Kolb-Archive.digest.vol-pg
January 19, 2019 - July 16, 2019
      with my feet. OTOH, Gene's has a full frame and we are trying to keep
      the weight down and keep it Part 103 legal. With no frame, it was way
      too flexible.
      So here is the result, pivots in the front, uses minimal hardware, just
      enough to keep it in shape. When you pull it down into flight position,
      a pin fits through the aft original windshield mounting tab on the
      fuselage frame, one on each side.
      Once the pins are in place, the lever swings down to keep them from
      pulling back out. Locks everything in place.
      Had to modify the fairing with big mounting pads to make the windshield
      pivot points parallel with the side of the fairing, otherwise the
      windshield bulged out with a big gap along the sides.
      Now I just need the weather to warm up and calm down, and we can try out
      the new windshield and the new engine - we also swapped out the free air
      277 for a fan cooled one. Assuming that everything works OK, then we
      modify the 277 to dual ignition.
      Richard Pike
      Kolb MKIII N420P (420ldPoops)
      Kolb Firefly Part 103 legal (Redoing the Firefly windshield)
      Kingsport, TN 3TN0
      Forgiving is tough, being forgiven is wonderful, and God's grace really
      is amazing.
      http://forums.matronics.com/viewtopic.php?p=486857#486857
      http://forums.matronics.com//files/p1070061_medium_316.jpeg
      <http://forums.matronics.com/files/p1070061_medium_316.jpeg>
      http://forums.matronics.com//files/p1070067_medium_192.jpeg
      <http://forums.matronics.com/files/p1070067_medium_192.jpeg>
      http://forums.matronics.com//files/p1070080_medium_182.jpeg
      <http://forums.matronics.com/files/p1070080_medium_182.jpeg>
      http://forums.matronics.com//files/p1070077_medium_996.jpeg
      <http://forums.matronics.com/files/p1070077_medium_996.jpeg>
      http://forums.matronics.com//files/p1070076_medium_142.jpeg
      <http://forums.matronics.com/files/p1070076_medium_142.jpeg>
      http://forums.matronics.com//files/p1070078_medium_210.jpeg
      <http://forums.matronics.com/files/p1070078_medium_210.jpeg>
      http://forums.matronics.com//files/p1070079_medium_178.jpeg
      <http://forums.matronics.com/files/p1070079_medium_178.jpeg>
      http://forums.matronics.com//files/p1070075_medium_446.jpeg
      <http://forums.matronics.com/files/p1070075_medium_446.jpeg>
      http://forums.matronics.com//files/p1070070_medium_429.jpeg
      <http://forums.matronics.com/files/p1070070_medium_429.jpeg>
      br> fts!)
      r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
      rel="noreferrer"
      -List" rel="noreferrer"
      target="_blank">http://www.matronics.com/Navigator?Kolb-List
      rel="noreferrer"
      The older I get, the less tolerant I am of those who are intolerant of
      others.
      If you forward this email, or any part of it, please remove my email
      address before sending.
Subject: Cost to scratch build Ultrastar airframe?
Date: Jan 19, 2019
Greetings, Since Kolb sells the plans for the Ultrastar now, has anyone tried to add up the materials cost to build one? Any rough guess at what the materials would cost? Also, assuming you're in driving distance of Kolb, would you figure it would be about as cheap to buy the materials from them as to buy them somewhere else? There is a very small, yet non-zero chance I might consider building one, so it would be interesting if someone has made a recent estimate of the costs. Still looking for a Slingshot carcass BTW. Cheers, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487095#487095 ________________________________________________________________________________
Subject: Re: Cost to scratch build Ultrastar airframe?
Date: Jan 20, 2019
Just buy a set of plans, get an Aircraft Spruce catalog, make up a bill of material and add it up. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487099#487099 ________________________________________________________________________________
Subject: Help with FS Wing Gap Seal
Date: Jan 20, 2019
I purchased a FS KXP which has a permanently mounted lexon gap seal that bolts into place. The builder never unfolded the plane, but I will be. I purchased some clear vinyl & Velcro to make a new gap seal. Presently the leading edge of the wings rest on & nearly touch the hoop that is above the pilots head when the pins are in place. Here are my questions: 1) How far back under the wing is the gap seal suppose to go? 2) With the leading edge of wing almost touching the hoop, does the gap seal go under the hoop or is it somehow held in place on top of the hoop & then the wings folded on top of the gap seal? Either way, I am six feet tall & with a helmet, I would be nearly touching it or maybe even slightly above the hoop height. Anyone have this problem? 3) Complicating things, the full length windshield rests on the top front edge of the hoop for support against the wind pressure. It is only secured to the nose cone. This setup may be incompatible with folding the folding wing process. My hoop doesnt have any of the tabs that allow the windshield side supports which run to the nosecone like many of the Firestars have. I eventually want to go to a full enclosure for the front. But for now, I would like to just come up with a gap seal that will allow me to fly for awhile. Any suggestions would be appreciated. Richard Swiderski Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487100#487100 ________________________________________________________________________________
Subject: pinging John Hauck
Date: Jan 19, 2019
Hey John, Aren't you close to Wetumpka? Hoping y'all are all ok after the tornado. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 20, 2019
My thoughts, having owned and rebuilt an Ultra Star; Never flown...but am t old that it is the best flyer of the whole Kolb stable..neutral thrust for one..Per Hauck... for starters.very minimal fuselage..the Firestar gear is a definite good mod...the low to the ground prop is always in danger of nicks...the Cuyana engine was good for the time..but I am told that it tended to leak between the thin case halves..Electronic ign on the UL 202 , made for easy starts e ven being inverted. If I had another one, I might try large bicycle wheels to improve prop clearance. The fuel tanks worked but could be improved on today.. All in all...not a good plane to build these days...Likely many sitting h ere and there not flown for years...I would place a want ad on Barnstormers . $1000 dollars or more plus shipping for two wing spars makes me shiver.. .then again...so does the price of hamburger! :-) I gave 1k for mine as a project...the cuyana engine is not worth much...v ery old...35 to 40 years old I think? The 377 or 447 should work. They are old too!! Hirth seems to have mended their reputation...so should be consid ered given that KOlb is using them.. I bought the Firestar II for 6k...with high time 503...and I do not dou bt that you would spend as much building a US... Two Fireflys sold on Barnstormers some time ago for 6 or 7k as I recall. .for both..from the same seller...I could not get a picture before someone , more local beat me to them..Minnesota? but I would have paid shipping... and still have come out...A good Firefly with low time engine is worth 9 to 10 k in my book. I have a boom tube, tail feathers and wings for a Firestar... I want to t urn them into some sort of hybrid not unlike the US...but with a wooden fus elage.. Here is what can be done with a bit of imagination...Bill Bronson's Kolb parts used in a half vw tractor config...Herb Sent with ProtonMail Secure Email. =90=90=90=90=90=90=90 Original Me ssage =90=90=90=90=90=90=90 On Sunday, January 20, 2019 11:28 AM, Rex Rodebush w rote: > > Just buy a set of plans, get an Aircraft Spruce catalog, make up a bill o f material and add it up. > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487099#487099 > =========== =========== =========== =========== =========== ________________________________________________________________________________
Date: Jan 20, 2019
Thanks for the great comments Herb. I pretty much suspect that you can buy most of these planes used for less than the cost of the materials, or at least that's how it works when I sell something. For years, I've wanted to build a steel tube fuselage for some odd reason, and I like the Kolb construction. Unfortunately, the US is the only model they offer full plans for. I may very well buy the plans, since they are available, but I might save it for a future project. As for combo planes, I also have a set of Airbike plans, and thought about maybe combining the Airbike fuselage with Kolb wings (because I don't care for wood construction). Somehow it seems a little too life threatening to eyeball something like that. I'll keep looking around, and see what I can come up with for Kolb projects. Cheers, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487106#487106 ________________________________________________________________________________
Subject: Re: Help with FS Wing Gap Seal
Date: Jan 20, 2019
slingshot003 wrote: > I purchased a FS KXP . > > . s . n . i . p . > > Here are my questions: > > . s . n . i . p . > > ... I am six feet tall & with a helmet, I would be nearly touching it or maybe even slightly above the hoop height. Anyone have this problem? > > . s . n . i . p . > > Richard Swiderski Richard: I had an Original FS with an aluminum/polycarbonate gap seal that went a little over a foot back on the bottom side. I am 6' 2+" with a fairly long torso. A friend had a similar situation (not as tall but a longer torso) in his Original FS. I think Dennis Souder came up with a solution (which I copied). Cut a hole in the underside of the gap seal big enough to receive an inverted 10" aluminum pie pan. That was deep enough to give you an additional 1" plus head room. The angled sides of the pie pan didn't offer any significant restriction for head movement. The best picture I could find is attached. Not very clear but you can see that the top of my helmet is above the bottom surface of the wing. Good luck! -------- George Alexander FS II R503 E-LSA N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487113#487113 Attachments: http://forums.matronics.com//files/gapseal_piepan_127.jpg ________________________________________________________________________________
Date: Jan 20, 2019
just sold an airbike and for an instant, I considered using the Firestar wings...7 rib... I never want to build another set of wood wings....!! The best flying plane I have had is the N3 Pup...The landing gear is a bit too lite for my long strip...and I landed too fast...went long and hit a rise that collapsed the left gear leg... Sits in storage waiting for the mood to strike.. I liked the Fireflys a lot...and would trade the FS II for one...Reg. EAB....waiting for the Gov shut down to end to get the paper work back from Oak city.. Herb Sent with ProtonMail Secure Email. Original Message On Sunday, January 20, 2019 3:25 PM, 13brv3 <13brv3c(at)bellsouth.net> wrote: > > Thanks for the great comments Herb. I pretty much suspect that you can buy most of these planes used for less than the cost of the materials, or at least that's how it works when I sell something. > > For years, I've wanted to build a steel tube fuselage for some odd reason, and I like the Kolb construction. Unfortunately, the US is the only model they offer full plans for. I may very well buy the plans, since they are available, but I might save it for a future project. > > As for combo planes, I also have a set of Airbike plans, and thought about maybe combining the Airbike fuselage with Kolb wings (because I don't care for wood construction). Somehow it seems a little too life threatening to eyeball something like that. > > I'll keep looking around, and see what I can come up with for Kolb projects. > > Cheers, > Rusty > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487106#487106 > ________________________________________________________________________________
From: "DavidGerdeman" <davidrgerdeman(at)gmail.com>
Date: Jan 21, 2019
Rusty, I bought a set of Slingshot plans from the factory last year and built up a material list to price. All the AL tube, not including the Spars and boom tube were $1,380 from TWMetals. I think that included shipping. I tried OnlineMetals but they would not quote anything not listed on their site. I found a source of 6" x .058 but it was the wrong alloy. You can't find the 6" 6063 T6 except from Kolb. I know they have to buy in bulk so I plan to buy from them if/when the time comes. I'm slowly learning SolidWorks as time allows but plan to finish the fuse cage re-design this spring. Whether or not I build it, it will be a good project. You know the plans don't show any steel fittings but most are available from the factory based on the MKIII. I plan to lay it out with rear controls and a 25' span. Call it a super stretch Slingshot or a clipped wing Kolbra and that's what I'm after. Plan on running a 912 with Oratex 6000 covering. All calculations are being performed and reviewed. I'm an engineer and have friends that worked in Aerospace. Taking time to think is what we do. :-) So figure $1,400 for small pipe, $1,500 for big pipe, Maybe $500 for 4130 steel tubing. That's $3,400 plus all the little bits to hold it all together. Add a $10,000 engine and $2000 in covering.... I think it would be a fun project but it's getting as pricey as a nicely appointed Sonex. -------- Sometimes flying, sometimes planning, hopefully soon to be building. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487136#487136 ________________________________________________________________________________
Date: Jan 21, 2019
Rusty by now everyone knows I am tigh...er Frugal....I bought the yellow sling shot shown on the factory site for $6500 as I recall...High time 582. I say...simply..bide your time and buy used..near a third of the price of new many times.. Covering is simple on Kolbs and reasonably cheap and a good way to do value added... Oddly, the list of kolbs for sale on Barnstormers is minimal now...usually two pages...Could be someone is buying them and refurbishing? Would be a good business...Might be going over seas?? That happened in the Sailplane business when the dollar was cheap...relative to European currencies.. I had dibs on a MkIII maybe an extra? Forgetful. with a low time 912s , certified engine for 13k...Did not want to go to West Va. to pick it up...bad decision to be sure...Guy in Pa. who bought it priced the engine for 13k on Barnstormers...:-) Herb Sent with ProtonMail Secure Email. Original Message On Monday, January 21, 2019 10:50 AM, DavidGerdeman wrote: > > Rusty, > I bought a set of Slingshot plans from the factory last year and built up a material list to price. All the AL tube, not including the Spars and boom tube were $1,380 from TWMetals. I think that included shipping. I tried OnlineMetals but they would not quote anything not listed on their site. I found a source of 6" x .058 but it was the wrong alloy. You can't find the 6" 6063 T6 except from Kolb. I know they have to buy in bulk so I plan to buy from them if/when the time comes. > > I'm slowly learning SolidWorks as time allows but plan to finish the fuse cage re-design this spring. Whether or not I build it, it will be a good project. You know the plans don't show any steel fittings but most are available from the factory based on the MKIII. I plan to lay it out with rear controls and a 25' span. Call it a super stretch Slingshot or a clipped wing Kolbra and that's what I'm after. Plan on running a 912 with Oratex 6000 covering. All calculations are being performed and reviewed. I'm an engineer and have friends that worked in Aerospace. Taking time to think is what we do. :-) > > So figure $1,400 for small pipe, $1,500 for big pipe, Maybe $500 for 4130 steel tubing. That's $3,400 plus all the little bits to hold it all together. Add a $10,000 engine and $2000 in covering.... I think it would be a fun project but it's getting as pricey as a nicely appointed Sonex. > > ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- > > Sometimes flying, sometimes planning, hopefully soon to be building. > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487136#487136 > ________________________________________________________________________________
Date: Jan 21, 2019
I've attached several pictures of the gap seal/windshield fairing that I built of composites for a MK IIIX. Gives you the general idea of what and how I fit and built it. If you need more I can provide pictures to try and answer questions. Rick On Sun, Jan 20, 2019 at 2:39 PM slingshot003 wrote: > > =C2=AC=C2=AC=C2=ACI purchased a FS KXP which has a permanently mounted le xon gap seal > that bolts into place. The builder never unfolded the plane, but I will > be. I purchased some clear vinyl & Velcro to make a new gap seal. > Presently the leading edge of the wings rest on & nearly touch the hoop > that is above the pilot=99s head when the pins are in place. Here are my > questions: > > 1) How far back under the wing is the gap seal suppose to go? > 2) With the leading edge of wing almost touching the hoop, does the > gap seal go under the hoop or is it somehow held in place on top of the > hoop & then the wings folded on top of the gap seal? Either way, I am si x > feet tall & with a helmet, I would be nearly touching it or maybe even > slightly above the hoop height. Anyone have this problem? > 3) Complicating things, the full length windshield rests on the top > front edge of the hoop for support against the wind pressure. It is only > secured to the nose cone. This setup may be incompatible with folding th e > folding wing process. My hoop doesn=99t have any of the tabs that allow the > windshield side supports which run to the nosecone like many of the > Firestars have. > I eventually want to go to a full enclosure for the front. But for now, I > would like to just come up with a gap seal that will allow me to fly for > awhile. Any suggestions would be appreciated. =93Richard Swiderski > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487100#487100 > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Jan 21, 2019
Hi David, Great first post! Thanks for the figures. I'd much rather talk about building a Slingshot than an Ultrastar :-) I have a set of Slingshot plans also, and had figured that many of the parts will be the same as the Mk3. That should save some of the tedious welding, and give Kolb some business in the process. I'm only about 100 miles away, so I'd be inclined to just buy the raw materials from them as well if there wasn't a huge difference in price. I figure it's worth a few extra bucks to keep these guys in business. I have a large number of Slingshot frame pictures, but no actual dimensions for the steel tubing or frame. The good news is that much of the cage isn't that critical as far as dimensions go. I'd want to duplicate the wing, engine, tail tube, and landing gear mountings as close as possible, but the less structural bits that hang off the front can probably safely vary some. For your purposes, I wonder why you're not starting with a Kolbra. That probably seems closer to what you want than the SS. I want single place, and will probably use the HKS engine. I have an RV-3B that goes nowhere fast, so I think I'll be happy going nowhere at half that speed. Feel free to drop me an email if you want to chat more about this offline. Cheers, Rusty 13brv3(at)gmail.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487139#487139 ________________________________________________________________________________
Date: Jan 21, 2019
Pfatchantz(at)protonmail. wrote: > Rusty > > by now everyone knows I am tigh...er Frugal....I bought the yellow sling shot shown on the factory site for $6500 as I recall...High time 582. > > I say...simply..bide your time and buy used..near a third of the price of new many times.. Covering is simple on Kolbs and reasonably cheap and a good way to do value added... Herb, I'm still looking for an airframe, and I have a line on one that will likely come up for sale at some point. I'd still like more of a project ideally, particularly if it's cheaper, but I do realize what deals you can get on used aircraft at times. If I find a complete airframe at a good price, I'll likely grab it, then focus my project needs on something else, like maybe an electric plane. Cheers, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487140#487140 ________________________________________________________________________________
Date: Jan 21, 2019
Here are the gap seal plans for the MKIII, but the lengths are about the same, obviously the width is different. The gap seal starts on sheet 30. http://oh2fly.net/oldpoops/Lexan%20rear%20enclosure.html The idea of riveting an upside down aluminum pan to the underside of the front part sounds really good. Here is the underside of the front of ours - I am 5' 10" and it is a tight fit with a helmet. W/O the helmet it is a lot easier. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal (Ready for a test flight on the new 277) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487141#487141 Attachments: http://forums.matronics.com//files/p1070090_medium_109.jpeg ________________________________________________________________________________
Date: Jan 21, 2019
Rusty I have an airframe for sale that you might want to take a look at. It's a Firestar 2 with the tall Slingshot landing gear. I tried to send you an e-mail with photos but it came back as undeliverable with a bad address. If you would be kind enough to sendme a direct e-mail (separate from the Kolb list) I will be happy to send you photos and info on this airframe. victorbravo at sbcglobal dot net Bill Berle -------------------------------------------- On Mon, 1/21/19, Rusty wrote: I'm still looking for an airframe, and I have a line on one that will likely come up for sale at some point. I'd still like more of a project ideally, particularly if it's cheaper, but I do realize what deals you can get on used aircraft at times. If I find a complete airframe at a good price, I'll likely grab it, ________________________________________________________________________________
Date: Jan 21, 2019
Meeee Toooo!!:-) Bill...Rusty has dibs certainly...but I have all the other parts...wings boom tube gear legs tail feathers...so post some pics and a price...Herb Sent with ProtonMail Secure Email. Original Message On Monday, January 21, 2019 12:52 PM, Bill Berle wrote: > > Rusty I have an airframe for sale that you might want to take a look at. It's a Firestar 2 with the tall Slingshot landing gear. I tried to send you an e-mail with photos but it came back as undeliverable with a bad address. If you would be kind enough to sendme a direct e-mail (separate from the Kolb list) I will be happy to send you photos and info on this airframe. victorbravo at sbcglobal dot net > > Bill Berle > > > ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- > > On Mon, 1/21/19, Rusty wrote: > > I'm still looking for an airframe, and I have a line on one that will likely come up for sale at some point. I'd still like more of a project ideally, particularly if it's cheaper, but I do realize what deals you can get on used aircraft at times. If I find a complete airframe at a good price, I'll likely grab it, > ________________________________________________________________________________
Date: Jan 21, 2019
David and Rusty Cannot think of any reason to get in the rear seat of a Kolb Slingshot...!! ??? Same for the Firestar II...Maybe a pet dog :-) Nice place for some camping gear however. Herb Sent with ProtonMail Secure Email. Original Message On Monday, January 21, 2019 12:14 PM, 13brv3 <13brv3c(at)bellsouth.net> wrote: > > Hi David, > > Great first post! Thanks for the figures. I'd much rather talk about building a Slingshot than an Ultrastar :-) > > I have a set of Slingshot plans also, and had figured that many of the parts will be the same as the Mk3. That should save some of the tedious welding, and give Kolb some business in the process. I'm only about 100 miles away, so I'd be inclined to just buy the raw materials from them as well if there wasn't a huge difference in price. I figure it's worth a few extra bucks to keep these guys in business. > > I have a large number of Slingshot frame pictures, but no actual dimensions for the steel tubing or frame. The good news is that much of the cage isn't that critical as far as dimensions go. I'd want to duplicate the wing, engine, tail tube, and landing gear mountings as close as possible, but the less structural bits that hang off the front can probably safely vary some. > > For your purposes, I wonder why you're not starting with a Kolbra. That probably seems closer to what you want than the SS. I want single place, and will probably use the HKS engine. I have an RV-3B that goes nowhere fast, so I think I'll be happy going nowhere at half that speed. > > Feel free to drop me an email if you want to chat more about this offline. > > Cheers, > Rusty > 13brv3(at)gmail.com > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487139#487139 > ________________________________________________________________________________
Date: Jan 21, 2019
I've had the pleasure (?) of riding in the back of a SS, but no one ever rode in the back of mine. It makes a good place for a fuel tank. Rusty (address maybe corrected) Pfatchantz(at)protonmail. wrote: > David and Rusty > > Cannot think of any reason to get in the rear seat of a Kolb Slingshot...!! ??? Same for the Firestar II...Maybe a pet dog :-) Nice place for some camping gear however. > > Herb > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487147#487147 ________________________________________________________________________________
Date: Jan 22, 2019
It's true the Firestar and SS are really 1 1/2 person planes but I fly mostly by myself now with a very rare passenger. I quit renting 172's and normally rent a little 150/152 when I feel like just blasting around or playing in a cross wind. Thruth is I own plans for many planes and while the SS is very high on my list of favorites, here in Ohio there isn't much to do with the low end of the speed envelope. The $25k-$30k it will cost to complete can be a Sonex or even a Grumman AA5. So my tinkering side wants to design the front cage just to clear my head, guess we will see if anything comes of it. -------- Sometimes flying, sometimes planning, hopefully soon to be building. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487168#487168 ________________________________________________________________________________
Date: Jan 22, 2019
wonder if anyone has tried a clipped wing Firestar?? Not so sure about a 22 foot wing span...24? Sent with ProtonMail Secure Email. Original Message On Tuesday, January 22, 2019 8:07 AM, DavidGerdeman wrote: > > It's true the Firestar and SS are really 1 1/2 person planes but I fly mostly by myself now with a very rare passenger. I quit renting 172's and normally rent a little 150/152 when I feel like just blasting around or playing in a cross wind. > > Thruth is I own plans for many planes and while the SS is very high on my list of favorites, here in Ohio there isn't much to do with the low end of the speed envelope. The $25k-$30k it will cost to complete can be a Sonex or even a Grumman AA5. So my tinkering side wants to design the front cage just to clear my head, guess we will see if anything comes of it. > > --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- > > Sometimes flying, sometimes planning, hopefully soon to be building. > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487168#487168 > ________________________________________________________________________________
Date: Jan 22, 2019
A Firefly is a clipped wing Firestar. The Fire Fly and Sling Shot both have 22 foot wing span. Both fly very well. I've flown passengers in the Sling Shot. Always enjoyed the quick roll rate of both models. I flew the Sling Shot before I flew a Fire Fly. Was a little apprehensive about those stubby little wings. My first flight was out of Oshkosh. It seemed to take a lot of power to taxi and a little slow on the take off. Also landed with a quick, short roll out. I mentioned this to Dennis Souder when I landed. He reached under the seat and turned off the parking brake with a big grin. After that, it ground handled much better. First Kolb I flew with a parking brake. I didn't have a clue. Glad I didn't put this new aircraft on its nose. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Pfatchantz Sent: Tuesday, January 22, 2019 9:12 AM Subject: Re: Kolb-List: Re: Cost to scratch build Ultrastar airframe? wonder if anyone has tried a clipped wing Firestar?? Not so sure about a 22 foot wing span...24? ________________________________________________________________________________
Date: Jan 22, 2019
I did quite a bit of searching for "clipped wing firestar", and it has been done, but there wasn't much detail. I think you could come pretty close to a SS, but it wouldn't have the stronger 6" tubes. Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487175#487175 ________________________________________________________________________________
Date: Jan 22, 2019
Bet the nose cone wasn't 500 bucks back then..:-) I think the nose cone could be abs molded...cost of the mold might be prohibitive.. Herb Sent with ProtonMail Secure Email. Original Message On Tuesday, January 22, 2019 9:32 AM, John Hauck wrote: > > A Firefly is a clipped wing Firestar. > > The Fire Fly and Sling Shot both have 22 foot wing span. Both fly very well. I've flown passengers in the Sling Shot. Always enjoyed the quick roll rate of both models. I flew the Sling Shot before I flew a Fire Fly. Was a little apprehensive about those stubby little wings. My first flight was out of Oshkosh. It seemed to take a lot of power to taxi and a little slow on the take off. Also landed with a quick, short roll out. I mentioned this to Dennis Souder when I landed. He reached under the seat and turned off the parking brake with a big grin. After that, it ground handled much better. First Kolb I flew with a parking brake. I didn't have a clue. Glad I didn't put this new aircraft on its nose. > > john h > mkIII > Titus, Alabama > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Pfatchantz > Sent: Tuesday, January 22, 2019 9:12 AM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: Cost to scratch build Ultrastar airframe? > > > wonder if anyone has tried a clipped wing Firestar?? Not so sure about a 22 foot wing span...24? > ________________________________________________________________________________
Date: Jan 22, 2019
Don't think you can break a 5" tubular wing spar, especially on a 22' wing. Don't know of anyone that has succeeded in breaking any Kolb wing spar, 5 or 6 inch. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of 13brv3 Sent: Tuesday, January 22, 2019 9:36 AM Subject: Kolb-List: Re: Cost to scratch build Ultrastar airframe? I did quite a bit of searching for "clipped wing firestar", and it has been done, but there wasn't much detail. I think you could come pretty close to a SS, but it wouldn't have the stronger 6" tubes. Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487175#487175 ________________________________________________________________________________
Date: Jan 22, 2019
Agreed. I recently re-read the "flight test to destruction" article about what it took to break an Ultrastar, and the wing was upgraded after that. It would be really hard to break for sure. Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487178#487178 ________________________________________________________________________________
Date: Jan 22, 2019
Thanks to all who sent replies. I attached a pic of my gap seal. Do any of you with a rigid gap seal have it set up so it stays in place & you just fold the wings into it? As you can see from my picture, the wind shield rests on top of the center section hoop and continues up about 1 1/2". With the center section mounted, the wing leading edge tubes hit the front of the gap seal & prevents the wing from mating with its anchoring pin. If the wing is first folded all the way forward & pinned, then the wind shield sticking above he center section hoop blocks the gap seal from being inserted. In order for this to have worked, I am thinking the wind shield must have been put on after the gap seal was installed. Maybe I am missing something here? I might be able to use this gap seal if I cut the top of the wind shield flush with the top of the hoop, but since the wind shield is not physically attached to the hoop (only to the nose cone) it might not be secure enough to handle any wind side loads as when crabbing. I am looking for a quick fix so I can get this into the air. I will do full or semi-full enclosure down the road. Any ideas out there? -Richard Swiderski Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487185#487185 Attachments: http://forums.matronics.com//files/lexon_gap_seal_160.jpg http://forums.matronics.com//files/lexon_gap_seal_163.jpg ________________________________________________________________________________
Date: Jan 22, 2019
Richard, I don't think you can get there from here. It's just the geometry of the way the wing swings. What you might consider is having the wings butt up against the gap seal rather than having them slide into it. Use some sailplane gap seal tape when the plane is all rigged. That's the solution I used on the Mk IIIX. Rick On Tue, Jan 22, 2019 at 5:25 PM slingshot003 wrote: > > Thanks to all who sent replies. I attached a pic of my gap seal. Do any > of you with a rigid gap seal have it set up so it stays in place & you ju st > fold the wings into it? As you can see from my picture, the wind shield > rests on top of the center section hoop and continues up about 1 1/2". > With the center section mounted, the wing leading edge tubes hit the fron t > of the gap seal & prevents the wing from mating with its anchoring pin. If > the wing is first folded all the way forward & pinned, then the wind shie ld > sticking above he center section hoop blocks the gap seal from being > inserted. In order for this to have worked, I am thinking the wind shield > must have been put on after the gap seal was installed. Maybe I am missi ng > something here? > > I might be able to use this gap seal if I cut the top of the wind shield > flush with the top of the hoop, but since the wind shield is not physical ly > attached to the hoop (only to the nose cone) it might not be secure enoug h > to handle any wind side loads as when crabbing. > > I am looking for a quick fix so I can get this into the air. I will do > full or semi-full enclosure down the road. Any ideas out there? -Richard > Swiderski > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487185#487185 > > > Attachments: > > http://forums.matronics.com//files/lexon_gap_seal_160.jpg > http://forums.matronics.com//files/lexon_gap_seal_163.jpg > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Jan 22, 2019
The wing=99s leading edge has a 1-1/2=9D tube that extends about 6=9D past the inboard rib and into the center section leading edge on my fire star ll Talking with Kolb they said that the 6=9D extension was not critical t o the wing and could be shortened (or cut flush with the inboard wing rib) t o allow easier wing folding. Call them to verify that fact, I found l Could fold the wing without shortening. Top section of my center gap seal is non removable and the wing can slowly swing into position with Velcro strip to seal and prevent chafing. They overlap about 1=9D Sent from my iPhone > On Jan 22, 2019, at 8:09 PM, Richard Girard wrote: > > Richard, I don't think you can get there from here. It's just the geometry of the way the wing swings. What you might consider is having the wings but t up against the gap seal rather than having them slide into it. Use some sa ilplane gap seal tape when the plane is all rigged. That's the solution I us ed on the Mk IIIX. > > Rick > >> On Tue, Jan 22, 2019 at 5:25 PM slingshot003 wrote: >> >> Thanks to all who sent replies. I attached a pic of my gap seal. Do any o f you with a rigid gap seal have it set up so it stays in place & you just f old the wings into it? As you can see from my picture, the wind shield rest s on top of the center section hoop and continues up about 1 1/2". With the center section mounted, the wing leading edge tubes hit the front of the ga p seal & prevents the wing from mating with its anchoring pin. If the wing i s first folded all the way forward & pinned, then the wind shield sticking a bove he center section hoop blocks the gap seal from being inserted. In orde r for this to have worked, I am thinking the wind shield must have been put o n after the gap seal was installed. Maybe I am missing something here? >> >> I might be able to use this gap seal if I cut the top of the wind shield f lush with the top of the hoop, but since the wind shield is not physically a ttached to the hoop (only to the nose cone) it might not be secure enough to handle any wind side loads as when crabbing. >> >> I am looking for a quick fix so I can get this into the air. I will do f ull or semi-full enclosure down the road. Any ideas out there? -Richard Swi derski >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=487185#487185 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/lexon_gap_seal_160.jpg >> http://forums.matronics.com//files/lexon_gap_seal_163.jpg >> >> >> >> ========== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?Kolb-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========== >> >> >> > > > -- > =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx > > ________________________________________________________________________________
Date: Jan 23, 2019
I can save somebody a lot of wasted time on this. I spent MONTHS screwing around trying to build center section fairings and seals that stayed in place as you unfold the wings, hoping to make the wings just seal against the gap seal automatically. I had one that butted up against the wing root ribs, I had one where the wings slid underneath the gap seal, that needed a special "shoehorn" tool to guide the wing under the seal. I modified all of these three or four times, scratched my head and modified some more. I'm not kidding when I say that several months were spent on this, trying to come up with something. The short answer is that it is a difficult puzzle to solve, because there are several parts or components that physically or geometrically conflict with each other. And then on top of that, the Kolb was designed so that the gap seal is supported by the wings... there is little or no solid structure in the RIGHT place to permanently mount the gap seal forward of the spar carry through. My installation was further complicated by having a non-standard engine, which had parts and pieces that were shaped differently than the Rotax, including three oil lines that "penetrated" through the gap seal and required delicate cutouts and removable pieces. So affter all those months and piles of discarded parts, I went back to a relatively simple piece of .016 bent aluminum that attached to the wing with Velcro. After everything I learned, I can say that the Kolb wing folding design makes it very VERY time consuming and challenging to make a center gap seal that stays in place and the wings just unfold and automatically seal against. At the end of the day, the original design shown on the plans (for the Firestar it is a piece of lexan or plexiglas held in place with velcro) will be the easiest way by far. I can hear John H laughing all the way from Alabama :) Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Tue, 1/22/19, Richard Girard wrote: Subject: Re: Kolb-List: Re: Help with FS Wing Gap Seal To: "kolb-list(at)matronics.com" Date: Tuesday, January 22, 2019, 8:09 PM Richard, I don't think you can get there from here. It's just the geometry of the way the wing swings. What you might consider is having the wings butt up against the gap seal rather than having them slide into it. Use some sailplane gap seal tape when the plane is all rigged. That's the solution I used on the Mk IIIX. Rick On Tue, Jan 22, 2019 at 5:25 PM slingshot003 wrote: --> Kolb-List message posted by: "slingshot003" Thanks to all who sent replies. I attached a pic of my gap seal. Do any of you with a rigid gap seal have it set up so it stays in place & you just fold the wings into it? As you can see from my picture, the wind shield rests on top of the center section hoop and continues up about 1 1/2". With the center section mounted, the wing leading edge tubes hit the front of the gap seal & prevents the wing from mating with its anchoring pin. If the wing is first folded all the way forward & pinned, then the wind shield sticking above he center section hoop blocks the gap seal from being inserted. In order for this to have worked, I am thinking the wind shield must have been put on after the gap seal was installed. Maybe I am missing something here? I might be able to use this gap seal if I cut the top of the wind shield flush with the top of the hoop, but since the wind shield is not physically attached to the hoop (only to the nose cone) it might not be secure enough to handle any wind side loads as when crabbing. I am looking for a quick fix so I can get this into the air. I will do full or semi-full enclosure down the road. Any ideas out there? -Richard Swiderski Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487185#487185 Attachments: http://forums.matronics.com//files/lexon_gap_seal_160.jpg http://forums.matronics.com//files/lexon_gap_seal_163.jpg ========== -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List ========== FORUMS - eferrer" target="_blank">http://forums.matronics.com ========== WIKI - errer" target="_blank">http://wiki.matronics.com ========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ========== -- Blessed are the cracked, for they shall let in the light. Groucho Marx ________________________________________________________________________________
Date: Jan 23, 2019
Who? Me? Not me. I've also been down that road. Sometimes we have to see for ourselves before we give up. I wish I still had that drive I had way back then to experiment and get "stuff" done. So much to do. So little time. Go have fun and don't worry about it. ;-) john h MKIII Titus, Alabama I can hear John H laughing all the way from Alabama :) Bill Berle ________________________________________________________________________________
Date: Jan 23, 2019
Cut off the top part of the windshield that projects higher than the hoop. Make up a piece of aluminum that can replace the top of the windshield that you just cut off. Shape it to seal the area above the windshield to the gap seal. Maybe put some velcro on it where it touches the gap seal, if necessary. Get some blind nuts like these or similar and put about three of them on the inside of the hoop. https://www.aircraftspruce.com/catalog/hapages/anchornutsmk1000.php?clickkey=3026140 Install the wings, install the gap seal, install the new windshield top piece that you just made, and then put in some screws to hold the windshield and windshield top piece securely to the hoop. You have added one small step to the assembly process, but you made a lot of other things simpler. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal (Ready for a test flight on the new 277) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487201#487201 ________________________________________________________________________________
Subject: MK II Weight and Balance
Date: Jan 24, 2019
I did some searching on the list here and have not found what I am looking for in regards to W&B for Kolbs in general, not to mention MKII. I may have missed it so pardon my re-asking. While going through my Light Sport ground school, we have been going over W&B extensively. So now that my rebuild is progressing I'm starting to think about my MKII W&B. As far as the weights, arms and moments I'm good with that. My big question is where is the center of lift/pressure? I've looked through the plans and build manual and am not seeing any reference. Per my understanding it is easy to determine the CG, it is determining if the CG falls within the acceptable envelope of % of wing cord that I'm not finding. Thanks in advance. -------- Mark Twinstar MKII Great Bend, PA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487226#487226 ________________________________________________________________________________
Date: Jan 24, 2019
Subject: Re: MK II Weight and Balance
it is determining if the CG falls within the acceptable envelope of % of wing cord that I'm not finding. Thanks in advance. -------- Mark Mark > You said you can find the center of gravity. Take the center of gravity measurement call it cg. Cg times 100 then devide by the measurement of the wing cord (should be listed in the plans) the wing chord for example in the Mark 3 is listed in the plans at 66 in. Example for mkiii with 66 inch wing cord. Cg 20 inches (20 X 100) =C3=B7 66 = 30.3 % of wing cord My mkiii plans say the results should be between 25 and 35 % Hope this helps Boyd Young Mkiii Utah ________________________________________________________________________________
Date: Jan 24, 2019
All is good. Tornado was 10.0 miles south of hauck's holler and 1.0 mile north of my girl friend Nell's home in Wetumpka. Thanks for asking. john h Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Saturday, January 19, 2019 6:51 PM Subject: Kolb-List: pinging John Hauck Hey John, Aren't you close to Wetumpka? Hoping y'all are all ok after the tornado. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 24, 2019
Mail is a little slow during this cold wet weather. Took 5 days for this one to make it through the system. ;-) john h Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck Sent: Thursday, January 24, 2019 10:16 AM Subject: RE: Kolb-List: pinging John Hauck All is good. Tornado was 10.0 miles south of hauck's holler and 1.0 mile north of my girl friend Nell's home in Wetumpka. Thanks for asking. john h Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Saturday, January 19, 2019 6:51 PM Subject: Kolb-List: pinging John Hauck Hey John, Aren't you close to Wetumpka? Hoping y'all are all ok after the tornado. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 24, 2019
The center of pressure is not anything that is important during the weight and balance. Center of Pressure is an aerodynamic factor of the wing's airfoil, and is very important during the design and engineering phase. The aero engineer(s) determine the Cp. Then they determinea safe CG range or envelope (which is based on where the Cp is, among other things). The reason that Cp is not shown on the plans is that (for most purposes) it's of no concern to the mechanic or the pilot, only the designers and engineers. All the mechanic / technician / inspector needs to be concerned about during "weight and balance" is... weight (in pounds or kilograms) and balance (as in the center of gravity) :). Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities -------------------------------------------- On Thu, 1/24/19, Mark K wrote: My big question is where is the center of lift/pressure? I've looked through the plans and build manual and am not seeing any reference. ________________________________________________________________________________
Date: Jan 24, 2019
Richard Pike, Your suggestion is the only logical solution if I am to keep the full length windshield without any major modifications, regardless if I keep the lexon gap seal or go with a fabric or vinyl one. I may just weld 3 tabs to the bottom of the hoop and rivet the shortened windshield to the tabs, then just velcro something to seal the gap between the windshield and the gap seal. This would get me flying until I commit to a full enclosure design. -Richard Swiderski Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487235#487235 ________________________________________________________________________________
Date: Jan 24, 2019
Been years Richard, since we stopped by to see your Geo powered Kolb and custom built trailer. Glad to see youre into it. G Aman Sent from my iPhone > On Jan 24, 2019, at 1:11 PM, slingshot003 wrote: > > > Richard Pike, > > Your suggestion is the only logical solution if I am to keep the full length windshield without any major modifications, regardless if I keep the lexon gap seal or go with a fabric or vinyl one. I may just weld 3 tabs to the bottom of the hoop and rivet the shortened windshield to the tabs, then just velcro something to seal the gap between the windshield and the gap seal. This would get me flying until I commit to a full enclosure design. -Richard Swiderski > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487235#487235 > > > > > > > > > ________________________________________________________________________________
Date: Jan 24, 2019
Guys, thanks for the info. Very helpful. Where can it is indicated on the plans for build manual the allowable envelope for the CG? % wing chord? Thanks in advance. -------- Mark Twinstar MKII Great Bend, PA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487241#487241 ________________________________________________________________________________
Date: Jan 24, 2019
Can't say anything about the MKII, but for the MKIII scroll to sheet 41: http://oh2fly.net/oldpoops/Lexan%20rear%20enclosure.html I would think that they are pretty similar. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal (Ready for a test flight on the new 277) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487246#487246 ________________________________________________________________________________
Subject: Kolb TwinStar Plans
Date: Jan 24, 2019
I built, enjoyed, and instructed with a Kolb TwinStar (1989 version) for 20 years. I now wish I would have kept the little plane. I'm now looking for someone who might have the plans and manual for a Kolb TwinStar (about a 1989 version) so I can build another one. Kolb no longer sells this model. Please let me know if anyone knows where I can find plans and manual. leblancds at cox dot net, Great little plane, I'd like to install a four cycle or electric engine on one. Thanks for your response. -------- The Past is History The Future is a Mystery Today is a Gift Thats Why They Call it the Present Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487247#487247 ________________________________________________________________________________
Date: Jan 25, 2019
Richard, Thanks for the great info. These diagrams are part of my build manual for plans. Mark -------- Mark Twinstar MKII Great Bend, PA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487251#487251 ________________________________________________________________________________
Date: Jan 25, 2019
Gary, thanks for the kind words. It is exciting to being close to flying again. -Richard S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487260#487260 ________________________________________________________________________________
Date: Jan 27, 2019
Richard, Thanks, I meant to type this information was "not" in my build manual or on the plans. Much appreciated! -------- Mark Twinstar MKII Great Bend, PA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487295#487295 ________________________________________________________________________________
Date: Jan 27, 2019
Subject: pics of my third iteration of the Mtn bike brakes..
