Kolb-Archive.digest.vol-ov
May 11, 2018 - July 04, 2018
      >   > I have been pulling out what's
      >   left of my hair over this issue. I really don't want
      >  to
      >   quit, I LIKE the Kolb airframe and it will fit my mission
      >   well. I like the HKS fuel economy and improved
      >  reliability.
      >   I just wound up with the wrong gearbox on it and cannot
      >   afford to change it.
      >   > What I have learned thus far is:
      >   > 1) My 3.47 to 1 gearbox really
      >   wants to swing a larger propeller than what is
      >   actually  "correct" for the height of the
      >  thrust line
      >   on the Kolb airframe.
      >   > 2) Turning the gearbox upwards
      >   will solve the prop diameter problem, but it creates a
      >   thrust line that is higher than the Kolb factory thinks
      >  is
      >   advisable.
      >   > 3) I could easily go to a 4 or 5
      >   blade propeller, solves the gearbox AND thrust line
      >   problems, but that interferes with folding the wings.
      >   > I have considered many possible
      >   solutions or "work-arounds" :
      >   > 1) Get a 5 blade propeller and
      >   remove it after every flight, which would allow ALL of
      >  the
      >   problems to be solved, at the cost of additional time and
      >   effort every time I fly. This will cost the least of all
      >  the
      >   "solutions".
      >   > 2) Remove the wings after every
      >   flight instead of folding the wings. This allows a 5
      >  blade
      >   propeller to be used but adds complexity and requires me
      >  to
      >   build a complicated ground fixture to allow the wings to
      >  be
      >   removed and installed by myself alone.
      >   > 3) Make a folding propeller, like
      >   the electric R/C model gliders have, where the blades
      >  fold
      >   rearward. This solves all of the problems, no complex
      >  ground
      >   equipment, but designing and manufacturing such a
      >  propeller
      >   will be prohibitvely expensive.
      >   > 4) Buy another gearbox from HKS.
      >   This is the best solution mechanically, but I cannot
      >  afford
      >   it.
      >   > 5) Turn the gearbox upwards,
      >   install the right propeller, and live with the possibly
      >   dangerous or funky flight handling of the airplane.
      >   > Any other/better/wiser/workable
      >   ideas from the Kolb List are very very welcome!
      >   > Bill Berle
      >   > www.ezflaphandle.com
      >   safety & performance upgrade for light aircraft
      >   > www.grantstar.net
      >          - winning proposals for non-profit and
      >   for-profit entities
      >   > On Wed, 5/9/18, George Helton
      >   wrote:
      >   > Subject: Re: Kolb-List: Re: High
      >   Thrust Line Question
      >   > To: kolb-list(at)matronics.com
      >   > Date: Wednesday, May 9, 2018, 9:39
      >   AM
      >   > --> Kolb-List message posted
      >   by: George
      >   > Helton
      >   > Well Bill, thanks for bringing up
      >   the
      >   > topic. I replaced my little Rotax
      >   377 with new low rpm Hirth
      >   > 2702 over the winter. I really
      >   hadnt measured the
      >   > distance between the prop hub and
      >   boom tube. You sparked my
      >   > interest so I stopped by my hanger
      >   this morning to check it
      >   > out. The Hirth uses a G50 gearbox
      >   with 2:29 to 1 ratio.
      >   > which translates to 2400 rpm prop
      >   speed @ the engines
      >   > max. HP rpm of 5500rpm.
      >   > Anyway, it measures 35.5 inches.
      >   This
      >   > is on a Kolb original Firestar. I
      >   did have to move the
      >   > engine forward 2.625 to
      >   compensate for the extra weight
      >   > of the new gear box. I went with a
      >   64 3 blade Powerfin
      >   > prop set at 6.4 degrees of pitch.
      >   This setup gives me 3.5
      >   > of clearance from the boom tube.
      >   Thanks for inspiring me to
      >   > check it out.  Im sure
      >   there is a good combination
      >   > of prop out there for an HKS.
      >   > George Helton
      >   > 1986 Firestar, FS100
      >   > 14GDH
      >   > Mesick, Michigan
      >   > gdhelton(at)gmail.com
      >   > Sent from my iPhone
      >   >> On May 8, 2018, at 11:08 PM,
      >   Bill
      >   > Berle
      >   posted
      >   > by: Bill Berle
      >   >> Everybody THANK YOU for
      >   taking
      >   > time for this discussion.
      >   >> I spoke to the Kolb factory
      >   today
      >   > by phone, and went out to the
      >   local UL flying field to see
      >   > an HKS engine run.
      >   >> Duane and Bryan at Kolb were
      >   asked
      >   > one specific question by me:
      >   What is the maximum
      >   > number of inches allowable or
      >   advisable between the center
      >   > of the propeller and the top of
      >   the tailboom?
      >   >> Bryan said that 36 inches is
      >   about
      >   > standard for a "normal" Firestar,
      >   and he would not want to
      >   > fly an airplane with that distance
      >   raised to 39 or 40
      >   > inches.
      >   >> I went back to my hangar and
      >   > measured, and the distance on my
      >   Firestar would be over 40
      >   > or 41 inches if I turned the
      >   gearbox upward. So if the Kolb
      >   > factory owner says 40 inches is
      >   too high, I can only be
      >   > humble and assume that I wouldn't
      >   want to fly it at 40
      >   > inches either. If any of the
      >   highly experienced Kolbers on
      >   > this forum are flying with their
      >   thrust line 40 inches above
      >   > the tailboom, I REALLY would like
      >   to know about it pronto.
      >   >> As big of an ego as I have had
      >   a
      >   > few times in my life, and as much
      >   as I think of myself as a
      >   > reasonably  skilled pilot, I
      >   don't need to be a test
      >   > pilot here and try to push any
      >   envelope at this early stage.
      >   > So if I can ask the Kolb ilst a
      >   favor... if any of you are
      >   > flying a Firestar with the engine
      >   thrust line 39 or 40 or 41
      >   > incvhes above the tailboom please
      >   post this on the list and
      >   > let me know ifyou have any issues
      >   with the handling,
      >   > pitch-over, etc.
      >   >> Bill Berle
      >   for light aircraft
      >   >> www.grantstar.net
      >   > for-profit entities
      >   >> On Tue, 5/8/18, Richard Pike
      >   > wrote:
      >   >> Subject: Kolb-List: Re: High
      >   >> Date: Tuesday, May 8, 2018,
      >   4:38
      >   > PM
      >   posted
      >   > by: "Richard
      >   >> Pike"
      >   >> Bill; notice the extent to
      >   which
      >   > Rick
      >   >> raised his engine. (Great
      >   > pictures) Maybe you can leave the
      >   >> gearbox down and raise the
      >   engine
      >   > up?
      >   >> Richard Pike
      >   >> Kolb MKIII N420P (420ldPoops)
      >   >> Kingsport, TN 3TN0
      >   >> Forgiving is tough, being
      >   forgiven
      >   > is
      >   >> wonderful, and God's grace
      >   really
      >   > is amazing.
      >   >> Read this topic online here:
      >   >> http://forums.matronics.com/viewtopic.php?p=479963#479963
      >   >> The Kolb-List Email Forum -
      >   >> Navigator to browse
      >   >> List Un/Subscription,
      >   >> 7-Day Browse, Chat, FAQ,
      >   MATRONICS
      >   > WEB FORUMS -
      >   >> via the Web Forums!
      >   >>      - NEW
      >   MATRONICS LIST
      >   > WIKI -
      >   >> Email List Wiki!
      >   >>     - List
      >   Contribution
      >   > Web Site -
      >   >> support!
      >   >>      -Matt
      >   Dralle, List
      >   > Admin.
      >   > Navigator to browse
      >   >      - MATRONICS
      >   WEB FORUMS -
      >   > via the Web Forums!
      >   >     - NEW MATRONICS LIST
      >   WIKI -
      >   > Email List Wiki!
      >   >    - List Contribution
      >   Web Site -
      >   > support!
      >   >     -Matt Dralle, List
      >   Admin.
      >   Navigator to browse
      >        - MATRONICS WEB FORUMS -
      >   via the Web Forums!
      >       - NEW MATRONICS LIST WIKI -
      >   Email List Wiki!
      >      - List Contribution Web Site -
      >   support!
      >       -Matt Dralle, List Admin.
      >  -List" rel="noreferrer"
      >  target="_blank">http://www.matronics.com/Navigator?Kolb-List
      >   FORUMS -
      >  eferrer"
      >  target="_blank">http://forums.matronics.com
      >  WIKI -
      >  errer"
      >  target="_blank">http://wiki.matronics.com
      >  b Site -
      >  rel="noreferrer"
      >  target="_blank">http://www.matronics.com/contribution
Subject: Re: High Thrust Line Question
Date: May 11, 2018
Increasing the size/shape of the horizontal stab ought to solve a whole bunch of apparent control authority issues. It would not be a big deal to increase the chord of any Kolb horizontal stab, and it would not take but a little creative thinking to make it work very well and still retain the folding ability. As long as you keep the basic concepts the same, all you can do is make things better. (Also - does nobody know how to edit/remove a whole boatload of previous/extraneous posts from their posts? So that we don't have posts that are full of scroll down/scroll down/scroll down extraneous/previous posts? Not that I want to be the list Hall Monitor; but seriously? This is stuff that we knew how to deal with back in Windows 3.5!!) Flame on... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480082#480082 ________________________________________________________________________________
Date: May 12, 2018
I bought my HKS engine used from a guy in Petaluma, CA who was using it on a weight shift trike. No dealer or distributor was involved. Jerry Olenik (one US dealer) was wonderful to me before he passed away, and Chris Gatin (other US dealer) was great as well. I have no complaints with anyone on the factory or dealer end of this. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Fri, 5/11/18, George Helton wrote: Subject: Re: Kolb-List: Re: High Thrust Line Question To: kolb-list(at)matronics.com Date: Friday, May 11, 2018, 11:14 AM Helton Bill, I was wondering? Did you buy this HKS engine and gearbox combination from a HKS distributor? If so, is HKS in such a state of financial insecurity that it wont even consider swapping the the gearbox you have for one you need for say a 20 to 30% restock or exchange fee? It sure disturbs me to think of that kind business practice. Id think they would have a hard time selling engines in the future. I mean I understand that you ordered the wrong gearbox, but come on. Maybe I just spent to much time in sells, rental and customer service. -George- Sent from my iPhone > On May 11, 2018, at 1:44 PM, Bill Berle wrote: > > --> Kolb-List message posted by: Bill Berle > > THANK YOU Rick, I appreciate the feedback. > > After all this enormous discussion and exchange of information, I am strongly leaning towards turning the gearbox upward and running a large propeller. > > The reason for this is that I believe I would have an "out" if I needed it... if I do run out of elevator control because of the thrust line being high, I can find a fairly straightforward way to increase elevator authority to overcome it. I can increase the chord or span of the elevator, add VG's under the elevator, add the outboard part of the stabilizer to the movable part of the elevator (called an "aerodynamic balance" on Cub type aircraft), etc. > > Onward ! > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > -------------------------------------------- > On Fri, 5/11/18, Rick Neilsen wrote: > > Subject: Re: Kolb-List: Re: High Thrust Line Question > To: kolb-list(at)matronics.com > Date: Friday, May 11, 2018, 10:30 AM > > Bill I > can only speak about the MKlll with a VW. I have run It with > A 72 inch prop with 7 clearance, 1 clearance, a 60 > prop turning 3200 rpm and 72 at 2000 > rpm. > With a 72 prop and 7 clearance one person > operation was fine but with two I would run out of up > elevator at full power. > The 60 prop turned large amount of power into > noise. The three blade 2000 rpm 72 prop gives twice the > thrust. > If you can fit a 70-74 prop depending on prop > recommendations with close to 1 clearance by raising the > engine do it. If you keep the prop clearance the same the > apparent thrust line change is half the prop shaft > change. > You might find the big reduction ratio a better > overall fit. > Rick Neilsen Redrive VW powered > MKIII > > > > > On Wed, May 9, > 2018 at 8:58 PM Bill Berle > wrote: > --> Kolb-List message posted by: > Bill Berle > > > > The replacement gear set does not fit into the same gearbox > case. So unfortunately I cannot just buy two new gears and > slide them into place. > > > > BUT... I am making progress towards one of the other > potential solutions. After consulting with an experienced > aircraft structures and metallurgy engineer, I believe I can > make a simple prop extension that is held on with one > central nut (a great big nut !) and remove the propeller > before folding the wings. > > > > The key to doing this SAFELY is called the Belleville > Spring, or Belleville Washer. It is a conical spring steel > washer that becomes flat (like a regular washer) as it is > tightened, providing a known, reliable tension/compression > force over a reasonable range of installation torques. > > > > This means that I can install the propeller, tighten the nut > until the Belleville Washer is more or less flat, and be > confident that there is plenty of tension/compression in the > propeller mounting without having to use a torque wrench, > elaborate bolt stretch charts, etc. etc. This also provides > a much more convenient and error-proof option instead of > havign to torque six propeller bolts and safety wire the > bolts, install six Cotter Pins, etc. > > > > All of this means I will be hopefully able to use a 4, 5, or > 6 blade prop with the thrust line within Kolb's > recommended distance from the tailboom. > > > > The only downside is that Kolbers around the world will > never stop making fun of me for turning a simple airplane > into a major engineering project :) > > > > The HKS engine is a VERY good quality engine and I believe > the other Kolb/HKS owners will agree they love the engine. > If you wish to use this engine on a Kolb, don't hold my > mis-adventures against the engine... just make darn sure you > get the 2.58 gearbox ! > > > > Bill Berle > > www.ezflaphandle.com > - safety & performance upgrade for light aircraft > > www.grantstar.net > - winning proposals for non-profit and for-profit > entities > > > > -------------------------------------------- > > On Wed, 5/9/18, George Helton > wrote: > > > > Subject: Re: Kolb-List: Re: High Thrust Line Question > > To: kolb-list(at)matronics.com > > Date: Wednesday, May 9, 2018, 11:37 AM > > > > --> Kolb-List message posted by: George > > Helton > > > > Bill, I know that this might sound > > crazy but, cant you just buy a different set of gears > for > > the gearbox? Being a mechanic may be a benefit here but I > > cant imagine that HKS cant supply replacement > parts. > > The gearbox case doesnt care what gears fit inside of > it. > > > > If they dont, Id sure shy away > > from buying one. > > George Helton > > 1986 Firestar, FS100 > > 14GDH > > Mesick, Michigan > > gdhelton(at)gmail.com > > > > Sent from my iPhone > > > > > On May 9, 2018, at 2:18 PM, Bill > > Berle > > wrote: > > > > > > --> Kolb-List message posted > > by: Bill Berle > > > > > > I have been pulling out what's > > left of my hair over this issue. I really don't want > to > > quit, I LIKE the Kolb airframe and it will fit my mission > > well. I like the HKS fuel economy and improved > reliability. > > I just wound up with the wrong gearbox on it and cannot > > afford to change it. > > > > > > What I have learned thus far is: > > > > > > 1) My 3.47 to 1 gearbox really > > wants to swing a larger propeller than what is > > actually "correct" for the height of the > thrust line > > on the Kolb airframe. > > > > > > 2) Turning the gearbox upwards > > will solve the prop diameter problem, but it creates a > > thrust line that is higher than the Kolb factory thinks > is > > advisable. > > > > > > 3) I could easily go to a 4 or 5 > > blade propeller, solves the gearbox AND thrust line > > problems, but that interferes with folding the wings. > > > > > > I have considered many possible > > solutions or "work-arounds" : > > > > > > 1) Get a 5 blade propeller and > > remove it after every flight, which would allow ALL of > the > > problems to be solved, at the cost of additional time and > > effort every time I fly. This will cost the least of all > the > > "solutions". > > > > > > 2) Remove the wings after every > > flight instead of folding the wings. This allows a 5 > blade > > propeller to be used but adds complexity and requires me > to > > build a complicated ground fixture to allow the wings to > be > > removed and installed by myself alone. > > > > > > 3) Make a folding propeller, like > > the electric R/C model gliders have, where the blades > fold > > rearward. This solves all of the problems, no complex > ground > > equipment, but designing and manufacturing such a > propeller > > will be prohibitvely expensive. > > > > > > 4) Buy another gearbox from HKS. > > This is the best solution mechanically, but I cannot > afford > > it. > > > > > > 5) Turn the gearbox upwards, > > install the right propeller, and live with the possibly > > dangerous or funky flight handling of the airplane. > > > > > > Any other/better/wiser/workable > > ideas from the Kolb List are very very welcome! > > > > > > > > > > > > > > > Bill Berle > > > www.ezflaphandle.com > - > > safety & performance upgrade for light aircraft > > > www.grantstar.net > > - winning proposals for non-profit and > > for-profit entities > > > > > > > > -------------------------------------------- > > > On Wed, 5/9/18, George Helton > > > > wrote: > > > > > > Subject: Re: Kolb-List: Re: High > > Thrust Line Question > > > To: kolb-list(at)matronics.com > > > Date: Wednesday, May 9, 2018, 9:39 > > AM > > > > > > --> Kolb-List message posted > > by: George > > > Helton > > > > > > Well Bill, thanks for bringing up > > the > > > topic. I replaced my little Rotax > > 377 with new low rpm Hirth > > > 2702 over the winter. I really > > hadnt measured the > > > distance between the prop hub and > > boom tube. You sparked my > > > interest so I stopped by my hanger > > this morning to check it > > > out. The Hirth uses a G50 gearbox > > with 2:29 to 1 ratio. > > > which translates to 2400 rpm prop > > speed @ the engines > > > max. HP rpm of 5500rpm. > > > Anyway, it measures 35.5 inches. > > This > > > is on a Kolb original Firestar. I > > did have to move the > > > engine forward 2.625 to > > compensate for the extra weight > > > of the new gear box. I went with a > > 64 3 blade Powerfin > > > prop set at 6.4 degrees of pitch. > > This setup gives me 3.5 > > > of clearance from the boom tube. > > Thanks for inspiring me to > > > check it out. Im sure > > there is a good combination > > > of prop out there for an HKS. > > > George Helton > > > 1986 Firestar, FS100 > > > 14GDH > > > Mesick, Michigan > > > gdhelton(at)gmail.com > > > > > > Sent from my iPhone > > > > > >> On May 8, 2018, at 11:08 PM, > > Bill > > > Berle > > > wrote: > > >> > > >> --> Kolb-List message > > posted > > > by: Bill Berle > > >> > > >> Everybody THANK YOU for > > taking > > > time for this discussion. > > >> > > >> I spoke to the Kolb factory > > today > > > by phone, and went out to the > > local UL flying field to see > > > an HKS engine run. > > >> > > >> Duane and Bryan at Kolb were > > asked > > > one specific question by me: > > What is the maximum > > > number of inches allowable or > > advisable between the center > > > of the propeller and the top of > > the tailboom? > > >> > > >> Bryan said that 36 inches is > > about > > > standard for a "normal" Firestar, > > and he would not want to > > > fly an airplane with that distance > > raised to 39 or 40 > > > inches. > > >> > > >> I went back to my hangar and > > > measured, and the distance on my > > Firestar would be over 40 > > > or 41 inches if I turned the > > gearbox upward. So if the Kolb > > > factory owner says 40 inches is > > too high, I can only be > > > humble and assume that I wouldn't > > want to fly it at 40 > > > inches either. If any of the > > highly experienced Kolbers on > > > this forum are flying with their > > thrust line 40 inches above > > > the tailboom, I REALLY would like > > to know about it pronto. > > >> > > >> As big of an ego as I have had > > a > > > few times in my life, and as much > > as I think of myself as a > > > reasonably skilled pilot, I > > don't need to be a test > > > pilot here and try to push any > > envelope at this early stage. > > > So if I can ask the Kolb ilst a > > favor... if any of you are > > > flying a Firestar with the engine > > thrust line 39 or 40 or 41 > > > incvhes above the tailboom please > > post this on the list and > > > let me know ifyou have any issues > > with the handling, > > > pitch-over, etc. > > >> > > >> Bill Berle > > >> www.ezflaphandle.com > - > > > safety & performance upgrade > > for light aircraft > > >> www.grantstar.net > > > - > > winning proposals for non-profit and > > > for-profit entities > > >> > > >> > > > > > -------------------------------------------- > > >> On Tue, 5/8/18, Richard Pike > > > > > > wrote: > > >> > > >> Subject: Kolb-List: Re: High > > > Thrust Line Question > > >> To: kolb-list(at)matronics.com > > >> Date: Tuesday, May 8, 2018, > > 4:38 > > > PM > > >> > > >> --> Kolb-List message > > posted > > > by: "Richard > > >> Pike" > > >> > > >> Bill; notice the extent to > > which > > > Rick > > >> raised his engine. (Great > > > pictures) Maybe you can leave the > > >> gearbox down and raise the > > engine > > > up? > > >> > > >> -------- > > >> Richard Pike > > >> Kolb MKIII N420P (420ldPoops) > > >> Kingsport, TN 3TN0 > > >> > > >> Forgiving is tough, being > > forgiven > > > is > > >> wonderful, and God's grace > > really > > > is amazing. > > >> > > >> > > >> > > >> > > >> Read this topic online here: > > >> > > >> http://forums.matronics.com/viewtopic.php?p=479963#479963 > > >> > > >> > > >> > > >> > > >> > > >> > > >> The Kolb-List Email Forum - > > >> Navigator to browse > > >> List Un/Subscription, > > >> 7-Day Browse, Chat, FAQ, > > >> - > > MATRONICS > > > WEB FORUMS - > > >> via the Web Forums! > > >> - NEW > > MATRONICS LIST > > > WIKI - > > >> Email List Wiki! > > >> - List > > Contribution > > > Web Site - > > >> support! > > >> > > > > > > > >> -Matt > > Dralle, List > > > Admin. > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > > > > > The Kolb-List Email Forum - > > > Navigator to browse > > > List Un/Subscription, > > > 7-Day Browse, Chat, FAQ, > > > - MATRONICS > > WEB FORUMS - > > > via the Web Forums! > > > - NEW MATRONICS LIST > > WIKI - > > > Email List Wiki! > > > - List Contribution > > Web Site - > > > support! > > > > > > > > -Matt Dralle, List > > Admin. > > > > > > > > > > > > > > > > > > > > > > > > > > > > The Kolb-List Email Forum - > > Navigator to browse > > List Un/Subscription, > > 7-Day Browse, Chat, FAQ, > > - MATRONICS WEB FORUMS - > > via the Web Forums! > > - NEW MATRONICS LIST WIKI - > > Email List Wiki! > > - List Contribution Web Site - > > support! > > > > -Matt Dralle, List Admin. > > > > > > > > > > > > ========== > > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?Kolb-List > > ========== > > FORUMS - > > eferrer" > target="_blank">http://forums.matronics.com > > ========== > > WIKI - > > errer" > target="_blank">http://wiki.matronics.com > > ========== > > b Site - > > -Matt Dralle, List Admin. > > rel="noreferrer" > target="_blank">http://www.matronics.com/contribution > > ========== > > > > > > > > > > > > The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Date: May 12, 2018
I looked at the stabilizer and elevator today and it seems that IF I had to enlarge the elevator area it would not be a difficult project. The worst thing that could happen is that I might have to move the outboard elevator hinge inboard 3 or 4 inches. No modifications would be needed (or advisable) to the Kolb folding elevatorcontrol mechanism, the brace wires, the weight of the elevator behind the hinge line, etc. On high speed aircraft changing the space between the hinges can allow oscillation/flutter to develop, but on a <100 MPH airplane that is a very low probability. Today I more or less finalized the straps and wood saddle blocks to mount my muffler under the tailboom. I bought real surplus aerospace hoop clamps which will strap the muffler in place, and had to shorten them by an inch or two and rivet them back together. Managed to find rubber C channel that fits over the straps the same way as the rubber channel on a padded Adel clamp. The rubber even matches the color of the airplane ! So all that is left on that mini-project is repainting the saddle blocks with good old Aerospace-Oleum rattle can paint. Next project is weight and balance, finding where the battery needs to go or where it should not go. After that, the gearbox rotation and prop selection process. After that comes finalizing the electrical wiring, and after that is engine start and figuring out if it runs correctly. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Fri, 5/11/18, Richard Pike wrote: Subject: Kolb-List: Re: High Thrust Line Question To: kolb-list(at)matronics.com Date: Friday, May 11, 2018, 7:04 PM Pike" Increasing the size/shape of the horizontal stab ought to solve a whole bunch of apparent control authority issues. It would not be a big deal to increase the chord of any Kolb horizontal stab, and it would not take but a little creative thinking to make it work very well and still retain the folding ability. As long as you keep the basic concepts the same, all you can do is make things better. (Also - does nobody know how to edit/remove a whole boatload of previous/extraneous posts from their posts? So that we don't have posts that are full of scroll down/scroll down/scroll down extraneous/previous posts? Not that I want to be the list Hall Monitor; but seriously? This is stuff that we knew how to deal with back in Windows 3.5!!) Flame on... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480082#480082 The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Gerry Olenik Green Sky Adventures
Date: May 12, 2018
Kolbers: Wasn't aware of Gerry's death. He and I go back to 1985. Homer Kolb wouldn't sell me a 447 for my original Firestar Kit because he thought it was too much horse power. Sent the 377. I horse traded the 377 with Gerry for the 447. Saw him every year at Lakeland, sometimes at Oshkosh. He was a good man. I also noticed his older brother died two days prior to Gerry's death. Tough times. Rest in peace my friend. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: May 12, 2018
Subject: Re: Gerry Olenik Green Sky Adventures
Gerry Olenik passed away earlier this month, I believe it was cancer. His two sons are running the business. He was patient and helpful with all my newbie questions. I'm sorry I didn't get to know him personally. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Sat, 5/12/18, John Hauck wrote: Subject: Kolb-List: Gerry Olenik Green Sky Adventures To: kolb-list(at)matronics.com Date: Saturday, May 12, 2018, 5:49 AM Hauck" Kolbers: Wasn't aware of Gerry's death. He and I go back to 1985. Homer Kolb wouldn't sell me a 447 for my original Firestar Kit because he thought it was too much horse power. Sent the 377. I horse traded the 377 with Gerry for the 447. Saw him every year at Lakeland, sometimes at Oshkosh. He was a good man. I also noticed his older brother died two days prior to Gerry's death. Tough times. Rest in peace my friend. john h mkIII Titus, Alabama The Kolb-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Re: primer bulb quality
Date: May 12, 2018
Well first, I want to thank everyone for their ideas & input. Believe me; I'd much rather have the Facet (or knockoff) than the squeeze bulb, along with an actual electrical system; not to mention a starter that doesn't give the pilot a pre-flight workout. I wrote the vendor about the primer, and they are sending a replacement. It'll be interesting to see if it survives any longer than the 1st one. I decided to start collecting parts for an electrical system, & ordered a used regulator: https://www.ebay.com/itm/Rotax-Hirth-Cuyuna-Kawasaki-Ultralight-Hovercraft-3-Phase-Voltage-Regulator/192415528687?hash=item2cccdbf6ef:g:YUcAAOSw6D1a8EcK Looks like a single phase model to me, but the vendor claims it's 'three phase' (term used by all the vendors for the finned units; I can't figure where the two extra phases come from since there's only one pair of wires coming out of the lighting coil....). The Twinstar already has a regulator, but it was built from components by my friend who built the plane. He is very qualified to design & build one, but it's so old that the schematic is long gone. Now....Does anyone know of any old watercraft or snowmobiles that used the old points-ignition 503 *and* had electric start? I'd really like to find a starter that will fit, without paying the 6-8 hundred$ for a new one. Surely there are used ones available, but I need to know what makes/models had them installed. Thanks again, Charlie On 5/11/2018 9:33 AM, George Helton wrote: > I agree with you guys. A facet electric fuel pump is the way to go. I > dont use a electric starter so I run it off a small 1.3 amp AGM > battery that charges off the rectifier regulator with capacitor in the > charging circuit to balance the voltage output. I didnt figure this > stuff out. Its all thanks to you guys on the Kolb-List . Gotta go > with experience. image1.jpeg > Ive since relocated the battery to the nose but the system remains > the same. > George Helton > 1986 Firestar,FS100, 2702 Hirth > 14GDH > Mesick, Michigan > gdhelton(at)gmail.com > > Sent from my iPhone > > On May 11, 2018, at 10:12 AM, B Young > wrote: > >> You could check a boat shop. >> >> I bought a used boat in the late 80s, 2 stroke outboard,,, have no >> idea how old the primer bulb was when I bought it, I had the boat >> 20 years, and was still using the same bulb when I sold the boat. >> >> Boyd Young >> >> >> >> --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 13, 2018
Subject: Re: Kolb-List Digest: 4 Msgs - 05/12/18
(Also - does nobody know how to edit/remove a whole boatload of previous/extraneous posts from their posts? > > > Im using an Android phone, your milage may vary... At the end of my post there are three dots "..." When I tap the dots, it expands the previous email. If I long tap the first word I want removed, the word will highlight with a couple of drop down balloons. Tap and hold the last baloon and drag it to the bottom, or where you want to delete, then I hit the sisor icon at the top and cut it out. Or Don't hit reply, just start a new thread using the same message header. Or reference the old message by copying and pasting a few words from the old message. Boyd Young ________________________________________________________________________________
Date: May 13, 2018
What Boyd said, if you're using Gmail's web interface and get posts via email. That's what I'm using at the moment. I've bold-highlighted all the stuff that was in the 3 dots. If you're using the forum, it shouldn't be an issue unless you've set it to default to 'quote'. That does raise a different issue. Example: I didn't see the original post for this thread (I get individual email delivery). If you use the forum or use 'digest' delivery, it's always helpful to include at least some context in your reply, or those of us using individual email delivery may not know what you're replying to. Charlie *On Sun, May 13, 2018 at 10:08 AM, B Young > wrote:* > > > * (Also - does nobody know how to edit/remove a whole boatload of > previous/extraneous posts from their posts? * > >> >> >> *Im using an Android phone, your milage may vary...* > > > *At the end of my post there are three dots "..." When I tap the dots, > it expands the previous email. If I long tap the first word I want > removed, the word will highlight with a couple of drop down balloons. Tap > and hold the last baloon and drag it to the bottom, or where you want to > delete, then I hit the sisor icon at the top and cut it out. * > > *Or* > > *Don't hit reply, just start a new thread using the same message header. > Or reference the old message by copying and pasting a few words from the > old message.* > > *Boyd Young* > Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: May 14, 2018
Subject: video
I lost my wife of 53 years in January, and per her wishes she was cremated. It is my intention to scatter her cremains at our annual fly-in as a lot of our friends will be here. I had heard of many such attempts that went rather badly, so I decided to make one that I could use with the Firestar. Here is the result. https://vimeo.com/269726719 password owyheeflyer Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: video
Date: May 14, 2018
Another successful Rock House invention. Good work. Now get it cleaned up and painted. ;-) Kolbs are good for many missions. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Monday, May 14, 2018 5:17 PM Subject: Kolb-List: video I lost my wife of 53 years in January, and per her wishes she was cremated. It is my intention to scatter her cremains at our annual fly-in as a lot of our friends will be here. I had heard of many such attempts that went rather badly, so I decided to make one that I could use with the Firestar. Here is the result. https://vimeo.com/269726719 password owyheeflyer Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: May 15, 2018
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Subject: Re: video
Oh my gosh, Larry - only you!!! I showed it to my grandkids and they were d elighted with your ingenuity. Arty gmail.com> wrote: I lost my wife of 53 years in January, and per her wishes she was cremated . It is my intention to scatter her cremains at our annual fly-in as a lot of our friends will be here. I had heard of many such attempts that went ra ther badly, so I decided to make one that I could use with the Firestar. He re is the result. https://vimeo.com/269726719=C2- =C2- password=C2- =C2- owyheeflyer Larry -- The older I get, the less tolerant I am of those who are intolerant of othe rs. If you forward this email, or any part of it, please remove my email addres s before sending. ________________________________________________________________________________
Date: May 23, 2018
Subject: video
https://vimeo.com/271570733 password owyheeflyer Here is a video that I made today. The weather has been total crap for so long that I almost didn't try to go as I expected it to blow me all over the sky. The flight was to see how the water conditions are back in the hills next door. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: video
Date: May 23, 2018
Another good one. Enjoyed the flight. Made me want to fly again. ;-) john From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Wednesday, May 23, 2018 8:40 PM Subject: Kolb-List: video https://vimeo.com/271570733 password owyheeflyer Here is a video that I made today. The weather has been total crap for so long that I almost didn't try to go as I expected it to blow me all over the sky. The flight was to see how the water conditions are back in the hills next door. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: May 23, 2018
Subject: Re: video
Nice video,,, I thought it a bit early for things to be drying out. Boyd On Wed, May 23, 2018, 7:42 PM Larry Cottrell wrote: > https://vimeo.com/271570733 password owyheeflyer > > > Here is a video that I made today. The weather has been total crap for so > long that I almost didn't try to go as I expected it to blow me all over > the sky. > > The flight was to see how the water conditions are back in the hills next > door. > > Larry > > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > ________________________________________________________________________________
Date: May 24, 2018
Subject: Re: video
Larry it looks like some desolate country up there... beautiful and unspoiled, but not exactly walking distance from the grocery store. What do you have for a safety plan or emergency assistance if you wound upw ith a mechanical problem out there in those brown hills and canyons? Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Wed, 5/23/18, B Young wrote: Subject: Re: Kolb-List: video To: "Kolb List" Date: Wednesday, May 23, 2018, 10:21 PM Nice video,,, I thought it a bit early for things to be drying out. Boyd On Wed, May 23, 2018, 7:42 PM Larry Cottrell wrote: https://vimeo.com/271570733 password owyheeflyer Here is a video that I made today. The weather has been total crap for so long that I almost didn't try to go as I expected it to blow me all over the sky. The flight was to see how the water conditions are back in the hills next door. Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Subject: Re: video
Date: May 24, 2018
VmVyeSBlbmpveWFibGUgdmlkZW8gTGFycnkuIEl0IGhhcyBiZWVuIGEgd2luZHkgeWVhciBoZXJl LCBJIGNhbiBoYXJkbHkgd2FpdCBmb3IgY2FsbWVyIHdoZXRoZXIgdG8gZ2V0IGJhY2sgaW4gdGhl IGFpci4NCg0KVGhhbmtzIGZvciBzaGFyaW5nLA0KDQpLdXJ0DQoNClNlbnQgZnJvbSBteSBpUGhv bmUNCg0KT24gTWF5IDIzLCAyMDE4LCBhdCAxOTo0MiwgTGFycnkgQ290dHJlbGwgPGxjb3R0cmVs bDEwMjBAZ21haWwuY29tPG1haWx0bzpsY290dHJlbGwxMDIwQGdtYWlsLmNvbT4+IHdyb3RlOg0K DQpodHRwczovL3ZpbWVvLmNvbS8yNzE1NzA3MzMgICBwYXNzd29yZCAgICBvd3loZWVmbHllcg0K DQoNCkhlcmUgaXMgYSB2aWRlbyB0aGF0IEkgbWFkZSB0b2RheS4gVGhlIHdlYXRoZXIgaGFzIGJl ZW4gdG90YWwgY3JhcCBmb3Igc28gbG9uZyB0aGF0IEkgYWxtb3N0IGRpZG4ndCB0cnkgdG8gZ28g YXMgSSBleHBlY3RlZCBpdCB0byBibG93IG1lIGFsbCBvdmVyIHRoZSBza3kuDQoNClRoZSBmbGln aHQgd2FzIHRvIHNlZSBob3cgdGhlIHdhdGVyIGNvbmRpdGlvbnMgYXJlIGJhY2sgaW4gdGhlIGhp bGxzIG5leHQgZG9vci4NCg0KTGFycnkNCg0KLS0NClRoZSBvbGRlciBJIGdldCwgdGhlIGxlc3Mg dG9sZXJhbnQgSSBhbSBvZiB0aG9zZSB3aG8gYXJlIGludG9sZXJhbnQgb2Ygb3RoZXJzLg0KDQpJ ZiB5b3UgZm9yd2FyZCB0aGlzIGVtYWlsLCBvciBhbnkgcGFydCBvZiBpdCwgcGxlYXNlIHJlbW92 ZSBteSBlbWFpbCBhZGRyZXNzIGJlZm9yZSBzZW5kaW5nLg0K ________________________________________________________________________________
Date: May 24, 2018
Subject: Re: video
On Thu, May 24, 2018 at 12:21 AM, Bill Berle wrote: > > > Larry it looks like some desolate country up there... beautiful and > unspoiled, but not exactly walking distance from the grocery store. What do > you have for a safety plan or emergency assistance if you wound upw ith a > mechanical problem out there in those brown hills and canyons? > > Bill, That of course is the question and it basically comes down to the risk one is willing to take. My risk has escalated since there is now no one here that knows my plans or movements. I have a Spot tracker that sends out a track every 10 minutes. I installed a link on my next door neighbors computer, but as busy as they are, it might not be even looked at until I am missed. That could take a few days. In essence my main protection comes from a feature that allows me to request help. ( that is a non emergency situation) and a button that will summon 911. All of that assumes that I will be able to utilize these buttons. Of course if I am not able to do so, then it is rather a moot point. My best protection is the condition and type of plane that I fly. The engine, the landing gear, the VG's, all are designed to give me the best possible chance of survival. Still it all comes to the willingness to accept the risk involved. In answer to a question from Roger Hankins to the late John Williamson, about what happens if something goes wrong? He said " Well then its going to hurt". Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: video
Date: May 24, 2018
Another famous quote from our friend John Williamson. John W, as we called him, died 10 years ago tomorrow. Grateful for the short time we had to spend together flying and exploring this great country of ours. John Bickham was John B and I was John H. We were the 3 Johns. We had a lot of fun flying together and enjoyed each others' company. A group of us Kolbers became family 15 years ago at the first Kolb Unplanned/Unorganized Flying at Monument Valley, Utah. We hit it off and have visited at our gatherings at MV and at the Rock House every year hence. At our September 2018 get together we can also remember our buddy John W. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Thursday, May 24, 2018 9:07 AM Subject: Re: Kolb-List: video On Thu, May 24, 2018 at 12:21 AM, Bill Berle wrote: Larry it looks like some desolate country up there... beautiful and unspoiled, but not exactly walking distance from the grocery store. What do you have for a safety plan or emergency assistance if you wound upw ith a mechanical problem out there in those brown hills and canyons? Bill, That of course is the question and it basically comes down to the risk one is willing to take. My risk has escalated since there is now no one here that knows my plans or movements. I have a Spot tracker that sends out a track every 10 minutes. I installed a link on my next door neighbors computer, but as busy as they are, it might not be even looked at until I am missed. That could take a few days. In essence my main protection comes from a feature that allows me to request help. ( that is a non emergency situation) and a button that will summon 911. All of that assumes that I will be able to utilize these buttons. Of course if I am not able to do so, then it is rather a moot point. My best protection is the condition and type of plane that I fly. The engine, the landing gear, the VG's, all are designed to give me the best possible chance of survival. Still it all comes to the willingness to accept the risk involved. In answer to a question from Roger Hankins to the late John Williamson, about what happens if something goes wrong? He said " Well then its going to hurt". Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: May 24, 2018
Subject: Re: video
I understand that the upgrade to a 4 stroke engine, and VG's etc. are a big part of preventing a problem. My question was what if you simply made a good safe survivable landing out there, and found yourself un-injured and standing in one of those canyons. Looks like a long walk to anywhere. The SPOT device is a real good option, and I believe that you can "call 911" from that and they will send the Sheriff or local state troopers out to get you. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Thu, 5/24/18, Larry Cottrell wrote: Subject: Re: Kolb-List: video To: "kolb-list(at)matronics.com" Date: Thursday, May 24, 2018, 7:07 AM On Thu, May 24, 2018 at 12:21 AM, Bill Berle wrote: Larry it looks like some desolate country up there... beautiful and unspoiled, but not exactly walking distance from the grocery store. What do you have for a safety plan or emergency assistance if you wound upw ith a mechanical problem out there in those brown hills and canyons? Bill,That of course is the question and it basically comes down to the risk one is willing to take. My risk has escalated since there is now no one here that knows my plans or movements. I have a Spot tracker that sends out a track every 10 minutes. I installed a link on my next door neighbors computer, but as busy as they are, it might not be even looked at until I am missed. That could take a few days. In essence my main protection comes from a feature that allows me to request help. ( that is a non emergency situation) and a button that will summon 911. All of that assumes that I will be able to utilize these buttons. Of course if I am not able to do so, then it is rather a moot point. My best protection is the condition and type of plane that I fly. The engine, the landing gear, the VG's, all are designed to give me the best possible chance of survival. Still it all comes to the willingness to accept the risk involved. In answer to a question from Roger Hankins to the late John Williamson, about what happens if something goes wrong? He said " Well then its going to hurt". Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Subject: video
Date: May 24, 2018
Larry needs a new SPOT X 2-Way Satellite Messenger. Bumped into these on line the other day. Lets you text through the satellite to any cell phone, both ways. https://www.findmespot.com/spotx/lander.php I may look into one for staying in touch while I do some extensive marine cruising. I have had a PLB (Personal Locater Beacon) for years. Never had to use it, but got it in case I do need it. It hooks you up to NOAA SARSAT Rescue Center, but only to be used in dire life and death emergencies. http://www.sarsat.noaa.gov/new.html Before flying in extremely desolate areas, best to get some training and experience in survival with the proper survival equipment. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Bill Berle Sent: Thursday, May 24, 2018 12:56 PM Subject: Re: Kolb-List: video I understand that the upgrade to a 4 stroke engine, and VG's etc. are a big part of preventing a problem. My question was what if you simply made a good safe survivable landing out there, and found yourself un-injured and standing in one of those canyons. Looks like a long walk to anywhere. The SPOT device is a real good option, and I believe that you can "call 911" from that and they will send the Sheriff or local state troopers out to get you. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Thu, 5/24/18, Larry Cottrell wrote: Subject: Re: Kolb-List: video To: "kolb-list(at)matronics.com" Date: Thursday, May 24, 2018, 7:07 AM On Thu, May 24, 2018 at 12:21 AM, Bill Berle wrote: Larry it looks like some desolate country up there... beautiful and unspoiled, but not exactly walking distance from the grocery store. What do you have for a safety plan or emergency assistance if you wound upw ith a mechanical problem out there in those brown hills and canyons? Bill, That of course is the question and it basically comes down to the risk one is willing to take. My risk has escalated since there is now no one here that knows my plans or movements. I have a Spot tracker that sends out a track every 10 minutes. I installed a link on my next door neighbors computer, but as busy as they are, it might not be even looked at until I am missed. That could take a few days. In essence my main protection comes from a feature that allows me to request help. ( that is a non emergency situation) and a button that will summon 911. All of that assumes that I will be able to utilize these buttons. Of course if I am not able to do so, then it is rather a moot point. My best protection is the condition and type of plane that I fly. The engine, the landing gear, the VG's, all are designed to give me the best possible chance of survival. Still it all comes to the willingness to accept the risk involved. In answer to a question from Roger Hankins to the late John Williamson, about what happens if something goes wrong? He said " Well then its going to hurt". Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: May 24, 2018
Subject: Re: video
Hell its only 25 or 30 miles back to "civilization". An easy day and half. Larry On Thu, May 24, 2018 at 11:55 AM, Bill Berle wrote: > > I understand that the upgrade to a 4 stroke engine, and VG's etc. are a > big part of preventing a problem. My question was what if you simply made a > good safe survivable landing out there, and found yourself un-injured and > standing in one of those canyons. Looks like a long walk to anywhere. The > SPOT device is a real good option, and I believe that you can "call 911" > from that and they will send the Sheriff or local state troopers out to get > you. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and > for-profit entities > > -------------------------------------------- > On Thu, 5/24/18, Larry Cottrell wrote: > > Subject: Re: Kolb-List: video > To: "kolb-list(at)matronics.com" > Date: Thursday, May 24, 2018, 7:07 AM > > > On Thu, May 24, 2018 > at 12:21 AM, Bill Berle > wrote: > > > Larry it looks like some desolate country up there... > beautiful and unspoiled, but not exactly walking distance > from the grocery store. What do you have for a safety plan > or emergency assistance if you wound upw ith a mechanical > problem out there in those brown hills and canyons? > > Bill, That of course is the > question and it basically comes down to the risk one is > willing to take. My risk has escalated since there is now no > one here that knows my plans or movements. I have a Spot > tracker that sends out a track every 10 minutes. I installed > a link on my next door neighbors computer, but as busy as > they are, it might not be even looked at until I am missed. > That could take a few days. In essence my main protection > comes from a feature that allows me to request help. ( that > is a non emergency situation) and a button that will summon > 911. All of that assumes that I will be able to utilize > these buttons. Of course if I am not able to do so, then it > is rather a moot point. > My best protection is the condition and type of > plane that I fly. The engine, the landing gear, the > VG's, all are designed to give me the best possible > chance of survival. Still it all comes to the willingness to > accept the risk involved. In answer to a question from Roger > Hankins to the late John Williamson, about what happens if > something goes wrong? He said " Well then its going to > hurt". > Larry > > > -- > The > older I get, the less tolerant I am of those who are > intolerant of others. > If you forward this email, or any part of > it, please remove my email address before sending. > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: video
Date: May 25, 2018
Great Video, thanks.. As Boyd mentioned, only May and that dry, what happens July / August? -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480393#480393 ________________________________________________________________________________
Date: May 25, 2018
Subject: Re: video
The rural fire district gets lots of exercise. Mid July through August is rife with dry lightening storms almost every day. Larry On Fri, May 25, 2018 at 12:52 PM, west1m wrote: > > Great Video, thanks.. > As Boyd mentioned, only May and that dry, what happens July / August? > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=480393#480393 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: video
Date: May 25, 2018
Yep, gets really dry at the Rock House that time of year. Pack rats fart little dust clouds. Kind of cute. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Friday, May 25, 2018 2:05 PM Subject: Re: Kolb-List: Re: video The rural fire district gets lots of exercise. Mid July through August is rife with dry lightening storms almost every day. Larry On Fri, May 25, 2018 at 12:52 PM, west1m wrote: Great Video, thanks.. As Boyd mentioned, only May and that dry, what happens July / August? -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480393#480393 -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jun 05, 2018
Subject: new video
I decided to go flying today, so recorded my flight. Unfortunately I foolishly uploaded an update to my Virb program and it will not display the normal speed,altitude, track and the other stuff that I liked so well. Every time they have an update, I lose something else that I liked about the camera. https://vimeo.com/273592183 pass word owyheeflyer Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jun 05, 2018
Subject: Re: new video
Hey Larry, thanks for taking us along. I wish that I could get my virb elite to record as smoothly as yours. George George H. Firestar, FS100, Hirth 2702 14GDH Mesick, Michigan gdhelton(at)gmail.com Do not achieve Sent from my iPhone > On Jun 5, 2018, at 7:38 PM, Larry Cottrell wrote : > > I decided to go flying today, so recorded my flight. Unfortunately I fooli shly uploaded an update to my Virb program and it will not display the norma l speed,altitude, track and the other stuff that I liked so well. Every time they have an update, I lose something else that I liked about the camera. > > https://vimeo.com/273592183 > > pass word owyheeflyer > > Larry > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Date: Jun 05, 2018
