Lom-Archive.digest.vol-aa
August 09, 2003 - November 01, 2009
Date: Aug 09, 2003
Subject: New LOM Email Forum At Matronics...
Dear LOM owners, Okay, so I'm a little slow in getting this setup! I was cleaning out my email box today and happened across a request from Jim Ayers where he was asking if I'd set up an email list for LOM owners. Better late than never, so I got on it today and set it up! You should have received the List FAQ earlier today. It has lots of interesting information about the List and some of the nifty features. Please have a look at it. Also, you'll find web links below that will take you to most of the cool features. Some of the archive links won't work until tomorrow after the nightly update. Please feel free to use this List as you see fit and to invite your friends to join and participate. To post a message to the List, simple send an email to the following address: lom-list(at)matronics.com Your message will be redistributed to everyone on the List. Again, I apologize for the delay in setting this list up for Jim. I just totally spaced it. Best regards, Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Aug 09, 2003
Subject: Re: New LOM Email Forum At Matronics...
Hi Matt, Thanks for setting this up. I have the FuelChek system in my RV-3 with the return fuel flow sensor on the return line from the engine. As you suggested, I disconnected the return flow sensor to see what the gross fuel flow was to the LOM engine. It was 16 gph. So when I have 5 gph being used by the LOM, 11 gph is being returned to the fuel tank. Jim Ayers RV-3 N47RV sn50 LOM M332A with automatic mixture control MT 3 blade electric CS propeller ________________________________________________________________________________
Date: Aug 12, 2003
Subject: LOM M332 fuel flow?
Hi All, Just curious what power setting and fuel flow is normally used? I changed from the manual mixture control to an automatic mixture control, and don't have it set up properly. Running too rich based on the black exhaust. I nomally cruise at 2400 RPM. Unfortunetly, I only remember that with 16.3" MP (full throttle) at 17,500' (-4 degree C oat) the fuel flow was 5.5 gph. The performance graphs indicate about 42 hp for between 3 to 3.5 gph. I'll be getting some new numbers at lower altitudes in the next couple days. Jim Ayers RV-3 N47RV LOM M332A ________________________________________________________________________________
Date: Aug 16, 2003
Subject: New USA LOM dealer?
Hi All, A couple friends of mine told me there was a new USA dealer for the LOM engine at Oshkosh. However, I couldn't find them where I was told they were located. They thought the new dealer was from Oregon. Anyone know anything about this? Jim Ayers ________________________________________________________________________________
Date: Aug 18, 2003
Subject: Oil in exhaust pipe
Hi All, I visited a high wing homebuilt with a LOM M332C installed on my way back from Oshkosh. He had oil seeping out of the slip joints in the exhaust pipes. In comparing his LOM installation with my RV-3 LOM installation and comparing various symptoms, he removed the cam case oil drain plug from his cold engine. The cam case was filled with FUEL and oil. The fuel pump oil cavity also had fuel in it. If he had checked these areas after running the engine to warm the oil, he wouldn't have seen the fuel in these two areas. The check valve in his fuel return line apparently wasn't working properly, because there was fuel pressure from the fuel tank to the fuel pump on the return line side only. However, leaving the fuel valve ON would also cause the fuel tank head pressure to continuously be at the fuel pump. He knew of one other high wing homebuilt with the same oil leakage at the exhaust slip joints. In talking to other high wing homebuilt owners with the LOM installation, I found another one. My RV-3 has four individual exhaust pipes. It is a low wing homebuilt, so it won't have the head pressure in the supply or return fuel lines. It has the oil valve installed in the engine. I do not have any oil leakage from the exhaust pipes. It does seem to me that diluting the oil with fuel is a very bad thing to happen. Jim Ayers ________________________________________________________________________________
Date: Sep 05, 2003
Subject: Fuel in oil
Hello Milos, Fuel can leak through the fuel pump into the engine oil on engine installations in high wing aircraft or aircraft with header tanks. The header pressure of the fuel into the fuel pump from either the fuel supply line or the return line causes fuel to leak through the fuel pump into the engine oil. On a high wing aircraft that had been setting for two weeks, the large fill port plug was removed from the oil cavity of the fuel pump. Fuel was observed to flow out of the oil cavity. The cam case drain plug was removed to drain the oil, and three quarts of fuel and oil was drained from the cam case. If the engine had been run prior to this inspection, the fuel contamination would not have been observed. A symptom of this problem could be oil leaking out of the exhaust pipe, and oil at the slip joints in the exhaust pipe. Unfortunately, the same symptom would occur from a leaking oil valve. Fuel in the oil side of the fuel pump would be a direct method of observing the problem. I have not seen this problem on my RV-3. A low wing design without a header tank. Best Regards, Jim Ayers ________________________________________________________________________________
Date: Sep 10, 2003
Subject: LOM engine parts order
Hi All, I need to order a few parts for my LOM engine. Does anyone need any parts for their LOM engine? I believe a combined order from all of us will get delivered quicker than an individual order. Let me know if you are interested. Jim Ayers RV-3 N47RV LOM M332A engine jeayers1(at)aol.com ________________________________________________________________________________
Subject: M332CE Revives LOM Fortunes ?
Date: Sep 15, 2003
Like a lot of builders, I looked carefully at the LOM M332B for my Glastar, as a competitor to Lycoming 320 and other engines in the 160hp class. In the end, I decided the M332B was really a 140hp engine, and LOM was just not responsive to North American prospective customers. Among anachronisms of the M332 was the generator (as opposed to alternator), a supercharger handle that was more suited to a Hoyt-Clagwell farm tractor, and - most disappointing of all - a low compression ratio meant for 3rd world countries that didn't have 100LL gasoline. 10hp+ was thrown away needlessly by the low compression ratio. Well, it seems that the factory has listened - 5yrs too late but better late than. The recently-introduced M332CE has increased compression ratio - 7.4:1 vs 6.3:1. The rating is 170hp, but at an anti-social 3000rpm, so perhaps the M332CE should really be called a true 160hp engine. Does anyone know how and why the M332CE was introduced, and whether the M332B has been discontinued altogether - or just discontinued from the North American market ? I'm interested to hear thoughts about whether this new M332CE engine makes LOM a real competitor to the Lycoming 320 - or does the M332CE arrive too late in the game just as other engine alternatives are becoming available, such as the XP-320. Seems to me the M332B was a perfect engine for tandem (small cross-section) aircraft, but I'm curious whether there is a direct performance comparison between the Lycoming 160hp "IO"-320 and the M332B/(CE) on a wider airframe such as the Glastar. ________________________________________________________________________________
Date: Sep 15, 2003
Subject: Re: M332CE Revives LOM Fortunes ?
Hi All, 2800 RPM is probably a practical limit for propeller RPM. An MT propeller can be used to 2800 RPM. According to LOM's performance chart, the LOM M332CE has about 155 hp at 2800 RPM with the supercharger engaged at sea level. So it seems to be fairly close to the 160 hp output of the Lyc. 320. I have looked at, and taken some measurements, from the Glastar cowl with a LOM engine. I am comparing this information with the cowl on my RV-3 with the LOM engine and some Email discussions I've had recently with the NemesisNXT cooling expert on my LOM cooling issues. Basic observations: The Glastar cowl inlet is approximately 7 x 10 inch oval with around 60 sq. in. of inlet area. The LOM engine inlet has about 52 sq. in of inlet area. My RV-3 cowl has 25 sq. in of inlet area. I only have a cylinder head temperature probe on cylinder #3. The cylinder head temperature only goes to the top of the green arc on an extended climb. The Glastar cowl exit ends just in front of the firewall. According to the NemesisNXT expert, the exit air has a vertical velocity as it leaves the cowl. If this has a high enough vertical velocity, it stalls the airflow on the bottom of the fuselage. When the cowl is trimmed for the HR2, the bottom portion below the fuselage is not trimmed. This forms a tunnel along the bottom of the fuselage to direct the exit air. I am going to extend the bottom of the cowl on my RV-3 by about 2 inches to improve the cowl exit air. This could be done on the Glastar cowl, also. On my RV-3, using the oil tank as an oil cooler has not been adequate, especially during the summer. I have added three small air inlets in the front of the cowl to provide additional air along the engine case. And I added an air hose directed at the oil tank from the engine baffle. I can only climb to around 11,500' before the oil temperature reaches the end of the green arc. (In cruise, it drops about 10 degrees C.) It seems to me that the engine and oil cooling for the LOM engine has not been refined to the same level that has already been done for the Lycoming installations. Jim Ayers ________________________________________________________________________________
Date: Sep 15, 2003
Subject: New SPAM and Virus Filtering Appliance At Matronics...
Dear Listers, I will be installing a new SPAM and virus blocking appliance this evening or tomorrow. The installation will involve some changes in the Matronics DNS MX records, and will impact how incoming email is handled. While I expect these changes to be transparent to all of the List subscribers, things might go differently... ;-) The Lists get bombarded with tons of SPAM messages and viruses each day and fortunately my custom filters have been extremely effective at filtering most of this from redistribution. Its time to move to the next level of technology, however, and this SPAM and Virus filtering appliance seems like an excellent solution. I will post a follow up message later in the week when things have stabilized and I have some filter statistics to share. Best regards, Matt Dralle Matronics Email List Admin. -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Date: Sep 17, 2003
Subject: Re: Fuel in oil
In a message dated 09/16/2003 12:35:28 PM Pacific Daylight Time, milospaclt(at)volny.cz writes: Hello Jim, if I understood well, yoe were described me the possible problem with fuel in the oil on the high wing aircraft not problem on your aircraft. I see you returned from OSC without problems. I am also back at work and busy again. Best regards Milos Hello Milos, I described the actual problem on one aircraft. I found three more aircraft with the same symptoms that could have the actual problem. And I have now found one additional high wing aircraft installation that doesn't allow the fuel pump flow through to occur, if the fuel valves are turned off. Best Regards, Jim Ayers ________________________________________________________________________________
Date: Sep 21, 2003
Subject: [Please Read] SPAM Filter Could Be Causing Posting Problems
For Some Members...? Dear Listers, Matronics is now utilizing a SPAM filter appliance to filter out the excessive amounts of inappropriate email that bombards the Email List Forums each day. The filter is reporting that over 66% of the email messages sent to Matronics email destinations are of SPAM content and reviewing the logfiles, it would appear to be true. That is indeed great! While the Lists are enjoying the breath of fresh air afforded by the new appliance, I am suspecting that a few legitimate email List posts are being blocked as too, although I can't confirm this. It is difficult to churn through the logfiles looking though thousands of blocked email messages trying to determine if any legitimate List posts were blocked. If you suspect that your posts are accidently being blocked by the SPAM filter appliance, I have created a new Trouble Report web page that will allow you to report your problems directly to me without having to use email. If the SPAM filter is blocking your email address for some reason, then its likely that I wouldn't be able to receive your direct email regarding difficulty in posting. The web form bypasses the incoming email and directs your message directly to me. Please include as much information as possible regarding the problems you are having including any bounced email or email error messages that you may have received back in regard to your posts to the lists. The more information I have about the email you are sending and what the errors you are receiving, the better chance I'll have in hunting down the problem. The Trouble Report Website URL is: http://www.matronics.com/trouble-report/ I apologize for any inconvenience the SPAM filter may be causing you. I will work toward resolving your issues as quickly as possible. Best regards, Matt Dralle Matronics EMail List Administrator Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Oct 31, 2003
Subject: All New Matronics Email List Online Chat!!!
Hi Listers! A number of Listers have been asking for some Matronics Email List online chat and NOW ITS HERE! Over the last couple of days I've set up a nifty web-based Chat site here on the Matronics systems. No special programs to download; all you need is a late model web browser like Internet Explorer or Netscape with a java plugin. I would recommend downloading the latest Java plugin if you experience any problems getting the page to come up. Here's a link to the Sun Java download website. http://java.com/en/index.jsp Look for the green box with the yellow arrow in the upper right corner. Before you bother, though, just try you browser because it'll probably just work. Each Email List on Matronics has its own "Room" and all rooms can easily be accessed from the same client. In the Email List URL Trailer at the bottom of each List message, you'll find the Link to this List's specific Chat Room. Just click on the Link, and then type in your name or email address in the User Name box. Try to use a name or email address that the other Listers know you by. You'll find me lurking around the various List chat rooms as "MattDralle". There's a couple of nifty features I'll explain right off. On the main Chat Window page after you login, you'll see a little icon with a Hammer and a Screwdriver. This is the Control Panel window. Once the Control Panel comes up, click on the "Settings" tab. Here you'll find, among other things, three check boxes to enable sound. Click all three and you'll be treated to a sound whenever someone enters or leaves the Room, or when someone sends a message. The other cool button is the one that has four little arrows pointing to each of the four corners of the button. This will rip the main Chat window from the web page and allow you to resize and move it anyway you'd like. Let's have some fun and get to know one another better using this awesome new Chat Room! To get started, just click the URL Link below for this List's specific Chat Room! Best regards, Matt Dralle Matronics Email List Admin PS - I'm working on a web link interface to the chat logfiles. Coming soon... ________________________________________________________________________________
Date: Nov 01, 2003
Subject: 2003 List Fund Raiser - Please Support Your Lists...
Dear Listers, During November of each year, I have a voluntary Email List Fund Raiser to support the continued operation, development, maintenance and upgrade of the Email Forums sponsored here. Your Contributions go directly into improvements in the systems that support the Lists and to pay for the Internet connectivity primarily dedicated to supporting the Lists. The traffic on the Lists continues to grow and the numbers are nothing short of impressive! Here are some statistics that show how much traffic the Lists generated this year alone: * 11/01/2002 - 10/31/2003 o Web server hits: 10,446,780 (870,565/mo) o Incoming Email Posts: 58,918 (4,909/mo) List-related upgrades this year have been plentiful, and List performance has substantially improved as a result. Upgrades and enhancements this year have included: * Internet Connection upgrade to a full, commercial-grade T1 Line! * New Web Server platform - Dual 3Ghz Xeon with 2Gb Ram and U320 SCSI! * Upgrade of Email Server platform - Dual 1.7 Ghz Xeon with 1Gb Ram! * All new SPAM Filtering Appliance - filters about 98% of the unwanted SPAM! * All new, web-base List Chat Room society! As you can well imagine, this year's upgrades translate into a fair amount of cash outlay on my part and this annual List Fund Raiser is the sole means by which I fund these upgrades. Unlike most of the other "list servers" on the Web these days, I have a strict *no-commercial-advertisement policy* on the Matronics Lists and associated List web sites. I was again approached by a number of vendors recently with advertising deals that have been very tempting. My commitment to providing a grass-roots, non-commercial environment prevailed, however! Commercialism on the Internet seems to be increasing exponentially every year, with more and more SPAM and pop up ads, not to mention the ever increasing Virus attacks. My goal with the Matronics List Service is to provide all members with a commercial-free, virus-free, and high-performance system with which the may share information, ideas, and camaraderie. The best news this year is that, with the gracious help of Andy Gold and The Builder's Bookstore ( http://www.buildersbooks.com ), I have been able to significantly expand the lineup of fantastic Gift offers to support the List Fund Raiser! In all, there are eight awesome free gifts this year ranging from List Archive CD's to Flight Computers with qualifying Contribution levels. Those great Jeppesen Flight Bags that were so popular last year are even back! A special thanks goes out to Andy Gold again this year for his very kind and generous support of the Lists. Thanks Andy, for these great incentives!! Over the next month I'll be posting a few reminder messages about the List Fund Raiser, and I ask for your patience and understanding during the process. Remember that the Lists are *completely* funded through the generous Contributions of its members. That's it! There's no support from a bloated advertising budget or deep pockets somewhere. Its all made possible through YOUR thoughtful and generous support! To make your List Contribution using a Visa or MasterCard, PalPal, or with a personal check, please go to the URL link below. Here you can find additional details on this year's great free Gifts as well as information on the various methods of payment. Contributions in the $20, $30, $50, $75, and $100 range are common. The Contribution web page is kind of long this year with the details of each of the gifts, so please scroll all the way down! SSL Secure Contribution Web Site: http://www.matronics.com/contributions I would like to thank everyone who supports the Lists this year! Your Contributions truly make it all possible!! Thank you!! Matt Dralle Matronics Email List Administrator Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 05, 2003
Subject: List Fund Raiser - Wow, Have You Seen The Free Gifts?
Dear Listers, The List Fund Raiser is going well so far this year and I wanted to say "Thank You" to everyone that has made a Contribution already this year! Though the generous support of Andy Gold and the Builders Bookstore ( http://www.buildersbooks.com ), I'm able to offer some truly awesome gifts with qualifying Contributions this year. There's quite a line up and a rather diverse set of options - certainly something for every taste and personality. Here's a list of this year's fine options: * List Archive CD * Aircraft Builder's Log * Pilot Flashlight System * Pro Pilot Logbook * FAR/AIM on CD * Jeppesen Flight Bag * Aviation History Book * Techstar Flight Computer Please support your Email List Community AND pick up a really slick Gift at the same time! The SSL Secure Contribution web site can be found at the following URL: http://www.matronics.com/contributions Once again, I would like to thank everyone that has so generously supported the continued operation and upgrade of the Lists Services here on the Matronics servers!! Thank you! Matt Dralle Matronics Email List Administrator Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 07, 2003
Subject: LOM reorganization
SGkgQWxsLAoKSnVzdCBhIGJyaWVmIGNvbW1lbnQgb24gdGhlIExPTSByZW9yZ2FuaXphdGlv bi4KCjEwLzEzLzIwMDIKTE9NIGNvbXBhbnkgaXMgbWVyZ2VkIHdpdGggYW5vdGhlciB0d28g Y29tcGFuaWVzLCBMT0sgYW5kIFZUw5pMLgpOZXcgZ2VuZXJhbCBkaXJlY3RvciBpcyBNci4g aW5nLiBWcmF0aXNsYXYgTcOhc2xvIGFuZCB0aGUgZGlyZWN0b3Igb2YgQXZpYXRpb24gCnRl Y2huaXF1ZSBkaXZpc2lvbiBpcyBNci4gaW5nLiBNaWxhbiBIcmRpbmEgd2hvIGhhcyB0aGUg c2FtZSBwaG9uZS9mYXggCmNvbm5lY3Rpb25zIGFzIGZvcm1lciBkaXJlY3RvciBaYXNhZGls LgoxMS8wNy8yMDAzClRoZSBuZXcgbWFuYWdlbWVudCBkaWQgbm90IHB1Ymxpc2hlZCBhbnkg bmV3IGRldGFpbHMgb24gdGhlIHJlc3RydWN0dXJpbmcgb2YgCnRob3NlIDMgbWVyZ2VkIGNv bXBhbmllcyDigJMgTE9NLCBMT0sgYW50IFZUw5pMLiAgU29tZSBuZXdzIGlzIGV4cGVjdGVk IGJ5IHRoZSAKZW5kIG9mIE5vdmVtYmVyLgoKSXMgYW55b25lIHJlY2VpdmVkIGFueSByZXNw b25zZXMgYmFjayBmcm9tIExPTSBpbiB0aGUgbGFzdCBtb250aD8KSSBoYXZlIGFza2VkIGJv dGggYnVzaW5lc3MgYW5kIHRlY2huaWNhbCBxdWVzdGlvbnMgd2l0aCBubyByZXNwb25zZSB0 byAKZWl0aGVyLiAgSSBrbm93IHR3byBvdGhlciBMT00gb3duZXJzIGhhdmUgbm90IHJlY2Vp dmVkIGFueSBjb21tdW5pY2F0aW9ucyBmcm9tIExPTSAKc2luY2UgdGhlIG5ldyBtYW5hZ2Vt ZW50IGNoYW5nZS4KCkknbSBncmFkdWFsbHkgZ2V0dGluZyBhIHBhcnRzIG9yZGVyIHRvZ2V0 aGVyIHRvIGdvIHRvIExPTS4gIElmIHlvdSBuZWVkIAptYWludGVuYW5jZSBwYXJ0cywgb3Ig cmVwbGFjZW1lbnQgcGFydHMsIHBsZWFzZSBjb250YWN0IG1lIGRpcmVjdGx5LiAgSSdtIHRy eWluZyB0byAKbWFrZSB0aGlzIGNvbWJpbmVkIG9yZGVyIHRvIGdldCBhIHF1aWNrZXIgc2hp cG1lbnQuICAoQXNzdW1pbmcgTE9NIHdpbGwgCnJlc3BvbmQgYXQgYWxsLikKCkppbSBBeWVy cwpqZWF5ZXJzMUBhb2wuY29tCg== ________________________________________________________________________________
Date: Nov 09, 2003
Subject: LOM reorganization - 2nd try
Hi All, Just a brief comment on the LOM reorganization. 10/13/2002 LOM Company is merged with another two companies, LOK and VT=DAL. New general director is Mr. ing. Vratislav M=E1slo and the director of Aviation technique division is Mr. ing. Milan Hrdina who has the same phone/fax connections as former director Zasadil. 11/07/2003 The new management did not published any new details on the restructuring of those 3 merged companies - LOM, LOK ant VT=DAL. Some news is expected by the end of November. Is anyone received any responses back from LOM in the last month? I have asked both business and technical questions with no response to either. I know two other LOM owners have not received any communications from LOM since the new management change. I'm gradually getting a parts order together to go to LOM. If you need maintenance parts, or replacement parts, please contact me directly. I'm trying to make this combined order to get a quicker shipment. (Assuming LOM will respond at all.) Jim Ayers jeayers1(at)aol.com ________________________________________________________________________________
Date: Nov 09, 2003
Subject: LOM technical response
Hi All, Now that I got the previous text corrected and out (hopefully), I received an answer back on my technical question. Still looking for any additional parts needed. I have enough now to send in an order, but don't want to miss anyone that is interested. BTW, I am not a dealer. I will try to get the best price available, and pass it on. My hope is that this will expedite the delivery. Jim Ayers ________________________________________________________________________________
Date: Nov 10, 2003
Subject: WLAS...
Dear Listers, Below are some of the nice things people have been saying about the Lists in that little message box on the Contribution form! Thank you to everyone that has made a Contribution thus far and for all the great feedback! Please know that I really appreciate the comments and support!! If you haven't yet shown your support for these Lists, won't you take a moment and make your Contribution today? The Matronics Lists are always Commercial-Free, SPAM-Free, Virus-Free, and High-performance and its your direct support through this yearly Fund Raiser that enables all of these valuable services you've come to expect. Thank you for your Contribution!! SSL Secure Web Site - http://www.matronics.com/contribution Matt Dralle EMail List Administrator ================================================================ =================== What Listers Are Saying ==================== ================================================================ You provide a service to us kit builders that cannot be measured. -Clifford M. ...great service to the aviation community. -Curt R. Thanks for being there - your List has really been of help. -Thomas R. Your lists have been most helpful to my RV-9A project. -Dean V. ...has been a great help to me. -Jim N. ..."must-have" for RV builders and pilots. -Douglas W. I find something every day on the List that helps me in my project. -Ron P. ...very valuable! -Patrick L. Don't know that I could have persevered and succeeded without the List. -Curt R. ...service continues to be awesome and is one of the most helpful resources for homebuilding that I have ever found. -Jim H. The information and hours of entertainment many of us derive from the Lists is priceless. -Chris R. I learn a lot about my [aircraft] through the Lists... - Lee P. Great source of education and entertainment. Love it!!! -Lar B. Great List & very well organized. -Peter D. I couldn't build my [airplane] without this List. -William G. The List is an important part of my daily routine. -Roger H. ...incredible resource. -Ron P. Excellent facility. -David M. ...unmatched service to all builders and flyers. -Ralph C. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 14, 2003
Subject: [PLEASE READ] - Why Do I Have A Fund Raiser Each Year?
