Pietenpol-Archive.digest.vol-cq
May 08, 2002 - June 04, 2002
Christian Bobka observed:
> Building ribs is a delight with aerolite. Put the pookey on the spruce
and
> I used a tooth brush for the activator and just coated the entire side of
> the gusset with a toothbrush.
Annoying as blazes, though, when you pull the staples and the gusset comes
up with them, and it suddenly dawns on you that you forgot the activator.
Someone suggested putting a little food dye in the activator so that it
leaves
visible evidence of its presence. Not a bad idea.
Do remember that the latest version of AC 43.13-1b specifically removes
FAA approval from Aerolite-type glues, owing to the deterioration of
joints in sun-baked areas.
It's getting so I don't want to use anything but resorcinol.
Owen (in sunny Florida)
From: | "Hubbard, Eugene" <ehubbard(at)titan.com> |
If you're doing the three-piece wing, don't forget the eight 2 inch x 5 foot
pieces for the root reinforcements. With the 4x8 sheet, I had almost
exactly enough for the L.E. and the root reinforcements. As it was, I had
to piece together two of the root pieces (lower surface of the center
section--used an inside doubler for strength--nobody will EVER see it...).
There wouldn't have been enough left over for gussets.
Gene
-----Original Message-----
From: Kip & Beth Gardner [mailto:kipandbeth(at)earthlink.net]
Subject: RE: Pietenpol-List: wing ribs
>Sounds pretty close to the way I did it. I'll expand on Kent's comments
>about gusset material--I got a single 2x4 sheet and ran out. I wound up
>using a lot of 1/16 inch plywood for gussets on the 1/2 x 1/2 root and tip
>braces, and to make bearing plates where bolts would otherwise be in direct
>contact with spruce members. You'll also eventually need a whole 4x8 sheet
>for the leading edge sheath unless you're using cardboard. Shipping costs
>are less of a problem if you get all of the really big stuff at the same
>time.
>Have fun!
>Gene Hubbard
>San Diego with a new motor mount!
Hi Guys,
I got 3 2x4' sheets when I bought my project. I cut each one into two 9"x4'
pieces for leading edge, and one 6" wide piece for gussets. I figure I'm
going to come up short both ways. I'll need another 9" x 4' piece for LE,
and I figure at least another 6" x 4' piece for gussets, maybe twice that.
If I were doing it from scratch, I'd go for the 4x8' piece - fewer joints
in the LE that way, and still enough for the gussets, I think.
Kip Gardner (cutting gusssets in OH; 224 down, 796 to go!)
426 Schneider St. SE
North Canton, OH 44720
(330) 494-1775
Subject: | Maybe you already knew this |
Dick and other interested Pieters,
Maybe someone out there is as unknowledgable about this airplane building as
I was/am. For instance, I called to place an order with Wicks for the Brush
and Spray I'll need for the covering of NX41CC. While talking to the lady at
Wicks my blood began to rise in degrees while thinking about that damn hazard
fee. When she told me it had jumped from 15 to 20 the 1st of the year I
exploded. She CALMLY suggested that I might like to order the stuff in
quarts. I asked what difference would that make. She again very calmly said,
there's NO HAZARD FEE when you buy it by quarts. I of course said loud and
clear, SEND IT IN QUARTS. Now I know most of you know this but by chance
there might be a loner out there that's as dumb as I.
I ordered enough Poly stuff Monday morning to take me through 3 sprays and 36
yards of 2.7 Dacron from Superlight. It was ALL on my porch this afternoon.
Now if that Fedman will get up here and do what he is to do then I can begin
to cover so my test pilot will be busy in July, I hope.
Now if EAA and AOPA will get off their ---es and start pushing the Feds for
the Sport pilot issue to be released ole Corky might just get to fly Charlie
Charlie before his kids send him to the nursing home. I'm really afraid it's
to be a big political splash at some big fly- in in August so credit can be
claimed.
Corky in La WHERE we were born and raised amoung some of the slickest
politicos
this great country has produced and it's very easy to spot those amateur
slickers.
From: | "Jeffrey Wilcox" <craigwilcox(at)peoplepc.com> |
Ray, I used Aerolite years ago to build a Taylor Titch. Great stuff! Put
some red food dye in the hardener so you KNOW you've put it on one side of
the wood. If ya don't see pink, the joint will stink!
Be sure when you mix the powder to use warm water - it mixes better. Mix it
to a bit of a thick consistency, and it will fill any gaps you may have
left. If you sand a joint, be sure to remove all dust - I usually used a
file for this reason.
Good luck and good flying!
Craig
----- Original Message -----
Subject: Pietenpol-List: GLUE
> Anyone have any comments about aerolite (spelling?) glue? Any
experiences, pros and cons, etc. I await your replies!
> Mike Hattaway
In a message dated 5/8/02 8:02:12 AM Eastern Daylight Time,
rodwooller(at)hotmail.com writes:
> One thing I have been very careful with is getting a really accurate join
> between the capstrips and braces. It takes a little more effort, but I
think
> it is worth the extra time.
One good thing about getting good accurate joint, there is more surface area
there for glue to stick to. That can't help but make a good strong joint. The
gusset should be good close fit too. Clamping pressure should not be so heavy
that all the glue runs out of the joint either ! Little glue coming out is
good sign of proper clamping though.
Ever try testing to destruction one of your ribbs ? They are STRONG if built
correctly.
-dennis the menace
From: | "Ian Holland" <iholland(at)telusplanet.net> |
Did the whole plane with Aerolite, and other than getting it across
the border into Canada, it was hassle free. Imagine two 1 kilo bags of
"white powder" and a tough Customs Officer.
Subject: | "FORD" Model "D" |
In a message dated 5/6/02 11:53:40 PM, pietenpol-list-digest(at)matronics.com
writes:
<< From: "Graham Hansen" <grhans@cable-lynx.net>
Subject: Re: Pietenpol-List: NEW "FORD" Model D! >>
I talked to Mrs Donovan this am, and she is sending me the latest info. Their
primary product is the aluminum small and big-block Chevy engines. They make
a run of Model "D' every few years. She did not know about Pietenpols. I
think that the price is going to be about the same as a rebuilt C-200. But
what a motor! Carl
This should get some interesting responses.... I have my piet project
in my basement, which during heavy rains, gets "damp".... Very heavy
rains and I see a little water in the corners on the floors. The shop
area is the driest corner of my basement and that's where the piet is.
I have a dehumidifier running constantly but I guess when I start to see
a bit of dampness or even water in the corners I get bit nervous. I
have put construction on hold until things improve but it's been pretty
rainy here this week and today was very heavy. It's supposed to rain a
bit over the next few days... So am I nervous for no reason or should I
get the project into a more regulated environment? I haven't done any
testing on the wood as far as moisture content, and I know that some
people swear by this.
Tom Brant, MPLS
From: | "rod wooller" <rodwooller(at)hotmail.com> |
Owen,
The main reason for making a close fit in the joints is so the rib doesn't
fall apart when I remove it from the jig as there are no gussets to keep
everything together.
I am probably making extra work for myself, but it's a labor of love.
Rod W.
>From: "Owen Davies" <owen5819(at)adelphia.net>
>Reply-To: pietenpol-list(at)matronics.com
>To:
>Subject: Re: Pietenpol-List: wing ribs
>Date: Wed, 8 May 2002 09:09:12 -0400
>join
>think
>Depends on your criteria. Precise workmanship is always satisfying,
>and you seem to be making an extra effort in one area so as to reduce
>the time spent in another. They would do that just as efficiently if you
>lopped the
>ends off square and left big, triangular gaps between them and the
>upper and lower capstrips.
>Owen Davies
05/09/2002 07:54:58 AM
Sounds like it is time to add a sump pump. The dryer you can keep the air
the better. But you work with what you have.
From: | "Greg Cardinal" <gcardinal(at)startribune.com> |
The joys of Minnesota weather....
I wouldn't be too concerned about this Tom. Store wood and steel where air can
circulate and keep it off the floor and away from walls.
Humidity doesn't bother T-88 at all.
Greg Cardinal, Minneapolis
>>> tmbrant(at)uswest.net 05/08/02 11:44PM >>>
Tom Brant, MPLS
From: | Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov> |
Tom---I'm with Greg Cardinal on this issue. I built 90% of my plane in
the exact same
kind of basement. (house from 1927) I just kept the wood off the floor,
nice and level with
blocks under the shipping crate. Kept the heat up in winter, kept the
dehumidifier going
in the summer sometimes. No biggie. I'll bet the outdoor barn where
Pietenpol built his
planes had some pretty good fluctuations in humidity levels. With the
wonderful glues we
have and good wood sources-----just have fun building and keep the common
sense level up.
Mike C.
Understood. It's why I bothered to fit the uprights and diagonals so
carefully, even though I was putting the gussets on in the jig and
I know the extra effort doesn't give any practical benefit. Enjoy.
Owen
Subject: | Re: BPA publication |
Pieters
Can someone give me the adress I need to contact to renew my Broadhead Piet
Assn. Newsletter-Magazine
thanks - Henry Williams
I started out with the intention of using Aerolite,
but wasn't happy with the result. So, I switched to
T-88. I think my dissatisfaction with Aerolite was
more about me than the product, but T-88 sure is easy
to work with. My Aerolite still sits on a shelf in my
closet. Need some?
Mark Boynton
Gilbert, AZ
> glue? Any experiences, pros and cons, etc. I await
> your replies!
> Mike Hattaway
> Forum -
> Contributions of
> any other form
> latest messages.
> other List members.
> http://www.matronics.com/subscription
> http://www.matronics.com/photoshare
> http://www.matronics.com/search
Doug,
Water vapor is heavier than air so you need to put the dehumidifier on the
floor for maximum effectiveness.
Chris Bobka
Nice and dry in my now drain tiled basement with two sump baskets on the
south side of Minneaplois
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Michael D
Cuy
Subject: Re: Pietenpol-List: damp shop
the exact same
nice and level with
dehumidifier going
Pietenpol built his
wonderful glues we
sense level up.
Mike C.
Subject: | Re: "FORD" Model "D" |
Is there a Web page, to see some photos?
Saludos
Gary Gower
> writes:
> about Pietenpols. I
> what a motor! Carl
>Someone on the list ( I can't remember who ) glued up his ribs in
> the jig
> and then carefully removed them before fixing on the gussets. The
> gussets
> were then just glued on both sides at once and held with clothes
> pegs.
That is what I did. I used T-88 to glue the spruce then took the rib out
of the jig and glued on the gussets. I used 1" binder clips to hold on
the gussets. No nails no staples. Not a single glue joint failed and I
was able to do two ribs a day.
Chris
Sacramento, CA
Subject: | Re: Broadhead 2002 |
Two Questions
( 1 ) What are the dates for the Broadhead convention this year?
( 2 ) I'm trying to remember the names of the motel/hotels nearby I think in
Monroe
Anyone know the name of 1 or 2
thanks
Henry Williams ( about to try TIG welder for the first time )
From: | "Richard Navratril" <horzpool(at)goldengate.net> |
Henry
Keep at it with the TIG. I have been taking a welding class doing aluminum
TIG. It takes a bit of adjustment but you will get it.
Dick
Subject: Pietenpol-List: Re: Broadhead 2002
> Two Questions
in
> Monroe
> thanks
I have my piet in a basement as well. I read in I think "Hoadley's" book on
wood, a great resource,
about a simple device to monitor the changes in humidity of the wood.
1-cut a small block of the wood you are concerned about to about 1"x2"x 3"
or whatever is close.
2- heat it in an oven to about 200 degrees weighing it occasionally until
the drop in weight levels off. This should be "oven dry" no absorbed
moisture. (Don't use the micro wave!)
3-hang the block on a first class lever made of coat hanger wire. make the
fulcrum closer to the block. A cup hook screwed into the block allows it to
be easily removed. ballast the opposite end with wrapped solder wire until
the lever balances almost level the block end slightly high.
4- mount the fulcrum on a sheet of smooth plywood and mark the pointer's
position when balanced. this is the "oven dry" reference point.
5- over a period of a few days mark the change in lever position as the
block re-absorbs atmospheric moisture.
6- Weight the block and work out the change as a %. this will be the
moisture content of the wood in its current environment.
7- when ever you get worried about the storage of your wood note the lever
position and relax.
John Mc
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Christian
Bobka
Subject: RE: Pietenpol-List: damp shop
Doug,
Chris Bobka
Cuy
the exact same
nice and level with
dehumidifier going
Pietenpol built his
wonderful glues we
sense level up.
Mike C.
Pieters,
Is there such a thing as liabity coverage for a Piet? If any of you have it I
would appreciate the name and number of a company. I have covered a little
elevator and rudder, charged the brakes and will call my test pilot today to
execute some naked taxiing. The steerable scott should be enough to control
it
Corky in La still waiting to hear from the Fedman. ( Two weeks, no letter, no
phone call)
Chris
Was there any problem with the gussets slipping when you first squeezed them
on?
Also, how did you keep the rib flat when it had binder clips all over?
Ken
> > the jig
> > gussets
> > pegs.
> Chris
> Sacramento, CA
From: | "Gary McNeel, Jr." <gmcneel(at)mykitplane.com> |
Subject: | OT - But aircraft related |
I am building a small half-scale plane for my son and his friends to play
in. Goes with the playhouse/fort.
It is similar in box construction to the Piet (and half the other DIY planes
built out there, but I think I will build an Eindecker for him). I am stuck
on what to cover it with. I want to use a fabric, but don't want to spend
the money for the real thing, just want the look. Will use house paint to
cover it paint wise.
Any thoughts on alternatives, etc? TIA
Oh, calling it the McNeel and Son Kid's Plane for now, until it takes more
form. Got one side done.
Gary P. McNeel, Jr.
MyKitPlane.com
EAA 665957
http://www.mykitplane.com/Planes/buildLogReport.cfm?PlaneID=43
http://www.mykitplane.com/Planes/planeDetail.cfm?PlaneID=68
"What's the hurry? Are you afraid I won't come back?"
Manfred von Richthofen, 'The Red Baron,' last recorded words, in reply to
a request for an autograph as he was climbing into the cockpit of his plane.
From: | "Wayne McIntosh" <mcintosh3017(at)insightbb.com> |
Corky,
I have liability insurance on my homebuilt ultralight through AVEMCO
Insurance. 1 800 276 5207 www.avemco.com My coverage is limited to
$100,000.00 Per accident and $50,000.00 property damage and $50,000.00
personal injury. That is not as much coverage as I would like but it was all
they would sell me. They also had hull insurance but I did not check into
it. The premium is $225.00 per year, it was more last year but I am on my
3rd year with them and I have not had any claims. Be sure you tell them
everything truthfully because if you do not they will not pay your claim.
For example they know my ultralight is too heavy to be legal and they know
that it's stall speed is 3MPH faster than allowed. I am sure they will
insure your Piet if you are qualified to fly it. If you want them to cover
your test pilot you will have to tell them. They seem to be reasonable
people.
Wayne McIntosh Lafayette, IN
Subject: Pietenpol-List: Insurance
> Pieters,
it I
to
control
> it
no
> phone call)
Subject: | Re: OT - But aircraft related |
In the same edition of the Flying & Glider manual as the Piet are the plans
for a "penguin," a flightless bird that nontheless has all of the same
parts. I have always wanted to build one for kids (and adults) to learn to
fly in without leaving the ground (these were used in WWI for just that
purpose). Looks a lot like a Piet, if you are not too far along, you might
think of one. As for fabric, I don't see why regular cotton bedsheet
wouldn't work. As long as it is cotton, it would shrink with a coat of
dope, then use your house paint.
Gene
Subject: Pietenpol-List: OT - But aircraft related
planes
stuck
> Regards,
> Gary P. McNeel, Jr.
> MyKitPlane.com
> EAA 665957
plane.
Dick
I wish I was taking a class, but I'll see if I can get it - I did a little at
Oshkosh and Ive lots of metal to pratice on
Henry
All this talk about wing ribs has kept nagging me about what I did. Or, rather
what I didn't do. I didn't scuff the mahogany plywood with sandpaper before
cutting it up into gussets. Will this be a problem for me? Almost half the ribs
are done now. Please comment.
Kent Hallsten
Thanks Gene and others who replied directly to me. I was debating the cotton
bed sheet, but it seemed so flimsy. And I wanted to stay away from dope
which seems pretty flammable for it being a kids play toy. Maybe not that
big a deal, just scares me a bit.
Also, Gene, I got the idea from the Penguin. Have the book in the garage for
reference. Using Gorilla glue to hold it together. That is some tough stuff
and dries faster than T-88. A bit cheaper too. I have the one side done and
am cutting all the pieces for the other side and will glue it up tomorrow.
It is a hoot to build. I don't want it to be automotive or anything like
that, just a play toy for my son and his friends. The Penguin may make the
list of things to build though. I am constructing this rather heavy so that
it is stable in the yard and tough. I will post pics as I go on
www.mykitplane.com under manufacturer of McNeel and Son.
-Gary
> From: owner-pietenpol-list-server(at)matronics.com
> [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Gene
> Rambo
> Sent: Friday, May 10, 2002 9:28 PM
> Subject: Re: Pietenpol-List: OT - But aircraft related
> the plans
> to learn to
> you might
> Gene
> From: Gary McNeel, Jr. <gmcneel(at)mykitplane.com>
> To: Pietenpol Group
> friends to play
> planes
> stuck
> want to spend
> house paint to
> takes more
> > Regards,
> > Gary P. McNeel, Jr.
> > MyKitPlane.com
> > EAA 665957
> in reply to
> plane.
From: | "Warren D. Shoun" <wbnb(at)earthlink.net> |
Gary,
Check with your local ladies fabric shop for white poly for medical
uniforms....or your local fiberglass supply shop for "deck cloth"...a light weight
fine weave glass cloth.
~Cheers,
~Warren.
Kent Hallsten wrote:
> I didn't scuff the mahogany plywood with sandpaper before cutting it up
Not likely. The scuffing is needed more for birch plywood than for
mahogany.
Mahogany doesn't seem to "glaze" the way birch does. Couldn't hurt to scuff
the rest of your gussets, but the ones you have should do fine.
