L29-Archive.digest.vol-as
June 23, 2017 - June 01, 2020
      I told him he might be going into a new business because trim motors seem t
      o be a common problem with the L29
         On Saturday, June 17, 2015994120586602274473yiv8510581628" href="mailt
      o:jetblast1(at)me.com" target="_blank">jetblast1(at)me.com> wrote:
      john cabrera
      On Jun 17, 2017, at 6:48 AM, Anthony Royal  wrote:
      The tech still has the trim motor assy as he has to get the old bearings ou
      t of the housing and order new bearings (metric you know) and lubricate eve
      rything with new grease. We spent about 4 hours just to troubleshoot. The m
      otor has an ingenious electromagnetic brake inside so when power is interru
      pted, the motor/jackscrew rotation stops and it is held in place. Interesti
      ngly, before we separated the motor from the jack screw housing, turning th
      e armature by hand would not retract or extend the jack screw but turning t
      he adapter on the jack screw housing did extend and retract the jack screw.
       So it's pretty much narrowed it down to the motor itself. Being that the m
      otor would not run initially when power was applied and took some unusual e
      ffort to get it started, confidence is high the bearings are the issue. Che
      cking the field coils with a meter showed good. Brushes were like new. Also
      , being that the trim motor worked initially for departure but nothing from
       there on, pretty much pointed to the trim motor. I had cycled several time
      s on the ground and got the trim moving light so the aircraft system seems
      to be good.
      We didn't take any photos at that time cause we didn't know what we were lo
      oking for but I will ask if he can when he puts back together. Basically, s
      eparate the motor from the jack screw housing. Gently pull apart and you wi
      ll see the electrobrake. In the end of the motor there is an insert that co
      uples the motor to the brake. Remove it by pulling straight out to see the
      front bearing. When we got the motor running, not at full rpm, you could se
      e the ball bearings and some were turning at a different speed or not at al
      l and you could see the armature just barely wobbling. There's only about 0
      .020" clearance between the armature and field coils. You could hearing the
       grinding of the bad bearings or possibly the armature hitting and feel the
       vibration in the motor itself. The grease being 20+ years old and having n
      o lubricity left, more than likely caused the bearings to fail and when pow
      er was applied, allowed the armature to cock just enough to be out of align
      ment with the field coil.
      This is our theory but it seems to be validated by what we did but will kno
      w more once we get the new bearings installed. I will post more later once
      we get the new bearings installed, test the motor on the bench, and test in
       the plane.=C2-Tony
          On Saturday, June 17, 2017 3:24 AM, Hartley Postlethwaite  wrote:
      Do you have any good pictures?=C2- This could be a good small comment to
      put in the next Red Alert.=C2- Deadline is the end of this month for subm
      issions.
      Feel free to send me a PM.
      Postal
      FlyingHartley(at)gmail.com
      http://www.matronics.com/ Navigsp; =C2- =C2- =C2- =C2- =C2- - MAT
      RONICS WEB FORUMS -
      http://forum=C2- =C2- =C2- =C2- =C2- =C2- - NEW MATRONICS LIST
      http://wiki.matronics.com
      http://www.matronics.com/c
Subject: Re: Flaps Won't Retract
Date: Jun 23, 2017
Hi Bill, Well we found the micro switch that wasn't working. Next to impossible to remove so we sprayed it with cleaner and been exercising it regularly. It now appears to be consistently working. Time will tell... One more question...does the 2.6l of fluid for the emergency side come from the main hydraulic tank, or are the accumulators filled separately somewhere with fluid? Does this happen with the Accu Fill lever or is that air only? Multiple manuals but no real concise answer. Thanks, Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470426#470426 ________________________________________________________________________________
Date: Jun 23, 2017
Always the micro Sw. Normal system fills all. Make sure tank is full. Might take a long time to bleed off pressure. Fill it up within in an inch of the top of the filter screen. Run the engine at 80% and hold that handle while actuating the speed brakes. Let the hyd pressure gauge go all the way up and back to zero, then retract the speed brakes and let the needle go up then back to zero while holding the handle forward. Takes about 4-5 times/ Never let go of the handle, I might suggest that when servicing the hydraulic system at the annual inspection, be sure the accumulators have the nitrogen pre-charge of 50 ATM in each bottle. Bottles must be completely empty of pressure before checking pre-charge. Open flap extension emergency valve and drain completely until accumulator pressure is zero. Lots of fluid and air out the right wing drain valve. > On Jun 23, 2017, at 16:17, RJM wrote: > > > Hi Bill, > > Well we found the micro switch that wasn't working. Next to impossible to remove so we sprayed it with cleaner and been exercising it regularly. It now appears to be consistently working. Time will tell... > > One more question...does the 2.6l of fluid for the emergency side come from the main hydraulic tank, or are the accumulators filled separately somewhere with fluid? Does this happen with the Accu Fill lever or is that air only? > > Multiple manuals but no real concise answer. > > Thanks, > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470426#470426 > > > > > > > > > ________________________________________________________________________________
Date: Jun 25, 2017
Bill,Also found have to emergency extend flaps and gear to get all fluid ou t before checking accumulator pressure. Just the flaps leaves fluid in the bottles and you get an inaccurate reading reading on one bottle. =C2-Just my 2 cents worthTony=C2- On Saturday, June 24, 2017 1:07 AM, William Geipel w rote: Always the micro Sw. Normal system fills all. Make sure tank is full. Might take a long time to bleed off pressure. Fill it up within in an inch of the top of the filter screen. Run the engine at 80% and hold that handle while actuating the speed brakes . Let the hyd pressure gauge go all the way up and back to zero, then retract the speed brakes and let the needle go up then back to zero wh ile holding the handle forward. Takes about 4-5 times/ Never let go of the handle, I might suggest that when servicing the hydraulic system at the annual insp ection, be sure the accumulators have the nitrogen pre-charge of 50 ATM in each bottle. Bottles must be completely empty of pressure before checking pre-charge. Op en flap extension emergency valve and drain completely until accumulator pr essure is zero. Lots of fluid and air out the right wing drain valve. > On Jun 23, 2017, at 16:17, RJM wrote: > > > Hi Bill, > > Well we found the micro switch that wasn't working.=C2- Next to impossi ble to remove so we sprayed it with cleaner and been exercising it regularl y.=C2- It now appears to be consistently working.=C2- Time will tell... > > One more question...does the 2.6l of fluid for the emergency side come fr om the main hydraulic tank, or are the accumulators filled separately somew here with fluid?=C2- Does this happen with the Accu Fill lever or is that air only? > > Multiple manuals but no real concise answer. > > Thanks, > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470426#470426 > > > > > > > > > S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jul 01, 2017
Subject: Re: Stabilator Trim Motor
Bearings for the trim motor are $70 + tax + shipping end user cost. =C2-I f anyone wants any, let me know and I'll hook you up with the contact On Thursday, June 22, 2017 11:50 PM, Anthony Royal <skyking76t@verizon. net> wrote: Will do. Tony On Thursday, June 22, 2017 11:05 PM, William Geipel wrote: A replacement would cost more so not a bad deal.Find out how much for the bearings and I would like to order a set. On Jun 22, 2017, at 14:33, Anthony Royal wrote: My bill was just under $400. There were several hours of trouble shooting t ime. With the electromomagnetic brake inside it's a little more complicated than a standard motor, plus the bearings and shipping cost to get the bear ings so I could pick up today today, plus the wiring repair. He's going on vacation tomorrow till the 8th and I'm leaving for South America tomorrow. I guess each bill will vary. May not be a bad idea to have the bearings on hand. They would have to be p repaid for though. =C2-I don't have the part numbers myself. Would have t o call the owner. On Thursday, June 22, 2017 12:22 PM, Bill Geipel wro te: how much was it?should we order the bearings to have them I stock while he can still find them? On Jun 22, 2017 10:13 AM, "Anthony Royal" wrote: Ok Bill and to all you L29 owners that have had some trouble with your tail trim motor not working at times. Excuse the long narrative but I think it is important to understand what may be going on with our motors and may sav e time looking and troubleshooting everything but the motor.I just picked u p my tail trim motor and what he found might be a common problem with these motors. First, the bearings were shot. They are magneto bearings and they don't make them anymore. So, he doesn't know how long he will be able to ge t them. Down the road they may have to convert to a standard sealed roller bearing. He only uses top of the ling bearings.....SKF, FAG, etc. Secondly, where the wiring harness goes just inside the motor, he found a w ire that had the two ends butted together, as opposed to lapping over each other and cold soldered. Definitely not an acceptable splice/connection in any application. He said there had been arching between the wires for a ver y long time and they finally burnt apart. He thinks this is what caused the trim motor to be intermittent and finally fail, along with worn out bearin gs. The safety wire with the red seals on the motor was still intact so the wiring problem looks to be a manufacturing issue. After the new bearings (and they are not cheap) and fixing the wire, the mo tor runs perfectly, quiet, and drives the jack screw now as it should. After talking with the owner, he has agreed to look at your trim motors and see if they can be fixed. He does not work on the jack screw assy, only th e trim motor, but send the complete assy. The only stipulation is you will need to sign a liability release, releasing him and the business from ANY a nd ALL liability associated with the repair of the electric motor before he does any work. I had to sign a release when I picked up my motor. The gent leman is very knowledgeable, thorough, and honest.=C2- So, here is the contact info: Owner's name is Mike Loving Blue Ridge Servo Motor Repair, LLC1017 Tennessee St.Salem, Virginia =C2-2 4153Phone: 540-375-2990email: blueridgeservomotor(at)gmail.com Hope this helps.Tony On Monday, June 19, 2017 10:09 AM, Anthony Royal wrote: Sorry, it didn't come across like that but that happens with emails. My ap ologies. I will post shortly. He's having to find the bearings. The bearings are mag neto bearings and his normal supplier won't sell to him because it's for an aircraft. He's going to another source. On Monday, June 19, 2017 8:16 AM, William Geipel wro te: Mine was a joke, but, we really want to know where to send it. to quote the Pres. sad! On Jun 18, 2017, at 09:06, Anthony Royal wrote: I would guess there are some intelligent people out there who maybe would l ike to know what may be causing their trim motor problem. If you don't want to know, then don't read it!=C2- Contribute something constructive inste ad of sarcasm. Hey, maybe I'll trade the trim motor repair info for a few flares.....peopl e in glass houses shouldn't throw stones. On Sunday, June 18, 2017 9:19 AM, Anthony Royal wrote: Play nice or I'll go home with my trim motor On Saturday, June 17, 2017 7:53 PM, William Geipel w rote: We don=99t care how he did it. Just tell him to remember and make su re you keep his contact info for us to ship ours. Bill On Jun 17, 2017, at 15:14, Anthony Royal wrote: I told him he might be going into a new business because trim motors seem t o be a common problem with the L29 On Saturday, June 17, 2015994120586602274473yiv8510581628" href="mailt o:jetblast1(at)me.com" target="_blank">jetblast1(at)me.com> wrote: john cabrera On Jun 17, 2017, at 6:48 AM, Anthony Royal wrote: The tech still has the trim motor assy as he has to get the old bearings ou t of the housing and order new bearings (metric you know) and lubricate eve rything with new grease. We spent about 4 hours just to troubleshoot. The m otor has an ingenious electromagnetic brake inside so when power is interru pted, the motor/jackscrew rotation stops and it is held in place. Interesti ngly, before we separated the motor from the jack screw housing, turning th e armature by hand would not retract or extend the jack screw but turning t he adapter on the jack screw housing did extend and retract the jack screw. So it's pretty much narrowed it down to the motor itself. Being that the m otor would not run initially when power was applied and took some unusual e ffort to get it started, confidence is high the bearings are the issue. Che cking the field coils with a meter showed good. Brushes were like new. Also , being that the trim motor worked initially for departure but nothing from there on, pretty much pointed to the trim motor. I had cycled several time s on the ground and got the trim moving light so the aircraft system seems to be good. We didn't take any photos at that time cause we didn't know what we were lo oking for but I will ask if he can when he puts back together. Basically, s eparate the motor from the jack screw housing. Gently pull apart and you wi ll see the electrobrake. In the end of the motor there is an insert that co uples the motor to the brake. Remove it by pulling straight out to see the front bearing. When we got the motor running, not at full rpm, you could se e the ball bearings and some were turning at a different speed or not at al l and you could see the armature just barely wobbling. There's only about 0 .020" clearance between the armature and field coils. You could hearing the grinding of the bad bearings or possibly the armature hitting and feel the vibration in the motor itself. The grease being 20+ years old and having n o lubricity left, more than likely caused the bearings to fail and when pow er was applied, allowed the armature to cock just enough to be out of align ment with the field coil. This is our theory but it seems to be validated by what we did but will kno w more once we get the new bearings installed. I will post more later once we get the new bearings installed, test the motor on the bench, and test in the plane.=C2-Tony On Saturday, June 17, 2017 3:24 AM, Hartley Postlethwaite wrote: Do you have any good pictures?=C2- This could be a good small comment to put in the next Red Alert.=C2- Deadline is the end of this month for subm issions. Feel free to send me a PM. Postal FlyingHartley(at)gmail.com http://www.matronics.com/ Navigsp; =C2- =C2- =C2- =C2- =C2- - MAT RONICS WEB FORUMS - http://forum=C2- =C2- =C2- =C2- =C2- =C2- - NEW MATRONICS LIST WIKI - http://wiki.matronics.com http://www.matronics.com/c ________________________________________________________________________________
Date: Jun 30, 2017
Ok, Please send me the contact info for the bearings at jetblast1(at)me.com Thank you John Cabrera > On Jun 30, 2017, at 6:26 PM, Anthony Royal wrote: > > Bearings for the trim motor are $70 + tax + shipping end user cost. If anyone wants any, let me know and I'll hook you up with the contact > > > On Thursday, June 22, 2017 11:50 PM, Anthony Royal > wrote: > > > Will do. > > Tony > > > On Thursday, June 22, 2017 11:05 PM, William Geipel > wrote: > > > A replacement would cost more so not a bad deal. > Find out how much for the bearings and I would like to order a set. > > >> On Jun 22, 2017, at 14:33, Anthony Royal > wrote: >> >> My bill was just under $400. There were several hours of trouble shooting time. With the electromomagnetic brake inside it's a little more complicated than a standard motor, plus the bearings and shipping cost to get the bearings so I could pick up today today, plus the wiring repair. He's going on vacation tomorrow till the 8th and I'm leaving for South America tomorrow. I guess each bill will vary. >> >> May not be a bad idea to have the bearings on hand. They would have to be prepaid for though. I don't have the part numbers myself. Would have to call the owner. >> >> >> >> >> >> >> >> >> >> On Thursday, June 22, 2017 12:22 PM, Bill Geipel > wrote: >> >> >> how much was it? >> should we order the bearings to have them I stock while he can still find them? >> >> On Jun 22, 2017 10:13 AM, "Anthony Royal" > wrote: >> Ok Bill and to all you L29 owners that have had some trouble with your tail trim motor not working at times. Excuse the long narrative but I think it is important to understand what may be going on with our motors and may save time looking and troubleshooting everything but the motor. >> I just picked up my tail trim motor and what he found might be a common problem with these motors. First, the bearings were shot. They are magneto bearings and they don't make them anymore. So, he doesn't know how long he will be able to get them. Down the road they may have to convert to a standard sealed roller bearing. He only uses top of the ling bearings.....SKF, FAG, etc. >> >> Secondly, where the wiring harness goes just inside the motor, he found a wire that had the two ends butted together, as opposed to lapping over each other and cold soldered. Definitely not an acceptable splice/connection in any application. He said there had been arching between the wires for a very long time and they finally burnt apart. He thinks this is what caused the trim motor to be intermittent and finally fail, along with worn out bearings. The safety wire with the red seals on the motor was still intact so the wiring problem looks to be a manufacturing issue. >> >> After the new bearings (and they are not cheap) and fixing the wire, the motor runs perfectly, quiet, and drives the jack screw now as it should. >> >> After talking with the owner, he has agreed to look at your trim motors and see if they can be fixed. He does not work on the jack screw assy, only the trim motor, but send the complete assy. The only stipulation is you will need to sign a liability release, releasing him and the business from ANY and ALL liability associated with the repair of the electric motor before he does any work. I had to sign a release when I picked up my motor. The gentleman is very knowledgeable, thorough, and honest. >> >> So, here is the contact info: >> >> Owner's name is Mike Loving >> >> Blue Ridge Servo Motor Repair, LLC >> 1017 Tennessee St. >> Salem, Virginia 24153 >> Phone: 540-375-2990 >> email: blueridgeservomotor(at)gmail.com >> >> Hope this helps. >> Tony >> >> >> >> >> On Monday, June 19, 2017 10:09 AM, Anthony Royal > wrote: >> >> >> Sorry, it didn't come across like that but that happens with emails. My apologies. >> >> I will post shortly. He's having to find the bearings. The bearings are magneto bearings and his normal supplier won't sell to him because it's for an aircraft. He's going to another source. >> >> >> >> >> On Monday, June 19, 2017 8:16 AM, William Geipel > wrote: >> >> >> Mine was a joke, but, we really want to know where to send it. >> >> to quote the Pres. sad! >>> On Jun 18, 2017, at 09:06, Anthony Royal > wrote: >>> >>> I would guess there are some intelligent people out there who maybe would like to know what may be causing their trim motor problem. If you don't want to know, then don't read it! Contribute something constructive instead of sarcasm. >>> >>> Hey, maybe I'll trade the trim motor repair info for a few flares.....people in glass houses shouldn't throw stones. >>> >>> >>> >>> >>> On Sunday, June 18, 2017 9:19 AM, Anthony Royal > wrote: >>> >>> >>> Play nice or I'll go home with my trim motor >>> >>> >>> On Saturday, June 17, 2017 7:53 PM, William Geipel > wrote: >>> >>> >>> We don=99t care how he did it. Just tell him to remember and make sure you keep his contact info for us to ship ours. >>> Bill >>> >>> >>> >>>> On Jun 17, 2017, at 15:14, Anthony Royal > wrote: >>>> >>>> I told him he might be going into a new business because trim motors seem to be a common problem with the L29 >>>> >>>> On Saturday, June 17, 2015994120586602274473yiv8510581628" href="mailto:jetblast1(at)me.com " target="_blank">jetblast1(at)me.com > wrote: >>>> >>>> >>>> >>>> john cabrera >>>> >>>> >>>> >>>>> On Jun 17, 2017, at 6:48 AM, Anthony Royal > wrote: >>>>> >>>>> The tech still has the trim motor assy as he has to get the old bearings out of the housing and order new bearings (metric you know) and lubricate everything with new grease. We spent about 4 hours just to troubleshoot. The motor has an ingenious electromagnetic brake inside so when power is interrupted, the motor/jackscrew rotation stops and it is held in place. Interestingly, before we separated the motor from the jack screw housing, turning the armature by hand would not retract or extend the jack screw but turning the adapter on the jack screw housing did extend and retract the jack screw. So it's pretty much narrowed it down to the motor itself. Being that the motor would not run initially when power was applied and took some unusual effort to get it started, confidence is high the bearings are the issue. Checking the field coils with a meter showed good. Brushes were like new. Also, being that the trim motor worked initially for departure but nothing from there on, pretty much pointed to the trim motor. I had cycled several times on the ground and got the trim moving light so the aircraft system seems to be good. >>>>> >>>>> We didn't take any photos at that time cause we didn't know what we were looking for but I will ask if he can when he puts back together. Basically, separate the motor from the jack screw housing. Gently pull apart and you will see the electrobrake. In the end of the motor there is an insert that couples the motor to the brake. Remove it by pulling straight out to see the front bearing. When we got the motor running, not at full rpm, you could see the ball bearings and some were turning at a different speed or not at all and you could see the armature just barely wobbling. There's only about 0.020" clearance between the armature and field coils. You could hearing the grinding of the bad bearings or possibly the armature hitting and feel the vibration in the motor itself. The grease being 20+ years old and having no lubricity left, more than likely caused the bearings to fail and when power was applied, allowed the armature to cock just enough to be out of alignment with the field coil. >>>>> >>>>> This is our theory but it seems to be validated by what we did but will know more once we get the new bearings installed. I will post more later once we get the new bearings installed, test the motor on the bench, and test in the plane. >>>>> Tony >>>>> >>>>> >>>>> >>>>> On Saturday, June 17, 2017 3:24 AM, Hartley Postlethwaite > wrote: >>>>> >>>>> > >>>>> >>>>> Do you have any good pictures? This could be a good small comment to put in the next Red Alert. Deadline is the end of this month for submissions. >>>>> >>>>> Feel free to send me a PM. >>>>> >>>>> Postal >>>>> FlyingHartley(at)gmail.com >>>>> >>>>> http://www.matronics.com/ Navigsp <http://www.matronics.com/Navigsp>; - MATRONICS WEB FORUMS - >>>>> http://forum=C2- =C2- =C2- =C2- =C2- =C2- - NEW MATRONICS LIST WIKI - >>>>> http://wiki.matronics.com >>>>> http://www.matronics.com/c ________________________________________________________________________________
Date: Jul 01, 2017
