ+NGuX+SDOQfQH+dZU/ jvWp3HnNN8/A5JrGUkt2apdlscZ8VfindeEYFWWaQvIpbbk9OleZXHxjvryQE3BAc4wSOQT71lzR tcpRa1ZFaeNZNXvGSaadlU52pklh0xwa0tOgc3SGNZAjcbpmAP0wTxWcq3K2rG6op+rLum6HPceY Y3TglQWcjbxjnHNGleCWUXa3mp7nTaWECscAnlSP8a53X3L5FBprY6RfCOgCw5tb6+kBX/VL+POe n41478f7K10rxMY9EtvJVyrKFxkAoOOOnOfep9tJvQ0pQTleW55wsc3hbVfJ1S5iLXUSz4Lk+WGO QrdslcH6Ed+K6yET6hp0dxpIhlVx80xcKikHBGTyeMdB/jWlWtyRvc4cXVWHg5ydtT9J/wBnW7l0 D9iPwvZsGN1qMKDfECUGy4MpPPs6445zXy74g1vxLrV7e3Hh7xNeRXERZ7rQ7WYfuPnwzRKPm8vI +6eU9wM1s60v+Xbs7L8rnNWhKpRhJJPmu9e1/L0OI1TxF4n1GDEuv6m7uzBHedynynDKcHk59cDg 11U+seJdN8GeHV07Vr4bIJmnMEasJHM55+ZT/CMU/rdW3vSTt5LvYwhh3f3o79r/AOZS0n4va9rm rvZWM2vPJiONIlt4FDyAsWw3kgbeOOnQnNdToniK+0HxLfhrW4128h0y6uJZNRhJhG23f9xEYwnm EuVDHJBXIA6NThi6n27W9EaSwsbWje/q9DjbnxfPYxw6nPZ+INV0u5kdZLfS7O0WexkDHMMqtCw3 A8BsYbBwAcgX7n45/DHQ/B+ovrHh74o2+rNbTJZyXNjoz2ZuSh8sS7rUNs3Abtp3YBxzW0MSr+8/ uSD6u2tG9PNnAftMfGzVfCHxlvLO1t9MuIbex0xUN3YwOxzp8DHJKZPzMevbA6VQ+DfxS8TfFPxE dN0HRfD0j7GaS6l0y0EdvGCC0skjR4VFXJJJ/Oo9tKLskr+haoLl5m3959PfAPW5PGek6pY/Dy7i 0u30u7jjl1vSrCCH+0ZvLbzMRFCqxj93tJG8jrjoPRbrwf4nFooXxXfSnj/XWkBx17BQK6YOpNXh Y466jTk09f8AhjPbSNZh8U2A169s9QgV1ZgbZo3X512kMJMZ3FeoNfDn7UPhyWD46eNGiQoIb24H lR9WZeAeTyf8ewpVnJxSlub4JJSfL2L/AOzv4NGv6dNf6nfXbsPLaOHcAojcHjBzyAoGfQ9K+rP2 dbbTNUsdT8D6oIvsPidN0S3HzbbyPDI4B6k7RgDqyL05r7fgXiurDEYbI6tlRm5xfnzppL05vzPl OPMkjVwOIzOm37WnyzXlyNSl/wCS3PDfiz8ctP8AhB4j1DRbu3ln1bS5ZLWe0jG1YZEJUqSeOo7V 594L/av8aXXxGs7jwhqEejtbEy/6PBHKyKB6yA4JOFDAAgtkYxX5/PKKlbHPA1d+fkfrflZ9rTx9 N4NYyns48y9LXPOvjN4llv8AxMbaJmkNuv7xyDzIwyT+v86wfh/4tbwR4/0fWtV0+y1a30q7iuX0 m8AaK6CMG2OCCCDjoQR6ivZ4orQq5pWUdoNRXkoq36HJkNN08DS5t5Lmf/bzb/U+xfjd8YPDX7Rn 7JuoTxaPF4du0km2Tafpl4yyCMpLCsk7zGFF3s8S7QTiMBgD+8f4f06+ms7qE37/AGq2jdWa1l3B XA6jIORkehFehxVm+KzTEqtVvyOK5G1a8U3Z/fc83hjKsLleGlQotOSk3OzvaTSuvLSx3nx4+MMH xQGhW/h6Gez0rQLCOxtbSdFDIijOCw5fkn5mOcY6V9d/8E4f2atK+DPhXVPjF8Y2hu9P0yDOkQFM Cd2GVKg9S/HHBx0zuxXveEOVf2pm9F4lfwL1ZPpeL935czj8j5rxdzd5RkVaNB+/XtSilv7+krea gpP1MH9qD4q+FP2qNb02/wBY8K3fh3W2ubX7Vq+p6qLmOcKFEgZAn7uIt5jBIwMBsHeRmsj4z+Cv h1bftG+KtJ8G6RayfYr+a3j03w3defEoh+QtFjaSpKlvugfNxxXzGaZs87z2tjK87xqSk0utk0or 5LQ+qyfKVkeTUMBRSTpRim+jerk/m9To/wBqrTfBmlfsq6BdeC47V9bvpP7PFrJbkzRbWYyFpG+f dnacdAJYsE8geNeCvDGk6XE41vSI9auLiKJXOoPgROqgEptAxnA6knj3rzssUqlWTrrSLenldv8A U9jHxjChS9k9ZJtv/wAlt/5Lf5nTw6J4et5A9voCW0m0A/ZL6ePPt97H6UsukaVdROi2CgyNuP2i fzVPscrux9GB9+ufscPiadL3XHT+uu6Pm6tGpPaVmZX/AApvwxcTSvqOnIVZQdtrM0e1vUcE49jm sPUfgl4WniFzYf2hFbMcebHdpIq89CfLyPxxWE8pw2K96je/VFRzLEYdqNW1u5Y8I/stW/jHWoLL w5fXitNkmZ5IyiIOSxIHQDmvXrPx9H8JPCdl4e8EatrNmdELSJe2M+w3k54MhbIYcjAxgAY9KxwW X16eMpRw1na7fN5a/wCYszxrnhpSei2089DBX4u+JrX7Tb+KdQGrPO6faL29t7e5uA+7lPNmVmIH AzyOvBqGfxp4puvE8ynwx4K1hrpf9Etri0ks/JQ8AqLFodx6cybjmvucZmOIy6hz4Z2cbcyfw9b7 nzFHC4fF1eXFK6mnZrR9P+HPRvir4ztJ/BvhWLxr4amivNH0yO3f+ybqW3ZmbBK5lSVVVWUYOwnH evPV+KvhHXtRn00W3iGC5dEZYVaK8MaRW8cRdyEjLAJCXJVeOeg5rzMn4x+r06UrRrObk2k1dayV uv8AN+RvjMio5hGrTp1HBQtZ73Xuvy25Sx8Q/iPonw/ub3Sfhbr/APwlmh3llJHc6utpNpyRCaEi YeWzNLlFkdS5CjIbAIIJ95+AHi5/2f8A/gm1F8QtMitD4d8Ta/feHLe0sGkF1EViaU3KNKW3gS5B BIOOhr1MVxPPCRw0MPh/ZTfNBK6dlNq9umjSb639TgpcJU8ZLESxFb2kHyyeltYJ2v11Ta7WOa+F /wAU3uNBt5kkjWfYo3xBTjDKcjg85Uc9frX6e/CjxGPGXwu0q+iYHzYF56gcAj9Gr9IxlNrL6E27 2t+R+WYSVs1xNNK17/gyxcARzcHk5OB61UjZVyAW/rXhtJwVj6CCam0xZJ1XBbowPHvSwXCsTnjn gkZziudtcx0xjLlLKsJEBdt2OwNVGkxMRydxp19FcdBJysMbo4VnV+TjtUlqzZ254YduK45+8ztT 5UWoSeVORz0Gfyq/olyLW/Rex7cHip5hcl9TuX17wX4dffGYycdsAVn3n7R/hXQVYeXa7s9WIz/O vxOMYxP2DV6HO6x+2/oOng/ZTbLj+7iuQ1//AIKKWNrkQzIpXoFIFaKpEHTZw3iH/gpRFuJjuVPX Pz1wXif/AIKSO5f7PcjHTC/X61z1MVGL0N4UOZanDar/AMFBNT1SbZaXMrE8bFJrlfEf7YWuNEzz zSqp/wBo8/rWE8RKeiNI0lBHNy/tBeItcG9JJkRzxubn61CfHOtX8RN1eSL7A9TXM57XZry8pWut SuHOb+/ZR/tyYJ/DNZV34g02FmWe53leCCS35EVLrQi7t3NPZuWxVk16xuMLAty5J6xwnA/E1Zsh HdRbktbpgDj5sDn9TXPUxnK0kbxoMkkjSPAEMKEjpKSTwPwrOuNbjs4CfP0uJuoWXAPp0LZrKNSd X4UDhGG7OU1nx1dWySG91m2ReFSOwgyCf945qWItqdmJbKPxDqjLg7LSORxjvwtb8iT01MXUu9NC vc/DHW/EWn5t/CesSTB2SM38LRZ46ZkAxjv6V5Vq3w71Ce0eeZdOURARyRJeQs6g89FY/wCNRLmg 1fRGlKcZppavQpWXgWXwZGl3qF/p8UswJCyTBNq54LE55I9FNTweKzKpMV2LsqwAazjeQFvbgZ/K uWpNK/VndCk5u70Xdm5obeINQvHXSNO1F4yx++Y4VUjsd2W6+1a3/CBeLbnUZ1ZrawZ4TMxWZ5t4 4GCBtFcntuR3Y506XTU3LT9nnUr3TpbjU9e1KSYDIS3Ijj4XjjB9PWvGv2sPhxL4I1RG0ue7EE0M EuXlY53b1bqfVV/OphiE3aw4Lmlax4R4akeDxc6yxm6b7wikyQ+OcHkH9RXpemaJcXWnQiFJkjdd wgVuFJ5PfFehJc1kzirUYVbxqK6TP0v+FWl3Wmfsy+BLfaUtrbS7Z0kdWKNO0cUjLkHqMrkdQD1r xTWPhN/wiktt4i1++0OxvbYbYbjdcKwDHO3/AFnzAnPB9666FNzc21t+GiOfHz9kqKh/L/7cyjd+ H9N8VeH7g+Ff7Fh1ONpbiTTZLa7jW4djuLwqzqcEbiVUtjBxgdMuPWbnztE0G30vQ7qdtNa8ljuW ul2IbqRCxKuMKNozk5656gVThTh9hP576nG51ZXTk0/TyZNpevJHdXdp4G8PQ3lsyLFcXMd7NH5k m5i4izuZUBLDJOTzjFXNJ8VXK6xqtsfD8MV9a6ZKyWg1EnJfCoCWXjJ75I7VhPEYVz5eXVef3l06 GIiubm/A820T45t4a1Qtb6HO3mOwuNN+0/I5dyzA5TJDNnoeCO2ON7xdrmgahpVvqum+CdT1m3lt JI59mpMkmnSHIkQxlCOc8OOTnHHAOtOeFk37r+/7wlTxMUtd/IqePdG8E/En41ajD4n8HX7Na6dp 9zqHiCTXGgtLSL7BCwL4i4IXCDqWIzjnjnNP+MngC00G/wDC/wAKPC2sRaSk5muLw6mqS6mAQqGT MRIRSchM98ntjplOjGN+V3/q5ko15aXVkeufso+OJtN8N6lH8MfD0Y8y+Dzw6rqfyr8hywZYs9hg Y7nmvaZPGHi65aIx6BpMSZzITqDnK4/hPk8HOOx6n8dqU4xiuVOxzVouUnzNX/4BzmteNdWh+IHh y11TRLeO01K/t7Y3NpqPmFDvEmWQxLkbowOvevl/9onRnn/aE8SWaRiWSfVZE8skgOWbkcj68g1F aaa5mujN8JG0rJnLfB7Q/EfgGe4sb63MalCkTrNFL8m8cgA/KQF/iz972NdbH4lufCvimx1svdx3 ulzpNDPPMUAdTnAIAxxx6da8fCYqWHxdPEUXrCSkn5p3R6uLw8cTh6lCqvdmmn6NWZ1//BQv4daH 4/sfDXxf8OW08un+LrWOLVJLWdUjgvo12gtwwBdAAOn+rJ6nNeBeDLbTPDmh3Os6dDPHGqsTJcPu 3IndTtAILAjjPK4r9czXARo8VvEr+FK1VealDn/9K0PzPh/Hzr8Lww8v4kL0X5OE3D/0lX9DgdQ8 W6PqN5JPLpl1I8pLMXvMZJPJ+5RDr+ioQf7ClkH9171gD+KqDX5tVhUxFWVSUtZNv72focZxoU40 4rRJL7j67+CL2XiD9hbXVFg32OCwvpjp5mYltkkj43/eGdvXqK+WG1/wxED5Pg63ycnfJqNycfkR X6bxngfaZZk1RO16NvuaPzPgnGOOZ53SfSvf/wACj/wD1b9j/wCCtn+0/wDFa38O6R4T0uLTwRLf XxeZ/s8OT3Z8AnBx6AE9q9c/b9/a40a08RWvw1+G9p5/hTwkgtpJLO4MPnXQGGcbePlxjHTIwR8u a+k4Ywf+rnCWNx17VMU/Zxf91XTa9by+cUfP8S1/9ZeM8Bl+9LBxdaf+NtcqfmrRfpJnzE1p4R8R skuoXvitGYnckrxTAfQ8fyrsvhH4u+H/AMHfFr6toUPiS8v5IWh3XrQlUDEEkbccnHfPevy/DZFP 2kal72P1itmS5HC256j4q+PnhXxb4cS4+JOgGe2tka40b55FnMzPGrrIA/l7HjBYqVyBHAwbEhB5 MftMaBbxiLSPB9oir3aROCOOyZ/WvdwGVrESlN2WrXrbseZisZKiowXa/wB5zuuftCreT7rLw5pM QYf8tDMT+G11H6VjSfETUdavUXTbK3iduFgtVkbdz7sTXtxyei9E2ec8wqR3OsXTbzT9KSX4gT2+ hxsM7FLPdSKfSMnA49cVi33xQtNHgNp4Esfs8LDbLfXv7yeZcAbeOFBx2GeetelhcshgXzXu2eZi MdPMfcStFde52P7H/jG1/wCFuQaP4gLxWuuRzWkdwj+WLeSRfkwRzyRjk96r6X4J1AeONd0rV4xP e6Feqqo7M3ngSheh7FNzfSryqiv7R5eW7adnb1Wn3onM6vssC5uVlFq/3r/gmhr+m2vwzgeW7kW8 1EkOltMcokW4YVwDlgRgHufUda5jxrMun+J5ZNMMi21yEubfe+WWJ1DKM9yM4z6ivs8RhaUU6ckn y7/O9z4/BYipirVntK6Xorfnqe1/FDSro/BfS9cs5pWkj07TZiZSXDLIJBLnPXnbz2xXHfsg+Cj8 RP2n9BjtBG+oz7jCJMbZGRTIIz/v7Cn0avxSPCeCynB4jM8LG0nO1uitUadu19PuPv8AL6/LjlQS 0cfzgn+dzrP2EP2T7r9oP4geJfhrYW8n/CRatoHiO0sNw+aW7i0+4nghx33NahQPUitf4jfHXwFq v/BNL4Q/Cn4beIBd+JvBGra3deINJls5YHMl1KPKlBIKEKqEH5t2XHHBNc+Sc1XMqEZ3fLVa+9af ij6TNf3WBrVI6JwX5v8AzPM/h9eS6PBHHCxCr0Uc1+nv/BPP4h/8Jl8B1s3kJm0x/KO454B4/JSo /Cv6KxNNvLeX+Wx/PMmoZt7T+Zs9nu4tr5PQ8cjjmqbJtPRRtJzivnLe7Y9tP37kc4zARnO3nnvU ti5aBSMGuO1po7b3plqSQBVAHA9KrGFmJPAUnPB6VpUi5JGdOXJcijiP2gKxBOeuf6/hVmWERspj /WudQ0fc6XNcyRYjlUcMPlYdAMHNKsn2eUPDyeoPesrF36H5ma/+3JqV6SIruXP++TxXL6h+1JrW qg+Q92y9CQpwa/n91na7P2+FJSehy+uftC6tZTOLqWYMvWOTPP4da5TUPjre3bOyT3CjGSCDio9v c0dOzsi34c8a3GvsvmF335wAev4de9XvEEl/DYu8I+7zy3auSpi7TSOyGEbg2WvhrrSeF7tbrxDI txDKP4B9z07812fjnxjpraULq3EqbMMgWJsE/lzTq15N6GMaaseZXPxY1nUNYiijWcwNhStvBhgc 8nk5wMVt6NJ4i1DUGWHQ9emCgnyFt2JIycMSOgOMiuhQUlpqQpWersdzb/C3xZcwpInh6OAtt+e8 uY2PX/eJHPtXRaF+z94t1i4vI7ybSNNkiZRIqEtjI7ALiiWGlolEmOIilozqNK/Zp1PTbmIaprsJ 3yKm6C3IIHrya2vCv7P9qBOupaxqLiOV0ZE8sdGPqpxUwwWtmyamKb2Ro3fwH8L2uuWUhiupPPaR ZQ1zIu444yFIFM0T4S+ErrTUGoaJps8sMjrvuYlkOVfj72fQV2wwcINW1OaeJm73LY0TSNFfUYdI 0vT7dXtd6i2t44xlTnIAH1rpNM8QRz6ejptxsU/TiteVU9kZq83c5HUtcSKC+jLf6i+WQZ/uuMGv hv4w+HYvAXiGWWJ7r7Nb3V5bxWG9hDcSB8oGGcHCnp+PavJx0lUnBPa/6HrYB+yjNx3svzR4/wDC aSXxD8abZ9fSOZp7h0ZCBsU4OAo6ACvr678Hwx6C/lxIpQK4wvoQf6V5GIk1JJHfUjomzq/CPh5Z NZvQiZz5Ug47Mg/+vXSt4EkfV7I7BiZJYTu91yP5VyRhKb0Mm1E6Twb8PvtmlQ+aRnYAQB3GRXhn 7d/wkWPwLYXsakiK3nhkbHeN43H6LJWyw7ilJmuHrJVEmfCbwx6b8UNPIAEMzorZ4GCdpz+Br3rw QloNASOE2jtAzRsLJgyLg+vc4wT9exr2cOlJRb7HPjouNWcV3Pv/AE83Wlfs+aOxllmtINJhkjs/ lPlSx2FuxYZ7kcYPHHPeviP9qj4rS3XjjSNMuRM8EFlBctbyAARzSsxy2MjhCijHue5rZztTrLu/ wscs4qVXDvtH8byJPgx4qvZbhtOdVaCOw+0w3Lth4pIpViI9sliR0I2muw8Va3qPi/4ajU/CUcVl 4gsNQmsJtMljG/WLJN82VC5cunnLJsVgpBYjOBt5MLWk4cv81/k1/wAA0xmHjGan/Lb5p/5MxfAs 3iHw3ZS6tfWDLp+n2lxPqbywTWzoizOyssbKWz5ZztODjmneHvjND8QPCPizWLfTXhstMt7U/wBo zxhHuIzfxKIRICX3Y3dwASDjmuKWGk8QprZb/cbOUVQknv0+88m+IHxI1nw3dS3PhyW1e5to/JuE uolmljZn3u6g8AFpDkgdSa0vgzf+PfEviVNd13UbyHwpZQsNSm1O2K2rQkfPAkWB5jlRjIHGeTzz 3U6aU+Y5pSXsrSN39sW+uNbilHw+LxeHLCLT/wC0NORClxFN9kiWKS4+ZjImwoitkhWG08kM/kHw o88ajdCz2qyxhmLgH5dwGMH6121mpPTY4aKtG0t+p9b/ALC8bSXGtR3bAYuUYoMjIKk8ccV9QWeY rdowAF25yT2xng16GGX7pX7HmYn+IzzbxzHn4ieFnhYKP7Ui4YcDCsBjj3zXzn8RbuDQ/wBrSV9T 0C/8UwjWZWl0DTi6T3wWNidu1XYHOGJAPAOcDmnXgpyhFrR/5mmCbjzyXQ6Dxte6fpkVzqd74K8e eAYdQcWsFz4j0+WSzjcZA2ymOIngMflVz8uQDzXnXjj4VeK9M8CvqOjW51/ww03mHV9IcXcMTBMs spXLwnaykrKEIODjmuSpkboXnSTa7dUddDN1XfJVdn+B6b+xtPa/Hf4Q+MPgz4qkjC6xbyahoUty eILtAGwOmAH2555+cV83/GDwfqXgz4ff2XaaddKtrN5F8yR/6godu18dCXHPv9a/Xa7hieHKGcS+ KFGVB+TU7R+dnc/McCpYPiLF5SlaM6sa681KHvfLmieMtBNH96KRceqkVNbu+0Aqce4r8op2b3P1 GpdH21/wT+jPin9m7xhpV380bfbLZFP91rdW/wDQnavkTT9Iu9Y1OGy0yKWW5uZFihhjHMjscAD6 mv1viSm6+RZLKKu3Ga/8mSPyfhaaocQ57CWiUqT++Ddz7+1ya1/4Jo/sVQ29g8J+Inj6JsTjl4I2 GHcegUcD8Mj5ia/P+51KW/upJ75jLNKxZ5H5ZmJyST3Ne9x8o5RQy/I4f8uYXl/ilv8AipP0keN4 buWcV8y4gmv94qWj/ggrRa+TSfnEkt7ggY2jHoOK634Y+EYvGviaOHUBMtsqNLM1uMvtUchAeC56 KpxufaucsK/P5VfZUpT6pH6nRhGpWjGW19fTr+BrfGnxOmteKJrHTVhFrpSC0jWBt0W9ThijZ+ZF I8tCST5UcYycVy+lWN5qt9ssIZJp5NgWK3jJxtQLn/x3Nerl1B06dFJa9fnf/M8/GVFKpUu/6/pH e2fweg8L26X3xW1GLS1zuTTYsSXL89NvRf8AgVTr4/k8L6df/wDCu7aOweKYiW4kjU3SxnAVgw4A 4OdoHX3r62jhvYwfN8bX3WX+Vz5eriPrkrR+BO1++v5HDahq0+p3DTX80k0jE5klJJJ/GoFlyQR+ dccZc256fs1BWieofsz/AAI8S/GzxvH/AMIOGsbXSXjub3X5lYQaeobKsWHWQkfIg5YjsASPqD4o T6V4f16aPw/C0N7q6SSHV5I8m7lhCoct03ZYADoOepya9vAYF0FLON5UoyjCOylOVrfdZ/efC8T4 +WLrUsjov+I1Oo19mEf82fNn/CI33xa0mwvLGSJ9RaY2dwZN5O5ZQokfYp2DMgHOBz7Uz4r+Bb3w ppGmQ6wUmu9LEllcvbZeMKCs0TBscgpOMH2qcrxUsTCoq38Rx1t3jytv8/uPocbgo4OOHlT+BS7b J8yS/FH0H4eh/wCE8/Y30yRMZTS7uycZz89tOjIP++cmvFf2WfEzeAvj54U1aZpENlqFvcMoyGMa zqpxxg8t2zivhc1xMKWSYilJ2l7WaXqpqX5H0mV0ZSzeE0tFCD++Lj+h+jll4M079lH/AILxeG7n wHdLYaX4h8bafe20Tfu1j03UVtHyM/wGO/mX/gLelfmj+298M4v2cP8AgpF8YvCVnEbay0vxJq9p axEYxAl2xiP08sDFfM5PU9jmEJ95wl9+n6n1uY01Uy2dPspfgtDe0ba9jDLDgiRFYfQjI/nX2R/w St8fvaeMNV0SRvkuYvMw3bnb/Mj8q/pScPaYOSXVH82V5Oni1J7xkvzsfbd6wiUByRKAQV9cf/Wz +VZolEjYAOD3zXya+A9xpc4ikhjv7/lViybOREBwAPyrl6nYnoSbhIm4ZPb6Um8GPMJ/D0rW9jPc iiyZeQBnPNXYo90gBI/+tXM22mup1WV0SzIqIcr9z0pUiEkYPPGO+OKwersWnyq5+R3gyz01NDVN H0LVb24XlnFoXJ+gVDj8q1PEGs6r4Fe0e70GayhnGVkuQA7qMZITCkde+K/mWEZTvd3ufvktNjyv xVJfeKtXurxLIKsjE/vSBx9NxrhdQn1C9tXbw3pk9+V+Yx28JfJzggda6oRcIqHYV43udP8ACvQd W1rUba11+3n0O5kfBhmj2ui9mxx1r17V/hPaadpbNf3V1dzRoTuLBVyPYDP61wYit7Oex6lKm5wX meH+HtVvvEOq63dXV/frYWURW1smtSImOQN/mdCRzx717BpWkx2PgJNWe3D28AQS3BXIUt0H51pj JODST7fic1BJK811Ob8MeJ9S0z46JZ6hc/8AErnhnEdsBwreYTnpgdD3r6D0LWUtPF0RU4FzaKD7 kN/9evocJJKnFni4iD9o0dvJq6T6S3PKqDn6Gk1TxLPp+o3D2hkVbuGNt646hevtV4yr7ON4iw9L mlZmbBo2qXUkV1YyTyySrnMkhYhuvQknGDXTeE/DOqC2mMxhuJmZvMLRspVjwR1r5F42UZSTfVnu KhFxjp0Naf4eamGSVVCjIZduQF9waxtQ8GajotvKz6jZ28WWcvMuACepOSK1p5vKi7pmdTBQq7o+ d/G37RGr+BvGmoxazqegT2NpJ5MdxDE2JISBuY4m+Y4z92pfh/8Atn+FvEWqWmj6Vfy/apUYeY8Z SLKqTyxPHA7169HNIYppR1bWtuj7HPUy2eHhzS0Xn1NTxF8WrfzNSeGZpEmgSXzIo2ZMpzywG0cD 1r5k+PnicarrzXN9GA6z294+05RA4II98FgCe/tWONg+aPr/AJlYKatO2un+RwngW4t/D+tzanYu JLyKdjHmIOiY479Sf0r2jwX+0RqNo8Fr40j86ymV/wDTII90seD93yxgN+Y/GuSXKpe8ddT99GNj 1eL4nTS2lrdfDm18572xjla51S6jgWKMLnlMZLAdQCeeKt+Ff2krp/GX9keIzaSy2LwypeWmVSdW QE/KScYLEdT0rDCY6jWq+zjDbr+B34/JKmDwyrymnfonfpfU9c+HXxEWeznjDLmG4kjAP+9kfoa4 L9rm7Hin4OzokxIsr5vMGPvLNFJEB/31Mp/Cu3EK0WkeLh176bPzy8NfDDVvi5450y08NmC2/ehZ 9W1AmKzsQTnzJ5cEIoweT6cV9SeIfhB4B+HHw5ne/wDjFp2teLPtaqNF0XTpLm0jt8YYrcpgMQei kDjqw6VVB2SsdWYSftZW8j6/vd8f7MGlStJvgWxjRWYKrFv7LBOVGcEgZIyccV+en7XXjX7D8TGg tdM0xrkafpxOpTpJJKQbSM7NjOYcdDkR7vetKClKnU5/539xy4hxVSmo/wAi+/cT9mvW31q1vbnU nT7Tbw3UIdVVBtaSJ8hQMDG9u1e+Xd3b6F4F8OMkAuTNqQRLx3Ksk7xhVwFxncVwDkc7eua4ed0K 8Ka+F83/AAD0ZUIYnCVqr+NOCXzvc2I7TTfihe3enaTLbR6rdFIZVW/EStuQB5MsCAwB5RlboQAc YqxbfBGy8IaV4ksrvU7KawuLKJZPJ1FRBCUuImUZNurxsWBzuUsSVAAzkb4jF0qMlDkbum/uR49K jUrRdpKyaX3vc840r4O6F471DztQ0bUdOsoWZGvrXU491ztb5VAMC7j06nA4yRWR8fCrW9hbajYX ljYW+y2i03S/EMLoikhSSnk7nLHJY7m69a6Y1qF1Ts7tfh93U5fZ1fivomdNrHwPvrn4o3niGxjn WCWOOOW2NwhhuovIVGjdDHyhAxg54NYVn+zJo0F/cXvg0araG4ZhcWBnVharkEIjlcunTBPIxg84 J7ORTVrM5/bOEun4nqn7NXg6LwBBqB3TyTz3Ad5JnB4AwAMAYHX1/pXt+m6jF5LsW3LJxnPXjFd9 FOMLPocdeV53POfihrJ/4TrwuIMAJqUQCknrhsCvk39ra81K2/aB1ZvDE72uqx3MtzG8DFGDHaCA ff5hn35qMRG/Io72N8FNQc3LZHR/BX9uzx14X0EQ+IZxqtu5NvcWWpIGBTgEOD2PIIIrttL+P9j4 A8RR+LfgwU8Hao+Bd6M5DaVqS5yYinRM8/L90HG3YRmt8NnKoVY4fEP3uj/QeOyp14OpR3PRfiT+ 0n8MvGXhbw/4y8A+F7Xw98UYNVt47iWzRljhiB3TTblwsiMq7ArgkFyeoDHR+LP7M2rfHyPxjqXw nh0yW58Q2LzPpEjmPfI8ezzY2Oe4DN/tPnPYfrdHLf7R4WxVOj0nGpbo9k/8z8wniFhOJcLiqj1c JU/x5l876fM/OP4vfs/fET4DXrQfFHw9rmjKrFRc3CM0Dn/ZlXKH8DXGWPjDU7DIgvrhR9c1+Izw 0qE3CorNH7JGtGvFSpu6Z9of8ExPF9jqmmavH8TPiL4Z8JwXEzRxjXNOubuSU7FDHbbkFFxtwxBB O4fw19NfA/8AYX8BeE/CupeLfDnj7TvF97ZSFLC5htIre1iEbfvf3jxo4cxsDhgCAe4Oa/XOGs6+ sf2TRr0+aGFm2kt5XlfX0dn8j8q4j4e+rrN8Th6nLUxcEm3tHli46equvnofD37dH7b8vx4/aM1z UNAsNF1Hw/YSLYaS9/a7820KiMSLyCBIys+MZAYA9K8nb43KkIN74R8MOD1McUqA/lJxXzHGOfzz LOsTiYyvHmsvSPup/NK59Lwdw7DJ8lw2DtyuMbtdnL3n9zbQW3xv01s+b4M0Zuc5jmnX8PvGva/A tw/hbwLHr2ieGwmr6sY1tdDs2lDFm5jJkblCiN9oY9FY2DA8tXk0cdWxv7mEbt9F1fRHuzwtPC/v Jysl36eYk/grwx4M0L7V8YrPTfDk7Ln7DFfS3Fy3ts4w31+vIrjX/a/0Twddm1+G3hlotPQbTc/a BFczn1L7GIH0xX39bMaPDVBfWGpYh/ZX2fU+Gp4StxHWao3jh19rbm9DE1D9pzw9qly01/4FSaV+ Wkm1eZjn8Urv/gn418J/FuO7jTTG0jWISIUhlZp7c2rbMHO5SWysilSOVcYKlQa4Mj4grZnmNGhD 4pyXppr9x7GYZRQy7BVKtT4IRfrt08+3n23K3xb1zw58Fr63gvPCVpq6XBcC4g1GWIoykZVkIfHB 7nPB4459c/Yh/ZsP7ZV0+qweAo/DngyxYrc+Jr+/lZZnXkw2y4XzXH8RyFQZLEcA+3Wo13nryjDq 92rPok1e79P0PArZhRwWRPOMU7KMb26t7JL1ex1v7Wn7ePgb9mazh+Gn7M+lw3tnpTMl7PYzCJBI fvfvQpMspP3nI44AxjFZ/wCzt8WNO/aH/Z8ubix0w2V34I1hZP7OjuGuJTDPhg5dgCQ0hfg/3M16 3EXENCOY4bKMO/3dGSu+8vtN/LQ+Y4S4bxX9nYrPscv3+JTaX8sPsxX5njlh4psrL4ia54POmrBe Wi3FwLxJz/ppWTzNu0YKkLkcNztB7V6N46+MGiX/AMIJNb0zST4nOngNc2sczC3hjyFeMhmby9uF O1VBAxwBXZl2KwNHC4qvWSVWHtEu7dnp9zR6GOw+YYnEYWhRl+6n7Ny7JXX3ap/M9H/Y6+KOifGj 4C6smj2FrpK2t7GJNFtmLrbGZJYTl9oJ3KqtnoN2OSK+eNevLHwz8VIksoZre8DzoXIURTjBMZRR 93DBM8Dk1+DYjH5ljoV1Up2oKbal/ea2+5XP0HL4Rw+ZOn9rkS/7dUt/xP0X/wCCkmpS+NvAXwC+ Kli0kcviTwnplobuDh4bjTLm5tJpd2c/dlsfx2+or54/4OFryH4Y/wDBVyT4k+D9Nt7jTPHvh/R/ FFlBfJmG6ju9NRHcgdcyCQ/UV3UKnJL2vXkj98ZR/wAj6GdP2tGcX3/NM8I8FeM28f8Ahq21d4Le 1e9DO1vagrHGwYqVUHsCK9r/AGNfHZ8EfHvRZmcpHdubd8ercD9cV/TOUTeJyyjLvBfij+aM9p+w x9eP8sn+DP1EvJFk+zyqWZHAbn+6w/8Ar1lxYLup4Csy8k9q+Zu4+6exZP30Lu2Ngjg549BU1t+6 lJXGWxk9MisNzfZD2XYXC/Ug96isc7iQRuwOlRUfLZGtNc1y1HC87/JgY7npVuKInnoSc5aoXccr bEkkJVx/t9QOKdEWU4IIwO3NZSXK7lRd9D8mPDv/AAUXtdAsxaRaTps0cYxutZXkycf3UU4/Osz4 m/tSXnx4n0+38O+DNWdoMtutY9huVOBjLcqPoM1/OFR0qWqeiP3yNOcld7nKa94l8T+GP3b+ENM0 eQgt5eqedcTAdiRhetec+Lv2iPH6SyxW2oJp9tDyY7Kzji4xyAW3EUliYyXMo6FqmtrnYfBDxnH4 v1vTr4Xd7dTPIFmnvZNzlwPw49u1e8+KZFk06UbuqEcfSvnsbUtU+893DU7QikeceHPCEF74Qs7G aR4rG5kS3a46lFaUAnp2zX0zN+zr4W0D4cf2DBDcX1lf5mMtzcPvLRoCpJThe+emfSuub5pS5jyp bJRPjf4h3x8N/F/RriM4Vru5tyy5OPnI+n8X411fxV/aPi+E2oaLdSWk10rQneVBwQSABnseCa+g w01GjGTOCsm6luupDb/8FBX169ay+H3gzWNUD7gLhyVVc9DtVW/mK7TRfiF8QPFYin1mystCt1h8 rDKWkZc55Uk4P1x9K4MxzjD4WDTd32OrB5ZUrNdjR1z9o2fwtpdjajzTcWaBZp3AVHIyPvd/xrC0 r9snWfD2uPdWfnzjl5baIkrKAMkt6Y9enFfJucqs/d3Z9DToxhH39Ei1rX7XPxd+KNhJJ4K0o2Gn IwT7RbW7zMdxO3k4B/A4HeuV1T4KfE/4hWAufFmr3TSzzBRY3WoCJgvOW2or/L2+9nnpXVDBX96q 7+RzSxcIXVNfM6/wx/wTqv8AW2tpbrT455JFDTl7GaX5s9EkuJNvTuVx7V6xo3/BOO5h0e5j8Ox/ 2Rc3EYRLm7mgVrXkZZVtYkBOM/fLV6MJOKUaei+48+pNTd56lL4zf8E91+HnwE8R6xqev32uarpl sLmGSV5htCEblIMhUgjP8Oa/O3xv4lu/Ej6qNTdfPghEabARlE+YfyFbUVKK173JUlOT9Cp8MtXh ivktZ5fKZQ0iM8ZfewUnbgA9x34r17wbe6Te6RcTES3ktqpa6kaJxFbbyFGSBxyQB6npXPjZ+yd3 1PXw+AnjHJUWrRst0t/+GO/8K2+l2S6VLqr6he6RIPJlvLG0IW1jCHYN7/KdxGOO2T71f/aY8C2H hDxD4SvvAlveW91dmVBbkmQ3WNuBgEgEdeMdKnAU+aXOZZhSr4eKjUVk7r5pK/5o6nwHpXjH7TeS