Pietenpol-Archive.digest.vol-da
February 02, 2003 - February 21, 2003
Date: Feb 02, 2003
Subject: Re: Thanks guys, keep them coming
Chris, I have found and purchased Taylorcraft 96542 s/n 8842. It still looks very good since the covering you did in 87 or so. I have all the records and receipts etc. Nice job. Doug Bryant, Wichita, Ks ________________________________________________________________________________
Date: Feb 02, 2003
From: Dave and Connie <dmatthe1(at)rochester.rr.com>
Doug, Welcome to the club. Now you need to join up with the Taylorcraft Owners Club and the Taylorcraft Foundation. Also figure out how far it is to Barber Airport in Alliance, Ohio. I expect to see you there the weekend after July 4 along with Kip. See http://www.taylorcraft.org for more info. BTW, why did you buy such a new plane? Pre-war is faster :-). Mine is Sn 3045. Dave N36078 '41 BC-12-65 > >Chris, > >I have found and purchased Taylorcraft 96542 s/n 8842. It still looks very >good since the covering you did in 87 or so. I have all the records and >receipts etc. Nice job. > >Doug Bryant, Wichita, Ks > > >_- ________________________________________________________________________________
Subject: long fuse gear
Date: Feb 02, 2003
Dick, I had to drive from Apple Valley down to Faribault and it took 90 minutes for a 35 minute trip. From the archives: Match: #165 Message: #16157 From: "Christian Bobka" <bobka(at)charter.net> Subject: Re: Landing gear question... Date: Jan 13, 2002 Gary, This aircraft is Frank Pavliga's Sky Gypsy and I talked to him about the landing gear at Brodhead a few years ago. There are three fuselages that Bernard published a drawing for. One is the one shown in the 1932 Flying and Glider Manual for the Air Camper (not the "new and improved"). It has a wooden Jenny-style gear. The second is for the 1933 "new and improved" Air Camper with the cub style steel tube landing gear (really the cub style gear copies the piet since the piet was first). The third is the fuselage Bernard Pietenpol developed for the corvair powered piet. No landing gear is shown for this fuselage. It is perfectly acceptable to mount any acceptable engine on this fueslage. You are not limited to the corvair. I will refer to this fuselage as the "long fuselage". It is desireable to use the long fueslage because it is about 7 inches longer than the 1933 "new and improved" Air Camper and the 1932 Air Camper. You fit better in the longer cockpit. Frank Pavliga used the long fuselage for sky gypsy and it originally had a Model A Ford but now has a Continental A-65. The problem is that the long fuselage shifts the loaded center of gravity aft quite a bit. Aerodynamically, this is compensated for by shifting the wing aft. There is no problem here. The problem is that if you take the1932 wood gear and put it on the long fuselage, the wheels are too far forward. Frank Pavliga did not realize this or otherwise ignored this fact for the first set of gear made for the sky gypsy. The wheels were so far forward that he had much difficulty in getting the tail to raise on takeoff. The airplane ON THE GROUND was far too tail heavy. He built a second set of wooden gear legs that shifted the axle back (maybe 5 or 6 inches) and this distributed the weight more appropriately forward and aft of the axle so that the plane handled better on the ground. This can be clearly seen when comparing the photo you posted with the 1932 gear drawings. As an aside, there is a big old lead weight that is tied to one of sky gypsy's motor mount tubes indicating that it was easier to intstall the wieght than to mess with tweaking the rigging of the wings if it is there for aerodynamic purposes or making a new set of gear legs if it is there for wieght distribution for ground handling. Maybe some of the local Ohio boys on the list like Mike Cuy can clue you in better than me since they are more familiar with sky gypsy since it lives in Ohio. Greg Cardinal and Dale Johnson have moved the axle on their wooden gear aft on their yet to fly long fuselage A-65 powered ship. Dale has the number at his fingertips and hopefully will post a note here with the figure. Chris Bobka ----- Original Message ----- From: "Gary McNeel, Jr." <gmcneel(at)mykitplane.com> Subject: Pietenpol-List: Landing gear question... > > I am interested in the landing gear on the Pietenpol. I like the gear as > seen in this picture: > > http://www.mykitplane.com/pietenpolGear.cfm. Is this the design that comes > with the original plans? > > Thanks. > > Regards, > > Gary P. McNeel, Jr. > MyKitPlane.com > EAA 665957 > gmcneel(at)mykitplane.com > http://www.mykitplane.com > And another archive: Match: #167 Message: #16172 Date: Jan 14, 2002 From: "Greg Cardinal" Subject: Re: Landing gear question... The axel on our plane is 19" aft of the firewall. Greg Cardinal >>> bobka(at)charter.net 01/13 11:48 AM >>> ________________________________________________________________________________
Subject: Thanks guys, keep them coming
Date: Feb 02, 2003
Yes Doug. Chuck Gantzer told me earlier today. Small world. I wouldn't mind calling you on the phone to talk about the old girl. I sold it to Hiram Douglas. He sold it to a kid, I think Jeff Lynn was his name. Who else owned it? she must be getting tired by now. Chris -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Doug413(at)aol.com Subject: Re: Pietenpol-List: Thanks guys, keep them coming Chris, I have found and purchased Taylorcraft 96542 s/n 8842. It still looks very good since the covering you did in 87 or so. I have all the records and receipts etc. Nice job. Doug Bryant, Wichita, Ks ________________________________________________________________________________
Date: Feb 02, 2003
From: Kip & Beth Gardner <kipandbeth(at)earthlink.net>
> >Dick, >As an aside, there is a big old lead weight that is tied to one of sky >gypsy's motor mount tubes indicating that it was easier to intstall the >wieght than to mess with tweaking the rigging of the wings if it is there >for aerodynamic purposes or making a new set of gear legs if it is there for >wieght distribution for ground handling. > >Maybe some of the local Ohio boys on the list like Mike Cuy can clue you in >better than me since they are more familiar with sky gypsy since it lives in >Ohio. > >Greg Cardinal and Dale Johnson have moved the axle on their wooden gear aft >on their yet to fly long fuselage A-65 powered ship. Dale has the number at >his fingertips and hopefully will post a note here with the figure. > >Chris Bobka Chris, Dick, Gary, We are all pretty well 'locked down' here in Northeast OH due to crummy weather, but I see Frank out at Barber Field fairly often & I can go look over 'Sky Gypsy' any time I want to, since it lives there. Kind of nice to have a 'reference plane' so close by! I can ask him for details or make measurements for anyone that wants them. BTW, Frank is finishing up the restoration/construction of a Taperwing Waco biplane, almost a 'scratch' plane - I think part of one wing is original. I helped him put the wings on about 2 months ago. I believe he's planning on selling it if anyone is interested. Also, once that's done, 'Sky Gypsy' is due for re-covering. North Canton, OH ________________________________________________________________________________
Date: Feb 02, 2003
Subject: Re: long fuse gear
In a message dated 2/2/2003 8:04:58 PM Central Standard Time, kipandbeth(at)earthlink.net writes: > I can ask him for details or make measurements for anyone that wants them Kip, I would very much appreciate any info in this regard that Frank can pass along. I have the long fuselage with the Model A and the solid wood gear, the same as his. I had built and installed the gear before the thread began on this subject. Of course that gear was intended for the original FGM version. I positioned mine in the location of the second version ("new, improved") which is probably equally wrong but I wanted to resist making any changes before doing my w&b and seeing what my tailwheel weight was. There may be meaningful differences dpending on whether Frank used fir or spruce on his fuselage. I did make a concerted effort to keep mine light in the tailfeathers and used spruce throughout. I'm fully covered, painted and complete and hopefully will be doing my final w&b this weekend. Thanks agin for the offer. Don Hicks ________________________________________________________________________________
Subject: Question about Gross Weight
Date: Feb 02, 2003
Can someone on this list tell me how the Gross Weight is calculated for an aircraft? Jon Botsford ________________________________________________________________________________
Date: Feb 02, 2003
Jon, For an experimental, it is whatever you want it to be. Believe it or not. You set the rules. No kidding. Chris Bobka -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Jon Botsford Subject: Pietenpol-List: Question about Gross Weight Can someone on this list tell me how the Gross Weight is calculated for an aircraft? Jon Botsford ________________________________________________________________________________
From: "Richard Navratril" <horzpool(at)goldengate.net>
Date: Feb 02, 2003
We were no shows at the Alan Jackson / Joe Nichols concert in Mankato tonight. Dick N. ----- Original Message ----- From: "Christian Bobka" <bobka(at)charter.net> Subject: RE: Pietenpol-List: long fuse gear > > Dick, > > I had to drive from Apple Valley down to Faribault and it took 90 minutes > for a 35 minute trip. > > >From the archives: > > Match: #165 Message: #16157 From: "Christian Bobka" <bobka(at)charter.net> > Subject: Re: Landing gear question... Date: Jan 13, 2002 > > > Gary, > > This aircraft is Frank Pavliga's Sky Gypsy and I talked to him about the > landing gear at Brodhead a few years ago. > > There are three fuselages that Bernard published a drawing for. One is the > one shown in the 1932 Flying and Glider Manual for the Air Camper (not the > "new and improved"). It has a wooden Jenny-style gear. > > The second is for the 1933 "new and improved" Air Camper with the cub style > steel tube landing gear (really the cub style gear copies the piet since the > piet was first). > > The third is the fuselage Bernard Pietenpol developed for the corvair > powered piet. No landing gear is shown for this fuselage. It is perfectly > acceptable to mount any acceptable engine on this fueslage. You are not > limited to the corvair. I will refer to this fuselage as the "long > fuselage". It is desireable to use the long fueslage because it is about 7 > inches longer than the 1933 "new and improved" Air Camper and the 1932 Air > Camper. You fit better in the longer cockpit. Frank Pavliga used the long > fuselage for sky gypsy and it originally had a Model A Ford but now has a > Continental A-65. > > The problem is that the long fuselage shifts the loaded center of gravity > aft quite a bit. Aerodynamically, this is compensated for by shifting the > wing aft. There is no problem here. The problem is that if you take > the1932 wood gear and put it on the long fuselage, the wheels are too far > forward. Frank Pavliga did not realize this or otherwise ignored this fact > for the first set of gear made for the sky gypsy. The wheels were so far > forward that he had much difficulty in getting the tail to raise on takeoff. > The airplane ON THE GROUND was far too tail heavy. He built a second set of > wooden gear legs that shifted the axle back (maybe 5 or 6 inches) and this > distributed the weight more appropriately forward and aft of the axle so > that the plane handled better on the ground. This can be clearly seen when > comparing the photo you posted with the 1932 gear drawings. > > As an aside, there is a big old lead weight that is tied to one of sky > gypsy's motor mount tubes indicating that it was easier to intstall the > wieght than to mess with tweaking the rigging of the wings if it is there > for aerodynamic purposes or making a new set of gear legs if it is there for > wieght distribution for ground handling. > > Maybe some of the local Ohio boys on the list like Mike Cuy can clue you in > better than me since they are more familiar with sky gypsy since it lives in > Ohio. > > Greg Cardinal and Dale Johnson have moved the axle on their wooden gear aft > on their yet to fly long fuselage A-65 powered ship. Dale has the number at > his fingertips and hopefully will post a note here with the figure. > > Chris Bobka > > ----- Original Message ----- > From: "Gary McNeel, Jr." <gmcneel(at)mykitplane.com> > Subject: Pietenpol-List: Landing gear question... > > > > > > > I am interested in the landing gear on the Pietenpol. I like the gear as > > seen in this picture: > > > > http://www.mykitplane.com/pietenpolGear.cfm. Is this the design that comes > > with the original plans? > > > > Thanks. > > > > Regards, > > > > Gary P. McNeel, Jr. > > MyKitPlane.com > > EAA 665957 > > gmcneel(at)mykitplane.com > > http://www.mykitplane.com > > > > > And another archive: > > Match: #167 Message: #16172 Date: Jan 14, 2002 From: "Greg Cardinal" > Subject: Re: Landing gear question... > > > The axel on our plane is 19" aft of the firewall. > > Greg Cardinal > > >>> bobka(at)charter.net 01/13 11:48 AM >>> > > ________________________________________________________________________________
Date: Feb 02, 2003
Subject: Press. oiled A
Les: When you drill and pressure oiled the crank, did you stay with the babbit, or go with insert bearings? Leon S Hutchinson Ks. ________________________________________________________________________________
Date: Feb 03, 2003
Subject: Re: Press. oiled A
I assume you guys are going to turn up the heat in your A powered ships. The pressured oil supply is not needed if turning Pietenpols recommended RPM. But I understand that it is nice to have. The engine is able to produce more power than designed for. Better breathing is what I have understood to help the most, increase the intake CFMS. The insert bearings I have seen available use a center thrust, is this the norm? If so it would not seem to be a good idea, since the thrust loads need to stay were they are for aircraft use. P.S. I have an A engine with most machine work done, and new bearings for $550.00 anyone interested email me at zigodan(at)aol.com. Dan ________________________________________________________________________________