Me too. > On Jun 30, 2017, at 23:16, John Cabrera wrote: > > Ok, > > Please send me the contact info for the bearings at jetblast1(at)me.com > > Thank you > > John Cabrera > > >> On Jun 30, 2017, at 6:26 PM, Anthony Royal > wrote: >> >> Bearings for the trim motor are $70 + tax + shipping end user cost. If anyone wants any, let me know and I'll hook you up with the contact >> >> >> On Thursday, June 22, 2017 11:50 PM, Anthony Royal > wrote: >> >> >> Will do. >> >> Tony >> >> >> On Thursday, June 22, 2017 11:05 PM, William Geipel > wrote: >> >> >> A replacement would cost more so not a bad deal. >> Find out how much for the bearings and I would like to order a set. >> >> >>> On Jun 22, 2017, at 14:33, Anthony Royal > wrote: >>> >>> My bill was just under $400. There were several hours of trouble shooting time. With the electromomagnetic brake inside it's a little more complicated than a standard motor, plus the bearings and shipping cost to get the bearings so I could pick up today today, plus the wiring repair. He's going on vacation tomorrow till the 8th and I'm leaving for South America tomorrow. I guess each bill will vary. >>> >>> May not be a bad idea to have the bearings on hand. They would have to be prepaid for though. I don't have the part numbers myself. Would have to call the owner. >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> On Thursday, June 22, 2017 12:22 PM, Bill Geipel > wrote: >>> >>> >>> how much was it? >>> should we order the bearings to have them I stock while he can still find them? >>> >>> On Jun 22, 2017 10:13 AM, "Anthony Royal" > wrote: >>> Ok Bill and to all you L29 owners that have had some trouble with your tail trim motor not working at times. Excuse the long narrative but I think it is important to understand what may be going on with our motors and may save time looking and troubleshooting everything but the motor. >>> I just picked up my tail trim motor and what he found might be a common problem with these motors. First, the bearings were shot. They are magneto bearings and they don't make them anymore. So, he doesn't know how long he will be able to get them. Down the road they may have to convert to a standard sealed roller bearing. He only uses top of the ling bearings.....SKF, FAG, etc. >>> >>> Secondly, where the wiring harness goes just inside the motor, he found a wire that had the two ends butted together, as opposed to lapping over each other and cold soldered. Definitely not an acceptable splice/connection in any application. He said there had been arching between the wires for a very long time and they finally burnt apart. He thinks this is what caused the trim motor to be intermittent and finally fail, along with worn out bearings. The safety wire with the red seals on the motor was still intact so the wiring problem looks to be a manufacturing issue. >>> >>> After the new bearings (and they are not cheap) and fixing the wire, the motor runs perfectly, quiet, and drives the jack screw now as it should. >>> >>> After talking with the owner, he has agreed to look at your trim motors and see if they can be fixed. He does not work on the jack screw assy, only the trim motor, but send the complete assy. The only stipulation is you will need to sign a liability release, releasing him and the business from ANY and ALL liability associated with the repair of the electric motor before he does any work. I had to sign a release when I picked up my motor. The gentleman is very knowledgeable, thorough, and honest. >>> >>> So, here is the contact info: >>> >>> Owner's name is Mike Loving >>> >>> Blue Ridge Servo Motor Repair, LLC >>> 1017 Tennessee St. >>> Salem, Virginia 24153 >>> Phone: 540-375-2990 >>> email: blueridgeservomotor(at)gmail.com >>> >>> Hope this helps. >>> Tony >>> >>> >>> >>> >>> On Monday, June 19, 2017 10:09 AM, Anthony Royal > wrote: >>> >>> >>> Sorry, it didn't come across like that but that happens with emails. My apologies. >>> >>> I will post shortly. He's having to find the bearings. The bearings are magneto bearings and his normal supplier won't sell to him because it's for an aircraft. He's going to another source. >>> >>> >>> >>> >>> On Monday, June 19, 2017 8:16 AM, William Geipel > wrote: >>> >>> >>> Mine was a joke, but, we really want to know where to send it. >>> >>> to quote the Pres. sad! >>>> On Jun 18, 2017, at 09:06, Anthony Royal > wrote: >>>> >>>> I would guess there are some intelligent people out there who maybe would like to know what may be causing their trim motor problem. If you don't want to know, then don't read it! Contribute something constructive instead of sarcasm. >>>> >>>> Hey, maybe I'll trade the trim motor repair info for a few flares.....people in glass houses shouldn't throw stones. >>>> >>>> >>>> >>>> >>>> On Sunday, June 18, 2017 9:19 AM, Anthony Royal > wrote: >>>> >>>> >>>> Play nice or I'll go home with my trim motor >>>> >>>> >>>> On Saturday, June 17, 2017 7:53 PM, William Geipel > wrote: >>>> >>>> >>>> We don=99t care how he did it. Just tell him to remember and make sure you keep his contact info for us to ship ours. >>>> Bill >>>> >>>> >>>> >>>>> On Jun 17, 2017, at 15:14, Anthony Royal > wrote: >>>>> >>>>> I told him he might be going into a new business because trim motors seem to be a common problem with the L29 >>>>> >>>>> On Saturday, June 17, 2015994120586602274473yiv8510581628" href="mailto:jetblast1(at)me.com " target="_blank">jetblast1(at)me.com > wrote: >>>>> >>>>> >>>>> >>>>> john cabrera >>>>> >>>>> >>>>> >>>>>> On Jun 17, 2017, at 6:48 AM, Anthony Royal > wrote: >>>>>> >>>>>> The tech still has the trim motor assy as he has to get the old bearings out of the housing and order new bearings (metric you know) and lubricate everything with new grease. We spent about 4 hours just to troubleshoot. The motor has an ingenious electromagnetic brake inside so when power is interrupted, the motor/jackscrew rotation stops and it is held in place. Interestingly, before we separated the motor from the jack screw housing, turning the armature by hand would not retract or extend the jack screw but turning the adapter on the jack screw housing did extend and retract the jack screw. So it's pretty much narrowed it down to the motor itself. Being that the motor would not run initially when power was applied and took some unusual effort to get it started, confidence is high the bearings are the issue. Checking the field coils with a meter showed good. Brushes were like new. Also, being that the trim motor worked initially for departure but nothing from there on, pretty much pointed to the trim motor. I had cycled several times on the ground and got the trim moving light so the aircraft system seems to be good. >>>>>> >>>>>> We didn't take any photos at that time cause we didn't know what we were looking for but I will ask if he can when he puts back together. Basically, separate the motor from the jack screw housing. Gently pull apart and you will see the electrobrake. In the end of the motor there is an insert that couples the motor to the brake. Remove it by pulling straight out to see the front bearing. When we got the motor running, not at full rpm, you could see the ball bearings and some were turning at a different speed or not at all and you could see the armature just barely wobbling. There's only about 0.020" clearance between the armature and field coils. You could hearing the grinding of the bad bearings or possibly the armature hitting and feel the vibration in the motor itself. The grease being 20+ years old and having no lubricity left, more than likely caused the bearings to fail and when power was applied, allowed the armature to cock just enough to be out of alignment with the field coil. >>>>>> >>>>>> This is our theory but it seems to be validated by what we did but will know more once we get the new bearings installed. I will post more later once we get the new bearings installed, test the motor on the bench, and test in the plane. >>>>>> Tony >>>>>> >>>>>> >>>>>> >>>>>> On Saturday, June 17, 2017 3:24 AM, Hartley Postlethwaite > wrote: >>>>>> >>>>>> > >>>>>> >>>>>> Do you have any good pictures? This could be a good small comment to put in the next Red Alert. Deadline is the end of this month for submissions. >>>>>> >>>>>> Feel free to send me a PM. >>>>>> >>>>>> Postal >>>>>> FlyingHartley(at)gmail.com >>>>>> >>>>>> http://www.matronics.com/ Navigsp <http://www.matronics.com/Navigsp>; - MATRONICS WEB FORUMS - >>>>>> http://forum=C2- =C2- =C2- =C2- =C2- =C2- - NEW MATRONICS LIST WIKI - >>>>>> http://wiki.matronics.com >>>>>> http://www.matronics.com/c ________________________________________________________________________________
Subject: Canopy not locked light
Date: Jul 16, 2017
My "canopy not locked" light won't go out, I saw a post on here discussing the issue but there were no replies discussing what to look for or a fix. I assume there is a switch in the small black box that the lock handle pushes into. Any suggestions for opening that box up without destroying it? Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471094#471094 ________________________________________________________________________________
Date: Jul 17, 2017
Subject: Re: Canopy not locked light
Josh,Take the entire locking assy off the airframe. On the back of the of t he small black box you can remove the back plate. Inside there is a small b all that rides along the shaft. Most likely the ball is stuck. Just spray s ome cleaner into it. You may have to take a small screwdriver and get the b all moving again.=C2- Tony On Monday, July 17, 2017 1:31 AM, N777ZE wro te: My "canopy not locked" light won't go out, I saw a post on here discussing the issue but there were no replies discussing what to look for or a fix. =C2- I assume there is a switch in the small black box that the lock hand le pushes into.=C2- Any suggestions for opening that box up without destr oying it?=C2- Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471094#471094 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: misc parts required
Date: Aug 08, 2017
Hi all, L29#2 out of annual, passed with flying colours (colors :D ). couple of things to replace and fix. 1. nose wheel bearings and race. Does anyone know the Timkin bearing equivalent number? I had heard these bearings are the same as the Yak52's? 2. Firecock valve in the front pit is leaking N2 bigtime. does anyone have a source? has anyone tried to rebuild one? thoughts? comments? Dirty Jokes? 3. was looking for a solution to the canopy open light staying on, but just read that solution and will try it this weekend. 4. anyone have pictures or diagrams to build a tail stand? I borrowed one, and the fella is super gracious, but its a long day to go and get it and take it back. and finally, source for fuel filters? The next jet goes in October and I'll need at least this. thanks . Skid -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471616#471616 ________________________________________________________________________________
Subject: Re: misc parts required
Date: Aug 08, 2017
> On Aug 8, 2017, at 08:09, skidmk wrote: > > > Hi all, > > L29#2 out of annual, passed with flying colours (colors :D ). couple of things to replace and fix. > > 1. nose wheel bearings and race. Does anyone know the Timkin bearing equivalent number? I had heard these bearings are the same as the Yak52s? Take the bearing to NAPA. hey have them. Match the number on the bearing. > > 2. Firecock valve in the front pit is leaking N2 bigtime. does anyone have a source? has anyone tried to rebuild one? thoughts? comments? Dirty Jokes? Always leak. Remove and plug the line. No more problems. > > 3. was looking for a solution to the canopy open light staying on, but just read that solution and will try it this weekend. Dark Tape. Remove bulb and dont forget to lock it. Half the airplanes didnt have one. > > 4. anyone have pictures or diagrams to build a tail stand? I borrowed one, and the fella is super gracious, but its a long day to go and get it and take it back. Copy the one you borrowed. > > and finally, source for fuel filters? The next jet goes in October and I'll need at least this. How many do you need? > > thanks . > > Skid > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471616#471616 > > > > > > > > > ________________________________________________________________________________
Date: Aug 08, 2017
Subject:
I need AZS 50 amp/28 v switch. Its a circuit breaker switch. I want original please. Source? Thanks ________________________________________________________________________________
Date: Aug 09, 2017
Subject:
Working on yak 52 annual. I want to inspect where brake cables attach to valve . I forgot where under floor this is to get a visual look. I see the pu7 valve . ________________________________________________________________________________
Date: Aug 09, 2017
Subject: E: L29-List:
dW5kZXIgdGhlIHJlYXIgcmlnaHQgcnVkZGVyIHBlZGFsLCB1bmRlciB0aGUgZmxvb3IKCgoKClNl bnQgZnJvbSBteSBTYW1zdW5nIEdhbGF4eSBzbWFydHBob25lLgoKLS0tLS0tLS0gT3JpZ2luYWwg bWVzc2FnZSAtLS0tLS0tLQpGcm9tOiBDU0xBIE11c2V1bSA8Y3NsYW11c2V1bUBnbWFpbC5jb20+ IApEYXRlOjIwMTcvMDgvMDkgIDEwOjE5IEFNICAoR01ULTA3OjAwKSAKVG86IGwyOS1saXN0QG1h dHJvbmljcy5jb20gCkNjOiAgClN1YmplY3Q6IEwyOS1MaXN0OiAKCi0tPiBMMjktTGlzdCBtZXNz YWdlIHBvc3RlZCBieTogQ1NMQSBNdXNldW0gPGNzbGFtdXNldW1AZ21haWwuY29tPg0KDQpXb3Jr aW5nIG9uIHlhayA1MiBhbm51YWwuIEkgd2FudCB0byBpbnNwZWN0IHdoZXJlIGJyYWtlIGNhYmxl cyBhdHRhY2ggdG8gDQp2YWx2ZSAuIEkgZm9yZ290IHdoZXJlIHVuZGVyIGZsb29yIHRoaXMgaXMg dG8gZ2V0IGEgdmlzdWFsIGxvb2suICBJIHNlZSB0aGUgDQpwdTcgdmFsdmUgLg0KDQoNCl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 DQpfLT0gICAgICAgICAgLSBUaGUgTDI5LUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUg TWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55 IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2 ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9z aGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRy b25pY3MuY29tL05hdmlnYXRvcj9MMjktTGlzdA0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAg ICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28g YXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1 bXMubWF0cm9uaWNzLmNvbQ0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgICAtIE5FVyBNQVRS T05JQ1MgTElTVCBXSUtJIC0NCl8tPSBBZGQgc29tZSBpbmZvIHRvIHRoZSBNYXRyb25pY3MgRW1h aWwgTGlzdCBXaWtpIQ0KXy09ICAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb20NCl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 DQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQpfLT0gIFRo YW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09ICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KXy09ICAgLS0+IGh0dHA6Ly93 d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg0KDQo ________________________________________________________________________________
Date: Aug 20, 2017
Subject: Check out this image
https://goo.gl/images/m4xe9v ________________________________________________________________________________
Date: Aug 21, 2017
thanks Dawg, I need 2-4 filters (may as well save on shipping). I'm not sure I want to remove and plug the fuel emerg stop system. I'll pull it this year and try and rebuild it. -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472052#472052 ________________________________________________________________________________
Subject: injectors
Date: Aug 21, 2017
folks,, mine are getting tired, and the mech wants me to replace them next year. Any sources out there? thanks Skid -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472053#472053 ________________________________________________________________________________
Subject: intermittent landing gear issue
Date: Sep 09, 2017
folks, recent intermittent issue with landing gear. Need some advice or thoughts about it. condition: hydraulic system full accumulators 75-80 all systems functioning (flaps, speed brakes) all other systems normal Take off, cycle gear it starts then stays stuck varying levels of "upness, sometimes a little, sometimes almost up, brake is cycling (to brake the spinning wheels) very little movement of pole retraction push the down button, they lock up and we get poles and greens. cycle up, same as before. cycle down, lock and land. open the drain in the right wing a bit, no air comes out, let the fluid drip a little (4-8 drops) tighten it up, test flight everything works. of note, when opening the hydraulic tank to check levels the fluid is quite frothy (cavitation) anyone see this, or have an idea as to where to start to trouble shoot. it is intermittent. flew 10 flights last weekend with no problems thanks Mike -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472703#472703 ________________________________________________________________________________
Date: Sep 09, 2017
aW4gdGhlIHJpZ2h0IHdoZWVsIHdlbGwsIGhvdyBtYW55IGRyYWluIHZhbHZlcyBkbyB1IGhhdmU/ IE9uZSBpcyBvdmVyIHRoZSBtYWluIHdoZWVsIHRoZSBvdGhlciB3aWxsIGJlIG9uIGxlYWRpbmcg ZWRnZS4gSWYgb25seSBvbmUsIGl0IGlzIHRoZSBmbGFwIGRyYWluLiB0aGUgZ2VhciBkcmFpbiBp cyBpbiB0aGUgY29ja3BpdC4gRW1lcmdlbmN5IHZhbHZlcyBjbG9zZWQgY29tcGxldGVseT8KCgoK U2VudCBmcm9tIG15IFNhbXN1bmcgR2FsYXh5IHNtYXJ0cGhvbmUuCgotLS0tLS0tLSBPcmlnaW5h bCBtZXNzYWdlIC0tLS0tLS0tCkZyb206IHNraWRtayA8c2tpZG1rQGdtYWlsLmNvbT4gCkRhdGU6 MjAxNy8wOS8wOSAgNzozMSBBTSAgKEdNVC0wNzowMCkgClRvOiBsMjktbGlzdEBtYXRyb25pY3Mu Y29tIApDYzogIApTdWJqZWN0OiBMMjktTGlzdDogaW50ZXJtaXR0ZW50IGxhbmRpbmcgZ2VhciBp c3N1ZSAKCi0tPiBMMjktTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogInNraWRtayIgPHNraWRta0Bn bWFpbC5jb20+DQoNCmZvbGtzLCAgcmVjZW50IGludGVybWl0dGVudCBpc3N1ZSB3aXRoIGxhbmRp bmcgZ2Vhci4gIE5lZWQgc29tZSBhZHZpY2Ugb3IgdGhvdWdodHMgYWJvdXQgaXQuDQoNCmNvbmRp dGlvbjoNCmh5ZHJhdWxpYyBzeXN0ZW0gZnVsbA0KYWNjdW11bGF0b3JzIDc1LTgwDQphbGwgc3lz dGVtcyBmdW5jdGlvbmluZyAoZmxhcHMsIHNwZWVkIGJyYWtlcykNCmFsbCBvdGhlciBzeXN0ZW1z IG5vcm1hbA0KVGFrZSBvZmYsIGN5Y2xlIGdlYXIgaXQgc3RhcnRzIHRoZW4gc3RheXMgc3R1Y2sg dmFyeWluZyBsZXZlbHMgb2YgInVwbmVzcywgc29tZXRpbWVzIGEgbGl0dGxlLCBzb21ldGltZXMg YWxtb3N0IHVwLCBicmFrZSBpcyBjeWNsaW5nICh0byBicmFrZSB0aGUgc3Bpbm5pbmcgd2hlZWxz KSB2ZXJ5IGxpdHRsZSBtb3ZlbWVudCBvZiBwb2xlIHJldHJhY3Rpb24NCnB1c2ggdGhlIGRvd24g YnV0dG9uLCB0aGV5IGxvY2sgdXAgYW5kIHdlIGdldCBwb2xlcyBhbmQgZ3JlZW5zLiAgDQpjeWNs ZSB1cCwgc2FtZSBhcyBiZWZvcmUuDQpjeWNsZSBkb3duLCBsb2NrIGFuZCBsYW5kLg0KDQpvcGVu IHRoZSBkcmFpbiBpbiB0aGUgcmlnaHQgd2luZyBhIGJpdCwgbm8gYWlyIGNvbWVzIG91dCwgbGV0 IHRoZSBmbHVpZCBkcmlwIGEgbGl0dGxlICg0LTggZHJvcHMpIHRpZ2h0ZW4gaXQgdXAsIHRlc3Qg ZmxpZ2h0IGV2ZXJ5dGhpbmcgd29ya3MuDQoNCm9mIG5vdGUsIHdoZW4gb3BlbmluZyB0aGUgaHlk cmF1bGljIHRhbmsgdG8gY2hlY2sgbGV2ZWxzIHRoZSBmbHVpZCBpcyBxdWl0ZSBmcm90aHkgKGNh dml0YXRpb24pDQoNCmFueW9uZSBzZWUgdGhpcywgb3IgaGF2ZSBhbiBpZGVhIGFzIHRvIHdoZXJl IHRvIHN0YXJ0IHRvIHRyb3VibGUgc2hvb3QuICBpdCBpcyBpbnRlcm1pdHRlbnQuICBmbGV3IDEw IGZsaWdodHMgbGFzdCB3ZWVrZW5kIHdpdGggbm8gcHJvYmxlbXMNCg0KdGhhbmtzDQoNCk1pa2UN Cg0KLS0tLS0tLS0NCk1pa2UgJnF1b3Q7U2tpZG1rJnF1b3Q7IEJvdXJnZXQNCk90dGF3YSwgT250 YXJpbw0KDQoNCg0KDQpSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6DQoNCmh0dHA6Ly9mb3J1 bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhwP3A9NDcyNzAzIzQ3MjcwMw0KDQoNCg0KDQoN Cg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRoZSBMMjktTGlzdCBFbWFpbCBGb3J1bSAtDQpfLT0g VXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQpfLT0g dGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCl8t PSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCl8t PSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQpfLT0NCl8tPSAgIC0tPiBodHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0wyOS1MaXN0DQpfLT0NCl8tPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAg ICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCl8tPSBTYW1lIGdyZWF0IGNvbnRl bnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KXy09DQpfLT0gICAtLT4gaHR0 cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgIC0g TkVXIE1BVFJPTklDUyBMSVNUIFdJS0kgLQ0KXy09IEFkZCBzb21lIGluZm8gdG8gdGhlIE1hdHJv bmljcyBFbWFpbCBMaXN0IFdpa2khDQpfLT0gICAtLT4gaHR0cDovL3dpa2kubWF0cm9uaWNzLmNv bQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0N Cl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQpfLT0gICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpfLT0gICAtLT4g aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KXy09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KDQoNCg= ________________________________________________________________________________
Date: Sep 09, 2017
YWxzbyB0aGUgZmx1aWQgbGV2ZWwgbmVlZHMgdG8gYmUgYWJvdXQgYW4gaW5jaCBmcm9tIHRoZSB0 b3AuIGRpc3JlZ2FyZCB0aGUgZGlwIHN0aWNrLgoKCgpTZW50IGZyb20gbXkgU2Ftc3VuZyBHYWxh eHkgc21hcnRwaG9uZS4KCi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS0KRnJvbTog c2tpZG1rIDxza2lkbWtAZ21haWwuY29tPiAKRGF0ZToyMDE3LzA5LzA5ICA3OjMxIEFNICAoR01U LTA3OjAwKSAKVG86IGwyOS1saXN0QG1hdHJvbmljcy5jb20gCkNjOiAgClN1YmplY3Q6IEwyOS1M aXN0OiBpbnRlcm1pdHRlbnQgbGFuZGluZyBnZWFyIGlzc3VlIAoKLS0+IEwyOS1MaXN0IG1lc3Nh Z2UgcG9zdGVkIGJ5OiAic2tpZG1rIiA8c2tpZG1rQGdtYWlsLmNvbT4NCg0KZm9sa3MsICByZWNl bnQgaW50ZXJtaXR0ZW50IGlzc3VlIHdpdGggbGFuZGluZyBnZWFyLiAgTmVlZCBzb21lIGFkdmlj ZSBvciB0aG91Z2h0cyBhYm91dCBpdC4NCg0KY29uZGl0aW9uOg0KaHlkcmF1bGljIHN5c3RlbSBm dWxsDQphY2N1bXVsYXRvcnMgNzUtODANCmFsbCBzeXN0ZW1zIGZ1bmN0aW9uaW5nIChmbGFwcywg c3BlZWQgYnJha2VzKQ0KYWxsIG90aGVyIHN5c3RlbXMgbm9ybWFsDQpUYWtlIG9mZiwgY3ljbGUg Z2VhciBpdCBzdGFydHMgdGhlbiBzdGF5cyBzdHVjayB2YXJ5aW5nIGxldmVscyBvZiAidXBuZXNz LCBzb21ldGltZXMgYSBsaXR0bGUsIHNvbWV0aW1lcyBhbG1vc3QgdXAsIGJyYWtlIGlzIGN5Y2xp bmcgKHRvIGJyYWtlIHRoZSBzcGlubmluZyB3aGVlbHMpIHZlcnkgbGl0dGxlIG1vdmVtZW50IG9m IHBvbGUgcmV0cmFjdGlvbg0KcHVzaCB0aGUgZG93biBidXR0b24sIHRoZXkgbG9jayB1cCBhbmQg d2UgZ2V0IHBvbGVzIGFuZCBncmVlbnMuICANCmN5Y2xlIHVwLCBzYW1lIGFzIGJlZm9yZS4NCmN5 Y2xlIGRvd24sIGxvY2sgYW5kIGxhbmQuDQoNCm9wZW4gdGhlIGRyYWluIGluIHRoZSByaWdodCB3 aW5nIGEgYml0LCBubyBhaXIgY29tZXMgb3V0LCBsZXQgdGhlIGZsdWlkIGRyaXAgYSBsaXR0bGUg KDQtOCBkcm9wcykgdGlnaHRlbiBpdCB1cCwgdGVzdCBmbGlnaHQgZXZlcnl0aGluZyB3b3Jrcy4N Cg0Kb2Ygbm90ZSwgd2hlbiBvcGVuaW5nIHRoZSBoeWRyYXVsaWMgdGFuayB0byBjaGVjayBsZXZl bHMgdGhlIGZsdWlkIGlzIHF1aXRlIGZyb3RoeSAoY2F2aXRhdGlvbikNCg0KYW55b25lIHNlZSB0 aGlzLCBvciBoYXZlIGFuIGlkZWEgYXMgdG8gd2hlcmUgdG8gc3RhcnQgdG8gdHJvdWJsZSBzaG9v dC4gIGl0IGlzIGludGVybWl0dGVudC4gIGZsZXcgMTAgZmxpZ2h0cyBsYXN0IHdlZWtlbmQgd2l0 aCBubyBwcm9ibGVtcw0KDQp0aGFua3MNCg0KTWlrZQ0KDQotLS0tLS0tLQ0KTWlrZSAmcXVvdDtT a2lkbWsmcXVvdDsgQm91cmdldA0KT3R0YXdhLCBPbnRhcmlvDQoNCg0KDQoNClJlYWQgdGhpcyB0 b3BpYyBvbmxpbmUgaGVyZToNCg0KaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3Bp Yy5waHA/cD00NzI3MDMjNDcyNzAzDQoNCg0KDQoNCg0KDQpfLT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgIC0g VGhlIEwyOS1MaXN0IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZl YXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBz dWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxv YWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11 Y2ggbW9yZToNCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0 b3I/TDI5LUxpc3QNCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdF QiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhl IFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20N Cl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAgLSBORVcgTUFUUk9OSUNTIExJU1QgV0lLSSAt DQpfLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNzIEVtYWlsIExpc3QgV2lraSENCl8t PSAgIC0tPiBodHRwOi8vd2lraS5tYXRyb25pY3MuY29tDQpfLT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAg IC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIg Z2VuZXJvdXMgc3VwcG9ydCENCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0 IERyYWxsZSwgTGlzdCBBZG1pbi4NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20v Y29udHJpYnV0aW9uDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0K ________________________________________________________________________________
Subject: Re: intermittent landing gear issue
Date: Sep 09, 2017
thanks Dawg, confirmed the emergency valves in both pits closed. There is only 1 drain in the right wing. it is right above the tire/wheel assembly. I cannot see any other drains near the leading edge or other. where in the front pit is it accessed? the fluid is as you've described. thanks for your quick reply. M -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472706#472706 ________________________________________________________________________________
Date: Sep 09, 2017
b24gdGhlIGxlZnQgc2lkZSB3YWxsIGJlbG93IHRoZSB0aHJvdHRsZS4gcmVkIGtub2IuIDIgZnVs bCB0dXJucyBvcGVuLiBsZWF2ZSBvcGVuIGZvciBhIGZldyBtaW51dGVzLiBnbyBmbHkuIHUgY2Fu IGRvIGl0IGluIHRoZSBhaXIgaWYgbmVlZGVkLgoKCgpTZW50IGZyb20gbXkgU2Ftc3VuZyBHYWxh eHkgc21hcnRwaG9uZS4KCi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS0KRnJvbTog c2tpZG1rIDxza2lkbWtAZ21haWwuY29tPiAKRGF0ZToyMDE3LzA5LzA5ICA4OjE4IEFNICAoR01U LTA3OjAwKSAKVG86IGwyOS1saXN0QG1hdHJvbmljcy5jb20gCkNjOiAgClN1YmplY3Q6IEwyOS1M aXN0OiBSZTogaW50ZXJtaXR0ZW50IGxhbmRpbmcgZ2VhciBpc3N1ZSAKCi0tPiBMMjktTGlzdCBt ZXNzYWdlIHBvc3RlZCBieTogInNraWRtayIgPHNraWRta0BnbWFpbC5jb20+DQoNCnRoYW5rcyBE YXdnLA0KDQpjb25maXJtZWQgdGhlIGVtZXJnZW5jeSB2YWx2ZXMgaW4gYm90aCBwaXRzIGNsb3Nl ZC4gIFRoZXJlIGlzIG9ubHkgMSBkcmFpbiBpbiB0aGUgcmlnaHQgd2luZy4gIGl0IGlzIHJpZ2h0 IGFib3ZlIHRoZSB0aXJlL3doZWVsIGFzc2VtYmx5LiAgSSBjYW5ub3Qgc2VlIGFueSBvdGhlciBk cmFpbnMgbmVhciB0aGUgbGVhZGluZyBlZGdlIG9yIG90aGVyLg0KDQp3aGVyZSBpbiB0aGUgZnJv bnQgcGl0IGlzIGl0IGFjY2Vzc2VkPyAgdGhlIGZsdWlkIGlzIGFzIHlvdSd2ZSBkZXNjcmliZWQu DQoNCnRoYW5rcyBmb3IgeW91ciBxdWljayByZXBseS4NCg0KTQ0KDQotLS0tLS0tLQ0KTWlrZSAm cXVvdDtTa2lkbWsmcXVvdDsgQm91cmdldA0KT3R0YXdhLCBPbnRhcmlvDQoNCg0KDQoNClJlYWQg dGhpcyB0b3BpYyBvbmxpbmUgaGVyZToNCg0KaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3Zp ZXd0b3BpYy5waHA/cD00NzI3MDYjNDcyNzA2DQoNCg0KDQoNCg0KDQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAg ICAgIC0gVGhlIEwyOS1MaXN0IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBM aXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxp dGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KXy09IEFyY2hpdmUgU2VhcmNoICYg RG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBob3Rvc2hhcmUsIGFuZCBt dWNoIG11Y2ggbW9yZToNCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9O YXZpZ2F0b3I/TDI5LUxpc3QNCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9O SUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2 aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmlj cy5jb20NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAgLSBORVcgTUFUUk9OSUNTIExJU1Qg V0lLSSAtDQpfLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNzIEVtYWlsIExpc3QgV2lr aSENCl8tPSAgIC0tPiBodHRwOi8vd2lraS5tYXRyb25pY3MuY29tDQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAg ICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KXy09ICBUaGFuayB5b3UgZm9y IHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAg IC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmlj cy5jb20vY29udHJpYnV0aW9uDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0K ________________________________________________________________________________
Date: Sep 09, 2017
I had issue like that too. Turned out to be my hydraulic pump. Started with intermittent speed brakes until they stopped working. Then the gear only worked at high throttle settings.. replaced the pump all was good Gregory "Wired" Colyer www.AceMakerAirshows.com 415-531-0970 Join us on Facebook www.facebook.com/AceMakerAirshows Twitter @AceMaker33 > On Sep 9, 2017, at 8:18 AM, skidmk wrote: > > > thanks Dawg, > > confirmed the emergency valves in both pits closed. There is only 1 drain in the right wing. it is right above the tire/wheel assembly. I cannot see any other drains near the leading edge or other. > > where in the front pit is it accessed? the fluid is as you've described. > > thanks for your quick reply. > > M > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472706#472706 > > > > > > > > > ________________________________________________________________________________
