Kolb-Archive.digest.vol-ph
July 16, 2019 - February 07, 2020
      In a other books about planes it is said that plane should balance in its flight
      position. So I would expect to see the Ultrastar fuselage tube to be horizontal
      when I hang it by the centerline of the 1" square tube.
      Please comment if there is no mistake in the manual.
      Did I understood the manual correctly and when the plane that is hanged will be
      in the position like in the picture below:
      https://photos.app.goo.gl/rJ4Evyaz5GMyrBma9
      Or should it be like that:
      https://photos.app.goo.gl/tS7Ca1pU9DQ482Dt8
      http://forums.matronics.com/viewtopic.php?p=490336#490336
      http://forums.matronics.com//files/image_590.png
      http://forums.matronics.com//files/1563303317024_image_503.png
Subject: Re: Kolb Ultrastar center and balance
Date: Jul 16, 2019
When I built my Ultrastar I followed the directions in the manual. I had to add about 12 lbs to the front to get the tube to its 10 degree angle. As I flew the plane I removed 5 lbs, than the rest of the 12 lbs. It flew great both ways. Dan -----Original Message----- From: Viktors.Zarskis Sent: Tuesday, July 16, 2019 3:02 PM Subject: Kolb-List: Kolb Ultrastar center and balance Hello! I am close to finish building my Kolb Ultrastar. I wanted to check balance point of the plane but have doubts that I understand the manual correctly. In the manual it is written: The "Ultrastar" should balance [with the pilot in the seat] at the 25% to 30% chord position. This translates to the balance point being located in the range from 16" to 19" from the leading edge of the wing. The centerline of the 1" square tube that the wings attach to is 18" from the leading edge. To check the balance hang the Ultrastar from a point within this 3" range, and with the pilot sitting in the seat the plane should balance. The fuselage tube will be at 10 to 12 degree angle [tail lower than front] when the airplane is considered balanced. In a other books about planes it is said that plane should balance in its flight position. So I would expect to see the Ultrastar fuselage tube to be horizontal when I hang it by the centerline of the 1" square tube. Please comment if there is no mistake in the manual. Did I understood the manual correctly and when the plane that is hanged will be in the position like in the picture below: https://photos.app.goo.gl/rJ4Evyaz5GMyrBma9 Or should it be like that: https://photos.app.goo.gl/tS7Ca1pU9DQ482Dt8 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490336#490336 Attachments: http://forums.matronics.com//files/image_590.png http://forums.matronics.com//files/1563303317024_image_503.png ________________________________________________________________________________
Date: Jul 16, 2019
Thank you for fast reply! I was worried that if i need to get the tail leveled in balance i had to add about 25 lbs in front.. At 10deg. angle it balances almost without ballast Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490352#490352 ________________________________________________________________________________
Date: Jul 20, 2019
Subject: video
https://vimeo.com/349243399 password owyheeflyer If you remember Mike Armstrong asked for some help getting started in his Kolb Mark III. He lives in Oregon and I offered to help him since I have the perfect place to do that very thing, and being bored I welcomed the distraction, plus that is what people do especially Kolb people. It was a pleasure to be able to help him out. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 21, 2019
Subject: Re: Kolb-List Digest: 1 Msgs - 07/20/19
boy Larry ... that State airport looks like a "happening spot".. with all that traffic i'm amazed you were able to get a landing slot. .............. ............. Tim b-list(at)matronics.com> wrote: * ======================== =C2- Online Versions of Today's List Digest Archive ======================== Today's complete Kolb-List Digest can also be found in either of the two Web Links listed below.=C2- The .html file includes the Digest format ted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation.=C2- The .txt file includes the plain ASCII versio n of the Kolb-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: =C2- =C2- http://www.matronics.com/digest/digestview.php?Style=82701& View=html&Chapter 19-07-20&Archive=Kolb Text Version: =C2- =C2- http://www.matronics.com/digest/digestview.php?Style=82701& View=txt&Chapter 19-07-20&Archive=Kolb ======================== ======================= =C2- EMail Version of Today's List Digest Archive ======================== ======================= =C2- =C2- =C2- =C2- =C2- ---------------------------------------- ------------------ =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2 - =C2- =C2- Kolb-List Digest Archive =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2 - =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- --- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- Total Messages Posted Sat 07/20/19: 1 =C2- =C2- =C2- =C2- =C2- ---------------------------------------- ------------------ Today's Message Index: ---------------------- =C2- =C2- 1. 06:46 PM - video=C2- (Larry Cottrell) ________________________________=C2- Message 1=C2- ____________________ _________________ From: Larry Cottrell <lcottrell1020(at)gmail.com> Subject: Kolb-List: video https://vimeo.com/349243399 =C2- password=C2- =C2- owyheeflyer If you remember Mike Armstrong asked for some help getting started in his Kolb Mark III. He lives in Oregon and I offered to help him since I have the perfect place to do that very thing, and being bored I welcomed the distraction, plus that is what people do especially Kolb people. It was a pleasure to be able to help him out. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jul 21, 2019
Date: Jul 21, 2019
Subject: new video
https://vimeo.com/349345840 password owyheeflyer Mike is getting more comfortable in his plane, so we expanded our flight range a bit. We flew for 2 hours 22 minutes and we both - my HKS running at full cruise, Mikes 80 hp rotax loafing along, burned 3.2 gph. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 22, 2019
Subject: Re: new video
Enjoyed both of your videos, Larry. It pretty out there this year. Nicely pr oduced as usual. George Helton Firestar, Hirth 2702 Mesick, Michigan gdhelton(at)gmail.com Sent from my iPhone > On Jul 21, 2019, at 9:08 PM, Larry Cottrell wrot e: > > https://vimeo.com/349345840 password owyheeflyer > > Mike is getting more comfortable in his plane, so we expanded our flight r ange a bit. We flew for 2 hours 22 minutes and we both - my HKS running at f ull cruise, Mikes 80 hp rotax loafing along, burned 3.2 gph. > > Larry > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Date: Jul 22, 2019
Thank you George, and Ki. I was beginning to think that I was the only one on the list that was conscious and awake. :-) You guys need to do some flying! Larry On Mon, Jul 22, 2019 at 8:55 AM George Helton wrote: > Enjoyed both of your videos, Larry. It pretty out there this year. Nicely > produced as usual. > George Helton > Firestar, Hirth 2702 > Mesick, Michigan > gdhelton(at)gmail.com > > Sent from my iPhone > > On Jul 21, 2019, at 9:08 PM, Larry Cottrell > wrote: > > https://vimeo.com/349345840 password owyheeflyer > > Mike is getting more comfortable in his plane, so we expanded our flight > range a bit. We flew for 2 hours 22 minutes and we both - my HKS running at > full cruise, Mikes 80 hp rotax loafing along, burned 3.2 gph. > > Larry > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Jul 22, 2019
It=99s been kind of a rough season for flying up here in Michigan. Rai n, winds and nasty weather in general. I=99ve gotten in maybe 7 hrs. s o far. Mostly long cross countries. Sent from my iPhone > On Jul 22, 2019, at 12:12 PM, Larry Cottrell wro te: > > Thank you George, and Ki. I was beginning to think that I was the only one on the list that was conscious and awake. :-) You guys need to do some flyi ng! > Larry > >> On Mon, Jul 22, 2019 at 8:55 AM George Helton wrote: >> Enjoyed both of your videos, Larry. It pretty out there this year. Nicely produced as usual. >> George Helton >> Firestar, Hirth 2702 >> Mesick, Michigan >> gdhelton(at)gmail.com >> >> Sent from my iPhone >> >>> On Jul 21, 2019, at 9:08 PM, Larry Cottrell wr ote: >>> >>> https://vimeo.com/349345840 password owyheeflyer >>> >>> Mike is getting more comfortable in his plane, so we expanded our flight range a bit. We flew for 2 hours 22 minutes and we both - my HKS running at full cruise, Mikes 80 hp rotax loafing along, burned 3.2 gph. >>> >>> Larry >>> -- >>> The older I get, the less tolerant I am of those who are intolerant of o thers. >>> >>> If you forward this email, or any part of it, please remove my email add ress before sending. > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Date: Jul 22, 2019
Its been much the same here, this is the most that I have flown this year. Sigh! Hang in there, gotta get better. Larry On Mon, Jul 22, 2019 at 6:00 PM George Helton wrote: > It=99s been kind of a rough season for flying up here in Michigan. Rain, > winds and nasty weather in general. I=99ve gotten in maybe 7 hrs. s o far. > Mostly long cross countries. > > Sent from my iPhone > > On Jul 22, 2019, at 12:12 PM, Larry Cottrell > wrote: > > Thank you George, and Ki. I was beginning to think that I was the only on e > on the list that was conscious and awake. :-) You guys need to do some > flying! > Larry > > On Mon, Jul 22, 2019 at 8:55 AM George Helton wrote: > >> Enjoyed both of your videos, Larry. It pretty out there this year. Nicel y >> produced as usual. >> George Helton >> Firestar, Hirth 2702 >> Mesick, Michigan >> gdhelton(at)gmail.com >> >> Sent from my iPhone >> >> On Jul 21, 2019, at 9:08 PM, Larry Cottrell >> wrote: >> >> https://vimeo.com/349345840 password owyheeflyer >> >> Mike is getting more comfortable in his plane, so we expanded our flight >> range a bit. We flew for 2 hours 22 minutes and we both - my HKS running at >> full cruise, Mikes 80 hp rotax loafing along, burned 3.2 gph. >> >> Larry >> -- >> *The older I get, the less tolerant I am of those who are intolerant of >> others.* >> >> *If you forward this email, or any part of it, please remove my email >> address before sending.* >> >> > > -- > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > *If you forward this email, or any part of it, please remove my email > address before sending.* > > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: new video
Date: Jul 23, 2019
TXkgODAgaG9yc2UgOTEyIGJ1cm5lZCA0IGdwaCBhdCA1LDAwMCBycG0gYW5kIDgwIHRvIDg1IG1w aCBkZXBlbmRpbmcgb24gaG93IGl0IHdhcyBsb2FkZWQuICBSYW4gb24gODcgb2N0YW5lIGNhciBn YXMuICBQbHVncyBjaGFuZ2VkIGV2ZXJ5IDIwMCBob3Vycy4gIE15IDEwMCBob3JzZSA5MTIgYnVy bmVkIDUgZ3BoIGF0IDUsMDAwIHJwbSBhbmQgODAgdG8gODUgbXBoIGRlcGVuZGluZyBvbiBob3cg aXQgd2FzIGxvYWRlZC4gIFJlcXVpcmUgYXQgbGVhc3QgOTEgb2N0YW5lIGZ1ZWwuICBQbHVncyBj aGFuZ2VkIGV2ZXJ5IDEwMCBob3Vycy4NCg0KSGFyZCB0byBiZWF0IHRoZSA4MCBob3JzZSA5MTIu ICBJIGZlZWwgaXQgaXMgdGhlIGJlc3QgYWxsIGFyb3VuZCBlbmdpbmUgZm9yIGEgTUtJSUkuICBZ ZXMsIHRoZSAxMDAgaG9yc2Ugd2FzIGFuIGFzcyBraWNrZXIgYW5kIGEgYml0IG1vcmUgZnVuIHRv IGhvcnNlIGFyb3VuZCB3aXRoLiAgQWxzbyBoYWQgdGhhdCBleHRyYSBiaXQgb2YgcG93ZXIgdG8g Z2V0IHRoZSBqb2IgZG9uZSB3aGVuIHJlYWxseSBoZWF2eSBhbmQgYXQgaGlnaGVyIGFsdGl0dWRl cy4NCg0KSeKAmW0gYWJvdXQgNSwyMDAgbWlsZXMgaW50byB0aGUgR3JlYXQgTG9vcCBub3cuICBX ZWF0aGVyZWQgaW4gYXQgU3QgSm9zZXBoLCBNSS4gIFRyaWVkIHRvIGZpbmQgUmljayBOaWVsc2Vu 4oCZcyBwaG9uZSBudW1iZXIsIGJ1dCBzdGlsbCBkaWdnaW5nLiAgSGUgaGFzIGEgbGFrZSBob3Vz ZSBhcm91bmQgaGVyZSBzb21ld2hlcmUuICBBbm90aGVyIDEsMjAwIG9yIHNvIG1pbGVzIGJhY2sg dG8gRGVtb3BvbGlzLCBBTCwgd2hlcmUgSSBzdGFydGVkIGNydWlzZSAxNSBBcHJpbCAyMDE5LiAg NjAgbWlsZXMgb2Ygb3BlbiB3YXRlciB0byBjcm9zcyB0byBDaGljYWdvLCB0aGVuIGJhY2sgaW50 byB0aGUgcml2ZXIgc3lzdGVtIGFuZCBob21lLiAgSG9wZSB5b3UgYWxsIHdpbGwgbm90IGdldCB0 byByaWxlZCBhYm91dCBtZSBhZGRpbmcgdGhpcyBsaXR0bGUgbm90ZSB0byBteSBLb2xiIExpc3Qg Y29udHJpYnV0aW9uLg0KDQpKb2huIEgNCm1rSUlJDQpTdCBKb2UsIE1JDQoNCkZyb206IG93bmVy LWtvbGItbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBbbWFpbHRvOm93bmVyLWtvbGItbGlzdC1z ZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24gQmVoYWxmIE9mIExhcnJ5IENvdHRyZWxsDQpTZW50OiBN b25kYXksIEp1bHkgMjIsIDIwMTkgODowNCBQTQ0KVG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29t DQpTdWJqZWN0OiBSZTogS29sYi1MaXN0OiBuZXcgdmlkZW8NCg0KSXRzIGJlZW4gbXVjaCB0aGUg c2FtZSBoZXJlLCB0aGlzIGlzIHRoZSBtb3N0IHRoYXQgSSBoYXZlIGZsb3duIHRoaXMgeWVhci4g U2lnaCEgSGFuZyBpbiB0aGVyZSwgZ290dGEgZ2V0IGJldHRlci4NCkxhcnJ5DQoNCk9uIE1vbiwg SnVsIDIyLCAyMDE5IGF0IDY6MDAgUE0gR2VvcmdlIEhlbHRvbiA8Z2RoZWx0b25AZ21haWwuY29t PG1haWx0bzpnZGhlbHRvbkBnbWFpbC5jb20+PiB3cm90ZToNCkl04oCZcyBiZWVuIGtpbmQgb2Yg YSByb3VnaCBzZWFzb24gZm9yIGZseWluZyB1cCBoZXJlIGluIE1pY2hpZ2FuLiBSYWluLCB3aW5k cyBhbmQgbmFzdHkgd2VhdGhlciBpbiBnZW5lcmFsLiBJ4oCZdmUgZ290dGVuIGluIG1heWJlIDcg aHJzLiBzbyBmYXIuIE1vc3RseSBsb25nIGNyb3NzIGNvdW50cmllcy4NClNlbnQgZnJvbSBteSBp UGhvbmUNCg0KT24gSnVsIDIyLCAyMDE5LCBhdCAxMjoxMiBQTSwgTGFycnkgQ290dHJlbGwgPGxj b3R0cmVsbDEwMjBAZ21haWwuY29tPG1haWx0bzpsY290dHJlbGwxMDIwQGdtYWlsLmNvbT4+IHdy b3RlOg0KVGhhbmsgeW91IEdlb3JnZSwgYW5kIEtpLiBJIHdhcyBiZWdpbm5pbmcgdG8gdGhpbmsg dGhhdCBJIHdhcyB0aGUgb25seSBvbmUgb24gdGhlIGxpc3QgdGhhdCB3YXMgY29uc2Npb3VzIGFu ZCBhd2FrZS4gOi0pIFlvdSBndXlzIG5lZWQgdG8gZG8gc29tZSBmbHlpbmchDQpMYXJyeQ0KDQpP biBNb24sIEp1bCAyMiwgMjAxOSBhdCA4OjU1IEFNIEdlb3JnZSBIZWx0b24gPGdkaGVsdG9uQGdt YWlsLmNvbTxtYWlsdG86Z2RoZWx0b25AZ21haWwuY29tPj4gd3JvdGU6DQpFbmpveWVkIGJvdGgg b2YgeW91ciB2aWRlb3MsIExhcnJ5LiBJdCBwcmV0dHkgb3V0IHRoZXJlIHRoaXMgeWVhci4gTmlj ZWx5IHByb2R1Y2VkIGFzIHVzdWFsLg0KR2VvcmdlIEhlbHRvbg0KRmlyZXN0YXIsIEhpcnRoIDI3 MDINCk1lc2ljaywgTWljaGlnYW4NCmdkaGVsdG9uQGdtYWlsLmNvbTxtYWlsdG86Z2RoZWx0b25A Z21haWwuY29tPg0KU2VudCBmcm9tIG15IGlQaG9uZQ0KDQpPbiBKdWwgMjEsIDIwMTksIGF0IDk6 MDggUE0sIExhcnJ5IENvdHRyZWxsIDxsY290dHJlbGwxMDIwQGdtYWlsLmNvbTxtYWlsdG86bGNv dHRyZWxsMTAyMEBnbWFpbC5jb20+PiB3cm90ZToNCmh0dHBzOi8vdmltZW8uY29tLzM0OTM0NTg0 MCAgICAgcGFzc3dvcmQgICAgb3d5aGVlZmx5ZXINCg0KTWlrZSBpcyBnZXR0aW5nIG1vcmUgY29t Zm9ydGFibGUgaW4gaGlzIHBsYW5lLCBzbyB3ZSBleHBhbmRlZCBvdXIgZmxpZ2h0IHJhbmdlIGEg Yml0LiBXZSBmbGV3IGZvciAyIGhvdXJzIDIyIG1pbnV0ZXMgYW5kIHdlIGJvdGggLSBteSBIS1Mg cnVubmluZyBhdCBmdWxsIGNydWlzZSwgTWlrZXMgODAgaHAgcm90YXggbG9hZmluZyBhbG9uZywg YnVybmVkIDMuMiBncGguDQoNCkxhcnJ5DQotLQ0KVGhlIG9sZGVyIEkgZ2V0LCB0aGUgbGVzcyB0 b2xlcmFudCBJIGFtIG9mIHRob3NlIHdobyBhcmUgaW50b2xlcmFudCBvZiBvdGhlcnMuDQoNCklm IHlvdSBmb3J3YXJkIHRoaXMgZW1haWwsIG9yIGFueSBwYXJ0IG9mIGl0LCBwbGVhc2UgcmVtb3Zl IG15IGVtYWlsIGFkZHJlc3MgYmVmb3JlIHNlbmRpbmcuDQoNCg0KLS0NClRoZSBvbGRlciBJIGdl dCwgdGhlIGxlc3MgdG9sZXJhbnQgSSBhbSBvZiB0aG9zZSB3aG8gYXJlIGludG9sZXJhbnQgb2Yg b3RoZXJzLg0KDQpJZiB5b3UgZm9yd2FyZCB0aGlzIGVtYWlsLCBvciBhbnkgcGFydCBvZiBpdCwg cGxlYXNlIHJlbW92ZSBteSBlbWFpbCBhZGRyZXNzIGJlZm9yZSBzZW5kaW5nLg0KDQoNCi0tDQpU aGUgb2xkZXIgSSBnZXQsIHRoZSBsZXNzIHRvbGVyYW50IEkgYW0gb2YgdGhvc2Ugd2hvIGFyZSBp bnRvbGVyYW50IG9mIG90aGVycy4NCg0KSWYgeW91IGZvcndhcmQgdGhpcyBlbWFpbCwgb3IgYW55 IHBhcnQgb2YgaXQsIHBsZWFzZSByZW1vdmUgbXkgZW1haWwgYWRkcmVzcyBiZWZvcmUgc2VuZGlu Zy4NCg= ________________________________________________________________________________
Date: Jul 23, 2019
Hello John! It sounds like you=99ve already passed me. I=99m in Mesick which is probably only 40 miles east of Ludington. 50 o r so miles from Manistee. Do you need Rick Nielsen=99s phone number? Sent from my iPhone > On Jul 22, 2019, at 8:36 PM, John Hauck wrote: > > My 80 horse 912 burned 4 gph at 5,000 rpm and 80 to 85 mph depending on ho w it was loaded. Ran on 87 octane car gas. Plugs changed every 200 hours. My 100 horse 912 burned 5 gph at 5,000 rpm and 80 to 85 mph depending on ho w it was loaded. Require at least 91 octane fuel. Plugs changed every 100 h ours. > > Hard to beat the 80 horse 912. I feel it is the best all around engine fo r a MKIII. Yes, the 100 horse was an ass kicker and a bit more fun to horse around with. Also had that extra bit of power to get the job done when rea lly heavy and at higher altitudes. > > I=99m about 5,200 miles into the Great Loop now. Weathered in at St Joseph, MI. Tried to find Rick Nielsen=99s phone number, but still d igging. He has a lake house around here somewhere. Another 1,200 or so mil es back to Demopolis, AL, where I started cruise 15 April 2019. 60 miles of open water to cross to Chicago, then back into the river system and home. H ope you all will not get to riled about me adding this little note to my Kol b List contribution. > > John H > mkIII > St Joe, MI > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com] On Behalf Of Larry Cottrell > Sent: Monday, July 22, 2019 8:04 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: new video > > Its been much the same here, this is the most that I have flown this year. Sigh! Hang in there, gotta get better. > Larry > > On Mon, Jul 22, 2019 at 6:00 PM George Helton wrote: > It=99s been kind of a rough season for flying up here in Michigan. R ain, winds and nasty weather in general. I=99ve gotten in maybe 7 hrs. so far. Mostly long cross countries. > > Sent from my iPhone > > On Jul 22, 2019, at 12:12 PM, Larry Cottrell wro te: > > Thank you George, and Ki. I was beginning to think that I was the only one on the list that was conscious and awake. :-) You guys need to do some flyi ng! > Larry > > On Mon, Jul 22, 2019 at 8:55 AM George Helton wrote: > Enjoyed both of your videos, Larry. It pretty out there this year. Nicely p roduced as usual. > George Helton > Firestar, Hirth 2702 > Mesick, Michigan > gdhelton(at)gmail.com > > Sent from my iPhone > > On Jul 21, 2019, at 9:08 PM, Larry Cottrell wrot e: > > https://vimeo.com/349345840 password owyheeflyer > > Mike is getting more comfortable in his plane, so we expanded our flight r ange a bit. We flew for 2 hours 22 minutes and we both - my HKS running at f ull cruise, Mikes 80 hp rotax loafing along, burned 3.2 gph. > > Larry > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Date: Jul 23, 2019