Dear Listers, I was thinking that perhaps I should explain why I have a Fund Raiser and also take the opportunity to express why I think the List Services here provide a far better experience than the commercial equivalents. I use the List Fund Raiser each year to offset the costs involved with running a high performance email list site such as this one. With the annual support from the List members through the PBS-like Fund Raiser, I have found I can run the entire site without having to inflect any of the members with those annoying banner ads flashing up all the time trying to sell Toner Cartridge Refills or other garbage nobody wants or needs. From the comments I've received over the years regarding the Lists, the great majority of the members really appreciate the non-commercialism of my List systems and don't mind my 'go-team-go' banter once a year to encourage members to support the Lists. I believe that the Lists services that I provide here offer a great many benefits over the commercial equivalents in a number of ways. The first feature I believe to be particularly significant is that you *cannot* receive a computer v*rus from any of my Lists directly. I've been on a few other List servers and have been unfortunate enough to download infected files people have innocently or not-so-innocently included with their posts. This just can't happen with my Lists; each incoming message is filtered and attachments stripped off prior to posting. I provide a Photo and File Share feature that allows members to share files and bitmaps with other members and everyone can be assured that these files will be prescanned for any sort of v*rus before they are posted. Safe and simple. Also, with this photo and file sharing technique, the Archives don't get loaded up with a huge amounts of bitmap "data" that slows the Archive Search times. Another feature of this system is the extensive List Archives that are available for download, browsing, and searching. The Archives go all the way back to the very beginning of each List and with the super fast Search Engine, the huge size of the Archives is a non-issue in quickly finding the data you're looking for. Another feature of the Archives, in my opinion, is that they have been primarily stripped of all the useless email header data and all the other header garbage that seems to build up in a typical email thread. I have received an extremely positive response from Listers regarding the List Browse feature and the consensus is that the format and ease of use is outstanding. Members report that having the previous 7 days worth of messages on line for easy browsing and sorting is hugely beneficial. And again, as with the real time distribution of List email, the messages are stripped of all the unnecessary email headers and potentially dangerous v*ruses. I've been running email Lists and services under the matronics.com domain since about 1989 starting with RV-List and 30 guys who I knew and who where also building RVs. It has grown into over 40 different aviation-related Email Lists and an associated web site that receives over 10,000,000 hits each year!! Additionally, the List email system forwards well over 90,000,000 (yes, that 90 MILLION) email messages to subscribers each year! With all the dot.bombs these days, I think there's a lot of value in supporting a service that has gone the long haul and is still providing and improving a high quality service at a price that's nearly free. I have to admit running these Lists is a labor of love and I hope it shows in the quality of the experience that you receive when you get a List Email Message, Search the Archives, or use the List Browser. The Lists will be here for a long time to come. If you just want to lurk a while for free, that's great and I encourage you to do so. If you use, appreciate, and receive value from these Lists, then please support them during the Annual List Fund Raiser! ----------------------------------------------- The SSL Secure Web Site: http://www.matronics.com/contribution ----------------------------------------------- Thank you, Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 28, 2003
Subject: What Listers Are Saying III
Date: Dec 22, 2003
Subject: LOM concerns
Hi All, I sent the following to Charlie Becker at EAA. If you have any concerns about LOM, you might send something to him, also. cbecker(at)eaa.org Hopefully he will be able to find a way to communicate with LOM. Jim Ayers 22 December 2003 From: James E. Ayers EAA # 82685 EAA Tech Counselor and Flight Advisor To: Charlie Becker Subject: LOM engine support? Good Morning Mr. Becker, I am concerned about the availability of maintenance and repair parts for my LOM engine. I purchased my engine directly from the LOM factory. I placed a maintenance/spare parts order on 30 November 2003 for more than $500 USD per the LOM factory representatives, Frantisek Tizek, request. I added part numbers to the description on two items and added two items on 8 December 2003. I addressed this to Frantisek Tizek by Email. I also asked Milos Paclt (technical support) and the director of Aviation technique division, Mr. ing. Milan Hrdina, for their assistance with this order. I have tried to locate these parts from Moravia, Nick Carter, Joe Krybus and Rick Schneider. All previous LOM distributors. (Rick Schneider had signed his agreement with LOM at Oshkosh this year.) I have also contacted friends in Germany who provided contacts in Czech Republic in an attempt to locate these parts. I have been in contact with LOM for eight years. I went to their factory engine class at Prague, Czech Republic, in November 2002. My impression of the LOM company is that it sells engines so the three factory mechanics can travel worldwide to repair them at their convenience. Every effort is made to NOT provide maintenance parts, or proper maintenance documentation. The LOM Company has just been merged with two other companies. My concern is that this maintenance support parts and documentation situation is only going to get worse. Can you please find some avenue of communication with LOM engine manufacturer to express my concern about being able to operate my LOM engine in the future? And to be able to SAFELY operate the engine now. Sincerely, Jim Ayers ________________________________________________________________________________
Subject: Re: LOM concerns
Date: Dec 26, 2003
Hello everyone, Rudy Kniese here, not sure if I am doing this right, but wanted to piggy back on Jim's note. If you are an owner of a LOM engine and have been "lucky" enough not to have any mechanical issues or parts issues you are blessed. Be sure that if you haven't experienced the poor customer service that LOM attempts to offer be sure you will at some time, and be prepared to be grounded for months at a time! It is imperative that we all take advantage at this time, since we have the ear of someone, Charlie Becker, at EAA that may be able to act as an advocate on our behalf. If we ever can expect to run these engines with the least bit of confidence, we must get LOM to service their product!! Please , please take an opportunity and contact Charlie and let him know if you have experience's of poor service like Jim and I have had. It takes more than a couple of complainants to make a just case! I also have attached my letter to Charlie describing my recent events over the past six months regarding a leaky propeller, one that has been leaking for 2 years! Unfortunately my personal experience with this product has been one that I would not wish on anybody, and I have bastardized my Glastar with this product. At the least I hope to stop anyone else from making the same mistake. Regards to all and Happy Holidays, C. Rudy Kniese ----- Original Message ----- From: <Jeayers1(at)aol.com> Subject: Lom-List: LOM concerns > > Hi All, > > I sent the following to Charlie Becker at EAA. If you have any concerns > about LOM, you might send something to him, also. > > cbecker(at)eaa.org > > Hopefully he will be able to find a way to communicate with LOM. > > Jim Ayers > > > 22 December 2003 > > From: > James E. Ayers > EAA # 82685 > EAA Tech Counselor and Flight Advisor > > To: > Charlie Becker > > Subject: LOM engine support? > > Good Morning Mr. Becker, > > I am concerned about the availability of maintenance and repair parts for my > LOM engine. > I purchased my engine directly from the LOM factory. I placed a > maintenance/spare parts order on 30 November 2003 for more than $500 USD per the LOM > factory representatives, Frantisek Tizek, request. > I added part numbers to the description on two items and added two items on 8 > December 2003. > > I addressed this to Frantisek Tizek by Email. I also asked Milos Paclt > (technical support) and the director of Aviation technique division, Mr. ing. Milan > Hrdina, for their assistance with this order. > > I have tried to locate these parts from Moravia, Nick Carter, Joe Krybus and > Rick Schneider. All previous LOM distributors. (Rick Schneider had signed > his agreement with LOM at Oshkosh this year.) > > I have also contacted friends in Germany who provided contacts in Czech > Republic in an attempt to locate these parts. > > I have been in contact with LOM for eight years. I went to their factory > engine class at Prague, Czech Republic, in November 2002. My impression of the > LOM company is that it sells engines so the three factory mechanics can travel > worldwide to repair them at their convenience. Every effort is made to NOT > provide maintenance parts, or proper maintenance documentation. > > The LOM Company has just been merged with two other companies. My concern is > that this maintenance support parts and documentation situation is only going > to get worse. > > Can you please find some avenue of communication with LOM engine manufacturer > to express my concern about being able to operate my LOM engine in the > future? And to be able to SAFELY operate the engine now. > > Sincerely, > Jim Ayers > > ________________________________________________________________________________
Date: Dec 27, 2003
Hello again, Apparently attachments don't work, so here is a cut and paste of the letter I previously mentioned that I had sent to Charlie Becker: December 20, 2003 Re: LOM Engine / Propeller Issues Dear Mr. Becker: First, again I would like to thank you for your time on the phone the other day and in advance thank you for providing any assistance that you may be able to in terms of resolving my outstanding issues with LOM. As per your request I am providing a written request for your assistance regarding the plight that I have been experiencing for now over two years with LOM. The issue at present is that I have a leaky propeller (V541) that has leaked from the onset of my first start of my engine on February 2nd 2001. It has been leaking oil from the hub since my first flight on November 2nd 2001. The larger issue is that I (we, other customers) have installed an engine that is unserviceable in this country due to the lack of an American Distributor and LOM's lack of performance regarding customer care. Parts seem to be unobtainable and when and if you secure a part it takes months not days for that part to arrive! Back to issue at hand: I performed all the work requested by Milos Paclt (Czech chief engineer) over the year 2001 and 2002 with no solution. LOM finally agreed to accept my propeller back for service in January of this year. This repair was supposed to be accomplished in 30 days and it took almost 3 months. Upon arrival back and re-installation the propeller continued to leak. I was put in contact with the Director Vladamir Zasidil whom did take up my cause and sent Milos Paclt out for a service visit. Milos worked on my propeller for a better part of 1 week and made a piston exchange to the model "C" as part of my condolence package for all that I had been through. At the conclusion of his visit the propeller still showed signs of leakage on blade two, and blade one appeared dry on ground runs. It was agreed that I would fly the aircraft for a period of 10 hours allowing the seals to seat better which in Milos' opinion would solve the problem. Upon the completion of 10 hours blade two got worse and now over extended time blade one has started to leak again. This leak allows oil to coat the windscreen and over time provides a nice lubrication to all leading edges! Mr. Zasidil made a 2nd resolution to me: (email expert received 6-25-03) Dear Kniese, > we are very sorry for permanent leaking of oil on your propeller. > Appreciate your patience with this problem. Our solution of problem is > following: We agree to take the propeller back and give you the same > amount of money which LOM got when prop. was sold from company. > If you prefer to get new propeller, instead payment, we can send you > the new prop. V541. > Send us your choice please, which way is more suitable for you. > Best regards > Vladimir Zasadil > LOM Praha The following is an email excerpt regarding my decision and Vladimir's response, to get this far took a while due to lack of responses in a timely manner on questions regarding parts and shipments and attainability of person in Prague due to out of town obligations etc. From: Rudy Kniese [mailto:crkaviator(at)earthlink.net] Subject: Propeller Decision Hello Vladimir, I am assuming you are back from OSHKOSH, I hope your trip went well. I am writing to convey my decision on returning my V541 Propeller back to LOM for a refund of $6,000.00. I am in final phases of confirming a replacement of an MT propeller for my airplane with an electric constant speed. This will remove all the suspected oil problems. I am awaiting shipment time frames and I am hoping you will allow me to use my existing propeller until the new one arrives. Please write and let me know of the process we will need to follow for return shipment and payment. Thanks in advance for all of you assistance thus far. Sincerely, C. Rudy Kniese Answer: Hello Rudy, to use your existing propeller until the new one arrives is possible. Then you will agree the shipping and payments with Mr. Tzek from our commercial departement. I shall happy if I may know your experience with your new MT propeller. Best regards Vl. Zasadil Since this time I have made several requests for parts that would be needed to make the exchange and install a new MT propeller that was ordered. I have received no responses or shipments sent. Another relevant fact now is that LOM apparently has gone through some sort of re-organization and Vladimir Zasidil may no longer be there. I am not even sure about Milos Paclt, since I have not received any responses from him either. The following are email transmissions trying to obtain those parts: 1st Request to Zasidil: ----- Original Message ----- From: Rudy Kniese Hello Mr. Zasadil, It seems the time is approaching to make the return of the V541 back to LOM and I would like to get some loose ends tied up so to speak. Would you be kind enough to answer these questions as soon as you can. 1- Will LOM arrange the shipment of the propeller back to the factory as we did in January for the repair? 2- How exactly will you send my refund of $6,000 USD. I am assuming you will not send until you get the propeller back. 3 -If this is the case how soon and how will you send the refund. I will be out of pocket some monies to replace this propeller with a new MT. Would it be at all possible to have half sent before to help me with this and then the balance sent upon receipt of the propeller. Mt is cutting my blades now and delivery is tentative for the end of the month beginning of November. 4- I have received information from Milos about some parts I will need to make the change from the V541 to the MT, due to the removal of the V541. Here was his list. You need following parts: Sh 0401 Flange Sh 4016 Lid of front bearing including Gufero ring Sc 4008 A,B,C paper gasket Govenor flange lid I need to know if these will be included in the exchange back. I am under the assumption these parts would have come standard with the engine had I not chosen the V541 propeller. Milos asked me to make a request to Mrs. Voskova for these parts. I will be in need of these to make the replacement. Anything you can do to expedite this delivery would greatly be appreciated. Mr. Zasidil, as always thanks for your assistance, Rudy K. 2nd Request sent to Virginia: (included copy of above email) ----- Original Message ----- From: Rudy Kniese Subject: parts and return information Hello Jirina Voskova I sent the attached email to Zasadil as you can see on October 13th, I have heard through the grapevine that Zasidil may no longer be there. Can you assist with my questions and provide the information requested?? If not please put in touch with someone that can assist. Thanks in advance, Rudy 3rd Request sent to Milos - Sent 11-18-03 Hello Milos, I am need of your assistance again. It seems lOM has recently dropped into a black hole!??? Attached are emails that I have sent inquiring on my propeller return and I have received no answers or parts. Can you please assist in some way? Please respond back as soon as possible. Hope your family is well. See ya, Rudy This brings me to the last communication I have received. It was a fax from a Julius Ohrival, title chief of sale piston engines. I do not know this person and have had no knowledge or contact with him before this. Since it was a fax, I will paraphrase its content: He acknowledged my situation, but informed me that my resolution needed to be reviewed by the new management at LOM and requested continued patience. I received his fax on December 5th and faxed him back on December 7th requesting email information and information on the parts needed to make exchange and installation. I have received no response from that fax. Now almost two weeks have passed. This is pretty typical and why it takes sooooo long to try to get anything accomplished, meanwhile planes may remain grounded or problems go unsolved. Charlie, there has been one other communication that I sent, I finally lost all of my patience when I was sent a fax inquiring about an overdue invoice for a part I ordered back in 2001. There is a long story with this also, I have attached that letter for your information, unfortunately it is not as polite as all my other correspondence, and to this date it has not received a response either. I include this as a separate attachment and just so you have all communications that have transpired. To summarize, I had requested from Zasidil a complete return for a refund of both the engine and propeller, due to the lack of performance and the un-serviceability of the engine here in the states. They would only offer me $1400.00 for the engine, their basic published core charge, and the deal they offered on the propeller; since they felt there was nothing wrong with the engine. Excerpt from email from this request: Dear Mr. Kniese, Please excause me you had waiting my response to your e-mail from June 25. I sent my response to you at 7:02 hrs today. The reason is my trip last week. Now, July 3, hrs 9:18 I received next e-mail from you. Let me send you my answer to your questions: 1. This is one extremely question, because of only the prop has an problem and this one can be removed. However, in such case there are possibility back to you the price, which you had pay for prop plus of M332CE engine price "core" ($ 1 400). 2. For the answer see my e-mail 7:02 today. 3. Dtto. Sincerely Vl. Zasadil I would be satisfied if you could get the following resolution: Resolution: 1 - I would like as soon as possible the parts needed to make the installation of the MT propeller shipped. 2 - The details worked out for me to return my V541 propeller, freight paid by LOM and my $6,000.00 USD refunded prior to shipment within the next 30 days. 3 - For LOM to service the product they sell and provide parts and assistance to its US customers in a timely and efficient manner. Days not months!!! 4- For LOM to provide an overhaul manual to its US customers Charlie, thanks in advance for your time attention in this matter. If you require any additional information please contact me directly. I have two years worth of correspondence, but tried to keep only what is relevant to the issue at hand. Regards, C. Rudy Kniese ----- Original Message ----- From: "Rudy Kniese" <crkaviator(at)earthlink.net> Subject: Re: Lom-List: LOM concerns > > Hello everyone, > > Rudy Kniese here, not sure if I am doing this right, but wanted to piggy > back on Jim's note. > > If you are an owner of a LOM engine and have been "lucky" enough not to have > any mechanical issues or parts issues you are blessed. Be sure that if you > haven't experienced the poor customer service that LOM attempts to offer be > sure you will at some time, and be prepared to be grounded for months at a > time! > > It is imperative that we all take advantage at this time, since we have the > ear of someone, Charlie Becker, at EAA that may be able to act as an > advocate on our behalf. If we ever can expect to run these engines with > the least bit of confidence, we must get LOM to service their product!! > > Please , please take an opportunity and contact Charlie and let him know if > you have experience's of poor service like Jim and I have had. It takes > more than a couple of complainants to make a just case! > > I also have attached my letter to Charlie describing my recent events over > the past six months regarding a leaky propeller, one that has been leaking > for 2 years! > > Unfortunately my personal experience with this product has been one that I > would not wish on anybody, and I have bastardized my Glastar with this > product. At the least I hope to stop anyone else from making the same > mistake. > > Regards to all and Happy Holidays, > > C. Rudy Kniese > > > ----- Original Message ----- > From: <Jeayers1(at)aol.com> > To: > Subject: Lom-List: LOM concerns > > > > > > Hi All, > > > > I sent the following to Charlie Becker at EAA. If you have any concerns > > about LOM, you might send something to him, also. > > > > cbecker(at)eaa.org > > > > Hopefully he will be able to find a way to communicate with LOM. > > > > Jim Ayers > > > > > > 22 December 2003 > > > > From: > > James E. Ayers > > EAA # 82685 > > EAA Tech Counselor and Flight Advisor > > > > To: > > Charlie Becker > > > > Subject: LOM engine support? > > > > Good Morning Mr. Becker, > > > > I am concerned about the availability of maintenance and repair parts for > my > > LOM engine. > > I purchased my engine directly from the LOM factory. I placed a > > maintenance/spare parts order on 30 November 2003 for more than $500 USD > per the LOM > > factory representatives, Frantisek Tizek, request. > > I added part numbers to the description on two items and added two items > on 8 > > December 2003. > > > > I addressed this to Frantisek Tizek by Email. I also asked Milos Paclt > > (technical support) and the director of Aviation technique division, Mr. > ing. Milan > > Hrdina, for their assistance with this order. > > > > I have tried to locate these parts from Moravia, Nick Carter, Joe Krybus > and > > Rick Schneider. All previous LOM distributors. (Rick Schneider had > signed > > his agreement with LOM at Oshkosh this year.) > > > > I have also contacted friends in Germany who provided contacts in Czech > > Republic in an attempt to locate these parts. > > > > I have been in contact with LOM for eight years. I went to their factory > > engine class at Prague, Czech Republic, in November 2002. My impression > of the > > LOM company is that it sells engines so the three factory mechanics can > travel > > worldwide to repair them at their convenience. Every effort is made to > NOT > > provide maintenance parts, or proper maintenance documentation. > > > > The LOM Company has just been merged with two other companies. My concern > is > > that this maintenance support parts and documentation situation is only > going > > to get worse. > > > > Can you please find some avenue of communication with LOM engine > manufacturer > > to express my concern about being able to operate my LOM engine in the > > future? And to be able to SAFELY operate the engine now. > > > > Sincerely, > > Jim Ayers > > > > > > ________________________________________________________________________________
From: "Wayne Cahoon @ Aircraft Engravers" <wayne(at)engravers.net>
Subject: Fuel Cap Engraving, Labeling, Indentifying
Date: Jan 23, 2004
Have your Fuel Caps engraved, it's permanent and easy to read. Aircraft Engravers has been engraving fuel caps for over 14 years. You can see our web page at http://engravers.net/aircraft/fuel_caps.htm Other types of engraving jobs can be viewed at http://engravers.net/main/ac_products.htm There are a few sets of loaner fuel caps for the more common styles if your tanks are wet. FREE shipping by USPS Priority mail for all fuel cap engraving orders in the month of February. Wayne Cahoon Aircraft Engravers (860) 653-2780 (860) 653-7324 Fax http://engravers.net/ ________________________________________________________________________________
Date: Mar 03, 2004
DNA: not not archive
Subject: [PLEASE READ] Virus Laden Spam Purports To Be From Matronics...
Dear Listers, First let me say that I normally don't condone the sharing of warnings about Internet viruses on the Matronics Email Lists. I don't want to start a storm of discussion regarding computer viruses on the Lists, so please just note the information below and refrain from commenting to the List. The circumstances I describe below are disturbing enough that I felt an explanation is necessary. That being said... There is a new email-bourne virus running rampant on the Internet that is cleverly disguising itself as legitimate email warning of such things as: "your email account is disabled because of unauthorized access" "Some of our clients complained about the spam (negative e-mail content) outgoing from your e-mail account" "Probably, you have been infected by a proxy-relay trojan server. In order to keep your computer safe, follow the instructions." "Our main mailing server will be temporary unavailable for next two days, to continue receiving mail in these days you have to configure our free auto-forwarding service." All of these messages include an attachment that you are instructed to click upon to "Get more information", "clean the virus from your system", or "check your system for infections". These enclosures all contain a virus that will infect your system and propagate even more copies of the original message. The disturbing part of these messages is that they appear to be coming from very legitimate addresses and have very legitimate, convincing dialog. For example, I have received a number of them today that appear to be from "support(at)matronics.com", "management(at)matronics.com", "administration(at)matronics.com", and "staff(at)matronics.com". The text of the messages seems believable enough, and given the forged source address, seem even more legitimate. Please be assured that no one at Matronics.com will be sending you these kinds of messages. If you receive one, it is a spam/virus that has forged headers and was sent to you from someone other than Matronics. Delete the message and the attachment promptly. Invest in a copy of Norton Antivirus and keep the definitions up dated on a daily basis. Again, I want to stress that I *DO NOT* want a big discussion of viruses on the Matronics Email Lists. Please do not reply to this email with any comments. You may write to me directly at dralle(at)matronics.com if you wish, but do not include the List. Since many of these appear to come from matronics.com, I wanted to assure everyone that Matronics wasn't the real source of these messages. Let's be careful out there and keep those virus definitions up to date! Today alone, the Matronics spam filter and virus blocking appliance has filtered out 11,550 spam messages and 375 viruses! That's just in an 18 hour period! Best regards, Matt Dralle Matronics Email List Administrator -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Date: Apr 25, 2004
Subject: MT Proeller Sale
First Annual MT Propeller Sale! Anyone interested in buying a new MT Propeller? Tell me what you engine and aircraft you want it for, and I'll provide a quote. Jim Ayers Less Drag Products, Inc. MT Propeller Certified Assembly jim(at)lessdrag.com 805-795-5377 ________________________________________________________________________________
Subject: You`ve got 1 VoiceMessage!
Date: - - - , 20-
Dear Customer! You`ve got 1 VoiceMessage from voicemessage.com website! You can listen your Virtual VoiceMessage at the following link: http://virt.voicemessage.com/index.listen.php2=35affv or by clicking the attached link. Send VoiceMessage! Try our new virtual VoiceMessage Empire! Best regards: SNAF.Team (R). ________________________________________________________________________________
Date: Sep 05, 2004
Subject: test, please ignore
test --------------------------------- ________________________________________________________________________________
Date: Nov 27, 2004
Subject: Lister Comments - Please Support The Lists
Dear Listers, Wow! People have been including some very nice comments along with their Contributions lately! I've included another set of below and will send another set in a couple of days. Guys, I really appreciate your kind words and support. In the last few days, the contributions have really started to come in and its looking like support this year may slightly surpass last year's. There's still a few days left in this year's Fund Raiser, so if you've been waiting until the last minute to make your Contribution, now's the time! Make Your Contribution Today: http://www.matronics.com/contribution Thank you! Matt Dralle Email List Administrator ----------------- More of What Listers Are Saying... -------------------- Every morning 5:30 am, coffee and the "List". It's how I start my day. Robert G. The list is still my favorite aviation magazine. Roger H. Great resource, without the distraction of pop ups and ads! Douglas D. I look forward to my daily list reading almost as much as my coffee! Hal K. Great service! Aaron G. I have made some great friends, because of it! Bob D. Great resource!! Richard S. I learn something of value every time I read the messages. Stan S. Great list! Thomas E. Now that I am close to completion of my [homebuilt], I look back and wonder how I could ever have made it this far without [the Lists]. Jeff O. Outstanding site and administration. Anthony S. Great forum for our projects. Darrel M. I have become a List Addict! George M. A very helpful resource for me. Dennis K. Great for staying up on the latest. Forrest L. Valuable benefit for the users. George A. Great tool for all [builders]. Tony M. Can't tell you how much I appreciate the archives. Ken B. I really enjoy the sharing of information and the "discussions" that come up. Ross S. [The List] reminds us home builders that help is just a few clicks away. Danny W. A great resource! Christopher S. Always a pleasure to support this list! Richard W. Thanks for helping all of us build better aircraft. John P. Great list(s)for data, info and making friends. John S. [The] List has helped me much with my building process. Raimo T. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 29, 2004
From: "coolmate_04(at)cashette.com" <no-reply(at)cashette.com>
Subject: Re: List of Contributors Coming Soon!
Dear Friend: Thank you for your email. Your message has not reached my Inbox because you are not yet on my Approved List. To reach my Inbox, please click on this link. When I respond to your message, you will be automatically added to my Approved List! Warm regards, coolmate_04(at)cashette.com __________________________ Note from Cashette: If you don't see any link above, copy and paste the link below to your browser: http://home.cashette.com/myCashette/newUser.do?ms=dralle%40matronics.com&mr=coolmate_04%40cashette.com&rid=coolmate_04&name=Matt+Dralle&sec=yU%2BS&dt=1101757047127 If you are a business, click Business. -----Original Message:----- From: Matt Dralle dralle(at)matronics.com Subject: Lom-List: List of Contributors Coming Soon! __________________________ Cashette stops spam. 100% effective and free! Go to http://home.cashette.com ________________________________________________________________________________
Date: Nov 29, 2004
Subject: Re: Lom-List Digest: 0 Msgs - 11/28/04
Dear Friend: Thank you for your email. Your message has not reached my Inbox because you are not yet on my Approved List. To reach my Inbox, please click on this link. When I respond to your message, you will be automatically added to my Approved List! Warm regards, coolmate_04(at)cashette.com __________________________ Note from Cashette: If you don't see any link above, copy and paste the link below to your browser: http://home.cashette.com/myCashette/newUser.do?ms=lom-list-digest%40matronics.com&mr=coolmate_04%40cashette.com&rid=coolmate_04&name=Lom-List+Digest+Server&sec=oR3z&dt=1101757203526 If you are a business, click Business. -----Original Message:----- From: Lom-List Digest Server lom-list-digest(at)matronics.com Subject: Lom-List Digest: 0 Msgs - 11/28/04 __________________________ Cashette stops spam. 100% effective and free! Go to http://home.cashette.com ________________________________________________________________________________
Date: Jan 07, 2005
Subject: [PLEASE READ NOW] - Addressing Upgrade At Matronics TONIGHT!
Dear Listers, Service Provider to upgrade to a larger IP subnet. I will be re-addressing all of the machines on the network including the Matronics Web Server and Matronics Email Server at that time. Name Service will be updated at that time as well and most things should work again pretty quick. There may be some bounced email for a few hours or even a day or so as the new name-to-ip-address resolutions propagate into the depths of the Internet. If you have problems posting a message to one of the Lists or get a bounced message back, please wait a couple of hours and try sending it again. Generally, access to the web site should work within 1-hour of Hopefully the transition will go smoothly and you'll hardly even notice! :-) Thanks for your patience! Matt Dralle List Administrator -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Subject: LOM parts help
Date: Jan 28, 2005
For engine parts & tech help contact: pavel.novak(at)sympatico.ca He is honest, knowledgeable, and fun! Dave --- Dave & Peggy Abbott --- 190 Duck Pond Ln Pickens, SC 29671 --- (864) 878-8134 --- pickenspilot(at)earthlink.net ________________________________________________________________________________
Date: Apr 16, 2005
Subject: [Please Read] Matronics Email Server Upgrade...
Dear Listers, I will be upgrading the Matronics Email Server this weekend. This includes some hardware improvements - more memory, faster, more capable processors - as well as a complete operating system upgrade from scratch. I hope to have both the old system and the new system running at the same time to minimize the actual impact of the upgrade. Hopefully there will be little actual downtime during the transition, but a few posts may get lost in the shuffle. If you don't see your post show up on the List in the normal amount of time (plus a little bit), then please just try posting it again. Upgrading the Matronics Email Server operating system (from Redhat Linux 7.2 to Redhat Linux WS 4) is a sizeable undertaking and requires a great deal of work to port all of the utilities, programs, and scripts over to the new system. As I've already mentioned, both the old and new systems will be on line at the same time, so interruption should be held to an absolute minimal. You might see a couple of odd test messages during the cut-over or other odd messages; please just ignore them. I have setup a new System Status Web Page that I will use to update List Members on the current status of the email and web systems. Please refer to it as often as you like: http://www.matronics.com/SystemStatus/ Thank you for your continued support of the List Services at Matronics! Its your yearly Contributions that make these major upgrades possible! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Apr 17, 2005
Subject: [Please Read] Matronics Email Server Upgrade Complete!
Dear Listers, The upgrade of the Matronics Email Server can be considered complete at this time. All known issues related to the upgrade process have been resolved and email services are running normal. The Nightly Digest processing has not yet been tested and will wait for tonight's update. If you encounter any odd behavior with respect to the Matronics Email Server over the next few days, please contact me via email at dralle(at)matronics.com or if that fails try dralle(at)speakeasy.net. Thanks to everyone for being patient through this arduous process of a major system upgrade! Matt Dralle Email List Administrator At 12:37 PM 4/16/2005 Saturday, Matt Dralle wrote: >Dear Listers, > >I will be upgrading the Matronics Email Server this weekend. This >includes some hardware improvements - more memory, faster, more capable >processors - as well as a complete operating system upgrade from >scratch. I hope to have both the old system and the new system running at >the same time to minimize the actual impact of the upgrade. > >Hopefully there will be little actual downtime during the transition, but >a few posts may get lost in the shuffle. If you don't see your post show >up on the List in the normal amount of time (plus a little bit), then >please just try posting it again. > >Upgrading the Matronics Email Server operating system (from Redhat Linux >7.2 to Redhat Linux WS 4) is a sizeable undertaking and requires a great >deal of work to port all of the utilities, programs, and scripts over to >the new system. As I've already mentioned, both the old and new systems >will be on line at the same time, so interruption should be held to an >absolute minimal. You might see a couple of odd test messages during the >cut-over or other odd messages; please just ignore them. > >I have setup a new System Status Web Page that I will use to update List >Members on the current status of the email and web systems. Please refer >to it as often as you like: > > http://www.matronics.com/SystemStatus/ > > >Thank you for your continued support of the List Services at >Matronics! Its your yearly Contributions that make these major upgrades >possible! > >Best regards, > >Matt Dralle >Matronics Email List Administrator Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jul 14, 2005
Subject: List Digest Truncation Fixed!!
Dear Listers, I finally figured out today what was causing the occasional truncation of the daily List Digest emails. Seems that every once in a while a message would contain a single "." (period) on line all by itself. The mailers would see this and assume that this was the universal emailer signal for "end of message", and consequently wouldn't process any of the rest of the Digest message. I've put in a filter today to remove any of these sequences so we should be back in business on the Digests. Best regards, Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Sep 06, 2005
Dear Listers, I will be taking the Matronics Web Server down for a few hours today, Tuesday September 6 2005 for a chassis upgrade. Archive browsing and searching along with subscription services will be unavailable for be processed normally during the upgrade. Please check the Matronics System Status Page for updates (although this page resides on the web server and won't be available during the upgrade): http://www.matronics.com/SystemStatus/ Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jan 09, 2006
Subject: All New BBS Interface For Matronics List Forums!