Date: Sep 09, 2017
dawg,,, yes the hydraulic dump valve. I don't think this was properly serviced after the annual and the gear were cycled. as well as the e-gear testing. So I unscrewed it (the hydraulic dump valve), let it sit. Drained the flap valve as well. Went flying everything worked well. So, I'll monitor. It could very well be a faulty pump or "intermittent failing pump" thanks guys. Mike -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472724#472724 ________________________________________________________________________________
Date: Sep 09, 2017
Z29vZC4gSSBoYXZlIGh5ZC4gcHVtcCBvdmVyaGF1bCBraXRzLgoKCgpTZW50IGZyb20gbXkgU2Ft c3VuZyBHYWxheHkgc21hcnRwaG9uZS4KCi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0t LS0KRnJvbTogc2tpZG1rIDxza2lkbWtAZ21haWwuY29tPiAKRGF0ZToyMDE3LzA5LzA5ICAxOjMx IFBNICAoR01ULTA3OjAwKSAKVG86IGwyOS1saXN0QG1hdHJvbmljcy5jb20gCkNjOiAgClN1Ympl Y3Q6IEwyOS1MaXN0OiBSZTogaW50ZXJtaXR0ZW50IGxhbmRpbmcgZ2VhciBpc3N1ZSAKCi0tPiBM MjktTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogInNraWRtayIgPHNraWRta0BnbWFpbC5jb20+DQoN CmRhd2csLCwgeWVzIHRoZSBoeWRyYXVsaWMgZHVtcCB2YWx2ZS4gIEkgZG9uJ3QgdGhpbmsgdGhp cyB3YXMgcHJvcGVybHkgc2VydmljZWQgYWZ0ZXIgdGhlIGFubnVhbCBhbmQgdGhlIGdlYXIgd2Vy ZSBjeWNsZWQuIGFzIHdlbGwgYXMgdGhlIGUtZ2VhciB0ZXN0aW5nLiANCg0KU28gSSB1bnNjcmV3 ZWQgaXQgKHRoZSBoeWRyYXVsaWMgZHVtcCB2YWx2ZSksIGxldCBpdCBzaXQuICBEcmFpbmVkIHRo ZSBmbGFwIHZhbHZlIGFzIHdlbGwuICBXZW50IGZseWluZyBldmVyeXRoaW5nIHdvcmtlZCB3ZWxs Lg0KDQpTbywgSSdsbCBtb25pdG9yLiAgSXQgY291bGQgdmVyeSB3ZWxsIGJlIGEgZmF1bHR5IHB1 bXAgb3IgImludGVybWl0dGVudCBmYWlsaW5nIHB1bXAiIHRoYW5rcyBndXlzLg0KDQpNaWtlDQoN Ci0tLS0tLS0tDQpNaWtlICZxdW90O1NraWRtayZxdW90OyBCb3VyZ2V0DQpPdHRhd2EsIE9udGFy aW8NCg0KDQoNCg0KUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOg0KDQpodHRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTQ3MjcyNCM0NzI3MjQNCg0KDQoNCg0KDQoN Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09DQpfLT0gICAgICAgICAgLSBUaGUgTDI5LUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVz ZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRo ZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0g QXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0g UGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3 dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9MMjktTGlzdA0KXy09DQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAg ICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250ZW50 IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+IGh0dHA6 Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgICAtIE5F VyBNQVRST05JQ1MgTElTVCBXSUtJIC0NCl8tPSBBZGQgc29tZSBpbmZvIHRvIHRoZSBNYXRyb25p Y3MgRW1haWwgTGlzdCBXaWtpIQ0KXy09ICAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb20N Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09DQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQpf LT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09ICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KXy09ICAgLS0+IGh0 dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCl8tPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg0KDQo ________________________________________________________________________________
From: "weloveflying" <yourordinarybeing(at)gmail.com>
Date: Sep 18, 2017
Although OEM's are the best options, you can also have cheap aftermarket parts as references, if not ultimately options. Like this metal machining services (http://www.powerjackmotion.com/product-category/metal-maching-service/) for example, you can have them see what they can do for you, especially if they can machine a firecock valve in this case. Hope this helps! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472976#472976 ________________________________________________________________________________
Date: Sep 18, 2017
Just a side note: I cant remember who had a leaky fire cock and I made the suggestion to just remove it. Well to further that discussion, not all L29s had fire cocks. Some series did, some didnt, Just as some L29s had canopy unlock lights and some didnt. So, machining a fire cock sounds expensive in which case I stick by my original suggestion. If you cant find one, And if some aircraft where never built with one, plug it. IMHO bill > On Sep 18, 2017, at 07:50, weloveflying wrote: > > > Although OEM's are the best options, you can also have cheap aftermarket parts as references, if not ultimately options. Like this metal machining services (http://www.powerjackmotion.com/product-category/metal-maching-service/) for example, you can have them see what they can do for you, especially if they can machine a firecock valve in this case. > > Hope this helps! > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472976#472976 > > > > > > > > > ________________________________________________________________________________
Date: Sep 22, 2017
Thanks for all the advice, 2 flights now zero issues, after having "serviced the aircraft" bleed valves. -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473064#473064 ________________________________________________________________________________
Date: Sep 28, 2017
Subject: L29 w/ Afterburner
Has anyone heard of an L29 with a J85-GE-5 or -5A engine with afterburner i nstalled?=C2- With 2400 lbs normal thrust and 3600-3850 lbs thrust with a fterburner, it would seem to be a good fit. Engine dimensions look good to go but was told the tail pipe might be an issue.=C2- Was told there is/wa s one L29 with this conversion but gentleman didn't have any specifics. ________________________________________________________________________________
Subject: Re: L29 w/ Afterburner
Date: Sep 28, 2017
As far as I know, some people got troubles with the cell structure. Jean de Roubin > Le 28 sept. 2017 =C3- 14:24, Anthony Royal a =C3=A9crit : > > Has anyone heard of an L29 with a J85-GE-5 or -5A engine with afterburner installed? With 2400 lbs normal thrust and 3600-3850 lbs thrust with afterburner, it would seem to be a good fit. Engine dimensions look good to go but was told the tail pipe might be an issue. Was told there is/was one L29 with this conversion but gentleman didn't have any specifics. > > ________________________________________________________________________________
Date: Sep 28, 2017
One person did reply the tail needed modifications for the tailpipe but don 't know how extensive the mods are.Anthony On Thursday, September 28, 2017 12:40 PM, "delfin29(at)me.com" wrote: As far as I know, some people got troubles with the cell structure.Jean de Roubin Le 28 sept. 2017 =C3- 14:24, Anthony Royal a =C3 =A9crit : Has anyone heard of an L29 with a J85-GE-5 or -5A engine with afterburner i nstalled?=C2- With 2400 lbs normal thrust and 3600-3850 lbs thrust with a fterburner, it would seem to be a good fit. Engine dimensions look good to go but was told the tail pipe might be an issue.=C2- Was told there is/wa s one L29 with this conversion but gentleman didn't have any specifics. ________________________________________________________________________________
Date: Sep 29, 2017
Anthony, It might be a good upgrade for the jet. It would be a much more expensive engine. Even installing a J-85 without AB would be a nice option. I am not an expert on the subject, but I have knowledge of both jets so I'll offer an opinion. The J-85 AB section needs room for the AB to open and close, so that may be an issue at the engine bay trailing edge. I'm sure you can get measurements from someone on the dimensions of the AB when in full AB. That would be the limfac in this situation. Also, mounting points will likely have to be manufactured. As I recall, the T-38 engine rolls into the fuselage on rails built into the fuselage and then is secured in place. The T-38 is similar to the L-29 in that the tail section "boat" is removed to access the engine. I think such an installation would be very interesting. I hope you can do it. Stan Sutterfield From: Anthony Royal <skyking76t(at)verizon.net> Subject: L29-List: L29 w/ Afterburner Has anyone heard of an L29 with a J85-GE-5 or -5A engine with afterburner i nstalled?=C2- With 2400 lbs normal thrust and 3600-3850 lbs thrust with a fterburner, it would seem to be a good fit. Engine dimensions look good to go but was told the tail pipe might be an issue.=C2- Was told there is/wa s one L29 with this conversion but gentleman didn't have any specifics. ________________________________________________________________________________
Date: Sep 30, 2017
Subject: Re: L29-List Digest: 1 Msgs - 09/29/17
Hi Stan,The consensus agrees with you that the major problem will lie in th e tail outlet. Zach McNeil says there is one guy who has made this swap and he's trying to find more info.=C2- Finding an airworthy engine with AB is the other problem. There are two J-8 5 engines in crates where I work but their model and flight status is unkno wn. I don't think anyone has opened the crates since they were received. Anyway, it was just a concept idea and may prove to be more involved than w hat I may want to do. Thanks for sharing your knowledge and input. RegardsAnthony On Saturday, September 30, 2017 3:16 AM, L29-List Digest Server wrote: * ======================== =C2- Online Versions of Today's List Digest Archive ======================== Today's complete L29-List Digest can also be found in either of the two Web Links listed below.=C2- The .html file includes the Digest format ted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation.=C2- The .txt file includes the plain ASCII versio n of the L29-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: =C2- =C2- http://www.matronics.com/digest/digestview.php?Style=82701& View=html&Chapter 17-09-29&Archive=L29 Text Version: =C2- =C2- http://www.matronics.com/digest/digestview.php?Style=82701& View=txt&Chapter 17-09-29&Archive=L29 ======================== ======================= =C2- EMail Version of Today's List Digest Archive ======================== ======================= =C2- =C2- =C2- =C2- =C2- ---------------------------------------- ------------------ =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2 - =C2- =C2- L29-List Digest Archive =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2 - =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- --- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- Total Messages Posted Fri 09/29/17: 1 =C2- =C2- =C2- =C2- =C2- ---------------------------------------- ------------------ Today's Message Index: ---------------------- =C2- =C2- 1. 07:46 AM - Re: L29 w/ Afterburner=C2- (speedy11(at)aol.com) ________________________________=C2- Message 1=C2- ____________________ _________________ From: speedy11(at)aol.com Subject: L29-List: Re: L29 w/ Afterburner Anthony, It might be a good upgrade for the jet.=C2- It would be a much more expen sive engine. Even installing a J-85 without AB would be a nice option.=C2- I am not an expert on the subject, but I have knowledge of both jets so I'll offer an opinion. The J-85 AB section needs room for the AB to open and close, so that may be an issue at the engine bay trailing edge.=C2- I'm sure you can get measureme nts from someone on the dimensions of the AB when in full AB.=C2- That would be th e limfac in this situation. Also, mounting points will likely have to be manufactured.=C2- As I recal l, the T-38 engine rolls into the fuselage on rails built into the fuselage and then is secured in place.=C2- The T-38 is similar to the L-29 in that the tail se ction "boat" is removed to access the engine. I think such an installation would be very interesting.=C2- I hope you ca n do it. Stan Sutterfield From: Anthony Royal <skyking76t(at)verizon.net> Subject: L29-List: L29 w/ Afterburner Has anyone heard of an L29 with a J85-GE-5 or -5A engine with afterburner i nstalled?=C2- With 2400 lbs normal thrust and 3600-3850 lbs thrust with a fterburner, it would seem to be a good fit. Engine dimensions look good to go but was told the tail pipe might be an issue.=C2- Was told there is/wa s one L29 with this conversion but gentleman didn't have any specifics. S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: viper engine mount
Date: Oct 07, 2017
I am looking for a l-29 viper engine mount, perhaps somebody may have one around... Thanks Jared Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473420#473420 ________________________________________________________________________________
Subject: Landing light malfunction
Date: Oct 13, 2017
Hey folks, returned from a flight the other day and got this: landing light switch is off, the light stayed deployed and on. As soon as the masterswitch is on, the light will come on (even if the switch is in the off position), the light will not retract. The only way to turn off the landing light is to flip the breaker. anyone seen this? thoughts? -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473502#473502 ________________________________________________________________________________
Date: Oct 13, 2017
Subject: Re: Landing light malfunction
Landing light up micro switch is either improperly adjusted or broken. Pull the light but leave it plugged in and check travel. Adjust or replace as necessary Bill N39DE Sent from my iPhone > On Oct 13, 2017, at 10:57 AM, skidmk wrote: > > > Hey folks, > > returned from a flight the other day and got this: > > landing light switch is off, the light stayed deployed and on. As soon as the masterswitch is on, the light will come on (even if the switch is in the off position), the light will not retract. The only way to turn off the landing light is to flip the breaker. > > anyone seen this? thoughts? > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473502#473502 > > > > > > > > > ________________________________________________________________________________
Date: Oct 13, 2017
I too have that exact problem. Bill C, with the light extended can we get to the micro switch? bill g. > On Oct 13, 2017, at 14:40, Bill Culberson wrote: > > > Landing light up micro switch is either improperly adjusted or broken. Pull the light but leave it plugged in and check travel. Adjust or replace as necessary > > Bill > N39DE > > Sent from my iPhone > >> On Oct 13, 2017, at 10:57 AM, skidmk wrote: >> >> >> Hey folks, >> >> returned from a flight the other day and got this: >> >> landing light switch is off, the light stayed deployed and on. As soon as the masterswitch is on, the light will come on (even if the switch is in the off position), the light will not retract. The only way to turn off the landing light is to flip the breaker. >> >> anyone seen this? thoughts? >> >> -------- >> Mike "Skidmk" Bourget >> Ottawa, Ontario >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=473502#473502 >> >> >> >> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Oct 14, 2017
No, but if you pull the screws out and let it hang (gently) by the harness, the inspection covers on the sides are easily removed and you can watch what happens as you cycle the switch. Pretty easy to adjust. Bill Sent from my iPhone > On Oct 13, 2017, at 6:49 PM, William Geipel wrote: > > > I too have that exact problem. > > Bill C, with the light extended can we get to the micro switch? > > > bill g. >> On Oct 13, 2017, at 14:40, Bill Culberson wrote: >> >> >> Landing light up micro switch is either improperly adjusted or broken. Pull the light but leave it plugged in and check travel. Adjust or replace as necessary >> >> Bill >> N39DE >> >> Sent from my iPhone >> >>> On Oct 13, 2017, at 10:57 AM, skidmk wrote: >>> >>> >>> Hey folks, >>> >>> returned from a flight the other day and got this: >>> >>> landing light switch is off, the light stayed deployed and on. As soon as the masterswitch is on, the light will come on (even if the switch is in the off position), the light will not retract. The only way to turn off the landing light is to flip the breaker. >>> >>> anyone seen this? thoughts? >>> >>> -------- >>> Mike "Skidmk" Bourget >>> Ottawa, Ontario >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=473502#473502 >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Oct 13, 2017
thank you. > On Oct 13, 2017, at 22:27, Bill Culberson wrote: > > > No, but if you pull the screws out and let it hang (gently) by the harness, the inspection covers on the sides are easily removed and you can watch what happens as you cycle the switch. Pretty easy to adjust. > > Bill > > Sent from my iPhone > >> On Oct 13, 2017, at 6:49 PM, William Geipel wrote: >> >> >> I too have that exact problem. >> >> Bill C, with the light extended can we get to the micro switch? >> >> >> bill g. >>> On Oct 13, 2017, at 14:40, Bill Culberson wrote: >>> >>> >>> Landing light up micro switch is either improperly adjusted or broken. Pull the light but leave it plugged in and check travel. Adjust or replace as necessary >>> >>> Bill >>> N39DE >>> >>> Sent from my iPhone >>> >>>> On Oct 13, 2017, at 10:57 AM, skidmk wrote: >>>> >>>> >>>> Hey folks, >>>> >>>> returned from a flight the other day and got this: >>>> >>>> landing light switch is off, the light stayed deployed and on. As soon as the masterswitch is on, the light will come on (even if the switch is in the off position), the light will not retract. The only way to turn off the landing light is to flip the breaker. >>>> >>>> anyone seen this? thoughts? >>>> >>>> -------- >>>> Mike "Skidmk" Bourget >>>> Ottawa, Ontario >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=473502#473502 >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Oct 14, 2017
Thank you! I'll give it a try this week -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473534#473534 ________________________________________________________________________________
Subject: Re: Stabilator Trim Motor
Date: Oct 26, 2017
Hmm..it seems to me you did spend at least $800US + time consuming. Why not for that kind of money just buy a new surplus factory sealed trim motor? Slide in replacement. And no need to sign a liability release. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473883#473883 ________________________________________________________________________________
Date: Oct 26, 2017
Here it is Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473884#473884 Attachments: http://forums.matronics.com//files/lun_2510_01_128.jpg http://forums.matronics.com//files/lun_2510_01_124.jpg ________________________________________________________________________________
Date: Oct 26, 2017
Where can we get one? John F. Cabrera > On Oct 26, 2017, at 1:53 PM, Alekh wrote: > > > Hmm..it seems to me you did spend at least $800US + time consuming. Why not for that kind of money just buy a new surplus factory sealed trim motor? Slide in replacement. And no need to sign a liability release. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473883#473883 > > > > > > > > > ________________________________________________________________________________
Date: Oct 26, 2017
here it is Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473885#473885 Attachments: http://forums.matronics.com//files/lun_2510_01_102.jpg ________________________________________________________________________________
Date: Oct 26, 2017
It's in Calgary Alberta. You can give me an offer at lekhkar(at)telus.net Andrey Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473887#473887 ________________________________________________________________________________
Date: Oct 27, 2017
Guys,Don't know what the issue is with your trim motor but there's not a lo t to it.I had my trim motor overhauled at a local servo shop. It had bad be arings and a bad power wire that had broken inside due to a bad solder join t. It cost $300 to repair. There are also 2 switches at the base of the rudder that control the trim m otor, in addition to the box on the trim motor. The switches at the base of the rudder have contacts inside. I had to clean the contacts. If these con tacts are dirty, the motor will not work. Once I did all the above, my trim motor now performs better than it ever has. I can send the contact info if you are interested,. On Thursday, October 26, 2017 5:29 PM, Alekh wrote: It's in Calgary Alberta. You can give me an offer at lekhkar(at)telus.net Andrey Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473887#473887 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Oct 27, 2017
send pix or location of trim switches at base of rudder. > On Oct 27, 2017, at 05:56, Anthony Royal wrote: > > Guys, > Don't know what the issue is with your trim motor but there's not a lot to it. > I had my trim motor overhauled at a local servo shop. It had bad bearings and a bad power wire that had broken inside due to a bad solder joint. It cost $300 to repair. > > There are also 2 switches at the base of the rudder that control the trim motor, in addition to the box on the trim motor. The switches at the base of the rudder have contacts inside. I had to clean the contacts. If these contacts are dirty, the motor will not work. Once I did all the above, my trim motor now performs better than it ever has. > > I can send the contact info if you are interested,. > > > > On Thursday, October 26, 2017 5:29 PM, Alekh wrote: > > > > > It's in Calgary Alberta. > You can give me an offer at lekhkar(at)telus.net > > Andrey > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473887#473887 <http://forums.matronics.com/viewtopic.php?p=473887#473887> > > > > > > > <=============== > -= --> http://www.matronics.com/Navigator?L29-List <http://www.matronics.com/Navigator?L29-List> > great content also available via the Web Forums! > s.matronics.com/" target="_blank">http://forums.matronics.com > > <http://wiki.matronics.com/> > http://www.matronics.com/contribution > <=============== > > > > > ________________________________________________________________________________
Date: Oct 27, 2017
No photos. Take off the rear most spine cover on top of the tail. Under thi s cover, on top of the tail, and at the forward base of the vertical tail y ou will find 2 black switch boxes, side by side. You can't miss them. Disco nnect the wires and remove the boxes. Remove the switch box covers. Very li ghtly clean the inside of each of the contacts with 2000 grit sandpaper. Fu rther clean with electronics cleaner, available at most auto parts stores. Reinstall. Run the flaps up and down to re-set the switches.=C2-The dirty switch contacts cause most of the trim motor problems. If the trim still doesn't work, would suggest having the trim motor tested. There are also microswitches in the square box on top of the trim motor. C heck to make sure the microswitches are not stuck open or closed. These mic roswitches control where the trim motor stops in relation to the flaps by t ripping various switch combinations. On Friday, October 27, 2017 8:07 AM, William Geipel wrote: send pix or location of trim switches at base of rudder. On Oct 27, 2017, at 05:56, Anthony Royal wrote: Guys,Don't know what the issue is with your trim motor but there's not a lo t to it.I had my trim motor overhauled at a local servo shop. It had bad be arings and a bad power wire that had broken inside due to a bad solder join t. It cost $300 to repair. There are also 2 switches at the base of the rudder that control the trim m otor, in addition to the box on the trim motor. The switches at the base of the rudder have contacts inside. I had to clean the contacts. If these con tacts are dirty, the motor will not work. Once I did all the above, my trim motor now performs better than it ever has. I can send the contact info if you are interested,. On Thursday, October 26, 2017 5:29 PM, Alekh wrote: It's in Calgary Alberta. You can give me an offer at lekhkar(at)telus.net Andrey Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473887#473887 <=============== -==C2- --> http://www.matronics.com/Navigator?L29-List great content also available via the Web Forums! s.matronics.com/" target="_blank">http://forums.matronics.com http://www.matronics.com/contribution <=============== ________________________________________________________________________________
Date: Oct 27, 2017
Just as an aside, I believe the 2 switch boxes under the rear most spine co ver on top of the tail control power to the trim motor to signal whether to run forward or backward, and all power in general to the trim motor. On Friday, October 27, 2017 8:35 AM, Anthony Royal <skyking76t@verizon. net> wrote: No photos. Take off the rear most spine cover on top of the tail. Under th is cover, on top of the tail, and at the forward base of the vertical tail you will find 2 black switch boxes, side by side. You can't miss them. Disc onnect the wires and remove the boxes. Remove the switch box covers. Very l ightly clean the inside of each of the contacts with 2000 grit sandpaper. F urther clean with electronics cleaner, available at most auto parts stores. Reinstall. Run the flaps up and down to re-set the switches.=C2-The dirt y switch contacts cause most of the trim motor problems. If the trim still doesn't work, would suggest having the trim motor tested. There are also microswitches in the square box on top of the trim motor. C heck to make sure the microswitches are not stuck open or closed. These mic roswitches control where the trim motor stops in relation to the flaps by t ripping various switch combinations. On Friday, October 27, 2017 8:07 AM, William Geipel wrote: send pix or location of trim switches at base of rudder. On Oct 27, 2017, at 05:56, Anthony Royal wrote: Guys,Don't know what the issue is with your trim motor but there's not a lo t to it.I had my trim motor overhauled at a local servo shop. It had bad be arings and a bad power wire that had broken inside due to a bad solder join t. It cost $300 to repair. There are also 2 switches at the base of the rudder that control the trim m otor, in addition to the box on the trim motor. The switches at the base of the rudder have contacts inside. I had to clean the contacts. If these con tacts are dirty, the motor will not work. Once I did all the above, my trim motor now performs better than it ever has. I can send the contact info if you are interested,. On Thursday, October 26, 2017 5:29 PM, Alekh wrote: It's in Calgary Alberta. You can give me an offer at lekhkar(at)telus.net Andrey Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473887#473887 <=============== -==C2- --> http://www.matronics.com/Navigator?L29-List great content also available via the Web Forums! s.matronics.com/" target="_blank">http://forums.matronics.com http://www.matronics.com/contribution <=============== ________________________________________________________________________________