ado8rRTukoM8yRgHaAwIJyOleZ/tOfGbWPCN/q3hTXLGP7SqW9xIYGaRd6ssoQEAZONufTNetKnJ rU8dR+0ulv0Pm20ivJ/COppd29zELO+huUEkbKBHIrozc9siIfjW54MsLrXRFBpdvNczMcCG3RnY /gM1vTjaKTKrVOabaP09+Itm2ifswaCNTla3hi8wsjKzECOxaAnCgnjGMYP3u9fnx+0J4XTxP8cL /wC3f2ilkLPT0tr22tV8q4xYxdHmkjVRwc5OQeMZ4roqLmUvX9Dgg/3kf8P6lf4VaDc+FofFkWix XcMNzak2Mk4JmDIrbvm2quWIUjZkYA5r1f8AZm1i+8c/s2SWHj2S9tNWfUGS2v545UdkheKbzGbY c90x/Eu4djXHKzjzXtbd/cdUZe84cvM3ay+85DWZZ5YLOYeJtN0yYZumk0i11NGW680kfL5HKMoU ENt5BIxXrGgand674LK62Yln1qUW1xcaZEQJUjlWUXBEiB23lVgOxXG+aPHzHB640OaSu1Y8yVZU 4uyd/M8h+LYu/GVy39n+PLLw/a48qDSoEuvIjjHYIEHPqepNcH4X+Cthb+KbG81jx1pN7cRTx4hk gu8kF/QREbj2yeM0Ohd3bRcMUlDk5Wd7+1l8c/EWm/ETVdC0K6vdI062KERwM0bzlkDrIx4IUhvl UYGME5OSfOfhV4u1251K4aHWNTjkTDrMt26uWLDOGznJHvWtWtJX5dERSpRa95XZ9ffs2azea94Y mfxP+8uBLhLhBtM6Z6uBwGByuRjI2kjdlm9a1E/ZYVRCy4GdoOeQP/1130puouZo8utBRk4o898U 6g0njHw5kq5GpxlRkcHJ9frXzL8cZ7fxB+1b4l/tsSRJZkRuLc/M0hUN7jgkjj0+tOv7koSf9amu Dj7SM490YcEtvqlvKummGRlY+a0YGXB43HHfpWtfeETf+B3inePykBI2cbnAJz7dc14ubYZzrRqw 2ev9fM9TLK/7l0pfFHR/p96M/wAAynQ4p5NTZmtTOFaLBz1wSM9CCT7fnX3D+wl4zm1vxmfDXiS+ FpJDYC40TWIST9siYbDKVz84iYndGBztAypGa/euCak8LSjl0pX9vRej6OV+X8E19x+P8ZOEZTx0 Y/wqienXlaUl+N/kzZn/AG/PDsfjHUvBH7SGmWdrq+mzzWF7p+oIrK0scjRvgnKuu5GGQSDiuU+J H/BP79n39p62e78BEeFdTmIcXXh+RURmIPBhIMeMkHgA+9fHShhc2i4VFaS0809j7aLr5dJVKesX 9zRx/wAAf2Ebz9i74pbtT1ux8R6brq+XZ3cdvskh8vJdWBLAbvMHQ84NfKP7Qfw28f8AhP4keMdJ 8OajfWHh7U9UupU0eG7lggmgMhEeY+EYbAozyMCvp82w9XI+E8DXwz5asalSLkt2pc2/ysfFZRio ZvxlmGFxPvUpUqUlF7Jxa2XrqeRSfA/xQOBpkknvHIhB/I1U034S+KNV1VNO0/RdRe4lIAjaFgOu OSRgfnX5BSwlavNRprmb6H7FVxNOlFyqOyR678Pv2RJfC+pafd+OL0PqqXMDQaBpkhEzSeYoRC/8 LM5VBj7rMGPyhiOr/aU/b/1XxZc2mj+EUi/tTRIpLC/8WybHm1SZZ3JnTCgqu0qo3l22qoJwFC/Y Qp1ODKkak7SrON7dIt3Sv6Xu/uPmHOnxZRlGN1S5rX/mSs38nsfL3iPXbzxDfPca7czXVyzHfLOx Zj+dZmMGvjcRiKmKqSq1XeT1bPp6FGGHgqdNWitEgrQ8NeIr3wtqiXmhTNBOnGV6MPQjuK3wOKqY GvDEUXaUGmvVE4mhDF0pUaqvGSsz9Jf2D/2BE/a9+Fmm+N/20dIfw74O0eU3cF0sospvEFsix4AA AaOA7SHmJLOG/d4b5xz/APwUr/4KjQLZv8Kf2P7G38K+EtJhFk95pcH2YSQgcRW6jGyPvu6sSTk8 Gv2bDYz+wMrnntWNsRXSjFdt9V5W1+XmfjGZUP8AW/PKeR03fC4V81R95aWi/R/dfyPzwnna4kZ5 WZmY5LE8k19P/wDBKbxstn8c9X8Jak5+x+NdIntBEDjdcxAyRn8FEv51+SYbESni4VJO7cl+LP1/ EUYrDSppWST/AARzX7RV5c/Cr9pu01VUCzWs6mWJRkNhzuTHfKMBXonwb+GN1B8YtZtPCFxpkmm+ IJy6rq7R/Y7VBGJWkmdvkHDYYfhycAfpGIg6uPxFODty1IVPWMoPm+/Q+NwF4YTDzau3TlD5xkuX 9T2v9nvXtG8Oa09p4Pi8rw9a6Yn2m/DQmO4vopgzpmNQUXEchjjc7sM5/iwPHP2htNt9G+KUd3Mb d/7OupLiOzjYM7gSIw+T7207Tlug6e1Y4zBUqmGr0YQ91Tp/O6cRxxFSjmNGrJ6yhU+9STPvO7vh 8Wv+CM2iNMq3GofDrxnqXh1fK5a1s72xgvgzdwDNp7gduRivIv8Aguzpn/Czv2L/ANjz4pwru/tH wNP4UlcDo2kXRjGfqJ/0r4OlDmhBf3JfgpM+8vdSX+E+Q/2aNS+3fDVEA5tLqaHJ99r/APs9eneH dWfQtbsr21dke2mSVWXqCGHNf0bwdWWJybDS/u2+5tfofzpxdS9lm2IXRu/3pP8AU/Wj4eeJk8Z/ DHQtSU/LdQJwPTHT9a1blx5+SCMgE44BI6151aHJUml0bFQnz04PukLDtZfmyO5zSKxjXJHPtXLN bNHbTd20x8su0BiMjJHvjFV4nCtmMADJ/GuWo9TrpLQ17SdWiyevHAqRZCAM8EZIxWi+EwlpKw9p CY8hjnr9aVGBHyHpz3yaxd2zRJWPiLwJ8L/hZ4n8Fzah8EdD0S6MLFIrm7t2dGkUfxB+SOQa5mx+ E3xXurlk1fx54e8P2fUWPhTSFYgDqNxCsD24Jr+W8Ooc8vbRu0f0BJysuV6Hnf7YGkPpfxEjjvJJ ZXe2izcSrhpCFxuP1INfM/jXQRKl0B/EjDP1rXDS56KY5rlk7lP9nK5Gn3lgsQwftBzt9eBX0hrO rLcWjoXIBUjg+1fPZjN+0Z9NgVzUkxvwvijn+GWkS3CFzHfwFlRdxIFyOAp6n2r6p13w7s0Qyzxi N7ZXEAjXGFcDLEDgN24r1cVC0m0eHF6s/Pv49fDXxXrV7Nc+EvDutah/ZmqSy+dZ2Ekiqm7duztw BxXoPwf+Fus+JNH+0fETw7FKkeIreLUiiyKcgk7GywHTtXRiK0ngvZ03aVkOhFLEKc1omz16z+Ce oT2FoPC0MPntIwlt7KzeURIAMYYHrn1UDjrW+v7LPifWfLEkMtuzYw17PCgZsn/lmTuxjtXzCyyp N+9qz2XmEIfCaek/8E438SX0dz42voXeLLomXlSM+mwBVPSvTvh7+wl4d8KpiKWYNgo32OGO3BUn JXgFscDjPYV7eGwSoRSR5WIxsq7uzvdN/Zu8MaON0GlLNjJIuXeUH8GOO3pW3oHh7TdIQwaRY29m IjgwRwrGuO3Qc13Kilozi5zUitkUtsQYPOcVzJ07xA3iB5tTvrSLS4jvEEaYfaPVvp71p7KW0SHU 7nn3xd/aB8I+Ifglq09nPdajY6uLjR41gt2RvPeEsMiTafukEDktuAUEnFfjxqdjHY/FG7sLtGxO HjKHg+n9K0nDlRdJ80mj1fwH+zBoPhaxW+8Va5HP4l0y6tbqy0uwdZFv7UlHJCfeddhfdgDaEYng V91a18GvDk3wDt7cadbRz3kMjyXCIoOFJYN83H8Ixx+dedWyxZrVp4qpJxjG3urq731+6xrDEzwl OVGnvq7nBfGD4caVp/wubTPD8cfmafaLcT+bIdySMjFCE6liDjJwMZ9K8c/am8R2Phf4PaB4jLXE 1/pdzA222YoYftNs5jbOACCoIPJ5Nelio1JOo4NKUo6W2XTTyPRyaVOEKTxV5QjVu/O8f15Tgvhr 8Yni0qS48N6/qNrNc8ylrlzghc4wW6/Ssax/af8AiVqGr3x0ySCxjXev9qRWUcMtwynCs8r/ADPn APJIryOHcwxPPVoYqN+W1m/mfXce5Ll1Ohh8Xl8+X2l7pM878XeKdc8ZeKpdT+MWureXd1bC1nnu LlV/cAllQbV2jEgRuAc7e3Ndr4e/a6XwP4ftNE8JatefZ7faqpp8fklsMGG5o9gf5lHLAnqOhIP2 eaUoQhh50tVUhzP/AMClFry2/U/MsIn78ZfZdtfRP9T74+Pmsi3/AGa7BLy4LzrDdymDBzt+0vEG Jx3Ibv2PA61+fX7Qes6zb/EfVLPQZEhtYo7WMIkKFnAtox8xIJNcVSPtIyt3/RBTfJODa+z+pq/C fQ9W0XRH1rxK880zwm32zOzeZlmYEDt8oXkegrZtI/F+vfs1xalpu6fVYvGL3HlxB5ALVLdcJsjy xTO3K4zzz1rmjD2dF01vr+ehfOpV1Vlqk0vw1LXh/wCDWo3WnaXr/wAQpNVuYUtE8rRYILwNfXhZ nJnSJGkjiHGRgE9MgYB0bPwt4r8V/C7x2fEEviK51C7Wwhslg0WayFrH9qRglsjfMYlMaE8DAGTn cTWl6kGqai9Vq+2hhLknzTut9F8/ysc145+FfiD4yWt8NG0jVNP8aWsKyG4u7eaOHV4VyCisflW5 A25bjfg55yT5Z8Kvhx4rHjzT01rw94jtII5cyy3NjcKikHuXXnn9cVU4VJO0UVQlRjF+0Z9Y+N/2 f4vHmqam/i0WepRSTStCL3Kz2oYltscyEMFGSQrblHp1zzOj/sc6X4Wu2mlNzDJLteK3F0CioOpc lck89FIwRz3Fd6o8yu0eX7eUdIs9X+DPhSPwpYSQQSEAyNgKRtTGAAOufXJyTnkmvQLtPtSIJWGV /UcjFd1KPJe5xVZczPN/GdkNP8ZaAC3mOb1CoVT6nk+9fH/7Tsck/wAX/HrWMsonF9FNuUbXOI/n T/x79BW8cN9eqRordxlb5Rk1+JrhavsOZ9E1+aR5b8PvHUvhTxJHLKsrW8jBJlOSSuev1H+I7177 q2rvpGkwtbgS2eoJvgZDlS3Tb+f6V5uFpvHU1Rj8Sa+6Tt+dvvO7Ff7HX9s1aE0/vir/AJfkc9r0 x06witrct5i46fxEnJP8v1r6V/ZN1mdrTRbrQ54ZLyxulGn3AbhLwKI5bVmH/LO4YMnpv8o8Asa+ 0qZvHK+I4yT9ym4Q/wDAUv1TPkMbln9o5BKMl701KX/gV/0Zo/8ABZj4H2njnwh4V+L/AIOtAraj FHpOqzR5z9qjhLWrSZwFaS2ieHYo4ayQn552z8F+Afjj4q+Hlyj+F9Uu4UTnymkLLj0x2ry+LqTy XOsRGk7Jy5l6S95fmetwdiP7YyTDTqK75VF+sfdf4o+s/wBkL9sHXvjX8RtM0Px1IHNgklzHID1+ 6mP/AB4H8K+m9f8Aj/4QuPEupeD/AIk6VFqX9mMFaM2plJV4xKuMA5O1xX6jl2KWa8H4dtcz9s42 8+Vs/Mcbhv7M45r68qeGUr+SmkeReI/hf4a+IHj1bf4M6PqEIViZLBLtGUnGcuxPlwjHYuSem3PF R/Er9n7xx8PdLnntbKzh0eCF5JrjR5Q7rEoy/mSMA5GBk444PSuJ4KhwxRlLCwUsRL/yVHsxxdbi WtGOIm44eP8A5O/PyOc+EWlJ4R8Iap481+Nopi8uk6BBKGVpb4xlbi67E/ZopWQHORPO2dyrXn0n w48M3vM2h6Uznq32SMfrivzrEVJ4+q6ld80vM/RKNGGDpxpUfdiuxnXfwC8GalOxm0SBRnG6KSRf 5MKYf2S/A86bhYXKtkgiO7k6/iT2INTTy6hU3VgnjakPhZHJ+xt4OupVjs4NTEjnaEhuSSxPTgg5 r66/Ze/4I/8Aw5/Z5srX4ofthJcGxskFzY+DtamR0d+Gja5iVVZieohJ5/jGMivosi4SpZniYxfw LV+nb5nzHEvFk8kwcppXnLSPq/8ALcxf24v2ltc/a9iOh6RqupeGPCUDDy9P0soj3KqcL5pwflA6 IvAFfPPxR+C2mfEzSreLx5cy/wBoWcRVPEip87jdJI3n4O1OWABRCpOS205Y+9xDjaWZ15UG/wBw lyxS6W+0vn+Gh5vCGWTybCRnJfv5vnm31b6P5fjqeft+wxZGYx/27fQSj/llLaKWPPBGG5Bx1BNb fwu/ZWHwh+Jvh/xJpnivZNo9/b3KrNbLCsgDgmMuZcKGXcpJ6Amvh5ZBLD1VaWz/AKsfb/2n7SDi 476HpnxR8HwfEH4kTeKNRsToSeWl3Z/2jC5vLpHkYb7SHBOSAGEjBdu0bW9afxEstU1rwxP4T+GF 4fDOjXd6lyJrkJLeSOIvkMsqKp/hcAD5Vw2Bls195K0ozqx0qOP/AKRFJfdZ/M+ai1hIwpS+FS/9 Klf8b29Cx+yd+yn4htvGclg3ieKa1uYpFt9NEZaJbojzVJjc7ShdGypGM46nGWfFjw2r3f2HxL9o 0jVJ4Hna5tY/MW5R0HlxBVBkVVc7du4jLA7a8zJJ1qtGph6vvRhyt/fon6PZ9EzozOVD29Oa0nPm UfW2tvVbryPpf9hL4r6PoH7Ffx3+HPxD1rSrDUPEDaHrWjavczKYLq7tHt454EflfNa3mu22khsB hjPAyf2ldQT41f8ABvPorOYptR+D3xQk0vy4zue102/0/wA5WPor3CkA99tfKV8HUwNotbuaXo4p L8z6/CV6daMmnrZfmfIf7P3w9bwl8NrTUYr9buDXf9JWFY9v2Zx8jqTk7uQPTpXYL8oORycnjvX7 jwGuXJKHkn/6U3+p+Dcavmzet20/CKX6H3x+xZ8bILz4E6fp1+7tc2DFAMHgLkdfpivcvD/jWPxP aCWFHBgYozEdfQ596zzPF0qWNdD7Un+hy5fg6tTCe1+zHT8Taspdj9OD6US3AWZlbJ29h1/zxXLU 906qS5mOkvAyBR1HOAeAKRZwCM89K5ajvsdlNcujLEUvlkAE9eTmpmugc4JGfWnFszkk9SVJysvz 5Cngipbdgpz82Bxweadibqx+f37Ft8lpba/pVguyK2uiUjAwORjI9uBXuWm2zsJfMii4YgNJ8x5H Xk1/J9Obdaeu9vyP6EcVGC+Z88f8FDfDsmieLNGuZyHaa12mVT8rEHPHt81fIvjLVBHFKBy7kqBW 2Ad6TXm/zZVSPvfd+RhfA8ebrkKZ+7esuB25FfSF9Z7bRtwbGM4xXh5inKsz6bAP9ykZXwT8cwza da6TLI3m295CRjnOJg1fc3iZd/hKdVLblX5drcjFfRTjzJNf1oj5qTs2mY3hX4Z6d4m8C6RqOsJP evfRsbkXUhOHRtpAI9h1617lo3wh8L6Pb250Gw0u1ZMbisSPIeO+7JFKnhkmVKrLZM1fFegNqCxL oKxxooAxEAq45yMD8K5648B6jYqLpnjDQtkIGJOM/TFbxp22MJXb3Nvwff8A2gSW12V85fmQ+ozy M+39a3bGLbMQwzx6d6uMNrjk9y7bWBv7pIYgu+R1RdxwAScf1rv/ABP+yZqWgRRS3d0l1JJKVeGy UDKrneVZyMnOAMgDJ5IqqnudCY+8eh+EP2OfCStHLqg1O6X+IT3SqGOB0EYBxyeprtvD37OHg7w/ aljoWnM5J+SUNOoG44/1mTnGM+9EbtBZRPz0tJINP+N/xN8KRWdhZWfhnX7iOytLO2EYW0kYsjMB wSSH9yBk9a/Gf9rzwqPh/wDtU3tu6FEi1S4hOP7vmEDGPatq1O0bk4afvIn0eGwtlNxM5S7jDo0r v8wXkBMnoNp6Zr6en/bx8Lad4E0/TLQzSx21tFHIlxIEZ5NnzdicZ9uQO1efharjzqpK12tba212 /rex7U6EZxU6a1UXp5uy1/F/IpeI/wBoO/8AjPbXWoeBLLT9H0i7eKxkv78vK5+Ty1RBhc4VuWOO WGM848d+MOr6tZ27eHvG0emzadpaw5e4+eKVUQiJiMAthWwN3TJFXRj7KnGz961vle9vyOOljmub DS1V1r5pW/Jnn3gnRPEvjjUVXwzBBpmlPMIfOtLVYi644IGOBivY9N/ZwVIbc3wnuG3rvkmctnIK /wAyKr2b2Q6mJulfZHyv8ZfAreEPHl5YnKfZ5pkKt6LKwXP/AAHb+dYel2UTapaLarud5UQ7Rjqw H9a7MPUftIRnqlp8iKkU6bmt2frB+0tDA3wkIsJLdQLeeKSQtj5zeK7KzFsfeY4HHLV88eOvC2ja fq02reJ7L7RgYJgj+WdhGApLZAIBIPHUDGQK6cCk4yctrv8AJHlZhKXtIKO6il+LON8f3j+D7e01 LxVqF2ltcXDCG3jjjKKHyAh2EjZ+7YY69ckk1Y8VaV4a+Hnwm0jU/Funy3qrfz6nFYCJhh5AirI4 Bz5WUyRk5yoPBq5ckp81+n4HOnNQSUev46nnPjTxjZ+NvFmmtqura/cXGpWiXSm2KxBIXJIZ22nA UDnoAAMAVY8O+K/D1n8HfHCaTqWqTW5v9PspL5ZS8km7zWwrEfdzGewz69Kzbu3K7v8A8A2UGkoc q6fmcH8Q/GGm6Xrd7Al9qZuEmDGVDtWGUY5jxyMH1Jz6V2vhzWdL+N/irR/7Vupo/GVqkYt9RnfE GvxIoHlykcCYICFbAzgBuxEQtJO7KnGUbNJHUfGXVbP4N/EHX9Tu9t34nvr24ksbTcHh02BmJWZw OGkYHKqegwSOgrzbwDqs3ifVr+61m4kmmuJN8s9w5aRnZiSxJ6k5ravaEWkZUo89n9x9Sfsqq8em XaFy8O9Tu3Z7sCf0H5V7RFKNRLfZ3GF4Jyc5+lduFbVNM8vFpe1Zy2v6MG8UWs1y++a1/wBIT5sc CVFyR9GNfI3xUktp/wBojxF9qXdFdakYmLnIUtAqgn/gYNetllV08fh2u9n6PR/g2c9f3cLWtvbT 16GH4C8H6D4O+KyWfjnQ49St9WgF1p0l48ixKuWVxhSNxV0dOeMrXoXgCGHxr4t1zwbd2kVokVyk mjsAUSO5CDEPPZ87Rz94rXNw9CVDNOXl1g2n5pXl+DidmfYp18oTUtHaS8npF/emzxHx14s1G01G +stVeeznhmeOaCOMeZGwOCoPH0619CfsYr/wkP7Ouv6VoXnW17HLK9s8sgZo5CgaOQEAcCQZx6jr XzmLxNStXlWqfE5N/O/+Z6+Iw9KlhYwp/CkvusfXX7PHjrTf22P2Y9b8Ka48UV54p0uQ7rkFV07W omDrLkqSFW6jgmbYMsGmQYBr8rZ/gL4j1P4karomi6Xdwz6ffXFrLDOhUWzRyFSjk9GXGCOvFfov FGCrZ5Ry3GUIc06tPkdu8HbX5WPguDcZSyaeZYKvK0aNRzV/5Zq+n/byke//ALLHwj074M/F3SZN Z12C68Q3m6Eaba4KJHjc+T/wAc8dxiuh/wCCi3xO174f/GYaZ4ZaK1g1rTLa/ea2jxLIDuhwW69Y TX6BRjU4I4OqcjU6qqq/aMpRS/BfmfDV3T4w44ouacaToSS6OUYzv+L/ACPCPBPx18Q+BblX0/Ub qAkklQ+QSeuR3r3jQf2tfFnxM8A3una1fm10VV/0zUIxl/KXBdVyQC3zIApIDO8SH5XavyjAZ/Xr Sm6srt3bbP2HE5NRpqKpxsla1j2LwD+0d8M/G3gjSPDfiHTraG20i1W0tre4zuhTkkhm+YZYsSck knOam1v9mbw34xjNx8KtfFvI3zC0vCHQZ6AMOQPrmvoqOGw+NopUfiR4lWviMJWk6msWzzbxh8Ff FfgR3bVtMmnt0P8Ax92H72Mj145H4gVD4D0fUfG+u22k+GbS4vtTvZFjgsbVC0ruTjAUdSePpXFH D1KVRU5LX8zsdenVpucZe7+XqfbfgD4K+C/2APAqeL/2gnt9W8czLmz0mJ1kSybHCRKRh5c5DSn5 V6Lkgmvln9ob9qDxD+0T4te/8W3LJaRMRa6XGSIbZc+ndvUnmv0fGTXD2WxwsH++qK78l1/y+8/K srpy4szeeYVV/s9F2guja6/r9x5/HqJJI7+xp63m/duPTivhXK7P061yq0Sm2eG2nmgiYMDbphow GKscIwIXJUHK4PHWrdjf3unzGXR71NPuhJLKlxp1pBbsvmJsK5RN23A4XIAycDnNdlPE8keWSuS7 uzRp/EPwrLpnwQ8I674LaOTX4JXsbycgE3kg4+bc3AIYHGeMDFcl4X1XxBqdyIfEtikE7RjydsKq BMoR4xlZHBy+9PXnnriurL8wjisZQUnzN3hK3RttWa9JI8rG0ksLiGnrD3o+iSf5pnZfs4fGK707 46+HZL7TlMbX8Su6C6VSm0EH5ogNpbKA5wTnqOToft1Wa+F9b86eN3YzT2CvFgiPbdBkJOem2ID6 mt+HLUcRjIXulTk3/wBuyTsY8RRv9SmutRJf9vQkjpP+COP7NPhf9qv4+3Xw6+K0s2/xBYavYaZq YuJIW0/UFhL2rKykFk3AAr0IkIxVjwP+xHdfFP4A/tDXnh/xVqNv/wAKrsbPWJPCE9p+713T7ecx yiQoyCNoY3jcblcsc8g818zLMJ0MZUw0lde05Vfpd/pY+xwuCWKo06idrxT+5Hyn8C/HN34ht5NP sreaLR9PjYx5jGyKcspZQ4A+8WZtvOP1Pou0jIU8/lX65wBXjicsvFWSk0vwPx/jyl7DMt7txTf4 mhqnxb8T/DP4UXc/w51ObT5YL2Jp2iVSTA6kHkjj5wg4/vV7L/wSr/an13xX8X9X8MfErWr7URrO n+dY/bHaQRTwHcVXP3QyM+cdwK+e4rxU8LnlKP2Wov8AFr9D2OGcJTxOS1nb3k5fglL9T9Bbd/Ii XOd2Qf6U93Vs7j19q9qolKTufO05NRSW4Wirls/MVp3lgNlc7Tngdq5JQUVc61UcnZjo5NqYHQev GDU1vlxwSST17daIJtkTdkW4Y92OOPU04jbIB0OM45GcVoo6mTlofnn+xte7fiR4jtJW6iOTb0wM kf1r6RtrGKQJI0eTwSW5A7Z56V/JlOCdaT8l+R/RLn7q9TwP/goLZLP4V0S4iIIt5JIyBjCggED9 K+GvEYN1qkjMQFXIUev4Vrg7JSS7v8y5bL0QvwQshH4qypJ3X2frkCvpa/tSLNsg4xjke1eNj4v2 rPocHL91HU8/+GQ04axpCSyRx6jFdsqASBXl/eE7SP4vX8K/RLV9IC+Gro8n7pCt2+XGB+VfTwp2 hqfOV56lH4BXyap8J4IHOW06/vLdh9XLD+ddRJ4f1/UZv7Rvv7JexlC7E8wrhDwAcLkmlUpSnblW lyYSSbuWPgRpv/CuRq8vjFYLe51CdWiihuy6MoB5CucpycYHpXoa+LoNStI2tRG4uFBQZLFlIyOM A9K9lYCVWTeyOX2qj5mFHos8uuQsz/ZooZVZXQ4Y8/d/Hoc9vzq14x8T32gapZW+nx7kuQQ0qgZQ /j+HasnhHBqLL9opXs7GdpHxEfw3qT3HjvULPT7ZFLCe9nSFAQR3Zh6dgK/SHwtaWfj3R7HVL+4k nRoEktiCPLZXAbcMdQcjrU4zDuKi7aahQne66mjJHbaaDtAYjvWLq+vIikIBkVzQh0NZM/Pn9o/x taab+1d4i0PTtNvxcXyx6hJqEVri2BaJeHlHVyQcfSvx/wD+CqXhw6b+0lrE8aSIRcxXO5xgHfGr Ej2yTXfXpXopnLQnaqfMvxKM1zrzy6fK0cLQxsqRvwOMfrjNdz+y98Pz4ym1BLgbzA0bZbk8g/4G vL9jzWjFHqyqSVOTb2Pszwb4SsbH4c2Wny2sIW1J80Iu0PIJNys2OrYC/kK5fxV8E7T4mfFuGXWZ Ha0gs45fsxP7tmDMNxHfHHX1qMNTf1n2T8/6/A+cVdxrX9Tv9I8CaZ4cS9t7SNE8kwzqijHTj+le d/td/tW2fwH0WHS/BMdneeJrva4jlO5LGMEMHdR1J/hXj1PHB+ijh40KcpPoX7R1pqCPn3QfAuu/ tha1/bLwxWdxdXDiWa3iyJZFhTftGeFGzPJ796jb9m+6+H/xs0LRPEccckTzxTxzCTZ5iBxk49iM 46mvLjVVLnqct3qesv3vJQTt5n6JftD/AAwdfgpZmeKJItclkvFi3ZZUknWQEjsDtJ/EHvXzz8SP Bh8ReDV0rxK0qxwWxs1nhOVeIkY4ByrhflzggjsOtXl8HGMubqzizCuvaxcVskYHjXw3LfeHYrjx DYvqT6VaqtppotMRRqh+QmIAB2APAxjHXqRVD4jacnjbxjp+m+OrfVEurO2tvsPiFYikEbvAheCc Lw0MjHnj5WJ7ZB3qQSdorQ5ac5y95vuef/EX4JanpE40zTfCfizUIZYEhlk02yZ1Eafdi3x/wAtn AODxUHhj4MXTfCTX9K0fwV4ltZpNT0+WWwa3lMzhVmG/azZ2qWAOMffHWk6ErX5XY1hXW3OrnM+K f2efEy+Jru4g8HeKpZDK2LxoNqyk5UsMnAB5+leleD/hLP8As+RabB4f0O91DxRq5RZdZaLzrXw/ G/DLGx+XzmUnL8gDpwTuFhZR1cX/AJmn1lSjyxkv8hfip8P7/wCL3jXXdO8R2FxZ6rBe3SaLrc0e yO9hEh2W0remMbH7dDxjHIeAP2d/GWgXd0uu+GNXiU7eGhJU4J5yOvenUozqJ2VzOnVhBJOVj3n9 nCBvCi3FrrRFvlV/d3TYYHfJuGD142/SvYdQ8S6XbFYxe2yM4yIzINx/XPbtXbhoOMFHseZi2pTc jm9Y1X7TrVvPpSm4hMZDTIjlMZBzuxg8oRj6nsa+Lvi94khvv2lvEVqxKTXFyVVMYHmq5dWz6n5T TqVHRqU5LdNFUqaqUqq8jc+IdtP4o+FusXPh5Wi13wfcQatC0XDPpt0Fin5HOUuQpAz0kc+tce/i y88DeHdHf7RL/bGo3KObhmO4bPmJz1+8VH0r6KMPqOOzHFx2jCdvWUrR/M86lfFYHCYOXWcU/RR5 mepftNeA9O+Mfw38P/FrwrbRkam6aZ4ls1XP2fUgNqznjhZQufZlYdxUP7JHia5+G/iO8tbyGb+y J7RinlRllWZTxwPUH6cdRXyWJy+vmuNVLCQvKpZpeur+W/yPYwuKp4bLW8TK3s7xbf8Ad2/Cx6H+ z58WdL+CHxcD+G7wR3FzcyahPpUEhZVYvgkLn5dyMFPJ7kAUv/BSW81b4YfE6DV/CJT/AIRLx5Ad UtrmyHls8zkGeN2H3juYP9JB6Gv2aPtuGuHcTRoSU62HcW3vy89lK3pp+Z+VQhTzfiXDzxCcaWIj JJbc3Jdxv6+8eIfAWa1tfjZ4b1QSSyTS3BAZiTkvGwOffk16p/wVHsbtfiB4SvbIDyr7REh80/3o 5nJH/kUV4eWVamM4HzKVWXNJVoSb9eVHr5tCOE47ypU1ZSo1Y/ddnzh4c8Ey6zfFJDGZFTcC5JUc jc7HrtVdzcenfpXWfF+7n8F6faeFfDyyQLZqs2pRoPn87I8uBhzjYJGdsf8ALSSQcqqY/K8PN0aV Wsu6ivV6v9D9Um1UnGHzf6HIW/jN/D0iJq5WWJ24LDp+HavQ/BnxU1GwjSbwdrFzEBjMRfeg79Cc /ka9jLcwnTknTdmcmLwsKkWpLQ+i/wBlj46fEb4t/EHTvCXhbR5vEV7fuEX7I2VRe8km77ijuTnr 64Ffb/irWPBH7BFqX8WjRJ/iXrcSxqI9q/ZlKjcNw+ZUBOGPDNjsCMfsfCjp46Msbio2jS1v5q35 fm0fjHHNStg3DLMDK86+jS6Rd18rvr2TZ8sfHHwpr3xz8T3HiKTxPHrVxccrDcnYsa9kj28BfbFe NeJfCOs+D5SniCwuIF/567coevRhxXhZzVrYyvLFS1T/AAXRfI+syHD0cvwsMHBWcV976v5v7jJ+ 3gjKkjHel+3Z+6enp3rx1Loe7y6Ab4gZ5p8ep4U/MQenFWtSeU9R8BqPG/wW8T28USefok1rqEYG ecBlPf0U5+grkdTmg0hLZ7ybbczgBIwwHlSfeQknnIPOB7c1wZXlX9iQliYTcpTm5a9Nmv1OJRVa pUoPa353T/Q2/B0v9n/EKyW0QKhuYbu3h5IVJCJNg/3WDJ9Vr2v9qn4a2Wv+HNQ1B72NruaUubcA AKssIUjGSeSpb8TXqZ5nz4azipSpUudVozv5RnZ3+SPnpr69gML7V2dOUH84Plt82eEf8E1/jSn7 O/7b3gzxFfRzS2ui63pepy2sON06OVWVFzwCdoA9zX6RfCj4appH/BXv9pD4PWsH2K1+LXhTxXod lDKuEQzwNPDJjuNsa4+ua8PO06GPxE491P8AFf5n6LlEufB0o+Tj+Fv0Pxs/Znle1t/GGjzHabK7 imWMjnLb0Y/+OLXoIfbIRn86/ZPDlpYKvTX2akkfkPiJC2Ppy7wQ+800a74a1vT2Dsb2wm8pE5Zp Yx5saj6ugH41yf7FnxOHws/aR8H6vIVSGPUY7ad5DgCGY+U5PsFcn8K8TxIpezxOGrLezX3NP9T0 vD2p7XD4qg9tH96a/Q/Z8SBipzuUjOPX8ahmdhLg59q9RtzhGS6pHgxtCpKL6NhDdmN+o3ccA1fg ugeMbsgDGKx5+hu4dRwwCS2PSpYvmYADHbmtoI5ajuWIn2ct69qsRso4Y/NWr2MUfF/hhPhF+zOt 3dWusWh1GePZNe6nqXmyNz3UH156Vw3iP/gpJ8NfBtuqyapLqd0rHMNjAzjP1OBX8eThiK8tPL8D +kqbgtTx39oz9v5/2j/DsWleAPAuuzCNw0d40e1TgHHRcDgnvXh9n8HfHfjxDdX0Gn6Lag8vd3Ko FHv1P8q9PBUHhoOMnfUJvnd0dV8PPhufh54i06G61aw1Sa5uPNeTTnLxxnIG0tznpXvmqxiK1O3k lSBx14rysYrzk2e7hZLkR8++AfhxLJ8bINee7RI1utqW6pkqQMZBz35r9WdTikHhhwECjywxZup4 PAr6ig+akl20Pm66aZ5v+yfrP2m28Y6WzfPba204/wB2RSBj/vg17/8ADiRdQ8KBJvm+zM8Jz/su R/KuujTs18vyMJStv5ki+GdOhnm+x20CyonmZK5Gevf/ADxVm10/90DZHy1dQCF7cY4x0r6SnTPP nMzfE/irS/hjox1Lxddm1tt0cXnyBiA7HCjAyRkn/GvLP2hfhtrHi7xtLfX/AMQvEOh6FIsaw6Fo BETn5QCfMzkljk/dOKug6dGupVafPpovMJUZ4mLjCfIlq35HH6H+zd8JvD1imseMzd6pEMF9T8T6 kfmb0YFlGTg8EZr7Ltv+CxvwW+DPwn0S0PiG61vU7Gyhgk0zQrSR9hRAuPMcLHjj+FjXLnuJqYxx U4qKheyXT+rHTgsHDCRbi2+azu+vn+J4742/4OOPD9veND4Z8B3My9pNQ1hYmx6lVhYD/vqvM/E3 /BxLq2pT+R4c8IaFFNNwivcT3Zz6fJszXiU6Lk0kdcpcqZ8p/HP/AIKm+Kvil8YIfF0tvaWWrWkB tkt9NSRLdkwR86O7ZPPfPQegr5y/aX+NutftA3EmpeNBDJemNUEscaoSi9FwoA4+ma9CpTlOm4s4 4WjNSR4nr0TXNpZPGFXEbxsijlip6n3611fwG+LE/wANLq9FjHEJNTiRI5btwkcZUt8zHuOTXk0J KlWjN7f8A9WpF1KE4LyPqb9m/wAZQ+JfCmoqurtrNxBch7i75C7pEB2qMcKNpFWvjZ8S774SWtrr PhmyjvZ5Q1l5chbau9gwY7eTjZ+tcntHDGe0Wup8+oL26pvT/go8hi+MvxS+LPjMW2h6ZqENs5ji