Pietenpol-Archive.digest.vol-ad
December 12, 1997 - February 04, 1998
screen,and
> >click on the little green and red icon and the lights will shut off.
> > Doug..
> One Question:
> Does it run under windows 3.x ?
> Saludos
> Gary Gower
RE.LIGHTS---
I wish i could answer your question,but i do not know if it will run on
3.x,it was forwarded to me by a friend.Maybe someone more versed in
computers could answer it for you.
Subject: | Re: Sitka Spruce |
> From: Ken Beanlands <ken.beanlands(at)west.gecems.com>
> To: Pietenpol Discussion
> Subject: Re: Sitka Spruce
> Date: Friday, December 12, 1997 5:33 PM
> Hi,
> Being from Calgary, I can vouch for these guys. It's a one man operation
> located in a small hangar at YYC (Calgary intl.). Gene (I think) is a
> pretty good guy and the last time I talked to him he had a couple of
> thousand board feet of S. Spruce. He provides complete wood kits for most
> popular designs and even builds up spars and the like for certain planes.
> When I was there last year picking up my spars (that he milled to spec
> and even put the top and bottom bevels on for me) he was building up a
> GP-4 spar on his bench for another customer. He's also built a couple of
> planes which gives him an understanding of what we need. He's
> opinionated, but definitely knows his stuff.
> Ken.
> On Fri, 12 Dec 1997, Gerard "Larry" Huber wrote:
> > Just got this post from the rec.aviation.restoration news group and
> > thought this list would be interested based on recent items
> > - - - SNIP - - -
> > Spruce kits
> > We were fortunate recently in obtaining a large quanity of sitka
> > spruce. We have 25 Years experience suppling quality sitka spruce for
> > ultra lights. The Sitka spruce is the highest quality aircraft grade
> > to be found in the world. All material is milled to your specs. We
> > have supplied kits to numerous customers all over the world.
> > Western Aircraft Supplies
> > 623 Markerville Rd. S.E.
> > Calgary Alberta, T2E 5X1
> > Canada
> > Bus ph 403-275-3513
> > Res ph 403-276-3087
> > Email wbeck(at)nucleus.com
-----------I also purchased my spar material from Western Aircraft Supplies
and am happy with the quality,he also carries an epoxy that is nearly
odourless,though is slow to set,but very strong.
---Doug Hunt..
Subject: | Re: Suggested plans for purchase |
The climb with the Fiesta varies from 200 ft/min with 2 people and 20 gallons
of fuel to 700 ft/min when I'm alone with only a few gallons.
There isn't much of a cruise window: from 62 to 66 (mph). Below that it begins
to descend, mushing down below 40 to a full stall. Full throttle in level
flight will produce 70 mph. Higher speds can be obtrained by aiming at a patch
of ground. I believe that my large flat nose a la Jenny produces more drag
than Bernie's arrangement.
Jim Malley
> From: GMalley <GMalley(at)aol.com>
> Subject: Re: Suggested plans for purchase
> Date: Saturday, December 13, 1997 9:51 AM
gallons
begins
patch
drag
> Jim Malley
________ Thanks for the response Jim,is your Piet the one that was in
Kitplanes a couple of years ago?If so i sure liked the burnished finish on
the cowling. How is the reliability of the Fiesta engine?
Doug Hunt
Subject: | to Greg Cardinal |
Greg,
Thanks for the info. on RAW and what I need to remember when
ordering
wood from them. We're busy here figuring exactly what we need and what
dimensions we should order. I'm even finding this to be a lot of fun.
Thanks again, John Fay (email aron(at)hrn.bradley.edu)
From: | "McNarry, John" <Mcnarry(at)assiniboinec.mb.ca> |
From: | Ken Beanlands <ken.beanlands(at)west.gecems.com> |
Subject: | Re: Re: Sitka Spruce |
Hi,
{Jean is the spelling the name is french pronounced like our
Canadian PM}is a pretty good guy {I agree} and the last time I talked
to him he had a couple of thousand board feet of S. Spruce. He
provides complete wood kits for most popular designs and even builds
up spars and the like for certain planes. When I was there last year
picking up my spars (that he milled to spec and even put the top and
bottom bevels on for me) he was building up a GP-4 spar on his bench
for another customer. He's also built a couple of planes which gives
him an understanding of what we need. He's opinionated, but{aren't we
all} definitely knows his stuff.
Ken.
> - - - SNIP - - -
> Spruce kits
> Canada
> Bus ph 403-275-3513
> Res ph 403-276-3087
Subject: | Re: Fuselage Length |
AirCampr(at)aol.com wrote:
> I have pretty nearly decided on using the Corvair engine in my Piet, BUT...
> I am really attatched to the look of the short, original fuselage. I think
> the longer fuselage makes the plane look too... something... I just dont
> like it. It's not as quaint. Can't really describe what I mean. Is it
> possible to use the Corvair engine AND use the short fuselage? Can the CG be
> made to be in the right place without too much trouble?
I try to save all questions and responses regarding Piet construction in
a special folder. I have no responses to this question. Did I miss
something?
Thanks -Bob Bailey-
Subject: | Walter Lom Aircraft Engines |
Hello List!
I have seen some recent ads for Walter Lom Aircraft Engines. These are
four cylinder inverted aircooled engines. I called tham and they do
offer a 65 HP engine. I presume these are from a former Eastern Block
country. Does anyone know anything about these engines? They ought to
be a natural for the Piet.
Bob Bailey
I've been wondering lately about engine weights and C of G. I
understand that the wing on the Peitenpol can be shifted to make the
weight and balance work. Would those of us that have completed thier
aircraft post the weights of the various engine combinations? Lets
see now, there are A Fords, B Fords, Corvairs, Contientals,
Lycomings, Franklins, Subarus, VW NOT!, etc..... I would really help
some of us decide on what engine to choose as there is more to
consider than just availability and price. Finished weights would
also help.
Thanks John Mc.
From: | jkahn(at)picasso.dehavilland.ca (John Kahn) |
Subject: | Re: More alternative wood -Reply |
In the talk about wood it occured to me that you
could save a fortune on spars simply by ordering spars
from short lengths (12 or evern 10 feet) and scarfing on
the last foot or two, since the under 12ft lengths are so
much cheaper. Anybody done that?
John Kahn
Bombardier Inc.
> BUT...
> think
> dont
> it
> the CG be
> in
> something?
> Thanks -Bob Bailey-
I used the short fuse and a continetal. should not be a problem.
Stevee.
> also help.
> Thanks John Mc.
Check out the cg article on grants piet page. It is something like
what you describe.
Steve (short fuse, all doug fir, A-65, wing back nearly 6", 620lbs)
> John Kahn
> Bombardier Inc.
Not exactly, but instead, I made my wing panels about 12'6" and made my
center section 4' and built in a larger gas tank.Works great with the
same three piece wing fittings.
Stevee
Could someone please describe the scarfing process. I'm wondering what
tools are needed, how difficult and time consuming it is, and how likely one
is to make a sound joint load bearing joint.
Brent Reed
From: | rdecosta(at)autoeurope.com (Richard DeCosta) |
So, if I were to use a Corvair, what kind of modifications would I be
making with the short fuse? extended motor mount, ballast (yuk!),
wing moved aft, etc??
> Stevee.
> > BUT...
> > think
> > dont
> > it
> > the CG be
> > in
> > something?
> > Thanks -Bob Bailey-
Web Developer, http://www.autoeurope.com
Homepage: http://www.wrld.com/w3builder
From: | "Warren D. Shoun" <wbnb(at)earthlink.net> |
Dear Brent:
On page 44 & 45 of Tony Bingeles's book "The Sportplane
Builder" is an excellent discussion of the process and a deatiled
drawing for building a great bench-top tool for doing scarf joints.
I am finding a great number of other helpful hints in his
books...all available from our EAA at (414) 426-4800. Best Regards,
Warren.
> Thanks
> Brent Reed
please check out my mom & dad's web page
http://pages.prodigy.com/runway/runway.htm
Ken Hannan
Subject: | Re: MODEL AIRPLANES |
Is this an advertisement or what? It keeps showing up on the list...
hmmmmm....
> Thanks
> Ken Hannan
Pietenpols, Electronic Music,
Website Design, Stompilation
Subject: | Free Flight page |
I just went to the 'ad' page. GREAT info about Free Flight a/c!
Kudos! However, I was unable to find any Pietenpols. :( Is there
supposed to be one? If so please let me know, so I can buy/download
it! If not, can you get a FF Piet? Thanks!
Unless you have about #250 ahead of the firewall on the short fuse you
will have to do something maybe everything listed above.
I did all three.
Stevee.
Well it's good to know at least, that it can be done! :)
> I did all three.
> > be making with the short fuse? extended motor mount, ballast
> > (yuk!), wing moved aft, etc??
Subject: | Re: on nails and staples -Reply |
>Greg,
>How did you set up to boil the cap strips?
I found it easier to just drop them in a tub of water and let them soak
overnight. If I was in a real hurry, I would use boiling water and it
would only take about 20 minutes.
Dean Dayton - deandayton(at)hotmail.com
Yeah, Howard Levy of Kitplanes did a nice job.
I finished the aircraft in 1989, and first flew it 1990. After some
overheating problems were corrected it has flown steadily since. Total time is
now 320 hours with no problems with the engine. Most flights are short (under
a half hour), but we have gone from New Jersey to Wisconsin twice and up to
Maine once as well.
Jim Malley
Where in Maine did you fly to? I live in Portland.
> Maine once as well.
> Jim Malley
From: | "Gerard \"Larry\" Huber" <glhuber(at)mail.wiscnet.net> |
Subject: | Re: Free Flight page |
A small free flight 13" span rubber power model Piet is available from
Peck Polymers at better hobby shops or via mail order (check model
magazine ads for address)
Larry
Dean Dayton wrote:
> >Greg,
I'm using a 4" diameter piece of PCV pipe about 36" long with a cap on
one end. Fill about 2/3 with really hot water stick about 6-8 cap strips
in there for half an hour and then clamp in a bending jig overnight. You
now have enough top strips to keep you busy all week.
Larry
John,
With the long fus. 635 empty C-65. Wing tipped back 3 1/2in I figure CG
is 17in back from LE with 160lb pilot.
Craig
Jim,
Where are you keeping your plane? We are just up in PA. It might be neat
to fly down this spring. I haven't been doing any long distance flying
with the Piet at all. Mostly the hour before dark is best.
Craig
From: | Michael D Cuy <Michael.D.Cuy(at)lerc.nasa.gov> |
>Dear Brent:> On page 44 & 45 of Tony Bingeles's book "The
Sportplane Builder" is an excellent discussion of the
process......
What Warren says here holds true with all of Tony's tips on
how to build homebuilt airplanes. That guy's books are really
worth it. If somebody doesn't know what to get any of you guys
for Christmas, this is it. Can't say enough about Tony B. MC
Has the mail storm ended?
I've terminated the users sending CAD RIB drawings. They have flooded
mine and nearly 100 others Mailboxes to capacity.
Stevee
Subject: | Re: Dare I look? |
I sure hope so - Thanks for all your work
Larry
Allright.
Lets all sit down for a little chat.
DONT DO THAT AGAIN!!
number 1 --You will kill nearly *ANY* discussion list if you post a 6
meg file and try to have it redistributed. Most peoples mailboxes have
a limit and according to the error that I recieved back we flooded many
peoples mailboxes and sunk a few mail servers with the RIBS Cad drawing.
Never, never post large files to a distribution or news list. This is
usenet 101 folks. You send a message saying you have it and the ftp
site where to get it or email directly on request. If you limit
yourself to about 50K you should be alright.
This problem shut down our server most of the day while I went through
by hand weeding out the problem messages, not a simple task when you
have to sort through hundreds of cryptic message id's. Then when you
think you get it done you find it has stuck on another one
rebroadcasting to the world.
Number 2 -- If you want to complain kindly *REMOVE* the offending large
file *before* you reply. If not you become another offender yourself
and your *complaint* gets redistributed behind the problem message.
USENET 101.
Any Questions?
Stevee
From: | "ernest l. hagness" <ehagness(at)mail.interconnect.net> |
> Allright.
> USENET 101.
> Any Questions?
> Stevee
Stevee; Please unsubscribe me from the list for a while . It has been
jamming my mail system up and causing me problems > enjoyed it while it
lasted and will get back on some day . Thanks and goodbye for now .
Ernie Hagness. ehagness(at)mail.interconnect.net
From: | Jerry Guyer <cigognes(at)oz.sunflower.org> |
I hope people read your message. I now have abou 10 copies of a
worthless file that I don't need.
Jerry G
Thank you, thank you, thank you!
> Stevee
Please have someone good-looking kiss you for me.
Owen Davies
Well, I go to my first official EAA meeting tonight at 7. I called
the guy who runs the Portland chapter to get directions, and he told
me that there are two other people in the chapter building Piets as
well! One of the planes is right on the airport the meetings are
being held at! Looks like I found where I'll be spending MY Saturdays
for a while. :)
Richard
> > Stevee
Steve, I add my thanks to you also. I had to call my server company and
have the gal there take the "ribs" off because it had tied mine up also.
Arden Adamson
Richard,
Did you go to a meeting in Portland OR? I am down there often from Seattle.
When do they hold their meetings?
Brent Reed
Kent WA
-----Original Message-----
Date: Thursday, December 18, 1997 11:11 AM
Subject: Pietenpol-List: Piet found!
for a while. :)
Richard
I probably should have specified in my email, but the meeting was in
Portland, Maine, not Oregon. Sorry !
> Brent Reed
> Kent WA
> From: Richard DeCosta <rdecosta(at)autoeurope.com>
> Subject: Piet found!
> for a while. :)
> Richard
From: | Gary McArthur <garymc(at)admin.hilconet.com> |
I sure hope that does it, my server monitor has given me a
"nasty gramm" about the overflow in my mailbox... :(
Gary
> Larry
Subject: | FELIZ NAVIDAD!!! |
MI FAMILIA Y YO LES DESEAMOS UNA MUY FELIZ NAVIDAD EN COMPA=D1IA DE TODOS=
SUS
SERES QUERIDOS.
SINCERAMENTE SU AMIGO
GARY GOWER
ggower(at)informador.com.mx
PS To my english speaking friends:
WE WISH YOU A MERRY CHRISTMAS IN COMPANY OF YOUR LOVED ONES
SINCERELY
GARY GOWER AND FAMILY
DECEMBER 1997
test
From: | Ted Brousseau <nfn00979(at)naples.net> (Ted Brousseau) |
Stevee,
Don't let Ernie get off so easy. I think you have solved the problem and
Ernie's too valuable to allow him to unsubscribe. In the holiday spirit you
should do HIM (smile) a favor and ignore his request.
Ted
Subject: | Re: Piet Builders |
>Hi Guys:
> I am building a long-fuselage Piet at hanger D17A at
>Brackett-LaVerne Airport in Southern California. Is anyone else
>building a Piet out my way?? If anyone knows, please
>contact me at wbnb(at)earthlink.net or (818) 215-2542. Thanks!!!
I have begun the planning stages of a long-fuselage Piet here in Ramona, CA.
I am accumulating $$ and studying the plans. I have built a jig for the
continental motor mount. Have 75hp to clean, assemble. May start on
structure next summer.
I thought we eliminated this nonsense with the RIBS fiasco. If you have
pictures or other big files DON'T MAIL THEM TO THE GROUP!!!!!!!!!!
This is not a difficult concept!
>Have a Merry Christmas each and everyone of you.
>Attachment Converted: C:\NETSCAPE\EUDORA\MikeClau.jpg
Ted Brousseau (Ted Brousseau) wrote:
> Stevee,
> and
> spirit you
> Ted
I agree it is a great loss, I've emailed him privately about it. I
hope we get him back.Stevee
> it
Subject: | Re: Apology was(Re: RIBS) |
I recieved this from Randy Green and have returned his name to the list
membership.
I believe in kindness and humility.
Stevee.
PS> Welcome back Randy.
randy.green wrote:
> Steve,
> I am asking that you and the entire Pietenpol Discussion Group please
> accept my deepest apology for accidently forwarding that stupid CAD
> file.
> I too, like every one else, was disturbed at getting that file and
> being
> relatively new to the world of internet mail did not realize that when
> I
> responded to the guy that originally sent the file that I was also
> sending
> it to everyone else in the group.
> I am asking that you reconsider suspending my subscription to the
> group. I
> have enjoyed this group very much and am very excited about Pietenpol
> airplanes. I am very sorry for the the inadvertent hassle I caused and
> am
> the victim of my own accident in that it took over 1-1/2 hours to even
> get
> your message because of all the other copies that came in. Perhaps
> someone
> could explain to me why sometimes the same message gets repeated
> several
> times.
> I hope that you and the group will be understanding in this matter and
> give
> me a second chance.
> Randy Green
> > From: Steve Eldredge
> > To: randy.green
> > Subject: Re: RIBS
> > Date: Wednesday, December 17, 1997 11:11 AM
> > Randy,
> > Your subscription to the piet list has been terminated.
> Reforwarding
> > RI:Bs CAD stuff has floodded the net and filled everyones mailbox on
> the
> > whole list. People are really mad.
> > Stevee
Subject: | Re: Alternative and Ultimatum was Re: Picture |
> have
Jim,
Thanks for taking up the banner. I get tired of being the bad guy.
Everyone else:
Let me suggest an additional solution since pictures can be worth a
thousand words sometimes.
I have a web page that I would be glad to post pictures to if you want
them posted then everyone can look at them at will without cluttering up
the list. Richard DeCosta may also be willing to do this as well,
Richard? Those who send further email to the list with attachments and
pics will be instantly terminated. (I promise it won't hurt a bit.)
Stevee
Sure! I can keep images/zip files/whatever on my server here, and
possibly also on my friends FTP server. If you want an image
available to the whole group, email it to AirCampr(at)aol.com (thats
me), and I'll email you back the URL, then you can post the URL to
the group.
Richard
> > you have pictures or other big files DON'T MAIL THEM TO THE
> > GROUP!!!!!!!!!! This is not a difficult concept!
Subject: | Welcome Back Ken |
Ken Hannan is back umugst us after an apology for posting the RIBS
jpeg. I believe that everyone has been properly educated.
Glad were all back as a happy family. NOW back to our regular
programing....
Just in time for Christmas!
SteveE
Subject: | RE: Welcome Back |
Welcome back everyone. One question to wrap this mess up. What is the
maximum message size that the list wants? Are we just going to say no
attachments and no really long stories? I would think that 100 Kbytes
would be reasonable? Any comments? [caveat, make sure you know what
you are doing!]
Has anybody given any thought to my suggestion of putting Piet designs
on the web? I could host 10 meg of files from my personal web page or
my employer may agree to host it at the durapharm site. They just asked
that I estimate traffic and size requirements. Anybody talked it over
with Don or Orrin yet? Anybody know them on a social level?
Carl J. Hixon
Project Engineer_______________________
Dura Pharmaceuticals, San Diego, CA 92121
Phone: (619) 784-6747 Fax: (619) 453-2544
Web Page: http://www.durapharm.com
Subject: | Re: Welcome Back |
> the
> you are doing!]
I don't think that there is any problem with the length of the message
if it is text. How many of you know how to check to see how big the
message is going to be before you send it? At this point lets stay away
from file attachments and imbedded graphics. It is easy enough to send
them privatly or post them on a web site.
> asked
> Carl J. Hixon
Thought about it, don't know Orrion or Don personally although I have
spoken with Don on the phone. I think that it would be a plus, but the
homework would need to be done. I doubt 10 meg would do it however.
Depends on what you put up I guess.
Stevee
Subject: | Hello from Texas |
Hello,
I am new to the list. My name is Bob Seibert. I just bought a Piet
project from John Goble in Austin, Tx. It is an assembled fuselage (not
on the gear yet), empenage and wing ribs.
