Pietenpol-Archive.digest.vol-bc
August 20, 1999 - August 31, 1999
HP....................................100@3200 rpm
HP (Continuous)...............90@3000 rpm
2. It is low stress
In the Corvair automobile the engine produced 180 horsepower in
the turbo- charged form. All 1964-69 model engines utilize the
same crankshaft, rods, pistons and cases etc. By flat rating the
engine for 90 hp continuous, the engine is only stressed to 50%
of it=92s rating in the automobile. No other auto engine conversion
can make this claim. In the automobile the engine was redlined at
5,500 rpm. My aircraft conversion produces 75% power at half this
rpm. These two facts are the cornerstone of the Corvair engines=92s
reliability as an aircraft power plant.
(And from his FAQ page)
Is cruising at 2800 RPM going to stress the Corvair engine?
Not at all. The Corvair engine turns more than 3000 rpm at 60 mph
in the automobile. They can run for hours at a time over 4500
rpm. Asking the engine to produce 75% power, the brake mean
effective pressure (BMEP) is lower at 2800 rpm than at 2000 rpm.
> > Theres more to this aspect than meets the eye, and I feel its
> > worth playing
> > it safe. If you are interested in the fatigue characteristics etc=
. of the
> > crank I have more information- but under MAXIMUM load a new Corva=
ir engine
> > running at normal temperature will explode with catastrophic
> > crank/connecting rod failure in 11 hours, according to Chevrolet'=
s fatigue
> > tests.This is GM's passenger car standard, essentially- thats how=
they
> > decide what is an acceptable connecting rod beam size, as example=
, its not
> > a shortcoming of the Corvair engine. This would be similar to a f=
ull
> > throttle run for 11 hours installed in a car. Naturally, the less
> > often the
> > engine is run at high speed/load/temp the longer it lasts, but th=
eres
> > definite limits.
We are not running the engine in an A/C application at MAXIMUM
load. No where close.... unless you use a PSRU, you can never
get even close to the 5500 rpm redline.
My $.02
Pat
Aeronca discussion list
OK guys, Daddy needs a new engine. I have to get rid of what's left of the
old C-85 to pay for it. Here's what's left:
Good crank, M 010 but needs to go to M020
Good case, no acc cover
Good cam,
Core cylinders (good for factory replacements only)
Stromberg carb
Generator
Conn rods
Other misc parts (I think the lifters are still there).
I'd like to get $1200 USD plus shipping for the lot but it's negotiable.
Ken
Ken Beanlands B.Eng (Aerospace)
Calgary, Alberta, Canada
Christavia MK 1 C-GREN
<http://www.spots.ab.ca/~kbeanlan>
Subject: | Re: Corvair engine codes and event announcement |
> > Before I paste the letter, I just thought I'd mention that for
> > you folks in So.
> > Cal., the greatest corvair show (and swap meet) on earth takes
> > place in just a
> > few weeks in Palm Springs. I've been told there are often many
> > whole engines
> > and countless parts available from people whose wives have
> > demanded they clean
> > out the garage. Here's a link:
> > http://www.integrators.com/sdcc/GWFBT&SM.html
I'm very interested in this event, but the hyperlink is no bueno. :(
Pat
Subject: | Re: Handheld Advice |
Yeah, I'm sending in the clear, to any and all who might want to hear...
Advisory Circular 43.13-2, Acceptable Methods, Techniques, and Practices
Aircraft Alterations has a good section on Antenna Installations in Chapter
3. May I quote...
" c. On fabric-covered aircraft or aircraft with other types of
nonmetallic skin, the manufacturer's recommendations should be followed in
order to provide the necessary ground plane. An acceptable method of
accomplishing this is by providing a number of metal foil strips in a radial
position from the antenna base and secured under the fabric or wood skin of
the aircraft. (See figure3.2)"
Figure 3.2 shows a sketch of a whip antenna centered in an 8-legged array of
foil, and has a note that reads: "NOTE: THE LENGTH OF EACH FOIL RADIAL
SHOULD BE AT LEAST EQUAL TO THE ANTENNA LENGTH."
I've used this methodology to hook up a handheld external antenna on two
Champs, and both worked well. Actually, I had access to "500 MPH tape",
which is aluminum tape 2" wide and about .005" thick. Put the radials under
the skin and covered them with pinked fabric strips to make sure they stayed
where I wanted them.
Try it, you'll like it!
Ed
From: | LaurenMWilliams(at)webtv.net (Lauren Williams) |
Subject: | Re: The Cost of Spruce for an Air Camper |
I have had much better luck buying spruce from Wicks. I have received
some poor material from Aircraft spruce, also they only finish it on two
sides. Wicks' spruce is all sanded to dimension on all four sides.
http://www.wicks.com/aircraft
At one point, I ordered a seven lb. kit of glue and 195 ft. of 1/4 x 1/2
cap strip from Aircraft Spruce. What I received was, 7 kits of glue and
about 20 ft. of cap strip, only half of which was usable due to slash
grain. That's when I started buying from Wicks.
I have been very pleased with both their materials and their service.
Lauren
From: | Gene Tomblin <tombling(at)MercyShips.ORG> |
Michael D Cuy wrote:
> When using a handheld radio in a Pietenpol or GN-1, can
> someone give me a simple, basic, practical way to install
> some kind of antenna. Mike C.
Mike,
The best and safest bet would be to get an old com antenna from an
AP or someone else who is around aircraft that are being parted out. You
could purchase a new one from Aircraft Spruce or Chief Avionics . They
tend to be
way over priced when you understand that it a very simple device .
Antennas are easy to build . I'm an FCC licnsed
radio technician and have built dozens of antennas over the years .
The trick in a piet would be providing a good ground plane under the
antenna . On a typical light aircraft the aluminum skin provides a
very good ground plane for the quarter wave vertical antenna to work
with . This could be done by sheeting the area under the antenna with
thin aluminum to at least one quarter wave length in all directions
from the antenna mounting point . The wave length
in Meters can be found by dividing the number 300 by the frequency in
Mega Hertz. For 121.5 Mhz this works out to 2.46 Meters , One
quarter of this is 0.61 Meters. Using the rough conversion of 39
inches to the meter this
is roughly 23.79 inches. The size and shape of the ground plane is not
critical as long as it is at least one quarter wave at the lowest
frequency you expect to use . The antenna it self needs to be the
right length in order to work well and not damage the transmitter
portion of your hand held. Shielding the ignition system on you engine
would be another thing worth doing . This is something I'm planning to
work on when I get my Piet project under way . I'm sure that a lot
can be done by just shielding the wires and leaving the plugs as
standard automotive types and not converting the engine to take
aircraft type plugs which are shielded and very expensive too . Take a
look under the hood of a Corvette, GM had to shield the wires on the
Vet because the fiberglass body did not provide shielding as it does
on steel bodied cars. WHEN your all done you should find that your
had held works better than it ever did with the rubber ducky antenna it
came with I have spent a few hours in a 1946 Aronica Chief with a set
up like this and the hand held was fine except the audio volume is
not adequate to hear over the noise of the engine but with a two place
intercom and a pair of David Clarks it works like a dream as long
as the batteries hold up.
If money is no object you could purchase one of the new antennas for
composite aircraft that are an etched circuit board to form a half
wave antenna that does not need a ground plant to work well . This
could be mounted
inside the fuselage behind the aft seat . This would be a way of
having a radio with out the normal outward
sign of an antenna sticking out somewhere
Gene Tomblin
Walt:
As you can see from previous posts that you must be VERY careful who you
talk to at AS&S. I just got the wrong person. Was your price $823? That's
what mine was without any plywood.
I bought a project from Ohio so now I'm good to go.
Doug
REPLICRAFT Aviation in NJ has great parts for the real Piet.
John Bayer
writes:
>Like I said in my last message.
>Aircraft Spruce lists the kit for the GN-1
>Not for the Aircamper.
>Apples and Oranges again.
>I have heard nothing but the best about that Canada company that sells
>kits for
>the Real Aircamper.
>I wonder why AS & S does not sell a wood kit for the aircamper.
>Is is because more people buying the 25.00 GN plans don't know what
>they are
>buying?
>May be a better design amyway.
>Gordon
>Doug Sheets wrote:
>> Jay & Clay:
>> I bought the Piet wood kit from AS&S and it is NOWHERE near the
>right stuff
>> for the Aircamper. I think now that I know the difference between
>an
>> Aircamper and a GN1 that they may have the wood for a GN1. The
>capstrips
>> were 1/4 x 1/4 not 1/4 x 1/2 as shown in the plans and the center
>section
>> spars were too short to use based on my 1933 Aircamper plans.
>Several pieces
>> didn't match so I ended up buying a project from a couple guys that
>went
>> thru the plans and ordered each piece. Also AS&S DOES NOT include
>any
>> plywood for $823; only the spruce pieces.
>> Doug
>> >From: Clay Spurgeon <cspurgeon(at)baseballexp.com>
>> >Reply-To: Pietenpol Discussion
>> >Subject: Re: The Cost of Spruce for an Air Camper
>> >Date: Thu, 19 Aug 1999 08:20:22 +0000
>> >Jay - If you're looking to go "aircraft grade", I have an e-mail
>in to
>> >Aircraft
>> >Spruce and Specialty for a breakout on their Pietenpol wood kits.
>They
>> >offer
>> >a spruce kit for $800 and three other Pietenpol kits, but I can't
>get the
>> >details on these through my server. They're probably plywood,
>> >hardware and metal kits. Give 'em a call if you want the details.
>> >Clay
>> > > From: Jay White <jwhite(at)mindq.com>
>> > > Subject: The Cost of Spruce for an Air Camper
>> > > Reply-to: Pietenpol Discussion
>> > > I was wondering if someone could give me an idea of what it's
>going to
>> >cost
>> > > just for the wood to build an Air Camper. Thanks.
>> >Director of Marketing & Merchandising
>> >Baseball Express, Inc.
>> >210-348-7000 X4300
From: | Michael D Cuy <Michael.D.Cuy(at)lerc.nasa.gov> |
Group- Thank you for the excellent advice on
antennas for handhelds.....now if I can scrounge up
some cash to buy the handheld !
Mike C.
From: | Clay Spurgeon <cspurgeon(at)baseballexp.com> |
I bought a wood kit from Wicks for a Mitchell Wing many moons ago -
the wood and the kit were excellent. They started as a pipe organ
company and this would give them a great background in wood
appreciation and selection. Got a reply to my e-mail from AS&S
saying they will fax the parts listings for their Pietenpol kits to
me. I'll let y'all know when I get it, and if its for a Peit or a GN-1.
Clay
> From: LaurenMWilliams(at)webtv.net (Lauren Williams)
> Lauren
x-mac-creator="4D4F5353"
Earl,
I have the same type antenna rig on my piet as Mike C. I just changed
from an STS to an ICOM. The new one they have was on sale at one of the
pilot shops in Pa. No VOR. Better Squelch. Works great. Talked to Flight
Service the other day from 50 or 60 miles out. Belt clip holds it on an
angle bracket next to my right knee.
Craig
Craig- Can I ask what Icon handheld you recently purchased
w/ no vor ? Perfect- I don't need the vor info.
Mike C.
From: | Mike Cunningham <mikec(at)microlandusa.com> |
Subject: | Re: Wicks vs. Aircraft Spruce |
I gotta put in a plug for Aircraft Spruce also!! Everything I have
ordered has been very good. One minor exception was a good test of their
service after the sale...some aileron sub-spars (4 pieces) in my Hatz
spruce kit were cut 1/16" under size. I discovered this several months
after receiving the kit but they replaced them immediately, no
questions, no cost, and please keep the old stuff. Good service!
My spruce kit was wonderful. I weeded out 10 or so pieces out of the 200
(40 extra) 1/4 sq.
cap strip they provided. All else was perfect including end grain well
within spec on all 8 wing spars
Tuesday I placed an order with Tangee (my rep) in Ca. Wed, 8 am I
recieved a call from AS&S in Ga. to confirm that order was shipping that
day, double check shipping address and method. Again.. personal service.
Wicks has been good on everything too.
-----Original Message-----
From: Michael D Cuy <Michael.D.Cuy(at)lerc.nasa.gov>
Date: Friday, August 20, 1999 6:49 AM
Subject: Re: Wicks vs. Aircraft Spruce
Mike, where was the Wicks advice a year ago? Aircraft Spruce &
Specialty knows my American Express Card number very well. They have
been super and a great supplier if I know what I want. If I don't, they
don't either. Early on I didn't even know what size cotter keys to get
and they couldn't help. Their catalog has a lot of information for a
new guy though and all in all I'm happy with their service.
Copinfo(at)ix.Netcom.Com
Tim Cunningham
Des Moines, Iowa (515) 237-1510
Hey Tim !
That's great to hear you are getting what you need at A/C
Spruce.....and they do have a good
catalog. I know what you mean about AN hardware, etc...it took me
a while to figure out
all the codes and lingo that go along with it...but now I almost
sound like I know what I'm
talking about :)) !!! Good to hear you are back flying.
Mike C.
Please hook me up with the group, my friend is ready to start the fuselage.
Thanks, Glenn
Finally got a chance to try out the new Yaesu. I was supposed to meet with
my father who was flying the plane back to St. John's while I was driving
in on the hiway. I first heard one of the local planes at the pond while
in the car. From the ground and while travelling at 110 kph I was able to
transmit and recieve an airplane at 25 miles using the built in antenna
and it was quite readible.
Later, from the ground at the dockside I had no problem talking to my
father when he was 35 miles out at 5000'.
In the plane, 25 mile range transmissions were still readible. In short, I
am really pleased with this performance. The size is quite small and
everything is designed to be water resistant. Price wise, it is quite
comparable to the ICOM. I have the COMM only version and it was $339 USD
when I bought it earlier this year.
Ken
> Mike C.
From: | Michael Brusilow <mb-albany(at)worldnet.att.net> |
>I just put my seat in (partially) and found
>it very uncomfortable. It is too late for any design changes at this point
>for me. My only options are to install some sort of padding or to design
>and install a new seat (molded to my rear and back) and install over the
top
>of the existing seat. Any comments?
>>Bart D Conrad
After being uncomfortable for a few years I solved the seat problem.
I removed to seat ( not easy ) & reinstalled it as low as possible.( As
close to the torque tube as I dared.) This permitted me to to place two
thick cushions on the seat. It worked for me. No more iron pants.
Re handhelds. buy the best quality.You won't regret it. ( I have a King KY
99 )
Before I installed the electric system on the 0-200, I ran the handheld off
a small 12 v battery. Never failed.
Mike B Piet N687MB ( Mr Sam )
From: | leonstefanhutks(at)webtv.net (Leon Stefan) |
Subject: | Antenna / ign. noise |
Gene Tomblin: Just how bad is noise from the unshielded ign. leads? UMA
Instruments makes a spark plug impulse sensor tachometer. However the
sensor will not work if you have metal brad shielding on the ignition
wires. this looked like another way to eliminate a couple of pounds of
tach cable for the weight conscious "A" builder. Also, plain wire would
save weight as well. Thank you. Leon Stefan
UNSUBSCRIBE PIET
L_Prange(at)ix.netcom.com
try RST. they do the ants. in the ez's
>Actually, Wicks has an on-line catalogue and website at
><http://www.wicks.com/> . Interestingly enough, they also have a pipe
>organ company!
>Ken
>> >How about putting Wicks phone #, e-mail, address on here for everyone
like me
>> >to use.
>> >thanks
>> >John D
>> http://www.magicneedles.qpg.com/W/wicks/
Subject: | Re: Handheld, Seat |
TEMPERFOAM GENTLEMEN! That is the stuff to use, forms to your lumbar and
southern exposure !
From: Michael Brusilow <mb-albany(at)worldnet.att.net>
Date: Friday, August 20, 1999 4:23 PM
Subject: Pietenpol-List: Handheld, Seat
point
>top
>>>Bart D Conrad
>99 )
YUP, works fine for me too!
Date: Friday, August 20, 1999 1:13 PM
Subject: Pietenpol-List: Re: Handheld Advice
>Earl,
>Craig
Gary please send your mailing address to me at: pphillips(at)kalama.com
I have some welding machine info for you.
Phil Phillips
Subject: | RIB TESTING RESULTS |
Group,
I , like many of you, have been searching for an alternative to
Sitka for use on the Pietenpol. I have been intrigued
by Western Red Cedar ever since seeing some exceptional 4x4's at a local
lumber co. The grade was called "ornamental/
deck" and the grading gave me goose bumps. One of the 8 footers had
perfectly vertical grain the full 8ft. When I ripped
it the kerf followed the same growth ring nearly full length. I have
tried with no success to get more detailed comparative info. from Forest
Products Laboratory in Madison, WI. Not to be discouraged, I built a rib
using the WRC, 1/16GL-2 3ply and
T88. Using the guidelines suggested in AirCamper.org/info/tips and
tricks/testing rib strength, I built a test jig that uses
controlled spring force vs. bulk weight. I applied the force at the
incremental spacing listed. I was very pleased to see
the 204# load with no ill effects. I continued to load in 1.4#
increments until I ran out of spring travel, at which point
the rib sustained a 358# load! I would be interested in hearing from
those of you have have tested ANY ribs and what
pitfalls I might face with using the WRC for ribs. By the way a 4x4x8ft.
"post" was $20. Two of them will make 90 cap
strips.
Group,
alternative to Sitka for use on the Pietenpol. I have been intrigued
local lumber co. The grade was called "ornamental/
the 204# load with no ill effects. I continued to load in 1.4# increments
strips.
Subject: | Re: RIB TESTING RESULTS |
There was an article in KitPlanes about a plane built completely with
Western Red Cedar a couple of years ago. Nice looking plane.
John W
Date: Saturday, August 21, 1999 2:16 PM
Subject: RIB TESTING RESULTS
Group,
4x4x8ft. "post" was $20. Two of them will make 90 cap
strips.
Subject: | Re: USELESS JIBBERISH |
Gordon,
I agree with you. When I got back from my trip to Oshkosh and Brodhead
there were 1028 messages waiting for me. The biggest percent were
"jibberish". You didn't hear me complain. It took less than 1 second to
delete each one I wasn't interested in. Kind of like scanning through a
monthly magazine. I have never found one that had every word that
interested me.
Besides, it was "jibberish" (something that had nothing to do with building
a Piet-is that the definition?) about six months ago that resulted in the
Great Piet Assault on Airventure99 last month.
Sorry for adding more "jibberish" but I have been on some lists where a
great question is asked and all the response goes directly to the person
asking the question. I soon dropped that list because I wasn't learning
anything. I would rather pay the price with using the delete key than miss out.
Every once in a while there is gold buried in the mounds... I figure it is
the price paid for the gold and living in a free world.
Ted
>Ah MIke
>Which messageges were you speaking about?
>I go thru at least 500 messages a day and find it easy to delete the
>ones that don't pertain to something I want to read.
>Maybe it just does not bother me.
>Gordon
>mike cushway wrote:
>> GUYS!
>> When making a personal response PLEASE don't reply to the group!
>> It's getting out of hand.
Steve wrote:
Is there anyone here that can tell me where I can buy some of this
western red cedar?? I live in Mississippi so I am looking near here or
how can I order some and NOT break the home bank.
Steve
writes:
> Group,
> local
> Forest
> rib
> 4x4x8ft.
> strips.
From: | walter evans <wbeevans(at)worldnet.att.net> |
Subject: | tailwheel cable attach points? |
I guess this has been done many different ways but, I have the tail assy
per the print with the coil spring and swing arms. Instead of the
skid/blade, added on a swiveling steerable tailwheel.
Should the wheel be steered by cables attached to rudder cables inside
the fuse ( more cables to pierce the skin) , or are they hooked to a
horn on the rudder itself? If so, wouldn't this put too much twisting
force on the rudder wood structure?
If from the fuse rudder cables, at what distance forward in the tail?
need all your input.
thanks,
Walt
different ways
but, I have the tail assy per the print with the coil spring and swing
arms. Instead of the skid/blade, added on a swiveling
steerable
tailwheel.
cables attached
to rudder cables inside the fuse ( more cables to pierce the skin) , or
are they
hooked to a horn on the rudder itself? If so, wouldn't this put
too much
twisting force on the rudder wood structure?
cables, at what
thanks,
Walt
Subject: | Re: tailwheel cable attach points? |
DO NOT connect the tail wheel steering to the rudder post. It was NOT
designed to take the torsional stress.
There are other ways, full swivel or swivel & lock for take off is good.
Other ideas ???
DG
Walt, I'm no expert, but I have a second set of cables going to the tail
wheel. J-3 Cubs and others are attached to the rudder. I don't know
why ours aren't. I tseemed odd to me to have extra holes in the fabric.
I did it according to plans and have the extra holes. I'd do it
different next time.
Tim Cunningham
Date: Saturday, August 21, 1999 5:04 PM
Subject: tailwheel cable attach points?
assy per the print with the coil spring and swing arms. Instead of the
inside the fuse ( more cables to pierce the skin) , or are they hooked
to a horn on the rudder itself? If so, wouldn't this put too much
tail?
thanks,
Walt
Subject: | Re: OT - USELESS JIBBERISH |
Ted
I guess it is defined by anybody what Jibberish is, I agree with the Jibberish
leading up to the Piet assult on BroadHead. Had nothing to do with building and
I
was not going even if I had a piet built, just no funds this year, I went last
year.
But that would be considered good jibberish.
I am not one to tell someone else what he can or cannot say on any list, but their
are things that should never be said on a list,
I learn alot form these lists and enjoy what anyone has to say, Yes, dig the gold
out and throw the rest away into the trash can. I have another email address I
thought was history when I quit the ISP. Low and behold I went their a couple weeks
ago and I had 3700 messages, most were from aircraft lists I had back then and
not
now. I had the systems guy delete them all for me as I could not do all at once.