Date: Feb 02, 2003
Dan, I might be interested. Can you send me pictures. Chris -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of ZigoDan(at)aol.com Subject: Re: Pietenpol-List: Press. oiled A I assume you guys are going to turn up the heat in your A powered ships. The pressured oil supply is not needed if turning Pietenpols recommended RPM. But I understand that it is nice to have. The engine is able to produce more power than designed for. Better breathing is what I have understood to help the most, increase the intake CFMS. The insert bearings I have seen available use a center thrust, is this the norm? If so it would not seem to be a good idea, since the thrust loads need to stay were they are for aircraft use. P.S. I have an A engine with most machine work done, and new bearings for $550.00 anyone interested email me at zigodan(at)aol.com. Dan ________________________________________________________________________________
Date: Feb 03, 2003
Subject: Model A Firewall Fwd. for sale
Included is the Model A engine, Slick Mag, Dan Price Aluminum Head, radiator, hoses, mounts & fittings, engine mount, cowling, prop. The engine needs rebuilt. I suggest drilling the crankshaft for pressure oiling, forged pistons, and an alternative induction system. $1500 for all. I have pictures. E-mail me direct for pictures or questions. Chuck Gantzer rcaprd(at)aol.com ________________________________________________________________________________
From: "Jack Phillips" <jackphillips(at)earthlink.net>
Date: Feb 03, 2003
Jon, Chris is right, up to a point. The gross weight is basically set by some structural parameter in the aircraft, usually the wing spar or the landing gear. You hear of a plane being stressed to +/- 10 G's, well that means the structure can handle a certain limit load, and depending on how many G's the designer wants the plane to be good for, he divides the limit load by that number of G's and voila - the gross weight pops out! When I was a young engineer just out of college and was working for General Dynamics on the F-16 initial design (sad that a plane designed in 1975 is still one of our front line fighters), the initial gross weight of the plane was 23,000 lbs. (which meant it could go supersonic straight up with its 25,000 lb. thrust engine). Later, some mods to the landing gear enabled it to takeoff with more fuel on board in external tanks and the takeoff gross weight was increased to 37,000 lbs, but its maneuvering gross weight was still 23,000. In other words, the gross weight is somewhat arbitrary. However, be aware that stall speed is a variable and goes up with gross weight. It is quite possible with a robust structured airplane to have a gross weight that is structurally safe but simply can't fly because the stall speed is too high. For my Pietenpol, I've figured on a gross weight of around 1100 lbs. Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Christian Bobka Subject: RE: Pietenpol-List: Question about Gross Weight Jon, For an experimental, it is whatever you want it to be. Believe it or not. You set the rules. No kidding. Chris Bobka -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Jon Botsford Subject: Pietenpol-List: Question about Gross Weight Can someone on this list tell me how the Gross Weight is calculated for an aircraft? Jon Botsford ________________________________________________________________________________
Subject: Re: Sat. Both sad and happy
Date: Feb 03, 2003
----- Original Message ----- From: <Isablcorky(at)aol.com> ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; Subject: Pietenpol-List: Sat. Both sad and happy +++++++++++++++++++ Corky, I share your feelings, both about the shuttle tragedy and the euphoria of your first ride. Thanks for sharing with us. Congratulations! John +++++++++++++++++++ > > Pieters and Friends, > Yesterday began very sad for our country and some space participants and > their families. This we all regret deeply. > > Yesterday, my test pilot Mr. Edwin Johnson, finally agreed to let me fly in > my airplane. Sounds funny doesn't it. He had test flown the first 25 hrs and > 36 minutes as required by the FAA before carrying a passenger ( that's me). > Earlier in the afternoon I had cranked up N41CC and taxied up and down the > runway waiting for him. The tailwheel didn't answer to helm as I wanted it so > I came in and made some changes. Finally he arrived and said he would ride > front hole and I would fly from the rear, where else? It took him 2 prop > swings before it started. ( I started it on the first swing earlier). We > talked about our signals etc before we taxied out for run up. Finally I went > to the north end of Lucien and did a few vrooms eased the throttle forward > and felt that 65 Continental try to force me through the seat back. Didn't > even forget to pressure the rudder to the right when the tail lifted. Didn't > know when we left the ground as it was so quick. Kicked in a little right > crab, ( SW wind), and she climbed like an angel on her way home. Made my left > climbing turn and the ball stayed centered. Man, I was livin. Went up to 1K, > 130 deg, to go chase hundreds of white pelicans down on the roaring Red. A > beautiful bird, most people have never seen them from above to see the > beautiful black-top wing tips. Anyway my front holer directed me to Desoto > Parish Airport for some attempts to land this airplane. I had failed to tell > him that I had not landed a tail wheel airplane since 1972. Oh well, he would > soon find out. I made my usual Kamakazi approach as he just sat up there > stunned. Came on down to 18 and leveled off to land as if I had been landing > a big bird. Was pretty high and did I ever spread the gears, ( dropped in). I > was embarrased. We went around again and on base he took it to show me how > well a Piet would slip. On final I slipped it and it was like the old L-16 in > '51. He applauded this landing. Hell, any landing would have beat that first > one. We left Desoto. Forgot to mention that between the Pelicans and Desoto > we went up to 2500 for some steeeeeeeep turns, sslooooooooooow flying and > some stalls, power on and half on. > All went well. I felt right at home. > Next we went to a sod duster operation strip. First landing, kinda bad, again > flairing out too high. Next one he applauded me once again. By then the sun > had set and it was beginning to cool down in 41CC so we came home. Landed at > Lucien, again kinda high but ground control was OK. That Lucien runway can't > be any wider 12 or 15 feet. > I guess you might say this was part of what they call a bi-annual. His only > comment was that we need to do it again as soon as we can get another > beautiful day. As all of you noted, the skies in East Texas and Western La > yesterday were as clear as I ever remember. > I ended the day feeling like a popsickle but very pleased to have piloted our > own creation. Joe Czalicka and I. Those building Piets, don't stop, it's > worth all the work. > > Corky in La > > ________________________________________________________________________________
Subject: Landing Gear Placement
Date: Feb 03, 2003
Pieters, I too, struggled with the placement of the gear on my long fuselage, and finally decided to use the simple weight and balance spreadsheet that I had been using on my computer. When I began building the plane, I made up a simple spreadsheet on the computer which listed the estimated weight and the moments of each major component of the plane such as engine, wing, fuel tank, pilot, passenger etc. Then as each part was built the actual weight was put into the spreadsheet and the revised W&B was automatically computed. When it came to the placement of the gear, I figured that I wanted to have the ground contact of the wheels to be about 12 degrees forward of the CG. Turned out to be perfect. I can use the brakes pretty hard without any tendency to nose over, (the brakes are not that effective)yet it is light enough on the tailwheel, (12 lbs) to handle easily on the ground. Generally speaking, the further forward the gear is, the more squirrely the plane is on take off and landings, but too far aft and it becomes too sensitive to nosing over under braking effort. Hope this helps, John, NX114D ________________________________________________________________________________
Date: Feb 03, 2003
02/03/2003 08:02:12 AM Congratulations Corky!!!!!! Isablcorky(at)aol.com@matronics.com on 02/02/2003 06:31:28 PM Please respond to pietenpol-list(at)matronics.com Sent by: owner-pietenpol-list-server(at)matronics.com Lincol99(at)aol.com, christinedigsjazz(at)shaw.ca, wayfollower(at)cox.net, claudiabartlett(at)austin.rr.com, T_FIN(at)Compuserve.com, hmposer(at)charter.net, Howdyhilary(at)aol.com, fleece(at)cox-internet.com, NewtonIvy(at)webtv.net, jamestownesimmons(at)yahoo.com, jbrainis(at)sport.rr.com, LCJELKS(at)aol.com, JimNikls(at)aol.com, Herzog807(at)msn.com, Jajouett(at)aol.com, Leeortho(at)aol.com, LGililland(at)msn.com, Linda(at)huarch.com, tvlux(at)cox.net, MAGSOUR(at)aol.com, Marionle35(at)aol.com, Mvphipps39(at)aol.com, rchapman(at)andersonsmith.com, RobertBeachbum(at)aol.com, nfn00979(at)naples.net, TomTravis(at)aol.com, wbeevans(at)worldnet.att.net, craigwilcox(at)peoplepc.com cc: Subject: Pietenpol-List: Sat. Both sad and happy Pieters and Friends, Yesterday began very sad for our country and some space participants and their families. This we all regret deeply. Yesterday, my test pilot Mr. Edwin Johnson, finally agreed to let me fly in my airplane. Sounds funny doesn't it. He had test flown the first 25 hrs and 36 minutes as required by the FAA before carrying a passenger ( that's me). Earlier in the afternoon I had cranked up N41CC and taxied up and down the runway waiting for him. The tailwheel didn't answer to helm as I wanted it so I came in and made some changes. Finally he arrived and said he would ride front hole and I would fly from the rear, where else? It took him 2 prop swings before it started. ( I started it on the first swing earlier). We talked about our signals etc before we taxied out for run up. Finally I went to the north end of Lucien and did a few vrooms eased the throttle forward and felt that 65 Continental try to force me through the seat back. Didn't even forget to pressure the rudder to the right when the tail lifted. Didn't know when we left the ground as it was so quick. Kicked in a little right crab, ( SW wind), and she climbed like an angel on her way home. Made my left climbing turn and the ball stayed centered. Man, I was livin. Went up to 1K, 130 deg, to go chase hundreds of white pelicans down on the roaring Red. A beautiful bird, most people have never seen them from above to see the beautiful black-top wing tips. Anyway my front holer directed me to Desoto Parish Airport for some attempts to land this airplane. I had failed to tell him that I had not landed a tail wheel airplane since 1972. Oh well, he would soon find out. I made my usual Kamakazi approach as he just sat up there stunned. Came on down to 18 and leveled off to land as if I had been landing a big bird. Was pretty high and did I ever spread the gears, ( dropped in). I was embarrased. We went around again and on base he took it to show me how well a Piet would slip. On final I slipped it and it was like the old L-16 in '51. He applauded this landing. Hell, any landing would have beat that first one. We left Desoto. Forgot to mention that between the Pelicans and Desoto we went up to 2500 for some steeeeeeeep turns, sslooooooooooow flying and some stalls, power on and half on. All went well. I felt right at home. Next we went to a sod duster operation strip. First landing, kinda bad, again flairing out too high. Next one he applauded me once again. By then the sun had set and it was beginning to cool down in 41CC so we came home. Landed at Lucien, again kinda high but ground control was OK. That Lucien runway can't be any wider 12 or 15 feet. I guess you might say this was part of what they call a bi-annual. His only comment was that we need to do it again as soon as we can get another beautiful day. As all of you noted, the skies in East Texas and Western La yesterday were as clear as I ever remember. I ended the day feeling like a popsickle but very pleased to have piloted our own creation. Joe Czalicka and I. Those building Piets, don't stop, it's worth all the work. Corky in La ________________________________________________________________________________
Date: Feb 03, 2003
Subject: Re: Landing Gear Placement
You can also check out the landing gear design info from one of Pazmany's books at. http://mykitplane.com/Planes/filesList2.cfm?AlbumID=5 It suggests that the angle from the forward most CG to the contact point of the wheels be 12 to 15 degrees ahead. There is some other info in the article also. I am in the middle of gear building now and it is one of the most difficult, but fun learning experiences so far. Kirk ________________________________________________________________________________
Subject: prop testing
Date: Feb 03, 2003
Howdy, Pieters- To those of you who have a Corvair on your Piet and who are flying or getting ready to, I have an offer. I just got a brand-new 62x34 Tennessee Props wood prop for the Corvair/Pietenpol. My engine won't be running for a while and definitely won't be installed on a Piet for a good long while, so I stand ready to loan my prop out for testing. The intent is not to have it sitting around, but rather for someone who is flying or on the verge of flying and who could get some useful data from it and maybe get in the air a bit sooner than if you had to order one and wait for it. The prop is through-bored for the safety shaft, 3" thick, left-hand turning, SAE #1 bolt pattern for AN6 bolts. I do not have a crush plate for it yet, but will soon (and all wood props must have one). Anyone interested, let me know off-line and we'll talk. The prop is crated for shipping (I just got it Friday) and it's a beauty. Maybe I'll take a picture and put it on my website. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Feb 03, 2003