urjRrI7beFjnJkk+VGxnG4jmsDxf+xd4gv8A4tXEXiG7uJXvnjn+zvMlxqPlynCvLt/djPPIYgdK 9WdSvik7rRHqezo4VrlerPoX4e+GLL9lD4dSx+FNUNxcw7mEeoGOMrvG1h5oIVQx29f7vsa4eyfW PjH8VLK60+xudVhtpot2paehltLdd6syGYjbu74U9BxWEYPRCdrubPs39tW9vP8AhSfhWCKS4i87 T7aBDDIwdEUIAFcYPLq2fbAr5D1/Um8DzoianeXeqbGDBruSSK0BUjbgkhn5z6Kffp04SLjG1zgx TTd/kchJ4xvjGIrrWdYKqSSZL+Zjj6lvT1qf4ueN9T0rx1dRW2qatsSO3Xy47uQAYgTnGcDpWr5r pX7mUVF9Cr4c+Lf/AAkmnDRPHOp6nZO7F7XWxcyFreQ8bZcHLxH81zkcZBl1CDxLongnW9NFzqj6 q2p2EECRXLt5qyLK6tGwOCjbVORweDUuU7WbZfs4rVJGV4x+KEvwl0efSvD2pT6l4hnQpe6iZ2ki sAR80UOTy/UF+3bnpxPw8+Imua54+8PWmo6tqk0FzqVrC8ck7kFGlQHPPpTqTmvd5ndF06UJe9bR kPxi+K/iXTfin4mg0rXNXggj1O7VI4rqRUVBM2FAzwB2rsPhT8a7/wCIehw6H4p1vU7HVLQBLDVR eSxpOpyfInAODk/dft0OQcjOU5xbs9TT2UHFaHtvwL0a41/wzLa+J5Ly4v8AT7mRJTeyO7qSc7SS T2xjtg+9ej/8IFbrFuEI2jnp+NaUueWrk7nFiOWMrKOxyus6DbWPjSzmt4YwIlckqgHYAj24NfEP xr36r+0Pr/8AYUZku/7Rk8tIuSChx+QxyTxUYynNRhGF3JtfeenkbpVKtR1rKKi/zO78B+MlXxhp k11gW9/bT6RqkZPAjlUruweuGO4e9cP498Fa748+KD2+hWTw22jstss9wPLjUocuc9D8xb7vbFfY V4V8XhamFpwvUqyhG3pFX/8AJo3PlcLOjhcVCrOVoU4yb9eZpf8AkrR6NaePtP8AhJ4M1LRdS1dr 2HV3V7zRNOJKSsjBlDsewYA/UD2rz/xv8e9T1OBIvD8H9n2yupMUHVlB6E/QV0YrHYfgzDfVMLLn xclaU/5V2X9eZnhsvq8TYh4mvHkw17xj/M+7MDwNff8ACOfGSC7hkzEb1kXJPMcpKg/k4P4V9u6d oI/bN/Y/8YfDrPm+L/h1P/a+gsvLSQsnnLbrxxujd4gM8sEPau3gOf1+WMy6o7/WIzir/wAzi2n/ AOSni8fweAlhMypq31eUJf8AbqkoyXzUz4f+E2v3Nh8T/Dkc85CQajb/ACN1AMgBz+BNfW//AAVB 0RfEHg74Z6goZjHFfRfJkYJMTDP4Ct+GqblwlnVFrWLpu3pL/gGPFU1DjDIay2l7ZffD/gnlXw+u LX4L+BX8a+PLdJZtyW+mWrkZurpfmQEdSkQCyOeBnyl3Bgwrz7R/FEHxG1+5kuLlbOWZpJpr6+Zp GbzHVpJMAZLDaD17e+a/KsXQlGNLDxdktX6vX8FY/UqctZ1O+xJ8fPhv4T8DS/Y/CXixPEuo290l vdpbWzKiZDGR0fJBCkKOpySfQ1Y/Z6/Zm8Q/Gj4u3Hhz4VvJNaRXXlnXpEYQRxZIEhx1J4wo5PsO R7eDyKtjcwp4HBvnnJpad+vyR5mY57QyvLquYY33KcIuTv2X6vt3P0w8ZftP/Df/AII3fAlPDHw1 EOrfE7WYg11eSqjXIfGPMndclUXLbYxwDwcndj8+PGXx4f8AaB8UXOvePdQfU9VvJDI807nfkn7q nOVH0NfqHGOJw+QYeGRYaV2knJry/wA3r6WPyrgDDYniPEVeJMbC3M2qafRf8BaevMbfhHxRrGhQ iTwbr08JXlrO8PmIR2G7qPTnNejeH/2ytY0FRbfE7Rjc2zHa1zbr5qlcdeOfzFfJ4HNJUElV1i/w P0LGZdGu7w0kjodP1z4bfFyISadcR6fcvj/j2cJz1+70zz6VmeIPgDqNmHm8LXUOpw9lDBZOv1x+ tepUw1PEx9rQfyPOp4qrhZKniFp3OE1qzvvD9wY9btri0fOAJlK5+h71QbUyuAxJ/wDrV5l3F2ke olzLmR79+xk0HizT/EOlvcWkZmsLxpkkmSOQqEj2FQzBm/5acKDz9RXm+q/2M16kdtc393JbOD5p SIfOOuGDNkdee49K3pyVXC1I9eZfkzlnH2eKjJbOL/NGjHrnn6PZappnnpNZThfOL/Oscp8yNsj0 kWTn/poK9c+Os73jXgZWZpdF07UOT98qGU/pivtcpw9LF5pgq04pqdJrXyi4tfgfC53OeHyzFU1v Tqp/JyUl+Z8xeD5RoXx30iZS8KTzNCkqY++lws4I7Z2sv51+jHjf9q3VPHf/AAV/8N/ETwufKu/C 1rpMN1JYDL6hAdPSG5Y7sAOUaQdwCBX57xHS5a1aa3dONvuj/kfpeQ1+SnBPZSf4N/5n5iQW3/CB ftYeJdPtDut9SNyCHBXygJPMHU8/dx+NegsvRiM8V+k+F+IVWnjFHVc6a8+ZP/I/OPEqlarh59XF /g1/mX9BvjpWsWtwpwYJFfp2B5rxfxv4cbwB8RNSsWKlLW5Lw7XB3RE7ozx0ypU4rt8S8Pz4OjVS +GVvvT/yOLw6r8uMrU+koX/8Ba/zP2R/Zs+KUXxk+B3hjxDayhzf2Mfn7T924T5JV/B1Nd1c/PGD wu0cY61z5VP22Dpv+6vyMM1p+wxtRf3n+ZCrLwU6jjirVoTyz49OPWqcPfsLn9y5ZjIbBPT371Zi wGJP8uCKuG9znqe6kmSMQigoD6VJA/BGT610NXRgpdj8LNB0L4dfa7eGe+/tS6uWCJHe3xbc5PA2 pnqfWvWfC3w2i0fUI00PStFtAIy6PHah3BAz1br+NfyhVxEaC2uz+lo07vVmZ4g+KNl4Pgl/4WP4 hksYZJDBDbwqU3FVBc4jX/aA5qk3j7wd4hWy/sLU7O7EiSRujyfNyMcg896xTr1veirL/gFzjCnK z3Mf4O6il/caVbxkE2F01udvcq+P5Cvo/W7TNrhV5A9fbmuHFQ5ajT7np4Zr2cWfNGk+K59L+N1t p/mFYGu0KqeiktjNfrlq4L+FrYuCyyQDJ/4Ca+uw9JOgmj5zEStPU+d/2XNbXT/2k/HmkFvmuLeC 6VOgGy4lVj/4+te8eGLHxRqPiGe18FarZ6bY2uoGS+jubbzXuYmKnapP3eN4z6nPauvDRs4t7WX+ RhWbXqejNp32fXGcIDHJAUzgZznI5z/SpI9UFm8cU2Q5z9/GOO+f/rV9RSpo8yUylqllZ+JgLTX4 Ir63LAmK6hVoiytkHBHUHGPpXL/ELw9a33jq0u711C/ZkRFkGQcM2VGT1OR0rOa5ZtxWtmjqwLSq xc3ZLX7k2l95+Sv7eX7QfivxZ+0T4kTUrTUNF0zRrr7FFpMjsFtkQbFY4O3c+Cxx69TivJT4zuJ4 bYK6SmX7zPOBtHvk183VquUnfc9FtztJs2LbV9PW/InvrZU2cyb8rnPTit/wJ490Pw1420y+e9Ey 286O6xxv84zyM4ralNQqRZlOL5GjnPFXj7TrbWLt7OEnfK5RrmQKuMn+Ec/rTorfXvEnw/uPEOiv ZrpVtc/YpDauiyJKULhSvLgEKcE4BwauU7t2fczirWbXY4uzhe90NZi5LRXYUrtycNwST9SPzr0j xh8GLeX4c2k7ybpLK1fyiiBBuJzliBz3rzaWH9vFu+x61JW1+RsfsIa0+jeJvEWjyyRus9rHdqyZ w3luFJH4SV67+0R5s/wk1C4tn2S2BW4RsA9DjofYmvJlF06/ozw8Tb62pW0djov+CfvjqbxF+zl4 +gvZt8ts0V0rL2Hy5IyOf9Wfzr64sb3S/wDhAonSe3hZoV2w7gCeOw6mvusDatSjL1/NnJjFyVHG 3b8j5C8ffBjSp/2q9D1T4qaa2oeGPEsb2tmZpSITfRncoKKRuG0HhgR164r6K+zWOiWcVpocMUNt AAscFogVEA4AGOBXkVcPOVaVl1/A6/bJU16fiZP7dfxCfw/8HNBv4o7aZrayhTe4Lx42xIHAQhtw xjPqD1r4tb4wzXiq1poGkSqgZhNLAYw47D942T+HXmsMHW5o81isXQ1tcivfissgiEnhrSCHYL8i 8ggDnhsc5Navxh+N58L/ABH1fTz4e0G5+yFEFzc6cZWYeUoyzZIrqdf372RyrDdHI5TVv2h2S3he 78MeFE+0KSjJpp3HDYI+U5U8DrXVeHv2h9TPwcvdXstG0fz9O1C3srcXaSBFieKZmIzIDkchcEY3 Nwc1M63O/hVynhrRtzO3/BOHuf2k7uyK7fCXgl1+8k76cpJPfGSelW/h9+0fdeKPiBodivhnwxbv d6jbRLc2unhHiLyqu8Edx1H0qHiFFOPIjRYRt/Gy78Rf2nNT8M/EHWbL+wPCU8dre3EaTSaejOyi RgCzc5b196wrz9qXVL7LR6F4bj5BxFYqucY7ril9Ys9YoawzsveZ9FfArxvq/j/wHZX8D2ttNPvL /Z4QCVVjGOpP9zr159q9DW31pofMlvJsEdQAMDvxiqpzlJaJHLWSpys9ThdaXUrbxvZpJe3EsE6S +bDIEYkbDjnGRyB0PWvIbr4JXNr448R3mh2Ks+rX88xnVWLsjNkL3wM5OPcda+94GySec5ipOKap Lm+ey/FnynFGcUsowVnLl9paP6v8EGlfs5a54UmvNal026n0+CF5b2H7NIVeFV3E5x8rDGQe3FZf xx+H134plkt/Buu3dgsK/wCkxzQBWMrKMoxVzjkNyCQc9ulfXZpw7mGUYl/V5xXtr2f8r/4KXyPm 8uzzA5svaVE3Gna6/m/4Z2PJrb9nXW41kMl3a3JyNhjcgn1zkf1rK1f4Ta/pmkuZ9IupJhJkPAfM zHg54UnvjHfrX5dmXB2aYNyqVKTnvdrX/gn6ZgeKMuxSUIVFHbR6GXJo9/Fe2011aXMU8UEchSWJ k2PEQozkf3UB/GvaP2U/j54j0v4j6hP4ajuJdVv/ACpJodKRU3xWqZMhJIYbIvObgnOMe4yyLGVs px9Kai1aUXbba+n42KzjL6Ga4WcZu65ZLurO2v4EX7ZvgqLw14r8MeKLWztorrWrmSaXUbOXCTNG 0e1DFjbGyKU+6Twyk9Rn6x+KHwp1T47/AAw+Flp4NMi6q2vww288cgQxvJH8p3EgDDqmCTjOMlRl h+uZZgpUaHEOHq2TcYTdttVKX6n5JnmLjVxvDmIpXtGpOGu+lofofKX/AAUv/aA0b43fGPT9M+Fc N1caH4JsG0VdamkDjX7lJpPN1TYETYZlMfDbn2om9mIzXzzo9zc6PfW8sUDM0LbsOCAfY/571+FY 73q03c/dKEeSnGPY+h/2Ov2Rtb/ac8S28WjaVdWumb8SXrAYfH3hHnrjnJJAX36V9Q/tA/taeDv+ CeXgF/A37L0VnqvjYxtFd61AA8GmMRhtjdWk9W6ntgYJ/ZuDcNS4QyapxBi1+9qpqmuvLtf1m9F/ dTZ+H8a1qvG2d0uG8K/3FFqVV9HJaqL8oqza/maR+afxB8Zap4/8VXur+NL24v8AUb19811csSzt j/PHQVj2V/LYSq9rI6Ef3TX4vmGPrZhiZ4iq7zk22ftmBwdLAYeGGoq0IpJI7TwZ8Y7nQp1XUMvG cAsvXFen6H8SbfXowbOVWGCcBgCePTI74ruwOM54+zm9TLE4ez5kSXr2moSCSSLyZV/5eI8o45zn K4P55rQ8P/EjxX4JnU+F9Za6iXB+y3z5J78HH8xXp08VPCtSov1XQ5KuHhiFy1Ud/oH7aPlW6WHx W0PfCcB5nXzV/Pn9a6aysfh18WITN4X1NNKnkIwkTjare6H+mK+io4vDZqrP3ah4VTDYjLZXj70D tv2Yfg9qngP446bdJc2moaZcQ3EElxbtggNGSMr7sB0Jryf4iXKeGfiLqUBCxQpNKsanjCRSNDn/ AMhE16FLCulgsQp7xcX8r2/U5J4lVMZQcdmmmvOzf6E/w8uW1C0TTZGMa6lbeQgY42SEBos+mJFT 9a+h/Em7xL4B8E6kFRLfUtBmtjJIdrSSQqqugJ4O1l6e59a9rhyvyPA1ne0Jzjtd2lG60+8+e4po c9LHUU7c8IS7aqTT/Q+QvErS6PrdheXsjZ03VEcFeTiRSpHr/wAsVGPevqb9j/xJaT/Hptb8Vanb WkH2Zibu7mWNWKxnABYj0xXyvFlCdLFxhFfZa/8AAZSR9fw9VjWwvO31T++MWfKmr30Gt/tba9dR yJNG0Fw0MisCHy6jIx14J6V32/zFXjCsewr7HwzhPD1cXSmrO6dnp/W58h4j2nDC1Fro19//AAxL GMqCCVI7ivMvj/aLH8QIro7s6jZwSlgeCyAxHp/1zzX03iBT58nm/wCVxf4nzXAlTkzaK7xkv1/Q /RD/AIJM+N4Ne/Zfk02P5ZvD+ozRMMnJSTEisc+5YfhX1KZMwfT/AAr5fh6pfAQt0v8Ame1xHTtm FRd/8iKCXdFtUdO/TFLHIUO2Q4Hp6V6UtHzHlx1TiXLSQhSckt057VakuRtDDnoODVU9zKqtEH2o sQXP4flTxMWb5Dlen4V0R1V2jlk1e1z+bvwtcro3ijTbqYsq29zHIxAyQAwJr6A+KH7bl7/bsEXw ihjtrWzwv266iDPccYxtPCr+v0r+WZ0oz5HJbXP6VfM3oed/EmW/8e2r6lrrGSddzMm3CR7iWYKP qf09q5mHSYdE09ZbsAMSP3WAMf1rxKOLlJckH1P1Stw9RwUlVqR91QUnf8fxPdP2bNJXT5LJoZ1n juLlZgecrkj5ee/FfV+pRqbQ84461pivek29z4Om4xj7u2p8W+NbyGw/aws4tAkYxyalbZBzgMWX co9s5r9qrRPtngSybJwbYHPUg49a+ywKvhrdv8j5nGaVb33Pjz4a6x/wjX/BRSa1clV1TSL6Hr95 keOUfj8pr65+Hmo/YPiNqkLEYmjilA9TjFb4SP7uN+z/APSmY15ar5fkjstb1JfPtNkqo3mbGz3J H19qgsWa7ZkuHO6Jyw7ZB5z2H86+pp/meVIu3MjRRlzgEetedDxLoPxwhhvvCWoPJb6BcyW1xPNE 8Sh8KSvzYzgc56c1Mp+xlzrfX8VY1w9OFepGFR+7dX+Tvb5nyb/wVA/Ze8CeKvC0/ii18TabbeNI bcLHYX13Gz6jFnokX3jIAcK2COx9R+d/gH4W6vq3j288O31hOb61GXgiGXjAYAnAByOR+dfO5hha sKkaijZT27fI9alWpvmgvs9L3a9T1H42+GvAumfDa7s/BWj6tpnijQLi2/tKScSunlvDzudvlQtI cBep2ntXz3e6veRR2zToscVxuaMhtzMoYqScHI5U9f61xYyHsWlGVy8PL2ibkjf8T+IIkWzeLTrI q8Kb/lZd7dydpFbem+KrxI7mx0y5j0/SPJhuX0q2jCR3UvmLCpYDlnUTMQTk43DvWEHZto1ktEjL 0q5W10nXoHJ3RNHIigZztfJ+nSvYfEP7TUOpfBuHT9I0xvNltTaS3Fw+edoBYAcdqVGPPzJs7acV KO5Q/YV8CXviXxnrOv2V9bxQaFYbLixkDGS5Wdwg2Y4AVlBOfb8PpXxR4Rj1/wCFOvyTyl2gAge2 A4YMp5yD6rjgVwYijJVIyfXX+vuPBqxVXEcvaLf3Jv8AQ7DwZ4M0L4EfFbwToGiWv/Em8YadcWpV 3Z4p5oYhMhwSeNpfgk9e9e4X1j4f8K2hm1c2Fpbx/wDLe/lAVPoXPFfb5fSVGHJ0T/NXODFzdWXN 3PAv2wfiZpfiWy8FT/DW8h1K98N+I7XUnS04jFqqSLLiQ4Q5DjoeahP7Y3hnWPH2n6Fp0UEL6lcx WyR3F8DIpZscRJuGckYy2Kua9+cnorLV6d/+AKMG4RXXU6j42N5/gTR9N1e2GqpcQoTbyytH5QLK QQwBPUdPrXkup/AHRtRiVj4c01Uwf9ZcTsRz14Za+Ty3+Fblvq/zPWzWap1mk7bfkind/A3S7a1V U0PSgkUglVP3xwQMZ5c10Gs/CyDxVrupXl5pWlPPMcNMFk3OwUBWb5uenPT6ivUlLkkv3Z5alKcW +coRfAG1jwJdE8NyuAG8x7WT73c48z0qSL4aWdto8+kpomgPBdXccrW0loWTeqEBgC3UAkfiaupL S/s195MJS25/wLrfAHT1tkil0Lwp5IwwVtLQgH1GTx1/lUUXwc03SNWs5LHSPDcE8dxG0ctrpkcb xvvGGDDnjrUKd7v2S+8pSle3tGO074d6T4q1e7eK28GXVx5ztIv2G3klLbud5JLFs9c8k1dvvgda 29oTLovhldoyNulQpyB6qB71nGfamivetrNjfC1nf+HNNhg0JrS2Qs+fs8C4CiRgAozgDcXJ9Sa6 Exa06Ms+qOzDByu0DGOxFOKnzO0VuZ1JJJXZzkmjXc/i4y317LO0VqwCyIpJJYLjO3/aNeP/ABA/ aq8W+GtSvrW01LUYLPTpnt41S8ZR5aMVAUAcDiv0LgPN/wCx61erUhze6vzPlOJ8ojnFOlTUra/8 A5fTP2gdX+IlndyeNPEmqWNnFFJKsN3dvKlzInKRcLnlsHnj5ea4XSNZvPGfiTUF8EXFzGqoWknu JDiWQnPB5Izg+uPxr1874pqZrWpRoR5Zya5V5Pr8jLK+HqGU0ZuesIp83rfb5m74K8ZX+h3rWPj6 RLWfd+780ZWRDxkPnHX1rstP8U2uq6ibTTZPtdwrbTHbKWJ+mBzX0OS54qWGUcwmlOOjb0v8u54W c5G51nPAxbhLVW6GvPp00IYahbTw7clvOiIwB1zkcYrpvgTZab4T8VWXiHw5HYxXsc+I7m2ROmDv yR1yCQQff1r6R4HLc0cXOEZtptO2unZni4WtmGAm4qcoqNrrprtdeZ9L/tg/sxaP8dvgXqmlaVpk lvZ2EB8VeEEsBtKxSW4kl0+N2B3+TJIYG6jeijqleb2nivUR+xPdy+CLuGx1F4Tpp1QxeZJaxXMR gnMRyMM8LyRFhn5JXA68b0MshiaGJUNJ1qHI3/eheN//ACbX0PmMfjpYLF4dVNY4fFKaX92pZ2/D 8T4k1n9mbXHldtO1LTrgMT98vGx/QjP4163+xx/wTX1z4weJjffEtUsvD2n5lmZ5QI5EXq7yfwp9 OSeBX47g/DDMamY06WJt7C95zT2itX53ey82fsebeJeX4TLateg261rQg1q5PRL0vq/JM9U/bO/b TtvgR4Jk+HP7JdlcafZsn2TUPFq2zReeAMGKA4AC4xwPXnJ4X4Evr2e/upJr6SSWWRizySEszMTy Se5rHxMzmWMxscDRi40aKsl026eSVl63fUXhhkSy7L3ja8uavXfNJ9de/q7v0aXQhkQSLiZEf/eA OKp3Gh29wx2oYyf7n+Fflul7s/UbFC68PSQZNufNHoODXbfBfwB9uc6nqoLQIWjSHJB3jqT+daYe m5VYpGdafJB3Os+Js8HhPw0boTSpLKfLggU/6w98+wFecWnxAnYPJLKw2Y+XfknJ7Cu/FVHRlGKf Q56EVON2XoviV58SRTSbggwA/bvipY9ctpJ1kty0Emc+ZbOVas/rHM7p2ZfsraH0H/wT/wDi54gu P2lvC+i32rTXelXT3XmW8x+b5bWVxg/7yj9a6/4/fFPQPAfjjUbL4maOmoabqGpXqxXCqPMhKSBm GRggEy9j2r9J4ex6r5XjKmJ1UFFf+Tx/zPhc7wnssywsKGjk5P8A8ll/kZ2iy+E/Fxjn+G2vhHUB hY3TjIPYA9R29a+lNH1GLXv2X9LkldVn8OeKmmEanA+z3kZMiqB/CJ1cce1exw+1TcZU5Xj7SnJe jbi//SkeRxEpVYSjUjaTp1E/uUl/6Sz5J+Mls+jeKfEFvHzPaEXcIYA/MkqyD+b1i+G7+W+1DRrV 5Ej823uJAZpVQpGFCrkscZyD9TXvYqnToZx9Zr/DTdVv5yjb/wBL0McmlOtlMKUN5Qp29VD/AO1M XRNFns/i2t+LcxWlpDJH5hOQ7Hjg55PP6V6zp8vn2MbqCQUBGPy/pWvDOLpV87xc6T92SVvlZHLx nRkstw/NunZ/O5bjyUG3t29K4z48aU1x4c0zUUKD7DO9vJkgEq4DKPplX/OvpeL8O6+T4iK6Rv8A dr+h8hwpXVDNsO31dvvTX6nu/wDwR8+JNzpvxX13w6pQ6fqun/aXVyeJYXABX6iRs/Sv0WjuREu1 yeuFNfm3CkufCuPaTPt+Loqni+bvFf5Do7kMHYA7efSlS4WaMNktkggj0r6SSv7p81H+YsWt2VBA Gc88GporpWAwDj+RpRjpYmb1uSi5BTOc9OaGuwozx/Wu2MbI8+T94/nLh0K8GlJqEttMtm7lI7hk IR2HUA9Dir3g2zTUfEcMdwoMSBpH3dMAf44r+UcVP2dGclukz+sMjw6xmY4ejJXTlG/pfX8D0k+B /EPjG4isvBVsl1NIAUidgOScdzyelcn478Fa98CvH9la/EeAR6kAk7RSlJVVH9ACV7GvHyeNFtO/ vM+78QsxxEMQ8G1yxSXzXT5fqfRPw8jmmu9Hmu0KmV0ZSzZ3KcYx6D2r6G1NdtqODwMcY9K3xMea bPz+i/cifEHxOnFt+1Rp7H+HUICR/wBta/bTwpG138PbJyDgWKHJ/wB0Gvs8rhzYey7/AKHz+YtR mmfBfjjWf+EY/wCCkHgyVjtS5vLqzcf9dLdVH6kV9taHKU+JdlIQR9ptCvHcqen6iuvBxvTgv8S/ Fs5cS9b+h0/h74WWGieONR19J9Qmu9T27obmYvDCBjGxDwp6dK6S58l5FEgLlezdBXquvJRS7HE4 qWpArLGCsKYHAAAqGaxhaNopIlZDztAwM9K5m3N8zLjJ02rHKat8A/B2veM08Qa74d0y81aOJIo7 q7hEmxVJIwrZUEZ64z71+av/AAUG8H6x+zB+1pda/wDDG78zUtVhlvWS3hLlbS4lwsbrj5iJAwGM /LtzTx2KqTpwcndU7WXkGEpRVST/AJr3+Z81/Ef9pzX/AIhWuqx+KbhFXXJYXvljtlj894eIycDI 215r4w8O3WgX0jXk8FxGkzIklpIskfqdrLwRz1HFeBi5+399dD2aEVR903rrX1j+Hf2cWFnPJd7A NQmVjNbCNmJWM5wA24ZyD90YxzU/gie0fxFoc2qp5sb74dmAcSFCqN+DFT+FY02np/W5rNNGjoVi p+JN7p8wKrqETR8epFVPC3man4eksVjk3Ruw3BDtXtyeg5qqDUJyT8zqo6p/I9D/AGXNH1z4ReOb 5NcL2Q1a2S2ks/NUu8ZkSX5gM4Hye3p619Ff2/MtpdWcMjiG6wJI05EmOmQOuDXm4mc7xT6HgY+T p1VKHVfpZnzZqP7RXjnQvG0Flrt7qurweHrmc6S0zSF7QldmY5B8wGzAxngGunPijxv4nSOS6SS1 MoDGYxMznPXLtk55r36eYzpw1jeXn/kbzwsZ2u7LyOE+Kdvq2nxPD4r1G8VrqJmijndwGwfTt1qh +yd4VOoftIeD1eaCTbqsUnlq/wAzFW3AD8q5qrrYmUZTlc6qXJQjKKXRn6XfH7R7Lw5daVa2kqu8 QMcjZxko7LuA6gEKDz3P0rlDqMLkRkttI4UKTmtspSjR18zys5m54h/Iqa+6LahYN+9yvO0jvVzS ItkEzokpLYIAQ8A9D+IrsqWdSNuxxxTVNi+RMEwsdwev8BrPjUi+jYRvnzyCu07sBQM47DLAVeIb ULIzoXT1NS/vJEAMgUL/ALUiLx+Jrn9VvXutQtlgltkCzKzObiJsbSOwbP8A+qtIq0W7GXN76XmT aV4Tsb2wb7clu6PI53vJGVb5s8nP86NR8GxafGJdPka3ibHMF0EVTgYyA2K8+FCb1idsq6jozMiu dQ8NJYrod9bES+dJP9pjjlGN5Cg5Gc4BPB781fh+JMlvp8kt6uiXAgUbxHvQuxPGAoOeD+nWtIqo pPS4pqnZXMu08eW17qN5NfwS2tstuznbGQCAVIC7vm+9gdDxzXyf438HeJPHOrKml6PqVxLfThV2 W77Wd2wOcYHJHJr6/h7D1cRh8VVpQbaSWi73PGx+Io0K1CNSaSu3qz0TQP8Agmv4nv7FP+Ep1a3t WBAFpZxNNtzjOSSo7nkZ6V9CfBP9iPTfg74dltoZZL26vd8U804xneoBI9B7e3Wv0HhfgKthcTHH 5hJNpaR7aafcfM5/xZSr4eWEwa0b1fcXRP2AfC11qFvqfiSzbUL3GWNzIfKzxwUXAbHT5ga9O0n4 J6X4XsUi0q0t4I0+VIUjCImOwAxgcZr7vAcLYLCzqV3HmlJ3u9bX7dj5XFZ/i60Y0E+VJWVtL+pz njbSLBr+ytWAW3W5AkVOAz+W7Krewwpx6kelYieD9MvtbS4nhiW0tGLhQOGcc449+fyr6SjgqS95 RX3ff+R5ksVUUbOT/r/hz6N+FXiK68RfB/SdP1q3uLW50bUmn0/VZCpf+zirkWqKwO2Npri5kPqX BHQGvKPj38Hv+EH+HnjTSPDKSSW98yatYwRKCdrSh2RQPRtwA64HSufBZZLByrNu6m5yXkmlp992 fC8Q55RxuKpqkrcns4y83GT1+SdjzT9mv9lG58ao2v8AxNcaVoFkQ8rXIxxnhcdWdsYCDk98V9TW fhPX77xPaeH9A8HpL4Rt12nR1uUEtw+wsZpmVgGZR/BnC88ZGT8jxrnc8gymcKOteonZfl92/wBx 9dwrlC4mztSqf7vRe/Rvq/8A21f9vHc/F/8AYym+M/wWj8M/DXwjYaBeTzrNLqEtoZ5gUORHGys2 0scA89M18Pft4/8ABPK8/ZB1Hw+fG8Nlq2meJYZZLWe7tEjlSaLZ50ciZYKQZEwQeQfY4/MPD/GU 8yovK83o80pyk05O9lyrS+/Rn6txhha2X1FmOW1eVRUU0la+r1tt1Ra/Yz/4JAaF+1bJbXPiG0ks ba7XzVTT5Wi2xZxvY89eoAHTvX2l4V/4N4f2e/B0SP4pS81GVQ24z3c2PXBBcLx9K8DPspy6GPqU 8FBxhBtb3u1vbyue9lGZ4+eDpyxU05yV9Fayex3TfsB/sjfB3RJLbxZpfgW0spXVpU1meziR3QcE 7+4BJ/E+tcRYfsrfsU/HS41DQvCWn+DtNnjuCkE/hbW4YZLgsoHmoIXwwzkAEEZGcVwQwFKLSjC7 OqWLrWbcrI5DR/8Ag3v+Dtt8Yb7U/iVquv8AjXwZdaf9ktNHmfybjRmZvmuBJBt844HGFBXOSr8Y /Jj/AIKdfsP+Fv2K/wBrXW/BHwh8ZxeMNCt4oLu2vkUGa1SZN6207L8jSIpXLJwQynCnKr5eZ4GK puqnqvy2R6mXYuVSfs5bW/4c+eZPCjrkpIh/3wQaSLw3NEcrcohHpk187blZ7dj27/gnzaXVj+1j 4VmaeJkhN0S2DwDaypn/AMersP26rZLryLzT7mK7LajdO8ceP3ZlO455/wBkD8K9vLOIv7PoYjL5 U3JVo7rpqnr9x8jnNPmzXBtbxf5qS/U+cIp3tpQ8HnW7g8SISMGvsn9iX4l3vij9n7xPoetSmZ7d jcRXEzZaQQkShcnuMngetepwpjalLFOClpa9vOMoy/Q7OI8HGth78uqf5px/U5X9pZTZfHTTJwT5 Wv6a8WOo3svX8mr5ytry40i6F5au3m20hyWJ6Z6fTtX6J4gRnKpiVF/C1L/ySm/0Z8fwBZ4Kg3/L y/dOaO/0nx5HqtqstrIQx5ZWPQ4HBr1X4dagdR8J20jvuI3rz7Of6Vy+HeLU8xsvtQf5p/oXx7h2 suT7TX5Nfqb8TFeQTx26Vj/E/Tzq3w91JQpLQKt0FHqjfMf++C9fsuaYd4rA16Ud5Qkvm0z8kyuv HD46hUltGcX8k0Z/7DvxCPw2/aP8K6goUQy3iWcu47f3c48piT7bwfwr9eP7RVpNqn7wwSDX4vwX UvGrT7Wf3/8ADH6nxrTUJ0qne6+7/hx8U2HxljxnB704Mwx6ew619ko8zsfFOSgrkiybh8pGV6nP arNs7KBuOMEHnjNNU25aEOoox1JPOyQG5I9aPM3t82D3zn2rrhC5wynY/KHxv4b0vxL8HZLT4aQ6 ZLp0sMgs2jw/kEk4A9Gx3615R8E/2Z7nXdHt9Te7jSW+EiiKQYwqPyR3I4H51/JGaQlTw9ZtfCf1 vw7jYYLH4fEVFdXv+B9AfDr4Q6b8KLZ/EXja/OLVS0IAwPTIUfMzHoB7180ftGx69+0L8VbjWxYv p2nIqW9qL91jcxL0ZgTnJJJ6dxXnZHhJyacVsvxZ6PGGf/23jpYmWi0SXkjvvgJp8+nJZw6ndx3U sMyJmJy2AMYHIr6b1OcfYck4yvevRxNHlqST7nhYedqaZ8OfFe8aL9pa3aOFpMX0Az6fvBX7dfC1 3vPhHpsin5XsIuD1/wBWtfYZKubDu3T/ACPns092SufnH+23rY8Iftg+DNTT5Gstfgdnzxt/c5/r X33BdGHxNoFxGRgO0RYe44/lXVgIXgm/5pfkjmxUtvRfmz09ZwwyGP8AjUJmWVMODn0JrsnSe5yQ noU5tZg045uZVjH95mxWPrnxb0bw5byy6pfQJGil3dmACqoyTk8dqxdqa1NI3nseC3n/AAUbs/iN 8XLfwH+zdo914p1a5DmbWYyv2LT4lIDTnnEiqSB95QWIAbmqn7Y9t4i+E/7LPijXbGG1j1G1EVw2 rNOXvpZ3kWIuXVcAhXIAUgAcAAYFc1So6kbx6G0aahJKXU/Nrw/4D0vV/B9nrjaXePZWmvWGn6pp F5ulkuElYO7JIAGTeQVCKM4HU16z/wAFhfgzpvwz+I2if8K90pLLTL3S4JGgtlO1DEXjz7YGwflX myw6jRlJ76Hoe1aqxiuv+R8nNrNrqfhmxsNOtSt3ApVlgLyvcOWJ3Y/hwCFwB29a9s/ZL/4J2fEL 4w+ONN1LxZouseGPCtqwupNU1WE28kyD5lSCOQZYvwA20qASeeh5aNJ1ZqMTarVVKLk9ziviDZHw l8XreaQtCsUjROeVK4ODXNeLvjL4msNWurHQNVltLCCV44hZKkZKZ+XLKMk475pVpuhOVt9jSnH2 kY3Oj+GHjbV9W1HR7K5uJJpLp2Ju7p2YjkkknqenrXqXxP8AjPceHWlsPD0u122rLeRgh+nKL6Zy M9+3rV0V7avGU1dR1/r5nBiaScopeZjeDviZf3OiXjy2kd9c2txDHE0xztaTKrlh15x69aj+G178 W/2pfET6R8F9A1HVHldUc2EJMVqM8GaY4jiXI6sVzXVjY+1mmlq/00Oik+RavY+0Phv/AMEQJ/D+ l23iL9qvxzc3t1BEJl0Lw4EWOF8g4kuJFbeuNwKqg65Dcc9Gn7O/gj4Y6ddTfCHw9pul6oU8uHVp lMtxHyMkStlhnHO3H0reNLko2ktbnK6rqVNDzj42/E4aDqUmrfEu+0+FLa0aJbS08x3mJcN5hIIO 4kYx0681q6d8K7u7+Fia540ubHRNYvUhuLHR7yaWSVIJmUI80asCpCuHKBt2FI47e5wvlP1qfsZ6 JtJN9XJ2S/P7jwuJcX7CDxEXdq7a7KKu3+X3nJ6v8LPinZmOSPRLKeyOGS7srSe4imTruSRZCP8A A9c1nX2jfE+Zgr6HZhFARFOmXQYADjnzOePav0qPhnUqNVFWVj89fH+GgnTlCVyM+EviMR+88NWj