Owen Davies
Subject: | Naked Inspection |
Pieters both interested and disinterested,
In todays mail I received a letter from the Fedman. Due to the lack of funds
he will NOT be able to come to Shreveport for the proposed naked inspection
and has instructed me to proceed toward completion of the aircraft at which
time he will inspect same. Praise the LORD from whom all blessings flow. Just
goes to show you that if you will be nice sometimes something good will
surely happen. Why only yesterday I wrote AOPA a letter of apology, since I
had been on their case pretty strong, after reading their position on the
Sport Pilot issue. I'm beginning to realize that I might even be wrong once
or twice in my short lifetime.
I will begin bringing NX41CC to my home shop from Lucein Airport this
afternoon and begin covering the feathers tonight or tomorrow. As I have
said, I don't plan to make this covering business a long drawn out process.
If things go you just might see Charlie Charlie at Benton in October.
Corky in La NOT waiting for the Fedman anymore.
From: | "walter evans" <wbeevans(at)worldnet.att.net> |
Subject: | Re: Naked Inspection |
Corky,
Great news! Must be like a big weight is lifted. On to bigger and better.
Just remember about the covering process,,,It's the most intimidating, but
the most rewarding of all the processes. When you're covering your first
piece, and you look at the fabric all baggy and loose. Then you hit it with
the iron at 250 deg. And you're amazed. It's a cool process, no matter
what kind of final finish you put on , even if it's 8 coats of hand rubbed
Gumbo.
And to think you were going to give this all up.
Keep plugging!
walt
NX140DL
Subject: Pietenpol-List: Naked Inspection
funds
inspection
which
Just
I
once
process.
There is a Super 8 in Monroe.
The Super 8 # is 800 800 80000.
Dale
Ken,
I thought about the difficulty in gluing gussets to both sides at once, so I
set up the rib on a couple of soup cans and glued the gussets on one side at
a time using small spring clamps to hold them.
Rod W.
Subject: | wing rib drawings |
Hi,
There are differences between my photo copied full scale rib and
the wing rib print. My photo copy is over a year old and it may have
distorted during the last year. My instinct is to go with the print but
I wanted to make sure that there are no errors on the print before I
proceed with building my jigs. My wife is planning on making the ribs
and if she makes them in inaccurate jigs (which I will be making) and
they have to be destroyed I think that my plane building days will be
over.
Any advice would be greatly appreciated.
Thanks Again
Norm and Adrienne Decou
No, not much slipping around. Just make sure as you clamp them you hold
the gusset in place and get the binder clip to squeeze in the right
direction (it will make sense when you try it). I only did one side at a
time. Never thought of doing both sides at once. Make sure you use
latex or some other type of glove when playing with epoxy. A box of 100
cost me 10 bucks.
Chris
Sacramento, CA
writes:
> Chris
> squeezed them
> on?
> over?
> Thanks
> Ken
> From: <catdesigns(at)juno.com>
> To:
> in
> > > the jig
> The
> > > gussets
> clothes
> > > pegs.
> rib out
> hold on
> and I
> > Chris
> > Sacramento, CA
I don't think it is a problem at all. My test pieces that I have broken
have all had great penetration into the mahogany plywood. Scuffing, I
think, applies to birch plywood because of its harder and smother
surface. Mahogany is a open pore wood species and therefor you should
get very good glue should penetrate as is. I read somewhere that
scuffing may weaken the plywood because you are decreasing the material
thickness of the outer ply. Try making a test piece and break it to prove
the glue joint is satisfactory with out scuffing. I think you will be
happy with it. Now the open pores will give you grief if you try to put
a glass smooth finish on mahogany. You have to use special wood fillers
to fill in the pores.
Chris
Sacramento, CA
writes:
> Or, rather what I didn't do. I didn't scuff the mahogany plywood
> with sandpaper before cutting it up into gussets. Will this be a
> problem for me? Almost half the ribs are done now. Please
> comment.
> Kent Hallsten
> messages.
Subject: | Re: wing rib drawings |
and the wing rib print. My photo copy is over a year old and it may
have distorted during the last year. My instinct is to go with the
print
but I wanted to make sure that there are no errors on the print before
I proceed with building my jigs
Norm, this is the same problem allot of people have noticed. I am
starting to wonder if BHP changed something without telling anyone. I
elected to redraw the wing rib per the plans. However I have heard of
people who just use the full size drawing as is. It's up to you I guess.
I did not use the full size drawing because the spacing of the spars was
not the correct dimension and I think the rib was to long. It did not
take me very long to plot out the points and connect them with a curved
line. I use a spruce strip and bent it in the best-fit-line to all the
dots and called it good. After I screwed that one up (tried to glue to
to my jig with Elmers glue, can you say wet soggy warped piece of paper)
the second one only took me about 30 minutes to draw. Glued it down with
spray on contact cement. Then covered it with Plexiglas and used
Plexiglas blocks to build the jig. T-88 does not like to stick to
Plexiglas. Worked great.
Chris
Sacramento, CA
"Martin Vandenbroek"
Martin,
I contend that as the water seeps through the floors and walls, it
evaporates. Evaporation consumes heat and therefore the body of air with
the vapor in it is colder than the air that does not have the vapor in it.
So you different temperatures.
All I know is that two friends of mine have identical reasonably sealed up
hangars here in Mn. One has his dehumidifier on the wall about six feet up
and the other has it on the floor. The one on the floor gets emptied two
times a day. the one on wall gets emptied maybe once day.
I also read somewhere that the dehumidifiers should go in the lowest spot.
chris
From: Martin Vandenbroek [mailto:mav(at)ece.ucsb.edu]
Subject: water vapor
Hello Chris. I am a GN-1 owner lurking on the Matronics list. I
enjoy keeping up with all the banter. I always thought water vapour
was lighter than air if temps are the same. Until dew point is
reached the water vapor tends to rise through static air. Also high
pressure areas are almost always drier and low pressure indicates
moisture.
From: | "Kevin Holcomb" <ksholcomb(at)mindspring.com> |
This is the same issue I have been dealing with. Here is what I have found
so far.
First, paper is not dimensionally stable. The aircraft companies that I
have worked for use vellum or mylar for prints instead. Paper does have the
advantage that it is cheap. Also, photo copy machines and especially fax
machines are not to be trusted. One trick that I have learned is to put a
box or circle of a known size on the the print (in an otherwise empty
corner) before copying. Later, when you want to use the print you can check
the dimensions of your box and thus have confidence in it.
As for the airfoil. The first thing I noticed is that it is dimensioned in
a rather unconventional manner, so be very careful when plotting it out.
Beyond that, I have noted differences between the Pietenpol airfoil printed
with the Air Camper plans in the 32 manual and the airfoil printed with the
sky scout plans in the 33 manual. This is interesting because according to
the 33 manual the Sky Scout airfoil is the same as the Air Camper airfoil.
There are two differences: 1. The 6.0 width dimension which the text in the
32 manual says should be 6.125 is back to 6.0 in the 33 manual (the 6.0
appears to give a better curve), 2. the dimensions at the trailing edge are
slightly different in the 33 manual (in this case the 32 manual appears to
give a better curve.) Like everything else in homebuilding there are some
decisions that you will to make for yourself.
Out of curiosity I have been playing with the airfoil in XFOIL (a great
piece of 2d CFD software) in the hopes of figuring out how good the airfoil
is/was. There are still a few more things I want to try in hopes of getting
a more accurate solution, but so far it looks like the airfoil is an ok slow
speed airfoil. Not suprising it has good lift, but not so good drag
numbers. It also seems to have a very low pitching moment when compared
with other airfoils. When I get numbers in which I have confidence I will
probably post them on my web page.
Best of luck with your project,
Kevin Holcomb
http://www.angelfire.com/va2/aerodrome/
Subject: Re: Pietenpol-List: wing rib drawings
> print
> Chris
> Sacramento, CA
I lofted my jig from the plan dimensional specifications. I found that
when compared to this, that paper plans had warped. You could say that
the paper plans had the less camber and the trailing edge was higher.
Jim Markle and I compared ribs the other day and if I remember
correctly, we found that his trailing edge, built from the paper plan
was 3/8" higher than mine.
Variances like this are pretty common, don't worry about it. Jim and I
have decided that he's building the "speed wing" and I'm building the
"Stol" version.
These worries come up everywhere, I like to call it H&H time, for head
scratching and hand wringing.
But I'll bet that we won't see squat for difference when finished and
also that most Piets for the last 70 years have been built off the paper
plan.
Larry
(Turtledeck finished, working on seats)
>so far.
when I make wing ribs, I redraw the rib, using the dimensions given, right
onto the wood that I use for the base of the jig. You can use two 2 foot
straight edges for the chordline, sliding them against one another to keep
the line straight. that is important. I convert all the dimensions from
fractional to decimal and then use a short six inch rule that is calibrated
in hundredths of an inch, and a drafting square to keep the plotting point
proper in relation to the chordline and accurate in dimension.
Make sure you use some wood that has been around a while so it is
Just put the blocks to hold the capstrips and such at the plotting points
along the top and bottom. Make these blocks 1/16 inch less in hieght than
the capstrip is wide so you tend not to glue to them. Use a piece of wood
that will be the same dimensions as your spars for where the spars are to
go.
I often wonder why anyone would go through the trouble and worry about using
a paper pattern glued to the wood base? Transferring the dta from drawing
to the wood allows you to become one with the airfoil and measuring
discrepencies as we know exist, will jump right out at you.
chris Bobka
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Larry
Neal
"Stol" version.
plan.
Larry
>so far.
Kevin,
Send us the data you discover.
Chris
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Kevin
Holcomb
so far.
Kevin Holcomb
> print
> Chris
> Sacramento, CA
Air foils are fairly forgiving for small errors. The important thing is the
fastening to the spar is good and every rib have the same smooth profile.
The you get a good structure and a smooth consistent airfoil. Some go so
far as to make a router jig so that every rib is machined to be identical.
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Subject: RE: Pietenpol-List: wing rib drawings
go.
chris Bobka
Neal
"Stol" version.
plan.
Larry
>so far.
I built a router jig for my ribs. To keep the ribs the same airfoil was one
reason, but the primary reason was to keep the leading edge stick straight
between ribs.
I was finding that it was very difficult to keep the leading edge notch in
the same location on each rib (remember, mine is a GN-1 rib which is a piet
airfoil with different spar locations)
I have seen framed up wings where the leading edge stick is pretty wavy when
you look down from one end. While it doesn't end up mattering when covered
with aluminum or wood leading edge, it's something that would have bothered
me so I made the jig. Every wib is now within 1/64" of each other and it
takes virtually no more time to do them that way.
pics of my jig are here
http://www.imagedv.com/aircamper/log/image-pages/02-04-02.htm
DJ Vegh
Mesa, AZ
GN-1/Piet hybrid
www.raptoronline.com <http://www.raptoronline.com>
N74DV
Who has the "pietpilot" id on ebay?
Chris Bobka
From: | "Jack Phillips" <jackphillips(at)earthlink.net> |
Once I had made all my ribs, I slipped them on a couple of pieces af scrap
spar material and gang sanded them, first on a belt sander, and then finish
sanded them with a long sanding block until they were all identical. Took a
total of less than an hour.
Jack
I plotted mine directly onto the jig base. I found that the paper
pattern was 5/8" to long. I then plotted the thing out from both
the 1932 and 33 manuals into a little program called RCAD, a
model airplane design program. I realized that I could use the
fuselage side view and plot the rib out as a "fuselage" then
download the thing onto 8 1/2X 11" sheets and tape them
together lining up the built in index's. It came out well but I
only used it as a study and comparison with the hand plot on
the board. Lots of fun and it made me understand the lines
more thoroughly. The old measure twice and cut once thing.
The board itself is a piece of 1" thick K3 board, same as flooring
underlay, doesn't warp or change dimensions at all.
One thing about the rib-you'll notice on both the plans and
in the 1933 manual that the last diagonal brace goes from the
TOP behind the rear spar down to the BOTTOM at the last
upright. It is opposite to this in the 1932 man. Bernard
changed it after finding it broken in previous wings.
I have some pics of this jig at mykitplanes if it will help at all.
Chris,
This might be Dave Anderson from Fridley, MN. He has an Air Camper based
at Anoka.
He used that ID a couple of years ago. Don't know for sure if that is him
now.
Greg Cardinal
>>> bobka(at)charter.net 05/12/02 04:54PM >>>
Chris Bobka
t
Norm,
I wouldn't be too concerned about changes in the photocopy. I just glued
the copy to the base of my jig and attached blocks and cams to hold the
uprights as shown in an old BPA newsletter.
Since we are all guessing at the dimensions of the leading edge slope and
radius, slight discrepencies in the airfoil are of no consequence.
>>> normdecou(at)sympatico.ca 05/11/02 11:23PM >>>
Hi,
over.
Thanks Again
t
It is common practice to scuff birch plywood prior to glueing. The hot
press during munufacturing tends to seal the surface.
I did some shear tests on birch ply gussets using Aerolite glue. Some were
scuffed, others were left un-scuffed.
In EVERY test sample the manufacturers glue joint failed, not the aerolite
joint.
My recommendation is to scuff if you want to. If you haven't, don't worry
about it.
>>> catdesigns(at)juno.com 05/12/02 12:30AM >>>
Chris
Sacramento, CA
writes:
> comment.
> Kent Hallsten
> messages.
t
Actually there is a concern. because mine was 3/4
inches off on the spacing of the spars, and an inch
off on the entire cord width. I solved my dilemma by
buying a set from charlie rubech.
Del
--- Greg Cardinal wrote:
> Cardinal"
> Norm,
> no consequence.
> Hi,
> full scale rib and
> old and it may have
> the print before I
> on making the ribs
> will be making) and
> over.
> Thanks Again
> t
> Forum -
> Contributions of
> any other form
> latest messages.
> other List members.
http://launch.yahoo.com
Do you have contact information for him?
Also, is that for 3/4" or 1" spar?
-Gary
---------- Original Message ----------------------------------
Date: Mon, 13 May 2002 07:37:49 -0700 (PDT)
>Del
I dont think that that little diference (caused by
copier or paper humidity) will affect the Piet's
performance...
There are more significant variations in other process
in the wing fabrication to worry about...
Just with the normal diference in the wings airfoil
caused by the heat shrinking betwen to ribs makes the
airfoil diferent in that point of the cloth.
Just build the best way you can, and decide if you
want the airplane for you to fly in it safetly, or to
win wormanship prices in the flyins... 15 years from
today or later, when it is finished :-) :-)
Saludos
Gary Gower
> You could say that
> edge was higher.
> I remember
> from the paper plan
> about it. Jim and I
> I'm building the
> "Stol" version.
> H&H time, for head
> when finished and
> built off the paper
> plan.
> Larry
> Holcomb"
> >so far.
From: | Kent Hallsten <KHallsten(at)governair.com> |
Subject: | My First Flight !! |
Subject: Pietenpol-List: My First Flight !!
YEEE HAAAWWW !!!! Sorry....I just had to get that out...
I shall remember this day for the rest of my life !! This evening, 5/4/02,
at 7:40pm, I took off for my first flight in NX770CG. YEEEE HAAAWWW !!
Chuck Gantzer
NX770CG
YEEEEEEEEE HAAAAAAAWWWW !!!!!!!!!!!!!!!!!!!!!!!
Hey Chuck,
How's everything going with your Piet? Do you have any more stuff
to post about your flights? Inquiring minds want to know!
Kent Hallsten
Hi Guys,
I have noticed that some builders make the ribs as per the full size drawing
and others plot to the plans. One difference being is that the large plan
shows only one side of the spar brace and the plans show both. I presume
that only one side is fitted at the time of rib construction to enable an
easier fit of the ribs to the spars. Is this the case?
Peter.
My take on it was that the spar brace is there only for ease of assembly.
The wedges on top of the spar give compression strength and there is plenty
of glue surface to hold the spar to the rib once the wing is assembled. The
F&G Manual plans don't show it on either side. I built my wing with the spar
brace on one side only, and clamped that to the spar during assembly.
Gene Hubbard
San Diego
Subject: Pietenpol-List: wing rib drawings
Hi Guys,
Peter.
Uhhh--Water vapor is lighter than air--molecular weight 18, as opposed to
approx 29. That's why you get less lift out of damp air. But if the floor
is damp, it starts near the floor and diffuses away as it rises.
Gene Hubbard
From: Christian Bobka [mailto:bobka(at)charter.net]
Doug,
Chris Bobka
Cuy
the exact same
nice and level with
dehumidifier going
Pietenpol built his
wonderful glues we
sense level up.
Mike C.
Subject: | Re: My First Flight !! |
In a message dated 5/14/02 7:32:29 AM Central Daylight Time,
KHallsten(at)governair.com writes:
<< How's everything going with your Piet? Do you have any more stuff
to post about your flights? >>
I still haven't done a 2nd flight in my plane. The time between
opportunities to fly the Pietenpol seems few, and far between. The spring
storms out here are ferocious, making the grass strip inop, then the winds
come and dry it out, then the storms come back...springtime in Kansas !! It
seems the only time I'll get to fly (after the strip dries out), is the early
morning hours, when the winds are calm, or the late evenings on the weekends.
I work 2nd shift. I have been doing some cosmetic stuff...clean and
inspect, drilled out the static hole a little bigger, changed the main jet in
the Model B carb, clean and check the mag, and adjusted the leading edge of
the horizontal stab down about 3/4 turn on the turnbuckles and re-saftied
them.
Chuck Gantzer ~~ anticipation is killin' me !!
NX770CG
Wichita KS
Subject: Re: Pietenpol-List: My First Flight !!
You have my sympathy Chuck. Last night I watched Mike's video again, to fly
vicariously with him.
Kent
Subject: | Re: Lindbegh and flying his "time off"....... |
Among other comments, Kevin Holcomb said:
> Today we have fancy computers, CAD and an army of specialist. Yet it
takes
> us years to design a product. Our tools have clearly not made us any more
> efficient.
My first impulse is to point out that many of the things we design these
days
are a whole lot more complicated than the equivalent products of the 1920s,
where equivalents even existed back then.
My second thought is about a piece of stock-market software I use. The
competition is prettier--at the moment; the one I now use (and I've used
both of the most popular competitors in the past) is due for a major upgrade
of the interface in another month or two. But the one I now use is far more
versatile than the big boys, is much better thought-out in its basic
functions,
and is capable of doing simple arithmetic accurately, something neither of
the
major competitors can say. Furthermore, where their customer support is
mediocre to lousy, and their bugs and design flaws have survived for years,
this company usually fixes bugs within a day or two after customers notice
them
and more than once has added features less than a week after I asked for
them.