Hi John what was different about your craft that you had to change gear location from the plans, and from the location that 500 other pieters placed theirs? thanks Del --- John Dilatush wrote: > Dilatush" > > Pieters, > > I too, struggled with the placement of the gear on > my long fuselage, and finally decided to use the > simple weight and balance spreadsheet that I had > been using on my computer. > > When I began building the plane, I made up a simple > spreadsheet on the computer which listed the > estimated weight and the moments of each major > component of the plane such as engine, wing, fuel > tank, pilot, passenger etc. > > Then as each part was built the actual weight was > put into the spreadsheet and the revised W&B was > automatically computed. > > When it came to the placement of the gear, I figured > that I wanted to have the ground contact of the > wheels to be about 12 degrees forward of the CG. > Turned out to be perfect. I can use the brakes > pretty hard without any tendency to nose over, (the > brakes are not that effective)yet it is light enough > on the tailwheel, (12 lbs) to handle easily on the > ground. > > Generally speaking, the further forward the gear is, > the more squirrely the plane is on take off and > landings, but too far aft and it becomes too > sensitive to nosing over under braking effort. > > Hope this helps, > > John, NX114D > > > > Contributions > any other > Forums. > > latest messages. > List members. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/Pietenpol-List.htm > Digests:http://www.matronics.com/digest/pietenpol-list > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > ===== Del-New Richmond, Wi "farmerdel(at)rocketmail.com" ________________________________________________________________________________
Date: Feb 03, 2003
Dan It seems like every guy I have talked to always wishes he had a little more power. Getting more power out of a A or most any engine is pretty easy, it is getting them to "live" that is the challenge. Henry didn't drill cranks till the V 8 which came out right after the A, and went from 40 hp to 85 hp with almost the same displacement. I am not a big fan of insert bearings for the A crank, but maybe they work. A properly done babbitt job with pressure works just fine for extra power engines. Les > >I assume you guys are going to turn up the heat in your A powered ships. The >pressured oil supply is not needed if turning Pietenpols recommended RPM. >But I understand that it is nice to have. The engine is able to produce more >power than designed for. Better breathing is what I have understood to help >the most, increase the intake CFMS. The insert bearings I have seen >available use a center thrust, is this the norm? If so it would not seem to >be a good idea, since the thrust loads need to stay were they are for >aircraft use. >P.S. I have an A engine with most machine work done, and new bearings for >$550.00 anyone interested email me at zigodan(at)aol.com. > >Dan > > ________________________________________________________________________________
Date: Feb 03, 2003
Leon I have always stayed with the babbitt. I have found that with pressure it will hang together at 4500 rpm for many miles of road use, way faster than we will run in a airplane. I am not sure I am a big fan of thin shell bearings in a A especially at high power settings as the A crank is still quite flexible and the babbitt will "adjust" to the required clearance which the thinly coated shell bearings can't. Maybe this doesn't really happen but it suits my experience. Les > >Les: When you drill and pressure oiled the crank, did you stay with the >babbit, or go with insert bearings? Leon S Hutchinson Ks. > > ________________________________________________________________________________
Date: Feb 03, 2003
Del, as my recent post on this subject says, if you build the long "corvair" fuselage, NO GEAR was ever shown on the drawings. So how do yo know where it should be? The point of my presentation is that if you don't know where it is to be per the drawings then this is one man's (my) best guess. Also, I use Sky Gypsy as a prime example of a much beloved Piet that was built one way and then promptly modified to be manageable by a very able pilot. May I suggest that the 500 less the Sky Gypsy are the 499 piets that never fly? Chris -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of del magsam Subject: Re: Pietenpol-List: Landing Gear Placement Hi John what was different about your craft that you had to change gear location from the plans, and from the location that 500 other pieters placed theirs? thanks Del --- John Dilatush wrote: > Dilatush" > > Pieters, > > I too, struggled with the placement of the gear on > my long fuselage, and finally decided to use the > simple weight and balance spreadsheet that I had > been using on my computer. > > When I began building the plane, I made up a simple > spreadsheet on the computer which listed the > estimated weight and the moments of each major > component of the plane such as engine, wing, fuel > tank, pilot, passenger etc. > > Then as each part was built the actual weight was > put into the spreadsheet and the revised W&B was > automatically computed. > > When it came to the placement of the gear, I figured > that I wanted to have the ground contact of the > wheels to be about 12 degrees forward of the CG. > Turned out to be perfect. I can use the brakes > pretty hard without any tendency to nose over, (the > brakes are not that effective)yet it is light enough > on the tailwheel, (12 lbs) to handle easily on the > ground. > > Generally speaking, the further forward the gear is, > the more squirrely the plane is on take off and > landings, but too far aft and it becomes too > sensitive to nosing over under braking effort. > > Hope this helps, > > John, NX114D > > > Contributions > any other > Forums. > > latest messages. > List members. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/Pietenpol-List.htm > Digests:http://www.matronics.com/digest/pietenpol-list > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > ===== Del-New Richmond, Wi "farmerdel(at)rocketmail.com" ________________________________________________________________________________
Date: Feb 03, 2003
----- Original Message ----- From: "del magsam" <farmerdel(at)rocketmail.com> Subject: Re: Pietenpol-List: Landing Gear Placement +++++++++++++++++++++ Del, To answer your question: Each Pietenpol that has been built seems to vary from the plans some according to the engine used, builder's preference on details, woods used, finishes applied and on and on. All of these changes result in a different CG location. Since the ground handling is dependent on the landing gear location and the landing gear location is dependent upon the CG (both horizontal and vertical) then each gear location should be figured for the particular plane if one is to get the kind of handling he is looking for. This is one of the challenges of building your own plane from plans rather than from a kit. In my case, I am running a heavier powerplant than usual, have added brakes, tailwheel, seat padding, electrical system, ELT, cowl tank and other modifications, all of which change the CG from the plans. Although the gear location is changed by only a couple of inches from the plans and is not super critical, I chose to be precise. John +++++++++++++ > > Hi John > what was different about your craft that you had to > change gear location from the plans, and from the > location that 500 other pieters placed theirs? > thanks > Del > --- John Dilatush wrote: > > Dilatush" > > > > Pieters, > > > > I too, struggled with the placement of the gear on > > my long fuselage, and finally decided to use the > > simple weight and balance spreadsheet that I had > > been using on my computer. > > > > When I began building the plane, I made up a simple > > spreadsheet on the computer which listed the > > estimated weight and the moments of each major > > component of the plane such as engine, wing, fuel > > tank, pilot, passenger etc. > > > > Then as each part was built the actual weight was > > put into the spreadsheet and the revised W&B was > > automatically computed. > > > > When it came to the placement of the gear, I figured > > that I wanted to have the ground contact of the > > wheels to be about 12 degrees forward of the CG. > > Turned out to be perfect. I can use the brakes > > pretty hard without any tendency to nose over, (the > > brakes are not that effective)yet it is light enough > > on the tailwheel, (12 lbs) to handle easily on the > > ground. > > > > Generally speaking, the further forward the gear is, > > the more squirrely the plane is on take off and > > landings, but too far aft and it becomes too > > sensitive to nosing over under braking effort. > > > > Hope this helps, > > > > John, NX114D > > > > > > > > Contributions > > any other > > Forums. > > > > latest messages. > > List members. > > > > http://www.matronics.com/subscription > > http://www.matronics.com/FAQ/Pietenpol-List.htm > > > Digests:http://www.matronics.com/digest/pietenpol-list > > http://www.matronics.com/archives > > http://www.matronics.com/photoshare > > http://www.matronics.com/emaillists > > > > > > > > > > > > > ===== > Del-New Richmond, Wi > "farmerdel(at)rocketmail.com" > > ________________________________________________________________________________
Date: Feb 03, 2003
--- Christian Bobka wrote: > Bobka" > > Del, > > as my recent post on this subject says, if you build > the long "corvair" > fuselage, NO GEAR was ever shown on the drawings. > So how do yo know where > it should be? The point of my presentation is that > if you don't know where > it is to be per the drawings then this is one man's > (my) best guess. Also, > I use Sky Gypsy as a prime example of a much beloved > Piet that was built one > way and then promptly modified to be manageable by a > very able pilot. May I > suggest that the 500 less the Sky Gypsy are the 499 > piets that never fly? > > Chris If the gear location isn't indicated on the long fuse option plans, I would assume it is not changed from the original plans, which is where I mounted mine. And it made sense to put the gear mounts per plans because that is where the upright longeron braces connect the wing connection hardware to the gear connection hardware. to directly absorb the weight of the wing on landing. So...should I reconsider? or will that work. thanks for your input Del ===== Del-New Richmond, Wi "farmerdel(at)rocketmail.com" ________________________________________________________________________________
Date: Feb 03, 2003
Hey Folks, In the papers I received with my plans there is a memo of sorts that talks to the movement forward of the landing gear on the stretched fuselage version. If there is any interest I could probably get it scanned and post it. Dave Hall Fayetteville, NC ________________________________________________________________________________
From: "walter evans" <wbeevans(at)worldnet.att.net>
Date: Feb 03, 2003
Just jumping in with my two cents. In spite of what engine you use or equiptment you put on, the CG is still in the same window. Assuming that the gear is hooked to the same attach points, if you use the split gear, the only way to relocate the wheels is by changing the style of the "V". If you do this, as the gear moves thru it's range of motion while the bungees are flexing, the toe-in/toe-out caster/camber is all going to be different from original. Except for moving engine forward about 2" (A-65 long fuselage) to compensate for my fat arse, the CG is still in the window(way to the rear). I built the split gear to the plans, and it seems to handle fine riding on the mains waiting to leave the earth. walt ----- Original Message ----- From: "del magsam" <farmerdel(at)rocketmail.com> Subject: RE: Pietenpol-List: Landing Gear Placement > > > --- Christian Bobka wrote: > > Bobka" > > > > Del, > > > > as my recent post on this subject says, if you build > > the long "corvair" > > fuselage, NO GEAR was ever shown on the drawings. > > So how do yo know where > > it should be? The point of my presentation is that > > if you don't know where > > it is to be per the drawings then this is one man's > > (my) best guess. Also, > > I use Sky Gypsy as a prime example of a much beloved > > Piet that was built one > > way and then promptly modified to be manageable by a > > very able pilot. May I > > suggest that the 500 less the Sky Gypsy are the 499 > > piets that never fly? > > > > Chris > If the gear location isn't indicated on the long fuse > option plans, I would assume it is not changed from > the original plans, which is where I mounted mine. And > it made sense to put the gear mounts per plans because > that is where the upright longeron braces connect the > wing connection hardware to the gear connection > hardware. to directly absorb the weight of the wing on > landing. So...should I reconsider? or will that work. > thanks for your input > Del > > ===== > Del-New Richmond, Wi > "farmerdel(at)rocketmail.com" > > ________________________________________________________________________________
Date: Feb 03, 2003
