Pietenpol-Archive.digest.vol-ao
February 07, 1999 - March 15, 1999
doesn't want to accept an answer just because somebody says that it is
so.
If I am just call me mister skeptic.
Ron
Gipson
Subject: | Re: Ford radiator placement |
PI>I don't know a whole lot about the Ford A engine, but It seems that I
PI>remember somewhere about a fellow who put his radiator at the chin
PI>location. ( at the bottom next to the fire wall.
If you look in the 1932 Flying and Glider Manual there are pictures of
one or two old
piets that had radiators mounted under the engine, and I seem to
remember that I
read somewhere that Bernard Pietenpol did it on one of the models he
built. I'm sure
it can be made to work. I would recommend to anyone who is thinking of
an automotive
engine setup that you subscribe to Contact! magazine put together by
Mick Myal. It
has a great deal of excellent material. In particular, for radiator
placement and
considerations that lead to good cooling, there is an article in the
July-August, 1998
issue ( #45 ) by Hans Mayer that will really help you.
His address: Contact!
email address: contact1(at)flash.net
new website: www.NonProfitNet.com/CONTACT/
The website also contains a list of all the back issues and their
contents. When I was
at Oshkosh two years ago I subscribed ( $20 a year ) and paid something
like $75 for
all of the back issues. Now that is a lot of money to me, and I
agonized a long time
before I decided to do it. I have not been disappointed one bit.
By the way, Mick
himself is working on a plane (I don't recall what type) in which he is
installing a
Geo/Suzuki 1.3 L. 4-cyl. That is one of the engines I am most
seriously considering
for my Piet, and he is going to have some articles about it soon.
John F. in Peoria
Subject: | Re: Help... do I have a major problem? |
Among other comments, Ron Gipson noted:
>Years ago, my brother and I built a replica Eidecker. The ribs were
>gussetted with mahogany door skins. The glue we used was yellow carpenter
>glue. Scuffing? Whats scuffing? I think if you try to pull a gussett off
>one of your rib joints that has been glued with T-88 you will find the
>integrity much greater than any joint in the entire plane we built and flew
>in the early 1960s.
I know it's a little off-topic, but I'd love to know more (lots more!)
about that Eindecker. Always wanted one.
Owen Davies
Over the years, I've had discussions with Vi Kapler & others at Brodhed
about this, 'cause it's what I wanted to do. Considerations are:
1. Moving radiator, coolant & plumbing radically changes c.g., so plan for
it:
2. Extra drag associated with ducting & cowling - you have to do some
engineering to balance airflow requirements vs. parasite drag - maybe O.K.
with more modern liquid cooled engines, but with an 'A' or 'B' you're pretty
close to the power-edge already.
3. Loss of thermosyphon effect ie: coolant will not circulate in "heat
rises" fashion if your water pump takes a powder, so landing decisions are
time-compressed.
Seems like Bernie had it right all along. I'd STILL like to explore a
radiator relocation, but I'd like to see data & info on a thru-the-prop, al
la Jenny approach.
Low & Slow,
Lee in MI
> one or two old
> remember that I
> built. I'm sure
> an automotive
> Mick Myal. It
> placement and
> July-August, 1998
> like $75 for
> By the way, Mick
> installing a
> John F. in Peoria
On pages 18 & 19 of the 1933 Flying Manual is an excellent description,
including drawings, of the Gere Sport Biplane's use of a wing mounted header
tank and a cowling mounted radiator, using a Ford or Chevy engine. Seemed to
work well and be popular.
Warren
Install the radiator where Bernie did, and you will be a HAPPY CAMPER !!
Subject: | Re: Rib strength & testing |
Hi All!
Here's my $.02 worth on ribs & testing!
I found my copy of the 1962 FAA Basic Glider Criteria handbook - a lot of
good info on figuring loads, etc. for flying machines in our speed range!
There is a section that describes how to load a wing rib.
If the wing fabric is attached by using rib stiching, the rib may be loaded
on the bottom cap strip ( in the test the rib is mounted upside down on
stub spars & the test loads are applied to the bottom cap strip) The loads
are to be 125% the ultimate air load (125% x 4 - 4.5 g's?) each rib will
handle (rib spacing x chord will give the sq. ft. each rib is supporting
(1ft rib spacing x 5 ft chord = 5 sq ft x ult load per sq ft x 125% = load
per rib -- my math gave about 40.75 # sq. ft.-- 1050# gross / 145 sq ft
wing area = 7.25# sq. ft. x 4.5 x 1.25) This is about 204# applied to your
test rib! This load is divided up into (16) equal loads (12 3/4# each)
that are applied at various points along the rib -- most of the points are
on the front 1/2 of the rib. (i.e at .007, .02, .04, .063, .080, .114,
.148, .185, .228, .272, .327, .38, .448, .528, .72, .9 the chord length)
The loads can be applied to the rib thru 1" blocks to prevent local
capstrip faliure.
Interesting stuff -- don't know how much of this load a Piet rib will
handle -- the test engineers I worked with always said that if the part
didn't break, the test wasn't a good one (it was better to have a failure
than not -- if the part survived, you didn't know if it was 5% or 200%
stronger than it needed to be!)
Mike Conkling
Pretty Prairie, KS
P.S. My Model A engine is now in our barn -- it's a former combine engine!
Pulled the head the other day & the cylinders look pretty good -- only
about .005 ridge to clean up at the cylinder top. It came with a WICO
magneto that is driven off the old spark distributer drive! Maybe we won't
need to make a mag. drive off the end of the crank !?
> From: Bill Talbert <wtalbert(at)flash.net>
> To: Pietenpol Discussion
> Subject: Re: Rib strength & testing
> Date: Saturday, February 06, 1999 8:18 PM
> Richard,
> You can use one or two. Although remember the larger your
> sample the more accurate your test.. If you test one, you
> will know the results for that one. If you test two and
> there is not a significant deviation, you have a better
> answer. Remember, you can do NDT ("non-destructive
> testing", also known as "quality control") just by bringing
> the weight up to minimum numbers (for instance the 400 lbs
> in my example) once you have satisfied yourself it will
> hold, stop. If it fails before you reach the minimum,
> wouldn't you rather know that on the ground? Decide what
> you want to know. If you want to know how much weight the
> rib can withstand, you have to take it to failure. If you
> want to know if you have a good glue joint, then take it to
> the minimum weight (personally, I would take it to min +20%,
> it is known as a safety factor). By the way make sure you
> use gross weight and not dry. Also don't fudge the
> numbers. If the expected gross weight is 857 pounds, use
> 857. don't say " 857, let's call it 900 to be safe" it
> compounds the problem . because if you use 900 then add a
> safety factor of 20% you are now 30% above. I cringe at
> this but.... but. Write a procedure. determine what you
> want to do and write it down and how you plan to accomplish
> this. Then give it to an engineer type and ask them to
> review it, see if they concur. (I hope none of you work
> with me, I could never live this down, suggesting you write
> a procedure). One last thing, you don't have to test every
> rib. If you are satisfied after doing "x" number without a
> failure, assume they are all of that quality. (assuming you
> don't change the process, i.e.. different glue, scuffing vs
> not, etc.) Good luck and great website
From: | Ray Masters <masters(at)bleriot.cac.psu.edu> |
Subject: | Re: Model "A" Advice |
On Sat, 6 Feb 1999 RdwdSgn(at)aol.com wrote:
> Ray,
> For the record, where are you located?
> Ron E.
State College, PA (Home of Penn State).
Dead-center of Pennsylvania, as we like to say.
Ray
I can't find my reference at the moment, but I remember that Mr. Pietenpol
did indeed mount a radiator at the chin location, but only once since he
found that the reduced air flow through the radiator caused cooling
problems. I would also think there would be a problem handling the extra
hose on the head to take care of the steam pocket. I am finding that the
best advice is to follow the plans! There was no mention of the chin
location in the Pietenpol Manual which is published by Don Pietenpol.
However, it did say that planes built by Mr. Pietenpol after 1937 had the
radiator mounted on the cabanes rather than on a mount on the fuselage, with
the to pf the radiator inset into the leading edge ofthe wing. This made
for a wider but shallower radiator, resulting in less frontal drag (inset
into the wing), with more visibility between the bottom of the radiator and
the top of the engine. Incidentally, I found this manual, which is available
through the Pietenpol family web site to be a very valuable book. It goes
into great detail on construction, and modification of the Model A.
Al Swanson
Fuselage done, ribs done, working on the metal fittings.
>one or two old
>remember that I
>built. I'm sure
>an automotive
>Mick Myal. It
>placement and
>July-August, 1998
>like $75 for
>By the way, Mick
>installing a
>John F. in Peoria
I have thought about making a top tank the same shape as the wing leading
edge and moving it back that few inches so that it blends in. Early plans
stated that the rad could be cut in half and the halves stacked so as to
double the thickness. I would also suggest that anyone contemplating using a
Ford engine relocate the waterpump to feed into the lower water jacket
inlet. Model As and Bs have the pump locatedat the head outlet. The pump in
its stock location, if working well, causes a low pressure area in the head.
This lowers the vapour pressure and makes these engines more prone to
boiling than if the pump is located lower and pressurizes the block. I have
seen several with this conversion and the owners felt it was a great
improvement. Piet .54 in Richards image file is a picture of a Piet with a
low mounted rad built in the early thirties.
The comment to check out Contact is a good one. With careful planning I'm
sure that a rad can be enclosed inside the cowl and still work efficiently.
The Funk brothers successfully did it with the model B.
J Mc
-----Original Message-----
Date: Sunday, February 07, 1999 11:17 AM
Subject: Pietenpol-List: Re: Ford radiator placement
Subject: | Corvair or Ford? |
Now I dont want to start a holy war on the list here :), so please,
anyone with an opinion please email me directly: AirCamper(at)Yahoo.com.
(BTW, finished rib #28 today!! :)
Anyway, I need to choose an engine now, before I start my fuselage. Up
until a few days ago, I was sure I would use a Corvair, but now I am
not so sure... I have been watching the videos of the '97 & '98
Brodhead fly-ins and have been enchanted by the Ford installation -the
look, the romance, but mostly the SOUND. What a beautiful sound!!
The problem is, I have heard rumors that the Ford installation
required a lot of "tinkering" to keep in running well. That is really
the only thing that is keeping me from making an outright decision to
go with the Ford. Anyone with thoughts email me please:
Thanks all!
Richard
p.s. Dont bother suggesting the Continental; I've fully considered
it and decided its not an option. <-- polite but firm tone of voice :)
http://www.wrld.com/w3builder
Now you can buy my CD at MP3.com:
http://db.mp3.com/Visitor/order.php3?cd_id=968
Richard,
I'm having trouble reaching your site, Fly.to/Pietenpol. I just get a
redirect service. Is the site temporarily down? I'd love to see the mpegs!
Don Cooley
Richard,
Just found the mpegs at your Aircamper site. They're great! Thanx for all
you have provided for us at your site!
Don Cooley
Subject: | Re: Corvair or Ford? |
Nothing wrong with a good holy war. I for one would like to hear the
opinions on the ford engine.
ocb
>From steve(at)byu.edu Sun Feb 7 16:56:52 1999
>Received: from adena.byu.edu ("port 1449"@adena.byu.edu
[128.187.22.180])
> by EMAIL1.BYU.EDU (PMDF V5.2-31 #31181)
> with ESMTP id <01J7GYVSL0W68WYB4B(at)EMAIL1.BYU.EDU> for
oilcanbob(at)hotmail.com;
>Date: Sun, 07 Feb 1999 16:57:15 -0800 (PST)
>From: Richard DeCosta
>Subject: Corvair or Ford?
>Sender: Maiser(at)adena.byu.edu
>Errors-to: Steve(at)byu.edu
>Reply-to: Pietenpol Discussion
>Message-id: <1D639F5494(at)adena.byu.edu>
>MIME-version: 1.0
>X-Mailer: Mercury MTS v1.44 (NDS) (via Mercury MTS v1.44 (NDS))
>Comments: Originally To: "Pietenpol Discussion"
>X-Listname:
>Thanks all!
>Richard
From: | Rob Hart <robihart(at)rph.health.wa.gov.au> |
Richard
As one very early in the piece, I still have a lot to learn. However,
in my brief experience I had thought that choosing an engine
specifically designed for aircraft (the continental) would make a lot
of sense. Am I mistaken? If not, for us Oz builders would the Jabiru
be OK? Fords or corvairs are a little had to come by here.
Thanks in advance for your comments
Rob
Oz Piets: Nearly the only ones to fly inverted...
I just tried it and it worked ok. You may need to include the http://
in front of the url. Complete url: http://Fly.to/Pietenpol
Let me know if that still doesnt get you there.
Richard
---ADonJr(at)aol.com wrote:
> Richard,
the mpegs!
> Don Cooley
From: | Michael D Cuy <Michael.D.Cuy(at)lerc.nasa.gov> |
Subject: | Re: spoke wheels |
> I have drilled pilot holes in the flanges...36 holes for easier to find
>US style rims, but I don't know what size the holes should be for the
>spokes, also what size should be the countersinks?
Bob- the hole size depends on the gauge size of your spokes. Don't
quote me on this but I believe my spokes were 8 or 9 gauge and it took
a 5/32" drill to accept them. Counter sinking was done one at a time
by using a standard countersink bit and going deep enough to allow the
conical portion/ tapered to seat some in the flange. You don't have to
countersink but I did it for more surface area to contact the spoke end.
>Lastly what size were the spokes you used, and did you roll the threads
Rolled threads are the standard for bikes and airplanes. You can use cut
threads but run the risk of eventual fatiuge failures. Buchannen's Frame Shop
in CA makes custom spokes for any application if you give them enough info.
They may be on the net.
Mike C.
find
Don't
took
a 5/32 drill to accept them. Counter sinking was done one at
a time
the
to
end.
threads
use cut
Frame Shop
info.
Mike C.
The plans do not show how and where Bernie installed the radiator. Are there
some detail plans that we have missed?
Thanks, Glenn in VA
I have a couple (few) of questions that I would like answered before I
start building. Thanks in advance for your help.
1- What does it cost build the Piet with spruce? What about other
recomended woods and their cost?
2- Which glue is recomended?
3- What recomendations on a source(s) or company(s) to purchase
materials for the Piet?
4- Whats recomended reading prior to building? Just the last few posts
about scuffing the gussets prior to glueing made me realize there is a
great deal of knowledge needed prior to construction.
I'm ordering my plans for the Piet today and can't wait to get started
building. Thanks again for everyones help, Randy.
Hi Steve:
I'm going to be in your area from this Thursday evening through Sunday.
There are a few questions about the tail group I'd like to ask someone who
has built one. Will you be in town and would you mind spending a few
minutes with me? Thanks.
Mark Boynton
Phoenix, AZ
Hi Richard:
I'm unable to access your site. It's worked in the past but now I'm getting
the error message "Netscape is unable to locate the server 207.140.1.221%20.
The server does not have a DNS entry. Check the server name in the Location
(URL) and try again." This happens when I try accessing through the
bookmark I'm using or through the hyperlink you included in your message
below. Any advice? Thanks.
Mark Boynton
Phoenix, AZ
> Richard
> > Richard,
> the mpegs!
> > Don Cooley
Richard:
That works. Thanks.
Mark Boynton
Phoenix, AZ
> The %20 should not be there in the 207.140.1.221%20. Not shure where
> it came from. You can still access the site via this address:
> http://207.140.1.221/w3builder/piet
> Richard
> ---mboynton(at)excite.com wrote:
> > Hi Richard:
> getting
> 207.140.1.221%20.
> Location
> message
> > Mark Boynton
> > Phoenix, AZ
> http://
> > > Richard
> > > > Richard,
> get a
> > > the mpegs!
> > > > Don Cooley
Should be here, I have my plane at home right now, so drop on by.
Steve E
Sent: Monday, February 08, 1999 7:50 AM
Subject: Pietenpol-List: To Stevee
Hi Steve:
Mark Boynton
Phoenix, AZ
Michael,
I have also found an old Model A engine form a combine. Is it the same
engine, same block etc. I wondered if it was the same engine and ok to us. I
didn't know how much of it was usable for a Piet. Where is Pretty Prairie at?
I'm near Burlington. The engine I found had a coil and electric system. To
bad....
Greg Yotz
Michael Conkling wrote:
> Mike Conkling
> Pretty Prairie, KS
On Sat, 6 Feb 1999, Earl Myers wrote:
> fall off, get tired or break something. If you used T-88 glue or the West
> System, I'll bet you get tired of dancing on the 2x4's before anything
> breaks! If you used Resorcinol Glue with unscoffed gussets, you then now
Which "flavour" of the West System's products do you use? I have some of
the 206 and 207 and have tried both for glueing wood. They both create an
exceptionally strong bond, but the viscosity of the glue is so thin that
it doesn't have good gap filling properties. Granted, this is something I
can live with especially when you balance off the ease of use (those pumps
are GREAT) and the lack of odour.
I have to laminate some 1/8" and 1/4" plywood to form the window frames of
my Christavia and I plan on using the West system product as it is
actually designed for this type of application.
Ken
On Fri, 5 Feb 1999, oil can wrote:
> Gezz, I hate to say this...
> After that I roughed up my gussets on a sanding wheel with a few good
> swipes, and the joints went from weak, to very strong.
Speaking of sanding, I ran across a little problem recently when I had to
sand several corners that had been varnished that had been varnixhed
before I realized I had forgotten the gussets. I was running through
sandpaper like crazy as it was bent over a sanding block at a hard angle
and was being chewed up quite a bit. Getting rather frustrated, I looked
for something else and found some older sanding belts for my belt sander.
I sacraficed one for teh cause and cut a section to fit the sanding block.
With the woven backing on the belts, they are quite resilient and worked
like a charm. Although more expensive than a sheet of sandpaper, they are
still pretty cheap and will last a LOT longer.
Ken
This sounds like a great test procedure. But I think that it if you do a
destructive test and the joints always pull away with wood, and not just
glue, you can't expect any more. If the design is sound and the wood to
spec. you can consider yourself in good shape. Correct me if I'm wrong, by
all means.
Brent Reed
Date: Saturday, February 06, 1999 4:14 PM
Subject: Pietenpol-List: Re: Help... do I have a major problem?
>Sorry guys, but i feel I have to put my two cents worth in
>on this, too. Richard, if you are to do destructive
>testing, do it right and controlled. I like the idea of
>placing them on mock spars. But the dancing on the 2x4, I
>don't. You want to establish if the ribs will safely carry
>the wing loads. The 2x4 does not spread the load, it
>concentrates it. You need to determine the load strength of
>the wing. I don't recall what the wing is rated for, I
>think it is +4 g's -1g. You can find it on Grant's page.
>Then establish the wing loading (lbs/sqft). Now line the
>ribs on the mock spars and cover them. You can use an old
>bed sheet and probably latex paint. This is not important,
>as you are trying to establish a minimum (threshold)
>number. After the test bed is stretched, load the panel
>with bags of sand. The amount of weight you add is a simple
>calculation. e.g. if the loading is 5 lb/sqft, stressed 4g+
>1g- and you have a 20 sqft test area you load a minimum 400
>lbs evenly across the surface. Actually you want to take it
>beyond that. (You can keep adding weight till it fails and
>then you know how well it is built). Another test you can
>do is if you get to, say 500 lbs, remove the weight and flip
>it over and try the other side. By all means, if it fails
>prematurely, examine the pieces and identify the failure.
>Now here is the kicker. If you look closely at the blue
>prints, the ribs are designed to rest on the main spars,
>the truss work on the ribs between the spars will make for a
>very strong design. I would be curious where that rib
>failed, but it may take a lot of sand. Piece of mind is
>much better than pieces of debris on the ground. Remember,
>you are going to bet your life on it.
I only use T-88! (now). My first two planes were built with
resorcinal....what a mess! I haven't used the West system. That comment was
from some others that have. T-88 is, in my opinion, the best all around
epoxy to use. It is gap filling, not runny. Each guy I knew that used
Aerolight had some problem with it meaning on large ares not getting enough
of the A & B in the right place causing delaminations. I stay with T-88 and
Stits (poly fiber) no matter what. For me, that is the best combination.