sQ2WOnXXQjA/j7YzT4PCPxCtoXVtKsYHckAvZMqrkD+Fm6j1/PPGOqPhfKqrSrduhyy8RcLQd1TZ Ivg7xoEAuLXQlboWaGLPoSdz1DH8OvErTh7q60KMZz5aRQDt0yAT+Rr0Y+F9OzXtn9x58vEijFpq n+JfbQvFro0Unim0gjbDERxJhjj2jP0pJvCeuz2yRz+K7ZVQ7h5dtzn/AL9YNaUfCekkk6sreiOO v4p09Wqav6kGofDibV7e3j1nxbd7bV2kRbaHb8xxySMZ6DjpWxpnhS2t9PFvfeLNUeMfL5YtIzhR 0GTIOK1p+EmGUvjk7+hz1vFiUo6U46ep0Wg6Z4J02+iuNfu9TvWg5EZuPJTIxztDkHp6V2nhzx94 K1rxFpum+HNPijvrm6QxO1yH2mM+aTtC88I3f+VfqHDvDOC4TwdaFBK8ld31baTPyfPeJMx4vzLD SqXUYySSirKzkr3PT5TBZyiORxuGcYGSpJ+hqvqLu0SsVOxDk7yBz6gc/wCTXjzcpJpbH6rFxTvJ akOleIQhv7Z1JlgkZlOMZRx5gwfYsRn2NU9e14WKyS3TLtgBZj7AZ5/xr0aFnFHNVi4Ns8j8Z+JD a6fpEt+T51zqEjFV+8GaCZ9vOOgH5CtT9lIWHxE8b6odYvI5zpqpIunOwO/c2N+O6rjB7ZYZq5Vo wnCPcyzL2lHLq9anvFP5efyPpAyqRshZV27e3Tnpj9K2G8OWF5Clt4ljiT7bAAs8qhmjK5cHPYHJ B9AfWrx1Z0oXjv0PynKsLHE1LVNU9/mz5/8AjZ4X8Z/FvXtKh8DXOmaZ4W0a5jddGaXyCGDI4kBY jzGIIO5hz2xxj6E+Enxvm8FeIY7nWNOdxHJJu+x3UEpOQRjG8etflvFOQ47OMS6sWmrbf0u/4WP2 fg3iTLcjwccPKMk76tJa2263219bn0R4Y/b58OQWdrFPpGuQyxyJIxS1aTABB/gzXzV/wVV8Z2H7 b3hPw5p/hrTrqCTTb2adb+eGa1e0iaMKyEFCGDnacg5HlgY5r4mlkWbZZjYV6NBtx7arb/gn6DLi fJswwsqdWuoqXe66/wCaN7/gn54u0/8AZ18CNpPjbUrOO6gt4raGfc7eYiKFGWKr83HNfnL8fviR +0Lq/wAYvE934gm8UeIdMutUunt4YFkngNuZm2CIL9xNgAC44FRQ4ezGMpTr0HzNt7b6t2+ex2Uu JMpr+5TxEbWSWv8AWxzawWWv31n/AMJb8Lte024mtfN1O813TrhoZ7lZSxCFIvM2MnljDHOQ43YI rofBHwx8LfFL4iw6Gljq2nST+ZJF9h0qS2isFVS6r5sh3bQPlGTnIXrnj6jFZPhc0y2pnGH/ANmn STjGnyycptWbbv0adr+RhSzF4fExwMpqtF6ufNFKO9klu3p+J+o37KnxjPwq8Lxad4he+vo4kVIj LJuKYA7sfSvl/wD4K0fAnQfipq9n43+BWl2Eut3LlNb0OfTPO+15X5LpcYIYYKtgnOVOOCT8ZkMY 4fERVaKcZaNSWnz+Z35tzVqLdOTTWqcXZnwNqfwesLm5eDxN4Q0SGRDiRLW4ms5s9/lYHbXMa9+z x4ZuZ2NrpviPS1HQW9xFdrn8ga+mzLgjKswfNKm6T7w1izw8v4rzDCe7Coqq7T0kjqP2WfhLpfw+ +Jt7rdtqlxPDp+nzgw3dsYpLdmKjcTnB+Xf6Vy/iaG0vfh3bwa5YWmq3F3czzPPaXMkEocMHbDEs mcSddmOvFeHgeA4ZdVxMqE1UUqU46rX3krej31PRxHEH1+tRrVocs1KG2qXK5My/gz+zvZfFvxqI I7HV9H0+z2SXUmqXcU6Mmfuq6RpycH6etfWOh+AfC/gzQX0nwja3Nui5CxQlSvTngg5znqTX5TVw 08FX5NYyjvfdM/ovhLLaOOwjxdZKcZXS7NdTyj9rC2sB8LdF1LR9OLat4d1G3Q367y0UBVgd6kkK C2wdwcDp0r5U8b2I0zXdQtYWRlLyeWR0IySuf0r9By3NcTn8cVPGu791f9uuPL+h+S4zhyHCmL+q 0FanzScPRtS/Btr5HK2evzaV8ky7Fz1A4r6E/Zf10614Gut8m4wXrqB1wpjQ4/PNcHhviHDO6VN9 VJfg3+hwceUebKKkuzi/xSPTYsM3zA/j0qeO1jvUaC6H7u4Vonxx8jgq36E1/TSXMrH891PI8C09 brwxr0sDHyrqwnZdy9VkRu30Ir9k/hP4zHj/AOGHh/XiUMmq2Fvcv5fIDMgLD2wSR1r8C4cpvC5p Ww3Rcy/8BkftfFk41suo4i3b/wAmR1kU5kA3c4qykmOoP41+hRp3ufmk6r0uCSbWDKOwOPUVOtyV wMZA9f8AP0q1CyMZSu7sX7XnIHf1pvnhs4OGHt1FVYzbsfjL4e/aHsPhF4Og0bQL2BLaFfmW1t1Y zvjl2JDZJ+uK5XWf2qmu75Z9Pgu5p0XZHJI+xUX0A6AfQV/MeJ+rTT9r7190j+m4QrfZ92xj3Xx+ 8VeL7xIowWBI++5YhfbJwPyrO8YT6t4i1k2sV3fLLKNwtA4IRfcrjp9K5JYqp8NKNom3sqcNW7s9 R/Zw0iXRYYRcSFv9IXD4I9PU5PNfVOsXoTTfmOflrz6kW5O52Ka5UfDfx91uSx+PcZt2ChbmN8gd Pnr9t/gFqDX3wA0eRG3N9igBH1jFfZ5Ar4afqvyPnc4d5xfe5+a//BVmF9M+JtteRHm2u4pcg9Pk GP8A0GvqXwB+1VY/EDwpoV/4NsdX1TY0J3x2skYkcKAwDOACNzEZ6EjitMDKMVKLe0r/AH2MsRFy jB9Gj36x8W+LNdiQxaPa6UHI/wCP2cO4Hr8vT8qvQ+EdW1Mbtf8AEEiIQD5enxbP1P8A8TXbPnqO 0djki1Fak0Hw00iI7rw3d9IerXNw+G7cquFP5eteSft2/sza38dPgmdD+Bt3b6FfJP5ssETm1ivo 9pXypWQZZRnOGyD3rCrQ5YNx3NYVPeV9j5l/ZV8L6X/wT5+MrR/F/XNKhk1LTs6nq5dRFHMwVxCh wDsBVgB/ERnHQV6R+1f+3z8Mfi18HdZ8JeHL7Vb86xB5cV9ZxR28cciuGRw1wybhuUfdBzUx9nQw 655JPX1v6GklOtWbgrq/4Hxd4T+CN54NuLHU9d17ZeyXtveMgL3M106SboVihCq27I5+Zs54xivS fH3xB8e/FT4uaXN8b7DWIdJ1Gxv9GtJdatI7R5DPEeBCFVlG5RjcM8da8+NKaws5NO8rNeltX6Hd KpCdeEV9m6+fb1PSv+CRGn+HvAnh3xdZ+I10e31iLW1htri8ES3L5jC7I2b5iMg8A9WNfa15cKy7 VB57Z6V6OEpRp04pHm4ublUZ+P37c3g//hHvjPr0Gxkjj1Cbap/usxYV42vhS61q8kj0mzmuXwr7 LdC2B0ycdK+ax0OWs0j38FK9KN/I9m+GfhV9D0fTdK0WOK78QXsogh8oDKyStgRhu3bJ+vvX014u /Ze8Ja58HLDw/wCCdMfxB463i1S4s8xyy3ZIaeWUngQoCSS33RtUkE17eU4aFSFWdVbK33I8jF1Z ualS25vz/pnf/AL/AIJlaL8MNOfWP2gNRfVHiEcreHdKPl2iGNg6B3wJJn3gYwUU5wQ3Wvsz4cQ6 L4I+H9tY/DrSNO0LSUcywWWlwJDGRj/WEIMZbGc85GDmphByknLoXOfuuxhfHP4vMfCcdnfSKiE7 nk5yV7KO5JPQDOa+bPFXjC61ZXFrG1rbnBV5P9YyjuR0XPpyfXB4HZCh9YqxprY5p1lRpuofMXiH wrL+0Z+0To/gzQQDbfaFlvpQMrHEDklj74JP0r65+IXxh0f4P+G9R1H4iSwnw7p3lQwy6hGhDP5w 8qMZyTkb+B2GTwtfsnDnC1DMMFPF4ifs40Zwknsv3a6+V5O/ofj3FXFlXLMfRwFCHtJ14Sjy7t87 6edor7zx/Q/2w73xzps998J7qSDR4ppIjJZSrbW6OBvbG4jHXPpzXjXiP/gqxc208kVveeI53jYp 8s+FJBxwd3P1r63H8VcM5TFVZ1Odvqr6+emh8rgOEeKM1k6bSpxXR2ul27mFrf8AwUI1LUPDkeqN aXdwsrMmy4uiWVskc/hj8xXJaj/wUA1ZwTY6TDg5IMk5OR19K+TxfjZgMJeODwzl6u36H1+B8DcT jYurjMX9yMC//b88UyyAWljYR57sXY/zFZtx+3D43unYQvYxf7sRJx+Jrw63jrjGv3WFivVtnp0v BHLE/wB5Wm/uKUn7XXj7UJQlpforsQAkUC5Yk9BXeeE/iF4ymtVm8Y6zO00gBTT4lVMDHVyBkCuz I/FDPM+xHKowhTjrJpP5JXe7IzPwuyDJ6N+WUpva7/F6bIzvH3xD8QW9xZ2Wmavei4mO5ykhG1Sc AD8c+/FaZ8RX4t0Se/vJWUAM7TNlzjGetenheL81x2YYmi6vuU1FK3dq7+7Ywq8H5RhMJQqRoLnn du/ZO3/BOD+KniW8huLRILu5XcHLYkYbhwBn9a+gP+CWniWTVfE2swXwklazngnad8EojqybVYnK 5KnP4dO/xOM4jzGvxHSwzxEvZ+0pq13az5br5n12HyLL8PktSrChFS5Ju9le+p+hcF3Hd2yAqpKE AEADAB5/Q03V2DRBThoguMYzj0P+fWv6DSvoj8dvZtnEa/q1p4c8T20l1I0P22Bo8kjYXjYED6/O x+grB+IusG5mtLFm2m+fdL2xEnLZ+pwv0JranL2cVTRq480lJ+v3HzV+1Z8fk0W9tdE8KwQ6nqcU xlaNmI8kuhVA235gWQtnBHy98EiuU/Z40rx5b/FrTtb+Hcu7xCpVFtwrLZiJm+eKRR1jIzkfePXO 4Zr4rM8fic0zP6pg46UZLXvLe3oup9hh8FhMvyedbHv3akZXv0i1a/q1sfpFb6u2mb7aaFkvEKmW 4WUEIxUEoox1DZGSc+wxXMfE7xY7iG0sPPgMQJkzLk7m9/pzzk8197UUqs0520/yP5whUhhqU402 9X+v+Wxm6H4sRY0hn+WVf+WrN8rZA5PuccnPPtWyl3ubLHgdcDr71xVqXIdeGxPtPUaXMY6kZ59j TP7RZ2Plk/Kf4ff2pQgXUqPRXH/2pNFkRyunToxGTjrTF1y5QAiafK843nIPr1rWOnQ55yb6kT65 Osg23EoPQcmmPrdwJP8AWH5SThlB9R3rXkjJWa0Mfa1INOMtSL+37iN8rMw4IBBGTmmnxTewkmK5 mU9MiRuf1rL+zcHU+KjH7kbLOcwo/DiJaf3n/mc542sbPxmq/wDCV2sOohOVku13sp9ieQOe1cbq Pwj8MXAP/EqijI5/dO64/I11UcBhqMOWELIT4hzKUuaVW/yRiXXwk0GCyvreyt5Io9QiMMwWVyzp gjAyTjgmvOtV/Za8MQqI7MX8caMz+QJAUywAJxjvtHftXl1eHsHKo6yun+Gu/wCSPp8Dx1mVOCpN Rav2d9Pn5l/4eeCLf4Qy2j6NNcSWtlIJZbWZI2a6QfeR2K5ORx1r3jV4tLsIXkeCP7LtDQygBldS N2Qc9xgiv5z8RuGpcPV6eIVVzVVvdbWtv3un+B/dHgPxvDjDA18JUoKm8OovR7qTld+Wq/E8g+JH hq2128uxpkEc2m3sLRzRRNwUYEOuPTuPrXxf+0d8MNR+GHjVF1OKX7HeRK1rduhCzBQEb/gQwMjt kV87kGNjRlKF/iS/D/hz1OPctnVtXitKbf3S/wAml955ZcSgORKMj/aFezfsgTrEuuwRZVS1vIEP /bQMR/47XRwZL2HEtFv+aS+9SR+YcXw9rkde29ov7mme3weg49/pViPg4Ar+poux/OFVXPIfjVZ/ 2X8SriQLtGoJHcq3qWADf+PBq/Qr/gmJ46bxh+zXFp8z5l0C9ntOSSSjYlUn/vth/wAB9q/C7LB8 T1ab6yl+KufsOJbxnDVKV72jH8PdPo2B+qvjrj0NTLOUGFO6vvoI/N6j01Hb8MAAQQSOR0/z6VL9 pzjbxgEnsfyrZQucrm7jHnHVSuewP60NcAjIwT6Y4quUlysfiPr3gm9+K2q2UVrpEOhQSvsgEw/e BP70h6D6e9d344/YQ1D4MeELbWb2+ttet5UzcR2sBCwsegBzyPfAr+NPrMcr9jRra87av2Z/WOMr xqy5o6X/AC2PONM+GV5rNyJvBUcsUinGHXKrntuPAq3b+Gb34dXEkvjIYaY73uSQ272BHb6V9dhq KaU/snk1Km8ftHS/BXxtF4g1dk04ERW9yoX0bPf9K+mNXud2mZY9v6V5NdRdSbXc9GkrU4p7nxR+ 00UX4yxyAZ2shPGM4av2Z/Zn17d8B9FXd8rafD+YQV9Xw4v9nqfI8LO2ueHzPg7/AIKrwi48RyjI 4EL+54kH9K+hv2d/EJ8V/sp+FdQB+eDTLUZ448oBD9B8la4OMXUqO2qlH7tTOs37GHoz6Y0HV2vd MtpMlg0YOfXivNvjZ+2VonwW119Hnsbq/wBTjjVyrSRwQru5ALucnOf4VNez7PV3PPUr6HjPxA/b 58cXtmZPB9t4X0SFhgTSym7cDsQzFFBx6qfxrwP4i/HD4rfFFbiC71m41BLghBM+oTwW0aY5PlQr Gjc89T+NcSpY7GVPY4Wk031Z0+0wmEpuriJqy6HAaH8BEttLuYvHN5/aAvJ/NmitQUUMPu4brx39 a6Xwb8OtD8FIw0aDa7fK0zklz/wLr+tfb5R4e06d6+aS5mul9PmfJZlxpOo1Sy6Nk/LX5Gl/aNlo cMk1mgjCNuM0YC4IPdz7+9cP40+NC6l4h0aW0dW+w6lFcNtYlsK+zcxPQHcf0rxOL+KMFSg8uy2K knZSa6K+y8z1+G+HcXKax2YSakrtK/XuzoP2c/G82hftkXVl4R8L6Z4qu77UBcC6urzyl0u3jbdN cKdwQlU5+bn5QBycH7Q+Lv7VvhDSbWzi0LxHDc3Ud9beZHpm6VHiEoEgaRfkAC7ict2r5nAR5otx XXX7j3canzJeR8f/ALfOi6R40+J82sQ3sjadq0cMlvJpcS3LzttAJX5gpHHJ3fnzXk0/hfVfCXho xfCu4a+Lfv7pRD5V4EA+VShzuC4J+Unqa8jF0/8AaG30O/D1P3KR6X+yD4DutN0C98aeILeabUL5 ns9IgQfMkspKST49BkoCcD/W8gqDX2L+wX4NXU4ta8Vo7S26s+k6ZcsCBdRq4e7uhnqss6qB3CwI D0r2MPSdDDJPd/8AD/5HNXnFtRj3b/RL82e3/EVZ9Qs9O0vRVj8zU59kjyKGESKCzNjcvII3deq9 DnFbHifXP7M0aTyUKQQIEBJx04C0uS3vHO5X0R4d4z16TXdRaW4fc44VFPAHsPrXlX7QHxDi+HHw 9vri4mjWVo2CA8EnHY17OS4dVKnPLoeZmdVxgoJ76GZ/wTl+HUuhfDTX/iD4miLal4kdraz3/eVH 6ke3lg/99V4L/wAFbfi/Pc6j4f8AA2mu32azzqt8Afv3DqUiU+6xlz7iWv2TiD/hG8P5tu063Lb1 nLna/wDAW18j8LymTz7xMhyq8MOpt/8AbkfZp/8AgaTPjW3v725tBZWkty8BYuLWNmKbyME7emcA VpaT4H1O5lVp7V4kVlBM2FIycdDzX8uSqVK0UpNtL8D+pIxhCTto2dhLYRWfgK/tILy3u3gYXDxW zZ8rIxg+v3T06Yrg/MCYyCRGc8ehriqx5bHsYKp7kl2KZP8ApQxzgVb0DSbrW9SW206NpJ5mwqqP 88VpRpSrzjTgrt6L1PNqVI0k5yeiPZPA/wAOoPBwzcLHearj5pDzFa/h3b2/P0rqYoVtkLElpH+Z 5H6k561++ZBlMcpwsaC33k+8v+Bsj8ozbHyx9eVR7bLyX/B3OftLUaj4jmu5RkIfk3H8B+lX7l9o I659RXNw4nUpVsS/+XlST+Wy/U6M49ypTo/yQivnuzzr4ozGTXoVySEhH6sa98/4JXXnl/EfxTD0 ZrO2l6ZGFuAv/s9fEuop8UU2v+fsPwcT6OUOXI5xf/PuX5M/QvQNTZLpVkK7WORwfoB+lXNSmDEq Fyz8HHAA56/pX9T0lzXPwSo+WS0PMPjrqCW/hyG7BLNp11FKdpHzKDhz/wB8k/lXh/xU+O6eFba6 uNImFzrequ1vYQABvs8KN5QkIHbcCQMZZn2j25cdiVl8JV5fZTfq9kvvaPUy/C/XnCmvtO3otG39 yZ5n4U/ZV1/4x+JdMtfDbzHUTdi6vtUcZaIFskKBwZCcZ5PXrhVr7o+HHw80r4JaKbPwzsn1NwPt Opjkqe4Q+v8Atdu3rXLwrk08Ap4itvO3/gWrk/xS+R8z4ncTwxSp5dh9o3cvT7Efw5maY1BUU9c9 2z+tcvrN611duW6sc5B619TK1j8kg3e19vzKitg5zzjljV7TdemsHCPl4u6n+H6VjKKlobU5uPvJ nQ2OpRXUKtE2QDjaOo470olQ/wAWG6ZzXMo8raO5z5kmNklB+ZjwahEwJ74PX61aiYt2GyyrgZyT 0HHTj1qF5CCVAA4FaIiVkyBuCMjd/u96juQXQlcD0zW8dTkmmtCrd8/eHJHQ1l3IK5yOWz3raOqM m7NGTdx7T6Ee9ZGoWm4ksRms52ij0MKnKRz+qARD5j+DDtXWfD7xhZeJfhhbWl0LZ7jTp5NMmt2P 3AozATn+9EVAPT5SK/GvGHButlVOqvsVF9zTX52P63+jDmEcPn2Iwsn/ABaMrebi4y/K5BBpNrZT OsFsT03hRuAzXG/tF/CjTPi74VOkvbJFcxhjbXLKxEEu3hgR09+nFfzvhZvDVFPsf2DmODpY/CVM PJWumj89/Hnw/wBU+HvjC90jxJAEvLV8Ng5V1IyrKe4I5ruf2YZXsfF93HMflntScA9w6/0Jr6Lh yrbiHDVOjnH8dP1P514owzpZViqD+KMZfh/wx73bv+8bHc9qvJJ+7BJ6jt/Ov6uTSP5ilrocV+0H pdvN4V0/UiCt1a3BtTt6NGys4z9GU4/3jXsn/BJHx3Pp3xV1zRJrjZbapYCdbcnG+WJwBj/gEj/5 FfinFMfqfEtOqvtcr/8Abf0P1rh9vF8NVKT+zzr8eb9T9BllKucE59+9Dzblxk5B/Ovt6a1sfndV qybFW52ls8ZFC3eFxn/P+TXXGOhwTnZg9wOd27kZz0zimrc8EMQCCa0UddTJy6H50/Ej9sf4ayeG W0zwV4XuLxlU+W0kaW6o/rn5mIz+dcv8AP2k9Z+I2v3OjeJE+1W81vLbRWcY/dxDI2/Kepxnk1/J 2bZLSxcnGLu+nkz+lKdaVRKW1mvuNv4n/DaHw94amtbdntlgXeIrYgA45OSOp4NfG3xL+KeoeOtU eJ3kgsITsitVOAqDgZ9Scc12YivKnTVFbHoYenzT53ujtP2XLnyLy4xn/XR/j1r601TUQ2l7ckk4 7+1eTP4menF6K58b/tLXO/4sFgTtUrjP1r9c/wBl/WfN+B+hPuJxp8ffjIGBX1nDmlCpbuv1PAzp Lnh8z40/4KgX8cHiBXujxLHECTyRzKMfrXrX/BO3XT4h/ZJtLYsx+zfabbGecBiR/OtME71qy7NP 7ia0bYem+up9WfDXVft/hOxYHOYwPXpXyx+3x8A9D8bfFyx17xN9sklNmkQjhmMceEc9cc559a+v wWAjj8ZCjN2Wu3ktj5nGY6eAw0q0Fd6b+Z5LZ+EtG8NIF0exhhCfdLDc+cf3m5ouNQM21LclVzgh Owr9ZwOEpYSmo047H5visXWxk3Oq7/kStbLLbbWaNE6bpXVR9Mk1xfjm21lrR1+HNxo8sjsVM91I 0qoQOVUL8uQfXI9q+V4ywOY5rSjhsBVUU0+ZdXtb9T6XhTF4PLZSr4um5O65X0W9zzuX4GeMPG10 ZPHHihICOBHaKzrj2XKAfhXD/Gr4S6j8NorVBdtqFjOCTc7AkgZeq7QSSNozn61+XY/gbE5Rl0sZ Ukrq1111Z99g+LKOY4xYWCdnfX5Hb/sZ+EbtfEg8XPfS20Wlq8ccMBIaaRk+bef7oRhx3J7Ac9fo fiN/EOoQzxXtvaQXOpXNiNNSMCZZBAXhd5OeHfgrjPB5OePDw9epSoqCe/8AwD2K0IzqOT6Fj9oD 4l3Np8GNOuJTDFdQtHbw70AeEENvCehrw/4Y6jf+MPG1mmp6k2n2byxibUJWYiBWbBc49OTx6VlO UqtdJ7u1x0koUnY+9PjNr2n+Hfh14Y8D/Ae+jmu/FckGlWC2kqsiRuFiedmUZy3QnPVnbqK+w/hj 4N0/4W+AdG8O+HvltdJtY7ZDgAuVHzOQO7Nlj7k19Nio81TljtFf1+h4tJ8kOaW7d/uLum+Hbo+M bjXfETxQ2cUDW1raLH+9fLKzu7dlJQYA7cnmub+Jvi37VciGEEqmP3ajC47Ae3euKo03yo3gre8c Bf29rHEWv5cKmGkZMZx3FfG3x31S6+O3x00vwl4bZ57f7QPNVTnCg9T/AJ9a+tyLDOrFUYrWbUV6 yfL+p85muJjh268vhpqUn6RVz7K+Ic+lfAr4a29jKy22m+ENOaa7dAD86Jvk/EABfcrX5H/F/wCO EfxV8c6prmrW017d6hcSTH7Q5KRBmyEUdlUYAHoBX6H45Yyng8qy/LV9pudvJLlj+EmvkfkPgNhJ 5hnOa5tPoo07+bfNP72k/mckvje+jQx6YsNonpAgB/Oqs815qbZuriRyepkc1/NcY1MT7kdj+nZO NL3nubPw+jW11G7t5iX+1WzqOMAMCDn/AL53D8aw7gG2vWV84B2HPtkVyYvDvDvlZ34HEKav3LXg rwRqPjjWPI0aM4X/AFlw/CRD1Jr23wd4MtPCFp9l8NHzJW4uNWYcyHusfoOvNffcC5M6tR46otI6 R9er+X5nxfFOYqnD6pF6vWXp2+Zu/Zo7WMRwIFA5+X+ZqpqUvlWrbDkt8uc9Miv03HTWEwtWf8sX 99v8z4nCR+tYinHu0VLSAW8HTBY5I74qvcy4chc9ePpXFlFD6rl1GP8Adv8Afq/zO3MKv1nG1H52 +7Q838fMX8USj+4qD/x0H+tfT3/BM/wsLLTfE+uE7JJJILUZ7puDce+Qa/LcHN1M/pzf/P1f+lI+ 0xa5cpnFf8+3/wCkn2dpurm2uIXkOwE8cc8/1rV8Sav5VmZoWbIGfXPFf1pg3ds/nnEp2VtzwT9o v4y2Ok+Br6O+k3y3SvDDZqQHlYjgc9AOck9AMmvN/wBkP9nPVfjHPJrF8JiqSmE3lzGUSNYwVYjc BjByB6DJPLFR5OawWY5jh8Cto+/L0T91fN6+iPcwuMjkWUYnMKv+GPrbW35H2RoOkab8O9GGm+BU CBRtn1FRiSf+8B6L19z34qOa42qx+Vj3P0r7F6JRR/PGIxE8VWnXqat6/P8A4BTvb9YrZyx68Z9/ WsBpNzljjGe1RNaqJEPeTl5ilDtGSce3SnbS3zDGOtTox3aHW921q4eFmVumRWpZ62lzkXGEfgc9 DUOHY1jUtZdC75oMhzjH0olYEAg8A9hWaWxq3zXGNIWYAYH19KOGXaeR+dNoXNd6kZADBsFlqtdT gTAY+Xj0rWF9DGbWtyr5onXIJ+Xt6VTu1w5Y4Jzzx1reCsYSdzJvo8ocA5H61jamwFucjDc8+1RU V9D0MG0nfoctr5ZYSWwf9quX8P6LL4Z1qXVLU3Dv4jnGnRwIx8tfLVnWV17lZVQeyluea/MfFOvG hkFVTXxOK/G/6H9HfR7w06/FdKrTdlThKT9LW/G52+h/GOz0zVIdO1K4CyXPAhRSZV+YKQVHTLED 61s3nxk8O6tfXljZ6lape2hMT2c0Zikzu28bgN3ORxnkGv5Yukz++o1ouLjdXTPM/iZ+yLYfHD/S L6Oey1BEHkahZplipyRG6n5SMn1BHrzXy9a/DrU/gn8fLbR/EOP3iSCO6QEJcIY2wRn3GCOxFezw /WtmOHqdqkP/AEpH5J4icOTo5dXxkV7s4yT8nys9lsVPDZ68/pV/eFAIOMV/XUZbNH8U1ItXRh/F DTzrHw71WHrJCiXKdyDG2T/46WrJ/Ym8Z/8ACBftE+Ertn2xy3q2cjM2AFnUxEntgbwfwr8f8R6f scfhq67fk7/qfqfAjVbLsRh+vM/xiv8AJn6vG6VQCW69+1DXO58jPGOAcivtKceblkfm1SfLzQe4 17n5Mofvc8804S4GScA8jOOTXfFXR5s5aj2l3Zz0I6d6aH9/f5j1ppcpDldan4XLr0U2rQQRMxDy KpK8E89vevWPgjFL4J+MCtpoCxXIKRoz5Idlzkk1/K+EqfvYyXmvwP6j9hyUWmtdD3K8ntbbR3i8 T3Iv5LslRGcjkjnGe3vXyl+0T4Ds/D1w9zodutvG8v8Aq1OSevNYY60p36pK/Y6sNeOhU/ZxvTFq UwzgebHkntya+rNSvvM0zrkbcg150lr/AF2PTWqVz5M/aSlEnj6NwSPU/jX6l/ska953wH8PsnK/ YUwc+gr6vht2o1Vft+p8/nO8H6nyd/wVPjNzPBIpGfKQ/TDsP/Zq6/8A4JH+JTe/CnW9MlcH7HfB sHsJEHb6qarBSti68fL9UTVS+q035/5n2V8Jb0r4XMP3TazPF1zwDXnn7ZenGXStLuwPuu8bYPTI BH8jX3OUVFHMaUu7f4pnyObwcsDUS8vwaPjD4ueNJtH1SyWGNwkUud4b5W7dByeorqfA0sHiTW7C 1u5o4TdzRwblIPzOccDvX6Bh8z9/EQ/k1/D/AIB8pXy1qhh5x+1o/v8A+CfO3x+stdi+KGpaP4gu b25NleSraW7tkbC3yMsa+q7eccivW/hL4Ls/B/wuslg1Nb3VruV7i7sEiZfsSlV2qcnk5BPQd+K/ NOFs3xeY53KtXndWenRL09D7zP8AL8Pg8pVKlG23zZ6LpXwd8WaiLV7fw9q+y9bZA8luyLIcE8E8 dATT5/2UNU1DS9V8ReKrixt1hiuLNbXU7hUaNYwfOWNOm445JOTgdq+/zrG4OpQXtJpxT1S1vvv6 PX5HxuV4XFQqvkg1JrR7W2/TT5ngv7OXii+0OSDRrjSmfS9Q1BIHvy+37OsjKm9lPUAYPatrxRDo Hhf4m6/4Z+GLLqtvZXKXM+pkN5CX0ZK7Yx327j3x6dK/AZUI4uMIvRJq33n6xUbpybPDfiPc634r nsLjWTcXSyLII4oV+VCshB4HC8j9Oa1PB9o+i6J5d4jCbeSyLg59OelcmEr+0qObW357HZOKjBJH rP7KnijXLX4/6A3grSpdR1KSUw2tvbIZHUspV3A9k3Ek8AZJxjI/WrwD4aufD1jDN4vnEuobQXRe UiPoM9SPX8vU/SUsTei2/iZ5Fejeouw/xt4naewcxqXC5O7adoz64+teY61eyXkysGRj3XrgDA+m PTmpw8FUkkya0uSLaPHv2mviVF8P/B90ySKszoSNp7muI/4JpfC77f4j1X4g+LIdy2m6eBpRyXzi NefUkH6E1+w8G4L61meFpRWzlN/9uxtH/wAmaPynjfH/AFHJcZWk9ZKMP/Amub/yVMxf+CnfxjvI fCdp4U0ORpL3xDMb7UWQBjHYwuGJbIyoebZzx9xl718PaRo+kRanN9qdktZeGdFLGMhc5X2J/IGv nvHnFqtn3sltRjCH3pzf/pSK8A8E8NwosT9qvUqT+6XIv/SDEvfDv2bMlifOQc4XB/QdKs6bor3E e9YCuefn4xX5llS9rUhyJtNPZbNdz9gxUrQbk7Mt2NnLoN/BcTuAkkoiwBwMgjNaHh34Q3XjXVpL zVHOn6PEVLXkv8XqF455B/8Ar11V8lrY3HUsLJWcrv0jfd+hlDMqeEw0666W+bsep6fpFrZWqWfh 23Nnpyfwjh7g5+8/fB9PzrTWJYkxENoXjAGPwr9my7BQwlKMKatGKsvTv892fmWPxUsRUk5u8m7t +f8AwCCZ8joaozjzZ9oAO0E/T1rzeJm/qLorepKMV83/AJI78iSWK9o9oJv8P+CQ3UoXdxz9Kobz JP3wO1deOj7DDOK2SsvusjLB3qVlJ97/AKnmXi6f7T4mu2GP9YV/Lj+lez/snfFG50W40Xw1pxaO PU9bglunH8caghI/oWbJ/wB0V+OZc1HOIvtU/wDbj9Dxkb5e1/c/9tPvNNSD2KCQgOo9ehAzWB8S vivZ+APCdzf+JJykAG1Y15aRiOEUd2Pp2HPQZr+s6VSGHi6knZRV36LU/nh0pYioqcVq3ZerPPP2 bv2W9V/aW8anxx8XkOk+GY2823tJRw0QOVAz0GQpz1Zucfdx9P3l9Z6RpY0rwXbJZaVBgLHGNpmU DjPoOOB71PDuHlONTHVl79V39I7RX3JHyHiJnUZ1KeV4eXuUdH5y6v72zIlu9qEAn1681A12wGCB jOBjp9K+htzPQ/N9IpJmbrFyHnEcZ2hfWqmcP6/ShK8rsv4YKxIpyvJyKVeAc8g/iadrEXbYM4BG 3oOPTJqJhlcfmalI0bLdnrLQELOCyDueuK14rlbyMtEQw9c9KicbamsG27dR2Dwcnn9abIzHpjIH akrA+bciZyQAoGT2FROBICH4/r7VolbUzbuVCNuQc7evPeoJmM6Avn6ntVp9WTbm0KV3GBGckY6Y /nXOavhWK/569KzbcnZHpUYqEUzhvHGsR6TaOXIO0ZrCv9X+1+LPh/oV1cS2MkjS3ErQDa/MbOYy ccZLMCT61+O+MddQyujRvrKd/kov/NH9WfRowbeZ4zFdI0lG/nKcbfhFmr+zd4budU0fxZ4s8b2U WlQR3Js7GyYbnWfkqGJ5Zy7B2Y8nZ/s8WtS+B2mQXL3V/ZtfyXSASXV1lnY9c88D1wMd6/nGym2n /Vj+v61OUaMaj3etvmYHxO1zwx+zpo9va6j4g1mTVIAu3SbC7cznpkyNnAB4IB9OlfMfj/4wX3xX +OOj6tfiSKGK5ht4Incuyxl8Eknqxyc//Wrtwang5xrX1umvk07ny/HOa0Z4WeU03dtWk/lt/mev Wt3t2jpx29KvrMWfB5yDX9gU46I/hOs/eZNZSxyXKLeKskEuUkQjh0YYI/EE14VFI/hzxLMtqrRP Z3DKDn5lZG/mCK/NPE2gnQw9XqpNfev+Aff+HVVutiKb2aT+5v8AzP11+EPjlPiL8LNC1yIqTqNj DOwUZ2uyAsvHociuiE5jIPAxxyMfnXu5Q/b4GjLq4r8j4fOI/VsfWhbRSf5im4bGTk8f1oM4bHBz j06168YtKx5E5pu9gafL/OBgDtxzQLsFOnNaqJzynZn4IaNpd3rWplrGNtkA8x3d9oCj3rrfCes3 8/iBLTQLn7LLNIFik3H5GPGc9a/kTCOalFQ3P69xHK4u+x6Nd6R4i+H16G8R311qdwR+4CKVT3O5 j9K5nxi+s/EK6tra7e2sY4QxeW4+dpGPoFHQDA616E4+2Xsna/V9DCMlH31t2I/BHg1/h/q7Ne3a XAndMPGhXBz6H8K+gNQ1QNpabCT8g/lXj1KcqbaPRptVI+Z81/Hm0+3+K1cZPzEYr9JP2N9RB+Au hCTChLQAKeufevp+HPdhVv5fqeHnLuo+rPnz/gpfH9ss4pTub91sCpyM+aD/AErF/wCCSvin+z/F /iXS+n2i3inVT/sOVP8A6HUYRtZhVXdP9GErPBR8rH3z8M7oWl1rEDtkJcB8D/aUH/Gsn9qax/tP 4WSyjObeWOTj/vk/zr7DL6lsXh2+8fxPmcfTTwtZeT/A+RNb/Z21f4lzR6jYaTf3NuxEMU6phGfO