Del, The mounting points are the same. The mounting hardware is the same. The V just changes shape as the axle is moved back. Looking at the wood gear shown 1932 F & G Manual, the forward leg of the V is more vertical and shorter than the aft leg of the V which is longer. As the axle moves back the legs begin to equal out in length. This is needed on the long "corvair" fuselage as used on sky gypsy because you moved the CG aft and you increased vertical surface area aft. There are three conditions: 1) low speed aircraft handling on ground with negligible total aerodynamic effects. 2) high speed aircraft handling on the ground with considerable total aerodynamic effects. 3) aircraft in flight. Landing gear has limited aerodynamic effects. In case one, you are dealing with taxiing, speeding up for take off and slowing down after landing. This is with little or no help from the rudder due to slow speeds. The farther forward the gear is located on the fuselage, the greater the distance between the CG and the gear axle. Also, lowering the tail slides the gear even further forward. We are used to the CG being defined as the point of rotation of all reactions but this only applies in flight. If a wheel is touching the ground, then the wheel contact point, which is just below the axle becomes the point of rotation because that is where the airplane is "attached" to the ground. The greater the distance between the CG and this ground "attachment" point, the harder it is for the pilot to transition from ground mode to flight mode. Small changes forward in axle placement greatly increase the tendency to ground loop. In addition, as the axle is moved forward, there is an increased side surface area aft of the "attach" point of the aircraft with the ground. With a forward axle, any crosswinds would cause the tail to swing right around into the wind. Don't forget that any surface moved from in front to behind the axle hurts you twice becuase forward of the axle it was helping to counter what was behind the axle. Now it is adding to what is behind the axle. Also, the distance from the axle to the end of the ship increases the leverage that side surface area exerts in a crosswind. Granted, this may increase rudder effectivity but we are dealing with a flying surface that is trying to use air on the downwind side of the fuselage to move the fuselage back toward the windward side. The downswind side of the fuselage is essentially blanked out so the rudder has limited effectiveness. In case two, a too far forward placement of the axle will cause increased ground looping tendencies due to CG placement relative the axle and side surface area relative the axle as noted in the previous paragraph. With the axle too far forward, it will be virtually impossible to lift the tail for takeoff until an abnormally high speed in ground roll is attained. A tail wheel airplane is not designed for this. It will present a high drag profile to the relative wind and the takeoff rolls will be too long. It will also increase the structural loading on the tail with some pretty large impact loads. You will be ripping the tail skid/wheel off on a regular basis. In case three, the too far forward placement of the gear would put vertical surface area (the wheel sides) far forward of the CG. This will tend to cancel the stabilizing effect of the vertical stabilizer. As cool as covered spoked wheels look, this is a big reason why many that have used spoked wheels with fabric covering have removed the fabric covering. The two big vertical discs negated the stabilizing effects of the vertical stabilizer. In summary, the axle needs to placed as far aft as possible but with consideration of limiting the tendency to noseover. Others posted messages to this list indicating the degree angle that the axle needs to be forward of the CG. This is do true but it truly neds to be understood. A picture would really help to see what is meant. We tend to think of the CG as a point on the wing where the ship balances. This is a valid CG location but this is the longitudinal CG or the CG along the longitudinal axis. We need to also consider the other axes. There is a CG about the vertical axis and a CG about the lateral axis. Combine these three and you get a single point about which all the mass of the aircraft is located. A guess on the Pietenpol, with its high wing, is that it is located at or about the center of the instrument panel. If you level the ship and then hang a plumb bob from this point and then make the angle forward of this (someone else mentioned it in an email a minute ago, was it 7 degrees?), your axle should optimally lie on that line. This would be the axle location that is as far back as possible yet far enought forward to keep you from nosing over. I hope this helps. Chris Bobka -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of del magsam Subject: RE: Pietenpol-List: Landing Gear Placement --- Christian Bobka wrote: > Bobka" > > Del, > > as my recent post on this subject says, if you build > the long "corvair" > fuselage, NO GEAR was ever shown on the drawings. > So how do yo know where > it should be? The point of my presentation is that > if you don't know where > it is to be per the drawings then this is one man's > (my) best guess. Also, > I use Sky Gypsy as a prime example of a much beloved > Piet that was built one > way and then promptly modified to be manageable by a > very able pilot. May I > suggest that the 500 less the Sky Gypsy are the 499 > piets that never fly? > > Chris If the gear location isn't indicated on the long fuse option plans, I would assume it is not changed from the original plans, which is where I mounted mine. And it made sense to put the gear mounts per plans because that is where the upright longeron braces connect the wing connection hardware to the gear connection hardware. to directly absorb the weight of the wing on landing. So...should I reconsider? or will that work. thanks for your input Del ===== Del-New Richmond, Wi "farmerdel(at)rocketmail.com" ________________________________________________________________________________
Date: Feb 03, 2003
Kip Center of axal to fire wall 21 " It seems right. Dale ________________________________________________________________________________
Date: Feb 03, 2003
Dale Are you to the point of final or close w/b yet? If so, how far back did you have to rake your wing to get acceptable balance? On my short Fuse Piet the wing is back almost 4". I am hoping to avoid that, this time It makes getting into the rear cockpit somewhat challanging. I installed the center section cutout but the trailing edge ends dont allow much room. Dick N. ----- Original Message ----- From: "D.Dale Johnson" <dd5john(at)juno.com> Subject: Re: Pietenpol-List: long fuse gear > > Kip > > Center of axal to fire wall 21 " > It seems right. > Dale > > ________________________________________________________________________________
Date: Feb 03, 2003
----- Original Message ----- From: "Christian Bobka" <bobka(at)charter.net> Subject: RE: Pietenpol-List: Landing Gear Placement ++++++++++++++++++++ Chris, Good explanation, you are absolutely right! Piet builders should understand that wheel placement is relative to the center of gravity of the entire mass and to use an arbitrary measurement such as "distance from the firewall" or "in front of the leading edge" are only asking for trouble. John +++++++++++++++++++++++ > > Del, > > The mounting points are the same. The mounting hardware is the same. The V > just changes shape as the axle is moved back. Looking at the wood gear > shown 1932 F & G Manual, the forward leg of the V is more vertical and > shorter than the aft leg of the V which is longer. As the axle moves back > the legs begin to equal out in length. This is needed on the long "corvair" > fuselage as used on sky gypsy because you moved the CG aft and you increased > vertical surface area aft. > > There are three conditions: > > 1) low speed aircraft handling on ground with negligible total aerodynamic > effects. > > 2) high speed aircraft handling on the ground with considerable total > aerodynamic effects. > > 3) aircraft in flight. Landing gear has limited aerodynamic effects. > > > In case one, you are dealing with taxiing, speeding up for take off and > slowing down after landing. This is with little or no help from the rudder > due to slow speeds. The farther forward the gear is located on the > fuselage, the greater the distance between the CG and the gear axle. Also, > lowering the tail slides the gear even further forward. We are used to the > CG being defined as the point of rotation of all reactions but this only > applies in flight. If a wheel is touching the ground, then the wheel > contact point, which is just below the axle becomes the point of rotation > because that is where the airplane is "attached" to the ground. The greater > the distance between the CG and this ground "attachment" point, the harder > it is for the pilot to transition from ground mode to flight mode. Small > changes forward in axle placement greatly increase the tendency to ground > loop. > > In addition, as the axle is moved forward, there is an increased side > surface area aft of the "attach" point of the aircraft with the ground. > With a forward axle, any crosswinds would cause the tail to swing right > around into the wind. Don't forget that any surface moved from in front to > behind the axle hurts you twice becuase forward of the axle it was helping > to counter what was behind the axle. Now it is adding to what is behind the > axle. Also, the distance from the axle to the end of the ship increases the > leverage that side surface area exerts in a crosswind. Granted, this may > increase rudder effectivity but we are dealing with a flying surface that is > trying to use air on the downwind side of the fuselage to move the fuselage > back toward the windward side. The downswind side of the fuselage is > essentially blanked out so the rudder has limited effectiveness. > > In case two, a too far forward placement of the axle will cause increased > ground looping tendencies due to CG placement relative the axle and side > surface area relative the axle as noted in the previous paragraph. With > the axle too far forward, it will be virtually impossible to lift the tail > for takeoff until an abnormally high speed in ground roll is attained. A > tail wheel airplane is not designed for this. It will present a high drag > profile to the relative wind and the takeoff rolls will be too long. It > will also increase the structural loading on the tail with some pretty large > impact loads. You will be ripping the tail skid/wheel off on a regular > basis. > > In case three, the too far forward placement of the gear would put vertical > surface area (the wheel sides) far forward of the CG. This will tend to > cancel the stabilizing effect of the vertical stabilizer. As cool as > covered spoked wheels look, this is a big reason why many that have used > spoked wheels with fabric covering have removed the fabric covering. The > two big vertical discs negated the stabilizing effects of the vertical > stabilizer. > > In summary, the axle needs to placed as far aft as possible but with > consideration of limiting the tendency to noseover. Others posted messages > to this list indicating the degree angle that the axle needs to be forward > of the CG. This is do true but it truly neds to be understood. A picture > would really help to see what is meant. We tend to think of the CG as a > point on the wing where the ship balances. This is a valid CG location but > this is the longitudinal CG or the CG along the longitudinal axis. We need > to also consider the other axes. There is a CG about the vertical axis and > a CG about the lateral axis. Combine these three and you get a single point > about which all the mass of the aircraft is located. A guess on the > Pietenpol, with its high wing, is that it is located at or about the center > of the instrument panel. If you level the ship and then hang a plumb bob > from this point and then make the angle forward of this (someone else > mentioned it in an email a minute ago, was it 7 degrees?), your axle should > optimally lie on that line. This would be the axle location that is as far > back as possible yet far enought forward to keep you from nosing over. > > I hope this helps. > > Chris Bobka > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of del > magsam > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Landing Gear Placement > > > > > --- Christian Bobka wrote: > > Bobka" > > > > Del, > > > > as my recent post on this subject says, if you build > > the long "corvair" > > fuselage, NO GEAR was ever shown on the drawings. > > So how do yo know where > > it should be? The point of my presentation is that > > if you don't know where > > it is to be per the drawings then this is one man's > > (my) best guess. Also, > > I use Sky Gypsy as a prime example of a much beloved > > Piet that was built one > > way and then promptly modified to be manageable by a > > very able pilot. May I > > suggest that the 500 less the Sky Gypsy are the 499 > > piets that never fly? > > > > Chris > If the gear location isn't indicated on the long fuse > option plans, I would assume it is not changed from > the original plans, which is where I mounted mine. And > it made sense to put the gear mounts per plans because > that is where the upright longeron braces connect the > wing connection hardware to the gear connection > hardware. to directly absorb the weight of the wing on > landing. So...should I reconsider? or will that work. > thanks for your input > Del > > ===== > Del-New Richmond, Wi > "farmerdel(at)rocketmail.com" > > ________________________________________________________________________________
Date: Feb 03, 2003
> >In a message dated 2/2/2003 8:04:58 PM Central Standard Time, >kipandbeth(at)earthlink.net writes: > >> I can ask him for details or make measurements for anyone that wants them > >Kip, >I would very much appreciate any info in this regard that Frank can pass >along. I have the long fuselage with the Model A and the solid wood gear, the >same as his. I had built and installed the gear before the thread began on >this subject. Of course that gear was intended for the original FGM version. >I positioned mine in the location of the second version ("new, improved") >which is probably equally wrong but I wanted to resist making any changes >before doing my w&b and seeing what my tailwheel weight was. There may be >meaningful differences dpending on whether Frank used fir or spruce on his >fuselage. I did make a concerted effort to keep mine light in the >tailfeathers and used spruce throughout. I'm fully covered, painted and >complete and hopefully will be doing my final w&b this weekend. Thanks agin >for the offer. Don Hicks Don, I will ask Frank about his W&B the next time I see him - might be a few weeks - I'm not getting out to the airport as much during the winter. Then it's a question of whether or not he's there too, although he's pushing hard to finish up the Waco, so he's there pretty regularly. I'll at least try to get out there for a bit this weekend & measure the firewall to axle distance on Sky Gypsy & will post it on the list when I do. Frank & his Dad built the plane out of 'conventional' materials A/C grade spruce & plywood, so without asking him, don't know why it's got the condition Chris was talking about, especially since he's just got a tail skid (no wheel) & that keeps the back end weight down some too. I don't recall seeing a chunk of lead on the motor mount when it was torn down for it's annual last Spring, but then I wasn't looking for one either! I'm not as worried about this so much on mine (yet!), since with the Corvair I'll have a chunk of lead up front by necessity - it's called a battery:). Regards, Kip Gardner North Canton, OH ________________________________________________________________________________