Its all in where you put it George. Just try different spots till you find it. Larry On Tue, Jun 5, 2018 at 6:16 PM, George Helton wrote: > Hey Larry, thanks for taking us along. I wish that I could get my virb > elite to record as smoothly as yours. > George > > George H. > Firestar, FS100, Hirth 2702 > 14GDH > Mesick, Michigan > gdhelton(at)gmail.com > > Do not achieve > > Sent from my iPhone > > On Jun 5, 2018, at 7:38 PM, Larry Cottrell > wrote: > > I decided to go flying today, so recorded my flight. Unfortunately I > foolishly uploaded an update to my Virb program and it will not display the > normal speed,altitude, track and the other stuff that I liked so well. > Every time they have an update, I lose something else that I liked about > the camera. > > https://vimeo.com/273592183 > > pass word owyheeflyer > > Larry > > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jun 05, 2018
George I have a pitot tube from ACSpruce that is made of plastic and the tube holder is threaded. It is made so that you can remove the pitot tube to keep a knucklehead from brushing against it breaking it. I took a piece of alum. flat stock and bent it to accommodate the holder for the virb. That point is the least amount of vibration in the plane. Not sure if it works for you or not, but it does for me. Larry On Tue, Jun 5, 2018 at 6:16 PM, George Helton wrote: > Hey Larry, thanks for taking us along. I wish that I could get my virb > elite to record as smoothly as yours. > George > > George H. > Firestar, FS100, Hirth 2702 > 14GDH > Mesick, Michigan > gdhelton(at)gmail.com > > Do not achieve > > Sent from my iPhone > > On Jun 5, 2018, at 7:38 PM, Larry Cottrell > wrote: > > I decided to go flying today, so recorded my flight. Unfortunately I > foolishly uploaded an update to my Virb program and it will not display the > normal speed,altitude, track and the other stuff that I liked so well. > Every time they have an update, I lose something else that I liked about > the camera. > > https://vimeo.com/273592183 > > pass word owyheeflyer > > Larry > > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jun 05, 2018
Larry, thanks for the video. Always enjoy them. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480697#480697 ________________________________________________________________________________
Date: Jun 05, 2018
I=99ll work on that. Thanks, Larry. Sent from my iPhone > On Jun 5, 2018, at 8:25 PM, Larry Cottrell wrote : > > Its all in where you put it George. Just try different spots till you find it. > Larry > >> On Tue, Jun 5, 2018 at 6:16 PM, George Helton wrote: >> Hey Larry, thanks for taking us along. I wish that I could get my virb el ite to record as smoothly as yours. >> George >> >> George H. >> Firestar, FS100, Hirth 2702 >> 14GDH >> Mesick, Michigan >> gdhelton(at)gmail.com >> >> Do not achieve >> >> Sent from my iPhone >> >>> On Jun 5, 2018, at 7:38 PM, Larry Cottrell wro te: >>> >>> I decided to go flying today, so recorded my flight. Unfortunately I foo lishly uploaded an update to my Virb program and it will not display the nor mal speed,altitude, track and the other stuff that I liked so well. Every ti me they have an update, I lose something else that I liked about the camera. >>> >>> https://vimeo.com/273592183 >>> >>> pass word owyheeflyer >>> >>> Larry >>> >>> -- >>> The older I get, the less tolerant I am of those who are intolerant of o thers. >>> >>> If you forward this email, or any part of it, please remove my email add ress before sending. > > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Date: Jun 05, 2018
Good video, thanks for sharing again. -------- 912ul King Kolbra ;fun plane O300 Cessna 172B ;travel plane Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480701#480701 ________________________________________________________________________________
Date: Jun 06, 2018
Subject: Firestar / HKS update
Well, yesterday was Weight and Balance Day, otherwise known as "No More Don uts For you Day" The Kolb factory website says that a stock "per plans" Firestar 2 should we igh approx. 325 pounds. I am guessing that this figure is pretty optimistic and definitely bare bones, pull start engine, tiny tires, etc. Mine has heavy wall steel tube, extra long main gear legs, brakes, and gian t 22 inch bush tires, plus my HKS engine is 20 pounds more than the 2-strok es like the 503. My aircraft came in at 389 pounds empty, with no gas or oi l, and without a battery. With 10 gallons of fuel, a gallon of oil, a 12AH sealed battery, and my fat butt in the seat it will be within 20 or 30 pounds of the max gross weight (725 lb. per plans). The CG worked out to be about 28% of wing chord, but this is speculative. T he Kolb plans say the wing chord is 64 inches, but the Firestatr only has t hat much chord for the outer half of the wing... the inboard half of chord is 53 inches, which would effectivey put the CG further aft. Considering that the usual "elliptical lift distribution" means that the in board half of the wingspan is doing much more of the work than the outboard half, logic tells us that the "chord" we choose to use for W&B should be t he inboard half. But the CG of my aircraft is within the published (and pre sumably accurate) limits whichever "chord" you use for your calculations. Bill Berle www.ezflaphandle.com=C2- - safety & performance upgrade for light aircraf t www.grantstar.net =C2- =C2- =C2- =C2- =C2- - winning proposals fo r non-profit and for-profit entities -------------------------------------------- On Tue, 6/5/18, Larry Cottrell wrote: Subject: Re: Kolb-List: new video To: "kolb-list(at)matronics.com" Date: Tuesday, June 5, 2018, 5:34 PM GeorgeI have a pitot tube from ACSpruce that is made of plastic and the tube holder is threaded. It is=C2- made so that you can remove the pitot tube to keep a knucklehead from brushing against it breaking it. I took a piece of alum. flat stock and bent it to accommodate the holder for the virb. That point is the least amount of vibration in the plane. Not sure if it works for you or not, but it does for me.Larry On Tue, Jun 5, 2018 at 6:16 PM, George Helton wrote: Hey Larry, thanks for taking us along. I wish that I could get my virb elite to record as smoothly as yours.=C2-George=C2- George H.=C2-Firestar, FS100, Hirth 270214GDHMesick, Michigan=C2-gdhelton(at)gmail.com Do not achieve=C2- Sent from my iPhone On Jun 5, 2018, at 7:38 PM, Larry Cottrell wrote: I decided to go flying today, so recorded my flight. Unfortunately I foolishly uploaded an update to my Virb program and it will not display the normal speed,altitude, track and the other stuff that I liked so well. Every time they have an update, I lose something else that I liked about the camera. https://vimeo.com/273592183 pass word=C2- =C2-owyheeflyer Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. /9j/4Uh6RXhpZgAATU0AKgAAAAgACwEOAAIAAAAgAAAAkgEPAAIAAAAFAAAAsgEQAAIAAAAJAAAA wgESAAMAAAABAAEAAAEaAAUAAAABAAAA0gEbAAUAAAABAAAA2gEoAAMAAAABAAIAAAEyAAIAAAAU AAAA4gITAAMAAAABAAIAAIdpAAQAAAABAAABEsSlAAcAAAAcAAAA9gAAKvYgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgAFNPTlkAAAAAAAAAAAAAAABEU0MtVzgzMAAAAAAAAAAAAAABXgAA AAEAAAFeAAAAATIwMTg6MDU6MzEgMTQ6MDU6MTYAUHJpbnRJTQAwMzAwAAAAAgACAQAAAAEBAQAA AAAegpoABQAAAAEAAAKAgp0ABQAAAAEAAAKIiCIAAwAAAAEACAAAiCcAAwAAAAEAUAAAkAAABwAA AAQwMjMwkAMAAgAAABQAAAKQkAQAAgAAABQAAAKkkQEABwAAAAQBAgMAkQIABQAAAAEAAAK4kgQA CgAAAAEAAALAkgUABQAAAAEAAALIkgcAAwAAAAEABQAAkggAAwAAAAEAAAAAkgkAAwAAAAEAGAAA kgoABQAAAAEAAALQknwABwAAKAAAAALYoAAABwAAAAQwMTAwoAEAAwAAAAEAAQAAoAIABAAAAAEA AAKAoAMABAAAAAEAAAHgoAUABAAAAAEAACrYowAABwAAAAEDAAAAowEABwAAAAEBAAAApAEAAwAA AAEAAAAApAIAAwAAAAEAAAAApAMAAwAAAAEAAAAApAYAAwAAAAEAAQAApAgAAwAAAAEAAAAApAkA AwAAAAEAAAAApAoAAwAAAAEAAAAAAAAAAAAAAAoAAA+gAAAAIQAAAAoyMDE4OjA1OjMxIDE0OjA1 OjE2ADIwMTg6MDU6MzEgMTQ6MDU6MTYAAAAABAAAAAEAAAAAAAAACgAAA3IAAAEAAAABwgAAAGRT T05ZIERTQyAAAAAAKCAAAAcAAAABAAAAACAKAAQAAAABAAAAADAAAAcAAAFIAAAExrAgAAIAAAAJ AAAGDpQAAAcAAACYAAAGGJQBAAcAAAsQAAAGsJQCAAcAAAGEAAARwJQDAAcAAAGQAAATRJQEAAcA AAGoAAAU1JQFAAcAAAXYAAAWfJQGAAcAAAAQAAAcVJQHAAcAAABAAAAcZJQIAAcAAAK8AAAcpJQJ AAcAAAJYAAAfYJQKAAcAAACoAAAhuJQLAAcAAAGQAAAiYJQMAAcAAABAAAAj8JQNAAcAAADIAAAk MJQOAAcAAAAQAAAk+LBAAAMAAAABAAAAALBBAAMAAAABAAYAALBCAAMAAAABAAQAALBDAAMAAAAB AAEAALBEAAMAAAABAAEAALBFAAMAAAABAAAAALBGAAMAAAABAAAAALBHAAMAAAABAAAAALBIAAgA AAABAAAAALBJAAMAAAABAAAAALBKAAMAAAABAAAAALBLAAMAAAABAAIAALBMAAUAAAABAAAlCLBN AAMAAAABAAAAALBOAAMAAAABAAAAALBPAAMAAAABAAEAALBQAAMAAAABAAAAALBRAAMAAAABAAAA ALBSAAMAAAABAAEAALBTAAMAAAABAAAAALBUAAMAAAABAAAAAE1NAF4BAjIwMTg6MDU6MzEgMTQ6 MDU6MTYAAoAB4AAAAggAAAAAAAAAAAAAAAAAAAAAAAlUSG0yMTEwMDAwMDAwMDAAAAAAAD6U+gEA AAAAAAAAAAAAAAAAAAAAAAkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAABTdGFuZGFyZAAA0QEBAAAAAAABAAFwaYiVAP9V/1X/Vf9V /1X/Vf9V/1UAALTNAAALwwAACwoAAAuhAAAAAAAAAAAAAAAAAAAAAABM45YATLeRAEx/gABMJNgA AAAAAAAAAAAAAAAAAAAAAEUA4wAAAAEAQAAbAAAAAAAAAAAACAAAIJWKgQAAAAAAAAAAAAAAAAhK AT4AGwAIAAgAAQzMAAB8AABAt0TTnv/4BYq2wQCRyziOMbo9/0MAgZUAAAC2UnAAYeEACARKfUr/ /wAAlQC6AAAAP2AIOUuTCMRaLkpBDs0qFgjYofYOAh2VxD8HcBFU5oaHrvo8yTw/B8QOzzKrQIZa xAD/////zYhBJAAbCbc0UZ5KAAAZQGn2GyUOuABb6kr5DnYFLZfErupJ6ozqjOpJ6kpV9gaqiweW OCCWBF6VSnAEQX1RAFVqSkBw9gAZaXBwB16BsoFAVlZAJ9hpAcLESryFAX0toFsYzwIBxWrEvg4K gSLqUQCACAVJEP//////////////////////////////////////////OTmHTPDw8EyHOTk5OYdM 8PDwTIc5OTmH8O8CtwLv8Ic5h/ACK8TcxCsC8IdMJCtObkFuTiskTPACy0u8sLxLywLwGgK6dCcV J3S6AhpM4uAjRUtFI+DiTAdM77dHkUe370wHAXJvykHye4AtLjYZWHL5NNo0rgnCQiIcXYXm1oQc OXRfOHCiPLJGmQRrNQN05+4E/mmeaZ4gA4Fq1zps5iTc7lE4c33JDippXCCdtqpwXnD4aul5BAKD aot9NtiDBP1WJ14LBVDNZWxJB/y38eJ6Xs3Y+gTU6vlpxNdGvkGBsJU4LzdRwIgV1w+S2ii2u3sw +uomaZKBlyh7u/K+azBviN4g4dewgQPXQbuYKMOS+4GpMHu+KtdEvjrX97uSkvwM9LuYgWyBSnKN yqXACNXdaKdCpfJ2wDHAuXJ+rdgGcZ7Yq6bIhWKodM21ms7nQquyn9acBC0EONdEILO+Aruuu9WV wXkKzxZbK17mVmtwur7IiD9pZYirBzBg9iu/h8Ve3+eVBenNzefKtn1wk1FNGsNHgQKo5wQEis3j cAcgQ5IIu0YMUF3jOTtq0b4gDLDswGxhDALXCwWcMMIomZUG7PXX0YE5vhTXgbv3kjuSxSiPlVyg XiiQvvq7W7u5u2m7WQyf7LRs+uwCKN3sHQnCnYjfEkK2LuzO+wkEF9EXe0L5mV8RfikDAxwlpX/J RVkcLYROP3Q1+ZeWXizYoyBRtsggKNcxvk3s4+JlZQgTgEDGDijNBSAAtlOKenBQXUh5RnlFXaxA F31EVtjn915SBdvNVOyyOQ8CPvB72EzYf+cUzXBpdtdJvk7XC6AD0z2VLoi91/mSwwyigXwwt1aa tsuB2AxHgbIwXCA2aZsgKNeMgVK+9YGbDOi7rteYiM4wN75lMP3Xw4FvknYMDoExvnzX/AAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAJUAlQCVAKBKoMWg7JUAlQCVAJUAbLJdXzknJC+VHVEMXScHGS+6 lWWguaCDtmXw64cKL+tqQV15XYhcZNNJLzlRVi9moH45FGzdXUq7mKAmoP8v8S+fL5w584cbOSco H++havGSomxGDMfTxy/PGi8HsV3soODTOFEUUcKV9i9eL17TJS+FL40v3NPVL6AvxmrLL7bTZtOM 0+8v4121XfLTxtM406JR4S/H0zbTJtO7L0Yvnl3s0xHT/9NM04zTNtPM0/IvipUAlQCVAFFOUQtR +5UAlQCVAJUAleGSMrtNtsaVR6C/KLa7pSg/UaBRllHEh0y+9rtcbL8oj+wl7OUM+KDEbGCVwpVf xQBs15UdoPWHVi9aUcpsf2xmbOfTfZXglStqz+xBUU3F1V1CxVKgk2w1DNvTIFGgLzugeJVEUZmV 3qCCoMugsmzHoJhsjWzWoIhsp2y8oK+VZpXWUZVs06B9oLuguaCKbBSVdJUkoL+ViZX7bH9snqAE oHJswaCZbP2gWpWtlf+V2gAAAAAAAAAyABEA6QAAAAAAAAAAAH59MtjMBYQA4ACXQFbYuRsjAGAA GgBYAbMbvH3HARQbaQgiCD5AawF5CFEARQBWAMQI7gA9AIAIbAA4AMsITwFxCHsAcADvADYA5gCd ANEBMQHvCK0BOQHVAHoAIwBbAFQAsADUANoAeQHFAW4AnQGMASMBCwGmAYwBawHnAN8AhAAdAKoI tgELAVoA6QEzAS4AMQCjAbYAnQCmAdEBFwEDAB0B1gA1AVgB5wDWAI8AnQAAAAAAAAAAAAAAAAAA AAAAAAAAAADStdZr0e3Wa1tbsLCcWwAAAAAAAAAAAAAAAAAAAAAAAAAAAAC7te7fSgBm0wAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAANWsckIJwmhqA0w3ZpkSCSXfn9UvTYEl5LgdKnsGzKlm3Ql2aa5U5nLBlZ6l XE0auHnuTJ9dMTmKJFIjMe46sYlBUthk52RwIGkQtka2QCDBL30k8+CSedfYXF6NVuHNu+rdim9p RmykB6jvkhq150kEsM3CimJpqSDDMGKBmJVaXV0vFmmRILS+KYGR1z6+OWm+MDKSUijxDDe+or4c vly+HIEFgWrXS4GADOqSPbtqvre+39fNvnLXubt5kmsMvJICu9iBFwAAAAAAAAC+AMwA9whUCKhA uhuzG/F9AOpTDvF9lthFDrOIvLuqxfrX8w6zQC8bYhs3fbUAtQC1ANEIB1bkOcAAAEoAAAAAAP/E bUYAAG1GAAAA9gAAAAAAJwD2ACcAAAAAAAAAAAAAACcA9gAnAF0APwAAAAAA9gAAAF0ISgE+AAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbAAAAAAAAGyUbJQ6YDtIAWwBbAAAAAQAAABYAAC/Q AABR5gAA/7YAANhR2EP/rxsl50T/xxsl507/tABKJ1F/P8WeL5W0gcWHCAUODqFRCIHxefr2AFb/ +/LXfnfbEXkArwA6XIaGxy8RgeEKSQARBPaX111TVicgJ7PnG25KBCIRzJf2SgRKDeGHOtrMEX9A QAiV3Aj23ZaWkg73PAGVCBlwwhDDmAA6zM7NvmkO5ikIOnAAvtimGynuAAoAXZVwG8NGAXYAxw4K FsNAxWbOx1EyCHYBsbbJXSjEjtMOOOF+FOBJlUoAxffjzpVRPkrYG6TFkl3C7q465ycIvkwFAAAA AAAAAYqvAAAAtnAbihKKEorriusAtrbBitYAAAAAAAAAAHCUipT/AAAAAAAAGwAAAAAAaVMAAH0B AAABAAEADgAAAAABAAAAAQCVAAAAzAD/AQD4oAAAAP4bAAAAAABeAAAAAAAAAAAAAAAAAAAAAAEA AAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPWK/Ip4inyK9IobcEOKmYpDigCK/wjsAAAAAQAA AAB9AAAAAAAAemmUiktLS0tLS0tLSwBpAGkAaQBpAGkAaQBpAGkAaQCXEcbMxhHGzMYRl8zGEcYR xswAgQEAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANAAAAADNaQgAAAAAAKAB vYIRW7NPKAEB//4AAAAAAAAAAAAAAAAAAAAAAACW/y4AAAAAAAAAAAAB/5BHIEdcK28rIc0AAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEruSiBK7s1wbUNtkG2JBL5trm2LbYXnAG0kbSRt 4+dwbYVt5m2y6gBt423Ebc/ncG2ybT9tqOoAbc9tRW0T2HBtqG0mbWTYJ210be5tz0BGbSZtwG0m fSdtdG1FbVIORm3AbTRt+wSVbUttS23aBCRt+237SgAOlW3abdpKALYkSgBKAEoAXpVKAEoASgBe JEoASgBKAA6VSgBKAEoAXiRKAEoASgDnJEoASgBKAH0kSgBKAEoAViRKAEoASgBAJEoASgBKAOcC SgBKAEoAXmAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADRBAdgBGwAAAQAAAABN AP8abQCVB20AQAAAEhIAlVMAEgD4ADAAABIAAL9uddzEDgBtfgAiqshLAMQOzEpd9ucAMHAAGycA QLbBQJ8AALdEaX9g/kfsXkgoQJJOCAEQXdO2SszFCEcAOyi2DiCD7g7ERzwTaRWWJFZ9VIEA53lG 2AFLlQEIBHAI2JU8AicA4MR9rpU469gvL+FPx8JVkpNAdwE/laAe9sXTfSAO8F3u9uezHwABS3gS 1eNVJLoRAtg8LBsODgjJxQ4vAEwbcKVBSsgAWABA4wjcxKpSAEDEiLLMkkYAeTgn6gQbljm858Ug WAcZUuNKPwjECD6VXJUA32LTCNPnB+fELwAASg6h2EfTcABFQOAI7sQAQDgA7lF9h3g9GiSlx6Fp eicAmfIkDsRAPuO6fT5RJJUA2EDvUVQZBEIZYtcg6MRH4PYqqGqVxOcFv/AoQARAWkoAGokBuxDH Dg4BAAFAWMc4tocE3DizQADEMgECQIoEUkDMQMI0xwAkZiCI3QA9VuNcTn3208yVSuPijwDCDrIB QCIAAcLrCAZVXVYAWDxKAQc6Fq4vzkmCdxlA5zo6CMdAZXC22XZKKYHTBAHbAYFKXVE/t4GFQJXm UQAA0z8ohzFvJDovUccBOhHHhpLHsUo4FQcIACT2IHbH51zTxerHh+cCDhReDgiuAi+SxZWWCVYB 3ZEOaXBKBHRKZjPqFBRN6g5K0AhOS04gDqoBRVGWCQ6Is+EgAVgHYgVmRRhpGQB9KkCV02YHQEzh JAjpbkuG124AG3nA43BG4wCVludwvIgAcdizKz8wTw4IAAjjrFEHtu49kmlYgeondcgtxCQANN0B QEx+zYEFSjpABsJAcFdJzS9A9uJ2aTRJzQIxEdvE03aBP3bqSsKBfsTclsQbcnAfQEBRxwBdQMcU MWl4DkIp6kCKTIWeXk8AgCcELEkaYYUgSuMKPwgQbH0ADJMaAYn2Qjh9geW2/T5L6iiVeec/SROB tjRdT4F1B44/yRBYVBGePjBK5D8HFHBOG+MBAKQIhjjOG+EnADpAs5V9AAFCBC/ZSgGB7AjdMEoB 4c1wauexwg5/4g6pMDw4WFuATunu+D/NAWrEQIEAlgEwMHm7OdOPRkobS2VwQN7Y+eMONMJKDpXP P8THACdJw7042NlOxwJSeQAOAIFdPECBG6724YhUAdNw2xsDffa8AV4QAUA9xHBeL1IHv7IQhj9U DsTjvpYgPL53ogFHZwARSQBGgfJ0QEnHqgFubs8b4jjKS8QEDq7zcBVyX0r2CRBAtpUBtjvEaVXi 3BRsptM2EPNe7XARxLKyPzgolZULtkE/s9AAJI/cUDjESk0ZUw4ExwA6YjIZANiVzOHEk7ZAAGlO Ad4IqIwZv26O3MQOxAB+ADskyEtwxA7MSl3u50AwcAAbRgBAOgNKvlIBEuInIFgOg3PArNPCkk4I AKRd07ZKzMUIRwA7KIgOVCfuDsRHPBNpFX8kVuxUgUrneTjYAUuVtgiScAjYlbMCJwDgxH0alTjr 2C854U9Kwjexk0B3tj+V7B7QUdN9VA7lXe7E57MfAOdLWBLV41UkuhEC2DwsGw4OCMnwDi8ATBtw pUFKyABYAEDjCNzEqlIAQMRTTcySRgC/OMTqBBuW7y3nUSBYBxk44wA/AJYbPpVclQDfYtMb0+eH 58QvAABKDuHYR9NwAEUgNwT2wgBAVHDuUX2RuT11JKXHooh6JwCd8iQOxEA+43nNPi8kleNAQO+V VBmSQhlikyDoxEc39iqoapXEUQW/8ChAZUBaSgAaiQG7EDwOgQEAAUBYxzi2MQfcOOdAAMQyAQLM iodSQMxAwjTHSiRmIIjdAD1WTlxOfcTTzJXMTuKPAMIOsgFAIgABwusIBvddVkAOAH2ylUAokAEA AAe2J9e6A1MASZbE2LYASqSeCJasSiCWzA6CPJa+t75wSi8kCDrhxZLdabuW9oDjAFXMAeGIAA7j 6kobxGUAzfZKoThdGgjnlSQAIHC2cMIwQHYAS5ZVOkqoDvahCIGVAH0ADqtpACRAUdMV4tUAGxvs NJbMICgBPQC4gsO2Rt8nPIjEDji2Vb0HSwBwxAgHUtfhxJYglemN40AyMpZK9j3jvAABH0tJQC8O x/LEXsQB9l1AUfJAx3B1OjFSXKfCQCDchwBi3AjERwFU20AA4Tz4rg7ElVEACgEBGuPpDm6BKUHM ShqexMQpgQCGYj/EAe5JwkontJbXs8QvS7ZWfbvzxONAAZWGStPT3au+YPDM19AIGU4nCFDOCEk4 zgEHAAHqAKFA5y9KAEvw4YPRSgF9Sigfga5u0ADyILCBIGY4arbCVJWBj0DCAMTnW+OPnnDh4fJw qlgAbOMHCDhbmZWV8ni4XT00NSAIUW4atg6dVA4/xJKsx8dpBLYekXm+eadACPbEDidUNkkmAdfc CIbMJzFRQZX2PgEIDgdACAd0OeGqzbZ2FuDdlQEOgQ4bCLZAcA+VquVdhGl0Sp5MTABeTT/QlksH tiggaUc4QQBdvMU8ni8OZUpafsQOuwAIoXIXVFZkttCzlg4gU6QBIOMOstspVBddcAAp58JOj5Vw kIG7xFHEYeHCAHBYIL53RKQ/HsK6AEAAP2B9WxuQ6MJKDnBuxFzHns00KIVd4/ZM8gCBi1aG1yFW kIF1Vj8F+GnXBdRp1gUDacMATP6G+Xj7EgAa/pf5cPuEAAAAAAAAAAAAgAVEMDIALc0mvpIAk0w/ qQAI4HAABRtKAM0ISjABJAAAAAAA2Nuy8FVhISRAUyXiNdwSy0NE2O8yV8zvef////////////// /341lUVFWDki22oackSY8M7PFyTcI8mO1P////9YTvDO20TiYUGTeY04WyRIxM51FVg24i0nZiQ2 ////////////////OuxdGePsh8EQ8vDtJw7i1v///////////////xBP8PgMtvOLB43YoFGr1sgA AAAAAABeMQHgG+h9XwCWANAAAOe8wrFXUNiwBMxRqwpgAAAAAAAABNAB5+cvAaAAAAAAAAAEltjm BAH/////th0BAAAAAAEAAQAAAAAAAAAAAAAns+KvJ23i2lgF4sJYBeLCWAXiwidt4tqpY++3qWPv t6lj76mpY++3qWPvt6lj77epY++3qWPvt6lj77epY++3qWPvt6lj77cA/wD/ALAAlQD/AAAAAAAA AAAAAAAAALQAQGBKRNjvMgAEAAAAAAAAAAAAAABAqAQBADp6AABrtKlj77cAAAAAAAAAAAAAAAAA AAAAAABrtAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAa7SpY6ljqWNlAP8AeQD/AHAA//8AAP8A AAD/AAgACAABAKlj77epY++3AAAAAAAACAAIANhK/QcA0P/MfWD/fwAg/hJA/AEPAQABsgEPAQAB sgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB/wCqAX27AAAAAADHAAEBAAAAQAAAAJUISgAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAOcAAAB2AAAAagAtAHYAAKlj/yH//P/rAGEARgAAAFAA1xRKFS0l fh+nnp7HFDTXXPI+lQFwwD3T0yeh6ucnCHB9yM9RXZVKIHkwh4EHzMF+wwQl27QYAc7ggcnOb2We JYDFdq4ATJVsKEpcDieuXH4QACietDrT7upAAErIfho6G2UBUMwFxADTTgfow2opzExHAHxR6jlc lWasfyurQPYAmVuoL1IBhgHY5keuurMOxxZAlUDmxwAbKEaHnQfzgJZd0pZWAgAA4gC7P8XHCKFL pJFHQLQIhzlACgAEAADMvgAI0xQBUn1u84U+XEpKQAE8AIDyCKSWVAgfVtjTxFgOSgddDiQbyyJ0 x0k6xzx+WJUlQEqXlYU/x2GVUQ5MSi+4P/Y6UBYWdQB+uxkStEoHxTWexENJmsTBYBGV2JXMAUjn 6gAAlQmAfQ7EurEEgLaVcCzMxYFHfoQBlNDmouFpfYPTSZXmeYEIhyRJ+QjIgHcg0JI/4fYBxMfO AeAEywA/lgj2xzSWEr0TG548tsfYQIhACdvDOiJA29M8GysIttPOsSInrMAAJW4Olgd453ZGfbZ0 5yC0cEfCYD0H06JLJA4EABkHXE1KE0rHx9gUx0lpAbsqB0yB3AQ6lTlcw0o9B91d2wcvGzgIsG/z uv4I+jxKML7dlUrqkZUxBFgB5q4Hpthwrn9pFABPOhsEADS9DrXTOr859pUgzINSKZ6W/GlRPSfG 04J/HofNFknYADDTcAfYPyQEzup27kpxqpXY3OYIgT5+4w7jIMRAXgBiPzn4lTspoRYbCD8ESsd9 VnkyGi+ZDsR6cF20BkkkhenEBwDqxAFYTyAa3Z62BVIDAB6VffIBAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAABAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAANlIEoHZAAAAAAAAAAAAAAAAAAAAADQACLgb2kD2QANALwhOCNUbJxtrGwcA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQFTY Tg4ODiJexhvKfQDYJ14bfQoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAjvKO8o7yjvKO8nCUcHtw74r1ipQAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABQCzxDwHG2W7TkoAhUDllsJph5bEmWzY 0zwCAKFwDlPNan5vVgGamgDTWQhAJJZKaUmV+7YptjoS6ns2wlSrkkkANAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAHGT/TAXE8Q54RAL8IADppAAAACgAAAAoAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAAQACAAAABFI5OAAAAgAHAAAA BDAxMDAAAAAAAAoBAwADAAAAAQAGAAABDwACAAAABQAAK3QBEAACAAAACQAAK4QBEgADAAAAAQAB AAABGgAFAAAAAQAAK5QBGwAFAAAAAQAAK5wBKAADAAAAAQACAAABMgACAAAAFAAAK6QCAQAEAAAA AQAAK7gCAgAEAAAAAQAAHLoAAAAAU09OWQAAAAAAAAAAAAAAAERTQy1XODMwAAAAAAAAAAAAAABI AAAAAQAAAEgAAAABMjAxODowNTozMSAxNDowNToxNgD/2P/bAIQABAMDBAMDBAQDBAUEBAUGCgcG BgYGDQkKCAoPDRAQDw0PDhETGBQREhcSDg8VHRUXGRobGxsQFB4gHRofGBobGgEEBQUGBQYMBwcM GhEPERoaGhoaGhoaGhoaGhoaGhoaGhoaGhoaGhoaGhoaGhoaGhoaGhoaGhoaGhoaGhoaGhoa/8AA EQgAeACgAwEhAAIRAQMRAf/EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCxAAAgEDAwIE AwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJico KSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZ mqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6 AQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYS QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQACEQMRAD8A+/qKACig AooAKKACigAooAKKACigAooAKKACigAooAKKACkLYpiuJvFLmiwri0UigooAKKACigApM0CuYVh4 28Napdx2en+INLubyQEpbx3sZlIAyfkzu6e1b1G4wooAKKAEJqMtVJEs57XvG/h7wyk51rWLO1lh Xc1uZgZjxkYjHzEnI4ArL8M/F7wZ4quILTS9aiF7MoK29wjQtvJA8vLAKXycbVJJ6jI5ptoEjsor +0mu57SG6gkuoApmhWQF48jI3L1GRyM1YqCgooAKKACkJoExM00mqRJ+UGhftPeNtTkSwudC0bXJ l+aVpbNlYoDyxZXVVH+0VwOK9CtP2k7HwuTBqHhe88NwSTAXD6Nr3luZdgJPlJsJIVhkk4GQM54r HRNK+5sk7Hb6L+2F4emAgi8a+I9FhUfK+o6dDd7sKByQssnYdcZOT3Jr1rw1+1LpGsJPcr4j8KX9 uMCOOSWTS5F+vnFieo6KP14p3QWueiaV8YIr7ToLt9Enull5D6VeQ3cOM8ESM0e4Y56fnV+b4v8A hu2Ei3Q1OGZWcLG2mzHeFz8wcKUAIGRuYHkA4PFHMhWPPtZ/ai0+wM8mn+HLu8tUdY0d7lY3ZsZY FVVgCMg4yTg54rxrxn8f/Gfiq7C2F1/wj+nBRmC0nET/AHj8zSffOOhwQO2M5pKppcThY86t5pbV 45V+03UM5Cr5y7NgzgMSTgjnjODVjWJSfLktoZjOHKM20kBQBjOR0JIOO/pzWal7ydzTlSizsfh1 8X73wt4jWTVIP7VljtvJt5L3LSQ4BC7WyBgBumeg27lBzXsXhv8AalttZ05m1bSjptxbNbG4miff GwMqCTCsBtGzeRlieMc9a1cktyFE9f8ACnxP8K+NJTBoGrRTXQAJt5AY5DkEkANjdjBztzjHoQSv jD4jaL4HvdGtdeaaP+1ZmijmRVMcOCoLSEkbV+cc845qiG7bnUvKsYBkZUBIAJOOT0FBfFUkIQue 1RtIRVJICMzGmNK2DTEfhrBLGlxLa3FvbRuA8f2iTzflbLfMQpPPIA4xwue+ewPgy3SCXWLK803X 7GJ0df7R16ysJZTkFle088zspzjKsp6nINefU9pfljon13a22Vrd93ppozqila5xerXi3V04Szsb GJGbZBaHKJk5wHZmdh/vM31rpdDUt4Rn8gbGMty0p8wKJVEUYVd3PzBnDBRjdhhnpWqi4xir3t1e +2+ml7/IuEo2nfRtafev0uSeHpNC0DUraXxVqE9/aSRGRU0ty7xvg4Dq2zPzcHDgjr8wxnTtfjP4 4sbzfpfifWY7eJm8iOa+lkUJngFGZl6Y656d+tTF1JTbkvdsrd763/Tr8u+T5UtNzubL9pXx2UWX VjpevQNF89vf6fF5ZJ7/ALtUYcdsn174q/a/Hexn82+8T+AdOvNkaxIum3z2cSqRtBClXyQOAcgc +wxo4oEbNh8bfhlKhkktPFWjXcy7Hhg8m5gi5PIfcjkc5IAxx0OK6e18Y+ANRmtItA8d6at1IQXG oafcWkYbud7JtQ/8CxnPtjGdF9C4zt0N+xtH1O8nh8LX2ka9ceW0j/2VqVvcFsYxwJNwUHI6EfN2 61W1Xw3rUVuz3unyW9k+Rck2rRiJlUENyPwyMjAIzyRXPKDi7luXPoY+ma1Z6TaR2VxE4e4BIkCb XcbmA+Yj+8SM47Y7VS1DRNSs7pVDXF9ZqSqtyZgSMgbOwzkE9B19qtS5JPm6mMvfguVbbktjZ3l5 dQSazfzTk3bys5mc+YXHLZ653cnuSTzXcWPxl8U6H4ptdTu9cur2G3jMZguZHa22BAh3IpGTgA56 lhk81v7a92lsDp2V2dzp/wC1FeMLlbuaweVyZEPltEsS7QNgDc8EE85OSeSMCsuH9ojWrmOa6tfE WcXHmxQy2MZRk+b9znYpI4HzZ3e4zxm8TUX2Sb0VvIB+13qD3rxTadZWEYGF8yJ5WyRwSQ4yM9gO egPersn7VMx0zUIHFjJdTq8dle2kckRgYqArtDLuD4Y5xuwQMcc10RrSTV43TMeeFtD88PGWlrF4 p1NLcpbxq6EBVwOUB7fWq2iXGuaPfpN4b1a+sb0/IslnPJFJ83G0FTnnpinKjCtDlmk12auUqji7 ouW3hV7kiXVtQEIk3FtkXnyg7dykglVwxOD824YbI4APSeH4tL8PnTpzp81/e2czTF5L2SGNnJXa QIdkildikESZzznoB3+ww9NctbXyX+f6JfM5va1p60tPN/5afn8jstX8fweKZIT4q8L2evmFSkH2 7WNVuGhDEZCGS7bbnA6elbtpc/Cp9LeHXvheLa5cMFn0/wAQ3aOMrgELIXUkE59OBnIznzMfVo0K UaWEhad9FfS3W6t+PzO/BUa1WpKpXn7iXbW/rcpaT4f+EAto11HR/GMRA+do9TtJfx+aBfyqzeeB /heZJbvR/EniXQbRNphtr/RorkswAJyY5kUgnPBQehz1qMVWjSt7NOV3a2ib81dpabu7S8yqEJ1U +fSyvfW35X16aX8jltb+HvhjUbj7bovxCtFuZd3nR3ugz2Sr90AKLdZRyN+eBjjrkkZx+EySxSyW fjvwrdPGpZYA9xA0h9AZ4EQH6sBXtrASt+6kpL11/E8v66k/3kWn6X/IbafB/VbyQqdT0JlBJUJ4 p07PQHp53c1u6T8EPEZlO3Sr28ljmXZJp032pQuOu+FmHXPesJ4TERV3B2No4qg3yqSv935nvHw3 8KjxBqF/p/jePUNd1SwvCsUOp3U00kMPkw7vkdiQN5IJx149q9g1PwDZXEUA07Slie3QjAl8gZ4A 3Hy3yQBwCMf046mHlyWlF/cdCrRdT3JK3l6a/icrqXwqe1tze6dNfXFyillgRUOWwMAM8ige5wM8 cDFc/q3wt1aGJrqe4S4JAZoIkeRnAAwuFjPp0z+NcPs3H4TovfQ4NvAkxuby41HSZbKCyeNRLnYz MSUx5RVflLqV3hdp25G4c1X17wZ/ZSW5udJ1mIsqqyq8cYRjnJCsmSPfpzik5VUYSpxtqhf+Ea05 bzbFPOylM7mAY5yDne2R+G3tU1toGnRTrKFMssUhKTEchj3wMZ9uD1z1Fcsq03Zm8MPBs+Xpb3Rr 2Yw2mj31vdOy8x367ccE/L5Yx8uec4HU5xWtY2dnYMZ7CO5hlkUq32i4EpUc5CkKuMjGeM9uATn6 KkuT330/M4anve71f5FockknpU0EL3DbY/xJOAKVWrSoxcwp051ZKJpxyQ2AZLYCSc8M7dB/k9qh 8trx975lZTuLscAY/wA9K8JN80q9Td/gux7MrNRoUtl+L7lz+047Q4iBllHAY8BfoP6+9UpbiSZy 0zFm/wBo9P8ACu7DQUZutNe89PRdvXucWIqXiqMH7q19X39OxFI/yMsb7W7ECpVU7WJVm2rlvl6e /wCfH5etewpxqK0Vex5tnB3fUppbwq/mTqVikYBW8skZIPGR0+6fyNOtLme3uUkszHbrI/lo80W5 iV3HO0jBHy9GHqPSuhVm0l3M3SSd+x0cMkzJEol8sIflJOCPfjv/AI+9bOji/muEhtNRuZHkYIsc DM7MScABVOc8jjvkY6GoxGPxNSTndryWlv8AJf1uZ0MFh6a5bL1fV/qz2fwt8MPF9zHBcahr1x4f hbDoJrpmmYYBBEasPUdWDD04r2/w74eTw7FIh1LVdUlc5aXUbtpmHsBwq/gMnuTgV5lX28oqpVu0 9u2mmnn3/q/oUvYRk6dO11v376/oETKvifURwc2Fr/6MuDVua1tZp1klgikkjIZGZASpByCPQg1z I6XuzndJ0DSriwUS2Nufs93cxxhYwoVBNIoUY/hA4x0FcBF4ZW4WaV9Ss4kmzIF2K5VSPTI29cVz 4iClEunKSeh8UeGrCZ9RKrHH5dyPLjubhtsSp2B3DplQeBkADAzwc258Uzw3EsFzZeVLExjZN2wq QeQRjrXqKo7JL+v6ucXIm22LP4inSCBlhjV513gnJAUMVOcd8qfwq/pmtajfmJLKElwhZ0j3MWOT yAOgxgYOeQTnnAwklP4kvuRurw1i7fM6ax0vUZnlt7iK1juEChozekNGxHR1WNsEdCpOVOQeQa6z wt4B1O7uRHr0tjNaP0Fvqj2+PXJaCQfhj8e9KUIytb9BRk43vc523tVsNUuLXUFgumt5Xgk2St5Z IJUsrDBIzyDj8O1cKZ71NaW21O8kaFXaDdbM0as23Cv8ygkZIY8Zwe3b3sdgI4WhTrUr2fd/d28/ uPIweMeIrTpVLabW/H9DW0nRtVGu6Lb639ugtNUdVt5Gl5dSwBIzz14PTHPXFdjdaeb/AETSdR03 zbe31Fp2uIVERWOFJQieVlWk5Ab75Zsjknlj4Ua9neLPZnh04rmW/wCRq69Jb+GtHsZEtI5pppZZ LZHZ1wAqAhkPCnMgIK/e2kfLtGeesPEEwttTiv2uIL5p1mt/IRQYJhIgYjccqfLV1HXqOnJPs4PC yr0FUir32Td9n599bXv63uefja6hXcZvs20rbq/Tt1t8klY9d0bVdB1jwhNeeLY4dF1TS1YSTnEb 31qyjG1n/wBZkKq8lm+QZOW577w14n0S1stMs9H8SraLaxK0d2bhTHL5kUsalhI48xELK5XPGxAO RgPMMGnW5cPHmbSvyrZrR+6tujem5zYPFONLmry5Ypu1+qeq1fzX/DHl1j8UvEl3JLJ4t1Fpb5JP KiMSxhfLGMAeXgH5i3PJ5+lej+HPiP4nntlNmYhBll33cownH/PIbpDngZVD9cAmvtKf1LL8phQz BK+vu7t6t6W/O6t3PjasMZj81nXwD0097ZbJdfy1ud7beMYo7+6v5Y3uWaxtYpRAhUecrTGQKJNp wN69s8/WppPG16975VvpG6NkDqzXGHIwOq7cdSRgMenavy52bfLsfpd9NdzGtvEV9BE1vLfWlos0 0smY0Lyxl5C5GPmGfmPUYHvVezvWs4LRY0wPuMZgqdOB0BY8dTgZxx1ocU9yeZo+MYpruDT9MjbT rO6l8svHO1i7OqpK8WCVJG4LGOdv93J71zPijTLafX9SlivYbZ5715BA8bKIUZmOCQOMcDAH8qyo w5XKSb1/TTQ1qNWSsvl+pnG1tpLmWA3sDpGreXL+8VGGSdoBGQfrxnv3rq/C99qmnJL/AGbaho5I miL+SgIIztbJ43KSeuc12qdOEW5q9/6v/X/D4qEpySWhv+EPHL+CLi5iCMqOsUd1v0/7WQy7mRhi 4jUH5z3PTNclP4p1uNre2hupYGEe0kbiWfngg557cY/rWCXVFyWups6XJcWVpHE9o8kvloAowGz0 I56V1tpaXd4Jmu7a82yQeSwaQK7RgZVFILYww78c9Bya+ozCvCeWxozbjdRs1ZvS2ybX3369T57C 0Zwx0qtOzte6d0te7s/u8jUsbDVLWx02yFrqN9aWFyl9FFNeoF88AnP3AR1C7QQvHfkneDa63hpP Dci2yWkIbDTXhEuHOWzsUBsnJO4Ence1eNfLFDlSm/nFf5nqReY+0Um4adLN/qjDv/Bmoajp1nb2 8VjEIJXZVj84n95tL4LZGMrkKAoyzHgsaw7v4fatYadd308tqVto2kcJKzOERckAbRngY/Acjmu/ D5lSoRUIwaivm/0OavhKleTnJq77Ky+7XT7zpLD4UakHA1K7DxICW+yRtMRyvY47Ek8E8DAbPHd+ GPhxp0SM0sp1NYpSOI2Ayp2lDtJ5DAggjjBBxW1XP68FbDe757v/ACOaOT0Kmtf3vLZf5s7uHRNF 01H8q0s4YmjDrulUBgRnKZG7HXnGTzikOpWce2K2lklKY8hYlPJOP4iQc9vu8+9fNynOrJzm22+r 1PbjGNOKjBWS6IuRzXrM7RLDp6ykEtcPud8cEben/joqOaa1d9lzcNqGDkxg+XGCBjIC8Z+lJDLl rqq2kWy2jitWYjcyxjsPTAOPrg/UVm32qQs+2GY3M7t9wIAo44zhefcc1dhHyUTrmpafHp8lvZ/Z 4ycMU3u2XL4LKEPVj069Tk81JJ4O1DUb+W8uTG00s3nEiIja+7ORhvX1zWELU+tzeT5hbb4SGVgo Eyn1jbnP0IIrdtPh2kEIRdVuoFgyWQTR4J75Ug5NDk59BL3epu2fgfTk2zR2rXFxwXJjy/Pc54/K tyPwl5cCNBp48gLz52I1UD056fXFHLLqxOSNKDwcgljO20iQjcNqtLtOPYgZ568de9XovDi2cZjn l/dscqVKxsT34C9M5707EtsvJY24eLZbAsi/K07M4Oep5IH6VoWvlxDIEMGeW2x4I9M7cfln8qom 7LXmWcA3Xk8Qcg5LbRnHoSMj8+M15z48+KvhvRDLofkzajJeQmKdg+1YYpFIOScksByBjoetNJtj 0NpPiOmqWqS6bbiKOTBTzCXcHPucYPpg/WvI/i9qWr3uq6dNqk8tlpbQKiOihAZUZzhtozwrnbkH G5sdWNUlZhe52Hwt1m71zw9BcazDNPMJTFG7uUEsagDdnq3zFh+Br06LWPs+IYLMgHq0Sg59Op5H uSO9D3DQna8ieNWMr25Y5YF2GTjn2649ahbUptj+TdAhsg9g359fxoQiCaSe6DOwzGD8xCDp+FON /HHHsgRAGADN1Jwc8HgjpVMk4i20O4i87zI7SFRkJ5hIIHbnIBP4fhWhHo6eXBHPeF2LZYRIAR7b gP61jGKsVdsvf2RZIWmlgnun4XM0o/mM1cighBWOG0iULyCFLMn/AAKrGXhbTuVEj+Wzk7SZAmSB 6D6GmizVWbbI3P3vLyc/j0qAJP3NrHiTdKmQuZZCeM5xz159faon1+ytR5UO3bnBCKBz39P507CM 1vEmOIIgzb84diwP+FY19rtxIxhhZl2/K+0le3TA+tNIDNNvdzKZNpSPGC7McV574l05bHWn1PRW s9YklC2t1G8wUJIcKpcFgCpAGQeBtyeOatbiN74ZaNcafpd3FqUqidpvLKRzJMiqoHRlJGfmPQ9h 6GuovfCdrq0kpmea5DhRIq3EiK6g5AI3cgHkA/hSe9wNqwgm2Rok09yDjHmSM7H/AHiTuOP09sVu hRbx/wCks7NggjZjH19+tIYx5kcwgqsq4OFLAAH6f56VK1t5Ss7AkRpk8AqpPrz688VSApT3vnEL GGXAwcknPUH/AD/Ootx+UY+72HApsggihihb995UakYLIN2Pzx/OrSm2iXcZjkNn5QNpGf0PFZoa JUu7frHGrsjZG45I5yM4zkf55qCfW4Vbd526Tbx5eeR6eh/GnuUU5vExCjyYt7jG1nPC8+nPb35q hceIb2cYMhjQdAgxt+h60WAom5mmbqzs3HqTVpdKvJQzykW8YGWZyBtx/nvQ9NxWNCPQZAB5OJmI BUS5Q4IznbjqOeCRzVs2iRNmNUhbPDD5iWHHbp0/A9am4xksOxWeSNVyQd0nOR24NUzp8d/gSxRG McDzVBVeBjjHtx1poRMmnR2xCwoZgnyqkYwq8e3b2rQhs3lRfOHlHBZI1HX8fT/P0bGW94QERbUP Tjpkn39gKfHbeZOPMBCBCS6g9B7/AOe9AFgmKzhQqyJIPmGBy3sM+3PT0rMe4km2q8rGFT8hcD+g GevWqQMrkK0j7MKh+6Mf/XpVyV6ITk52tnH8qZDMBtYSznZWheWF2/dSuQpGf4WHP4H2556ynU5m VRGFjYZyVGc/nmoXmNMrGeSQ5lk3bRxuOSPWq5WSQhYsyOeBlc8/QVYy9Bo93cqBgxZ9Qf8AA1oR 6JZRJuuLhZiclVVvvDPoOnT1qW+wy9EkdujrZQ7CG4Lj0HPTB/MmmrO92D9ohkg8ptoAbEZxjkno eWOAfTOBgGpsBZW+FuimaUSRuMoYPm3/AFb8aiS+uJ5DLBAIguQSenA9TznjP507CHGWNcq6mWV1 HzOflC4zkA9uP5VN9m+1IzNgjI+UYGMD0/z/ADoGOBECgWsYCEdenGeM+/1Paq0ks77wBk4IYqOT 7Z7/AP6qBFqKEeYzz7nfGSFyNxzycfQ0l/chWKKzqehHQk57nHpxTGUDK8n7yXpkDr0+lI8gOxVG AO+e1UIBk45OcYyaR5fnAHIHWkSc6qrIpVxuDcYxSpp9xC6rP8lu7BY5CCSGJxtIA49j/kzew0b0 Wh2ccbG6lbzVIypXZ2PTPX19uamt4o4Y9lrDlsD5iBn+XP1xRe5RHNcl1cNMsaEYMaDOe+AO39OK gjuCk5aElE3c72AI6U7CuQrK0pJkmZmIDEkc1cj+1HDqTbxtlFc4G7+fHSlsIlmlgu1RVBnIG0GR F+Q89Pzz+P402ySaQ+VOyjY5xtAUBC3HU8nGM9s0wuWxAqPHuK4dcv8ANxjgnoc5HpUguWSOSKEk EYXKnjuccDpnH+eaQCRq9zL+8VnQD5V6sBuPT9eevWppwkCCQuCW2/KvDZ6kjB57/Q56cUxlaS8Z J8pEvmLndk8544xnOfr9OMVUkl+1yvIdgLseQTgH0GapILjCpAypyD1JNAHzYI44/GhiHsfLjHY7 vlHb3qKNTIyqDlnPFIQyCS3hCbIy7E4O1cDr1+v49qnkmlmiCcxxEEsATyOO3esrDMvfJZSiIhpB IQI3diSpPQH/ABPPQfW/KDGsYnlWQNncoxtwD2x3/WrW4yuCm5UEbKSfuk9/b3pwtkkuHhnuYbV3 3DYGUup4PC9cjP8ALPFUSWFa2sFAtl81eFLyjczcdT0HX0GKY1zNN8rSljnGwAevHsfxpBcvRW8R DuEcpu+RN3G3nBOPw5FRxyAvK8e5DIAQuS3Q8c56nJ/AgdhSC4SzmWRt5O535J64/wDr1LbL5zKB tbCkrngZAPU+vf8AnVAaTXCG3jLxht5EeI8sA+Bz6EnJ49qz7/U2e5cxKEcEgEY5HQ/yoSEZw3bT 1BBIJ71KrLgD5NpI5Izj/wDVTGhoUbsAnLHnnofoaufZpFJMYWQY4UHkfialu2g7FKVyJNsi7MHb 8w29uxPX/wCtWho1tumMwbZgYBGcjnr0PIH+c0dBH//Z/+IASE1QRgBNTQAqAAAACAADsAAABwAA AAQwMTAwsAEABAAAAAEAAAABsAIABwAAABAAAAAyAAAAACADAAAAAoFmAAAAAAAAAAD/2wCEAAEB AQEBAQEBAQEBAQEBAgMCAgEBAgMCAgIDBAMEBAQDBAQEBQYFBAQGBAQEBQcFBgYGBwcHBAUHCAcG CAYHBwYBAQEBAgECAwICAwYEBAQGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYG BgYGBgYGBgYGBgYGBv/AABEIAeACgAMBIQACEQEDEQH/xAGiAAABBQEBAQEBAQAAAAAAAAAAAQID BAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHw JDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6 g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk 5ebn6Onq8fLz9PX29/j5+gEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEQACAQIEBAMEBwUE BAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkq NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqi o6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAM AwEAAhEDEQA/AP7+KKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooA KKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAOmaizj JxzQYy0ZLRQbBRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQA UUAFFABRQAUUAFJnrgE0EylbQTPUZ+YU4d6CFJhRQahRQAUUAFFABRQAUUAFFABRQAUUAFFABRQA UUAFFACEE9DSbcZ5NBlKLHUUGoUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQA UUAFFABRQAUUAFFABRQAUUAFFABRQRFXd2GO2KKClGwUUDCigAooAKKACigAooAKKACigAooAKKA CigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAoo AKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACi gAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAK KACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKACigA ooAKKACigAooAKKACigAooAKKACigL2CigNwooAKKBcyQmR60uaBc6EBzmloCMuYKKCgooAKKACi gAooAKKACigAooAKKACigAooAKKACigAooAKKACigAooAKKA2CigLhRQAUUAFFABRQAUUAFFABRQ AUUAFFABRQAUUAFFABRQAUmcUEylYbvGehx70m/2qlG5m5jSxPfFMLdMk8+taKFjF1Gxd3oaXzMH 73T1o9ncfOw35/ioD54DUuRBzvsKWJzzSfnQoC5w/Oj1pONilK49P5VJWZvTCigsKKACigAooAKK ACigAooAKKACigAooAKKACigAooAKKACigTQfn+FJnpQZPQaDnjdzT6CoCHjvTSwBPOaZMpXGlz2 puTzV+zMnNInorM6wooAKKACigAooAKKACigAooAKKACigAooAKKACigBCQOOeKjLZyO1VGNzCUh n503cORmtkjG/MyEv2yajZiSTk1tGPKJxsN3Nn8elMLYyKuMRXF3Y4z3qRXxxk0nHuNOxYVumTTs 84J/KsGrD5R350tRJ2HFdCZVA75paxOqKsgooKCigAooAKKACigAooAKKACigAooAKKACigAooAK KACigAooAMUmPz+tBjLcTpjA600tggelArjSevWm9O9axjYynLohMjsabvrTYx3LdFcx6QUUAFFA BRQAUUAFFABRQAUUAFFABRQAUUAFFABR68UANK5zz+NRYxnrVRfKc8oiY+tNK/U1sn2Mvh2GFeuO 1RFRzgfQ1rCV9CyIj0NRlR27VrHRmTVhh4J9qkDD6fWqlHQRYQ8Ack1Mq5zwa5pqxqiQDrgflUgT n2rnlK5UYskAxxRUHRFWCigYUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAUUAITik3UGbm JvHHBppbr/hVcrM+YQnPNNq4xtuRKQVG3U8VZkMNHoO1XEC/RXIegFFABRQAUUAFFABRQAUUAFFA BRQAUUAFFABRQAUUBsNLAcZqMnOapRuYylcbTScVtFdDO19SIvx159BULNxwa2jHlBuxBuweaVie uc1tblZkMP40L26n2rTyCxajHPGc1eVc9jXDVdjSOtibAGcCiuU6kuUKKBhRQAUUAFFABRQAUUAF FABRQAUUAFFABRQAUUAFFABRQAUm4etBMpWIix55ptWo3MHKwUevtWtiWH40hOAfagTG7vTPHemH vQRsNxjjn8KYTjPJyK2iFjT9OaPWuE7VKwUUFBRQAUUAFFABRQAUUAFFABRQAUUAFFABRQAHjOai Z/wFOKuZzl0Ii4HY1A0mO5/CuqEDPYYZPamNIxwPetVFIiUug3Oc8Ug3dxiqtbczuNboMCk9BjNU ABff2r5r+O/7X/7On7NdrPL8Xvij4b8N6hGu4eHlmFxqjZTco+zx5kG4YwSAORyBzVxi6r5YhseB /s6/8FR/2VP2g/EemeCdN8Xp4P8AGmsS3K2mj+KWWCG6WJl2GOcnyy0iNlUJDbkkXGQpf9KBJEsR l8xPKUbjKSNoHrn0rkxdN05WOilrZj1dHG5GV1yRlTkZBwR+dOrktY3CikK9hNw4OaWgXMgooKCi gAooAKKACigAooAKKACigAooAKKACigAooE3YYW4qOqitTGUriUVsQlYbtPFJjpQDQu36n2pCDQG +gP261GT7nPvTSuQ1Z2Gk4wMc00+p7+tbJDsfyFxf8FC/wDgrJ4Q0a50h/HngbxTKkDQwa3rXhq1 N2jEYEpMYUOw6/MCCTzmvoP4Q/8ABdH4/wDw/wDBnh7w1+0h+zA3xM8a6Whi1D4kfDrVV0WLUAGO 2X7BJBKscmzaGCzBWYEgICFHzeHxM6Kmp+821bpZJO/3tr0t5ns8tCvsuW3z/M+nvh//AMF+/wBn DxH8WbbwR8QPhN8Xfg98PLrTmuB8YfFUMN7Zw3i8m0ltbQyzqhUNiZQ/zbQUUEsPuBf+CrH/AATu /wCEVvvGk/7WPwt0/QNMx50msTXFjdLnpi2mjWd/+AxmuqOMhaPM7N9O2rX46P5hLAzV+X3vQ+4f B3jLwp8QfC+heNfA/iHSfFXhPxPaxX2n+IdDnW4tbuCVA8cqOpwVKkGul69DXZJcrae6ONprcKKQ gooAKKACigAooAKKACigAooAKKAehEzZyKifgdfataZzvVkPpjtTdvX6117AMK47HjuaZjFMzcQ6 dqb65FBD0Oe8R+KNB8J6PqWveI9Vs9I0fSIGuLi+vXCIiKCSfc4BwBknoByK/IXxF/wWJ8DaP4pv NJ074UXup+H4Jdserza7FDeyR7m/ei2WFwTs2HaJTgvgnjJ4cdmMcDZNXb6HbhMI8U3rY+cfi/8A 8FwPFFlZRWvwu+CFppFw8p8zxH41vGv0EQ3D93bwBDvztYFpMYBG3ncPx/8Aj38XviB+2B4qg8Yf tBTX3iC1si40+00+6e0trCMoo2w22fLUuI1ZmwCdvOcVyyzdxpKpBpP79bnVTwMIycZXa+4+Q/Hk nw38IQ2Fx4V07UbLUbKVf9Ke6Zppk3kh42BAXB7969U1f9rb49fGCLT9L1P9oHx/oVjo+nwaPZ6V bajLBYpaRxGIQyJAURiFUhmbLNuYtnNdeGr4iVP2k2pPX+vkcdXkjU5Kei/XU+0v2Hf+Ci3x3/ZQ 8TG18Z6pJ8Q/gpGoS/8AD8DfbZIw83mNdQnIkjlVWkbnKEthl5DL/Uz+y1+3N+z3+2B/b9t8HPE1 7f6z4Vt7a41HQ9XtZLSeFZkzlN/Eqo+Y2ZMgNjkhlJ0qSjXvKPTddS1dL3v+HPqbxFrUXhvRNS12 4tL29t9LjMslvp6hpigPzEAkDgZJ5HANfm/d/wDBQPxbonxD8ceFPEH7P2vNoujX8djoeraHqCTS 68su5o7xQ6KkVqYo5ZGlZtqBcbmwxVU6akm30Mj6Ysf2vvgLP8ZYP2f73xrp2nfFY2UdzLoc0ita xTMsbfYxcfce4xIGCDqASOmK+oqylHl0LjFPUKKksKKACigEFFABRQAUUAFFABRQAUdKA2DI9aKB J3CigYU1uMe3rQRN9CLpnmk6Zq4xuZDd2Bz19BTdwGf6Vuo3Cw3f83XP0p+5RzQ1YVrib/anbuhz x9KOVitYYxz0BqB3K9DVwJkyPzcDrTDL0GRVivofztXHhHTLn5Wto2z/AA4A/lz/APrrkdT+E2g6 gN82nwO3OTsGfp/KvmdJbHXCbieYa7+zV4S1Xcs2k20mc43JnqK8O8Q/sR+BtSVwmiWqbs/NHGB+ VHJHdo6KVeUXa+h4wv7EeteC9VOu/DfxX4s8C6wu3ZqfhK/nsLmMqcjbJEysMHBGDwfTt1fwvH7f n7M+teLvEHwa/ac+Kv27xtOlxq//AAsS9PjCK+kQBVlZdXFyEk2qqb0CNtAXJAwLpwdOTmnq1/wf vPQji+fSauj3u6/4Kkf8FUvC/jbwDd6pp/w18WeEtCna41bRbHw2lomuQoAj2k1wJme2kfzN6PBG AGiO4Ffkf7Jvf+C+NzpGjPNqf7F/xCfXI4iTbWHiK2NqZB0G9oA2z1baSP7prplXdOC0u9fu6DWH oVmkpcv437n198Nv+C1P7CvjHwjoet+NfH+tfCLxRe28b3/gbxlo+oTXGnXBA8yHzbeF45lVicSK cMoDELyB9k/s+/tn/sw/tS2viC5+Bfxg8NeNpPC941jfaYRNp1/BIBkP9nukjmaFh9yZUKNhtrEq cdEakajag72/zsclTA1KceZ7H0pBqFhdSyQWt7aXE0IDPDBIrsoPAJAOQOD+VW6o5GrbhRQIKKAC igAooAKKAD160nXt0oJk+g0pnvTSh54q4y5TPlY0pjqDTGX0GD71anckhZW54P5VheIdc0vwtoWs eJdduWs9H0G2kvLq7CNIY4o0LO21QWbCgnABJ7ZrqTvsKWzPz48R/wDBV/8AYW0DS01CL43aZrst xaJeQ6f4fsrq5uJFYj90w8sLDNg8xyshXndtxX5dftC/8F073VfB/iDw98C/hpe+GNcvowln488U alC9xEXc4eG3jVl3bRwXYjrlTjlOahJReo4073cnY/B7xn+2p+0R8TvLHxU+KPjfXV0+WR7fTvEO oSzwKXIOVUMQhDYPy4+uMg+Tat418VanPb62lxLdTadE0cSo+WRmB4AA57c+wHauLFYaHtU299E/ UuliJQvFaPf5npPgPXPEPinTrS91exXf5TKs0SLlmDY+dF+ZuQPmYjg8Z6V6vptpcQRyjVtWl1Ro /mCsqxrECMbAv3VGA3OWJ45xXhYqEKV6S1t1+dj0sO5SinL5/MvC80m5067aZrQ6YqfvZdTXKEBS SGOB8nHrg1896v4f8L6xb3V9p7TpZ2kgkibRoQYXO5lD/Kcc8dOvzGnl86lCTd9n8tWaYylGpy27 fgcJoPiTVPDV3dDRdaaOXcSLZhjcMZAOemB2PFe8/Ab4s+I/hP46T4n/AAy8aXvwx8f6Yoea10a4 eCw1QpMJjaXGx1/0aQJGrx8ISASDgEetWc6DlUhu913SPLornfLKXf8Ar8z9VvAf/BYT41QeLprv V9N0WzTxFdSy6n4e1DU7mfQgJ0g86aDMjy26kQlljjcCN5XdcbnU+oftFfEH4z+IPA/gr4i+A7jx Npd14j0y+S4uPDWuRa5a313JHGl1PB5ZZoYZhMARiNVIlBC7mR+unjI1LxW/+RjKDkn5f1+ht/sm fs1/EvW5fEMninwtpWheGrS2t9IfxZFbvrmpbtsM1yYhHG0t1kXBOzaY95++VRlP9KPw08O6l4T8 C+GvDmq6xd69c6PbiBNSv4I7ecwgnyUdI/lDpFsRiuASpOBnFOrorHRGHIjuaK5xhRQAUUAFFABR QAUUAFFABRkDqaBN2I2Y9j+VMyfU1cY3MWxM4xwRSq545496vkQth6vnOTxTtw55rJq2hanYaX6Y FMLYycmqjC4m7kTSY6dvWomkPJB710xp2JbsReYcdqZ5vXNbRjcnmDzeQBwKd5vv3ocbCUrIb5i9 z/8AXpfO6/N0pNWGpEZnxnnIqAz8kf8A1qRN76ELS9gOnoahM/JORTsRsf4/3gj/AIKs/txeD20m 30747+IbvTNIYGDTtSEbwkDs/lIGYYHILH8a+1fAn/BwN+1/oWp21z418P8AgLxvpsC7f7NtLdNL EwHdnO9ienIx+NeDUyb7VKbXl0PTjXhP44n238Nv+DjbQ5BMvxW+AGtwyzHMUngi4huEjGOATI6k 8jrivtr4ff8ABdn9hnxlFZweJL7xf4G1mZsPY6vpdw0EXbLTKvljr/e7GsPq2IoNcy5vT/I1dKEr ckr7b6H2h4D/AOCgn7DPxMbHhn9ob4bSSqMvBqd8lm0Xs3mYx6V9M6D4j+Fni/TU1Xw5418I67pj DIv7G+hkiYEddwbBHT1op11LRrlfnoKVCa8/Q6SfwJo+oRLPFDb3EMuGSaMBlcEdQR9R0NcjqXwX 8PX24TaZbytn+JB+fTrXVF3VybtO1zyTX/2VPA+rtLJLoNs7yHO5o88/5/lXz94p/YD8B6rI01vp q2shzhrcbG6EY4+tZTpaI6Y4mVJ3Wn4HG+C/2PviX8EPGU3xB+AvxT8c/Crxtc2bafN4i8G30tpN dWrMrm3l2nEsO9Efy3BUMiNgFQR7TB8aP+CoPgDxT4N8V2P7SnibxvbeDbyS5k8JeL7eCfTNajdN jW94qIryR4zt2srKx3BgQCJhUnRslqux0xxEa/8AEV/6/qx7XqH/AAV5/wCChHhuCzm1b9n74Ia6 bfUoJrlNJGpWizaeOZrdN00my4cfdnO5U7xPX05rP/Bev4PaJp15dXf7Mf7RqXtmgb+zpYdMBmbe FKoy3BHCktltvC46kCt4YuK0mrMmWCp1PglbXr+lkfUumf8ABZT/AIJz6hpK6pcftAJorpbC5n0r W/Dutw3dv8oLRsotSHkXOCEL8g4JHNfaPw6/aW/Z8+LfhrSPF3w4+M/w18WaDrllHqEFzpmsW3mi CRN6tJEzCSFgM7kkVWUqysFKkDpg1U1jqcNTCzpK7Wh7LYX9jqtjZ6npl7a6jpuoxJPb6hYSLNBP G6hkkR1JVlZSCGBIIIIq1VbGDVtGFFIQUUAFGMcYoE49QrOTWNJk1OfRY9U099ZtYVuJNJSZDcxx MxVZGjzuCFgQGIwSCKdrhtoy60saZDOoYdiee/8Aga5jxT438I+C9Mv9Y8V+ItF8Pabp8YklvtZu Y7eJQchQSxHJIwP0o21YcvNoj4P+Ln/BTn9mH4cWBbw94lvPiXrUrlItI8IxFUBQ/MXlm2KFPTK7 z1+Wv57/ANtL/gqT8evjhomieF9C1n/hSOgXstzKmo+DY7yC7vYJTJEIJJWYblELGNtrKJCWO0A7 Rh/aUaUlGK5r+Zc8HKK9/T+uvkfh9FpmsXOoz6RouoQ39zcyl5b3VJREnUfM2SSvUnjJODxXU6P4 T8Sakt94M1C5sdOu7eQeZdWLRyRBW+65OQ55G77pOO3NOtmUF79mmtbdLaK2nY56eGcveeqb5TIv Pg5rkhuDcyXOpWNgm3zrGQvcSKAeFCEgZ74Y4Ge4481s9T16TVV0rwloGu6rc2DD/iX20bSyEKTk nAyAB3P611UsZHNb3aio/hc2rYCWHcbe9fY+yfANl8RZ7GNvEGjyaSxyqR6kwhCRH5TgjJB78j6V 6fZeHYTdznUbi7vNPnWNItLt1Fx5jmQb5HLDAXaQu0cDIGQa+NxteFOVqXvLXXt/TPocHgJSV59i 5d2miW2l6haPBIdPtx93T0ErFAQSpUAj74b5c9BzxzVOO20LXltRp4kJwFDNamNX287drYOc4yOT zivMq1qnLzX0vftv/wAE7/q8Z6b6afeeSeL/AAj8PtInOrX9veQPd3saXE1nNg25cnAYAn5SR83O O2MV4V4ps9P0y8tY9NOpXWlXx/camkTMcE4JJXjj69ua+pyzFzxCTqWslp622PCzDDUqClCC9fRm dB4a1nxTfNe+GtfW01XkGwu5PkljUYHBOQ4wAVz7/X3jwt8W/jL8MrK20nRPEWr2+k3Em26060vH 8hnyVJeMcK2AcOBwMjNeoqlKpJK3LNX176HjrDSgpT6P/gH7ufsp/wDBQu4htby50bxg+heKQmla TafCvXUA0O/kWyhsftzXwV5IVSOJW8hii5iiUSSdv1g+KP8AwUP8DfAH4aeHtZ8Xa7oXjP4geMbF tU03wbYS/ZHhswCPMndgW3hgzEbULrG+yMFcHanVWIVnutzWb5Y872e3mUv2Qf8Agq3+z/8AtUaz aeBroyfDP4mX1y1tbeGdduUlt75sFkWGbC5kYK2EK9QAGYsAf07sb+x1S0g1DTL201GwuhuivbGR ZoZBnGVZSQRkdjScbakQmpq6LdfJ3w4+Pd/4n/aH+LHwY1IW5Xwjq2qW9mY1CusNlovhC8wf7xL+ InOf90dq0pQ57+SOilT9pfyTf3H1jRWJkFFABRQAUmQO9Am+UbvHHWkL9cfrTUbmbmNMmM89Kbu6 8mtPZkiZ7Um8ZI9KtKwg3jnk03eo9eapRbAPNAz60wy+4pqn3GRmUjvgComlznJPHpWkYWFsRmTO RzUZk9/yrTlsZ76kRkPPJ696bvJ71o7E7Cb8Z+ammTGTk9aGL0GmQZ6/dprSkcfrWckWRNPj+Lp3 9ahabGc9Pak0QV2n96hM+O5z/KmlzCP8J7UFk027C288yDqCrYPT2q9b+JNTt9g8+STb0LsW/nXm wqPRo9adNVI3Zu/8J1fKgWaGF3AwPkA7e2K6PwV/wl3jTxHHp3h/T9S1K6WPzG0vSo3mYquATgZP Uj86VTFexXPJ2S1bCnhlLp6H0ZqPw98X+Hra2uvE/hvxD4cF6gkt11y2ms1mQ/xq06KGXHcE/U1m 3/xC8cfDNLKPTvEHifS7ueRRZafoV88RZsj5l8qQhSM+mc4/DClmWHx9oxtL8djSnTrYdcqbX5H0 B4G/4KP/ALcXgLxxoFroXx9+JdvNp8Izp3iu5F8IRtLEbboEZAwMn0IzX6IfD/8A4Lk/t1+F7e5X UfEfhLxm95+8F94z0V7iSIc/KggljRehx8hPrmnHBUpNtScbvTt1Criujgnp6dz7P8Mf8HF/ifQr LSl+KHwM8M3Fpb7f7R8SaNq0sdxN6+TaPCqh+vymY9ua+vvhr/wcLfsb+Pftk+v+BPi74E0yzTd/ a+sWEd0kxwTsVLZ5W/E8UqmFqxdk1Jb6Dj7Oqua7Vu59Z/Dz/gr/AP8ABO/4laTp+pab8btN0h72 VYjp3iW1lsLiBif+WiyAYHvzX2l4S+OP7OfxGnvLTwX8W/h14kks4hPKNK1KGVFRuc7s7ex6E471 zc/dW9UXLDTir2O/Xwp4Q8Q2cd9ps2l6tZXZJiu7KSOeKTt8rKSD+BNcvqvwN8J6h5gn0e0fzOf9 WOKnlUzOMrHkWt/sffDTVvNEvhrT9zjr5YH49Pevn3Xv+Cb/AMM7nUbnVNNsrrT7y6tzaMLWRo4z E28Ou0HHzLIyt/eU4ORXPKjbZnTTxEqS0Zf0j4F/tRfCjw/pfhP4RftP/HDwX4R8N2zWeneEtJ1+ 7XTLGEhgI4YNxjjRdxKqqjaSCuCAR6T4R/al/wCCpXwe8HaR4LsPif4X+Jdj4YtPsVtrnxJ0ZNQ1 iZFQrG090rK9xIvy5kk3O+zLsxJY6xxNWjp8S8y5yhXXvLXv10Og8A/8FYP28/h5qTXvxc+CulfF tI9LFrNpmh6hb6BYvdxqAt7Gi2Ms0bSbcyI07oC7FEQBUH3B4T/4Lifs+v4Usb74n/B/4/eBPGEG nm41LQdM0e31axS6SPc9tb3AnQzbmBVGeOIHI3bOcdccZDaehnLAqd3B/LyPdvEv/BYH9gnwz4A0 z4hTfGO31OzvYoZrjwzptuRrmmRyBdzXFpKUdTGzqrqu9t3Ch8V7/wDBL9tz4CftBeMNa8JfDTXd U1SHS7C21G38W31m9ppGppP5YEUEsmCbhGlRWiZVb5vl3Ybb0xlGd+V3scdShOk7SR9UNrOkKs7t qunKlt/rGadAI/8Ae54/Gvi/4gf8FGv2P/h/pmtXkvxc0nxdqeiSzW7eGPAqNqN/NLEQGRAMR4JO A7SKjdmODU1akaC5puyFSoyrO0Vc/PD4jf8ABayzbTol+G/wU1CH7V5mbnx7d7JQu8BCIbbJ5H3s yDbnvjJ/FuX9p7402nx0Pxu8DfETxL4I8SNtSbRdJubq5sry3gGI7adrueWa4hUZOyaR1+UYACgV 5n9vODcaULp9z04ZQmuacrf1/keieMf+ChX7SOpvNqHiL40+NtRFm73nmeHJ4tJZSQVAdLZVyAow Bz1HXmvz+1T9sfxl4lv77/hIdc1bxNHPdNKb/V72Wa6YNzySxBOefwA/hFc1KnVzW8qjas1p0T1N amIp5ZyqCWv5epwEHxehvNWGnRzanZQ3Vwd9zfgy26I27eCR91Rx8xz0bJAryX4jprV74kY/bNd1 hI0x9m02MmOIBcLJzgbQONvJ9xXpYbA+wmnJJ6X7f09TzcdP61Sbu/6/zPNr7R/Ffh+6F5JJejBE e2CIhwp5wzMQMdfceh6V6p4M8MfEW4vbPxtCInSAcaNqMhjuZo8Hli5G4DdkYJxgccV04irQcFUa 0krd97a/gc1HBVVNNPzPV7/4w3Hh66msnhj+1OQm6NUk2EcgbOhOeD7MeK7bw1421LxDoWtap4Y0 Sy0O9tzEsd7fqpN2xYeYecYAC52/N/h83i8vjQTnKVk7K3fZHv4XHSrvlSu9f1PnHx58UfiDDeXH h9ddn1H7NKxkms3jIdlO4LgkHZzgAdcY6jl3wq8a/FKXxM8/23UAHQxtcXp2qMHdkgkgEYzgjHI9 s+nTy6g6cuXblu/Tt+h5Dx1epWsne2jPqvULZvCsOkweJbnVrubVQVbUdMeNfs53AySOyhQOOfop 44ydfSbk6VNqeo3Fy9lZWyshvZpStmCQXHUfe2jOA3U8YBFfNYlqvSvFJJ39dHY+koVPZVFGTat1 6bbnwv8AFHWvFOp3lxeWF/aala75B59iXZ9oYbW5A5xgDOcDvzXIeE/H/inSVt5onWJ7NAVtZhjd 8u45BPAySTxztPrX32DwVKrh4Jq2h8bKvOFVyT6/f2PRLbxZo2vsdQm0i40vVoT5balpUhtISS4A LrtwTzng8/z5m48QXVnq83ma156sx8y3DDJwSOTna3BbgdzXOqCw0+V6/nb+v61O6riOaN2v66/g ex/C34iaTY3OqRRPp2n3arGtvdazKRBcYJBjO3JwwPU5AxzgHNfQ0nxG1vwb4K1vRfEvh3wx4i8N +I7SUWtlqUsx+zvLtZZ7eSNgAy7QBwQRkYyxJ83ndDEttvWy8n/wVc3oQWJw/JZWV/vv/wAA+YvD Wp2OmiXUlh1Wy8SJO5h1G0uwojgAKGIIgBUn+9u+bdjbzk/qJ+yj/wAFFtT+HXhr/hU+veOfjv4c srEq+j654O8TTu9iqSmR42tL+U2W1mBGFVATI24HdkelVqzi/dtZHlUansZqLSttr30P3j/Zq/4K gfBdbm/0H4pfEr4s6kmqOJbTxJ8QtK0wx2WEOYidLAchjtC5jfDZywBzXy14S/bt8Iaf+3b4p8a+ BfB2veI9G8fav4jOnap4icaFaajFdeG/BVvGiO6SS7/P8PTfL5XIaLbkllRYbMKbjKTkr2eiPYVC VKTbjZSVvS+h+8Hh/wCO/gLUfhLo/wAZfFGoJ8NfCOqQCV5viBJHp5tiXKBXLNjLMvyjOWyvAY7R N8Hfj98Ifj9o2o6/8IvGlh4z0rSJ/s1zcWUc0LQSEEhWWVVYZAyDjBBBGQa3jHnjzLY82pB020+j sevhwc0bxx1pcrMucb5nXiq93fWtha3N9fXEFnZWaNLLd3TiOKJFGWdmPCgAEknpT5WLnbPyZ+IH /Ba39iT4f+PrvwHdax8QfEX9n3f2O48W+FtKiuNJjZXKO4Z50leNSCSyRtkD5d9fbP7PH7XP7P37 VGm61qfwR+IFj4sTw9cfZ7uxkhlsryLK7kk8mZVcxsvKvjBwRwVIG7wzUeYi/Nsz6SPpTW445qIx sIbjdk4am5xgYzirQDC3Xg1EXPY1pFWAYWIz/jTN/UAE1dgE3ntnNN3HvmgBhz0qM7+TzxTCww5G TzULSEdsgVe+hLIzKeeCce9RtLjPrVLqQxnnHjBP1qNrjGeTxTcbk7DPPPPHNN849OlTKIDGl9R+ FQtJ2z/9apauwImY85HHtUDM3OQTVRJP8L7Xrb7RexCN7dGAAxLIsefxYgfrWQ2lanCqTNY3scE2 dlzJE2xvoeh/CvGhJR+JntJe4me0fAX4DeK/jx4puNE0Bobez0kRvd6hdMFC75AiRJn70rnO1e+0 +lfc/wAI/Cdp8Df21ZfB2geELXXSvh8W48Ofa/7REU0lrEztME4kdWUs0XQE84AOPjM+zZVZ18FB 2tSlJ+un5L8z0sJT9mozfdH3L8XPjH4V+EllqXjPXdbtNa8UQPKfOgk8/ToJuCtsiowjluAvyiNF 8qPLMynBJ+CfAFxoKXHiP9qX9pfVrf8AtnXEZfDng3xlZDVpbu2cFRLHBNhZjs3IhICR8SEAMhr4 nh2hVw1CpWhpOf7umtnr8T+S1fY9nGOEpKD9X92x8RfFP4oWPjj4h33jPwt4bsvAunFFgttG02Rp RGiqVyzNwzkE5wAPb14dvGWrqpj+1udx3FY8IM+vHev2TBUHh6UITlzSikm+7R85iOWpJtaL9CC5 8S6pqt1Bd6ze3Gpi2/1cF25dF9gD24H1rtoPibeiJoJbe02MpTCRBMZGONuMfSute5toYSp+0tZb GLo/jPWfDsE9nps0cH2mQSeYwBPTGMGrv/CS6tq8skmqeJ7qIHkRWzYUH/dUgCq5nVjyvZG8uXDS dRbn1t8Lf2wPjt8M20VvDnx3+MNrF4bYNZ6dL4kvZdPtiCCNlrKxg4x/cNfop8P/APgtJ+3xZNJL ZfGa88TtK6xP/wAJPpllMpYKWCjyFQKWVGyeDxXJjadKhTclozryqhUzfEqk1fm7eWp9kfD3/g4Y /ap0vxLb2XxD+HPwg8UaJZQ+W9rDJPot5NMApJZ23qP4uAB0/P7f8C/8HE/w+uls7b4p/ADxP4a1 B5QJpPC97HfWscRPDDzNkhO3B+7z29a540HUb5ZXsc9egqNm043+Z9keEv8Agtz+wH4pW7bVvGPi PwhKpHlw61pU5MgJAyWC4XH1r648H/trfsUfEy6Nh4U/aB+FupX6wC4NidSiilVD6hiOR6VnKEqe 6tYwVOW6PetLtfhz4rS2m0DXfDeurqUXmwnS7mG4MqY4YBSSV561U1T4OeFNTieO50ezkBGCrRg5 9qnlUr6E80qaR4X4p/Y4+GGuxTJP4ZsNk42nbGM9P59a+ZfFP/BN74d3iFtNtJ7B4po54pLRijxy x58uRcch13Ng9RuOMZrGVNrWLszanWcdGeKav+wZ8XbLU7PUPCvxn8aabBprTFtMluJJorhmCBPM RmMciKnmDa6MQXDKUZctl+JPgV+0npGt6bd28HhfVfDttbm3uNCsYZbZpv3hbzo5XeR45duE4zHg A+WTycq9KWIXv6/odlLERpNculvxPILnQ/ibpviy+u/iB8LvFNro8A22154KeHVr1UCDKuk7WqSE yA4IeMBSAdxGW87s9d8Ox6PrGt+ILbWfh88BmuJvB+t6Tf3WoMPMZAF+yRTQmZl2tsWVlXdy4wa4 JUXS0izvjVhVXvf18jJ1l/DFvpmkW+jXejeIJPFt3FpllYaRqVpPdTXMsRKWiwq7TF9isfLK5GNv BAFfL3xA+BXj7w3qt+BanRtPt4UmOkatbPZ3yxMWJKowBYbwRlc9CfWvWyqusE71NVLt0d1b8zzc fhVjLRjpyv71a7O78I6Tqnh7w/ocF/oGozpq7OY7q1/dsrM3APOct8vpkHAqbxhrmkfD/VG0zVEu 9dmuVLoEkZoYNw3KifIBsBJ9OeOSMmK9eWLm40WnzP7rOzJxf+x0721VtO90SeEvifoOupff2rp0 A0y2z580nKmNRhuGB5LbeQynoe1ZXiX4taRcX0EWgwLJo6MR9plGUcqTg/XHGcdueteXLBV4V1G/ uxdn69PyOGtj3yRfV6f1+J5nong/WPHGoRTaZqCLbYkuDqNy3kyxb2I2DPDZz7d+DjFfWX/COX+i +HNI0AalZG5uyUSzYvtiIG0l/lwWL5BOBk/XnfNK8XOnRtdp3/r+t2erl2GVKnKSfkeK2nwQstF1 i51nWNfs96TIEALvCrMV+UkqfpjGck817Xo2hKxu5fC/hvVPE91GnlTSXSNbwW7kqWYSzqRtHAGw kAZBGRirxeZrEJJe7FK3y7kYLB+zb0vb87nZaD4N1nX9LQeI9QvNHtlJhazkvFvJG2ychd0RVctg dGJAGME1z198P4/El14i0MeEvGy+GDAtwzXVvfSQQtmFFmAyWG4urBSMEOrDgc/Owx8aU3GNrJ/j p/kexVwrqxi56uX4Kx5Lefs5apYT3F34alvzaWLiP+xrwMJJMBjmN5BGW5GMY65XtxyB8FX91rdq Ne0GePWdMJT7PPA6TNjc3+rIO4k9s8AnkgZr63DZ59Zi3eziv6/yPl6mB+r1Y6aN/wBfpY2vGXhe 7bwp4gsre8g0eJGUxzrG6lQSDubA+Uk56nnIHBzj5Bj8F+O72ecWV7Dd2un5+aBWZpsnlVx3JH4V 7OU4mnUpzlUjt/wCMdhXKUVB9Lfmd/4a+GHxKbV7SZ/BOp3tlI6FreRGhnAVic7iCMHnnOe2PX7Y uNNt7Lw9Y6dDZXo02/mKy+EteLZgZULZznhSdhyCDyRnnjyOIMVDnpqlNOPXun3/AEPSyTByhGft Fa/9ffsfOHjfwhJZte/8IjHeQQRzuJdMv2ysK4jKlZMYZG3nGeRjvxXlmg23iKS4Fo2mS3t9I5E1 pDF57QADLMGGcHAJwK9PDV4TpuU3Z9fQ8evgpwqWit7/ANfmfqB4IsNQ8K+HfBkPjBLfT72S3aX7 RqBeFZI1ZgVztO5xxuPUEkYrzXxT8atL0/W9Zs9N8MyX0dhcmSK5ScFAnqqFT2HAznpgV+fUKf8A aGIl7OVo6+lrn1OKx8cvowpSs5bNfJf8Awbv42eK7OG40jSNd8UaV4d1mHNzoK39wLO6RiGxJCX2 9V5TnBHAGOPd/wBm79rzxn+zx4zsvGHwj1u/8L6u9zHJqvh6IsNJ1ZEIxBcW5Ox1KgjKhXG4kMCa /RKdKfs4Si9lr5o8O0aknOS3P6RvgT/wWb+DXjGxsrD42+EfEnwr8QS7V/tjS4jqui3B7upT9+h/ 2NkmMH5zX6XaD+0x+z34n8Or4q0T4z/De70PYJGum1e3ieEFguJI3YPG25gpV1BBIBGa0pYmFZe6 zlxOAnQe10cvqv7Zn7KGiFV1b9ob4S2LMcAT61bcn0+9XlXxH/aG/Zn/AGlfh948+BPw5+OfhjxP 42+JOiX1jpmkeBdUCahcTfZpHURyAbFHyfMX+Tbu3gruFae1jFpcyM4YSo9VE/hz+J/g630XXtb0 GzeS18UaS01teQ3VxBcBbiK4kUqsscjIw2BcsCRk9W616/8AsjftE/F/9kvxZqHjj4Yav4bn8Raz ALeWXU7UXSJEZI2eMLOoCsVXYXX5gpbBAOSnmtOLlB97L0/pHic3sKyivT8f8j++rwL400Dx74T0 TxXoGu+Hde07VIEf+0vDV4l7YmQqN6xyrjcA2QDgE8cDNdlszzkY9aqcrPQ9SceVtdjwmf8Aaa/Z 6ttfsfCsnxn+HI8Q6jdy2EWjpq1u0/2iIsHiKhvlYFSOcZPAzXlVx+3p+yzbfFfxH8Hr34n6Vp/i XwlZS3+oarqGINHto4whcG7YiPd86jAPJOASSAXFp6XJPpzwx4u8L+ONEs/Efg/XdM8SaFqKh4dV 0iZZ4XBAI5B64I4PPNbvrzWy03Brl0ZE3UjnikX3J49Kq/QBDxmnBl5yMEUXAk2j0GPamMoAP1ov YLETY7mqrICT6+lNMTXQrMgGRjpVcg8AA4q1IiUSFhweDmoGyM4zxWmhBEchupA9xUi8kgk/TFKe wJDmjyQc8U0RrnBJrJOw3GwPtAOOf5VUcgnoetEdAcT/AAt/FC5u4TGC/Tkd6vS6Brljo+n6q9iV ttVbyrZopo3ldj0Hlq28Z7ZXnIrxJ14w5VL7Wnz1PXhFuJ7h4S8MftA/Dywn8T6DpPxj8KDQdrXG v6Nb39vFaeZwu+RBtjyGxyQfmx3rjbHx7478F+OJPEdvrus6H4iFu1vLq1wZIrmSEpseGTdjejKN jKwOQMGvI9lhMZOpKKjJyVm1a7XZ/ejpjKtBK97LX5l2f4x+KfEl94Vu/EtpoXiPQ/BczTW3hrUb UQWd1JnIedYCjS4wMBmIwNuMFg3K/EDx94o+IuvP4g8ceIr3WdUlRYkadQIoIlGFijRcLGijgKoA rrwuU0sLOMor4b28uZ3f36L0QVMTOd4/1oeeuqfMtuWcE+nWmRWtzjcsLD/eODXqXSvcm3LZM9b+ EHwK+KPxz8Z6R4J+HHg7xN4s1nVLhIjD4b0651FoFY4MjrAjEIAGJ47GvqH48fsF+Ofgt4fvdSur zUrPWPD1obvU/DPjG0bSrsICoZoVkAZlXLE7whIAxknbXzlfi3L6WNhgPbwdWSvycy5rXtflvff8 i50KsYc/I1HvbT7z4BaO4TgpJjrkc5/KmDzBgMrYHbFfUp32OT1JVuLlGyryI3+wSor6y/Z6tJdX 8JfGK5d2nvfDFhBqcMcmSAEW4jYnHOMyL09e1fM8X1nQwMpr+aC++cV+p+n+EGEjjM9pU59YVvvV Go1+KP08+DHh3RdT8EWnxK12y0mHT9S0nRWg1fT7VLq4v768EKz+YrMHggtWguWcoA6xxo+WYDf+ dn7UHjo6d8WNe8OW0NvcRaKyE6paXKTRXJlgicyI6AB0bO8PltxYsDgivQwsHGba21PgMXN1IpNH gEHxCudwzc3o6dG3D6c1vxfEZhho5nU56duTz/nNen7TozzXT09D03wl+0V8R/Bup2Gq+EPH/i/w vqelBhbXmg6pc2UsAYYIQxNlcj0r7I+HH/BUv9t/4fx2H/CO/tB/ECcaQ5lgt9buxqW7J5QtcqWK Hj5cgdcYqalKnKzsWq8oaPX+rH3D8OP+Dgr9tjwha2dj4ivvA3jy2jmMrf8ACS6UTc7TndF5sLA4 zyCS2Og44r7P8C/8HKOtytYweOf2d9A1KF5f9Iu/DmstbShMc7VkjIJyfy9awng4v4GPni9GrH13 8P8A/gv7+yzq17J/wl/hT4l+HrW6uW2R3dlb3Plo7IAS8DHiMBhjbltw5yvzfcXgL/gqp/wT0+JM N7Jb/HTw/wCGJba4FuLbxxby6Y9yTzuj3ghkz3yK5FQqQWqLUL/C76H054c+Lf7MvxMilbwf8V/h l4kSKUQMNP1S2Zg7dBgsDz+tdXcfBz4ea9FJLHpuianC5KtLbBJVJ/u5GRkVlUipaNENypO+zPIf Fv7Fnwd8U28sN54P0l1kycLCvWvnnVv+Cdvg7S9Rk1fwPqXiDwdqf2UWH2vw5dy2jNbrJ5gt22MM xB/m2H5ck8c1EsMnqtDaniZR0b/rY8G1r9hD4q6Zpmv6R4b+IkrrqlxNerea3axXt1DPLMZWdHkU kDzCxC/dG44A4x+ePxy/Zk+Lfw+8RWd94l8KQ+MV85RNp3hWK9t59SWZZPKdZ3jeCF0eOZmgRZpW S3LADcNvDGp/Zk3UUd7/AI9Tv5VmclTvZ/5dDzHTvhxqGq3Ou2CeFviB4YttOLyW+g6NaRa28QS2 DvHeuJbYwztKSiKsbr/tkKxHn+pfDrxla3egiKTQ7JNY2r/Yl3b3lrLZuU8wxzyTQpbptwylhIVL cKx4rehXoV1Jub97XzvrucOMyirGUoS8rW30/roe2W9pceF9JvtC8BXEOsX2g4u9a8T6ZGbyz03E au+ZFV41i2EEvuIGTyvIHJf8JZ8Vda1mLw5otrqfifV0bzhc2cAESA4Xe0mfXHBPGPUmsKGGhrWq uzV3d9vI6fatT5Kd2ui+XU+pvB+r2fw50ZD8QdR0ufxZeHMOlxXJmmt+pO8KCoxkknkDOM81s3fi zxvq9kW8EeDJp7W9Amkv5bf7Hbz543FyoDnavGT0AXBr5nF0fb1nUk+WD29P+HPbpVnSgqcVeXX1 OY1nwB8Qbee48SwXus3rTrHdLoazC1tLeRAcoWYsDcDAKqjqoV1GQxKjL8D6Qkt1d6Nr/wDwlyfE jUolntzphhnitgku3a8gQhcKWLSI5YbVOeRnWE6STcVd2/Ld/MzVOpKdnfd/f0ud1rngXyYPDer6 H4zgTVPEUy2eqataNI0hmDszQrliJAWRh8uwMQpbb1XudO0LVtJ0i+Gr6vP4ltLF1YM9nH5caDrg yudpz3ZgBweQCRyVcZGmlFqzv+HY7YYKV7tprc4/X9A+HOkaQuoWtiDo9yDD5sDvfwqdzZ8vYG80 KcE7QVwGORgkeY6J4V8Ja1qtnpPhjX9Rs9ORku51XTxpS3X74B3W4QbCGj3YDITmM4ORgd+Hxldw lJ7dfl+ZNTCUoyUE9bfmfRVpMnh4xR+H7eAadJIfItrAsXUNjCsTgkr8pOMcnjA6ZV5K1pPfy+Jb tLLTNPjmuxNfoGknt1+dpYnjy37tTtZSnXBGFPHzlCpOu5OTv0Xr/wAA9mrSVBRjFbd+xzF9pnhL Xf7UhtrhdUsfE8Iu4/ElxHIbNzsVRscKGyAuCNo6dOtcf4ZtvCvgW9vYNkOoQxXE8v2mdUBVTI5R A4GfuMVIPfsQa63mNbDwqUJ7tflofPY2vSotTas76ea3uaXxJGvfFqx059BvvPufCMR8jTr6UxSK shAZI8DbIzYUqCBkL1J6/Gt1o3ifS9RutI8QaffWepW7EvY3EbxeWpGVZtwBGRj6n1Fe1wnWhBTo P4ld/Lf83+R4eaxeLbxTjo3b8Etf66GZ4YTVfFWv6f4SDWiT6jeQ28Oo3KfZ4Yy0gU72YZUBSeSQ PXjp9US/sq/E3wzdWeqQrZ6loiyhGvrZw6wvwWDKTkjORuGRgZJA5r6XFZ7RyNxo1H8d2n8jPLMA 8ZCU4fZZ9Y6b4Wvo9GsZJta0SGxtrYOL7yw5j+6NjMwyj7s8DPYgsCDXkPiTVbLQUvr6bVmlW2U5 u7QK6tk8HP8ADzgbue3rXwmCzF16rVNPd/iz7nF4aNChzve1/uPlBf2g9dstbGoaPqF8kySxot3J cSMVQELz6H8TnjNenWv7T/jNpLfWrHWtRtdW8POTB/Zk8ibD8xdWG4ZWTOGBDZHXqMffUMq9napO TuvzPyfAY+cXU53dP+vyPn3V9SuGa7eJWSXVA0yrOXVYixyFBI5OCR2ByMkAGtnw/wCLb/whf6LN ZSeVqOlzxSxSKqy7GDBlbnO4bscHjFbThzqy3ZMdZKdr2PWviv8At1/HTWovDenRfELVvDy+F3ea N/Cd3JpW64eMRTXDi3wkknDEybdx81gGAwo+5fh9/wAFGP2qfFX7EHxA8E+I/i3438QalJrmnWOg X1hCJ9Vn0+OK4kv45bzb50UYk+whGZix+dB8ucenzOlQVSbtdf8ADGspTquSiuj/AAPyH8UfEnxT f+K/tEl7f6bqkR3yLCsyiIAAEsSQqEMfmAHXPXPPv3wx+PGi+HtGuNA8a+HrDxno7aklxei2S2sr 8B3hadFvPJa4VmjhCBkceWXLANyrdGEwsYJW17s8yF6Nm7tpH9ff/BNj9rP9lnVv2aP7Q0Gf4YfA iy07U7tr3wbPrEpuIWVVxc3M14FM07wrG7yIzryOVOVX5r+NH/BdXwToXjPX/Cvwj+Hl1r2haRa3 EI8a+Ip4o0luxIFilRI5GAtiocgkl2JX5FwQYxOJVG73a6HoYmr7CKnNaPYxP2Tv+C3eheK/Gdt4 H/aMstL0G0127CRfEjTJY49O07KNiOWJVLeWXCAPuJG85z2/oSgvLa8t4bu0niuLa6QSRXMDB45F YZDKRwQRyCKeFruvHmasZYbELEx5kOaTg5YACqkGo2dzJdx29zDPJp8nkzJG2TE+xX2t6Ha6nHow 9a6lqnY6FFsufaSMDsKi+1o4O1w46fKc0ctw2Kl5qdnYW815fXdvZWluu6S7u3EccYHcs2ABVW31 3Sb1jHY6np95Iqq5S1mSQhWOFJwehIOD3xV2ETS3cEKNJNIkMacs8pwAPfNRmdM7dy7yM7c849aA I2kHJ5ppYDOBkmqJsRnHPHemsyjPJpeQNEfnA9Rx6GvKdM8Z3Fz8bPHHgSSYNa6L4X0PV4bcHlWu r7WIZGxnuLOLt296ErJv+t0hxj7XRef4I9QaTpgfnXH+NPHnhD4eaDc+KPHXiXRfCfhyzdEl1nXZ 1t7eNndUTc7YAyzAe2cn1pxi5PlSMlrof4bGuDUI54/tsiS7Ojx8CvoPwT8atAm174UWnxB0Cf8A 4V98KLd/I0fwfbxpPeXbHcbudnPzSMwTLHdhYkAXg5+TzXBzxcE6T96PM1fa7i4q/kr/AJH0FKrC F01p/wAFH15oP7Xvwr1uf7R8Rdb8VXvh3w8UOnfDaOOYWDcFjvkRhJOyyKu5pHWSUkbpdu4V8fft TfGPQ/jf8TG8V+F9Ov8ATtDsbCDTbeG+ijgZ1hDAERx/JGgDbVUfwqCcEkV8rkOQ4jLsZzNWpxi1 6ydm3/W1j08RiYVaTkt+2+i/r5nznFbXspCoGTPRUzmvqT4a/sRftTfFbQv+Ev8ACfwN+LOp+Cgw DeOE8O6jJpCAtguZ0hYEDDZ27vunjIr3uIuMMr4Tpe2zHFQox0V5yUbt6JK73b2PPw+FrYnSlBy9 Fc+5fgv+w7+xf4fvp3/bB/bauPhTPZRpL/wg3w+8LzXWpaguwGWJJ7qSNYGVyF/ew5O0kKedv0Ze ftMf8EUv2XhOnwC/ZF8c/tYeMdPctZ+Ov2ntXe9sywGF32cK21oyjlubZzk/TZ/J/GWN8SPFbHvA ZNCOWZe0v37cZVakWtbWbUF001bW9j73L8LleT0/a4iXtKn8vZ/13PFfil/wXU/a88SaFeeB/gra fDz9lr4byNuh8F/ArR7TRYIRjGP3EcaHgAfcH3QOnFflD4++NHxN+KWoz6r8Q/H/AIw8a3ty/mPN 4jv5rsbueQHYgHk9APvH1NfsHhD4AZP4URliYc2JxlT+JiKrcqkn1s3dpdkummx87n3FFXN4qlH3 Ka2iv1OCSaAq0hZVUcbmUVMk1ttKrMFB6sCc1+7vXQ+YvazRZVEblbg/7pINff37Gthoek+FvjP4 j1zTp9ZGvaHcaIlrgtEiqqXWQqHLyvLFFEoxgK8hPOK+M4+xTwmWVGkm24pX2u5Kz+W69Ox+v+Bm WvNOJMPFycVGNSTa1fKoSTj/ANvJ2fWz01PL/iJ4duvBfjL4SeBbK78Rv4XkkS/Xw7HI8k6+fqlz GUWL7pnEICA8kk4zziqn7Zngm/8ADvxv8VXsNnaRaBqlw8dpPooj+xJLBiK5s0CEhDbzBojFwUUR 8bSpP0OV4p4yhRrS3nFN27tJnwXE+BhlOY4vC02+WlVnFX35YyaV/lY+TjbyqAuyQd8Yq/pWlavq +o2umaRp11qWo3LbYrGxjaaVz1wFHJ4ya9CpJQTlJ6I+f3dkfol8Ev2AfFXi0WOtfF3xBF8O9C1B /Lt9OtE+2ajdyBgGh2qcRt9SeSASO36DaZpH7IfwK01NA1PRfhBaato7Ksbarc2Wt6ncn5w7S/aU KW4IXlczuCu1QvBb8b4l4oxGbVVh8C3GMXutL28+iWp9NhMDChFSqWu+/Q+TviR8Jrv4i+J7HxF+ zr8N/if45+HWlo39p6d4M8Kahd6XZyiUs8f2ydGiy6OgYq6rHldm4EAfDnjkeMdH128F74FPg6yu 5QlvouqDa8OOg37lLHg5JGO2BX0nBXE2FziLo0sVCpUorlqKM1NqW65rXs7dDy8wwcsO7yg0pbNq 2hnw2nj2KBLldPsXt879sVza/mQJN3fv61p2GveKbp47ddBtjJu5YXiQFuB3lkKr0PYda+8WMgtp Hluk9T0Hw/J49n1fTLBUi8KQ3Uw3eILvU4Ps9ntyTMTEwIxjjnqBX0hqn7U/xq+AWraLceBf2oPH F3bXmLiG48O+IbmRYpExlJY1kdFPPQ5DLwc8gZSxEKtRQ5b362LtKC0d/wAT6T8Af8Fvv23/AAhd WjRfHVvEtvZSiX7D4rs7W6hlXHMRG1TtPtgjsRX3D8Pf+Dkj496E2nwfEX4Y/C3xxCgZGawefSZp 8j5TkGQBwe+CCD93vWn1SMtE7CTW8o6n294B/wCDj/4Gant/4WP8APG2iyGIGSXwjf2uoqr98CXy iQefTHvXYePf+CoH/BOj9peXTj4l8YXXhg6XbyeTo/xI0TUUshOSfLk8yxdnEgSS4ibGFKSsu4Kz Z8vMMFUnBwir3+89HL8RHCV41FLY+xf2Yvi3+xauoappnhT46fBmfwzezhNN0GLXrdlgmuERp3zd OJQpa3RREHlKluwJ2/dg+EfwQ8eQs+mnwZr8Mqlj/Zk1vcZA6n5CeK4cDhlGnyvz3NM2ryrV3U6P ttfrb5/1Y8d8b/8ABPr4G+MIbtb3wVpDpfYMnlwqASDkHp2IB+orxvW/2ALy31O21jw98QPGSXNj aS2Vvb6/cf2zbW8MrxvIscV6JY4yzRJl1UMcYzWv1ZLZ/wCRyU8XKPn+np1Pnm7/AOCf/wAYvCFu 8nhTxvpOuyvfm9li8XaZFKbiPY4+xvJEEkNuHbeAGDqUQK6qCp4H4kfDD9pPTtF120s/h/FbajaT wzWF74ZvS8TIkSh4ZEmRiVaffJlWB2bYuTmUebisqjXkpTV/6fQ78PmSpRaWje39feeQarpfiKz1 z4mjxja/EmTw9qVlG2lW/iTw8Vt4XWOV7hI/sclwfOJjijR3MYd5SzbQCw88sor69F9pl74ws7jx RPYPHYtf30enx2lm+Ay4lZN0ojX5kHzKASBxkeVWwsqMnyRutLfck/vZ6lDERcfelqr/AItv8Bnh eSX4f6RoOl+Hxreu3GtMJbaXVXFv9qgZUY3MckgVltwHzvDEEyADpmrPiLxP4wn8GtrV9p8iaJNe vYR6Lchs3W1VLyebuRUVC6ZIzwRnk1h9T+sT9rUVpN7djoqYr2UVGnrZf5aEbeLNT1jS9I8Kz6Lb afp1jZjN+j/2fDcOQJJRDw5O8gLncd3OTzXS+FrP4fy+BD4x+IAtfD72yy28Ph68lkaNCjOCsYGB JIfmywLBflG7hqVahOhBQpSu2/zv/l+JrSxEa8ueellr8rHA+EPiHomt61qr+Gxqki6kw0zS/CLy