ABkjPSp9R/ZOm0Gx+3+L5nsgIkuRaxuZJQnzbcRr67D1PvwK+lzWFHCxrV41febWi+6x5OV4irNU qLp6Jbv5O54Z8Qp764vWvtDgRriQNbNbTIAIoRt2SZzksTkdOMd+1PwHqWvW+qazdSXJS7uiu+3g IVXDc4A6AcfpX5FSrVMFjY1aOj5l+L2Pv6kKdbDONTVWPoa5/aE+JVl4BsILXVPsiNkPM0peSU8k HzSGPQ4G3AxXmmp+BPHvxU1UXGr3N9ds7M0k3z4Oep3P1zwScZFe1UqYrFSlCDsuvmc0IUKKjOSL +keBLD4Y/D7WoPEV9aNqskoMFtEDO8hZApJ6hcepx2IrmWubbR7VIvCtilkyFma4bBaV2ADMR052 ivLxWHdCpTinrGzN6c/bqUnszl7y1+ygLlcKSRk4ClmJIA9ySfxrJvlcqTuWNcZOePyFYKkoRtFH TGSvqfpb/wAEsP2fl+EXwQPivWrKNdd8W4eK4kUebFp+AYUBPQOR5hH8QKZ+6K+i/EWuQLI8kjB9 q7GSPhc469q6Ix91JHLUlaTbOO8R+Jp9Q057SMRRxFxhUGGYYJ69xXHX11Ho1lcT6iE+RS3zHAU9 vrxXs5bR3foeZjauyPhz9o7xXL8Yfi1Z+H9IkZ45ptrrGcjaDlj+XFfbOgeFoPhD8GNC0GFVgnuo 1v7sA42IUxEpPsuW57MK/oXwtwSrZjVqtaQUY+m83+Kifzr415i8Jk1HDJ61HKXr9hfhKT+R+W/x x+PbfGP9pHxHfQO0ulXsM2lWKZJAtogfKYDsWdd+PVzXA285iysKIobHzMMnA4/pX4VxJjI8VZzi sRUd4yqza/wrSP4WP37hXLP9WchwWBitadKCf+K3vP5yuWrNiEKu5x/dHANaELLAqrAvLc4/pXrZ fRp4aCVKNhYqcqkvfZ1Wk/D2GXT47rxsrpCzhorJR+9nYcjjsP8AJ9K6xYJNU8t9QVY4oh+5tE+5 EOn4tjvX0eDwEY1fbNe+1Z+Su3+LPn8ZjHKHIn7qenm/+Aiyq+WPlyAOfrzUMk+8gEjFe/otDxNx rdCTjHXB71RjG3e0hG4nmvnMzj9azDCUOkW5v5LT8T2sA/YYPEVertFfPf8AAo6hN94joKr2vzYO RnpzW+ay91Q7sMBHdnk+pzG81e4dOTJKxH4mvQfgvOulfEzwwcnEWqWhOOM4lXNfi+Bn/t6qf31/ 6Ufo+Kj/ALK4/wB39D7z8a/ESw8D+E31PxJOLWKIY2AgvKcZCoO5IB+gyTgAms34FfAK8+PniNPG /wC0DDLpvhewZZNM8NzgkzKSCJJQfXghTycZIAwtf1DaWZShgI7PWf8AhXT/ALeenpc/nrH4+HD+ FqZhL4vhgu8n1/7dV362PoHxN4uTU0W00WIWmmW/yxWsfGf9pvU/oOgrBlviwKr+H1r7yFNU4KB+ AV67xNaVSWt7/wBfMrPPzgfL3yfWoGuMP+8PA7npjrVqKRhOTsZsshmnLEc5705GByQcN9OKyVzo krskVSvA69BgdaNxXIyCabSsTF6ioORk+lIdrH6ZySKmemxcRGUZ+U4PAx6U62uXsnLwt069cH60 W5lqO9pXRp2WsLdkgjYx/h/wqw77l54/CptZlKXMrkbY3df/ANVMkyi4bIPv2qr3FtqVrpiDls45 5qs0hC/KSGxjmrWqJTs7lG4ZsbVPJ9KwdaOyNguMn15rN7npUH7queN/GqRodBunUtkow44J4rpf +EYjT9o9dQiMhk063j+zxqASIXOSRnjcRuH4V+CeNU9MIn3n/wC2n9pfRkoc9DHRiutH85np+veI 9N1PT4dL0rTHtoILhbqe+uCqtd3IjMZmCAfKW3MSc9z1zWf8SfH9ppXw711wAotdOnkikH3mfyyB gjodxAzX4VGN5o/rDGVIxg+ZaWPz6nSXxFNc3OqTSz3EhZ2mnJLOc8kk85rntRje0uobuFdotZUb jrkHP9K9XELmTZ/O0qsqlRyk7tn0PHPtOd3c4P8AKr0Mm6JSOvav6xwsuaEX6fkfzDiY2lIsKcLw cgcc15H8TNKfTPiNevKrJHf7bpSTw28ZJ/763CvjfEek55Wpr7Mk/wA1+p9X4e1VDMJQb+KDt96f 6M/QX/gnT43XxF+zhaWruDPo1xNasN2WAz5i/ow/Kvd/tO4fPg5+vU1PB83Vyuk+119zZ4nGcVRz asrbu/3pC+b+8yW4GMDH9Kaz7SDnPqpNfTQ1Z8tUTS3ESfs5JJGR700XQLHrnoMdQa6EtdDkc7LU /Mp9NgfVvGOj6HpEcOnWdgQ1/FEEjZiAcA4AH0yTXzb4d1d/CniSPUYIY7prOcOkMhOxypzhsdRX 8fUqsaE6dXokmf1jgIyqQqU5O97fii943+OfiL4meLI7zV54oNgWGO0s0KxgZ6Bcnv712lhpc94q G6kbzABuccc13YWo63M2jurU1SSijOn3R+KYo3lklSIggM2cnNerXurv9gTbn7orzKzcptnbSXKk eE/GXVJbXWoJ4f8AWI7EFhkflX6FfsW6u1x8BNCe4fc0lvluO5JNfR8Ouyqr0PHzqN4xfmePf8FI WefQYfsoKybW4Q8AeYua8s/4Jra9/Y37RkVvvKi9sp4z74Ab/wBlrLCytmcr+f8A6SwSvgbL+tT9 IfB955Xiq78vhZ4o5D+ZFbfxD0H/AITLwTfaeknlNcR4EhHAIIIOPqK+khW9g6dX+Wz+48SpSVeM 6f8ANdfecN4V8cT+HvD1hph0mTV9R0wwxxNawGOKNR1beTgnBI4xz1qv468H+JfHumz3mvWml6XD ErMwVTLNLGrEojHhcKDjp613Y3EYarTk+e7nsuuuuvzOTDUq8Jxi42Ud36aafI8T+Ofw18CeDvAt zD4Gu01bXZIzO1ykodYUDlGPy/LncGGP9k14d8IfCOkXviWYeI75ozNPbyTwhCzpBGcbh/vF8e2K /PcU3VnUTlrTqU0/m4u34n0VOXLD3Voz1uPxRplj8NU0e20yG7vYL+SdLi7jDosPIXjPJ5HUYrL1 fxtretWxiuruS3i24EFovlqVHHO3rx617n172Xu01urF/V3UScumpyeqabDaIwk4LYO4dGP/AOqu T1i4LSE2qHa3Bd+ikda5VFybuaSklojndXu4rNiZpPOlAyOMBfb2711X7J3wKm/aa+Oum+HpA39n bhd6iy8COzjYbxnsWyqA9i4oqLVQKi7K5+teyLTNKS20oBIIVEaRRgKsaqMKB6DAxXPa/M0tgUUH Y24MGOeRzweoraCszjlJu5xupPIdruECgHackZFeHftP/Fz/AIR7wveJBMqvKCoVWOcY/wD119vk WFUmpNbHzGa138KerPL/APgnF8JT8U/irP4j8S7vsMTtmZh923i/eSsPQ/KAPyr0z/gpJ+0KfBHw d1+/t38rUvErHS9PSMj90jqQ5HQgJArAEdGKV+3cH1lk/C+YZs9Hy1ZJ/wDksf8A0lW9T+ffEWm8 +4xyvJVrHnpJryXvT/Cbv6H5geEomHibTJJsoklyi7/UEgGtyZtly0aYxF8uffNfy1kjfP73d/kf 1tmEVyaFzSrSbUryOGyR5ZpDtREHJNelaD4Rt/Bjo+qqt9rBwyWo5jg9GY/5z/P9JyyipvmkvdX9 WPisxrezjyR+J/gu50Mdi9zetdatJ51w/O8nhR/dUfwj2qaecLhUIwPavrKEeVXe7Plq0ud2Wy2K 8l020rnvnmmxYfOcj6iulLsYy21I9ScwKBnnOAD+QqheTiPhQQOmK+ew6VfOK0+lOMY/N+8e1N+y y6lD+eTl92hkzS+bJg8/SpHkFtZyv/zyVmz9Bmscyqc9VLt/X6HXg6fLTPKtEtHuNTRpUO1SW3Yr qvDV9NZ+LNPmsIpLiS3uYphGnVtrg/5+tfjWCupxkt+ZH6FiEuVryZ+gX7PH7Nl3qtxaePP2nWW6 mIEuleFnIZIBnKtIndhgYU9MbmJJVY/YNd8TS6zOTKFihj4jtkHyoP8APev7F4ay+WFoSxFdWqVN Wuy6L5fmfxVx/n8M0xqwuGd6NH3V5v7Uvm9vIy5r3CHbznoFHWoTctxjJ7jNfQ6yPhrKOw17wOeQ QR6HP5Uya78qzkgEaO8rIRKQdygZG0c4wc88dhSnH3LJ9vzCnNOpdq61++36blSPLZOAP1zgU9V2 glyvykY+lZRR0SfNYeJNuc9h1pNoPCEDJ71pYylqgU4BDnjtxik3hsbe3rSa1HfQRmJX5Tz70K2S SuOc4xxxSaKTsRMxHPHy+hxzV601fadtx07MMcVM12Kg+XcurLlAUIwedwpxlBbB6Y9fakintqVL pjg7c46detVZH2oAo565zWuy0MlpKxTuT82V+v41ha4o2HqPUmsmtT0qOx5F8aYBLo8q44OR9a2f hj4g/wCEr0rw9rd2A14I1tLm5ycsU3If15x2NfhvjRhlLCYat1jNr71f/wBtP7N+i9jHHE4zC9JU 1L5xlZf+lM7jxXcvcalEsiBYnXClQQeCQCa5b4v+H57n4E+I79ldjHHFCGXOBH5oBY/rX4LS+OPq vzP6nzjmq0Kzj/LL8j47u18iOTac4OASPWub1qRU05kfBLZz9e1elU+Gx+Ar4j2rwxe/2j4fsbgn /WwRtx7qCa27SUDGc4B6Cv6hyWp7TB0Jd4x/JH86ZvT5cTVj2lL8y5Gx2Dnketef/HmEq+j3XVf3 tuwAxgAhhn/vo/lXBxpS9rk2IS1sk/uaZ2cHT9nm9C/Vtfgz6E/4JY+PDZ+JfEPh+5YBbuCO8iBb q6HYwA9w6n/gNfaYlO8lsdR24r5fgGup5fKHVSf6M38Q6Dp5kp9JRX6oVbjOT1Gcc9hRNIETPJPq fX3r7uK5bLufASnzpvsRG5WNSpBzjqO1J54V+TtyTz/SuuMTglPbyPzn/au1CCw+E0sPg030U8k0 cbeQ+0Oh+8CAMkfjXyvJY3EVii3qJbR7S48wgMwPt1r+M6t25RfT8rH9d5Hy+x5l1ZS8E6ab3xlb JnhZN/PYDmvaVja2tWYFdzIWJzjn+texllK1Js7MZNqSRw0mphfE5JPzDH55rvtS1wtYx/NxsHCn 2rxZ/wASR6FN+5E8v8R3MGta6Ib2MEQkklj1r7z/AGN9Tjb4S6bHalSkKsqjOQADX03D0Vao77pH i5y3yx8mee/t7Ti50SEKoUGOXljjHzJzXgH7Kd9B4R/aN8JTWl4lwZrlYpTGCFXfldue/WuenH/h RT8/zKpv/Y7eT/A/Tjww0ia+jyD/AJZvHkfUEV21pIsiBZOQ3UV9C7OFjx1pK5dtoobZMW6Ko4+6 AK8c/bP+OMvgf4VajpXw8uLKbxNqoNnFC8oDWquCHlIHIIHT3I9K4K1qFFuK2OqjepUSk9D4b+F/ wx1Dwjdz3Oo6rc3Rlia2aAZ8llYknrySSWPbrXoejeH4bDcFjVAeCVAGePXvXz2Gw/I5zlvNpv1S sv0PYqKCfuI2JkFpNHFbIr7+QfQY6GooLNr9P3I24O7zSxCnrj68mvQhTUjFz5WZmswR6fGklwTP MvGG+79B2HArgPFl1LM5kjbywjMTtGC2T7+5/Sun+6YrTU4TVIy0hxxk/MOpPrX6Ff8ABMH4D/8A CsPg3P4o1+Jl1bxXteISjBjslz5QHHG8kv7gp6VkoNSbZU5LlsfTWhatPHekT26XKnhYHOBk8Zyf riuT8U6jKmqTLfiONvMKvCgGEOfbsMV204KckkefOTS1PPfiH4rg0HRpmkfcdpxv9BXwv+0X49uf iT4th03SWdnuZRCijnqcV95gIToYOpVW9tPV6HzFVqrjIRe27Ptv9nPwPF8Ev2creO3j8q81yMWk bLx/o0ZDSN/wN8f98tXwv/wUI+MFv46+M40G1SO9svDQNsFIyv2pv9ccdcqQqEesZr9c4zlTyDga ODS/jOEPu96X4xf3n4RwNTnxR4kVMdLbDRnP5y9yP/ksk/kfOutK8Gr2jSbYttwhWNBjYCQeAOlb 9t4QvNe8XXVnpEZfZMxeYjCoCc5J7V/MmXU5TxThBa8yX4M/rDGyUKPNN6JM9E8NafbeEIWtfDAW 5vpBiXVWXIQ/3UHrWzp+nR2CEli8r/MzyHLM3ck+tfr+Cw6pRUFtHfzl1+7Y/NMZXdRuezl+C6ff uTNcYwQOKryy4ye4P4160bHmuLI1bc/zdKlNwEUcgGtopRM5XehQu7zfKC2SOoHpjpWdqF3jO018 1kL9pSr4l/8ALycn8loj38yjyVKVH+SKXz3ZThctJkngetP1px/YN2W7ROePZSa8/GR9tOpZ9H+R 3UX7NQ06o5vwj4av/GOqx22i27Syy7VVIkJALHgYGSSewGScV93/ALJn7F+l/BextvEnxVtEvdcf 95a6bMARbOP439Wx+C5wuTlmx8L+GFm2N+uV1+7pa+sun+Z4Hi1xY8gy14WhL97X0XdR+0/0R7Pq uuPfTCSRgDjCoBhUX0UdhWZJdeaSBhcH0r+k5O71P5JgtLkRlwQSeeo5pjSmQnPY4wauMTKpJPRD 1PGcgAHv1qtcShpyQTwcDFKrblLw9+bXYVB2BPI/GnZ29Twe+fwz+lYpG8hyKCDxnjuO9L5mUGR0 47jFN72JS0uMaT5TtzgegpQ23r9MjuaLWHe7EOBk5596GkAyCcgc4xzS9SrW2GSNtByB7ZH5cVG3 yjJbnrgU1qEk0Otr97Nh5ZYr/cPetGDUVuuhww/hPGKhq2xV7qzEuH2p3A6dM96pO2NwHB75rVK6 M7tMrySBm2k8dyR2rG1j5gS/zDHfmsZK0tT1aHvR0PLPi2m7T3VBzgmuM+A3iPyr3U9CkQB4d9/b SgjnJUNHtPXnDDHTLV+V+K2D+s5PN9YtP7t/wP6c+jxmX1HP6UXtO8X81p+Nj6DuFn1zw3BLdICG jCidRkDIyP5gZHSsnx5pMq/BLxTYajI0Sf2bNcAK2QxjHmD89gFfzJCajKL7Nf5n9v4yhOtSmuko tferHwv4pb7Em0ZKNghvbGa5S8l+0xgDkgd+9enVld+R/PUFZnsXwqvPtngHTS3OyPYf+AsV/pXW 2j4bIHHqRiv6V4YlzZXhX/cj+CR/P/EUOXH4j/HL82XbaQNkHoefSue+L9iNT+H95kZe2kinU55G G2t+jfpXp5zR+s4DEU+8JL8DzckqOhmOHn/fj+Y39irxovg39oDw1PdvJsup/sh2n/nqpjGfUbmB r9MJZicfN8xx09a/MPDed416fo/z/wAj6zxRp2lQqdGmv6+8etzsJGe5yD/P+dRtOQ6gsv4cdq/U o2crn5PJuMUmM+0gY3HoO/bn+VMlugSBIcYHG32rrjE8+pNLQ/IK8s7zVNBMmr6rqN5+7En75zjJ GTxnn61wV1pqyzZdndm4y5zX8XVISTbfU/s/B8kHKEFZJnoXwz8B2VlPHcxFnmZeXZvugjPAroPE t4tpG/kjgDBz3/w6V7+UuTwftH5mONt7ZRXkeWJqP2nxDOxOeRxmuyv9QLWse0jO0fL+FfOTd5ys erFe6kcF4sKwTecP42wTmvuX9hLUhN8H7AxnkFx1/wA9q+j4cT5qmvT9Tx87fuR9f8zmP298t4Tj EZGCswGTznAP9K+P/hZrcugfELR7zcR9mu4ZPTo4NYyk4ZnBP+aP5l4aKlg3bsz9eD4rsNHs4rzU rmGCLAk852ABUr1Hr26Vy/jD9sTQfDsRj8Kwz6zcDgFcxRD6sRk/gO/WvenWhTheTPJp0J1JaHkf jX9o/wAW+OSYrnUP7MsmyDa6Z8mQexbOT+dcU+nJPfCS6zv4IlkOdxP615FbFSrOy27Hq0qEaa8z Vs9G8uANMu5EJwAMZOOuT36VZ2LLtVgsaqCGZz9eamnFWLn7wPapagm6ZZCuSA4/Q/hVOe/v7u4k j00BscKuAFHPc9/w6Vbm4ppkqK0Ys+lyXD/8THaJZAF+RtoBPf6dRXC+N7KG1tj5QLbmIDE5/H8a 6KMeZe8Yza05TJ/Zx+FE37Rn7QOl+F9IV3sFbz9Ru4s7YLVCDI2R3PCrn+Jlr9XbX7PoS2ukWlrJ FbW8GI2WPbFFGm1QmegOOg9AamLUrpEVfdtcqa/qkdrG7Rsysg3YU9fofXiuE8U+LLW6bzJSY5JG 2qM8yNgt+JwCfoDXpZZTdSV+x52NmoRt3PnX9p/4o/YNFaEMqMwJMinntgH8ugrxv9jr4Xz/ABj+ MsV6I/NUTi3tlc8GRmwSfTGetfo+Awn1iphMEv8Al5NX9I6/ofF4/GrA4TGY9704O3q1ZfmfYv7V Pxbs/hf4H1rVNOeMWPhmw+yWCkDEsq/JGSB/z0mOT/vE9q/JXWNbkvdTmvb+Uy3FxK00kjk7nctu Yk+pJr3vHrH/AFeGW4GLs4xlUkvNtJflI/Pvo8YOVeea5nLaU404vuoJ/o4mnofgWfxrPFd6mRp+ mRESPcOMb8H7qep9/wCfSvQrec3yfZfD0bWWn/xyqMSTn1Y9cYwK/N+F8vcFLFyXvVPhXZW1l+iP 23Psb7R+wXww1fm+i/zNixhjsYlSAAbRgY4pZbk5IJAr9ApwVNKCPjptzfMyKS78sYzg1ALneSCf xropy7GUoWFW7Gep9KSS+CITLIqqOoJ56HoO/SuLOMcsvwVWs30svV6I6cuwn1rFQp26/gtzMudQ 835lyFIGARyOKo3E5c8dPSubLqaweApU+yTfq9X+Z24qXt8VOXmSWwB4POeldR8PPDT+LfEdvZ/2 Y+qxTFo2tAzKs7bfuZUhj1GcMuARllyDXj04Sqq0FeUtEu7fQ7K1SGHTnN2jHVvokt2fY37NP7Mu lfs86TFqGsW8M2vyx/u4Dlks89Tk4LNjALEAnHRVwo9A1TW3vJ2e5dmkfqzf59K/dOGchp8O5fTw kN7Xk+76/dt8j+UONOJqnFWaVMW/gvaC7RX+e/zt0M1pvMPXk9z6/wCRS+YduOc+te2kmz5i/LER Hxux24pquM/L9OlWlpYy2aYSSeVETn5un0qvEuATjr71FQ1opq5KrEd+v4Uu7BG7kVCNZdhd2ARw fc9KRpsk4HfnmlYd9AEu58cZ70wPkjJ46/40DEWTfj6du3+FLv67unP1oaEtdhrEk4JpJI2GcmhO xTTfUTO0HfycA8etNO6EhkLAgA7qVtbF2Vr9SUXhbibCnOCxqNp9zMCfz6VpFGDTiys8wUMDyO/S s3VZMryMgjp0zWVSKbPSws2o2POPiTa+dZyk9xyCK8IutTl8E+M7TWLFXLWUwZ0jO0vGeHTPbKkj 2zXyXGGEWMwFWg9pJr70fsPhlmMsuxtLEx3hJS+53Psr4a3kHi3w1by6Jc77R7YEbOd2FBU49x+u e/FbltoFvraT2XiC3+1WupQS2c6ABWMcikO35NxX8bVk4SceqP8ATekoYihGpDWLS+6x+bXxCsLr SV/s/U4yt1psktncA9RJE5Rh+lcpJprtYGaU+WqnAyOterUb6H81V6Xsak6b6Nr8T074GXgm8ErE DuEE8sfP13f+zV3lrjHfrX9GcGTc8owzf8tvudv0PwLiqKjmeIXnf79S9CSSOc59+Kdc6fHq1rLZ z8LdRvESe24YzX1zUakZR7nySlKlONRbpr8zxjS5LzwT4liO4Jd6dcBlZW5R0f29xX6p+A/FcXjP wbpOrWWfK1C1iuAD1BZQcfzr8Y4DlLB5nXwsuzXzjK36n6V4k044vLsPiYvTmX3SV/0Nf7RwMnJ/ wFI11twSGJzkZxzz/wDWr9ejHU/E51LRbepCZST83U5+UHrUU8uPvHjHbgECuyMeiPOqS6s/JPS1 mt/h2TfA+aEIy3ORXKWmiy3kUtzIdltByXP8R9BX8X4uajZn9p4H3pzXZnZ/Cm/E+l3EhUgoSoY5 9BzUXjy/22x2t2xkjrivdw0fZYH5GVV82Isea6Jd+bq1wc8k12M13vtI8nJ2gYPevl42vqexraxy vjBvMsUB6iTtX2V+wdfkfCC0AYDY7r/n9K+l4bf72p/hPHzvWivUd+19ocvi3R7e10wwtOxkX944 XAKEZ+mcV4b4M/ZlttOlW48RXD3s8TA+RbZWIH/e6n9K4sybhjZTXRovL1bDpPzPcIL3U9ez/bE0 87rFsRZmLBcDIUDoBxWQl15k7puDlMZGAMcfzrSc5YiTb3NElS0RctUi8rdIspCnIUgDH4n/AD1r Wt3MrjzQCp4G4dOcfypxXKhPUuXN/BptjHubbhWZpJOi57Z9aF1FbmL/AEMGV43BBhTIXHfdXXTj oYyau20Qo3+g+ZrDR2scC4G473POSTzgcflVt9Tt9NtUMThTjA9SOMfyq4uK1ZMrmbqusiaDzMOS ybS8oOzjtmvJ9Z1W++JXiK90fSZBvt7OV4VjBG+TcBx7hc1E6rjG0eg1BXuz7o/4Jj/s3x/s9/CK e/8AFkUUXijxFIJrosAXghA/d2+T6fMxx3bHO0GvoW71KJN5J3sp3Z6gCuijR9lFJ7nLWqqpNtHH eONXtXswNM3mVh85bsPp2ryLx34j/se1meeXJAbYqZGO38q+mybD3jd7s+fzSvZ6Hxj+0L44m8S6 0tnpzM807+XGuckkmvr39iD4YJ8HPhVda1PGFu4o/sVrISctcyr+9k/4ChYexZTX6xwXg5Y/P4/y 0o2+c9PwPzHxFx6yvhqavaVR3/8AAfe/H8z5j/4KifGU3F/pHgrRpCwt/wDiY3yoc/vGBWFD7hS7 Y/21r5v8O+Cre0iW+8aliWw0Omofmk/3vbpx+dfG+KF+IuM8TScv3VBRi32SSbXrzNo9/wAHMMsh 4Jwc+X95W5p+rlJ2f/gKidjbebrQjbUQsdtHjyrVOFTHt3Na6TrDGBEMAdvSu/BQUIqVrLZLsj2s XJyfLe/fzY9b3ZHknp6VA2oAKQOueM16Ebs4/Z6laS7Yt8x5Gaabo55IxW8LEyjcUXWGBB/KoLlx 56Ox5wSFz07f4/nXyvF0vbQw+EX/AC8mvw/4c9vIqfspVa/8sf6/IrSzbVGMDHYVAZC0mMV7GPn7 Oi0u1v0OLDRcpps7j4R/CPVPirr1vZ6FbSyCU4+UEb1HG7dghUyMFsHnhQTnb9t/CP4IaP8AAXRw sEcNzr0i4luSo2Ww67IxnjDdsk9yWYlj7vAmTvFYh4+ovcp6R85dX8vzPzfxW4jWX4RZXRf7yrrL yj0X/bz/AAubd5qTSbzuLuxyWY5JNU1cuDnp71+tOV2z+eoxta7FDkYGMj39acpI4xwOP0pqNkJy bY8LnjnngURriTBXpg8Y9qrWxOhDdPmTYOqkk/0pol8oYGfTpWFT3mddJcsRwkyPl6/TinevOMe1 TexVubQTPrg9zQ2D+uMil5j5baMRR3P0JxjimqQo5PPp6e9Fw5bageWBQUjYGdpP0PSjcIrzD752 5OcdWpGJIyQR9P8AP0pDtrcbIQOB/DjvSbsdSen5091oUtyKbHzbSceuO9V5J2hOHG5T74Iqotil G6I5Z1ZTt7+lZ19znBH4+lNrqa0Ja2OQ8awedYyfxcHNeK+LNB+1mYBclsgZH6V4ecU+ek0fpHCF b2Umzf8A2R/2jIvgz4vXw34uhkNjcXKNb3qniDcw3BvbIBB6Alsg54+vdb1y1s/E9vfaQ5eym+TM fRS3fH4iv494rwn1TNK0Vs2395/pR4VZzTzbIaVNv36SSf3uz+7Q/N34qamsHxA8XG2dLj/ib3To xGVZjKwLD2PFcDc6k7WM1vd5ZmkDg+hAIxWUpWjZrufj+ZK+Nru/2n+Z3nwBu9mlX0BH+ruBJn/e QD/2Q16XZtzz0PSv33gKbnk1FPdc3/pTPwfjKHLmlW3W3/pKLsZwwGflHarO3n5T09PWvvKeh8NV R5B8TLE6Z8Q75VzsuiLheOvmDccfjmvu/wDYU8a/8JT+zvp6SSNJNpUktlJnsFbcg/74da/Fsti8 NxZVp/zSl+KufqPEn+0cK0qq3UYP7tD1/wC0FiNx+Xg8Gka63d/mXpj/AD61+z+y2PwN1tGMadXI 2MQR8314pkk3mbecnp15FdEVscVSWjR8Q/G34YaF4x1K7ufDmmweENDVx5GjW05dLeED7hZsu7HH Ls5718qfEfxaLjUH0/w8UNtbMU3wj5cA449a/g7C4x42SpN3ULa9z+8PqLwUeeSs5Nu3Y7P4e2La X4TRb2GSN5P3h4Oce9YPjONry+SF2aFJGCmSQcIDxmvu8RLlwiit2keDTXNiHJ7anNal4ai8K69L BaymZVJHmkY3c9cVpJI86RpEGckABVGSa+Si+rPdlG2xs2PwC13xgIhcxjTYHO4zXXDY/wBzr+eK 97+Fnh28+G/g2PSPD807CMlnnxtZiTz9BXtZbXqYVynFbqx5uMhDEJQl3N228PNOwk1UB2kJOWyS COKvxacke2NNqIcZwM/nW/sr3lLVsxU+i2Len27rdeXJ8u5c7kBb8PSuOuLoaVq0giUHexZ5CPvN wBz07VLspIpJ8rbNOK2NxOGgVW80EjB+4uOgHTPX8qvQ6ctvbHYrBdoOwsCcjjOB+P0rWGj13HKK tYdm3mtHjunEkTDJjwOnufXgUkl3Fpwigjxbw7TuSMYO70AGMdK2lp6mcVd+RSluopcQeXuBXa+z O4gnJJ9KY8YaQRxK7+UeN4JVT35P1qnTjo/6/qwnOya7md4x1KY2o0/SInmnnIiiih5LkkKFA/Sv pT4Xfshax4Y+CmgWFlBYxapfagt7qtyyDzIUPO0N1ZlUjjplSO9ZVK0YyjEfs3yuTPpKbw99it4x Gd2MfKRjGKy9Tu9uVIBUDnPHU4r0KD5kkzzaq3sed+NfFUdgWyQSufmA/U/yr5w+PnxO/cyi0kAJ z8w7kf8A16++yTDctm9j5LMq3PJRW545+z94Kl+JHxOOpXSmWG2fZHkZ3OTjOO/OK+8vH01n8N/C 9ppLuIrLwzaPJeSjn99t3zNx1xgL7hBX7D4RUPazxOYT2cnb0iuX9Uz8P8dsW40sLltPVtJW85NN fk0fmB8QfFDeKPiLrHiHXtt5rGrXLzBCdyWqE4RB7KgVR7Cs/T7Z5bjz9RYySt3YdPp6V+Tzh7bF 16s/jqzlOb827qPoj92wdGOBwVDDU1aNKEYRXlFJX+djYiuNq4B6dKtx3Aii68969WMtkc0oXuRT 3u88HjPaoWvM9Cc9OK2hN7GfKMWbuc89qPtIY8frXRGVkZuJLY4lm5JAA7VVbUEuXkaEkorFQwHD Y4J/MEfhXxmPrLF55RpbqH52cv8AI9/DU/YZdUn/ADf52K80u3kk4Fel/s8fs16z8cPEiRWcDJaJ h5ZJQQiL1DOe2eoXqRycKQW97E0KmPq08JS+Ko0v838jx6uMpZVhquNr/DTi3/kvnsfb3gTwPo3w S0UWPhPEl7IoF1qXG5uMYT6DAGOAAAMAYp9/eYU+VkE/3jX7lgsFDLKFPDUVaEVb/g/M/kjNMzqZ 1iauMxDvOcr+i7L00SK0CFuT6Z6fzqULkDHGP0/ziu1a6nlSXQXaBgEdeuKfHgDHPrx+tXbQjZij buB6gHj396R5PKByQQvc8VdiW9CkJTJIW461JGRnn0HXpXHJ6tnfBaJIUSAdOx5xxijcqseB+NK4 0l8gB8vhAGwOtDMyklT0oeo9VsDSKwGDjHGM0zeFB2/e4/GhaD32BXIPYnPpSFyxznPb04phq7oN wXHOD0o3bgRkY54FJvqCWgLIQTtPPTr+NRFtoODnPp2o2HdjJG+Y4zgjqKrSLg5GR0HH86aZVu5T nym4rx2OeKqXUwYHPb9RVS10LpqzMDxBF51syggYrzjW9EzJJ5Y/OvLzBKSsfacPzdJs8g+J+jNo /iG2vYgSH+Rgw465r0L4J/tBan8OYpNO1WeS60WQCSOKUbjbyBgQUPVenQeg4r+XvELBOnmtRtfE k1+X6H9h+FvEM8tw9GtCVopuMvNb/hc878b6Rp+peP8AU7rQElFnqMzTos4BKu3zH8C2fzrzXXrB oLotMm3JI49q+QUX7PXc9THVYVMXUlDWLba9LnYfBXbb395HnIlSNyB22kj/ANnr060ccjrj261+ 5+HdXmyyMO0n/n+p+K8cU7Y+Uu6T/QuI37zgH1HvVqF+AQCD61+i030Pz2otzhPjtoL/AGfTdWtl 4j3Wkp9Dnen55YfhXs//AATS8aNHrfiDQmZwlxFHeRqTwpVtjnHvvT8q/IM1SwXFlKo9puH4+6fp 1K+O4Qq01vGMvwfMfXTvheG6j86Xzyi7RtJH8Q7D2r9lUrn898rQx5Aigkk7sUwuFkwwKn6dq1j7 xjNcrPxq8Z+O9Z16aT+2dSurlpOvmyEj8ugrI04yadexmBllkba20c5PXFfw7gsPCnJRhHQ/u+rV lLWTufTejeE7XRfhfe6j46vbyHV4IlkNnHBtijLruVS7febGOB6143puieIPiJfO9nazPBuz5zgI ij/ePFfc8aYb+wadCi5Jzmru3TbT77/cfNcI4iGb18RWqrlp05JJ9763+6z+Z2lj8AbjWJLZtXuk jRFwwg+Zm/Ht+tek+D/hdpvhqBF021VpgP8AXuMvj/eNfH4TD83vSPpswqwlWn7J+70O90Tw/FIg MzAMVwBnNT3UK2yE2oZ2XBXYcEfU9a9ujFRVmv6ueLUbk7pjY4S6BZCwfJPmt0JJ6c1LgGQJKyuu c5Bxk1Su9GhaW31LkN9HbxER7CIySPLHbuf09a4e+guLq9d4Yd0cjErG+N3sc/jXLWV37uhvTtbV 3sOuvP0yxJmePMZCpHEw+8ehz7e/v71oaZqbTWIhmyrSLncnUr/nmrjJLQdufcgs4o5T5V2DgZ+R DxgZ/Wlu7mMKqE4YcF8fmfwrdLlfM92RLVWRUklt4H4Y7TyxP3jgfpWPfePZLi48mwA2A7Qx+8xz 2A9a5sVjIYOF3qyqdH2rPrL9mP8AZvk0640y/wDFdqiS2ai9kZsbmumLKEA64jUEf7zOeymvpmBt qeWjqm3BIPb1NcmCblLmlq2PEPSy2INUunk+WCXdvO1HYY3dK5Lxff2+hxyf2oXZ2UFQBjBPPPoc dK+mwsOaSSWp4teXKnc+fvi18QJIbW4hiKiNyNzADsc818mfGHxVLq12lpY5aa4fyo19ycZr9CpT WCwNSs+iPlKVL6zjIx8z6a/YW+HEHheB9WuEVrbQIhPvYY865IxGv13ncR3Ct6Vy/wC398WrjQ/h /HomlTH7f4jmJnk/iS2QhnOc8FmKj3Aev2zh2hLhzg2tVatP2dv+3pafm0z+e+Kay4o8QcJhl8Ea l/8At2HvfpJHxnFbJbZCjL/3j1zVuCXPTt7V+K0oqn11P6RqPnJxPgDNK94Scg4rpjUtZIxcbjWu Sw/Smi4yR1zXVz3sY8ogusqQD0NL9q4GO386tVNBch1nwe8HQeNvit4U0bUbiXyvEF+lpPFHGwMK F1AIYdSwLdOmB612v7XfwA8HfA7VNIk+AniSbxL4W1hZltLm5XEiPC4SRTwMjcTjjOQa+JwEHLNa 1Z6pNq/rb/Kx7eLq8uFpUV1t+p6Bp/8AwTQ8T+EfF+hjxxNZz6Pq2m22r22t2hL2r28iAnaSMM6s GXB4ACtg7gB9G6DDp/w88NJo3gaMW9moPmTD787HqxPXkn6nPNftXA+VqUZ5nWWr92Pklu/m/wAj +efFTiOU6lPJ6D92PvT85PZP0WvzKEt4ZHYOOP8APNIHDJh+h/vd6/QEnJs/HXNR0RJFJgYB9jmp