I am located near Taylor, Tx. - about 20 miles NE of Austin. Hopefully
our grass strip will show up on next publication of the San Antonio
sectional. It is "Macho Grande" identifier 41XS. Anybody who flys fun
airplanes is welcome to drop in. 30deg 32.31'N - 97deg 25.17'W 2500'
grass (would you believe weeds and dirt). Flybys are allowed only if
they are less than 50'AGL. (smile) Its actually pretty smooth. I fly my
RV-6 out of it using 5.00 x 5 tires.
Anyway, I'm looking forward to this Pietenpol project. Now I just gotta
clear a lot of junk out of the shop, get the fuselage home and buy the
wife another couple of christmas presents....
FIRST QUESTION-
I will start on the gear first. I am getting a couple of motorcycle rims
with the project and I do want to go the spoke rim route. I have the
equipment to build up hubs and axles. Where is a good source for spokes?
Bob Seibert
I like the idea of having acad files, graphics, etc, available for
downloading on a as wanted basis. It would be much better than having
them tossed at you at random and I really would like to have some of the
acad stuff.
I intend to put at least some of my bi-plane piet (ok i know some of you
are cringing) on acad to get the right angles, check critical
measurements etc. I did this with a Nieuport and it worked great. I
would like to discuss this with anyone interested......
Jerry
Subject: | Continental engine mount |
Anybody out their producing the Continental engine mount to Pietenpol's
supliment plans?
I'am having a heck of a time trying to get my local welder to figure it
out.
Brad Schultz
NX899BS
To all subscribers and their families,a very merry christmas and productive
newyear
Canada .
Subject: | Re: Continental engine mount |
Brad,
George Medue in Ohio welded my engine mount for me and did a nice job. I
you want me to get a phone number let me know. He must have a jig
already made up.
Craig
Thanks I would be interested in talking to him. I think I've got things
going here to get it built but that's subject to change
clawler wrote:
> Brad,
> already made up.
> Craig
Brad,
George Medue's phone is 513-849-0278.
Craig
Doug, Thanks for the Christmas Greetings! I envy you a lot being in sunny,
central Alberta!. As a matter of fact, i just got back yesterday frpom
visiting my two sons and grand daughter in Whitecourt. Great weather, great
folks!
All the best to you in 1998.
-=Ian=-
> From: Doug Hunt <ve6zh(at)cnnet.com>
> Subject: xmas
> Date: Wednesday, December 24, 1997 23:11 PM
productive
> newyear
> From my family and myself. Doug Hunt...in snowless central
Alberta
> Canada .
Subject: | Landing gear cost |
Getting down to the point of having to make a decision on what feet to
install on the bird. So far, it will be metal, with brakes. However, when I
look at the traditional cost of applying 6" wheels and cleveland brakes, I
come up with a cost of about $650.00. Has anyone got a source of alternate
materials that is not so pricey? (And that will hold up)? The plans call
for a one inch stub axle, but most of the prchased wheels are 3/4" or 5/8
". I am starting to get confused again, so I thought I would see what the
group is using as alternates.
Any comments?
Thanks, and Happy New Year!
-=Ian=-
Tried that # but get a not in service message. What town is he in?
Maybe the area code has changed. Thanks
clawler wrote:
> Brad,
> Craig
Brad,
The address I have is 68 Oaklawn Ave. Medaway Ohio 45341. I just did a
search on one of the internet phone books and don't get a listing. Maybe
I have the last name spelled wrong. Oh well we tried.
Craig
Subject: | Evil VW Engine question |
Let me preface this question with the following
1. Yes, I have read the Pietenpol FAQ and the VW engine
statement.
Question:
Does anyone know of an operating gear reduction drive
for a Type I VW engine? I'm planning on using a
highly stroked and slightly larger bore engine, with
FULL electrical system on the Piet. I was thinking
of a reduction of around 2:1
Eric Ulmer, ServiceNet
612-317-7768, 7857
Subject: | Re: Pietenpol List |
Pietenpol List Members:
Three new Piets are being built in Raleigh, North Carolina!
Myself and two other electrical engineers at BroadBand Technologies
are pooling our skills to build three Improved Aircampers. We intend
Corvair power and Cub-type landing gear. Right now we're studying the
plans, scheming, and getting ready to purchase some wood. Let us
introduce ourselves ...
Glenn Robb 919-405-4773; I'm an avid woodworker who's been making fur-
niture for about 7 years in a small basement shop. My shop is just
big enough to build a wing-half or fuselage. I've got plenty of
tools, and look forward to the ultimate woodworking project. With 65
hours, I've only been a private pilot for a month, but I plan to get
some tail-dragger time in the next year. Our group is planning to
stop by Broadhead and Oshkosh this summer.
Mark Cassada 919-405-4767; In my youth I had dreams of rebuilding a car,
building a house and building my own airplane. So far I've restored a 68 Camaro
and contracted/built my own house. The Pietenpol will hopefully fulfill
my next goal. I'm a 200hr pilot of which 70 hours are in a 1967 7ECA Citabria
I just recently purchased. I'm hoping to learn a lot during the build of
the Pietenpol. Hope to see you this summer.
Bill Beerman 919-834-4660; I'm a private pilot with ~250 hrs. of cherished
flying time. In my teens and twenties I lusted after MG sports cars of any
type, and while my MGB awaits restoration, my passion has since grown for
airplanes amd flying. I'm hoping to be able to convert my skills in automotive
work and home rebuilding to those of an airplane builder. Mark and Glenn have
promised to help me build a garage this summer to house some of our
Pietenpol-building operations. I plan to hold them to it, no matter how
buried they get in spruce and airplane dope!
Glenn Robb (robb(at)bbt.com)
Mark Cassada (mcc(at)bbt.com)
Bill Beerman (wcb(at)bbt.com)
First, welcome to the list. Second, consider yourselves very fortunate.
It's hard enough finding other interested builders on the internet.
Finding 2 other guys interested in building the same type of plane and
work together is amazing. I know that you'll get a great deal of
enjoyment from the project.
Actually, I'm building a highly modified piet with a steel tube fuselage
and enclosed cabin. It was designed by Ron Mason and he calls it a
Christavia but it's really a Piet...Honest SteveE...It's a Piet (OK,
maybe it's not but I really love the Piet list). BTW, anybody want me to
post a complete set of Christavia drawings to the list? Just Kidding!
But seriously, the Piet list is made up of a great bunch of guys and it's
certainly been inspirational to see members complete and fly thier ships.
Hope to join them this summer.
Ken
Subject: | Re: Landing gear cost |
> when I
> brakes, I
> alternate
> call
> 5/8
> the
> Any comments?
> -=Ian=-
I used Matco 6" wheels and hydrolic brakes. They manufacture for
homebuilts and I really like the quality. They are much like
clevelands, but cheaper. Not sure what prices are now. Check them out
at WWW.MATCOMFG.COM. I used the W62 model. with the 3/4" axles. You
have to choose before welding the gear to match the axles. Duane
Woolsey used the 8" azuza (?) wheel on his plane with the manual brakes
and a 5/8" axle. Functional, but not really suitable for non hard
surface runways. check my web site for a pic of his wheels. (and mine)
The long and short is.... Unless you build up your own wheels a la
motocycle derivitive, this will be one of the larger one-time outlays of
cash. I guess you could also scrounge for used cessna/piper/etc sets as
well. I saw main gear for a cessna find a home on a Christavia MK 4 for
about $400. (catch that Ken?)
Stevee
Thanks a lot Steve!
I browsed the Matco web site and it helped a lot! Any idea (guestimate)
what your package cost? I am also assuming that you have two master
cylinders (MC6) for differential braking. Thanks loads! I guess everyone is
recovering from the holidays as the chat line has been pretty quiet. I
needed a new belly pan for my Yellow Lab
as she managed to impale herself on a stump while retrieving a stick. Good
for 20 stitches and $368.00. She needed the belly repairs as a priority!
After all the First Aid courses taken at work over the years, I finally got
to apply the knowledge. Just like building a Piet, I guess, follow the
instructions and it all works out!
My next project will be a sidecar for my motorcycle so that my dog can get
to the airport with me.
Best regards,
-=Ian=-
> Subject: Re: Landing gear cost
> Date: Friday, January 02, 1998 11:06 AM
> > when I
> > brakes, I
> > alternate
> > call
> > 5/8
> > the
> > Any comments?
> > -=Ian=-
> Stevee
From: | "Larry L. Neal" <llneal(at)earthlink.net> |
I've got the steel list that Don Pietenpol provides with his plans, but
does anyone have a complete materials list?
Larry
Does anybody want to try some 5.00 x 5 Clevelands? I have a complete set
of used wheels, tires, brakes, axles and master cylinders off of a (ugh)
Long-Eze. This is a complete system minus only the brake lines and
pedals. They are in good used condition. (If you want a little larger
tire, you can buy 6.00 x 5 tires to fit these wheels.)
The axles are a standard four bolt flange. Everything was perfectly
functional when the guy parted the airplane out. I am putting spoke
wheels on my new piet project and will not need these. I would take the
first $250 I could get. (or interesting Pietenpol parts trades)
I'm at seibert.swbell.net so if anybody wants these, let me know. I'm
located in the Austin, TX area if anybody wants to drop in.
By the way, the 5.00 x 5's actually work just fine on grass strips so if
ya want a piet (or anything else) with small tires, these ought to work
as-is.
Bob Seibert
(512) 365-8918
Subject: | Engine Options for Piet |
I've put together a Homebuilt Aircraft engine site
on my ISP home account,
http://www.isd.net/eulmer/engines.html
Does anyone have any specific Pietenpol engine links
that I could add?
Also, I got John Gregga's GN-1 Plans in the mail today
and should be getting Don's full set shortly. I'm building up a jig
table in my basement now. If anyone
has any experiences building the Piet with the metal
option, I'd like to hear if you'd do it again in metal
the second time.
612-317-7768, 7857
I am curious to know if anyone took a look at the Garry Price designs,
particularly the three piece wing and gapless aileron.
the pros and cons before I purchase the plans.
Bill Talbert
Subject: | Strut and Cabanes |
What's the recomended size tubing for the cabanes and struts? Bernie's
plans don't reflect todays sizes.
Brad Schultz
brsch(at)afcon.net
NX899BS
Subject: | Re: 3-Piece Wing |
> >From the pictures I've seen, He does nice work but would like to here
> Thanks
> Bill Talbert
Hi Bill,
I don't have Garry's wing plans, but I do have his plans for the
aileron piano hinge, the steerable tailwheel and the fiberglass fuel
tank. I can tell you that his plans are beautifully done with more than
enough detail & specs to answer any question you may have during
construction. Even birdhouse builders like me can figure them out easily
without any "creative" ideas of my own. If you've seen his work, you can
assume that he "engineered-out" any cons that may have come up.
Piets Forever,
Lee Schiek
Stevensville, MI
P.S. For Skip Gadd & Dick Hartwig - nylon plate going out in 1/5 mail.
Haven't gotten any messages in a while. Is everything ok?
bed(at)mindspring.com
Is anyone out there? I just got back from a 10 day ski trip and don't have
any Piet messages.
What gives?
Barry
From: | djscott(at)heartland.bradley.edu (David Scott) |
Subject: | Wing Rib - Auto Cad - Careful what you get |
THIS IS JUST A QUICK NOTE ->
Last month there was an AutoCad drawing of the wing rib put out
on this usenet and I have found it to be not per the pietenpol
prints which are given by Don Pietenpol. Some of the discrepancies
are:
1. Spacing between front and rear spar was not 27-3/4 inches.
I found it to be about 28-1/4.
2. The last brace at the trailing edge was not from the upper
side of the rear spar to the lower capstrip at the trailing
edge. This is weaker support for the Aerodynamic forces if
it is backwards from the print.
I did not check any further.
I guess the term Caveat de-Emptor has a familiar tune.
Subject: | Re: Wing Rib - Auto Cad - Careful what you get |
I noticed this, too. Does anyone have a more accurate one? Also, what
is the status of whether or not we can make CAD drawings of the whole
plans?
> are:
Is this working?
> From: Bill Talbert <wtalbert(at)flash.net>
> Subject: Test
> Date: Sunday, January 04, 1998 11:38 PM
> Is this working?
Yes it is working(i guess) Doug ve6zh(at)cnnet.com
OK, here is the message where I let everyone know just how much of a
beginner I am in all this! :) I am ready (financially speaking) to
get outfitted to build my Piet and order the materials to build the
ribs. HOWEVER, I would like advice in the tools I purchase. I have
done some woodworking, but not alot. So, not only will I be learning
to build an airplane, I will be learning fine woodworking skills.
Soooo...
Can anyone who has the time please email me (or the list, if you
feel they could benefit) any advice about what tools are best for
building a Piet. All I have right now is a couple screwdrivers and a
shiney new hammer I got at Home Depot this past Saturday. The more
specific the reply, the better. :)
Thanks to any and all who reply!
Richard
http://www.wrld.com/w3builder/piet
Subject: | Re: Piets HELLO? |
Barry, SSSHHH! We're all calculating W&B at the same time!
Larry ;-)
> any Piet messages.
> What gives?
> Barry
I seem to have lost my address to the guy who was making Corvair prop
hubs.
I'd rather support another homebuilder remotely than work with a local
machine shop, to be honest.
Does anyone have the name?
Larry
Subject: | Re: Tools, etc... |
Richard,
I, too, am just beginning my Piet project. Started by buying a bench
grinder/sander, a good sturdy bench vise and a good quality hack-saw. Am
beginning with metal fittings, (elevator and rudder horns), and tail surfaces.
The sander is good for sizing the wood pieces, as well as the steel ones.
Ordered spruce from Wicks, got it shaped at a local cabinet shop and am now
gluing up the rudder. It's fun to see the first pieces that are recognizable
as aircraft parts. I suggest you get cast aluminum hinges from Vi Kapler,
(he's on the BAP homepage). Check Harbor Freight for affordable power tools.
(ADonJr(at)AOL.com)
From: | Greg Cardinal <CARDIGJ(at)mail.startribune.com> |
Subject: | Tools, etc... -Reply |
I would highly recommend a good quality compound miter saw with a
GOOD fine tooth carbide blade.
I purchased a 10" Delta for $ 175.00 and a 40 tooth blade for around
$50.00. I cut all the rib uprights in a single afternoon and they fit very
nicely.
Greg Cardinal
>>> Richard DeCosta 01/04/98 04:08pm
Soooo...
Richard
Subject: | Re: Tools, etc... -Reply |
You MUST get a drill press. It is the one bench power tool you won't be
able to get by without. All those holes must be drilled
with as much precision as possible. A benchtop one is all you need.
After that a bench grinder and table saw.
john
I was under the impression that most of it could be built with hnad
tools (non-power tools). Is this not the case?
Richard
> john
> Content-Length: 516
> Richard
> > john
Cabinet maker precision is necessary on much of the structure.
Holes must be straight and line up to mating fittings with very close
tolerances to properly transfer loads from metal to wood... ESPECIALLY
spar and lift strut fittings. Perfectly perpendicular holes are one of
the most important aspects of aircraft construction from a structural
standpoint.
You can do just about everything with hand tools except drill perfectly
perpendicular holes like spar fitting holes and longeron holes.
Therefore a drill press is essential. Drill blocks can be used to make
straight holes when a drill press won't work, but a drill press should be
used wherever possible.
A bench top model is handy because you can move it around on a jig table for
doing longeron holes on your fuselage etc. Check for quality by running the
chuck all the way down and jiggling it sideways to feel for side play. The
cheap ones can move from side to side quite a lot, which can mean irregular
holes. Buy the one with the least side play.
All the other power tools are basically nice-to-have time savers.
Personally, I would not want to fly an airplane where the holes for the
primary structure were drilled by eyeball with a hand power drill.
john
Bombardier Inc.
Subject: | Re: Propellor Hubs |
<< I seem to have lost my address to the guy who was making Corvair prop
hubs.
Larry >>
William Wynne, formerly of PAS has a nice hub for $399. I am calling him this
morning to place an order for a cam. Phone 904-426-7795.
William Koucky
Subject: | Tall wheel spokes |
Two questions everybody. . . . .
1. I'm making up tall wheel hubs per Henderson/Pavliga design, with
brake addition. Source for ROLLED thread spokes?
2. Brakes to be mechanical & used only for taxi manuvering & parking.
Question: Do I REALLY need to consider a different spoke layout to
absorb loads, or can I keep straight lace arrangement for looks?
Has anybody actually experienced axial load failure caused by braking
loads against straight lacing?
All opinions, thoughts, second guesses appreciated.
Lee
Subject: | Re: Strut and Cabanes |
> Bernie's
> Brad Schultz
> brsch(at)afcon.net
> NX899BS
Get the equivalent round tubing conversion table in the aircraft spruce
catalog. I used it to find the size then went up one size just for
safety's sake. I think I ended up with something like 1-1/4" x .049.
don't clearly remember however.
Stevee
Subject: | Re: Tall wheel spokes |
Lee
>> Hi Lee: John McNarry here. I would recommend that if you build tall
wheels that you do widen the hubs. The ability of motorcycle wheels
to absorb loads perpendicular to the axle is very good, but I've
managed to bend sidecar wheels.( Oh all right. I was driving it
beyond its design.) I would expect that some day if you fly long
enough that a strong side load will be transferred to the gear
through the wheels. Therefore wide hubs are nessacary!
I got around the problem of longer spokes by fabricating a larger
outer hub flange. ( Drilled full of spoke and lightening holes it
looks ok.) Decide on how wide you want to go and then swing an arc
the length of your present spokes. Were the spoke length line
intersects the flange line will determine your new hub spoke circle
diameter. I made mine slightly cup shaped. \------/ ?
An altenative to fabricating Hubs would be to spend some time
looking at used motocycle junkyards. Rear dirt bike hubs are usually
quite wide and a 21" front rim may lace on.
J Mc
ADonJr wrote:
> Richard,
> hack-saw. Am
> surfaces.
> ones.
I hope you are not sanding surfaces that are to be glued. Sanding clogs
the pores of the wood and weakens the bond. I did nearly zero sanding
on my project. Most material removal and cutting should be done with
carbide tools and saws and finished with a sharp hand plane. All finish
cuts for my wood parts were done with a 200 tooth 7 1/4" hollow ground
crome blade. Very smooth clean cuts.
Power sanders are an invaluable tool however for metal fittings. Much
better than a grinder.
Stevee
> am now
> recognizable
> Kapler,
> tools.
> Piets!
> Cooley
> (ADonJr(at)AOL.com)
> From: "Lee L. Schiek" <concrete(at)qtm.net>
> Subject: Tall wheel spokes
> Reply-to: Pietenpol Discussion
> Organization: Concrete Specialties Corp.
> Lee
> J Mc
Hi John, Thanks for input. My hubs will be 6" wide, so I guess I'm not
too worried about side loading. My main concern is loads on straight
spoke lacing with brakes (originially I said "axial" - maybe I meant to
say "torsional" loads. In other words, with straight spoke lacing, there
is less resistence & strength to braking loads at the hub; that's why
Model A cars etc cross-laced the spokes-to absorb the braking action.
But I like the looks of of the Henderson-type straight lace, but then
again, he didn't have brakes. What da ya think, and where are ya at
in your Piet project?
Lee
Subject: | Re: Tall wheel spokes -Reply |
A source for rolled threads is:
Buchanan's Frame Shop
805 West 8th Street
Azusa, CA 91702
(626) 969-4655
Rambling comments on rims found at a junkyard:
Rims drilled for 36 spokes are MUCH more common than 40 spokes.
Look at the bigger Hondas and Kawasakis for 40 hole rims.
Pre-drilled rims will have spoke holes drilled at angles that don't allow
them to be used with straight spokes, re-drilling will be necessary.