The competition consists of multi-million-dollar corporations; one is owned
by
Reuters, which surely ought to be able to afford the best. The company now
beating their socks off consists of one man. In a small industrial city in
Poland!
Maybe you're right after all. Something isn't working here.
Owen Davies
> software I use.
> Owen Davies
Is this software top secret or is it available to
other interested people such as myself?
Del-wisconsin
About midway through the seats today.
I finally realized that I could finish the seats before installing the
control tube/aileron horn assembly. I looked for a while like this part
would be captive under the seats for good, but you can thread it in from
the rear pit under the front seat and into position. I checked the
dimensions and I'm absolutely sure that Mr. P adjusted this to work out
properly, job Bernie!
I am making a mod to the seats though. Several struts under the seat
pans butt-join against the forward and rear members. I'm going to run a
long wood screw into these to give a metal part in shear. Just don't
like butt joints, myself.
Now I'm thinking about the fuel tank. I have a lovely big hole up
front, could probably put thirty gallons up there, but I suppose ten or
twelve will be enough as I don't have any plans to follow Corkie to his
vacation spot in Yucatan.
But what to do, should I weld it in steel, or $Pay$ someone to weld in
aluminum? Sorry, I just can't bring myself to put in a fiberglass tank.
No-way, not this airplane...
First what thickness of steel? Oh, I guess I'll need a baffle! Match
upright edges and weld down or pop rivet flat and solder? I'm now doing
H&H work over Mike's, drawings, hmm.
Larry
del magsam asked:
No secret. It was just off-topic, and I'd already
gone too far out on that limb. AmiBroker.
Go to www.amibroker.com
You can download it for free, but as you will see
there are good reasons to pay the trivial price.
You might want to check the Yahoo groups as well,
to get a feel for the product and the support. There
were four of them, last I checked.
Worth noting, AmiBroker is fairly specialized. Its
function is technical analysis and the development
of mechanical trading systems. This is not something
most investors would feel they need.
Owen Davies
Subject: | Re: Compression Spring Shocks |
Piet'ers,
I am building my landing gear like the 2nd to last original Piet, the one at
Pioneer field OSH. Am currently working on the compression spring shock,
think I have it figured out. There is a good illustration in the first
Bingelis page 255. It appears to show the hole for pin located mid way up
the slot for pin and sliding collar when the spring is at rest.
To me it seems the hole should be located at the top of the slot when the
spring is at rest so there would be no slop in the suspension, also then the
spring could 'work' the full length of the slot. Bingelis may have drawn it
this way so it would be easier to understand.
Anyway some of you guys must have experience with this type of LG or even
built one, please let me know if I am thinking on the right track or out in
left field.
Skip, looking forward to Brodhead.
Subject: | Re: Seat Stuff & Fuel Tank |
someone to weld in
a fiberglass tank.
Larry - get some .050 or so 5052-H32 aluminum and make
the tank from that. It is remarkably easy to cut and
form into what you want, leaving flanges where the
pieces join. Check with the shop doing the welding -
they may even have you pop rivet it together to make
the welding easier. Most shops will weld it up,
including the filler neck, vent, and drain fittings,
for a nominal fee. They will also pressure test it for
you - be sure to specify 3 psi or less! As they charge
by the hour, tho, do all the cutting and fitting before
you take it to them. I've done several tanks this way
and each has turned out to be everything I'd wanted.
If you want a baffle, you can pop rivet it in with
aluminum rivets - they weld right over them when they
do the whole thing
Craig
Lake Worth, FL
Bakeng Duce NX96CW
PeoplePC: It's for people. And it's just smart.
http://www.peoplepc.com
A rudder bar in the front cockpit, with pedals in the rear, does a great job of
keeping tension on the rudder cables so they don't get snagged on something.
However, it doesn't prevent a pilot under stress from standing on both pedals and
straining the rudder control system, unless it has the push rod set up that Greg
Cardinal describes.
Despite that, a lot of airplanes are rigged so that it is possible to leg-press
the
rudder horn. Does anyone have actual knowledge of rudder horn failure in a Piet
in
that situation?
Mike Hardaway (NOT Hattaway)
on 5/16/02 7:24, Greg Cardinal at gcardinal(at)startribune.com wrote:
> To the issue of rudder pedals vs. rudder bar...
> There is a Pietenpol based at Glencoe, MN built by a gentleman who
> preferred pedals instead of a bar. His solution was to install the rudder
> bar in the FRONT cockpit and rudder pedals in the rear cockpit. Half inch
> tubing with rod end bearings (instead of cables) connected the rudder bar
> with the rudder pedals.
> A very nice solution.
>>>> llneal2(at)earthlink.net 05/16/02 09:01AM >>>
> This also means that if I "stand" on the pedals, the simultaneous pull
> will put stress on the rudder horn and spar.
> Larry Neal
One other idea is to put the brake pedal on a rotating collar on the
rudder bar, but I think the cable to this would be continual problem.
Has anyone used heel brakes with the rudder bar?
Larry
Hi Larry,
I used heel brakes with the rudder bar. I went through the same questions
you are going through now, and finally decided in favor of the rudder bar.
Then I planned to use a couple of Scott heel brake master cylinders from a
J-3, but found they were too tall to fit under the rudder bar. I designed
and built separate heel brake levers to fit under the rudder bar, actuating
separate master cylinders. I haven't flown it yet, but it feels good in the
many hours of "basement flying" I've put on it so far. I can send pictures
if you are interested.
Jack
Be nice to see some pictures Jack.....
Peter.
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Jack
Phillips
Subject: RE: Pietenpol-List: Seat Stuff
Larry
Hi Larry,
Jack
Pieters,
Yes I am at this point. Question? Do/did you rib stitch on the ailerons? I
poly-tacked my fabric to the ribs on the underside where that BHP angel curve
is negative. Sure glad I did. It will make the stiching a bit easier. Also
are the elevators and rudder stitched?
Corky in La with Isabelle who has a heating iron in her hand
In a message dated 5/17/2002 7:21:51 AM Central Daylight Time, Isablcorky
writes:
> Pieters,
> curve is negative. Sure glad I did. It will make the stiching a bit easier.
> Also are the elevators and rudder stitched?
Date: Fri, 17 May 2002 08:21:51 EDT
Subject: Covering
Pieters,
Jack,
I think that does it for me, I've decided to follow your lead.
I will be installing the rudder bar with mechanical heel brakes. The
mechnical levers and cable routing will be simpler, so I don't see a
space problem.
I'd like to see your pictures as well, if you could send offline or post
on one of the usual sites.
Larry
>Larry
>Hi Larry,
>Jack
On Fri, 17 May 2002, Isablcorky(at)aol.com wrote
Also
her hand
Corky -
On a slow flyer like the Piet, with no true airfoil to
the tailfeathers, it is not generally necessary to
ribstitch the stabs, rudder, or elevator. Of course,
with isabel standing there with a hot iron in her hand,
I'd do whatever she asked me to!
Do cover the tail ribs with reinforcing tape, on the
outside ofthe fabric covering.
Craig
Lake Worth, FL
Bakeng Duce NX96CW
Corky,
Erring on the cautious side, I rib stitched everything: wings,
ailerons, tailfeathers. Although you likely could omit stitch-
ing the tail surfaces and ailerons on a Pietenpol, most light-
planes use stitching in these places.
If you rib stitch the tail surfaces, be careful to not overtighten
the stitches lest you deform (pull inward) the capstrips (on
the rudder, for example). When I recovered my Pietenpol, I
glued in some small spruce blocks between the capstrips
so they could resist this sort of thing. A trick similar to that
employed by the Wright Brothers with their wing ribs.
Graham Hansen (Pietenpol CF-AUN)
My " how to license an experimental aircraft" states 2" high
lettering for the N # for the Piet. Just wanted to make sure this is
still the case and nothing has been changed.
walt
NX140DL
I am thinking about using biscuit joiners on the white ash struts. Anyone
have a comment on the use of these things ? They are small (1/2"x1")
I have been watching Norm (TOH) use them on furniture for years....How about
airplanes?
Thanks for any advice.
George
about
> airplanes?
> George
George,
Biscuits are great I have become addicted to them for edge gluing and butt
joints.
If you are talking about the two ash cross members between the lift strut
attach points at the lower longeron, I don't think biscuits are needed,
there is a huge gusset there called the floor. Also those ash struts are
used mainly in compression.
Now the smallest size biscuit may be useful in the butt joints in the seats.
Skip, taking my Piet project for show and tell to chapter 1025 pancake
breakfast tomorrow morning.
From: | Kip & Beth Gardner <kipandbeth(at)earthlink.net> |
Subject: | Re: Fuselage struts |
>about
>> airplanes?
>> George
>George,
>joints.
George,
Normally, I think they would be a good idea, but if you are proposing what
I think you are, you would be cutting into the lower longeron. I'd be leery
of doing that myself, even though the floor does provide reinforcement as a
'super gusset', as Skip mentioned. I guess what I'm saying is that I'd be
real concerned about making cuts into any load-bearing member for the
purpose of installing biscuits.
Cheers!
Kip Gardner (STILL cutting rib gussets in 'warm & sunny OH' - NOT:)
(330) 494-1775
--- Kip & Beth Gardner
wrote:
> Gardner
> Gdascomb(at)aol.com
> white ash struts.
> >about
> >> airplanes?
> >> George
> >George,
> >joints.
> George,
> Cheers!
> sunny OH' - NOT:)
> (330) 494-1775
I have never been impressed with a bisquit joiner, the
bisquit is not very strong. they are not consistant in
thickness leaving a very sloppy fit. don't need them
in edge glueing. the glue joint is stronger than the
wood your glueing. I have a professional sharpening
service and end up modifying the cutters width to fit
the bisquits many times. whenever I need a spline
joint I put a saw cut in it and have some thin
hardwood laying around for the spline. I agree with
the last post, that it is not a good place to use it.
and not needed.
Del
Subject: | What are you building? |
Pieters,
For some time I have been following the list an enjoyed it very much.
Sometimes questions are asked about some of the construction details or
problems have come up which need answers.
On a number of occasions I have felt that I could be helpful but then
upon reflection, have decided not to answer any of the inquires because
I don't know what plans are being referred to. Is the plane that is
being built a GN-1, or is it a Pietenpol? And if it is a Pietenpol, is
it from the plans published in the Flying and Glider Manual, or the 1933
plans, or the long or short version, and what engine is going to be
used, etc?
I might suggest that if we had this information from the builder, it
would cut down on a lot of the confusion and make answering these
questions easier and more accurate because the person answering has
probably been through the same thing, building the same configuration.
"Pietenpol" has become almost a generic term for any parasol design, and
each individual makes little changes that he feels might make it better.
If we could get on the same page, it would sure be more useful for
those that follow don't you think?
Let me have your thoughts about this.
John Dilatush, NX114D "Finished the prop and run the engine up. Just
have to do the lift struts now and go make like a bird!"
Subject: | Control cable exits |
Heres one I want to throw at you, Im covering the rear fuse area and was
wondering on the best way to find the exit holes for my control cables. The
way I came up with was to set the tail up with control surfaces, run the
cables out and then mark the area of exit with tape. I then have taken
measurements for each hole. Does anyone have a better method of doing this?
Carl L. trying to eliminate fabric patching
Please visit my website at
www.megsinet.net/skycarl
Subject: | Re: What are you building? |
The problem with this is that, at least in my case, my airplane is an
interpolation of all of the Piet plans. I have a '33 plans fuselage, but I
want the spreader bar gear from the F&G Manual. There are also differences
between the F&G and '32 plans. I don't even know if we are sure how many
different plans there are out there . . . aaaaarrrrrrrgggggghhhhhh.
In short, I don't think your question can be answered that easily.
Gene
working from four different plans, picking and choosing the best parts . . .
going a little crazy
Subject: Pietenpol-List: What are you building?
> Pieters,
> used, etc?
Subject: | Re: Control cable exits |
Carl,
That's how I did it. Layed a straight edge over formers to simulate fabric
and took measurements from longerons and rear tip of fuse. but I have yet
to cut the holes thru.
walt
Subject: Pietenpol-List: Control cable exits
The
this?
The
this?
Carl,
Try and using a piece of paper before you cover and then "cut, fit and try"
until you have the exit holes right. You of course have to have your cables
temporarily installed first. Then mark carfully and measure the placement
of the paper pattern relative to the uprights and longerons. Go ahead and
cover, then place the paper in the same location has you had determined
before. Then go ahead and punch your holes. The holes can then be
reinforced with some thin leather patches with fabric holding the patches in
place, of course use plenty of glue. That's it!
Subject: | Re: Biscuit joints |
Biscuits are an excellent alternative for edge gluing, but read on. They
are supposed to be loose when fitted into the slot. The biscuit is made
of compressed wood. When used properly with a water borne glue (Elmer's
Carpenter Glue) they swell up to fill the slots--no need to grind the
cutter to make a thinner slot. I doubt that there is a good structural
application for them in aircraft, mainly because the adhesives (Epoxy,
resorcinol, plastic resin) are not compatible with the biscuit system.
Dick Hartwig
Subject: | Piets hiding in the woods |
I was towing gliders today and got called out to an off field retrieve.
Landing at a small grass strip a couple miles east of RioVista Texas, I
noticed the owner had a beautiful Starduster in his hanger. I told him
I was building too and mentioned my Piet, at which time he got excited
and waved over his friend on a tractor.
It turns out that Mark, (if I remember right) is building a Pietenpol.
Better yet, he's on the list.
Then to top off the whole deal, he casually mentions that his buddy
next door is building a Piet as well!
Larry
(In Texas, where you can't swing a dead cat without hitting a Piet
builder ;-)
Subject: | Pietenpol airfoil properties |
I have completed my examination of the Pietenpol Airfoil. I started with
the coordinates in the 1932 Flying and Glider Manual with the exception that
I used two mid chord upper surface coordinates from the 1933 manual (sky
scout) as they provided a much smoother curve. Using an engineers scale
and a pair of dividers I took my best guess on the leading edge based on the
curve shown in the 1932 manual. Then I keyed the points into the computer
and used several lofting features in unigraphics to get a best fit through
the points. By allowing the software to move the points around by up to
1/32 I was able to get a much smoother curve. As the dimensions shown were
only to the nearest 1/32 some smoothing was required. From there I
normalized the airfoil (divided the x and y by the chord length) and created
a number of additional points on the curve to provide better definition for
XFOIL (the airfoil analysis package that I used.) XFOIL is interactive
program for the development/analysis of airfoils developed by Mark Drela at
MIT (thanks Mark). Best of all it is freeware
(http://raphael.mit.edu/xfoil/). XFOIL can provide both viscous and
inviscid solutions.
Based on this analysis I can say that the Pietenpol airfoil isnt bad, but
its not great either. It has good lift characteristics, however it is a
high drag airfoil. Here is a sumary of my results:
At Reynolds number 1,600,000 (35 mph, Sea Level, 60 inch chord):
2 deg angle of attack: Cl=.8087, Cm=-.0929, Cd=.00691, L/D=116.96
4 deg angle of attack: Cl=1.0248, Cm=-.0939, Cd=.00881, L/D=116.35
10 deg angle of attack: Cl=1.4898, Cm=-.0702, Cd=.02173, L/D=68.56
12 deg angle of attack: Cl=1.5361, Cm=-.0578, Cd=.03447, L/D=44.56
At Reynolds number 3,500,000 (75 mph, Sea Level, 60 inch chord)
2 deg angle of attack: Cl=.8177, Cm=-.0949, Cd=.00790, L/D=103.54
4 deg angle of attack: Cl=1.0357, Cm=-.0960, Cd=.00753, L/D=137.57
10 deg angle of attack: Cl=1.5665, Cm=-.0813, Cd=.01685, L/D=92.95
12 deg angle of attack: Cl=1.6723, Cm=-.0697, Cd=.02303, L/D=72.62
For comparison I ran a few modern airfoils also using XFOIL and divided the
pietenpol numbers by the modern airfoil numbers. Here is a summary of those
results:
Piet/NACA4412 at Re=1,600,000, angle of attack=12 deg (i.e. take off /
landing performace) : Cl= 97% (higher than 100% means pietenpol airfoil
provides more lift), Cm=84% (higher than 100% means pietenpol airfoil has a
higher pitching moment which is generally considered bad), Cd=170% (higher
than 100% means the pietenpol airfoil is higher drag, high is bad.)
NACA 4412, Re=3,500,000, angle of attack=2 deg (cruise performance):
Cl=116%, Cm=90%, Cd=144%.
NACA 2412, Re=1,600,000, angle of attack = 12 deg: Cl=106%, Cm=177%,
Cd=196%.
NACA 2412, Re=3,500,000, angle of attack = 2 deg: Cl=175%, Cm=179%, Cd=156%
NACA 23012, Re=1,600,000, angle of attack = 12 deg: Cl=108%, Cm=932%,
Cd=243%.
NACA 23012, Re=3,500,000, angle of attack = 2 deg, Cl=234%, Cm=999%,
Cd=141%.
Bottom line is that it is easy to see why this airfoil is not in use on
current production airplanes. That said, it does in general provide above
average lift. The Cm is high, but is within that of the NACA 4412 which is
a well accepted low speed airfoil. Cd is very high; however, if speed is
what you desire, you probably are not building a Pietenpol. For further
study I would like to repeat the process with the Clark Y and the Eiffel 36
to better understand how this airfoil compares with other contemporary
airfoils.
Just for grins I used the Clmax computed by XFOIL to predict stall speed and
came up with 43 mph at 1010 lbs and just barely under 45 mph at 1080 lbs.
Actual numbers may be slightly worse than these as they are based on 2
dimensional airfoils. These numbers are just within the 45 mph limit in the
Sport Pilot NPRM. These numbers are probably good enough for rough order of
magnitude calculations, however beyond that they should not be taken as
anything more than an educated guess. Also, as with everything else, your
milage will vary.
Kevin Holcomb
> Kevin,
> Chris
From: | "Robert Haines" <robertsjunk(at)hotmail.com> |
Subject: | Re: Pietenpol airfoil properties |
Kevin,
Are you suggesting alternatives to the traditional Piet airfoil(s)?
Robert Haines
Du Quoin, Illinois
From: | "Michael Brusilow" <mb-albany(at)worldnet.att.net> |
Kevin's erudite & precise analysis of the Piet airfoil is much
appreciated. It confirms what we have known for over 60 years. The Piet
is a low & slow airplane.