SGVyZSBpcyBhIHBpYy4uLkJyYWtlcyBhcmUgbXRuIGJpa2UuLi5Hb3R0YSBoYXZlIHRydWUgcmlt cyBvZiBjb3Vyc2Ugb3IgYSBsYXRoZSB0byB0cnVlIHRoZW0gdXAuLi5vciBiZSB3aWxsaW5nIHRv IHRyaWFsIGFuZCBlcnJvciB3aXRoIHNoaW1zLi4ub25lIG1vdW50cyBmb3J3YXJkIGFuZCB0aGUg b3RoZXIgbW91bnRzIHJlYXJ3YXJkLi4gbGl0ZSBhbmQgZWZmZWN0aXZlLi5OYXR1cmFsbHkgSSBn ZXQgdGhlbSBmb3IgYSBidWNrIG9yIHNvIGF0IGEgc2FsdmFnZSB5YXJkLi4uLjotKSBIZXJiIFtJ TUdfMTEzOS5KUEddCgpTZW50IHdpdGggW1Byb3Rvbk1haWxdKGh0dHBzOi8vcHJvdG9ubWFpbC5j b20pIFNlY3VyZSBFbWFpbC4 ________________________________________________________________________________
Date: Jan 27, 2019
Subject: close up of my third build firefly...
dGhpcyBwaWMgc2hvd3MgdGhlIGZ1bGwgZW5jbG9zdXJlLi4uaXQgZmFzdGVucyB3aXRoIGEgaW5j aCBieSBpbmNoIGFuZ2xlIHRvIHRoZSB0b3AgbG9uZ2Vyb24gb24gdGhlIGxlZnQgc2lkZSBhbmQg dHdvIHJpdmV0cyBhdCA4IGFuZCAxMCBhbSBvbiB0aGUgbGVmdCBzaWRlIG9mIHRoZSBub3NlIGNv bmUgYW5kIHRoZSByZWFyIGJvdyBhbGxvdyB0aGUgcmlnaHQgc2lkZSB0byBsaWZ0IGNvbXBsZXRl bHkgdXAuLi5UaGUgcmlnaHQgYW5nbGUgYWx1bWludW0gaXMgZmFzdGVuZWQgdG8gdGhlIGxleGFu IGFuZCBoYXMgYSB0YXBlcmVkIHNjcmV3IGF0IHRoZSBmcm9udCBvZiB0aGUgYW5nbGUgdGhhdCBz bGlkZXMgaW50byBhIGhvbGUgaW4gdGhlIHRhYiB0aGF0IGhvbGRzIHRoZSBub3NlIGJvd2wuLi50 aGUgcmVhciBvZiB0aGUgYW5nbGUgaGFzIGEgbGF0Y2guLi4gVG8gZW50ZXIuLi5qdXN0IGRvbiBh IGNhcCBhbmQgcmFpc2UgdGhlIGxleGFuIGFuZCByZXN0IGl0IG9uIHlvdXIgaGVhZC4uLi4gS2Vl cHMgdGhlIGhhaXIgb2lsIG9mZiBvZiB0aGUgbGV4YW4hISA6LSkKICAgVGhpcyBiaXJkIGdvdCAi ZmFjdG9yeSBidWlsdCIgcmF2ZXMgZnJvbSB0aGUga29sYiBndXlzIGluIHRoZSBTdC4gTG91aXMg YXJlYS4uLlZlcnkgc2F0aXNmeWluZy4uZ3Vlc3MgaWYgb25lIGRvZXMgaXQgZW5vdWdoLi4uZ29v ZCB0aGluZ3MgY2FuIGhhcHBlbi4uLmtpZHMgaW4gdGhlIG90aGVyIGV4YW1wbGUuLi4uOi0pICAg SGVyYiBbSU1HXzExMTUuSlBHXQoKU2VudCB3aXRoIFtQcm90b25NYWlsXShodHRwczovL3Byb3Rv bm1haWwuY29tKSBTZWN1cmUgRW1haWwu ________________________________________________________________________________
Date: Jan 27, 2019
Can't speak to the Mk II specifically but the 25 to 35% is probably a nice conservative range that will not catch you out. I've flown the Mk III at 1200 lb loading and cg calculated at 18%. I had 1/2" between the stick and the seat frame tube. Not a lot of margin but she flew with fingertip pressure and flared nicely. At that weight with horizontal stab gap seals (stabilizer to boom tube) I put her into a stall and held her in it for 1000' using only rudder input to keep the wings level. When I released back pressure she flew away. I've flown her at 40% at design weight (1000 lb) with no problems, too. Stick pressures were light but not necessarily too light. In both cases I was flying on a high pressure day with no discernible convective activity. Turns were limited to 30 degrees bank. I don't advocate flying at these CG extremes but for phase 1 testing only. My personal limits are 20 to 35% for everyday flying. If you decide to test at those or similar limits do so ONLY after you have some time in the airplane and approach further limits gradually. I highly recommend horizontal stabilizer seals to the boom tube. They really increase rudder authority. If you're working toward a Sport Pilot ticket as well as rebuilding a Mk II, please have a more experienced pilot do the first flights of your airplane then give you some dual once it is out of phase 1. Rick Girard PS When doing measurements to calculate moment arms be sure the aircraft is positioned properly. In general this is with horizontal stabilizer level. If the Mk II has specific instructions in the plans use them. As you're just learning weight and balance you might want to consider using a zero point that is in front of the nose so that all measurements are positive. Having to screw around with negative and positive arms can be tricky. Good luck and have fun. On Thu, Jan 24, 2019 at 8:54 AM Mark K wrote: > > I did some searching on the list here and have not found what I am lookin g > for in regards to W&B for Kolbs in general, not to mention MKII. I may > have missed it so pardon my re-asking. > While going through my Light Sport ground school, we have been going over > W&B extensively. So now that my rebuild is progressing I'm starting to > think about my MKII W&B. > As far as the weights, arms and moments I'm good with that. My big > question is where is the center of lift/pressure? I've looked through th e > plans and build manual and am not seeing any reference. > Per my understanding it is easy to determine the CG, it is determining if > the CG falls within the acceptable envelope of % of wing cord that I'm no t > finding. > Thanks in advance. > > -------- > Mark > Twinstar MKII > Great Bend, PA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487226#487226 > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Jan 28, 2019
QWN0dWFsbHkgdGhleSBhcmUgdW5hYmxlIHRvIHdhbGsuLi4uZnVsbCBvZiBob3QgZG9ncyBhbmQg YmFsb25leSEhICBUb3VnaCBsaWZlLi4uISEKCnRoZSBmdWxsIGVuY2xvc3VyZSBpcyBhIHNpbXBs ZSBkZXNpZ24gYW5kIGZvbGxvd3MgdGhlIGxpbmVzIG9mIHRoZSBmdWxsIGVuY2xvc3VyZSBvZiB0 aGUgZmFjdG9yeS4uLk15ICBwbGFuIGlzIHRvIGRvIHRoaXMgb24gdGhlIEZpcmVzdGFyIElJIHRo YXQgSSBub3cgb3duLi4uLnRob3VnaCBJIGFtIGEgYml0IGJvdGhlcmVkIGJ5ICB0aGUgY3Jvb2tl ZCB1cHBlciBsb25nZXJvbiBhbmQgaXRzIGJlbmQgYXQgdGhlIHRocm90dGxlIGFyZWEuLi4KICBI ZXJiCgpTZW50IHdpdGggW1Byb3Rvbk1haWxdKGh0dHBzOi8vcHJvdG9ubWFpbC5jb20pIFNlY3Vy ZSBFbWFpbC4KCuKAkOKAkOKAkOKAkOKAkOKAkOKAkCBPcmlnaW5hbCBNZXNzYWdlIOKAkOKAkOKA kOKAkOKAkOKAkOKAkApPbiBTdW5kYXksIEphbnVhcnkgMjcsIDIwMTkgNTo1OCBQTSwgU3R1YXJ0 IEhhcm5lciA8c3R1YXJ0QGhhcm5lcmZhcm0ubmV0PiB3cm90ZToKCj4gTmljZSB3b3JrIEhlcmIh Cj4KPiBUb28gYmFkIHlvdXIgcG9vY2hlcyBhcmUgc3RhcnZpbmcgc28gbXVjaCB0aGV5IGhhZCB0 byBjb2xsYXBzZSByaWdodCBvbiB0aGUgdGF4aXdheS4gKGRvbuKAmXQgbWFrZSBtZSBjb21lIGJh Y2sgZG93biB0aGVyZSB0byBtYWtlIHN1cmUgdGhleSBhcmUgZ2V0dGluZyBlbm91Z2ggYXR0ZW50 aW9uKS4KPgo+IElmIEkgZXZlciBnZXQgYmFjayB0byBmbHlpbmcgeW91ciB3aW5kc2hpZWxkIGlk ZWEgbXkgZ2V0IGEgY2xvc2VyIGxvb2suCj4KPiBIYXZlIGZ1biEKPgo+IFN0dWFydAo+Cj4gRG8g bm90IGFyY2hpdmUKPgo+IFsgXQo+Cj4gRnJvbTogb3duZXIta29sYi1saXN0LXNlcnZlckBtYXRy b25pY3MuY29tIFttYWlsdG86b3duZXIta29sYi1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBP biBCZWhhbGYgT2YgUGZhdGNoYW50ego+IFNlbnQ6IFN1bmRheSwgSmFudWFyeSAyNywgMjAxOSA1 OjA2IFBNCj4gVG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29tCj4gU3ViamVjdDogS29sYi1MaXN0 OiBjbG9zZSB1cCBvZiBteSB0aGlyZCBidWlsZCBmaXJlZmx5Li4uCj4KPiB0aGlzIHBpYyBzaG93 cyB0aGUgZnVsbCBlbmNsb3N1cmUuLi5pdCBmYXN0ZW5zIHdpdGggYSBpbmNoIGJ5IGluY2ggYW5n bGUgdG8gdGhlIHRvcCBsb25nZXJvbiBvbiB0aGUgbGVmdCBzaWRlIGFuZCB0d28gcml2ZXRzIGF0 IDggYW5kIDEwIGFtIG9uIHRoZSBsZWZ0IHNpZGUgb2YgdGhlIG5vc2UgY29uZSBhbmQgdGhlIHJl YXIgYm93IGFsbG93IHRoZSByaWdodCBzaWRlIHRvIGxpZnQgY29tcGxldGVseSB1cC4uLlRoZSBy aWdodCBhbmdsZSBhbHVtaW51bSBpcyBmYXN0ZW5lZCB0byB0aGUgbGV4YW4gYW5kIGhhcyBhIHRh cGVyZWQgc2NyZXcgYXQgdGhlIGZyb250IG9mIHRoZSBhbmdsZSB0aGF0IHNsaWRlcyBpbnRvIGEg aG9sZSBpbiB0aGUgdGFiIHRoYXQgaG9sZHMgdGhlIG5vc2UgYm93bC4uLnRoZSByZWFyIG9mIHRo ZSBhbmdsZSBoYXMgYSBsYXRjaC4uLiBUbyBlbnRlci4uLmp1c3QgZG9uIGEgY2FwIGFuZCByYWlz ZSB0aGUgbGV4YW4gYW5kIHJlc3QgaXQgb24geW91ciBoZWFkLi4uLiBLZWVwcyB0aGUgaGFpciBv aWwgb2ZmIG9mIHRoZSBsZXhhbiEhIDotKQo+Cj4gICAgVGhpcyBiaXJkIGdvdCAiZmFjdG9yeSBi dWlsdCIgcmF2ZXMgZnJvbSB0aGUga29sYiBndXlzIGluIHRoZSBTdC4gTG91aXMgYXJlYS4uLlZl cnkgc2F0aXNmeWluZy4uZ3Vlc3MgaWYgb25lIGRvZXMgaXQgZW5vdWdoLi4uZ29vZCB0aGluZ3Mg Y2FuIGhhcHBlbi4uLmtpZHMgaW4gdGhlIG90aGVyIGV4YW1wbGUuLi4uOi0pICAgSGVyYiBbSU1H XzExMTUuSlBHXQo+Cj4gU2VudCB3aXRoIFtQcm90b25NYWlsXShodHRwczovL3Byb3Rvbm1haWwu Y29tKSBTZWN1cmUgRW1haWwu ________________________________________________________________________________
Date: Jan 28, 2019
Subject: Re: close up of my third build firefly...
VGhhbmtzIGFsbC4uCiAgSG9waW5nIHRoYXQgQnJvIFBpa2VzIGludGVybmV0IHNlcnZpY2UgaXMg b24gZmliZXIgbm93Li4uT3RoZXJ3aXNlIGhlIGlzIHN0aWxsIGRvd25sb2FkaW5nLi4udGhlIGZp cnN0IHBpYy4uLjotKSAgSGVyYgoKU2VudCB3aXRoIFtQcm90b25NYWlsXShodHRwczovL3Byb3Rv bm1haWwuY29tKSBTZWN1cmUgRW1haWwuCgrigJDigJDigJDigJDigJDigJDigJAgT3JpZ2luYWwg TWVzc2FnZSDigJDigJDigJDigJDigJDigJDigJAKT24gU3VuZGF5LCBKYW51YXJ5IDI3LCAyMDE5 IDY6MDkgUE0sIFJpY2hhcmQgR2lyYXJkIDxhc2xzYS5ybmdAZ21haWwuY29tPiB3cm90ZToKCj4g VGhhdCBpcyBvbmUgcHJldHR5IEtvbGIhIFRoZSBwdXBzIGRvbid0IGxvb2sgbGlrZSB0aGV5J3Jl IGluIG5lZWQgYXQgYWxsLCBidXQgaWYgdGhleSdyZSBsaWtlIG1pbmUgYSB0cmVhdCBpcyBhbHdh eXMgYWNjZXB0YWJsZS4KPgo+IFJpY2sKPgo+IE9uIFN1biwgSmFuIDI3LCAyMDE5IGF0IDY6MDMg UE0gU3R1YXJ0IEhhcm5lciA8c3R1YXJ0QGhhcm5lcmZhcm0ubmV0PiB3cm90ZToKPgo+PiBOaWNl IHdvcmsgSGVyYiEKPj4KPj4gVG9vIGJhZCB5b3VyIHBvb2NoZXMgYXJlIHN0YXJ2aW5nIHNvIG11 Y2ggdGhleSBoYWQgdG8gY29sbGFwc2UgcmlnaHQgb24gdGhlIHRheGl3YXkuIChkb27igJl0IG1h a2UgbWUgY29tZSBiYWNrIGRvd24gdGhlcmUgdG8gbWFrZSBzdXJlIHRoZXkgYXJlIGdldHRpbmcg ZW5vdWdoIGF0dGVudGlvbikuCj4+Cj4+IElmIEkgZXZlciBnZXQgYmFjayB0byBmbHlpbmcgeW91 ciB3aW5kc2hpZWxkIGlkZWEgbXkgZ2V0IGEgY2xvc2VyIGxvb2suCj4+Cj4+IEhhdmUgZnVuIQo+ Pgo+PiBTdHVhcnQKPj4KPj4gRG8gbm90IGFyY2hpdmUKPj4KPj4gWyBdCj4+Cj4+IEZyb206IG93 bmVyLWtvbGItbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBbbWFpbHRvOm93bmVyLWtvbGItbGlz dC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24gQmVoYWxmIE9mIFBmYXRjaGFudHoKPj4gU2VudDog U3VuZGF5LCBKYW51YXJ5IDI3LCAyMDE5IDU6MDYgUE0KPj4gVG86IGtvbGItbGlzdEBtYXRyb25p Y3MuY29tCj4+IFN1YmplY3Q6IEtvbGItTGlzdDogY2xvc2UgdXAgb2YgbXkgdGhpcmQgYnVpbGQg ZmlyZWZseS4uLgo+Pgo+PiB0aGlzIHBpYyBzaG93cyB0aGUgZnVsbCBlbmNsb3N1cmUuLi5pdCBm YXN0ZW5zIHdpdGggYSBpbmNoIGJ5IGluY2ggYW5nbGUgdG8gdGhlIHRvcCBsb25nZXJvbiBvbiB0 aGUgbGVmdCBzaWRlIGFuZCB0d28gcml2ZXRzIGF0IDggYW5kIDEwIGFtIG9uIHRoZSBsZWZ0IHNp ZGUgb2YgdGhlIG5vc2UgY29uZSBhbmQgdGhlIHJlYXIgYm93IGFsbG93IHRoZSByaWdodCBzaWRl IHRvIGxpZnQgY29tcGxldGVseSB1cC4uLlRoZSByaWdodCBhbmdsZSBhbHVtaW51bSBpcyBmYXN0 ZW5lZCB0byB0aGUgbGV4YW4gYW5kIGhhcyBhIHRhcGVyZWQgc2NyZXcgYXQgdGhlIGZyb250IG9m IHRoZSBhbmdsZSB0aGF0IHNsaWRlcyBpbnRvIGEgaG9sZSBpbiB0aGUgdGFiIHRoYXQgaG9sZHMg dGhlIG5vc2UgYm93bC4uLnRoZSByZWFyIG9mIHRoZSBhbmdsZSBoYXMgYSBsYXRjaC4uLiBUbyBl bnRlci4uLmp1c3QgZG9uIGEgY2FwIGFuZCByYWlzZSB0aGUgbGV4YW4gYW5kIHJlc3QgaXQgb24g eW91ciBoZWFkLi4uLiBLZWVwcyB0aGUgaGFpciBvaWwgb2ZmIG9mIHRoZSBsZXhhbiEhIDotKQo+ Pgo+PiAgICBUaGlzIGJpcmQgZ290ICJmYWN0b3J5IGJ1aWx0IiByYXZlcyBmcm9tIHRoZSBrb2xi IGd1eXMgaW4gdGhlIFN0LiBMb3VpcyBhcmVhLi4uVmVyeSBzYXRpc2Z5aW5nLi5ndWVzcyBpZiBv bmUgZG9lcyBpdCBlbm91Z2guLi5nb29kIHRoaW5ncyBjYW4gaGFwcGVuLi4ua2lkcyBpbiB0aGUg b3RoZXIgZXhhbXBsZS4uLi46LSkgICBIZXJiIFtJTUdfMTExNS5KUEddCj4+Cj4+IFNlbnQgd2l0 aCBbUHJvdG9uTWFpbF0oaHR0cHM6Ly9wcm90b25tYWlsLmNvbSkgU2VjdXJlIEVtYWlsLgo+Cj4g LS0KPgo+IOKAnEJsZXNzZWQgYXJlIHRoZSBjcmFja2VkLCBmb3IgdGhleSBzaGFsbCBsZXQgaW4g dGhlIGxpZ2h0LuKAnSAgIFtHcm91Y2hvIE1hcnhdKGh0dHA6Ly93d3cuZ29vZHJlYWRzLmNvbS9h dXRob3Ivc2hvdy80MzI0NC5Hcm91Y2hvX01hcngp ________________________________________________________________________________
Date: Jan 28, 2019
TyBib3kuLi5qdXN0IHJlbWVtYmVyZWQgdGhhdCB0aGF0IHBpYyBpcyBnb2luZyBvdXQgd2l0aCBl YWNoIHJlcGx5Li4uYmV0dGVyIGRlbGV0ZS4uLkhlcmIKClNlbnQgd2l0aCBbUHJvdG9uTWFpbF0o aHR0cHM6Ly9wcm90b25tYWlsLmNvbSkgU2VjdXJlIEVtYWlsLgoK4oCQ4oCQ4oCQ4oCQ4oCQ4oCQ 4oCQIE9yaWdpbmFsIE1lc3NhZ2Ug4oCQ4oCQ4oCQ4oCQ4oCQ4oCQ4oCQCk9uIFN1bmRheSwgSmFu dWFyeSAyNywgMjAxOSA2OjA5IFBNLCBSaWNoYXJkIEdpcmFyZCA8YXNsc2Eucm5nQGdtYWlsLmNv bT4gd3JvdGU6Cgo+IFRoYXQgaXMgb25lIHByZXR0eSBLb2xiISBUaGUgcHVwcyBkb24ndCBsb29r IGxpa2UgdGhleSdyZSBpbiBuZWVkIGF0IGFsbCwgYnV0IGlmIHRoZXkncmUgbGlrZSBtaW5lIGEg dHJlYXQgaXMgYWx3YXlzIGFjY2VwdGFibGUuCj4KPiBSaWNr ________________________________________________________________________________
Date: Jan 28, 2019
https://www.microsoft.com/en-us/p/resize-image/9p87m9tknkvl?activetab=pivot:overviewtab -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal (Ready for a test flight on the new 277) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487319#487319 ________________________________________________________________________________
Date: Jan 28, 2019
I have a site for photo's...just never remember to use it...We could have saved you grief by remembering to delete associated messages that contained the pic...Herb Sent with ProtonMail Secure Email. Original Message On Monday, January 28, 2019 7:51 AM, Richard Pike wrote: > > https://www.microsoft.com/en-us/p/resize-image/9p87m9tknkvl?activetab=pivot:overviewtab > > > ------------------------------------------------------------------------------------------- > ________________________________________________________________________________
Date: Feb 02, 2019
Subject: Long Distance Trailering
Hi Kolbers, My Kolb Firestar is being sold to a person in another part of the country over 1000 miles away from here, and we are going to arrange for it to be shipped to him by freight truck or trailer. I want to make sure that it arrives undamaged. One of the big questions I have is whether it is better to put it in the truck or t railer with the wings attached to the U-joint, or whether it is better to remove the wings entirely and mount or hang them in the truck separate from the fuselage. This is not going to be a 100 or 200 mile trip. Also, neither the buyer or seller will be doing the driving. So neither of us will be there to check on it during the trip. When I look at the U-joint attaching the wings to the fuselage, It looks to bevery strongly built, however I also understand that it may not have been intended to take ROAD vibrations and loads. The U-joint can certainly take 2 or 3 times the load and dofce that any Kolb will ever see in flight... BUT... tens of thousands of small up and down vibrations may not be something that this U-joint was designed for. I would welcome the opinions of Kolbers who have lots of experience (good or bad) with trailering or trucking their Kolb. Has anyone experienced damage or wear on the U-Joint due to ground transport? Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities ________________________________________________________________________________
Date: Feb 02, 2019
Subject: Re: Long Distance Trailering
Bill Over the years I have haled my MKIII over 6,000 miles with no damage. I bought a long single axle boat trailer and fully enclosed it. The key is a lightly sprung transport. Most trucks and trailers long enough to transport a Kolb are designed to carry a heavy load and are going to bounce your Kolb around way too much. I left my wings attached but supported them at the universal joint and at the tips. Good luck Rick Neilsen Redrive VW powered MKIIIC On Sat, Feb 2, 2019 at 2:41 AM Bill Berle wrote: > > Hi Kolbers, > > My Kolb Firestar is being sold to a person in another part of the country > over 1000 miles away from here, and we are going to arrange for it to be > shipped to him by freight truck or trailer. I want to make sure that it > arrives undamaged. > > One of the big questions I have is whether it is better to put it in the > truck or t railer with the wings attached to the U-joint, or whether it is > better to remove the wings entirely and mount or hang them in the truck > separate from the fuselage. > > This is not going to be a 100 or 200 mile trip. Also, neither the buyer or > seller will be doing the driving. So neither of us will be there to check > on it during the trip. > > When I look at the U-joint attaching the wings to the fuselage, It looks > to bevery strongly built, however I also understand that it may not have > been intended to take ROAD vibrations and loads. The U-joint can certainly > take 2 or 3 times the load and dofce that any Kolb will ever see in > flight... BUT... tens of thousands of small up and down vibrations may not > be something that this U-joint was designed for. > > I would welcome the opinions of Kolbers who have lots of experience (good > or bad) with trailering or trucking their Kolb. Has anyone experienced > damage or wear on the U-Joint due to ground transport? > > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and > for-profit entities > > ________________________________________________________________________________
Date: Feb 02, 2019
I transported a Kolb Mk1 from central FL to MS on an open trailer built to haul a Thorp T-18. Light weight springs, like Rick describes. It was a 'project' plane, but we re-attached the wings at the pivot point for transport. We did not use the aft tube attach points; instead used a cradle under the wings' leading edges back there. IIRC, I just strapped the axles directly to a 2x4 (no wheels/tires on the axles). The only damage was to the 30 year old wing fabric, from some of the strapping flapping in the 'breeze'. I'm pretty sure the only reason for the fabric damage is that it was ready to come off anyway, and would have failed a punch test. Charlie On 2/2/2019 12:35 PM, Rick Neilsen wrote: > Bill > > Over the years I have haled my MKIII over 6,000 miles with no damage. > I bought a long single axle boat trailer and fully enclosed it. The > key is a lightly sprung transport. Most trucks and trailers long > enough to transport a Kolb are designed to carry a heavy load and are > going to bounce your Kolb around way too much. I left my wings > attached but supported them at the universal joint and at the tips. > > Good luck > > Rick Neilsen > Redrive VW powered MKIIIC > > On Sat, Feb 2, 2019 at 2:41 AM Bill Berle > wrote: > > > > > Hi Kolbers, > > My Kolb Firestar is being sold to a person in another part of the > country over 1000 miles away from here, and we are going to > arrange for it to be shipped to him by freight truck or trailer. I > want to make sure that it arrives undamaged. > > One of the big questions I have is whether it is better to put it > in the truck or t railer with the wings attached to the U-joint, > or whether it is better to remove the wings entirely and mount or > hang them in the truck separate from the fuselage. > > This is not going to be a 100 or 200 mile trip. Also, neither the > buyer or seller will be doing the driving. So neither of us will > be there to check on it during the trip. > > When I look at the U-joint attaching the wings to the fuselage, It > looks to bevery strongly built, however I also understand that it > may not have been intended to take ROAD vibrations and loads. The > U-joint can certainly take 2 or 3 times the load and dofce that > any Kolb will ever see in flight... BUT... tens of thousands of > small up and down vibrations may not be something that this > U-joint was designed for. > > I would welcome the opinions of Kolbers who have lots of > experience (good or bad) with trailering or trucking their Kolb. > Has anyone experienced damage or wear on the U-Joint due to ground > transport? > > > Bill Berle > www.ezflaphandle.com <http://www.ezflaphandle.com> - safety & > performance upgrade for light aircraft > www.grantstar.net <http://www.grantstar.net> - winning > proposals for non-profit and for-profit entities > > > ========== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Feb 02, 2019
SSBicm91Z2h0IHRoZSBGUyBJSSBiYWNrIGZyb20gU291dGggRWFzdCBBbGFiYW1hLi4uCgogSSB1 c2VkIGEgIFRhbmRlbSB0cmFpbGVyIHRoYXQgd2FzIGhlYXZpbHkgc3BydW5nLi4uLgogSSBwbGFj ZWQgZm9hbSBjdXNoaW9ucyB1bmRlciB0aGUgdGFpbCBib29tIHRvIGJyaW5nIGl0IDUgb3Igc28g aW5jaGVzIG9mZiBvZiB0aGUgZGVjay4uCiAgVGhlbiBJIGRpZCB0aGUgc2FtZSBmb3IgdGhlIHdp bmdzLi5iZWluZyBjYXJlZnVsIHRoYXQgdGhleSBkaWQgbm90IGJvdW5jZSBhbmQgY2hhZmUgdGhl IGZhYnJpYy4uLkkgd2luY2hlZCB0aGUgd2hlZWxzIHRvIGVhY2ggc2lkZSByYWlsIG9mIHRoZSB0 cmFpbGVyLi4uYW5kIHRvIHRoZSBmcm9udCB0byBzdGFiaWxpemUuLmFsc28gd2luY2hlZCB0aGUg dGFpbCB3aGVlbCB0byBib3RoIHNpZGVzLi4uCiAgSGFkIGEgdmVyeSBzY2VuaWMgbGVpc3VyZWx5 IGRyaXZlIHVwIDIzMS4uLi4gSGVyYgoKU2VudCB3aXRoIFtQcm90b25NYWlsXShodHRwczovL3By b3Rvbm1haWwuY29tKSBTZWN1cmUgRW1haWwuCgrigJDigJDigJDigJDigJDigJDigJAgT3JpZ2lu YWwgTWVzc2FnZSDigJDigJDigJDigJDigJDigJDigJAKT24gU2F0dXJkYXksIEZlYnJ1YXJ5IDIs IDIwMTkgMTI6MzUgUE0sIFJpY2sgTmVpbHNlbiA8bmVpbHNlbnJtQGdtYWlsLmNvbT4gd3JvdGU6 Cgo+IEJpbGwKPgo+IE92ZXIgdGhlIHllYXJzIEkgaGF2ZSBoYWxlZCBteSBNS0lJSSBvdmVyIDYs MDAwIG1pbGVzIHdpdGggbm8gZGFtYWdlLiBJIGJvdWdodCBhIGxvbmcgc2luZ2xlIGF4bGUgYm9h dCB0cmFpbGVyIGFuZCBmdWxseSBlbmNsb3NlZCBpdC4gVGhlIGtleSBpcyBhIGxpZ2h0bHkgc3By dW5nIHRyYW5zcG9ydC4gTW9zdCB0cnVja3MgYW5kIHRyYWlsZXJzIGxvbmcgZW5vdWdoIHRvIHRy YW5zcG9ydCBhIEtvbGIgYXJlIGRlc2lnbmVkIHRvIGNhcnJ5IGEgaGVhdnkgbG9hZCBhbmQgYXJl IGdvaW5nIHRvIGJvdW5jZSB5b3VyIEtvbGIgYXJvdW5kIHdheSB0b28gbXVjaC4gSSBsZWZ0IG15 IHdpbmdzIGF0dGFjaGVkIGJ1dCBzdXBwb3J0ZWQgdGhlbSBhdCB0aGUgdW5pdmVyc2FsIGpvaW50 IGFuZCBhdCB0aGUgdGlwcy4KPgo+IEdvb2QgbHVjawo+Cj4gUmljayBOZWlsc2VuCj4gUmVkcml2 ZSBWVyBwb3dlcmVkIE1LSUlJQwo+Cj4gT24gU2F0LCBGZWIgMiwgMjAxOSBhdCAyOjQxIEFNIEJp bGwgQmVybGUgPHZpY3RvcmJyYXZvQHNiY2dsb2JhbC5uZXQ+IHdyb3RlOgo+Cj4+IC0tPiBLb2xi LUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IEJpbGwgQmVybGUgPHZpY3RvcmJyYXZvQHNiY2dsb2Jh bC5uZXQ+Cj4+Cj4+IEhpIEtvbGJlcnMsCj4+Cj4+IE15IEtvbGIgRmlyZXN0YXIgaXMgYmVpbmcg c29sZCB0byBhIHBlcnNvbiBpbiBhbm90aGVyIHBhcnQgb2YgdGhlIGNvdW50cnkgb3ZlciAxMDAw IG1pbGVzIGF3YXkgZnJvbSBoZXJlLCBhbmQgd2UgYXJlIGdvaW5nIHRvIGFycmFuZ2UgZm9yIGl0 IHRvIGJlIHNoaXBwZWQgdG8gaGltIGJ5IGZyZWlnaHQgdHJ1Y2sgb3IgdHJhaWxlci4gSSB3YW50 IHRvIG1ha2Ugc3VyZSB0aGF0IGl0IGFycml2ZXMgdW5kYW1hZ2VkLgo+Pgo+PiBPbmUgb2YgdGhl IGJpZyBxdWVzdGlvbnMgSSBoYXZlIGlzIHdoZXRoZXIgaXQgaXMgYmV0dGVyIHRvIHB1dCBpdCBp biB0aGUgdHJ1Y2sgb3IgdCByYWlsZXIgd2l0aCB0aGUgd2luZ3MgYXR0YWNoZWQgdG8gdGhlIFUt am9pbnQsIG9yIHdoZXRoZXIgaXQgaXMgYmV0dGVyIHRvIHJlbW92ZSB0aGUgd2luZ3MgZW50aXJl bHkgYW5kIG1vdW50IG9yIGhhbmcgdGhlbSBpbiB0aGUgdHJ1Y2sgc2VwYXJhdGUgZnJvbSB0aGUg ZnVzZWxhZ2UuCj4+Cj4+IFRoaXMgaXMgbm90IGdvaW5nIHRvIGJlIGEgMTAwIG9yIDIwMCBtaWxl IHRyaXAuIEFsc28sIG5laXRoZXIgdGhlIGJ1eWVyIG9yIHNlbGxlciB3aWxsIGJlIGRvaW5nIHRo ZSBkcml2aW5nLiBTbyBuZWl0aGVyIG9mIHVzIHdpbGwgYmUgdGhlcmUgdG8gY2hlY2sgb24gaXQg ZHVyaW5nIHRoZSB0cmlwLgo+Pgo+PiBXaGVuIEkgbG9vayBhdCB0aGUgVS1qb2ludCBhdHRhY2hp bmcgdGhlIHdpbmdzIHRvIHRoZSBmdXNlbGFnZSwgSXQgbG9va3MgdG8gYmV2ZXJ5IHN0cm9uZ2x5 IGJ1aWx0LCBob3dldmVyIEkgYWxzbyB1bmRlcnN0YW5kIHRoYXQgaXQgbWF5IG5vdCBoYXZlIGJl ZW4gaW50ZW5kZWQgdG8gdGFrZSBST0FEIHZpYnJhdGlvbnMgYW5kIGxvYWRzLiBUaGUgVS1qb2lu dCBjYW4gY2VydGFpbmx5IHRha2UgMiBvciAzIHRpbWVzIHRoZSBsb2FkIGFuZCBkb2ZjZSB0aGF0 IGFueSBLb2xiIHdpbGwgZXZlciBzZWUgaW4gZmxpZ2h0Li4uIEJVVC4uLiB0ZW5zIG9mIHRob3Vz YW5kcyBvZiBzbWFsbCB1cCBhbmQgZG93biB2aWJyYXRpb25zIG1heSBub3QgYmUgc29tZXRoaW5n IHRoYXQgdGhpcyBVLWpvaW50IHdhcyBkZXNpZ25lZCBmb3IuCj4+Cj4+IEkgd291bGQgd2VsY29t ZSB0aGUgb3BpbmlvbnMgb2YgS29sYmVycyB3aG8gaGF2ZSBsb3RzIG9mIGV4cGVyaWVuY2UgKGdv b2Qgb3IgYmFkKSB3aXRoIHRyYWlsZXJpbmcgb3IgdHJ1Y2tpbmcgdGhlaXIgS29sYi4gSGFzIGFu eW9uZSBleHBlcmllbmNlZCBkYW1hZ2Ugb3Igd2VhciBvbiB0aGUgVS1Kb2ludCBkdWUgdG8gZ3Jv dW5kIHRyYW5zcG9ydD8KPj4KPj4gQmlsbCBCZXJsZQo+PiB3d3cuZXpmbGFwaGFuZGxlLmNvbSAg LSBzYWZldHkgJiBwZXJmb3JtYW5jZSB1cGdyYWRlIGZvciBsaWdodCBhaXJjcmFmdAo+PiB3d3cu Z3JhbnRzdGFyLm5ldCAgICAgICAgICAgLSB3aW5uaW5nIHByb3Bvc2FscyBmb3Igbm9uLXByb2Zp dCBhbmQgZm9yLXByb2ZpdCBlbnRpdGllcwo+Pgo+PiA9PT09PT09PT09PQo+PiAtTGlzdCIgcmVs PSJub3JlZmVycmVyIiB0YXJnZXQ9Il9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05h dmlnYXRvcj9Lb2xiLUxpc3QKPj4gPT09PT09PT09PT0KPj4gRk9SVU1TIC0KPj4gZWZlcnJlciIg dGFyZ2V0PSJfYmxhbmsiPmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQo+PiA9PT09PT09PT09 PQo+PiBXSUtJIC0KPj4gZXJyZXIiIHRhcmdldD0iX2JsYW5rIj5odHRwOi8vd2lraS5tYXRyb25p Y3MuY29tCj4+ID09PT09PT09PT09Cj4+IGIgU2l0ZSAtCj4+ICAgICAgICAgICAtTWF0dCBEcmFs bGUsIExpc3QgQWRtaW4uCj4+IHJlbD0ibm9yZWZlcnJlciIgdGFyZ2V0PSJfYmxhbmsiPmh0dHA6 Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24KPj4gPT09PT09PT09PT0 ________________________________________________________________________________
Date: Feb 02, 2019
Burt Howland, an old aviator, owned and flew a Bearcat until he was physically no longer to fly it, designer of the Honey Bee and Chip Monk, was the smoothest pilot taxiing I have ever seen. He never got in a hurry and was very gentle and respectful of his aircraft on the ground. I never forgot that, however, I didn't always taxi like he did. He also designed another model, but I can't remember the name of it. He and his wife, Ellen, were good friends I met at the Ultralight Flight Farm the first time I flew my Firestar up there in 1988. Ellen was a WASP during WWII and also a flight instructor. Burt lived and had a grass strip and hanger in Maryland, NY. I flew up there in 1989, spent a week with them, flew all the New England states in a day, a long day, from his airstrip. From there flew to the Ultralight Flight Farm, Niagara Falls, Sault St Marie, Canada, and Oshkosh. I trailered my MKIII from Muncho Lake, British Columbia, to Oshkosh, and south to Alabama in 2000. For that trip I had a borrowed enclosed trailer, strapped the wings to the walls, supported the tail boom in a cradle. Only problem was dust from many sections of road that were gravel and under repair. New Lexan had to be replaced. Back then it was not that much of a job. Now days it is impossible. john h mkIII Titus, Alabama ________________________________________________________________________________
Date: Feb 02, 2019
I transported my Kolb via enclosed trailer from California to Texas. I would definitely remove the wings and suspend them with straps from the ceiling of the trailer, and then protect them as best you can from any type of rubbing (from the straps and from the trailer). I also had a cushioned boom tube cradle. On Sat, Feb 2, 2019, 1:43 AM Bill Berle > Hi Kolbers, > > My Kolb Firestar is being sold to a person in another part of the country > over 1000 miles away from here, and we are going to arrange for it to be > shipped to him by freight truck or trailer. I want to make sure that it > arrives undamaged. > > One of the big questions I have is whether it is better to put it in the > truck or t railer with the wings attached to the U-joint, or whether it is > better to remove the wings entirely and mount or hang them in the truck > separate from the fuselage. > > This is not going to be a 100 or 200 mile trip. Also, neither the buyer or > seller will be doing the driving. So neither of us will be there to check > on it during the trip. > > When I look at the U-joint attaching the wings to the fuselage, It looks > to bevery strongly built, however I also understand that it may not have > been intended to take ROAD vibrations and loads. The U-joint can certainly > take 2 or 3 times the load and dofce that any Kolb will ever see in > flight... BUT... tens of thousands of small up and down vibrations may not > be something that this U-joint was designed for. > > I would welcome the opinions of Kolbers who have lots of experience (good > or bad) with trailering or trucking their Kolb. Has anyone experienced > damage or wear on the U-Joint due to ground transport? > > > Bill Berle > www.ezflaphandle.com - safety & performance upgrade for light aircraft > www.grantstar.net - winning proposals for non-profit and > for-profit entities > > ________________________________________________________________________________
Date: Feb 02, 2019
victorbravo(at)sbcglobal. wrote: > Hi Kolbers, > > My Kolb Firestar is being sold to a person in another part of the country over 1000 miles away from here, and we are going to arrange for it to be shipped to him by freight truck or trailer. I want to make sure that it arrives undamaged. > > . . S . N . I . P. . . > > Bill Berle > > . . S . N . I . P. . . > > The "Trailering a Kolb" section on my web site has a lot of information and a wide variety of solutions concerning this subject. http://oh2fly.net/Main_trailer_kolb.htm -------- George Alexander FS II R503 E-LSA N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487394#487394 ________________________________________________________________________________
Date: Feb 02, 2019
I would consider renting a U-Haul and having either the buyer or seller transport it. Using a commercial freight hauler is asking for trouble in my opinion. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487399#487399 ________________________________________________________________________________
Date: Feb 02, 2019
there are web sites where one can hire independent haulers....sometimes, just guys with a Dodge diesel truck and a 25 foot enclosed trailer... My experience with one of them was not good....He claimed to the buyer that He had hauled planes before....When we started to load...I could see he had no idea...!! Get some references...Herb ________________________________________________________________________________
Date: Feb 02, 2019
I have no personal experience with these guys, but they transport a lot of Van's Aircraft quickbuild kits, without crating. https://freefreightsearch.com/brokers/14306-partain-trading-company-inc-dba-partain-transport-company One thread on the Van's Airforce forum: http://www.vansairforce.com/community/showthread.php?t=94007&highlight=partain+transport Charlie On 2/2/2019 8:04 PM, Herb wrote: > > there are web sites where one can hire independent > haulers....sometimes, just guys with a Dodge diesel truck and a 25 > foot enclosed trailer... > > My experience with one of them was not good....He claimed to the > buyer that He had hauled planes before....When we started to load...I > could see he had no idea...!! Get some references...Herb --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Feb 03, 2019