Good luck finding a matching pair of rims. It took two of us over 3 hours
searching a motorcycle boneyard before a matching pair were found.
The weight difference between alloy and steel rims is not great.
Greg Cardinal
Dear Lee:
I also used Buchanan Spoke & Rim, Inc. (805 W.
Eighth Street, Azusa, Ca. 91702 telephone (626) 969-4655 fax
(626) 812-0243 to redo some Honda Trail 90 36 spoke Hubs and
rims. I had them true and relace with 9 gauge stainless
steel spokes. The spokes cost $1.00 each and the labor was
$54.00. per wheel. Not cheap. Each spoke will take in
excess of 1,000 pounds of terror and there are at least 8
spokes in EACH wheel at work all the time. The finished
product looks beautiful and are hell-for-stout. If I were to
do it over, I would change the rim to a 16" or 18" as
these size motorcycle tires with good load range are much
more readily available and cheaper.
> 805 West 8th Street
> Azusa, CA 91702
> (626) 969-4655
> Greg Cardinal
Great info! Thanks a bunch!
Lee
Hi Lee
I've built my wheels, tail feathers, ribs and fuselage sides. I
have been working on my engine a B ford block much modified. I
decided on the tall wheels split gear with brakes. I don't like the
thought of taxiing, on hard surfaces, near expensive aircraft with
out brakes. I intend to cover the spokes with fabric disks and so the
cross laced motorcycle wheels won't detract from the appearance. I
have been thinking about brake operating mechanisms but haven't
developed much past the mental image yet.
Piets are Fun! J Mc.
From: | Domenico Bellissimo <DCSBell(at)netcom.ca> |
> Soooo...
> Richard
Re: Your tool requirements. Buy anything that has anything to do with
woodworking. Just kidding. You will need a table saw with a std. blade,
a rip blade and a planer blade. A band saw is not necessary, I converted
mine to cut 4130. Small tools such as hand planer you will definitely
use. You will need some 'C' clamps and some hand spring type clamps.
Chisels, at least two different sizes. Large square, and a small one
too. If i left anything out buy it anyway you will probably use it. Oh
yes a measuring tape and make sure you measure everything 3 times or you
will end up building more than one aircraft. At least I did. Anyway I'm
on ICQ Nick:C-GDCB, you have already authorized me to your user list.
Domenico Bellissimo
> hubs.
> Larry
If my memory serves me right I believe the person who has the drawing
for the three piece wing also has prop. hubs available. And again if my
memory serves me right it's Vi Kapler?? Can anyone confirm???
I'm sure I read this in one of the BPA Newsletters.
Regards Domenic Bellissimo
Subject: | RE: Tools, etc... |
Another question about tools:
Can anybody point me to a good pneumatic-adjustable-speed-floor drill
press? I was thinking that since I have this awesome compressor...it
might be cheaper?
Carl J. Hixon
Barry,
Please try again.
Stevee
Larry,
I understand that Vi Kapler also has Corvair propeller hubs. Check the
BPA homepage for his address.
Mike List
> hubs.
> Larry
Subject: | Re: Evil VW Engine question |
> statement.
> Question:
Eric,
I saw a Wittman Tailwind (small two seater, high-wing cabin type) with a
Type 4 VW/Porsche engine with a reduction drive at the Lancaster Air
Races. The owner's name is Ivan Andersson and he had the cowling off so
you could see the engine. The drive consisted of a long shaft over the
top of the engine supported by bearings and driven by belts at the
firewall side of the engine. There is a picture of this airplane in the
December 1997 issue of Sport Aviation, p. 78. He was using a 3-blade
prop as well.
The airplane flew OK and sounded quite different in the air, but keep in
mind that this is a very clean, small airplane compared to the Piet. I
don't think that this particular combination would work on an Air
Camper, and even with the reduction unit it is too light to balance the
Air Camper. The light weight, not the torque output with a reduction
drive, is probably the main reason for keeping the VW's out out of the
Air Camper.
Mike List
They make them at Brodhead. Try e-mailing Lee Stanton at (
ljsc37(at)brodnet.com) he should be able to steer you to the right person.
Also think Vi Kapler in Rochester has them,
> hubs.
> Larry
Lee,
I'm not absolutely positive about the 1st question, and I'd say that rolled
threads carry more load than cut, yes. I doubt though, that you'll find any
spokes of any sort with rolled threads, they don't carry *that* much load to
be effective. Sorta like hammer forged belt buckles.
Regarding straight spokes. I submit that this will be a problem. Any
braking loads will be greatly amplified, (though I'd betcha it busts in the
middle not on the "non rolled" threaded side). Landing loads are diminished
as well, versus most crossed patterns.
Please don't do this, they will definitely loosen up at the least. This is
not Piet experience, but bicycle stuff, where the weight vs strength issue
is even more important.
To be honest, straight spokes don't look that spiffy anyway....
I have not read the referenced design notes and I still don't have a Piet
built, so take it for what it worth. I'll take your question as a heads up
and read this stuff, though I am currently planning to use a couple of
mid-sized motorcycle front wheels myself.
Larry
> Lee
Richard,
Good question, and though I know that you've already gotten some
replies, I'll add my two cents worth.
Clamps, clamps, clamps!
When you're tired of buying these, as Santa for more......
When Santa's tired of delivering, pistol whip your piggy bank and get
more.
Long clamps, spring clamps, screw clamps, pipe clamps, visegrip clamps,
bench clamps.
Anytime you glue wood, you want to apply pressure and make sure that
it's directed properly as well as evenly distributed.
This makes clamps the one thing that you can *never* have too many of!
Larry ;-)
> Soooo...
> Richard
Subject: | Wire Spoked Wheels |
To all you tall spokes folks out there, I salute you! Can any of you
tell us how much your wire spoked wheels weigh, with or without tires
and brakes? Thanks.
Mike List
From: | Jim Wright <jwright(at)bcsbel.be.Lucent.com> |
Subject: | RE: Evil VW Engine question |
I too have been wondering about ... (Here I go...gulp!) VW engines for the
Pietenpol. After reading Eric's question, I did a web search and came up
with the following site:
http://www.arc.net/Able/prod03.htm
Prices are a bit steep for someone who has bought $500 VWs before (Over
$5000), but what's interesting is their claim that the engine is maximized
for 2500 rpm and can utilize a 70 inch prop. This would appear to bring
the conventional wisdom into question. I have to believe that with the
right non-stock parts, even one of us "Low and Slow" guys could put a VW
engine with similar performance. Just think of it as a Corvair running on
four cylinders!
I'm a Model A fan myself, but as I am currently living in Belgium. The VW
would appear to be the only Belgian-approved non-certified engine that is
flying here in amateur built aircraft.
Jim Wright
jgw(at)skynet.be
> statement.
> Question:
Richard- I found that taking your .060" and .090" 4130 chromolly sheet steel
to a place which can shear off various width strips for your fittings is
handy.
Ask them to shear parallel to the white printing on the steel too. This shows
the grain of the steel. (Tony B.'s books explain why) Also a band saw with
a slower moving blade works great on fittings. I imagine Bernard P. used
a hack saw for his early planes and that would work fine today as well, but
you'll find out what works best for you as you go. Mike C.
Lee- try your local motorcycle shop and ask them if they can order a set
for you thru Buchannen's (spelling) in CA. They rolled my spokes after
my local shop faxed them a sketch of my homemade hubs and intended
rim size, etc. They were not cheap but they are the way to go. I'm told
cut threads can be much weaker and should be avoided.
loads (and acceleration in the case of a motorcycle). Straight spokes are
used if you have no brakes. Maybe we have a lurking mechanical engineer
in the audience who might shed some light on this for us.
>Lee
Subject: | Wire Spoked Wheels -Reply |
I don't have mine together yet but I will let you know when they are
finished.
Greg Cardinal
>>> michael list 01/06/98 05:06am >>>
and brakes? Thanks.
Mike List
Subject: | Re: Wire Spoked Wheels -Reply |
> From: Greg Cardinal <CARDIGJ(at)mail.startribune.com>
> Subject: Wire Spoked Wheels -Reply
> finished.
> Greg Cardinal
> and brakes? Thanks.
> Mike List
21" X 3" alloy rims ,brakes and backing plates. Less tires 18 lbs
each
J Mc
P.S. If you are considering tall gearand brakes, may I suggest the
split type as it allows easier tranfer of brake torque to the
fuselage.
Subject: | Re: Wire Spoked Wheels |
Dear Mike:
My Honda Trail 90 wheel with 9 guage stainless steel spokes and
Dunlop F17-100/90 tire & tube, with mechanical brakes & axel, weighs 17.5
pounds and is 24 5/8" tall by 3 3/4" wide.
> and brakes? Thanks.
> Mike List
Subject: | flying 3x in 3days |
Flying is great.
For Christmas my wife (bless her heart) bought me some thermal
underwear, the warmest socks on the planet, and sent me off flying. A
brother in law gave me a new pair of smith snowboard goggles (he owns a
snowboard shop). Needless to say I had few excuses left but to go fly.
The pre-Christmas snow storm had nearly melted off and with all the
family obiligitory visits out of the way the New Years weekend was a
time to fly. I had Thurs and Fri off and the weather turned warm.
Checking my new panel mounted thermometer it was a balmy 39 degrees. I
finished my preflight by hand propping the engine through a half a dozen
times to get the juices flowing (mine) and a little pre-start oiling for
the engine. The old Continetal sprang to life on the second pull and I
even remebered this time to turn on the fuel! After a quick oil
pressure check, I start to pile on the layers of clothing while the
engine warms. A couple of my comrades drive by retreating to their
heated hangers to piddle with their planes. They have become accustomed
to my mid winter flights. Their passengers however-faces glued to the
frosty windows can't believe their eyes as they see this abobinable stay
puff pilot stuffing himself into an open cockpit puddle jumper. I must
have answered the "Isn't it freezing?" question 10 times. It's not
really that bad. Warmer in fact than any snowmobile trip I've been on.
Admitedly though, my flight at 22 degrees was a short one.
Taxi over for fuel. Filled the tank for $18.01 and flew all three days
and still have some left. Was a joy not to have to shell out 50 clams
an hour anymore. I could really get used to this idea! The flights are
full of things to do. After every flight I add something to the
fix/adjust it list. -provides a good excuse to go flying again. I
think that I finally fixed my tailwheel problem. I cut about 2 inches
out of the spring and nicopressed the tailwheel cables at the most
comfortable length. I can now get the tail down on landing most of the
time. The rest of the time can be blamed on the novice tailwheel
pilot. The static source is still giving me fits. Instead of reading
20mph over now it reads 20mph under. I've tried behind the panel under
the seat, in the rear cockpit, non at all, and now through the rear
cockpit aluminum. For those of you that are still building your wings,
you'll save yourself this greif by running a second line up to your
pitot tube that can be used as a static port. One solution that I did
find is that without the front pit cover on all my static problems go
away.
Fridays flight was very short. On the surface the winds were nearly
calm, but at 100' I started to get pounded. Good thing for seat belts.
They were used several times during the next 15 min to keep my body from
departing the airframe. I had an unexpected shake test as the
turbulence thumpped me sensless. 20 degree buffets left and right and
gusts in every direction convinced me that this wasn't fun anymore.
Strangely on 100' up on final the turbulence stopped and I got down
without breaking anything. That was enough for the day. (so I
thought) After getting home, I re-flew my landing enought times that I
couldn't shake my disappointment in myself that I went back out to the
airport. After checking the wind and watching others overfly I could
tell that the turbulence had passed. I jumped in and ran another
curcuit and made a great landing just to make sure I could go to bed
satisfied with myself.
Saturday was the warmest yet. I think we topped 50 degrees! The snow
was nearly gone except for the 10' pile at the ramps edge. I decided to
do some GPS checks on my cruise speed. I picked up a ground track that
followed I-15 south for about 15 minutes. The GPS numbers confirmed my
suspicion that I was going pretty slow (one formed by noticing that
every car and truck on the interstate was passing me), a whopping
59mph! I turned around and flew northbound and felt a little better now
that I was passing the semi trucks. Passenger cars just about stood
still as I clocked 74mph! I predict close attention being paid to winds
during future cross-country flight planning. I got my first rain drops
splattering my windsheild and forehead as I entered the pattern to
land. I can't wait for longer-warmer days of spring to arrive!
I am very pleased with this little flying machine!
Keep building!
Stevee
A comment was made the other night about the Piet's spinning
characteristics (negative). Anybody on the list spun their airplane and
lived to tell the tale?
john
Bombardier Inc.
Subject: | RE: flying 3x in 3days |
Steve,
If I wasn't ready to build a Piet already - I would be now!! Great update!
Jim Wright
jgw(at)skynet.be
Spruce question:
I can get 1/4 sawn Sitka 2x6s from a commercial wholesaler here in Toronto
in 16 ft lengths. Don't know what the quality is like right now.
Assuming I can select planks that meet mil spec, roughly how many boards
would I need for the entire airframe?
johnk
Bombardier Inc.
> and
> john
> Bombardier Inc.
Not yet, but I can tell you I have never flown a better slipping
airplane. You can tell when you are slipping because the airstream gets
around the windshield and hits you in the face.(Awesome!)
BTW what was the negative spinning comment?
Stevee
John Kahn wrote:
> Spruce question:
> Toronto
> boards
> johnk
> Bombardier Inc.
About 8. four for the spars. 1 for the longerons. 1 for the tail. 1 for
the fuse cross members 1 for everything else. You might get by with
seven, I used a total of 108 board feet. The one thing I did hate was
watching all that good lumber turn to dust as I cut it to dimension.
Stevee
PS. Let us know the $$.
An engineer I was talking to was just recounting a story of a friend
of his that had a Peit years ago who went and spun it and it took a
long time to recover. I had read previously that the airplane spun
quite nicely, so maybe the particular airplane had CG problems or
something.
One thing I remember from an Oshkosh forum a couple of years ago was
a recommendation to build in about 3 degrees of washout into the wing
during the covering process to make the stall characteristics much more
benign (the wing has a reputation for wanting to let go all at once in
a stall, which would also aggravate the spin tendency). With washout the
stall became very docile.
johnk
I was quoted $8.29 Canadian a board foot, which is about 6$ US right now
with our dollar way down in the dumps.
So that's about 85$ US for a spar. This is a wholesale supplier. They don't
sell to the public. I have to buy using a friend's numbered company sales
tax codes etc.
A spar of certified grade spruce would cost about 50% more.
Shouldn't a 2x6 yield a fair amount of cap strip and other material as well
even if it's only 1 1/2 x 5 1/2?
johnk
Subject: | Swivel Tailwheel |
While tuned into the History channel the other night, I saw a really good
program on the characteristics of the F4U Corsair. It appears that it had a
swivel, non-steerable tailwheel, that was locked for take off and landing.
It seems that it would simplify the rigging associated with attaching a
steerable tailwheel to the Piet.
Any one tried this? Obviously, I am not a tailwheel pilot (yet). I saw
comments on the Chat group the other day about someone supplying a unit,
but fat fingers errased the message.
I see the whole gammut of skid, to fixed tail wheel, to steerable
tailwheel, to swivel tailwheel. Can anyone point in the right direction to
resolve what the pro's and con's are of each? I have ruled out the skid
because I will be on 50% grass and 50% asphalt.
All the best in 1998,
-=Ian=-
From: | Kevin McDonald <kevin.mcdonald(at)dev.tivoli.com> |
> > and
> > john
> > Bombardier Inc.
> gets
Hmm,
I have not even tried a stall in mine yet. A 15,000 hour pilot
took it up and said it dropped a wing severely and took a few
hundred feet to straiten it out - I believe that was power on.
He recommended several thousand feet altitude before stall
training for someone unfamiliar with the aircraft.
My CG is at the aft most limit but I still would not expect
J-3 type characteristics from any Piet!
My logbook shows loops and rolls from previous owners but
I'm content with a nice pasture jumper and I'll leave the
more intense maneuvers to airplanes designed for that purpose...
Fly Safe
Kevin
Austin, TX.
Subject: | Re: flying 3x in 3days |
Stevee,
Are you using a preheating system of some sort? My C-65 wouldn't start
the other day when it was 50 or so. I don't have elec. out to my hanger,
so I need to come up with a system to get the time warmed up.
Craig
Subject: | Re: Swivel Tailwheel |
Dear Ian:
Real Piet Pilots would probably be better informed than me....Have flown
Piper Cub, Aeronca Champ, Piper Vagabond and Luscombe. Steerable tailwheel is
definitely a plus on airports where you want to keep from hitting other birds.
It does wonders for your blood pressure and those who would like to stay
friends and fly with you. At these slow speeds you might be O.K., and I think
you would go to steerable rather than simple swivel if you taxied both down a
flight line with a crosswind blowing.
> -=Ian=-
> -=Ian=-
Well, with my limited tailwheel experience, I think the best tradeoff is
a tailwheel that is stearable but has a spring type lock so that the
tailwheel can be made to swivel. This allows you to lock up a wheel and
swing the tail gor tight maneuvering but still retain some level of
control during take-off, landing and taxiing. Both Scott and Maule make
such tailwheels and I believe it's generally agreed that the Scott is a
better (though more expensive) unit.
I have an old Maule tailwheel that only unlocks when the tail is swung to
the right. I'm not sure if this is supposed to work this way or if it's
broken. Anyone out there know if this is normal?
Actually the tailwheel you described is fairly common among warbirds.
I've seen simular arangements on T-6 Harvards (yes, Harvards, I am
Canadian after all). I believe they were also used on the P-51 and P-47.
BTW, I also saw that episode. Planes of Fame, wasn't it? It's a great
show. They walk through everything from the pre-flight to shutdown. So far
they've don the P-38, Corsair, PT-17, and my personal favorite, the
Chipmunk. They were running all day on Christmas Day on the Speed chanel (I
believe).
Ken
Much about tail wheels deleted
I use the matco 6" solid tail wheel. It is lighter than certified stuff
but still much more beef than is really needed for a piet. It weighs
about 4.5 lb. I think. It is steerable and fully swiveling both
direction. I have been very satisfied with it so far. I have flown
from pavement only so far and can't imagine what is would be like
without tw steering. Check their web site. www.matcomfg.com I know
that they are avail. from aircraft spruce for about $125. They also
have an 8" pneumatic one too.
stevee
Locking full swivel tailwheels were very widely used especially on large
taildraggers for many years. You lock the tailwheel straight when you line
up on the runway. With the tailwheel locked there is still a fair amount
of directional control from rudder and brakes especially as you speed up.
The problem is that all directional control when slow taxiing on full swivel
is with brakes, so the airplane must have easy to operate wheel brakes.
My personal preference is a lock-to-steer/full swivel tailwheel (I will
probably have to make it myself) with a locking pin that would lock the
steering horn to the wheel fork for steering and you could retract it from
the cockpit to let it full swivel.
johnk
> From Steve(at)byu.edu Tue Jan 6 13:45:29 1998
> Date: Sun, 14 Sep 1997 04:02:16 -0500
> From: Kevin McDonald <kevin.mcdonald(at)dev.tivoli.com>
> Subject: Re: spins
> Sender: Maiser(at)adena.byu.edu
> To: Pietenpol Discussion
> Reply-To: Pietenpol Discussion
> Organization: tivoli
> Mime-Version: 1.0
> X-Mailer: Mozilla 4.01 [en] (WinNT; I) (via Mercury MTS v1.32 (NDS))
> X-Listname:
> Content-Length: 1133
> > > and
> > > john
> > > Bombardier Inc.
> > gets
> Hmm,
> Fly Safe
> Kevin
> Austin, TX.
The amatuer aerodynamicist in me thinks that in Piets with no washout
a set of stall strips along the inboard wing would cure the nasty stall.
I don't believe the problem is in the airfoil.