Mike B Piet N687MB ( Mr Sam )
All,
Just a reminder of the fly-in at Midway airport in Midlothian Texas,
Saturday June 1st.
We now have a Midway-sponsored pancake breakfast beginning at 8:00am
($5), along with a hotdog lunch (Free for all Piet builders). Most of
the heavy stuff and homebuilts will be concentrated in the morning
timeframe, so show up early. After lunch, we will have a Piet
discussion in the hanger if we can find room.
So far we expect a sampling of Piet's or two and GN-1's, along with
many other homebuilts and classics. The Confederate Airforce is making
a concerted effort to show up with R 4-D, B-25 and maybe, just maybe a
Corsair, but no promises. So far though, the only builder/owner that
has committed to arrive is Mike King. You guys are making us nervous,
anyone with a flying Piet in range of Midway, let us know and come on down.
Regardless, this thing has pretty much gotten out of hand and is growing
on it's own, totally out of control. It should be lots of fun right up
until the riot police arrive.
I have name badges for Piet builders, so we can finally meet one
another, I'll be wearing a black baseball cap with "TSA 1992" on it, so
look me up and we'll start making introductions!
Larry
Nope. I can't imagine building a Pietenpol with anyone elses airfoil. That
said, it does suggest that there is room for a new plane along the same
lines as a Pietenpol. Perhaps a future project; I seem to have no trouble
finding intersting projects for the future. For now I have a large enough
project just deciding between the various options in the existing plans.
Long fuselage or short? Steel tube or wood? Change the wing ribs to 1/4 x
1/4 instead of the 1/2 x 1/4? Fir or Spruce? Tail wheel or skid? Darn, if
I add a steerable tailwheel I need brakes, and the rudder horn probably
needs to be moved to the bottom. Speaking of brakes, should they be toe,
heel or actuated by a lever on the stick? Jury struts or heavier struts?
Should I add a door to the forward cockpit? At the Pietenpol flyin last
Sunday (Arthur Dunn Airpark), my old lady saw that other builders put them
in and is being most persistant in her demands for a door (that is one thing
it would have been better if she hadn't seen.) Should I raise the turtle
deck to allow for the shoulder harness ancors to be above my shoulders? And
most of all, model A or A-65. Worst of all is if I went with a model A I
would probably want to relocate the radiator (howabout beneath the fuselage
like on several OX-5 airplanes with a header tank in the wing leading edge)
as it is darn hot most of the year here in Florida. Anyway, those questions
right now are my own personal hell. I settled on the Piet because it has 2
seats, is a reasonable first project and has the look and feel of an
antique. That said, I want to make it as close to prints as possible, but
which prints? The tail wheel is very tempting as there are so few grass
strip destinations but the cascading design changes are enough to drive me
to drink.
I ran the numbers for my own understanding. What is interesting is it does
explain how the Pietenpol gets away with a fairly small wing (140 sq ft) for
a two seater. The drag numbers are not quite as bad if you compare the Piet
at 0 deg (Cl=.6) to the other airfoils at the same Cl value (the 23012 would
need to be at a bit over 4 deg angle of attack). However, the Piet is still
a high drag airplane even if you look at it from that point of view. At
best it has 25% more drag than you would expect from a modern airfoil. As
drag is a product of velocity squared and the Pietenpol has so little
velocity, I am not sure it matters. I'll keep it close to the plans and be
prepared to descend rapidly when the engine fails. Although the high drag
will preclude much of a glide, the high lift will allow you to use smaller
fields should you have to. I cant imagine trying to use the airplane for
serious transportation (serious recreation is more my speed.) I suppose you
could clean it up, replace the cables with streamline wires, use internal
pushrods instead of external wires, change the airfoil, fair everything in
sight and pick up a bit of speed. Thats more of a project than I want, and
I cant help but wonder 'why bother'? If thats what I wanted I suppose I
would build a Bakeing Duce.
Best Regards,
Kevin Holcomb
Subject: Re: Pietenpol-List: Pietenpol airfoil properties
> Kevin,
> Robert Haines
> Du Quoin, Illinois
>antique.
>Best Regards,
>Kevin Holcomb
Kevin,
I have an old copy of KitPlanes that has a picture of a Piet with the
radiator up front, like on a Model A (the car). The prop shaft goes through
the radiator.
This makes a lot of sense to me, the radiator gets the maximum flow of
cooling air, is vertical (proprerly oriented to airflow) & probably
wouldn't need a header. Always wondered why more 'A' builders dont do it
this way.
Cheers!
Kip Gardner (got my wing rib jig plotted & drawn out last night)
426 Schneider St. SE
North Canton, OH 44720
(330) 494-1775
Kip Gardner pointed out:
through
> the radiator.
There have been Piets as well in which the radiator was mounted under the
engine, tilted to minimize the vertical size, with air ducted through it and
exiting the bottom of the cowl. The radiator itself was half as high as
usual
and with two layers. Can't remember whether the water ran through them
in parallel or in series. I believe The Master himself built one such, but
you've already seen what my memory is like. No idea whether it worked
well enough, or whether the improved visibility was useful enough, to
justify going to all the work.
Owen Davies
Kevin,
Excellent analysis. I need to reread.
Did you mean knots at the end when referencing sport pilot?
Chris
-----Original Message-----
Holcomb
Subject: Pietenpol-List: Pietenpol airfoil properties
inviscid solutions.
results:
Cd=196%.
Cd=243%.
Cd=141%.
airfoils.
milage will vary.
Kevin Holcomb
> Kevin,
> Chris
Subject: | fuselage stiffeners |
Hey guys, on the original Piet plans the forward top-of-the-fuselage
stiffener is 7" wide and the rear is 6". On the newer, extended fuselage
plans, these are reversed. Why? Is it to allow a little more room for
instruments for the rear cockpit?
Jeff in TX working with wood
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
Thanks, I did it for myself, however I am glad that others are interested.
Please let me know if you find any errors as there is much that I can learn.
I meant 39 knots/45 mph. I believe that is the requirement for stall speed
in the landing configuration. Folks with flaps also have to worry about 45
knots/52 mph which applies to the cruise configuration, but thats not a
Pietenpol problem. Are these numbers incorrect? I must admit I didnt go to
the source (the actuall NPRM) when I grabbed those numbers, I pulled them
out of an EAA publication.
Kevin
Subject: RE: Pietenpol-List: Pietenpol airfoil properties
> Kevin,
> Chris
> Holcomb
that
the
were
created
for
at
> inviscid solutions.
the
those
> results:
a
> Cd=196%.
Cd=156%
> Cd=243%.
> Cd=141%.
is
36
> airfoils.
and
the
of
> milage will vary.
> Kevin Holcomb
> From: "Christian Bobka" <bobka(at)charter.net>
> To:
> > Kevin,
> > Chris
We have been waiting for someone to do this a long time. can you compare it
to a Munk M-6 in addition to the clark Y? Also maybe the USA 35B used on
the J-3 cub?
Holcomb
Kevin
> Kevin,
> Chris
> Holcomb
that
the
were
created
for
at
> inviscid solutions.
the
those
> results:
a
> Cd=196%.
Cd=156%
> Cd=243%.
> Cd=141%.
is
36
> airfoils.
and
the
of
> milage will vary.
> Kevin Holcomb
> To:
> > Kevin,
> > Chris
Kevin,
Your numbers are close. Sport Pilot NPRM says
Vso at 39 kts max (landing config with flaps down etc)
Vs1 at 44 kts max (clean)
I think the actual piet numbers are quite below this.
chris
Hi group
After to take a training on St. Louis MO, i had time
to visit Creeve airport , there was friendly man that
is building a Piet and have too a beautifull biplane,
so a good museum with about 45 old planes, great
visit.
About the Piet, i change the rudder bar with two
smallest bars joined by an "T" arm with pedals whit
three pivot points so the arm for the peddals ever is
90 degrees with the longitudinal axe, i use standard
aluminium pedal and brakes, about the weight is 700
grs. This bars not send pressure to the rudder , this
is just experimental, but this fill god. Let my try
a little draw of this..
***** pedals
pivot point
|||||| | T arm
small bars
T arm ||=============||
If you put the pedals directly on the rudder bar, the
pedal turn and maybe you have a toe pain, other you
can't use cylinders brakes on the rear side so pedals
with "I" support for the front side, joined with 3/8
4130 tubbing, i have all for brakes on the front, but
because the planes like a Piet (with tail wheel)are
brake sensitive , i let the front side whitout brakes,
i know, whit my poor english this is hard to
understand, if someone is interesting on the pedals i
can e-mail directly some pictures of this so some cad
drawings ..
Saludos
Javier Cruz
While I have no hard data on the stalling speed of the Pietenpol,
it seems that each of the four different Pietenpols I have flown
stalled at considerably less than 45 mph. Over the years, I have
had many opportunities to test my Pietenpol's landing speed
against that of other lightplanes.
Back in the 1970's, I was able to compare its touchdown speed
to that of my 65 hp.Taylorcraft BC12D and this was noticeably
less than that of the T'Craft under the same conditons. How much,
I cannot say, but it was less than the 38 - 40 mph stalling/landing
speed of the T'Craft. I didn't compare ASI readings at the stall be-
cause they were unreliable (position error, etc.). Only three-point,
engine at idle, landings were made.
Later on I owned a Luscombe 8E with a stated power-off stalling
speed of 48 mph. Its touchdown speed was dramatically higher
than that of my Pietenpol. My son had a rag wing Luscombe 8A,
but it too landed somewhat faster than my Piet.
At present I have a 65hp. Wag-A-Bond reproduction of a Piper
PA 17 Vagabond which is pretty much stock. The advertised
stalling speed of the PA 17 is 45 mph. Again, its touchdown
speed is dramatically higher than that of my Piet under the same
conditions of loading, etc.
So my conclusion is that a Pietenpol should easily meet the 45
mph stalling speed requirement. Of course, if a Piet is too heavy
its stalling speed could crowd that 45 mph figure.
This analysis is great and finally we know how it compares with
other airfoil types. BHP was looking for a section with good lift-
ing capability and it seems he found it. He needed lots of lift on
low power and speed wasn't a priority. Locally we have a saying
that Pietenpols have a "hull speed", like that of a boat, and they
cannot be forced to go much faster. Besides the obvious parasite
drag, the airfoil analysis shows why this is so.
Subject: | Re: rudder pedals |
05/21/2002 07:51:56 AM
Hi Javier: Please send me photos of this at: John_Duprey(at)vmed.org
javier cruz (at)matronics.com on 05/21/2002 12:55:50 AM
Please respond to pietenpol-list(at)matronics.com
Sent by: owner-pietenpol-list-server(at)matronics.com
cc:
Subject: Pietenpol-List: rudder pedals
Hi group
visit.
***** pedals
pivot point
|||||| | T arm
small bars
drawings ..
Saludos
Javier Cruz
Subject: | Re: Pietenpol-List Digest: 12 Msgs - 05/20/02 |
If you are comparing airfoils to the Piet, remember that the Piet is
reflexed and if you compare the pitching moment the Piets is very low. If
you change this, you have to compensate by changing something else such as
the area of the tail surface and so on and so on and so on . . . . . . . .
Javier,
I'd like to see the pictures too. Thanks. My e-mail
is markb(at)ci.gilbert.az.us.
Mark Boynton
> Thanks
> John
> Sent by:
> To: pietenpol-list(at)matronics.com
> cc:
> Hi group
> that
> biplane,
> visit.
> is
> this
> try
> ***** pedals
> pivot point
> |||||| | T arm
> small bars
> the
> pedals
> but
> brakes,
> i
> cad
> drawings ..
> Saludos
> Javier Cruz
> Forum -
> Contributions of
> any other form
> latest messages.
> other List members.
> http://www.matronics.com/subscription
> http://www.matronics.com/photoshare
> http://www.matronics.com/search
Yes, thats in there. You will note that the Pietenpol airfoil has a higher
pitching moment than either the NACA 2412 or the NACA 23012. It has a
slightly lower pitching moment than the NACA 4412.
Subject: Pietenpol-List: Re: Pietenpol-List Digest: 12 Msgs - 05/20/02
Subject: | Re: fuselage stiffeners |
Subject: Pietenpol-List: fuselage stiffeners
Jeff,
I have read where the longer fuselage version was done in order to provide
more room in the rear cockpit and used with the Corvair engine.. I would
guess that the wider crosspiece is the result of this change. Puzzled me
too.
Pieters,
Would someone in the know please give me the identity of the Regulation that
allows the use of X in lieu of the EXPERIMENTAL on aircraft numbers.
Corky in La trying to get as much covering done BEFORE our usual humility
settles in.
From: | "Greg Cardinal" <gcardinal(at)startribune.com> |
Corky,
It is in FAR 45.22(b)
Do a Google search on "FAR" and search from there.
Greg Cardinal
>>> Isablcorky(at)aol.com 05/22/02 08:32AM >>>
Pieters,
that
humility
settles in.
t
Corky,
It is section 45.
45.22 says that you can use an x after the n if you are registering an
experimental. then 45.23 (b) says that if you use only an N on an
experimental (without the X) then you MUST put the word EXPERIMENTAL in 2
inch letters near the cabin or cockpit entrance. SO, it you use NX, then
you don't need the 2" experimental.
chris
Subject: Pietenpol-List: FAA Reg
Pieters,
settles in.
Chris,
What are the dimensions and locations for the big numbers on the wing
panels if we want to look authentic?
Greg Cardinal
>>> bobka(at)charter.net 05/22/02 09:07AM >>>
Corky,
It is section 45.
chris
Pieters,
that
settles in.
t
From: | "vickie and steve" <vic_bs(at)bellsouth.net> |
Subject: | center section strut lengths on gn1 aircamper |
what is the best center to center measurements for the front and rear
center struts on the gn1 version of the aircamper. Should the back ones
be longer than the front or vice versa.
Well, I didn't have any trouble remembering how to braze, in fact this
is fun!
I put together my control tube a couple of weeks back and last night
made up the elevator bell crank. It was easier than it looks, I wish
I'd started on this end of things sooner.
One question though, my brazing rod leaves a glass-like slag that's a
bear to get off afterwards. Does anyone have any tips on how to remove it?
Larry
Subject: | Re: center section strut lengths on gn1 aircamper |
Tonight I can measure my second GN-1 which has the cabane struts on it. Not
sure of the dimensions but I know they were done to plans.
On my other GN 1 I plan on making them 2" longer to raise the wing
DJ
Subject: Pietenpol-List: center section strut lengths on gn1 aircamper
Subject: | J-3 struts on ebay |
Hi all,
thought some of you may wish to know that there is a pair of J-3 struts
(front & rear) on ebay right now. may be a good chance to get a set of
struts for super cheap!
I have my struts already but I know some of you still need them
here's the link
http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&item=1830386890&r=0
&t=0
DJ Vegh
OK, let's get this one straight...
Below see the regs, in their entirety, but first, the discussion.
How is all this interpreted?
Every GADO and FSDO that I've ever worked with say this:
Even if you DO have the "NX" number displayed, you STILL must have the 2"
"EXPERIMENTAL" on display where it is visible to each occupant entering the
aircraft.
Why? Several reasons, probably, but I imagine it comes down to these. "Gonna
fly it in a movie?" or "It isn't an OLD airplane, you just built it" (Yep,
it IS the same "external configuration" as Bernies originals, but they don't
care) or else it's classic CYA... you may know more about this particular
reg than the FAA rep that shows up to sign off your airplane.... but,
legally, his is the final word.
Remember, the 2" EXPERIMENTAL doesn't have to be on the OUTSIDE of the
airplane... just visible to anyone that enters the airplane.
Also, in any 2 seat airplane, like a Piet, remember that you have to have
the "Passenger Warning" placard installed where it is in clear view of any
passenger.
A couple of quick tips...
Go ahead and put the "EXPERIMENTAL" sign, somewhere, where it's visible....
it'll save an almost certain delay when the Friendly FAA Fellow shows up to
Never tell the Friendly FAA Fellow that he's wrong, or you'll have a lengthy
delay before the first flight.
If you're absolutely certain that the Friendly FAA Fellow is wrong....
DON'T go over his head to his supervisor at the station, or, even worse, to
Washington... or you'll probably be converting the Piet into a doghouse.
Remember, when in doubt, be conservative.... and.... the Feds usually win.
Ric Ryburn
Technical Research/Maintenance Support Specialist/Aircraft Maintenance
Technician
Piedmont-Hawthorne Aviation
Norfolk, VA
The regs follow:
Here is ALL of 45.22
45.22 Exhibition, antique, and other aircraft: Special rules.
(a) When display of aircraft nationality and registration marks in
accordance with 45.21 and 45.23 through 45.33 would be inconsistent with
exhibition of that aircraft, a U.S.-registered aircraft may be operated
without displaying those marks anywhere on the aircraft if:
(1) It is operated for the purpose of exhibition, including a motion picture
or television production, or an airshow;
(2) Except for practice and test fights necessary for exhibition purposes,
it is operated only at the location of the exhibition, between the
exhibition locations, and between those locations and the base of operations
of the aircraft; and
(3) For each flight in the United States:
(i) It is operated with the prior approval of the Flight Standards District
Office, in the case of a flight within the lateral boundaries of the surface
areas of Class B, Class C, Class D, or Class E airspace designated for the
takeoff airport, or within 4.4 nautical miles of that airport if it is
within Class G airspace; or
(ii) It is operated under a flight plan filed under either 91.153 or
91.169 of this chapter describing the marks it displays, in the case of any
other flight.
(b) A small U.S.-registered aircraft built at least 30 years ago or a
U.S.-registered aircraft for which an experimental certificate has been
issued under 21.191(d) or 21.191(g) for operation as an exhibition
aircraft or as an amateur-built aircraft and which has the same external
configuration as an aircraft built at least 30 years ago may be operated
without displaying marks in accordance with 45.21 and 45.23 through
45.33 if:
(1) It displays in accordance with 45.21(c) marks at least 2 inches high
on each side of the fuselage or vertical tail surface consisting of the
Roman capital letter "N" followed by:
(i) The U.S. registration number of the aircraft; or
(ii) The symbol appropriate to the airworthiness certificate of the aircraft
("C", standard; "R", restricted; "L", limited; or "X", experimental)
followed by the U.S. registration number of the aircraft; and
(2) It displays no other mark that begins with the letter "N" anywhere on
the aircraft, unless it is the same mark that is displayed under paragraph
(b)(1) of this section.