Dear Listers, I'm very proud to announce a completely new BBS interface is now available for all of the Email Lists at Matronics! This is a full-featured system that allows for viewing, posting, attachments, polls - the works. But the best part is that it is *completely* integrated with all of the existing email tools currently available at Matronics! What this means at the most basic level is that, if you post a message to List from Email in the traditional way, it will show up on the BBS system *and* get distributed to everyone currently subscribed to the Email List. By the same token, if you are on the BBS and post a message to a given List-Forum, the message will not only show up on the BBS, but also be distributed to everyone on the Email List!! It is really a very nice implementation and I am very pleased with its operation. All of the tools you have come to know and love such as the List Search Engine and List Browse and Download will still be available and contain all of the latest posts. Think of the new BBS interface as just another method of accessing the all of the Lists. You can use the BBS to view all of the latest posts without having to do anything except use your browser to surf over to the site. You can view and look at all of the various List's posts. If you want to post a new message or reply to an existing message from the BBS, you will have to Register on the BBS. This is a *very* simple process and will only take a couple of minutes. There is a small icon in the upper righthand side of the main BBS page labeled "Register" to get you started. I strongly recommend that you use the exact *same* email address you are subscribed to the Email Lists with when registering on the BBS. Also, while not an absolute requirement, I would really appreciate it if people would use their full name when choosing their Username on the BBS (for example "Matt Dralle"). This just makes it easier for everyone to know who's posting. Also, I have enabled the ability to upload a small user picture with your profile called an "avatar". Please use a *real* picture of yourself *with* your cloths on! Thank you! Maximum size of the bitmap is 120x120. You can either be subscribed to the BBS, or any number of Email Lists, or both. Registering on the BBS will allow you to email directly to all of the various Lists. However, to receive direct List Email, you will need to be *subscribed* to the various Lists as you have in the past. No changes here in operation. I have added numerous links on the BBS pointing to the Email List subscription page. I've had the BBS connected to the Lists for about a week now, so its already loaded up with a fair number of messages. You can post photos and other documents directly to the BBS and links to them will appear in the List Email distributions. Also, when any messages posted to the BBS are viewed in the List Email distribution, there will be a URL link at the bottom of the message pointing back to the BBS. And here's what you've been waiting for -- the main URL for the new Matronics Email List BBS is: http://forums.matronics.com Please surf on over, Register, and have a great time! I think this will be the dawn of a whole new era for the Lists at Matronics! Best regards, Matt Dralle Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jan 29, 2006
Subject: Six New Email Lists / Forums At Matronics!
Dear Listers, Its my pleasure to announce the addition of six new Email List / Forums to the aviation line up at Matronics! These new lists support all the usual features you've come to know and love from the Matronics Email List including full integration with the All New Web BBS Forums Site!! The new Lists include: LycomingEngines-List Textron/Lycoming Engines RotaxEngines-List Rotax Engine for Aircraft M14PEngines-List Vendenyev M14P Radial Engine MurphyMoose-List Murphy Moose Aircraft Allegro-List Allegro 2000, a Czech-built, Rotax-powered Aircraft Falco-List Sequoia Aircraft's Falco Experimental To sign up for any or all of the new Lists, surf over to the Matronics Email List Subscription Form and follow the instructions: http://www.matronics.com/subscribe Don't forget to check out the All New Web BBS Forum now available along with all of the usual message and archive viewing tools at the Matronics Email Lists site. Surf over to the following URL for information on the BBS Forum: http://forums.matronics.com Enjoy the new Lists! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: M337A Starter
Date: Mar 03, 2006
Does any one know where I can get a 12v starter for my M337A repaired in the US? Also does any one know where I can buy another 12v starter for my M337A in the US? Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=19414#19414 ________________________________________________________________________________
Date: Mar 04, 2006
Subject: Re: Lom-List Digest: 1 Msgs - 03/03/06
Dave, Almost any industrial auto generator and starter repair depot should have no problem fixing your starter. Recently took in the starter from my diesel tractor (giant sucker) and they fixed it fine. Rewound the armature I think. Mel Hinde ----- Original Message ----- From: "Lom-List Digest Server" <lom-list-digest(at)matronics.com> Sent: Saturday, March 04, 2006 2:56 AM Subject: Lom-List Digest: 1 Msgs - 03/03/06 > * > > ================================================== > Online Versions of Today's List Digest Archive > ================================================== > > Today's complete Lom-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Lom-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/lom-list/Digest.Lom-List.2006-03-03.html > > Text Version: > > http://www.matronics.com/digest/lom-list/Digest.Lom-List.2006-03-03.txt > > > ================================================ > EMail Version of Today's List Digest Archive > ================================================ > > > Lom-List Digest Archive > --- > Total Messages Posted Fri 03/03/06: 1 > > > Today's Message Index: > ---------------------- > > 1. 02:15 PM - M337A Starter (Dave Nicholas) > > > ________________________________ Message 1 > _____________________________________ > > > Subject: Lom-List: M337A Starter > From: "Dave Nicholas" <Nicholas2(at)wadsnet.com> > > > Does any one know where I can get a 12v starter for my M337A repaired in > the US? > Also does any one know where I can buy another 12v starter for my M337A in > the US? > > Thanks. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=19414#19414 > > > -- > > ________________________________________________________________________________
Date: Mar 05, 2006
Dave and Mel, I had my LOM generator repaired at an auto generator/alternator repair shop at 105 hours TT on the engine. It worked fine, until a I installed the 10 pound lighter B&C alternator/regulator. Jim Ayers In a message dated 03/04/2006 10:37:40 AM Pacific Standard Time, mhinde(at)look.ca writes: Dave, Almost any industrial auto generator and starter repair depot should have no problem fixing your starter. Recently took in the starter from my diesel tractor (giant sucker) and they fixed it fine. Rewound the armature I think. Mel Hinde ________________________________________________________________________________
Date: Mar 25, 2006
Subject: Feedback Request (Alternative Engines) Kitplanes Magazine
Hello all, I would like to hear from you if you're a builder who has successfully installed and flown a LOM (or other alternative) engine in your homebuilt plane. I'm compiling a builder's roundup for Kitplanes magazine, and am looking for an installation that's flown for a minimum of 300 hours, and is currently flying. For the builders that we profile, the magazine will also be able to pay you $100 for the write-up. I'll be at Sun 'n Fun until late morning on Friday (April 7), so if you fly in, I'd be happy to take the photos there. If not, we would also need at least 2-3 good photos, including a close-up of the engine and an overall shot of the aircraft. Additional photos would be great, and all photos will be returned. If you have digital photos, it is very important that they be high-resolution, at least 300 dpi. I have a list of specific areas to address if you'd like to participate, but we can handle that off-line. Please feel free to contact me off-line at: bootless (at) earthlink (dot) net (my despammed email address). Thank you so much! best, Cory Emberson Contributing Editor Kitplanes Magazine ________________________________________________________________________________
Date: Apr 01, 2006
Subject: Matronics Email List Wiki!
Dear Listers, I have added a new feature to the Email List Forums at Matronics called a Wiki. What's "Wiki" you ask? A Wiki is a website. You go to it and browse just like you would any other web site. The difference is, you can change it. You can put anything you want on this web site without having to be a web designer or even being the owner. You can write a new page just like writing an email message on the BBS. You don't need to send it off to anyone to install on the site. It is kind of like a Blog (weblog) in which anyone can post. Here is a great page on where the term Wiki came from and what it means in the context of a website: http://en.wikipedia.org/wiki/Wiki So on to the new Matronics Email List Wiki... I've created this site for anyone from any of the Email Lists to use. I envision that there are a great many things that can be added to this new Wiki since there are always new and interesting tidbits of useful information traversing the Lists. Off the main Matronics Email List Wiki page, you will find a link called "Community Portal". Here you will find more links to stubs for all the various Lists found at Matronics (and a few other links). Brian Lloyd and others from the Yak-List have already begun adding content in a number of areas. Bob Nuckolls of AeroElectric fame has added a great article on "Ageing Aircraft". I have discussed the new Matronics Email List Wiki with Tedd McHenry and Dwight Frye of the RV Wiki Site and they have decided to merge their site over onto the new Matronics Wiki server giving everyone a single source for information on RV building and flying! This migration will begin today and you should be able to find all of the content currently found at www.rvwiki.org moved over to the Matronics Wiki within a few days. To make edits to the Matronics Wiki, you will need to have a login account on the Matronics Wiki and I have disabled anonymous edits. This protects the Wiki site from automated spam engines and other nuisances that could compromise the data at the site. Signing up for an account is fast and easy and begins by clicking on the "create an account or log in" link in the upper right hand corner of any page. Note that you do not have to have a login or be logged in to view any of the content. The Matronics Email List Wiki is YOUR Wiki! It is only as useful as the content found within. The concept of the Wiki is that the people the use it and update it. If you've got an interesting procedure for doing something, MAKE A WIKI PAGE ON IT! You can even upload pictures. Saw something interesting at a flyin? MAKE A WIKI PAGE ON IT! Don't be shy, this is YOUR site to share information with others with similar interests. Here is a users guide on using the Wiki implemented at Matronics: http://meta.wikimedia.org/wiki/Help:Contents This gives a lot of great information on how to get started editing pages. And finally, here is the URL for the Matronics Email List Wiki: http://wiki.matronics.com Brian Lloyd has written an excellent introduction to Wikis on the front page. I encourage you to read it over, then drill into the "Community Portal" and HAVE FUN!! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Apr 02, 2006
Subject: better 12 VDC Starter Solenoid pn?
Hi All, Does anyone know the part number for the bigger 12VDC starter solenoid the some LOM engines are using? Jim Ayers ________________________________________________________________________________
Date: May 22, 2006
Subject: Matronics BBS Forums
Hello Listers, I just wanted to send out a reminder to all of the Listers regarding the new-ish BBS (Bulletin Board System) Forums that are available at Matronics for the Email Lists. The BBS Forums give you Web-based access into the same email content that is generated by the Email Lists. When an email message is posted to any of the email lists, a copy of the message is also copied to the respective List forum section on in the BBS Forums. By the same token, when a message is posted within the BBS Forum interface context, it will also be posted to the respective email list. Basically, the BBS Forums give you yet another method of accessing the Matronics Email List content. Some people prefer email, some prefer web forums; now you can have it either way or both with the Matronics Lists! You'll have to register for a login/password on the BBS Forum to _post_ from the BBS, but you can view message content without registering for an account. To Register for an account, look for the link at the top of the main BBS Forum page entitled "Register". Click on it and follow the instructions. Site Administrator approval will be required (to keep spammers out), but I will try to get these approved in less than 24 hours. If you haven't yet taken a look at the Matronics Email List content over on the BBS Forum, surf on over and take a peek. Its pretty cool. The URL is: http://forums.matronics.com I want to stress that the BBS Forums are simply an adjunct to the existing Matronics Email Lists; another way of viewing and interacting with the Matronics List content. If you like Email, great. If you like Web Forums, great. If you like both, great. Its up to you how you view and create your content. You will also find a URL link at the bottom of this email called Matronics List Features Navigator. You can click on this link at any time to find URL links to all of the other great features available on the Matronics site like the Archive Search Engine, List Browse, List Download, FAQs, Wiki, and lots more. There is a specific Navigator for each Email List and the link for this specific List is shown below. Thanks for all the great list participation and support; it is greatly appreciated! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: May 29, 2006
Subject: Two New Email Lists at Matronics and Wiki Reminder!
Dear Listers, I have added two new email Lists to the Matronics Line up today. These include a Continental engine List and a Lightning aircraft List: =========== continental-list(at)matronics.com http://www.matronics.com/Navigator?Continental-List Everything related to the Continental aircraft engine. Sky's the limit on discussions here. =========== =========== lightning-list(at)matronics.com http://www.matronics.com/Navigator?Lightning-List This is an exciting new design from Arion Aircraft LLC in Shelbyville Tennessee. Pete Krotje has a very nice web site on the aircraft that can be found here: http://www.arionaircraft.com/ =========== Also, if you haven't checked out the new Matronics Aircraft Wiki, swing by and have a look. Remember, a Wiki is only as good as the content that the members put into it. Have a look over some of the sections, and if you've got some interesting or useful, please add it to the Wiki! Its all about YOU! :-) The URL for the Matronics Wiki is: http://wiki.matronics.com Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Jun 03, 2006
Subject: List Enclosure Support
Dear Listers, Over the years, I have resisted the urge to enable enclosure support on the Matronics Lists for a number of reasons relating to performance, capacity, capability, and security. However, its now 2006 and most everyone using email these days is on an email client that, at some level, supports the viewing and handling of enclosures. I get a fair amount of email each month from people on the various Lists asking why their posts of this or that picture didn't go through. Back quite a while ago by popular request, I enabled enclosure support for a few Lists such as the RV10-List, Kolb-List, and the Tailwind-List. Contrary to my fears, there really hasn't been any significant issues on these Lists relating to the advent of enclosure support and for the most part, members have policed themselves well with respect to the size of things they have posted. Having enclosures enabled on some Lists and not others has given me a fair amount of headaches with respect to filtering messages and content since the formats are often quite different between a typical MIME encoded message and a generic plain-text message. The spammers are getting more cleaver all the time and are constantly trying to thwart my best efforts at keeping them from posting to the Lists. So, for these reasons, I've have decided to go ahead and enable limited enclosure posting on all of the email Lists at Matronics. This will not only increase the utility of the Lists, but will afford me a better opportunity to filter out the chaff. Here are some of the features and limits of enclosures on the Matronics Lists: 1) Enclosures will only be posted to the Real Time version of the Lists. 2) Enclosures will NOT be included in the Daily Digest version of the Lists. 3) Enclosures WILL BE forwarded on to the BBS Forum Web site. 4) Enclosures will NOT be appended to the Archives. 5) Enclosures will NOT be available in the List Browse feature. 6) Only the following file types and extensions will be allowed: jpg, bmp, gif, txt, xls, pdf, and doc All other enclosures types will be rejected and email returned to sender. The enclosure types listed above are relatively safe from a virus standpoint and don't pose a particularly large security risk. 7) !! All incoming enclosures will be scanned for viruses prior to posting to the List. This is done in real time and will not slow down the process of posting the message !! Here are some rules for posting enclosures. Failure to abide by these rules could result in the removal of a subscriber's email address from the Lists. 1) Pay attention to what you are posting!! Make sure that the files you are enclosing aren't HUGE (greater that 1MB). Remember that there are still people checking they're email via dial up modem. If you post 30MB worth of pictures, you are placing an unnecessary burden on these folks and the rest of us, for that matter. 2) SCALE YOUR PICTURES DOWN!!! I don't want to see huge 3000 x 2000 pictures getting posted that are 3 or 4MB each. This is just unacceptable. Use a program such as Photoshop to scale the picture down to something on the order of 800 x 600 and try to keep the file size to less-than 200KB, preferably much less. Microsoft has a really awesome utility available for free that allows you to Right-Click on a picture in Explorer and automatically scale it down and resave it. This is a great utility - get it, use it! http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx Look for the link "Image Resizer" 3) !! This would seem to go without saying, but I'll say it anyway. Do not post anything that would be considered offensive by your grandmother. And you know what I'm saying; I don't want to see anything even questionable. !! 4) REMEMBER THIS: If you post a 1MB enclosure to a List with 1000 members subscribed, your 1MB enclosure must be resent 1000 times amounting to 1MB X 1000 = 1 Gigabyte of network traffic!! BE CAREFUL and BE COURTEOUS! I hope everyone will enjoy the added functionality of enclosures. Please police yourself and use good judgement when posting messages with enclosures using the guidelines I've outlined above. Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Matronics Email List Web Server Upgrade Tonight...
Dear Listers, This evening I will be upgrading the Matronics Web Server hardware to a new Quad-processor 2.8Ghz Xeon system (yes, 4-physical CPUs!) with an Ultra 320 SCSI Raid 5 disk system and 5GB of DDR2 RAM. As with the older system, the new system will be running the latest version of Redhat Linux. Most of the software configuration work is already done for the migration, but I still have to sync all of the archive and forum data from the old system to the new system. I am anticipating about 2 to 3 hours of downtime for me to fully make the transition, although it could be considerable less if everything goes according to plan. The Matronics Webserver will be *UNavailable* from the Internet during the work, and you will receive a time-out if you try to connect during the upgrade. Email List Distribution will be *available* during the upgrade of the Web Server, and List message distribution will function as normal. This represents a significant performance upgrade for the Matronics Web Server and you should notice nicely improved searching and surfing performance following the upgrade! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Aug 06, 2006
Subject: New Incoming Message Size Limit Implemented...
Dear Listers, Due to a number of requests to limit the size of incoming posts to the Lists because of the recently added enclosure feature, I have add a new filter that will limit the total size of any given message posted to the List. I have initially set the limit to 2MB and we'll see how everyone likes that. If a member attempts to post a message that is greater than the set limit, they will receive an email back indicating that their message wasn't posted to the List and why. Also included in the message will be the current size limit and how large their message was. Some might say that 2MB is still too large, but its a place to start... Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Oct 29, 2006
Subject: Comcast Was Blocking Matronics Email Lists...
Dear Listers (Specifically Comcast Listers), For about the last two days, Comcast was blocking incoming email from the Matronics Email Lists because their spam filters thought the mail was spam. I was that people on Comcast are receiving List messages again. If you are a Comcast user, you might want to email them and express your displeasure with their Spam blocking policy, particularly as it relates to "matronics.com". Sorry for the hassle... Matt Dralle Matronics Email List Admin Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 01, 2006
Subject: Matronics Email List Fund Raiser - November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the List services at Matronics. It's through these sole Contributions of List members that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site ( http://forums.matronics.com ), Wiki site ( http://wiki.matronics.com ), or other related pages such as the List Search Engine ( http://www.matornics.com/search ), List Browse ( http://www.matornics.com/listbrowse ), etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisments. During the month of November I will be sending out List messages every few days reminding everyone that the Fund Raiser is underway. Each message will generally highlight a particular feature or benefit of the Matronics Lists or detail a new feature or service that was added this year. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. Once again, this year I've got a terrific line up of free gifts to go along with the various Contribution levels. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on Matronics Lists and have been either donated or provided at substantially discounted rates. This year, these generous people include Bob Nuckolls of the AeroElectric Connection (http://www.aeroelectric.com/), Paul Besing of Aeroware Enterprises aka Kitlog Pro (http://www.kitlog.com/), Andy Gold of the Builder's Bookstore (http://www.buildersbooks.com/), and Jon Croke of HomebuiltHELP (http://www.homebuilthelp.com/). These are extremely generous guys and I encourage you to visit their respective web sites. Each one offers a unique and very useful aviation-related product line. I would like publicly to thank Bob, Paul, Andy, and Jon for their generous support of the Lists again this year!! You can make your List Contribution using any one of three secure methods this year including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure site below: https://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years. I know it sounds a little cliche, but you guys really do feel like family. Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 03, 2006
Subject: Have You Tried The New Matronics List Forum?
Hello Listers, One of the major new additions to the Matronics Email Lists this year was the addition of a new and full function Forum Web Site at: http://forums.matronics.com The best part of these new Forums is that they are tied directly to the Classic email distribution Lists! That also means that posts go in both directions. If you post a message on the Forum web site, it will be cross posted to the respective Email List. And, if you post a message to a particular Email List, it will be cross posted to the same respective forum on the Forum site! So, no matter what your content viewing pleasure is - either direct email distribution or web-based GUI interface, you can have it at the Matronics Email Lists! Won't you make a Contribution to support these Lists? It is your SOLE Contributions that make their continued operation and upgrade possible! The Contribution site is Fast, Easy, and Secure. Please surf over and make your Contribution today: http://www.matronics.com/contribution Thank you!! Matt Dralle Matronics Email List Administrator _- _- _- _- _- _- ________________________________________________________________________________
Date: Nov 06, 2006
Subject: Wow, Cool! New List Feature... [Please Read]
Dear Listers, By popular suggestion, I've written a substantial new code module for the Matronics Email Lists system. Here's how it works... During each November, I send out quite a few PBS-like "Please make a Contribution to support your List" emails. Wouldn't it be cool if, once a member made a Contribution, they didn't have to receive my support pleas anymore for the rest of that year? Well, that's exactly what I've written! Following this posting, anyone that makes a List Contribution in 2006 will no longer receive my Contribution Pleas for the rest of the year! The best part is this not only applies to the Realtime distribution, but also the Digest distribution! For those that have made a Contribution, the Daily Digest email-version will be invisibly stripped of my requests as well! (Note that my requests will still be present in the online versions of the Digests, List Browse, and on the Forum site.) For those submitting their Contribution by personal Check, please be sure to include your email address along with your Check as this is what is used to determine eligibility. So, in a nutshell, here's how it works: Make a Contribution = No more "Please Make a Contribution" messages! How sweet is that? If that's not a great reason to jump on the Matronics Email List Contribution site and make your donation today, I don't know what is! Don't forget that there are some totally awesome free gifts to be had along with your List Contribution this year!! Don't wait a minute longer to support your Lists! http://www.matronics.com/contribution Thank you for your Support!! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 08, 2006
Subject: If You Got This Email, You Haven't Made A Contribution Yet!
:-) If you received this particular Matronics List Email message, its because you haven't yet made a Contribution to support your Lists! This is the first PBS-like funds drive message under the new distribution system. The new system selectively sends out the Contribution messages ONLY to those that forgot to whip out the 'ol credit card this year to support the continued operation and upgrade of the Matronics Email Lists! Don't you wish PBS worked that way? :-) You heard that right. Once you make your Contribution, these support requests messages during November will suddenly stop coming to your personal email inbox! Pardon me if I seem kind of excited about the new feature. I've wanted to implement something like this for a number of years now, but it was always such a daunting task to modify the back-end List processing code, that I just kept putting it off. Finally this year, I just decided to bite the bullet and put the code-pounding time it to make it work. A few days later, bam! A working system! Anyway, I'll stop gushing now. I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site like this. It also goes to pay for the Commercial-Grade Internet connection and to pay the rather huge electric bill to keep the computer gear running and the air conditioner powered up. Your personal Contribution matters because when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercialism that is so prevalent on the Internet these days and I particularly don't want to have it on my Email List site. I'm pretty sure you don't either. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution today to keep it that way!! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 08, 2006
Subject: Clarification On New Contribution Module Operation...
Dear Listers, A number of Listers emailed and indicated that, even though they had made a Contribution this year, they still received the Contribution message yesterday. I looked into it and I found a slight anomaly (ok, bug) in the new code specifically as it related to Listers that had made their Contribution through PayPal AND have a DIFFERENT email address for their PayPal account and for their Matronics List subscription. If your PayPal account email address is DIFFERENT than the email address you are subscribed to the Matronics List(s) as, then my new code module couldn't tell that you had made a Contribution, since it was using the PayPal email address instead of the List email. I've fixed this issue for any new PayPal Contributions, but I don't have any easy way of resolving this for any of the previous Contribtuions. Again, this is ONLY an issue if your PayPal and Matronics List email addresses ARE NOT the same. Otherwise, everything works great. If you made a PayPal Contribution before 11/09/06 AND your email addresses don't match, please drop me an email at " info(at)matronics.com " (do not reply to this message!) and give me your Name, and both Email Addresses and I will manually update the records so that things will work as advertised. Sorry for the hassle! New code; new bugs... :-) To make a Contribution, please see: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administration ________________________________________________________________________________
Date: Nov 10, 2006
Subject: Wiki...
Dear Listers, I added a new Wiki web site to the Matronics Email List features earlier this year. What's a Wiki, you ask? Well, here's the Wikipedia (http://en.wikipedia.org/wiki/Wiki) definition: A wiki (IPA: [ w .ki ] or [ wi .ki ] ) is a type of Web site that allows the visitors themselves to easily add, remove, and otherwise edit and change some available content, sometimes without the need for registration. This ease of interaction and operation makes a wiki an effective tool for collaborative authoring. The term wiki also can refer to the collaborative software itself (wiki engine) that facilitates the operation of such a Web site, or to certain specific wiki sites, including the computer science site (an original wiki), WikiWikiWeb, and on-line encyclopedias such as Wikipedia. Under the Matronics Email List Moniker, there is now a very nice List-specific Wiki available! It a place for Listers to put articles about any aviation topic that suits them. The purpose is to provide what the mailing lists do not: structure and persistence. The mailing lists are a fantastic resource to ask a question and get good (and bad and funny and annoying) answers. But once the question is asked and answered it is not in front of the List anymore. If a new person subscribes the next day, he/she does not see that information unless he/she goes to the trouble to search the archives, a hit or miss proposition. The result is that the same thread of conversation gets created and/or revisited. There are several things that happen as a result: 1. The person gets his or her question answered; 2. The information gets better as more people think about and answer the question; 3. The people who have seen the same question asked and answered get annoyed at seeing the same things over and over and over and ... So this is where the Wiki comes in. You know what questions you wanted answered. You may have asked or answered the question. You know the information is useful. So you put the information here, in the Matronics Email List Wiki! It doesn't matter that this information is 100% complete or correct. Just writing something creates a placeholder and makes useful information available immediately. It has the same immediacy as the mailing list but it has persistence and structure. But what if the information is incomplete or incorrect? No problem! Anyone else coming along can edit the article! If I write something and you discover something I have left out or stated incorrectly, you can fix it right then! So let's begin and make this the place for information about building, flying, maintaining, and understanding our airplanes. But what about whether something is "appropriate" or not? Don't worry. Write it down. Let the reader determine whether or not it is appropriate. If it is, he/she will read it. If it isn't, he/she won't. It's as simple as that. And when you do write that article you won't have to worry about whether some editor is going to decide whether or not to print it in a newsletter or whether the webmaster will have time to put it up on the web page. The last question I hear brewing out there is: if anyone can post anything, won't this just become a mass of garbage? Surprisingly, the answer is a resounding no. If you want proof, go visit the Wikipedia, a free-to-everyone encyclopedia written by whoever wants to write articles. The articles there are as good as anything I have read anywhere and anyone can add anything anytime they want to. So don't hesitate. Write it down. Put it here. It will never hurt anyone. The more information we get here, the more useful it will become to other people and the more information they will put here for YOU to use. Here's the URL to start (there are lots more bured under this starting place): http://www.matronics.com/wiki/index.php/Matronics:Community_Portal But please don't forget that this Wiki and all of the other Matronics Email List features are supported solely by YOUR Contributions!! November is List Fund Raiser month and there are lots of Free Gifts to be had with your qualifying Contribution. Please make a Contribution to support the continued operation and upgrade of these great services!!! Thank you! http://www.matronics.com/contribution Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 13, 2006
Subject: WLAS [Please Read]
Dear Listers, I sat down at the 'ol computer tonight to have a look at a few of the nice comments List Members have been including along with their Contributions this year. I was amazed at how many I found and even more amazed at some of the very nice things Listers have been saying about the Lists and how valuable the they are to them. I've included quite a few of these nice comments below. Please read over some of this great Lister feedback. No doubt you will find that you agree with at least one or two of those comments - maybe all of them! If you find that do, won't you please make a Contribution to support these Lists today!! Its fast and easy with the Matronics List Contribution Web Site: http://www.matronics.com/contribution Don't forget that I've now fully implemented the new *List Fund Raiser Squelch* feature that will automatically intercept any future iterations of my "Please Contribute" messages -- that is, *once you've made YOUR Contribution*! How cool is that? (Make sure the email address you enter along with your Contribution matches exactly your subscribed List email address. An exact match is how it works.) Thank you for your generous Contributions this year and for all the wonderful comments!! Matt Dralle Matronics Email List Administrator ================= What Listers Are Saying (WLAS) ================ Absolutely the best deal on the Internet!! -Owen B I love The Matronics... -Robeto B My wife has her soaps & I've got my lists! -Hal B These lists are, indeed, the lifeline of our hobby. -Bob R The best source of information for my a/c. -Tony C The Zenith list is the first thing I read in the morning. -Herbert H You do more good than you can imagine. I wish I'd known about you while I was building my Kitfox, but you are still an after-the-fact resource. -Ben B ..an excellent site. -Ashley M The "List" has been the ultimate help for my Zenith CH 701 project!! -Brian U I appreciate the list being here for me. -Geoff H ..a great service. -William C The List continues to be an interesting and useful facility. -David M Your list is a constant goad to keep me working on my project. -Thomas S ..a great service. -Robert W The Pietenpol list is a great resource. -Benjamin W The Yak-list is Awesome! -James S ..great service. -Robert S The features you have implemented recently have you poised to knock out yahoo groups... -Danny D I like how your forum looks/works and the list service... -Ken E ..great service. -David P Very useful web site. -Wayne E ..a very valuable service. -Chris D Great sites... -Randall R I used to look at [that other] site also but it's gotten so cluttered with advertising that I've stopped looking at it. -Wayne E Without your services, the build would be a grope in the dark... -Fergus K The information and help I've received greatly outweighs the donation... -Lee P ..great service! -Christopher D I really don't think I could be building my plane without the wisdom I find on this list. -William G It really makes building a pleasure. -James P ..great service. -Doug W I'm getting near the end of my build (Europa tri XS) don't think I could have done it with out the help of the forum. -Stanislaus S Marvelous service. Couldn't have done it without you. -Jim G Love the list, this is a wonderful way to help others... -Michael S ..good service. -Derek L The list is responsible for helping me complete this project and educating me in the process. -Jeff D Definitely worth the donation. -Ron L ..great service to the aviation community. -Tony P I have been flying my plane for 5 years (RV-6) but I still get valuable information from this service. -Don N A very helpful site. -Roland S It's a great community to be part of. -David L Great sites. -John C A great place to find and share not only information but to meet people across the country and make lasting relationships. -Uncle Craig Great facility. -Peter H Its a great source of information! -Michael W Great improvements to the List... -Edward A Great service!!! -Rich D ..great resource! -William C ..excellent lists! -Michael S Couldn't have built my RV4 without the list. -Warren M ..a great service... -James N I would not have missed [the list] for anything during the building of my Europa. -Svein J ..another great year. -Robert D ..this [is an] essential builder's resource. -David A ..excellent service. -Gregory B I've learned a huge amount of "stuff" over the past year and look forward to it every day! -Smith M ..a great communication tool... -Jon M Finished building 5 years ago, but still are lurking on your great list! -Lothar K ..a valuable service. At 11:00 pm Matronics is the goto place for my RV questions. -Mike D ================= What Listers Are Saying (WLAS) ================ ________________________________________________________________________________
Date: Nov 15, 2006
Subject: LOC
Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by popping a personal check in the mail to: Matt Dralle / Matronics PO Box 347 Livermore CA 94551-0347 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 17, 2006
Subject: List Value...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least 0 or 0 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some lame magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that same amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... Won't you please take a minute to make your Contribution today and support YOUR Lists? Contribution Page: http://www.matronics.com/contribution Again, I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 20, 2006
Subject: Why? [Please Read]
Dear Listers, Each year I like to explain why I have a Fund Raiser and also take the opportunity to express why I think the List Services here provide a superior experience over the commercial equivalents. I use the List Fund Raiser each year to offset the costs involved with running a high performance email list site such as this one. With the annual support from the List members through the PBS-like Fund Raiser, I have found I can run the entire site without having to inflect any of the members with those annoying banner ads flashing up all the time trying to sell little-blue-pills or other garbage nobody wants or needs. From the comments I've received over the years regarding the Lists, the great majority of the members really appreciate the non-commercialism of my List systems and don't mind my 'go-team-go' banter once a year during November to encourage members to support the Lists. I believe that the Lists services that I provide here offer many benefits over the commercial equivalents in a number of ways. The first feature I believe to be significant is that you cannot receive a computer v*rus from any of these Lists directly. Each incoming message is filtered and dangerous attachments stripped off prior to posting. I also provide a Photo and File Share feature that allows members to share files and bitmaps with other members and everyone can be assured that these files will be prescanned for any sort of v*rus before they are posted. Safe and simple. Another very important feature of this system in my opinion is the extensive List Archives that are available for download, browsing, and searching. The Archives go all the way back to the very beginning of each List and with the very fast Search Engine, the huge size of some of the Archives is a non-issue in quickly finding the data you're looking for. And added just this year is the new Email List Forum that allows members who prefer the Web BBS-style of List interaction. The beauty of the new List Forums is that they contain the exact same content that is distributed via email. Messages posted via email are cross-posted to the respective Forum and vice versa. The Forums also allow for another convenient method of sharing pictures and other files. Additionally added this year is the new List Wiki that allows members to build their own "Online List Encyclopedia" of sorts, documenting various aspects of their project for all to share. I've been running email Lists and services under the matronics.com domain since about 1989 starting with RV-List and 30 guys I knew and who where also building RVs. It has grown into nearly 70 different aviation-related Email Lists and an associated web site that receives over 23,000,000 hits each year!! Additionally, the List Email system forwarded well over 87,000 postings last year, accounting for an unbelievable 39,000,000 (yes, that's 39 MILLION) email messages delivered to Matronics List subscribers! I think there's a lot of value in supporting a service that has gone the long haul and is still providing and improving a high quality service all _without any advertising budget_! I have to admit running these Lists is a labor of love and I hope it shows in the quality of the experience that you receive when you get a List Email Message, Search the Archives, use the List Browser, or surf the Forums and Wiki sites. The Lists will be here for a long time to come. If you just want to lurk a while for free, that's great and I encourage you to do so. If you use, appreciate, and receive value from these Lists, then please support them during the Annual List Fund Raiser! List Contribution Web Site: http://www.matronics.com/contribution Thank you, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 22, 2006
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 24, 2006
Subject: More Great List Comments - Please Make A Contribution!