Rick=99s cellphone is 1 (941) 586-8268 Sent from my iPhone > On Jul 22, 2019, at 8:36 PM, John Hauck wrote: > > My 80 horse 912 burned 4 gph at 5,000 rpm and 80 to 85 mph depending on ho w it was loaded. Ran on 87 octane car gas. Plugs changed every 200 hours. My 100 horse 912 burned 5 gph at 5,000 rpm and 80 to 85 mph depending on ho w it was loaded. Require at least 91 octane fuel. Plugs changed every 100 h ours. > > Hard to beat the 80 horse 912. I feel it is the best all around engine fo r a MKIII. Yes, the 100 horse was an ass kicker and a bit more fun to horse around with. Also had that extra bit of power to get the job done when rea lly heavy and at higher altitudes. > > I=99m about 5,200 miles into the Great Loop now. Weathered in at St Joseph, MI. Tried to find Rick Nielsen=99s phone number, but still d igging. He has a lake house around here somewhere. Another 1,200 or so mil es back to Demopolis, AL, where I started cruise 15 April 2019. 60 miles of open water to cross to Chicago, then back into the river system and home. H ope you all will not get to riled about me adding this little note to my Kol b List contribution. > > John H > mkIII > St Joe, MI > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com] On Behalf Of Larry Cottrell > Sent: Monday, July 22, 2019 8:04 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: new video > > Its been much the same here, this is the most that I have flown this year. Sigh! Hang in there, gotta get better. > Larry > > On Mon, Jul 22, 2019 at 6:00 PM George Helton wrote: > It=99s been kind of a rough season for flying up here in Michigan. R ain, winds and nasty weather in general. I=99ve gotten in maybe 7 hrs. so far. Mostly long cross countries. > > Sent from my iPhone > > On Jul 22, 2019, at 12:12 PM, Larry Cottrell wro te: > > Thank you George, and Ki. I was beginning to think that I was the only one on the list that was conscious and awake. :-) You guys need to do some flyi ng! > Larry > > On Mon, Jul 22, 2019 at 8:55 AM George Helton wrote: > Enjoyed both of your videos, Larry. It pretty out there this year. Nicely p roduced as usual. > George Helton > Firestar, Hirth 2702 > Mesick, Michigan > gdhelton(at)gmail.com > > Sent from my iPhone > > On Jul 21, 2019, at 9:08 PM, Larry Cottrell wrot e: > > https://vimeo.com/349345840 password owyheeflyer > > Mike is getting more comfortable in his plane, so we expanded our flight r ange a bit. We flew for 2 hours 22 minutes and we both - my HKS running at f ull cruise, Mikes 80 hp rotax loafing along, burned 3.2 gph. > > Larry > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Subject: new video
Date: Jul 23, 2019
RG9nIGdvbmUgaXQuICBJIHdhcyBpbiBMdWRpbmd0b24gNCBkYXlzIHdhaXRpbmcgd2VhdGhlci4g IFNlY29uZCBkYXkgYXQgU3QgSm9lLiAgTWF5IGdldCBvdXQgb2YgaGVyZSB0b2RheSwgZm9yIHN1 cmUgdG9tb3Jyb3cuICBXZWxsLCBtYXliZSB0b21vcnJvdy4gIE5vdGhpbmcgaXMgZm9yIHN1cmUg b24gTGFrZSBNaWNoaWdhbi4NCg0KVGhhbmtzIGZvciB0aGUgY29tZSBhbmQgUmlja+KAmXMgcGhv bmUgbnVtYmVyLg0KDQpqb2huDQoNCkZyb206IG93bmVyLWtvbGItbGlzdC1zZXJ2ZXJAbWF0cm9u aWNzLmNvbSBbbWFpbHRvOm93bmVyLWtvbGItbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24g QmVoYWxmIE9mIEdlb3JnZSBIZWx0b24NClNlbnQ6IFR1ZXNkYXksIEp1bHkgMjMsIDIwMTkgNjo0 OCBBTQ0KVG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSZTogS29sYi1MaXN0 OiBuZXcgdmlkZW8NCg0KSGVsbG8gSm9obiEgSXQgc291bmRzIGxpa2UgeW914oCZdmUgYWxyZWFk eSBwYXNzZWQgbWUuDQpJ4oCZbSBpbiBNZXNpY2sgd2hpY2ggaXMgcHJvYmFibHkgb25seSA0MCBt aWxlcyBlYXN0IG9mIEx1ZGluZ3Rvbi4gNTAgb3Igc28gbWlsZXMgZnJvbSBNYW5pc3RlZS4gRG8g eW91IG5lZWQgUmljayBOaWVsc2Vu4oCZcyBwaG9uZSBudW1iZXI/DQpTZW50IGZyb20gbXkgaVBo b25lDQoNCk9uIEp1bCAyMiwgMjAxOSwgYXQgODozNiBQTSwgSm9obiBIYXVjayA8amhhdWNrMzZA b3V0bG9vay5jb208bWFpbHRvOmpoYXVjazM2QG91dGxvb2suY29tPj4gd3JvdGU6DQpNeSA4MCBo b3JzZSA5MTIgYnVybmVkIDQgZ3BoIGF0IDUsMDAwIHJwbSBhbmQgODAgdG8gODUgbXBoIGRlcGVu ZGluZyBvbiBob3cgaXQgd2FzIGxvYWRlZC4gIFJhbiBvbiA4NyBvY3RhbmUgY2FyIGdhcy4gIFBs dWdzIGNoYW5nZWQgZXZlcnkgMjAwIGhvdXJzLiAgTXkgMTAwIGhvcnNlIDkxMiBidXJuZWQgNSBn cGggYXQgNSwwMDAgcnBtIGFuZCA4MCB0byA4NSBtcGggZGVwZW5kaW5nIG9uIGhvdyBpdCB3YXMg bG9hZGVkLiAgUmVxdWlyZSBhdCBsZWFzdCA5MSBvY3RhbmUgZnVlbC4gIFBsdWdzIGNoYW5nZWQg ZXZlcnkgMTAwIGhvdXJzLg0KDQpIYXJkIHRvIGJlYXQgdGhlIDgwIGhvcnNlIDkxMi4gIEkgZmVl bCBpdCBpcyB0aGUgYmVzdCBhbGwgYXJvdW5kIGVuZ2luZSBmb3IgYSBNS0lJSS4gIFllcywgdGhl IDEwMCBob3JzZSB3YXMgYW4gYXNzIGtpY2tlciBhbmQgYSBiaXQgbW9yZSBmdW4gdG8gaG9yc2Ug YXJvdW5kIHdpdGguICBBbHNvIGhhZCB0aGF0IGV4dHJhIGJpdCBvZiBwb3dlciB0byBnZXQgdGhl IGpvYiBkb25lIHdoZW4gcmVhbGx5IGhlYXZ5IGFuZCBhdCBoaWdoZXIgYWx0aXR1ZGVzLg0KDQpJ 4oCZbSBhYm91dCA1LDIwMCBtaWxlcyBpbnRvIHRoZSBHcmVhdCBMb29wIG5vdy4gIFdlYXRoZXJl ZCBpbiBhdCBTdCBKb3NlcGgsIE1JLiAgVHJpZWQgdG8gZmluZCBSaWNrIE5pZWxzZW7igJlzIHBo b25lIG51bWJlciwgYnV0IHN0aWxsIGRpZ2dpbmcuICBIZSBoYXMgYSBsYWtlIGhvdXNlIGFyb3Vu ZCBoZXJlIHNvbWV3aGVyZS4gIEFub3RoZXIgMSwyMDAgb3Igc28gbWlsZXMgYmFjayB0byBEZW1v cG9saXMsIEFMLCB3aGVyZSBJIHN0YXJ0ZWQgY3J1aXNlIDE1IEFwcmlsIDIwMTkuICA2MCBtaWxl cyBvZiBvcGVuIHdhdGVyIHRvIGNyb3NzIHRvIENoaWNhZ28sIHRoZW4gYmFjayBpbnRvIHRoZSBy aXZlciBzeXN0ZW0gYW5kIGhvbWUuICBIb3BlIHlvdSBhbGwgd2lsbCBub3QgZ2V0IHRvIHJpbGVk IGFib3V0IG1lIGFkZGluZyB0aGlzIGxpdHRsZSBub3RlIHRvIG15IEtvbGIgTGlzdCBjb250cmli dXRpb24uDQoNCkpvaG4gSA0KbWtJSUkNClN0IEpvZSwgTUkNCg0KRnJvbTogb3duZXIta29sYi1s aXN0LXNlcnZlckBtYXRyb25pY3MuY29tPG1haWx0bzpvd25lci1rb2xiLWxpc3Qtc2VydmVyQG1h dHJvbmljcy5jb20+IFttYWlsdG86b3duZXIta29sYi1saXN0LXNlcnZlckBtYXRyb25pY3MuY29t XSBPbiBCZWhhbGYgT2YgTGFycnkgQ290dHJlbGwNClNlbnQ6IE1vbmRheSwgSnVseSAyMiwgMjAx OSA4OjA0IFBNDQpUbzoga29sYi1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOmtvbGItbGlzdEBt YXRyb25pY3MuY29tPg0KU3ViamVjdDogUmU6IEtvbGItTGlzdDogbmV3IHZpZGVvDQoNCkl0cyBi ZWVuIG11Y2ggdGhlIHNhbWUgaGVyZSwgdGhpcyBpcyB0aGUgbW9zdCB0aGF0IEkgaGF2ZSBmbG93 biB0aGlzIHllYXIuIFNpZ2ghIEhhbmcgaW4gdGhlcmUsIGdvdHRhIGdldCBiZXR0ZXIuDQpMYXJy eQ0KDQpPbiBNb24sIEp1bCAyMiwgMjAxOSBhdCA2OjAwIFBNIEdlb3JnZSBIZWx0b24gPGdkaGVs dG9uQGdtYWlsLmNvbTxtYWlsdG86Z2RoZWx0b25AZ21haWwuY29tPj4gd3JvdGU6DQpJdOKAmXMg YmVlbiBraW5kIG9mIGEgcm91Z2ggc2Vhc29uIGZvciBmbHlpbmcgdXAgaGVyZSBpbiBNaWNoaWdh bi4gUmFpbiwgd2luZHMgYW5kIG5hc3R5IHdlYXRoZXIgaW4gZ2VuZXJhbC4gSeKAmXZlIGdvdHRl biBpbiBtYXliZSA3IGhycy4gc28gZmFyLiBNb3N0bHkgbG9uZyBjcm9zcyBjb3VudHJpZXMuDQpT ZW50IGZyb20gbXkgaVBob25lDQoNCk9uIEp1bCAyMiwgMjAxOSwgYXQgMTI6MTIgUE0sIExhcnJ5 IENvdHRyZWxsIDxsY290dHJlbGwxMDIwQGdtYWlsLmNvbTxtYWlsdG86bGNvdHRyZWxsMTAyMEBn bWFpbC5jb20+PiB3cm90ZToNClRoYW5rIHlvdSBHZW9yZ2UsIGFuZCBLaS4gSSB3YXMgYmVnaW5u aW5nIHRvIHRoaW5rIHRoYXQgSSB3YXMgdGhlIG9ubHkgb25lIG9uIHRoZSBsaXN0IHRoYXQgd2Fz IGNvbnNjaW91cyBhbmQgYXdha2UuIDotKSBZb3UgZ3V5cyBuZWVkIHRvIGRvIHNvbWUgZmx5aW5n IQ0KTGFycnkNCg0KT24gTW9uLCBKdWwgMjIsIDIwMTkgYXQgODo1NSBBTSBHZW9yZ2UgSGVsdG9u IDxnZGhlbHRvbkBnbWFpbC5jb208bWFpbHRvOmdkaGVsdG9uQGdtYWlsLmNvbT4+IHdyb3RlOg0K RW5qb3llZCBib3RoIG9mIHlvdXIgdmlkZW9zLCBMYXJyeS4gSXQgcHJldHR5IG91dCB0aGVyZSB0 aGlzIHllYXIuIE5pY2VseSBwcm9kdWNlZCBhcyB1c3VhbC4NCkdlb3JnZSBIZWx0b24NCkZpcmVz dGFyLCBIaXJ0aCAyNzAyDQpNZXNpY2ssIE1pY2hpZ2FuDQpnZGhlbHRvbkBnbWFpbC5jb208bWFp bHRvOmdkaGVsdG9uQGdtYWlsLmNvbT4NClNlbnQgZnJvbSBteSBpUGhvbmUNCg0KT24gSnVsIDIx LCAyMDE5LCBhdCA5OjA4IFBNLCBMYXJyeSBDb3R0cmVsbCA8bGNvdHRyZWxsMTAyMEBnbWFpbC5j b208bWFpbHRvOmxjb3R0cmVsbDEwMjBAZ21haWwuY29tPj4gd3JvdGU6DQpodHRwczovL3ZpbWVv LmNvbS8zNDkzNDU4NDAgICAgIHBhc3N3b3JkICAgIG93eWhlZWZseWVyDQoNCk1pa2UgaXMgZ2V0 dGluZyBtb3JlIGNvbWZvcnRhYmxlIGluIGhpcyBwbGFuZSwgc28gd2UgZXhwYW5kZWQgb3VyIGZs aWdodCByYW5nZSBhIGJpdC4gV2UgZmxldyBmb3IgMiBob3VycyAyMiBtaW51dGVzIGFuZCB3ZSBi b3RoIC0gbXkgSEtTIHJ1bm5pbmcgYXQgZnVsbCBjcnVpc2UsIE1pa2VzIDgwIGhwIHJvdGF4IGxv YWZpbmcgYWxvbmcsIGJ1cm5lZCAzLjIgZ3BoLg0KDQpMYXJyeQ0KLS0NClRoZSBvbGRlciBJIGdl dCwgdGhlIGxlc3MgdG9sZXJhbnQgSSBhbSBvZiB0aG9zZSB3aG8gYXJlIGludG9sZXJhbnQgb2Yg b3RoZXJzLg0KDQpJZiB5b3UgZm9yd2FyZCB0aGlzIGVtYWlsLCBvciBhbnkgcGFydCBvZiBpdCwg cGxlYXNlIHJlbW92ZSBteSBlbWFpbCBhZGRyZXNzIGJlZm9yZSBzZW5kaW5nLg0KDQoNCi0tDQpU aGUgb2xkZXIgSSBnZXQsIHRoZSBsZXNzIHRvbGVyYW50IEkgYW0gb2YgdGhvc2Ugd2hvIGFyZSBp bnRvbGVyYW50IG9mIG90aGVycy4NCg0KSWYgeW91IGZvcndhcmQgdGhpcyBlbWFpbCwgb3IgYW55 IHBhcnQgb2YgaXQsIHBsZWFzZSByZW1vdmUgbXkgZW1haWwgYWRkcmVzcyBiZWZvcmUgc2VuZGlu Zy4NCg0KDQotLQ0KVGhlIG9sZGVyIEkgZ2V0LCB0aGUgbGVzcyB0b2xlcmFudCBJIGFtIG9mIHRo b3NlIHdobyBhcmUgaW50b2xlcmFudCBvZiBvdGhlcnMuDQoNCklmIHlvdSBmb3J3YXJkIHRoaXMg ZW1haWwsIG9yIGFueSBwYXJ0IG9mIGl0LCBwbGVhc2UgcmVtb3ZlIG15IGVtYWlsIGFkZHJlc3Mg YmVmb3JlIHNlbmRpbmcuDQo ________________________________________________________________________________
Subject: new video
Date: Jul 23, 2019
U29ycnkgYWJvdXQgdGhhdCBmb2xrcy4gIFRob3VnaHQgSSB3YXMgZ29pbmcgYmFjayBjb3B5IHRv IEdlb3JnZSBILg0KDQpNeSBiYWQuICA7LSgNCg0KSm9obiBoDQpta0lJSQ0KU3QgSm9lLCBNSQ0K DQpGcm9tOiBvd25lci1rb2xiLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25l ci1rb2xiLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBKb2huIEhhdWNr DQpTZW50OiBUdWVzZGF5LCBKdWx5IDIzLCAyMDE5IDg6MzEgQU0NClRvOiBrb2xiLWxpc3RAbWF0 cm9uaWNzLmNvbQ0KU3ViamVjdDogUkU6IEtvbGItTGlzdDogbmV3IHZpZGVvDQoNCkRvZyBnb25l IGl0LiAgSSB3YXMgaW4gTHVkaW5ndG9uIDQgZGF5cyB3YWl0aW5nIHdlYXRoZXIuICBTZWNvbmQg ZGF5IGF0IFN0IEpvZS4gIE1heSBnZXQgb3V0IG9mIGhlcmUgdG9kYXksIGZvciBzdXJlIHRvbW9y cm93LiAgV2VsbCwgbWF5YmUgdG9tb3Jyb3cuICBOb3RoaW5nIGlzIGZvciBzdXJlIG9uIExha2Ug TWljaGlnYW4uDQoNClRoYW5rcyBmb3IgdGhlIGNvbWUgYW5kIFJpY2vigJlzIHBob25lIG51bWJl ci4NCg0Kam9obg0KDQpGcm9tOiBvd25lci1rb2xiLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20g W21haWx0bzpvd25lci1rb2xiLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBP ZiBHZW9yZ2UgSGVsdG9uDQpTZW50OiBUdWVzZGF5LCBKdWx5IDIzLCAyMDE5IDY6NDggQU0NClRv OiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUmU6IEtvbGItTGlzdDogbmV3IHZp ZGVvDQoNCkhlbGxvIEpvaG4hIEl0IHNvdW5kcyBsaWtlIHlvdeKAmXZlIGFscmVhZHkgcGFzc2Vk IG1lLg0KSeKAmW0gaW4gTWVzaWNrIHdoaWNoIGlzIHByb2JhYmx5IG9ubHkgNDAgbWlsZXMgZWFz dCBvZiBMdWRpbmd0b24uIDUwIG9yIHNvIG1pbGVzIGZyb20gTWFuaXN0ZWUuIERvIHlvdSBuZWVk IFJpY2sgTmllbHNlbuKAmXMgcGhvbmUgbnVtYmVyPw0KU2VudCBmcm9tIG15IGlQaG9uZQ0KDQpP biBKdWwgMjIsIDIwMTksIGF0IDg6MzYgUE0sIEpvaG4gSGF1Y2sgPGpoYXVjazM2QG91dGxvb2su Y29tPG1haWx0bzpqaGF1Y2szNkBvdXRsb29rLmNvbT4+IHdyb3RlOg0KTXkgODAgaG9yc2UgOTEy IGJ1cm5lZCA0IGdwaCBhdCA1LDAwMCBycG0gYW5kIDgwIHRvIDg1IG1waCBkZXBlbmRpbmcgb24g aG93IGl0IHdhcyBsb2FkZWQuICBSYW4gb24gODcgb2N0YW5lIGNhciBnYXMuICBQbHVncyBjaGFu Z2VkIGV2ZXJ5IDIwMCBob3Vycy4gIE15IDEwMCBob3JzZSA5MTIgYnVybmVkIDUgZ3BoIGF0IDUs MDAwIHJwbSBhbmQgODAgdG8gODUgbXBoIGRlcGVuZGluZyBvbiBob3cgaXQgd2FzIGxvYWRlZC4g IFJlcXVpcmUgYXQgbGVhc3QgOTEgb2N0YW5lIGZ1ZWwuICBQbHVncyBjaGFuZ2VkIGV2ZXJ5IDEw MCBob3Vycy4NCg0KSGFyZCB0byBiZWF0IHRoZSA4MCBob3JzZSA5MTIuICBJIGZlZWwgaXQgaXMg dGhlIGJlc3QgYWxsIGFyb3VuZCBlbmdpbmUgZm9yIGEgTUtJSUkuICBZZXMsIHRoZSAxMDAgaG9y c2Ugd2FzIGFuIGFzcyBraWNrZXIgYW5kIGEgYml0IG1vcmUgZnVuIHRvIGhvcnNlIGFyb3VuZCB3 aXRoLiAgQWxzbyBoYWQgdGhhdCBleHRyYSBiaXQgb2YgcG93ZXIgdG8gZ2V0IHRoZSBqb2IgZG9u ZSB3aGVuIHJlYWxseSBoZWF2eSBhbmQgYXQgaGlnaGVyIGFsdGl0dWRlcy4NCg0KSeKAmW0gYWJv dXQgNSwyMDAgbWlsZXMgaW50byB0aGUgR3JlYXQgTG9vcCBub3cuICBXZWF0aGVyZWQgaW4gYXQg U3QgSm9zZXBoLCBNSS4gIFRyaWVkIHRvIGZpbmQgUmljayBOaWVsc2Vu4oCZcyBwaG9uZSBudW1i ZXIsIGJ1dCBzdGlsbCBkaWdnaW5nLiAgSGUgaGFzIGEgbGFrZSBob3VzZSBhcm91bmQgaGVyZSBz b21ld2hlcmUuICBBbm90aGVyIDEsMjAwIG9yIHNvIG1pbGVzIGJhY2sgdG8gRGVtb3BvbGlzLCBB TCwgd2hlcmUgSSBzdGFydGVkIGNydWlzZSAxNSBBcHJpbCAyMDE5LiAgNjAgbWlsZXMgb2Ygb3Bl biB3YXRlciB0byBjcm9zcyB0byBDaGljYWdvLCB0aGVuIGJhY2sgaW50byB0aGUgcml2ZXIgc3lz dGVtIGFuZCBob21lLiAgSG9wZSB5b3UgYWxsIHdpbGwgbm90IGdldCB0byByaWxlZCBhYm91dCBt ZSBhZGRpbmcgdGhpcyBsaXR0bGUgbm90ZSB0byBteSBLb2xiIExpc3QgY29udHJpYnV0aW9uLg0K DQpKb2huIEgNCm1rSUlJDQpTdCBKb2UsIE1JDQoNCkZyb206IG93bmVyLWtvbGItbGlzdC1zZXJ2 ZXJAbWF0cm9uaWNzLmNvbTxtYWlsdG86b3duZXIta29sYi1saXN0LXNlcnZlckBtYXRyb25pY3Mu Y29tPiBbbWFpbHRvOm93bmVyLWtvbGItbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24gQmVo YWxmIE9mIExhcnJ5IENvdHRyZWxsDQpTZW50OiBNb25kYXksIEp1bHkgMjIsIDIwMTkgODowNCBQ TQ0KVG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29tPG1haWx0bzprb2xiLWxpc3RAbWF0cm9uaWNz LmNvbT4NClN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IG5ldyB2aWRlbw0KDQpJdHMgYmVlbiBtdWNo IHRoZSBzYW1lIGhlcmUsIHRoaXMgaXMgdGhlIG1vc3QgdGhhdCBJIGhhdmUgZmxvd24gdGhpcyB5 ZWFyLiBTaWdoISBIYW5nIGluIHRoZXJlLCBnb3R0YSBnZXQgYmV0dGVyLg0KTGFycnkNCg0KT24g TW9uLCBKdWwgMjIsIDIwMTkgYXQgNjowMCBQTSBHZW9yZ2UgSGVsdG9uIDxnZGhlbHRvbkBnbWFp bC5jb208bWFpbHRvOmdkaGVsdG9uQGdtYWlsLmNvbT4+IHdyb3RlOg0KSXTigJlzIGJlZW4ga2lu ZCBvZiBhIHJvdWdoIHNlYXNvbiBmb3IgZmx5aW5nIHVwIGhlcmUgaW4gTWljaGlnYW4uIFJhaW4s IHdpbmRzIGFuZCBuYXN0eSB3ZWF0aGVyIGluIGdlbmVyYWwuIEnigJl2ZSBnb3R0ZW4gaW4gbWF5 YmUgNyBocnMuIHNvIGZhci4gTW9zdGx5IGxvbmcgY3Jvc3MgY291bnRyaWVzLg0KU2VudCBmcm9t IG15IGlQaG9uZQ0KDQpPbiBKdWwgMjIsIDIwMTksIGF0IDEyOjEyIFBNLCBMYXJyeSBDb3R0cmVs bCA8bGNvdHRyZWxsMTAyMEBnbWFpbC5jb208bWFpbHRvOmxjb3R0cmVsbDEwMjBAZ21haWwuY29t Pj4gd3JvdGU6DQpUaGFuayB5b3UgR2VvcmdlLCBhbmQgS2kuIEkgd2FzIGJlZ2lubmluZyB0byB0 aGluayB0aGF0IEkgd2FzIHRoZSBvbmx5IG9uZSBvbiB0aGUgbGlzdCB0aGF0IHdhcyBjb25zY2lv dXMgYW5kIGF3YWtlLiA6LSkgWW91IGd1eXMgbmVlZCB0byBkbyBzb21lIGZseWluZyENCkxhcnJ5 DQoNCk9uIE1vbiwgSnVsIDIyLCAyMDE5IGF0IDg6NTUgQU0gR2VvcmdlIEhlbHRvbiA8Z2RoZWx0 b25AZ21haWwuY29tPG1haWx0bzpnZGhlbHRvbkBnbWFpbC5jb20+PiB3cm90ZToNCkVuam95ZWQg Ym90aCBvZiB5b3VyIHZpZGVvcywgTGFycnkuIEl0IHByZXR0eSBvdXQgdGhlcmUgdGhpcyB5ZWFy LiBOaWNlbHkgcHJvZHVjZWQgYXMgdXN1YWwuDQpHZW9yZ2UgSGVsdG9uDQpGaXJlc3RhciwgSGly dGggMjcwMg0KTWVzaWNrLCBNaWNoaWdhbg0KZ2RoZWx0b25AZ21haWwuY29tPG1haWx0bzpnZGhl bHRvbkBnbWFpbC5jb20+DQpTZW50IGZyb20gbXkgaVBob25lDQoNCk9uIEp1bCAyMSwgMjAxOSwg YXQgOTowOCBQTSwgTGFycnkgQ290dHJlbGwgPGxjb3R0cmVsbDEwMjBAZ21haWwuY29tPG1haWx0 bzpsY290dHJlbGwxMDIwQGdtYWlsLmNvbT4+IHdyb3RlOg0KaHR0cHM6Ly92aW1lby5jb20vMzQ5 MzQ1ODQwICAgICBwYXNzd29yZCAgICBvd3loZWVmbHllcg0KDQpNaWtlIGlzIGdldHRpbmcgbW9y ZSBjb21mb3J0YWJsZSBpbiBoaXMgcGxhbmUsIHNvIHdlIGV4cGFuZGVkIG91ciBmbGlnaHQgcmFu Z2UgYSBiaXQuIFdlIGZsZXcgZm9yIDIgaG91cnMgMjIgbWludXRlcyBhbmQgd2UgYm90aCAtIG15 IEhLUyBydW5uaW5nIGF0IGZ1bGwgY3J1aXNlLCBNaWtlcyA4MCBocCByb3RheCBsb2FmaW5nIGFs b25nLCBidXJuZWQgMy4yIGdwaC4NCg0KTGFycnkNCi0tDQpUaGUgb2xkZXIgSSBnZXQsIHRoZSBs ZXNzIHRvbGVyYW50IEkgYW0gb2YgdGhvc2Ugd2hvIGFyZSBpbnRvbGVyYW50IG9mIG90aGVycy4N Cg0KSWYgeW91IGZvcndhcmQgdGhpcyBlbWFpbCwgb3IgYW55IHBhcnQgb2YgaXQsIHBsZWFzZSBy ZW1vdmUgbXkgZW1haWwgYWRkcmVzcyBiZWZvcmUgc2VuZGluZy4NCg0KDQotLQ0KVGhlIG9sZGVy IEkgZ2V0LCB0aGUgbGVzcyB0b2xlcmFudCBJIGFtIG9mIHRob3NlIHdobyBhcmUgaW50b2xlcmFu dCBvZiBvdGhlcnMuDQoNCklmIHlvdSBmb3J3YXJkIHRoaXMgZW1haWwsIG9yIGFueSBwYXJ0IG9m IGl0LCBwbGVhc2UgcmVtb3ZlIG15IGVtYWlsIGFkZHJlc3MgYmVmb3JlIHNlbmRpbmcuDQoNCg0K LS0NClRoZSBvbGRlciBJIGdldCwgdGhlIGxlc3MgdG9sZXJhbnQgSSBhbSBvZiB0aG9zZSB3aG8g YXJlIGludG9sZXJhbnQgb2Ygb3RoZXJzLg0KDQpJZiB5b3UgZm9yd2FyZCB0aGlzIGVtYWlsLCBv ciBhbnkgcGFydCBvZiBpdCwgcGxlYXNlIHJlbW92ZSBteSBlbWFpbCBhZGRyZXNzIGJlZm9yZSBz ZW5kaW5nLg0K ________________________________________________________________________________
Date: Jul 23, 2019
Darn it! I would have been glad to pick you up. You could have hung out up h ere in the land of misfit toys. Yes , the Great Lakes can be very unpredicta ble. Just like flying, always error on the safe side. Did you get ahold of R ick? Sent from my iPhone > On Jul 22, 2019, at 8:36 PM, John Hauck wrote: > > My 80 horse 912 burned 4 gph at 5,000 rpm and 80 to 85 mph depending on ho w it was loaded. Ran on 87 octane car gas. Plugs changed every 200 hours. My 100 horse 912 burned 5 gph at 5,000 rpm and 80 to 85 mph depending on ho w it was loaded. Require at least 91 octane fuel. Plugs changed every 100 h ours. > > Hard to beat the 80 horse 912. I feel it is the best all around engine fo r a MKIII. Yes, the 100 horse was an ass kicker and a bit more fun to horse around with. Also had that extra bit of power to get the job done when rea lly heavy and at higher altitudes. > > I=99m about 5,200 miles into the Great Loop now. Weathered in at St Joseph, MI. Tried to find Rick Nielsen=99s phone number, but still d igging. He has a lake house around here somewhere. Another 1,200 or so mil es back to Demopolis, AL, where I started cruise 15 April 2019. 60 miles of open water to cross to Chicago, then back into the river system and home. H ope you all will not get to riled about me adding this little note to my Kol b List contribution. > > John H > mkIII > St Joe, MI > > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com] On Behalf Of Larry Cottrell > Sent: Monday, July 22, 2019 8:04 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: new video > > Its been much the same here, this is the most that I have flown this year. Sigh! Hang in there, gotta get better. > Larry > > On Mon, Jul 22, 2019 at 6:00 PM George Helton wrote: > It=99s been kind of a rough season for flying up here in Michigan. R ain, winds and nasty weather in general. I=99ve gotten in maybe 7 hrs. so far. Mostly long cross countries. > > Sent from my iPhone > > On Jul 22, 2019, at 12:12 PM, Larry Cottrell wro te: > > Thank you George, and Ki. I was beginning to think that I was the only one on the list that was conscious and awake. :-) You guys need to do some flyi ng! > Larry > > On Mon, Jul 22, 2019 at 8:55 AM George Helton wrote: > Enjoyed both of your videos, Larry. It pretty out there this year. Nicely p roduced as usual. > George Helton > Firestar, Hirth 2702 > Mesick, Michigan > gdhelton(at)gmail.com > > Sent from my iPhone > > On Jul 21, 2019, at 9:08 PM, Larry Cottrell wrot e: > > https://vimeo.com/349345840 password owyheeflyer > > Mike is getting more comfortable in his plane, so we expanded our flight r ange a bit. We flew for 2 hours 22 minutes and we both - my HKS running at f ull cruise, Mikes 80 hp rotax loafing along, burned 3.2 gph. > > Larry > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. > > > -- > The older I get, the less tolerant I am of those who are intolerant of oth ers. > > If you forward this email, or any part of it, please remove my email addre ss before sending. ________________________________________________________________________________
Subject: Re: Bing 54 jets - cleaning?