(c) No person may operate an aircraft under paragraph (a) or (b) of this
section --
(1) In an ADIZ or DEWIZ described in Part 99 of this chapter unless it
temporarily bears marks in accordance with 45.21 and 45.23 through
45.33;
(2) In a foreign country unless that country consents to that operation; or
(3) In any operation conducted under Part 121, 133, 135, or 137 of this
chapter.
(d) If, due to the configuration of an aircraft, it is impossible for a
person to mark it in accordance with 45.21 and 45.23 through 45.33, he
may apply to the Administrator for a different marking procedure.
[Doc. No. 8093, Amdt. 45-5, 33 FR 450, Jan. 12, 1968, as amended by Amdt.
45-13, 46 FR 48603, Oct. 1, 1981; Amdt. 45-19, 54 FR 39291, Sept. 25, 1989;
Amdt. 45-18, 54 FR 34330, Aug. 18, 1989; Amdt. 45-21, 56 FR 65653, Dec. 17,
1991; Amdt. 45-22, 66 FR 21066, Apr. 27, 2001]
And now, for 45.23
45.23 Display of marks; general.
(a) Each operator of an aircraft shall display on that aircraft marks
consisting of the Roman capital letter "N" (denoting United States
registration) followed by the registration number of the aircraft. Each
suffix letter used in the marks displayed must also be a Roman capital
letter.
(b) When marks that include only the Roman capital letter "N" and the
registration number are displayed on limited or restricted category aircraft
or experimental or provisionally certificated aircraft, the operator shall
also display on that aircraft near each entrance to the cabin or cockpit, in
letters not less than 2 inches nor more than 6 inches in height, the words
"limited," "restricted," "experimental," or "provisional airworthiness," as
the case may be.
Ric,
You might think so but the reg is the reg and many an FAA has been
embarrassed by not knowing his own rules. Any EAA tech counselor like
myself knows the rules pertaining to homebuilts as well as anyone else.
Start looking for the NXs at the flyins and note the lack of the
experimental.
chris bobka
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Ric
Ryburn
Subject: RE: Pietenpol-List: FAA Reg
aircraft.
passenger.
Ric Ryburn
Technician
Norfolk, VA
The regs follow:
other flight.
45.33 if:
section --
45.33;
chapter.
And now, for 45.23
letter.
the case may be.
I thought we pounded through this a while back...if it is 4130 no brazing
allowed....
chris bobka
Neal
Subject: Pietenpol-List: Brazing
is fun!
Larry
letter.
the case may be.
Cy Galley
Editor, EAA Safety Programs
cgalley(at)qcbc.org or experimenter(at)eaa.org
Corky,
It is section 45.
chris
Pieters,
settles in.
Chris is correct. If the DAR or Corky's FedMan is in doubt, have a copy of
the reg handy. It is the final rule. I know of several who when faced with
this very situation have stated "they did not know that" and the NX, as
stated, has stood (stated has stood? where be my Englich).
-john-
> Ric,
> experimental.
> chris bobka
I hope you are not brazing 4130 .
Dale Mpls
From: | "walter evans" <wbeevans(at)worldnet.att.net> |
Larry,
Yeah, it seems that on the old steel tubing it was great. But if you're
using chromoly, the braze isn't compatible with either the chromium or
the molibdenum, I forget which.
Seems to be common knowledge out there. Thats one of the first things my
mentor told me while looking over my new plans.
one of the things that pushed me to learn Oxy-Acet. welding, and I'm glad I
did.
A few on this list are really good on the metalurgy , and posted some really
good notes on this. Check the archives.
walt
NX140DL
Subject: RE: Pietenpol-List: Brazing
> allowed....
> chris bobka
> From: owner-pietenpol-list-server(at)matronics.com
> Neal
> To: piet list
> is fun!
it?
> Larry
In a message dated 5/22/02 9:58:55 AM Pacific Daylight Time,
llneal2(at)earthlink.net writes:
> is fun!
> Larry
Larry,
Boiling water will remove the flux. Doug Bryant
Subject: | Re: J-3 struts on ebay |
Subject: Pietenpol-List: J-3 struts on ebay
> Hi all,
Pieters,
There was and AD on Cub struts a few years ago due to corrosion. Before
bidding on these, you might check this out and see if these struts comply.
I do understand, however, that one might cut the ends off and the center
that is left is still long enough for a Piet.
How are the 1/2 x 1 fuse braces aft of the rear seat orientated ?
Is the 1" vertical or horizontal? Either way looks OK to me. Thanks for any
help.
George
Chris,
I must have missed this discussion during one of my work induced
off-list comas.
Jeez, yes, I've just done up every braze in the ship with 4130, #@$%
I'll go back and search the archives, so everyone doesn't have to repeat
it to me, but I'll bet it's a metal chemical reaction and I've got to
scrap everything.
Like most of us trying to do a good job, the 4130 selection is a natural
and seems right when faced with the choice of old gas pipe or
broomsticks. I'm going to start a list of suggestions for Don P. I
think this should be close to the top.
Damn, Damn, Rats!
But thanks Chris, Dale, Walt, Doug, et al for the quick heads-up.
Larry
(Throwing tools and swearing are an important part of the homebuilding
process...)
>allowed....
>chris bobka
>Neal
>To: piet list
>is fun!
>Larry
>Ric,
>experimental.
>chris bobka
Yep, you're right... I've seen it a lot. I've also been involved in building
about a dozen homebuilts, and have worked in the industry, off and on, since
the 70s.
Yep, the reg is the reg. But the FAA employee on the scene is the
interpretation of the reg you have to worry about. Yes, you can certainly
show it to the Friendly FAA Fellow when he's there.
And he can certainly find 143 problems with your airplane that need to be
rectified before he'll hand over the AW.
Next time I'm back in my old neck of the woods, I'll take a picture of the
$25,000 planter. It took the guy 10 years to build, and started life as an
airplane.
Never got it licensed.
I work in a Part 145 repair station. Truth is, most of the people that we
deal with every day that work for the FAA are extremely friendly, helpful
and courteous. Another truth is that many in the FAA don't like homebuilts.
It's unfortunate, but true.
Fortunately, we have advocacy groups on our side. The EAA keeps the FAA
largely off of our backs, and has done wonders for helping to prevent some
very BAD policies from going into effect over the years, and has gotten some
other changed.
Unfortunately, there are also other advocacy groups, such as PAMA, the
various business aviation groups, and the airlines, that have more clout,
that don't like homebuilts, for various reasons.
Good bet is to actually talk to YOUR local FAA guys, and ask the ones who'll
be doing your inspection what THEIR take is on it. Get it in writing, and
carry it in the aircraft. That way, if you get ramp checked, you can show
that he blessed it.
The only point to my post was that it's easy to satisfy even the most
nit-picky inspector without ruining the pretty paint job. And it's real
cheap insurance.
Your mileage may vary. :)
Me, I'm putting the "Experimental" on mine.
Ric
(Currently planning TWO projects... Corby Starlet and Air Camper)
(And yes... I LIKE wooden airplanes with car engines. :)
Steve Wittman I believe Brazed the tail feathers on his tailwind. I could be
wrong so I am sending this message on to the tailwind group.
Subject: Re: Pietenpol-List: Brazing
Chris,
off-list comas.
scrap everything.
Damn, Damn, Rats!
Larry
process...)
>allowed....
>chris bobka
>Neal
>To: piet list
>is fun!
>Larry
hi,
I've thought of a similar set up....
as long as you're sending photos
thanks
mike
mpj01(at)aol.com
I think that stiffener dim is because el maestro needed room for His
vacuum tube radio!
Steve in WA
Pieters,
What size are the turnbuckles used in the control system, cross
braces, and wing drag wires. The plans call for 326SF but I couldn't find
that size listed in the Aircraft Spruce catalog. The closest I can find is
the AN 130 listed on page 135 of their latest catalog. I just want to make
sure I'm ordering the correct ones before spending a small fortune. Has
anyone found a different (read less expensive) source for these? I'm
figuring I'll need at least 20 turnbuckles. I've also been checking eBay but
haven't found any yet.
Sam Marinucci
NX115SM (reserved number)
Subject: | Plywood in SW FLA |
Does anyone know of anyone who sells 1/16" marine or aircraft plywood in SW
FL? Like Tampa or south?
Also, is 1/16 Okume going to work for the leading edge? I know it is light,
but does it have the strength? Anyone used it?
Thanks, Ted Brousseau
Naples, FL
I'm sorry if this offends anyone on this list but something needs to be
done about the obsolete contents of the Pietenpol plans if this design
is expected to live into the future, The simplicity of the Piet lures
first time builders and yet the plans call for brazing of steels which
are long since obsolete and materials which no longer exist. We have our
own people thrilled about how well their brazing skills are only to find
out they have to throw their crafts in the scrap pile myself included.
We have builders wondering what the hell a #326 turnbuckle is or a
# 1667 streamline tubing or 14 gauge hard wire. I for one am very tired
of building parts to the plans only to find from the list that they are
no good even though they are perfect according to the plans I'm working
from. I would gladly pay twice the money up front for a set of updated
plans than to keep throwing my hard fought work in the scrap pile. Very
few Piet builders have local mentors that can help them avoid the known
pitfalls of building a Piet. Why did I pay good money for obsolete
plans?. There is not one steel part on my Piet so far that I have not
made at least twice. Something needs to be done to bring the Piet plans
up to where a novice bullder can build a Pietenpol from the plans.I
have been in contact with other Piet builders and I'm not the only one
with this opinion. I really feel that it's time to put pressure on the
people who are selling the Pietenpol plans to bring them up to todays
standards. Again if this offends anyone I appologize
but I'm a first time builder and this crap gets really frustrating.
Ed G.
In a message dated 5/23/02 8:09:29 AM Central Daylight Time, cgalley(at)qcbc.org
writes:
<< Steve Wittman I believe Brazed the tail feathers on his tailwind. I could
be
wrong so I am sending this message on to the tailwind group. >>
This is correct. I got a case of builders withdrawl, and have started
building a W10. The Tailwind plans call for braizing 1 1/8" X .025"
stainless steel trailing edges to the 4130 tubing on the tail, as well as the
ailerons and flaps. The plans also specifically call out braizing the
channel, in the tail section, to the tubing. All tubing in the plans call
out 4130 steel. Everything else is welded, preferably oxy / accy weld.
Chuck Gantzer
NX770CG
Still waiting for my next sojourn in the sky.
Yes he did, one and one only.
A picture of it appears in the Sport Aviation Assoc.
magazine, issue summer 2001. Four piet articles in
this one including a very nice restoration of a 1928
piet built from a kit supplied by Bernard himself.
www.sportaviation.org . Unfortunately this issue
doesn't appear to have been uploaded as a
number of others have.
As for underslung rads, the definitive installation
is the P51. this system consists of a small inlet,
enlarging greatly inside the fuselage to slow down
the airflow through the large rad. then reducing to
a small outlet in the rear. A rad on the nose right
behind the prop suffers from prop air pulsing with
the passage of each prop blade going past it and
has to be larger because of this.
I think the plane you're refering to is Jim Malley's.
Definitely a beauty with all that burnished aluminum
and varnished wood. On his first flight he suffered
overheating and had to install a supplimentary rad
between the gear legs. The Kitplanes issue is July
1992.
> through
> > the radiator.
and
> usual
but
> Owen Davies
NOTHING needs to be "done" to the plans. You're building an old airplane
from old plans......it's cool.
I'm a first-time builder without a "mentor". I have used my wits, common
sense, skills learned from other hobbies and the "obsolete" plans have not been
an obstacle. They have been part of the journey and education (which is one of
the stated goals of homebuilding).
I now have a nice Piet and yes, some piles of parts that didn't quite fit. Boy,
did I learn a lot, and I'm better for it. I submit that those who aren't willing
to do some research and be prepared to wrestle with their own shortcomings
should pick another project........or maybe find another outlet for their leisure
time and discretionary money instead of building an airplane.
The Piet plans are fine! Do a little digging to find out their peculiarities and
nuances and you will be rewarded with a sense of tradition and feel closer to
your plane and the group when it's finished. If you want everything tied up
in a neat and perfect package, homebuilding ain't for you whether you are building
a Piet or any other plane from plans.
My vote is to revel in the tradition of the entire experience and leave the plans
alone. If you have trouble deciphering some things, you're on the site to get
ALL your questions answered (and more, sometimes) right here.
Just hang in there, It'll all come together and be a beautiful thing, you'll see.
Larry
--- "Ed G." wrote:
> flyboy_120(at)webtv.net (Ed G.)
> of the Piet lures
> longer exist.
I was also dissapointed when I first got the plans,
and I agree to a point that it could be better if some
things where updated in the plans. but I overcame it
by making it a part of the experience to subscribe to
this list, read every book I could get my hands on,
and go look at every piet I could. I love to learn and
I've learned tons from people like Michael Cuy(order
his tape, its invaluable) and others on this list. you
can make the plane using the same materials that
bernard did, they are still in everyday use, and you
can braze them. but the nice part is that the you can
substitute todays aircraft materials and excepted
methods and have a safer plane then what bernard had.
In the end I have had a positive experience with those
old plans. and have not scrapped one part yet, because
I went and got the whole learning experience rather
than just looked at the plans.
hang in there
Del
Subject: | Fw: re brazed tubes on Tailwinds. |
As promised!
Subject: re brazed tubes on Tailwinds.
Cy,
I saw your message on the Tailwind news site and did not see anyone
respond, so after looking at my W10 drawings, the only brazing is done where
light metal channel is brazed to the u shaped stainless steel trailing edge
on the rudder, the elevators, and I believe on the ailerons. Steve always
said that the powers that be don't like to see the brazing used, but if you
do not use very much heat, the quality of the metals don't change.. Also
trying to weld thin steel U channel to stainless or even to 4130 is
extremely difficult
Safe flights,
Jack Steele
Tailwind W8 C-FSNY
Subject: Pietenpol-List: Turnbuckles
> Pieters,
but
> Sam Marinucci
Sam,
I also was unable to correlate the size turnbuckles called for in the plans,
rather simply decided to look at the cable sizes required and then find
turnbuckles and fittings that were right for the size of the cables.
Instead of puchasing new turnbuckles, which as you know will cost a small
fortune, why don't you contact B&B Aircraft Supplies at (913) 884-5930, in
Kansas? They carry a lot of used stuff including turnbuckles at about half
the cost at Aircraft Spruce. You will have to specify the component parts
of what you want but you can do this by referring to the Aircraft Spruce
catalog.
Good Luck,
John Dilatush NX114D, just finishing up the lift struts
Salida, CO
From: | "Ed Grentzer" <flyboy_120(at)hotmail.com> |
Ok so I was a annoyed To hear that ANOTHER Piet builder had to scrap his
control tube because he brazed it according to the plans. Everyone says do
your homework and avoid the pitfalls.They also say stick to the plans. Well
I'll tell you what, I have read everything I can find on brazing and
chomemoly and I have found nothing in writing that states that it can't or
shouldn't be done. I even bought an aircraft welding book just for that
reason. Not a word. I borrowed a 1000+ page welding text book, nothing.Tony
Bingelis, nothing. Acceptable practices,guess what.I spoke with our Welding
instructor who used to weld jet turbines all he said is why use a high
strength steel with a weaker joint material(he did mumble something about
the chrome). So what would be so wrong with a small notation in the plans.
How much time is involved in ordering material and building a new control
tube, time that could be put towards the next step in building. My fuselage
is on it's gear and it's awesome, It has been a great and rewarding learning
experience. I still feel that if 4130 is the accepted aircraft steel of
today and it's not acceptable to braze it then the plans shouldn't show a
braze or there should be a notation. And I would also really like to know
how many Piets and other homebuilts have been flying for many years with
brazed 4130 parts in them without any problems. The stuff brazes beautifully
and the brazes I did before hearing about this on the list are as strong as
any others that I've done on mild steel. So is brazing 4130 a REAL problem
or is it someones theory that it shouldn't work. I'm not trying to be
argumentive but when someone wrote to
Larry Neal "I hope you're not brazing 4130" last week it really rang my
bell. Because he missed some E-mails he might have done something
potentially dangerous because he was following the plans.
Respectfully Ed G.
>From: "LAWRENCE WILLIAMS" <lnawms(at)msn.com>
>Reply-To: pietenpol-list(at)matronics.com
>To: "Pietenpol-List Digest Server"
>Subject: Pietenpol-List: Piet plans
>Date: Fri, 24 May 2002 07:19:02 -0400
>sense, skills learned from other hobbies and the "obsolete" plans have no>t been
an obstacle. They have been part of the journey and education (whi>ch is one
of the stated goals of homebuilding).
> I now have a nice Piet and yes, some piles of parts that didn't quite fi>t.
Boy, did I learn a lot, and I'm better for it. I submit that those who> aren't
willing to do some research and be prepared to wrestle with their> own shortcomings
should pick another project........or maybe find anothe>r outlet for
their leisure time and discretionary money instead of buildi>ng an airplane.
>The Piet plans are fine! Do a little digging to find out their peculiarit>ies
and nuances and you will be rewarded with a sense of tradition and fe>el closer
to your plane and the group when it's finished. If you want eve>rything tied
up in a neat and perfect package, homebuilding ain't for you> whether you are
building a Piet or any other plane from plans.
>My vote is to revel in the tradition of the entire experience and leave t>he plans
alone. If you have trouble deciphering some things, you're on th>e site to
get ALL your questions answered (and more, sometimes) right her>e.
>Just hang in there, It'll all come together and be a beautiful thing, you>'ll
see.
>Larry
Subject: | Re: Piet plans - AC 43.13 |
When in doubt - refer to FAA AC-43.13 manual.
DJ
----- Original Message -----
Subject: Re: Pietenpol-List: Piet plans
Well
nothing.Tony
Welding
fuselage
learning
beautifully
as
> Respectfully Ed G.
no> >t been an obstacle. They have been part of the journey and education
(whi> >ch is one of the stated goals of homebuilding).
fi> >t. Boy, did I learn a lot, and I'm better for it. I submit that those
who> > aren't willing to do some research and be prepared to wrestle with
their> > own shortcomings should pick another project........or maybe find
anothe> >r outlet for their leisure time and discretionary money instead of
buildi> >ng an airplane.
peculiarit> >ies and nuances and you will be rewarded with a sense of tradition
and
fe> >el closer to your plane and the group when it's finished. If you want
eve> >rything tied up in a neat and perfect package, homebuilding ain't for
you> > whether you are building a Piet or any other plane from plans.
t> >he plans alone. If you have trouble deciphering some things, you're on th
> >e site to get ALL your questions answered (and more, sometimes) right
her> >e.
you> >'ll see.