Dear Listers, There's a little less than one week left for this year's List Fund Raiser. I thought it would a great time to share a few more of the great comments I've been receiving from Contributors regarding what the Lists mean to them. There are some particularly poignant ones in this batch and I encourage you to have a look at some of them. Don't forget that once you make your Contribution, the Contribution Squelch kicks in and you won't receive any future messages from me regarding the Fund Raiser this year! This holds true for the Realtime and Digest distributions and now also the HTML and TXT links included with the Digest! (Note that for technical reasons, if someone replies to one of my contribution messages, the Squelch will _not_ be activated, and you will still receive it. Contribution messages will also still be found on the Forums site and the List Browse). Please make your Contribution today to support these List services! Pick up a great Gift too! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ============================= WLAS #2 ============================ Tackling my project without the List would be like building on a deserted island. The List has made me part of a learning (and laughing) community. -Larry W Thank you for providing such a fantastic resource for us Kolbers. I'm very happy to contribute towards keeping such a wonderful resource available. -Geoff T ..you do a great service for the flying community by providing this service. -John L ..solidly administered. -James C A great source of information. -Ralph S The Lists have likely saved a numbers of lives... -James F ..exceptional user service. -Larry W Better than a magazine! -Aaron G Thanks to your List I will be able to finish and fly my project. Without the help of the great people on your List I doubt it would have happened. -Ed G I learn something on a too regular basis thanks to these lists! -Ralph C ..valuable service. -John F ..a well administered service. -Stewart C Great forum! -Ronald C A great service! -Andy H Been reading the lists since my first RV in 1999. Good work and as necessary to me as a rivet. -Albert G The lists are a great help. -Gary S This resource has been critical to my building success so far. -Timothy F Great system and support! -Richard P Very helpful in the building my CH 701. -Ralph S Another year of entertainment and pleasure! -Larry B A great resource for all of us. -Larry W Another year of great service! Once again, the information is worth more than I can ever contribute. Thank you also for the "community" that the List fosters. I cannot tell you the number of times that seeing an friend's name come up has caused so many awesome memories to come flooding back - along with the eager desire to gather with these great guys again. I love hearing the beginner's enthusiasm, the builder's progress, and the flyer's success... -Robert B Our list has great info and I love reading the "Flame Posts! " -Stephen M Great service! -James B Excellent source of information. -David P You provide a very valuable service to the aviation community. -David H The RV related lists have been a tremendous help in the construction of my RV-7... -Norman R Awesome list!! -John E Great bunch of guys and very knowledgeable! -Herbert G Thank you for making it so easy to stay in touch with my fellow RV-10 builders. -David J I love the list and have been a reader for a long time. -James V Continues to be a great service! -George A Awesome List server. -Deke M Many of us would never finish our airplanes without [the List]. With it, I'm getting close! -Ronald C An excellent source of both information and inspiration! -William R Forums and format are easy to use. -Jack B Great help with my kit building. -Ralph H Super service. -Richard N Still loving it. -Jared S You have a fantastic web! -Harvey R ..a great service. -James M Glad you are there... -David A I get some great information on your list. -John P Fantastic service. Couldn't have made it as far as I have without it. -Stephen T A great learning experience with my RV-6A. -Ron B Great resources! -Jason H Well done. Very valuable. -Jeffrey D Great resource for the experimental aircraft community. -Chris H This List has been one of the most helpful tools in building my RV-10, since I build alone, and do not have any help readily available. Without the List, I could not have embarked on building my RV-10. -Jim H You run a great list there. -James H Really like the Kolb List. -Don W ============================= WLAS #2 ============================ ________________________________________________________________________________
Date: Nov 27, 2006
Subject: List of Contributors Coming Soon - Make Sure You're Listed!
Dear Listers, The List of Contributors (LOC) is just around the corner! On December 1st I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. As a number of people have pointed out in their Contribution comments, the List seems at least as valuable of a building/flying/recreating tool as a typical your magazine subscription! And how interactive is a magazine, after all? :-) Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by droping a personal check in the mail to: Matronics / Matt Dralle PO Box 347 Livermore CA 94551-0347 USA (Please include your email address on the check!) I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 28, 2006
Subject: Who is "Matt Dralle" & What Are "The Lists"? [Please Read]
Dear Listers, Who is Matt Dralle and what exactly are these Lists? Well, I've been working in the information technology industry for over 20 years primarily in computer networking design and implementation. I have also done extensive work in web development and CGI design during this period. I started the Matronics Email Lists back in 1990 with about 30 fellow RV builders from around the world. Since that time, I have added 63 other kinds of aircraft related Lists to the line up and numerous other List related services such as the Forums, Wiki, Archives and Search Engine just to name a few. For flexibility and reliability, I have chosen to run all of my own servers here locally. Other List-related systems include a 1 Gigabit, fully switched network infrastructure, a commercial-grade Netscreen firewall, a Barracuda spam filter, a local T1 Internet router, and a commercial-grade business T1 Internet connection with full static addressing. The computer servers found here include a brand new, quad-processor Xeon Linux server for List web services, a dual-processor Xeon Linux system dedicated to the email processing List functions, and another P4 Linux system serving as a remote storage disk farm for the archives, databases, and for an on-line hard drive-based backup system with 3.2 Terra Bytes of storage, soon to be upgraded to over 6 Terra Bytes! This entire system is protected by three large, commercial-grade uninterrupted power supply (UPS) systems that assure the Lists are available even during a local power outage! Speaking of power, imagine how much electricity it takes to run all of these systems. One month this Summer, I had a staggering $1368 bill for electricity alone! I recently upgraded all of the computer racking infrastructure including new power feeds and dedicated air conditioning for the room that serves as the Computer Center for the Matronics Email Lists. This year I added another rack to house the new MONSTER quad-processor web system that didn't quite fit into the first rack! Here's a composite photo of the List Computer Center before the addition of the second rack: http://www.matronics.com/MattDralle-ListComputerCenter.jpg As you can see, I take running these Lists very seriously and I am dedicated to providing an always-on, 24x7x365 experience for each and every Lister. But building and running this system isn't cheap. As I've stated before, I don't support any of these systems with commercial advertising on the Lists. It is supported 100% through List member Contributions! That means you... and you... and YOU! To that end, I hold a List Fund Raiser each November and ask that members make a small Contribution to support the continued operation and upgrade of this ever-expanding system. Its solely YOUR Contributions that keeps it running! Please make a Contribution today to support these Lists! http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle PO Box 347 Livermore CA 94551-0347 USA (Please include your email address on the check!) Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2006
Subject: Last "Official" Day Of The List Fund Raiser!
Dear Listers, Well, its November 30th and that means three things... 1) Today I am now officially 43 years old... (arg...) 2) It marks that last "official" day of the List Fund Raiser! 3) Its the last day I will be bugging everyone for a whole year! :-) If you use the Lists and enjoy the content and the no-advertising, no-spam, and no-censorship way in which they're run, please make a Contribution today to support their continued operation and upkeep. Your $20 or $30 goes a long way to further the List operation and keep the bills paid. I will be posting the List of Contributors next week, so make sure your name is on it! :-) Thank you to everyone that has made a Contribution so far this year! It is greatly appreciated. List Contributions: http://www.matronics.com/contribution Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 08, 2006
Subject: Matronics Fund Raiser - 2006 List of Contributors
Dear Listers, I would like to thank everyone that made a Contribution in support of the Lists this year! It was really nice to hear all great comments people had regarding the Lists! As I have said many times before, running these Lists is a labor of love. Your generosity during the List Fund Raiser only underscores the great sentiments people have made regarding the Lists. If you haven't yet made a Contribution in support of this year's Fund Raiser please feel free to do so. The nice List gifts will be available on the site for just a little while longer, so hurry and make your Contribution and get your great gift. Once again, the URL for the Contribution web site is: http://www.matronics.com/contribution I would like to thank Andy Gold of the Builder's Bookstore ( http://www.buildersbooks.com ), Paul Besing of Aeroware Enterprises ( http://www.kitlog.com ), Jon Croke of Homebuilt HELP ( http://www.homebuilthelp.com ) and Bob Nuckolls of AeroElectric ( http://www.aeroelectric.com ) for their extremely generous support during this year's Fund Raiser through the contribution of merchandise. These are great guys that support the aviation industry and I encourage each and every Lister to have a look at their products. Thank you Andy, Paul, Jon and Bob!! Your support is very much appreciated! And finally, below you will find a web link to the 2006 List of Contributors current as of 12/7/06! Have a look at this list of names as these are the people that make all of these List services possible! I can't thank each of you enough for your support and great feedback during this year's Fund Raiser! THANK YOU! http://www.matronics.com/loc/2006.html I will be shipping out all of the gifts in the next few weeks and hope to have everything out by the end of the month. In most cases, gifts will be shipped via US Postal Service. Kitlog Pro serial numbers should go out via email this weekend. Once again, thank you for making this year's List Fund Raiser successful! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: ground for starter bendix
Date: Dec 17, 2006
Anyone else had starter problems with LOM? I do need to re wire the ground on the bendix, but the "belt tightener " screw on the supercharger is somewhat a mystery. the LOM engine manual is not real explicit on how to adjust it. bobf ________________________________________________________________________________
Date: Dec 17, 2006
Subject: Re: ground for starter bendix
Which engine do you have? Starting is the weak side of my M332A engine. I understand there may be a larger starter solenoid. Mine has a 30mm diameter. There may be a 34mm diameter starter solenoid. Jim Ayers RV-3 LOM M332A 3 blade MT electric CS propeller In a message dated 12/17/2006 3:46:29 AM Pacific Standard Time, bobf(at)feldtman.com writes: --> Lom-List message posted by: Robert Feldtman Anyone else had starter problems with LOM? I do need to re wire the ground on the bendix, but the "belt tightener " screw on the supercharger is somewhat a mystery. the LOM engine manual is not real explicit on how to adjust it. bobf ________________________________________________________________________________
Date: Dec 17, 2006
On Sunday 17 December 2006 13:09, Jeayers1(at)aol.com wrote: I have a 332B LOM on the glastar. It is a 12 volt system. It appears to me to be a rather small bendix - probably the 30. I clearly have some ground issues for the bendix and am redsigning the grounding wire - trying to use a ground braid strap of copper instead of wire. How do you adjust the "strap" adjustment screw on the top/side of the supercharger. somtimes it feels or sounds like there is somthing binding and that is why the starter doesn't turn it well, and gets hot. Other times it spins great. glad to finally meet another LOM owner! bobf > Which engine do you have? > > Starting is the weak side of my M332A engine. I understand there may be a > larger starter solenoid. Mine has a 30mm diameter. There may be a 34mm > diameter starter solenoid. > > Jim Ayers > RV-3 LOM M332A 3 blade MT electric CS propeller > > In a message dated 12/17/2006 3:46:29 AM Pacific Standard Time, > bobf(at)feldtman.com writes: > > --> Lom-List message posted by: Robert Feldtman > > Anyone else had starter problems with LOM? I do need to re wire the ground > on > the bendix, but the "belt tightener " screw on the supercharger is > somewhat a > mystery. the LOM engine manual is not real explicit on how to adjust it. > > bobf ________________________________________________________________________________
Subject: supercharger tensioner
Date: Jan 02, 2007
My supercharger is staying "ON" when control is turned "OFF"... tensioner belt needs adjusting - should I turn it left to loosen the belt or right to tighten the belt to allow MP to be 29.9 inches when "OFF"? Four or five turns? bobf ________________________________________________________________________________
Date: Jan 05, 2007
Subject: Re: supercharger tensioner
The supercharger tension needs to be loosen. I tried adjusting the supercharger tension when the starter didn't seem to stay engaged. I have the 30mm starter solenoid. Apparently I need the 34mm starter solenoid. I have a 12 volt system. Regards, Jim Ayers In a message dated 01/02/2007 3:53:08 AM Pacific Standard Time, bobf(at)feldtman.com writes: --> Lom-List message posted by: Robert Feldtman My supercharger is staying "ON" when control is turned "OFF"... tensioner belt needs adjusting - should I turn it left to loosen the belt or right to tighten the belt to allow MP to be 29.9 inches when "OFF"? Four or five turns? bobf ________________________________________________________________________________
Date: Jan 05, 2007
On Friday 05 January 2007 10:02, Jeayers1(at)aol.com wrote: I did loosen it - and it strted fine - two props! now, I need to adjust it because the supercharge stays "ON" delivering 37 inches MP even when the supercharger control is put in the "OFF" position. I know I can just leave the SC ON and drop the MP back with the throttle, but I want to be able to turn it off properly. The glastar cowling is not too bad to take off, but it is requiring some on and offs -- cause to check the full throttle manifold pressure, I cannot hold the plane still - it skids on the brakes! The only way is to taxi out and do a takeoff with full throttle.... I'll let you know when I get it figured out. I am also tying to get hold of Joe Krybus at Santa Paula Airport - he apparently is a LOM expert and see if he has any hints. thanks! bobf > The supercharger tension needs to be loosen. > > I tried adjusting the supercharger tension when the starter didn't seem to > stay engaged. I have the 30mm starter solenoid. Apparently I need the > 34mm starter solenoid. I have a 12 volt system. > > Regards, > Jim Ayers > > In a message dated 01/02/2007 3:53:08 AM Pacific Standard Time, > bobf(at)feldtman.com writes: > > --> Lom-List message posted by: Robert Feldtman > > My supercharger is staying "ON" when control is turned "OFF"... tensioner > belt > needs adjusting - should I turn it left to loosen the belt or right to > tighten the belt to allow MP to be 29.9 inches when "OFF"? Four or five > turns? > > bobf ________________________________________________________________________________
Date: Jan 22, 2007
On Friday 05 January 2007 10:02, Jeayers1(at)aol.com wrote: Jim - starting good now - tensioner adjusted, just a little more tweaking. down to 33 inches in off position, still 37 inches supercharge on. I am just about due my 50 hr engine inspection, so will be draining oil, checking comperssions, and retorquing bolts per the manual. might get to some of it this weekend. Seems to miss a little bit at less than 25 inches MP in cruise - might need the injectors cleaned out. Sat for a while before the builder got it running enough to get the phase I sign off. runs okay, but might be smoother at lower power settings. High power settings are really smooth and powerful. so far - pretty happy with the engine! bobf > The supercharger tension needs to be loosen. > > I tried adjusting the supercharger tension when the starter didn't seem to > stay engaged. I have the 30mm starter solenoid. Apparently I need the > 34mm starter solenoid. I have a 12 volt system. > > Regards, > Jim Ayers > > In a message dated 01/02/2007 3:53:08 AM Pacific Standard Time, > bobf(at)feldtman.com writes: > > --> Lom-List message posted by: Robert Feldtman > > My supercharger is staying "ON" when control is turned "OFF"... tensioner > belt > needs adjusting - should I turn it left to loosen the belt or right to > tighten the belt to allow MP to be 29.9 inches when "OFF"? Four or five > turns? > > bobf ________________________________________________________________________________
From: Barracuda Spam Firewall <postmaster(at)matronics.com>
Subject: **Message you sent blocked by our bulk email filter**
Date: Feb 10, 2007
Date: Feb 10, 2007
Date: Mar 07, 2007
From: Klaus Dietrich <klaus.dietrich(at)oracle.com>
Subject: Buzzer
Hi, flying a LOM 332 AK powered Bucker since two years, I'm just wondering who else is on the list? I have now 200hrs on the engine and so far all is fine (except one engine stop inflight, due to a sticking gravity valve after aerobatics....) Have cleaned the contacts of my buzzer with the result that it's not working anymore; any idea how to properly service and adjust the buzzer? And do I have to do any service of the magnetos yet? Thanks Klaus (Vienna) -- Klaus Dietrich Oracle Financing EMEA Tel/Fax: +43 1 33 777 825 http://www.oracle.com/financing ________________________________________________________________________________
Date: Mar 07, 2007
Subject: Re: Buzzer
Klaus - I have the 332B engine - 50 hrs on a glastar. You can get the buzzer from moraviation.com in Canada or probably from the factory in Prague - you are so close. You have already cleaned the points on the contact - there is only a capacitor and a coil in there. MAke sure all the connection are solid for the P leads going to the buzzer. It is more likely a connection problem! There is a procedure to check the current draw through the buzzer points, but don't let it be "on" for more than a few seconds, or it might burn it out. Do you have the engine manual? So far I am happy with the LOM engine here in the USA. We have no LOM mechanics in Texas, so I guess I will have to do most of the work! Besten gluck! bobf Klaus Dietrich wrote: > Hi, > > flying a LOM 332 AK powered Bucker since two years, I'm just wondering > who else is on the list? > I have now 200hrs on the engine and so far all is fine (except one > engine stop inflight, due to a sticking gravity valve after > aerobatics....) > > Have cleaned the contacts of my buzzer with the result that it's not > working anymore; any idea how to properly service and adjust the buzzer? > And do I have to do any service of the magnetos yet? > > Thanks > Klaus (Vienna) > -- > > Klaus Dietrich > > Oracle Financing EMEA > Tel/Fax: +43 1 33 777 825 > > http://www.oracle.com/financing > > > > > > > * > > > * ________________________________________________________________________________
Date: Mar 07, 2007
Subject: Re: Buzzer
Hi Klaus, I installed the "Slick Start" in place of the buzzer. It is a solid state unit, so there is no maintenance. Aircraft Spruce sells them for $349.95 US. I think they were about $270 US, when I bought mine. I have a M332A engine in a RV-3. Regards, Jim Ayers Newbury Park, California (805) 795-5377 In a message dated 03/07/2007 1:06:44 AM Pacific Standard Time, klaus.dietrich(at)oracle.com writes: Hi, flying a LOM 332 AK powered Bucker since two years, I'm just wondering who else is on the list? I have now 200hrs on the engine and so far all is fine (except one engine stop inflight, due to a sticking gravity valve after aerobatics....) Have cleaned the contacts of my buzzer with the result that it's not working anymore; any idea how to properly service and adjust the buzzer? And do I have to do any service of the magnetos yet? Thanks Klaus (Vienna) -- _ Klaus Dietrich Oracle Financing EMEA Tel/Fax: +43 1 33 777 825 http://www.oracle.com/financing_ (http://www.oracle.com/financing)
AOL now offers free email to everyone. Find out more about what's free from AOL at http://www.aol.com. ________________________________________________________________________________
Date: Mar 28, 2007
Subject: New to the list.
Hi All. I'm a final year studnet living in S.Africa. Ive heard this and that abt the LOM engine. I hope to start building an a/c next year, so getting an engine installed is only much further down the line. Are there any interesting sites on the web about the LOM used in homebuilds (in addition to Moritavias's site)? How many people on the list? Martin ________________________________________________________________________________
Date: Mar 28, 2007
Date: Mar 28, 2007
Subject: Re: New to the list.
Hi Martin, I monitor this list. Regards, Jim Ayers RV-3 with a LOM M332A engine and a 3 blade MT electric CS propeller. In a message dated 03/28/2007 4:26:36 AM Pacific Standard Time, longwayround(at)vodamail.co.za writes: --> Lom-List message posted by: Martin Hi All. I'm a final year studnet living in S.Africa. Ive heard this and that abt the LOM engine. I hope to start building an a/c next year, so getting an engine installed is only much further down the line. Are there any interesting sites on the web about the LOM used in homebuilds (in addition to Moritavias's site)? How many people on the list? Martin ________________________________________________________________________________
Date: Mar 30, 2007
Here is a site detailing installation of a LOM M332 in a Bucker Jungmeister: http://www.bucker.info/ click on "LOM Installation" Chris --- Martin wrote: > > > Hi All. I'm a final year studnet living in S.Africa. > Ive heard this and that abt the LOM engine. I hope > to start building an a/c next year, so getting an > engine installed is only much further down the line. > > Are there any interesting sites on the web about the > LOM used in homebuilds (in addition to Moritavias's > site)? > How many people on the list? > > Martin > > > browse > Subscriptions page, > FAQ, > http://www.matronics.com/Navigator?Lom-List > > Web Forums! > > > > > Looking for earth-friendly autos? Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center. http://autos.yahoo.com/green_center/ ________________________________________________________________________________
Date: Jul 10, 2007
Subject: Re: Lom-List Digest: 0 Msgs - 07/08/07
I have been trying to match a fixed pitch prop to my LOM M332B engines for the last 4 months without much success. I started with 79" pitch which gave a static RPM of 1800 then to 75" pitch which gave 2000 static RPM and now I have 65" pitch for just under 2100 RPM. It appears that this engine has much lower torque than an equivalent Lycoming/Continental. Does anyone have any experience with fixed pitch props and LOM engines? Or alternatively any experience with CS electronically controlled wooden/composite props with LOM engines? Getting desparate,hope someone can help. Malcolm Ducker Speedtwin UK Quoting Lom-List Digest Server : > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Lom-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Lom-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-07-08&Archive=Lom > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-07-08&Archive=Lom > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Lom-List Digest Archive > --- > Total Messages Posted Sun 07/08/07: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > ________________________________________________________________________________
Date: Jul 21, 2007
Subject: Re: Lom-List Digest: 0 Msgs - 07/20/07
Has anyone on the LOM list replaced the ignition wires to reduce radio noise (RFI)? I'm thinking about doing that and converting to automotive spark plugs as well. Thoughts? bobf On 7/21/07, Lom-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Lom-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Lom-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-07-20&Archive=Lom > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-07-20&Archive=Lom > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Lom-List Digest Archive > --- > Total Messages Posted Fri 07/20/07: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > ________________________________________________________________________________
Date: Sep 08, 2007
Subject: New Realtime Spell Checker Added To Matronics Forums!