Date: Nov 01, 2017
Subject: PLEASE READ - Matronics Email List 2017 Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are 9 great gifts to choose from! There's something for everyone, to be sure. Please make your List Contribution using any one of three secure methods including using a Credit Card, PayPal, or by Personal Check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Subject: Re: L-29 Rear Canopy Seal
Date: Nov 02, 2017
Hi Tony, If you are still interested I found a lead for a Canopy Seals-front and rear. You can contact me at lekhkar(at)telus.net Andrey Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474130#474130 Attachments: http://forums.matronics.com//files/seal_hose_176.jpg ________________________________________________________________________________
Date: Nov 02, 2017
Guys, I am getting emails asking send them a list of spare parts for sale. Just for clarification- I dont sell parts in stock for my L-29 in Calgary. I only try to help people in a desperate need for L-29 parts to keep airborne. How it works: If someone is asking for canopy seal, I start a search thru about 100+ privet sources of L-29 spare parts located all over former Soviet Union countries. Once I found, I contact you guys, and if you agree on the price I buy from a guy over sea but its stored in Russia until my visit as they are not willing to ship over sea. At the same time I ship you the same spare part from my stock located in Calgary. What you see on the picture thats what you will get. I just take small fee for my time and a risk associated and so. By saying that, ask only parts if you need it in emergency as they are not cheap at the end. The cheapest way just start looking on your own and your own risk. Dont spend $$ on a repair of broken part more than a new part costs or just slightly less, unless if its not available. I hope you are with me. Keep flying safe. Regards, Andrey Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474140#474140 ________________________________________________________________________________
Date: Nov 03, 2017
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Help Keep Airport Courtesy Cars Running
Date: Nov 04, 2017
Last November, a few people (out of thousands) complained to me that my fundraising efforts for the Airport Courtesy Cars site were too often. In response, I will only ask for donations once a year, in November. In the past few months I have transferred all the data to a web based platform. As a result, the site will work on ANY device with no bugs, crashes, or Android and Apple permissions required. Please refer to website for more details. The site now lists over 1,830 courtesy cars across the U.S. I receive a very small percent of my operating costs from advertisers. Most of my expenses are covered from small donations from pilots like you. I take no salary. Please consider any donation to keep the site up and running in the coming year. Donations can be made via the secure PayPal tab on the site (you don not need a PayPal account), or by mailing your donation to: Airport Courtesy Cars. P.O. Box 85762, Tucson, Arizona 85754. All donors will be listed on the donor page (unless you request not to be). Any donation is greatly appreciated. You can continue to email me your updates and suggestions to: airportcars101(at)gmail.com Thank you, Glenn www.airportcourtesycars.com -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474294#474294 ________________________________________________________________________________
Date: Nov 05, 2017
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2017
Subject: Re: Tires
Date: Nov 08, 2017
If you need brand new tires in US https://www.desser.com/pc_combined_results.asp?search_prod=(searchlike~p.sku~600/180|Or|searchlike~p.nm~600/180|Or|searchlike~p.ds~600/180|Or|searchlike~p.search_terms~600/180|Or|searchlike~%20p.opt5~600/180)&search_keyword=600%2F180 >From my experience: Old stock tires crack on the sides in 3-6 months of installation. Keep flying safe. Andrey [Wink] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474643#474643 ________________________________________________________________________________
Subject: Re: Tires
Date: Nov 08, 2017
https://www.desser.com/pc_combined_results.asp?search_prod=(searchlike~p.sku~600/180|Or|searchlike~p.nm~600/180|Or|searchlike~p.ds~600/180|Or|searchlike~p.search_terms~600/180|Or|searchlike~%20p.opt5~600/180)&search_keyword=600%2F180 Copy this full link and put in new window to see 600X180 tire price. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474644#474644 ________________________________________________________________________________
Date: Nov 09, 2017
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 09, 2017
Subject: Re: Tires
I have these tires on my airplane. No problems whatsoever. The only thing is the Desser does not have the inner tubes for our airplanes. Do anybody know anyone who makes them new? John F. Cabrera > On Nov 8, 2017, at 2:19 PM, Alekh wrote: > > > https://www.desser.com/pc_combined_results.asp?search_prod=(searchlike~p.sku~600/180|Or|searchlike~p.nm~600/180|Or|searchlike~p.ds~600/180|Or|searchlike~p.search_terms~600/180|Or|searchlike~%20p.opt5~600/180)&search_keyword=600%2F180 > > Copy this full link and put in new window to see 600X180 tire price. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=474644#474644 > > > > > > > > > ________________________________________________________________________________
Subject: Re: Tires
Date: Nov 10, 2017
the Desser does do the inner tubes for 600x180. You will see bellow a pics when on Desser web site. The price is $175. Andrey Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474752#474752 Attachments: http://forums.matronics.com//files/tube_104.png ________________________________________________________________________________
Date: Nov 10, 2017
Subject: Re: Tires
Has anyone used these inner tubes out there on our airplanes? I looked at these before but my concern was the stem. It did not seem to be long enough to fit our wheels. John F. Cabrera > On Nov 10, 2017, at 8:14 AM, Alekh wrote: > > > the Desser does do the inner tubes for 600x180. You will see bellow a pics when on Desser web site. The price is $175. > > Andrey > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=474752#474752 > > > > > Attachments: > > http://forums.matronics.com//files/tube_104.png > > > > > > ________________________________________________________________________________
Date: Nov 11, 2017
Subject: Make Sure You're Listed! List of Contributors Published in
December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 13, 2017
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that ilk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 15, 2017
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 17, 2017
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some point, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 23 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 19, 2017
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Front Canopy seal
Date: Nov 20, 2017
Ok, it was working. Now canopy closed and locked. N2 in the system (tested with 50 showing), push up the canopy seal lever, can here N2 moving. But no expansion on the seal. Anyone think of something other than a bad seal? (would I be able to hear N2 leaking out of the seal if it were bad?) thanks -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=475324#475324 ________________________________________________________________________________
Subject: Re: Front Canopy seal
Date: Nov 20, 2017
Late to the party. U probably did most of this. Front or rear? If front, the usual issue is the seal in the fill-tube behind your right shoulder. They bend easy, the rubber seal dries out. Sit in the front, facing backwards, close canopy, seal it and listen. If you hear air at the tube, grab it and force it tighter. Does the seal inflate at all? slide your ear or a plastic hose along the canopy. (One end in your ear.) Move the canopy seal knob further forward or aft and listen. There is also a pressure reducer valve, and the air valve at the knob can leak. Spray soapy water along the seal. If it is not inflating at all, it may be the switching in the canopy locking handle. Have you used the outside handle when sealing it from the outside? Or wiggling the canopy handle inside, pushing harder? If its the rear, throw it in the pool. Watch the bubbles. Or fly only in warm weather and dont pressurize. > On Nov 20, 2017, at 11:57, skidmk wrote: > > > Ok, it was working. Now canopy closed and locked. N2 in the system (tested with 50 showing), push up the canopy seal lever, can here N2 moving. But no expansion on the seal. > > Anyone think of something other than a bad seal? (would I be able to hear N2 leaking out of the seal if it were bad?) > > thanks > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=475324#475324 > > > > > > > > > ________________________________________________________________________________
Date: Nov 21, 2017
Date: Nov 24, 2017
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 26, 2017
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2017
Subject: Fund Raiser Behind By 31% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 31%. Please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Date: Nov 28, 2017
Date: Nov 29, 2017
Date: Nov 30, 2017
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 54! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 03, 2017
Subject:
Can someone refresh my memory of exact location of the Primary PT125 inverter. I was thinking rear left floor Thanks ________________________________________________________________________________
Date: Dec 03, 2017
Subject:
Can someone refresh my memory . Exact location of the primary PT125 inverter. Under left rear floor? Thanks ________________________________________________________________________________
Date: Dec 03, 2017
Subject: E: L29-List:
eWVzLiBJIHRoaW5rIGl0IGlzIHRoZSByaWdodCBmb290LgoKCgpTZW50IGZyb20gbXkgU2Ftc3Vu ZyBHYWxheHkgc21hcnRwaG9uZS4KCi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS0K RnJvbTogQ1NMQSBNdXNldW0gPGNzbGFtdXNldW1AZ21haWwuY29tPiAKRGF0ZToyMDE3LzEyLzAz ICAxMjo0MCBQTSAgKEdNVC0wNzowMCkgClRvOiBsMjktbGlzdEBtYXRyb25pY3MuY29tIApDYzog IApTdWJqZWN0OiBMMjktTGlzdDogCgotLT4gTDI5LUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IENT TEEgTXVzZXVtIDxjc2xhbXVzZXVtQGdtYWlsLmNvbT4NCg0KQ2FuIHNvbWVvbmUgcmVmcmVzaCBt eSBtZW1vcnkgLiBFeGFjdCBsb2NhdGlvbiBvZiB0aGUgcHJpbWFyeSBQVDEyNSANCmludmVydGVy LiBVbmRlciBsZWZ0IHJlYXIgZmxvb3I/DQpUaGFua3MNCg0KDQpfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAg IC0gVGhlIEwyOS1MaXN0IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0 IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGll cyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93 bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNo IG11Y2ggbW9yZToNCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZp Z2F0b3I/TDI5LUxpc3QNCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNT IFdFQiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEg dGhlIFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5j b20NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAgLSBORVcgTUFUUk9OSUNTIExJU1QgV0lL SSAtDQpfLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNzIEVtYWlsIExpc3QgV2lraSEN Cl8tPSAgIC0tPiBodHRwOi8vd2lraS5tYXRyb25pY3MuY29tDQpfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAg ICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KXy09ICBUaGFuayB5b3UgZm9yIHlv dXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1N YXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5j b20vY29udHJpYnV0aW9uDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0K ________________________________________________________________________________
Subject: Re: Tires
Date: Dec 05, 2017
Good day Gents, Ive been offline for some time and may have missed this Tyre opportunity, is there still an option to buy a set of mains please? Thanks Marty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=476125#476125 ________________________________________________________________________________
Subject: Re: Main tires for sale
Date: Dec 05, 2017
good day, are these tires still for sale? I'm looking for at least one set but will take more if there are available Thanks Marty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=476126#476126 ________________________________________________________________________________
Date: Dec 05, 2017
Desser Tires has them. You can buy them on the website. John Cabrera John F. Cabrera, M.D. > On Dec 5, 2017, at 10:55 PM, Marty wrote: > > > good day, are these tires still for sale? I'm looking for at least one set but will take more if there are available > Thanks > Marty > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=476126#476126 > > > > > > > > > ________________________________________________________________________________
Date: Dec 05, 2017
Hi John for the info, I'm hoping to find a cheaper source than Dresser if possible Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=476128#476128 ________________________________________________________________________________
Subject: Re: Help Keep Airport Courtesy Cars Running
Date: Dec 06, 2017
Thanks to those of you who donated this past month and year to help keep Airport Courtesy Cars website up and running. Your names are posted on the donor page. This month ACCs will transform to a fully web based platform that will work on any device, bug and permission free. Just bookmark the website on your home screen. Continued donations are greatly appreciated, along with new listings or corrections. See you next November. Glenn -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=476153#476153 ________________________________________________________________________________
Subject: Re: No Title
Date: Dec 07, 2017
Under the rear pilots feet. Im pulling mine out this winter if you need one. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=476199#476199 ________________________________________________________________________________
Date: Dec 17, 2017
Subject: 2017 List of Contributors
Dear Listers, The 2017 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors (LOC). It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 And finally, I'm proud to present The 2017 Fund Raiser List of Contributors: http://www.matronics.com/loc Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Date: Dec 25, 2017
Subject: Temperature regulation
Does anyone out there have a spare of of these? It=99s the motor that attaches to the cabin air mix valve. Controls the temp in the cock pit. Mi ne is frozen. I don=99t know how to take it apart with out risking si gnificant damage to the unit. John F. Cabrera ________________________________________________________________________________
Subject: L29R AFM
Date: Dec 31, 2017
Seasons greetings, Has anyone ever seen an AFM for the R model? If so, where could I get a copy? D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=476925#476925 ________________________________________________________________________________
Date: Jan 01, 2018
Update: for both aircraft, it turns out the "ground" wire pulled itself loose from the cannon plug. Both are functioning now quite nicely. Thanks for the hints. M -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=476961#476961 ________________________________________________________________________________
Date: Jan 04, 2018
Subject: L29 Brake Parts
Hi all and HNY! Was wondering if anyone out there had any leads on replacement rubber brake c ylinder pistons. I am just finishing up my annual condition inspection and have 3-4 that are in pretty rough shape. Any leads or info would be greatly appreciated. Christian Moersch RED EAGLE AERO Sent from my iPhone ________________________________________________________________________________
Subject: Re: L29 Brake Parts
Date: Jan 05, 2018
If they ain=99t leaking, don=99t touch. > On Jan 4, 2018, at 09:29, cmoersch3 wrote: > > Hi all and HNY! > > Was wondering if anyone out there had any leads on replacement rubber brake cylinder pistons. I am just finishing up my annual condition inspection and have 3-4 that are in pretty rough shape. > > Any leads or info would be greatly appreciated. > > Christian Moersch > RED EAGLE AERO > > Sent from my iPhone ________________________________________________________________________________
Date: Jan 05, 2018
Unfortunately when disassembled to rebuild and clean they don=99t fit v ery well anymore. Very loose in the cylinder. Christian Sent from my iPhone > On Jan 5, 2018, at 06:00, William Geipel wrote: > > If they ain=99t leaking, don=99t touch. > >> On Jan 4, 2018, at 09:29, cmoersch3 wrote: >> >> Hi all and HNY! >> >> Was wondering if anyone out there had any leads on replacement rubber bra ke cylinder pistons. I am just finishing up my annual condition inspection and have 3-4 that are in pretty rough shape. >> >> Any leads or info would be greatly appreciated. >> >> Christian Moersch >> RED EAGLE AERO >> >> Sent from my iPhone > ________________________________________________________________________________
Subject: Tail dolly dimensions
Date: Jan 06, 2018
Hi Does anybody have a drawing so i can build a tail dolly, i believe it can also be used for the nose? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477140#477140 ________________________________________________________________________________
Date: Jan 08, 2018
Subject: Left inside main Gear Door
Anybody have a left side inside main landing gear door p/n XL 229.501-01.05 for sale?=C2- This is the door attached to the fuselage. No corrosion or damage. Just need door only ThanksTony ________________________________________________________________________________
Date: Jan 07, 2018
Subject: Re: Left inside main Gear Door
Hi Tony, I have new or used,new has to be drilled and fitted Pete Sent from my iPad > On Jan 7, 2018, at 5:17 PM, Anthony Royal wrote: > > Anybody have a left side inside main landing gear door p/n XL 229.501-01.0 5 for sale? This is the door attached to the fuselage. No corrosion or dama ge. Just need door only > > Thanks > Tony ________________________________________________________________________________
Date: Jan 07, 2018
Why? > On Jan 7, 2018, at 18:37, Taylor wrote: > > Hi Tony, > I have new or used,new has to be drilled and fitted > Pete > > Sent from my iPad > > On Jan 7, 2018, at 5:17 PM, Anthony Royal > wrote: > >> Anybody have a left side inside main landing gear door p/n XL 229.501-01.05 for sale? This is the door attached to the fuselage. No corrosion or damage. Just need door only >> >> Thanks >> Tony ________________________________________________________________________________
Date: Jan 08, 2018
Bottom of door corroded off up about one inch and broke off.=C2- Skin, re inforcement, and c-channel support. Could probably fix but may be cheaper t o buy a door by the time I buy everything plus time.=C2- Right side was r epaired, I assume by the military, by cutting the corner off and patching b ut the underlying [parts were still good. On Sunday, January 7, 2018 9:50 PM, William Geipel w rote: Why? On Jan 7, 2018, at 18:37, Taylor wrote: Hi Tony,I have new or used,new has to be drilled and fittedPete Sent from my iPad On Jan 7, 2018, at 5:17 PM, Anthony Royal wrote: Anybody have a left side inside main landing gear door p/n XL 229.501-01.05 for sale?=C2- This is the door attached to the fuselage. No corrosion or damage. Just need door only ThanksTony ________________________________________________________________________________
Date: Jan 07, 2018
do we need to drill drain holes on the bottom? > On Jan 7, 2018, at 19:55, Anthony Royal wrote: > > Bottom of door corroded off up about one inch and broke off. Skin, reinforcement, and c-channel support. Could probably fix but may be cheaper to buy a door by the time I buy everything plus time. Right side was repaired, I assume by the military, by cutting the corner off and patching but the underlying [parts were still good. > > > On Sunday, January 7, 2018 9:50 PM, William Geipel wrote: > > > Why? > > >> On Jan 7, 2018, at 18:37, Taylor > wrote: >> > > Hi Tony, > I have new or used,new has to be drilled and fitted > Pete > > Sent from my iPad > > On Jan 7, 2018, at 5:17 PM, Anthony Royal > wrote: > >> Anybody have a left side inside main landing gear door p/n XL 229.501-01.05 for sale? This is the door attached to the fuselage. No corrosion or damage. Just need door only >> >> Thanks >> Tony > > > ________________________________________________________________________________
Date: Jan 08, 2018
No way to do that. On the very bottom tip of the gear door, just below the jack pad, you have the outer skin, behind the skin is a flat reinforcement plate, and a c-channel backer.=C2- The c-channel was fine but the skin it self looked like when magnesium corrodes. It just fell apart when I touched it. The plane stays in a hangar too and the door has good paint on it.. Th e reinforcement was almost in as bad a shape. The skin is riveted to the re inforcement and the reinforcement rivet holes had cracked thru. I cut out t he bad skin but would have to do a lot of small rivets to attach a new patc h and probably have to look at some type of automotive panel adhesive to he lp attach the patch to what's left of the reinforcement plate.....paper thi n.=C2- Be much easier and probably cheaper to install and fit a new or us ed door. If it was just the outer skin,like on the right gear door, the rep air would be a breeze.=C2-=C2- I believe this is the end that gets hit when you pull the jack out if not c areful. I've never hit it though.=C2-=C2- On Sunday, January 7, 2018 9:59 PM, William Geipel w rote: do we need to drill drain holes on the bottom? On Jan 7, 2018, at 19:55, Anthony Royal wrote: Bottom of door corroded off up about one inch and broke off.=C2- Skin, re inforcement, and c-channel support. Could probably fix but may be cheaper t o buy a door by the time I buy everything plus time.=C2- Right side was r epaired, I assume by the military, by cutting the corner off and patching b ut the underlying [parts were still good. On Sunday, January 7, 2018 9:50 PM, William Geipel w rote: Why? On Jan 7, 2018, at 18:37, Taylor wrote: Hi Tony,I have new or used,new has to be drilled and fittedPete Sent from my iPad On Jan 7, 2018, at 5:17 PM, Anthony Royal wrote: Anybody have a left side inside main landing gear door p/n XL 229.501-01.05 for sale?=C2- This is the door attached to the fuselage. No corrosion or damage. Just need door only ThanksTony ________________________________________________________________________________
Date: Jan 09, 2018
I might have one in my basement, see attached photos Might be willing to trade for other spare parts or $$ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477202#477202 Attachments: http://forums.matronics.com//files/21c78bfc_708c_49ce_8ec8_13f549b6619a_169.jpeg http://forums.matronics.com//files/e2867b42_d78b_4681_bfe3_f0a522806cfa_173.jpeg ________________________________________________________________________________
Date: Jan 09, 2018
Ground wire? Mine grounds through the airframe I found. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477203#477203 ________________________________________________________________________________
Date: Jan 09, 2018
Thanks Josh for responding. Already have one coming from another owner but appreciate it all the same. On Tuesday, January 9, 2018 6:23 PM, N777ZE wrote: I might have one in my basement, see attached photos=C2- Might be willing to trade for other spare parts or $$ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477202#477202 Attachments: http://forums.matronics.com//files/21c78bfc_708c_49ce_8ec8_13f549b6619a_169 .jpeg http://forums.matronics.com//files/e2867b42_d78b_4681_bfe3_f0a522806cfa_173 .jpeg S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jan 14, 2018
Subject: Nose Gear
Ok guys....need some help here. In process of doing the condition inspectio n on the L29.=C2- I'm servicing the nose gear strut with fluid and nitrog en.=C2- Maintenance manual says to depressurize the strut and add 3.38 oz s. of fluid and let set for 1-2 hours. then compress several times until th e upper H-H edge of the piston rod nut is level with the K-K plane of the c ylinder closing nut ( see Fig. 3.11). Excess fluid escapes thru the filler valve opening. After this operation, the quantity of AMG-10 (Aeroshell Flui d 4) will be correct. Fill with nitrogen to correct pressure. Does anyone have a copy of Fig 3.11 they could email me?=C2- I have not b een able to find this figure in any of my books.=C2- I have 4.25" of exte nded strut. With the 3.38 oz of added fluid, the strut will hydraulic lock upon compression at about 3" of exposed and I'm pretty sure that is not rig ht.=C2-=C2-Any help is appreciate.skyking76t(at)verizon.net ________________________________________________________________________________
Subject: Re: Nose Gear
Date: Jan 14, 2018