Thanks Charlie ! I read that VAF thread and sent him an e-mail. He certainly comes highly recommended in the Vans community. The buyer and myself are both strongly wanting to get this done safely. I will be here to help load and secure the Kolb when it leaves, but having a transporter who gives a s*** about it while it's on the road is definitely worth the trouble to find if we can afford it. The first thing I tried to do was get one of my friends in the local ultralight community to trailer it for us, but his old marginal vehicle cannot make the trip. I cannot take it to him myself, and he cannot get time off work to come get it. I have no personal experience with these guys, but they transport a lot of Van's Aircraft quickbuild kits, without crating. https://freefreightsearch.com/brokers/14306-partain-trading-company-inc-dba-partain-transport-company One thread on the Van's Airforce ________________________________________________________________________________
Date: Feb 03, 2019
Dollar a mile is a nice number if you can get it.. Herb Sent with ProtonMail Secure Email. Original Message On Sunday, February 3, 2019 9:20 AM, Bill Berle wrote: > > Thanks Charlie ! > > I read that VAF thread and sent him an e-mail. He certainly comes highly recommended in the Vans community. > > The buyer and myself are both strongly wanting to get this done safely. I will be here to help load and secure the Kolb when it leaves, but having a transporter who gives a s*** about it while it's on the road is definitely worth the trouble to find if we can afford it. > > The first thing I tried to do was get one of my friends in the local ultralight community to trailer it for us, but his old marginal vehicle cannot make the trip. I cannot take it to him myself, and he cannot get time off work to come get it. > > > I have no personal experience with these guys, but they transport a lot of Van's Aircraft quickbuild kits, > without crating. > > https://freefreightsearch.com/brokers/14306-partain-trading-company-inc-dba-partain-transport-company > One thread on the Van's Airforce > ________________________________________________________________________________
Date: Feb 03, 2019
The Van's guy seems like a good bet. I think the main thing is that after it is loaded the trailer is not opened until it arrives at the destination. Loading and off loading additional items along the way can cause problems. When I moved from Ohio to Missouri I rented a U-Haul and also removed the wings and supported everything on 6" upholstery foam that I bought at a fabric store. No Problems. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487408#487408 ________________________________________________________________________________
Date: Feb 03, 2019
I've used Partain's service for two RV kits, and they were fantastic. It will arrive in the longest trailer you've ever seen :-) Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487414#487414 ________________________________________________________________________________
Subject: Jabiru 2200 installation and flight comments?
Date: Feb 10, 2019
Greetings, While considering engines for the latest Slingshot project, I ran across the Jabiru 2200 engines. I know Thom had one on a Slingshot, and he seemed happy with the performance. I've heard of a few on Mk-3s as well. Is anyone still flying with a Jabiru? Has anyone flown with the Jabiru 2200 and some other engine on the same plane for comparison? I'd love to see some additional installation pictures, particularly how the exhaust was routed. FWIW, I'm currently looking at the HKS, Jabiru 2200, and 912. All of these have some pros and cons. Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487506#487506 ________________________________________________________________________________
Date: Feb 10, 2019
Subject: Re: Jabiru 2200 installation and flight comments?
the HKS is only about as powerful as the rotax 503=C2- the jabiru would b e a nice fit for your kolb=C2- Sent from Yahoo Mail on Android On Sun, Feb 10, 2019 at 8:23 AM, 13brv3<13brv3(at)gmail.com> wrote: --> Ko lb-List message posted by: "13brv3" <13brv3(at)gmail.com> Greetings, While considering engines for the latest Slingshot project, I ran across th e Jabiru 2200 engines.=C2- I know Thom had one on a Slingshot, and he see med happy with the performance.=C2- I've heard of a few on Mk-3s as well. =C2- Is anyone still flying with a Jabiru?=C2- Has anyone flown with th e Jabiru 2200 and some other engine on the same plane for comparison?=C2- I'd love to see some additional installation pictures, particularly how th e exhaust was routed.=C2- FWIW, I'm currently looking at the HKS, Jabiru 2200, and 912.=C2- All of these have some pros and cons.=C2- Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487506#487506 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Feb 10, 2019
brubakermal(at)yahoo.com wrote: > the HKS is only about as powerful as the rotax 503 the jabiru would be a nice fit for your kolb The Jabiru 2200 checks all the boxes for me, but I haven't seen many for sale used, and new isn't an option for any of these engines. The only real installation issue is that the wings won't fold with the standard pusher exhaust config, but I have to believe that can be fixed. Otherwise it's a clean installation, with reportedly good performance despite being direct drive. The other bonus is that the US Jabiru dealer is only about 3 hrs west of me if needed. The HKS appeal is that it's the lightest, most compact 4-stroke option, as well as being the quietest with the 3.47 gears, and probably the most fuel efficient. My old 503 SS performance wasn't all that bad, but I was young, and feeling the need for speed. Now that I'm getting old, and have proven repeatedly that I won't travel in the plane, I could probably be happier with the lower performance. Of course the 912 is hands down the most popular option, but they're pricey, heavy, noisy, and require water and oil coolers. The years have taught me to go with the flow a bit more than I used to, but I hate to be too conventional :-) Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487510#487510 ________________________________________________________________________________
Date: Feb 10, 2019
For me the problem with the jabiru is the direct drive. You'll need a shorter prop, which is ok if your plane was designed to fly faster. Say 125 mph or so. The faster turning shorter prop becomes more efficient at higher speeds. The kolbs need a longer slower turning prop too get the most out of the engine horse power. Boyd > > ________________________________________________________________________________
Date: Feb 10, 2019
Might do some checking about the cooling of the Jab...I have chatted with tractor and pusher builders and some have mentioned cooling difficulties...Herb Sent with ProtonMail Secure Email. Original Message On Sunday, February 10, 2019 5:29 PM, 13brv3 <13brv3(at)gmail.com> wrote: > > brubakermal(at)yahoo.com wrote: > > > the HKS is only about as powerful as the rotax 503 the jabiru would be a nice fit for your kolb > > The Jabiru 2200 checks all the boxes for me, but I haven't seen many for sale used, and new isn't an option for any of these engines. The only real installation issue is that the wings won't fold with the standard pusher exhaust config, but I have to believe that can be fixed. Otherwise it's a clean installation, with reportedly good performance despite being direct drive. The other bonus is that the US Jabiru dealer is only about 3 hrs west of me if needed. > > The HKS appeal is that it's the lightest, most compact 4-stroke option, as well as being the quietest with the 3.47 gears, and probably the most fuel efficient. My old 503 SS performance wasn't all that bad, but I was young, and feeling the need for speed. Now that I'm getting old, and have proven repeatedly that I won't travel in the plane, I could probably be happier with the lower performance. > > Of course the 912 is hands down the most popular option, but they're pricey, heavy, noisy, and require water and oil coolers. The years have taught me to go with the flow a bit more than I used to, but I hate to be too conventional :-) > > Rusty > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487510#487510 > ________________________________________________________________________________
Date: Feb 10, 2019
Boyd, For what it's worth I've been working on a friend's Zenith 701 with a 2200A Jabby and a two blade Sensenich prop. I set the prop for 3120 RPM static at which it pulls 310 lb. as measured with a digital force gauge. My concern on a Kolb would be the need for a light weight prop. The Sensenich is built similar to the Power Fin, i.e. light and hollow and won't tolerate FOD like a Warp Drive will. Rick On Sun, Feb 10, 2019 at 5:53 PM B Young wrote: > For me the problem with the jabiru is the direct drive. You'll need a > shorter prop, which is ok if your plane was designed to fly faster. Say > 125 mph or so. The faster turning shorter prop becomes more efficient a t > higher speeds. The kolbs need a longer slower turning prop too get the > most out of the engine horse power. > > Boyd > > >> >> >> >> -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Feb 10, 2019
There's precious little data available for Jabiru equipped Kolbs, but I've been exchanging emails with Thom, who owned a Jabiru 2200 Slingshot. He was definitely a fan, and it sounds like it had plenty of performance with the 64" prop he was running. Cooling shrouds are a must, but I wouldn't expect any air cooled engine to have optimum cooling without them. I've actually been trying to buy an HKS that was up for sale, at a price that would make it worth trying. It doesn't look like that's going to work out though, which may be for the best. Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487513#487513 ________________________________________________________________________________
Date: Feb 10, 2019
Have a MK 3C with 2200 Jabiru 1100 hrs ,unusual cooling configuration, no heat problems. Cruise 70mph 2700rpm Sen wood prop 4264 I think, 3150 rpm takeoff. Have some Picts I could e mail. Sent from my iPhone > On Feb 10, 2019, at 7:33 PM, 13brv3 <13brv3(at)gmail.com> wrote: > > > There's precious little data available for Jabiru equipped Kolbs, but I've been exchanging emails with Thom, who owned a Jabiru 2200 Slingshot. He was definitely a fan, and it sounds like it had plenty of performance with the 64" prop he was running. Cooling shrouds are a must, but I wouldn't expect any air cooled engine to have optimum cooling without them. > > I've actually been trying to buy an HKS that was up for sale, at a price that would make it worth trying. It doesn't look like that's going to work out though, which may be for the best. > > Rusty > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487513#487513 > > > > > > > > > ________________________________________________________________________________
Date: Feb 10, 2019
zeprep251(at)aol.com wrote: > Have a MK 3C with 2200 Jabiru 1100 hrs ,unusual cooling configuration, no heat problems. Cruise 70mph 2700rpm Sen wood prop 4264 I think, 3150 rpm takeoff. Have some Picts I could e mail. That's good to hear. I'd love to see any installation pictures you have. Thanks, Rusty 13brv3(at)gmail.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487516#487516 ________________________________________________________________________________
Date: Feb 11, 2019
Subject: Re: Kolb-List Digest: 9 Msgs - 02/10/19
Jab vs 912 is no contest! Even with rads and WD prop, the 912 will run the pants off a jab on a slingshot. I have a 912 on mine and I wouldn't trade it. Been flying it for ten years. Started with 582. What a difference. I cruise at 95+ with 4 gph with full camping gear. If you set it up right (change angle of engine mounts) it is light on stick. Like driving a Beemer. Will send pics if needed. My two cents. Ted Cowan slingshot 912 ul zoom zoom Sent from my iPhone > On Feb 11, 2019, at 1:37 AM, Kolb-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-02-10&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 19-02-10&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Sun 02/10/19: 9 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 05:19 AM - Jabiru 2200 installation and flight comments? (13brv3) > 2. 01:15 PM - Re: Jabiru 2200 installation and flight comments? (Malcolm Brubaker) > 3. 03:30 PM - Re: Jabiru 2200 installation and flight comments? (13brv3) > 4. 03:51 PM - Re: Re: Jabiru 2200 installation and flight comments? (B Young) > 5. 04:00 PM - Re: Re: Jabiru 2200 installation and flight comments? (Pfatchantz) > 6. 04:31 PM - Re: Re: Jabiru 2200 installation and flight comments? (Richard Girard) > 7. 04:33 PM - Re: Jabiru 2200 installation and flight comments? (13brv3) > 8. 07:20 PM - Re: Re: Jabiru 2200 installation and flight comments? (Gary Aman) > 9. 07:30 PM - Re: Jabiru 2200 installation and flight comments? (13brv3) > > > > ________________________________ Message 1 _____________________________________ > > > Subject: Kolb-List: Jabiru 2200 installation and flight comments? > From: "13brv3" <13brv3(at)gmail.com> > > > Greetings, > > While considering engines for the latest Slingshot project, I ran across the Jabiru > 2200 engines. I know Thom had one on a Slingshot, and he seemed happy with > the performance. I've heard of a few on Mk-3s as well. Is anyone still flying > with a Jabiru? Has anyone flown with the Jabiru 2200 and some other engine > on the same plane for comparison? I'd love to see some additional installation > pictures, particularly how the exhaust was routed. > > FWIW, I'm currently looking at the HKS, Jabiru 2200, and 912. All of these have > some pros and cons. > > Thanks, > Rusty > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487506#487506 > > > ________________________________ Message 2 _____________________________________ > > > From: Malcolm Brubaker <brubakermal(at)yahoo.com> > Subject: Re: Kolb-List: Jabiru 2200 installation and flight comments? > > the HKS is only about as powerful as the rotax 503=C2- the jabiru would b > e a nice fit for your kolb=C2- > > Sent from Yahoo Mail on Android > > On Sun, Feb 10, 2019 at 8:23 AM, 13brv3<13brv3(at)gmail.com> wrote: --> Ko > lb-List message posted by: "13brv3" <13brv3(at)gmail.com> > > Greetings, > > While considering engines for the latest Slingshot project, I ran across th > e Jabiru 2200 engines.=C2- I know Thom had one on a Slingshot, and he see > med happy with the performance.=C2- I've heard of a few on Mk-3s as well. > =C2- Is anyone still flying with a Jabiru?=C2- Has anyone flown with th > e Jabiru 2200 and some other engine on the same plane for comparison?=C2- > I'd love to see some additional installation pictures, particularly how th > e exhaust was routed.=C2- > > FWIW, I'm currently looking at the HKS, Jabiru 2200, and 912.=C2- All of > these have some pros and cons.=C2- > > Thanks, > Rusty > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487506#487506 > > > S - > WIKI - > - > =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. > > > ________________________________ Message 3 _____________________________________ > > > Subject: Kolb-List: Re: Jabiru 2200 installation and flight comments? > From: "13brv3" <13brv3(at)gmail.com> > > > > brubakermal(at)yahoo.com wrote: >> the HKS is only about as powerful as the rotax 503 the jabiru would be a nice > fit for your kolb > > > The Jabiru 2200 checks all the boxes for me, but I haven't seen many for sale used, > and new isn't an option for any of these engines. The only real installation > issue is that the wings won't fold with the standard pusher exhaust config, > but I have to believe that can be fixed. Otherwise it's a clean installation, > with reportedly good performance despite being direct drive. The other bonus > is that the US Jabiru dealer is only about 3 hrs west of me if needed. > > The HKS appeal is that it's the lightest, most compact 4-stroke option, as well > as being the quietest with the 3.47 gears, and probably the most fuel efficient. > My old 503 SS performance wasn't all that bad, but I was young, and feeling > the need for speed. Now that I'm getting old, and have proven repeatedly that > I won't travel in the plane, I could probably be happier with the lower performance. > > > Of course the 912 is hands down the most popular option, but they're pricey, heavy, > noisy, and require water and oil coolers. The years have taught me to go > with the flow a bit more than I used to, but I hate to be too conventional :-) > > Rusty > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487510#487510 > > > ________________________________ Message 4 _____________________________________ > > > From: B Young <byoungplumbing(at)gmail.com> > Subject: Re: Kolb-List: Re: Jabiru 2200 installation and flight comments? > > For me the problem with the jabiru is the direct drive. You'll need a > shorter prop, which is ok if your plane was designed to fly faster. Say > 125 mph or so. The faster turning shorter prop becomes more efficient at > higher speeds. The kolbs need a longer slower turning prop too get the > most out of the engine horse power. > > Boyd > > >> >> > > ________________________________ Message 5 _____________________________________ > > > From: Pfatchantz <Pfatchantz(at)protonmail.ch> > Subject: Re: Kolb-List: Re: Jabiru 2200 installation and flight comments? > > > Might do some checking about the cooling of the Jab...I have chatted with tractor > and pusher builders and some have mentioned cooling difficulties...Herb > > > Sent with ProtonMail Secure Email. > > Original Message >> On Sunday, February 10, 2019 5:29 PM, 13brv3 <13brv3(at)gmail.com> wrote: >> >> >> brubakermal(at)yahoo.com wrote: >> >>> the HKS is only about as powerful as the rotax 503 the jabiru would be a nice > fit for your kolb >> >> The Jabiru 2200 checks all the boxes for me, but I haven't seen many for sale > used, and new isn't an option for any of these engines. The only real installation > issue is that the wings won't fold with the standard pusher exhaust config, > but I have to believe that can be fixed. Otherwise it's a clean installation, > with reportedly good performance despite being direct drive. The other bonus > is that the US Jabiru dealer is only about 3 hrs west of me if needed. >> >> The HKS appeal is that it's the lightest, most compact 4-stroke option, as well > as being the quietest with the 3.47 gears, and probably the most fuel efficient. > My old 503 SS performance wasn't all that bad, but I was young, and feeling > the need for speed. Now that I'm getting old, and have proven repeatedly that > I won't travel in the plane, I could probably be happier with the lower performance. >> >> Of course the 912 is hands down the most popular option, but they're pricey, > heavy, noisy, and require water and oil coolers. The years have taught me to go > with the flow a bit more than I used to, but I hate to be too conventional :-) >> >> Rusty >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=487510#487510 >> > > > ________________________________ Message 6 _____________________________________ > > > From: Richard Girard <aslsa.rng(at)gmail.com> > Subject: Re: Kolb-List: Re: Jabiru 2200 installation and flight comments? > > Boyd, For what it's worth I've been working on a friend's Zenith 701 with a > 2200A Jabby and a two blade Sensenich prop. I set the prop for 3120 RPM > static at which it pulls 310 lb. as measured with a digital force gauge. My > concern on a Kolb would be the need for a light weight prop. The Sensenich > is built similar to the Power Fin, i.e. light and hollow and won't tolerate > FOD like a Warp Drive will. > > Rick > >> On Sun, Feb 10, 2019 at 5:53 PM B Young wrote: >> >> For me the problem with the jabiru is the direct drive. You'll need a >> shorter prop, which is ok if your plane was designed to fly faster. Say >> 125 mph or so. The faster turning shorter prop becomes more efficient a > t >> higher speeds. The kolbs need a longer slower turning prop too get the >> most out of the engine horse power. >> >> Boyd >> >> >>> >>> >>> >>> > > -- > =9CBlessed are the cracked, for they shall let in the light.=9D > Groucho Marx > <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > ________________________________ Message 7 _____________________________________ > > > Subject: Kolb-List: Re: Jabiru 2200 installation and flight comments? > From: "13brv3" <13brv3(at)gmail.com> > > > There's precious little data available for Jabiru equipped Kolbs, but I've been > exchanging emails with Thom, who owned a Jabiru 2200 Slingshot. He was definitely > a fan, and it sounds like it had plenty of performance with the 64" prop > he was running. Cooling shrouds are a must, but I wouldn't expect any air cooled > engine to have optimum cooling without them. > > I've actually been trying to buy an HKS that was up for sale, at a price that would > make it worth trying. It doesn't look like that's going to work out though, > which may be for the best. > > Rusty > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487513#487513 > > > ________________________________ Message 8 _____________________________________ > > > From: Gary Aman <zeprep251(at)aol.com> > Subject: Re: Kolb-List: Re: Jabiru 2200 installation and flight comments? > > > Have a MK 3C with 2200 Jabiru 1100 hrs ,unusual cooling configuration, no heat > problems. Cruise 70mph 2700rpm Sen wood prop 4264 I think, 3150 rpm takeoff. Have > some Picts I could e mail. > > Sent from my iPhone > >> On Feb 10, 2019, at 7:33 PM, 13brv3 <13brv3(at)gmail.com> wrote: >> >> >> There's precious little data available for Jabiru equipped Kolbs, but I've been > exchanging emails with Thom, who owned a Jabiru 2200 Slingshot. He was definitely > a fan, and it sounds like it had plenty of performance with the 64" prop > he was running. Cooling shrouds are a must, but I wouldn't expect any air > cooled engine to have optimum cooling without them. >> >> I've actually been trying to buy an HKS that was up for sale, at a price that > would make it worth trying. It doesn't look like that's going to work out though, > which may be for the best. >> >> Rusty >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=487513#487513 >> >> >> >> >> >> >> >> >> > > > ________________________________ Message 9 _____________________________________ > > > Subject: Kolb-List: Re: Jabiru 2200 installation and flight comments? > From: "13brv3" <13brv3(at)gmail.com> > > > > zeprep251(at)aol.com wrote: >> Have a MK 3C with 2200 Jabiru 1100 hrs ,unusual cooling configuration, no heat > problems. Cruise 70mph 2700rpm Sen wood prop 4264 I think, 3150 rpm takeoff. > Have some Picts I could e mail. > > > That's good to hear. I'd love to see any installation pictures you have. > > Thanks, > Rusty > 13brv3(at)gmail.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487516#487516 > > > > > > > > ________________________________________________________________________________
Date: Feb 11, 2019
tc1917(at)bellsouth.net wrote: > Jab vs 912 is no contest! Even with rads and WD prop, the 912 will run the pants off a jab on a slingshot. I have a 912 on mine and I wouldn't trade it. Been flying it for ten years. Started with 582. What a difference. I cruise at 95+ with 4 gph with full camping gear. If you set it up right (change angle of engine mounts) it is light on stick. Like driving a Beemer. Will send pics if needed. My two cents. Ted Cowan slingshot 912 ul zoom zoom > Thanks for the comments Ted. The 912 is a great engine for sure, and if one comes along that seems to be a good deal, I'll grab it. I have a few takeoffs and landings in a 912S SS, and lots of pictures of the installation. Regardless of the engine used, it seems the rear of the engine needs to be raised on the SS. Even my old 503 had nearly an inch spacer under the rear mounts when I was done with it. As it turns out, the mount was removed on the cage I have, and I'll be restoring it. I'll likely build in a bit more angle when I do. Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487523#487523 ________________________________________________________________________________
Date: Feb 11, 2019
Thanks for the comments, but fate was working overtime today. I ended up talking with a local pilot, and he mentioned having a 912UL he was planning to sell. Turns out it's a great engine, at a great price, and less than an hour from my house. In a few days, I should be the lucky owner of a 912. Now I need to work on selling my RV-3B so I don't have to sell a kidney or two to pay for this :-) Cheers, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487537#487537 ________________________________________________________________________________
Subject: Back-Up Battery
Date: Feb 11, 2019
Kolbers, I am considering a Battery back up system, and wondering if anyone has experience with TCW Technologies? Thanks, Nick Cassara Palmer, Alaska 99645 607AK ________________________________________________________________________________
Date: Feb 11, 2019
Subject: Re: Back-Up Battery
TmljaywgVHJ5IHRoZSBBZXJvZWxlY3RyaWMgQ29ubmVjdGlvbiBhbHNvIG9uIE1hdHJvbmljcy4N Cg0KUmljaw0KDQpPbiBNb24sIEZlYiAxMSwgMjAxOSBhdCA1OjQ1IFBNIE5pY2sgQ2Fzc2FyYSA8 bmlja2NAbXRhb25saW5lLm5ldD4gd3JvdGU6DQoNCj4gLS0+IEtvbGItTGlzdCBtZXNzYWdlIHBv c3RlZCBieTogTmljayBDYXNzYXJhIDxuaWNrY0BtdGFvbmxpbmUubmV0Pg0KPg0KPiBLb2xiZXJz LA0KPg0KPiBJIGFtIGNvbnNpZGVyaW5nIGEgQmF0dGVyeSBiYWNrIHVwIHN5c3RlbSwgYW5kIHdv bmRlcmluZyBpZiBhbnlvbmUgaGFzDQo+IGV4cGVyaWVuY2Ugd2l0aCBUQ1cgVGVjaG5vbG9naWVz Pw0KPg0KPiBUaGFua3MsDQo+DQo+IE5pY2sgQ2Fzc2FyYQ0KPiBQYWxtZXIsIEFsYXNrYSA5OTY0 NQ0KPg0KPiA2MDdBSw0KPg0KPiBfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PQ0KPiBfLT0gICAgICAgICAgLSBUaGUgS29sYi1MaXN0 IEVtYWlsIEZvcnVtIC0NCj4gXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2 aWdhdG9yIHRvIGJyb3dzZQ0KPiBfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBM aXN0IFVuL1N1YnNjcmlwdGlvbiwNCj4gXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDct RGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KPiBfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBt b3JlOg0KPiBfLT0NCj4gXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0 b3I/S29sYi1MaXN0DQo+IF8tPQ0KPiBfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KPiBfLT0gICAgICAgICAgICAgICAtIE1BVFJP TklDUyBXRUIgRk9SVU1TIC0NCj4gXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJs ZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQo+IF8tPQ0KPiBfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5t YXRyb25pY3MuY29tDQo+IF8tPQ0KPiBfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KPiBfLT0gICAgICAgICAgICAgIC0gTkVXIE1B VFJPTklDUyBMSVNUIFdJS0kgLQ0KPiBfLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNz IEVtYWlsIExpc3QgV2lraSENCj4gXy09ICAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb20N Cj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0NCj4gXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUg LQ0KPiBfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KPiBfLT0gICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQo+IF8t PSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQo+IF8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQo+ DQo+DQo+DQo+DQoNCi0tIA0K4oCcQmxlc3NlZCBhcmUgdGhlIGNyYWNrZWQsIGZvciB0aGV5IHNo YWxsIGxldCBpbiB0aGUgbGlnaHQu4oCdICAgR3JvdWNobyBNYXJ4DQo8aHR0cDovL3d3dy5nb29k cmVhZHMuY29tL2F1dGhvci9zaG93LzQzMjQ0Lkdyb3VjaG9fTWFyeD4NCg= ________________________________________________________________________________
Date: Feb 11, 2019
Good advice; that is the ultimate source for electrical info. Having said that, quite a few RV-x drivers use them. Having said *that*, do you mind telling us how you'll be using it (beyond the obvious 'backup')? There may be less expensive alternatives. Charlie On 2/11/2019 7:42 PM, Richard Girard wrote: > Nick, Try the Aeroelectric Connection also on Matronics. > > Rick > > On Mon, Feb 11, 2019 at 5:45 PM Nick Cassara > wrote: > > > > > Kolbers, > > I am considering a Battery back up system, and wondering if anyone > has experience with TCW Technologies? > > Thanks, > > Nick Cassara > Palmer, Alaska 99645 > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Feb 12, 2019
Well Nick, I installed a Aerovoltz iron lithium ion battery in my Firestar last year. The battery is very small and light 1.3 lbs. I use it as my primary battery. It starts my Hirth 2702 without a problem. The battery is relatively inexpensive, they come in variety of different sizes. I did also order the special balancing charger. I highly recommend this system. I bought it from Aircraft Spruce. They actually had the best price. George Helton Firestar, 2702 Hirth 14GDH Mesick, Michigan gdhelton(at)gmail.com Sent from my iPhone > On Feb 11, 2019, at 6:44 PM, Nick Cassara wrote: > > > Kolbers, > > I am considering a Battery back up system, and wondering if anyone has experience with TCW Technologies? > > Thanks, > > Nick Cassara > Palmer, Alaska 99645 > > 607AK > > > > ________________________________________________________________________________
Subject: Battery Back up...