RwvZoFAWRC52HDEcs+TkjrjPXw6hb6GdQ8DajZzvrDpLDPcWskklr12hTIyhk++5J5GCfvA4NYnB Om+XSLsn620f3sWHxka6vur2++/5GDoPxNvvCHiCfwbY6JptvNoc5jXQ9QxN/aNv5fMkeNoG3kOo B56YOQON8ban4c1mLUNW0C5FtG9xumsvmL2Uqlj5cgJCsdpOCCQRzxyKx/s9RqLEXvdJv5/1b1+Z 5+axVem1KPw3Sf8AXlZnlmn/ABNnsriazivUcOMfbUBZQV524UnnPftx3FdD49XxVr2m6Bd6OqX9 pIYzcI8Ujbg0q7iTzjA3E8jgcA1thaUMDjYTm7J3ufMZb7Ws50Yvo169/mea6f4B137W15rSf2XP ZXIkj+ySyTbccgOdxBORkDcT9D0/RLwB8SJdM8PMbm9g0vUG2kWMsZCS7DuLtwU2njqD1PSvQ4mj HF06atdei2f+X+R7fDVCWBlVk/u7NXR32neKdA1iLT9F1W1Fhb39x51zq2nyF4nLOTh8MxHJEYyx ABXoBznePfhD4a8QadrUWi6je6hYXcb/AL+2Ch4WCArgjg8EfKeTngY5r4iNWrlk06eq3v6NH1MI xxUXGWl1b+vvPyk8a/Arx14K1XVL+xuLvV9Kt3Vg+zy2SMleoYfKx+mcc965W411NC0yR54vLiYk O0ThCXI6Bjz2HJyeO1fttPNaebUIThZNaNedk9fmfluY5bLJ5ycl7vTz6HO+H/iNcX9+bG+k+0W8 kbOIA+FQAErjsG3AfUcZFe62eh3MnhuS+vJ7dLtmDBbgHzcbY2x6t97OCBjAPNcmJpPBu8+//DnJ kcZYyEnLTlb/AK+TPn7Up0sdQv7gxRyNdBv9Lu0zGiKzH7jcjO3oRzjAxivov9nvWtf0W18Ralpu pNLoU0savbahIn2ONiw3HawwMDcABnJC9O3bjOWrh3GW1kvTVbfM2wKl7ZOOj1fyOZ+K83hPW/GG r6lafa401W/WWVtNtt8cDrGizHe2N3zuzbRnouSM5r7C8P8AwR8PT6Fo8+kWll4u07SlxMt6kLXB d49j+ahQ/PjphTjaMHI3Dy8Tj6uAo0ls9r9tLXPdweEpYyrU08+3qGs6NonhfwrNo2hRanZLNLI0 9nfW1vI6YAG0ShPMJ4IAJAAGMc8/PGq+GtMgufKhk1O4ilCO1tfj5RuI4Oc4HI5554qsvx9XErnq pXvr/n9/4nJnWCpU+SENlsjufAvgCwutS0zXRe2ej6faahFZ+XJA1355yJHXYzBGXbjJclem4dK/ pH0L/gqf8cPEGt32nfCz4Q2lx4U09YUtdO1yxnmubaBYVhXdL5sCsxeKRjhABnaAcZPasz9jGUpq 6XXRGWBymFl79r9P1OT8ef8ABRP9qvxl4TewT4OapbWmFF1PptlFNLI25QoVRcK6sJNrKyDcpAbI wao/Az9vf9qfSvF/xM8FanpHw8sPEnjfxK2sm88XafPPcaekmlwBmMVtdiL7ODaxxLh2O+5ycbdh ijnyqRm1H3Um9+yv/kerVyyGGjyqXM3ZfJtX+6xteIf25v255JtUtNZ+JH7PXwvsbcSBNeW2t5VY htqkJPK5UHk/OMjGCATWHZ/tq/toeLNJvpPAv7TPwk8QzaRE3nan4Y8MafLplu6KMm4u5ZGijALI X6soYNsIZc4S4iVk4RvonfWy8tTT+zqUdov5v/I8u+NXj39rH4nfAfxT4I/aN+MHinxVY+K7i1gj k+C9loEWnrsuVeW1uH2RSbgEHzIQEZDkyqxQ/Jfw50zxr8Fdet7n4b+IPFsGpX11Ypb6r8Q/EV7q XkSWsyvBLcG3a1hjjjITEeydflUFGC5HRDPoSg+dpW+/ocksB+9iqS0f3fiem/GH4sftD+NjZt4w /aK+IF5pn2eQnS/DNtBq3mzbiuwk26RxgK5QNtcrktvUFs4F3+0r4v8AhB400r4k/DHwx4k+IPjL S7+5+1eIvixq98sM0LyiRPOuLa4E0iKSVSEFFP8Ay0WQ5rk/1ioSXM57FTwNWgvdgpJJ+vb+ujsf oR4e/bk/aMfxfb/EjUvH3wYt7PWdCRZPAus3t6miabIfLk+a3ild1u8KRvDMvzMobLAV6bcf8FW/ F/h7wvqGteIPhN4P12a2upLOGbwhrc6CZlO0TGKeAFIWOSpMmWyAASDW9PiGLaulqY1MvjJ8qTTX p5nzN/w+r8Z+KPEr+FJNH0b4eXWoTpY21lo2nTahqUNzu4Vprn/R2L7XRUWJySw5XBNfdepf8FPP Bnh/4V+AfiDe6B4o1m5gu2j8U+GtH04T6qLYaVdyrcQL5iRRE3cdsGEjAIkj8HAYddDMZ1a3JOHK tfv6GlTKoRpc0X7yf4W18ux+fWr/APBfTxnFqmoJp/7OGg2mlxzF4IL7W5Lm8S24AWXaiRrKc5LA lR93B+9XoH7GH/BRy1/aQ/br8UeKPEXg6LwlHr/gGPw9pui6fcm5mL2V/Leu5Z1VBuS4lYl2RVEI G4kgN3ZhXlgrxte9vu5kzyKdSnQna+6ktu8WvzP380TxHo/iXQ9H8SaDqNvqWg6/axXlnqduSY7i GRA8ci5xwVYHn1r+Tz/g4M8d/Fvwb8X/AIdQSahqcHwm8TeH/LsLbTbi4jt57yOdzMHUN5bTKDEQ wGdrKCTivbymEcROS68rscGMhKleL0abX4P9T/O8+IelxWF1HHC5dMjOBwD6V5mkiROYp2maJTnZ EcDNfM03zantcvIrs6DSV0i/vrOxEVzbm6lWPzY41ncZOOFLKCfbcPrX9H37M3/BFXxfceELL4rf Fb9lL9rr9oPwzq8UN5o2m/CN7LTdOvEKFmF0YvtFyinAA8so4zztPI/NvFTEZ5RympT4fqU6eJm7 RnUTcY6q7t1dr26XPa4ewtHFV17e/It7f13ses+LLn4//si2i2/7On/BI3w9+zne2r77P4g/Fzwn e+I/EqFW3B1vNVRpEcN837ttoIUDhRj8n/2kP2nP+Chfxk1C8T42ePvi/NZhm/4p6wefT7GMH+ER W+0FB2ByK/B/D76N2DjjYZ1xbjZZpjFrH2jvSg+8afw3XR2Ppc04ilhoOhgKXs49Xb3mvU/PPVfC +tWs7TanbarbPOdwbUEZS2T1+Yc1z8ujTrxvO4ddy1/YVJRhFRitEuh8BKc225MoNpVxhiFVh2UZ Gai/s+YEZXLDsh4/WtE76EyjZshktZ8DdDKB0AHP8qgMTKoUghs5O4YwPxqh26EexwRhsH64r9Cv 2QfGrJ4Y1TwJo1ojeMVutR1KHU5GTEUa6S3kArIQjZu44+TlQCQ3Dc/G8eZPUznA+xpbqUX6pXVv xP2HwN4rw/Bud/W8T8Ps6kU30bs7/JJnNeMvihofjz44X/jHSdb1LU7Pwpo2sy2utz232Ys9vaXZ sJhGMeXI1wYZWA4R5CASFBPQfG5tf1r4XeFNUtNHn1m++Lmtv4rSXZ9qvluZNM0yK8jXaoIEt5cF wozkLEDkrke1leH/ALPw9OnPTk09Enp90T4fivMKed5hWxNN39o027WvJpOb8rzTa8ma/wAL/wBg D46+O9H0rxB4jh8P/DjStdI+xv4rlPnTrv2ZEceW3E/KF5O4qGCA7hf1X9gz4xaAkF5Dc+Er6FLh Yp/7M1Jre6tVIBzIXjMUTHLJtMjHcpG1htLfLV+PsJ7aVGKbWqv0f/AOClklSSUk0mehaD+0V+yV 8KbHU/B3xh/Zq8dftE+IrN2Fu3jn4vapJotoR8pxFo5tiWyCDucHaqDaCCX9AH/BYbxR4CkT/hmn 9lb9i/8AZ5FtIklvrfhf4f6fqWuRFGyh+3Xqyzlxz827OTkYNfiWZ+B2ceIeLlPOs2nDAyd44fDJ 0uZP/n5Ne++uiaVj3KfEVDLoctClef8ANLWz8j5z+Ln/AAVS/wCCgfxtgew8d/tWfFm70tn3f2To Oof2RaL8oUAR2gjUKABhei44Ar4F1fWNb8Q6jJqOuavqOsX05Jkv9VneeViTnJZiSeSe/ev3DgXw xyPw1ouhk2EjQTVnbd27vdv1PnswzSvmjTryvb+tC/Y2MQCkrvbI5b61rwxHjIxyOv0r7qcrHnP3 mWPBUUc2vPbyDcrhx047/wBK9UtNNGmN9gTcbdm3xbwSOvI5/wA9ab31Cbs3Y5q70+31y+Gn2Fnb R28DkXGpxxLjOMlFPdvU9qoX3h2xh1nRbKCOaCG6Sbc0DsGJVeMZ6EEVWzsaLXTc6CPwzdqD9j1v VYPL24Sc+Yoz+VOuYvEGlSQQrqsOpXk8hWLTrdGFxIcdQq9vfgVPtSFGMt1Y6K2X4k6fturq2uBA Iwy28XlzYHAyd2Tn6Va8HfHH4r+B9Wm1bw54q8b+HtSsJyI7rwveT2TWzKuxipiZdjFThiOTnnrW cKka3RM3UfZxbjI+3fhh/wAFgP23/hXM58PftL/EqBZkWN7TxZKNYgYL0JS7SUBuMbxhscbsV91+ Bv8Ag5G/bM8Ji3i8VTfDH4lWZcnZqGleRdMMD5N8DLjnnLhjyfwl4SL20MebdSR9w/Dv/g6CsLpY k+LH7LsVq6cNc+ENcHznHZJkOwd/vt6V9qeAv+Dh/wD4J3eOUCeMrT4pfDi5XCyrrGi/2jFGeNxJ tGkLL1wVDE4+6KxnhJLbUr2UJ35Z7dz7J8H/APBRL/gm78WZba18PftH/Cj7bdsCLDxLcf2XO2VJ UBblVy2OqjJHcAivfrbwR+zJ8XbWOXQNX+F/jW1vcrFdeH76yvllxwQrRs27p0571xVKCekkTKnO Op55q/8AwT6+Cd9djVdC0M+GtXWN4k1fw1NJY3CqwwVDxEHGO2a8Gn/4JuzeGLqS8+Hni59Mzata C017TbLV7YLhMMI7mJ1EgMSEOMONpG7DMDyVMIvss2pY6UbX6Hzf4w/YW+OGn6hc3f8AZXg3xTbQ WWy1ntzc2dwLtUIS6fLSIcybXdUWMEKVXZuLV4f43+AfxGhutRm8R/CTxTJp1gIltLLSmTVkbPEj ENNbxxlVAK4jfccjKDkediMM21JaW/r8D0qeOUrrTU890zR9H+Hs9pcQeAzp2vT3klsNV8U6TNp8 sUTwiVpA+XtoxuJt93mo7SLhUdSrNnat42uJNXN1YWy6+JFub2VvDbILjy7cqZZphEd6oAyk+Yqg q/AwCa+cznA4qUo1KMru7v8A8N6kYvFzpU+Wkra3066GrYarB4lv9QtLzVJvBfivTLZBYQ+IbOOO K28xX37EfDI5BU5C4OPcV6J4f+Bmn3Xw4v8ASfEt6viDXtSCvqmq2USfZWlyRGyKOmF2ZY/eCsc+ nNOtUwVFKa9521/H8z6DKr42mpz7X+f/AAx+f/8Awr3W/DXjhPBmrW0ul6fbSmPKL/qQ3OfRlKj7 4O0hTzwa+27TRtBfQrTSohNaxwxCD+19NkeN26/Pu6ZznP0Jr0MdUdTlqpXTV/XTU87CZUqFatF6 X1Xz1Pny7urvTtRjh0vXo5IxMrbNZG4ld38ZHGeB9eT657Obxd4faOOyPhy2vXtT5jS3kkkkbDbx tLEALnHH4V3Y3HRxEIuEeVx+61tj52Od/U3KNr69fzKmgfEfSNPtzaw6T9laKYIdiSbyuQcA547c jnn1r2jw78U5ba6ebSLSVYdSeIYhO6CNQ2fn3OSMbmJ6e2MADyKsfa3jV0v/AMBndlHEH1ySpyVp dD1k3R8bWbWOpNo9uHjdPtN8y+WpYKNyM+AmDkdcd+MV+WvxH+APxF0bUfEN14zvbPSPCdubg2lx 5Ul2LmJpUMflyxqY4zyeZGQARNnIdQ2/DmJpYKtyzbt0/wAX/DFcYYGeOpU6iV+S97drL9TxHw/4 A0rw7rya1qPiW8aXTXE4tmRAZJVkZlBySpA+UFQ3OTz6e8+OPHerr4a0yysINGmjsspNfm3i+2Fw wLTNIwY5YrwAw4O0AgYr7XHYuWPrUnKPLFH55lWOqUpeyjH49P1Klh8OrHx18L9T8a6l4g06bW7C aD7D4c0v57q5jeQrJHIqqXUICGxnnOOcEj0T4f8AgjxJoWmwaPp/gLxHcWkKtM0H2Fwsg2ZdW8wA kkElVB5596xxGZ06UXTk0oxl1e/X8NT6yNOeA9m403KUld26X0SO31DwJo2seJ/CGp2fhrUorHT/ ADm1e3trO2SSJZEYEbdzq7CTGdwBIUAkdB794a0/w/o2g7fEM99BcXVzILLUtYZYLZbZpQfKCKVZ pMu33CBl8heDnDG5/ToqNtbLbr1PdwOCquEpJcl7Wv8AJlnx1J8ONXSR/Den6xp9jOiRRyahdzT3 O7ejF2D7eSN6ldin5lIxg7vlvxfdpoPiG5ijuy9jp6b1uijAzK/3TgMxByS2OTgE9sVeX5t9cShJ Wbv+n+f4HNmuBlh4ucnf9DlfDfjzVzZyXazs2nuzK8ESCDz12LuGxWzghipzjgdOlfWXgrULu18O /wDCe614ourHwnNCWv72989oWlkkwoaMk8AkIGC8Dbj0rzM9xksnw97c19Et99vxPPyHnq25pbK9 /Q9N+HviDRPE/h6e08G/HTWF0XwwZZHg0e8msbS3DnjFs7/eZtx6YLszHqCdKe/0rwRrmr67b674 vn1bWo/LE0rSWtu5VB8q+UwBHyKcAHOM88ivzevxBjJ1p4fl5Hbbrdo+wpRpVV7bmTicfoZ0HUbv UL9vA3hjUGuMwXU08ISS5LfM6TZXc4J/hbIJOBkV28LW9no09r4I0m+8GQzIxn0Hw8VsrAMypuMs OQNxREySucIAcYrtwub1lH2M5tpefT/gFYRRkkpHn1h8WNM8Otqsq+Llv9ThBhCzXRvIE3HJIXDI rZULk4xuxk5Ir1jQviW2p2yXFlqVhrtxcgtGNMiW0SB9owszhlKNjtgkgkYOKeLqSq2cbpv+tSpZ jSlWcINO36aGtP4q1Mo11dWvhpom/wBdbaisQjkUgCRypVYzhSxJJbIHocj5p+OXj2bwNottf6a3 h621m5meT+z9MvnNm9qM7ZlTYBvOUzGrMMDpxmubA1FGpySbabt+Jnm2NeCozqQtzJO1+9v8z4B1 v9oPxLrN0f7O13UNDNqvlyT2wMUbAHoT1wOwHrmuo8NftLSw7rHxBPq+rQwygtrmm3MxuFJBbaNz kMu4g7WBUc8c8ffwyeajyR33v5dvU/LMPxDiIVOepqvwPatC/aYuNDuY11GODWVmRP8AicLOUlIP zK0gCIC3zdcDnI4zz9L+CP2j/BetJB4S1fxNo9tpdyFkn0PVraJ8SyRGNwlwygt8jMhBOGyRzxjm xuPxODTcW2rfdb+ke7lucxxUnTqWj5rb+tRfEWpfs53mt2Nnep8JWQ25tLbxBaTpbTRgnn7QY9od sDaGYnbx0I4z7H9mfQ/CWpS+IvC1/rN/FeAFITcvbmNWUnCSKdj5zkK+QcDOa5XxliYWVaN29m12 Z6Ly3D4iblB35GQ3nxG0n4aeI9O8StZa1a+L9EljfT9Ou9QvTa2iRtkBIi4SM7grZiIBYDBxXH+K vjvb/H/xFBr/AI3jl8W+K7OHybKfxdNLqcFnAAQI4YQ6pHgDAVQoXqoU4rsw2eYumnOEmrpJ27Pt 2ObH5tQq1Y0Kqu09+zZ/Hx8ZbG1s7HRUt41RUydqHPfOSfWvnttMklzIrj5z3FfoOHbdznUuamm+ rEGmXKn+A49Cc/yr6S+Bvx9/a5+F2qR6N+z38cPjx8NtU1EhEsPhF4l1bSJZzuBwFspFLHIB6VzZ nToSpSlibKEdW3oklu79LG+CxNTCzvSer/E/TDwh/wAFS/8Aguz8FkZ4P2l/2wbm2Yk/8XVgu/FE bYx0/teCcY9hj9a9ch/4OJf+CpVlC+m/G/SfgH8dLZxg23x0+FmhXLhO6Zt4IDgjg5zXwuBxORZ2 3HAY2E2v5KkZfgmz6j+08TQs69HT/DY29N/4LzeCtdeOb41/8ElP+CfPj3UPuza54P8ADd14Su3B 682shUE+u2h/+Ck//BHDx7qhvvil/wAEhfGHhO5v23XV/wDCv4q3LRRHGMw2t5aFRg/wmUAV7X9l Yyiv3dZOxm8fga+s6bj9z/yPh79s/wCJn/BKzxH4Mlf9ijwD+1j4U8f380byWnxyt9BbTLRN2XWK ewnMjkDIAaEZ9RX5Urq98hOdrf7LDpXtZNHE+x/2u3NfptY8PM40adX/AGd3j+pP/bk4yrQRuv0N QrqqmV5pYTluPl7V6zjynnKd9C7Hq9q5KzI5Oeu3A/ma/RP/AIJoeDZPiD+0RHo+leDv+EyhutOk t77S5UbaLSWWJZsFOSzJ+7KDlkkk28iufFV44OnKpUlaKWrNadKWJlyw3Z2tn/wTd/aj8DaD8XNY 8c/AX4t+EydC8vRRfaBfWouriTVrJHjzNGvyi0NyxPPQdQc10Os+APj14f8A2YPDN5p0fjPwd4t+ Hr6w99dW8k1peGBZ/C9hBbxhOWTyTCdnAPlzPzzn5nBcQZdxHBOhVjUi+z3X9I9SrgcRg9JRcWu/ dP8AyPmPVf2ov2zbefUX1X4l+PLi51SMRTTavZxXEhTkbFMkRManOCFKhtq5ztXHm/xc/aT+NvxZ sbfQvF+ux6doNmAU8L+G7NNJsFIUjPlRADueOmSTgE1rhuFsujUhVp00nHbt93yMnjazi4t7nzPJ HIuSxDeuantbWSfbltqn8a+tTsjzlFt3Ohi06OJRgFm9T9DU9vAv2ySJhw0Yz+YrByuarqm7Gvb2 8lpteNXnt1YFoQPmHzfw/wCFaNq8UuCjKQSAegweeDnpXPJ31QuVJln4fqv/AAla78AEyfeOB0Ne n6vJc+JJ5tM0NdtrZORca2hwA3P7qM/3j3I6VvF+9cqouWdmdNpulWUdnBHZwiCGIYEa87eBnPqc 9T9a4/X/ALNY+KPC0k80dtEguQ0s7BVAKYGc9PSlz3uhU5WevUvw317rRli0MLa2CAK+t3a43Y6+ Up5J/wBo4H1ruPDdp4f8PXJ3XdtJfvMTLf3citPL8nUseQM9hgVhWbs0hc/Kv6+47C58ceDoLcLL 4h0ZnQFMRyrIcbh0C5Of8K+YpfEqxXGuRadai7jvb+aeO82PJuR3GNqgcnA7kVlhaMqbbasdE3eL S/rX/I5/UJbi7EkctprU8jk4SZBbxkj/AGQe3uTXExo0ckhKB/m27JOcc160Wnsc7eli6gud2GcD Ax8ucdP/AK1aKWrkbhPIp+X/AFfGcjNF+hHOoXVrkUu8skUUlxPNIRwzkhfc+lb/AIf1jXtC1UNp OsanpdysW43OmTvBJww4BUg470NJrUarSjs7H278Of8AgoJ+3B8KriB/A/7VHxr0yK2mUrZ6hrlz qFsxVdoDR3DOjoB0RgV9uK+5vAf/AAX7/wCCj/w90+zk1b4seCviLFGrK9h470C3ecZf/WGWBYyz Y4HzEDn5e9c1XDQnZ2+78zWnUVRSc7aK/rqu33n2Z8Pv+Dov412car8TP2Yvh34tgjPzXvhbU7rS WdQvTEizDcTklunovFfcvgD/AIOUP2UfFtvY/wDCxv2e/i34QN6gdrjQpbDVrePLEHdukifAPGVV icg4HOOWpgJXundCjyTu07ep9aeFv+Cvv/BKT4o2FgdZ+J114Fu74hn0j4geG7+CW0OePMeCKWI5 P9yRuMk4AOPa9L1z/gmf8cLoWvhX44fs3eKdQuMhdPtNe09LqT5MnbG7q5wOTgcd68ypg3G/MjW1 SltqvI39Q/YC+B/iWEXvgzXHs4bxhdrL4R1U+TK2wRrMRG5VyECqGwcBQAeK8h8QfslXPwjto4pv 2lYfh9pOsrJZxW/j2bTxDeSSEZCyXKhmmwMgh9/JwetedisCqkeWWq6J6nZhcdKk7JfccX4p/ZK+ JPiWK21XSrj4X+NprJXFrq+jyTozr0RXbzZUdFYsSNvJJznJz8++Nf2efjXoNzLcQ/DfWtOgnbyp R4Vlj1BPL8tizKrmPGZMoF/usW35+U+b9UjT9x7bHsVM0VdX6nxZ4g+A/wAXdEea7n0nW7Frh1WR b60uYdu+J3baUR12owWNizDJdSoZQxX518c3njDw7c6Rot9Dfw3y6WdYY6fH9sjgs03Z894SVgkH lszQSskiqQxQKwLehRpUZzinufE4nJqmtRWaWv8AXpueIWXj/Wdb1u4tbi4gtpo0Dm8EhWNFOeVG ScjaRwPy7/SvwI+JOjvr13p3iHW7mVLeKQwbFYqz5wpxxkcEE8YIz2rbNMuhCnJRjdxV9TycFUhg 60JN+6mj9EdB8P6hqWnWeqaPrWl3VvIizCKyuFR4AckKUO1gevqOtXbLxb4g8JyTW2patLiVSRYX bNI0oyynajg71yOucdccYFfA1oxxKd9P8+n+Z+yUa6jGL3TSOS8eeCfgJ8StOa88WeH4tE1vdg+J /Djf2bdsW+UM/ljY456sDj6ivnLRf2cV0PxFfXfhvxpB4n8LXUzMYr9RDPAoyBGw+4XGMlv3Y5UA dq68szetRpyoYjWGyfVPoeHmeQ4Wc6deiuWSd2u53lzJ4X8Oz/ZLrVr3TpreUIsc2nT2y4yfnMhX bj8T1ruLDWNHac6Za+MjPlMm8tpLhreIE5+YKgZl3KMhCSQcc08wyz20I+01V7q3pc9OFenVtGO+ xj3PiPw1pSXn2/xBJFFbTB7qSCOVnyw3HCMSe/fJ+uKt6L4s+GevpqFpYeIdQkubEK4ufJaJWO4I Sol8sMwKjLhhwFxnBxMcvlKHOv6X9M1ljFSlGMld/wCRx+v65pdhLHYXdvceXKS63djA08oLHCLk EgH72Tk4z1xivN/EfhnS/EiSWbx3scbxeZiFRvjYEfIQeo4GDgggkEAV9TlVP2MU1sup8/mdb65K VOWn+Rxv/CE+HbHVLO4GteLdEsFLRrpk9pC8TnaRsGP4STu5G4kkknrXnfxh+K895odh4E0iS5vf D2lv56zX2YrrewA8tgvG1cDC/N0B6nFXjaE8yqUudJRg07rq9dPyPl8wtgKMlTbvJcv9fceW6XNq WkLfW+l3s6W906NPLp820sqkFQUJAJBUfKTnJ455roL7x74q1A6Zpl7qWq+ToyKbe/uNzJbheTxk ++Mdz25pxwlLE1fbVIpyWv3K35HzOHx1Tl5bvlatY7fTf2lPHVndtbp4tv8AaUIN7dOWy5A3FtwJ 3jYORnrj6bPjf9q3xafDenW9ncaZY+J2Vkk1WOTdLdx4AzubOCRkZJ/hyAM8+HV4PpVK0eVNN66d tbr+vI9TDcQV8NGcb3008mz5EsfEvinVNTQJM9oNTlQXF5FIJGde7shcZwMnr6dK+nPDhm0TUoFg 8WXJsLKMSJbOAke5gBjIPrx6kDgivpM3wlLB8tOEFLR36baHgOs6Uue70+V/6Z623xTnFxZzW80H 2i2EjNeSRiaaInAbEhyVBxyevQYrk9Z8fQ+IHhvb26s3tblgsiarb5SVsksArDCnGOc+tfG0ckcW pS/4bc0xWbV8TG1R3RwNzafC/wAYRy6nZxSaPdxNIZEgZvJZmQ8uHyBx83ykY9Oa8I+IPgzV/C8O oatpsdxf201w0NtArBnMe3KsQOCoPO0+g/D6zJK9TCVo4fEPR2Sf9eRxymozUL2/r+kcza67rx1L 7NqkN3bGzH+tdUYfdBCOCRtcYBx1G7tUsWq+LdT1WZpWGmNbFR9tnAiScg4DDdndx6elfV18HQi7 S2Sfzv089zqjHk92P9P/AIJ0NxJqets0TX3n3WMvbsAkpccheSTjP/6uK9t8GfGH48eFLS7TS/F/ iax025gWKa3nvSflXjAySYyByDx0AyAa+Ux2FwlWn7OotE9P+B+B0YTF1MOrwlZv+vyOUk+IF7f3 EF1q96dUkuHkxdTOWy/Ric9SeTnkcE0vw/ufE9z490+LS7OdIFmZjiRILfGVbcemwBB6AAsOc4xv 9Up4eFRNWXK/wMalOpKune7v/X5H52fFT9lLV/EFvolvba/ZWST6tY6Z9rldphCLq7jtt7IIkLYa RW4I4UjnNflbPLfW1zNBFNIfLzgLyMDnP5V6+X4pVpSp2ty2/E+0nCKppxfUjXU9RVQxdthJAZlH OP8A9dWI9e1CI52xb14+6Qa9OcVUTjJaMw5nHbQ9G8OfHX4o+EiG8NeOPF/h85BzoGq3VmTjkfcc d69Vi/bX/aUZTFqPxq+LWt2x4Njr/iO91G2x0x5Vw7p+lfB534Y5Jn7brYZRk/tQbpy/8Cg4y/E9 fD8QYrD2SqNrs9V+Nzs9J/br+KVjp0+lX2mfC7xHZXWA8XjH4feFNZkYdP8AW3Ng8qnryrg1FpX7 VfgcX/2/xT+zV8APFm8/NaXujXmlwHjH3dMu7bHrxivkpeCtHCWlgcyxlFrb/aq1SPzjUnJNeTPR jxO5aVaFOX/bqT/A4n4l/FT4NeOg8nhj4EeAfhTcyYJbwfqGv3ES8YIVL+9ucDv1P414Y1t4dl+5 cInuCQf1r9M4Zy/GZVhVRxuI9vNN+/yqLa6XSbV130PDx1aliZc1KHIu25Xk03S2bK3ingdHHpVO TS4P+Wc+evOQa9+MtrnHbUhbTMZ2v+lfdX/BNeLxnD+2B8MdN8HeKb/wpe61FqlvLq2n3Elu0Uf9 k3Z8zcjLhlYK6EnCuqN2qa1KNaEozV01tuaUnKk+aLs0ex/CH/gp7/wUC+Fvhn4o63p37YP7Q2oe JbBLGz0uPxV4o1HXUsHe73S3AgvXlh2+VC0JLKeZ1xz0/QH4Xf8ABYr/AIKieI/2e/FHjW5+KzfF L4n3HiCy0zR9N1nwboGqT39iyyqyC2SyEk6+d5oVgCAyyDkjj8qzHwayLHT54UXTl8P7uTjv5L1Z 9fh+LsVCNpNS667nU3f/AAUX/wCCq3hOHUNb+OP/AASm/Zy+Jy2sRkuda+N/7MxHkpkEu8kMNvtH PUkda+dtS/4KA6X8e9K8X6bqf/BIX9nm6+IV7bSJFr/7Ptr4t8PQ6S7AgTf2dBdzw/L1CkKuR0rk j4JYnKa8KmEzDEQaa0lJyTS6WZt/rdQxkWqlCMt9U9n87/mfHngX/gk//wAFHfjs2peI/AP7G3xp ksLpmuxda1pJ0CzZWIfET35hSQbXUqELEg5AIBI5j4x/8E0v25f2flguvit+y78Y/CdhOokXXbfS JdQ07qx2tcWvmwq4VGYozBgBuIA5r90eUYiNPn9m7LrY+DnjqEp8iqRu9ldXPk+08L+Jbi4Syi0L VL6d/lVLK3d5ScHjaASTx2qW48K67pmos2p6RqmnI8ZAOoW8kIJBBI+YDkV4FfF06MuSUkm+mh7F LL6tWDqRg2u9tCWJrK2lHnTxKEYZCNz97msTUP7OdWaCeXzSBu8tDtbk8Hp7U6cm7aaGPJKO6Kmi 6Lqmr3ISx02/vVRwG+xj5h1OMnjkA9T2r0yz8GeMIYpbWw0TVNIuBmQSDUgkQUswHyAHn5TnnsfW t3JLZjnPk/q5rWfhP4ladcQwyeIoYFnfLSAvOBkAfxKOe3YcdeRl2tfDzxVqYhkvNbgv5rY/K00P lbeQSeM5HHSlzKOxkqsYtOxmL4F8UZD6k0muDA/dPfSp+HTj6Vs22iWljM09/wDDqa4iDZFvFc+e FxwWy7ZbOQMdttRUlJ2SN6fLyyafTT1uv0udhB4i8J2flhvAl7pToB88emxnHpyufQ+9aukyN8Qd Q+w6JrfgLwzb2oLG7+IGrx6MhAyTjzQATluisScHg1wYmq8DCVaaclFN2inJvToldv5BSw8sRJQi +vdHW/8ACnfA19Mtx4r/AGpvgH4VE6OYltItX1tye6/6HbuEzjgyFOtcKvw6/ZT0V5JPFH7QfjLx IryFRF8KvCb3DqQfvyf2jNaKiHtsMp9QK+ZocUZnmP8AumXzUf5qjUF9zfN/5KerUyvD4d3q118t fL0F025/Y70O8tNUtB8ePHf9mXIZ9H12z0zR7a4VXDHc8c85KsAQU2jr1ryD4geJtH8b+NNc1nwb 4WtPBfh7U5YhBoVowkitAsKpjICgsxVnIAABY44r6TKY5jKcp43kStZKLb67ttLojyMbGjGyotv1 X5GNa6dDbQx7EbfLtZ5ZOrHcRmqyqkWvOXZQqW7Et2+8K984I+9L0L/2yS6nFvpieczSf8fEnyxK enJqSLS7dY/Pvbhbq4KB1EhwifvMYA79+tVZrQFLk0e4mpzwLHcBZEUbnGM4zyeKzLHxVa2mnWlu qtLPDCIzk7FB8wt1Ptj86pJrQcfei/X/ADEm8TzS/wDL9DbAkfJaKXbG3HXpVOHW7KMlpYb+8lB6 3GSO2Djp2qXHnVzRXh8J6H4f+PXxS8Gof+EF8ceOfBcx2MLnw1qtxp7qyMWRgYnU5UnIPbPFeh+P /wBtj9q34q+CtK+H3xL+OPxE8f8AhXSJ1urfTvGmrz6myTLu/e75S0hY7mySxznnOBWE8NTlZtbM 1VeUlZu/5/ecJ4X/AGifj/4NuorvwZ8TfHXhu5i27ZfDl9c2rDa25R8jDgNgge1fcvw1/wCCrP8A wVE8Ci2Hhv4+fE3VrR/3Yh8YW8PiKN/n3/8AMRjnwxIOWGDjIzjpjXwtGprJI1hiJrdX9T9C/h1/ wXA/4KYLbwWfi/4ZfAr4kQwmbzr7xR4cewuZQDj5jZXMMYK9BtjGfevqyH/gobf/ALT198SPhv47 /Zh8H6Y+hzPod34q+HkmozhlZUkceULeVl3qjDaZOF3fe7+HjKEKUrUr3s2uuqt8+p7WAwkMTCVS UlFQcVL533+5rfseDx/smy+JZ7u/8N/B74t6Jqyu/mWqmO7tbtSqhQjyGFkcMZMoRhRGpLMzbV9I 8O/sDfF+ODTpNG8CeN7WaBF8ibUr61sCrg7mhYoJ2cb3OB8oGG+Y5pYarjq0OWpFN6X6f1o/vPHx eW5eqspSrJJu9ldvtbsfafgH9lz9pix0WHRx4T8JW9sAVuLnV9Rkubi1Z/urEVjXPqTlRlmGOMn0 NP2HP2kLvR7zR9c8b+AtP0613XitY6bdTXEIP3kSSS4OMspJGzBLZwawpcMSqyk5ysn2O2XEeEws FRpwclFW10PmXVLmXwv4Qgu7nT7/AF6W3h2S2q2a3IncAcqm3DZLZwA2AGz0wew+E8PifX9O1C70 PSNFitY0F3faVYRwedaxyHCeaDt8tsKRt6jAxjIz8FVy+FSjObm9JLRPt1/rqfWY+rGjjJYfS0br 5X0IdY1DXI4RYXHh6517QIxIXhvV+UOpxgFQ5UZ+U5+UA5HQ18+3niqHQdQvoW+G17LLLKqRxylG 2AjG4YGQNqg52qM+gGa3wtKpJcsall289F+S/E8HEc2Gqc9NXRJba5c3F7YJcSeDpV166McNzpd7 E7INwURlSFYLk43N8xOeT29b0bT01Z5J75NN8RC1ObZbNFeC2K9QBHhc9Oue/QdZxjeFg5WafTsr O3yNcK3XqOMmr3Oh1C9sYDJbPpenFLSMytcXsqwRSquBtwpVsduvPBGK+a7fxL4a8Tarq8ugXdl5 NijiLVLa4nKMxkKsAWwZGUD3HTJJPy9eQzrTi5OV1vbfYeOxFGXKre9qjr9L1V7XTtR/t1W1y2aH cJGlEEcZXOQCd21ugyCv+90FeLv4V+EPjn+0dbmvL3wfqEpMbxiRpmDEg7ihG5s8jhuMdOa9+p7R Tc6SvHt+H3nz2NpRxMFRqLe+vmeW3nwW1tfK0/wJ4o0DxhbzSBi11MY7nBdht2ELsPHXLZ6YrzXW /Bnxc0LWE0O48N3stkzNsurmJmiZQDwuV7nA6+nPFduGr0a13U91u7t2t2/E+Zq5VLDJyWsUuh4a dM8TaRr5t/7N1W6ku/McpP0tzHwV54BAPOMdq9x8BaHo/wAQClnqVpaPdRIoUQxqnlv6buSp46bq 9nMMSqVOGIpPWK2XzX9epzYTBvE1oR6tr8dLs2tV+FEejuLjRdTu7O+tZj5k2ojcsaP1LAfMTgt3 IORwKZ4lvbqL7PcaNPosVvagrLY26yfaHVlJRQGAyOh+YkjqDzXlVMYsw5G01utNttPlr9xGaZVU oTStvovlscTZ+Nhe6jZ2N1qLwTbjJcWMSKkPHAEpGDsyRnaQ3JxjrU66p9rfy73U9MAhceRdW7SK 4A8w72w+MnO0kZJ3dc4FdOKwv1Zxi1rb+r+p48qDotJLZfj5leD4k6j4bke21LRdJ+zuqiO9ti25 iekjZJ3HBOflB6Zx32fDGv2viO6k0b7RPqT3UxktUtEaVR1BbccktzyDx7VnjcF7GLqwd7q/TQyj Tv70ddvv/rQ7rT/g9aw3uqa1ruj4utQdlig1CZXS0ABBc4JLE8t14weOMVsaD4N0jSLeFtWs4pJL cLJPqV4xdfMAwxTOQAAcgfz6j57MM+nUXJTa92yVvLf73b5HdLmjK1rWVv8AP5hrkOk+I7WSxv70 WcTFWTXdPAguJCxyYkcjJ+UHJ5AyD1xWOngye8gk0nwxfajFcoxkN1czCVGxjAfqM9CMc9c+g46G Mlhaap1I3S97W97K2i/rdm0oTjL3l/W33b/efP8Ar/gH4qW/i+W0tfDUur2l/cBI5bDjawUbnJIG 1CSec4GD6jP3r8GPD3izwnYTJ4gvre+u763EUWmRRK1vbgEk/PwxbsWA7d69jPMbhMTh6cYz1kk/ NWWv+X/DHqZTRTqRlf8Aq3/DHyH4ve+tPC8mq3W2zuLW/sLwQcO0Xk6hDKGBPGQqE/41/OZfRTtd XDiFyrOcELmvVyd89arZaWj89z1aVo0V6spNFMPvQyD/AICRRiUBl/eKHPI55+tfRWsLbYYdxwSW OOOaBGaQyWONScOWC/3lGa0IdNa4QvE6gbsAuDxTHZD/AOyLg7sFT2AyeD61G2lXS5G0HHGAe9Cd h8qYk+nXalQ8RyFAyCOtVk0+7kkSGOCWWaVgixRLuZmJwAAOpJqoR5tErilE+nfA/wCxL+1p8QrW DUfDPwG+JK6PcIJI/EHiGwfRtMdT0IubzyoTnnGH52tjODj7v/Ze/Yn+O37P3xp8P/Eb4hfFP9nb 4S/8IZMou7DxP4oTXbi7gmLQzx2w0cXUTzJCxlG+aKM/KPMJJWv0rhzwozfiaPtIUvZw/mn7q/E/ PeIvE/KOGpOlVrc9T+SHvS+dtj03wZ+y1+yB4V+KvjzxX8Vf2p9R1b4eeLrm9W4+F3wf0OSUXVlL eGaKza+vGXbs2W8iyfZjtkiVgDsBP7lfs3f8FSv+CcP7FHgbRvAX7PH7Nev2UGiQvGPEWpXTXGq3 bO++V5bmSNpH3yZcplYwSQqooAr9MyzwXw2U1Y1sbj6at0Wuvc/O8x8XcbmlH2OAy+o7rd6f8Mev ar/wcVfCu6lk8v4D608YAO63uvLY8H72AQR14NUNN/4OJvAcF9HOPhD4ptVgG0SR3h3bQCcdMHns Rjntivqq2TcO8vLUxjck9Hy7M+Wo4/iXn54YWKT3XPrY9Cs/+DjH4QX8bwzfDnxJZ3jqBFJfzkoW wB821cjPP+Nd3pf/AAXc/Z98RJD/AGlp2s+H7kcPLayGXawHbC5I6/5NfSZbwrgsSl9Wrxmuqdl2 PmMzz/MsJf6xQlFp6NXfV/kfQfw6/wCC037M32u2e98X2NtNE2VvvsGx+OhYOoXPvn8q/RLwl+3H +xD+2x4G8Q+CfiF/wrT4h6Bb+WmoeFPidpNrrGk3asxaNjDOssZ+eIHBHBUEdBj+NvpkeEdLg3hr E8WYSSpfVeR1Gt3Gc4wT06xlJO/a/kf0d9HDxZxXE+cUOH8QpylW5uS97KUIubV30ai9O9u54Ncf 8Ewv+CJvxB1m11bUv2Wv2e4tQtSDGfCZutAtJBncN8FrLFE59SyH0rgPjN/wQS/4JA/FzwzqFr4L +C/h3wFrBBMOpeAPFd/ZTxtuUnYJbiWHJA2gSROoDHAUkMP4N8JvpN5bXqUqOY11ODajN3s0tuZX ++x/XnG/h3mPs5Tw9HlktY6aN72du+1+h+fHwo/4Ntv2BLPXtQt7341/tF6dqSXBM/hmfVdEdAFD AIjrZBgcN0bJ+vWuz+Mn/Bsr8CNR0+7v/gV+0R8QfCuuERiOz+JVla6zZOo3Egvbrbupy+c4YfLj HOR/d+Z5A8uqcsZc0JxUqcltKEleMl3TTP51yriOnmdJydPllFuE1fWMou0ovzTR82+DP+DXjxn4 i/tGHxx+1x4E0OFB+5m8IeG7nVpBIHB+dZp7fy+BnIJ57Y5rwP8AaF/4Nsv2rvhlZHUvg78Q/hp8 fNOS4EI06KQ+GdY8sxsftDR3jG1WMMoQgXTMDIhCld5TyFgppWe6PT+s0dI3fqeU+C/+DdD/AIKH +LvD2paxeaF8JPB2safkW/grxP4rtW1PURtBBgNqJrbBOQPMnj5HYc18e/Gr/gkr+398BdVt9J8d fsu/FG8e9BeLUPANh/wlVk/zHjz9NM8SthSdrMGxg4AIJ+MzLiSjk+JjQxqdJy+Fy0T9H5n02AyT +0KTqYWoptbpbpngvjb9hX9rbwHo58Q+NP2Y/jp4X0RlM/8Aa2teFNSt7ZY15aQu0QVVA5JJwK+P 9Q8B6xfeZY6foeoXVzsKyJa2zyvGA/JbA4/xx617+DrfWUpQ1T7a3PLxWElhZWmrM4vVfBX2Qy29 1pAheMyLsuItpGF4Bz7189/2Qyz67AsLK0CFlGOm2Rf6E16tNO2py87tZmLp0Jae4hZZEZl3Y9ec H9Kdb6hPaboY7YLsZflJwMgdf51pGNr3Id3oyx/bGqNtWJI0Ax8qKWzg/wCNZ16mpTut1dJMP4d4 jKqeelCSWw6ejehtLoviyQHZb6gqpk7VKxgbRzxxUieEfEVxN9nlidX44uZuB8u7sfSpckh/Ca8X w21aRd8k+nocM2xmZidoBI6daZ4f8Cvq+o3lnJexW8dlNHCZYo9xbdnkD8P1ojUuVbmu0d5Y/CfT 5ot0+q3rO8EsipCAo3JEXxznjitnSPhj4Ya2ne9hv55I9rhmlwuN8akcY5+Zv0rB1uwoxS6HWXPw 28IafazNHoyNJEYyGmd24eBm6E+vOfYVQ+GHhDT7rRGvJdNtriQy3S+fLCGZdkW7gkHpwazlUstT WF7P+u57RH4ailgvPLtIyssEEv7tAMEvEM/qa9q0LwK5glQxKBE9uVKkDG9JwQfQ8c1yymndkTtK zeq/pH1rofw9trey8SSGOMM19chf9lf3mffPAr6v/wCCWGl2t34i/atu7hEkmtvFdlh2UD72mXpP GOOQD+H0rhlU5sVRT/vfhY+jy6Clk+YO23sf/SpH9GHhWLT1e9ZYIv3NzIgwoyv7+Uf0r26Kzt47 a2xHFtR9xJ9DtH86+phBJOx+bTexv6dBbNa3j7ExtjfoMcHNbPiCGKO21btvsW+76/NzRFJLQd7N n55/Ar9krWvip8GfAXjTS/iHJaLrcZun0DULK1u4rcx3DJtU4WVQTFyN3G9yMMdwb4t/YL+M1vBq T+HdR8E3F1eIqs+nQyaP5xWMgM4US9SEJAwM7sAZAX8uxGS/WYNLS/bc/TMwxkaWMqykrvmf5tHz dffsf/tGeELqfy/COo3UczZ+2+HbmGRoSzryGMsblVTeeE+YgfJz8vnXjD4c/ELTf7Gu/Evg34hJ r63EUVnEdPu2SGR98CGaaM+TCMcvL5gUK6s75DbfIr5JXpW5HdLuY4eVFQabd/U+eV+GGl6nDPpf ijRNJk1aa4UxWTSQNdISwAbYCZAwbaPmJYFiMcjOzefB+X4aRWN3Z30OlWcVzNZNYadc293h0IVm dUJOGyMPuYkgfQxzYmlGpGS5o21T6300/roS8H7NRcZ+9/T19fzOPn8E2fiUXOu/adQit9rWsrzK kkTfMWICFuoB7AnketchB8FfBSW7aVoniKbS9UjxJLcAn7MqONxjAbCxdWG4t1BBzWOFzurgvdUN FvbXS/8AkTGnTm4upDlbe/fp+hZsfht4a0G806wsPF+pa7NcagRdR6gYJLVAoxsdi2PLJI4GMkHn g57jUvhf4F+H+uavq8OnWElzf3cbWdteI8Q8tmRWZZkyu35ThcdzyBXXLOqrXbn0/L8v1IjUpqbn a8Y9+vUwNZ8D3UeuXw8I+J5PDfhrxHDLJL587XEMjMu8x5OBGny43EgryQMcV5FY+IdPFlqNv4g8 d2emxwypHHZlv9a5wCdo3ZAUfePPuTWUsyVanGEovmtr562/rvcwxleCs3K0W3p8t/mztfFvgLwX Y6Dp3jLSo9N1W21fKHVLG4aC4UhlDnyUOx14PKoen0NYPgX4O6Pq0t5PotrPDZI/nHVQQbdjjlSf lDPwQVAGMjnOMxDPZqlyNeX3Wtc46tGksVTdNc2z+X9fmem+FfgfpniO3KajrcNlaXSjN3KWacE7 h5acBABgj73YE9RWJ4q/YL8PeJoxNofjrUtLkVAQJ7RmDKqk7Qu84BGe/GDXZhM3qYComldL/JrT 5HqVMseZ0+ao9U7q3Y+bz/wTv+KF5f3Fxonj34OzafBN5RuvtOoJeRsHAxIq2gjB9ldueOtVo/2F fi7pd8W1vVPD+o21hLH+60K+ZDdxhg2Y2cIQQRxuCH09vdr8Z4fmXNfm/J/1r8jwXwdXry54STV/ mke13f7K/hHTFjjm0ywvtVVDH9oMrTGRQNuB5pUjv2rkfEPwu8ZeC4WXw14TnjivZVX7b4T0/fjg bVl8rnsDkjnPU4r5X+3P7SnyVnaK+53/AMjsznhRYalegtY79zn9F+GX7RPjG+Fhp/hHUNLsInCy az4mX+zIYx0yfMw5B4A2hj6da9Qg/ZL1k2Elj4m8dtZ7ZfNurnRreS/hmAYEhfMKsD1GChzgHkEV riMyweDcY0featfste5y5XwliMZedVci8+vyM9v2ZPCdjd22p3fifxPqVtp+RFBKtrbRMvVj5YBd yCwz6E89ePQvC3w8+HEGm2523c1zI7iSNp5VJ2cBnf5IlXcTgZbOMYJIB8jNs8r4mCdOne1lZfj/ AJnvV+FqNCcYTvJ/dfa33M9JDfDvw8k9h4Y8O2urPbhpH1PULf7SFyysQoclsYwNpweOfSsT7PdT Ws1zYtYQSiR2On7ZC6tyPNEYXaqgnAIxjbxmvFoRqUk6k3dvT0/q57+AyGjQleMbbep+XfxkkmX4 T+PZ4pNs9lpdxcAnjHlxmQ9D6KeP8n+fPSrJLy9tElQsjuQcOQG6+mK/c8kVqk36fkz85lZUH5f5 HoUfhiwLY8uQdv8AWNge/Wpl8NadzuRz9W64+or6z2cZ2R4yryIJ/DOmoQGRAxH9wNn9Kx7nw1ZJ lRDbuT/CqncPyqp4eH3hHEzTsysPC9mwJe0ddvZQ9VofDD7pUi1CKJY2GFniK9RnHJrN4Tszqp4u 3xamknhHVJHWG3aO6klcKkcSuWYnoAADzmvrTwD+wZ8bPEMVvrvxGu/CPwH8Czos6+J/ivdtaXVw mVJEFhGr3kjlCWQtFHE23HmrnNfVcL8A47i2t7PDL3V8Un8MfVnicRcbYHhml7bFSab+GK1lJ9kv 6se8ab8I/wBif4XeSdUj+If7SfiC2O4nUZP+EW8NucDAMVu73Uig7uRcJuwMqBlT6Bpv7UGs+CrE aZ8E/h58L/gfZLEIBd/DvQ7e31WaNYzGomvnBubhgjON8srsd7knLsT+5YHKMh8PleEVia8d5S+C L8kfjuMzPO+O3acnhMO/sx/iSXm+nyPJPE/xX+J/jK6ku/EvjjxNq8lx8zSaheytnJz0zz1NeeyS 3LuzTTNIxPLSEtn3ye/SvjeKvFWrjqlqlVu20Y6RX9fofVcN+HGGy2H7mkot7t6yfq33IwpkQcyl mI6Z9aRY9oYMHYD1yB0r4yXG/wBYXw3b79D6+nw57KybHrtAOFYMP4iP51Z2BkbKbWz/AMBHqf0r zqmeVcfUbWij+Z2Ry6nhIWtdkO2CL95l0ft606D947bgVT0zz0+lbUuK61BuMJty8jKpkVKraUoq 3mdRoei3WqziC1EsMQYeZcMDsXv27+1fVHgTxLP8PbR7Xw74g1mxluNpnvo5pI2lZc4+6eAMnA7Z /GvwPx74+xfFOVT4elNzp1bOrFu6cYtSjH/wKMZfLzP2vwZ4FwuUY5Zy6ajKndU2lrdpqT+5tfee 8aV8c/i5pjJPZ+P/ABFDB18xrp2J7gAE1tXn7enxt8FRo9r8TNcluDyli0u5pCPoeB05NfwhlvgH lnF+KjhsPh1Fydm43Vu707f8A/qvO/ECfDeDniK8lK2yfV9vmzyBP2yf2ldc8cv8Qbv4hazZXrzx XHlQSuFbywoVeD02oAe5/GvqrQf+Cpn7VehOotvG14/A3OkzxHoOnPtX+otbiKNPL8rymkvcwGHp 4eMuso04RinLu7R/M/z4wuQRoY3H493TxladaS6Rc5OTS7as9o0D/gsp+1No2TLrd9czMRmYXbM/ XOOcnHSvdvDn/BeH9oKxVItUjW+hz8yXccM5PPTLr9a445ukneJ3vLmrNM9js/8Ag4F8QWumypr/ AIKspFhUkNHGqvv7AbWGD7dPwr6g/Zt/4OBdF8U6LqEnxi8EyaPDYvELC7gjl86YEPv+cuQwUhBn A+8RzjA+H8eFhcZ4e5ni3TU8bh50XhI7OUpVYxqxT8qblK392/Q9zw4wGOqcYYHC0pWw1WFVYh78 qjBunL5ztH52Pt7SP+C4/wCy9qcLQagtzCk3DRXDhcgnByCMYx2rxv4jf8FS/wBhfwDbHxv4Sl0X S5NSuVgvdJ0y0t1kfcGPmKy7SMEZKnI54APX+T/o0eNmd/61Zbk2ZZfUVPF1Y0ZPeMed8qqX6KLa bf8ALc/b/GnwupYHIcbmOFxKcsPCVSNtG+VXcPPmWi87Hyt4+/bZ/wCCUn7REtjqHxH8FfDfXdZs G3x3/ifwxYXEw5JKmXhyuWYlc4+Yn3rob/Wf+CJPxR0C40DW/hB+yjax38MkMt1pXhG00a9KyJtc /abKKO4ViP4lfcDgggjNf7Q4vwipYm04RhJ+T3P81sJ4vYnBXhUc4rf3lt/wD5s8E/8ABLP/AIIb eItQ1G5VLG/i1k77WaDxvq1obNTzsCPKhXHPDhzzgjirsX/BAb/gk7qHiafxRpHxW+K03h6aRJf+ EV0zxXpNzbwn5gQGa1M7R4IIXeXyp+Z87a+EzTwdlhpNRjJLpfz6P8j7fLPGiniIr2nK2t7abdSl 8Wf+Dbf9i3xN4bW6/Z9+O/xQ8DazwwbxK2neJ7Epu3bVhRLSZWPIy0zYJHHFfN/iv/g1nTxD4IvJ /A37alpdeK/LeWDRfFPgRrC1aYKWjhlli1GZ4gZAFZ1ik2gllV8bW+Rx3htWorng2le1mtU/8j7H L/FHB15WnHXdOLumvn18rnzHp3/BtD+3Nqmo6hZW/wATP2Y40tWkT7Ve65rSo25Bg4/swvgHqdvb jNfKOs/8EL/+Cl+h+I7nQk/Z2uNeubeVEGpaDr+iXFtIqx43q/2oEA8cMAeegxXyGL4Rx2FvzQvb t+D9GfV4PijAYy3s6q176f1Y8i8Xf8Eq/wDgoP4K8QP4U1r9k34zTauhmKvoekSaraygxx4Mdxa+ ZBJywHyueQQeQQPCdM/Ye/az8Bat4hPjz9nr4teA1W/gEc/jfRbnSIrhljkZkhe4VBM+FICoWJPA ya8arleIo3TptHtYbGUqsXyTT9Gu4yD4NeP9DvrTStc8KatouqSwXqpYavGbd5GFq+0Lvxv3bTt2 53cYzuGeattBlS3ui8EuxIY8rg4z50X/ANbivPq0JUviR0QipJpG5rGkv9lvt6Hf/o3UY6WzZA/C sT4J6G03h0h12qLjUycL2W1PB/EVx3ZtTlaM23sfROn+Hc292Gi3H+z7ddzDb/y2twDj8cfjX0j4 f8MxfY7lmiBcz2vBXj7lyMD0rnlaSZhUkna/f9T6WTQxFYeLH2FFS4uj8wIPRzn6da7L/glgTbXv 7VjSOWL+J7BtpIbP/Esu+/Tua4464mi3/fPp8saeTZiv+vP/AKUz+gDw/feXNraAeWIdQmHynr/p E9e7tdxyWEbtJKhtNj5RiFJJQYOOCPn6Hvg9q+rg7L+u5+Zy95rQ6DRb4NbTkSErNbI2TyBgN/UV r+Jb7bpmpSg/8ub8L9D1/Org7WKWm5+fH7M/7L/wt8e/DDR/Fl9pCw+KPtbLN4i0aaSyvJSj+bEx lhZWJVWXBzx619DQ/s8eOdDeSTwf+0N8fNCk+ZFW58T3erRLvEO5vLvWlQtlmO4jI7HFfnOHpTj7 0ZPU/T86rcuKqwnFO0mvxNLTR+1zp114hjsPjZoviOHTbvybe38eeGbOdSGtbZ1Vmtfs7kBpic7s kjkmtuLx7+1RbQGLWfBXwO8ZbmUR3FidQ0YldxjIZWNyNzMM5BAUcYY11KtWhuk0eTKhSk9Lx0Od ufiN4h1poIviB+yRpmq2l5MY3k8I63aapJ5bICCEu4LYFznDKWUDqGavl/x/B+zb4o8V+BW1b9nX 4yfDAWl6PN1A6PGIbpHVjJCG0m6mk4VHcl4wpweeuefFzp1YPRxf/DfodGGwzhNe+pJXunp0/rqb N98Kf2MdfSSHSPiv4v8ACa6iWtNniKHVLNTiLbwdSgwoCDasgwAAqq2AoHA6d+xP8H9W1g3Hw9/a J8BamRArNpl9c21w0ikL5busM8WF4bOFBYt1GKVTK6VWL5WtTk56kNJRehha/wD8E2vi9aBtU8Le JPC3iK8jCtbhp5LK3jOT+82hJdx2lVGGXGM5PQ+L/ED9kj9p+PRZtM1TwzqHiOZV3RfZktZYIW+b hZfMD8DHSIZ/u8ZrzcZkDqNNfZ/4f8yqWKhFOHfufK3if9mv4qaF4d1OLWfDniy51G9tjmzbT75L e0kYf6pywWBsDGSpdePvCvy98RfC743WespE3g7WLHTfM8mG+1lo7WNWLbUydxAbJ+XBOSOMgVWX 4ZRlN1VZRX32PHxeVfWfdgnq9z9CfhL4W8U+DvBmm6DcSaT4h1m5mVlWdyLOJWAwse7hs8njqeTj Jr174g6vq2m2lrpiXGk6Zp1raL9p+xxqm58AEH1G4noMH04r5OuozxEpJWV72/I+jwWDlTouL3SS enn3+RwHw18VrperQpe6hG0MLlpZtQkEVvGjcfLkFeW9cV0/xH8deJ/F3j3TPh34Mh8Qahd31jO9 rp3gW3km8+MxPmRhCx3Y5c5x8qjOMZrtjRlVrKMdXYVBSo0JwUtnb0tv8j4h+Ivxo8afDmeSIT6/ ZaxveJ4i7oVIO0q/ckKuORjGRg8VU8M/tGfHPVLUx/bdRvLKXy5T9sjkAZGbZ+7kYbv7vHBwc4Na 1+H4YiLrydrP8tD5DEY7E4Oo4wm1r/TP040NdTl0DSrzxC6Pqt1Zxube7Ls6syZPbcTnA5z9B0rn 77xXL4S02VIdWtbosAGt79G+V+5G7G7ovJx05HQD5HB04+9GMXvofodOo6dL2l3dLru3a/3I4zS/ i14vvtQn0+01Jb2byWVbS5mM2OB8/dAB2wM8jg9u+sm13Vxbxal4knCuwmkgIYqqkHjg/Ng4HPPG eDmvYxFKOBXKob/h/mLDY6riEuZ9f6/Ib4m0rTo4pohp09+GRQsrSBY2GCMsB8wGfVm4J6GuKsLG HRIIHvbGDz+GxanaISTkqynhsceg4HJJryViJTilFdfz0PTxjlWqKq+gt545uLO1Wy0vTLRB5vyR WpkF0y5BydqlTlcfxE/NXbaPriXVlNcapBFpCiMhbyZyFV26gMPvsGAOMe+eme2VKOGp+/LVu3z/ AKRph5SrzSS2R+Qvxnkhm+EfxPyJI1j8O6ixDEqxIs5SOgHGR71+BOg5FzaZyAsnUnjr0r9zw+Gj hK0opdF+p+S4ecqmFbatq/yPTLxp/srlSxfoDECSa59xcg4Jn4+X5kbivXk7u6OGmlGNy/qMpihe XeV2L1OeMfpXO2upZKtFcQpJkZPmN83twetKUuV6l0qfMm0jutMvgICl8scCg8T3EgbOWIAz27/k a9D+Gfwz1r4k3+ty2M1jpXhnT2T7b4u1XJsbRccqP+ekpUfLGvJ4zgZYfTcMZNPinF08HTlbmere 0Yr4pPyS/wAjwM/zOPD+GrYqom1FaJbybaUYrzb0/wCGPs/wt458I/BHS49J+B2hxQeJFyJvjB4p hS51+TcMEW2cpYp1x5QD7WIaSQYryXxB4h8SeKL6TUNf1jUNZvbhyXutRkMjk56nPHJr9szniSjk eHWWZf7lCCabXxVH/NJru0fmuTcOVM2xDzLMffrS2X2acf5Yry6vqzn5IkGN58wMeifljApoMUe1 VQfu/l2r6DP+FfhWf8Q1K7dGL0unp5bn6xlWUxo2qSX3khlyFyrbGHcc59KjaJjlAigkZ35OT7e9 fLRUq0+7Z9C5ciaXQXbhAAkgz3P5dKbiTgAMT0yn6V1xhOhG3K7dzm9qqt/e2HqjFeeGbGdw61IG bYVLDcf4cc5r2aWCnGnpp/wdDzqteEp2eqEjhdnLFkkPTkdPpXonhzwLe3/l3GpRPZ2zkERsv72X 8D04r4PifiWHC1H2za59VHu3b8l3PteGOH58T11SS9xfE+yXT1f9bHtNjoMVvCIbSAWtunGwDg/X 1+ta0um6TparNqcpduotVO3fj19BX8m5lnNfH1W1eVSo9/Pv8j+o8FldLL6SS92EVsee698SZEZt P0MLdS52/acDyYQOy8c49Tx9a5SxhsZZDd6ndT3t5OcsWPAPt71/QHA3DlPhTA+0krV62/8Adh29 W9X/AMA/BeOeI6nE+MUIfwaP/k0ur9Etv+HOotoAzM0YKRKSAZf4h6Vt29tHg8MinJ3Nxn/CvrKc LWb/AK6nxte8mrmpFDEXIXB7ncP61my3c9xdDT9Gs5dRviPuRcog65JFduEw/tlOpUnywguaUnol FbnJUqSvGnTXNOTSilu2dbonw9CyrqHiDZqd4MFLXGIIeh6Y+cg+vH1r0g28cKhZJGCpnAyEUf4C v5f8SvEJ8YYqNLD3jQpXjTj37zfnL8FZdz+mfD7gtcKUHVrO9aprOXbtFeUfz1PM/E/jvTtMLW+l ut3eIedrkxL7k/xdOn614Xq+uapr0rT6hcyXOchQx+VR7L0Fft3gxwauHacM1xdO9eekE1bkjp7z 7Sl96Xqz8j8V+L5Z3Vnl2FqWow+NrXmkvs+aX4v0Rz8ik4IKk5wY8D86VDMB8oaJeQDHwT+XP/66 /p/A8T4zBrmjUlbXZv8Az6H8+YvI8LirxlBN7bJ9fzNrT9Q1SNw9vqWpWuBj/Rp5Iz+GD9a7bTvH fjjTQpsPGni6xiU5xDqEwyRxnBJ5GTX6BkviDmUqXO6ja00eu22/mfD5rwLltSdvYpOz20tf0Ohj /aT+OHh3L6V8XPH9qkK7gkeoP8uOcnB9K7vwz/wUJ/a20hVk0j9oPx1arHzzcyOeB065/Cvr4+JF VpQxEYS83Ff1/XY+Ul4Y4TmvQc4+kme9eHP+Cu/7bug7Gg+Ouuaiqcq2pRO4OOpJORx716jbf8F2 f229LWCa/wDEPhrxGbYjbLLaR+a2D/eAzW2G4ry3MP4mGjddYu2/4GFXgTG4TSlipL/Er7Hqmk/8 HIv7Smm+RH4o+Hvg/XBAwOZbYxSAjuCrjB7/AIV7VpH/AAc3+Ib6H7P4r+BujSpnPmWlzcI69O4c 89SDx2rZ4fI8XJJqcLejX/DGLwGd4SL5KkJ39Yv/AIc9ZP8AwcZ/s8+Oo7CD4n/s6weIFspBLDJq CQ3bQSAYEi+dG2GHTcMH6V103/BZP/gmH8TbW1i+I/7KvhOV7PiK8ufDek3bR84yA8OPcjpwDjI4 5a/AGTZkkqWJj/28rb/1+BtR4s4gyuT9pQb/AMMr7f12sYmuftS/8EHvivLbXPiL4H6X4ZvYePM0 bSZNJik6gl0sriJGb5iMsCQDgYGBWh4W8Jf8G+F9ZvbeHbmLwu94JlFvLrWvW/lmZNjuu+4kUPtz jIYAknbXzGN8E6db+FyTS6xl9x72G8YsVh1avCcebdShdefc7LSP2K/+CNHiq9abw9+1f44tLG/i hibTj4k0yB4VRo3BDS6e25iY13ZPTIyK9O0v/gmj+xHq0V7Y+F/2yrK9S+dZLW6kuNKlNuyLKIxI odC/+t5I2k7R0zXwmZeDdXD6unOO+yurrtvufWYLxdoYq6coPVeT116/1bY8b+Of/BP7xx8OdD8X a94E8W+EPi/4UujcXP2zwlMHv4UZeN9sjOzdcHyzIe5AGcfmx+yz4i0T9lvU/i/Y+M5r/WNT+IWq 2159g0iylt2sFhtLiHa4uhE7FxNG4+UYB9ufH4e8Bc54nxd8LyqFO/vTdrt2skrN6ddLLufSZr49 5JwflFeji3J1MQ4WUFeyg23eV0temt/I/aP4B/Hb4QfGvW9S0jQviR4a8KeJNUujJaeFPiA02mXV 0DJIQqOEe3aQ7wAgm3HPTiv0WT4Q+OZLG+s4n0Z5VjQAtcFMEeV2K56o/IBHTmpz3wvzfhqs8Pia a5l2ejTe67r8jyci8R8q4koLEYao3F+Wqdtn2Ztaf8KPG+maZELuPSZZvsoiMcFyuC2HHDMFGPmH cd+KpeIPCfxAl0/ULSz8E6tfs9u0Xm2t7piqCwwCfMuVYDg9q+fjwjjope5t5n0FLiLBzlrUt6pn Pfss/BHx78JfhVZ+FvGUOm/24l0Jja2V7DPtQW0cY+YNg8oema+iv7AvgpcwwMjygKEmiYsQYwRw xzjafy+lfKy4EzPDQt7K+nRo+0zLjjLcwxVWpGr8Um9U1u/Qz7PwhrMN1q0smnhUvryORdskZLAQ 2ynGDn/lmeMdqlg8Oao7hf7Pmby3UEBfu4mZjz9CK86pw3jqUW3Ql9xss+wdRpKtH70Zdr4W1VIb BDo16Zdw4jhJbIiVcdD3BFYXiDwNPaXvh7+1NHntVtXDg3MJQc2twnp/tqPxHtXm47BzwKXtouN9 rq12d1LFQxbl7GSlbs7kVv4O0+5FmqaKk/lA4RYdxBx2GOteZ+Ivgn8PvEUTx+IvBPh3UJktwvl6 nZRueI24wyn19K4LU6kuTrvbqdPNKMedbX3PINI/ZJ+FWl6pcz+HdFm8K3MkUM7zeEbiXS3aQSTA OTAyHOAAD2xW5b/BfxJodtI/hr4yfGXSLiKLyUS78Q3WrRDcGYny75pkzn+LbkdAQOKtUpUruEmv xQOspP30n+Z8OfFr4XfGnxB+2T+zj4bvP2ovj7oukeONJ8ST38vgvVYNKt7n+zkspbZJbNIPsL4a 5cM5tjI6hVdyFGOl+Lv7OPx88J6FoqW/7TF78VbDUte0nTE0j45eD/Dt/Gv2i/SE+ZNptrYzPHtk +YbhIQDiQE5CpxdRtSSep6kcNTlLDQire1Su/NzlH8kc343+BH7QOkeH9a1TV/gj+yx8R7nTLcXE a/DrUPEHw7vZGQN8iYN8qvtJVG3pgnBwOadqHwF+Aet2toninSvjp8NNWkt44rmwutCOu2m5I+QL i1inZowxYbiUdyAWBJrGeBoVZWmrf13OONSaXNTl8n/X5nE6n+yl8Fr2IHwz8efhzZRSxpAmmfEm 0uNBuJ5CrGMMbtkJkzyVEfGPuiqWk/s8/Ef4GvH8YfCtt4Z8f2+kuJI9V8EX8GqmWJisTIqgRmRX VnQheQGOCx5rzavD8qbVShU2s/u1/Q0wuMgnyVofFdfKWjPE/wBp39nH4l/HWfTviVZfCHxLZW99 Jdy3Oj6Zpt0dOF6GiS4dUaLezu0I3LuZQ4c/xk18sab8IPGXwyvtPh8VeFdV8P3tqfOgs9VdFGY0 DkorMSwGASMMOoPoNMywlenzWV07PTppc+ejho1mmt1pr1sz1GXxTqsssDSx3SSyIrJLhyWDgBJA COATjBwAcnHv53qun2F5cra+I9dEMrz4kkLB1UhsYIQFs7uOM8c5FfJYTAyw95JbP8z6KnVVWFpv T/gK51/gjwnpmlfuLJLuZ7gkzatJGNu05bs3yrt9T+ua7DVbi5snt4NPgi1O8lYBJ9RIaNFx97y1 wB04yM1jiI+2mvaatP7vI9bBwjhoNR/rzOLl8S3l3cTW+r64smo2x2DRPD4WBY+Ork9hgADnPoc8 TjUrmNShL6pd3cwfOoOWRQv+9w456AD9axr4aMWraP8ArV+mx6NCSlFN69fXyN+3u3sQ0kb7btwA 00Ss20jAK7H4BGSeM9xg9sh9+uQtm8kc7s4mYcZA+6pHALAkfjzwa8aMnVndu73+47qdWNNcsD+Y P4kP8cJfA99quqfHDx/4k025stl3pmr31xKksbrhozlyGUgkHI6V8X2uoyW9wkcNu87xENnOAc1/ RUP3c33X6H5VyRq0pRStqdf/AMJBqkSjdpm5euVnRiD9AaoS+OzC5jks9hXP3XFdyxd3ojyXgLK/ MZN94zhvIJIvs86tICMkgismLX7FUWKW1ZHUj98oywrnxF6trHZhYfVrp9T60+D3grwp8TfDl3dX ya/4f0jSW8vU/FfUyHy1CWVvkhXdgu7bsOwNlmxtz9E32tQrp+neGPD1hBoXhTREKWehW5LJGT1k kJ5kmbq0jZJJ/AfsnB+CfC2UyxFT+LilpbeNJP8A9vevpFH5jxJi1xBmcaCf7vDavtKrJf8Atkfx k+qMDfKPmkZQwyOmR9PWqcsrNgB2KZHy5zX55xNjqk6jhJ26/wCX5n2mTYSEYppX6f19xArbmUdA pGFU5zVtInXaSPu9lHWvEwGE+s6/ZW7/AE9TvxeIdL3Vv29CXrhQFVezgfWoGGThUzt/MD/9Veng sNerGSVkjkxFXlg09blkLtGPLzg9+1Mb5eFPzZxnse1fRU5e1d+h48ocunUYwXDIqHknLsMgnrge /atDTbC71S5hs7O2aeefP7pB8x9znoO/NcGY41UoynNqMYq7fkt2dmDw7qzjCCblJpJd22e8+GPh 5aaZ5V5qDRXeoLyqqP3cR9vUg969DNuoYBWHPTcMfj7V/DnG3FUuKcdKrG6px92C7R7+r3f3H9l8 GcLR4bwUKT+N+9N92+notkYGt+LNO0CBzvV51yvmHBGcfwD+I+/SvFtQ1fU/EruXuJre0c8wsSry c9z+P8q+08OOFI04vMsTHb4E+r/yX5ryPkPEniiUZLL8O7X+Jrov83+R514j0/UrNUngW6ubV3ET W+mb1kUEHDYHXkAZPrXZeF9OkBVr3zURQvl+eTlm9SrYOMcc4JI6YOT+uV2qlm92fj9OHLC6+77z 2PTbSMiOeZzO/GAMbVGOwHTrU93qGnaep+1yhGONsafefB4AHWuyjSdeUYR1crHl15+yi5PZf1/n 95oaZoeo+Iwk1+z6Houf9Xj/AEi4GOMZ+6P84PWvUtIs9E0e2Nvp6xW8S/efOXY46lu5r8T8XOOJ V75Ll8v3UH+9kv8Al5NdP8Me3Vq/RH7l4V8FRw0f7Vx0f3k17kX9iPe38z38kzN1vxnomixs00/n T/w2sXLsf6Djqf1rw3xH451TxAJYQfsmnucfZIWyD67j3+nAr1vBTwqWOlHM8fG8VrTg+rv8T8u3 dnm+LniN9SUstwUrSa9+S6J/ZXm+vY5D5CRvJyuBhu1Upd7MHBxnuB7/AP1q/q/HU1TjZr+ux/NO Gk5SbvoxI4kIf7zFx8wHbnNSeXCqj7zcdP8APetsHCFSF5rT8L9ia/NTnyxepYVXJHlKQcbS45I5 6j35x6fjWZquq/YfLhbc91N/yxj+dhn6d693A1Z16iUV7iWi8zy8RGFKNpaye7HQ6bLcRN9qWMK4 +ZJVzkdxj1qNbSCwiK2sMEfzc/ZgEwfU4/zxXhZzl+ItUqyk1G+i669f67Hq4DGUW4Qitbf5le40 O11cRfa7aG5WHgNMcgevHuR6Uo0iC1ULbxQptGBHbIFA/GubLcJWrxXLNwj07nZjK9Ok+XlUn5/l 8zhNf02SaRh+6hVsg5Ubvzrkl0aCJlGd2/8AhYfNn+tfp+Hxn1amqcbvzfX/AIc+Kr4T2k3NpLro att4XckGV0cHJyUAOK2E0EQ7ZBvxnBVRg12UswcXo+xy1MKmrtF60t2O+xnQJHuyGlA2t75rE8Ve Gf7PtYNbgQs9nIC3k52MuRn6967auZyp25Hq9dzljg43vJH0Z4M+zz6VYXMq25sZ0Dia4UHtnjI/ qK7ex1bw9vu7Wz1PSrWbT42luJrnUbex2gEcje6BjllAC5JyBySM+VU4px+Gm/Y15d9+3b7jSXDG CxUf31CL6bfnb1PSPDHiTS7iwhuNC+IvjuHVLWcBrKyvZ4bSSIxg5DiUsCHDKQF+YEEMMYPa6p4v u9SkXUNf1271C9aNIf7Q1y6eeeRUQIil5CWbCKqjJ4AA9K/rnw7y2rgcFHMszq2m43d7JRi1F2fm rH8eeKOLhjMfPKcto3jGdtLtyknJXWuzvf0PPNR+It1Z3WkXegXd/Z6zoF9aapp2t27zQXVldQSr LHPGqEEkEFSsg2kMQVPBH0La/t3ftfQQW5P7RfxSgaNcD/TRv474AAGen4DjvX4D4leItLNc0lXw VpU1FQ95XT5W7tdk7/Ox+++GfhxUyXKIYfHe7Uc3P3XZpSsrPu1b5Gg3/BRn9sqxVXj/AGifiaiA 42zXm4n3OQR6cH24rX03/gqP+29aBYov2i/iLICcLGs0UrfkV4H+cYr86n4hVKSbdGm/Ll3/ABP0 H/UCjUf8Wa8+b/gHe2X/AAU4/bakRftXx38aTOcDyLqO2mIIPr5fHOTWov8AwVE/bWtUkR/jp4gl JbPky2tpMxJ6g5QjjiudeJLatLCU3fsmv1FHw8guZrE1NPNO/wCBq2v/AAVH/bkR4XX416iJXP8A rJdKsmz26GPPv+VbUP8AwVS/bat8+Z8ZHlkLbme80yykdyTnkbOntxjoKKnHlKX/ADCRX/bz/rsa R4IqK9sTJr0R0th/wVf/AG8NUYJZ/EjTroZ6Noen8ehZgmB07mvT/C//AAVa/bK0DUIr/XfiB4S8 RrtYS6LLolo1s+QR85CheCfwwK/JvEnxBw2d4OtlFLCRlVqxaTu37NtWU79HHdLdtH6XwLwNVynE 0sxq4mUacGm1ovaJO/J5p7P1NC6/4K5/tWpJc3FlN8O7DT5SuyzHh2zEK4GOGcck9wufp1zb8P8A /BYD9rbVpX8OR6J4F8aahrTi3tLC28PLJLvYYCQrHhyT2AA9uvP4xTweJzPC0sBhqn7+jGF8Rb4X G3M+zckmnHazbZ+qe0oYCtVxlen+6qOVqN/ivey8lF2afkfsB+x7f/tM674W1nxN+0vb6FpGra7H byaV4dtLRbW+tLYfaNzXQUlVd2YMIz8yc78E7V+rXRWUKwYMHB6YHKNzxX2uZ1KVXESdGPLF2036 a/ifMYKE6dJRqu8l1/r7j5B+IljG37Y/7I8yqMw6J43A2jp+70pe3sa9N+PUmzw/4HEgb5/HHhwe vH9rW+fwry4Lqu59NhJc1XBX6W/9OyZ7FrEAnsLuHYCZsrhgOeD/AFxVRbOBt/7lZPkHUA8/ia1U b6pHhbooXfh3SLpHE+m2suG5EqKTjHTn/PNeD+PvgF8MvEVkbibwP4cS/wDOim+3Q2iJPlWBGJAA w7jOaVSinfSxrTrODTL2k/A7w7pFksHhfVfF3hN2jYGTwzq1zZORI5ZgdjjcN3I3Zx270a38NvHd 9Z6V5PxZ8QTHQ2Mlo+uaToupzQsY2Rv3tzaPL86OyklycMQCM1dPmpK0X+pnKUXe6Wv+R8DWvwI+ JPjv4O/Dnxrrnx01jxBq3jbULFb+x8T+EvCUtnMZ78Q5Ag0yCZVWNmwolGS2GLDivQZv2L7N5VTx h4G+HvxHawiiktNX0N7rwtdwTiWR3zETdwsDlCNqxjKnIYHIzlQjUaUo7ndmNOFLmilpzyS1dtLb 9evc4Xx1+y3pWmzaemk6F8YbIalM8OLU6NcWVogUu2Vingdg20Rj91KRn7oqlrX7KXge6urJIm1j TtQvbRWa31jwvqNojPGufnnshPDHyo3CRgzHPynqeKeT0GpRg7Sez7Wd/wAdTlhjJwlGW9unfQ+U fFeleBvC+napFeQy6Hc6a1taXdlaeHdaCWVxNax3As3vJLaO0WZUmjJVZWJyPQCofCFh4V1m10xt Is5r6SQN+4WIygbhyd4wQASORnr3r4DiDKqmXSu5p8yeuz1ufZZbjKeJlyuPvLY9BtPhnDeeRMr2 2kwJxGIw0o3cHaGxj7inAJPTGa4fxVpqeFtUSObVr65u3j2paWMYaBQPuEIUyT36nOc89vkaDvPr q9/J9T3KlCMF7trrX5n4kTfDH9k/XNNfTf8Ahc1s2nXKlPsV9ISrKBnBHYdK5lf2O/2Rr+d5LT4n +FowQfmSZ4Mjn+7+n19q/o2OX1I35amp+LRxbpxa5Lamb4j/AGJvgfBo95qXg3xd4K8ZazbAPH4Z vPEEmkLdZ6xifZIsbY+7uUKSQCyjJHgln+z9+ynqurW/h7x3N4z+Bviu7mRPsnju4F3pEmfvPBqN sWjmQHGBt3EE8ZHPVTw1WUeRS99bX2a/RkQxKTd1od34w/YO/Zx8LaPDq2ofGGzj0aR/LTWLaZRa k/whZJtjMxIbjbwFJye3B+Iv2GvgdoXhe28Yr8WG1fR5X8uOPw5eQXU92wAOEwCvII+b7vPevayD IMVmmNo0JW5G1ztbxitZP5K/zsefnOcwyzC1K9veStFd5PSK+bsYl5dQQWemeHfD1lFoXhjRV8qz 0e0yVjH8TsTy8jHlnOSSTzVVU8rbvf8AMjP1xX6rxRnNKVZybUYKygu0YaRX3L7z4DIcsnSpKL96 bd5vvKWsn9/+Q7eVAC4k6j/69VntwZF3O3z9sdP8mvhMRg6fEVVTpS23/r5H2GGxM8pptTXoSxx+ UqgEg4B471aJkZR84DZBGP8APvXtV8qhClGlT2X426nlU8ZLmc57/kKEco2CDz1YdOKbhm2jBRjk YUDmuX6j7KS5UdP1lz3Y750yu5Xc9WUf5/lTSszZBVVB7NjJ78muLE1o0otr+tDpo0pSaZ0vh/wx e65P+6X7Pbq2XvXXCr7DH3jX0BoGjafoVsLawjKt/HeSAea/19B7V/OHi9xrLkeWYeX/AF8a/CP+ f3H9AeFHCMYyWZV1qvgT+7m/y+82vtEcW5y21I8FpXOFXP8Ak8V5j4p+IccDNYaQJLqc8MU6A99x H/oP5mvyDg/hqXEGMhTekVrJ9lp+J+qcWcRQ4fwcqi1lLSK7s838i6vJGvNTma5umOdh+6vXgfp6 Vowh93RsdCce/wD+qv6JdSCiqVNcsYaJeSP5z55VeatWfNOTu/U1FulWA26RRj5stI+f6UiylJFk iOGzkbfu8ZqOfm+EzjHkTualvfa9qcv2TSo98inDXWMRJ+PPp0/nXfeHvBsVtOl9qt2LnUuokucs VPoi+2ev6CvB4x4r/wBWqMsPSf7+UdbbwT/Jtfdc+r4P4Rjn9VYisv3UGv8At9p/lf7zv5UhsI7i XVLmBbeJeXnY4AHf1z2xivMfEXj8SLJYaJHGkPQ3sqYYj1UHoPrk+wr878N+A6vG2JVWaaoU2nJ9 3/KvXq+i82foHHvGtPhDCunTadeStFdl/M/Tou55dcXE88jSySNMz8l5DuP51Q84RMVMi565UHr6 V/alGnSyWjFxSVrJLtZW0XlY/kWvUq5nVbm23Jttvr1bYbs4+fI65xzntU6yMoTAbAH3se/rTwih jZNSld6elnuaVIywy5ktH37ii4aPGWQLk9+T7/59KiaW6nYdMcZxjA/OvVnKPLGjFXV+nl3PPjCU W6knZ26/oXG3+XIXvGjDIygx4DZPG7J5yOv4CvNka48JXGpauJtS19boDenBlQhxgj1UKTkZHTOe MH16+YUsDFqWnpvtp+NkcVLCTrSutb/dvr+B2o1S9kiE5hkFuZWVZG5RiOoBHBHQ8HBznoasxk3W PPlC7edikBT/AIV8zj8wq4yvLB1VyKLs++n+Z7mDwdPDUliIPmcldfmbEEaDBUpsX+FW4JqK/OUD IrAxk8KMLj14r1oypwpqELbtaeWhxxpyc+Z/1c5PWoDLF5qN8+M7ivtXDRxRxT5+cMx+83Jrvw2I tFRjq9jGvSvL3tEdvbWvneWwG/1/KuwtNG82JpLmZI1J/wBUB1/E8/hTk23r0MVGKT6s5+50T7U0 9iCtvcQfNFcOSAy57Dv+NcLP4os9I1KPw34k0x9et0WZnXTnJmcGNyirgja5fHynrwDXq0KTxjdO mtbN/cjgqP2b5pbaI1dM+LyeBvD9g+u+DUu/Deo2txHZv55e4W6Q5QdAnl7SucqWG4sCdu2vDrGz 8Z+MdQsdYs7JdS013S3kisYod0ZKbwh2oCud7EnB57jHHBg8xwfEuT4V29lJTk5TvuvaQil5WlF/ J+bKpUMZlGPxNTn54SilGNvhahU5mvVSXz9EfY/g3Stc8O2FtA5jiuZANxYq7Rj88fz57V2RlvZZ fNaV5ZFz+9uZAxAz2xwB7D8q+6438Taue01gMO+WhBJf4/N+XZfefHcL+H1DKK8sxqxUq9R32+Bd l+rLbXUkKK5kiMzfLtAGQPr+VZN1q80eRvDy+xPHPT16D1r8QzDMqdFcsXqv+CfrGDy+VVpyW/8A w5hS6hLcN/pAeVUHCk4Ue1bukaRd6+5SwkTTtgybmQiNAeoHuP1r57C5pBzvNNv9EericC1G0Nv1 NjwXrd1Nqvi7RNWtZNQh8NzJBBrmhyB7a9kKKzKcj7yAgHk4OR2r0OO21S5wkNksaEnbE64Pr6ZP T9a7qteDk3BWSOOnRbjaWvf7jrdL8D+Kr5BNezwaJZM3/HxdExlgPQH5mOPQfjXS2vhzTLGSKG1t JfEepOxw2oMILfA7rGMu59jXweb8TyxUpUcC7JfFU6R78vdrvsj7PK8lhhFGeLV29Yw6vTTm7J9u pd8T2U8ei3lo+vW+hapKpaK3tohIyEcooiUkAbsA7yO9bHw/8H/Fj4nX8GhfCn4eeIPFet5C7rS1 fUJlznBO1Qkajk5YAAAnIwa+byzKnjotUpOFO/vTfxT76vX5/ce7jsxjguX2iU6iTtFfDD18/L7z 9TPgl/wR4+LHja60/X/2g/Hdr4G0+fDP4d8PumpawR1aMt/x7QHn7wM2P7tfs98B/wBk74Gfs82M Efw68FWcGsNABN4w1v8A0zV7gmNt2Z2GUU9dkexf9mvpY1aWEpLDYePLFfez561TEzdavK8n9yPp G0KGdmByrQphu5G6TH061WkXZE21T8mPun/ZI/A1xxSWp02SR8lfEdnb9sT9lGJZFXyvD3jic8cs MaIv82H5V6P8dVnk0/4dRAo3n+NtAIVRyMahGxOSeeFP5ZqZRvqe9Sko1MGuy/8Acsz2W7d/JuQ7 IzDkiMEEHI7Z+lSwqjMq7Bk7QTjOQTito3TseDKXusim5WQgAkEjHbp0rIvFD2YBXIC5IPPbvTeq ZV7LUZp5JhViMsVA7c8mrEgIgIAG4DOCOlVDSJE9bnxn8N5jefsy/s5SpI0Rvb3QJt0a7iQb1JO/ qB19819hxqjPzk44LlSp6H1pKXNK3T9DrzL3G0/55/8Atpka5aRS/Y2eNf8AR339PbFXVgjCkFE2 5xluw/KtLanl62Vz8x/2sdNE/gH4xmAaWrz/ABF0vMWrSpDE4GgacpG5vlBwAckjp1GK/PTS/Eb6 dHaRafffatU0/wDdvBpU+2HknIXb8r/KcBu/T/aPznEMKUfZzrK67bnoxr1KE37N6yUV/wCSROo1 P4nJp2iXKS6Rq/mKFb7KDJHG7DAA+X5lJzjjr7Vgaz468RW15AZo0vYriUlYLsmUrtP90KTt6DJ9 /TNfnNeNOnzVF1etum7Po5517JqLT2f6f5H8ZGn31rHp2qSas+r292qZtP7ORXiZhnPmFmBUdPuh u/FchD4u1JWKxanNF7IWH8hX7zTk27HwygpddjY07xjqn2qCNteurFJWCvdlpGVBnrwMn6V7pbfE f4W6RAlpdv41+K96QyvZa5MNJ0puynyoy8rEZ3f6wdhgjOe6nypXbd+xz1E3pH7z2Ox8S6zpPhSx guvBut+ErbUWF3pWk6bcCezjBDbUeHPnLG+4vsc4PJGATl0Gu+PvEt62peMpLJtsQjtrCxhS0jhH yhmEEOIkLYy2ASSR0CgV99gKeOyi9BQ9k3Zzk0uZxdrx9HbXqtT5HE18LmP72b9qldRSukpK65tO zenR6W0LoWRfmYh5fUDkY+vWnhEYBnVi2cMSSw6fyrzcyoRzCTnK6Vv1N8HUeFiktyTywAVUFkzy AabiMOVCMvPLDnj6162X06eCw6Ueu/c5MZOWIqOTWxMsG1W+fKMTkDINTrEQVzux7ZxXdCrTaeu1 /mcXLKNk0IyBCHLSDHAXPFEjDgf3j/COtfI5zm7jelB+rPbwOA5rVJbdiKODc4BPHIxnI/Xiu+0L wY9xtu9TLQ23VbY8SP6Z9Afz+lfl/E3EX9gYVzk/flpGPn39F/wD9A4YyF57iFC1oLWT8u3qz12B rLTbSO3hRQ6gAQxDp/hWddaklpA97qN2La2TkbeSxH8Kjufev5uhSq5lWcpJynN/Nts/o6pXp5fS UV7sKa17Kx5tq3ibU9fJgszJYaVGcZQYZvU+uT659uBxWZa2UKIFjBQq3DORub3Jr9qyfKKeQYf2 ENZy1k/PsfiOeZvPPsR7Zv3IfCvLv6s0ZYYrdVZrgu7AfIFwR6jrVWS6duMgLnoD/M16Enyu3U8y Muf3pdf+CR/bNhYEs0jHAiQfMT6Cuj0zQb++cXGos8NsuGWxThm929B/niuHMs1hklD27XvfZT79 7dl/XQ9HJ8plnVdUUmobyfZdvX/M9IS+MUENnEsFtaQj5UgQKB/ifUn9a5vVfG0VgzQ28rT3AyMo c7eO5/oK/LcrySrxJi2ptycm5Tk9Wrvd/oj9azbO6XDWD9xL3Vyxiuvb/g+XmcDfeJLzUjvnklmK nAWQ4Veew7dvyrHN2DuLAb8dD6f5Ff0tlGJp5Jh44bCQ5YxW3d935n835tTqZ1ipYjESu5a+nZL0 FWd2RQsZTHt/9fipIo3uTII0JZTyxBwPpXdGvVxjSbPLlQhh1zJafl/TLZUwBVaRZCe0Y6VFG0eQ X3OGOcDpmj2rpTUb3tvb8i3R54N7lySO3QLIxKKxBCgbcH0qJ2gZSFbax4J7t7+1fYUs1p4RRhe1 ltvv0PAq4OVW7avr/mMIiVV2qzgDBc4H4c/Sqcm9gBHGFU8Fm7/Q9q4MdmMZR5aUXfo31vv/AF5H ZhMFKTcpvRfmFnLd2yXEESrd6XOQ0mmN8qMwHDo3VHAPBAwckEEE1q/2eZ4jd6KZNRthjzIsYmtG PG2UDtngOPlPHIJwProQfFOWuvTjfE4de+utSn0n5yjs+ttT5yrUjw9jvZ1H+4rv3e0J/wAvlGXT s9Oohe3s1LXUqST9rW3YEj/ePIH05P0qncXzzoQIRDF0CLwMc88ck57mvjKuYPCXha8ra26f1/XU +upYX2rU7u35+f37FEXe4eUxABG35xmsz7HHLKojAZgfu4x7Vvgs6q+7T6X27+ZGKy2mry28zrfD 7yXlybZBEn2fgoFDN+NegKrXMSraGFo4MgyAgAEHB3N0AGDnuACTivq51ZzcYT0v/lf7rnge5Dml f/gnnPiXxT4WTxDoPhCy1BNX8XT3Fu82oaTPEbLTEecK8chOd0m04ZGwBkcAjFeaazP4g8Q6pcX+ neItH8S2/hO8W1sLbSZFt7RZ3w6stxEyltifIGdyWZTgkAAWsXUqzp0qE3B8zXNrezStb/wJfqUq dPCQlUrw500vdWlrPV372T/4co+MNM8U+Ofjroln8VPFt54gHiKwh1KW0mkkdJpIrcR/ZgVIwyxR KN452r6nNfQWm+FPCGh3VjqOk2EGjXMFu8B+xu+xwZGO4rnG/BVc+iDjqW4sPj6eSvE4Si17NN2u l5artdty06mmJwrx3sa1nGTs7K+m/wCW2uptyXlqrMVS5eQ4AIAX2z78+1Pj1Ce4lS3gjjikbjy4 FLM3se2f8OlfJ4nO3fkj1PWpYHrJHQWvhXUb5lnvp1s4pP7jb5WHp6L/AJ4rrLHwfoiY82Fm2HrK Qxb346c1wUsG6suar1NamJjFWhobieHNFLBBp8DkcBlQcH1z61b1WzGn6ZFFotgl74g1OVLPTtPU nZNcy/JGGz/CDl2PGFRjnivXwGBjia9KlTSTm4xXrJpfqceKxLw1GdSbdopv7tWei+FvhvpvhfS9 O0ee+GdPXEkkB33N3KzF5ZnPRWkkZ25JxuxjArtLSKLTX82Gz0nSLWEgnULyQTzEj1dwFXI7AAjP U1+ccV8Rxz2tVeHbpYXmeu0pq+iXVLZd5dD7rIeH/wCx6dP2i9piGldbqDtq30b/AARl3mr+HYi7 2sl9rtw5xIYGYxOw/vSODkHnlR0719I/Az9jn9pn9oaWGbwT4Gk8IeDL1l3eM/EQfTtOdSdoKTSD zboAqQREJMYw23IrkwOUfW4Krio+zpK3LT72197/AOR27nXjM0eGk4YZ89V/FN7Lvy/5/cfqn+zD /wAEmfCng7XdX139oK58P/FG03RNpGmeH7m6tLYfu1d/tUZRHZgxAXExRlzuT5sL+tfhnwd4R8B2 ug+HfBXhnw/4U0a1O5dK8N2cVnAGMMwL7UAG48ZJ5PcmvXxWM+sWjFWirWR52Hw0aLbvd93/AF3O ytGG2zLE4YEgdc9qqxArhMHb5KjAP/TP/GuJLU0nGyJNPZPPK5BOxO/qz46mqF02UmjztHA5HUgH Ptx/SqvbRF7aHyj8QVx+15+zLOQP9F8I+NnMmM4zJoAPH4j/ABr0T44z7YPhIrbgZfHOhrn+If6S Tz+VTN3X9dz2aF/aYT5f+nJHslzJhLh2wEx3Gcc96dBJtklUnJGz09TWkFu2eM9VZEe8hpsJ8vUc +w7flVB9rKgP3MY2ngfzpvXQW5Fayh7eORUMauiuEkXay5Geff2qRm3IoXdux2OMf/XqoxsiKml2 fHnwlCn9m39l1ByrLoDp2yNquMfgK+tra5LXN4jqiLbldrA7icrk8Y46+9VBNu7/AK3O7OFapUXa pP8AQi1BVkjIIJ3KeefanNIGQjAC9q0bszyN9bHx/wCOPBvhrx9bfGDw/wCKtNTV9LTxlbTfZGlk i2uvh7TgGDIysDhj3715pp3wC+F+lxgad4M0uyC42RR3FzIR3xy5PbgZxXyPEL9rNQltb07nvQo8 1pp2so/+kR/M6D/hVvgiSJjN4V0uZGYnbKGkGf72GbGT2+lV/DXwz8EjSdNuW8F+GJLieBHkkudN SV2YqOWZgckA/wD66+bpYWlQhypaNr8maSwMask5I/zlSNAk0G9gknkg1JA+2L7yvwTXiC2kkVwp mglRP7zKQOtfsdOSlLQ+Xpwsnc1HNuqAAZZ+FHcn0FfX3w0+FOneAobHxl8QbC3v/F0yrLpnge9T K2R6rcXSn/lrwCsJGBnL84Wv0fgTJo4yvPH1l+7w9pa/anryR89VdrsrdT47i7NZYSisLSf7yveK t0j9qXlZOy82j0qe8vtR1C61bU5DfandsWkupMttJz0J5qzHLJkK5ZzjChR19xW/GGNqTipylfme r69zi4dwkIv2cY25VZIat8ymMbG2hiee+OxolvPMQhVZH4yQa+Bq5/UqU3Bq3ax9XSypKSle9twF 66oEJjZTwHAyR9asR3aHOVLMf7w9/wCddOD4mj7HlqwvJKxnWyaSqXhOyJZC0m7dIFDAfKp3DFRe dKHCh5BzjC9DXhVcdWpz5nOyfRPoejHCUrcqje19+thdjtsUMdw/jJ4q7b2d5eSmG1jad2wOgOPz 6V51XEuhCdWb0Wrv5HVh8MsRKNOnHVtfeemaJ4di05oZ7t2mu1PRBtSP6epru4JlUCX+z42XoJbl 3Zm47AEfy71+B8T5rPO67qSlaO0Vpt/wd/8Ahj9/4bymGQYf2ajzSbvL1tr8kc7rfiWx0RmjKR3O ov8AMumQAnZ7yEdMf3f5d/Obu5vNVnN9rE3mtn5LOM7VQegxxivquE8leBjHGVNZSXursusvn08j 47jDPXjKjwVH4U/ea2b7fLr5kymW4cFQUjX0GFUentUkjpAP3a+a/XzMfKPp/jX1cpNO7PlJJLRl fLfeLjcpzlgeBj/9f5Vc0+zv9TdksolWL+O8lzsH0zyT7VlVnChTdWq7Rjv+lvMqhSnjakaVJXlL 8PXyPVPD/hyy0sNIq/abmQAme4IVjz0Udvr+tX9Q1XTdL8xb8yW+Djy0G4sfXjlv0HNfkmPxWI4r xijTWr0jHsun+b8z9kweBw3CmBvJ2trKXdv+rJeh5xrfipr9TDbM1tDggLD/ABd/mPGOPT9a4h22 5YqMg/cY1+95HkFHh7DqlB80n8Uu78vLt5H4JnWfVc/xDqy0ivhXZf5vf8NhEw+4RqAf74HJ/wAm rMUSPkRqXl4zwSV/z+PWvVoRdSS/A8yrVsuZ62/zNaDS2ij3zndjkqSAMdOoNRvPCN6pHLEn3Qis Qo/PqTivWxGH/s2KjO93fbomjz6NZ4y7jsn16lURFg2Gxj14z1/pmiO4cLsAyw4Dd/TFeV7Vwu31 vY7qnvOz1WhHuZjhUeZgctsG4AE+tQPOGyuDsHVVyorSMpJXfUz5LyWui6f5iLclcLwFH3d3IFPj EsmApeQuRtijyWz6ADOa7KMpVWlr/X9bEzSpRen9amjCn2VyJZ3aQj/jysiGY/Vui/qeOQKsQNPH ew3UGo2elXUQ+QWx3sQeCGJzvBGcg5HbFfWcPYzEZJiI1cM/eg7y6pLrHzvtL/hz5/OMHRzejKnW XuyVkut/5vk9joraw0PxLcQwkR6Fq/O23jwlpfnP/LItgo/fy24ODtPRaoa9pUWmI0Mhkt2hYq9n 5eJdwOCGJGVP19K+n4s4Zw1GKzPBv9xW1S35Jfah8ns/5WeDw1nuIqTeX4tXq0dL/wA8X8M/8/P1 OBjaO7vorNFDzXUgjjid8MxJ4xXp+qeCJ/D1toc2vWmt6DZ3F7DbSanaafNdBd21pNhOyOR0iO/Z 5ij7oLJuBr4jJVBV4zqPkTuk299D7nNouVO0E3tsm/M3PF3wusv7Bur3SIvEXinSr+V45J/BV1JF cbxB5mJw8cdxbxqA3mAwvGcbUkc7XPket+HfCGk6TbaV+zrpHjDRtU8RLC+r6zrN8vlxKJDthjPm eZK6yMAW8sEFVZQC3H20cljjpQxFafNGCi3Fbvfl+Wl3a90vM+SxmJ+rwnhlBNTekumjX4306WZx 3hr4R6Tpd19v1fWbu81WOQSyPGGjtVEX76VXbqx2xtySvbivXdPtFg8PyaHLo2nHSpCb03Ohxg2r /aHypx96NgvlKeSpbBDbjheLOcZ7bDRxNNcvvyXnp7OSf4E4WKhiVh5Nu0VLy+1Fr/ybQ8M+MNxd 6DdfDvxjK8puvDWpGCW4Y4kuoXCsWPuVR0Yc8ndxuwPqM+HtX+w2Xnabd28t+5kiSdDD5ysAFZS+ NwJBxjr268/N49PFYj91Dl9rFyUX0tuvJc0Xbyse7h+WhRi5zTdN2b6eX4SV/O50c/w88U6PYvqf iHw54m03SoztYzWM0MY5+6zuo5zx9eO1Ng1nRtPhH2O1aMg8rIjbjzjkkY6VlhMDHB2qVZJS7NpW /EeJxbrycKafL5Ju9jZ0vxFZXBkW5u0tFjXcqyGUiQ/3BsRufrgVJ/wlN1N50dtbQY3/AC+Yxdm9 8A9/T+VctXMouo6bkrJXvur9lbrb5CWClycyi23020t/mbOk6v4gvWnWDTWunALnyQAFUAdsFv5d RXrHg7wr8W/FdlN4x0n4d+L/ABJY2FxcaZp8fhzS5jFbSIqC7uXZI2AYeZHbjdn703IyM3lFFV69 XHzqtxw1Kc4RtZc7Xs4OTbu+Wc1JK1rx8iszxPsqFPBwprmrzjFybu+VPnnFK2ilCLi3vqj0r4c/ sz/td/Fh9PuPAvwd8eazpmrpKbbxDdW5tdMwjsjj7RMUt1YFWXDMCSjYHBA+uvhH/wAEnP2r/iVr rRfE77L8JfDulzCOXU/Et5aalPcYl8txb21q77tuFYNI8SsrKyM4NfJYKlgMPNVpQdSUVopP3U7b qKt17t6H0laWMqU3h4yVNP4ml7z8m23fTppqftX+zZ/wT3+AvwHgkvJ9OX4meMbOeFY/F3jqytZm tHVIvmtYdhWAkysSxLvk4L7QFr7c1i7ttB0y71K71K4tbLTo/MkmjEY2ASsAF3LjIPIHPJxyMCod SpmVZRWrk7Jer0NbU8BTcpPSKu36atnhvhr9oYWYWyvtNtbq0TG0you8YG0fvFAbO0DvXq+lfEDw N4knsbqPUbvRbm0OVgbE0Z+R0Cn+IfeJ7n3r+5eMPoq0aWBpfUJNVYRV30lJLVvtd32P4j4P+lPP EY2qsfD93KT5ejjG+iXeyO4tY1uFtfsl3HewqGBms33beM+xA+oqpbL5YKMZECwA4ZiTnZk+/wCF fxrxJwpjuFMQ6GNpuLT36P0Z/Y2QcS4PifDqvg6ikn23XqQ2eDcB3aTLRoPkkIxhpDjg+/Wq8hQM +PMBTkAE56Hnnr9PavnlLoe613PlP4iolz+1j+znbyPKiz+D/G8ReGR4mGZdABAKnI4zyDwR1zXc /Hlljg+D0m4t/wAV7oI+Ynn/AEo4/n/Ko+K6Xke5TV54NeS/9OzPX9TSVXkmN1MkAYAwYz0bOc56 4wMf7NX05mnBLD5VGNxz3pxu3Y8T4SPKfvFG59px09vWs24ZU+yYTBaQDLAY6VrLS4R3sh6kBgCo IQDDMPcjv7fzpkjKsYO1D35z/SrT5XuQ9j45+FUqQ/s7fsqoyAf8gGMKMHOIDj+Qr6yscJJfS5LG 4dWAA6fu1HHrUdV/Xc9HOY8tSol0qVPzQl9KxifHRc8LgbvpSrLtQHLBiM+mOP51pL3WeMo8iPlj V/Ftr4Zn+MWoz6Zeamj+MoIRb2biNgf+Eb0xt5JB4GPQ9a830z496O920Uvg7xLaWqx/6wXMZViC wACnHQDpj+Ic8Gvnc4nRhVSqJt26dj26VKpON6bSVo7/AOCJ1ekfGzwbqeppbavbeKvDenMSJNWa JLnyQFJB8uIGRyWGABz8w6A1l3nxN8P6ZBp2n+BR4q8X2Wn28O7XbqK50eNmC4dFhliMhxzksBkn PIANeQquD5JNt6dOr/q5Sw+J51FNW79D/PW8MTaJ4S0nUE0XWPD99qd5cwtDqepZWa3iD/vANxK7 SvBGQSAeua8f1vSpb661GfTITPZfa5TDZi5jklMeSQ4+bPy8fe6/nX6XCn7yUe6/JfqfNVKzl70z 3n4AeEvtFlqnim+tNY8V6v4NmjEOl3koSy0iNiCLhPNJVrgkEIoBCld2GJUr9g6H8LvgfrVvFrnj P4r+ObPWtXdpp7DT9JhvFtFK5WPc9wrOwbIPCjjIJ6V+15lV/sbJMHTw1NylO835t7v0urLyXmfl 9KLzHM8VOrNL2dopdtE0vne79UuhqyeA/wBn+1ic2/xL8XzuhZVW50hUwAcLnEhzng5HQHvivPvE cHgnSdP0w6JqGra7qEyD7REsa28cDZYEBm+8vK4I98gcV8Rh+IY4/HU6WNjyU1e736P/AIB9HVy2 VHDVJ4Z3n08zmbfVtADBbjw/rl0isufLvYIzt6NjMZ5z+XvV4ap4GYIZ/BXi5WPWWPVbbHToAbb1 9/zr7LHZNw5mKcoYhwtre3Rf8Gx89hMzznBu0qKlfz+79SXzfh1IyFPCvjMfIdy/2raHB+v2f61k 3P8Awij7jaad4rtWxj95fW0gHr0jHt6dK+Or5JkkXdYxvt7p9NTzPNHo8OvvKyR6cI1GNQDIMAyF Dk5+vP8A9aoZVi8xTCZtoyB50YbJ554ccV539lZJdt4qb/7dRpUx+ZrahFW82aEL2O9ftVtclEIz Hassbt9CSQCD7GvRtI8XeB9Jt0g/4RXxI5wS80OpQRMx/GFj+p/CvL4j4eyXNaapU8XUjH7XurV9 vTc9nh/iHMcmqyq1MPCT2Wr08zcj+JngaByH8CeLL9/4R/bNsAvTBA+zfXOavw/EDwNqks1pdaV4 u8JxFQP7Zjvra/lTLrkbPIQZCFjnPUAcZ4+GreF+SRoyrrFVJuPwxaSTa6Psm9/I+vfifmtWapLD QipaOV5XS7q/VLYyhZ/BWyilng8SeMbi5bBIubJGLnbz82em/wBuR1wa5HxBfeEIL6NPDX9uavbr 80l3rAjtV68KFUknt6Y9+teplmBoYvFQWLk4U7NvltfayS+f4HhYrGV8PRcsNHmn5317t/1uY8vi O4dmT7LBFAeFjgO0kcjr+XOPX14dDrmmqytNo17MEblYbxFP0GYj3+tfYPLuHK9RLnq/+So+eePz qlFvlpr7/I6CDxB4RZknuPBOu3Dbt3kSa5CkJwe6raZ/DdXRr8TtFtkaODwS0Ig4jKasjpkknO37 MOOnft715fEPCvDubJRVasox2Stq+/8Al2R63D/FOcZRKVT2VNyl1d9FvYoXHxLuLgXHlaELWUj5 JmvFYr9AYj/L864a51GS7kaS4QzSyHmWW5LFvr8lcmR8NcN8Oc0qSqSk1a7a0t0+Z0Z3xHnfEXLG rKEY72Sau77kUdzEhw2nrIfQTEYz/wAB7Vr6Vd6BFqVu2u6Rc3GlZPnR6bdbbhh7FkKjnuQceh7+ /KvlFpOCndJ2V+vT/M8GhQzCMknKPnp06/PojsX1X4Wyc2vh7xsrJgfvNStin3QCMfZxwWyep44y SMnk/wC1oldvs2mpbKNxCLMWYZ4GTtAJHHOB9PTysnzGlQcpYla/Zt08zux2Bqz5VSdk73v1/wCC UbjV7eCGWW6dLeKEbne5uAiAdcnIA964a++LHgmycxy+KNHdAVx9kk+1DBHfygeeufTvXr/XMFXb lKM2/VHnrD4qOkJRSXkcBqv7SnhCyjaCytb29lwGXyLcop5wRudumPbtTz8ebaC100r4YaeK/iSb zVf51LEfKTnnB+n4VVWWBlZunJ6W3/Et4bErRSS17EM37RQllbTT4WFkY8EoCV3fXnOPf3qX/heT efaXF74Ngew2lgkEj25lQZXIbBGN4OTg/dIyOyxNfBzVo02tElrt1Lo4WvF80prV66HQeGfHzeL4 9Tk0nwjdvLpCbnhe+/dfMkhEjkRfKDII41GQGeVF3DdyzW/H/izw/MdN1PwhHozsSmJL6MCUrjcd 2DuGcc5x6V5eT5nh8FOdOsrz2jZ2a2bfr2O7OcvqxjQknyxqPS6+Jrm0+XK38je8Ca3aeO5Nd0fX 9Tt/C0Ol6PqOppPFcQOt1JbWck0Vucspy7pt687sAZxXW+BpYvElmk8HiP4c2cNs5idtS1RLNIgO PnHlSqrdOM888jnH0eBxmGrRdNU2ku8rXfn9x4eOw1bBNVJNyb7Rvpseg2nhzXNSmazgvPCOupfR yG3fw5rdlcRSKhTIdzbqsZxux1yVIx3HTeIofDqWR0/xD4p0+70dJ4orHVNJ1S31DxFaLsYYuAsI img3BhtBLINmD1B+84fz/AuMspx6UKFZr3ua6jNfDJeT2fl6Hw2c4HFVKkMfgU5VqV/d5WuaL+KL +667Oxp3Xw00Lwnq2ma54c8VnxDFeeRJY+PNWtneCNsI0hEUDphlc4IO5v3a5GGYH7f1vxX4c1n4 X+Bteuvhlp3jjWNb8UarGb/WLnyJrNpLTRpZGj8qMqVHnZAfkbcZNfhnFOMw+S5jUwmObhUoyqRa jd8sFUi6UlfT31K91ukj+yc34Kx2N4Jy/Osr5Z0MQsPKE5JKTqzoz+s05W1tSnSULPrd9T4Y0uLx rpGu3tvr91q/9gX0MbWUtj+4sobmW0SXy/lUAnZIWAAwQAr7tpA9i0Lwlpes6DpWs+ItAi1u3nsI bu4v7JrhZYt99JE++ESlycIFDIXxlcRDDPX3NTPa1GboKyVGbhCS8lzWl5vmv5fM/nOlgY29pO79 rFSlHzd02v8AwFepR+I3hH4fyaXpFn4VtNOi1TV9TtrW21A3M97ZxW76epugAZAGbLsTkAq+RuAU g9d+zp4XuY/CXie+1bwr4U1aQa3rds0Pi0fZ7mK3jsIypR3jceVhwyR7VXliGwwx343NMTjMLQp1 rqUpVFeEddOVapb38uyODCZTRw9fFVqVpRhGn8T25nLZ9H/mL+04nwx8R/Ab4gfDbSbGw0LxXe6f bXGl6HdXlsjLdQXcM2EltpWglHkrNEEnZXTe7Ancgr0r4R/tVfCP4e/snfBqyuPEGp+Nv2h9FtJL DxB4c8RR4i0+SLVo4LbZdWqvDNbHSXnZCf3iyoA5YMHHXl/g9n+c1VUw65XUlzOVR7xceV2Td0tE 9FuvM+azDizLsroz9nP3lNSaSbV0krdley+Z9v8AwI+M/wAI/wBr7XPH3wegk1DSZNTt5b22/t6G OVbtWkl8yPYrbdyq4ddrnIjkOQUNacf/AASR8LWXhLxxDP8AFK+8SeLdT06WPRL6703+z7XTLzym EUzrHM5lXzSpIbIwCADX7HD6MPtacJTxqcmnflV1dNq1/Jo/O8T4/wAcvq1aTwkk9LNuzs+rXp+R +Sug/D+2svAHxC8AeMfD2oWfxvi1g2dl8kjvaCNrVJID5ef3vmR3QChWOGTn5uPYotJ0O0uvgWui +HUn1bwNYwQ+KJPsgW3u3WyjguHO4BpmMnmuCy9cE4NfxtjsbSy+tUw0otTpycZafai9V+Fj+uaW VyrQhWptOE1zLXeLjo/xR9L/AAX+Jb+Df2gPjF4g8E6GJbz4p6NBpHhSzEcbK1+8cCm4eGMsyxRK s1w+Qu4RlRy4z+1fgb4f6d8Kvg7pXguxzdTadbvJd38p3TXdy7wNNPI3BkdnJJY8nvmvu8DVjRyS UlvXqtf9u0lf7nKovnE/OM1oy/tWFOW1Gkn5c03b70oP5S8zyf4NftQ+I/gf4f8A2Avg5ofhDQ9e 0z9pPWfEGn32s6reTW8+lpaajKfMiRI2EjkXLcMQMxgZAJZf2bWbdJKoA+SdAQOB1gr88p0+SlCX e/5s/Uc4ppYmpJPdsz7C4iH9pSO6JHHPETK2Ao/dWpyc/Wvgf9sr9ozwVomh+H/h/wCHfHnhfUvF 2par/wATPwzpeoQXF7a2kKTyF5oVYvGvnta8sB94Y6iv0bwjyz+1+KMqw8ldSxFK/oppv8j8x8U8 weVcN5piI6OGHqtevs3b8T4UsvjlBbSCM3QQ5xkt1P8AjXpWg/G+xnljXztnA/f7j6/z/wA/T/bi pld46roz/E3+0LyaT6r+v67nv3hj4+XVk6mz1V9qHpIQcEdsj3r6T8NftNQXPkxa/ZWupooCmacn f0xjepDdO2fSvynjnwpwHF+HdOvTTv5benY/TOBfFrMeCcSpUajsn8tO/c9m0Hx94D1p0Nlqr6fc lQPKvCGjzz3XDDlu4NdPJbEoZ7eW3vYmAInsHEqnAPJxyBz3Ar/OHxP8CsfwRUnWoRdSivvXr3P9 JfC/xxy7jyEaVWSp1mur0k/L/I+TfHSLJ+1x+zRIOsXhLxsxYnoPO8Pfh6V037QJBtvg0N45+IGg kbTg5F0Tkn0/wr8A8mrH9JUNKmEv1S/9OSPb7yZXjuQDyHx6DhsYHvUqTNvnPz7SB0xx96mlrb0P E1USPzsF+QvzY69eAef0rPLBkiDEME2sMjABqp6aFbbB57ibaSx4xg9uTVdpnWNPmwQPvHjFVFqz Mr2Vz4r+G11Kf2c/2R9hT528Pbiy5yPsxzxxg/55r7DguVXeCdoyOG4/hpP3LW/rc9TOZc1So/8A p5U/NED3cblVDhXfvVG51WCFmQz5CnAIPp3pTqqJ4ii5Hxv4juvDOs/8Llste1vStIhfxpCYbjUn 8sF/+Ec01Qobcu1uTyM8ZGO486sdB8E2csVyfG/hm8BAEk9vNArZ+Xj55ucAE5znJ6evn4rKI5nJ TlJqyt+p3SzGeEfs4q+kXf8A7dSNdbbwsrpexeO/CrjeXWBnhZgT0YfvfvYO35s/QGrk6zoshsfG Hgdo2iwBc3CLE0h5BY+eSvXt+PJ45XwnSk9ZMuOezjG1kf54Op+GvhzpngS41K2+JJ1Hx8s8aJ4U tbG6SMwnG4tJJEqh1OcjcfbNcp8PIdf8Q+JY9H07VtM0a4mjdX1DWriO0too9p3l2fjAXPAyx6AE 4FfpOW4J4zFQoXS5mld7JdX6LU+VxmLWGoTryi/dTdt3Za7d/I+5bTxN4Waz0XwP4R12w1C3tn4e zZPO1S5YDfcMEyMtgBV52qqjnGTF4o1dfCpkXX7mPRhA6xP9pJCqzJvUEjuV5HrX0PGXEixlb2OD doRSjHXXkjZL8lfzZ81w1l3sU6mIXvyfPJf3pNt/dsvJHEN8TvhxbuFvvGESSjB+SGaXOe/CntVU /GP4ZrGyDxWzr1KCyuiD+Udfnzw03+85/eaPsOeKlycrSROvxa+GqQQPdeMbREulLDy7e6lfg4wy rGSh9mAz16Un/C1/hgyEx+KmmAxkxWVyGHsAY+vWs/YVKkU5P5G3Ooy0j6jY/i98N7qQQWuuyqcF iZLS4XOP+A9f88Vv6b438MapcQ2tpqWZZ22ATRPHHk46sygAe5/OuevQnTV7bK51U6sbXe5W1v4g +ENBaSK+1hMwEg/ZIpJB9chcEZ/OsT/hefwxCE/2xO7Ln5XtJ1LZ7DC4/lUUcPKqlJojn5dv6/rU rj44/DbIzqd0u9gB5VpMVXPc5Gf59K+hx4K1rVvADfEnwDbx/F/wzZANfJ8Lnj1PVNMQR72eeyZk uERQGDP5ZVdpyQME3TwdeWqil31MalWnF2a0f+Z4Npnxh8NatGV0/SvEEAXGZ72FI9wPGc7yOx6Z +ta48Z6fMGdba9b/AICqkfrWtTD1LcsVojRSg5N630+RQu/iL4N0+VV1DXrTTZpBvW3vkufMxnHP lxOPXvzj8stfjH4Na6FumpWVzk4EyzSwxjPfMkIrow+Q/WbOpVUfk2Y18fKguWEHL8Ds7DxdpN9F uj1b4ewLyPM1DxNYxt0HO1nBHXuPyxS3niSwiieWLWvh/cvGpP2bTPENhPIxAOAFWQsTnjCgnpwc 17ceGsPyNyxKTSdvdd20tulrs86ecVk0/YN691ZL8b6HI6V8S4bu1W91PTRY20lwtopFzu8x2YD5 RtyQBgk8V738J/HX7Mk95rtl8cfF/jbwhLbXgitD4Z08XUT24HzyO+1yJCxG1NgACNliWAHw3tpR lKEFzNfmfZ4rL3hqFGvN29p9lbpa2b9bX9D9Bfgz+z9+xP8AGfR/FniXRvj5420jwr4GSCTWPFs8 djNaacs8jJCZVZY2QsyPheScdOK/RbTf+CPv7LGneDNW+JfiL9ofxhrPw/0XTpNTutf0l9PsreC3 VDIbhpHjlAQIr5JHbnGMHzpYis2k42b8jirJJNvZH8+vjhvAzeItXm+G93q174Ke9ki00+ISrX7W 6qpSWQrGiksGBwq4ByuSQTWZotrpb3iHUYZ57VAxaKKQqWIBIGcZx9P6V/V/BXgjg+IMnp4+vVnG pUjKVlays2o9L6pan4ZxL4n4rJ8wnhadOLjGUVd3vsr/AHN/gdx4ft/D1jfafJq2iDW9LgnBubGS aSGS4iJ+ZQ6kbCBnawHBwTnpX0L4K+FPhmT4k6f4ruNSsT/wgmg5/s4kW9h4ksJpo4NP1lYB+6Fy gL2d0o+YXCRsd8hmev1fjrwRynKOHcRVy+hatSXPzNttqNnJX/wuTt3SPy3hLxZzPMM9o0sZVvSq e7ZKyV7xi158zjr2ufgVL4iurfV9Y1FgbyTUIrq3/fsfkE0bxk/grnA+lZFioETfMMggt04yDX8c 