Date: Feb 03, 2003
--- John Dilatush wrote: > Dilatush" > > > ----- Original Message ----- > From: "Christian Bobka" <bobka(at)charter.net> > To: > Subject: RE: Pietenpol-List: Landing Gear Placement > ++++++++++++++++++++ > Chris, > > Good explanation, you are absolutely right! Piet > builders should understand > that wheel placement is relative to the center of > gravity of the entire mass > and to use an arbitrary measurement such as > "distance from the firewall" or > "in front of the leading edge" are only asking for > trouble. > > John As long as I have everything built, I'll bolt it together and see where I'm at. then change from there if need be. I will be using a sonex style tailwheel set up, which will cut weight by a good measure. and aid in controllability. thanks for the explanations. Del ===== Del-New Richmond, Wi "farmerdel(at)rocketmail.com" ________________________________________________________________________________
Date: Feb 03, 2003
In a message dated 2/3/03 7:18:52 AM Eastern Standard Time, dilatush(at)amigo.net writes: > When it came to the placement of the gear, I figured that I wanted to have > the ground contact of the wheels to be about 12 degrees forward of the CG. > Turned out to be perfect. I can use the brakes pretty hard without any > tendency to nose over, (the brakes are not that effective)yet it is light > enough on the tailwheel, (12 lbs) to handle easily on the ground. I am curious John, how did you arrive at the 12 degrees forward of the CG ? Or is that 12 inches ? -dennis ________________________________________________________________________________
Date: Feb 03, 2003
I owned a 1938 Aeronca chief at one time. The gear was far forward, to me it made a forgiving aircraft, and I think one would have had to worked hard to put it on the nose. The down side is it was hard to see out of when in the three point attitude. You had to land with your peripheral vision when three pointing. And it took a long time to get the nose up. But with the gear as far forward it put a lot of weight on the tail, and made it feal more positive to me. In retrospect my father-in-law has a Champ, and one day I was by myself in the front seat, during the run up with brakes set I relaxed the stick forward and almost put it on the nose, scared the crap out of me. With my Chief and his Champ side by side you could really tell how far forward the gear was on the Chief compared to his Champ. And it seems to me when I used to build model RC planes putting the gear farther forward help ground stability. Now I have not followed this discussion that well but felt like telling you guys this just in case it might help. If not nothing is lost. DNA Dan ________________________________________________________________________________
"Jim Skidmore" , "Jim Markle" , "Ron Oehler" , "Peter Denny" , "Pete Gavin" , "Pat Halligan" , "Mike Dolan" , "Jeff Coffey" , "Greg Cardinal" , "Frankh" , "Ed Hansen" , "David Kujawa" , "Dan Carroll" , "Chris Bobka" , "Ron Hoyt"
Subject: blast it
Date: Feb 04, 2003
Pete, Here it is. An attachment will come as well. I have pictures here at home to personally deliver on tuesday evening. Chris BLAST IT! Part VIII by Chris Bobka This series was discontinued after the seventh installment when son number two began to walk! That also coincided with David Kujawa leaving the chapter newsletter editorship and taking over editorship of Sport Aerobatics magazine and moving away to Arizona with his lovely wife, Diane. Instead of looking forward to dropping off articles at David and Diane's and sharing a few beers, I was frought with fear at having to bring articles to ugly Pete and Bob. I hope you can find me some forgiveness for leaving you all hanging. So sorry. Much prodding on the part of Pete, Greg, Frankh, and others from the Pietenpol chat group has gotten me back to finishing off the series with this final installment. We left off with the gauntlets ready for installation to the front of the box. I have included Figures 11 and 12 which show a cutting diagram for the gauntlet and what the finished gauntlet should look like. As shown in Figure 12, cut some darts into the big end of the gauntlet to help it lay flat as shown in Figure 13. Put some caulk around the left opening in the box and, using a heavy duty stapler, shoot some 1/4" staples into the box around the circumference of the glove to hold it in place. Don't do what Norm did so make sure you use the left handed gauntlet in the left hole of the box and make sure you orient the thumb so that it is at about the 12 o'clock position. If you put the wrong gauntlet on that hole, you will have to stand on the cieling in order to sandblast. Like Norm. Put more of the caulk on top of the gauntlet and then take one of the rings from Figure 3 and and use enough 1-1/4" drywall screws to hold the gauntlet in place. You can clean up any of the squeezed out caulk at this time. Install the other glove. Thumbs up! Next we need to install the door. You cut out the door opening in Figure 4 and at that time, I instructed you to save the cut out piece. Go get it. Have an assistant hold the cut out piece in the door opening. Take two old door hinges from the junk box and mark off the screw positions on the door and on the frame to the rear of the door. Ensure that the hinge pins lie directly over the cut line and the hinge lines are in line with each other. Now take the door piece and lay it onto another piece of plywood that is bigger than it. Mark off the same general shape but about 1-1/2 inches all the way around it EXCEPT for the rear edge. This mark off should be even with the rear edge of the door so the door can swing open. What we are making here is a piece of plywood that will overlap the door jamb so as to contain the direct blast of the sand. With your radial saw, cut out the new piece. As the hinges on the door must lay in the same plane as the box, it will be necessary to make cutouts to allow this new piece to clear the door. Cut these out with a sabre saw. The top and side views of Figure 14 clearly show this. You may design a better way and I know that there are better ways but this is the way I did it. Go for it! Make the latch as shown in Figure 14 from some scrap plywood. Attach the door and latch to the box. If you want, you can get some felt weatherstripping about 1/8" thick and 1/2-3/4" wide and put it around the door jamb as indicated to help contain some of the sand. An 1/8" looks thick but it will compress right down. Well that is it. The box is done. Now we have to come up with the gun. You want a good one. The reason is that the gun uses air that passes through a venturi in the gun to create suction which pulls the sand up from the hopper, through the feed tube, and through the venturi itself, accelerating the sand along the way. At the venturi, the sand makes a sharp turn before it exits the nozzle. My dad, the physicist, says that force times mass equals impact. We want impact as that is what does the sandblasting. Mass is related to the the size and density of the particle. Force is the effectiveness of the gun at accelerating the particle. Every particle of sand that comes out of the gun also is trying to wear down the venturi of the gun. A cheap ceramic nozzle coupled with a soft steel venturi will not last long as the sand will abrade it right down and the venturi will no longer be properly shaped to create a quality vacuum (if a vacuum sucks, is it good or bad?). Lots of air will come out of the nozzle but no abrasive. Then you will blame me that the sandblaster does not work. We need space age materials. We need titanium. We need carbide. So I will tell you what gun to get. It is shown in Figure 15. It is available at Grainger, among other places, and can be found on the internet as of February 2003 at: http://www.grainger.com/Grainger/catalogpageview.jsp?xi=xi&CatPage=1427 You want model 3JT01 for the 12 CFM model. It lists for a wopping 77 dollars but buddy Jim Markle at jim_markle(at)mindspring.com has agreed to purchase these guns from Grainger at his substantial discount and have them drop shipped to interested buyers. The best thing is that parts are available too as listed on the same web page. The gun does not have a trigger. You do not want a gun with a trigger. A gun with a trigger takes up too much room and your finger gets tired holding the trigger. Instead of a trigger, I merely connect and disconnect a Milton coupling right at the aft end of the gun. You could get fancy and use a foot pedal air switch or you could put a valve at the point where the air line goes into the box. Use what you think you would like. Once you have your gun, attach it to the end of the pickup tube inside the box with an appropriate length of 5/8" ID cheap clear vinyl tubing from the big rack of tubing at Home Depot that I told you to get earlier. Use some hose clamps to hold the hose on at both ends. Drill the smallest size hole you can get away with to let the air line into the box. It should be located near where the pickup tube is located so that both hoses can flop around more or less together. You need a vacuum cleaner of the big shop vac variety. This is a necessity as you are creating a mammoth sandstorm inside the box. Without a shop vac, it will be so cloudy inside the box after a minute that you won't be able to see your hand in front of your face. You are pumping air into the box at 100 PSI and at 11-15 Cubic Feet per Minute. All the air has to go somewhere. If there is no shop vac then this air will blow out through every seam and put dust all over the garage and make a big mess. It will also go into your lungs and you will contract silicosis and die a horrible slow death. The key is to create a negative pressure inside the box so that the dust is trapped by the filter of the shop vac. Better yet, use an extra long vacuum hose and put the shop vac outside as even the filter on the shop vac won't trap all the fines. Their are endless varieties of abrasives to use. I use number five white silica sand. You can remember number five as that is how many fingers you should have on one of your hands. It is the same stuff that you see in sand filled ashtrays next to the door to elevators in office buildings. Many sandblasting supply outfits are reluctant to sell you sand for sandblasting beacuse they are afraid you will not be using proper breathing protection and they will be sued by your hiers after you die of silicosis. If you tell them it is for ashtrays, then they will chum right up and gladly sell it to you. It will come in 50 or 100 lb sacks. 100 lbs should do for starters. Dick Navratril, a Pietenpol builder here in the Twin Cities area (horzpool(at)goldengate.net), says you could also try a larger swimming pool dealer to get sand. In his swimming pool supply shop, he carries red flint granite sand sized at .45-.55 mm. It is rather aggressive but doesn't dust nearly as much as white silica sands. Some may try to use glass beads or walnut shells. It all depends upon the finish you wish, the aggressiveness of the cleaning, and the price you are willing to pay. You may consider building more than one sandblasting box. Each can have a different abrasive. It is difficult to change abrasives from big to little for the following reason: you will probably never get all the big stuff out. What will happen is that you will make a change from big particles to little particles. You will think you have it licked and you will be blasting away looking at the fine, uniform finish on your blasted piece. Just as the ten millionth particle comes out of the nozzle, a stray big particle will come out, and whamo! there appears what will looks like a huge crater in your work as that single particle hits. It may not bother you and it may not matter based on the part you are blasting but sometime it may matter. Again, the choice is yours. Once my new hangar is done, it will sport a couple of blasting boxes each with a different abrasive. Additonal abrasives management discussion is outside the scope of this article. I am sure that industrious users of their new blast cabinet will seek out information on http://www.google.com for more information. A few tips on use are in order. All the debris you blast off of the pieces you are sandblasting will fall down into the sand. Eventually, they will migrate to the bottom of the hopper as it becomes their "turn" to be sucked into the pickup tube. Large pieces of debris will clog the venturi of the gun. The short term fix is to hold your free hand over the discharge nozzle of the gun, forcing the compressed air down the hose abrasive supply hose and the pickup tube and blowing all the junk out. This will work for a while but sooner or later you will have to empty the abrasive out the bottom of the hopper and sift it. I use a big sifter from the cookingware aisle of the supermarket that looks like a bowl made out of screening. This is the long term fix. Use a pair of pliers kept in the box to hold small parts so you are not always blasting away at the fingertips of your gloves as you hold parts. The box makes for really good storage of parts that must be kept rust free. The large quantity of sand acts as a dessicant to keep the air in the box dry. You can also experiment with different air pressures. 