Date: Feb 12, 2019
Charle and Kolbers, An A&P from whom I was renting hanger space last year, thought it would be good to have a back up power source for the fuel injection and ignitionif things when bad, I could I can flip a switch and change the power source. hopefully giving me time to land somewhere safe. Nick Cassara Palmer, AK Kolbra 607AK ________________________________________________________________________________
Date: Feb 12, 2019
Subject: Re: Battery Back up...
Date: Feb 12, 2019
On 2/12/2019 7:35 PM, Nick Cassara wrote: > > Charle and Kolbers, > > An A&P from whom I was renting hanger space last year, thought it would be good to have a back up power source for the fuel injection and ignitionif things when bad, I could I can flip a switch and change the power source. hopefully giving me time to land somewhere safe. > > Nick Cassara > Palmer, AK > > Kolbra 607AK > If you're electrically dependent, he's right, at least in theory. I'm currently working on an electrically dependent engine (Mazda rotary) in an RV-7, & have friends who have been flying rotaries for years. Most of the guys I know are flying with a single alternator and single SLA battery (PC680 or similar), though a few have more elaborate systems with dual alts and/or dual batteries. The battery & alternator can be considered redundant power sources, unless total current requirements to stay in the air severely limit endurance on the battery (a working alternator has unlimited endurance). You can create a 'third layer' with a 2nd battery, kept charged through a Schottky diode, and only connected to your engine bus if you activate the 'panic' switch. The Schottky will only have about a half volt drop at most, once the battery is close to topped off, so it will always be fully charged as long as the alternator voltage is set above 14V. Lots cheaper than the TCW, and capacity can be whatever you want/need. If you're interested, we can go further with it. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Feb 13, 2019
Hey guys... Just to add some generic info about li-ion batteries and their care and feeding. Unlike lead-acid or ni-cad or ni-mh, lithium-ion cells are more critical of under voltage, over-voltage, or over-current. Most cells have a protective device that does not allow them to go below a certain cut-off voltage, or to be charged too high. But for starting a engine, most of those high capacity cells do not include that same protection device. If charged over 4.2v per cell, they can be damaged. If allowed to discharge below 3.3 they can also be damaged. Most consider 3.6-3.7 as a minimum cut-off. A pack can be assembled with high discharge cells using 18650 size, with up to 20-30A max current per string. IE 3 cells in series will net 11.1 - 12.6 volts. Multiple parallel sets can boost the current. But.. you will want to add a circuit which protects them, both in discharge and re-charge voltage, and to keep each group of cells balanced, and the discharge current within limits. The use of a diode, feeding a aux pack into the buss will keep it "out of the circuit" until the main battery drops enough that the aux is .5-.6v above it.. where the diode will then begin to conduct and provide current. That DOES NOT charge the cells however, as the diode is a one way device. And another factor, is that if your primary circuit or buss has a high drain problem or failure, THAT needs to be isolated first. Otherwise your back-up battery won't last very long. Some will use 2 packs that are switched so that one is charged.. while the other is active in circuit. Both can be used in parallel with high power diodes, for starting purposes. Up-side to li-ion.. they do have a long life when not in use. Ni-cads and Ni-Mh are both much worse at self discharge, and ni-cads bad about "memory" of not cycled fully. But none of the new high density technologies are without their particulars. Lithium polymer just tend to catch on fire if mistreated. Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487568#487568 ________________________________________________________________________________
Date: Feb 14, 2019
Good info on Lithium batteries. Also, they need to have the cells "balanced". They only charge until the cell with the most charge is charged and only discharge until the cell with the least cell is discharged. If there is a great difference between the cells it will seem like the capacity is reduced so it is a good idea to balance the cells on the ground to increase capacity. We only need the battery to use the starting motor but it is a nice back-up if the charging system fails. The Rotax has two ignition systems that are independent from the charging system and each other so I haven't heard of ignition failures as much as fuel problems. Dead stick landings are usually affected more by stalling than the wings falling off so I think practice is more important than three batteries. Respectfully, Dennis Baber Cape Coral, Fl baberdk(at)gmail.com 305-814-7218 Stay Curious ________________________________________________________________________________
Date: Feb 14, 2019
I installed a Aerovoltz iron lithium battery in my redrive VW powered Kolb MKIIIC in the summer of 2014. The battery has provided great service. The plane sits all winter while I'm in Florida and shows no measurable discharge. I take my balancing charger out to the plane every spring and check the battery cell balance. So far the voltages are within .1 volts and the balance charger can't improve that balance. These LiFe batteries don't seem to catch fire but they don't like to be over charged so I monitor the voltage while flying. Areovoltz has published a advisory to not use their batteries with some Rotax charging systems that have caused a battery melt down. The battery weighs 10lbs less than my old lead acid batteries and has lasted one year longer so far. Denny I don't understand what you are trying to say "Dead stick landings are usually affected more by stalling than the wings falling off so I think practice is more important than three batteries" Rick Neisen Redrive WV Powered MKIIIC On Thu, Feb 14, 2019 at 9:32 AM Denny Baber wrote: > Good info on Lithium batteries. Also, they need to have the cells > "balanced". They only charge until the cell with the most charge is charged > and only discharge until the cell with the least cell is discharged. If > there is a great difference between the cells it will seem like the > capacity is reduced so it is a good idea to balance the cells on the ground > to increase capacity. > We only need the battery to use the starting motor but it is a nice > back-up if the charging system fails. The Rotax has two ignition systems > that are independent from the charging system and each other so I haven't > heard of ignition failures as much as fuel problems. Dead stick landings > are usually affected more by stalling than the wings falling off so I think > practice is more important than three batteries. > > > Respectfully, > Dennis Baber > Cape Coral, Fl > baberdk(at)gmail.com > 305-814-7218 > > Stay Curious > > ________________________________________________________________________________
Date: Feb 14, 2019
Reference cell balancing: A small PC board is included in most serious "cordless" applications. Multi-function. During discharge, it measures the total output current, and limits that. Much like a active resettable fuse. Most are not adjustable, but instead selected for the particular application current. Cells can be assembled in parallel to boost current capacity, but that is not ideal, unless each has it's own current control, and tied together with high current diodes. Still basically in parallel, but also protected. And each cell voltage is monitored, and if one cell is higher than others, a small leakage current is established, that lowers the high cell voltage. It is minimal loss. The device also watches the minimum total voltage and will shut it down, if too low. During charge, the charging current and profile is regulated, AND the cells are kept balanced, again by slight current bypass, for any cells which are too high. If you simply take a rectified alternator output it will always be higher voltage than the peak system battery voltage, to charge it to the max. (approx 13.8 for lead acid). With any of the high energy density cells, the charge regime is very specific for the type of chemistry being charged. So that is why the above control board is used (required), to charge properly, from a poorly regulated engine source. And also why one pack can be "on-line" while the other is charging unencumbered to it's proper maximum voltage and rate. With most of these cells having a voltage of about 4 volts.. 3 cells will never be higher than 12.6V. If a diode is used, that will drop .5-.6 volts so the 3 cells will supply 12.1 max, down to 10.5. Some equipment can stand the higher voltage provided by 4 cells (16.8 minus .5-.6 for 16.2 max). A starter motor would probably be fine with the slightly higher voltage. Electronic devices are usually regulated internally but.. look at the specs before proceeding. Switching supplies can be used to boost or drop the battery voltage.. but that adds significant complexity and cost for the high current applications. The battery control boards are mass produced, and rather inexpensive. Each will have specific cell count, and output current range. Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487589#487589 ________________________________________________________________________________
Date: Feb 14, 2019
George 2Which aerovoltz battery do you have and what did t cost ? Thank u Chris Sent from my iPhone > On Feb 14, 2019, at 10:29 AM, Rick Neilsen wrote: > > I installed a Aerovoltz iron lithium battery in my redrive VW powered Kolb MKIIIC in the summer of 2014. The battery has provided great service. The p lane sits all winter while I'm in Florida and shows no measurable discharge. I take my balancing charger out to the plane every spring and check the bat tery cell balance. So far the voltages are within .1 volts and the balance c harger can't improve that balance. These LiFe batteries don't seem to catch f ire but they don't like to be over charged so I monitor the voltage while fl ying. Areovoltz has published a advisory to not use their batteries with som e Rotax charging systems that have caused a battery melt down. The battery w eighs 10lbs less than my old lead acid batteries and has lasted one year lon ger so far. > > Denny I don't understand what you are trying to say "Dead stick landings a re usually affected more by stalling than the wings falling off so I think p ractice is more important than three batteries" > > Rick Neisen > Redrive WV Powered MKIIIC > >> On Thu, Feb 14, 2019 at 9:32 AM Denny Baber wrote: >> Good info on Lithium batteries. Also, they need to have the cells "balanc ed". They only charge until the cell with the most charge is charged and onl y discharge until the cell with the least cell is discharged. If there is a g reat difference between the cells it will seem like the capacity is reduced s o it is a good idea to balance the cells on the ground to increase capacity. >> We only need the battery to use the starting motor but it is a nice back- up if the charging system fails. The Rotax has two ignition systems that are independent from the charging system and each other so I haven't heard of i gnition failures as much as fuel problems. Dead stick landings are usually a ffected more by stalling than the wings falling off so I think practice is m ore important than three batteries. >> >> >> Respectfully, >> Dennis Baber >> Cape Coral, Fl >> baberdk(at)gmail.com >> 305-814-7218 >> >> Stay Curious >> >> ________________________________________________________________________________
Date: Feb 15, 2019
Subject: Fixing my prop protractor
I've had my Warp drive prop protractor for 13 years and I've found it to be a valuable tool so when I found the level vial empty of fluid I was a bit bummed. Today is sub freezing, icy, and generally TV worthy but I'm even tired of that so I decided to track down a replacement vial. Turns out that it's a Stanley part but they're out of stock. Found the right size at McMaster Carr for less than $3 but shipping would probably push it up to $15. More searching and thoughts about levels in general and I decided to check out the string level sitting in a tool box out in the hangar. It's a Swanson part that can be had at Lowe's, Amazon, and Harbor Freight. The vial popped right out of the plastic frame of the string level and right into the prop protractor. Problem solved and I can pick up a new string level the next time I'm in The Big Tool Store (legendary local store where you can walk the aisles for hours). Rick -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Feb 16, 2019
Subject: Firestar Sale
Hi Kolbers, Tonight the shi pping sontractor showed up to take my Firestar to its new owner in Missouri. The new owner is Mr. Brandon Goring, and I sincerely wish him the best with this aircraft. It is my understanding thata he is going to put a 503 or other "appropriate" 2-stroke engine on it. Just to give everyone here some comfort, please rest assured that I returned it to almost stock configuration before I shipped it out. He is getting a safe airlane that is not "wonky", "strange" or greatly modified like it was when I was testing it. Please welcome Brandon and his aircraft to the Kolb List when he arrives. Importantly, I REMOVED the short extensions that raised the leading edge of the stabilizers and bolted them back in their original location. This was strongly suggested by John H and many others. The tall landing gear is still on it, however I did give the original stock length (aluminum) gear legs to the new owner with the aircraft in case he wants to start with the short gear. I had installed hydraulic brakes and Azusa aluminum wheels, instead of the cable brakes. These were left on the aircraft because many Kolbs have been successful with this upgrade,a nd it does not cause any abnormal characteristics. This Kolb has the upgrade heavy duty tailwheel as sold by Kolb. The 14 gallon plastic fuel tank was installed behind the pilot seat, since he indicated it was going to be flown as a single seat aircraft.This tanks is just about directly under the CG, so it will make the aircraft balance better and with less concern than even the stock fuel system. The vortex generators were left on the wings and tail, since these are now well known to be a safe and beneficial upgrade. I had installed stick-on trim tabs on the elevators and rudder. His engine installation will more than likely require the tabs to be re-adjusted, but the majority of Kolbs have stick-on trim tabs so I believe these are worth him keeping. Bill Berle www.ezflaphandle.com - safety & performance upgrade for light aircraft www.grantstar.net - winning proposals for non-profit and for-profit entities ________________________________________________________________________________
Date: Feb 17, 2019
Subject: Auto Response: Kolb-List Digest: 1 Msgs - 02/16/19
Hello, I am away until 2019/3/1 and am unable to read your message. ________________________________________________________________________________
Subject: 912 installation photos?
Date: Feb 19, 2019
Greetings, I'll be installing a 912 on the Slingshot, and I've been looking around for pictures of similar 912 installations. With all the the stuff you have to mount for a 912, there seems to be no standard location from the few pictures I've seen. I'd be interested to see where others have mounted the radiator, reservoir, oil tank, and oil cooler. The oil cooler is the one item that appears to be mounted in the same place by nearly everyone. Typically it hangs off the back of the engine mount, but they make two oil coolers, a small and large. I've seen both used, so now I'm not sure which one is needed for TN latitudes? I've seen the radiator in front of the engine, but that may interfere with the BRS canister. I'll be putting the fuel tank where the rear seat would be, so there's an open area below the engine. Unfortunately, I don't think any of this stuff can be mounted inside there. Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487688#487688 ________________________________________________________________________________
Subject: Re: 912 installation photos?
From: "DavidGerdeman" <davidrgerdeman(at)gmail.com>
Date: Feb 20, 2019
Rusty, I don't know if Ralph Burlingame from Michigan is on here but he is on the Facebook page. Maybe he could take pictures of his Kolbra with a 912 ULS for us. Have you watched his videos on YouTube? Might see something there too. Can you email me at davidrgerdeman(at)gmail.com ? Slingshot talk... -------- Sometimes flying, sometimes planning, hopefully soon to be building. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487708#487708 ________________________________________________________________________________
Date: Feb 20, 2019
DavidGerdeman wrote: > Rusty, > I don't know if Ralph Burlingame from Michigan is on here but he is on the Facebook page. Maybe he could take pictures of his Kolbra with a 912 ULS for us. Have you watched his videos on YouTube? Might see something there too. > > Can you email me at davidrgerdeman(at)gmail.com ? Slingshot talk... Good ideas David. I found some nice pictures linked to his FB page, and made some captures from videos. If I need any specific details, I have to believe he'd take some pictures since he doesn't seem to need much of a reason to use his camera. I noticed that he's got the smaller oil cooler, but most of his videos have snow in them too. He also doesn't have a BRS in the way. I considered mounting the BRS in the rear of the plane, but there isn't enough room. The only other option is on the bottom of the fuselage, pointing backwards of course. With the proper routing of the bridle, it's not a bad option really. Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487713#487713 ________________________________________________________________________________
Date: Feb 20, 2019
13brv3 wrote: > > DavidGerdeman wrote: > > Rusty, > > I don't know if Ralph Burlingame from Michigan is on here but he is on the Facebook page. Maybe he could take pictures of his Kolbra with a 912 ULS for us. Have you watched his videos on YouTube? Might see something there too. > > > > Can you email me at davidrgerdeman(at)gmail.com ? Slingshot talk... > > > Good ideas David. I found some nice pictures linked to his FB page, and made some captures from videos. If I need any specific details, I have to believe he'd take some pictures since he doesn't seem to need much of a reason to use his camera. > > I noticed that he's got the smaller oil cooler, but most of his videos have snow in them too. He also doesn't have a BRS in the way. > > I considered mounting the BRS in the rear of the plane, but there isn't enough room. The only other option is on the bottom of the fuselage, pointing backwards of course. With the proper routing of the bridle, it's not a bad option really. > > Rusty Rusty, I would be happy to send you any pictures that you need. Contact me on Facebook messenger and I will give you my email address to send you pictures and/or advice. -------- Ralph B Kolb Kolbra 912uls N20386 550 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487715#487715 ________________________________________________________________________________
Subject: 582 starter stud O-rings
Date: Feb 20, 2019
Going through the 582 on my MKIII, doing one of those REALLY SERIOUS annuals, needed to replace all the O-rings that fit on the starter studs to shock mount it to the starter cover plate. Rotax is proud of those little puds, replacing all of them will run you about $100. Went down to the local industrial supply place and showed them a printout of the Rotax part sheet, he quickly figured out how the Metric sizing worked and was able to order me some new (American) Metric O-rings; with shipping it came to $50.28 delivered to the house. They fit perfectly. Food for thought. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal (Ready for a test flight on the new 277) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487722#487722 ________________________________________________________________________________
Date: Feb 21, 2019
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: 582 starter stud O-rings
Richard- Along the same line, a few years ago a friend needed to replace a U-joint on the stern drive of his boat. The dealer wanted $120 for the complete assembly. I looked at it for him, and found that it was a standard 1100 series Spicer Journal assembly. I think it was $14 at the time, and took us an hour to install. A lot of these exotically expensive parts are commonly available, if you care to look. Bill Sullivan Tarboro, NC Date: Wednesday, February 20, 2019, 9:18 PM Pike" Went down to the local industrial supply place and showed them a printout of the Rotax part sheet, he quickly figured out how the Metric sizing worked and was able to order me some new (American) Metric O-rings; with shipping it came to $50.28 delivered to the house. They fit perfectly. ________________________________________________________________________________
Date: Feb 21, 2019
Richard and anyone else with a 582, For what it's worth McMaster Carr has those o-rings for about $48 plus shipping. The difference is that's for 20 ship sets. Add $8 for shipping (o-rings ship in an envelope) and you and nine buddies could do the starter set for $5.60 each. Since they last 15 years if you have six buddies chip in you could do the o-rings every 5 years and have a few of each size left over for spares. Same kind of deal for 912 intake o-rings. About $10 for 50 from McMC or $15 EACH from Rotax. Rick Girard On Wed, Feb 20, 2019 at 9:44 PM william sullivan wrote: > williamtsullivan(at)att.net> > > Richard- Along the same line, a few years ago a friend needed to replac e > a U-joint on the stern drive of his boat. The dealer wanted $120 for the > complete assembly. I looked at it for him, and found that it was a > standard 1100 series Spicer Journal assembly. I think it was $14 at the > time, and took us an hour to install. A lot of these exotically expensiv e > parts are commonly available, if you care to look. > > Bill Sullivan > Tarboro, NC > > Date: Wednesday, February 20, 2019, 9:18 PM > > Pike" > > Went down to the local industrial > supply place and showed them a printout of the Rotax part > sheet, he quickly figured out how the Metric sizing worked > and was able to order me some new (American) Metric O-rings; > with shipping it came to $50.28 delivered to the house. They > fit perfectly. > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Feb 21, 2019
That should have been you and eighteen buddies. That's based on the 6 x 3 o-ring coming in packs of 100 and all the others in packs of 50. Sorry about that, I was thinking of least waste of the packs of 50. Rick PS if you need the 62 x 1.5 starter body o-ring they're $16.50 for 20 vs $11.38 (part no 850500) EACH from Rotax and you need 2. On Thu, Feb 21, 2019 at 5:18 PM Richard Girard wrote: > Richard and anyone else with a 582, For what it's worth McMaster Carr has > those o-rings for about $48 plus shipping. The difference is that's for 2 0 > ship sets. Add $8 for shipping (o-rings ship in an envelope) and you and > nine buddies could do the starter set for $5.60 each. Since they last 15 > years if you have six buddies chip in you could do the o-rings every 5 > years and have a few of each size left over for spares. > Same kind of deal for 912 intake o-rings. About $10 for 50 from McMC or > $15 EACH from Rotax. > > Rick Girard > > On Wed, Feb 20, 2019 at 9:44 PM william sullivan > wrote: > >> williamtsullivan(at)att.net> >> >> Richard- Along the same line, a few years ago a friend needed to >> replace a U-joint on the stern drive of his boat. The dealer wanted $12 0 >> for the complete assembly. I looked at it for him, and found that it wa s a >> standard 1100 series Spicer Journal assembly. I think it was $14 at the >> time, and took us an hour to install. A lot of these exotically expensi ve >> parts are commonly available, if you care to look. >> >> Bill Sullivan >> Tarboro, NC >> >> Date: Wednesday, February 20, 2019, 9:18 PM >> >> Pike" >> >> Went down to the local industrial >> supply place and showed them a printout of the Rotax part >> sheet, he quickly figured out how the Metric sizing worked >> and was able to order me some new (American) Metric O-rings; >> with shipping it came to $50.28 delivered to the house. They >> fit perfectly. >> >> >> >> >> >> >> >> >> >> =========== =========== =========== =========== =========== >> >> >> >> > > -- > =9CBlessed are the cracked, for they shall let in the light. =9D Groucho Marx > <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Feb 22, 2019
TW9zdCB0b3ducyBvZiAzMGsgcGx1cyBoYXZlIENvcmssIHJ1YmJlciAgYW5kIGdhc2tldCBsb2Nh dGlvbnMgYW5kIGhhdmUgYWxsIHNpemVzIG9mIE8gcmluZ3MuLi4KCiAgIEkgYm91Z2h0IGFsbCBv ZiB0aGUgYmVhcmluZ3MgdG8gYnVpbGQgYSBjIGJveCBmcm9tIGEgYmVhcmluZyBzdG9yZS4uc3Rk IGJlYXJpbmdzIGFuZCBzZWFscy4uLlRoZSBwbidzIGFyZSBsaXN0ZWQgYXQgQ1BTIHVuZGVyIGdl YXIgYm94IHBhcnRzIGZvciBvbmUgZXhhbXBsZS4uLgoKaHR0cDovL3d3dy5iZ3J1YmJlci5jb20v CgpIZXJiCgpTZW50IHdpdGggW1Byb3Rvbk1haWxdKGh0dHBzOi8vcHJvdG9ubWFpbC5jb20pIFNl Y3VyZSBFbWFpbC4KCuKAkOKAkOKAkOKAkOKAkOKAkOKAkCBPcmlnaW5hbCBNZXNzYWdlIOKAkOKA kOKAkOKAkOKAkOKAkOKAkApPbiBUaHVyc2RheSwgRmVicnVhcnkgMjEsIDIwMTkgNToxOCBQTSwg UmljaGFyZCBHaXJhcmQgPGFzbHNhLnJuZ0BnbWFpbC5jb20+IHdyb3RlOgoKPiBSaWNoYXJkIGFu ZCBhbnlvbmUgZWxzZSB3aXRoIGEgNTgyLCBGb3Igd2hhdCBpdCdzIHdvcnRoIE1jTWFzdGVyIENh cnIgaGFzIHRob3NlIG8tcmluZ3MgZm9yIGFib3V0ICQ0OCBwbHVzIHNoaXBwaW5nLiBUaGUgZGlm ZmVyZW5jZSBpcyB0aGF0J3MgZm9yIDIwIHNoaXAgc2V0cy4gQWRkICQ4IGZvciBzaGlwcGluZyAo by1yaW5ncyBzaGlwIGluIGFuIGVudmVsb3BlKSBhbmQgeW91IGFuZCBuaW5lIGJ1ZGRpZXMgY291 bGQgZG8gdGhlIHN0YXJ0ZXIgc2V0IGZvciAkNS42MCBlYWNoLiBTaW5jZSB0aGV5IGxhc3QgMTUg eWVhcnMgaWYgeW91IGhhdmUgc2l4IGJ1ZGRpZXMgY2hpcCBpbiB5b3UgY291bGQgZG8gdGhlIG8t cmluZ3MgZXZlcnkgNSB5ZWFycyBhbmQgaGF2ZSBhIGZldyBvZiBlYWNoIHNpemUgbGVmdCBvdmVy IGZvciBzcGFyZXMuCj4gU2FtZSBraW5kIG9mIGRlYWwgZm9yIDkxMiBpbnRha2Ugby1yaW5ncy4g QWJvdXQgJDEwIGZvciA1MCBmcm9tIE1jTUMgb3IgJDE1IEVBQ0ggZnJvbSBSb3RheC4KPgo+IFJp Y2sgR2lyYXJkCj4KPiBPbiBXZWQsIEZlYiAyMCwgMjAxOSBhdCA5OjQ0IFBNIHdpbGxpYW0gc3Vs bGl2YW4gPHdpbGxpYW10c3VsbGl2YW5AYXR0Lm5ldD4gd3JvdGU6Cj4KPj4gLS0+IEtvbGItTGlz dCBtZXNzYWdlIHBvc3RlZCBieTogd2lsbGlhbSBzdWxsaXZhbiA8d2lsbGlhbXRzdWxsaXZhbkBh dHQubmV0Pgo+Pgo+PiAgIFJpY2hhcmQtIEFsb25nIHRoZSBzYW1lIGxpbmUsIGEgZmV3IHllYXJz IGFnbyBhIGZyaWVuZCBuZWVkZWQgdG8gcmVwbGFjZSBhIFUtam9pbnQgb24gdGhlIHN0ZXJuIGRy aXZlIG9mIGhpcyBib2F0LiAgVGhlIGRlYWxlciB3YW50ZWQgJDEyMCBmb3IgdGhlIGNvbXBsZXRl IGFzc2VtYmx5LiAgSSBsb29rZWQgYXQgaXQgZm9yIGhpbSwgYW5kIGZvdW5kIHRoYXQgaXQgd2Fz IGEgc3RhbmRhcmQgMTEwMCBzZXJpZXMgU3BpY2VyIEpvdXJuYWwgYXNzZW1ibHkuICBJIHRoaW5r IGl0IHdhcyAkMTQgYXQgdGhlIHRpbWUsIGFuZCB0b29rIHVzIGFuIGhvdXIgdG8gaW5zdGFsbC4g IEEgbG90IG9mIHRoZXNlIGV4b3RpY2FsbHkgZXhwZW5zaXZlIHBhcnRzIGFyZSBjb21tb25seSBh dmFpbGFibGUsIGlmIHlvdSBjYXJlIHRvIGxvb2suCj4+Cj4+ICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICBCaWxsIFN1bGxpdmFuCj4+ICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICBUYXJib3Jv LCBOQwo+Pgo+PiAgRGF0ZTogV2VkbmVzZGF5LCBGZWJydWFyeSAyMCwgMjAxOSwgOToxOCBQTQo+ Pgo+PiAgLS0+IEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIlJpY2hhcmQKPj4gIFBpa2Ui Cj4+Cj4+ICBXZW50IGRvd24gdG8gdGhlIGxvY2FsIGluZHVzdHJpYWwKPj4gIHN1cHBseSBwbGFj ZSBhbmQgc2hvd2VkIHRoZW0gYSBwcmludG91dCBvZiB0aGUgUm90YXggcGFydAo+PiAgc2hlZXQs IGhlIHF1aWNrbHkgZmlndXJlZCBvdXQgaG93IHRoZSBNZXRyaWMgc2l6aW5nIHdvcmtlZAo+PiAg YW5kIHdhcyBhYmxlIHRvIG9yZGVyIG1lIHNvbWUgbmV3IChBbWVyaWNhbikgTWV0cmljIE8tcmlu Z3M7Cj4+ICB3aXRoIHNoaXBwaW5nIGl0IGNhbWUgdG8gJDUwLjI4IGRlbGl2ZXJlZCB0byB0aGUg aG91c2UuIFRoZXkKPj4gIGZpdCBwZXJmZWN0bHkuCj4+Cj4+ID09PT09PT09PT09Cj4+IC1MaXN0 IiByZWw9Im5vcmVmZXJyZXIiIHRhcmdldD0iX2JsYW5rIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5j b20vTmF2aWdhdG9yP0tvbGItTGlzdAo+PiA9PT09PT09PT09PQo+PiBGT1JVTVMgLQo+PiBlZmVy cmVyIiB0YXJnZXQ9Il9ibGFuayI+aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCj4+ID09PT09 PT09PT09Cj4+IFdJS0kgLQo+PiBlcnJlciIgdGFyZ2V0PSJfYmxhbmsiPmh0dHA6Ly93aWtpLm1h dHJvbmljcy5jb20KPj4gPT09PT09PT09PT0KPj4gYiBTaXRlIC0KPj4gICAgICAgICAgIC1NYXR0 IERyYWxsZSwgTGlzdCBBZG1pbi4KPj4gcmVsPSJub3JlZmVycmVyIiB0YXJnZXQ9Il9ibGFuayI+ aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgo+PiA9PT09PT09PT09PQo+Cj4g LS0KPgo+IOKAnEJsZXNzZWQgYXJlIHRoZSBjcmFja2VkLCBmb3IgdGhleSBzaGFsbCBsZXQgaW4g dGhlIGxpZ2h0LuKAnSAgIFtHcm91Y2hvIE1hcnhdKGh0dHA6Ly93d3cuZ29vZHJlYWRzLmNvbS9h dXRob3Ivc2hvdy80MzI0NC5Hcm91Y2hvX01hcngp ________________________________________________________________________________
Subject: Antenna Questions
Date: Feb 26, 2019
No. 1: Will a handheld rubber ducky antenna suffice for airport traffic use? No. 2: Can an external antenna be mounted 2-3ft from the engine? No. 3: If mounted on Lexon, does the antenna need a ground plane, & if so, how large should it be & would the ground plane need to be grounded to the air frame? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487825#487825 ________________________________________________________________________________
Date: Feb 26, 2019
Subject: Re: Antenna Questions
On Tue, Feb 26, 2019 at 2:43 PM slingshot003 wrote: > > No. 1: Will a handheld rubber ducky antenna suffice for airport traffic > use? > Barely! > > No. 2: Can an external antenna be mounted 2-3ft from the engine? > Mount your antenna on the bottom, attach it to a round alum ground plane riveted to the cross members there. > > No. 3: If mounted on Lexon, does the antenna need a ground plane, & if so, > how large should it be & would the ground plane need to be grounded to the > air frame? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487825#487825 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Feb 27, 2019
I use a hand held using a Ram Mount with the antenna sticking through the w ind shield with a rubber grommet in the windshield. It has worked real well except the wind noise. I have started using a leather mic cover with a tin y hole , this has made me more clear. But the radio itself and 8" or so ant enna works well Get Outlook for Android ________________________________ From: owner-kolb-list-server(at)matronics.com <owner-kolb-list-server@matronic s.com> on behalf of Larry Cottrell Sent: Tuesday, February 26, 2019 3:56:03 PM Subject: Re: Kolb-List: Antenna Questions On Tue, Feb 26, 2019 at 2:43 PM slingshot003 > wrote: bxtn(at)gmail.com>> No. 1: Will a handheld rubber ducky antenna suffice for airport traffic use ? Barely! No. 2: Can an external antenna be mounted 2-3ft from the engine? Mount your antenna on the bottom, attach it to a round alum ground plane ri veted to the cross members there. No. 3: If mounted on Lexon, does the antenna need a ground plane, & if so, how large should it be & would the ground plane need to be grounded to the air frame? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487825#487825 -List" rel="noreferrer" target="_blank">http://www.matronics.com/Naviga tor?Kolb-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution -- The older I get, the less tolerant I am of those who are intolerant of othe rs. If you forward this email, or any part of it, please remove my email addres s before sending. ________________________________________________________________________________
Date: Feb 28, 2019
Thanks for the replies. I found out that all our antennas need a ground plane, as it is the other half of the dipole antenna. It can be the airframe itself grounded to the antenna, or a sheet of aluminum, or even sticky-back copper foil tapped to lexon in the form of 4 to 8 spokes that have a radius equal to the length of the antenna (shorter works but not as good.) They need to be soldered at their intersection. Craft stores carry the foil tape. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487857#487857 ________________________________________________________________________________
Date: Feb 28, 2019
> > Check with a local ham radio club. They they have testing equipment > they might think it's a unique enough project they might come out and help > you for free. To find a club maybe check with arrl.org and you should be able to find or search for a ham radio club near you Boyd Young ________________________________________________________________________________
Subject: More Kolb History
Date: Mar 06, 2019
I flew my Firestar from Alabama to OSH 1989 via Homer Kolb's in PA, Bert Ho wland's, Maryland, NY, The Flight Farm, Monterey, NY, Niagara Falls, Sault St Marie, Canada, down the west side of Lake Michigan to OSH. Dick Rahill and I had a lot of fun flying at OSH. We had been flying the UL traffic pa ttern a while trying to outdo each other until the last landing. We were l anding to the south. In 1989 we had to make a hard right hook, right befor e touchdown, to land. Dick and I were making that turn tighter and tighter . This photo shows Dick flying the Kolb Factory Firestar, the 1985 Oshkosh Grand Champion UL just prior to it being totaled. I had just landed, pull ed off the airstrip, turned around and caught Dick in full stall just prior to impact. He rolled it up in a ball. Homer kept the wreckage for many, many years before he rebuilt it. I had flown this Firestar at Sun and Fun 1985 before they took it to OSH. The last trip to PA to visit Homer I got to fly the FS with a DC 503. It was a high performer and fun to fly. Rest in peace, Homer and Clara. john h Titus, Alabama ________________________________________________________________________________
Date: Mar 06, 2019
Forgot to add in my previous: Shot photo through my FS windshield. john From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@m atronics.com] On Behalf Of John Hauck Sent: Wednesday, March 06, 2019 3:42 PM Subject: Kolb-List: More Kolb History I flew my Firestar from Alabama to OSH 1989 via Homer Kolb's in PA, Bert Ho wland's, Maryland, NY, The Flight Farm, Monterey, NY, Niagara Falls, Sault St Marie, Canada, down the west side of Lake Michigan to OSH. Dick Rahill and I had a lot of fun flying at OSH. We had been flying the UL traffic pa ttern a while trying to outdo each other until the last landing. We were l anding to the south. In 1989 we had to make a hard right hook, right befor e touchdown, to land. Dick and I were making that turn tighter and tighter . This photo shows Dick flying the Kolb Factory Firestar, the 1985 Oshkosh Grand Champion UL just prior to it being totaled. I had just landed, pull ed off the airstrip, turned around and caught Dick in full stall just prior to impact. He rolled it up in a ball. Homer kept the wreckage for many, many years before he rebuilt it. I had flown this Firestar at Sun and Fun 1985 before they took it to OSH. The last trip to PA to visit Homer I got to fly the FS with a DC 503. It was a high performer and fun to fly. Rest in peace, Homer and Clara. john h Titus, Alabama [cid:image001.jpg(at)01D4D435.AEE9F370] ________________________________________________________________________________
Subject: Re: More Kolb History
Date: Mar 06, 2019
John, did that airplane have a normal gap seal? Just looking at the picture it is hard to see it. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal (Ready for a test flight on the new 277) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487958#487958 ________________________________________________________________________________
Date: Mar 07, 2019
This story just reminds us that we are still waiting for JH's history of his adventures with Kolb. We'd really like to read it an have it recorded. It's aviation history that'll never be repeated...... JG ________________________________________________________________________________
Date: Mar 07, 2019
Richard/Kolbers: I don't remember for sure. I imagine it was the standard white nylon gap seal that came with the FS kits at the time. You are referring to the "center section" I am assuming. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Wednesday, March 06, 2019 8:20 PM Subject: Kolb-List: Re: More Kolb History John, did that airplane have a normal gap seal? Just looking at the picture it is hard to see it. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal (Ready for a test flight on the new 277) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487958#487958 ________________________________________________________________________________
Date: Mar 07, 2019
Hi John G/Kolbers: You are absolutely right, John G. I don't think it will be repeated. As I look back 35 years ago, this month, when I bought my first Kolb kit, every day was a new day of building, modifying, experimenting, and making mistakes. The cross country flights were virgin territory everywhere I went. Most important the lasting friendships from people I met along the way. Most of the people I know, I met through these little airplanes. I have one more adventure to get under my belt before I settle down. Next month I turn 80. I plan to celebrate my 80th year by cruising the Great Loop https://www.greatloop.org/ . It is an approximately 6,000 mile route along the waterways of the Tombigbee and Mobile Rivers, Gulf of Mexico, the Atlantic Coast, Hudson River, Erie Canal, Lakes Erie, Huron, and Michigan, the Illinois, Mississippi, Ohio, and Tennessee Rivers, and finally the Tennessee-Tombigbee Waterway back to Demopolis, Alabama, where I plan to start my trip. I'm also going to try to visit Fort Hamilton, where John Wilkes Booth was imprisoned, on the Dry Tortugas, 75 miles out of Key West, Florida, while I am in that area. Entire cruise should take about 2 to 3 months depending on the situation. I do not have a schedule to follow or dead lines to meet. I may make this an annual affair until I get too old to enjoy. ;-) Then I should have time to get started on the Memories of a Retired Army Aviator. In fact, writing would be a good pass time for the days, maybe weeks, of getting weathered in with nothing to do but polish Grumpy, my 25 foot Rosborough RF-246. Should have plenty time. I don't plan on doing too much polishing on Grumpy. To keep this Kolb oriented, I plan on meeting Marcus Kolb when I am in the Philadelphia, PA, area. I have a lot of Army and airplane friends that live along this route that I plan to visit. john h mkIII Titus, Alabama From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of JC Gilpin Sent: Thursday, March 07, 2019 2:00 AM Subject: Kolb-List: More Kolb History This story just reminds us that we are still waiting for JH's history of his adventures with Kolb. We'd really like to read it an have it recorded. It's aviation history that'll never be repeated...... JG ________________________________________________________________________________
Date: Mar 08, 2019