Date: Jul 24, 2019
I accidentally dropped a piece of McDonald's Big Mac on the seat, after which a stain remained (I can't remove it with ordinary wet wipes). What products can remove this greasy stain or only dry cleaning will help? Please, advise the best car carpet cleaner (https://cleanhomeguide.com/best-car-carpet-cleaners/) that can remove any stains on the carpet in the car and the seat. Are there any? Or the only way out is to go to dry cleaning? I just would not like to spend so much money on a few stains. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490512#490512 ________________________________________________________________________________
Subject: Re: wing center gap seal
Date: Jul 27, 2019
Hi all, I have one of the first Firestars and that gap doesnt prevent me from flying without it. In fact since it is not part of the wing or fuselage I would not want to depart into my prop. Dont ask me how I know that. I have wondered how others deal with it. -------- Firestar 1 1987 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490556#490556 ________________________________________________________________________________
Subject: Re: Fat Ultralight
Date: Jul 27, 2019
Good to know, I have been considering both options with my early FS from 1987. Not sure of the date first flown the date is on the drawing shipping tube. I am over weight enough to exclude most trailer friendly UL. I looked at the firefly with the 250 limit, leaving me with one gallon. Out of curiosity I weighed my plane and got 307# with a 447. Easier to fly a two seat plane solo all day. I took LSA training and fuel load with a male instructor was always an issue, not with female instructors. -------- Firestar 1 1987 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490557#490557 ________________________________________________________________________________
Subject: Kolb air airworthiness directive
Date: Jul 27, 2019
I noticed a link on the Kolb home page today leading to this. https://kolbaircraft.com/FirestarAD.htm Has anyone installed this? My plane has a metal bracket welded to the frame and bolt in the general area this new part completely covers it. -------- Firestar 1 1987 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490558#490558 Attachments: http://forums.matronics.com//files/7106c9ed_33d7_457e_a6a8_8821574c6ef9_203.jpeg ________________________________________________________________________________
Subject: Re: Kolb air airworthiness directive
Date: Jul 27, 2019
My brace. -------- Firestar 1 1987 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490559#490559 Attachments: http://forums.matronics.com//files/19e907e8_d8c0_413e_8fe4_f72ecbf1010e_205.jpeg ________________________________________________________________________________
Date: Jul 28, 2019
From: Boudro Construction Verns Welding <verdixbo(at)sisqtel.net>
Subject: Re: Kolb-List Digest: 4 Msgs - 07/27/19
Thought it was kinda smokey. ----- Original Message ----- From: "Kolb-List Digest Server" <kolb-list(at)matronics.com> Sent: Saturday, July 27, 2019 11:37:28 PM Subject: Kolb-List Digest: 4 Msgs - 07/27/19 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Kolb-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Kolb-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-07-27&Archive=Kolb Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 19-07-27&Archive=Kolb =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Kolb-List Digest Archive --- Total Messages Posted Sat 07/27/19: 4 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 02:51 PM - Re: wing center gap seal (Charlieoneseven) 2. 03:11 PM - Re: Fat Ultralight (Charlieoneseven) 3. 06:21 PM - Kolb air airworthiness directive (Charlieoneseven) 4. 09:23 PM - Re: Kolb air airworthiness directive (Charlieoneseven) ________________________________ Message 1 _____________________________________ Subject: Kolb-List: Re: wing center gap seal From: "Charlieoneseven" <Hynesc(at)yahoo.com> Hi all, I have one of the first Firestars and that gap doesnt prevent me from flying without it. In fact since it is not part of the wing or fuselage I would not want to depart into my prop. Dont ask me how I know that. I have wondered how others deal with it. -------- Firestar 1 1987 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490556#490556 ________________________________ Message 2 _____________________________________ Subject: Kolb-List: Re: Fat Ultralight From: "Charlieoneseven" <Hynesc(at)yahoo.com> Good to know, I have been considering both options with my early FS from 1987. Not sure of the date first flown the date is on the drawing shipping tube. I am over weight enough to exclude most trailer friendly UL. I looked at the firefly with the 250 limit, leaving me with one gallon. Out of curiosity I weighed my plane and got 307# with a 447. Easier to fly a two seat plane solo all day. I took LSA training and fuel load with a male instructor was always an issue, not with female instructors. -------- Firestar 1 1987 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490557#490557 ________________________________ Message 3 _____________________________________ Subject: Kolb-List: Kolb air airworthiness directive From: "Charlieoneseven" <Hynesc(at)yahoo.com> I noticed a link on the Kolb home page today leading to this. https://kolbaircraft.com/FirestarAD.htm Has anyone installed this? My plane has a metal bracket welded to the frame and bolt in the general area this new part completely covers it. -------- Firestar 1 1987 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490558#490558 Attachments: http://forums.matronics.com//files/7106c9ed_33d7_457e_a6a8_8821574c6ef9_203.jpeg ________________________________ Message 4 _____________________________________ Subject: Kolb-List: Re: Kolb air airworthiness directive From: "Charlieoneseven" <Hynesc(at)yahoo.com> My brace. -------- Firestar 1 1987 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490559#490559 Attachments: http://forums.matronics.com//files/19e907e8_d8c0_413e_8fe4_f72ecbf1010e_205.jpeg ________________________________________________________________________________
Date: Aug 01, 2019
Victorbravo has given a very good way of doing what would be the best way to go about getting what you want, or make it look like an ultralight ( 1 seat) and fly it that way. -------- 912ul King Kolbra ;fun plane O300 Cessna 172B ;travel plane Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490649#490649 ________________________________________________________________________________
Subject: Re: Life Insurance
Date: Aug 07, 2019
At your age, I don't think it's a good idea to take life insurance. You won't get that much out of it. And depending on if you work or not, this could be a big hit on the family's budget. My dad is a veteran too and he struggles o paying the house insurance, although he got a good deal on the progressive insurance (https://homeownersinsurancecover.net/progressive-review/ (https://homeownersinsurancecover.net/progressive-review/)). Think twice before doing such a step, although you do it for the family, it might turn out to a load for them [Exclamation] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490760#490760 ________________________________________________________________________________
Date: Aug 08, 2019
OLD SAYING: NEVER BE WORTH MORE DEAD THAN ALIVE -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490763#490763 ________________________________________________________________________________
Date: Aug 10, 2019
Subject: Life insurance
I don't think there's a company out there that will pay any amount if you are killed in an experimental airplane accident. Every life insurance policy I have tried to get in the last 30 years always has some sort of exemption. There may be one out there, but I'm sure the premiums are pretty high. Mark....Ultrastar,500+ hours and counting with the original UL2 ________________________________________________________________________________
Date: Aug 10, 2019
Subject: Re: Life insurance
Not exactly what you're talking about, but you can get an AD&D policy that covers flying, to supplement a regular life policy. Try here: https://www.eaa.org/eaa/pilots/eaa-insurance-solutions/eaa-personal-insurance-plan No idea what it costs; I'm old enough that I don't carry life insurance any more, other than the minimal stuff offered by my employer's retirement plan. Charlie On Sat, Aug 10, 2019 at 7:16 AM Mark Shimei wrote: > I don't think there's a company out there that will pay any amount if you > are killed in an experimental airplane accident. Every life insurance > policy I have tried to get in the last 30 years always has some sort of > exemption. There may be one out there, but I'm sure the premiums are pretty > high. > > Mark....Ultrastar,500+ hours and counting with the original UL2 > ________________________________________________________________________________
Date: Aug 12, 2019
I just received the parts and am in the process of installing them. The parts do the same job as that welded brace on your plane, so you should be good, assuming that both bellcranks have a similar brace as in the photo. Your brace is at least as strong as the the ones provided in the kit from Kolb. My plane has no braces attached to the end of the bellcrank pivot bolts. I can see how the bolt or the weld could be weakened over time due to the repeated bending loads from the bellcrank. The kit from Kolb includes two braces and the pop rivets needed to attach them to the root tube. The rivet holes are not drilled in the braces. One of the braces needed to be modified with a rotary file in order to fit on my 1985 Firestar. On my airframe, there's a little piece of tubing that secures the fuel tank welded about 3/4" away from the aileron bell crank. The new bracket needs to be filed down by at least 1/4" in order to clear the fuel tank brace tube. I think I can make the Kolb bracket work. If not, I guess I'll weld on a bracket like yours. I applaud Kolb for taking the initiative to identify and engineer a fix for this problem. -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490817#490817 ________________________________________________________________________________
Date: Aug 13, 2019
I was concerned when I got my FS kit, late 1985 or early 86, to discover the butt welded pivot bolt on the aileron bell crank with no bracing. I designed a strap brace to stabilize that pivot bolt. Looked a lot like what Kolb came up with at a later date. Never had a problem with it. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of wakataka Sent: Monday, August 12, 2019 7:24 PM Subject: Kolb-List: Re: Kolb air airworthiness directive I just received the parts and am in the process of installing them. The parts do the same job as that welded brace on your plane, so you should be good, assuming that both bellcranks have a similar brace as in the photo. Your brace is at least as strong as the the ones provided in the kit from Kolb. My plane has no braces attached to the end of the bellcrank pivot bolts. I can see how the bolt or the weld could be weakened over time due to the repeated bending loads from the bellcrank. The kit from Kolb includes two braces and the pop rivets needed to attach them to the root tube. The rivet holes are not drilled in the braces. One of the braces needed to be modified with a rotary file in order to fit on my 1985 Firestar. On my airframe, there's a little piece of tubing that secures the fuel tank welded about 3/4" away from the aileron bell crank. The new bracket needs to be filed down by at least 1/4" in order to clear the fuel tank brace tube. I think I can make the Kolb bracket work. If not, I guess I'll weld on a bracket like yours. I applaud Kolb for taking the initiative to identify and engineer a fix for this problem. -------- There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. Mark Twain Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490817#490817 ________________________________________________________________________________
Date: Aug 13, 2019
I did this modification about four years ago on my original Firestar. The on ly thing you might have change is the castle nuts. I had to go to half castl es because the welded studs( bolts ) were just a bit short. This is a must d o mod. for anyone who hasn=99t done it yet. Are you back home, John? George H. Firestar 1986, Hirth 2702 14GDH Mesick, Michigan gdhelton(at)gmail.com Sent from my iPhone > On Aug 13, 2019, at 8:21 AM, John Hauck wrote: > > > I was concerned when I got my FS kit, late 1985 or early 86, to discover t he butt welded pivot bolt on the aileron bell crank with no bracing. I desi gned a strap brace to stabilize that pivot bolt. Looked a lot like what Kol b came up with at a later date. Never had a problem with it. > > john h > mkIII > Titus, Alabama > > > > > -----Original Message----- > From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server@ matronics.com] On Behalf Of wakataka > Sent: Monday, August 12, 2019 7:24 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: Kolb air airworthiness directive > > > I just received the parts and am in the process of installing them. The pa rts do the same job as that welded brace on your plane, so you should be goo d, assuming that both bellcranks have a similar brace as in the photo. Your b race is at least as strong as the the ones provided in the kit from Kolb. > > My plane has no braces attached to the end of the bellcrank pivot bolts. I can see how the bolt or the weld could be weakened over time due to the rep eated bending loads from the bellcrank. > > The kit from Kolb includes two braces and the pop rivets needed to attach t hem to the root tube. The rivet holes are not drilled in the braces. One of t he braces needed to be modified with a rotary file in order to fit on my 198 5 Firestar. On my airframe, there's a little piece of tubing that secures th e fuel tank welded about 3/4" away from the aileron bell crank. The new brac ket needs to be filed down by at least 1/4" in order to clear the fuel tank b race tube. I think I can make the Kolb bracket work. If not, I guess I'll we ld on a bracket like yours. > > I applaud Kolb for taking the initiative to identify and engineer a fix fo r this problem. > > -------- > There is something fascinating about science. One gets such wholesale retu rns of conjecture out of such a trifling investment of fact. > > Mark Twain > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=490817#490817 > > > > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Aug 13, 2019
R290IGhvbWUgMiBBdWcuICBHcmVhdCB0cmlwLiAgMy41IG1vbnRocy4gIDYsMzAzLjIgbWlsZXMu ICA0MTYgaG91cnMgZWFjaCBlbmdpbmUuICAyLDg5MCBnYWwgZ2FzLiAgRGlkbid0IHdhbnQgdG8g Y29tZSBob21lLiAgOy0pDQoNCk1pc3MgUCdmZXIsIG15IE1LSUlJLCBsYW5ndWlzaGVzIGluIHRo ZSBoYW5nZXIgYXQgR2FudHQgSW50ZXJuYXRpb25hbCBBaXJwb3J0Lg0KDQpqb2huIGgNCm1rSUlJ DQpUaXR1cywgQWxhYmFtYQ0KDQpGcm9tOiBvd25lci1rb2xiLWxpc3Qtc2VydmVyQG1hdHJvbmlj cy5jb20gW21haWx0bzpvd25lci1rb2xiLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJl aGFsZiBPZiBHZW9yZ2UgSGVsdG9uDQpTZW50OiBUdWVzZGF5LCBBdWd1c3QgMTMsIDIwMTkgOTo0 NCBBTQ0KVG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSZTogS29sYi1MaXN0 OiBSZTogS29sYiBhaXIgYWlyd29ydGhpbmVzcyBkaXJlY3RpdmUNCg0KSSBkaWQgdGhpcyBtb2Rp ZmljYXRpb24gYWJvdXQgZm91ciB5ZWFycyBhZ28gb24gbXkgb3JpZ2luYWwgRmlyZXN0YXIuIFRo ZSBvbmx5IHRoaW5nIHlvdSBtaWdodCBoYXZlIGNoYW5nZSBpcyB0aGUgY2FzdGxlIG51dHMuIEkg aGFkIHRvIGdvIHRvIGhhbGYgY2FzdGxlcyBiZWNhdXNlIHRoZSB3ZWxkZWQgc3R1ZHMoIGJvbHRz ICkgd2VyZSBqdXN0IGEgYml0IHNob3J0LiBUaGlzIGlzIGEgbXVzdCBkbyBtb2QuIGZvciBhbnlv bmUgd2hvIGhhc27igJl0IGRvbmUgaXQgeWV0Lg0KQXJlIHlvdSBiYWNrIGhvbWUsIEpvaG4/DQpb Y2lkOmltYWdlMDAxLmpwZ0AwMUQ1NTFDMC4wQ0ZFNDlFMF0NCltjaWQ6aW1hZ2UwMDIuanBnQDAx RDU1MUMwLjBDRkU0OUUwXQ0KDQpHZW9yZ2UgSC4NCkZpcmVzdGFyIDE5ODYsIEhpcnRoIDI3MDIN CjE0R0RIDQpNZXNpY2ssIE1pY2hpZ2FuDQpnZGhlbHRvbkBnbWFpbC5jb20NCg0KU2VudCBmcm9t IG15IGlQaG9uZQ0KDQo+IE9uIEF1ZyAxMywgMjAxOSwgYXQgODoyMSBBTSwgSm9obiBIYXVjayA8 amhhdWNrMzZAb3V0bG9vay5jb20+IHdyb3RlOg0KPg0KPiAtLT4gS29sYi1MaXN0IG1lc3NhZ2Ug cG9zdGVkIGJ5OiBKb2huIEhhdWNrIDxqaGF1Y2szNkBvdXRsb29rLmNvbT4NCj4NCj4gSSB3YXMg Y29uY2VybmVkIHdoZW4gSSBnb3QgbXkgRlMga2l0LCBsYXRlIDE5ODUgb3IgZWFybHkgODYsIHRv IGRpc2NvdmVyIHRoZSBidXR0IHdlbGRlZCBwaXZvdCBib2x0IG9uIHRoZSBhaWxlcm9uIGJlbGwg Y3Jhbmsgd2l0aCBubyBicmFjaW5nLiAgSSBkZXNpZ25lZCBhIHN0cmFwIGJyYWNlIHRvIHN0YWJp bGl6ZSB0aGF0IHBpdm90IGJvbHQuICBMb29rZWQgYSBsb3QgbGlrZSB3aGF0IEtvbGIgY2FtZSB1 cCB3aXRoIGF0IGEgbGF0ZXIgZGF0ZS4gIE5ldmVyIGhhZCBhIHByb2JsZW0gd2l0aCBpdC4NCj4N Cj4gam9obiBoDQo+IG1rSUlJDQo+IFRpdHVzLCBBbGFiYW1hDQo+DQo+DQo+DQo+DQo+IC0tLS0t T3JpZ2luYWwgTWVzc2FnZS0tLS0tDQo+IEZyb206IG93bmVyLWtvbGItbGlzdC1zZXJ2ZXJAbWF0 cm9uaWNzLmNvbSBbbWFpbHRvOm93bmVyLWtvbGItbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0g T24gQmVoYWxmIE9mIHdha2F0YWthDQo+IFNlbnQ6IE1vbmRheSwgQXVndXN0IDEyLCAyMDE5IDc6 MjQgUE0NCj4gVG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29tDQo+IFN1YmplY3Q6IEtvbGItTGlz dDogUmU6IEtvbGIgYWlyIGFpcndvcnRoaW5lc3MgZGlyZWN0aXZlDQo+DQo+IC0tPiBLb2xiLUxp c3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJ3YWthdGFrYSIgPHdha2F0YWthQGNoYXJ0ZXIubmV0Pg0K Pg0KPiBJIGp1c3QgcmVjZWl2ZWQgdGhlIHBhcnRzIGFuZCBhbSBpbiB0aGUgcHJvY2VzcyBvZiBp bnN0YWxsaW5nIHRoZW0uIFRoZSBwYXJ0cyBkbyB0aGUgc2FtZSBqb2IgYXMgdGhhdCB3ZWxkZWQg YnJhY2Ugb24geW91ciBwbGFuZSwgc28geW91IHNob3VsZCBiZSBnb29kLCBhc3N1bWluZyB0aGF0 IGJvdGggYmVsbGNyYW5rcyBoYXZlIGEgc2ltaWxhciBicmFjZSBhcyBpbiB0aGUgcGhvdG8uIFlv dXIgYnJhY2UgaXMgYXQgbGVhc3QgYXMgc3Ryb25nIGFzIHRoZSB0aGUgb25lcyBwcm92aWRlZCBp biB0aGUga2l0IGZyb20gS29sYi4NCj4NCj4gTXkgcGxhbmUgaGFzIG5vIGJyYWNlcyBhdHRhY2hl ZCB0byB0aGUgZW5kIG9mIHRoZSBiZWxsY3JhbmsgcGl2b3QgYm9sdHMuIEkgY2FuIHNlZSBob3cg dGhlIGJvbHQgb3IgdGhlIHdlbGQgY291bGQgYmUgd2Vha2VuZWQgb3ZlciB0aW1lIGR1ZSB0byB0 aGUgcmVwZWF0ZWQgYmVuZGluZyBsb2FkcyBmcm9tIHRoZSBiZWxsY3JhbmsuDQo+DQo+IFRoZSBr aXQgZnJvbSBLb2xiIGluY2x1ZGVzIHR3byBicmFjZXMgYW5kIHRoZSBwb3Agcml2ZXRzIG5lZWRl ZCB0byBhdHRhY2ggdGhlbSB0byB0aGUgcm9vdCB0dWJlLiBUaGUgcml2ZXQgaG9sZXMgYXJlIG5v dCBkcmlsbGVkIGluIHRoZSBicmFjZXMuIE9uZSBvZiB0aGUgYnJhY2VzIG5lZWRlZCB0byBiZSBt b2RpZmllZCB3aXRoIGEgcm90YXJ5IGZpbGUgaW4gb3JkZXIgdG8gZml0IG9uIG15IDE5ODUgRmly ZXN0YXIuIE9uIG15IGFpcmZyYW1lLCB0aGVyZSdzIGEgbGl0dGxlIHBpZWNlIG9mIHR1YmluZyB0 aGF0IHNlY3VyZXMgdGhlIGZ1ZWwgdGFuayB3ZWxkZWQgYWJvdXQgMy80IiBhd2F5IGZyb20gdGhl IGFpbGVyb24gYmVsbCBjcmFuay4gVGhlIG5ldyBicmFja2V0IG5lZWRzIHRvIGJlIGZpbGVkIGRv d24gYnkgYXQgbGVhc3QgMS80IiBpbiBvcmRlciB0byBjbGVhciB0aGUgZnVlbCB0YW5rIGJyYWNl IHR1YmUuIEkgdGhpbmsgSSBjYW4gbWFrZSB0aGUgS29sYiBicmFja2V0IHdvcmsuIElmIG5vdCwg SSBndWVzcyBJJ2xsIHdlbGQgb24gYSBicmFja2V0IGxpa2UgeW91cnMuDQo+DQo+IEkgYXBwbGF1 ZCBLb2xiIGZvciB0YWtpbmcgdGhlIGluaXRpYXRpdmUgdG8gaWRlbnRpZnkgYW5kIGVuZ2luZWVy IGEgZml4IGZvciB0aGlzIHByb2JsZW0uDQo+DQo+IC0tLS0tLS0tDQo+IFRoZXJlIGlzIHNvbWV0 aGluZyBmYXNjaW5hdGluZyBhYm91dCBzY2llbmNlLiBPbmUgZ2V0cyBzdWNoIHdob2xlc2FsZSBy ZXR1cm5zIG9mIGNvbmplY3R1cmUgb3V0IG9mIHN1Y2ggYSB0cmlmbGluZyBpbnZlc3RtZW50IG9m IGZhY3QuDQo+DQo+IE1hcmsgVHdhaW4NCj4NCj4NCj4NCj4NCj4gUmVhZCB0aGlzIHRvcGljIG9u bGluZSBoZXJlOg0KPg0KPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBo cD9wPTQ5MDgxNyM0OTA4MTcNCj4NCj4NCj4NCj4NCj4NCj4NCj4NCj4NCj4NCj4NCj09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KPT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09DQo9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KPT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09DQo+DQo+DQo+DQo ________________________________________________________________________________
Date: Aug 13, 2019
Subject: Fly-in
I want to remind every one of our annual Rock House Fly-in again, Sept 7th till we drop. all on this list are welcome regardless of what you fly. 42 40.419 N-- 117 51.198 W Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: Fly-in
Date: Aug 14, 2019
SG93IGFib3V0IGEgMjAxMiBSQU0gU0xUIENyZXcgQ2FiIExvbmcgQmVkIDRXRCB3aXRoIDV0aCB3 aGVlbCBhbmQgUlpSPw0KDQpJIGNhbiBhbG1vc3QgZ2V0IGl0IHRvIGZseSwgYnV0IG5vdCBxdWl0 ZS4NCg0KSSdsbCBiZSB0aGVyZSBMb3JkIHdpbGxpbmcgYW5kIHRoZSBjcmVlayBkb24ndCByaXNl Lg0KDQpqb2huIGgNCm1rSUlJDQpUaXR1cywgQWxhYmFtYQ0KDQpGcm9tOiBvd25lci1rb2xiLWxp c3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1rb2xiLWxpc3Qtc2VydmVyQG1h dHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBMYXJyeSBDb3R0cmVsbA0KU2VudDogVHVlc2RheSwg QXVndXN0IDEzLCAyMDE5IDg6NDAgUE0NClRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3Vi amVjdDogS29sYi1MaXN0OiBGbHktaW4NCg0KSSB3YW50IHRvIHJlbWluZCBldmVyeSBvbmUgb2Yg b3VyIGFubnVhbCBSb2NrIEhvdXNlIEZseS1pbiBhZ2FpbiwgU2VwdCA3dGggdGlsbCB3ZSBkcm9w LiBhbGwgb24gdGhpcyBsaXN0IGFyZSB3ZWxjb21lIHJlZ2FyZGxlc3Mgb2Ygd2hhdCB5b3UgZmx5 LiA0MiA0MC40MTkgTi0tIDExNyA1MS4xOTggVw0KDQpMYXJyeQ0KDQotLQ0KVGhlIG9sZGVyIEkg Z2V0LCB0aGUgbGVzcyB0b2xlcmFudCBJIGFtIG9mIHRob3NlIHdobyBhcmUgaW50b2xlcmFudCBv ZiBvdGhlcnMuDQoNCklmIHlvdSBmb3J3YXJkIHRoaXMgZW1haWwsIG9yIGFueSBwYXJ0IG9mIGl0 LCBwbGVhc2UgcmVtb3ZlIG15IGVtYWlsIGFkZHJlc3MgYmVmb3JlIHNlbmRpbmcuDQo ________________________________________________________________________________
Date: Aug 13, 2019
Subject: Re: Fly-in
eagerly waiting for one and all. Larry On Tue, Aug 13, 2019 at 7:49 PM John Hauck wrote: > How about a 2012 RAM SLT Crew Cab Long Bed 4WD with 5th wheel and RZR? > > > I can almost get it to fly, but not quite. > > > I'll be there Lord willing and the creek don't rise. > > > john h > > mkIII > > Titus, Alabama > > > *From:* owner-kolb-list-server(at)matronics.com [mailto: > owner-kolb-list-server(at)matronics.com] *On Behalf Of *Larry Cottrell > *Sent:* Tuesday, August 13, 2019 8:40 PM > *To:* kolb-list(at)matronics.com > *Subject:* Kolb-List: Fly-in > > > I want to remind every one of our annual Rock House Fly-in again, Sept 7th > till we drop. all on this list are welcome regardless of what you fly. 42 > 40.419 N-- 117 51.198 W > > > Larry > > > -- > > *The older I get, the less tolerant I am of those who are intolerant of > others.* > > > *If you forward this email, or any part of it, please remove my email > address before sending.* > -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Subject: 912 mount angle thickness?