As I understand it, with a rectangular wing and no fuselage intersection
to encourage root first separation of the airflow there is no root-first
progression and the wing goes all at once unless there is twist (washout).
Stall strips along the inboard leading edge might help out a lot by doing
more or less the same thing.
An aquaintance put stall strips on his Thorp T18 (which stalls like a
P-51) and it became a pussycat.
It'll be several years before I get to experiment with all this alas...
johnk
Bombardier Inc.
Steve,
Congradulations on flying over the holidays. I loved the comment about
everyone saying it must be freezing. I flew my Nieuport 17 that same
weekend and got the same questions. I try and fly at least once each
month of the year. Making a Model B powered bi(piet?) for my wife, and
can't wait to get going...
Jerry
> From: Michael D Cuy <Michael.D.Cuy(at)lerc.nasa.gov>
> Subject: Re: Tools, etc... -Reply
> Date: Tuesday, January 06, 1998 7:20 AM
steel
> handy.
shows
with
used
but
------------A good and very cheap way to cut 4130 sheet metal fittings,is
to take a hacksaw blade and grind down the backside of the blade until it
will fit into a jigsaw(variable speed is best ).Break of the blade to the
desired legnth. Clamp down the sheet stalk to your bench,safety glasses
on,and it will cut like butter,even on gentle curves.When the blade wears
out,a couple of minutes has a fresh one ready to go.A single 12 inch
hacksaw blade will yield several high quality blades.----------Doug
Hunt--------
Steve,
Sounds like a lot of fun! Why do you think you are not getting up to 85
m.p.h. like you anticipated?
Brent Reed
Date: Tuesday, January 06, 1998 8:09 AM
Subject: Pietenpol-List: flying 3x in 3days
>Flying is great.
>away.
>Keep building!
>Stevee
Does anyone have the discussion group e-mail from 12/15/97 to 1/5/98?
Seems I have a gap in there. If someone can zip it and e-mail to me I'd
sure appreciate it.
Steve, thanks for getting me back on line.
Bill Talbert
Recieved my #58 news letter today. Doug Hunt
Stevee,
For someone from Florida, what are snowboard goggles? Something good for a
piet pilot? Something I should be looking for?
Ted
> A brother in law gave me a new pair of smith snowboard goggles (he owns a
>snowboard shop).
>Steve,
It is obvious - he was trying to fly level.
I love it when the tower asks me to keep my speed up and I push the nose
down to get it up to 80 mph - the fastest speed of the trip to land... Go
figure.
Ted Brousseau/APF
nfn00979(at)gator.naples.net
Sunny SW Florida
> tax codes etc.
> johnk
hi John,
If I remember correctly, it was such a long time ago, I believe i did
cut all my cap strips from 1x6x16'. Send me your home email. Dom.
Hello list,
Does anyone have experience with the 65hp Lycoming? I have one that
probably saw service on a airboat. Is it worth rebuilding for use on
the Piet and are there any parts available?
Bob Bailey
Subject: | Re: Lycoming O-145 |
An interesting engine but parts, service, reliability,
life expectency, and actual power output indicate that the
Continental A-65 is a better choice.
But if you want something unique....
~ktm
> Hello list,
> Thanks,
> Bob Bailey
> Hello list,
> Thanks,
> Bob Bailey
RUN!!! Don't just walk away! Research it carefully. . . .it came off an
airboat because it was TOO dependable & in-spec for aviation use?....
Seriously Bob, low HP Lycomings & Franklins can EAT YOU ALIVE in rebuild
costs. I'm sure there are exceptions out there, but look very carefully
and plug-in airworthy parts costs before you commit to it. For the
money vs. dependability factor, I think I could end-up with with an "A"
powered Piet with 5 spare engines. My neighbor/friend/fellow adult-
beverage consumer has a $20K+ Flybaby: 4K for airframe + ?? for Lycoming.
Ted Brousseau wrote:
> >Steve,
> 85
Ha ha ha! that is great!I really don't care what my top cruise will
be. I choose the wrong design if I was looking for better cruise.
> nose
> Go
> figure.
> Ted Brousseau/APF
Snowboard goggles BTW are just like ski goggles as far as I can tell,
unless you are talking to an avid snowboarder.
Stevee
Any feedback on using the CAM Honda conversion in an Piet? It weighs around
240 lbs and puts out around 100 hp.
I just feel it would be more reliable than a flat head.
Website http://www.eclipsecat.com
The home of Advantage Software the makers of Eclipse
From: | jkahn(at)picasso.dehavilland.ca (John Kahn) |
Subject: | Re: Honda engine |
The CAM conversion is pretty expensive in the end, as are the
soob conversions once you pay for all the reduction drive stuff.
Ironically I think the cheapest way to go is with one of the small
continentals, or the model A/B.
The Ford engine is pretty reliable, and has a very robust looking
forged crank with a huge bearing at the propeller end, just like a...well..
an aircraft engine. I have not heard of them coming apart internally...
One engine I would like to use is Model B engine (which has an even
beefier crank with full pressure lube) and which can be made to produce
over 60 hp. It was a certificated engine in the prewar Funk airplanes.
johnk
Bombardier Inc.
From: | "Sayre, William G" <William.Sayre(at)PSS.Boeing.com> |
"I just feel it would be more reliable than a flat head."
It's funny how often we hear that the old Ford engines are unreliable
and yet the most common failure is with the one aircraft part mounted to
that engine....the mag!
> From Steve(at)byu.edu Thu Jan 8 15:03:00 1998
> Date: Thu, 08 Jan 1998 11:57:47 -0800
> From: "Sayre, William G" <William.Sayre(at)PSS.Boeing.com>
> Subject: Re: Honda engine
> Mime-Version: 1.0
> X-Mailer: Internet Mail Service (5.0.1458.49) (via Mercury MTS v1.32 (NDS))
> X-Listname:
> Content-Length: 234
> Bill
And you can get a dual ignition head for it to get around that problem
as well.
There *is* another auto engine I've always wanted to investigate deeper...
It's actually a truck engine; the NAPS-Z series used in Datsun pickups
through the early 80s. It's an inline 4 with aluminum head, an alloy
forged crank, 5 main bearings, in the 2 litre range...
and it has a DUAL IGNITION head.... yup, two plugs per cylinder... you
could run one set of plugs from the distributor hole and the other set
from a mag driven from the cam or somewhere...
Being a truck motor it should be able to produce 60-70 hp in the low 2000
rpm range without too much trouble, direct drive. Unlike the model A you
would need to run the prop off an extension shaft with a support
housing/bearing like the Wittman V-8 conversion.
johnk
From: | "McNarry, John" <Mcnarry(at)assiniboinec.mb.ca> |
The old Ford engines do have breathing problems but the low rpm, and
that long rear main bearing to handle gyroscopic loads sure make the
direct drive viable. Simplicity!
I always thought the Datsun had dual plugs for emmission reasons. I
think they turned off one set at higher manifold pressures. ?
Sure do like my Honda Civic though its so damn reliable I call it the
fridge. Use it forget it! Now does that reliability move with the
engine to the airframe?????
J Mc
If you go to the Ford links on the Piet web site you can
find an article by a fella that got the Model A up to
65 HP with the right head carb combination. That's at
about 2300 RPM, still plently low enough for a good size
prop.
On a NAPS-Z engine I would use the dual plug head but
dispense with the dual head ignition rotor in favour of
a true dual ignition installation, say a normal distributor in the
distributor hole and a mag driven somewhere else.
The other nice thing about the Datsun engine is the cam is
driven by a duplex roller chain instead of a belt.
clawler wrote:
> Stevee,
> hanger,
> Craig
Craig,
Sorry I didn't respond to this earlier. Funny you should mention this.
I had the most difficult time starting my engine when it was around
48-50 degrees. I cant say that it really means what it implies, cause
I think that I have learned something about starting these old engines.
I have found that during preflight after checking the oil that pulling
the blades through 12 times or so with the fuel off loossens things up
a bit. After the preflight is done, but before going mags hot, I again
flip the prop, but this time with the fuel on, and with gusto. Gutso=
grabbing the prop with both hands, one on each blade (one overhand one
underhand) and spinning the prop through as fast as I can. I have found
that if I can build enough momentum up to get the prop through one extra
compression stroke after I let go it is lubricated enough. This action
also creates enough suction to get the fuel into the cylinders. At this
point I go mags hot (check tailwheel for tie-down) full rich, throttle
completely closed, and give it a good flip with both hands on the
decending blade, leg doing the swing kick and all. If it doesn't start
on the first or second pull, I go mags cold and do a couple more gusto
flips. After the engine starts I leave it running at idle and check oil
pressure. I get about 10-15lbs. I use this engine warm up time get
dressed in my warm gear. I let it idle for about 5 min before going to
1000rpm.
Hope this helps
Stevee
> > Mime-Version: 1.0
> (NDS))
> > X-Listname:
> > Content-Length: 234
> unreliable
> mounted to
> > Bill
> as well.
> deeper...
> pickups
> 2000
> you
> johnk
Hey I thought I was the only one with this dream! I have had four
nissan pick-ups and loved each one. We drove them for 100k + miles and
sell it and buy a new one. Currently I own a 90' Nissan with the Z24
engine 4 cyl 134hp 93K miles and runs like a top. Even if I did run it
out of gas last night on the hiway.
Stevee
Hi guys Happy new year
Have any of you guys seen or may have a Piet with a passenger door.
The other weekend I dummied up the center wing struts and put a rib where in
should go, blocked the fueselage up where it will be when gear is under it.
Than got the dear wifey to try to get in the passenger seat, well it didnt
go over very well specialy after the coke crate slipped out from under her
when she was getting out, any to keep peace in the family I promised to see
about a door.
Some where I remember reading about someone selling plans if any of you can
help maybe I can get her interest back up.
From: | "Warren D. Shoun" <wbnb(at)earthlink.net> |
Dear Rick:
The Piet at Yesterday's Wings has a nice looking door...design by
Garry S. Price, Director/Curator. He sells several of his design
packages for $35.00 each. I don't know if the door is one. Also check
out the YW pictures at
http://www.wrld.com/w3builder/piet/pics.html. where, if you look
closely, you will find a picture of a passenger door. See BPA issue
51, 1st Quarter 1996 for more info on Yesterdays Wings. Hope this
helps. Best Regards, Warren.
Sorry .....didn't mean to send this to whole group.
Bruce
Subject: | wing dihedral and radiators |
Hi fellow piet builders,
I'm currently building an "A" powered piet with a friend, and I have a few
questions.
Has anyone had any luck putting the radiator in front like an Jenny?
How is dihedral put into the three piece wing and is it nessesary? I've
thought of cutting the center spars to give about 3/8 inch dihedral at the
wing tip.
Thanks.....
mike
Dear Rick:
Also look on page 9 of BPA issue 53-3rd Quarter 1996...has very
good picture of Yesterdays Wings door. Best Regards, Warren.
I only have one question . does anyone else have trouble with their
explorer browser when someone adds an attachment to the piet disscussion
group or is it just me!!!!
It's just you. Sorry.
-----Original Message-----
Date: Thursday, January 08, 1998 8:01 PM
> From Steve(at)byu.edu Thu Jan 8 16:54:10 1998
> Date: Thu, 08 Jan 1998 14:49:06 -0700
> Mime-Version: 1.0
> X-Listname:
> Content-Length: 1998
> > > Mime-Version: 1.0
> > (NDS))
> > > X-Listname:
> > > Content-Length: 234
> > unreliable
> > mounted to
> > > Bill
> > as well.
> > deeper...
> > pickups
> > 2000
> > you
> > johnk
> Stevee
> Stevee
Ooops... finger trouble on the last post...
If it makes 134 hp, probably in the upper 3000 rpm range being a truck
engine, it should easily manage 70 hp or better at 2500 donchathink? I'd
love to get the power curve for that motor.
Wonder what it weighs stripped down?
johnk
Yes, me too
Bob Bailey
Mine works OK.
> From: Robert M. Bailey
> Subject: Re:
> Date: Friday, January 09, 1998 10:30 AM
disscussion
> Yes, me too
> Bob Bailey
Stevee,
Thanks I'll try you system
Craig
Subject: | 2.5 ltr. General Motors |
I was enjoying the latest Sport Aviation (Jan 98) when I noticed a
picture of a beautiful blue and gold Piet (p 126). Then I noticed that
the description said it had a 2.5 ltr. General Motors engine. Does
anyone know anything about this engine? Is he running a reduction drive?
Dean Dayton - deandayton(at)hotmail.com
Subject: | Re: wing dihedral and radiators |
I have a radiator on the nose of my Ford Fiesta Piet - about 125 sq. in. with
2 inch cores - there isn't a lot of room up there for much more. Perhaps due
to the flat faced nose or the proximity to the prop, not enough cool air
passed through the radiator; in fact the coolant boiled out on me (literally)
on the first flight and on a number of times afterward while I tried various
modifications. Finally, I added a radiator of about 60 sq. in. under the
fuselage in series with the one in the nose and the engine has been happy for
over 300 hours. Some people have told me that some of the old Jennies were
similarly modified, though I haven't seen one.
Jim Malley
Subject: | Re: 2.5 ltr. General Motors |
Gotta be the old "Iron Duke" 2.5L OHV four. Used up through the Chevy
Citation series, late 80's, perhaps later. Seems like it would weigh a
good bit more than a model A, but owner claims empty weight of 615
pounds. From the position of the prop relative to the engine, I'd
guess he's running it direct drive. I wonder how big the end bearings
are.
| | Glenn Scherer
__|
~~~: Farmersville, TX USA
) scherer2(at)airmail.net
\_(
> questions.
> wing tip.
> Thanks.....
> mike
Hi Mike,
With the help of two friends and 1" x 2" support structure under each
wing we first leveled the wing. The center section carry-through spars
and root spars of both wings were cut to allow for dihedral. Next 1
degree was calculated and the end of the wing lifted to that dimension
(what ever it was I don't remember now. But more importantly and I have
yet to perform this is to add (and I have to check this out yet ) is a 1
to 1 and Half degree washout. This will help with the Pietenpol sudden
Stall Characteristic. I'm told that because of the high wing design it
does not have the normal fuselage to wing root connection to help with a
more gentle stall characteristic, and if there is no washout the wing
stalls all at once. Some people install a stall bar about a foot in from
the center fittings on both leading edges. Anyway if you do any futher
homework on this subject please let me know.
Domenic Bellissimo
Stevee,
You just don't get it do you? What are ski goggles like? Remember, I am in
Florida!!!
Ted Brousseau/APF
Sunny SW Florida
Robert M. Bailey wrote:
> Hello list,
> Thanks,
> Bob Bailey
I remember Richard Burton of Hockley Valley, Ontario (a Pietenpol Flyer)
telling me of this firm in Florida that had a lot of lycomings that they
rebuild and were for sale for use in air boats.
Richard approached the firm to inquire about their use in aircraft
engines and the firm did not recommend it. The firm's rebuild parts were
not certified parts, some were remanufactured but not to airworthiness
standards and some were new but also not certified. Apparently you could
purchase a rebuilt 65 for $3,000.00 and a used engine for air-boat use.
Dom. Bellissimo
>> Bernie's
>> Brad Schultz
>> brsch(at)afcon.net
>> NX899BS
>Stevee
I like Stevee's answer, but I would also check out airplane known for their
great loads, like a PITTs' Special. Join your local EAA chapter and see other
airplanes finished and in process. Nothing like eyeballing another's work to
see if your own work measure's up.
Jim, Thanks for your reply. I've seen photos of your plane and it's even on
Kim Strikers Broadhead video. Looks very nice. Do you think you'll fly there
again?
Domenic,
Thanks for your reply. I plan on visiting with Don pietenpol this afternoon,
I live about 20 miles away from him. I have a few other questions for him as
well. If I find anything out I'll get back to you.
mike
> From: Steve Eldredge
> Subject: Re: flying 3x in 3days
> Date: Thursday, January 08, 1998 4:17 PM
> clawler wrote:
> > Stevee,
> > hanger,
> > Craig
> Craig,
> 1000rpm.
> Hope this helps
> Stevee
Re "cold start" Here in Alberta ,50 degrees means the mosquitoes are just a
bit sluggish,and you may be thinking of a jacket.I fly 46 CHAMP WITH A
C-85 NO ELECTRICS WITH IMPULSE MAG.The preflight starts with giving the
primer 4 to 5 full shots of primer,remaining preflight is then carried
out.Then standing BEHIND the prop,were throttle can be seen,2 non dramatic
flips of the prop will usually have it running.With impulse mags, great
effort on the prop is not needed.
By primming first and allowing 5 to 10 minutes for the fuel to vapourize
before starting seems to help.
There are small propane fueled heaters you may consider if yours is
difficult to start,but at temps above 15 to 20 f. should not be required
,certainly not at 50 deg.f.
Happy aviating Doug.
Jim,
Could you give us some more info about your Fiesta installation. What
kind of ignition system, prop reduction, electrical system(?), etc.
>Date: Fri, 09 Jan 1998 21:20:55 -0500 (EST)
>From: GMalley <GMalley(at)aol.com>
>Subject: Re: wing dihedral and radiators
in. with
Perhaps due
air
(literally)
various
the
happy for
were
>Jim Malley
a
from
>Domenic Bellissimo
I attended a Pietenpol discussion at Oshkosh a couple of years ago. In
it Vi Kapler recommended about 3/8 in washout. He said that Bernie did
not think that this was necessary, but that he thought it made the stall
characteristics better.
Subject: | Wing Rib measurements and photocopies |
I am just starting to lay out my wing rib jig. I had a copy of the full
size layout received from Don Pietenpol made. On my copy, the distance
between the spars was 27.5 inches, not 27.75 as noted on the drawing. Also,
the deflection on the lower edge was .5 inches, not .625 as shown on the
drawing. BEWARE OF USING PHOTOCOPIES ON SCALED DRAWINGS! This may be
common knowledge, but it was new to me.
On a similar note, I measured the bottom deflection on the drawing received
from Don Pietenpol. It is a maximum of 9/16, rather than 5/8 shown in the
drawings. Is this enough to make a difference, am I picking at nits, and can
I use the original as the layout print for the rib jig? What is the
required accuracy of the airfoil? Words of knowledge will be greatly
appreciated.
Al Swanson
You could upgrade your browser for free, assuming its Internet Explorer, to 4.0.
Contact your internet provider or search for "microsoft" + "Explorer". Or,
You could also check your browser directory for "funny named files" that
were not
there after you installed your browser. Check dates on file details.
>Yes, me too
>Bob Bailey
Ted, You Floridians are usually transplanted snowbirds who should know better.
Of course you could get in an airplane and fly to mountains to ski or
snowboard.
Skiing is the closest you can get personally to flying without wings, engine
or chute!
If you use a jump, you can catch some "air". (Tahoe is a ski area that has
sun 250+ days
a year!) Watch out for moving trees.
>Stevee,
>Florida!!!
>Ted Brousseau/APF
>Sunny SW Florida
Subject: | Re: Passenger door |
Hi Rick!
Glad I'm not the only one who has to consider the spouse getting in and
out of the front Piet cockpit! I got the door plans from Garry Price at
Yesterday's Wings and it looks well thought out. His door is for wood
fuselage Air Campers only. There are a few fuselage members to add to
carry the loads around the door frame, but he has tried to minimize the
weight impact by routing them out. I thought it was a fair trade to
make it easier for the wife and kids to enjoy the plane.
You can find mention of Yesterday's Wings on the Buckeye Pietenpol
Association website. He also has plans for 3-piece wings, fuel tanks,
tailwheel assemblies and aileron mods.
Mike List
Thanks to all the guys who provided the weights and other details on
their wire spoked wheels. Helps me with the weight and balance
spreadsheet for the Piet and the design of my 80% scale WWI Albatross DI
fighter (uses the same size wheels)!