You are pretty amazing, John! Hope I am still flying when I hit 80 , much l ess planning a trip such as yours! Best of weather to you, Lanny Lambdin Sent from my iPad > On Mar 7, 2019, at 8:46 AM, John Hauck wrote: > > Hi John G/Kolbers: > > You are absolutely right, John G. I don't think it will be repeated. As I look back 35 years ago, this month, when I bought my first Kolb kit, every d ay was a new day of building, modifying, experimenting, and making mistakes. The cross country flights were virgin territory everywhere I went. Most i mportant the lasting friendships from people I met along the way. Most of t he people I know, I met through these little airplanes. > > I have one more adventure to get under my belt before I settle down. Next month I turn 80. I plan to celebrate my 80th year by cruising the Great Lo op https://www.greatloop.org/ . It is an approximately 6,000 mile route alo ng the waterways of the Tombigbee and Mobile Rivers, Gulf of Mexico, the Atl antic Coast, Hudson River, Erie Canal, Lakes Erie, Huron, and Michigan, the I llinois, Mississippi, Ohio, and Tennessee Rivers, and finally the Tennessee- Tombigbee Waterway back to Demopolis, Alabama, where I plan to start my trip . I'm also going to try to visit Fort Hamilton, where John Wilkes Booth was imprisoned, on the Dry Tortugas, 75 miles out of Key West, Florida, while I am in that area. Entire cruise should take about 2 to 3 months depending o n the situation. I do not have a schedule to follow or dead lines to meet. I may make this an annual affair until I get too old to enjoy. ;-) > > Then I should have time to get started on the Memories of a Retired Army A viator. In fact, writing would be a good pass time for the days, maybe week s, of getting weathered in with nothing to do but polish Grumpy, my 25 foot R osborough RF-246. Should have plenty time. I don't plan on doing too much p olishing on Grumpy. > > To keep this Kolb oriented, I plan on meeting Marcus Kolb when I am in the Philadelphia, PA, area. I have a lot of Army and airplane friends that liv e along this route that I plan to visit. > > john h > mkIII > Titus, Alabama > > > > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com] On Behalf Of JC Gilpin > Sent: Thursday, March 07, 2019 2:00 AM > To: kolb-list(at)matronics.com > Subject: Kolb-List: More Kolb History > > This story just reminds us that we are still waiting for JH's history of h is adventures with Kolb. We'd really like to read it an have it recorded. It 's aviation history that'll never be repeated...... > JG ________________________________________________________________________________
Subject: Need parts list/plan prints for Firestar
Date: Mar 08, 2019
Greetings fellow Kolb enthusiasts, I just got a nice old Kolb Firestar and am trying to get a hold of a parts list/booklet and/or the plans prints to get to know all about the bird. I have all the engine info, and the builder manual for the Firestar, but it seems to be lacking any parts info that would be pertinent to ensuring correct parts/assembly and replacing anything I may need to. I will be looking for some Kolbs next month @ SNF when I go, but would like to see if anyone here can point me in the right direction or if anyone has anything that may help. Emailing Kolb didn't get a reply, but didn't pursue it further, yet. Thanks for any help, hope to see some of you @ SNF, and any help is greatly appreciated, Thanks, Steve -------- Kolb Firestar new to me Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487980#487980 ________________________________________________________________________________
Subject: Re: Need parts list/plan prints for Firestar
Date: Mar 09, 2019
I have a wrecked one with a blue print book and misc parts. Looking for anything in particular? -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487982#487982 ________________________________________________________________________________
Date: Mar 09, 2019
Looking for any info on parts I may need in the future. And would like to see the designed mounting setup for the wings and struts and landing gear. Would also be nice to have measurements to bounce the rigging against. Easier to see how it was planned to be put together when deciding to replace parts or making sure they are actually there/correct and not left out by one of the previous owners. Dont think I need any parts now, but a parts book/list or prints might tell me otherwise. Lol Steve -------- Kolb Firestar new to me Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487984#487984 ________________________________________________________________________________
Date: Mar 09, 2019
I too am looking for all the associated prints, part list, builder manual, and operating manual fora 7 rib KXP Firestar. I spoke with Kolb & this is no longer available. It sure would be nice if we as a group could digitize this stuff (that is no longer availble from Kolb) so it can be preserved and made available so that second hand Kolb owners are not left to figure things out for themselves. It would make for a safer Kolb community and it would be greatly appreciated to those new to Kolb aircraft. I have a scanner & will pay for postage of KXP material; scan them and return it to you; then make it available to for all to use. It would be best if someone with a website would store this stuff. As helpful as the Kolb Company is, I'd bet they would even put a link to it on their website. I still have the prints for my old Twinstar MK II. If they are no longer available from Kolb, then I would donate them to someone who needs them on the condition that they digitize them and make them available for the future needs of others. -Richard Swiderski Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487986#487986 ________________________________________________________________________________
Date: Mar 10, 2019
I have seen a link to one of the books here on this site but I am not sure which model it was. It would be a project to get my Firestar book all together and posted I may have to do that... -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487997#487997 ________________________________________________________________________________
Date: Mar 10, 2019
Richard I believe I hav the builders manual for the KXP as I built and flew on 19 years ago do you have the means to copy it and return it to me ? I wish to hold on to it for old times sake. CHRIS Sent from my iPhone > On Mar 9, 2019, at 11:15 AM, slingshot003 wrote: > > > I too am looking for all the associated prints, part list, builder manual, and operating manual fora 7 rib KXP Firestar. I spoke with Kolb & this is no longer available. > > It sure would be nice if we as a group could digitize this stuff (that is no longer availble from Kolb) so it can be preserved and made available so that second hand Kolb owners are not left to figure things out for themselves. It would make for a safer Kolb community and it would be greatly appreciated to those new to Kolb aircraft. > > I have a scanner & will pay for postage of KXP material; scan them and return it to you; then make it available to for all to use. It would be best if someone with a website would store this stuff. > > As helpful as the Kolb Company is, I'd bet they would even put a link to it on their website. > > I still have the prints for my old Twinstar MK II. If they are no longer available from Kolb, then I would donate them to someone who needs them on the condition that they digitize them and make them available for the future needs of others. -Richard Swiderski > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487986#487986 > > > > > > > > > ________________________________________________________________________________
Date: Mar 10, 2019
Chris, That would be great! Yes I can scan up to legal size pages. Send me an email at i2bxtn(at)gmail.com and we can work out the details. Thank you. Richard Swiderski Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488000#488000 ________________________________________________________________________________
Date: Mar 10, 2019
Seems like you are getting what you need, but if not, I have a complete set of blue prints rolled up in a tube (way beyond legal size, very large, blue print size - something like 2' x 3') for a Firestar KXP 7 rib, back from the Phoenixville. PA Kolb days. I do not believe there ever was a build manual, just those blue prints with their notes. If you don't get what you need, contact me. I won't part with them, but I could take them to Staples and get them reproduced (probably cost over $50 - I did that once before). If you are nearby, we could meet at Staples. I live near Upperstrasburg, PA 17265 Dennis Urban denniswurban at gmail Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488004#488004 ________________________________________________________________________________
Date: Mar 13, 2019
I made a copy of the 1989 Firefly manual today. I had trouble getting the link to work, I try to make it work better when I can but if you feel like trying here is a link. www.west1m.com/flyin/FireflyManual.zip I have some Firestar prints also I will try to do the same with those if anyone thinks these were worth the effort. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488055#488055 ________________________________________________________________________________
Date: Mar 14, 2019
Subject: Re: Kolb-List Digest: 1 Msgs - 03/13/19
Thank you for the offer. As my FireStar KXP plans are no longer available, I for one would be interested in your offer. -Richard Swiderski On Thu, Mar 14, 2019 at 2:40 AM Kolb-List Digest Server < kolb-list(at)matronics.com> wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-03-13&Archive=Kolb > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 19-03-13&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Wed 03/13/19: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 03:29 PM - Re: Need parts list/plan prints for Firestar (west1m) > > > ________________________________ Message 1 > _____________________________________ > > > Subject: Kolb-List: Re: Need parts list/plan prints for Firestar > From: "west1m" <west1m(at)hotmail.com> > > > I made a copy of the 1989 Firefly manual today. I had trouble getting the > link > to work, I try to make it work better when I can but if you feel like > trying here > is a link. > www.west1m.com/flyin/FireflyManual.zip > I have some Firestar prints also I will try to do the same with those if > anyone > thinks these were worth the effort. > > -------- > West1m > Hastings, MN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=488055#488055 > > -- *Click on to Richard's Blog: <http://GodStuffRichard.blogspot.com> <http://GodStuffRichard.blogspot.com> * *Thoughts On God And Life <http://godstuffrichard.blogspot.com> -**Prose, **Prayers, Poems & Ponderings * ________________________________________________________________________________
Date: Mar 14, 2019
Richard if you want me to send the KXP builders manual why don=99t you give me your address and I will mail it ?This discussion has been going on f or days yet I haven=99t seen an address . It=99s simple address , manual done deal . Chris Sent from my iPhone > On Mar 14, 2019, at 11:22 AM, Richard Swiderski wrote: > > Thank you for the offer. As my FireStar KXP plans are no longer available , I for one would be interested in your offer. -Richard Swiderski > >> On Thu, Mar 14, 2019 at 2:40 AM Kolb-List Digest Server wrote: >> * >> >> ======================== >> Online Versions of Today's List Digest Archive >> ======================== >> >> Today's complete Kolb-List Digest can also be found in either of the >> two Web Links listed below. The .html file includes the Digest formatted >> in HTML for viewing with a web browser and features Hyperlinked Indexes >> and Message Navigation. The .txt file includes the plain ASCII version >> of the Kolb-List Digest and can be viewed with a generic text editor >> such as Notepad or with a web browser. >> >> HTML Version: >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=h tml&Chapter 19-03-13&Archive=Kolb >> >> Text Version: >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=t xt&Chapter 19-03-13&Archive=Kolb >> >> >> ====================== >> EMail Version of Today's List Digest Archive >> ====================== >> >> >> ---------------------------------------------------------- >> Kolb-List Digest Archive >> --- >> Total Messages Posted Wed 03/13/19: 1 >> ---------------------------------------------------------- >> >> >> Today's Message Index: >> ---------------------- >> >> 1. 03:29 PM - Re: Need parts list/plan prints for Firestar (west1m) >> >> >> >> ________________________________ Message 1 ____________________________ _________ >> >> >> Subject: Kolb-List: Re: Need parts list/plan prints for Firestar >> From: "west1m" <west1m(at)hotmail.com> >> >> >> I made a copy of the 1989 Firefly manual today. I had trouble getting the link >> to work, I try to make it work better when I can but if you feel like try ing here >> is a link. >> www.west1m.com/flyin/FireflyManual.zip >> I have some Firestar prints also I will try to do the same with those if a nyone >> thinks these were worth the effort. >> >> -------- >> West1m >> Hastings, MN >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=488055#488055 >> >> >> >> >> ========== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?Kolb-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========== >> >> >> >> > > > -- > Click on to Richard's Blog: > Thoughts On God And Life -Prose, Prayers, Poems & Ponderings > ________________________________________________________________________________
Date: Mar 15, 2019
Subject: Re: Kolb-List Digest: 2 Msgs - 03/14/19
Chris, I=99m sorry for the mix up. Earlier, I sent my address & phone numbe r to your yahoo email. I re-sent it today just in case. If you still do not get my email, leave a message on my land line (352-three 07-9009). Thank you for voluntarily putting yourself through this trouble for me, a stranger. =93Richard Swiderski On Fri, Mar 15, 2019 at 2:40 AM Kolb-List Digest Server < kolb-list(at)matronics.com> wrote: > * > > ======================== > Online Versions of Today's List Digest Archive > ======================== > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html& Chapter 19-03-14&Archive=Kolb > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&C hapter 19-03-14&Archive=Kolb > > > ======================== ======================= > EMail Version of Today's List Digest Archive > ======================== ======================= > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Thu 03/14/19: 2 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 08:24 AM - Re: Kolb-List Digest: 1 Msgs - 03/13/19 (Richard > Swiderski) > 2. 06:48 PM - Re: Re: Kolb-List Digest: 1 Msgs - 03/13/19 (chris > davis) > > > ________________________________ Message 1 > _____________________________________ > > > From: Richard Swiderski <i2bxtn(at)gmail.com> > Subject: Kolb-List: Re: Kolb-List Digest: 1 Msgs - 03/13/19 > > Thank you for the offer. As my FireStar KXP plans are no longer availabl e, > I for one would be interested in your offer. -Richard Swiderski > > On Thu, Mar 14, 2019 at 2:40 AM Kolb-List Digest Server < > kolb-list(at)matronics.com> wrote: > > > * > > > > ======================= > > Online Versions of Today's List Digest Archive > > ======================= > > > > Today's complete Kolb-List Digest can also be found in either of the > > two Web Links listed below. The .html file includes the Digest formatt ed > > in HTML for viewing with a web browser and features Hyperlinked Indexes > > and Message Navigation. The .txt file includes the plain ASCII version > > of the Kolb-List Digest and can be viewed with a generic text editor > > such as Notepad or with a web browser. > > > > HTML Version: > > > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html& Chapter > 19-03-13&Archive=Kolb > > > > Text Version: > > > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&C hapter > 19-03-13&Archive=Kolb > > > > > > ======================= ======================= > > EMail Version of Today's List Digest Archive > > ======================= ======================= > > > > > > ---------------------------------------------------------- > > Kolb-List Digest Archive > > --- > > Total Messages Posted Wed 03/13/19: 1 > > ---------------------------------------------------------- > > > > > > Today's Message Index: > > ---------------------- > > > > 1. 03:29 PM - Re: Need parts list/plan prints for Firestar (west1 m) > > > > > > ________________________________ Message 1 > > _____________________________________ > > > > > > Subject: Kolb-List: Re: Need parts list/plan prints for Firestar > > From: "west1m" <west1m(at)hotmail.com> > > > > > > I made a copy of the 1989 Firefly manual today. I had trouble getting t he > > link > > to work, I try to make it work better when I can but if you feel like > > trying here > > is a link. > > www.west1m.com/flyin/FireflyManual.zip > > I have some Firestar prints also I will try to do the same with those i f > > anyone > > thinks these were worth the effort. > > > > -------- > > West1m > > Hastings, MN > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=488055#488055 > > > > > > -- > *Click on to Richard's Blog: <http://GodStuffRichard.blogspot.com> > <http://GodStuffRichard.blogspot.com> * > *Thoughts On God And Life <http://godstuffrichard.blogspot.com> > -**Prose, **Prayers, > Poems & Ponderings * > > ________________________________ Message 2 > _____________________________________ > > > Subject: Re: Kolb-List: Re: Kolb-List Digest: 1 Msgs - 03/13/19 > From: chris davis <capedavis(at)yahoo.com> > > Richard if you want me to send the KXP builders manual why don=99t you > give me your address and I will mail it ?This discussion has been going > on f > or days yet I haven=99t seen an address . It=99s simple address , > manual done deal . Chris > > Sent from my iPhone > > > On Mar 14, 2019, at 11:22 AM, Richard Swiderski > wrote: > > > > Thank you for the offer. As my FireStar KXP plans are no longer > available > , I for one would be interested in your offer. -Richard Swiderski > > > >> On Thu, Mar 14, 2019 at 2:40 AM Kolb-List Digest Server > ics.com> wrote: > >> * > >> > >> ======================= > > >> Online Versions of Today's List Digest Archive > >> ======================= > > >> > >> Today's complete Kolb-List Digest can also be found in either of the > >> two Web Links listed below. The .html file includes the Digest > formatted > > >> in HTML for viewing with a web browser and features Hyperlinked Indexe s > > >> and Message Navigation. The .txt file includes the plain ASCII versio n > > >> of the Kolb-List Digest and can be viewed with a generic text editor > >> such as Notepad or with a web browser. > >> > >> HTML Version: > >> > >> http://www.matronics.com/digest/digestview.php?Style=82701&View =h > tml&Chapter > <http://www.matronics.com/digest/digestview.php?Style=82701&View=html &Chapter> > 19-03-13&Archive=Kolb > >> > >> Text Version: > >> > >> http://www.matronics.com/digest/digestview.php?Style=82701&View =t > xt&Chapter > <http://www.matronics.com/digest/digestview.php?Style=82701&View=txt& Chapter> > 19-03-13&Archive=Kolb > >> > >> > >> ===================== > >> EMail Version of Today's List Digest Archive > >> ===================== > >> > >> > >> ---------------------------------------------------------- > >> Kolb-List Digest Archive > >> --- > >> Total Messages Posted Wed 03/13/19: 1 > >> ---------------------------------------------------------- > >> > >> > >> Today's Message Index: > >> ---------------------- > >> > >> 1. 03:29 PM - Re: Need parts list/plan prints for Firestar > (west1m) > > >> > >> > >> > >> ________________________________ Message 1 > ____________________________ > _________ > >> > >> > >> Subject: Kolb-List: Re: Need parts list/plan prints for Firestar > >> From: "west1m" <west1m(at)hotmail.com> > >> > >> > >> I made a copy of the 1989 Firefly manual today. I had trouble getting > the > link > >> to work, I try to make it work better when I can but if you feel like > try > ing here > >> is a link. > >> www.west1m.com/flyin/FireflyManual.zip > >> I have some Firestar prints also I will try to do the same with those > if a > nyone > >> thinks these were worth the effort. > >> > >> -------- > >> West1m > >> Hastings, MN > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=488055#488055 > >> > >> > >> > >> > >> ========= > >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/N avi > gator?Kolb-List <http://www.matronics.com/Navigator?Kolb-List> > >> ========= > >> FORUMS - > >> eferrer" target="_blank">http://forums.matronics.com > >> ========= > >> WIKI - > >> errer" target="_blank">http://wiki.matronics.com > >> ========= > >> b Site - > >> -Matt Dralle, List Admin. > >> rel="noreferrer" target="_blank">http://www.matronics.com/contribu tio > n > >> ========= > >> > >> > >> > >> > > > > > > -- > > Click on to Richard's Blog: > > Thoughts On God And Life -Prose, Prayers, Poems & Ponderings > > > > =========== =========== =========== =========== =========== > > -- *Click on to Richard's Blog: <http://GodStuffRichard.blogspot.com> <http://GodStuffRichard.blogspot.com> * *Thoughts On God And Life <http://godstuffrichard.blogspot.com> -**Prose, **Prayers, Poems & Ponderings * ________________________________________________________________________________
Date: Mar 17, 2019
West1m, Thanks for the manual, although its a firefly, it has some good info. Pages 16 and 18 are too blurry to read(camera shake?), but the rest can be zoomed in and easily readable. I am sure it will help many. Thanks again, Steve -------- Kolb Firestar new to me Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488116#488116 ________________________________________________________________________________
Date: Mar 17, 2019
Subject: flight to Rome,Or
https://vimeo.com/324836152 password- owyheeflyer Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: flight to Rome,Or
Date: Mar 19, 2019
Great flight looks like it was a bit bumpy here and there. The rocky cliffs look great, much different than farm fields. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488160#488160 ________________________________________________________________________________
Subject: Hangar winch
Date: Mar 21, 2019
My hangar is on a somewhat sloped hill, I take off down hill, land up hill, and drag the airplane up the side slope of the hill to get it back into the hangar. The older I get, the less I enjoy dragging the airplane back uphill into the hangar. Today I had a happy time - attached a winch that drags the airplane back into the hangar for me! When Harbor Freight puts this little winch on sale it is $50. Not too bad, and then my son works in a garage, and was able to gift me a used battery that still works good enough to drive the winch. So here's what I ended up with: replace the original steel winch cable with paracord. Cheap, #500 working load, and a lot easier to live with than metal cable. Bolt the rig to something sturdy, get your self a pulley, and you are good to go! The winch has a remote control fob, which makes it easy to move around in the hangar and align the tailwheel to the ramp, check the rope winding up on the spool, etc. It is not very fast, but that is not a bad thing; gives you time to make sure nothing is going to go where you don't want it. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal (Ready for a test flight on the new 277) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488179#488179 Attachments: http://forums.matronics.com//files/p1070156_medium_834.jpeg http://forums.matronics.com//files/p1070155_medium_127.jpeg ________________________________________________________________________________
Subject: Re: Hangar winch
Date: Mar 21, 2019
On 3/21/2019 5:40 PM, Richard Pike wrote: > > My hangar is on a somewhat sloped hill, I take off down hill, land up hill, and drag the airplane up the side slope of the hill to get it back into the hangar. The older I get, the less I enjoy dragging the airplane back uphill into the hangar. > Today I had a happy time - attached a winch that drags the airplane back into the hangar for me! > When Harbor Freight puts this little winch on sale it is $50. Not too bad, and then my son works in a garage, and was able to gift me a used battery that still works good enough to drive the winch. > So here's what I ended up with: replace the original steel winch cable with paracord. Cheap, #500 working load, and a lot easier to live with than metal cable. > Bolt the rig to something sturdy, get your self a pulley, and you are good to go! > The winch has a remote control fob, which makes it easy to move around in the hangar and align the tailwheel to the ramp, check the rope winding up on the spool, etc. It is not very fast, but that is not a bad thing; gives you time to make sure nothing is going to go where you don't want it. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kolb Firefly Part 103 legal (Ready for a test flight on the new 277) > Kingsport, TN 3TN0 > > Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. > Looks good, but 500 lbs would worry me a bit, if I had to stand in the possible arc of a snapped line. "Be careful out there." --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Mar 23, 2019
Nice, inexpensive solution to a problem. Very clever! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488206#488206 ________________________________________________________________________________
Subject: Re: My Firestar 2 Build
Date: Mar 23, 2019
I haven't posted for a while, when the weather is below 0 or even 20 the hanger is just to dang cold to work in. The engine is moving on. I had to order starter o rings thanks to the oil injection leaking over the starter and taking out the o rings. I still need to rebuild the carbs and install the starter. I went with the Challenger muffler mount. Here are a couple of pics. (http://s275.photobucket.com/user/dngspot/media/front_zpszgldaco0.jpg.html) (http://s275.photobucket.com/user/dngspot/media/under%20muffler_zpsbvqdnbad.jpg.html) (http://s275.photobucket.com/user/dngspot/media/carb%20side_zpsi0rbjqmw.jpg.html) Forgive the messy shop. I spent the day working on the landing gear legs. The right tube was a bit small about half way in. I ordered a reamer and took care of that. (http://s275.photobucket.com/user/dngspot/media/landing%20gear%20leggs_zps3rawpdhy.jpg.html) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488208#488208 ________________________________________________________________________________
Date: Mar 23, 2019
Question- Is there much chance of the muffler mount cracking? Stainless? Bill Sullivan -------------------------------------------- On Sat, 3/23/19, loctupdave wrote: I haven't posted for a while, when the weather is below 0 or even 20 the hanger is just to dang cold to work in. The engine is moving on. I had to order starter o rings thanks to the oil injection leaking over the starter and taking out the o rings. I still need to rebuild the carbs and install the starter. I went with the Challenger muffler mount. Here are a couple of pics. (http://s275.photobucket.com/user/dngspot/media/front_zpszgldaco0.jpg.html) ________________________________________________________________________________
Date: Mar 23, 2019
Yeah, stainless can crack just like anything else. Id just keep my eye on it. Itll crack before It breaks. George H Firestar 14GDH Mesick, Michigan gdhelton(at)gmail.com Sent from my iPhone > On Mar 23, 2019, at 4:29 PM, william sullivan wrote: > > > Question- Is there much chance of the muffler mount cracking? Stainless? > > Bill Sullivan > -------------------------------------------- > On Sat, 3/23/19, loctupdave wrote: > > > > I haven't posted for a while, when the > weather is below 0 or even 20 the hanger is just to dang > cold to work in. > The engine is moving on. I had to order > starter o rings thanks to the oil injection leaking over the > starter and taking out the o rings. I still need to rebuild > the carbs and install the starter. I went with the > Challenger muffler mount. Here are a couple of pics. > > (http://s275.photobucket.com/user/dngspot/media/front_zpszgldaco0.jpg.html) > > > > > > > > > ________________________________________________________________________________
Date: Mar 24, 2019
Thank you for the attention. I will keep an eye on the bracket. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488217#488217 ________________________________________________________________________________
Date: Mar 24, 2019
Interesting talk about muffler brackets. This is what happened to me yesterday on a short flight to Amery airport. I was already in my seat when the the guy I was chatting with asked what was wrong with my muffler. It was kind of angled a bit funny.He then helped me wire it together so it wouldn't fall off and scratch up my prop.. -------- West1m Hastings, MN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488235#488235 Attachments: http://forums.matronics.com//files/broken_muffler_176.jpg ________________________________________________________________________________
Date: Mar 24, 2019
My shop only looks that good if I just finished cleaning for about four hours !Nice looking work Sent from my iPhone > On Mar 23, 2019, at 4:29 PM, william sullivan wrote: > > > Question- Is there much chance of the muffler mount cracking? Stainless? > > Bill Sullivan > -------------------------------------------- > On Sat, 3/23/19, loctupdave wrote: > > > > I haven't posted for a while, when the > weather is below 0 or even 20 the hanger is just to dang > cold to work in. > The engine is moving on. I had to order > starter o rings thanks to the oil injection leaking over the > starter and taking out the o rings. I still need to rebuild > the carbs and install the starter. I went with the > Challenger muffler mount. Here are a couple of pics. > > (http://s275.photobucket.com/user/dngspot/media/front_zpszgldaco0.jpg.html) > > > > > > > > > ________________________________________________________________________________
Date: Mar 25, 2019
zeprep251(at)aol.com wrote: > I dont recommend isolating the exhaust system from the engine. I think it should be one with the engine,as tight and secure as you can make it. > Unless your secondary goal is to get rid of vibration. Then you isolate it from the engine, keep it tight at the connections, and flexible at the mounts. Then (IMO) you have the best solution: reliability and less vibration. The original muffler mounting on the 277 on the Firefly was set up to be tight, and it shook worse than you could imagine. We assumed it was because it was a single. Wrong. it was because the muffler was too tight. A single cylinder engine waving that muffler back and forth 5,000 times a minute was a disaster waiting to happen. And it very nearly did: during the 45 minute ferry flight from the test field to David's hangar it broke 3 out of 4 new muffler hangars. The first picture shows that setup with the original curlyque muffler. The current setup is in the later pictures, there is no stress on the muffler hangars and vibration is about 90% less, and at 5500 rpm (the sweet spot for this engine) there is literally no vibration now. The goal was to let the engine move without it also moving the muffler - or at least moving it as little as possible. So far it seems like a good plan. Addendum: test flew the Firefly Saturday with the fan cooled 277, (the pictures show the original engine) first flight since the blackberry patch adventure last year, and it flew as nice as ever, engine ran good, but wouldn't idle right. Will be swapping the carb out today for a new one that we just happened to have. When you have a partner who has had even more U/L type airplanes over the last 30 years than you have, there seems to be no lack of spare parts... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal (Ready for a test flight on the new 277) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488251#488251 Attachments: http://forums.matronics.com//files/p1060084_medium_210.jpeg http://forums.matronics.com//files/p1060450_medium_158.jpg http://forums.matronics.com//files/p1060451_medium_132.jpg ________________________________________________________________________________
Date: Mar 25, 2019
I use rubber hanger straps, scrounged from my local muffler shop, look like they are made from conveyor belt material, for vibration isolation for other applications, but would probably work well for an exhaust hanger. I remember many years ago when I discovered the problem of over soft Lord Mounts on my FS/447. Thrust and torque was causing the engine to get way out of line. While down at Brother Jim's in Tallahassee, Florida, one flight, I got the bright idea of using shock absorber donuts to make up some engine mounts. Jim zipped them up with the TIG welder and I flew back to Titus, Alabama. Before I got home the entire exhaust system was disintegrating from vibration. Reckon the airframe would have been next had I had a longer flight. Vibration is some bad stuff. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Monday, March 25, 2019 7:58 AM Subject: Kolb-List: Re: My Firestar 2 Build zeprep251(at)aol.com wrote: > I dont recommend isolating the exhaust system from the engine. I think it should be one with the engine,as tight and secure as you can make it. > Unless your secondary goal is to get rid of vibration. Then you isolate it from the engine, keep it tight at the connections, and flexible at the mounts. Then (IMO) you have the best solution: reliability and less vibration. The original muffler mounting on the 277 on the Firefly was set up to be tight, and it shook worse than you could imagine. We assumed it was because it was a single. Wrong. it was because the muffler was too tight. A single cylinder engine waving that muffler back and forth 5,000 times a minute was a disaster waiting to happen. And it very nearly did: during the 45 minute ferry flight from the test field to David's hangar it broke 3 out of 4 new muffler hangars. The first picture shows that setup with the original curlyque muffler. The current setup is in the later pictures, there is no stress on the muffler hangars and vibration is about 90% less, and at 5500 rpm (the sweet spot for this engine) there is literally no vibration now. The goal was to let the engine move without it also moving the muffler - or at least moving it as little as possible. So far it seems like a good plan. Addendum: test flew the Firefly Saturday with the fan cooled 277, (the pictures show the original engine) first flight since the blackberry patch adventure last year, and it flew as nice as ever, engine ran good, but wouldn't idle right. Will be swapping the carb out today for a new one that we just happened to have. When you have a partner who has had even more U/L type airplanes over the last 30 years than you have, there seems to be no lack of spare parts... -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal (Ready for a test flight on the new 277) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488251#488251 Attachments: http://forums.matronics.com//files/p1060084_medium_210.jpeg http://forums.matronics.com//files/p1060450_medium_158.jpg http://forums.matronics.com//files/p1060451_medium_132.jpg ________________________________________________________________________________
Subject: 582 ignition parts for sale
Date: Mar 30, 2019
This winter I replaced the ignition coils and coil triggers in my 582. Because this engine is at least 20 years old, it just seemed like a good idea, even though what I had was working OK. HOWEVER - some of you are aware that there has been a problem with the Rotax coils where the wires got gummy, and the insulation sort of went all wonky, deteriorating. That was my situation, so I cut out some of the original wires and soldered in new ones, and then potted the new wires in silicone. Have had zero problems since. Five years with no problems. But I found a good deal on some brand new coils, and I replaced the wonky ones. So now I am selling the old ignition coils and trigger coils, because that seemed better than just throwing them in the trash. I have two ignition coils, part # 966-462, and two trigger coils part # 961-761, and 961-769. $35 for all, that includes shipping, maybe someone would like to have them for test purposes. PM me. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal (Ready for a test flight on the new 277) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488369#488369 Attachments: http://forums.matronics.com//files/p1070161_large_106.jpeg ________________________________________________________________________________
Subject: anyone have a spare pointy nose cone
Date: Apr 01, 2019
Greetings, I'm looking for a new nose cone for the current SlingShot project. I've seen pictures with both the older round nose, and the newer pointy nose, so I'm assuming they're interchangeable. I've asked Kolb about it, but since it's SNF week, I don't really expect to hear from them until sometime next week. In the mean time, I thought I'd ask if anyone knows for sure that the two types are interchangeable, and also if anyone happens to have a new nose cone they don't need. Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488404#488404 ________________________________________________________________________________
Date: Apr 01, 2019
Subject: Re: anyone have a spare pointy nose cone
What is the cost now?? last I knew and with a bad memory...450 bucks?? That was 8 years ago...memory again?? Same as used on a Firefly? I bought a damaged one from Travis back many years ago for 75 bucks. The instrument panel was de laminated which suited be for I wanted to be able to detach it to access the rear. Herb Sent with ProtonMail Secure Email. Original Message On Monday, April 1, 2019 11:18 AM, 13brv3 <13brv3(at)gmail.com> wrote: > > Greetings, > > I'm looking for a new nose cone for the current SlingShot project. I've seen pictures with both the older round nose, and the newer pointy nose, so I'm assuming they're interchangeable. I've asked Kolb about it, but since it's SNF week, I don't really expect to hear from them until sometime next week. > > In the mean time, I thought I'd ask if anyone knows for sure that the two types are interchangeable, and also if anyone happens to have a new nose cone they don't need. > > Thanks, > Rusty > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=488404#488404 > ________________________________________________________________________________
Date: Apr 01, 2019
Pfatchantz(at)protonmail. wrote: > What is the cost now?? last I knew and with a bad memory...450 bucks?? That was 8 years ago...memory again?? Same as used on a Firefly? Cost is one of the questions I asked, but I don't expect a reply anytime soon due to SNF. I fear it will be high enough that I'll be compelled to fix the one I have, and I really despise fiberglass work. I wonder if I can make an all aluminum nose :-) Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488412#488412 ________________________________________________________________________________
Date: Apr 01, 2019
My (actually, our) friend in FL who used to make rotary bits & pieces has an original Twinstar with an aluminum tube/fabric covered nose. Probably about 1/4 the weight of the F-glass nose on mine (the one I bought from him). Just a thought... On Mon, Apr 1, 2019 at 4:03 PM 13brv3 <13brv3(at)gmail.com> wrote: > > > Pfatchantz(at)protonmail. wrote: > > What is the cost now?? last I knew and with a bad memory...450 bucks?? > That was 8 years ago...memory again?? Same as used on a Firefly? > > > Cost is one of the questions I asked, but I don't expect a reply anytime > soon due to SNF. I fear it will be high enough that I'll be compelled to > fix the one I have, and I really despise fiberglass work. I wonder if I > can make an all aluminum nose :-) > > Rusty > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=488412#488412 > > ________________________________________________________________________________
Date: Apr 02, 2019
From: william sullivan <williamtsullivan(at)att.net>
Consider bringing it to a local auto body repair shop. They all do fiberglass work. I fixed my own, and modified the lower flange for a compass. It was smelly, but worked just fine. Bill Sullivan -------------------------------------------- On Mon, 4/1/19, 13brv3 <13brv3(at)gmail.com> wrote: Subject: Kolb-List: Re: anyone have a spare pointy nose cone Cost is one of the questions I asked, but I don't expect a reply anytime soon due to SNF. I fear it will be high enough that I'll be compelled to fix the one I have, and I really despise fiberglass work. I wonder if I can make an all aluminum nose :-) Rusty ________________________________________________________________________________