50-60 PSI works good for most work. It is hard for many air compressors to keep this up at 12 CFM so from time to time you need to give the air compressor a chance to catch up. Also, most air compressors have a duty cycle which means that it is expected that a certain percentage of the time, the air compressor should be off and resting. It cools when it rests. You may consider a supplemental fan blowing on your air compressor to keep it cool. Do not take stuff out of the blaster unless you have gloves on. The pros say to use surgical gloves. Oils and acids from your skin will cause the part to rust, even under paint. As stressed in the beginning of this series of articles, moisture is the bane of all sandblasters. you must have adequate moisture control in your system. The ideal air supply system uses many feet of metal, not plastic or rubber, air line between the compressor and the sandblaster. The metal absorbs the heat from the compressed air. As the compressed air cools, the water in it will condense out and deposit, in the form of water droplets, onto the inside surface of the cool pipe. As the air passes through the pipe it will roll these droplets along until they hit a moisture trap that will inertially snag them and keep them from traveling further. It is important to note that moisture traps trap water droplets, not water vapor. Putting a mositure trap at the compressor outlet will not do much good since the air will carry mostly vapor here as the air is so hot. The best "final" moisture trap I know of is the 1/2" coalescing air filter as illustrated in Figure 16 and sold by Tip Sandblasting at 1-800-321-9260. It uses a roll of toilet paper inside the unit to absorb all remaining mositure after the air has traveled through the standard inertial moisture traps of your system. The price is up there on this unit bust the performance is spectacular. Finally, as you sandblast and between sips of Guiness, USE PROTECTIVE BREATHING EQUIPMENT APPROPRIATE FOR SANDBLASTING. If it is good for wearing while doing drywall work, it should be good for sandblasting but read the labels on the devices you might want to use! Also, use hearing protection if you have the shop vac next to you. Ideally you can use a Walkman and its little earplug type earpieces under your hearing protectors so you can listen to the Grateful Dead as you blast away. Good luck with your new unit and try to imagine how life was before you had it! ________________________________________________________________________________
Subject: I added this too
Date: Feb 04, 2003
Jim et al, I forgot to add this as the second to last paragraph: Jim Markle has posted ten pictures of his box on a website for viewing: http://www.shutterfly.com/osi.jsp?i=67b0de21b3322ee6e4b7 thanks. Chris ________________________________________________________________________________
Subject: Ron skip and John
Date: Feb 04, 2003
Ron butcher, Skip Gadd, and John Dilatush, I am working this evening on finishing up the end of the sandblaster articles and putting all the drawings in useable format for your use. Please bear with me. I will have the stuff in the mail by next monday. Thanks for your patience. Chris ________________________________________________________________________________
Date: Feb 03, 2003
Subject: Re: Question about Gross Weight
I have a formula for " minimum safe horsepower" around here somewhere. I believe it's based on the minimum hp that will provide a climb of 300 ft/min. The ford A hp comes out right at that figure. So my assumption has been that the power available was the original bases for Bernards choice of gross weight. Now that we have more powerful engines in use the gross wt can be optimized for other parameters, with safety in mind, of course. As Jack has pointed out we must be carefull in our assumptions. One question is how come the new plans come with a 3/4" spar when the original was 1"? Who determined that this is safe? Who performed the necessary calculations? Where can we see these and what design load was used? What are the permissable G loads with this spar? The answers are important to us now that we have overcome the original power limitations. Clif. ----- Original Message ----- From: "Jack Phillips" <jackphillips(at)earthlink.net> Subject: RE: Pietenpol-List: Question about Gross Weight > > Jon, > > Chris is right, up to a point. The gross weight is basically set by some > structural parameter in the aircraft, usually the wing spar or the landing > gear. You hear of a plane being stressed to +/- 10 G's, well that means > the structure can handle a certain limit load, and depending on how many G's > the designer wants the plane to be good for, he divides the limit load by > that number of G's and voila - the gross weight pops out! > > When I was a young engineer just out of college and was working for General > Dynamics on the F-16 initial design (sad that a plane designed in 1975 is > still one of our front line fighters), the initial gross weight of the plane > was 23,000 lbs. (which meant it could go supersonic straight up with its > 25,000 lb. thrust engine). Later, some mods to the landing gear enabled it > to takeoff with more fuel on board in external tanks and the takeoff gross > weight was increased to 37,000 lbs, but its maneuvering gross weight was > still 23,000. > > In other words, the gross weight is somewhat arbitrary. However, be aware > that stall speed is a variable and goes up with gross weight. It is quite > possible with a robust structured airplane to have a gross weight that is > structurally safe but simply can't fly because the stall speed is too high. > > For my Pietenpol, I've figured on a gross weight of around 1100 lbs. > > Jack > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Christian > Bobka > Sent: Sunday, February 02, 2003 11:36 PM > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Question about Gross Weight > > > Jon, > > For an experimental, it is whatever you want it to be. Believe it or not. > You set the rules. No kidding. > > Chris Bobka > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Jon > Botsford > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Question about Gross Weight > > > > Can someone on this list tell me how the Gross Weight is calculated for an > aircraft? > > Jon Botsford > > ________________________________________________________________________________
Subject: wire wheels for sale
Date: Feb 04, 2003
I am selling a pair of wire wheels I had intended to put on my Piet. These are an original pair of wheels from the early 1920's. They are size 24x4 which is called for in some of the Piet plans. Some Jennies came with this same wheel, but these are not clinchers, they are drop-center. Of course, they do not have brakes. These are the same wheels that are on the Golden Age Air Museum's model A Piet in Pennsylvania, and you can see a photo on their web site. 24x4 means that the wheel is 16" in diameter and the tire is 4" tall, for a total of 24". The axle size is 1 1/2, correct size for the Piet. When I bought the wheels, I disassembled them while I was working at the Air & Space facility at Silver Hill. We soaked them in several chemical baths to remove all rust and coat the metal. I primed them with chromated black paint and clear coated over that. The wheels had some surface rust which has left the surface with a "textured" look from light surface pitting, but they are not damaged or weakened. I had planned to cover them with fabric anyway. I ordered all new spokes from Buchanan's and trued the wheels. It was everyone's opinion that these wheels have never been mounted on an airplane due to the lack of wear marks on the bronze bushings. I have quite a bit invested in the wheels, but if someone really wants them I am willing to negotiate. I have found anopther pair of wire wheels that are a different size and I like better. Anyone that is interested please e-mail me and let me know what you would give for these. Gene ________________________________________________________________________________
Date: Feb 04, 2003
----- Original Message ----- From: <Dmott9(at)aol.com> Subject: Re: Pietenpol-List: Landing Gear Placement +++++++++++++++++++ Dennis, That measurement is 12 degrees, which is a line drawn from the calculated center of gravity of the entire plane swung forward of vertical 12 degrees to the point of ground contact of the wheel. This measurement depends on the usage of plane and can vary from about 10.5 to as much as 20 degrees. At the minimum of 10.5 degrees, you would find on a plane that doesn't have brakes and a low CG. At the other end of the scale you might have a design such as a Helio Courier with a high CG and used for short fields and heavy braking. David Thurston in his book "Design for Flying" suggests 16.5 degrees as the average for a certified aircraft. However remember that the further forward the gear is, the greater tendency to ground looping and the harder it is to raise the tail on take off. I used 12 degrees arbitrarily and have found it perfect for a Pietenpol. Hope this helps, John D. +++++++++++++++++++++++++ > > In a message dated 2/3/03 7:18:52 AM Eastern Standard Time, > dilatush(at)amigo.net writes: > > > When it came to the placement of the gear, I figured that I wanted to have > > the ground contact of the wheels to be about 12 degrees forward of the CG. > > Turned out to be perfect. I can use the brakes pretty hard without any > > tendency to nose over, (the brakes are not that effective)yet it is light > > enough on the tailwheel, (12 lbs) to handle easily on the ground. > > I am curious John, how did you arrive at the 12 degrees forward of the CG ? > Or is that 12 inches ? > -dennis > > ________________________________________________________________________________
Date: Feb 04, 2003
Dave, I would be very interested in seeing this if you are able to scan and post. Don Hicks ________________________________________________________________________________
Date: Feb 04, 2003
To all, Thanks for you insight on gross weight. It is very helpful. jon b ----- Original Message ----- From: "clif" <cdawson5854(at)shaw.ca> Subject: Re: Pietenpol-List: Question about Gross Weight > > I have a formula for " minimum safe horsepower" > around here somewhere. I believe it's based on > the minimum hp that will provide a climb of 300 ft/min. > The ford A hp comes out right at that figure. So > my assumption has been that the power available > was the original bases for Bernards choice of gross > weight. Now that we have more powerful engines > in use the gross wt can be optimized for other > parameters, with safety in mind, of course. As Jack > has pointed out we must be carefull in our assumptions. > > One question is how come the new plans come with > a 3/4" spar when the original was 1"? Who determined > that this is safe? Who performed the necessary > calculations? Where can we see these and what > design load was used? What are the permissable > G loads with this spar? > > The answers are important to us now that we have > overcome the original power limitations. > Clif. > ----- Original Message ----- > From: "Jack Phillips" <jackphillips(at)earthlink.net> > To: > Subject: RE: Pietenpol-List: Question about Gross Weight > > > > > > > Jon, > > > > Chris is right, up to a point. The gross weight is basically set by some > > structural parameter in the aircraft, usually the wing spar or the landing > > gear. You hear of a plane being stressed to +/- 10 G's, well that means > > the structure can handle a certain limit load, and depending on how many > G's > > the designer wants the plane to be good for, he divides the limit load by > > that number of G's and voila - the gross weight pops out! > > > > When I was a young engineer just out of college and was working for > General > > Dynamics on the F-16 initial design (sad that a plane designed in 1975 is > > still one of our front line fighters), the initial gross weight of the > plane > > was 23,000 lbs. (which meant it could go supersonic straight up with its > > 25,000 lb. thrust engine). Later, some mods to the landing gear enabled > it > > to takeoff with more fuel on board in external tanks and the takeoff gross > > weight was increased to 37,000 lbs, but its maneuvering gross weight was > > still 23,000. > > > > In other words, the gross weight is somewhat arbitrary. However, be aware > > that stall speed is a variable and goes up with gross weight. It is quite > > possible with a robust structured airplane to have a gross weight that is > > structurally safe but simply can't fly because the stall speed is too > high. > > > > For my Pietenpol, I've figured on a gross weight of around 1100 lbs. > > > > Jack > > > > -----Original Message----- > > From: owner-pietenpol-list-server(at)matronics.com > > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Christian > > Bobka > > Sent: Sunday, February 02, 2003 11:36 PM > > To: pietenpol-list(at)matronics.com > > Subject: RE: Pietenpol-List: Question about Gross Weight > > > > > > > Jon, > > > > For an experimental, it is whatever you want it to be. Believe it or not. > > You set the rules. No kidding. > > > > Chris Bobka > > > > -----Original Message----- > > From: owner-pietenpol-list-server(at)matronics.com > > [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Jon > > Botsford > > To: pietenpol-list(at)matronics.com > > Subject: Pietenpol-List: Question about Gross Weight > > > > > > > > > Can someone on this list tell me how the Gross Weight is calculated for an > > aircraft? > > > > Jon Botsford > > > > > > ________________________________________________________________________________
Subject: some sources on gear position
Date: Feb 04, 2003