Dear Listers, Today 9/8/2007 I have added a new real-time spell checker function to all of the BBS Forums at Matronics. When you reply or create a new message on the Forums, you will notice that misspelled words will be high-lighted in yellow. If you left-click on the word, you will be prompted with a drop-down list of suggested spellings. http://forums.matronics.com Enjoy! Matt Dralle Matornics Email List and Forum Administrator ________________________________________________________________________________
Date: Oct 01, 2007
Subject: New to LOM
Hello all, I have been watching the list for a while and see very little activity. just wondering if anyone is out there? I just purchased a M332A powered aircraft and am wondering how the product support has been lately? I am keenly aware of the problems in the past, but recently all seems to be quite. Is this because everyone gave up on them or have they improved? I am aware of the fact that I will have to be the expert on the motor, and I don't mind tickering. The a/c is strickly for fun so never has to fly, I can wait around for parts if need be, just as long as they can be gotten eventually. Thanks fo any and all input, Luke in Wisconsin ________________________________________________________________________________
Date: Oct 01, 2007
Subject: Re: New to LOM
My supercharger band broke on the way to OSH in my Glastar. Hand propped it to start, flew back home and got a band - A&P replaced it all is AOK again. Petr Prokop at LOM in Prague is great. He responds quickly to emails. is very literate in english - they really do a good job of support - and yes you will have to become your own expert. I called Joe Krybus in California and he said no one in Texas knew about LOMs.... apparently a Mr Rundle in Louisiana does bobf On 10/1/07, luke wuest wrote: > > > Hello all, > > I have been watching the list for a while and see very little activity. > just wondering if anyone is out there? > > I just purchased a M332A powered aircraft and am wondering how the product > support has been lately? I am keenly aware of the problems in the past, but > recently all seems to be quite. Is this because everyone gave up on them or > have they improved? > > I am aware of the fact that I will have to be the expert on the motor, and > I don't mind tickering. The a/c is strickly for fun so never has to fly, I > can wait around for parts if need be, just as long as they can be gotten > eventually. > > Thanks fo any and all input, > Luke in Wisconsin > > ________________________________________________________________________________
Date: Oct 01, 2007
I have two projects that will be perfect for the LOM engines. I have been reluctant to commit to buying a LOM because there doesn't seem to be a lot of info re: operating, amintaining, and just plain experiences with them. The engines seem to be well-designed and well put together but it sure would be nice to know how they are with hours on them. Luke, what airplane do you have? I heard about Joe Krybus before and that he has engineered a number of LOM installations on Buckers. I would imagine he has a degree of familiarity and experience with these engines. Do you have his snail mail address? Thanks, Chris --- luke wuest wrote: > > Hello all, > > I have been watching the list for a while and see > very little activity. just wondering if anyone is > out there? > > I just purchased a M332A powered aircraft and am > wondering how the product support has been lately? I > am keenly aware of the problems in the past, but > recently all seems to be quite. Is this because > everyone gave up on them or have they improved? > > I am aware of the fact that I will have to be the > expert on the motor, and I don't mind tickering. The > a/c is strickly for fun so never has to fly, I can > wait around for parts if need be, just as long as > they can be gotten eventually. > > Thanks fo any and all input, > Luke in Wisconsin > > > > browse > Subscriptions page, > FAQ, > http://www.matronics.com/Navigator?Lom-List > > Web Forums! > > > > > Pinpoint customers who are looking for what you sell. http://searchmarketing.yahoo.com/ ________________________________________________________________________________
Date: Oct 14, 2007
Robert, For my files and just in case, would you send me the email addr of Petr Prokop please. The LOM in the Spitfire is running well but for ocassionally dropping a plug in start-up/run-up. Fortunately I put a cylinder temp probe on all six so can pin it down quickly. I wonder, to all on this chat, with the "shower of sparks" device, is it necessary to have the plug gaps so small? Could I help the above problem with wider plug gaps, say 22 thou? Any other sugestions? Dave Austin 601HDS - 912, Spitfire Mk VIII ________________________________________________________________________________
Date: Oct 14, 2007
You'd have to ask the factory, but 0.017 is what they call for. I had thought about maybe converting to autoplugs, but wanted to use Bosch iridiums and you can't adjust those plugs like a regular boot type. I didn't. Just put new plugs in and it runs great. I am showing the LOM/Glastar to a friend who may buy it from me. It is not IFR and I really wanted that in an airplane - and dodn't wnat to spend the money to build it to IFR myself although I could. Flew a Cherokee 235 today. Samy airspeed as the Lom, but twice the fuel burn! 14 gals per hr vs 7 gals per hour. You are smart to have the four cylinder probe system! Petr.Prokop(at)lompraha.cz --A nice guy! Joe Krybus doesn't have an email. He is somewhat curt on the fone, but every word is like gold.He sent us detailed engineering drawings on the engine - a great guy too! bobf On 10/14/07, Dave Austin < daveaustin2(at)primus.ca> wrote: > > Robert, > For my files and just in case, would you send me the email addr of Petr > Prokop please. > The LOM in the Spitfire is running well but for ocassionally dropping a > plug in start-up/run-up. Fortunately I put a cylinder temp probe on all six > so can pin it down quickly. > I wonder, to all on this chat, with the "shower of sparks" device, is it > necessary to have the plug gaps so small? Could I help the above problem > with wider plug gaps, say 22 thou? Any other sugestions? > Dave Austin 601HDS - 912, Spitfire Mk VIII > > ________________________________________________________________________________
Date: Nov 01, 2007
Subject: November is Matronics Email List Fund Raiser Month!
Dear Listers, You've probably noticed that there are no banner ads or pop-up windows or spam from any of the List and Forum services at Matronics. These include, for example: The Email List Postings - http://www.matronics.com/listbrowse The Email List Forum Site - http://forums.matronics.com The List Wiki - http://wiki.matronics.com The List Search Engine - http://www.matronics.com/search This is because I have always enjoyed a List experience that was completely about the sport we enjoy - airplanes - and not about advertising! But running a high performance, highly available service like this isn't free and a fair amount of money in terms of computer upgrades, business-class Internet connectivity, and electricity. Consequently, many similar sites turn to advertising to support these costs. Advertising that you have to look at each and every time you read an email message or browse the their web site. Rather than subject my List community to another constant commercial bombardment, I have chosen to hold a PBS-like fund raiser each year in November to support the continued operation and upgrade of the List services. It's solely through the Contributions of List members that the Lists and Forums continue to be possible! During the month, I will be sending out a Fund Raiser reminder message every few days and I ask for your patience and understanding during the month throughout these regular messages. Think of them as PBS' Pledge Breaks... :-) To minimize the impact of the Fund Raiser on the List community, I implemented a new feature late last year specifically related to making Contributions. If you are an Email List subscriber, once you make a Contribution using the online web site, you will no longer receive the email from me regarding the Fund Raiser! There are a couple of exceptions to this, however. If someone replies to a Contribution message I've sent, you might receive that. Additionally, the messages will always be posted to the Forums site. To a first order, however, once you make a Contribution, you won't get my email messages about the Fund Raiser for the rest of the month. For Contributions by check, the squelch will take effect once the check is received. There is a whole new line up of really great Contribution gifts this year! When you make a qualifying Contribution, you can select one of the many free gifts that are available during the Fund Raiser. These gifts are provided through the generous support of a number of our industry's leading supporters including: Bob Nuckolls - AeroElectric - http://www.aeroelectric.com Andy Gold - Builder's Bookstore - http://www.buildersbooks.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com Please visit these guy's respective sites, as they have some great products to offer and are generously supporting the Matronics List Fund Raiser. You can make your List Contribution using any one of three secure methods this year including using a credit card, PayPal, or by personal check. From the Contribution site, you can select any one of this year's free gifts with a qualifying Contribution amount. The Contribution page is pretty loooonnnnng this year in order to list great selection of great gifts available so be sure to scroll all the way to the bottom of the web page to see everything that's available! Please make a List Support Contribution: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous support! Your Contributions truely keep this operation afloat! Thank you, Matt Dralle Matronics Email List Forum Administrator ________________________________________________________________________________
Date: Nov 04, 2007
Subject: List Fund Raiser
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. I've got a bunch of really nice incentive gifts this year. There's really something for everyone! Please make a Contribution today: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2007
Subject: What Listers Are Saying...
November is Matronics List Fund Raiser month and a number people been sending some really nice comments regarding the Lists. I thought I'd share a few below. The Lists are completely supported by your Contributions. All of the bills for new hardware, connectivity, and electricity are paid by the generous support of the List members. Please make your Contribution today to support the continued operation of the List and Forums: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ================= What Listers Are Saying ================ Flying and building is much safer with this List!! Robert D. Thanks for having and maintaining such a great resource to all of us builders and flyers. Wayne E. Love the fact that you haven't caved to advertising! Peter J. ..a great resource!! Robert C. Not building at the moment, but the Lists keeps me right up to date with what's going on. Chris D. The web forum has been running great. James O. I enjoy this [List] site very much... Paul C. This is a great list! Albert G. ..a valuable resource! Roger C. I am deployed to Pakistan right now, and being able to go on-line and keep up with the aircraft discussions helps keep the aircraft building dream alive in my mind! Gregory C. ..fantastic service! Roger M. ..clearly a work of passion! Mike C. It is a great service to us! Kevin C. The list is a wonderful resource... Ralph O. [The Lists] have been the single greatest resource in building my RV-9A and now my RV-10. Albert G. ..a valuable and always improving service. Dick S. STILL THE BEST BARGAIN AROUND!! Owen B. ..such a valuable tool. Jon M. [The Lists] have been an invaluable resource for me as a Zenith homebuilder. David G. The opportunity to meet (on line at least) many other interesting builders and to make some new friends is truly appreciated. Albert G. ________________________________________________________________________________
Date: Nov 09, 2007
Subject: If You Got This Email, You Haven't Made A Contribution Yet!
:-) Dear Listers, If you received this particular Matronics List Email message, its because you haven't yet made a Contribution to support your Lists! Implemented for the first time last year, the Matronics system selectively sends out the Contribution messages to those that forgot to whip out the 'ol credit card this year to support the continued operation and upgrade of the Matronics Email Lists! Don't you wish PBS worked that way? :-) You heard that right. Once you make your Contribution, these support requests messages during November will suddenly stop coming to your personal email inbox! I wanted to implement something like this for a number of years, but it was always such a daunting task to modify the back-end List processing code, that I just kept putting it off. Finally last year, I just decided to bite the bullet and put the code-pounding time it to make it work. A few days later, bam! A working system! I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site like this. It also goes to pay for the commercial-grade Internet connection and to pay the rather huge electric bill to keep the computer gear running and the air conditioner powered up. I run ALL of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercialism that is so prevalent on the Internet these days and I particularly don't want to have it on my Email List site. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator [Please note the following regarding the selective posting system. There are certain circumstances where you might still see a Contribution related message. These situations include if someone replies to one of the messages, or when using the List Browse feature, or when accessing List message via the Forum. Since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 11, 2007
Subject: Post Mortem - Matronics List Pummeled By Spam...
Dear Listers, Over a 3-day period, Thursday 11/8 though Saturday 11/10, the Matronics Lists were pummeled with over 450,000 spam emails causing posting delays and a few duplicate messages. Yeah, I really said nearly half a million spams! The good news is that I don't believe a single one of them actually made it to the Lists thanks to the aggressive List filtering code and the Barracuda spam filter. The bad news was that it caused quite a back log of email messages starting Friday and continuing until late Saturday when I noticed that delivery seemed a bit sluggish. By about 11pm on Saturday night, I had managed to get the backlog cleared out of the spam filter by temporarily adjusting some of the filtering. A check of the queues this morning, and everything looks like its working great and there are no incoming filtering delays and spam levels appear to be back to "normal". There were a number of people asking what was going on, so I thought that I'd send out a follow up post mortem on the event... November is the annual List Fund Raiser. Your contribution directly enables me to buy systems like the Barracuda spam filter that keep the List free of that garbage. Please make a contribution to support your Lists! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 13, 2007
Date: Nov 15, 2007
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least 0 or 0 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some lame magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support the Lists? Contribution Page: http://www.matronics.com/contribution Again, I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 18, 2007
Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! And pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 20, 2007
Subject: [Please Read] Why I Have A Fund Raiser...
Dear Listers, Each year I like to explain why I have a Fund Raiser and also take the opportunity to express why I think the List Services here provide a superior experience over the commercial equivalents. I use the List Fund Raiser each year to offset the costs involved with running a high performance email list site such as this one. With the annual support from the List members through the PBS-like Fund Raiser, I have found I can run the entire site without having to inflect any of the members with those annoying banner ads flashing up all the time trying to sell little-blue-pills or other garbage nobody wants or needs. From the comments I've received over the years regarding the Lists, the great majority of the members really appreciate the non-commercialism of my List systems and don't mind my 'go-team-go' banter once a year during November to encourage members to support the Lists. I believe that the Lists services that I provide here offer many benefits over the commercial equivalents in a number of ways. The first feature I believe to be significant is that you cannot receive a computer v*rus from any of these Lists directly. Each incoming message is filtered and dangerous attachments stripped off prior to posting. I also provide a Photo and File Share feature that allows members to share files and bitmaps with other members and everyone can be assured that these files will be prescanned for any sort of v*rus before they are posted. More recently, I have enabled limited posting of a number of file formats including pictures and PDFs. Another very important feature of this system in my opinion is the extensive List Archives that are available for download, browsing, and searching. The Archives go all the way back to the very beginning of each List and with the very fast Search Engine, the huge size of some of the Archives is a non-issue in quickly finding the data you're looking for. And added just a couple of years ago is the new Email List Forum that allows members who prefer the Web BBS-style of List interaction. The beauty of the new List Forums is that they contain the exact same content that is distributed via email. Messages posted via email are cross-posted to the respective Forum and vice versa. The Forums also allow for another convenient method of sharing pictures and other files (http://forums.matronics.com ). Additionally, added recently is the List Wiki that allows members to build their own "Online List Encyclopedia" of sorts, documenting various aspects of their project for all to share ( http://wiki.matronics.com ). I've been running email Lists and services under the matronics.com domain since about 1989 starting with RV-List and 30 guys I knew and who where also building RVs. It has grown into nearly 70 different aviation-related Email Lists and an associated web site that receives over 34,000,000 hits each year!! Additionally, the List Email system forwarded well over 77,000 postings last year, accounting for an unbelievable 33,000,000 (yes, that's 33 MILLION) email messages delivered to Matronics List subscribers! I think there's a lot of value in supporting a service that has gone the long haul and is still providing and improving a high quality service all _without any advertising budget_! I have to admit running these Lists is a labor of love and I hope it shows in the quality of the experience that you receive when you get a List Email Message, Search the Archives, use the List Browser, or surf the Forums and Wiki sites. The Lists will be here for a long time to come. If you just want to lurk a while for free, that's great and I encourage you to do so. If you use, appreciate, and receive value from these Lists, then please support them during the Annual List Fund Raiser! List Contribution Web Site: http://www.matronics.com/contribution Thank you, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 22, 2007
Subject: What Are You Thankful For...?
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite kind of comments is when write to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 24, 2007
Subject: Comments
Dear Listers, Below are a few more of the nice comments Listers have been making along with their Contributions in support of the Lists this year. Please make your Contribution today to support the continued operation and upgrade of these services. Remember, there is _no advertising budget_ to keep these Lists funded. It is solely through your generosity that they continue. Please make a Contribution: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List and Forum Administrator ------------------------------What Listers Are Saying------------------------------ The list has been invaluable in the building of my Zenith CH701. George R Thanks for keeping the lists a non-commercial venue for us to gather and share knowledge. Neal G What a fantastic resource! Ralph C It's a pretty cheep troubleshooting tool with and unlimited resource of personal knowledge. Bruce G A full house of Info & Ideas... Ellery B I really enjoy the Piet list. Steven D The Lists are an indispensable resource for those of us building OBAM aircraft. Bret S ..a great service. Frank D ..all in all it is a great resource if you ask specific questions. Richard S Your list has really helped me in my first build. Michael W Always a pleasure to support this great resource... Richard W I enjoy the lists very much, they are very beneficial. Bob L Great place to chat with other builders and Flyers. Ellery B Your lists are a great service to builders and owners! Richard D A real good place for someone that is starting to get interested into flying without investing any money at first. Ellery B The list has been an great help to my building process. David B I'm close to finishing my Zenith 601 thanks to you and the Zenith List. Jeff D ________________________________________________________________________________
Date: Nov 26, 2007
Subject: Make Sure You're Listed! List of Contributors Published Dec
1! Dear Listers, The List of Contributors (LOC) is just around the corner! On December 1st I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. As a number of people have pointed out in their Contribution comments, these Lists seems at least as valuable of a building/flying/recreating tool as a typical your magazine subscription! And how interactive is a magazine, after all? Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle PO Box 347 Livermore CA 94551-0347 USA (Please include your email address on the check!) I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2007
Subject: [Please Read] What are "The Lists" and Who's This Matt Dralle?
Dear Listers, Who is Matt Dralle and what exactly are these Lists? Well, I've been working in the information technology industry for nearly 25 years primarily in computer networking design and implementation. I have also done extensive work in web development and CGI design during that time, along with some embedded system development as well. I started the Matronics Email Lists back in 1990 with about 30 fellow RV builders from around the world. Since that time, I have added 63 other kinds of aircraft related Lists to the line up and numerous other List related services such as the Forums, Wiki, Archives and Search Engine just to name a few. For flexibility and reliability, I have chosen to run all of my own servers here locally. Other List-related systems include a 1 Gigabit, fully switched network infrastructure, a commercial-grade Netscreen firewall, a Barracuda spam filter, a local T1 Internet router, and a commercial-grade business T1 Internet connection with full static addressing. The computer servers found here include a quad-processor Xeon Linux server for List web services, a dual-processor Xeon Linux system dedicated to the email processing List functions, and another P4 Linux system serving as a remote storage disk farm for the archives, databases, and for an on-line hard drive-based backup system with 3.2 Terra Bytes of storage! This entire system is protected by three large, commercial-grade uninterrupted power supply (UPS) systems that assure the Lists are available even during a local power outage! Speaking of power, imagine how much electricity it takes to run all of these systems. One month last Summer, I had a staggering $1368 bill for electricity alone! I recently upgraded all of the computer racking infrastructure including new power feeds and dedicated air conditioning for the room that serves as the Computer Center for the Matronics Email Lists. Last year I added another rack to house the MONSTER quad-processor web system that didn't quite fit into the first rack! Here's a composite photo of the List Computer Center before the addition of the second rack: http://www.matronics.com/MattDralle-ListComputerCenter.jpg As you can see, I take running these Lists very seriously and I am dedicated to providing an always-on, 24x7x365 experience for each and every Lister. But building and running this system isn't cheap. As I've stated before, I don't support any of these systems with commercial advertising on the Lists. It is supported 100% through List member Contributions! That means you... and you... and YOU! To that end, I hold a List Fund Raiser each November and ask that members make a small Contribution to support the continued operation and upgrade of this ever-expanding system. Its solely YOUR Contributions that keeps it running! Won't you please take a moment to make a Contribution to support these Lists! http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle PO Box 347 Livermore CA 94551-0347 USA (Please include your email address on the check!) There are some great gifts available with qualifying Contribution levels too! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2007
Hello All, Sorry it took awhile, I have been out of the country for a couple of weeks. I bought the M332A powered Hatz built by Lorin Wilkinson in the 1990's. It has a 28 volt engine system, with a Narco Voltage Converter to 12 volt for the rest of the a/c. Knock on wood, so far it is running very well. Starts on the second blade with the SlickSTART magneto booster. Has anyone put a oil filter on their engine or just the screens? An thoughts? Also what fuel are you burning, 100LL or autogas? Thanks for the info, Luke -------- Luke Wuest Read this topic online here: http://forums.matronics.com/viewtopic.php?p=148870#148870 ________________________________________________________________________________
Date: Nov 27, 2007
I put an oil filter on the return line to the oil tank. Was using autofuel 87 octane, but since it now contains 10% ethanol I decided not to risk it and use Super grade Shell which so far has no ethanol. (Canada). I'd be interested on other people's comments on this one. Dave Austin 601HDS - 912, Spitfire Mk VIII - LOM 337CE ________________________________________________________________________________
Date: Nov 27, 2007
The builder of my glastar put a auto type oil filter - spin on type on my 332B. The oil seems very clean - absolutely nothing in the screens when I have check them at 40 hrs and 85 hrs (CI) - I don't burn autofuel due to 1.) the risk of getting ethanol (I don't care about the engine - it is the unkown gaskets and O-rings that couldd issolve!) and 2.) burning only 7 gals per hr, I don't mind the exorbitant av gas prices - better than the 30 gal per hours in my twin commander! Do you guys have oil drip problems? and radio noise (I suspect the spark plug wires) bobf glastar 125GS On 11/27/07, Dave Austin wrote: > > > I put an oil filter on the return line to the oil tank. > Was using autofuel 87 octane, but since it now contains 10% ethanol I > decided not to risk it and use Super grade Shell which so far has no > ethanol. (Canada). > I'd be interested on other people's comments on this one. > Dave Austin 601HDS - 912, Spitfire Mk VIII - LOM 337CE > > ________________________________________________________________________________
Date: Nov 27, 2007
I have a Lom M332A on my RV-3.? It came as a 28 volt system, but I?converted it to a 12 volt system.? I installed the SlickStart in place of the LOM vibrator. I had oil temperature problems from the beginning.? I installed a oil cooler and an oil filter between the engine outlet and the oil tank.? The oil temperature dropped 25 degrees C.? The oil temperature now?stays in the middle of the green arc in a continuous climb from sea level to 15,000' AGL.? Before the addition of a small oil cooler, I couldn't climb above 11,000'. I use 100LL. Regards, Jim Ayers -----Original Message----- From: lwuest <lukester(at)earthlink.net> Sent: Tue, 27 Nov 2007 9:02 am Subject: Lom-List: Re: New to LOM Hello All, Sorry it took awhile, I have been out of the country for a couple of weeks. I bought the M332A powered Hatz built by Lorin Wilkinson in the 1990's. It has a 28 volt engine system, with a Narco Voltage Converter to 12 volt for the rest of the a/c. Knock on wood, so far it is running very well. Starts on the second blade with the SlickSTART magneto booster. Has anyone put a oil filter on their engine or just the screens? An thoughts? Also what fuel are you burning, 100LL or autogas? Thanks for the info, Luke -------- Luke Wuest Read this topic online here: http://forums.matronics.com/viewtopic.php?p=148870#148870 ________________________________________________________________________ ________________________________________________________________________________
Date: Nov 27, 2007
Bob, Yes to both of your questions. Dave Austin 601HDS - 912, Spitfire Mk VIII ________________________________________________________________________________
Date: Nov 27, 2007
Dave - I figured - I bought some special Magnecor spark plug wire, and figured out what kinda auto spark plug would fit - I just can't figure out how to take the spark plug wire off the magnetoes. They seem to be rather tightly connected or pushed up in there. Might end up emailing Czechoslovakia..... I broke the supercharger band and had to hand prop start it on the way to Oshkosh -- they were very helpful in getting me a new band and my A&P put it on. All fixed now. If I get it fixed so it doesn't make so much RFI on the radio - I wil put a note on the LOM thread here. Oil dripping I can live with. bobf On 11/27/07, Dave Austin wrote: > > Bob, > Yes to both of your questions. > Dave Austin 601HDS - 912, Spitfire Mk VIII > > * > > * > > ________________________________________________________________________________
Date: Nov 28, 2007
Subject: Wow! A Ton of Comments!
Dear Listers, I've been getting a ton of great comments from Listers along with their List Support Contributions lately! I've shared a bunch more below. Please read over some of them and see what your fellow Listers think of the Lists and Forums. There are just a couple more days left before the official end of this year's Fund Raiser. Please make a Contribution today to support the continued upgrade and operation of these services. There are still lots of awesome gifts available, so browse the extensive selection and pickup a nice item along with your qualifying Contribution. http://www.matronics.com/contribution Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator ----------- What Listers Are Saying About The Lists ----------- In the big picture, you are most certainly saving lives. The fact that you do it at a very good level of service, quality, and simplicity is just icing on the cake. We all owe you a debt of gratitude. Bruce M Can't go a single day without reading my lists. Even when I am overseas. Terry W Best list ever. No comparison. Johann J I get the digest for the two lists I subscribe to each morning -- they go great with my coffee! I can't tell you how much I've learned from this great service... Mark S ..great lists, best on the Net! Robert S It is very nice to enjoy a SPAM free list. Ken L You run a great list. Makes a builder feel like there's lots of help out there for the asking, and it's appreciated. Steve T The list is a very valuable resource. Thomas S You run a good list. James G Thanks for a great forum. Jimmy Y Thanks for a well-maintained list(s). Michael M Great job! Worth every penny! Stephen T Helps me learn and think about issues I didn't know I didn't know. Martin H I find the list very useful... Robert F What you do provides me with daily contact with a passion of my life, aviation. Wendell M ..the list it is very valuable information. Dwayne H ..a great service to homebuilders. Andrew H I have learned quite a lot from reading the Forums. I have been reading at the forum pages and I like the way it works. Ron L [The List] makes a builder feel like there's lots of help out there for the asking, and it's appreciated. Steve T The list service many purposes, not the least of which is motivation to join my fellow RVer in completing my project and getting in the air. John S Thanks for running a great site. Its simplicity is its greatness. Don't know how I would have been successful without it. Timothy F ..terrific service to experimental and general aviation. James F You have a well run operation. I am happy to support what you do. Mark S A wonderful service to the GA community. David M Great list - let's keep it ad-free! Ben C They have been of great help, learning and friendship for all the members Worldwide. Great job of yours, a little idea that grew really big and wonderful. Gary G ..a thoroughly enjoyable and informative List. John W A GREAT LEARNING TOOL!! Dwayne Y This is a very well-run list and it is a valuable resource for the Pietenpol enthusiast. Graham H Thanks for running this great site - helps those of us on the east of the pond keep in touch. Malcolm H Thanks for the major contribution to my continuing education program. Oldbob S I'm just getting started in the building process & find Matronics to be the most valuable site. Scott D Without the information and encouragement from the listers my project would have been sitting in the corner of my shop collecting dust long ago. Now it's almost ready for final assemble and covering. Edward G Great List. No Ads, just RV-10 builders. Keep it going. Rick E Wonderful source of info for building & flying... Graham H The Yak-list is a superb single source to get answers to questions on the operation of these aircraft. Craig W This list is valuable to everyone and your hard work is very much appreciated. Jim S ________________________________________________________________________________
Date: Nov 29, 2007
Subject: Just Two Days Left...