Date: Apr 01, 2019
Thanks for the comments. I'm happy to report that the nose cone I have isn't nearly as bad as it initially looked. There are plenty of extra holes to fill up, but there's really only one side with a significant deformity. Even new cones need some work to fit, so it may not be that much more work. I'll still wait to hear what Kolb says about a new one, but most likely the cost will push me toward just fixing this one. Cheers, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488431#488431 ________________________________________________________________________________
Date: Apr 01, 2019
Your best bet is to fix the old one, and save up your money to buy a new one when you screw the old one up. Ask me how I obtained this brilliant piece of knowledge. Larry On Mon, Apr 1, 2019 at 6:37 PM 13brv3 <13brv3(at)gmail.com> wrote: > > Thanks for the comments. I'm happy to report that the nose cone I have > isn't nearly as bad as it initially looked. There are plenty of extra > holes to fill up, but there's really only one side with a significant > deformity. Even new cones need some work to fit, so it may not be that > much more work. I'll still wait to hear what Kolb says about a new one, > but most likely the cost will push me toward just fixing this one. > > Cheers, > Rusty > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=488431#488431 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Apr 01, 2019
lcottrell wrote: > Your best bet is to fix the old one, and save up your money to buy a new one when you screw the old one up. Ask me how I obtained this brilliant piece of knowledge. > Larry > LOL! Screwing one up certainly makes the price of a new one look better. Of course fiberglass will give you the opportunity to screw it up multiple times... Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488435#488435 ________________________________________________________________________________
Date: Apr 02, 2019
Hello Rusty, My present FS has a longer (about 10") nose cone which tappers down to a very slender front nose, but it is not pointed, it is flattened. It completely changes the FS from its gawky blunt nose to a sleek, streamlined plane. In my opinion, it is much more attractive than Kolb's longer version. I absolutely love the look, but I designed my trailer around the short stubby nose, so in short, it makes my FS much harder to load as I now have to go up and over the original wheel well. With great pain to my vanity, I am planning in the near future to replace it with an old stubby nose that I acquired years ago. At my point in life, function trumps beauty, so my thoughts were to sell it for half the price of Kolb's longer nose cone. One of my FS's previous owners still has the mold. If I ever track him down, it would be a great asset to be made available to the Kolb community. It truly is a work of art. -Richard Swiderski Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488455#488455 Attachments: http://forums.matronics.com//files/p1050898_200.jpg ________________________________________________________________________________
Date: Apr 02, 2019
Hi Richard, I think you're FS has been telling lies :-) It's a neat look, but I'm trying to keep the overall length as short as possible for easier trailering and storage. My garage is just barely long enough for the stock nose. Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488469#488469 ________________________________________________________________________________
Date: Apr 05, 2019
Subject: Bryan Melborn Has a New Toy
I sold my electric unicycle to Bryan Melborn today at Sun-N-Fun. If you see him get him to sell a few Kolb airplanes in between riding around the airport. Better yet buy a Kolb yourself. We were stirring up the traffic Nazis. When I pushed the unicycle through the gate, I was told that they didn't allow bicycles it isn't it is a unicycle, then those things aren't allowed inside the inner gate that I was riding out of to go to paradise city. Bryan got real bold and rode it down to the main runway area. During all this bicycles, electric and gas scooters, motorcycles, cars, trucks etc. were zipping around unencumbered everywhere. Anyway hot some rain, airplanes etc. Good show. No John H this year. Rick Neilsen Redrive VW Powered MKIIIC ________________________________________________________________________________
Date: Apr 06, 2019
Subject: Re: Bryan Melborn Has a New Toy
I didn't get any photos of Bryan riding the unicycle and I can't find a video of me driving the unicycle but I did find a youtube video of the unicycle. See the following. https://www.youtube.com/watch?v=L64O9NTx2yE Sorry not Kolb related Rick Neilsen Redrive VW Powered MKIIIC On Fri, Apr 5, 2019 at 6:50 PM Rick Neilsen wrote: > I sold my electric unicycle to Bryan Melborn today at Sun-N-Fun. If you > see him get him to sell a few Kolb airplanes in between riding around the > airport. Better yet buy a Kolb yourself. > > We were stirring up the traffic Nazis. When I pushed the unicycle through > the gate, I was told that they didn't allow bicycles it isn't it is a > unicycle, then those things aren't allowed inside the inner gate that I was > riding out of to go to paradise city. Bryan got real bold and rode it down > to the main runway area. During all this bicycles, electric and gas > scooters, motorcycles, cars, trucks etc. were zipping around unencumbered > everywhere. > > Anyway hot some rain, airplanes etc. Good show. No John H this year. > > Rick Neilsen > Redrive VW Powered MKIIIC > > ________________________________________________________________________________
Date: Apr 08, 2019
bryan and myself (owner of firefly al force one) both cracked a rib on that thing lmao at the sun and fun my grandson did vid my fall=C2- im sure it will be out there soon lol -----Original Message----- From: Rick Neilsen <neilsenrm(at)gmail.com> Sent: Sat, Apr 6, 2019 11:41 am Subject: Kolb-List: Re: Bryan Melborn Has a New Toy I didn't get any photos of Bryan riding the unicycle and I can't find a vid eo of me driving the unicycle but I did find a youtube video of the unicycl e. See the following.=C2-=C2-https://www.youtube.com/watch?v=L64O9NTx 2yE Sorry not Kolb related Rick NeilsenRedrive VW Powered MKIIIC On Fri, Apr 5, 2019 at 6:50 PM Rick Neilsen wrote: I sold my electric unicycle to Bryan Melborn today at Sun-N-Fun. If you see him get him to sell a few Kolb airplanes in between riding around the airp ort. Better yet buy a Kolb yourself. We were stirring up the traffic Nazis. When I pushed the unicycle through t he gate, I was told that they didn't allow bicycles it isn't it is a unicyc le, then those things aren't allowed inside the inner gate that I was ridin g out of to go to paradise city. Bryan got real bold and rode it down to th e main runway area. During all this bicycles, electric and gas scooters, mo torcycles, cars, trucks etc. were zipping around unencumbered everywhere. =C2- Anyway hot some rain, airplanes etc. Good show. No John H this year. Rick NeilsenRedrive VW Powered MKIIIC ________________________________________________________________________________
Subject: 277 keeps falling off the pipe
Date: Apr 09, 2019
Situation: the Firefly now has a different Rotax 277 on it, 2.58:1 reduction and a 62" two blade Ivoprop. Engine runs great, all the numbers are good, but it won't stay stable on the pipe. It will run stabily at 5700 or above, but as soon as you retard the throttle even a little, it slowly reduces the rpm's to 4700 and then stabilizes. Give it a hair of throttle and it begins to slowly increase rpm and stabilizes again back at at 5700. Years ago I had a Rotax 532 on my MKIII that would do the same thing because it was overpropped with a three blade 64" Ivo. Removed one of the blades and it would then stabilize pretty well at most any rpm. So the question is this - anyone else have a similar experience with a 2-stroke engine that kept falling off/climbing back up the pipe, and if so, did you cure it by reducing the prop length/prop load? I would like some confirmation/reassurance/feedback before I start shortening the prop. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal (Ready for a test flight on the new 277) Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488650#488650 ________________________________________________________________________________
Subject: Re: 277 keeps falling off the pipe
Date: Apr 10, 2019
Richard, Is the exhaust a stock 277 exhaust pipe? If not, an improper taper in the tuned section could be the cause. Also, adjusting the midrange/full power jetting in your carb might help. I would theorize that an overly rich mixture in the problematic throttle range could produce those symptoms, but you say the egt numbers are good so that doesn't seem likely. -Richard Swiderski Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488658#488658 ________________________________________________________________________________
Subject: Kolb Plans Correction
Date: Apr 10, 2019
Kolbers, A few weeks back, I said I spoke with Kolb about the getting the plans and builders manual and was told they do not have any for the FS KXP. Well I spent some time talking with Bryan Melborn at Sun & Fun, and he said they have plans and manuals for all the models. -Richard Swiderski Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488659#488659 ________________________________________________________________________________
Date: Apr 10, 2019
slingshot003 wrote: > Richard, > > Is the exhaust a stock 277 exhaust pipe? If not, an improper taper in the tuned section could be the cause. -Richard Swiderski Well, yes and no, I am starting to think no. The original pipe was a curlyque like the one in the bottom left of the attachment, but we wanted to try something to reduce the engine vibration, and I found a supplier of tapered cones for people who are fabricating their own exhausts and headers. Short version; got a cone that was exactly the right taper and diameter at both the top and bottom when cut to the length as referenced according to the top center pipe in the catalog. At 16 3/4" long, the top diameter where it welds to the can is the same as the diameter of the opening in the can. The diameter at the bottom (small end) is the same as the diameter of the 879-190 female joint connection. Consequently I would have bet money that the straight section would be identical to a stock Rotax pipe with that configuration, but I am starting to think it is not. Flew it twice last night, took a bit of pitch out of the prop each time, trying to compensate for it maybe being overpropped; this chart shows the correct prop diameter and pitch for a 277: http://www.ultralightnews.ca/articles/rotaxproprecommendation.htm Since we are running a 62" two blade IVO, it seemed possible we are overpropped, However I flew it twice more today each time taking out pitch, to the point that you can't even give it full throttle or it will overspeed, and that was not helpful, so I think I will assume it is not overpropped. I think I weld the original curleyque pipe back on and see if it runs properly. If that issue gets fixed, then I'll worry about the vibration. Or sell it and get a different engine. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488665#488665 Attachments: http://forums.matronics.com//files/img450_medium_173.jpg ________________________________________________________________________________
Subject: Richard's rpm seaking engine
Date: Apr 18, 2019
Richard, Your problem may be caused by oscillation of the slide and spring in the body of the carburetor. Bosch makes several different springs. Try a heavier or stronger spring. I had the same trouble with my 447 and a stronger spring cured it. Jack B. Hart, FireFly 004 Winchester, Indiana ---------------------------------------- ________________________________________________________________________________
Date: Apr 18, 2019
Date: Apr 18, 2019
I once removed the exhaust system from a Rotax 447, sent it out for refinis hing of the exterior.=C2- It was sand blasted and plated with a ceramic p roduct.=C2- When it was returned to me, I could hear what sounded like pi eces of sand inside the muffler if it was turned over or shaken.=C2- Trie d blowing and vacuuming it out to no avail.=C2- Assembled it onto the 447 and went flying.=C2- I had not changed anything other than the exhaust r efinishing.=C2- However, the 447 acted pretty much just like what you des cribed.=C2- It would not hold a steady RPM.=C2- I thought incorrectly t hat the sand pieces were maybe to blame.=C2- Although the plane had set f or several weeks, I assumed the tuning of the carb should still be OK.=C2 - BUT, because I didn't really know what else to do, I changed the needle position.=C2- I can't recall which way it was moved (up or down) but the next flight resulted in a proper running engine that would hold the RPM se lected.=C2- Maybe the temperature had changed requiring the needle to be re-positioned.=C2- All of this was years ago, I got older and can't recal l all the details. Bill VarnesFireStar 447 RotaxAudubon NJ In a message dated 4/9/2019 9:39:38 PM Eastern Standard Time, thegreybaron@ charter.net writes: So the question is this - anyone else have a similar experience with a 2-st roke engine that kept falling off/climbing back up the pipe, and if so, did you cure it by reducing the prop length/prop load? I would like some confi rmation/reassurance/feedback before I start shortening the prop. ________________________________________________________________________________
Subject: Wanted - Kolb Firestar II Prefer 503
Date: Apr 21, 2019
I am looking to buy a nice Kolb Firestar II. I would prefer a Rotax 503 and the second seat option. I can be reach through this forum or my email shaypet(at)gmail.com. Raleigh, NC Peter PS willing to travel for the right one. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488841#488841 ________________________________________________________________________________
Date: Apr 21, 2019
Subject: Re: Wanted - Kolb Firestar II Prefer 503
Peter Not a bad trip..I am in Allen Co.,Ky....542 miles...looks to be an overn ite trip. Leave early...4 am or so...load by 3 pm and head home...overnite in Knoxville or there bouts.. any how...This is a 2004 Firestar II..Engine has 450 hours..electric sta rt 503 DCDI. Shows some wear and tear..but now bad for the age...Register ed EAB. Three blade Power Fin...EIS box..full instruments...ELT locator. s trobes...10 gals.. For 12k, I am tossing in a low time engine, Expired BRS . Herb Sent with ProtonMail Secure Email. =90=90=90=90=90=90=90 Original Me ssage =90=90=90=90=90=90=90 On Sunday, April 21, 2019 8:39 AM, shaypete wrote: > > I am looking to buy a nice Kolb Firestar II. I would prefer a Rotax 503 a nd the second seat option. I can be reach through this forum or my emailsha ypet(at)gmail.com. > > Raleigh, NC > > Peter > PS willing to travel for the right one. > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=488841#488841 > =========== =========== =========== =========== =========== ________________________________________________________________________________
Date: Apr 22, 2019
I think we are back on track, new muffler installation, flew it six times this evening, the vibration is gone. So we are half way home. Also came to the conclusion that the prop is too long and the engine is too loaded down. As long as you keep the Firefly in a shallow descent, the engine does not hunt at all, it stays at a constant throttle setting. Raise the nose and load up the prop and it falls off the pipe. So now we need to learn what is a good length of prop for a 277 with a 2.58:1 gearbox. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488874#488874 Attachments: http://forums.matronics.com//files/p1070187_medium_179.jpeg http://forums.matronics.com//files/p1070186_medium_154.jpeg http://forums.matronics.com//files/p1070181_medium_957.jpeg ________________________________________________________________________________
Date: Apr 22, 2019
Richard, I've lost the part of this thread where you said what the 277 is propped at now. Can you measure the pitch? I've got a couple of props around here I can loan you if we can get close. Rick On Mon, Apr 22, 2019 at 8:29 PM Richard Pike wrote: > > > I think we are back on track, new muffler installation, flew it six times > this evening, the vibration is gone. So we are half way home. Also came t o > the conclusion that the prop is too long and the engine is too loaded dow n. > As long as you keep the Firefly in a shallow descent, the engine does not > hunt at all, it stays at a constant throttle setting. Raise the nose and > load up the prop and it falls off the pipe. > So now we need to learn what is a good length of prop for a 277 with a > 2.58:1 gearbox. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kolb Firefly Part 103 legal > Kingsport, TN 3TN0 > > Forgiving is tough, being forgiven is wonderful, and God's grace really i s > amazing. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=488874#488874 > > > Attachments: > > http://forums.matronics.com//files/p1070187_medium_179.jpeg > http://forums.matronics.com//files/p1070186_medium_154.jpeg > http://forums.matronics.com//files/p1070181_medium_957.jpeg > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Apr 22, 2019
Richard Good luck with prop selection it's a pain Sorry to change the subject but I see a white strip on the back of the Kolb part of the motor mount. What is it. Rick Neilsen Redrive VW Powered MKIIIC On Mon, Apr 22, 2019 at 9:29 PM Richard Pike wrote: > > I think we are back on track, new muffler installation, flew it six times > this evening, the vibration is gone. So we are half way home. Also came to > the conclusion that the prop is too long and the engine is too loaded down. > As long as you keep the Firefly in a shallow descent, the engine does not > hunt at all, it stays at a constant throttle setting. Raise the nose and > load up the prop and it falls off the pipe. > So now we need to learn what is a good length of prop for a 277 with a > 2.58:1 gearbox. > > -------- > Richard Pike > Kolb MKIII N420P (420ldPoops) > Kolb Firefly Part 103 legal > Kingsport, TN 3TN0 > > Forgiving is tough, being forgiven is wonderful, and God's grace really is > amazing. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=488874#488874 > > > Attachments: > > http://forums.matronics.com//files/p1070187_medium_179.jpeg > http://forums.matronics.com//files/p1070186_medium_154.jpeg > http://forums.matronics.com//files/p1070181_medium_957.jpeg > > ________________________________________________________________________________
Date: Apr 23, 2019
rickofudall wrote: > Richard, I've lost the part of this thread where you said what the 277 is propped at now. Can you measure the pitch? I've got a couple of props around here I can loan you if we can get close. > > Rick That is very generous, thank you. We are using an Ivoprop and the problem is the length. We have tried taking the pitch out and that helps, but in order to make the engine behave, we have to way under pitch it. So we are going to shorten it down as soon as we figure out what length it needs to be. And to Rick Neilsen: just as an experiment, we got several super bright LED strips and hooked them up to a cheap sequence flasher to see how they worked as strobes. https://www.ebay.com/itm/2Pcs-17CM-Universal-COB-LED-Strip-Car-Daytime-Running-Fog-Lamp-DRL-Driving-Strip/223078189539?hash=item33f07f09e3:m:mj_Z4BzKmmoMH7vefuvwlew You can see them from a couple miles away when it is almost dark, but they are no way as bright as one of Dick Kuntzelman's units. They main thing they have going for them is they were cheap and it was an interesting way to spend an afternoon. OTOH, if there is anyone overtaking me on final, they'll for sure see it! -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488896#488896 ________________________________________________________________________________
Subject: Tires, wheels and brakes?
Date: Apr 23, 2019
Greetings, I'm working on an old Slingshot, and it currently has Van-K 6"x4" aluminum wheels, and MCP hydraulic brakes. These seem like quality items, and I have no problem with either, other than the fact that I'd prefer split hub wheels to these one piece wheels. The problem is the tires. They're ancient, and really low quality Duro tires that appear to be for mowers? The size is 15 6.00-6. The wheels don't allow the use of tubes, and aircraft tires in this size are rarely tubeless. I think there are a few, but they're over $300 each, and for that price, I'd rather just replace the wheels and brakes (if needed) to get split hubs. Question 1- Is there a good quality tubeless tire that will fit these wheels? I will be operating almost entirely from paved strips. I'm very hesitant to run lawnmower tires on a plane, since I'd hate to have to explain to the FAA why I installed tires like that if there's an accident involving one of them. Duro, Carlisle, and some others exist in a 15x6.00-6 size, but even the 4ply doesn't inspire confidence. Question 2- If there's no reasonably priced tire for these wheels, is there a reasonably priced tire/wheel/hydraulic brake package that uses aircraft tires? I was looking at Black Max, but those seem to have the same issue as what I have, except that they do offer split hubs. Their tires are Carlisle, and I'm not sure if you could use a tube and aircraft tire with the Black Max wheels. Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488906#488906 ________________________________________________________________________________
Subject: Re: Tires, wheels and brakes?
Date: Apr 23, 2019
An a&p friend brought me a pair of Citrabria tube type=C2- 6x6 'take-offs ' that I installed on the BlackMax one peice wheels on Tracy's Twinstar=2E No tubes and no air added in almost 2 years=2E =81=A3Charlie=8B On Apr 23, 2019, 12:42 PM, at 12:42 PM, 13brv3 <13brv3@gmail=2Ecom> wrote: > >Greeting s, > >I'm working on an old Slingshot, and it currently has Van-K 6"x4" >al uminum wheels, and MCP hydraulic brakes=2E These seem like quality >items , and I have no problem with either, other than the fact that I'd >prefer s plit hub wheels to these one piece wheels=2E > >The problem is the tires =2E They're ancient, and really low quality Duro >tires that appear to be for mowers? The size is 15 6=2E00-6=2E The wheels >don't allow the use of tubes, and aircraft tires in this size are >rarely tubeless=2E I think th ere are a few, but they're over $300 each, >and for that price, I'd rather just replace the wheels and brakes (if >needed) to get split hubs=2E > >Que stion 1- Is there a good quality tubeless tire that will fit these >wheels? I will be operating almost entirely from paved strips=2E I'm >very hesi tant to run lawnmower tires on a plane, since I'd hate to have >to explain to the FAA why I installed tires like that if there's an >accident involvin g one of them=2E Duro, Carlisle, and some others exist >in a 15x6=2E00-6 s ize, but even the 4ply doesn't inspire confidence=2E > >Question 2- If th ere's no reasonably priced tire for these wheels, is >there a reasonably pr iced tire/wheel/hydraulic brake package that uses >aircraft tires? I was l ooking at Black Max, but those seem to have the >same issue as what I have, except that they do offer split hubs=2E Their >tires are Carlisle, and I' m not sure if you could use a tube and >aircraft tire with the Black Max wh eels=2E > >Thanks, >Rusty > > >Read this topic online here: > >http:/ /forums=2Ematronics=2Ecom/viewtopic=2Ephp?p=488906#488906 > > ========= - y List utilities such as List Un/Subscription, load, 7-Day Browse, Chat, FAQ, >_ -======================== MS - >_ -= --> http://forums=2Ematronics=2Ecom == nfo to the Matronics Email List Wiki! =2Ecom ============= bution Web Site - -Matt Dralle, List Admin=2E =2Ematronics=2Ecom/contribution ===================== ________________________________________________________________________________
Date: Apr 23, 2019
The Carlisle tires are junk. They are made for golf carts. Kolb originally supplied them on my Xtra. I replaced them with Goodyear Aircraft tires. They are expensive but worth the money in my opinion. I use Matco split rims and went with two Matco calipers on each wheel. I also use tubes. Very happy with the results. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488912#488912 ________________________________________________________________________________
Date: Apr 23, 2019
I don't spend money I don't need to, that is why I have a VW on my MKIII. I have been flying the Carlisle tires since I got them with my Kolb kit. They have served me well. They do shake a bit till I touch the brakes after take off and that maybe is a need for balancing? I have had a few flats from leaking Matco wheels and a few pinched tubes but that isn't the fault of the tires. Most of my flying has been off grass so I haven't had much wear. A few years ago I moved from my own grass strip to a real airport with paved runways so now my tires need to be replaced but that is 26 years of service. Will you get better service from aircraft tires?? I don't like paying insurance and a bunch of lawyers that add no value to aircraft parts. As usual worth what you paid for it. Rick Neilsen Redrive VW powered MKIIIC On Tue, Apr 23, 2019 at 4:51 PM Rex Rodebush wrote: > > The Carlisle tires are junk. They are made for golf carts. Kolb > originally supplied them on my Xtra. I replaced them with Goodyear > Aircraft tires. They are expensive but worth the money in my opinion. I > use Matco split rims and went with two Matco calipers on each wheel. I > also use tubes. Very happy with the results. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=488912#488912 > > ________________________________________________________________________________
Date: Apr 23, 2019
To expand on this (I was previously typing on my phone), the tires are 6.00-6, standard fare on most small/mid size certified a/c, and were removed from the Citabria at annual due to wear (only a hint of tread groove still showing). Intended for tube operation on split wheels. I mounted them on the one-piece wheels on the Kolb without any tubes. I've probably added air to my RV's tube type, split rim tires 3 or 4 times since installing the Kolb tires, and have never added air to the Kolb. I really didn't know if running them tubeless would work, but it seems that as long as the tire (and its bead) and the rim are both in good shape, they'll hold air for a looong time. If 6.00-6 tires will fit your rims, it might be worth taking a shot at picking up a couple of freebies, like I did. A busy maintenance shop likely has several pairs lying around. Charlie On 4/23/2019 2:17 PM, Charlie England wrote: > An a&p friend brought me a pair of Citrabria tube type 6x6 > 'take-offs' that I installed on the BlackMax one peice wheels on > Tracy's Twinstar. No tubes and no air added in almost 2 years. > > Charlie > On Apr 23, 2019, at 12:42 PM, 13brv3 <13brv3(at)gmail.com > > wrote: > > > Greetings, > > I'm working on an old Slingshot, and it currently has Van-K 6"x4" aluminum wheels, and MCP hydraulic brakes. These seem like quality items, and I have no problem with either, other than the fact that I'd prefer split hub wheels to these one piece wheels. > > The problem is the tires. They're ancient, and really low quality Duro tires that appear to be for mowers? The size is 15 6.00-6. The wheels don't allow the use of tubes, and aircraft tires in this size are rarely tubeless. I think there are a few, but they're over $300 each, and for that price, I'd rather just replace the wheels and brakes (if needed) to get split hubs. > > Question 1- Is there a good quality tubeless tire that will fit these wheels? I will be operating almost entirely from paved strips. I'm very hesitant to run lawnmower tires on a plane, since I'd hate to have to explain to the FAA why I installed tires like that if there's an accident involving one of them. Duro, Carlisle, and some others exist in a 15x6.00-6 size, but even the 4ply doesn't inspire confidence. > > Question 2- If there's no reasonably priced tire for these wheels, is there a reasonably priced tire/wheel/hydraulic brake package that uses aircraft tires? I was looking at Black Max, but those seem to have the same issue as what I have, except that they do offer split hubs. Their tires are Carlisle, and I'm not sure if you could use a tube and aircraft tire with the Black Max wheels. > > Thanks, > Rusty > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 23, 2019
Thanks for all the comments. I pretty much expected opinions to vary from use anything that holds are, to use only certified tires. I understand the Carlisle (and other cheap tires) tend to have balance issues, and balance weights will likely end up in the prop as part of Murphy's law of pusher engines. Other than the fact that they don't rate them for speed, the 4 ply Carlisles seem sufficient for the Slingshot. The path of least (effort and financial) resistance would be to try a pair, and since they're only $23 each from Amazon, I might just do that. BlackMax told me they don't make wheels for tubes, but they do have a 6x6 wheel that has the hole in the center, where it would be on a normal split rim. It's a one piece wheel. Desser said they have a Aero Classic tubeless tire for $226 each. Sounds like it's a Cirrus tire. It's 6 ply, which is way overkill, and from what I understand the higher ply tires are very hard to mount on one piece wheels. BTW, I always wondered why most aircraft tires need tubes from how well the beads tend to seal. I guess the split in the rim is the typical reason. It might be worth trying some cheap 6x6 aircraft tires without the tubes on the one-piece wheels. Finally, there's Matco, which may be an option, but they have so many confusing types on their page that I eventually give up after staring at it for a while. Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488917#488917 ________________________________________________________________________________
Date: Apr 23, 2019
Rusty, I=99ve basically ran those very brands for many years. Your wor ry is not realistic. I now run Black Max brakes and one piece wheels. I have two sets , 6=9Dinch wide for my booney tires 15 X 6 and 6X4 Aero som ething from Aircraft Spruce for paved runways. There rated for 70 mph. Both set are mounted tubeless. I=99ve never in 34 years of flying ultr alights had a blowout. Sent from my iPhone > On Apr 23, 2019, at 1:40 PM, 13brv3 <13brv3(at)gmail.com> wrote: > > > Greetings, > > I'm working on an old Slingshot, and it currently has Van-K 6"x4" aluminum wheels, and MCP hydraulic brakes. These seem like quality items, and I ha ve no problem with either, other than the fact that I'd prefer split hub whe els to these one piece wheels. > > The problem is the tires. They're ancient, and really low quality Duro ti res that appear to be for mowers? The size is 15 6.00-6. The wheels don't a llow the use of tubes, and aircraft tires in this size are rarely tubeless. I think there are a few, but they're over $300 each, and for that price, I' d rather just replace the wheels and brakes (if needed) to get split hubs. > > Question 1- Is there a good quality tubeless tire that will fit these whee ls? I will be operating almost entirely from paved strips. I'm very hesit ant to run lawnmower tires on a plane, since I'd hate to have to explain to t he FAA why I installed tires like that if there's an accident involving one o f them. Duro, Carlisle, and some others exist in a 15x6.00-6 size, but even the 4ply doesn't inspire confidence. > > Question 2- If there's no reasonably priced tire for these wheels, is ther e a reasonably priced tire/wheel/hydraulic brake package that uses aircraft t ires? I was looking at Black Max, but those seem to have the same issue as w hat I have, except that they do offer split hubs. Their tires are Carlisle, and I'm not sure if you could use a tube and aircraft tire with the Black M ax wheels. > > Thanks, > Rusty > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=488906#488906 > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Apr 24, 2019
Naturally I would jump in with my scrounging method...The local AP/IA gives me tires..They are pulls but many have a lot of wear left. Herb Sent with ProtonMail Secure Email. Original Message On Tuesday, April 23, 2019 6:16 PM, 13brv3 <13brv3(at)gmail.com> wrote: > > Thanks for all the comments. I pretty much expected opinions to vary from use anything that holds are, to use only certified tires. > > I understand the Carlisle (and other cheap tires) tend to have balance issues, and balance weights will likely end up in the prop as part of Murphy's law of pusher engines. Other than the fact that they don't rate them for speed, the 4 ply Carlisles seem sufficient for the Slingshot. The path of least (effort and financial) resistance would be to try a pair, and since they're only $23 each from Amazon, I might just do that. > > BlackMax told me they don't make wheels for tubes, but they do have a 6x6 wheel that has the hole in the center, where it would be on a normal split rim. It's a one piece wheel. > > Desser said they have a Aero Classic tubeless tire for $226 each. Sounds like it's a Cirrus tire. It's 6 ply, which is way overkill, and from what I understand the higher ply tires are very hard to mount on one piece wheels. BTW, I always wondered why most aircraft tires need tubes from how well the beads tend to seal. I guess the split in the rim is the typical reason. It might be worth trying some cheap 6x6 aircraft tires without the tubes on the one-piece wheels. > > Finally, there's Matco, which may be an option, but they have so many confusing types on their page that I eventually give up after staring at it for a while. > > Thanks, > Rusty > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=488917#488917 > ________________________________________________________________________________
Date: Apr 23, 2019
> > To balance tires i got this this idea from Nick Casara. Instead of using stick on weights inside the rim. I took a tubeless tire patch taped it on the light side of the tread till the tire would Ballance. Un mounted the tire mount the patch on the inside of the tire tread. Remount the tire using talcum powder to keep the tube from sticking to the patch. Keep the bead of the tire free of talc. Balanced tire with no visible weights to fall off. Just mark the tire, rim and tube so final assembly is the same as when first tested. Boyd Young Mkiii Utah ________________________________________________________________________________
Date: Apr 23, 2019
Just to give a little background on my experience with Carlisle tires. I had about 140 landings (on pavement) with the ones furnished by Kolb. The Cord was showing so I replaced them with another set of Carlisle's. After installing on the rims I added about 6 oz. of weight on one and it still would not balance. I then noticed that the runout on that tire was well over 1/2 inch in one spot. I think the cord was overlaped too much (made in China). I also had a very difficult time seating the tire on the rim due to poor manufacturing tolerances. I decided to run it anyway and see if it was a problem. At a very, very fast taxi it was hardly noticeable. At a normal taxi speed it was like going over a 1/2 +" high speed bump and was in resonance with the landing gear. Very bouncy, not good. I then replaced them with Goodyear 8.00-6 tires. They seated on the rims very nicely and had no noticeable runout. They are also 6 ply where the Carlisle's had 4 ply. The downside is that the Goodyears are about 2.3# heaver per tire and of course the high cost. Anyway, we'll see how long they last. My landings are much slower and better now so that should help. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488921#488921 ________________________________________________________________________________
Date: Apr 23, 2019
I forgot to add that the Goodyear tires required very little balance weights. I think I used about 3/4 oz on one and a little more on the other. Not sure it they really needed it but decided to balance them anyway. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488922#488922 ________________________________________________________________________________
Date: Apr 24, 2019
Thanks again. I like the wheels and brakes, so I'm going to try one of the less expensive aircraft tires, but without the tube. I have to believe that's a better option than the Carlisle, and hardly any more expensive. Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488928#488928 ________________________________________________________________________________
Date: Apr 24, 2019
After some further research, it appears the Van-K wheels I have are actually two piece rims, not one-piece. All their current videos show the welded one-piece wheels, so I overlooked the bolt-together rims that were also on their site. I'll know for sure when I take them apart, but certainly I'll need new o-rings for the center, and valve stems. This will make mounting the tires much easier. Thanks again, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488930#488930 ________________________________________________________________________________
Date: Apr 24, 2019
On 4/24/2019 8:19 AM, 13brv3 wrote: > > After some further research, it appears the Van-K wheels I have are actually two piece rims, not one-piece. All their current videos show the welded one-piece wheels, so I overlooked the bolt-together rims that were also on their site. I'll know for sure when I take them apart, but certainly I'll need new o-rings for the center, and valve stems. This will make mounting the tires much easier. > > Thanks again, > Rusty > If they don't have the smaller dia recess in the center of the rim, it would certainly be tough (impossible?) to mount a tire without splitting the wheel. My one piece BlackMax wheels have a deep recess, just like automotive tires. It was relatively easy to mount my tires. How wide are your rims? IIRC, mine are close to 6" between the rims. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 24, 2019
ceengland7(at)gmail.com wrote: > > > If they don't have the smaller dia recess in the center of the rim, it > would certainly be tough (impossible?) to mount a tire without splitting > the wheel. My one piece BlackMax wheels have a deep recess, just like > automotive tires. It was relatively easy to mount my tires. How wide > are your rims? IIRC, mine are close to 6" between the rims. > > Charlie > Hopefully I won't have to find out. I did learn a few "facts" about tube type tires that don't seem to match the reports I've read here. In theory, tube type tires are to be designed with pin hole leaks, rather than being sealed. The idea is that no air can get trapped between the tube and tire. I asked Desser if that was really still true, mentioning the reports of people using them with no tubes, and no leaks. I haven't heard back from them yet. The cheapest tubeless aircraft tire I can find is made by Goodyear, at about $160 each. They're 6 ply, which is overkill, and I'd be afraid they'd be too hard to mount if the wheels were one piece, but if they're really two piece, I'll probably get a set of these and have no nagging concerns about tires in the future. Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=488941#488941 ________________________________________________________________________________
Subject: off-the-shelf seat options?