Earl Myers
Date: Monday, February 08, 1999 12:18 PM
>Ken
Ken;
I used West System to make a new canopy frame for a Stitts Flutterbug and
found that I could change the consistency by adding small amounts of
fiberglass chop until it was a thick as I needed. It does add a little
weight but fills gaps and is exceptionally strong.
John Mc
Date: Monday, February 08, 1999 10:18 AM
>Ken
From: | Wayne and Kathy <ktokarz(at)incentre.net> |
Richard DeCosta wrote:
> Got some new stuff on my website for anyone interested:
> 1. Three new mpeg videos:
> a. 'A' Ford doing two really neat fly-by's
> b. Same ship doing a neat looking slip to landing
> c. Same ship again, this time from another Piet
> 2. Piet sounds in WAV, MP3 and RealAudio formats
> a. 'A' Ford Fly by sounds
> b. Corvair take-off
> 3. About 40+ new images
> Enjoy! I sure do!
> Richard
Hi Richard,
For some reason I am not able to access your site. Something about a
url not having a dns entry. Sounds like a cool site.
=A0
=A0
Steve Eldredge
Steve(at)byu.edu
IT Services
Brigham Young University
=A0
Hey Gang!
I found that by going directly to Richard's site, http://207.140.1.221/w3
builder/Piet,
which I have bookmarked, the mpegs are listed as one of the choices. They are
large mpegs, 2 -4 megs, and take a while to load, but are really great. Check
'em out. Thanx, again, Richard.
Don Cooley
Just a note to anyone interested...
Put your Piet on the Web!
Anyone who wants a FREE Lifetime Web Site (5 MEG) can go to one of my sit=
es
at
http://www.hotyellow98.com/mmorgan
Just click on the FREE Lifetime Web Site and its yours...
Its a great deal, FREE, no gimmicks or catchs, free web design manager to=
o.
Mark Morgan : )
Bel-Air Aviation
Apparently a lot of people have had a lot of trouble getting at my
site via http://Fly.to/pietenpol. You can still access it via the old
url: http://www.wrld.com/w3builder/piet or
Also, I am now compiling a list of suppliers for Piet materials,
(spruce, wheels, instruments, etc...) Its linked off my site now, but
if anyone has more links (like Orrin Hoopmans address for instance)
please email me directly.
Richard
> > b. Corvair take-off
> > Enjoy! I sure do!
> > Richard
> Hi Richard,
Subject: | Re: Help... do I have a major problem? -Reply |
I am using epoxy glue and it is a must to presaturate the parts
before final gluing. I scuffed the ply on all gussets but got
glue on an unscuffed surface which seemed to soak up the glue
scuffed or not. After 5 min. of soaking the sheen is gone and the
ply looked like wet plywood the grain contrast is clearly visible
indicating that the glue did soak in scuffed or not.
HOWEVER THIS IS WHAT I WOULD DO, DOESN'T MEAN
IT'S THE CORRECT WAY OR THE SAFE WAY TO PERFORM
AIRCRAFT CONSTRUCTION, may be the brand plywood
clamping pressures type of glue etc. affect the ability
of the wood to absorb glue, so I would throughly test a sanded
piece of glued ply with and unsanded piece and note the results.
maybe ply thats been stored in a stack 10' high has the grain
so tightly compressed that it won't absorb glue but my ply
which is 1/16 birch soaks up glue or water sanded or not!
The okoume is like a sponge put glue on it and it's like
disapears.
Date: Saturday, February 06, 1999 5:35 PM
Subject: Pietenpol-List: Help... do I have a major problem? -Reply
I used birch ply and Aerolite glue. Tested gussets both sanded and
unsanded. NO failures in any of the glue joints. I concur with most of the
others, test a couple to destruction and get on with the rest of the plane.
Greg Cardinal
>>> Richard DeCosta 02/05 7:51 pm >>>
I just got my copy of "Aircraft Building Techniques" from the EAA and
have read 3-4 chapters. I am now on rib #25, meaning I have done 24
ribs before reading the section of the book on plywood.
I am a little concerned now, as I have not "scuffed" or sanded my
plywood before gluing to the ribs as the book suggests. I did the
water test as described in the book, whereby one pice of scap plywood
is scuffed and the other is not, then water is placed on both. As the
book predicted the water soaked readily into the scuffed piece but
kindof beaded on the un-scuffed one, meaning glue would not soak in as
well either.
Is this a major factor in the strength of my ribs? Should I scap the
25 ribs I have built? or will they be strong enough without this
scuffing?
Concerned,
Richard
Subject: | Re: Wood Prices? |
I ordered douglas fir boat lumber at $ 4.00 a board foot 12% moisture
content. figure about 30% to 40% waste after cutting out knots
planing and sawing. I received 160 bf plus 1/4, 1/8 okoume and
1/16 birch boat ply plus shipping for about $1500.00 dollars.
Iv'e found that building a Pietenpol is much cheaper
than smoking and drinking and much safer than chasing women.
Date: Monday, February 08, 1999 8:36 AM
Subject: Pietenpol-List: Wood Prices?
I guess you could call that a free Piet as I can if I ever build mine, I
quit smoking back in 1980 when I was smoking two packs a day at 50 cents
per pack, now I think they are 2 bucks a pack. But I never saved the
money as I kept buying toys, Boats , motorcycles and now building
airplanes, But I think flying an airplane is much safer than smoking or
riding motorcycles.
I still drink beer and even brew it sometimes.
Gordon
writes:
__________
Subject: | Re: Fw: Corvair or Ford? |
G'day guys
I have no experience with the Jabiru personally, but have heard good
reports about them. For those interested, check out the web site:
http://www.jabiru.net.au/engine.htm
It looks like (for the non-purists) that it would fit well with the
Piet, but with appropriate mods to the CG position. Long engine
mounts, move the wing? Couldn't get a price, though
Still no comments about the Continental?
And a HUGE thankyou to Richard for his ongoing commitment to
keeping us all informed with, through and about his website.
Should never take that kinda dedication for granted. Done wonders for
the Piet profile down here. Buy you a beer if you're ever here, mate.
Rob
Oz piets: Nearly the ones to fly inverted...
Rob wrote:
Still no comments about the Continental?>>
Rob, what comments do you want, I missed your previous
message.
Mike ( Piet N687MB )
Just Richard's comment about choices between Corvair or Ford, with a
'polite but firm "no"to the Continental option' (to paraphrase).I
wondered what was problem with an engine which at first sight might
appear suitable.
Ta
Rob
My reasons for saying no to the continental, I'm almost embarrased to
say, were purely aesthetic. I simply like the Corvair and Ford engines
better than others (I don't care for the sound or look of a
continental, for instance). And, since the Corvair and Ford are both
very safe and reliable, I am choosing between those two.
Richard
> appear suitable.
> Ta
> Rob
Subject: | Re: RE: To Stevee |
Steve:
Thanks. I'll give you a call when I get there.
Mark
> Steve E
> Subject: To Stevee
> Hi Steve:
who
> Mark Boynton
> Phoenix, AZ
Richard wrote: And, since the Corvair and Ford are
both very safe & reliable.....>>>
Don't know too much about the corvair ( there are
not too many of them flying ),but I will argue about
the reliability & safety of the Ford.
As a display & curio item they can't be beat.Where I
live the terrain is rough & mountainous. Not a field in
sight. I know what it feels like to be behind a Ford
engine over that country,& I also know what it feels
like to be behind & continental over that country. The
answer is obvious.
Mike B ( Piet N687MB )
Folks
Shoulda asked in the last email, but here it is now. This interloper
from down under will be briefly passing through LA and Tucson, AZ in
either the last week of Sept., or the first of Oct. Are any of you
guys with finished ships anywhere near either? I've never seen a
completed Piet in the flesh, and would love to.
Ta
Rob
From: | "Sayre, William G" <William.Sayre(at)PSS.Boeing.com> |
I remember a conversation around a Brodhead campfire where it was determined the
most common failure on the model-A conversion was the magneto. Ironically,
the only aircraft item installed.
I started a Contental powered Piet until attending Brodhead with the specific goal
of comparing power plants. Was surprised to see how the performance of the
model-A was at a par or superior to the others. In talking with the owners
and long time builders my fears of reliability were eased and I now have a model-A
mounted on the front. Could be that slow turning engine is so relaxed as
it works.
Bill Sayre
> From: mb-albany(at)att.net[SMTP:mb-albany(at)att.net]
> Reply To: Pietenpol Discussion
> Sent: Tuesday, February 09, 1999 7:02 AM
> Subject: engines
> answer is obvious.
Date: Tuesday, February 09, 1999 11:06 AM
Subject: Pietenpol-List: Re: Visit
>BUT IF YOU ARE EVER IN THE CLEVELAND, OHIO AREA..............YOU COULD
>BECOME AS ONE WITH A PIET!
>From: Rob Hart <robihart(at)rph.health.wa.gov.au>
>Date: Tuesday, February 09, 1999 10:39 AM
>Subject: Visit
>Folks
>Ta
>Rob
>Richard
Richard- That is the beauty about the Piet (or homebuilts in general)
is that we have lots of choices to 'customize' our planes to suit our specific
needs, desires, and wants. Nothing wrong with your reasoning. (sniffle,
sniffle...)
Naw, they all have good and bad points. I do agree with Mike Brusilow though
because I've see the terrain near where he flies. Wooded and hilly.
Earl Myers description of the A were right on too. You have to take each of
these engines for what they are, their limitations, cost, AND yes,
aesthetics
and romance their various sounds. It all counts. Pick what works for you.
On a side note, I was fortunate a few years ago to fly Ed Snyder's
Ford
powered Piet and don't get me wrong, I LOVE the sound and sight of those
babies, but flying one was different. It's like flying my Cont. at about
60% power.
Everything happens slowly. The controls feel totally different at 55 mph than
75 mph. Really different. Not bad, just sluggish. I noticed that on
this fine
85 F day that the radiator supplied a ton more heat back my way too. I bet
that's nice though for winter flying.
Some can't tolerate auto fuel oders...and I couldn't help notice that the
exhaust stacks
were right in line with my nose. The view with the radiator was not the
problem
I thought it might be. Actually I've had passengers that blocked more of my
view than that radiator did. And with all Piets, they don't glide like
Champs or
Cessna's. You've got to keep the speed up (point the nose down steeper than
you are used to or carry power) down to flaring height or they ker-plunk
pretty
good. Nevertheless, the Ford powered planes are still awesome to watch and
to ride in. A trip back in time.
Mike C.
Subject: | one last thing..... |
My commets on the Ford powered Piets were generalized observations.
Most of them produce 35 to 40 horsepower, But YES, there are some
hummers out there souped up to produce much more than that, and those
Ford Piets can get out and go. (but they are in the minority)
Mike C.
Well, I'm not building a Piet, but I'll be happy to comment on the Cont.
I'm rebuilding a C-85-12F (-12 = electrics, F = flanged crankshaft). The
first thing to note is that these engines, the A-65, A-75, A-80, C-75,
C-85, C-90 and 0-200 constitute the cheapest of the production aircraft
engine to buy and service. The A- series is particularly inexpensive
having no electrics, low compression and 4 gph fuel burn. However, some
parts are getting harder to find. In particular, cylinders and
crankshafts. The C- series is a little easier to maintain (except the
C-75) as the cylinders and crankshaft are the same as the 0-200 and can be
bought new from Continental. Well, actually, the crank does have 1/8" more
throw, so you also hace to swap to the 0-200 con rods and pistons.
The three most common models of the 4 cyl Conts are the A-65, C-85 and
0-200. It's not uncommon to find a running A-65 in the $3000 - $4000.
Overhauled models can be had for about $6000. C-85's cgenerally go for
$4000-$6000 used and $6000 to $8000 overhauled depending on whether they
have electrics or not. The 0-200's run for about $4500-$6500 used and from
$7000 to $10,000 OH'd. Here's a list of costs for my C-85:
Used crank, prop, carb, baffles
Rear Accessory case + oil pump $180
Still need
Oh yeah, the -$100 is correct. I happened across an A-75 with the crank I
needed for $1100 and sold all the parts I couldn't use for $1200. I got to
keep the prop, carb, baffles, exhaust, air box, sump and the O/H kit the
purchased. It was the best deal I made on the entire project!
Overall, I'll make out better than if I had purchased an overhauled engine
and I'll know exactly what I have when I'm all done. The beauty of a
project like a Christavia or a Piet is that you have a few years to shop
for the best deals. I'm sure that if you check around your local area
you'll find someone with an old A-65 or C-85 sitting in the back corner
that's just itching to get rid of it.
One other possibility that has never been mentioned is the Cont C-125. The
low compression version of the popular C-145 and 0-300 would make an
interesting choice for the Piet. It certainly isn't heavier than the Ford
and has a bit more get up and go. The 6 cylinder makes for a low vibration
engine and the fuel burn isn't that bad. The up side is that there are
still a few of these engines kicking around and usually at a good price.
Just food for thought.
Ken
May be of some intrest ?
MODEL A engines, cleaning out garage, 7 engines have numbers, not
rusty, $100 to $250. PH: 304-776-6569, Wheeling, WV.
Greg!
As far as I know there is no difference between the "industrial" &
"automotive" -- as a matter of fact, my engine had spent the last years in
a Model A! (with both dist. & mag) Being a later block, it has more
reinforcement around the flywheel bearing & and some blocks also have
exhaust valve seats. The ID is a diamond casting mark between valve &
timing gear cover (front end of engine in a car & back end of the engine in
a Piet! ;-) -- it's only about 1/2" long. All this good info came from
Terry Oberer (St Louis Model A Club) at the '98 Brodhead -- he was kind
enough to take on a guided tour of every "A" block on the field, showing me
what to look for.
Pretty Prairie, KS is about 40 miles WNW of Wichita.
Mike C.
PP, KS
> From: Greg Yotz <gyachts(at)kans.com>
> Date: Monday, February 08, 1999 10:45 AM
> Michael,
us. I
Prairie at?
To
> bad....
> Greg Yotz
> > Mike Conkling
> > Pretty Prairie, KS
engine!
won't
I think the answer is just too obvious
The Ford is to a Piet what icecream is to apple pie
I have to look thru my 10 yr old Model "A" Ford catalogs but I think
there are alot of good parts for rebuilding them now to make them even
better than before. Sure wish I had kept my 31 Sedan I sold in 91 or my
coupe I sold in 1959 Got 75 bucks for it.
Gordon
>answer is obvious.
__________
Subject: | Re: one last thing..... |
Airworthy Standards Chapt. 549 (Canadian) has the formulas or charts to
calculate P2, The minimum rated engine power in Brake horsepower for fixed
wing aircraft with a take off mass of 0 to 2000 lbs. I ran the numbers for a
Piet at 1080lbs. gross. It worked out to 33 hp.
Sooo. ....anyone who would think of taking an engine that is at least 69
years old and expect it to put out 82.5% of it's original power out put with
out doing a very thorough and complete overhaul is dreaming, if he expects
his aircraft to fly well. I have ridden in both an older A powered Piet and
an A-65 powered GN-1. They seemed very similar to me but the old Ford was
tired and I'm sure it wasn't putting out all that it could. The point is
that the Ford with proper overhaul and attention to detail can be made to
put out a lot more than the bare minimum and for less money than it takes to
overhaul a timed out Continental. The biggest gains in power will be
realized in the breathing and that means cam timing. Not just that the
gears are lined up but that the lift and duration are with in specs. . It
would not be wise to assume that because the engine idles and runs well that
it is breathing properly. Have somebody dial indicate and degree check your
cam or buy a new regrind to spec. Anyone using the Ford will also be well
advised to pay close attention to cooling oil and ignition systems.
Fords can be safe reliable engines.
Model A engine specs: 200.5 cu.in., 40 brake hp @ 2200 rpm , Bore 3.875",
Stroke 4.250", Compression Ratio 4.22:1, Cylinder offset 0.125"
Mains 1.625" Timing end and center brgs 2" long rear mmain 3". Rod journals
1.500" dia 1.625" wide. Bearing clearance 0.001"
Cam Lift 0.302" Clearance 0.015" Base circle 0.954", Intake opens 7 1/2
BTDC, Closes 48 1/2 ABDC Exhaust opens 51 1/2 BBDC, closes 4 1/2 ATDC.
John Mc
PS The Fords sound better, and better yet if they have a collector type
exhuast header made up, more power too!
From: Michael D Cuy <Michael.D.Cuy(at)lerc.nasa.gov>
Date: Tuesday, February 09, 1999 9:23 AM
Subject: Pietenpol-List: one last thing.....
>Mike C.
where are you in finishing your piet?
Gordon
writes:
>Folks
>Ta
>Rob
__________
Hey, fellers, it is a really interesting discussion, but I can't assimilate
it all right now...maybe when I start collecting pieces.
Can anybody tell me how to unsubscribe from the list??
Jim
I got it,
So long for now Jim,
Steve e
Weir
Sent: Tuesday, February 09, 1999 9:19 PM
Subject: Pietenpol-List: Unsubscribe
Jim
Subject: | Re: FORD "A" ENGINES |
Anyone know of anyplace (still in someone's head maybe?) where I can
get or build a checklist of things to look for in a Ford engine?
(photos/images of "good" engines and "bad" engines would be cool, too=
I am going to my father-in-law's friend's house tomorrow afternoon,
who has a couple of them, and I want to make sure I know what to look
for, and what to watch out for.
I scraped just about every inch of Grant's site, and couldnt find muc=
h
there in the way of an "Idiot's Guide to Ford Engines". :)
I indend to put the checklist (and any corresponding images) on my
Website for others to use as well.
Richard
p.s. if anyone is wondering why I am so obsessed with putting so much
information on my site, it's because when I started gathering
information for the Piet, I couldnt find SQUAT and nearly gave up
looking and quit the whole thing. I want to gather as much informatio=
n
in one place as possible so that new builders and potential builders
won't get discouraged to find no help or information out there.
Besides, I'm just a little obsessed with airplanes to begin with...
---Earl Myers wrote:
> RICHARD;
> READ WELL THE E-MAIL TO THE GROUP FROM JOHN MCNARY REF THE FORD
"A" ENGINE. HE IS 100% CORRECT AS I KNOW OF SEVERAL STRONG FORD PIETS
THAT PAID ATTENTION TO THE CAM ISSUE. FORD " A" FACTORY CAMS WERE
NOTORIOUS FOR BEING PRODUCED IN A WIDE RANGE OR TOLERANCE CAUSING A
WIDE RANGE OF PERFORMANCE..........JOHN HAD SENT ME A LONG STORY
SOMETIME AGO ON ANOTHER ENGINE TYPE. THIS MAN REALLY SEEMS TO KNOW
WHAT HE IS TALKING ABOUT !!!!!
> ONE OF MY NEXT PROJECTS IS TO HAVE AN "A" OR "B" DONE UP RIGHT. B=
Y
THIS I MEAN A HEALTY CAM, BIGGER CARB, PORTED HEAD, BIGGER VALVES,
PRESSURE OIL SYSTEM, SHELL INSERT BEARINGS AND SO FORTH. YOU ARE
LOOKING AT AROUND 70 RELIABLE HP WITH THIS SET-UP. THIS WILL GO IN MY
SCOUT FIRST THEN WHEN TESTED OUT, INTO A (FUTURE) '33 AIRCAMPER EITHE=
R
BUILT OR BOUGHT AND REBUILT.............THE RACING VERSIONS CAN GET
110-130HP BUT I DON'T WANT THAT MUCH HP OR RPM. A SLOW TURNING=
PROP ON THE FRONT OF THAT BUILT UP ENGINE.............THAT SOUND IS
HARD TO FORGET !