1I8r0P6upvYF0m91J5TZRPObdcsq8nHJz/Ovqub4b3Wh+C/BGq6/q/hvUItU0sXSWmnzXDzwCY7I lcAJiVdpIwWTKgMcNXm4zMIYSVOm9ZTbS+SbO7C5bVxsKtWnG8aaTl5JtJfi0cJceF9JudWtrdPE T2uXiWbVdZQpEu9yPmYM23Chj/wEj3qxrF1ptp4kntPDV345msfCatZrq8GoL8gZ3OIiq4jiLPId o+8XboSSejDc1ecYzSXfr1tp52OX3Y+9PVa7eh9vfAOX9jrQvhRY3/iTxf8AFG9+JfjG8nttS0nT ry/s/wCzF3TCCOKS0VEkWa3VjI0jMPmK7UKhh9Afs/237PPxJ+Ku34rwfFT4yfDDwtoWo3Efwz8Q ak9lfwpZW4MSPcRTQ3ACRJtU+aJMKq5Khlbzc7xFPKo18U0uSnrfrZaL1PdyTK8XxRUo4Kn7z+ym 9E2tbdt/xOp/a8+Kv7CNro/xB+GHwr/ZT1H4Q/GC3nivLXxzba4LqyngVWlAtxKskbW1zBLDPFsS NnTbslwyo/nngT/gmD8V/H/wX8PfHTwl4m8Hx6f4k06PWRp13vsb+NJFRggkWMqxCl2JJXoOpIx1 U6t4KTWlr/eeXU/cL3pap2t2Pmyx0O+0Ow8S2mpIdU1S01K3gnF7K7FsLcCRS8TLuwyJznv34wfD z9my9+JXhvXPiFr2pTaf8PfBcF9cXL6I9obp7qODe0Tyqm5EIjyscgZgA+0KH3tkqcKSUktbfLqU sTUkpNvf/L/gH1R4Y8O3Pw28DaVbXBtVv4rCxv5/B2qkvp2rWFym6GYHduiukVwp2ESAF2ziNjX6 ifsc+PPhJ4k+HeifDWPVtStvFnhvXL/Vl8O+KViEqwXEOniOGF0CiYB7SbL4JIkwMZCr6nENKj4h 5dX93/b8BTT862GUk2/OdFr15PQ+ty/HZpwNkVKPM55VjsU1/wBg2MjG2n8sMRTqL/uJHpe7+Afi HPDp/wAQrLStWm1OwulktorTw/5t1/Yt06H7G95CHbyHdJILiMCJdoKXGQcnNC5+NvgX4U+DNCl8 S6m11qF7o0DW+haeDJc3RXVrlyPRAVTO5iByOpr3f7ErSoOzUpVqrlpbRXmk31UuVLmv2Vtz8wzD GUfrClS5owp0acXf+ZRi5pd4ubly+XzPhPxd8btZ+InxCbxxJo+meHI1FulvY6eMsvkRxxxyu55d yI1yTgegAr7B/Zz034Z+OtU1efxjp3iDx343uHaax8FS3UiNK4WRg0SGaOCZVITdG52ssYXywCd3 7lg8Hjctyim8scVWoN3bSd4TactXe1rX9E12R+X4nHUK+OqLGJunWUVZNpKUU1H8/vt0ufpv4H/Z F/4W/wDDPxlr2jfCLVPhp4av9Llls9e8OXsWn3F00cTPG0kFq7LMjrsUrIi4VmGCQr1/O98JtCv7 PxV4yh0IwxeIfC5j1fSrvUIVu4keOdCpaGUNE6/dDblPB7ECvjOE+Isbm/EEMPjKrbi5xuurcHtt dcyVu56+b4DD4DKatbDQ+zCXf7X58rdz9dvhL/wUU0PXdI07QPiVp1r8Mfip4Y1SLU9K8Y6WgTQp r6Eylo5VQZtkmMrxOpyhR2ywzX9Jnwe+J2gfGH4f+F/iD4cnWXSPFNokyeW4cRNjDxEjglZAyk/7 Oa/qTwawtTL8Ji8DNtqFVTjd3dqkbOPonC6fXn73P5o8Z1Cti8LjYr44OD6awd0/mpP/AMB7WPjj 9pz9lfwp4i13UPHel6Rb28vimYDVxGOLmcrbxLMRnAzHCAcAZILHLMSfk+H9j3woU1GT+xbNzAU6 x/8ATCJu31r+SPHLhmOS8RYlqNo1rVF589ub/wAnUj+kPCLiOWb5BhveblSTpv8A7cdkv/AOV/M9 Y/Zh+Bmg6H8Ur7xzp+lw2tp4dtX03TTgMs22WcTXgXAxmZWiU5PFsHBxJgfqRrd1v8O3bliF8qXO O5325/z/APrr43PsVS5MLhKLvGhSin096TlUn81Kbj/26fR5FCVWWIxU96tST9IwSpx+TUOb5nxH 4Y+Dmu/ESL/gnL8UdB1/wpb6Z+z14n1ibXdE1e6kXUfs+qa3PbW1wkaI2IzLZSxhnKAyMozgOyfU X/BVn4vftA/An9nSL4r/AAA8YT+Er3w34lt4dbltrG0vfMsZ4FjRyZ4n2bbnyBlSp/ed6+Mhh37C jUkvdlKcfmmm/wD0pH6xm2MhPGVaKesNX/29e35H8h3xU/bF/aN+LxuU+IPxq+IniFrmQyyafPqU sNpuYFdwgjZYl4JUYQAKAo4AFUf2HtSnh+NHjPUrydt66FJCJXbLMz3due/+4a/cfo9YZS4yyqKW 1VP7k3+h+E+O+LnHg/NXtejJffZfqfrTBqdwWEgcgdcv3/Otuz166hkUxyMP9oE/p689q/2mglNX 7n+LlWLpy5d2n/TO00z4g6hZY/0kOqdpMLn8fyr07RfjHIq5knlj2kBSvOOMYrKrhFU2M4V3R1ls eraZ8doLNEkmvig56v3x+eeelXbH9tSbw9dGa38U3lv5B4VJM7sdsDtmvCzHhmjmVKcatNSTWx62 WcQV8trwqUajg0+nyPefgt+0Ra/tC/tS/Cma3+74K8G+J/NulOHmkuLnRs5APRRbgc4yWOR3r65/ aF8uW2+Cm/ftT4gaEVOT2uGIHJ9K/wAW/HHhelwbxPjsDQVoxkpJdFzRUrfK5/uP4O8RVeK8gyXH VXeUqaTb68tapH73a57zOYwLxsLjzMn1J4GeOegx+FRG8RHkO9dzKvK4I/iB/wA/5P5RzWPrraXs VZNSiDSDK5dhwOo+XFZUurwxRRvvIUgDjjJwelTOool8jKf9tx4UpJhMY5IAGK8jvv2ivhHCljs+ InhG9GoRi4gOlXsd5vhLbRP+6LYhLfL5n3c8ZrOVa2yH7J66nwt4O/aR8JaV8EP2dfDkOneLNQ8T eAV0l9W0C30q5hlge1s8SRq06pHId7BQyMyEg5YYzXp2q/teeJb9of8AhDPhT4mv45ULmXV/3RiH k5QFYg6lhJwwDEYHys2RV2lKXb+mdOb4iFSpOzv7838nax5RL+0H8e9e0kxRX/hnw5dvvibV/Ctg 1/cwttxlIJGm/eoQSA6lTjBU98TUNT+JnimZ5vE/xR+IVraL5czvpDQeHYtyq0f3t8bYOWJGNpK/ dyARssJHXm1PFlifd0MDTvAumpfWZsNI1rX73zllXVNRJvQ0gVVZi7TRoCyIg5LHCrgjaMe2R6r4 ps5IY4PEtroUUUjE6VZkSOgHYpbIHzg4yZeo5zW0oK9lciVS8m7nbWWm69qlqlxNPrN9DCyuV8iN EJI7PPJI4GOeHB6etUdQ1/wNpNzdw+JfGc16hUBrSMrcvEQeQRI8mT0x+74wMVlLmd1FPYin1v0P 8+3xx8J9d+GNjpp199GT7dBLGzaRIZ2kYkuA4dABjgZGenXpVL4jeGvDVt8SL+x0iTXJLjW1iu3t bWGB4ljntI5yVYH5dsjsNu0/LgZyOfXhVfOklpaX4NfoYTnFwbWrOx+Emn376rbagND1qOw8EXEV x/bUMapZpB9ojhM0rNg8vIijbnlq+ttS8C6n8fbnxza6fq2n/wBhWtvDql1J4qBsNKhNtZuqO9yv 70uwQxpEqtuPPCozVjLDSxeKulZKP6p/1/wThpc1CXdNXfqm/wArvQ/MP4neD9b8DeMtT8Na7pk2 kappuxZLGb5tmVBHPfKkHNeevGSfvFfXiuqmlyppnfzc+q66lm3tFlmEfnqVBGc/L3xV4K9s58lJ 2ROG3DaGGenvTtrZD2NeV7uyijZ7KO1E2ChgKvuHpwf0969WM0ng/RdK1LUtSsLW71a3E8GkSCdr hozkB+IzH2PVwfbvWFaqptJPV3NVHlVzzbUtYk1x5seY9qPvSllUk9eQe3+e1UNN0GXVL+30+1ay eWYEmS5cRomBn5m6Dpj605TjRi29EtTqw2DnjqsKNJXlNpJeb0KyWunl2jeOMshwSjcfpXqXgO+1 fwdeR694P17W/DuqYKfbNFu5baQA8EEoQen8625nHVHFUio3TR3f2/V/EWs32q6/qF9qms6pM9zc 6rqUpmuJ5HYs8ju5LO5YkliSSSSc1rm6gtFMXLMvHA7+lTe2goyurGfB4Lg+IV7BpGoi80mN2Mia jGN7KQM8qeuRkYz3r0PSv2NtH1MZj+IF/A6EcPp6OD7f6wV005Llu+hnXqWV0j1e0/4J46Jdwxyf 8Lb1CNZgDhdGTv2/4+P84rs7X/gnVpUUBuY/H3k3Okqz28ltZOXviBuAkBkPl8qB8m/7x9AK3qVv apJLQ5Y1dbPscnL/AME5vjtqenQ2Vp4w+HCQwzmSJmu7wOu7r0t+vA71saF/wSy+MV20UeoeNPh7 Am4O12k15M/A+7t8peDnr7V5VPCexukt2/8AM9rE5tLE8id/dilb0Vv0Psv4Ef8ABM/xRpsPjTwV 4v8AjjqOg+EfGMMTS6f8PmlS2vJ45GeMXdtMBHPHGxV0BOQV425zXr97/wAEv/20/Afwq+JXwk+E vx8tvHXwV+KUENle+Bbu6eznkiS/gu1kijlV4bcrJCocrOhdCQVbcQm31CGLgubRxd0/n/XkcNPH xpyfOm4yWp+e/wAQf2PPj7+yVLY2fxih04aR4hYpo15YahDe7xCB5gIjY7ABJHjPFcxok+dRsY5S ggnlCyGQfLsOAT+Rr+7PCOKq8P4Vt7Ka+6cl+h/KniRNQzjEKPVxf3xiztV5SPaMMvBwO9e3fDrX 9YlfSNH0ghvGfhqeW+8N+YGZL1pY9l5okgB+aG8iAVQQcTKijYJ5Wr94jRjjKFSjVXNGSaa7q2q+ auj8HxdSWDrQrQfK4tO/bpf5b+p+V37QnwR0T4deIdO1bw1qpPwz+ISS6hoF3qkUjzWuGxPpc7qp BubaQ+W3Quhim2qJVFfP8Phdp7aKWx1KC5bZ5kgtg/7sZA+YlcDkgde9f5icZZDU4WzPEYCa/hya T7x3i/nFpn+g/CWew4jy7D4xbziua3SS92S+Uk0Tafp+qaf9sSIXbusZL/YU83CL8xckZwB69vwr 3/wf41uPEOmPoDr4c0+y0LTw0us6nC0wjhjwgGxg3zF3BJAJGTgAZFfF4vCfWZQkvsO/4H2OExjw tOpBP47J77J3/O33Hn/iPw/4fiRrvTPHFhPOVBkhgtLiIbx/dJQDGeh49eOleTXcyTOkgOZFVUZI E8tflAXJxjJIAye5yeprt5VFtR20/I4oaP3v63Pafhbpt8Z9JkjLwRahqiRpKhO7elvNx6/8tMe/ Nfpj+ybdz6p8a/GniHyNKS70vwH4ghu9MVpI2uZU0tysswOAS2GBYHd8zE4zX5h4g1ebD4mF7fum /wBPwP6J8HsD7P6tiOX3nXUVfp7sZfe7WXqzyr4sxeGfiv8AD/U/FGuHWn8d/AtLDT71/BVujvfa FdFGsL6RZDvxa3U/2KSZydq3elwqMIK/pT+Hd1H4H/Yo8K+FLtFsNS8D+G4bG+tSRtzHZRtG4wcB ZEaKQD+HeUOGVgPssqnKOGjGW1kl32X6H4zxlQjTx+IcVZupNtLZJye3l0R/PrpngXxN4q+HOua5 o8E9rr954xuZ11C7+5JZKYDKcOCMYfahHJZyMnbxB4SuX8D6n4o+HPhzUWufA/xGulvNS0KWdZSX TEkeEQb0PmRpCTuIcOwIzjCqYyM5ulTac46tdtLr7zzPqlRUlUnFqErpO2ja/Ox+tem/D/wj8YY7 74Y+OrnUPDfja6i+0Qx6iBFAzTTtKl1EuRui8pm2uuDktGx2/KPMfhH+zb/ws7U9W8JQ67r/AIX8 ReA1j/s+58MW6sG1SD/RbyZJApkKq9rAW2EqwkbKsygr4WX5ziOHs2w+aYd+/Tb0ezi9HF94tN3X VH61kValnvBOe8P4tXhNUqkV1TUlzSXZpRjqfE/xc8a+IvGEF/8ABDxPp3g7w38YPgvruo6dF4ru rc2097cC6keW3W63KIiZ2d0Eq+XvcsphPNfm5rmi61Yazd6brtpf2WqW8mJ7fUo2SZTjPIbnoR+d f2tT4ZwkMNHNMDFqnim52f8Ay7ckpci8t3Hyduh/D1HiPFe1llWMledBJJ/8/IptKb/vdJLo9epo 21ssSqFX5RxtXvXo2gXtxE1vdwTzQX1k6lbmJisisOVdSOQRjr6jNfXcM8sajg9mrfd/TPFz2TlT 5uz/ADP2L/Y//wCCnvjD4PraeDvi9b3vjLwax2R+JbPC6tZKf7/RbhBjndhxknc3C1+f0vh+z0j9 pPV9e8O2O7wH4/vdb0+w1wnNvdw5+128sfHAMT2kZQ4ZH3qwVlKj4PP+B58N57hs3wsb0JVYOf8A cbmubz5X+F7dj1ss4lhm2V4nLartV9lNR/vJRdvmvx3PIPi14Rh0/VpNajh/0S8bZceWMbW6BiOe vT8vWv2i/wCCOH7S0OnXuqfs8eItVb7Hesb3Q/tTklJAuHhGSeqDgDAHloMZbn+m+EcJHLMxqUP5 4tL/ANLj+Vl6s/COM67zjJoYhfYcZfNe7L8Hd+h/Qrqtja6zp1zZTqpjuk2kEZCn+F+e4IBB9QK/ Lz4leI/j14J1m28CTTfDi7ufGWpDSX1nTI57O4sbc20atfqJZtq7Q0e3cxHmSRqSdwB/LPHzgqfE GJyytSWsqnsptbqEnzX/AO3Ups+p8COK6WV4fMqFd35abq01prOKcbf9vPkR3Wn33xX+FmjzS6PF 8E08PaVp0aafaafcTTS3KfaZo40iWKT9587rH5i4jw8ZyikGsnRPj/8AtA+L/C08R0L4R2OrW0Er aj4fM1/M2kYki8yO8uYQ9taTRoqPJHLIpVd/Uq2z+I83liZ4mtOS3lLfR9d/O+5/X+SZZg6GDpwj OV4qC0Ss3bVryPq/4E6x8EdK/Zh8I3HxS8ZfD/4ffEvxxaXWiRa3mCTXJ1fWNTe1to48G4uYEvJn aJdu1ZGZkKuSa1/2hvGHiP8AaS/Yy+IPgWb4WeMv7T8eeELuSY+I7OXRHGp2cSTwtHa3G26MT3tk GjfyTHIpTDjeu7z6GPcsvjTqaOnJyj6Wbl9zS/pHt5rh/q+Z1a8HeMvdfm01y/g2fwzXX2iTVfNB KYTyzGwPy9se2K96/ZPvv7N8b+NL5kIP2OJFdu373JGc+oU/4V/Qn0cKTnxxlSj/ADv/ANIkfhf0 g5qnwdmqb/5d/wDt0UfpPb/FCxiiVbtAxxjJJFSSfFLTvnMbFs/3j1+mMV/s5HBy6M/xwndvWN/1 MOb4mO5Zo2GSQBnH+cdvwrPn+M8+morT3lpCQPvyDp9cVpWpU8PG85bFYTAVsZLlhH+tjd8LQ/tI /HOUab8Hfhn438XWk7bTqukWTw2H1a5l2wqMY6uOo9RX2n8Lf+CVP7TXjmSwvfi18R/Cnwq0u5kH m6JpEja1qqqRz9wiDPJ6St39s/yv4ufSmybw9jPDYaarYlfZjqk/7z2X5n9ZeE/0WcdxVyYnHRdK i9bvdry6n6KfCH4JfDf9mP46fAjwz4Supro3Pg/xu+qeKNelRry/uIrzw2hL4wqxqpbZGBhQWPJJ J9T/AGjPjx8NILr4O6fD4/8ACM93pfjjRtQu7K11K3kntrRWl3XTxqxZYQduXxgZznA4/wAleNeL cRxlmOIzTFu9StLmfklol6JJH+p/CmQ4bhTCZdl+GVqdCKS/8Gzbb9W7k+s/t0/BBNPS90jxBq2u C7m2x2ljpl1bzHbMEcslwkZjCj5wWA3qMpv4B8H1b9vfUW1O+TQfhpJe6SYohDNrGrfZLl5A8gk3 RpDIqrtKbW3Mc5yor5nllJq+xtzwitWctP8AtJ/tKa7pWp3thpvg/RdI1KSU21/bWxa8tEZIhER5 0rIwUrKzO0bK4kwNmzJ8y1TxV8ZdZTTrXxx8ftQWHTJVuLfU/D17Z27q20L5TpppjeVSfnJkjk2l mGQDiumFGKdnqzJ4uzVl2OKl0PwnNdQah4j8SfEjxpqhjt438Q3jSTrfLbtI8CvPdOsziN5H2sxJ Us20jOa6PQXtru6nfT/DGq3l2+HZPJfXbgEDmRcFNp3YJ/eEZyDkV2QoK12rHBKpKXxM9b0zR/id Iiromj+JNK0mcld+pw2WlYP8IfMZnVcdVVs8A+9S6t8OfFF7bNaX+v6Lq2oRtl1sxfX7ucEYBnVw hBz91RjAI71cacVIxqScm0dT4U+C/il8W1z4ekmhmWM+ZrV6VWPoxASLDc45Dg8n2r0F/D2jeAkk F54p8EeFJnAE7wxwzXzjHGI3DZIBxkxdCMmqt0RDg47HD6h8RPhJopgFifEXj7y3VfL13KWTjbyR EyqoPQAiL+E8HgjHuf2gNYl2af4B8B+F9DuZV2xx2FgJ5lwVII45PXPynPoO9ui5aydk/wCtxt26 FPUfDPx8+IIh1LX9N8UG0us7lnjS0hjBOc+R8nHfATsMA8V1fhH4DaTbXTz+O7y4W2tQT9nuUa0j fI6DDeYWB9Bj681lUqqCtFDim9+h/A94V8NfEHxfp2kR/wBhReIpYL1ltLy6iEvnT7Vf7M7fN5ys q5CN0wQCuWB9xX9mf4reMfFhv/EWm6EkmrQ2ccN/pmp2um28URgRY8oSW2mMx5Xbn8a3w1f625ez 3jzL7nZ/kc6qKTdu39f15C6vaeNvhtp9zd+IbLwpdGwFvazaN5jsWtWysT/JIUdA52EqifMvJyAR 7zovjn4ja74Z8BfDj4ZeCvCNre3A3SXeuyNcxazdmTK3M7yk/vUAUKucAqD0UKO/JuXknN3cnbfp 7t7fe19xjGTqpW0v+R8jftTfDz4seFfEGm3fx21XVde8Ua1ay3lu9pqCSwqGlbeQvlBVBf8AhTAw BjAxXxOxZ4zKGKshw2O9YU7axXR2PWlhvYwhNfDJafJ2IQzqRh+h9Olblrr2rQy7orhBI3G4xrn6 VbM4q1luSXOo6pdjbcXSNGGLbAoVcnqcAYzXp/xL8RS+K7bwBAunWmmroGh29mDE4kMxHzbycDB2 uvHOMDmvPqUeapCpF25b387o6alJ042aXkeVvblPLghuWeWdsNGnyge3HU1s3C/2bANHti73d3zP MvDY/uCtqr57Q76v0R25U3hFVxPWK5V/ilp96V2Q6VpMt1dW9laQtPd3TrFGg5ZmYgAD6k16xqL3 fhfU7fw3PaKkWlt5MsMZVyZWUF3JBIJ4AxntjtW/M+h5E0lZI9S+HXgDxl8VdZmsfBmmyX0VmR59 /M4gtYTzgPJjAbg/KAx9sZNe5r+zR4+sdYLaveeHG8MWIaS+u/Chnv8AUlUAlVVHjUb3YBAfn2k7 iMCsa1SNJ+8yo0pNXXQ+oIPEXwx/Ym0fw1Hf/C3wx8W/j34vsF1C60X4nQPe6d4btLhN0ETRBlDX Towdl2goNmG5xXjln8Xv7e8S2msT/D3QvAVlrswj/s3wpNctYiRzhXSO4klkQbj08wgfKABzlfXI wkoJb7+t/wDIccDLEQcm7W/r8z648Ma79st0gtY2aeDCsgG7kng4HPJrufCHw8+Num+KPFWreIp/ EmseEtXQSWGjyaPJD/Z/OeHC4KhOMnrkHjHPdzqlpfW9vkeVCLjuj17QfEcESW6vI25gBtbgj65r 1fSvEFtsLBkZsc7ccGq1av8A1/X+ZEXzM6/SvGkFrdqfPji7bmwe/avprwz+0FY6Ppwinv0jWNfv scjj8RjilSqezdmOUFNb9D8if+CkPx38P/FzVPAel6Jrdjqdx4TlvVubW1mWSW2eTyRtcA5Q5QjB weD6V+a9jKI3RpAyrnORkn07V/cvg5aPDuGl/wBfP/Tkj+XfESLWb1l/g/8ASInqEiwi+vIonE8U UzqlwuQHUMQG555AzV+2lmheGaFnhngYMjxsVZWB4II5BB5r99wMuVq3RI/CcwjzKSfn+DPRviJ4 Y8K/FzwXqdr4iFlp3h/4m3SRXmryu6R+EvFwjc2+sBUP/HrfRiZZ0IdRvu2VA0Ntt/H7U/C/iTwN rXi7w14ism0DW/BNwbPUtP1P5WjmWTZ5ClThyWG4YyCq7xlRmv4++kxw6sLjMNmMFpNOnL1jrG/m 4u3/AG6f0/8AR0zmWYYavl8nrD94vS1p/jFS9ZmeLLW9bhiNnpN1e/bHMMb2iEiQ45UcfMR0IGa7 v4ZeDNQfWvEGh3TGzuJbQQ3emXyOkm03EfB5UqNwj5/2h61/KWNxf1WnKS3X+Z/SOHwzqNKS0fXz 3/E+8fhL+y54Ft9RbxVdznWriSWOwi8Ia/5bRWs82VDgsAtwjEFFJA8s5V1y0Tv+hvjf/gnPomna xo3hTwt4I8H6r4t1rTU1C08SaNaCCwvrO4iR5LgN5YPkx+Wy+YUyPKk243nd+CZx4hTwnE+By2XM liIzcbP3WqbpqS/xP2l0u0W+h9jLLsPLAPDPSpOFRqXaUOV2+5p/Jn4u+IrSDwB8SR4d13TrvwhN 4O8UXtlqOm6vGI5LSW3iVJTIFyOGfOQSDkkEg19afsmeI/CGr/Gr4qX/AIe1qz1EP8OfEs03yOsK hNNfLkkDjHXv+tfVcf4Wq6depGD5PZzu+3vO34H7l4OZvgYYXD0K1Ze1VSk0urcaUU36XT+48D+B GpX+j/Hvw0bu0uNUstbv5dJ1nw/coFTUtPuEMF7bNkn7sal0kKkxTLDIoLIpH9Sfjj4KfGfxr8Lr PV4dY+HmleDfEemQ+HJNWslvlfyJJ1FjfyRtG5WFHd1fDfJHcvI25Y+PuZ1XhFCPL0j+H+d2j+dM 2ccwxFau5XcpSt21f5Lofm/qf7I/7RPwGGrad4n8MJ4m8MaRYMV1jwTN/aFm8xlaWXamFn6GMMzR Afu25yrY+LdCtote8SyLawI93pdqsq20ahJDLNKzZyRhSsi27+yg+9eNg6E5Zpiq0VZOMLfdZnq4 7ERllODppq8Zzuu2t9fU+wPAXhi18Yad4U0Lxb8QNKvLvwt51vpaafMbjV7XYsRe3iuFZJC0KuhA 2nAkXdkBRX3H8ONI8XeA49I8W6nfapeeHvGN/qPh201PT43s9Qhijs7a4nADHJkUiB2kdsS+fKOD nHFjaEpylKPRv8Lfrp63O3hXHRw/1im1b2lKa/DmX/pJ+BH7SE0F1+0X+0W9o9+0B8YX0kR1PInK Myspbk84Oc5OfXmuOs/Fdj4h0228N/Ee3m1K1ssQ2Xiq1UNqumLg4RSSBNBk5MTnudjIWJr/AEM4 Fq06WSYKnW1p1KUYy8rfDL1T/C6P4p4twk6+Y4ipR0qUpuUfPvF+Ul92j6HL+JfA2o+GXguBPbax oOpHNn4l0xi1rcDGSvrHKucNGwDDrgqVZsjT5DbTbiDt/iX29a2jhJ5NiXGp9lrbqt9O6a29SqeM hnOGU4faT06p9U+zT0Z3cPKphSUOMMOneu48N+ItU8P3MFxYtBNEk8Vw2mX8az2sjxNuRmjbjcp6 Pwy5yrKea/VqVKNaCjNJxe66P1PzjEtxbs2muvVNdT6D0Pw58NPjHoWv2Gp+Nk8A+OJlBsvD/iC1 3aNqOcBo1vA+YJc/MqyRkcAbycGvNfEXwzuv2PfH/hnxVe/G/wAI6NrnhyWK8ZJEu1u42BDiKKKB Ji54DbnEYyVOD0HwvHPiHDgjMsNXr0ZKPMmmtVJRs7eqk2rdtT1uD+E6meZbicPTlzvlacftLm0v 6NWd+juuh+8UH/BVf4Z33w20DxHo+kS3uo31lC15f61eQ6TpcFw0KOdkrb3k5YYXyxn1Pf8AKD4+ ftpSftB+MR4l1X4Y678S/Eekfa9D0/SfhV4dnlsHhin+0KRcSiRzMFVJSyHcmWwAK8Lxa8T6lapV yzK4y92TTmk2+y5LX3T3PX8KvDRZZGnmWYzSk46Rbsltfmb6prY82+HX7SP7TEL+IPEGh+BPB3w7 069s44LO28UXsS38yPKc3LySzJJiHyyCkSCYNKu3by6enal8Xv2idf0/TNJ8S/HTwZq9joTF4NA0 6A6VpsMscryRyQ2mk2i2aMTI3lzMZJUAClkAUD8x4L8D874uqLFVcM1G+jnopX3b6n6PxZ4x5Nwv B0IYjmlbXkV2rX07Lb7j6btP2kdE0P4d+DPCWhz+JINe8PaZf6Rqmv8AhO1h0N9fhkuYprF55o5G mZ7bYyqX3H96+1lDFW978Y/8FT/jBrtvBDpXgfwXZz/YHsZNV1p7u8vJFYYdj5MkEKuWG7Cx4GQP UV+u8MfQgo18XPFZ1jZTjKTtTp+6op/Z5u1uyPxviv6Y1WrhKeDyvCRjKmtatTWUm3vyrTtu+h+X hu9MtLzUbrT/AAj4H0xtTuZbl1g0azmZDJGEZEkmR5VjKj7gfbks2Mkk5mteKbu4aya+1W6kjtU8 mKKVv3cagAKiL0VQqgAADAAHav7I4T8M8m4GlTeBwsIODXvWvL/wJ6/8OfytnniBnHG8pLG4mVRT +ze0df7q0/4Y5iXxSm5Y45JbiRvlEUJLOx9gO9egaJ4R8f6zeaFZDR/+EfHiC8hsIL/xUJraJJZW ARpEjjeaOHBLmbytgVSd3QG/ELxjyrw9oOrj61m9oLWT9F+p7fBHg1j+MqihhqenWT0ivmfW3gr9 nD4atcWcnxI+Lnj3xHaXexHsPg54f+yiAurMN9xqrRyhVEZRtlm5DyDAZUy/1T8K5fhH8OdPkn8F /sc+Fb7xfaPN5HiX4oavceLLhiVXyXeNoFSJgQNyRkj5Ww2WJP8AnF4p/SozzjlTw2Xt4Wg9NPjk vN9Pkf3L4b/R3ybgpKviIqvX817qfkj3GT9oL9rPVLwSadrOm+ALG8sBBBofhPQ7W0sY3UtmaN79 Lglt7sD0GFjGAVLPy2q6J+0B44WyuviB8U/EuprYFGR9T1E2VmHWKSEyCK0WODzGjeQN8oBzn1Nf ytVvVm6k25Set3q2z+hI1VTjyQjZLQ5iP4IeBI9YXV77UdD17X5Aqy6jBG8t6+AFG6UJKScDG5uo UelesaL8P/AOmRCabwdc3ESkYXxFeC2gYY6qI1RxyBxg9avbZESlLX3jo5rPwhJC0SeFvBmkJ0MU YuL64XnqpYxD9T6c10Fn4U+2XEmo6foHinVF2f8AHxYrHpkAVQMqJAqtj5f75+8enbRRsZJK6b2O gi8LaVezWU3ibTNM095VBSfW5pdQmQg5G4SzGJeVIwxC8+hrRvNE+Hl5FHp7+IxqcqPhLDwpY6cm Bn5lbyYCckdGL8e/fWLa0iSly67nWaV4f8OGW2g0b4XWWnx2ihV1fxNGlxcOCCBiOIszc4/un9a9 DgGoaYm7XfHFt4V0Zd+yz03SrfTIScD5QZVck4PUL1Y5Y8Yab9SZR3SPPNf8f/BzStsF/wCKPFHi 27Ri67GB+bpyXEcZ4PH7th0rznVf2irtLF7Lwrpv9lW4Vl+0ag0NxOOgBCxpHGMc/wALZ45653jS lU1asuxlOSV7HmWpfEz4geKZTbXnivxDeGXA+xWcpjQjpgJGAp6enpVrTPAnjPUCso0/U7eObjzr pJTk477QSBxySMA49edlyx0M0ubzPX9P+EHgvTLJdS8ca/rZdDyLSLy1UA4xhgWbvzgAZr0zSvE/ wu8NWzz6TJc2UchQSX7Qi3KgYAIMAyeQMhSMnNY1L1NOgpR5Njk9c+LXh+722Nl4w8QyGdwxg09W sLXAJXLbgWfPQnGTx+FDTNT1DVYnm0TU9aOijDtdLB9kQHrlpHIZgDjjapOO/NYSfKktrG0ZJaM/ gV+GGp3FxDqtrDrHg+BPKaSCDxpqn9nx2k7/ACrcRgnLyoM4Az16V93fD34Y+KvGvgmHUta0rVNa 8Y+KIftD+Nr6fWgzBkYwyKIbVoTt3oRnJ4x8vIPzmJzrC8JPEVMTNpTfuq2i0blZ9bvVnqZZw5iM 2b9ik09X5Fi5/Ys+L2qeFtI8AT61qWr6Va3YvRqmn6Q7sj7cIhe5likCLljsCAZYnGTXsXw8/ZL+ Jvw08Q6J4v0XxZ4stdWtJQljrLWtuLbTp8hlPkyTnILL17YBr4nCeLODyOM40U5805S1fWT29Fex 9TR8NsRiLKU0r/keE/8ABSfXfG6+IfCOm/GXXNc8VeOk0SOfS/EMcemW9n9ka4kBjZYIVlLbllY7 3Y5K/MQAB+RETJ5ciM6qGI5Nfq+TYipjqPt6iSc9Ul0X+Z8zmsY0YwoQ15HJa976/LQdtgVslvN/ 2cdfenqbbzAAsgiz8y969ZHi3e5113ZNo9rZXOqaBfWtlqQLW17dRkJMFI3bCQA2MjOCcZGaPEWp rd3MMsFrHHALeEKmSAB5EY4GfaocWnqdD2t1Rj2N2tpOlxBZySSJngjcoPrWpqeg6/p81lca1pWs aKdUbdC+rQvA02GwXUMAWAOQSAcdKUaV5OT10/A1eKboxoLRKTfq7W/D9T0v4Y+BNe8YavcNpmny S2WgItxd3MjqkUQLbU3MSMbnwK9htPhdpFl4wvNI8Z+J9FhuhdmJpNGc3VkpP3n8xQASpYgY4DJh sivcyDh7F8R1Z08JT53CPM+nVJfN9F6nkZpmVLL0p1pcqbt89/wS1P1q+Gfh7wh4L8DaZ4e8HpCu k8bJrFGmWWSRfvs6glyTjJ/DIwa9E8Valpfwg+G+r+ItUaOHVHs3up5nORBDt3qnP8TkKe/y7R/E wr5DHUpwnyTXvXtZ99rWPcoVOaLmndNf1+H5n423Pi3UPin8RNW8Y61NcXt9rFx5uLiQylV4Ece4 5JCoFUf7te+ab4j1Twf4m+Hd5ZWUeoXeq+JrHTE0q0nWF72BjieLLqflZysbjYflDcjOa4Kz58Qv m/u1/Q9ClBU8PJW7L8T+nr4QWyaVo9pp/hux07wZFJHsx4RtYbJ03nJO5FG85Ocvu56g99WLw54o 8KLrGv8Ai74g694h1KT7SFYX1/HZRWxZWjDwTXMsXnKFO6VFjB3cIvOSV6j1ep40vcu7H84Go/td WPxC+JHibUtPiZRqV1NPHaRBE8xN/BHIJlxjI5LknAJOD6je/GrUfCjrBrmm61okzgMLfVYHti4J YAjeBkEo4B6ZU+lfQU6yjeLex50qVnzS0MHXv2kNeGmyS+G9LOqaohXytOldUEhzjAbPXH512Nj+ 0Pa+FPBw8TfFHU9G0rxCsbeT4Pt5zPCtwQTEty/ARMgEqfmYbtoYdclW55ejG4yUVJ6P+v6+Z+Xv gPU7XVvEXjLVf+EjuPE+s6xOLu/1GS3MUbyvJKxcM7b3LFmJyi4z3zx7ZYqkjgMCVPHGOtf3T4NV /wDjHMP3/ef+lzP5i8Soc2c1f+3P/SYo9bECxtAQpVnijzkH5iEAJ5981cEbqxGSNx6gd8V+75di lV5W+qt9x+G5lhuRNdmdh4P1y30XUL3Ttbhk1Hwl4qtzp2s6Up2tPasytuTPAnikSOaJjnbLFGxB AweT+NfwIPxKvtBg1azbxb4x+FCwy3a6KrK/jjwvIipa6pEYyHkuLSLy1dcl0tkZG2fYZAfz7x5y FcQcOYqVNfvKUXVj/ippt/fByPsPBLP3w9n9LmfuVWqcv8NRpf8ApShfyv3Oo+C/gr4BWWvW/hu5 8HG2vr3aLFLi4nijinLM0RaLz13EiNyCFYkqTyckfP8A+0T4MtfD3i9vG+iaJZQaHEpt7+zt7Y2r ynzol8zDAGQj5COpzycYNf424Djp4vN1gZ1L+0jZaae9dL111P8AUHGZGqWB9qlZQafyjv8AgcVo fxw0bwb4m0xNV1zXbrwveoLHUdN06aRo1tJGCuyKzCMyxuqzRrziWCMkZUV+8P7EX7TXj28+Ml34 e8T+L/D1prXhvTf+Eft9Dkna/j8QWcjRzQz2y+YjAyykXcTRqyvHcHanz7z3cQ5OsDLDZrOgqlbD uXs1bWLkuVvy92T+88PGYijUjKla63T7aNO3rt95+XP/AAU38XeAfG37W0OseGbjw/eXEPmad4gv Y7YiM31vbxxyLcAgl3SNYomBLMBCEP3MDyX9jLTvGdt8TfipJ4s8LXXhO01r4Q+KrzTbWTTDp0Fz bSac2y4j+VfMQgMBIM9CM8EV9RmeKxGMyCtUxMeWTp3a7Ny/TQ9rw+wtKlneBcb3c/wUNP1+45P4 BW/iXxN488LeJvDsGlHxN4BsY4SNXlljgu2V1Vd+MjMlsBAeMdXOH+ev68f2efHPxf8AFPwL8KT6 l4Q+CGsfD74iabJHarZ3erWm9fIEMtvcJLbZWRjHIGUKVcKxB4Hm/UY+LkrpX5Xb+vv/AAPgHTjG XvNq+v33/wAvxPMdb8ca34S8IDwd4tnubzxXpGoSR6lrmoK2y+SVi0F7BIcGa3ZMR+bsjDPb3GRl Gz+E37Qfi7TPEnjTx7PHcXfh+78RXy2eoX2lFkupra1HkMI5FYeUW2sN4yeWBxivLxuYzyui5w3v b7mfo3hlwVQ4yzBYbEX5Gm9Hbz38kn89D4u+Lnw/1vwJP8LD8NPET6Bp/g6K7v8ASpNKimivIbiS 5+0G6klDs73RRoYN6jlbWIY61/R3+zX8dL/9pH9kLwP4tksoYvHvw78Vra65pkcTK1rdQvp6agVL KB+8sj54CFhtdYy25Wxrw7UWMy/mWrk6knfu5yl9ybsvKxn4gcKy4A4jqZdVmuWm6autuScY7/8A bstfO5+CPx3sNdT9oP49/wDCRQXcGp3vie8uf9KjMZkiaQiKRQQP3bIFZMcbGWvIJbT5jwRjnoeR 6V/fHClBTyPAf9e0fwrntXkzPE/4/wBDU0HxFqfh3z7eIRX+j6iNt3oOoAyWl2nIwynow6rIuGUg FSCKtX2habrMdzqXg43DrApkn8M3bB7y1XuyY/10Q65A3AD5hwWr6WjD+2Kaw8v4kE+T+8kruPql rH7ux8zi5f2JVeKiv3U2udfyt6Kfkm9JfJ9GZWmaikcAhlVmaLIB9R6c1sRa0qFgIGI6ZcjP8jX0 OTY5SorS7St9x52Z4CXtHZ6PX7/+CXYteuYyu2CFSDn5zn/Cu+/4Wz43mg8NWs2pw3UfhRpn05NQ tortYDLH5bDEqsHUL9wNkRklkCMzFp4iyfB8X0Fg8dRVSCkpK+6ad001r/mjnyjE4jhqs8VhKrhN pq6ts1Zp/wBdDIttZ1JfPa2mi003kaQzf2RFHZidEbeiv5IXeA3zDOcHnrV661PU9TnnuNT1PUdQ ubht8k97M8ruxwMsWJya+ry7LMPhEo06cY2S2S6JJa90kl8j5vMsdWxUnKrUlLV7t9Xd+W7ZpaUE WfynJPmcfN2r1PRkR5VhjjBUnCjH+HNfufATjWwqi1rCTX32f6n4N4ht0KzadlKKf3XX6HokWg3z OltDBJNcTLlLSJC8z4wPlQZZuq8AfxD1Ge80P4MeOdcFrOmktpdjc79t9rL+So2sytlFzKpyGxuU BscHBBPTxz4mZF4dUHVzPExg7aQWs5W6KK1++y8z5Xgrw8zvxBrqnl2HlJX1m1aC9ZPT5K7PWdE/ ZfS6G/Xdav5RIgPlaHAsW3BOTvffuGSnVR39ePb9O/ZC8JapZzaZL8O7vE673vdQe580hcMWy7DY AByUC8A/3mz/AJ5+Jv0vc04im6GSQ+rUb/E9Zyttfok+y9Gz+9/Dj6MGXcNRVfNZfWKvZaQj6Ld+ r/A9w8Ofsj+CPDVvbPbp4S8MKxUvI08dsrjoeoUn+IZz1BHXp1kfwm+G9peRxx+ITrk6YVbfQxJc dMbQGCFcYyPvccdMV/JWb8R4ziOvKvjKsqs5btv+rH9N5dlWHyqkqOHgoRXRKx6n4Y8K6FosLzaL 8MrS6tpQPOvfEl4I4ZgeN+2SNwRlex7elS3Hj2+0lpdPi0zwbpenoWCwWjpqSR44+UMxjQFcjbsA Hda8l3btud6kkb+meLNamPn6Ympa7ctGyx6ZoWqw6aFUHiMrCiE5xnnPXGRWzp7+MPEBuYdM+Fmg pe2zp5k+r3H2ieF3QSKH3nLNg7iCCfm6c8jdm03YlSvsdJJfa3pEME2u+MNC8PfZ3xs8L6NE8nsA 5B5z6gZ/WqEGq/Da61S0Ky+KPFcUhAlt76GOFJJD3bCoeMdFz19hWqjfWJKV3Y9X0Y6I4iTQPDXh vw/qOAqy3kJa5HynptGT8uf4u3bnGhfeHH1RZz4n8aR2FvhM2tu32SCUbTx88nXDHI29QD1waH2G 7oxLrwp8BNDt/tes6/pLLhWBa5a8uiBzwFO7r1AB9CK4rX/i78KtFCWfhfwpd+If7PQfZr+6nntL WPd1XYCGPQZBHp6Ctoc09NkDjy2Tex4/4i+NHi7WrVbG0ktPDmnqxMcOhgxSrkY+aTJd+MH5mPIz xzny2G21DV7ht8d5qVw5yPKDvL9DjJP4YrtjFU9jDnu/I9a8LfArXtbjt57ttL8PWA+ZrnUrhWfH XhV6Hn+LFe5eEf2evhci/bL3VtU8VrZ9YdPdkgDbejmNXZR9043Z5755zeIe0UZwpO2p9A6ToPg/ wZaltP0C3Ft5Rc6ToNuhuJPlwApZQ5kOBku/r0JJqvf6zprwGS2hXTklBYQ6nAkcsRPAU7gCTnOe W6cZrKCctX1NF7u255Rq9tZXLSy3Ximz0qOc4864SF5F7HYHVDuz2XPbpXLv4V0C+QTWWraprUts wUpf3EZVyNp4TOwZHT72cng1ol0QorojC8VTaV4aKNeINW19o8W2nQgZQk4OQo4X7uegPp2HHraf EfxL9lS7dLbTtxKabMxKDPXKhWLE46AYpKXJrIVNXe2h/nxtYQ2HiK0s74bbIPGZfLT59m4BsY6n ANftR8dP23NY+Hg8L2nwY0PSLjSNSgcvc+O9LuY4gU2BVhEc0YwFOSCSRleOefzPj3hSXGlfA0nP lh+8cmrX1UWrJ77edj9E4Zz1cOU8TLl5n7qS+b3fTc+adQ/4KJ/tDzXUKLr/AII8NwRgF10bSPN3 cf8ATd5Sc8d62v2cf2wP2jPir8bfB3h7xx45W+8O3t2c6AmnW1pbysIXZCWjjDgAgHG4V4OZeFWX ZLgcRVXNOUINptq17Pt2tc9PLuN8VmeLowSjFSnZryuv8y1/wVb1bS/EvxO+FulaJfDU/FVjoX2P UNLt4zugka6kkhQEjklZWIAJ4xnrX5yXHwB+L1jph1bUvBOo6VpYha4Goa1LBZQvGqli6tK6hhgH GM56DJr9e4WvVwFGS1XKvu6fgfnufWpYqqn/ADS/9KZ5C4ZWPy88dD0pIsgjINe+vdPJ6HbeKPEk HiqbSXj0Ow0iaxtkhm/s9mC3LJGqmXaflQsVLEKAMscAADG20Ta466pJZwyukKJsgjOxEjQKMqOB hV5P41hWjeSa/r+rG1KPMmj0jwB8QvGPg2C4j+H2q22iuk32p9Q02yi+1xSCNoxtn8syR/I74AdV 5bvXM+LvEPiLxz4jvPFHi7Um1/xDqGzz9du/nnlCRqi5YeiIq/QVUozppXdkyrwvZasyI57u2SaD Tnu99zgNHaFvnwcgEDrzg163aWurTCLWTp2oWGjQRqnnXeZZHZV+d9q7m3MctjHf2r9i8IsZPKq9 avP3aVlzTekUovv89j4jjKjHF0owXvT1slu7nunwh/aG8S+FL+Kw8J2Op6+iSnGla7GI7HcWABC7 /M5GOiqfavTP2kPiZ42+Ielx/D6Zr7WGuCL3V7uxs5IgSSGS1OCwZg/L4xyoHqK7PFejleJpQzqh h7PEOyk5pK8d5KC733b+V9THg+WLpVHgKtX+Frblvp/K5Pt5a+Z8zfDDwdJpniSO11CwmjljYZtL 4NEQOoyrYIFe4/FD4h6L8IPib8GfGr6BL4qT4czSz3Ph9bpbcTyTIDG6sFYqwZWZiQcZj6bhn+c6 d62K5b/Zb+/T9T9am1QwjbW7S/U+5/Cf/BaO+0rS7m+0j9kzxXq1ho4Uz6lHrzNb24I+UyMtiQoI B6kZxXjPxi/4LN/GT41+FPEXgDwx8MPBPgG38S6fdWtxrPm3N9fQwtA+8wHfGiy7QwBZH68AECu6 nl7i029jwKjjJNI/Mn4efEjxd4EutK1rw9pum3sOm201pG+qOyLIJJvMJYIQSQ2cDjt1xXt+sftW fETXp7H+1tN0Twde2rK0Wv6EZopyqktsZmb54myVMZyrBjkc8TgMgwuJx8a2IrTinp7tu73v019d DoxubV6WGlSpU4y6636dreh5Vc/EDx/4z0vxjrFq2o3VwjC8hudKSFTawIz+fG7hQ7ghlIJJOF9M 149rPiHXNZW0i1fVtTv4rJSYre9md0iyADtUnC52joB0HpXV7KFNvl7nFUvyLmX/AA56R8FtVstP 1TW4bu6t7dbmGMh7g7F+VyOWPAGWHXHavqzTbyCbyZbe4SeN2GJoGDL19RX9q+CeOpVcihh1Jc8X PTqlzN/dqfzX4lYSrDM3Va91qOvySPZNKlln02yknkLSJGUZ8cnaxI/JSB+FXxKDuLDaEyCD24xx X79llKy9P+D+R+FZu+aTj/XQzZ9e0jT3xd31tC46W0ZMkufZFyxP0Fe5/DTX/iJ4zHg+08D+F/Fm n+OvAl+174Y8e3NhLb2CQlwbvSr12AMMDhjcR+aApbzVAIuWI8vizjjK8novD4iqpVLX5FZu22q2 V78uu7duptw5wZmGZ11iqUHCCduZ6Lbp3aV5afynrS/CPWrL4k+BPF8PgGTwTp1v4kju7jwzHqFt c2emRLYTq7JsYKsSySNGmAzBGRGLHL155+058EfHvxA+GPjHS/BGi2Ora5qSwPFbDVLG0aSX7ZFJ IN08yqu2NDySM8AE9D/iVgPAzi7OuMVjcvyXELCxrWjKVOStTVZuPM3pfltfX5s/0wxfjFwxkOR/ V8fm1D2/slzJVE7y5FzWW+9+h+ffgj9kf9rtLizia38LeFjZOsrS+N9S03UbQlWyoZIvtJdemVKF Tnoa+7fFngn9q/xR8AbH4U3vxL8GWXiTV7xrDWr/AEbWprPQ5NFjmNzDGlpFbqq3DTlY2dUGy3tL eCMIjzq/9t0vo08S5hUpylguVc2vNOK0Wuzl5LofzhifpL8J4KLj9e52lpywm/xUfMxfHP7PdxLD 4O8V+KfEHwx8S+MbLWdOuNXvMT+RfoIFsRaopgG5WxaoQ5VSsZZ2+81fZH9jeA7PTLfT9N1DwjoU Fr4W17Qre30iFlS1l1az8mQryP3CusT7QoztbAUYFe9mX0SuIc5wVbAqVKnKUVq5aWcttE+i6EcP /TD4d4Yx2EzKUK1WlGctFDVuMUm/ea/m3e+p8u/Cv9nTwT8KLK+uW+NVvqOs3sgc+XpBWCE9CATc AsDk4yByo44r9D/h1+1h/wAKv8EL8P4/F+galoVleSahYyrpRiuNOkkRGYQN5+zDXYkun3xuWkuJ wxKsFX7ij9EXFVU1icxhG/8ALFvr5tH5bjPpe4etO+EyypK1viaj07K/W+vmZvjD9rP4c+LYbeDX ZLl0s9ObTWnsY1V7iMmNlL7nIZ0ZSyHA2+ZKB98g/HXiTWP2QLVtX8S6roHxH8QTWkdxdvYf2rHB BK5aSZxhUDgF2Y4DDG6uzE/RMyhUpLF42c7NydnGK0W2zf47n0PBv0yOIsgxUa2XZfCDl7q5lKdr tXfxRX4bFyy+Lv7I76Pod1rHwQfxLqFrbIyXGp67drEpIVgEEbggDAAySSPvFssT1fhP9uz4YfCb R9W0X4W/Bbw/4U0/Ur6TUp7S21O8kE91IkaPM29zl2WGME/7I966cj8DOG+H8HTjCzVk7tyk9dXu 7bvsdPHX0geLvEnNsRjcb8Upcr5YxirRSjHZX0UV1+Z+bXxK+Itv4s8daz421WYQS67aW8ktxMWZ N8ZaAnOOBlVwCTwwGSc1yVvLHqYZrGZL7ABb7ERJtHHXbn1/PivY+s4fA0Y4WlKKVO8UtFonbRHl U8NXrzderF3lZ9Xq0UZYdisGXYy8EMOazkluLaaO5tZ5ra5hbcksTFGUjoRXnUakoT9pBvmi7p9m tmj0p04Tg6c0mmrNd1szdmvNP8QFmvRb6T4hz8uoR/JbXZ6fvAOEkP8AfHynvyc1kTrPYSm3v4Zb W4Q8xyjAPuCOGHow4PHJr7TD4mNaf1iGntLcy/ln1t2UviXzXQ+TjhpYaLws237P4H3hfS/nH4X8 n1L0EsTKMHAHYVqQNjahOdvevYp1bSu/62+7Q4q1O6t2OnstrA87yvGFGSc+3rXfeGPBmqeKdSg0 2xudOgubrlIbiRnkb/tnEHkHGf4R05xxlZ7xzl/CmH58XU1tpFayfyX5vRdziy3hLG8RVeXDw06y ei/ry/A+kPDf7P8Aodg81x481D4pWOnae4S7vfCvhDUZfIyQu6ItGzXB3E42RMAFDMQp4+xvh/4d /Yi0XR5NQ1jUvHep6zHGxj07xZoWsWSS/NxuWSIRkYdwDhM7EJG4ZP8AMvEH0ns5q+2w+VP6vTl1 S5pvfr0vfovmfuGS/R3yzEqniMdy16i+zKSjFarpdX2699j6N+Dvh/4ba14P03X7PSvEj2+q3Fw0 cfhnRpVg8sTskRLMqKC0ap0z2DYIOPsfRvgvptxBGbfwI9xFOpV08VXMOxhnukYbAxjufqe3805r nGMzmo6+NqyqTe7k23+J+4LKMJkrdDB0404R0Sja1l6HdWXgqbSsRG/8H+HLK2YKkNlbvPjIB43F lB59PwPFWp9E8FJCF1/xdqGsnacWEN2GXd/dUAqATg4BA6j2rzVFvZfeV8yjb+CfA8c9xqOg/DBL u5f94dRuo7eO4lwOd7kFhgHHBbNdLL4Shj8mK7az8PxznLHTj9tC8EdPLEangnOSODyKfvLcbkon PXugfDeHDa34o1fWw7Y+wyRRWoY44IEad/qMdehFcw1z4d013h8N/DS41AISBfT2bupUKcYaQk8Y znHc/htHml7qdhSgtWy9pF78U7uQTaZoVvpenwviOOdsN8xA+6MsxHrj860YPh78QvFLQXV3rM1n dgeW503l0XcBtY5yq7jkZO0Hn3G0FGnu7mV7rRf1c7O18B+CvBsUzaz4p02w1O0QsW1O6W9mPH8M YAYjdz8pyc9cCua1L4yfDvQbe5utItn8b6z0iksbeSzteGPyMvmK2QcEk7c449KylKcruKvbbzt2 K+FXueSa58afGesB1tZbPwnYZOy18PQrbuwP99hvbrzw7deuTXnl14g1S+WRL3V9XvYZCC8d3NJK hPToTjjjtXZQXOrtWv3MZ1eV6FbTLPVNYujaaZpt/d3f/PKyt5Jec46gY/xr2Pw78APGeuMh1lbD w9a71PmahmaXnjiNM5IOOCRXQ5qN9QtKWq6nrVj8HPhx4ZuQmoWereMb3yvOeTKRW+/kBRGgMm7O OGGMN1JBA9OW58NaKunxeH9Ls/Dodts2nraSykgp1BjAA+Yckgjp0NZTcqmmyNHHl1e5k614y0GS 3vbO6fVrIRuzF2tLlz8vXb5KHjjgkgnmoNI1/wAH3Ngy6ZrF14muGcExTW722w4zhmdQ2AO5BPPX vVQhy6X9SN/67GTrWqaG8TX19c6LY2zuSq6JIZ5GAHQui9SWHQnGa81h1bR72Zrfw94MW5UPkarM gf3JMkoKrnHb8q3ULK8jNroyvdeHrC2Il168ltb12LQ2+m3LnYMfLyrZP6DntVBfBfje7gE+h65q el2jEkbb51wDzyD39s+vrTnUTWomnJWRI2nX/huCSSTxHFdXjDEtw6wSOPvdW2579d39K4nxH8Q/ ENiGi0zxIkUjgAm0hgZc+525zjB56dq57KUrvYnWOx/D14q8JXOs+MLXWfCmi3OtaRZ+WZJ7AK2G Ep5x+Rr9bP2mvgfrHjHwf8JdS0bw58Rvixr8lmZUS2tEvo7WJ4oWKtFEI0jQDaquOTtO5m4I+Cxm YUsJicsqVWvdc1LyvA++p4CpiKeMpU9ebla87SPhHTPgl4hOpLZ6x4O0/wAMvqBjggXVZdNSZpZH WNF8k3IlILNyQD0rE+DnhG80P4neFb6w+I3hO8jGp7bLQNFvInvkyTw0CMzqoztw3XtxzXp8SZ5h cfgsQqd5R5WtE+qe/bQjhvL6+Cx9HnSj70Xq1tdafP8AQ9m/amS58VfHnSby1Gn6XDrmgwtctfWd teSLMmHMStMP3bhGiXeuGXtyTnmr7wT49utOttL1TUtANssarObmW8ukmVeFV4mbYoPO4D6dMg+1 wfGeIyvBtK37uPpokeFxLy4fMMTF7+0lb72fMPjj4XeELGC48PWk9ne+L7fa0d7pcZs7VEOOHVnb zGC5xgjnHJGRXsHwD/ZJ+GviLxoG+I/iHxhd+BUttySWEFlp13PcHOIyPtUoSMfe8wtzjbt5yO/H YmthqU/ZR5prZPRNnm4SnSqTgqj5Yvdnu/7TH7JnwGks/Ctv+z7oF14QuLdpJtW1nxTqkt4ZBhVS CFUeVeu9mJIPQA4r82fGWnW/hzXLvw4L8uukSsFFoC0GWVdzBWzgnauc88D0rLI8fiKlGP1mKVTW 6W2+n4GuJp0YzlGhJuPRvd/0z6T+AXww8IfG+ZNFvrfTPD2v2swt4b2S4llgvA8aqJDbYBV4sPKz m4jib5R5ZCMHPH/7PWl/BnxJc23ijWptbtZEeK38PO4S7hnHlt+/CFkVfLb/AFe8P+8QnAPP6Fwt hcLm2ZYeli9Kbd56291K7/BfifN5zXrYPD1ZUdZJWXrt+p4PrXjOW33waBpMVjFH8n2mRFVgAc/K Mcc+uafo/iTUYZrI3+r3otiu8xmVguTz0z3Nej4i8WU83k8LgIKnh4P3YrS7Wl3+hnwrlE8vj7fE Pmqvdvp5I6K/8RaBezwySSb5IDxOGIdT6giul034g3Kutno9nfXQzhY7SFpWb6YGa/KKzq4iCpzk +WOyvtfex97QnCnJyitWdnH4u8VK0ep6h4O168t7TABvtPLqo9cMOn0pvwl+L3w+s/2g313x/Dfv 4NuVdNQvtLQT30NpHBGzQxxynYXXyXCu2TlstuAxUYKk1KXK7+61+RGYVOeKUlbW/wCB+oVl/wAF B/8Agm54KSGwi+Dvx1+JSmMLu8X36afCvHVRYXKcZ4wV/CvnLxt/wUO/Yu1P/hJY/A//AATq+Huj 634ks59OXx14h1T7Xc2YmVkN0kJgYG4XduWTzA4Kj567qFCcep4XJpZM+AfBFvZaDbhtchtyNC1G SN7a7TzFZk3KVI78/wAq5v42atZ+Jrqz1DRLBLaOVsNb2yeWnyqBkD374x1pqNql7m0p88bdjybT 5Z7S2ghkW5XzJHEkMTtHjoRyD1575ru7jwjfXyGXTbSS7ijsxeE2g8wwxjAYvjJCgkZb+HPPHTar +7XMu5vSiq8eVuz/AD7fc/wNj4S6YLvxPqFvPFhY7NyykcjEsfBzX0PD4NgS7tpNOmn0+4d1Hm2r lM8jrjrX9M+FmW/W8oVWLcZKU7SWjWiPwfjnHPDZg6cldOKunr3NJfHPjjw9YQ2DG1vI7RnSTUJr YyzkM2B8qFQxHYn8QaZL4vt7yaBpdM8c6qMAtDqch8mR8nJEcUcQVcYGG39+a/RKXFeYxf1Ss5cq Wsor3pJ3a12Xy18z4qpwxgZXxNJLmb0UvhVrLbq+uuh3Wh/FjWNCUx6J4OGlJjl4LSOJvqSee1d5 bfHP4lXTbUn1LT/tL5NuI5VTO1V3kopGMAZ5/hry8w4hyLglwxdfCPnb0ctW2teu9tHfvY1pcMZp xap4aOK93tHRJPTptdaelztLDx1471a8t7K48a6XaS3bKga+F4EXI4LN5RAH1PFaXiC++IGkExr4 u07XpEAbyPDUstzncAeGYKvGcEbsjHTpXzq+mLg6WIjhaWGqK/XltFW8yf8AiVJTg69arF/O7MXS L/4k6x/aZN7qOmLplq9x/pifNM4ZVSCNQxLyM7rx2UO5wqEiSC2+Ik8bvfT+JoIVYYNnZi5PJwTg TA59uf1roxP0s3eSp03p6Bh/ow4Oi0ptHNa14c+NOpzPpllp95cWcNwjrrclxFEitFIskchjZt5Q sBkDnGeM8V1d94S8fafZQXOoXWqTsziP/iWCRk+6TvJMfyDgjv1A5Jr5HEfSfx06k6lKHxJLfZq/ +f4H2FD6PeW06cac0moOT0XdL/5E7HSvgx4y1K1gu7nVdbEd0qyLbq4hZQVB2kshJ9Og+gre039n jULrUNPt9Z8QanpVnc3CRzahcXCmOFC2DISEwFAJJ+nYV81i/pJ5ziNEkrve57eC8CsqoauPTQ66 2/Zasbqe4E+paktvHdSeVtvGmeS281jGD8iYk8vYCemQTgAgDvLf9kfwHLA0d3YavcrKMEz3cxYg 8EfKcH8jXyWYeOGfYxuKqpLyPq8D4WZPhbfu9VbsaOkfsa/DCwt1sINDvWjQcNLdTTFQMDA3k4A9 BXeW/wCyF8Fj4au7a90GyTU4ryEi5urhYZhC8co9sruQc+p6mvmZ+Imc1VyfWHZK1vQ918J5bSbk qSTb/N7nlnj79kD4TeINLTTYPiTJ4bt7aKK3ttPsYbTW4EjFw07x7RC0o3M7nPnDG7nj5TyPw1/Z Q8FeAH1dB488Ya4mo3SzINK8N6VatACPmXzLwSn6eWkSryNrHLHppcV4ivRUaycpK+vM1e7uzmnk lGlUbg1FdreVkelz/AXw3eLNJLffETVIrkKJbHxHqunzWzKMkqEgso3UE4+7IMdMVzsH7HHw6ur2 S5/se9gtp12rYW15dSQxnGCQZHd93flse1ehgOPMwyy6pSsuzu/z7nLi+G8LjpNzj+n5FG+/YS8A XEplt9W8UaYzMoEcEsVxEMDuGjZuTjJJI68Cvmn47/s7y/ADQ9M8VeIPEl54g8M6reppUNhFpDLP DJKSyLG5kx0TkA/xEKFzlfusn8YK9GvS9tFWuk7eq1t33S9WfNZj4fUsTTmqUrOzav00el+z0v6H 0z4H/wCCcljFJBP8TfixpthasoZ9M8MbXmX5DlQ53jO/jJXopOORj6w8KfsYfsteHPs0sui+LfG9 1EfvXJlEcuc/fJ2oB6EAfdz656uJfHTHYyUqeXxVKGvvPWVjmyjw1wtC1TFy532WiPPPE/7PHi34 UeJdR8c/DH4beGfj/wDDWUGS5+DPxMsrQ6vZRq24HT7hFEcm0ZAhlUOQB88jHJ+hf2avGX7P3xIg 1Kz+Gei+Gfhj4o0xiusfDmGyXw74hsGVixWaFsSMqljgjKcnt0/IMzzivmnNOpNttK+t7+d3rr1/ yPv8Jl9LAxUYxXu/gfX8vhnwsHtP7UXVNZ2kgw31xK8IyOdyFgp6f3TjjrT/ACPCto72+laDdxOr keZp9nDKy4OQAXg2gdOoPfnvXgK61R6LSl/Xodpe23ju8mt59GntvDFogxLb6rFG2VwckbWBVhz+ vB7aMHgrxLeXMAvPF9ykFw67/I3rx3xIQw7Hp64rKLdK7lrroVZu50F/4c8L6VaKkGveHtVuzHj/ AIqPUpmdvnxjbGGycg4Gw88Y7lmh6rLc2+o2/h7wtPpclrN5RvI4PssVwR/y0jEi7thODuJfP93v Tvz+RfJbdnSQw/FBrC3tgpshEwJkkjSZyMKB+8HkgnKnoncE7sHNFPhDrviVoptWfXLg53E2ziJS M/dU7uOAM845HrWilGC1JXvWsbo+Hnhrw6bKXxLqXh3S9PtiJfI1GXy7m4wx6MrAEj/ZGeBjrWLc /Ev4SeFIEt47rxD4uuCzF44X8u3kIJIDJIoHTaPlX175ptursKdo7s4fWP2ndUlgFl4b8J+HNEtE V0VNQC3bIcYSRDhMOOvzbgSBx1z5Rqfxd+IGuqYdS8X6lDaYG2x0txaQIBnACxBRgemOw9BXVCgl rLUylPm2OBa9DswabzS33mduM9O+fXvV6xhvtRcw2ltPcM2BstEZmA9flre2rTM5Nz0PUtA+DniX XbdprqbTdIt2GDb3sm6dhj7wQc/gT3r1jRfhH4G0aQrr2unWb1h+7s402ICMdlJZjjsSOnSsp1LO 0TWNPl1ex6tZR2+kW1pHoOhWQsX4Uyr5O7OAWKjnjjIwOoGD0rPHim1tUEF3cw3c7kFLYOF9cq20 DeeG4xx29RlzN6lWS8jzDxX4rvrtJbeJdak+cObaOSKGLarZKD5d+SMDPfJ6GuQshresJdCym1Wx aOMkm1Ml35JVWOQh+dmAU/KuSceprqjFRs2ZS0901l0jT9CiXU9c119YeYBv7N1W5ngkjUsAHKLg kgZOwkZ4BKng27Hxn4m8QajLpOgCDw3pLP1ltJIgQB97eJJAeuQcnrjIJq4+8ryFd83KV5fDGk6X PJNrGsnxzqyDH9lwIRCrFuC+7ICk/njjPbYtLfUb0RJqt3o+kaTACp0jS41iG0fdT5cjgHHG3Ptn i7OTuSla7NGy8MmW4kuNH8MWtpbrw02qsgRyOpbIY9+pHt252INA142X2ZrjRr0wRv5srxlnLEYz lWRV6njYegxioqO+7Bu9zxHxdq2kWN81jbWj6hrMZ2H7KrOvmYy3KPg/QE42nOOo80GgX+ob7pEf l+0eFB/u7uAeAfu57c8cxUTjuS78ysfxyfFDwevhvxvo+q6bHcaemoxicW1uWijYtI2ehHt3+tfq r+2n8PI/iP8AAn9nqW81KWEadDG3yAs0gksYMgc/7PU5r4T2KzGplc2lrKV/P3bH3dWr9VWNhFv3 UrfOzPz9+HvwMsfDvivRfFMepahcP4Uuoby3s5igjbypQ4RuM7CwwRx1NYnwu+EMelftL6HfeF/F XhG48IWeqyiM3ev2Fpq8IRQxiazmlS5eRd4UGOJlkKt5ZfacfYcTYBYfDYlJb05J/c7fm7nzORYy TxdCTbspx8+p6l+0heT2nx+1PQrKX7Jb2OjTTW97Gd7vNLGH8whuMhUiUD0QHqTXxNrvxg+IdyIo LnxPrTQxjYn2cJC7AcZYxKu76nP+GXCFb/hLwtnvTizr4qh/wp4mUlq5t/frY4g+IdcWe71SbUbp rzaCbm7JZz25zzXqHhz4yeKbPTYZf+Fn3+l3P2gJJo2maZHNKkAK7phI4Cfd3YXnlecA17VSkpe8 eLG2hU8ffGHVdftrez0fx74+1KXJ8+51XyLNCOMBUgx75JPb348Kf7dLM0rXDXUznLNOcsx7nPel CKhpaxUY8vwl+0ubq3kDmKdZFIZXgfBB9q9tl+K1jfaC+n3Ok/ZddkuYWbUwm3MQjkEwypA3O5iz uVjiP72S26pSb2dh+zUrX7mZq8ulapbxXVncwrjAKkKCT3AA9K+lfh58GvCvifw7Y6jrVsLi7uBu VFJURpj5R+NeBmOKnhoJx7nu4HDxrVHG2h61pv7PvgrTWaSLS7aaSIA5kG5Tx0+tekaZoXhnQgqx 6fZQbeipGFz+ntXz+IzCdZatn0FHCRoNtL+rs5zxn4ztNN0PXNRjjWaLT7eR44FUYlKrnGPf/wCv X5deGfD+vReJdPhMohGoSNaP5xCFVnVoWJ3dtrnP417vDi5Izb7r8j5/P5XlHyv+Z0V38NPFHhjR tK1/xNpugjTPEMLz2bNcQzy7E6mSOHc8LHIIEgTIIIyDmsm08I6tqFktrFpFqhuMMs8aM0uWOeAB +GBXuOd9U+pjKtTwsfZype/Zp389n9x6vquma0nnCTJbU3jv7i4vkfebiSJTMCDjkTGT8q4zW7Qz JAt3Ku+14WO3jZCQTkk5qHK8ro8lU7Wued6nZwWl7JJbSXM8GcqzA85HOeOte1/D/wCG/ibxvp9p e20N9ZQWrlIryVWjHIGSCccfz5repKKheRNRezl7jvbb5H0LoHwJ8WaJqFxriXMWpXU0XlyoF2yS AEc5A5OR3698kV3em+FfEkgjvbfRZr2KBgTGg37iG5VlU7h0wRwevSv6J8IeMMsy3K/q2KrKm4za Sb3TS+/d/cfj/iXkmMzTMHi6FNyUkm7LRO7uvIjvfC2sWUN5ea1pd/aidjI017CyKSWBzk9MnNan hXwVrHiu7a20DTvtZtgGlupfkgg5GN7noT1CjLEZIBAOP22rxZlmWYKrj3VjKnTSu007vpFebPyh ZLjsfiIYWMGpTfVbLS7fkfSPh74LwWAVtRg0/V7487pfuJ/ur/U8/Su8t/htbmXDafZhe6qgwPz/ AB/Kv4U454yxPG+OliqztHaEekY9F69/M/p/hfhynwzh44elrLeT/mff8NDp9P8AhZp6Krrpdsuw Z3JEg/pXUWPwxt5AD5ZhXoXVQue1fDbSTZ9VSbgkn8zoLT4WW6MdrTsp9zyc+3/166SD4X2oVdpd GXgOxPA/E4FZ8yldmlOO5vWvgSe2gzYwWEzxHB81CWY7T3UHB5HY+neunbwo1patd3ljHFboN/2q 8cQRDnAyzgBcscfjV8qkKMvZ67FiaXwpaSwQ3WoaKwcEj7NMLrbtH3W8nftJzwDjOeKz4Nb8PSxz CDQ9dkmgyEje2hjRiBw25nPB5/hJ9jV08LOS2M5V1HRMni1rXWQXGm+CNtsuR9o1Hcc4bAJ2KOOP U+xrmWvfED3txe2c+j2t48pjaOWJruOPdkGNUmd1GR/CACSAc5Ax2Qy+MbKTuYxx7h8PXQ6+30j4 gapAiPe+J57SJVjC6eHtosAkDiHaAc9/YZ6VUTwJdG5P2y2D3KHbtut00mSc89TzXU4Qh7sTmqTc ne9zsNP+HWo5ii/s9vKkPmttjWJl4zjL4I57foa2P+EJsLdZDLqFlBLASfss0gklxgdlXAHPByev NXKpbbr/AJhbdvr+hLBoVtG4+SW+/hFvpcTMxGT/ABMMdPTNbNrYXkm6PTPDupuJmIETkyAYHoAB nH5daSftH2M3e6VuhrRJ4vtZBZ29iugsgP7qcRWcgwGJBD4JOM+pwK+Kf229A1fxJ4Y+CfhPVruW Ya98T9AsnE7vMse8TAcZCv8AeGSCcdMgg11YaK9pHTUmW/uvQ+7o9NGmNCRawTNuG2OJ4V3dR2JY Hr37V6LpkPiPUZUXSLDULWxQDc9tCXZJCMqVdlKjGG6qcnGRxiueS0uioaGpe6H4nvLpdQ1+5bSV WIq000uXaPkf6vAWRstjkHPHcCvMfi3+yn8DPjKLTVfFvizU9A+JunCJtH+I/gO7tdB8RWpD5VYp 3RiwY/uzHKHXliFDEEYJuDvE1jB6nlun6z8f/wBmOWV/itow/aT+Elk5834meBbP7Z4v0e3A2o99 pQOJ0RSS01pkgK7yIAK+yfhx8R/hb8YfDOn+LfhF45HjPwxdcreaNPFGvmYBMcgYboXAHKMFIPJH PO9Snzxc46eXYWlN2PQ5dDv9QMatcjR0k5a7+3TQSysW74lVCentyeve6vgHMkM9vdRa1Hbr5E1h fuZoGiySRFIhBDAgdWYYGCowCOPm2NXe6OtX/hFdCmg0vWNKk8Izaskix6hqVs1xbkLgE+fAHihU 8AGZ4y27AGSKZe/Fz4Y+GXvLKXxXFrV3o7BZLLw/GpQEpjO5goyeVyGxwMdOLi+d+6Sk92ed6v8A tXC1nkPhXw9Amxj5d1rLtIR8oA+SMjBzk/fOeD658U8QfH74j69uS78V3lnbl2YWumN9nWME/wCr 3IAzJjAwzNx1Jyc708PbdkyqLZHlM2rLPLJ9okmuJnyzNKScn398c0yPUoMBhCu085PXGfp/Wt0r swvfWRds5ZbmVY7e3kmlzkRwx72Oe3QmvUPDvwr8Xa4Q8+ny6LbP8xudYHkgjPG1QMn8sc9aqUlH VsiN3pY9p0T4L+GNNe2OsXlxqVxjLRRKI4S+N23ABYjHfvkcda9etzo/h+zeCJ7LT4Z8Hy7O0gDL tyf7hOcEDoM+/UclWo6l0jop0uTc5abxZpa3RgX+3dTaQ4aG5t4o4tgIy28qvynHXPqewqG58Wpp qSX0unw6BGjqwa0tYstgDIyFY84PckdQRxRyOm1di2OC1L4o/wBqMbXT9J1HUEY5MttEYUZj94nC k4IzyawH1O1uW+0a62r6AJpASEiVR0OcZCnPBwTxzj2rpS5FeO4qkubSxFF4u+Humyt9il1vUbvB Y3Wq7ZwSBklQzbQe3y5bp+NJ9RF+EurDWtS8N2vJMjSR26Y35bbF95jzkjJ5JPY1tZ2uKSvpcjt7 vwPZxhtQ8S3HiC5wP3EkmFc9AcbCM5A5zkAds1q3fivxNeE2Oi22mR2L4ji8pIxuydoyQMYPHHbn 0q5rm1ZlLRXOfgh8QSXE4mmtVkmG3zolVQTnjaSoJ5HUfnWjpuoXliZSz22oNuO92UNK6g5xnjaD nnp2BHpXLz6ImMbK7Kb/ABEtrJg8b3+peVkfZra9na3bBwRtEioRyTg9+nSuK134y+INUuDpdhBf 6NpzHc6QMyuOCckngjJwVHPPNCp6XG+i6nLw32oX6NBG95PM+C0qky7iTgHoeprqdK0ee7WVZLy7 t7lv+WUrx224ZHRnU88HIwcZ6VjVnra44vmex/Kl8Sl8I/E678MSweP/AAr4L1PRIjFLYeJDOrPk qQQyIykAg9Cx5r9T/ilb6Jqv7L3wc1LVPE3hXRdOs4LbOteIdSj0i3nK2xUpHJIpDOQrEIBk7T6G vg41ZZXTwcqkG/ZTeqV78ylt36H3MqccZUr8sknUj9zSS1+4+N5PGf7POnIkcXxw8Kra3Eey5k02 01XVriOQckKYLZlZcjOeOPzrxDw7H+zTbfHXwvrPhfxh4v8AE3jEaoribTtHlstNmkfhhJ9qMcqB ctwI+oAzXrZ5nOMzelUVOi1FxknzK104taLyOXLstw+AqQlKom7qyWut09ToP23dNGlftHaBNFFN Zf214Wt5Y2XcCxD3ERJKg8kJj8B618r3/hG2vUilS0YNGuwRuWYLgdslf4snGO/eu7guN8qwqfSE fyPO4tqXx9SV9HJ/ev8AgHlvizw0tnY3iLCyBCOAAG5I9zXZ/syN478F/ES58S+CbfW7TWY9D1e2 h1OxtBNJC02l3CDaSjBXIYgEYbnAOTX0jn7K68n+R41Gj9Yg5Nnh2q/Djx/pMkz3nhHxRCAdztNY zJgepytcmftVpI63VvcQFOCk6FSD+NKMlNXLlH2UrPU1rO8i3xvuyh4LN0rfR4Jt5YjHY8VlO62N IvmtY7TStM06bRby6SOEXKDqRzxyTX0v8PPiJqnhzQdKsYNDttbEcIVBcPJHgHHdDyeCOc9a8HNK bxEGm7Wej3sexltT2E1K1/I9Vh+NUyPbjW/BXiHSop2K/bNNdbmJPl6kbQ+M5zgN16cVp3PiSxu1 j3X6QQv+83XjhHKk9Dnofyr576nOGj96/VH0bqU60XJOz/lfa29zz3xtLofiXw1qvh7w3qVpea7c lMw2TrMIk8wZDlT8uQrev05zXkun/AvxdNbeaLxYi6kj7PBI7Ajkduuf5V9NlklQp3fV3Pk80ftK mnRH0JB8JfEnju10251LVddOlRhWsbWRY4HsovlKwDK7lUKApHt2Net6Z8ErVIPJltYrhHkMrRXD M6s/9/HTdz168UVMbyvlhttoRGTq+9Uu5NI6vw/8IINMgvU1C2trq0895LdLaIyOiu29hyvXeWP0 I5rr7P4Q6BKiy/8ACPWsEoPBaBHftg579P1rhliXOScXoZuk2rNr+vy/4BPH8KEt5maHQtP8r/ns tusfpz1JH5VeHwpuLmRG8to0yP3cAxjnPUY/z+i9vOUXF/j2LjSjTtc1IPhfe22VRLwqTtyrk1he I/DqfDu0vPEc4nuZriN1ew8yC0+1ZCAbmZSwKddyfvOSM4xtiHNVtGL3/wCAXTq/Vnflv01Oni+G PiTWrUjxDJFYW95tN1pOhk7rkBQDFJO3z+X1GEEZ9+SK9G0P4e/YrWKw03TLextLcYWC3CoF55OB 3zzn15r28dnjqUFhaV400+az+1K1uaXS6WiWyTfVtvysHllqnt5pObVlZbK97L9W9/uOutPh1I80 bvPfwtEQxhs42O7kAK3y5wT2+tegweDUsQsl2IrBR1uNZYW6847uRySR+YrwLc1337bHre0asnpy /lruRw3PhaxDtc+ItEgZSP8ARrAvdyrnsfIDqSCOxx6E1Zg8S+GEVhDbeIr+VgCoWCK2QZ7EtIW+ ny9hmt44KVrR0RjXxak7t67eoT+LbhPI/s/wrBEuSPO1K7knWRs+iKgxg/dBqSTVPGV0YZo4bHRo LnKr/Z9lwx4OQZN7cYPI9cmuyngox1k72OaeLlFtLT+kbum+D/HmvSgO/ju/gLkj+zYpfL3jgngo gHbAPGeldZpv7Pniu5V1vdO07TZNhwmrTIXY9T8qFjuPJxyeM49Or3aeyRi6l9WegWP7Od9aRC51 G8Z4Ubd9nsrXjGcbsyPGMHgggeucEEV1kHwV8KackhvJ72OR2Xm5vIYUPQkEKjcjHGGPfkcUnO72 HzdLGs+ifD7SZ47Rk0ESwgf8tJb1j1GNzyKAQuDj16A12ulX3heMCO306a4jdSiW4CRxuoP3PmAO OQepyD7E1lyuSu2K6pySsUR4U8OXck72vhe1sW1h1kNxa2x+0LtcEESxLu25GSdx71sN8P7wO0v9 r6toaJiNbozRRRyqFyCvmxscHnLYDE5zmpUVBWZUpNxurGXdfCfw7fzR3WoeM78wSrv3CS3ukcED KLtVTk44Ocde+K5fUvh1o2nuI9C8XRBgw8zULvS5HdQRkYPnjkjAJEbfeOMYONU5LpoLRbkd3o3i pNXsVtIh4l0vyyDeaZp4ju1fGRtSRguzGckyDlQoVic10N5oHiZNLmvZLf7GHIBsp/K+0ELhcbYm 27c9VDE569hT5nG6ehMrNaGr4f0G1vrqXTkW/tLskxvePok9rBIVIO5bmWMRupJYAh2B28d8fGP7 SXgvTtW+Nv7GnhDSXsbm31DxddavLFazwPFOmny2k8gPlYXC8swbON/AJ4rpwzTkkvP8E2Wo8uh+ iKTaV4csnf8AsiG2RgYmns7PzMADJO4qQQc8H1GDyQtOtvErassf2PS9TulgUIiRRvDCU3DP3hhT z29zx1PIpOWrYklKz7Emo2mt6jDI8+mPpto5RYri2RJpNoG/IUqUdep6EZBpsHhxL24S4mk8uWLn 5FjVslBgHgDdk9Mnvwajbd3NLJWXY1bzRILa2a7vruG2iYZd9VuPLZTzkMBIB6HBGT6V8G/tG/D7 9n7whb+IPjh4Z+JN3+z78TfDdvLdX/xP+EMIe21FVz8uoWhP2XUQzYG1iJH+VVcZGdqNWUZe6rkx itHc/C744f8ABVr9oz4q6BpVhpHiqLwImiIbfUZ/AEB0mfVmLkx3xl8x5oiy4V7dGEaFFIL7/l+f Phf+1x8RvDuuQahH8SvHGj6k0xl/tKPUrh13tu3O21g4JL8sMn2Oa92hg6UdGtyJ1WtY9D9lfgP+ 2ZrPieG30/x54gm1K4wsa6/cSmR5N3IYsT8wPr2Oe4r6l8Va7pup29vdhtRu7m0bzrf7BuCyPt+U 7z8hBDYGW2nJB4zXLicGsNstP6/zIjUclYpW3iCSW2Q3E5nuNi73tYmKHpkKAWP6nqKni1WRpXji guGbeRtggldmHYDAJP4c1jFp+Qoz5Umep6V4D8VarHHN/Z89rbXGCHvspweOFHzckjqB1FekeH/A /hW0KnxJq2oJNbEl4ZtPuYYMg42K6qS/PsvpxzXPKahotWUqbqN+h6zpkmj6bCX8O/YbaMDDy2cb CTBfp0L54wR/9fDzqs8Di5S7hllmO5TBKcovYZK7wAAchs4zgdahxu33NOXZHKXPjm6Scw2uqWdt cSSbhbWbgqxJGdxVDjsOSP0NVbP4kwwQLDJBqeo3E3yrbSQzSKxzg43gZ/hA7D1q/Z3Wgr+RYj+K PieFC9j4ZvolhZgZ5F2lBuwCwOOTwME4zjr0rIvfiLqqtIt5ayStP8my8KRE4OH4yW9sjg4PPBpq K2iyZOyuTQfEPXJ3jhtZrK18vIFvp4/eKv8AFwFznGeSwzXX6ZZ3l/ta5k0+BXKkzyPHcyRfLnJW Vto6YPLEZAwM1qo8jumGr2LF5rfhTSUkFloukareYZPOvYTknOc4XIHXuSAAKqSWWiamzvetbyWt sdwhs2MbkZO5WZjySAuD/tAkHgC48ys2F1EuR+HPCcUSwWL29jexEh5OGDY25B2j69wfTNcZeWlj Z+YYvEdzc3IyosZbd4xuD4wCdoAzg5789ehuL5r9zGaWqicVq0JeIQ/2yiI7EbY2ZgqqM/eGOO2d tcFeZs5pPsMz3VxuDG9hcNE3XkHO7pXQrO1hKy0NPTk8QXKz3QNzcSMNkm0l+wyo7t07fjXRyaXq pSF9W1efR7S5AKfbHCy4z/c3EgA59+nHNRU00DmabaPS/CvhHSprCeW08R6PIyLkw3MDvI0hB2gY B9Mcn+eD5drVzJpN9HHb2ul3F5OzglLXYsLZzwGAycnoc4HSuOEOZvdCim9F8j+QrV/h/wCAddvL Sa98a6faRycR3+nme9gc9CQ8Ubh+QehxxX2bJ+2X8PdK+D3hb4S3OoRXa+BGiaLXmt9N1QT7I5E8 sW91yoPmNl1BcD0Br5WvWni406NOLbhK97eq/U+1pYaFGU51Zpcyt3PGZP2zfCOmaZd2ej3/AIph S6l8x7HQbmTSon7/AHYYgAfTBx7V4xrn7SfhN9ePiPwt4DgGtPmc3evW739w10ST5pnjlgbJbksV Y89+/VDBY2qlGyirWet3Z77nN9YwlCXOpOTXl1X3kGo/tB/HH4h6rop1DUNO1GaWEmO8k06O9kiV WbEJacSlVDA4X/az3rn4o/iNp91aT6toV74j077Us1zp9tJeYnjDhmjUxMoVmGQTtPJ4xX0OXYCn lMVTi3b17X0XY8nHY+WZybqJLVvbr+pZ/tLx35moS6X4P07SLS7bbDp89j5ssQHC5NwWdyBkZP1r 2vwmPjZqet3Q+FPhDWPiLZeGI4zqJj0t5IfMMbLtnihC+WVfzNoOCfLJ5ANd0pRnqlex53s2rL+v T8zOaT9ou51Rrm78QXOnqjkyWEEMGxOeVVcFVwOOhxXdaX4d8TeJrfWrXxzeX91azWF0Laz0PSNO uHnupU2KjlprYQo2SWnVpWXaP3UnbGWMU2uZpLU1lhny6LXoeSS/suNdqT5UVuXPEfOfzUfXt+VQ Xn7H2vRrv0zxJZZLbANszoeSOCUH+TXLHHR6tGvsG7WK1p+yr8YrVJo7LUfDksMy7C9zI6Y3A9tv oK9E0b9nH462Wn2lkPGngrRLe3UD7RbJJPP6j7yY6f5NcWJxNCWkk2dNNVI6rT/gnYab+yd4z1gF /E3xg1+4izho9JtxAPQ4O76/w13Wn/sQfDeSYPq2oeNdeXfwuq367Tz32KD6d+1cqzCEE1SppPz/ AK7GsqU6q5pS6Hvfgr9n7wB4JLReG/DVvZs5w89w8k7NgnnLsfX9BXr0XgeOFVWNrQbv4UHT9BXn V8ZOVRablqhe9naxsReFLVEX98sknQxhQuPVj/OtmDQLRgiwyQkjPOc/yPvVRfS2/wCpcqfL8DL8 Wgrv2r5YU/xRucgfiMD861bXSrON/JFy8k3ZVbLHB9BWUKl9X0MlDudRYaaGVlh0+7u8/wAKISxr pm0Z7RLdrvSfsVvKwXztRljtkxz3cjmt0r2sW3Fq66FOXU/AlmNl74k0SB8lTFZyC9kyPaIN6fyr zHx/4g02/wDD95pnga0vNa1y+ZRFfakiWltDhJFBfcjOyK0gmCqqsZLeD5wN1dOEwk6clJrRHFiK 3NHlTuareI9R+zTtZ+B4/NhVcTS3z3aHoMbFSM5/4F9M9q0+vfEK5lT7HBo+hRRnY1npWmqzbx/F mfzJM4xkAhT1xW1PBxVm2RLESs+T+tTVtdD+I2soJrvxPrvkuSwgtJ2gVyccCGEKMcH+HHUVvaZ8 G9SvX3y6brM+FKm8vZUtl3Bdy484ZIxx78YrppxhTXuqxy1HKold6nf6b8I3a0McqeF9NlQqTeNN c3Nw2cKBhTsyfm/hHQ+lelad8ENPmVPtGp3upRK4UCxgS0UDbuyWk3Ejdkcjv07U3W5XuLluen6F 8LfC+l5lOnxQkshMerXssvqVzs2KWJU9cjsBW5c6z4J0Z2P9o6Us/wBzdpsCSSnDE4UlmIwPX14A qXJzehXI+plL8RNLjRLmDSdWvpIiIzdXcgVH5IGFAIB+bGRnt6Zq1B438T3T3LQ6bNY6c2dxIPlx AEDexJXjOFz9fSq5bWbK2u+5hax43tLAWkHiDX7qGXUk3xwyF1jkUOwI+UudoKuCeACDn0ORaeIP CGuXCzQXUM1gsW0zSJcsgb5gEKldwOR1I78U4u17EtcruibTLqwFxHc/YtNltbVyPJitjbKcrgDf JlmGGUghV+6RyQcb8/iWOGWMabptoZXKtHDBA8sgBGCqknGCd3PfPbFNxervoTKzvZDreb4j3csN xZWd5a20qhWguQLdCm4DcoRhtwTgnHTOehrbbwz4svne9vdc02FyG/dz3MmFwCeMdeeOvHoc8tR5 NmJK70NbRvBTS3MCNrSXd5G27yFMgAOQQVZgBzyRgkHaecV6Ha+F5UiQhraN1DRrPKgEpwGHd2GC oA5A/qcnK25tGnZD7PTr2FgYtSvLk2wbdbxxxxxq5ZgQMKSSW4+939act1fm/ngZ7jzoEAijciFi BlmfDZYgEY+Xj0zuNQtbsrltsWL/APtOKy+16leW1haRBpDKhcOvLDJ9Tg4xyefoa+EfibbeFvGf 7Y37KM9vqlnd2XhXTdcurmz1CJ2+2x3lhKY0UOfm509vlPA55OcVtgleTt2l+TIq62fmfb6Hwho1 uzzabp+hWmQJ3kcWiHK/KFETE/MAOfUt9a5e78e/Brw+kMLTanqT+VnyvDU97IvllsnJdwo7kjcD jHHPPMoz6Gs5pLY8j8QfHy3FyI/CVidFgjQINR1/Ubi7uh+7wjLFveEMvA+YSA4+Yc8+fXvx38at 50cHizVpAVwEQpbqOc5BChl9wpH6110sN7PWTIqVLawPPdT8eaxqZlF9ePPIV2g73lcYHZ3Ykdu9 flj/AMFNviZfWnw78BeBbBpbaDxdfzXN6+8l5ltUj2ow4GC84OP+ma+nPbQglLQyjJ6tn476Job6 jDqLsZRbQrEtxKuCIopJAgkIOM4laIfjXreufs8X2meBJvHfhrxnoXiP7BJN9o8NwTob9YotpedQ rFXUAklQSVCkntntqYhUpJMt0rLm+f5o0vgn8TL7SZE06a78pIMzRTTlmSEryThfmPGW2rySMDqc /u5+yP461H4t6JqejWd3vu/DHk7xdON5jlLgYQHLYZT6/fArbFyTpX7f5/8ABOOEXztH3DbfDrR2 a31PU0u5dQhBRvsZ8iRgR0wm5m5bO0+mcA9PXtMgbw3Z6bbaTH4deGyYyXN3eWix3V1heMvEVQYw B9w8bs5O5q+bniXsj0uRQWv/AAx0B+IQt4mOq6PeWwiVma508tdQxxqc84G/nLHhCR06kCtrR/Fj a5Zwt4an0e6WY5jL7pJVUodqOpxjOTncucjnFVT95X2JaUXe/ctS6lqEkgWS9spltQHmRQ8hduRt bLY5f0HGDxnOKVvrNtCDbQWOo3l3M5jayiKxuGH8JByQTnPB7DirV9iGux2emxfbLWUCyGlyklfK vSTJHvxjIJy33cLlsHI47mhdalpWhiWecic7G2ySSB24ZSNv3QOoJPofY1e0rEpWZwWt+N9Z1RLF dK0DXLxicNEoV1JUDrIo7A42knGevYZFl4c8R6hK994pkazjcki3gMbBVOTyQOD9PyOa1j7m4paN Ipz+IrXQfPt/D+n6rPmMH7SjxoSQeTuVeOQecjGBnPfKu9R8batHIt5NNDEZD/oasWcAk8M5yfQd ec1ra2rCMnG9jHVL20uHeOwuZdmR51wuFJJA+8Ofu/y9wTFN4l1GFWBvr6IyqEMVtPI0XDZwA5YZ Pc9xj2xcWpGb93Ugk8XalcuIheW8C5JPyFunHBVwemMkg9PypXOuawkwdbuCdH5YiTaB2GFK855H UYrRRS0ZL0MWe6uJdsl5HcIi4yIl3ZOOnyZx65I71ZtYxcqgtRG8W4FhgFc54BAxjqae3yMU9dD2 3w14Xltkt1uNRgiZzn7Fbru3HoDnPbPqM9s4Neka9Fb6Np8MV9pMl2bgFo7m2kysRGW3HbJ90gZx 7HBGKxlq0bWPKNS8X2cbTppdmumsAI5LyEB1U/LwB16gHjnnOaw9M10TyyG6hhuxdcs00e3d3HX7 ox0XgcjrzWbjy/12YKooSu/6/rU/jhtP2cIysbXGv30ylQWVIdnzY5AyTxngHv6Cugtf2d9BQBph qk7BurMg/pUwrx1aSR11ItpK7eh3WlfBbwhalANBt5JNwH+kkv079f516Zpnw10S0UC10LT4mBBB jiUbvocVjXxaho2OFNt7bHb2XhVrcCOKxRAv/LOMAduwwBW3B4Yu2j2/2czlsH5yBxXHVrufQ64x j8Pe/wDkPbwNfTtxpFumOeoJ9iD1NXdK+G39ipMNK0jRNI89/MkktY1iZ2PckAck96zhjHF8qdkV CknJPt/wTej8EXxQG6vIo044Vck9sYq5beBVVA41xxkkbUVcjB6Y/wDrV51fF8qv9x1UaPtpNR6L r5M6fTfBtpbESSXGo3RPBXYCP5V39j4UtplR00i53Zzvmjxxjp9awlW/lev9fmZyjy2UdzZg8NxE gDRbh2XnHlkd/fpW/b+F5GYKmiSBGBI8wbM+w/8A11UVKV3LfUco7Nm7beGbhXmaeysbO2gzvYvv wB1JwcAD9Kp3/i34baElu914m0qZpULCPRg185w207hCGMZz/eC54qYxjewvZtKy2PQPBqWfi21N 3oOn6xPE4LA3ljcWyYXqdzIFPTsTXWt4a05o0nn1rwvp6Enma+gUZHb5jnv6fyrqhFylZIUrUpWZ gvP4RtZY/M8Q2l0hJBTTLO4nZcZ6lo1HJGOCeo5wM1O2ueGI1RrLQfEOoyjjzLhre1Vjt6kK7t14 6D69K1jgp7y0/wCGOaWLitEupCPEM0ciSaf8O9LupgB/pGpTzXLj0OAEx19T1755rf8ACTeO5YZP sFhoujQu2BJY6armPceF3ShvoPX3zXTSwMY6yMZ4mXYju7f4j6mixan4q1QRzZHkW04t04YD5o4M EfiOffNVbb4Q69qk6BNP1nVJHPy3MsLumc8nc/IxxnP9K7YxjDSKsc8obHd2vwI1e3dYNQsbCwPX ztSuQMfLngI2eCMHjjvXpmkfBg2ZaC6ubHzZDsVdNsklU544eQfe5HHUZz2rKdSytcIxta256DZ/ B2z0+H/iZNM4YgCPV7pbRVDHALCMgLkj1I9xXTR+AdH0yJS2neGoYl5Myw/a8gDnLEHJyQe30rGV Tm2NUnuOi8OeD7RbkW/mWtzcNi4j8PxtYK5O4DKw4BYEkDvzyfWC50Pw5tlGmP4iMiYn86W6kupj gZOBOZON24Y4wAMYqIxer2IlP+vkczJZeI94SPxReack+WjkltIpJE+bhCyQAA/K3ykZPzHnBxtT eG/H81nDKfFBnywLTT2y2okXOBuBlBwCefu5J6DirjCzu9f+GE/IxLvSbiK2Zbq8tLy/cuFe9mZU Y4zxtZsnPzYGc8/NjOEis/D1hCYr++tp9Rkbdu0mzWLIGMqPMZjnlsE56jr0rZabdTKS3RNbanBY R2sKar4guYIBtZrxIIC2QBuY28MQBzxhcdcdyTum58RzTxz6ff8AiGKOcJmAyeYj4GA48zcQTs6j B4yepJOyuLbVdP6/M3rXR9ZuLiRJIPsTuA/EmzcCc5GAPmO1cDg4OQCGFbun+GNE3yLeXdrc6hKy MbK0ld5ZR1OYy+T1OG24JPcji5Psioxbu2dEvh7T0M9rNHLDMsLMYr5UiKqSASQfnIY/hjJ9K0LS GLT4mLJo1mnn7F+yxhJPmYDAIyVxuC5IOCoz6nLn6D5ebXuQXmpTee1vazOyGYp5km5tp25yybQN vzDJ7EY4wRVux1iG9nv4vJs7i7t3EUjSMuGGAWYKDjB2tkZPAbnAOBXvsOKXR/1c00v51s3t7ScW Mc4CBowFO4nDgA4wPlbGOvbk1ZaeKyhaWabz4g6pG1tulCk4whyMqRwc8/fByaHLWxVnbQqR68Yo bmO1aCCKzGf9IYR7CHySQAMMVcnjBAGTjk189/tFfte/Cr9m3wK3ivxp4gj1nUE3x6V4d8L/ADX2 oXHHyCVcpCBnLMx4UE4Y4DVGm5NKKuJy5Vc/nK+L3/BSv9ob4vazqoh8ZX/gTwpqBaOLwp4Oma1S OIgKUeZR5ku4A7wzbWLNhVBwNz4Z/tPfFT+1tO8U3HjTUNQ1zR/ktdZu7lnubRWEitGsmfMVGSV1 OSBiR1B+fFe9TwMdlv8A1ciNXpI+6/A/7UWseJporLxhfNIr8/23OXDo2eA6ucYyMEqPlIIbkNt9 2k1Ce4BMk1xOqEHOflx16e/HNclWEcM+XsEqmztoZEmpiF5EeRraPH+sYH5uOcAA56ViyaqDK6R/ 8e6cieVtjMfovb6nt0qIyvqTL3rrsKNTncR/PLgty8Axkf4de9fnh/wUT8JXWq/D/wAFeM7Q3F1F 4P1CWG4Cg7YoroIPM6nA3wxr25cCtKdoyWo78tv68j84/h5e2MMt/ZX7afHp2u262rTamhaCJxNH LG74IITcmCQRjdnoK+o/h/bweCtL8TeNviH4uuE0rT9OK6d4U0Yj7PdXDeY3ltI6hXjZ5pWCoZCc AM2AWJjqeqZa9+Liz4L0i4bT7gSoxj2EkYOMV+u3/BMbxTqdp4n+I+sTXdyLLT7CCNh8pRpHmyoO 4HPCP+dddd+477EfDK6P1wuvHPifWZjI3iFrKxYnCxBI5WXd95QADznOOnXGcV22kxyXloEu/EWv ylxtdLgokZVhjady7T1PX1rwpUEldG6nvY6iTxh/wjyNFFcLq527ljgOWGA3OB7YzjjBx2OMG58b aprsawf2HdEgBgVtS5C7yQwK5P3ueOmPrUU007voVKqlZW/rUZZ+P4tPNyNR8Ta4Y9pBg1B98cJV dqhPMyE+793GDznk5rWtPirrJgtLT7HdXlj5jxNeQJ9kkXh8OFBXzBnABBA+bcMgEV1SXM0kK9tX uddpfi5tSu3gsbO/eK1G57nXLmdIFGTjDSNg5BAwGyTjnnjvoJI9ZK/8JJ4z0mW3hJEUKvE6ROuD nkk5I+XODz1IzVSiqd7GUnb5HQtPpVhajyLSbU4bhBE0dtIWVmAA2ARnAJbHzN8pzjJxWRcQazqr NINShhAzEqeYsAAwXBKjGOOdu7jgHHGUlZ66jlG9raMpW3hvS4Z/tereIbR7mBcvBp4j3sWQ7hxn kLke7bQR8xrPufEOjljaacZpbaMl4oCjKqlsc5YfMcjnOcnH1GqvJrQXLa1jnrm58S6gsdvD9isr SWTclq5bnPPVgeORySO3XAIw59LtbECfUJLqYByGW324PoucnBPoRxkHuK6IpLYlO6uyGXWLKS1E VrpTRhDxOyBm4JwdwVcnI/rWTawLM+4IsswBJMrgrwM55I568e9EXYyvpsb9r4e1K6t5JoJYkiUN 5jb1yoA+uc47ex9DjV06HwzNCIr6e5guIpN4kkhVw354K+nXvTvdXQRiu1jXWG9s0uHW/CWDgyJB LqKxscZ5CK+QSd3O0Zz1Ncze61JI6Nb3+oBVXa6uqFmGOQ20DIPGRkH5RRq9SJ82wC5juY7bTfJj eLgGaGZYWLEnJOcgKcjnP8ubjLZ6ZAZJUvluW4QKjOi4yM742IGcEj8OOaxqKzauRZuR/PPH4fnZ EkjsptrDGG4P+ceua1YPCOqTOiG1jhXB+Z+c8/XivnY1eWKcnrr+p6z5o767f5na6Z4JlGHk8sn2 QA9P/r12dj4LYMjLHhB/eGc+9DqptOS6HVTsnr0OssvBIIjIURqT12ZP4mtyHwhgKpViRxwf0rKo pSs9tWKGm7NqDweihAYlVjn7gzjnit2z8FIXTdChLkgl88/hz60lS5lyijd6Nf8AANZfA1uoKT28 K7m5l5GenHPXv+daVn4GtJQXisPOaTJGyEqHHY88frWMqKbt/X9f5m8WoWS8/wCv1OwtPh5MoEn9 kzw787XmXGR6fhxmrUfh7SbVYXvdf8NadbO+wfabqPfkDODtYkHA/u//AFrpUZP3oomVSKaV/wCk O/tf4dWZjl/4SWXWFdmXy/D1hcSbdp5yXRBg9OCazH8aeE43iOn+HfEd2zqRu1Ce3t4lPupWRz24 BWvQo5fOWkna5hUxdtI97DY/H3iC5UQaN4O8P2Y9SJ75gemcEovPHGD2rGu/EvjZ9RtxHa3S3Erq 32zw3Y2dgYcHgl2w5A9AWPsccb08BGOr36nOsTOqtNO5cTw7q+oqf7Y1O5iZ3Of7UvC+1sn7y56n r09fQ1p6f4H0oOdt3c3zIDuOl2TN6DGTjHPfB/Wt/Z8q5YoyV5bnZWXwy1i72iy0l7ZYwzfatSMY DY9nAIArqrb4XatbNbwy63YB5YyWisxJK0ajB52Lt5zkY44ySKftEtH0Ene1+n+R19p8IYo4xdzL qN4qIsh3GKAnI6Zc557c8HrjitK++ESarpd9pMtvoOgCcqBqM87ajeKRnoqYSOUNjDbiBt71hKpf RI0i97ndWHhqy0a1tLTUL/SZ4rRvmeJxbysuAMlFiJB4bIzx/eqrqHijQdOum0+LwtrN9axZaO+j me8TO/oqDbIWOCcBCBk9eM4WnIl2ldplyDx/9jlBbSLfRY7w+RDPrcRt1lY/w/vAuGBxj724g8jr WwdT8XassktobOwh2NIssUbzuuMZ24HLBSowAc84HFVFJy1ZUdBq2OvLE0k2pavKdrssUkXlSOQC SMMFznbg4U459M1Kuk6gsrSSxOEwd76hMqjLEBkxHnaO+OmPateVLREWdnpcinXTYUkE+ri0VVLB 7Yh9xzwo74xjLYBzzg5qG78TaZawm1gt9POWDec8hdyMAnhGwemCuOR6mlyuUtOxOjMKXxPJLtjN 8kLR8lLFQSxPGCxyfTpjH4Vk3WsaxeBHtdKvUdJMvc3Jba3IAzuBz19Ocgcjir5FtsK9tEV7Hw/4 o1R1a8kktrZdv7n5jsyzdMY5z0UnqcdcCuhj8G2dtcQx3V/55QCRnt4nfBBAI3EBFwRnOc+nNDkp Oy6CS0u/62/QsRf8IxomzchfYwY291coxVgB1XJIXBD4I4IA9zPJf2epNHJYwvb2+nhZIZBHIFGA N5UEHB2ORnjleOMCly3u2h3IZ5JbOMrJbs0PzeWbjfK0hJ+UjnHGSAO5bPRgwmW+laMyMl3YyABt 8qvhUChWHIOTlCMHqcDd0ypX3CLS0JZ9cukgZY9Suo03AplyGlLA/dPXggDgN0PHenwak8P2dn1C 5u7eLK/artIw0hIIxkkAAIV6DPQnqarRAvd3Nwav9r+0PY2ElyyxM8k7MiRb1IGQw4QFRkcEENuy MkjDufG3h/Qp7q7udc0aCd2+e0jklvLogIBsATIXOFxgjqeBnmV+IuZR6HLXnx90u0BjstH1LVGW UmK41RxBEmD8pAG48cehB/IeU6/+03qsWoyafpslpZzGHzZotMRf3YY4BLy5IY7T90Z4bp31hhub WRcZcyXKeV6l8Vdd1oNNqOqkSuCN8k7XTxcdjJkEAg/w8gDjvX4N/t1/FrUviJ8adS0NdRlutA8B xrY21urt5XnMokuH2kkBvMPl8Y+WJfSvTwsFGVl0FKN0j450bRPEfifUG03w1oes6/fxqXNnodtJ cyKgPLEICQMnqa7XSr/xd8O9bhi13Stc0K9jAZrDWLeS2n2nuUcAkHkdMGu7m5HpuYqPRn2L4E8U R69e6S8F5Fp9pISzSbgoiYryBnouADk5CqGyGEaqf0R8F+M5ptF02xtr65m8uLCPMxztDEFcHBAB AIB52shPJNRiYqqnK2t/zJi23y/1odZ/aU1w4UyStKxwFhXcSfb3rrtN8I+L75TcDTpNPtX3E3Oo IyYC5yduC3YjOMZ7ivNqWitTo5dL2PSdG+HGnQmCS81K4vppCGNkpESk8nBzzj5Tkg/gOa1/FXw0 8HeKfAHivwn4qOjv4f8AEVpJBdQTJ82xlAUrsBcyK/zDhmUqDkbcjneIb9LmlON2l3P5pfjv8EPF H7PfjrVfDl0b7WfCU0hbS/FzWktvDfQHlch1G2UA7WAyMglSy4Y+GXOpxvEYAGUf3O1ezTl7WKZz y91s2PB/g/xR471WLQfB+hat4i1ecFxYaRbtcOqKMtIwQHagHLMcADJJAFf0pfs5/soRfsv/AAv0 zQPHWl3Q8d+KlGo6lNdx+THvPyrFC20mSKNRt3YYFmkYEBlrlxM9FEvlvpLqe9aSlw9xbW9nYvaL fgiNYLfe02ASyr0ZxjHc4984rvb3Rbq1mgk1+GC0tX3LcmYSRSxjDfdTALMSEABwOevHPA7JpX1L 9nZGg+leFreVZdOgS5jlDK0kiSBRg4bayq5HUEnJ+97YNPUEvWeWJta05ln2hEtLZt8mPMJwrAGM E4wGAxk59a0jHS7YppR1/q5QtPhlJfXw1a8ux510IyvnYaOAqWIZEA2q5LkEjJ6DoBXp0XgnSdFj hvpbwancum/zLlVbncAvy7vmG3H8QPUY45bqcuxK97VaFDWPIvZWgbVY7VGk/wCPeGI/MvI8w8YA GWzzk4I4JBL9M8NaQ2+WbzJJYNrZdBHtY87Qc5L4A69Djg54ethb7sjm1nTtBmEdu0sVyg3Kloqh UO0Ko9Oxw3IwfqaguvinrFw8LwZtZIHyJInIkHAG7djggjIODgk44OKUKMb83cd90zjb7WdX1GZ2 h1+93KoURrHGUAA6jAHzHnnJ7c9K6vw/YanEr3WqzxyQozZWFVaTnAG0Bjk8E54+vBNdGyuiFP8A I077xhFF5thZWUtrCpA82TbK6joQDiPHvuLcgenL7bV4Lh4VTT7ix24fEznaH28sACQGJHXPp6Zq oRs11KnabsmI+s+HpZ4bGwTUZ28sFrS6jKNu5yQuec/LzkdDwK3NP0+zlJeXVfsUhRXW3jQ5jPDb uhycDp6j25cXtch9jqIvDbs4unvWkt5VbcVfyw0X8T7Nylj1ODjODg8ZOD4n0nQNGtEn0dZHuYpF JiaXckvB3MCOflOMEHAyc56CI3bsS1bRnlFxqeqzuIPt900ETZSIuzBQTnAyfcn+tCyTttOIiV5b A+bHv2J/xP4aOpayZDfMrJk6SHamLchl4yoKgnn3HH/1utTvcSEDd0kBzsO7A/xz2/ycH3Jcmmuh +ZVh4RRIoiqK4X+NgCp/z7V01n4ZtAUDFM9kb72a+LlUum3/AFv+B7jw7jFf1pY3rDw0C+Cfkb/n mjN+HNdhB4VD7YYrW4d8ZI24Y+3f1610wfK2n/TLhBR1t6/195t2ngLWGKTRaJOIl4aRw3HTA+77 nv6VpTeFtP09yNR1jw9pTR4LLqF0iSgk4+4CWPftXV7OT2V/6/4JlO0dL2RBd6n8OtLjdJvFgvpU H+o8MW0l2zdSCGIC56cEjHvVJvHngiJAtpoPi7VXBAW7uZYbNWGTk7cMAenY11Qwkpq70JWLSWhB L8StcYONJ8KeFNNTzfkmuVmuptoHRt2ELZxkhR9Ko3PjL4gXwZLbXLvSoXbd5Og28dqVHHG8AsR9 WPaumGFhFKy2OeVaaa6f1/wDKHh3xf4imaa6g8S61K53Ge6kmkQtnOeTt/Gti0+H8luXllhgnu3J UWlnIj3DEew3MMZ6mtopRSiYpaK79Tr9A+HniK5zcxeEL7VLWc7AuqGSNUOcZ3KVI9OfX8a9G0z4 Y+Oo7YaadO8N6Tufd50kMDTYbtv2lxxk4z2pSSTaZUY9GdXYfCi4hS6+16nf310oLImlW5kLNuIK 5OQMYJIGOox6V12mfCrRrNpGn0zUrkvg51DMeS2RggNgKWIwxHXj3HPKrfVL7zWHvNN6anVReB9L sogq6JpFtcPj/WQK78HcQTIGGR9PcHFUGTwzpdqVvtQikCvsjaL5ZAFGCAUwOORt2++ecmIybSQR 11MWbxVo5CrZ6c+oTwRjgsUyNmM569ewxz3PFUj4714I0Wn6ZZWiYOTOBvUnAJ6DAJP6mq9nzJc2 gm9dEZl54u8bXyQrLq6wrAcf6MFQkDj7wBz+f0qCPUr2acR3cmoahIMqRKz8beTyOO2M/rWvKo7I yU769zq7J0WR7qbT4rNQMq0o83GCpPryCSPyFblvrdla2V3PZ6fqOqPbqTt0wxxLK6lP+ehBAGDx tOexIINKo7NKxoko3ujhbr4nwa7Fe6VefDfX9TjlIAtrkoYc7x94kYBHB6Hlfxru4dQC2Nm0/hqa BuETTdHuAzQqOFLSMVIwoHCvg575IrOKU+hUmqa3+RqwaV9peA2/hrVNXu4QViv9XklmnSMA5USF yTw57/pmpYvA2ts8EawPYwINv2K/unn3H5wSxdiVwV4xjqOfVckYvXQWqV0TXfwfstR+y30viHVr I2qur2FoInhlOVCs+9S+chh8pUcngkZF3Q/hjY29xdyXK2OrOrFoVu7aUJgOMk4lO7AxllC9SOCc hc8tl0M+VW10O203wiLG1Jun8OR4mKobOzJkwuS6kGQ4PUnOenHQk17u7uLOJJ4LjS5YY4h+9hDx kPvG5tgJV9wKnGQAAMDkkTrJtMfKqdziLu6FtbTyrZzTSgNIltCwRJ8bCNx8s7B8oJOMcHGAeG6V 4iiu4JdO/wCEZUXvyqz39wZXmwR8vHIH3uijofl5yHaVloRfzK66Rd7DMLDSobe4YBdN8t49u1gH kLBCcblY8rn5MZAOTfP761cWNu9rL5RjEccxdQCUJBA6kMpwpwB6ccuV1q2OUbe6tznrGy8UeZHP Hpks8TNIv2aCOHazFgcksw2lvrntjFRah4s0zw48Nl4hjuftMsTJLfybZGVQFwXVHbY3zA4CgH5u uBTm43stWCjrZnmXij4o6BdW0q+GtJtp5vvR6jMCytlSM4DRuy5YjBc9uDxjzfUvihraySf2cs9h ZB0eKPKP9nKjHBAUuGHVZPMHJKhTitadCUlroTJqOrW//BOH1DxTrurBob281Ke1kYt9licRwsTn J2KQoJHB4HFc7eXc0TQXMFm8stsCoZWDOgOMgdWGcZIH93p2rqVPkTaIUnLRmJNrq3X2k397IjTp 5YhugYCnzEZXIDbskDqegwBnnPdNOYEQW1vyPmaBQzN6Enk54/Wqet7MIS5Wo9zKnjtVYtEiqFyC zdc9ce/Gfzr8F/jRZy/8Lr+KkToQw129ZQ4wdjXDFDj/AHSD+NdGFhy6FTqe0un0Prf9mK+8KfDn 4dza94y8O3GtaVrXiKa3vYIISsc0SW1psiuHDK/kqJZ3wpz87EbSuR638bNE+H/i74eXfhW5OqRe K7GC5utBOp2zF4XsbVZp4Y5BEheCWA8szMvmAhC23nCrUtUt3v8AguptCPNG6srH5yeC/EV1o8si ZaRbZtyxuSoO07tvbg4IPsxHevvL9m7xsus/Ezwho+ovNFp+qXrxSyZ+edmt3MkpI7b/ACgB1Ai7 jAr0ZP3LGMIPmT7M/YjS/B+jaZAl5bKkPl5/f3ihHUCTk553DaOcnsQc/eqnrOq2NpZRxCa5vDHi MLG5jBKYOV/u8AjqTy55GK8Plc7I3k9NOh5vqnxK1PR3nj0Wxd0MbKElQu3K4+buCMnAAB6A54Ff JXxh+PN/Hol7aS+J9e8Iah/pEsMWizTWkksiW0hUO6NyjyEDAORgNgEA1rGkpNxYc9rxT/4B5V4C /bH1C20nxR4C/aZ8MQ/F3wLdNGmm3mq6fA195RUBllwUWTYFBViocsWLOeAvhqaf+w7feL9S1z/h E/iBcaNO4+y+Eg0lnYRZwGLuHad+mQodQMnrXXGpOHuRty/lpt6GKpRu5J2b/Nn158Nv2p/BvwX8 J+O9P+C3wz8NaZ4jtbeBNA1CTw9DOJkCO8zXDK6yyTrmfy2CMpMUSybgTn9Avhp8RPEXi7wr4H8U ePPEM2qajqGjxT6rpmqRM901wUTdkAJ5PUgqFwu8KoXbzlWp8r5nuy4+7q+h7Jb+O7a1NsdHgsrQ sFHnrCrzKFJITf8AiTnafvHuKzzr9u7wzXV1fa5coSzRzSNKmQBuO8cDgbupHA4xxWFOnykpefSx uWmpXmq4gsLXT9IhSN5HNpkXDqEyzZ3ZPyBshQOncnnq9Pj0HRbQ3x1NJ2aIktGR8incA7IFzgkN /CwbBzg8Evyq3UuUU2XLvWdTuNkVtc7wrFzcRKFjcKAxI5BJAZeh78HqKzpIdUa8gWTVoXeJiEXH p8pbbGflYZbgjjoc85cYrS/Qlyujq9I8Pwf6LJc6neXFtJnfshwAhLF1JYZKYDMcAYClhjBrT1bW 4NGENutppgh2B/NmDhdq7gp3KQSCMDOc5/i4zU8zk9CpW7X6nlmq3Nx4gnitZJo0DvshhijIto1B bO3knJb37HqTxInw/mM4ivbmSJ2TzcQrs2gE/KwcZGeOg6OvOa35uRJIzi+dpk0mjeHNLWRLzUX3 SIyiKzfJX0Iz6Z9e/UU2/wBfha3WHTYdPke5yWY5Ln5dpfk7gx5JGOqqec4rWOhSe5nWmmX08cTr ZAefKIVupyEiDnou45yevvwemDXa2fh27tlH2mOdX5Z3gBI4Gdo9+vX0/Gm5OGliORq5011YwQwX Is7a6uJIoxH9ldASyE4Ysv3iCSOQy5LYJOAK4a51O7Ny00ukWoDqDvaJ9sh4OR15O717+9EPMzqR 925U1LVI1uLia3tBYS3yBf8AiXN5agKSQrHGdoJbAOTz1PQ85MjTb7qbUHUZO8zkIFYngADjkjvn 9TmXS97mT/r8huXNGxTjsb77TOo1OWe3wRFHdiFoM4B/hjVuv+2c7j7Vcgg1+2RJWttL1B8AmCIm I4x2Y7uvPGOuMkVfPo7owpu6uFtfXE8pSbw7faXIik4lCyIeeQGVjyOP88VLLPZNIypdRw9TslyG wDzjd/P2PvWSerQ5J7I+MIvEXwtthbrP4nudU8wgFNIsbl9vudyrnAGfxqSP4g+A7LzpNM8G+LtW dXUqLmSDT0YZOW3fOw+m0/hXz1LLG7OWjt+B69TGLp0Hn4vawsSxaL8P/DFg7uDFcalJJfyqOPvY 2gnjrgdencxXHxD+KGppIv8Aadt4fgJyF8PWUdpjAyRuOW/X0r01hKdNLq1ucn1iTltqZEkPinX/ ADf7V13XNUMq75EvryR0YDjJGcDtxUkHgB1H2mebSERSPma4idhnGGHLEjpnHTPOOK7FGMVZE77v +md7pvwxhndEF8Jyyb9lhbTMAM4OC4RT+BIHrXoWk/CmaCKZpYPOhmJCvqbQ27LjHG0F2IAzkggd s+qqaxt1Bx1Vnb/gHU2fwSNxcxm413SYYJmwRY5mfluBycdx0Ge2DXc6b8GrazR5bWfWr29gfoLe OPIxgAsdpXJ46np9Ky5uVPmRrB6vXdncw/DvThslv9IjZLPJFvrtyZDuORtKsTyRuwRnp34x1kGg 2lhF58t7Z2a2rBBFp8KsuADkfUE8nr1rGUm3ZE76Eep+L/CGnRJ9o8Qi7YLgkyecWBXn5YwcZwRk jI4PasFfid4TthJBoWiTXhkIjd7eMYmXaCvzf3h15B6ngmo9m+hUpp7DZPiBr14jW9noslkkpB33 Em0BuQDu4zkfpgE+vPz694kuEmjlvY9P2nas9mQ4dSvIYruA5K8Ntx24HFcqe5LbcUYixTXeYW1a e/ZWHmBFcqvTHTGMYOR6Z962Y/DWnWOJLxLZH6NDKQuM4AcqBhs5Pf19iU5WskOEfM0rmz03KCCa BWfMZGAysAeGLMQQOOMnjPPaqAg0qA75BGUclWgSUF2JAJI289u/17ZE6p6f10Ka5fkSodGVHjSO