Try this, Collapse the strut completely, (on jacks of course), add fluid until it is overflowing, let the strut extend, top off with nitrogen and a nice cocktail. Just a thought. How much nitrogen pressure do you have in the strut? 19 + 1 is correct. (ATM) > On Jan 14, 2018, at 16:46, Anthony Royal wrote: > > Ok guys....need some help here. In process of doing the condition inspection on the L29. I'm servicing the nose gear strut with fluid and nitrogen. Maintenance manual says to depressurize the strut and add 3.38 ozs. of fluid and let set for 1-2 hours. then compress several times until the upper H-H edge of the piston rod nut is level with the K-K plane of the cylinder closing nut ( see Fig. 3.11). Excess fluid escapes thru the filler valve opening. After this operation, the quantity of AMG-10 (Aeroshell Fluid 4) will be correct. Fill with nitrogen to correct pressure. > > Does anyone have a copy of Fig 3.11 they could email me? I have not been able to find this figure in any of my books. I have 4.25" of extended strut. With the 3.38 oz of added fluid, the strut will hydraulic lock upon compression at about 3" of exposed and I'm pretty sure that is not right. > > Any help is appreciate. > skyking76t(at)verizon.net ________________________________________________________________________________
Date: Jan 15, 2018
Worth a try. In my civil aircraft, we added just enough fluid so the strut would stop 0.5" from full collapse, to keep from bottoming out metal to met al if you lost pressure. That worked good for those. I've never been able to get that much in mine. It completely extends the st rut. Last time I added 18 atm, I let out enough so that when I pushed down on the nose, the strut went down and bounced back to full extend, then sett led back down about an inch. That worked good. This summer the strut seemed to increase pressure and go back to just barely short of full extend on it s own. Became worried might fully extend on the ground at the wrong time an d lock in straight position and lose steering. Thus, trying to set as much per book with regards to fluid as possible and then work with pressure.=C2 - On Sunday, January 14, 2018 7:27 PM, William Geipel wrote: Try this, Collapse the strut completely, (on jacks of course), add fluid u ntil it is overflowing, let the strut extend, top off with nitrogen and a n ice cocktail.Just a thought.=C2- How much nitrogen pressure do you have in the strut? 19=C2-+=C2-1 is co rrect. (ATM) On Jan 14, 2018, at 16:46, Anthony Royal wrote: Ok guys....need some help here. In process of doing the condition inspectio n on the L29.=C2- I'm servicing the nose gear strut with fluid and nitrog en.=C2- Maintenance manual says to depressurize the strut and add 3.38 oz s. of fluid and let set for 1-2 hours. then compress several times until th e upper H-H edge of the piston rod nut is level with the K-K plane of the c ylinder closing nut ( see Fig. 3.11). Excess fluid escapes thru the filler valve opening. After this operation, the quantity of AMG-10 (Aeroshell Flui d 4) will be correct. Fill with nitrogen to correct pressure. Does anyone have a copy of Fig 3.11 they could email me?=C2- I have not b een able to find this figure in any of my books.=C2- I have 4.25" of exte nded strut. With the 3.38 oz of added fluid, the strut will hydraulic lock upon compression at about 3" of exposed and I'm pretty sure that is not rig ht.=C2-=C2-Any help is appreciate.skyking76t(at)verizon.net ________________________________________________________________________________
Date: Jan 14, 2018
I use the same approach as Bill, works well. But not the same cocktail Bill Culberson N39DE (till tomorrow) Sent from my iPhone > On Jan 14, 2018, at 6:26 PM, William Geipel wrote: > > Try this, Collapse the strut completely, (on jacks of course), add fluid u ntil it is overflowing, let the strut extend, top off with nitrogen and a ni ce cocktail. > Just a thought. > > How much nitrogen pressure do you have in the strut? 19 + 1 is correct. (A TM) > > >> On Jan 14, 2018, at 16:46, Anthony Royal wrote: >> >> Ok guys....need some help here. In process of doing the condition inspect ion on the L29. I'm servicing the nose gear strut with fluid and nitrogen. Maintenance manual says to depressurize the strut and add 3.38 ozs. of flui d and let set for 1-2 hours. then compress several times until the upper H-H edge of the piston rod nut is level with the K-K plane of the cylinder clos ing nut ( see Fig. 3.11). Excess fluid escapes thru the filler valve opening . After this operation, the quantity of AMG-10 (Aeroshell Fluid 4) will be c orrect. Fill with nitrogen to correct pressure. >> >> Does anyone have a copy of Fig 3.11 they could email me? I have not been able to find this figure in any of my books. I have 4.25" of extended stru t. With the 3.38 oz of added fluid, the strut will hydraulic lock upon compr ession at about 3" of exposed and I'm pretty sure that is not right. >> >> Any help is appreciate. >> skyking76t(at)verizon.net > ________________________________________________________________________________
Date: Jan 14, 2018
Till tomorrow? > On Jan 14, 2018, at 18:15, Bill Culberson wrote: > > I use the same approach as Bill, works well. > > But not the same cocktail > > Bill Culberson > N39DE (till tomorrow) > > Sent from my iPhone > > On Jan 14, 2018, at 6:26 PM, William Geipel > wrote: > >> Try this, Collapse the strut completely, (on jacks of course), add fluid until it is overflowing, let the strut extend, top off with nitrogen and a nice cocktail. >> Just a thought. >> >> How much nitrogen pressure do you have in the strut? 19 + 1 is correct. (ATM) >> >> >>> On Jan 14, 2018, at 16:46, Anthony Royal > wrote: >>> >>> Ok guys....need some help here. In process of doing the condition inspection on the L29. I'm servicing the nose gear strut with fluid and nitrogen. Maintenance manual says to depressurize the strut and add 3.38 ozs. of fluid and let set for 1-2 hours. then compress several times until the upper H-H edge of the piston rod nut is level with the K-K plane of the cylinder closing nut ( see Fig. 3.11). Excess fluid escapes thru the filler valve opening. After this operation, the quantity of AMG-10 (Aeroshell Fluid 4) will be correct. Fill with nitrogen to correct pressure. >>> >>> Does anyone have a copy of Fig 3.11 they could email me? I have not been able to find this figure in any of my books. I have 4.25" of extended strut. With the 3.38 oz of added fluid, the strut will hydraulic lock upon compression at about 3" of exposed and I'm pretty sure that is not right. >>> >>> Any help is appreciate. >>> skyking76t(at)verizon.net ________________________________________________________________________________
Date: Jan 15, 2018
If that works for both of you, I will give it a try. Thanks for both your i nputs. On Sunday, January 14, 2018 8:19 PM, William Geipel wrote: Till tomorrow? On Jan 14, 2018, at 18:15, Bill Culberson wrote: I use the same approach as Bill, works well.=C2- But not the same cocktail Bill CulbersonN39DE (till tomorrow) Sent from my iPhone On Jan 14, 2018, at 6:26 PM, William Geipel wrote: Try this, Collapse the strut completely, (on jacks of course), add fluid un til it is overflowing, let the strut extend, top off with nitrogen and a ni ce cocktail.Just a thought.=C2- How much nitrogen pressure do you have in the strut? 19=C2-+=C2-1 is co rrect. (ATM) On Jan 14, 2018, at 16:46, Anthony Royal wrote: Ok guys....need some help here. In process of doing the condition inspectio n on the L29.=C2- I'm servicing the nose gear strut with fluid and nitrog en.=C2- Maintenance manual says to depressurize the strut and add 3.38 oz s. of fluid and let set for 1-2 hours. then compress several times until th e upper H-H edge of the piston rod nut is level with the K-K plane of the c ylinder closing nut ( see Fig. 3.11). Excess fluid escapes thru the filler valve opening. After this operation, the quantity of AMG-10 (Aeroshell Flui d 4) will be correct. Fill with nitrogen to correct pressure. Does anyone have a copy of Fig 3.11 they could email me?=C2- I have not b een able to find this figure in any of my books.=C2- I have 4.25" of exte nded strut. With the 3.38 oz of added fluid, the strut will hydraulic lock upon compression at about 3" of exposed and I'm pretty sure that is not rig ht.=C2-=C2-Any help is appreciate.skyking76t(at)verizon.net ________________________________________________________________________________
Date: Jan 15, 2018
After 2 days searching, I just found the diagram that shows the H-H and K-K planes and it wasn't a Fig 3.11.=C2- It was a Fig. 45 .....and you both were correct to collapse the strut all the way.=C2- =C2-Thanks for the guidance!!! On Sunday, January 14, 2018 8:34 PM, Anthony Royal <skyking76t@verizon. net> wrote: If that works for both of you, I will give it a try. Thanks for both your inputs. On Sunday, January 14, 2018 8:19 PM, William Geipel wrote: Till tomorrow? On Jan 14, 2018, at 18:15, Bill Culberson wrote: I use the same approach as Bill, works well.=C2- But not the same cocktail Bill CulbersonN39DE (till tomorrow) Sent from my iPhone On Jan 14, 2018, at 6:26 PM, William Geipel wrote: Try this, Collapse the strut completely, (on jacks of course), add fluid un til it is overflowing, let the strut extend, top off with nitrogen and a ni ce cocktail.Just a thought.=C2- How much nitrogen pressure do you have in the strut? 19=C2-+=C2-1 is co rrect. (ATM) On Jan 14, 2018, at 16:46, Anthony Royal wrote: Ok guys....need some help here. In process of doing the condition inspectio n on the L29.=C2- I'm servicing the nose gear strut with fluid and nitrog en.=C2- Maintenance manual says to depressurize the strut and add 3.38 oz s. of fluid and let set for 1-2 hours. then compress several times until th e upper H-H edge of the piston rod nut is level with the K-K plane of the c ylinder closing nut ( see Fig. 3.11). Excess fluid escapes thru the filler valve opening. After this operation, the quantity of AMG-10 (Aeroshell Flui d 4) will be correct. Fill with nitrogen to correct pressure. Does anyone have a copy of Fig 3.11 they could email me?=C2- I have not b een able to find this figure in any of my books.=C2- I have 4.25" of exte nded strut. With the 3.38 oz of added fluid, the strut will hydraulic lock upon compression at about 3" of exposed and I'm pretty sure that is not rig ht.=C2-=C2-Any help is appreciate.skyking76t(at)verizon.net ________________________________________________________________________________
Date: Jan 14, 2018
Tomorrow I will be selling my L-29 to a friend of mine from Tennessee. Sent from my iPhone > On Jan 14, 2018, at 7:33 PM, Anthony Royal wrote: > > If that works for both of you, I will give it a try. Thanks for both your i nputs. > > > On Sunday, January 14, 2018 8:19 PM, William Geipel wro te: > > > Till tomorrow? > >> On Jan 14, 2018, at 18:15, Bill Culberson wrote: >> > > I use the same approach as Bill, works well. > > But not the same cocktail > > Bill Culberson > N39DE (till tomorrow) > > Sent from my iPhone > >> On Jan 14, 2018, at 6:26 PM, William Geipel wrote: >> > > Try this, Collapse the strut completely, (on jacks of course), add fluid u ntil it is overflowing, let the strut extend, top off with nitrogen and a ni ce cocktail. > Just a thought. > > How much nitrogen pressure do you have in the strut? 19 + 1 is correct. (A TM) > > >> On Jan 14, 2018, at 16:46, Anthony Royal wrote: >> >> Ok guys....need some help here. In process of doing the condition inspect ion on the L29. I'm servicing the nose gear strut with fluid and nitrogen. Maintenance manual says to depressurize the strut and add 3.38 ozs. of flui d and let set for 1-2 hours. then compress several times until the upper H-H edge of the piston rod nut is level with the K-K plane of the cylinder clos ing nut ( see Fig. 3.11). Excess fluid escapes thru the filler valve opening . After this operation, the quantity of AMG-10 (Aeroshell Fluid 4) will be c orrect. Fill with nitrogen to correct pressure. >> >> Does anyone have a copy of Fig 3.11 they could email me? I have not been able to find this figure in any of my books. I have 4.25" of extended stru t. With the 3.38 oz of added fluid, the strut will hydraulic lock upon compr ession at about 3" of exposed and I'm pretty sure that is not right. >> >> Any help is appreciate. >> skyking76t(at)verizon.net > > > > ________________________________________________________________________________
Date: Jan 15, 2018
Bill,Hate to hear that. If you have any parts you want to part with let me know,. Good LuckTony On Sunday, January 14, 2018 9:39 PM, Bill Culberson wrote: Tomorrow I will be selling my L-29 to a friend of mine from Tennessee. Sent from my iPhone On Jan 14, 2018, at 7:33 PM, Anthony Royal wrote: If that works for both of you, I will give it a try. Thanks for both your i nputs. On Sunday, January 14, 2018 8:19 PM, William Geipel wrote: Till tomorrow? On Jan 14, 2018, at 18:15, Bill Culberson wrote: I use the same approach as Bill, works well.=C2- But not the same cocktail Bill CulbersonN39DE (till tomorrow) Sent from my iPhone On Jan 14, 2018, at 6:26 PM, William Geipel wrote: Try this, Collapse the strut completely, (on jacks of course), add fluid un til it is overflowing, let the strut extend, top off with nitrogen and a ni ce cocktail.Just a thought.=C2- How much nitrogen pressure do you have in the strut? 19=C2-+=C2-1 is co rrect. (ATM) On Jan 14, 2018, at 16:46, Anthony Royal wrote: Ok guys....need some help here. In process of doing the condition inspectio n on the L29.=C2- I'm servicing the nose gear strut with fluid and nitrog en.=C2- Maintenance manual says to depressurize the strut and add 3.38 oz s. of fluid and let set for 1-2 hours. then compress several times until th e upper H-H edge of the piston rod nut is level with the K-K plane of the c ylinder closing nut ( see Fig. 3.11). Excess fluid escapes thru the filler valve opening. After this operation, the quantity of AMG-10 (Aeroshell Flui d 4) will be correct. Fill with nitrogen to correct pressure. Does anyone have a copy of Fig 3.11 they could email me?=C2- I have not b een able to find this figure in any of my books.=C2- I have 4.25" of exte nded strut. With the 3.38 oz of added fluid, the strut will hydraulic lock upon compression at about 3" of exposed and I'm pretty sure that is not rig ht.=C2-=C2-Any help is appreciate.skyking76t(at)verizon.net ________________________________________________________________________________
Date: Jan 16, 2018
Late to the party..... [Laughing] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477350#477350 Attachments: http://forums.matronics.com//files/__copy_823.jpg ________________________________________________________________________________
Date: Jan 17, 2018
Yes, I finally found that diagram by accident after 2 days searching page b y page thru the books but yours is much more readable than mine. I believe it's a Fig 45, not Fig 3.11 as was in the instructions.. Thank you for sending. Anything I can help you with let me know! On Tuesday, January 16, 2018 3:24 PM, Alekh wrote: Late to the party..... [Laughing] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477350#477350 Attachments: http://forums.matronics.com//files/__copy_823.jpg S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jan 16, 2018
what does it say? > On Jan 16, 2018, at 21:23, Anthony Royal wrote: > > Yes, I finally found that diagram by accident after 2 days searching page by page thru the books but yours is much more readable than mine. I believe it's a Fig 45, not Fig 3.11 as was in the instructions.. > > Thank you for sending. Anything I can help you with let me know! > > > On Tuesday, January 16, 2018 3:24 PM, Alekh wrote: > > > > > Late to the party..... [Laughing] > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477350#477350 <http://forums.matronics.com/viewtopic.php?p=477350#477350> > > > > > Attachments: > > http://forums.matronics.com//files/__copy_823.jpg <http://forums.matronics.com//files/__copy_823.jpg> > > http://www.m================ > http://wiki.matronics.com================ === > http://w===== > > > > > ________________________________________________________________________________
Date: Jan 17, 2018
Maintenance manual says to depressurize the strut and add 3.38 ozs. of fluid and let set for 1-2 hours. then compress several times until the upper H-H edge of the piston rod nut is level with the K-K plane of the cylinder closing nut ( see Fig. 3.11). On Wednesday, January 17, 2018 3:17 AM, William Geipel wrote: what does it say? On Jan 16, 2018, at 21:23, Anthony Royal wrote: Yes, I finally found that diagram by accident after 2 days searching page by page thru the books but yours is much more readable than mine. I believe it's a Fig 45, not Fig 3.11 as was in the instructions.. Thank you for sending. Anything I can help you with let me know! On Tuesday, January 16, 2018 3:24 PM, Alekh wrote: Late to the party..... [Laughing] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477350#477350 Attachments: http://forums.matronics.com//files/__copy_823.jpg http://www.m================ http://wiki.matronics.com=================== http://w===== ________________________________________________________________________________
Date: Jan 17, 2018
It's a figure 3.11. You need see fig 14.5-6 for charge procedure. Here is Russian manual, and it says: 1. Hang up the aircraft (wheels are hanging up, not touching the ground). 2. Depressurize the strut 3. Take the nipple out 4. Add 100cm3 of fluid thru the nipple hole 5. Wait for 1.5-2 hours 6. Slowly compress until the upper H-H edge of the piston rod nut is level with the K-K plane of the cylinder closing nut. Excess of oil will get out. 7. Install the nipple back 8. Fill up by Azote at 2atm more than normal pressure. The pressure will decrease about 2atm over short time. 9. Fill up a log book and ready to go. I hope it helps. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477371#477371 Attachments: http://forums.matronics.com//files/5070_1516210334.jpg_112.jpg ________________________________________________________________________________
Date: Jan 21, 2018
Subject: Re: Fwd: [barnstormers.com] Re: Recovered Pietenpol 325 hours
Begin forwarded message: > From: Kenneth Howes <howestheflying(at)hotmail.com> > Date: January 8, 2018 at 05:47:11 GMT+9 > To: "L129bs(at)gmail.com" > Subject: Re: [barnstormers.com] Re: Recovered Pietenpol 325 hours > > Let me know if you have other questions. > > > From: noreply(at)barnstormers.com <noreply(at)barnstormers.com> > Sent: Sunday, January 7, 2018 9:43 AM > To: howestheflying(at)hotmail.com > Subject: [barnstormers.com] Re: Recovered Pietenpol 325 hours > > > Hi Kenneth Howes, > the following message from bill was sent through the barnstormers.com web > site in regard to the following listing.. > https://www.barnstormers.com/ad_manager/listing.php?id=1329820 > BARNSTORMERS.COM > www.barnstormers.com > This website is dedicated to the sport and commercial aviation industry. > > > to reply to bill simply reply to this email. > > From..........: bill > Email.........: L129bs(at)gmail.com > Phone.........: 303-408-6899 > City..........: westcliffe > State/Province: co > Country.......: usa > IP............: 97.73.240.146 > > PIX? > > ------------------------------------------------------- > BARNSTORMERS WARNING! The number of scammers working on the Internet are > increasing dramatically. Scammers hide behind false names, addresses, > telephone numbers and proxy IP addresses, and constantly change their > identities. If you receive a response to your ad that is suspicious, please > forward that email to baroness(at)barnstormers.com as soon as possible. We > appreciate your help in identifying scammers. Thank you. > > See Barnstormers "Internet Fraud" page for some examples at: > http://www.barnstormers.com/fraud/fraud.html > > ________________________________________________________________________________
Date: Jan 21, 2018
Date: Jan 29, 2018
Subject: Book Flights, Airline Tickets, Discount Airfare on FlyFrontier.com
| Frontier Airlines https://booking.flyfrontier.com/Booking/Index ________________________________________________________________________________
Date: Feb 23, 2018
Subject: Re: Temperature regulation
Hi John I have a new one Pete Sent from my iPad > On Dec 25, 2017, at 7:31 PM, John Cabrera wrote: > > Does anyone out there have a spare of of these? Its the motor that attaches to the cabin air mix valve. Controls the temp in the cock pit. Mine is frozen. I dont know how to take it apart with out risking significant damage to the unit. > > > > > John F. Cabrera ________________________________________________________________________________
Subject: Hang Start
Date: Mar 31, 2018
anyone seen this? I highly suspect it is the batteries, but.... I did use the EPU. So. -7 celcius today in the great white north. Went out, preflight, nitro, fuel, everything in the green. Normal start sequence with the little EPU, she starts up and gets to 20% RPM and sits there at 20%. nothing more, shut down. Again, same result. got out the big epu (commercial for Falcons/Kingairs etc), same results, the epu kicks out 400 amp, then drops to zero (expect that) and the planes sits at 20%. Egt's never over 575. any thoughts? I am really thinking its batteries in the nose are weak or done (odyssey's that are fairly old) -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478948#478948 ________________________________________________________________________________
Date: Mar 31, 2018
Subject: Ignitors and Wires
Does anyone out there have qty (2) new ignitors and qty (2) new ignitor wir es for the M701?=C2- Part number on the ignitors is=C2-PAL N 80-3. If n ot, I'll take salvage parts if they are good. At the very least I need the ignitor wire that runs from the controller on the left side to the ignitor on the right side...the longest wire.=C2- My wire burnt off inside the metal elbow that attaches the wire to the ignito r. The ceramic is cracked in the elbow so I can't salvage it. Also, I think I have asked this question before. Has anyone ever taken the oil pump plate off the bottom of the oil pan to look at the oil pump gears? Mine is weeping oil around the oil=C2- pump mounting screws. Tightening doesn't help and there is a black 'centering screw" that I would like to kn ow how to set and exactly what it does. Thanks Anthony ________________________________________________________________________________
Date: Mar 31, 2018
Subject: Re: Hang Start
1. Battery 2. High pressure fuel pump 3. Start box not going into final cycle On March 31, 2018 17:08:50 "skidmk" wrote: > > anyone seen this? I highly suspect it is the batteries, but.... I did use > the EPU. > > So. -7 celcius today in the great white north. Went out, preflight, > nitro, fuel, everything in the green. > > Normal start sequence with the little EPU, she starts up and gets to 20% > RPM and sits there at 20%. nothing more, shut down. Again, same result. > > got out the big epu (commercial for Falcons/Kingairs etc), same results, > the epu kicks out 400 amp, then drops to zero (expect that) and the planes > sits at 20%. > > Egt's never over 575. > > any thoughts? I am really thinking its batteries in the nose are weak or > done (odyssey's that are fairly old) > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478948#478948 > > ________________________________________________________________________________
Date: Apr 01, 2018
Subject: Hang Start
QmF0dGVyaWVzLiBRdWVzdGlvbjsgV2hlbiB5b3UgcHVzaCB0aGUgc3RhcnQgYnV0dG9uLCB0ZWxs IG1lIGV4YWN0bHkgd2hhdCB5b3UgaGVhci4gRVhBQ1RMWS4KSVUgc2hvdWxkIGhlYXIgdGhlIHN0 YXJ0ZXIgZW5nYWRlLCAoMjAwIGFtcHMpLCB0aGVuIGVpdGhlciB0aGUgc3RhcnRlciBleGNlbGxl cmF0aW5nIHRvIDQwMCBhbXBzIE9SIGlnbml0ZXIgZ29pbmcgdGlja3RpY2ssIHRpY2t0aWNrLCB0 aWNrdGljay4gTk9UIHRpY2suICB0aWNrLiAgdGljayBldGMuIHNvbWV0aW1lcyBpZ25pdGVzIGNv bWUgYmVmb3JlIHN0YXJ0IGFjY2VsZXJhdGlvbiBzb21ldGltZXMgdGhlIG90aGVyIHdheS4KSWYg eW91IGRvbid0IGhlYXIgYWxsIDMgb2YgdGhvc2UsIERPIE5PVCBQVVQgVEhFIEZVRUwgVE8gSVQu Ck5ldyBiYXR0ZXJpZXMgb3IgMjQrIHZvbHQgRVBVLgoKCgpTZW50IGZyb20gbXkgU2Ftc3VuZyBH YWxheHkgc21hcnRwaG9uZS4KCi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS0KRnJv bTogc2tpZG1rIDxza2lkbWtAZ21haWwuY29tPiAKRGF0ZToyMDE4LzAzLzMxICAxNjowNiAgKEdN VC0wNzowMCkgClRvOiBsMjktbGlzdEBtYXRyb25pY3MuY29tIApDYzogIApTdWJqZWN0OiBMMjkt TGlzdDogSGFuZyBTdGFydCAKCi0tPiBMMjktTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogInNraWRt ayIgPHNraWRta0BnbWFpbC5jb20+DQoNCmFueW9uZSBzZWVuIHRoaXM/ICBJIGhpZ2hseSBzdXNw ZWN0IGl0IGlzIHRoZSBiYXR0ZXJpZXMsIGJ1dC4uLi4gSSBkaWQgdXNlIHRoZSBFUFUuDQoNClNv LiAgLTcgY2VsY2l1cyB0b2RheSBpbiB0aGUgZ3JlYXQgd2hpdGUgbm9ydGguICBXZW50IG91dCwg cHJlZmxpZ2h0LCBuaXRybywgZnVlbCwgZXZlcnl0aGluZyBpbiB0aGUgZ3JlZW4uDQoNCk5vcm1h bCBzdGFydCBzZXF1ZW5jZSB3aXRoIHRoZSBsaXR0bGUgRVBVLCBzaGUgc3RhcnRzIHVwIGFuZCBn ZXRzIHRvIDIwJSBSUE0gYW5kIHNpdHMgdGhlcmUgYXQgMjAlLiAgbm90aGluZyBtb3JlLCBzaHV0 IGRvd24uIEFnYWluLCBzYW1lIHJlc3VsdC4NCg0KZ290IG91dCB0aGUgYmlnIGVwdSAoY29tbWVy Y2lhbCBmb3IgRmFsY29ucy9LaW5nYWlycyBldGMpLCBzYW1lIHJlc3VsdHMsIHRoZSBlcHUga2lj a3Mgb3V0IDQwMCBhbXAsIHRoZW4gZHJvcHMgdG8gemVybyAoZXhwZWN0IHRoYXQpIGFuZCB0aGUg cGxhbmVzIHNpdHMgYXQgMjAlLg0KDQpFZ3QncyBuZXZlciBvdmVyIDU3NS4NCg0KYW55IHRob3Vn aHRzPyAgSSBhbSByZWFsbHkgdGhpbmtpbmcgaXRzIGJhdHRlcmllcyBpbiB0aGUgbm9zZSBhcmUg d2VhayBvciBkb25lIChvZHlzc2V5J3MgdGhhdCBhcmUgZmFpcmx5IG9sZCkNCg0KLS0tLS0tLS0N Ck1pa2UgJnF1b3Q7U2tpZG1rJnF1b3Q7IEJvdXJnZXQNCk90dGF3YSwgT250YXJpbw0KDQoNCg0K DQpSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6DQoNCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNz LmNvbS92aWV3dG9waWMucGhwP3A9NDc4OTQ4IzQ3ODk0OA0KDQoNCg0KDQoNCg0KXy09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8t PSAgICAgICAgICAtIFRoZSBMMjktTGlzdCBFbWFpbCBGb3J1bSAtDQpfLT0gVXNlIHRoZSBNYXRy b25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQpfLT0gdGhlIG1hbnkgTGlz dCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCl8tPSBBcmNoaXZlIFNl YXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCl8tPSBQaG90b3NoYXJl LCBhbmQgbXVjaCBtdWNoIG1vcmU6DQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmlj cy5jb20vTmF2aWdhdG9yP0wyOS1MaXN0DQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgICAt IE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFp bGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KXy09DQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5t YXRyb25pY3MuY29tDQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgIC0gTkVXIE1BVFJPTklD UyBMSVNUIFdJS0kgLQ0KXy09IEFkZCBzb21lIGluZm8gdG8gdGhlIE1hdHJvbmljcyBFbWFpbCBM aXN0IFdpa2khDQpfLT0gICAtLT4gaHR0cDovL3dpa2kubWF0cm9uaWNzLmNvbQ0KXy09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8t PSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsg eW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5t YXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KDQoNCg= ________________________________________________________________________________