lf5hkkk9MfkK0jHoYzndjxICwx26dRilLgodx/LrRYfMraDQ4PA4I7+n+eahv59sOFIy3qOneqei 1JjaT0K/mYwV/wD1U4OXbBwM+lcnLZne532BHB749hThJwSfxPoKJIqLE83dkdunFNVvnxyOehFK 1mO+gOduOoJ/xpFYMep5/E0XtuO3QQE4xjI9zxStJwD6+tO6ewcttxCxYEke2RQzZzngtnjH60mO 2t2KvzEAkn2FNbGwnjI9O9HNroUoaakW4hOeMc5qvLzhj2749qVtSoxZTnYBTkevXvWdejIP6DNV zWN4QMjUjuyoJI9q5XWYgpJK15+J1R9NlkuV6HmHxh0oXfh+4IB3R4YbRnHIyfyzXNaDapFpWI3W SROQH7DHSv5/8UKKjjaE7bxf4P8A4J/SHh1VcsvqRb2l+aQ9bbz5ME7gecHt9K4bx5beVqLAL8px +BxzX5m17skz9B+0mO+EU/2LxdInaaF1x9CG/pXrls+cHHKntX6/4dTvgJrtN/lE/L+OoWxkX3iv zZeiXzOeh/lVqNGYHBIHt/n2r9Pouz1PzauuiMvx/YQ6r4A1OG6JDQIt1EQP40P8sE/nWJ+xv46/ 4Q3496HIAzR30jWMgX0lG1f/AB7afwr8l8Ql9XzHDYpO2n/pLv8AqfpfBi+s5VisO1o+b/yaNv0P 0NabzNvXpg496EcRc4wMY6YxX7FFuUU+5/PcklJ36CyMAvzfe+v50ki+WoByMrzmtYOxlON9D//Z /9j/4UhwRXhpZgAATU0AKgAAAAgACwEOAAIAAAAgAAAAkgEPAAIAAAAFAAAAsgEQAAIAAAAJAAAA wgESAAMAAAABAAEAAAEaAAUAAAABAAAA0gEbAAUAAAABAAAA2gEoAAMAAAABAAIAAAEyAAIAAAAU AAAA4gITAAMAAAABAAIAAIdpAAQAAAABAAABEsSlAAcAAAAcAAAA9gAAKvYgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgAFNPTlkAAAAAAAAAAAAAAABEU0MtVzgzMAAAAAAAAAAAAAABXgAA AAEAAAFeAAAAATIwMTg6MDM6MjQgMTY6MDE6MDQAUHJpbnRJTQAwMzAwAAAAAgACAQAAAAEBAQAA AAAegpoABQAAAAEAAAKAgp0ABQAAAAEAAAKIiCIAAwAAAAEAAgAAiCcAAwAAAAEAUAAAkAAABwAA AAQwMjMwkAMAAgAAABQAAAKQkAQAAgAAABQAAAKkkQEABwAAAAQBAgMAkQIABQAAAAEAAAK4kgQA CgAAAAEAAALAkgUABQAAAAEAAALIkgcAAwAAAAEABQAAkggAAwAAAAEAAAAAkgkAAwAAAAEAHQAA kgoABQAAAAEAAALQknwABwAAKAAAAALYoAAABwAAAAQwMTAwoAEAAwAAAAEAAQAAoAIABAAAAAEA AAKAoAMABAAAAAEAAAHgoAUABAAAAAEAACrYowAABwAAAAEDAAAAowEABwAAAAEBAAAApAEAAwAA AAEAAAAApAIAAwAAAAEAAAAApAMAAwAAAAEAAAAApAYAAwAAAAEAAAAApAgAAwAAAAEAAAAApAkA AwAAAAEAAAAApAoAAwAAAAEAAAAAAAAAAAAAAAoAAAZAAAAAIQAAAAoyMDE4OjAzOjI0IDE2OjAx OjA0ADIwMTg6MDM6MjQgMTY6MDE6MDQAAAAABAAAAAEAAAAAAAAACgAAA3IAAAEAAAABwgAAAGRT T05ZIERTQyAAAAAAKCAAAAcAAAABAAAAACAKAAQAAAABAAAAADAAAAcAAAFIAAAExrAgAAIAAAAJ AAAGDpQAAAcAAACYAAAGGJQBAAcAAAsQAAAGsJQCAAcAAAGEAAARwJQDAAcAAAGQAAATRJQEAAcA AAGoAAAU1JQFAAcAAAXYAAAWfJQGAAcAAAAQAAAcVJQHAAcAAABAAAAcZJQIAAcAAAK8AAAcpJQJ AAcAAAJYAAAfYJQKAAcAAACoAAAhuJQLAAcAAAGQAAAiYJQMAAcAAABAAAAj8JQNAAcAAADIAAAk MJQOAAcAAAAQAAAk+LBAAAMAAAABAAAAALBBAAMAAAABAAYAALBCAAMAAAABAAQAALBDAAMAAAAB AAEAALBEAAMAAAABAAEAALBFAAMAAAABAAAAALBGAAMAAAABAAAAALBHAAMAAAABAAAAALBIAAgA AAABAAAAALBJAAMAAAABAAAAALBKAAMAAAABAAAAALBLAAMAAAABAAIAALBMAAUAAAABAAAlCLBN AAMAAAABAAAAALBOAAMAAAABAAAAALBPAAMAAAABAAEAALBQAAMAAAABAAAAALBRAAMAAAABAAAA ALBSAAMAAAABAAEAALBTAAMAAAABAAAAALBUAAMAAAABAAAAAE1NAF4BAjIwMTg6MDM6MjQgMTY6 MDE6MDQAAoAB4AAAAggAAAAAAAAAAAAAAAAAAAAAAAlUSG0yMTEwMDAwMDAwMDAAAAAAAD6U+gEA AAAAAAAAAAAAAAAAAAAAAAkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAABTdGFuZGFyZAAA0QEBAAAAAAABAAFwaYiVAP9V/1X/Vf9V /xH/Ef8R/xEAAAuuAAALaAAAtGwAAAs4AAAAAAAAAAAAAAAAAAAAAABM728ATMs9AEwj6gBMt+kA AAAAAAAAAAAAAAAAAAAAAEUA4wAAAAQACAAbAAAAAAAAAAAAAQAAIJWKgQAAAAAAAAAAAAAAAAhK AT4AGwABAAgAAOxbAAB8AABAjsmVAAAH6hdwvAAAf9d/bxMgACsAAJUAAABwAHAAYeEACH0/fT8A cAAAlQC6AAAAP2BJ70uTCMRaLkoNDs0qFgjYofYOAh2VxD8HgRFB5mmHrqiyyTw/B8QOzzKrQIZa xEr/////AIjvJAAACbc0UZ5KAEAZfQL2GyVeTgBbVgf5DukFW5fErlaBVgdWB1bsVuxV9gaqOweW OCCWBF6VSiQEQX1RAFVqSkBw9pXJaXBwxV6BsoFAVlZAJ9gIAcLESryFAX0toFvUzwIBfgB1ApYA 0NOhrJ7EBOf2AP//////////////////////////////////////////AgKs4GBgYOCsAgICAqzg YGBg4KwCAgKsYLrLdcu6YKwCrGDLM2JlYjPLYKzgujPuYSdh7jO64GDL3G6DvYNu3MtgYMvjUxB7 EFPjy2DgRyN/S25LfyNH4ALgunXj3ON1uuACAXHuO+1vcyEgIewNyCFjudqbdDb7RQB85JuQIRES uG8YWb+chAm2Qnba2++DcvoZFsHBmB1KZ0l+HAWe9UqaMwjXikUPh2HFgZNQJ1LPuxoi6jB9vhtf GwpWEARTGz2KG+OIcNxA0EBbQOReZOfT5xRAuucVQJJACxtEG2Ebv17NzSu7exvwG7kbeQgTG2UI TRsoCBd9XF6rIF8IHAg4CGAIvAg3AY0BPgGnCMUbzQ6lCFEIKAgTQPsIAQExAWgIwghRCF4IFvrR +pv79Q9tIitnyCZSeiZgeo0UgL6eFulpotalX1A5qWOVZUHAQcJfhZOef0hRWV4ufdYIBiAE2Gbc FGDYBJ59QtjnfZHNmeefXlEElNjVQOtAFn1FVpm2cV7lfX9ASX0MQJpAn0CXDrLqukDhQNhA9Bs4 G+QbXRtPG60bQQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJu79TsSvjvsWadkEq0VuLFgsKhVQnKuv9I8oliLuaFz Mp1s9YNZMZpfAmHSS3or5ZJqgQqV9IHncFBSJWXB8GoMLzBTgYdR0TATOS+BwdPmUUDXSgyzvlNp yIppYHJsOgXboIZgtQzzVpPNz4eQ4GuICerd4MpRLVbJ50h9gtga2OzYls0XCNZeW9ds8K9AHYoF 6j2KCEDE2IzNZBtCBDIOml71zRogKX0NVn0EAopiBP9WcF44fRfYVRvBfd4EPg6ifUkEDv+Z/7D/ NfF/fEW5rRIPmQVUyHwELIFkQgnrchfK9IBzSq3v+T2FUOqnCBG7v+OOAbY9zaLqSFFicPykKzJO DDAFHc2V6ia7oXDzMJ6BX2lpBVnqAM3mIFYosM3VIPQFrucZzVmI+M1pzRKIAnCfaagEgNhvaTLq 3NgL2GN9lP8u/9r/P/HCfAG53RKUTS9TsiFI9LCoMhd5rXaco/clStvvjeHVNtqlKHcGFQ3g8VY8 XtQbTaDnze5f+FLPcH9ehF7x2MaIh+okDqNpuedI2BjYgdhycN0ofQSA2B99d9hJffJ9rthl6qpp Kn1UQD199BucQJMbtBtNQItAcWr8afsvlC8ylQBqLqDolQC+i2wrDNLggpXuJPiVANMmhwZRGV2k 0ypRX+xs03OVqew/DP27aYEfgREMLS8YUW8opuxADKAMLZIEuyC7Bbv+DMHTmS9qL0y7gJUNoCkM 8bvzDNbTGDn9Xc0gLLsgbP/sUrvGL0gHwIFslQCVAIGhDEgotew0gX9WupUAxals2ZUAgTgoVmxP UX+VAJUAlQCVAIh9lQCVAJUAvuyVAC/jlQCVAJUAiNpw25UAlQBsd+wElQC+YRrirD0HMI4/lQBR 3XVklQDCi1EpXT2VFbfvKAeVAJWQlZzsxSh87D6gLtO3DIJRsl34ahzFXsVGB3hdmewx7B1dRTl4 XEhd6DkHxVLFQTmFOfHTHmyl7MbF+2w601Y5JQdmai0vVC9hUZrvvcUN7KoHoOIy7LwvoQcSlQCV ACSkOSVd5jl9xZdPG5UAkhAMk5UA4jJcQwfnoPOVAJUAlQCVAOIGlQCVAJUA4h2VAJK9lQCVAJUA K10a+ZUAlQCgf1zXlQAC7ABvCJ0AbgAAAAAA+gAAAAAAAAA+CLoAAAAAAAAAAABdASYIKBvbCNwA 5AFhQAEAOAGwCKwbxkAAG28IdAgXCAIBqwgMCK4I3BtRG5kbQhtgAPoAAQAAAAABrACpAAABRRt+ AbEAAAAAAAAAiQCcADwAAADeAAAAAAAAAAAAAABVAWwBDQAAAAAAAAAAAAAAAAAAAAAAQAB1AKEA AAAAAAAAAAAAAAAAAAAAAAAAAAAhAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACcWwAA AAAAADqzAAAAAAAAAAAAAAAACd8AAAAAAADStQAAAADxsJxb8bA6s0oA0rXR7eYqt7cAAIcqtrYA AO7fAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAG+QLCAP8+uko1DJvCwQo9uNNOkHWwv0Z0Na2fc+4WSmwObyHa1XNSWv+nX9 P5OXjaXnSEKG7yVmHsWGaeitlhOg35ON3LDEvdD3V/pLm8uMXBcM1LbDBHwwQLaAijwMxuAtDIXq qF6GfY8OHwRGDrx9ml4DDnjnBg72QEcbydhI6iQg7BvxQPYbsxvFGwcIcQg+Gy99Oed1ttsIpQh3 CD0IiwgqCCgIBAg5CLJANQ6YCAIIJAiYGwkIVwEqAfcI7AiHCJgbcwCWAAMBWAio5xPN8TAOILVw i4rQBRMOSNjnGyQbFwioGyQIzgHZAYsINghpAYsIVAHZCKN9IQ7zfQ19tefNulIAAEoAAAAAAP/E bUYAAG1GAAAA9gAAAAAAJwD2ACcAAAAAAAAAAAAAACcA9gAnAF0APwAAAAAA9gAAAF0ISgE+AAB9 +kDMLzIAAAAAAAJeVl7Hu99cAKw5CAgAAADEGyVeTgBbGyVeTgBbQKVexwAnAFv9MgBbAFsAAABv AAAAcwAAfSAAAEDYAAB9+gAAVgcAivsmXscAAAEAAQAAAQAAcLwbJV5n/9YbJV5O/9YAAAABeeZA zAAAALsAgAAAxQcAAAAAAAAAAAAAAAAAAH36AAB9+gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAF7HzaQIjgAAAAA/7L/CrgAbAABX1yZwWAAAUeWShXBYlQAAAAAAAAAAAAAAAAAAAAjvAFte Ti80AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbAAAAAAAAGyUbJV5OXsIAWwBbAAAAAQAAABYAAC/Q AAAk+gAA/7YAANhRfUv/phslXtn/wRslXmf/1gA/J1F/P8WmL5XigcWHCAUODqGVCIHxefiXAED/ //LXfnfbEXkArwE6XIaGxy8RgeHOSQARBGWX111TVicgELMOVm5KBCIRQJf2AARKDeGHOtrMEUJA zAiVRQj23ZaWkg73PAHHCMJwxMnDmAA6zM7NvmkO5ikIOrYAvtimG1HuAAoAXZVwG8NGAekAxw4K FsPCxebOx1EyCHYBsbbJXSjCjggOOOF+FOBKlUoAxULjP5VRPkrYCKTFklzC7gc65ycIvkwFAAAA AAAAQIrkAAAAKHB9cFtwW3BScFIAKHC8itYAAAAAAAAAAHCUipT/AAAAAAAAAQAAAAAAaVMAAH3Y AADYAAEADgAAAAD9AAAAcACVAAAAzAD/UQAOSecAACMbAAAAAABeAAAAAAAAAAAAAAAAAAAAAAEA AAAACAAAAAAAAAAAAAAAAAAA7gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAO9wBXBccHRw73BXcP6K+4r9igCK/wjsAAAAAQAA AAB9AAAAAAAAemmUilNSUlNTOEtSUgBpAGkAaQBpAOoAaQBpAGkAaQDGEcYRxhHGEWgRxhHGEcYR xhEA0wSWAPgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANAAAAADNaQgAAAAAAL4B vYIRW7NPKAEB//4AAAAAAAAAAAAAAAAAAAAAAACW/y4AAAAAAAAAAAAB/5BHmkfpR1BHZs0AAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAG1xbWdtQ9hwbY9tj23tzXBKDkrYStNWcG0sbSxK UVZwStNKUUqH53BKUUpRSmIEcEqHSsVKR+dwSn9Kf0q8DnBKR0orSvbqRkoQShBKzNhGSk5KdUpO BEZKzErMSpQORkp1SmpKdVYkSpRKlEry6iRKAkoASgJWJEqySgBKsjAkSgBKAEoABCRKAEoASgDn JEoASgBKAAQkSgBKAEoABCRKAEoASgB9YEoASgBKAH1gSgBKAEoA5wJKAEoASgBWYEoASgBKAF5g SgBKAEoABGAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADTuAQhAGwAAAQAAAABN MkEnbXCVB20ABwAAgRIABZMAAACVAJUAKPoAAFhujtwADohtfgAiqsjyAMQOzEpd7ucAMHABGycA QHC82LEAlpZEpKluYhRk1yG7wpJOCAEQXdO2x8zFCEcAOyiIDiCD7g7ERzwTaRV/JFbNVIEA53k4 2AFLlbYIknAI2JWzAicA4MR9rpU469jTL+FPSsJVkm5AdwE/laB39lHTfSAOGl3u9uezHwABS3gS 1cRVJLoRAtg8LBsODgjJ8A4vAEwbcClBSsgAWABA4wjcxKpSAECWUxnMBEYAeTj26gQblu8t51Eg WAcZUuMAPwjECD6VXJUA306VG9PnB+fELwAASg7h2EfT4QBFQOAI9sQAQHAA7lF9h+s9GiQprqFp eicAnfJwDsRAPuOVfT4vJJUA2ECUlSA/BEIZYpMgt8SRN/YqqGqVxMUFv/CBQARAWkoAGokBuxAp Dg4BAAFAWMdGtocH3DizQADEMgECQIoEUkDMQMLhx0okZiBp3QA9Vk5cTn3E08yVSuPijw7CDrIB QCIAAcLrCAY8XVYAJzxKAQc6Fq4vzkmCdxlAzTo6CMdAZXC22SnMKYHTBAHbAYFKXVE/t4GuQJXm UQAA0z8ohzFvJDovUcdROkLHhpLHsUo4g8XYACSAIHbH51zTxX3Hh+ckDuReDgiuAhuRxQCWFFYB 3ZEEBHBKBOVKIiPqOhQZ6g5K0AhOS04gB6oBRVGWCQ6Is+EgAVgHYthmVhhpPwB9KkCV04sHQEzh cAjpbkuG124AG3nA42lG4wiVlrNwTrYAcdjnYD/gTw4IAAjjrFEHtu49BGlYgerEa8gtxCQANN0B QEw6zYEFSjpA98JAcE9JzUxA9uJ2aTRJzQIxEdvE03aBgHbqSsKBfsTcxMQMcjgfQEBRxwBdQMEU X2l4Dq0p6kBeTGueXk9AgCcELEkaYYUgSuMKPwgQbH0ADJMaPIn2QjhegeW2/D5L6iiVeec/SXSB tjRdT4F1ro4/2clYVBGePjBK5D8HFHBOG+MBAKQINjjOiOEnADrMsyR9AAFCBC/ZSuMooJbdMEoB 4c22ag6xwg5/4g6pMDw4WHSAEOnC+hnNPLzEQIEAlgAwMAO7K5WPRkobS2Vwwt7YNeMONMJKDsXP P8SVDidJw7042LxOlQJSeQAOALtdPECBGwf24YhUAdNw3Rspffa8AV4QAUA9xHBiL1IHv7IQhj9U DgDjvjggPL53ogCBZwERSQBGgfJPQEnHEgG+bs/n4jjK3MQEDq7zAB9yMUr2CRBAtpV9tjvEaVXi 3BRsptM2FYJe7eERxLKyPziBlZULtkE/s9AAJI9TUDjESk0ZUg4ExwAOYksZStiVzOHEkwFAlWlO Ad4bqKmPv26O3MQOxAB+ADuqyPIAxA7MSl3u50AwcAEbJwBAOgNKvsABEuInIFgOB3PArIfCkk4I AaRd07ZKzMVpRwA7KLYOVCfuDsRHPERpFX8kVuxUgQDneTjYAUuVtgiScAjYlbMCJwDgxH2FlTi5 INMv4U9KwumxbkB3AT+V7B7QUdN9ILPwXe72zbMfAAFLJxLV41UkutgC2DwsAQ4OCMnwDi8ATBtw pUFKyABYAEDjCNzEqlIAQJZTssySRgB5OPbqBBuW7y3nUSBYDhnz4wA/CMQbPpVclQDVYtMb0+cH 58QvAABKDuHYR9NwAEVA4ATuwgBAVHDuUX2RuT0aJKWuooh6JwCd8iQOxEA+4+B9Pi8klcRAQO9R ID9sQhlikyDoxEc39iqoapXEAQW/joFABEBaSgAaiQG7ECkOgQEAAUBYxzi2hwTcOLNAAMQyAQJA igRSQMxAwjTHSiRmKIjdAD1WTlxOfcTTzJXMTuKPDsIOsgFAIgABwusIBk1AVsIOAH2yAEAokAEA AEe2J9e6KVMASZbE2LYASqSrCJasSqyWzA6CPJa+t75wSi8kCDrhxbHdCLuW9oDjAAbMfeFTQA7j BUobxAQBzfZKtThdGgjnlSQAIHC2lcLsQHYAS5azoUqoDvbhCIGVAEAADqtpACRAatNd4okAGwHs NJZKICgBPQC4gsO2RuSDPIjEDji2VTIHAQBwAAgHUtfhxJYglemN40AyMpZK9j1PvAABH0tJQC8O x53EXsQB9moAOUsgZnB1OjGxXKfCQOHcBwBilgjERwFU20AA4Tz4hQ7ElVEAfrYBGkvpDkKBKSjM PxqexMQpKADhYj/EAe4IwkonhZbXsycvS7ZWfbvzxONAAZVpStPT3atsYPDM19AIGU4nCB7OCEk4 zhsHAAFAAKFA5y9KAEvw4UPRPwF9Sigfu65u0ADyILBHICI4arbCVJWBj0DCAMTnW+OPnnDh4Utw 4VgAbOMHCDiTmVGV8niiniA0wSAIUW4atg7yVOc/xJKsxz5pBLYekXm+eaVACPbEDidUNkkmATDc CIbMJzHFQZUOQwEIDgddCJV0OeGqzbZ2Fn3dlQEOgQ4bCLZAcA+VquVcN2l0Sl1MTAB9TUrQlksH toEgaUdU0ABdvMU8ni8OZUoMfgDntgCWoWcXOFZkttCzzg4gU6QBPeMAZNspVHJdaQApGBBOj5Vw cYG7xFHEYeHCAHB4IL53RKQ/HsS6AAAAP2B9Wxu8U8JKDnB/xFzHns00oYVATvZM8gCBi1aG1yFW kIF1Vj8F+GnXBdRp1gUDacMATP6G+Xj7EgAa/pf5cPuEAAAAAAAAAAAAgAVEMDIALc0mvpIAk0w/ qQAI4HAABRtKAM0ISjABJAAAAAAACP//////////////////////////5RSHgRDaGtf///////// ////////////////////////////////////////////e1+H4zKZeYTPWe9j9gyOoETr7wVGvUyG ////////////////bS5caE5yxbFfthp5MgkCdP/////uY3Wt/////18t4tsAAAAAAAAAAAAAP8Op xgAAAAAAAAAAAAAAAAAAAAAAAAAAbNLqtht/QM1Ab1vUAAAAAAAAgacA9wGLAaAAAACWAABAuthv BAH/////cAcBAAAAAAAAAQEAAAAAAAAAAABY1vD/WBbi2N2B4r/dgeK/3YHiv1gW4ti8+Ro2vPka NljW4gZY1vD/WNbw/1jW8P9Y1vD/WNbw/92B4r9YFuIbWBbiG92B4r8A/wD/ALAAlQD/AAAAAAAA AAAAAAAAAGUAALjEROvvBQAEAAAAAAAAAAAAAAAA1SEBADp6AAB5/VjW8P8AAAAAAAAAAAAAAAAA AAAAAAB5/QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAef1Y1ljWWNZlAP8AeQD/AHAA//8AAP8A AAD/AAgACAABAFir4n1Yq+II//z////8CAAIANhK/QcA0P/MfWD/fwAg/hJA/AgwAQABuAgwAQAB uC95QMwAAKnGENoa17z5GjZYFuIbMbZMugAB/wCqAV67AAABAAAAMF4BAAAAQAAAAJUISgAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAF9AAAAtgCzAX0AAFgWABsADv8hAGUASwAvAKYAam1JsOhJ EYyUpqbHFDTXXPI+lQEAwD3TXCeh6ucnCHB9yM9RXZVKIHl9h4EHzMF+wwQl27QYAc7ggclCImWr JYDFdq4ATJWpKEpcDieuXH4QACieJTrTCepAAErIfho6G2UBUMwFxADTfQe/w2opzExHAHxR6jlc lSKsfyurQPYAmVs0L1IBhgEI5geuuq4OxxZAlUDmxwAbKCeHnQfzgJZd0pZWAgAAIwC7P8XHCKFL pJFHALQIhzlACgAICADMvgAI08znln1u84U+XEpKyQE8AKjyCEaWVNikVtjTxFgOSgdcDiQbyyJ0 x0o6xzx+UQARQEqXlYWyx2FdUQ5MSi+4P/ZD1hZHdQB+uxkStEpHxTVdxENJmsTBYNjH2JXMAXfn 6gAAlQmAfQ7EurEOgLaVgSzMxUdHfoQBlNDmouFpfYPTSQLGeYEIhyRJ+UkMgEkw0JI/4fYAxJVC POAIywA/lpaxxz+WEowTAZ48tsfYQGlACdtYACJA2NMBGysIttPOsSInrMAAJW4Olgd4AXZGfbZ0 5yDvcL3CYD0HZqJLXQ4EAMKVXE1KE0rHx146x0lwAbsqB0yB3Ic6lTlcwwA9xd1d3QcvGzgIsG/z A/4I+rY6ML7dlUrqkZUxBFgB5q4HpthwrpZpFAhPOhsEAOG9DlCVOr859pWszINSKZ6W/GlRPSfG 059/HofNFknYATDTcAfYziQEzup27sdxqpUF3G8IcD5+44HjIMRAXgBiPzkSlTspoRYbCD9+Ssd9 VnmvGi+ZDsR6cF20BkkkhenEBwDqxAHjTyCF3cy2BVIDSh6VAfIBAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAABAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAANlIEoHZAAAAAAAAAAAAAAAAAAAAADQAQEF9633mQLJA1wi+CIUIhAgTCOcA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAXl8E /QQHDuDYaxvOfQd9R0DgG+kAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAjiaOJo4mjiaOJnCUcHtw74r1ipQAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABQCzxDwHG5a7TkoAtEDllsJph5bEmWzY 0zwCANJwDlPNan5vVgGamgDTWQhAJJZKaUmV+7YptjoS6ns2QFSrkkkANAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAHGT/TAXEBgJ4RAL8IADppAAAACgAAAAoAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAAQACAAAABFI5OAAAAgAHAAAA BDAxMDAAAAAAAAoBAwADAAAAAQAGAAABDwACAAAABQAAK3QBEAACAAAACQAAK4QBEgADAAAAAQAB AAABGgAFAAAAAQAAK5QBGwAFAAAAAQAAK5wBKAADAAAAAQACAAABMgACAAAAFAAAK6QCAQAEAAAA AQAAK7gCAgAEAAAAAQAAHLAAAAAAU09OWQAAAAAAAAAAAAAAAERTQy1XODMwAAAAAAAAAAAAAABI AAAAAQAAAEgAAAABMjAxODowMzoyNCAxNjowMTowNAD/2P/bAIQABgQEBQQEBgUFBQYGBgcIDgkI CAgIEQwNCg4UEhYVFBIUExcZIBwXGB8YExQcJh0fISMkJSQWGygrJyMqICQkIwEGBgYIBwgRCQkR IxcUFyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMj/8AA EQgAeACgAwEhAAIRAQMRAf/EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCxAAAgEDAwIE AwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJico KSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZ mqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6 AQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYS QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQACEQMRAD8A+qNwDBe5 Gf8AP50LkZBycHqcc/l+X4UxC0UhhRQAUUAFGQDjIzQAxpokOHkRT7sBUbahaKCftMJwM4VwT+AH JoAT+0rMAFrqFMgHDuFP4g8inLfWr523MDY64kBoAI722kJCXMLn/ZcGuN+MGoW6/DzVkSWN3byU CBhk5mQY/WmXT+NepxscWuPalDNYWqNbRxhRE0rdx97cozz6d6hv9JuZo7x5tXvpcQYwpWIEgMed gB79M962cJy3f3GXPTj8Mfv/AMtvzI5PDGltqJ8y3FwwjOWuHaYnLDB+Yn+6aiS2t4tPsgkSRpLK r7FUAdTJ/Ss1BJNClUnLdntvmTCeVvLVwCAmVdSAQM87Tnn0449QalVpzICyIBgggPx9eV/zmsrs sl2t3Y1DOZUTKRSSMBxt25/VhTdwG+XcyBSrCId1kTdn8mpp0/zMGVo2IOQVjxz+ZqdR6Df7MRMC KNQAez7fw6dKYmiQKVddyOvTawAH5AU7MCgPD9yymS21CJGcEkzW/nEHv824H27VZsNBjW3QX/l3 NwMhpVDpu54OCxwce9SlJPcp2aJY/D9igXMK5HXazge+Bu4p3/CP6bnP2Y/9/G/xq9epAq6Fp6AB LcLjvkn+dTDTLPHzW0DduYl/wosADTLEY/0O246ful/wrh/i9DaWPw+kgSNR515aRoTySfPQ9Tye AetFrsuDs7mZI+YW/wBi4iX/AMeQ/wBaqzDAuQOc3MaH3DCNf6mu2TORIhlkEc11cHkJAhP/AAHe T/MVSlXyhYwEbikZOP8Adj2fzYVm9GM9v8sCTzAo3EbSenH9ef5mnMMjtntmuc3CigAooAKKAK2n 232W3aPJOZ5ZP++pGb+tN0uOaK3kS4ffJ9pmbrnCmRmQf98laVh3LdFMQGigArzX4zv9q8GaMFP+ v1W0I9+Gf/2WhfEivssou6xearAkNOCMDJ+VFbp/wGsL/hL9FupJYUvo1lW5XcHBTldjjkgZ+Uoe P7wrplJJXZzpN6IgvfEOmol5GbkE3JKR7FLjGxF5IBwMk9fQ+hqtF4s0nVNQkW3u4mkhMkRTeNw/ eLzgHp8uQfQisnUhPSLTZXLKOrR9CMCV469RzilOSOOD2zWZoFFABRQAUUAV7VZFmu97EqZgYx6D Yn9c/nSW13DNPdxoQGgnEUmePmMaP/6CwqXJIdiZpo0IDMBmk+0R5wMn6CpdWKGosb5rtwIyDn9M /wCFNNw29gQi47Fual1H0Q1FEf2pmBIYg9h5ZrzL4zvPYaV4WsrS3kMY1qGON3wyLiGQKD8+49c9 P4TkjjMxlJyRcYrVev5HN6x4kvtMFuStvd3JlYrBBDIT92RQWIyFU7W5OPutjODXk/jHWjp2sW1/ cwPFCsHnFA2HTzMgDYTnpFg9gcDOWGd8RTnVpuOhlCUIyugtPFU89naXUlm8MUkywOz4XDnIP0GR 359q53Q21BfE6SwQI0bqHDbtiMCCxOQCAdxJx71yYbD+wk+V32/A1lU9ove0PvegnAya7DEMgdxS b19RUuUUOzG+Zz0JHbAprz7BllIFSpuTtFA0krtkL34UHjFRHUxk8Cu2GGbWpyTxFnoA1OItnPLD H3uB+H+e1P8AtsTDDbBzk7hnNEsM7CjiRXuIDs2xGTJA+Qgbc9+SOB+ftUrRI5B3uPTGK5p4ex0R rpjYRFcRiSGdZkyQGDbhkEg8/Xj8KjuM24QEx5d9qAFUJPoN2cnrWMqUkbKaZXurye13SSQlEA5Z mIC/XkivL/i1ffbbjwpp5P7m51N5C0RKHCwuMhlIIPz9Rz71ML86TXUtJWfo/wAjgtJuNQv7+XxJ cXNrLYMJjYR+V+9hjjncNk8dcj1z7Ac8H46g87U4UkEsy3GmRh1WR2LSK7MAeoHynOePukDrz6Te mxydUjDTUpLPwzPdLiaOKTbCOinkIcemcn1zz06Vv+GwBp897wwjSVyc5IIJGM8emKxs7oq920fa xjkJGZG/AYo8kZ+ZmPvurlVNvc15kirLeWdszJI6gg561VbxJYx5CuCfbmu2ll85anLUxkVoJBrs d6CsJAAOCSM/z/KiVnLZLtgdB6/j1/8A110RoKlK3UwnWc1cz5ZGTG3CJ24wcewqpJcEIcsT7V0p GO5VF0+TtJ+venNdlSBncx6960SE0ObVTAmWdU5AXd6k4Az9SKiuvFSadH5lxMkKg5Abkv8ARRkn r9f51M1FK7HBNuyOQ8QfGAw3aT2VkJPs0Uswubp2CxYABAReTkNnJPY8dK5e78eeJbho4L7XpjJD GVZLJ/s6c5GcJwwyOM9gcYzXmVZx2id1OPKtdzldsQCKsKxrHIzoABhSc5I44PzHnvk+tWFtp5zF cmefK4VJUlZGwowOQc4A6D6VzORomWzb3/hzTZ7+yERszIzy23lgbTIVGVwMYyF447nnJrmZbc32 