Dear Listers, There are just a couple days left for this year's List Fund Raiser. Over all, participation has been good, but things have been pretty slow this week for some reason. If you've been putting off making your Contribution until the last minute, this is it! The last minute, that is... :-) Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Please make a Contribution today! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2007
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, Its November 30th and that means a couple of things. Its my 44th birthday for one, but I'm trying to forget about that... But, it also means that its that last official day of the Matronics Email List Fund Raiser! If you been drooling over one of the really sweet free gifts that are available this year with a qualifying Contribution, then now is the time to jump on one!! If you've been meaning to make a Contribution, but just keep putting it off, then now is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! Rather than the guy that, er, ah, forgot (or whatever)... :-) I want to thank everyone that has so generously made a Contribution so far this year in support of our Lists. It is your generosity that keeps this operation a float and I don't ever forget it. Hopefully everyone will feel the same. The List Contribution page is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Thank you all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 03, 2007
Subject: Slick start on LOM
After 100 hrs, my shower of sparks has started to act up - it is mechanical, but I hate to mess with cleaning and bending the spring -- In the past some have posted about adding a slick start - Any suggestion as to the pin out for the magneto-slick start hook up?. Seems my shower of sparks has a voltage in, a lead to the start-magneto ground switch and a lead to the p lead of the right magneto. I doubt the instructions will talk about the LOM so I thought I'd ask early, even before A/C spruce gets me the slick start! Thanks in advance - bobf 125GS glastar/LOM 332B ________________________________________________________________________________
Date: Dec 04, 2007
Subject: Re: Slick start on LOM
I am not the person that installed it on my M332A, but I will check out the wiring and post in a day or three. Luke Wuest ________________________________________________________________________________
Date: Dec 04, 2007
thanks! bobf On 12/4/07, luke wuest wrote: > > > I am not the person that installed it on my M332A, but I will check out > the wiring and post in a day or three. > Luke Wuest > > ________________________________________________________________________________
Date: Dec 04, 2007
Date: Dec 06, 2007
Subject: Matronics List Fund Raiser - 2007 List of Contributors
Dear Listers, I would like to thank everyone that made a Contribution in support of the Lists this year! It was really nice to hear all great comments people had regarding the Lists! As I have said many times before, running these Lists is a labor of love. Your generosity during the List Fund Raiser underscores the great sentiments people have made regarding the Lists. If you haven't yet made a Contribution in support of this year's Fund Raiser please feel free to do so. The great List Fund Raiser gifts will be available on the Contribution site for just a little while longer, so hurry and make your Contribution and get your great gift! Once again, the URL for the Contribution web site is: http://www.matronics.com/contribution I would like to thank Andy Gold of the Builder's Bookstore ( http://www.buildersbooks.com ), Jon Croke of Homebuilt HELP ( http://www.homebuilthelp.com ) and Bob Nuckolls of AeroElectric ( http://www.aeroelectric.com ) for their extremely generous support during this year's Fund Raiser through the contribution of discounted merchandise. These are great guys that support the aviation industry and I encourage each and every Lister to have a look at their products. Thank you Andy, Jon and Bob!! Your support is very much appreciated! And finally, below you will find a web link to the 2007 List of Contributors current as of 12/6/07! Have a look at this list of names as these are the people that make all of these List services possible! I can't thank each of you enough for your support and great feedback during this year's Fund Raiser! THANK YOU! http://www.matronics.com/loc/2007.html I will be shipping out all of the gifts in the next few weeks and hope to have everything out by the end of the month. In most cases, gifts will be shipped via US Postal Service. Once again, thank you for making this year's List Fund Raiser successful! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 08, 2007
Luke - If you are out at the plane this weekend, I'd appreciate if you could peek at the hookup for the slick start. thanks! bobf On 12/4/07, luke wuest wrote: > > > I am not the person that installed it on my M332A, but I will check out > the wiring and post in a day or three. > Luke Wuest > > ________________________________________________________________________________
Date: Dec 11, 2007
Subject: Rep: SlickSTART install
Hello Bob, Sorry it took awhile for me to post. I did not have a chance to get to the airport until today. My SlickStart is Model# SS1001 series A. Believe it or not, it is installed exactly like the starter vibrator. My aircraft is setup a little different than most, I have a separate mag switch, starter switch and an ignition boost button, just like allot of antique radial powered aircraft. The SlickSTART has 5 connections on it, 1, 2, 3, VIN, GND. The posts marked 2 and 3 have no connections. The VIN post receives voltage from my starter switch positive solenoid contact, this is wired thru my ignition boost switch. Voltage into the SlickSTART should only be applied when the starter is engaged, my install takes it a step further and only allows voltage in when the starter is engaged and the ignition boost button is held in. The GND post is wired to my magneto switch external ground post. Post #1 has 3 wires attached to it. A heavy one going to the R/H magneto P-lead, and two light gage wires going into my Mag switch. I have to do more research into my mag switch install. There is a connector on the back with six wires going internally into the switch, 2 of the wires are from the SlickStart number 1 post and I don't know what any of them do. Unfortunately it is very hard to get at, I have to stand on my head in the rear cockpit (open cockpit biplane) and work WAY up under the panel. I will try to gather more info and post. Unison Industries has published a service letter on the different ways to install the SlickSTART box, it is number SL2-96 and gives some incite into the different ignition boost systems. Th standard LOM system is very similar to the "install to replace starting vibrators that do not include a relay" system. ________________________________________________________________________________
Date: Dec 11, 2007
Subject: Re: Rep: SlickSTART install
Luke - thank you very much - this is of great help. the only problem now is that they are indefinite back order from Unisom according the A/C spruce. So - guess I'll button her up now that I have the buzzer working and wait til the slick start shows up and put it in with the great information you have given me. I'll let you know how it goes. thanks again and Merry Christmas bobf On 12/11/07, luke wuest wrote: > > > Hello Bob, > > Sorry it took awhile for me to post. I did not have a chance to get to the > airport until today. > > My SlickStart is Model# SS1001 series A. Believe it or not, it is > installed exactly like the starter vibrator. My aircraft is setup a little > different than most, I have a separate mag switch, starter switch and an > ignition boost button, just like allot of antique radial powered aircraft. > > The SlickSTART has 5 connections on it, 1, 2, 3, VIN, GND. The posts > marked 2 and 3 have no connections. > > The VIN post receives voltage from my starter switch positive solenoid > contact, this is wired thru my ignition boost switch. Voltage into the > SlickSTART should only be applied when the starter is engaged, my install > takes it a step further and only allows voltage in when the starter is > engaged and the ignition boost button is held in. > > The GND post is wired to my magneto switch external ground post. > > Post #1 has 3 wires attached to it. A heavy one going to the R/H magneto > P-lead, and two light gage wires going into my Mag switch. I have to do more > research into my mag switch install. There is a connector on the back with > six wires going internally into the switch, 2 of the wires are from the > SlickStart number 1 post and I don't know what any of them do. Unfortunately > it is very hard to get at, I have to stand on my head in the rear cockpit > (open cockpit biplane) and work WAY up under the panel. I will try to gather > more info and post. > > Unison Industries has published a service letter on the different ways to > install the SlickSTART box, it is number SL2-96 and gives some incite into > the different ignition boost systems. Th standard LOM system is very similar > to the "install to replace starting vibrators that do not include a relay" > system. > > ________________________________________________________________________________
Date: Dec 11, 2007
Bob, What did you find wrong with the buzzer? Just need the points cleaned? So far, so good with mine - 40 hours plus quite a number of run-ups. Dave Austin 601HDS - 912, Spitfire Mk VIII ________________________________________________________________________________
Date: Dec 11, 2007
Actually, the points were clean, but must have been a couple thousandths apart cause when I check across them, they were not contacting "at rest" - so according to the engine manual, you just bend it slightly so it touches the grounding post - then the ohmeter dropped to nothing. I have about 90 hrs on my LOM engine. It is part of the annual check which I had done to clean them - I just didn't actually check the ohmeter til it was obvious there was not spark to start it with. after adjusting, it started fine. The slick starts will be shipping again soon according to Unisom who makes them. Till then I will use the buzzer; but look forward to quicker starts and less cranking. bobf On 12/11/07, Dave Austin wrote: > > Bob, > What did you find wrong with the buzzer? Just need the points cleaned? > So far, so good with mine - 40 hours plus quite a number of run-ups. > Dave Austin 601HDS - 912, Spitfire Mk VIII > > * > > * > > ________________________________________________________________________________
Date: Dec 12, 2007
Subject: Re: Lom-List Digest: 4 Msgs - 12/11/07
concerning the Buzzer maintance you have to re-adjust it properly evry 50hrs or so; best done on a bench with a Multimeter and a stabilized Voltage of 24V! This is a bit tricky to do on the plane. I take my buzzer out, dismount the contacts, clean them thouroughly with a file (no holes, craters etc), reassemble and then adjust the gap to the correct Amp. value (max 1,0Ah). Take care when re-mounting the spring-contact that both contacts are 100% aligned and parallel to each other! Adjusting the gap is done the following way: * you need a 24V transformer (best with selective Amps) and an Multimeter to read Amp * put +24V on contact 3 or 1 and ground on contact 2 or 4 * have your Multimeter set to measure Ah (0-5Ah) and connected into the circuit * set your transformer to 24V and limit to max 2,0Ah! * turn on the transformer with 24V and check the Ah (do not let it on more than 20sec, otherwise the buzzer will get too hot!) => the correct Ah should be 1.0Ah (+/-0.2Ah)! * to achieve the correct 1.0 A-setting, you have to bent very slightly the moving part of the spring-contact with a small plier! => bending the spring in direction of the fixed contact will increase the Ah => bending the spring away from the fixed contact will reduce the Ah Hope this helps! Klaus Klaus Dietrich Oracle Financing EMEA Tel/Fax: +43 1 33 777 825 http://www.oracle.com/financing Lom-List Digest Server wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Lom-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Lom-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-12-11&Archive=Lom > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-12-11&Archive=Lom > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Lom-List Digest Archive > --- > Total Messages Posted Tue 12/11/07: 4 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 11:11 AM - Rep: SlickSTART install (luke wuest) > 2. 11:33 AM - Re: Rep: SlickSTART install (Robert Feldtman) > 3. 12:32 PM - Re: Rep: SlickSTART install (Dave Austin) > 4. 12:54 PM - Re: Rep: SlickSTART install (Robert Feldtman) > > > > ________________________________ Message 1 _____________________________________ > > > From: luke wuest <lukester(at)earthlink.net> > Subject: Lom-List: Rep: SlickSTART install > > > Hello Bob, > > Sorry it took awhile for me to post. I did not have a chance to get to the airport > until today. > > My SlickStart is Model# SS1001 series A. Believe it or not, it is installed exactly > like the starter vibrator. My aircraft is setup a little different than most, > I have a separate mag switch, starter switch and an ignition boost button, > just like allot of antique radial powered aircraft. > > The SlickSTART has 5 connections on it, 1, 2, 3, VIN, GND. The posts marked 2 > and 3 have no connections. > > The VIN post receives voltage from my starter switch positive solenoid contact, > this is wired thru my ignition boost switch. Voltage into the SlickSTART should > only be applied when the starter is engaged, my install takes it a step further > and only allows voltage in when the starter is engaged and the ignition boost > button is held in. > > The GND post is wired to my magneto switch external ground post. > > Post #1 has 3 wires attached to it. A heavy one going to the R/H magneto P-lead, > and two light gage wires going into my Mag switch. I have to do more research > into my mag switch install. There is a connector on the back with six wires > going internally into the switch, 2 of the wires are from the SlickStart number > 1 post and I don't know what any of them do. Unfortunately it is very hard to > get at, I have to stand on my head in the rear cockpit (open cockpit biplane) > and work WAY up under the panel. I will try to gather more info and post. > > Unison Industries has published a service letter on the different ways to install > the SlickSTART box, it is number SL2-96 and gives some incite into the different > ignition boost systems. Th standard LOM system is very similar to the "install > to replace starting vibrators that do not include a relay" system. > > > ________________________________ Message 2 _____________________________________ > > > From: "Robert Feldtman" <bobf(at)feldtman.com> > Subject: Re: Lom-List: Rep: SlickSTART install > > Luke - thank you very much - this is of great help. the only problem now is > that they are indefinite back order from Unisom according the A/C spruce. So > - guess I'll button her up now that I have the buzzer working and wait til > the slick start shows up and put it in with the great information you have > given me. > > I'll let you know how it goes. > > thanks again and Merry Christmas > > bobf > > > On 12/11/07, luke wuest wrote: > >> Hello Bob, >> >> Sorry it took awhile for me to post. I did not have a chance to get to the >> airport until today. >> >> My SlickStart is Model# SS1001 series A. Believe it or not, it is >> installed exactly like the starter vibrator. My aircraft is setup a little >> different than most, I have a separate mag switch, starter switch and an >> ignition boost button, just like allot of antique radial powered aircraft. >> >> The SlickSTART has 5 connections on it, 1, 2, 3, VIN, GND. The posts >> marked 2 and 3 have no connections. >> >> The VIN post receives voltage from my starter switch positive solenoid >> contact, this is wired thru my ignition boost switch. Voltage into the >> SlickSTART should only be applied when the starter is engaged, my install >> takes it a step further and only allows voltage in when the starter is >> engaged and the ignition boost button is held in. >> >> The GND post is wired to my magneto switch external ground post. >> >> Post #1 has 3 wires attached to it. A heavy one going to the R/H magneto >> P-lead, and two light gage wires going into my Mag switch. I have to do more >> research into my mag switch install. There is a connector on the back with >> six wires going internally into the switch, 2 of the wires are from the >> SlickStart number 1 post and I don't know what any of them do. Unfortunately >> it is very hard to get at, I have to stand on my head in the rear cockpit >> (open cockpit biplane) and work WAY up under the panel. I will try to gather >> more info and post. >> >> Unison Industries has published a service letter on the different ways to >> install the SlickSTART box, it is number SL2-96 and gives some incite into >> the different ignition boost systems. Th standard LOM system is very similar >> to the "install to replace starting vibrators that do not include a relay" >> system. >> >> >> > > ________________________________ Message 3 _____________________________________ > > > From: "Dave Austin" <daveaustin2(at)primus.ca> > Subject: Re: Lom-List: Rep: SlickSTART install > > Bob, > What did you find wrong with the buzzer? Just need the points cleaned? > So far, so good with mine - 40 hours plus quite a number of run-ups. > Dave Austin 601HDS - 912, Spitfire Mk VIII > > ________________________________ Message 4 _____________________________________ > > > From: "Robert Feldtman" <bobf(at)feldtman.com> > Subject: Re: Lom-List: Rep: SlickSTART install > > Actually, the points were clean, but must have been a couple thousandths > apart cause when I check across them, they were not contacting "at rest" - > so according to the engine manual, you just bend it slightly so it touches > the grounding post - then the ohmeter dropped to nothing. I have about 90 > hrs on my LOM engine. It is part of the annual check which I had done to > clean them - I just didn't actually check the ohmeter til it was obvious > there was not spark to start it with. after adjusting, it started fine. > > The slick starts will be shipping again soon according to Unisom who makes > them. Till then I will use the buzzer; but look forward to quicker starts > and less cranking. > > bobf > > > On 12/11/07, Dave Austin wrote: > >> Bob, >> What did you find wrong with the buzzer? Just need the points cleaned? >> So far, so good with mine - 40 hours plus quite a number of run-ups. >> Dave Austin 601HDS - 912, Spitfire Mk VIII >> >> * >> >> * >> >> >> > > > > > > > > > ________________________________________________________________________________
Date: Jan 08, 2008
Subject: Magneto P lead connectors
I have been unable to locate P lead connectors for the PAL magnetos from any of the usual sources. Can anyone help with a source please? Thanks, Steve ________________________________________________________________________________
Date: Feb 18, 2008
Subject: LOM engine feedback
Finally - got LOM engine to start easy - Had the starter rewound, installed a slick-start from Unison, and enlarged the primer fuel enjector opening - starts very easily now. Thanks to all who have helped. bobf Glastar ________________________________________________________________________________
Subject: Re: LOM engine feedback
Date: Feb 19, 2008
Hi Bob, I have a 337CE in the Spitfire. The only way I can start it is at full throttle, which must be doing some harm to the engine when cold. Would you tell me more about the slik-start from unison. Is it easy to install? Does it replace the "shower of sparks" unit? Would you send me their email addr. please. Thanks. Dave Austin 601HDS - 912, Spitfire Mk VIII ________________________________________________________________________________
Date: Feb 19, 2008
Subject: Re: Lom-List Digest: 1 Msgs - 02/18/08
Congradulations Bob, Hopefully it continues to run well. I just got mine out and ran it for the first time in a month and a half, it fired right up, you will come to love the slickstart. Luke -----Original Message----- >From: Lom-List Digest Server <lom-list(at)matronics.com> >Sent: Feb 19, 2008 1:56 AM >To: Lom-List Digest List >Subject: Lom-List Digest: 1 Msgs - 02/18/08 > >* > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > >Today's complete Lom-List Digest can also be found in either of the >two Web Links listed below. The .html file includes the Digest formatted >in HTML for viewing with a web browser and features Hyperlinked Indexes >and Message Navigation. The .txt file includes the plain ASCII version >of the Lom-List Digest and can be viewed with a generic text editor >such as Notepad or with a web browser. > >HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-02-18&Archive=Lom > >Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-02-18&Archive=Lom > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Lom-List Digest Archive > --- > Total Messages Posted Mon 02/18/08: 1 > ---------------------------------------------------------- > > >Today's Message Index: >---------------------- > > 1. 07:31 PM - LOM engine feedback (Robert Feldtman) > > > >________________________________ Message 1 _____________________________________ > > >From: "Robert Feldtman" <bobf(at)feldtman.com> >Subject: Lom-List: LOM engine feedback > >Finally - got LOM engine to start easy - Had the starter rewound, installed >a slick-start from Unison, and enlarged the primer fuel enjector opening - >starts very easily now. Thanks to all who have helped. > >bobf >Glastar > > > > > > > > ________________________________________________________________________________
Date: Feb 19, 2008
Dave - it from Unison.... Spruce sells them. it is very similar to the "buzzer" which is model T technology - that the Czechs have with the engine. It is a direct plug in - Luke Wuest on the LOM forum let me know about it. It was very easy to install. I had issues with the starter (had it rewound) and that is better now. The book says to start with the throttle half open. It fires and runs pretty fast, but it is easy to pull it back. Google Slick-Start Unison and that'll give you the information. in the past six months they have gone upf rom 330 bucks to 425 bucks. let me know if I can help! bob On 2/19/08, Dave Austin wrote: > > Hi Bob, > I have a 337CE in the Spitfire. The only way I can start it is at full > throttle, which must be doing some harm to the engine when cold. > Would you tell me more about the slik-start from unison. Is it easy to > install? Does it replace the "shower of sparks" unit? Would you send me > their email addr. please. > Thanks. > Dave Austin 601HDS - 912, Spitfire Mk VIII > > * > > > * > > ________________________________________________________________________________
Date: Feb 20, 2008
Hi Bob, A couple more questions, What engine do you have and what magnetos? Which if the slick-start models did you install? the 1001 or 1002? Thanks again. Dave Austin 601HDS - 912, Spitfire Mk VIII ________________________________________________________________________________
Date: Mar 16, 2008
Subject: slick start
I don't know how many lom-list viewers there are but for those of you with the LOM engine, like Luke and others, I have had a great experience by removing the old LUN buzzer from my 337-B and replacing with a unisom slick start. it really starts fast now. I had actually ruined the starter, and took it off and had the armature re-wound and the bearing re-machined at a local automotive starter and alternator shop. It starts really sweet now - second or third blade and it is running! thought you should know bobf glastar with LOM ________________________________________________________________________________
Date: Mar 18, 2008
Subject: Help for new installation
Saw a reference to this group on the net. I am about to do a new installation of a M332CE and don't quite know where to start, I've got nothing except the motor and prop firewall forward. I am based in Victoria BC, so if there is someone within a day or 2's drive from Vancouver or Seattle, or if you know of somebody, that would let me come and look at their installation I would appreciate it. Look forward to hearing from you Mike Pienaar ________________________________________________________________________________
Date: Mar 18, 2008
Subject: Re: Help for new installation
You are in Luck! The continent=B9s greatest LOM expert, Pavel Novak is locate d on Victoria Island at Qualicom Beach. Contact: ZFF engines Ltd. Pavel Novak Address: 997 Robin Place, Qualicum Beach, B.C. V9K 2P4 Airport location: www.qualicumbeach.com/airport_index.asp Airport Identifier: CAT4 E-mail: novakp(at)shaw.ca Telephone: 250-752-4597 Website: http://www.zffltd.com/ Steve On 3/18/08 1:20 PM, "Mike Pienaar" wrote: > Saw a reference to this group on the net. > > I am about to do a new installation of a M332CE and don't quite know wher e to > start, I've got nothing except the motor and prop firewall forward. > > I am based in Victoria BC, so if there is someone within a day or 2's dri ve > from Vancouver or Seattle, or if you know of somebody, that would let me come > and look at their installation I would appreciate it. > > Look forward to hearing from you > > > Mike Pienaar > > > > > >> >> >> >> >> >> href="http://www.matronics.com/Navigator?Lom-List">http://www.matronics. com/N >> avigator?Lom-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> >> >> >> ________________________________________________________________________________
Date: Mar 18, 2008
Re: Lom-List: Help for new installationThanks a lot, I will definitely give him a call Regards Mike ----- Original Message ----- From: Stephen Beaver To: lom-list(at)matronics.com Sent: Tuesday, March 18, 2008 10:31 AM Subject: Re: Lom-List: Help for new installation You are in Luck! The continent's greatest LOM expert, Pavel Novak is located on Victoria Island at Qualicom Beach. Contact: ZFF engines Ltd. Pavel Novak Address: 997 Robin Place, Qualicum Beach, B.C. V9K 2P4 Airport location: www.qualicumbeach.com/airport_index.asp Airport Identifier: CAT4 E-mail: novakp(at)shaw.ca Telephone: 250-752-4597 Website: http://www.zffltd.com/ Steve On 3/18/08 1:20 PM, "Mike Pienaar" wrote: Saw a reference to this group on the net. I am about to do a new installation of a M332CE and don't quite know where to start, I've got nothing except the motor and prop firewall forward. I am based in Victoria BC, so if there is someone within a day or 2's drive from Vancouver or Seattle, or if you know of somebody, that would let me come and look at their installation I would appreciate it. Look forward to hearing from you Mike Pienaar href="http://www.matronics.com/Navigator?Lom-List">http://www.matronics .com/Navigator?Lom-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ail Forum - ">http://www.matronics.com/Navigator?Lom-List ; - MATRONICS WEB FORUMS - matronics.com ;- List Contribution Web Site - ; -Matt Dralle, List Admin. ://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 18, 2008
You could also visit http://www.moraviation.com/ Click on Manuals and purchase the installation manual for the engine. Steve On 3/18/08 2:30 PM, "Mike Pienaar" wrote: > Thanks a lot, I will definitely give him a call > > Regards > > Mike >> >> ----- Original Message ----- >> >> From: Stephen Beaver <mailto:sbeaver(at)columbus.rr.com> >> >> To: lom-list(at)matronics.com >> >> Sent: Tuesday, March 18, 2008 10:31 AM >> >> Subject: Re: Lom-List: Help for new installation >> >> >> You are in Luck! The continent=B9s greatest LOM expert, Pavel Novak is lo cated >> on Victoria Island at Qualicom Beach. >> >> Contact: >> >> ZFF engines Ltd. >> Pavel Novak >> Address: 997 Robin Place, Qualicum Beach, B.C. V9K 2P4 >> Airport location: www.qualicumbeach.com/airport_index.asp >> <http://www.qualicumbeach.com/airport_index.asp> >> Airport Identifier: CAT4 >> E-mail: novakp(at)shaw.ca Telephone: 250-752-4597 >> Website: http://www.zffltd.com/ >> >> Steve >> >> >> >> >> On 3/18/08 1:20 PM, "Mike Pienaar" wrote: >> >> >>> Saw a reference to this group on the net. >>> >>> I am about to do a new installation of a M332CE and don't quite know w here >>> to start, I've got nothing except the motor and prop firewall forward. >>> >>> I am based in Victoria BC, so if there is someone within a day or 2's drive >>> from Vancouver or Seattle, or if you know of somebody, that would let me >>> come and look at their installation I would appreciate it. >>> >>> Look forward to hearing from you >>> >>> >>> Mike Pienaar >>> >>> >>> >>> >>> >>> >>>> >>>> >>>> >>>> >>>> >>>> href="http://www.matronics.com/Navigator?Lom-List">http://www.matronic s.com >>>> /Navigator?Lom-List >>>> href="http://forums.matronics.com">http://forums.matronics.com >>>> href="http://www.matronics.com/contribution">http://www.matronics.com/ c >>>> >>>> >>>> ail Forum - >>>> ">http://www.matronics.com/Navigator?Lom-List >>>> ; - MATRONICS WEB FORUMS - >>>> matronics.com <http://www.matronics.com/c> >>>> ;- List Contribution Web Site - >>>> ; -Matt Dralle, List Admin. >>>> ://www.matronics.com/contribution <http://www.matronics.com/c> >>>> >>>> >>>> >>>> >>>> href="http://www.matronics.com/Navigator?Lom-List">http://www.matronic s.com >>>> /Navigator?Lom-List <http://www.matronics.com/c> >>>> href="http://forums.matronics.com">http://forums.matronics.com >>>> <http://www.matronics.com/c> >>>> href="http://www.matronics.com/contribution">http://www.matronics.com/ c >>>> >>>> >>>> >>>> ________________________________________________________________________________
Date: Mar 18, 2008
Re: Lom-List: Help for new installationThanks, I've ordered it to-day. Regards Mike ----- Original Message ----- From: Stephen Beaver To: lom-list(at)matronics.com Sent: Tuesday, March 18, 2008 1:30 PM Subject: Re: Lom-List: Help for new installation You could also visit http://www.moraviation.com/ Click on Manuals and purchase the installation manual for the engine. Steve On 3/18/08 2:30 PM, "Mike Pienaar" wrote: Thanks a lot, I will definitely give him a call Regards Mike ----- Original Message ----- From: Stephen Beaver <mailto:sbeaver(at)columbus.rr.com> To: lom-list(at)matronics.com Sent: Tuesday, March 18, 2008 10:31 AM Subject: Re: Lom-List: Help for new installation You are in Luck! The continent's greatest LOM expert, Pavel Novak is located on Victoria Island at Qualicom Beach. Contact: ZFF engines Ltd. Pavel Novak Address: 997 Robin Place, Qualicum Beach, B.C. V9K 2P4 Airport location: www.qualicumbeach.com/airport_index.asp <http://www.qualicumbeach.com/airport_index.asp> Airport Identifier: CAT4 E-mail: novakp(at)shaw.ca Telephone: 250-752-4597 Website: http://www.zffltd.com/ Steve On 3/18/08 1:20 PM, "Mike Pienaar" wrote: Saw a reference to this group on the net. I am about to do a new installation of a M332CE and don't quite know where to start, I've got nothing except the motor and prop firewall forward. I am based in Victoria BC, so if there is someone within a day or 2's drive from Vancouver or Seattle, or if you know of somebody, that would let me come and look at their installation I would appreciate it. Look forward to hearing from you Mike Pienaar href="http://www.matronics.com/Navigator?Lom-List">http://www.matronics .com/Navigator?Lom-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ail Forum - ">http://www.matronics.com/Navigator?Lom-List <http://www.matronics.com/c> ; - MATRONICS WEB FORUMS - matronics.com <http://www.matronics.com/c> ;- List Contribution Web Site - ; -Matt Dralle, List Admin. ://www.matronics.com/contribution <http://www.matronics.com/c> href="http://www.matronics.com/Navigator?Lom-List">http://www.matronics .com/Navigator?Lom-List <http://www.matronics.com/c> href="http://forums.matronics.com">http://forums.matronics.com <http://www.matronics.com/c> href="http://www.matronics.com/contribution">http://www.matronics.com/c ail Forum - ">http://www.matronics.com/Navigator?Lom-List ; - MATRONICS WEB FORUMS - matronics.com ;- List Contribution Web Site - ; -Matt Dralle, List Admin. ://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 29, 2008
Subject: Two New Lists Added to the Matronics Lineup!
Dear Listers, I've added two new Email Lists to the Matronics List and Forum lineup today. These include the Rans-List and RV12-List. Please surf over to the Matronics List Subscription page and sign up for these new Lists if they are of interest to you: http://www.matronics.com/subscribe Full support on the Forums, List Browse, Archives, etc. is available. Rans-List: http://www.matronics.com/Navigator?Rans-List RV12-List http://www.matronics.com/Navigator?RV12-List Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Apr 26, 2008
Subject: Four New Email Lists At Matronics!!