y2xNgxhdzFTjoxBPHHIwcnH0JJLSJGisbXzWkyAJEMnJHDhR6Hj1OB71cejbB+7oysuheINR37ni eJ8DzvLESJgkhSSxOeeD7VdtPBmpzRAtqFwzGMsYokDFSG2sDkdMZ/8Ar45vnje/Yle9pbc3rHw9 a2O2FZdTulTLbYAw4BJ3Hg4GwHrjJIwK66yFr9mmFnGI3kJfzJ2BZlDj75BJyOpB5B/u4pXa0ZOi vc3U1O7ulKMlokboGSOADftfI3qSDgHnjAJ3D8dA3unSyQFtRE1zLG7CKSQvjGMZbdtbC46gYZsH 7pznblY5O2jIb7xHDbx3draTW0MzFiY4I1KSqSQVTAVW+bgjI6/TOOmvavFAohljELsHMFlsj3t6 7SDgZzgZOc9cDkULag5ply4vrq9gWdLxjDOAdl8QMY+XByTubbtwcg5J4yOKMaTRxxreXsKJGoZS EXySCSqgYPDfKc+2eOKjm5XqKUm9jPeKG5nKRX7SsjlEuESJvukttbnIcZbntnvyKle50zRYZJdS vbe2VnYI9z+4VgNvAyfnJOQT7jIHO5S0tbcmMXs+5xV98TfDG+5FqbrVJUJZktFHlM2OCxlwCQx4 64wMZFcEvxduYoHjsNPtYJZ2G57omc5HUhBgc57g4zxzRGk5egXvK6KsnxG8S6hCqvd3CWoBUeWV hTnaSPlxnoG+vXmsRdUm2T77kwxTj50jkJEg9Dzg9z/+utlSUbtdBTbWp4D498WaWsuq6L4YsptQ 8WRbYnkXFpHZJIsm24cuv71AylfkD/NxxyV56zu72C1jW+uba5vox+9uIYiqsc9lLEgfielddOLS 1MpRt8yW41JyznzHGck7j1BGP8efesmfWbaLASZxJn5lClQSBn8frmqKtboZk2uWxDJKM7iW+Y7m b3/lmsG6t9Jk2y2tt5LqpAeAlCuQQR8uOx/D1zVcl1p1JbSWgyO23IPL1C9UgFdsh8/cScAndk8c cZH41+W37Z/w31bwh8SdM+JMltdnw94+jSM3sseyNLq3RYWXpgbo0VgT1YSf3eNqWkmPXd/1/Wp1 3wU+K3gzSfDl94U8Y6cdX8J6qUln05ZCrJcRn5LlB90sFIBU8HCnqor1n44ftI/Cz/hAYfC3gPTY 59VgsprKC/a2WN7OCZEjkieTarSYjTai/MFLswIyQXjKcrq2zNoq6vf/AIHQ/K6K9eO+knDbA+Tw PrX3f+w+t74k+NHh02NnNe23haO61CUsRGgTyWjUgkEbvNdBg9c9qrER90qnO12z9sL2DxFqayXM t28WJRIkjoieWw+YlieBgbewOBjFZkPhpbRjbXQlme4QyJHkjAMZMjHJbEeADnttPOOa85JRXuhF 6KyKz6Z9nMnkaPazuVVVmu+GAyTvxxub8OhHoMZFz4X03VbZX1DSdN1C4hdxbolt5zEhcqMDJyrb jjHIIGTmqV1e7MnpfuUR8DvBl6U/trQrNwpCi3uLJY5GB4DglchQc4XdkDGR0B6CT4H/AAWgtlsm 8AeH7zLMv2uO2QFlLMACDgt94c4GNw64wZlO/X+kVVjZHEab8Dvht4c1xPEmmeDNI0/VbdTCl3bL tAXrwrkqO/zD1IGcmvbNKTS7a0kjighd4ZARM+VRgy8gE4booGApzu68YpylzasHZpo7XTfDdg0L XGp3UdpZvIpW1xuboCR5Skv0bjdjPqByLhh0TS2u4Fkna2GEW+8lEOMMCNrMAJMAbRk/xck5NXzt bl3vYayac8N7PCHkQyiNnveQYzuYlipxwRjKk5Ga6HSbC+1S5tkFpYJ8yxlr6ZI1O5iFJGRsjB/i ORkNnoQIV23oLltt/X9aHo9lZ3dizxvbXLiAmNFEDTIcxtkBtuW5HUdD2zxUj3stmDcFLi1urYGN JfI3+Y+4Kyt5inDYwee3ZaSinohcttOxbXXNUlt44pJyI2cSCT/XSBQCq7FypLfe690wCDxVO8uT dys2sSJPDKNoktX+cZBySoJY5VlP+1sI55IqmrNocGmrJmxbW1lb3KlYLqS2keF0ijhRkibzF+bJ UnOUOcgErg9wDHqWoRXDRafYXVtNLKPKJmEcSsOuDuIHBzglhg8CnGLu9QjFdTy6O1jdjK9laXSy Kc2fC5+YHG3B2jB245/GprJZLWdlFtADITttrSNmck43AZUkdecgHv2NbNfgDStZHaw6ZcTCznlj vPJhZQ8FqnNqR90nK5HyqTgZBOM5JpdW1tNKa50+5nvob2AHCWyOCQWOc5Iwx46A9hxkZJPWyIcn JWW5v6B4wki/tGNLK0hurgyFJ7s7JGDL9zaikcKCCuOCeeCa5rX/ABNFbRxEHSJ0QOQ8UwbcGAA3 gHORk/eyeTk8YqvZtSaM6jt+B59c3cFzM09xbJArZZYrVfcAnLHJHPck1nBorlXWS3ZomYEQ3DZI AIIzwV554yenetWrkOOt9i/saJh5TbIgNu2QkbmHTGBnHt9OKsxXDIqbRFEpJUtGcEen9e35VhzE y2sQXkCanDtnLzpGQ7WqAI5A5HueR0+lOa9trOEERW9rhsdgzMB6Z5PH6U1Z7kp30Phix8DWot0n a+jmMhBa2tI5ZCgPTJVQOvv3Fek2PwstrlUFtZaocgE3Fx5Fqo4/vlmftkAoDx715sm1rsXR3u1u /wDI27b4Xsht4Lz/AIRywwAS9xcyTPJg84Vtozjt1984rp9O+FmmS3Zie8uLp8A40qHyVxkcLtTJ 7DGffjvaq8t9O+5vGMm3Y63R/g/bBMnQ725mXOJ9UZihU4IJxyOPxNen2Pw9sNLH2ua20TT2nCxm GRfNPAwcGPBXPHUE+/FaOpz6M0fu3TWv9ItX0FjBCLe5m1SZbZyAIIoodibT0YgNg8cE44FVZ9T8 GWMUF1Np9vK4jfBvGDO27qyleAMgcEHOB1xWdPmnrFf12Ka0v3GSfEPRoisGmafO8pGAUhKxHB+V gG4yOxx39uKl1438eziUx2cNvbk7VvLhhmRAAc4VuMnJGVB4PbrtGFldu5ManNsYVzqHi6+hQXWp +XJGFKxoGSR2AOcE/eAwxz656kE1iXNjdTO95qF5qGoSTsF3DJQDGSQ2cEYPIwP1pQklqtRLVrqX reyhintrcaTa27ytnzLk72Y5OBgDnj64IHHp1luirGMX0NvFKY0EEYDD5SBt6jDD5v07mhyKa0si 9/Y2lSov73UHEY/1Vyw3HryP7vy5x/nL0XR7FvOhitrZQgc+cDLMR1/i4XBJUAjnjvWMZPsJRexJ Pe6WqR+W+oXoiXH2dXCRoOrLwc846cdevNQ21te3kTMuj32yVSweItiQ8djnBGQcdhznvRy81xNd zo7fwjqjvcj+y5gZwyBmJVQ23djYATnqMZ79QcZ1Y/h5AiQnVnSKS4UAfZmHocEBvpjv06ZOKx5+ TTcPTyL3/CKeG7aKQ28K3MkRyNhBAIxuzg4xxxggnPbmtaLRXgeE2sYs942KRgtySCRgEKeQecA8 jPOahtydmzS2lpMo3Nw+lMrT3SPNFGEWONlRzuy3zYLNjOQT2HOOMVU+33z2jGC2eymdvmnG+QFG LDbgKMDlQCzEZPfsl5MG7bla5u2S2ghdEcWamMpM6F1+Uk9srkDoOMtjvVFryYqyyOIYP9XGsrBV txkHowznHGcDJJzwcV1qPO7PQn0KJ+03Ox57pb5QVWOQFf3JUjazIMg7lJGOMFsZIGDJFJMeAsjZ 3R/ZotsiMDj5Pmwd2NoAAz1OTtockyeR6XNy2uJ5YktHW3uFIOzClF2fKcgEk98cjJzjnGSs+q6X ZyW8kl3DAp3CZnYpEx3BQNxBHY4zjG7OBuArOV47F7r0OL1H4geFrFQJ9Q1C4+fzDDpkTO3Po7MA rds46cHHfjrv4r4ieDTNJQM+FF9qc25QuSSCkfBzux97HfHpUaLlYlxUNtTkrv4ieIpN3ma/cCIY At9OIgiULggDaN2Pl6Z/HqK5STXZ5Xd1j8/LbRdXRaV8HOeueeTz9K2VLl2FqpakEl0TGVWcu0Z5 YJsUgr+PP+FVQxlYSReYCQOFAbOO5x3q7WEocrLkfiCxksVjluZQwc7zNtRYzjGMevAzz/LJ4DV/ Hy3mlXT+DJE1q9ljP2e4BU26scgM2WX5c4JA5waIaX0uLW9tkeYWGj3lveza3q1zNc+IdUhSO5lM mYV8vcQigAADLMc4z6k4rTnmmkK7lkYJwBnAGM9Mfn+daSjy7v8ArYykknp/W/8AXoZVxJd3GFSR YWx8zOu5uCOB6Hr2qmLZyzYLzlgRlRnOfy/KnDmp3TCT1sun+Rt2PhTUrwRtHayiN8sLg5CnBwR6 5yOg9vx6e3+HsjNGn2tCruUO6MoqksoB5BbqDkgDocZqJz5dIlK2yX9aHoel+D9OiktrGNrSCWYF JC7lE+6G3MzgEY5GQcHPPX5eL+MHwh0z43fCrXfDb6FFqXh26BWHxFJcJ9hguY5TFHNBNE5VpgVc 7mAHz7XGNwbD2k179tFv/mdHLC2uj/U/nj+K3wq+JH7Pviu58JeNtMu7EZL2t+QrW97CfuyxupZG ypBwGOMj8fI7vX3uQVy3T8K96/MkY05p6l7wh4W8WeONfsNC8H6HqGvaxeyAJbWEZcZ9SeiqMZLE gDHpX9Gv7Jn7IerfCP4WXeuiK4vdf1dRJruv6IiNBZhPmWGNZByqDcC4Q7nLYY5ULw4ufM1CO7Bt pXex9FNqN0vmWtnqks5EbIRqkcbsIyjHnaEJOxj2BOF+huabomrXzBWvbWGyugVmg8gqyuD97eHz /eO0jPJySBzwL3b3NVr7up3mkaFYh7a4vobMwoylXjuP3y5GFZd3IJIxgl+v3iBkrf2HhuJLmHTL TUIlnk3wSeRHcShQWXaCu5xuUYALEZ2/KcYMJye5DVtTzbXXS4doru5mQRbwRNbvbknL4CmSNQTw gUEnoW53ALiaVpV1rRa6sb+W8uH2iN/NMu8qqkgD+JQOOo9Occ7v4btXsOXMrdup3J8LwTC7F+Cs sagriN02uu0EgL8p45yeh3E4ByJ7Wex0J4JVs4bvymLg2bZaVRlGO48r1+6Qc469KSfRk/E11f8A wWc/ea0b3yEtYWSSHcjGZBGI+doIK4z1/i5z1J4rrdDtXjVLnUbS51CaUsAl5MTE6thNuAPvDLEg cHgEEZrRrlVmJJq3X+meu+GbJEhM76bHPNcsxgtVTcioyFlThwSpzwOmMYzjNelWkUFrhrjRYrP7 VEAfLuN2/CuuQRlTk7WwTjBPXgnmlzJ2NEr6GLeeI9O02+NvHaSNJBOu9iGYhd275AVJPqPQEdSO efW+t2tbQQWNzdXQQSSTXYTDHIyewwOxwM55zjnSMfZ2YO1NC6fftZxq12Lj7PqaYk8yI+ciA/8A LMD5QrDapPJwFyexyZL1kWVbEpHf70EbZ+zyLg4CZO08bSCP9s5IwDWi1+Eq9tkcHcPf2uowCPWH 84MHNzKcKq7QVbBGQcnvng1o/YNXN45tLgzXdvwtxHH5bL0PGCVA3NgHP0xWt0tzPWx0Omaf4xRj fRosjyrIi3LxPc7lTg4UqTz0BxztOOlbd1aX2grDqmtW1ve2SuP30dsAuTwVYAq2S30zjGeuE3bR f1qRzO9ixpPjyaae2sLTSX8u2kBWfzTwFYnOGGF+dsdePTIFJJqWl6vaNqN1bXt61muDBIz2xhIf LbdpbenTLZHfoeulnCwSlbQ871vUxqG8G0jjVGb96ilpeAdgMjFiQBx27dSBXMyX8mmuJxZw39zN lI47sZVD/fOGGCBznnr0roem+xPPd6DpFaZ3a6ghmjwP3TR7kORnBHTP/wBf61fE7y7GbdCwZSP3 Shhwf06e30wKiUuW4SjuhkageaGmiJRiTEFzk554x/nB9KbNLOzu0bb1VhuI444zjv8A5FctloYv e41ldc7pnkMgGeMkcDgfr/kUK255FwZW3bxvbBH+QTWk4+RXfQrad4V0u1MhnvNPQGIoY4Iw0hwP 9oZbAxnn0q3LZaDbiQXeoMWh2h4VkCY2kcAMcdMjOBwfXFeOptNKxpOVtX3Ix4k8C6Phxp1vMWVk OyMM/Ixk8c59uO30tR/EZJGEWk6TfEQpnzrZfLwM4zheoxjqe3XtWsabmveRpCfKrIq3nxD1eSZT p1vFEv8ArGjEpLAYx0yQQDycY6flUl1HxVq8imO7mEcWE/0Zdnz9CSXYgk9Tx9AK6qdFRSb7CmnK yuQ2miW0zRwm4ubu4z5ckct2r7GBBOdoAx7Z7GuksNB8z5rbRTsgLDcIGjiB4z80mP07dq0nJWSY RTe/9anVw6JaoqNPHa2iZ/1MJGWIPJDg/ODyQMHOBzzU9nbaGkBWBbhYGHNxdlGLtjqN2CxABGCO vc1zvmvZscddia4vNHWFFkvIpUhc7bRTtePo2CMnABPPPTvkjGbHfaVL5sptbmZHlxG7OwVic9SR uHHOWJHGOKUYttLY0SWqe5Uc2k8yu42Qx5cpp8ZuHHzKMDOADnODk/e5BycX20S6vYBFa213BICw EkLBFePIUYXZuyck534xjhSvLcr2TJ5ebRdAs/h/qN8QZruWCXYC+3crofukAseSfvemDnHSu5g8 G6LZuILxxdkIuZrh1cBjuy5wx45x17Z5AqHUe9tv+GCMJJpM6qw0zSdOcwxWdo8DjzEPmRxo24DA LjGVyFPsSQamj1TR9MR7cLZrMh3/AGO2j86ZcD72FOTt+UdTgscnvWVTWVzRaGRqPjARXEPkWniD XbGRz/pVqrWqoCCDIfMCHbj+EEHkkZ4rPi8S3F2J7y3XRdIKB1W7u3e6OeNpAwcnqT84IHfrhKO9 kQ+xLcazqM1sLI+Sk21QdZiCxKpABdgJi6qp2jCnnB5yRxVZr15Ddte3kkV1IEaKGaXZKFxj5VKq zDDHGCDtGeCQXyqW7L5rXXYeNBnt5ZpUtLWJNzvOVjwhb7pxu3ZySDnP/AvVEtWWfawkjtopgrfZ iqS4B2tGxbJDkk8YzgDIOTib8ujRCbcndFOaxSzhQxXMUsXzxnzJMnHO7JZc8EjLE8bWHODVZjNF LBJEkMVtcD93eWoBQjKkE5z8x6HnI3duc05tpNstRv8A15HNav4m8OxXu+91uylu/MJbyWZ513cb QsZO4/NxnIGCOcVxGq/ELT4XhOn6dJqkMIXEmq4gxleRx8zZAPdSce3N04t2dtzKU+Vrz/Q4q48Y ai7xSi/j0tCdvl6UCoI5DYZiSDg9iOOOwrnLnWPtXnPvu7vy84e9mLlQSDgZ98+vB7dT0QpqNwu5 eRkvq98yPFue3i4JiABUEY+p6jP49hxWe+oM6ESHc5PBc/MT6jPPWq1uTCN+pVOpyMR+6ic9P3gB YDpVYXoUsDDG+B/EcAe3HfA/+tVWkrLuU1Zf131D7ZHLJtQhVLciPken+f8A69dJawRMkLLJawhD uY5Lycg/7WAM89OlYylbRAk3a7sZ/im0ubfStQGjT2suqPE5h+0owjMnOM7cHG7GcY718+/D9kOn 3aq0h1ZZj9vLnDm5wpfI4I4wRkDjbxgitKbUtXoTy6tL+tzu9jsdjRs4jBO6Y49ifzrQi0LVGKMb I20E7MomuEKqWx90f7WOce6+tOxD953W51en+A52eQ3UCu9soM0DYTb/ALPbkg+xypwPXu/Dvh9b GaRdMsLbfvURRyw7ZPmGwKSQWyWUsDgYJJztBFRKpz6LS5p7O+r3f+Zq3umW0Ygk1O/mK2zj5PN+ TOwMA4OWJ56N/Dn1Brj9T1mCxF3FYrNe8hBA6HCgMW3dmOOW+bP3skntnH3tVomVJctrnx/+0T8Q /iJoXw98XS6XoUl/eXlq0EH7o3CYlARyVUEviKQsVJwcJkYyG8z8Afta6hoGu2cnh7wBrfh74fy2 UOkXqXlsiJMULSfazZ4WOTa7sHiyDIqtiSKTy5YvQw8eS/Z/l/VzKrGUmtdP+B/mez/FL9o34GfH T4fnwJqdn4e1nxDbfvzbz6rp2m6da5R1Ftb3GutbMiZCuTucoWI/ena1fFnwmtP2SPCvxCs/B1r8 HfCXxG8Ua5eRxxeI/iXr13daHo85Zd1shthHFeDAYK/ksvmMArToAzXC9K+t0l9/YudraaX30/pH 6DfEH9o7wf4N8O6k+i/A7wT8PLPRroWS6ppWojVLBbx7dLuKInyovJDxuGxLCS25ipbY1effs4fE nxz8StC1y71fxZqfi7VUktme+vn2wWzSwh5FgiXEMEeWwUiVVXLEj5q86FG37yT1djRSc4xiz6mt fDWqeH2t77UWihWYCVZJ02tKp6c5G9Tz3IOCO3PoT3VvaRzQyp9tSPMYSCUMAVO113Yx82Dz3AI5 AFTL3tUKKcdP67nMT3ereRNb/wBoS29thEjSOZ4JAOQNvdgVODg4J6dDnV0/WtXdjbWcaRXbrhb2 bdNDsLZ+YIQAeTzkAhuQc1q/d0J5ea935HdaV4ah1BPPvrmJ73IeWS8kdmXBX5MYXywQyncTzlcY 5rSk0rSLWGzmsYdLvJo4jL9oRXlO0En5vLwcElGwGBx/ewM5Sl0WpfMoK39dzjY7zxPaNqa6d4s8 VXS6k7bdI1Iwy2dvksXESBA6x7mHAfgZHUkmXS9P10tJLqS6Xqt4HCDT7aE2oYY2xgqGJbJXGRt6 ZB5GbSdNb3/r/Mzlq9Pkd0mgaqLOO7GivFd2KKpFuw3LtyG2rtG45YAdPcnkjutAtdNig1WOeKa1 l1BVC3UtobhrRBFnIfa6o+7YCoYEjdweaxnU7mkadtty/pWs+HLuNrjSNX01kuWK7IrgGSI4+4Iw Q2CjbGTk8n0q/rU5ZEj0trVNzbkh8xgUaTbtPJx7Bl25G07sk1pFXs/uB+5ujzabSdfleaaeExJH mT7GqKpZCzfMCcjCs2Sc8YAyTzVS/ka005xfpeGVgUi8uYIrIFcZPXdhhgqOcI3bpstdOxnP3dXu v6/Q5611q/t2gK20RsUKMlvndHleA4HQsDnAweGxyOK1QNYvIbZo5ZXM0exYZEHmqfl2qpYAgEsA AfbjuLlrdFc3KzStrCGwnUa/pV/P5/yxiESKXYHqhZcdD3GBuBJwAD6JoTvClpv0DUoYEuEkighU NFOy9drg/K+WX5ecYzhSc1Ur9GUldWR0tveub7T4Zba3tditJb2VukkUcuAXR2UAgk5IGAPovUN8 WRTXi6fDp8U+pJeKySXV3goMMF2pEAWKKFH3V5PRSAKXKm7roJ63SIU/4pm3ka8s/DU97FFl4nYP uG07oiudvyn5vlHyg7c9CPJvFerjxBf20djbQx28QUiy03eIAxA3Kik9Nw75Jx1PWtoK7cmYyvI4 +7ulPmKI1V85aOIkeX0z9R2x/KsiXIcSGESOMkhyMKAeQeMjvx14rS6WrFGyTff+v0LMUjyuCZDi TnAGDjtnn0zV1Y4GM8ij5cnjO48knHHt35rGpdvyIm76NbkmRNsbdK6Y29cED2zzn/PeoLi2aSOV Ip3jnOVS5jOWTqB16ke+elTezuxJdtNS/FbBtqGRxLu5Ujg454GTyeO/FOa2gt5PKgkeQvhuF+8R 1Xj6/T61Du0r9CLNNo8Xj0vxZfjyr+a98uVvM/0fKqQDknp0+vp1rTs/CGo3ClBHcCZyCd3zID1A 56kH37AZzXne08hyjodFF4Qkg2lJhHc+aGVrlViABH3STjBOBznqe9aVzoiyLbJJd2583CCQyEqm AckYG0jIPJyT61tCbdmbwk1dki6XY2Nwk8OrmUoS+7T4nABC5xwc5z0x+nfTjn0aZ5ikFxekt+9j mdmdzuJG7JJ5Pt26+mkXeyNLtXu+/wDmXlmjiQvJdw2cdsCrBn8yQ5YEYCZP0HJ69KmXxLYxXU32 gTtcRDaksrm3YgcbcBshhke/J9MVSjaN7EKDauVW1G71r95aaPJvnbeqQkvuY9MqTwMYwcc9Ogrd bQfFF1eLCgt7eO5bJkMjSMvzFQB29R17e1a8trI0Ub38iVfDtpJczQza1cyajB/rItPjM8inbyHC gkAkEDJGcDpiu3tvC0Nrtjngv7cxop/4mbiON1MeRjaC2QCCMKQQeuMZ56kuXRkwi52l/wAP/W5v ixvLW3EsSWMUCAp9qtIgxRSFCyIzttbqB904I7YNZ1ssdrcPcrqd8soiLPbWayKpIILcg/N3OMZJ JrPlT1SKcZJuJykvjS3Nyw0/w14y1CZVWMNrsstpGV42u6kBOTgFmH8X59jLqGgzadNbf8I+mi6h EMoI/Jfy2dM4Zk3YGVJ2nOckAjjEpKRc1ZWuYSX2kl5PN03T725YYb7SmVO4dU3dODtAAXjGQmch 9prP2W/hWOAWeqsx8hIwsY3FieGbo/IzgEjB4wK19moq6Jbb0Q6ZddKT3RknigdkaZEG4dA+eMbg RliQcMBwRxUws7jN1EBLEsgba07C4lDbssxEY/3gPQHBJ6mH7t7BJXuW7a1izcMGuJ44ARNDACUU LyCcg7v4lBHcjvmpW1JLHyZrOz+zNbRbQJpjzgLztz94KCeTgHPIwKz5ubce+tjmdQ8ZJpuP7S8R 2GmrcSHl3KP5YDDaYl+fOW6YJGTn28/1X4neFmaeKK31zV5nYbJEfyICRhuS2eMdcq3Y54FVyOb0 RUZWdnppb8TitX+KusXShorfTNIiLYUKplcjDEHJGCeWOcdTmuR1Dxfq2qqLe+1vVdQhGF+w72VR wONo+QD5QenatadJQ1epn7TQ5uO/mXZBFBHbMqn/AFh5wRzg+mB696rXV9dXLGSabznk4b59oOCD gjr1H510xfKmgUntYh82VYhOGwhYrvX5VGMce/b17VG15IQyIR7ygc568ZP1/Ks+a5Ert6kLXMkg Zie24KwJJ9/6/hVX7arAmYPIp44OcnPfH5/hVXctid726/5kbT72AD54BxjJ6cH6+9N89m3FDk5G Q2OPekrsL6+hJHDJOAoLnnO84xkDn+ldDpunvvfyIrm6kYBQEGQDn25zSdrhytu7/rQ6aXSbe0sk u9dvrHRbGRtv2i8nVUUltoQj7xdmIwACSWUc5ritP8Dadc+L9RvPC0M09lcCJL261QSWUM8wi3Bk DrlysagM6bh2LZjIGcqvKtCoUZfFI9e0nwnp/nWQGmxyGVvMEsaMykjaxh3hsgrsJJA7DoRmuqu9 K0OCaNNRRTNMwjSaNSA6g7yS5wGYkdQefnXkgGs5Sclcu3NoZuraho8cd2YLeHUJ1xF5lvIhlllV 23FhgFmLEfNx1U84K1yVxr95q7xLENSunhRl+Y7NqM27AIOd3PcnlsgZ4LUXLRgpW2E0XwVr+qTC G3s5Z5bofacKq/KCDuZwCeCVGWJGOeMDIxdQ8CeLIrjUobLU/DyfvGAsYZiZmA2qCqbSdxOcY69e M83GUYtJDU1HRf1qRaF4VvLWeC71yddQtkbDvGfK9z3w2DyDx1zg8GsbxDomj3q3FjNpNnOuwJ/Z cib2Crg7mDZOeTwAAB265itJr4SYSTa5zxbXP2cfAPi55Z7nwpok8twVctaWwgESEbmLeXyPlAwc /dYAda8vn/Yr8J2zXeseGpbXRNQUMYhqtuuoRISABtWRdgkXKnIJILfKBxjelVlCOuo5Rsnba33H TfDf4D+L7TWvFupfHHxtpvxHstfS2WHTLu1KRMlr55SQqfkEn72XGM53nnAxX034b8MeHvCtt/Y/ grRNH0aB2MjLpsKWZYjrkDZuOMDd1+UHtxN+nTQOXlt/Whs214GneFGeeZB5MkER+0SKWTARjj+6 FAOcgEY6DOlb217ePdyWlu9qFRpGEUZUAAtuGeidMEYz8vXFNxS22FrF3Xodr4f8EWjXU6zywziQ SHyrcFyjAAkM2QQoUemcnHOQR3U+jeGvDkUkkV5F57tFvtYnEnk+qbivL43cFl4Ge7VFSd7RRpGn 3OL1XW3mMiSPNdFOWZQVjj3HdtB5B+b5845BJPzZNQafqkl9JHJHHGJoCWeKRV2hSV+6uDjvwoOD txzRy72JipN2OjFpd2kKF7e1EaynbMIVeZSfmdUUEZ3IUO8bvug5HSu80S3S8hjhn0+4uvmZibg+ cRhSVQ5wWYFc5HIOQFJGKzmrJibUuh1whg09Lb7NpxsLSNWDF2dvMCnONyKeDhwGGACVzkYy+S5s baO8nmu3+wQSSTRNIokk7NgKBkR4wSQfm246gkzFa3LjaTujDu7XR2iM0Unn2LMhgh1NPtUbsh3b 235Viu9cggjDc5X5jjp4as4Lhbaz0+/05ImUSDSX+yRLIQ6+XlMAZOQcHPB69a3jFISvsUr601t5 Ixpeq6pMwXh7sKcsxC7izjI27dpO4fd5xjA4+ytfFNtqCXUujpr6/L5zSstqqKoO8na7Fi/IACqV /DNXsr7kJqW50dtp93eySQHTrnyYFMj/AGYK+1go+703cqvDdM8ZJrb0/Sho0MWqywS3V2EMjWd3 HIzRshBYssZYscZxgEHPBPa1UWwO713Or0y5R2S91vV7DfKPLh/ta7Wd4CuGCMJD5iFQccA44wvX b1E8Vjphk1O4ubWDUNQieVGRINsq5csBGFG47iMEhRtzyaUt7IqWl0YOlQXGo6lNFIsKaLvd8SbI vOGwu2MscM+NoOc9cZya7CW+06zuFu9YtLW8jlMqvo8MwUxNE2zjadyECMtwDuyozkEVpy8zsCfK uZ6nhHifUJvEepvaxLp9hEkSr87sqxqDnBJxxhuOpz65rkiYHRYPtPz4AbzCy/MD0zxj0/A54roi rKyMbO6bZiSB5Z4lkdnZenmuPQeuBngcc8A1OvmRTSTTKkDOxIZ3SQg5ByQD07c+pHXiqkuTYOW3 yLcjxMscyD/UDK4AUhvTHc4zyPU5Jqwse5jsZ33kk8nBI/mfp6e4rN6E1Jq12V3ICKfMHz5KeWDw B349qasRG8oqSCb7q4+UdeeoyfSsajuc97NpFuK0LIkpmDMSBs3KrDtgAnP/AOvrT3jHliN3d2Ug LMoGTxnqeR+R+hxUp2uEb31M46qzRWkcNndweWTv3qDhRxxkDn25qpJdedJDLHqKxBCQ+ZNrL26j 0xn9DmvLhS5dbbmzlbcikj0kalP51888mz5YkBXaR3JJOegP+eLaSIsItrN2m8ortjdnl2lvvL33 4Y9eM46Y69Ovogi+XoXBp2sXKLY2mnXYV9rRlUAdF65BPOemTgdOnpr6b8L9b1WZZbqQWuHKtFLd ZkORx35xzyB0xmtIyTu0ayi53SETw54ItZXt7rxKNVunneI6doQE9xE2CRE2xj5ZxnlyO3vXQWmm 6g01wumeFG8N21iolS98QyLfSlR94hI2AQHkgGUkcEoM8W5c1+n9f8OVf2aVzoW0pbyOCCTWodPh iDxslmVtXcbsIu9ELfe7rIOoPHBO5bado00VpayWjalqFpcGRbi7DtDbbc7HLzFipyfvE9sA9QYU WtG9SnKz06jX1W0hnvG8iw0rTUm3CLU/vzZydxXhG5IA45wTkDgV7vxlHAoTULvSmuUkjZldREsc eDuC5OScnkZxnA71Mo2SVgjJ9dipN4007yGNncXty8ON4kby0YM33gDjOCBjkfe6v25e68T3zST3 Ubzfam+5FG7SvtCbcfvcBU28ZGO2Mjora6i5tLrcvXNzqM8ED3hZdyiNrmVScbiTliANpyyYY56j noabcaai/vw0lsocR7JtyIrbRl2Pzck4zwc46jPKfl3KSckihf6tHpaSeQtxcoknlrHBG7zyqM5J 2nPG3r23Z4IxU1nctLaRy6fbwRyFCvmSI/mSANliwz8vzZwpLfMF6jkS5NuzY1J3tY1NT8XadpyQ pq+q2Gn+RiSWFp4xLKW+bIRAW2hgQGwRhccY588v/jT4f02GEWKaprl8i43kCKBeucMwL4B4zjnn kZpxp87shzklqzhtW+N/iKWWVdLNnoiSygiSVDPJEpHzAEjBB4JypY8civPdU8V61dR+TqWtanex wElUDbAM5ywA4Oc/rWsKSW/9ak83N5HLf2pczbHWAwMOdxUZJGfmPXk+h9aWS5u3xIbkqpHQHJI7 ke/JrWPuomVt77EUlxFyVaScZzmQ4b/HPA71HJc+ZGT5/KgDCqcgYGCcD6fjTir6PoHs3qmQNcqq F2dvlG0yuQAM8YP4/wBKiF58zOJSyhvvRLuGc9PQ4OO9XdKyFy8y16At4gwpDDjb8x3EjOfwP/1u apJOVkYgOgYgbuxwQPb65qYpR0fUJ2ja5E0sjlgHMfX7ozjHfkUkkO518yWbEZ7kcnPYgccdee9H w2sYufIr9TShtLy5lWCytrm4mc7FEKk5J4HHqT/Ou40v4feJdSeR3S30y3ibaZLmRRyu3OB1PXAG eT+kyqRhoy0m9vvO/wBM8Gafp8v2S7YzXzAvucm3QYOAMtjrzgjPYDJ6U/Fmrjw5bJZ6RpDaz4pv HjS30WAO6rGzKPOl2BikKg5aQryVGFBbA4KtS+qN4xto9/Ir6R8KPFDeJ38c6/qOizXP2ONI/D5t ZI1t/wB4Xl2u8rkMzEAHAOEXIYgCvW1vLK2jQPaWNtCzbIbeJI5Y1HlkMTIAm5iVB5wARnJBwRSt ZWFOPK7NkUl9bR7/AC0+y3ABjM0aK2/dFuC5I6YAGFHr13HGDfW2oSx29laTNdSW7mTzWkKKgLd+ 20l1wBwO56kaptO7M1dal2Hw7HaI7XJvYDdKZIvL2l1GWDK2F+XLBgG5ABDAGoriDS7ORFa3W6nc KWLQbSi5UA4JIbGxWO1VxuYepDV3pcLdE9ipf+IrqCBILi5nugjqz3UG6BUbB2AMMgghcEsCCRxt xmubXV5pkjlYyq1unzmyBHmqM7w7NkISpXIVSDxnvVRgooJe90G/ZNS1Kyt0hj3tbEgSWs2QxB+9 hCTtHJZ/YdMHc+PQ7WJ1kR4vKGd80q+fBgKBu3E4Ykhgc8BlYewrdvQrl5WuYzo9MsY1kl+0eXMo Y7doVccqDzz27Ac+g6UbmCCTy0inMrwKyszAAZ3EBMN97jByCCAcjGOb1fyH3ILS0RhJ9lgeO4fa FktM8/MQxbcf7pAIB7fWr1j4Y1G8VpIIbw+T80kioUiB5JTd05GO/XqaFeBU77bnp+h+DNH0jzLa /mljZA7h7Z1G1sjaX3K5PzlDwQBggkENWtruo+Hsxy6IzPbRt+7uGhCDlizRqX3E4Qx5J6Fu6isJ NydtiJPmvZf8A5W71dLmSeC1Y/ZAqLE+353fcqttQDarcjoTnPG3GSotWvEt4bee6vZ7xNn2Irvd vmYKUByW4VTnqefQ1btHVlJqFvMW10B71Rum+y/OI5C4jXcpxnaB1IwepyScdjXcaVo+n2ciR3MD 6vcMSPOu0BWVipMbBSwDZLKuOeVY9wKcrbdxcvLdnbWlg86JeQjTzps4SPy7ZRbeWisqkbycOAxH AP8AC+D8prbkMzw2ermyhewtZ/MdlMcuMHZ5TKfmC7VLFkLcEt8oJxh3RW+rX9W0KK6nYaVM9q9t Z3UMtzIWa8kZVRiy7Avl/MNoRdzKx9sfdPKXEssY+3PbXaeYx/fxyCKOM8AyKFVSTk4yCec+22ow 7hLS1jVfULRWuvtWnteC184efGZWQOIyoYeVIAux2zuywYAjAyRWdPqE0UbGG8liSWMp5cJYtIhy Cq7clSdy84zyfY1oqelkSo+zehXt7y9m1E6kXv5op3Af7TJ9ouQARyTgZYBeDgD5TwcVv6fbJFby faFksfs82f38eSmASVJBHIPBGwHIzlc8XJdEVFc252Oi3OprczW40q7kurZ2aWRY44dyjHynAYqR hQGz3UbeCTvQT6peNdwXGlYsXAkDwogRY1wxkDbDjcm3knsDzj5c+VJ7h0suph6rLqls8Ol6cl7a 3N5HuCOFdGxlSxVt5k6srKeBjnJOBz9r4Q0q+maCRVW+RSrXkhiZ5WYtsRcAgR7ljGecZJ4IGN9o 6IOVwdht5aw+HtMtbG31a/1OLzhcMfPmkUSNglFcEbQAHP3zn+JQBlvJJ9R1W7uljfV78hmUyI4j kZFGDuBZd2eCcbiM5rejG2liJSs+5WmW7TebS7toDndGr2zOZY9pG5mDjJ+70AGM8LjmnHbamMuP sd+rM0gjEbxM2B8oPzNjO0bj7+3OqTTSsYuPTqaYjmY29xL4f0i8gt1DE215KrrnHrGMsD8vPHX7 1YuparqEV1HO+izx2+4STS2481xk5ICqC4A4BwD1HTrUSlv/AF0LkrPVkFv4g0aXdaPeLbyKPlhv 0e3dlHJIEgUso6ZHHXmtPymkRZhcrcLEOIbRgEJ7k8n/ACacdNzGer/AkS1nkUbkCYJH7shuOMH3 P/6sVPDbN8uxmxgg7hlTye+TzjHpgHrWOjt2MmlF3RIzOCo3cqPTBbjHrnt+nvUEYmj3SvsgbcRE yZ5GQc7vfrx7jtzL91WE9Hr/AFsczp3w78Syq8+oavFYpKoL/aJtoX5sZbngfl/jLbeFvCttHJFf eLv7RhiKsx0U/aXkyAAgEaseBjgDOD6VwqtZ2t5HQ0mrrX/hztNO0nwhbXMcNpZXd2rBMrdn74K5 I43MOpByBjuBjFdrb3Vnp8rW2maZplvI7hQloqFohkDkuX4BzzwMc8AVmnLq7ouM7PYvbp7wme41 fVrO2tkd5oLHy1Eh+ZdxZEByCpzhh9KoSWfhUXZOp29xqxfb/wAhO5a5iwrZBbcx4B75PTvwDrGn JyabKUlF328jSXXtK0yRraxsoYbUofKFpAnl7VPylO3AAPPv1HWjf+KYooTJqs2+7mO1ZJoSyysO ADkgFAOcYJDA8jg1tCLsmKU3KxzN34wtbadZJVurgF8gQBoUZOuPn4U5B7HJHAHFQQeJda1m8/sm FpfMlZEiSRSCHyMJ82Q2RuP8XXLEdK1emrLS102CKF7h5Jb67m1CKNPLDvIQgYFA3Qg4YgYB3A84 LbTh8Gkz3YhKWz2bmURtM2REF3ZKhcjeMHoDkEL6ZOcuoSWnvM3H0XQbaKa4aczbnIfT+MKx5A+Z gQuVYcnkjoRwKd3NAYGnsbC4uVtsIbe5mJ+ZApYfIcYAAOPp6ZqIpvqU3yptvYNW8QadAxOr31vZ ROSzxwSC2G0k7lVuWI746+wzmuI1P4q+CoJMWL397N5pZbXSkdREhH3C7k7hlVHU9Dz3MSjJb7BZ R3Zw2p/Fq/d430vS7LTD55cvfBJT83QBSOFB3YHbcc54xxusfEPxdqEiLceIryBVjZZLXTJzBC+T kghTtI6DAA4HfJJ1VLl3B/u1p3Ryc2uRiBreK2iSIlibiba87E4Od5UHGVHT3/vGsiNLqOTyzcO6 TDJ81zg49B6HHSnL3bXM3Lmu+39f8MPLMhImZtyHGzAO0g+uT1/zmofPfyiixptycOo+YZ6YPYe2 avmurjku6GmR3jLhigACfKDljjGevHf86iM7hBFsaZQoj5P3TnOfr/jmm9d+gk7Mb5szYLGNHjI6 jj0H1NNLvHsLbt6EnC5GQOMn8fypPT4lcc11Gs0IdpfIj6nDk/MB6e3T/OKaJHkZSoIA6YAIBwcA ntTit+4Rkr2sS7JU8tnRQWJGEHXGO46npWlY6be3cTm1sricW3zPsXhUGPmYYyRyOfcVsmviIs20 lsej6L8KfEmrxLcXUU+nwoTu89djodhbJU4O31boNp5zxXoGm/CvSrJ18wvqVyshLGZo0h2fLzjJ diCQCAPUZ61wyxL2ibRgo79TurzTdIsdNF9dLp2jafYjcbuaaGGJQyhNylgSx27sc9ywwOa5qNPE eu2Sy+CdIkhtpCjt4l16MKkkIlVGCR8SEgFiCQqOAnOCpHJKV3qtTaMfw/r/AIB0LfDzSldZ9S8Q eL9XnizGHsL5NPIwHdnaOER7o88FfmxlTn5itYVnoWkaRqdxcaPf6xB9qlRZ9SZkmuZw24FWMw3t gswU447bSeZ9lzbshz5dDX1vUrm7jhsreabUpgDEklztG0h+jgYG7LBvqwxnIFZMcWsXE1x/ZcIn d8TJaXMmG/1bnJVFxkpl+MdiDXXGN4q5lUumai6LqK2InOltPDdBBKNzq8e9sH7xVcgsQdwbJjxt PIqSeDTtIn+xyLfxPEEZPtciukqkMxc8/IADk5z82RlcGspQVSyuOlKUU7ambrOqQWlotnPZXE83 ncJKxAUMHBRlX5g3B4O07QuN2Qar6TY6vN9psbUy3hljkaRokCou1smVsElR8qtlh0xWlPRWZM5X b7lCbwwZ50MwukltgJPseol40KYO7AK85YHgED5hwOSHz6ZZWVrb3D21ts4U3zLIEl5DEgMv8S8H BK4ToC3Nc3LcOa26OYvZLuF3Q2VyqQJ8wLFE4XjAAOCCwOSeQexNc9Fb63PcPcJqNgLaTIYCHd8x B+824cZ/2ucE9K2Wg09Ul0OrttN/tdraK3slNwcKba1JRnZmPcZYj7g6H6jFdtpngX7ZHMJLoIls hD7JG3scD5Qqgt1OCpznEgAHBDm0gcXLRdPzOk0rw/ptvY3E0lvLNh/Ms98H7pPMiIA2hQW3blJC nGAfm7i3capptj9og0+TTvPWUyjzA8kL8Y3BMcg7m5ToMNuPyisW3JlN2/rseZa7r0d7ND5qT20w Blku5J3YyMzA7m3EqJD8w+mM5K88rGBu8xblnfO77IEIYDgkdTyckYwOefptGnbVhs+Z7aGjpOly 31ySZsWqDcblmAUdSzbicEgA8Dng545HsWh6CbKC32Ri5W7kCGYlniV+EVlRWAc/NjOce2DgRP3v dHGNrpHR/YpZZtOhsbjFxOTCFuIEdE4K+WQfkQMd25COjjghsvqTWyGxtoG+zQXxCwxW87Rzq+12 VVTacsoIwBkZAX5uoHPe17hytO7KuqR6f9jnQC386SUzC4n3OhAyqhW2AgZXjORnPB4Y5UVil3bK kcklvKuLh4mkLRBiMr13YH3ACMbSxPyg5rSnG2jJcuhLc6VNG6SwNDLK+S95Z3MNyDDlFEgO48AK ck5CnPUHirqGks8909ol9cJK27yIs/ZxuDJxhPukqCoHTbjI6C4dA5UloUbPT5jd29pFG0N3GPNj ms5AqQL0wJSoVFBcHdnGM5OAKS+0nUbmUwzTxZG598al0t4wXbII+/8AKCcE8e/UaRkk1fp/TB2l e/8ASNvR9EiW4EYns7nULJmL2QfEjHaW+5liy/Lyy5xyc4ya9C077VDd6RcX9nFb28pj8iexgleQ Mf8AW7SBjzQhA3AEKQvSs0lzXKTtHU3f+Jhbv9p04kWcLLJ9gtECx25ZiuPkUs3J24yckDOeVPSp 4lm0xbK61GKK7S3tx5FhawrMB87RiOYYcAYVTkhsblGMkCk5KEfMa8zzVphrGtN/aKxz/wBoCTyU 0xy08xxtMUW5mCPhVULtAI25wKzta1PT9Cmt10W1vLqLUIYpo5o5FBkO1Gf5Sm1o94kCptAG4cfL x001Z2XZA3Z6I8g1fXtV1S4ktLt7VLSyOBNDFHuQ9W+ZQNxHI6gYXtispZ7QtDZxwl9shaOVmBkG cfKSBhuNw6dTW6utImMpX0Ru2mmM91DZySXFjM4yYrkgmJX4U7SF3/3vl7Z6AVvpb3gsY7oLpxjn /cJNsSIb2UDBO05G05I7c85xRKTvohu7ObuLnTmeSKGMDBDB4jgY7nknIyAeO49+cV7iKweNr6Ef ZZQM3iINq5IA+Y44zjBwPQ1NR2VmZTXM7GvHbRFD5NvDLEEJdI1+QduO3Uduv4VTbQdGb/V2NvZj zA+bZPLy2SeSuCRkZ/POcmlK8HYiUl0/r+tSRNASfMdpd6tBKcOJbaQtj14YEBapX2n+MLOSFbC/ svENiiNnSNaT7LIpbG0xyoCBxkFTG2eMMuOc51HExirNtlf+2dRt4PM1LQ9dsYQoMlxp8K38Z+bA 2rAWlOcg7vL4Gc4GalN7plxdJbwarHJchQRYD5ZQmcbmQ4YHPqPb6EbPREqPK077o0JbPyryTy4o I0cMv2yJQFdQ2BuaXJ4xn7wJ5yRWNqeovZ2kwvb+NLHIZX1GdIRcdQNq8euep/IV5/LbR9vxNJS5 XdLbUyE8W2s0UYF3DqKygOFX77ADGwbcEjgKcE5wKb/wlwSR4ltrkgklbUSfuPvEnCnJ9s7h9a6O W7t2NYPua0PiWV38pbNIxCx3LIVTY5BOWJ+79e2OeuKnmN7cam7vCv2CTcokQgRqOAUUdOm3JJ/w p8yi/vKUeiM6+vtMjcSC7S4mJUExM7YwWGdqbuP0zn8MGXVr5jHGYEDIxAEqbT7ttIwGOOuO59cV nUr8ur/r+kdNKi4q7JrbxPqlrJGYUjfzCBtWFmI4xnJBPHHP8q1P7f8AFF1J9le2uJLmU5muI0Z5 X5zkYwBjqeDnk/SY4hXvb0OiWHUlqzpUk1hfs1xdm1t2ikZ5PtGxEAKH7xxsCjpz1yRg9KoT+N9L RoPtusyyvAhKwWjNcEDYdqggEdj1IPTpiujSpsYydtEv6ucJe/Em7ZGe10i8Q5dwt3cE7nYgB8AD 0PAC5yeT35LUfHXivUEnsm1mfTLG8k3m008fZ4n4C5IB5/PFWqStqZN2TXc4iaESTyPJPNOzjGyd jkjHBOODweM57VKJ/Lh8nb5SpgARfIuOhHH0H51fLbdhO667kBuUaNo/OMk+P9VEvB55yex74z0+ lQo8kiH93bRAtkFvncDseDgHgr3GP0nV38xWcVb5/mTlV4ZSNwYcAYXGCf6fWoZJVL42NMTg5xgN k9Mj2P4UuV3bBe7q/wCuhUlUzeZI80/mhwQibdpHPfnngfnSCNPMVN6SAH0JOD69OarSXuopxWye xIfKjkO4M8g53SDk444//XUDSkJucZ2kYUADHUZx6VOq2CL9n8gRW+TckisvPmD7pOO+Of8APbFP jihUspUo3dG+U44+vbBojt/XYUpczu1oaMMMty8cVtD9paQ4/dg7m544x7fXp9B2tn4B164ZjJbt BAgBMkpCcdQNpwcnH45H1pO1LQiMXI9T0b4caXpfnvdXdzeSwRsHECABck4bAYkjcu3IzgsM7ete j6d4fGmxw3GhxLbmIlUeKEMygqSTx8x+XnIb0GRnjinVcvdWxuvd2NS38L6izSLcW1xatLh1ZysW 9MqOVBBDHI+UjJIByScnF8eeKNC8H6bp9q+n3GsazqF0LeysYx5Ul5NhpPldvlO0KXLAjCoT6hs3 OysgUVppuZfw98Hw2iHxD4h+x6vrmstK8lzOzObEne22I7CwjBCQruAJBJZs8Hsby3upWM8cz3lm YihgRWK7uAjhjkFQw3EZA+YAnOM6U423X/AInK71ILPSLxpBIlst0SCpMVuEWU/LkElSrYAGQWBJ b2Obcfh27nElqZ5poURJbqGCHdtddyKSCwU7S7bQQ3DMOC7btJdbLWxLV9LmneeFrbT0N7FazXsp ZBby20irtcE72bAcAbvm2kHgkDhgazbzU7K1t7gPHGz3E6+XdzuBE2yFVwNilSwAQZ3ZHGdxY5zi nLcttS3exzGoazbzJO1rqE08sqRD7Ujo4uN0gBjLYRQBwSVJGQOPmzWGnh+5nvNRkmjmSC7QD/T4 XM0agxp5rYflt7fd4GCcj7tapXFFczsdpa+HNM0m2h1K7t4IAJJVhuiWkZWRcJgKMhiegAHbris8 WssQR9HktEj3+c/k+ZOyxtsLkb0xv3FiFJGOuCGDGYy5tUS43u7GDc6hNGIUW2kWGIGaRLtDNDkK wDgDk5LKq8HaVAYkLXHXtxPIk7Opgyi+TI6KoA3jGAyhnyy/eDHOCMHBrSMUtQlrp5lJZr6VJFnG 9ImBzdl8SkqDgxsCpBTaSCm0he4rqNP8JNcvK16s1u20sPORViD5X5QMBegxgEEFxknaQ18qitBK L36nd6dpkNj5WYWxagodQlC42iQAjHOfl7/MBznOMK+XU7zSrK8UpPZJev8ANGsUrxSMrsWc5Zt2 1Cdp3MMnguQcZcvNqbJ8rZzMuv310RBealHewxl5EEUwG15F+Z2zuKlm+91LBBwAOOaF0tzujdpb q5uCFJjKxq3IKgAjkgn7oA9uBmtoxS1M5Nv5DG0g3aT3Igj8gs6KzYcyOAMqEG47sEHuecjnJroN P8A63qF9aTTNAsUyNdG+nuRtEfls2SwJBZgrYXKk4UAEnBUpONkiXG6PQdI0Sayu/sdv9qtblQBL PcNmEbUZ3RlYAoQAqZO0Hjgg89rJeaTLfpctJawRODMthbq88ly24A7MqUBZiVxxgkMPmyKxfWxr TjZWME3aQxtNHfXEdzajbcPCks0WcKrIwUkH5Qh+TJxg5zipr7U40tVhl1GcSQxeVBHeJFJGYsqM BGKsp8sBGQFsKow7Y4UY2srf0yZSvdMxPMujCk2ko0tlcrun+xMQ0RyC5G3u2eCwJzng4Nc7JZ3F v9oUT3XnTkqmY8tkYwdx+YMT/C3rnnrXQob3FOXYtf8ACRanpkFvdJJJpk5l2K6XBjkQLjMmQSAM sCQDkEkjHIqbz7kagJLxrK+trJSSblA0bOQxJBIPmbgBy2Rg8AHNJRux3erZuSQRXbWkTyyG3jdh I7kS28gPSTYSCR1P1B6V1Vz4bntoYbjTLe4Zw2+O3nDSQXQRFKxkAg5J4wCOvGAeYi+4WSd2tiTS /DtjplzDJqTXH2hG3SXloY2aHdkEEEghQ6txtKjPzNgg08y6DZJe2EGoSXE05VEWUuwPTc0hKBlk wxJGMEDvjm0+ZXf9Ibild/1udrpVnqN+tumpC3msorkxG7abNxKjNukdXlJyuB8xDbfmyoycHB8Q 66kl7aWtrYvbaFZMrCS7lKNI+MtIgfpwwXhlJbACkDbUw99lynf+vmeY6v4s8PQIjadc3c97cri6 SzhMAlX5Sy7pHZl3Mpz/AA4OQo6VwuqajeatPDesvkW0KeWkhTBKD7qD6c8+46Y47IR5bJ+gqkre 6ZFwDNOnnLFBBbcGKLACgMe31I5JJ55rsrbwtbpbG/lur2wS7tjLaztbtG05VyHKnJO0cYbAHFVr sjGUU7tFKd9MiSaJLl7xxkKZw21SBgMCcj7rdfdsY4xzUU8iyeRbAs5BG1fuEk9ecDPOB+FNruPl cXbqyxKUgigEazQLMm5muFJ3Y68kDPIOPTJHUVAl1vIZlO9eoOemGGPXt+tD03MneP8AXyJYrDTr d5XsPP0xpX3MbNvkJ6lipJDE9yR71JG19boscF1DcyBc+bcJ5bkerbOB25Ax6daztrYzk9eYu/2z f21rM9/p8kcgwHazdZEJz8xBJVmxwOF5zUWn+MtA1W9i06LUoI7yMHdbyFreZhu5yjYPPA6VnKPN qjJRclodfPrs32Y2sty0ts74CM6KxXH+znDY/vEfUcCud1AaPelQRFcBv4LnbhQDwR7j9PU9Ktaa 21J577f1ofPumfEDxDfeJp/COoNp8eoabDEt79hnYsHfsoMfz4x2ABHHBNd3BG8s4jZby8cgg7gJ JG4IyPlwgJwMYJHv0rmU4zimlvqay912v2/U07LQZHspbl4DBFOwV2aMucZPcHjB4wP51r3uihVU 2cEUNsjDfJEQ2DjgZwCTwecnjnvWMnyO7KXMtf67ki6VAryzNcK0MBw0Nmzo85OAXIP3l64ySMA9 e2tBoVjeQ3MMKXksW5CVli2tH8x427ueD97oC2MHgmoyurnVs9NCu2gG6f7RHp/2K0JAlgVDIqp/ EcFgdwweQcHJ9jVWe+8JaQJ1k1jTnkMW3yY4xMyHg4UR/d7ckjPQ+0Qp303sae2cn6nI33xH0uAx LpPh+OSKIoPtMv7kgjkkAFhtOAOD2I57Zd/428SXtrxe6dpzXbM7R6ZCTMwbAwXcnAwcDkHgg12f VlHXsJzk+tzjZ2a7aBbiW8v3TK7ryXhRk/dH4k4z1NMRU3o9vE2FwFjIzkkdPz/pxV8uiC/fqRXL mDeplSOBMrubBY4wepHTIrl2u7CWaVIb7fNKCpWJg5wTna+OCAcEfTil2SIlJ7rp/X5kTARyLKfl ZMjYMfn7g596cY1doS0bsrsCUV9xA9Accdu1a26P+v6Rb10fRiq7+aHICllyQP4h/hmo0VlBBTOF xlh9OTiskuhnDVfeOWIJsDKHWQg7UGdx9PrUpYIAfLKsv8L4bP8AkGlKLl8x83I7sobJyxeRYQi5 +dss546Y4A7jv3rN+2aTunhF9Y+bD8xVplBQDsQO2PXP6Gk972Iu5aLoRW2saPeQpPaXv29C5jEV jG8mW5BIwp54P5VqWSJqMyQ20N5PIW2Kn2eVcnOABxyfTrnHQ96VoqxT2af9W0Oqi8N6j5ws7iG8 snKCULexPCjoTjflgAV47Z6e4r2PQ/hRp1vZJc+ILk3sko3JDZPGin5AVK5LF87vyGSB3wnU1SRX spRtJf0jv9M8OW+mvFFoumW+yKQA3LCNZJAzFto2MDu9m3cdscHpRp+uQusuoQQOZGObWN2DhdmM kZLLgOv90ZXA9uaXvXb3RrvbodDpmmWkKyQWEMFvaq+4wzsBJEMqXcPuUEkg8KP4s4JORLcvaaWH uZL+4hiR4zsysHmDkFvl+Yrs3Hdjg4OORUSXO7JC+G7Z5v8AEn4njw9YaZb28FtPrmttHZ6dpUss ELTTleXTIBcBSWZ+SqK+UwRt5nQPAlrPJoGp+JLg+J/Fcfms8t4HYl23Ze3QNtjR1k8vChjhSMil Gn0HKVtV1PWrWCyisbG0sFtIrRpfMLxyjzsDg5Xbhm6Ic88jA7No6bJpzA2l/eyvh1kP2RTtjUKQ GbZxku33eoJUksyDPTP3UYxbjodN9v0uOCONolj1CMLPHLcEoT93gIuQWB3cM2OnQq2cS/1YxCKD TkJunIjufIwNwERfcU7jgEYOcBhxjJmyk+xTTu7f1sYMX9rfaxdWkUTWF4zZMUbpaPKVUYYk5JBy Sp4O08oScZ15ol0sk0GsX2n3GnpI/lzqx+zgDeomcZ+QmPeSQ6kCMscg7qU4x2Ml7268jsNP0zR/ sWnILx5/K81bWG3hJW8ZWXcAWACqvyHGw8N1XcSYL7U7c2etXdnqGmmXTSUaPzIZJDKyKuHSNm2/ KmQNrbQNp+aiOsi1HmWpi6h4pS/ubfTrGO3vXSNhsvD5byAcMeF5yVOCoG3aBjBzXDXmtvJK/wBs m1ez1C7cebGyjDAkoQOeVBL4BweSOPlp6w/rzM5Ta0K1lbX2oCZA0VhEqFIZyIrmVAz52sIo+pky ApwdrAH5enRf8IGZ9Ne6uEjS4sgj3N/ehTHhSThVUKI9sZwSGbvkYJxXMo/M0V2y3pmnaOBPCzm+ hsJGf7RBIbZmaNTwqyFz94jDHGRzsXNVf7Ta3uXijuLmC8RkhLq6FjLkEBQMfJlxk4J467eKd3Iq Wjvc4+81IeXMJLS0gNsv71yBCZWBDLIfm4HIJbnlBwMnOdHDqV9ZvbSXN1eQKVhCMWXaNxHllgSG UBywBAPz47c9FlHRLYmTuiSPRpbdhNaWztJOylJImYPuDEECMAnAOBySSGU/LnFdnpXhyZoI9VuE EmyTekEsbQSS4GN4JUglAq7lAJIZT8vU5zly3d9hztFqyOks9Ne3hEb2cH2hV3x6nBuUrhlEmEyM MBID1HLDIAYBus8mTT30coJ9tlG4MsUDZlGWACg4xyHyrsMc9SxImyd/MFcxtRV4Ibye3trN7eeK S5bzo1W8QIRvBDbW4w2PujZHkgZzXOqby4jF69ynnZOJRJGsbbiwEYzg85xgHnG0E9Q+Wyswemha e8mtYJYLlYpkuDvEy7Q8O5kDSFQRszuCjg8ycDsa1/qtpDJbw6g/9qFvLO1d0TYCAKCWy5ULkAnD EH+HoKs5aomSt5HPw6pbTztJeLFbeWE2LYr5SrjgMzEk5DEd+doORjl8moQPCybYr9iuZJY35kVg uTjoqgcZxgnH3sA1dhuOjtuiKGOS6FvNGjm6uXEgZkMysynA+XHzgFR827HBznINdSto1rDvtrG+ mtHKJNHLC8ezhQu5wWXJk6Z67cADOFi6voJa3v0OzjhjvrN2ubVfsxgCDAjgiiLbdzsUJwo2gHBH 3h8uW2mG5sLBYLqNNYiiFyiHydrtFats3NwJMsGdjt5/iJHBAqbJ2sXy323C58U/2bciIX0FrEG3 jUU3TMAFLKMYJYnhSGJHHJIICcveeJoEsb61Wza+vI2K+fOmHEfSMdcjBJOSNxPfjbWkaaVrE83P oXrXXvEeoWUzaZcX621rCZ/+Je5S3dsKWD52jIYr90HHPXiuK1jxZrF1BcwXM1wt5cyHzvmZ45MD hihP3ie5z1I4422oqO24r236GFapbO0MixwEbSGlV9xc4JBZeCmTnKjkjuamjh1GW7W6mZI0fcqx oxeNOpCYAHQY5wBx14zW0ZXZK0aIorWWSZJUjmmlRyWV1GF2eik9QTzhueBxWnfW2sW2nER2cf2S P5JLtbcxxSB9v3wB83XoeASADzVXjHQPiluc+SFgeJ5pEeUkM8ibl5PQDIxkMPXpUP2jAkjVcM6F XjwcNnrj/P8ALmVoyXLk1ubmm65Pp0Nzb+Qk63KGMRynDxnopTOQOTjGOgx9Ku4sFLzuFdedx8sk AjORnHuBmq20W4r9BQYTADtV4nG1fn3H6+4z+n0pIFYPG+wsMDbsG0MeT3/+visJfu3a5hNdEXlm SdEQpG7bv+W2eRu49MdOmaR7W3ZNghtx5bYdcjanzAE8gYzx37fhUON9H1FDe/cxb/R/Dd/lb7SN Iv5GZXBvIklEZDH5hu4U5PX3PSqz6BprG2thpllGFXMflICgOOCAAORwK0U3C1yfhsl/T0PPfit8 Kb7+2IvHPhi01G28R6UwZzYFmeYLxt2jI3HGAX447YrM8J/ErU7j7Jo/inSRp2tpuWGK+XyApU4O wMwLHoSy5UHPSvHy2fNH2M3rDbva/wClzrq2mudadPuPoW30S+vtLGpzSpGuFPn2w82IDPA3j5QT 8xxnOPpmqt3qPg/THjk1XU7N3syQwa5S4AwDwix7m+Yd/XuK6PZym20utjPWC0ZxmofFPRIZIv7L s7ua1TO7K+Ssi555JJGBxwO2c5648vxa164Mj6Kmm6KuBsuI4ftLogJ4JkyAxzycDOPYY1jR5d9S 6cuZ8t7nC6tresahubVtYv71v4oFm2wbcEYVV4H0xg/z5sTuGia3LeZgMxTkKR065wOf51001ZWR vdN+6TW/2vzpVlmaHcAWkzuwOOfenm9UhGkN/duh27rdCqEH3bAxn8a1vt/WxEOltF2YsWr35dhb 6VOGiBCzXcyKW9SANxzk9xn+VQXZ16W7miur5LNWAzDDGVkQhu27I/8AHB/WndO9tf6/4BrJe7qj EuNEsZHD389xf7zllupWkRXz2TO3t/d4q+kUCRLHFAkYPyjgKg64A7Y6fnRK0+pF+azM+W/sYneN ppVZcnZHGz5GAD0H40rX0PlstvaajMM8honTafq4AAOTznHNZT016iaunb+uhXN9qUsKNDpkdk7n 719KNy8/dwmRk8chj9D1qDyvExlzJf6TBHGMGPyHLHPH3jJjrz93oKuavrYiM1J28v8AhyRrTUkV PtOvXSHP8MUS7hnO3lTkYz0weDz1yn9is/mPc3eqTSKNv+ueML2xiIqBwTzjP1PROW7Ww+bm0X9f 1qSweE9NuZ4WmhvbqU9Le5uZpY3+XoFZipz2B9RXrOh/CbV76CCWKCzsIQ5QrcyxxN2GNvXG7GcZ 6iplU5Ny+WT6Hf6N8PfC1hP9n1bUIryaZCqwqVjUMFGT3MgVsHp+vFd3D4Zu9FsbTTdO011+ceUk sUsX2nzFwWAY4KnAPY4ZfQY5p1eb3WCjytPrY6LT/B19qdg0N6bK1klXyWhnjR1ucsw3qOuSB90n kKzZ+Wsr/hXv/CMpdWeneLbzTH3K4sJ4YbtBhGbaVKAqm4k88jkBhjnC6eiNYxafkXLHxH4i0xLR dV0C01FnTfI2kJ9mZ5GOxsIcnftdssN2NpXuSMKf4naoniK/sNX0TVbfR4UV4dSngDERna+5zGrq igHbnagYHdnDEUnDrJAknqvkVk8feHdTS6XQ9X03WJwzJFaaNItw8ingnau4ABigO7gHALAc1kXs t7rV7MdM13TtGsIEZRdLOs90y4BwPMVUEm0sAcsQoZjzkDeSvpEnk7/0yxpXh3QtPkkvrWBL9p1k UXt3e7ppQQzrIm4FVUHcw5KkE4IHNdNcxJpNlaXcMwtTZxFTHjyLeRnLbGyCVjztYL/eKtySaiEe V2YpNt2/rqc7Jc3du9kq63NqJmfIVWZthMQHzYzuUFsdsnbyCMhur+KLiG8utPtYbqe48tNkCn94 ZVfduIJIYg/KSFXgDjjnRQ5vhJ9podD4fv8AxNqmoWenzxposuq5untb8iDzYwzjIVlZiMxyAPn+ HC8g16fpWiut0qvqN9DdqrXMV3I7Wy+Tt2q2G5ZghwQM7lyACuTUT0t/X9bA9dPMh1jxXFaQ29hA 9/q1h5LjzI7hZo1Kt87mMZUqQhyWVewPGa4K0v7jVnMSW+qAzb/NKnzBvO6XayqgAwquxDEYAz2K kVO9n6jaeiOV1DxVmedoTb2tpMebxlE6MDEd2MjaWYRsDyOnHNRW2tad5F1Pdsl1LfFlZ7NGa6WN V5jf94FCkk/NgHjAJC4ZxhomZqTd09gg1DV9fnNvbm8bT7VAot7UNM8EZkx8jfeTMrnI+b5pMkkm u90rwuLSG31S50w21u85kJ1B5meQYOQSjiQYPJ5LcLjkBi7Ws1/WpSV9zpLmLTLPbNowsLfUIUW3 uv7Qdd6q2QmUHzI5UZYuWAwM4JAHO6lqLTXKahbxzwSzbY7eSUhdijOAT8ilRluERc7iOP4sI6tu SHKaitOhiyabeT3pYWIimto90t0IiuxG+UMNuV3l9uDjOAvpVVLG1tkjjsUaVro4NkzMTKy4KNwo UYQA4O5QdpIYcDoilbzKktDYl0/+z5ZLW5ihia3PmQxRbmLRPH8omDqBtcBcH5vlfj7wxcs7F737 IzxXCXE0reVDGES2t3JXaNka/u0O1go5P3DwFwVurIIxcUbGjR6NcXcMaxRtNbtHBLZMHRnQ8u7b QH80FN4bk5QrtIIQS20uikaXa28dibmRXWe3ufMWP/WtgNLvyx3My5OBhowc8kxew+ValWXV9Lee 3hsL9haOhWS1SVWEL7GXjq0eQpJXaMcndjDVi6nqtisplivLO7uQwX7TbPNiQAKGkZSWKkhTlAQP lBG3LbqX5Eub3RBceKnNlcW6XZup7iUNmeAQRBC8jAFQCHYMxw7k7RlVC4BXD1TV0lR/Mh/seKFn Voogx+cDewbJyDvyO2MkdAFXWC1bXQVnZnMXOv8A9pM5E6N5+BPcyvtEjl2If+IAhSFyME9erVX3 XcsrQHcVtuDApV8KAQWwTgsRk9ec4BrZe6mgWraNGxkuNPQTpcGCUggpKdu9vmUEdgQWIBIGNp9C K6bSLb+0HsooYlkaeTEdtJGJ0dwwOwYX52Yn7u08nGPmxWU7wvcq6WjZ2WieHGZDcQTWaXEjyxPb SyGP59sg8smNgApZSvACg7g2Nua100R7hHvGmSCC0hZp7SSR4nSMGP8AeFNuVXytnzjPzKTxnFZv 373BO6Rf/snUGnsLWy1q7g1K6JUGEiO1Zyz7MBs/MMLuPyn95hQeM4GsRNbFxdTL9hvA7+fYgO82 2STdJIXBYnCP1PHv0qoia7OxzDQXV9ALXRlsLOKC6UG/n/0e6bMQfI+YbYxsI3bQQXGSNyqKkUce nPf6ZqOh3DSWErT3JLuqhh/Ay5CNyBgbdxwR7Vr5NkyWuiKT+KdUlW30/wAPrI8F6otUtrPdG11l AIiYwSrdGAGNxJGT0rnZJIprqeV7kwwyFmPlKJMvxuBHBI3YOOM8cgHNaxjb1FLSTtrYju7l7Rpw wtdjjejxFWyCc7up2nGOOo9PXXjt7q6R5fMhBKh0tpVcOVIBLA9MAOCD7j2q17mjJku5pwafK0Dy XGnR/Y7dAJYbSR7WVuA5JYgDLYKjcGHytweMs1C8RJ7i8sLize1jy7WjT+asZ5ygJAOMs3J444LY BpXiXpG0uqMC6uICkqiOR4ySBJNzx1Hb0HbB564qtu3tsBdFiLfuAuVX1A645qtmYSd9WxFj86Z1 diThsDPykcDHTofx/nm55jEAoqLsb5kUYwcEYPQ44/IewrOTaFJuKae//BLUduJlXajEvjBkO3LY HOTxxx0/+vVkrcW6PH5ZkBYfvSmwh+4zj0wQCf8AGsptIzsNYMzyJMqzC3O0NGfvckd+uOfTqapS zeS0wzJGrjIG5XwQ2DzgZXGRnjqPYURinovUVSVm7GJqUk8kbtYyp5qttHmYwV3c9D1/H061LbTo 375JvP8AL+QiMbcsP4VOev54rTbRkwjd39Cbx18f9BvEePw1pb3bnCrfapE0CKcHkL97ODjnH0r4 k+JMfi7XLhPHPhm4t4vFljcrc/I7RpdoAA8IGcAlVABbpgV5dKjHC8tSe8Xr6PR/gawknLlJtD+L Nn4ksbRdV1K60/UlLINL1xik5YFdyqv8QHH3c54rurScXaJIrSuWxyymMAY75ANepVTg2r6fmNXc uT5suxqfOxtBdcY3YYqRnpVy2aBT87OHcZKrw2CMk/XjpXNy6a6k05XfKNklt1iiUKYw/I8wEAH8 e5pWvo4CYyy42YOxgAwHOMdyP6V0w0u7HSvJbEMd2kwdIkkAJwoZCSeM98Z6n/Ip0gQlUhiKJJyF 7Dt/n6Vak4g5X28v6/M1oLJBtDu0Xy5HO3B9sc+lOnS1bzBNIWKHcJG7kf8A1qPNG0WpX1M15YQ7 m1t4fO6GWc/e9Dzisq4QyzMLq5knONnlZAgfv90dRg46kVm79xN30bKsmofZlihsbBRISIwinbGi jgE99oHHFOC3j7WkeR5VY4GCFA54Hc8Z9PpTSVOxl2t1LABkWVtsmUAZvMGOM57dhkdqntrW5ukJ ihkm2LuZIV3YyQOnbqOn5YFN6aXDSSb/AK/pna6f8PfEE8gEtoLGEAbjduMhSMg7Qc+/TjB6YNej 6L8LbWJrG5uf+JkbjcFVZQkBkyNoUr8zKeFJwBlwATkEc061r22/yLjFKXLY7HT/AAvZxTw2UOmW +n3Ftgq4UIszrvDJvcE7jjbyRnKkkZr0iHRJ1trZYrtmMX3rWMl3UAklWJVMjYWYDI9M81hz3dmt UaJWui9d6XpHhpS+oTRQvfM6LGVG2Tdg89X6g4x/fAJ55zW8ZaRZrfSWNvdS/Z2AVrSTyE2lupyF D92wM4zkMMbhnP322h8vRmDf+N4DahE1q5hkurrMd9bggxgYPQNgnByBu4yOeK4a51y4uI4VnvH+ wxgyKbhVl2BXfaCwz8ucZwpIwOMji6dJLVkSqW2d7iS63c/aJb6RbmCVj5cPlEKzsyYKMAFBBIJ9 eCCWBzUd1batK0U4kSzjyxN2kOxyzjd823krwCM4AA6HkVuvddmiZRvex88XnhnxP4a+I6+OvD+h a1ex61H9k1CwjaG3L7Cxjmjd5E8sZLDYMjcSSRg16T4M8c6Ab7UrXX9XufDmpwIBNpnilJLWeCAl 0WYO4Mcgwr4AJztIBJJojUVPR9zTk57OL/rf8j1qy1WzhshPaqZtMRtsmpafeRtMNssigxuuwYJ2 4OHOQNrH71IJ73UJRPbyXbjTNspuFuDLIjqFOAyqVGT8o5GCSehBpcqTb/rsYW5G31HQeAVu7u1u dTvri385GkkvJUxGW2vtTI4CYV+7EkM3TIXs/DHg/TdNa3/tFo423ozG22F5yULbHjcfK/IIYE4/ ug7amVSy0HH3Urd/8i/Jq2n6RpGoSwqYWsphI6xOtqMqrMsmxWbLEkAcYVc8k8153ffELTrC0hj0 yRjNMCZHjKv8zABh2+6QFBKkkDdnk0oxvoF/0OBbxhOXvFs7aB55pgsj3K+a4yCflBGOACM84zxj qGJqutz3EDmVFV52xYQA+SCD824nhlGeQxON2e5roUF1HzKzVzStbfxD5KFdPvoY4naP7VFGVy7H lN+Pm+ZyCoJ+9nit2Dw7qH2fTDqlvf2EF0jvbW7xsr8MVdVjGWLNtYfL7cnOKXwvf+uhL00R3Wia do+lWdxJZx2n9oRsY/JvkjubhELBWcqR+7+ZgucFvvHGMk6OoeILnS2hl1JI5Hkt5AZ45RifMrsS 5+ZwS7YIHBHOQWycuVSd2Va2nc4W71OC/initYJZdShm2fZLEv58Em0KMuPlVTvwSxAOABjODo2P hi+itry78SR3UENv8y+RAt3bbjPjcZQSuCEAyC3DN/EOJqpbR3/r/ML30/rcuyahpk9uQlzNHJ5o klJmNorKHx86yB8gkhVcdtx2jKhdbbfTC2kjudX8yeOPFjBbFYpj5zo5ikUxuy5AVVXgMr8jBC1o ld7oq/Rm7eWel2emaUkB1K3bZIbizgkjliiWOefcJRgkYVQNrFm2gEnDDHNx3SWH2i4hmNzb2jl2 gWNIA/zRsI1dWCkbTkfLnG0c7gaz1k7vuTKThoRebql+B9nu4LSfSuUjcqQgZ0JC5OVXnGAoBZsd DUjTamtrbxzTQ+RqMbGDULhCrTIjkOULFVYllMe4MV/dkBmZcDb2ffp/X+ZSlZNP+vL8znhNdpqd zdpGzwpErtHbSvhIQ4VhvILLyNg2HgAjJzk5k9rusfsyBjBaoZPss+PvsedrAnjAVuxz8uG4zb0S dxSl0+ZXjs47yVYS0moBJQwsdrsOilmOASeMnPXavONq02SxSWCWQzNHepIynBCRsnUqqr8owSSQ Gxgg8c7lG0dVtuRtsW4dNingnt4ZJZXgBjN4dzOhDFtvAC/dbru6A9cGr9tod8ZIkkhCXs5EpF3G jptkC+Ucyks+8OTnbj7pywJ21zW0K1WrOgtfD1vIVsmnhimurlSm2Yui5UbV3BjuxlTwBkqUwcVv 6j/ZMN6IEkstTNkfKikkiktxKNrHcXJBBLEvjnOCQAeDE5c1kjVryNm7fSLCKMabOl7fWrNN+8je O8Quu+EYIwcBTt+bb8y4bvVTVNY02WdDoqS3dwm0wzaogdIsbA2EAJ2AtJjacHGcE5AOV7dhtWTu rG7omrtPJBq0zWtvewF5J10yE+SqEvI7kJGVbYwTghgVKjaQDWH4ie+8SWsN1p3h+xUCaO5lv74r ELljg7iiIvmcK+ctxnoAd0i2asyKmt0jzsXN7orQ295dJBDLDvh+zxEO8bEhX4I54YZbGOeDzXGX d1d4e0S4ne3jZ/JklBV1HI3DJJXkv+ZPU89UYpomVrXSM/yYmR40EDNOzE3MZIOMdCVyAOvPsc1F 5dwbRY8Ha6kjcdvzf73f+H1xk+taRairEQlqixGzwxcMjMCCQzKpbJxwD9eg9D+G9a3ekralZbNk md3ZzbuESJQMqOdxYZOScjjHTFKVNvVA7JXFbWbprdVQy7oQFhhlJBQAbjt5Azz09+1Zvml5VXz1 hfJIK/MAeMt2B64zzSj7ttB77kMe+R12j5snCx5JA6455OMepJzVu0VFLLPCrKCdwZSw9cHp3GeP SlN3tYx+JIlUbkkeWZ2RmybhVMpDA4J69T/Md8U11G8FhkEKuwYw5HUcdM/j+tZ3avYyk+Va7r8/ 6/IvwW0FsHltz+8d/mjQDcFJxz755/GmQPFLtEgKI5BYRYHzdcYH3j1647cjtkldXe4+dR3Hqr+e S0kUmG+8rLwOucZB6duMeo6VmzTKcoIyZcqOmMAnGDwff68VcY3dl0M0k9H1K9xPGXCphEdjwflX PIx7dgPc1FawtBcmKXCW7EkLDliDuyWz93GP84FOSskjSPKtWfPsNvaNsC7nEgA/e9eKdLp7SosJ dIFPO7HzN169hj/Oayj2ZhGXNpY8S+JHgPVl16y8deE766fWLKE2p0u6RHgkV2DOeQNrZweOu0Ct jwr450vVNto17HDqlmxjksJNolLKcE7c9OKrDNVIuDXvQ0+T1/DY6JRVrp6npUVzkqUWV2kTduYg Aeme/wDn8rLJOUbbH5TIuN6jCsCc84NU5a2RdMnWwmeMSMqjk5Qjf/8AX/8A1VNFY+Uo+0FI3HO7 b97Oecde2PwqebWxajJx10CV7aF978quMbOMZzj+nrTZ75PlaGNI2BwT1LDFXCTlbQ0k7Lla1Ior 0FJUdJJuNxkY4VecD1xms6SW8wTJJCC2MRQqSQDwRk9/w7da0i3JsiVNvSIyN2CuVE3y4VgWDKfT r35+tKW8xSNue+GGe+P14PXpVyVk7gm1p1/4BcsYrh9kEUSzXTYAWLOCc88HPv8Ap1rs7HwNrV9P HGVtS5ViYHlAZQoznGTnv+WeQQTnUkk9S3HmWmx1ll8OobYO1/fJ5cQDvdeXI0UfzAHCBdzjJAyM 5BJAr1XRNC0i2twLOWySxtpHeW9sYGDBth5UEmQ5ZiO3Az82MVyTm+mxUFyq39XN+e01m5vZLO4+ 2z3EKrcyBjhWUDbhVKYZSWGd+5iGB5wMtl0dlSRr7RdRsZ1ImGssxMDAKMxLsyFfKsTyMg8KMVnz cl+45RbsUP8AhLLCwe3kTTNU1aJFKtdI0NrHjB3bmkLO+TkKQGGcnOCGXKv/AB/rRaKDTbqy0W1m dQYJXa4udgUqyo/G1sndllbGeNw3GpinPVenzNKnKcnNr0Nxq76hqNpc3sqqfLuLlTOFypzKOfkY ELwDhunUKRdnvr+8huw8cRt7w799oMjy925wU3DCHaAMkDjHPGNo0lSsvQmUnK932LcWjIRAl1Nd Lb3hkMjQxF2C5JUqS4BLHDE5+UHIDcCr40a3trxoDbTrZqDLHOm5/s2CCSGyobl8E7VAJ4xwBPMl dmbjzaWJNNvNPewSyVImW+kUD7Q64hBlLKSzISx++QBIPlJ+7t52rhktlextra6eW0/1omOITIrY dfLwNzbjyDxwMlsjBF32JlLl0/rQ5jUGvJrZ4b+2t4tJlI33emowAY7jEG29CCB8pBHBOOgORH8O fA2r6Xp1hqfh621e4gZmQXtt57ROyFN8YBwJMBlB2kkOc4anKF1YTj71omcngnxp4duNMa18R22r +G4R9nfSvFwEd7FIUKxvC0SgMCkYXDKNwcncoXB3dO1uXT7O5ur3wzqf9q2beVHeQXMJSeNQm0gE xjLLhdp3BQwHzZqIycW4pGjtv10ub0PxVsoLKz0zUrK/8N3+r3AgtB4jsjZxlQjrs3FzEXLFgqgg tywJOAMvUPGcV7FqVxp+o6MI7qMQTS/2ggEqKN5xtO0ZwHAwAFDHDYJrTRXdxTutkeU30l9eXVxl bQwwyFP9Fn86JSRyFfJVjjOOuQSehFSWOkXkshSOO4u2ZA/7pGcqq8Z745GMnvXXGNlcxlrv1NK2 0y6NzZ6bFbz3WpXD8WIGwjtngDjBXnscH1rorPwtd2/zXk1vFbxkOsNoc7vmUeWhfA53hiDkjrjt WNWS1HZO6PUobjRLWeygS00qQXUgmt7fKyzyL5/lJ5bISrKGdDsVTwueetaOo6y2nWd5ZQ2d22me WYo9TititwsbFPLSVWIU5w/IGf3jck5FYuVru5bTerOfWaDVJLKG3t7nw5sjclb3dFI0jNhORlTG FUN3PzLl8rhKep+H49S1JXuo4tXvbyXa2n2ipI1x+/kBDhiWiOFKdWyHU4wFUax1tYWqvY5eSV7S 8u9PiuLhobi4zCY0duVKkAMAS4Ozbz35wDnOtHfanetBbTbGQq0a/ZyMltjcDOMEYwSByd2C2afK lqVp8R0lvp8CR3JxYy6XZR7zBM3HnYbywdzhxk7gVUnG0/Lxk9DbC4WVEtyLZ5z5e1JGMEsI8x2f azKVkLMpyOB5AO3JzUNXv5g+Y25ZJQYpbq5Aj2lft8shkt9xBbC85KZII3MeST34mu/CZiupr+zD aba6oGmgQOpkjIm2xxO0jqpUJHliACoQZVgfni6jZIvpsc9eaDp5gs5LeTVmeSNS14rBISFB3FAn zSA7tvBG35xhgu41rtNMnvrG6vI7HWoNOt2LXdsXVTs4UOUV90fyLlRs+UHlc7w76pdTNNS0XX/g le0tzJcT273iLbIGWC2mREZ1bHDM6KGIBA+YLjPUZJGWJLeee5a2jt2ty/nyafsDboYwzNEVTDqc qpysgwDyxzuGqS2C3tHt/wAEzvJe4e4uorOS1jYhPskCEMMDYQ2fmQuAy8YB46EmoJbaW4l+3ajA +LvzJQs6kMzhCVCDABy4xzuGfQHm4yva5Oy2LFrZpcXM0Q+2Ml2AkUHmqxUgqP3nBDApuwBjseOl dPbtJayvb63cTv8AZFwltBKkcTKq7NivkqqEqFbPO0E7geuT95WNVC1zWtL61s/lbUHnnlji3adc NJAjzZI8rC5zF90nJ6nII+UDI1DWlaYWmn6hC0IQxxyXOVQwNuDQ5IBY5OR8owHPb5gRSXp/wAj7 qIrO9tL22D3bB720ZsXemI0yBCsbKqoSxZjukVizIMBDhMsxsSaHHqdhcTTxG7iEMaK9vOiLDI4I DZZcFSqO+1vL5AOcblLnNq7TG3e6Z6PF4f8AGj2ulR6XfCf7KUnW5sruGB0DBGGZwOFAUk4fG1gS cAZ8Z1m/aJbSzttQvbh0ct/p025YVD5LKVXaI2UnOQx+QEgZAp04rdkSfMrP+v6RwE6z/a5PPH3Z Cq2s3VccYOeehXv3q7FEJWZJSbXJ2PKwGR3BVTjoeCMj9eOnZ6ijaL5WI7eTapbuitbv8xG0EgnK suQCeO3T19607SKzukZo54FckExX6L8wCgABtwySSVAx2ByM4qlHlSLhBJryJ7ywFpp3m3FjGbgq HS9jBbarhwi4Hyfwtljkgj88VhZBInEMsiFpF8/eFmbgBCA24KA3X1HAI6hp9EZWva39dCtKQTbi HHnPwoZskYIBAzyAOOuRxViaGRslZ454whA28HAPOMjtnrk9R6UrczSexUl0WxAhaMSwhnQKNu4E 7nK8AHpx1xn1ycVaMqeYGZ0EhOGRV7E8YIPX/PPbOTvFozjbls0XEuItkjsZUluMbY0ON5JPY9ev bH3fepIY4N7yJJAEVTlWfaoHrz7Efhis7cplGXT+uo1YuVkJd24JlIIG4DBOP4RnsDwM1M6yKWJg E+Acb0AHH8X6D9KzlLmM1HmbTIJLxiqx/ZyqOT9zhsbugx0P8POf0554rLNO4eaWGPIC+Z1I569O nX6Gto6dBximttRSqkllJ3tkb2YbvvZA7Y+v0q7JEkcSKy7sEhxKiljwR+Wcg1LXvER93fU8J8pf k8l8rGSPlHPHf/PpSLttgrXEyqjnKpKQ3/181inbS2rKuoq6RNIqzYMCNIpyT54+Xj/H0714b4z8 B6rceILLxTot/Dp+oWsX2dont0aB42cFz03F/lwDu45698pNUbVErtaPzVtTWk49epv6VrcN00Fv LHNBdoA7Q4KttOB1OMjj3Fd/HPGNpeeVVlXaRgDP1A69eK6VKMlePUuUfZTSZFLeuFLCZ42yW+7n r6/rSC8u5yUy7owLHzOQo7nkegP5ChK2vYqMnK6vsSNDK4h2hiCMrCo7cYz6nrVWS0mt2Y72iQYk IGAR82Ov5VqqiXzFra7f/ALMaq0ZkNx1IUFRyRn1x6//AF6JIXgjJiSUoWyAoyDgYPIFaRst/wCv 6uEW4K6Nm28M6peSwRiIxvOSQZcqMDqBn0x6eorvtF+H0QuyNUkUtp/E9gEOS4x8mODnJyR1AOeR WVSpyeqNuXZo9K0LwpYSZm0xxFbhyhuLaKR54nYKepO0kBWbsNoz2Irp4PBupSwaZ/aVzPctsM4m kmEaHAIyNh4IRlzkZwDtX5snzpTcbrctrmaSXkaTaBoGhQNf6nNA0V7IczzXBjSNlYHyixIGDlcL 2wvI6hNL8SWSuLaTTWnhiLtGbOOREKBgVYSuAhVcPyOnzc/LxLblJyT9C1TstNiprnjDW7mwkjtF 0aysSjuFvGbULmRGOQIlKqM+YB82NvyEjJwB5trDwXESTXmuavqmoKPtaF3VIo5GA8xzEFCnlWG4 4JAJwcEDaFNt67EqfJZR6Fe81ZndYW2W1rArbrCV4WzHgAIxVQAoAUYKuDtb5h35/T4NrK8MFtBK kiPHb3kYl25II+Rgw2k4ONu3HXOa6o0+VWRlNvm1Z0hlllitD5Mc0YQZuLsmMHA7Lx1Kx9DnjPY4 6iLzhBc3cdjLFbPGBNKsDbxJ5gwjKhZQ3yglCCfT0rB227A4um9Si+oWOjQ3N5bPZbAwVJ/LRG3L tyzA5fGM8MCMngnGRx93riXJSe/uzc286hwkYbymZVfAUHLdGHUnJI5wBWXvVHZLR7jjK2rIF1XW dTt54whe3i2tLPFhtuJNvOR8oLFF2nqdvsDp6H/biyJZieJba4KNsdV+VX2kZAHyKxYEHIBwwy1d TiouxEZO93/X/BOoS/8AtTXMMNtETJcEmSdgfKXaVCE8A/KQfXOMHIyJitzPOk4up9KliwZIp9rt IioxyuRklUERBbDcn5iQAcotx13/AOHCNrL+v60F0jX5NOubIahcC9hdwzpcAqduTuVAc54DYPQk n1ydP/hJdIuZLeS3aC2E+GksLhjMGA4bdhchiyb+ccFAMYyask/ULmhLqPh+OPTrlWt4rJolDWiO ZN+GBUjcQAo3Pwq4GcfxDPK6/PY689nJjT2iDFY41jZxG3mMdp3LhCd2/ClRwDtGNpmlG0m5IHJ2 S66nAt8JdP1MzyWxnsbm/wD3sv8AZDSJL+5YuTtQ47fMcYIJ3bgKj8e+BNR8F+C9NutK12/1jUUn giMt3DBJECb2FZJASjASbScEbFHRmA3Y0clBO234Exanbm2PUfCPw68Gafp0cV8bTWtYtvPuhcaj EsreegySWxtL7V3jyxGASvDY21bm1fw35RtDbW9oj5kFnNAkcEGWLFAIwuZW5BJODvC5wKz9nzXt /XUObVpaC23i4pPM7/bLCBlURRROkaRMDuBGY2AXMQbaoU7kBzkZFS31W0d7i2u5IbwW8pkiuFdo wcK+0dS3L5HJ465xnNKGl7FX07mld6vcXMuo2llfTXFrpcZa2gugGTyl/cvhWzzySDngKCoGcDJk BlV/7RuJViePev2V1Gx8ZAIRs4K4BU5wGz8uc0R93qKU77IW01Hfaxvdz3tuscioTGUk8hCUwArh drklwfnXIBGR1PYabqNrHJbz2GjahplvaMUk1KVQ0M6SMyk8kJHlw20hlA24+bnA5Po/kTFpdd+n 3/8AAK2jRWVvfTRK9wNOJmeWW2G2aL5Plk6YLbM9OR15A+bpLfVbC1NgdV0uVV1BNrahcxEiWMsU WRFfk7CduACThieQFC+K9jRVOSzfY6e5u1R9bsNSOuXV05aSUM6oJJfkJV8BiwZkjAPUEkcbuMG1 12e9kg03VdWV7VZjbf2Xq4j3F/3gwGOdrYwSXyT8uFZUFJK10LmsrdyrqF4JXXTb23k0pLaf54Co ErlWdJtmAW8vB3LwF4cAnBJ53WtW0hoBHE8l1IYirX1w7sTt2gBixyzqoI+XGMR5zzmuVWt/XcLu N36nOxR3upXlxc3g2XUzFwmBCoDhjjB46YO0E5B4PatKDQpLph5OoWaz2gRhZXc0KTKXycouPlCg MSuccZDEnAe1kSpcquieUPaSGS90iK6WO3dluN7KsjMhCOzLhWVTuYYOMAKcc5l0+K21C9sZppC1 2rH7RbyXCRM6k5IjAJYgITk7eCD2ofoWrXS6bEtvPdQ3cGs6YmXtzmGHJiaB8bi6oMscFnO7gcEK fl417K+FsscV5G0l59naONruQnyw0gOfKQcBHSVuByGP3jTVnezHrJWRdu9PPnvaT2kkF3JILxbW SOeI20TQ+Z57gKvOCTu29CD/ABc5Vt4ftkEEdmkl4k/zI8wl2lNnEgVi6rkEnlc7IkPO/JS1Vuw5 LTQ2tH0VLvT106CZLiBroR29tZuZGnDSJmWOIjKqQqqCwVjtGCAuD2OmxpPFpkGnXRig0IPLNPpR RrjY53ZTyyoZiqBFJc53hQgLHL017f0x03s0Y/jjxBpdnpcun/a1S5UOxsNNCotsWjCq8+SWaUDA A3ZzzlcNu+ftWu5NVvECTjzItgXzn3OxO3LFmG1RuB7ggEEknJLpK+4qk0tDNe2eeK4YWfypJhmv BgKd3Tp12lT3x7dCiBYwNvzSqCFaVmkUYXggZztP06+tdal3Mk+VpsoNqEF1G7WsDXMqKcOFDRy4 BCjc3ykduMjua2bRY2kC26gNF8ruh8ogEgHkk7ecfNyPyqr9EaU9Wy1Kbh4Lb7Tc+bNdZj+S4Xeo jX/nnncF+ZcMwHQgElSBnzH7ObZ0YG5hXdlQOCDnuSem08njp34hu10TJWTa2Ea0nSO3eG+OyEMx inTlm6kc+p49QMCkthOFuTclbiROnmAqW7bR06jqfpxQm7+QpaWRPHHL/rAR5MOV8377Oc+/A6Hj AzxT8St872753bm55A4wD7YxzjPviob6kNW0f9aFaCK4lkiiVtiBcb5xhVGSevTHHXjvWmkdsHFv IgSOT5fLL7dwAHUk8HIHH8qynJN2fQw+FtJEE7Ozbl24+b5ouiEHp14I5/8Ard9K0llEdzF5wRow D5bEukvBHQdCOuPr6YqXroUqdmr/ANbnOzyzyzgGRlkgO0hQF3E/3sYx068DLH1qrNdJjAVHkQn9 1GOG6jA5z16fStvhtYiUXzeS/wCCJbyR7EhyHllYIBCOM4PHTHpzn1zVr95IRsLNGxz5bbiyEnqS D03YJ+lRGV2Elooo8CYu6xhWdV3fcX5TjnvUlvbwxZKIzszD5j945J5Oe9Qor+vXQIySVu+xu26X H7pEiCKhyZJRjPOCR78//rpssMb/AOsUSSvncq9AOOR+n4VEXGTdluaqKi79/wBP+HPJPFPgeZr6 XxFpCtbarawP+4UlUuB/Cr4PKg5x05PXisrwf47sdeggtzcWkGrnMclkZQsqkfKRsPIG4EdqWDXP Fw/l/J3HO1S8r+R6JEyzBo0jQyt1JBwOcYx+FXTHtiZWRH2tjAJz1xn2H68V1RXL/XyBXim2i1FY TzyxoqujRjBEYJJ/A98Y4/Lpz6DpvgXW9QVTPB9mtl+SW8ulbaCR8oOMnkgY4+tRzKm0a0007R2Z 6Jpnwx0C1eC01STUtQ1G4USf2dpNrJKNufuF8bEzgknIwCOmDno/+FdGCFr7SLWw8MvGVjt4bp1v 7ycchpGCqqIoABJLO3zLxjJXlnWd7tm9ua72Ocs/hnrFi19q2r6vapDKxcXakypJu2k/MAcnDL6d eOldVpbWLXVydN0jUNZt/lWW/kWS2iVEUEgebjfGW/iVcYJGcmlVrp/CugKL1Z2wtNWtY4I7l7XS t0xje5s4/PG5ssi5DIiEMpGOcbSSemOJ1PUUvLNreXU7qC1lUL9sidYYZZN5O3EYXYuMnGSDjqOa iNOUnZqxXMqcdDkm1+JvLvILPSbaUlVS/u4CxYxphd+0E5yOT8oPT1rMv/Et1ElpElwGdo2EMKgr A+4bi+G3fOWTgljgngd60jh43T7GEqr1MaS+1m8uGlt5bm4R2jSSS8LNu2KFMYLAHjAwFXgLgDFK ug3N/ELy0uPs00rCaSB4zD5e1DgqrHJHLc4z9Cdp3lamrh1T7nS2fhNzEiWk8ckUQUSLZRO0quq4 OWGGXMm0Ac8MAcNjcjppNi91Ibjy2kTPmQyqgdQANoJRtxCjIKkgg/kRlzb/ADHe+pVfxFY2tzAJ Z5biGZiZjE2wAOvzR7VbBVcADJOR3OBusjxLLaxyZvI/szI72yOnEIGflCk9QpIDkbiQeOTWe3Qb 953W55hPc3t/ITdRlZriXEjxgMedzMWxnC4PYDp161LYW98zxuLRptjYE3DRxZztBJ4yemR7jmtI 6K5Gslddj0OxiaJLWy0mONJ22IIY9jmckb1Y7RwCepyDtAAxgZpRWeqWGrzxTXF/9ovSEuLKNl3X EpcFlZy208gN164xnms4yS1BLVNF+5vb2KUjyyk7/K/nKQkgc7lOQeNwIHQAjnPAxw99qsmVt9+G R281HU7VGwgKzj5S24r+bdTVJqNrdf8AhwlvZdTRhunuQZr65xduBceXBKCzZPy8gMQQCAcgY5we mbFnp13cTL5MTbp3OyWIkldvQggEHDFeBzg44J40i+a1xTfTt/X9eR3Wk+Fr6/Ev2iUxSyRiFb6S QxKQSoG4kkN04BK42r2GK7fSPD+maUdNW604Xt7cXMkMazn7NIjoAMFi21052Nt5G1iyrgF8JVOi 6CUb6o3b27SX7JLYyRyXVsrIbeOfyIv3cjRBTuX5gYArkkDIcDC8V5L45ttJ8UWtzousGa9SJfLu LCABbWaAbgyMysCCrbV24YHn0O6Iw53qTvqeRav4s1XwXr9jZ6hG2t6Xr900FhfaTEryxOi7vKli lctyqO+8MQ24japAB9EiKXLxF4/LEuEZ1DQRAg575OP4flAxgfUdEI9P6/rQ1klVs7HRW+lSwyNc 2qWhggZJGdWEiOWCvtlDcZG/AAHPPBzkNuVurq1WyjewWeFnAsPJKvI4A3MVydjFFJyPlwo5o5e5 no9UW/sim6X7Np4guWH7w2J3S3Cj72BtwvUgj7vB7UT2oghSJxGyyhGMyn7jbiFAypPQqSqnoDjO eJS13/q5PPfYuaTpgkmWO1kt7bVgVBN1ypG8ICSMhSXBJLhVwvLHIzu2ljcRTxauLSJ41m4jWMpt jXDspY7YztVA+A3G9VHQ0/hWwRVtGWrieBrq+e3u/sFoI222FypeSFWYbkTGN4RdjMzBeY92wY4S O5Fs8UV3bDUbJ5Eb7VdxoROo2YIfAchd4+XOMMByM0cnNsW4qNlEL65kW306G38Qw+QrMUlhjURW ozlQdvIcZbgYPTDNtBGLa6hdxvPa6hM19lwrlEJuJBIFbqdpA2qcOVyoPT5QKI7Nh8O/oJPHqMln cRG11G33gsFtSZI5TkBUMfygYHmHOSMMQAO8ljodvcR28F/JEiyyMvnzOsaxEofvZXd5W4ISchQd yggnNO1lZC7+Rcu9P0uObVBZxRlRMvk3DhIkMYBHQ5JlymeCo3E4OMsJrNdQv7prLRba/tWuomli OqXayyzhyFl+6cAFN4J2jhDy20UlPYL20K09skVtbT3CGCxMAiZriMvHHJ87BxISFXIPDBiOmdxo isY7y0hedNXurcQlIPLV1toh55VSXPByzPkgqP8AeJxTT5thxjdWOl0bSEuLBbbzmvLOCRMxSIFj BcH77x7sHbu6kHG7AABIfeW11alNMgjtI4JJFZpVhDyW6sOcsEZnQbQQVLYB55fFTK3UcXtb1H6l JdQadDqEdxp94bqIr5CsbeQHb+8kMRYbs4ONgI2uo3bgVGdpOqxzxxzs8EUOmyRTq16ofoRukT5B ufJXIOPucnAAa7XZTqXd/wCtzLv/ABsihEitFtE09WiitbqNZ/NdlO6TcqhdpHJU+rZAJOKUvizV PtN3d+Rb29xexMrDy0UiN/NcZcBSJAGPzccADA6VXJyq7B3SdmYOseK9Q8TQWcF0HNnp0aqZZ3G5 uTukckZLl93zcn5ivQVz5iV2eDanUh7rG9Y1JCkc/wARzwccc+laxajoiObmVi5JJBbxyW1tcTu4 2xrJ8sanIwSTuPfvuxx0ps0ds8FopVtsjbDuQsjLlssQcjgdfwGMg1S11KXLdMa9hbWighbmIQxJ vjcKybmGNmUJ5KkHtyO2RiBIjFIzJO6KQh8nzT6gbSc46kdccfThqKVkhWSasyQXEtyGhido9o8r MAG3k4ycjOR13ZHfjHSpEt5FIY45POmnY/6sAL2BJPPfHb8KvRXuK/Lsy8qeWQGmMskTBvKHJDZ3 ZOevOCOKjlW3eNQW8uV8FpOcYxu4AyMnk556DjPTGT5bmeupIoVt8yo7pG6hvKIIxk4B9Oe/40Bm MgiUo23ndj5hjBOR6dfpUSa6BLR+pZMLKCqLKFUBpJQCCwJ+UYyACQD68gevD4FQyXMSrC8oYlQ6 BmwM5HHG7gc//XrN6si9rkgtIpNLWSV2zK+xVZlMgJDFhtPXG09O5HrWNc7FEzBInhc4AY4Oc4A5 64yRkelS9HYOa0VoZjSBHlMoLbmP7wgFeD15zkYP5j1qKNflcSSyuzN8vl/MWXJOAee4OOP/AK+0 lb5mcpWvI19kSiVJZHZMbdijYCcdT82OdxOQTn2zxBbpLcuttEpkedlAW2JaQAH7uAM5JJ55zgdS eFFdGPl5lZPU8MW7iRhkEHdg888e55/wqUXkfJWByyYy2QAeucd+4H/6+MI+7uyYR5H5F1byRvK/ eF7fq0LfdGf4RjHP1qQFB90GLOMjbtI/P0qo2u/I2VRzevQhuLFLqN5Wczxz/eDkFe/WvL9d+FFr e6gPEWiw3el6+mES/wBGVfMdAc4Iwcg/hwcZ9MpfupKpF25d13ReGfLJQkj0jwF4X1HxBDMqmGKW yk8iQXuBI0gySQoJwPl4JHIIPevfNL+FMFq/k6m91d3bqAiKNsatk5Gc5YcjoASRwO1KpiubYt0m 73/q52P/AAjumW0r21hpcsnkMqNBaxIsiuoBYeZIC3UnjYCAcEnkV3Gk2V9bSRn7FZaZLOWWSC2A Vkbaw2blGN2SpLbiODxyK5o1U1d9TVb6bXOq1KC0aCGOTULbTmtfmmjExWQsC+Qqd2H8Qwc/KOvF cOl3e289vo/h+e6hmu7iONZNQRo4kQb8sS+7n5mHKkZwScDAHU5bxXl+pvKndJt7HHXcFoXNs13L qd1pZZZf7TJlfdgK+eVVMIpBKKvIHRRgw6r4p0mayMdu+pWaWkBjnlhSNZXcspJ5G1FyBncCdwXO Sfl6aWG5ZXlv+RE5pprv/X+ZyWnm5eO6XTYJ9StrWIzSyRxmUxqq7pC2TgYzywH44GakS1vtSJaG aO5dZViaB3EMZUyHAJf7m7b1JAGCCBkit72f9aHKrxTSWhfl0Bb+1k8y5uZVSTcJpD5k6MOWORtV gWJ+YZxk8EjAsSeF9Enezupo3jjwsYazKNKVEQVpFZgFOCc4IUgY+Ynk5qrpoXfnRpXuleH7aS6u GubezjdMLNcuJWchl+VGYE7QHJy2Xwm3J+81C/8AFWnxTXiT3IdbdgqtpzMrsoPyE7WAACk8Y4wO meFKm6mkiOb2bdnqcFd+JIUY/wBm2UluZAR+/WOWUK3UZI445+6CDyCCARz17dz3weWWN4544QqM rOFCgr8pDZLcDruA4P0GkYOEiX7uiLVpo2oajiPy5JvmKYlfGAxADMDyO31GTg9uw8PabZWc1w1+ kDrE0cgjgheTz/3iosagkFiZCEI5IUFsDBqKtW0TTlXMuxhvJM832ezito9LlkCPqF5ESYweXIUY JyRwQQQAeAekyWlhaw6YLREP2yQI0tzL/rdoVtxxg4O45wM44yT0IX1bKlouXewkNtd3TFfM2Swg SRrINi7SSf4yWCBVAHUkKPet2O1MsE0jTOywbU3K4aRiqjDgcg5KcjGRuHU05K2qX9MiHdmb4l1a 40CJI9Zs5bS1u2H7y12srfKV5YZBQMJB8pxk4yelefT3lxqjafFp+jpaaffEr9pnk8uFTtyzADJb JKnGR1JB7Uo73ZMpOy1PQdP8HXUioqTPJE0kix3kSHYwVW3KCQATtG7ALAZHaul0/TdPiEqWJne4 gTzJHeHbHHIGBaIfNkAAfMQD0UYUkkimr2Go7s7WDxItjpy2n2c3H2F40Nzb+fFFNJvSRt0YKmQH aUG4DG0HGVyue3jXddQSXJsbOxQoEfTB++tHiUhXCq4UcjcRwx3M2QSSEu19R32RyF14juLlZLSF I0hmckpJAsjrFhiF3n5mUYH3j3GMVDaYZ7i4LRtJH8/mbjmEn+8OhyATgY4OeK3T5Y2Y7cjdun4n MfELTNL1zwvfJcalqon0iSO7spLQgW5mhuFukjkhDbpIndQCd67c7hu2hTP4K8S3OpaDpmsTW2np Hq9vBcLHeFihBXCgrznBIBwO564pU5a32/4cq916Hq93ri6w0k9xb3W1w14t1b+Whk/eNkFgAzbm 2guckBSpyV4pLOJZbjV7aeS4lv1kW5G1n8rzEkAJDkZyQhLZJUkNyflMGPMpfl+Juadpb2dvcyRm 6ubSBwJg7pG7MyozAbslivXGCRyx2hSRr2a73Nw1jeXUg+ZJzNnyMSIpk3ugV03Rvzjhm27iRihu +/8AWo3HYp2MMlkl9qcK2Xl2koI+0SzrNMxLINxG1mUDcr4K8oxByOZbTUzHO2mSXwu0Wc/u74nd KPlZn+YALkhiG2s4OSSSeHK8kTL/ACG/a7jTyJdPa4hnurcM8LODFIoI3o+/duUn+IkAEK4G8cc/ LqMly8txdApErSf6TdgNG5AA38ksxUY2qu1eFOMZBu1i+a2qMfUteTSLO3KXMMKYVmnnjM8jszYL so53YQKAxYqDnJBFaUL3HmwX32e6vLSYRyzvI4VZMvlDt2nnqpLBs7mHHApaLUcZK2hVivjpN3dm 0kka2uJNoVZFDjMahlZiMklg+RjoQMnGaord3jyNCjTiWWRiIyDAqkgKceo+TGMdhkng1ekm2hN6 6nRyWV/p12jXljI0UmMajDHiJwRsBTOATvB5we2T1rrCsIFqluzPMyIF+0RgSEK2E8sZBdCh3BcH 7idumU9dEDZftdO1DVnmvNVttSntrG5iTdJuRQxkPzyEhjuGTtznrnAwN3VtFBFYmRYFitrENDLa LAlldi5dJPmBx5j7dwYhyu4MFU/KMGztccdL3K893oAs7z/hH457S9gklMdvLdRBoSfMkBBwsbKu CGwjDair8jEGvNLnxTepf2jm7vMGRN1vcG2BmU7X+YrFjbgffO44Kj+EblZu9yZPl2MTWdZ12a4i vLZLG/uEMjS3d0qZYshVmU5IGVONoQBSAVPauSuL6cxr5lldB0OxY4SGWBc/f4cnlyx2kY+bryRX RCNnqR8WwtjqenTpFE8k/wBqLnzbaQGCWMDH3W2kgscqRgcAdd3DZbeKBJGVGeP5x5jg55JAHtlT 0469hWm7fYrWWoSI5e5jthLbwy45RcKgyBg5zn5W445z6ZqzcfZLa1a2toJI7mFAx37ZCz4IZsgD A+bCjBx60WUti/JEdpDO87QSTs+5SR5o2tg5PJzgKOvoNtSGIB51dHkUY8sWREojG/kc9SfXd3HP OKrqGyepo3UelyC58qzmsdQgmkLG+uC++ElCiKpj4deSXLHKlflBUmSHWdN1Kykni1GyvLBrcLsi uI3cRpIvmRld3VWRldSCQVbqeDT+HYGuRJ2Mg7ztddipFgY6kHkBuPbv1prfaZGRYnClzuYE7lUH +NSeQeBxyee+OVy8l/MnR/NFiR48KsDEMMtklSqkZPb3PT361Akaq4V2cs24smVKD+7+GeSPw45x ld9AlJpLuNmLRosRgaPzP3fmfcUnuenUdOp6g1eh+yzpI0in95zs7ZJHT0A9wcnIrKVPoS480rv+ ty7FFGUMbGX7Tw4jjDB1HyjnI6ZJ4xxkHvyWFtPf6hZW6Rqlzdy7V2HAOWwrHd8vXJyT9ah6LcXL zNJGx4pewsNTk0iyjj8nSVEYu1BAmlH35GDFsDqODwFHQ5zwhIkjZGfyC4J+cl/x7bexopO8fVfm YSi5aR/pGLKzyMiqNi2igkYGduM/MMcfpyB1rXspQjpIH+zOq48yL5mJJz6cZIPr07VvpJMa0dh0 xn8xWt2VoUYqQBszySOAOMYOT3zxjmuq8NWth/alrcXErSRoxka3hGy4LIQxCvyFYghRnOSw+XrW M01HTcu3M21/X9M+T4NPijl2yTCYITlnyzAZ7DpVzz43iLqNy4wNwILEccfn+tKUedctv6/pGEKj V0X7VJdiIVy68/IuW+p9B7VqWPh+5vJrdpUWBWP3rtsbjjjPPT3pbJtHT7P7/wCv8j0jTvC1lb+W 147XyuFdIgvkxrnjkkkjnjHt2xXpejaZDaWU7WEcdi5XD30KYjdQ3P7wgg/OAMg/wgc4riqVOZao 6acNml/XQ8i+LngHxGiW/iL4W6hLY65aT/abu2tVz9tiAC+V8y+UpKY5bGCq9lIGh8MNW0TxVFqV rrmua1deJ7Wc2zw6heTvbwyR/e8tSql1wSQdqBgTgZwDlhqk6lN03pKGnS7RvJKCUkvX1PcJfC3h MWUFjrN9cwSvAzi5ivp/3SquNwUHaMEu3cLs6DdWcl3oGjs93ZeJPFN1DKAI2ur2WSJtoB3GOEgv GcZw27IIDDIGMYUqrej0/r/IiFRQSSWun9f10Kk/jq0sZp0tIra9+0uFEtjCXeYn+Iqe4xnnGcEb iM1yt34mkiukm0+5tpLydt4dHk3xv93LYI5BAYHk7lHAwcenShazV9TPmb/r+uxj6a32u5ktLoTR RorSi4RAjPycrwOvOMY9M+g3Z9OsSIbmdLkWshCxyT5lKE5IjP1GGJI6k88ZOqbvfcT967ZpWthZ WuLqaCzgMc6hYULRlEbPmDGSCcEHJb0HuLl3c2N4bjbPHbOkBkWW5Lyh0DnJ+7lcsvJDEcsuRUS+ L5FJ8tjk7nxVp+jNtdY9WWPc8VwYkhAkCnBDKuBywJCkggqN3cczN4p1C9tLm9M9351t8/nqJZkV 3ABZt5+/tAX6LxnqNPY8tmzFyurGTqF9dajNDG9xIVRR5kNsvlK2OB8vAHG7HHboOlVRp08Uksk0 MyCOMO89yh8x22hmwGGW6kdR94ZxmrtojO9yxHBBGEmkt5kmQbniCbBgN03HgYXce3Kj6HQtBa+Z MurtIIBIilLJQ0J4zgbSp7DG0YPJz0LRKUk20bRmm9Uan/CRWmnx20Kohtn+bewjUnaeMjbu5KA5 4/ukdCKEnivT43jkFjBDMzRq0SJGtrKYw6giILtJGc8kkksc4PEqm5PUlS1uc9eX6z3DSkjYpyS6 FAMqRxzwOntwM9eVjnllI89ruGIgLtUhsc5x1O35c8ewrWMElqDlb1/rQcuovH57JILlpJBhXIVs jLgA9M/K3Az04z1G9BHqdxZCa9luXSSRnWCxiMpcqNoTtx8zDcT3IwTgUNKIn0V/61O98J+DLPxW 0+ufEYeIHsoreKC30bVJVCq4CsqyS8mNCoYgqCVDqmSCQ3WSeC9HsZ3s7X+xVm2T7EhV8wQqq+WS JNvUltpfJUbOBtGOeE7pFyio+phX1raWCzRNqRubtJHtt1ypdAiFAB5ancpZoiRgfKQAccZwtU1i 3iF60OpWr7WMUMVuD5jfvOrkgDaRtOCS3yqMKMYqMbvTYUpOSf3HHNLeSzTSqhiNthXXZuDR8DDh h8wzkEEdxnOM1cRmmR7h/LSaddyjZGqbmbaBtOAvBJI7AD2xrGP9feZ7K5qRoyRRpdLGHg3OXkjQ 7SVAw2MHqBjrw44FbsGpX+w29tNIkdsxMcCnbuYkgbSAc8McL6A4PPOctetytd/U0G02DfaXVxZR pPaM3mW178plbGPmRuOu1DnqcDBPXzDXvD1n4S1qPVNKsrp9MeN/t2hWObjLs0TpJBGhyrByEMEa vu88/dIpv3dRxS+R7Fp1xp15YvEsdvdC62onmmeKS3Py5lAJHzv86hXUDLY25CAbNtetFbsk1zDp sEUbgCQTSpcNiGNBweGCsJc5IBRgw242prms1sLWDuammXEa6beGWyh1a5SA7gWLrHGxjVCQuUti yEyrIQGyAAM5p93MILa7BE1pYohtHtre2U2u/MhG4YG8h8KNxO3IxjZVcvRBvaxktqek3kulWt1O 2nzWEB8u4kjefhm8zgJj5WDLs24YEbmIzzj3LWs94sVvY/Z9Wt5FjkkdEmVizjaNhAONu3Lc8OGB wQDajrdiavqTT6hpVtBbr5j3j26g7I0MaedsMUbON3zc/MoA4zySPlGPJrk7/YhqreebR90PksFM QKJhVHCxgEKQoAxn85+07jlK/UtRQeGrg3LahcJf7vs0iIgKkhQA6nIwoUD7wBONu1eSy2Fktbi6 vINOtrpNLtpPLW91OMCVlCKXAHCqSZM7f4Sy8/xBX6E7Xs9zGaGA3Vvo1pqVhPq5iM0umRTo87qp KklVY4Yp225xnJwTXYxeD2itLe5u4MW1qYo5ntgJpInMbHBVCN5wCxBcbVKgg5AqpS5TRx5dGX9N 0nW9ZlS4tYor8pbs8doJD5TRKHQtIcfcDRhXB/2jwrBq6uPwrcaT9nu7rQIX09ohLJLqF99pRfMm BWQLEwwnk7FCbgWZWPRSDDnroG61Nj7ZPKNQOkWt1eXqohtwqeXEscjo2WkD/MBvMR+RTyM9GWsO 6eS01FIxeR3VtqUUd5ILWLDo7xKNoWVUypMbHaqBW2Y3BVDVOsXYU0eaeJfEGo3UMdhI15brKzvD HeKrPsQsgGVySSC27cRuLFu4rmhpepG2+z3FrLKi7At0zc7VVVRM84AUD5Rjrg9BXUrQRPMrtG1b aWiwRG4NsxuEInuIeTbxjHzBcjLgMp9twGDyDynn2lskyQhzBG53MytuKYBXJUnJ/wAOlNLVhHfY z5IrWeRoLm2gW1kcOsuP32f7y7sbHwRjnjAIPo22/t20MNvaGyu57ICNtRlmNowOSQ7bUffJx1wM FeAMKK0G48i8yZNTdU8zULG+sbaN8MdOVrrKlAG8vYdz4zuCsF9CKjsr+yvbyO303VYZpEBd42V4 3j27mKsrhWU+X8/ThW5wc4uFovQlv2bu9TobW0hLW19JagxTIssNzYSnbEVc/eUMGwwAwRjIwVxw Tf1K0SynupYC8BhZB9mvD884cIpkbcRuJdsgLnPXjvm372n9WBR1u0ZcksGoWzQSW5haE7R9lAVJ 33hcZJ64BbOT156inKLiaJrpkSd9gOJwWZRnCg54Ujbx+GOcGq1i2aSfPdtjLuR7V7eURzFJnAW4 IGG+YnAJ5OCDySeh96qrLFEYZVInV3QG4hffgENkYHIB54H1xxUVEo3YVLdEL5sCkRbTHkALvQhl XofYjoADjP4UsUbRIjlJGeXam9+Dlm/h7jp78j3rL4bWMVeLt/XUW3eGZZY/Ih2O+9rqVdr8FgcD PAOVJJGfkxn1kg2B5QPPSGHHzggFlyuOcZ45568getZSd2mVZcquKsc9xcQzyNtuEmz5sWI/m2kk qRwMYPT1zUkdt9ncpIrTo0avtc4I6lWAwMuQVYE//qOXmsumhnPmjtr/AMMZGpXbXlxJ5c9zEHY/ PJJvkUbyGbd2Bx+dZcs7bhMq8IdzfPhpCx4yMex9MZ9SKcou1vIXNKLS7IVcp5s7265zlllTqucZ bsB1z0HzGrAlNq8Y8vdhT80ZG0lc9fU4B9P1yNOVNfMra9yW2kllXKyyPCGBKL/c6Hg47ZAHsele o+G9Og024nupklvPspSSL7TZBEhkdSjBmZSUILqcHgEBuCBnOuudOMRU042klqfLlh4N1HUEjXzU hjCFm8/rtGBnA+uev9K6OPwLa2EdpLezyCSc/LEgTbs7uWzwPTg5Ncsq9r2/r+tyo0ua0tjp9O0W KxNtcwoUi8sljG4Z1wQwLlQQowOPXB47jprLSdQ/eS2pgu1GVCRMMZ5BK5A4BGO1c9STi9f61OiK UlZdDvbDSLdgr3lxfTpbqVdExEykBuFY9fmDHg5PHQ8natUsbWKBrm3MpUBWlbb5u1c7WUEjIxgd c8E4HfCT1aWn9MuM0np+PYw73xdp0NjcxvZXUFrMnkfaLgRyqSCSqhTgtwCM4A6885r5c8Wx69J4 hk8X6GbDRrjhPskQLfaY1B2qVXaoY8Ychjz90A0RXsqimtd9vy+Roo7puyMbTvilc6tPeWWoaPs1 