Mike List
Robert,
There is a Piet baised at Williamsport Pa with a Lycoming 65 in it. I am
not sure who owns it now, but the people at Aeroflight would know. I was
built by Bill Silk up at Tunkannick Pa. Carl Nicewinder from X\Sunbury
owned it for several year and flew it quite a bit. Someone from Textron
in Williamsport said the engine should be in a museum.
Craig
Subject: | Re:More about Tools, etc... |
PI>Richard,
About tools: I have only built ribs so far but I found a sanding
machine to be very
useful. I am referring to the type that has a 6" disk sander and a
four inch wide
belt sander. I also bought a couple of little X-acto hobby saws. They
are good for
cutting the ribstock . Another builder told me a mistake he had made.
He did not
have a table saw, so went to a friend and cut half of all his ribstock
one night, then
went back a couple months later and they cut the rest of it. But they
weren't
accurate enough, and the second batch was just enough fatter that he had
a terrible
time getting it into the same jig. There are a couple solutions to
this, just keep it in
mind.
John Fay
> 1
> a
> from
> >Domenic Bellissimo
Thanks Dean for the information. I'll do some math and see what 3/8"
yields in degrees.
Regards, Domenic
> Stevee,
> Florida!!!
> Ted Brousseau/APF
> Sunny SW Florida
Oh, in that case, they are a lot like snowmobile goggles ;=)
Actually, they are plastic lense goggles that have vents around the sides
to allow them to remain fog free. They are very comfortable to wear (I've
had mine on skiing all day without any discomfort). They come in either
tinted or clear. Some of the tints they use today are actuall quite good
for night skiing which may carry over into flying. THe wrap around design
will also work well for pilots. You can get sets to work with or
without glasses underneath. Finally, if you'd like to take a look at a set,
try out:
http://www.oakley.com/product/goggles/
Not advertising, just giving you a site with some pics ;-).
Ken
> From: Domenico Bellissimo <DCSBell(at)netcom.ca>
> Organization: None
> > questions.
> > wing tip.
> > Thanks.....
> > mike
> Hi Mike,
> Domenic Bellissimo
Just a thought guys; perhaps Bernie didn't think dihedral or washout
was nessacary because the high wing gives the roll stability due
to the pendulum effect of the fuselage hanging under the wing.
I wonder how effective the center section is with the radiator
disturbing that air flow. Would the disturbed air at the center
section take the edge off of the stall?
Perhaps Bernie's Ford power has more advantages than are first
apparent. J Mc
On Thu, 8 Jan 1998, Robert M. Bailey wrote:
> Hello list,
> Thanks,
> Bob Bailey
If it will run, why not just use it. It's not that hard to set it up on a
test stand and check everything out. If you are getting good
compressions, not throwing oil or producung metal, give it a whirl. If
it's too expensive to O/H down the road, you'll at least have gotten a
couple of years use out of it. It's better than tossing the thing. If you
do plan on tossing it, let me know. I need an MS-3SPA or simular carb and
would be interested in buying it. I'd even consider a Stromberg.
Ken.
From: | Jerry Guyer <cigognes(at)oz.sunflower.org> |
Ok, here's my A65 starting tech.. also with 2 impulse couplers on my
Luscombe 8A.
pull 12 times with mags off
one shot prime
pull one or two blades
one more shot prime
throtle cracked 1/8 inch no more
mags hot
flip prop with one hand (no great effort)
It seems when ever some one trys to help me and they give a big kick a__
pull I end up having to do all sorts of things to get back in the
groove.
Subject: | RE: Lycoming O-145 |
I think Ken's pragmatic viewpoint is very smart! I'm curious though...a
question to the group.
If we can run non-certified engines in a Piet (Model A, Corvair, etc), then
why couldn't you use a Lycoming airboat engine and rebuild it with the less
expensive non-certified parts. As long as proper care was taken in how you
build-up the motor, I would think that safety would not be an issue.
Someone was saying the other day that the Model B Ford engine had be
"certified" before too.
Maybe this Lycoming idea isn't so bad.
Jim Wright
jgw(at)skynet.be
From: Wright, James Glynn, III (Jim) [SMTP:jgw(at)lucent.com]
Sent: Tuesday, January 13, 1998 00:51
Subject: Pietenpol-List: FW: Lycoming O-145
>From: Ken Beanlands
>Sent: Tuesday, January 13, 1998 12:46:21 AM
>Subject: Re: Lycoming O-145
>Auto forwarded by a Rule
> Hello list,
> Thanks,
> Bob Bailey
a
you
and
Ken.
(_) (_)
> > Hello list,
> > Thanks,
> > Bob Bailey
> a
> you
> and
> Ken.
Get a Lycoming overhaul manual and tear the engine down, do a dye
penetrant on the case and cylinders to look for cracks, get the
crank and rods magnafluxed at a community college, buy new pistons,
etc.... if the innards check out ok and can be rebuilt to overhaul
manual specs without having to buy major parts, use the engine. If
it was used in an airboat any internal damage that makes it unuseable
will show up when you check out the internal parts. I think the main
thing that happens to airboat engines is damage from overheating.
johnk
Bomabardier Inc.
Hello list,
Thanks for all the comments, it seems that the majority opinion is to
proceed, but with caution. The engine is not in runnable condition
(missing carb and mags) but the price was right. It was given to me by
a friend that had no need for it. I get the overhaul manuals and go from
there.
Again Thanks, Bob B.
Subject: | Re: More about Tools, etc... |
Sanding joints to be glued is bad practice. On the ribs you might get away
with it since the gussett is carrying the load. If I ever hear of someone
doing it in a scarf joint however I am going to have to loose my cool. (or
something)
Stevee
Aron(at)hrn.bradley.edu wrote:
> PI>Richard,
> machine to be very
> four inch wide
> are good for
> He did not
> one night, then
> weren't
> a terrible
> mind.
> John Fay
From: | rdecosta(at)autoeurope.com (Richard DeCosta) |
Finally, after 5 months of reading, drooling, visiting other
builders, and setting up my site, I am now ready to begin my ribs!
Does anyone have any close-up pictures of ribs I could take a look
at before I begin? Thanks all!
Web Developer, http://www.autoeurope.com
Homepage: http://www.wrld.com/w3builder
> something)
> Stevee
You *should* sand birch ply where it is to be glued. There
is a glazed surface in the ply from the manufacturing
process that needs to be removed.
johnk
> From: Jim Wright <jwright(at)bcsbel.be.Lucent.com>
> Subject: RE: Lycoming O-145
> Jim Wright
> jgw(at)skynet.be
> To: Jim Wright
> Subject: FW: Lycoming O-145
> >From: Ken Beanlands
> > Hello list,
> > Thanks,
> > Bob Bailey
> a
> you
> and
> Ken.
> (_) (_)
> Here is a quick test if you have two engines that will take the same prop.
If they will both spin the prop at the same static rpm then it holds
true that they are developing equal power. The prop is a torque
absorbsion unit. It takes 33 bhp to make a stock Piet climb at
miniumum climb. that gives you 7 hp more than you need with an A Ford
and almost twice that with a Continental or Any other 65 horse
engine. Horsepower is only a measurement of the rate of doing work.
The work I'm interested in my engine doing is pulling my wood and
rag creation into the atmosphere. Isn't the view great? It shouldn't
matter other than aesthetics what engine is creating the horsepower
and thrust. I do like the old and slow as well as Grant's low and
slow motto. If you can get reliable power for less money, go for it!
The Model B was never certified as it came from Ford. The Funk
brothers made substantial changes to it:
-they inverted it
-used chrysler industrial oil pump
-thier own cylinder head
-etc..
The later Funk aircraft switched to Continental power.
What ever engine you choose to use make sure to keep the systems
simple and sure. Most engine failures are a result of simple little
problems ignored. Fuel flow, Ignition, controls etc.. One of the best
test stands is your own airframe as your systems are all there too.
Safe building and Flying J Mc
Hi Guys:
Just wanted to thank the group for the info on the passenger door thing.
I took Warrens advice and checked out Richards DeCostas collection of Piet
pictures. After browsing through about 10 or 20 pictures I thought maybe I
died and went to heaven.
Any way I now have a door in the side of the Piet and had the wife
try it out. I'm building with her blessing again.
Subject: | Re: passenger door |
Rick,
We have two doors on our Piet. I have never seen the slightest flex because
of the door being there - and that was during some pretty hard landings when
new at it.
Ted Brousseau
Naples Florida
>Hi Guys:
thing.
From: | "Larry L. Neal" <llneal(at)earthlink.net> |
No offense Steve, but I've been told to sand, and sand each and every glued
surface to remove the purported glaze and also rough it up a bit.
It's good practice to use thinner to clean off the surface to remove sanding
dust and sap afterwards though....
My test coupons have never broke on the glue line when doing this.
Larry
> something)
> Stevee
> > PI>Richard,
> > machine to be very
> > four inch wide
> > are good for
> > He did not
> > one night, then
> > weren't
> > a terrible
> > mind.
> > John Fay
From: | Michael D Cuy <Michael.D.Cuy(at)lerc.nasa.gov> |
>Larry
What Larry says above is what I've read in Tony Bingelis' books
as well. (especially the birch plywood) I think the key here is
to get the dust off afterward. None of my test pieces broke in
the wood and I sanded just about 95 % of all the glue joints in
my project. Mike C.
The books that i have on the subject strongly recommend that no sanding be
done due to the concern of damaged fibres. The only accepted method for
cleaning a joint is a planer type saw blade and a plane. However, my
feeling is that the effect can be helped by the type of glue that you use.
With the old style cassein glues, it may be more critical than with
Aerolite or T-88. Mahogony ply also should be checked for glaze and
'lightly sanded". If you need more information on the references that I dug
out, let me know. I believe that you would be risking the certification
process in Canada if they knew you were sanding joints.
Best regards,
-=Ian=-
> From: Larry L. Neal <llneal(at)earthlink.net>
> Subject: Re: More about Tools, etc...
> Date: Tuesday, January 13, 1998 23:33 PM
glued
sanding
> Larry
away
someone
(or
> > something)
> > Stevee
> > > PI>Richard,
> > > machine to be very
> > > four inch wide
They
> > > are good for
made.
> > > He did not
ribstock
> > > one night, then
they
> > > weren't
had
> > > a terrible
> > > mind.
> > > John Fay
> Stevee,
> am in
> Florida!!!
> Ted Brousseau/APF
Whoops.
Sorry Ted. Glad someone else posted a good answer, although they are a
bit like snowmobile goggles :). I've been out sick for the last five
days and I guess it shows.
Stevee (feeling a little better).
Subject: | Laminated vs. Solid Spars |
Pietenpol List:
=0D
In Pietenpol's Corvair/3-Piece-wing supplements, the spars are lami-=0D
nated from 3/4" strips. Utilizing shorter lumber would save me $20-$25 =0D=
per spar. I'd don't feel this is worth the trouble of all that scarf =0D
jointing and laminating, so I'd like to use solid 3/4" stock.=0D
=0D
My question: are there any other reasons for laminating the spar? Lam-=0D=
inations are usually superior in strength, only because they allow =0D
defects to be removed from otherwise unsuitable full sized stock. =0D
=0D
Points of attachment are supplemented with plywood plates (1/8" each =0D
side). Is it necessary to use plywood reinforcement along the entire =0D
spar length, or are folks adjusting their rib plans to fit the thin-=0D
ner spar?=0D
=0D
I see some concern over sanding wood before gluing. Plywood MUST be =0D
lightly sanded before gluing. Government tests quoted in the EAA's =0D
"Wood Building Techniques" book show an average 40% increase in bond-=0D
ing strength for most species. Light sanding removes the crushed =0D
cells from the wood surface, which form a glaze inhibiting good glue =0D
penetration. It is the hot steel rollers which burnish the surface =0D
during manufacture, when the plys are compressed. I have the written =0D
instructions from Ciba-Geigy for their Aerolite 306 glue. I quote, =0D
"Surface Preparation: Thoroughly sand the surface to be joined. =0D
Ensure that all surfaces are free from dust or other deposits".=0D
=0D
Hope this helps=0D
=0D
Glenn Robb=0D
Feel free to loose your cool at anytime(place silly icon here)Comercial
scarfing machines CAN be !you guessed it, jigged sanding drums,plus a 10:1
joint (MIN) allows for a large gluing surface.
Any credible publication on wood joinery will likely list all the
technical reasons why sanding is benifical,alot which have already been
submitted to the group.Common sense should not be overlooked(RIGHT BERNIE)
IN MY HONEST OPINION (dose not take all that long to type, dose it?)
> Date: Tuesday, January 13, 1998 11:36 AM
away
someone
(or
> something)
> Stevee
> > PI>Richard,
> > machine to be very
> > four inch wide
They
> > are good for
> > He did not
> > one night, then
> > weren't
had
> > a terrible
> > mind.
> > John Fay
Stevee,
Glad to see you are on the mend. Thanks for the reply. I guess what I want
to know is whether these northern things are something I should be looking
at for down here? Are they "better" than the standard a/c goggles?
Ted
>Whoops.
>something)
>Stevee
>> PI>Richard,
>> machine to be very
>> four inch wide
>> are good for
>> He did not
>> one night, then
>> weren't
>> a terrible
>> mind.
>> John Fay
>Hey, I thought a scarf joint was made with a sanding drum on a tilting
table? I know you are not supposed to sand a glue joint, but I'll have to
research the scarf joint.
Barry Davis
Where are the pictures of Richard Decosta? I must have missed the post
giving the address.
Thanks in advance
Barry Davis
bed(at)mindspring.com
Hi Barry:
Try http://www.wrld.com/w3builder/piet
> giving the address.
> Thanks in advance
> Barry Davis
Subject: | using j-3 type landing gear |
by all means you can use the engine. Certified engines are for
certified aircraft, not experimental aircraft. There is an advantage
to using certified engines on x's because of the flight restrictions
during the test period. If you have a certified engine you only have to
put 25 hrs in the local test area. If you are using an non-certified
engine they you have to fly of 40 hours prior to leaving the test area
or carring passengers...big deal.. use the lycoming....
Jerry
>giving the address.
>Thanks in advance
>Barry Davis
Subject: | using J-3 type landing gear |
Pietenpol discussion,
Bill Rewey said in BPA news issue #58 " using J-3 type landing gear
on a pietenpol results in the much weight on the tail wheel which causes an
aft CG problem.
Iam building a 1966 extended fuselage with a corvair engine and
a three piece wing. I was going to use the J-3 type landing gear like
bernard did back in 1966 to save time on building my project.
I know that Bernard Pietenpol did have problems with this type of gear.
He had them placed to far forward on his fuselage.
Did Bernard Pietenpol fix the problem and find the J-3 landing gear
an excellent type of gear for the pietenpol?
Well, I wear glasses and they cover them and still feel really
comfortable. I will probably use them throughout the year. They don't
look authentic as the leather bug eye goggles of the period, but they work
great keeping out the cold and the wind.
Stevee
On Wednesday, January 14, 1998 7:23 PM, Ted Brousseau
[SMTP:nfn00979(at)naples.net] wrote:
> Stevee,
want
looking
> Ted
> >Whoops.
Subject: | on Sanding joints |
My understanding is that fine joinery techniques, such as violin building
and airplane building don't join bare sanded surfaces. You can use
anything you like to remove mass material to get the right angles and
shapes including an industrial sander. The point is that when you finally
apply the glue to the joint you want the pores of the wood open to get the
best joint you can. Granted this was more of an issue when Resorcinol and
Urea Formaldehyde glues were the norm. My guess is that you will find that
even if material is removed with a sander it is recommended that the joint
be scrapped or planed for the final gluing. With modern epoxies where
mechanical bonding is the means of attachment this is less of an issue. (I
would still prep the joint the same way however) I have read that some
fine woodworkers recommend freshly breaking a piece of glass with a
straight edge to final scrape the piece to be joined. The new glass edge
is only good for a couple of passes before needing to be broken again. I
didn't go to this extreme. I used a freshly sharpened hand plane.
Your joint mileage may vary....*greatly*.
May your joints be strong,
Stevee
On Wednesday, January 14, 1998 5:13 PM, Doug Hunt [SMTP:ve6zh(at)cnnet.com]
10:1
BERNIE)
> away
> someone
> (or
> > something)
> > Stevee
> > > PI>Richard,
> > > machine to be very
> > > four inch wide
> They
> > > are good for
made.
> > > He did not
ribstock
> > > one night, then
they
> > > weren't
> had
> > > a terrible
> > > mind.
> > > John Fay
From: | Greg Cardinal <CARDIGJ(at)mail.startribune.com> |
Subject: | RE: flying 3x in 3days -Reply |
Check out the following page for goggles:
http://www.icc-comm.com/motorcycles/goggles.html
They have authentic looking goggles that fit over glasses.
For more pages do a web search using the word "goggles".
Other news, our fuselage is complete enough to sit in. My partner and I
are building a long fuselage ship. I'm 6' 200 lbs ( 200!!!! that sure is
depressing in print) and the rear cockpit is surprisingly roomy. I didn't feel
the least bit cramped. The instrument panel is closer to my face than
expected but not a problem. The leg holes were made larger to prevent
bruised shins.
Greg Cardinal
>>> Steve Eldredge 01/15/98 10:01am >>>
Stevee
> Stevee,
want
looking
> Ted
> >Whoops.
are a
I'm having a little trouble finding T-88 in Seattle. Does anyone know where
I can get this stuff?
Brent Reed
>'lightly sanded
I just bought some from Wicks Aircraft Supply. Don't have their # off
hand, tho. Anyone?
> Thanks,
> Brent Reed
> >'lightly sanded
Subject: | RE: More about Tools, etc... |
Wicks 800-221-9425
Stevee
On Thursday, January 15, 1998 4:45 AM, Richard DeCosta [SMTP:rdecosta(at)autoeurope.com]
> hand, tho. Anyone?
> > Thanks,
> > Brent Reed
> > >'lightly sanded
Wicks aircraft Number is 618 654 7447
I have been "listening" with interest to the discussion about the door
plans and am wondering if there is a way to convert an already built
fuselage. The wife is going thru the same issue on "how to get into the
front cockpit". Can it be retrofitted with ease, with difficulty, or no
way". Any comments?
> Subject: RE: More about Tools, etc...
> Date: Thursday, January 15, 1998 11:55 AM
> Wicks 800-221-9425
> Stevee
> > hand, tho. Anyone?
know where
> > > Thanks,
> > > Brent Reed
> > > >'lightly sanded
From: | "Gerard \"Larry\" Huber" <NoSpamglhuber(at)mail.wiscnet.net> |
Where can I find the pictures of the door in a Piet. If you reference
DeCosta's site - what is the name of the PIC - it takes time for me to
download pic's.
Larry
>giving the address.
>Thanks in advance
>Barry Davis
Here is Richard DeCostas web page
I not sure which ones had the door try the WY pictures. There are several in
this web page.
Back to the gear. I building my own and does anyone know how far to move the
gear forward? I havent seen anything on it except somewher I read where they
moved it I think 7 inches and the artical said it was a bit to far. duh
I have read all of the discussion about snowboard goggles, etc. Why not
get the real thing? I don't think that they cost much more than a good
pair of snowboarding goggles... Flight Suits Ltd. sells several styles
of goggles, leather and canvas caps, etc. If you buy a leather bomber
jacket they even give you a white silk scarf!!! Great store! I bought
a nomex flight suit and leather flight boots from them. Check out their
web site and get a free catalog.
http://www.flightsuits.com/index.htm
On Thursday, January 15, 1998 8:20 AM, Greg Cardinal
I
is
didn't feel
> bruised shins.
> Greg Cardinal
don't
work
> Stevee
> > Stevee,
what I
> want
> looking
> > Ted
> > >Whoops.