> EARL MYERS
ype>
RICHARD;
=A0 READ WELL THE E-MAIL TO THE G=
ROUP
=46ROM
JOHN MCNARY REF THE FORD "A" ENGINE. HE IS 100% CORRECT AS I KNOW OF=
SEVERAL STRONG FORD PIETS THAT PAID ATTENTION TO THE CAM ISSUE. FORD
A" FACTORY CAMS WERE NOTORIOUS FOR BEING PRODUCED IN A WIDE RANGE OR=
TOLERANCE CAUSING A WIDE RANGE OF PERFORMANCE..........JOHN HAD SENT
ME A LONG
STORY SOMETIME AGO ON ANOTHER ENGINE TYPE. THIS MAN REALLY SEEMS TO
KNOW WHAT HE
=A0
=A0 ONE OF MY NEXT PROJECTS IS TO=
HAVE AN
"A" OR "B" DONE UP RIGHT. BY THIS I MEAN A HEALTY CAM,
BIGGER CARB, PORTED HEAD, BIGGER VALVES, PRESSURE OIL SYSTEM, SHELL
INSERT
BEARINGS AND SO FORTH. YOU ARE LOOKING AT AROUND 70 RELIABLE HP WITH
THIS
SET-UP. THIS WILL GO IN MY SCOUT FIRST THEN WHEN TESTED OUT, INTO A
(FUTURE) '33
AIRCAMPER EITHER BUILT OR BOUGHT AND REBUILT.............THE RACING
VERSIONS CAN
GET 110-130HP BUT I DON'T WANT THAT MUCH HP OR RPM.=A0=A0=A0 A SLOW=
TURNING=A0 PROP ON THE FRONT OF THAT BUILT UP ENGINE.............THAT
SOUND
IS HARD TO FORGET !
EARL MYERS=A0=
http://db.mp3.com/Visitor/order.php3?cd_id968
Stay obsessed Richard. The information is great, useful & inspirational.
Besides, I have no requirement that my sources be completely sane...{;
Warren
This reminds me of the story of the king that decided to have a foot race
for his whole kingdom. He laid out the course and the people gathered for
the race. Many made a quick start and finished long before others, but the
last one to complete the race finished long after all the others. This last
was ushered before the king and asked why it took him so long to pass. The
traveler told the king that he might have finished much sooner but he came
upon a large pile of debris in the middle of the road and stopped to clear
the path. Many passed by as he did this work. At the under it all was a
great sack of gold pieces. He had brought it along to give to the king that
it might be returned to the owner. At this the king said it belonged to
him. He had placed the obstacle, and the treasure, there. He who travels
the journey best makes the path easier for those who follow.
Thank you, Richard. May well all follow your example in all we do.
Brent Reed
Kent, Wa
Richard
looking and quit the whole thing. I want to gather as much information
> RICHARD;
> ONE OF MY NEXT PROJECTS IS TO HAVE AN "A" OR "B" DONE UP RIGHT. BY
SCOUT FIRST THEN WHEN TESTED OUT, INTO A (FUTURE) '33 AIRCAMPER EITHER
HARD TO FORGET !
> EARL MYERS
RICHARD;
FROM
SEVERAL STRONG FORD PIETS THAT PAID ATTENTION TO THE CAM ISSUE. FORD "
ME A LONG
KNOW WHAT HE
INSERT
THIS
(FUTURE) '33
VERSIONS CAN
GET 110-130HP BUT I DON'T WANT THAT MUCH HP OR RPM. A SLOW
TURNING PROP ON THE FRONT OF THAT BUILT UP ENGINE.............THAT
SOUND
IS HARD TO FORGET !
EARL MYERS
Subject: | As long as we're voting.... |
>Warren
Richard- - I SECOND this vote by Warren S. and if it comforts you any
I'm a bit obsessed myself !!
MIke C.
Hi all the advertisement that I posted yesterday is from a magazine called
Hemmings Motor News, that I picked up from the local book store. it has a
lot of ads for model A parts and machine shops. and they have A web site
www.hemmings.com
check it out.
Was checking the NTSB web site on another incident
and ran into this accident involving a PIET.
Thank goodness the durability of the craft saved its
occupant.
NTSB Identification: FTW99LA042
Accident occurred DEC-02-98 at ENGLAND, AR
Aircraft: HOLIMAN PIETENPOL AIRCAMPER, registration: N396S
Injuries: 1 Serious.
This is preliminary information, subject to change, and may contain errors.
Any errors in this report will be corrected when the final report has been
completed.
On December 2, 1998, at approximately 1425 central standard time, a Holiman
Pietenpol Aircamper homebuilt airplane, N396S, was substantially damage
upon collision with a power line while maneuvering near England, Arkansas.
The commercial pilot, sole occupant of the airplane, was seriously injured.
The experimental airplane was owned and operated by the pilot/builder under
Title 14 CFR Part 91. Visual meteorological conditions prevailed throughout
the area for the local personal flight. The flight originated from the
Saline County Airport, in Benton, Arkansas, approximately 30 prior to the
accident. According to witnesses near the accident site, the high wing
tailwheel equipped airplane was observed maneuvering at low altitude in the
vicinity of the accident. A nearby resident reported to law enforcement
officers hearing the sound of the airplane engine flying near his
residence. The resident reported that the sound of the engine stopped about
the same time that his home lost electrical power. The resident went
outside and observed that the single powerline servicing his home was down
on the ground and the remains of the wood and fabric airplane came to rest
came to rest about 200 feet beyond the point where the wire was severed.
The 74 year old commercial pilot was occupying the front seat of the 2-seat
tandem airplane. Examination of the wreckage of the airplane by the FAA
inspector that traveled to the accident site revealed that the fuselage and
both wings sustained structural damage. The inspector further noted
continuity to all flight controls. Likewise, continuity was established to
all engine controls. Fuel was found at the site and there was no fire.
Index for Dec 1998 | Index of Months
From: | Michael Brusilow <mb-albany(at)worldnet.att.net> |
Re Piet accident:
the 2-seat tandem airplane>>>>>
What?
Mike B ( Piet 687MB )
Subject: | Re: Piet accident |
>Re Piet accident:
> What?
Maybe because it was powered by a VW engine? :-) :-) :-) :-)
Sorry, just a thougt about my impossible dream.... VW powered piet :-(
Saludos
Gary Gower
Subject: | RE: Piet accident |
Front seat? Both wings? Wow!
bed
Hear, Hear! Thanks again Richard! It is a great insiration to look at all
the finished Piets and the photo's of the bits and pieces are worth
thousands of words.
When you are looking at the engines take the time to remove the pan and head
if possible. The areas to watch for are cracks inbetween the valve seats and
cooling ports and cracks on the outside of the water jacket. I wouldn't
worry too much about the condition of the pistons or valves as you will be
replacing those. The rods should be free of file or chisel marks on the
I -beam section. (Many mechanics seem to feel that they have to make great
big ID marks.) These marks become stress risers, not a good thing! Really
all you want is a crack free block a good crank and a set of reuseable rods.
You should replace just about everything else. The beauty of the Ford engine
is that they are still very popular in the antique car world and there are
many part suppliers. The hardest thing is to find someone that is capable of
doing a first rate job of the babbit work. The antique car guys in your area
will probably know who.
John Mc
Date: Wednesday, February 10, 1999 8:37 AM
Subject: Pietenpol-List: Re: FORD "A" ENGINES
>Warren
Helluva long way to go. Haven't started cutting yet!
Rob
Unsubscribe. PC sick - going in for surgery
From: | Malcolm Morrison <morrisons5(at)prodigy.net> |
Please sign me up. New email account!
Thanks Malcolm
account!
Malcolm
Subject: | Yesterday's Wings |
I have A couple of questions about Yesterday's Wings Aero Museum. Are
they still open; I tried to call them and got a message that the phone
had been disconected? Also does anyone have an opinon about thier three
piece wing plan with 1/8" gap, and the no-gap aileron plans.
Thanks, Randy.
Subject: | Re: Yesterday's Wings |
Randy,
Don't know about the phone deal. However, I have bought several of
their plans and would tell you that these are extraordinarily professional,
detailed and well thought out plans, which include color photos of the
various steps. Personally think they are well worth the money.
Best Regards,
Warren
Randy: Did you call directory assistance and get a # for Gary Price? He
runs Yesterdays Wings. Let me know what you find out.
Warren Shoun wrote:
> Randy,
> Best Regards,
> Warren
Yesterday's Wings has a web site, as part of the Hampton Airfield site:
www.hampton-airfield.com. Although I couldnt access the site today, I
think it is generally still functional and available.
Richard
three
> Thanks, Randy.
Randy, et al,
Here's the skinny on Yesterday's Wings...
Yesterday's Wings Aeroplane Works, Inc
Historic Hampton Airfield, Lafayette Road, Route 1
North Hampton, NH03862-9998
Office Phone: 603-436-7360
Airfield Office: 603-964-6749
Drawings are excellent quality, people are pleasant to talk with. Enjoy!
Don Cooley
This is for Mike C, and others with exp here,
=A0
Mike,=A0 Nice smoke job picture on the BPA page!=A0 I have got my pie=
t down for
upgrades and improvements and would like to add that feature.=A0 Can
you share
what you did to get the white stuff?
=A0
=A0
=A0
Steve Eldredge
Steve(at)byu.edu
IT Services
=A0
Subject: | Re: Smoke System |
> Mike, Nice smoke job picture on the BPA page! I have got my piet down for
> upgrades and improvements and would like to add that feature. Can you share
Heh, heh, heh. Boy that smoke system is alot of fun.
Here is what I did: On one of the rear cylinder exhaust pipes
you weld a fitting about 3" down from the flange. (I used a
Swagelok 1/4" female fitting) Drill two small (Number 40 or
so) holes into the exhaust pipe inside that fitting you just
welded on. Run 1/4" copper or stainless tubing out from that
fitting about 8" long then connect to rubber hose (to reduce
vibration and prevent cracking your metal tubing or fiting)
The run the hose into some 1/4" poly tubing- the black or
translucent kind we use to run airspeed lines, etc. I think even
the hardware stores carry something just like it.
Run that poly tubing back to your rear cockpit however you like,
and then go to Wal-Mart. In the garden dept. buy a 1/2 gallon
bug sprayer/ pressure pump by hand type of deal for about
10 to $15. Unscrew the 'wand' or cut it, leaving some of the
vinyl tubing intact. Use your choice of how to connect the
bug sprayer outlet to your hose in the cockpit going to the
smoke injection port on your exhaust stack.
Call around to local oil distributors and ask if they carry
Texaco Canoupus Oil No. 14 I think it is. It used to be
called Corvus Oil. Don't quote me on the No. 14, but I can
look at my 5 gallon container at home to confirm that or not.
Ask what's the minimum they'll sell you....usually 5 gallons.
IT's not cheap. It's what the airshow boys use. I paid 30$
for 5 gallons. (but got quite alot of smoke time with that)
Anywho, fill your bug sprayer about 3/4 full, tighten the
lid and pump up the pressure. Start your engine and let it
warm up. Run the engine up a little and press the bug
sprayer's button to fill your line and start injecting oil into
the hot exhaust stack. Whala, insant IFR.
Be careful testing this out- Make sure your fitting isn't
leaking or weld poor. The idea is to keep the oil inside
so you don't create a fire hazard. If your holes are too
big you will go thru too much oil too quickly and most of
it will just make your gear and belly oily.
In selecting a pump, see if you can try it out at the store
first- It shouldn't take 100 pumps to get the pressure up-
you want one that builds up pressure in fairly short order.
I've tinkered with the idea of using a windshield washer
pump and a motorcycle battery to pump the oil but
just wanted to keep it simple.
The bug sprayers don't last super long either with that
oil. If you purge the lines out with air when you are done
(ie: turn the sprayer upside down and just pump air thru
the line) they last longer.
Lastly, before you go doing this, make you are not in
the non-smoking section on you sectional !
Mike C.
This is for Mike C,
page! I have got my piet down for upgrades and improvements and
would like to add that feature. Can you share what you did to get
the white stuff?
pipes
you weld a fitting about 3 down from the flange. (I used
a
Swagelok 1/4 female fitting) Drill two
small (Number 40 or
welded on. Run 1/4 copper or stainless tubing out from
that
fitting about 8 long then connect to rubber hose (to reduce
The run the hose into some 1/4 poly tubing- the black or
even
the
can
30$
that)
it
inside
too
that
Mike C.
One last thing- they tell me that the Courvus
oil is primarily a vegetable oil used in the food
processing industry and dentist drills. I am told
that this oil produces the BEST smoke you can
make, but have toyed with injecting some Wesson
oil or the like.
Mike C.
Subject: | plywood questions |
I have ordered my fuse materials and have a few quick plywood
questions for anyone with time to anwser.
1. Do the large plywood sides of the fuselage need to be all one
piece, or can 2 sheets be used?
2. Is 3-ply or 5-ply plywood better?
3. Can the same type of plywood be used for the seat parts as used in
the gussets?
Richard
Subject: | Re: plywood questions |
Richard
re: your plywood questions. #1 yes you can use two sheets. I did mine this
way be doing a 12 to 1 splice and positioning the splice on a vertical member.
I used a belt sander to do the initial bevel and finished it off by shaving
with cut glass. It's easy to keeep it straight...the straighness of the plies
will show you the way. #2 The ply I used was 1/8 inch-seven ply. I think it
was from a/c Spruce. #3 Sure you can use the same material for seats as you
do for gussets but certainly not the same thickness!
Don Hicks
DonanClara(at)aol.com
I bought 1 sheet of kumme (spelling?)mahogany(marine grade)and it easily
did both sides,as it was over 4x8 in deminsion.I think it was 3 ply.
Doug
> Subject: plywood questions
> Date: Friday, February 12, 1999 5:10 PM
> the gussets?
> Thanks,
> Richard
From: | Dave and Connie <dmatt(at)frontiernet.net> |
Randy,
Below is part of a note I sent a while back when I was researching
wood prices.
I will be placing my order shortly for all of the spruce in one shot.
Corporate bonus amount was announced, check should be here next
week. Yipeeeee!!!!!
When I get a final price including shipping I will post it.
Dave
>Jean Peters at Western Aircraft Supplies
>Calgary, Alberta Canada
>(403)250-1955
I talked to Jean Peters today. In $US his prices are $686 for a
fuselage and tail kit and $862 for a wing kit. This is for spruce
only. Plywood and everything else are not included. Add a $30
crating charge and shipping. He uses Delta and ships by air because
it is cheaper than trucking. I was given a 4 day lead time. Credit
cards are not accepted (good thing for me). He wants to see a
postal money order or some sort of guaranteed check. Seemed like
a good person to me. He did offer to do a rib kit or a tail kit
but the quotes were off the top of his head so I am not listing them.
Mike,
I have heard that the "Dawn Patrol" guys with their Nieuports use
automotive windshield washer reservoirs and pumps to squirt the oil into
the exhaust stacks. Like the idea of hand pumping/ no electrical
better, though.
Mike List
Subject: | Route to Brodhead |
I know snow is still on the ground, but I am getting excited to make the
trip from Florida this summer. I was looking at charts last night. Could
hardly fall asleep.
I am looking for suggestions for good places to stop along the way for fuel
and pitching my tent. I would prefer grass and auto fuel but am not real
picky and will take whatever works out as reasonable. Don't have a
transponder so that is the only limitation.
Went up for a spin this afternoon because there wasn't a cloud in the sky
and I couldn't think of any reason not to.
Thanks, Ted
GN-1
Naples, FL/APF
Subject: | Piet wood Bill of Material |
Has anyone ever seen or done a real material listing, bill of material
or whatever you want to call it of an Aircamper? Mr. Cuy?
earl myers
material
listing, bill of material or whatever you want to call it of an
Aircamper? Mr.
Cuy?
earl
myers
Subject: | Re: Route to Brodhead |
Ata boy!
(jelous in Alberta.Only 40 deg F today,plus a foot or so of snow)Played
Ham Radio all day with old friends,a good day it was!!!!!!!
73 Doug Hunt VE6ZH
> From: Ted Brousseau <nfn00979(at)naples.net>
> Subject: Route to Brodhead
> Date: Saturday, February 13, 1999 7:28 PM
Could
> hardly fall asleep.
fuel
> Thanks, Ted
> GN-1
> Naples, FL/APF
Warren Shoun wrote:
> Randy,
> Best Regards,
> Warren
Thanks for the info. Do you have the mailing address? Thanks and may
you be blessed with a tailwind.
Randy,
Thanks. Have Tailwind plans but will finish the Piet first...{8
Have two addresses:
1. G. S. Price
2. Yesterday's Wings Aero Museum, Inc.
The only phone number that I have is (603) 436-7360. Good Luck!
Best Regards,
Warren
Subject: | splicing steel tubing |
I am just a little bit curious about how to,...or if it is permisable to
take my scraps of steel tubing and splice two pieces together, so to
make one, then weld it into my fuselage as a structural part.
The material I'm using is 3/4x 035, and I'm thinking that I could cut a
piece of tube maybe 6" long in half lengthwise then weld the halfs to
the main tubes for a structural splice.
Slip a piece of smaller tube inside the tubes to be spliced, then weld
it in.
Does anybody have any suggestions ?
From: | "David B. Schober" <dbs(at)fscvax.wvnet.edu> |
Subject: | Re: splicing steel tubing |
AC 43.13-1b has all the specs for "accepted" methods of splicing structural
tubing. If you use that as a guide, you won't go wrong. If you don't have AC
43.13-1b, it's available on the FAA web site http://www.faa.gov
> it in.
David B.Schober, CPE
Instructor, Aviation Maintenance
Fairmont State College
National Aerospace Education Center
Rt. 3 Box 13
Bridgeport, WV 26330-9503
(304) 842-8300
Mr Schober is right! This is the only legal way to do it and it does work.
AC43.13 is the "bible" for repairs and FAA approved methods...........
Date: Tuesday, February 16, 1999 7:47 AM
Subject: Pietenpol-List: Re: splicing steel tubing
AC
>> it in.
>Rt. 3 Box 13
>(304) 842-8300
Take a quick look at where the splices will be. Each time you do that,
you are adding weight. The "Acceptable Methods" has considerable overlap
of the pieces. Near the tail could affect your CG. If you are just
planning on doing one or two joints, I would spring for the new tubing.
It is still fairly cheap. Just my thoughts on it.
Ted- The guy you want to talk with is Bill Rewey, 3339 Moundview Road,
Verona, WI 53593 He's not on e-mail though.
Bill has taken his Piet to Sun-N-Fun several times and probably knows the
route like the back of his hand. He's a great guy- parked near him this past
Oshkosh. If you write him he'll call you back w/ his phone no.
He will be at Sun-N-Fun this year (via his C-172) and doing a PIETENPOL
forum. He's also doing a Piet forum at Oshkosh this summer.
Mike C.
Subject: | RE: Route to Brodhead |
For my trip planning to Broadhead I have been using www.airnav.com.
Impressive site. All you do is specify range, type of fuel, type of runway,
etc and it gives you a list of airports along your route. Really cool.
Steve E.
Michael D Cuy
Sent: Tuesday, February 16, 1999 7:05 AM
Subject: Pietenpol-List: Re: Route to Brodhead
past
Mike C.
>Warren Shoun wrote:
>> Randy,
>> Best Regards,
>> Warren
That will be great, the Tailwind is a great cross country airplane, perfect
complement for the wonderfull Pietenpol :-)
Saludos
Gary Gower
Sat in my fuselage tonight for the first time.
OCB
>OCB
Bob- Congratulations ! Feels good, eh ?
(now tonight after work do the same thing, but
don't forget to do a mag check before takeoff:))
Mike C.
Subject: | first run on Lyc. 0-290 |
WOW I mean WOW I know it was going to have more power but WOW the
tail wanted to fly at 1300 rpms it runs great but now I have to do the
W&B, I moved the engine aft 4" and the wing forward 5" ( the wing was
back 4" for the cont 65) and with bathroom scales its lookin good.
But does anyone have any good scales they'd want to share? I've
thought of buying the scales from aircraft spruce (275.00 for
taildragger) but would anyone want to go on shares and pass them around?
thanks much
Robert B.
> >OCB
> Mike C.