Date: Aug 15, 2019
Does anyone know the thickness of the aluminum angle used for 912 mount adapters? I need to order some angle to make my mounts. I'm guessing 3/8" thick maybe? Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490894#490894 ________________________________________________________________________________
Date: Aug 16, 2019
Subject: Re: Kolb-List Digest: 1 Msgs - 08/15/19
Hello Rusty - I have a Kolb Mark III Twinstar Classic with a Rotax 912. The aluminum angle is 1"x3" and is 1/4 thick. There is also a sheetmetal plate underneath the engine that mounts all the way across to each aluminum angle via the motor mount bolts. The sheetmetal is 1/16" thick. I hope this helps! Mike On Thu, Aug 15, 2019 at 11:40 PM Kolb-List Digest Server < kolb-list(at)matronics.com> wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-08-15&Archive=Kolb > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 19-08-15&Archive=Kolb > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Thu 08/15/19: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 05:53 PM - 912 mount angle thickness? (13brv3) > > > ________________________________ Message 1 > _____________________________________ > > > Subject: Kolb-List: 912 mount angle thickness? > From: "13brv3" <13brv3(at)gmail.com> > > > Does anyone know the thickness of the aluminum angle used for 912 mount > adapters? > I need to order some angle to make my mounts. I'm guessing 3/8" thick > maybe? > > > Thanks, > Rusty > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=490894#490894 > > ________________________________________________________________________________
Date: Aug 16, 2019
armstromike(at)gmail.com wrote: > Hello Rusty -I have a Kolb Mark III Twinstar Classic with a Rotax 912. > The aluminum angle is 1"x3" and is 1/4 thick. > There is also a sheetmetal plate underneath the engine that mounts all the way across to each aluminum angle via the motor mount bolts. > The sheetmetal is 1/16" thick. > > > I hope this helps! > Mike > > Perfect Mike. Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490904#490904 ________________________________________________________________________________
Date: Aug 17, 2019
Subject: Fwd: flight
My first attempt was not sent to the list- too big. So I will send the pictures in three files. They have been reduced in size quite a bit, so I think it was volume rather than size. I have been wrong before however. After checking the weather and winds, I decided to go fishing on the Owyhee River. The spot that I like is about an hour away by Firestar 2. I really haven't been flying all that much this year and my conscious was bothering me. Every thing started out quite nicely and I had a bit of a tail wind at 5K. As I approached the half way point the winds kicked up and I was all over the sky I persisted for a few miles and it got even rougher. Things tend to get worse here as the hours near the midday point, so I gave up and turned back for home. As I reversed my course I dropped some in altitude as the winds at 6 k were supposed to be 12 to 19 MPH. I noticed several bunches of feral Horses below. I did not have a real camera so I did what I could with the low resolution screen shots from my Garmin Virb. I am used to seeing some fairly "flashy" feral Horses in some of these herds, but today there was about 6 white ones. They as near as I can tell are not albino, but are white with "creamy" tails and manes. I will fish another day however, when it is not so drafty. Some of the shots are just scenery, the last four have horses in them if you can find them. Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 17, 2019
Subject: pics
Date: Aug 17, 2019
Subject: pics
Date: Aug 17, 2019
Subject: pics
Date: Aug 18, 2019
Mike - this came to me - RUSS, not RUSTY. Dont think he got it! Russ > On Aug 16, 2019, at 10:54 AM, Mike wrote: > > Hello Rusty - > I have a Kolb Mark III Twinstar Classic with a Rotax 912. > The aluminum angle is 1"x3" and is 1/4 thick. > There is also a sheetmetal plate underneath the engine that mounts all the way across to each aluminum angle via the motor mount bolts. > The sheetmetal is 1/16" thick. > > I hope this helps! > Mike > > On Thu, Aug 15, 2019 at 11:40 PM Kolb-List Digest Server > wrote: > * > > ======================== > Online Versions of Today's List Digest Archive > ======================== > > Today's complete Kolb-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Kolb-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&C hapter 19-08-15&Archive=Kolb <http://www.matronics.com/digest/digestview.php?Style=82701&View=html& Chapter 19-08-15&Archive=Kolb> > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Ch apter 19-08-15&Archive=Kolb <http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&C hapter 19-08-15&Archive=Kolb> > > > ====================== > EMail Version of Today's List Digest Archive > ====================== > > > ---------------------------------------------------------- > Kolb-List Digest Archive > --- > Total Messages Posted Thu 08/15/19: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 05:53 PM - 912 mount angle thickness? (13brv3) > > > > ________________________________ Message 1 _____________________________________ > > > Subject: Kolb-List: 912 mount angle thickness? > From: "13brv3" <13brv3(at)gmail.com <mailto:13brv3(at)gmail.com>> > > > Does anyone know the thickness of the aluminum angle used for 912 mount adapters? > I need to order some angle to make my mounts. I'm guessing 3/8" thick maybe? > > > Thanks, > Rusty > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=490894#490894 <http://forums.matronics.com/viewtopic.php?p=490894#490894> > > > > > ========== > -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > > > ________________________________________________________________________________
Subject: Re: pics
Date: Aug 18, 2019
Beautiful. Thank you. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490948#490948 ________________________________________________________________________________
Subject: 912 radiator?
Date: Aug 20, 2019
Greetings, Is everyone paying $500 for the official Rotax radiator, or are there other popular options? There are a number of Ebay radiators in the $210 range that mention the 912, and they appear to be the right size, but none of them list the inlet and outlet diameter. One seller did state that his was 25mm inlet, and 30mm outlet, but I believe they should both be 25mm/1". Aluminum radiators aren't exactly rocket science, and I'm tempted to give one of those a try, but it's frustrating that I haven't been able to get inlet and outlet sizes for any of the others that are listed. I get the impression there are only about 2-3 different radiators for all the dozens of listings, and maybe only a couple sellers, each with a few different aliases. Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490967#490967 ________________________________________________________________________________
Subject: Re: 912 radiator?
Date: Aug 20, 2019
On 8/20/2019 11:40 AM, 13brv3 wrote: > > Greetings, > > Is everyone paying $500 for the official Rotax radiator, or are there other popular options? There are a number of Ebay radiators in the $210 range that mention the 912, and they appear to be the right size, but none of them list the inlet and outlet diameter. One seller did state that his was 25mm inlet, and 30mm outlet, but I believe they should both be 25mm/1". > > Aluminum radiators aren't exactly rocket science, and I'm tempted to give one of those a try, but it's frustrating that I haven't been able to get inlet and outlet sizes for any of the others that are listed. I get the impression there are only about 2-3 different radiators for all the dozens of listings, and maybe only a couple sellers, each with a few different aliases. > > Thanks, > Rusty Why not just find an ebay special motorcycle rad for a 100+hp bike? Or check a cycle salvage yard, if there's one near you. Drag certainly isn't as big an issue as it was with the -3, so if you 'go big' (and thin) & feed it with a sheet metal wedge diffuser, you pretty much know it'll work. You can get silicone size adapters from/to almost any common diameter now, so fitting size shouldn't be too much of an issue. If you want to go with an auto rad, IIRC, a stock Honda Civic rad is about an inch thick (might be a bit thicker) & has ~1" fittings. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 20, 2019
I have some 582 radiators and engine and prop I nop longer have a use for Chuck Riley 559-493-0338 RCR Light Aircraft former Titan dealer On Tue, Aug 20, 2019 at 11:04 AM Charlie England wrote: > > On 8/20/2019 11:40 AM, 13brv3 wrote: > > > > Greetings, > > > > Is everyone paying $500 for the official Rotax radiator, or are there > other popular options? There are a number of Ebay radiators in the $210 > range that mention the 912, and they appear to be the right size, but none > of them list the inlet and outlet diameter. One seller did state that his > was 25mm inlet, and 30mm outlet, but I believe they should both be 25mm/1". > > > > Aluminum radiators aren't exactly rocket science, and I'm tempted to > give one of those a try, but it's frustrating that I haven't been able to > get inlet and outlet sizes for any of the others that are listed. I get > the impression there are only about 2-3 different radiators for all the > dozens of listings, and maybe only a couple sellers, each with a few > different aliases. > > > > Thanks, > > Rusty > Why not just find an ebay special motorcycle rad for a 100+hp bike? Or > check a cycle salvage yard, if there's one near you. Drag certainly > isn't as big an issue as it was with the -3, so if you 'go big' (and > thin) & feed it with a sheet metal wedge diffuser, you pretty much know > it'll work. You can get silicone size adapters from/to almost any common > diameter now, so fitting size shouldn't be too much of an issue. If you > want to go with an auto rad, IIRC, a stock Honda Civic rad is about an > inch thick (might be a bit thicker) & has ~1" fittings. > > Charlie > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > -- *Chuck Riley * *RCR Light Aircraft *Office : 559-224-8841 Cell: 559-493-0338 ________________________________________________________________________________
Date: Aug 20, 2019
ceengland7(at)gmail.com wrote: > > > If you > want to go with an auto rad, IIRC, a stock Honda Civic rad is about an > inch thick (might be a bit thicker) & has ~1" fittings. > > Charlie > Hi Charlie, The Civic is about double the size of the stock 912 rad, and just a little thicker. Seems like the two normal outlet sizes are 28mm and 32mm. They sure are cheap :-) There are probably other common small car and motorcycle rads that would work as well, but I'd spend an eternity trying to sort through them. If anyone knows of another auto rad that is close to the right size, and with 1" outlets, that will make the search easier. I'm pretty sure I can make one of the Ebay 912 rads work, but it would sure be nice if I could get the sellers to answer a question. I'll mount the engine later this week with any luck, then start getting serious about a radiator when I see my mounting options. Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490972#490972 ________________________________________________________________________________
Date: Aug 20, 2019
Discontinue > On Aug 20, 2019, at 1:21 PM, Rudolph Riley wrote: > > I have some 582 radiators and engine and prop I nop longer have a use for > Chuck Riley 559-493-0338 > RCR Light Aircraft former Titan dealer > >> On Tue, Aug 20, 2019 at 11:04 AM Charlie England w rote: >> >> On 8/20/2019 11:40 AM, 13brv3 wrote: >> > >> > Greetings, >> > >> > Is everyone paying $500 for the official Rotax radiator, or are there o ther popular options? There are a number of Ebay radiators in the $210 rang e that mention the 912, and they appear to be the right size, but none of th em list the inlet and outlet diameter. One seller did state that his was 25 mm inlet, and 30mm outlet, but I believe they should both be 25mm/1". >> > >> > Aluminum radiators aren't exactly rocket science, and I'm tempted to gi ve one of those a try, but it's frustrating that I haven't been able to get i nlet and outlet sizes for any of the others that are listed. I get the impr ession there are only about 2-3 different radiators for all the dozens of li stings, and maybe only a couple sellers, each with a few different aliases. >> > >> > Thanks, >> > Rusty >> Why not just find an ebay special motorcycle rad for a 100+hp bike? Or >> check a cycle salvage yard, if there's one near you. Drag certainly >> isn't as big an issue as it was with the -3, so if you 'go big' (and >> thin) & feed it with a sheet metal wedge diffuser, you pretty much know >> it'll work. You can get silicone size adapters from/to almost any common >> diameter now, so fitting size shouldn't be too much of an issue. If you >> want to go with an auto rad, IIRC, a stock Honda Civic rad is about an >> inch thick (might be a bit thicker) & has ~1" fittings. >> >> Charlie >> >> --- >> This email has been checked for viruses by Avast antivirus software. >> https://www.avast.com/antivirus >> >> ========== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?Kolb-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========== >> >> >> > > > -- > Chuck Riley > RCR Light Aircraft > Office : 559-224-8841 > Cell: 559-493-0338 > ________________________________________________________________________________
Date: Aug 20, 2019
Subject: Re: unsubscribe
ICAgVW5zdWJzY3JpYmUNDSAtLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0tLQ0gRnJv bTogIkxpbmRhIEpvbmVzIiBham9uZXNAZGZuLmNvbQ0gU2VudDogOC8yMC8yMDE5 IDM6NTY6MTQgUE0NIFRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQ0gU3ViamVj dDogUmU6IEtvbGItTGlzdDogOTEyIHJhZGlhdG9yPw0NIA0NDQ1EaXNjb250aW51 ZSAgDQ1PbiBBdWcgMjAsIDIwMTksIGF0IDE6MjEgUE0sIFJ1ZG9scGggUmlsZXkg cnJpbGV5MzUxQGdtYWlsLmNvbSB3cm90ZToNDSAgIA0NDQ1JIGhhdmUgc29tZSA1 ODIgcmFkaWF0b3JzIGFuZCBlbmdpbmUgYW5kIHByb3AgSSBub3AgbG9uZ2VyIGhh dmUgYSB1c2UgZm9yIA0NQ2h1Y2sgUmlsZXkgNTU5LTQ5My0wMzM4IA0NUkNSIExp Z2h0IEFpcmNyYWZ0IGZvcm1lciBUaXRhbiBkZWFsZXIgICANDQ0NDU9uIFR1ZSwg QXVnIDIwLCAyMDE5IGF0IDExOjA0IEFNIENoYXJsaWUgRW5nbGFuZCBjZWVuZ2xh bmQ3QGdtYWlsLmNvbSB3cm90ZTogLS0gS29sYi1MaXN0IG1lc3NhZ2UgcG9zdGVk IGJ5OiBDaGFybGllIEVuZ2xhbmQgY2VlbmdsYW5kN0BnbWFpbC5jb20gDQ0gT24g OC8yMC8yMDE5IDExOjQwIEFNLCAxM2JydjMgd3JvdGU6DSAgLS0gS29sYi1MaXN0 IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiMTNicnYzIiAxM2JydjNAZ21haWwuY29tDQ0g IEdyZWV0aW5ncywNDSAgSXMgZXZlcnlvbmUgcGF5aW5nICQ1MDAgZm9yIHRoZSBv ZmZpY2lhbCBSb3RheCByYWRpYXRvciwgb3IgYXJlIHRoZXJlIG90aGVyIHBvcHVs YXIgb3B0aW9ucz8gIFRoZXJlIGFyZSBhIG51bWJlciBvZiBFYmF5IHJhZGlhdG9y cyBpbiB0aGUgJDIxMCByYW5nZSB0aGF0IG1lbnRpb24gdGhlIDkxMiwgYW5kIHRo ZXkgYXBwZWFyIHRvIGJlIHRoZSByaWdodCBzaXplLCBidXQgbm9uZSBvZiB0aGVt IGxpc3QgdGhlIGlubGV0IGFuZCBvdXRsZXQgZGlhbWV0ZXIuICBPbmUgc2VsbGVy IGRpZCBzdGF0ZSB0aGF0IGhpcyB3YXMgMjVtbSBpbmxldCwgYW5kIDMwbW0gb3V0 bGV0LCBidXQgSSBiZWxpZXZlIHRoZXkgc2hvdWxkIGJvdGggYmUgMjVtbS8xIi4N DSAgQWx1bWludW0gcmFkaWF0b3JzIGFyZW4ndCBleGFjdGx5IHJvY2tldCBzY2ll bmNlLCBhbmQgSSdtIHRlbXB0ZWQgdG8gZ2l2ZSBvbmUgb2YgdGhvc2UgYSB0cnks IGJ1dCBpdCdzIGZydXN0cmF0aW5nIHRoYXQgSSBoYXZlbid0IGJlZW4gYWJsZSB0 byBnZXQgaW5sZXQgYW5kIG91dGxldCBzaXplcyBmb3IgYW55IG9mIHRoZSBvdGhl cnMgdGhhdCBhcmUgbGlzdGVkLiAgSSBnZXQgdGhlIGltcHJlc3Npb24gdGhlcmUg YXJlIG9ubHkgYWJvdXQgMi0zIGRpZmZlcmVudCByYWRpYXRvcnMgZm9yIGFsbCB0 aGUgZG96ZW5zIG9mIGxpc3RpbmdzLCBhbmQgbWF5YmUgb25seSBhIGNvdXBsZSBz ZWxsZXJzLCBlYWNoIHdpdGggYSBmZXcgZGlmZmVyZW50IGFsaWFzZXMuDQ0gIFRo YW5rcywNICBSdXN0eQ0gV2h5IG5vdCBqdXN0IGZpbmQgYW4gZWJheSBzcGVjaWFs IG1vdG9yY3ljbGUgcmFkIGZvciBhIDEwMCtocCBiaWtlPyBPciANIGNoZWNrIGEg Y3ljbGUgc2FsdmFnZSB5YXJkLCBpZiB0aGVyZSdzIG9uZSBuZWFyIHlvdS4gRHJh ZyBjZXJ0YWlubHkgDSBpc24ndCBhcyBiaWcgYW4gaXNzdWUgYXMgaXQgd2FzIHdp dGggdGhlIC0zLCBzbyBpZiB5b3UgJ2dvIGJpZycgKGFuZCANIHRoaW4pICBmZWVk IGl0IHdpdGggYSBzaGVldCBtZXRhbCB3ZWRnZSBkaWZmdXNlciwgeW91IHByZXR0 eSBtdWNoIGtub3cgDSBpdCdsbCB3b3JrLiBZb3UgY2FuIGdldCBzaWxpY29uZSBz aXplIGFkYXB0ZXJzIGZyb20vdG8gYWxtb3N0IGFueSBjb21tb24gDSBkaWFtZXRl ciBub3csIHNvIGZpdHRpbmcgc2l6ZSBzaG91bGRuJ3QgYmUgdG9vIG11Y2ggb2Yg YW4gaXNzdWUuIElmIHlvdSANIHdhbnQgdG8gZ28gd2l0aCBhbiBhdXRvIHJhZCwg SUlSQywgYSBzdG9jayBIb25kYSBDaXZpYyByYWQgaXMgYWJvdXQgYW4gDSBpbmNo IHRoaWNrIChtaWdodCBiZSBhIGJpdCB0aGlja2VyKSAgaGFzIH4xIiBmaXR0aW5n cy4NDSBDaGFybGllDQ0gLS0tDSBUaGlzIGVtYWlsIGhhcyBiZWVuIGNoZWNrZWQg Zm9yIHZpcnVzZXMgYnkgQXZhc3QgYW50aXZpcnVzIHNvZnR3YXJlLg0gaHR0cHM6 Ly93d3cuYXZhc3QuY29tL2FudGl2aXJ1cw0NID09PT09PT09PT09DSAtTGlzdCIg cmVsPSJub3JlZmVycmVyIiB0YXJnZXQ9Il9ibGFuayJodHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vTmF2aWdhdG9yP0tvbGItTGlzdA0gPT09PT09PT09PT0NIEZPUlVN UyAtDSBlZmVycmVyIiB0YXJnZXQ9Il9ibGFuayJodHRwOi8vZm9ydW1zLm1hdHJv bmljcy5jb20NID09PT09PT09PT09DSBXSUtJIC0NIGVycmVyIiB0YXJnZXQ9Il9i bGFuayJodHRwOi8vd2lraS5tYXRyb25pY3MuY29tDSA9PT09PT09PT09PQ0gYiBT aXRlIC0NICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDSByZWw9 Im5vcmVmZXJyZXIiIHRhcmdldD0iX2JsYW5rImh0dHA6Ly93d3cubWF0cm9uaWNz LmNvbS9jb250cmlidXRpb24NID09PT09PT09PT09DQ0gDQ0gICANDSAgLS0gDQ0N DQ0NDQ0NDQ0NDQ0NQ2h1Y2sgUmlsZXkNIFJDUiBMaWdodCBBaXJjcmFmdA0gT2Zm aWNlIDogNTU5LTIyNC04ODQxDSBDZWxsOiA1NTktNDkzLTAzMzgNDSAgICAgICAg ICA ________________________________________________________________________________
Date: Aug 20, 2019
ICAgDQ0gLS0tLSBPcmlnaW5hbCBNZXNzYWdlIC0tLS0NIEZyb206ICJBbHZpbiBM aW5kYSBKb25lcyIgYWpvbmVzQGRmbi5jb20NIFNlbnQ6IDgvMjAvMjAxOSA0OjAy OjQyIFBNDSBUbzoga29sYi1saXN0QG1hdHJvbmljcy5jb20NIFN1YmplY3Q6IEtv bGItTGlzdDogUmU6IHVuc3Vic2NyaWJlDQ0gVW5zdWJzY3JpYmUNDSAtLS0tIE9y aWdpbmFsIE1lc3NhZ2UgLS0tLQ0gRnJvbTogIkxpbmRhIEpvbmVzIiBham9uZXNA ZGZuLmNvbQ0gU2VudDogOC8yMC8yMDE5IDM6NTY6MTQgUE0NIFRvOiBrb2xiLWxp c3RAbWF0cm9uaWNzLmNvbQ0gU3ViamVjdDogUmU6IEtvbGItTGlzdDogOTEyIHJh ZGlhdG9yPw0NIA0NDQ1EaXNjb250aW51ZSAgDQ1PbiBBdWcgMjAsIDIwMTksIGF0 IDE6MjEgUE0sIFJ1ZG9scGggUmlsZXkgcnJpbGV5MzUxQGdtYWlsLmNvbSB3cm90 ZToNDSAgIA0NDQ1JIGhhdmUgc29tZSA1ODIgcmFkaWF0b3JzIGFuZCBlbmdpbmUg YW5kIHByb3AgSSBub3AgbG9uZ2VyIGhhdmUgYSB1c2UgZm9yIA0NQ2h1Y2sgUmls ZXkgNTU5LTQ5My0wMzM4IA0NUkNSIExpZ2h0IEFpcmNyYWZ0IGZvcm1lciBUaXRh biBkZWFsZXIgICANDQ0NDU9uIFR1ZSwgQXVnIDIwLCAyMDE5IGF0IDExOjA0IEFN IENoYXJsaWUgRW5nbGFuZCBjZWVuZ2xhbmQ3QGdtYWlsLmNvbSB3cm90ZTogLS0g S29sYi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBDaGFybGllIEVuZ2xhbmQgY2Vl bmdsYW5kN0BnbWFpbC5jb20gDQ0gT24gOC8yMC8yMDE5IDExOjQwIEFNLCAxM2Jy djMgd3JvdGU6DSAgLS0gS29sYi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiMTNi cnYzIiAxM2JydjNAZ21haWwuY29tDQ0gIEdyZWV0aW5ncywNDSAgSXMgZXZlcnlv bmUgcGF5aW5nICQ1MDAgZm9yIHRoZSBvZmZpY2lhbCBSb3RheCByYWRpYXRvciwg b3IgYXJlIHRoZXJlIG90aGVyIHBvcHVsYXIgb3B0aW9ucz8gIFRoZXJlIGFyZSBh IG51bWJlciBvZiBFYmF5IHJhZGlhdG9ycyBpbiB0aGUgJDIxMCByYW5nZSB0aGF0 IG1lbnRpb24gdGhlIDkxMiwgYW5kIHRoZXkgYXBwZWFyIHRvIGJlIHRoZSByaWdo dCBzaXplLCBidXQgbm9uZSBvZiB0aGVtIGxpc3QgdGhlIGlubGV0IGFuZCBvdXRs ZXQgZGlhbWV0ZXIuICBPbmUgc2VsbGVyIGRpZCBzdGF0ZSB0aGF0IGhpcyB3YXMg MjVtbSBpbmxldCwgYW5kIDMwbW0gb3V0bGV0LCBidXQgSSBiZWxpZXZlIHRoZXkg c2hvdWxkIGJvdGggYmUgMjVtbS8xIi4NDSAgQWx1bWludW0gcmFkaWF0b3JzIGFy ZW4ndCBleGFjdGx5IHJvY2tldCBzY2llbmNlLCBhbmQgSSdtIHRlbXB0ZWQgdG8g Z2l2ZSBvbmUgb2YgdGhvc2UgYSB0cnksIGJ1dCBpdCdzIGZydXN0cmF0aW5nIHRo YXQgSSBoYXZlbid0IGJlZW4gYWJsZSB0byBnZXQgaW5sZXQgYW5kIG91dGxldCBz aXplcyBmb3IgYW55IG9mIHRoZSBvdGhlcnMgdGhhdCBhcmUgbGlzdGVkLiAgSSBn ZXQgdGhlIGltcHJlc3Npb24gdGhlcmUgYXJlIG9ubHkgYWJvdXQgMi0zIGRpZmZl cmVudCByYWRpYXRvcnMgZm9yIGFsbCB0aGUgZG96ZW5zIG9mIGxpc3RpbmdzLCBh bmQgbWF5YmUgb25seSBhIGNvdXBsZSBzZWxsZXJzLCBlYWNoIHdpdGggYSBmZXcg ZGlmZmVyZW50IGFsaWFzZXMuDQ0gIFRoYW5rcywNICBSdXN0eQ0gV2h5IG5vdCBq dXN0IGZpbmQgYW4gZWJheSBzcGVjaWFsIG1vdG9yY3ljbGUgcmFkIGZvciBhIDEw MCtocCBiaWtlPyBPciANIGNoZWNrIGEgY3ljbGUgc2FsdmFnZSB5YXJkLCBpZiB0 aGVyZSdzIG9uZSBuZWFyIHlvdS4gRHJhZyBjZXJ0YWlubHkgDSBpc24ndCBhcyBi aWcgYW4gaXNzdWUgYXMgaXQgd2FzIHdpdGggdGhlIC0zLCBzbyBpZiB5b3UgJ2dv IGJpZycgKGFuZCANIHRoaW4pICBmZWVkIGl0IHdpdGggYSBzaGVldCBtZXRhbCB3 ZWRnZSBkaWZmdXNlciwgeW91IHByZXR0eSBtdWNoIGtub3cgDSBpdCdsbCB3b3Jr LiBZb3UgY2FuIGdldCBzaWxpY29uZSBzaXplIGFkYXB0ZXJzIGZyb20vdG8gYWxt b3N0IGFueSBjb21tb24gDSBkaWFtZXRlciBub3csIHNvIGZpdHRpbmcgc2l6ZSBz aG91bGRuJ3QgYmUgdG9vIG11Y2ggb2YgYW4gaXNzdWUuIElmIHlvdSANIHdhbnQg dG8gZ28gd2l0aCBhbiBhdXRvIHJhZCwgSUlSQywgYSBzdG9jayBIb25kYSBDaXZp YyByYWQgaXMgYWJvdXQgYW4gDSBpbmNoIHRoaWNrIChtaWdodCBiZSBhIGJpdCB0 aGlja2VyKSAgaGFzIH4xIiBmaXR0aW5ncy4NDSBDaGFybGllDQ0gLS0tDSBUaGlz IGVtYWlsIGhhcyBiZWVuIGNoZWNrZWQgZm9yIHZpcnVzZXMgYnkgQXZhc3QgYW50 aXZpcnVzIHNvZnR3YXJlLg0gaHR0cHM6Ly93d3cuYXZhc3QuY29tL2FudGl2aXJ1 cw0NID09PT09PT09PT09DSAtTGlzdCIgcmVsPSJub3JlZmVycmVyIiB0YXJnZXQ9 Il9ibGFuayJodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGIt TGlzdA0gPT09PT09PT09PT0NIEZPUlVNUyAtDSBlZmVycmVyIiB0YXJnZXQ9Il9i bGFuayJodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NID09PT09PT09PT09DSBX SUtJIC0NIGVycmVyIiB0YXJnZXQ9Il9ibGFuayJodHRwOi8vd2lraS5tYXRyb25p Y3MuY29tDSA9PT09PT09PT09PQ0gYiBTaXRlIC0NICAgICAgICAgICAtTWF0dCBE cmFsbGUsIExpc3QgQWRtaW4uDSByZWw9Im5vcmVmZXJyZXIiIHRhcmdldD0iX2Js YW5rImh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NID09PT09 PT09PT09DQ0gDQ0gICANDSAgLS0gDQ0NDQ0NDQ0NDQ0NDQ0NQ2h1Y2sgUmlsZXkN IFJDUiBMaWdodCBBaXJjcmFmdA0gT2ZmaWNlIDogNTU5LTIyNC04ODQxDSBDZWxs OiA1NTktNDkzLTAzMzgNDSAgICAgICAgICA ________________________________________________________________________________