> >Larry
I just looked at great length. It doesn't address brazing directly. The
only thing that is said is that do not use a brass wire brush to clean welds
as included brass in a weld might cause cracks. It also says not to weld
over previously brazed joints as they will be weaker. I have a call into
EAA HG to check on this.
Subject: Re: Pietenpol-List: Piet plans - AC 43.13
DJ
Well
nothing.Tony
Welding
fuselage
learning
beautifully
as
> Respectfully Ed G.
and
her> >e.
you> >'ll see.
> >Larry
Subject: | Fw: Brazing 4130 |
This what I got from EAA.
Cy Galley
Subject: RE: Brazing 4130
Cy,
Just got off the phone with Richard Finch, and he said that it is definitely
a BAD deal to braze 4130! The stuff will crack before your eyes, he says.
On the Pietenpol, he said either build the airplane according to plans
INCLUDING using 1020 steel tube (which is plenty strong enough and much
cheaper) or don't braze if 4130 is used.
That's the story!!
Joe
Subject: | soaking capstrips |
Hi,
We are getting ready to start building ribs. While making the rib jig I
soaked some pine for 16 hrs in an ABS tube, so that it could be bent for
the outside profile of the jig. I had marginal success when I tried to
bend it in my bending jig. Before we start using our good sitka spruce
capstrips, we were hoping that someone might be able to tell us how long
they soaked their 1/2 x 1/4 capstrip. We are hoping to get a minimum
and maximum soaking time(ie soak for at least 8hrs but never longer than
2 days). Any suggestions would be greatly appreciated.
Thanks Again,
Norm and Adrienne Decou
Subject: | Re: soaking capstrips |
Norm,
I steamed mine for two hours, this worked well for me. Others soak in
hot water overnight.
Believe it or not though, you can just patiently bend them by hand and
that works too!
I questioned this and then tried it for myself, no problems. Just make
your jig sturdy enough to hold the wood in bent position and once the
glue sets, you're out of the woods.
Try cutting a test piece of capstrip and bending slowly, If you're not
happy with the results try the hot water next. If you want to steam, I
wrote up a description of building my steamer that should be searchable
in the archives.
Larry
Norm Decou wrote:
>Hi,
>Thanks Again,
From: | "Ian Holland" <iholland(at)telusplanet.net> |
Norm, I had really good luck using a 2 inch iron pipe with a plug on
the bottom and heating about 12 inches of water in the tube to boiling
for about 15 minutes. The strips bent very easy and stiffened up as
soon as they cooled. My bending jig was cut out of a 4 by 4 as per the
BPNews letter. No problems, no splitting and no rejects. I don't know
what you have planned for the ABS, but the secret appears to be hot
water. Good luck,
-=Ian=-
>Chris,
>off-list comas.
>scrap everything.
>Damn, Damn, Rats!
Larry,
Bummer! I remember the earlier discussion very well, about a year ago.
Chris posted an excerpt from Richard Finch's book that expained the reason
it won't work, so if you are inclined, I'm sure you can find it in the
archive. My condolences. My wife says that every guy has at least one
'dammit' in his toolbox, sounds like yours is getting a workout.
Kip Gardner (whose 'dammit' will probably be out sooner or later)
(330) 494-1775
I steam my western red cedar for about 20 - 30 minutes , and it goes into the bending
jig easy, with gentle pressure.
Kent Hallsten
For what it worth, I just took a 5 gallon bucket full of water and stuck 2
or 3 cap strips in it and let them soak. was doind a rib a day and when I
took one out I'd put another one in. So I guess they averaged a day or two
in the water.
No problems; let them stay in the bending form for about a day, then stuck
them in the jig. My cap strips were 1/4 x 1/2 doug fir.
I know a guy that built a Falco and he just tossed his sticks in the
swimming pool. Its not a real hi-tech deal.
Keep at it, its FUN!!
Lou Larsen
Subject: Pietenpol-List: soaking capstrips
> Hi,
> Thanks Again,
Larry, I'm not sure I agree with you. In todays times, with the
litigation-happy population we have, I wonder if a simple disclaimer by the
Pietenpol folks on the plans would be appropriate, It could basically say
that the plans are drawn and the design was based on materials and
techniques commonly available and used in 1930 and that due diligence should
be performed to insure that the methods and techniques presented should be
examined to make sure they conform with acceptable standards currently in
use. I aint no lawyer but if I continued to make 100 bucks a pop off great
granpa's 70 year old efforts, I would probably make an effort to either a)
bring this thing into the 21st century or b) make damn sure a person who
built it understood that they needed to pay REAL close attention to the
plans before they launched a project.
I think that part of the problem may be that the Piet has developed a
reputation as being the simplest of the simple and all ya gotta do is buy
some wood, glue it up and fly it. It's not really that simple - as we all
know.
Maybe you and I and others are able or willng to do years worth of research
and ferrett out all these "inadequacies" before we build three of the same
things, but some folks may not be able or willing to figure all this out.
I've been especially disappointed with grega's plans - BAD. But I've been
lucky enough to have some very experienced builders to follow around. I
guess you and I may appreciate how "cool" building from original plans is,
but I can empathize with someone who doesn't have the resources around them
to help figure all this stuff out.
So have you flown your plane any more? We need to see some pictures.
Anyway,
Best at ya.
Bert
> sense, skills learned from other hobbies and the "obsolete" plans have no> t
been an obstacle. They have been part of the journey and education (whi> ch is
> I now have a nice Piet and yes, some piles of parts that didn't quite fi> t.
should pick another project........or maybe find anothe> r outlet for
their leisure time and discretionary money instead of buildi> ng an airplane.
> The Piet plans are fine! Do a little digging to find out their peculiarit> ies
and nuances and you will be rewarded with a sense of tradition and fe> el closer
to your plane and the group when it's finished. If you want eve> rything
tied up in a neat and perfect package, homebuilding ain't for you> whether you
> My vote is to revel in the tradition of the entire experience and leave t> he
plans alone. If you have trouble deciphering some things, you're on th> e site
to get ALL your questions answered (and more, sometimes) right her> e.
> Just hang in there, It'll all come together and be a beautiful thing, you> 'll
see.
> Larry
Kip,
You're right!
I'm going to stop by Home Depot and get myself a set of standard &
metric dammits just to be ready! ;-)
Larry
Kip & Beth Gardner wrote:
>>Chris,
>>off-list comas.
>>scrap everything.
>>Damn, Damn, Rats!
>Larry,
>(330) 494-1775
Living in a high humidity area (north Florida) I had no problems bending
capstrips.
A wood's moisture content is a function of ambient relative humidity.
There's some good info available on this. Even a way to check moisture
content using a Fluke digital multi-meter. E-mail me off list and I can
send anybody a copy if you want it.
All I did was soak those things in the kiddie pool for about 30 mins. I
figure this basically moistened the outer fibers. Dried them off and stuck
em in a pre-bend jig overnight. Then put them in the jig the next day. Not
the first broken or cracked capstrip. I'm not sure this would work in
Arizona. Some of you that live in humid climates might want to at least try
it.
Have a nice holiday all. Lets remember our veterans...
Bert
Subject: Re: Pietenpol-List: soaking capstrips
> water. Good luck,
> -=Ian=-
I don't know about you guys but I prefer the simpler approach.
I soak mine in an ABS tube that is filled with water up to about 36" for
about 25 minutes. I then "hung" it from one end with a 2" spring clamp on
the other end. As it dried it sagged to the right shape. Within 1 hour it
was dry and to the perfect shape. No special jigs or steamers required.
Why fight it when you don't have to???
DJ Vegh
Mesa, AZ
GN-1/Piet hybrid
www.raptoronline.com
N74DV
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Lou
Larsen
in the water.
Lou Larsen
> Hi,
> Thanks Again,
Hi,
I soaked my cap strips for 30 minutes in hot water in a 3 foot length of ABC
and they bent very well.
Jim Boyer
NX499JB
Richard Finch, Performance Welding--
Do not braze chrome moly!
"This steel has a definite grain structure that
actualy opens up at medium-red brazing
tempuratures. When brazing alloy is melted
onto the steel surface, it flows easily into the
many small cracks and crevasses in the
chromemoly steel. Then, as the braze joint
cools, the brass will not compress and it forces
major cracks to form in the 4130 steel. Often,
a brazed 4130 steel part will crack completely
in two before your eyes as it cools.
I have this and his auto engine conversion book.
A great deal of useful info in both. I'm glad I
spent my hard earned money on them.
welds
> From: "DJ Vegh" <aircamper(at)imagedv.com>
> To:
> DJ
> From: "Ed Grentzer" <flyboy_120(at)hotmail.com>
> To:
his
do
> Well
or
> nothing.Tony
> Welding
about
plans.
control
> fuselage
> learning
a
know
> beautifully
> as
problem
> > Respectfully Ed G.
airplane
common
> no> > >t been an obstacle. They have been part of the journey and education
> (whi> > >ch is one of the stated goals of homebuilding).
> fi> > >t. Boy, did I learn a lot, and I'm better for it. I submit that those
> who> > > aren't willing to do some research and be prepared to wrestle with
> their> > > own shortcomings should pick another project........or maybe find
> anothe> > >r outlet for their leisure time and discretionary money instead of
> buildi> > >ng an airplane.
> peculiarit> > >ies and nuances and you will be rewarded with a sense of tradition
and
> fe> > >el closer to your plane and the group when it's finished. If you want
> eve> > >rything tied up in a neat and perfect package, homebuilding ain't for
> you> > > whether you are building a Piet or any other plane from plans.
> t> > >he plans alone. If you have trouble deciphering some things, you're on
th
> her> > >e.
> you> > >'ll see.
> > >Larry
Steve,
2 degrees incidence is what I have seen referred to. I think the rear
cabane is supposed to be 1" shorter than the front. Mine are equal and the
tail flys low and it won't flare well on landing.
Ted Brousseau
Naples, FL
Subject: Re: Pietenpol-List: center section strut lengths on gn1 aircamper
Not
> DJ
> From: "vickie and steve" <vic_bs(at)bellsouth.net>
> To:
From: | "Dick and Marge Gillespie" <dickmarg(at)peganet.com> |
Grega's plan page 7 calls for the rear cabane strut to be 3/4 of an inch
longer than the front.
DickG
> Steve,
the
> Ted Brousseau
> Naples, FL
> To:
> Not
> > DJ
> > To:
ones
Subject: | Re: Piet plans and Brazing |
Don't jump to conclusions about bike frames. The most common brazed steel
alloy tubing used in bike frames is Reynolds 531. Its metallurgy is very
similar to 4130 EXCEPT for the removal of chromium and addition of manganese.
In general, calling bike frame tubing "chromoly" is an adverising gimmick.
Reynolds, Columbus and Tange bike frame tubes are specifically formulated for
brazing. 4130 is specifically formulated for welding.
Mike Hardaway
catdesigns(at)juno.com wrote:
> My old Cro-Moly 10 speed bike frame is Brazed so is my friends old racing
> frame and both are doing fine after some serious abuse.
help.
George
George... the fuse braces have the 1" in the horizontal, that way you get
more gluing surface for the gussets
Jeff Hill... putting the antique boat in the water today
remember.... the GN-1 has the spars in different locations than the Piet.
Therefore, dimensions for the struts on the piet will NOT be the same as the
dimensions for the Grega.
As long as you have about 2 degrees AOI then all will be fine... whatever
the dimension may be.
DJ Vegh
Mesa, AZ
GN-1/Piet hybrid
www.raptoronline.com <http://www.raptoronline.com>
N74DV
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Dick and
Marge Gillespie
aircamper
DickG
> Steve,
the
> Ted Brousseau
> Naples, FL
> To:
> Not
> > DJ
> > To:
ones
Ted: I worked out the geometry on this when I built mine. Grega's plans
call for the rear to be longer than the front ones. I think that this may
be why the gregas seem to fly tail low (as you've told me). I built mineso
that the rear cabane strut is the same length as the front. Then I measured
the AOI with the center section in place. It comes out to about 1.6 degrees
AOI if I remember correctly. I can dig up the calcs if anybody's really
bored and wants to see them.
Bert
> Steve,
the
> Ted Brousseau
> Naples, FL
> To:
> Not
> > DJ
> > To:
ones
Pieters,
T88 as the resin in fiberglass? Have any of you tried this? Would it
make for a stronger or weaker fiberglass product?
Ken
From: | "Wayne McIntosh" <mcintosh3017(at)insightbb.com> |
Subject: | Re: T-88 vs resin |
Ken,
I used T88 as the resin when I made my laminated Ash and fiberglass
tailwheel spring. Regular epoxy resin made for structural fiberglass would
be easier and lighter. The T88 is thick and it takes twice as long to wet
the glass. The reason I used T88 was that I did not want to buy resin and
only use the 4 or 5 ounces I needed and have the rest left over. The T88
works fine but is harder to work with for use with fiberglass cloth.
Wayne McIntosh
Subject: Pietenpol-List: T-88 vs resin
> Pieters,
> Ken
Subject: | rib vetical braces |
Hi,
Thanks for all the great information on bending capstrip. I tried
very hot water for about 1/2 an hour and it seems to be working well on
the finger joint pine so I am sure that it will be effective on the
capstrip.
The plans (improved pietenpol aircamper plans) do no show vertical
braces in front of the rear spar and directly behind the front spar.
When I look at the full scale photocopy of the rib it appears to show a
vertical piece of capstrip at these locations. My instinct is to stick
with the plans as the spar and spruce wedge should take all of the load
in this area.
I thought I would ask about this as these verticals may be necessary
for attachment. I also wanted to know what the photocopy was showing in
these areas (gusset material). Any input would be greatly appreciated.
Thanks Again
Norm & Adrienne Decou
From: | Kip & Beth Gardner <kipandbeth(at)earthlink.net> |
Subject: | Re: rib vetical braces |
>Hi,
>capstrip.
>in this area.
>Thanks Again
Hi Norm,
Those verticals are probably not necessary, but are one of the things that
have 'evolved' over the years. I think the primary reason for them is to
make jigging up the ribs they
aren't really structural. They also give you a way to nail the rib to the
spars without nailing through the top of your capstrip. It has been
recommended several times on the list that you glue a small piece of spar
material (1 inch, or 3/4 inch plus 1/8 inch doublers, depending on your
spar setup)) on your jig at your front & rear locations so that you can be
sure you have enough space between the verticals to get your ribs on the
spars. I'm planning on using them & putting spar material on my jig in the
correct locations.
Cheers!
Kip Gardner
Larry -
I didn't know that you could get metric 'dammits' - do you have a source? ;).
(330) 494-1775
Norm,
I did not include the uprights, but I did screw short spar sections into
place on my rib jig.
From there, I used square gussets for the gussetting located in front
and behind the front spar in the rib, both upper and lower in the
construction to butt up against the spar sections. When I took the rib
out of the jig to glue the opposite side gussets, I used a short piece
of 1" material to locate them as well.
This way when I build the wing, these gussets will locate the rib
accurately for and aft against the spar.
Larry
(Purveyor of find Standard, Metric and Witworth Dammits. Available
separately or in sets. Call for free catalogue ;-)
>>Hi,
>>capstrip.
>>in this area.
>>Thanks Again
>Hi Norm,
>correct locations.
>Cheers!
>Kip Gardner
>Larry -
>(330) 494-1775
Pieters,
Just a little note of info or caution. I initially ordered 36 yds of fabric
to cover my Piet.
It isn't enuff. Having to order an additional 5 yds. Might help someone avoid
my error.
Corky in La just a cover'in away
Subject: | [ Skip Gadd ] : New Email List Photo Share Available! |
From: | Email List Photo Shares <pictures(at)matronics.com> |
A new Email List Photo Share is available:
Poster: Skip Gadd
Subject: Larry Williams' Pietenpol
http://www.matronics.com/photoshare/Skip.Gadd@ssa.gov.05.27.2002/index.html
o EMAIL LIST PHOTO SHARE
Share your files and photos with other List members simply by
emailing the files to:
Please view the typical Share above and include the Description Text
Fields as shown along with your submission of files and photos.
o Main Photo Share Index:
Subject: | [ Lawrence Williams ] : New Email List Photo Share Available! |
Poster: Lawrence Williams
Subject: Pietenpol
http://www.matronics.com/photoshare/lnawms@msn.com.05.27.2002/index.html
Subject: | Re: [ Lawrence Williams ] : New Email List Photo Share |
Available!
To: Email List Photo Shares
Sent: Monday, May 27, 2002 3:03 PM
Subject: Pietenpol-List: [ Lawrence Williams ] : New Email List Photo
Share Available!
Subject: Pietenpol
Nice
"Email List Photo Shares"
Subject: | Re: [ Skip Gadd ] : New Email List Photo Share Available! |
From: "Email List Photo Shares" <pictures(at)matronics.com>
Subject: Pietenpol-List: [ Skip Gadd ] : New Email List Photo Share
Available!
Great job Larry!!
walt
Piet dudes-
Don't know if the list can stand two YIPPEE, YIPPEE, YAHOO letters in the same
month but NX899LW committed aviation 27 May. Powered, sustained, controllable
flight just like Gustav Whitehead back in 1901.
It was MAGNIFICENT!! Control forces were of the "two finger" variety. Everything
held together and the landing was silky. Can't say enough good about this old
airplane with it's brazed fittings built from obsolete plans. ;-)
I haven't come fully back to earth and I'm sure I'll be replaying it over and over
until I can get back up again. Can't wait.
Larry
Subject: Pietenpol-List: NX899LW
> Piet dudes-
> Don't know if the list can stand two YIPPEE, YIPPEE, YAHOO letters in the> same
month but NX899LW committed aviation 27 May. Powered, sustained, co> ntrollable
> It was MAGNIFICENT!! Control forces were of the "two finger" variety. Ev> erything
held together and the landing was silky. Can't say enough good a> bout
this old airplane with it's brazed fittings built from obsolete plan> s. ;-)
> I haven't come fully back to earth and I'm sure I'll be replaying it over> and
over until I can get back up again. Can't wait.
> Larry
Way to go Larry!!!!!!