Subject: | Re: Engine Noises |
Get yourself a box fan so you get the feel of air rushing past you. Not bad
is it? Congradulations on your accomplishment.jas
>>OCB
>Mike C.
Subject: | Re: first run on Lyc. 0-290 |
Check out your local farm and ranch store. They may lend you a scale. One
scale is all you need. Did mine that way. jas
>thanks much
>Robert B.
>> >OCB
>> Mike C.
Subject: | Grain Orientation |
Need some advice before I cut up my beautiful douglas fir for the tail
feathers. When looking at the end of the horizontal tail beams, which
way should the grain be oriented? Seems like for best bending strength
the grain should be vertical, like the rib capstrips, which would be
good for the hinge bolts to run through. But for the tail brace wire
lug bolts it would be better with the grain horizontal. My plans aren't
real clear on this, nor are any of the other wood aircraft design books
I have. Help, have to cut up this fir before the wife makes plans for
it!
Mike List
Subject: | Re: Grain Orientation |
To all:
Which way will the wood be strongest? I thought the orientation of the rib
capstrips was supposed to be horizontal, or perpendicular to the forces
acting on them in the air (parallel to the ground as the plane is standing
on it). Have I got it wrong?
Mark Boynton
Phoenix, AZ
> it!
> Mike List
From: | Greg Cardinal <gcardinal(at)startribune.com> |
It doesn't matter in this situation since you have holes
drilled both vertically and horizontally. Just follow
Tony Bingellis' recommendations regarding use of
washers and plywood under nuts and bolt heads to
spread out the clamping forces.
Greg Cardinal
>>> michael list 02/19 3:12 AM >>>
it!
Mike List
Subject: | RE: Grain Orientation |
Normally capstrips have their grain oriented vertically so the gusset nails,
or staples in my case, do not tend to split the capstrip. Of course if
you're using a glue-up jig without nails, it doesn't really matter.
Randy S.
Sent: Friday, February 19, 1999 8:50 AM
Subject: Pietenpol-List: Re: Grain Orientation
To all:
Mark Boynton
Phoenix, AZ
> it!
> Mike List
I know I may sound like a heretic, but I've got an opportunity to buy a
flying Horizon 2 (Fisher Aero design).
I'ts got an 80HP Limbach with 65 hrs on it.
Does anybody know anything (good or bad) about this design or engine?
I probably won't stop building the Piet. But at the rate I'm going, I
may be to old to fly it by the time I'm done;-)
Dean Dayton - deandayton(at)hotmail.com
The Limbach is a VW conversion from Germany and is purportedly very
good. As for the fisher horizon , I've only heard good things. However
as with any airplane make sure and do a thorough inspection and history
check.
Wayne
I'm not really up on the VW engine, but I have done some reading.
They say one thing to watch out for is duel ignitions that have the 2nd
set of spark plugs wired through the valve covers. As this has been
known to cause engine fires.
Also look at the heads for single or duel port intakes. The single port
doesn't breath as well as the duel intake type.
>From steve(at)byu.edu Fri Feb 19 20:22:58 1999
>Received: from adena.byu.edu ("port 3338"@adena.byu.edu
[128.187.22.180])
> with ESMTP id <01J7XXK9FVUS8WYXIW(at)EMAIL1.BYU.EDU> for
>Date: Fri, 19 Feb 1999 20:20:06 -0800 (PST)
>From: Dean Dayton <deandayton(at)hotmail.com>
>Subject: substitute?
>Message-id:
>MIME-version: 1.0
>X-Listname:
The bathroom scales are probably quite accurate!
I keep our chapter's scales here at my place for the chapter. They are beam
type grain scales and have been calibrated. I also made up a set of bathroom
scales because I needed them when the chapter scales were out of order. They
are $6.00 scales from Kmart.
We recently weighed a Kitfox using both systems. The difference was 4 pounds!
Thats less than 1% error and not worth worrying about in a w&b calculation.
I can't guarantee all scales are that accurate but there is a good reality
check - weigh yourself on each one and make sure you get the same numbers.
By far the most important part of a w&b on a taildragger is to have the tail
elevated the correct amount. A couple of inches will really change moment arms
on a high wing airplane.
Bob Seibert
The proper way to do what you are attempting is the cut the larger piece at an
angle of 30-45 degrees and insert the smaller piece inside. The 2 outer pieces
will need to have a space pf approx 1/8 inch so all 3 pieces an be welded to
gether.
Then for additional strength you can ( not req'd) go apprx 2 inches from the
weld and drill a 1/8 - 3/16 inch hole in the outer tube and weld the inner
piece of steel to the outer piece of tubing
Subject: | Lyc. 0-290 Atten Seibert |
Bob thank you on invfo on scales, i've been quite worried on them. i
bought news one for the W&B, so far the #'s tells me I may need some
wieght in the tail, we'll see...might move wing around and see what
comes up, I'll keep you guys posted
Robert B.
are beam
bathroom
order. They
4 pounds!
calculation.
reality
numbers.
the tail
moment arms
> Regards,
> Bob Seibert
Look for would prices on the internet I got 160 bf of boat lumber
Doug fir and enough plywood to build two Piet's for 1500.00
this includes shipping, i'm well pleased!
Russell
Date: Saturday, February 13, 1999 3:31 PM
Subject: Pietenpol-List: Re: Wood Prices?
>Randy,
>wood prices.
>week. Yipeeeee!!!!!
>Dave
>>(403)250-1955
Can anyone advise as to a fair price for a 1965 Corvair engine. I have
located one that has not run for at least two years and is still in the
car. What should I look for in a Corvair engine.
Thanks in advance and may you be blessed with a tailwind.
Sounds good. Where did you find it?
Thanks, Larry
> Russell
> From: Dave and Connie <dmatt(at)frontiernet.net>
> Subject: Re: Wood Prices?
> >Randy,
> >wood prices.
> >week. Yipeeeee!!!!!
> >Dave
> >>(403)250-1955
x-mac-creator="4D4F5353"
Dean,
Two friends just got a Horizon signed off by the FAA a couple of weeks
ago. Nice plane. I had it about a foot off the ground so far. They put a
regular VW on it. I give you their phone numbers if you are interested
in calling them. They are not on line.
Craig
I paid $50 each for two Corvair engines a few years ago. I think up to about
$200 is about average.
William Koucky
Traverse City, MI
Subject: | Titebond adhesives |
To all:
Just a little information to pass along.
I've been considering using Titebond II adhesive instead of a two-part epoxy
(considerations of ease of use and cost). I spoke with a technical rep.
from Franklin, the manufacturer. I told him I would be making gusseted butt
joints with douglas fir and asked if Franklin had done any tests to
establish the useful life of the glue joint. He stated that they haven't
conducted specific tests to answer that question but that Titebond has been
in use for over forty-five years with no reported failures. I asked about
temperature extremes (I live in the Phoenix area) and he stated that at
above 150 degrees F., bond strength drops by fifty percent - down to 18,000
psi. He also stated that there is no difference in strength between
Titebond and Titebond two - just that Titebond II is water resistant and
Titebond is not. Just FYI.
Mark Boynton
Phoenix, AZ
Subject: | Fwd: Corvair Cooling |
To Domenic Bellisimo:
Hi Domenic:
You may have missed my original message (see below). Anyway, could you
comment. Thanks.
Mark Boynton
Phownix, AZ
> Subject: Corvair Cooling
> Date: Fri, 22 Jan 1999 14:41:05 -0800 (PST)
> Message-ID:
> To Domenic Bellissimo
> Domenic:
> I was reviewing the pictures of your Piet on
> Richard DeCosta's website and noticed that you're using forced air
cooling
> for your corvair engine. How has that worked out for you and have you
taken
> any temperature readings? Beautiful work, by the way. Also, do you have
> any kind of estimate as to how much horsepower you are developing - that
is
> a 110 engine isn't it?
> Mark Boynton
> Phoenix, AZ
Would someone please sign me up again for this discussion group. I seem to
have been disconnected. I learn a lot. Thanks.
Arden Adamson
adamson(at)execpc.com
steve(at)byu.edu
Sent: Friday, January 22, 1999 9:25 AM
Subject: RE: Ribs
Good advice so far on the root rib anti-buckling problem. Here is a
little more. I put the diagnals and the 2" 1/16" ply fabric strip on the
cap strip for a fabric anchor and it worked fine, except that over time the
rib attach point to the spars has let go a little and I would suggest
increasing the surface area at this poing by gluing a piece of wood to the
top and bottom of each spar as a rib stop so that the rib cannot work loose
and slide outward on the spar from the root. -another problem solved if you
can build the 1 piece wing.
Steve E.
Michael D Cuy
Sent: Friday, January 22, 1999 7:04 AM
Subject: Re: Ribs
rib or two.
It doesn't have to be anything fancy, just a few spruce diagonals to
keep those
end ribs from 'bowing' in when you heat taughten the fabric. Makes
em' stay
aligned straight. For you guys wondering about the 'inter-rib
lacing' to keep
ALL of the ribs upright, there is an optional way to do this: Run
1/4" x 3/8"
spruce/fir, etc. strips the whole length of the wing panels glued to
each rib
down the center. One strip at the bottom of each rib and one strip
at the
top. This took only about 15 min. per wing to do with clothes pins
as clamps
and T-88 glue.
Mike C.
suggest that you brace the butt ribs. If you don't, the ribs will bend when
the fabric is tightened, I placed two diagonal braces from the cap strips
top & bottom to the spars at the second bays.
Subject: | Re: Titebond adhesives |
If you are planning on using an adhesive that looses 50% of it's strength at 150
deg. F, I wouldn't want to fly your airplane! The inside of my wings will reach
close to 300 deg. F in the summer sun. Granted they are painted dark green and
absorb a lot of heat energy. It's amazing how much heat will build up inside the
structure when the sun is on it.
> To all:
> Mark Boynton
> Phoenix, AZ
Rt. 3 Box 13
(304) 842-8300
To Domenic Bellissimo:
You may have missed this message I sent to you (see below). Could you
review it and comment. Thanks.
Mark Boynton
Phoenix, AZ
> From: mboynton(at)excite.com
> Message-ID:
> Domenic:
cooling
taken
is
> Mark Boynton
> Phoenix, AZ
Subject: | Extended fuse plans error? |
I have started drawing my fuselage out for the jig, and came across an
oddity. I have checked and rechecked my measurments, so I dont it's
that. The measurment that reads 29 3/4" below and behind the back seat
seems to be off. If I do all the measurments from the aft part of the
fuse, I get that gap to be and inch short. Is this a misprint or am I
missing something?
Another quick question: are the seat bottoms and legs built into the
sides when in the jig, or later?
I should be getting all my fuse wood from Jean Peters on Wednesday. He
called me to confirm something about my order, and we chatted about
Piets for almost 20 minutes; on his dime! Really nice guy. I havent
seen the wood yet, but I highly recommend him for customer service and
friendliness.
Richard
Now you can buy my CD at MP3.com:
http://db.mp3.com/Visitor/order.php3?cd_id=968
"Instrument flying is an unnatural act probably punishable by God." -Gordon Baxter
300 degrees!!?? May as well bake cookies!
Steve E. (white wings)
-----Original Message-----
David B. Schober
Sent: Monday, February 22, 1999 3:47 PM
Subject: Pietenpol-List: Re: Titebond adhesives
150
reach
and
the
> To all:
epoxy
butt
been
18,000
> Mark Boynton
> Phoenix, AZ
Rt. 3 Box 13
(304) 842-8300
Does the adhesive will "recover" his strength, once the air of take off,
cools the wings down?
At 8,000 ft ASL will be as hard as "Cromoly" wings :-) :-) ;-)
Now serious: I glue my props I carve for personal use, with Titebond II (4
years in perfect shape with Titebond [no Titebond II available here at that
time]) never "melt" in summer... could not notice any diference, remember
one thing the adhesives used in Mr Pietenpol's era, {some of them are still
flying to date}.
"I think" (personal idea) those adhesives (casein glue, etc.) were maybe 50%
the strenght of what the Titebond, or any modern good glue, gets in summer
today...
Just a thought, Go figure....
Saludos
Gary Gower
at 150
inside the
>> To all:
>> Mark Boynton
>> Phoenix, AZ
>Rt. 3 Box 13
>(304) 842-8300
Well, I did it. I bought a the Fisher Horizon 2 prototype from Mike
Fisher. It hasn't flown in about 5 years. He kept it in the showroom
(and hauled it around to airshows). He's going to do an annual on it
and I should have it in a couple of weeks.
If your interested, there is a picture at
http://www.glness.com/fisher/horizon2.html
>Date: Sun, 21 Feb 1999 21:35:11 -0500
>From: Craig Lawler <clawler(at)ptd.net>
>Subject: Re: substitute?
>Reply-to: Pietenpol Discussion
>Dean,
a
>Craig
My wings were built in the '43/44 time frame and have never been apart. They have
been recovered severla times but Howard wings are skinned with plywood prior to
fabric. They were built in the factory using Casein glue and it is still holding
up
well. The 300 deg F is no exageration. The dark green absorbs the heat energy and
the heat just continues to build. The wings are very tight, very few drain holes
and
only 5 inspection panels per wing. I've gone out in the early morning, OAT about
60
deg. and washed the airplane. The water will just steam off the top wing surface.
Two rules. Use an adhesive that will withstand temps upt at least 250 F. Paint
the
upper surfaces white or a light reflective color. After that, keep the airplane
out
of the sun as much as possible!
> flying to date}.
> today...
> Saludos
> Gary Gower
> at 150
> inside the
> >> To all:
> >> Mark Boynton
> >> Phoenix, AZ
> >Rt. 3 Box 13
> >(304) 842-8300
Rt. 3 Box 13
(304) 842-8300
From: | Michael D Cuy <Michael.D.Cuy(at)lerc.nasa.gov> |
Guys- Just to make sure everyone is clear on the plans
for this summer......The Pietenpol gathering at Oshkosh
will take place PRIOR to the Pietenpol Fly-In at Brodhead.
BOTH events will go on and not cancell each other.
We hope to confirm an arrival date/time w/ EAA for hopefully
opening day which is Weds. the 28th of July. Then on
Friday or Sat. those Piet owners who want to fly down to
Brodhead will do so.
Please make sure that if you or you know of anyone
who is planning on making the trip en-masse to Osh with us
lets Grant or I know so we can keep you posted on
details.
Thanks !
Mike C.
Subject: | Re: RE: Fwd: Corvair Cooling |
Domenic:
Good stuff. Keep us posted on how the temperatures work out. Hope its
cool.
Mark Boynton
Phoenix, AZ
> Hi Mark,
> Thats a good observation. yes it is forced air cooling. I wanted to
remove
> the fan and twisted 90 degree fan belt. I know it may only have been a
> problem with the turbo-version (belts would fly off) but I still wanted
to
> explore taking it off. I replaced the whole fan assembly with a 1 inch
> aluminum plate which I machine cooling fins on. I placed a 1 inch border
all
> around the aluminum stock for the screws. The thickness at the screws was
> 0.5 inches. This realy helps to stiffen the engine. As you know the
corvair
> engine would expand and contract and also move around a bit. This may
have
> been the cause of oil leaks in these engines, especially with the stamped
> head and oil covers. I also replaced the head covers and oil cover with
ones
> I purchased from Clarks' Corvair Parts. The oil pan is also 0.5 inches
thick
> which helps to stiffen the engine. No oil leaks so far.
> Now to answer your question: How has it worked out. well so far in
ground
> tests in this cold weather ...no problem. I plan to have the first flight
> this April, at least thats when I'm puting on the insurance. I eventually
> plan to put a six position thermal computer at all the spark plugs to
> monitor the temperature in flight. i'll keep you posted but have no data
as
> yet. Jack Watson haas the same configuration and has been running it on
the
> ground for the last 5 years (no first flight as yet) and he has not
> experienced any heat related problems. He has run his in the summer. Just
> over the VW starter that I am using I have an air inlet for cooling the
fins
> on my top cover. It dumps toward the back which helps to cool my Chev.
Spint
> alternator. The center is separated by internal baffles like the regular
> continental forced air cooling method.
> Horse Power?:110 H.P.: Don't know exactly unless I test it with some
scales,
> but estimate graphically about 83.5 H.P. at 2800 RPM at sea level. Maybe
> sometime this summer I'll set up a test with an Engineer friend of mine.
If
> I do I'll certainly post it.
> I'm glad you liked my photo's. Thanks to Richard he posted them for all
to
> see. Some friends here said they could access his site but could not
access
> my photo's for some unknown reason.
> Subject: Fwd: Corvair Cooling
> Date: Monday, February 22, 1999 3:56PM
> Hi Domenic:
> comment. Thanks.
> Mark Boynton
> Phoenix, AZ
> > Message-ID:
> > Domenic:
> cooling
> taken
have
that
> is
> > Mark Boynton
> > Phoenix, AZ
Subject: | Re: Fwd: Corvair Cooling |
Hi Peter:
That's too bad about Vertical Systems. I'm afraid I'm stumped about what to
do. Does anybody out there know what happened to the company Vertical
Systems. They're the ones who marketed the plans for converting the Corvair
engine to use the Rinker propeller speed reduction unit. They were active
on the web as late as October of last year, but seem to have disappeared
since then. Thanks for the hint on the Aerolite, Peter.
Mark Boynton
Phoenix, AZ
> Hi Mark,
> Still no progress in contacting vertical systems. My e-mail bounced back
as
> you described and directory assistance in S.B. drew a blank. Sounds like
> they have evaporated. Any ideas?
> As for the adhesive for the wing ribs. It seems that I recall hearing
from a
> number of people who are using titebond in their Pietenpol construction.
I
> have no question that its better than anything that was available in 1929.
> For myself, I'm using Aerolite on the wing ribs. It is cheap and a
delight
> to use. If you haven't seen or used it, it comes as a powder and a liquid
> catalyst. You apply the catalyst to one piece and the glue (mixed with
> water) to the other. The nice thing is that you can mix the powder with
> water in a plastic container and keep it for a few weeks in the
refrigerator,
> using it only as it is needed. There's no waste as there is with T-88,
and
> its shelf life (as a powder) is eternal. You don't have to rush a job
> because your charge of epoxy is kicking its catalytic process in the
mixing
> container (like T-88). It cleans up with soap and water and doesn't cause
> problems if you get a bit on your skin or clothing. It also dries quite
> rapidly if you use a thicker mix (although this seems to possibly reduce
its
> strength). Aerolite would be inappropriate for bonding larger surfaces,
but
> its perfect for wing ribs.
> I bought the $24 kit from AS&S, and after finishing my ribs the amount
> consumed is almost imperceptable in the package. Aerolite has been
maligned
> recently in the homebuilt aircraft community, but it has a long history of
> performing well on wooden aircraft.
> --Peter
To all:
I can't remember if I mentioned this, but the tech rep I spoke to at
Franklin did day that as the temperature comes down, the Titebond adhesive
does recover its full strength. One observation: at 18,000 psi at 150
degrees, this adhesive's tensile strength figure is still higher than that
of the wood it would be supporting.
Mark Boynton
Phoenix, AZ
(4
that
remember
still
> flying to date}.
50%
summer
> today...
> Saludos
> Gary Gower
strength
> at 150
reach
green and
> inside the
> >mboynton(at)excite.com wrote:
> >> To all:
epoxy
rep.
butt
haven't
been
about
at
18,000
and
> >> Mark Boynton
> >> Phoenix, AZ
> >Rt. 3 Box 13
> >(304) 842-8300
Subject: | Re: Extended fuse plans error? |
Richard,
I did not recall a problem with measurements along the length of the fuselage,
so I
just went back and added up the fuselage length based the numbers presented on
my plan
set. I built to the "extended fuselage" shown on the "supplementary plans", but
I
also checked the figures from the short fuselage plans dated 1-19-33.
In both cased the fuselage-top and fuselage-bottom figures added up to give a
consistent fuselage length.
The short fuselage length worked out to 163 inches, the extended fuselage to 172.375
inches.
I suggest you recheck your overall length, and every measurement.