rPqwzDM6KqonMa7eAcHJ6cdaKVWavdlSppmZ4tsb27WEXFrNLbuVDmM5QgEcezEk4OOnFPtrprLw LeS+W/n3kTSLsjOxWYglc9vvceuK3c7q4UIe+k+59Q6j8SUs443nls7JJf8AVy3E3yN/wLgfrXK6 j8bNOtVmH9tedNGeIYIsh/8AdkUMv6/XFexHC0qe+rPM9rUntocrqfxz0xLhJINPubnILSreSrC3 1BUtke2Pxra8PeNbvWNIuJr2yGnm9UyabIzYZoShw2QFIAOGDEYYHjoTWdbFRh7vXsONHS7OS8Uf E/VfDiWdvaajdalq4dZIBKscexOQdyoPmz0+YnJ7cZr1vwT8QrHxZYbUIgvrcJ59uqHIU8BgvUKT 7fLgg9MnkVa9Xkl1X9f15Gs6VoJo3Z2V2EiEA44IJwenUd+gqqZgqnJY55Ga7EYJFOS7cK3l4GOu 7vVE3cqsNzADgk5AGPQ8+n8+vo27bjSuYOp+IZrf5IAH5x58hy3GRkLwP89K5q4vC7tJLNvLAgsx yR/n+lebXrObstjrpwUTMvn+QYAKv696z7iQbVdkVJNoXEYOGwOTk/WuVssgSTJb5eD6V0nhySzB hF1HJNGjZKA7QeRwcH+VZTZcNzf+IVpZReE7f7D58RnuEWRXZWDAKzY45HKg1w/h/T1vb6G23x/M cZZ9g6ep4p0rOLsaz0Z6JceBHNi0b2UjRkDlVEg9QcrnnPNeOa9bHTfDtrobxTRXS38cDB4nUMsb YJBIweFzWlHRSuNpyd49Dnfi54sli8d6ssMCBm8krIT/ANMk7YrjINV1vXbv7Lan5psIUTCooJAy WY4UcjJJAHc1218RUcnG9jnpUoqKZ6lpGl+GPhzp6z+Jo4Nf1iXZcoLi3keC1RQ67U3AeaxLrkHC glT1UZpa58bzdTSXFlp0txcS8+feNgZ7jYvUY6fMMelcdB8rdSW728l/m+v3dBuLqO/Q5Wx1HVmv LrWbhJVuzKs/myggnByAo79BgDAGB0ArsvBmrXF1JH4nivbptdgnlkkkZ9ocNx5bKOCh4OOnH4VF ST54zX8y/HT9S6sUoeh734F8f2fjixZ4oHtb+3fbd2Tj51bp8uOoJ7+2O9dFNcJJGSoyvqP5ivbg 7pHnSVmYt7ci32lnO05KjnLcHg+3H549K5q/1PMgIWVXdctlcAcEcd8f/X69+TE1b+4jenG2rMW7 1GUsBkAZJOR09gfyrJubkoQXIU43MDjgAng+/wDk1yWSRoynDqkF3HI0EyzLE2xyp4DDggH8RVQ8 u5kdUBO4KOMnPrWSGWBgRod24k5Ix/n1q/p8lxGA7LtXqqgfM/0H9aylqXF6mpqEuo3unyQlnMbG PbDvwpy2AT68+vHT61jW/n2Nz++RoipI5Hfjv3/+vWsaMqcbtbl86k7XOrtvEeoRWbvFMVcJhX5B D4GDj8Rj61xXjfbca54fsw3SSScj/ZwFH863hTcad31Eqi9pp2f5M4fxp4di1rxtBdyEnT7ny0kZ M+Y5AOVUYJBwvUgDpk9a63wx4UsfC0Lwzi1tXcN88XmC6YnBG9tzgAKxTAUZBOQTzWVZ80rWvrfc 2pQjyNyla2m2+/nt3Ok0jVPDdnpj6ReaKlzbh9yO9lAsQBBJ4RV75HCfxDryR5rrk8GsXw/4RTw3 cJbGHZIJ5RHFGRnJPzFQgHJO7bgdsE0knLRIWibd9Dd0v4PpD5p1fWZ7xhBjyrZtsaS5BOHYN8oB IwFzkg+1WhplzpuiPcWVjJFY24BkulQ7ER/u7z0TcCGw2GO8ZHNd+Eq06F5tXfTt6/J2/rR8OKpT rpU07R69/T566/53WTHrd5ot1balZXIguoZRGrgf3ifkkXupxjnuR7V6Nc/GWO80mOS3sWTUpAFl im5hjxnPQgnI6dOvJ45X1hpyu731+Y/ZRsklZI19MvDq2kpe3ErLMo273G1jHwVYqCdrMpB69G4P PNO6mG35HYgYUsT0z79B1/n61xuTbLtbQ5m8vpPOzkFsjo2M96pXUIv5i1xGrh1YN8uG5IPBHQcd vQdMU5OyFcc0SWyhBEI064UADnn/AOvSLG1zdRrDD5jsCAB9PSs47gtzYt9NFhC0l68RlA3Mc/u4 vqe59v8AEVg6j4pkW4b7JapPEV2NI4Idx/Id+PepowdRuS2RqrR0Zp2njnS9QJjnc2U7PGQJOnDA /e6dq2orkThZY3V1mnb5gcg7Q2P/AEAV6cKiloZTpuOvQbLMrRtu/inH/jrgH9Fri/FF+kHjKCY7 WNpp2Cu7uxJH9BWns3UkoLq0vxM+dU4Sm+ibMLW9V1KO9TS9Inijs54xP5twgDyFTyuB2O0kLkkB jz3EejXWrX8jxSy2o8viRlRiE4+6Bnls47jHvXDGPNPl2OuUrQvua2pyi1g8l7kyTSqU2RLghT3P PHt/9am+C40eyukvAJHE7jplADnIH47+euG4x0G9KKjUsZzk3TO+8JWfiHxMJme3fyLZDvvWkVBK VOFRmb+Ikbd3Occ9CSnh3U28IzXDapDbX2lXDPFqttbyGRXgclyykqhLpI7kHr2UnIxglJardFOz 06MwfH3guz8M6zLHD5M+m3qefZMo8xJIJCduCT0wp6ngjPoTxcnmadOLaXzGiwPKlk554G1jnk5I we/I6jLZR5o6MJKK+H+v6/E63wLq8cE8tpc3KCKU4WIqSSSCSQT8oAxjHUlhjuR018yx5CxhkyVH UZx3/kaqaSZla7K9pDDPZXInDGZiNpxgDFUBELYncN+DwntWM5CaLlj4dvtb/eOBHAhGZ3OF9wO5 PtWtNbaf4YshMS8SuSBnmab3/wBhfy7dD1i7k1BGsFbVnH6vrE1/hfLRIVP7uNThVH4dawLu4hOd xz6KDXqwgoRsjNtt3Mq4mByCoVT2qTRIdYvLoR6K0sbRnLSB9qIDxyf6deuKioopXZpByWx6Ja29 9BaRpeXUdzKjl2dYvLBznjGT/eP/ANbpXG+I4LtdZ1DUpotyyxRrFHHl2KKPmGPXPT6j6UsFjIfW Ie1dkmtfTuZ4ug5UJqmtWtjL02LUNUKpBF9lhjA855AC755wB0HUnnJHGR63murfTEW00tVeRvlM p5UH27HrnjgZ96cV7vO9ym7vkKEkgWcMZGkAf5iG5b1PP06n2rQ0KTVJriZLRAstyVaN5SfLRAqj ecZP3gVHGATz6F0ac6lRRgrt7Cr1IUqbnUdktWenxa9qX2WytJrpWt7Y/PEsahZP/HQpPC/MV5x9 0Z4i1C4ieMSoo8xoyzxou0BvbnvjpwBngAYr658Mwo7tyctOyi+Vu73urpLpv1dj4RcYSry91KEY 6u+rkuZKy2s7Nt77dFczda1+CTw2ugqlpc21lIXtlkU74QwCvGj5HynqQP4hnGAK4hIobhmtpkEk bgmMnp8w6Z/rX53Qre0m0ux+jYlwj+6W8Xbt63fk9vVlK3uJLe7h8zKSht8WCY3cAnIwRlWwPTkf MO4Ho8F9/bNjBOknlgIquo42tjJ4BPXORk5wRXXJ6HHbW5NbQStIIo0ZmYgIoHLH/JFdvoXw6kXb d6yrvNJjyrKLhserk8Ko/wDrdeDy1JFQjzMzPGnjSx0J5LGw+z3mp2zEeVGCYLQY5Ax95gOD6c5w ARXkM3iS+u75rufdNI2ctwCM4yR6dB7CtIQsvMdSdnZbD9Xkt49ON1D5kTqdxiwoDISACMHjndx7 da5x9ZgceXkx45wRkmu2nV094ThfVGhoVvpN+7y6jqcESIRiBpPLMnvk9u3HP079tC/9mQrBBGiw r92NRjHr+tcmKqtu3Q66FNW1JU1JLheDtI4KmmzbHgJlClM9x6c1xwTqS5UXP92rs8xj1ppUlstO U2lkTkqBliD2zzgZ988896uQoIclm3bYd7ZHCjqD9Oleu5NnJFKKJLW2uNZuJILGIMgKqbkv8sY6 t09eMYIJHthh3Wk6VaaPAI7dBvIAkkI+Zz/QegHA/PP23C+W2Txc15L9X+n3n5/xlm1ksDSfnL9F +r+RoByx+UZPoKgvrmS2sLySKBppo4HaNBncWAyAB6nGO/Wvrq0nCEpLdL+tD4TDU1UqxhLZu2ui 17vscBpC38GmNaanDe2swi228Vyhjfy0AWQZ+XBGEIJHPmHutaFrBcvbQpd30l88QxHLJIQ2xmLD k5OdxJOMHknua/EHhXRqNNWd7/K3/BP3X2kavvrW7YamLaLTJJdRVTHw5Yb8qc4428n5gMEdDzkV c+EesXPirU00qVpT57LFbtcEqZUQEbgSdoCgAELk5KgVWyZe59H6VoOkeEdNuL8TwI9uP9J1S6O2 GPPVI89T0XPq3cgpXl/jf4w/2zNc6N4dlm0+xlf5tRyRLct6k9UQ9PXAA4GVrGMeZ3ZpKSgrHli2 twrxyyP5eWypDAHg9R6Veu40HlTOgzIh3YA+Z8n0H0/Otm7OyMIptNsabo3+i31uEj3iJuSRuCKA RgcnqT9CK4toSAM/MM+vFVDRWNovmK09uMbskcdD3rqfDni2W6MWn3QMz7hEkucls8KD3Jzxke2R 1NRWp88dNzalPlkdC8i7irLtYdQetU9a15dK0cyFEd0k3Rl3I5xwMY5x16ivPw9TlqrS5014c0Hq cZaPBapODLHEyjG+RwCTjJA9Twfc5x1wK0NHsbrxQ5M8YttPVslhktLjsM5HH0xk98Aj6bLMFLG4 mNJfPyXU8HNMfHAYaVaXTbzfQ72wt7fTrZLa2jCRIMKB39ye5q0stfrVOEaUFCOy0R+L15zr1JVa j1bux63DIwZSVIOQwOCD9aRpdjkbgcH7w6Gnpzbav+v1M+WXJvont6/8N+RzPj3VWsNOtrp8upvF EhIDHlWO4Z6kEBvqKoaTqaXkZaJhhVKKokDBT1OSCQ2OSPfB4r8x4ohbHy9F+SP1fheV8sp37v8A NstxwHzXNxPFKeQ6yBju+ox3wevr60SWj/YoQrCDyJTKs8IK7W2lVA7cK2MHIJJ4GcV88z3rtbG9 rvjTWvG00Vvq11/ogCCKFfljjYAgPtzyx+bJOTz6AAYItDDKu6LCED5nGfTnGPUHt3oSsrCb53cm 1S6URRPgE+WASR1I+U4456fzqgsxvLTBLbkm2lApDvkdQCOny4yOOvWkl1K1bNDTr22vrmW0tJ4Y YUXa6r9G6sM9x79K4hw8UjRZA2nBDc1UV3NY7aEbb3GMAjsOlQ2Fw+j6vbXTI4EUqO69Syg5OPyp so7zWfEWmz4k37JCQSX+TjBIOTwRgDkZ6rXH6lZXfiW/iMU7tp6bSzlSgwx525HPTAJ/oTXFTp+w TqTW2z7+nyfyNVU9olFPcj0fQX1O4S/1TPl5zHbtySO24/THH06AYru4LkKoAwABgAdBX6nkOCWE w/PL4pav9Efm3EOLeLr8kfhj+fVl+GV2Qvg7AQCewznH8j+VP873FfR05XWp8lWppPRB9o6f0oFw fujFVJ6bmcIa7EN3p1jrKC3voxOkEyyhc8bgD19RgnisHVvFOnXWqWmn6a8cqW8bJiE4QEgBFXBA xgFeOMsoHcV8ZxF7GMak7+9Ky+5p/wDD/I+44dVdunTt7kLv707f8D5lsQl4crko6lkCsNxAPr+f A9u/FWreONHMUzeY4+by8ZHHfr0wO/5evwx9pa2hUvLlElYRouV4yTgJ+XTGenNQahfNcPbRRSmS SYBgVP3STgn2Gc9fTvnFMQNc/YC6WMkoe0O12OCqqy5J2nhQAvXpjNJYtNFayT3CxedLKzqyJtIj yAAeoBz9OD9RRGKdjTYw9OmhsPFV5GY2SGVY7j5emOh/8ebIFUNYlhttWuYFlQFZCQrcHDcjr7EU 5aSZpHUqGdxKWCrkdwaW5uFk+8CpP5UiyWwtbbWI/IeeSC4g5DIgkEsXUgoSNxU85z09l41tKW5g iR2u4XVXAiaNuAhx8pzgAcAD+eKwrzjN+ye/Ts/IcItLm6D4LojpWjBc+9frtOVz8xxFKxfiuc45 FWBcdq7YSPHq0h3ncE5wO5qvcXxEbbVIB4U929awxeJ9lC/U68uwPt6tnst/8vn+RzjQz3ujavY3 LyRkzI6n/ZLsQSPTP6Vwxgu9NJu1JSW3mCSIGII7jkHocdQe1fn+bJ1pxnHXS36/kfouXpUlJd2n +CX6HrOn366lZpcfajslVZvlTcwXaoI68kHjr6Dtmp3IgAkceX/EyEcsCFOT7HPp3714m6Ot+6zK vZLO1jmF1cSRBdz5ZPlQZJznJ654GO+AOabYS2j6ZBKbtfJZW8qZkdipOcZVhk85OT3PepY0iHTb dLf7UqXcLec+1ymN8m08YGc8Y255xzx1wpDRzsVjUW0sRQCJw5JH3dwH1yecj+RezuN69TIubWeH X4rmVjGYY1jAUhmb95z8vU8Z/Q+tZ3jSwdr3+1IlYxTxoXU9YjgDB/LGfX8KuesmaU2c0sjqcqxH uKsLeSsAC2cdOKzNC/olxd3OuWi23yTyTBQy54zwSfbGc+2a0/GFzqek3ctlK6EOx23ATa8iEDhu x4289umeorKph4VZJy6DjVcHyrqf/9n/4gBITVBGAE1NACoAAAAIAAOwAAAHAAAABDAxMDCwAQAE AAAAAQAAAAGwAgAHAAAAEAAAADIAAAAAIAMAAAACh00AAAAAAAAAAP/bAIQAAQEBAQEBAQEBAQEB AQECAwICAgICBAMDAgMEBAQEBAQEBAUFBwYFBQYFBAQGCAYGBwcHBwcEBggJCAcJBwcHBwEBAQEC AgIDAgIDBwUEBQcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcH BwcH/8AAEQgB4AKAAwEhAAIRAQMRAf/EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCxAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcY GRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKT lJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP0 9fb3+Pn6AQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsRAAIBAgQEAwQHBQQEAAECdwABAgMR BAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVG R0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKz tLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQACEQMRAD8A /v4qKfb5E24fLtOfpirp/EiZ7M5X4eyTS+A/Bck5zM+l2pY4xk+UvauvrfHRSrVFF3V3+Zz4GTdC m2tbL8jiJGbS/H9s2Ctp4q08xE9vtFs25R/vNHLJ+EHtXb08XryS7xX4Xj+gYXTnj2b/AB1/UKK5 DqCigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigA ooAKKACigAooAKKACv8APq/bo1Ma7/wVj+ICq7SCy8UXycDOChm4/lXsZco+yqc3eP5s+i4cdpYl r/nzU/Q/b/8AZYiI8JzNt2tJdH15wgr1X4tN5s/w4swd3n34JHr93/Gvv4QSxDvtr+TPyard0dP6 2Pa9RPl+acfLBBj8gtfN3xckWX4mfDCxZv8AVuWIzx99f/ia8/Cy1+T/ACNMRHRr0PbtYvre2aea WeOFIYjySO20f0r4d/aJ+KHgXSPGXw1tNT8VaJBBYTl583KnyxujBLAHI6GvGjmVCg+arJLR/lY9 GjldfFS5KMHJ9kmL4n/bt/Z40F1CeLJtblgiC7LK2d8kLt4YgD1718PfHX/goh4O8V+Fl8NeEvDG ts8k6O8t7IkQIUk8KCx7+vavj63GtOnNexjzNH6Zk3hNj8VFTxDVOna93vb00PO/+G6P2irrwxo2 g+B/h3bW9hbpsgmjsprl5SBgfNkL6dq4bUvGX7e/j6w1LUbq98S6HYFSZVjEdrsQAnPyjcBjNfNY jGZhimuV8sXf5H2OHyPhnLIqVaftp9vsv/I8u+En7OPxY+MUl8t5rt5YWyszSu8jyhmAzk/MB/FX 054b/wCCctpKlrJ4k8aaxfP5mDFHGsaNyAc9T6960o8NP2k1WfNJb+b1OTMfFXlhyYGiqcUtO69G ee/ED9kLwP4d+LnhvwrpSX9za3Yie4WWVmB+YjAHbha/Q/R/2afht4Xs/D9snhjS2v7RYj5hgTcA SCe3pX00clhSnCMFbS7PzfMuLcXjHzVqjb2Ow1jwv4d0bw54lvINNtYPs8UjgLGBgrF9M96+UP2Q fB1i9zr2tPbIXM7uHx2VS39a9HE4S2Fkl1lFfcmfPRxMuZvyf6H9r9cz40vDp/g7xXfKxVrPTbmU HOMFYmP9K5MHBSrQi+rX5npYqXLSnJdE/wAjU0a0Sw0fSrGMAR2VtFEuPRVA/pWlWVWXNJy7l0Yc sIx7I5Dxqpt9LtNbTaJPDN3FfFj0WIEpcH/vw81deDnBByDW1R3pQb6XX5P9TKmrVZrvZ/mv0Ciu U6QooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooA KKACigA/Cmocg4LdT1FMTHUUhhRQAV/nTftE67b6t/wU9+J+qyTeTax6/qUzyucKMl+STxzmvYwH KqFRy/mh+bPo+HKc5SxKgrv2U189LH7M/B39qP4EfDbwTBb+JviFottfCRnaKImZ+mOiA+hrzj4x f8FF/gnPrHg6bwtB4i8Rr4emM0uy2ESyZ24ClyDztPUV1Y7jnB4as+V8712+ZzZL4R5vjo2lT9nF W1n7q6HF+If+Cn/j/wATS3Nh8OvgrNLLN+6DXDy3DAn5fuRoB17bq+efFPx7/a++I3xA0WPUdIu/ CuvrGfsMcFiIdiEt8wLbm7Hn2+lfDVeJMxxEn7CPJHXXy6/gfef6i5BlmuYYj2s7fCtr+qZ6Ddfs 7ftbfEQSS+NPiHqy20pCtDPqErjlsH5AQvavKfEf7GGv6P8AEjwr4O1DxRJqX9tKJJfLi2suXcYz k9Qv61y4fIalZuVVt6N+px1/EejhIqGW0IwtpdrX7z7M0H9gT4TaROf7WtL/AFeaJdzLPO5UkFeM ZxiuV+Pv7OPww8K6F4PtdC8K6Xa3d1dBGKQjcwCjvj6d6+iyfIKcZqTXd/g2fn+ccY4zEturVbtp 8j7V8N/DXw34Y8LeE9PtdMs4ysQZvkGQeM/yqPx3ZWumfD7xfdLDHGILOYjaPSPA/nXqZdgY+7db v9T5nE4met2eSfsraBb2fw81a/aMK88zEHHYso/p2r3iziV5IQwDZdj27bzn866atFc9T/EzGNTR XZ8Y69ANa/ait4SAV05Ix/u4Qn+ZFfZWuLjVYISB+6bbjHXahrpxNP8Afv8AwL8jGLtG/n+p498W bj7B8LvF94CMvb3ATPHJ+Rc/iP1ryn9lqwGm/DbX9TKvukjncZX1wo+nIrPExXsoR7z/AENYdfQ/ sBrG8R6WNb8P65ozAEaraTW3Jx99Cv8AWvCw9TkqRn2aZ72Ip88JQ7pofoF+NU0TSNRCshvbaOUq RgqSoJB9wcj8K1qmtBxnKL3THRmpQjJdURTwRXME1vOiyQzqUdSOGUjBB/Cue8JSSLpA024lkmu9 AlewkZzl2EZxG7e7x+W//A61gk6Ul1TT/NP9DKd1Vi+jTX5f8E6aiuY6QooAKKACigAooAKKACig AooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKzNZ1rSPD2mXes69qVlo+k2Chprm5kEc cQJABZjwMkgfUiqhByailqyZyUU5S2Qmja5o/iLT4dV0HU7LV9NuPuT28gdG+hFalEouLcXuEZKS TWwUVJQUUAFFABRQAUUAFFAAeAT6V/mF/HG91/xp+298R9L0+dLVda1G4kkYLvK45wD07iuxUozw laEnu4/lI+24Hx0sJXrYqC1hBvXY/Yr9nD9gnwH4i8G6V4k8bz6vrV/eI7shmZIyAxA+VcdgK971 L9kP4SeHfip8OdF0HwlYWkUyvJMQCxkwxxuJ/wB2qy/hWlTk5NbX/JnicQeIuY45yU6rs7Ky0R94 6b8MPCui3klvp2i6dapE6p+7gAIy3POO+P0rw/U/DOnal+03pi/ZlZNMskGAOnysf/ZzXs4bKoRh NpfZf6Hw+Ix0pTV31Po2S2gM0yhNoMqDp/tH/GvlXW7FNR/aU8Owqu5dPs0yPT5XP/s1XCglGS6c rMp1G7a9T6K1OPdd374wcN27kk/0r5X/AGi4kvvGHw20VRnNxvIHHVo1H8q2wMWmr7JP8mYV3pr/ AFqfUerwBJNCtVOFhtkwPzP9K8Z+ONybP4S+LHU4M8RjyD1Luq1OAglKmrdV+YVb8sten6Gb8ArJ bH4P2RZfnu3yc+5Y16VYwLH5JVWJWNpGz/Dkf/Xrnit/Vl67Hxn4AhGu/tLeK7xiXW1laIf8BKIP 5GvrvUGWbXJiVBAWWT/x5R/U/rV17+1lbokvwIp6I+eP2ibwWPwi1FTndqAiiA/3pC+P0o+DFj/Z XwQDhCr3kUa8g5+dt1LEL3aKf88n+RdNfF/Xc/rMor5c+mOY8NERN4h01B+50vUZFj9hIqTkfg0z AewFdPXTi/4jb66/ernNhFaml20+52CuSkzpHiyGRUIsfFURjkbst1CuU/F4t4J/6YKO9GG15o90 /wANf0DEr4ZLo1+On6nW0VzHSFFABRQAUUAFFABRQAUUAFFABRQAUUAFFADWkRThnVT7mmrLE5IW SNiPQg4oem4Lsh5IHUgVQvNX0nT4xNf6np9jCWCb5p1QbjwBknrQtdgem5KmoWEm3Ze2j7uRiRTn 9aRNR092ZEvrR2Q4IEikj9aaXYTkurCTULCJgkl7ao7AkAyAZA61m3HinwzaQLc3XiHRLa3c4Ekl 0iqT9ScUWDmRWTxt4OkWZovFXh6Vbdtsmy8jbYemDg8VlyfE/wCHscQm/wCEx8PurMUULdISzf3Q M8nihK+wpVEt2Zlt8Y/hvPDNNJ4q0qzNu210llXcn12kj9anb4vfDFdpbxv4fAbBH78dwD/Ij86f KyVVXU14PiB4LuQWg8S6VKv+zKDn6UXHjzwtbJ5j6i0iZxmOF3/9BU0mmtGP2kejOX/4XZ8PQ0qv qeoRNAMt5lhOgA+pQDtWe3x/+GKvJH/bN0XjQSYFq5LAnHHFUqbdrEe3W1ihbftH/C28nFvaanqM 7nPS1YDg471DJ+0l8NkuBbCTW3fnJFsAFx65bPPb1qnSYe28iD/hpn4ZtcC0STWjc5wV+zD5fc/N 09+leU/tC+OPAPxf+Ffiz4ZQ6peabqPiKKM2tw5MQt5opEmjduDlQ0Yyo+8MjI6jXD+5NTvszDES c4ShbdMn+AniDwd8H/hPo/hldVtPEniOF3kvja3AUTOWIDDzXAGECLgY6V6PP+0A8UqpF4A1u9Rm xugu4XBHqMHHX1NYxje7kzaL5UlFGffftGXdg6eZ8M/EZt2zmQy4Ccd/3eMe+axJP2s9Etp5orzw hqcKwsBlblSSp/ixtFPkXVg6r7Fy5/aq8OW4Bk8O6vArgFXJDKeM44we+KyH/amtBJzb2lrERuHn WsuSP+Auf5UuXUrndrm3ZftHLIES6s9AErgEETzIv6xH+dWG/aMiCSg6TonmL9zy9UVyfcqyoR9B mkob3KUuhmj9pTzJzb/2RdWxDAeZ9i81D9Ctxis7U/jzqV7KsGna5Fo7QtuJOlt+8HOASzOMe4wa qDhdXMpSl3JtO+P+o2qN/aOu+DtSBY/MYbiIduAwj2/ia6Jvj5NLbR3ECeD1jk5Vm1VU3Y6/fAxV ShFv3dBRlNLXUoJ8YPFV1KTa/wBmzq43hYL60l2r64Bz+tSN8T/iBJbC4j07VhAwyskelLKre+5Z MU1Tit2Q5yex5h8Vfj9498MeAfHepQJqFlqOi6PeXaMdMKNFshdg/LHGMA5xX+f54IuW1/8AbV12 +lZ5hPd3e44J3HPPH4VlKP7yME9H/wAA/QuEof7BmFV7qK/KX+SP6w/gNaLb/DvQo8bWFsRkLg8t nj161du4kvP2gfCluOtnYCQ8cgFpMZr9Go03zzb7S/U/G6s9Fby/Q97jQG8kYBv9aP0Oa+avDipc /tI+KJmU40+3Vc+m1I88/wCe9KnT92o/L/IipL4Vbqe4MoDhvmx56n8uf0xXzBoKjUf2mdYlzuGn W6JkdsJGP5k15sdp+n+RvKN+X1PfHxLNM3UTSIvI7kn/ABr5X+La/wBofHv4faauCltGkhH1kY/0 qKHu8z8n+RNTXR9z6f1wEa3GgIX7PCoweg+UA/zr5v8A2lrwW3woe3DAnUrmGMf99Fv6UYSC56ev YdT4XZHb/Dq1/sz4TeGY9gTMYc5HXCZP866wIkYn5C/Z4ApYdOf/ANmuSm9PVv8AM1j2Z8c/s2Iu p/FLx3rjN5kZumfnpje7f0FfULOPtGqS87ooVGT7licfkK0rq1erbo0iI25U2fLX7Wl39k8E+HtF G4SXV5GOO4RD/UivVdBtl0r4R+HrBR5TXMkY9eETn+dYYnaj6Sf9fcdELLVdz+p0lgygLlT3z0rg vGnxA07wP4X8QeJNUtZn/sEH/RUcCW6cgeWkWeGZyQAPXjtXy8pPmjFLVuy9WfQN2Tb6Dvh3puu6 d4dafxLbQW/iLWrmbULuOOXeI3mbcI92B/q02x+nyV2Ml55N1DBLHsiuRiOTPBf+6fQ46euDXVjq 6lVlJbX09Nkc+EpuFOMXv19Xv+Jbz7f/AFq5bxjBf3HhvUm02EPq1in2q1HJ/fxESRjA5KllAIHJ BNYxqcrUl0NKseaLj3L3hnXbXxP4f0fxBZq6W+r26TBG+9GSPmRvRlOVI7EGteUzLsMSo65+cE84 9qc42bRaldXRFFcCVQyFSFOGBBBX6g8g/Wq19JqkcavYrZyOjZZZMgMvswPB+owfUdazbdtAUhYt QjeSOF3WOd8kIwwWH+zzz9VyKWeW9UI1uYJcE5BB+YfUE4I+hz7UubTQXMVW1QrsWYiyZjt+cAgn 2YHH4Hn2qOdtUeVntb6ERBQGjMYDKf7wPOM89Qaj2hTZnRahfW9z5N3PqjG6J8vMCMiY77lX5R/v 49qsJd6jLIs1lqNrd20vIQoMkDqUYY4/Os3Weo7JdSGbXLqB4UuLa6jWRiu+NA6k/lnoPSrsGrNL GXgmgukBI5OOc9M+36UKu07MvlW6LH9pq6Mk0N1b9i6fNt/rn2xVCb7UyyC08RL5wAZVmiX5R33Y wea39ou5ETm75vEjR3KXV1NEoyyy2Up3Af7pXr7c1yR1DxWAqaf4ykuZXjyIb2BI5WOflbgLgdvu 81zSr2dmzRU+xgLF4v8At8d5Nrfi60uZGbzBaXwmgx0wY5Acf8BUY7GoNYTxy8Sw2HjmaZ5pGXy7 iQwswA+6rx4II9cGl7fuNUknpsZtrp/jiwgNlHrPjxYjCcTpqC3oRs8gGUs59RkYGO1MN94zuJI3 i8X6n/xL8CZbnzLdjgYz0wecZ6itY4hJ7ESpPc001vxvLZzWurCe8tLjIfLLMrL745wfcVSh1PTI ks3v5r+wEjNFEn2u4tcsflwIywG7rg9fStY4uP2kTKi07JnE+Jvhr4d1rzXvB4l1CcrmJ55UnMRz yo3YYfga5O8+HFrZ3Njc6XLrzSafGYwHuJVKYGAQpJVjyep445qqmJurIUYWd0rMj0i8+L9hq62d lr/jSKG2iOY5vLu0LfwltrZXjsVAq9J438YtDMut6Z4V8SXUUrRype6YbdjzxglRk8jkE5PT0rz6 lGm3eLaZ6FPFPRSSaKbeKvDUMSXetfCa9tZ7kmOWTRpWd4xnI3Khb5cnIz0z0FIz/B6eaeFPF/ij wnqF2rF0vSHK4HLDJyAPp2qFPEUr8r5l+Jq4Yato1ys6PT/CGrW9sjeHvi3b6rBCCytcztbswPAU jAXHOM0al4a+McemSR3Gn6J4xt2yPLYRvHKpPckMSce3NbU86h8NRWZjLJKm9N3RwmqnUdMs2tdS +G8NpGPlZ7SFrdlPfBVl4+grz3W7zSbWGG+he68MG7QLkwFxuHO5sqcYAxycV6VPF05RvCWhwTwl SEuWcNSlZ6NLMwFvqOnXFqDGz+YrO+5jkENuIGeMA9McUur2s5F7IRBfNIGRMXAGEHDYBwOCFzz1 OMis5YmKv72geyk3ZoxpdJuILWzeU315NA6/uogHVCeVQ43sMjPT09K1NP1eWR9QjbWNiWwVk8uT a6BuhB46E4ziso5jT/nQ6uDna/KbEHi3xgJFi0/XdetbS3Z0lOfMaXy+SAu1gQc9eD6Vam8VeME1 EWaRi6hchWf7ErliAXxuHIwPb/CoeY0Frzof1WptZma+m6xNPd6jZ+EdUmu7rYkhjtpFDbx8u1Sg HrkjG3vWtaeEdVuYEMfhrxddPcbUfbprv5e5iF+Xb0UjJ/ujGeDmj+1KPSYvqdTdoq6f8OfE/wDa 0hj8J+LLgZXZu0KeMoc7QQcYwMZPPTBram+EnxGvZ0e88K6+8cT/ACl7NyxUvsIZcY6fNkc7e1TL MaVmlr6FrDSvfYqw/Bz4q3tzJ9i8IeI7aON1T/SYkUSrnBxuOPlxnkA88ZrbHwT+Md0LaQ+Fb20u IsDzGuIGIGCOnmDpye/XvzShjr3tB/cU8Ntqi3ffBf44SIh03w1qNtKEyR/acCgsOgI80854z0/C pZvgl8abtxA/grTZ2TAWe5u4PQHJO5u+e3bvmlPFtvSm38hRw6tZtG3F+zp8UruCGHUdK8M70PzM 19gAZ/h2p6c/X862R+zD44u4dl9P4TikRPLVhcSuQpByNxjBxkL9Rn0Aq416tvgt80R7GK05ibTf 2VvF0C3Vtdax4ZSzuCX/AHc02/cSM5/dgYxu/HFXYv2S9Wkga1vfFGkC3zuXy4piynBGN28DGcHp 6jvkCq1+qX3/APAKdOF27lnT/wBkJ4IlguviBILXcWeJbHfvz/tNJxg+3/1tqD9mHQdIjaO8+Iup RQION0cUZXoTyT7H86rnn1aFyx6IbB+zn4Fnu1C/FLWZ3fLeTHcW5DAcfdIPHStyT9nr4f6bbXs9 x4i8SzxbWfaqQsRwxPlqsOWPzDgZJIHvnNy398aUdNDxPSNd/Zx8Q/FvRPgtBpPxWh8fava3N7bQ XunzWMMsEA/evvdUGBuUYxk7l4717pefs8/DaOdJl+GN3rU8fKmXUgqZ+br8+R0HQfxD0OMKV6ib UpOxtXg6aV6a1V/xsfMX7X/wuvfD37O3xl1rQfg94HsorfQbx57xPFd0Lq3jMTBnEX2QpIRnOwyA Hpmv4R/gLbfbv2uvFMygbba5u3IHT5nYf1rowNFrGU10dl+J91w/Uk8lx8na6X5RbP64/hDAIPAX htdp2tZw9vXH+Jqjp+J/2h1wObHT0zge2f61+uU4+9P0Z+ETekV5o90tuZyRxmQn/wAd/wDrV80/ DZhdfG74n3nLJbtIufpx/wCy1jZ8lR36fqjW+sU+57dxxkEYlc4z6Jj+Yr5i+GIF38eviTecMLXc