Date: May 06, 2019
Greetings, I've read that you can find boat seats or cushions that are close to what we'd need for the front seat of a FireStar/SlingShot, but the ones I've found seem too large. Spruce has a couple reasonably priced options as well, but again, there will need to be modifications. What's the closest off-the-shelf seat you've found? FWIW, the seat bottom is 12.25" wide, 16" deep. I'd want 1.5-2" thickness. The seat back is 22" tall, but tapered from 11" wide at the bottom, to 7.75" wide at the top. Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489105#489105 ________________________________________________________________________________
Date: May 06, 2019
Subject: Re: off-the-shelf seat options?
https://www.overtons.com/moeller-replacement-white-cushion-set-for-2070-seat-355109.html?CAWELAID=120071730000281298&s_kwcid=adwords__&gclid=EAIaIQobChMI5p2i-K2H4gIVlsRkCh0xxATLEAQYDiABEgJJM_D_BwE I couldn't find dimensions but there is a phone number to call. It did say 3.5 pounds. Boyd Young Mkiii UT On Mon, May 6, 2019, 9:57 AM 13brv3 <13brv3(at)gmail.com> wrote: > > Greetings, > > I've read that you can find boat seats or cushions that are close to what > we'd need for the front seat of a FireStar/SlingShot, but the ones I've > found seem too large. Spruce has a couple reasonably priced options as > well, but again, there will need to be modifications. What's the closest > off-the-shelf seat you've found? > > FWIW, the seat bottom is 12.25" wide, 16" deep. I'd want 1.5-2" > thickness. The seat back is 22" tall, but tapered from 11" wide at the > bottom, to 7.75" wide at the top. > > Thanks, > Rusty > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=489105#489105 > > ________________________________________________________________________________
Date: May 06, 2019
Thanks, but I've found any number of similar links. What I'm looking for is something that's known to work. I do need it to fold, and some boat seats do fold, but most have too much thickness in the seat bottom. This is the closest thing I've found so far for cushions. The bottom is probably OK, though a bit too wide. The back would need some work. http://www.noralenterprises.com/store/index.php?route=product/product&path=35_46&product_id=84 Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489108#489108 ________________________________________________________________________________
Date: May 06, 2019
13brv3 wrote: > Greetings, > > ...S...N..I..P... > > FWIW, the seat bottom is 12.25" wide, 16" deep. I'd want 1.5-2" thickness. The seat back is 22" tall, but tapered from 11" wide at the bottom, to 7.75" wide at the top. > > Thanks, > Rusty I know that you are looking for "Off the Shelf", however, for sizing, comfort and price, I chose to make my own. Biggest issue being size. At 6'3", I couldn't afford to give away any more room than necessary. The foundation for both the back and the bottom are from 1/4" plywood. For the back , used 1" thick foam. For the seat bottom, I used seat cushion foam (memory foam) from WICKS. There are different thicknesses and densities. Your weight and sitting height will dictate these. (I think I used 1 1/2" thick, medium density.) The 1" foam for the back and black vinyl for covering both the seat and the back came from a local fabric shop. For added safety, I used sheet aluminum (at least .090, maybe .125) for the seat bottom. Fabricated a similar setup for the rear seat. Used fabric shop foam for the back seat cushion to lower cost. The rear seat setup is easily removeable. The attached image will give you a general idea of the setup. Sorry there's not a better shot of the seat bottom. If you need additional images, let me know and I'll try to get some within a week. -------- George Alexander FS II R503 E-LSA N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489111#489111 Attachments: http://forums.matronics.com//files/fsii_seats_116.jpg ________________________________________________________________________________
Date: May 06, 2019
I have a bad back and tried several "off the shelf" seats in a simulated wood fuselage to find the most comfortable one. Wound up using the standard sling seat with several layers of Temper Foam in the seat, back and lumber area. Very easy on the back even after a 2+ hour flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489113#489113 ________________________________________________________________________________
Date: May 06, 2019
Guess it really isn't a sling seat as it's fabric is supported at three places. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489114#489114 ________________________________________________________________________________
Date: May 06, 2019
As I recall, my original SS seat was foam from a life preserve seat cushion, and my wife sewed a vinyl cover for it. There's no reason I can't improve on that with some better foam, and material, but if there's something out there that will work, and isn't stupid expensive, that's probably the path of least resistance. I'm 6-1 but it's all torso, so I never have head room, but legroom is not usually a problem. I had about 1" foam in the original seat bottom and back, but I'd probably go for 1.5-2 in the bottom, and maybe 2" in the back. I also won't use the rear seat, so there's no reason for the seat back to be that narrow. I can fairly easily make a new seat back structure to fit any seat back cushion I find. I need to go find a marine supply place to look around in, which was much easier in FL than here in TN. Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489115#489115 ________________________________________________________________________________
Subject: search all of Craigs list
Date: May 06, 2019
Thought this might be useful...as it is a good way to link to pics of any airplane or aviation item that is listed for sale on Craigs list... Herb http://www.searchcraigslist.org/ I may be the last fellow to know about it.... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489119#489119 ________________________________________________________________________________
Subject: Re: search all of Craigs list
Date: May 06, 2019
On 5/6/2019 9:09 PM, herbgh wrote: > > Thought this might be useful...as it is a good way to link to pics of any airplane or aviation item that is listed for sale on Craigs list... Herb > > http://www.searchcraigslist.org/ > > I may be the last fellow to know about it.... > > Haven't seen that one, but here's another: https://www.searchtempest.com/ --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 08, 2019
IT WORKS! Over the last couple of weeks we tried taking 2" off the prop length; no improvement. But a 60" prop is still plenty of prop for a 277, so no real harm done. We were about ready to turn the 277 into a boat anchor, and then something stirred way back in the memory banks - Back in 1983, I had a Maxair Hummer with a 277 on it, and when it was new, the engine ran properly with factory jetting. After several months of flying and getting well broken in, it got wonky. Kind of like this one. Something we noticed on this engine, you could not get the EGT's above 950 under load. If you went smaller on the needle jet, then it would not accept throttle. If you lowered the jet needle lower than normal, it would not accept throttle. The low and mid range was too lean. So we took off the intake silencer, took everything back to stock jetting. No improvement. The symptoms were constant: would not run normally between 5200 and 5800. It would run fast, or it would run slow, but not at a usable rpm. So we decided to go bigger on the low end jets and and then see if it would accept smaller top end jets. Bingo! Stock jets are a 148 main, a 2.72 needle jet, an 8L2 jet needle in the middle #2 clip position, and a 45 idle jet. Now running a 145 main jet, a 2.70 idle jet, an 8G2 jet needle with the clip in the bottom #3 position, and a 50 idle jet. Set the Ivoprop so that it turns 5900 on climbout and it runs perfect, EGT stays about 1025, good throttle response. Finally. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489131#489131 ________________________________________________________________________________
Date: May 08, 2019
Richard Pike wrote: > IT WORKS! > > ...S ...N ...I ...P > > Finally. Flaming enthusiasm, backed up by horse sense and persistence, is the quality that most frequently makes for success. Dale Carnegie -------- George Alexander FS II R503 E-LSA N709FS http://www.oh2fly.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489132#489132 ________________________________________________________________________________
Date: May 08, 2019
Awesome troubleshoot and fix. Congratulations on a job well done. Definitely one for the archives! -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Pike Sent: Wednesday, May 08, 2019 12:29 PM Subject: Kolb-List: Re: 277 keeps falling off the pipe --> IT WORKS! Over the last couple of weeks we tried taking 2" off the prop length; no improvement. But a 60" prop is still plenty of prop for a 277, so no real harm done. We were about ready to turn the 277 into a boat anchor, and then something stirred way back in the memory banks - Back in 1983, I had a Maxair Hummer with a 277 on it, and when it was new, the engine ran properly with factory jetting. After several months of flying and getting well broken in, it got wonky. Kind of like this one. Something we noticed on this engine, you could not get the EGT's above 950 under load. If you went smaller on the needle jet, then it would not accept throttle. If you lowered the jet needle lower than normal, it would not accept throttle. The low and mid range was too lean. So we took off the intake silencer, took everything back to stock jetting. No improvement. The symptoms were constant: would not run normally between 5200 and 5800. It would run fast, or it would run slow, but not at a usable rpm. So we decided to go bigger on the low end jets and and then see if it would accept smaller top end jets. Bingo! Stock jets are a 148 main, a 2.72 needle jet, an 8L2 jet needle in the middle #2 clip position, and a 45 idle jet. Now running a 145 main jet, a 2.70 idle jet, an 8G2 jet needle with the clip in the bottom #3 position, and a 50 idle jet. Set the Ivoprop so that it turns 5900 on climbout and it runs perfect, EGT stays about 1025, good throttle response. Finally. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489131#489131 ________________________________________________________________________________
Subject: Excellent Slingshot project for sale on Barnstormers
Date: May 10, 2019
You know how they say timing is everything... If you go to Barnstormers, and search for Slingshot, you'll find exactly what I was looking for a few month ago. If I had the money and the space, I'd buy it and squirrel it away for the future, but neither of those are true, so one of you needs to buy it to save me from having to consider this :-) Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489168#489168 ________________________________________________________________________________
Date: May 17, 2019
Subject: Re: Kolb-List Digest: 0 Msgs - 05/16/19
I have collection of Ultralight and ultralight flying magazines from 80s on. Been in storage for a long time. Probably fifty or more. If anyone is interested, free and u pay shipping. I can delineate what issues I have to a serious collector. Ted Cowan. Sling shot 912 zoom zoom. Sent from my iPhone > On May 17, 2019, at 1:37 AM, Kolb-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-05-16&Archive=Kolb > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 19-05-16&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Thu 05/16/19: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Subject: Pilot Acces for sale
Date: May 17, 2019
Hello fellow pilots. I have some items for sale that I no longer can use. Years ago I earned my pilots license and purchased a Kolb Mark III Kit. I spent approx. a thousand hours building and got about 3/4 of the way done. At that point I realized I didn't have the funds to complete it and sold it. I'm selling my pilot accessories now. All are new or nearly new. They include Sigtronics headphones, Sportys transceiver, Sportys intercom plus more. I also have a few aircraft building tools (specialty iron, swagging tool, rib drilling guide, etc.) For a list with specifics and prices email me at rphillip1999(at)yahoo.com Safe flying to all. Russ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489266#489266 ________________________________________________________________________________
Subject: Re: second chantz chutes
Date: May 20, 2019
Hi All, I am french trike ultralight pilot and i bought an old trike with a second chantz parachute model 900 (i attach photo) It seams to be in a good condition. I would like to expertize it but i have no documentation about it. I come to you because i see that your community use lot of 2nd chantz chute. Does anybody have documentation about this chute ? i am searching info about the rocket system, how does it work. How can i disassemble it. ? I plan to open the canister to look inside if there is moisture (without removing the chute in the first step). I would like to identify the rocket PN to see if i can found something equivalent. The rocket is in a metal tube. there is on one side a cap with 3 plastic screw and silicone seal. on the other side there is a cap without silicone seal but it seams to be fix with 3 or 4 rivet. threre is also an allen screw, don't know what is used for. Canister is also seal with silicone seal on the 2 side. One escape side there are 3 plastic screw, on the other side only a cap sealed. Thanks a lot for all your info that you can provide to me, with my regards from france !! Richard Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489303#489303 Attachments: http://forums.matronics.com//files/img_9603_169.png http://forums.matronics.com//files/img_8798_120.jpg ________________________________________________________________________________
Date: May 24, 2019
Subject: Re: Kolb-List Digest: 0 Msgs - 05/15/19
how can i stop this kolb digest e mails notices On Wed, May 15, 2019 at 11:40 PM Kolb-List Digest Server < kolb-list(at)matronics.com> wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-05-15&Archive=Kolb > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 19-05-15&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Wed 05/15/19: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > ________________________________________________________________________________
Subject: Good flight Saturday
Date: May 26, 2019
Since things seem slow lately - Saturday one of the locals had a fly-in/cookout at his strip and I took one of the young ladies from church on her first light sport airplane flight. She is going into aerospace as a career, and is a CAP Cadet-Captain, so I wanted her to get some stick time in the MKIII to and from the fly-in, and also to get some exposure to the homebuilt scene, since up to this point she had only been around Cessnas. About half way back the light came on in her head and she was then able to keep it smooth and stable the rest of the way home in spite of light thermals and a quickening breeze across the East Tennessee mountains. My wife snapped these pictures as we were leaving out. Good times. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489379#489379 Attachments: http://forums.matronics.com//files/p1250800_large_910.jpeg http://forums.matronics.com//files/takeoff_cropped_large_179.jpeg http://forums.matronics.com//files/p1250804_large_210.jpeg ________________________________________________________________________________
Date: May 28, 2019
how can i stop this kolb digest e mails On Fri, May 24, 2019 at 9:50 AM AD DECKER wrote: > how can i stop this kolb digest e mails > notices > > On Wed, May 15, 2019 at 11:40 PM Kolb-List Digest Server < > kolb-list(at)matronics.com> wrote: > >> * >> >> ================================================= >> Online Versions of Today's List Digest Archive >> ================================================= >> >> Today's complete Kolb-List Digest can also be found in either of the >> two Web Links listed below. The .html file includes the Digest formatted >> in HTML for viewing with a web browser and features Hyperlinked Indexes >> and Message Navigation. The .txt file includes the plain ASCII version >> of the Kolb-List Digest and can be viewed with a generic text editor >> such as Notepad or with a web browser. >> >> HTML Version: >> >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-05-15&Archive=Kolb >> >> Text Version: >> >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 19-05-15&Archive=Kolb >> >> >> =============================================== >> EMail Version of Today's List Digest Archive >> =============================================== >> >> >> ---------------------------------------------------------- >> Kolb-List Digest Archive >> --- >> Total Messages Posted Wed 05/15/19: 0 >> ---------------------------------------------------------- >> >> >> Today's Message Index: >> ---------------------- >> >> >> >> >> >> >> >> >> >> >> ________________________________________________________________________________
Date: May 30, 2019
*http://www.matronics.com/subscription * *will do it. * *Bye* On Wed, May 29, 2019 at 2:28 PM AD DECKER wrote: > how can i stop this kolb digest e mails > > On Fri, May 24, 2019 at 9:50 AM AD DECKER wrote: > >> how can i stop this kolb digest e mails >> notices >> >> On Wed, May 15, 2019 at 11:40 PM Kolb-List Digest Server < >> kolb-list(at)matronics.com> wrote: >> >>> * >>> >>> ================================================= >>> Online Versions of Today's List Digest Archive >>> ================================================= >>> >>> Today's complete Kolb-List Digest can also be found in either of the >>> two Web Links listed below. The .html file includes the Digest >>> formatted >>> in HTML for viewing with a web browser and features Hyperlinked Indexes >>> and Message Navigation. The .txt file includes the plain ASCII version >>> of the Kolb-List Digest and can be viewed with a generic text editor >>> such as Notepad or with a web browser. >>> >>> HTML Version: >>> >>> >>> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-05-15&Archive=Kolb >>> >>> Text Version: >>> >>> >>> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 19-05-15&Archive=Kolb >>> >>> >>> =============================================== >>> EMail Version of Today's List Digest Archive >>> =============================================== >>> >>> >>> ---------------------------------------------------------- >>> Kolb-List Digest Archive >>> --- >>> Total Messages Posted Wed 05/15/19: 0 >>> ---------------------------------------------------------- >>> >>> >>> Today's Message Index: >>> ---------------------- >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: May 30, 2019
*http://www.matronics.com/subscription * *This will do it.* *Bye* On Wed, May 29, 2019 at 2:28 PM AD DECKER wrote: > how can i stop this kolb digest e mails > > On Fri, May 24, 2019 at 9:50 AM AD DECKER wrote: > >> how can i stop this kolb digest e mails >> notices >> >> On Wed, May 15, 2019 at 11:40 PM Kolb-List Digest Server < >> kolb-list(at)matronics.com> wrote: >> >>> * >>> >>> ================================================= >>> Online Versions of Today's List Digest Archive >>> ================================================= >>> >>> Today's complete Kolb-List Digest can also be found in either of the >>> two Web Links listed below. The .html file includes the Digest >>> formatted >>> in HTML for viewing with a web browser and features Hyperlinked Indexes >>> and Message Navigation. The .txt file includes the plain ASCII version >>> of the Kolb-List Digest and can be viewed with a generic text editor >>> such as Notepad or with a web browser. >>> >>> HTML Version: >>> >>> >>> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-05-15&Archive=Kolb >>> >>> Text Version: >>> >>> >>> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 19-05-15&Archive=Kolb >>> >>> >>> =============================================== >>> EMail Version of Today's List Digest Archive >>> =============================================== >>> >>> >>> ---------------------------------------------------------- >>> Kolb-List Digest Archive >>> --- >>> Total Messages Posted Wed 05/15/19: 0 >>> ---------------------------------------------------------- >>> >>> >>> Today's Message Index: >>> ---------------------- >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Kolb Ultrstar Wing Condition
Date: Jun 02, 2019
I recently bought a Kolb Ultrastar. The Aircraft A&E only has 26 hours of total flying time with no know accident history. However it has been stored in a basement for 20+years. As a result the aluminum in the wings has oxidized pretty well and the steel rivets show a fair amount of corrosion. My plan is to recover the wings, but before I did that I wanted to ask your opinions as to the viability and structural integrity based on the included picture in the link below. Additionally the aircraft came with a Kuyuna SN# 21673 2 stroke motor and any information/ service manuals would be greatly appreciated. Below the link to the photos mentioned. https://photos.app.goo.gl/MdWtRZLrgfcztcKH9 Thank you in advanced -------- Peter Raleigh, NC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489433#489433 ________________________________________________________________________________
Subject: Re: Kolb Ultrstar Wing Condition
Date: Jun 03, 2019
Here's the Cuyuna engine guy http://zdenterprises.net/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489454#489454 ________________________________________________________________________________
Date: Jun 03, 2019
Impossible question to answer just based on pictures. I would remove the aluminum surface oxidation in several spots to determine the depth. I would suspect that the aluminum is probably OK. You might also drill out a number of rivets in random locations to see if the corrosion is through the rivet or just on the surface of the head and how deep. I would probably consider drilling them all out and replacing with stainless steel rivets. A lot of work but not a lot of money. Again, these are idle thoughts and not recommendations. Worth what you paid for them. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489456#489456 ________________________________________________________________________________
Date: Jun 03, 2019
I have heard that aluminum oxidizes and the oxidation forms a protective barrier that stops further oxidation? If this is so leave it alone. I was surprised to see the rust on the rivets. I think mine are stainless steel. Absolutely drill out a few rivets to see how bad they are. Wow that would be a major job drilling out and replacing thousands of rivets. Then you would have to disassemble the structure to get the remainder of the old rivets out. I have remainder of a few rivets that didn't seat properly still in my plane but you would have thousands of them. Also that engine didn't have that great a reputation, can you still get parts? Good luck. Rick Neilsen Redrive VW powered MKIIIC On Mon, Jun 3, 2019 at 10:43 AM Rex Rodebush wrote: > > Impossible question to answer just based on pictures. I would remove the > aluminum surface oxidation in several spots to determine the depth. I > would suspect that the aluminum is probably OK. You might also drill out a > number of rivets in random locations to see if the corrosion is through the > rivet or just on the surface of the head and how deep. I would probably > consider drilling them all out and replacing with stainless steel rivets. > A lot of work but not a lot of money. > > Again, these are idle thoughts and not recommendations. Worth what you > paid for them. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=489456#489456 > > ________________________________________________________________________________
Date: Jun 03, 2019
Different kinds of aluminum have different corrosion properties. Pure aluminum forms an oxide layer that protects that below it. This is called alclad aluminum. I do not believe the aluminum tubing in Kolbs is alclad. On Mon, Jun 3, 2019 at 11:21 AM Rick Neilsen wrote: > I have heard that aluminum oxidizes and the oxidation forms a protective > barrier that stops further oxidation? If this is so leave it alone. I was > surprised to see the rust on the rivets. I think mine are stainless steel. > Absolutely drill out a few rivets to see how bad they are. Wow that would > be a major job drilling out and replacing thousands of rivets. Then you > would have to disassemble the structure to get the remainder of the old > rivets out. I have remainder of a few rivets that didn't seat properly > still in my plane but you would have thousands of them. > > Also that engine didn't have that great a reputation, can you still get > parts? > > Good luck. > > Rick Neilsen > Redrive VW powered MKIIIC > > On Mon, Jun 3, 2019 at 10:43 AM Rex Rodebush wrote: > >> >> Impossible question to answer just based on pictures. I would remove the >> aluminum surface oxidation in several spots to determine the depth. I >> would suspect that the aluminum is probably OK. You might also drill out a >> number of rivets in random locations to see if the corrosion is through the >> rivet or just on the surface of the head and how deep. I would probably >> consider drilling them all out and replacing with stainless steel rivets. >> A lot of work but not a lot of money. >> >> Again, these are idle thoughts and not recommendations. Worth what you >> paid for them. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=489456#489456 >> >> >> >> >> >> >> ========== >> -List" rel="noreferrer" target="_blank"> >> http://www.matronics.com/Navigator?Kolb-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> ________________________________________________________________________________
Date: Jun 03, 2019
eW91IHdpbGwgbG92ZSBzdGVlbCByaXZldHMgd2hlbiB0cnlpbmcgdG8gZHJpbGwgb3V0IHN0YWlu bGVzcyBvbmVzLi4uOi0pICBIZXJiCgpTZW50IHdpdGggW1Byb3Rvbk1haWxdKGh0dHBzOi8vcHJv dG9ubWFpbC5jb20pIFNlY3VyZSBFbWFpbC4KCuKAkOKAkOKAkOKAkOKAkOKAkOKAkCBPcmlnaW5h bCBNZXNzYWdlIOKAkOKAkOKAkOKAkOKAkOKAkOKAkApPbiBNb25kYXksIEp1bmUgMywgMjAxOSAx MDoxOSBBTSwgUmljayBOZWlsc2VuIDxuZWlsc2Vucm1AZ21haWwuY29tPiB3cm90ZToKCj4gSSBo YXZlIGhlYXJkIHRoYXQgYWx1bWludW0gb3hpZGl6ZXMgYW5kIHRoZSBveGlkYXRpb24gZm9ybXMg YSBwcm90ZWN0aXZlIGJhcnJpZXIgdGhhdCBzdG9wcyBmdXJ0aGVyIG94aWRhdGlvbj8gSWYgdGhp cyBpcyBzbyBsZWF2ZSBpdCBhbG9uZS4gSSB3YXMgc3VycHJpc2VkIHRvIHNlZSB0aGUgcnVzdCBv biB0aGUgcml2ZXRzLiBJIHRoaW5rIG1pbmUgYXJlIHN0YWlubGVzcyBzdGVlbC4gQWJzb2x1dGVs eSBkcmlsbCBvdXQgYSBmZXcgcml2ZXRzIHRvIHNlZSBob3cgYmFkIHRoZXkgYXJlLiBXb3cgdGhh dCB3b3VsZCBiZSBhIG1ham9yIGpvYiBkcmlsbGluZyBvdXQgYW5kIHJlcGxhY2luZyB0aG91c2Fu ZHMgb2Ygcml2ZXRzLiBUaGVuIHlvdSB3b3VsZCBoYXZlIHRvIGRpc2Fzc2VtYmxlIHRoZSBzdHJ1 Y3R1cmUgdG8gZ2V0IHRoZSByZW1haW5kZXIgb2YgdGhlIG9sZCByaXZldHMgb3V0LiBJIGhhdmUg cmVtYWluZGVyIG9mIGEgZmV3IHJpdmV0cyB0aGF0IGRpZG4ndCBzZWF0IHByb3Blcmx5IHN0aWxs IGluIG15IHBsYW5lIGJ1dCB5b3Ugd291bGQgaGF2ZSB0aG91c2FuZHMgb2YgdGhlbS4KPgo+IEFs c28gdGhhdCBlbmdpbmUgZGlkbid0IGhhdmUgdGhhdCBncmVhdCBhIHJlcHV0YXRpb24sIGNhbiB5 b3Ugc3RpbGwgZ2V0IHBhcnRzPwo+Cj4gR29vZCBsdWNrLgo+Cj4gUmljayBOZWlsc2VuCj4gUmVk cml2ZSBWVyBwb3dlcmVkIE1LSUlJQwo+Cj4gT24gTW9uLCBKdW4gMywgMjAxOSBhdCAxMDo0MyBB TSBSZXggUm9kZWJ1c2ggPGpycm9kZWJ1c2hAZ21haWwuY29tPiB3cm90ZToKPgo+PiAtLT4gS29s Yi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiUmV4IFJvZGVidXNoIiA8anJyb2RlYnVzaEBnbWFp bC5jb20+Cj4+Cj4+IEltcG9zc2libGUgcXVlc3Rpb24gdG8gYW5zd2VyIGp1c3QgYmFzZWQgb24g cGljdHVyZXMuICBJIHdvdWxkIHJlbW92ZSB0aGUgYWx1bWludW0gc3VyZmFjZSBveGlkYXRpb24g aW4gc2V2ZXJhbCBzcG90cyB0byBkZXRlcm1pbmUgdGhlIGRlcHRoLiAgSSB3b3VsZCBzdXNwZWN0 IHRoYXQgdGhlIGFsdW1pbnVtIGlzIHByb2JhYmx5IE9LLiBZb3UgbWlnaHQgYWxzbyBkcmlsbCBv dXQgYSBudW1iZXIgb2Ygcml2ZXRzIGluIHJhbmRvbSBsb2NhdGlvbnMgdG8gc2VlIGlmIHRoZSBj b3Jyb3Npb24gaXMgdGhyb3VnaCB0aGUgcml2ZXQgb3IganVzdCBvbiB0aGUgc3VyZmFjZSBvZiB0 aGUgaGVhZCBhbmQgaG93IGRlZXAuICBJIHdvdWxkIHByb2JhYmx5IGNvbnNpZGVyIGRyaWxsaW5n IHRoZW0gYWxsIG91dCBhbmQgcmVwbGFjaW5nIHdpdGggc3RhaW5sZXNzIHN0ZWVsIHJpdmV0cy4g IEEgbG90IG9mIHdvcmsgYnV0IG5vdCBhIGxvdCBvZiBtb25leS4KPj4KPj4gQWdhaW4sIHRoZXNl IGFyZSBpZGxlIHRob3VnaHRzIGFuZCBub3QgcmVjb21tZW5kYXRpb25zLiAgV29ydGggd2hhdCB5 b3UgcGFpZCBmb3IgdGhlbS4KPj4KPj4gUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOgo+Pgo+ PiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTQ4OTQ1NiM0ODk0 NTYKPj4KPj4gPT09PT09PT09PT0KPj4gLUxpc3QiIHJlbD0ibm9yZWZlcnJlciIgdGFyZ2V0PSJf YmxhbmsiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/S29sYi1MaXN0Cj4+ID09 PT09PT09PT09Cj4+IEZPUlVNUyAtCj4+IGVmZXJyZXIiIHRhcmdldD0iX2JsYW5rIj5odHRwOi8v Zm9ydW1zLm1hdHJvbmljcy5jb20KPj4gPT09PT09PT09PT0KPj4gV0lLSSAtCj4+IGVycmVyIiB0 YXJnZXQ9Il9ibGFuayI+aHR0cDovL3dpa2kubWF0cm9uaWNzLmNvbQo+PiA9PT09PT09PT09PQo+ PiBiIFNpdGUgLQo+PiAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgo+PiByZWw9 Im5vcmVmZXJyZXIiIHRhcmdldD0iX2JsYW5rIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29u dHJpYnV0aW9uCj4+ID09PT09PT09PT09 ________________________________________________________________________________
Date: Jun 03, 2019
NjA2MS1UNi4uLi5veGlkaXplcyBhbmQgcHJvdmlkZXMgYSBwcm90ZWN0aXZlIGNvYXRpbmcuLiAy MDI0IGlzICBhbGNsYWQuLi5oaWdoIGNvcHBlci4uLmFuZCB3aXRob3V0IHRoZSBmYWlybHkgcHVy ZSBjbGFkIHdvdWxkIGNlcnRhaW5seSB0dXJuIGdyZWVuIHRvIGFuIGV4dGVudC4uLnZlcnkgdGhp biBjbGFkZGluZy4uLnNvbWUgZ3V5cyBwb2xpc2ggdGhyb3VnaCB0aGUgY2xhZGRpbmcgb24gdGhl aXIgZ2EgcGxhbmVzLi4uCgpTZW50IHdpdGggW1Byb3Rvbk1haWxdKGh0dHBzOi8vcHJvdG9ubWFp bC5jb20pIFNlY3VyZSBFbWFpbC4KCuKAkOKAkOKAkOKAkOKAkOKAkOKAkCBPcmlnaW5hbCBNZXNz YWdlIOKAkOKAkOKAkOKAkOKAkOKAkOKAkApPbiBNb25kYXksIEp1bmUgMywgMjAxOSAxMDozMiBB TSwgPGphbWVzLnZhbmxhYWtAZ21haWwuY29tPiB3cm90ZToKCj4gRGlmZmVyZW50IGtpbmRzIG9m IGFsdW1pbnVtIGhhdmUgZGlmZmVyZW50IGNvcnJvc2lvbiBwcm9wZXJ0aWVzLiAgUHVyZSBhbHVt aW51bSBmb3JtcyBhbiBveGlkZSBsYXllciB0aGF0IHByb3RlY3RzIHRoYXQgYmVsb3cgaXQuICBU aGlzIGlzIGNhbGxlZCBhbGNsYWQgYWx1bWludW0uICBJIGRvIG5vdCBiZWxpZXZlIHRoZSBhbHVt aW51bSB0dWJpbmcgaW4gS29sYnMgaXMgYWxjbGFkLgo+Cj4gT24gTW9uLCBKdW4gMywgMjAxOSBh dCAxMToyMSBBTSBSaWNrIE5laWxzZW4gPG5laWxzZW5ybUBnbWFpbC5jb20+IHdyb3RlOgo+Cj4+ IEkgaGF2ZSBoZWFyZCB0aGF0IGFsdW1pbnVtIG94aWRpemVzIGFuZCB0aGUgb3hpZGF0aW9uIGZv cm1zIGEgcHJvdGVjdGl2ZSBiYXJyaWVyIHRoYXQgc3RvcHMgZnVydGhlciBveGlkYXRpb24/IElm IHRoaXMgaXMgc28gbGVhdmUgaXQgYWxvbmUuIEkgd2FzIHN1cnByaXNlZCB0byBzZWUgdGhlIHJ1 c3Qgb24gdGhlIHJpdmV0cy4gSSB0aGluayBtaW5lIGFyZSBzdGFpbmxlc3Mgc3RlZWwuIEFic29s dXRlbHkgZHJpbGwgb3V0IGEgZmV3IHJpdmV0cyB0byBzZWUgaG93IGJhZCB0aGV5IGFyZS4gV293 IHRoYXQgd291bGQgYmUgYSBtYWpvciBqb2IgZHJpbGxpbmcgb3V0IGFuZCByZXBsYWNpbmcgdGhv dXNhbmRzIG9mIHJpdmV0cy4gVGhlbiB5b3Ugd291bGQgaGF2ZSB0byBkaXNhc3NlbWJsZSB0aGUg c3RydWN0dXJlIHRvIGdldCB0aGUgcmVtYWluZGVyIG9mIHRoZSBvbGQgcml2ZXRzIG91dC4gSSBo YXZlIHJlbWFpbmRlciBvZiBhIGZldyByaXZldHMgdGhhdCBkaWRuJ3Qgc2VhdCBwcm9wZXJseSBz dGlsbCBpbiBteSBwbGFuZSBidXQgeW91IHdvdWxkIGhhdmUgdGhvdXNhbmRzIG9mIHRoZW0uCj4+ Cj4+IEFsc28gdGhhdCBlbmdpbmUgZGlkbid0IGhhdmUgdGhhdCBncmVhdCBhIHJlcHV0YXRpb24s IGNhbiB5b3Ugc3RpbGwgZ2V0IHBhcnRzPwo+Pgo+PiBHb29kIGx1Y2suCj4+Cj4+IFJpY2sgTmVp bHNlbgo+PiBSZWRyaXZlIFZXIHBvd2VyZWQgTUtJSUlDCj4+Cj4+IE9uIE1vbiwgSnVuIDMsIDIw MTkgYXQgMTA6NDMgQU0gUmV4IFJvZGVidXNoIDxqcnJvZGVidXNoQGdtYWlsLmNvbT4gd3JvdGU6 Cj4+Cj4+PiAtLT4gS29sYi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiUmV4IFJvZGVidXNoIiA8 anJyb2RlYnVzaEBnbWFpbC5jb20+Cj4+Pgo+Pj4gSW1wb3NzaWJsZSBxdWVzdGlvbiB0byBhbnN3 ZXIganVzdCBiYXNlZCBvbiBwaWN0dXJlcy4gIEkgd291bGQgcmVtb3ZlIHRoZSBhbHVtaW51bSBz dXJmYWNlIG94aWRhdGlvbiBpbiBzZXZlcmFsIHNwb3RzIHRvIGRldGVybWluZSB0aGUgZGVwdGgu ICBJIHdvdWxkIHN1c3BlY3QgdGhhdCB0aGUgYWx1bWludW0gaXMgcHJvYmFibHkgT0suIFlvdSBt aWdodCBhbHNvIGRyaWxsIG91dCBhIG51bWJlciBvZiByaXZldHMgaW4gcmFuZG9tIGxvY2F0aW9u cyB0byBzZWUgaWYgdGhlIGNvcnJvc2lvbiBpcyB0aHJvdWdoIHRoZSByaXZldCBvciBqdXN0IG9u IHRoZSBzdXJmYWNlIG9mIHRoZSBoZWFkIGFuZCBob3cgZGVlcC4gIEkgd291bGQgcHJvYmFibHkg Y29uc2lkZXIgZHJpbGxpbmcgdGhlbSBhbGwgb3V0IGFuZCByZXBsYWNpbmcgd2l0aCBzdGFpbmxl c3Mgc3RlZWwgcml2ZXRzLiAgQSBsb3Qgb2Ygd29yayBidXQgbm90IGEgbG90IG9mIG1vbmV5Lgo+ Pj4KPj4+IEFnYWluLCB0aGVzZSBhcmUgaWRsZSB0aG91Z2h0cyBhbmQgbm90IHJlY29tbWVuZGF0 aW9ucy4gIFdvcnRoIHdoYXQgeW91IHBhaWQgZm9yIHRoZW0uCj4+Pgo+Pj4gUmVhZCB0aGlzIHRv cGljIG9ubGluZSBoZXJlOgo+Pj4KPj4+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3 dG9waWMucGhwP3A9NDg5NDU2IzQ4OTQ1Ngo+Pj4KPj4+ID09PT09PT09PT09Cj4+PiAtTGlzdCIg cmVsPSJub3JlZmVycmVyIiB0YXJnZXQ9Il9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29t L05hdmlnYXRvcj9Lb2xiLUxpc3QKPj4+ID09PT09PT09PT09Cj4+PiBGT1JVTVMgLQo+Pj4gZWZl cnJlciIgdGFyZ2V0PSJfYmxhbmsiPmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQo+Pj4gPT09 PT09PT09PT0KPj4+IFdJS0kgLQo+Pj4gZXJyZXIiIHRhcmdldD0iX2JsYW5rIj5odHRwOi8vd2lr aS5tYXRyb25pY3MuY29tCj4+PiA9PT09PT09PT09PQo+Pj4gYiBTaXRlIC0KPj4+ICAgICAgICAg ICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCj4+PiByZWw9Im5vcmVmZXJyZXIiIHRhcmdldD0i X2JsYW5rIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCj4+PiA9PT09PT09 PT09PQ= ________________________________________________________________________________