I
used to be a systems admin at the Navy Civ job I had.
I use Netscape 4.5 and it is easy to go thru my email daily but I have had some
services where it was just plain hard to deal with over 50 messages, so maybe some
of these people on the list are using slow email programs and I can understand
their
concern with Jibberish.
I have a new 450 mhz system coming soon and maybe the email will be even faster
handling then.
Gordon
Ted Brousseau wrote:
> Gordon,
> interested me.
> Ted
> >Ah MIke
> >Gordon
> >mike cushway wrote:
> >> GUYS!
Walt, I attached to the rudder cables as they came back just behind the
pilot's seat, with just enough movement allowed to avoid interference. I also
made my rudder stops using swaged sleeves on the rudder cable. They hit
against the seat structure which may not be the best solution and may have to
be modified after I see how they work in the real world. Don Hicks
Walt Evans....Walt, I neglected to say that the attach at the tailwheel is on
horns that are a part of the full swivel tailwheel assbly. This is a small
lightweight unit that I bought from a source in Calif. I used it before on
another plane with no problems.
Don Hicks
Mike, I am confused. You tell me you fly without a radio and give me the
incentive to fly NORADO for two weeks and love every minute of it when I
have a radio because I fly out of a towered field. And now that I am
convinced NORADO is the way to go you up and start talking radio....?
Seriously, we have a wire antenna mounted on the bottom of the fuselage just
behind the rear cockpit. You should be able to pick up one used for around
$10 max. They come straight, 45 degree bend and (guessing here) 60 degree
bend. We have the latter. Mounted on the bottom of the fuselage (inside),
just behind the seat back, is a 2 foot by 2 foot piece of flat aluminum for
the ground plane that has been mentioned. Works great.
Ted
P.S. You want to get a microphone that sounds good in an open cockpit. I
think a helicopter mike will work well. Maybe someone else could help here.
>Mike C.
Saw Piet with tail wheel horn cable, attached to rudder horn cable, prior to
rudder cable entry into fuse. Didn't pay that much attention to clamping
device but was a clean connection. This was on an old Piet (at Sport Flyers
airport northwest of Houston) so it must have worked. This Piet didn't have
cutout in wing above pilot area. I would not like that at all, too old to
fight entry hassle, not to mention lack of visibility forward & up.
John D
If I build a Piet at all, and am leaning that way for sure, it will be
because of 'jibberish". I have admired the Piet for long time, but there are
hundreds of other neat planes out there. The "jibberish" on this site, with
it's humor & obivious friendly people made me think that I would like to be
part of this. It appears that you guys have a great time even when on the
ground.
From: | robert hensarling <rhrocker(at)admin.hilconet.com> |
From: TXTdragger(at)aol.com <TXTdragger(at)aol.com>
Date: Sunday, August 22, 1999 8:52 AM
Subject: Pietenpol-List: Re: OT - USELESS JIBBERISH
The only "useless jibberish" I've seen on this list was the initial
complaint about useless jibberish.
Robert Hensarling
http://www.mesquite-furniture.com
Uvalde, Texas
are
with
>ground.
This conversation begs for the introduction of the idea that a direct cable
linkage to the tail wheel horn leaves one open to loss of rudder control if
the tail wheel should be damaged or jammed in some way. Including a spring
in the tail wheel link allows forcefully over-riding the spring to get at
least some rudder control. Having suffered a damaged tail wheel, I can
assure you that rudder control takes on new meaning. Of course, it becomes
another one of those compromise things where you have to decide how strong
the springs should be to allow tail wheel authority and still be able to
over-ride it.
John W
Kerrville, Tx
jandd(at)maverickbbs.com
From: | TXTdragger(at)aol.com <TXTdragger(at)aol.com> |
to
Flyers
have
>John D
Subject: | Re: OT - USELESS JIBBERISH don't think so |
I also belong to an Air Warrior III Squad (an online WW2 flight game), and
the "jibberish' is out standing. I have met a lot of guys & gals from all
over the world that love airplane & flying. If you have a computer try
www.gamestorm.com not a Piet for sure but for some their only chance to
"fly". By the way, any hotshot pilot might get a dose of humility at any
time there. Where else can you "jibberish" (real time) with other gunners on
B17 (on long mission) & realize none are actually within 1,500 miles with
another. Like I was in Houston & one was in NW Canada. Thurs nite there was
1,200 people flying in over 12 arenas (250 max per arena). You can actually
talk (not type) to each other while flying, using VOX. If you are already
online gamestorm cost $9.99/mo..cheap thrill.
For what it's worth, here is what I did.
I got a 3 inch tailwheel from an outfit in Calf. It has horns. I
modified it to fit the Piet spring, I led the cables thru pulleys on the
last fuselage station,& then thru the seat back to the rudder bar.
The rudder cables run independently the rudder bar.
Subject: | Re: RIB TESTING RESULTS and Alternative woods too. |
I haven't done any load testing but I have had some experience with
cedar. In my case, Port Orford Cedar. Port Orford Cedar is a white wood
and is on the list of approved Aircraft woods.
The reasons for this approval is that it falls between spruce and fir in
weight and strength is more resistant to splitting than either. It is as
easy to work as spruce and glues well. The clincher for me is that it is
rot PROOF. I have seen it in service where oak has turned to powder,
fir is falling apart but the Port Orford Cedar is ready for another 50
years service.
The one problem with Port Orford Cedar is availability. I would expect
that only folks in the Pacific Northwest will be able to find it. I do
know that ship loads of it were being sent off to Japan at 20 cents a
board foot a few years ago. This was a good deal for the Japanese who
revere white cedars, not so good for boat and aircraft builders in the
U.S. who do likewise.
Lauren
Thats interesting. Are you actually flying one on one or in a flight crew doing
a
mission?
Sounds like something I could be interested in when my new computer gets here.
Thanks for the interesting Jibberish.
Gordon
From: | Joe & Marian Beck <flyretina(at)feist.com> |
Subject: | Re: 'Plane Crazy" |
Ken Hannan:
Would you please put me in line to borrow your tape. I completely
missed the thing and would like very much to see the 30 day miracle man
after Greg.
Thanks.
CJB - Wichita
Subject: | Wichita Piets - Jibberish |
Hi Joe, Doug, Chuck,
I just wanted to drop you a note to intro myself. I am a Pietenpol nut
from way back and only recently got onto this discussion group. I for one
have to applaud the Jibberish because it is inspiring me to get back to what
I wanted to do 10 years ago. After contacting him thru here I met Chuck
Gantzer and went to visit him yesterday. He showed me his project and then
pictures of Doug's and Joe's local projects. I had no idea there was this
kind of interest in Wichita. Seeing Chucks wing almost complete and the
level of interest in the area has put the bug in me to get back to the
project I tried to start in 1989 but didn't follow thru because my ex wife
didn't like having a shop in the spare bedroom. Well she's history now...so
I am going for it. In fact, I have already been to see Gus Weebie about
supplying some of the wood materials I need. He quoted me a good price to
provide spars for the 3-piece wing. I am needing to get my hands on a copy
of Vi Kapler's 3-piece wing drawings so I can get gus started. The set of
plans I bought from Orrin Hoopman did not have the 3PW drawings. I already
have a rib jig I built in 1989. I have compared it with Chucks ribs to find
only some minor differences. I am off today to look for some cap-strip
material. I want to see what kind of WRCedar is available in town. Chuck
and I weighed my Douglas FIR rib built 10 yrs ago to find it was 4.5 oz.
heavier than his cedar ones. Looks like Cedar is a good choice to me. I
think I might drop into Benton this afternoon and see if anyone is around.
See you on the 11th at the Benton Piet Fly-in.
Terry Bowden
I ordered 160 board ft' of clear douglas fur along with 1/6, birch,1/18
and 1/4 marine grade okoume enough to almost build two Piets
was 2500.00 including shipping.
----- Original Message -----
From: | Lauren Williams <LaurenMWilliams(at)webtv.net> |
Sent: Friday, August 20, 1999 10:16 AM
> Lauren
Subject: | Re: AirWIarrior III JIBBERISH last one |
I will answer this one on Piet channel, in case someone else is interested,
but in future will go direct.
You can fly, gun, whatever. It was slow night, so 5 of us gunned & BS'd on
intercom while OTW to target. Norm is to fly escort on fighter, & buff has
only pilot. Pilot puts on autopilot & becomes bombidere over target. There
are about 20 aircraft you can fly, according to mission & skill level. There
is no a/c that is best, all have good & bad traits, like the real world. You
have to learn to fly each type plane, landing alone, takes several days of
practice, because if you blow landing you lose 66% of score for that flight.
Anyway try www.gamestorm.com and they will walk you thru it. Don't
get discouraged because of site problems, like all they are having trouble
with demand. First month is free & you can withdraw with NO Charge. Wish I
did own stock in it, as it may appear......but I don't.......just a total
airplane nut.
WARNING.......IT IS VERY ADDICTIVE........
John Davis txtdragger(at)aol.com
John W talked about a damaged tail wheel. I had one also on my second
flight. The Scott tail wheel was fine, but the spring wasn't a real spring
and during taxi runs it went straight and now my wheel is up touching the
rudder. I was airborne and couldn't figure out why all I had was left
rudder. I couldn't get the rudder past neutral because the tail wheel
blocked it. I landed all right and bought a new Taylorcraft leaf spring
from Aircraft Spruce the next day. I still think the tailwheel horn should
be connected to the rudder horn like on Aeronca's, J-3's etc. Do we know
something they don't?
Tim Cunningham
Subject: | unsubscribe please |
Please eliminate me from subscription list - I spend most of my e-mail time
with this and keep getting double messages on top of it.
Thank you.
Just finished my last rib last night. Now I spent the afternoon trimming
the "gusset overhang".
Thats 24 ribs and 4 end ribs in the books. ( three piece wing, center
sect. made already)
Walt
night. Now I
spent the afternoon trimming the gusset
overhang.
in the books.
( three piece wing, center sect. made already)
Walt
Walt,
You are now entitled to do a rib jig which is a little dance you do when
the last one is completed.
John W
Date: Sunday, August 22, 1999 4:20 PM
Subject: WHEW!
trimming the "gusset overhang".
Walt
Unsubscribe
Most people connect the tailwheel steering cables to the rudder cables,
swedging outside the plane after the rudder cables exit the fuselage.
These cannot be connected direct, but must have a spring at the tailwheel
steering arm so the rudder and tailwheel can have some independent
movement.
John Langston
>good.
>Other ideas ???
>DG
__________
Subject: | Re: Plywood ribs. |
Steve,
While plywood ribs are quicker to make, they are also heavier. This is
why so many planes use built up ribs.
John Langston
writes:
>Steve
>Mohawk, Avid, Kitfox, Prospector all use plywood ribs with cap
>strips.
>Mohawk has a 1" wide cap strip and the spars are 2 1/2" alum tubing
>with
>capstrip glued right over it connecting to aileron section. Not sure
>just
>what the Kitfox has for sure.
>Gordon
>vistin(at)juno.com wrote:
>> I got my copy of Kitpalnes today and while reading the article I
>noticed
>> the Piet written about used solid plywood ribs. Is this possible?? I
>am
>> interested in this as I did build a Stewart headwind using the same
>type
>> rib construction.
>> If so should I use a cap strip??
>> Steve
__________
Subject: | Re: Continental engines |
Wind driven generators are as old as the hills-they were used in the
First World War. I used to fly an Aeronca Champ with such a generator and
it suppiled power diectly to the radio we were required to use. There was
no battery involved and to talk to the tower on the ground required
running the engine up to 1500 RPM to get enough juice for the radio to
work. We could not hear the tower when taxiing at lower RPMs.
John Langston
writes:
>Great Idea! People are now wider, taller and need creature comforts.
>Did you also add the door modification? The tradition, as I see it, is
>that B. P.
>tried many things to improve the parasol design and, if he was living
>now, would
>applaud all the experimentation.
>As to Continentals w/o generator/alternators, have you guys seen the
>generator
>mounted within the landing gear and driven by a RC propeller? Trade a
>little drag
>to recharge the battery for your handheld or ??
>jshutic(at)nordson.com wrote:
>> Steve, some additional details are offered concerning my
>"wide-body"
>> Aircamper. First of all, much thanks to Mike Cuy who let me look
>over his
>> Hardly a traditional Piet, but an enjoyable project all the same.
__________
Subject: | Re: continental engines |
John,
Franklin made a two cylinder, 60 HP engine back in the early 70s. It was
sold in a Champion 7ACA which was to be an updated "Airknocker", but
didn't sell well. I worked on one about 1972.
John Langston
writes:
>Doesn't Franklin make a two cyl engine of 50 hp or so also? Seems
>that
>would beat the socks off of a 40 hp Model A.
>John W
>From: Ken Beanlands <kbeanlan(at)spots.ab.ca>
>Date: Wednesday, August 18, 1999 12:19 PM
>Subject: Re: continental engines
>>Well, I'm finally back from my 3.5 week vacation and road trip from
>>Calgary, AB to St. John's, NF. That's a 13000 km round trip.
>>Unfortunately, we didn't have enough time to make it to B'head or
>OSH
>>despite the fact that we were fairly close by. However, next year we
>hope
>>to be to OSH in the Christavia.
>>As for engines, another possibility in the same price range is the
>new
>>Franklins. I know I've mentioned them before, but heck, I like them.
>They
>>weigh 240 lbs with accessories, puts out 120 hp and will fit on a
>>continental mount. Strip off the accessories an you will end up with
>a 200
>>lb engine. Although the thrust will be higher than an 0-200 or
>simular
>>engine, I don't think it would be too much for the Piet frame as it's
>a
>>much smoother engine than other 4 bangers due to a viscuously damped
>>flywheel.
>>My 150 hp version should be here early next month!!
>>Just a thought.
>>Ken
>>On Wed, 18 Aug 1999, Michael Brusilow wrote:
>>> Dave wrote:
>a
>>> Piet. Forget about a starter though. The added weight and addition
>of an
>>> electrical system will add 10 to 16 lbs for a gen., 16 lbs for a
>>> starter, another 20 lbs for a battery, wiring, switches . . . You
>will
>>> end up with a one place airplane with poor performance. Hand
>proping is
>>> neither dificult or dangerous as long as you know what you are
>doing.
>>> Get someone who knows and have them teach you. You will be glad you
>did
>>> with the improved performance of an airplane about 50 lbs
>lighter.>
>>> Don't know about that.
>>> I have been flying my Aircamper with an 0-200, starter & altenator
>for 8
>>> yrs. Two years prior, it had Ford engine.
>>> My power configuration ( battery included ) does not weigh as much
>as
>>> the Ford engine plus the radtiator & water. ( give or take a few
>pounds
>>> in either direction ).
>>> As for performance, my aircraft cruises a + or - 80 mph at 2250 rpm
>>> which is low for an 0-200 ) & climbs at approx 600 ft/min depending
>on
>>> the oat. No problem with two people.
>>> Poor performance? Try Ford Piet on a hot day from a short grass
>strip
>>> with trees at the end of the runway.
>>When once you have tasted flight, you will always walk with your
>eyes
>>turned skyward, for there you have been and there you will always
>be.
__________
Subject: | Re: unsubscribe please |
Sounds like the computer subscribed you twice. Did you save the message that
tells you how to unsubscribe?
Let me know if not and I will go find mine and send it to you.
GB
> Thank you.
From: | Ethos Atlanta <ethosatlanta(at)mindspring.com> |
Subject: | unsuscribe please |
Please remove me from subscription list - I spend most of my e-mail time
with this and keep getting duplicate messages.
Thank you.
Warren Shoun wrote:
> Unsubscribe
OK Folks,
This is the message you were asked to save, case you were going on
vacation, Got Mad, or other reason to unsubscribe. Read below and
please everyone save this message.!!
Gordon
Welcome to the Pietenpol Discussion Mailing List
This list is for builders, pilots, owners, enthusiasts, and anyone
else
interested in this 60+ year old design. Anyone is welcome to present
questions/answers to the lists, and participation is encouraged.
Hopefully
this will be a forum that will encourage and promote the Pietenpol
design
for another 60+ years.
To subscribe to this list send a message to:
listserv(at)ucsnet.BYU.EDU
Include the following line in the message body:
SUBSCRIBE PIET
To unsubscribe from this list at any time, send a message to:
UNSUBSCRIBE PIET
To send mail to the list use:
PIET(at)BYU.EDU
Thanks, and enjoy.
Steve Eldredge (list manager and piet builder)
John,
You know I didn't know about that .......but I still did it.
walt
Date: Sunday, August 22, 1999 6:03 PM
Subject: Re: WHEW!
Walt,
when the last one is completed.
John W
Subject: WHEW!
Walt
Walt
Did you take vedio so you can post it on DeCostas Web page?
GB
walter evans wrote:
> John,You know I didn't know about that .......but I still did
> it.walt
> From: John Weikel <jandd(at)maverickbbs.com>
> Subject: Re: WHEW!
> Walt,You are now entitled to do a rib jig which is a
> little dance you do when the last one is completed.John W
GB
Naw,,,got two left feet.
walt
Date: Sunday, August 22, 1999 7:24 PM
Subject: Re: WHEW!
Walt
GB
it.walt
afternoon trimming the "gusset overhang". Thats 24 ribs and 4 end ribs
in the books. ( three piece wing, center sect. made already)Walt
I really ment did you get a Video of it. Keys on backwards on my
keyboard:-))
Gordon Brimhall wrote:
> Walt
> GB
>> it.walt
>> Subject: Re: WHEW!
>> W
Subject: | Re: 'member this?- Registration Numbers |
Walt,
I don't have the reg in front of me, but there is a loophole that allows
some liberties with replicas. Piets are considered replicas of planes that
were registered by the CAA in those days. All of the antique airplane guys
and particularly the replica builders homed in on the loophole long ago. The
reg allows you to use markings authentic to the era of the plane including
"N" plus "C" or "R" or "X". There are the basic requirements for size and
"N" at minimum must precede the number. I will get the actual reg out at
work tomorrow and double check the wording.
Terry
Terry,
thanks, I would be very interested to read it.
walt
Date: Sunday, August 22, 1999 7:49 PM
Subject: Pietenpol-List: Re: 'member this?- Registration Numbers
>Walt,
allows
The
> Terry
Tim, sure, they know that their fuselage is welded tubing...we know that ours
is glued wood unless of course you are one of the few who went to a tube
fuselage.
Isn't that what the concern is...the high stress levels on the wood
rudder...even though you attach to the horn. At least that's the message I
got.
Don Hicks
Subject: | New Builder Needs Special Plans |
Hello,
I am doing the research for a friend (who does not have a computer) that is
building a Piet. He has the Model A engine almost complete, and is ready to
start on the fuselage (and he is really anxious!).
He needs the plans for the three piece wing and the full size template
(plans?) for the wing rib. Is there a single place where these items can be
purchased without purchasing other plans?
Also, he has been told to build the "longer" fuselage. His plans are for a
163 inch fuselage. Should he build the "longer" fuselage, and if so, where
can he get the plans for it?
Thanks very much, Glenn
trying to locate the full size template (plans?) for the wing rib. Also need
the three piece wing plan.
Subject: | Marginal Aviation |
Any of the old "Marginal Aviation" gang in the discussion group? My earliest
meories of Pietenpols is from the Antique Airplane gatherings at Blakesburgh
Iowa in the '70's. Guys like Forrest Lovely, Alex Whitmore, and Gary Hansen
were always there with a Piet in one form or another. Anyone know those guys?
Terry
Subject: | Re: 'member this? |
Walt, The regs say:
FAR 45.22(b) A small U.S. registered aircraft built at least 30 years ago or
a U.S. registered aircraft for which an experimental certificate has been
issued under 21.191(d) or 21.191(g) for operationg as an exhibition aircraft
or as an amateur-built aircraft and which has the same external configuration
as an aircraft built at least 30 years ago, may be operated without
displaying marks in accordance with 45.21 and 45.23 through 45.33 if:
(1) It displays in accordance with 45.21(c) marks at least 2" high on each
side of the fuselage or vertical tail surface ....
So the bottom line is since the first Piet was built more than 30 years ago
you can use the 2" letters.
Scott
> Just wanted to share what inspired me to build a Pietenpol. Was looking
for
> a project and then got issue. 'nuff said.
> Now I have a question. When it comes to "N" numbers. Jim Malley talks
of
> a FAR 45.22, which says that an aircraft designed more than 30 years ago is
> exempt from many of the current markings. Since then I've talked with a
guy
> who , last year finished a Kitfox, and he said that that reg has more
strings
> on it than it's worth.
> Has any or all of you guys registered yours with this reg?
> Fill me in, please.
> walt
Subject: | Re: New Builder Needs Special Plans |
Glenn
Don Pietenpol has everything you need.
Ted. T
You would be surprised at how many of our "FAA Friends" don't know this
regulation !!!!! BIG HINT=copy this and keep it your airframe logbook and a
copy of it IN YOUR AIRPLANE AT ALL TIMES !!!! This came right from the
mouth of the Cleveland, Ohio Chief of MIDO !!! MIDO does the initial
airworthiness thing to get you going. Down the road somewhere a FSDO
Aviation Safety Inspector might approach you being fresh out of "Fed school"
just looking to Violate you because HE doesn't know the rules! This happens
all the time. (Ask Bob Hoover). Anybody read his latest book entitled "AIR
OF INJUSTICE" ? If not, you cannot believe what happened to that man and
numerous others. Do your homework and in certain cases, TAKE IT WITH YOU!
Earl (the Fed antagonist) Myers
Date: Sunday, August 22, 1999 10:19 PM
>Walt, The regs say:
or
aircraft
configuration
>Scott
>for
talks
>of
is
>guy
>strings
>> Fill me in, please.
>> walt
From: | "Everett L. Schermerhorn" <musical(at)rconnect.com> |
Please unsubscribe me from the Pietenpol mailing list.
From: | "David B. Schober" <dschober(at)mail.fscwv.edu> |
Subject: | FAR45.22 was 'member this? |
The full text of 45.22 follows:
(a) When display of aircraft nationality and registration marks in
accordance with 45.21 and 45.23 through 45.33 would be inconsistent with
exhibition of that aircraft, a U.S.-registered aircraft may be operated
without displaying those marks anywhere on the aircraft if:
(1) It is operated for the purpose of exhibition, including a motion
picture or television production, or an airshow;
(2) Except for practice and test fights necessary for exhibition
purposes, it is operated only at the location of the exhibition, between
the exhibition locations, and between those locations and the base of
operations of the aircraft; and
(3) For each flight in the United States:
(i) It is operated with the prior approval of the Flight Standards
District Office, in the case of a flight within the lateral boundaries
of the surface areas of Class B, Class C, Class D, or Class E airspace
designated for the takeoff airport, or within 4.4 nautical miles of that
airport if it is within Class G airspace; or
(ii) It is operated under a flight plan filed under either 91.153 or
91.169 of this chapter describing the marks it displays, in the case of
any other flight.
(b) A small U.S.-registered aircraft built at least 30 years ago or a
U.S.-registered aircraft for which an experimental certificate has been
issued under 21.191(d) or 21.191(g) for operation as an exhibition
aircraft or as an amateur-built aircraft and which has the same external
configuration as an aircraft built at least 30 years ago may be operated
without displaying marks in accordance with 45.21 and 45.23 through
45.33 if:
(1) It displays in accordance with 45.21(c) marks at least 2 inches high
on each side of the fuselage or vertical tail surface consisting of the
Roman capital letter "N" followed by:
(i) The U.S. registration number of the aircraft; or
(ii) The symbol appropriate to the airworthiness certificate of the
aircraft ("C", standard; "R", restricted; "L", limited; or "X",
experimental) followed by the U.S. registration number of the aircraft;
and
(2) It displays no other mark that begins with the letter "N" anywhere
on the aircraft, unless it is the same mark that is displayed under
paragraph (b)(1) of this section.
(c) No person may operate an aircraft under paragraph (a) or (b) of this
section -
(1) In an ADIZ or DEWIZ described in Part 99 of this chapter unless it
temporarily bears marks in accordance with 45.21 and 45.23 through 45.33
(2) In a foreign country unless that country consents to that operation;
or
(3) In any operation conducted under Part 121, 127, 133, 135, or 137 of
this chapter.
(d) If, due to the configuration of an aircraft, it is impossible for a
person to mark it in accordance with 45.21 and 45.23 through 45.33 , he
may apply to the Administrator for a different marking procedure.
If you want to operate IAW 45.22 (a) there are a lot of restrictions,
but 45.22 (b) allows you to use 2" numbers, use NX, not put
"experimental" at the cockpit entrance, and the only restriction is that
you can't fly thru an ADIZ or DEWIZ and if you want to operate in a
foreign country unless they ok it. That's not many restictions in my
book!
walter evans wrote:
> ( Jim Malley are you out there?)Just wanted to share what inspired me
> to build a Pietenpol. Was looking for a project and then got issue.
> 'nuff said.Now I have a question. When it comes to "N" numbers. Jim
> Malley talks of a FAR 45.22, which says that an aircraft designed
> more than 30 years ago is exempt from many of the current markings.
> Since then I've talked with a guy who , last year finished a Kitfox,
> and he said that that reg has more strings on it than it's worth. Has
> any or all of you guys registered yours with this reg?Fill me in,
> please.walt
David B.Schober, CPE
Instructor, Aviation Maintenance
Fairmont State College
National Aerospace Education Center
1050 East Benedum Industrial Drive
Bridgeport, WV 26330-9503
(304) 842-8300
(2) Except for practice and test fights necessary for exhibition purposes,
it is operated only at the location of the exhibition, between the exhibition
locations, and between those locations and the base of operations of the
aircraft; and
any other flight.
a U.S.-registered aircraft for which an experimental certificate has been
issued under 21.191(d) or 21.191(g) for operation as an exhibition aircraft
as an aircraft built at least 30 years ago may be operated without displaying
high on each side of the fuselage or vertical tail surface consisting of
the Roman capital letter "N" followed by:
aircraft ("C", standard; "R", restricted; "L", limited; or "X", experimental)
followed by the U.S. registration number of the aircraft; and
on the aircraft, unless it is the same mark that is displayed under paragraph
this section -
it temporarily bears marks in accordance with 45.21 and 45.23 through 45.33
or
of this chapter.
a person to mark it in accordance with 45.21 and 45.23 through 45.33 ,
he may apply to the Administrator for a different marking procedure.
but 45.22 (b) allows you to use 2" numbers, use NX, not put "experimental"
at the cockpit entrance, and the only restriction is that you can't fly
thru an ADIZ or DEWIZ and if you want to operate in a foreign country unless
they ok it. That's not many restictions in my book!
walter evans wrote:
( Jim Malley
for a project and then got issue. 'nuff said.Now
Since then I've talked with a guy who , last year finished a Kitfox, and
he said that that reg has more strings on it than it's worth.Has
me in, please.walt
(304) 842-8300
Subject: | Re: Marginal Aviation |
I used to run with the "Marginal" group. I saw Forrest, Alex and Marty at OSH this
year. Went to Blakesburg last year for the first time since '86 or '87 and saw
Gary there.
> Terry
(304) 842-8300
Walt- The 30 year old design deal with that FAR that allows you
to use NX------- is used by us to ELIMINATE the need for the big
EXPERIMENTAL sign otherwise required. In other words, if you use
the NX you don't need that big ugly sign inside or outside of your
aircraft. Don't let the FAA boys tell you otherwise.....have the reg.
printed out and hand it to him with your other paperwork. My guy
didn't have a clue as to what I was talking about.....so I just handed
him the reg a let him read it. NOTE: the FAA in OKC will not recognize
that NX when you register or get your airworthiness certificate !
It is merely an X in place of that EXPERIMENTAL billboard. Just a marking,
not something on paper. It's a neat little thing to know about....thank you
to Frank Pavliga Sr. and Jr. for telling me about this rule.
Mike C.
From: | Greg Cardinal <gcardinal(at)startribune.com> |
BHP recommended attaching the tailwheel steering cables to the rudder bar
4 inches out from the pivot point.
This info is on the supplemental plans sold by Orrin Hoopman.
Greg Cardinal
>>> walter evans 08/21 4:03 PM >>>
Should the wheel be steered by cables attached to rudder cables inside the
fuse ( more cables to pierce the skin) , or are they hooked to a horn on
the rudder itself? If so, wouldn't this put too much twisting force on
thanks,
Walt
Donot attach to rudder or rudder cables. Weld an extra set of tabs to rudder
bar approx. 4" either side of center hinge point and run another set of
cables to tail wheel. This will allow the tail wheel arc the same as the
rudder
Joe Santana N444MH
>From: walter evans <wbeevans(at)worldnet.att.net>
>Date: Sat, 21 Aug 1999 18:03:24 -0400
>the rudder itself? If so, wouldn't this put too much twisting force on the
>thanks,
>Walt
Tim,
I just broke my first tail wheel spring at a friends grass strip near
home. A Scott. Replaced it with a John Deere cultivator spring. About
30% heavier. Seems to work great. Had the 4 year old neighbor kid with
me when it happened. He said if he knew we were going to crash he would
have brought his tool box. Stuff happens.
Craig
Subject: | HELP!! Basic Fuselage Confusion |
Help! My friend is very confused about which fuselage to build for an Air
Camper powered by a Model A Ford engine. He is in his mid-70's and feels he
has no time to waste. He wants to get it built, and to get it into the air!
So he is pushing me to try and find some answers for him. I hope this group
of Piet experts can help him.
Here are the details of his most pressing problem:
He purchased the Pietenpol Air Camper plans, fuselage sheet dated 1-19-33,
length of fuselage is 163 inches.
Several people have recommended building the "longer" fuselage version.
He has been told by a Pietenpol builder to use poplar for the fuselage,
because quality fir is just not available.
Questions:
Should he build the longer version? If so, what are the advantages?
Where does one get the longer version plans (without having to buy other not
needed plans)?
Is poplar wood a good replacement for fir?
Many, many thanks!!
Glenn
This is a great info pack for those of you south of the Border. Anybody
know of any obscure regs that might apply to Canada?
Don, you are absolutely right about the Champ and others having a tube
structure and the rudder has the strength to attach the tail wheel there. I
forgot that mine is made of sticks and cloth. I'm glad someone designed the
Piet other than me. I have a Scott tail wheel with full swivel and it works
great. I hate to have the extra holes for the second set of wires, but it
does work good. I hate the flying wires too, but what do I know. I just
love flying the thing.
Tim Cunningham
From: DonanClara(at)aol.com <DonanClara(at)aol.com>
Date: Sunday, August 22, 1999 7:47 PM
Subject: Pietenpol-List: Re: Tail Wheel
ours
>fuselage.
>got.
>Don Hicks
Subject: | NX instead of Experimental |
Mike and Gang, The FAA guys don't know how to read and interpret their own
regs. My inspector didn't understand and insisted I have Experimental
plastered on NX899TC. I put it on for him while he was standing there and
ripped it off as soon as he signed my airworthiness certificate. So, having
the reg doesn't help. He said if Oklahoma City put NX on the registration
he would allow it. I called him a moron. I was nicer to him when he came
back for the second inspection a few days later.
Tim Cunningham
Date: Monday, August 23, 1999 8:11 AM
you
>Mike C.
Any Piet guys heading to Blakesburg 3,4 or 5 September? I hear it's a
great event to see lots of old Aircraft. One year they had 11 Pietenpols.
If the weather holds NX899TC will be there.
Tim Cunningham
Subject: | Thanks for all "member this" |
Thanks to all who answered and will answer. That clears up alot for me
and I'm sure others.
Saved all the responses to my files.
walt
answer. That clears up alot for me and I'm sure
others.
files.
walt
From: | Dave and Connie <dmatt(at)frontiernet.net> |
Subject: | Re: HELP!! Basic Fuselage Confusion |
The longer version is used if you are not using a heavy engine such
as a Model A. If he is going with the A engine then build the short
fuselage.
Quality fir is available. Better yet use spruce like was intended.
You can get all of the spruce from Western Aircraft in Calgary. Some
people have also found adequate Douglas Fir in lumber yards.
>needed plans)?
http://www.pietenpol.com
The FAA says spruce, douglas fir, western hemlock. Use others
if you do the research. Piets have been built from other woods.
Dave
Mike on NX40772 my antenna was mounted in the vertical fin using stainless
steel whip in a plastic sheath. It had a plug I think it was called a banana
type that attached it to the coax. If you removed the fin theyou could unhook
the antenna. I also have this similar arrangement in my Duster Sailplane only
using a dipole type antenna.
Craig Aho
Subject: | Re: Thanks for all "member this" |
Yeah, I'm still here.
Terry and Mike C. gave accurate information.
It was my local FSDO office which first told me about the availibility of
small numbers and NX. But don't be surprised that some local FSDO types have
trouble with the obscure reg, the FAA elite at Oshkosh were similarly
confused: I was "grounded" during the '91 convention for not having the
"experimental" sign. To prove my willingness to comply, I bought one, stuck
it on with copious amounts of suntan lotion and went to the hearing. The vote
was 4 to 1 supporting the loophole. The sign slid off and so did I. I've kept
a copy of 45.22 with me ever since.
Jim Malley
Subject: | Fwd: Advisory Circular 20-27D |
Hey Guys,
I thought since we were on the subject of the FAA, I would pass along the
attached advisory circular. If you have Microsoft Word (version 6.0 or
newer) you should be able to download it and open it right up. I recommend
that everyone print yourself a copy for reference. In most cases it will
send you off in the right direction for at least the common questions that
may come up. For those of you who are inexperienced with Advisory Circulars,
they are FAA supplemental information which do not supersede FARs but are
intended to provide guidance for an acceptable means of compliance to the
regs. They are not the only acceptable means...but one that has already been
blessed by the FAA. There is a lot of helpful information in this one for
CERTIFICATION AND OPERATION OF AMATEUR-BUILT AIRCRAFT. If anyone has a
specific need to locate a particular FAR, AC, TC, STC, AD, TCDS etc..., let
me know and I will grab it off of the system at work and forward to you. We
have the subscription with all of the latest updates. I hope this is useful
to some of you.
Terry
(CDT)
Subject: | Low and Slow ....over town? |
I got this off of the AVweb.com weekly e-NewsWire called AVflash. Thought it
would be of some interest. It brought to mind something I saw in Grant
McLaren's 1990 or 91 Piet calendar. One of the months had a great pic of
downtown Manhattan (NY not KS) as viewed thru the struts of a Piet.
Terry..................
EAA GETS FAA CLARIFICATION ON HOMEBUILT OVERFLIGHTS OF POPULATED AREAS
EAA finally got a clarification from the FAA regarding limitations for
homebuilt aircraft that fly over populated areas. The FAA said that
amateur-built aircraft that received an airworthiness certificate before
May 28, 1998, and have authorization to take off and land over densely
populated areas continue to have authorization to fly over those areas
for "en route operations." Amateur-built aircraft receiving
airworthiness certificates after May 28, 1998, may fly over populated
areas if the aircraft has no hazardous operating characteristics or
design features, and the aircraft is controllable throughout its normal
range of speeds.
THAT LAST PART LEAVES A LOT FOR INTERPRETATION..HEHEHEE...tlb
Subject: | Delete this unless you like humorous Jibberish |
SHORT FINAL...
I am a flight instructor at a large flight school where my girlfriend is
a student. She is preparing for her private checkride, so every once in
a while I quiz her.
She was having difficulty remembering when a pilot needs a complex
endorsement, a high-performance endorsement, and a type rating. I asked
her if I could be a copilot on a Boeing 747.
She looked at me with a puzzled expression and said, "Let's see ... ummm
... how many horsepower does it have?"
Subject: | Re: Low and Slow ....over town? |
> range of speeds.
Would it not be up to the builder to determine what the "normal
range of speed is?" I can't think of any homebuilt a/c which is
not controllable throughout it's normal speed range, and if mine
were uncontrollable at a certain speed, I would not categorize
that speed as "normal".
Pat
Subject: | Terry-populated areas |
Terry- The guy who signed off my Piet last year always gives me
a rash of onions when I fly over the southern suburbs of Cleveland.
He always points out the 'densely populated area' reg.
THANKS to you I just forwarded his own employers new interpretation
of the rule to him to digest !!!
Hey, if Glasairs and Lancairs can shoot IFR approaches into International
airports, why can't I fly my 74 mph Pietenpol into a Chicago area outlying
uncontrolled airport.....like Plainfield, Illinois where I stopped for an
excellent
lunch and some 80 octane on the way home from Osh ?? PS- this is an
old time airport which has housing developments close in from every side.
You take off right over a Wal-Mart and Sears....but somehow they still
operate ok.
Mike C.
Subject: | Using 4220 mags on Continental |
Ken,
I also would be very interested in how you were able to make use of the
4220 mags, having bought four.
-Bill
> Date: Wed, 18 Aug 1999 12:01:06 -0700
> From: Pat Panzera
> MIME-version: 1.0
> Comments: Originally To: "Pietenpol Discussion"
> X-Listname:
> Ken Beanlands wrote:
> > My custom rebuild will be $6500 USD but does not include carb, mags or
> > altenator. The rebuilder was able to use the $15 4220 mags with a little
> > modification. I also had an 0-200 MS carb in the shop that he re-jetted
> > and used. The engine is now running and awaiting some minor tweaking.
> How about more detail on the mag conversion. I've been told that the
> 15 degree lag is not enough, that the 0-200 needs something like 20-25
> Pat
Subject: | Re: Terry-populated areas |
> excellent
> operate ok.
> Mike C.
Clow field (Plainfield) has been a burger stop on more than a couple of
occasions--the old time diner is right out of the fifties with a wall of
windows looking over the tie down area/ taxiway...I'll bet you had several
noses against the glass as you taxied up to the diner....
JoeC
Zion, Illinois
Subject: | Fly-In at Tyler Pounds field |
The Historic Aircraft Memorial Foundation is having a Fly-In Sept 4 at
Pounds Field in Tyler Texas.
Their idea of historic will be WWII war birds It would be nice to show
them some real historic aircraft types
There wilol be the usual pancake breakfast at $4.00 per plate at Crystal
Jet which is the new name on the old Tyler aero hanger if you know
Tyler Pounds if not it's on the NW side of the tower . It is where the
general avation stuff is on the tower side of the field . Not to be
confused with Tyler Jet which is on the same side of the field but is
populated by the high $ exec-jet types. The day begins at 8:00 Am and
goes until Noon . They will be doing a Young Egals ground school and
giving free Young Eagles rides for the 8- 17 year olds
I just though I'd post this in case a GN-1 or two would want to
follow I 20 from Dallas to Tyler
Gene Tomblin
THIS is a rule that is WIDE OPEN to intretation, IE, what the heck do they
mean?
Doesn't get any wider than that, huh? Anybody have a "for instance"??
As a personal flying rule, I avoid built up areas (and water,nooooo we don't
do WATER!) and towns whenever possible when flying the old planes...........
Earl Myers
Date: Tuesday, August 24, 1999 9:31 AM
Subject: Pietenpol-List: Re: Low and Slow ....over town?
>> range of speeds.
>Pat
>Earl Myers
Earl- A big Amen to that no over water rule for me too. Maybe 1/2 mile or
two but that's enough for me. When the photo guys at EAA told me to
"just fly 20 NM over Lake Winnebago" to the photo site at New Holstien I
about filled my pants. No thank you, I'll go the scenic route !
I ain't flyin' no speed demon.
Mike C.
Subject: | RE: Low and Slow ....over town? |
If I want to fly, I nearly have to fly over a town. I live in a valley with
high mountains on either side. If I go south I can stay over sparsly
populated areas, but If I go north it is either over water, (utah or Salt
lake) or over city. Mostly I stay south for pleasure flying. I have had to
fly over short stretches of salt lake and believe me it is very
uncomfortable. I fly sailboat to sailboat. It sure was nice to take in
some new scenery on the trip east!
Steve Eldredge
IT Services
Brigham Young University
> Michael D Cuy
> Sent: Tuesday, August 24, 1999 10:29 AM
> Subject: Re: Low and Slow ....over town?
> planes...........
> >Earl Myers
> Maybe 1/2 mile or
> Holstien I
> Mike C.
I BET YOU WOULD HAVE FILLED YOUR BRITCHES WITH FOAM (it floats!) !!!!!!
Date: Tuesday, August 24, 1999 12:32 PM
don't
planes...........
>>Earl Myers
>Mike C.
Steve;
I saw the pictures of those mountains....got hypoxia just looking at them!
I used to fly Maintenance Test Fights for a flight school/engine shop before
the planes were returned to service. That started it then the oldies came
later and just carried the same watchfull eye on that. Townes have too many
News camera's.
Earl
Date: Tuesday, August 24, 1999 12:47 PM
Subject: Pietenpol-List: RE: Low and Slow ....over town?
with
to
>Steve Eldredge
>IT Services
>> Michael D Cuy
>> planes...........
>> >Earl Myers
>> Maybe 1/2 mile or
>> Holstien I
>> Mike C.
I THOUGHT THE GREAT SALT LAKE WAS ONLY AN INCH DEEP!
with
to
>Steve Eldredge
>IT Services
>> Michael D Cuy
>> planes...........
>> >Earl Myers
>> Maybe 1/2 mile or
>> Holstien I
>> Mike C.
Interesting, My friend just started flying lessons out of Long Beach Airport and
the instructor always takes him out past the Break Water in the ocean to
practice in the C150. I wonder what the Glide ratio is and if with a power out
they could make land. Maybe that is the practice area defined by FAA.
I'll have to ask him if he carries his Rubber Duckie with him. (Not Antenna)
We used to Sailboat and always felt we were in free flight with the wind moving
at a fast 8.5 knts in our Hans 38T
Gordon
> Steve Eldredge
> IT Services
> > Michael D Cuy
> > planes...........
> > >Earl Myers
> > Maybe 1/2 mile or
> > Holstien I
> > Mike C.
> >Earl Myers
> Mike C.
for those who don't know the lake, it's 11 miles wide and 27 miles long.(one of
my favorite fishing spots)
JoeC
Would anyone care to estimate the glide ratio of a Piet? What is the glide
angle for maximum distance? One half of 11 miles is 5.5 miles or about 29,000
feet. At 10:1 and 3,000 feet altitude on a calm day you could theoretically
make it to either shore with a little to spare.
Maiser(at)adena.byu.edu on 08/24/99 04:08:54 PM
Please respond to piet(at)byu.edu @ INTERNET
cc:
> >Earl Myers
> Mike C.
JoeC
I for one have flown over Lake Winnebago twice and outside of gliding
distance of the shore. I ended up in the lake just short of the shoreline.
OK, I was on floats and I was heading for the seaplane base for OSH.
One piece of trivia that I found most entertaining was the meaning of the
indian word Winnebago. Due to the shallow nature of the lake (less than
20') it has a high concentration of algea that gives the lake a bit of a
odour. It's naturally occuring (not polution) and has been around for
centuries. Hence, when the Native Americans named the lake they called it
Winnebago; "Smelly Water". Everytime a "Smelly Water" passes me on the
hiway, I have a little chuckle.
As for flying over open water, there is nothing like flying the 40 mile
gap between Newfoundland and Nova Scotia. The engine goes to automatic
rough as soon as the floats pass the shoreline. I always try and get as
high as possible (8500'-9500') but have had to do it at 1500' (2500'
ceiling) and only 5 miles vis once. That wasn't fun. Same thing applies,
fly from one vessel to the next. Fortunately, there is a lot of shipping
both between NF and NS and out the St. Lawerance. You never really leave
gliding distance of a vessel (except at 1500' ;-)
Ken
> > >Earl Myers
> > Mike C.
of
> JoeC
Ken Beanlands B.Eng (Aerospace)
Calgary, Alberta, Canada
Christavia MK 1 C-GREN
<http://www.spots.ab.ca/~kbeanlan>
Subject: | water, cities,mountains |
The classic water,cities flight was made by Tom Nolan in a 65 Piet. It
was written up in the newsletter a few years ago
Here in NY State we have the Hudson river which flows south from the
Adirondack mountains to the Atlantic ocean. It flows past New York City
at its southern end. The Statue of Liberty is located there.
I am sure everyone is aware that the control zones of LaGuardia, Newark
& JFK airports encompass that entire aera,
There is a Hudson River corridor thru which one can fly no radio below
2000 ft. It is truly a magnificent flight. Below the Empire State
building & World Trade center & over the Statue of Liberty.( I did it in
a 150 )
Well, not only did Tom fly the corridor, but he turned east over the
Atlantic Ocean & flew off shore under the JFK veil. VFR, no radio, in a
Piet. Go beat that!.
He took pictures of that flight from the cockpit. He had them at
Brodhead one year. Unreal.
PS: mountains later
Tom Nolan
in a 65 Piet. It was written up in the newsletter a few years
ago
the
at its
Newark
below 2000
ft. It is truly a magnificent flight. Below the Empire State building
World Trade center over the Statue of Liberty.( I did it in a 150
the
Atlantic Ocean flew off shore under the JFK veil. VFR, no radio,
in a
Brodhead
one year. Unreal.
PS: mountains later
Subject: | Re: Low and Slow ....glide over lake |
"little to spare" could be like "a little pregnant".
John D
maybe the secret is in the meaning of the words
"densely populated area" I would take that to be
areas like Washington DC, up around A&M, and
maybe the valley girl types out in california.
food for thought
There is a book: How to License a HOMEBUILT AIRCRAFT, by Paul Bergen
Abbott. He makes AC-20-27D very readable and understandable. Even has
some pictures and examples of the forms. Leon S.
You got to be from Texas...........
John D
Subject: | Re: water, cities,mountains |
Small correction, the cieling of the corridor is only 1100 feet. I used
to do scenic rides in the Howard from Kobelt Airport, about 70 miles
north of the City, down the corridor, around the Statue, and back to
Kobelt. There is nothing like NYC from the air!
> It was written up in the newsletter a few years agoHere in NY State we
> have the Hudson river which flows south from the Adirondack mountains
> to the Atlantic ocean. It flows past New York City at its southern
> end. The Statue of Liberty is located there.I am sure everyone is
> aware that the control zones of LaGuardia, Newark & JFK airports
> encompass that entire aera,There is a Hudson River corridor thru which
> one can fly no radio below 2000 ft. It is truly a magnificent flight.
> Below the Empire State building & World Trade center & over the Statue
> of Liberty.( I did it in a 150 )Well, not only did Tom fly the
> corridor, but he turned east over the Atlantic Ocean & flew off shore
> under the JFK veil. VFR, no radio, in a Piet. Go beat that!.He took
> pictures of that flight from the cockpit. He had them at Brodhead one
> year. Unreal. Mike B Piet N687MB ( Mr Sam ) PS: mountains
> later
(304) 842-8300
to do scenic rides in the Howard from Kobelt Airport, about 70 miles north
of the City, down the corridor, around the Statue, and back to Kobelt.
flight was made by Tom Nolan in a 65 Piet. It was written up in the newsletter
a few years agoHere in NY State we have the Hudson river which flows
south from the Adirondack mountains to the Atlantic ocean. It flows past
New York City at its southern end. The Statue of Liberty is located there.I
JFK airports encompass that entire aera,There is a Hudson River corridor
thru which one can fly no radio below 2000 ft. It is truly a magnificent
flight. Below the Empire State building World Trade center
over the Statue of Liberty.( I did it in a 150 )Well, not only did Tom
fly the corridor, but he turned east over the Atlantic Ocean flew
off shore under the JFK veil. VFR, no radio, in a Piet. Go beat that!.He
took pictures of that flight from the cockpit. He had them at Brodhead
one year. Unreal.Mike B Piet N687MB ( Mr Sam )PS:
mountains later
(304) 842-8300
Subject: | Re: Handheld Advice |
This arrangement was described in detail in the BPA newsletter #33, page 7.
It looks like it is worth trying if you want the antenna hidden. I am
planning to use this scheme.
Al Swanson
>Craig Aho
I think the glide ratio is probably 6 or 7 to one.
My RV-6 is really only about 9 to 1. Its a little cleaner than a Piet but neither
is a glider!
I have a friend who flys an S1S Pitts. He carries a brick with him in case the
engine quits. When the engine quits, he throws the brick out to see where he will
be able to glide to:-).
Bob Seibert
> To: piet(at)byu.edu @ INTERNET
> cc:
> > >Earl Myers
> > Mike C.
of
> JoeC
think. You go down in a hurry. If the engine quits don't make your base
leg too far out. I you have to go in water a Navy guy told me to put a wing
tip down first and spin around. If the gear goes in the water first you'll
be upside down. I know I think about those things more than I used to.
Oh, the Piet does glide pretty well without power.
-----Original Message-----
From: mbell1(at)columbiaenergygroup.com <mbell1(at)columbiaenergygroup.com>
Date: Tuesday, August 24, 1999 3:36 PM
glide
29,000
theoretically
>cc:
>Michael D Cuy wrote:
don't
planes...........
>> >Earl Myers
or
>> Mike C.
long.(one of
>JoeC
I need to know the size of the Piet longerons . thickness and so fourth.
Steve
Subject: | RE: Piet cabine. |
1"x1"
Bart D Conrad
Boeing Field Service
DC-9/MD-80/DC-10 & 737 Heavy Mtc
Phone: 713-640-5882/713-324-4192
Fax: 713-640-5891
Pager: 713-318-1625
> From: vistin(at)juno.com[SMTP:vistin(at)juno.com]
> Sent: Tuesday, August 24, 1999 8:57 PM
> To: Pietenpol Discussion
> Subject: Piet cabine.
> Steve
There was an interesting article in this months Experimentor about wooden
struts and thier design. The Piet was even featured with it's wooden
landing gear legs. Quite an interesting article.
Ken
It's nice to know that some things never change! I have fond memories of
flying into Clow for 'burgers 'n such back in the early '70's, when I was
based at Schaumburg/Roselle. Lots of ghosts came out when I saw the
message...all of them good!
Ed
From: | Randall Reihing <rreihing(at)eng.utoledo.edu> |
hi Everyone,
Does anyone have a factory new 0-200 crank, rods, pistons for-sale, or
know where I can find one? Thanks, Randall Reihing
Randall Reihing
University of Toledo
College of Engineering
MIME Department
419-530-8244
FAX: 419-530-8206
E-Mail: rreihing(at)eng.utoledo.edu
Hey everyone, I ordered the lumber for the fuselage a few weeks ago from
WICKS should be ready to pick up soon. this is a first time project any
suggestions on the best and easiest glue to use? thanks, Robert Bush
I am receiving 2 copies of each message on the Pietenpol discussion
group, what should I change to only get only 1.
I used Aerolite on the ribs. T-88 on everything else.
Aerolite takes on slight "set" almost immediately, this works great when
working with small gussets. T-88 remains slippery until it sets. Thats OK
on larger pieces that are easier to clamp but can be frustrating on small
gussets.
Greg Cardinal
>>> 08/25 1:56 PM >>>
from
Robert,
My Aircamper is my second project using T-88. First one is still flying
, and nothing blew off.
walt
From: RBush96589(at)aol.com <RBush96589(at)aol.com>
Date: Wednesday, August 25, 1999 4:00 PM
Subject: Pietenpol-List: glue
From: | Michael D Cuy <Michael.D.Cuy(at)lerc.nasa.gov> |
>Robert,
>walt
Robert, Walt.......My Air Camper is my first project and I also
used T-88 with nothing blowing off yet either.
PS- white vinegar on a paper towel will remove this sticky stuff from
your hands too.....and leave you smelling like a cucumber salad :))
Mike C.
Robert,
walt
Mike C.
I will be starting on my piet soon.May I ask what did the wood cost you for
the fuse?
if you talk to 3 different people you'll get 3 different replys---me I used
aerolite on the entire fuselage and found it very easy to use and quite
satisfactory (the usaul tests and saving samples for future tests) I used
baby food jars for mixing and found that any left over will last several
weeks if jar is kept sealed..just be sure to apply catalist to half the
joint.
JoeC
From: | "donald r. brewer" <DonCarBrewer(at)compuserve.com> |
robert bush,,, epoxy glue is my choice. i have used it on boats and plane=
s
for many years. T-88 is very good, as is Epolite, they are a 1-1 mixture=
with good filling properties. highly recommended,,,,,,, don brewer
from wicks--all the spruce and 1/8 mahogany ply===423.65 (shipping included)
from Riteco --Australian hoop pine 1/4" , 1/8" & 1/16"==174.01(shipping
included)
JoeC
Zion, Illinois
> the fuse?
Love that T-88.
John W
Date: Wednesday, August 25, 1999 3:46 PM
Subject: Pietenpol-List: Re: glue
working with small gussets. T-88 remains slippery until it sets. Thats OK on
gussets.
Greg Cardinal
>>> 08/25 1:56 PM >>>
Robt. Bush. Glue...West system
Thanks for the info on glue everyone sounds like t 88 is the thing to use
Robert Bush
Subject: | everyone can get AS&S catalog free |
Just a tidbit of infro. in case everyone isn't aware. Mostly for guys
just starting or dreaming.
You can get the free Aircraft Spruce catalog free ( not a penny) on
the internet. The group has discussed A.S. recently, and if you like
them or not, you can't beat their catalog . It has good pics of the
hardware and screws and brackets and blah,blah,blah.
Even if I'm buying from Dillsburg,( they only list numbers), this gives
the numbers on all the stuff. AND stuff like heat treating,metal
guage,bending radiis, and alot more "keeper" charts for ref.
Their main site is:
http://www.aircraft-spruce.com/
and to get right to page to order book:
https://www.aircraft-spruce.com/spruce/order.cgi/01-38400?,catalog_order
the cat. is already listed near the top, just go down and fill out
address etc. Soon you'll get a Fedex mailer full of "book"
The good thing is you can get them for all of your friends. Not like
the address has to match the email. I've gotten many for my friends thru
my comp.
walt
everyone isn't
aware. Mostly for guys just starting or dreaming.
Spruce
catalog free ( not a penny) on the internet. The group has
discussed
A.S. recently, and if you like them or not, you can't beat their catalog
. It
has good pics of the hardware and screws and brackets and
blah,blah,blah.
they only
list numbers), this gives the numbers on all the stuff. AND stuff
like
heat treating,metal guage,bending radiis, and alot more
keeper
charts for ref.
Their main site is:
href"http://www.aircraft-spruce.com/">http://www.aircraft-spruce.com/<=
/A>
order
book:
href"https://www.aircraft-spruce.com/spruce/order.cgi/01-38400?,catalo=
g_order">https://www.aircraft-spruce.com/spruce/order.cgi/01-38400?,catal=
og_order
near the top,
just go down and fill out address etc. Soon you'll get a Fedex
mailer full
of book
them for
all of your friends. Not like the address has to match the email.
I've
gotten many for my friends thru my comp.
walt
Subject: | Trailing edge, wing |
1, Has anyone used, or heard of using, the 3/16" x 1 1/2" formed aluminum
trailing edge material available from both Wick's and AS&S ???
2. Ditto on the use of aluminum to wrap the leading edge ???
Thanx,
DG
How much is T-88 yall n where can I get it.
Steve
writes:
> >Robert,
> still flying
> >walt
> from
> Mike C.
From: | leonstefanhutks(at)webtv.net (Leon Stefan) |
Most folks in central KS. are using Aero-Poxy. Probably because it's
sold by our local wood guru Gus Wiebe. Works fine. Here is a tip on
mixing that worked for me. Get 2 Rubbermaid salad dressing squeeze
bottles. they are clear. Put your parts A&B in there separate bottles ,
than you nerver have to mess with spoons again. Mix in medicine cups,
like the one you see shrink rapped on top of your bottle of Pepto-Bismo.
You can get these at hobby shops. R/Cars use them for mixing there 5
min. epoxy. They have 5 different measurements marked on the side. You
must mark the one you want with a sharpie before you add your glue,
because the markings disappear when glue is put in cup. Squeeze the
thicker part in first, to your mark, then add thinner part next to its
mark. Perfect measurement every time. You never get sticky fingers. Soap
and water clean up before it sets. Mix and apply with toothpicks on
small gussets, Popsickle sticks for bigger gussets. Mixing batches was
so easy and fast I even used these small cups on my biggest job, putting
on my plywood fus. sides. If you have a little glue left over in bottom
of your cup, leave the tooth pick in and set aside for a few days. when
cured,squeeze sides and bottom of cup to crack epoxy loose, use
toothpick as a handle to lift old glueplug out and cup is reusable Leon
S.
Subject: | Re: everyone can get AS&S catalog free |
Group
I was contacted by an Aircraft Spruce Sales Rep because someone on
this list forwarded my message about the price upgrade on the Piet, Or
as I said GN-1 He didn't really like my slam about they must be
raising the price because the Pietenpol has become popular.
He went on to say that the price in catalog was wrong last year
because the 823.00 was suppose to be for the Pietenpol and not the
GN-1 and this year in the 1999-2000 catalog they changed it to be for
the Pietenpol but forgot to change the GN-1 to Pietenpol. something
like that. I just pointed out to him that I was reading from two
catalogs and it looked to me like they had raised to price for the
GN-1 spruce kit from 823.00 to 1300.00 and maybe someone should edit
the catalog before sending the thing out.
So whoever forwarded my message to Aircraft Spruce, Thanks alot
because I really enjoy talking to the Head Dish and Bottle Washer.
Miss all that sinse I was in my High Pressure Govt job.
For updated information give Jerry Aguilar a call. He is their
Marketing Director.
Gordon
> guys just starting or dreaming. You can get the free Aircraft
> Spruce catalog free ( not a penny) on the internet. The group has
> discussed A.S. recently, and if you like them or not, you can't
> beat their catalog . It has good pics of the hardware and screws and
> brackets and blah,blah,blah.Even if I'm buying from Dillsburg,( they
> only list numbers), this gives the numbers on all the stuff. AND
> stuff like heat treating,metal guage,bending radiis, and alot more
> "keeper" charts for ref.Their main site
> is:http://www.aircraft-spruce.com/ and to get right to page to
> order
> book:https://www.aircraft-spruce.com/spruce/order.cgi/01-38400?,catalog_order
> address etc. Soon you'll get a Fedex mailer full of "book" The
> thru my comp.walt
Group
I was contacted by an Aircraft Spruce Sales Rep because someone on this
list forwarded my message about the price upgrade on the Piet, Or as I
be raising the price because the Pietenpol has become popular.
He went on to say that the price in catalog was wrong last year because
the 823.00 was suppose to be for the Pietenpol and not the GN-1 and this
year in the 1999-2000 catalog they changed it to be for the Pietenpol but
forgot to change the GN-1 to Pietenpol. something like that. I just pointed
out to him that I was reading from two catalogs and it looked to me like
they had raised to price for the GN-1 spruce kit from 823.00 to 1300.00
and maybe someone should edit the catalog before sending the thing out.
So whoever forwarded my message to Aircraft Spruce, Thanks alot because
I really enjoy talking to the Head Dish and Bottle Washer. Miss all
For updated information give Jerry Aguilar a call. He is their Marketing
Director.
Gordon
walter evans wrote:
Just a
tidbit of infro. in case everyone isn't aware. Mostly for guys just
You can get the free Aircraft Spruce catalog free ( not a penny) on the
like them or not, you can't beat their catalog . It has good pics of the
hardware and screws and brackets and blah,blah,blah.Even
if I'm buying from Dillsburg,( they only list numbers), this gives the
numbers on all the stuff. AND stuff like heat treating,metal guage,bending
radiis, and alot more "keeper" charts for ref.Their
main site is:http://www.aircraft-spruce.com/
and to get right to page to order book:https://www.aircraft-spruce.com/spruce/order.cgi/01-38400?,catalog_order
the cat. is already listed near the top, just go down and fill out address
my comp.walt
From: | Michael Brusilow <mb-albany(at)worldnet.att.net> |
Subject: | Re: Trailing edge, wing |
>Thanx,
>DG
Sure have. I used both. Been there since 1988.
On aluminum trailing edges....consider this. After the wing is assembled and
aligned, turn the wing up on the trailing edge and pour them full of Epolite
epoxy to add some rigidity and to give them a wood-like "density" effect. To
keep the weight down...use plenty of microballoons mixed in with the epoxy.
This is a little trick used by some of the antique airplane rebuilders and it
really seems to work out well....Terry B
Incidentally....I plan to use wood.
Subject: | Wicks vs. AS&S, half VW, model "A" |
In a message dated 8/25/99 7:22:02 PM Eastern Daylight Time,
arkiesair(at)surfree.com writes:
<< I was reading from two
the catalog before sending the thing out. >>
VS.
included) total 597.66
Hi gang, been a Pietenpol fan for about ten years now and I'm planning to
start construction on one in soon so I'm really happy to have found you guys.
Right now I'm just looking around at prices and suppliers. Can anyone tell me
why there is a $332.33 price difference between Wicks and AS&S?
Also I'm still going back and forth between the Sky Scout and the Air Camper.
I have the 32 and 33 Flying and Glider manuals. At the end of article about
the Sky Scout the PacMag engine is suggested as an alternative to the "T",
now I know I can't get this motor but a half VW seems to have the same
numbers, any feedback guys?
If all of you think this is a bad idea then I'll go with the Model "A"
Aircamper. Which brings me to my second question, anybody know where I can
get a model "A" motor suitable for rebuild in the Maryland/Pa. area?
Ross Gutmeier
From: | walter evans <wbeevans(at)worldnet.att.net> |
I was just going to say....wouldn't it be easier , cheaper, lighter to just
get a 14 ft. piece of 1x2" clear white pine , and if ripped right on an
angle, to get two trailing edges? Think thats what I'll do.
walt
Date: Wednesday, August 25, 1999 8:11 PM
Subject: Pietenpol-List: Re: Trailing edge, wing
Steve,
Fyant ,( if you want) you can get it at Aircraft Spruce, or any other
supplier. Get the qt. kit, which consists of two "ketchup squeeze bottles"
that are handy to use . About $25.00
walt
Date: Wednesday, August 25, 1999 6:45 PM
>Steve
> writes:
>> >Robert,
>> still flying
>> >walt
>> from
>> Mike C.
Another question..I plan on starting on my piet soon.What part of the plane
is usually begun first?And hwo much is a good guess on all the wood for the
airframe price wise..
Subject: | Re: Wicks vs. AS&S, half VW, model "A" |
Ross,
I flew a 1/2 VW on an ultralight. ran good,
Then built a FFP404 and wanted one on that, Just not strong enough. Got me
around the pattern,thats about all. then put on Rotax 447, like day and
night. Rotax is rated at 41hp. They talk of the 1/2 VW as 35 hp but I dont
think so. The 1/2 VW will fly alot of planes , but not a Piet. I sold my
VW to a guy in NY ( I can send you a pic of it on his plane directly if
you'd like)
What I've heard is that even a 4 cyl. VW won't fly a Piet.
walt
Date: Wednesday, August 25, 1999 8:20 PM
Subject: Pietenpol-List: Wicks vs. AS&S, half VW, model "A"
>VS.
included)
guys.
me
Camper.
>Thanks,
>Ross Gutmeier
Greg,
My first project I did ribs and then wings. I guess most people do this.
But you go through a long dry time of wondering what the plane will look
like. ( too long between starting and sitting in it).
So on the Aircamper I started the fuselage first, then all the little sub
assys., with ribs in between. Now all ribs are done and thinking about the
wing.
Just incase anyone is put off from starting because of not a big enough
shop.....this is my second project in a 10ft.x20 ft. basement.
walt
" building is not so much the destination, but more so the journey"
Date: Wednesday, August 25, 1999 8:33 PM
Subject: Pietenpol-List: PIET
Is there a site one can find a good runout c-65 -85 ..How much Difference
between the two? I went to OSH and caught the PIET fever..Got to fly one
with a nice old fella..Flew just like the champs/cubs I use to fly but a
slower landing speed the PIET have..Very honest ship she was.
Subject: | [Fwd: FW: Aircraft Spruce: Pietenpol Discussion] |
This is exactly what Jerry said about the prices. I had it a little
wrong.
Seems Wicks is a much better deal.
Gordon
Date: Tue, 24 Aug 1999 15:34:10 -0700
Subject: Pietenpol-List: FW: Aircraft Spruce: Pietenpol Discussion
Dear Gordon,
I viewed with some interest your comments posted to the pietenpol emai
l group. The discrepancy between last years printed price and this ye
ars catalog has nothing to do with as you put it "trying to cash in on
the Aircampers popularity". The printed price last year was actually
a mistake in that the price for the Pietenpol Aircramper spruce kit wa
s mistakenly put in the price of the GN-1 Aircamper Spruce kit. The c
urrent correct price for the GN-1 kit is $1289.00 and the current pric
e for the Piet. Aircamper is $800.00.
Sincerely
Jerry Aguilar
Aircraft Spruce
Glide ratio? Didn't know it had one. Mine is more like a fall ratio. I
would guess maybe 2:1 on a good day. Depends on how hard you want to hit
the ground when you get there.
Ted B
Here's another one...check into Tite-bond II. No mixing, available at
hardware stores, inexpensive, strong, water-resistant (very). It's what I'm
using. 'Course, I haven't flown mine yet....
Don Cooley
From: | LaurenMWilliams(at)webtv.net (Lauren Williams) |
Robert,
Use T-88 epoxy. It's a 50-50 mix (easy to measure) and it has a slight
amber color so that areas saturated with glue won't look white under the
varnish. It is great to work with. You can get it from Wicks. Very
satisfying.
Lauren
Ross,
The Model A has 200 cubic inches of displacement. A VW (4 cylinder) is
about half of that and a Half VW would be about 1/4 the displacement of
the Model A. 1/4 the displacement means 1/4 the power at a given RPM
and with the tiny prop even less than 1/4 the thrust. Of course you
would turn the little engine faster, but you wouldn't come any where
close to being able to pull this draggy aircraft into the air. I don't
think that anyone has successfully used a 4 cyl VW on a Peitenpol, much
less, half of one.
Lauren
Is titebond II approved for aircraft use???
Steve
> at
> what I'm
> Don Cooley
Added onto that question... How much should a rebuilt C65 be worth.
I have a chance to buy one for $3500 and thought that seemed pretty
reasonable for a completely
rebuilt aircraft engine. But I'm not an expert by any means.
Greg Yotz
Date: Wednesday, August 25, 1999 7:44 PM
Subject: Pietenpol-List: Re: PIET
I took it you meant to use the VW on the Scout? If so, I haven't heard of
anyone doing that.
I have a 1500cc VW on a VP-1 and it does ok. After looking at the Scout
plans last night I
would say you would be happer with the 1800-2100cc VWs on that plane. And
then it wouldn't perform
as good as the torquey 'T'. If your talking about the Aircamper then I
would stick with the 'A' or
an aircraft engine(C65).
Just my two cents worth.(At todays prices, really only .875689 cents.....)
Greg Yotz
Date: Wednesday, August 25, 1999 6:57 PM
>VS.
included)
guys.
me
Camper.
>Thanks,
>Ross Gutmeier
I was just about ready to start construction and I got an assignment to a
customer site for a year. I have an apartment and I commute Monday and
Friday. I started on the ribs because I can do them on my kitchen table. I
think that I will probably get tail surfaces done while I'm here also.
Mike Bell
Columba,SC (RestonVa during the week)
Maiser(at)adena.byu.edu on 08/25/99 08:40:01 PM
cc:
Greg,
wing.
walt
Lauren, Mike, Greg, Walt,
Thanks for all of your feedback. Looks like I'll be going for the Model "A"
AIrcamper.
Ross
STICK WITH THE MODEL "A".....
From: Lauren Williams <LaurenMWilliams(at)webtv.net>
Date: Thursday, August 26, 1999 5:00 AM
Subject: Pietenpol-List: Re: Wicks vs. AS&S, half VW, model "A"
Ross,
less, half of one.
Lauren
I haven't purchased wood yet and I'm still in the planning stage, but I've
read that if you have limited space, do the wings first cause they can be
hung up, out of the way when you start the fuselage. I've also heard that
if you build the tail first, you'll learn all the skills for the rest of the
plane.
Joe
Spring, TX
>From: Greg Estrada <jetflyer(at)mhtc.net>
>Reply-To: Pietenpol Discussion
>Subject: PIET
>Date: Wed, 25 Aug 1999 19:30:49 -0700
>walt
Walt- you got it, buddy. I went to the local DIY store and purchased
plain old pine baseboard moulding and simply ripped the top 1" or so
off and whala, you've got that nice triangular shape for the TE ready to go.
MC
From: | Clay Spurgeon <cspurgeon(at)baseballexp.com> |
Subject: | Engine choice, Tom Nolan |
Questions for the group:
1. Curious if anyone has experience with both Model A and Continental
65 performance and could compare and contrast,
2. If anyone has experience with Ron Kelley Model A engines - he's a
Model A engine builder outside of Dallas and builds "updated" A's for
reliability and horsepower (around 70HP). Talked with him once and
he sounds very knowledgeable - has done a lot of research and dyno
testing on carb/head/plug combos - would like to know if anyone is flying
behind one?
2. Anyone have an e-mail address for Tom Nolan?
Clay Spurgeon
San Antonio
Joe
keep me posted, when you start
John D
Subject: | Re: Engine choice, Tom Nolan |
Clay- I have tried both and let me just say that both are a total blast and
you should have one of each. Now for the differences......
The Cont. Piets controls feel totally different- much more responsive due
to the higher cruising speed. An average guess might say the Fords cruise
about 55-65 and the Continentals about 65-75 mph. These are general
numbers......unless you are an engine wizard like Lowell Frank or Wil Graff
who can get 70 hp from a Model A.
The Fords are very nostalgic and sound sweet...but be prepared to
have the radiator on a hot summer day pour lots of hot air right in the
face of your passenger....and the exhaust stacks are right in line with
your nose so if you lean out the left side you get a nice dose of carbon
monoxide. Then again on a winter flight in the North the seat of choice
is passenger, Model A.
On a hot day with a Ford you'll be restricted to carrying lighter
passengers
depending on your field length, obstructions , elevation, density altitude.
The Continental will let you go with 2 adults on just about any day below 85 F
or so.
The visibility restriction of the radiator is, I think, over-rated. If you
have
a passenger in the front of a Cont. you still can't see squat ahead so
no big difference there. When landing most any taildragger from the back
seat you'll mostly be using peripheral vision anyway.
Whatever you decide just try to build a light as possible. You can modify
things here and there slightly, but there is no need to add weight anywhere.
A heavy Piet will just dissapoint you in the long run.
Mike C.
total blast and
responsive due
cruise
general
Graff
the
with
carbon
of choice
carrying lighter passengers
altitude.
below 85 F or so.
If you have
back
modify
anywhere.
Mike C.
Thats the way I see it too. If your going to build a Legend, why not built it
the way it was designed and have a new antique to fly, that is what I will do
when I start building, just have too many projects right now.
Gordon
RW1 UL Piet
Mohawk MK IV
> AIrcamper.
> Ross
2. Anyone have an e-mail address for Tom Nolan? Thanks,
Clay SpurgeonSan Antonio
Subject: | Re: Cost for Cont A-65 |
reasonable for a completely rebuilt aircraft engine. But I'm not an expert
by any means.
>Greg Yotz
Greg I paid $700 for an A-65 from a Luscombe that had a prop strike. The
crank was bent, but it came with a crank that was serviceable. I sent the
cranks to Aircraft Specialties in Tulsa and the ground it to .020 under for
$400.00. The bearings, seals and gasket set was another $400.00. I gave
Divco $75.00 to rework the case for new thrust bearings. I bought a new
camshaft from Fresno for $200.00 The engine came with old Eisemann mags that
quit while I was flyinig. So, another $805.00 for new Slicks and a new
harness from Mattituck. So, $3500.00 could be a good deal if the end
result of a rebuilt engine includes all of this. Other wise your start
charge may be $3500 and you'll still have to have work done. There are a
lot of $2000.00 A-65's out there, but I would tear it down myself and
rebuild it so I know what's inside. Remember it's YOUR BUTT up there. Good
luck. Also check out Wingsonline.Com for parts.
Copinfo(at)ix.Netcom.Com
Tim Cunningham
Des Moines, Iowa (515) 237-1510
You would probably be OK with Great Plains' new reduction unit for the VW.
This should slow the prop down enough to be effective on the Piet. Check
out <http://www.greatplainsas.com/welcome.html> for more info.
Ken
On Wed, 25 Aug 1999, walter evans wrote:
> Ross,
> you'd like)
> walt
> From: Gutmeier(at)aol.com <Gutmeier(at)aol.com>
> Subject: Wicks vs. AS&S, half VW, model "A"
> >VS.
> included)
> guys.
> me
> Camper.
> >Thanks,
> >Ross Gutmeier
go to richards site. www.aircamper.org unsubscribe and then resubscribe.
If the problem continues, email me directly.
Steve Eldredge
IT Services
> awl942(at)webtv.net
> Sent: Wednesday, August 25, 1999 2:31 PM
> Subject: mesages
> Thanks,
my plans are on the table and ready to start. Any
comments on using grade c and better sitka spruce for
every thing with the exception of the spars? c and
better is pretty clean and of course you would not
use any piece with a swirl or knot. What are the pros
and cons of the long fuse verses the short? Also has
anybody used air powered staples to assemble the ribs
etc? one more question, is baltic birch too heavy or
not strong enough for the ply's? thanks in advance.
Does anyone know the all up weight of the A engine. If not how about the
weight of the engine alone?
Marc Davis
Subject: | Re: sitka grades |
I used an Arrow electric staple gun when I built my cedar stripper canoe.
Staples were used to hold the 1/4"x1" cedar strips together while the glue
cured. The stapler was about $30 CDN ($20 USD) and was certainly
durable enough (3 boxes of staples had little effect on it). There were
three problems with the electric stapler in that application:
1. Not enough power. I felt like Tim Taylor looking for a way to add MORE
POWER (RRR RRR RRR). It worked OK with 1/2" staples but there wasnt enough
power to staple the 1/4" strips into the oak stem using the 3/4" staples.
Air powered will probably work better. Crank it up to 200 PSI and you'll
probably get a good 1000 yds range! I could only get the staples to stick
into the wall at less than 10' with my wimpy gun ;-) This brings up
another point. Wear eye protection (and maybe a cup just in case ;-).
2. It was hard to accurately figure out where the staples would end up. I
finally resorted to marking guide lines on the sides and front of teh
stapler to help with placing the staples where I wanted them.
3. Glue! Since I was edge gluing the planks together in a cove and bead
seam, the glue would run out over the sides as I stapled. It would get all
over the bottom of the stapler. Fortunately, the glue was water soluable
and easily washed off. T-88 may not be so forgiving. Granted, you probably
wont have near the amount of excess glue on a wing rib.
Ken
Subject: | speaking of the tail surfaces |
Someone brought up the tail surfaces, and that brought back some
thoughts. After I finished my horizontal stab. I looked at all of the
pics around and realized that everyones was a little different.
I ran into confusion with trying to join three different width wood,
on a centerline, plus bevel one thickness to the other so the joints
could be gusseted. then when the "main beam" that runs a few inches
behind the horz. stab. leading edge, joins the sides ( that are routed
out) , you run into yet another difference of thickness'. This had to
be gusseted also.
I don't know if you can follow my ramblings or not.....
Even after I finished them , and they came out ok, I went back to see if
I had missed something very basic.
Did any of you have this problem?
This is the part of the plane that I mostly had to wing it ( sorry)
walt
surfaces, and that
brought back some thoughts. After I finished my horizontal stab. I
looked
at all of the pics around and realized that everyones was a little
different.
trying to join
three different width wood, on a centerline, plus bevel one thickness to
the
other so the joints could be gusseted. then when the main
beam
that runs a few inches behind the horz. stab. leading edge, joins the
sides (
that are routed out) , you run into yet another difference of
thickness'.
This had to be gusseted also.
I don't know
if you can
went back
to see if I had missed something very basic.
had to wing
it ( sorry)
walt
Piet fans,
Tite-bond II was recommended by our chapter designee. I'll have to check
into approvals.
Don Cooley
Subject: | Re: Wooden struts |
Ken,
For those of us who don't subscribe to "Experimenter, could you summarize the
major points of the article on wooden struts? Thanx, much.
Don Cooley
Subject: | RE: speaking of the tail surfaces |
Yes, I ran into that too. I ended up stacking two gussetts on top of
each other to compensate for the differences in the thicknesses. I
think I'll write a book some day on interpreting the Piet drawings. It
would probably be a best seller.
Bart D Conrad
Fax: 713-640-5891
Pager: 713-318-1625
> From: walter evans[SMTP:wbeevans(at)worldnet.att.net]
> Sent: Thursday, August 26, 1999 12:41 PM
> Subject: speaking of the tail surfaces
thoughts.>> After I finished my horizontal stab. I looked at all
of the pics around and realized that everyones was a little different.
wood, on a centerline, plus bevel one thickness to the other so the
joints could be gusseted.>> then when the "main beam" that runs a
few inches behind the horz. stab. leading edge, joins the sides ( that
are routed out) , you run into yet another difference of thickness'.>
=A0> This had to be gusseted also.
sorry)
> walt
Subject: | Re: Model A weight? |
>Marc Davis
plus or minus 235 lbs. ( does not include radiator & water )
This discussion on glues is interesting, so I'll throw in my limited
experience.
I am currently building wood wings for a Wag-Aero Cuby, my first project. I
started using T-88 because I read good things about it. Several people in
my EAA chapter convinced me to use resorcinol instead, one of which is an
FAA DAR who will be inspecting my plane when the time comes. He admitted
though, he is personally more familiar with resorcinol than epoxy. He
expressed concern over the longevity of epoxy when it is heated, say like in
a dark colored plane setting in the sun. As many of you have said though,
you have used it for years and it is still holding up.
I found T-88 easy to use, but resorcinol has a longer pot life so I can mix
up a larger batch while building ribs. Resorcinol is easy to use too, but
it is a dark purple/brown color. Makes less than perfect glue globs really
show up. Resorcinol can be purchased at many larger lumber yards too.
I think either one is as easy to use as the other and both would perform
equally well. Just depends on your preference and what your DAR says about
it.
Last year, I wrote Franklin Adhesives about using Titebond II in airplane
construction. They quickly and very nicely responded and said they do not
recommend Titebond II for aircraft use. Personally, I think is is a good
glue and holds up extremely well even when unprotected in the weather (like
my bird feeder-three years in the weather, glued with Titebond II). I would
think it would be great for an experimental airplane, but have no personal
experience using it for this application and would like to hear more about
its use and approvals. I'll locate that letter in case any of you are
interested in the "official" response from the manufacturer of Titebond II.
Has anyone tried some of the "instant" CA adhesives for airplane building?
Todd Chisum
Tulsa, Oklahoma
Wag Aero Super Sport project (there's a Subaru powered Piet in my future)
>into approvals.
Don...
Re: Tite Bond...if you haven't already done so, please do some testing to
satisfy yourself that it is really waterproof ( or highly water resistant)
and that your test panels will always pull wood when you break them apart. I
may have been living in a shell, but in over 50 years of building I have not
heard of Tite Bond being used in aircraft. That sure doesn't mean that it
can't be or isn't an acceptable substitiute for the several tried and true
glues. Just don't take a chance until you have proven to yourself that it is
at least equal to those. If you're new to building don't hesitate to get
that old 'second opinion' Good luck
Don Hicks
Can anyone tell me what the width of the cowel supports are? I looks as
though they are 1.75" but I'm not sure. Also are the control panels and cowel
supports supposed to overhang the fuselage sides slightly?
Jacob
>Group
>Marketing Director.
>Gordon
I know Mr Jerry Aguilar for several years, they used to call him (at the
phone or desk) when a spanish speaking costumer called, I met him personally
3 years ago the first time at S&F. He is a great help (also for english
speaking costumers). Good and hard working get to high positions, Is good
to know that he is the Marketing Director.
A saw him at S&F talking to some brazilians (in portugese - english -
spanish) at the same time until he got the clear idea of what they needed!!
Saludos
Gary Gower
>Don Cooley
Great glue, I have some pieces outside (sun & rain) for 4 1/2 years and
still glued... I use it in my props.
Saludos
Gary Gower
>Steve
No but your plane is EXPERIMENTAL, remember?
Some good glues (and materials) are not certified but used extensively in
aviation,
some are rare as the TPG (Taylor Paper Glass) remember the "paper airplane".
I think the only certfied glue in USA is the Resorcinol, but I can be wrong.
Saludos
Gary Gower
Has anyone installed a fuselage tank instead of the wing tanks? I'm planning
to use a Continental engine and I've read that you don't need the forward
tray if your going this route. Are there plans for building a fuselage tank
or is it an off-the-shelf item? How should it be installed inside the
fuselage? I've also read that you want to make the engine mount brackets
slightly longer to account for a fire cloth and sheet metal face, but how
much longer should it be? Lastly, can anyone give me some more info. on the
type of fire cloth to use and the gauge of the sheet metal face?
Thank you
Jacob
(snip)
All manufacturers of something that YOU INTEND TO USE in aviation, will run
away from you as a mad dog! They dont want to get sued.
Call all the "timing belts" manufacturers that are used in reductions units
and they will not sell it to you if you say that is for "aircraft use". Use
the frase "is for an airboat" and they will show you the catalog.
If you want certified glue, use Resorcinol. but be very carefull with the
bonding surfaces. (been there, done that) We built a VP-1 with Resorcinol,
I prefer Tite-Bond II hands off.
Saludos
Gary Gower
Robert-
All our Piet kits and any wood assembly we do, uses the Weldwood Plastic
Resin glue. I have tried others, but I was most comfortable with the
Weldwood.
Steve
Replicraft Aviation
Can anyone tell me what to use for wire wheels and where to get them? Time
to raise the fuse. Thanks. Ryder
We have been exchanging some nice emails in the past couple days. He is taking
my advice and going to get on the list. I told him I could not be relaying
messages as it would be much better for him to speak for ACS.
I will bounce all companys together for my supplies. If I can get good stuff at
a fair price from ACS I will drive over and pick it up, I like to keep my
business close to home. But I will not pay a higher price just because they are
close.
Gordon
Gary Gower wrote:
> >Group
> >Marketing Director.
> >Gordon
> Saludos
> Gary Gower
Take a look at the DawnPatrol website to see a Newport 12 with just such
a setup. It looks like a good idea to me but perhaps you could get the
real poop from a builder who has done it.
John W
Ryder,
The LEAF catalog shows wire wheels that might be what you need.
John W
Date: Thursday, August 26, 1999 7:15 PM
Subject: Pietenpol-List: wire wheels
From: | robert hensarling <rhrocker(at)admin.hilconet.com> |
Date: Thursday, August 26, 1999 7:19 PM
Gary, I think you're correct. We checked to see if T-88 was certified for
use in a PT-19 project I'm helping with, and it wasn't. I built a Team
Airbike wing with the T-88, it's great stuff!!
Robert Hensarling
http://www.mesquite-furniture.com
Uvalde, Texas
>>Steve
>aviation,
airplane".
wrong.
>Saludos
>Gary Gower
Out of the blue here I was wondering what the Piet has been load test at for
G-loads..And if anyone would know ..Are there Piets based in brodhead? I
live 30 miles west.I would like to meet some Piet pilots there if any
based.1 more question.Does anybody know of a way to borrow a wing rib jig?
Thnks .Greg Estrada..On the seventh day God had Bernard design the
Pietenpol...
Ted Davis is based in Brodhead. Piet pilot + CFI . Lowell Frank is in
Palmyra. Two of the best Piet drivers around. For engine and airframe
,You won't find better than these guys.
Ted.T
I wonder If I can find these fellas hangin' around the airport,,Sure would
love to go flying in a Piet again..
> Ted.T
I tried using both electric and hand staplers for gussets on the ribs. I
never got past the test stage. The staplers where just too brutal an
approach. not accurate in positioning and unless round wire staples are
used, too destructive of the spruce cap strip.
I used brass coated aircraft nails, T-88 Epoxy, and cut the gussets to
patterns for each position on the rib. To set the nails, I pre- pricked
the outer nail locations with an awl, tapped the nails in enough to mark
the rib material, lifted the gussets off and glued. Then I put the
gusset back in place with the nails in their former indentations and
tapped them home. I then pricked the positions of the rest of the nails
on the gusset and set them one at a time.
I put furniture oil on the rib jig, as a parting agent, weeks before
using it and left the rib in the jig until the glue set over night.
So, when I went out in the garage to do a rib, I'd plug in the electric
teapot to steam the forward end of another cap strip. Then I would take
the set rib out of the jig and hang it up on the rack on the wall,
taking great satisfaction in the growing evidence of Airplane! Then I
would take the dry upper cap out of the pre-bending jig and insert it in
the rib jig. The lower capstrip snapped into place and I would then cut
the vertical and angled struts to fit in each space. I had precut
gussets in stacks along the back of the workbench and could ready them
with their guiding nails, using the awl to prick the plywood, fairly
quickly. Once all of the gussets where located by their 'guide' nails, I
would lift them off one at a time, glue and then secure them, as
previously mentioned. Somewhere along the way, I would turn off the
teapot and put the limber cap strip into the pre-bending jig.
The process of figuring out how, and in what order, to do the work has
been one of the greatest satisfactions of the building process. I did
the ribs first and then the tail surfaces. I bought the wood as I needed
it for each individual group of parts.
I put off building an airplane for a lot of years because I thought that
my craftsmanship wasn't up to the standards that I would want in an
airplane. I found that that concern took care of itself when I started
to build.
I find Aircraft Quality spruce and plywood to be inspiring materials to
work. Part of this inspiration to do fine work comes from the way the
woods feel under the blade of an edged tool, like a plane, hard back saw
or chisel. Part of it is the wonderful appearance of the finished parts.
I also include the monetary value of the material as a prod toward clear
thinking and craftsmanship.
Given the choice, I would spend a very great part of my time building
airplane. Unfortunately, life intrudes now and then with other demands.
Lauren
I consider Resorcinol to be something of a pain in the neck. It is
aircraft certified but it requires high clamping pressure and is
sensitive to temperature. It has no gap filling capabilities and stains
everything purple. I used it for a little while years ago but gave it up
quickly.
Lauren
Subject: | Benton PIET Fly-in |
Hey...for those of you thinking about attending the 1st annual Piet fly-in at
Benton KS on Sept 11, I have some news. Tonight I phoned Kevin Helf in
Owasso Oklahoma (his 65 Cont. Piet was pictured on p.38 of the Sept 99
Kitplanes) to see if he had heard about the fly-in. He relayed that he had
heard about it and that there might be as many as 5 Piets make it from the
Tulsa area. They are hoping the weather will cooperate.....Terry B
Weldwood Plastic Resin glue is great stuff to work with. I have built a
lot of boats using it. Last winter I got to restore a boat that I built
30 years ago. This boat is built of douglas fir plywood with mahogany
and douglas fir framing it was fastened with bronze annular ring boat
nails.
I have had to redo every glue joint in the boat. The Plastic Resin glue
had totally failed. every bit of it had crystalized and separated from
the wood. Granted, this boat had been out of doors it's whole life, most
of it afloat in salt water. In fact, when I pulled it into the hanger
last fall, I realized that that was the first time that it had EVER been
under a roof, so it has had absolutely brutal treatment.
I guess that it depends on what kind of protection you can give it and
how long you want it to last.
Lauren
Ryder, find copies of Kitplanes for March 1990 and July 1992 and you
should have the wire wheel question covereed. The Buckeye Peit. Assn.
news letters have also had very good info on the subject. Get all of
these that you can afford.
Lauren
Subject: | Re: PIET 1" thick |
Date: Thursday, August 26, 1999 7:51 AM
the
>plane.
Joe, you can build the ribs, fuselage sides and the tail group and it all
stores nicely as it is only one inch thick until you slip the ribs on the
spars or put cross braces in the fuselage.
All my spruce came from Jean Peters of Calgary. Excellent quality and he
understands wood aircraft and Pietenpols. Someone else may have his address.
John Mc
I won't comment on the sitka spruce, except to say, look up the specs and go
from there. And...a few years ago in the Boeing air museum they had on
display an old aircraft spar.
The spar had a graIN drop of about 3 inches in about 6 inches distance.
About baltic birch , I used it for gussets, and found that the glassey
surface would not give a solid glue joint. I solved this by giving the
surface to be glued a good roughing so as to allow some tooth for the
glueing surface.
>From: Ken Beanlands <kbeanlan(at)spots.ab.ca>
>Subject: Re: sitka grades
>Date: Thu, 26 Aug 1999 13:40:30 -0600 (MDT)
>Ken
I've been watching the conversations here for a while as I have been
considering a Piet myself. Todd Chisum's comment about CA
(cyanoacrylate) superglues caught my eye and needs a reply. I've been
using CA glues to build model airplanes for 14 years. They work great on
balsa wood and plastics but are sometimes a little iffy on bass wood or
the spruce I uses in my models. I suspect that the same would be true on
the sitka spruce in full scale aircraft. I have noticed that it doesn't
always "kickoff" or catalyze consistently. Sometimes these instant glues
don't seem to set up well. The articles that I have read in the RC
magazines seem to indicate that this has to do with the alkalinity of
the wood and the humidity. There are a lot of handy varieties of CA
glues (various viscosities ect) but I would stick with the glues such as
T-88 or others. CA glues also have very very noxious fumes. If you were
going to use enough to build an airplane you would need a respirator.I
have read of moderlers developing severe allergies to CA's at least as
severe as those that some people have to the resins used in fiberglass
aircraft. I seem to remember that Rutan used some CA's on his
round-the-world plane but that was a composite aircraft. A little long
winded for my first message here but I hope it is helpful
Matt Kirk
here for a
while as I have been considering a Piet myself. Todd Chisum's comment
about CA
using CA
glues to build model airplanes for 14 years. They work great on balsa
wood and
plastics but are sometimes a little iffy on bass wood or the spruce I
uses in my
models. I suspect that the same would be true on the sitka spruce in
full scale
aircraft. I have noticed that it doesn't always kickoff or
catalyze
consistently. Sometimes these instant glues don't seem to set up well.
The
articles that I have read in the RC magazines seem to indicate that this
has to
do with the alkalinity of the wood and the humidity. There are a lot of
handy
varieties of CA glues (various viscosities ect) but I would stick with
the glues
such as T-88 or others. CA glues also have very very noxious fumes. If
you were
have read
of moderlers developing severe allergies to CA's at least as severe as
those
that some people have to the resins used in fiberglass aircraft. I seem
to
remember that Rutan used some CA's on his round-the-world plane but that
was a
composite aircraft. A little long winded for my first message here but I
hope it
is helpful
Matt Kirk
Steve wrote:
I am interested in using this glue on my project. How bout more feedback
on it!
Steve
Subject: | Soob variations. |
What different ways are yall using the soob on your Piet/Gn. Any direct
drives?? What redrive ratios and so fourth.
Steve
Interesting. ON the tailwind list they are trying to go from the fuse to
the wing with their fuel. Just a little irony.
Steve Eldredge
IT Services
Subject: | Wood List for Fuselage? |
Does anyone have a building materials (wood) parts list for the fuselage on
the Aircamper? Sure would save me a lot of time calculating!
Thanks, Glenn
>on it!
>Steve
A local guy just built a set of laminated spruce landing
gear legs for his Fly Baby and he used Titebond II, testing
samples in the vise, soaked in water for two weeks, with
PERFECT results. I would not hesitate to use this.
Mike C.
Subject: | Re: Wood List for Fuselage? |
Glenn,
If you get one, post it. It may be a good idea to post it to the
Aircamper website. Do you have a list for the wings?
Joe
>Thanks, Glenn
get a quote from wicks aircraft supply they will
itemize it. they have a parts list.
calculating!
> Thanks, Glenn
Here is the response that I received from Wicks:
Thank you for your interest in the Pietenpol Aircamper. However, at this
time the designer/ plan owner Don Pietenpol does not have a material listing
showing the individual parts needed to build the Aircamper. I will keep
your name and address to forward any information that becomes available.
Kit Plans magazine "sort of" mis-printed information. Yes, we do sell
everything needed to complete the plane - minus engine and avionics,
although we're not certain what the materials are.
Still hoping for a list.....
Glenn
Thanks. The engine is suppose to be completely overhauled by an A&I.
I'm looking at the paperwork this weekend. It also has a prop that should
be suitable for use with a Piet.
Greg Yotz
Date: Thursday, August 26, 1999 10:16 AM
Subject: Pietenpol-List: Re: Cost for Cont A-65
>by any means.
>>Greg Yotz
that
Good
>Tim Cunningham
That is what Jerry was telling me when I told him someone on this list had said
they got a list from Wicks and the prices was really low. Jerry contacted Wicks
to check and they told him same thing (No List) so I wonder just what list the
person on this list was referring too in making the statement that Wicks was so
much cheaper than ACS.
Don't remember your name but please post it again with the list you are
referring too so we all can compare the two companys prices.
Gordon
> Glenn
You would think after 70 years their would be a list out someplace.
Bet Replicraft has a list, an western aircraft has a list but they use it only
to sell kits and material package.
Good idea to get one and post it to web site.
Gordon
> Thanks, Glenn
Subject: | RE: Wood List for Fuselage? |
I am near completion of fuselage. Have built wing ribs and tail feathers. I would
be willing to fax a copy of my orders to anyone who wants to put together
a list. Maybe compare it to other Piet builders parts list. I seemed to have
not that much wood left over so I guess my list is semi accurate. I am often
guilty of not ordering a little extra for screw-ups. Bart
> From: Gordon Brimhall[SMTP:arkiesair(at)surfree.com]
> Sent: Friday, August 27, 1999 8:00 AM
> Subject: Re: Wood List for Fuselage?
> Gordon
> > Thanks, Glenn
I would put it together for the list but don't have a fax that works anymore.
Gordon
would be willing to fax a copy of my orders to anyone who wants to put together
> > Gordon
on
> > > Thanks, Glenn
The test for waterproofness in glue is to BOIL it water.
From: | Mike Cunningham <mikec(at)microlandusa.com> |
I'm with Matt Kirk on CA for home builts. I have used a lot of it over
the years as a RC modeler. It has several advantages
and dis-advantages. In big scale models we never trust CA to hold
anything that will be subjected to heavy vibration, fike fire
walls (I now use T-88). We also don't use it on primary structural
joints like spars and tail attachments. I don't have any scientific info
to pass along but I have always fealt that CA is somewhat brittle. I
would never trust my back-side to it!
Date: Friday, August 27, 1999 12:05 AM
Subject: CA glues
Matt Kirk
Thanks for the input on using CA in homebuilts. Your experiences with CA
are similar to mine in R/C models. I tried it on one nose rib for my Cuby
but found unless the joint was PERFECT there were little gaps that moisture
could find its way into. I sealed the edges with resorcinol. The use by
others of Titebond II is interesting. I'll try that on my next nose rib.
Todd Chisum
>I'm with Matt Kirk on CA for home builts. I have used a lot of it over the
>walls (I now use T-88). We also don't use it on primary structural joints
>like spars and tail attachments. I don't have any scientific info to pass
>along but I have always fealt that CA is somewhat brittle. I would never
> From: Matt Kirk <mattkirk(at)chipshot.net>
> Subject: CA glues
>considering a Piet myself. Todd Chisum's comment about CA (cyanoacrylate)
>superglues caught my eye and needs a reply. I've been using CA glues to
>build model airplanes for 14 years. They work great on balsa wood and
>plastics but are sometimes a little iffy on bass wood or the spruce I uses
>in my models. I suspect that the same would be true on the sitka spruce in
>full scale aircraft. I have noticed that it doesn't always "kickoff" or
>catalyze consistently. Sometimes these instant glues don't seem to set up
>well. The articles that I have read in the RC magazines seem to indicate
>that this has to do with the alkalinity of the wood and the humidity. There
>are a lot of handy varieties of CA glues (various viscosities ect) but I
>would stick with the glues such as T-88 or others. CA glues also have very
>very noxious fumes. If you were going to use enough to build an airplane
>you would need a respirator.I have read of moderlers developing severe
>allergies to CA's at least as severe as those that some people have to the
>resins used in fiberglass aircraft. I seem to remember that Rutan used some
>CA's on his round-the-world plane but that was a composite aircraft. A
>little long winded for my first message here but I hope it is helpful
> Matt Kirk
Subject: | Re: everyone can get ASS catalog free |
Dear Gordon,
Regarding your email on pricing of wood kits. Our pricing and quality of
spruce is competitive with anyone in the market. And of course we guarantee
to meet or beat a competitors price.
The only real way to see if there is in deed a difference in price is to
obtain kit lists from both companies and compare what is contained in each
kit, to make sure you are comparing apples to apples. There are also
different variations of the same plane one with a one piece wing and one
with a three piece wing.
All this really got my curiosity up so what I did was make a friendly call
to Wicks and inquire
about their spruce kit for Pietenpol Aircramper. What they told me, you can
call and verify, was that they can supply materials needed for the plane but
they do not have a list of materials, thus they have no idea exactly what is
required in the kit or an idea of the actual cost. Wicks does not have a
set spruce kit built up for the Aircamper. Again this is why I say the only
way to really compare prices is to sit down with the kit list from each
company and see what is contained or to supply the same list to each company
and request a quote.
Sincerely,
Jerry Aguilar
>Subject: Re: everyone can get AS&S catalog free
>Date: Thu, 26 Aug 1999 17:11:45 -0700
>taking
>stuff at
>are
>close.
>Gordon
>Gary Gower wrote:
> > >Group
> > >Marketing Director.
> > >Gordon
>personally
>good
>needed!!
> > Saludos
> > Gary Gower
Dear Gordon,
Sincerely,
Jerry Aguilar
>taking
>stuff at
>are
>close.
>Gordon
>Gary Gower wrote:
> > >Group
> > >Marketing Director.
> > >Gordon
>personally
>good
>needed!!
> > Saludos
> > Gary Gower
Matt;
I have tried some of this too but ALWAYS come back to T-88 due to it's
versility and ease of use. CA's do have their limits, something to do
with molecular intra-facial tension....something. I got crosseyed
listening to all that as well as smelling it. I stick with T-88 or a
high quality Marine adhesive in a pinch. T-88 is just so easy, FORGIVING
and cut and dried The "structural gap filling" qualities is a good butt
saver. I have played with spruce pieces with a glue-gap of 1/4". Each
case, when totally dried, the wood still let go first. That is to say
you don't do that with airframe parts, just a confidence building test.
TO THE LIST IN GENERAL:
Ref Resorcinal, where did youse guys read/SEE or hear that this was an
"FAA APPROVED ADHESIVE" ?? The key words here are "approved". Inquiring
mind wants to know....!
Earl Myers
ALSO; If any of you have any AN/MS hardware questions, I may be able to
help as I was in that business for a number of years
(12).......manufacturing and distribution.
Earl Myers
Date: Friday, August 27, 1999 1:01 AM
Subject: CA glues
Matt Kirk
A cup is not a bad idea when it comes to staplers.
I was using a air powered stapler on my first Piet tail section. I was
using 40 lbs of air pressure.
One day I went into the shop to work and I didn't realize my son had
adjusted the air pressure up to 120psi.
I got ready to set a staple and used the stapler. After I pressed the
button there was a small hole but no staple.
So I did it again. Still no staple. So I checked for a jammed staple, but
there was none.
So I tried it again. Still a hole. This time though I thought to myself
there seems to be alot of air kicked out of the vent when I stapled that
time. So I checked the air pressure and found it was set high. I looked on
the back
of the wood and sure enough you could see where the staple had sliced all
the way through.
After I fixed everthing and finished my work I went into bed.(didn't replace
wood but filled holes with T-88)
When I was pulling my boots off I noticed two nice little staples sticking
in one toe. I thought I sure was glad
I had my boots on. Then I thought I'm sure glad I wasn't sitting down and
working in my lap.
Still never figured out where the third staple went. But I bought a more
comfortable pair of safety glasses with side covers so I would be sure to
wear them everytime. Didn't want everyone to think a one eyed pirate was
flying around in an Air Camper.
Greg Yotz
Date: Thursday, August 26, 1999 2:21 PM
Subject: Pietenpol-List: Re: sitka grades
>Ken
>Ken Beanlands B.Eng (Aerospace)
>Calgary, Alberta, Canada
>Christavia MK 1 C-GREN
><http://www.spots.ab.ca/~kbeanlan>
Group-brewed a pot of coffee one Sat. morning and jotted down all
the sizes I would need of wood for the Piet wings with my
calculator and fudge factor....it doesn't take that long.
Plus- some guys use birch, some guys use mahogany,
some guys use Finnish plywood.....
Mike C.
How about making a plywood floats with TB II and landing in "sleep" volcano
lake?
That will be a real boiling test :-) :-) :-) (Couldnt stop this one)
I did boil (for 5 minutes) a piece 2 years ago let it cool, it was still
bonded, but pulling hard it did unglue, but I will never boil my plane,
would'nt even dare to live it outside in a rainy day.... We love them so
much to be that cruel...
Saludos
Gary Gower
Subject: | I've got wood list |
I've got both the wood/cut list that Aircraft Spruce used (from a guy in
Indiana) and an itemized quote from A.S.&S.
Glad to share it but I'm trying to scan it and can't get good copies.
Being the computer genius that I am, I gave up.
Anyone know the knack of getting a good scan, or other means?
walt
Aircraft
Spruce used (from a guy in Indiana) and an itemized quote from
A.S.S.
scan it and
can't get good copies. Being the computer genius that I am, I gave
up.
good scan, or
other means?
walt
Great, You made it to the list Jerry.
But why a different email address, other companys use their company address.
LikeI told you it was someone else saying he called Wicks and got the great
price for all the parts, talking like they had a package all ready. Maybe it is
impossable to have a package because of the different verations, we need to get
a list together on this list and price it all out. I have volunteered to do it
if I can get a list of needed spruce.
I see you have a packaege listed for the GN-1 Aircamper and a price that was in
error in the 1998/99 catalog with the corrected price in the 1999/2000 catalog.
Are you planning to have a complete list for the Real Pietenpol Aircamper in
standard form, with maybe an option for the 3 piece wing? Would be nice.
Thanks Jerry for making the list.
Gordon
RW1 Piet
Mohawk MK IV
Plane Fun wrote:
> Dear Gordon,
> Sincerely,
> Jerry Aguilar
> >taking
> >stuff at
> >are
> >close.
> >Gordon
> >Gary Gower wrote:
> > > >Group
> > > >Marketing Director.
> > > >Gordon
> >personally
> >good
> >needed!!
> > > Saludos
> > > Gary Gower
Subject: | New Product Idea |
Jerry,
Here is an idea for a product- laser cut wing rib gussets. They could be
of a generic size or tailored for a specific airplane. My Cuby took over
700 1" x 2" pieces, plus a bunch of other sizes. That's a lot of time with
a saw and sander!
Talk to you later,
Todd Chisum
Tulsa, Oklahoma
Wag Aero Super Sport project (but there is a Pietenpol in my future)
Subject: | Re: I've got wood list |
How can you have it if they don't have it Walter:-)
Please mail it to me. I don't have a scanner yet, still waiting for my
new computer to arrive that went into shipping Monday.
I want to get all lists together and then start compiling a Pietenpol
Builders Manual when ever I start mine complete with all the
construction pictures. Won't do anybody any good on this list now but
for the future Youngens it may be of help if the FAA don't legislate
us out of business.
Gordon
RW1 UL Piet
Mowhawk MK IV
Real Piet "Soon"
> guy in Indiana) and an itemized quote from A.S.&S.Glad to share it
> but I'm trying to scan it and can't get good copies. Being the
> computer genius that I am, I gave up.Anyone know the knack of
> getting a good scan, or other means?walt
my new computer to arrive that went into shipping Monday.
Builders Manual when ever I start mine complete with all the construction
pictures. Won't do anybody any good on this list now but for the future
Youngens it may be of help if the FAA don't legislate us out of business.
Gordon
RW1 UL Piet
Mowhawk MK IV
Real Piet "Soon"
walter evans wrote:
I've got
both the wood/cut list that Aircraft Spruce used (from a guy in Indiana)
and an itemized quote from A.S.S.Glad
Being the computer genius that I am, I gave up.Anyone
know the knack of getting a good scan, or other means?walt
Subject: | Re: New Product Idea |
Todd
Great idea, I just cut enough today for a test rib on my UL Piet, pain in the
seat. The UL calls for 1/16" gussets.
How about a Laser Cut Piet In A Box
I suggested a die cut set of gussets like we did in the old days. Laser much
better.
Gordon
> Jerry,
> a saw and sander!
> Talk to you later,
> Todd Chisum
> Tulsa, Oklahoma
Hi Matt: Look into West systems glue. T-88 is real good and popular, BUT,
some of the Broadhead fellas into'd me to West and the rest is becoming
history er my story. Ryder
Why not just rip them up on a table saw? You can even stack the strips and
cut 30+ gussets per pass. Best to use a scrap piece on the bottom to avoid
splintering the edges. It would only take a couple of hours if they were
square gussets. It would be a little longer if you had to cut angles, but
even that's doable.
Ken
On Fri, 27 Aug 1999, Gordon Brimhall wrote:
> Todd
> better.
> Gordon
> > Jerry,
> > a saw and sander!
> > Talk to you later,
> > Todd Chisum
> > Tulsa, Oklahoma
Actually the 45 degree angle ones are easy, just flip it over for each cut once
you
are doing it. I had 4 pieces of wood stacked up. I was cutting 1/8 for this test
rib.
I have a table saw, band saw, sander belt/wheel. Just miss having my Mill and Lathe
I had 20 yrs ago.
Gordon
> even that's doable.
> Ken
> > Todd
> > better.
> > Gordon
> > > Jerry,
> > > a saw and sander!
> > > Talk to you later,
> > > Todd Chisum
> > > Tulsa, Oklahoma
Another point to consider, if the wood "breaks" instead of the wood when
pulling apart, and is waterprof enough almost to boiling point... the test
pieces resist sun, rain and time for several years unprotected we will...
Remember that the wood on the plane is going to be protected (including
glue) with poliurethane (sp?) barnish, that is really resistant to water,
the plane will be hangared when not flying, the pilot will have enough care
to not get into rain when flying, if it gets a little wet he will dry it
fast with a cloth.
Then we would ask:
When is the glue going to get enough water to melt? Remember when planes
were made with Casein glue (we are maybe to young, so read some aviation
history :-) that was a glue that melted with water, they only resist because
where covered with some sort of "marine barnish", (Remember no certified
aircraft parts available) these planes (or parts of them) are still in one
piece in museums.
Do your testing and get confidence yourself, I got enough confidence for
using this glue nothing has unglued in several years. I am curious to know
when Franklin Co. begin manufacturing the TB II, just for lerning...
Buy the way, working with Resorcinol did not make me happy, to complicated
to get a perfect bond, and the risk of not being well done is still there...
certified or not.
Saludos
Gary Gower
>fast with a cloth.
>Then we would ask:
>piece in museums.
>certified or not.
>Saludos
>Gary Gower
Gordon,
When I posted that, had it right in my hand. Contacted them on 5-98
about a qoute, they put me in touch with "Charleen".
She was very knowledgable about Piets,even said a friend had one at
Brodhead, where she had visited.
She asked which model/length etc. I was building. She sent me a 3 page
list of dimentional sizes and running ft., based on a lumber list
supplied to them years before, by a guy in Jeffersonville Indiana.( I
also rec'd a copy of that, which is the " cut to length list")
This was no plywood, only spruce, for the long fuselage with the 3 piece
wing. All rib cap strips cut to lenght + 1" (no "specialty cuts
included like round leading edge or trailing edge)
The Qoute in 5-98 was $1,138.13. I rec'd the wood in a couple of weeks
and was very pleased with the quality ( this is my second wood project).
I played around with scanner settings, and found if I don't shrink it
down too much, you can still read it. I can send it to you, but it will
be large.
walt
-------I still like Aircraft Spruce--------
-----Original Message-----
Date: Friday, August 27, 1999 5:59 PM
Subject: Re: I've got wood list
Pietenpol Builders Manual when ever I start mine complete with all the
for the future Youngens it may be of help if the FAA don't legislate us
out of business.
Gordon
RW1 UL Piet
Mowhawk MK IV
Real Piet "Soon"
a guy in Indiana) and an itemized quote from A.S.&S.Glad to share it but
I'm trying to scan it and can't get good copies. Being the computer
genius that I am, I gave up.Anyone know the knack of getting a good
>Gordon,
list of dimentional sizes and running ft., based on a lumber list supplied
to them years before, by a guy in Jeffersonville Indiana.( I also rec'd a
wing. All rib cap strips cut to lenght + 1" (no "specialty cuts included
>The Qoute in 5-98 was $1,138.13. I rec'd the wood in a couple of weeks and
> I played around with scanner settings, and found if I don't shrink it down
too much, you can still read it. I can send it to you, but it will be large.
>walt
Hi Walt,
Could I get a copy too??
Thanks, Glenn
Subject: | Re: No apologies necessary |
Ted,
Your misinformation fits right in with my procrastination (actually just
long ours at the office). I haven't ordered the plans yet but I will do so
very soon. Thanks for your research. If that manual is advertised on the BPA
webpage, then I certainly missed it.
Date: Wednesday, August 18, 1999 8:07 PM
Subject: Pietenpol-List: sorry
Brian.
Sorry for misinformation. I just checked the Pietenpol page and the
manual is $ 27.00 including shipping. Ted.T
Subject: | Turtle deck ribbing |
Could someone tell me the dimensions of the turtle deck ribbing?
Jacob
Subject: | RE: Turtle deck ribbing |
1/4" x 1" tapered at the tail end to fit.
Steve Eldredge
IT Services
Brigham Young University
> MACKORELL(at)aol.com
> Sent: Friday, August 27, 1999 8:54 PM
> Subject: Turtle deck ribbing
> Jacob
Ted,
Check out Don Pietenpols' Officail Pietenpol website.
www.pietenpol.com/
This is where you will see the builders manual listed.
Brian
My fault , I need to be more careful with my Pietenpols. the manual is
listed at Don Pietenpols site. Not B.P.A Ted.T
I think Allen Rudoff's plane is put together with
casein glue. Its not hanging in a museum its flying.Ted.T
Subject: | Flight Log to Brodhead finally complete |
Mostly.
If you are really bored, check out my flight journal to Brodhead 99' Thanks
to everyone! It will live forever in my memory...
Enjoy.
Check out http://steve.byu.edu/piet.htm
Steve Eldredge
IT Services
Subject: | Re: Turtle deck ribbing |
Jocob,
I used 1/4x1" that I ripped out of clear pine. Started with standard 5/4"
stock.
walt
Date: Friday, August 27, 1999 10:57 PM
Subject: Pietenpol-List: Turtle deck ribbing
>Jacob
Subject: | Re: Flight Log to Brodhead finally complete |
Date: Saturday, August 28, 1999 12:54 AM
Subject: Pietenpol-List: Flight Log to Brodhead finally complete
What a great story Steve! Many, Many thanks for taking the time to document
and share it with the group. After reading it, I've got an urge to go out
to the airport and fly.
Adios!
>Mostly.
>Enjoy.
>Steve Eldredge
>IT Services
Walt,
Thanks for the info!
Jacob
Great, I just sent it all over the world, Hope you keep it their so I can add a
pointer to it on some of my web sites.
Gordon
steve(at)byu.edu wrote:
> Mostly.
> Enjoy.
> Steve Eldredge
> IT Services
Subject: | Marine Plywood in Piets |
I am looking for information regarding the use of Occume or Khaya marine
plywood in a Piet. I am planning on beginning construction in the next
year and would like to use it where feasible, mainly because
I own a business whose primary product is selling it.
Any comments/suggestions/opinions ?
Wayne Meier
for anyone who is interested. I posted my woodlist 2,3,4,5 ( #1 is
blank) which shows Aircraft Spruce's list to me last year , with
dimentional sizes and a cut list #5.
These are LARGE , but if you download them and print them, the printer
will fit them to a page.
http://www.aircamper.org/users/wevans/
under woodlist
walt
posted my
woodlist 2,3,4,5 ( #1 is blank) which shows Aircraft Spruce's list
to me
last year , with dimentional sizes and a cut list #5.
download
them and print them, the printer will fit them to a page.
href"http://www.aircamper.org/users/wevans/">http://www.aircamper.org/=
users/wevans/
under woodlist
walt
Subject: | Re: my wood list |
Thanks Walter, I'm sure this will help me. - James McFarland
for anyone who is interested. I posted my woodlist 2,3,4,5 ( #1 is blank)
which shows Aircraft Spruce's list to me last year , with dimentional sizes
and a cut list #5.
under woodlist
walt
Kerri Willette , Tileko Ridsdale ,
David W Padrusch , Everett Millett ,
Steve Large ,
LarsErik Johansson ,
Tim Gardner , Antonio Genovino ,
Steve Grant , Jeff Files ,
Bob Carpenter , John Carpenter ,
Michael Comet <comet@comet-cartoons.com>, Ros Bertran ,
Pietenpol Air Camper , mis(at)autoeurope.com
Belinda (Lindy) Piper DeCosta born Aug. 28 8:24pm. 8lb 4oz. Mother and
baby (and father :) all going well. She has her mother's eyes and lots
of beautiful black hair.
Richard
http://www.AirCamper.org/w3builder
Subject: | Re: It's a girl! |
Date: Saturday, August 28, 1999 9:56 PM
Subject: Pietenpol-List: It's a girl!
Good for you Richard! Congratulations to your entire family!
Robert Hensarling
Uvalde, Texas
>Richard
Just thought I'd mention....I had a Steel Rule company make up a 2 1/2"
diameter punch with an additional cutter down the center...making 2 halves
for wing rib gussets. There is a local guy with a punch press that stamps
them out for me. A 4' x 8' sheet of 1/16" ply makes thousands of these half
moon gussets. They cost about $0.01.5 each.
Look in your local Yellow Pages....these guys are everywhere!
Steve
Replicraft Aviation
Richard,
Congratulations, I have a son and two daughters and I wouldn't trade them
for all the pietenpols in the world.
Nice to see whats really important in life, and it's fun to build aeroplanes
too!
this your first? were you there?
walt
e-mail me a cigar!
Date: Saturday, August 28, 1999 10:31 PM
>Richard
This is the best thing in your life, just take lots of photo's as
thay grow up faster then you can think. Ours little gril will be
20 soon and she's the best thing in our life.
Congratulations,thats #2 i think,we had our girls 7 minutes apart! 7 years
ago.All the best.
Doug Hunt.
> From: Richard DeCosta
> Subject: It's a girl!
> Date: Saturday, August 28, 1999 8:29 PM
> Richard
Steve;
Are these available from you?
Earl Myers
From: Replicraft(at)aol.com <Replicraft(at)aol.com>
Date: Saturday, August 28, 1999 10:53 PM
Subject: Pietenpol-List: New Product Idea
half
>Steve
>Replicraft Aviation
Me too, what can I do?
John Langston
>I am receiving 2 copies of each message on the Pietenpol discussion
>group, what should I change to only get only 1.
>Thanks,
__________
Subject: | Re: Marine Plywood in Piets |
Any good grade of marine plywood shouldn't give you any problems.
John Langston
>marine
>next
>because
>Wayne Meier
__________
Robert,
We used T-88 on our project and it appears to be quite popular. It is
mixed in equal parts which makes it easy. It does run though and you need
to be careful about drips and excess glue. We're very confident in its
strength.
John Langston
>Hey everyone, I ordered the lumber for the fuselage a few weeks ago
>from
>WICKS should be ready to pick up soon. this is a first time project
>any
>suggestions on the best and easiest glue to use? thanks, Robert Bush
__________
Subject: | Re: speaking of the tail surfaces |
We ran into this problem too and used two thicknesses of gussets to solve
it. It really worked out well.
John Langston
writes:
>be gusseted also.
>walt
__________
Richard,
Just got back from the airfield to read your note.
CONGRATULATIONS!!!
LLN
P.S. This recent construction project of your(s) has not had sufficient
attention. We are all concerned about performance and adherence to
plans. Please post stills and videos to the web site ASAP! ;-)
> Richard
Subject: | I'll have to get a hamster |
Started routing spars yesterday, and got two done. Man, sure is alot of
chips and sawdust. The deck wsa a winter wonderland.
get started today after the neighborhood wakes up.
walt
got two
done. Man, sure is alot of chips and sawdust. The deck wsa a
winter
wonderland.
neighborhood wakes
up.
> with.
> a boat that I built
> Plastic Resin glue
> and separated from
> the wood.
> you can give it and
> Lauren
I was at a forum about wood aircraft at OSH about 4 years ago and the
man said that the urea-formaldahyde glues should no longer be used in
aircraft. He was from
Australia and they have found quite a few where the glue joints were
separating after 20 to 30 years of service. They seemed to think that
the heat had a lot to do with it. I also thought I heard a year ago
that now the FAA has joined the Australians and British in forbidding
these glues. Maybe someone has better or more recent info.
John in Peoria
Subject: | Fw: I'll have to get a hamster |
Steve,
on the original plans , the spars are out of 1"x4 3/4" by about 13ft.
spruce. To reduce weight there are two sections on each side that is routed
out . There are 3 areas that stay the full 1x4 3/4,,, the butt end( near
the plane) ,,the center area where the struts attach to the spars,,, and the
tip ( I'm building the three piece wing)
If you could see a cross section of the routed area, it would look kind of
like an "I" beam. Between 3/4" from top and up from bottom , is
untouched. inbetween there is routed out 1/4" deep on each side.
This is to reduce weight , plus the pulley controls for the wings, mount in
the routing.
I can post a pic later today of my progress, if you'd like.
walt
Date: Sunday, August 29, 1999 9:18 AM
Subject: Pietenpol-List: Re: I'll have to get a hamster
>Steve wrote:
>A little info here! Can you explain this routing of the spars and if
>possible send discription or pix.
>Thanks
>Steve
> writes:
>> of chips and sawdust. The deck wsa a winter wonderland.
>> walt
From: | walter evans <wbeevans(at)worldnet.att.net> |
Subject: | note about wood list |
To anyone who is looking at the wood list that I posted, there is one
correction that I want to note... the cut list had the 2 center section
spars as 28" long. This should be 29" long as per Pietenpols prints.
I'm not blaming Aircraft Spruce, because they sent this to me for my
approval, and I didn't catch it. (I had to lengthen mine).
So if these lists brings you to the wood ordering point,,, be sure to
bring up this correction to the supplier.
walt
list that I
posted, there is one correction that I want to note... the cut list had
the 2
center section spars as 28 long. This should be 29
long as per
Pietenpols prints. I'm not blaming Aircraft Spruce, because they
sent this
to me for my approval, and I didn't catch it. (I had to lengthen
mine).
wood
ordering point,,, be sure to bring up this correction to the
supplier.
walt
Congratulations on your first completed "homebuilt", Richard!
Mike List
> Richard
Subject: | Re: I'll have to get a hamster |
In a message dated 8/29/99 7:56:52 AM Central Daylight Time,
wbeevans(at)worldnet.att.net writes:
<< get started today after the neighborhood wakes up.
walt
This brings up a question I have been pondering since I am about to start
ripping capstrip materials. What is the etiquette for neighborhood noise
with respect to hours of operation? I am sure it must vary from one neighbor
to the next. Being a single dad, I have to do most of my work after my 3yr
old is in bed. I'm kind of a night owl anyway and I picture myself wanting
to fire up the table saw or run the bench grinder at 1 am. I guess I will
limit my outdoor noisy stuff to the hours between about 8am and 9pm. So far,
I am friends with all of my neighbors as far as I know. Has anyone ever
pushed the limit and have a grouchy neighbor story to relate?
TerryB
congrats on a job well done!!! do I see a "Lucky Lindy" logo on the side
of your Piet in the future???
JoeC
Zion, Illinois
> Richard
I am confused. I logged onto the Pietenpol web site to see what was
available to suppliment the plans. There is a builders manual. I thought I
remembered seeing a chapter the proffessed to be a part listing???
Ted
> However, at this
Subject: | Re: Pietenpol Builder's manual |
Can anyone who has the manual tell me how many pages are devoted to the last
couple of chapters that actually give building tips?
I don't mind buying the book if it really has some substantial information
contained in it.
Ted
I did the same thing but I used the instrument hole cutter than cut the plugs
in half and quarters
JoeC
> Steve
> Replicraft Aviation
Richard,
Where are the pictures posted?
Mark Boynton
Gilbert, AZ
P.S. Love that name.
> Richard,
> CONGRATULATIONS!!!
> LLN
> > Richard
_______
Get FREE voicemail, fax and email at http://voicemail.excite.com
Talk online at http://voicechat.excite.com
Terry,
I would start by finding out what your town laws are. Each town has
deffinite start and stop times for weekdays, sat, and sun. Nice to know
that if a neighbor complains, you are, at least , legally in the right.
This being Sun, I waited till 10:00
walt
Date: Sunday, August 29, 1999 10:24 AM
> walt
neighbor
far,
> TerryB
Yes but since I don't plan on boiling my airplane why should I worry
about a boil test, I doubt if any epoxy glues will pass a boil test however
they are the first choice of many of the old school boat builders,sail boats
powered run about etc. The point is no one glue is perfect, each has it's
strengths and weakness'. The marine epoxy I use is Raka Epoxy you can
find it one the net, one of the advantages is it'll gap fill like crazy and
the
glue in the joint is stronger than the wood itself, The advantage with the
TiteBond is that ventilation and rubber gloves is not needed but neither
of these glues will pass a boil test. The birch ply soaks the epoxy up and
sometimes traces are seen coming through the other side of the 1/16
ply. Also epoxy doesn't need the clamping pressures other glues need!
I do however plan on painting my wings white as with any epoxy plane
to keep temperatures down as much as possible.
----- Original Message -----
From: | Lauren Williams <LaurenMWilliams(at)webtv.net> |
Sent: Friday, August 27, 1999 10:46 AM
Subject: | Re: OT Noise in town was I'll have to get a hamster |
MY neighbor on one side 10' away used to tease my Puppy Beagle, when the dog
grew up he barked at the neighbor every time he was out in his yard, So he
complained to me. But that was after he had borrowed all my tools plus my Troy
Built Tiller to do his new yard.
My other neighbor behind me used to come home from work at 10pm and start doing
car body work because he slept during the day. So during the day on my day off
I
would put my stereo out on the patio and play load music, He complained, I said
it works both ways.
I had a old bus pull up and took up residence by my sidewalk on my corner lot,
After 3 days I went out to ask him to go live someplace else, He pointed to his
Protected by 45 sign. I called police and they moved him out. He came back in
two days, I called the city Manager and asked him what his address was so I
could have this person go live in the front of his house, the police came out
and moved him again, he never came back.
So now I live in the middle of 2 1/2 acres, my closes neighbor is 250 ft away
from me. Life is too short to live in the city, I will never live that close
to anybody again. Got two neighbors that work on cars alot, never even hear them
now.
I believe in most city's a 10pm time is on the books to be quite.
Gordon
walter evans wrote:
> Terry,
> walt
> From: BARNSTMR(at)aol.com
> Subject: Re: I'll have to get a hamster
> > walt
> neighbor
> far,
> > TerryB
Yes, the skin of the Jodels was Okoume 1.5 mm. Seems like
the African nation of Gabon was once under French rule and
Okoume was easy to get in France. Its side hardness is not what
true mahogany or birch is but a slight coat of epoxy makes it durable
enough for the floor board. Bacteria and fungi love Okoume so make
double sure every thing is sealed with maine varnish or epoxy!
Russell
Sent: Saturday, August 28, 1999 3:59 PM
> Wayne Meier
Subject: | routing the day away |
put some pics (from video) on the site of the routing experience.
walt
spar1,2,3
site of the
routing experience.
users/wevans/
walt
spar1,2,3
I woke to the sound of the neighbor removing six inches of snow from his driveway
at three AM once. This was not the first time. I got up, got dressed and went
out to confront him. When I asked if he was aware that people sleep during this
time and would he cease, he replied "well...you mow your lawn before noon !" and
then " I have to clear the driveway so my wife can go to work at six" His
wife has been observed to leave before eight thirty to nine, as she did
later that am.
Aside from that, if you get along with neighbors, ask what is acceptable to
them. Otherwise, be reasonable- ten is usually late enough for loud noise
outside. I feel seven am is too early, but most house construction crews near
here start about then.
Wayne
> walt
> TerryB
From: | leonstefanhutks(at)webtv.net (Leon Stefan) |
I studied mu plans for hours and hour, over weeks and weeks. Finally I
just ordered a wood kit from Western Aircraft. Three weeks later I took
delivery of 2 shipping tubes containing the most beautiful, sweetest
smelling aircraft quality "wood list" there is. Haven't given a moments
week stated "electric and hand staplers are to brutal on wood unless you
use wire staples" Wire staples are exactly what you want to use.
Craftsman 1/4 wire staples from Sears with my Arrow JT-21 stapler are
fast and accurate. they don't splinter cap strips. He also had a long
process for nailing gussets. steaming one capstrip at a time and leaving
rib in jig overnight. make your bending jig wide enough for at least 3
cap strips. (2X4 works fine) You are ahead on pre-bent capstrips. One
ugly rainy day last Nov.,using squeeze bottles for epoxy, medicine cups
for mixing, and staple gun, I knocked out 4 ribs in one day. I could
have built 5 but I took ill. actually I was just sick of building ribs.
Leon S.
Hello Everyone
Fuselage
1" x 1" x 35' 4pcs
1" x 1" x 6' 1pcs
1" x 1" x 5' 1pcs
7/8" x 2" x 6' 2pcs
7/8" x 1" x 6' 1pcs
3/4" x 1" x 8' 4pcs
3/4" x 1" x 3' 1pcs
1/2" x 1" x 6' 5pcs
5/8" x 1" x 5' 1pcs
Wing
1" x 4 3/4" x 14' 4pcs
1" x 4 3/4" x 29" 2pcs
1/2" x 3" x 7' 4pcs
1/2" x 1 1/2" x 7' 2pcs
3/4" x 3/4" x 5' 4pcs
1/2" x 1/2" x 7' 4pcs
Tail
1" x 1" x 8' 2pcs
1" x 1" x 5' 2pcs
1" x 1" x 7' 1pcs
1" x 1" x 6' 1pcs
3/4" x 1" x 8' 4pcs
3/4" x 1/2" x 5' 2pcs
5/8" x 1 1/4" x 9' 1pcs
3/16" x 1/2" x 6' 7pcs
3/16" x 1/2" x 4' 7pcs
500' of capstrip 1/4" x 1/4" for up to 65hp.
I do not know if this is an accurate list that was given to me as I have not
had a chance to verify this with my plans. If anyone out there could verify
this as accurate please get back to me. Hope this helps everyone.
Bobby
srkraut(at)idirect.com
Date: Sunday, August 29, 1999 10:36 AM
Subject: Pietenpol-List: Re: Wood List for Fuselage?
I
>Ted
>> However, at this
listing
Earl-
Yes, I have a box full...we are currently building both a Grega and an Acro
ll rib set, so the supply is rather low. But, getting another sheet or two
cut is not a problem. Please note the 1.5 cents was for the cuttung only,
material was always supplied by me...
Steve
Walt, are you on the CorvAIRCRAFT e-mail list?
Pat
the two differences between your list and mine:::::::
building a 6 place tandem)
7/8x2x6' 2pcs should be 7/8x1x8' 2pcs
this is the only difference to my list , and I've completed fuselage, all
ribs, all tail surfaces,spars, just yet to build wings.
Your list like mine doesn't include leading or trailing edges.
this is my 2 cents worth
walt
Date: Sunday, August 29, 1999 3:53 PM
>Hello Everyone
>Fuselage
>1" x 1" x 35' 4pcs
>1" x 1" x 6' 1pcs
>1" x 1" x 5' 1pcs
>7/8" x 2" x 6' 2pcs
>7/8" x 1" x 6' 1pcs
>3/4" x 1" x 8' 4pcs
>3/4" x 1" x 3' 1pcs
>1/2" x 1" x 6' 5pcs
>5/8" x 1" x 5' 1pcs
>Wing
>1/2" x 3" x 7' 4pcs
>Tail
>1" x 1" x 8' 2pcs
>1" x 1" x 5' 2pcs
>1" x 1" x 7' 1pcs
>1" x 1" x 6' 1pcs
>3/4" x 1" x 8' 4pcs
not
>Bobby
>From: Ted Brousseau <nfn00979(at)naples.net>
>To: Pietenpol Discussion
>I
>>Ted
>>> However, at this
>listing
I'd have to say I didn't find the builders manual very informative. I'm
gleening more info off this mailing list than I did from the manual. I
bought the manual and the plans, but I haven't ordered any material or
started anything yet. I'm still trying to figure everything out and work up
the courage to take the plunge.
Jim T
Pat,
no, the only interest that I have in corvairs is my mentor freind who is an
AP and has been building geared corvairs for a while. I was impressed with
his workmanship so I posted some of his pics on the Aircamper/org site.
walt
PS he designed and build a new crankshaft for this eng....
http://www.aircamper.org/users/wevans/dickmtr1.jpg
>Pat
Thanks Bobby and Walter for the info.
What type of materials has different builders been using, Spruce, Fir, Pine??
Spruce being lighter and fir being stronger and pine lighter and weaker.
Gordon
bobby wrote:
> Hello Everyone
> Fuselage
> 1" x 1" x 35' 4pcs
> 1" x 1" x 6' 1pcs
> 1" x 1" x 5' 1pcs
> 7/8" x 2" x 6' 2pcs
> 7/8" x 1" x 6' 1pcs
> 3/4" x 1" x 8' 4pcs
> 3/4" x 1" x 3' 1pcs
> 1/2" x 1" x 6' 5pcs
> 5/8" x 1" x 5' 1pcs
> Wing
> 1/2" x 3" x 7' 4pcs
> Tail
> 1" x 1" x 8' 2pcs
> 1" x 1" x 5' 2pcs
> 1" x 1" x 7' 1pcs
> 1" x 1" x 6' 1pcs
> 3/4" x 1" x 8' 4pcs
> Bobby
> I
> >Ted
> >> However, at this
> listing
Russell,
Have you researched the Titebond Polyurethane glue which is listed as being
waterproof? You can go to their website and find some info on it - but it
doesn't
say how it compares to Titebond II strengthwise. It does claim, however, that
it
is "twice as thick as other polyurethanes" and is "unaffected by finishes."
Good
luck on your Piet.
Jim
Subject: | Re: everyone can get AS&S catalog free |
Walter, please help me. Not knowing much about computers, I don't know
how I was unsubscribed from the Piet discussion group. Please tell me
how I can resubscribe. Thanks in advance.
walter evans wrote:
> Just a tidbit of infro. in case everyone isn't aware. Mostly for
> guys just starting or dreaming. You can get the free Aircraft Spruce
> catalog free ( not a penny) on the internet. The group has discussed
> A.S. recently, and if you like them or not, you can't beat their
> catalog . It has good pics of the hardware and screws and brackets and
> blah,blah,blah.Even if I'm buying from Dillsburg,( they only list
> numbers), this gives the numbers on all the stuff. AND stuff like
> heat treating,metal guage,bending radiis, and alot more "keeper"
> charts for ref.Their main site is:http://www.aircraft-spruce.com/ and
> to get right to page to order
> book:https://www.aircraft-spruce.com/spruce/order.cgi/01-38400?,catalog_order
> the cat. is already listed near the top, just go down and fill out
> address etc. Soon you'll get a Fedex mailer full of "book" The good
> thing is you can get them for all of your friends. Not like the
> address has to match the email. I've gotten many for my friends thru
> my comp.walt
know how I was unsubscribed from the Piet discussion group. Please
tell me how I can resubscribe. Thanks in advance.
walter evans wrote:
Just a
tidbit of infro. in case everyone isn't aware. Mostly for guys just
You can get the free Aircraft Spruce catalog free ( not a penny) on the
internet. The group has discussed A.S. recently, and if you
like them or not, you can't beat their catalog . It has good pics of the
hardware and screws and brackets and blah,blah,blah.Even
if I'm buying from Dillsburg,( they only list numbers), this gives the
numbers on all the stuff. AND stuff like heat treating,metal guage,bending
radiis, and alot more "keeper" charts for ref.Their
and to get right to page to order book:https://www.aircraft-spruce.com/spruce/order.cgi/01-38400?,catalog_order
the cat. is already listed near the top, just go down and fill out address
The good thing is you can get them for all of your friends. Not like
the address has to match the email. I've gotten many for my friends thru
my comp.walt
Randy,
go here and fill in the blanks.
Bookmark this page
http://www.aircamper.org/MailingList.cfm
walt
Date: Sunday, August 29, 1999 10:35 PM
know how I was unsubscribed from the Piet discussion group. Please tell
for guys just starting or dreaming. You can get the free Aircraft
Spruce catalog free ( not a penny) on the internet. The group has
discussed A.S. recently, and if you like them or not, you can't beat
their catalog . It has good pics of the hardware and screws and brackets
and blah,blah,blah.Even if I'm buying from Dillsburg,( they only list
numbers), this gives the numbers on all the stuff. AND stuff like heat
treating,metal guage,bending radiis, and alot more "keeper" charts for
ref.Their main site is:http://www.aircraft-spruce.com/ and to get right
to page to order
book:https://www.aircraft-spruce.com/spruce/order.cgi/01-38400?,catalog_o=
rder the cat. is already listed near the top, just go down and fill out
thing is you can get them for all of your friends. Not like the address
has to match the email. I've gotten many for my friends thru my
comp.walt
Plastic resin (urea-formaldehyde) glues are discussed in the latest version
of AC 43.13-1B, Acceptable Methods, Techniques, and Practices, page 1-4:
Plastic resin glue (urea-formalde-hyde
resin glue) has been used in wood aircraft
for many years. Caution should be used due to
possible rapid deterioration (more rapidly than
wood) of plastic resin glue in hot, moist envi-ronments
and under cyclic swell-shrink stress.
For these reasons, urea-formaldehyde should
be considered obsolete for all repairs. Any
proposed use of this type adhesive should be
discussed with the appropriate FAA office
prior to using on certificated aircraft.
Aerolite glue is urea-formaldehyde. I scrapped half my ribs made with this,
and started over with T-88. Aerolite has been used for years, but I knew if
I used it I would think about this paragraph everytime I flew the plane.
T-88 works great, very pleased with its gap filling properties. There is
some talk about epoxies softening at elevated temps, but they are very high,
and airflow over the wing quickly cools it down. The softening is not
cumulative as it is with Aerolite.
Al Swanson
>> with.
>> a boat that I built
>> Plastic Resin glue
>> and separated from
>> the wood.
>> you can give it and
>> Lauren
>John in Peoria
Ted, I found the Builders Manual a good deal. There are chapters from
Modern Mechanics magazine written by Bernard, also 3 chapters on coverting
the Ford A. Also chapters on building the Sky Scout- it was in this chapter
I found a great step-by-step recommendation on how to put the fuselage sides
and bottom together. The last 15 pages are builders hints. In addition
there is a color photograph of Bernard, and the manual is personalized to
the purchaser and signed by Don Pietenpol. It is worth it just from the
history it contains.
Al Swanson
>contained in it.
>Thanks,
>Ted
Subject: | RE: It's a girl! |
A hearty Congratulations! All our best to your family....
Steve Eldredge
IT Services
> Richard DeCosta
> Sent: Saturday, August 28, 1999 8:30 PM
> Richard
Congratulations Richard!
Now when do we get to see pictures???
Love the name....
Belinda (Lindy) Pietenpol DeCosta just doesn't sound right.....
Greg Yotz
Date: Saturday, August 28, 1999 9:08 PM
>Richard
Subject: | Partially Built Piet |
Just wanted to ask everyone's opinion.
I looked at a partially completed Piet yesterday that I'm thinking about
buying.
The wings are complete but not covered, three piece. Fuselage is
complete except final control cabling and instruments, long design.
Engine mount for a Lyc is complete and test hung. 65 HP Lycoming in
'good running order', what ever that means for sure.
There is half of an engine cowl complete and a fiberglass fuel tank. It
is setting on Champ style gear with no rubber or rims.
The plane is just about ready to cover and the gentlemen who built it
was an exceptional wood worker. He passed away
with congestive heart failure and his son is selling.
Ok, now for the questions.
What should I look at specifically, if anything for safety or
correctness. All joints look good, T88 was the glue. The ribs are
better than any of mine. All the wood is Spruce and looks good as far
as grain run out and per inch. The plane was supposed to have been
inspected by the FAA once but he couldn't find any paper work or logs.
Same with the engine.
How much is the aircraft worth and how much the engine?
This will put me way ahead of my project. If I buy I think I'll keep
working on the one I've started though, even after I've finished the new
one.
Thanks everyone,
Greg Yotz
opinion.
Piet yesterday
that I'm thinking about buying.
covered, three
piece. Fuselage is complete except final control cabling and
instruments,
long design.
and test
hung. 65 HP Lycoming in 'good running order', what ever that means
for
sure.
complete and a
fiberglass fuel tank. It is setting on Champ style gear with no
rubber or
rims.
cover and the
gentlemen who built it was an exceptional wood worker. He passed
away
with
congestive heart
Ok, now for the
questions.
if anything
for safety or correctness. All joints look good, T88 was the
glue.
The ribs are better than any of mine. All the wood is Spruce and
looks
good as far as grain run out and per inch. The plane was
supposed to
have been
inspected by
the FAA once
but he couldn't find any paper work or logs. Same with the
engine.
how much the
engine?
project.
If I buy I think I'll keep working on the one I've started though, even
after
I've finished the new one.
Thanks everyone,
Greg Yotz
Point in favor, if the glue holds better than the breaking point of the
wood and is waterproff (even with the "help" of the barnish) is a good glue.
It is still possible to find Casein Glue? Will like to know if someone uses
it for any project, even is its not an airplane...
Saludos
Gary Gower
Subject: | Re: Partially Built Piet |
> Thanks everyone,
> Greg Yotz
Looking at the going price for completed Piets, Flybabies and the like,
I'd say that the airframe is worth around $4000-$5000 and the engine
another $1400-2500 USD, depending on the condition. Definitely check the
engine for compression and runout on the crank. This will give you at
least an indication as to whether it's had a prop strike. I'd say offer
him $4000-$5000 for the lot and see how it goes.
From: | "David B. Schober" <dschober(at)mail.fscwv.edu> |
My rule of thumb for any partially built homebuilt is that its value is
only marinally more than the value of the material. The engine may cause
some concern in that parts for a 65 Lycoming are getting scarce and this
engine may cost more in the long run that an equivelant 65 Continental.
Compariny it to another Piet I know of that's for sale, was flying with
a corvair until corvair died, landed in hay field and took out one wing,
all ribs built to repair wing, asking price $2500. I'd start in the
$2000 range and go from there. Things to look for are how close to plans
is the construction. Weight of components and quality of construction.
It all comes down to a willing buyer and a willing seller!
Greg Yotz wrote:
> Just wanted to ask everyone's opinion.I looked at a partially
> completed Piet yesterday that I'm thinking about buying.The wings are
> complete but not covered, three piece. Fuselage is complete except
> final control cabling and instruments, long design.Engine mount for a
> Lyc is complete and test hung. 65 HP Lycoming in 'good running
> order', what ever that means for sure.There is half of an engine cowl
> complete and a fiberglass fuel tank. It is setting on Champ style
> gear with no rubber or rims.The plane is just about ready to cover and
> the gentlemen who built it was an exceptional wood worker. He passed
> awaywith congestive heart failure and his son is selling. Ok, now for
> the questions. What should I look at specifically, if anything for
> safety or correctness. All joints look good, T88 was the glue. The
> ribs are better than any of mine. All the wood is Spruce and looks
> good as far as grain run out and per inch. The plane was supposed to
> have beeninspected by the FAA once but he couldn't find any paper work
> or logs. Same with the engine. How much is the aircraft worth and how
> much the engine? This will put me way ahead of my project. If I buy I
> think I'll keep working on the one I've started though, even after
> I've finished the new one. Thanks everyone, Greg Yotz
all ribs built to repair wing, asking price $2500. I'd start in the $2000
range and go from there. Things to look for are how close to plans is the
Greg Yotz wrote:
Just wanted
mount for a Lyc is complete and test hung. 65 HP Lycoming in 'good
running order', what ever that means for sure.There
is setting on Champ style gear with no rubber or rims.The
plane is just about ready to cover and the gentlemen who built it was an
exceptional wood worker. He passed awaywith
congestive heart failure and his son is selling.Ok,
now for the questions.What
should I look at specifically, if anything for safety or correctness.
All joints look good, T88 was the glue. The ribs are better than
any of mine. All the wood is Spruce and looks good as far as grain
run out and per inch. The plane was supposed to have beeninspected
by the FAA once but he couldn't find any paper work or logs. Same
with the engine.How much
is the aircraft worth and how much the engine?This
will put me way ahead of my project. If I buy I think I'll keep working
on the one I've started though, even after I've finished the new one.Thanks
everyone,Greg
Yotz
Head to www.aircamper.com follow the mailing list links,
Best Regards
Steve Eldredge
IT Services
> Randy Gaskins
> Sent: Monday, August 30, 1999 10:57 AM
> Subject: suscribe
Group,
I am in the process of fabricating the control system for our Piet. I
recall talking to someone at Brodhead last year about the sizes of the
control pulleys that mount on the torque tube, and remember being told
that the front pulley needs to be larger than the 2" diameter shown on
the plans because of the almost 270 degree direction change the front
elevator cable must go through from the front stick lug, over the pulley,
and to the back. (The concern is the bend redius of the cable / pulley
for such a severe direction change.) In looking at the assembled torque
tube, however, it is immediately obvious that there is not enough room
between the torque tube and the rod connecting the front and rear sticks
to install a much larger pulley without moving the connecting tube higher
on the sticks. But then I get concerned about clearance between the
connecting rod and the underside of the front seat.
Has anyone shared this concern and successfully done anything about it?
Is anyone aware of a documented rule of thumb for pulley sizes and
degrees of change of direction for a primary flight control cable?
A cursory reading of AC43-13 revealed nothing, and I certainly
would appreciate any advice.
Thanks in advance,
-Bill
Problem has been looked into, cause found. resolved. Let me know if you
still have a problem, please email direct.
Steve Eldredge
IT Services
> nle97(at)juno.com
> Sent: Wednesday, August 25, 1999 10:34 AM
> Subject: Re: mesages
> John Langston
> >Thanks,
> __________
Subject: | How heavy is too heavy?? |
Hi all,
I've been reading with great interest the posts from the past 4 days, and
learning a lot about this wonderful aircraft. But, I have a question for
y'all (from Texas!) that I was wondering about:
I weigh about 250 lbs, and that being the case, is it still advisable for me
to entertain thoughts of building a Pietenpol? I was planning on using an
A65 or even C85 for power, any advantage there?
Am I dreaming the impossible dream, or could I pull it off with all that
mass in the back? I have a Cessna Cardinal that is big and roomy, but I
really have always wanted to build a wood and fabric plane, and the
Pietenpol seemed like the right answer to me. Any hope, or am I doomed to
spam cans?
Subject: | Re: Control pulleys |
Hi Bill: I'm putting a nearly 3" pulley on mine but I 'm not that far yet.
Have a friend that has one on his and the result is a lighter touch to the
stick and less wear all around. Ryder
please delete me from the list thank you
Subject: | Re: How heavy is too heavy?? |
Hi Gary, I weigh 260 lb. an am 6'2" tall. I have no problem in flying my Piet,
except that it is very tiring for a long trip, but i have heard this also from
most of the rest of the group... Dave
Gary Meadows wrote:
> Hi all,
> spam cans?
Dave,
That is certainly good news on the weight thing. I had read a quote from
somone that was 230 lbs and it sounded like he was a little tail heavy ;-) I
was concerned about the width too, I'm a little wider than you since I'm
only about 5' 10", & 250, but we're not that different, so I think I may be
able to do this!
I ordered a book on wood aircraft, a bag of sticks, and some T-88 from
AS&S today, I'm gonna play with gluing some, and just play with it a little,
and I think I'll order the full plans set in a few days and get to work. I
always loved building R/C models, this should be even more rewarding!
By the way, after cross countries in my Cardinal, I feel a bit tired too!
About 3 hours at a stretch is about all I can handle without a break. I had
a 150 before the 177, and man after 3 hours in that thing, I felt like I
needed to go in traction! I do bet the open
cockpit is more tiring, but man what a way to go!
Randall - Thanks for sharing your information also, it's good to see that
two wide bodies can fly at the same time in the Piet. I'll bet the front
seat ingress was quite a site to behold! Maybe I'm not the only economy size
pilot out there after all! I like to think of it as "full figured" ala Jane
Russell! (Well, not exactly!)
Thanks again for the info everybody, this has really helped my decision.
I'm gonna build a 2'X 2' box to see how it feels, but I think I'll be okay.
Maybe I need to go out and sit in it for an hour or two, (making appropriate
airplane noises, with a floor fan blowing in my face), and see how stiff I
get!
Many Thanks,
Gary Meadows
GARY;
I WEIGH (AT TIMES) UP TO 240 AND HAVE FLOWN IN PIETS AT THAT WEIGHT. ALL
YOU HAVE TO DO IS MOVE THE WING BACK TO COMPENSATE. DON'T GIVE UP AS THIS IS
A VERSITILE AIRPLANE! A LITTLE PUSH BACK FROM THE DINNER TABLE HELPS TOO.
THAT WILL HINDER YOU FROM GETTING INTO YOUR OWN FRONT COCKPIT...ER...FLITE
DECK ALTO I GOT IN BOTH PITS AT 240/245 & 6'-2"...... IT IS TIGHT! I BUILT
MY SCOUT A BIT WIDER TO ACCEPT ME (245 AT THAT TIME, 225 NOW). GO FOR IT!
EARL MYERS
Date: Monday, August 30, 1999 3:49 PM
Subject: Pietenpol-List: How heavy is too heavy??
>Hi all,
me
>spam cans?
Now that I have the shop and benches set up, tools in place and a nice
pile of 5/4 lumber, when I re-saw the lumber into cap strips do I want
verticle grain or flat grain showing on the 1/2" side? I seems to me
that the verticle grain would be stronger but the flat grain certainly
bends nicer.
At least this question is one I know someone has a for sure answer.
Thnx
Ron Gipson
nice pile
verticle grain
or flat grain showing on the 1/2" side?I seems to me
that the
verticle grain would be stronger but the flat grain certainly bends
nicer.
answer.
Thnx
Ron Gipson
From: | Dror Kalish <dkalish(at)bgumail.bgu.ac.il> |
hello !
please delete me from the mailing list.
thank you.
Dror.
From: | berenshtein michael <mberen(at)ee.bgu.ac.il> |
hello !
please unsubscribe me from you mailing list.
thank you,
Michael.
Subject: | RE: How heavy is too heavy?? |
I'm 6'-2", 250 lbs., and building a "wide body" Pietenpol. The fuselage is
widened by 2". What a difference! If you would like more information, give
me a call sometime in the evening at 440-965-4677. (no computer at the
house)
Sent: Monday, August 30, 1999 3:46 PM
Hi all,
spam cans?
charsetwindows-1252">
5.5.2448.0">
I'm 6'-2, 250 lbs., and building a
wide body Pietenpol. The fuselage is widened by 2.
What a difference! If you would like more information, give me a call
house)
Hi all,
about:
there?
plane, and the
spam cans?
Get Your Private, Free Email at
HREF"http://www.hotmail.com"
TARGET"_blank">http://www.hotmail.com
Subject: | CONTROL COLUMN PULLEY P/N'S |
I am getting ready to order the materials for the control column. Does anyone
have a recommended part number for the three pulleys? I am thinking of using
a 3 inch pulley on the forward end, based on piet discussion comments from yesterday.
Many of the pulleys in the supplier catalogs AS & S say...shall not be
installed on frequently used aircraft controls to bend the cable more than 15
degrees from a straight line. Thanks, Bart
Bart D Conrad
Boeing Field Service
DC-9/MD-80/DC-10 & 737 Heavy Mtc
Phone: 713-640-5882/713-324-4192
Fax: 713-640-5891
Pager: 713-318-1625
From: | Michael D Cuy <Michael.D.Cuy(at)lerc.nasa.gov> |
Subject: | Re: CONTROL COLUMN PULLEY P/N'S |
Bart- Many guys have used the pulley sizes spec'd out on the
Piet plans with no problems......but one tip here: use galvanized cable
not stainless. The wise older IA who runs our airport told me all the brace
cables can be stainless but anything that will move or go round a pulley
should be galvanized.
Mike C.
>Glenn,
Hi Joe,
Attached is the list that I have so far. I understand someone has posted a
list to the aircamper.com web site.
Glenn
Pietenpol Wood List
Fuselage
1" x 1" x 15' 4 pieces
1" x 1" x 6' 1 piece
1" x 1" x 5' 1 piece
7/8" x 1" x 8' 2 pieces
7/8" x 1" x 6' 1 piece
3/4" x 1" x 8' 4 pieces
3/4" x 1" x 3' 1 piece
1/2" x 1" x 6' 5 pieces
5/8" x 1" x 5' 1 piece
White ash
1" x 2 =BC" x 2' 1 piece (engine support)
2" x 2 =BC" x 2' 1 piece (engine support)
=BE" x 2" x 4' 1 piece (floor struts)
Wing
1" x 4 3/4" x 14' 4 pieces
1" x 4 3/4" x 29" 2 pieces
1/2" x 3" x 7' 4 pieces
1/2" x 1 1/2" x 7' 2 pieces
3/4" x 3/4" x 5' 4 pieces
1/2" x 1/2" x 7' 4 pieces
Tail
1" x 1" x 8' 2 pieces
August 20, 1999 - August 31, 1999
Pietenpol-Archive.digest.vol-bc