fRnzdSsN6q7IDnePlbJIIXnGegziusGv3Uq7dQlvXnTcsFqro2xTuXaQpG3Jx2GeT0wD6dNqUU07 6fh/wzOdx5etraG7awXN3HPKImFw4Vma4jLbE2g7yvOGO4ZzkAfr1GkWd7Z2rzhIorhwQttbEncA OGc8EHJUgcAkYxxijRfgCs5WenkMFskVpJJKkto27a91I4SP7xGBuwWO3cMEkjlvUVauNbtIYZ9I aaO9WQx/6XNu2oQT/COcHI5GeP7p4rRLmVl0LqPRbmfLqvh+8sRJcTq1zESRbNG3kuF6qdpG7IA4 3Y56dccvfPd6XLcwyxCC5jIUmMtE4+8GUpkFRnHykAjjrirVN0nrv+IVlaXMv6ZilJprdnRFhhnk B+1xKYpFzxggHao3dCfQde2nZi4igKJLGyDE0c0LAzowP3o2yBkfNzxzzyRxcnzrUz2sluWF1FPs M5nSeW78powsLgKhVcKTu3FxsZ0wMHGMEY5o2UmpWkdo1zbxPBPldl2A7syAkFTjKAFucHkgZ6Zr Nx0tcbUXrc39SsNOv2jna6vmvJDvkW2VPLBbgPksQuflzknqcE4APOyXFg95IiLPObI/vJpfNlLM MttaRQNpyBxxnnpwDdmrXM9rWJfJvZ4XCXNs1mAJlMrosg+UrgDj5h0wOe+AM1z120Nl5k9zNGiI cG4kJRFTGfmB4A5I5xg+pqoRuOVPk67HOaZ418J6veJpGl6rZ32p3Ab/AEazkByV528csNpJ78Lk 4xiu5tdLm1S5lh8y9yCjRhlaROqrggHGM9eg49hmmnTeoo769v6/A9O0jwZpEMMlxrKXCC2t/LC2 0THdOLhch97AY8vcvRhnaMdSvU3PhzUbSeOaVbLQrUlJNqxfaS0TOyquIiAcKrOQMAMhViTyeWpP 2mhrGSV33Opnu41t2s7LUBa3PlybGxG5dmePy5tpJJO0n+62FAAxvNcxr+q2t9PbvcsZoNihUWVS zlY23b2Z9wBXcPujaWCgkiojBSaSJqO25zF542Nxpdxoupq9o0D5+07N7uFMsnln5iT++f1xxkks BXLjYHP2SR5kuMERSIFn34U4HJJBOcDvtHy5xWkFZt9jH4HcpNEQ62sCzN9swGjkJCSID94lueCT x7ema0BJAy3QdH3yKCiByqsQ43EHnOfnXGedp56A62HfmJY2t5LW9igtWSTOUkZwoO0kkMuMnjuW OBwRyK2dLiv7i+hTTJpJ7i7ljHlYHnNIWBXaOeewK8klQcZxUJJaMeyuzsdOlkUNaXVi0uMkws4T zGDpGqgp98AMrndtGcjqMNzeo2FjoGtWnjGdH12PUYobOKyvrgf2laymVFR4QEY+SoBJTcqjDSAk 70rKaat1SBSTuj0eWHR/s73lkbd7hhGlzDfOZJY2O85wWDOF+RemCwL7s4xZjtNbsrG0mS9W3h1x Bb3E0UcSLDvAZRI5BClwpPGGYF+SpZauMuVailHVP+v+AZMep6Y1u8+mtbG7uFAT+zxHGIfKDnj5 QzkhjwDksFLMx21Sj3XRvbhdW8yTWH8ieO6JWY7Y2KMrK2SzMT2KbihbpxVkiV7rKSWthaqt9rN2 k/2xdzx2YQuxEnIYtwCQjYwCMvuLDaofEvb9p0vmgO/T57kHN4xkMHH7uMMckkKhxycbiAAOTfM3 uKUrWsZmnxyTTQKVazhjJjuJEKh9pAPHBOSrDGMkZ7kHHUPZRWcl7diO8jjhDxqhmUTMGj2ruwpB xtKt03DdynBprS/U0hrZsrGaKJ44rwFl3l/sWnANCrPuDyOAcfcChgOTgckYDbNjaXV1h40i1Gxt JB/pEZCqhbAjj2JyUAIGcDHyg4HWZ3k7sad1ex0GiWFjCuqswsrVrq5CxyXAzK6tsSRlKKwJ2EKr FcAjgZBJ6rUprzX3jxFc2J09HmG8/bIJpmeR3dUChl4WNWDF2+QndghFzcd2+g+fmWvUhXRdas7d dSu52sJ4t0a+UNsL4QMYssc+YMAcDB2kDJAJtT2N79jkgF9f6lFOlwv263jWXz3RRI0uwO5QkjZn C7BtP8JpSfL52B9GX7STVd9tpM1nY6gLqQWbXA/06e4d2dpTiaQDKDAAwnUE4Zt1Y95qF089nex3 GmW2L85ub+ea4tk3SsY0CGHblAhySXAEikDdlAvJEt33POZLWCS8t7nS7sXM8ytNI0k5DrIx2lwo 3NuGx3ySMghsjOa2NRuVtZbeeGVfOePzpF02GBI4o41CEIhwEzIsgYYyOcfLwdnrqKVo7Hl+oTX0 p8yGeAxKcCKOJI3XZg7mXCq2FJAGRnAOM1RkQXXnYDOvyuCj48whQpAwTuwTtBIB4OeK1u3e5EZO Oki6Z4s3CrM7RRxEL86lFlBwcHBz247AZ9MuVpUWKEwSJC/y5UYLZJD5bBycg9R3HpTslowUd2QW kkGEaJpTJFhgpcH7vJHzgg5UD/PFXpdFttflh0y/NsmmOCWe3dlnlAVnClWGMNtA9DuA4yACpK17 F2u2+xqxwaXbXDmzjE8/mAsImC4UICwZiDkkg8EHp1Oa406frdjDNcWOo2lzbw7C9hrauckr93z1 BIU7GGSjYJX0zWj0V2aN3WrLsd1q+yZ9R0q2doiFWLSrhXaQKQMLuVVH1J79+1K58R26rew3Fhqb vYuSyx27M5C91xw3XggnnPPFVzxauiaekdC1YajFrFnBNAQY5wzi33FinyndkEZB+XkEevStTy7e SaZ5mW1h8wK5GZXC5wQACDkDPyj0xmk/UbSSt2/MrqLdvMUu8Kpubcyb2JB+6c8/j3zz14WKaVZ7 dbST/RmC7yjGIsCMkdODkDAwefpmuWT5XrrZGafKXLaO2jBXz4HkQuMTRM0LLwORjOcd8dh+DXt5 ES4dhGgkBPOQcYztAPGM9P8A9WMOblV0KS5o2XUvDF1HFJHHPcTSNsJiwSq7gqgE5x8oPbjrzxjN uonaBgk4hjjQFZblREVOB8vJOQMkZ/HHPG1N23X9bD5mt+v/AATnJXzI9wrJ57EYiXlONxPUHHB6 d/fsiBNwZIm2QqQrI5Axg7SOp3ZycZ/Klo7NaCdNSTsTi0uzBc2hty3lgE7nw4VTtKoCwyvzZPBP APHOas4hVI7h7g+dbkblAI6EDI29uOT1yvNUpWs7BNJRZf05dtwiPBFcRrJkQ3Cv5eMjOSoyflPb ng8g9fpTTNE03SrIakt5p1xdXU0H2e1jVYwuC5LlXcOkfmoBkoxIxll5FZVmlJRjfW36ClzSVl0/ X+kfLdn50wmgew1DMv3DbEckg4XPXA7gAdOvr0thpL3ElvDqMPkWqHLyXEgSUrySp/iPOBwQOenp xyjyqyfn+DN7y3eh0P8AZdjCjzpf3Dx4BMOQsWCAdxP90ElQvzE4rabUoYr62spZLW3tyBGJYEMR mAwvJ5wM5J+Uk8/SsXdp33/UiM1bV6O3yM678UPFG0Aa2nu7ZyW28qCeuCQABjoAPUk8AVg/2vIN NvHubmCBpQVcQ55DYODn5uoY9D04x1qvZaWX9bGtOPKlrb+rHHXOpSKxtsA6azYVohhcqQFPJ3MB gnn8qr6hpUG1XsWa7iSPDz3amNTJs+baMYxyoA56jniuiyg3y7AlfQ424+HvhswXWuuz6fq2or5n 2qweWMSSrkIzBcGQcDIPUEdq534Za9PfW93Y6/qFnFr1jcS2RPltFLK6uf3hQbjuZWVtoJZQxXL9 TFFSi3T6RWnptb8jWMeaN9+h7lca8ba2W3upn8m7h8pSuER1wPkVmBZkG3B65I4x1rB1fxQksFu1 vwq742e0f5jnLZbOSRz06HAx61tSjzWfczvzNx6/1/X3nET639v3S2YEyqVXzLdi8OUUgFmHGcZX tWzYW6XjwxXc8atNCD87hURcZBbPX5cYAOc45J69MJJe6QlaSv8AM35/Cj6dbwXYuI3sZ/mMDlw7 AOqlsDBAIDruJxlWGQa2LSz0sXjxLLHPBaAuP7ORJfnxjerE9clmyBkhRgrndU05ynuaXV9NiW70 ux1P7TafbJZ5IW/4+ZUCLImSVc7gzFiDuwNuMg4zuIjsfC0VxbpFC8t1bRRxyTNZoxA3Hb+9lOQg 3A/cBzu6ZUkOEnTeqIkuaWxlalYWulIfsypPc3KGTbaxGFGCsFJDMSSD8xwAoBB4HOYCl9M9vcS3 lsYEiYtZ2MSRRHYSSSScgkFjsG0E9jkU5X6mbtPd7GOLuySULc2y3UcDLiWHKyNh8kZ4wdwXnB4y AeaqwWtl9nnjhkMG92cRW+NjY4Y4Azk5GfUgcmnGLTTeo/UmsNNvL9pNq+X9nG94JjkFe4OSBtBI 6nuK4/xZ8Fk8fTQ2V7c6/pcmnxmNbLSmDuWcdWQ/ez3PQKO3fWlWVGSdr2/4YxUb6XPQfAv7OHw+ +Gc8WqDVf7b1udD5sl8/760YuVEQBTywxRXBb5gQyFSeje8afbXCWEHh2wg/suea38yE2sbMbpGg d3cguqRzBFVTJzkDbtYvxy160sS7v+rGtkvIyr+/+ypewaZp2pw2Txobss7/AL5FfAWVgQWUy7VM zAEbwDgnNY1r4wl8OGOWMs0JgVXtbQySLJKu0mUMHAO5TyQBjkcdKap9EJfFb+tDjtS1Jp7ZfIvi 8BcJLp/3GGEDAkjkqWJOCM/IvPAxkjfPFb+ZcS7kDYhjIVVCLtXIAwMqp4wN3HXpV8trgpX37Bul bzpWVLm3td8iwkhW3nAPAOSc4zjGeenbZ0y5mt7WGWeSWz81f+WqgCb7wwAADs3HuThl6Hbih+8n YUo8u39am7dadZR6cLu3uIG8mJXkkjRE2NhQcAehOCTk4KkgdBTWyjvJdPuIDqDJbNsWBCsYWNQC yxnaeHcsBgcEnOdxUR0JUeVI6q10me4lns4dFsbJsLIwSRWEZi3Dy88B0KoWI78HcM89svhy107T omMN/HdTRqPttq4cRyBpm3y5UhVZFKoQwO5i5Yj5RnNvRlRSenRFG9u9K02e9ltdWkvYpLdvN8xh 8uWUH5nbMzbirkKMMWJUIBXz5ZapceJPFOoxahbPd2+mXENzpbTK0UeXi2sygACR2fzNvXh49p++ ZKfRMuK5W33PVrfUgIYJkvZGvHzEz6qjSySBR5aRly2MAHpgHAbg/Kp0Jrv7XPDpiyzW5kjjMqT7 JfPYsWWRD6eXIcbSeCfmIzWnLaxEHy3sy7aabFp0Mlz9nthBbxhtriXe7LMxjfkszAGLfuVFXAC9 DVFdSUsoZFtzp4kC3Ei7HLDGWGPurwGAJyWBwQTwpPqiYyt9xgajqWp3LzrNcrLKUCyW8QyxDEsx YnlmGDzkj5hjpWZb2yWzOTPAu7IS21BGMaAoo35Jyrcgr1Py9BxnRNRW2w73epvWyjT2ubeZh5U0 asl3cBof4vmX5WG1iQvXsQSEPNMt7wr9olt1FnbXjKHM5+Y7VY/e+UBdxbCgAA45yATMUrNFxXRF i0s5oku5JBClpK0RhhjHzTAhv3Y3ZIzhicAkbAQQeR28uoNqz6Pb3senSwQmPZF9nieWNIySQxiM ZD7g3GBlZiSxPzUubZEX5UbWn+Gbm3U38bS2d+bhkQa3Ym6AcpsyIyWIYZDEYJRnBXDKhOhJFbtf 6LPva+uZRE0k0akCS4LSsQwLkwZIPD5G1Sd/OFiUurHKNkkaGpXk+o2Nn4dvk0u70eV41a6lWSN7 cSIjOInUjBYqk6sQ3LEDKnDc7putaXp73unPrFx5N1bGGxaR3drNmlKEFuD5pdG+UFRnf8rbwVN2 9CpO+kRsviLxj4fkhg0220ax0TUodg1i1EkV3dqVgV4ZZFPGcRgImX6lmALPTLySfWopjqOm2mnR ygxadcxN9lthH5nzAec5jMRDxruyOiHcpPCjFuWhDjppv/kcHr0N14fkh0+5l1CGW6hKxG1LpGU8 9iQIyV3biW/dncoOSSecclI9pIkUtvqE7l2IkmaRWSNRyEBXO7Mhcs+RuJOFBGT0U5WVyYzi9GZM GUlZFS2lidywES+dkbTliD3AyxXIxuznOcWbeV1WSWIm1X7hk2Y80Yy2zHByB6Egg+taXSuPmT0f QcVimMdpDFuVgrNEwAVccA8EdQF7jv6CiBocAkOFZoyCz/I7YJbLckLu9jwT3HKm+wSfNozQu9Fv raGC4dxJb3K8LHIhYopRckHJwSeuM/u2/unENo28iPb87KTtmUKON24HOST90e5J9Ku6Zp/DsWFk W0eMsZfMVlJjPIkcj75XGApIYZyeD3xyy4v/ALKh8hJJnIYqoHXjdg84PPTjqe/adtwiubR6lO2u r67me91GcyM+MtGNqg8AH5s9z2xxjrjnT+1B0djDHgkDbGGLuxz1JOBww7fh3MyXQ0qdUjDu9I03 Uzl7dYb6Ng8c8JaKYggHO5DkHjPUdKil0G6hVvsWuaimVHyXYFwiEZHXAY5yCeT09Ty/aKNxTV1y r+rkDweJba3EccOk6hIqhUQs9szEj73KuMnJ5z2GR0qeDVNTs7RlvtEvh9n3I8dopuAfUAJluGAy No++T61lzpqzMo+9v/X9foaUHiG01CNv7PvYriEBvMUn98uB0YDoRjH3TklvStq2uLaTFw7h0VjG Qm1sfKNqbTnH93tyfXmp5bXj3FUThp2LX2i0igSQny4FONrkbY+uAQCWPXk4P3cGuQv7l3jLq0lz 5ZJO1hjaGGCc89+vv1pwjbcEk7J9CBdqhbjcY0i+9EQAytyegOT0AHTrSK0pEsW118xflZiV5BJy eev4jrVXvdPoRdrS39bEjzxWSTLvCm3Ta4yFBC/eyTwRtORnOCo9qlgjgm1C2V1lXK74zMgcyL03 gfMCCW5ByeRyAOR6aPUmaV7X/wCG1PQvC1hPHCbl4ZjeSIxF0sSYtxuyXCNgSAKDkZ5BI4xmvYLS PRbiGym8y6tp3xJDtaaOZwTI6SBgWBLjG4DADH744VeSorO0fMubvtv2763Pn1NR8O2sD/bJpBZw ShvM2jzLgnPBPVBjOP8AexwME6+reLdLtLG0jtr2bz7tJJ5vOGQZMMqFSRjPUk/yPNcrpT0fTb8L /wCRoptXSdrHCX3i+5vYXtneaV7eMJ5+856+/UA7sfWuRi1PU0up7qeQXlwoaIm5jQKrZ6JkYDe4 HFdUFGmrPqOMW7P+ti/ZR3OqI06y3EroNkk1sxaTex6HJ4JK9/TNdZa6bFNbmSeVTaW3ZSpOdrfM SOfyIHTPasKj5fdFG8ba7sjjsRFZxSaNDqqNu3SX7IFLrxuwRnC57Z4CjgEnF3VIL1Etp0fzGnbA Nw/mvGCoDbVBBUgDg9PTHGHKSlp8tDZLmVzDuBAL1bt72S5a2KeTNeFpZGj5X1+Xpx1+4enQeO+O PB/h7WLq81QXd1Y62IDBHq+nyPFMJGxv+YEH+EnOO2KmVKppUh8SRdOsoWT2/r9Dy3w/qWueGPE2 lfDbWmfxde3Ft9oiupZJPM8mMqGkkV/myM4O0HocEV9A2ekxyGzJ024DYkVl3f6xlO0Y3fKuSMcZ 65ySBWyqKpaSfxX07W/4I5pUm2lt1O10/wAGi38iwlRtMiiZfPhgVHBZfnJJyA2BuG0cjgEDkjpo FJEt1NY2bw6FF81yER3Ac8A7PvSleQN4x8wycbhcKilp/XUL3SuyPUNL1GdrPSEtr+xsrtlMupSA SF8d0YklQxYqFG0Ekckk4yhpj+ErxvPkZV+e3Iu3LeYqcsrJGwOTkLyfoTyRcJuVkupEubZIoPq+ mRv9mhNvcwpIZWuZgA3Pyj+LaFxkbRn5T0OKih8T2dg0K+TeG5w73V3LIGLbztYIuAqgjapXJzt5 4xjo5Oe1zKUk7swNRuorm+nns4ohZTMGd5Bhdxzkoq8qgbjGT09+GT3dxJbXYaS3hkmYho4odihS 2Sq4+7gnj/dx9HKOitqZu12rkf2YtaJGI43lGSY2+XJ+U4UYyWwQM8g7jwe3V6V4VfWLmCDS4ZfO 1OdkS2uuZ1Bxty/AyS3J2gZx25E6RVxRXMev23h2y0G91BIry5gubqOSGbSvDsmwXkRbcFnVXJeD YmW+U5A5LludCzi8y7j0+x1O1sD8r/Z/3Mk2FXKo0pGV2jcGbBbkZA7YpO12Xfl0/pmX5tq+lv8A YNH02/gNy6/br4Ad2aT95JkM+Aq/KV43AqdysecNwllpdxpVra3drDIqiW1nhVoX+V38xZJDu5G9 flGGHBbGMkU4qxPNZanF3fiC/uWbT/Lt5oZHAMzxKYkUN/qgwGMK2AOWyqnG0SMC9Bc61PbSTXM9 7qNyPLdym+SVgy58wkbnB6A5JG1BgkYrWMbLYn4kVr2KW1e5llMENtqDP5QgXzUZVI2mNpBlRnIy B6g4zWdawXNslvJNBarbO5JSALI6oM4Yc5J2sSOR7nHJiLTsmaRstX3NS187TXke0nhtLQM0a2ls ke4GQPwoGSBk9RyBsyTtAosZL6bUbmG1tIJYp1WLyrOMNuUQ8Eb88sQGwvfGOSBRFESk7aI1fDdl CTY2sCXxgcYuopIg0LHfgFiSVwFfJY4HIXbyS3S6RbS6Vd3qSWdpPbadCTHd6Wu6YqeDvIdUEe6R EbBwBkBGIOYneWgLWKsabXMEMKs0/wDoghVxFH/pCMShHIYDHKoc8/eUMGLYaWW0vL7T9Qks5Jba y3I0moSOYlkVcLIqhvlZmIQ9RkoTkgZpvTcSSSZ574k84zpa6W66vdXpaM/2iEzDvUnzJFOUVdpD cv8Ajmur0vTrDTltdCMKW0du0bxWt0cfu3EbeZwSpBDLlASMKu7djhKPNO67Fyk1Ff15Gmmnpe2P 2qK0n02XT8tBCz/vZisbMJRG2MYK/e4PPRg2Kgv9dnsn0WbV9QlvbnS4Y0t8l82sCu+IEV2KxoSW PAAPXqzE6b3M9texzd1q8SPDNb3qXRuF8y7sRD5UUT+Y2I1CgblVCvOOGLAAgA0up376nNcyqzyJ DC6gXjlih8piueeSGkUk4GRk5IU4aXLqW4klvqGnx6WYZbaS5uIX3xpBKY0jMiZZ9pU8kbctwQVz 2GMmS6ga+ZJnguJnyIoERVhYgFgCcDkED2wCM4xVK6u2Vy8zsja0eC8mkeYXck00ER3xRASEou4F MNjLAGPoD98Y+7g2bWEWk8vmC3mCEELcuUKuVXnGQyjjggYznrghc+bRxQ4y1szWOoXF1BGmnpeP dbNt5eSKqoZWklVSrgHjy2GSQvV+AOa0bZbtmn/0Kz1EQgPM0YQ3UACKpYYO3gAOFbqTkDvTVu4K 6NnSZNb8Nf2idSsZ5tCvRLBbw63fKHkOQudq5IYI8g3AEZc4G4HPV3E9/PZ62boWOqrcxvGt3cyb V8uNHjR5GRQUkaKFo0j+8C8bfKyjdjJe0T/ryBXhZvp/X5nmknh5tP1ZkmP9kJAsRk0+4VixKiMN JjC/OQMk9SECgtwRpaj4luNQtpjaae0cuoW2+K9vgySxF5pZAyLITkklyDnpuBGCa31kr9yLNaMr X0Vtb3SGW0ln0lkK2VhLEssMKlcfvWjPy5lk3hFAJOSyktzwUnih5Z2W5E8EM6vF9rtE2rC7ASEl DyFzKOjAnYfmzyK1aTJlUenSxnanePcajezLbtBBesGFtMolEa8EED/e9skgZLYqJo0t8zPPcW02 5lG376qxIyfm46t3HJ6mr3WnUN3YitbdP3jThGicM4t5GdQ7gcFuo24+nB545rUli32sUixrAYX8 nz3GN20jOHJx1xx7g5FPZ2sFlZu2pnXkdo2+K1eYIi7TgguoJ3BiB8xG0+/I/KkqXVvvMcMZli+d t6Z3Yx27jAOeD05NVbzKXvWZqLFrEsUN1K97YQukbG0YNFHKC3ygDlSoMbck4yrehAsm2WCIyusK GPcEgZwpZlIba20FufmGQOoOeayUupbjzXHtNBMqsFO/YW8mRgzpjknj1U/oeTmpIWl/eR3kqKpQ u2IwzI2cnOD144zkdBxVvRpPoUo8tn2/r8iCKBBJINguFQhfKXJ3Nuxx05yF4zn5qdNJJJOA0LKC gO5VC7enJyO+Tzn0NOUrtGkoJWaKokaV4R5Y81ZBuDMSp3Y249DweffmtKwsbiWR/MKIsZ3B4s+d yehPI6Bema52+UhXv6nRQeHoYoy3lq4YgmWNT8wXB69sjPOeo5p8mnPGrrOd0NkwO6Mt8+eRnHfq fbP5ZOqr6dCqsH26GBrXhjTtWtfIkjd4gRHHdWajz4jtyGQgcHOcH2B4788v/CQeF002fUEudWhg kjjOpachF2pH/LQxHnAxnhieSQBjh315f66mfxWsNi1vS9UuIUtZ5ZsK0k+nrlZ4lznLoxBzhCME Z7ZpytFJPduJ3Z9rBJo8AMN+MYPVRg/L3yPTnbWK17GO+5Q3S29ySFQE4AlVijZ7c91wN3v361pw 3MluhjSGVhIW8+EbXLcYXBOADjB9eOvJFHKtfxLUefXzITukV7cSgbyWLxgF3GABk88Ekgj0H0q5 omgS6rd6fZ28DXAmZVaCEMvPygcg9SWxj/Z4HFVOfJF9rf1+BKfM7Jbn0p4X0BbOLXLK4srX7TZh EdtTk4t3to8yAySBl2qqPujKNnIwRwDZgtNHsZ9bGlRLfeF7VIpIbzWYljmZolX96mCCQxkVzGWx hhngYric2+ZrV6fi1p89WzVxSjzP+tz4cEa3mwW8dwLiOQqtrCGKMoA6u3fJHb9KNRiuZ9SEd7Os iICP3LgRxAfKoznHTjsOmCe2il7Oy/rYysm+WHoXf7MKlnCR3WXGWZtqLGq5AI5OTjOMfnnjegsr i8urc3Ucdxasd378sqT5b0U7vX079e/PUnzO7NJSlqkaulaDHELyHdOsWQzRQN5XmZYgJxnavA+Y 56niukWHT7PSSYUl1GaxhJW2uXUgkglztBDbQMDoxyM5GeM3W51Lyt/kaUk9OpjWOoXE1reTatNY 2a8ItnKzZJBAOAoPTn5SR6+lZmqvqeprdanbvE9uhLvdqWYzfPgEhsdSBzySRk8jjZRUW2k7Fypv R/1/X+ZsWUaadbC31Ox07yJlP+lTuzEsWwQOOGxzhR0Cg5yc8VcJppmeGxwkhXcn2dEwqH5nZi3U ggY+fPXGO7fvNtP+kXKCirNHF+K/AWr61Faa9s1Rb+Iz/Y9YtJEWZFfb5hBkztBwFzjBwQCcEjA+ FHjDVbnUpvB/j+Qaf4s8PIJJZpnF0kkRZvLkRtiqSMAn5SQc5VgeYoVIwvTjq07r73dfebKKqwat /Vz6k0rxXp1xHpkllPdLcuypLZfIiJlW4JJUDOM7gEwH4Geaqap4gljv5ZLx/ItYAzDyU+zzTDoA SclZNpGfmbODyQTW1Om07SXf5/8AAON6OyX/AA5wqa5rl2moX9ja6n5sakM6N8iLuZcBi2QNpx/E Tk8/MawppzeG2E960M1k2TdvCjbOCSME/P8AdznIIzjkCuqDV2lY0vom0UcKJGQSpKBkAwkKr46E FgcZHPPOSfTAsxWrSSXF3cpvDgTeYSX3DZuGSOpOSODkZ7c425uV3ZnGzTbZQle3itpZ5ryGKOBg jXrsEt+ckHceRwTjIHf0rO8H+MtB8aeI7Xwjo2t2v2uAHBieRYTyAThQd3Vj8obqSBilGDqK8U9N TKq43X6f18j3RJPB+k6hH9o1vRn1GCNrd9O+1w/aGV0PzSbXLLu3BT8v8ZX5s4rIt/HfjzTLoyeF vAsen6FakRN4hjuYlBVTIjzRlsjBaI4dMkmEjCls1zOmtpuy/MPg1Wtjzc/tX2tn4k1C2k0CPT9E jEluLiEoZ7ieA7ElkD7PKiCsW2kMCw2gYAFerHxPfXtlb6slzDHpF9CfJZtzsuUZkBT5ccNjCt8u 4YPy4G9Wh9Xtba34kOftLvsZ6ajfSWkOmNeywzNsWT7NCmy4XzM/vfn2sB8pVccGMYAIDGlf2mvW A/s++tj9tt2YtFDH5nkuqrlScfKyqFyvG3G09SDlezt3JvYibTLq6dImWeCWXypBDaRiUyoCD2wy sVCnjPOepODkrds0lztImaNgRkhCSu04AA+Vs7Ryf4c8nrdnFpLZCu07d/8AItzjzbFo3gj8yxlY KIUKyMpBC4YcEDn16jnpVKWP7MIwEO04DFzgkhsNheCecZI56+hpcq+4mdrq3/DbGtZxXEsEOp2o uTbyO0Rn2htpVEdgFYqTksBkjGW4ziu202OBJTqNnNDaSzyPAJb3fHLEjR4L7UYFVCqw2nIAGGzj JzdS12XOXLZPff8AA6ixtrWO2Gp20FtZacZgq2+03bTPscibBG3Y5ZCw5+XI5yd2vd6O9tataJbX 0mraWxkzbBVnaJ43Ds65OwbjEMt97zW5zwuLfLo2TfXfY5OCwk1NNO1aaWIMHa1WdAy2oKjJdGA3 TPhOVzhS+RglVLrrUrvSLPSoNUWbU0s/3SWN3M8DW0e8F0eM5CqSx47HnnBFbtJ2T3RKaVkmYdpq 8Fil88gsFg1OYzpBdxMEgDEblG3l13+aeR0EecDipNSea8SC9v4Z7Swn82QSu+JZQoO0AbSVbkDB IHKE5AOYoQ5bN/0x81/dl/X9MsajcaqtvqIZby9sbe4T/TWiZXiiYMqB5BxtYJx8uDjAGASadtqt 29pLbIJb6ztWLrZSsZI4i21WdMdyEXJz6D+EVvGP6gp236GZtmsNkWsJexw37FzayAlF+QbZA2C2 4F2O0Dgt1GTTYYIZImNpby2ZeJLdrhlJE0hVchQuPmIXhAD1BJGKmO90UnB2X9XK92XlBFh5JhjL L5rKI55Y1ITkD1H8IPGTnNV7e0EkrzJbizt0DxlmIKllBG7nPAzj8OopLuzTmvY6LTNVbTjNHCxt ZUjEIvo2ffGDG4cBPuvwcAZGABnqwrSj/tLXmkuWvJTbiIZnu3BY7VysW7jDZHGepeo5UtZCbT27 nV6fYeVOv/EtnWWRndY+ZDGuGK+adg4CkbsjBT5uARnq5LfT9FguPO0eRZdSjAa6NuzMqvuiRQFU AxhZo2HGcDIBwoMzbvZCjUtfXY4geJZpNTTS0kl0wWFwEWRQ7JHtO4FSDu3LycjPDnjGQdnRptNu I5jqdld6e9/meNL1j5UqLHt8yAgZyW3R7iTuKZJYkJVuny7dSubne5S1HRbOy06OSWY3V5K80n21 irJAv+qwW6DJRCS3CCUFVbHz83BFr2p/aLye2aPR08ydNTuI5IUYFvKITYCDgoVxkjIfnvTpq+/T /Mmc+Z6Mn8R682tC5H9mwyxmQStarN5ju28HLseeVQoV46ZAXJrzu6T7EIoAkUlxAuyVISQqEDY2 7+HedpJx7DjBC3yWt94pPm3X9alddkKnzH3sASs8jgkyHIAxj5lJbgeo61vxRRXrxy37wxPBIG+w JGohKDJLFdwLHPygdMNyVwAdb2eg4xvd3INQjZ0nmiZHimBZTYqYNq4OUVSMYLBhxuHB65xVUXkM DL5c8kah2BaVCuGPHGM/dUhug6mlCPMt9g5VD3TdtmjMcwt4rC8LEBxG4lmQMSQQQq5K715znKHo MGssySiRpfNZLZ3EZ/s9vIdFGBjAxjOOMn15OCKd9blWtdp7f5Fm3ZVuEWWaSFZpkHkTKPKUn5Ud tozjaGxznrjpT42t0TEkcMYLEeZM+Dj5fmBIyBj19/XFRtuXa+jI5ruHbcSTwvJBFH5hGNzcscja fXC8c4zx61Va4ZoI4QrxpIWQ8bzg/wAQBO3OfT0HHFX8PU6IytZsrpcbfJR4hOIxuJzkKemTz7fn 7YpxvBK8rRWybkJ/eK+G5IbH1GOmM/TFTFq4oq23kWlV1gDxOssuRklgd44AAHXjJzg8cfUb+k3U zvHHIo+zjAD5LPwPbPP8+OelYVY6dgimrfL/AIJ2wu4ooridFGRhViDAIMZGDnJGBinncyRgtGMb Uf5drAYGSe2On65I7+V7N3d+5pbntY2bRIEZHijlh34PyjO0HjPHPUAZ/Gn3FrZTrK8qRvtwDgAD ofTHoD+ftmfa8j3KdKLVjgtc8FaTrFzIl1bNuiKhmjOHj425GMEYXgcnp715nqPw313QreQeF9Sn uo42y+j6+8kyjIyCsmGbhgODuGBxjiuqni3Sj32/QzlSs7GVI2vaZGkmseHp0CqFGo2Z+024YucE 4UMqhcjlSPlzkDgQ2utw6h9ojsLi3uFjUNiAhiBg7XYA8HBIr0ISjUTcWccaTTu+lzbe6gcS3bSS Rt95/LjDICHO5dvI6LnBA9Oa9E8PaC7Tah5j2N7LZsVVreVfNdw6n5ct8wHzcDgjuDxROeqS6/8A AJhJK6v0/Q9shW90nwqJLp2uvItWuDpmpbo5MeVIjeWPlDIJnYnaCCUJwuGVsG+mtNdsYDCrtMwh tY2ld0doxuBwvK7xGyn7wHDnuMYw5l7y76W6WFUjze632/A//9k ________________________________________________________________________________
Date: Jun 06, 2018
Subject: Re: Lithium Batteries
This is a update on my lithium battery (LiFe) in my redrive VW powered MKIIIC. The battery has been in service for four years and is performing great. Every year I take my balancing charger out to the hanger to balance the cells. This year the cells were showing 3.33 volts on two cells and 3.34 volts on two. The battery was also showing 13.20 volts which is its rated voltage after 7 months in storage. Once again I didn't balance the cells because my balance charger can't balance the cells any better. With the lead acid batteries I had to replace the batteries every three years. Rick Neilsen Redrive VW Powered MKIIIC On Tue, May 31, 2016 at 5:58 PM, Rick Neilsen wrote: > Lithium battery Update > > My LithiumFe battery is two years old. For the second winter the battery > was left in the plane with no battery maintainer or charger attached. > Maintainer/chargers aren't recommended and with only a 10% per year > discharge not needed. The big VW started up just fine (after almost 7 > months in storage) with no charging. Later I took my balance charger out to > the hanger and checked the cell voltages. They were all exactly 3.35 volts > so no balancing or charging required again. > > This new battery has so much reserve capacity that I have modified my > start procedure. With my old 12 pound 12AH lead acid battery I would prime > the engine and pull it through one engine revolution so that it would start > on the first cylinder going through compression. When the temps were in the > 50s this was critical to get the cold engine started. When the voltage > dropped the ignition wouldn't fire. With the 1.8 pound lithium battery I > just prime and hit the starter. > > See the following for battery details. > > Rick Neilsen > Redrive VW Powered MKIIIC > > On Tue, Jul 1, 2014 at 1:05 PM, Rick Neilsen wrote: > >> We had a discussion last year about these batteries. As time goes on we >> are getting more experience with them so please share your experience in >> your airplane. >> >> Some basic facts about these batteries are they are much lighter, smaller >> and currently more expensive than equivalent lead acid batteries. They need >> to be charged with a special balance charger at least infrequently to >> achieve a long life. >> >> Battery manufactures rate their batteries with two terms, amperage hours >> (ah) and cold cranking amps (cca). I'm not sure these terms exactly equate >> to lithium batteries but this is all we get. AH is the total energy in the >> battery, CCA is the short time cold starting power or in third grade >> analogy a big engine with a small fuel tank. With many products there are >> some that may over state the performance/values of their products. >> >> Impressions about Lithium batteries are that they are, voltage and >> temperature sensitive. The Lithium batteries that are being sold as lead >> acid replacements like mine are described as Lithium Iron Phosphate. The >> claim is Lithium Iron Phosphate batteries don't catch on fire and don't do >> other bad things??? >> >> I have very limited experience. My new Aerovoltz lithium iron phosphate >> battery is rated at 15ah, 275cca, weighing 1.8lbs it cost $180 including >> shipping. My old lead acid batteries were all 12ah with app 185cca weighing >> 12lbs. When I installed the new lithium battery I did >> the recommended top off charge then turned off the master fuel valve and >> cranked five times for 5-10 seconds with a cool down (for the starter) with >> no change in cranking speed or voltage. My old 12ah lead acid battery would >> drop off near the end of the second crank. When I first got the lithium >> battery I was convinced they forgot to put the guts in the battery case, it >> is that light. I always kept a battery maintainer on my old lead acid >> battery because it was so low in power and they do self discharge. With the >> tested power of the lithium battery I will not be using the battery >> maintainer. I also don't know if the maintainer is ok with lithium >> batteries. The manual with my Lithium battery states that there is less >> than a 10% discharge per year. Also I stated from memory that my plane >> weighs 587lbs empty, well opps that was before the battery change and >> redrive upgrade. It now weighs 576lbs. Redoing my weight and balance >> calculations >> >> Please share your facts and label you "impressions" as such. Also if you >> are debating with someone please read the others responses. >> >> Rick Neilsen >> 1st Redrive VW Powered MKIIIC >> >> > ________________________________________________________________________________
Subject: new video
Date: Jun 06, 2018
Thank you for posting your videos, I enjoy them greatly Rick From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell Sent: Tuesday, June 05, 2018 6:38 PM Subject: Kolb-List: new video I decided to go flying today, so recorded my flight. Unfortunately I foolishly uploaded an update to my Virb program and it will not display the normal speed,altitude, track and the other stuff that I liked so well. Every time they have an update, I lose something else that I liked about the camera. https://vimeo.com/273592183 pass word owyheeflyer Larry -- The older I get, the less tolerant I am of those who are intolerant of others. If you forward this email, or any part of it, please remove my email address before sending. ________________________________________________________________________________
Date: Jun 06, 2018
Good service out of the lithium battery, Rick N. I have been using this brand battery for the last 18 years: https://www.batterymart.com/p-odyssey-pc680-battery.html It is an AGM. I remember before the AGMs battery, acid attacking my Aerothane paint, epoxy chromate primer and 4130 fuselage. Was a pain in the butt. 2000 Sun and Fun Flyin, I was getting close to departing on my second flight to Alaska. I had used a lead acid battery from Walmarts for my first flight. Had to replace it when I got to Arlington, WA. It wouldn't crank the 912UL in Ashland, OR. Last year I had to replace my last Odyssey after 11 years service. In the hanger I have a small solar panel/battery charger/maintainer to keep it charged. In the last few years my MKIII has gotten very little use, but the little solar charger did its job. Of course the AGM weighs 15 lbs. Rick's Lithium weighs a fraction of that. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen Sent: Wednesday, June 06, 2018 11:08 AM Subject: Kolb-List: Re: Lithium Batteries This is a update on my lithium battery (LiFe) in my redrive VW powered MKIIIC. The battery has been in service for four years and is performing great. Every year I take my balancing charger out to the hanger to balance the cells. This year the cells were showing 3.33 volts on two cells and 3.34 volts on two. The battery was also showing 13.20 volts which is its rated voltage after 7 months in storage. Once again I didn't balance the cells because my balance charger can't balance the cells any better. With the lead acid batteries I had to replace the batteries every three years. Rick Neilsen Redrive VW Powered MKIIIC On Tue, May 31, 2016 at 5:58 PM, Rick Neilsen wrote: Lithium battery Update My LithiumFe battery is two years old. For the second winter the battery was left in the plane with no battery maintainer or charger attached. Maintainer/chargers aren't recommended and with only a 10% per year discharge not needed. The big VW started up just fine (after almost 7 months in storage) with no charging. Later I took my balance charger out to the hanger and checked the cell voltages. They were all exactly 3.35 volts so no balancing or charging required again. This new battery has so much reserve capacity that I have modified my start procedure. With my old 12 pound 12AH lead acid battery I would prime the engine and pull it through one engine revolution so that it would start on the first cylinder going through compression. When the temps were in the 50s this was critical to get the cold engine started. When the voltage dropped the ignition wouldn't fire. With the 1.8 pound lithium battery I just prime and hit the starter. See the following for battery details. Rick Neilsen Redrive VW Powered MKIIIC On Tue, Jul 1, 2014 at 1:05 PM, Rick Neilsen wrote: We had a discussion last year about these batteries. As time goes on we are getting more experience with them so please share your experience in your airplane. Some basic facts about these batteries are they are much lighter, smaller and currently more expensive than equivalent lead acid batteries. They need to be charged with a special balance charger at least infrequently to achieve a long life. Battery manufactures rate their batteries with two terms, amperage hours (ah) and cold cranking amps (cca). I'm not sure these terms exactly equate to lithium batteries but this is all we get. AH is the total energy in the battery, CCA is the short time cold starting power or in third grade analogy a big engine with a small fuel tank. With many products there are some that may over state the performance/values of their products. Impressions about Lithium batteries are that they are, voltage and temperature sensitive. The Lithium batteries that are being sold as lead acid replacements like mine are described as Lithium Iron Phosphate. The claim is Lithium Iron Phosphate batteries don't catch on fire and don't do other bad things??? I have very limited experience. My new Aerovoltz lithium iron phosphate battery is rated at 15ah, 275cca, weighing 1.8lbs it cost $180 including shipping. My old lead acid batteries were all 12ah with app 185cca weighing 12lbs. When I installed the new lithium battery I did the recommended top off charge then turned off the master fuel valve and cranked five times for 5-10 seconds with a cool down (for the starter) with no change in cranking speed or voltage. My old 12ah lead acid battery would drop off near the end of the second crank. When I first got the lithium battery I was convinced they forgot to put the guts in the battery case, it is that light. I always kept a battery maintainer on my old lead acid battery because it was so low in power and they do self discharge. With the tested power of the lithium battery I will not be using the battery maintainer. I also don't know if the maintainer is ok with lithium batteries. The manual with my Lithium battery states that there is less than a 10% discharge per year. Also I stated from memory that my plane weighs 587lbs empty, well opps that was before the battery change and redrive upgrade. It now weighs 576lbs. Redoing my weight and balance calculations Please share your facts and label you "impressions" as such. Also if you are debating with someone please read the others responses. Rick Neilsen 1st Redrive VW Powered MKIIIC ________________________________________________________________________________
Date: Jun 06, 2018
Hopefully, I didn't mess up everyone's mind to badly with my msg below. My excuse is, I painted some sheet metal valley tin on the roof of my house in the hot Alabama sun just before coming in and trying to type an email. Let me see if I can straighten it out. 1994, I used wet lead acid battery for my first flight to Alaska. It gave up in Ashland, OR, but was able to limp into Arlington, WA, to change it with a new wet battery. On that same flight I had to get a jump start at Deadhorse/Prudhoe Bay Airport, Alaska. The new battery didn't like cold weather. 2000 Sun and Fun, Tom Pehigny gave me two Hawker Odessey batteries to try, a 12 and 6 amp AGM. End of my battery problems. Back then if I could have gotten a lithium battery and the money to pay for it, I'd have probably used one. Lithium wasn't available and the small AGMs were just being introduced. Please excuse my feeble attempt to write an email. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck Sent: Wednesday, June 06, 2018 12:08 PM Subject: RE: Kolb-List: Re: Lithium Batteries Good service out of the lithium battery, Rick N. I have been using this brand battery for the last 18 years: https://www.batterymart.com/p-odyssey-pc680-battery.html It is an AGM. I remember before the AGMs battery, acid attacking my Aerothane paint, epoxy chromate primer and 4130 fuselage. Was a pain in the butt. 2000 Sun and Fun Flyin, I was getting close to departing on my second flight to Alaska. I had used a lead acid battery from Walmarts for my first flight. Had to replace it when I got to Arlington, WA. It wouldn't crank the 912UL in Ashland, OR. Last year I had to replace my last Odyssey after 11 years service. In the hanger I have a small solar panel/battery charger/maintainer to keep it charged. In the last few years my MKIII has gotten very little use, but the little solar charger did its job. Of course the AGM weighs 15 lbs. Rick's Lithium weighs a fraction of that. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen Sent: Wednesday, June 06, 2018 11:08 AM Subject: Kolb-List: Re: Lithium Batteries This is a update on my lithium battery (LiFe) in my redrive VW powered MKIIIC. The battery has been in service for four years and is performing great. Every year I take my balancing charger out to the hanger to balance the cells. This year the cells were showing 3.33 volts on two cells and 3.34 volts on two. The battery was also showing 13.20 volts which is its rated voltage after 7 months in storage. Once again I didn't balance the cells because my balance charger can't balance the cells any better. With the lead acid batteries I had to replace the batteries every three years. Rick Neilsen Redrive VW Powered MKIIIC On Tue, May 31, 2016 at 5:58 PM, Rick Neilsen wrote: Lithium battery Update My LithiumFe battery is two years old. For the second winter the battery was left in the plane with no battery maintainer or charger attached. Maintainer/chargers aren't recommended and with only a 10% per year discharge not needed. The big VW started up just fine (after almost 7 months in storage) with no charging. Later I took my balance charger out to the hanger and checked the cell voltages. They were all exactly 3.35 volts so no balancing or charging required again. This new battery has so much reserve capacity that I have modified my start procedure. With my old 12 pound 12AH lead acid battery I would prime the engine and pull it through one engine revolution so that it would start on the first cylinder going through compression. When the temps were in the 50s this was critical to get the cold engine started. When the voltage dropped the ignition wouldn't fire. With the 1.8 pound lithium battery I just prime and hit the starter. See the following for battery details. Rick Neilsen Redrive VW Powered MKIIIC On Tue, Jul 1, 2014 at 1:05 PM, Rick Neilsen wrote: We had a discussion last year about these batteries. As time goes on we are getting more experience with them so please share your experience in your airplane. Some basic facts about these batteries are they are much lighter, smaller and currently more expensive than equivalent lead acid batteries. They need to be charged with a special balance charger at least infrequently to achieve a long life. Battery manufactures rate their batteries with two terms, amperage hours (ah) and cold cranking amps (cca). I'm not sure these terms exactly equate to lithium batteries but this is all we get. AH is the total energy in the battery, CCA is the short time cold starting power or in third grade analogy a big engine with a small fuel tank. With many products there are some that may over state the performance/values of their products. Impressions about Lithium batteries are that they are, voltage and temperature sensitive. The Lithium batteries that are being sold as lead acid replacements like mine are described as Lithium Iron Phosphate. The claim is Lithium Iron Phosphate batteries don't catch on fire and don't do other bad things??? I have very limited experience. My new Aerovoltz lithium iron phosphate battery is rated at 15ah, 275cca, weighing 1.8lbs it cost $180 including shipping. My old lead acid batteries were all 12ah with app 185cca weighing 12lbs. When I installed the new lithium battery I did the recommended top off charge then turned off the master fuel valve and cranked five times for 5-10 seconds with a cool down (for the starter) with no change in cranking speed or voltage. My old 12ah lead acid battery would drop off near the end of the second crank. When I first got the lithium battery I was convinced they forgot to put the guts in the battery case, it is that light. I always kept a battery maintainer on my old lead acid battery because it was so low in power and they do self discharge. With the tested power of the lithium battery I will not be using the battery maintainer. I also don't know if the maintainer is ok with lithium batteries. The manual with my Lithium battery states that there is less than a 10% discharge per year. Also I stated from memory that my plane weighs 587lbs empty, well opps that was before the battery change and redrive upgrade. It now weighs 576lbs. Redoing my weight and balance calculations Please share your facts and label you "impressions" as such. Also if you are debating with someone please read the others responses. Rick Neilsen 1st Redrive VW Powered MKIIIC ________________________________________________________________________________
Subject: Re: new video
Date: Jun 06, 2018
Great video as usual Larry. I know you've tried the camera mounted almost everywhere on your plane. How did it do on the center wing section, was the vibration too great? At that location seems you would get the pilot doing his thing plus the view he gets during flight. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480714#480714 ________________________________________________________________________________
Date: Jun 06, 2018
I would have preferred that, but the jello that resulted was just too much. Depends on the camera, but the ones that i have won t work there. Larry On Wed, Jun 6, 2018, 2:41 PM japowell wrote: > > Great video as usual Larry. I know you've tried the camera mounted almost > everywhere on your plane. How did it do on the center wing section, was > the vibration too great? At that location seems you would get the pilot > doing his thing plus the view he gets during flight. > > -------- > Jim P > WAR EAGLE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=480714#480714 > > ________________________________________________________________________________
Date: Jun 08, 2018
Subject: Placement options for CHT probe
Greetings from Sebastopol, CAHas anybody used a cylinder head bolt ( immedi ately next to a spark plug) instead of the probe ring=C2-under the plug? I am currently using the cylinder head bolts, wanting to eliminate the wear and tearon the probe ring when checking/changing plugs. Seems that the tem p. readings are lower- maybe due to the heat lost near a fin?FSII 503 dcdi =C2-EIS monitorCHT runs around 100-120 deg John Fitt ________________________________________________________________________________
Subject: Re: Placement options for CHT probe
Date: Jun 07, 2018
On 6/7/2018 8:35 PM, John Fitt wrote: > Greetings from Sebastopol, CA > Has anybody used a cylinder head bolt ( immediately next to a spark > plug) instead of the probe ring > under the plug? I am currently using the cylinder head bolts, wanting > to eliminate the wear and tear > on the probe ring when checking/changing plugs. Seems that the temp. > readings are lower- maybe due to the heat lost near a fin? > FSII 503 dcdi > EIS monitor > CHT runs around 100-120 deg > > John Fitt From the Lycoming world: Washer-based cht probes on the plugs always indicate significantly higher than probes screwed into the heads. The plug is the hottest spot in the cylinder. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 07, 2018
Thanks for the reply. Any way to save on the wear and tear? Sent from my iPhone > On Jun 7, 2018, at 7:22 PM, Charlie England wrote: > >> On 6/7/2018 8:35 PM, John Fitt wrote: >> Greetings from Sebastopol, CA >> Has anybody used a cylinder head bolt ( immediately next to a spark plug) instead of the probe ring >> under the plug? I am currently using the cylinder head bolts, wanting to e liminate the wear and tear >> on the probe ring when checking/changing plugs. Seems that the temp. read ings are lower- maybe due to the heat lost near a fin? >> FSII 503 dcdi >> EIS monitor >> CHT runs around 100-120 deg >> >> John Fitt > =46rom the Lycoming world: Washer-based cht probes on the plugs always ind icate significantly higher than probes screwed into the heads. The plug is t he hottest spot in the cylinder. > > Virus-free. www.avast.com ________________________________________________________________________________
Date: Jun 08, 2018
Your CHT seems very low. Do you have your EIS set for centigrade or Fahrenhe it? The most common cause for the disfigurement of spark-plug base rings is over - torque of spark plugs. I was surprised to find out that my engine ( 40hp H irth 2702 ) only requires 108 inch pounds ( yes, inch pounds) of torque and w ith the spark-plugs seal ring installed with no anti- sieze compound. George H. Mesick, Michigan Sent from my iPhone > On Jun 8, 2018, at 12:23 AM, John Fitt wrote: > > Thanks for the reply. Any way to save on the wear and tear? > > Sent from my iPhone > >> On Jun 7, 2018, at 7:22 PM, Charlie England wrote: >> >>> On 6/7/2018 8:35 PM, John Fitt wrote: >>> Greetings from Sebastopol, CA >>> Has anybody used a cylinder head bolt ( immediately next to a spark plug ) instead of the probe ring >>> under the plug? I am currently using the cylinder head bolts, wanting to eliminate the wear and tear >>> on the probe ring when checking/changing plugs. Seems that the temp. rea dings are lower- maybe due to the heat lost near a fin? >>> FSII 503 dcdi >>> EIS monitor >>> CHT runs around 100-120 deg >>> >>> John Fitt >> =46rom the Lycoming world: Washer-based cht probes on the plugs always in dicate significantly higher than probes screwed into the heads. The plug is t he hottest spot in the cylinder. >> >> Virus-free. www.avast.com ________________________________________________________________________________
Subject: Fuel level indicator
Date: Jun 08, 2018
I have an external tube to check the fuel level (see pix). It's sometimes hard to see the fuel in the tube. I thought of adding a small ball float in the tube for visibility. I know J3's use a cork on the bottom of a wire for fuel level. Don't know if it is coated or sealed with anything? Any ideas from the group on what to use? Obviously must be compatible with fuel. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480739#480739 Attachments: http://forums.matronics.com//files/img_20180608_133656384_489.jpg ________________________________________________________________________________
Subject: Re: Fuel level indicator
Date: Jun 08, 2018
Rex Rodebush - if you're really lucky you can find a bead from some sort of necklace that will be liquid-proof end not dissolve in fuel test it first! > On Jun 8, 2018, at 4:15 PM, Rex Rodebush wrote: > > > I have an external tube to check the fuel level (see pix). It's sometimes hard to see the fuel in the tube. I thought of adding a small ball float in the tube for visibility. I know J3's use a cork on the bottom of a wire for fuel level. Don't know if it is coated or sealed with anything? Any ideas from the group on what to use? Obviously must be compatible with fuel. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=480739#480739 > > > > > Attachments: > > http://forums.matronics.com//files/img_20180608_133656384_489.jpg > > > > > > ________________________________________________________________________________
Date: Jun 08, 2018
On 6/8/2018 3:15 PM, Rex Rodebush wrote: > > I have an external tube to check the fuel level (see pix). It's sometimes hard to see the fuel in the tube. I thought of adding a small ball float in the tube for visibility. I know J3's use a cork on the bottom of a wire for fuel level. Don't know if it is coated or sealed with anything? Any ideas from the group on what to use? Obviously must be compatible with fuel. It's been done, so you wouldn't be the 1st. You do need to be sure it can't hang up in the tube, block the fuel's movement in the tube, or *escape the tube*. Depending on how the system is plumbed, you could block the fuel vent, give yourself a false fuel level reading, or even block fuel flow (if it escaped the tube). --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 08, 2018
This guy has an interesting idea - the pattern behind the tubing changes shape depending on whether there is fuel in front of it. http://mybearhawkpatrol.com/finish/fuelsight.html Or you could just go with this: http://www.univair.com/piper/piper-pa-11/view-all/u10853-000-piper-fuel-gauge-float-ball/ -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480742#480742 ________________________________________________________________________________
Date: Jun 08, 2018
On 6/8/2018 4:20 PM, Richard Pike wrote: > > This guy has an interesting idea - the pattern behind the tubing changes shape depending on whether there is fuel in front of it. > http://mybearhawkpatrol.com/finish/fuelsight.html > > Or you could just go with this: > http://www.univair.com/piper/piper-pa-11/view-all/u10853-000-piper-fuel-gauge-float-ball/ > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 He did say that he used polyurethane tubing. If you look up polyurethane's chemical resistance, benzine isn't one of them. https://www.engineeringtoolbox.com/polyurethane-chemical-resistance-d_1878.html Hard to find gasoline without benzine..... Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 08, 2018
Richard, The Piper fuel ball looks perfect! I'll order one. Thanks! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480744#480744 ________________________________________________________________________________
Date: Jun 08, 2018
Rex R/Kolbers: Looks like you are using yellow Tygon type fuel line with a yellow background. My sight gauge is clear, for the most part, with Cub yellow fabric background. Been working good for me since day one. john h Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rex Rodebush Sent: Friday, June 08, 2018 3:15 PM Subject: Kolb-List: Fuel level indicator I have an external tube to check the fuel level (see pix). It's sometimes hard to see the fuel in the tube. I thought of adding a small ball float in the tube for visibility. I know J3's use a cork on the bottom of a wire for fuel level. Don't know if it is coated or sealed with anything? Any ideas from the group on what to use? Obviously must be compatible with fuel. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480739#480739 Attachments: http://forums.matronics.com//files/img_20180608_133656384_489.jpg ________________________________________________________________________________
Date: Jun 08, 2018
My sight gauge uses clear Tygon. Working fine since 1992. john h Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Friday, June 08, 2018 4:35 PM Subject: Re: Kolb-List: Re: Fuel level indicator On 6/8/2018 4:20 PM, Richard Pike wrote: > > This guy has an interesting idea - the pattern behind the tubing changes shape depending on whether there is fuel in front of it. > http://mybearhawkpatrol.com/finish/fuelsight.html > > Or you could just go with this: > http://www.univair.com/piper/piper-pa-11/view-all/u10853-000-piper-fuel-gauge-float-ball/ > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 He did say that he used polyurethane tubing. If you look up polyurethane's chemical resistance, benzine isn't one of them. https://www.engineeringtoolbox.com/polyurethane-chemical-resistance-d_1878.html Hard to find gasoline without benzine..... Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 08, 2018
Order two for a pair of balls. ;-) john h Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rex Rodebush Sent: Friday, June 08, 2018 4:47 PM Subject: Kolb-List: Re: Fuel level indicator Richard, The Piper fuel ball looks perfect! I'll order one. Thanks! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480744#480744 ________________________________________________________________________________
Date: Jun 08, 2018
John, Wasn't aware that the tygon came in clear. The only one I could find was yellow from McMaster-Carr. I'll see if I can find the clear version. BTW, can't afford two balls, at my age one will be enough! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480749#480749 ________________________________________________________________________________
Date: Jun 08, 2018
John, The only Tygon that I can find that is recommended for gas is the yellow version. Do you change your gas gage line every few years or so? Do you know what type of Tygon you use? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480750#480750 ________________________________________________________________________________
Date: Jun 08, 2018
The clear food grade should be fine. It is PVC. john -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rex Rodebush Sent: Friday, June 08, 2018 7:43 PM Subject: Kolb-List: Re: Fuel level indicator John, The only Tygon that I can find that is recommended for gas is the yellow version. Do you change your gas gage line every few years or so? Do you know what type of Tygon you use? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480750#480750 ________________________________________________________________________________
Date: Jun 08, 2018
Amazon is a wonderful thing. If you don't believe me, ask Larry Cottrell. Do a Google search or go to this page to find all kinds and colors of Tygon: https://www.amazon.com/Plastic-Tubing-Tygon/s?ie=UTF8&page=1&rh=n%3A16414401 %2Cp_4%3ATygon john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rex Rodebush Sent: Friday, June 08, 2018 7:24 PM Subject: Kolb-List: Re: Fuel level indicator John, Wasn't aware that the tygon came in clear. The only one I could find was yellow from McMaster-Carr. I'll see if I can find the clear version. BTW, can't afford two balls, at my age one will be enough! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480749#480749 ________________________________________________________________________________
Date: Jun 08, 2018
Tygon (capitalized) https://en.wikipedia.org/wiki/Tygon_tubing On 6/8/2018 8:58 PM, John Hauck wrote: > > Amazon is a wonderful thing. If you don't believe me, ask Larry Cottrell. > > Do a Google search or go to this page to find all kinds and colors of Tygon: > > https://www.amazon.com/Plastic-Tubing-Tygon/s?ie=UTF8&page=1&rh=n%3A16414401 > %2Cp_4%3ATygon > > john h > mkIII > Titus, Alabama > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rex Rodebush > Sent: Friday, June 08, 2018 7:24 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: Fuel level indicator > > > John, > > Wasn't aware that the tygon came in clear. The only one I could find was > yellow from McMaster-Carr. I'll see if I can find the clear version. BTW, > can't afford two balls, at my age one will be enough! > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 09, 2018
It's been so long I don't remember what I made the float out of. I don't think it was cork, maybe I carved it out of wood or found a plastic ball used a permanent marker to make it more visible. I do remember building a restriction that I fit inside the line that keep the float from sloshing out of the sight tube. Did this by cutting 2 sections of fuel tube 3/16 or so long pinched it and using a wire slid them down the sight tube to match the top and bottom of the fuel tank with the ball in-between. The fuel could get past the restriction to float the ball, and at the same time keep the ball out of the pumps and carbs where it could cause trouble. Boyd Young Mkiii utah On Fri, Jun 8, 2018, 2:17 PM Rex Rodebush wrote: > > I have an external tube to check the fuel level (see pix). It's sometimes > hard to see the fuel in the tube. I thought of adding a small ball float > in the tube for visibility. I know J3's use a cork on the bottom of a wire > for fuel level. Don't know if it is coated or sealed with anything? Any > ideas from the group on what to use? Obviously must be compatible with > fuel. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=480739#480739 > > > Attachments: > > http://forums.matronics.com//files/img_20180608_133656384_489.jpg > > ________________________________________________________________________________
Date: Jun 09, 2018
Russ, used to use shellac but modern fuel additives in car gas might affect it like they did the old sloshing compound. Sent from my iPhone > On Jun 8, 2018, at 4:24 PM, Russ Kinne wrote: > > > Rex Rodebush - if you're really lucky you can find a bead from some sort of necklace that will be liquid-proof > end not dissolve in fuel test it first! > > >> On Jun 8, 2018, at 4:15 PM, Rex Rodebush wrote: >> >> >> I have an external tube to check the fuel level (see pix). It's sometimes hard to see the fuel in the tube. I thought of adding a small ball float in the tube for visibility. I know J3's use a cork on the bottom of a wire for fuel level. Don't know if it is coated or sealed with anything? Any ideas from the group on what to use? Obviously must be compatible with fuel. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=480739#480739 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/img_20180608_133656384_489.jpg >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Subject: Rotax 5 year rubber replacement
Date: Jun 21, 2018
Rotax requires a rubber replacement at 5 years for their 912 engines. Coolant, oil and fuel lines, carburetor diaphragms, flanges , etc. They also want the fuel pump replaced after 5 years. Also, my engine mounts are about 9 years old. (Have about 60 running hours on them over the last 5 years). They seem OK but wondered if I should go ahead and replace them. Any comments appreciated. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481060#481060 ________________________________________________________________________________
Date: Jun 21, 2018
I've had good luck with my three 912 series engines. Never let me down since 1993 and about 3200 hours. Only time I ever had one quit on me was landing at Toad River, BC. Was determined the idle jets iced up from a long slow approach down the mountain side to the gravel strip. Weather was perfect for carb ice. This last 912ULS I changed out the coolant hoses around 5 or 6 years. Used locally procured Gates hose rather than spend all that money for Rotax hoses. Engine oil hoses are super high quality silicone with the blue outside cover. They have been on their since my first 912ULS around 2000. They are steel braid reinforced. No problem with degradation of the interior of the oil hoses. Used to change out a lot of the other rubber stuff, carb diaphragms, etc., but haven't bothered with this last engine I mounted in 2007. I do keep my eyes on the carb sockets to insure they are not cracking. If I see a crack or feel they need changing, I change them. This last time I changed them with JBM sockets. I see they want 76.00 a piece for them now, three times more than the two stroke sockets. ??? Hope I don't have to replace the ones I have, but they have lasted much longer for me than Rotax sockets. While I am at it I may as well share my feelings for Rotax oil filters at 25.00 a pop, last time I looked. I have used Fram (oh my God!) Tough Guard TG-3614 oil filters since day one on all my 912's, about 5.00 a pop. They do a good job for me. I wouldn't tell anyone to not follow procedures established by Rotax for 912 maintenance, I don't recommend anyone doing as I do, but that is the way I do it with pretty good success. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rex Rodebush Sent: Thursday, June 21, 2018 9:55 AM Subject: Kolb-List: Rotax 5 year rubber replacement Rotax requires a rubber replacement at 5 years for their 912 engines. Coolant, oil and fuel lines, carburetor diaphragms, flanges , etc. They also want the fuel pump replaced after 5 years. Also, my engine mounts are about 9 years old. (Have about 60 running hours on them over the last 5 years). They seem OK but wondered if I should go ahead and replace them. Any comments appreciated. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481060#481060 ________________________________________________________________________________
Date: Jun 22, 2018
Subject: Re: Kolb-List. Oil filters
> > My first oil filters for the 912,,,,,, if I remember correctly were > champion filters, they had Rotax written on one side, and on the other side > was the champion name and there part number.... I tried at my local parts store by but the part number was a priority number for Rotax. But the tough guard number John mentioned was a good cross reference number. Boyd Young ________________________________________________________________________________
Date: Jun 22, 2018
Subject: New Video
Checking for water and Antelope this morning to the East. I have a friend who drew a tag for this area, so I thought that I would check on the water situation this year. The flight revealed that there is very little water at all out there. While the wind was calm for a while, the further East I went, the stronger the wind became. Enjoy, Larry https://vimeo.com/276524631 password owyheeflyer -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jun 22, 2018
Subject: Re: New Video
I dont know how to do that Larry. Do you do it in a message and post it like a picture? -George- Sent from my iPhone > On Jun 22, 2018, at 9:38 PM, Larry Cottrell wrote: > > ________________________________________________________________________________
Date: Jun 23, 2018