> are a
five
So how many pints, quarts, or gallons of epoxy should I need to do this
project?
Thanks for the phone numbers.
Brent Reed
Kent, WA
Date: Thursday, January 15, 1998 8:55 AM
Subject: Pietenpol-List: RE: More about Tools, etc...
>Wicks 800-221-9425
>Stevee
>> hand, tho. Anyone?
where
>> > Thanks,
>> > Brent Reed
>> > >'lightly sanded
Subject: | Re: Re: More about Tools, etc... |
to:Brent Reed,
You asked how many quarts, pints or gallons?
You should only get enough to glue whichever part of the piet your
building. The t-88 does have a shelf life and will go bad. You will be
able to tell when it goes bad. The clear resin will get cloudy.
Sincerely,
-=Ron Lebfrom=-
From: | Domenico Bellissimo <DCSBell(at)netcom.ca> |
Subject: | Re: using J-3 type landing gear |
> aft CG problem.
Actually Ron,
I think they were placed too far aft. Not by the pick-up points on the
fuse though. I know when Jack Watson and I were fixturing my gear, we
placed the wheel axel forward about 8" (need to measure to be sure). You
need to do some preliminary weight and balance for your particular
needs. For instance where are you going to place your battery? How heavy
did your construction actually come out to? Once you know this you can
make your fixture to weld it up. Make sure your fuselage pivot points
are in-line, this will keep the stress off the pivot when it needs to
rotate. Use a 1/4 ' rod through the holes while welding to keep it
in-line. Tac the complete side of the gear first before welding it
complete, and move your torch to different welding spots to keep the
heat from distorting the structure. Are you intending to use bungees or
springs. Both Jack and I used Urethane pucks which we had made up for
$30.00 per foot. We chose duro #90. I have to be honest though I haven't
flown yet and the duro number may be too hard. I'll have to wait and
see.
Hope this helps you.
Domenic
Subject: | MOVING gear was:RE: Piet door |
the
> gear forward? I haven't seen anything on it except somewhere I read where
they
Rager
I moved my axles forward 5 inches from the plans. I did this in order to
put more weight on the tail because I installed brakes and plan on flying
off of pavement most of the time. I think I have around 40# tail weight.
Not sure how this compares, but I can get the tail off easily by the time
I have the power lever at full. I can land 3 point solo, and haven't felt
the tail come up during agressive brake tests.
for what it's worth....
Stevee
Subject: | Re: Door Pictures? |
Dear "Larry"
Let me side-slip ya' a little bit here....the best picture that I have
found is on page 9 of the Issue 53 - 3rd Quarter, 1996. I could fax you
a copy if you reply directly to my e-mail with a good fax number. Warren
> download pic's.
> Larry
A while ago someone referenced a piet in January's issue of SA. I went looking
for it and now I'm not sure if I recieved it or not.
What was the picture of on the front cover?
Help!
Stevee
Subject: | Re: Sport Aviation |
Cover is a MG-2 Biplane.
> Help!
> Stevee
From: | "Woodbridge, Gary" <gwoodbridge(at)datatimes.com> |
Subject: | RE: Sport Aviation |
Steve and others:
I did not receive mine either. I would have remembered that bipe. I
called them up and they are sending another.
The lady said they where getting a large number of complaints about no
delivery.
Gary Woodbridge
Senior Systems Engineer - UMI / OKC
Maule M7-235B - N723M
>From: Steve Eldredge[SMTP:steve(at)byu.edu]
>Sent: Friday, January 16, 1998 3:04 PM
>Subject: Sport Aviation
>looking for it and now I'm not sure if I recieved it or not.
>Help!
>Stevee
Thanks for the replies. I called eaa and they are sending me mine too. I
did find a way to see the cover of the current issue on the net that is
kind of cool..
Check out EAA's homepage and follow EAA's publications to Sport Aviation.
They have the current table of context too.
Just wish I could read the articles!
Stevee
On Friday, January 16, 1998 2:26 PM, Woodbridge, Gary
[SMTP:gwoodbridge(at)datatimes.com] wrote:
> Steve and others:
> delivery.
> Gary Woodbridge
> >Help!
> >Stevee
The January cover was Jim Moss's MG-2. Ther referenced Piet was on page
126, Larry Harrison's "Poplar Piet" made from a poplar tree cut from the
family farm.
Al Swanson
>kind of cool..
>Stevee
>> Steve and others:
>> delivery.
>> Gary Woodbridge
>> >Help!
>> >Stevee
Have not recieved my SA. Jan98 yet either!
Steeve,is the 40# weight on your tail wheel in the level position?Mine is
looking a little on the light side so far,will be using brakes ,so may have
to build new gear legs but will wait till after the covering and all
goodies are installed.
Doug
> Subject: RE: Sport Aviation
> Date: Friday, January 16, 1998 4:42 PM
I
> kind of cool..
> Stevee
> > Steve and others:
> > delivery.
> > Gary Woodbridge
went
> > >Help!
> > >Stevee
Subject: | Re: Re: using J-3 type landing gear |
DomDominic,
Domenic,
Thanks for the reply. I still have a few questions about the J-3 type
gear. You said that I should do a preliminary weight and balance. Can
you provide more detail about this? I thought that you did the weight and
balance after you had your wings,engine, and everything else installed.
I was wondering how they placed the gear without the wings and engine
being built first. I think alot of people are having alot of problems with
the placing of their gear.
>you asked me if I was going to use springs are bungees. I am planning
on using springs. I hear bungees are a pain. I saw your name in the BPA
news. It looks like your well on your way to completing your project. I
still have a long way to go ............ My tail section is complete and I
have
all the wing ribs complete. I am going start my fuselage in one week:)
I am currently finishing up the remodeling of my kitchen.
Thanks again for the help. I appreciate the information.
Sincerely,
-=Ron Lebfrom=-
Have any of you had experience with Excel glue?
I have used T-88, how would it compare with it?
Thanks for any help you can give.
Bruce
flyer(at)clas.net
> Doug
Doug,
Actually I think that #40 is a bit heavy. I wish that it were around #30 Duane
Woolsey is about 32 and it seems right. I wouldn't worry at this point. I
also have the short fuse, which will make a slight difference.
Stevee
There seem to be two types of material to bond in an Air Camper: solid
wood (spruce, fir, etc.) and plywood (birch, mahogany, etc.) I agree
with Steve that for solid wood joints the final prep of the pieces
should be with a sharp tool, not sandpaper. For the plywood gussets,
however, it is recommended to scuff the plywood surface just prior to
bonding. I've used 220 grit on birch plywood rib gussets with Weldwood
adhesive and gotten good results, including a ten year old rib built in
Florida with gussets still good and tight. If you have never used a
hand plane, they are great once you get used to them.
Mike List
> Bruce
> flyer(at)clas.net
Bruce,
Roger Mann, who has plans out for an ultralight Piet as well as several
other designs, uses Excel glue and claims it works great. You can
contact him at (864)972-5606.
Mike List
PTNPOL wrote:
> Domenic,
> have
> Sincerely,
> -=Ron Lebfrom=-
Hi Ron, You are correct. you normally do the weight and balance at the
end, unless you are deviating from the plans. And of course If you are
going to have brakes. I think I mentioned that I may have moved mine 8"
forward. Thius is incorrect I think it's more like 5". The idea of
moving it forward is to keep the tail down when applying brakes.
Somewhere I have made a drawing for what I did. I'll try and find it.
Dom.
Hi Dom, If you can find the drawing, I also would be interested in what you
did. There is a jig for making the gear in one of the issues of the BPNews
that I have marked for reference. Memory says that it moved the axle 4
inches forward from the original. Let me know if you want me to find the
reference.
Best regards,
-=Ian=-
> Subject: Re: using J-3 type landing gear
> Date: Monday, January 19, 1998 18:13 PM
> PTNPOL wrote:
> > Domenic,
type
and
with
BPA
I
and I
> > have
> > Sincerely,
> > -=Ron Lebfrom=-
> Dom.
> reference.
> Best regards,
> -=Ian=-
> > PTNPOL wrote:
> > > Domenic,
> type
> and
> with
> BPA
> I
> and I
> > > have
> > > Sincerely,
> > > -=Ron Lebfrom=-
> > Dom.
Hi Ian,
I'll try and find the drawing I have. I don't think it's complete by any
means though. A friend was putting it on autocad for me. He did one part
, which he reproduced for me, but the other parts were lost during a
hard drive failure. I'm still going to try and get him to re-do the lost
parts. Perhaps I'll get some pictures taken and then send them to
Richard to post on his Homepage.
Dom.
regar
Subject: | RE: MOVING gear was:RE: Piet door |
On
> Rager
Yes this is measured wings level, flying attitude.
> Stevee
Well, the day has finally come! I just got my capstrips, nails & glue
from Wicks Aircraft Supply! I have officially moved from Pietenpol
'enthusiast' to Pietenpol 'BUILDER'. Whoa. I am looking at the wood,
thinking, "This pile of wood will actually FLY someday..." Pretty
cool.
I don't know how much time I am going to have to work on it every
day, so... anyone have any suggestions for keeping wood that isnt
being used safe and warp/bug/damage free?
Richard
> From: rdecosta(at)autoeurope.com (Richard DeCosta)
> Subject: Happy Day!
> Reply-to: Pietenpol Discussion
> cool.
> Richard
>Congrats Richard!
If you cut off a scrap of the wood and force dry it in your oven
don't exceed 212 f and don't use the micro wave. I tried the mic and
filled the kitchen with smoke! The idea is to have a sample with
absolutely no absorbed moisture. Keep weighing the sample as you dry
it until its weight stops changing. Record the samples weight.
Then place the sample in the location you are going to store the
wood. It will absorb moisture from the ambient atmosphere. Weight it
again and work out the weight gain as a pecentage. This will be the
moisture content of the wood in storage. It should be less than 12%.
You can mount the block on a first class lever and counterbalance it
to sit level. Then mark the lever position each time you weigh it
and after a while you will have a scale marked out. From then on you
just have to glance at it to know if your wood is safe. I have my
wood and unvarnished components hanging from the floor joists of my
house. I also am fortunate enough to live in a fairly dry climate.
Good luck and Enjoy building! All of us dream about flying but
getting there is half the fun!
John Mc
Richard,
Congratulations! Start building! You will love it. I am still in
withdrawals each day because there is no longer a project in the garage to
build on when I have a few spare minutes. Going flying requires at least
two hours of spare time. Building on the other hand is something I can
enjoy with only 10-15 min spare time. Not to worry however, I am
seriously looking at another "antique" designed with the real world builder
in mind --Steve Wittman's W-10 Tailwind. It seems to be the "Pietenpol"
high performance airplane designs. Wonder how well they knew each other.
Steve E.
On Thursday, January 22, 1998 6:36 AM, Richard DeCosta
> cool.
> Richard
Congratulations! I, too recently received my initial supply of wood from
Wick's. After inventorying and inspecting the shipment, I put all the
lumber back in the crate, with the top screwed on, where it will stay
covered, dry, and bug free until I need it. As I need pieces, I take it
from the roof of the garage, and let it sit for a week or two in my shop in
the basement until I need it. My feeling is that it will stabilize in that
time to a safe working moisture level. Bernie Pietenpol lived just 100
miles south of here, so I figure if it worked for him, it should be OK for
me as well.
Good luck in your project.
Al Swanson
>cool.
>Richard
I am putting together a survey on my website for people who are
building, have built, or have flown a Pietenpol. I have several good
questions on it so far, but are there questions any of you think
should be on the survey? Heres what I have so far:
Set of Plans
Original 1929 Revised 1934
Grega Other
Engine
Ford Model-A
Chevy Corvair
Continental
Ford Model-T
Lycoming
Ford V8
Franklin
Kinner
Velie
Other
Type of Fuselage
Original
Long
Type Landing Gear
Propellor Size & Material
Instruments In Panel
Airspeed Indicator
Altimeter
Compass
Coolant Temperature
Oil Temperature
Other Guages:
Type of Wheels
Type of Wood Primarily Used
Average Distance (ft.)
T/O
Landing
Any others that should be on it? Once it's done, the results will be
available to anyone who has a web browser.
Richard
Like Steve I'm nearing the end of my Piet project--need to cover my one
piece wing and make a cowl/airscoop for Escort Engine. I'm currently
interested in a Pober Pixie or Christavia as a next project. I'd be
interested in buying plans--bargain price, of course--if you know
someone who has some they'd like to get rid of. Bill
There has been a lot of discussion lately regarding landing gear position.
I find that I'm still as confused as before.
I would like to know where the gear should go assuming the following:
1. Long fuselage
2. Wooden landing gear
3. No brakes
4. Continental A-65
If you say "Follow the plans" then my next question is: Which plans?
The 1932 plans give a different location than the 1934 plans. And the long
fuselage plans don't give an axel location.
Also, what are you using for a reference location from which to
measure?
Greg Cardinal
> Subject: Survey
> Good Idea!
> Set of Plans
> Grega Other
> Engine
> Ford Model-A
> Chevy Corvair
> Continental
> Ford Model-T
> Lycoming
> Ford V8
> Franklin
> Kinner
> Velie
> Other
> Type of Fuselage
> Original
> Long
Wing: One piece: Three piece
> Type Landing Gear
Gross Weight:
Fuel Capacity: Tank location:
> Airspeed Indicator
> Altimeter
> Compass
> Coolant Temperature
> Oil Temperature
> Other Guages:
> Type of Wheels: Brakes: Tailwheel:
> T/O
> Landing
> Richard
> Thanks Richard J Mc
On Friday, January 23, 1998 4:37 AM, Richard DeCosta [SMTP:rdecosta(at)autoeurope.com]
> Set of Plans
> Grega Other
> Engine
> Ford Model-A
> Chevy Corvair
> Continental
> Ford Model-T
> Lycoming
> Ford V8
> Franklin
> Kinner
> Velie
> Other
> Type of Fuselage
> Original
> Long
> Type Landing Gear
> Airspeed Indicator
> Altimeter
> Compass
> Coolant Temperature
> Oil Temperature
> Other Guages:
> Type of Wheels
> T/O
> Landing
> Richard
How about these?
Percent completed
Date started
Date completed
Registration #
Hours spent building
Cost
Primary source of materials
Tools found valuable
Finished weight
Location of CG.
How many inches back is your wing from vertical
Covering material
Paint type
Fuel tank location/size
Location/Home Field
Type of Glue used
General Comments
Fun Quotient (rating 1 to 10)
STeve E.
Great! This is just what I need! Thanks to John McNarry for some
great suggestions, too.
> How about these?
> Percent completed
> Date started
> Date completed
> Registration #
> Cost
> Finished weight
> Location of CG.
> Covering material
> Paint type
> Location/Home Field
> Type of Glue used
> General Comments
> STeve E.
Also, for those of you who might be interested in the progress of my
3D Pietenpol, here is the latest rendering:
http://www.wrld.com/w3builder/Piet/images/3DFlotingPiet.gif
Richard
> > Subject: Survey
> > Good Idea!
> > Set of Plans
> > Grega Other
> > Engine
> > Ford Model-A
> > Chevy Corvair
> > Continental
> > Ford Model-T
> > Lycoming
> > Ford V8
> > Franklin
> > Kinner
> > Velie
> > Other Subaru
> > Type of Fuselage
> > Original
> Wing: One piece: Three piece Aileron Gap Seal
> > Type Landing Gear
> Gross Weight:
> Fuel Capacity: Tank location: Tank Material &
> Construction Method
> > Airspeed Indicator
> > Altimeter
> > Compass
> > Coolant Temperature
> > Oil Temperature
> > Other Guages:
> > T/O
> > Landing
> > Richard
> > Thanks Richard J Mc
Subject: | Floating Pietenpol |
Hi Guys:
I want to thank Richard DeCosta for his contributions of
the "Amazing Floating Pietenpol" as well as the wonderful
gallery of pictures. These items have, and I am sure will
continue to be very helpful as well as entertaining.
I bugged Grant a bit the other day for giving so much
newsletter space to guys who spend years being "wanna be
builders". He made a good point that many of us do not
infact contribute building experiences and information to him
to share thru the newsletter. Soooo......maybe we could all
gang-up and give the poor bugger enough to put in the
newsletter as well as here.....by the way, Grant...do you read
this chat line? Warren.
>Hey William
Tell us more about you escort engine conversion, or how about more info from
you guys out there in Piet land about other power plants other than the
model a,continental or corvair. Raven has a neat setup for the Geo engines
(except for the price)any one ever used one? thanks
Richard,
Thats, a neat looking 3D Piet! ....appreciate your website and the work
you're putting into it. Pix like you have at your site makes great
reference and idea material.
Also, if anyone knows of a set of Piet plans for sale, I'd appreciate
knowing. In the process of trying to decide my next building project, I've
acquired plans for several types (wife says I'll be too broke to build, due
to money spent on all those plans:-). So-- just to make sure she's not
wrong, I'm considering ordering the Piet plans, but thought I'd check here
first in case someone was needing to bail back out.
I'm really enjoying the list and info therein.
Bobby
> cool.
Richard,
You should get a dust protector for your keyboard so you don't get all
that spruce sawdust down in it! Enjoy the building and thanks for all
those pictures!
Mike List
Richard,
How about:
Doors?
Cruise speed (level-no fair diving).
Ted Brousseau
Subject: | Plywood Gusset Question WAS RE: Happy Day! |
> all that spruce sawdust down in it! Enjoy the building and thanks
> for all those pictures!
Actually, my computer and keyboard are in a different room from where
I'll be building. :) Thank's for the advice, though!
I've got another question for the group: I have the spruce, nails,
glue and most of the tools I need to complete most of the ribs, but I
have yet to buy the plywood for the gussets. Wicks aircraft lists a
4'x8' piece starting at $100, and the local lumber yard at $14! There
must be a major difference in quality there. Could someone tell me
what to look for in the plywood I use. At Wicks they have for 3 to 7
ply, 45% and 90% and the prices are high. Do I need to bite the
bullet, or can I get the $14 sheet and still be safe?
Thanks all!
Richard
> > cool.
> Richard,
Hi, Bill,
I am getting to the point where I am looking for an engine. Got any
comments that you would like to share on using the Escort engine? Such as
ease, support, reduction gear, power etc? I am not having much luck
snagging a Continental 65 or corvair.
Thanks, -=Ian=-
> From: William Conway <ConwayW(at)ricks.edu>
> Subject: Plans
> Date: Friday, January 23, 1998 12:26 PM
Subject: | Re: Plywood Gusset Question WAS RE: Happy Day! |
Richard, I don't think that you want to go the route of non- certified
plywood! If you have not already done so, PLEASE join the EAA. They have a
whole bunch of books and articles that get to the meat of your question.
Besides the safety aspect, there is the question of resale value. You will
want to have available the parts/material list that went into the bird.
anyone considering a future purchase will want to know that before they
commit to a purchase.
In Canada, we have to follow the guidelines in "Acceptable Methods,
Techniques and Practices, Aircraft Inspection and repair" By Jeppeson and
obtained from the local community college.
EAA publications that I have found really helpful are:
"Custom Built Sport Aircraft Handbook"
"A Giuide to the Construction Standards for the Amateur Builder"
"FireWall Forward" by Tony Bingalis
"Aircraft welding" (They also do some first class videos)
These are just some of the books that I have read (and reread). Part of the
fun of building your own aircraft is the immense opportunity to learn. You
may get away with some shortcuts, but you may also have many hours of work
dissallowed at inspection time.
All the best in 1998, and congradulations on making the big decision to
start.
-=Ian=-
> From: Richard DeCosta <rdecosta(at)autoeurope.com>
> To: Pietenpol Discussion
> Subject: Plywood Gusset Question WAS RE: Happy Day!
> Date: Sunday, January 25, 1998 2:23 AM
> Thanks all!