Dear Listers, I have added four new Lists to the Matronics line up today. These include the following categories: Citabria-List Citabria, Decathlon, Scout, and Champ Zenith601-List Zenair Zodiac CH 601 Zenith640-List Zenair Zodiac CH 640 Zenith701801-List Zenair STOL CH 701 and CH 801 All services are enabled and now available including Search, Browse, Digest, Archives, Forums, Chat, etc., etc. etc...: Citabria: http://www.matronics.com/navigator?citabria-list Zenith601: http://www.matronics.com/navigator?zenith601-list Zenith640: http://www.matronics.com/navigator?zenith640-list Zenith701801: http://www.matronics.com/navigator?zenith701801-list To subscribe, go to the Matronics Email List Subscription Form: http://www.matronics.com/subscribe To check the new Lists out on the Matronics Forum go here: http://forums.matronics.com Enjoy the new Lists!! Don't forget me during the Fund Raiser! :-) Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Jun 12, 2008
Subject: VISIT TO EDMONTON, ALBERTA, CANADA
Re: Lom-List: Help for new installationHi All, If I remember correctly there is somebody in Edmonton with a LOM installation. I will be in Edmonton from late Saturday 28 June to Tuesday 1 July and if you are there I would appreciate it if you could show me your project. I would just like to see an installed engine and it should not take more than a few minutes. Many Thanks Mike ________________________________________________________________________________
Subject: LOM ENGINE SPARK PLUGS
Date: Jun 25, 2008
Gentlemen, I am looking for a set of spark plugs (L22.62 or L22.62A) for my Lom Engine. Can some one help? Is there an equivalent plug that I can use? Regards Bert Bert Filippi Perth Western Australia ________________________________________________________________________________
Subject: Re: LOM ENGINE SPARK PLUGS
Date: Jun 24, 2008
Bert, The ever increasing price of the LOM plugs is causing more and more people to switch to automotive plugs and wires. The NGK 5123 DR8HS is the plug to use. NGK also make some nice caps/wires which fit the plugs and only need to be terminated at the magnet end. As always, Pavel Novak is the authority on these things: novakp(at)shaw.ca I believe he may stock the wires. Steve On Jun 24, 2008, at 10:21 PM, Bert Filippi wrote: > Gentlemen, > I am looking for a set of spark plugs (L22.62 or L22.62A) for my Lom > Engine. Can some one help? > Is there an equivalent plug that I can use? > Regards > Bert > > Bert Filippi > Perth > Western Australia > > ________________________________________________________________________________
Date: Jun 25, 2008
I agree with Steve - I plan to switch to auto plugs and wires (due to RFI radio noise from the old wires), just haven't done it - Pavel is the authority. If you want to remain stock, the guys in Czechoslovakia are very nice and can ship them, also Moravia.com in Canada sold me five of them last year but they were something like 37 dollars apiece - I'm wondering - any tricks with removing the wires from the magneto end to do this? they seem rather tightely in there when I just loosen the grounding connector tht holds it up in there. wonder if I have to take the magneto apart (drop the bottom) to get the wires out? bobf On Tue, Jun 24, 2008 at 9:21 PM, Bert Filippi wrote: > Gentlemen, > > I am looking for a set of spark plugs (L22.62 or L22.62A) for my Lom > Engine. Can some one help? > > Is there an equivalent plug that I can use? > > Regards > > Bert > > > Bert Filippi > > Perth > > Western Australia > > > * > > * > > ________________________________________________________________________________
Date: Jun 25, 2008
Subject: ARLINGTON
Re: Lom-List: Help for new installationHi All, Does anybody know if there will be a LOM installations at Arlington. If so I would appreciate a contact number so that I can arrange to meet Thanks Mike ----- Original Message ----- From: Mike Pienaar To: lom-list(at)matronics.com Sent: Thursday, June 12, 2008 11:11 AM Subject: Lom-List: VISIT TO EDMONTON, ALBERTA, CANADA Hi All, If I remember correctly there is somebody in Edmonton with a LOM installation. I will be in Edmonton from late Saturday 28 June to Tuesday 1 July and if you are there I would appreciate it if you could show me your project. I would just like to see an installed engine and it should not take more than a few minutes. Many Thanks Mike ________________________________________________________________________________
Date: Jul 20, 2008
I got 10 of these NGKs for 19.95 over the internet - new! Has anyone changed out the wires trying to get rid of RFI in the radio? I have some Magnecor wires with rather high spiral wound inductance, and hope to change the wires and plugs to the NGKs Next question is - since I am doing that, has anyone also put a ferrite doughnut on the wire as well to soak up RFI - or is that over-kill? I have a GX-65 radio works fine, but when I get far away from the station I have to turn to squelch off and listen to the radio noise to hear the ATC in the background of the spark plug noise. Not impossible, but always trying to improve things! It is RFI in that when I have the engine running on the ground, and turn it off, the noise goes away; also, when I have the engine running and unplug the antenna from the radio - the noise goes away (so do the received radio signals of course) bobf LOM in glastar. On Tue, Jun 24, 2008 at 9:30 PM, Stephen Beaver wrote: > Bert, > The ever increasing price of the LOM plugs is causing more and more people > to switch to automotive plugs and wires. The NGK 5123 DR8HS is the plug to > use. NGK also make some nice caps/wires which fit the plugs and only need to > be terminated at the magnet end. > > As always, Pavel Novak is the authority on these things: novakp(at)shaw.ca > I believe he may stock the wires. > > Steve > > > On Jun 24, 2008, at 10:21 PM, Bert Filippi wrote: > > Gentlemen, > I am looking for a set of spark plugs (L22.62 or L22.62A) for my Lom > Engine. Can some one help? > Is there an equivalent plug that I can use? > Regards > Bert > > Bert Filippi > Perth > Western Australia > > > *http://www.matronics.com/Navigator?Lom-List > blue; text-decoration: underline; ">http://forums.matronics.com > style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution > * > > > * > > * > > ________________________________________________________________________________
Date: Nov 01, 2008
Subject: Matronics Email List Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the List services at Matronics. It's through soley through the Contributions of List members that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site ( http://forums.matronics.com ), Wiki site ( http://wiki.matronics.com ), or other related pages such as the List Search Engine ( http://www.matronics.com/search ), List Browse ( http://www.matronics.com/listbrowse ), etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisments. During the month of November I will be sending out List messages every few days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. Your personal Contribution counts. Once again, this year I've got a terrific line up of free gifts to go along with the various Contribution levels. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on Matronics Lists and have been either donated or provided at substantially discounted rates. This year, these generous people include Bob Nuckolls of the AeroElectric Connection (http://www.aeroelectric.com/), Andy Gold of the Builder's Bookstore (http://www.buildersbooks.com/), and Jon Croke of HomebuiltHELP (http://www.homebuilthelp.com/). These are extremely generous guys and I encourage you to visit their respective web sites. Each one offers a unique and very useful aviation-related product line. I would like publicly to thank Bob, Andy, and Jon for their generous support of the Lists again this year!! You can make your List Contribution using any one of three secure methods this year including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure site below: https://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years. I know it sounds a little cliche, but you guys really do feel like family. Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 01, 2008
Subject: Contribution Site URL Clarification
Dear Listers, In my List Fund Raiser kickoff email last night, I mistyped the URL for the *initial* Contribution web site and couple of people reported receiving SSL certificate errors. The actual payment entry pages where were correct, however, so there were no certificate issues that impacted payment data. I'm sorry for the confusion. Please use the following URL to start your List Contribution: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 03, 2008
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 05, 2008
Subject: List Fund Raiser
A couple of years ago I implemented an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, he or she will instantly cease to receive these Fund Raiser messages for the rest of the month! Its just that simple. Don't you wish PBS worked that way! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site like this. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 06, 2008
Subject: Reminder
Dear Listers, Just a quick reminder that November is the annual List Fund Raiser. The Matronics Lists are 100% member supported and all of the operational costs are provided for my your Contributions during this time of the year. Your personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 10, 2008
Subject: Fund Raiser List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics PO Box 347 Livermore CA 94551-0347 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 12, 2008
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle PO Box 347 Livermore, CA 94551-0347 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 14, 2008
Subject: Fund Raiser Lagging Last Year By Over 30%...
As of the 13th, the Fund Raiser is currently about 30% behind last year in terms of the number of Contributions. Yet, oddly the number of messages posted per day is up by 10 to 20% on the average. It costs real money to run these Lists and they are supported 100% though your Contributions during the Fund Raiser. Won't you please take a minute right now to make your Contribution to keep these Lists up and running? Contribution Page: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 16, 2008
Subject: What's My Contribution Used For?
Dear Listers, Some have asked, "What's my Contribution used for?" and that's a good question. Here are just a few examples of what your direct List support enables. It provides for the very expensive, commercial-grade T1 Internet connection used on the List insuring maximum performance and minimal contention when accessing List services. It pays for the regular system hardware and software upgrades enabling the highest performance possible for services such as the Archive Search Engine, List Browser, and Forums. It pays for 19+ years worth of online archive data available for instant random search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power this List Service such as the List Browse, Search Engine, Forums, Wiki and PhotoShare. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. How many places on the Internet can you make all those statements these days? It is YOUR CONTRIBUTION that directly enables these many aspects of these valuable List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport... List Contribution Web Site: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 18, 2008
Subject: What Members Are Saying...
Dear Listers, November is the Annual Matronics List Fund Raiser. The Lists are supported solely through your generous Contributions during this time. Please make your Contribution today and pick up a really nice free gift at this same time: http://www.matronics.com/contribution Listers have been including some really nice comments regarding what the Lists mean to them along with their Contributions this year. I've included a few of them below. Please read them over and see if some perhaps echo your feelings as well. Thank you for your support this year! Matt Dralle Matronics Email List and Forum Administrator ------------------------------------------------------------------------------ Best bargain in the entire industry!! -Owen B Every year your lists are better, sure #1 in e-mail list in the world. -Gary G Thank you for an awesome site! -Ashley M Your lists are important to me and well worth paying for. -Calvin A Thank you for providing such and informative and ad free environment to learn by. -Myron H As always, a valuable and extremely useful resource. Stephen T As always, a great service. -Reade G Very much appreciate this site and the communications it has enabled between builders. -Larry M This service is worth every penny. -Robert S Great site! Thanks a ton for its functionality! -Peter B The RV-10 list feels like my community. -Dave S The lists are fantastic, a great source! -Jimmy Y I've learned a lot from the List. -Gabriel F A wonderful resource. -Gerald G Well done. -Richard N Years of good service. -William M Valuable service. -Keith H The site is quite helpful. -Jon M Very interesting List that I read form the beginning. -Alain L A well managed site. -Carl B Great service. -Svein Kare J Still the most useful program on the computer. -Fergus K Great contribution to my project! -Robert K Thanks for keeping a great list. -Dt G The List continues to provide excellent information. -Tony C This is a wonderful resource that has easily saved me a bunch on my build-time. -Ralph C Thank you for providing a great service. The Zenith builder's community would be in sad shape without the Zenith-List's. -Terrence P I really do get pleasure out of reading the List every day. -Bill V Great source of information. -Arthur V Thanks for a great service. Very enjoyable. -Louis B You know we all could not do without your support!! -James S Great resource! -Douglas D Thanks for the great service. -John B ________________________________________________________________________________
Date: Nov 20, 2008
Subject: Behind By 21% - Advertising May Be Needed...?
Dear Listers, The percentage of people making a Contribution to support the Lists this year is currently lagging behind last year by approximately 21%! I'm hoping that everyone is just waiting until the last minute to show their support... ;-) Please remember that it is solely your direct Contributions that keep these Lists up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I will likely have to start adding advertisements to offset the costs of running the Lists. But I *really* don't want to have to start doing that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 22, 2008
Subject: LOC
Dear Listers, Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by popping a personal check in the mail to: Matronics Email Lists c/o Matt Dralle PO Box 347 Livermore CA 94551-0347 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 24, 2008
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some lame magazine or even just a single dinner out. Isn't the List worth at least that much to you? Won't you please take a minute to make your Contribution today and support the Lists? Contribution Page: http://www.matronics.com/contribution Again, I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 26, 2008
Subject: Just A Few More Days...
Dear Listers, There are just a few more days left in this year's List Fund Raiser. There are some great gifts available when you make a qualifying Contribution and there's plenty still available. Don't forget that its *your* Contribution that keeps the computers running, the electricity turned on, and the computer room AC cooling! If you look forward to reading your List email each day, won't you please take a minute right now to make your personal Contribution? Credit Card or Paypal: http://www.matronics.com/contribution Personal Check: Matronics / Matt Dralle PO Box 347 Livermore, CA 94550 Thank you for your support! Matt Dralle ________________________________________________________________________________
Date: Nov 28, 2008
Subject: Just 3 Days Left - Please Make Your List Contribution Today!
There are only three days left until the end of this year's List Fund Raiser. Please take a minute to show your support as so many others have this year and make sure YOUR name is on the forthcoming List of Contributors 2008! Its quick and easy using the secure web site with a credit card or PayPal: http://www.matronics.com/contribution or by sending your personal check to: Matronics Lists c/o Matt Dralle PO Box 347 Livermore, CA 94551-0347 (Please write your email address on the check!) Thank you in advance for your support of these List services! Matt Dralle Matronics Email and Forum Administrator ________________________________________________________________________________
Date: Nov 29, 2008
Subject: What Listers Have Been Saying
Wow! Many of the members making a List Support Contribution this year have been using the Comments field to leave a personal message about the Lists. Thank you! I have included a number of them below. Please read over a few and see if you perhaps can echo some of the same sentiments regarding the value of the Lists to you... There is only a couple more days left for this year's List Fund Raiser and we're still way behind previous years. If you've been waiting until the last minute to show your support, Now is the Time! Please make your Contribution and pick up a great gift at the same time! By Credit Card or Paypal: http://www.matronics.com/contribution or By Personal Check: Matronics / Matt Dralle PO Box 347 Livermore, CA 94550-7227 Thank you in advance!! Matt Dralle Email List and Forums Administrator Here is some of the great feedback members have been including along with their personal Contributions this year... Over the years, the info I have received from the RV-List has saved me thousands of dollars, and dozens of hours of time by helping me avoid bad purchases, pointing me at vendors with low prices and excellent support, and providing solutions to the typical head scratchers that you run into. Kevin H Valuable service. Best List(s) on the Internet! George A Please accept this token not as an indicator of what this list has been worth to me this past year. Lew G Great information and entertainment. Tim V Thanks again for another great year of service. This project would be beyond me if it were not for the list. Moreover, the friendships I have found are worth their weight in GOLD! Robert B Great support you provide to all the subscribers! Freddie H Read it every day. PF B Thanks for your excellent management of the Matronics Lists! Your services are head and shoulders above the rest. James M Without the "List", there would be no Kolb "community". Bill T Thanks, Matt, for a great service! I've been monitoring and using the lists since 1999. Richard D Thanks for such a terrific site and for all the work and effort you put into it. John R A great service year after year. John D ..another year of fantastic service. Jerry B This list is a great resource. Arden A Great list. James M Lists were a great help while building HRII N561FS. John S Great resources for both the beginner and experienced. George R Good service. Gary G The List is an invaluable resource! William C AeroElectric list is a great source of info and learning! Janice J Thank you, Matt for being there for us making it all happen on the List for so many years - Great JOB! Sam S Thank you for providing a great venue. You definitely hit the nail on the head with your solicitation asking if readers look forward to receiving the email digests. I certainly do and when I move from a dreamer to a builder, I expect the anticipation will only increase. Joe S Thanks for a Perfect working list. Hans-Peter R Great List Bryan K Such a great selection of valuable forums! David G Nice job! Walt E Good resource... Robert P Thank you for another great year! Scott S I could not do this without you... Robert D I believe I've been a list member for over a decade now. Thanks for the service! Tim L Great List Hendrik W ________________________________________________________________________________
Date: Nov 30, 2008
Subject: Last "Official" Day Of The List Fund Raiser!
Dear Listers, Its November 30th and that means three things:.. 1) Today I am now officially 45 years old... 2) It marks that last "official" day of this year's List Fund Raiser! 3) Its the last day I will be bugging everyone for a whole year! If you use the Lists and enjoy the content and the no-advertising, no-spam, and no-censorship way in which they're run, please make a Contribution today to support their continued operation and upkeep. Your $20 or $30 goes a long way to keep the List bills paid. I will be posting the List of Contributors next week so make sure your name is on it! Thank you to everyone that has made a Contribution so far this year! It is greatly appreciated. http://www.matronics.com/contribution Best regards, Matt Dralle Email List and Forum Administrator ________________________________________________________________________________
Date: Dec 08, 2008
Subject: List of Contributors 2008
Dear Listers, This year's Fund Raiser has drawn to a close and I want to thank everyone that so generously made a contribution this year in support of the Matronics Email List and Forum operation. Your generosity keeps the wheels on this cart and I truly appreciate the many kind words of encouragement and financial reimbursement. If you haven't yet made a Contribution in support of this year's Fund Raiser, please feel free to do so. The great List Fund Raiser gifts will be available on the Contribution site for a little while longer, so hurry and make your Contribution today and still get your great gift! Once again, the URL for the Contribution web site is: http://www.matronics.com/contribution or by personal check to: Matronics / Matt Dralle PO Box 347 Livermore CA 94551-0347 I would like to thank Andy Gold of the Builder's Bookstore ( http://www.buildersbooks.com ), Jon Croke of HomebuiltHELP ( http://www.homebuilthelp.com ) and Bob Nuckolls of AeroElectric ( http://www.aeroelectric.com ) for their extremely generous support during this year's Fund Raiser through the contribution of discounted merchandise. These are great guys that support the aviation industry and I encourage each and every Lister to have a look at their products. Thank you Andy, Jon and Bob!! Your support is very much appreciated! And finally, below you will find a web link to the 2008 List of Contributors current as of 12/7/08! Have a look at this list of names as *these* are the people that make all of these List services possible! I can't thank each of you enough for your support and great feedback during this year's Fund Raiser! THANK YOU! http://www.matronics.com/loc/2008.html I will be shipping out all of the gifts around the end of December. In most cases, gifts will be shipped via US Postal Service. Once again, thank you for making this year's List Fund Raiser successful! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Apr 03, 2009
Subject: LOM shut down
I follow "the book" printed by LOM and shut down my LOM on the glastar with the ignition. I always worry about a P lead problem and stand clear of the prop when turning it through... I have shut down by cutting gas valve OFF and letting engine die of fuel starvation. I note it is a little hard to start later cause the fuel pump has no gasoline in it. this was posted on the cozy list below.... how do others shut down their LOM? bobf Are you trying to get someone killed? You should NEVER shut down the engine by killing the ignition. All you need is for a P-lead to break and you've got a hot engine ready to fire up as soon as someone moves the prop. And P-leads break from something as simple as a bird scouting around for a new nesting place. Folks - if I'm out of line, just let me know and I'll graciously back off, but this sounds like a tragedy waiting to happen. Phil Kriley Cozy Mk IV Plans 1460 ________________________________________________________________________________
Date: Apr 03, 2009
Subject: Re: LOM shut down
Oh please. Rule number one: Follow the manufacturers instructions. The LOM family of engines, and the ubiquitous Russian radials M14, ASH11 etc are all certified engines throughout most of the world, which means that the engines and the operating handbooks have been certified as being suitable and safe. They all of them have automatic mixture controls and are all shut down with the mag switch. They also all of them use some form of electrical spark enhancement/timing system (variations on the shower of sparks) to help them start, and have magnetos that are reluctant to make enough spark when it is not being employed. It IS possible to start and engine without these, and it has happened, but anyone who has tried to start an LOM or M14 with the buzzer out of commission will know that it is a lot harder to do that on an engine with impulse mags. The fact that the engine stops when the mags are turned off indicates that the P leads are functional. The chance of them failing after that AND of someone swinging the prop AND of the engine deciding that despite having no ignition retard or shower of sparks it WILL start is IMHO, minimal. Yes you could claim that ANY risk is unacceptable in aviation, but the only way to embrace that philosophy is to lock the hangar and throw away the key. It is for each of us to decide what the risk threshold is and act accordingly. Let's not get our panties in a knot because someone else's threshold is different to our own. Steve On 4/3/09 8:41 AM, "Robert Feldtman" wrote: > I follow "the book" printed by LOM and shut down my LOM on the glastar with > the ignition. I always worry about a P lead problem and stand clear of the > prop when turning it through... I have shut down by cutting gas valve OFF and > letting engine die of fuel starvation. I note it is a little hard to start > later cause the fuel pump has no gasoline in it. this was posted on the cozy > list below.... how do others shut down their LOM? > > bobf > > > Are you trying to get someone killed? You should NEVER shut down the engine > by killing the ignition. All you need is for a P-lead to break and you've got > a hot engine ready to fire up as soon as someone moves the prop. And P-leads > break from something as simple as a bird scouting around for a new nesting > place. > > Folks - if I'm out of line, just let me know and I'll graciously back off, but > this sounds like a tragedy waiting to happen. > > Phil Kriley > Cozy Mk IV Plans 1460 > > > > > ________________________________________________________________________________
Date: Apr 03, 2009
The LOM book says: shut down by switching off the ignition. There is no mixture cut off in the LOM engine controls.? In fact, some LOM models don't have any mixture control in the cockpit. I have an electric pump between the fuel selector and the mechanical engine pump.? The only thing it is good for is to pressurize the fuel system before the engine start,? Kind of a bandaid. The primer pump system?is still required. I hope this helps. Jim Ayers RV-3 LOM M332A modified with automatic mixture control unit. -----Original Message----- From: Robert Feldtman <bobf(at)feldtman.com> Sent: Fri, 3 Apr 2009 5:41 am Subject: Lom-List: LOM shut down I follow "the book" printed by LOM and shut down my LOM on the glastar with the ignition. I always worry about a P lead problem and stand clear of the prop when turning it through... I have shut down by cutting gas valve OFF and letting engine die of fuel starvation. I note it is a little hard to start later cause the fuel pump has no gasoline in it. this was posted on the cozy list below.... how do others shut down their LOM? bobf Are you trying to get someone killed?? You should NEVER shut down the engine by killing the ignition.? All you need is for a P-lead to break and you've got a hot engine ready to fire up as soon as someone moves the prop.? And P-leads break from something as simple as a bird scouting around for a new nesting place. Folks - if I'm out of line, just let me know and I'll graciously back off, but this sounds like a tragedy waiting to happen. Phil Kriley Cozy Mk IV Plans 1460 ________________________________________________________________________________
Date: Apr 04, 2009
great feed back. thanks - and I will continue to follow the book! bobf On Fri, Apr 3, 2009 at 7:41 AM, Robert Feldtman wrote: > I follow "the book" printed by LOM and shut down my LOM on the glastar with > the ignition. I always worry about a P lead problem and stand clear of the > prop when turning it through... I have shut down by cutting gas valve OFF > and letting engine die of fuel starvation. I note it is a little hard to > start later cause the fuel pump has no gasoline in it. this was posted on > the cozy list below.... how do others shut down their LOM? > > bobf > > Are you trying to get someone killed? You should NEVER shut down the > engine by killing the ignition. All you need is for a P-lead to break and > you've got a hot engine ready to fire up as soon as someone moves the prop. > And P-leads break from something as simple as a bird scouting around for a > new nesting place. > > Folks - if I'm out of line, just let me know and I'll graciously back off, > but this sounds like a tragedy waiting to happen. > > Phil Kriley > Cozy Mk IV Plans 1460 > > * > > * > > ________________________________________________________________________________
Subject: Electrical, Fuel system and other questions
Date: Apr 07, 2009
Hi All, I hope to be installing a supercharged M332 in the next couple of month's and have a few questions after going through the engine installation manual. The motor is still in the crate and sealed so I can't look too closely to see what I've got. It has a 12 volt alternator, will it have an internal or external regulator and are there any other electrical pointers you can give me, I've looked at the engine installation manual but the quality of the printing is so poor I can hardly read anything. Where do I get a starter buzzer? For the fuel system, where do I get a "hand operated pump" or has anybody found a substitute for this. Has anybody built their own oil tank and do you have any plans or hints for this. I'm building a low wing aircraft, best place to see what it looks like is here http://kisbuild.onfinal18.com/ Thanks for the help Mike ________________________________________________________________________________
Date: Apr 08, 2009
Subject: Re: Electrical, Fuel system and other questions
Yes, you probably need a regulator. Can=B9t say which type without knowing th e alternator model. Starter buzzers are advertised by Moravia =AD Perhaps there is one in the box with your engine ? You most likely don=B9t really need an external pump. The LOM fuel pump and fuel injection system are one and the same. If it fails, an external pump i s not going to help. You could use a small Facet electric pump to prime the plumbing on first start though. You can make an oil tank or adapt one from another source. I made one from cardboard to check fit, then cut it out of soft aluminum and had it welded by an expert aluminum welder. Good luck. On 4/8/09 12:32 AM, "Mike Pienaar" wrote: > Hi All, > > I hope to be installing a supercharged M332 in the next couple of month's and > have a few questions after going through the engine installation manual. The > motor is still in the crate and sealed so I can't look too closely to see what > I've got. > > It has a 12 volt alternator, will it have an internal or external regulat or > and are there any other electrical pointers you can give me, I've looked at > the engine installation manual but the quality of the printing is so poor I > can hardly read anything. > > Where do I get a starter buzzer? > > For the fuel system, where do I get a "hand operated pump" or has anybody > found a substitute for this. > > Has anybody built their own oil tank and do you have any plans or hints f or > this. > > I'm building a low wing aircraft, best place to see what it looks like is here > http://kisbuild.onfinal18.com/ > > Thanks for the help > > Mike > > > > ________________________________________________________________________________
Date: Apr 08, 2009
I converted the buzzer to a slick-start - starts much faster - Buzzers are about 500 bucks from Moravia in Canada. If you want mine, it is available contact me off line (bobf(at)feldtman.com) Ditto on the fuel pump. I do have a facet, for the purposes noted, and actually, put a line with a electrical temporary valve to prime the engine for start with the facet. I've just encountered some problems with my LOM, huge oil usage, an engine near failure on downwind at about 1000 feet, with sever rough and loss of power thank goodness I was on a "downwind leg" as I was departing the airport, and landed fine. We'll see what gives. I might be looking at some major work bobf On Wed, Apr 8, 2009 at 6:56 AM, Stephen Beaver wro te: > Yes, you probably need a regulator. Can=92t say which type without knowin g > the alternator model. > Starter buzzers are advertised by Moravia ' Perhaps there is one in the box > with your engine ? > You most likely don=92t really need an external pump. The LOM fuel pump a nd > fuel injection system are one and the same. If it fails, an external pump is > not going to help. You could use a small Facet electric pump to prime the > plumbing on first start though. > You can make an oil tank or adapt one from another source. I made one fro m > cardboard to check fit, then cut it out of soft aluminum and had it welde d > by an expert aluminum welder. > > Good luck. > > > On 4/8/09 12:32 AM, "Mike Pienaar" wrote: > > Hi All, > > I hope to be installing a supercharged M332 in the next couple of month's > and have a few questions after going through the engine installation manu al. > The motor is still in the crate and sealed so I can't look too closely to > see what I've got. > > It has a 12 volt alternator, will it have an internal or external regulat or > and are there any other electrical pointers you can give me, I've looked at > the engine installation manual but the quality of the printing is so poor I > can hardly read anything. > > Where do I get a starter buzzer? > > For the fuel system, where do I get a "hand operated pump" or has anybody > found a substitute for this. > > Has anybody built their own oil tank and do you have any plans or hints f or > this. > > I'm building a low wing aircraft, best place to see what it looks like is > here http://kisbuild.onfinal18.com/ > > Thanks for the help > > Mike > * > > ail Forum - > ">http://www.matronics.com/Navigator?Lom-List > ; - MATRONICS WEB FORUMS - > matronics.com > ;- List Contribution Web Site - > ; -Matt Dralle, List Admin. > ://www.matronics.com/contribution > > * > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Apr 08, 2009