I did the framing for the aft seat bottom after the fuselage was built up into
a boxed
3-D shape. Was a bit awkward to do but worked out well.
Dick Winkel
This is an interesting trend. The Christavia designer, Ron Mason, just
recently sold the prototype of his MK 1. I'm sure you have a good plane.
I've admired Fisher's designs for years and would love to build one of his
Tiger Moth replicas. Hmmm... I could see a pretty yellow and black RCAF
paint scheme with that big greenhouse canopy....
Ken
> >Dean,
> a
> >Craig
Subject: | change of address |
Steve,
Please change my account address from
aron(at)hrn.bradley.edu to
jefay(at)yahoo.com
John in Peoria
From: | Craig & Shari Hanson <chanson(at)polarcomm.com> |
Just a short note to ask a question. If you use 1/2" spruce for the spars,
and using 1/4" wood strips for the top and bottom caps, can the top and
bottom caps be 1/4" aviation grade plywood instead of spruce or equivalent
wood?
Craig
spruce for
the spars, and using 1/4 wood strips for the top and bottom
caps,
can the top and bottom caps be 1/4 aviation grade plywood instead
of
spruce or equivalent wood?
Craig
In case you haven't heard yet there is another piet for sale.
Steve E.
Pietenpol Aircamper for Sale
80 h.p. Ford Escort with 2.5 to 1 reduction, new Hegy 76x60 prop, 76 TTAF ,
new paint (Cub yellow wings and tail area, Bahamma blue fuselage, antique
look motorcycle wheels with straight axle and mechanical brakes, new
ignitiion system and battery, well built, frequently admired. At local 4800
altitude it takes off like a 150 h.p. Super Cub. Forced to sell. $7,000.
Call Bill at 208-356-3819 home or 208-356-1415 work.
Subject: | Test, Please ignore |
Couldn't resist, eh? I am trying to see if I still get mail
from the group.
subscribe
Apparently I got knocked off
Too quiet out there. Have I dropped off the server again?
Ian- This will wake them up......
My next Piet will be VW powered with gear reduction, all
pine construction, retractable gear and flaps, widened by 8"
with a 35 foot four piece wing.
MC
I don't think you dropped off the server. I think everyone is just frozen
up a bit. It is nice a warm down here in Texas. Near 80 for today. Just
right for working on your pietenpol. Got mine togather in the shop but now
I can't even run up the engine. Will have to take the wings off to get it
out of the shop. Plan to move it to the airport in a month. jas
Where did you dig up plans for that sucker. I thought I burned them after
building mine. Just be careful with that retractable gear. Had a little
trouble with mine. Wouldn't come down unless you were at sea level. Tied in
with the altimeter. Wasn't that good a design. jas
>MC
Oh yeah, Richard, Jim S. I forgot to tell you it will be the
biplane version with a ballistic parachute system !
MC
after
a little
Tied in
be the
MC
Test has came thru load and clear.
I have been busy expanding my work shed another 11' x 33' with a front
section 22' x 16' just so I can start some of my many waiting projects.
Gordon
writes:
__________
Guys- on a more serious subject, Jim Sury in TX has
been sending me .jpg photos of his progress on his
GN-1 and it's looking very, very nice. Cream and
orange with Continental power. I know we should not
send attatchments on this list, but I wonder if Jim could
send a few of his latest pics. to Richard D. to post on
his now famous Piet web page ? (nothing like volunteering
you, eh Jim ?)
Mike C.
Subject: | Re: Jim Sury's Piet |
Nothing like getting volunteered Mike. I was waiting to do that after I
get it in front of the hanger. Away from all the junk in the shop. But
since I got volunteered I will send one to Richard DeCosta. jas
>you, eh Jim ?)
>Mike C.
"I" beam spars are usually made up with a plywood web & wood caps -- on the
spar you describe the ply may be 1/4" thick, but 1/2 of the plys are
running cross grain to the spar. You'll end up with a spar that is only
equal in strength to a 1/2" wide spar.
Mike C.
PP, KS
wood?
Craig
Craig,
Michael is correct on this. Consider going to your nearby lumber yard that
sells contractors I beam floor joists. They normally have samples and load
carrying tables that they will give you or at least let you fondle. You will
get some first hand views of grain orientation and strength comparisons. Your
family probably thinks that you are worth the $100.00 that doing this right is
going to cost you...{8
Best Regards.
Warren
> Mike C.
> PP, KS
> From: Craig & Shari Hanson <chanson(at)polarcomm.com>
> Subject: SPAR CAPS
> Date: Tuesday, February 23, 1999 10:04 PM
> wood?
> Craig
I came across this on the Wings Online page. It would probably fit a Piet
nicely.....
For Sale Lycoming O145
2/25/99 - Lycoming O145 of tcraft w/logs includes mags and carb complete
engine $1000. 200smoh aceaeromotive(at)hotmail.com
Ken
Hi My Wife works at a library and gets good discounts on book purchases
for us. Can anyone give me the ISBN (library of congress) numbers for
Tony Binglis books so that I can order them I have only found one # so I
know I can get the books for $18.00 each (better than EAA member price)
John Duprey
Subject: | Re: Bingelis Books |
John:
The Tony Bingelis book Sportsplane Construction Techniques is 0-940000-92-X
and The Sprotsplane Builder is 0-940000-30-X for the ISBN numbers. I do not
have the other two.
Joe Matthews
Columbus, GA
Subject: | GN-1 Landing gear |
Does anyone know the gage of the channel on the landing gear that goes under
the Fus. . This holds the gear together and there are two of them, front
and rear.
Barry
Hello.....Anyone out there?
Subject: | Oil Lines, Model A Ford Engine |
Hello,
Does anyone have detail plans that show how the additional oil lines are
installed on the Model A Ford engine (or can describe the proceedure)? The
plans from Pietenpol are incomplete and confusing.
Thanks, Glenn
Subject: | Need suggestions |
O.K. Here's the deal. I haven't had to order plans yet because I had a
rib given to me that I made a jig out of, so I've been up to my ears in
rib building.
When I order plans, I'll order the exteded fuse. option too, along with
supplemental plans for aileron gap seal, 3 piece wing, etc., etc., etc.
So far I'm up to about $200. Any suggestions?
Also, I have access to 4"X7/8"X14' spruce. Can I get away with the 7/8"
on the longerons, or should I plane it down to 1/2" and laminate 2
pieces together?
Any insight will be appreciated.
Larry Ragan
Jacksonville, Fl.
lragan(at)hotmail.com
I have always loved flying and generally anything to do with aviation,
but I have never felt to inspired as I do after visiting the X-Prize
web site (url below). This has little to do with the Piet directly,
but I'm sure most of you will appreciate it. For those of us too young
to have been around durring other historical events, we now can feel
like we are witnessing history being made.
http://www.xprize.org
Richard
http://www.wrld.com/w3builder
Subject: | RE: Need suggestions |
It's a shame to make sawdust of good spruce, why not laminate it up to 1
inch with 1/8 stock?
R. Smith
Sent: Tuesday, March 02, 1999 9:42 AM
Subject: Pietenpol-List: Need suggestions
rib building.
pieces together?
Larry Ragan
Jacksonville, Fl.
Subject: | Re: Need suggestions |
If this is quality air dry Sitka Spruce, rather than white lumber yard
spruce, AND is clear, true vertical grain, with more than 8 rings per inch,
you would be quite safe in just ripping 1" wide stock X 7/8" deep. Brace
all of your corner points with 1" triangle pieces with the vertical grain
placed to take any additional compression. Use good quality birch ply for
gussets and you will have a very strong fuselage.
Warren
> Regards,
> R. Smith
> Subject: Need suggestions
> rib building.
> pieces together?
> Larry Ragan
> Jacksonville, Fl.
Greetings:
I hear that there will be a Pietenpol gathering at Oshkosh this year. I am
going this year and would like to know what you folks have planned. I am not
a Pietenpol owner/driver but have an interest. Could someone give me the
scoopage on your plans/schedule for this year.
Joe Matthews
Columbus, GA
>rib building.
>pieces together?
>Larry Ragan
>Jacksonville, Fl.
I remember reading that Bernie measured to 1" then cut to the center of the
mark. The kerf of the blade (thickness) is lost in sawdust when cutting the
wood resulting in longerons of approx. 7/8" x 7/8". The piet is kinda
overbuilt anyway.
Barry
Subject: | Re: Oil Lines, Model A Ford Engine |
Hi Glenn
The changes are reasonably well depicted on Dwg 8 of the 1933 plans drawn
by Orrin Hoopman. Some of the missing detail is I suppose due to assumed
knowledge of the A.
In stock configuration the A is oil by gravity and splash. The large oil
tube that runs at an angle from the valve chamber drains oil into the timing
end or front of the splash pan. This oil runs back filling the dipper
troughs of the pan splash pan. Oil runs by gravity from the valve chamber to
through the drillings in the block to the main bearings.
The conversion has the cast iron side cover replaced with a steel sheet.
When you remove the cover you will see a tube cast into the block that
slopes up from the oil pump towards the cam gear end of the valve chamber.
This is the oil pump outlet. The copper line inserted into the oil outlet
carries oil from here to the front (formerly rear main) and is T'd into the
center main.
The 1/8th pipe plug just above the pan flange on the oil pump casting bump
is a pressure port. ( If you want to scare yourself put an oil pressure
gauge here :-). This line, from the port, fills oil into the prop end of the
splash pan for the connecting rod dippers. The other line from the bottom of
the rear end of the valve chamber drains the oil from the chamber to the
front end of the splash pan. You will have to drill and tap this hole. 1/4"
seems small but I figure that Bernie was counting on less oil in the chamber
by piping it from the pump outlet to the front of the splash pan. Notice in
the drawings that the splash pan has dams and baffles welded into it. Some
of the early A's had a tube pressed into the rear main to carry oil away
from the crank main slinger. Cut this tube off and extend the splash pan to
catch the oil.
If I was doing it I would consider having an aluminum pan made up that steel
pan is heavy.
Hope this helps
John Mc
Date: Tuesday, March 02, 1999 6:26 AM
Subject: Pietenpol-List: Oil Lines, Model A Ford Engine
>Hello,
>Thanks, Glenn
>snip<
>pan is heavy.
>Hope this helps
Hello John,
I am sure that your description will help. I am trying to locate this
information for a friend that is strongly considering builting a Piet, but
only if he can get some answers before he starts. I will give him your
information, which I know he will appreciate very much!
He is very knowledgable on the Model A engine (he has rebuilt many) and
should have no problem with your description.
Thanks very much!
Glenn
I have 6 inch exhaust stacks on my C-85-12. I was wondering how to
fabricate a heat exchanger for some heat for my carb. Anybody got any
suggestions. 6 inches of exhaust stack isn't a lot to work with. jas
>Greetings:
>>Thanks,
>>Joe Matthews
>Columbus, GA
Joe- We are planning a 'mass fly-in' of Pietenpols/GN-1's to Oshkosh
on opening day, Weds. July 28th. THIS DATE has not been totally
confirmed yet but most likely will be the day. Tom Poberezny said
he would like us there early since alot of the crowds leave towards the
weekend or right after. The good part about this is that we will be
able to have the Piets at Oshkosh for a day or two, then fly down
Thurs, Friday to the Brodhead, WI Pietenpol Fly-In and enjoy BOTH
events BACK to BACK. I should be a great time- the more Piets
the better. I am keeping track of who is joining us to Oshkosh for
our newletter editor Grant MacLaren. (so EAA knows how many
parking spots to rope off for us) Grant has been working with
Golda Cox and Tom Poberezny at EAA and hopes to do a multimedia
presentation on Pietenpols one night at the Theater in the Woods.
Also on opening day Bill Rewey will be doing a tent forum at EAA
about Pietenpols. Please spread the word and hope to see you
at BOTH events !!
Mike Cuy
Clev. OH
Greetings:
year. I am
planned. I am not
give me the
Joe Matthews
Columbus, GA
Oshkosh
totally
the
be
BOTH
Piets
for
at BOTH events !!
Mike Cuy
Clev. OH
Subject: | Re:Sources of Ford Engine Parts |
As some of you are searching for parts, here a few sources..
Antique Auto , 3560 Chestnut, Pl. Denver, CO 802216, 800 846 7332 B HJigh
Compression Heads, does babbit pouring, align boring, 660 brass thrust
washers.
Mike and Ed Stein, 31 Gilbert RdSouthampton, Ma. 010703 413 527 5129
Hart's Auto Parts, 419 399 477 Cecil, Oh.
Check with your local Modeal A Club for more sources. I have a lot more if
someone needs them.
Keep em flying.. Dr. O Lanham, Bellevue, Ne
I've lost all my Piet links. I've searched and found 4 links. I'd
appreciate others if you would send them to me. Thanks in advance and
may you be blessed with a tailwind, Randy.
All my links are here: http://207.140.1.221/w3builder/piet/links.shtml
Richard
Subject: | Pietenpol Fly - In |
A Pietenpol Fly-In is scheduled for Sept. 11, at Benton Airport, about 10
miles northeast of Wichita KS. I'm curious as to how many Pietenpols are in
the Wichita area, and can make it there. We would also like to spark some
interest in this type, and invite everyone to attend. Maybe even convince a
few people that the time and effort to build one is well worth it.
As for the wing that is here in my living / dining room...it looks WAY COOL,
and is comming along nicely !!! The ribs are all nailed in place on the
spars, the leading edge is bolted & glued on, the trailing edge is glued on,
the pieces are all cut and pre-fit for the ailerons, and I'm now working on
epoxying these pieces in place.
Chuck Gantzer
Wichita KS
Subject: | Western Aircraft Supply |
FYI... yesterday I finally received my shipment of fuselage material
from Western Aircraft Supply. The spruce is of SUPREME quality.
Absolutely perfect. If you order from him, and you live in the US,
however, be prepared to wait about a week for the wood to clear
customs. Man! What a lot of hassle that was!
Anyway, now that I have it I can start building something to sit in...
The pieces in the kit are cut to the the right lengths (actually just
over) and you cut the appropriate angles, etc, to fit it together, and
90% of them are labed as to what they are, and where they go (written
on masking tape). I'm very impressed. Only one piece got damaged in
shipping, and it was a small piece, easily replaced.
A very happy Camper,
Richard
Subject: | Re: Western Aircraft Supply |
Richard,
I know that the address and the phone number have been on this group before
but could you let me know again what they are?
Craig
The address is on my suppliers page:
http://www.wrld.com/w3builder/piet/Suppliers.shtml
---Craig & Shari Hanson wrote:
> Richard,
before
> Craig
> Richard
Er, shouldn't that be, "A very happy Air Camper?"
"Everything that can be invented has been invented."
- director of the US Patent Office, 1899.
Subject: | Re: Built up spars |
Greg,
I finally got to talk to Tony Bingelis last night about the built up spar techniques.
(I just had not seen him for over a month!)
Tony feels the gluing/clamping method used should match the kind of glue being
used.
The epoxy glues would really work well with vacuum bagging. His main warning
was that the epoxys set up too fast to have that be practical. By the time you
assemble a large part, and get it bagged, most epoxys have "gone off". Tony
says to be careful or you could wind up with a big expensive mess. He said he
has heard there are some slow epoxys on the market now but he has not used
them. He indicated that he really liked the idea but had not tried it himself.
He was real enthused with the idea and said that if you have the vacuum
bagging equipment, it would sure be an easy way to build a spar!
The non-epoxy glues really take more clamping pressure than vacuum bagging
will give and he did not recommend trying vacuum bagging with other types of glue.
Sounds like C-clamp manufacturers still have some job security!
Bob Seibert
Subject: | Gadgets for builders |
Greetings to the members of the discussion group:
I am writing an article on the gadgets, special tools, benches that builders
need to build in order to actually build the aircraft. There have been
articles which touch on this subject, but nothing comprehensive. They tend to
be specific to a particular aircraft.
I have gathered a number of items, but a more robust list with good examples
would be ideal. So, I am looking for ideas. The deal is that I will give
full credit for any ideas used. Unfortunately, I cannot pay for them.
Writing has not been a way to get rich. You would be basically putting your
idea into the public domain for others to use and benefit from. If thats cool
with you, we are in business. I can recieve pictures drawings, whatever it
takes to get the idea accross. Any questions, please e-mail me directly.
Joe Matthews
Columbus, GA
Subject: | Re: Brodhead/EAA |
At this time I am not sure about Osh. and B'head this summer. I have a GN-1
that is ready to fly, but I haven't flown much in four years and don't know
if I'm up to the trip. Please keep me informed about the plans though. How
soon in advance will you need to know who's showing up?
Thanks, Larry Pasley
> details.
> Thanks !
> Mike C.
Richard,
What kinds of problems did you have with customs? I will be having
my wood delivered to the Rochester, NY airport which is an
international airport and local. My plan is to pick up the wood
there to save on trucking it to the house. Would it be better to
have the wood shipped to Toronto and just drive it across the
border myself?
Dave
Check with your shipper for a "freight forwarder" or "customs
broker" office. They do this all the time, know the forms and often
even the customs officers personally and usually the cost is minimal.
Good Luck,
Warren
> Richard,
> border myself?
> Dave
Subject: | To nail or not to nail, that is the question. |
I have cranked out my first few wing ribs, using the glue and clamp
method. I am thinking it would be better to nail the gussets rather than
clamp, so I can speed production. I would use brass aircraft nails, a
friend advised me against nailing. I would like to here others opinions
and experiences.
John Duprey
Subject: | Re: To nail or not to nail, that is the question. |
I used a staple gun on mine. Sppeded things up tremendously. I could
do a rib in about 2 hours (not including drying time).
than
opinions
> and experiences.
> Thanks
> John Duprey
Hi,
It is that time of the year again - annual time! I stripper her yesterday
and have a question. We have threaded aluminum rod, with a nut at each end,
used to connect the top and bottom of the long flat aluminum piece (I can't
remember the proper name at this moment) that covers the joint between the
wings and the center section. Some of the nuts corroded with the aluminum
rod and broke off.
I am looking for alternatives. What have you used that you have found to be
better?
Thanks, Ted
Of course the weather is perfect. Not a cloud in the sky, near 80 and
little wind. Just wait till we get back into the air... or until I try to
fly to Brodhead this summer. Do you think we will have this kind of weather
then???
John;
I have used several methods of gussett attachment over the years. On the
thick (1/2") Piet ribs, you can use 1/4" steel, brass & cement coated
aircraft nails or an electric staple gun. The nail method goes all the way
back to the Wrght Bros so it is the typical method to use. One of my planes
had 1/4" thick ribs so nailing on that one wasn't the best choice.With the
nails, I used a magnetic tack hammer. The small magnetic end will keep the
small nail head put to lightly "set" the nail into the rib thru the gussett.
You then flip or rotate the hammer to the face side to finish driving the
nails, 4 to 6 per gussett. Don't use nails any longer than 1/4" as this will
keep the nail tips from touching each other from one side to the other
considering the gussett thicknesses......
With the staple gun, use "fine wire" staples and be carefull of the
"striking" force the stapler uses so you don't crush the wood. I always just
left the staples in the ribs as the marginal extra weight wasn't worth the
extra time or damaging the wood trying to pry out the staples. Don't make a
big deal about leaving the staples in......but make sure you don't use the
thick or heavy duty staples as they will split the ribwood. I also
exclusively use T-88 Epoxy Glue as it is structurly gap filling and will
follow the nail down into the wood.
By the time you get the rib making down pat, you will be done!
Earl Myers
Date: Sunday, March 07, 1999 8:04 AM
Subject: Pietenpol-List: To nail or not to nail, that is the question.
>and experiences.
>Thanks
>John Duprey
In a message dated 3/7/99 8:19:41 AM Central Standard Time,
aircamper(at)yahoo.com writes:
<< Subj: Re: To nail or not to nail, that is the question.
Date: 3/7/99 8:19:41 AM Central Standard Time
Sender: Maiser(at)adena.byu.edu
Reply-to: piet(at)byu.edu (Pietenpol Discussion)
To: piet(at)byu.edu (Pietenpol Discussion)
than
opinions
> and experiences.