> Richard
> > > cool.
> > Richard,
<< I am not having much luck
Thanks, -=Ian=- >>
If you are looking for a Corvair I might be able to help. I found as many as
I wanted for about $50 each (in Michigan). Contact me if you need to be put
in touch with CORSA; the national Corvair group.
William
Hi Richard:
Ian's comments are right on in all respects.....especially with
regard to the available instructional material from EAA for $150.00 and
the resale documentation. Having said that, Aircraft Spruce is in my
backyard and I have had several discussions with them ...and other local
builders.....the big issue on certification is very much related to
insurance standards. Most suppliers buy the same high-grade Baltic
Birch multiply plywood from Finland that you can get from specialty
supply shops for tool & die and model makers. They then "certify" it
and pay for the liability insurance in case there is a structural
failure and your family accepts the business card from the friendly
Products Liability lawyer at the end of the cemetery driveway.
That the quality of this plywood is leagues above the $14.00 stuff
is a major understatement. It is completely free of voids, knots and
imperfections and is glued under up under a "heat treatment" type of
process. It is certified for uniform glue spreading and veneer
thickness. I can refer you to an importer out here that has some of the
best "stuff" that you will ever see. HOWEVER, IT IS NOT CERTIFIED AND
IS NOT INSURED.
Anderson International Trading, 1171 N. Tustin Avenue, Anaheim,
Calif. 92807-1736 (714) 666-8183: 1-800-454-6270
:http:///www.aitwood.com.
Example: 1/8" 5 ply is $55.82 for a 61" X 61" sheet, plus a
minimum $10.00 UPS shipping charge and will be cut exactly in half, with
the face grain or across as per your instructions. This really is
beautiful stuff. A 2" X 4" X 1/8" piece of lumberyard stuff can be
broken over my bench vice by hand. I had an extremely difficult time
breaking this stuff with a mallet.
From my own research, this is the highest quality birch plywood
available. These folks have this material from ply 1/64" up to 12 ply
15/64". ONCE AGAIN, IT IS NOT CERTIFIED.
However, this is what I chose after making some in person, piece by
piece comparisons, with out regard to the cost. I know that I won't be
kissing my butt good-bye because a material failure here.
Hope this helps. Warren.
Subject: | Plywood: Follow-up |
Hi Guys:
If anyone does go to the http://www.aitwood.com site, go to the
"ultra thin plywood" portion of the catalogue. This is where the good
stuff is listed.
Warren
Hi Richard:
Ian's comments are right-on in all respects...especially with regard
to the available instructional material from EAA, and on the resale
documentation issue.
Having said that, Aircraft Spruce is in my backyard and I have has
several discussions with them...and other local builders.
The big issue on certification is very much related to legal
supply shops for tool & die, and architectural model makers. They
then provide some type of "certification" and pay for the liability
insurance, in case there is a structural failure and your family accepts
the business card from the friendly Products Liability lawyer at the end
is a MAJOR understatement. It is completely free of voids, knots and
imperfections thru and thru, and is glued up under a "heat-treatment"
type of process. It is certified for uniform glue spreading and
veneer thickness. I can refer you to an importer hot here that has
some of the best "stuff" that you will ever see. HOWEVER, IT IS NOT
CERTIFIED AND IS NOT INSURED.
Anderson International Trading. 1171 N. Tustin Avenue, Anaheim,
Calif. 92807-1736 (714) 666-8183: 1-800-454-6270:
http://www.aitwood.com. On the catalogue web-page, go to the
"ultra-thin plywood" section. This is where the good stuff is
listed.
minimum of $10.00 UPS handling charge and will be cut exactly in half,
with the face grain or across, as per your instructions.
This really is beautiful stuff. A 2" X 4" X 1/8" piece of
lumberyard stuff can be broken over my bench vice by hand. I had an
extremely difficult breaking this stuff with a mallet.
available. These folks have this material from 3 ply 1/64" up to 12 ply
15/64". ONCE AGAIN, IT IS NOT CERTIFIED AND IS NOT INSURED.
piece comparisons, without regard to the cost. I know that I won't be
kissing my butt good-bye because of a material failure here.
Subject: | Re: Plywood: Follow-up |
Thanks for the great info, but, how can I know if something I want to
use in my plane is certified and insurable? Does every piece of the
plane need to be certified and insurable, or is there a list of
things that need to be?
Richard
Pietenpols, Electronic Music,
Website Design, Stompilation
Subject: | Certification / Insurance |
I don't have a good answer for that one Richard. Each "aircraft"
vendor in the homebuilt market seems to attach different legalese to
their products. Some other folks won't even sell to you if you mention
that the material is going in a "homebuilt airplane". It seems to me
that all I can do is select the best material for each job; make each
piece to impossibly high standards and keep a journal and photo album
for my own education and entertainment....This is supposed to be fun!!!
Warren.
Subject: | Re: Certification / Insurance and plywood |
>Warren.
How true! Would Bernard Pietenpol have gotten so caught up in the
"certified aircraft" mumbo/jumbo? I think not! Good quality is what you
are looking for. And since your life depends on it, better make sure it is
great quality, not just good. But just because it has "papers" does not, in
itself, make it better. Benard used engines out of CARS! I am sure lots of
people thought he was crazy. If you want everything to be certified you
better put in an aircraft engine, use aircraft wheels, etc, etc. In the end
you won't REALLY have a Pietenpol! If you take this thinking a little
farther, then you aren't qualified to even be working on an airplane unless
you are an A&P. Better just buy a factory airplane!
You don't have to have materials documented as "certified aircraft" for
insurance or sale of a homebuilt but it MAY help. Good records on parts (be
they genuine "aircraft" or not) is always nice but not required. Perhaps
someone could supply specifics on the insurance: i.e. what insurance
companies require it and exactly what do they require? Does it get lower
rates? Is this only for structural components? Etc. Or was this just
referring to the parts suppliers insurance if someone were to go after them
for bad parts?
For what it is worth, Pete Bowers recommended door skins in his Flybaby
plans and noted that the plywood for the fuselage has very low stresses
(grossly over built). Given the similarity of construction I would say the
same applies to the Pietenpol (but have to admit I haven't analyzed it).
Apparently door skins were readily available at that time. I looked
seriously at luan lumberyard plywood (called underlayment) but didn't build
the plane. Underlayment needs to be free of voids so at least in that
regard it is what is needed for aircraft. I did some soak tests on the glue
that came out ok: no delamination. I cut up some and found no voids in the
core. It is only three ply so it is noticably weaker than aircraft material
with 5 plies as someone noted in their testing. Another thing to watch out
for on lumber yard plywood: often the outer plys are VERY thin and the
inner ply is very thick. I would avoid this type. Anyone have any real
data or experience with any of this? Strength of luan compared to birch? I
seem to remember them being about the same but it has been a long time.
Other than one person breaking some test samples, no one has given much
solid information. Most of the remarks seem to be just emotional responses.
Sure some material will be stronger than others, but is the extra strength
needed? I would also be interested in finding a supply of thinner plywood
(haven't checked out the web site given yet). Most of the lumber yard
material is thicker than needed for ribs (the original question) and seems
to be more suitable for the fuselage.
In the end, each person must make his own determination of suitabilty for
the construction materials for himself. Buying aircraft plywood does make
that easier by providing consistency.
Jim
Hi guys:
My reference had only to do with Product Liability insurance on the
part of the vendor and/or manufacturer of commercially available
materials.
The various EAA publications regularly carry advertisements for
firms that will insure homebuilt aircraft. Their requirements appear to
uniformly rely on the fact that you have a "signed-off" legal
aircraft. Having "certified" materials is not what is required, for
either the FAA paperwork to go flying, or to get insurance. Good
material and good workmanship is, for both.
For an interesting comparison, view the web site, and compare the
thin plywood list with any of the homebuilt catalogues. Most of the
homebuilt catalogues don't even offer 5, 7 or 12 ply material. It may
sound like an "emotional" opinion as to the strength...but it is
certainly a real experience with real material.
Warren
On Saturday, January 24, 1998 6:03 AM, Bobby White [SMTP:bobwhite(at)yournet.com]
wrote:
> Richard,
> Bobby
Bobby,
So what kind of plans to you have for sale?
Stevee
Subject: | Piet Images Archive |
I finally got to the point where I couldnt stand it anymore! The Piet
Image archive has been organized! You can now view over 200 images
acording to catagory: wings, engines, finished birds, etc...
Images in short supply are those of engines (especially Corvair
installations, hint, hint), and of assembled (but not covered) wings.
Submissions GREATLY appreciated! :)
http://www.wrld.com/w3builder/Piet/pics.html
Make sure you hit [RELOAD] when you get there!
Richard
Forgot to mention this in my last post. I added 45 new pictures
to the archive this morning. They are pictures of the Piet being
built in Limington Maine. All are hi-res digital photographs.
[RELOAD] when you get there! :)
Richard
Subject: | RE: Certification / Insurance |
Thanks for the information/references. This is the kind of details I
was looking for. Otherwise it is hard to tell experience & fact from
opinion & speculation. Still wondering about the strength differences
between 3 ply "homebuilt" material and material with more plys. The
higher ply count obviously is better, but exactly how much? Guess I
should get out the books and see if I can find something on this....
Jim
From: | Warren D. Shoun[SMTP:wbnb(at)earthlink.net] |
Sent: Sunday, January 25, 1998 10:09 PM
Hi guys:
materials.
Warren
Subject: | Plywood Source. Was RE: Certification / Insurance |
I found that B+D International had the same high quality finish plywood mentioned
here for about 30-35 bucks a 1/16" or 1/8" 61x61" sheet.
Great service and great price.
Steve Eldredge
Subject: | Re: Plywood Source. Was RE: Certification / Insurance |
You dont happen to have a toll-free # for them anywhere? I'd rather
buy plywood than long distance. :)
mentioned here for about 30-35 bucks a 1/16" or 1/8" 61x61" sheet.
> Steve Eldredge
Nevermind, I found it. For anyone else who's interested here it is:
800-222-7853
> > Steve Eldredge
Subject: | More flying over weekend was RE: Floating Pietenpol |
On Friday, January 23, 1998 3:56 PM, Warren D. Shoun
[SMTP:wbnb(at)earthlink.net] wrote:
> Hi Guys:
Grant has been on before, but isn't a member at this time.
I'd be glad to write something. What topics do you want to hear about? Not
like I'm the end all expert, but glad to share...
BTW I am about 8 hours into my flight testing at this point. I'll tell ya
there just isn't much to it in this airplane. 3 engine instruments
(tach,OP,OT) and my flight instruments to scan, once every few minutes.
The rest is enjoying the view!! I've been following the flight test
handbook the FAA published, and so much isn't applicable. IE; retractable
gear, fuel systems, flaps, constant speed props, and on and on. This is
such a simple flying machine, that once it is rigged, it is straight
forward flying. I have flown all normal maneuvers upto imminent stalls,
and spins. I am going to fly a few more hours before I go into a stall
series. I don't intend on doing any spins. One thing that I found is that
60 degree turns are ridiculously tight. Going so slow you turn on a dime.
Flying Saturday, I did my first short cross country flight from Spanish
Fork to Nephi. It was about a 45 min flight to cover the 30 miles, Trucks
passed with regularity. Ground speed 55mph. Any winds aloft make a real
difference. I didn't intend on landing, but my bladder dictated a touch
down. The trip home was about 25 min. Headwind turned to tailwind and I
was actually *passing* traffic! Ground speed got up to 80mph! This is
great fun. I hope to have my flight restrictions flown off by spring. I
also got a new prop to try. I have been flying with a 72x74" Sensenich, I
borrowed a Flotrop 72x78" to see about getting a better top speed. I'll
post the results.
Happy Landings,
Stevee
PS Weather is supposed to be above 50 degrees all week!
From: | "Sayre, William G" <William.Sayre(at)PSS.Boeing.com> |
Subject: | B & D International |
I can vouch for B & D International Inc, I have used their plywood and
it is very nice. Extra plys make for amazingly more strength!!! They
deal in millimeters so be prepared to convert. Believe you will find
knot-holes removed and plugged.
Bill Sayre
> Thanks all!
> Richard
> > > cool.
> > Richard,
Bite the bullet Richard, buy the best. The reason: Water proof glue and
the filler in the $14.00 version is a cheaper grade of wood versus what
should be the same type of wood as is on the outside, be it birch or
mohogany. There has been some discusion in the Piet. group about sanding
the plywood gussets for better adhesion (thereby getting rid of the
sheen/oily film caused by the rollers during the manufacturing process),
actually I don't like the idea of sanding because it breaks or cuts the
fibers. A better way is to take a straight commercially available razor
and scrape the surface without marking the gusset (same idea as if you
were planning). However it's your choice, enjoy building.
Regards, Domenic/ DCSBell(at)netcom.ca
Ian Holland wrote:
> Hi, Bill,
> Thanks, -=Ian=-
> > Subject: Plans
What's your location? I live in Toronto. I have a corvair you can have
$100. It's a 140HP. You'll have to remove the heads and replace with
110HP heads. I may have a line on a set of 110HP heads for free. You'll
next have to remove the camshaft and replace with a 95HP cam, Possibly
available from Clark's corvair Parts, in Sheldon(?), Mass. (try
searching for them on the internet. Also check if they have any rebuilt
engines or if they can build one up for you to your specifications.
Regards, Domenic
> Richard
Richard, The aircraft grade plywood has an aircraft inspector's stamp
all over the sheet. Also your receipt will specify the certification.
It's the retail version of the 'certificate of compliance', normally
issued to the retailler by the manufacturer. Hope this is helpfull.
Regards, Domenic
> Richard
Oh yes, One more thing I forgot to mention. There will be areas on the
fuselage that require large gussets. Try to cut out a piece for these
larger gussets that have the inspection stamp showing. Then you can
prove to your aircraft (FAA) inspector that you did use certified
material.
Later, Domenic
Subject: | Re: Piet Images Archive |
> Richard
Richard, I can send you some pictures of corvair engine installation,
But i'd like them returned. Send me your address. Or perhaps a friend
can scan them for me. I'll let you know.
Later, Domenic
If you send them to me, I can scan them and put them in the mail back
to you the same day. I have a super high resolution scanner at work.
If you'd prefer to have a friend scan them, that'd be fine, too.
Thanks much! Those pictures will be most helpful, as I am using a
Corvair engine in my Piet.
Many thanks,
Richard
If you send them, use this address:
Auto Europe
Attn: Richard DeCosta
39 Commercial St.
Portland, ME 04101
> Later, Domenic
Subject: | Re: Plans...Corvair Engines |
<< What's your location? I live in Toronto. I have a corvair you can have
Regards, Domenic >>
Rt 2
Shelburne Falls, MA 01370
Corvair Underground (parts) 1-800-825-vair
Po Box 339
Dundee, OR 97115
I have a set of 110 heads I am not using. Do not know what shape they are in.
I suggest talking to William Wynne down in Florida if you are thinking about a
Corvair. He will do any part of a project. I will post his number tomorrow.
I would love to talk with anyone rebuilding or flying a Corvair.
William Koucky
Subject: | Re: Plans -Reply |
Ian, the Ford Escort is basically an unknown for me since I haven't flow it
yet. I used the conversion kit made by Ed Lubitz, a Canadian airline pilot.
It has a simple, cast iron reduction system 2.5-1. The engine conversion
is mainly changes to the carb, removing emissions system, and shifting
the location of the distributor. The engine is reversed with the flywheel
forward. I have a full electrical system and somewhere between 70-80
h.p. I've run the engine about four hours static (mounted on plane)
without prop. It doesn't idle very well but from 2000 - 5000 rpms it runs
very well; this would be its normal operation range taxi/takeoff/climb. I
got the components second hand so don't know if they're currently
available. The engine weighs about 270 pounds. I hope to have the
plane in the air by April /May first. Ed apparently flew a Piet to Oshkosh
in the late 80's with this engine conversion. I've not run into anyone with
this set up so have no other reports. My whole installation seems solid
and I hope it will work well. Ask me in a few months. Bill
Rick, the Ford Escort engine conversion is based upon a kit designed by
Ed Lubitz, a pilot from Canada. The engine weighs 270 pounds
approximately and puts out 70-80 hp, more with various cam
configurations. The redrive (2.5-1) is mounted on the flywheel and
block--engine is reversed for airplane. The installation has starter and
full electrical system. Conversion is all external--mounting redrive,
modifying carb, shifting location of distributor, removing exhaust emission
controls. So far I have 4 hours static on the engine. Doesn't idle well but
runs fine in 2000-5000 rpm range. Conversion manual says it takes 2000
to taxi and 4000-4200 cruise, 5000 to take off. I've had some cooling
problems but have been running engine without prop--something you can
do with a car engine conversion. I have high hopes for the installation
but don't know how it will be for reliability or anything else. I hope to be
flying it by May 1--ask for details then.
Just got unit back from being serviced- up and running again
Ron
Subject: | Re: Propellor Hubs |
I have read two books so far about building wooden airplanes, one
from 1936 and one from 1947 (cause thats all that the Portland Public
Library has! I will, as $ allows, get a couple from the EAA), and
they have two different views about building wing ribs. One says to
draw the rib from the plans, using measurements from the datum,
etc... and the other says, if possible, build the gig right on the
full-size plan from the manufacturer (or designer).
How many of you build right on Bernie's full size plan and how many
draw the whole thing out from the (scaled) plans?
Many thanks!
Richard
> Many thanks,
> Richard
> Auto Europe
> 39 Commercial St.
> Portland, ME 04101
> > Later, Domenic
Ok, I'll talk to my friend and see how busy he is. otherwise I will send
you the hard copy. I think you'll be impressed.
Domenic
> Regards, Domenic >>
> Rt 2
> Po Box 339
> Dundee, OR 97115
a
> William Koucky
I'm just about finished my corvair version. Just finished making the
cowling. Looks good. Now I have to alodine and paint it. Next I'll
tackle the wind shields and last my flying struts. and that's all she
wrote. Will test this spring.
Later Domenic
Thanks! I can't wait to see them!
> Domenic
Subject: | Re: Building Ribs |
> Many thanks!
> Richard
I didn't get a full size dwg. so I scaled mine up. It wasn't difficult
at all. There were one or two mistakes in the dwg. that will be quite
evident when you draw to full scale. You can blend it in correctly with
no problem.
Domenic
> Many thanks!
> Richard
I built mine from the plans measurements plotted on to a piece of
particle board.
Plot the points
using a flexible straight edge; loft the points
using cheap wood of the same demensions as the rib members (1/2x1/4")
nail rib members into place.
Nail guide blocks surrounding the rib mockup.
remove and discard mockup pieces.
hot wax the jig.
drill holes for clamps and holes at rib member intersections so you can
tap the rib out of the jig after nailing one side.
Stevee
From: | "Warren D. Shoun" <wbnb(at)earthlink.net> |
Dear Richard:
I would suggest that you at least take 3 measurements on the
full-size rib from the plans and see if they are close enough for you as
to matching tolerances. On my copy at least, I decided to go ahead and
do a full measurement layout.
For grins and giggles, I took this to one of the old time mentors at
Flabob airport, known far and wide for his expertise. At first he just
laughed and suggested, tongue in cheek, that at these burning speeds of
70 mph I should be so picky, picky, picky???
Well, I decided to be picky, picky, picky anyway, and I do feel
better, and that's the truth.
Warren
> Stevee
I think I'll sell my KR2S, and RV4 plans at the moment because I want
either something that either has folding wings, or will land slow enough to
operate out of my (kinda short) field.
I'm holding on to a set of Sonerai 2LS plans for now, but may let them go.
I'm keeping a set of Cougar (which is kind of a Tailwind wannabe with
folding [sort of] wings), and a set of Raven (weld-it-up-yourself) Kitfox
look-a-like.