I did some research in my extensive aeronautical library and have turned up the following: Source: Aircraft Design Vol II Aero Structures by Cecil Hugh Latimer-Needham published 1939 says: "The point of wheel contact with the ground [not the axle centerline] should make an angle with the vertical through the CG in side elevation (aircraft rigging position) of not less than 10 degrees, and may increase with wheel brakes up to a maximum of 14 degrees. The tendency of aircraft to overturn when landing with wheel brakes may be provided against by arranging for the brakes to be released as the tail skid leaves the ground. It has been found, however, that if the angle, made by the line joining the point of wheel contact [not the axle centerline] to the CG with the vertical through the CG when the tail skid is touching, is at least 20 degrees no overturning is likely. An angle much greater than 20 degrees results in excessive tail loads at landing and difficulty in taxi-ing and at takeoff. It may be noted that the overturning tendency is not great at the moment of touching down, since the aircraft is still largely airborne and skidding of the wheels takes place. Towards the end of the run both aerodynamic lift and control are negligible, the braking effect increases and for safety the braking laod should be decreased." Latimer-Needham is an Englishman. rigging position refers to tail elevated so that upper longereons on the piet are level. Source: Prelimiary Aircraft Design by R. C. Wilson published 1941 says, in the context of drawing a side elevation with the tail in rigging position, as defined above: "E. Location of the Landing Gear (Main Wheels and Tail Wheel System) From the assumed CG draw a line downward and forward making the vertical an angle of not more than 20 degrees nor less than 12 degrees. The former angle should be used when extremely effective brakes are to be used, the latter when no wheel brakes whatever are contemplated. A fair normal figure for ordinary wheels and brakes is 18 degrees. The axle of the main wheels [not the point of wheel contact with the ground], with shock absorbers fully compressed, will lie on this diagonal line." Wilson is from the U.S. I added the comments in the [ ] for emphasis. Note that the Brits define the diagonal line as that from the CG through THE WHEEL POINT OF CONTACT WITH THE GROUND. The Americans define the diagonal as that from the CG through THE AXLE CENTERLINE. The diameter of the wheel, therfore, comes into play in the British scenario. I hope this helps. Chris Bobka ________________________________________________________________________________
Date: Feb 04, 2003
Clif, I've often wondered those things too. But just to add....... was in a hanger and saw an Aeronca (don't know which model) wing with the fabric ripped off. It's amazing to see, the wing had 3/4" wood spars. They look like a skinny piece of book shelf. Since then I've pulled some "G's" in one doing steep turns. That memory always pops in my head at those times. walt ----- Original Message ----- From: "clif" <cdawson5854(at)shaw.ca> Subject: Re: Pietenpol-List: Question about Gross Weight > <<>> >> One question is how come the new plans come with > a 3/4" spar when the original was 1"? Who determined > that this is safe? Who performed the necessary > calculations? Where can we see these and what > design load was used? What are the permissable > G loads with this spar? > > The answers are important to us now that we have > overcome the original power limitations. > Clif. > ----- Original Message ----- > From: "Jack Phillips" <jackphillips(at)earthlink.net> > To: > Subject: RE: Pietenpol-List: Question about Gross Weight > > > > > > > Jon, > > > > Chris is right, up to a point. The gross weight is basically set by some > > structural parameter in the aircraft, usually the wing spar or the landing > > gear. You hear of a plane being stressed to +/- 10 G's, well that means > > the structure can handle a certain limit load, and depending on how many > G's > > the designer wants the plane to be good for, he divides the limit load by > > that number of G's and voila - the gross weight pops out! > > > > When I was a young engineer just out of college and was working for > General > > Dynamics on the F-16 initial design (sad that a plane designed in 1975 is > > still one of our front line fighters), the initial gross weight of the > plane > > was 23,000 lbs. (which meant it could go supersonic straight up with its > > 25,000 lb. thrust engine). Later, some mods to the landing gear enabled > it > > to takeoff with more fuel on board in external tanks and the takeoff gross > > weight was increased to 37,000 lbs, but its maneuvering gross weight was > > still 23,000. > > > > In other words, the gross weight is somewhat arbitrary. However, be aware > > that stall speed is a variable and goes up with gross weight. It is quite > > possible with a robust structured airplane to have a gross weight that is > > structurally safe but simply can't fly because the stall speed is too > high. > > > > For my Pietenpol, I've figured on a gross weight of around 1100 lbs. > > > > Jack > > > > -----Original Message----- > > From: owner-pietenpol-list-server(at)matronics.com > > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Christian > > Bobka > > Sent: Sunday, February 02, 2003 11:36 PM > > To: pietenpol-list(at)matronics.com > > Subject: RE: Pietenpol-List: Question about Gross Weight > > > > > > > Jon, > > > > For an experimental, it is whatever you want it to be. Believe it or not. > > You set the rules. No kidding. > > > > Chris Bobka > > > > -----Original Message----- > > From: owner-pietenpol-list-server(at)matronics.com > > [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Jon > > Botsford > > To: pietenpol-list(at)matronics.com > > Subject: Pietenpol-List: Question about Gross Weight > > > > > > > > > Can someone on this list tell me how the Gross Weight is calculated for an > > aircraft? > > > > Jon Botsford > > > > > > ________________________________________________________________________________
Date: Feb 04, 2003
Subject: Re: some sources on gear position
Chris does aircraft rigging position refer to the plane positioned- tail up - as if it were flying in straight and level? Henry Williams trying to decide on dihedral: yes or no ________________________________________________________________________________
Date: Feb 04, 2003
Subject: Re: long fuse gear
Dick N Not ready for W/B yet. Have the wings covered but not the fuselage Moved the wing back 3 " Moved the engine forward 1.5 " Put on a heavy prop. I hope we are close. Dale ________________________________________________________________________________
Subject: my feeelings on dihedral
Date: Feb 04, 2003
Date: Dec 31, 2000 From: Christian Bobka Subject: Re: dihedral Why mess with the dihedral. Every aircraft has apparent dihedral (what you see) and effective dihedral (what you get). Successful aircraft designs without dihedral or anhedral or negative dihedral have enough effective dihedral to provide the stability required. Such things as a slab sided fuselage (like the Piet or a Taylorcraft, for example) create a lot of effective dihedral. Some airplanes like the C-141 Starlifter and the Avro BAE 146/RJ-85 had so much effective dihedral early in their design phase that a lot of negative dihedral was necessary to get the aircraft's stability in a desirable range. In a side slip/gust upset, air gets dammed up under the wing and against the fuselage and provides way too much corrective action so the negative dihedral is used to correct this characteristic. So the bottom line is why change something that ain't broke. Did not Bernard do all the tinkering for us and found the right combination? Just think. In a correctly designed aircraft, if a vertical gust upsets the left wing, lifting it up, the aircraft sideslips a little to the right, creating a little more lift on the right side, bringing the right wing up THE SAME AMOUNT as the left wing went up initially. SO....a little rudder action on your part to keep it heading the way you were going and the plane flies sweet. Add a little dihedral, THAT IS NOT NEEDED, and the scenario goes like this. A vertical gust upsets the left wing, lifting it up, and the aircraft sideslips a little to the right. But there is too much effective dihedral, so a little more lift is created on the right side during the sideslip and it is more than what is needed to right the aircraft. So the right wing goes up a little more than the left wing did initially. This has the same effect of having a gust upset from the right. Now the aircraft sideslips a little to the left.... And there you go, round and round. A miserable airplane to fly because it has too much stability. As an exercise, think about what would happen if you did not have enough effective dihedral. Read old issues of Kitplanes where Barnaby Wainfan discusses dihedral effect. Or read Perkins and Hage's Aircraft Stability and Control. Or read Aerodynamics for Naval Aviators. If you still don't get it, then pull out your trusty copy of Langewiesche's Stick and Rudder. It is all there. Leave it alone. ________________________________________________________________________________
Date: Feb 04, 2003
Dale, In a nutshell it sounds like my Piet. My WB came in at the rear CG with my 200+ arse. I built to plans for the long fuselage. You shouldn't have any probs. walt ----- Original Message ----- From: "D.Dale Johnson" <dd5john(at)juno.com> Subject: Re: Pietenpol-List: long fuse gear > > Dick N > Not ready for W/B yet. > Have the wings covered but not the fuselage > Moved the wing back 3 " > Moved the engine forward 1.5 " > Put on a heavy prop. > I hope we are close. > Dale > > ________________________________________________________________________________
Subject: Re: my feeelings on dihedral
Date: Feb 04, 2003
the only reason I'm adding a tad of dihedral is to kill the "drooping wing" visual effect of a straight winged Piet. DJ Vegh N74DV www.raptoronline.com Mesa, AZ ----- Original Message ----- From: "Christian Bobka" <bobka(at)charter.net> Subject: Pietenpol-List: my feeelings on dihedral > > Date: Dec 31, 2000 > From: Christian Bobka > Subject: Re: dihedral > > Why mess with the dihedral. Every aircraft has apparent dihedral (what you > see) and effective dihedral (what you get). Successful aircraft designs > without dihedral or anhedral or negative dihedral have enough effective > dihedral to provide the stability required. Such things as a slab sided > fuselage (like the Piet or a Taylorcraft, for example) create a lot of > effective dihedral. Some airplanes like the C-141 Starlifter and the Avro > BAE 146/RJ-85 had so much effective dihedral early in their design phase > that a lot of negative dihedral was necessary to get the aircraft's > stability in a desirable range. In a side slip/gust upset, air gets dammed > up under the wing and against the fuselage and provides way too much > corrective action so the negative dihedral is used to correct this > characteristic. > > So the bottom line is why change something that ain't broke. Did not > Bernard do all the tinkering for us and found the right combination? > > Just think. In a correctly designed aircraft, if a vertical gust upsets the > left wing, lifting it up, the aircraft sideslips a little to the right, > creating a little more lift on the right side, bringing the right wing up > THE SAME AMOUNT as the left wing went up initially. SO....a little rudder > action on your part to keep it heading the way you were going and the plane > flies sweet. Add a little dihedral, THAT IS NOT NEEDED, and the scenario > goes like this. A vertical gust upsets the left wing, lifting it up, and > the aircraft sideslips a little to the right. But there is too much > effective dihedral, so a little more lift is created on the right side > during the sideslip and it is more than what is needed to right the > aircraft. So the right wing goes up a little more than the left wing did > initially. This has the same effect of having a gust upset from the right. > Now the aircraft sideslips a little to the left.... And there you go, > round and round. A miserable airplane to fly because it has too much > stability. > > As an exercise, think about what would happen if you did not have enough > effective dihedral. > > Read old issues of Kitplanes where Barnaby Wainfan discusses dihedral > effect. Or read Perkins and Hage's Aircraft Stability and Control. Or > read Aerodynamics for Naval Aviators. If you still don't get it, then pull > out your trusty copy of Langewiesche's Stick and Rudder. It is all there. > > Leave it alone. > > This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>. ________________________________________________________________________________
Subject: Question about Gross Weight
Date: Feb 04, 2003
Citabrias also have 3/4" spars, as do Pitts Specials and many other aerobatic planes. 1" is overkill, which is why BHP routed them down. I used 3/4" spars fore and aft in my Piet. Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of walter evans Subject: Re: Pietenpol-List: Question about Gross Weight Clif, I've often wondered those things too. But just to add....... was in a hanger and saw an Aeronca (don't know which model) wing with the fabric ripped off. It's amazing to see, the wing had 3/4" wood spars. They look like a skinny piece of book shelf. Since then I've pulled some "G's" in one doing steep turns. That memory always pops in my head at those times. walt ----- Original Message ----- From: "clif" <cdawson5854(at)shaw.ca> Subject: Re: Pietenpol-List: Question about Gross Weight > <<>> >> One question is how come the new plans come with > a 3/4" spar when the original was 1"? Who determined > that this is safe? Who performed the necessary > calculations? Where can we see these and what > design load was used? What are the permissable > G loads with this spar? > > The answers are important to us now that we have > overcome the original power limitations. > Clif. > ----- Original Message ----- > From: "Jack Phillips" <jackphillips(at)earthlink.net> > To: > Subject: RE: Pietenpol-List: Question about Gross Weight > > > > > > > Jon, > > > > Chris is right, up to a point. The gross weight is basically set by some > > structural parameter in the aircraft, usually the wing spar or the landing > > gear. You hear of a plane being stressed to +/- 10 G's, well that means > > the structure can handle a certain limit load, and depending on how many > G's > > the designer wants the plane to be good for, he divides the limit load by > > that number of G's and voila - the gross weight pops out! > > > > When I was a young engineer just out of college and was working for > General > > Dynamics on the F-16 initial design (sad that a plane designed in 1975 is > > still one of our front line fighters), the initial gross weight of the > plane > > was 23,000 lbs. (which meant it could go supersonic straight up with its > > 25,000 lb. thrust engine). Later, some mods to the landing gear enabled > it > > to takeoff with more fuel on board in external tanks and the takeoff gross > > weight was increased to 37,000 lbs, but its maneuvering gross weight was > > still 23,000. > > > > In other words, the gross weight is somewhat arbitrary. However, be aware > > that stall speed is a variable and goes up with gross weight. It is quite > > possible with a robust structured airplane to have a gross weight that is > > structurally safe but simply can't fly because the stall speed is too > high. > > > > For my Pietenpol, I've figured on a gross weight of around 1100 lbs. > > > > Jack > > > > -----Original Message----- > > From: owner-pietenpol-list-server(at)matronics.com > > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Christian > > Bobka > > Sent: Sunday, February 02, 2003 11:36 PM > > To: pietenpol-list(at)matronics.com > > Subject: RE: Pietenpol-List: Question about Gross Weight > > > > > > > Jon, > > > > For an experimental, it is whatever you want it to be. Believe it or not. > > You set the rules. No kidding. > > > > Chris Bobka > > > > -----Original Message----- > > From: owner-pietenpol-list-server(at)matronics.com > > [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Jon > > Botsford > > To: pietenpol-list(at)matronics.com > > Subject: Pietenpol-List: Question about Gross Weight > > > > > > > > > Can someone on this list tell me how the Gross Weight is calculated for an > > aircraft? > > > > Jon Botsford > > > > > > ________________________________________________________________________________