> Thanks
> John Duprey >>
I used weights on my gussets, with T88 Epoxy. They say that ya don't want to
squeeze out T88 too much, and using weights took less time than nailing, and
it left a clean looking gusset. It took 15 different weights, of aprox. 10
to 15 oz each. Heavy duty half inch drive sockets worked well. One problem
I had using this method, was out of the whole stack of ribs, on 4 different
gussets they leaned a little, because the weight wasn't centered, and I had to
replace them. Ya will soon discover exactly how much epoxy is required to
do the gussets on the rib in the jig, and the gussets on the flip side of the
rib that was just removed. Happy glueing John, and don't forget to take some
pictures !!
Chuck Gantzer
ps Hey Richard D., who is Gordon Baxter ?
I have used cabinetmaker's screw inserts set into a small block glued to the
underside of the rib. They take a #6 stainless machine screw. Since you will
be going through the capstrip be certain that the block is of sufficient size
to eliminate any loss of strength (do not use this method unless you are
following the plans and are using 1/4" X 1/2" ribstock. A description of the
insert I used appeared in an issue of the BPA Newsletter about four to six
issues back. It worked great for me. I also used this method for attaching my
cockpit and engine cowling. Don Hicks
John, Earl Myers reply to your questions re: nailing was very good Over the
years (40) I have used mostly 1/4 brass nails and Weldwood Plastic Resin glue
with excellent results but it is more critcal than T-88 regarding temp, mixing
consistency and pressure. I used staples for the first time (on my leading
edge} with T-88 and was pleasantly surprised at how fast and effective it was.
I would not hesitate to recommend this was to go on rib gussets. I agree with
Earl re: leaving in the staples. The same goes for nails. The weight is
insignificant and I have see antiques put together with caseine glue where the
glue had deteriorated and the only thing holding it together was the nails!
You won't go wrong following Earl's advice. Don Hicks
I have found out that the Happy99.exe attachment may be a virus. Do not
open it
Craig
virus. Do
not open it
Craig
Subject: | Re: Know where to steal good ideas... |
Hi All!
Found a good article in the March/April 1999 "WoodenBoat" ( I had gotten
that issue for an article on making a 7" smoothing wood plane & discovered
the other article!! ;-) -- it was a product review on Aerodux 500
resorcinol glue for boats.
Compared to the US resorcinol glues, this product can be used as low as 45
degrees F & with glue joints up to 1/16 inch. There are (3) speeds (!)
ranging from 15 min to 2 hrs (at 90 degrees F).
This should be a product to watch!! The only down side is there is no
distributor in the US! (it has used in England for the past 30 years) It
could be available by the time I get to any major wood work!! ;-)
Mike Conkling
Pretty Prairie, KS
Couldn't say where this came from! My reply was a "reply to author"
response.......I did see a Happy 99 message come back in along with my
regular Piet mail. It must have piggybacked thru me, however, I havn't had a
problem with a/this "virus" nor do I have any anti-virus "medicine" in the
computer. I will have shortly. I guess it didn't "get" me??? I don't know if
I would know what a virus is I guess (yet) ??? Sorry??????????
Subject: Pietenpol-List: Virus
Date: Sun, 07 Mar 1999 22:32:32 -0500
Hi Guys: Happy99 is a virus, the others are right DO NOT OPEN! It fried
some computers at my office.
John Duprey
Subject: | Re: happy 99 virus |
Use your search engine and search "happy 99." You get get a couple of hits
on sites with instructions on how to delete the virus. I have seen it sent
at least 6 times in the last two weeks. Maybe we should lable all
attachements, pictures or otherwise, with an aviation name so we wont be
gun-shy about opening files.
From: Michael D Cuy <Michael.D.Cuy(at)lerc.nasa.gov>
Subject: Pietenpol-List: Re: Brodhead/EAA
Date: Mon, 08 Mar 1999 09:07:35 -0500
>Larry- The plan is to gather at Hartford, WI the night before
opening day of OSH (wed. July 28th is opening day) EAA needs to
know about how many parking places to rope off for us to keep us
together so if you know by say 3 weeks ahead of time or even maybe
2 that should be good. They don't expect us to have it down to the
exact number, but a good estimate is what's needed. Thanks for
asking and let us know if you will be joining us as time gets closer.
Mike Cuy
a GN-1
don't know
though. How
before
to
the
for
closer.
Mike Cuy
Subject: | Re: Oshkosh Fly-in |
>Hi Michael,
> I have a question, is there any chance of catching a ride with one
>of the pilots in the EAA fly-in? I live near Green Bay, WI and would be
>willing to drive to meet a ride. I plan on building a Pietenpol some day
>and a ride in one sure would give me an idea what it's like. The plans I
>have, now I'm in the process of building a place to build it.
Bob- Keep your eyes on Grant's Piet web site for details, but your best
bet is to post just what you did here to me to the Piet discussion group
Piet(at)byu.edu The plan is for all Piets going into OSH to meet July 27th.
eve. at Hartford, WI then lauch off to EAA on opening day, Weds. July 28th.
Then most/all will migrate down to Brodhead WI on Thurs/Friday/Sat to join
up for the regular Piet Fly-In which will take place as usual. Your chances
of catching a ride are far greater at Brodhead than at EAA though.
ps- I'm cc:'ing this to our fine discussion group and who knows, maybe you'll
get a bite.
All the best,
Michael Cuy
Hi Michael,
be
day
plans I
best
group
28th.
join
usual. Your chances
you'll
get a bite.
All the best,
Michael Cuy
I used the brass aircraft nails and a pair of tweezers and had no
problems. The key issue is the glue drying time. That is more of a
limiting factor than putting in about 150 nails per rib. If I had to do
it over again, I would still use the nails.
Thanks Bob, and tell Tony thanks too.
I think I'm going to go ahead and use the clamping method. I'm using the Gougen
West
Epoxy System for my whole plane. I noticed in this months Sport Aviation there
was
another West System fan. I think it was the 'Cotton Candy' builder but I maybe
wrong. I
always read the magazine front to back and sometimes the details are fuzzy the
first time
through. I'll have to go back and look.
Greg Yotz
Seibert wrote:
> Greg,
used.
glue.
> Regards,
> Bob Seibert
Ted;
Most of the Piet's up here use either small ss screws into the rib (some
reinforced for this, some not) along the edge of the metal "root rib gap
seal" OR are laced top to bottom with leather, uh, thong material or....like
you use on the bottom of your sidearm holster to wrap around your
leg..............I have a one piece wing so didn't need a thong cord or
laceing cord or whatever you might call it!
Earl Myers
PS: Just had a big snow storm, expecting a whopper tommorrow and another
Sat......80 degrees, what is that like anyways? Won't see that till late
June here!
Date: Sunday, March 07, 1999 9:30 AM
Subject: Pietenpol-List: Fasteners?
>Hi,
end,
>rod and broke off.
be
>better?
>Thanks, Ted
weather
>then???
To close the gap on my 3 piece wing I used an Al strip 3" wide and 12 or so
feet long. strapped on with 1/8 bungee cord I purchased from a camping
supply store.
steve E.
Earl Myers
Sent: Monday, March 08, 1999 9:37 AM
Subject: Pietenpol-List: Re: Fasteners?
Ted;
Earl Myers
June here!
>Hi,
end,
>rod and broke off.
be
>better?
>Thanks, Ted
weather
>then???
Ted- I used small pk screws (or similar) to screw my approx. 3" wide
alum. strip around the wing root/center section areas into wood blocks
I glued to either face of the ribs. (or you could screw them into the
rib capstrips. Originally I was going to try a few tabs of velcro about
a foot apart around the airfoil to do the job but decided against that in
the end.
Mike C.
Try and find a short wing Piper (Vagabond, Pacer, Colt, Tripacer) to look
at. It is a bit of work and is really smooth. The only fastener is thru the
trailing edge wrap around, and is a screw that pulls the underwing portion to
it from a fastener bracket flush riveted on the inside. Very simple and has
worked since at least 1948.
Warren
This is what Norton antivirus had to say about it
Virus Information
Virus Name: Happy99.Worm
Aliases: I-Worm. Happy
Infects: N/A
Likelihood: Common
Length: 10000 bytes
Characteristics
Memory Resident No Triggered Event No
Size Stealth No
Encrypting No
Full Stealth No
Polymorphic No
Comments
This worm modifies WSQCK32.DLL to send itself as attachment when a
posting is made to USENET or MAIL. Delete SKA.EXE and SKA.DLL in
WINDOWS\SYSTEM folder and replace WSOCK32.DLL with WSOCK32.SKA in
Subject: | Painting big numbers |
I have got my plane almost ready for spring, but I still want to pain=
t my
N-number in large letters on the wing.=A0 I want to go about 24" high=
.=A0 any
suggestions about how to mask and transfer something that big to the
wings?
=A0
Steve e
Provo
=A0
Steve Eldredge
Steve(at)byu.edu
IT Services
Brigham Young University
=A0
Subject: | Re: Painting big numbers |
Steve the sign shops have masking film that they can cut on computer. If you
can not find one then give me a call and I will have the sign shop next door
do it.
Ken Hannan
1-888-693-2496 toll free
To: Pietenpol Discussion
Date: Monday, March 08, 1999 10:46 AM
Subject: Painting big numbers
I have got my plane almost ready for spring, but I still want to paint
my N-number in large letters on the wing. I want to go about 24" high. any
suggestions about how to mask and transfer something that big to the wings?
Steve e
Provo
Steve Eldredge
Steve(at)byu.edu
IT Services
From: | Kevin McDonald <kevin.mcdonald(at)dev.tivoli.com> |
> high. any suggestions about how to mask and transfer something that
> big to the wings?
Hmm I've been trying to figure out to get large N numbers 'off' my
Tri-pacer. If you fly your piet below 500 feet you want to reconsider!
to me the joy of experimentals is that you get to use small N numbers...
Ktm
Subject: | Engine question? |
Just as a matter of curosity, does anyone know of a 4 stroke Rotax 912
being installed in a Piet?
Bob Bailey
Subject: | RE: Painting big numbers |
I thought of this and intend to paint only on the top of the wing. Maybe
still not a good idea?
Steve E.
Kevin McDonald
Sent: Monday, March 08, 1999 1:56 PM
Subject: Pietenpol-List: Re: Painting big numbers
> big to the wings?
Ktm
Subject: | Yesterday's Wings plans |
To all:
I should begin work on my wing ribs shortly. I intend to use the no-gap
aileron plans from Gary Price @ Yesterday's Wings, when I'm ready to
assemble the aileron's. My question is, do Gary prices plans call for any
modification to the wing ribs I should be aware of before I launch into
building the ribs according to Don Pietenpol's plans set? Thanks.
Mark Boynton
Phoenix, AZ
Subject: | Re: Yesterday's Wings plans |
Not at all. Would suggest that you do get his plans ahead of time though,
as you will be using his plans for the end plate ribs only. He also has a
really great set of plans for fiberglass wing tank, which is also very well
drawn, excellent detail, and color pictures of the various construction steps.
Warren
Hello
I live in Cedar Hills, UT and am building a RagWing Special about 25-30%
done.
I saw you email address on a post on a email list I sponsor, I'm guessing
that you are a peitenpol builder. what is your building status and can your
project be seen?
Carlos
Carlos K. Gurr
RWS #327 (unnamed so far)
Cedar Hills, UT
http://netnow.micron.net/~carlosg
Ken Hannan,
You wrote
This worm modifies WSQCK32.DLL to send itself as attachment when a posting
is made to USENET or MAIL. Delete SKA.EXE and SKA.DLL in WINDOWS\SYSTEM
folder and replace WSOCK32.DLL with WSOCK32.SKA in WINDOWS\SYSTEM folder
How do you replace WSOCK32.DLL with WSOCK32.SKA.
I have no problems with the delete but the replace has me baffled
Craig
=FF=FE<=00!=00D=00O=00C=00T=00Y=00P=00E=00 =00H=00T=00M=00L=00
=00P=00U=00B=00L=00I=00C=00
=00"=00-=00/=00/=00W=003=00C=00/=00/=00D=00T=00D=00 =00W=003=00
=00H=00T=00M=00L=00/=00/=00E=00N=00"=00>=00=0D=00=0A=
=00<=00H=00T=00M=00L=00>=00<=00H=00E=00A=00D=00>=00=0D=00=0A=
=00<=00S=00T=00Y=00L=00E=00>=00<=00/=00S=00T=00Y=00L=00E=00>=00=0D=00=0A=
=00=0D=00=0A=
=00<=00M=00E=00T=00A=00
=00c=00o=00n=00t=00e=00n=00t=00=00'=00"=00M=00S=00H=00T=00M=00L=00
=005=00.=000=000=00.=000=009=001=000=00.=001=003=000=009=00"=00'=00
=00n=00a=00m=00e=00=00G=00E=00N=00E=00R=00A=00T=00O=00R=00>=00=0D=00=0A=
=00c=00o=00n=00t=00e=00n=00t=00=00"=00t=00e=00x=00t=00/=00h=00t=00m=00=
l=00;=00
=00c=00h=00a=00r=00s=00e=00t=00=00u=00n=00i=00c=00o=00d=00e=00"=00
=00=0D=00=0A=
=00h=00t=00t=00p=00-=00e=00q=00u=00i=00v=00=00C=00o=00n=00t=00e=00n=00=
t=00-=00T=00y=00p=00e=00>=00<=00/=00H=00E=00A=00D=00>=00<=00/=00H=00T=00M=
=00L=00>=00<=00H=00T=00M=00L=00>=00<=00H=00E=00A=00D=00>=00<=00/=00H=00E=00=
=00<=00B=00O=00D=00Y=00
=00b=00g=00C=00o=00l=00o=00r=00=00#=00f=00f=00f=00f=00f=00f=00>=00=0D=00=0A=
=00<=00D=00I=00V=00>=00K=00e=00n=00
=00H=00a=00n=00n=00a=00n=00,=00<=00/=00D=00I=00V=00>=00=0D=00=0A=
=00<=00D=00I=00V=00>=00&=00n=00b=00s=00p=00;=00<=00/=00D=00I=00V=00>=00=0D=
=00=0A=
=00<=00D=00I=00V=00>=00Y=00o=00u=00
=00w=00r=00o=00t=00e=00&=00n=00b=00s=00p=00;=00 =00=0D=00=0A=
=00<=00P=00>=00T=00h=00i=00s=00 =00w=00o=00r=00m=00
=00m=00o=00d=00i=00f=00i=00e=00s=00
=00W=00S=00Q=00C=00K=003=002=00.=00D=00L=00L=00 =00t=00o=00
=00s=00e=00n=00d=00 =00i=00t=00s=00e=00l=00f=00 =00a=00s=00
=00a=00t=00t=00a=00c=00h=00m=00e=00n=00t=00 =00w=00h=00e=00n=00 =00a=00
=00p=00o=00s=00t=00i=00n=00g=00 =00i=00s=00 =00=0D=00=0A=
=00m=00a=00d=00e=00 =00t=00o=00 =00U=00S=00E=00N=00E=00T=00 =00o=00r=00
=00M=00A=00I=00L=00.=00 =00D=00e=00l=00e=00t=00e=00
=00S=00K=00A=00.=00E=00X=00E=00 =00a=00n=00d=00
=00S=00K=00A=00.=00D=00L=00L=00 =00i=00n=00
=00W=00I=00N=00D=00O=00W=00S=00\=00S=00Y=00S=00T=00E=00M=00
=00f=00o=00l=00d=00e=00r=00 =00a=00n=00d=00 =00=0D=00=0A=
=00r=00e=00p=00l=00a=00c=00e=00
=00W=00S=00O=00C=00K=003=002=00.=00D=00L=00L=00 =00w=00i=00t=00h=00
=00W=00S=00O=00C=00K=003=002=00.=00S=00K=00A=00 =00i=00n=00
=00f=00o=00l=00d=00e=00r=00<=00/=00P=00>=00<=00/=00D=00I=00V=00>=00=0D=00=0A=
=00=0A=
=00<=00D=00I=00V=00>=00H=00o=00w=00 =00d=00o=00 =00y=00o=00u=00
=00W=00S=00O=00C=00K=003=002=00.=00S=00K=00A=00.=00<=00/=00D=00I=00V=00>=00=
=0D=00=0A=
=00=0A=
=00<=00D=00I=00V=00>=00I=00 =00h=00a=00v=00e=00 =00n=00o=00
=00p=00r=00o=00b=00l=00e=00m=00s=00 =00w=00i=00t=00h=00 =00t=00h=00e=00
=00d=00e=00l=00e=00t=00e=00 =00b=00u=00t=00 =00t=00h=00e=00
=00r=00e=00p=00l=00a=00c=00e=00 =00h=00a=00s=00 =00m=00e=00
=00b=00a=00f=00f=00l=00e=00d=00<=00/=00D=00I=00V=00>=00=0D=00=0A=
=00=0A=
=00<=00D=00I=00V=00>=00C=00r=00a=00i=00g=00<=00/=00D=00I=00V=00>=00<=00/=00=
B=00O=00D=00Y=00>=00<=00/=00H=00T=00M=00L=00>=00=0D=00=0A=
=00
Craig:
You cannot replace the WSOCK32 file as indicated with windows. Windows will
not let you do it. Exit Windows into MSDOS. Use CD to get to the
Windows\SYSTEM subdirectory then copy command to replace the file. I did it
and it worked fine. Restart Windows.
Joe
Is it possible to get brass staples for an air stapler?
Alan Davenport - gandalf at goldcom dot com
A mouse trap placed on top of your wife's alarm clock will
prevent her from rolling over and going back to sleep.
Hi Carlos,
In fact, I am building nothing at all at the moment. I am trying to arrive
at a decision and am very much interested in the Pietenpol. I'd like to
gain as much knowledge as I can before I make the 'big' leap.
Best Regards,
Les
Sent: Monday, March 08, 1999 3:37 PM
Subject: Pietenpol-List: Homebuilts
Hello
done.
project be seen?
Carlos
Carlos K. Gurr
Cedar Hills, UT
I am upset about this virus I have just been infected with. Steve,
can't attachments be blocked from this group?
Brent Reed
I'm sorry. I got too hot there. I fixed my machine and it didn't kill me.
I now see that it was not the fault of anyone on this list. I apologize.
Brent Reed
You can get stainless, I believe.
Kevin Southwick
Subject: | fuselage construction |
I have cut nearly all the side pieces for my fuselage and am nearly
ready to start gluing. One question I had is: At what point do you
attatch the large plywood sides that cover the front part? Do you
leave it with no gussets while you construct the fuselage box, or do
it while its in the jig (one side anyway)?
Thanks gang!
Richard
BTW, I am consructing a new FAQ (frequently asked questions) from all
the answers to the questions that fly around this group everytime
someone like me has a newbie question. Look for it on my site in a
month or two. Would be sooner, but I'm having too much fun building to
worry about the website right now... :)
I don't know as I never looked into it. I did use light office staples
for a couple of pieces on a trial basis (then removed them). If you are
looking at a power stapler, be careful of the wire guage as some of them
drive pretty aggressive. Trials previous ( not on the Piet project) with
the thinnest guage power staple that I could find gave some tear out on
the back side of the strip. The slow tap,tap,tap associated with the
tack hammer did not cause any splits in over 3000 nails driven. I found
a really nice 3 ounce brass hammer in House of Tools that worked very
well.
Steve,
This doesn't answer your question regarding how to
apply letters but it does have relevance to aircraft
markings from the late '20's.
Edited for brevity:
Air Commerce Regulations, Aeronautics Bulletin # 7,
effective June 1, 1928:
Places and dimensions of marks.
"...the top of the letters to be toward the leading edge,
the height to be at least four-fifths of the mean chord;
provided, however, that in the event four-fifths of the mean chord is more
than 30 inches, the height of
the letters and figures need not be more but shall not
be less than 30 inches.
In the case of a monoplane the mark shall be displayed on the lower
surface of the left wing and
the upper surface of the right wing.
The marks shall also appear on both sides of the rudder, of size as large
as the surface will permit,
leaving a margin of at least two inches.