Date: Jun 04, 2019
Thank you top all that have responded. I drilled out a rivet as some of you had suggested and would appreciate your opinions . I added a picture of the rivet on the link posted in my initial thread. Below a link to the Rivet picture https://photos.app.goo.gl/N4vr3GxbQyiQScYaA -------- Peter Raleigh, NC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489489#489489 ________________________________________________________________________________
Date: Jun 04, 2019
Looks like good advise from all of the other replies. I too would be concerned about using a Cuyuna engine. (Like.. do I make a cool go-cart out of it, or use it as a boat anchor??). I'm not a Cuyuna fan, but you probably didn't notice. I'm surprised no one has mentioned Alodine. It is a non-electrically applied surface preparation, which treats the aluminum as if it has been anodized, only a thinner surface layer. And I believe your parts would need to be disassembled to do a proper job. One link adds some details. https://www.experimentalaircraft.info/articles/aluminum-corrosion-treatment.php Normally it is applied by dipping the parts, although I have done constant flow over some parts, and believe that was with success. I've used plastic gutters for straight tubing dip tanks.. and with a different job, used 4 PVC 4" drain tile tubes.. one for etch, one for Alodine, and two for water rinse. All in one frame holding them vertical, but each one removable. Worked great. As others have mentioned.. your disassemble efforts could be significant, if you go that route. I agree, but also agree in the removal of any rivet heads that end up inside a structure. Complete disassembly does make that and Alodine application easier.. its just twice as much work as building one initially. I don't know a lot about the early Kolbs.. but I'd have to wonder why SS rivets were not used initially.. unless someone was cutting corners. Best Wishes, Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489494#489494 ________________________________________________________________________________
Date: Jun 04, 2019
Peter, Sometimes guys would dip the steel rivet in heavy oil or paint to protect it from corrosion before pulling. It looks like this was not the case with yours. I would strongly consider drilling out the rivets and replacing with SS. As one other person mentioned; drilling out steel rivets is much easier than drilling out SS rivets and if you keep a sharp bit it should go fairly fast. Also, unless your're built like Popeye invest in a pneumatic puller from Harbor Freight before installing the SS rivets. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489496#489496 ________________________________________________________________________________
Date: Jun 04, 2019
Rex et al, Really, REALLY Bad ideas being tossed about any containment by the thought process. The rivets are steel, NOT stainless steel. They are used because Homer was trying to make a legal ultralight. He had plenty of strength in the thin wall aluminum tubing. He needed an attachment that was just strong enough to pull the rivet to the recommended dimension and strength without having it distort the aluminum structure. Stainless steel rivets are not some sort of cure all. Even my Firestar, with its .028 wall thickness tubing uses plain steel rivets for the same exact reason. Treat the corrosion per your favorite product and application method then make all attachments per the original builders manual. Barring that, replace with what you found. Rick Girard On Tue, Jun 4, 2019 at 12:21 PM Rex Rodebush wrote: > > Peter, > > Sometimes guys would dip the steel rivet in heavy oil or paint to protect > it from corrosion before pulling. It looks like this was not the case wi th > yours. I would strongly consider drilling out the rivets and replacing > with SS. As one other person mentioned; drilling out steel rivets is muc h > easier than drilling out SS rivets and if you keep a sharp bit it should go > fairly fast. Also, unless your're built like Popeye invest in a pneumati c > puller from Harbor Freight before installing the SS rivets. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=489496#489496 > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Jun 04, 2019
Subject: video
https://vimeo.com/339877641 password owyheeflyer Flying times have been few and far between this year. In fact it got to be so normal that having crappy weather was normal and, I missed what ever windows of opportunity that might have been viable. It appears that things are looking up a bit, so here you go. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jun 04, 2019
Rick, I don't agree with your thinking at all. If steel rivets are badly corroded I don't think they should be used. If you replace them with steel rivets they are just going to corrode again. I don't see any problem with replacing them with SS rivets. Just because steel was used initially is no reason not to improve them if you can. I am not aware that the clamping force of steel rivets is any weaker than SS rivets. If you have that data please let me know. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489499#489499 ________________________________________________________________________________
Date: Jun 04, 2019
I like alodine; it really is liquid magic for protecting aluminum. But it really is a pain to use, since the aluminum must be squeaky clean with absolutely no oils or foreign matter of any sort for the etch to work, and then for the alodine to work. And its hazards shouldn't be ignored. https://www.chemical-supermarket.com/files/Henkel%20Alodine%20Conversion%20Coatings/1201%20Alodine,%20MSDS.pdf You need a well ventilated area and good skin/eye protection, but what isn't often mentioned is that exposure to sunlight quickly kills its effectiveness. If you do decide to use it, try to find the powder form (like instant Tang; you mix it yourself) instead of the liquid. Much cheaper to ship, and more importantly *much* cheaper to purchase, if you can find it in small enough quantities. Most vendors want to sell you many pounds at a time, when around a half pound of the powder would last through many projects (if the mix is kept away from sunlight and in a light-proof container when not in use). If it were mine, I'd do what I did to the old Twinstar I basket case I restored: Clean it up well with a good degreaser & scrubber (stainless if you use a metal brush; Scotchbrite pads work fine too), then paint with rattle-can self-etching primer. This: https://www.napaonline.com/en/p/MSR7220 is easy to find and very effective, but there are lots of other products that work just as well. If you ask, they may tell you the next on-sale dates, so you can save a few bucks a can. Charlie On 6/4/2019 11:28 AM, Jerry-TS-MkII wrote: > > Looks like good advise from all of the other replies. I too would be concerned about using a Cuyuna engine. (Like.. do I make a cool go-cart out of it, or use it as a boat anchor??). I'm not a Cuyuna fan, but you probably didn't notice. > > I'm surprised no one has mentioned Alodine. It is a non-electrically applied surface preparation, which treats the aluminum as if it has been anodized, only a thinner surface layer. And I believe your parts would need to be disassembled to do a proper job. One link adds some details. https://www.experimentalaircraft.info/articles/aluminum-corrosion-treatment.php Normally it is applied by dipping the parts, although I have done constant flow over some parts, and believe that was with success. I've used plastic gutters for straight tubing dip tanks.. and with a different job, used 4 PVC 4" drain tile tubes.. one for etch, one for Alodine, and two for water rinse. All in one frame holding them vertical, but each one removable. Worked great. > > As others have mentioned.. your disassemble efforts could be significant, if you go that route. I agree, but also agree in the removal of any rivet heads that end up inside a structure. Complete disassembly does make that and Alodine application easier.. its just twice as much work as building one initially. > > I don't know a lot about the early Kolbs.. but I'd have to wonder why SS rivets were not used initially.. unless someone was cutting corners. > > Best Wishes, Jerry > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 04, 2019
On 6/4/2019 3:33 PM, Rex Rodebush wrote: > > Rick, > > I don't agree with your thinking at all. If steel rivets are badly corroded I don't think they should be used. If you replace them with steel rivets they are just going to corrode again. I don't see any problem with replacing them with SS rivets. Just because steel was used initially is no reason not to improve them if you can. I am not aware that the clamping force of steel rivets is any weaker than SS rivets. If you have that data please let me know. > You might want to reconsider. There are dozens ( likely hundreds) of different types of pulled rivets. Various alloys of steel, various alloys of stainless, various alloys of aluminum, various materials and alloys used for the mandrel, various *types* of pulled rivets in each material type (some capture the mandrel, which plays a role in shear strength, while some do not, for example), various head sizes, various head shapes, then there are true structural pulled rivets ... Those are just off the top of my head (pardon the pun). When you change a structural fastener, you need to at least have confidence that the replacement meets or exceeds the strength of the original, and doesn't 'violate' some other requirement that the a/c designer might not have detailed for you. I think that if you do some research, you'll find that many stainless pulled rivets are significantly weaker than the same size/design in steel. That plane was apparently stored in a really hostile environment. If the replacement steel rivets were dipped in a bit of rust inhibiting primer before being pulled, they'd likely outlast the rest of the plane if it's kept in a sensible environment. The Twinstar I I restored is about 35 years old, and while there was some surface rust on the steel rivets, they were in great shape, as was the aluminum, with only one exceptional point on one wing. Likely had a mouse or rat's nest at that spot while it was in storage. I'm not recommending this to the OP; I can't see his project or choose his risk tolerance. But if I had confidence that none of the rivets looked any worse than the one pictured, I'd be tempted to clean it up, paint with self-etch primer, and then spray everything down with a good penetrating corrosion inhibitor. The certified world has some corrosion inhibiting products that will seep into every crack, crevice, or opening they touch. Not saying to use this one; just the 1st product name I remembered. I think it was what we used on the old '46 Luscombe 8A that taught me to fly. http://www.corrosionx.com/corrosionx-aviation.html Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 05, 2019
Subject: new video
https://vimeo.com/340501352 password owyheeflyer I flew this yesterday and found that while I was so close to the ground, my camera did not show the sky and I spent all the time trying to peer up at the top of the screen. I tossed that one away, and made a new holder for my camera so that I could get a bit more sky in the screen. I am happy with this one. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Re: new video
Date: Jun 05, 2019
Great video. I found myself leaning over in my chair on some of those turns! I don't know if I'd trust my old Rotax 377 enough to follow that route or not. My fun factor goes way down when I don't have a safe landing spot in gliding range. At 60 mph, I'm guessing you may have had just enough inertia to pop up out of the canyon and land on the rim if things got quiet all of a sudden. How do you mount your camera to avoid vibration? Whenever I've mounted mine to the airframe, the video comes out like looking through Jell-O. Martin B. -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489516#489516 ________________________________________________________________________________
Date: Jun 06, 2019
Wow, great low level Larry. I just love it. Some might consider it dangerous but what the heck. You gotta have some fun now and then at my age. It =99s where good preflights and maintenance payoff. Thanks for the ride along ! George H. Original Firestar, Hirth 2702 Mesick, Michigan gdhelton(at)gmail.com Sent from my iPhone > On Jun 5, 2019, at 5:25 PM, Larry Cottrell wrote : > > https://vimeo.com/340501352 password owyheeflyer > > I flew this yesterday and found that while I was so close to the ground, m y camera did not show the sky and I spent all the time trying to peer up at t he top of the screen. I tossed that one away, and made a new holder for my c amera so that I could get a bit more sky in the screen. I am happy with this one. > Larry > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Date: Jun 06, 2019
Thanks! On Thu, Jun 6, 2019 at 4:33 AM George Helton wrote: > Wow, great low level Larry. I just love it. Some might consider it > dangerous but what the heck. You gotta have some fun now and then at my > age. It=99s where good preflights and maintenance payoff. Thanks fo r the ride > along! > George H. > Original Firestar, Hirth 2702 > Mesick, Michigan > gdhelton(at)gmail.com > > Sent from my iPhone > > On Jun 5, 2019, at 5:25 PM, Larry Cottrell > wrote: > > https://vimeo.com/340501352 > > password owyheeflyer > > I flew this yesterday and found that while I was so close to the ground, > my camera did not show the sky and I spent all the time trying to peer up > at the top of the screen. I tossed that one away, and made a new holder f or > my camera so that I could get a bit more sky in the screen. I am happy wi th > this one. > Larry > > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jun 06, 2019
Martin, I use a Virb elite ( out of production now.) with the cradle mount and I use the pitot tube I think from Aircraft Spruce. It is just a flat piece of alum bent to give the right angle to the camera. I added a bit of shock rubber to keep it from flexing. Mounted on the nose cone is the only place on my plane that will give me a reasonable vibration free spot to put it. I personally prefer to get the full view in front of me, and if I want selfies I use the wing secure point to give a different view. Larry On Wed, Jun 5, 2019 at 9:51 PM wakataka wrote: > > Great video. I found myself leaning over in my chair on some of those > turns! > > I don't know if I'd trust my old Rotax 377 enough to follow that route or > not. My fun factor goes way down when I don't have a safe landing spot in > gliding range. At 60 mph, I'm guessing you may have had just enough > inertia to pop up out of the canyon and land on the rim if things got quiet > all of a sudden. > > How do you mount your camera to avoid vibration? Whenever I've mounted > mine to the airframe, the video comes out like looking through Jell-O. > > Martin B. > > -------- > There is something fascinating about science. One gets such wholesale > returns of conjecture out of such a trifling investment of fact. > > Mark Twain > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=489516#489516 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jun 06, 2019
SGkgTGFycnksDQoNCknigJltIGdsYWQgdGhlIHdlYXRoZXIgaW1wcm92ZWQgYW5kIHlvdeKAmXJl IGluIHRoZSBhaXIgYWdhaW4uIEkgcmVhbGx5IG1pc3NlZCBnZXR0aW5nIHRoZXNlIHZpZGVvcy4g WW91IGRvIHN1Y2ggYSBncmVhdCBqb2IgIG1ha2luZyAmIHNoYXJpbmcgdGhlbS4gV2VsbCBkb25l ISDwn5GNDQoNClRoYW5rcywNCg0KS3VydA0KDQpNYXJrIElJSSBjbGFzc2ljDQoNClNlbnQgZnJv bSBteSBpUGhvbmUNCg0KT24gSnVuIDUsIDIwMTksIGF0IDE1OjMxLCBMYXJyeSBDb3R0cmVsbCA8 bGNvdHRyZWxsMTAyMEBnbWFpbC5jb208bWFpbHRvOmxjb3R0cmVsbDEwMjBAZ21haWwuY29tPj4g d3JvdGU6DQoNCmh0dHBzOi8vdmltZW8uY29tLzM0MDUwMTM1MjxodHRwczovL2NsaWNrLmVtYWls LnZpbWVvLmNvbS8/cXM9MGNkODdkYmE0ZmE2NDBiMmYyODRhYzhmYmNkMzQ4YzU4OTYwNjg2MGU0 OWU0NTg4NmFlMWJkMmM2MzJmYjkwOTMwNjI0MDcwYmUxMzI0NzgwMjAwNWQyOGQwY2YyMzJlM2Ey YWY1ZmFhY2MwNGMzMzRmMTMwMTUxMjVkZTFlYWM+ICAgIHBhc3N3b3JkIG93eWhlZWZseWVyDQoN CkkgZmxldyB0aGlzIHllc3RlcmRheSBhbmQgZm91bmQgdGhhdCB3aGlsZSBJIHdhcyBzbyBjbG9z ZSB0byB0aGUgZ3JvdW5kLCBteSBjYW1lcmEgZGlkIG5vdCBzaG93IHRoZSBza3kgYW5kIEkgc3Bl bnQgYWxsIHRoZSB0aW1lIHRyeWluZyB0byBwZWVyIHVwIGF0IHRoZSB0b3Agb2YgdGhlIHNjcmVl bi4gSSB0b3NzZWQgdGhhdCBvbmUgYXdheSwgYW5kIG1hZGUgYSBuZXcgaG9sZGVyIGZvciBteSBj YW1lcmEgc28gdGhhdCBJIGNvdWxkIGdldCBhIGJpdCBtb3JlIHNreSBpbiB0aGUgc2NyZWVuLiBJ IGFtIGhhcHB5IHdpdGggdGhpcyBvbmUuDQpMYXJyeQ0KDQotLQ0KVGhlIG9sZGVyIEkgZ2V0LCB0 aGUgbGVzcyB0b2xlcmFudCBJIGFtIG9mIHRob3NlIHdobyBhcmUgaW50b2xlcmFudCBvZiBvdGhl cnMuDQoNCklmIHlvdSBmb3J3YXJkIHRoaXMgZW1haWwsIG9yIGFueSBwYXJ0IG9mIGl0LCBwbGVh c2UgcmVtb3ZlIG15IGVtYWlsIGFkZHJlc3MgYmVmb3JlIHNlbmRpbmcuDQo ________________________________________________________________________________
Date: Jun 06, 2019
Thanks! Larry On Thu, Jun 6, 2019 at 10:10 AM K I wrote: > Hi Larry, > > I=99m glad the weather improved and you=99re in the air again . I really missed > getting these videos. You do such a great job making & sharing them. Wel l > done! =F0=9F=91=8D > > Thanks, > > Kurt > > Mark III classic > > Sent from my iPhone > > On Jun 5, 2019, at 15:31, Larry Cottrell wrote: > > https://vimeo.com/340501352 > > password owyheeflyer > > I flew this yesterday and found that while I was so close to the ground, > my camera did not show the sky and I spent all the time trying to peer up > at the top of the screen. I tossed that one away, and made a new holder f or > my camera so that I could get a bit more sky in the screen. I am happy wi th > this one. > Larry > > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jun 06, 2019
Larry... It's one thing to get the aviation fix from your great videos.. but I've also been introduced to a musician which I didn't know before. I may have to pipe that stuff into the work shop as inspiration! Thank you for BOTH!! Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489532#489532 ________________________________________________________________________________
Date: Jun 06, 2019
Try Govi, Johannes Lindstead, as well as Jessie Cook. Thanks Larry On Thu, Jun 6, 2019 at 12:24 PM Jerry-TS-MkII <12flybellaire(at)gmail.com> wrote: > > Larry... > It's one thing to get the aviation fix from your great videos.. but I've > also been introduced to a musician which I didn't know before. I may have > to pipe that stuff into the work shop as inspiration! > > Thank you for BOTH!! > Jerry > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=489532#489532 > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jun 09, 2019
Subject: Sport Pilot Tailwheel Instructors
Hello all - I=99m getting back into aviation after ~ a five year brea k and have recently purchased a Kolb Mark III with a Rotax 912UL.. I live in Bend Oregon and am looking for some tailwheel instruction. Training in my plane would be great however it only has brakes on the PIC side. I can travel if need be and my preference is to train in a small, light, and similar airplane. Any contact information or suggested sources would be greatly appreciated. Thank you for your time and consideration. Mike 541-480-7892 ________________________________________________________________________________
Subject: FS1 Angle of incidence in straight & level flight
Date: Jun 10, 2019
I want to install a fuel level sight tube on a FS1. Anyone know what the angle of incidence for the wing in straight & level flight? The angle of the fuselage would suffice as well. or even the engine line. My mechanical float sender is no longer reliable & I don't want to pay the price of a new one. -Richard Swiderski Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489600#489600 ________________________________________________________________________________
Date: Jun 10, 2019
Subject: Re: FS1 Angle of incidence in straight & level flight
When doing the weight and balance calculations the angle of the wing is specified. I would expect this angle would be for a cruise attitude, and would be a good reference. My Firestar 2 plans show a 9 deg. angle using the bottom of the wing. Just a guess. John Fitt Sent from my iPhone > On Jun 10, 2019, at 3:49 PM, slingshot003 wrote: > > > I want to install a fuel level sight tube on a FS1. Anyone know what the angle of incidence for the wing in straight & level flight? The angle of the fuselage would suffice as well. or even the engine line. My mechanical float sender is no longer reliable & I don't want to pay the price of a new one. -Richard Swiderski > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=489600#489600 > > > > > > > > > ________________________________________________________________________________
Date: Jun 11, 2019
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Subject: Re: Sport Pilot Tailwheel Instructors
Hi Mike - Check with Joe Sheldon at Cline Falls Airpark in Redmond. He's not an instr uctor, but he does lots of work on ultralight-type and light sport aircraft and probably knows who might be giving instruction in the Bend/Prineville/ Redmond area. His contact info is: joe(at)lsaaviationsrvc.com=C2- 541.892.76 37=C2- www.lsaaviationsrvc.com If you can get someone to ferry your Kolb down to Cave Junction (Illinois V alley Airport) one of the best instructors around is Wolf Emonds. He has a full-time flight training school. What's even better - he has a lodge pract ically next to the airport that he lets students stay in. Contact him @ cap taindrakesfaa(at)gmail.com=C2-=C2- 541.415.0600=C2-=C2- captaindrakesf aa.com=C2-=C2- If you decide to go this route, you might want to contac t Dave Richards at Eagle's Nest Airport (OR65) in Eagle Creek, Oregon who d oes a lot of ferrying of Light Sport aircraft and definitely knows how to f ly taildraggers. He's usually eager to ferry.=C2- Reach him @ 503.407.853 1 If you want taildragger instruction in a Cub, contact Steve Huggins, who is an instructor and who also lives @ Eagle's Nest. Reach him @ drhuggins1@ao l.com or 503.939.3375.=C2- He might be willing to train you in your own K olb. And...if you're not averse to doing a little traveling, join us at Sandy Ri ver Airport (O36) on Saturday, July 27 for our annual ultralight/light spor t fly-in and barbeque. We usually have anywhere from 15-20 ultralight-type LSAs fly in, and we have almost a dozen which hangar at our field. Bring th e family! Hope this is helpful - Arty TrostSandy River AirportTalon Typhoon "I refuse to tip toe through life just to arrive safely at death." wrote: Hello all - I=99m getting back into aviation after ~ a five year brea k and have recently purchased a Kolb Mark III with a Rotax 912UL.. I live in Bend Oregon and am looking for some tailwheel instruction. Traini ng in my plane would be great however it only has brakes on the PIC side. I can travel if need be and my preference is to train in a small, light, an d similar airplane. Any contact information or suggested sources would be greatly appreciated. Thank you for your time and consideration. Mike 541-480-7892 ________________________________________________________________________________
Subject: Rotax 503 Puller plate 876 080 or 876-081
Date: Jun 23, 2019
I am looking to buy a used or borrow a Puller plate 876 080 or 876-081. I would also need the Mag Puller 42 x1.5 #876 065. I live in Raleigh NC Thank you Peter -------- Peter Raleigh, NC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489780#489780 ________________________________________________________________________________
Subject: Elevator and joystick throw
Date: Jun 28, 2019
Hi all, I've just finished building my Firestar II tandem and in the process of test flying. One thing that the person test-flying initially has noted is that the elevator authority feels a little limited, and 'spongy' feel at either extreme. Flying here in W Australia can be very turbulent and windy much of the time and he feels an improvement in the elevator authority would be useful. The joystick has a cable pivot point separation of 3" and the elevator control horn a cable pivot separation of 4". So we are thinking of increasing the joystick pivot separation to around 4" also. However, this would mean having to raise the front of the seat about 1/2". Has anyone found a similar problem and if so how did you address it? Thanks Steve -------- Gator Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489907#489907 ________________________________________________________________________________
Date: Jun 29, 2019
Gator/Kolbers: I haven't heard of this problem before. Usually elevator function is right on set up the way the plans and instructions indicate. Elevator cables need to be tight. A tiny bit of slack in the elevator cables will produce a lot of slop in fore and aft movement of the control stick. Geometry should be right on unless someone has changed it from the stock set up. Get someone to lock the elevator in place. Snug the elevator control cables until there is no play, fore and aft, in the control stick. You will be surprised how much this will improve elevator authority. That's what I have discovered. That's what I did to correct the problem. We recently made this correct to Larry Cottrell's FSII. I flew it loose, corrected, and flew it tight. Flew like a new airplane after that. John h MKIII Baldwinsville, NY -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of smgates Sent: Saturday, June 29, 2019 2:13 AM Subject: Kolb-List: Elevator and joystick throw Hi all, I've just finished building my Firestar II tandem and in the process of test flying. One thing that the person test-flying initially has noted is that the elevator authority feels a little limited, and 'spongy' feel at either extreme. Flying here in W Australia can be very turbulent and windy much of the time and he feels an improvement in the elevator authority would be useful. The joystick has a cable pivot point separation of 3" and the elevator control horn a cable pivot separation of 4". So we are thinking of increasing the joystick pivot separation to around 4" also. However, this would mean having to raise the front of the seat about 1/2". Has anyone found a similar problem and if so how did you address it? Thanks Steve -------- Gator Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489907#489907 ________________________________________________________________________________
Subject: Re: Elevator and joystick throw
Date: Jun 29, 2019
I would also help to gap seal the elevator to the stabilizer. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489911#489911 ________________________________________________________________________________
Date: Jun 29, 2019
I built a very early Firestar II. I was kinda' disappointed that control cables NOW rubbed on the bottom of the fuselage tube at the forward end. In the Kolb Newsletter of July 1, 1995, Kolb suggested the addition of a control cable fairlead made from Lexan sheet to keep control cables from rubbing on the aluminum tube. I got fed up and added a second row of 4 control cable pulleys to one of the fuselage cross tubes to raise the cables and to enable me to properly tension the elevator cables without fear of sawing either aluminum or Lexan. Dunno' if my mod was necessary or even advisable, but it worked for me. Things may have changed since then. Jerry King -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489915#489915 ________________________________________________________________________________
Date: Jun 29, 2019
> > Before I started messing with cable locations I would put Vortex > generators underneath the horizontal stabilizer in front of the hinge area > and see if that increase your Authority I did that to my Mark 3 and it made > a significant difference. The v gs that I bought were stolspeed from John Gilpin in Australia. Try https://stolspeed.com/installing-vortex-generators Boyd Young Mkiii Utah ________________________________________________________________________________
Subject: Re: Elevator and joystick throwElevator and joystick throw
Date: Jun 30, 2019
Hi all, Some useful and interesting suggestions - I'll take them on board. Many thanks Steve ________________________________________________________________________________
Date: Jun 30, 2019
Subject: Re: Kolb-List Digest: 4 Msgs - 06/29/19
The joystick has a cable pivot point separation of 3" and the elevator control horn a cable pivot separation of 4". So we are thinking of increasing the joystick pivot separation to around 4" Just had another thought. If you give the eleveator more throw, it may work like a spoiler, stall, and make for even less authority than you have now. Make sure the elevator horn is attached solid with no flex or movement. The plans should have listed the maximum movement up and down of the trailing edge of the elevator. Boyd Young Mkiii > > ________________________________________________________________________________
Date: Jul 01, 2019
I did the same as Boyd (v.g.'s on my elevator) and also had much better control when landing. Seemed much more stable and responsive. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489951#489951 ________________________________________________________________________________
Date: Jul 01, 2019
> > If you buy the stole Speed The Vortex generators read the instructions. > Without looking I believe they go 4 inches in front of the elevator hinge > on the bottom of the horizontal stabilizer, and I believe you use the 30 mm > spacing. Boyd Young ________________________________________________________________________________
Date: Jul 01, 2019
And most importantly, don't get caught=2E ;-) =81=A3Sent from BlueMail =8B On Jul 1, 2019, 1:55 PM, at 1:55 PM, B Young wrote: >> >> If you buy the stole Speed The Vortex generators r ead the >instructions=2E >> Without looking I believe they go 4 inches in front of the elevator >hinge >> on the bottom of the horizontal stabilizer, and I believe you use the >30 mm >> spacing=2E > > >Boyd Young ________________________________________________________________________________
Subject: Wanted to buy - Open or enclosed trailer for Kolb FSII
Date: Jul 14, 2019
Anyone have an open or enclosed trailer for a Kolb FSII that they would like to sell. Peter -------- Peter Raleigh, NC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490283#490283 ________________________________________________________________________________
Subject: Kolb Ultrastar center and balance
Date: Jul 16, 2019
Hello! I am close to finish building my Kolb Ultrastar. I wanted to check balance point of the plane but have doubts that I understand the manual correctly. In the manual it is written: The "Ultrastar" should balance [with the pilot in the seat] at the 25% to 30% chord position. This translates to the balance point being located in the range from 16" to 19" from the leading edge of the wing. The centerline of the 1" square tube that the wings attach to is 18" from the leading edge. To check the balance hang the Ultrastar from a point within this 3" range, and with the pilot sitting in the seat the plane should balance. The fuselage tube will be at 10 to 12 degree angle [tail lower than front] when the airplane is considered balanced.
January 19, 2019 - July 16, 2019
Kolb-Archive.digest.vol-pg