Date: Aug 20, 2019
Subject: Re: Re: unsubscribe
ICAgVW5zdWJzY3JpYmUNDSAtLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0tLQ0gRnJv bTogIkFsdmluIExpbmRhIEpvbmVzIiBham9uZXNAZGZuLmNvbQ0gU2VudDogOC8y MC8yMDE5IDQ6MDY6NDEgUE0NIFRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQ0g U3ViamVjdDogUmU6IEtvbGItTGlzdDogUmU6IHVuc3Vic2NyaWJlDQ0gDQ0gLS0t LSBPcmlnaW5hbCBNZXNzYWdlIC0tLS0NIEZyb206ICJBbHZpbiBMaW5kYSBKb25l cyIgYWpvbmVzQGRmbi5jb20NIFNlbnQ6IDgvMjAvMjAxOSA0OjAyOjQyIFBNDSBU bzoga29sYi1saXN0QG1hdHJvbmljcy5jb20NIFN1YmplY3Q6IEtvbGItTGlzdDog UmU6IHVuc3Vic2NyaWJlDQ0gVW5zdWJzY3JpYmUNDSAtLS0tIE9yaWdpbmFsIE1l c3NhZ2UgLS0tLQ0gRnJvbTogIkxpbmRhIEpvbmVzIiBham9uZXNAZGZuLmNvbQ0g U2VudDogOC8yMC8yMDE5IDM6NTY6MTQgUE0NIFRvOiBrb2xiLWxpc3RAbWF0cm9u aWNzLmNvbQ0gU3ViamVjdDogUmU6IEtvbGItTGlzdDogOTEyIHJhZGlhdG9yPw0N IA0NDQ1EaXNjb250aW51ZSAgDQ1PbiBBdWcgMjAsIDIwMTksIGF0IDE6MjEgUE0s IFJ1ZG9scGggUmlsZXkgcnJpbGV5MzUxQGdtYWlsLmNvbSB3cm90ZToNDSAgIA0N DQ1JIGhhdmUgc29tZSA1ODIgcmFkaWF0b3JzIGFuZCBlbmdpbmUgYW5kIHByb3Ag SSBub3AgbG9uZ2VyIGhhdmUgYSB1c2UgZm9yIA0NQ2h1Y2sgUmlsZXkgNTU5LTQ5 My0wMzM4IA0NUkNSIExpZ2h0IEFpcmNyYWZ0IGZvcm1lciBUaXRhbiBkZWFsZXIg ICANDQ0NDU9uIFR1ZSwgQXVnIDIwLCAyMDE5IGF0IDExOjA0IEFNIENoYXJsaWUg RW5nbGFuZCBjZWVuZ2xhbmQ3QGdtYWlsLmNvbSB3cm90ZTogLS0gS29sYi1MaXN0 IG1lc3NhZ2UgcG9zdGVkIGJ5OiBDaGFybGllIEVuZ2xhbmQgY2VlbmdsYW5kN0Bn bWFpbC5jb20gDQ0gT24gOC8yMC8yMDE5IDExOjQwIEFNLCAxM2JydjMgd3JvdGU6 DSAgLS0gS29sYi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiMTNicnYzIiAxM2Jy djNAZ21haWwuY29tDQ0gIEdyZWV0aW5ncywNDSAgSXMgZXZlcnlvbmUgcGF5aW5n ICQ1MDAgZm9yIHRoZSBvZmZpY2lhbCBSb3RheCByYWRpYXRvciwgb3IgYXJlIHRo ZXJlIG90aGVyIHBvcHVsYXIgb3B0aW9ucz8gIFRoZXJlIGFyZSBhIG51bWJlciBv ZiBFYmF5IHJhZGlhdG9ycyBpbiB0aGUgJDIxMCByYW5nZSB0aGF0IG1lbnRpb24g dGhlIDkxMiwgYW5kIHRoZXkgYXBwZWFyIHRvIGJlIHRoZSByaWdodCBzaXplLCBi dXQgbm9uZSBvZiB0aGVtIGxpc3QgdGhlIGlubGV0IGFuZCBvdXRsZXQgZGlhbWV0 ZXIuICBPbmUgc2VsbGVyIGRpZCBzdGF0ZSB0aGF0IGhpcyB3YXMgMjVtbSBpbmxl dCwgYW5kIDMwbW0gb3V0bGV0LCBidXQgSSBiZWxpZXZlIHRoZXkgc2hvdWxkIGJv dGggYmUgMjVtbS8xIi4NDSAgQWx1bWludW0gcmFkaWF0b3JzIGFyZW4ndCBleGFj dGx5IHJvY2tldCBzY2llbmNlLCBhbmQgSSdtIHRlbXB0ZWQgdG8gZ2l2ZSBvbmUg b2YgdGhvc2UgYSB0cnksIGJ1dCBpdCdzIGZydXN0cmF0aW5nIHRoYXQgSSBoYXZl bid0IGJlZW4gYWJsZSB0byBnZXQgaW5sZXQgYW5kIG91dGxldCBzaXplcyBmb3Ig YW55IG9mIHRoZSBvdGhlcnMgdGhhdCBhcmUgbGlzdGVkLiAgSSBnZXQgdGhlIGlt cHJlc3Npb24gdGhlcmUgYXJlIG9ubHkgYWJvdXQgMi0zIGRpZmZlcmVudCByYWRp YXRvcnMgZm9yIGFsbCB0aGUgZG96ZW5zIG9mIGxpc3RpbmdzLCBhbmQgbWF5YmUg b25seSBhIGNvdXBsZSBzZWxsZXJzLCBlYWNoIHdpdGggYSBmZXcgZGlmZmVyZW50 IGFsaWFzZXMuDQ0gIFRoYW5rcywNICBSdXN0eQ0gV2h5IG5vdCBqdXN0IGZpbmQg YW4gZWJheSBzcGVjaWFsIG1vdG9yY3ljbGUgcmFkIGZvciBhIDEwMCtocCBiaWtl PyBPciANIGNoZWNrIGEgY3ljbGUgc2FsdmFnZSB5YXJkLCBpZiB0aGVyZSdzIG9u ZSBuZWFyIHlvdS4gRHJhZyBjZXJ0YWlubHkgDSBpc24ndCBhcyBiaWcgYW4gaXNz dWUgYXMgaXQgd2FzIHdpdGggdGhlIC0zLCBzbyBpZiB5b3UgJ2dvIGJpZycgKGFu ZCANIHRoaW4pICBmZWVkIGl0IHdpdGggYSBzaGVldCBtZXRhbCB3ZWRnZSBkaWZm dXNlciwgeW91IHByZXR0eSBtdWNoIGtub3cgDSBpdCdsbCB3b3JrLiBZb3UgY2Fu IGdldCBzaWxpY29uZSBzaXplIGFkYXB0ZXJzIGZyb20vdG8gYWxtb3N0IGFueSBj b21tb24gDSBkaWFtZXRlciBub3csIHNvIGZpdHRpbmcgc2l6ZSBzaG91bGRuJ3Qg YmUgdG9vIG11Y2ggb2YgYW4gaXNzdWUuIElmIHlvdSANIHdhbnQgdG8gZ28gd2l0 aCBhbiBhdXRvIHJhZCwgSUlSQywgYSBzdG9jayBIb25kYSBDaXZpYyByYWQgaXMg YWJvdXQgYW4gDSBpbmNoIHRoaWNrIChtaWdodCBiZSBhIGJpdCB0aGlja2VyKSAg aGFzIH4xIiBmaXR0aW5ncy4NDSBDaGFybGllDQ0gLS0tDSBUaGlzIGVtYWlsIGhh cyBiZWVuIGNoZWNrZWQgZm9yIHZpcnVzZXMgYnkgQXZhc3QgYW50aXZpcnVzIHNv ZnR3YXJlLg0gaHR0cHM6Ly93d3cuYXZhc3QuY29tL2FudGl2aXJ1cw0NID09PT09 PT09PT09DSAtTGlzdCIgcmVsPSJub3JlZmVycmVyIiB0YXJnZXQ9Il9ibGFuayJo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGItTGlzdA0gPT09 PT09PT09PT0NIEZPUlVNUyAtDSBlZmVycmVyIiB0YXJnZXQ9Il9ibGFuayJodHRw Oi8vZm9ydW1zLm1hdHJvbmljcy5jb20NID09PT09PT09PT09DSBXSUtJIC0NIGVy cmVyIiB0YXJnZXQ9Il9ibGFuayJodHRwOi8vd2lraS5tYXRyb25pY3MuY29tDSA9 PT09PT09PT09PQ0gYiBTaXRlIC0NICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExp c3QgQWRtaW4uDSByZWw9Im5vcmVmZXJyZXIiIHRhcmdldD0iX2JsYW5rImh0dHA6 Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NID09PT09PT09PT09DQ0g DQ0gICANDSAgLS0gDQ0NDQ0NDQ0NDQ0NDQ0NQ2h1Y2sgUmlsZXkNIFJDUiBMaWdo dCBBaXJjcmFmdA0gT2ZmaWNlIDogNTU5LTIyNC04ODQxDSBDZWxsOiA1NTktNDkz LTAzMzgNDSAgICAgICAgICA ________________________________________________________________________________
Date: Aug 20, 2019
Subject: Re: Unsubscribe
ICAgVW5zdWJzY3JpYmUNDSAtLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0tLQ0gRnJv bTogIkFsdmluIExpbmRhIEpvbmVzIiBham9uZXNAZGZuLmNvbQ0gU2VudDogOC8y MC8yMDE5IDQ6MTQ6MDkgUE0NIFRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQ0g U3ViamVjdDogS29sYi1MaXN0OiBSZTogUmU6IHVuc3Vic2NyaWJlDQ0gVW5zdWJz Y3JpYmUNDSAtLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0tLQ0gRnJvbTogIkFsdmlu IExpbmRhIEpvbmVzIiBham9uZXNAZGZuLmNvbQ0gU2VudDogOC8yMC8yMDE5IDQ6 MDY6NDEgUE0NIFRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQ0gU3ViamVjdDog UmU6IEtvbGItTGlzdDogUmU6IHVuc3Vic2NyaWJlDQ0gDQ0gLS0tLSBPcmlnaW5h bCBNZXNzYWdlIC0tLS0NIEZyb206ICJBbHZpbiBMaW5kYSBKb25lcyIgYWpvbmVz QGRmbi5jb20NIFNlbnQ6IDgvMjAvMjAxOSA0OjAyOjQyIFBNDSBUbzoga29sYi1s aXN0QG1hdHJvbmljcy5jb20NIFN1YmplY3Q6IEtvbGItTGlzdDogUmU6IHVuc3Vi c2NyaWJlDQ0gVW5zdWJzY3JpYmUNDSAtLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0t LQ0gRnJvbTogIkxpbmRhIEpvbmVzIiBham9uZXNAZGZuLmNvbQ0gU2VudDogOC8y MC8yMDE5IDM6NTY6MTQgUE0NIFRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQ0g U3ViamVjdDogUmU6IEtvbGItTGlzdDogOTEyIHJhZGlhdG9yPw0NIA0NDQ1EaXNj b250aW51ZSAgDQ1PbiBBdWcgMjAsIDIwMTksIGF0IDE6MjEgUE0sIFJ1ZG9scGgg UmlsZXkgcnJpbGV5MzUxQGdtYWlsLmNvbSB3cm90ZToNDSAgIA0NDQ1JIGhhdmUg c29tZSA1ODIgcmFkaWF0b3JzIGFuZCBlbmdpbmUgYW5kIHByb3AgSSBub3AgbG9u Z2VyIGhhdmUgYSB1c2UgZm9yIA0NQ2h1Y2sgUmlsZXkgNTU5LTQ5My0wMzM4IA0N UkNSIExpZ2h0IEFpcmNyYWZ0IGZvcm1lciBUaXRhbiBkZWFsZXIgICANDQ0NDU9u IFR1ZSwgQXVnIDIwLCAyMDE5IGF0IDExOjA0IEFNIENoYXJsaWUgRW5nbGFuZCBj ZWVuZ2xhbmQ3QGdtYWlsLmNvbSB3cm90ZTogLS0gS29sYi1MaXN0IG1lc3NhZ2Ug cG9zdGVkIGJ5OiBDaGFybGllIEVuZ2xhbmQgY2VlbmdsYW5kN0BnbWFpbC5jb20g DQ0gT24gOC8yMC8yMDE5IDExOjQwIEFNLCAxM2JydjMgd3JvdGU6DSAgLS0gS29s Yi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiMTNicnYzIiAxM2JydjNAZ21haWwu Y29tDQ0gIEdyZWV0aW5ncywNDSAgSXMgZXZlcnlvbmUgcGF5aW5nICQ1MDAgZm9y IHRoZSBvZmZpY2lhbCBSb3RheCByYWRpYXRvciwgb3IgYXJlIHRoZXJlIG90aGVy IHBvcHVsYXIgb3B0aW9ucz8gIFRoZXJlIGFyZSBhIG51bWJlciBvZiBFYmF5IHJh ZGlhdG9ycyBpbiB0aGUgJDIxMCByYW5nZSB0aGF0IG1lbnRpb24gdGhlIDkxMiwg YW5kIHRoZXkgYXBwZWFyIHRvIGJlIHRoZSByaWdodCBzaXplLCBidXQgbm9uZSBv ZiB0aGVtIGxpc3QgdGhlIGlubGV0IGFuZCBvdXRsZXQgZGlhbWV0ZXIuICBPbmUg c2VsbGVyIGRpZCBzdGF0ZSB0aGF0IGhpcyB3YXMgMjVtbSBpbmxldCwgYW5kIDMw bW0gb3V0bGV0LCBidXQgSSBiZWxpZXZlIHRoZXkgc2hvdWxkIGJvdGggYmUgMjVt bS8xIi4NDSAgQWx1bWludW0gcmFkaWF0b3JzIGFyZW4ndCBleGFjdGx5IHJvY2tl dCBzY2llbmNlLCBhbmQgSSdtIHRlbXB0ZWQgdG8gZ2l2ZSBvbmUgb2YgdGhvc2Ug YSB0cnksIGJ1dCBpdCdzIGZydXN0cmF0aW5nIHRoYXQgSSBoYXZlbid0IGJlZW4g YWJsZSB0byBnZXQgaW5sZXQgYW5kIG91dGxldCBzaXplcyBmb3IgYW55IG9mIHRo ZSBvdGhlcnMgdGhhdCBhcmUgbGlzdGVkLiAgSSBnZXQgdGhlIGltcHJlc3Npb24g dGhlcmUgYXJlIG9ubHkgYWJvdXQgMi0zIGRpZmZlcmVudCByYWRpYXRvcnMgZm9y IGFsbCB0aGUgZG96ZW5zIG9mIGxpc3RpbmdzLCBhbmQgbWF5YmUgb25seSBhIGNv dXBsZSBzZWxsZXJzLCBlYWNoIHdpdGggYSBmZXcgZGlmZmVyZW50IGFsaWFzZXMu DQ0gIFRoYW5rcywNICBSdXN0eQ0gV2h5IG5vdCBqdXN0IGZpbmQgYW4gZWJheSBz cGVjaWFsIG1vdG9yY3ljbGUgcmFkIGZvciBhIDEwMCtocCBiaWtlPyBPciANIGNo ZWNrIGEgY3ljbGUgc2FsdmFnZSB5YXJkLCBpZiB0aGVyZSdzIG9uZSBuZWFyIHlv dS4gRHJhZyBjZXJ0YWlubHkgDSBpc24ndCBhcyBiaWcgYW4gaXNzdWUgYXMgaXQg d2FzIHdpdGggdGhlIC0zLCBzbyBpZiB5b3UgJ2dvIGJpZycgKGFuZCANIHRoaW4p ICBmZWVkIGl0IHdpdGggYSBzaGVldCBtZXRhbCB3ZWRnZSBkaWZmdXNlciwgeW91 IHByZXR0eSBtdWNoIGtub3cgDSBpdCdsbCB3b3JrLiBZb3UgY2FuIGdldCBzaWxp Y29uZSBzaXplIGFkYXB0ZXJzIGZyb20vdG8gYWxtb3N0IGFueSBjb21tb24gDSBk aWFtZXRlciBub3csIHNvIGZpdHRpbmcgc2l6ZSBzaG91bGRuJ3QgYmUgdG9vIG11 Y2ggb2YgYW4gaXNzdWUuIElmIHlvdSANIHdhbnQgdG8gZ28gd2l0aCBhbiBhdXRv IHJhZCwgSUlSQywgYSBzdG9jayBIb25kYSBDaXZpYyByYWQgaXMgYWJvdXQgYW4g DSBpbmNoIHRoaWNrIChtaWdodCBiZSBhIGJpdCB0aGlja2VyKSAgaGFzIH4xIiBm aXR0aW5ncy4NDSBDaGFybGllDQ0gLS0tDSBUaGlzIGVtYWlsIGhhcyBiZWVuIGNo ZWNrZWQgZm9yIHZpcnVzZXMgYnkgQXZhc3QgYW50aXZpcnVzIHNvZnR3YXJlLg0g aHR0cHM6Ly93d3cuYXZhc3QuY29tL2FudGl2aXJ1cw0NID09PT09PT09PT09DSAt TGlzdCIgcmVsPSJub3JlZmVycmVyIiB0YXJnZXQ9Il9ibGFuayJodHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0tvbGItTGlzdA0gPT09PT09PT09PT0N IEZPUlVNUyAtDSBlZmVycmVyIiB0YXJnZXQ9Il9ibGFuayJodHRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20NID09PT09PT09PT09DSBXSUtJIC0NIGVycmVyIiB0YXJn ZXQ9Il9ibGFuayJodHRwOi8vd2lraS5tYXRyb25pY3MuY29tDSA9PT09PT09PT09 PQ0gYiBTaXRlIC0NICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4u DSByZWw9Im5vcmVmZXJyZXIiIHRhcmdldD0iX2JsYW5rImh0dHA6Ly93d3cubWF0 cm9uaWNzLmNvbS9jb250cmlidXRpb24NID09PT09PT09PT09DQ0gDQ0gICANDSAg LS0gDQ0NDQ0NDQ0NDQ0NDQ0NQ2h1Y2sgUmlsZXkNIFJDUiBMaWdodCBBaXJjcmFm dA0gT2ZmaWNlIDogNTU5LTIyNC04ODQxDSBDZWxsOiA1NTktNDkzLTAzMzgNDSAg ICAgICAgICA ________________________________________________________________________________
Date: Aug 20, 2019
ICAgVW5zdWJzY3JpYmUNDSAtLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0tLQ0gRnJv bTogIkFsdmluIExpbmRhIEpvbmVzIiBham9uZXNAZGZuLmNvbQ0gU2VudDogOC8y MC8yMDE5IDQ6MjU6NDggUE0NIFRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQ0g U3ViamVjdDogS29sYi1MaXN0OiBSZTogVW5zdWJzY3JpYmUNDSBVbnN1YnNjcmli ZQ0NIC0tLS0gT3JpZ2luYWwgTWVzc2FnZSAtLS0tDSBGcm9tOiAiQWx2aW4gTGlu ZGEgSm9uZXMiIGFqb25lc0BkZm4uY29tDSBTZW50OiA4LzIwLzIwMTkgNDoxNDow OSBQTQ0gVG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29tDSBTdWJqZWN0OiBLb2xi LUxpc3Q6IFJlOiBSZTogdW5zdWJzY3JpYmUNDSBVbnN1YnNjcmliZQ0NIC0tLS0g T3JpZ2luYWwgTWVzc2FnZSAtLS0tDSBGcm9tOiAiQWx2aW4gTGluZGEgSm9uZXMi IGFqb25lc0BkZm4uY29tDSBTZW50OiA4LzIwLzIwMTkgNDowNjo0MSBQTQ0gVG86 IGtvbGItbGlzdEBtYXRyb25pY3MuY29tDSBTdWJqZWN0OiBSZTogS29sYi1MaXN0 OiBSZTogdW5zdWJzY3JpYmUNDSANDSAtLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0t LQ0gRnJvbTogIkFsdmluIExpbmRhIEpvbmVzIiBham9uZXNAZGZuLmNvbQ0gU2Vu dDogOC8yMC8yMDE5IDQ6MDI6NDIgUE0NIFRvOiBrb2xiLWxpc3RAbWF0cm9uaWNz LmNvbQ0gU3ViamVjdDogS29sYi1MaXN0OiBSZTogdW5zdWJzY3JpYmUNDSBVbnN1 YnNjcmliZQ0NIC0tLS0gT3JpZ2luYWwgTWVzc2FnZSAtLS0tDSBGcm9tOiAiTGlu ZGEgSm9uZXMiIGFqb25lc0BkZm4uY29tDSBTZW50OiA4LzIwLzIwMTkgMzo1Njox NCBQTQ0gVG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29tDSBTdWJqZWN0OiBSZTog S29sYi1MaXN0OiA5MTIgcmFkaWF0b3I/DQ0gDQ0NDURpc2NvbnRpbnVlICANDU9u IEF1ZyAyMCwgMjAxOSwgYXQgMToyMSBQTSwgUnVkb2xwaCBSaWxleSBycmlsZXkz NTFAZ21haWwuY29tIHdyb3RlOg0NICAgDQ0NDUkgaGF2ZSBzb21lIDU4MiByYWRp YXRvcnMgYW5kIGVuZ2luZSBhbmQgcHJvcCBJIG5vcCBsb25nZXIgaGF2ZSBhIHVz ZSBmb3IgDQ1DaHVjayBSaWxleSA1NTktNDkzLTAzMzggDQ1SQ1IgTGlnaHQgQWly Y3JhZnQgZm9ybWVyIFRpdGFuIGRlYWxlciAgIA0NDQ0NT24gVHVlLCBBdWcgMjAs IDIwMTkgYXQgMTE6MDQgQU0gQ2hhcmxpZSBFbmdsYW5kIGNlZW5nbGFuZDdAZ21h aWwuY29tIHdyb3RlOiAtLSBLb2xiLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IENo YXJsaWUgRW5nbGFuZCBjZWVuZ2xhbmQ3QGdtYWlsLmNvbSANDSBPbiA4LzIwLzIw MTkgMTE6NDAgQU0sIDEzYnJ2MyB3cm90ZToNICAtLSBLb2xiLUxpc3QgbWVzc2Fn ZSBwb3N0ZWQgYnk6ICIxM2JydjMiIDEzYnJ2M0BnbWFpbC5jb20NDSAgR3JlZXRp bmdzLA0NICBJcyBldmVyeW9uZSBwYXlpbmcgJDUwMCBmb3IgdGhlIG9mZmljaWFs IFJvdGF4IHJhZGlhdG9yLCBvciBhcmUgdGhlcmUgb3RoZXIgcG9wdWxhciBvcHRp b25zPyAgVGhlcmUgYXJlIGEgbnVtYmVyIG9mIEViYXkgcmFkaWF0b3JzIGluIHRo ZSAkMjEwIHJhbmdlIHRoYXQgbWVudGlvbiB0aGUgOTEyLCBhbmQgdGhleSBhcHBl YXIgdG8gYmUgdGhlIHJpZ2h0IHNpemUsIGJ1dCBub25lIG9mIHRoZW0gbGlzdCB0 aGUgaW5sZXQgYW5kIG91dGxldCBkaWFtZXRlci4gIE9uZSBzZWxsZXIgZGlkIHN0 YXRlIHRoYXQgaGlzIHdhcyAyNW1tIGlubGV0LCBhbmQgMzBtbSBvdXRsZXQsIGJ1 dCBJIGJlbGlldmUgdGhleSBzaG91bGQgYm90aCBiZSAyNW1tLzEiLg0NICBBbHVt aW51bSByYWRpYXRvcnMgYXJlbid0IGV4YWN0bHkgcm9ja2V0IHNjaWVuY2UsIGFu ZCBJJ20gdGVtcHRlZCB0byBnaXZlIG9uZSBvZiB0aG9zZSBhIHRyeSwgYnV0IGl0 J3MgZnJ1c3RyYXRpbmcgdGhhdCBJIGhhdmVuJ3QgYmVlbiBhYmxlIHRvIGdldCBp bmxldCBhbmQgb3V0bGV0IHNpemVzIGZvciBhbnkgb2YgdGhlIG90aGVycyB0aGF0 IGFyZSBsaXN0ZWQuICBJIGdldCB0aGUgaW1wcmVzc2lvbiB0aGVyZSBhcmUgb25s eSBhYm91dCAyLTMgZGlmZmVyZW50IHJhZGlhdG9ycyBmb3IgYWxsIHRoZSBkb3pl bnMgb2YgbGlzdGluZ3MsIGFuZCBtYXliZSBvbmx5IGEgY291cGxlIHNlbGxlcnMs IGVhY2ggd2l0aCBhIGZldyBkaWZmZXJlbnQgYWxpYXNlcy4NDSAgVGhhbmtzLA0g IFJ1c3R5DSBXaHkgbm90IGp1c3QgZmluZCBhbiBlYmF5IHNwZWNpYWwgbW90b3Jj eWNsZSByYWQgZm9yIGEgMTAwK2hwIGJpa2U/IE9yIA0gY2hlY2sgYSBjeWNsZSBz YWx2YWdlIHlhcmQsIGlmIHRoZXJlJ3Mgb25lIG5lYXIgeW91LiBEcmFnIGNlcnRh aW5seSANIGlzbid0IGFzIGJpZyBhbiBpc3N1ZSBhcyBpdCB3YXMgd2l0aCB0aGUg LTMsIHNvIGlmIHlvdSAnZ28gYmlnJyAoYW5kIA0gdGhpbikgIGZlZWQgaXQgd2l0 aCBhIHNoZWV0IG1ldGFsIHdlZGdlIGRpZmZ1c2VyLCB5b3UgcHJldHR5IG11Y2gg a25vdyANIGl0J2xsIHdvcmsuIFlvdSBjYW4gZ2V0IHNpbGljb25lIHNpemUgYWRh cHRlcnMgZnJvbS90byBhbG1vc3QgYW55IGNvbW1vbiANIGRpYW1ldGVyIG5vdywg c28gZml0dGluZyBzaXplIHNob3VsZG4ndCBiZSB0b28gbXVjaCBvZiBhbiBpc3N1 ZS4gSWYgeW91IA0gd2FudCB0byBnbyB3aXRoIGFuIGF1dG8gcmFkLCBJSVJDLCBh IHN0b2NrIEhvbmRhIENpdmljIHJhZCBpcyBhYm91dCBhbiANIGluY2ggdGhpY2sg KG1pZ2h0IGJlIGEgYml0IHRoaWNrZXIpICBoYXMgfjEiIGZpdHRpbmdzLg0NIENo YXJsaWUNDSAtLS0NIFRoaXMgZW1haWwgaGFzIGJlZW4gY2hlY2tlZCBmb3Igdmly dXNlcyBieSBBdmFzdCBhbnRpdmlydXMgc29mdHdhcmUuDSBodHRwczovL3d3dy5h dmFzdC5jb20vYW50aXZpcnVzDQ0gPT09PT09PT09PT0NIC1MaXN0IiByZWw9Im5v cmVmZXJyZXIiIHRhcmdldD0iX2JsYW5rImh0dHA6Ly93d3cubWF0cm9uaWNzLmNv bS9OYXZpZ2F0b3I/S29sYi1MaXN0DSA9PT09PT09PT09PQ0gRk9SVU1TIC0NIGVm ZXJyZXIiIHRhcmdldD0iX2JsYW5rImh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNv bQ0gPT09PT09PT09PT0NIFdJS0kgLQ0gZXJyZXIiIHRhcmdldD0iX2JsYW5rImh0 dHA6Ly93aWtpLm1hdHJvbmljcy5jb20NID09PT09PT09PT09DSBiIFNpdGUgLQ0g ICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NIHJlbD0ibm9yZWZl cnJlciIgdGFyZ2V0PSJfYmxhbmsiaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2Nv bnRyaWJ1dGlvbg0gPT09PT09PT09PT0NDSANDSAgIA0NICAtLSANDQ0NDQ0NDQ0N DQ0NDQ1DaHVjayBSaWxleQ0gUkNSIExpZ2h0IEFpcmNyYWZ0DSBPZmZpY2UgOiA1 NTktMjI0LTg4NDENIENlbGw6IDU1OS00OTMtMDMzOA0NICAgICAgICAgIA= ________________________________________________________________________________
Date: Aug 20, 2019
ICAgVW5zdWJzY3JpYmUNDSAtLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0tLQ0gRnJv bTogIkFsdmluIExpbmRhIEpvbmVzIiBham9uZXNAZGZuLmNvbQ0gU2VudDogOC8y MC8yMDE5IDQ6MzA6MjIgUE0NIFRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQ0g U3ViamVjdDogS29sYi1MaXN0OiBSZTogVW5zdWJzY3JpYmUNDSBVbnN1YnNjcmli ZQ0NIC0tLS0gT3JpZ2luYWwgTWVzc2FnZSAtLS0tDSBGcm9tOiAiQWx2aW4gTGlu ZGEgSm9uZXMiIGFqb25lc0BkZm4uY29tDSBTZW50OiA4LzIwLzIwMTkgNDoyNTo0 OCBQTQ0gVG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29tDSBTdWJqZWN0OiBLb2xi LUxpc3Q6IFJlOiBVbnN1YnNjcmliZQ0NIFVuc3Vic2NyaWJlDQ0gLS0tLSBPcmln aW5hbCBNZXNzYWdlIC0tLS0NIEZyb206ICJBbHZpbiBMaW5kYSBKb25lcyIgYWpv bmVzQGRmbi5jb20NIFNlbnQ6IDgvMjAvMjAxOSA0OjE0OjA5IFBNDSBUbzoga29s Yi1saXN0QG1hdHJvbmljcy5jb20NIFN1YmplY3Q6IEtvbGItTGlzdDogUmU6IFJl OiB1bnN1YnNjcmliZQ0NIFVuc3Vic2NyaWJlDQ0gLS0tLSBPcmlnaW5hbCBNZXNz YWdlIC0tLS0NIEZyb206ICJBbHZpbiBMaW5kYSBKb25lcyIgYWpvbmVzQGRmbi5j b20NIFNlbnQ6IDgvMjAvMjAxOSA0OjA2OjQxIFBNDSBUbzoga29sYi1saXN0QG1h dHJvbmljcy5jb20NIFN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IFJlOiB1bnN1YnNj cmliZQ0NIA0NIC0tLS0gT3JpZ2luYWwgTWVzc2FnZSAtLS0tDSBGcm9tOiAiQWx2 aW4gTGluZGEgSm9uZXMiIGFqb25lc0BkZm4uY29tDSBTZW50OiA4LzIwLzIwMTkg NDowMjo0MiBQTQ0gVG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29tDSBTdWJqZWN0 OiBLb2xiLUxpc3Q6IFJlOiB1bnN1YnNjcmliZQ0NIFVuc3Vic2NyaWJlDQ0gLS0t LSBPcmlnaW5hbCBNZXNzYWdlIC0tLS0NIEZyb206ICJMaW5kYSBKb25lcyIgYWpv bmVzQGRmbi5jb20NIFNlbnQ6IDgvMjAvMjAxOSAzOjU2OjE0IFBNDSBUbzoga29s Yi1saXN0QG1hdHJvbmljcy5jb20NIFN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IDkx MiByYWRpYXRvcj8NDSANDQ0NRGlzY29udGludWUgIA0NT24gQXVnIDIwLCAyMDE5 LCBhdCAxOjIxIFBNLCBSdWRvbHBoIFJpbGV5IHJyaWxleTM1MUBnbWFpbC5jb20g d3JvdGU6DQ0gICANDQ0NSSBoYXZlIHNvbWUgNTgyIHJhZGlhdG9ycyBhbmQgZW5n aW5lIGFuZCBwcm9wIEkgbm9wIGxvbmdlciBoYXZlIGEgdXNlIGZvciANDUNodWNr IFJpbGV5IDU1OS00OTMtMDMzOCANDVJDUiBMaWdodCBBaXJjcmFmdCBmb3JtZXIg VGl0YW4gZGVhbGVyICAgDQ0NDQ1PbiBUdWUsIEF1ZyAyMCwgMjAxOSBhdCAxMTow NCBBTSBDaGFybGllIEVuZ2xhbmQgY2VlbmdsYW5kN0BnbWFpbC5jb20gd3JvdGU6 IC0tIEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogQ2hhcmxpZSBFbmdsYW5k IGNlZW5nbGFuZDdAZ21haWwuY29tIA0NIE9uIDgvMjAvMjAxOSAxMTo0MCBBTSwg MTNicnYzIHdyb3RlOg0gIC0tIEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieTog IjEzYnJ2MyIgMTNicnYzQGdtYWlsLmNvbQ0NICBHcmVldGluZ3MsDQ0gIElzIGV2 ZXJ5b25lIHBheWluZyAkNTAwIGZvciB0aGUgb2ZmaWNpYWwgUm90YXggcmFkaWF0 b3IsIG9yIGFyZSB0aGVyZSBvdGhlciBwb3B1bGFyIG9wdGlvbnM/ICBUaGVyZSBh cmUgYSBudW1iZXIgb2YgRWJheSByYWRpYXRvcnMgaW4gdGhlICQyMTAgcmFuZ2Ug dGhhdCBtZW50aW9uIHRoZSA5MTIsIGFuZCB0aGV5IGFwcGVhciB0byBiZSB0aGUg cmlnaHQgc2l6ZSwgYnV0IG5vbmUgb2YgdGhlbSBsaXN0IHRoZSBpbmxldCBhbmQg b3V0bGV0IGRpYW1ldGVyLiAgT25lIHNlbGxlciBkaWQgc3RhdGUgdGhhdCBoaXMg d2FzIDI1bW0gaW5sZXQsIGFuZCAzMG1tIG91dGxldCwgYnV0IEkgYmVsaWV2ZSB0 aGV5IHNob3VsZCBib3RoIGJlIDI1bW0vMSIuDQ0gIEFsdW1pbnVtIHJhZGlhdG9y cyBhcmVuJ3QgZXhhY3RseSByb2NrZXQgc2NpZW5jZSwgYW5kIEknbSB0ZW1wdGVk IHRvIGdpdmUgb25lIG9mIHRob3NlIGEgdHJ5LCBidXQgaXQncyBmcnVzdHJhdGlu ZyB0aGF0IEkgaGF2ZW4ndCBiZWVuIGFibGUgdG8gZ2V0IGlubGV0IGFuZCBvdXRs ZXQgc2l6ZXMgZm9yIGFueSBvZiB0aGUgb3RoZXJzIHRoYXQgYXJlIGxpc3RlZC4g IEkgZ2V0IHRoZSBpbXByZXNzaW9uIHRoZXJlIGFyZSBvbmx5IGFib3V0IDItMyBk aWZmZXJlbnQgcmFkaWF0b3JzIGZvciBhbGwgdGhlIGRvemVucyBvZiBsaXN0aW5n cywgYW5kIG1heWJlIG9ubHkgYSBjb3VwbGUgc2VsbGVycywgZWFjaCB3aXRoIGEg ZmV3IGRpZmZlcmVudCBhbGlhc2VzLg0NICBUaGFua3MsDSAgUnVzdHkNIFdoeSBu b3QganVzdCBmaW5kIGFuIGViYXkgc3BlY2lhbCBtb3RvcmN5Y2xlIHJhZCBmb3Ig YSAxMDAraHAgYmlrZT8gT3IgDSBjaGVjayBhIGN5Y2xlIHNhbHZhZ2UgeWFyZCwg aWYgdGhlcmUncyBvbmUgbmVhciB5b3UuIERyYWcgY2VydGFpbmx5IA0gaXNuJ3Qg YXMgYmlnIGFuIGlzc3VlIGFzIGl0IHdhcyB3aXRoIHRoZSAtMywgc28gaWYgeW91 ICdnbyBiaWcnIChhbmQgDSB0aGluKSAgZmVlZCBpdCB3aXRoIGEgc2hlZXQgbWV0 YWwgd2VkZ2UgZGlmZnVzZXIsIHlvdSBwcmV0dHkgbXVjaCBrbm93IA0gaXQnbGwg d29yay4gWW91IGNhbiBnZXQgc2lsaWNvbmUgc2l6ZSBhZGFwdGVycyBmcm9tL3Rv IGFsbW9zdCBhbnkgY29tbW9uIA0gZGlhbWV0ZXIgbm93LCBzbyBmaXR0aW5nIHNp emUgc2hvdWxkbid0IGJlIHRvbyBtdWNoIG9mIGFuIGlzc3VlLiBJZiB5b3UgDSB3 YW50IHRvIGdvIHdpdGggYW4gYXV0byByYWQsIElJUkMsIGEgc3RvY2sgSG9uZGEg Q2l2aWMgcmFkIGlzIGFib3V0IGFuIA0gaW5jaCB0aGljayAobWlnaHQgYmUgYSBi aXQgdGhpY2tlcikgIGhhcyB+MSIgZml0dGluZ3MuDQ0gQ2hhcmxpZQ0NIC0tLQ0g VGhpcyBlbWFpbCBoYXMgYmVlbiBjaGVja2VkIGZvciB2aXJ1c2VzIGJ5IEF2YXN0 IGFudGl2aXJ1cyBzb2Z0d2FyZS4NIGh0dHBzOi8vd3d3LmF2YXN0LmNvbS9hbnRp dmlydXMNDSA9PT09PT09PT09PQ0gLUxpc3QiIHJlbD0ibm9yZWZlcnJlciIgdGFy Z2V0PSJfYmxhbmsiaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9L b2xiLUxpc3QNID09PT09PT09PT09DSBGT1JVTVMgLQ0gZWZlcnJlciIgdGFyZ2V0 PSJfYmxhbmsiaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDSA9PT09PT09PT09 PQ0gV0lLSSAtDSBlcnJlciIgdGFyZ2V0PSJfYmxhbmsiaHR0cDovL3dpa2kubWF0 cm9uaWNzLmNvbQ0gPT09PT09PT09PT0NIGIgU2l0ZSAtDSAgICAgICAgICAgLU1h dHQgRHJhbGxlLCBMaXN0IEFkbWluLg0gcmVsPSJub3JlZmVycmVyIiB0YXJnZXQ9 Il9ibGFuayJodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDSA9 PT09PT09PT09PQ0NIA0NICAgDQ0gIC0tIA0NDQ0NDQ0NDQ0NDQ0NDUNodWNrIFJp bGV5DSBSQ1IgTGlnaHQgQWlyY3JhZnQNIE9mZmljZSA6IDU1OS0yMjQtODg0MQ0g Q2VsbDogNTU5LTQ5My0wMzM4DQ0gICAgICAgICAg ________________________________________________________________________________