vPbGB/7JXnuNoVHfp+qNNfdVuv6HvUAMkiqAQDOufw2nkV8s63G2q/tR6ZbscrptrGMZ+78pPP51 jHT2j7JifS/c+mdZw2u6q3GyFWHX3A/oa+UP2qJmHhDwnpmCklzfp045WNh/WpwvxR5v6siqzsnb +tT3zT7MWfgnw1YorZ8jbnGDg7V/XFRa5cfY9K8RXm5QtrCW9OFVj/WuWlG8Y/11Kcu58s/slW26 x8Yasw+88mCe/wApH6Fv1r6PwSl6FZ/38yxZ79FH/s1XUvKtV82KnpGLPjv9q6f7Z4k+HuiAndPc SSYPoXRR9Oh/OvofXIvsnhXwhYqW/dRSS9Pw/pXNi/iop9Iv9TelT306n9RTHarN/dGa+SdPkt/i z8UdG+JWq6aU+F/hkvp2ifaQVN/qO5le4eI8bFIZI2PO4kjqK+Xm+X969oa/N3S/V/I+gkrtQX2t D60TgFQc7P5dqq3cEF1E1vcJvtrjjrgq2cgj0579jVOzQXMzTb28Nxc6bqKBL+yOY3B+W7h7OOBh uzDsfYitksGAIbC9j/dPTBrGlUutd0FjzTwrLcaT4w8ceGphPDbTSJqtlAQNrRzDE7RNnJHnBmIP Qyj1GfRvPj2K/nr5Z4Dk8E+jehpQqJRSb8hRTWiKdzYwTy28nmTw3lrko6SEOB3B7OvPRs+vUDGD L4kj0dR/wkU9lZWbyLDBfK5FvK5AGHP/ACwYtkYYlTxhiTtETrxi730KjTbdkjZkuLCWR7Vri3E6 r5hiYgsF/vFM8j/aWsO41+zs44bxdV066tbpvLRPtMYMrgH5YpCQrtkY2vg+4rSVaC1uL2ctVYhg 8b+DrmPUXbxDo6Po+Uu0kmVHtDjO2RSdyAjnnK4FYl94p8H2TRW2meMPDumXRgL2ymRHiZfXYrDI HH+qZTz0rCWKptJp6lxw8+xh6V8YdAmCR6+9np6sxVby3uFntZGBI4kwrocAf62OMDsx6mtc/GH4 UQ3Vyj+NNJS7tmEcghdiS7cjKAHcTjriTH88vr1N6SdjSWFmtUiy3xO0uKY/Z528QWAiMjvb28vm nldiopXZJkFs/vEYYGIzk41P+Ey8NX62062niAu8fmK39mXKmMY+6TsDK3J4+X61ksdBycX+Q/qc 90YaeKdTR7abR7fxPexTyOTa3OjzKYlOSDvVB5a544WYnjJHJret/E91d23mT+BvGcMqS+WyGzUk 8geYmXwV9yQ/H3R0pRxN3ZRb+Q3h/NIJfEesRJMbbwT40uzEwAQQR4l6ZKl5VJ/4Fs/GorjW9cu3 uon+GPii68kq0Du1ugmOOSSZcoR9D7GolWlqlTbLjQtq5pGde2fiu5+2tpvgHUoJXQNE1xqUCZcj BXaC4jA9V3Z7jvWBJ4d+K8aTLaaFppmWI+U8morjzDk7GTYfl9XDAtjOwdKiMq+lqenqa8lO2syb TPDnxTgSQt4U8JWVxPCAXj1V12ynBckLFhgfXAI960Y9D+MDLcpc6X4Gni8kLAJb6WRkk7lyIVDK eOAFIx1NVGOJ/wCfa+8GqfWRg3fwz+JV+L2S1Hgnw5dXSKEkt7i5yknG53CbQ+cd8HA61tr4D+Kj W01vPrvgafcqhGks5nKEfez84DA/QEepo+r4rdJIv2lG1nczb74TfEa/IC+LPDOmrHKksYgtJvl2 nlSPNAINa9v8KfGawtFc+PNPkfzjIJP7KBbaf+Wf+sHyj1+971UaGLb95pfiTKdC1kmxqfB3xM/k i8+I8kiwO7YXSoxuDAgA/N/DnjH45rx74na78FPhW1lp3xf/AGiNP8NXN/DJFCt4sKSTKGVmIAVv mXK8gDGRxWGJpVoJSqVkvkOnUpu6VO55T4N8c/sheLdT1fTPh98a/FHjnW4IY7m+g8P6Vc3k8cYw olkS2tGYbjwWIwTxXrE9p8INVQPcn48anGdswU+CtUXg8DhrAfKcfd6e1csGpaqvJ+iHVxcYOzo6 jtM8OfCDSHS90nwp+0BcTxCSHCaBqKllcFmUq0Cg9Tgnp0BBrOS0+HumR302j/CD9qGRrqFFkW10 6a3ZgBhSPMljy3qev96oq4alLScpsujnNSm04RS6bHyr8Mviz8NdG+OPxM+Dupfs7ftE+JbrVn0t oNO1WwtWWweWW9iMskkt6IljleMqrh2DGIj0z+hsej2LWludO/Zz1KCSGGXZDfXOnxCP5gpTKXEg y4APTBA5IPFc2WxpOLhGm5Nb/p+B3ZvUrxnGU3ZNXXp/w5lPY/E9Jmi039mv4PCHcgL3Xi0xblX7 vCaVIcr6duxrWtbH4uFZt/wN+A+nkrldviu4l3tuwQ3/ABJlxxkg5Oehx1HtwwitZUPvZ4zxM73c jgZfFX7S76t4hsdO/Zn+D72uk3z21vdSeLHAvI1AZJdv9nAruVh8pJwTjPevp7T4IIoIT/wiZtJn ALhIYFAJGT0ft0rDDR953w1uhrUnKyvUvcmknu4mgFt4YZ97AEmSJfL4JycE9MY4z1FIt34iA/d+ H9OjHy4DXuOp5ziM9Op/TNdvtJp2jQ/IxsnvIPtPiwkf8SfQVXPfUJCcZx/zw9MH9KteZ4gKpmz0 hXLfNi4cgDfjI+QfwZP14966PaYjW0EiGo9y2BqbLy9jG3HRWYdee47YqFotaP3b/TV6dbVj65/5 a/T/ADzWtq9un4k+6Qtba+zRn+19OVQuGAsjy2OozLwM9v1pz2ersHC60EJB2n7MvynjBPPPeoUK 7veSRV4dhradqbY/4n94p3Z+WGLpuzj7vpx+tZGnaJrqz6sL/wAXaxdQm4/0YCGBPLjMUfBxFyQ/ mHPowHbNKdCrdfvPwEpR7G6NLGcvqGqyck484jvntj6f5zRLpMEoKtc6mM8fLdSD19D7/oK1+q6W cmTzeRa+w22d22Qn3kb39/c/p6CqzaNpjkF7RXOc/MSeePU+wq5YaL3FzMpWnhPwzY+b9k0DSIPO k81ttuvzP8vPTr8q/lWrHYWMShIrK1jQDGFjAGOmOlFPCwjsgc2yyEQEEKoIyOlOrSMEr2Qm+58O eKdNguf2/vhDerEnn6Z4F16UtjnDS2Ef/s1fcdYYZazS7/ojvxr9yj/h/wDbpHyh+3Rff2f+yD+0 LOSBv8M3UHJx/rAI/wD2av8APf8A2OLYa38dviRrjglopFUHn/lpLIT/AOg16OW0lLG0W+6/X/I+ hy6u6eSZhy9l+i/U/rY+GcAh8JeH4QMbLS3XHphRXPeF/wB98evFkq7f9CsFXHp8iH/Gv0ynPWb8 v1PxqcfhXme4WuRIrYyCzNxx0FfMXwVH2jxx8WL85bN3Kob1+eQf4VnL+HUXkvzLj8UfU91TKxoS TndKevHUivmT4Fn7X8QPi3qqgEfaZUBJ/wBqQY/lXn1YvkqP+tzW8U4o+gbJcSwk8AyMfrhT/hXy 74VRtX/ao8Rzqd6WCiP6bVRa5lFWq37fqipXvFeZ9A6mWefXJwzAucD6kuf8K+Sv2m5Rc698NdEG 5zPcu5C+xjUUqK963k//AEkVT/L8z6nvI1Sy8P2oDMqRRcdP4ia8++J15/Zvw48dXnILW04zjoTH tH6mufCU/egvT8y6jsmzyL9lq0Fr8NNWvcHdeStjI6kso/pXttvgpAWc4nuS3pnDdP0rObs6kvN/ 1+AoKySZ8T/Gxm1j49eCdLBV/sUcTOvoS7Of0r6g8ZhDPolgDzDaRR4x3c8/zFZ41/vIpdIL8WdF KWiv3P6QNT8M+NL231BYPHj2s1zbSQxqmnxhFYggMcktkZ7EV5h4B+FerXHwt8NeGdW8ea81vFbx GaCOGANaXEbBnRZNm7McqkcknK18M8vlKMozqPW363/M+jjV5Zppa6/oetQeENSiNuz+OfFk72y7 QT9nG4f7QEOD+NKngohLyOXxX4vnjvW3OGulH124Qbc/7OK1jl8UkuZ6eY5Tvd2K938OtIvrjTLq 61bxZJNo7FrdhqcqlCRg5IOWz3DZFOT4eaQrXLPqvi2c3oAmD6tPiQdOVDAfpS/s2ldvX7y/ay0R yWv/AAv8L2+s+EfEzXevI3h6ZrVnk1a4JEE6+XtDmTcv73yTwQODXVP8OPAZN682kxSHVCTc+Zcy EXJIwTJl/mOABk+lL6tQ+F/mJVJ3bFfwT8P1e1abTtOL6eCIPMnYmAEYITLfLx6Vmy+BfhNKt1FN pHhd0vCZJ0Mi4m4wS43fNwB1z0p+wwy7FxqTWxXg8PfBcT2UMGm+BZrl1kNsoETttjxvMY5Py5Gc dM81cXTvhPbiFo9F8JBb1/LQpYowmccbchPmPt1pKWGS0sJynctbPh1D523QtKJsmG/ZpJYxHnGc R8dDWhHf+FE4g0iT96m/5NJk+dcZyMR80va4fpH8AtPuQTeLdAs4Y5F0bX2RmEaiPR5sg5wB9zjk 1zU/xS0m21CCyTwF8QpZZ7iO381dH2xo75CF3ZgFGRjJ6EiuatmNK6fs2/ka08NKV1zW+Z1EHjC6 njkki8EeMkMb7GWSGFDn1GZeR7jirJ8Rawz3CxeCvEB+z4+/Lbr5mf7v70g/nW6xstHGiyPY9HJD G1rxYd4h8F5KruXzNRjUN044BwefpweaE1Txs7wj/hEtJijkXcxfVjlDg/KQID3wMj1pvE172VLT 1EqcOshq6h46a6jiPh3w7DbyQM5c6lI2yQOoCECDoVJYH/ZxjvWiq+K3VczaBbMUyf3UkmH9Pvrx 7+3ShVMVJ6RSE4011HrbeJWEfm6tpCMIxu8uyfl+OeZT8vXjr71IbPW2Kk63Cg2YOy0H3uORljx1 4/WtPZYh7zS+RPNHsU7nSNeltpEh8V3tvctHhXW2hwsn94AoePY569as/wBkahmU/wDCS6xhyCB5 cHy+o/1XepWGrP4qv3D54rZEzaS7+YH1XV2R3DACULtA/hBUA4P5+9RNoFszxsb7Xf3bhwBfygHG OD83I47+tP6g3vUf3kqpboMbw3p7KVa41zHP/MSuB169JP8A9VQQeFtM+xQW9ydQuWWBInZrybL7 QBknf9445PU96h5bT5tW/v8AQtVXYdP4Q8PXJlM2n+Z523cDK+PlzjA3YHXt1rHn+F3w8uWZp/B+ hSMz7yTbjrx/gKqWU0HpKN/UqOKnHZ2Pj34YeFtL8A/tr+MLDS7aGzg8Y+CGm2oMAta3sSjj6Tn8 q+/qWW0lCM4LZP8ARG2Pm5OEn1X6sKK9KxwHwh4ytItN/bYjusMr+KvAWj844P8AZ/iNCfyGo/rX 3fXzuSRtXxS/vHv5x/Awsv7n/tzCivojwAwBnA60UJAB4opdbDCjpQ9hBRTAKKACoYs77jJ6uMf9 8rUy3Q11JqKoQUUAFFABRQB8dSRrdft26U2CTpXw1vm9h5moWS/rsP5V9i1zYfefr+iO3Fy92ku0 f1Z8M/8ABSm+Gn/sR/HiYuUMlhbRDnGd95brg+3NfwafsCwLN42+Id4SPnvbZOvvIf616WVf79RV +v6M92jFrIcdJd4r8Yn9ZvgmEQ6JpMIJysMS8/7K964b4dlbr4vfFG6Ug+VH5WR2+UD/ANlr9Hw8 tJvy/wAj8lqR1ivP/M9yt3ZQ7ZUKiSEen3q+Yv2dj5tt4/1J2Obq+YdfVgf602l7Od/L8yftR+Z7 krKIUd2+5E7dexcGvmz9nANc2HxE1cj/AI/b1+vuQf8A2auOcXyTfmv1Nb+8l6nv9mwzCW+UKsj5 IxxnH9a+XPgYf7U+OvxM1osWWGaVc+nzH+i1ySuqVR/L8Sqnxxse+u3mpcDcW865SP6jI/xr5E+M jLqfxw+Hek7fMWzRJCCehMjH/wBlqP5n2T/IJbL1R9barlNQ0+HLfukjB46YTOK8N/aDvW0/4Q+I eVVr1ljGSed0o/oKxwK/e00t7xHVuov5kPwKshp/we0oY2G6ZX7YIO9v6ivRrcNtsioGQhk+uVP9 SK4U3ySXm/1NeW2jPhy9J139qG4UHeNMwmOw2xqv8zX1J4qKz+Lxb5wtvJEgwefkCk/yNTmL5akk 91GP6GlC2j6XZ/Tv9hl82eQ6jflJhgJlcRn1X5c/mTXknhzRpdE8d+LvC134i8QzWetouuaajXBX YGcpdopH92QxuR/08D3r46eCvKLcn1X6/ofR89uh6ZJ4dtZZpJWv9eAlUqUXUJlUdOQA3B47VWbw lp7wtC+oeJW3End/alwG57ZD9PaiWWwbu2/vGqjJW8LaU7q7PqzbF2BTfz7cYxnG/GffrnnrVa08 FeHrW2trY291eLagLuuLmWVpcf8APRmYlz7tmnHLKSd7D9o7WMjX/hd4J8QaPrOkXWg2CDWIGgaU J+8jyDgo3VcE5wOMim+FPCPhVtE8P3UnhPw/a6jY2ywuFtY8wSqNkqAgdmDD8KccvpRbSiJ1ZXsd VF4a8OwwSWsOhaPFbSvvaNbZArNjGSMYzitNbW2SQSpbwJKo2hggBA9M+nA/KuiOGpq1orQXM+4r 28LPDIY1327FlOOhIIP6E1NVxpxV7ITYUVdgCmSoroQwyAQ34g5H6ipnG6aBbj6KoQUUAFFFgCig AooAKKACmpnB3Dncf50rajHUUxHxr4r8rQv2v/g9fsUjPifTdY0oZONx8pboAf8Afgn8DX2VXLho 2c15/ojqxErxp+n6sKK6jlPiL44Xll4e/ab+EGt3cqwJfeC/EdtuOfmeK80WeMfgUJ9sGvt2vAyp WxOJXmv1PoM0X+y4SXlJf+TBRXvnz4UUANfoOD1H86dU/aY+gUVTQgooAKKACoYhh7n/AHx/6CtT LdDJqKoQUUAFFABRQB8i6Ftuf23fGzEEvpfw8s4wc9BLfykj/wAhfyr66rkwq96p6/ojvxvw0V/d /WR+a/8AwVy1P+y/2CfjVJu2/aFsY/ri6if/ANkr+I//AIJ3W/2i78X3QyzTavGnPfain/2avVyV XzGjfv8Aoz2G2uH8bZ9Y3+9H9X/h9PKs7OIYwMAfgtebfB5vN8bfF68HJ+1+X16De4/pX6JRfuyv 2X5o/KZrVep7Ld3Qs9M1G6yFNtaSScccYz/Svnn9nNGj8Catdlj/AKbfnPvwD/7LV1Je5JLuv1FF e8tT13Vp/smg6rdn5XtbAuOenyMf/Za8F/Zrh8n4a6vdZIa9vT391/wrnmvcl6r9R83vL0Z7pBgQ Ek/6u2Jw3PUg18sfsvIs2qfFHWSEJeaTDdjnccfrXFVj+6mvNfma68yaPoSJsxWoDfeuC31x/wDs 18fa2o1f9qKxgYK66bBGv+6Qhb/2aselT0f5hNfCrn15qTBtcuzkFbcMOeRxha+Wv2rNQe3+HOk2 IZt+o3kQP+1hWY/qBWeDjacb9P8AIqpJ2aPT/B0H9mfDPwpZ4G5bf5sHnhVFdBhoptg+RYLfYffl R/SuOn8Cl6hzanxJ8GI/+Eh+PvjHVW+ZRdSAHORgycf+g19GXU4vfF91LvD/AL2WUZHJ5I/rWWYy /fVV6L8DbDJJL0Z/UzXIeKfDD6zLpGsaZcLYeJfDUrTWUzZ2OGG2SGUDkxSLweuCFYDKivmqsG1p ufQTV00anh/V5NZ0/wA+6sJdJ1G3kaG6tXcMYJV6jcOGBGGVu6sDxmtutBxldXCigYVm2YS3ur6z VQg3/aFAHGHzu/HeHJ/3h60Ey3RpUUFB60UAFFABRQA1M7F3H5gMH606lF3SY2FFMQUUAFFABRRY AooAKQZy+fX+lTJ6odhaKoR8Y/tDRLpnxk/Zm8UMNo0/xbHa7vT7XbTWmPxMn619nVz0n7816G9R e7FhRXQYHxV+09Y/8Xc/Ze1MqhS8v/EOiPn+IXWiXkoX/vu0Q/hX2dayie2t5lPyzIrD8RmvAy9/ 7biV/hPdzBP6nhn/AIv/AEpk9Fe+eEFFACNgKS3ReaWptqxhRVCCigAooAKp2qkT6iSWIaYEZPT9 3GKmW6GupcoqmhBRQAUUAFFAHyV4Ij879sr443HX7F4M8Pw59N9zqTY/8cFfWtc9D7XqdmL+wv7q /U/JT/gtrqf9mfsA/Ek5Ia7vLeMe+Flf/wBkr+Pj/gm1aedZaiHQk3WvsD/3xEK9TIVfMKeu1/yP YqycOH8U+8ofm/8AI/qd0cbYbYZJCk9+OEry74FHzZvibfFcC51Nx9fnJ/ka+/oyXJO3l+Z+XVF7 0WvM9L8ZXJs/BXi+6IJEGkyH0/5ZyV5F8B42g+E9tK/We4kc8dcbx/QVpLWnL1RMV7y9Gdx8RJhZ +AfGk/P7rS5Uz3B8pwP5/hXmfwFiW2+ENjJjBurh24PXl/8AAVzv4F6op25vkepX9wLTSNblJKi0 sieRjGEf/CvnL9liIJ4H8calux9puGUHHXlf/r1m6bUHr1iDfvL0Z7xZn5rJQWIG9hzj+9/jXyJ4 Ij/tf9p7xTcA70tJNnrt27ErkqaQqen6mltj6luJc32oSA8hSenqSf6V8l/tZ3BlPgDRY1O66unY 4POQEUDHvuNZUVaV+yf5MdTy8vzPpFYFtvDvh2wIP/Hso4P944/oKqahc+QurXBKhLaIE89dodj/ AErzIL93E0e7Pjn9k2Lz/EXi/X5FU/vGYtjuN7n+de46Mwl1i8uMsVii57H5mz1/4CaWP/i1V/es Vh/hT8j+qiivAPojN8tLfVRKqlTqEW1jngtHyvHqVZufRfYVpUEx6oKKCgrH1CNl1HRLtDtKSvBI c/8ALN0Y4/F0i/KmTJGxRSKCigAooAKKAGr/ABAHof8A69OqYqysMKKoQUUuoBRTAKKGAUUAFMDf Oy4PAB/n/hSa2GPopiPkL9ra1aPR/hzryhQfDni7Rb0sxwFEd4hP9Pzr69rkpP8AfTXkv1OupH9z CXnJfl/mFFdZyHxz+14ZrK7/AGYdaiQlNN+KWkwSt/dju7e9sTn6m5UfjX1R4VfzPDHhyQliXsLc 5bqf3a9a+ewmmY11/difQYzXL8O+zkvxub1FfQnz4UUANfARiegBp1LqAUUwCigAooAKqWxJmvxj 7swH1/dpUT3Q11LdFWIKKACigAooA+TvhgvnftYftO3Gd32fRPC1uP8AZ/5Cr/ru/SvrGsqXX1Z0 Yl6r0X5H4k/8F+NX/sz9grVog2DqGtxR9Oo+yXh/wr+W7/gmPYo+l6IWTKX2vux/2hvRf6frXfkE f9vXz/JHu4yXLw/V85RX4yP6ctPbbFEx4Ajc/hXlX7Ph/wCKT8WXpbm61OQ8Hr3r7+hL3ZNeR+W1 r8y+Z2Hxcn+yfC7xucq26xMXPuu3+tcp8Iovs3wj8NpwJLrzH6+5/wDiq1lK9NPzQR0nbyZY+Nd2 9r8K/Gsik/NAYh3+9sXA/wC+v1rG+FkBs/hB4XiGB56s/Pb/ADurJtci9f0Hf3vkbXxAvjYeAvHl 1vCmCwmHPT/Vn/GvJf2c4/snwZu7orze3RB9/m/+xrOov3a85IPtWfRM9htJApj5YGGEn8Tivkb4 BSG/+MXxI1sjIS6mKkDtvcj9FFclaX7mfbT8y18Ubn07A+6S4ZiAruqdfbv+dfIP7Qk/9p/Fz4ca OjBhBslIz/el/wDsKz5rSk12f5DlG6V/61Pq/U5Fjn02If8ALCOFfyG7mvOfHmpJp/gfxrfsxQpa 3ABH/XLaP1rgpX92K62NJO99TwT9lqAWPgPxZqxUI0qy4PuQF/rXqHhbE0uolV3b2WMc9eOg/OuK v8cn3kzemlZpdkf1Y0V4p7pieIFddPF3EXWTTJo7nKjJ2IwMgA9494/Gtuny6XJXxNBRSKCql8B9 mZ2KhYGWUk9AFIY/oKcdyZ7Mt0UigooAKKACigBgP7xlwcYBz69f/rU+lEbCimIKBx+FLqAUUwCj HXiiwBRQAUnfpSYC0UwPmH9ryzkufgh4vngytxp0AuY2/utG6OD+lfRujXi6jpGlagp3LfW0UwI7 hlDf1rkj/Hfp+X/DnW3egl2b/FL/ACNGius5D5P/AGzmSy+Dum+IHHPhPxl4V1INj7vl63YBj/3y zV9I+FmU6Dp8afdtA1v9PKZo/wD2WvAo6ZlU/wAK/NHvVl/wm0n/AH5fkjfqvPd2tssjXFxDAsUb StvYDai/eY+wyMmvfbtueCWKKAGv9xvoadS6gFFMA/GilbUYUUxBVCzctc6spH+quAo/79RH+tRP df10ZS6l+jpVPYkgkidp7eZZNqxBlZcfeBx+oIH61PSjGzYWCiqAKKAPlr4OWwk+P/7VOqgk+Zd6 FY/9+bOST+dwa+pa5sK7xb83+Z246PLNL+7H/wBJTP5+/wDg4v1r+z/2L9A04sVGo66z9cfct3XH /kX9K/np/wCCYdju0LwIygn7TqE0uNvTFw/+Fenw7K+PaXZ/lE9rM7Lh1+dSP/tx/Ry0n2fS7mdh xDaSvn3HP9K83/Z/Up8Mp5ssPtV5I+SeTxj+lff0GuSXqv1Py2rfmVvMvfH+4+zfCjxSGbYLiSKP r1y8f+FTeAmg034a+C/tc0NpD9nVizkKF3eWOSa0+xFW6/oStJP0OS/aKvo7f4Sa2RMNl5cRJuzx jzFP/stbXg25sYPhv4LVry1e2FvHvcOCoHyBsnp25rlctIW7stR39DzP4ofELwprfwb8f6l4Z8Qa N4gtDNJYyy2c6SqkoKI6MVJAYdMUz4U6haaZ8DPD4ZwvnTFz6nhj/WnKL5Ir+9b7ieZcz9DtJvEF nbw6lL5if6LAM8+gP9BXy/8AsuXyf8Vrqsjbmnlk+Zs+hx/6FUVqL9k11vH9Rqr7yPok+KdC054o 7/VdOspLmfcqzTKhbbjpk+1fJXi/UrXxF+0pogguIbiHTYIsOpBAIVm7H1auGcoqNRJ62Zaj8Olk z0X9pv8AaS+Hf7M3gy++KXxMn1SHwxpU627fY4POkeRkZVAXI4z3JGK811X4x6B8V/2YLL4peFft tv4f+I1hFeWK3KBJWguHDIWAJwShB696zp05U6mGcl7s3b/wH/hwk7xny9P1Oi+D7LonwTLuQpv2 TGe+5938l/Gus8FahFsEjOF+03OR07H/AOxry5R2feTOlWSkvkf1jUV4h74yWNZopIXGUlUqR6g8 Uy3lFxBBOFKCZA+PTIzinbQnqTUUigqKeJJ4JoHGUmUofcEYoE1oQ6fdrfWNleoCq3kSSgHtuAP9 at02ugRd0mFGBknHNIYUUAFFADTgMp5zyP6/0p1JdRhRTEFFABRQAUUAFFABR0xxSYBRTA8g+PGl LrXwo8bacy7/ALTp1wuMf9M2P9KsfAjVW1z4KfCXVXYtLe+HNOaQ5/jFvGG/8eBrla/fr0f5o6kv 3L9V+TPV6K6jlPlj9tq0a5/ZY+MsyA79G0v+1FwOhtJY7ofrDXv/AINdJNBilRtyz3FzKPo88jj9 GFeGo2zFvvD9T3JSvlyXab/9JR1FNaNHzvRXyCpyM5B6ivca6M8Ow715ooQARwRSKcqpz1FAC0ev WgAooAKKACs2xVVutaIzl7lSfr5MQ/oKzmtY+v6MpdTSoq5bEhRTAKKACigD5e+AVwLz4lftVz9T D40t7fPsmk6ecf8Aj5/OvqGuPAO9O/m/zZ3Zg71F6R/9JR/NB/wcya39h/Zq+FOll1VdQ1K8k5/v IbRR+jmvxz/4JgWZXQfheAAC8Uk/THV5Wr0uGpf7dV9H/wC2nv55BLhyi2t6i/DnP318QXBtfCHi O43OptdNmbp0+RzXOfAxPK+Feh52lp55CeO+8/41+gUvhl6r9T8nqfEk+z/Q579pe68v4XzxjKtd X0Sf+PZ/pVXx18M1+JXwZ0bwQXSCaa1ieEMfklkUfKrj+6Tx7HmrVSUIwa3TGopybfb9T8qvip4P +N978EvH3hibW9cHhFbnVPDq28mpCQQ3ts08DhMksFWSN8EHHTFfgv8AsLfHr9o3V/BXxX+EI8be KZfDfwgtJtVt7W4kkNnbRS30cEztgjzpRLcoVjJAIB5WuTGY/wB2FSKS963zd1c9DDYPm5ob2/qx +tei/te/s7+C/genwK+HVj49udTiuTfapqeq20cb6hcu5kmnlYSEBmOOBgKAFAwAK+k/D/7W2iN4 G8M+GrDw14gMmlg+a7iMK2QBkfP7Hr61+aVfGjK8NBOpdyvf1b8z3J8D4uUmlZdDVm/aoXU9G1WG w8NarN/asJWGUTRlcMpAbIbkfN2ry7wb+0Hr3g3wV4v0HwnpME3i67jkigupZFeGznYAqZEHJ2jB xxnI9a8TGePmWL4acm46tWs1Y1w/AGKv70lbprufHU/hTQda8Q6fb/E+DVviD461i2lurq/vNXdJ 53VlEjxqD+6QNIu1UGFAGSTyeu+E134v+COqXGt6p4ll13Q7e6P2E6jcHzreJyBHC8x++RkKDjnI 4r5er46YD2kXChJqX3vXVefb7j3q/BmJlS5JyVlqvL+v+CfPf/BSn9p/xd8YvAFz8IpLPTdI0vV5 xbGJP30l7fj50jRzjplRgDLM+O1eJfs6/t8fEjwJ+zZ4c+BnxY8MSu/gqWGy0+QhYJIbOFQkUUiY 5KgH5upA9a/VMXxUngMNjHo4tyUXvZqKb/JHylLIZOdTDx1f83TS5+l/wj/bht/HvgjUvDP9jjQF 8JyWyqfP3/alaIndjA246Y5r6n+GvxPGp2enyR3O/AL49yP/AK9e7wpiFj8FTxTja/N+p4Gb0pYa vUot3tY/txor54+lCsXQLo3WntvZmktLie2YkYJMUrpn8QoP4079CWveRtUUigpsjpEjySMEjjBZ iTwAOpNAGF4VtJbDw1oFnOzvNb2kSsWGCDtGR+HT8K36F5ijsFFAwooAKKAGSEqoI7Efzp9JbtDs FFMQUUAFFABRQAUUAFIeMdetDGLRQI5nxlZi/wDDOtWpG7zoHTHrkFf614p+yRfte/ALwTA5Jk0W S+0057C3vLiFR/3yi1yyX7+L8n+aOyH8CS81+TPpGiuo4zxf9o7STrv7P/xt0ZU8x9S8KarCo9S1 pKB+pqL9nzX5PEnwx8N6qwJiu7DTZo2znzBNp1lOT/31K35V4tR2zCHnB/me1BXwEvKa/I9tor2j xRMcg7jgdvWloAKagwigjoBS6gOopgFFABRQAVQs8fadWx/z8D/0VFWdTePr+jKXUv01zgD6j+dO o7RYkOoqxBRST6gNEiFmQMNydRnpTHuIIwS80SAerAVzLGUkm3NaN9exfs5bWPkP9mubUdJ8TftN 3fiXR9V0JfEXj+S+097i3dVv7T+zdOgWaI4+ZS8Ei/VTX1Q2uWYxsS4kB77doH13EV4GX55RhRUW 7vXb1Z6mMwk5VG0tLL8Ej+T3/g5s8S69L8N/g5aajHo0GlS3N8bSOG4Mk4O6y3mXgAA7Rtx/tcnt 8M/8EwrMx6D8MzgjbpYc/jGx6/jX0fA9d1a9apLS6l+aPa4pioZFhYx/5+foz9s/HM32b4f+L5Dj I0yReP8AcYVL8IY/J+GHg6PPzFS3HHVga/SqXwO3dH5HNXkvRnmn7Ttwo8E6FaYJa61VeOucCTp+ lfQWg2it/wAInarlAyQx9fXNTV+CPzKXxteh+efilUvfh3o1gwL/APCSePvEM5Dc+YG1O75Prnf+ tfixrKXvgz4d/wDBSyxtbHRvD2mfDPS9A0zSTZ2qRPG1/dvcSkkAclrFT26fjXw2dYRTq4G8naMm 7d3dLX5Nn1GW13COI03t+r/yPx3+A/iW68X3OsWHiq8bVbLUPluVnPDKSc8jp0/Cv2N8DXEc+lxw E+ZAybMPzlcY5Pfj+dfyl4q4RUMbOhSVqa5XptflP1LIqsqtGNWer1X4np/hXTNA0jRrLSvD0cEG j2CmKGOJ96oAcbQcngcjrxjFP0nSfDOm6vr0+kw2cGr6rKk+oKjfM7FQqs6Z4JVRzgZ21+U4jF1p Sq1ZSd5K0vv6/NI92FKMVFLpsVL7RPCkviHStdvbawbxHZxPb2k0jYkVGwXVRnp0zirHiK10HUtH urTX7SxvdLGJJY7hQUYoQynnuCAR7gVyyxFdezbduX4fLW+nzLlGMrr+tj8Uvj7LrHi/45/B74fX N6bLw3NE3iPXQEUmFY3M5cNjKHy8KCCOXFfMHx/8Vy2vxKltkvby9022SzaT7OV3yKURnK9txyfz r+71hIvC06cne0F+L1/Q/JcPUl7VyS3Z9SfBTx7JYzeIfs80jQ3NvZMoY4Y4DjkZ6niv2V+Bmvyj RtODSMcIMEdfr+lfU8B1VHA06S0tKX3XPluKaD+sym+qX5H+iJRXlnpBXO6dEbHXddtdriHUvLvo 2I4LFRFIo+nlox/660Ey6HRUUFBWF4kEc2kz6fLFcTrrBWyKxHD7ZSEdh/uqWY+gU01vqTUvyu25 ugBQABgDj6UUigooAKKACigCKdXeCZEO12UgH0OOKfG6yIkinKuAw+hqPtWK6DqKskKKGAUUAFB4 yeeKACigAoPQ8kUpbMaCimIo6nH5thdoehQ181/snxtY+C/HegMI1Hh3xfqluqr1VXaOfn8Zj+GK 46srVafnf8mddKN6VTys/wAbfqfUVFdhyGH4m08av4c1/SmUOuo2c0BB6HejL/WvmH9ia/1K5+AP w7tdSS3VrTw/oyxFDlmVLCC3k3+jCa3mXA7KK8DFytmFDzUj3sKk8vr+Uov80fXVFe+eCFFABTU+ 6o544qW/eS/roPoOoqhCK25VYZwwzS0o7IdgJx+dFHUQVymg6tY3mp+NYYbgF9J1NbeYNxsf7Jay Y+m1wfzrjxNeMJ01J2u//bZG1Om2pWW3+aOikvLWLAeeMHOOvvisjVNbFtaCWxs7nVJhJEPKjwp2 lwGbLED5VycZzx615WN4goRjOKd3Z6I2o4KpKztoWJNatUHSX8RjFZtx4otIsjdEv+9IOPyrmxHE q5f3UfvNqeXSv7zMGPxPPFbGA3L30+W+cJgkEkgYA7Agfh65pH17V5WYxWd4Cem5do7+v1rwXmeJ cVDn27I9BYGmm3Yw1j1Rrq91CDSoF1C8VVllxl5QmdoYjkhcnAzxk1Olr4ouQzPZzwEnHyInI+pN ccMJN7R3OiVaEbXewq6Vq8aAy2WoFmODvnUZ69lpshj06JvMtCJT2EbMw9s5rpp4XlWqI9om9Gfy V/8ABzprbz+HvgNpyJd2xfzwguLcxBjLIOQe4/dc1+en7EX7Uvw7+EM/grwt4nh1Z9Q0zQ4jM1vG HRTt8vjLA8kMRx0U9K+v4TzOlhZVJVHa6a/I+vzThjF5jk+Fhhop2k29bdWl+p+o/j79ur4Kaz4H 17RrC/1tL/UYPKjV7NgG6ZyenrXY+AP25f2edI8IeG9J1Lxbd2dzp1sqzA2M7ANjJHyqa+2p8XYN UmnU1vc+BqeGebxmv3D7dDyv45/tnfArxlbeB7TQfFj3cdjfi4uy1nMnlJjBzlevJ4r6q+G37an7 P/ivxn8PvDOj+M1vda1S/s7OC3FtMPMlkdEVclMDk9+BSq8V4OUFy1Fpc5KnAOa05Pnw8l/wD4Iu f2mPhMtn8NNAvvElvb3PhrV7+61PzEYLC0t40mM454z0r4i/bFvvCtr+zX+29478Ly22o6f8S/E/ he3jvIywW7hRNWlXGe43rXBjczoVa+HhGV5Rk9PS7CnkmLw9KVWrSahNJptaP0+R+I/wztNEnSzt YG065tL6wjF3BHjLBkG9SM9+RX6SfCrXY7vw/od5pDE6JNAoQOrCQLgBRtPIIxyG54r+TuOqVf2l
February 22, 2018 - March 28, 2018
Kolb-Archive.digest.vol-os