Maybe I'll join you shortly, taking the plane out to the airport next week
and putting together!
Salida, CO
In a message dated 5/27/02 9:19:18 PM Central Daylight Time, lnawms(at)msn.com
writes:
<< Piet dudes-
month but NX899LW committed aviation 27 May. Powered, sustained, co ntrollable
It was MAGNIFICENT!! Control forces were of the "two finger" variety. Ev erything
held together and the landing was silky. Can't say enough good a bout this
old airplane with it's brazed fittings built from obsolete plan s. ;-)
Larry >>
Congratulations Larry !! YEEEHHAAAWWW !!! What a rush !!
Chuck Gantzer
NX770CG
p.s. who in tarnation is Gustav Whitehead ?
From: | "Gary McNeel, Jr." <gmcneel(at)mykitplane.com> |
Congrats Larry. Wow! -Gary
> [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of LAWRENCE
> WILLIAMS
> Sent: Monday, May 27, 2002 9:18 PM
> To: Pietenpol-List Digest Server
> Piet dudes-
> Larry
Congratulations Larry... Great pictures...Looks great!! Sounds like she
flies sweet too. Ed G.
>Date: Mon, 27 May 2002 22:17:47 -0400
>Piet dudes-
month but NX899LW committed aviation 27 May. Powered, sustained, co>ntrollable
> It was MAGNIFICENT!! Control forces were of the "two finger" variety. Ev>erything
held together and the landing was silky. Can't say enough good a>bout this
old airplane with it's brazed fittings built from obsolete plan>s. ;-)
>Larry
In a message dated 5/27/02 7:19:18 PM Pacific Daylight Time, lnawms(at)msn.com
writes:
> Piet dudes-
held together and the landing was silky. Can't say enough good a> bout this
Larry,
I have about 300 flights on mine and every one is just as exciting as the
first. You'll see. Congratulations!!!!!! Pictures look good too. Doug
Bryant
Bert,
That sounds about right. I think the numbers on the GN-1 plans, calling for
a shorter front cabane, is probably incorrect according to your
calculations. You are still a little short of 2 degrees with equal lengths.
Knowing how mine flys I would make my rear cabane shorter next time.
Ted
mineso
measured
degrees
> Bert
> From: "Ted Brousseau" <nfn00979(at)naples.net>
> To:
> > Steve,
> the
> > Ted Brousseau
> > Naples, FL
> > To:
aircamper
it.
> > Not
> > > DJ
> > > To:
rear
> ones
Congrats Larry! Nice to see another piet flying. Good to know yellow looks
real good on these birds. I'm ready to start putting yellow and gray on mine
real soon. Try not to have too much fun. Ha Ha.
Carl L.
Please visit my website at
www.megsinet.net/skycarl
WILLIAMS
Piet dudes-
Larry
Pieter's,
I just had to commit in writing on my vacation schedule for the
American Flight Simulation shop and was un certian about the offical 2002 dates
for Broadhead. I e-mailed Gar Williams
and got a prompt reply staiting that Broadhead will be the 19th 20th and 21st of
July 2002.I told Gar I would post the dats on
the list as Grant has not updated the BPA page in a very long time and it still
shows 2001 dates only.
Gene
in St Louis
Can a Web portal forever change your life?
Win up to $25 Million on iWon - click here!
This is on my event calendar now, for easy reference. Thanks Gene.
Gang, feel free to add events, etc. to the calendar on the site. If you have
an account, and you login, you can add planes, manufacturers, events, web
sites, etc. to the site without any interaction with me. If you have ideas,
let me know and I can try to add them.
I do nothing with the names, don't even know anymore how many accounts are
on it. It is just a resource for the community, like this list.
-Gary
> genet(at)iwon.com
> Sent: Tuesday, May 28, 2002 10:53 PM
> Subject: Pietenpol-List: Broadhead 2002
> Pieter's,
> offical 2002 dates for Broadhead. I e-mailed Gar Williams
> 20th and 21st of July 2002.I told Gar I would post the dats on
> time and it still shows 2001 dates only.
> Gene
> in St Louis
Mike,
I am about to make up the covers that close the gap between the center
section of the wing and the wing panels.
I know that Frank Pavliga and his dad "laced" these covers in place, and
really thought this was the best solution for handling the undercamber
of the wing. But before I start punching holes in the covers, I thought
I would check with you and ask how you handled the problem on your
plane. Did you use the same solution? If so, what did you use for
lacing? What is the thickness of the aluminum that you used? Did you
put grommets in the holes to protect against cutting the lacing?
Or, did you come up with another solution to the problem of the
undercamber?
Your kind words of wisdom will be heard and appreciated!
Cordially,
John Dilatush, trying to make like a bird!
I used 1/8" bungee cord for lacing. Holes down the center of the gap
seal every 8" or so. I believe Mike used small blocks of wood glued to
the ribs on both sides and screws through the gap seals. The screw
route would be more work, but would do a better job, and look better. I
have had a problem with the seals puckering and making a gap at the
leading edge.
Glad to hear of your continual progress,
Steve E.
Subject: Pietenpol-List: Wing Gap Covers
Mike,
undercamber?
Cordially,
http://www.matronics.com/browselist/pietenpol-list
From: | Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov> |
>Bryant
Larry----WONDERFUL news and congratulations on your first flight
!!!! What Doug says
here is right on the money. I never tire of taking the Piet up for a
ride. You are really going
to get some good 'payback' for all the blood, sweat, and tears, and money,
and time, and.....
for your efforts now.
Mike C.
From: | "Michael Brusilow" <mb-albany(at)worldnet.att.net> |
I used .025 al strips ( wide enough to cover the gap ). The top strip
extended from the flop around the leading edge to the level of the fwd
vertical strut. Another strip extends, on the bottom, from there to the
flop.
The seals are held in place with tapered 3/16 machine screws which
fastened to right angle plastic lock nuts which in turn are screwed to
the ribs.
Larger holes than the screws require are drilled to allow location of
the lock nuts. Counter sunk washers fill the hole nicely.
The edges of the seals were slightly bent to create a spring effect when
the seals were fastened in place.
I hope I have this right. I haven't been with my friend for quite a
while. Health problems, which should be resolved soon.
Mike B Piet N687MB ( Mr Sam )
Thanks to Mike C., Steve E., and Mike B. all for your prompt replies to
my question about wing gap covers.
I think that I will take all of your advice (what's the plural?) and
avoid the lacing, instead going to a screw in type arrangement.
I really appreciate your efforts to get back to me with the answers.
This is what makes the list so valuable to builders, none of us have to
work alone.
I ordered my 8 turnbuckles to do my tail wires this morning. I'm going
to use 1/16" 7x7 cable . I only want to do this once so my question is :
Is it acceptable
to connect the cable directly to the tang fittings on the verticle
stabilizer with a nico press eye with a thimble or or does there have
to be a shackle used between the cable and the tang fitting ?? Yeah, I
know, I'm getting a little gun shy. Thanks in advance. Ed G.
From: | "Jack Phillips" <jackphillips(at)earthlink.net> |
Hi Ed,
Actually , if you make the fittings to the plans there is no room for a
shackle. I'm just running the thimbles through the fitting and building the
cables in place. I was in Cleveland over the weekend and got up with Mike
Cuy and he did the same thing. If I had it to doo over again, I would
probably make the fitting bigger (ALL the fittings!) and used shackels so
you could remove the cables for painting.
Jack
-----Original Message-----
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ed G.
Subject: Pietenpol-List: Tail wires
Is it acceptable
Ed. I'd guess that'll work fine. The only downside I can think of is you
have to remove the fitting to take it apart. But that's what I did. Just
my too sense.
Bert
> Is it acceptable
Thanks Jack. I wanted to keep it as simple as possible and just connect
them up with an eye spice. The only Piet I ever took notice of those
connections on had modified tang fittings with shackles so I wanted to
make sure there wasn't some rule I wasn't aware of. Ed
Pieters,
I keep hearing the word "shackles" in your messages, and the last time I
checked the cost of them was a little more than gold bars. May I make a
suggestion?
If you go to your friendly farm equipment dealer, you will find that he
has various sizes of drive chain (#50, #60, odd links etc. in stock).
Get a short chunk of chain, usually costing less than $3.00 per foot and
take off the outside links. Then go see the Mr. Aircraft Spruce catalog
and look up clevis pins. If you use two clevis pins thru the holes in
two links of chain - Presto! you now have a substitute for a clevis at
just a fraction of the cost. Don't worry about strength, one guy said
that his test fixture broke at 2500 lbs using this set up.
If you are lucky and the farm equipment man is in a good mood, then he
might separate the outside links for you with his magic chain splitter,
otherwise you will have to grind off the heads of the pins and punch
them out.
In my opinion, the installation looks neater than using the FAA approved
shackles and you can dazzle your friends with telling them how thrifty
(cheap) you are!
John Dilatush, NX114D Trying to figure out how to get all the parts of
the plane out to the airport without damage.
Is the Midway Fly-in still on for this weekend?? Are any Piets gonna be
there? Mark McKellar Mt. Pleasant, Tx
Subject: | Re: Midway Fly-In |
Subject: Pietenpol-List: Midway Fly-In
Mark,
The Midway fly-in and pancake breakfast is definitely on!
Will we have Piets? I'm not sure. Lot's of email, but so far the only
confirmed fly-in is a well known local guy. We'll just have to see.
Will we have airplanes? You better believe it! This is looking like a
great turnout, we will have quite a few homebuilts arriving. Get there
early, pancakes at 8:00am.
Will we have fun? Absolutely!
I'll be wearing a black baseball cap and beard. Look me up.
If the fleet does not arrive I may add hornrim glasses and a rubber
nose. ;-)
Larry
Mark,
My GN-1 is now at Aero Country near McKinney where it is
getting its annual inspection. We are trying very hard to get
it ready for the Midway Fly-In this Saturday.
It is normally based at O'Brien Airpark, just a few miles away
from Midway Airport, but had to move it north of Dallas to get
it inspected.
If ready, it will be there on the flight line. It is a white GN-1,
77MK, with a red stripe down the side. Look for a couple
of guys with big smiles on their faces.
We will be there one way or the other. Hope to see you
Saturday.
Mike King
GN-1
77MK
Dallas, Texas
With a bit of disappointed I have to say I will miss being there. That
morning is my son's very first official T-ball game. Maybe another time.
Everyone take good pics and put them where we can all see them. Sounds like
it will be a great time.
-Gary
> [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Mark
> Sent: Thursday, May 30, 2002 8:12 PM
From: | "Oscar Zuniga" <taildrags(at)hotmail.com> |
Subject: | compression spring shocks |
Skip wrote:
>Am currently working on the compression spring shock, think I have it
>figured out
>Anyway some of you guys must have experience with this type of LG or
>even built one
Well, I fall into that category. Sorry for the slow response to your post;
I'm still in catch-up mode after my move to Texas and you may have already
gotten good responses to your question! I guess I'll have to keep plodding
through my digests til I get caught up. Anyway, I have built this type of
shock strut for my M-19 "Flying Squirrel", the prototype has flown for a
couple hundred hours off of all types of surfaces in Indiana, and photos of
my setup are on my website at http://www.flysquirrel.net/gear/gear.html
specifically about halfway down (I think). After you look at the webpage
you can email me off-net with specific questions or let me know if I can get
you some more detailed photos.
Oscar Zuniga
San Antonio, TX
Subject: | Re: side by side Piet for sale on Barnstormers.com |
Hey Mike...interesting site. Followed all directions and saw various
a/c...but alas, no Pietenpol. Don Hicks
Pieters
On the tail section my plans show the tail fin to be one inch longer
(19) than the horizonal stab (18) is this right. It would appear since
the fin sits on the horizonal stab it would be the same or shorter.
Ken
Subject: | side by side Piet for sale on Barnstormers.com |
I found it. The landing gear looks really odd!
Mark Tracy
DonanClara(at)aol.com
Subject: Re: Pietenpol-List: side by side Piet for sale on
Barnstormers.com
make it 18". Same as the H-stab. One of my GN-1's is 19 per plans (and
needs to be fixed) and the other is 18. 18 is what it should be.
DJ Vegh
Mesa, AZ
GN-1/Piet hybrid
N74DV
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Ken
Maynard
Subject: Pietenpol-List: GN-1 Plans
Pieters
Ken
I went to the AF Museum in dayton a month ago and many of the antique
military types, most notably the DH-4, used the chain pieces as shackles
exactly as described....
chris bobka
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of John
Dilatush
Subject: Pietenpol-List: Tail Wires
Pieters,
suggestion?
them out.
(cheap) you are!
Are there any pictures of this? Of the shackles? I am having trouble
picturing them in use. Thanks.
-Gary
> [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Christian
> Bobka
> Sent: Friday, May 31, 2002 6:29 PM
> Subject: Pietenpol-List: chain shackles
> chris bobka
> Dilatush
> To: Pietenpol-list(at)matronics.com
> Pieters,
> suggestion?
> them out.
> (cheap) you are!
From: | "Kevin Holcomb" <ksholcomb(at)mindspring.com> |
Subject: | History Question |
I started chasing this Pietenpol project because it matches my interest in
aviation history with my desire to build an airplane. Along the way I have
found myself more and more curious about the airplanes history. I have read
bits and pieces in different places, has this ever been gathered together?
Are there any books (or historically detailed magazine articles) on the
airplanes history? I am especially interested in the Bernie Pietenpol built
(or kitted) Pietenpol's (how many, what configuaration gear on which ones,
which engines on which ones, etc.) Were there any air campers with the Sky
Scout style gears? How about alternative radiator locations?
I have been spending so much time trying to fix the configuration for my
project that I am interested in what the original configurations were.
Thanks in advance,
Kevin
http://www.angelfire.com/va2/aerodrome/
Subject: | Another History Question |
Have any of you ever heard of a
Stahlwerk Reisler R.III ??
Was designed by a couple German bros. in 1922 and bears a STRIKING
resemblance to a Piet... or should I say the Piet is similar .... hmmmm???
I just came across some images of this aircraft today.
DJ Vegh
Mesa, AZ
GN-1/Piet hybrid
N74DV
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Kevin
Holcomb
Subject: Pietenpol-List: History Question
Thanks in advance,
Kevin
Subject: | Re: chain shackles |
From: "Gary McNeel, Jr." <gmcneel(at)mykitplane.com>
Subject: RE: Pietenpol-List: chain shackles
> -Gary
Gary,
I'm sorry, but I have no pictures of these and the way these are used and
no scanner if I did. Maybe someone else on the list can help you.
original Message-----
> > Bobka
> > chris bobka
> > Dilatush
> > Pieters,
> > suggestion?
> > them out.
> > (cheap) you are!
Hi Kevin,
If you haven't read them, be sure and read the series of articles that Bob
Whittier did about the Pietenpol in EAA Experimenter a couple of years ago.
They gave a pretty complete history of the airplane, including its
predecessors. If you can't find them, let me know and I will scan them and
send them to you. Veru interesting.
Jack
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kevin
Holcomb
Thanks in advance,
Kevin
Where are the images DJ? -Gary
> [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of DJ Vegh
> Sent: Friday, May 31, 2002 8:35 PM
> Subject: Pietenpol-List: Another History Question
> .... hmmmm???
> DJ Vegh
> Mesa, AZ
> GN-1/Piet hybrid
> N74DV
> Holcomb
> way I have
> I have read
> Pietenpol built
> with the Sky
> Thanks in advance,
> Kevin
Subject: | Swirly aluminium.... |
I was wondering how some aluminium was made to have the little swirls on it
(I know it has a name, I cannot think of it).
Once, long ago, I saw how it was done, but now cannot recall it. If any of
you know the name or where there is info on doing it, I would appreciate
hearing it. Thanks.
Gary P. McNeel, Jr.
MyKitPlane.com
EAA 665957
http://www.mykitplane.com/Planes/buildLogReport.cfm?PlaneID=43
http://www.mykitplane.com/Planes/buildLogReport.cfm?PlaneID=68
"What's the hurry? Are you afraid I won't come back?"
Manfred von Richthofen, 'The Red Baron,' last recorded words, in reply to
a request for an autograph as he was climbing into the cockpit of his plane.
Subject: | Metal sales online |
I stumbled on this. Nice site, easy to use, prices seem reasonable. I have
not done business with them yet though, will give it a try.
http://www.onlinemetals.com/
Here is another, not as easy to use.
http://www.metalmart.com/
Sadly, neither seem to have 4130 flat plate.
Gary P. McNeel, Jr.
MyKitPlane.com
EAA 665957
Subject: | Re: Swirly aluminium.... |
Some call it "swirling" others "burnishing" but I seem to
remember there was a better name back when I had
my 1st car, a 56 studebaker Hawk (no fins). It had this
neat swirled dash panel.
Check out Custom Planes, Sept. 2000.
1- scale swirl size to look good on panel.
2- use those plastic foam scouring pads like Scotchbrite.
3-use a disc-anything from a half inch bolt up to
a 3" sanding disc and double sided tape, in drillpress
4-PLAN YOUR PATTERN before going at it.
5-overlap swirls 50%
6-use light touch-practice-especialy at the edges.
Check out aluminum Fokker Tripe frame in Custom
Planes Aug. 2000. obviously made by swirling dervish.
I used 1/2" bolt to do my throttle quads-pics in Mykitplane.
( Thank you Gary. your service sets the standard.)
Subject: Pietenpol-List: Swirly aluminium....
it
> hearing it. Thanks.
> Regards,
> Gary P. McNeel, Jr.
> MyKitPlane.com
> EAA 665957
plane.
check archives. "shackles&chain&motorcycles"
1st mention I got was from 96.
Subject: Re: Pietenpol-List: chain shackles
> To:
> > -Gary
> Gary,
> John
Christian
> > > Bobka
shackles
> > > chris bobka
> > > Dilatush
> > > Pieters,
I
a
> > > suggestion?
he
and
catalog
splitter,
> > > them out.
approved
> > > (cheap) you are!
of
I believe the correct term is "Engine Turning". It is the technique used on
the cowling of the Spirit of St. Louis, and is actually very easy to do. I
made a couple of inserts for my instrument panel this way:
1. First I made a grid of squares on a piece of particle board. I made
mine 1" squares, due to the size of "swirls" I wanted. I drilled a 1/8"
hole at each intersection (the corners of the squares, where they touched
the adjacent squares).