Date: Aug 20, 2019
ICAgDSBVbnN1YnNjcmliZQ0gLS0tLSBPcmlnaW5hbCBNZXNzYWdlIC0tLS0NIEZy b206ICJBbHZpbiBMaW5kYSBKb25lcyIgYWpvbmVzQGRmbi5jb20NIFNlbnQ6IDgv MjAvMjAxOSA0OjM0OjM5IFBNDSBUbzoga29sYi1saXN0QG1hdHJvbmljcy5jb20N IFN1YmplY3Q6IEtvbGItTGlzdDogUmU6IFVuc3Vic2NyaWJlDQ0gVW5zdWJzY3Jp YmUNDSAtLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0tLQ0gRnJvbTogIkFsdmluIExp bmRhIEpvbmVzIiBham9uZXNAZGZuLmNvbQ0gU2VudDogOC8yMC8yMDE5IDQ6MzA6 MjIgUE0NIFRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQ0gU3ViamVjdDogS29s Yi1MaXN0OiBSZTogVW5zdWJzY3JpYmUNDSBVbnN1YnNjcmliZQ0NIC0tLS0gT3Jp Z2luYWwgTWVzc2FnZSAtLS0tDSBGcm9tOiAiQWx2aW4gTGluZGEgSm9uZXMiIGFq b25lc0BkZm4uY29tDSBTZW50OiA4LzIwLzIwMTkgNDoyNTo0OCBQTQ0gVG86IGtv bGItbGlzdEBtYXRyb25pY3MuY29tDSBTdWJqZWN0OiBLb2xiLUxpc3Q6IFJlOiBV bnN1YnNjcmliZQ0NIFVuc3Vic2NyaWJlDQ0gLS0tLSBPcmlnaW5hbCBNZXNzYWdl IC0tLS0NIEZyb206ICJBbHZpbiBMaW5kYSBKb25lcyIgYWpvbmVzQGRmbi5jb20N IFNlbnQ6IDgvMjAvMjAxOSA0OjE0OjA5IFBNDSBUbzoga29sYi1saXN0QG1hdHJv bmljcy5jb20NIFN1YmplY3Q6IEtvbGItTGlzdDogUmU6IFJlOiB1bnN1YnNjcmli ZQ0NIFVuc3Vic2NyaWJlDQ0gLS0tLSBPcmlnaW5hbCBNZXNzYWdlIC0tLS0NIEZy b206ICJBbHZpbiBMaW5kYSBKb25lcyIgYWpvbmVzQGRmbi5jb20NIFNlbnQ6IDgv MjAvMjAxOSA0OjA2OjQxIFBNDSBUbzoga29sYi1saXN0QG1hdHJvbmljcy5jb20N IFN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IFJlOiB1bnN1YnNjcmliZQ0NIA0NIC0t LS0gT3JpZ2luYWwgTWVzc2FnZSAtLS0tDSBGcm9tOiAiQWx2aW4gTGluZGEgSm9u ZXMiIGFqb25lc0BkZm4uY29tDSBTZW50OiA4LzIwLzIwMTkgNDowMjo0MiBQTQ0g VG86IGtvbGItbGlzdEBtYXRyb25pY3MuY29tDSBTdWJqZWN0OiBLb2xiLUxpc3Q6 IFJlOiB1bnN1YnNjcmliZQ0NIFVuc3Vic2NyaWJlDQ0gLS0tLSBPcmlnaW5hbCBN ZXNzYWdlIC0tLS0NIEZyb206ICJMaW5kYSBKb25lcyIgYWpvbmVzQGRmbi5jb20N IFNlbnQ6IDgvMjAvMjAxOSAzOjU2OjE0IFBNDSBUbzoga29sYi1saXN0QG1hdHJv bmljcy5jb20NIFN1YmplY3Q6IFJlOiBLb2xiLUxpc3Q6IDkxMiByYWRpYXRvcj8N DSANDQ0NRGlzY29udGludWUgIA0NT24gQXVnIDIwLCAyMDE5LCBhdCAxOjIxIFBN LCBSdWRvbHBoIFJpbGV5IHJyaWxleTM1MUBnbWFpbC5jb20gd3JvdGU6DQ0gICAN DQ0NSSBoYXZlIHNvbWUgNTgyIHJhZGlhdG9ycyBhbmQgZW5naW5lIGFuZCBwcm9w IEkgbm9wIGxvbmdlciBoYXZlIGEgdXNlIGZvciANDUNodWNrIFJpbGV5IDU1OS00 OTMtMDMzOCANDVJDUiBMaWdodCBBaXJjcmFmdCBmb3JtZXIgVGl0YW4gZGVhbGVy ICAgDQ0NDQ1PbiBUdWUsIEF1ZyAyMCwgMjAxOSBhdCAxMTowNCBBTSBDaGFybGll IEVuZ2xhbmQgY2VlbmdsYW5kN0BnbWFpbC5jb20gd3JvdGU6IC0tIEtvbGItTGlz dCBtZXNzYWdlIHBvc3RlZCBieTogQ2hhcmxpZSBFbmdsYW5kIGNlZW5nbGFuZDdA Z21haWwuY29tIA0NIE9uIDgvMjAvMjAxOSAxMTo0MCBBTSwgMTNicnYzIHdyb3Rl Og0gIC0tIEtvbGItTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIjEzYnJ2MyIgMTNi cnYzQGdtYWlsLmNvbQ0NICBHcmVldGluZ3MsDQ0gIElzIGV2ZXJ5b25lIHBheWlu ZyAkNTAwIGZvciB0aGUgb2ZmaWNpYWwgUm90YXggcmFkaWF0b3IsIG9yIGFyZSB0 aGVyZSBvdGhlciBwb3B1bGFyIG9wdGlvbnM/ICBUaGVyZSBhcmUgYSBudW1iZXIg b2YgRWJheSByYWRpYXRvcnMgaW4gdGhlICQyMTAgcmFuZ2UgdGhhdCBtZW50aW9u IHRoZSA5MTIsIGFuZCB0aGV5IGFwcGVhciB0byBiZSB0aGUgcmlnaHQgc2l6ZSwg YnV0IG5vbmUgb2YgdGhlbSBsaXN0IHRoZSBpbmxldCBhbmQgb3V0bGV0IGRpYW1l dGVyLiAgT25lIHNlbGxlciBkaWQgc3RhdGUgdGhhdCBoaXMgd2FzIDI1bW0gaW5s ZXQsIGFuZCAzMG1tIG91dGxldCwgYnV0IEkgYmVsaWV2ZSB0aGV5IHNob3VsZCBi b3RoIGJlIDI1bW0vMSIuDQ0gIEFsdW1pbnVtIHJhZGlhdG9ycyBhcmVuJ3QgZXhh Y3RseSByb2NrZXQgc2NpZW5jZSwgYW5kIEknbSB0ZW1wdGVkIHRvIGdpdmUgb25l IG9mIHRob3NlIGEgdHJ5LCBidXQgaXQncyBmcnVzdHJhdGluZyB0aGF0IEkgaGF2 ZW4ndCBiZWVuIGFibGUgdG8gZ2V0IGlubGV0IGFuZCBvdXRsZXQgc2l6ZXMgZm9y IGFueSBvZiB0aGUgb3RoZXJzIHRoYXQgYXJlIGxpc3RlZC4gIEkgZ2V0IHRoZSBp bXByZXNzaW9uIHRoZXJlIGFyZSBvbmx5IGFib3V0IDItMyBkaWZmZXJlbnQgcmFk aWF0b3JzIGZvciBhbGwgdGhlIGRvemVucyBvZiBsaXN0aW5ncywgYW5kIG1heWJl IG9ubHkgYSBjb3VwbGUgc2VsbGVycywgZWFjaCB3aXRoIGEgZmV3IGRpZmZlcmVu dCBhbGlhc2VzLg0NICBUaGFua3MsDSAgUnVzdHkNIFdoeSBub3QganVzdCBmaW5k IGFuIGViYXkgc3BlY2lhbCBtb3RvcmN5Y2xlIHJhZCBmb3IgYSAxMDAraHAgYmlr ZT8gT3IgDSBjaGVjayBhIGN5Y2xlIHNhbHZhZ2UgeWFyZCwgaWYgdGhlcmUncyBv bmUgbmVhciB5b3UuIERyYWcgY2VydGFpbmx5IA0gaXNuJ3QgYXMgYmlnIGFuIGlz c3VlIGFzIGl0IHdhcyB3aXRoIHRoZSAtMywgc28gaWYgeW91ICdnbyBiaWcnIChh bmQgDSB0aGluKSAgZmVlZCBpdCB3aXRoIGEgc2hlZXQgbWV0YWwgd2VkZ2UgZGlm ZnVzZXIsIHlvdSBwcmV0dHkgbXVjaCBrbm93IA0gaXQnbGwgd29yay4gWW91IGNh biBnZXQgc2lsaWNvbmUgc2l6ZSBhZGFwdGVycyBmcm9tL3RvIGFsbW9zdCBhbnkg Y29tbW9uIA0gZGlhbWV0ZXIgbm93LCBzbyBmaXR0aW5nIHNpemUgc2hvdWxkbid0 IGJlIHRvbyBtdWNoIG9mIGFuIGlzc3VlLiBJZiB5b3UgDSB3YW50IHRvIGdvIHdp dGggYW4gYXV0byByYWQsIElJUkMsIGEgc3RvY2sgSG9uZGEgQ2l2aWMgcmFkIGlz IGFib3V0IGFuIA0gaW5jaCB0aGljayAobWlnaHQgYmUgYSBiaXQgdGhpY2tlcikg IGhhcyB+MSIgZml0dGluZ3MuDQ0gQ2hhcmxpZQ0NIC0tLQ0gVGhpcyBlbWFpbCBo YXMgYmVlbiBjaGVja2VkIGZvciB2aXJ1c2VzIGJ5IEF2YXN0IGFudGl2aXJ1cyBz b2Z0d2FyZS4NIGh0dHBzOi8vd3d3LmF2YXN0LmNvbS9hbnRpdmlydXMNDSA9PT09 PT09PT09PQ0gLUxpc3QiIHJlbD0ibm9yZWZlcnJlciIgdGFyZ2V0PSJfYmxhbmsi aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Lb2xiLUxpc3QNID09 PT09PT09PT09DSBGT1JVTVMgLQ0gZWZlcnJlciIgdGFyZ2V0PSJfYmxhbmsiaHR0 cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDSA9PT09PT09PT09PQ0gV0lLSSAtDSBl cnJlciIgdGFyZ2V0PSJfYmxhbmsiaHR0cDovL3dpa2kubWF0cm9uaWNzLmNvbQ0g PT09PT09PT09PT0NIGIgU2l0ZSAtDSAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBM aXN0IEFkbWluLg0gcmVsPSJub3JlZmVycmVyIiB0YXJnZXQ9Il9ibGFuayJodHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDSA9PT09PT09PT09PQ0N IA0NICAgDQ0gIC0tIA0NDQ0NDQ0NDQ0NDQ0NDUNodWNrIFJpbGV5DSBSQ1IgTGln aHQgQWlyY3JhZnQNIE9mZmljZSA6IDU1OS0yMjQtODg0MQ0gQ2VsbDogNTU5LTQ5 My0wMzM4DQ0gICAgICAgICAg ________________________________________________________________________________
Date: Aug 20, 2019
You can unsubscribe the same way you subscribed. We aren=99t your mot her On Tue, Aug 20, 2019 at 6:34 PM Alvin Linda Jones wrote: > Unsubscribe > > ---- Original Message ---- > From: "Alvin Linda Jones" <ajones(at)dfn.com> > Sent: 8/20/2019 4:30:22 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: Unsubscribe > > Unsubscribe > > ---- Original Message ---- > From: "Alvin Linda Jones" <ajones(at)dfn.com> > Sent: 8/20/2019 4:25:48 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: Unsubscribe > > Unsubscribe > > ---- Original Message ---- > From: "Alvin Linda Jones" <ajones(at)dfn.com> > Sent: 8/20/2019 4:14:09 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: Re: unsubscribe > > Unsubscribe > > ---- Original Message ---- > From: "Alvin Linda Jones" <ajones(at)dfn.com> > Sent: 8/20/2019 4:06:41 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: Re: unsubscribe > > > ---- Original Message ---- > From: "Alvin Linda Jones" <ajones(at)dfn.com> > Sent: 8/20/2019 4:02:42 PM > To: kolb-list(at)matronics.com > Subject: Kolb-List: Re: unsubscribe > > Unsubscribe > > ---- Original Message ---- > From: "Linda Jones" <ajones(at)dfn.com> > Sent: 8/20/2019 3:56:14 PM > To: kolb-list(at)matronics.com > Subject: Re: Kolb-List: 912 radiator? > > > Discontinue > On Aug 20, 2019, at 1:21 PM, Rudolph Riley wrote: > > I have some 582 radiators and engine and prop I nop longer have a use for > Chuck Riley 559-493-0338 > RCR Light Aircraft former Titan dealer > > On Tue, Aug 20, 2019 at 11:04 AM Charlie England > wrote: > >> >> On 8/20/2019 11:40 AM, 13brv3 wrote: >> > >> > Greetings, >> > >> > Is everyone paying $500 for the official Rotax radiator, or are there >> other popular options? There are a number of Ebay radiators in the $210 >> range that mention the 912, and they appear to be the right size, but no ne >> of them list the inlet and outlet diameter. One seller did state that h is >> was 25mm inlet, and 30mm outlet, but I believe they should both be 25mm/ 1". >> > >> > Aluminum radiators aren't exactly rocket science, and I'm tempted to >> give one of those a try, but it's frustrating that I haven't been able t o >> get inlet and outlet sizes for any of the others that are listed. I get >> the impression there are only about 2-3 different radiators for all the >> dozens of listings, and maybe only a couple sellers, each with a few >> different aliases. >> > >> > Thanks, >> > Rusty >> Why not just find an ebay special motorcycle rad for a 100+hp bike? Or >> check a cycle salvage yard, if there's one near you. Drag certainly >> isn't as big an issue as it was with the -3, so if you 'go big' (and >> thin) & feed it with a sheet metal wedge diffuser, you pretty much know >> it'll work. You can get silicone size adapters from/to almost any common >> diameter now, so fitting size shouldn't be too much of an issue. If you >> want to go with an auto rad, IIRC, a stock Honda Civic rad is about an >> inch thick (might be a bit thicker) & has ~1" fittings. >> >> Charlie >> >> --- >> This email has been checked for viruses by Avast antivirus software. >> https://www.avast.com/antivirus >> >> ========== >> -List" rel="noreferrer" target="_blank"> >> http://www.matronics.com/Navigator?Kolb-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributi on >> ========== >> >> >> >> > > -- > > > *Chuck Riley * > *RCR Light Aircraft *Office : 559-224-8841 > Cell: 559-493-0338 > > ________________________________________________________________________________
Date: Aug 20, 2019
And Bob's yur uncle. https://www.ebay.com/itm/Motorcycle-Parts-Replacement-Engine-Cooling-Radiator-For-Honda-CBR600RR-2003-06/173297685160?fits=Make%3AHonda&epid=4007796152&hash=item285958d2a8:g:BNoAAOSwIVxdR-pB https://www.ebay.com/itm/Motorcycle-Aluminium-Replacement-Engine-Cooling-Radiator-for-Honda-VTR250-97-07/183743581775?hash=item2ac7f88e4f:g:2AIAAOSw-QBcLHCI https://www.ebay.com/itm/Motorcycle-Parts-Engine-Cooling-Radiator-for-Honda-CBR600RR-07-15-CBR600RA-09-15/173760040889?fits=Make%3AHonda&epid=24028443614&hash=item2874e7cfb9:g:IuUAAOSwy5xdQWM8 https://www.ebay.com/itm/For-Honda-CB1000-94-95-Motorcycle-Parts-Aluminum-Cooler-Engine-Cooling-Radiator/183653486876?epid=19028435603&hash=item2ac299d11c:g:hKoAAOSwXWZdSUaX -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490983#490983 ________________________________________________________________________________
Date: Aug 21, 2019
30 mm means it's made in Austria and imported. That is 1 1/8 in American. A standard 1" heater hose will be snug. Respectfully, Dennis Baber Cape Coral, Fl baberdk(at)gmail.com 305-814-7218 Stay Curious ________________________________________________________________________________
Date: Aug 21, 2019
30 mm means it's made in Austria and imported. That is 1 1/8 in American. A standard 1" heater hose will be snug Closer to 1 3/16 > > ________________________________________________________________________________
Date: Aug 21, 2019
Thanks, I looked at some bike radiators last night, and had never seen curved radiators before. In the mean time, I've all but confirmed that this radiator is very similar to the $500 Rotax unit, with 25mm inlet and outlet, so I think I'll give it a try. https://www.ebay.com/itm/Aircraft-Drone-Rotax-912-914-Viking-Suzuki-Aeromomentum-ALUMINUM-RADIATOR/273379324254?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 Thanks. I think I'm all set. Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490986#490986 ________________________________________________________________________________
Date: Aug 21, 2019
MSIgPSAyNS40IG1tDQoNCmpvaG4gaA0KbWtJSUkNClRpdHVzLCBBbGFiYW1hDQoNCkZyb206IG93 bmVyLWtvbGItbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBbbWFpbHRvOm93bmVyLWtvbGItbGlz dC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24gQmVoYWxmIE9mIEIgWW91bmcNClNlbnQ6IFdlZG5l c2RheSwgQXVndXN0IDIxLCAyMDE5IDk6NDAgQU0NClRvOiBLb2xiIExpc3QNClN1YmplY3Q6IFJl OiBLb2xiLUxpc3Q6IDkxMiByYWRpYXRvcj8NCg0KMzAgbW0gbWVhbnMgaXQncyBtYWRlIGluIEF1 c3RyaWEgYW5kIGltcG9ydGVkLiBUaGF0IGlzIDEgMS84IGluIEFtZXJpY2FuLiBBIHN0YW5kYXJk IDEiIGhlYXRlciBob3NlIHdpbGwgYmUgc251Zw0KDQpDbG9zZXIgdG8NCjEgIDMvMTYNCg0K ________________________________________________________________________________
Date: Aug 21, 2019
Are you running a 912UL or 9112ULS? 80 hp 912 requires very little cooling. I used to bypass my engine oil cooler completely in the winter in Alabama, summer in Northern Canada and Alaska. 912ULS was just the opposite. Took a lot of cooling to keep it happy. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of 13brv3 Sent: Wednesday, August 21, 2019 9:51 AM Subject: Kolb-List: Re: 912 radiator? Thanks, I looked at some bike radiators last night, and had never seen curved radiators before. In the mean time, I've all but confirmed that this radiator is very similar to the $500 Rotax unit, with 25mm inlet and outlet, so I think I'll give it a try. https://www.ebay.com/itm/Aircraft-Drone-Rotax-912-914-Viking-Suzuki-Aeromomentum-ALUMINUM-RADIATOR/273379324254?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 Thanks. I think I'm all set. Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490986#490986 ________________________________________________________________________________
Date: Aug 21, 2019
Interesting about the difference. Mine is an 80hp UL. I'm starting with the small oil cooler, and was trying to stick with pretty much the standard radiator size. I'm just a bit north of you in TN. Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490992#490992 ________________________________________________________________________________
Date: Aug 21, 2019
Higher compression ratio. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of 13brv3 Sent: Wednesday, August 21, 2019 4:48 PM Subject: Kolb-List: Re: 912 radiator? Interesting about the difference. Mine is an 80hp UL. I'm starting with the small oil cooler, and was trying to stick with pretty much the standard radiator size. I'm just a bit north of you in TN. Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490992#490992 ________________________________________________________________________________
Date: Aug 21, 2019
Check out the radiator from the Honda 1100 Magna. I used it with my 582 and put it on another. Both worked perfectly. If you're putting the 912 on a Mk 3 or a Kolbra it's one to look at. Rick. On Tue, Aug 20, 2019 at 1:04 PM Charlie England wrote: > > On 8/20/2019 11:40 AM, 13brv3 wrote: > > > > Greetings, > > > > Is everyone paying $500 for the official Rotax radiator, or are there > other popular options? There are a number of Ebay radiators in the $210 > range that mention the 912, and they appear to be the right size, but non e > of them list the inlet and outlet diameter. One seller did state that hi s > was 25mm inlet, and 30mm outlet, but I believe they should both be 25mm/1 ". > > > > Aluminum radiators aren't exactly rocket science, and I'm tempted to > give one of those a try, but it's frustrating that I haven't been able to > get inlet and outlet sizes for any of the others that are listed. I get > the impression there are only about 2-3 different radiators for all the > dozens of listings, and maybe only a couple sellers, each with a few > different aliases. > > > > Thanks, > > Rusty > Why not just find an ebay special motorcycle rad for a 100+hp bike? Or > check a cycle salvage yard, if there's one near you. Drag certainly > isn't as big an issue as it was with the -3, so if you 'go big' (and > thin) & feed it with a sheet metal wedge diffuser, you pretty much know > it'll work. You can get silicone size adapters from/to almost any common > diameter now, so fitting size shouldn't be too much of an issue. If you > want to go with an auto rad, IIRC, a stock Honda Civic rad is about an > inch thick (might be a bit thicker) & has ~1" fittings. > > Charlie > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Subject: Lord Mounts?
Date: Aug 23, 2019
Greetings, Does anyone happen to have a new or lightly used set of Lord mounts they don't need? I've got a set on order with Kolb, but they don't have them in stock, and I haven't got an ETA. Hopefully those will come in soon, and it will be a non-issue, but if someone has a set, I might be interested in buying them. Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491005#491005 ________________________________________________________________________________
Date: Aug 23, 2019
Subject: Re: Lord Mounts?
must be slow at Kolb?? Same mounts for the Hirth engines? My thought is that rubber degrades over time and I would be careful not knowing the age of the used ones.... By the way..how many folks look at their 503 or 447 fan belts on a regular basis...easy to overlook....I pulled the one from the Firestar II that I bought and the belt looked to be original....more like a round rather than a v belt..Herb Sent with ProtonMail Secure Email. Original Message On Friday, August 23, 2019 8:40 AM, 13brv3 <13brv3(at)gmail.com> wrote: > > Greetings, > > Does anyone happen to have a new or lightly used set of Lord mounts they don't need? I've got a set on order with Kolb, but they don't have them in stock, and I haven't got an ETA. Hopefully those will come in soon, and it will be a non-issue, but if someone has a set, I might be interested in buying them. > > Thanks, > Rusty > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=491005#491005 > ________________________________________________________________________________
Date: Aug 23, 2019
Yes, I have a set. Let me look around. Call me. Theyre in great shape. Low hours. I just keep them around for spares. 951-965-4269 George Sent from my iPhone > On Aug 23, 2019, at 9:40 AM, 13brv3 <13brv3(at)gmail.com> wrote: > > > Greetings, > > Does anyone happen to have a new or lightly used set of Lord mounts they don't need? I've got a set on order with Kolb, but they don't have them in stock, and I haven't got an ETA. Hopefully those will come in soon, and it will be a non-issue, but if someone has a set, I might be interested in buying them. > > Thanks, > Rusty > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=491005#491005 > > > > > > > > > ________________________________________________________________________________
Date: Aug 23, 2019
I would assume they're the same mount used for the Hirth, since the weight and power are essentially the same. Of course I have no way to know that for sure. I should have ordered them months ago, rather than waiting until the last minute, so some of this is on me for sure :-) George, I'll try sending an email, since phones are pretty unreliable where I live. Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491009#491009 ________________________________________________________________________________
Date: Aug 23, 2019
I have a 912ULS and my mounts are about 9 years old with about 100 hours of run time. They seem fine with no observable cracks or deterioration. Wondering if anyone has any information on when to change them? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491010#491010 ________________________________________________________________________________
Date: Aug 23, 2019
I bought new ones when I mounted my new Hirth 2702 a couple of years ago. Sent from my iPhone > On Aug 23, 2019, at 11:17 AM, 13brv3 <13brv3(at)gmail.com> wrote: > > > I would assume they're the same mount used for the Hirth, since the weight and power are essentially the same. Of course I have no way to know that for sure. I should have ordered them months ago, rather than waiting until the last minute, so some of this is on me for sure :-) > > George, I'll try sending an email, since phones are pretty unreliable where I live. > > Rusty > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=491009#491009 > > > > > > > > > ________________________________________________________________________________