Thanks for the response. Bob, I would like to know a bit more about the electrical temporary valve that you put in to prime the engine. A photo or general description would be appreciated. Good luck with the repairs, hope it is not as bad as it sounds. Stephen, is the tank just a tank, if that makes any sense, the engine installation manual shows 2 drainage valves and a de-aerator which looks like a tube inside the oil tank that goes from the bottom to the top and the top end is open inside the tank and the bottom of the tube is connected to the engine. The manual is not very clear on what connects to where. What capacity did you make the tank? Thanks again for the help Mike ----- Original Message ----- From: Robert Feldtman To: lom-list(at)matronics.com Sent: Wednesday, April 08, 2009 9:03 AM Subject: Re: Lom-List: Electrical, Fuel system and other questions I converted the buzzer to a slick-start - starts much faster - Buzzers are about 500 bucks from Moravia in Canada. If you want mine, it is available contact me off line (bobf(at)feldtman.com) Ditto on the fuel pump. I do have a facet, for the purposes noted, and actually, put a line with a electrical temporary valve to prime the engine for start with the facet. I've just encountered some problems with my LOM, huge oil usage, an engine near failure on downwind at about 1000 feet, with sever rough and loss of power thank goodness I was on a "downwind leg" as I was departing the airport, and landed fine. We'll see what gives. I might be looking at some major work bobf On Wed, Apr 8, 2009 at 6:56 AM, Stephen Beaver wrote: Yes, you probably need a regulator. Can=92t say which type without knowing the alternator model. Starter buzzers are advertised by Moravia ' Perhaps there is one in the box with your engine ? You most likely don=92t really need an external pump. The LOM fuel pump and fuel injection system are one and the same. If it fails, an external pump is not going to help. You could use a small Facet electric pump to prime the plumbing on first start though. You can make an oil tank or adapt one from another source. I made one from cardboard to check fit, then cut it out of soft aluminum and had it welded by an expert aluminum welder. Good luck. On 4/8/09 12:32 AM, "Mike Pienaar" wrote: Hi All, I hope to be installing a supercharged M332 in the next couple of month's and have a few questions after going through the engine installation manual. The motor is still in the crate and sealed so I can't look too closely to see what I've got. It has a 12 volt alternator, will it have an internal or external regulator and are there any other electrical pointers you can give me, I've looked at the engine installation manual but the quality of the printing is so poor I can hardly read anything. Where do I get a starter buzzer? For the fuel system, where do I get a "hand operated pump" or has anybody found a substitute for this. Has anybody built their own oil tank and do you have any plans or hints for this. I'm building a low wing aircraft, best place to see what it looks like is here http://kisbuild.onfinal18.com/ Thanks for the help Mike ail Forum - ">http://www.matronics.com/Navigator?Lom-List ; - MATRONICS WEB FORUMS - matronics.com ;- List Contribution Web Site - ; -Matt Dralle, List Admin. ://www.matronics.com/contribution et="_blank">http://www.matronics.com/Navigator?Lom-List a href="http://forums.matronics.com/" target="_blank">http://forums.matronics.com _blank">http://www.matronics.com/contribution ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 04/08/09 05:53:00 ________________________________________________________________________________
Date: Apr 08, 2009
A lot of the complexity in the tank shown in the manual comes from accommodation of an inverted system. - Not something you will use much in a KIS. Basically you will need an outlet at the bottom, a return line near the top , a vent line and a filler cap. Not much more than that. I would make it of a t least 8 qts capacity, no more than 10 and plan to keep it 2/3 full. Steve On 4/8/09 7:14 PM, "Mike Pienaar" wrote: > Thanks for the response. > > Bob, I would like to know a bit more about the electrical temporary valve that > you put in to prime the engine. A photo or general description would be > appreciated. Good luck with the repairs, hope it is not as bad as it soun ds. > > Stephen, is the tank just a tank, if that makes any sense, the engine > installation manual shows 2 drainage valves and a de-aerator which looks like > a tube inside the oil tank that goes from the bottom to the top and the t op > end is open inside the tank and the bottom of the tube is connected to th e > engine. The manual is not very clear on what connects to where. What capa city > did you make the tank? > > Thanks again for the help > > Mike > > > > > ----- Original Message ----- >> >> From: Robert Feldtman <mailto:bobf(at)feldtman.com> >> >> To: lom-list(at)matronics.com >> >> Sent: Wednesday, April 08, 2009 9:03 AM >> >> Subject: Re: Lom-List: Electrical, Fuel system and other questions >> >> >> >> I converted the buzzer to a slick-start - starts much faster - Buzzers are >> about 500 bucks from Moravia in Canada. If you want mine, it is availabl e >> contact me off line (bobf(at)feldtman.com) >> >> Ditto on the fuel pump. I do have a facet, for the purposes noted, and >> actually, put a line with a electrical temporary valve to prime the engi ne >> for start with the facet. >> >> I've just encountered some problems with my LOM, huge oil usage, an eng ine >> near failure on downwind at about 1000 feet, with sever rough and loss of >> power thank goodness I was on a "downwind leg" as I was departing the >> airport, and landed fine. >> >> We'll see what gives. >> >> >> >> I might be looking at some major work >> >> bobf >> >> >> On Wed, Apr 8, 2009 at 6:56 AM, Stephen Beaver >> wrote: >> >>> >>> Yes, you probably need a regulator. Can=B9t say which type without knowi ng >>> the alternator model. >>> Starter buzzers are advertised by Moravia =AD Perhaps there is one in th e box >>> with your engine ? >>> You most likely don=B9t really need an external pump. The LOM fuel pump and >>> fuel injection system are one and the same. If it fails, an external p ump >>> is not going to help. You could use a small Facet electric pump to pri me >>> the plumbing on first start though. >>> You can make an oil tank or adapt one from another source. I made one from >>> cardboard to check fit, then cut it out of soft aluminum and had it we lded >>> by an expert aluminum welder. >>> >>> Good luck. >>> >>> >>> >>> >>> >>> >>> On 4/8/09 12:32 AM, "Mike Pienaar" >> <http://mjpienaar@shaw.ca> > wrote: >>> >>> >>>> >>>> Hi All, >>>> >>>> I hope to be installing a supercharged M332 in the next couple of mon th's >>>> and have a few questions after going through the engine installation >>>> manual. The motor is still in the crate and sealed so I can't look too >>>> closely to see what I've got. >>>> >>>> It has a 12 volt alternator, will it have an internal or external >>>> regulator and are there any other electrical pointers you can give me , >>>> I've looked at the engine installation manual but the quality of the >>>> printing is so poor I can hardly read anything. >>>> >>>> Where do I get a starter buzzer? >>>> >>>> For the fuel system, where do I get a "hand operated pump" or has any body >>>> found a substitute for this. >>>> >>>> Has anybody built their own oil tank and do you have any plans or hin ts >>>> for this. >>>> >>>> I'm building a low wing aircraft, best place to see what it looks lik e is >>>> here http://kisbuild.onfinal18.com/ >>>> >>>> Thanks for the help >>>> >>>> Mike >>>> >>>> >>>> ail Forum - >>>> >>>> ">http://www.matronics.com/Navigator?Lom-List >>>> ; - MATRONICS WEB FORUMS - >>>> >>>> matronics.com <http://matronics.com/> >>>> ;- List Contribution Web Site - >>>> ; -Matt Dralle, List Admin. >>>> ://www.matronics.com/contribution <http://www.matronics.com/contributi on> >>>> >>>> >>> >>> >>> >>> et="_blank">http://www.matronics.com/Navigator?Lom-List >>> <http://www.matronics.com/Navigator?Lom-List> >>> a href="http://forums.matronics.com/" >>> target="_blank">http://forums.matronics.com >>> <http://www.matronics.com/Navigator?Lom-List> >>> <http://www.matronics.com/Navigator?Lom-List> >>> _blank">http://www.matronics.com/contribution >>> <http://www.matronics.com/contribution> >>> > > > > href="http://www.matronics.com/Navigator?Lom-List">http://www.matronics.c om/Na > vigator?Lom-List <http://www.matronics.com/contribution> > href="http://forums.matronics.com">http://forums.matronics.com > <http://www.matronics.com/contribution> > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > > > - Release Date: 04/08/09 05:53:00 > > > > ________________________________________________________________________________
Date: Apr 08, 2009
Re: Lom-List: Electrical, Fuel system and other questionsStephen, thanks for your quick response, where does the vent line connect to or does it just vent the tank overboard? Thanks Mike ----- Original Message ----- From: Stephen Beaver To: lom-list(at)matronics.com Sent: Wednesday, April 08, 2009 4:23 PM Subject: Re: Lom-List: Electrical, Fuel system and other questions A lot of the complexity in the tank shown in the manual comes from accommodation of an inverted system. - Not something you will use much in a KIS. Basically you will need an outlet at the bottom, a return line near the top, a vent line and a filler cap. Not much more than that. I would make it of at least 8 qts capacity, no more than 10 and plan to keep it 2/3 full. Steve On 4/8/09 7:14 PM, "Mike Pienaar" wrote: Thanks for the response. Bob, I would like to know a bit more about the electrical temporary valve that you put in to prime the engine. A photo or general description would be appreciated. Good luck with the repairs, hope it is not as bad as it sounds. Stephen, is the tank just a tank, if that makes any sense, the engine installation manual shows 2 drainage valves and a de-aerator which looks like a tube inside the oil tank that goes from the bottom to the top and the top end is open inside the tank and the bottom of the tube is connected to the engine. The manual is not very clear on what connects to where. What capacity did you make the tank? Thanks again for the help Mike ----- Original Message ----- From: Robert Feldtman <mailto:bobf(at)feldtman.com> To: lom-list(at)matronics.com Sent: Wednesday, April 08, 2009 9:03 AM Subject: Re: Lom-List: Electrical, Fuel system and other questions I converted the buzzer to a slick-start - starts much faster - Buzzers are about 500 bucks from Moravia in Canada. If you want mine, it is available contact me off line (bobf(at)feldtman.com) Ditto on the fuel pump. I do have a facet, for the purposes noted, and actually, put a line with a electrical temporary valve to prime the engine for start with the facet. I've just encountered some problems with my LOM, huge oil usage, an engine near failure on downwind at about 1000 feet, with sever rough and loss of power thank goodness I was on a "downwind leg" as I was departing the airport, and landed fine. We'll see what gives. I might be looking at some major work bobf On Wed, Apr 8, 2009 at 6:56 AM, Stephen Beaver wrote: Yes, you probably need a regulator. Can't say which type without knowing the alternator model. Starter buzzers are advertised by Moravia - Perhaps there is one in the box with your engine ? You most likely don't really need an external pump. The LOM fuel pump and fuel injection system are one and the same. If it fails, an external pump is not going to help. You could use a small Facet electric pump to prime the plumbing on first start though. You can make an oil tank or adapt one from another source. I made one from cardboard to check fit, then cut it out of soft aluminum and had it welded by an expert aluminum welder. Good luck. On 4/8/09 12:32 AM, "Mike Pienaar" http://mjpienaar@shaw.ca> > wrote: Hi All, I hope to be installing a supercharged M332 in the next couple of month's and have a few questions after going through the engine installation manual. The motor is still in the crate and sealed so I can't look too closely to see what I've got. It has a 12 volt alternator, will it have an internal or external regulator and are there any other electrical pointers you can give me, I've looked at the engine installation manual but the quality of the printing is so poor I can hardly read anything. Where do I get a starter buzzer? For the fuel system, where do I get a "hand operated pump" or has anybody found a substitute for this. Has anybody built their own oil tank and do you have any plans or hints for this. I'm building a low wing aircraft, best place to see what it looks like is here http://kisbuild.onfinal18.com/ Thanks for the help Mike ail Forum - ">http://www.matronics.com/Navigator?Lom-List ; - MATRONICS WEB FORUMS - matronics.com <http://matronics.com/> ;- List Contribution Web Site - ; -Matt Dralle, List Admin. ://www.matronics.com/contribution <http://www.matronics.com/contribution> et="_blank">http://www.matronics.com/Navigator?Lom-List <http://www.matronics.com/Navigator?Lom-List> a href="http://forums.matronics.com/" target="_blank">http://forums.matronics.com <http://www.matronics.com/Navigator?Lom-List> <http://www.matronics.com/Navigator?Lom-List> _blank">http://www.matronics.com/contribution <http://www.matronics.com/contribution> href="http://www.matronics.com/Navigator?Lom-List">http://www.matronics .com/Navigator?Lom-List <http://www.matronics.com/contribution> href="http://forums.matronics.com">http://forums.matronics.com <http://www.matronics.com/contribution> href="http://www.matronics.com/contribution">http://www.matronics.com/c ------------------------------------------------------------------------- --- - Release Date: 04/08/09 05:53:00 ail Forum - ">http://www.matronics.com/Navigator?Lom-List ; - MATRONICS WEB FORUMS - matronics.com ;- List Contribution Web Site - ; -Matt Dralle, List Admin. ://www.matronics.com/contribution ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 04/08/09 05:53:00 ________________________________________________________________________________
Date: Apr 08, 2009
Glad you're OK, Bob. Keep us in the loop about the problems. Chris --- On Wed, 4/8/09, Robert Feldtman wrote: > From: Robert Feldtman <bobf(at)feldtman.com> > Subject: Re: Lom-List: Electrical, Fuel system and other questions > To: lom-list(at)matronics.com > Date: Wednesday, April 8, 2009, 11:03 AM > I converted the buzzer to a slick-start - starts much faster > - Buzzers are > about 500 bucks from Moravia in Canada. If you want mine, > it is available > contact me off line (bobf(at)feldtman.com) > Ditto on the fuel pump. I do have a facet, for the purposes > noted, and > actually, put a line with a electrical temporary valve to > prime the engine > for start with the facet. > I've just encountered some problems with my LOM, huge > oil usage, an engine > near failure on downwind at about 1000 feet, with sever > rough and loss of > power thank goodness I was on a "downwind leg" as > I was departing the > airport, and landed fine. > We'll see what gives. > > I might be looking at some major work > bobf > > On Wed, Apr 8, 2009 at 6:56 AM, Stephen Beaver > wrote: > > > Yes, you probably need a regulator. Cant say which > type without knowing > > the alternator model. > > Starter buzzers are advertised by Moravia Perhaps > there is one in the box > > with your engine ? > > You most likely dont really need an external pump. > The LOM fuel pump and > > fuel injection system are one and the same. If it > fails, an external pump is > > not going to help. You could use a small Facet > electric pump to prime the > > plumbing on first start though. > > You can make an oil tank or adapt one from another > source. I made one from > > cardboard to check fit, then cut it out of soft > aluminum and had it welded > > by an expert aluminum welder. > > > > Good luck. > > > > > > > > > > > > On 4/8/09 12:32 AM, "Mike Pienaar" > wrote: > > > > Hi All, > > > > I hope to be installing a supercharged M332 in the > next couple of month's > > and have a few questions after going through the > engine installation manual. > > The motor is still in the crate and sealed so I > can't look too closely to > > see what I've got. > > > > It has a 12 volt alternator, will it have an internal > or external regulator > > and are there any other electrical pointers you can > give me, I've looked at > > the engine installation manual but the quality of the > printing is so poor I > > can hardly read anything. > > > > Where do I get a starter buzzer? > > > > For the fuel system, where do I get a "hand > operated pump" or has anybody > > found a substitute for this. > > > > Has anybody built their own oil tank and do you have > any plans or hints for > > this. > > > > I'm building a low wing aircraft, best place to > see what it looks like is > > here http://kisbuild.onfinal18.com/ > > > > Thanks for the help > > > > Mike > > * > > > > ail Forum - > > ">http://www.matronics.com/Navigator?Lom-List > > ; - MATRONICS WEB FORUMS - > > matronics.com > > ;- List Contribution Web Site - > > ; -Matt Dralle, List Admin. > > ://www.matronics.com/contribution > > > > * > > > > * > > > =========== > =========== > =========== > =========== > > * > > > > ________________________________________________________________________________
Date: Apr 08, 2009
It just vents overboard to allow for expansion. Steve Beaver (614) 937 4189 On Apr 8, 2009, at 7:36 PM, "Mike Pienaar" wrote: > Stephen, thanks for your quick response, where does the vent line > connect to or does it just vent the tank overboard? > > Thanks > > Mike > ----- Original Message ----- > From: Stephen Beaver > To: lom-list(at)matronics.com > Sent: Wednesday, April 08, 2009 4:23 PM > Subject: Re: Lom-List: Electrical, Fuel system and other questions > > A lot of the complexity in the tank shown in the manual comes from > accommodation of an inverted system. - Not something you will use > much in a KIS. > > Basically you will need an outlet at the bottom, a return line near > the top, a vent line and a filler cap. Not much more than that. I > would make it of at least 8 qts capacity, no more than 10 and plan > to keep it 2/3 full. > > Steve > > On 4/8/09 7:14 PM, "Mike Pienaar" wrote: > > Thanks for the response. > > Bob, I would like to know a bit more about the electrical temporary > valve that you put in to prime the engine. A photo or general > description would be appreciated. Good luck with the repairs, hope > it is not as bad as it sounds. > > Stephen, is the tank just a tank, if that makes any sense, the > engine installation manual shows 2 drainage valves and a de-aerator > which looks like a tube inside the oil tank that goes from the > bottom to the top and the top end is open inside the tank and the > bottom of the tube is connected to the engine. The manual is not > very clear on what connects to where. What capacity did you make the > tank? > > Thanks again for the help > > Mike > > > ----- Original Message ----- > > From: Robert Feldtman <mailto:bobf(at)feldtman.com> > > To: lom-list(at)matronics.com > > Sent: Wednesday, April 08, 2009 9:03 AM > > Subject: Re: Lom-List: Electrical, Fuel system and other questions > > > I converted the buzzer to a slick-start - starts much faster - > Buzzers are about 500 bucks from Moravia in Canada. If you want > mine, it is available contact me off line (bobf(at)feldtman.com) > > Ditto on the fuel pump. I do have a facet, for the purposes noted, > and actually, put a line with a electrical temporary valve to prime > the engine for start with the facet. > > I've just encountered some problems with my LOM, huge oil usage, an > engine near failure on downwind at about 1000 feet, with sever rough > and loss of power thank goodness I was on a "downwind leg" as I was > departing the airport, and landed fine. > > We'll see what gives. > > > I might be looking at some major work > > bobf > > > On Wed, Apr 8, 2009 at 6:56 AM, Stephen Beaver > wrote: > > > Yes, you probably need a regulator. Can=99t say which type without kn > owing the alternator model. > Starter buzzers are advertised by Moravia =93 Perhaps there is one in > the box with your engine ? > You most likely don=99t really need an external pump. The LOM fuel pu > mp and fuel injection system are one and the same. If it fails, an > external pump is not going to help. You could use a small Facet ele > ctric pump to prime the plumbing on first start though. > You can make an oil tank or adapt one from another source. I made > one from cardboard to check fit, then cut it out of soft aluminum > and had it welded by an expert aluminum welder. > > Good luck. > > > On 4/8/09 12:32 AM, "Mike Pienaar" http://mjpienaar@shaw.ca > > > wrote: > > > Hi All, > > I hope to be installing a supercharged M332 in the next couple of > month's and have a few questions after going through the engine > installation manual. The motor is still in the crate and sealed so > I can't look too closely to see what I've got. > > It has a 12 volt alternator, will it have an internal or external > regulator and are there any other electrical pointers you can give > me, I've looked at the engine installation manual but the quality > of the printing is so poor I can hardly read anything. > > Where do I get a starter buzzer? > > For the fuel system, where do I get a "hand operated pump" or has > anybody found a substitute for this. > > Has anybody built their own oil tank and do you have any plans or > hints for this. > > I'm building a low wing aircraft, best place to see what it looks > like is here http://kisbuild.onfinal18.com/ > > Thanks for the help > > Mike > > > ail Forum - > > ">http://www.matronics.com/Navigator?Lom-List > ; - MATRONICS WEB FORUMS - > > matronics.com <http://matronics.com/> > ;- List Contribution Web Site - > ; -Matt Dralle, List Admin. > ://www.matronics.com/contribution <http://www.matronics.com/contribution > > > > > et="_blank">http://www.matronics.com/Navigator?Lom-List <http://www.matronics.com/Navigator?Lom-List > > > a href="http://forums.matronics.com/" target="_blank">http://forums.matronics.com > <http://www.matronics.com/Navigator?Lom-List> <http://www.matronics.com/Navigator?Lom-List > > > _blank">http://www.matronics.com/contribution <http://www.matronics.com/contribution > > > > > href="http://www.matronics.com/Navigator?Lom-List">http://www.matronics. com/Navigator?Lom-List > <http://www.matronics.com/contribution> > href="http://forums.matronics.com">http://forums.matronics.com <http://www.matronics.com/contribution > > > href="http://www.matronics.com/contribution">http:// > www.matronics.com/c > > > - Release Date: 04/08/09 05:53:00 > > > ail Forum - > ">http://www.matronics.com/Navigator?Lom-List > ; - MATRONICS WEB FORUMS - > matronics.com > ;- List Contribution Web Site - > ; -Matt Dralle, List Admin. > ://www.matronics.com/contribution > > > href="http://www.matronics.com/Navigator?Lom-List">http://www.matronics. com/Navigator?Lom-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http:// > www.matronics.com/c > - Release Date: 04/08/09 05:53:00 > > ________________________________________________________________________________
Date: Apr 08, 2009
will let you know the final. bobf On Wed, Apr 8, 2009 at 6:35 PM, Chris Kinnaman wrot e: > > > Glad you're OK, Bob. Keep us in the loop about the problems. > > Chris > > > --- On Wed, 4/8/09, Robert Feldtman wrote: > > > From: Robert Feldtman <bobf(at)feldtman.com> > > Subject: Re: Lom-List: Electrical, Fuel system and other questions > > To: lom-list(at)matronics.com > > Date: Wednesday, April 8, 2009, 11:03 AM > > I converted the buzzer to a slick-start - starts much faster > > - Buzzers are > > about 500 bucks from Moravia in Canada. If you want mine, > > it is available > > contact me off line (bobf(at)feldtman.com) > > Ditto on the fuel pump. I do have a facet, for the purposes > > noted, and > > actually, put a line with a electrical temporary valve to > > prime the engine > > for start with the facet. > > I've just encountered some problems with my LOM, huge > > oil usage, an engine > > near failure on downwind at about 1000 feet, with sever > > rough and loss of > > power thank goodness I was on a "downwind leg" as > > I was departing the > > airport, and landed fine. > > We'll see what gives. > > > > I might be looking at some major work > > bobf > > > > On Wed, Apr 8, 2009 at 6:56 AM, Stephen Beaver > > wrote: > > > > > Yes, you probably need a regulator. Can=92t say which > > type without knowing > > > the alternator model. > > > Starter buzzers are advertised by Moravia ' Perhaps > > there is one in the box > > > with your engine ? > > > You most likely don=92t really need an external pump. > > The LOM fuel pump and > > > fuel injection system are one and the same. If it > > fails, an external pump is > > > not going to help. You could use a small Facet > > electric pump to prime the > > > plumbing on first start though. > > > You can make an oil tank or adapt one from another > > source. I made one from > > > cardboard to check fit, then cut it out of soft > > aluminum and had it welded > > > by an expert aluminum welder. > > > > > > Good luck. > > > > > > > > > > > > > > > > > > On 4/8/09 12:32 AM, "Mike Pienaar" > > wrote: > > > > > > Hi All, > > > > > > I hope to be installing a supercharged M332 in the > > next couple of month's > > > and have a few questions after going through the > > engine installation manual. > > > The motor is still in the crate and sealed so I > > can't look too closely to > > > see what I've got. > > > > > > It has a 12 volt alternator, will it have an internal > > or external regulator > > > and are there any other electrical pointers you can > > give me, I've looked at > > > the engine installation manual but the quality of the > > printing is so poor I > > > can hardly read anything. > > > > > > Where do I get a starter buzzer? > > > > > > For the fuel system, where do I get a "hand > > operated pump" or has anybody > > > found a substitute for this. > > > > > > Has anybody built their own oil tank and do you have > > any plans or hints for > > > this. > > > > > > I'm building a low wing aircraft, best place to > > see what it looks like is > > > here http://kisbuild.onfinal18.com/ > > > > > > Thanks for the help > > > > > > Mike > > > * > > > > > > ail Forum - > > > ">http://www.matronics.com/Navigator?Lom-List > > > ; - MATRONICS WEB FORUMS - > > > matronics.com > > > ;- List Contribution Web Site - > > > ; -Matt Dralle, List Admin. > > > ://www.matronics.com/contribution > > > > > > * > > > > > > * > > > > > =========== > > =========== > > =========== > > =========== > > > * > > > > > > > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jun 27, 2009
Subject: LOM changes
Changed all the flexible oil lines, tired of the oil leaks off my LOM, and also removed the stock spark plug wires (I didn;t, A&P did) - will see if new Magnecor RFI surpression cables will improve the radio noise! bobf ________________________________________________________________________________
Subject: Re: LOM changes
Date: Jun 29, 2009
Dear LOM List and Bob Just thought I'd let you know that provided all goes well I should be getting back 3 M332's from the factory (in 4 weeks) for our Aero 145 project in Australia. 2 of the engines were running but had not been looked over properly since the 1960's. Cheers James Lewis ________________________________________________________________________________
Date: Sep 14, 2009
Subject: Generator problems
Hi folks.- I have an AK 337 with the factory 24volt generator.- The gen erator has stopped working and I would like to have it rebuilt.- I know I can get the replacement alternator, but it costs around $600-800.- Any i deas?- Thanks=0A=0A=0A ________________________________________________________________________________
Date: Sep 14, 2009
Subject: Re: Generator problems
Mark, How is it driven? You might be able to find a 24 volt alternator and make a drive adapter for it. It you wanted to go to 12 volts there are a number of small tractor dynamos (permanent magnet alternators) available from John Deere and others. Again, a drive adapter would be required but once done you'd have a ready source of replacement parts without the high ticket price. Rick Girard On Mon, Sep 14, 2009 at 3:46 PM, Mark P wrote: > Hi folks. I have an AK 337 with the factory 24volt generator. The > generator has stopped working and I would like to have it rebuilt. I know I > can get the replacement alternator, but it costs around $600-800. Any > ideas? Thanks > > * > > * > > ________________________________________________________________________________
Date: Sep 14, 2009
The LOM generator is a simple object, and is no different in design from an y other generator. - Any aircraft electrical specialist should be able to hel p you, or an automotive shop with an interest in the vintage market. A quick Google search for =B3generator repair=B2 found 5 in the city where I live. For an aircraft generator overhaul shop, I would start here: http://www.aircraftaccessoriesofok.com/capabilities_i887911.html?catId=4002 5 If they won=B9t look at yours, they can probably suggest someone who will. Are you certain it is the generator that has failed and not the control box/wiring? Steve On 9/14/09 4:46 PM, "Mark P" wrote: > Hi folks. I have an AK 337 with the factory 24volt generator. The gener ator > has stopped working and I would like to have it rebuilt. I know I can ge t the > replacement alternator, but it costs around $600-800. Any ideas? Thanks > > > > ________________________________________________________________________________
Date: Sep 15, 2009
Subject: Re: Lom-List Digest: 3 Msgs - 09/14/09
Thanks guys.- Steve, how do I tell if it's "the generator that has failed and not the control box/wiring?"- I've opened up the regulator and all the wires looked good. - Unfortunatley, I'm a shade tree mechanic and everyone around here that I ask about it looks at the engine and says they don't know anything about it.- I'm not even sure how to test it other than my generator trouble lig ht used to come on at low power settings, and now it doesn't come on at all and my batteries are not getting a charge.- I would rather have it rebuilt than put another in.- I'll look up your re ference. Rick, I don't know to make a drive adapter. But I can ask around. Thanks --- On Tue, 9/15/09, Lom-List Digest Server wrote: From: Lom-List Digest Server <lom-list(at)matronics.com> Subject: Lom-List Digest: 3 Msgs - 09/14/09 Date: Tuesday, September 15, 2009, 6:57 AM * ======================== ---Online Versions of Today's List Digest Archive ======================== Today's complete Lom-List Digest can also be found in either of the two Web Links listed below.- The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation.- The .txt file includes the plain ASCII version of the Lom-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: - - http://www.matronics.com/digest/digestview.php?Style=82701&View =html&Chapter 09-09-14&Archive=Lom Text Version: - - http://www.matronics.com/digest/digestview.php?Style=82701&View =txt&Chapter 09-09-14&Archive=Lom ====================== ---EMail Version of Today's List Digest Archive ====================== - - - - ----------------------------------------------------- -------- - - - - - - - - - - - - ---Lom-List Digest Ar chive - - - - - - - - - - - - - - - - - - - --- - - - - - - - - - ---Total Messages Posted Mon 09/1 4/09: 3 - - - - ----------------------------------------------------- -------- Today's Message Index: ---------------------- - ---1. 02:52 PM - Generator problems- (Mark P) - ---2. 03:42 PM - Re: Generator problems- (Richard Girard) - ---3. 04:24 PM - Re: Generator problems- (Stephen Beaver) ________________________________- Message 1- __________________________ ___________ From: Mark P <flybynight010(at)yahoo.com> Subject: Lom-List: Generator problems Hi folks.- I have an AK 337 with the factory 24volt generator.- The gen erator has stopped working and I would like to have it rebuilt.- I know I can get the replacement alternator, but it costs around $600-800.- Any i deas?- Thanks=0A=0A=0A- - - ________________________________- Message 2- __________________________ ___________ Subject: Re: Lom-List: Generator problems From: Richard Girard <aslsa.rng(at)gmail.com> Mark, How is it driven? You might be able to find a 24 volt alternator and make a drive adapter for it. It you wanted to go to 12 volts there are a number of small tractor dynamos (permanent magnet alternators) available from John Deere and others. Again, a drive adapter would be required but once done you'd have a ready source of replacement parts without the high ticket price. Rick Girard On Mon, Sep 14, 2009 at 3:46 PM, Mark P wrote: > Hi folks.- I have an AK 337 with the factory 24volt generator.- The > generator has stopped working and I would like to have it rebuilt.- I k now I > can get the replacement alternator, but it costs around $600-800.- Any > ideas?- Thanks > > * > > * > > ________________________________- Message 3- __________________________ ___________ Subject: Re: Lom-List: Generator problems From: Stephen Beaver <sbeaver(at)columbus.rr.com> The LOM generator is a simple object, and is no different in design from an y other generator. - Any aircraft electrical specialist should be able to hel p you, or an automotive shop with an interest in the vintage market. A quick Google search for =B3generator repair=B2 found 5 in the city where I li ve. For an aircraft generator overhaul shop, I would start here: http://www.aircraftaccessoriesofok.com/capabilities_i887911.html?catId=40 02 5 If they won=B9t look at yours, they can probably suggest someone who will .. Are you certain it is the generator that has failed and not the control box/wiring? Steve On 9/14/09 4:46 PM, "Mark P" wrote: > Hi folks.- I have an AK 337 with the factory 24volt generator.- The g ener ator > has stopped working and I would like to have it rebuilt.- I know I can ge t the > replacement alternator, but it costs around $600-800.- Any ideas?- Th anks > > > > le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Sep 15, 2009
Is the generator properly polarized? You'll have to find an old time mechanic or instructions on the web. I'd try that first if it is indeed a generator. As I recall you short between Field and positive battery terminal, but it's been years since I had to do this on a VW generator.Well, it turns out my memory is pretty good. Here's a You Tube video. http://www.youtube.com/watch?v=NV8FFgia7uU <http://www.youtube.com/watch?v=NV8FFgia7uU>Rick On Tue, Sep 15, 2009 at 9:43 AM, Mark P wrote: > Thanks guys. Steve, how do I tell if it's "the generator that has failed > and not the control > box/wiring?" I've opened up the regulator and all the wires looked good. > Unfortunatley, I'm a shade tree mechanic and everyone around here that I ask > about it looks at the engine and says they don't know anything about it. > I'm not even sure how to test it other than my generator trouble light used > to come on at low power settings, and now it doesn't come on at all and my > batteries are not getting a charge. > I would rather have it rebuilt than put another in. I'll look up your > reference. > Rick, I don't know to make a drive adapter. But I can ask around. > Thanks > > > --- On *Tue, 9/15/09, Lom-List Digest Server *wrote:
August 09, 2003 - November 01, 2009
Lom-Archive.digest.vol-aa