George, go to your YouTube video, and highlight the URL. You do that by starting at one end of the URL, left clicking and dragging across it until it all turns light blue. While it is blue, right click it and click "Copy." Then go to your post to the Kolb list, pick the spot where you want to put that URL, right click and "Paste" -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481136#481136 ________________________________________________________________________________
Date: Jun 23, 2018
https://youtu.be/TCtOJjyyIUg Well, let=99s see if this works? George H. Sent from my iPhone > On Jun 23, 2018, at 9:35 AM, Richard Pike wrote : > > > George, go to your YouTube video, and highlight the URL. You do that by st arting at one end of the URL, left clicking and dragging across it until it a ll turns light blue. While it is blue, right click it and click "Copy." > Then go to your post to the Kolb list, pick the spot where you want to put that URL, right click and "Paste" > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=481136#481136 > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Jun 23, 2018
worked for me. LC On Sat, Jun 23, 2018 at 10:07 AM, George Helton wrote: > https://youtu.be/TCtOJjyyIUg > Well, let=99s see if this works? > George H. > > Sent from my iPhone > > On Jun 23, 2018, at 9:35 AM, Richard Pike > wrote: > > > George, go to your YouTube video, and highlight the URL. You do that by > starting at one end of the URL, left clicking and dragging across it unti l > it all turns light blue. While it is blue, right click it and click "Copy ." > Then go to your post to the Kolb list, pick the spot where you want to pu t > that URL, right click and "Paste" > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kingsport, TN 3TN0 > > Forgiving is tough, being forgiven is wonderful, and God's grace really i s > amazing. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=481136#481136 > > > ======================== ==bsp; - The Kolb-List Email Forum - > http://www.matronics.com/Navigator?Kolb-List > _======================== ==; &nbp; --> > http://forums.matroni================= ======== > http://wiki.matronics.comhttp://www.matronics.com/contribution > <http://forums.matronics.com> =========== > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jun 23, 2018
Well, Richard. That=99s to easy. These are all videos shot last year. You=99ve inspired me to try some n ew ones. Thanks guys! https://youtu.be/MrWcaBNRVLU George H . Firestar, FS100, Hirth 2702 14GDH Mesick, Michigan Sent from my iPhone > On Jun 23, 2018, at 12:07 PM, George Helton wrote: > > https://youtu.be/TCtOJjyyIUg > Well, let=99s see if this works? > George H. > > Sent from my iPhone > >> On Jun 23, 2018, at 9:35 AM, Richard Pike wrot e: >> > >> >> George, go to your YouTube video, and highlight the URL. You do that by s tarting at one end of the URL, left clicking and dragging across it until it all turns light blue. While it is blue, right click it and click "Copy." >> Then go to your post to the Kolb list, pick the spot where you want to pu t that URL, right click and "Paste" >> >> -------- >> Richard Pike >> Kolb MKIII N420P (420ldPoops) >> Kingsport, TN 3TN0 >> >> Forgiving is tough, being forgiven is wonderful, and God's grace really i s amazing. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=481136#481136 >> >> >> >> >> >> ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= >> >> >> ________________________________________________________________________________
Date: Jun 23, 2018
Thanks, Larry. Sent from my iPhone > On Jun 23, 2018, at 12:16 PM, Larry Cottrell wro te: > > worked for me. > LC > >> On Sat, Jun 23, 2018 at 10:07 AM, George Helton wrot e: >> https://youtu.be/TCtOJjyyIUg >> Well, let=99s see if this works? >> George H. >> >> Sent from my iPhone >> >>> On Jun 23, 2018, at 9:35 AM, Richard Pike wro te: >>> t> >>> >>> George, go to your YouTube video, and highlight the URL. You do that by s tarting at one end of the URL, left clicking and dragging across it until it all turns light blue. While it is blue, right click it and click "Copy." >>> Then go to your post to the Kolb list, pick the spot where you want to p ut that URL, right click and "Paste" >>> >>> -------- >>> Richard Pike >>> Kolb MKIII N420P (420ldPoops) >>> Kingsport, TN 3TN0 >>> >>> Forgiving is tough, being forgiven is wonderful, and God's grace really i s amazing. >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=481136#481136 >>> >>> >>> >>> >>> >>> >>> ======================== ==bsp; - The Kolb-List Email Forum - >>> http://www.matronics.com/Navigator?Kolb-List >>> _======================== ==; &nbp; --> http://forums.matroni========= =================http://wiki.matronics.com http://www.matronics.com/contribution============= ================== >>> >>> >>> > > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Subject: FAA Inspection
Date: Jun 26, 2018
Sent all of my paper work in to the FAA in Columbus, Ohio last week expecting it to take a couple of months to get a reply. Well, low and behold, 4 days later they call and setup an inspection for July 3. I screwed up one of the forms but the inspector said he would correct it and bring a new one with him. He also sent me the repairman's form for me to have notorized. Been trying to get all of my papers in order so it looks organized. Will let everyone know how it all turns out. Thanks to this forum for all the help and encouragement. Without you guys it would not have been possible. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481225#481225 ________________________________________________________________________________
Subject: Re: FAA Inspection
Date: Jun 27, 2018
Ichiban! Post us some pictures of the completed airplane. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481228#481228 ________________________________________________________________________________
Date: Jun 27, 2018
Jim I'm coming up on the time for my inspection. I've reserved my N number but have no idea what forms to order. Could you send my a list of what you submitted? Thanks Joe > On June 26, 2018 at 8:46 PM japowell wrote: > > > > Sent all of my paper work in to the FAA in Columbus, Ohio last week > expecting it to take a couple of months to get a reply. Well, low and > behold, 4 days later they call and setup an inspection for July 3. > > I screwed up one of the forms but the inspector said he would correct it > and bring a new one with him. He also sent me the repairman's form for > me to have notorized. Been trying to get all of my papers in order so it > looks organized. Will let everyone know how it all turns out. > > Thanks to this forum for all the help and encouragement. Without you > guys it would not have been possible. > > -------- > Jim P > WAR EAGLE > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=481225#481225 > > > > > > > > > ________________________________________________________________________________
Date: Jun 27, 2018
Richard, I will need to down size the pic's. How do I do that? -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481232#481232 ________________________________________________________________________________
Date: Jun 27, 2018
First of all, I want to thank Mr.Pike for resizing these photos so I can share with you all. Thank you Richard. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481235#481235 Attachments: http://forums.matronics.com//files/20180626_134129_medium_195.jpg http://forums.matronics.com//files/20180626_134123_medium_411.jpg http://forums.matronics.com//files/20180626_133826_medium_121.jpg http://forums.matronics.com//files/100_3751_medium_280.jpeg ________________________________________________________________________________
Date: Jun 27, 2018
japowell wrote: > First of all, I want to thank Mr.Pike for resizing these photos so I can share with you all. Thank you Richard. Jim: Very nice looking Kolb FSII. Noticed that the shoulder harness, in the 1st and 3rd pics is attached to the bar in front of the fuel tanks and in the 4th it is attached high. Hope this last one is the final attach point. I believe the other two is too low. I've been told that the attach point should be above the shoulders. Not sure what the authorities would say..... As Beauford would say... "These words are worth what you paid for them." -------- George Alexander FS II R503 E-LSA N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481237#481237 ________________________________________________________________________________
Date: Jun 27, 2018
Nice looking rig! Fly safe and good luck! Blue skies. George H. Firestar, FS100,Hirth 2702 14GDH Mesick, Michigan gdhelton(at)gmail.com Sent from my iPhone > On Jun 27, 2018, at 8:54 PM, japowell wrote: > > > First of all, I want to thank Mr.Pike for resizing these photos so I can share with you all. Thank you Richard. > > -------- > Jim P > WAR EAGLE > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=481235#481235 > > > > > Attachments: > > http://forums.matronics.com//files/20180626_134129_medium_195.jpg > http://forums.matronics.com//files/20180626_134123_medium_411.jpg > http://forums.matronics.com//files/20180626_133826_medium_121.jpg > http://forums.matronics.com//files/100_3751_medium_280.jpeg > > > > > > ________________________________________________________________________________
Subject: Image Resizer
Date: Jun 27, 2018
japowell wrote: > Richard, I will need to down size the pic's. How do I do that? Several people have wondered recently how to resize pictures for the Kolb List. This little program is the easiest I have seen: https://www.bricelam.net/ImageResizer/ After you install it, it sort of hides and waits until you want to use it. To use it, right click the picture you want to resize, and it pops open an option box with several sizes you can resize to. For instance, the pictures Jim Powell posted in the FAA Inspection thread were resized to Medium, and all of them are less than a meg in size. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481240#481240 ________________________________________________________________________________
Subject: Re: Image Resizer
Date: Jun 28, 2018
Thanks Richard. I down loaded it for future use. Now I have now excuse. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481255#481255 ________________________________________________________________________________
Date: Jun 28, 2018
HomebuiltHELP offers a video called "How to license your Homebuilt Aircraft". I used it and it made the process very easy. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481257#481257 ________________________________________________________________________________
Subject: Engine mount Mk3 to Hirth F30
Date: Jun 30, 2018
Greetings Kolb ers: I am in the beginning stage of retrofitting my R582 powered Mk3 with a Hirth F30. I recognize the wheel has already been invented and have no desire to reinvent I thought to inquire as to the existence of an engine mount kit for my project. Does any one know of a kit, kit vendor, manufacture, or builder who can source a Mk3 to F30 engine mount? My idea of a good mount configuration is a vertically oriented bolted sandwich of engine, rubber, air-frame, rubber at four corners and two horizontal sandwiches located port and starboard to control thrust. What say you all? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481289#481289 ________________________________________________________________________________
Date: Jun 30, 2018
Subject: Re: Engine mount Mk3 to Hirth F30
Is this a used engine? The F-30 was replaced by the 3002/3003 series back s few years ago. I think your best source for information would be Matt Dandar at RPE (Recreational Power Engineering) hes been the distributor for Hirth for 20 some years. He has pictures of different installations on his website that might help? The other great source would be Heaven Bound Aviation. You can Google both. I converted my original Firestar to Hirth 2702 this last winter. Ive flown nothing but Rotax engines for 30+ years so it was hard for me to switch brands. But, Rotax has left us air-cooled two cycle users high and dry, unless youre confident in flying a rebuilt engine. Theyve discontinued the 377,447 and 503 series. Ive put 35hrs on my engine since May. I do run the Hirth recommended (Blue Max oil @ 90 to 1. Good luck on your project. Feel free to email me off the list if I can help. -George- George H. Firestar, FS100, Hirth 2702 14GDH Mesick, Michigan gdhelton(at)gmail.com Sent from my iPhone > On Jun 30, 2018, at 3:46 AM, mojaveclimber wrote: > > > Greetings Kolb ers: > I am in the beginning stage of retrofitting my R582 powered Mk3 with a Hirth F30. I recognize the wheel has already been invented and have no desire to reinvent I thought to inquire as to the existence of an engine mount kit for my project. Does any one know of a kit, kit vendor, manufacture, or builder who can source a Mk3 to F30 engine mount? My idea of a good mount configuration is a vertically oriented bolted sandwich of engine, rubber, air-frame, rubber at four corners and two horizontal sandwiches located port and starboard to control thrust. What say you all? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=481289#481289 > > > > > > > > > ________________________________________________________________________________
Date: Jun 30, 2018
Subject: faa forms
I have received an e mail from Nick Cassara of Palmer, Alaska, who like myself is coming up on an inspection. He requested that a list of the necessary forms be posted on the list. So Kolbers if you have recent experience with the registration process some help please. Thank Joe ________________________________________________________________________________
Date: Jun 30, 2018
Subject: Re: faa forms
EAA sells a registration package with instructions. On Sat, Jun 30, 2018 at 3:58 PM, mojavjoe wrote: > I have received an e mail from Nick Cassara of Palmer, Alaska, who like > myself is coming up on an inspection. He requested that a list of the > necessary forms be posted on the list. So Kolbers if you have recent > experience with the registration process some help please. > > > Thank > > Joe > ________________________________________________________________________________
Date: Jun 30, 2018
Thanks Charlie. I just ordered the kit. Joe > On June 30, 2018 at 5:05 PM Charlie England wrote: > > EAA sells a registration package with instructions. > > On Sat, Jun 30, 2018 at 3:58 PM, mojavjoe wrote: > > > > > > I have received an e mail from Nick Cassara of Palmer, Alaska, who like myself is coming up on an inspection. He requested that a list of the necessary forms be posted on the list. So Kolbers if you have recent experience with the registration process some help please. > > > > > > Thank > > > > Joe > > > > > > ________________________________________________________________________________
Date: Jun 30, 2018
Seems that the local fsdo office participated in a wings seminar. At that time they handed to everyone who wanted a package the necessary documents and information. Has anyone tried calling there local fsdo to get the paperwork,,,. It was free.... Boyd Young Mkiii Utah On Sat, Jun 30, 2018, 6:22 PM mojavjoe wrote: > Thanks Charlie. I just ordered the kit. > > > Joe > > On June 30, 2018 at 5:05 PM Charlie England wrote: > > EAA sells a registration package with instructions. > > On Sat, Jun 30, 2018 at 3:58 PM, mojavjoe wrote: > > I have received an e mail from Nick Cassara of Palmer, Alaska, who like > myself is coming up on an inspection. He requested that a list of the > necessary forms be posted on the list. So Kolbers if you have recent > experience with the registration process some help please. > > > Thank > > Joe > > ________________________________________________________________________________
Date: Jun 30, 2018
When I submitted mine two weeks ago, I contacted to FSDO in Columbus, Ohio. I spoke with one of the inspectors who was quit helpful. He took my email address and sent me the packet for applying for the airworthiness certs. He also started a file on me so he could keep all of our correspondence concerning the building and certification of my aircraft. I am sure any FSDO would do the same. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481307#481307 ________________________________________________________________________________
Date: Jun 30, 2018
PS He also sent me a check list of what he expected to see on the aircraft when he visited. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481308#481308 ________________________________________________________________________________
Date: Jul 01, 2018
Subject: Firestar / HKS progress report
Hi Kolbers, greetings form Los Angeles, I want to post an update on my Firestar/HKS progress. We're getting close to flying, finally, after a long long time. The wiring was finished, the fuel system was finished, installing the instruments and sensors are finished, and it's almost ready for engine runs. Today we pre-oiled the engine using the HKS method of removing one set of spark plugs, and spinning the engine with the starter, First I turned the engine over by hand slowly about 50 blades to prime the pump and get poil through the engine galleys. So when we hit the starter button it jumped right up to 15 PSI on the gauge. Next trip to the airport will be engine start and observing the engine behavior, temperatures, and smoothness. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities ________________________________________________________________________________
Date: Jul 01, 2018
Subject: Re: Firestar / HKS progress report
Good going , Bill! It seems like it has been a long road. Good luck on your engine runs and taxi tests. -George- George H. Firestar, FS100, 2702 Hirth 14GDH Mesick, Michigan gdhelton(at)gmail.com Sent from my iPhone > On Jul 1, 2018, at 2:14 AM, Bill Berle wrote: > > > Hi Kolbers, greetings form Los Angeles, > > I want to post an update on my Firestar/HKS progress. We're getting close to flying, finally, after a long long time. The wiring was finished, the fuel system was finished, installing the instruments and sensors are finished, and it's almost ready for engine runs. Today we pre-oiled the engine using the HKS method of removing one set of spark plugs, and spinning the engine with the starter, First I turned the engine over by hand slowly about 50 blades to prime the pump and get poil through the engine galleys. So when we hit the starter button it jumped right up to 15 PSI on the gauge. Next trip to the airport will be engine start and observing the engine behavior, temperatures, and smoothness. > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and for-profit entities > > > > > ________________________________________________________________________________
Date: Jul 01, 2018
Subject: Re: Rotax 5 year rubber replacement
Depends on how you view maintenance, I guess. If you have an SLSA and its maintenance manual says "service per Rotax", you're stuck with the schedule AND what you can use in the way of parts. Anything other than Rotax or A/C manufacturer supplied parts have to have a letter of authorization. The same would apply I believe if you bought a 912 S instead of the ULS and you wanted to keep it "certified". As for what to use if it's your option I highly recommend Silicone hose for all the coolant lines. Pegasus Racing and others have it in metric and inch sizes. You buy it once. Orings and such can be had at McMaster Carr but you'll have to buy in qty 50 or 100. Usually for half what Rotax charges for 1. So you pay less AND get a lifetime supply. :-} I went through Rotax 2 and 4 stroke schools in 2007 so I've had a chance to test this out for the last 11 years. If you rub in a coat of good ole white lithium grease on hoses, orings and carb sockets they last longer. How much longer I can't say without knowing your aircraft's environment. For me, with a hangar, I know it's at least twice as long as stored samples that dried out. Rick Girard On Thu, Jun 21, 2018 at 11:09 AM, John Hauck wrote: > > I've had good luck with my three 912 series engines. Never let me down > since 1993 and about 3200 hours. Only time I ever had one quit on me was > landing at Toad River, BC. Was determined the idle jets iced up from a > long > slow approach down the mountain side to the gravel strip. Weather was > perfect for carb ice. > > This last 912ULS I changed out the coolant hoses around 5 or 6 years. Us ed > locally procured Gates hose rather than spend all that money for Rotax > hoses. Engine oil hoses are super high quality silicone with the blue > outside cover. They have been on their since my first 912ULS around 2000 . > They are steel braid reinforced. No problem with degradation of the > interior of the oil hoses. > > Used to change out a lot of the other rubber stuff, carb diaphragms, etc. , > but haven't bothered with this last engine I mounted in 2007. I do keep my > eyes on the carb sockets to insure they are not cracking. If I see a cra ck > or feel they need changing, I change them. This last time I changed them > with JBM sockets. I see they want 76.00 a piece for them now, three time s > more than the two stroke sockets. ??? Hope I don't have to replace the > ones I have, but they have lasted much longer for me than Rotax sockets. > > While I am at it I may as well share my feelings for Rotax oil filters at > 25.00 a pop, last time I looked. I have used Fram (oh my God!) Tough Gua rd > TG-3614 oil filters since day one on all my 912's, about 5.00 a pop. The y > do a good job for me. > > I wouldn't tell anyone to not follow procedures established by Rotax for > 912 > maintenance, I don't recommend anyone doing as I do, but that is the way I > do it with pretty good success. > > john h > mkIII > Titus, Alabama > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com > [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rex Rodebush > Sent: Thursday, June 21, 2018 9:55 AM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Rotax 5 year rubber replacement > > > Rotax requires a rubber replacement at 5 years for their 912 engines. > Coolant, oil and fuel lines, carburetor diaphragms, flanges , etc. They > also want the fuel pump replaced after 5 years. Also, my engine mounts > are > about 9 years old. (Have about 60 running hours on them over the last 5 > years). They seem OK but wondered if I should go ahead and replace them. > Any comments appreciated. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=481060#481060 > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Subject: Re: Official Kolb-List FAQ (Frequently Asked Questions)
Date: Jul 02, 2018
TL,DR. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481351#481351 ________________________________________________________________________________
Subject: Airworthiness Certs in Hand
Date: Jul 03, 2018
Met the FAA inspector at the hanger this morning. Real pleasant guy. He took around 45 minutes looking over the plane and asking questions. He said he really liked the Kolbs because of their simplicity and how well they flew. He also liked them because they were a good reliable airplane. He checked all of the placards and instrument labling to make sure they were done correctly. After that he ask for my construction log. He ask to see pic's of how it was when I brought the project home and pic's of it finished. Then, he checked my log book for the proper checks and entries. After that and a few comments, he signed it off and wished me well. It took two weeks from sending in my request for an inspection until it was sign off and ready for 'phase 1'. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481374#481374 ________________________________________________________________________________
Date: Jul 03, 2018
Excellent! Glad you had a good experience getting your Kolb registered. My experience with the inspector that did my MKIII was also excellent, 26 years ago. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of japowell Sent: Tuesday, July 03, 2018 1:44 PM Subject: Kolb-List: Airworthiness Certs in Hand Met the FAA inspector at the hanger this morning. Real pleasant guy. He took around 45 minutes looking over the plane and asking questions. He said he really liked the Kolbs because of their simplicity and how well they flew. He also liked them because they were a good reliable airplane. He checked all of the placards and instrument labling to make sure they were done correctly. After that he ask for my construction log. He ask to see pic's of how it was when I brought the project home and pic's of it finished. Then, he checked my log book for the proper checks and entries. After that and a few comments, he signed it off and wished me well. It took two weeks from sending in my request for an inspection until it was sign off and ready for 'phase 1'. -------- Jim P WAR EAGLE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481374#481374 ________________________________________________________________________________
Subject: Fire Fly Video's + more
Date: Jul 04, 2018
Hello Everyone , I bought my fire fly last september and currently have 43 flights on it . I live in the pacific northwest in a little town called Glenoma in Washington state , its about 20 miles north of Mt St Helens , 20 miles SW of Mt Rainier , and 20 NW of Mt. Adams . All my flying is in the mountains . So thought I would share some video's that I have made. Enjoy ! https://www.youtube.com/channel/UCE5XgW-7J2LYKaOvgk1hJAQ/videos?view_as=subscriber Thanks Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481400#481400 ________________________________________________________________________________
Date: Jul 04, 2018
Beautiful area. Have had the good fortune of flying near your airstrip, which is really unique. Also made a road trip just east three years ago. Thanks for sharing. When I get time I will take a look at your other vids. Right now I am loading the truck for a trip to Atlanta and the 2018 Vietnam Helicopter Pilots Association Reunion. Should be 12 of the of the 28 AH-1G Cobra pilots I flew with 1969-70, Phu Bai, RVN, in attendance. Looking forward to a lot of fun, war stories, and a lot of laughs the next 4 days. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of snowman Sent: Wednesday, July 04, 2018 9:44 AM Subject: Kolb-List: Fire Fly Video's + more Hello Everyone , I bought my fire fly last september and currently have 43 flights on it . I live in the pacific northwest in a little town called Glenoma in Washington state , its about 20 miles north of Mt St Helens , 20 miles SW of Mt Rainier , and 20 NW of Mt. Adams . All my flying is in the mountains . So thought I would share some video's that I have made. Enjoy ! https://www.youtube.com/channel/UCE5XgW-7J2LYKaOvgk1hJAQ/videos?view_as=subs criber Thanks Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481400#481400 ________________________________________________________________________________
Date: Jul 04, 2018
QXBwcmVjaWF0ZSB5b3VyICYgeW91ciBncm91cHMgc2VydmljZSBKb2huLsKgCgoKU2VudCBmcm9t IG15IFZlcml6b24sIFNhbXN1bmcgR2FsYXh5IHNtYXJ0cGhvbmUKLS0tLS0tLS0gT3JpZ2luYWwg bWVzc2FnZSAtLS0tLS0tLUZyb206IEpvaG4gSGF1Y2sgPGpoYXVja0BlbG1vcmUucnIuY29tPiBE YXRlOiA3LzQvMTggIDExOjE0IEFNICAoR01ULTA1OjAwKSBUbzoga29sYi1saXN0QG1hdHJvbmlj cy5jb20gU3ViamVjdDogUkU6IEtvbGItTGlzdDogRmlyZSBGbHkgVmlkZW8ncyArIG1vcmUgCi0t PiBLb2xiLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJKb2huIEhhdWNrIiA8amhhdWNrQGVsbW9y ZS5yci5jb20+CgpCZWF1dGlmdWwgYXJlYS7CoCBIYXZlIGhhZCB0aGUgZ29vZCBmb3J0dW5lIG9m IGZseWluZyBuZWFyIHlvdXIgYWlyc3RyaXAsCndoaWNoIGlzIHJlYWxseSB1bmlxdWUuwqAgQWxz byBtYWRlIGEgcm9hZCB0cmlwIGp1c3QgZWFzdCB0aHJlZSB5ZWFycyBhZ28uCgpUaGFua3MgZm9y IHNoYXJpbmcuwqAgV2hlbiBJIGdldCB0aW1lIEkgd2lsbCB0YWtlIGEgbG9vayBhdCB5b3VyIG90 aGVyIHZpZHMuClJpZ2h0IG5vdyBJIGFtIGxvYWRpbmcgdGhlIHRydWNrIGZvciBhIHRyaXAgdG8g QXRsYW50YSBhbmQgdGhlIDIwMTggVmlldG5hbQpIZWxpY29wdGVyIFBpbG90cyBBc3NvY2lhdGlv biBSZXVuaW9uLsKgIFNob3VsZCBiZSAxMiBvZiB0aGUgb2YgdGhlIDI4IEFILTFHCkNvYnJhIHBp bG90cyBJIGZsZXcgd2l0aCAxOTY5LTcwLCBQaHUgQmFpLCBSVk4sIGluIGF0dGVuZGFuY2UuwqAg TG9va2luZwpmb3J3YXJkIHRvIGEgbG90IG9mIGZ1biwgd2FyIHN0b3JpZXMsIGFuZCBhIGxvdCBv ZiBsYXVnaHMgdGhlIG5leHQgNCBkYXlzLgoKam9obiBoCm1rSUlJClRpdHVzLCBBbGFiYW1hCgoK CgotLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQpGcm9tOiBvd25lci1rb2xiLWxpc3Qtc2VydmVy QG1hdHJvbmljcy5jb20KW21haWx0bzpvd25lci1rb2xiLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5j b21dIE9uIEJlaGFsZiBPZiBzbm93bWFuClNlbnQ6IFdlZG5lc2RheSwgSnVseSAwNCwgMjAxOCA5 OjQ0IEFNClRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQpTdWJqZWN0OiBLb2xiLUxpc3Q6IEZp cmUgRmx5IFZpZGVvJ3MgKyBtb3JlCgotLT4gS29sYi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAi c25vd21hbiIgPGFscmVkbW9uQGNlbnR1cnl0ZWwubmV0PgoKSGVsbG8gRXZlcnlvbmUgLCAKwqAg SSBib3VnaHQgbXkgZmlyZSBmbHkgbGFzdCBzZXB0ZW1iZXIgYW5kIGN1cnJlbnRseSBoYXZlIDQz IGZsaWdodHMgb24gaXQgLgpJIGxpdmUgaW4gdGhlIHBhY2lmaWMgbm9ydGh3ZXN0IGluIGEgbGl0 dGxlIHRvd24gY2FsbGVkIEdsZW5vbWEgaW4KV2FzaGluZ3RvbiBzdGF0ZSAsIGl0cyBhYm91dCAy MCBtaWxlcyBub3J0aCBvZiBNdCBTdCBIZWxlbnMgLCAyMCBtaWxlcyBTVyBvZgpNdCBSYWluaWVy ICwgYW5kIDIwIE5XIG9mIE10LiBBZGFtcyAuIEFsbCBteSBmbHlpbmcgaXMgaW4gdGhlIG1vdW50 YWlucyAuIFNvCnRob3VnaHQgSSB3b3VsZCBzaGFyZSBzb21lIHZpZGVvJ3MgdGhhdCBJIGhhdmUg bWFkZS4gRW5qb3kgISAKaHR0cHM6Ly93d3cueW91dHViZS5jb20vY2hhbm5lbC9VQ0U1WGdXLTdK MkxZS2FPdmdrMWhKQVEvdmlkZW9zP3ZpZXdfYXM9c3VicwpjcmliZXIKClRoYW5rcyAKQWxhbgoK CgoKUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOgoKaHR0cDovL2ZvcnVtcy5tYXRyb25pY3Mu Y29tL3ZpZXd0b3BpYy5waHA/cD00ODE0MDAjNDgxNDAwCgoKCgoKCgoKCl8tPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDC oMKgwqDCoMKgwqDCoCAtIFRoZSBLb2xiLUxpc3QgRW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBN YXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBM aXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBT ZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJl LCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT3CoMKgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmlj cy5jb20vTmF2aWdhdG9yP0tvbGItTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09wqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqDCoCAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVu dCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT3CoMKgIC0tPiBodHRw Oi8vZm9ydW1zLm1hdHJvbmljcy5jb20KXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgIC0gTkVXIE1BVFJPTklDUyBMSVNUIFdJS0kgLQpfLT0gQWRkIHNvbWUgaW5mbyB0byB0 aGUgTWF0cm9uaWNzIEVtYWlsIExpc3QgV2lraSEKXy09wqDCoCAtLT4gaHR0cDovL3dpa2kubWF0 cm9uaWNzLmNvbQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLSBMaXN0IENvbnRy aWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPcKgIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBw b3J0IQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4KXy09wqDCoCAtLT4gaHR0cDovL3d3 dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQoKCgo ________________________________________________________________________________
Subject: Re: Fire Fly Video's + more
Date: Jul 04, 2018
John, Sounds like fun , have a great trip ! Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481403#481403 ________________________________________________________________________________
Date: Jul 04, 2018
Subject: Firestar/HKS Engine Test Run
Greetings Kolbers, Yesterday we finally were able to test run the HKS engine installation on m y Firestar 2. The HKS engine started right up and ran, but it needed carbur etor adjustment. I had a friend there who has experience with the HKS engin e, and he was kind enough to adjust the carburetors using a dual vacuum gau ge. The one big issue I had was that the engine vibration was far far more than I was ever used to seeing on an aircraft. Part of this is that I'm "an air plane guy" instead of "an ultralight guy", Part of it is that the HKS is an opposed 2 cylinder engine with a very high compression ratio (11 to 1). Bu t part of this is also that it did shake and vibrate a LOT, and I started t hinking about how things tend to get loose and rattle apart in a high vibra tion environment. The one thing that really worried me is that around idle speed something be came resonant and the wing struts started to vibrate up and down in the mid dle, maybe half an inch up and hald an inch down versus a straight line. Al uminum does NOT like this kind of vibration! Neither do fasteners. After ab out two minutes we shut the engine down, and someone foun the wing strut at tachment pin (the short clevis pin) on the ground next to the airplane. I h ad put the pin in place from above without the safety pin )ground runs only ). The vibration backed the pin completely out! Does anyone else have this kind of wing strut vibration with the Kolb? Photos of the test run and adjustment wre posted here, scroll halfway down the page to to post # 952 http://www.homebuiltairplanes.com/forums/showthread.php?t=28504&page=64 &p=433039#post433039 Bill Berle www.ezflaphandle.com=C2- - safety & performance upgrade for light aircraf t www.grantstar.net =C2- =C2- =C2- =C2- =C2- - winning proposals fo r non-profit and for-profit entities /9j/4AAQSkZJRgABAQEBXgFeAAD/4TueRXhpZgAATU0AKgAAAAgACwEOAAIAAAAgAAAIngEPAAIA AAAFAAAIvgEQAAIAAAAJAAAIxAESAAMAAAABAAEAAAEyAAIAAAAUAAAIzgITAAMAAAABAAIAAIdp AAQAAAABAAAI4pybAAEAAABAAAA6+pyfAAEAAABAAAA7OsSlAAcAAAAcAAA7euocAAcAAAgMAAAA kgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAACAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAAU09OWQAARFNDLVc4 MzAAADIwMTg6MDc6MDQgMTA6NDc6MzEAACKCmgAFAAAAAQAAEoyCnQAFAAAAAQAAEpSIIgADAAAA AQAIAACIJwADAAAAAQBQAACQAAAHAAAABDAyMzCQAwACAAAAFAAAEpyQBAACAAAAFAAAErCRAQAH AAAABAECAwCRAgAFAAAAAQAAEsSSBAAFAAAAAQAAEsySBQAFAAAAAQAAEtSSBwADAAAAAQAFAACS CAADAAAAAQAAAACSCQADAAAAAQAYAACSCgAFAAAAAQAAEtySfAAHAAAoAAAAEuSSkQACAAAAAzAw AACSkgACAAAAAzAwAACgAAAHAAAABDAxMDCgAQADAAAAAQABAACgAgAEAAAAAQAAAoCgAwAEAAAA AQAAAeCgBQAEAAAAAQAAOuSjAAAHAAAAAQMAAACjAQAHAAAAAQEAAACkAQADAAAAAQAAAACkAgAD AAAAAQAAAACkAwADAAAAAQAAAACkBgADAAAAAQABAACkCAADAAAAAQAAAACkCQADAAAAAQAAAACk CgADAAAAAQAAAADqHAAHAAAIDAAACoDqHQAJAAAAAQAAEGwAAAAAHOoAAAAIAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKAAAH0AAA AFAAAAAKMjAxODowNzowNCAxMDo0NzozMQAyMDE4OjA3OjA0IDEwOjQ3OjMxAAAAAAQAAAABAAAA AAAAAAoAAANyAAABAAAAAcIAAABkU09OWSBEU0MgAAAAACggAAAHAAAAAQAAAAAgCgAEAAAAAQAA AAAwAAAHAAABSAAABMawIAACAAAACQAABg6UAAAHAAAAmAAABhiUAQAHAAALEAAABrCUAgAHAAAB hAAAEcCUAwAHAAABkAAAE0SUBAAHAAABqAAAFNSUBQAHAAAF2AAAFnyUBgAHAAAAEAAAHFSUBwAH AAAAQAAAHGSUCAAHAAACvAAAHKSUCQAHAAACWAAAH2CUCgAHAAAAqAAAIbiUCwAHAAABkAAAImCU DAAHAAAAQAAAI/CUDQAHAAAAyAAAJDCUDgAHAAAAEAAAJPiwQAADAAAAAQAAAACwQQADAAAAAQAG AACwQgADAAAAAQAEAACwQwADAAAAAQABAACwRAADAAAAAQABAACwRQADAAAAAQAAAACwRgADAAAA AQAAAACwRwADAAAAAQAAAACwSAAIAAAAAQAAAACwSQADAAAAAQAAAACwSgADAAAAAQAAAACwSwAD AAAAAQACAACwTAAFAAAAAQAAJQiwTQADAAAAAQAAAACwTgADAAAAAQAAAACwTwADAAAAAQABAACw UAADAAAAAQAAAACwUQADAAAAAQAAAACwUgADAAAAAQABAACwUwADAAAAAQAAAACwVAADAAAAAQAA AABNTQBeAQIyMDE4OjA3OjA0IDEwOjQ3OjMxAAKAAeAAAAIIAAAAAAAAAAAAAAAAAAAAAAAJVEht MjExMDAwMDAwMDAwAAAAAAA+lPoBAAAAAAAAAAAAAAAAAAAAAAAJAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAU3RhbmRhcmQAANEB AQAAAAAAAQABcGmIlQD/Vf9V/1X/Vf9V/1X/Vf9VAAALiwAACwoAAAuyAAALqgAAAAAAAAAAAAAA AAAAAAAATCSCAEzC/ABM3DIATHkJAAAAAAAAAAAAAAAAAAAAAABSAOMAAAABAEAAGwAAAAAAAAAA AAgAACCVioEAAAAAAAAAAAAAAAAISgE+ABsACAAIAAHl1wAAfAAAQAfVXI//EooMaTcAtkxk8ETw vv/6ANiVAAAAiDFwADQHAAgESn1K//sAAJUA4VwAAAE0Se9LkwjEWi5KQQ7NKhYI2KL2DgIdlcQ/ B4ERVOZJh676ssk8PwfEDs8yq0CGWsQA/////wCsw6gAAAVwAgRpXCB0m6Fz7NhRXncAW835+Q52 6luXxK7N/s2jzaPN/s35wziVfUX2Q6Q8XONglRtzBJVZJIpBujQAP8c8dn08gUpCIPbpqQiGB2mB aQ5pxBJm40BOgc0FSkBp58yHSkIHCH1dSnFpxDzYSjz///////////////////////////////// /////////5WV011qampd05WVlZXTXWpqal3TlZWV02rFTPBMxWrTldNqTHmRI5F5TGrTXcV541Iy UuN5xV1qTOB0w7DDdOBMampMt09X1FdPt0xqXTnvun90f7rvOV1RXcXwAuAC8MVdUdjEScQZMwyO SMtmR9Zgh6ypAp0kOu8pwgTCHNydlqvEhCOWy4q67it7rA+3gvZoT/pPkmLMTsTcaMSpM8iOE5GQ R6JM8uD9I7NOp0+VYpIv1k6Hlnwz/WCfMNm+fLbBcAGBOIqLiovvGpH6y1ZPDXDbIE+7EpW+vmsF LnDiBOUv8lxOt+Fd3znaoIQgfGxjbIogQ5IWaqwo9AehOb3FUmq5iGWKV1YG55OSXWpRKBFq0Wzk DMAMOAw2kp6Bri/MXJk56uwsoM7c7NxnlnPjfzN5dUe6yCsY4PO3LwJPYo72QWKrfxzCppbiM9h1 j5GYR+xgwe7Mz7d05e4AT6H2VJZV3HrjMyMRdQQHoAKYy4BOuk87wqqVC/Ysf9XcSUeJMKO+8Yr0 BZfXYOr4ihwHLrprdVp0VLYd14psRlE4gQcFenBF5wRdKl1pAuxcygei7PiI9ZLMbLQgkKA1B0Vs isUWxQOH11yoIB9pdlbs6kQMj2oN7Dc5QSi4DJcoMiibKE8o+1zixejFlmwtlSfc5MLPlo/jSDOp dU66GGCcrDF5jSQnYjv29fYzYjlOBJaDM7Z16Lo/YPvgMHR7zyzPTO5oZWD2aJb+3BHEyI6XkTQH rAL7dRR/J0UgTppRqk/2f1+WZGBDMFu+7gX8zSG+EOqkBaPFR5FEdcNFaLZAvhhsb6DOvpsFlYr7 XhJdTV0weW5cyAdTKI2IJpKQbJkgVaALOYLsOsWHxTHFq1zTiB5pcOf7VlUMymoHKMo5aQwUko0M jyhiDIUohVwjxeAHsewLoPIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACSCgwbkty7IbuGu9273LuO ux+7ebslkp+SJpIXkoOSursZuxS7frvRu6m7kAy7DGIM15LrksySObu0u/WSxZJquztsVOzx7LXs VgymDObsMQzdDF8MugyfL4jTXlz104i7uaCWXexscuxnbLeVHWobXc/T1S+KKH1snVEvUbIvui+r 0+Evbi+rXeZqwl2C02ZRzFwx0x8vdS81XfJd+V3NLy/TK1ypOawvzS+305DTnl1yXWovtdMf05bT ndPy037TTFE7XcLFtsVyh1PFZ4cMh/VMXEwRGr8aERobOZvFYMVeB/EHq8WDxQ1MAEyWTNVMxjlH OaE5gzmmOdkHxQdMB57FXcXfxfgveS8nLwldVGoAajNcc2rrXONcrlyLUVeV5KC2UQnv2y8FOQEv eS/lL12gSVGL06BRh2rcB54HBmrIXSKgW2yMbI5sYaBq7Pyg5+zOoNNR+2xioDWgJmxx7Pfs7uww oCyVqqBy7P6g0qBElX6g6Oy3bAlsD6BFoECgWGxmbGmgAaDnbJMbvhu7G78bPBsLG2QbLBv6QABA bBv0G4obvhswG0cb4xvMG6cbCRs3G94bsgguCBYIGQhZG1YbKxsQG2EbWxsVG34BXgHvAScBpgiW CPYBTQivCG0IxwhVAJwAfgFIAF9AeQCpAXAAZAGRAbYAFABnAYgAqAEVCHMATQAeAO4BEwhpAd4I tgF2CLQBHQgJARMAVQjZAI8AowHOCGcbThusAGYAMgChALIBtgF/ABcBiBvPARIBNwE5Ac8BGgHW CDABZQECCDgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADcUtz2luDEAyOrdX262iva4LS3wQI6 f8x/N38EwmuWCsRXjoXLA7oWK0lgXsL9fy5iZ2KJf2fc4sSlM0wzjnUxkQXiKaxRuvCOfjODy5Aa TY7442DE4Ms1ksUoLyjvKBKVLrtSux1MpGAZkWzjxzD/15m7ZChf17xppojSMDZqhkzerATTP11w oEaBX5JBgbeIl7shUb3TcAcLXIJc1tPH14uIZGnNaTgohNP9lU5dYlHYoOrsAAzwgZeB4KCpXVRd F5UclTUAAAAAAAAAAAAAAAAAAAGgAaAINgH8QFp9ln2qfbVAun1f2OAEzHDZ1/OInTD7oGxHXuwQ CKgAlgAAAAAAAAAAAABKAAAAAAD/xG1GAABtRgAAAPYAAAAAACcA9gAnAAAAAAAAAAAAAAAnAPYA JwBdAD8AAAAAAPYAAABdCEoBPgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgwAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANhR 2FFed16kAFsAWwABAAEAAAAWAAAv0AAA8HgAAP+2AADYUQ7F/6vYUQ4o/zXYUQ45/x0ASsRRfz/F pi+V4oHFhwgFDg6hUQiB8Xn7Sf/4/+vyiH532xF5ALoBOlyGhscvEYHhCkkAEQT2l9ddU1YnIBCz 5xtuSgQiEUCX9gAESg3hhzrazBFCQEAIldwI9t2WlrH29zwBxwgZcMRdw5gOOszOzb5pDuYpCDpw AL7YphvB7gBZAF2V4RvoRgF2AMcOrRbDwsVmzsdRSwh2AbG2yV0oxI4IDjjhCsx5SpVKAMVC486V UT5K2ACkxZJcwu4HOucnCL5MBQEAAAAAABuK1gAAAAdwXnAbcBtwTHBMAAdpN4rWAAAAAAAAAABw lIqU/wAAAAAAABsAAAAAAGlTAAB9AQAAAQABAA4AAAAAAAAAAAAAlQAAAMwB/7IA+LsAAAD+GwAA AAAAXgAAAAAAAAAAAAAAAAAAAAABAAAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB9cP6KPooo cPyK9Yr1iomKfXAAiv8I7AAAAAEAAAAAfQAAAAAAAHpplIpLS0tLS0tLS0sAaQBpAGkAaQBpAOoA 6gBpAGkAxhHGEcYRxhGXEWgRaBGXEcYRAL4IxAD+AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAADQAGwAAzWkIAAAAAAAoAb2CEVuzTygBAf/+AAAAAAAAAAAAAAAAAAAAAAAAlv8uAAAA AAAAAAAAAQCsR8VH4is6K+nNAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABK3EozStxe vkrvSuJK7wSBbaht1W2oDnBtm21vbSFecG0KbWhtCg5wbW9tkG0sQHBtaG0qbT8EcG1Dbe1tQ0Bw bYVt6W2F50ZtPm1kbT59Rm02bSVtHH1GbWRtJm2N2EZt4W0UbaJWJG2obSZtkAUkbeRt5EoAtiRt 2W3ZSgBWJEoASgBKAOckSgBKAEoADiRKAEoASgBeJEoASgBKAA4kSgBKAEoAXiRKAEoASgB9JEoA SgBKANgkSgBKAEoA2CRKAEoASgAOJEoASgBKANgkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAA0DgHYARsAAAEAAAAAtgBO120SADltAAAAABKVlQCWrBIAEgAAAAASAAC+AEovRwgA bQex3Qi7lgCA4wBVzAHhAAAO4+pKCMRpNwg6AAAAANg0AJaVcBtKiABA7EB2AEuWFDpKqA7E4QgO lQBAAA6rCAAkQCnTGuLVABsb7DSWSiAoAT0AuILDtkbkJzyIxA44tlW9rgEAcAAIB1LXqsSWIJXp F+NAuzKWAPY94xAAAB9LSUAvDsfyxF7EAfZqAC9LAGYAdToxllynQF1KGwcA3NwIxEcBVN1AAOF3 +K4OxJVRAH4BARrj6Q5CgSkozEoansTEKYEA4WJKxAHuScRKJ4WW17MnL0u2VlW73cTjQAGVCErT 092rbGDwzL72CBlOJwhQzghJOM4bBwBRXQChQOcvSgBL8OGA0UoAfUrqH4GubtAA8iCCgSAiOGq2 wiCVgY9AQADE51fjj55w4eFLcOFYAGzjBwjEW5mVlWR4PV09NMEgCFFuGrYOwFQOSsSSrMfHaQS2 HpG2vnmnQAj2xA4nVDZJJgEwlgiGzCcxlUGVDkMBCA4HAFg8SgEHOhauL85JgncZQM06OgjHQGVw ttkDSimB0wQB2wGBSl1RP7eBrkCV5lEAAC8/bIcxbyQ6L1FmAToRx4aSx7FKOBXF2AAk9r52x+fi 08XNx4fnJA4Uig4IrgIbksWVlhRWAd2RBARwSgTlSiIj6joUTQUOStAITktOIAeqAUVRlgkOiLPh IAFYB17YSefnaT8AfSrYldOLB0BM4XAI6W5LwL5uABsDwONwRuMIlZbncLyIAHHYzSs/4E86CAAI 46xRB3DuPQRpWIEOxGuKLcQkADTdAUBMOs2BBUo6QAbCQHBXSc1MQPbidog0Sc0CMRHbxNN2gT92 6krCgX7E3JbEiHI4n0BAUccAQMzBFF9peA6tKepAikyFnl5PQIAnBCxJGmGFIEoBCj8IEGx9AAyT GgGJ9kI4fYHltv0+S+oolXnnP2Z0gbY0Xfahda7sP8kQWFQRnj4wPOQ/BxRwThtYAUqkCIY4zojh JwA6zLOVfQABQgQv2UoBKOyW3TBKAeHNcGrnscIOf+IOqTA8OFh0gBDp7voZdAFqxECBAJYAMDB5 uyvTj0ZKG0tlcMLe2DXjDjTCSg4Hzz/ElQ4nSd29S9jZTpUkUnkADgC7XTxAgRuV9uGIVAHTgdsb KX32vAFeyQFAPcRwXi9SB7+yEIY/VA4A477EIDy+d6IAR2cBEUkARoHydEBJx6obgm7P5+JwykvE BA6u83AfcjFK9hQQQAEAAbY7xGnM4twUbKbTHRDzXsrhEcSysj84KJWVC7ZBP7PQAKyPU9I4xEpN GVIOBMcADmJLEAHYlczhxJMBQJVpTgHeSaipj79ujtzE58QAfgA7qsjyAMQOzEpd7udAMHABGycA QDoDSr7AABLiJyBYDoNzwKyHwpJOCAGkXdO2x8zFCEcAOyi2DlSDQQ7ERzxEaRV/JFbsVIEA53lG 2AFLlQEIknAI2JWzAsQA4MR9rpU46yAvL+FPSsJVsW5AdwE/lewe0FHTfSAO5V3ug+ezHwABS3gS 1eNVJLoRAtg8LAEODggs8A4vAEwbtqVBSsgAWABA4wjcxKpSAEDEU07MkkYAeTjEQAQbljkt51Eg WAcZUuNKPwjEGyKVXJUAD07TCNPnB+fELwAASgDh2EeVcABFQOAI9sIAQCAA7lF9kes9GiSlx6KI eicAnfJwDsRAPuPgzT4vJJXE2EDvUSAZkkIZYpMg6JYWN/YqZGqVxAEFv2qBQARAWkoAGokBthBK Dg4BAAFAWMc4tocO3DjnQADEMgECQIoEUkDMQMI0x0okZiiI3QA9Vk5cTn3E08yVzE7ijwDCDrIB QCIAAcL5CAZNXVbEDgB9spXYKJABAABHtpXXuilTAEmWxNi2AEqkqwjOrACslkAOgjyWvre+AEov Rwg64cWx3Qi7lvaASwBVzAHhiEAO4+pKG8QEAM32SrXEXRoI55UkACBwtpVA7EB2AEuW5DpKqA7E 4QiBlQBAAA6raQAkQGrTFeLVABsb7DSWSiAoAT0AuILDtkbkJzyIxA44tlWvB7YAcAAIg1LXqsSW IJXpjeNAuzLcSvY947wAAR9LSUAvDsfyxF7EAfZqQDlLIGZwRzoxUlxjQEA9G4cAYtwIxEcBVNtA AOF3+K4OxJVRAH4BARpL6Q7KgSl1zBkansTEKYEA4WJKxAHuacJKJ4WW17MnL0u2Vn2788TjQLaV aT/T092rvmDwzNfQCJxOJwhQzghJOM4bBwABQAChQOcvSgBL8OGA0T8BfUooH4GubtAA8iCwgSAi OGq2wlSVgY9AwgDE51vjj55w4eHycKpYAGzjBwg4W5mVlWR4op49NMEgCFFuGrYO8lTnP8SxrMfH aQS2HpG2vnmlQAj2xA4nVDZJJgHX3AiGzCcxlUGVDj4BCA4HQAgHdDnhqs22dqrg3ZUBOoEOGwi2 QHAPlarlXYRwdEpdTEwAXk1K0JZLB7YoIGlHVEEAXRDFPKUvDmVKiH7EDrYAlqhyF1RW1bbQs84O IFOkASBLALLbKVRyXXAAKefCTo+VcDuBu8RRxGHhwgBweCC+dxOkPx7EunBAAD9gfVsb2VPCSg5w f8Rcx550NHCFXU72TPIAgYtWhtchVpCBdVY/Bfhp1wXUadYFA2nDAEz+hvl4+xIAGv6X+XD7hAAA AAAAAAAAAIAFRDAyAC3NJr6SAJNMP6kACOBwAAUbSgDNCEowASQAAAAAANhGg8VGYcQkuFQ74jF/ 2HWYWGris1++h2j////////////////aLTlWU7xqwF8excFB2+80Ux7i3v//////////g4NMtHvy TFBBdQIGOCokqsJWjvtYauJQRhEaRf///////////////59zB1vcLGodRmyH5FfmJPju43kw7+eT G/////8x3hqaU6IT/WmrCGkof961AAAAAAAAM7kAA16jG7MAzAAAAABW2dDXy0MbSNjniLr7mwAA AAAAAHScALXnLxtAAL4AvgAA6krY5gQB/////2nuAQAAAAAAAAEAAAAAAAAAAAAAWMbiAFgP8Hzd 7OKt3eziCd3s4glYD/B8WJLixFiS4sRYkuJBWJLixFiS4sRYkuLEWJLixFiS4sRYkuLEWJLixFiS 4sRYkuLEAP8A/wCwAJUA/wAAAAAAAAAAAAAAAACdABs6PydU4qIABAAAAAAAAAAAAAAAQOBuAQA6 egAAFkRYkuLEAAAAAAAAAAAAAAAAAAAAAAAAFkQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABZE WJJYkliSZQD/AHkA/wBwAP//AAD/AAAA/wAIAAgAAQBYkuLEWJLixAAAAAAAAAgACADYSv0HAND/ zH1g/38AIP4SQPwB+wEAATcB+wEAATcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAf8AqgFpuwAA AAABAACHAQAAAEAAAACVCEoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABGwAAACAAEQEbAABY kgBAAAX/owDbAIwADgApALvkStTzFDpaZqamx4U011zyPpUAcMA9ZlwnoernJwhwAcjPUV2VzCB5 MIeBB8zBBMMEJdu0GAHO4IHJzm9lqyWAxXbmSlaVqShKXA4nrl1+EAAoniU60+7qQABKyH4aOhtl AFDMBcQA004Hv8NqKcxMRwCrUeo5XJUirH8rq0D2AJlbNHpSAYYB2OZHx7rBDscWQJVA5scAG+on h50H84CWXdKWVgIAAOIAuz/Fx9ihMqSRRwC0CJE5QAoABAAAzGAACNPMAQh9bvOuPlxKSl0BKQCA 8ghGliDYH1bY08RYDkoHXA4kG8sidMdKOq48flGVSUBKl5WFsikMXVEOTEov6cT2Q9YWR3UAfrsZ ErRKB8U1nsRDSZrEwQIRldgAPQF35+oOAJUJ9n0OxLqxDoC2UXAszOdHR36EAZTQ5qLhaX2D00kC xnmBCIckSfkIVoBJINCSP+H2AcSVzgHgCMsAP5YIZcc/lhK9ExumPLbH2OqIQAnbWDoiQH/TPBsr CAHTzrEiJ2DAACVuDggHeAF2Rn22dOcgtHC9xGA9B2aYS5UOBADCUVxNShMAx8fYFMdJcAG7KgdM gdyHOpU5XMNK4QfdXd0HL1Y4CIJv87r+CMa2Suy+3ZVK6pGVMQRYAebHB6bYcK6WaRQITzobBADh Qw5QlTp5OfaVrMyDUime3fxpUT0nxtOffx6HzRZJ2AEw03CH2D+qBM4OPO7HcaqVBdz0CHA+fuOB 4yDEwl7E3D85EpU7KbUWGwg/BErHfVZ5vRpRmQ7EenBdtAZJJIXpxAcA6sQBWE8ghd2etgXzKUp2 x33yAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQEAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADZSBKB2QAAAAAAAAAAAAAAAAAAAAA0 ABvxfXvY8NjwfVIbuxvfQMRAERssAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAANhWDtFWu1YH5w5AD9jlXnMOYthjAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAI7yjvKO8o7yjvJwlHB7cO+K9YqU AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAUB s8Q8Bxtl0k5KALRA5ZbCaYeWxJls2NN2AgDScA5TzWp+b1YBmpoA01kIQCSWOmlJlfu2KbY6+Op7 NsJBq5LOADQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABxk/LwFxPEOeEQC/AACAaQAAADgA AAAKAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAABAAIABwAAAAQwMTAwAAAAAAAAAAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAA IAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgAAAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAg ACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAAAFByaW50SU0AMDMwMAAAAAIAAgEA AAABAQEAAAD/4QvFaHR0cDovL25zLmFkb2JlLmNvbS94YXAvMS4wLwA8P3hwYWNrZXQgYmVnaW49 J++7vycgaWQ9J1c1TTBNcENlaGlIenJlU3pOVGN6a2M5ZCc/Pg0KPHg6eG1wbWV0YSB4bWxuczp4 PSJhZG9iZTpuczptZXRhLyI+PHJkZjpSREYgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8x OTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj48cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0idXVp ZDpmYWY1YmRkNS1iYTNkLTExZGEtYWQzMS1kMzNkNzUxODJmMWIiIHhtbG5zOnhtcD0iaHR0cDov L25zLmFkb2JlLmNvbS94YXAvMS4wLyI+PHhtcDpDcmVhdGVEYXRlPjIwMTgtMDctMDRUMTA6NDc6 MzE8L3htcDpDcmVhdGVEYXRlPjwvcmRmOkRlc2NyaXB0aW9uPjxyZGY6RGVzY3JpcHRpb24gcmRm OmFib3V0PSJ1dWlkOmZhZjViZGQ1LWJhM2QtMTFkYS1hZDMxLWQzM2Q3NTE4MmYxYiIgeG1sbnM6 ZGM9Imh0dHA6Ly9wdXJsLm9yZy9kYy9lbGVtZW50cy8xLjEvIi8+PHJkZjpEZXNjcmlwdGlvbiBy ZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxu czpkYz0iaHR0cDovL3B1cmwub3JnL2RjL2VsZW1lbnRzLzEuMS8iPjxkYzp0aXRsZT48cmRmOkFs dCB4bWxuczpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMi PjxyZGY6bGkgeG1sOmxhbmc9IngtZGVmYXVsdCI+DQoJCQkJCTwvcmRmOmxpPjwvcmRmOkFsdD4N CgkJCTwvZGM6dGl0bGU+PGRjOmRlc2NyaXB0aW9uPjxyZGY6QWx0IHhtbG5zOnJkZj0iaHR0cDov L3d3dy53My5vcmcvMTk5OS8wMi8yMi1yZGYtc3ludGF4LW5zIyI+PHJkZjpsaSB4bWw6bGFuZz0i eC1kZWZhdWx0Ij4NCgkJCQkJPC9yZGY6bGk+PC9yZGY6QWx0Pg0KCQkJPC9kYzpkZXNjcmlwdGlv bj48L3JkZjpEZXNjcmlwdGlvbj48L3JkZjpSREY+PC94OnhtcG1ldGE+DQogICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg IAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgIDw/eHBhY2tldCBlbmQ9J3cn Pz7/2wBDAAEBAQEBAQEBAQEBAQEBAQICAQEBAQMCAgICAwMEBAMDAwMEBAYFBAQFBAMDBQcFBQYG BgYGBAUHBwcGBwYGBgb/2wBDAQEBAQEBAQMCAgMGBAMEBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYG BgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgb/wAARCAGDAk0DASIAAhEBAxEB/8QAHwAAAQUBAQEB AQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1Fh ByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZ WmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXG x8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAEC AwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHB CSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX 2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD94CgC7T97+EFakPRjtG0+g/PFWgqn eNuCF+UkdTTdgGd65KnkAf59q/tTnufzO4uxU4B+Ubc8Zb/PtS7OF+QKR0OateWOnAT1znP40KmQ cDcM88U3LQSViqUYlwFALlfwpNjHoGIAPzHvVxo0wcA5HJz7f5FNeNWXZtIT19sf/WFLn0L5WUzC MEKG2s3HHI56VH5TcA4LgcjHtWh5QJXI3bfQ4z6H+VRmJgGxkpkYyf8APpQpsnlTKW3B2gMdw7Y9 aXZ99SRgdAB0GaubMZCpwvcn/PpTCmdyg4wPTPf1o53cOW5TYLlmXnC8e3Tn+dN2owK4wAOQfWra oWLMgA44x82KjKgMeQQVyxUdx7U3JWJsQEAsMAID1IHfvSkMOAVVT/CVqYAnaSACD83H8qQjbngr uPQj2pJ2KIdqZJP/AAKmsvB+YkbegH6VYK4b7gJPQ5pDwN21gG6jPpQpiaKzRg4P+1xjtj/Io2qF OAwbHGe4x/jVhhg4OBknOBTPlOMcbR/Fn5evNJzkHTzIcclvvbjzx7UwDkna20jBGKsOCDhVIIXn imbWOVGaadoglZkB4GQwwMbc9valIJGGKlNvGB7VPtQD5fl3D7w65pjxAEY4H+7Upj6lMoB8uMkA c5pCCednI6Amre0fP/Ft6gimlQvQEkN931qnNWJ5blJlxsXbgnooP+fSoDG+eeMnrjPetEp905PX lSKiMeRKMEjPI/u04zQnEzXQntgZOMZqEx7FUqv3cYya02iYA8DHONo9h/8AXqN1GOx4+XJ7GrjP zMnCxnMgLKdvdeBTTGWHzclgc5HHNXSMkgKCWwQB+YqN1yOcj1KHt3q1OVxOKZnMpGDnaoPRh+v6 00pkPuwTkZIFaLKSOgxjof8AP1qF4wGwQpxjr0rTmM+VplExYTGDnpn/AAqIoeQCRg455/D+VaTA gg/KGB4yc/j/ACqB48kjlTn7yiqTdyTNMZXr8xLcCmlTggKcjoSKvmE5GVBHfnr/AJ4qIq3OASOw IouJMpBTgNlgT6emKgdSRkNhickN3wavlBywBGPvVXdV4wpDfywapTYct2UQoPzlduAPmAqtJAB8 w3NzyGHp61pOoO4AHnHysf4R/wDqNQspJbYo2hvXPUdK0hPUiUZWRnspyMLld/zVE0YIyoP3hnJ/ lWh5RI5xs3Z59aZ5QwCq4Ur8taKoubcnlk0ZpiYBgRkL6mojFtUjaSQOV9/atFk2kkZ6sM49OaaU LBhj5v73eqjUdiHEzGjyXGeWblvxqMx7TnBzngDj8/yFaZjTccj6Ar+n6VGVI5wdxPp/n1qlO7JS aM0xc5O72D/p/KkKEBdqqQoGd36f0q60RAbAYsBnBPBNARcKGYqCq855o59LhGLZnhPRQcnge1Ru i7v9X8o6LurQeEj7uST+lRlf9nceCcYzwOcVSlcaUluZ+xc7iuee/wB78qrOrjgE47Ag/wCfWtVo +O2Ce2c1CyYxyMgd6pTRPKzNEYOODwvOM9aYwbIGAdw+Uf3a0imQRhsndwT/ADFV2gKjcFPBGSw6 46fyFP2jCSViiY2CMQuCerHOOnp+FHG1T37fL+eP061cWIqqrgfKBuLdse/50wKo4b3xgn0/+tT5 4hCJQKHJzuBz35qFgwbGRhky3HvWnsG0HAJB6yIP89RTCi7iORuHTqfrVc4+RFApmPDEH/aC+1V/ KGOOSF5bH5VorGuODuRfQVCYyd4ADELlS3pVwmRytmeYzkYJIz94rSBOOhU57r0rQMShixyV6L/n 8aheNmUsuSoPcc5quZMFB2KjxleFOcKQfz6/pULJ0Yg5AyDt/Sr2zAxw2c5JHemLEepL8j0/WruK 3KZ5QgscMMrwf7vFNKELgMWYD5Tj1zWiYjs2bcg8n600RZDHawIb5hgHae39aftOpKjK5QK/wKPu jKlT1yf/ALKlPClgwGTwT0I//VVhlGGO1OBwNvv2/ShkPAIDAdOfT/8AXSvoLl0K5QDeQyttbgrQ 8QwGChQw4yB078VZCEfMAy9zk/n/ACoaMc5yML9KycnzCt1KWBvG3LDHBx+dMCccAOAuRkc/54xV 0KSp5Od35DHv+FCx4LrtBAHBxzk1DlYdtEU9i+5HGcjp/nJqJoTkZCnjj5a1PLAKFQTk8Ag9f8kV G8R42gg99wqJTSQ401Jn2/sCZLKCF/iZu9ACnHJznhlPX8Kt7CM4GemPzpoXIA24+b5Sx+vSvl+c +mcSr5Y5GB8p7dPy/Gnsn95RhehJqfywMpwMnAOP607ycA7sse+aXtE0OMSsPvAAY3fKKTB9Bux1 Bq15Q67TweP8/hSmEAJ3AGT6/wCeKlyQ+WSWiKGF3FR1B9MUmxxuIPy/dDZxtq4Y17BWy/CmntH1 AyzD/Z/l+VHO2tAUXbUolEOW59h6GoyrDGcZC+tXPJy3TA29AT1703yzggDg9OKfM2he92KgjxnI ByP7vTmomAZHB4yeM9K0fJyCyh8huVK9feotgxwCVI5Likp2QcrRTIOH68gYAHSjYMsCDjuWP8qv 7QDyr9O4/rTTGc44+X73y+9HP7orK5nvGOrDAxxgZpGj/wBjjjGRV7Z0wCQQckCmGMnB5+UfLg9e aSqC5EjOCfNlRjcerH1pdueQDuz1B9quLFk9zjtmgJt5CnOOdop+1uHKUmReoU4z17/h+NRqDzhg OFz9avMpxtCn34qIx8ZA5zyB7VamrENWZVKYyMD5h8xJ/wA+lNKjByfu9sZq0UGVJHP+yv8AOmlF 6LwM5ZW9cU+a47IqhThjyBjqBQygEEBmGeTk4Gf/ANVTbcZ25Cdm708gDLHO45wCaXODi0yps67g Tk/Jk+tNKuByvyk8/wCfwq7t2s2d20DqBt7VE6N821fqxNHO0wcbK5SeMBFVVPvn/PtUBTGflbkr wK0zGSc4Jz91TxUBjH3gecZIz+lVGZFtDP2HP8R5A4P8qgKlcnouOmK0WUqSenc57VGUw2RlgejA f59a0jUM2k7WKLDGRgcDnPvUZVhkEA+pXn6VeKc9MgevpTTEf4Qc4545/wA8VftIkuJRaPqvbOSM dveomQZBUYJHJB9KvmMfe6hm5BqF4yAo2nBqlOLJaaKDKOcZw3YVCYyRnJAcdK0DGwHCkg9BjPeo vLxwRx649DVKViFFuRm+V8xByRn+lNMX3/lP+yx/pWiqBQVPGOrE1EyZ6A8n5vmqudsSg9+pnvGS AeBvI3AYycd+n+c1X8khiwBUbhtJ6fl+VaPl9R8wBPXv+FRuoYHAzg9N1WpaE8rRnbOBgErtA3Ho eO9RMrFVXAVyOOe9aMiHDfKDg/dNMaE5BCggDoR6n+VNTSQ+RlIouTuVip6MR/OoGjICjaQGByw/ u1pCLOFblv4mz371CYgeAOpO4k9qFJW8ieV2KJjVmBJGAeBmoTGScbV+90PP+etaJjIXhcrnGT7V CYmG4qQMYwo/X+lWpuwcrRQ8vB3KoQN95vfFMEZICbTu9QPl/DFaBB75yBgk9qRhk8L27iq57C5W 0ZzxlVbjLluBg1FsJO8fL/dJHr0/pWh5JKnOM/wYHINNZTk5AYA9zirUrk8qsZzxgZ4De+P8+1V3 jJyF+UN0AX9K1MZztUkYPDH+VRMh2g4+Uf3up+tOL1FyXMwx7trEZHqwzkZ5prxqMFVJZcbRt9Kv MhwVUYC9QT1phjBXjOV6AHv6VfM7k2SKBibOSpwvTJ559/yqNoxh8INyt82TWngr0XJIAIqExEHO M/LzkVSmDS6GWUVQcpkE8lRSGM9dqkIAGq8UO9gOgXnFR+Q7Bj/e6nkjFVzomzKLwhegOTxuHTpV d12jABZicBiP4frWo0QGc8kFdo9ffrUbRBTtDc/3cdR/nFNTslcpRdjNaFg2VBCsODn/AD7U3ymL fNhl/iAPT3xWj5WQq5PsAD0pvlHaR8zAtgsfl7+tV7TzGoXRnGLnAOf8jNAiBOV5Gcc8fhWhJECx wSCF5bBX35H41G0fGQDhpOVkXj86n21hcjuZxiIzgLn+PmmFMghgVC4znJ/D8c1pNHhWyHBHUqPe ofLKnBCYdeN2cD3/ACpxq3E4NbFIRqwLcbiF2uEA+tH2cgdDlvQdfr+VXDHwNygnHJ/hx6j9ab5Z C5DZ5/XPan7VoSpq5REWQGx8x6bv1FOMbSEZUFstyo/h+tXGRh1zkk/dPpSlGLEFGI3fKS3tWcqj Bx1KDRfMWZTyDkDtSCLAA8vJPVxV5o9zcAfxbgTx1pvzYb5DjABJPY/5FYuo5Map2KhiLjKqxy3I PaoiO4yu7qE6VeAOWYDITgCmbV6MjnH9ykpO9hcvun24IwDggkA8ZNM8r51VVJK4yCT6f41eKgrg 52sMcUCM8fIMZ4Jr5j2l9T6Vwa6FQxj5k29Txhv/AK1KF4OOFzkj/P1qz5eDtwFG3naOaUIvoSD7 0c9w5UV3AzxnO7oTxzTNgxnhi38IJ/OrYXklhtDNwabtLL0J5/h/Wp50yrNIqFAo2qfmcclhjgji nMvy8BeR1P8ADn0NW2iJUj7wxzntTDGcZwR8o4PepU4sTjqVCh3Hgbm6cUmw5YqOSAoAXPFXTETj A4A+9QI8EZwpYUOoFkUWjIAC4wo/WkEWcAbeP4ccVf8AKHI27gD2/nTNittUZ4zlvxqfaWY2jP8A KZsrjhTwT7etJ5fDDYSf/r1oKpycsNrHlQaTysglQcD36U/aoFBlExtx8uBnB4yKhMIBxypQcMta Pltk5BGRyCMdD1FIIxycAhjyueRikqjDl12M5k4ycH2BppjPYAg9Qp6/Sr5Q4JCgE9zSKhC4GBu6 DH9apVJCdNWKBj4HDHOCM+n+TUPlHDjHGeGP860THkOMZ+X5snj2qMxjrgkjqV6da09qmZuDbM4o cMELBT1IqJohjdtJwV59s1omMluF445NRNGF3EEsf4h6VcaibE4tRKIQYUDIB9F70vljofnGeCRV 4x8ABdu1ucVG0O7BbcFYU+fUUYspMMhupIPBJprgKG5PzHuvFXNhBHyhSRyc+1BBOPlxyATmkpWC ysUWXn+Lg8gf5+lDICMDBH3QAf8APpVgRsOg5B456cdaCgUYAUE9afOyVFXKEiIdxCqcgHrj86a0 bDbgYyoHFXXQYJ+XnqAKYysCCQQoPBWnGo7akSiUWjOBlS2PvYB6emKj2sDnkEdev+FaBADbgpVv 72KiKH0yvsKakriaM8pnIICqfUVGVIzuzkcrkVekiB+XkseWNRFDkn7x6YArZS1MpK/QpbC3Az25 AqJ4zgrgk7uQav8AlgZzuJJ4wf0qIqfmOR2yF/z9apTimU49DNEfXIbeBxgVGYznLA7d3ORWmYgW IDjdjjBqJ4zgYxyeAf8AP0q/aeZHsnYzTFncN2R6GmGM5DoqZB7+1aBjIx1BHoOvv/KohHgk7SNv c1cZkqDM8wg/NlWIPJJppi6ngKcd60RETlQAS3RqGTHIHHZiKXtVYfs0ZJiAbG0qB0IYU0RZJyrY 3dD1+lae05znGFOSP1zUJh+Zmxk/3h1P+eKOeQnBmeYFwp9eSAe9QFMYAxw3O2tUxkjqM9yf51Dt OWCj5gfm/wA/lR7RicDKaLO7OTu++Kb5QbkknPBwPWtIpyCAzFuzUwx5J2lQxPK/w9a0U2yOVIy/ LJGAM5POO2OuP0qJoiNufTdnH5/0rVaPbkjseGIP4c1G0SnknvyM+tae01F7NyMgxndweAw6duKb 5bE5GQuPut9K02gypynU/dAz070eWADhSxB4H+fpR7RolUzI2ct8uQRzgU3acHKfLs4JzjpWkyHD bVIG0cn/AD71GYuMHK/wjB+7/nFUqjQOGhmtGCeQfu8KO9MwOSFJUDnd9K0fJ+Y9Rg9z2prw9gCF JHykfe5qvaWJjTsjOwuAdv3R94n8/wClRmMsh6bSepX+VaBiOSo9TwfWmtBwcg/L0JpqoiuV2KDx bWOeg6EN+NR7BgoCQT0IWtAxsADjeT61EYsHGCeOCHp+1uHK0UTGrAlf7wxtGMetMKLGnQgeo5+v H4VfKcHCjgc/NURjXGcA7E4BH3ef/rmjndtxqDsUCkhwCrYA6E5/z0qEwgjbydpXO41pbUAO1eOm P8/hURDDlR65Oe3+cU+dJE21M/y2HQZ54UetRsAWwecHsPz/AKVoFSG3BTns4xzmoihX7uPlGTj3 9KpTlcOR2KJR8NtReBlWI9+tNaJjgOCzk8sp7Z//AFVeZSq7gcnnKnp+dREEEMQF4+b+tUpyZDjY phNyjcCpydvzH061LsA74x7H+dS7Tt5HIG3r7UuwggDJTK8k1m5tl2iV2TI2gryMn6+9N2FVxjgj qT+tXABufGMqnzE/xUwq+3JHyhV5HrWEpNsLIoiMqcsuPm+Ubv1pMKCeOT1q3sb5+oLHkAdPQUwx HPG0cc5QUe0Y4xjFn23jpgYyvzHP5807b87bgcKflb/P1qQJggcsd3YU4D7u7t92vlvaaH0ijdlf 5cnA49xRhdvIAwOTirBVWPALEHkZ7UpVSVxkDHINJ1CnForYG05UA+uaVVwATg9do+tWNo4IDHGe NtGwlgSN+B6dKXtbK4lTuQEYPIAPXkGmhMcFclh1TvVoqu7OGPyjDMCeB/kUuwHJGDheAOo4qHVt sVyMqbCcYXk+/T60hyBjnO3jn0q0IzkhcDKYOfakCnYSAVPPXvS9oHJdlTaccgjPb8f/AK1N8vDZ VSB9PWrZGFAUBv8AZU01oypOCPvEDJ/KqVQUo6lbaeoBJz2oKHsRk9Rt9qnEZCtuKk56A0Mu0jGA COoap9pYFFlQpjn73PHH+fSm+WeccZHIIqyVY5PAJ9D2/wAmk8voeucZbNUqjJkk2VmRcEkKePlx 7U0rySwAB6fL+lWtmCSvsCcUuwEAA554H9aOdIHEomIjcf7x4Ur/AF/GmNHhMEnvjA/z61d8tmJx tXA/u/1oCAc4OD0arVWxPsmZpQsc8kbefWoPLYHGAcjnP+FapiwcYGcYJJphQrwBk5xk/wCNaKsr aEezd9SiUYZDY+XOD9KjMfzNuXA9EHbv/WrzKp5bADDgM3+fWkK9cpg4GTnrR7SwODM7yuHJb5R0 yP1NNMZUk7AdxGK0zCTn5Qc9i3vUbKg5Axk/N/jVKsxKjEz/ACjjGCMei00ruyNpBx83Hp6VbYhe vc/LuppC45IJ9Bk4oVXQThdlIw8HBA+X+IVG0WQc9hzgZrSMecjH0qJ43BYdjgHFVGoT7MzPLb5f Qrx8vT15/CmGJuTxlum0/rWoY1C8FtpPJb/P1qBkbGfQ9QRVqqiORszjEck7cnHft9aYVPXbhSuc 5zjn/wDXWj5QcklAvoQOtRmM5LFSc/4f/rq1VM/Z2ZmvF1wMDHXH61GY+W5Khh1C/wAq09meMYV+ 5NRmNtpAQ5xgZpqqJwbZlmPALEEN6Ac+9MMY5YZG0cnb/EetajQnDZ6j0NRm3G4joGPOR61bq3B0 1Fmc0YCcKcnsDUfkjhTnJYYOK0/KyG+7s9/8/SmeWCVP3j3BP+fWhVHYFAy2hLIRnB2+v8qjKbeB yB1BrUERBAUDrzimPESPlwOOOKFVSdmL2ehltGRt4BBPzAe1Ruozg5QgnPHvWoYwScrgd8VCYgdx 4wD8tX7ZPqLk0M/yyByowem7oR3/AKVD5WQ20ANnmtUxIM8nBHUGoWhyucncRywPr6Cp9rZh7MzT G/TB+imomicE4DH3Pb2rUMZ24xxt5ydv1qNojjHUjoua0jVD2LsZPl4Byu7IOOf0prx7Q3GQp+UN x24ya0mHJwoyfu/hTEQgnIAOOSRn9Kv2pPJK5mPGSCVGSo4XH+faoDG/3j98Jg5PzfTJrY8vaB8p yeoI6+/6VGYyDtxkgc801W0E4NGQYz2wC3Q5oMeAMEcngD/Psa0WiGVJGV9cimNEMZyCewXBzxQq 3vC9k0zMeHIzzkHqq+3SonjUvtAJBP8AEv8An2rVMIwwwwJHU00xYyoJOP4DVe0shOkzNMePL2qB j7wI/lTTFkFcjI5AxWiYcHqCh+82fWmlGwOSw7Ejp/nFT7V2GqVmZTR7cKOSR37VCYzjpnrgH696 1jEoUnKjLdMelQvABliMKOc//WqlVSG6bMtoTlgMZPUgfL+dRtFjcOCCv58VqlF2kEqfdl9P/wBR qJkBIIGVA6H9KtVifZWWxltGdpBUfMc5/wA/SoghyxGCmOBnjpWqUK/KVyMddvFQtAu0gfMW6YHf 2rRV0mJ0rmWUwX3cYUYB7YJqIwj5QoAG3v8A568CtNo+VJwTj+IU0xuvVgP9kjge+fzq/au1zLkd rGXsOfmVSScglqiaLJBCg5xn3Oa0jGCxBGQD8/4f5FQ+XtyuOB0wD2qlUYKLbM8xkjBXB3dCf4fr 60hUAMMFSeCpbNaHlsG4GOOMNz+X4U0wrgrjKgfLnj9Kl1FcOR3KJUgLkEkH7pqQK4HHTH9z2xn8 6tpFwAQMfX7tIInCkJwQeWZs/jXPKs7DjSlYz2j38jcNj4IY9Md6l8vjLAuSTkBfu1N5JUbTmQEb cEenenhGGSqhiT83NYSqyaNYU+Vn2bsYjIUNg+vSjbxwhxgdhxU4UYChQzkY68rz/wDrpxUk8DAB 4IPpXzHtlc+k9kmQeXtwCMFjyMdOM/yoVARgglSeQfSrm3OABgg8Kf4aYUyfl4OfkJNCrXG6evkR eXlCCnGRxk/57UuznG3GO3t/kVNtznk4ZeaQK5AIJwBjGKjnVh+z0IQo2nhuP4Tz/npQQQR3zu5F WQhORgYPbGKXZhgVXGG7D2qXVH7Mq7SCQFHK5yTTSuGyMqD0q2YweQOd4zmk2YBzjr2/z71LrIHS sU2UADgfVfp3FJsAY8YJHGfSrhUE52gEKedtNK7gQQcnv/X9f1pqohcisVAo+bknFRhCFztwO9XP KAztUn1B/nSMgIUBSBnoOtae0ViHCxTEYJzjgn09aQqDkAE568dFq0RnHYAccd6DGMYIyeyj/P1q VWlcPZlLy+cop5PIx7f/AFqaY1zgKcr1JNXhEDk4IYen/wCuozFleRxnnLVSrJEyplLZjOMnaP8A P9KMDJyuAB0xVwxYOTj7xztb1/8A1CkMbAkEAgeq8/nVurdCULMomMgE4yB3NKyfKVwckcMKu7ME qRwT3X2pvl8EkDb/AAnNL2qH7N8xSMfAyAT6baaY/vYHU8DFXvLxuJHA680wqcZwG9AKPah7JGZN 8uc9/UVlSTZzg5B6jNad3nOdnHoD6ZrFlRs7duRu6D/PsapVLidO3QYZNzfe6HilVjwSSxI5wfWo WXAPG7nkUpYqygZx8vWq9qyFBXNCNj8+TnJHT6ZqwE3A4GAy5VjzVaHJ3cYPQH8KvQ5+bK7QPujN Wql0L2epAyc9CQzcj0qIxsuSSMckVpNGAFVmLDbyO9QMgydqn3/GrVRmfsyls54wQeSSajKZDADp 0NXjCADnr3UU3yjxt4C84zVutZC9nczynsev93t/nFMCLliQQc9f/rVeMYBzlgB0zUbA4xsIJPBA z39al1WheysU2jGANu4k9Me3WmOoBJIyRjhunH+cVckRg3GMbfvH6V8i/tq/FvVvgz8D9Y8UaRb6 vJeXV3HbzXWixbprW3KO802TwmI4mG49CR3xXNjMwp4HBzrS2irnTg8BUx+MjRj8UnY9L8YfHP4W eCNd0/wz4h8VWdtq+qSbY7OA+d5K4zvlK8xjAbDHg4Poa9PsL+y1a1t9QsrmG8s7uJXt7mCYMrKe hB/Gv5NPjL+27f3Ph/xN4a8BaXoXgrxJZeHmn8Qaymr/AGjUb4qFZy07FvO+Zp2CocAYIzyw9r/4 JjftceLvC3xH8BeBfiV8ctE1/TPi/rjWNj8OmimuLi1uZv3VnIs5OxJGm8tCBwyfeIZVA/Mcj8Tc TmeZ+zq0lGk3ZWd5L16H6Hmnh3HA5aqlObc13WjtvY/ppVcgYBy3XK0gjAx8p44PHarezkuc7yOh +tLsC5JHRuM1+sqvofmaplAxj5cjjIIzUbR4BOADjrV0x4yoxkjkk8A9B/SmFCDvBwABg7gRV+0u ieRoz3iXDfKRt+62P1phXaNoGeO4q+8eVPAzjkD+dDp97IHKc/LVKrdaicGZnlgAfxANyStRvDlT jHTj1rSMS9SCQDwTURjIPc+uaFNh7Nma0W3aMdueelRlDjnr2YmtXyst7k85NRiPOGPGRwCvtVKp Zi5ZIyXhOSOdwHf+GmNGSxbHLDnIrUMeAGK7iO49OOaYYV+bPAz/AB0/bJC9izL2YJ2jjsf50xo8 BmxhcfKP51pmMYKhRjdlueaiMWFQg4y/IYevvQq9x+y1MtkPQKxGBmho1zjHbqPrWg0XPIGe43VG 0ePlXAx1JNV7cXsTOaI9flwD3+9UbxkZwDlsfMa0/LOWz13feIqPYwJxwd/Dc9Kaq3FyW6Ge0RKn Kjg9QetRMgABCKEz/Ef5mr/lkqMtl+z7aRk4YEFgVypA4pqpZiVO6Mvysv8AdBUpwMdP881GY8An IQMeATzV8xgAnb1Hp36/0pjKcE5AXOFyM9TWiq36kqFkZjISOVTZv4Jb/PtUDQD5T+QFbBhGc8KF +8D9KrCPkgqDg/KR+tXGskL2cuUzNjgNgAAnuBUZUKApByrfL/jWmYlIbAwXHB+lRNDkEBQVK5HO frWkayI9lZGY8ZYdW255GOnvTCuA2NwB6/j1rQdQqvtBznkkH3qIRMDgr91/mG6q9tysn2fkUjhc gA5B5Cjv6/zqIIo4KlTjpirph3Ddwdxwef8APpSBeTjkgjJHb2qXVHGmyokYUlSPmH8RH86aY8k/ Lj/nptXpV5IwckL94fe3f0/KvDfjR8fvCfwQl8IW3iTQPGevXfja7vINAsPBehi/mZ7WJZZt6mRA oCHOSexrkxOLo4ak6lSVorr2OnC4LEYysqdOLlJ7JK7Z7I6HcSQQPL+bg1EYW7Z4H8Vfnz4P/wCC mXwW8f3mr2Phf4WftEajd6Ro19qFwreC9LtVe1s4DNcvGbjVI922JHYKPnbadqk4FcFef8FVfh88 u3QfgJ+0BqVvHxJPqel6PYtnttU6i2e/evnZcXZFF/xk7dtfyPoY8G8QPWVJpebS/Nn9DYQ4ySVx 75/z2oCn5toDFT93Hb1/WvyHt/8Agrz8O7G9uofEvwW+K9vpkejQzWt5pDWF1dy3u1vMt1t3uI4/ LVhGBK06lwxJjTA3fQnhv/gpV+ylrdxeRXPxBXRxY6LHeXVxq+gX1nHljJ/o6ebbr5lwoQbkj3r8 w2u3JHw2H4+4crf8vbeqf+R9LV4Qzqnr7O/o0fe+zG4YAUD5WJpQgK5AOMfLXi+j/tLfs/eIfOi0 L40/C7XJrXRWv9Rt9D8c2V69nZgAtLcLDK5hVQy7vMxt717BaalpmpRwSWOoWN4t4kb2zW12r+ZG 4/duoB5VgrEN0IU4J5r18PxDlGK/h1ov5nnVsnzHDL95SkvkWdjDPyj3FIFPIAyCc1OfLZtqsu/a DjeM7d2M9fUEU4jkKcA46N/n6fnXpxxEZL3WedKjLmtYrBQpOcHJ5pCrZPH3f7pq5sXfkqMDqS3T 3/nTCrAYBB+mPz+noaPrCJ9iyuB84UjoO9MKHPP5gVaKfMOOcdzS7SPYt0wOn+eKPbIFBtFbZgAH 5uu4qDTXjBJ3ZX+8c+tWyp4GCM9cUzaB0JbPXIo9rZg6ZAV2k5znAx7UwohPAIKj/OKslDkDbhcc E0qqTww4xxiqVZ3F7IpGMDIwSCeOOlDRcn5Gx6Yq55YAztJGR1pCpyBzg9z/ACqvatEqlYqfZ1ww YdB12mmFFJZQoI74q4V2/e6k/wAK00Llegz6mp9pcPZlUR+gA47/AE5pjRM2W4OOAufb/A1c2/KV IK8np/jSBCQ3ZmPCnPp/9an7ew/YpFUoc5UZJPIzURiyPQYXIA61eMXYFQpbpn3/AP1U3b6AFR0G 7/PpVKsS6TZT2Ehvlzzzk+oqBshW6KVHc1oldudoUcDO6oHTK8EE98VftUS6bRgTrkcDJxyMe9ZD phskMuBxn6108sW4EYxluv4VjzQMrkgHIPDVXtosnkaZj7W5+QEN94+lRGPIwMtg88f571pNDxt2 jLLUZjJIXg4xk5qlXsS6VxlopzjBGTz/AJ/CtiNM4BUE8YUCmWcOADjljycVqJGVDfKScDgDH60/ bagqbiVSmTyoyKYI/mIyGz1FXmRjzjgDgDmkKDvng9cdqbrpg6LM4py3TDN97PahYh1wCPSroj7g AEH5gw6VG6diPvMMd6Xt0JUdChIgHBHTuO9RmL1HGeMGtDYC5ICgA8cf59aZ5ZGefl9cU1iAdLyM 4xsVz/tdjXl3xm8CJ8SfhV8SfAn2W3u5fFXgrU7Gwiu0DL9qmt5FhY5YdJGU9V6dR1r10rjnBXJ+ aomjJByCvTBP86ipOFam4y1TNKKqUK8Zx+KOv3H8Dus/DPW5/iXd/DeXR9OPipPEM2nXE8bGGOKW zmfz3nPLRxxrDI77h8sYbjGM+4/Cr4Z/C/8AZ8+K3hTxNe63rGtfEXwD4gs9Q0a/gjt7Ozh1K1dZ ongVWm+0NFJEWKSvFvCMBG/3T/RH+3l8Cvg7pC/D74taN4H0fQfiZL47msU1fw7YLaSX8N7bXcl0 bpUwkrmRi5lcF9zHLYY1+fvxI/Yt8a/ET4OyfFIeANZi8HSC6m8NfESweHz4riIoPtNtbiXz5I0Y xv8ALGY3UEg4ya/OMj4L4e4cxEsVmVaKvL93zS5V6a2uz9nzTjjOuJ8FDC5dQlyqPv2jzO/V7aI+ pPgT/wAFIGbX59P+MWsR6l4anbafEy6PHZy6ey9WZIUCvH0LDAZQcjIBFfr5oGvaL4n0ex1/w7qd lq+k6jD5llqFhceZHIp6YI75ByOo6EZr/Ow8M/tk3tjb6no/iG1mg1y2uZY47yDDRllLbAwODxkj vncSe1frn+w//wAFW9U+Edkum+IJbS48KzxTPDomqXjrbz+VtwqyKpNvKysqb8Nk4JRsAV+qU8Xg sYl7Gau+iPyTFZRiaMnzR1P682j3ZDZA65znjP8A9aomQMGBA2+49v8A61c18O/H/hL4q+CtA8f+ BtWttb8L+J7BbjTL63PO08Mjr1WRG3KynlSpBrs2TcrgjKj0/wA+9R7dxZ5UqMk9ig0QzlUBGAMA UjR5JBzjHSr3lFRwP++fpTdmDlskkdh/Sk63mNUbIz2i4YfdwPmHt60wwkY4PAGD7VfeJstli2Oj NTTHheDyRyADR9YS6i9kZpj54x1z+NMZMcAZbHzN9R2q88YzhepHzHP3aaYyc5B69CKr6w4i9imZ /lk44U8NjNMMYBZSuQcZ54q80YBPBUL0+Wo2ix3+8OMmhYjmK9k0jOMX8R+UH7zYpCiFOQmc4U7u tXmTDHA+bGWUVHtDEZHG444FHtrscaepQYYxjaMHO7NRiMLkMMc8EA+vNaDRqVwRkD7xH1qIxt8x 5AA4B/nTVZidJma8fPA3Anl/4sdqQxnH8ROeCFq7sPHBAwOWNMYHLH8sVf1nQj2RRMYCnjHoPp6U 0xjB5IyvUCr2GGSVBZvUdKjK4xlWyq8YX1FNVx+xKRXDEAHIHIx/OoChPRW46YrRKjnIxzyueef8 moQjAkLjKnk5prEqwvYu5mtHtDHpgcc96ieCRiDgjOOhrSaNWypUgFuMg9v/ANVQeU2Aeuev1rSF dNkypNFFo/lBAb5hk1B5WVKqAAPmwrVplHH3shAOoY4H4VAyYCjI3cbgMj8q1jXIdFXM0IoJBBCn oS3NMaEkdCcN36CtJ41ClR8ufUiqxQ7TvX7+3oMjpTVbzJ9mkUthIYbWAHX5cVCUJwQvA6rjqe1a JRgnPBzzkUx04yACG4Jxnv8A/qqvbuIexXKU/L5HABHfAH51+Wf/AAUw1PUvDi/s869pN39lu7Xx rrVvGSo5WfT2UkHr93cOPWv1UWPhc9COo9fU/r+PFfj9/wAFQ/Fvg/ULb4NaDp/iLQ9S8SaB8Q7l tV0SzvkluLNZbKQJ5yKSYyShwGwa8DiOtSllFVSelv8AI+t4IptcS0dO/wAvdZ8v+G7M6Ld2t1ph W0mu7O+tZ3VVBaG4tmilXGOhjeReP7xrmvF2n2mnJpm0pD9o85srGRuwE/2feu60oDborLuO+d1J Q/d/csf1xWP4xtbe5TTGliWXaZgoGfl4T+dfIYbD01BWR2V6837rZ4jrXxB8YaBot3reu/Dq0vNO 0TTri51KXTNbKs0cKszFIXi44Q8Fz1PPFXYviHo01kl1qnw58V2/n20cqLDaW9z8rbe/mgA/OM4z 0rrPipAF+E3xGeFQGHgfXNoVM9baboK7ez022fTtPVoY2/4lqgKq7dvyp0Hp1r8O+p1eX4vwR+sw q01Dm5fxPGD4j+FGpOsUn2myd7RZhHqPhy5j2rwNpbyypbJ6An7prf8ADvinw1aC0m8LfFS50KXU dPaztzYeMptPuJrZhhoSPMVypHBU8Hng16NH4f0i4aEzWNtKTbMG8yAHjj+XFZdx4E8O3qwI+mWz KYG8xTCP9nr+v51zVMFPS8Vf5o1WJha3M0j1G1+P/wC0hoei6ivhL9ojx1cvFpsMEZ8QayniGKIw yGSNwl4JcSbnwXGHZcIW2gLXQfDD/gpZ+3JbalLZ69rHgXxZAyCSyufFXg1Y5njVI0dQtnOiqpKB /mGczMFwuFT5B174A+BdZs5ln0i2dZdOOfMgU7flxlc9PvdRXJfDr4XatJp8c0XirxTYiPXdVt4z b67O26GO5nWPgvgYWNMccYFONTG4dr2fNH0kwdDB1oXlaXrFH7U+F/8Agqh8WtLsbC38bfBbQfEN /FZ3g1PVPDHiyTTo5pmdjatHbyQTFAqeWr5lfcQSNoOwe5eF/wDgqt8KprOxXxd4D+K2i6pb+Ho5 NXhstAtdSjk1DJE0UM63ERZQNjKzwxbvmyqYG78Lk8NfEaxkgFj48u7iztNPl22eqaZazeYwIwZJ DH5jEZP8f1qX7R8YdNXy9vg3Wh9pDTTXWizRTMjH7ilJgo78lSa76Of55h17taa9dThqZRk+ItH2 UL+Wh/SB4X/4KM/sq+JGEV745vPBV3JqElvBaeNfDF7ZjCw+YZHn8poY0OGQF5AS4245Xd734e/a Q/Z+8VfZv7A+M3w21N7+ztZrS2j8aWguHW5lWKFRAZBIrtI6JsZQwZlBGSBX8nGq+PPGGi2BvdU+ Gem6gs+qW9tCun+ImhZVlnWME7oW3EFgeCOlF5rOl3gafU/hn4htfKkYkxW9vMzKB1TbJ/eKgbu2 a9ihx5ndG3vRmvNNP8Dz6vCOVVH7qlG/Z3P7KbW+sb2FLmyu7W6t5GZUuLecMjMGKnDezAg+9Toy OokQq8TqSjocr9T/AI/Wv43/AA/4g8I+EdXvdV8K6z40+Huty6JJYajqWhWuoaXcSWc65ltWmgA8 yNwfmQMynJzXtOg/tPfFXTNUk1bQv2s/G/8AaV5oU1iIvFfxFOqeXbTMGci3vmk2SZUbZCokTnYV LNn1aHiRXduegn6SX6o8qrwRR+zVt6xZ/V0RnIIOB1Ge3v6U3YV6hhzjf0z19a/nU0L9vD9sC3Ca rY/EfwT4302WyMdvHq3gq2a1aQ7AJg9mYmLL5bYAbYd7EqcDb6Npf/BRr476Z4jtfEfiP4badrth DaNFPofhrxxLptjcSsAvnTRz2tyfl+chYmhBOzJG1t3q0vELASS56c4/JP8AU4avBmNTvGcX8/8A gfqfvIVJzntjBI/z60hTs2Tg/eBr8tPDf/BVf4Y3UwsfGPwk+Kvhua5v1jt7/SY7PU7GK3L4M1w3 npKp2YbZHFIdx2gn71e0+G/+Cjf7J2toI9W8f3/g+/kikkGn+JPBGpx+XGihj5lwtsYd3JXajuSw woIIavSocdcP13b2tn5po86pwnnFN/BdeVmfb4QE8ggZz8wpzbeVKgY6GvDfCv7Un7N3jYf8Ur8c /hbqsjvL5doPGNvBcYjLbyYJWWRR+7bG5QSMNjaVJ9ximguY47iCaK4gufL8meFg0b787ArDgsdp 4z2r28PnmV4n+HVi/mjy62U5hh/jg18hpUEHHZeRSbTkDJzjgfSrHl7C3BDEfMrLg+/FJyehTGdo YD36/nj9a7liYtHI6DW5VdiCvy53NgAduOv6UFOQHAAPYV87ePP2sfgH8O/HcngDxj8UPB/h3xFp Dw/8JDp+qarHG9p59v5sKMC2fMKSQSFQDiOVGOAwNfRkM0F7Bb3drPFcW9xAslvNC4ZXQjIZWHVT kciphioTZUsNOEVJrQiZSASAOfQUwpxkDkjsKtFMZPODjJpmB1xnHQVt7a6MvZXZQlhLZG3k9cCq MkCsSMEhenNbTKcfdPPr7VEYlORtK5POF/z6U1iNRewSMCSxyAoUE9+fSlTT1U/d4x0Ird8vGePY bl/z6UAKfUZK/MKv6wHsVcoLAqABBnOegpdmMHaNxx3qyQNo43ED5selN2hlU5xz0VqlYjUfsWVS vJGASOy0wqAc5zz0z71aAOWGV4PLZqFvkJ+XkjqD6UniLgqRBs2kEKSSaaVzklcj2qdty4yRvz/E O3+c009MkHk4wR6UvrFxqiyttGDyoUKSSe1Yb6vZrOtsp3MW+aQtwOayfEmrTQiSBVMcKryF/i4r yK98QC3uYpC7dcEJ9a+ZzHiiOFrezj03P1bhfwvxWdYV1qnVaJH0PhW2vwFP3QDUbAY+YryTyT6/ /rrD8O6qNQtFywYBV+YH16fn/jU6+IvDT3senjxBoj3013Nbx2SatF5xmi5ljEYbcXTDEjHGDnoa +hwuYUsTRUr7n5zmeTYrK8dOhUj70T8Ov+C1Pxc13wLbfAnwZ4Wk1lPEHjbR/GVrp02jRFmstYvY bKw0O4dukf8Ap98mGbssmOleD/ET/gp7r/w3+E+pfs+eBtB0fUbaK0jsvCupXamOHSEZAjrHCpwx CIgAPAwOuAK3P+C8nwtkHjX9jT48WXiCct4c+IzaTrHgWa7kaG6jgBv4L5LdRtxCYp1lkb/nrAOl fzjfFjxxLo/gjxd4kub24i1O6sJo9MlFwUm+1XGVR1PXcC5bPX5TjFfhPjBUxOYcQYKlf3Iq9u7b sf0L4M/VMv4WxlaS1uvlZH5va5qkWqeJde1C2jeK3v8AWLqeCEtnaryMyrnvgMPatjS9evbaN9PW Z/JM7SxruP3yvPPvtX8VHSuI08ZMpYE4XJKivpH9kL4baD8Zv2sf2avg/wCLG1GLwv8AFP4/+D/D fiSfSblYbtbDUtWtrWcwOysFk8ud9rEEA4JB6H9By6vXwmHgovXY/MMaqWKxM5SWl7n9HP8AwQ/+ K3xR+Cmpal4L+InjC1vPBHia3Mtj4Ks7a41K8e6bLfaGn3rHbiKNQCAr7wxBYYUr/WbY3dnqlna6 jp1xHd2d3Gr21zbuGV1I4I9/rX8ofwo+FWvfsa/t/fFP9nbSfjlZTeEfDHwea9k8b6npiWmqLa3i W1wljsJaMXAR4S0q4BXcwVMlR+2f/BMvWfGnib4MeOtb1/xPqXifwpP8YNXi+G8+q3BuJRpsaxec 6zE/Mj3TXGFxwVc5O7jzeG+L+IJ8V1cuxiTSV1bp/n89T0+K+EMijwtTzLCyaeid/tX8uj/A/RHy g3UMqk8D/H9aaU254GCvX8KvBMDIHBbkE1GfmChVA+YfN9a/VY4i5+Puiykykgblwc8qW9e1RlSQ cF9xHPp9f51dZNzNxnnH4U0xnLY5LH7uPeq+s6CVB3KBVdpA3ckcMv8AWo2TLFTye+KvEAcEE8nJ Y8fSoSnDjADHbjBqFXuyvYOxT2DkhTkrwd1MZSBgAEEfr6VeVehA/eHlgp/OoyCMj+Fs5JH860WJ aEqBQ2HOccDsKrlTxkHOPy4rSKYxwAB0IFRbBllPXHXFS8RqCouxn7SckAf7XH61G8ZGG2n6Y960 CgBBIJOPyqKUYBKA89c9+apYjUHRsUDGQcqvcltxqNkPIwVfHFaBB/H5t3NVxGpwQCAvHyfrVOvK 4vY3RWCnklccjLY5qAxnO35j64P8qv7ckYJHpkfl/Ko9mF4z8y80liLFexuUCmc9QNvzBfwqF4u4 IJB5yPvfSr5DHbjpt6Eds9B+dQlMbV44PVR0q1WsEqV0UWTJbjoO9RsqnzD8pG7IVTt+vFXWQjdj liP3gAP+fSoWX5W4JZRgEqPX/wDUa3jiWYujZFJxlRgHd/C3T8v1qJkIOPu5+6N5+UdzirpUc8Hg cZFNcAEOQBj7h3VpGukiJUHcznTcw+6QP4tnP1zTSu0ljxtTllHFLf3tpplrdahqN5aafY2UDy3t 5fyrHDDGoyzu7EBVAHJPSvlX4kftX+GPDa6XZfDzw/q3xP1jX9TksbLUNHP2bRbedIZZCbi9YfMN sD4MCSgnALJkGubF5xg8vhzVZqJvhcrxeOl+6g5H1E6HYxzhT2zz759PpXzb8SP2oPhl4Gmm0fSb m5+IHi/LLbeGvBai62ybTj7Rc58mFAQobLGQbsqjYr4r+Lfj/wAZ6zaG6+P/AMUYPAvhTUIVmsfh 14WaWwW8idWUr5EW671FSrn5AZIztVhGGANed+D5vF3j67t/DHwB+FWoWFtDdRLF4s8YaYYlkZz8 rwaejeYyMmf+PhoGDAgpgHPxWY8dbxwy/wC3pfpHf77I+qwHCCXvYjXyX6v/AC+87H41fEb4/fEX wp4jvrvxinwl8Mi0byNC8H33kSrGT8v2zU2XzDwwDeX5SsF5XBIP58/Gyb4X33gLwSnwykGspofj Sxl1nxBp1jJJZymW3mjwLwrtnfcMkozAd8cZ/Yzwx/wS1+JvxGuLLVfjr4lm8Qy6fcmbT7PxbfrJ Z2sy7hG8Gmw7YI3KyyL5gXeBkFj243/gpX+yX4E/Z0/ZM8L6vo15cahrs3xe0CzadoFhhht2t7p2 CIq85eNcZycdTnJr89zDM62ZYhOUnOX953+5LRH6Nw3hsNhcZCnGNk7/AA6dHu9W/mfHXwi0GLxR rvgDRZUVxqnjLSbY5O3Kzb42wPowr6Vv/h14U+y2hTR4S7XE5kZC3+xj8OteBfs0yySeOPhnfRlp rTT/ABvoslzPEMpGRcIrbj0UqGOR/OvrO91/wdpssllrHi/w7p08d1ceVFqGuwQsU81gCA0g7KK+ vr46nCMY89lbv1Ph4ZRiqzdqbav2Z+ZXxICP8MfHkU2Uhk8JawjkcqFNvN3+hNd3Yg/ZbEKQAunr yfouBXn/AMTVlPwu8ciIZkbwtq6xjb/et5e34ivQrBNtvZAnJFioJ+oWvhFG59n7SX1X5/oT24UG HDKSYGwB2ztoPMsJyMi2yOev3elLakB4CcH91zj6r/hQpHmR9FzBg/T5e3pxUuDMlr1K0o3QkbR5 f2DnjuMf4GuU+Hyr/YsHlFcSeIdUkw0f966nOfx/rXVKVW2kG4ZFiuAPcf44rmvh6Nug6cQu0yaj dZUk/KpkkIP48H8fxPNOLcjojNqlLQ7TYrAYUjdZSYUjuCKsPCjSSK3HMXLeu/n+tMRSzkYcH7PJ kbeuSPeuo0zwn4q8Rs40Hw7r+vFXj3/2To8twVXfjpGCex/zxVww9Sq7RV35HPOtGnZydvU838TW kcumRN5RcJ4h01lX7q7l1KHp6cZrqWs7fypflVV8uYfKOmWHP6V6jqH7NP7ROs6LFJpPwO+K99b/ ANu2Zne28AXpCxLdRyM5/d52hYyd3T+Vb1h+zr8ctTnubW1+FXjh5YBMswm0GSFFkGMqXkAXdyPl zntiuHBVMJmNWcKElUlD4lHVr1S2O7Fwq4OhTlVXKn30ueGS6bZvvYwxkNddQg/55f5/KvPPGnhH QZtD50q2ffqunB2KDOHuEB/Qn9a+3tJ/ZN/aF1uKSex+F3iCJUkZimrPDYyNhCpxHM6MTkcDGSDw DV21/YV/aS8e2f8AY+keCI7HVl1HT5hp2p6tEs6xRzqWd0VmMagK3+s254xnNdNfBKFB1KkLQju2 rJLzb0RyUcXB1VGMvelt3Z8R3fwt8GPI00eiWUUyRzCGe0Ty5FyVJwy4I9/XvVYfC6HTooYtB1zx JocKTzSRWtjrsywBy4zmPdtOSTkEEe1fqzY/8Ezv2mrnTrzU9YtvAPguGyE3np4t8YBT5e7Hmb7a KZFXC5+ZgcMOOuPEZ/2WviPDqN7YXF34TVbC8mjF9HrDPDLhsrJGVjJ2tg43bT6gVx8H5fR4/qVY 5HH606ekvZe8ovs3HRP5mfE2f4TgunCpm1eOHjU+H2klG/om7n5zXOieONM8V6Bodh491OS2vNJ1 i+ul1TTre63SQS2qRoWaPeF/fv8AdYdfpjqDofxIhIhfVvBuoQG9ZrqXUfDMnmm3LsvlIY5lCnG3 5ird+DX2tH+yF40m8X6Vq+reJfB+maZp3h7U7SZoLqa4m8y6kt5EKIYlBULA+7LAg7cBhyOst/2X dRBubfxB458M6XbyFvIudJikvsx7t3zCTySG9QM/XNfodDwW8R8TblwFXXuv89vmfB4nxt8M8Nfn zOjdb2kn+W/yPwb+M1l8e/AOr6DdaLqvw/1PQvGXxA0nQ9J0fxH4em/0CS+kjiiY3KS5kRXcsTsU gHHJxXrul+GP2y/h9Bd6xpWm/DK+1OwVbiKH4e/FLVtBu7i4iLFDEJLXZvXYCGkkGCwweOP03+JX 7F3hDxnP4Us9b+N2h6Lp/hT4g6Lr32i106Fp7xtPnEixAtc7Y97RqN/z8bgBnBr1J/hl8GtLmnOt fHTwibOZm2RR6va2c8S5YBZGaV1J5zkAdcYBzXv4HwE8UcVGKeBdn/M4L79TwsZ9IjwlwcG/7Sjd dIqbv6WWp+Xlh+2f/wAFCPAGkodR8P8A7RNrHoOnMbqOy8f6R4wiWFkZTGn2i6aWRVG7CBSFxnAr vP2fP+Cu/wC0xZWV7PcePPEnxI0HR7qSwtYPGfwck1KHzHRWHnXdjbrM1wkkpG0y4Cogxjr946zp f7ItvFIb39oDwtBI8jLd2tx8QNM3bTkNjAzzuYe3GK8J+GXw1/4J1/A3w9quieFv2j9IFrq/iiTU tQ/t/wCI+m3czTTIiMkZht0CIFiXrk/MSSRXtw+j34q0IOUaUYar/l4l+TPJf0lPCPE+7KtObt0p Sfy+Hc+e/jX+2N8A/wBpTxh4Y+IXx28LeCn8feH9Cs7C4vvDHjxvCMV8tveyT+TeW17aXXDRTeRt f94o5BxtC/r34E/4K/8Awf8AEUemxXPgDXmSeO1ikTwB4j07Wo1Zhhim+aBiinaFAXLA5+Xbg/Gm rfEf/gnL9gisdT+OOixSWcgEmp6PrYuppSF25K/ZpEz8q8qq9Bj38KPiH/gkLot/c+I7HVtBg8cL f/aNO8d+HdNvrfVrWYKFYRLHCsJDgNuEkTg7m6DAHrYXwE8V6U2/b0o+cqid/wDyVnk4n6Q3hZVg v9mxEl/doy/zR+8/h7/goN+zVrCRPqXiXW/CFzOAZLDxL4SvI3t1C/N5skcTxZDcYSRt3GOcge5+ Hf2ifgb4tisJtB+LHgDUJNTWNrSxTxRbC7w+doe3L+ZGx2nCOqtnA25Ir+ea0/bV/wCCb3hq1jsP 7b8Q+I1t4vLe91/Q7+8uLj7x3uzbV3fNjCIq9MAVgXH7fX/BOS1QR6V4K8T6ykaqCsvgB7hWdsMx CzzkcEYDEg4zgAEivco+DnHtGSWIx2EXe83p9yR5Nbxs4RxFOUsPleOk+n7pa/ez+o+11Kxv1za3 dtcEj5kgkVmX/ZYZyrZIBU4I6EVbZs9SRn+Hnt1wf61/Ldp3/BUD9j/wi8U3gT4L+O9Hu7Kdbi3v 9A8A6dpkySqVAdZI7kNkiKIcnkKAeABXbf8AD5bSpoXHh/4U/G7UYJE2+Ze6pZ2YcYONp+0Me/GK 714a1MLG+KzTCx9Kn/A/ruc68UMTipWwuS4yWnWnFa/ef0qlzgjcAyp1GdtRPcwRusTzRRySD5UM gz+Ar+Yaf/grt4hjZzpPwA8etCfvvqnxLt7dmYHjJEZ68dz1H1rzDVf+Cu/jb7TJNB+zzfR3hJ82 41P4lRSMWx3Cx55/GumjwPwpUl72d0bf3fe1+85aniBxsoL2eQV7/wB6UY6H9YF1qFjYxGa8vLOz hVhma5uFRcn3J4qudV0xYDc/2hYC0UE+et0nl7fXdnFfyMap/wAFePixOi7PgToSmMMY/wC0vGFx MVyMZyEXH3V6Vws3/BX34/xvLFF8JvhdFztEeo3OoPt+X/ZlX3rqXAvBqgr5zBvypyf6mUeO/EOd R8uQyS/vVoL9Gf2EW3i/wpfGQ23iPR5VXqUvl78evPfpXzj8Zf23v2Wf2f8AXNJ8OfFn4waD4Y1v XIlms9NWyutQkWBm2iSUW0Mnlx5VsM+AdpxnBx/LKv8AwVo/acSWWSz8DfBi3LDbDEdJvpFX0xm5 /nXy3+1l+018Wv2hZoYviN8Ivgz4U8Z22rWb6j4v8AeHDb6teR2dvLbC3uLk3D71/exbl65t4ueM t5eYcN8I0MRCnhcbKtKXTlUbeeu59Fw/nnG+OjKWYYGOHjFfz89/LRafef3l+FvFHhrxv4b0jxZ4 O1/SPE/hrXrFLjRdd0TUEubO6t2+68UqEhlPPTuCDg1uMScn25A5yM//AFjX8Lf/AATu/wCCmHxP /Yu8Z6z4W1/Tta8c/Ax9RiXxp4Ge92tp88sayC/0tn+VJhG674ztSYYVtjbJE/uG8B+JvC3xN8Oe F/FPgjxP4b1nQ/Gnhq11jwzeQ67BHJeabcgmCdIXcOFba+NwB+V8/dbHwueYR5JV9+ScG9JdP+HP v8BKeOh7sXft1IPEGnC8t3KIC3zcD1zx/SvyO/an/a3+HvwB+JmofC7xZYaprPibQYbG41bwfpWv WdreTLdCVbeNVa+hl3rPbtDJbgpOC0ZAxJEJvln9qv8A4Kr/ALSnhn4jfta/s3eAfCHw/wBG8afD /wAexeFfhB4v8L+KAuozX11dSRw3Et3JdfZoGijiJaTKeVLwxjZcV+Ini2Dxz4m+IX7O+sfET9m3 xIp0Hx3pTfErwX8GPAl7cazrHh+a536rDqGoaksx1LULhbDzFV1ltUa8dXPzeVH8PjstpZliPaRi 5Rj8VlJr58p+r5BxlnnC2VvDQqqnKp8LvFP/ALd5tL/kfut8CP2ur3x94N+L3hTwDpXh6++Mnw21 +O11jV9VvmN7qB+1GKTVYAZpmVbSP7JKJ2Yuq2pLps2MfsL4g/tReFPD/gHTlk8KfAH4q2Sf8IjJ r3gu8d7aWSy1W3E9oyw3KRwyjbG04eO5zGEUHBIkH4L+IdX+E/jey1jxJ8PfiFoXwV1ic+Kb69j8 PX8VjHqvglrq1WxuVO4fZ777HdySzwQwZMcbNHu2iIfmR+098dfifaeF/iV4C0W/Ot/Djwd440A2 d9J4nXULG1kttIi0+xk08TEyyE2llYo+48KsIeJWQEepQoYZZHWr4eolGKWjjNS1drq7enrY+azX McXmWb0Y4qLdWV7z5oyTsr6pJa+l0fuf+3h8XvFVz8JdN8B/tMeEn1L9qb4N/FLxtpOj+AtG1iMX lhoVzp9rGs1zM5aOTH2i2ceXcTrOYVdZ3HA/l7/aB1Xxb4iTRivhbxFpPhS2Mrf8TC1+Z7oNtZpB GWCgDAXd/eY19pfBH9p/VPiN8E/F9r4p8q+8dfDSDVNWuvEGrzzXd3qX9o+XHdT75WYec0dvCrY/ hgBGMAD84r34t/EvXtRllstc1y2tjcyfYdPsGJ2LISdvyjLdfzPFfnmZRnmeeUalOPN7OCV2+v3f ofe5dVpZbwvUpzqOKqzbso7pfPb0Z5jayMkmNvI/1keeeevFfSH7KXxA0/4SftTfs5fFLWHig0b4 b/Hjwf4g1Sa5U+Wtrp+q29xKzewWE5rx+Twn4z1e6nvrvw/4iu7q7lL3N1LYymRmY8sTjqeaZeeF fEtgpgu9N1m2Mabtl1ZNwv48j65/WvssPF06Ou6PiKjhOs+V6M/dLx98RPFX7Wf7cfxb8YfCOPUv FOs/GT4hXmm/Da209FSS90hj9ksQQ5CqjWkUTMzlQgJZmABav7Pf2YPgvb/s8fAT4a/B+G5gvrrw h4eVdbv7YsY7jVJ3ee+lQsoby2uJ5iu75gm0EAiv5C/+CJvxy+Bfwc+Nx8Q/GbVvD3hDUtQ8HXWn +F/EGoadc3skc6eSWWIqpFqLiObAlIZ5DE0UewO/mf21jjuegx/n/PXmuDhrA2x1THVHepLReSPS 4uzSpUy+jgacbUo6t93/AMAfu4JGOneozkjAGeBj60pJxncATTc5IbK8Nlsjr34r7RYhtn526KsN fAHAHK8hjTGDKQSpyOh6j86lyQGAYuoAwfX/ADiomK45HzBeM5pqvruP2GhECTuPXcTyRTfmBA6s Svyk+/WrHy43DuOeajz1K/eGMZFP6whKhZlUqGQtk7sfKS1MxhcucZHf3/yKnfK/KMAN8tRkthgF 3E/eOaca7aB0Y3ISMcjnJ5yKiPBI29Txk1ZIXBBBGDz81RMzLxtyB1GKf1lJh7HQgxgnGGHQgHn/ ADxSbCTnOMdQ38qm4GDtOcfMFOfyNROACD0AHHBq1iGyZUCuysNw288fNUe3Izkjnk/5/Cp8nkDn vk+1M9Qc4Yj5a0+sMj2GpXYHacKDk+tQFSoXCk4xzvxjAq22AG7nHXH5VA4LHJOST6e9NYhFfV7E DjjByPVh2qLbjPHB6j0/zmrDAj+IcZxgVGxVSpz97jDULE2G8PqVmCnduB4PTGf89qrzvHDG7yOq Rxp8xkYBQo6k54ArI8U+KtC8H6adW8QXctrYtcLDGbewluJGkIJCpHErOxwrHgHoa+OvF/7TEuo6 rJ4euPBt5o/hPVdOuI2gf4gQaR4r1KGSJ082w2Rzx2oSZX/eN529VIxE/TnxecYPAxvUlr2/4B0Y XKsTi5e7HTv0PrzxB4h0DwvplzrniPWNN0LSLUr5+o6perDCoPT5m4ySeB1PGK+T/HX7UUohuU+G fh831jBEz3njjxVFLa6fHCo3F4LXiac8Nw/kgcHLg4r5Z+G/wV/aG+Mvju9s7Lwn4x1e5tI7VtN8 W/GbX5L+w0mzhHlJ9lX5RI0yRq7yAxZkZiEK4r9O/h9/wTn8OCW21P4y+LL/AMc3qLui0Wz/ANH0 6I8fKI8AcMowwUNx16V8fj+NnOnai+X8/wDgH0WG4Zo0Zr2nvP8AA/FC88Y/tKfHHx3o1v4e+Eni vUbfxFqEdp4T+JXxsZGWG48p599p4XtSqRxbYG/1s8Mm4xu6NhlqLxj+zd+0l4X/AOCg3wa+COvf tA+LtRuPGv7P8uuW1lBex2ml6fqkuqNYt5FrBCkMTrbs6CVI96CRsPkkn+pTxFY6ZpLeG3jsrS3W 08XW0cTJbBSDLFLEOQOv7wCvzy8X+CtE1/8A4K9fB/VdZtJJzpv7DWuXmhnzSvl39p4psSre5CTv ke9fn8swq4iq5ybbs9W7s+7y7CQakrfZlZelix8M/wDglz8NPDc0+vePNav/ABX4j1O6WTWb8TPJ NdTO67mlupSZpG9ya/RXwX8NfBXw309bDwb4b03RxLbRQ3E9pbqJpkjVtnmv1ZuWOT3JPU127uRb QsRy5UDPTqM9foD+FI67DE5Zgi7jtI6Z6DPT+KuaWIqVN2eZFPmuyJixmeIFxiXIBb1PYdPT8q/H r/guPoNnr37F9jY6iglt2+M3hxJYG6MJLa7Xaf8AvsH8K/YeYrv7b3dsbj/01C4+vIr8mf8Agtpa zy/sV3l7A2xtJ+L/AIPllBP8Bn8s/n5uK2wF54yOp35XNUsfCXb/ACP5r/hv8CvhBo174N1DUfAO garZxarYyahp2paat1BcRrIGdJYpAVdTzkEV1o+AfwvaSdk8A+GJWaZiwl0eFtvPAGV4HXgV3Xg+ IXel6G6IzSJ9iYBP7xkVen0b9a+1G+BWi2moapY3Wo6l59jfSwyojp8rxyOjH7vcoa/UaWEyujTj KUY3t2Ph6maZxKs+WrKyb6s+DviVfpa/DfxfNJKiRw6NerPI5wqgxP6+oNehWM0LxWPlyRkyacrL +8B+XC4P06V5z8TNp+HXicY3E6TdY79Vbj9cV6PaosaWyhfkFguCQfb/AOtXxULczPpeZfVfmTw4 Jt2X5Va3JIHoCOev0qRDlo+222OTw23p36VWtwF8glEIW0bLMPmCkLx+JxT1jjxahY4wFgYqqgfK /HP5E/maicVJGKd92V7iWOG0uZ5P3Yj07fKfRQMnI9sfoa+XNN+P9v4Ts9N0qw8GjXf7OC7r3VfE Zs45mJfePKjhZtp3DBMitwdyqSQPqCSKH7O6bYh/oXYY+8eeOnJNfFep/B3X9S0TR/Ffh6VdSi1X TY5rrToQVmjkZCzbFC4ZcjgZ3cgYPWvX4er5dh8X++pxm+nNe34fqeXntHMa2FtSk4rry2v/AMD5 Ht0H7cXj3Srf7JoPwF/Z1a0SQGM+IdBu9Vul5J+aS4mbrk8A9MDAAGPs74Pf8FhvjR4I0e20jTfh 38DvDviNINtxqsvhu6PmN2EbG4xGgG0bBhfx6/jPdaXf2UkkFz5ttLAcSw3C7WVsjqp/lVN7J5Fx LcY2D77pnkfh/KvQ8TMpqeJvCksnq1nhqL1/cfum7bKXJy88fJux4HA9TCcEcRLM/YrEVbW/fN1L ecedtRfmkft98VP+Cqn7cvjhdLOma18MtN0i0uGk1XRLLwg6pqHHG93nJYDrtPymvGX/AOCon7a1 zcPAnxA8NaNcRDDWC/Di0R4xjjlg3APRhkdK/MjRPEfiTw4I1s9RS9slGfsV0xkQ9/qua9QtfFvg /wAWwR2GteVpl63+rW8l+Xd2aOXt1Hoa/nfLMBxz4PZLDLVRVbLad7Tope0V9b1FvJ/3m2/7x+51 5cD+IuYSxVGp7DGzteFR+47dIPZei/8AAT651T/gpF+3FcvcI/xv/s4ujL/xLvBGlKy59C1sTxnN UPBf/BSH9tHwPobaDL8dvFk9lLqE1zeaxa6PY/a5ppG3M8+LfcxxhRjOFUDAwK+KvF3h7xDptjcS eHtRh1gCJmgsb5x5zEDhUk4DH034/wB6vHfCHiLxOIL0eIkt4bj7bcfZ9OuopLe4SFZGVWMbZ+8E VsgkfNjtXo5ti+HfFHhmpluIre2w0mpShdqSa2bW915px9Tgw2WZxwDnsMZ7BU6sU0pNKUWnuk3d a+Vn6H6Y/Ef9r/8Aal+NXhSXQtT/AGnfi0NNuLhZhJoHio2amRM4DeQqkgHJ2nGDg8GvhvxX4t/a L0/cNY+Nnxl1WwR18q9PxGvmhbPZh5ny9OjD6ZrHt9esIJ2urDUJdJvyF8wgbVY+jr0bp3/Cuqg+ I1tHsg16ONYyh/4mlqC9u3PPmD70ZOPcepFeTwJm3ih4BYN4Th2o6uVuTm6MXyTTe7VrXfmr+iPR 4o4d8L/GSuq2dUYUcekoqo4qUGui1W33erPG7nxd4/uQftnxJ+JN+Hjw63nj+/k4YYbIabvkj6Gs KS51K4h+y3Gs+ILi381pBbXfiG5kRXbaCcGQ8kKoz7CvbNY8H6FrMYvdDuLXT5ZkBXypA9rJnoeP u/h+VeCeIjeeG5xBrFtLaMP9TKI9yFe21xwelf01wX4+x4+goUcbUjXW9OU5KafpfX5H4bxb4IUu CqvNUwVOVF7VIwi4v8NPRlFtD06aTLW25m5ZpZ2Zt3HOSc1YTQ9GlB36fYyjGButlY8DHAI9K5uP xfYFwpnBYLtMhHzf8CFWk8X6Yrq4mCH+8g9un6V97PPM9qu0q8//AAKX+Z8hTyfKKfw0YJf4V/kd EPDWhqrBtM094xj5mtFZdpHIPHuatweHNEtZPMtrGwgbyzsMFiiNyTnt6AVi2viKa9YJY2d5eSKQ v+iQGTr0zgfhzVe68V3VhBJNJpkyFX2H7UrRx+Z12k9B908fpkVwzx+bVV71WTfq/wDM7YYHBU4+ 7TSXodDP9gsIJJL57aJVXc9y0e2PjGef4ee1eXah4nm8Q3D2XhqGa4hikZZNRYbY155KnHPWvNZv EWpaprM4+JtzD/Yc0MK6Pa6IJVsUmPMhuWwTnI4LEL835el2PiWx02GO1sILOKwhT9ylswx7c9/x pUMbNTfNdy+ZpLCqytoiSy8HQyM01+xurtvvNKny7jjp7ckVvxaNbROAtsoCk4VVxtH+H+NXLfVh eKG2Rt+96lxx6Y9O9XWklIJJA9dp6DH+NFTH1W/eehVPB04r3Qgs2QgYUxlvvdF46e3rXeaPJJAq qrjanAiHT2xXDxzuMAbQFRcDs2Otb+nzsZEff8isvy5/z6V4mYynVp+R6uBpqn11PVbe8gkGyaJ2 kA5DSHdj2/Cub17S7eX/AEi3iRXI+YH6/wD16LQPdfckMcjFcSI+PTgjH1rUuLW8eIMYlxs+Yu/T 68e459q+Po1XhcQuVn0cqbxFL3lqeQ3diI/MYn5gOWHzHgda5m9VGyJ0yFTCTbfmVf6jP8zXqWv6 PdWMqrOImaaNJAttcLKNrjIwykjIzgg8gggjPFedaguwbm+dS/zY+br719pgcyVaOh4GYZbUwdV0 6kXGS6PRnLS4gwu1VJHG0jv0INYeoxzfPJDK0bLLujw33ZB91h269jkdsHpXRTAOpQLzkbCRgrj0 P51myqjDkZwPnyevr+ea9ijjLNST1R5MsI+XbRnzX8QvGviLQbiK1vbe2fS3uFdzEfJS5RTnazcl Djjn6j1r9Qf2c/8Agvf8X/gPott4Ss/hB4D8TadpPhGz8P8AhzVtasTeaxp9pGbgQ2VpcuCiW/l3 l0mwxkkEbmc7i355/FiBo9E2TeHLLVNLlbGoalcXjxNp7dpiixMxRTjJXPfIxmvMbb4M+HvDOt+G 7W+8Uyw+KF1Gz1TTbiCzS60e8DxxTW0JY7GVsMTk58xWwApGW+Z4lx+JzfM6EZXly/Z6XfW1z6HI qFHL8BVcbR5vv9Ez9B7P40/Cj4/ax8TviP48vNI+EvjfxR4w1XUPGOkXnxPvVj1C5vNr3VzFDO+C rnChVXcNuMcjP55+I/E+m6Lrs0Xg3xJca5pd1p88dhr2i6vdwxrDNB5dwkkMkcb/AHZXidGBR/3i q0iNubm/HXhm/wDCunDwdaXB8RXN9/xMdRCWrbbW1B2sxTcwVnZYvnGGxGAeKs+HfHmmeG/jT4Z8 deGPh14cvfD2i6zpWoXHwz8YXDXljfCzWOS8tbnYEb7NNJFIxjHRGC5Yrk/V57x/isPlscLQwyp8 ukpxuvaaWtJLy9Tyck4JVbMauIqYuVSMtY05Wfs7u7cW/PzR2Pw0+IepfBvxrpGu32m2XiPQ9Zso ofEfg7XpRdQXmlrIu+3kMgIVXMOcYzjAPXB2PitZ+K/G8Mq+EvAd1F4ci8Px2cvivw1HII9Q0uxC tB9qKqLeJVXyC0fy4ezAOHUGtTxj8VvGHi/xzr/xK0XS9CstT8Z+D76x8Q+FfDkFldRjS7mBQwS1 t4VWBjJA8jAKjqu1sYO5vKNH8M6tbfCXxzLrGharZ6tb32mSRXN+Z4QsM7TGRlj27ZGPkRoM4P7w 84LCvznNasauXQdOLUpfzSctOt1bS3Q+2yzDUYZnP27vGP8AKkteltba9T6p/Yo+F48Z3vjb4caj 448M6N4Vk8ONqUmpaRocrT3erT2t5Dp1veXMkKmOAL5jbJikIEwO4SNta1b+E7XQLmbSLG3Gk/2b MwWD7MpXng+YqsMHCjofXtX7D/srRfCjwl+wRonxF+G9t4csNe1Lw7Do/wAYdb1fSP8ASry7tYJT NDAqvEkpit5ljhaNy0s9xsn8r57iD8tfjJ4hmu/ib4w1eazv7UXWoSR3cMun+TNH5Xyh5IV6My8k jvg9DkZZLKnUpOdRa9GcmbVaiqqnGXu3vbzOCnkuEkPy6bK6ghnZducei7fb1NPD6zdT/Zre6hF0 LCHZcLaDyd55Clf4l9R6fUCuG8Q+JIrPTTqOkpd3V82pQwxpNYtHGkmS2WLY+Uqh49fY5rs/hpLr V5qdlc3unM9pZ3cEmou8wLOu9eFwevI/3RkgZxi8Tn2Jop8t1G2pWV5L9exdOmtZSdkf1SfBf9hf 9lHwTP8AB34r+MND1a/+LfhXS9J1LxJo6+JT/YDa5FEkiobRVAaK2uPM8sZAIAVw0e2Mfp3P8dH1 h1itJPMKuwBjb1r8MPgp8XZviRc2di3iq11HXbuHfBobStDdSLgsTHC4DOuI3OVB4Uk9q/R7wTZa lbrD9psryHJ+bfCVwx/yOtefgsweI/eU+p+i5xwzgcrtSqTUnHofoH4F8Q3OqvdC6kLKV3Ku7vn/ AOvXonmANkZJwuQa8I+GDSbpAwK4tudxz3H9a9n889u3Vs19Vhq0pUddz8nzLDQp4txWxc35BIyB jjP0pDKcd8455xVMSk5+90Gf60wuW3kcjHBANdHtdTh9mXN6kjcML1OKTzM98HuPr6VRE25hyMg9 AeD/AJ5oMjDdgYO0Yw3+fal7TUPZGgzMRuwSVftjiot3B+9yOeKoed8owwLKeFFNMjE5+bGOxqlU aQvZIvyE85JK5+lRMwyQSRxxVN5G+cZJPao2kcd931qlPQt0kkXfMKgKccdxTS44yR0GazzICW/C gvnnpjtinGdupDpsstIDn5QCG6g00vuwNuSOmDVN3YnGPvNzgVEHPPJGeq1rGpcXsrIuu4AG4dSO /eoGYEegHQ1WLh22g72XjaD93/I9cV4z8R/izF4cjvfD3g+2j8Y/ER41XT/CunFriRJHB2mWKP8A eO20FhCg8xwpP7uIPPHM8RSo0nKbskOnh6lSSjFHtq7ncRBHZz9xFUls56YryfxX8bvg94GWU+M/ ij8PfDcsEUjvaax4utobgoj7HKQtJvYq52kKpwcjtX5jftD/ALKPxV8QfGWws/i38UfG0snin4RW fibUvAzayLe10uRNWktVt1EBaMkqIpNseAjO4BJAkbU0v9gH4B6Dd39vqekWGrwW/wDakAu/FU73 ECSwXEawyu9wzgDLhskZGK+bq8X4aF+WN13bPp4cMUoKPtKj5pW0jH9bn1pb/Gr9jX9rXxnpH7Le qeMNO+I7+Or2dbnw5Y6NdSWN0LKF7p0kneHyJIykD55dT0zuxX1F+wP+yd8HvhX8BvhVrFh4A8Np 4vPheNJ9ZFu0zbVkbyiiv8scgjCKxRVJO7k9a+Lv2fJ/2fPhh+0X4F0izv8AwV4Svze31xaalJ4g tfIihlt2gWKV4mKK7NtAbcw/fIC2DuH66/s4jy/g/wCHLfAi+wX+sWyAAr8kOo3Ea/UbUHPevhM0 4gWeYnmpvRaaH1EMilkmBcXGSvZ62/Q9KFwlv4stNKVY1W80K7uN+Bu/dSwqf/R4/M10+PmUDOM/ dHfryf0rmJ9OkbxppOqqcR2fhzU7dohEfmaWe0YHPQEeQeO+72rqRweOMNhif5/yrz4pXOB6HkXj /IWxuGMo+weNNBkVI0X5hNeeRhvb98D9VFfG3j62az/4KXfs36sFVW1j9mbxrpxI+9iK+tJsfoDX 2h4/jV9OZvTxX4bYk+2rwEV8afGeRrP/AIKGfsPsy7Tqnw8+JlqGJz8yWVvLg9v+Wf8AOnDl19Ge xlcp+3Vuz/I/Qrafs0SNvBjij3lQen19+OKknCMF6n5U/h55K5/mahkHl27MuF+T5VznoDjNJO6t HIu7oY+c9Msv/wBelFXR4rd/UftJi81hz5yruxzzKpyPyFflv/wWStmuf2BvilMUBe18a+E7gJu3 bdmq2qn/AND6e5r9Sw6x2nBzkoVAHP3v/r1+Wf8AwVel1HUf2B/2o11CyjtbTQdd8O/2LJCXZri1 Go6SzStkY3edLOuASNqLk7tyjswDSxsDowibxMfU/n2+GdwEsvDsrIo2C0bDD+JZEP8A7LX6s6+I X8d+PwmfLTxXfBN0YYf8fEvTP5/jX5J/DeSRtG0QgBMxx5cH/aX+eK/WXxC+7xr46eLJVvFl7n5Q vWVj0OPU1+lVXzcvofHzjCnVqL+8z8hviL8/w/8AECHc2NOmAAPU4P8AWvQrZ02Ww4H+idFz93jj H5V5d8SHVfh/rYcKw8llwTj7zAdRXo1tLlbV1A+azxtb/gP+Br5WMrN9tD6GVnRXqals5DQLzxbs WRsdtuP5UxCQYNqnaLNsEjjPy1UhlO+3P3mFkwJGB2UfnUnmKXtwd7YtjhV/vfL1pyTcTGL2JCz+ VKUOAtopDBscfWuM+Fchk8BeBnyuX0G1YlOF5h7D0/xrfvbh47G7crtVLDks21up/SuG+C1w03w8 8F7nzt0W2XcTncvlCuL/AJeWOxq+HcrHda74U8O+J7dU1jTYLxo7P9zd52zRkdCjjngnPORnqDXz 34q/Z9voXnuPCt9DeQLKuNOv4wkqjsFcfK31O335r6gglOzIO3/QWHJ9qmB2O5JBxJHggdOR0rvp Y3EYZrlkeXWwOHxT95H5sar4c17QbhoNStbmwuEbaYbmy27sD+E9CPesK7s5JLa5kkD7tuSqRrzg cYr9FvF1jY6pF4dstQt4Lq0ufEm2WCeIMrKUkzk9unavMvFvwL0u9huJfDVwNPm2yEafdBnhbHAC t1Xr3zX0OV57ho4pe0jbueJj8jxMMPenK7Z+UfiD42a74D1BoLa/knsUPGnX48yPb6DnK/ga1rD9 onwL4zhjsteWz06+6RLeTYUNnrFPwUP/AHye3NfPX7XPgfxd4L+IJ0T+w9Sw9iszG0sXaH5ifusO G4wcjswr5/svhH8X9T0eLxFZeAPFMuiztGE1VNOfyQZDiMF+g3HgevavM4+8LuBM+xqxeFvhcVv7 Sk+Vtv8AmW0vuv5n0HBPiLxjkeD+q4hLE4brTqq6X+FvVf1offeuXOpW6fa9AvY9XtD8yWtzMBMq /wCzIPlYcfxYPua8mvPiLIssto9xd6VeRZMsLyOp57lD9e3FeM+HfB37SHhsLDYeDvFP2MfM2n39 iWh49FY/L1HTHY9xXpt74R+KuvW1tbeKvhFr9tLNbGS0nurTbuQnG+GXhgNwIyPcZ61+bQwXGHDs lTxkY4qkv+XlO0Z2/vQ0T+X4n3NT/U3iCPtcHN4Wr1pzu4f9uzW3zLlj8V/Evh2V59I1gRIX3Pby HzLeT/eTPfplcGvTrL496N4ltv7J8WrHpzTDbIl3IJLORvVZOik+jbT6E1823/wQ+McEJ1DTvCms z6ZJJ+7a6dV2tnAUvuxu6jBwfx4rynV9G8baVeTadqfhTWra6gH7+CWwbA4znpg8HryPSuPNOCsg 4qtioxdPELVVIe7Nevf5/JnRkvGme8KJ4eSVWg9HTn70GvLt+XkfVXjLwldSI+o+DdSR/MO7+ybu 6BDDP/LKXPPTo351ifs86HffFP48eA/hh4y1C78KaFqviGL/AITDVXgYy2elQ/vLyVB/f8pHCZyN 5WvKfDem/GfRrDT9R07Qr6bQNSaNbC01C9j8hmkI2JHvcFGYnheMk9DXuun3/wAXvBsWo+JJ/A+r eG9U/wCEbm8rUJpIiwtHdWd4337miYxFW28YBBr6bJuJPELh+j9VxlsRSatGqtJx/wAa627r7zys 2yHw9z2axWDvh6t7yovWD8oy6X7P7j96vFf7WnwL/ZlksPAfwV+H3w58L6fYqfP1q8ktzeXkcQAi lmZhJNNKzBiWP8Sn7pww9O8c/ttfs7fHX9nPUxefD7R7rUdVs3svEU1xpFtFeeW0AWR4pGDN5gff IjcABtpDgZr+TjwtY+J/HvjGy1HXL+8up/tUKy3F4GkO1B8qgkY6KOvGST9ftSG41+KB9GvdX1O3 063tIljstP06C3hbLSJsDiPlkI2kqd3ygngiuCNKhGuvaV5e13vfW59LgXjcdRcqeHj7HblsrWPk P4kSeIPhx4z1jwvNqUt1Bb7XsL2SAxreWNzGrxSGNuPnjddyZxncuTzXPWmuS6omfD9w1lqKIofw /JOSkigdbZj06n92enbNey/HXwF4l8Xz+E08IWF1rD6fplwNUa/1q3RlJkypzJIHP8XbAwQpx0+S T4a8XW08yf2RdQzWcn71vOQbGB653cexFfvGTcQ0p4CEq9ne1/8ANPofgmeZDLCZrUp0tFF6Hv3h /wCMOq6LcGLUbcSGH5JopVKtx1z/APX/ABr6Z8JfFPwv4lCxLcR2t1x+7uH2/kfxr5f0v4beOvF8 cFr4o0nTrK9lsvM07xYPFOn7mQKNi3KeeCwOAN33snnPzY4nSPhj8Sr3Ubuy0bTbaeSyZN08niG1 tI2Vs7SjTSpuzz0zjvXqVqWEr0PbU5c0Or6x/wAS/U8Wm8RSrezkrS7d/Q/SaNoZcGKWB1c9Ufd1 6Vo26su394VC/cz1x6n8a+YPB3gT9p3RbFtVXwhFeaJZCL7XdSeLdOMEKsQq73+04QlioGepOPr9 K/DPwj8bvitr9l4T8D/C9/FXiC8C/aLTQfGumXXkRlgpmnKXBMcSlgSzAADqa46OXVsxrxo4dc8p aJLdv9TXE47D5dh5VcQ+SEVdt6JJdzv9Euv3yo45bHy/3vb17V+iHwf/AGPPih8QdGt/E154fj0D SbiRf7M/4TW5axtbhCu9ZXCK85iyFBCxrvDZSQYzX3Z+yP8AsBfD34OQWHjD4pyab8RPiREqOLTZ u0fS5sBiLeNwDM6npNIo6ZRUr64+J3ii2sM+RMsAKBVgRR8vrz369+tfvXA/0YKOfYmLzic4yl9i Flb/ABSaevkl8z+VfEf6ZU+CsHOtw7h6eIVPTnqpuLfeMFKN7ebs/wCVn4gfEr9h/wCMFmt5qtrq fgfxPduXZ9O0LVpIJFUMqqirNbwxj5SSFGAFjIHO1W/Orxp4Q13wnqtzo+vaXqOk6lZSf6TY31uU cDPDYP3lOOCMg84Nf0CeL/HMcXnEzoFGWJQ9/wDP9a+AP2hNU8IeNNFmtNYltI9UtEZtH1UgNNby kdM9TG2AGToeDwwUj9r4r+hhkuF4dniMlrSp4iKuoVGnGXknZOL7PVH4T4YfT2464s4sVDiXCQqU astalJSjKF+rjzSUkuy5bdD8r7mzKkGPe0oJaaHb0XjBB79+g4/GskDB+ZGyrAFcf59MVV1H/hZ6 M7N4S8HpEp3K5+K2jrtUDklGugwJB+6QD2xnOOOm8Q+M4rVL+XQvBsNtLa+ZGJPijpCybWAPzR/a A4bBHyEbuOQDX8GYnD4jBV5UqmkouzXZrRn+llCtTxNGNSGsZWafdHbSW6PC8RiDfL83mRbv89el c38UvCmof27b2sGkW2o+G7fwrpdnrmiGIwzWskNpGI5IZBn5vuJt4xtUqeGrM03xrqUEmk6vrdp4 Lj8OG/sf7XSw+J+mXWoLbTSorYso7gylgr5KlRt53YAJH2H418QeDZvAcSfDm40LWNR8YatfvoWo +JPEFtpLa5qEUrRyyrLcso8uHc4iiByFYcB5HNeHjsVOlyxXxvb+ux6uFoOq3Jr3UfnR8JNJnPjC O48eQ30vh/xB4iij8U3tveA3n2K3baII5JQRkDpnIbChuBX7b/Dv9iH9l7wNbjx/oxn8caLrl1Z6 jZ3PifU490Nn9nmimNs0KxYjH2hZSuNwaMqT0UfhbrkPiHQ77UNRsH+HywXCFtb0fTfiLY6hDe5H LqkMrHzuANyAlsfMG4Ne9/s/+EPhZ4+1/QPh74mvfEGka74sSOz8N+JvDXiFtQjt5ru6hjWF7J8G D/XMTLvXARtyEUVcPiK+HVKUnGmt/wDPod2HrYeMeaKvU6f5KyZvftEfstaD4I/aG8ZfC3wk9zF4 b1bw0uvWUouIZLx7Jo2YoGeSJAsMqTdfmYKn3t2B5L481P4g67ovwX+DEcd54T8O6H4cW38J+J9Z nbF1bx313dXM8rJkrBBcapqsj4LYJcZ2JGsf6v6Z+x98N9W/ai8UaP4xh8Y6n4VuPhFbWL+L9Q8Q eXLa3t8t4tjqKxQrFG5DWcdsYgux5JN5Xcwr5g+Dn7Onw6+IHxy0vwl8V4k1LTbLw5qFrNoMWp3U M+qXkIlRLiR4nAiEcFrbKVDK7sivhwZCMHWw+My6VOjLmnTSvpqo90vN6as9p5DnGW4OGPxFNxw9 ZtRa0UprptrZa6W9T9I9f+D8vwp+HXwc+CPwu8cfDj4zeDvAnhLVtT8XXF9q0CWtn4smmjjubqbT 7SVhG32WW1EELAnPmMCzNKx+Gv2uY/BVx8SYbnwnq2i6lcSaNG19ceGZklgB3yLCnmLhZHKxsxdU UbHiBywZj+qf7Qv7CH7PfwX/AGQviJB8IvDGt+GBq/g4a9qem3/jbU9UsftNrqNo7Sx291cukcjx W6x+YoD7UAJI3Z/DFobLS7EyW1rDF5EOd6xDPIxjPfPFfG1uJI5LCMYw5l93+Z7GVcH/AOsXNUlV 5beTf6/ocHqGkL4ovNJ0IXH2OdWN9ODANy7QyR7xnod0v4V90fsYfDD+2PE3i6y1OO3ns7LQY2S8 37o95lACt9Qrfr71+fPgfWri8+I/jP7TuzBBbxoCTuVViBOPblq/WX9g3UxZ2fxY1Tepe2u9N8nJ yV8tLg429slv5V50c9xmOxnLKK5Zrb/gnvVuFsuyrK3XpSftKb0ff5H2BrPw/wD2B/g3YXvi/wDa E+MniHw94tv7CK3sfDPgTwLDdPb/AGbzmYC6e4ifzJFupEYwB8YUfxGvPdV/aC/4JdfDy68I65b+ F/2kfHN94lVrnwld2HxFudLu41BRY5FFmVePcWOAGLZVh1r8bv2x/E0vif4u+KTqGogW+hw2NtYR XLSMrMYjLIiBV+8TOOW44Iz0FVv2R9RtrD49eA/Gd1Hp95a/CZ5PGl/YarH5kM2m+FrKbWp7Qgng XC6a0GOmbgDvX2/DvCWEzTFU1HSUnY+HznizNMBgpylO6Sv6n9Mkv/BW34E/CzwpbSyeBvjdo+la Nq9x4da78Xak1xcLq1hHC93ZT3tzYbpLqJLm2eQSuZQJVZs5yfO5/wDgvP8AA6W6vLPT9A8eXs1o yrutvEGkSI/fKny/mHuMgdTwK/O7wtor+KP2UvAtj4qW4v8AX/HOl694o1CO4txK66xqGrT3CXis w4afTl0ck4wwA6g1+WmraJHeWzxNIkkpBZZZoxJn8MYwfp0NfX8Q8MwyTMXhqNdyUe+mp8ZkueVM 6warVaSi5PvfT7j+kf8A4f4/BoSNC/hr4j2mTtb7Stox3HsCtuR6c+/Suy1z/gt18I/DetQaHrB1 7TLi70+G4iuZ7BLi3j8wPhWKW4I4QH6OCdor+SDU/CX9iWd5PcahJiJv9Fty5ZevRNzEj144OSal 8HeKdQ8PXAt7XXLzS9LS6kuLqyV3aGeVo9hBjXjcykpuPQHrXjf2dWjrKbSPXjUpVJLlij+2XwD/ AMFL9N8W6vo2lWmh2utw+I7CS40afS2LNNHHG0p2BSdzFFYjaCTjABPFfop8Jvip4e+MPgfQPH3h g3ceka7bzGOG8iAaOSN9kinBwwVlYblyDX8ZH7I3jy10O++C3iGSJrWx8KeNNdhureDLDyRFdMUi TrysihV9cCv05/YT/ay+C/7Kuj/tMeHPiZrPjLT9C8DftHeII9H8Q6ZrOl2+jro1wIJ7SNmum3rK 895euB91i2AS3B8aWcrCw/ePRM7pZV7aXu7/AIH9INvfQXaGaCQvGk8kbSFSMNG7I4OQOjKR74o+ 1Io/1gzgZUt/nmvgXwh+3H8ENX8LW7eEYfi14qtLmRryHxJp2t6JcSXEc8zSF8x/u9pZ2AwnAyB6 jq5P23fhdHGBH8Lfircyjs+u6bHjg9Dg9/bvW0c8wj6nG8qrJ20+8+zPtcStt8xMsDtJbsDyf1/x o88YG5kLEev6/wCTXwRd/tp+Drq5t5IvhX8RbGJY545kTx7pvzbwNrfNYudy7QQFYDk53dK5m0/b p0e60vT3tPhB4pPmWsLnUtQ+K9pDcSfMCQ6R6OycjIOAB1xg81X9u4Lu/uF/ZdbuvvR+jjTxKhbe pGeHHTr60xrlW3MOBjkc+nFfn6P23tGk+eT4Oa9GNwxHH8XYu57/APEm5x/SryftteF4nVv+FDat K4KgO/xeTpxyf+JQO4HFUuIMAur+4Tyutfp9593+emw53KB3ANeT/Fv4g3PgTw9Y3Om6Rd6zqfiD WBptlaWGoC3njke3mkMqsYZeVWBsAxn3rzXwf8eNd+MWieMh4H+APj++1bw1oVvf2mjfCDxTF4q8 RXjfb7eF7dbE6aFhzFNLIXl6JHkKSy183/Ea8/bb13X/AAfq1n+wv+3LDonhvxGupRWKeGLOWWQi CWFwf+JHuAKTuACR1J3Z2leynmEcRBumvyX5sn6g6VRc7VvU+pfCUWrn4ZWGsao1xB4l1XTdP/ti 8Lf6U0w3fI8gjQttdpMfKoG5sKoyK93/AGTPAvhHQvizcX+neHdG07WIPCGuR/2jZaVHDL5bz6UC GZVBJPlLzn19TXnlkb9/BliNS0jXdDvpLmNLvS/FFkLXUoZlI8xLm3XiKZWyroQCrgivUf2ftXNn +0fe+H2DFD8MfEV0PL+78l/o68n+9+846jrzX43isTiamZOLk7Xelz7vD4elHC6JXseVftlBT+1b oKHb++/ZqIO6TC7V8RQ5/wDQ/wBTX4Lf8FePgK3izR/Bvx78IeItS8I+MfCXifXLbWdRg1a+aS4s 0viLJbdBP5EHlStPyqB2M+S2UAP75/to7F/ai+HbsrH7f8CLy3QbBtXy9esWPJHX5vb055xxnxC/ ZA8U/Ef9n/xj4u8eaBex+CLzwL4mm0ixt9LvLrUry4k1EXlk0SW0LmBX8iMh5Cu9ZAVSVSRXq4aP tMPbluNVlQx9KV9Fy7H8evwa+PPxy+GXirwlrXxL+Id/8U9N0G6gmax1u1tYXuIV2tAlzftC87IH RGId2DFNzKxwa/tV/wCCZfx01b4yfsofCzxHqPhfWfCytrWq21nLrN81wdQt1vZGjuYpWjTzFbzW QttA3xsB7fxe638Jda1vW737XZ6np3hGy1drbUdUjsHmkjRCHmWPAKtIseX5YLhck9q/uG/4J2/s /wDxh8E/sl/DJvFWjeFNO0/T7W+1rQdI0vxBc3Wpro+p6lNd2rXEbWqIhKXO5QjlfLXORiscFleY SwMq0afLSv5K/oup9XxfWyenOFGM+arZN6t6dLvp8z7nE3+kbdwBEbcbu6sAf51aZsHGfbrnNc6J 2OpW5Qp5caXKSsj7sSbl4OOP4T+tbLO5DrGv3k3B938VRFvqfCOPunmXxLnMWizMq5ceLfCSkBCT 8+t2y549M18MftLayuk/t8/8E6mllighul+J9u6ySKrySS6NGqqqswLkFtxC5woZjwDj7k+JQZvD c8qh2ePxN4bZsn/nlq8Dn/0Gvy6/b58RaL4L/ba/4JseLdfvk0zS7PxL8Qrdr+SInaZ9GjT+7kfM R0ok1Gmz1MrTWIjy+f5H7Bu4CIAu6LyDkrzyB3/I9cVXkdjHN8pd12fK4Ab7w4znFeb+GPiJ4f1w WMFlcpK2r6fLNpx3H95GM7SB2yuSM9q9Hm2QKGQckx7x0OSccj/Peqoy54JnkSVmXHkIgKeSc7B8 oI6ED+lfj/8A8FkfjV4e8N/sc/HX4W3WgeMLjXfFXhTR5dO1nTvDLy6TayPq8TRC6uQ37sf6HIC2 Cql4lZlMiA/r+8yq21kyEjGGZR1CjNfm7/wVMtP7T/YU/a206RZBFB8H4brgkc296spx+CDFdmEl GGKjc6MEqf1qN+5/Il8C/FfxzvfAXhvWLmTwQ8N9bI6faNJuGkjjZgAG2XC565zwDmv0F8a/H79p KLxj4qjK/BC8ZNfulk1RPBuqQC6ZW2+aIv7ScpuCA7d7Yz17n5i+F2l22neB9NgtUdLW2tmaKJU4 jG8k4Hp2x0r6D1mTT9KkiUz217fXIaS60+21ywiurdWwY2njuLqIqH3MVIzuCk8Dbn7ell8a9NSr Vnf1t+h5mJxeKljqlKhQjJqT6f5niXxBkD+CL2MjMTvErgt/emXNelQyBBCDkAW3cfT+f9K8X+I7 u/gi7VJWjaS+tAjx8EN9pj4H/wBevT1mkPkguyH7BiMBgdrE8t068+4rzKTalIqTborU27aYK0O4 qE+znLbug4zTzIT5QO3f9mPG36VgxGUGNVmmT/QWUbQPlPHzDinxyBRAd7cWx7ZzwOtHI+TUySJd bmC6bfYYkf2eu39e1cF8DmkT4ceCRiRyugWe4umD/qFzn0OR+tdhdbJraeJ9zh7NFbLcFSef5Vxn wbeFPhx4AaPzGSTwxalXZj91oUI7/Subll7Y6G08M0+57BDKdu3IU/YW+XPfvzirTzZMhP8ADNGS Rj1/xNc6jKLckk86eFOZD/D0z+dPeZJGkA2hROnbnjGBWjjdmEJxSK/iS7VLjwjsyQfFTKFB+8wh m/8A111vjjxPZ+F9MgTwN4T1zx/rU0cjX+pX0dpa29tg5Kw28tyu5h8o3ytt/wBjByvlXid7Yah4 EzEg2+NJGQMgPzfZrg8e+Aea66V4I1lZYYjiK6UptGApYFh+ePrjnoK9PJM1WTYp1fYwqS0tzptL 5XS+84M6yyOb4SFP206cdb8lk36tp/hY/Gf9pH9lb9qD47/EvXfHx8BW1qdTmjjhTUPGGnLN5ca/ KZitwRvwucAnHAHAr5u1L9gH9qnTLIfavCFnHp73tvAqDx9pzK008ixwjaLju7oMkYGecDkf0X/a 42lfJVWEpIIP+wOc1h+Lpom0a3VwpA8U6GxJHcXlvg16eP4sxuPrSqzhG77J/wCZyYHh3DYOjGlG UuVd3/wD+f1/+Cc37VyeXL/wiej7m4DL48sNykMFIJ8714yM0yf/AIJ2/tVx/vZPCNhdvEm3EHjO zkOAcbR+9xwTX9GJvFY4zjiTHy+jj/69TC7wOAHBmbIc8ffrzZ5vWqR5XFfj/mbRwEKc/if4f5H8 3Fx+wZ+1N9phsG+HMks88U0kEA8WadzDGyq783GMAuo9eRVG5/YB/anssvP8NSxEu1ynjHTm+bJH OLj1DV/RtcXuPEumry+7w1qGf9nEsHU/nTtXvwY5+Vz5vIU+j+n51xLMp4SN4wT+87KmC+sTV5H8 zniL9j39oPwja6fe+IPh7fWFvqusWthYyf2rayGS8uXCQQjbKTudnAHbntX2z+yL/wAEeP27P2jv iZpWm+Ffh1D4G8O6Nq9u3iz4t+P/ABJbWfhnw9D5oXzLy7VpMEn5ViRHkkJwqNX7AaN8FNR/aX+J v7PfwgsNZsvD6638adCvtd17UZgsNjpGlRtqOp3Bzjc0VnY3LqhI3sqpn5q/vD+E0vwf+DPwe0bR fAFj4f8AD/wv0LT5G8P3NpcR/wCnW8a/vdQuJ8hZDKyNK07HDqyuWIcCvRo4t5hRcXT333uOOC+p yjVUr2fbTQ/zb/2jv2Tvil+yl458SeA/FHw9srL+yLho7fWdCjMlncW+5jFcWx25kidQrq6fKQwO euPk/T9L8QeNtesfD/hyyfVNU1F2W2sYFVWkYDLks2AAFUkk8ADOetf6YH7RPws+B37T/ha48G/G 34Z+HYNM1SF/7B1G5uzpuvWolfy/t1iNnmqu51JM8caP5ZEikbd38jnxu/YZsf2OvjZqGqaPrdh4 z8HeMtKmj8F+LEszb30aJOrT215bf8s7hCq/MMq64KN95E8+v4bZdisNLE4OtJTiryhPr35JLf0a R9lHxPzDDWo4ihFRlopR0X/bye3qvuP5wvi3+yJ+1D8Rtb0u+034F6hpUGkaH9jluJ/FGm+beN58 0wnkX7RlTsmSPackCMHPOK890X/gnf8AtTarcLC/gC30yMXEcd3cX/ivTwIVaTYXYfaMsAckhdzE cqDkV/SZ9sYxMu7cQnHP+xms631EefclWGDdBQu89pH/AMTXo0M2rYehGnCmtF5nweJwbxVedWU3 du/3n4l+G/8AglB8RpdZWy8WfEbwNpumNptxP9t0L7Xfzb0O1EEMkEI2sxALeYCoydpxg/UHh/8A 4JjeGtO8K6n4d1j4oajr93LKG0kv4aSGztT5QJBUyySZ8wn5ldRj+DOSf0LOqKur254VjocxyMZw HXNdFZeIdLsNTtbrWAj6fbapHJfozEJ5KouQxz0LFc98cAr1H13BL4p4k4ow2XZfyxrVpKKulbXe 976dz5LjXGcP8J8L4jMsw5nRoQc3a99O1utz5F/ZC/4Jh+D/AB3aXcHxW+E2q6ZFoV2IP+E8v/GN 0NL1iEtvFxp9vDNHI0m3ahUgw+rB90aft38OvhF8I/2bPDtx4c+FPgfRvBNnfFX1m/stMSO81CRQ AJJ5QoMmABgHgc4Hr8X6t/wUL8KeC9f0extNb0e3vWjk/s7S5NOb7PGtuSPLbKeUAERWGDjayAkE 7R538dP+CoF58T9ROqag/huGWK0WFLfw1o1vYwKiKAPkhVRk4Jzjkk1/pl4e+DGUcH5gqiqU6kpL 95Nz1hJW92FOzsn63Xmj/I/xf8UPFnxiwEsPSw1TDYe69lSUNKkf551bpNryTXzPuvxP8UhbiRIb yVWI4KSY9v6frXy54++ODQQym8vWlCK21ncqVX86/NzxJ+2pY30csCSsX52MG74Pevkrxz+0Hq+u wOkM86ZkJGH2jHav3fHZzw7w7hU8KlUmflHA30e+Os4xXLmcpU6T3V9GfXXxr/agawWSHS7gPNMn G1uc/n7V+c/i34s+IPEN3NLc6jMqs3EKyH0rzjWfE19qtxJNcTvLI+dzt9a5l28wHcc/L/F3r8pz fjrNcybjKdl5aH9ycC+EXCvBmGUaNJc3d6s/Tr4WaN8JvGX7HXxF8Uax8OPAr+M/DOm+I7GTxrde FbR9Wa4Nv50E63flearxi5iCMWODGMdMV6b+y/8ABbwBffsq/C/WdQ8AeCde8RX+nSXuu+LvEngu 2v7sW01zLKBLPKhbG0wxLuOAuAvGBXy1+zHJL4r+CP7Qnw8a9isoW0ZtSiM0byKyx2c806hI3V2L Jp4XAYE5HPavpo/EXxp8Pv2SPgb4b+EcPhvUfiHqXgXSJrHTfF3gjSdf024sXtI4wkun6pBPaSh5 GmiUyISHAb5SuR/mN4q4LMMB4h4yrrySnzJXdndI/uPg6tl+I4bo0dFKKSe10j6G0uw8OWksvhLS Phd4Y0fTtMhF15+l+G1jhuI5XkMcEaKvlhWKuz46ZjGCr1wnirxafFGtXlzY6VZ+Dha3c1lpy21r EymNCYpGXaMBZcMSAeQ+0jHFfM3jjxx+0X4MtdDt9N1Tw14n+JfjT4p2ury+FrHSrvS9CsbdoIoR plpHZ3UQt7FMIxIYSmOEuGUrIX9J1PQPGsdlpf8Awlmsw+KfFM7L/wAJFrUMrFbrUJPmlnQtzsZy xGRwCOATXyeQYTF18zc8R8UVve+r6fJdD085rYOlgYxpPST2tbRdfmdT8afF/i3SPhN4l8Wafq+o 654iwdPs5ozJPcSXdziOKMKcsxLyqNn8WVpQ938M9B1fWfB/jjWtZ07wlpdvfTn4lfs6anFN5Vi/ nkz6lbWMTKB5ZYyTB8DO5uAR1Pwc07wle/tHfs5fDjxX8TtB+EmiQ/FqPxIfiB428UxWNra3OkW8 l9pgkndCqiTUrOzgxg53DAIJA/b79qH/AIJ+/Cjw58MvHXiTWv2yvF3i7xd4p0SHTtS+Hug/Ci2b RZ2n/dzJJNJMk7RGNyp2vESigDaea6c+4oxWVYpYeMVUUtWppNfjF/g0zo4UyfJcXiI1sbOVOnfe n8Vl84pn4UfFb9pr4k6P/wAJjY618A9X1LXYfA2ltaaz4Ds7u6soZrG6muLS9a2urW3uPL+1bSVK n/UdTjNfLnwB18av8erP4g6Zaa895J8T9Timj1PSfsLR+H9TimwSGU7kEqQtuHzfIFyu4CvqL4xT /EObx341PgubRfF+s+BbH+zfGYu76ewmh0eEG8XUvs0VvIGjaO6IZUYuHXykSQlS/TaL8JPEqP4K +DPwnvfD2ofErx14znkvfF2qaQtvb32ppbS3dzIRHuYwQQWPlQruKExtMFR7mUN4uWZPXwvt8xrY aNBKNrxlJxm3so3b0W7tt2P1HxK4/wArzrD4LJMuxksRQjJyUZU4wlTWmsuVLfZc2/c/cf4geH4f iL8OLfwa9vY6nPr3wb1pbGx1C6MFtNehlkto5pF5EbTJHuP93NfzHfHr4Dap8MvBdr4ktL2W/wBH 1HUmhMF5abZraCQboPMwTnPzqccD5e5wP6JvDXgb9sfX20+XxXefs9eHL6xtLiKGy8E/BnVtQEYB AMccn29cIcDdyozjnvX4tftlan4i8G+MfiF8JfGlvLFqmmarJHJp8mmmyj+yzqs9pMsDO3lo0UkT qu5gBgZYc1+HZ9iMYsTSnT1jezS10+4+x4BlhZ0q9GTs7Jr12PzX1fwJH4C8S+AfF+nXay6H8XfA 1pcOnmmSS31a3iijvUYnsZG3DsA5X+GvsL9kXxeug6x8SvCtyWiudc0WG8tZA3B+ymVZB9SLhD/w Gr3ijwlpnij/AIJw/D/x7pngHwlZ678Hf2qJvDviTx7b2bLrVxZ3lpNeBJ5v4oVfUrGNQSSNiADC jHz34X8TaR4F8Y2PinWb9tL0i30i8W/upI22qJISiAhQW+Z2Qd8ZFe5QrQ+twlFHFioVK2VV6Mpa xb1Plr4764NU+KXjyYzTPIni26RfNfIEcaoigd+Np9a7P4dzyeF/gF+0p8QEFvNcaxoWg+AtBWQH 7VHfa1dtfPNBjgj7H4cvbZ++29A/iqP4iQ/AjXFe/wBJvvH58cajrt5d+J/EseraTNodxDPK8kEV tY3MlpcwSRpJGjyPLKjsrFNoIx9cfBnweNJ8YfsBfDfw9Pput3X/AAsDxJ8cdcs9dt7bybyx0VS9 vpl0Le6mhdZIvBt3sxKcf2oVIBLLX9F+HnsFmUZ30hFy226W/E/nLjWvUeA5GtZNRtdXstdt+h9v eO/hbaeHPiR8MvD2m+Ob9rX4R6Evh+1is5dtvrFno1tb6fbuwXI2ypCJWHzA7VPGOfkTV/2U9MdN XsvDv7RvhDxFfWcdy1volz8NI9Ob7YmRFBNNDfysibsKzBG29kc8D7x1C1C6tpkkcMU7WAKyXU7/ ADRxB41JBx8zElVPI4YnPAB/Bb44prfhj42/Fa40aXV9LeD4g6xJaXNk8ilUN1IykOvoCPpxXi8Y ZxmOYZl7T2nwt20Vredt/mdnCmW4TA5f7NU7cyV+vnpfVEfxu+HPxE+H+pWtp4z0mzt7B7iZdJ8Q 6PP9o0++2lQWjl4wcBW2OFkVXBZVzXgRkeMiRcE9859fT39fevp/R/2h11/wpqPgX4oSC/0nVY1j udQkTdNHImfIuEUdZ4mO4N1I3oTtZs+G23gbWtTlV9HuNA1SMxrIvk+MdE3BH5USx/2mXiY4OUkC uuCGAI48bDZsq1O1ZWflse1UwkcO7xenmfZv7Pjrrvhnw7o4YtDqnxwOmEqP+Wd6IUOfTP2lhXzt fWHiY/s+eI/B+qHUbbWvEPjXwzqHh7RbzTruS51Dy9Puh5EEKRF9xgEDAuqx7VQ7wrIW9X+DGs2P w6/4Q3w7rmuaLb+J3+OmhagNG0/VorySONpbRVDPCzxlz5RO1HbgqDhsgfvL4Y/ZV+Elr+0f4f8A jv8AEHSdFvI/D1hql9oGl+M0tbm1eZ7KCzRH0m4t5IbzPmTyBZtiwnZhTjC/HZrUisTZddj3MLZ0 k72Z88f8E6NG134efCTwB4b8T/YTrl1P9v03ToVLSW9ndSTTpDMjAbZQXlZlHQtgnOa/X63jvpIJ 2WGIq1rJJtgtC24Acjqe56DPSuduJ/h3BPZ3PgX4TfCrSJowjQa5H8HdCEwkB+V4ljsxGBjIHDHD EAjOa9D8D+A7rxN9pv8AxT4m0nwx4UuLqa4mtgYbRp7jDAqsAVETKtJnoBzwOK8PFV6lRJ2SOpwj KVrnNxaTqd1NNligJ4xYrlTjg/dI4yScfSuVsfAfiOz8K+Hb2XxA8NrqdheQ2cNvYWyzQpFIsbK6 GHHVl2nqQOetfeXhP4XeDksZNVvNI8OWOkPA00EuiaxcwxtCqY8yW4F8WkyO7ZxyOetczrcHw7Ww istLs9MsrzWYPL022F1eSfxnzJpN1ztYN2yc8kjrXHCtJJ3SK+rJW1Pj1NA1TykDeKNXJZG/dixs vXsfJz0P6Vo2ukXsENwLrXL2R/Jk+9b264bqWYrGOnB4PboO31loXhnw7JqY1GzjfWIrW8WztbLT Y1kjkwqqXAkuR1JwcfL1r4o+JulwQ+LPENk2nE6eL+ZYrLVNNijaOFvuJ5aswACsBgEjAFEJVZPS 39fIv2MVHcs69+3Dffs8aj4Z+AOj+KfiX4b1T4r31xrGrQ/BnT9TuPGPiKzhQR/2Zpf2AP5Mohj1 CYyXNvLFuWEEBRIy/jF+07+0X8UvG+l6jeaHe/t4eHZNK8T3Da1qfxL8EajJerc3lqsyQ3kkNuI9 hjieUBpdzK0jCPZ8w/ZT4VX3gT4eeNfDfjS5+FHwv1nVvDE8n9ka9P8ADXS5NcsVkBSX7FqJgFzA zRvIuElVSHZWG1iK/TnX9c+HPxD0Wxs9Y8GaF8QfC15FDPHZ3mm2epQoBHJsHkzSZ3Kl1cjhdyiS YfxkH1qWb4rLoKKimv68hRw1Cp1Z4J+zF4ts/E/7Mn7NusL4lbxENd+GegXZ1yZXWS+V7eE/aXEm ZFZ85Ic7sudxJ5r6v+ADWTftQ+K9Qd08q1+GurWwf7pXzdQ084yB38k/98ivKk+FHw303wtpei+H Ph7No3hPQ7CO20DRvA1na6Sul26Y8sW0ds0aiNRgeVyBtAC8V82618GfFOlXlx4l+DPijxjb3d4J E1LTtY8UTabqy7vmZPP8yMSKzIPvbOcH5ic18zOnXqYl1LpHqxq0IU+Wzeh9jftZrp2tftV/s9Kq rcQS/D7xRNqlsbtY2mtNOltrySJC3yrJIsDKrMQu7YCe4/VrS/GWpR+ArJ9JvpEg8W+FvsXw60Xy 0t5HkgtdyzXseGKR+VBcMXVSfLTO0MVWv5vZv+Fk/DWDxL8TPix4M8d+MpNI8PixgvrbxVDqlzBa yXttcTJHC0jmSJmtU3opVVTezZA2n9Hv2eob3xL8CPBvxJn1DW7f4rWcVjN8P9U1e7QySabdvDIt /DG2Q0Bs72OCQn5w0UygZKsv1mSqH1dqUlzeXY83MG3GMoxaUevmeN6z/wAE/f2RPA3hhPiP4z8b vp/h3xNfqt9ovg6we4W3uIkP9pxy2cbPdKr8q0ts8uImyoVdufS4f2pfCn2GfSf2ev2mPDes+A7P W/B+h6pZS+EZ7e6t7TUL6OzhtfPumVrScWquf9TgJEiRqMDy/gz/AIKM+PvGOi/Djw98N/Dml6Pr tjf+P9Wj+J/iNbWa11mbWJZpzveXDIEIlmcINqyRyArlY8r+Gf7HvjWx/Zz/AGxfhhL8atc0S203 XtUj1LWNd1O9b7LDcJdW94ljNvAVH2WcqIVVQzzAKBv+X7NupWwsfecox6aWSPnoT/fv2q1l1Tf4 +p/WN+xr8Xl8Z+IPiV4NGoR3dt4emtr/AEcz3kssskc7SRXLRtL80kYa3gkZssRLcOrEHiv0ASR+ FA+QdG9/85r8Mf2Pdb+G9t+3P4+uPhJ8U/A3xI8Fa38CtU1TU7PwXrD3S6Df3Wq6aUtJ96g+ayJI 7nLBpA5U/NtH7XWmtwTGMb1Kkjec+1fA57Vw2HzJxi1qkz26FKtKinKLj6nKfFG5itfB3iO4mk2L EbKQu5wNwuk2jPuxXHvX4zf8FirESfFT/gn3qUQxLB8U/FULSpjdtm0yHIx77AMV+xfxMeK58GeL TIqSQjRjIBIu4FkZWU8+hAI9wK/Jr/grosZ8efsBy7E4+NeuBZGUbV/4la8Ee+RXJQlGpI9DA0/3 kb93+TPRf2XZ77xN4k1B/tku7wZpzxaRPJKQIpIgAF2jqvUEHseMda/V69ZJtPE6qDG6RSIVHJVt pGa/M/8AYc0lJfDfjq/byGnfX5PPl8s7vLKNtC89znJ9q/SW9McPhW7kd8GKFdxDfwqGP/sop05q SZ5MYckImmV3GblSiQSBSM8YVf8AA18P/wDBRzSzf/sY/tfw7sxt+znqTJyc7kikcH/xwV9ro5a2 vHOSyQyZJY7eVXg/rz9a+Xf28bX7T+x5+1cvLGT9nnxGucdk024b+hrWjb28deqOvBwisVH1X5n8 j3wtH2jwTpxcqyvYNsbPsTn9c8+1fpl4w0u3ifwylvY+ZGfAPht2jjgWQK76RaM3U9SSSa/MT4Ou j+AdIYqyh9JRgiygD/V9CPy/wr9XbqcajH4dkWdHK/D3wuGaJFK8aVbrgZ/3effPpgfftp04X8z5 fHqpTzSso/zP8z8ffiDfiLwXLIqliNSsNmef+XqKvR0vV2QgAgG1+5uPtXhXxFv9vgxyu759T03O T/CbyEE/hmvTUvgBDhw2y1+Ut7//AKq8+MFzs9KUv9middBdnMXzFQ9sQw3ehGaj+2YWLqC0PA/m P51y0d/zES5G21bOR7jvUf28r5YLA7YJMZOevf8AlVuNnqc7lK51097tWYZC5t12sD75/wAa4P4S 3Jh+HHw+jKldvhezzGx+ZR5K4X9P0q8b7cGTfv8A3MfQnP3v/rmuI+GGpBvh/wCBmY5ZvDVqdytk f6pc1nypz1OhSapHuP2z/Rzkgg2Q3Hd9f8Kj+2BWdgyHFxGx/Qf0rhv7WQW7KT1sV5PrSPqwEjMO AZI8bCauq4PQ5oOVmX/Euolb/wAD8KAvi2QDcB/z63GQPy710s2oFVYMCG2TL19xz+teN+JNaiOo +BSXC58XSbG/2ha3ORn866KXWM+YfMGcTck/7VcylSUmrnU5PkieiLfjzG28jccAHn/V1z/jLU1j 0a3yST/wleh5BHGDewD/AArmjrCpI+H2hXbI38j5BXMeLNbim0qGJ5MZ8R6S4Xfj7l1CR+orOcoc pdNT50e7nUxhxuAO2XBHUfMP/rUNqakSEMRmVhjP+2tePy+JUUNum5O8As/+0MZ/Ss6bxVAu8NN9 4ttKyDP3/r7Vh9ZhGWhl7N8x6hd6uD4lsH8xRt8N33yh+uZ4f5YIqLUdV3tJuYgvJgHcO7nB/lXh 114ws4tfsp2uURjot4vPfdNCePzzU3/Ca2c0gZp0jG4ZycZyzdfyrnqYmMo2aOiNNtxP2M/4J9fC 7WvFGseJfi3asYtN8A32mabCLjTWkjnN9s+3sZBkKsdikyOQrlWvICBnBr9lvCHxf8ReNPiL4U+F /wAOfCuuav4d0O+kmF3a2RvoPDt1YpaiUG0mjjjhW2SWK4igZZ41u5oZF8z7LBbV+M37Jnj248DH 4afDDUruGTw/q3gl/FfiCystSj/12p3NgzLJ5e7cX02ytI9snzhnZRxtr9ovh98T/h9+zZ8EviP4 t+I+sXUdv8W/F/iLXvFnxAvrKW4gjtZLiSOwsltreOW4kEltFbTNIIPJXzisjbY9texlGIyeGIp4 uNWzkuR3kkr36p9V0O+vl+PWElRlF3jaSSV9+p5t+1R+0x8L/g34Ps5IbGz1XxRplpqFvHNe6++o ahJdbgs7y3PlsuoO5gUy3DTyyBuJmEpKL/N74++PXiT4ueOf7c8T3lusUNvFHo2kwRCKG1t4icRx hcAKA3A6ANjjoPWP20/2oNF+L3ia80H4bWvhS08GGe3mu9d8NeJX1mTWp/KQxie/k+cpAu2MQHCw sjKFHFfnrf6rBY+IJZLmaTZDYxxm1hXdI7b9xKgAdRgc8DHWv6P4cw2X5dgFKaXv6XfZn5HnLxeO r8sW/d6eZ9Sy6gsZkTzgSq8MRhT+7XBz9MdPeuPufFENrcThpww+1ZUlhwoduP8APvXz18SPin4q 07TfDEfg7wi3iXUNTvZrR9Kt7uZpzHt3RMojjcuxO/K4GOgJrxOHwh+2l8R77ztG+GfiHTbXUEkk gnj8Hyw2ojjc783FwwjZvnAxwT2B7fhnFuWwynN6lGE1yp6O62Z9hk2InicJGU1Z9fU+1pvGVvHq Vu7XCALo0yqGYdTIMY9e349e1eS/Gnxfr174F1hvCd/i/iuUlu7eG6WFpbXAD7XbgYIUnPQKa810 j9i39trxXrMF3q7X/hmzm0Zwup6t4lsYLNY8N8nlW++VJGIwCYx2ywA49l8M/wDBLv416vLc3Hjb 43aDosLRK1m2l+INR1aR3JXckiFYhGQPQtnt1rz+FuKsRwdxDQzKhVXtKTuv6Q+IMgwnE2T1MDWp 3p1FZ327n5ga7F4oM4a98pZJXb72oxOzc8ncGOa4i516XSZzHcXkVtJhcs9wv169O9fsx4i/4JY6 n4f06/1rwR8VdG8VeJ0LOdI1TQxpNvdRgABY2E8pSTOQMgK5IJ2ck/kv8e/hv4q8D69c+H/iN4V1 nwjq+G+zJqloVjnUfLvgl+5KmRw8bMp7Gv6vybx8xnEEnOnV5p9U73+7r6n4rjfDTC5UlGUOWPR9 P+Aef3DWt+zSw39q80zbittdq7c/7KnNZtz9sgIWUs8Y/iDHHPrnpXlEmkJbu3l35YZ4ATafc5zW 7pus6jpyhTfRX8RX/U3J3YH+y33vyNfd5d4s4xTXtoXj5HkVuEqcF+7lr2Z2UbpLnPQ9yKSWM8EN uXHX0qhZa/pF4W+1WhhkK/M6uVA/FRz1HUfjXWWNho98w8q9dOfuuQefr0P4V9/geMMmzeF6c9fx +48DE5VjMHP3ke8fs4XcFnY/Gqa+8YW/g3R7f4bRz6tqbWxuJo7dNRtRLLDbD/XFYXuFKZyVkNfU /wCzN4avL7RdD8WeJb3U7fQNA0O30/wmmoSysY4EjyAjPwIYkkYblJTzJJM4MbY+GLDwr4Sa3ul1 u9vbJre0ebTGtLIzPNcAfKobcoTtlj0BJGSNpv6f43+IOi2kun6V8QPGEGnziRZtL1HVjqFqyyE+ YDFcBwNxJ3Afeyc1+K+IvCmL4tzuGIw8f4S66Xb13dr2+Z9Rw9mdLIcLP2sv4zXXbl06Xf3pfM+5 vCFre3WseMfHcF3c38DX8z2NveMrfZprhspDGM5DRwhCc4G2RCM9vWvDlxcapptpqF2kAuLSH/SY JR5aybQ2/dn6t1xjAyfT849F+PvxC8PaZeaOlj4P1qxurtZr+S40yWxuJpgsagtJG5U/LEg5XHA9 K7rSf2mfFqWclnp3hKTRdRkVjpt9aumoW63bcJI6FoztQMzYKuCyqCrLla/NsLwdnOTYdRxFN3bu 5WfV9z6PFZ1gszrt0Xtsro+4/g94l03wj+1J4bv/ABvpula/f+GILa8vLrXrGOa10nfdwm1W3i2F UkiktnnMuC6yxR7djRsz/rh+1V8YF8N/CzUPEWs30iWVpqEErys7YwrA7cgdxjAPXp35/m88JePv ENj4/wDHeqX2qaZ4kttQOnWPhrUo4xprXFtbJcTKTbSSM0b5kkQpnHmYRGkMiA/fP7bfxji8SfCD 9ljTvEFpHr+meMvENnqXjjTPCHiBJvOtbNLcSWfnxsU8yU3rHO75HiB6DJ+CxnDeZcVcWxjy+zoU lq2rWiuvm5eSPcjmtDh3Jld89ao7JJ3vLt6L8Dpvj18UPh9+zPplvpdxd27/ABX+Leq6d4g+NVss Us2qaaIbeNtKtInjXZGYJIo5spN5qyRRyFTHcIa5b9kz47eHfil+1V+z5qPg9NeisfDmua9b3Zsr VUlkmuNGuI/JjRkYH5ZCp+XpIcc/MPj/AMV+KV+I3iLW7rW76DxJ4i1e+a68RalewndJcSHkAMSE UYwqKxVECquFVRUXwi8caB4Q/az+Dscd9H4V0Dw1460VdcubVvs8a2u9Wu3dlGR8kkoZuTweR29X jatgMThPq9FP2VNNQV9Nt7W1b+8x4NwWIwVd1q2tao7ye78kn0S7I/q9+OH7WOk/AHwZqvxX8fN4 30Pw14TNjBcarqWtPD+9nuDHCn2Ow2CYs04GHRuAC+QOP5qv28vjV8OfjR8WPCXxF+HV5phh8U+C 7WHxTotpGqT6feQ7hF53llkLPAYRlGK5iYZyOP08/wCCw/ho6N+zx8N44byS4hvfilM17EVt0jNv DoepOd5jbDMu1WG7HI55IFXfjX+yf4C8ef8ABPb9n/WdD0LQtH8bWXg3wfq8uveFPDsEd9Pbyaci 3DXjKvmTruuQ7YYfNsYt2r+Y/ZQxNqMY+8+p/RuVSnl3Ji5TtG9n5eZ+OFj8ZfAGmfsV/F34H6n4 k1my8f8AiT4w6ZrXhzw9awN9huIYZNNTdMwYANtiuNo+Y/uznHGfl/x/p82s21l4cbybeHU5baO4 kuDIYliSRJJN3lqX6RsPlBOSPWv2o8D/AAz+E/gv9kn4y/CPxNp3hvxB8RvH/i21ufCPii48JW/9 sWSyLZR3AgnZ2dY4ls2ddoIV5uR81ee+EvAXwE+Ad7N44+L3jvwjpmi382i2ca/Evwtf3lotqJXN +qy2NnO0Uzj7OY3KrtZdu2UMxi+jwfB2efVVUlHlhTerYsRxXlMJ14813PWK7n4bePvhnpWjS3M+ g2uu2GhafZNb2r28UmqC+uy6gNucRSRxbSMHY7nglefl/Tf9nmPw34n/AGmvjn4r8O31n4q8Cfs/ /Ajwd8Mfh/408PhlsrjVYltLZb+EZyEvrPw/4hmPr9qbPU1Y+J/jv9n3xN4A+KUvgvxd4W+IPiPQ 9e0m48ISfDeK+0+yhuG1NZIHuBf2CSvb/Z4QvlptbzXdj8qIG9i/Zo+H9h8J/wBmewla1udM8W/G f4veJvF3iuyvtOSF20mFks/DrQyL/rLcRDVZUzjDXcg2gYJ/TPDrM/qeLx2FinOUIxcpdEt9z8r8 SMsVTCYLHVOWEazlGEVpdppN8t77I9M1nxHDoiWa3JJbxBf/ANn23l7mbcxWYHI6fLbtyfSvz2/a F/aWvPC3xH+JXhe81/VDJb+H3sdE0qHwfHJB/pkcMzq0ovF3KRFCpdkJAZsoxRc/ZfjTU0Gn6HJG SBH4g7JngW0uMe4PpX4x/ta67oi/HHxfdXc7SzS2uksYIF3NkafbgD/x2uXN48lNTM8slFzcbHyx 4kmeKzhTOGkudy4x0wc4P4jp0p/hjx5r11PYeGpYPCCaRcXFvayzr8O9JF99nd9pYXhtDP5m05Em /eOueK4TXdZl1S6Lwo0aBNsCA/dX1z3PvXd/D7xv4X8NveDxL8KvA3jgzad5VnceJJtZWS3l5xKn 2LVbZd/Tlw6jA+Q18hWqObdtz6HDunCrBzXuprTuj2qA+AbPx18L7jwNoeseH30/4maGk0epaobn zs3SsGBY8EeWOmAcntgV9BXn7anxH8SeFoda+Ieu634s1zw18Q9Li0PU7zUmkaOzmt7v+0ImVyfl eNUChcYbac8DHwh4Punk8a+EbyctDFD4x02Xyt7vHGv2lDhQSSQOepzj3zXa+EtL0nWtGuLXX9Rh 0jR7y91ORdYkheVbW4tlsykhVT8y7Z3Uj0fjmlgZ1aFKXNZvuejnmMwOYY9Sw8OSC6LT8tD+vD9h rxPpvib9nDwR4jvL7Xdb17R7/V9PvLa00/zFt/s1/OIUaVuBtgNtwA2PUV+gnhd/Dl01vqvja+1m 5gidfsmnW+hstrCpJG0Kke3IyOMfma/Gj/gkNf6X4q/Zp8aa673cyRfHLXI7CFr7yIvLazs5jweS f9IHAHO7rnr+r+nm41m/itbWwuiCjGLzblPJhjI+8UKHcee+Dzjoc187i2lXkOkv3Z67q3jNNeux aaZ4pv7DwtoyGSW0e1aAxxr2IMOGyOO5/GuIj8Wah4q1O812bWtQ0O5gtvK0u30jSGujtYBQp2xh R8uTvba2c85xjI164ntbX/hFbW+sNO08X227u7iUeXJMo+6wWEnauASF3DtgkAVDLfQy6vo2iWev 6RqNkWV72bT2vvLSTPzFxPawtnjPyqQARz6ca0NnZ7M9t8L6xL4dHh3SpvHWtLGLpLi4s5dCjbcx bkEgsQMdR19MGvFP2irnT9S8d/abO8nv0fS41eadz95XfAA7YDLyeoxX0XoGh3N74m07WL28eVLd F+zpFHIE3A8/MynJIPOf1rxH9pSWb/hKtMvx80dxYzRRSQwhlXY3QHaD/H3/ADqKUv3yK5bx12Pm MWSqwO+MdCNzcHjv+Ve0/CT4o3Pw31Zo799T1DwvenGq6ZY30qyRtkfvotrA7wARtyAw4POCPHzN CxxtmLbzmMxgfrV1bh4mzbgBpFYSM8aN27Ajr711zvKNrHPFRUlqfr15NjqGkW2r6BdywW2qwQzS 20NzO6Swtgg7lcDLLtGRn8RzSRJpmoxm3a/vft1lHH5cU00vnWZYcKT1c85xJv7gccV8P/Bb4veK bWO0+HUTxXs4uM+GRNOB5W58yQvkYK/eIyeOg/hA9tuNS8UeHYYtRnS6+2btt5Dp17+5Vu6Mcbix XnLE59MjNebUpzgzrhUjNaFj43X3imPwDrYhmTWP7NeS4jayKwttjjf5GxghtzLwcgHpXl3xJ/a0 vP2Z/D3gLQ7K+1yy1TwKNP0/QrPVdOjmt7Wx1G1eZtqqxdYGjXTY2DNuiKttQoA1bvxM1vUvFXgL WWvddg8N6cHt4Lm5kvnaRZJJFaSKNQv7yUrG4UbSMqScqOPz8/4KMT+LrTxr8Cbnw7eRXOs3Xha0 TUbV7kyWLfYrmdhPcW5g3RSNJbvETjneQU2KFHfwnCniM9r66qKR6ucXw/DtDmWjlJnMftT/ABU+ J3xeOhfFHwjqFj4f027tpJLm48Oz3F9/YkQdY3N15qrGm5A/loN8YTfGR+7Vovz80TwF4O+K3j/4 FTeNNY1/xhb6x8QftGoHXt0SXU0Un2t4lihYLbxpDbzbII9qASk/e5PrfivxNr2meHNMgdvDmteN n0G8m0pLLRYY7C8YdLY20x2MVkOyRpDuDkl9hdFrvPgJP4N8UfE/4f3Nz4B0rwR8RPg54K1DVvGM 3hLXvM8MapZGxkhe4W1b95BdG8ksi+WMbDOwRr+7P2+azlhMqqe9aPK/y/zPncmnQxeaUoyjeV0v +B6nq37Is1x8M/2o/wBpPxl8L7WLwrpjWuiW8mgWLONOWSV7hjG0TttYER7h12Z+TaDz+vunftia podq8/iTwLqOsx2elKyv4T1K3a6vbtd29ViuHiijXATDPMAWLZ2gV+fH7KniPw94Z8IeO9Q1vwzZ alqXxL8e6hqX9uieOS3W0hZba1tyDKDt/cySBiMfvfWvqiDwbZ65Y/2no0VtcLINwg0HUWmNvyMA wkEt0cEq5HTtivx3LcJLEYCEqm9tz7LiTGp5vUUVotPuPuK/+OHgjxV8M9f1Cy1+wMVz4Xb7TYT3 scd5byyYURSR7sq+4qB65GCQRXwh/wAFVLeTxZ8Sf2AdGsJI476f446ph97f6s2EQI6+4PPPymuD 1/wbZnz7fxH4Tvrq1trqOSGR7J5IVkjdWjfZJb53K8aEHbjKKQSQK858ceGdT8ceIPhV4ivfHvjW WX4M+LZtZ8B6XqdxFdW8N9JE0bLI8kRmMIRmAiWRUXAChcAD1MPSrYeV1LQ8WniMP7Rcy0v+h+nn 7Lmi3XgHwNr9nfOkt5e6ndyMUGPkXcFx7fMTX2Nqmopd+C9Qhjdkn+ws3ykHcxDcHPbmvyG8KftG eOPC01xb+JPD2l+IdBn0W88668N7rHU1vD5jIqQTSNBKrboUy88GwqzfOH2R/W/w7/ah+G3juz1T SjqV54U1ayijhOieN7dNPnnkaFZf9FYuY7lVZihaF3XepAJBVmU8dUw9Ncy1OWjg1PZn3NZ38Z0y 9BYeYsD7sp3wpxmvAP2vSs/7Mn7T8EmXS4+A/igcHdu/4lV1xj6V0Vn4st2s72CO4jlWAfvhDKrF flJwcc5/z0rzj49X51j4G/G/S5Sr/wBqfCPxJbkqScCTT7hRx/wID65ooZxSeIipb3R0YbBShioS 81+Z/GZ8EfjJ8PpfB9lo154jsdNu9PsVju01aT7KqnZtxvfAOGByQTjgnHWv030j9ov9n/TtP0VL v4iaHYXb+EtJW9sjDcSLHOluEcgrGV+baGyvBJJBI5P5sfBnTtPufh5pkgsYnc6dGxlaIbmJhXOP evf30zSLiDTWfT7bK6RbKPkx0TH9M/jX6VRWYYpRlG3L8/8AM+ezKvlEMxq+0hK/M9eZf/Is+P8A 4japnwaP4lOraXkNn/n+g4PNegHWiApL7c2mflA9a+Avif8AH7wtDo9vplrfza9Ndajabf7EQ3Kx LFcxSM8u3JVdsZA4zkjjGSNtv2i/CMscz2T63fn7GvlImjy25Zucr++Cfn06YJrm9vXnU91GcYwV JK59urrqooXzRuitieTmq7+IY1VlM3C2/wA2D+H9K+Ep/wBoKC6Fw1po+rx/uv8ARvtTxpubJHO1 mx1B71kXPx28QT3EsVr4ZgSCQ7Vll1V5GIBPOzylHQjvWqWNk9jKXsoS0Z9+z+Lbe0E0/mLmC3X5 RJ1wfXPqRXnvw48XW8Hw/wDBcO8u8PhWz3kcHiJOcfnXxJcfE/4i3cE1stlp9ktwNqSpburcgbWX c/X5Sf8AGpvDnw4/aJ15dG0Dw1Y/EfU4001YNK07R9BeRpIFUAlTFAHbhRyDVuliPZ6kxnFO1/kf fEnjKLawR0ObZdh3+/P+fzqvdeO7aAl5Z4oB565Es20AhPevnjw1+wv+2D41sp5IvAnxLmsZLopd Q+K9Wks9zLnpDeTISoyei45xXsfg7/gk9+0PrL3J1bTfAfgKSGJWQeJdbgL3A9ENks/P+/t6GvOn 7GnrKql8zZKdT4YHnPxA+OnhHRJPCF5d65aXQ0/xMslzZ6S32q4Ae3uF3eVGS23MiZOP4h7Z0Zf2 hfBcCoZtZnIeNvlh0i5mwGfjJWPjpnntz0r6v0T/AIJGeJojaDxV8VfB1lDOg82PR7aS+kXjnbH5 iMw4HOAPU17jo3/BJz4V6BLpg8S+PfF/iGeX57g+HLK3s4mGRtUCTcwY8nOSMZzilLEZZF/xb+lz TkxTt7p+XupftF6V++/s/Ttau9+8CSEQ7W7BhmTPQfxAHrx2rg/E/wAa/FGt6Q9p4W0L7Pqj3VrN bzazeh40eGaOQgpHncCIyvDr1r97vD//AATr/Zo0eOKdfA3iDxE9ndc3Wu+JpxuJ6K8cBjRgPXYP Y19AeGP2VPgxpE0Q0T4H+AYrixut1neah4WtdQuFbH3ke5Jl6HBxmuSWZ4CD91OX4fqaxw2Ifkfz ED4jfGDVRbWlpo+mi9uHVVSKzmuC8jNkBVVx1JAx3wcZ7eh6b8Lf2xfFUL3ei/Dfx1ceVP5VxJo3 gGZgsh6ARurnuD375r+r3Q/h/qem27WOlWVvpkFxMpnttA0JLVdpyMv+5K7hgfmPSuwj+Gl3dybb
May 11, 2018 - July 04, 2018
Kolb-Archive.digest.vol-ov