Date: Aug 23, 2019
The mounts are expected to be in on Monday according to Kolb, so I'm all set. Thanks, Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491012#491012 ________________________________________________________________________________
Date: Aug 23, 2019
FWIW, when we rebuilt the wrecked Original Firestar of 1985 vintage into a Firefly, the Rotax 277 seemed to vibrate a bit much, so we replaced the Lord mounts with new ones, even though the originals (33 years old at the time?) seemed undamaged. No difference. So I have four 34 year old Lord mounts in a box, no reasonable offer refused. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491019#491019 ________________________________________________________________________________
Subject: FireFly Weight and Balance
Date: Aug 24, 2019
Can anyone tell me if the CG limits for the FireFly are different from the FireStar (12.8 to 22.4} I have a copy of the W&B for the FireStar not for the FireFly. Thanks, Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491026#491026 ________________________________________________________________________________
Date: Aug 24, 2019
Subject: Re: FireFly Weight and Balance
> > > Can anyone tell me if the CG limits for the FireFly are different from the > FireStar > I think the Firefly and firestar have different size air frames and possibly airfoils . so to run the calculations for CG for and aft in inches, comparing one to the other, I think would not be wise.. I think if you calculated the inches to percent of wing cord on the firestar, then using the same percent of wing cord on the Firefly . Calculate back to get the inches... I think you would be more accurate. And on the other hand someone may have the plans and numbers of the Firefly and make it easy! Boyd Young Mkiii Utah > ________________________________________________________________________________
Date: Aug 24, 2019
Thank you for the reply. I'll do what you suggest if no one with a FireFly post the exact numbers. It would be much easier with them. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491029#491029 ________________________________________________________________________________
Date: Aug 24, 2019
Hi I recommend u call KOLB Im sure they know the answer. Chris Sent from my iPhone > On Aug 24, 2019, at 2:03 PM, sidsx wrote: > > > Can anyone tell me if the CG limits for the FireFly are different from the FireStar > (12.8 to 22.4} I have a copy of the W&B for the FireStar not for the FireFly. > Thanks, > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=491026#491026 > > > > > > > > > ________________________________________________________________________________
Date: Aug 24, 2019
I tried that. Never received a reply from them. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491031#491031 ________________________________________________________________________________
Date: Aug 24, 2019
Keep calling Kolb until someone answers the phone, usually Bryan Milburn. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of sidsx Sent: Saturday, August 24, 2019 2:07 PM Subject: Kolb-List: Re: FireFly Weight and Balance I tried that. Never received a reply from them. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491031#491031 ________________________________________________________________________________
Date: Aug 24, 2019
Here is a scan of the W&B instructions from my 2013 Firefly -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of sidsx Sent: Saturday, August 24, 2019 1:04 PM Subject: Kolb-List: FireFly Weight and Balance Can anyone tell me if the CG limits for the FireFly are different from the FireStar (12.8 to 22.4} I have a copy of the W&B for the FireStar not for the FireFly. Thanks, Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491026#491026 ________________________________________________________________________________
Date: Aug 24, 2019
Thank you so much!!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491035#491035 ________________________________________________________________________________
Date: Aug 25, 2019
Concern about CG limits on any Kolb aircraft is for all practical purposes unnecessary unless there is a significant deviation from, or modification of, the airframe from the original Kolb design plans. The best way to optimize the CG on any Kolb airplane is to test fly the airplane and trim the control surfaces to fly hands off straight and level. Modifying a Kolb aircraft's CG is beneficial only for the purposes of minimizing significant control surface deflection necessary for neutral-hands off straight and level flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491047#491047 ________________________________________________________________________________
Date: Aug 25, 2019
I agree with Gene Zimmerman. I've built 3 Kolbs, US, FS, and MKIII. Never did a weight and balance on the US and FS. Test flew it, added a trim tab to aileron, elevator, and rudder. Trimmed and test flew for best cruise flight. My MKIII has aft CG on paper. Flies neutral with no pitch trim at glide, idle rpm. Bring up the power and it takes a lot of nose up pitch trim to fly neutral. That doesn't sound like aft cg. Pushers with high thrust line like the FS and MKIII have significant pitch change from idle to cruise power or full power. Lots of Kolbers don't recognize this, thinking something is wrong with their airplanes. Build it according to plans and it will be within cg limits. I have made significant modifications to all my Kolbs and never experienced a cg problem, never had to add 40 lbs of lead to the nose cone, etc. john h mkIII Titus, Alabama -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Eugene Zimmerman Sent: Sunday, August 25, 2019 11:59 AM Subject: Kolb-List: Re: FireFly Weight and Balance Concern about CG limits on any Kolb aircraft is for all practical purposes unnecessary unless there is a significant deviation from, or modification of, the airframe from the original Kolb design plans. The best way to optimize the CG on any Kolb airplane is to test fly the airplane and trim the control surfaces to fly hands off straight and level. Modifying a Kolb aircraft's CG is beneficial only for the purposes of minimizing significant control surface deflection necessary for neutral-hands off straight and level flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491047#491047 ________________________________________________________________________________
Date: Aug 27, 2019
I cannot argue with John H's success in Kolb airplanes. I do argue that while Homer's designs have proven themselves to be quite stable and forgiving, promoting the idea that weight and balance calculations are not needed might be carried over to other aircraft where the results could be deadly. I make two sets of W&B calculations at worst conditions of both forward and aft loading. In Kolbs, it really helps to have someone else read the scales while pilot is seated in the airplane :o) I bought 4 (1 spare) new very flat bathroom scales for $10 each many moons ago that worked perfectly for the job. You do need to take care not to side-load the scales for accurate readings. Climbing into the pilot seat while aircraft is on scales will spread the main wheels slightly and cause a scale side-loading error. The cure for side loading is greased plates on top of one main wheel scale. Un-greased plates on opposite side keeps things level. Cheap 12 x 12 floor tiles work fine for this purpose. BTW, if you are flying a Cessna Cardinal (rearward wing) with constant speed prop; two heavyweights in winter clothing up front with no other passengers or baggage, you could get yourself in trouble. There is a reason why Cessna added slots to the stabilator on early Cardinals and many pilots found out the hard way during flare. Jerry King -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491070#491070 ________________________________________________________________________________
Date: Aug 28, 2019
Sid, Measure the chord of the FIrefly wing, include the aileron. Divide by 4. That's the quarter chord point measured from the leading edge. That is roughly the ideal CG. Divide your original chord measurement by 10. Add and subtract that number from the quarter chord point. That's your CG range from 15% to 35% chord. If you find your CG is a little aft, BUT by no means further than 40% chord, you're still OK, Kolbs tend to fly better with an aft CG. However, if you can move something forward to get into the 15 to 35% range, do that. Last, It is vitally important that you get the aircraft at the proper attitude for measuring the arms. Roughly, it's horizontal stabilizer level. Check with Kolb they may have an angle for the engine mount (about 3 degrees for the Mk III) or the underside of the wing (9 degrees on the Mk III). I know that the Kolb uses the the leading edge of the wing as the origin for calculating the CG. Do yourself a favor and use the nose of the aircraft instead. The reason is simple, no negative numbers in your calculations. If you keep the origin forward all calculations are additions (you could put the origin at the tail for that matter and all calculations would still be consistent and that's what you're after). Nothing can screw up a CG calculation faster than adding a moment arm when it should be subtracted. Hope this helps, Rick On Sat, Aug 24, 2019 at 1:06 PM sidsx wrote: > > Can anyone tell me if the CG limits for the FireFly are different from th e > FireStar > (12.8 to 22.4} I have a copy of the W&B for the FireStar not for the > FireFly. > Thanks, > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=491026#491026 > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Aug 28, 2019
Eugene, That's about the worst advice I've ever seen on this forum. First, if the aircraft has any sort of experimental certificate, either ELSA or EAB, a weight and balance measurement is REQUIRED by law. It's a part of your aircraft's operating limitations. Second, Aft CG has probably been the cause or contributed to far too many stall spin accidents, or as the FAA calls it, Loss of Control. Just because it's an ultralight doesn't give the aircraft a pass on the physics of flight. Assuming an aircraft is in proper trim is like assuming the pistol is unloaded. There is one positive side to not doing a W & B, you'll probably qualify for next year's Darwin Awards. Rick On Sun, Aug 25, 2019 at 12:01 PM Eugene Zimmerman wrote: > > Concern about CG limits on any Kolb aircraft is for all practical purpose s > unnecessary unless there is a significant deviation from, or modification > of, the airframe from the original Kolb design plans. > > The best way to optimize the CG on any Kolb airplane is to test fly the > airplane and trim the control surfaces to fly hands off straight and > level. Modifying a Kolb aircraft's CG is beneficial only for the purpose s > of minimizing significant control surface deflection necessary for > neutral-hands off straight and level flight. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=491047#491047 > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Aug 28, 2019
I agree with your observations on weight and balance. If you can get the center of gravity right below the center of lift you won't need any trim tabs. I also like to calculate it with an empty tank of gas so if that ever happens you can still fly it to the ground. Respectfully, Dennis Baber Cape Coral, Fl baberdk(at)gmail.com Stay Curious ________________________________________________________________________________
Date: Aug 28, 2019
SSBkaXNhZ3JlZSBvbiB5b3VyIHN0YXRlbWVudDogICJJZiB5b3UgY2FuIGdldCB0aGUgY2VudGVy IG9mIGdyYXZpdHkgcmlnaHQgYmVsb3cgdGhlIGNlbnRlciBvZiBsaWZ0IHlvdSB3b24ndCBuZWVk IGFueSB0cmltIHRhYnMuIg0KDQpJbiBvbmUgcmVzcGVjdCBpdCBpcyBwcm9iYWJseSB0cnVlLiAg VGhhdCBiZWluZyBmbHlpbmcgdGhlIEtvbGIgd2l0aG91dCBwb3dlci4gIEhvd2V2ZXIsIGFzIHNv b24gYXMgeW91IGJyaW5nIHRoZSBwb3dlciBpbiwgdGhlIGhpZ2ggdGhydXN0IGxpbmUgd2lsbCBw dXNoIHRoZSBub3NlIGRvd24gYW5kIGFmdCBzdGljayBwcmVzc3VyZSB3aWxsIGJlIHJlcXVpcmVk IHRvIGhvbGUgdGhlIGFpcmNyYWZ0IGxldmVsLCB1bmxlc3MgeW91IGhhdmUgZm9yY2VkIHBpdGNo IHRyaW0gb3IgYW4gZWxldmF0b3IgdHJpbSB0YWIuICBJdCBpcyB0aGUgbmF0dXJlIG9mIHRoZSBi ZWFzdC4NCg0KSSByZWNlbnRseSByZWxhdGVkIG15IGV4cGVyaWVuY2Ugd2l0aCBteSBNS0lJSS4g IE5vIHBpdGNoIHRyaW0sIG5vIHBvd2VyLCBwZXJmZWN0IGhhbmRzIG9mZiBmbGlnaHQuICBCcmlu ZyBpbiB0aGUgcG93ZXIgYW5kIGJyaW5nIGluIHRoZSBub3NlIHVwIGZvcmNlZCB0cmltLg0KDQpq b2huIGgNCm1rSUlJDQpUaXR1cywgQWxhYmFtYQ0KDQpGcm9tOiBvd25lci1rb2xiLWxpc3Qtc2Vy dmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1rb2xiLWxpc3Qtc2VydmVyQG1hdHJvbmlj cy5jb21dIE9uIEJlaGFsZiBPZiBEZW5ueSBCYWJlcg0KU2VudDogV2VkbmVzZGF5LCBBdWd1c3Qg MjgsIDIwMTkgMTE6MDAgQU0NClRvOiBrb2xiLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDog UmU6IEtvbGItTGlzdDogRmlyZUZseSBXZWlnaHQgYW5kIEJhbGFuY2UNCg0KSSBhZ3JlZSB3aXRo IHlvdXIgb2JzZXJ2YXRpb25zIG9uIHdlaWdodCBhbmQgYmFsYW5jZS4gSWYgeW91IGNhbiBnZXQg dGhlIGNlbnRlciBvZiBncmF2aXR5IHJpZ2h0IGJlbG93IHRoZSBjZW50ZXIgb2YgbGlmdCB5b3Ug d29uJ3QgbmVlZCBhbnkgdHJpbSB0YWJzLiBJIGFsc28gbGlrZSB0byBjYWxjdWxhdGUgaXQgd2l0 aCBhbiBlbXB0eSB0YW5rIG9mIGdhcyBzbyBpZiB0aGF0IGV2ZXIgaGFwcGVucyB5b3UgY2FuIHN0 aWxsIGZseSBpdCB0byB0aGUgZ3JvdW5kLg0KDQoNClJlc3BlY3RmdWxseSwNCkRlbm5pcyBCYWJl cg0KQ2FwZSBDb3JhbCwgRmwNCmJhYmVyZGtAZ21haWwuY29tPG1haWx0bzpiYWJlcmRrQGdtYWls LmNvbT4NCg0KDQpTdGF5IEN1cmlvdXMNCg0KDQo ________________________________________________________________________________
Date: Aug 28, 2019
Rick, Who died and made you God?! This is why some of us went to ultralights so that we could get away from aviation Nazi's like you. You think you know it all, but have no idea how much time Eugene has in the air proving you wrong. I think he knows more about the physics of flight then you will ever understand. Maybe you could suggest you disagree without be an a-hole about it. Talk about a an entry into the Darwin awards. Grow up!! Terry On 8/28/2019 10:46 AM, Richard Girard wrote: > Eugene, That's about the worst advice I've ever seen on this forum. > First, if the aircraft has any sort of experimental certificate, > either ELSA or EAB, a weight and balance measurement is REQUIRED by > law. It's a part of your aircraft's operating limitations. > Second, Aft CG has probably been the cause or contributed to far too > many stall spin accidents, or as the FAA calls it, Loss of Control. > Just because it's an ultralight doesn't give the aircraft a pass on > the physics of flight. Assuming an aircraft is in proper trim is like > assuming the pistol is unloaded. > There is one positive side to not doing a W & B, you'll probably > qualify for next year's Darwin Awards. > > Rick > > On Sun, Aug 25, 2019 at 12:01 PM Eugene Zimmerman > wrote: > > > > > Concern about CG limits on any Kolb aircraft is for all practical > purposes unnecessary unless there is a significant deviation from, > or modification of, the airframe from the original Kolb design plans. > > The best way to optimize the CG on any Kolb airplane is to test > fly the airplane and trim the control surfaces to fly hands off > straight and level. Modifying a Kolb aircraft's CG is beneficial > only for the purposes of minimizing significant control surface > deflection necessary for neutral-hands off straight and level flight. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=491047#491047 > > > ========== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?Kolb-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > > -- > > > Blessed are the cracked, for they shall let in the light. Groucho > Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > ________________________________________________________________________________
Date: Aug 28, 2019
Terry: Grow Up! > On Aug 28, 2019, at 6:15 PM, Terry wrote: > > Rick, > > Who died and made you God?! This is why some of us went to ultralights so that we could get away from aviation Nazi's like you. You think you know it all, but have no idea how much time Eugene has in the air proving you wrong. I think he knows more about the physics of flight then you will ever understand. > > Maybe you could suggest you disagree without be an a-hole about it. Talk about a an entry into the Darwin awards. Grow up!! > > Terry > > > > On 8/28/2019 10:46 AM, Richard Girard wrote: >> Eugene, That's about the worst advice I've ever seen on this forum. >> First, if the aircraft has any sort of experimental certificate, either ELSA or EAB, a weight and balance measurement is REQUIRED by law. It's a part of your aircraft's operating limitations. >> Second, Aft CG has probably been the cause or contributed to far too many stall spin accidents, or as the FAA calls it, Loss of Control. >> Just because it's an ultralight doesn't give the aircraft a pass on the physics of flight. Assuming an aircraft is in proper trim is like assuming the pistol is unloaded. >> There is one positive side to not doing a W & B, you'll probably qualify for next year's Darwin Awards. >> >> Rick >> >> On Sun, Aug 25, 2019 at 12:01 PM Eugene Zimmerman > wrote: > >> >> Concern about CG limits on any Kolb aircraft is for all practical purposes unnecessary unless there is a significant deviation from, or modification of, the airframe from the original Kolb design plans. >> >> The best way to optimize the CG on any Kolb airplane is to test fly the airplane and trim the control surfaces to fly hands off straight and level. Modifying a Kolb aircraft's CG is beneficial only for the purposes of minimizing significant control surface deflection necessary for neutral-hands off straight and level flight. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=491047#491047 <http://forums.matronics.com/viewtopic.php?p=491047#491047> >> >> >> >> >> >> >> ========== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List <http://www.matronics.com/Navigator?Kolb-List> >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com <http://forums.matronics.com/> >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com <http://wiki.matronics.com/> >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution <http://www.matronics.com/contribution> >> ========== >> >> >> >> >> >> -- >> =9CBlessed are the cracked, for they shall let in the light. =9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> >> ________________________________________________________________________________
Date: Aug 28, 2019
I would like to thank everyone for their input, I find this forum to be very helpful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491114#491114 ________________________________________________________________________________
Date: Aug 29, 2019
Since "tkrolfe(at)toast.net" is a guest I can not respond to him directly so I'll do it this way. Rick's comments on weight and balance were completely correct. This is required by the FAA. To suggest that you not bother to do one is very foolish. Your were completely out of line. If you can not respond to comments in a civil manor I suggest you be a guest on another forum. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491118#491118 ________________________________________________________________________________
Date: Aug 29, 2019
Subject: Video
https://vimeo.com/356765787 Password- owyheeflyer -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Aug 30, 2019
Subject: FireFly CG ....