The Pietenpol keeps calling to me when I really ask myself what the most
honest, practical, and nastalgic fun airplane might be. The Piet certainly
has the largest following of knowledgeable people.
Isn't it funny how the mind operates? I don't have time to stop and fix
myself a glass of tea, but I'm all excited about building my very own
airplane:-)
Bobby
After a hiatus of nearly three months, I am connected to E-mail.
once more.
My old E-mail address was
grhans(at)freenet.edmonton.ab.ca
and it is decommissioned.
Please resubscribe me into the Pietenpol Discussion Group.
Thanks.
Graham J. Hansen
Richard- I built a rib jig then before gluing any thing together
stretched out a length of Saran wrap over the whole thing. It
keeps your jig clean and the ribs come out very easily. Mike C.
Hi Mike:
I appreciate your comments. From the pictures, your project is one
of the highest quality work products to be seen. Please keep your
details and pointers coming. Thanks. Warren.
>Richard,
The only plywood I have seen at the lumberyard for $14/sheet is 1/8"
luan or doorskin. You definitely do not want to use this in your
airplane. It is mostly endgrain material in the middle with a thin skin
on both sides. Not strong enough for aircraft use. I built a kayak
with it and the skins actually pulled off of the endgrain material!
Bite the bullet and get the good stuff, you will have much peace of mind
and find it easier to work with.
Mike List
Jim,
I sent Richard a reply to his question on the $14/sheet plywood and
advised him to stay away from it based on my experience using it in a
kayak. In a stressed area the skins pulled off the endgrain, and this
was just during the building process! As you mention, this stuff is
called both luan and doorskin, which has a thick core of endgrain
material with two thin face sheets. I don't think this is the same
material as Pete Bowers "doorskin", which was probably a European grade
of thin plywood. Play it safe, get the aircraft grade stuff, you won't
be sorry.
Mike List
Subject: | Re: More flying over weekend was RE: Floating Pietenpol |
Steve,
Sounds like you are having a real blast up there! I am real interested
in hearing how your stall tests come out. Are you planning on borrowing
a chute for your stall series? Maybe I sound like a protective mother,
but you never know with stall tests. Besides, the chat group needs
their mentor and providor!
Safe Flying!
Mike List
P.S. Lockheed is going to be sending us up there for two weeks at a
time, so maybe I can catch up with you in Provo on the weekends!
A few months back a wise Pietenpol builder on this list (and I
forget exactly who it was now) mentioned that white vinegar
on a rag will remove T-88 from your hands. It sure does.
Ah, the smell of vinegar on your hands in the morning. MC
Mike,
I been doing lots of stalls with my piet. Nothing real severe. I've let
one wing drop to maybe 1/4 turn spin and chickened out. I think it is
really important to do lots of stalls and slow flight so we know what to
expect in an emergency situation plus it's fun. The plane flys straight
hands off, but my Rt wing has a tendancy to drop first. I have no clue
why.
Craig
Subject: | Broadhead '98 Lodging |
I'm looking for lodging recommendations for Broadhead `98. Our group
will probably drive, so anything within 10-20 miles is useful.
Please reply directly to me (robb(at)bbt.com), and I'll send out a sum-
mary of the responses.
Thanks in advance,
Glenn Robb
Hello group from Dallas. I am in the process of buying
a Piet located in South Texas and bringing it back to
Dallas. I recently joing the Piet group and association
and would like to meet and talk to local (Dallas-Ft. Worth)
area Piet owners, builders, and pilots. I would like to gain
more light and knowledge of this great airplane.
Thanks in advance.
Mike King
Dallas, Texas
(214) 905-9299
mikek(at)intex.net
ring: 214.905.9299 fax: 214.905-1438
zap: mikek(at)intex.net
web site: www.comedy-wire.com
Subject: | Control pressure |
After hooking up the elevators on my Piet, I'm concerned about the
amount of pressure it takes to move the stick. Steve or others, how
much pressure does it take to move the stick back and forth in your
plane? Do the control surfaces move easier in the air? As I sit in my
plane I need a fist on the stick and a pretty good pull to move them.
Comments???? Bill
From: | Kevin McDonald <kevin.mcdonald(at)dev.tivoli.com> |
Subject: | Re: Control pressure |
Hmm,
this is not a balanced elevator but I didn't really notice any
major pressure but some efforrt is required.
Is there any binding of the cables or control surfaces?
any stuck pulleys?
You will finds the elevator to be very light and sensitive in the air.
The ailerons are slow and not very responsive.
Has anybody added gap seals to the ailerons?
~ktm
> my
> Comments???? Bill
Subject: | RE: Control pressure |
I have noticed the same thing in the air as Kevin. On the ground, moving
the elevator requires just enought to lift the weight of the elevators.
Check for binding, but it is a bit heavy. I also put a pully on the back
of the rear cockpit seat to negotiate the bend to the top of the walking
bar. Aileron forces on the ground on my ship are heavy. I imagine that I
have some binding due to the rear position of the wing. I would say though
that my ailerons are very responsive, but I have a full length piano hinge,
therefore no gap. (Not implying that my roll rate is particularly swift,
just that I get wing movement with each input of the stick.)
Stevee
On Thursday, January 29, 1998 2:11 PM, Kevin McDonald
[SMTP:kevin.mcdonald(at)dev.tivoli.com] wrote:
> Hmm,
> any stuck pulleys?
> ~ktm
> > my
> > Comments???? Bill
Bill,
My alerons are fairly stiff, but the elevator is very light. In fact I
had a hardtime adj to the lighter control pressure the first time I flew
the plane. Maybe you have something rubbing.
Craig
From: | Ken Beanlands <ken.beanlands(at)west.gecems.com> |
On Thu, 29 Jan 1998, clawler wrote:
> Bill,
> Craig
I've had a simular experience in a friends Christavia, heavy
ailerons/light elevator. He solved the problem by adding aileron spades
to the top and bottom of the aileron control horn. By adjusting the size
of the spades, he was able to nicely balance up the control forces. There
was no noticable difference in cruise.
Ken
Subject: | Re: Back on line. |
> once more.
> Thanks.
> Graham J. Hansen
Welcome back,
Stevee
> stall
> Steve,
> interested
> borrowing
> mother,
> Safe Flying!
> Mike List
Mike,
Let me know when you are comming! I'd be glad to have you for an
afternoon and dinner to chat.
Stevee
> From: Graham Hansen <grhans@cable-lynx.net>
> Subject: Back on line.
> Date: Tuesday, January 27, 1998 11:17 PM
> once more.
> Thanks.
> Graham J. Hansen
Subject: | Model A Radiator options |
Does anyone have any information regarding placing the radiator on a Model
A - Air Camper under the motor as opposed directly in front of the cockpit?
This has been another reason I've been leaning towards an air-cooled version
as I tend to like to see in front! I tought I'd seen something about this
before. Has anyone built one like this, and are there cooling problems?
Jim Wright
jgw(at)skynet.be
From: | jkahn(at)picasso.dehavilland.ca (John Kahn) |
Subject: | Re: Model A Radiator options |
You can do it that way but you must have a header tank up high somewhere
so steam bubbles in the head have somewhere to go. Possibly you could
build a header tank into the center section leading edge.
I had also thought about mounting a rad flat in the center section with
appropriate scoops and/or ducts, and putting the gas tank in the nose (which
would mean moving the model A's carb down below the engine).
johnk
Have you looked in the 1933 Flying Manual from EAA? In an article on the Gere
Sport, page 18, they describe installing a radiator beneath the Chevy engine,
complete with photos of the installation with a header tank. Might be
interesting.
(new Guy), Ed Woerle
Ken,
I not sure spades fit in with bernie's philosphy. Guess I'll continue to
use lots of rudder instead:)
Craig
-----Original Message-----
Sent: Friday, January 30, 1998 7:53 AM
Subject: Pietenpol-List: Re: Piet Chat
Thanks for the quick response...as for the intro, I am Ed Woerle, a
50-something Senior Aircraft Mechanic for FedEx. Also have IA ticket, and am
multi-engine land rated. I own a T-41A and Cessna 150. My fly-buddy is a
FedEx Captain, he has a private strip where we keep my aircraft, as well as
his Twin Commanche, L4, Cessna 120 and Cessna 140. His current project is an
RV8 (will be one of the first kit-builts to fly). I am lusting for a Sky
Scout, and plan to keep everybody up nights trying to answer my questions. I
can be contacted at either of the following:
EdWoerle(at)AOL.com
Ed0248(at)AOL.com
Since I plan to start with the empennage first, I have several questions
regarding it, to wit:
1. Mr. Hoopmans' plans show the leading edge routed 1/2 inch for the rib, the
"center beam", what I would call the spar, is 3/4 inch thick, and the "main
beam" is 5/8 inch. These don't add up for a flat plate as described by Mr.
Pietenpol in the Air Camper instructions. Where am I misreading this?
2. Are the plywood gussets inset into the leading and trailing edges and end
pieces, or are they glued on top?
3. The plans don't show where the flying wires attach to the stabilizer. As
I read the plan, where they are supposed to attach the attach point is below
the surface of the stab. Do we glue a spacer on the t/e and the spar to bring
them up to grade?
Finally, I can't say enough for the guys at Replicraft. I asked for two
different catalogs, and asked them to bill me for the postage, which is high.
They came almost immediately, by first class mail, and I was told that they
feel it is important they keep the loyalty and interest of us by treating us
so well. I know where I'm going to buy some of my stuff!
I know, I'm LOOOOOOONG winded.
Bye
Ed
Hi Jim:
You might want to get a copy of the 1933 Flying Manual from the EAA Aviation
Foundation Library. I think the cost is about $6.00. In addition to a lot of
info on the Piet, there is a great article on the Gere Sport Biplane, which
mounted a Model A Ford, with the radiator under the engine. From page 4-18 are
several detailed drawings, photos and descriptions.
Warren
Subject: | Re: Model A Radiator options -Reply |
Orrin Hoopman sells plans for an underslung radiator. They are more
accurately "informational drawings" than plans. Included with the
underslung radiator are drawings for a steerable tail skid and a Velie
engine mount.
His address is:
Orrin Hoopman
800 SW 17th St.
Austin, MN 55912
>>> "Warren D. Shoun" 01/30/98 10:29am >>>
Hi Jim:
Aviation
4-18 are
Warren
> johnk
Hi John, Are you coming to the meeting on Monday?
Domenic
>>Warren.
>for bad parts?
>Jim
>Right on Jim, was trying to come up with a diplomatic to say it. Agree with
you 100%. Also wanted to thank you guys for all the neat engine info.
Regarding plywood, has anyone checked into Hobby Shop birch plywood? Here in
the Memphis area at least two of the local "Building Supply" houses have
sheets of modeling plywood up to 3/32" in sheets up to 2'x4". Sure looks
interesting for gussets, etc.
Subject: | Latex fabric finishing information. |
I recall considerable discussion several months ago regarding the use of
latex
paints on fabric and cannot remember who was experimenting with this
method.
Also, I was off-line for about three months and have lost any info. I had
stored--
except for some hard copy I made but cannot find in the chaos resulting
from
the moving process.
Some day I will be recovering my Pietenpol and would appreciate any and all
information I can get on the latex system. Thanks.
Graham Hansen
From: | rdecosta(at)autoeurope.com (Richard DeCosta) |
Subject: | 35 Pictures added |
I visited Everett Millet in Windham, ME yesterday and got a good look
at the Pietenpol he is building. He is the nicest guy you'd ever want
to meet! He let me poke around his workshop with my digital camera
for over an hour and a half, showed me his new hangar, and explained
a lot of the construction process. I brought back 35 pictures which I
have added to my website, under the section called "Everett Millett's Piet".
Enjoy! I sure did!
http://www.wrld.com/w3builder/piet/
Richard
Web Developer, http://www.autoeurope.com
Homepage: http://www.wrld.com/w3builder
Subject: | RE: Latex fabric finishing information. |
Graham,
Stevee here. I painted with laytex. I have unfortunatly had my plane out
in the weather all winter long since it went to the airport in October. I
have to say that I am very satisfied so far. Even under snow and ice it is
still doing fine. I even crack the ice of on good days and go flying. No
problems so far. Not a rubbed glossy finish by any strech, but it fits the
era of the airplane wonderfully.
I'll tell ya this is one fun plane. I have people trying to "catch" me
while I out on Saturdays to talk about the "Air Camper" on the ramp.
Dad's and their sons have come out of the wood work because they see that
it might be something they could tackle. It's great to share the dream
with them. I just wish that I had enough hours flown off to give rides. I
even get looks and waves from Bonanza and Commanche drivers, (secretly
wishing they were flying like barnstormers instead of cross country
commuters.) The most fun though are the rough leathered of pilots of ye
ster-year. I've met a couple of sage old guys who have long since hung up
their pilot wings. They see me pull up to the fuel depot and they get a
glint in their eye. What ever they were doing or whatever they were
talking about gets put on hold as they saunter over and say something like,
"That looks like a Pietenpol. I remember when...."
On Sunday, February 01, 1998 9:12 PM, Graham Hansen
> latex
> method.
> stored--
> from
> the moving process.
all
> Graham Hansen
BTW, to whomever asked about the passenger door, among the new images
are some good pics of a passengere door. Go to
http://www.wrld.com/w3builder/piet/ Image Collection, and they are
under Everett Millett's Piet, called EM-psgrDoor1.jpg,
EM-psgrDoor2.jpg and EM-psgrDoor3.jpg.
Richard
Subject: | Re: Latex fabric finishing information. |
> Great stories Stevee!!! Thanks for sharing them with us. Keeps me going.
Warren
Do tell more. I am interested in hearing the whole story of the process
you used using latex. Iv'e heard of people using it but never any details.
Sound like it would be a little cheaper than poly-brush and the family of
polys.
jas
>Graham,
>> latex
>> method.
>> stored--
>> from
>> the moving process.
>all
>> Graham Hansen
jimsury(at)fbtc.net
Mike,
It may have been me that pointed out one of the many uses of vinegar. I
would like to add that I think I have an allergy to epoxy now. I have used
it for years in boating and believe that it can build up a reaction on the
skin, until one day things start happening. The skin on my fingers near the
nails (most sensitive) will now turn red and start peeling if I get epoxy
(or other harsh chemicals) on them. I use latex gloves now and save the
vinegar for the tools and brushes. Just wanted to save someone else from
finding this out a few years down the line.
Ted Brousseau
Naples, FL
P.S. How's your mom? How's your bird? Hope to meet you some day.
Jim,
I have news for you. I have a Continental A65/75 and I can't see in front
of me!! Especially with a passenger, but still flies with the nose high
enough to not be able to see well without one.
Ted Brousseau,
Naples, FL
>Jim Wright
>jgw(at)skynet.be
Ted,
Thanks for the Continental info.
Right after I sent this out I received my newsletter. In the back Grant has
a quote about the fact that the "guy talking about the radiator blocking his
view and blowing heat in the cockpit has never actually flown an A-powered
Piet!"
Unfortunately he's right in my case!! Can't seem to find one over here in
Europe yet to get a ride...Oh well... I'll just have to plan my vacation one
year to coincide with Brodhead!
For what it's worth though, he's got me re-considering "dusting off" one
Henry's best! Hard to beat the sound of a Model-A Ford! Hope the Belgian
authorities agree.
Jim Wright
jgw(at)skynet.be
Date: Tuesday, February 03, 1998 05:03
Subject: Pietenpol-List: Re: Model A Radiator options
>Jim,
>Ted Brousseau,
>Naples, FL
cockpit?
version
>>Jim Wright
>>jgw(at)skynet.be
Steve,
When it is possible to do so, could you remember the procedure
you used on your covering... including precautions necessary
to avoid messing up the job? I'm sure there are others in the group
who would also appreciate such information.
Traditional dopes and such are becoming frightfully expensive and,
let's face it, they are not very healthy materials to be working with.
Latex, on the other hand, is a benign substance by comparison and
should be less expensive.
As you pointed out, a high gloss finish is not necessary on an air-
plane like a Pietenpol. Even a traditional doped finish does not have
that "wet look" unless it is made up of many coats, hand-rubbed
and waxed. And that much dope will likely cause distortion of a
light structure through shrinkage of the cover. I think you are onto
something, Steve.
> Subject: RE: Latex fabric finishing information.
> Date: Monday, February 02, 1998 7:46 AM
> Graham,
out
I
is
No
the
Sounds interesting. Tell us more. Especially about UV protection.
I
up
like,
Yep. I've been flying mine since 1970 and it is a great little sportplane.
Darned good skiplane too, although it should have a canopy and heater
for that sort of thing.
Many thanks for the information. More! More!
Graham
of
> > latex
> > method.
had
> > stored--
> > from
> > the moving process.
> all
> > Graham Hansen
Subject: | RE: Plywood Gusset Question WAS RE: Happy Day! |
Mike,
I have a question about "endgrain material." Do you mean that the grain
is perpendicular to the sheet? This seems like a very strange way to
make a plywood lamination. Seems like there would be a lot less waste
using the standard method of peeling a log into a sheet, resulting in
the more normal plys. If the grain is perpendicular to the sheet, then
by all means, this is not suitable because the sheet is VERY weak. Only
the thin outer layers will support tension and then only in one
direction (with the grain). I will look more closely the next time I
find a sheet of plywood with a thick core.
I have luan lumberyard material that has 3 equal thickness plys and is
of "conventional" construction; i.e. all the layers have the grain
running parallel to the face with the inner ply turned 90 degrees.
It has been good to see more discussion of WHY certian things are bad
and what to look for.
Jim
Sent: Thursday, January 29, 1998 4:06 AM
Subject: | Re: Re: Plywood Gusset Question WAS RE: Happy Day! |
>Richard,
Mike List
Hi guys:
I've just finished the legs of my landing gear ready to fabricate the
axles.
But before I weld the 1 1/2" axles in place I thought I should probably get
the wheels first just to make sure that they needed that size of axle. I
think that I will use 6" wheels. Wow are the wheel and brake setups in Wicks
and Aircraft Spruce high or what? Will have more in wheel and tires than
airframe. Any of you guys have any other ideas. Tried to fine used 172
wheels but they are getting scarce.
Also the information and ideas on this chat line thing are really great.
Thanks alot.
Im not sure where he got them, but Mr. Millet, in Windham, ME has
very nice a/c wheels with brakes that were, if I remember correctly,
around $75 each. I can find out if you like.
Theres a picture of one here:
http://www.wrld.com/w3builder/piet/acimg/EM-wheel.jpg
Richard
> axles.
> Thanks alot.
TED,
Do you have the chord angle rigged right?
What speed are you getting?
How did your weight and balance come out?
A plane should not fly so nose high...
>Jim,
>Ted Brousseau,
>Naples, FL
>>Jim Wright
>>jgw(at)skynet.be
From: | Gary McArthur <garymc(at)admin.hilconet.com> |
Rick:
I got a pair of Goodyear wheels w/brakes from the Flymarket at Sun-N-Fun.
The pair cost me $40.00 There were probably 15-20 more pair for the same price.
There were all sorts of master cylinders for 5-20 bucks apiece also. I bought
retread tires from Hawkins Aircraft Tire Co. (1-800-321-9717) for about $25 ea
and I forget what I paid for the tubes. These are the same wheels used on my
Ercoupe - not the greatest braking power in the world - but they do the job -
besides the Pietenpol will be at least a couple of hundred pounds lighter...
Gary...
Rick Rager wrote:
> Hi guys:
> axles.
> Thanks alot.
Richard, I also would be interested in more information on the
whhels/brakes. I only got about a quarter band on the photo.It looks like a
wire wheel from what I could see. Can you supply address/phone number and
resend picture?
-=Ian=-
December 12, 1997 - February 04, 1998
Pietenpol-Archive.digest.vol-ad