The width of the letters and figures shall be at least
two-thirds of the height, and the width of the stroke
shall be at least one-sixth of the height.
The letters and numbers must be uniform in shape
and size.
A space equal to at least one-half of the width of a
letter shall be left between each figure or letter."
For reference check out Sky Gypsy. The Pavligas did
their homework and the markings are true to the regs.
in use at the time.
Greg Cardinal
>>> 03/08 12:46 PM >>>
I have got my plane almost ready for spring, but I still want to paint my
wings?
Steve e
Provo
Steve Eldredge
Steve(at)byu.edu
IT Services
Greg,
Thanks for the regs on the numbers. This is the kind of info that makes this
group so valuable.
Best Regards,
Warren
Remember that some people will just complain "just because they could read
your numbers".
It looks that some people just love to complain "for the love of it".
Saludos
Gary Gower
>> big to the wings?
>Ktm
>Steve E.
Well, only if you dont fly inverted in a low pass over the "complainers"
house :-)
Saludos
Gary Gower
Warren,
Thanks for the info.
Mark Boynton
Phoenix, AZ
though,
a
well
steps.
> Warren
Subject: | RE: fuselage construction |
Richard, Build man build.... We can wait for the good work you do on the
website for later. I build my sides with the sheeting before bringing the
two together. I have heard however that others have sheeted after. Even
one I know of sheeted one side only, installed his controls, seatbelts, and
other stuff before closing the other side. Doesn't seem to matter.
Steve E.
Richard DeCosta
Sent: Tuesday, March 09, 1999 5:14 AM
Subject: Pietenpol-List: fuselage construction
Thanks gang!
Richard
Baxter
Maybe I am lucky, I am using Cheap Free Juno and it does not allow
attachmets to come in, that costs money extra.
Gordon
__________
Richard- Steve E. is correct.....tain't no right or wrong
order to installing gussests or side slabs of plywood
to your fuselage.
A worksaver though is to leave your plywood firewall
to the very end of your project. This was the last piece
I glued and nailed to the plane. Fit it up with all of your
engine service controls/lines as you go, but save the
gluing for last. Without that firewall in place you can
install the front controls, rudder pedals, gear fittings,
and make varnishing easier- without wreching your back
or asking for a second person to help.
Now get back to work. :) :)))
Mike C.
Subject: | Re: fuselage construction |
Richard;
While the first side is in the jig, attach the side gussetts or the plywood
siding. Remove that frame from the jig, turn it over then do the same (ply
or gussetts) depending whether it the left or right side. When you get that
far, turn both sides upside down on a table to begin assembling the "box"
portion of the fuselage. I did the front x members/ply then the seat (rear)
then pinched the tail together then went back and filled in the rest of the
stuff. If you try to do the box without all the gussetts on, you will have
some curveature to deal with. Doing it this way lets the sides find their
own "set" at the seat on back to the tail. without the ply/gussetts, you
will get a fuselage with a series of "jogs" in it that will prevent the
nice, smooth curve back to the tail. Just do one side at a time, doesn't
matter if it is left side-inside or right side-outside, just keep track on
what you are doing. I have known of two people that built two very fine LEFT
sides..................
Earl Myers
Date: Tuesday, March 09, 1999 7:16 AM
>Thanks gang!
>Richard
Baxter
here's a trick some dressmakers, sign painters & billboard painters
use...lay out your numbers on brown wrapping paper,,borrow your wives
pattern transfer wheel and go over all lines giving you a perforated
outline,,mask this perforated paper to the wing surface and dust
perforations with bag of chalk line powder,,,remove paper from wing surface
and you have remaining a dotted outline of numbers to be followed by a
steady paint brush. hope this helps...
JoeC
>Greg,
makes this group so valuable.
>Best Regards,
>Warren
Subject: | Richards Piet page |
Hi Guys: Anybody having any luck getting into Richards web page today?
Tried at work & home Can't get in.
John Duprey
Subject: | Re: Richards Piet page |
Sorry folks. I have an al-cheapo server that dies at the drop of a
hat. When I become wealthy I'll upgrade. It should be back up in the AM.
Cheer.
Richard
> John Duprey
Working fine for me just now Richard.
Warren
> Cheer.
> Richard
> > John Duprey
Subject: | Re: misc. questions |
Could anyone offer words of wisdom on these items?
1. Steerable tailwheel versus free swiveling .
2. Al. cladding on the firewall and tray behind engine. Some pictures look
like this is not a universal practice.
3. How to keep axle from turning if you use brakes on the Jenny style gear.
4. A good source for refurbished or new radiators for the Ford powered
Piet.
5. Projects near Kalama, Wa. for possible visitation.
Phil Phillips
I have several ideas about anti-rotation devices for Jenny style gear with
brakes, but I would also like input from those who have done it before. I
acquired a length of 1 1/2 4130 last evening so I guess that decides which
gear style.
How do you get away from the firewall requirement and why would you want
too?
J Mc
Date: Tuesday, March 09, 1999 8:09 PM
Subject: Pietenpol-List: Re: misc. questions
>Piet.
>Thanks
>Phil Phillips
In the Pietenpol Manual published by Don Pietenpol there is a section on
building the Sky Scout. Bernard recommended laying out each side in the
jig, then gluing gussets on that side. Then glue the plywood sides. When
each side is done, take the two sides and clamp them together and saw the
longerons to eactly the same length. Then take a tri-square and mark off
strut stations and a few extra marks to measure alignment accuracy. Next
build and install the front bulkhead and front seat back, being very precise
in the installation. Then install the floor. When that is all done, pull
the tail pieces together and mitre them together. I followed these steps,
and it worked great.
By the way, this manual was very helpful and interesting. Lots of good tips
and history. Well worth the money. It was serial numbered and signed by
Don Pietenpol, and included a color picture of Bernard Pietenpol. I believe
it is available on the pietenpol family website. It will make a good
collector's item when I have finished the plane.
Al Swanson
Fuselage done, ribs done, working on the metal parts.
>Steve E.
>Richard DeCosta
>Subject: fuselage construction
>Thanks gang!
>Richard
>Baxter
Since I'm a low time tailwheel pilot I like my steerable
tailwheel - it helps keep me straight in a cross wind.
> Some pictures look like this is not a universal practice.
You mean no fire shield? In a wood plane I'd like all the
protection I can get. I have one behind my A-65 but I'm not
familiar with the Ford installations.
Just my 0.01 cent worth...
Ktm
From: | "David B. Schober" <dbs(at)fscvax.wvnet.edu> |
Greg,
Do you have a copy of Aero Bulliten 7? I've been trying to find one for some time
without success.
Greg Cardinal wrote:
> Steve,
> Edited for brevity:
> provided, however, that in the event four-fifths of the mean chord is more than
> In the case of a monoplane the mark shall be displayed on the lower surface of
the left wing and
> The marks shall also appear on both sides of the rudder, of size as large as
> and size.
> in use at the time.
> Greg Cardinal
> >>> 03/08 12:46 PM >>>
> Steve e
> Provo
> Steve Eldredge
> Steve(at)byu.edu
> IT Services
David B.Schober, CPE
Instructor, Aviation Maintenance
Fairmont State College
National Aerospace Education Center
Rt. 3 Box 13
Bridgeport, WV 26330-9503
(304) 842-8300
From: | Greg Cardinal <gcardinal(at)startribune.com> |
Dave,
I don't have a copy of the entire bulletin. I found parts
of it printed in the back of an old textbook. The book
is "Dyke's Aircraft Engine Instructor". This book was
published in the 30's. Good luck finding it.
If I were trying to find copies of the Air Commerce
Regulations the first place I'd check would be the
Library of Congress, next would be the Smithsonian, also, don't overlook
local libraries, especially large
university libraries. Some libraries are designated
Federal Depositories and are required to store govt.
printed materials FOREVER!!! The internet is a
great place to start.
Back to the query about letters, a Pietenpol should
have the lettering on the topside of the right wing, the
bottom side of the left wing. Letters should be 30"
high and 20" wide. The brush stroke should be 5" with
2.5" between figures.
Good luck in your search, keep us posted.
Greg Cardinal
>>> "David B. Schober" 03/10 10:25 AM >>>
Greg,
some time without success.
> Steve,
> Edited for brevity:
more than 30 inches, the height of
large as the surface will permit,
> and size.
> in use at the time.
> Greg Cardinal
> >>> 03/08 12:46 PM >>>
my
any
wings?
> Steve e
> Provo
> Steve Eldredge
> Steve(at)byu.edu
> IT Services
Rt. 3 Box 13
(304) 842-8300
Subject: | An 'A' I'm looking at |
Could I get anyone on the list who has the time & knowledge to take a
look at these pics of an 'A' engine I am looking at buying?
http://207.140.1.5/99/ModelAEnginePic1.jpg
http://207.140.1.5/99/ModelAEnginePic2.jpg
http://207.140.1.5/99/ModelAEnginePic3.jpg
The guy opened it for me and says there are no cracks to be found, and
very little wear on all parts. I am not an expert, so I could use a
second opinion.
Also, is $350 a good price fo this engine?
Richard
Subject: | cont. 65 ground power unit |
Hello,
I would like to ask if anyone has had experience using the continental 65
from a WWII surplus ground pwer unit. We found a vey affordable one and all
looks very good. I have head the front bearing might not be the same as on an
aircraft.
Any input would be appreciated.
Thank you
Mike Johnston
Plainview mn
Subject: | Re: cont. 65 ground power unit |
I have never seen one but I have heard that the Continental GPU's had a cast
iron crankshaft.
If the engine is assembled, there is probably no way to tell by visual
inspection.
There is no reason why a cast iron crank can't be used, its just not going to
be quite as strong as a forged steel one.
Good luck,
Bob Seibert
Thanks Bob,
We have the case apart and everything mics out to within factory specs. One
question I do have is about the front bearing. And I have a few mechanics I
can ask about the cast crankshaft.
Thanks again
Subject: | Re: glues, epoxies. |
I have been using T 88 for the fuselage. For a different project have also
tried
"West System Epoxy" made for the wood boat building industries by the
Gougeon Bros. Their website (www.westsystem.com) has a list of projects that
used their epoxies. It includes numerous aircraft. I left the stir sticks
(pine
scraps) in the plastic mixing cups and kept the batch cups and sticks as
proof
of cure. the stuff is amazing and in no case was I able to break the bond
between the wood and epoxy. I'm considering switching to the West system
when my T 88 runs out.
John Mc
I am building my plane using the gougeon epoxy. I have used their epoxy for
years. I built an ice boat, restored a wooden sailboat and I am now building
my plane with it. It is good stuff. Be careful of exposure as many users
develope
I have used the west Epoxy on Boat building projects, and am impressed . It
does a great job & is easy to work with. It is pricey but good. I am
currently using T-88 and might consider switching. I will check out the web
site.
John Duprey
also
> tried
that
sticks
> (pine
> proof
> John Mc
for
building
users
> develope
I have designed a baseball type hat that has a Piet logo on it and I
am
wondering if anyone would be interested in some for themselves.=A0 I
am trying
to make this years trip back to Brodhead and Oshkosh a memorable one
and
also champion our cause.=A0 The hat will natural kakhi with dark fore=
st green
embroidery.=A0 If I can get enough interest I'll get a group discount=
and have
them done in a lot for $14-15 each.=A0 These are high quality hats.=
=A0 Check out
my web site for the graphic.=A0 for another $2 they will add text acr=
oss the
back that says "Low and Slow for 70 Years"=A0 So if your interested l=
et me
know how many.
=A0
=A0
Steve Eldredge
Steve(at)byu.edu
IT Services
=A0
The only problem I have with West System Epoxies is that it is quite thin.
This makes it kid of poor for gap filling and gussets around the edges of
the glue joints. However, this also allows it to soak into the wood quite
a bit making for these inredibly strong joints. It's mainly an astetic
thing. It looks like there is insuffecient around the edges of the joint
despite the fact it's strong enough.
Ken
> tried
> (pine
> proof
> John Mc
> develope
Let me know how it works out...would be great to cover my bald spot with a
Piet!
Ed
Steve,
The hat looks great! Put me down for three of them....no I don't have three
heads, but I'll give the extras to friends.
See you at Broadhead.
Don Cooley, Ercoupe N3571H, Piet a-buildin'. Fairfield, CA
> am wondering if anyone would be interested in some for themselves. I
> am trying to make this years trip back to Brodhead and Oshkosh a
> memorable one and also champion our cause. The hat will natural kakhi
> with dark forest green embroidery. If I can get enough interest I'll
> get a group discount and have them done in a lot for $14-15 each.
> These are high quality hats. Check out my web site for the graphic.
> for another $2 they will add text across the back that says "Low and
> Slow for 70 Years" So if your interested let me know how many.
> Steve Eldredge
> Steve(at)byu.edu
> IT Services
Steve look great to me, save me one, I like the low and slow on the back
idea!
John Duprey
Ken, try mixing in a bit of fberglass chop, you can make the mix any
consistency you want up to peanut butter. the bost guys stick plywood
together at ninety degrees. They mask the glue area off with masking tape
lay on a good bead of the mix and fillet it out with a tongue depressor.
The excess is scrapped off. The joints I have made this way always break in
the plysheet and not in the epoxy bond.
J Mc
-----Original Message-----
Date: Thursday, March 11, 1999 11:29 AM
Subject: Pietenpol-List: Re: glues, epoxies.
>Ken
also
>> tried
that
sticks
>> (pine
>> proof
bond
>> John Mc
for
building
users
>> develope
From: | Wayne and Kathy <ktokarz(at)incentre.net> |
> John Duprey
John I don't know how the computers at your work got fried but it could
not have been "Happy99" as this virus only copys your wsock32.dll file
to a file called wsock32.ska and attachs itself to your out going mail.
this virus doesnot cause any other damage to your computer except to the
aformentioned file.It' sole pupose is to plug up servers by virtue of
high volume mail.If you have not opened it simply delete it. If you have
opened it, go to
http://www.zdnet.com/zdnn/stories/news/0,4586,2208275,00.html
print out the sheets and follow the instructions there clear and easy.
Wyne Tokarz
> big to the wings?
> Steve e
> Provo
> Steve Eldredge
> Steve(at)byu.edu
> IT Services
Hi Steve, I can help you in one of two ways;
1: I can provide you with custom made vinyl numbers in virtually any
color you want or,
2: I can supply you with vinyl paint masks, you simply stick them on the
wing and paint away. Peel them off and perfect numbers with no
bleed-under.
Call me at 780-594-0418 , email at ktokarz(at)incenre.net or here at the
piet group.
Wayne Tokarz
Steve,
I'm new to the list. Hiding in the background trying to learn all I can
about the Piets.
Even tho I'm not building yet I'd like to go for a hat. Maybe get me
motivated if I look in the mirror and see an airplane there! I'd also like
to look at the web site you mentioned but I don't have the URL. Mind
posting that?
Thanks much and am enjoying the discussions so far.
Les Lampman
Oak Harbor, Whidbey Island, WA
steve(at)byu.edu
Sent: Thursday, March 11, 1999 9:13 AM
Subject: Piet hats.
I have designed a baseball type hat that has a Piet logo on it and I am
wondering if anyone would be interested in some for themselves. I am trying
to make this years trip back to Brodhead and Oshkosh a memorable one and
also champion our cause. The hat will natural kakhi with dark forest green
embroidery. If I can get enough interest I'll get a group discount and have
them done in a lot for $14-15 each. These are high quality hats. Check out
my web site for the graphic. for another $2 they will add text across the
back that says "Low and Slow for 70 Years" So if your interested let me
know how many.
Steve Eldredge
Steve(at)byu.edu
IT Services
Hi,
Want to sign me up for a hat too?
TWO FOR EARL & KATHI MYERS !
Date: Thursday, March 11, 1999 7:58 PM
Subject: Pietenpol-List: Re: Piet hats.
>> Steve Eldredge
>> Steve(at)byu.edu
>> IT Services
>idea!
>John Duprey
Two new videos on my site:
http://207.140.1.221/w3builder/piet/Videos.shtml
These were captured from Mike Cuy's Piet Construction video. For those
of you who are serious about Piets, this video is well worth the $20!
I have only 2 clips from it on my site right now, but there are many
more to come; the tape is nearly two full hours. Everything from
Flying with Mike, to construction shots, to a full walkaround of his
ship, etc...
Enough of my feverish ranting. Enjoy the videos.
Richard
Now you can buy my CD at MP3.com:
http://db.mp3.com/Visitor/order.php3?cd_id=968
"Instrument flying is an unnatural act probably punishable by God." -Gordon Baxter
Subject: | Re: An 'A' I'm looking at |
Richard;
I have 3 Piet (ford) engines. I paid $200-$400 each for them. They were
nowhere near the APPEARENCE of the one depicted below. None of these had any
of the accessories either. If this engine at least turns over by hand (mine
did) and there are no visible cracks cyl to cyl or exhaust valve to cyl that
you can see, i would take it if it were me. You still are taking a chance on
the thing being rebuildable. None of mine had the accessories nor heads. You
could sell all those extras at a swap meet and at LEAST break even.Go for it
and hold your breath a bit........the engine I used in my Piet (yet to be
converted) cost $1,000. It was recently rebuilt with 5oo miles on it for
break-in then removed from the car and replaced with the original
engine.This had only the head and complete block. I had to buy all the
extras (carb, intake, alum head, H2o pump on so on. I bought a racing Model
T H2o pump by the way...long thin tube with impellors mounted down low. I
also bought a new, stainless, lifetime stock pump as a back up. All my "A"
parts came from Snyder's here in Ohio, good company to deal
with....knowledgeable and they do speak "Piet" as the manager is building
one.
Earl
Date: Wednesday, March 10, 1999 6:04 PM
Subject: Pietenpol-List: An 'A' I'm looking at
>second opinion.
>Richard
Baxter
I suppose then, that if I found one for $300 that is RUNNING now... (I
did find one like that!). I should grab it? The only prob is its in
California and Im in Maine, making shipping almost $300 as well.
Unless I can find a REAL cheap way to get it here.
---Earl Myers wrote:
> Richard;
were
had any
hand (mine
cyl that
chance on
heads. You
even.Go for it
to be
for
racing Model
low. I
my "A"
building
> one.
> Earl
> From: Richard DeCosta
> Subject: An 'A' I'm looking at
and
> >second opinion.
> >Richard
-Gordon
> Baxter
Hi SteveE===sounds like a plan to me,,,put me down for 3 caps...since I
passed that 60 plus barrier last year the "LO N SLO" is looking good to
me.
regards
JoeC
Zion, Ill
> Slow for 70 Years" So if your interested let me know how many. Steve
> EldredgeSteve(at)byu.eduIT ServicesBrigham Young University
me.
regards
JoeC
Zion, Ill
I
have designed a baseball type hat that has a Piet logo on it and I am wondering
green embroidery. If I can get enough interest I'll get a group discount
and have them done in a lot for $14-15 each. These are high quality
hats. Check out my web site for the graphic. for another $2
they will add text across the back that says "Low and Slow for 70 Years"
So if your interested let me know how many.Steve
Ken;
What didn't you like about T-88?
Earl Myers
Date: Thursday, March 11, 1999 1:39 PM
>Ken
also
>> tried
that
sticks
>> (pine
>> proof
bond
>> John Mc
for
building
users
>> develope
Actually, I have used both cotton flox and micro baloons as a thickening
agent. The micro baloons make a nice, sandable filler and the flox is
used where I need more strength. I learned all this when building the
fiberglass fuel tanks. Unfortunately, adding this decreases the simplicity
of the West System epoxies and maked the T-88 more attractive. For
structural joints, I think it's a better product as it will nicely gap
small inperfections in the wood without compromising the glue strength
with a filler material.
However, for laminating, large surfaces, West System is the better choice.
Ken
> J Mc
> From: Ken Beanlands <kbeanlan(at)spots.ab.ca>
> Subject: Re: glues, epoxies.
> >Ken
> also
> >> tried
> that
> sticks
> >> (pine
> >> proof
> bond
> >> John Mc
> for
> building
> users
> >> develope
Is this the same engine as in the photos (afetr it was removed)? One that is
running is much better that one that isn't assuming all else is OK.......You
might want to look into the CA engine. If it "sounds" good, swallow the
freight and go for it. It is a better place to start I guess. The blocks I
mentioned were found outside behind garages.............still don't know if
they can be rebuilt but the extra parts paid for the cost of buying them
(clutches, bellhousings, etc)
Date: Friday, March 12, 1999 10:39 AM
Subject: Pietenpol-List: Re: An 'A' I'm looking at
>> Richard;
>were
>had any
>hand (mine
>cyl that
>chance on
>heads. You
>even.Go for it
>to be
>for
>racing Model
>low. I
>my "A"
>building
>> one.
>> Earl
>and
>> >second opinion.
>> >Richard
>-Gordon
>> Baxter
Baxter
You might try Amsterdam for a supplier on your hats.
1-800-833-6231
They send me catalogs all the time for Promotional stuff.
Embroidered hats
5.99 ea. for 24
24 Hats 143.76 + 50.00 = 193.76 / 24 hats = 8.07 each
One time Embroidered Charge is 50.00 but no charge on repeat orders.
Free on 144 units.
Printed hats are 2.99 each with a one time screen charge of 35.00
They also have all that other stuff, Cups, shirts, pencils, pens etc.
Gordon
__________
Nothing, really. The West System with the pump system is just really
convenient to mix. One pump of resign and one of hardener and you're all
set. I still use T-88 for structural joints. The reason I tested the West
System stuff for it's adhesive properties is because I still have a gallon
kit in the basement left over from the canoe I built last winter and I had
run out of T-88.
Ken.
On Fri, 12 Mar 1999, Earl Myers wrote:
> Ken;
> Earl Myers
> >Ken
Gordon, thanks for the lead! I called them and did an apples to apples
comparison and here is what I found.
there 5.99 special is a cheaper cotton cap with one color >7000 stiches plus
a $25 digitizing fee for the art work. Not to bad for a cheap cap
I asked them to quote my what I wanted and it was almost $17 per cap with a
minimum order of 48. UGGH. I want these to be first class caps.
They are sending their catalog anyway though.
Steve e
Well it was an idea anyway. They have a rather large catalog I keep
getting once a year even though I told them three yrs ago I am not in
business anymore. Still have a few hundred pencils and pens but heck they
send me free pens and calanders every year trying to get me to reorder.
Your right, Only the best for the Piet Builders and Flyers.
Gordon
>stiches plus
>with a
>Steve e
__________
How do I order this video??
Thanks, Glenn
Richard,
Is there not supposed to be any sound on those videos you just added?
Brent Reed
Date: Friday, March 12, 1999 12:01 PM
Subject: Pietenpol-List: Re: new videos
>Thanks, Glenn
From: | Dave and Connie <dmatt(at)frontiernet.net> |
Ken,
Gee, thats odd. I have a gallon or so of Raka epoxy left over
from my canoe and was wondering about using it. I used silica
as a filler when I needed a little more thickness on the canoe
(16' Prospector from Canoecraft).
I didn't trust the pumps for measuring. Every bit that went
on the boat was measured in plastic measuring cups.
Where is the cheapest place to buy some T88?
My check to Western Aircraft will go out on Monday or Tuesday.
I am going to get all of the spruce in one shot - $1578 US +
shipping.
Jean warned me about using US made birch plywood and advised
either Finland birch or mahogany. What are the general thoughts
on this? Where is the best place to buy from?
Dave
Soon to be building....
>run out of T-88.
>Ken.
From: | The Endicotts <rasala(at)brutus.bright.net> |
> Steve Eldredge
> Steve(at)byu.edu
> IT Services
Please put me down for one.
thanks, Larry
Right, there is no sound. I decided not to put sound on some to save
download time (it almost doubles the size of files!)
Richard
---Brent Reed wrote:
> Richard,
> Brent Reed
> From: Glenn Burroughs <glenn(at)sysweb.com>
> Subject: Re: new videos
those
$20!
> >Thanks, Glenn
Richard,
Can you find someone who can measure the cylinders of the one you have
photo's of? Bore size will tell you if it can be rebored again. I wouldn't
advise reusing the pistons as the ring lands will likely be worn. If you can
turn it over and have a dial indicator resting on the valves you can get a
very good idea of the camshafts wear. (I have the specs buried on my desk
somewhere) For now just see that all the ex valves have the same lift and
that all the intakes are the same as well. Valve clearance will change this
a bit, you can measure it and add it to be more accurate. The camshaft is
the key to a good performing model A as breathing is their weakness. The
condition of the crank and babbit is not really relevant, nor is the bore,
other than if it already bored out too far.
The "Short block" is really all you are looking for. I would suggest that
you grab the one you have close by and try to sell off all the stuff you
don't need.
I wouldn't feel safe just buying an engine of that age putting on the
aluminum head and doing the other conversions without doing a thourough
rebuild.The fibre cam gears are prone to failure and the babbit job may be
questionable even on the running engine.
The rebuild to like new on a model A will still be cheaper than the same
work done on an aircraft engine.
Save the cross continent frieght and put the funds into good quality new
parts.
Check out the BPA website there are a few good pic's of engines and some
even using small block "chevy" pistons.
John Mc
Date: Friday, March 12, 1999 8:40 AM
I will take a hat as well.. Doug.
> From: The Endicotts <rasala(at)brutus.bright.net>
> Subject: Re: Piet hats.
> Date: Friday, March 12, 1999 3:52 PM
> > Steve Eldredge
> > Steve(at)byu.edu
> > IT Services
> thanks, Larry
Subject: | Finland Birch Plywood |
These guys are close to me and have a huge warehouse of wonderful
stuff. I got some of the most beautiful finland birch plywood you can
imagine here.
Go to http://www.aitwood.com
and check out both the Finland Birch Plywood and the Ultrathin
sections. Also got some of their Australian Hoop Pine for the leading
edges. Until you handle this stuff, it is hard to believe how flexible
it is. Good luck
Warren
> > Richard;
> were
> had any
> hand (mine
> cyl that
> chance on
> heads. You
> even.Go for it
> to be
> for
> racing Model
> low. I
> my "A"
> building
> > one.
> > Earl
> and
> > >second opinion.
> > >Richard
> -Gordon
> > Baxter
There is one way. It's called the backhaul. Call some private trucking
company and find out if they are hauling to california and coming back
empty or lightly loaded. Often they will help you for $50 or some liquid
barter.
Wayne Tokarz
Steve,
I'd like a Pietenpol hat, too. When you have a price, I'll send
a money order to cover cost and shipping.
Graham Hansen (Pietenpol CF-AUN)
Steve,
you have a
price, I'll send
shipping.
CF-AUN)
Steve
Can you post the URL for your site again, My bookmarks were
reset (vast low wing conspiracy) and I do not have your
locale.
Subject: | Re: An 'A' engine |
Warren;
You seem smarter than the average bear, Are the internals
much different on an "A" engine compared to an "8N" tractor
motor? I have read there are almost interchangeable and the
tractor motor is sleeved so it can be rebuilt more often.
They definitely seem to have the same DNA
Bill,
I think you are on the right track here. From my reading, these 8N
tractor engines are still supporting most of the rural farm equipment in
Russian, where Henry built a complete plant in the 20's. Also, so many
were built here, that between the tractor and the "A", there really are
a bunch of useable engines around, IF, you contact the local "A" club.
The performance of this engine seems to be seriously improved if the
head is carefully worked over, with the major mind set that any engine
is really an air pump, so get it to breath in and out in a balanced
fashion and you have a winner. Grant's BPA webpage has a great review
on various head and carb modifications. However, you quickly upset the
traditionalists when you port and polish, put in decent valves and small
block chevy pistons and match the cfm to a good carb....of course you
then turn a 40 hp air pump into an 70-85 hp air pump...at the same rpm.
What my progressive research led me personally to, was that what I was
looking to "improve" had already been done. Take a close look at the
original Jeep engine and the 151 Chevy engine. By the time you do the
head, valves, pistons, real bearings and match the CFM to a good carb
for air flow balance, you have a great modern and efficient engine and
your pocket book is quite a bit lighter. I ended up choosing a sleeved
all aluminum Geo Metro 4 cylinder on the long fuselage variation. For
me, this really is an progressive educational experience. The Piet is
my first "real" plane project, and I intend to build at least one more
plane, so I am looking at a wide variety of applications to learn on the
Piet. It is such a stout, basic, traditional and lovely old bird.
Buttered popcorn or plain sir, and enjoy the movie!
Best Regards,
Warren
Bill Talbert wrote:
> Warren;
Warren
The 8N motor is way to heavy for flight, what I was thinking
is using the "A" block bored for sleeves and bushings and
getting away from the babbit. As far as the purists, I bet
they are not using vintage gas or plugs, so where do you
draw the line?. My hope is to do as you suggest, get more
power from the ford.
thanks for the quick response
Bill,
With good machine shop work, I think that you will have a great
power plant. Bored, balanced, polished and flow matched, with today's
fuel and ignition, you should see 70 hp without any stress or strain. I
have seen one that dynoed out at 106 hp at 2250 rpm! The actual
compression of the old "A" was often only 4 or 5 to one so that it could
run on the fuels of the day. If you build in even a 7 or 8 to one and
maintain it on a leak down test, you will do very well. You may want to
consider some type of bolt on harmonic balancer, and these old beauties
will run forever, and their sound is just good for the soul! Good
luck.
Warren
Bill Talbert wrote:
> Warren
> Bill
Bill,
You might find it interesting to check with these guys. They are
not cheap, but they make some of the prettiest brass radiators in the
world for the old car guys.
The Brassworks: handcrafted radiators
289 Prado Road, San Luis Obispo, Ca. 1-800-342-6759
Warren
Subject: | Re: An "A" engine |
Sir;
This is where I got my radiator done for my Piet Scout. The workmanship is
second to none! They do know what they are doing. The brass had NO heat
warpage or heat discoloration. My radiator was custom built with an internal
overflow tube, painted black on the (modern, effiecient) fins and is 11"
wide, 5" thick. I had them supply the moto-meter, drain cock, etc., "ready
to run" so to speak.....with shipping, it cost just under a (ouch)
$1,000........
I did this because of all the brass on it. I wanted it to be "flawless"
(wish my Scout was). This radiator will take your breath away as far as
radiators go, so will the cost. I looked at several $250-500 typical
radiators............yuck on the final appearence (to me). There is a Piet
builder locally that has an extra (new) inexpensive radiator. I can check to
see if he still has it. It is the fella with the Funk "B" engine and wood
struts.........
Date: Saturday, March 13, 1999 1:46 PM
Subject: Pietenpol-List: An "A" engine
>Bill,
>Warren
Hey, All!
Speaking of wood struts...does anyone know about Wilbur Graff's (sp?) struts?
I saw his plane at Brodhead in 1996, and was very taken with the idea of
wooden lift struts. Curious about weight and strength. I hope to see his
plane, and him, at B'head '99, but thought I'd ask, anyway. Thanx for any
info.
Don Cooley
Earl,
Flawless is the word for the work that I have seen from them. Went up to
their shop and everything that they put out is made to exacting standards by
real craftsmen. Thought their prices were painful too, but boy are these things
beautiful and they are made hell for stout and for real world use.
Congratulations.
Warren
Earl Myers wrote:
> Sir;
> $1,000........
> struts.........
> From: Warren Shoun <wbnb(at)earthlink.net>
> Subject: An "A" engine
> >Bill,
> >Warren
Grant has a page with a cross section of this wooden strut on the BPA
webpage. Am presently playing with something similar with a fiberglass wrap and
wetted out clear so the wood shows and same for the wood landing gear. There was
going to be some follow-up information on this at some time from Grant. Maybe
this discussion will bring it forth?
Warren
ADonJr(at)aol.com wrote:
> Hey, All!
> info.
> Don Cooley
I have seen Wilburs aircraft and have thought about the wood struts ever
since. Has anyone used wood pieces 1/2 airfoil shaped clamped to a steel
strap running the length of the strut? The wood would hold the strap
straight and carry the compressive loads and the steel strap in tension
would be very strong.
In regards to A's and 8Ns. The A has a larger displacement and is much
lighter.
I sawed a scrap A block through the ports to see how much the ports could
be opened up. I will photo the parts and scan them in if anyone is
interested. Breathing on an A is the most efficent way to more horsepower
provided the engine is properly rebuilt. Sleeving an A block is possible
only as a dry repair sleeve. If you look carefuly at the lefthand side you
can see the cylinders below the water jacket. Wet sleeves are out.
John Mc
Date: Saturday, March 13, 1999 12:19 PM
Subject: Pietenpol-List: Re: An "A" engine
>Hey, All!
struts?
>info.
>Don Cooley
Gary Price at Yesterdays Wings has used a wood encased square tube strut.
Richard's webpage has some pictures of the finished plane, but not the detail.
Looks pretty good, and sound too.
Good to hear from someone who has opened up the "A" to see what is there.
Thanks also for the info on the 8N as I have never taken the time to do a close
comparison.
Warren
> lighter.
> John Mc
> From: ADonJr(at)aol.com
> Subject: Re: An "A" engine
> >Hey, All!
> struts?
> >info.
> >Don Cooley
Warren Is right Gary's wood coverd steel struts are strong and very good
looking. I plan to go have another look at Gary's piet within a month or
so, I will post a detail photo after that.
John Duprey
Warren Shoun wrote:
> John
> comparison.
> Warren
> > lighter.
> > John Mc
> > >Hey, All!
> > struts?
> > >info.
> > >Don Cooley
From: | Joe & Marian Beck <flyretina(at)feist.com> |
Steve:
Please put me down for 3 Piet caps. Thanks!
CJ Beck
Subject: | A word of caution about engines in general |
Folks,
Maybe I read it wrong, but I thought I saw a message from someone interested
in buying a running "A" engine. Please be aware that something like this may
indeed be running, but you don't really know how good the engine is until
you check it out with measuring tools. Even then you may not know, unless
you are really engine-knowledgeable and plan to look at the overhaul parts
list and machine-shop receipts that the seller SHOULD be able to supply you
with.
Obviously, you can decide (or not) to trust that what the guy tells you
about it is true, but please be careful of buying a running "A" engine and
just bolting it to your Piet. Something this old has probably been
overhauled many times, but how good was the last one? Remember that our
parents' generation were young and working in the factories when these
engines were originally made.
Just my cautious two-cents worth. The "A" is a fine engine, but there's no
substitute for close, knowledgeable scrutiny, when it comes to flying
airplanes or spending money!
Subject: | Re: A word of caution about engines in general |
No doubt! I was the one looking at the running engine. I have no
intention of just bolting it to my Piet. :) Can't imagine! I am going
to totally rebuild ANY engine I get. I just figured one that is
running is bound to be a better candidate for rebuld than one that is
not. I am going to pop the head off and take my measurements of the
engine I buy, for sure.
Thanks for the advice tho.
Richard
A very careful, bordering on paranoid, builder.
---Michael Hinchman wrote:
> Folks,
interested
this may
until
unless
parts
supply you
> with.
you
engine and
our
there's no
> Mike
http://www.wrld.com/w3builder
Steve, I being one of the more silent people of the group I was
fortunate to have just deleted the file- happy 99 before opening it. I
was just sent the same file with no message by someone who had to have
gone to my web site because of the subject that they used for the
e-mail. Before deleting the file I wrote down the persons e-mail
address and time sent. My question is there anything that can or should
be done to stop this kind of practice.
phil
Check out Crusader Toys @
http://www.Crusadertoys.com
Will Graff is the guy I was speaking about! He is supposed to be at B99. I
think his struts are 4 pieces with a metal cable or something running down
the middle. His Piet a/c with the Funk B really scoots!
Earl
Date: Saturday, March 13, 1999 2:19 PM
>Hey, All!
struts?
>info.
>Don Cooley
Subscribe
Subscribe
Does anyone know how to get a hold of Gary Price? I would sure like to
hear what he did with the square tubing etc.
Ian,
Go to
http://users.aol.com/BPANews/events.html
which has his address and phone number, and hooks you up with Grant's
pages of tons of fun and useful Piet "stuff".
Warren
Hi Steve!
Please but us down for 2 hats! "Low & Slow" on the back is perfect!
Mike Conkling
Pretty Prairie, KS
Hi Steve,
Not sure if my first message made it through. New to the mailing list.
I'd like to sign up for a hat, low & Slow on the back sounds good.
Les Lampman
I got a message from Walt Evans but lost the reply address. Anyway,
Walt, send me any and all pics of your progress. I will post them on
my site.
Anyone else wanting a visual record of your building progress online,
send 'em on over! Only two rules:
1. Email images to rdecosta(at)wrld.com NOT THIS YAHOO ADDRESS! Yahoo
will spit them out!
2. Make all your filenames in this format:
for example: RDeCosta-Ribs1.jpg or WEvans-Fuselage3.jpg
That way I wont get your pics mixed up.
Very shortly I am going to install ColdFusion on my server, and at
that point I will have the ability to handle automatic uploads of your
pics, as well as your profile, descriptions of each pic with dates,
etc... Look for it in a few months. For now Email will do.
I have decided to get a domain name with the contribution $$ coming in
(got $6 so far, thanks guys!). As soon as I get enough ($70), I am
going to reserve AirCamper.org (once I clear it with Mr.Pietenpol,
that is). Once that and ColdFusion are in place, you will all be able
to remotely upload and administer your projects progress online via
www.AirCamper.org/
Richard
p.s. not that its terribly important, but I have picked a name for my
plane (it needs one, doesnt it?): "The Scarborough Flyer" (I live in
Scarborough, ME).
Sure, If they are a member of this list I'll remove them it was
intentional, Additionally, I have found that the host service provider
frowns at this kind of activity and if supplied with the details will take
appropriate action. I have seen this terminate more than one person's
access to the net.
Steve e.
Phil Peck
Sent: Saturday, March 13, 1999 7:38 PM
Subject: Pietenpol-List: what to do
phil
Steve,
I doubt seriously that the Happy99 attachment was sent intentionally.
Happy99 redefines a couple of files on the target computer and then proceeds
to attach itself, unknowingly, to the outgoing email from that machine. The
person sending the email doesn't even know there's an attachment going
along. The attachment is small enough that most users wouldn't catch the
extra bit of time it takes to send that email, especially not if sent with
other items.
I had to rid my computer of the beast after my wife received an email from a
women's mailing list she belongs to. The email was from someone she
regularly corresponds with. There could be one along with this email but I
checked my files minutes ago and the buggers not there. If there is an
attachment with this email is NOT supposed to be there.
Les Lampman
steve(at)byu.edu
Sent: Monday, March 15, 1999 8:25 AM
Subject: Pietenpol-List: RE: what to do
access to the net.
Steve e.
Phil Peck
phil
I fully agree with Richard. I bought a "running" C-85-12F from a guy in
Florida. It had been living on the stern of an airboat and was indeed
running. I figured that it was worth the $1000 USD he was asking for it.
The engine arrived and I finally decided to tear it down. Boy, am I glad I
did. The crank had started out it's last life as a 0.020" under but was
now 0.030"-0.035" under! The jugs were completely shot as were the mags.
Sure, it was running, on 3 cylinders and one mag! It's now in the shop
being rebuilt. Was it a good deal? Sure, I still ended up with enough good
parts to have it rebuilt for less than I could have purchased a used
engine for.
Ken
> Richard
> > Folks,
> interested
> this may
> until
> unless
> parts
> supply you
> > with.
> you
> engine and
> our
> there's no
> > Mike
Agreed. It has been propagated around the university in great numbers. We
have 30K students and they all have email. UGH.
Stevee
Lampman
Sent: Monday, March 15, 1999 9:43 AM
Steve,
other items.
Les Lampman
steve(at)byu.edu
access to the net.
Steve e.
Phil Peck
phil
February 07, 1999 - March 15, 1999
Pietenpol-Archive.digest.vol-ao