Hello gang,=C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2-i weigh 250 lbs, is my fat ass too heavy for the front of a Fi reFly? of course i refer to CG. i'm concerned about "elevator authority". . ............. 2 Broke Tim ________________________________________________________________________________
Subject: Re: Video
Date: Aug 30, 2019
Beautiful video. I had heard about the accident. It's a risky business. Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491138#491138 ________________________________________________________________________________
Subject: FireFly Page
Date: Sep 01, 2019
The page has been down due to hosting problems. Finally got them resolved and the page is back up. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Sep 01, 2019
Date: Sep 01, 2019
Date: Sep 01, 2019
Date: Sep 01, 2019
Date: Sep 01, 2019
Date: Sep 01, 2019
Subject: Re: FireFly Page
Date: Sep 02, 2019
Good deal; it is a great resource, would hate to lose it. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491154#491154 ________________________________________________________________________________
Date: Sep 04, 2019
Subject: Re: Kolb-List Digest: 1 Msgs - 08/15/19
how do i stop kolb forun to my e mail On Fri, Aug 16, 2019 at 7:59 AM Mike wrote: > Hello Rusty - > I have a Kolb Mark III Twinstar Classic with a Rotax 912. > The aluminum angle is 1"x3" and is 1/4 thick. > There is also a sheetmetal plate underneath the engine that mounts all the > way across to each aluminum angle via the motor mount bolts. > The sheetmetal is 1/16" thick. > > I hope this helps! > Mike > > On Thu, Aug 15, 2019 at 11:40 PM Kolb-List Digest Server < > kolb-list(at)matronics.com> wrote: > >> * >> >> ======================== >> Online Versions of Today's List Digest Archive >> ======================== >> >> Today's complete Kolb-List Digest can also be found in either of the >> two Web Links listed below. The .html file includes the Digest formatted >> in HTML for viewing with a web browser and features Hyperlinked Indexes >> and Message Navigation. The .txt file includes the plain ASCII version >> of the Kolb-List Digest and can be viewed with a generic text editor >> such as Notepad or with a web browser. >> >> HTML Version: >> >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-08-15&Archive=Kolb >> >> Text Version: >> >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 19-08-15&Archive=Kolb >> >> >> ====================== >> EMail Version of Today's List Digest Archive >> ====================== >> >> >> ---------------------------------------------------------- >> Kolb-List Digest Archive >> --- >> Total Messages Posted Thu 08/15/19: 1 >> ---------------------------------------------------------- >> >> >> Today's Message Index: >> ---------------------- >> >> 1. 05:53 PM - 912 mount angle thickness? (13brv3) >> >> >> >> ________________________________ Message 1 >> _____________________________________ >> >> >> Subject: Kolb-List: 912 mount angle thickness? >> From: "13brv3" <13brv3(at)gmail.com> >> >> >> Does anyone know the thickness of the aluminum angle used for 912 mount >> adapters? >> I need to order some angle to make my mounts. I'm guessing 3/8" thick >> maybe? >> >> >> Thanks, >> Rusty >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=490894#490894 >> >> >> >> >> ========== >> -List" rel="noreferrer" target="_blank"> >> http://www.matronics.com/Navigator?Kolb-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> >> ________________________________________________________________________________
Date: Sep 05, 2019
The same way you got it started. https://www.matronics.com/subscribe/ -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491199#491199 ________________________________________________________________________________
Subject: Kolb Mark III Classic For Sale
Date: Sep 05, 2019
1991 Kolb Mark III Classic. Rotax 582. 616 TT, 302 SMOH by Rotax Service Center (LEAF). 3 blade Warp Drive prop. All new powdered coated panel and gear, interior, seats, exterior glass, tires and gearbox. Interchangeable full length and half length doors. Easily removed rear windows. Dual control sticks and throttles. Grand Rapids EIS, Icom A-22 Comm with external antenna, Sigtronics intercom, wingtip strobes. Match painted wheel pants in box. Folding wings with factory ground handling dolly for tail. $18,495. Also available for additional $3195: 2007 Hallmark enclosed trailer custom built by factory for this aircraft, with finished interior, interior lights, roof vents, custom aluminum wheels. Easily trailered and assembled by one person with supplied equipment. Anchors solidly in trailer. Flown regularly. Fly or trailer it home. A&P owned since 2006. All excellent condition. Belvidere, IL 815-978-2762 or e-mail Gary at siegfam(at)mediacombb.net . Photos in current ad on Barnstormers.com. Many more photos available via e-mail. ________________________________________________________________________________
Subject: am i too fat?
Date: Sep 08, 2019
4oCLd2l0aCBhbGwgdGhpcyB0YWxrIGFzIG9mIGxhdGUgYWJvdXQgRmlyZUZseSBDRyBub2JvZHkg aGFzIGFuc3dlcmVkIG15IHF1ZXN0aW9uIC0gaSB3ZWlnaCAyNTAgbGJzLiBpcyBteSBiaWcgYmVs bHkvZmF0IGEqcyB0b28gbXVjaCB3ZWlnaHQgaW4gdGhlIGZyb250IG9mIGEgRmlyZUZseT8NCg= ________________________________________________________________________________
Subject: Re: am i too fat?
Date: Sep 08, 2019
Do a weight and balance where you add a few pounds to the extreme end of the tail boom and see. With that much moment arm, it will only take a few pounds at most. Just be sure and placard it so that no one less than xxx number of pounds ever tries to fly it. My buddy Ed had a Hummer that was balanced for him, and a prospective buyer took it for a flight. Problem was that Ed weighed 250 and the buyer weighed ~ 175 - it was a wonder he got it back on the ground safely. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491233#491233 ________________________________________________________________________________
Subject: Kolb Ultrastar first flight and flight manual
Date: Sep 09, 2019
Hello to all Kolb ultralight lovers! First of all, I have finished building my own kolb ultrastar from scratch and made a first flight. Here is my video: https://www.youtube.com/watch?v=onifVDlbdNY&t=341s I want to get airworthiness and register my plane in Latvia to fly it legal. To do that i need to write flight manual for the plane with its characteristics, maintenance schedule and preflight / inflight checklist. Could someone please help me with these documents? May be it could be something similar from kolb firefly.. I bought drawings and building manual from new kolb company in 2015. I have tried to email them about flight manual, but got no response. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491250#491250 ________________________________________________________________________________
Date: Sep 10, 2019
Viktors Zarskis You have done an outstanding job on building your Kolb UltraStar and produc ing the video.=C2- Congratulations!=C2- In the USA we do not need a fli ght manual for flying in the Ultralight class and I did not make one for my FireStar because of that.=C2- You will probably receive some replies fro m some of the other Kolb builders who did license their ultralights in the Experimental class where a flight manual is required.=C2- Bill VarnesKolb FireStarAudubon, NJ USA In a message dated 9/9/2019 9:15:30 AM Eastern Standard Time, me.victorio@g mail.com writes: Hello to all Kolb ultralight lovers!First of all, I have finished building my own kolb ultrastar from scratch and made a first flight.Here is my video : https://www.youtube.com/watch?v=onifVDlbdNY&t=341s ________________________________________________________________________________
Date: Sep 13, 2019
Subject: video
https://vimeo.com/359600172 password - owyheeflyer Larry -- *The older I get, the less tolerant I am of those who are intolerant of others.* *If you forward this email, or any part of it, please remove my email address before sending.* ________________________________________________________________________________
Date: Sep 13, 2019
Subject: Re: video
Another great video by Larry Cottrell.=C2- Thanks Larry! ll1020(at)gmail.com> wrote: https://vimeo.com/359600172=C2- =C2- =C2-password=C2- =C2- - owy heeflyer Larry=C2- -- The older I get, the less tolerant I am of those who are intolerant of othe rs. If you forward this email, or any part of it, please remove my email addres s before sending. ________________________________________________________________________________
Subject: Re: video
Date: Sep 13, 2019
Wow! What a spectacular video of a part of our country I will probably never get to see in person. Thank you for sharing your special part of the world with the rest of us! Awesome video and dialog. Terry - FireFly On 9/13/2019 4:02 PM, Larry Cottrell wrote: > https://vimeo.com/359600172 password - owyheeflyer > > Larry > > -- > /The older I get, the less tolerant I am of those who are intolerant > of others./ > / > / > /If you forward this email, or any part of it, please remove my email > address before sending./ ________________________________________________________________________________
Subject: MKIII for sale $3000
Date: Sep 13, 2019
Just now saw this: https://hudsonvalley.craigslist.org/avo/d/kingston-kolb/6968683106.html -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491285#491285 ________________________________________________________________________________
Subject: Re: video
Date: Sep 14, 2019
Very cool video! It's definitely different from anywhere I've lived. Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491288#491288 ________________________________________________________________________________
Date: Sep 14, 2019
Subject: Re: video
Another great video, Larry! That is some nice looking flying country you =99ve got out there. You=99re on my bucket list. Flying weather has no t been great up here in Michigan this year. So I=99ve been spending ti me working on a new Ultracruiser. George Helton Original Firestar, 2702 Hirth 14GDH Mesick, Michigan gdhelton(at)gmail.com Sent from my iPhone > On Sep 13, 2019, at 6:12 PM, Terry wrote: > > Wow! What a spectacular video of a part of our country I will probably ne ver get to see in person. Thank you for sharing your special part of the wo rld with the rest of us! Awesome video and dialog. > > > Terry - FireFly > > > >> On 9/13/2019 4:02 PM, Larry Cottrell wrote: >> https://vimeo.com/359600172 password - owyheeflyer >> >> Larry >> >> -- >> The older I get, the less tolerant I am of those who are intolerant of ot hers. >> >> If you forward this email, or any part of it, please remove my email addr ess before sending. ________________________________________________________________________________
Subject: Kolbs in NC
Date: Sep 17, 2019
We're in Oak Island on a little vacation and so of course had to check out the local airport. Upon arrival I noticed these two very nice Kolbs just finishing up for the day. Talked with them for a bit and hope to see them again/get a ride over the Outer Banks later this week when we go back out (wife wants to go sky diving). But I was curious as to how many Kolbs are in or around NC? There are no other Kolbs at my home airport and really no one even around the area that I know of and these guys aren't on any of the websites etc, but just thinking it would be cool to know where more kolbers are and do some flying together. https://photos.app.goo.gl/Xs6gV2bd2fx97VTS7 https://photos.app.goo.gl/pFJ539oZq6Au6Zxc7 https://photos.app.goo.gl/jzinyuPzjq4qJVsu9 -------- 912ul King Kolbra ;fun plane O300 Cessna 172B ;travel plane Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491334#491334 ________________________________________________________________________________
Subject: Re: Kolbs in NC
Date: Sep 17, 2019
My memory is not what it used to be, but didn't this list at one time have a map or something that pinned where all the listees are? -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491338#491338 ________________________________________________________________________________
Date: Sep 17, 2019
Seems like I have seen something like that, I know I made a Google maps thing when I was in the t-bird group that did that. Was neat, but of course only was useful for a rather small percentage of the folks there and I'm sure only another small percentage was on that one particular group. Guess that's just one of the limits of online things where the small percentage of kolbers are even on any site at all and those that are divided on many different sites (not many that I know of for Kolbs). Is there an actual company forum and or link to this site? -------- 912 King Kolbra NC27 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491344#491344 ________________________________________________________________________________
Date: Sep 21, 2019
Subject: American eaglet
Anyone interested in an American Eaglet ? I have one ,was an Gas flight approved Numbered no engine hanging from the roof in my barn ,no windshield Asking $1400 OBO Sent from my iPhone ________________________________________________________________________________
From: "Dennis Souder" <dennislees135(at)comcast.net>
Subject: Early 80's Kolb UltraStar aerobatics
Date: Sep 21, 2019
Kolb UltraStar owners, Other's will probably enjoy seeing this too. The link has video of early 80's UltraStar aerobatics. Enjoy Dennis Souder http://www.windsockstorage.com/airplane-fun/ ________________________________________________________________________________
Subject: Re: Early 80's Kolb UltraStar aerobatics
Date: Sep 22, 2019
Hey, if it isn't the wild man himself! Great to hear from you Dennis. Hope you've been well. Did you pull that video out of the dusty archives? Rusty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491435#491435 ________________________________________________________________________________
Subject: Rear wing mount universal fitting play? Tail shake?
Date: Sep 22, 2019
How much if any play (can pick up rear of wing by rear mount 1/4in) play is in the castle nut the bolts universal to the fuselage frame and from universal to wing. Another notch on the castle nut is too tight, while where it is, is to lose I believe. Thinking about using very thin washers to get a "half notch" on the nut. Anyone else have play here, if so how much? On another note, seems like everyone's horizontal and vertical stab have some flutter/vibration in them. How much do you have if any and how much is ok? Anything you have done to help stabilize/stiffen this area? -------- 912 King Kolbra NC27 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491440#491440 ________________________________________________________________________________
Subject: Re: Rear wing mount universal fitting play? Tail shake?
Date: Sep 22, 2019
Not exactly sure of what your question is asking, but here are some things I have learned: You can scrounge/create a very thin washer to put under your rear universal joint big castellated nut and get the play down to very minimal. You can fit as many washers as you need around the fitting that comes out of the wing root rib & joins said universal fitting to take up virtually all the slack. Keep fooling around with it, while mine is not totally tight, play is probably less than 1/16", and in flight, is unnoticeable. If your tail cables are tight, flutter in the horizontal stab will be unnoticable. All Kolb vertical stabs/rudders have slow pulse flutter in them, if you take your feet off the rubber pedals the rudder will start to flap. So keep your feet on the pedals! Or put a counterweight on your rudder similar to what Kolb sells for the ailerons. Like this: http://oh2fly.net/oldpoops/pg6.htm -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491443#491443 ________________________________________________________________________________
Date: Sep 23, 2019
Rusty, Yes - just digitized some dusty old tapes. I have some more that I'll get posted before too long. Brings back many good memories. Dennis ________________________________________________________________________________
Date: Sep 24, 2019
Mesmerizing!!!Warm Memories! Thanks Den!=C2- I was in PA last weekend and touched base with Bill Marti n and Marcus, (Mike Hogga & I missed each other this time).Marcus and I wer e reminiscing about those times. I vividly remember you test flying the Laz er.=C2- You doing all kinds of maneuvers above the Kolb strip with your w ife running back and forth to position herself for the best pictures. Your "little" daughter was playing in the area while you were zooming by and abo ve. Also remember a day when a gaggle of us were out for a breakfast fly an d got caught in a pop-up rain storm which caused us to make a bee-line for Mike Horvath's strip. Dick Kuntzleman and I had MKIIs (Dick still has his). Mike had the UltraStar and was flying as slow as he wanted.=C2- We all g ot landed safely as it began to downpour=C2- :=C2- )=C2- Best of time s in a KOLB.Long before, I was on patrol (local police) and couldn't believ e what I was seeing in the sky!=C2- "Cpt Zoom" (flying magazine) was up t here with Dennis doing Dogfights and other maneuvers. Was how I got into Ko lbs. And Homer, Clara and the family have a been in my heart since.JC -----Original Message----- From: Dennis Souder <dennislees135(at)comcast.net> Sent: Mon, Sep 23, 2019 8:23 pm Subject: Kolb-List: Early 80's Kolb UltraStar aerobatics <!-- #yiv0509535921 _filtered #yiv0509535921 {font-family:"Cambria Math" ;panose-1:2 4 5 3 5 4 6 3 2 4;} _filtered #yiv0509535921 {font-family:Calib ri;panose-1:2 15 5 2 2 2 4 3 2 4;} #yiv0509535921 #yiv0509535921 p.yiv05095 35921MsoNormal, #yiv0509535921 li.yiv0509535921MsoNormal, #yiv0509535921 di v.yiv0509535921MsoNormal {margin:0in;margin-bottom:.0001pt;font-size:11.0pt ;font-family:"Calibri", "sans-serif";} #yiv0509535921 a:link, #yiv050953592 1 span.yiv0509535921MsoHyperlink {color:blue;text-decoration:underline;} #y iv0509535921 a:visited, #yiv0509535921 span.yiv0509535921MsoHyperlinkFollow ed {color:purple;text-decoration:underline;} #yiv0509535921 p {margin-right :0in;margin-left:0in;font-size:12.0pt;font-family:"Times New Roman", "serif ";} #yiv0509535921 span.yiv0509535921EmailStyle17 {font-family:"Calibri", " sans-serif";color:windowtext;} #yiv0509535921 .yiv0509535921MsoChpDefault { } _filtered #yiv0509535921 {margin:1.0in 1.0in 1.0in 1.0in;} #yiv0509535921 div.yiv0509535921WordSection1 {} -->Kolb UltraStar owners, =C2-Other =99s will probably enjoy seeing this too. The link has video of early 80=99s UltraStar aerobatics. =C2-Enjoy =C2-Dennis Souder =C2-h ttp://www.windsockstorage.com/airplane-fun/ =C2- =C2- ________________________________________________________________________________
Date: Sep 23, 2019
Yeah I think that mostly answers my questions. I don't really feel the play in the air, but anything that moves will wear or wear faster so I'd prefer it be right/tight. My wires are fairly tight and bolted as I never really fold it. Universal play: https://photos.app.goo.gl/7jw5uTUmbRkyqAyR7 -------- 912 King Kolbra NC27 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491452#491452 ________________________________________________________________________________
Date: Sep 24, 2019
After watching your video, I checked the MKIII and the Firefly, the MKIII fittings move a little less than your video, one side of the Firefly just barely moves and the other side does not move at all. -------- Richard Pike Kolb MKIII N420P (420ldPoops) Kolb Firefly Part 103 legal Kingsport, TN 3TN0 Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491460#491460 ________________________________________________________________________________
Subject: Re: Early 80's Kolb UltraStar aerobaticsEarly 80's Kolb UltraStar
aerobatics
Date: Sep 24, 2019
Jim, Good to hear from you. It's been a long time, thanks for sharing your recollections. I do remember that day that the group was hit by a rain storm. I don't know if it was zoom or someone else, but I took off in the laser and someone else in a FS. It was very low ceiling. As soon as I was airborne I knew I made a mistake. Couldn't see anything, so descended to tree top level and at least could see the ground just in front of the leading edge of the wing. I was scared to death because I knew there was someone else flying around and I could not see foreword. Aerobatics did not scare, but this did. Yvonne is still running around taking pictures. Iris is almost 30 now - time passes so quickly . Dennis ________________________________________________________________________________
Date: Sep 26, 2019
Benny, If you never fold the wings, maybe you should just tighten up all the bolts so that there is no play at all.=C2- On my FireStar I removed the big ca stle nut & cotter, then installed a self locking (fiber/plastic) nut.=C2- Checked it on pre-flight for a long time.=C2- It never loosened and I di d fold the wings after every flight. Bill VarnesKolb FireStarAudubon NJ In a message dated 9/23/2019 10:07:37 PM Eastern Standard Time, the3benny3@ gmail.com writes: Yeah I think that mostly answers my questions. I don't really feel the play in the air, but anything that moves will wear or wear faster so I'd prefer it be right/tight. My wires are fairly tight and bolted as I never really fold it. Universal play: https://photos.app.goo.gl/7jw5uTUmbRkyqAyR7 --------912 King Kolbra NC27 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491452#491452 =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2 ====================== ________________________________________________________________________________
Date: Sep 26, 2019
Date: Sep 27, 2019
Subject: kolb 40 years old?
when did the ultrastar come to oshkosh for the first time Sent from Yahoo Mail on Android ________________________________________________________________________________
Subject: Re: kolb 40 years old?
Date: Sep 28, 2019
Malcolm, Homer and I went to Oshkosh in 1979 and the twin-engine Kolb Flyer was displayed that year on the ultralight flight-line. We formed Kolb Co that fall, December 1979. The UltraStar first was shown at SNF (& Oshkosh) 1982. Dennis ________________________________________________________________________________
Date: Sep 28, 2019
wow=C2- Sent from Yahoo Mail on Android On Sat, Sep 28, 2019 at 9:22 AM, Dennis Souder wrote:
