Pietenpol-Archive.digest.vol-as
April 30, 1999 - May 18, 1999
Thanks Mike.
Thats quite a compliment comming from you , after following your
building process through pics on the web
walt
-----Original Message-----
To: Pietenpol Discussion
Date: Friday, April 30, 1999 10:50 AM
Subject: Walt Evans Work
Its not linked up yet, (wll be tomorrow) so heres the address
for
Walt's pics: http://www.aircamper.org/users/wevans/
Walt- Your workmanship looks just great from the photos you have on
Richard's Piet site. I love the wheels !! Keep pluggin away !
Mike C.
From: | walter evans <wbeevans(at)worldnet.att.net> |
Subject: | Re: put some pics on Richard DeCosta's Piet site |
Ken,
pics look great. It looks like you're cramped for space like me.
walt
Date: Friday, April 30, 1999 4:45 PM
Subject: Pietenpol-List: Re: put some pics on Richard DeCosta's Piet site
>http://www.aircamper.org/users/Khannan/pietenpol/
>please check out my pietenpol project
>Thanks Ken
Hi Steve!
Good job on the hats!! -- finally got mine today! We must have a slow
horse on our leg of the Postal system!!
Re: the recumbent bike bussiness-- I guess it's just another case of a
bicycle mechanic trying to build a flying machine!!! ;-)
Mike C.
PP, KS
Subject: | Re: Adjustable lift strut attachments |
These are called 1A, 2A & 3A fits......
Date: Friday, April 30, 1999 12:11 PM
Subject: Pietenpol-List: Re: Adjustable lift strut attachments
>via Mercury MTS v1.44 (NDS))
>Message-ID: <14E0DAB53FC(at)adena.byu.edu>
>Ken,
> You can use a standard one.
> When I was buying my taps, I chatted with an old guy at King Bolt near
where I
>live and learned a bit about tap and die. Some are manufactured to closer
>matching fit than others, so you may want to dress up both your lug and
your
>fork. Just check carefully that it doesn't remove too much material.
>Warren
>Ken Beanlands wrote:
>> I'm quite sure that this is correct and it does make perfect sense in
>> hindsight. I'm just a little annoyed with myself for not figuring it out
>> sooner. At the very least, I could have lucked into it by waiting to tap
>> after I welded. DOUUUUGGGHHH!
>> Just to clarify, is a special, close tolerence tap required to finish the
>> tapping, or is that what they use for the initial tap? In other words, do
>> I have to buy another tap or can I use a standerd one?
>> Thanks,
>> Ken
>> On Thu, 29 Apr 1999, walter evans wrote:
>> > Ken,
>> > Just remember that what my AP told me comes from a guy who is a
licenced AP
>> > who's been doing this alot of years, and he tends to be a perfectionist
to
>> > detail and safety. Who can say what percentage of safety factor is
figured
>> > into the certified aircraft.
>> > I just wanted to pass along something I learned , that I didn't know
6 mo.
>> > ago. You should check with some AP's that you can find, and get their
>> > input.
>> > It's a strange building technique , but kinda makes sense when you
think
>> > about it.
>> > walt
steve(at)byu.edu wrote:
> The hats are done and look great I have 3 left of the $18 version (low and
> slow on the back) if you are still interested. Add $2 shipping per order
> Best Regards,
> Steve Eldredge
Hey Steve!
Received our hats yesterday and they really are nice! Great job! And
they fit the whole family, from 3 to 30 something.
See you at Brodhead!
Mike List
I have several sets of airplane plans at home, and one set for the Smith
Miniplane uses...(to attach the top wing to the lower wing) an
An46-26 eyebolt in the lower rear wing mount, and a 3/8 cut thread homemade
nut, pinned, and welded into the wing strut.
I have been looking into this system for my ace, except that the cut thread
nut, would be replaced by a formed thread coupling nut, welded into the wing
strut. Then to avoid the welding scale, I would either use white lead, or
just scerw a beez wax coated bolt into the coupling nut and weld the nut
fast into the strut.
The bolt to plug the thread hole, and the bezz wax to produce a smoke gas
schield to keep oxygen away from the weld.
About the an4626 bolt, wicks catalog says that this bolt is strong to
125000psi, and it costs only 14.00 or so each.
ocb
>From: Ian Holland
>Reply-To: Pietenpol Discussion
>Subject: Adjustable lift strut attachments
>Date: Wed, 28 Apr 1999 10:49:48 -0700
>The machine is on the gear and I have been following the discussion on
>the 3/4 X 2 1/2 inch lift strut with great interest. Along these lines,
>I am wanting to install adjustable fittings on each strut to allow
>dihedral adjustment and wash out adjustment (also to make flight tuning
>easier).
>The question is " what are folks using to do this?" I look at the
>catelogues and see prices starting at $100 per attachment. With the
>scrounging, experimental expertise out there in the Piet community,
>someone must have a better way. Care to share it?
>On the gear with the centre wing section and wires on, the machine is
>starting to look impressive. I also am in the process of tearing apart a
>Corvair motor, 1997 vintage.
>Best regards,
>-=Ian=-
pls delete me from this discussion group.
THANKS......
May see you guys there after all.
Mike King
GN-1
Dallas
>OSH is July 28-Aug 3
>Brodhead is July 30-31
>for the full scoop see http://members.aol.com/bpanews/count.html
>Steve Eldredge
>IT Services
>Brigham Young University
>> Michael King
>> Sent: Thursday, April 29, 1999 12:58 PM
>> Subject: DATES
>> Hey Gang,
>> What are the dates for OSHKOSH and
>> BRODHEAD? May try to make one or
>> both of them.
>> Thanks in advance.
>> Mike King
>> GN-1
>> Dallas
Group:
I have never been to Brodhead but would like to go this year. Is there
camping space available or a camp ground there? I want to bring my Dad's
motorhome - is there space available?
Doug
Yes, without hookups. I think they charge $5.00 for the entire time.
Bob B.
> From: Doug Sheets <doug_sheets(at)hotmail.com>
> Subject: Brodhead
> Date: Saturday, May 01, 1999 9:46 AM
> Group:
> Doug
Subject: | Re: Hats not Hatz |
Richard DeCosta wrote:
> That'd be great. I need to log some more X/C time before my big trip
> to OSH in July.
> --- Mike Cunningham wrote:
> > Richard, your gonna need your right arm too fly your Piet! I just
> > took a
> > look through my American Hatz Assoc. roster and don't see anybody in
> > Maine.
> > There are some members in CT, NY, PA, etc. If you like I will email
> > you
> > some info on them. Maybe you can take a 172 down their way.
> > From: Richard DeCosta
> > Date: Friday, April 30, 1999 11:04 AM
> > Subject: RE: Hats not Hatz
> > >I'd give my right arm for a ride in a Hatz. Any of you guy near
> > Maine?
> > >Careful you guys, we Hatz builders are lurking out here :-)
> > >From: John Duprey <j-m-duprey(at)erols.com>
> > >Date: Thursday, April 29, 1999 8:06 PM
> > >Subject: Hats not Hatz
> > >>Steve: I got my hat today, It is even nicer than you described!!
> > This
> > >>thing should last forever. Thanks!
> > >>John Duprey
> > >My homepage: http://www.AirCamper.org/w3builder
> > >....Oh that I had wings like a dove! for then would I fly away, and
> > be at
> > rest. -Psalm 55:6
> > >Visit www.AirCamper.org - A Low 'n Slow Online Community!
> ....Oh that I had wings like a dove! for then would I fly away, and be at rest.
-Psalm 55:6
Richard: Pick me up in Mass on the way I will help pay the gas, I want a
ride in one too!
John Duprey
Subject: | Re: Sorry Folks, was RE: Piet hats. |
Steve,
I just thought you were trying to sell 3 hats so you sent a message for each
one.
Ted
P.S. Do you (any one else that is smoking) have a shut off at the fire wall
so that exhaust doesn't come back through the "oil line" when you disconect
the rubber hose and supply? I am assuming that you don't fly around smoking
ALL the time!!
>What a blooming idiot. Here I am unintentionally spamming my own list.
>Beg you pardon.
>Steve Eldredge
>IT Services
>> steve(at)byu.edu
>> Sent: Friday, April 30, 1999 9:32 AM
>> Subject: RE: Piet hats.
>> version (low and
>> shipping per order
>> Best Regards,
>> Steve Eldredge
>> 1005 E 620 N
>> Provo UT 84606
>> Steve Eldredge
>> IT Services
>> > Behalf Of Les
>> > Lampman
>> > Sent: Sunday, March 14, 1999 9:17 PM
>> > Hi Steve,
>> > Not sure if my first message made it through. New to the
>> > mailing list.
>> > I'd like to sign up for a hat, low & Slow on the back sounds good.
>> > Les Lampman
Doug,
We have "camped" at Brodhead before. There are nice, grassy areas
to park your motorhome. There are no hookups so fill your tanks before
you get there. It is fun being "right there".
See you at Brodhead,
Have fun!
Tom
__________
From: | Joe & Marian Beck <flyretina(at)feist.com> |
Steve:
Received caps the other day. Love 'em! Thanks again for your efforts
and committment to quality experimental aviation.
The Wichita Piet clan has two spare fuselages (one short, one long) "on
display" in my shop now.
CJB, King of PolyTak
From: | Michael Cuy <Michael.D.Cuy(at)lerc.nasa.gov> |
>ALL the time!!
Ted- Good question. I have no valve but will be putting on a 'cap' at the
cockpit
end of the tubing when not in use this year. Otherwise you do get some
backpressure
when the smoke system is not in use......little puffs of air that will push any
residual
oil back thru the line and oil up your cockpit area some. A little messy, but
otherwise
not too big a problem.
Mike C.
the fire wall
so that exhaust doesn't come back through the oil line
when you disconect
around smoking
ALL the time!!
'cap' at the cockpit
some backpressure
push any residual
messy, but otherwise
Mike C.
My shut off system is very complex. Might take a long post to describe it,
but I'll try.
When my smoke bottle isn't connected,
1/4" bolt shoved in the tube.
PS. They send me Canopus 68 -Useless it is thick as molasas. Alas, back
to the drawing board.
Steve Eldredge
IT Services
> Behalf Of Ted
> Brousseau
> Sent: Saturday, May 01, 1999 9:27 PM
> Subject: Re: Sorry Folks, was RE: Piet hats.
> Steve,
> message for each
> one.
> Ted
> at the fire wall
> you disconect
> around smoking
> ALL the time!!
> my own list.
> >Beg you pardon.
> >Steve Eldredge
> >IT Services
> Behalf Of
> >> steve(at)byu.edu
> >> version (low and
> >> shipping per order
> >> Best Regards,
> >> Steve Eldredge
> >> 1005 E 620 N
> >> Provo UT 84606
> >> Steve Eldredge
> >> IT Services
> >> > Behalf Of Les
> >> > Lampman
> >> > Hi Steve,
> >> > mailing list.
> sounds good.
> >> > Les Lampman
Subject: | Re: Smoke shut off |
>Steve Eldredge
Steve- I certainly hope those guys will exchange your 68 for the 13 you wanted.
Geez. All that wait and they send you the wrong stuff.
Mike C.
molasas. Alas, back
Steve Eldredge
you wanted.
Mike C.
Subject: | FW: Wing Wash Out |
Steve Eldredge
IT Services
Sent: Saturday, May 01, 1999 7:32 PM
Subject: Pietenpol-List: Wing Wash Out
Today a friend with a good deal of taildragger exp. flew my GN-1, it's
first flight since rebuilding. He is concerned about proper rigging. Since
I purchased the machine and didn't build, thhere is a lot I can't tell him.
He asked about wing washout. Can anyone tell me what it should be?
Thanks, Larry Pasley
Carlisle, Arkansas
Subject: | aleron gag seals |
I've got 107 TT on my Piet and still haven't come up with a good
salution for the gap seals, anyone have some info? I had packing tape
on it for awhile, then it left one wing one evening and I put it in a
nieghbors field (the wing got kinda heavy) got some duck tape smeard it
on and got back to my field. Just another day with the Piet.
Subject: | Re: aleron gag seals |
x-mac-creator="4D4F5353"
Eli,
The gap seals I used are made of Moncooat RC airplane model covering.
Any hobby shop. Found the same color as my paint. Seems be holding up
fine on the ailerons. Need to replace it on the elevator. More sun there
I guess.
Craig
Wow, it sure sounds like sealing the aileron gap makes a lot of
difference. I had a thought about a solution. Model airplanes
are generally covered with a shrink plastic film that has a heat
sensitive glue on one side. It sticks really good and would
provide a tough and flexible web. I'd cover six or eight inches
top and bottom on both wing and aileron and heat it together at
the gap. I've also thought about using the same stuff over
some six ounce woven glass that would be epoxied to wing and
aileron, leave the gap untreated, and then cover with the same
plastic material as above. May you could try about a foot of
each on each wing, that way if it fails the limited area
shouldn't unbalance your plane too badly to fly OK.
The plastice comes in a lot of colors, so you might not even need
to paint.
Good luck!
Mike Bell
Columbia, SC
Doug and others that camp;
It is usually crowded at the Broadhead camping area and I think it is
free. This year I hear it will be REALLY crowded camperwise and it is hard
to manuver in that parking lot if you have a big rig. You can drive on down
to the second entrance for more room but I don't know about the turning
radious........might have to park it alongside the road and scout the
grounds on foot. This is not a fancy to do like Oshkosh so there are not a
lot of rules or signs...........
Earl Myers
Date: Sunday, May 02, 1999 8:36 AM
Subject: Pietenpol-List: Re: Brodhead
>Doug,
>Have fun!
>Tom
Subject: | rear step hole and tail handle |
Wanted to ask a question about a few things that I have been thinking
about.
First, I've seen on some Piets. a rear step hole, that appears
to be under the rear seat, for rear entry. Is this a handy "must"?
I'm using 24" wheels , so it will be high. If so, do you step right on
the longeron, with the inside boxed in?
Second, when a J3 cub needs to have the tail moved around,
they have a handle just forward of the tail, to pick up and swing
around. Nothing like this is on the plans, and I don't think I've seen
this in Piet pics. What do builders do?
thanks alot,
walt
ps. want to add this as I go, and not have to backtrack.
things that
I have been thinking about.
Subject: | RE: rear step hole and tail handle |
First about the step. I built one into my plane but then covered it over
after I got the fuse on the gear. It isn't nessesary for my plane with
800x6" wheels. I built mine by reenforcing the longeron with 1/4" ply so I
wouldn't damage the longeron with my shoes scuffing on it all the time. It
was located under the seat, but like I say I never used it and didn't cut
out the fabric for it. With regards to the tail wheel, I built the rear
mount per plans and use the down tube to the tailwheel as a place to lift.
I'll be darned if Bernie didn't have it right again!
Steve Eldredge
Steve(at)byu.edu
IT Services
evans
Sent: Monday, May 03, 1999 11:52 AM
Subject: Pietenpol-List: rear step hole and tail handle
Wanted to ask a question about a few things that I have been thinking about.
First, I've seen on some Piets. a rear step hole, that appears to
I'm using 24" wheels , so it will be high. If so, do you step right on the
Second, when a J3 cub needs to have the tail moved around, they
have a handle just forward of the tail, to pick up and swing around.
Nothing like this is on the plans, and I don't think I've seen this in Piet
thanks alot,
walt
From: | "David B. Schober" <dbs(at)fscvax.wvnet.edu> |
In the gliders, we use surface tapes. Just glue it on with Super Seam or
whatever, put a couple coats of dope, then color and your done. Just make
sure you don't do a heavy buildup where it flexes.
David B.Schober, CPE
Instructor, Aviation Maintenance
Fairmont State College
National Aerospace Education Center
Rt. 3 Box 13
Bridgeport, WV 26330-9503
(304) 842-8300
Subject: | Re: rear step hole and tail handle |
Steve,
Thanks for the response. The step seemed logical, but it's hard to
picture the "climb" that you'll have ahead of you when it's finished.
On my little fisher 404, the tailwheel spring sticks out past the hinge
of the rudder, and still you have to reach under from the back to grab
the spring as a handle to lift the tail and pull it. I just figured that
the tailwheel tubes were too far under.
Thanks for clearing that up.
walt
Date: Monday, May 03, 1999 4:56 PM
Subject: RE: rear step hole and tail handle
over after I got the fuse on the gear. It isn't nessesary for my plane
with 800x6" wheels. I built mine by reenforcing the longeron with 1/4"
ply so I wouldn't damage the longeron with my shoes scuffing on it all
the time. It was located under the seat, but like I say I never used it
and didn't cut out the fabric for it. With regards to the tail wheel, I
built the rear mount per plans and use the down tube to the tailwheel as
a place to lift. I'll be darned if Bernie didn't have it right again!
Steve Eldredge
Steve(at)byu.edu
IT Services
Behalf Of walter evans
Subject: rear step hole and tail handle
thinking about.
appears to be under the rear seat, for rear entry. Is this a handy
"must"?
right on the longeron, with the inside boxed in?
around, they have a handle just forward of the tail, to pick up and
swing around. Nothing like this is on the plans, and I don't think I've
seen this in Piet pics. What do builders do?
thanks alot,
walt
From: | Michael Brusilow <mb-albany(at)worldnet.att.net> |
<<From: Eli or Robert or Teresa Bozeman
Subject: Pietenpol-List: aleron gag seals
Date: Monday, May 03, 1999 11:45 AM
salution for the gap seals, anyone have some info?>>>
I fought that problem for a long time. Then I got me some 100 MPH tape
( Wag-Aero ) & it has worked great for the last four years. Put it on
the tail too.
Mike B ( Piet N687MB )
Bozeman
R>To:
sealsDate: Monday, May 03, 1999 11:45 AM
Piet and
still haven't come up with a goodsalution for the gap seals, anyone
have
some info?
Then I got
me some 100 MPH tape ( Wag-Aero ) it has worked great for the last
four
years. Put it on the tail too.
Just a comment on a sad event yesterday. Out at Kakabeka Falls our Ultra
light instructor and a passenger were found in the wreckage of a Cuby
II. No telling how long they were on the runway. Pictures show a typical
departure stall effect. Will have to wait for the transport safety
investigation for cause. Kakabeka falls is about 20 NM from Thunder Bay
Airport with lots of trafic into it.
No mention was made of an ELT, even though TB is a busy commercial
airport. Again will have to wait for the findings. It started my
thinking of a very light ELT for the Piet. After almost two and a half
years of building and interacting with the Piet chat group, I don't
think I have heard the topic come up.
What works (none of them do all the time), what's affordable, and any
recommendations?
Sure got my wife worked up, as we both knew the instructor.
Walt wrote "I've seen on some Piets a rear step hole.....is this needed"
I also have the large wheels and short legs so it's a real chore slinging
that leg up over the top longeron, One of the pix you saw may have been my
project... anyway, I tried to solve it by ordering a pre-formed fiberglass
step from T.E.A.M. (Tennesee Engineering and Manufacturing) who put out the
MiniMax and sell the step for that plane. I boxed it in under the rear seat
and positioned on top of the bottom longeron at a cross member. The box
structure is to fair it out in line with the fabric contour between the
longitudinal side stringer and the bottom longeron. After all of that it does
not do the job and I may remove it. Problem is that the hole goes straight
in rather than at a forward angle. This makes it quite awkward to use. I
once had a 1930 Buhl Bull Pup that had a retractable tube-within-a-tube that
was actuated by a plain 'ol screen door spring and had a finger ring welded
on the end to grab it with. Worked like a charm, but on the Piet there isn't
room to keep it inside the fuselage and fit under the torque tube. Maybe
someone else can suggest a way to mount one like that. Good luck
Don Hicks
From: | "R. Mueller" <rmueller7(at)earthlink.net> |
Subject: | Flying and Glider Man |
I was wondering, is the "Original Air Camper & Sky Scout Builders Manual"
listed on the Pietenpol website the same material as the original F&G
Manual/EAA reprint, or are there pertinent revisions to the material that
one would need? I have a copy of both the EAA reprint and the original '32
Manual (I think that was the Air Camper year), so if the info is the same,
I woould rather not buy another copy.
Ryan
Hi Tom,
My gear (right side only) is welded. Today I will sand blast. Erwin a friend
is re-making my lower part of the intake, including a new "Y". It looks good
I saw it last night before the RAA meeting. He had run out of Gas, so I took
him my bottles. I pick up my new 'Pucks' today. When this is all done I'll
get the other side done.
The Brampton flying Club airshow committee has asked for my plane for a
static display. Of course I will comply... I will have to make up
some'History Story Board for the display and to promote Petenpols' 70th
Anniversary, as well as the Brussel's Flyin coming up on the 19th June. If
you have any ideas for the board let me know, I'm not much of an Artist.
Domenic
Date: Tuesday, May 04, 1999 8:56 AM
Subject: Re: gap seals
Will your Piet really do 100 or would 70 MPH tape have been just
as good?
Mike Bell (NoPietYet)>>>
Aint no 70 MPH tape.
Mike B (Piet N687MB )
Subject: | Corvair Authority |
I am trying to contact William Wynne re his rebuild manual. The only
number I have is a 1-500 number inaccessable from Canada. Any one have a
real number I can call?
-=Ian=-
Subject: | Steve Eldredge and May issue of Sport Aviation... |
Congrats Steve! I saw your photo and bio on page 126 of the May 1999
issue of Sport Aviation. I showed it to my wife and asked how come
wives in Utah were so understanding about their husbands airplane lusts.
She said, "Most women are just happy to have there husbands lust at all
and that they attach ceiling fans to the ceiling better in Utah." And
"That I better not trying to attach anything to our ceiling fan!".
Anyway, I always love turning back to the "What our members are
building/restoring" section to see what nice looking Piet is there.
Hope to see your flying machine at Broadhead.
Also, everybody should look at "Hints for Homebuilders" section this
month. I've been taking pieces over to a friends because I couldn't
come up with the money to buy a power planner. But this guy has got the
right idea. He took a Black and Decker electric hand plane and made a
simple attachment to turn it into a power planner. The ingenuity of the
homebuilder will never stop amazing me.
Greg Yotz
P.S. Got my new bandsaw blades and starting to cut more pieces today.
photo and bio
on page 126 of the May 1999 issue of Sport Aviation. I showed it
to my
wife and asked how come wives in Utah were so understanding about their
husbands
airplane lusts. She said, Most women are just happy to have
there
husbands lust at all and that they attach ceiling fans to the ceiling
better in
Utah. And That I better not trying to attach anything
to our
ceiling fan!.
to the
What our members are building/restoring section to see what
nice
Broadhead.
Hints for
Homebuilders section this month. I've been taking pieces
over to a
friends because I couldn't come up with the money to buy a power
planner.
But this guy has got the right idea. He took a Black and Decker
electric
hand plane and made a simple attachment to turn it into a power
planner.
The ingenuity of the homebuilder will never stop amazing
me.
Greg Yotz
and
Actually, ELT's are generally quite inexpensive. check out
http://www.avionix.com/elt.html for 2 ELT's at $199 each. This was a topic
of a great deal of discussion in the local Newfoundland media last year
when a Pilatus PC-12 crashed. It had an engine failure and they tried to
make the field at Clarenville. The ceiling was less than 500' and vis was
poor. The Gander tower tried to vector the plane to the field, but the
field shows up on thier screens as a dot about 5 miles in diameter (a very
good firend of mine is an ATC in Gander). They broke out of the clouds at
quite a distance from the field and ended up in a bog. with a number of
seriously injured passengers and crew.
In the aftermath, it was determined that the plane was without an ELT.
According to Transport Canada, you can remove an ELT for service and
legally operate the plane for a specific number of days without it (30,
60, 90 ?, I can't remember which). When the media figured out that the
ELT's cost less than $500, they had a field day at both the airline's and
Transport Canada's expense. I, too, was wondering about the logic behind
this waiver. Murphy's Law dictates that the only time you will need one is
when it's not installed. Even if the PC-12 had some sort of exotic ELT
that cost 10 times what a gen av one does, it's still only $2000 to have a
spare standing by.
Personally, I have an ELT and fully intend to use it in my Christavia.
It's VERY cheap insurance. This is especially true for Canada with such a
low population density.
Oh yeah, here's a question asked at a TC safety seminar. What do you do if
you make a precautionary landing in a remote area while on a flight plan?
For example, you're flying a flight plan in a float plane (say that 5
times fast ;-) and decide to put down on a lake due to deteriorating
weather and can't call anyone before you land.
The answer surprised me. One hour after your ETA, you TURN ON YOUR ELT!
After hearing the explanation, it makes perfect sence. SAR will start a
search if you have not reported in 1 hour after your ETA on a flight plan.
Since they are already looking, you might as well make it easy for them
and allow them to send a helicopter directly to you. Of course, you should
make every attempt to contact someone before this. When I flew on floats
in Newfoundland, I always had a list of ALL the frequencies used in the
area including company frequencies of the airlines, Gander Center
frequencies, etc. That way, it increased my chances of reaching an
overflying airliner in such a case.
Oh well, enough rambling.
Ken
> recommendations?
I have the ACK ELT in my Air Camper. Mounted behind the front panel on the
fuse crossmember. I may be wrong, but I think the regs say that you have to
have one if you are flying outside your test area, and you have more than
one seat. The ELT was about $200 and has the remote indicators and switch.
I mounted the antenna ahead of the front windshield. It is about 24" long.
Not very authentic looking but the only place I could find a ground plane.
Steve Eldredge
IT Services
> Behalf Of Ian
> Holland
> Sent: Monday, May 03, 1999 10:00 PM
> Subject: Safety
> Falls our Ultra
> show a typical
> Thunder Bay
> recommendations?
It will do 100. I did a "high speed" (ha ha) pass Saturday and had to
throttle back a bit to keep it under 100. Controls were very heavy at that
high speed however.
Steve Eldredge
IT Services
> Mike Bell
> Sent: Tuesday, May 04, 1999 6:54 AM
> as good?
> Michael Brusilow on 05/03/99
> 07:12:02 PM
> Please respond to Pietenpol Discussion
> cc:
> Subject: gap seals
> Subject: aleron gag seals
> good
> MPH tape ( Wag-Aero ) & it has worked great for the last four
Subject: | RE: Steve Eldredge and May issue of Sport Aviation... |
Thanks! I am axiously awaiting my copy. I figure I better put something in
having been a year and a half since completion....
Steve Eldredge
Steve(at)byu.edu
IT Services
Yotz
Sent: Tuesday, May 04, 1999 8:12 AM
Subject: Pietenpol-List: Steve Eldredge and May issue of Sport Aviation...
Congrats Steve! I saw your photo and bio on page 126 of the May 1999 issue
of Sport Aviation. I showed it to my wife and asked how come wives in Utah
were so understanding about their husbands airplane lusts. She said, "Most
women are just happy to have there husbands lust at all and that they attach
ceiling fans to the ceiling better in Utah." And "That I better not trying
Also, everybody should look at "Hints for Homebuilders" section this month.
I've been taking pieces over to a friends because I couldn't come up with
the money to buy a power planner. But this guy has got the right idea. He
took a Black and Decker electric hand plane and made a simple attachment to
turn it into a power planner. The ingenuity of the homebuilder will never
stop amazing me.
Greg Yotz
Howdy from Big "D"
I too have an ACK Model E-01 in my GN-1 Aircamper.
It is mounted under my rear seat with remote switches
in the rear cockpit. The antenna is mounted atop the
right wing. The external handheld radio antenna is
mounted on the left wing.
The Model E-01 ELT is automatically activated upon
sensing a change of velocity, along it's longitudinal
axis, exceeding 3.5 feet per second. It is designed
to be removed from the aircraft and used as a personal
locating device when it is necessary to leave the scene
of the accident. Not a bad idea when flying low and slow
in rural areas.
Mike King
GN-1
77 MK
Dallas, Texas
Like Steve's, mine has the
>Steve Eldredge
>IT Services
>> Behalf Of Ian
>> Holland
>> Subject: Safety
>> Falls our Ultra
>> show a typical
>> Thunder Bay
>> recommendations?
Re Elt:
I mounted my Elt on the front cockpit floor in line with the left
side of the front seat.
I mounted the antenna on the fairing between the wing & center
section.
Mike B (Piet N687MB)
Re
Elt:
cockpit
floor in line with the left side of the front seat.
I
mounted the antenna
on the fairing between the wing center
section.
size3>
Mike B
(Piet
N687MB)
Steveeeee- Congrat's on making the May issue of Sport Aviation !!! Looks good
PS- don't forget to checkout the classifieds under books/video's and you'll see
my stinking video
now advertised !
Mike C.
Thanks!
you'll see my stinking video
now advertised !
Mike C.
Subject: | Re: Corvair Authority |
<< I am trying to contact William Wynne re his rebuild manual. The only
-=Ian=- >>
I have been trying his number for weeks. Only a machine answers. I have
left about six messages, all unanswered. I have the manual and have been in
contact with William many times. I do not know what is up. I will mail his
number when I get back to my computer.
William Koucky
Hey guys, I've got a King KLX 100 GPS/COM handheld, used 2 seasons.
Its great for us low and slow pilots, you can run around all day down
low and never get lost, then hit hme and get a direct home.....
I'm needing 800.00 out of it OBO
Robert B.
All,
Rats. Big hairy greasy ones! I mailed a check to William Wynne about two
weeks ago. So far, no conversion manual and the check hasn't been cashed
yet. If either of you make contact, give him my regards. He's probably on
vacation or something. By the way, William K., how have you found the
conversion manual?
Mark Boynton
Gilbert, Arizona
> Thanks,
> -=Ian=- >>
in
his
> William Koucky
Hmmm... I sent him a check six weeks ago for the manual. I still
haven't received my manual or any explanation what the delay might be.
I wonder if he is sick.
> Thanks,
> -=Ian=- >>
> William Koucky
When welding nuts, be sure to sand off all Cadmium be for applying heat. Do not
inhale cadmium gas/smoke!
Warren Shoun wrote:
> Ian,
> Let me encourage you to just keep an eye out with the aircraft supply
> houses for sales and surplus. Several weeks ago, I found a 50# box of
> surplus forks at AS&S and bought 8 of the following for $5.00 total.
> 3 7/8" long X 1/2" rolled threaded fork. Head is 7/8" wide:
> 1 3/16" deep slot; hole 5/16" and will accept a tab 3/16" thick. These are
> new surplus and are cadmium plated.
> Also found some new truck wheel lug nuts that fit perfectly and am
> seriously considering welding these in the ends of my struts for fittings,
> unless anyone here can talk me out of it.
> And yes I did check and they are gone, and the counter guy told me that
> they get this kind of stuff in all the time.
> Good Luck.
> Warren.
> Thanks,
> -=Ian=- >>
> William Koucky
I have also attempted to contact him and failed to get a reply. I even
sent a letter by snail mail with a s.a.s.e. requesting a price list.
This was over 6 weeks ago and haven't received anything. My $$$$ will
be spent elsewhere.
Subject: | Re: Brakes on Jenny style straight axles |
To Mike Cuy, and any of the rest of you with brakes.
I machined the 4130 1.5" OD straight axle today. I have cut
threads for spindle nuts and turned the bushing section to accept my
converted motorcycle wheels.
I noticed that your pictures Mike, have a shaft protruding down
through the bottom block. Is this bolt preventing axle rotation and
acting as a travel limit? How is the bolt fastened to the axle and if
this is what you are doing is it working out well?
I guess what I'm asking is how do you stop the axle from rotating as
the brakes absorb the wheels torque?
John Mc
the
have to
than
switch.
long.
plane.
You're right about the reg, Steve, at least in the US. There was an
extensive discussion on r.a.h awhile back about it. US regs say you
have to have one. I thought it was a little weird on something like
the Piet, but that's the rule.
Glenn
Subject: | Adjustable lift strut attachments |
On my struts I used s.a.e.fine thread allthread nuts. these nuts are 2
1/2" long, I mild a groove the lenght of nut and welded a piece of .090
4130 down each side, this was my weld barrel . Next I got the forkends
from a hotrod magazine ( 1/2" rolled threads rod ends for model A Ford)
at a total cost of $6.00 per unit.
I gave one to a friend of mine that owns a machine shop, I asked him to
destroy it for me. He brought it back a few days latter and said
theres no reason for him to tear up his macherey on it, so we believe
its strong enough for the Piet.
Thanks, Bob - I sure need to see a bunch of Piets to see how to make mine!
>From: baileys(at)ktis.net (Robert M. Bailey)
>Subject: Re: Brodhead
>Date: Sat, 01 May 1999 11:57:16 -0500
>Bob B.
> > Subject: Brodhead
> > Group:
> > Doug
In a message dated 5/4/99 10:28:32 PM Eastern Daylight Time,
randy(at)icomnet.com writes:
> Thanks,
> -=Ian=- >>
in
his
> William Koucky
be spent elsewhere.
XXXXXXXXXXXXXXXXXX
I have to say that the manual is worth the money and dealing with William has
been great (when I was able to reach him). He helped me in all areas. I have
tried to call and will try again. His number is 904-426-6028. I thought it
was because of Sun n Fun. He is a busy guy. I have been waiting for him to
return my call to answer a question so I can finish my assembly. I find that
asking the question on VirtualVairs is worth while,too.
William Koucky
Traverse City, MI
Does anybody know what a corvair engine weighs when installed in a Piet?
>> I machined the 4130 1.5" OD straight axle today. I have cut threads for
>> spindle nuts and turned the bushing section to accept my converted
>> motorcycle wheels.
>> I noticed that your pictures Mike, have a shaft protruding down through the
>> bottom block. Is this bolt preventing axle rotation and acting as a travel
>> limit?
John- Yes and yes. In addition to those two issues this shaft also prevents
the axle from moving left or right
as you bump along the ground. Frank Pavliga had this happen early on and every
so often they would have
to shove the axle back to it's proper position under the bungees. ***as a word
of caution, no matter what design
you end up using to get the job done, a good thing to do is loop and nicopress
a length of cable around each
axle/gear leg so that if your bungee lets loose the axle won't travel all the
way up to your belly and cause extra
damage.
>> How is the bolt fastened to the axle and if this is what you are doing is
Actually what's happening here is that bolt or shaft is welded to the bottom of
the axle. The shaft is then
run thru a collar or 'tube inside of a tube' that's welded to the inside lower
steel gear fitting.
A little grease there helps it not to squeak. So far the setup works very well
and I'd do it again.
Many solutions though to this dilemma. The WWI guys were ingenious at solving
this very problem.
For more clarity I can mail you (and anyone else interested) a .jpg format
picture that shows
exactly how this thing works.
Mike C.
brakes.
I machined the 4130
1.5 OD straight axle today. I have cut threads for spindle nuts and
turned the bushing section to accept my converted motorcycle wheels.
the bottom block. Is this bolt preventing axle rotation and acting as a
travel limit?
also prevents the axle from moving left or right
on and every so often they would have
***as a word of caution, no matter what design
nicopress a length of cable around each
the way up to your belly and cause extra
damage.
How is
the bolt fastened to the axle and if this is what you are doing is it
working out well?
bottom of the axle. The shaft is then
lower steel gear fitting.
works very well and I'd do it again.
at solving this very problem.
format picture that shows
Mike C.
Mike; "ole Earl down the road here would like one!
Date: Wednesday, May 05, 1999 9:16 AM
Subject: Re: Brakes on Jenny style straight axles
cut threads for spindle nuts and turned the bushing section to accept my
down through the bottom block. Is this bolt preventing axle rotation and
travel all the way up to your belly and cause extra
damage.
the bottom of the axle. The shaft is then
inside lower steel gear fitting.
Mike C.
Subject: | Re: Tailwheel Spring Packs (fwd) |
This is something I found on the RAH usenet group and thought it was quite
interesting. I'll certainly be checking it out. Saving some weight that
far back in the tail has got to help with W&B.
---------- Forwarded message ----------
Date: Wed, 5 May 1999 11:40:54 +1000
Subject: | Re: Tailwheel Spring Packs |
Ken,
you might consider using limbs from a compound bow (bow and arrow) or have
leaves made up by a bow manufacturer for tailwheel springs! They are light,
have very accurately known spring forces, can be made any shape you need and
last forever and don't corrode.... I'm extremely happy with mine - they cost
me a song to have made exactly to my specs (in carbon fibre).
Go look in the yellow pages and talk to a bow man.
<303print(at)northrim.net> wrote in message
news:7gnfhh$n8k$1@nnrp1.dejanews.com...
> My tailwheel spring for my homebuilt is a bit soft. I know I can make a
new
> one that will solve the problem in the verticle plane. But what reall
worries
> me is that the spring also has a strong tendancy to twist torsionally when
> turning. Will the stiffer spring pack also alieve the storsional twist or
> should I convert to a tube spring with a Scott 3400?
> Thanks
> Ken Bauman
> -----------== Posted via Deja News, The Discussion Network ==----------
> http://www.dejanews.com/ Search, Read, Discuss, or Start Your Own
I saw composite tail springs in the Aircraft Spruce catalog (or was it Wick's).
I think they were speced for a Kitfox.
> From: Joe Hovel <jhovel(at)hitech.net.au>
> Newsgroups: rec.aviation.homebuilt
> Subject: Re: Tailwheel Spring Packs
> Ken,
> new
> worries
> > Thanks
> > Ken Bauman
Steve,
Got my hat today. Thanks I like it.
Domenic
Mike, I don't know what a .jpg format picture is and whether you're
referring to snail or E-mail but would sure like to see anything you have
that shows meyours works. I have an anti-torque devise on mine that was
designed by a friend but feel there might be room for improvement. Easier to
make changes now, if needed, than later.!! Thanks, Don
Date: Wednesday, May 05, 1999 7:19 AM
early on and every so often they would have
bungees. ***as a word of caution, no matter what design
and nicopress a length of cable around each
damage.
Mike; how much travel did you allow with the stop cable?
I was wondering how loose the fit would have to be, so that the
axle could tilt and allow one side to move more relative to the other?
So far the setup works very well and I'd do it again.
Mike C.
Yes! Please and thanks :-)
John Mc
I would be interested to find out where you obtained the forks and
nuts,sounds very interesting indeed!
Doug
> Date: Tuesday, May 04, 1999 9:59 PM
What cam are you using in your engine?
Doug
> From: Wkoucky(at)aol.com
> Subject: Re: Corvair Authority
> Date: Wednesday, May 05, 1999 6:32 AM
only
have a
> > Thanks,
> > -=Ian=- >>
have
been
> in
mail
> his
> > William Koucky
> be spent elsewhere.
> XXXXXXXXXXXXXXXXXX
has
have
thought it
to
that
> William Koucky
> Traverse City, MI
Dear Sirs,
Can anyone tell me what wing wash out should be - or could be - on a GN-1
with no dihedral? I'm having a time finding anything on this. I'd
appreciate your help.
Larry Pasley
> > easier).
> > Best regards,
> > -=Ian=-
> Ian:
> I've got about six strut forks ,they are the cut type but a heck of a
> lot of Cubs have flown on cut threads over the years ( they look like
> they are in fine shape.) Got them from my Uncle who was a Piper Cub
> builder years ago . I'll only need two of them. If you have a hard
> time finding what you need, E-Mail me and I'll let you have a couple if
> you need em. I'm scrounging for cables, pulleys, bungees etc now too.
> Cheers,
> Bert E-Mail: BWM(at)planttel.net
Steve,
Before you get rid of all those hats I better ask a question. Did you get
my check I sent about 3 weeks ago? I haven't seen a hat here and I am
getting worried.
Ted
Naples, FL
>but I'll try.
>Steve Eldredge
>IT Services
>> Behalf Of Ted
>> Brousseau
>> Steve,
>> message for each
>> one.
>> Ted
>> at the fire wall
>> you disconect
>> around smoking
>> ALL the time!!
>> my own list.
>> >Beg you pardon.
>> >Steve Eldredge
>> >IT Services
>> Behalf Of
>> >> steve(at)byu.edu
>> >> version (low and
>> >> shipping per order
>> >> Best Regards,
>> >> Steve Eldredge
>> >> 1005 E 620 N
>> >> Provo UT 84606
>> >> Steve Eldredge
>> >> IT Services
>> >> > Behalf Of Les
>> >> > Lampman
>> >> > Hi Steve,
>> >> > mailing list.
>> sounds good.
>> >> > Les Lampman
Subject: | Staining Longerons |
Hi Guys
Ive got a weeks holidays comming up, and am going to use it building my fuse
woodwork. I've been thinking of using Minwax on the longerons and
crossmembers to get the cockpit to match the planed color scheme. My own
tests have shown no problem with glueing strength (T88 and LePages Epoxy),
and weight increase on a 12" x1"x1" could not be measured on a postal scale.
Anyone have experience with longer term or hi temp effects of using stain ?
All the wood aircraft I have ever seen are varnish only, so am I missing
something, or just the only one nutty enough to think of it ?
----- Original Message -----
Sent: Wednesday, May 05, 1999 7:07 PM
to
in the dec 1970 issue of sport aviation, an article by Bud Rinker states the
following;;
base engine--------200 to 220
add cooling fan----add 20
base engine w/gearbox---add 25
add cooling fan-----------add 20
add starter & alternator---add 30 to 40
hope this helped you
regards
JoeC
Zion, Illinois
John- My guess is about 6 to 8 inches.
>> I was wondering how loose the fit would have to be, so that the axle
Good point. I just got two sizes of 4130 tubing that fit inside one another
with a little play. Can't
tell you what sizes I used at the moment, but they are fairly tight. In the
real world my axle only moves
mabye 3/4" up when taxiing and maybe 1" on a really hard landing.
Mike C.
stop cable?
have to be, so that the axle could tilt and allow one side to move more
relative to the other?Good point.
I just got two sizes of 4130 tubing that fit inside one another with a
little play. Can't
tight. In the real world my axle only moves
mabye 3/4 up when taxiing and maybe 1 on a really hard
landing.
Mike C.
>Dear Sirs,
>Larry Pasley
Larry- the wise older gentlemen where I fly (who rebuild and rig Cubs, Champs,
etc.) suggested I put 3/8" washout about 3 ribs in from the wingtip. I guess
it keeps the ailerons working longer as you begin to stall.
Mike C.
Dear Sirs,
GN-1
I'd
Larry Pasley
Cubs, Champs,
etc.) suggested I put 3/8 washout about 3 ribs in from the
wingtip. I guess
Mike C.
From: | Mike Cunningham <mikec(at)microlandusa.com> |
Hi Richard,
I haven't forgotten about getting you some Hatz addresses, Just been swamped
here at work and haven't remembered to do it while at home. Will get them to
you soon. By the way, it would be quite a trip for you but Biplane Expo is
coming June 4-5. Bartlesville OK, N.E corner of OK. It's a national Biplane
Assoc. event. Lots of Hatz Nutz
will bow there plus Stearmans etc.
Tnx,
Date: Friday, April 30, 1999 4:35 PM
Subject: Pietenpol-List: Re: Hats not Hatz
>to OSH in July.
>> took a
>> Maine.
>> you
>> Maine?
>> This
>> >>John Duprey
>> be at
>> rest. -Psalm 55:6
rest. -Psalm 55:6
Subject: | Re: corvair stuff |
To Walt Evans,
Hi Walt. I'd like to take you up on your offer of Dick Lawson's phone
number and address. Thanks.
Mark Boynton
Gilbert, Arizona
> for Tom Bowdler and everyone,
> A few days ago you mentioned Bob Schiffel. I just got off the phone
> with my " mentor" Dick Lawson. Dick built Bob's corvair engine. This
> is unique because it has a reduction drive on it that Dick Lawson had
> fabricated with his own aluminum castings, machined to his own specs.
> He has two of these on planes.
> Dick had mentioned tonite that , when he made some parts , he made an
> extra. He has a prop hub for corvair, and a cutdown flywheel hsg. if
> anyone is interested.
> Dick is a special guy, he is in his 70's, sharp as a tack, is a
> toolmaker by trade, licenced AP. Even has corvair engine stuff around.
> He can even fabricate special parts,without cleaning out your wallet.
> His first love is airplanes.
> If anyone is interested I can give phone # , or even address.
> walt evans
<< What cam are you using in your engine?
Doug
I am using a stock,reground cam on William Wynnes advice. He said that the
other cams available are not worth spending the cash on, on a high drag plane
like a piet. He said that he didn't think that it would improve the
performance.
William Koucky
From: | "Ragan, Lawrence M." <Ragan.Lawrence(at)mayo.edu> |
William
Did you use any of Wynne's component's? I had the opportunity to stop and
visit with him about 6 months ago and he had lot of things related to
Corvair's, (cranks, prop hubs, etc.). He seemed to be very knowledgeable,
(I'm not sure I know enough to judge), and I had planned to utilize his
resources. I may try to go down there (about 2 hrs south) and see him again
if I can get in contact with him.
Larry Ragan
Jacksonville, Fl.
I found excellent plans for a modular workbench at
http://www.aircamper.org/WorkTables.cfm but have a few questions:
1. The article suggests using "5/8ths inch particle board top covered with
Formica for the work surface" and the addendum article for the work surface
suggests: "use one or two thicknesses of 7/16" chipboard (or OSB). While it
doesn't look pretty, it doesn't seem to warp like plywood." and further
down in the plans suggests using "3/4" Sanded Exterior Plywood" for the
work surface. Any recommendations which to use for a good solid flat
worksurface?
2. A friend I met at Broadhead last year suggested a 4" border around the
workbench surface for clamping. This would result in a 16" x 52" footprint
instead of the 24" x 60" in the plans. Would 16" make the workbench too
tippy? Perhaps a solution would be to add a 2x4 to the bottom section of
each of the legs which would result in a 19" width at the bottom or maybe
just a horizontal 2x4x60" screwed to the bottom between the two legs.
Sincerely,
Paul Schultz
Iron Mountain, MI
pschultz(at)uplogon.com
Subject: | RE: Smoke shut off |
Ted thanks for the heads up (no pun intended) I have replied privately.
STevee
> Behalf Of Ted
> Brousseau
> Sent: Wednesday, May 05, 1999 8:08 PM
> Subject: Re: Smoke shut off
> Steve,
> Did you get
> getting worried.
> Ted
> Naples, FL
> to describe it,
> >but I'll try.
> molasas. Alas, back
> >Steve Eldredge
> >IT Services
> >> Behalf Of Ted
> >> Brousseau
> >> Steve,
> >> message for each
> >> one.
> >> Ted
> >> at the fire wall
> >> you disconect
> >> around smoking
> >> ALL the time!!
> >> my own list.
> >> >Beg you pardon.
> >> >Steve Eldredge
> >> >IT Services
> >> Behalf Of
> >> >> steve(at)byu.edu
> >> >> version (low and
> >> >> shipping per order
> >> >> Best Regards,
> >> >> Steve Eldredge
> >> >> 1005 E 620 N
> >> >> Provo UT 84606
> >> >> Steve Eldredge
> >> >> IT Services
> >> >> > Behalf Of Les
> >> >> > Lampman
> >> >> > Hi Steve,
> >> >> > mailing list.
> >> sounds good.
> >> >> > Les Lampman
What specifications were used to reground the stock cam?? I've always heard
the 95 H.P. cam should be substituted into the 110 H.p. engine.
Domenic
Doug
plane
performance.
William Koucky
Paul,
You might want also to consider MDF (medium density fiberboard). Its very
common in cabinet making and your local building materials store should have
it. From my experience, its the ultimate in flat surfaces. Also, in its
thickness, its very resistant to compression, so I wouldn't hesitate
clamping to it. You would need to put some type of solid edge on it though,
just something to protect it, and then put a laminate surface on it. The
edge banding can be very thin and still be amply effective.
Mark Boynton
Gilbert, Arizona
with
surface
it
> worksurface?
footprint
> Sincerely,
> Paul Schultz
> Iron Mountain, MI
Larry,
If you're able to make contact with William Wynne, would you let us know if
he's still in business. I'm one of the ones who sent a check (hasn't been
cashed yet) and are still waiting for the conversion manual. Thanks.
Mark Boynton
Gilbert, Arizona
> William
and
knowledgeable,
again
> Larry Ragan
> Jacksonville, Fl.
Me too. I'm real interested in the manual, but get a voice mail at the
land number (thanks) that has exhausted the recording tape.
Alternate.... Has any one got a copy of the manual that they are done
with, and want to recover the dollars spent? If so, I will buy it.
Mark,
It may take me several weeks before I even have a chance to go down there,
but given the chance, I'll get in touch with Wynne , and I'll keep you
posted.
P.S. Did you have Wynne's most recent ('99) conversion manual, and if so,
what'd you think?
Larry Ragan
Jax, Fl.
This is what I'm using. Originally, I didn't have anything protecting it.
However, while I was building the canoe, I used to dump out the remains of
the mixed epoxy resign on the bench surface and ended up with a rather
hard surface. Since the resign would have been wasted anyway, it didn't
cost me anything.
Ken
On Thu, 6 May 1999 mboynton(at)excite.com wrote:
> Paul,
> Mark Boynton
> Gilbert, Arizona
> with
> surface
> it
> > worksurface?
> footprint
> > Sincerely,
> > Paul Schultz
> > Iron Mountain, MI
Larry, If you manage to hook up with Wynne, can you let me know if he is
still in business? I would like to get ahold of his rebuild manual
-=Ian=-
Mark,
Sure, His phone is 973-383-7821 in northern NJ. I know where he lives,
but don't know his exact mailing address. You can get it from him.
He is a day person, not a night person, so I usually like to call him before
walt
PS By the way, there was some pics on the Pietenpol web page of a guy in
Brodhead standing behind a two cylinder engine ,in old garb , I think titled
"HAHAHAHA" Well , Dick Lawson built the crankshaft for this motor and
rebuilt it to run like it did.
He's quite a guy.
If you or anyone wants to see these pics, I can put them on the
AirCamper.org/users/wevans site
From: mboynton(at)excite.com <mboynton(at)excite.com>
Date: Thursday, May 06, 1999 11:14 AM
Subject: Pietenpol-List: Re: corvair stuff
>To Walt Evans,
>Mark Boynton
>Gilbert, Arizona
>> walt evans
At an Oshkosh forum a few years ago, Vi Kapler advised a 3/8" washout
for better stall warning. He went on to that this was his opinion and
that Bernie Pietenpol never used any washout.
Dean Dayton
dayton(at)netwalk.com
Michael Cuy wrote:
> >Dear Sirs,
> GN-1
> >Larry Pasley
> Cubs, Champs,
> I guess
> Mike C.
At an Oshkosh forum a few years ago, Vi Kapler advised a 3/8" washout for
Dean Dayton
Michael Cuy wrote:
>Dear Sirs,
a GN-1
>Larry Pasley
rig Cubs, Champs,
I guess
Mike C.
Hi!,
Did anybody have information about mounting a subaru ea65 engine on a
piet?
And anybody have plans to build a reduction for a subaru ea81?
thanks
Nahuel Garavaglia
ngarav(at)yahoo.com
Did any have info about mounting car engines like:
DATSUN L20
VW 2000 (Equiped on golf)
Fiat Engines
Renault Engines
Nahuel Garavaglia
ngarav(at)yahoo.com
Thanks to you and Dean Dalton for the information. It's appreciated. Now
I'll try to get it set up right.
Larry
> >Dear Sirs,
> >Larry Pasley
> Champs,
guess
> Mike C.
Steve , I would like to unsubcribe from the list for a while as summer
has seemed to have created more projects than I need !
phil
Check out Crusader Toys @
http://www.Crusadertoys.com
I thought that washout was to keep your tips from stalling before
your wing root and therefore provide a modicum of spin protection
and stability at the start of a stall. If you want an aerobatic
Peietenpol (oxymoron) then you would bend your tips up a little
instead and promote tip stalling. NASA designed a wing with a
more aggressive airfoil at the tips that was "spin proof". I
wonder why I've never seen it on a production or experimental
aircraft?
I haven't received my plans yet. How do you set washout on the
Piet? Is it built in or do you tighten and loosen support/drag
cables?
Columbia, SC
lpasley on 05/06/99 10:41:01 PM
cc:
Subject: Pietenpol-List: Re: washout
appreciated. Now
Larry
> >Dear Sirs,
- on a GN-1
I'd
> >Larry Pasley
rig Cubs,
> Champs,
wingtip. I
guess
> Mike C.
Subject: | Re: washout and stall |
Speaking of stalling, can anybody out there talk about the stall
characteristics of the Pietenpol Aircamper? Mush? sudden break? buffet?,
drops a wing?, etc? Anybody ever spin their piet either intentionally or
accidentally? Standard recovery procedures work?
Joe
>From: Mike Bell <mbell(at)sctcorp.com>
>Subject: Re: washout
>Date: Fri, 07 May 1999 08:52:06 -0400
>aircraft?
>cables?
>Columbia, SC
>cc:
>appreciated. Now
>Larry
> > >Dear Sirs,
>- on a GN-1
>I'd
> > >Larry Pasley
>rig Cubs,
> > Champs,
>wingtip. I
>guess
> > Mike C.
I am a little confused on this one. I have flown quite a few
hours in several Ercoupes which are highly spin resistant.
The basics of spin resistance are:
1) Wing tips are always LAST to stall. This insures
controllability with stall occuring. Because of the
greater moment arm at the tips, should one wing
tip be producing lift while the other is not, greater
spin tendancy will be present. Whereas if it is the
wing roots which are causing the differential lift,
spin tendacy will be less.
With the tips being last to stall, the control surfaces
will be still be effective with the start of a stall.
Methods for this are:
2) Limited elevator down force capability will prevent
deep stall of the main wing. An Ercoupe is never
really able to deep stall the main wing much past
the middle root portion (non-accelerated stalls).
It is really neat to demonstrate - yoke all the way
back, decending about 600 fpm, but full control
useage and about 50 mph on the airspeed.
Get a CFI with you, and in a C152 and C172, you
can get a 152 to marginally stay stable if you keep
ball centered with the rudder, but a spin will happen
quickly with a little more induced stall with power
to push the tail down or just kick the rudder a little.
A C172 is another animal. It has a little more
elevator and well, you know the rest of the story.
You can get more main wing stall with it and quicker
results.
3) Dihedral angle can help, but not always true.
I would be interested in reading the sources, if you
happen to know where to find them. I believe the above
will most likely be the reason why you will ALWAYS see
wings with methods implemented for the tips to stall last.
Remember - No plane will stall-spin unless a stall occurs first!
(Only for a CFI license does one ever have to show
proof of spinning an airplane for a license certificate...)
David Scott
Washington, IL
> aircraft?
> cables?
> Columbia, SC
> cc:
> appreciated. Now
> Larry
> > >Dear Sirs,
> - on a GN-1
> I'd
> > >Larry Pasley
> rig Cubs,
> > Champs,
> wingtip. I
> guess
> > Mike C.
---------1---------2---------3---------4---------5---------6---------7
/--------------------\ |~~\_____/~~\__ |
|scott(at)haulpak.com | o' ~~\|~~~ |
This insures
controllability
greater moment
tip be producing
spin tendancy
wing roots which
spin tendacy
will be less.
With the tips
will be still
Methods for this
are:
- angle of incidence less at the tips (washout)
- airfoil effectivity less at the tips (size, area, etc..)
- rectangular wing plan form (top view of wing)
- negative angle control surfaces
(move upward more than down)
will prevent
deep stall of
really able
the middle root
It is really
back, decending
useage and about
Get a CFI with
can get a 152
ball centered
quickly with
to push the
A C172 is another
elevator and
You can get
results.
true.
Sometimes
it actually worsens the tendancy for
single wing deep stall.
will most likely be the reason why you will ALWAYSsee
(Only for a CFIlicense does one ever
have to show
proof of spinning
David Scott
Washington, IL
stalling before
wing with a
aircraft?
cables?
Columbia, SC
lpasley lpasley(at)aristotle.net> on 05/06/99 10:41:01 PM
Please respond to Pietenpol Discussion piet(at)byu.edu>
To: Pietenpol Discussion piet(at)byu.edu>
cc:
appreciated. Now
Larry
> >Dear Sirs,
- on a GN-1
I'd
> >Larry Pasley
rig Cubs,
> Champs,
wingtip. I
guess
> Mike C.
|DAVID SCOTT |______ \______====== )-+
\--------------------/ (O)
Subject: | Re: CORVAIR AND Wm Wynne |
<< Did you use any of Wynne's component's? I had the opportunity to stop and
Larry Ragan
Jacksonville, Fl. >>
He sold me a block with the crank and cam together for a very good price.
The block was already helicoiled for new studs. I bought new upper studs
from him. The studs go in too easy (fingers). The question I had for him is
about the fit of these studs. I can't get an answer and the fit does not
seem right. The studs do not go in straight either. I don't know if this is
a problem or not. The block came with the bell housing already cut and in
place. The crank was threaded. He does seem very knowledgable to me, too
and easy to work with. I just wish I could get in contact as I have
everything else ready to go.
William Koucky
To all:
Has anyone done any research on aluminum v. wood spars. I'm curious about
feasability, weight, cost, strength, compatability with wooden ribs, and any
other pertinent issues that should be raised. I know that Wag-Aero offers
this option with their Cub-like kits.
Mark Boynton
Gilbert, Arizona
Subject: | Re: '99 Wynne manual |
Larry,
I was unaware that he has a newer version of his manual. All I have right
now is the hope that he's still in business. I hope you get a chance to
make contact with him. Let us know. Thanks.
Mark Boynton
Gilbert, Arizona
> Mark,
there,
> posted.
> what'd you think?
> Larry Ragan
> Jax, Fl.
Hello
I haven't been following the entire thread, I may have missed some thing
but you would an
Ercoupe have no aileron control during landing in a cross wind? I owned
a 1946 Ercoupe for 10
years, few it many hundreds of hours and it was the easiest airplane I
ever landed in a cross wind.
The aileron were coupled to the rudder, no cross control to prevent
stalling. All you had to do was
get your ground track strait down the runway, forget about were the nose
was pointed. Once down
the on the mains, point the nose down the runway, easy. The stalls are
very mild. I could pull the
power all the way off, pull the wheel/stick all the way back and mush
down with full aileron
control. I loved my Ercoupe, hope to have another one once I get my Piet
finished.
Mike Madrid
Date: Friday, May 07, 1999 8:28 AM
A friend has an Ercoupe that he likes quite a lot. Partly
because he can open the canopy while cruising. I never asked him
what it's like to land in a cross wind with no aileron controls.
So, what's it like to land in a cross wind with no aileron
controls??? It's also a really neat looking plane. I think he
bought his for only about $12,000 and it looks like a lot of
plane for the money. I think that I like it also because it was
built the same year I was, 1946.
I think you reversed one thing below. Airfoils must be more
effective at the tip, not less to prevent stall spins.
Plan form of the wing certainly affects stall characteristics -
the elipitical is referred to as the "perfect" plan form, in that
it stalls evenly from tip to root. I don't know if that's
perfect or not. Unless I get into aerobatics (not likely with a
Piet) I think I would greatly prefer a plane that stalls at the
roots first and the tips last. I think that swept back wings
also tip stall earlier. I don't remember why???
I find really good explanations of general aerodynamics in books
that are sold for the model aircraft market. They seem to cover
a lot more design detail without becoming an outright engineering
treatise that I seem to find so hard to digest in full sized
aircraft design texts. Andy Lennon is the author of one that
I've gotten a whole lot of understanding from. I can't remember
the name, but it should be easy to find by author. His book is
the one that I learned about the NASA wing design from that I
mentioned. I have another book at home that is pretty good that
is also titled as a model aircraft book, The main difference
seems to be that Reynold's Numbers are a lot more important when
dealing with small aircraft. Also, if you make a mistake with a
model and the design is unstable, you always walk away from the
crash. I'll try to remember to send the author and title later.
Columbia, SC
David Scott on 05/07/99 10:42:17 AM
cc:
etc..)
certificate...)
David Scott
Washington, IL
before
protection
aerobatic
a
> aircraft?
> cables?
> Columbia, SC
> cc:
> appreciated. Now
> Larry
> > >Dear Sirs,
be
> - on a GN-1
this.
> I'd
> > >Larry Pasley
> rig Cubs,
> > Champs,
> wingtip. I
> guess
> > Mike C.
Mike, you want your tips to stall last so that you have good control in
slow flight (aelerons are still functional). I remember well that you
use rudder to lift a wing in a stall, not aelerons). An attempt to
recover with aelerons from a spin can delay or make recovery worse. If
the wing root stalls first, the break is more gradual, and recovery is
is easier (neutal aelerons). Any attempt to use aelerons to recover a
dropped wing at the stall causes a failure of your check ride. In
Canada, spin recovery is mandatory to get your licence.
Subject: | Re: Contact with Wm. Wynne (sort of) |
In a message dated 5/6/99 3:10:51 PM Eastern Daylight Time,
mboynton(at)excite.com writes:
<< Larry,
Mark Boynton
Gilbert, Arizona >>
I just got the low down on whats going on. Seems that William Wynne is still
in business. He had some problem with a partner in the building he was in
and is moving. I had another phone number and I talked with a worker in the
other shop. He said he put a note on the door and I also had a message on
his machine. It seems as thou he has been moving stuff and has not had time
to return calls. I will get the low down on the new manual when I talk to
him, too. I expect to talk to him soon. I am telling him to call collect.
I think he has a number of people wanting to talk to him and he must have a
huge phone bill.
William Koucky
William,
Thanks for the info.
Mark Boynton
Gilbert, Arizona
> << Larry,
if
been
> Mark Boynton
> Gilbert, Arizona >>
still
the
time
collect.
a
> huge phone bill.
> William Koucky
Joe,
I have about 1/4 of washout and have checked and rechecked alignment,
but the right wing will mush and drop before the left. No clue why. Not
a problem at all, I just know that's the way it is. It's a blast to slip
to the left. Full rudder. Wing down low and if the right wing starts to
drop a little just a couple hundred RPM picks it right up. To get into
trouble you'd really have to force it.
Craig
William,
Let me know if you get in touch with Wynne before Tues. I may drive down
there Tues p.m. If he has moved, I not sure of where to look for him. When
I met him last winter, he was partners in a co. that built Lancair IV's.
They had 8 planes in varying stages of completion in that one hangar. Very
impressive.
When building the 3 pc wing, is it a good idea to make sure the wings weigh
the same? Our chapter had a discussion about building composite aircraft
and it turns out that if you build one wing in the winter and the other in
the summer (no climate control) then one wing will weigh more.
Joe (reading the plans stage)
>From: Craig Lawler <clawler(at)ptd.net>
>Subject: Re: washout and stall
>Date: Fri, 07 May 1999 14:01:58 -0500
>Joe,
>Craig
Subject: | Washout, stalls and spins.... |
To the group,
In 1970, when I completed my Pietenpol, I rigged the wings at
+2 degrees incidence and reduced this to +1 degree at the tip
rib.
Flew it that way for two years and then removed the one degree
of washout. Since then, the incidence angle is a constant +2
degrees. I cannot notice any difference in the power-off stalling
characteristics, which are about the same as those of a 65hp.
Aeronca Champion; a definite break with instantaneous recovery
upon moving the stick forward. My airplane tends to drop the right
wing first, but this is likely an individual characteristic, not typical
of Pietenpols.
I have done lots of spinning in ATC'd airplanes, but have never done
fully-developed spins in any homebuilt I have flown; only stalls and
incipient spins. If I am not sure about the spin characteristics of an
airplane, I'd rather avoid doing them at all, and practice spins and
recovery in airplanes with predictable spin behavior. I owned a Lus-
combe 8E for many years (until two years ago) and would go out at
least once a year and spin the dickens out of it. It loved to spin but,
being a certified standard category airplane, always behaved
predictably.
The Wag-A-Bond (Piper PA 17 Vagabond clone) I now have conforms
very closely with the PA 17 specification, including the large amount
of washout in the wings. In a power-off, unaccelerated stall it simply
mushes without a break and drop of the nose; one could mush all the
way to the ground by simply holding the stick fully back--but the high
rate of sink and the sudden stop at the bottom would get you.
As far as I know, BHP did not use washout, probably because the
rectangular wing planform tends to stall first at the center (or root),
progressing outward toward the wing tips which will (should?) stall
last. This is why I eliminated the washout from mine after flying it for
a couple of years.
I know of Pietenpols that have been spun, and of one case where the
pilot was barely able to recover from a spin that had flattened. This
only
reinforces my desire to avoid spinning any airplane with doubtful or un-
known spin behavior.
Graham
I think you have mistaken the "deep stall" phenomena. The deep stalls
are usually associated with T or high mounted vertical
stabalizers/elevators. The normal down pitch after a stall is due to the
fact that the elevator/stab is still capable of providing some
stabalizing force even after the wing has stopped producing lift. If, for
some reason, the stabalizer becomes ineffective, the plane will continue
to descend in a nose high, full stall attitude. This can occur on a T-tail
plane or any plane where the tail is 5-15 degrees above the chordline of
the wing. The turbulent air from the stalled wing will "mask " the
elevator and stabalizer making it ineffective. At this point, only
vigerous application of power, elevators and flaps can help break from the
stall.
You can see the result of this on an F-4 Phantom. Even though it's not a
T-tail, the delta wing and engine outlet put the root of the stabilators
in the deep stall position. You will note that the stabilators have a very
prnounced down angle to get them out of the wing shadow.
Actually, the prototype Canadair 601 Challenger was lost in just this
manner. The test plane had been equipped with an emergency drouge chute
attached to the last bulkhead inside the tailcone. Sure enough, a deep
stall developed and the test pilot fired the chute which pulled it out of
the stall. Unfortunately, the explosive bolts used to attach the chute to
the plane malfunctioned and the chute could not be cut. All of the crew
bailed out except the pilot. He almost recovered the plane but ran out of
height and impacted the desert floor. It was speculated that with another
300-500', he may have recovered enough to land it. The pilot was killed
instantly.
Ken
Yes and no. True, you hear all sorts of people complaining of a "heavy
wing". However, for the most part, these are wings that haven't been
rigged properly or have been built/rebuilt with a twist. our Cessna 180
has an 88 gallon fuel capacity, that's 44 per wing or 264 lbs. Even with
over 100 lbs differential between the wings (yeah, even with BOTH on the
selector, one tank always drains quicker) the difference in flight
characteristics is almost unnoticable. Heck, I've even flown with a 65 lb,
16' canoe strapped to one float and it still tracked almost perfect.
On the other hand, the PA-28 Cherokee had a distinct spin recovery
problem when the weight differential was too great. This prompted the
installation of "tabs" in the filler necks. If the fuel was above the
tabs, you don't spin. If the fuel is below the tabs, there is not enough
fuel in either tank to exceed the differential needed to duplicate the
problem.
However, I don't think that the few pounds in difference between the
structure of two wings will make much difference.
Ken
> >Reply-To: Pietenpol Discussion
> >Joe,
> >Craig
In Canada,private pilots are trained in spins,and must demonstrate it on
your check ride.
Subject: | Re: Subaru engine |
Back when I was interested in the subaru engine for my ace, I looked into
re-drive plans, I never found any. But there is a company which makes a fine
quality re-drive for the subaru (soob).
http://www.mts.net/davejohn/index.html
>From: Nahuel Garavaglia <ngarav(at)yahoo.com>
>Subject: Subaru engine
>Date: Thu, 06 May 1999 18:20:35 -0700 (PDT)
>Hi!,
>piet?
>thanks
>Nahuel Garavaglia
>ngarav(at)yahoo.com
Subject: | Ford A Engine Comments |
David,
Reference your question about "Any suggestions on rebuilding as far as work
that I
*should* pay someone to do for your Model A engine?" It primarily depends on
your abilities, time, and resources. If you are a machinist, my guess is you
could do everything yourself. However, purchasing the molds to pour the
babbitt into, the reamers, line boring machine etc. would probably not be
cost effective for rebuilding only one or two engines.
If you are an average engine mechanic, you could have Jim or another A-Ford
engine shop, boil and clean the block, magniflux/check for cracks, have the
cylinders bored oversize, pour the babbitt, linebore the block, and your
could reassemble everything yourself. I wouldn't really recommend that
approach. I did something similar to that once and originally thought I
would be saving quite bit of money. I think I saved less than $100 dollars.
Jim can buy the pistons, rings, valves, springs, gears, gaskets etc.
wholesale -- I couldn't. It took me all summer working part time to get my
engine back together (different engine, I sold that truck). Like many
things the Ford engine is simple to work on, but it is a lot easier if you
start with one properly put together in the first place, rather than
assembling it yourself for the first time.
Caution, there are some parts that look good and will work fine for a static
display type engine. I.e. after-market valves etc. The original and quality
replacement parts will give you great service, but over the years (ever since
the 1930s) certain manufactures produced "look a like" copies that did not
offer the same performance. Jim, would know where the valves he was
installing came from and what their track record is. (I bought a set of
valves at a swap meet that look great -- new-old-replacement-stock (NORS) but
I wouldn't put them in my engine after all the articles I read on "bogus
parts" in the Model A Club magazines.
I hope that is of some help to you. If you are planning to significantly up
the horsepower on the Model A engine, I would recommend checking into having
the babbitt bearing replaced with more modern insert bearings. I don't think
Jim offers that, but babbitt works great for stock to slightly modified
engines. Chevy used babbitt bearings in their engines until 1953 (my dad had
one with babbitt bearings -- std trans and one with inserts the automatic
trans).
Don't forget to let Jim know what you plan to do with your engine. He may
have some helpful suggestions and recommendations. Also, I haven't had an
engine rebuilt since 1989, and they may have come up with some new thoughts
and/or cautions.
Good luck with your project, if I can be of any encouragement, please let me
know.
Hap
PS I changed my e-mail from haptucker(at)hotmail.com to FordPiet(at)aol.com.
Subject: | Re: Washout, stalls and spins.... |
I took flying instruction from an elderly man in the Wentzville MO.
area, when I did stalls he made me keep the wings level with rudder
and to stay away from aileron saying that if a wing didn't have wash out
or was improperly rigged the ailerons could get you hurt
He claimed that if you praticed stalls using nothing but rudder
to keep the wings level it was a lot safer in a homebuilt or
some of the older factory planes.
-----Original Message-----
Date: Friday, May 07, 1999 3:59 PM
Subject: Washout, stalls and spins....
To the group,
rib.
typical
of Pietenpols.
an
but,
predictably.
amount
simply
high
root),
for
a couple of years.
This only
un-
Graham
From: | robert hensarling <rhrocker(at)admin.hilconet.com> |
Date: Saturday, May 08, 1999 3:30 PM
Subject: Re: Washout, stalls and spins....
I don't know Russell, but that method seems like a good way to get
into a spin to me.
Robert Hensarling
http://www.mesquite-furniture.com
Uvalde, Texas
out
To the group,
rib.
stalling
right
typical
of Pietenpols.
done
and
of an
and
Lus-
at
spin but,
predictably.
amount
simply
the
the high
root),
stall
flying it for
a couple of years.
the
This only
doubtful or un-
Graham
Subject: | Re: Aluminum spars |
Yes the April issue of the experimenter has article on
aluminum spars taken from a book I think the name
of the book was Stress without Tears and can be
ordered from the EAA, does comparison on I
beam (wood) solid spar, box spar, and similar
Aluminum spars which of course win in the
strength to weight all out testing. I hope you
like math!
Date: Friday, May 07, 1999 10:39 AM
Subject: Pietenpol-List: Aluminum spars
>To all:
any
>Mark Boynton
>Gilbert, Arizona
Nahuel,
I have some info as soon as i get time
I'll dig it out of my collection and
email to you. Also us your search engine
to look things up, theres a lot of info
on the ea-81, ea-71 and the bigger one
EA-92 (16 LBS. heavier few more hp.
on the internet however if you plan
on using a ea-81 in a Pietenpol
I would plan on a reduction drive.
do search on +EA-81 SUBARU
you'll find more info than you can
imagine.
Date: Thursday, May 06, 1999 8:20 PM
Subject: Pietenpol-List: Subaru engine
>Hi!,
>piet?
>thanks
>Nahuel Garavaglia
>ngarav(at)yahoo.com
Russell,
Your instructor was absolutely right in insisting that only rudder
be used to keep the wings level when doing stalls in homebuilts
and older designs. My instructors said the same thing and when
fooling around with stalls, I keep off those ailerons! Most of the
older designs have non-differential ("barn door") ailerons, which
can cause trouble if misused.
Possibly some more modern designs are less critical in this regard.
I never did stalls and spins with the few I have flown, and thus don't
know their stall/spin characteristics. Perhaps others in the group
could provide some information in this regard.
Graham
Russell,
in
doing
said the same
thing and when
off those
older designs
have
non-differential (barn door) ailerons,
which
are less
the few I have
others in the group
this
regard.
Graham
From: | walter evans <wbeevans(at)worldnet.att.net> |
Russell,
I aggree with you. You never use aileron to keep wings level in a stall.
Of all the planes I flown, and all the instructors, non said to use
ailerons. Ailerons are ineffective due to the air not flowing over
them. Using rudder increases airspeed at the tip of the outside wing
and lifts it like magic.
Just get ready to.... dump the nose and "Step on the high wing"
walt
From: robert hensarling <rhrocker(at)admin.hilconet.com>
Date: Saturday, May 08, 1999 4:39 PM
get into a spin to me.
Robert Hensarling
Uvalde, Texas
MO.
rudder
wash out
at
tip
degree
stalling
65hp.
recovery
right
not typical
never done
stalls and
spins and
owned a Lus-
out at
to spin but,
predictably.
conforms
large amount
it simply
all the
back--but the high
you.
the
(or root),
(should?) stall
flying it for
where the
flattened. This only
doubtful or un-
I think he meant to say: http://www.mts.net/~davejohn/index.html
> >Hi!,
> >piet?
> >thanks
> >Nahuel Garavaglia
> >ngarav(at)yahoo.com
Even in Cessna's I was taught to use the rudder to keep the wings level
in a stall.
Dean Dayton - N7167S
walter evans wrote:
> Russell,I aggree with you. You never use aileron to keep wings level
> in a stall. Of all the planes I flown, and all the instructors, non
> said to use ailerons. Ailerons are ineffective due to the air not
> flowing over them. Using rudder increases airspeed at the tip of the
> outside wing and lifts it like magic.Just get ready to.... dump the
> nose and "Step on the high wing"walt
walter evans wrote:
Russell,I
Of all the planes I flown, and all the instructors, non said to use ailerons.
Ailerons are ineffective due to the air not flowing over them. Using
rudder increases airspeed at the tip of the outside wing and lifts it like
magic.Just get ready to.... dump the nose and "Step
4:39 PM
Subject: Pietenpol-List: Re: Washout, stalls and spins....
3:30 PM
and spins....I don't
know Russell, but that method seems like a good way to get into a spin
to me.Robert
Hensarling
Uvalde, Texas
I
took flying instruction from an elderly man in the Wentzville MO.area,
when I did stalls he made me keep the wings level with rudderand
to stay away from aileron saying that if a wing didn't have wash outor
was improperly rigged the ailerons could get you hurtHe
claimed that if you praticed stalls using nothing but rudderto
keep the wings level it was a lot safer in a homebuilt orsome
russell ray
3:59 PM
Subject: Pietenpol-List: Washout, stalls and
spins....To the group,In
1970, when I completed my Pietenpol, I rigged the wings at+2
degrees incidence and reduced this to +1 degree at the tiprib.Flew
it that way for two years and then removed the one degreeof
washout. Since then, the incidence angle is a constant +2degrees.
I cannot notice any difference in the power-off stallingcharacteristics,
which are about the same as those of a 65hp.Aeronca
Champion; a definite break with instantaneous recoveryupon
moving the stick forward. My airplane tends to drop the rightwing
first, but this is likely an individual characteristic, not typicalof
Pietenpols.I have
done lots of spinning in ATC'd airplanes, but have never donefully-developed
spins in any homebuilt I have flown; only stalls andincipient
spins. If I am not sure about the spin characteristics of anairplane,
I'd rather avoid doing them at all, and practice spins andrecovery
in airplanes with predictable spin behavior. I owned a Lus-combe
8E for many years (until two years ago) and would go out atleast
once a year and spin the dickens out of it. It loved to spin but,being
a certified standard category airplane, always behaved predictably.The
Wag-A-Bond (Piper PA 17 Vagabond clone) I now have conformsvery
closely with the PA 17 specification, including the large amountof
washout in the wings. In a power-off, unaccelerated stall it simplymushes
without a break and drop of the nose; one could mush all theway
to the ground by simply holding the stick fully back--but the highrate
of sink and the sudden stop at the bottom would get you.As
far as I know, BHP did not use washout, probably because therectangular
wing planform tends to stall first at the center (or root),progressing
outward toward the wing tips which will (should?) stalllast.
This is why I eliminated the washout from mine after flying it fora
couple of years.I
know of Pietenpols that have been spun, and of one case where thepilot
was barely able to recover from a spin that had flattened. This onlyreinforces
my desire to avoid spinning any airplane with doubtful or un-known
spin behavior.Cheers,Graham
I didn't know there was a mailing list for the Piet! Good to see! I've
been building for about 8 months. I've got the ribs, tail feathers and one
side of the fuselage built and have bought two 110 corvair engines. How
can I get previous posts on this mail list? Anyone using a ram air cooled
corvair on their Piet? Don't really like the odds on throwing a fan belt.
Wayne Sippola
Winnipeg
Hello Wayne
Welcome to the list. I am building in Alexander just west of Brandon and
have about the same amount done except not using a corvair. There is a Piet
builder in the RAAC Winnipeg chapter, Dennis Scarfe,who I heard was building
a piet. E-mail me back and we can exchange Phone numbers and have a chat
about Piets. A couple of hundred clicks isn't too far away.
John McNarry
Date: Saturday, May 08, 1999 6:05 PM
Subject: Pietenpol-List: hello
>Wayne Sippola
>Winnipeg
In response to mike bell and his question on the stall in a piet. my piet
stalls very gently and can be held in a full stall with the stick back and
the wings held level with just a little bit of rudder. I believe that this
is called the "falling leaf maneuver". My piet also spins and recovers very
nicely with opposite rudder. I have only spun the piet with the instructor
on board but it spins both right and left and recovers very nicely.
Duane woolsey Piet NX6398
> huge phone bill.
> William Koucky
I met William Wynne a few years ago when he got to fly with Steve
Wittman in his Olds powered Tailwind. William was a super guy, aviation
in the blood type. Just keep one thing in mind, he doesn't make a
living and probably barely recovers costs from his experiments with the
Corvair engine, so be a little patient with him while he moves things
around. He will be the one carrying all the boxes, machine tools, etc.
himself.
Welcome aboard! I'm in Thunder Bay, Ontario and am looking at the same
thing, whether to keep the Corvair with the fan, or look at using a
baffle/ ram system. I have a good core and have stripped off about 50
pounds of metal that won't be needed. The engine itself looks like it
would be easy to adapt. I am planning electrics, but no starter, as it
looks reasonably complicated to include one.
My unit is now on the gear, the wings are built and I am getting pretty
close to a pre cover inspection. So far the logged construction time is
at 850 hours. If you get to Thunder bay, let me know and we can compare
notes.
What is the max. up elevator deflection on your piet??
Doug
> From: Dlwoolsey(at)aol.com
> Date: Sunday, May 09, 1999 12:31 PM
piet
and
this
very
instructor
What is the distance from your firewall to the axle centerline?,and the
distance from the firewall to the gear front pivot point? Please.Have seen
at least 3 different specs so far.
Corvair with fan ,alt but no starter. Doug in Alberta.
> From: Ian Holland
> Subject: Re: hello
> Date: Sunday, May 09, 1999 6:25 PM
> notes.
Any one else using the West system for glue? I am and I will probably use
it for varnish as well. I understand many wooden boats are using it. I
Just ripped up $100 Cdn worth of fir into longerons last week. Beautiful
piece of lumber with 35 rings to the inch. Have not found any vertical cut
lumber locally but should be able to get it ordered in. Got a set of old
Cleveland hubs, brakes and master cylinders plus 30 feet of streamlined
tube for the struts at a local airfield for a good price.
Good to know there are some builders close by, Ian and John. I fly on
435
sqn with Dennis Scharf, so I know him well. Guess that's all for now.
Wayne Sippola
Winnipeg
Front edge of firewall to the axle centreline is pretty close to 16
inches. FE of firewall to the centre of the front attach point is 12
inches. I am using tubular gear with wheels (600x 6) and brakes from
Tracy O'Brien. I used the jig diagram suggested by Bill Rewey June '92
in the BPA Issue 36 . It worked out pretty good, and saved a lot of
hassle.
I built the extended fuselage and hope I don't end up with too much
weight on the tail. Hard to tell at the moment as the motor has not yet
been mounted. I'm guessing at 40 pounds as she sits now.
From: | Dave and Connie <dmatt(at)frontiernet.net> |
Wayne,
I suggest that you get in touch with Western Aircraft Supplies
in Calgary. Jean sells really nice spruce. I had mine sent
to Rochester, NY from there.
Dave
Thanks for the quick reply,my fuse is about 4 inches longer i think,about
16 inches from firewall to the gear pivot(front),cloned my gear from Graham
Hansen's CF-AUN,has the same measurements,his has a C85 sans electrics,so
is probably lighter.I am concerned mine will be light in the tail,so have
installed the batt. tray there,my gell cell is about 12 lbs.My Piet was
painted ENERGY YELLOW in Airtech process last week,is the most intense
yellow i have ever seen!Starting final assembly now,have to build the
cowling yet,not sure how i will do it yet,will have to be light,have to
much up front already.
Will let you know how it turns out.
Doug
> From: Ian Holland
> Subject: Re: hello
> Date: Sunday, May 09, 1999 10:15 PM
> hassle.
Wayne
I have been using the West System and have no complaints about it at all a
really good product. I aquired some syringes from the vet. that make
measuring out small amounts easier than the pump system that came with the
cans. Perhaps some day in the future we can host a Western Ontario, Eastern
praires Piet gathering. :-)
John Mc
PS Say hello to Dennis for me.
Date: Sunday, May 09, 1999 6:32 PM
Subject: Pietenpol-List: Re: Glue
> Good to know there are some builders close by, Ian and John. I fly on 435
>Wayne Sippola
>Winnipeg
I feel rather sure I want to build a "Pete". Can you help me hook up
with someone in the Houston, Tx. area? The first order of business seems
that I should see how one suits me. Any help will be greatly
appreciated. Any info on "Petes".....anything at all will also be
appreciated. I'm sure I'll be talking to you again. Thanks.
From: | Greg Cardinal <gcardinal(at)startribune.com> |
Am building a long fuselage, Jenny style gear, A-65 powered, brakeless
Piet. The distance from the firewall to the axle centerline is 19".
Greg Cardinal
>>> Doug 05/09 6:03 PM >>>
seen
> From: Ian Holland
> Subject: Re: hello
> notes.
Kyle,
Mark Boynton
Gilbert, Arizona
> like math!
> Subject: Aluminum spars
> >To all:
about
> any
offers
> >Mark Boynton
> >Gilbert, Arizona
No, no, no. You got it all wrong. If your right wing starts to drop, put
in full right rudder and full left aileron. You'll never get a good spin
by avoiding ailerons and stepping on the high wing. Better still, if you
use full power, it will spin real nice to the left. ;-)
Ken "it's not a spin unless there's at least 3 rotations" beanlands
On Sat, 8 May 1999, walter evans wrote:
> Russell, I aggree with you. You never use aileron to keep wings level in
> a stall. Of all the planes I flown, and all the instructors, non said
> to use ailerons. Ailerons are ineffective due to the air not flowing
> over them. Using rudder increases airspeed at the tip of the outside
> wing and lifts it like magic. Just get ready to.... dump the nose and
> "Step on the high wing" walt
I've been using it on my Christavia MK 1, here in Calgary. I have found
that it is ver strong and due to it's thin viscosity, it really works its
way into the wood. The only problem is that the same thin viscosity makes
it poor for gap filling. I've been using a combination of T-88 for
structural joints and West-System stuff for laminations.
As for using it as a varnish, keep in mind that it is NOT impervious to
UV. If left untreated, it can detiorate over time. I built a canoe using
the West-System epoxy and was warned of this from several sources. It was
actually finished with a UV protective varnish. However, I have heard that
there is no problem applying fabric over the epoxy resigns. So, unless the
area is exposed to direct sunlight, go for it.
Ken.
435
> Wayne Sippola
> Winnipeg
Subject: | Re: rear step hole and tail handle |
> once had a 1930 Buhl Bull Pup that had a retractable
> tube-within-a-tube that
> was actuated by a plain 'ol screen door spring and
> had a finger ring welded
> on the end to grab it with. Worked like a charm, but
> on the Piet there isn't
> room to keep it inside the fuselage and fit under
> the torque tube. Maybe
> someone else can suggest a way to mount one like
> that. Good luck
> Don Hicks
About 6-8 years ago Mr. Olsson (spelling?) from Arizona
had his very nice piet at Oshkosh. He had several
interesting features on his plane. (One that I am quite
interested in was his raising of the bellcrank to the
elevators to a higher position so that the elv. cables
did not rub on the stabilizers when the plane was at
rest.) He had built a very nifty retractable step to
assist in getting into and out of the cockpit. I am
sorry, but I do not remember the details. But I have
noticed in the roster that he is a menber of the BPA, so maybe you
could contact him and find out. Like all
BPA guys, he was very friendly and ready to answer any
questions I had--my problem was that I was not yet
building so wasn't yet ready to absorb all he told me.
Note the lesson to be learned: show up at Brodhead and Oshkosh with a
notebook ready to write down the
things you learn, and don't be afraid to ask questions.
John in Peoria
To All Flying Corvair Piet. owners,
My current Stats:
Engine static = 2600 RPM
@ Full throttle in Cruise + 2600 RPM
aircraft weight and balance is well within the envelope.
Aircraft empty weight = 807 Lbs.
Aircraft engine feels like it is flying with a governor on it.
My Problem: It flies slightly tail low or in a nose high attitude like it is
underpowered, or you were flying in slow flight. My clinb to 800 ft. circuit
altitude above the ground was slow.
timing: currently set for 14 deg. BTDC with the vacumm advance wired in one
position. But I don't know which posion is full on or full off right now.
The engine starts easy. I have a starter installed.
Propeller: Home made 66X32
This week-end the intake including the 'Y' split before the runners to the
intake boss was replaced. The result was ...no change. Not even 1 RPM
difference. There could only be 1 of four problems or a combination. 1.
Fuel 2. intake system 3. Propeller 4. Timing.
I'M next going to illiminate Timing.
So here are the questions:
What did y'all do to the distributer, ie weights, springs, vacuum advance
Plate?
Some of the literature I've read said to change the springs to 1960 model
year, but when I looked up the specs... they were exactly the same tension
rating.
Should the weights be welded to full advance or otherwise.
In what position did you lock the vacuum advance?
What timing was it set at idle?
What should it be at full throttle/static?
Should I expect any improvement with timing changes?
What RPM are y' all achieving and with what prop. pitch?
I would appreciate your knowledgable response as soon as posible.
Stuck with "aircraft on ground",
Domenic
Subject: | Re: Ford A Engine Comments |
Hap,
Thank you for the information.
David
>David,
>that I
>trans).
>and/or cautions.
>know.
>Hap
Don't forget the camera and plenty of film!
John Mc
Date: Monday, May 10, 1999 12:20 PM
Subject: Pietenpol-List: Re: rear step hole and tail handle
>John in Peoria
Subject: | Re: Corvair Fishing |
Domenic
You could set the timing plate in a locked position so that the vacuum
advance is inoperative the vac advance is only used on cars at part throttle
for economy cruising at a lean mixture. The static timing (retarded) should
be as the corvair to ensure easy starting. The springs need to be only
strong enough to return it to statc timing at low power settings. The max
advance can be limited or changed by the pins or slots that the weights move
in.( alittle welding a little filing) If you can find advance curve diagrams
for a corvair at peak torque speed set the max for that. The timing won't
need to change once you have it started and the throttle set for enough
power to keep it in the air. Aircraft mags dont have advance curves just an
impulse on one mag for starting.
John Mc
Date: Monday, May 10, 1999 12:41 PM
Subject: Pietenpol-List: Corvair Fishing
>My current Stats:
is
circuit
>Plate?
>rating.
>Domenic
Domenic, I appreciate the info. As I am just starting on the Corvair,
and trying to get the rebuild manual from William Wynne (as you probably
have seen), van you recommend another Corvair manual, or source? My unit
has twin carbs, one on each intake manifold, so I am assuming that i
will have to make up a carb mount and splitter feed header to connect. I
think this is the piece that split that you were referring to. My block
number is T0429RH which I make as 1967 april 29 for manufacture.
I have removed the transmission cover and the crank and cam gears have
absolutely no indications of any wear on them, yet the amount of oila nd
grease on the outside (including a petrified mouse under the belt end)
indicates that it has not been overhauled previously. With the plugs
out, and a squirt of oil in each cylinder, the motor turns over by hand
easily (using the fan belt to pull on). I have not checked the
compression as I have to strip the unit to get at the crank for
threading.
All in all, a very interesting motor!
I guess if I can't contact Mr. Wynne, i will go with another rebuild
manual. Any suggestions out there? I have the Corvair Underground
catelogue coming, but would appreciate any commentsfrom those of you
that have gone through it.
-=Ian=-
Domenic, it sounds like you should revisit the rigging. I remember
reading somewhere that the issue you are describing is corrected by
shimming the horizontal stab, but I don't remember how much. Might be
worth while talking to an airframe guy. If I can remember where I saw
it, i will pass it on.
To Peoria John Fay.........thanx for the info on Mr Olson (sp?) of Arizona.
I'll follow up and try to get his address. ill pass it along if it proves
successful. Don Hicks
Downloaded Domenic's photo's. Beautiful work! I intend on going a much
simpler route with the prop hub bolted to the crank like DHP used. I am
pretty sure I'll stay with the original ignition and carbs. How easy is it
to hand prop a corvair? With the small cylinders I would think it would be
easier than the A Ford. I got the GM corvair manual and found I will need
to have the crank ground 10 thou. The journals average 1 thou under
allowable and I'd like the bearings in good shape.
Long way from it but am thinking about building the wings as per the plans
with the spars spliced over the cockpit. However I think I will modify
slightly and cover each wing separately with another cover over the
joint/fuel tank area. The wing won't fit in my garage in one piece and I
don't think I'll have to take it apart much once it is flying.
Just laying up the second fuse side. I would like to put the ply skin
on
both sides of the fuse before I join them together. Is this a good idea or
should I skin the second side after all controls, seats etc. are in?
Wayne Sippola
Winnipeg
> From: John McNarry <jmcnarry(at)techplus.com>
> Subject: Re: Corvair Fishing
> Date: Monday, May 10, 1999 7:06 PM
> Domenic
vacuum
throttle
should
move
diagrams
an
> John Mc
> From: BELLISSIMO, DOMENIC
> Subject: Corvair Fishing
> >My current Stats:
it
> is
> circuit
one
now.
the
advance
> >Plate?
model
tension
> >rating.
> >Domenic
Subject: | Re: Michael Cuy's video |
Wow, have I had a great week already. I received Mike Cuy's
video over the weekend and my Piet plans yesterday. Talk about
pumped up!
Mostly I wanted to comment on the value of the video. It is
great. He certainly sets a standard for construction and I love
to see the Piets flying. I've never seen one live and the flight
part of the video is a lot of fun and encouraging. I whole
heartedly recommend it to anyone who wants to get some good ideas
and experience a little of what the aircraft is like.
Are there any Piets under construction or flying in South
Carolina? It seems that most of the activity is in the mid-west
and Canada. I'd like to get up close to one and get 3D and
tactile views. I'm sure that I could see plenty at Oshkosh but
that is out unless I can get a businees trip to Chicago at the
right time and that is not likely.
Mike Bell (NoPietYet)
Columbia, SC
Subject: | FW: Corvair Fishing |
Wayne,
My prop.shaft/Hub is also bolted to the crank using the original 6 bolt
pattern, but not on a threaded crank. I left it as it was. The shaft is
supported by a dual angular bearing ( made by G.M.- New Departure). The
Shaft is stepped so that it rests on the inside race.This is easier than
threading the crank. I then brought forward an oil line the spray the
bearings. I had the end and bell housings cast ($100.). I made the Kapler
designed 3 piece wing. If you ever need to take it apart, away from your
home airport it would help you tremendously. I closed my fuselage side at
the very last moment. Even after I closed it, I found it difficult to work
inside. Another friend left the firewall off untill the last moment. The
ignition is original except I installed a second coil (switched if needed)
for redundency.
Domenic/ Toronto
plans
skin on
Wayne Sippola
Winnipeg
> Domenic
vacuum
throttle
should
move
diagrams
an
> John Mc
> >My current Stats:
it
> is
> circuit
one
now.
the
advance
> >Plate?
model
tension
> >rating.
> >Domenic
Subject: | FW: Michael Cuy's video |
I'm sure there must be some Piets in your area. Can you not get on the
U.S.A. aircraft registry and do a search?
Try to come to Oshkoshor Brodhead this year, it's the 70th Anniv. , One not
to miss.
Domenic/ Toronto
pumped up!
Columbia, SC
Subject: | Re: Adjustable lift strut attachments |
I finally got in the replacement barrel ends for my struts and replaced
the old ones. You may recall that I had tapped what I though were poor
quality threads in the barrels before I installed the original set only to
find out that this tight thread is done on purpose . It accomadates the
expansion that occurs due to welding. I welded them in on the weekend and
ran the tap down last night. Before I welded them in, there was no way to
install the fork ends. After I finished, ine was still very tight and
needed the tap. The second had, indeed, expanded to the point where the
rod end would fit with just a little persuasion. I didn't persuade it too
much and instead ran the tap down to clean up the thread. It was an
expensive lesson as the barrels cost about $50 each, but I feel a lot
better about them now. I also bought 2 new, rolled thread, magna-fluxed
rod ends at about $50 each as well.
Fortunately, I was able to afford the new parts because I substituted
round tube struts in place of streamlined stock. Now, I just have to
figure out how to streamline them without breaking the bank or getting too
heavy. My current plan is to hot wire some foam blocks to form the
fairing. I can then attach them to the strut and cover with fiberglass.
BTW, aircraft lock wire works great for hot wire cutting. It has enough
resistance to get some good heat going.
Ken
Subject: | FW: corvair fishing |
Thanks Doc,
This is exactly what I needed.
dominic:
Call William Wynne at(904) 426-6028 in Port Orange Florida. He can help
you.
As Bill says in his "Corvair Conversion Information Pack":
Points and Concdenser: Use AC or Echlin (NAPA) standard points. (The
heavey duty points have a high spring tension, which is not necessary at
rpms below 4000.)
Cap and Rotor: Echlin RR1820 and RR1830 are respectively very high quality
brass contacts. These come from NAPA stores. (Do not settle for the RR182
or RR183, these are the standard ones.)
Coil: I use Accel super stock coils. This and mamy other 12 volt coils
must have a ballast resitor in the current circuit so that the coil gets 12
volts to start, but only 6 volts to run. This is mandatory. The stock GM
coils have a special resitance wire in the harness to perform this function.
Remember to put AN365 nylon lock nuts on the electrical connections to the
coil.
Distributor and timing: When someone tells me that his Corvair is not
making the proper power it should, my first suspicion is the timing. Many
people set the timing at idle and leave it. This is not good enough. You
must know how much ignition advance you set at the rpm you will be flying
the engine.
After 30 or so years of service, most Corvair distributors are tired. Most
of the Corvair parts houses sell remanufactured distributors with the Dale
brand points plate. I highly recommend these. (When the top bushing is
worn out on the distrubutor the dwell will change as it runs, and will wear
the cap and rotor.) You cannot expect reliable performance from a worn
distrubutor. The old distributors have a tendency to have sticky mechanical
advances.
When setting up the distributor for your engine, remove the vacuum advance.
This advances the timing when the engine is at high rpm but at low load.
This condition does not apply to airplanes with fixed pitch props where a
given rpm will produce nearly the same load. Lock down the points plate so
it cannot move. Mark the balancer at 34 degrees...this in now you timing
"RedLine." (sic) This must be done with a certain degree of precision.
Detonation could result from having the timing advanced more. Use light
weight springs on the mechanical advance weights. You want all the advance
by 2000 rpm. When you run the engine, watch the advance work with a timing
light. Work on the mechanical advance if you are not getting full advance.
For hand prop engines, I set the distrubutor at 8 degrees static, and make
sure it will advance to 32-34 degrees. On electric start engines, set the
static at 12 degrees and make sure it will advance to 32-34 degrees. This
is very important. Without full advance, your engine will not make full
power.
Hope this is of lome help to you. Pictures were great!
Doc Mosher - Neenah WI
docshop(at)prodigy.net
From: | Michael D Cuy <Michael.D.Cuy(at)lerc.nasa.gov> |
Mike- Thanks for the kind words about my video. (the rebate is in
the mail :))))
Sanford NC, Jimmy and Connie Dean have a nice A powered black
and yellow Piet at their home airstrip. I belive they are on e-mail.
I'm sure Grant has thier home address.
It's not flying....fabric work to be done.
Mike C.
Hi Ian,
Before going any farther with your Corvair engine, I strongly recommend that
you consult two books. The first is "How to Hot-Rod Corvair Engines" by Bill
Fisher, the second is "How to Keep Your Corvair Alive" by Richard Finch.
Both books are invaluable resourches of tips and tricks for rebuilding,
modifying, and maintaining these engines. Both books also discuss their use
in aircraft. In fact, in the latest edition, Finch even talks about the
installation of a Corvair engine in his Cessna before selling it for use in a
Piet. If I recall correctly, his engine had a PSRU built by Bud Rinker.
Here's some advice I received when searching for rebuild assistance from a
lifetime GM mechanic-sage who shares his love of Corvairs on a few different
internet platforms:
>ABSOLUTELY- you MUST get a copy of Bill Fisher's excellent book, "How To
>HotRod Corvair Engines"- it was originally published by HP books in 1964?
>and has been revised and updated many times since then, Clarks Corvair
>Parts currently holds copyright on it, and sells it- it may also be
>available other places. Read it carefully, its the best book I have ever
>read hands down on automobile engines of any type.Theres some aspects in
>the book that must be taken with a grain of salt, as it was written when
>parts were still cheap and plentiful, but theres more information in there
>than you'll believe.
You also need to get both the Clarks catalog and the Corvair Underground
catalog. I learned a lot from them.
I, too, am waiting for the resurrection of William Wynne.
--Peter
Do they really have to be streamlined. I've noticed several light planes that
simply use round tube. Does it really make much difference? This is a
question, not an opinion;-)
Dean Dayton
Ken Beanlands wrote:
> Now, I just have to
> heavy.
Subject: | Round vs. Streamlined |
Dean Dayton wrote:
Dean-
for his lift struts and they look good. I think the streamlining
is more for the eye than for drag reduction......especially on
something as draggy as a Piet. I've heard of guys using balsa wrapped
w/ dacron, foam, etc. to fair the tubes.
Mike C.
I've located a shop that has an after market distributer kit. It includes
heavier weights and three sets of springs, Light medium, heavy for the
corvair distributer. They could not tell me which of the sets would open to
full advance @ 2000 RPM. Does anbody know what tension of spring should be
used for this application? The specs I've found in al the corvair literature
are all the same.
Domenic
Domenic
John Mc
>My current Stats:
is
circuit
>Plate?
>rating.
>Domenic
Subject: | Re: Round vs. Streamlined |
This round tube strut then wrapped with fabric over balsa is how I did my
struts for my '24 Dormoy 'Tub. One heck of a lot cheaper than streamlined
tubing...could be done with Gary Price's rectangular tubing method
too..........
Earl Myers
From: Michael D Cuy <Michael.D.Cuy(at)lerc.nasa.gov>
Date: Tuesday, May 11, 1999 2:03 PM
Subject: Pietenpol-List: Round vs. Streamlined
>Dean Dayton wrote:
>>Do they really have to be streamlined ?
>Dean-
>Mike C.
Subject: | RE: Adjustable lift strut attachments |
Duane has round tubing and has over 100hours and hasn't fallen out of the
sky. I haven't streamlined my D-tube aluminum struts and still go flying
regularly. I guess my point is that drag reduction on the piet is kind of
an oxy-moron. Asthetics is the bigger consideration.
Stevee
Steve Eldredge
IT Services
Brigham Young University
> dean dayton
> Sent: Tuesday, May 11, 1999 12:16 PM
> Subject: Re: Adjustable lift strut attachments
> light planes that
> Dean Dayton
> > Now, I just have to
> or getting too
> > heavy.
There is one advantage to using some sort of streamling. The drag
reduction may not have a great effect on the overall speed of the plane,
but they do increase the force on the tubes. In my case, there is 9' of
strut tubing with about a 5.5' span unsupported (by a jury strut). Under
compression, the main failure mode is buckling with a tube of this
geometry so if the tube already has a buckling load (imposed by the drag)
it's that much more prone to failure. Streamlined tubing is very rigid
fore and aft due to it's shape and is also under less load.
I plan on countering some of the fore/aft loads by adding a cross member
to the 2 jury struts to form an "N" shape. There is a forth strut that
spans the two main struts at the jurry fittings.
However, I did notice that Chris Heintz has used round struts on his
latest creation, the CH-801. THis is the 4 place, 180 hp followon to the
CH-701. If an airplane this big and ugly...err..heavy can get away with
round tubing, ours should be a snap.
Ken
On Tue, 11 May 1999, Michael D Cuy wrote:
> Dean Dayton wrote:
> Dean-
> Mike C.
Thanks, Peter. I appreciate the info, and will see what I can do to get
them.
Ken, mind sharing where you got the barrels and forks from? Also, the
tube diameter and thickness along with the rational for it?
-=Ian=-
This is a note about the fuse skin....this is the second wooden plane that I
put the skin on the fuse while it was flat ( just assuming that was the way
to go) , but anyway, just remembered that when I tried to get the rear seat
in( the part you sit on,) it wouldn't go in the fuse. This is the long
fuselage for the A65, and I built the seat complete , less the top. When I
went to put the top in, it wouldn't go. Had to shave and scrape and bend to
get it in. This was made exactly to the print.
And while thinking of it, when putting the control tube assembly in the
bottom of the fuse, it was too long and had to cut an access notch in the
back seat to clear the tube.
Anyone else have this problem?
walt
Date: Tuesday, May 11, 1999 9:45 AM
Subject: Pietenpol-List: Re: Corvair Fishing
> Just laying up the second fuse side. I would like to put the ply skin on
>Wayne Sippola
>Winnipeg
>> Domenic
>vacuum
>throttle
>should
>move
>diagrams
>an
>> John Mc
>> >My current Stats:
>it
>> is
>> circuit
>one
>now.
>the
>advance
>> >Plate?
>model
>tension
>> >rating.
>> >Domenic
Subject: | Weight and Balance |
Hi List!
When I aquired my GN-1, it didn't include the GN-1 plans used in its
construction. I'm interested in checking the CG, and am wondering if I can
use the formulas that were in the last newsletter (which I think were for
the Pietenpol) for th GN-1, or is there another way to figure the GN-1 CG.
Mine has a 65 HP Cont, and the fuel tank in the forward cockpit.
Thanks in advance!
Robert Hensarling
ASC BFI
PPL GN-1 N83887
Domenic:
Do you have a variable speed drill? The distributor would be turning at
1000 rpm at 2000 crankshaft rpm. You might be able to cobble up a
distributor test device using a drill to drive it and a strobe type timing
light to measure the advance and rpm. You would also need a degree wheel. I
saw that somone else posted the advance degrees you need. Better yet would
be to find someone with a distributor test bench. They aren't so common now
that most vehicles have gone to electronic ignition. Don't overlook bushing
wear and breaker point spring tension.
John Mc
Date: Tuesday, May 11, 1999 12:11 PM
Subject: Pietenpol-List: FW: Corvair Fishing
literature
>are all the same.
>Domenic
>From: jmcnarry(at)techplus.com
>Date: Monday, May 10, 1999 8:06PM
>Domenic
throttle
move
diagrams
>John Mc
>>My current Stats:
>is
>circuit
one
>>Plate?
>>rating.
>>Domenic
Walt, I put the notch in the back of the seat as per the plans. The back
torque tube brace is mounted to the cross brace as per the plans.
I had some input from the group early on, and framed the fuselage Two
sides and cross braces, then put the seat together piece by piece. It
was tight, but no problem.
Subject: | Re: Weight and Balance |
Robert, if you want a complete set of plans for a GN-1 for reference,
let me know. I bought them and never pursued it. Make me an offer.
-=Ian=-
Date: Tuesday, May 11, 1999 7:35 PM
Subject: Pietenpol-List: Re: Weight and Balance
Hi Ian, sure, I really ought to have a set. How much, and where to send the
check?
Robert Hensarling
Uvalde, Texas
>-=Ian=-
robert hensarling wrote:
> Hi List!
> Thanks in advance!
> Robert Hensarling
> ASC BFI
> PPL GN-1 N83887
Robert,
Tony Bingelis's book "The Sportplane Builder" has a good section on
weight and balance. You can get from EAA. You should be able to use it
with no problem.
Basically, if all your trying to do is locate where the CG is, you
should be able to find it without much effort. There's an old
engineering trick called "summation of moments about a point" that will
tell you exactly where the CG is. No real voodoo there.
Or, you should be able to do one similar to the one in the BPA
newsletter (third quarter 1998). Unfortunately, there was a mistake in
the data sheet printed that indicated a pilot weight of 115 lbs. That
should have read 155 lbs - I E-mailed Grant Mclaren with the correction
later but I am not sure if it was ever corrected. The CG on that one
(Poplar Pete) turned out to be right where it' supposed to be. I got a
hop in it the other day and it flies right in trim.
Ask around the local airport or talk to a local engineer-type. There
should be someone that can help you. Good Luck.
PS: I've got a GN-1 on the gear now and am putting together a site for
"Aircampers" both Piets and GN-1s. I just got it up and running in a
basic form today-its still under construction. You guys visit when you
can.... I'm no expert but if I can help with the weight and balance -
ring me up at...
bwm(at)planttel.net
www.bwmproductions.com/GN1
Cheers
Bert
Date: Tuesday, May 11, 1999 8:15 PM
Thanks Bert for the info. The log book indicates a weight of 706, and a CG
of 14.5, and that the leading edge was used as the datum. I just wanted to
try it myself to see if I could get close to the original calculations.
Robert
>> Hi List!
can
CG.
>> Thanks in advance!
>> Robert Hensarling
>> ASC BFI
>> PPL GN-1 N83887
>Robert,
>with no problem.
>ring me up at...
>bwm(at)planttel.net
>Cheers
>Bert
Ok guys, one more thing here. I bought the Flight Simulator 98 that someone
suggested, then got the Microsoft Sidewinder that someone suggested.
Problem is I don't know exactly how to download the piet into the program.
Seems like I was able to download it the other day, but I don't know where
it went, except I know it didn't go to the 98 program. What am I doing
wrong here?
Robert
The plans I have are incomplete for my GN-1, but they include the weight
and balance information. The plans and a few other items are at a friends
right now, but should be home this week-end. If you still need the W/B when
I get them, you are welcome to it.
Thanks, Larry
> Hi List!
can
> Thanks in advance!
> Robert Hensarling
> ASC BFI
> PPL GN-1 N83887
Bert, I tossed you an e-mail re the extra fork ends that you had.I am
not sure if it went. I am interested if you can let me know what you
want for two sets.
I was thinking about how to streamline round tube with foam, and decided
that I would glue some sandpaper around a piece of round tubing, then file
the grouve in the foam with the sandpaper covered tube. then once the foam
is sanded out, and fitted and glued to the tube, I would sand the foam to
the streamline shape on the outside, and cover with fabric.
ocb
>From: Ken Beanlands <kbeanlan(at)spots.ab.ca>
>Date: Tue, 11 May 1999 08:54:26 -0600 (MDT)
>Ken
Can anyone help me locate a Piet Builder or owner near the Houston,
Texas area? I simply do not know how to start about this. I really want
to fly one first before building one, but if mine is the first one then
I'm sure I can't be too disappointed. Any suggestions?
> -=Ian=-
I've got to ask but don't want to sound stupid. What is a GN-1? Is
there a web site for the GN-1? Does it compare to the Piet and if so
how? Thanks in advance and may you be blessed with a tailwind. Randy
Gaskins
Subject: | Re: one other thing |
Robert, why are you flying the simulator when you can fly the GN-1. Tell
you what, I'll figure it out for you, send me the GN-1!
Subject: | Foam streamlining struts |
I assume that whom ever has used foam that you have used fiberglass on the
foam before applying fabric. Surely the foam would not stand the fabric
cements or the heat. Seems like wood would be easier. Am I missing
something?
Steve E
Provo UT.
PS. Yesterday was so nice I had to extend my lunch for an hour. Honest I
was back to work on time, just 1000' too high...
SE
> Behalf Of oil
> can
> Sent: Tuesday, May 11, 1999 9:38 PM
> and decided
> tubing, then file
> once the foam
> the foam to
> ocb
> and replaced
> were poor
> accomadates the
> the weekend and
> was no way to
> point where the
> persuade it too
> magna-fluxed
> or getting too
> fiberglass.
> has enough
> >Ken
Subject: | RE: Weight and Balance |
Randy,
Long time no hear! The GN-1 is a Piet look a like. It was based on the
piet, but modified to accept what was once redily available Cub parts, and a
continetal engine. It is generally 50-100lbs heavier than a stock piet, and
uses a different airfoil. There are other differences, but they look very
similar. I have heard they fly similarly as well, but I haven't had the
chance to fly one yet.
Steve Eldredge
IT Services
> RGASKIN
> Sent: Wednesday, May 12, 1999 5:00 AM
> Subject: Re: Weight and Balance
> reference,
> > -=Ian=-
> Gaskins
Randy- In addition to the good points Steve E. mentioned,
the GN-1 has a 'fixed' wing position relative to the fuselage.
The Piet's wing can be moved fore and aft to various
degrees to accommodate all the marvelous combinations of
your dreams- engine type, pilot weight, fuel locations, etc.
To make your center of gravity right on a GN-1 you either have to:
get it right the first time......make your engine mount longer or
shorter.......or add ballast. Both planes fly very similar although
the Piet generally has better climb and smaller engines due to it's
inherent empty wt. being lower. Then again if a Piet is overbuilt and
comes in with too heavy of an empty weight, you can kiss the
advantage goodbye. Hope this helps !
Mike C.
Subject: | Re: Foam streamlining struts |
Actually, you would have to use fiberglass for 2 reasons. First, the foam
probably won't stand up to the covering chemicals. Second, struts are
commonly used for ground handling. People push the plane forward by the
struts. It may be fine that YOU know not to push on the struts, but will
the other people that may have occassion to move your plane know it?
Balsa was my first choice until I priced it out. It will run about $400
CDN to get enough to cover it with! Besides, with a good wire foam cutter,
you can cut the foam cores in an evening, complete with cut out for the
strut. Fiberglassing them to the strut is not that much harder. I'll be
sure and give a full report, including pics, when I'm done.
Ken
> something?
> Steve E
> Provo UT.
> SE
> > Behalf Of oil
> > can
> > and decided
> > tubing, then file
> > once the foam
> > the foam to
> > ocb
> > and replaced
> > were poor
> > accomadates the
> > the weekend and
> > was no way to
> > point where the
> > persuade it too
> > magna-fluxed
> > or getting too
> > fiberglass.
> > has enough
> > >Ken
Subject: | FW: Foam streamlining struts |
Be carefull about covering your round struts. I makes inspection difficult.
Make sure it is rust protected before the covering, if I'm not mistaken, I
believe Brian Kenny found some mild corrosion on his strut after removing
the covering. Brian can confirm this. He did not replace the streamline
covering.
Domenic
Ken
> something?
> Steve E
> Provo UT.
> SE
> > Behalf Of oil
> > can
> > and decided
> > tubing, then file
> > once the foam
> > the foam to
> > ocb
> > and replaced
> > were poor
> > accomadates the
> > the weekend and
> > was no way to
> > point where the
> > persuade it too
> > magna-fluxed
> > or getting too
> > fiberglass.
> > has enough
> > >Ken
> Mike C.
Thanks guys for the information. As the great tailwind says, build it
as per plans and a great Piet you will have. May you be blessed with a
tailwind. Randy Gaskins
To the List,
Does anyone know if the "Eelco" aluminun exhaust headers for corvairs are
still available? Are they still in business? Big Jim recommended these in an
Article he wrote for BPAN issue #31.
Domenic
Subject: | Re: FW: Foam streamlining struts |
Thanks for the advice. My struts are already scheduled for the powder
coating shop along with my LG legs and bungee struts, engine mount and
seat frame. Also, the welded ends will be exposed allowing for inspection
of the most likeli area for cracks to develop.
Ken
> covering.
> Domenic
> From: Ken Beanlands
> Subject: Re: Foam streamlining struts
> Date: Wednesday, May 12, 1999 11:12AM
> Ken
> > something?
> > Steve E
> > Provo UT.
> > SE
> > > Behalf Of oil
> > > can
> > > and decided
> > > tubing, then file
> > > once the foam
> > > the foam to
> > > ocb
> > > and replaced
> > > were poor
> > > accomadates the
> > > the weekend and
> > > was no way to
> > > point where the
> > > persuade it too
> > > magna-fluxed
> > > or getting too
> > > fiberglass.
> > > has enough
> > > >Ken
The barrels and forks came from Wicks and cost about $50 USD each ($200
for the set).
Since I'm building a Christavia, not a Piet, my dimensions etc will not
apply. However, The front strut is 1-5/8"X0.083" and the rear is
1"x0.095". It was easy to get these numbers. I wanted the struts to be at
least as strong as the originals. The struts take loads in two modes,
tension for possitive G and compression for negative.
The tensile strength was easy. All you have to do is come up with a strut
with the same cross-sectional area; ie. the same amount of material. That
can easily be done by comparing weight per foot between 4130 streamlined
struts and round.
Compression is a bit more complicated. The geometry determines that in
compression, these struts will fail due to buckling. On the streamlined
struts, they will buckle across the minor axis as it is a lot weaker than
the major axis. So, by matching the minor axis diameter and with the
heavier wall thickness, the buckling strength will be about the same. This
actually took a bit of research as there was no mechanical specs on the
streamlined tubing. It was gathered by looking at other approximate
shapes.
Ken.
> Thanks,
> -=Ian=-
I think this has been done by Aircraft Spruce in their catalog. They have a
conversion table on the steel page.
Steve Eldredge
IT Services
> Behalf Of Ken
> Beanlands
> Sent: Wednesday, May 12, 1999 10:56 AM
> each ($200
> for the set).
> etc will not
> struts to be at
> with a strut
> material. That
> streamlined
> struts and round.
> streamlined
> weaker than
> the same. This
> specs on the
> shapes.
> Ken.
> Also, the
> > Thanks,
> > -=Ian=-
Tnx.
My firewall to front gear pivot center is about 17 inches,and aprox 24 to
axle center.
Started reinstalling the engine last night,but first wieghed the corvair
on a balance beam scale.With 2 stock carbs,magnesium fan,fan
shroud,belt,mech.fuel pump,dist,full oil,prop hub,support chain,throttle
linkage(between the carbs ala stock),plug wires wieghed in at 233# no
exhaust installed.
Doug
> From: Ian Holland
> Subject: Re: hello
> hassle.
>wrong here?
>Robert
Robert, no ofence intended, just found the right moment to put this that I
found somewhere (hope you solve the problem soon)
"So many times computing problems end-up being the interface between the
chair and the keyboard!"
Saludos
Gary Gower
Date: Wednesday, May 12, 1999 9:41 PM
Subject: Pietenpol-List: Re: one other thing
Amen!
Robert
someone
>>wrong here?
>>Robert
>Saludos
>Gary Gower
Subject: | Rib Construction Methods |
Has anyone used ribs sawn from plywood? There is a lot less
construction time, but a small weight penalty. If so, how do you
work out how much wood to leave when you carve out the inside of
the plywood?
Columbia, SC
Subject: | Re: Rib Construction Methods |
I did. Granted, they were for my Christavia, not a Piet. I used 1/4"
plywood without a capstrip. However, if I had my time back, I would have
used capstrips to keep the robs from bowing. The entire stack of 30 ribs
weighed 11 lbs. Considering that the other ribs had to weigh something,
it's not a great weight penalty compared to the time savings.
As for routing, I just created lightening holes where they wouldn't
interfere with the drag/antidrag wires. I did test them at one point by
placing 2 pieces of 2x10 across 2 ribs and then loading 320 lbs of
sandbags on the ribs. No problem.
Ken
> the plywood?
> Thanks,
> Columbia, SC
From: | Michael Brusilow <mb-albany(at)worldnet.att.net> |
Mike Bell wrote:
I owned & flew an Ed Sampson built Piet prior to building my own. His
Piet had plywood ribs with cap strips. I had no problems with the
aircraft.
It was nosed over (pilot error) at the Rhinebeck aerodrome. It was
repaired & sold to someone in the midwest.
Mike B ( Piet N687MB )
from
plywood?
I owned flew an Ed Sampson built
Piet
prior to building my own. His Piet had plywood ribs with cap strips. I
had no
problems with the aircraft.
at the
Rhinebeck aerodrome. It was repaired sold to someone in the
midwest.
Ian,
I can't remember if I answered your questions...so here it goes again.
I too have the same series engine (T0219RH). I chose to use an aircraft
carb. rather than the originals. I think they would be too cool hanging out
there in the wind. , but then that depends on how you cowl them in. My carb
is mounted under the engine hanging on a 1/8th plate alum. bolted to 4 of
the oil pan bolts. I have a welded tube(2") coming off the top end of the
carb (90 degrees) then it procedes back just past the pulley with another
(90 degree) bend with a short extention to the 1 1/2 " 'Y' split. the
runners after the split are made of electrical thin wall tube conduit with a
nice gentle 90 degree bend. These are terminated at the intake boss where
the old carbs were mounted. The reason I mounted the carb under the engine
is the same reason all aircraft carbs are mounted underneath... to prevent
fuel fires. This way any excess fuel can run off through the air box.
I'm going to sort out my timing problem this week-end. My gear leg is
painted and will also be mounted this week-end.
Domenic
threading.
-=Ian=-
Subject: | Re: Corvair Carb |
Domenic,
Just a thought your power problem may be due to induction pulse
limiting. That is the reason we used to be able to drive the old low
horsepower VW beetles wide open and they would turn so many rpm. Just
something to think about.
J Mc
. My carb
a
From: | Wayne and Kathy <ktokarz(at)incentre.net> |
> My current Stats:
> Plate?
> rating.
> Domenic
Hi Domenic
I am confused with something. you say that the prop is a 66x32 and you
spin it at2600 rpm. My C-65 spins a 72-42 at 2250 rpm static. If my math
is any good you are running less than 65 hp. any one else out there have
an idea on this one.
To Wayne and Cathy,
Hello, Our engines are completely different. You can spin a larger propeller
at a lower RPM because of your torque curve. You have a longer stroke engine
with a much larger sized piston. My stroke is short with a much smaller
piston, therefore my engine requires higher RPM to develop similar H.P. Also
since it spins higher, the prop. diameter must be kept to a certain max.
diameter (calc. by formula) to keep the prop. tips from going supersonic. I
would like to see 2900-3000 RPM at full throttle. This is still well below
the sonic speeds (Approx. 3500 RPM). I'll be changing the centrifical
springs in the distributer this week-end, and re-time the engine to 35
degrees.
Hope this helps your understanding,
Domenic
> My current Stats:
is
circuit
one
> Plate?
> rating.
> Domenic
Hi Domenic
Subject: | Re: FW: Corvair Fishing |
Domenic, thanks for the info. I was figuring that I would do something
similar (for the same reasons)I can't see the carbs sitting exposed. Did
you retain the Corvair fan? What carburators did you look at, and what
did you settle on?
Sure glad I'm not breaking new ground on this sort of application. I
have a rebuild book on order and another on back order so hopefully will
have some ideas in them.
thanks again,
-=Ian=-
Subject: | FW: FW: Corvair Fishing |
Ian,
I did not retain the fan. It's pretty cool here in Canada most of the time.
With the oil cooler I reached only 165 degrees.
I settled on a Stomberg Carb. MA3 I think?? came off an 85 continental.
dom.
did you settle on?
thanks again,
-=Ian=-
Subject: | How many 'Scouts? |
Out of curiosity, how many of us are building Sky Scouts? I see lots of
pictures and read of lots of Air Campers, but not many of the single-place
brothers are talked about. Just wondering.
Ed Woerle
Subject: | Model A radiator specs |
Can anyone tell me how wide a Model A radiator is? Would like to find a core
to cut in half, like mentioned in Air Camper article. Plan to modify Kapler
c-section to allow radiator to go behind leading edge when adjusting wing for
rigging/wt&bal. Need to know how wide to make the opening. Thanks.
Ed Woerle
Subject: | Re: How many 'Scouts? |
I have a red and black Ford powered Sky Scout on the home stretch about
ready for final assembly (NX899EM)
Earl Myers-Ohio
Date: Saturday, May 15, 1999 12:34 AM
Subject: Pietenpol-List: How many 'Scouts?
>Ed Woerle
Subject: | Re: Model A radiator specs |
Ed;
I will get back to you shortly with some Scout radiator info....
Earl Myers
core
Kapler
for
>Ed Woerle
I'm working on one in St. thomas, Ont Canada. I've got most of the ripping
done for the entire plane, and the router machining should be started
sometime in june (I'm trying to get all the real dusty work done outside
while I have good weather).
Power will be a Wis-Con A0-32 (basically a shrunk A-65), with electrics and
redrive. The final weight and power on the engine will be very close to the
PackMag twin BHP mentions in the Flying and Glider manual. Prop will be a
GSC wood, 72x42 (original prop size). The only other changes I am making
from the plans is the 3-piece wing (I'm using GN-1 spar drawing with
original airfoil and spacing) and a tailwheel instead of a skid.
The lumber is Spruce, 12-14gpi I dried myself (took a year). I'm lucky
enought to be able to get most of the materials locally, and sooner or later
I'll be putting up a budget page on Aircamper.Org- it might be interesting
to see what we are spending on these things in different areas.
The big question in my mind right now is glue. Epoxy or Cryoacrilite(sp).
The later is available about 2 blocks from my, is waterproff and gap
filling, and in my own tests I have never broken at the joint, always beside
it. I just cant seem to find any info on longer term/ hi temp properties-
But at $5 a bottle its worth digging.
> Ed Woerle
Larry Harrison(Bainbridge GA), builder of Poplar Piet , now has a Scout
on the gear, tail group complete, controls complete, ready to start the
ribs, etc Looks really good.
>Scout
>the
Does that mean he built it out of Poplar wood?
If so I have 12 Piets growing in the back 40.
Gordon
__________
Subject: | Now what did I do? |
Steve E, somehow I wound up with two, count 'em, two subscriptions to the
list. Please un-subscribe me from one of them, or tell me how to go about it
myself. It's embarrassing when an O.F. sends HIMSELF junk mail!
Thanks a bunch, for both the favor and the great list.
Ed Woerle
Subject: | Re: Now what did I do? |
Ed;
Who you calling Junk Mail!
Subject: | Re: Glue: west system |
This might be of interest to CDN builders- I just got back from Lee Valley
Tools- complete West system kit-pump, book and 38 oz bottle for $62 CDN
Re Scout:
Ed Snyder, who previously built an Aircamper, and has another one
under construction, finished a Model A Scout last year.
He flew it a few hours, but was grounded with engine trouble. The
engine work was done this winter & as soon as the weather warms,he will
fly again.
He says that the aircraft flys great except there is zero foward
visibility. In the Scout configuration, the pilot sits directly behind
the radiator.
Ed asked me to ask the group if anyone has plans for a fwd mounted
cowling radiator.
Mike B ( Piet N 687MB )
Re
Scout:
Ed
Snyder, who
previously built an Aircamper, and has another one under construction,
finished
size3>
He flew it a
few hours, but
was grounded with engine trouble. The engine work was done this winter
as
soon as the weather warms,he will fly again.
size3>
He says that
the aircraft
flys great except there is zero foward visibility. In the Scout
configuration,
the pilot sits directly behind the radiator.
size3>
Ed asked me to
ask the group
if anyone has plans for a fwd mounted cowling
radiator.
size3>
Mike B ( Piet
N 687MB
Hi group===don't know if anyone out there is interested but I just came
across a fellow with a running Lycoming 125hp gpu sitting on an air-boat
(aluminum Landau) with trailer. he is selling for 2500$. someone may
want to grab the engine and recoop half of his investment by selling the
boat and trailer.for those interested his info is;Robert Lila, 33164 N
Eastview, Gages Lake, Ill...847-223-0607..this would make a dandy Piet
puller.
regards
JoeC
Zion, Illinois
> >Scout
> >the
> Gordon
He did and you do.
> __________
To Ken Beanlands,
Was looking at one of your recent messages to the Pietenpol
Discussion Group in which you mentioned the loss of the pro-
totype Canadair Challenger and its test pilot.
I knew Norm Ronaasen well. We were classmates during high
school here in Camrose (Camrose Lutheran College, in those
days) and graduated in June 1947. He was an exceptional per-
son and, from all accounts, a superb pilot. We, who knew him
well, still mourn his loss.
During the early 1960's he was based at Cold Lake flying CF104's
and one summer they were temporarily moved to Namao. I hap-
pened to be home on time off from flying helicopters on the Alberta
Forest Service contract when he phoned me and came over for a
visit at our home in Sherwood Park. We had a great time reminisc-
ing and getting caught up on things. He invited me to the officers'
mess for lunch the next day, and I got shown around the base by
Norm and his buddies. Even got to sit in the cockpit of a CF104!
That was the only time we saw each other after high school, but we
sort of kept in touch via mutual friends and acquaintances until his
tragic death in 1980.
Norm built an nice Emeraude which is kept by his brother Arne who
lives on the family farm in the Barrhead area. Apparently, he carried
pieces of that Emeraude all over during the years he was posted to
different places with the RCAF. I'm not sure just when he was able to
complete it, but it was under construction for quite a few years.
I have a video tape from The Fifth Estate TV program made during the
early 1980's that covers Norm's life and the events leading to his
death.
If you have not seen it, I could make you a copy.
As you pointed out, deep stalls are generally a problem with aircraft
that
have high-mounted horizontal tail surfaces. The Challenger has this and
I recall that the prototype BAC111 (I think it was) airliner was lost
with the
entire test crew when it simply mushed all the way to the ground in a
deep
stall. It also had a T-tail. I'm very glad Pietenpols (and Christavias)
don't
have them!
Graham (Pietenpol CF-AUN)
Ed,
Although I can not name names, I have three customers who are building Sky
Scouts. Although the catalog requests between the Pietenpol and the Sky Scout
are about 30 to 1, you are a dedicated bunch!!!
I have enjoyed being able to support their building process, and look forward
to the day of their first flight as much as they are...so please add 3 to
your list of builders.
Steve Speidel
Replicraft Aviation
Are the larger spoked wheels used on the camper in the original design
plans?......or should I be thinking of converting something like
motorcycle wheels? I'm afraid I'd have a lot to learn about
manufacturing my own. And what about brakes? I really enjoy the
appearance of the larger wheels.
Subject: | Re: Spoked Wheels |
Mike Cuy used brakes from a go cart, his rims are Motorcycle and he made
the hubs. He reports it works well. I plan to do much the same thing.
You might want to get his video, it shows what he did, also has a lot of
great tips and flying scenes. Well worth the $.
John Duprey
I agree Mike Cuy's video is worth viewing. His wheel design is
similar to what Frank Pavliga and Howard Henderson did on their beautiful
ships. Frank and Howard don't have brakes.
Another alternative is modified motorcycle wheels. The major
concern is side loads imposed on the wheels. I agree this could be a
problem with the "cub type" gear, less so with the straight axle.
What I did was copied from Brian Kenney. He and I used Honda
motorcycle rear wheels with large hubs and short spokes. The bearings
are pressed out, internal stiffeners reduced by machining to accomodate
the larger axle and bronze bushings placed in the bearing races. Brakes
are already there and stopping the axle rotation when applying brakes is
easy.
Brian made a sketch for me which I resketched (before my days of
computing) that I will gladly share with any list member who sends me
their snail mail off list.
Have fun!
Tom
__________
What kind of pistons do you 'A' guys you when you rebuild?
Richard
My homepage: http://www.AirCamper.org/w3builder
....Oh that I had wings like a dove! for then would I fly away, and be at rest.
-Psalm 55:6
Visit www.AirCamper.org - A Low 'n Slow Online Community!
____
Free instant messaging and more at http://messenger.yahoo.com
Has anyone investigated some of the beefier mountain bike wheels- It might
save some weight, and some of them take a hell of beating without damage on
the bikes- Probably need to bake a custom hub and shorter spokes. I'm still
quite a ways from needing to worry about it, but I'll be looking into this
for my scout eventually
I did a similar thing. Used 21" motorcycle wheels with drum brakes. The
issue of side loading and wider hubs was addressed by making a new spoke
flange for the side opposite the drum and extending the hub width. If you
look around you will find some dirt bikes use removable spoke flanges. The
New spoke flange has a larger OD and allows the use of the original spokes.
the hub is bored out to take 1.500" bronze bushings and the wheel rides on
1.500" 4130 tube. The tube was machined for threaded hub nuts. The problem
now is to design a method of absorbing the axle rotation as the brakes are
applied. Mike Cuy's solution merits some study.
John Mc
-----Original Message-----
Date: Sunday, May 16, 1999 7:42 AM
Subject: Pietenpol-List: Re: Spoked Wheels
>easy.
>Have fun!
>Tom
It's like having a wife and a girl-friend...you love 'em both but can't
afford but one, don't need but one, more than one is too much of a good thing.
Ed
Hi Mike!
As a part-time bicycle mechanic trying to build an aeroplane(! :-), I would
say that MTB rims won't make a good wheels for a Peit. The spokes we use
on even MTB wheels are only 2mm dia. (.080 ) so if you go to a bigger
spoke, you could seriously weaken the rim. Also, the tires are only 2-2
1/2" wide on a 559mm rim (aka 22" bead seat dia. -- inflated dia of the
wheel is about 26 1/2" )
Now, if you were making an Ultra-Piet, I could set you up with a neat set
of BMX "aero" freestyle rims ("flames" optional! ;-) that would be strong
enough!
Sun Metal makes some very good Alloy bike & motorcycle rims -- and the
better "Hog" custom shops will have a spoke machine to cut & roll thread
your spokes to size. Lacing up your own wheels isn't too hard of a job --
you will need a simple frame to support the axle & let you gauge the
out-of-round, wobble & centering of the rim on the hub. (on a semi-related
note, I have some bits & pieces from a '46 T-Craft (tail feathers, etc that
use (we think) some 30's Harley spoke nipples for the tail brace wires --
the nipples are threaded #8-36UNF)
Pretty Prairie, KS
P.S. Sure seems like there are a lot of "Mike"s in this group! Well over
the national average I'll bet! Might have to go to "call signs"! ;-)
> From: Mike Lund <malund(at)sprint.ca>
> To: Pietenpol Discussion
> Subject: Re: Spoked Wheels
> Date: Sunday, May 16, 1999 10:12 AM
might
on
still
this
> Mike
From: | walter evans <wbeevans(at)worldnet.att.net> |
Danny,
I made my wheels from 18" motorcycle rims ( 3"x18") tires. Made a hub from
4130 tubing with end plates fabricated and welded to the shoulder machined
on each end. Then found Harley Davidson spoke sets to match. Got a thumbs
up from my AP. His only concern was the shoulder on the spoke near the hub.
But if you look at the front wheel of a "Hawg", this is what they have.
I have pics on AirCamper.org. Check out...
http://www.aircamper.org/users/wevans/wbehub1.jpg
http://www.aircamper.org/users/wevans/wbewheel1.jpg
http://www.aircamper.org/users/wevans/wbewheel2.jpg
http://www.aircamper.org/users/wevans/wbewheel3.jpg
The white bushing is just a temp. that I made out of PVC water pipe
fitting , so I could true the wheel on the 11/2" axle shaft. Making brass
bushings now.
If anyone is interested I can post hub mat'l sizes, spoke kit #.s etc. I'll
have brakes fitted to them before the Piet is done.
walt
Date: Sunday, May 16, 1999 1:18 AM
Subject: Pietenpol-List: Spoked Wheels
Subject: | Fw: Spoked Wheels |
I made mine from 3"x18" rims, with H.D. spokes and hub made out of 4130.
My AP gave a thumbs up.
The pics are on
White bushings are temp. made out of PVC pipe fitting, I'm making brass now,
and I will fit brakes before Piet completion.
walt
Date: Sunday, May 16, 1999 12:51 PM
>Hi Mike!
>enough!
>Mike
>Pretty Prairie, KS
>might
>on
>still
>this
>> Mike
Subject: | Fw: washout (and MUSHING)) |
Danny,
I'm forwarding Ken Beanland's letter in case you have not seen it. He
explains what happens with a deep stall situation: basically, the wake
from the wing flows backward and upward to render the elevators inef-
fective and pitch control is lost. The drogue chute Ken mentions was
installed during testing to recover from deep stalls (and spins), should
one develop.
My late friend, Norm, was exploring high angle of attack behavior when
one engine quit and a deep stall resulted. They deployed the chute and
the nose dropped, breaking the stall. Unfortunately, they couldn't get rid
of it because the release systems all failed. And they couldn't get the dead
engine lit, either. With all that drag and one engine out, the airplane was
going down. Norm ordered the two other crewmembers to bail out, which
they did. He didn't have time to get himself out and was killed. The
surviving
crew members tell the whole story and credit Norm with saving their lives.
The whole thing was a classic example of multiple failures resulting in the
loss of a fine pilot and a valuable prototype. From all accounts, Norm was
extremely unhappy with the condition of the a/c and had reported problems,
including the sick engine, previously. Murphy's Law then kicked in.
An aeronautical engineer, who knew Norm well, told me that even with two
good engines he wouldn't have had enough thrust to fly with the chute
attach-
ed. Perhaps he could have successfully crash-landed on the desert surface
if he had both engines to bring the nose up some. We will likely never know.
Hope this and Ken's letter explain what occurs in a deep stall. The
Pietenpol
is not susceptible to deep stalls of this sort, you will be glad to know.
Graham
Date: Friday, May 07, 1999 3:19 PM
Subject: Pietenpol-List: Re: washout
>I think you have mistaken the "deep stall" phenomena. The deep stalls
>are usually associated with T or high mounted vertical
>stabalizers/elevators. The normal down pitch after a stall is due to the
>fact that the elevator/stab is still capable of providing some
>stabalizing force even after the wing has stopped producing lift. If, for
>some reason, the stabalizer becomes ineffective, the plane will continue
>to descend in a nose high, full stall attitude. This can occur on a T-tail
>plane or any plane where the tail is 5-15 degrees above the chordline of
>the wing. The turbulent air from the stalled wing will "mask " the
>elevator and stabalizer making it ineffective. At this point, only
>vigerous application of power, elevators and flaps can help break from the
>stall.
>You can see the result of this on an F-4 Phantom. Even though it's not a
>T-tail, the delta wing and engine outlet put the root of the stabilators
>in the deep stall position. You will note that the stabilators have a very
>prnounced down angle to get them out of the wing shadow.
>Actually, the prototype Canadair 601 Challenger was lost in just this
>manner. The test plane had been equipped with an emergency drouge chute
>attached to the last bulkhead inside the tailcone. Sure enough, a deep
>stall developed and the test pilot fired the chute which pulled it out of
>the stall. Unfortunately, the explosive bolts used to attach the chute to
>the plane malfunctioned and the chute could not be cut. All of the crew
>bailed out except the pilot. He almost recovered the plane but ran out of
>height and impacted the desert floor. It was speculated that with another
>300-500', he may have recovered enough to land it. The pilot was killed
>instantly.
>Ken
>On Fri, 7 May 1999, David Scott wrote:
>> 2) Limited elevator down force capability will prevent
>> 3) Dihedral angle can help, but not always true.
As far as axle rotation with DRUM brakes goes, Mike Cuy's method
works but there is an easier way. (Mike has disc brakes and needs to stop
axle rotation as the brake apparatus is welded to his axle)
Brian Kenney used the part of the brake plate that normally
attaches to the motorcycle frame (rear wheels) and attached a cable to it
which connects to a piece of tubing attached with a strap to the front of
the ash piece on the bottom of the wood gear. When the brakes are
applied the cable holds the brake plate in place and the wheel stops.
The axle is held pretty tightly in place by the bungees anyway.
For those who expressed an interest in my sketch of Brian's method,
they'll be in the mail in a few days. In the mean time for those who
asked the wheels come from a mid 70's Honda 360. They are rear wheels
and were obtained at a motorcycle "junkyard". The larger hub gives them
a little different look.
Have fun!
Tom
__________
From: | robert hensarling <rhrocker(at)admin.hilconet.com> |
Subject: | Walt, Tom, and/or John-spoked wheels |
Guys, I have cub gear on my GN-1 (and honestly don't know right this moment
the length of the axle, or the diameter or it).
Would any of the types of wheels each of you "spoke" of work with cub style
gear? Would any of you guys consider building a set for the cub gear, and
if so, how much would I be looking at ($). Being a woodworker, I'm out of
my league on this part of the project.
You can reply in private if you want.
Thanks!
Robert Hensarling GN-1 N83887
Uvalde, Texas
Richard
There are two choices for pistons of the A variety. Ford always used
what are refered to as "cam ground" pistons. They have a symetrical cam
shape when cold and expand alond the wrist pin to become cylindrical
when at operating temp. Many old engines when rebuild used a cheaper
solution a "slotted" skirt. that allowed for the expansion. If you use
the original style pison you should be alright.
Some folks are now using pistons from modern engines. There are many
to choose from,mostly from the small block chevy or fords. You need to
know the bore size (3.875" stock") that will clean up your cylinder
walls and then check out the parts catalogues to find a suitable match.
The "slipper skirt" used on the V8 pistons makes no difference to the
application. Weight is a small problem but not at the slow speeds the A
runs. Compression ratio however does matter. Be sure to check out the
wrist pin to piston crown height. The piston should be flush to very
slightly above the cylinder head deck at TDC. Be certain it will not
touch the head. A little modeling clay placed on the piston and with the
head in place turn the engine over. (no, not upside down ;-) ) remove
the head and cut the clay in half and view the thickness. This will be
your piston to head clearance. Wrist pins sizes can be matched by using
thicker rod bushings.
Hope this isn't too confusing
John Mc
Date: Sunday, May 16, 1999 7:49 AM
Subject: Pietenpol-List: 'A' pistons
>Richard
at rest. -Psalm 55:6
>____
Richard
variety. Ford
always used what are refered to as cam ground pistons. They
have a
symetrical cam shape when cold and expand alond the wrist pin to become
cylindrical when at operating temp. Many old engines when rebuild used a
cheaper
solution a slotted skirt. that allowed for the
expansion. If
you use the original style pison you should be alright.
engines.
There are many to choose from,mostly from the small block chevy or
fords. You
need to know the bore size (3.875 stock) that will clean up
your
cylinder walls and then check out the parts catalogues to find a
suitable match.
The slipper skirt used on the V8 pistons makes no
difference to
the application. Weight is a small problem but not at the slow speeds
the A
wrist pin
slightly above
the cylinder head deck at TDC. Be certain it will not touch the head. A
little
modeling clay placed on the piston and with the head in place turn the
engine
over. (no, not upside down ;-) ) remove the head and cut the clay in
half and
view the thickness. This will be your piston to head clearance. Wrist
pins sizes
can be matched by using thicker rod bushings.
John Mc
-----Original Message-----From:
Richard DeCosta
16, 1999
7:49 AMSubject: 'A' pistonsWhat kind of
pistons do
rebuild?RichardMy
homepage:
href"http://www.AirCamper.org/w3builder">http://www.AirCamper.org/w3bu=
ilder....Oh
-Psalm
55:6---------------------------------------------------------=
Visit
Slow Online
Community!-------------------------------------------------------=
--____
R>Do
You Yahoo!?Free instant messaging and more at
href"http://messenger.yahoo.com">http://messenger.yahoo.com=
Subject: | Re: Walt, Tom, and/or John-spoked wheels |
G-BUCO that great looking Piet from Great Britan has large diameter wheels
on split gear as do several of the aircraft on the Aircamper.org site. There
is an advantage to this as the braking torque is easily transfered to the A
frames of the gear. As to cost ... No idea as most of what I do is done by
scrounging.
John Mc
From: robert hensarling <rhrocker(at)admin.hilconet.com>
Date: Sunday, May 16, 1999 3:53 PM
Subject: Pietenpol-List: Walt, Tom, and/or John-spoked wheels
>Thanks!
>Uvalde, Texas
From: | "R. Mueller" <rmueller7(at)earthlink.net> |
Subject: | Model T show in Belvidere |
Stopped by the "Little Hershey" Model T/Car Show/Swap meet, and was very
disappointed. Not a single decent A block to be seen. Only 1 block for sale
(of any kind), and it was a severely rusted A block (it had crust rust in
the cylinders) that looked about ready for the boat anchor conversion. A
bunch o' mint Fords to gaze at, but no engines to be had. Ah well.
Ryan
Is it alright to download the images from the library and save them for
future ref?
Beautiful photos, guys.
Doug,
Thanks for the article on the Nieuport Corvair. Very Interesting.
Domenic
Subject: | Re: Deep stalls.... |
He's a guy I would love to have met. The story I related was my
recolection of that very Fifth Estate TV program you mentioned. If I
remember correctly, wasn't he also involved with the ill-fated Avro Arrow
test flight program? The show certainly portrayed him as a Canadian hero,
which he rightly deserved.
Ken
> early 1980's that covers Norm's life and the events leading to his death.
> Cheers,
Guys:
Would any of you Canadian guys (or American for that matter) that are close
to the border be willing to fly your Piets to NW Pa for a fly in on June 6?
(If the weather permits)
We are having a dress rehearsal this year for a Millennium fly-in on July
16th, 2000 that will focus on old airplanes and old cars at Port Meadville
PA (GKJ).[35 mi. S. of ERIE]
If you do get here, I will buy you breakfast and fill up the tanks!!!
Plus, I can get some helpful tips for my Piet!!
Thanks, Doug
'Tom Bowdler'
Pretty good offer, I wish I could. I'm still trying to work out the bugs in
my new piet. with the hopes of flying to Brodhead and Oshkosh this year.
Also my daughter has her Squdron annual inspection that week-end. I will
pass along this information on your behalf. I know there are a few Piets. on
both sides of the border.
Domenic
Guys:
Thanks, Doug
Subject: | Model A Ford Magneto Ignition |
Hello,
I am monitoring this group for a retired friend who is planning to build a
Piet powered by a Model A engine. He is making good progress on the engine,
and plans to utilize a magneto ignition. The magneto he needs is a WICO
SPEC-XV1509. Anybody have an extra one??
Glenn
Hi Richard:
Some go to Egge Machine in SO. Cal. I think they are on the Internet.
Or check out the "Secrets of Speed Society" homepage, or the 4-Ever-4
club, if they have one. I think you can use 283 Chev. pistons, but not
sure what rods.
John Bayer
writes:
>Richard
>____
Subject: | Re: Model A Ford Magneto Ignition |
Anybody know what mags of new production are most easily adapted? Have
never worked with mag ignition before.
John Bayer
jrbayer2(at)juno.com
Meany Magnet School Piet Project
>Hello,
>build a
>engine,
>WICO
>Glenn
I finally found my engine, and it's only 8 miles from me! The guy that
has it (and is going to restore most of it for me, since Im no expert)
is Jim Harris of http://www.forengines.com. He's going to doing most or
all of the work (while I watch eagerly over his shoulder!) over the
next 6 months. The engine was manufactured in 1930, and is in super
shape.
Im psyched!
Richard
-Psalm 55:6
____
Richard;
Congratulations. Are you going stock or modified? (how
many HP?)
Well, all I can say is that it will conform almost exactly to the 1932
plans by BHP. There are a couple modifications I MAY do, but Im not
sure yet. Hoping to end up in the 65 HP range.
Richard
--- Bill Talbert wrote:
> Richard;
> many HP?)
> Bill
-Psalm 55:6
____
Yahoo Richard! Sounds good!
John Mc
Date: Monday, May 17, 1999 7:02 PM
Subject: Pietenpol-List: A Engine
>shape.
>Im psyched!
>Richard
rest. -Psalm 55:6
>____
Ok Guys,
After talking to some of you and to some local A&P's I've made a
preliminary decision to power my plane with a Continental 65-100.
This is my first plane and I don't look forward to building a motor.
I'll save that for the next one maybe. Some of the mechs have told me
that Lycomings may be a little easier to work on......some disagree. I'm
curious why I havent heard of any of you using them. Any answers here?
Anyway, several people have mentioned the advantages of having a little
extra power, is there any disadvantage to the 100 over the 65? Also, is
there a difference in the engine mount?
Thanks for all your help so far.
Eager to get started, DannyMac
Robert, Daniel, Mike and Earl,
My sketch and description of Brian Kenney's Honda wire wheel
conversion will be in the mail this morning.
Any othes who want it I still have some copies or will make more.
Send me your snail mail off list.
Have fun!
Tom
__________
Smart move choosing Continental Danny,
A friend had a Lycoming 65 powered J2 and it had no guts. I have
heard the Lycs were optimistically rated at 65 hp but 45 was more like
it.
Peter Mc Hugh has an 0200 Pietenpol and thinks that is fine. I've
also seen 85's mounted on Piets. I'm using a 65 Continental which is
more than adequate. They are quite popular and there should be lots of
them around from all the old cubs, t-crafts and airknockers. Mine came
from a Champ the owner was upgrading to an 85.
Tom
__________
Thanks Tom,
This is how we learn.
> it.
> Tom
Check out this site
http://www.modelatrader.com/partsdirectory/directorymenu.html
ken
>it.
Danny- What Tom cites above here is what I've found too. There is
a big difference between a Lyc 65 and Cont. 65. Parts are more difficult
and more $$$ for the Lyc too. As I recall the Lyc. head has both cyls. cast
in place so if you have a problem w/ one, you have to replace the whole assy.
Mike C.
had no guts. I have
like
it.
is
are more difficult
cyls. cast
assy.
Mike C.
Subject: | RE: Spoked Wheels |
Would love to have your sketch, thank you for making it available. I am
just starting the "pietenpol path" and am gathering all info I can. I
have my "A" stripped and ready for assembly. Thanks again. Chad
Johnson, 1307 Eastmoor Drive, McPherson, Kansas, 67460.
Subject: Pietenpol-List: RE: Spoked Wheels
Date: Tue, 18 May 1999 08:24:06 -0700 (PDT)
Any chance you could scan it for posting on AirCamper.org? Richard
> am just starting the "pietenpol path" and am gathering all info I
> can. I have my "A" stripped and ready for assembly. Thanks again.
> Chad Johnson, 1307 Eastmoor Drive, McPherson, Kansas, 67460.
> From: bowdler(at)juno.com [SMTP:bowdler(at)juno.com]
> Sent: Tuesday, May 18, 1999 10:53 AM
> more.
> Have fun!
> Tom
> __________
> Get completely free e-mail from Juno at
> http://www.juno.com/getjuno.html
> ATTACHMENT part 2 application/ms-tnef
-Psalm 55:6
____
I'm new to the list, and I don't even have a set of plans yet, but I do
know that Continentals - A65 to 0-200 are used here, and that the C90
appears to be the preferred engine. I believe people are also using Subarus
and Air Cams. You see, we don't have a lot of Model A Fords over here, and
I think they would be a little underpowered for our green and crowded land.
I'm thinking about a Subaru EA81, as they are a fair bit cheaper then the
alternatives.
Leo in England
>....I've made a
OK, That pretty much explains about the Lycoming.......What about the
Cont.100? Don mentions that his plans include the motor-mount for the
65 hp.....what about the 100? Do they use the same mount?
Obviously the weight diff can't be substantial, so if I can get a
100 for nearly the same price as a 65, shouldn't I go for more bang for
my buck?
Michael Cuy's video notes Buchanan Spokes as a reference for his wheels. Had
used them
prior to seeing the tape for redoing my Honda motorcycle wheels as they are only
3 miles from
me. They have moved to a new industrial park The current info is:
Buchanan Spoke & Rim, Inc.
805 West 8th Street
Azusa, CA. 91702 Phone: (626) 969-4655 Fax (626) 812-0243
They have a great catalogue of rim, hubs, etc. All high quality aftermarket
stuff, and not
cheap.
They charged me $1.00 each for 9 gauge stainless spokes and nipples (will pull
1,000 pounds
each!) for $36.00, plus $54.00 labor to lace and true each wheel. Paid $10.00
each at a
motorcycle salvage yard, polished them out with Mothers Mag & Aluminum Polish ($7.50)
and put
in new bearings and brake pads. Hub came with an arm to prevent brake rotation
that can easily
be affixed to the gear.
Note: There are a LOT more choices for tires if you 18" rims.
Warren
>my buck?
Danny- Mike Brusilow has a nice 0-200 powered Piet and it gets out
nicely. Don't quote me, but I think the A-65 and 0-200 might use the
same case, thus mount. I'm hoping for additional guys to respond for
you though if that's not true.
If you want the 65 Cont. it will perform wonderfully for you if you do
the following: Build light, build light, and build light.
It might seem fun to have a starter, battery, elect. radios, instruments
in both cockpits, strobes, etc.....that is, util you find yourself on a hot
day trying to clear some wires or trees on takeoff. I realize some guys do
require radios at their home bases so this isn't a stab at them by any
means..just try to keep it light and you'll get some good performance.
A sick 65 Cont. is
another thing to avoid if you can.
Mike C.
if I can get a
for
my buck?
DannyMac
the
for
instruments
hot
guys do
performance.
A sick 65 Cont. is
Mike C.
Danny...
Just a thought: no matter which engine you use, you should probably overhaul
it before flight, unless you can get a terrific deal on a recently overhauled
engine (and I mean both operating hours AND calendar!). I somewhat agree
with the Continental over Lycoming. Parts are available and not TOO
expensive. Somehow my overhaul manuals for these engines escape me right
now, but I would almost bet money that the mount for any of the "C" engines
is identical. As for weight differences, here's what I was able to come up
with:
A-65-8 170 pounds dry
A-75-8 170 pounds
C-75-8 177 pounds (this is a no accessories case)
C-85-8 178 pounds
C-90-8 184 pounds
O-200A 190 pounds
All of the -8 engines are not set up for electrical systems or starters.
Some may have flange cranks, but others have a tapered shaft, requiring an
adapter. The O-200 comes in basically one flavor...starter and
generaror/alternator. Main differences in the dash numbers is for pull vs.
key starter, alternator vs. generator, and even a fuel injected model (also
available in the C-85 and C-90). The choice is yours. Will the "A" engine
be less expensive to obtain/overhaul? UNDOUBTEDLY. Will it be less
dependable? Questionable, with proper care of both. Less power? Uh huh.
More fun? YOU BETCHA!!!
The little Continentals are fairly simple to overhaul, and sip fuel (I get a
little less than 5 gph on my '66 Cessna 150)
No matter which way you go, the only person that should make up your mind is
you. Weigh all the factors, make your decision, and enjoy your Piet.
Ed (working on airplanes too darned long to be still doing it) Woerle
Not to sidetrack the discussion, but maybe someone could answer me a
quick question about the 'A' engine installation: I am under the
impression (due to lack of knowledge?) that planes with an 'A' engine
do not have an electrical system. Is this true? If so, how does one do
about adding one (I will very likely need a transponder and radio,
since I am within the Portland Class C airspace, or if I hangar it
elsewhere, will need to fly into 'C' airspace quite often).
Richard
--- Ed0248(at)aol.com wrote:
> Danny...
> overhaul
> overhauled
> agree
> right
> engines
> come up
> with:
> A-75-8 170 pounds
> C-85-8 178 pounds
> C-90-8 184 pounds
> O-200A 190 pounds
> starters.
> requiring an
> pull vs.
> (also
> engine
> huh.
> (I get a
> mind is
-Psalm 55:6
____
From: | "Lightsey, Mark - TP2MAL" <MLightsey(at)socalgas.com> |
Subject: | RE: Model A Ford Magneto Ignition |
On my Corben Super Ace, I used a Slick 4301 with good results.
Sent: Monday, May 17, 1999 2:53 PM
Subject: Pietenpol-List: Re: Model A Ford Magneto Ignition
John Bayer
>Hello,
>build a
>engine,
>WICO
>Glenn
Chad;
How close are you to the Flint Hills area?
Earl Myers
Date: Tuesday, May 18, 1999 11:12 AM
just starting the "pietenpol path" and am gathering all info I can. I have
my "A" stripped and ready for assembly. Thanks again. Chad Johnson, 1307
From: | bowdler(at)juno.com [SMTP:bowdler(at)juno.com] |
Have fun!
Tom
__________
April 30, 1999 - May 18, 1999
Pietenpol-Archive.digest.vol-as