2. Then I made a base plate to support the workpiece that I wanted to
swirl. On the bottom of the base plate, I drilled two .121" holes 4" apart
and pressed in a couple of small lengths of 1/8" welding rod. I made sure
my base plate would fit anywhere on the grid board, and could be easily
picked up and repositioned.
3. I then fastened my work piece down to the base plate. Since I was
making an insert to hold instruments, I made sure I was putting the screws
in locations that would be cut out for an instrument hole. If you are
making a piece that is to be continuous, you will have to screw it down
around the edges and then trim off the area with the screw holes.
4. Then I clamped the grid board onto the work support plate of my drill
press. I made my "swirler" from an old Continental exhaust valve with a
piece of Scotchbrite superglued onto the face of the valve and trimmed to
fit.
5. I positioned the base plate with the workpiece screwed to it on the grid
board so that the swirler tool would start the pattern near one corner of
the workpiece. Then I turned the drill press on and lowered the tool onto
the aluminum until ihad burnished a swirl pattern. You don't have to press
too hard, and it only takes about one second to swirl each location. Then I
indexed the base plate one set of squares over and made another swirl. This
is continued until you reach the end of the row, then you reposition the
base plate to begin the next row. In this manner, you can easily make nice
uniform overlapping swirls. It took me severl hours to make the setup, and
then about 15 minutes to actually put the engine-turned pattern on my
instrument panel inserts.
I have pictures of my setup, and would put them on the list but every time
I've tried to do that it gets screwed up. If anyone wants to see them let
me know and I will email them to you.
By the way, Pieters, I visited Mike Cuy last weekend and finally got to see
his airplane. Beautiful job! And what a nice fellow he is. We couldn't
possibly have a better ambassador for the Pietenpol community.
Jack
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of clif
Subject: Re: Pietenpol-List: Swirly aluminium....
it
> hearing it. Thanks.
> Regards,
> Gary P. McNeel, Jr.
> MyKitPlane.com
> EAA 665957
plane.
Subject: | Re: History Question |
From: "Kevin Holcomb" <ksholcomb(at)mindspring.com>
have
read
built
Sky
> Thanks in advance,
> Kevin
Kevin,
Your interest in the history of the Pietenpol is one of the things that
enrich your construction of the plane. One just is not building and
airplane, but you are also re-creating a little part of our aviation
heritage and that lends to the experience. People have many times asked me
"what is a Pietenpol" and my answer is that I am building a "replica of a
antique airplane" -and then they understand. There have been many
variations on the original plans, all of which seem to be called
"Pietenpol", but as someone said to the effect "You can make changes and
have a good airplane, but if you follow the plans you will have a better
airplane!". I'ts really hard to improve on the original common sense
engineering of Bernie Pietenpol.
Whittier's articles in the Experimenter magazine of a few years ago is a
good source for information as well as the Buckeye Pietenpol Newsletters
that were edited by Grant McLaren if you can find them.
Forge Ahead and Good Luck!
John Dilatush, NX114D, Plane going to airport this morning for final
assembly, after 7 years in my workshop, I'm experiencing separation anxiety!
"Turned?" As in "engine turned?" Not much like what
you do with a lathe, but that sounds awfully familiar.
Owen Davies
To: Pietenpol Group
Sent: Saturday, June 01, 2002 12:55 AM
on it
any of
appreciate
hearing it. Thanks.
Gary P. McNeel, Jr.
MyKitPlane.com
EAA 66595
I believe that a circular wire brush on a hand held drill will do the
trick.
This is an ancient procedure that probably dates back to the
time when craftsmen fashioned metal shields and armor.
During the 1950's I apprenticed under an aircraft mechanic
who had been in the business since the 1920's. He called the
pattern "whirlies" and told me that, aside from being "pretty",
it is an excellent means of covering scratches and minor form-
ing marks without painting. He said its use should be restricted
to non-structural parts.
Lindbergh's Spirit of St. Louis used it on cowlings, etc. accord-
ing to the custom of that period. No doubt he was happy with it
because it didn't add any weight, as painting would have done.
It was popular in the early days of aviation and is therefore most
appropriate for Pietenpol airplanes.
Graham Hansen (Pietenpol CF-AUN)
I've only been able to find scale model replica photos but here's a couple
of the Stahlwerk Reisler R.III
http://www.imagedv.com/aircamper/stahlwerk1a.jpg
http://www.imagedv.com/aircamper/stahlwerk2a.jpg
DJ Vegh
Mesa, AZ
GN-1/Piet hybrid
N74DV
In a message dated 5/31/02 9:53:12 PM Pacific Daylight Time,
gmcneel(at)mykitplane.com writes:
> hearing it. Thanks.
> Regards,
> Gary P. McNeel, Jr.
> MyKitPlane.com
> EAA 665957
Gary,
Here's how I do the spot finish on many of my projects. This is shown on the
Spirit of St Louis movie with Jimmy Stewart for just a few seconds during the
aircraft production scenes.
I use a 1 inch diameter wire brush from Ace Hardware (only one I could
find),put the work piece on the drill press table, run the drill press
spindle at slow speed, press lightly for each spot overlapping a little less
than half of the previous spot. Continue making rows. No other tools are
needed and it is very easy. Doug Bryant
Burnishing. Just cut a scotchbrite pad and glue it to the face of a small
rotary sanding disc. The size is up to you. The swirls overlap. It is best to
do your pattern before you cut it to shape Don Hicks
Doug,
After the swirling, do you use anything as a protectorant to guard against
corrosion?
DickG. in Ft. Myers
it
of
> > hearing it. Thanks.
> > Regards,
> > Gary P. McNeel, Jr.
> > MyKitPlane.com
> > EAA 665957
> Gary,
the
the
less
I'm going to ramble a bit so be warned...
Our impromptu "Broadhead South" did happen and we had a good time.
Attending were about ten fearless Piet types and a bunch of interested
onlookers at the Midway fly-in and pancake breakfast.
I did not take notes and am notorious about names, so bear with me when
I reference folks and I'm sure that I've missed a bunch of you.
Midway was booming with traffic when I showed up. We had Stearmans, a
CAF AT-6, Stinson Reliant, couple of Beach 18's, couple of T-28's and a
whole bunch of unexpected Thorp T-18's, in fact I counted five of these
before it started drooling over all the neat hardware.
The Stearman's kept us jumping with each round motor takeoff stopping
the current conversation to take a look.
The T-28's boomed in with a synchronized landing and taxi, after which they parked
like a dance team and even coordinated their engine shutdowns - Neat!
The field was packed with tin. We had local interest and apparently a
news crew at one point, though I did not see them. There was even a
Jazz Band in the main hanger at breakfast and a bunch of local aviation
legends making an appearance including one who used to make a living
chasing Russian Bear bombers across the Bearing sea in an F-4 Phantom.
Lots of hanger talk, more hanger talk...
One interesting vignette was when Juan Martinez, Midway Airport Manager and all
around great guy, introduced one of the
lads on the line to the CAF Captain flying the T-6. There was a short
conversation, the nod of a greyed head and pretty quick Johnny was
taking his first Texan ride. I've got the pictures of him taxiing out,
you've got to see the grin!
I quickly found Jim Markle, who as always had a couple of new ribs to
show off. They are impeccable by the way, and he has marked them with
the date of build, so I just have to tease him about his rib serial
numbers and accompanying yellow tags [:-)]
Jim had a couple of young students in tow (about five or six years of
age) and was doing a great job of promoting future Piet building. We
then hunted up Mike King who had just showed up in his newly-annualed
Piet/GN-1. Mike got up at 4:30am to finish his annual to make the show
and was the hit of the Piet crowd.
Pretty quick a bunch of local builders showed up including Joe,
(damnation what's your last name again lad!) who displayed his most
excellent tail feathers in front of the FBO. After talking with Joe and
after experience with my fuselage, I agree. Build the tail and wing
first, it's too much trouble working around the fuse and you can hang
the flying stuff from the ceiling when you get to that point. Lessons
learned , sigh...
The wild bunch, Hank and his friend, also a Hank but refereed to as
"Hankie" made an appearance as well. Hank and Hankie are the guys I ran
into while towing a glider out of a field near Grandberry TX and are
building a beautiful new Piet. They brought a bunch of great building
pictures to review and we got a lot of detail out of them.
Then of course, we just had to do a photo session in front of Mike's
ship. We had a pretty good group sharing building experiences and the
gang was downtown in Piet'sville for some time. Incredibly, not only
did I meet several new Piet builders in the area, but found that my new
friend Hank is not only both a Piet builder as well as an EAA Tech
counselor living about ten miles from me. Do I have good luck or what?
I've checked the "find EAA guy" item off of my to-do list.
To top things off, Edwin showed up ferrying a wingtank for me. This was
a special trip on his way up north and with a gift from none other than
our cherished Corkmiester to help me along. Corky has decided that Erik
Lindberg has upstaged him, so he's apparently going to lay off his
transcontinental ambitions. The tank is nearly complete and equipped
with cap and drain, what a present!
I'm am really thrilled about this! I'm going to have a bit of Corkie's
Piet in my airplane, what a treat! Corky - thank you, thank you, thank
you! I will treasure my "extra ten" every time I fly. Thanks for
conning Edwin into an extra stop too, he's a great guy and I really
enjoyed getting his first hand report on your progress. Even the
natives in Texas enjoy a view of the more cultured do-in's in the more
respectable locals [;-)]
Two other pilots, Mary Lou and Phil also flew up with Edwin in his
absolutely beautiful Maule from the land of crawdads and good company.
Great folks!, the enthusiasm was like a family reunion. You should see
Edwin's Maule, but my apologies as I did not get a picture. It's
fantastic. I was absolutely amazed to hear the Edwin had recovered and
painted it himself. Looked like a factory job to me.
We got a lot of good hanger flying done and then decided to do lunch.
The charcoal would not light, so one Piet guy (didn't catch his name)
helped me to accelerate things with a bit of 100LL. With a cup of gas
and a propane torch, we ducked behind the side of the grill and reached
in with the torch, whoosh-bang! Not an approved maneuver, but we
managed to get it started quite nicely. It's amazing how great a
charred hotdog on a mashed bun tastes when you've got good company.
A bit more hanger flying and we were treated with the take off and a
fly-by of a restored Russian jet trainer. Noisy as hell but quite
impressive. Then the T-28's rolled out in a formation takeoff and
followed suit, scaring a couple of errant Cessna's out of the area.
Next the Beech's left most gracefully and we concluded business with
the "off the shelf " aircraft.
Meanwhile, Mike King and I tried to wear out the tires on the Champ.
The Champ's solo seat is up front, so Mike took the helm and without
ever being in one before, showed me how to fly it rather quickly.
Next I got a treat. Mike put me in the back seat of his ship with his
friend/ instructor / A&P Bruce up front, and I finally got a Piet
check-out....
Did I pick the right airplane? Would I be disappointed? How would the
Piet compare to the mighty Champ? Well, let's say If I wasn't already
building one, I'd consider some horse trading for a finished Piet right
now! What a dreamboat!
We taxied out and I found the tailwheel response was fantastic. Sure,
the visibility is like the back of any taildragger, but it felt
comfortable. Better yet, It felt good to be able to see and hear
everything around us. I could hear, look up and s-turn easily, the
cockpit was roomy and comfortable, but surprisingly well insulated from
the wind.. On taxi, the prop blast around the cockpit, faint smell of
gasoline and exhaust and the visible blur of the prop when I looked out
to the side was incredible. I started thinking this is a REAL AIRPLANE!
We took off with the open exhaust barking and the whir of the prop in
our ears, I left the ground without noticing actually, and it felt so
well behaved that I started wondering if it would handle or end up a
"truck". So I did a wide pattern and used the time to put in some
s-turns, wow! I can't get over the feeling when leaning over the side
and waving to people below! No dirty lexan, feel every prop blade in
the blast, check out the tops of the trees and listen to the wind in the
wires!!!
I even tried the legendary trick of putting my left hand into the
slipstream - slooow turn to the left. Right hand - instant gentle pull
to the right.
My first landing dropped it in a foot or two, but I was happy. None the
less I had a good excuse for some more tries, and the next landing was
absolutely fantastic. On Bruce and Mike's advice I carried more power
on final than I would expect (yes Virginia, them wires in the wind add
up) but otherwise Mike's ship handles like well tuned Cub or Airknocker,
which I think is a good compliment.
Well, I'm tired, sunburned and a little beat up, but what a day! Thanks
to all named and those I've neglected. By general consensus, I do
believe that we will do this again next year. I'll post the pictures in
a couple of days on one of the usual sites. Thank you all for the help
and stopping by, it was great meeting you all.
Larry
(In Texas where it's good, but don't get better than this.)
In a message dated 6/2/02 5:14:08 AM Pacific Daylight Time,
dickmarg(at)peganet.com writes:
> Doug,
> corrosion?
> DickG. in Ft. Myers
Hi Dick,
Good to hear from you. I don't use any form of corrosion protection here in
Kansas, but I suppose a clear alodine could be applied. Doug Bryant
In a message dated 06/01/2002 2:15:57 PM Central Daylight Time,
grhans@cable-lynx.net writes:
<< aside from being "pretty",
ing marks without painting. >>
The amphibion Fleetwing Seabird in the late thirties used burnishing over
most of the stainless steel hull skins to cover irregularities. Quite an
eye-catcher. Two are still flying in Calif. and Florida.
There are now some picturs online showing how Jack Phillips did it. Thanks
Jack.
http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID=45
Gary P. McNeel, Jr.
MyKitPlane.com
EAA 665957
Subject: | Selling some Piet stuff |
Gentlmen,
I am going to be selling one of my flying aicampers and the fairly complete
Scout project and a host of spares, props, magnetos, complete (moded) Model A
engines; too many planes. If you all know of anyone interested, please let
me know.
Doug Bryant
Wichita, Ks
Subject: | fleetwings seabird |
There is another fleetwings seabird (in pieces) in the northern most hangar
at brodhead. seems that the metal was swirled in sheets and then the sheets
were cut and the aircraft spotwelded together. then the overlaps were
swirled.
chris bobka
Doug,
Why the fire sale?
Chris bobka
Doug413(at)aol.com
Subject: Pietenpol-List: Selling some Piet stuff
Gentlmen,
A
me know.
Doug Bryant
Wichita, Ks
Subject: | Re: Selling some Piet stuff |
In a message dated 6/3/02 10:34:54 AM Pacific Daylight Time,
bobka(at)charter.net writes:
> Doug,
> Why the fire sale?
> Chris bobka
Bought a Cub and still have half interest in another Aircamper. Doug
Bryant
Doug...What do you have in Model A carbs/manifolds? Don Hicks
Only one model B carb, three after market B's, one or two extra manifolds, and
a complete A engine ready for installation. Doug Bryant
EVERYTHING has to be protected here in Florida. One of the prices to pay
for living in "Paradise". Couldn't a clear coat or clear lacquer or
something like that be sprayed on?
Ted B in Naples
> > Doug,
against
> > corrosion?
> > DickG. in Ft. Myers
> Hi Dick,
in
Gang-
Does anyone (Doug) have or know of a radiator that is available for an "A" Piet?
My engine seems to be running hot and all I can come up with is that my VW/Audi
radiator isn't up to the task. It was the recommended radiator in the 70's
BPANews but I am not having good results with it.
I know there was a Kapler radiator for sale at B'head last year or the year before,
does anyone remember whose it was?
Barring the above, does anyone know of a radiator building shop that is quick and
reasonable (read:cheap!)?
Still logging the hours and fixing little bugs. Looks like my time will be flown
off at the exact moment that I head for Brodhead. Amazing how that works...
Larry
From: | "Michael Conkling" <hpvs(at)southwind.net> |
Spar varnish (or equal) was used on the nose of the Spirit of St. Louis
swirls -- as a result, there is a "golden" hue to the Alum. as it sits in
NASM.
Also, the "quick & dirty" way (used by Fokker in WW1) was to just "sand" the
cowl all over with a grinder or dual action sander (no nice rows -- just
random stuff! ;-)
Mike C.
Pretty Prairie, KS
> Ted B in Naples
> From: <Doug413(at)aol.com>
> To:
> > > Doug,
> against
> > > corrosion?
> > > DickG. in Ft. Myers
> > Hi Dick,
here
> in
Doug,
Please send info about aircamper for sale...specs, etc. Any photos available?
Send to my E-mail rather than post on the list. Please send contact info for
off-list communications
mikehattaway(at)hotmail.com or 229.244.0089 after 9 pm or 2558 Winnwood Circle, Valdosta,
GA 31601.
Thanks, Mike Hattaway
Sign-up for Video Highlights of 2002 FIFA World Cup
From: | "Greg Cardinal" <gcardinal(at)startribune.com> |
Larry,
Custom radiators can be made up by:
Carlberg Radiator Service
1310 East 66th St.
Richfield, MN 55423
612 866-5107
Shop was once owned by Wally Carlberg, a longtime EAA'er who flew west a
few years ago. The shop was then purchased by Forrest Lovely. Forrest, who
has since retired, has been involved with Pietenpols since he was in high
school. Anyway, this radiator shop does custom work and they have made
radiators for Pietenpols in the past. I have no experience with them and I
don't know how expensive they might be.
Greg Cardinal, Minneapolis
>>> lnawms(at)msn.com 06/04/02 06:13AM >>>
Gang-
"A
" Piet? My engine seems to be running hot and all I can come up with is
t
hat my VW/Audi radiator isn't up to the task. It was the recommended
radi
ator in the 70's BPANews but I am not having good results with it.
ye
ar before, does anyone remember whose it was?
q
uick and reasonable (read:cheap!)?
b
e flown off at the exact moment that I head for Brodhead. Amazing how
tha
t works...
Larry
t
I think the archives list an outfit in wichita falls texas that did a dandy
radiator job for a reasonable price for one of the listers. Might want to
go look fopr it.
Chris Bobka
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Greg
Cardinal
Subject: Re: Pietenpol-List: radiator
Larry,
1310 East 66th St.
Richfield, MN 55423
612 866-5107
Gang-
"A
t
radi
ye
q
b
tha
t works...
Larry
t
Subject: | Bozeman Pietenpol Crash |
Has anyone heard anything further on this? I visited the NTSB site and found the
preliminary report. Nothing further.
http://www.ntsb.gov/ntsb/brief.asp?ev_id=20020417X00530&key=1
May 08, 2002 - June 04, 2002
Pietenpol-Archive.digest.vol-cq