Date: Apr 01, 2018
Subject: Hang Start
T1IgYSBzdGFydGVyIGJveCwgaWduaXRlciBib3gsIG9yIGlnbml0b3IgcGx1Z3MuCgpIVU5HIFNU QVJULgoKCgpTZW50IGZyb20gbXkgU2Ftc3VuZyBHYWxheHkgc21hcnRwaG9uZS4KCi0tLS0tLS0t IE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS0KRnJvbTogc2tpZG1rIDxza2lkbWtAZ21haWwuY29t PiAKRGF0ZToyMDE4LzAzLzMxICAxNjowNiAgKEdNVC0wNzowMCkgClRvOiBsMjktbGlzdEBtYXRy b25pY3MuY29tIApDYzogIApTdWJqZWN0OiBMMjktTGlzdDogSGFuZyBTdGFydCAKCi0tPiBMMjkt TGlzdCBtZXNzYWdlIHBvc3RlZCBieTogInNraWRtayIgPHNraWRta0BnbWFpbC5jb20+DQoNCmFu eW9uZSBzZWVuIHRoaXM/ICBJIGhpZ2hseSBzdXNwZWN0IGl0IGlzIHRoZSBiYXR0ZXJpZXMsIGJ1 dC4uLi4gSSBkaWQgdXNlIHRoZSBFUFUuDQoNClNvLiAgLTcgY2VsY2l1cyB0b2RheSBpbiB0aGUg Z3JlYXQgd2hpdGUgbm9ydGguICBXZW50IG91dCwgcHJlZmxpZ2h0LCBuaXRybywgZnVlbCwgZXZl cnl0aGluZyBpbiB0aGUgZ3JlZW4uDQoNCk5vcm1hbCBzdGFydCBzZXF1ZW5jZSB3aXRoIHRoZSBs aXR0bGUgRVBVLCBzaGUgc3RhcnRzIHVwIGFuZCBnZXRzIHRvIDIwJSBSUE0gYW5kIHNpdHMgdGhl cmUgYXQgMjAlLiAgbm90aGluZyBtb3JlLCBzaHV0IGRvd24uIEFnYWluLCBzYW1lIHJlc3VsdC4N Cg0KZ290IG91dCB0aGUgYmlnIGVwdSAoY29tbWVyY2lhbCBmb3IgRmFsY29ucy9LaW5nYWlycyBl dGMpLCBzYW1lIHJlc3VsdHMsIHRoZSBlcHUga2lja3Mgb3V0IDQwMCBhbXAsIHRoZW4gZHJvcHMg dG8gemVybyAoZXhwZWN0IHRoYXQpIGFuZCB0aGUgcGxhbmVzIHNpdHMgYXQgMjAlLg0KDQpFZ3Qn cyBuZXZlciBvdmVyIDU3NS4NCg0KYW55IHRob3VnaHRzPyAgSSBhbSByZWFsbHkgdGhpbmtpbmcg aXRzIGJhdHRlcmllcyBpbiB0aGUgbm9zZSBhcmUgd2VhayBvciBkb25lIChvZHlzc2V5J3MgdGhh dCBhcmUgZmFpcmx5IG9sZCkNCg0KLS0tLS0tLS0NCk1pa2UgJnF1b3Q7U2tpZG1rJnF1b3Q7IEJv dXJnZXQNCk90dGF3YSwgT250YXJpbw0KDQoNCg0KDQpSZWFkIHRoaXMgdG9waWMgb25saW5lIGhl cmU6DQoNCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhwP3A9NDc4OTQ4 IzQ3ODk0OA0KDQoNCg0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRoZSBMMjktTGlzdCBF bWFpbCBGb3J1bSAtDQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0 b3IgdG8gYnJvd3NlDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVu L1N1YnNjcmlwdGlvbiwNCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93 c2UsIENoYXQsIEZBUSwNCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQpfLT0N Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0wyOS1MaXN0DQpf LT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09DQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCl8t PSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0K Xy09DQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpfLT0NCl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpf LT0gICAgICAgICAgICAgIC0gTkVXIE1BVFJPTklDUyBMSVNUIFdJS0kgLQ0KXy09IEFkZCBzb21l IGluZm8gdG8gdGhlIE1hdHJvbmljcyBFbWFpbCBMaXN0IFdpa2khDQpfLT0gICAtLT4gaHR0cDov L3dpa2kubWF0cm9uaWNzLmNvbQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJp YnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBv cnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3Qg QWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0K Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0NCg0KDQoNCg= ________________________________________________________________________________
Date: Apr 02, 2018
Subject: Rear canopy
Im looking for a complete rear canopy with good glass. Thank you in advance! Sent from my iPhone ________________________________________________________________________________
Subject: Re: Rear canopy
Date: Apr 03, 2018
(972) 218-9700 Cold War Air Museum > On Apr 2, 2018, at 21:49, Brian wrote: > > > I=99m looking for a complete rear canopy with good glass. Thank you in advance! > > Sent from my iPhone > > > > ________________________________________________________________________________
Subject: AirNav.com Now Linked to Airport Courtesy Cars
Date: Apr 04, 2018
Airport Courtesy Cars website has been updated to link to AirNav.com. Click on any of the over 1,850 airport IDs within the site and you will be taken to the AirNav.com page for that airport. Please note Airport Courtesy Cars is now fully web based and works on any device. We have also added many locations with MOGAS. Have a great flying season and please consider a small donation to keep this site running and get your name added to the donor page. Thanks, Glenn -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479056#479056 ________________________________________________________________________________
Subject: Re: Ignitors and Wires
Date: Apr 04, 2018
In August I will have couple new ignitors. I already pre-paid them but they are in Russia at this time. Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479099#479099 Attachments: http://forums.matronics.com//files/igniter_634.png ________________________________________________________________________________
Date: Apr 05, 2018
Hi Andy, I found 2 new ignitors and 2 new ignitor wires. Should have them in 3 or 4 days.=C2- But thanks for the reply!=C2-=C2- Tony On Wednesday, April 4, 2018 4:42 PM, Alekh wrote: In August I will have couple new ignitors. I already pre-paid them but they are in Russia at this time. Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479099#479099 Attachments: http://forums.matronics.com//files/igniter_634.png S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 06, 2018
ok. we replaced our batteries today, start with EPU same results. Exactly what I hear. the starter goes (200 amp), then the tick tick tick... not ticktick ticktick. The the 400 amp goes... egts' climb to 600, then drop off to 550 and stay there. the mechanic last year did say the ignitors were on their last leg and should be replaced. We are sourcing them, but have had no luck so far. Should we replace ignitors before start box? Is there anything I can do to start box in terms of checking it works? I know its mechanical, so could lubricate be sprayed on some of the gears or valves? We'd prefer not to have to buy a ton of parts to figure out it was the ignitors. The tail is off our 2nd ship, I may swap the ignitors and see? thanks for the replies. -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479142#479142 ________________________________________________________________________________
Date: Apr 06, 2018
The ignitor box controls the start sequence so I dont think it is the box. Ticktick = both ignitors..Tick tick is one plug. Have you changed fuel filters lately? Sometimes if you dont bleed the air out after filter change it wont start. I like the idea of first changing the plugs with the other engine. When you pull the plug see if it is sparking. > On Apr 6, 2018, at 17:07, skidmk wrote: > > > ok. > > we replaced our batteries today, start with EPU same results. > > Exactly what I hear. the starter goes (200 amp), then the tick tick tick... not ticktick ticktick. The the 400 amp goes... egts' climb to 600, then drop off to 550 and stay there. > > the mechanic last year did say the ignitors were on their last leg and should be replaced. We are sourcing them, but have had no luck so far. > > Should we replace ignitors before start box? Is there anything I can do to start box in terms of checking it works? I know its mechanical, so could lubricate be sprayed on some of the gears or valves? > > We'd prefer not to have to buy a ton of parts to figure out it was the ignitors. The tail is off our 2nd ship, I may swap the ignitors and see? > > thanks for the replies. > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479142#479142 > > > > > > > > > ________________________________________________________________________________
Date: Apr 06, 2018
Does it do the same thing on ships batteries? > On Apr 6, 2018, at 17:07, skidmk wrote: > > > ok. > > we replaced our batteries today, start with EPU same results. > > Exactly what I hear. the starter goes (200 amp), then the tick tick tick... not ticktick ticktick. The the 400 amp goes... egts' climb to 600, then drop off to 550 and stay there. > > the mechanic last year did say the ignitors were on their last leg and should be replaced. We are sourcing them, but have had no luck so far. > > Should we replace ignitors before start box? Is there anything I can do to start box in terms of checking it works? I know its mechanical, so could lubricate be sprayed on some of the gears or valves? > > We'd prefer not to have to buy a ton of parts to figure out it was the ignitors. The tail is off our 2nd ship, I may swap the ignitors and see? > > thanks for the replies. > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479142#479142 > > > > > > > > > ________________________________________________________________________________
Date: Apr 07, 2018
Try first to change the plugs. Best regards, Jean > Le 7 avr. 2018 00:07, skidmk a crit : > > > ok. > > we replaced our batteries today, start with EPU same results. > > Exactly what I hear. the starter goes (200 amp), then the tick tick tick... not ticktick ticktick. The the 400 amp goes... egts' climb to 600, then drop off to 550 and stay there. > > the mechanic last year did say the ignitors were on their last leg and should be replaced. We are sourcing them, but have had no luck so far. > > Should we replace ignitors before start box? Is there anything I can do to start box in terms of checking it works? I know its mechanical, so could lubricate be sprayed on some of the gears or valves? > > We'd prefer not to have to buy a ton of parts to figure out it was the ignitors. The tail is off our 2nd ship, I may swap the ignitors and see? > > thanks for the replies. > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479142#479142 > > > > > > > > > ________________________________________________________________________________
Date: Apr 07, 2018
CWAM went away, heard everything got liquidated Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479154#479154 ________________________________________________________________________________
Date: Apr 07, 2018
Ive got igniters and a ignition box if needed. Shoot me an offer/pm Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479158#479158 ________________________________________________________________________________
Date: Apr 08, 2018
We discovered ours gave the same indications as your when starting on EPU, but got a normal start on ship's battery. Stan Subject: Re: L29-List: Re: Hang Start From: William Geipel <l129bs(at)gmail.com> Does it do the same thing on ships batteries? > On Apr 6, 2018, at 17:07, skidmk wrote: > > > ok. > > we replaced our batteries today, start with EPU same results. > > Exactly what I hear. the starter goes (200 amp), then the tick tick tick... not ticktick ticktick. The the 400 amp goes... egts' climb to 600, then drop off to 550 and stay there. > > the mechanic last year did say the ignitors were on their last leg and should be replaced. We are sourcing them, but have had no luck so far. > > Should we replace ignitors before start box? Is there anything I can do to start box in terms of checking it works? I know its mechanical, so could lubricate be sprayed on some of the gears or valves? > > We'd prefer not to have to buy a ton of parts to figure out it was the ignitors. The tail is off our 2nd ship, I may swap the ignitors and see? > > thanks for the replies. > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario ________________________________________________________________________________
Date: Apr 09, 2018
Update: first thanks to all reponses, love this little community EPU connected: Start normal, hear the fuel pump running, hear the clutch engage, the starter spins, we hear the "secondary boost of amps" and everything spins much quicker, the plugs spark with the same intensity and frequency of our other L29 (so I don't think its the plugs anymore), EGTS arc up to 600, fall back to 575 then 550 as she stays at 20%. We then shut her all down. Went out, and hit air start without fuel etc, so we could hear the sparking, she sparks exactly like the other one we have (she starts fine) I'm thinking start control box now. -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479190#479190 ________________________________________________________________________________
Date: Apr 09, 2018
Not trying to be condescending, just throwing things out there. The start control box controls the start sequence. So if it is doing all 3 steps, what could the box not be doing? After 19 seconds the sequence is stopped by the start box. (4th step) The ignitors work. Otherwise there would be no light off. If only one ignites, it would result in a HOT start. It sounds like fuel flow. If the engine starts, EGT rises, RPM increases, it can only be fuel. (It could be air flow if it were an air starter. (Or the intake/exhaust covers where still installed) Just Kidding! As I mentioned before, if the fuel filter was changed, did you bleed the fuel line? Is the Fire Cock open completely? During start, do you push the fuel shut off full forward? When it is at 20%, have you tried pushing the throttle up a little? Has this airplane flown before or is this a new project? Bill > On Apr 9, 2018, at 06:38, skidmk wrote: > > > Update: > > first thanks to all reponses, love this little community > > EPU connected: > Start normal, hear the fuel pump running, hear the clutch engage, the starter spins, > we hear the "secondary boost of amps" and everything spins much quicker, the plugs spark with the same intensity and frequency of our other L29 (so I don't think its the plugs anymore), > EGTS arc up to 600, fall back to 575 then 550 as she stays at 20%. > > We then shut her all down. Went out, and hit air start without fuel etc, so we could hear the sparking, she sparks exactly like the other one we have (she starts fine) > > I'm thinking start control box now. > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479190#479190 > > > > > > > > > ________________________________________________________________________________
Date: Apr 09, 2018
Fuel nozzle issue or main fuel pump pressure? Also spitballing. Christian Sent from my iPhone > On Apr 9, 2018, at 08:22, William Geipel wrote: > > > Not trying to be condescending, just throwing things out there. > > The start control box controls the start sequence. So if it is doing all 3 steps, what could the box not be doing? After 19 seconds the sequence is st opped by the start box. (4th step) > > The ignitors work. Otherwise there would be no light off. If only one igni tes, it would result in a HOT start. > > It sounds like fuel flow. If the engine starts, EGT rises, RPM increases, i t can only be fuel. (It could be air flow if it were an air starter. (Or the intake/exhaust covers where still installed) Just Kidding! > > As I mentioned before, if the fuel filter was changed, did you bleed the f uel line? > > Is the =9CFire Cock=9D open completely? > > During start, do you push the fuel shut off full forward? > > When it is at 20%, have you tried pushing the throttle up a little? > > Has this airplane flown before or is this a new project? > > > Bill >> On Apr 9, 2018, at 06:38, skidmk wrote: >> >> >> Update: >> >> first thanks to all reponses, love this little community >> >> EPU connected: >> Start normal, hear the fuel pump running, hear the clutch engage, the sta rter spins, >> we hear the "secondary boost of amps" and everything spins much quicker, t he plugs spark with the same intensity and frequency of our other L29 (so I d on't think its the plugs anymore), >> EGTS arc up to 600, fall back to 575 then 550 as she stays at 20%. >> >> We then shut her all down. Went out, and hit air start without fuel etc, so we could hear the sparking, she sparks exactly like the other one we hav e (she starts fine) >> >> I'm thinking start control box now. >> >> -------- >> Mike "Skidmk" Bourget >> Ottawa, Ontario >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=479190#479190 >> >> >> >> >> >> >> >> >> > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Apr 09, 2018
Thanks so much Bill. 1. Not a project, shes been flying quite a bit 2. Last week, normal start but stayed at 20% for almost the whole 60 secs, then she kicked up and went to normal rpm and egts. 3. A couple of days later weve been experiencing thisnissue. 4. Today swapped igniters. No joy. 5. Fuel is leaking after the start attempt. (In the can the. Out thebtail, we have nice white thick exhaust during the attempt. 6 stays at 20% with reducing Egts, then I shut down. All plugs and covers removed. ;) Firecock fully open. No fuel system service Fuel pressure is at 8kgs per cm2 during this sequence. Mike -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479206#479206 ________________________________________________________________________________
Subject: fuel filters
Date: Apr 09, 2018
Hello, I'm looking for 4 -6 units. Mike -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479217#479217 ________________________________________________________________________________
Date: Apr 09, 2018
We will check filter (I doubt it, was serviced -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479218#479218 ________________________________________________________________________________
Date: Apr 12, 2018
Subject: Re: fuel filters
Did you find any filters? On Monday, April 9, 2018 8:14 PM, skidmk wrote: Hello, I'm looking for 4 -6 units. Mike -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479217#479217 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 13, 2018
Get the engine started? > On Apr 12, 2018, at 07:46, Anthony Royal wrote: > > Did you find any filters? > > > On Monday, April 9, 2018 8:14 PM, skidmk wrote: > > > > > Hello, > > I'm looking for 4 -6 units. > > Mike > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479217#479217 <http://forums.matronics.com/viewtopic.php?p=479217#479217> > > > > > > > http://www.matronics.com/Navigator?L============ ====== > > <http://www.matronics.com/Navigator?L29-List>http://forums.matronics.com <http://forums.matronics.com/> > bsp; --> http://wiki.matronics.com > ================== > > > http://www.matronics.com/contribution > > > > > > ________________________________________________________________________________
Date: Apr 13, 2018
I've got some ordered with Bob when he gets home. As for the engine. NEgative... same issues. -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479317#479317 ________________________________________________________________________________
Subject: Hang start update,
Date: Apr 13, 2018
Have checked all front to back. We figure it is the Automatic starting device that is on the pump. I've taken one off an old engine, and we hope to test it this week. If its not the ASD, then I guess I'll have to spring for a new HP pump. I hate just changing parts till it starts. cheers -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479318#479318 ________________________________________________________________________________
Date: Apr 13, 2018
If Bob doesn't come thru, I've got 35 fuel filters and I can hook you up. Wouldn't happen to know how to get the oil pump out of the M701?=C2- Mine won't come out the bottom. Drops down about a quarter inch and that's it. =C2- Does the oil pan need to be dropped? On Friday, April 13, 2018 1:18 PM, skidmk wrote: I've got some ordered with Bob when he gets home.=C2- As for the engine.=C2- NEgative... same issues. -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479317#479317 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 13, 2018
Subject: Re: Hang start update,
Hey, if you got an old engine, would you be willing to sell the oil pan and oil pump assy if I should happen to need one? I've got a feeling I will. On Friday, April 13, 2018 1:20 PM, skidmk wrote: Have checked all front to back.=C2- We figure it is the Automatic startin g device that is on the pump.=C2- I've taken one off an old engine, and w e hope to test it this week. If its not the ASD, then I guess I'll have to spring for a new HP pump. I hate just changing parts till it starts. cheers -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479318#479318 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 13, 2018
Could be the HP pump. In any cases, the HP pump is not made for civilian fuel, but for military fuel (civilian + lubricant ). Jean > Le 13 avr. 2018 =C3- 21:34, Anthony Royal a =C3=A9crit : > > Hey, if you got an old engine, would you be willing to sell the oil pan and oil pump assy if I should happen to need one? I've got a feeling I will. > > > On Friday, April 13, 2018 1:20 PM, skidmk wrote: > > > > > Have checked all front to back. We figure it is the Automatic starting device that is on the pump. I've taken one off an old engine, and we hope to test it this week. > > If its not the ASD, then I guess I'll have to spring for a new HP pump. > > I hate just changing parts till it starts. > > cheers > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479318#479318 <http://forums.matronics.com/viewtopic.php?p=479318#479318> > > > > > > > > http://www.matronics.com/Navigator?L29-List <http://www.matronics.com/Navigator?L29-List> > > s.matronics.com/" target="_blank">http://forums.matronics.com > > <http://wiki.matronics.com/> > http://www.matronics.com/contribution > <=============== > > > > > ________________________________________________________________________________
Date: Apr 14, 2018
skyking76t(at)verizon.net wrote: > Hey, if you got an old engine, would you be willing to sell the oil pan and oil pump assy if I should happen to need one? I've got a feeling I will. > > > > On Friday, April 13, 2018 1:20 PM, skidmk wrote: > > > Yes, send me what you need. Id rather swap for parts than exchange cash. Pm me, well figure something out. > > > > > > Have checked all front to back. We figure it is the Automatic starting device that is on the pump. I've taken one off an old engine, and we hope to test it this week. > > > > If its not the ASD, then I guess I'll have to spring for a new HP pump. > > > > I hate just changing parts till it starts. > > > > cheers > > > > -------- > > Mike "Skidmk" Bourget > > Ottawa, Ontario > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=479318#479318 (http://forums.matronics.com/viewtopic.php?p=479318#479318) > > > > > > > > > > > > > > s.matronics.com/" target="_blank">http://forums.matronics.com > > -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479335#479335 ________________________________________________________________________________
Subject: Looking to expand our fleet
Date: Apr 18, 2018
Hey folks, anyone out there contemplating selling their L29? we are looking to expand our fleet and maybe interested in a quick sale. If you know of someone in your area that may wish to sell one, please put me in touch with them please pm me cheers -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479423#479423 ________________________________________________________________________________
Date: Apr 26, 2018
Sounds like you are not getting a flame over in all combustion chambers. Check your fuel injectors. One might be clogged and you are not getting a perfect spray pattern. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479565#479565 ________________________________________________________________________________
Date: Apr 26, 2018
I was thinking of the injectors. But it was flying a short time ago. How about bad fuel? Bad fuel could cause bad injectors and if there are enough green plants growing it. Prist.. Hard to believe it will be the high pressure pump. But u never know > On Apr 26, 2018, at 05:55, dkloiber wrote: > > > Sounds like you are not getting a flame over in all combustion chambers. Check your fuel injectors. One might be clogged and you are not getting a perfect spray pattern. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479565#479565 > > > > > > > > > ________________________________________________________________________________
Subject: Re: Stabilator Trim Motor
Date: May 07, 2018
Hi Guys, It happened I crossed over the L-29 Stabilizer Trim mechanism new surplus oversea for a decent price. While I have one here in Calgary I would sell mine (new surplus) to put couple hundred bucks toward my fly tickets this July-August. I would let it go for 870US plus shipment cost around 50US to USA (will confirm with UPS at particular address) from Calgary Canada . Payment could be thru PayPal. If I dont buy that one oversea then its lost. Pictures you can see at top. Contact me at Lekhkar(at)telus.net Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479915#479915 Attachments: http://forums.matronics.com//files/lun_2510_01_124_184.jpg ________________________________________________________________________________
Date: May 16, 2018
many thanks to all who got involved. As it turns out it was the HP fuel pump afterall. Switch it out, it immediately when to 31%, a couple clicks on the ground adjust and 35% was obtained. 3 small fuel leaks where the pump associated with the pump replacement. Hopefully, she'll be back together and flying this winter though, the injectors are coming out for a good sonic cleaning. Cheers Skid -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480169#480169 ________________________________________________________________________________
Subject: Telescopic coupling...
Date: May 30, 2018
Hey, I am looking for a Telescoping Coupling for my front canopy. Part number XL 229.881-18 part 1 and 2. This is the little telescopic arm that feeds your canopy seal. Mine was bent a little while ago and now doesn't seat well, so it vents nitrogen like crazy. Cheers. Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480523#480523 ________________________________________________________________________________
Date: May 30, 2018
aXQncyBzdW1tZXIuIGZseSB1bnByZXNzdXJpemVkLgoKCgpTZW50IGZyb20gbXkgU2Ftc3VuZyBH YWxheHkgc21hcnRwaG9uZS4KCi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS0KRnJv bTogZm91Z2FwaWxvdCA8Zm91Z2FwaWxvdEBob3RtYWlsLmNvbT4gCkRhdGU6MjAxOC8wNS8zMCAg MTM6MjcgIChHTVQtMDY6MDApIApUbzogbDI5LWxpc3RAbWF0cm9uaWNzLmNvbSAKQ2M6ICAKU3Vi amVjdDogTDI5LUxpc3Q6IFRlbGVzY29waWMgY291cGxpbmcuLi4gCgotLT4gTDI5LUxpc3QgbWVz c2FnZSBwb3N0ZWQgYnk6ICJmb3VnYXBpbG90IiA8Zm91Z2FwaWxvdEBob3RtYWlsLmNvbT4NCg0K SGV5LA0KDQpJIGFtIGxvb2tpbmcgZm9yIGEgVGVsZXNjb3BpbmcgQ291cGxpbmcgZm9yIG15IGZy b250IGNhbm9weS4gUGFydCBudW1iZXIgWEwgMjI5Ljg4MS0xOCBwYXJ0IDEgYW5kIDIuDQoNClRo aXMgaXMgdGhlIGxpdHRsZSB0ZWxlc2NvcGljIGFybSB0aGF0IGZlZWRzIHlvdXIgY2Fub3B5IHNl YWwuIE1pbmUgd2FzIGJlbnQgYSBsaXR0bGUgd2hpbGUgYWdvIGFuZCBub3cgZG9lc24ndCBzZWF0 IHdlbGwsIHNvIGl0IHZlbnRzIG5pdHJvZ2VuIGxpa2UgY3JhenkuDQoNCkNoZWVycy4NCg0KRGFu DQoNCg0KDQoNClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToNCg0KaHR0cDovL2ZvcnVtcy5t YXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD00ODA1MjMjNDgwNTIzDQoNCg0KDQoNCg0KDQpf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PQ0KXy09ICAgICAgICAgIC0gVGhlIEwyOS1MaXN0IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2Ug dGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCl8tPSB0aGUg bWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KXy09IEFy Y2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBo b3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cu bWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/TDI5LUxpc3QNCl8tPQ0KXy09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAg ICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBh bHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBodHRwOi8v Zm9ydW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAgLSBORVcg TUFUUk9OSUNTIExJU1QgV0lLSSAtDQpfLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNz IEVtYWlsIExpc3QgV2lraSENCl8tPSAgIC0tPiBodHRwOi8vd2lraS5tYXRyb25pY3MuY29tDQpf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PQ0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KXy09 ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPSAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCl8tPSAgIC0tPiBodHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0K ________________________________________________________________________________
Subject: Re: Telescopic coupling...
Date: May 30, 2018
[Laughing] :P [Laughing] Summer or Winter.... still need the pressurization to fly high... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480525#480525 ________________________________________________________________________________
Date: May 30, 2018
Pot is legal in my state. We need nothing to fly high. I actually straightened one out by sliding a punch or rod into the tube and making sure the gasket was good. I will search my shelves. > On May 30, 2018, at 13:38, fougapilot wrote: > > > [Laughing] :P [Laughing] > > Summer or Winter.... still need the pressurization to fly high... > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=480525#480525 > > > > > > > > > ________________________________________________________________________________
Subject: Front canopy required.
Date: Jun 03, 2018
Lost our front canopy in flight today. Need a source for a new used one. Any ideas or if you have one. Please reply Thanks -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480610#480610 ________________________________________________________________________________
Subject: Re: Front canopy required.
Date: Jun 03, 2018
Zach MCNIEL > On Jun 3, 2018, at 12:15, skidmk wrote: > > > Lost our front canopy in flight today. Need a source for a new used one. > > Any ideas or if you have one. Please reply > > Thanks > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=480610#480610 > > > > > > > > > ________________________________________________________________________________
Date: Jun 04, 2018
We got our fix. I hope it lasts. D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480623#480623 ________________________________________________________________________________
Date: Jun 04, 2018
Look for the old one and put it back on... ;-) That's what happened to my jet many years ago. The front canopy departed on initial climb out, some farmer found it, brought it to the airport and they put it right back on. LOL D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480624#480624 ________________________________________________________________________________
Date: Jun 04, 2018
Guys, what was a reason for the canopy fly off? I can tell that since 1964 and until 1992 no any L-29 had a canopy fly off (at list in USSR). Did we just forget to lock a canopy? It could be a good lesson learn for others. Per L-29 manual its very dangerous situation as canopy can cut a head off, and thats why per manual for emergency self leaving in flight a pilot should band his head down before open a canopy. Fly safe. Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480629#480629 ________________________________________________________________________________
Date: Jun 04, 2018
SSBrbm93IG9mIHRoYXQgY2FtZSBvZmYgaW4gMTk5NS4KU2VyaWVzIG9mIEwyOXMgaGFkIENhbm9w eSBVbmxvY2sgbGlnaHQsIHRoZXkgbmV2ZXIgbG9zdCBvbmUgc28gdGhleSBzdG9wcGVkIGluc3Rh bGxpbmcgdGhlIGxpZ2h0LiBUaGVuIHRoZXkgbG9zdCBzb21lIGFuZCB0aGUgbmV4dCBzZXJpZXMg aGFkIHRoZSBsaWdodC4KV2UgbGVhdmUgdGhlbSB1bmxvY2tlZCBiZWNhdXNlIGl0J3MgaG90LiBU aGVuIHdlIGZvcmdldCB0byBsb2NrIGl0LiBPaCB3ZWxsLCBpdCBoYXBwZW5zLgpJdCBpcyBkZXNp Z25lZCB0byBnbyB1cCBhbmQgb3ZlciB0aGUgcmlnaHQgd2luZy4gSSB3YXMgaW4gdGhlIGJhY2sg c2VhdCBmb3Igb25lIG9mIHRob3NlLiBTbyBmYXN0IHlvdSBjYW4ndCBldmVuIHNlZSBpdCBnby4K VGFrZXMgbG90cyBvZiBwb3dlciB0byBmbHkuCgoKClNlbnQgZnJvbSBteSBTYW1zdW5nIEdhbGF4 eSBzbWFydHBob25lLgoKLS0tLS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLQpGcm9tOiBB bGVraCA8bGVraGthckB0ZWx1cy5uZXQ+IApEYXRlOjIwMTgvMDYvMDQgIDA5OjQ0ICAoR01ULTA3 OjAwKSAKVG86IGwyOS1saXN0QG1hdHJvbmljcy5jb20gCkNjOiAgClN1YmplY3Q6IEwyOS1MaXN0 OiBSZTogRnJvbnQgY2Fub3B5IHJlcXVpcmVkLiAKCi0tPiBMMjktTGlzdCBtZXNzYWdlIHBvc3Rl ZCBieTogIkFsZWtoIiA8bGVraGthckB0ZWx1cy5uZXQ+DQoNCkd1eXMsIHdoYXQgd2FzIGEgcmVh c29uIGZvciB0aGUgY2Fub3B5IGZseSBvZmY/IEkgY2FuIHRlbGwgdGhhdCBzaW5jZSAxOTY0IGFu ZCB1bnRpbCAxOTkyIG5vIGFueSBMLTI5IGhhZCBhIGNhbm9weSBmbHkgb2ZmIChhdCBsaXN0IGlu IFVTU1IpLiBEaWQgd2UganVzdCBmb3JnZXQgdG8gbG9jayBhIGNhbm9weT8gSXQgY291bGQgYmUg YSBnb29kIGxlc3NvbiBsZWFybiBmb3Igb3RoZXJzLiBQZXIgTC0yOSBtYW51YWwgaXTDosKAwplz IHZlcnkgZGFuZ2Vyb3VzIHNpdHVhdGlvbiBhcyBjYW5vcHkgY2FuIGN1dCBhIGhlYWQgb2ZmLCBh bmQgdGhhdMOiwoDCmXMgd2h5IHBlciBtYW51YWwgZm9yIGVtZXJnZW5jeSBzZWxmIGxlYXZpbmcg aW4gZmxpZ2h0IGEgcGlsb3Qgc2hvdWxkIGJhbmQgaGlzIGhlYWQgZG93biBiZWZvcmUgb3BlbiBh IGNhbm9weS4NCkZseSBzYWZlLg0KDQpBbmR5DQoNCg0KDQoNClJlYWQgdGhpcyB0b3BpYyBvbmxp bmUgaGVyZToNCg0KaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD00 ODA2MjkjNDgwNjI5DQoNCg0KDQoNCg0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgIC0gVGhlIEwyOS1M aXN0IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5h dmlnYXRvciB0byBicm93c2UNCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExp c3QgVW4vU3Vic2NyaXB0aW9uLA0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5 IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToN Cl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/TDI5LUxp c3QNCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMg LQ0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1 bXMhDQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT0NCl8tPSAgICAgICAgICAgICAgLSBORVcgTUFUUk9OSUNTIExJU1QgV0lLSSAtDQpfLT0gQWRk IHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNzIEVtYWlsIExpc3QgV2lraSENCl8tPSAgIC0tPiBo dHRwOi8vd2lraS5tYXRyb25pY3MuY29tDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgIC0gTGlzdCBD b250cmlidXRpb24gV2ViIFNpdGUgLQ0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMg c3VwcG9ydCENCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwg TGlzdCBBZG1pbi4NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0 aW9uDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PQ0KDQoNCg0K ________________________________________________________________________________
From: "Jorgen Nielsen" <jorgen.nielsen(at)mweb.co.za>
Date: Jun 05, 2018
Hi Mike Let me know if you cannot get one - I have spare new front canopy, but its all the way in South Africa, so not convenient to ship. -----Original Message----- From: owner-l29-list-server(at)matronics.com [mailto:owner-l29-list-server(at)matronics.com] On Behalf Of skidmk Sent: Sunday, 03 June 2018 20:15 Subject: L29-List: Front canopy required. Lost our front canopy in flight today. Need a source for a new used one. Any ideas or if you have one. Please reply Thanks -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480610#480610 ________________________________________________________________________________
Date: Jun 05, 2018
I just bought Zacks inventory but I have not had a chance to see if he has a canopy. Ill have a look Tomorrow or Thursday and let you know. Best regards, Bill Culberson Red Star Aero Services 251/716/8119 > On Jun 3, 2018, at 6:07 PM, William Geipel wrote: > > > Zach MCNIEL > >> On Jun 3, 2018, at 12:15, skidmk wrote: >> >> >> Lost our front canopy in flight today. Need a source for a new used one. >> >> Any ideas or if you have one. Please reply >> >> Thanks >> >> -------- >> Mike "Skidmk" Bourget >> Ottawa, Ontario >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=480610#480610 >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Jun 05, 2018
I wasn't flying, I was on the ground watching. It departed on takeoff, about 50 feet in the air. went up and over the wing, didn't hit or touch the airplane. We've looked at it, and discussed with the pilot. It was a simple "forgot to lock it" .... there were some factors that contributed, Ie the checklist fell on the floor just prior to lining up etc. accident. Call that for a reason. -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480688#480688 ________________________________________________________________________________
Subject: Urgently need info on L29R
Date: Jun 05, 2018
Hey! I fly an L29R OKO in Canada and the Federales have decided to unleash hell on me because my AFM is the same as everyone else a straight L29 AFM which according to their infinite wisdom is totally unacceptable for the R variant. So I basically need any and all available information on the R variant. Any technical publication, manual, technical order, AFM if you ever heard of one... anything! Thanks for the help. Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480702#480702 ________________________________________________________________________________
Date: Jun 06, 2018
Subject: Re: Urgently need info on L29R
Try this link for the R model stuff http://l29support.com/33501.html John Cabrera > On Jun 5, 2018, at 6:39 PM, fougapilot wrote: > > > Hey! > > I fly an L29R OKO in Canada and the Federales have decided to unleash hell on me because my AFM is the same as everyone else a straight L29 AFM which a ccording to their infinite wisdom is totally unacceptable for the R variant. > > So I basically need any and all available information on the R variant. > > Any technical publication, manual, technical order, AFM if you ever heard o f one... anything! > > Thanks for the help. > > Dan > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=480702#480702 > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Jun 06, 2018
Check list felt on the floor..- we used to say loud to military training TC on a runway before takeoff : Canopy is closed, Flaps -15. If you dont say it on a radio you would not get permission to take off. Simple, but effective. I do it until now, but loud to just myself. Outside of check list. Think about. Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480711#480711 ________________________________________________________________________________
Date: Jun 07, 2018
Thanks John, But I required something more official. Something form the manufacturer or at least the Czech air force. Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480725#480725 ________________________________________________________________________________
Date: Jul 27, 2018
Subject: VOR antenna
I am going to install a VOR in my bird and I was wondering where folks out there have mounted the antenna. Is there somewhere on the airplane that works better? Is there somewhere in the tail that works? Where and how did you run the coax to the cockpit? Thanks you. John F. Cabrera ________________________________________________________________________________
Subject: EGT Thermocouples
Date: Aug 28, 2018
Guys, Anyone know where I could find some EGT Thermocouples? D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=482741#482741 ________________________________________________________________________________
Date: Sep 09, 2018
Subject: Auto Response: L29-List Digest: 0 Msgs - 09/08/18
Thank you for the email. Please know that Howard has passed away. If you are NOT a solicitor, please contact his wife Judy at tudulu2(at)aol.com ________________________________________________________________________________
Subject: weird bumping (thumping noise) sound from the Jet??? Help
Date: Sep 10, 2018
Folks, anyone experience this issue? Low time engine -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483074#483074 ________________________________________________________________________________
Date: Sep 10, 2018
Subject: Re: weird bumping (thumping noise) sound from the Jet??? Help
Iron count up? Do you use a pump to put oil in? What kind of oil? Stops bumping with tail off, fly with tail off! LOL. IS IT MORE bumping at around 80%? On Mon, Sep 10, 2018, 12:02 skidmk wrote: > > Folks, > > anyone experience this issue? > > Low time engine > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483074#483074 > > ________________________________________________________________________________
Date: Sep 11, 2018
Is turbine stop time no change/variance from when it was normal? Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483108#483108 ________________________________________________________________________________
Help
Date: Sep 11, 2018
Did you get any of my questions via this site? > On Sep 11, 2018, at 11:23, Alekh wrote: > > > Is turbine stop time no change/variance from when it was normal? > > Andy > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483108#483108 > > > > > > > > > ________________________________________________________________________________
Date: Sep 12, 2018
no change or variation in any engine parameters. -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483145#483145 ________________________________________________________________________________
Date: Sep 12, 2018
Hey Dawg, Got the questions, we use oil from the can direct. Mobil. As for the thumping noises,, not really noticed at 80% or not. Most prevalent during take-off (100%) less so in cruise 85-90. It seems that it is getting more prevalent, up to and including the bumping on shut down this time. there is no variation in any op specs on the T's and P's. there is no evidence of flaming, or pop flames coming our of the tail. there is what I feel maybe more than normal soot on the tailcone (in the vicinity of the antenna's) what might you be thinking about the 80%? I will change the fuel filter tomorrow, aerate (bleed) the fuel system and see if that cures it. -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483146#483146 ________________________________________________________________________________
Date: Sep 12, 2018
Help Have u cleaned the injectors? Had a thumping when power back in decent at 80-85%. Cleaned injectors and went away Sent from my iPhone > On Sep 12, 2018, at 2:09 PM, skidmk wrote: > > > Hey Dawg, > > Got the questions, we use oil from the can direct. Mobil. As for the thumping noises,, not really noticed at 80% or not. Most prevalent during take-off (100%) less so in cruise 85-90. It seems that it is getting more prevalent, up to and including the bumping on shut down this time. > > there is no variation in any op specs on the T's and P's. > > there is no evidence of flaming, or pop flames coming our of the tail. > > there is what I feel maybe more than normal soot on the tailcone (in the vicinity of the antenna's) > > what might you be thinking about the 80%? > > I will change the fuel filter tomorrow, aerate (bleed) the fuel system and see if that cures it. > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483146#483146 > > > > > > > > > ________________________________________________________________________________
Date: Sep 12, 2018
yes sir ultrasonically cleaned, about 3 hours ago. symptoms went away for about 3 hours, and are now back with a vengeance. -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483148#483148 ________________________________________________________________________________
Date: Sep 12, 2018
Help What exact oil are you using in the M701p? On September 12, 2018 13:11:53 "skidmk" wrote: > > Hey Dawg, > > Got the questions, we use oil from the can direct. Mobil. As for the > thumping noises,, not really noticed at 80% or not. Most prevalent during > take-off (100%) less so in cruise 85-90. It seems that it is getting more > prevalent, up to and including the bumping on shut down this time. > > there is no variation in any op specs on the T's and P's. > > there is no evidence of flaming, or pop flames coming our of the tail. > > there is what I feel maybe more than normal soot on the tailcone (in the > vicinity of the antenna's) > > what might you be thinking about the 80%? > > I will change the fuel filter tomorrow, aerate (bleed) the fuel system and > see if that cures it. > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483146#483146 > > ________________________________________________________________________________
Help
Date: Sep 12, 2018
Stock engine uses a mineral oil. Royco 481. (or Shell sp3 or 3sp, cant remember which) Mobile jet and 2380 are synthetic. May cause metal in your sample. Had several airplanes that rumbled around 80% never had any other issues. Is the thumping a metallic sound? Had one of those. Required new engine to stop the thumping. > On Sep 12, 2018, at 12:16, Anthony Royal wrote: > > > Have u cleaned the injectors? Had a thumping when power back in decent at 80-85%. Cleaned injectors and went away > > Sent from my iPhone > >> On Sep 12, 2018, at 2:09 PM, skidmk wrote: >> >> >> Hey Dawg, >> >> Got the questions, we use oil from the can direct. Mobil. As for the thumping noises,, not really noticed at 80% or not. Most prevalent during take-off (100%) less so in cruise 85-90. It seems that it is getting more prevalent, up to and including the bumping on shut down this time. >> >> there is no variation in any op specs on the T's and P's. >> >> there is no evidence of flaming, or pop flames coming our of the tail. >> >> there is what I feel maybe more than normal soot on the tailcone (in the vicinity of the antenna's) >> >> what might you be thinking about the 80%? >> >> I will change the fuel filter tomorrow, aerate (bleed) the fuel system and see if that cures it. >> >> -------- >> Mike "Skidmk" Bourget >> Ottawa, Ontario >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=483146#483146 >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Sep 13, 2018
Help My previous L-29 would make that kind of noise (hollow thumping) at cruise settings 80-90% power. Not engine related, I believe it was just the inlet ducting. I inspected it numerous times and found no issues. Normal. Bill Culberson Red Star Aero Services 251/716/8119 > On Sep 12, 2018, at 3:22 PM, William Geipel wrote: > > > Stock engine uses a mineral oil. Royco 481. (or Shell sp3 or 3sp, cant remember which) Mobile jet and 2380 are synthetic. May cause metal in your sample. > > Had several airplanes that rumbled around 80% never had any other issues. > Is the thumping a metallic sound? Had one of those. Required new engine to stop the thumping. > > > > > >> On Sep 12, 2018, at 12:16, Anthony Royal wrote: >> >> >> Have u cleaned the injectors? Had a thumping when power back in decent at 80-85%. Cleaned injectors and went away >> >> Sent from my iPhone >> >>> On Sep 12, 2018, at 2:09 PM, skidmk wrote: >>> >>> >>> Hey Dawg, >>> >>> Got the questions, we use oil from the can direct. Mobil. As for the thumping noises,, not really noticed at 80% or not. Most prevalent during take-off (100%) less so in cruise 85-90. It seems that it is getting more prevalent, up to and including the bumping on shut down this time. >>> >>> there is no variation in any op specs on the T's and P's. >>> >>> there is no evidence of flaming, or pop flames coming our of the tail. >>> >>> there is what I feel maybe more than normal soot on the tailcone (in the vicinity of the antenna's) >>> >>> what might you be thinking about the 80%? >>> >>> I will change the fuel filter tomorrow, aerate (bleed) the fuel system and see if that cures it. >>> >>> -------- >>> Mike "Skidmk" Bourget >>> Ottawa, Ontario >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=483146#483146 >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Sep 13, 2018
Use Mobil jet. Ill change it at the next oil change -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483161#483161 ________________________________________________________________________________
Date: Sep 13, 2018
Help Mobil is absolutely wrong and damaging for m701p. Only mineral oil. On September 13, 2018 11:11:44 "skidmk" wrote: > > Use Mobil jet. Ill change it at the next oil change > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483161#483161 > > ________________________________________________________________________________
Date: Sep 13, 2018
Help It might scrub the engine a little to much maybe creating a little iron in the stew. Sent from my iPad > On Sep 13, 2018, at 10:09 AM, skidmk wrote: > > > Use Mobil jet. Ill change it at the next oil change > > -------- > Mike "Skidmk" Bourget > Ottawa, Ontario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483161#483161 > > > > > > > > > ________________________________________________________________________________
Subject: fuel tanks
Date: Sep 25, 2018
I have external fuel tanks for sale. Well used with all the usual dents. I made one in to a baggage pod. Works well. Bill ________________________________________________________________________________
Date: Sep 26, 2018
so, an update. noise on shutdown isolated to the bottle left burner can. It sounds like the injector, or the liner has broken/come loose. The EGT on start up goes to 575, then settles at 325 which is too low. Taking the can off to inspect the can, and the blades. Evidence of scorching on the outside of the can. I'm hoping a simple burner/injector replacement will solve the issue. Otherwise a new engine is in order I would suspect -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483370#483370 Attachments: http://forums.matronics.com//files/img_7926_2_149.jpg ________________________________________________________________________________
Subject: Re: VOR antenna
Date: Sep 26, 2018
Split style one on each side of the tail, use existing cable with an adapter to go from the large connector to bnc. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483398#483398 ________________________________________________________________________________
Subject: Parts request
Date: Oct 05, 2018
Gents Looking for 2 ignition leads. 1 of mine is arcing. EGT probes with leads? And 5 turbine blades? Thanks -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483626#483626 ________________________________________________________________________________
Subject: Re: Parts request
Date: Oct 06, 2018
found egt probes and blades. Looking for 2 ignition leads. -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483644#483644 ________________________________________________________________________________
Subject: L-29 presentation
Date: Oct 08, 2018
I suggest this link : https://www.youtube.com/watch?v=4K_X5rcbfMU&feature=youtu.https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D4K_X5rcbfMU&feature=youtu.be Jean de Roubin ________________________________________________________________________________
Subject: New engine
Date: Oct 10, 2018
Looking, prefer low time. Must have proper paperwork Reply privately. -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483754#483754 ________________________________________________________________________________
Date: Nov 01, 2018
Subject: PLEASE READ - Matronics Email List 2018 Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are 9 great gifts to choose from! There's something for everyone, to be sure. Please make your List Contribution using any one of three secure methods including using a Credit Card, PayPal, or by Personal Check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 03, 2018
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 05, 2018
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2018
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that ilk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, Commercial-greade Internet Connection, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 09, 2018
Subject: List Contribution - Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 11, 2018
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 13, 2018
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 15, 2018
Subject: Make Sure You're Listed! List of Contributors Coming Soon!
Dear Listers, There's just two more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 17, 2018
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Looking for some advice
Date: Nov 18, 2018
My emergency blow down valves in the rear cockpit weep hydraulic fluid out near the handles when the flaps or gear are actuated. Are these as simple to rebuild as just replacing an O-ring ? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485219#485219 ________________________________________________________________________________
Subject: Looking for some parts
Date: Nov 18, 2018
Looking for the following parts: Taxi light Main tires Hydraulic resovoir / tank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485220#485220 ________________________________________________________________________________
Subject: Rear EGT never works
Date: Nov 18, 2018
My rear egt gauge never works, tried a new gauge, the selector switch to change the engine gauges between front and rear works fine. Front egt works fine, anyone know where to look maybe for a splice or basicslly where that wiring comes from? Could I split into the front gauge or would that mess with the readings? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485221#485221 ________________________________________________________________________________
Subject: Canopy seal care
Date: Nov 18, 2018
Whats everyone use on their canopy seals to keep them happy and healthy? Mine are developing cracks but still hold pressure. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485222#485222 ________________________________________________________________________________
Date: Nov 19, 2018
Subject: LOC
Dear Listers, Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by popping a personal check in the mail to: Matronics Email Lists c/o Matt Dralle 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 21, 2018
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 23, 2018
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 25, 2018
Date: Nov 27, 2018
Subject: What's My Contribution Used For?
Dear Listers, Some have asked, "What's my Contribution used for?" and that's a good question. Here are just a few examples of what your direct List support enables. It provides for the very expensive, commercial-grade Internet connection used on the List insuring maximum performance and minimal contention when accessing List services. It pays for the regular system hardware and software upgrades enabling the highest performance possible for services such as the Archive Search Engine, List Browser, and Forums. It pays for narly 30 years (yeah, I really said *30* years) worth of online archive data available for instant random search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power this List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. How many places on the Internet can you make all those statements these days? It is YOUR CONTRIBUTION that directly enables these many aspects of these valuable List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport... List Contribution Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2018
Dear Listers, There are just a Two days left for this year's List Fund Raiser! If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2018
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 55! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: Canopy seal care
Date: Dec 06, 2018
Time to time use a talc powder, or buy a new tube if it's developing cracks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486156#486156 Attachments: http://forums.matronics.com//files/img_5__copy_176.jpg ________________________________________________________________________________
Date: Dec 09, 2018
Who has new seals? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486200#486200 ________________________________________________________________________________
Date: Dec 10, 2018
I have some last to let it go. Contact me off line if interested. Shipment from Canada Calgary. Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486207#486207 ________________________________________________________________________________
Date: Dec 19, 2018
Subject: 2018 List of Contributors
Dear Listers, The 2018 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 And finally, I'm proud to present The 2018 Fund Raiser List of Contributors: http://www.matronics.com/loc Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: Looking for a midtime bird with lowtime engine
Date: Dec 21, 2018
Hey folks, Merry Christmas to all. PIcking up my new L29 in VA first week of January, I can't wait. I"ve promised Tony he could come and fly it anytime. I am still looking for an engine. Prefer to have one that is around 100 hours since OH or less. If it comes with a flying plane thats even better. It must have proper paperwork. Skid -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486475#486475 ________________________________________________________________________________
Subject: Re: Looking for a midtime bird with lowtime engine
Date: Dec 22, 2018
Royal sold his bird? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486491#486491 ________________________________________________________________________________
Date: Dec 22, 2018
Theres a L29 in Woodward, wi for sale listed on barnstormers with 60 hours on the engine I think Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486492#486492 ________________________________________________________________________________
Subject: GPU plug help
Date: Dec 22, 2018
My GPU plug isnt letting power in, it never has, when I plug in my battery cart I hear a relay click but I get no power anywhere at all whatsoever, not even from the internal battery, when I unplug the gpu, my on-board battery kicks back in. Someone said there may be a switch up above the engine, Ill need to check that but anyone else have any ideas? Any yes, the battery cart is good, its used to start a kingair 350 regularly and voltage checked good at the plug. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486493#486493 ________________________________________________________________________________
Date: Dec 23, 2018
yes, I saw that had entered into communication with the fella, agreed on a price but he disappeared. Yes, Tony sold his ship and the GSE. What an amazing caretaker of his ship. We'll take as good care of it too. Skid ACMWarbirds -------- Mike "Skidmk" Bourget Ottawa, Ontario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486500#486500 ________________________________________________________________________________
Subject: Anyone need some inverters?
Date: Dec 25, 2018
I have 4 inverters that I took out of my 29. Free to anyone who can use them. You pay for shipping :) I dont know if they work, old avionics were removed by previous owner. One for sure spun up and sounded like a vacuum cleaner when it ran. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486554#486554 ________________________________________________________________________________
Subject: Re: Engine won't turn no power
Date: Mar 04, 2019
Did you guys ever figure out the issue? We have one doing the exact same thing. Tried multiple start boxes, has voltage going into the box. Makes the click upon pressing the starter button but nothing else happens. If you guys found a smoking gun I would love to hear about it. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487926#487926 ________________________________________________________________________________
Date: Mar 04, 2019
Did you guys ever figure out the issue? We have one doing the exact same thing. Tried multiple start boxes, has voltage going into the box. Makes the click upon pressing the starter button but nothing else happens. If you guys found a smoking gun I would love to hear about it. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487927#487927 ________________________________________________________________________________
Subject: L29
Date: Mar 22, 2019
Does anybody have the tail off their L29?? ________________________________________________________________________________
Date: Apr 05, 2019
Subject: L29 Ground Start Cables for Sale
If anyone is interested, I have a set of what looks to be original L29 grou nd start cables. They are at least 4/0 copper welding cable encased in blac k rubber and about 45 feet long. Outside dia looks to be just shy of 1" and copper cable looks to be about 0.625-0.75" dia. According to the charts I have looked at it should carry at least 400+ amps at 50 feet. Has the Sovie t aircraft plug on one end and ring terminals on the other to connect to a battery bank. These cables came with my L29 when I bought it in 2010. They are VERY heavy and had to shipped by truck.=C2- Estimated weight is 80+ lbs. If interested contact me offline and I will send photos.=C2- $250 + shipping. Paypal..=C2- skyking76t(at)verizon.net ________________________________________________________________________________
Date: Apr 07, 2019
Subject: Parts
I need an igniter box.... Bill ________________________________________________________________________________
Date: May 16, 2019
Subject: Fuel filters
Hello all: I would like to purchase 2 fuel filters for my L-29. Thank you very much. Gene Freeman N229DD Cells: +1 239-258-0047 +65 96356314 Sent from my iPad ________________________________________________________________________________
Date: Aug 23, 2019
Subject: Hydraulic mule connections to my L-29
Hello all: I have been attempting to power the hydraulic system of my L-29 from a hydraulic mule. I have connected the high pressure line from the mule to the aft auxiliary connector located at the right aft wing root and identified as Ha-11. This is the smaller of the two connectors that has M16 x 1 threads. The forward connector is the one that is larger (M22 x 1.5) Ha-3. The Album Schematic shows Ha-3 as an out flow but it is ball checked preventing outflow. When I power up the mule, I can extend and retract the Air Brakes (thats all Ive had the courage to operate!) but massive amounts of 5606 jets out of the hydraulic over pressure line at the bottom of the fuselage. No matter how low I set the pressure output on the mule, this still happens. The manuals mention a hydraulic truck connected to these ports but make no mention of how this is done. I am VERY confused! Any help will be greatly appreciated. Gene Freeman N229DD Sent from my iPad ________________________________________________________________________________
Date: Oct 30, 2019
Subject: Fire extinguishers
The list has been very quite for a long time. I am in the process of an annual and I was wondering if anyone out there knows where we can get out stock fire extinguishers recharged. John F. Cabrera ________________________________________________________________________________
Date: Nov 01, 2019
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are 9 great gifts to choose from! There's something for everyone, to be sure. Please make your List Contribution using any one of three secure methods including using a Credit Card, PayPal, or by Personal Check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Builder-Pilot ________________________________________________________________________________
Date: Nov 01, 2019
Subject: PLEASE READ - Matronics Email List 2019 Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are 12 great gifts to choose from! There's something for everyone, to be sure. Please make your List Contribution using any one of three secure methods including using a Credit Card, PayPal, or by Personal Check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Builder-Pilot ________________________________________________________________________________
Date: Nov 03, 2019
Date: Nov 05, 2019
Date: Nov 07, 2019
Date: Nov 09, 2019
Date: Nov 11, 2019
Date: Nov 13, 2019
Dear Listers, There's just a few more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 14, 2019
Subject: Value of the List...
Date: Nov 17, 2019
Date: Nov 19, 2019
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 21, 2019
Subject: Reminder
Dear Listers, A quick reminder that November is the annual List Fund Raiser. The Matronics Lists are 100% member supported and all of the operational costs are provided for my your Contributions during this time of the year. Your personal Contribution makes a big difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 23, 2019
Subject: [Please Read] What are "The Lists" and Who's This Matt Dralle?
Dear Listers, Who is Matt Dralle and what exactly are these Lists? Well, I've been working in the information technology industry for over 35 years primarily in computer networking design and implementation. I have also done extensive work in web development and CGI design during that time, along with a fair amount of embedded system and software development as well. I started the Matronics Email Lists back in 1990 with about 30 fellow RV builders from around the world. Since that time, I have added 80 other kinds of aircraft related Lists to the line up and numerous other List related services such as the Forums, Wiki, Archives and Search Engine just to name a few. For flexibility and reliability, I have chosen to run all of my own servers here locally. Other List-related systems include a 1 Gigabit, fully switched network infrastructure, a commercial-grade Netscreen firewall, a Barracuda spam filter, a local 1G Internet router, and a commercial-grade business 1Gb/s Internet connection with full static addressing. The computer servers found here include a quad-processor Xeon Linux server for List web services, a dual-processor Xeon Linux system dedicated to the email processing List functions, and another P4 Linux system serving as a remote storage disk farm for the archives, databases, and for an on-line hard drive-based backup system with 3.2 Terra Bytes of storage! This entire system is protected by three large, commercial-grade uninterrupted power supply (UPS) systems that assure the Lists are available even during a local power outage! Speaking of power, imagine how much electricity it takes to run all of these systems. One month a couple of Summers ago, I had a staggering $1368 bill for electricity alone! Recently, I upgraded all of the computer racking infrastructure including new power feeds and dedicated air conditioning for the room that serves as the Computer Center for the Matronics Email Lists. As you can see, I take running these Lists very seriously and I am dedicated to providing an always-on, 24x7x365 experience for each and every Lister. But, building and running this system isn't cheap. As I've stated before, I don't support any of these systems with commercial advertising on the Lists. It is supported 100% through List member Contributions! That means you... and you... and YOU! To that end, I hold a List Fund Raiser each November and ask that members make a small Contribution to support the continued operation and upgrade of this ever-expanding system. Its solely YOUR Contributions that keeps it running! Won't you please take a moment to make a Contribution to support these Lists! http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550-7227 USA There are some great gifts available with qualifying Contribution levels too! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 25, 2019
Dear Listers, The List of Contributors (LOC) is just around the corner with just few more days in this year's Fund Raiser! Later in December I will post a list of everyone that so generously made a Contribution to support the Lists this year. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 28, 2019
Subject: What Are You Thankful For...?
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite kind of comments is when write to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2019
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 56! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 27, 2019
Subject: 2019 List of Contributors
Dear Listers, The 2019 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 And finally, I'm proud to present The 2019 Fund Raiser List of Contributors: http://www.matronics.com/loc Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: l29
Date: Feb 05, 2020
Has anyone used the Dresser 600-100 tires. I need a pair but will I be the 1st to purchase. Gary Houston ________________________________________________________________________________
Subject: Re: l29
Date: Feb 05, 2020
Seem to work ok! Best Regards, Bill Culberson Red Star Aero Services 251/716/8119 > On Feb 5, 2020, at 2:11 PM, Gary cole wrote: > > =EF=BB > Has anyone used the Dresser 600-100 tires. > I need a pair but will I be the 1st to purchase. > Gary > Houston ________________________________________________________________________________
Subject: Re: l29
Date: Feb 05, 2020
I have used them for the past 5 years. They work well. If you replace the i nner tubes with the ones they have for that tire the stems are not exactly t he same but they work. John F. Cabrera > On Feb 5, 2020, at 12:11 PM, Gary cole wrote: > > =EF=BB > Has anyone used the Dresser 600-100 tires. > I need a pair but will I be the 1st to purchase. > Gary > Houston ________________________________________________________________________________
Date: Feb 05, 2020
Subject: l29
John F. Cabrera, M.D. Begin forwarded message: > From: John Cabrera <j.f.cabreramd(at)icloud.com> > Date: February 5, 2020 at 1:45:08 PM PST > To: l29-list(at)matronics.com > Subject: Re: L29-List: l29 > > =EF=BB > I have used them for the past 5 years. They work well. If you replace the inner tubes with the ones they have for that tire the stems are not exactly the same but they work. > > John F. Cabrera > > >>> On Feb 5, 2020, at 12:11 PM, Gary cole wrote: >>> >> =EF=BB >> Has anyone used the Dresser 600-100 tires. >> I need a pair but will I be the 1st to purchase. >> Gary >> Houston ________________________________________________________________________________
Subject: Re: l29
Date: Feb 05, 2020
They are out of stock till April so I will send in cores to Wilkerson for re capping. $240.00 each We have had excellent results in the past. Gary Sent from my iPad > On Feb 5, 2020, at 2:28 PM, Bill Culberson wrote: > > =EF=BBSeem to work ok! > > Best Regards, > > Bill Culberson > Red Star Aero Services > 251/716/8119 > >>> On Feb 5, 2020, at 2:11 PM, Gary cole wrote: >>> >> =EF=BB >> Has anyone used the Dresser 600-100 tires. >> I need a pair but will I be the 1st to purchase. >> Gary >> Houston ========================== ========================== ========================== ========================== ========================== ========================== ========================== ========================== ==== ________________________________________________________________________________
Subject: Re: l29
Date: Feb 05, 2020
I have used the ones from Desser for the past 5 years. They work well. If y ou replace the inner tubes with the ones they have for that tire the stems a re not exactly the same but they work. John F. Cabrera John F. Cabrera, M.D. > On Feb 5, 2020, at 2:58 PM, Gary Cole wrote: > > =EF=BB > They are out of stock till April so I will send in cores to Wilkerson for r ecapping. $240.00 each > We have had excellent results in the past. > Gary > > Sent from my iPad > >>> On Feb 5, 2020, at 2:28 PM, Bill Culberson wrot e: >>> >> =EF=BBSeem to work ok! >> >> Best Regards, >> >> Bill Culberson >> Red Star Aero Services >> 251/716/8119 >> >>>> On Feb 5, 2020, at 2:11 PM, Gary cole wrote: >>>> >>> =EF=BB >>> Has anyone used the Dresser 600-100 tires. >>> I need a pair but will I be the 1st to purchase. >>> Gary >>> Houston >> ========================= ========== =============== ==================== ===== ========================== ==== ===================== ============== =========== ======================== = ========================== ======= ________________________________________________________________________________
Date: Mar 03, 2020
Subject: Test; List Server Issues Resolved...
Dear Listers, The Matronics Email List Server was having some issues and not accepting incoming posts for a couple of days. It is resolved now. Sorry for the hassle... Matt Dralle Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: Re: New Incoming Message Size Limit Implemented...
Date: Mar 04, 2020
An electronics is followed for the tipping story for the mid o the paths for humans. The challenges of the who can write an essay for me (https://www.essay-on-time.com) on the request of the all officers. The writer is ensured for the documents. Path is done for the file work. Its matter is scored for the mid of the host of the terms for the citizens. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=495143#495143 ________________________________________________________________________________
Date: Mar 04, 2020
What??? > On Mar 4, 2020, at 07:21, EricWalker wrote: > > > An electronics is followed for the tipping story for the mid o the paths for humans. The challenges of the who can write an essay for me (https://www.essay-on-time.com) on the request of the all officers. The writer is ensured for the documents. Path is done for the file work. Its matter is scored for the mid of the host of the terms for the citizens. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=495143#495143 > > > > > > > > > ________________________________________________________________________________
Date: Mar 04, 2020
Exactly... Bill Culberson Red Star Aero Services 251/716/8119 > On Mar 4, 2020, at 1:11 PM, William Geipel wrote: > > > What??? > > >> On Mar 4, 2020, at 07:21, EricWalker wrote: >> >> >> An electronics is followed for the tipping story for the mid o the paths for humans. The challenges of the who can write an essay for me (https://www.essay-on-time.com) on the request of the all officers. The writer is ensured for the documents. Path is done for the file work. Its matter is scored for the mid of the host of the terms for the citizens. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=495143#495143 >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Mar 27, 2020
It can also recover deleted mailboxes from your corrupted EDB file. EdbMails online state. One of the high-performance Exchange server export and migration tool to get back your deleted mailbox data with accuracy. If there is a requirement of data integrity, scalability, and performance arise and EDB to Office 365 migrations. It can export and migrate emails, contacts, calendar, tasks, attachments, public folders etc., from an offline EDB and online Exchange server. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=495453#495453 ________________________________________________________________________________
Subject: P-100 Fuel pressure transmitters
Date: Apr 16, 2020
Hey guys, I am looking for a P-100 Fuel pressure transmitters. Does anyone have a spare for sale? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=495845#495845 ________________________________________________________________________________
Subject: Re: P-100 Fuel pressure transmitters
Date: Apr 17, 2020
$30,000 comes with jet attached. > On Apr 17, 2020, at 06:10, fougapilot wrote: > > > Hey guys, > > I am looking for a P-100 Fuel pressure transmitters. Does anyone have a spare for sale? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=495845#495845 > > > > > > > > > ________________________________________________________________________________
Date: Apr 16, 2020
Contact me offline; number below. Call/text as I think I have one. Bill Culberson Red Star Aero Services 251/716/8119 > On Apr 16, 2020, at 5:00 PM, William Geipel wrote: > > > $30,000 comes with jet attached. > > >> On Apr 17, 2020, at 06:10, fougapilot wrote: >> >> >> Hey guys, >> >> I am looking for a P-100 Fuel pressure transmitters. Does anyone have a spare for sale? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=495845#495845 >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Subject: New fuel filter for M701 - M701-06-1193/1
Date: May 25, 2020
New fuel filters M701-06-1193/1 available Price: 75 USD/pcs Condition: factory new (2019/2020) Min orde: 10pcs Shipping cost: 75 USD by DHL Express - 3 days navratil.2(at)seznam.cz or info(at)apn-avionics.com Petr there is some reference on me: http://forums.matronics.com/viewtopic.php?t=16762244&highlight=navratil Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496493#496493
June 23, 2017 - June 01, 2020
L29-Archive.digest.vol-as