"pietenpol"
Subject: RE: fuel gauges
Date: Feb 04, 2003
Eddie, Follow these rules: The tank in the fusealge is the main tank. The tank in the wing is and auxialry tank. The fuselage tank must be no closer than 1/2 inch to the firewall. Both tanks must be vented and vented in such a manner is to prevent ice formation on the vent (even in florida). Both tanks must have a sump and sump drain at their lowest point in a parked attitude. Air must be able to circulate around the tanks somehow and fumes and liquid fuel must be able to escape down and out from the space beneath the tanks. The fuel for engine use will not be drawn from the main tank at the sump but at some point higher than the sump. Test pressure is 3-1/2 psi for the tanks. And what you asked for: "Where two or more tanks are interconnected and it is impossible to feed from each one separately, only one fuel-level gauge need be installed." Obviously the gauge is for the main tank only as the aux tank will drain into the main tank. Copper fuel lines must be annealed after they are bent. Ed, I hope this helps. chris -----Original Message----- From: Ed Grentzer [mailto:flyboy_120(at)hotmail.com] Subject: fuel gauges Hi Chris...How's it going...good luck with your D.A.R. application..We definitely need more qualitied D.A.R.s out there. I have a technical question..I'm building a 7.5 gallon wing tank for the forward 15" of my center section. Behind the tank will be a small baggage compartment. I'm trying to keep the cg forward as much as I can so this tank is centered above the most fwd/rearward recommended cg measurements. The function of the wing tank will just be to replenish the cowl tank during flight. I think Walt Evans has a similar set up but with a full sized wing tank. Anyhoo..I read somewhere that "each fuel tank must have a fuel quantity gauge" My question is if a tank is only used to refill a tank which has a gauge does that tank ( the wing tank) have to have a gauge?? My tank mold is finished but if I HAVE TO install a gauge now would be the time to add the sender boss to the mold. Thanks in advance. Ed G. ________________________________________________________________________________
Date: Feb 04, 2003
Bernie routed down the center portions of his spars to save weight but didn't rout the spar caps. The material in the center of a beam (spar) in bending does very little other than carry shear loads. This is why there are many spars with the "beef" located at the top and bottom with only a plywood shear web between the caps. A much more important measurement than the spar thickness is the spar's width, from top to bottom. Before we go writing off Bernie's spars as overkill on thickness, lets do a real comparison with these other famously strong wings that includes spar width, length of the wing in actual bending (the Piet wing inboard of the strut attach points sees less bending load than the outboard portion), comparable flight loads, etc. A blanket statement that 1" is overkill because something like a Pitts has thinner spars is not really supportable. The experiences of a very large number of builders who have successfully and safely flown 3/4" spars is certainly more reliable than comparing apples and oranges, but I'm not sure anyone has any idea how much safety margin is left over when pulling significant flight loads on spars thinner than designed. Mike Jack Phillips wrote: > > Citabrias also have 3/4" spars, as do Pitts Specials and many other > aerobatic planes. 1" is overkill, which is why BHP routed them down. I > used 3/4" spars fore and aft in my Piet. > > Jack ________________________________________________________________________________
Subject: I discoverd something
Date: Feb 04, 2003
While researching dihedral I learned that the word meaning "negative dihedral" is the word "cathedral". I never could remember whether a cathode was negative or positive. Now I will remember a Cathode is negative... chris bobka ________________________________________________________________________________
Subject: Re: I discoverd something
Date: Feb 04, 2003
hmmm I've always known it as "anhedral" DJ Vegh N74DV www.raptoronline.com Mesa, AZ ----- Original Message ----- From: "Christian Bobka" <bobka(at)charter.net> Subject: Pietenpol-List: I discoverd something > > While researching dihedral I learned that the word meaning "negative > dihedral" is the word "cathedral". I never could remember whether a cathode > was negative or positive. Now I will remember a Cathode is negative... > > chris bobka > This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>. ________________________________________________________________________________
Date: Feb 04, 2003
Chris, In the R/C soaring group I run with, they call negative dihedral, "annhedral", ever hear that one? Doug Blackburn Doug/Elizabeth Blackburn Yucaipa California Inland Slope Rebels, Riverside Ca. http://inlandsloperebels.com ----- Original Message ----- From: "Christian Bobka" <bobka(at)charter.net> Subject: Pietenpol-List: I discoverd something > > While researching dihedral I learned that the word meaning "negative > dihedral" is the word "cathedral". I never could remember whether a cathode > was negative or positive. Now I will remember a Cathode is negative... > > chris bobka > > ________________________________________________________________________________
Date: Feb 04, 2003
DJ, The prefixes A or AN mean "without" so anhedral is no dihedral and no cathedral. Atheist meaning without God and anonymous meaning without name. Chris Bobka -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of DJ Vegh Subject: Re: Pietenpol-List: I discoverd something hmmm I've always known it as "anhedral" DJ Vegh N74DV www.raptoronline.com Mesa, AZ ----- Original Message ----- From: "Christian Bobka" <bobka(at)charter.net> Subject: Pietenpol-List: I discoverd something > > While researching dihedral I learned that the word meaning "negative > dihedral" is the word "cathedral". I never could remember whether a cathode > was negative or positive. Now I will remember a Cathode is negative... > > chris bobka > This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>. ________________________________________________________________________________
Date: Feb 04, 2003
Doug, I think words take on meanings of their own, despite their Latin roots. My references are books from the 'thirties. chris -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of TWINBOOM Subject: Re: Pietenpol-List: I discoverd something Chris, In the R/C soaring group I run with, they call negative dihedral, "annhedral", ever hear that one? Doug Blackburn Doug/Elizabeth Blackburn Yucaipa California Inland Slope Rebels, Riverside Ca. http://inlandsloperebels.com ----- Original Message ----- From: "Christian Bobka" <bobka(at)charter.net> Subject: Pietenpol-List: I discoverd something > > While researching dihedral I learned that the word meaning "negative > dihedral" is the word "cathedral". I never could remember whether a cathode > was negative or positive. Now I will remember a Cathode is negative... > > chris bobka > > ________________________________________________________________________________
Date: Feb 04, 2003
wow.... learn sumthin' new every day..... DJ Vegh N74DV www.raptoronline.com Mesa, AZ ----- Original Message ----- From: "Christian Bobka" <bobka(at)charter.net> Subject: RE: Pietenpol-List: I discoverd something > > DJ, > > The prefixes A or AN mean "without" so anhedral is no dihedral and no > cathedral. Atheist meaning without God and anonymous meaning without name. > > Chris Bobka > This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>. ________________________________________________________________________________
Date: Feb 05, 2003
OK, I should know better than to make blanket statements like "1" is overkill". Good points, Mike. Citabria spars are (I believe) six inches in height, but they are also several feet longer than Pietenpol spars. I was responding to the remark that some Aeroncas used 3/4" spars. I think 3/4" is a much more common thickness than 1". Before deciding on 3/4" spars for my bird, I ran a quick stress analysis, with a number of assumptions: 3/4" spars Gross weight 1050 lbs 65% of load carried by front spar, 35% by rear spar ultimate tensile stress for Sitka Spruce is 9400 psi no load carried by centersection (actually a pretty fair assumption, it turns out) even lift distribution over entire spar length The result was that with the lift strut fittings as designed by BHP (not in-line with the struts as modern ones are) the wing is good for about 4.9 G's. If a more modern lift strut attach point is used, which doesn't impart its own bending moment to the spar, the wing is only good for 3.92 G's These are ultimate loads, and I wouldn't expect the wing to survive too long at these loads. This was enough to convince me that Pietenpols have no business doing aerobatics, but are plenty strong for normal fun flying. Jack -----Original Message----- Bernie routed down the center portions of his spars to save weight but didn't rout the spar caps. The material in the center of a beam (spar) in bending does very little other than carry shear loads. This is why there are many spars with the "beef" located at the top and bottom with only a plywood shear web between the caps. A much more important measurement than the spar thickness is the spar's width, from top to bottom. Before we go writing off Bernie's spars as overkill on thickness, lets do a real comparison with these other famously strong wings that includes spar width, length of the wing in actual bending (the Piet wing inboard of the strut attach points sees less bending load than the outboard portion), comparable flight loads, etc. A blanket statement that 1" is overkill because something like a Pitts has thinner spars is not really supportable. The experiences of a very large number of builders who have successfully and safely flown 3/4" spars is certainly more reliable than comparing apples and oranges, but I'm not sure anyone has any idea how much safety margin is left over when pulling significant flight loads on spars thinner than designed. Mike ________________________________________________________________________________
Date: Feb 05, 2003
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
Chris-- Wow. What an interesting post you had about dihedral. My feelings on dihedral are that I think just a titch of it in a Piet makes the wing look a bit better. (like it's not sagging at the tips.) Guess my approach to building is one of pleasing my eye in some instances. Good post though ! Mike C. 18 F in Cleve. ________________________________________________________________________________
Date: Feb 05, 2003
I thought is was anhedral. When I spell check it, the correction comes up "cathedral." Anhedral is what Burt Rutan called it on my Vari Eze. Cy Galley Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org ----- Original Message ----- From: "Christian Bobka" <bobka(at)charter.net> Subject: Pietenpol-List: I discoverd something > > While researching dihedral I learned that the word meaning "negative > dihedral" is the word "cathedral". I never could remember whether a cathode > was negative or positive. Now I will remember a Cathode is negative... > > chris bobka > > ________________________________________________________________________________
Date: Feb 05, 2003
An easy way to remember it is that the word, "catheter" is definitely negative. Even I can remember that. ________________________________________________________________________________
Date: Feb 05, 2003
Jack, My curiosity compels to ask you, " give me an estimate of G's on a Piet wing (with 1 1/2 degree DIhedral) in a steep turn of 60 to 90 degrees,cruise speed "? Thanks Corky in La ________________________________________________________________________________
Date: Feb 05, 2003
----- Original Message ----- From: "Jack Phillips" <jackphillips(at)earthlink.net> Subject: RE: Pietenpol-List: Question about Gross Weight +++++++++++++++++++++ Jack, In reading your stress analysis, I noticed that you used tensile strength of the wood. I believe most wood beam failures occur due to compressive failure of the fibers as opposed to tensile failure. Compressive strength in wood is usually lower than tensile. Ever notice how a stick breaks? You might want to go to: http://www.fpl.fs.fed.us/documnts/FPLGTR/fplgtr113/Ch04.pdf Where there is a table of compessive strengths of various woods to use in your calculations. I hope this helps, John +++++++++++++++++++++++++++++++++++ > > OK, I should know better than to make blanket statements like "1" is > overkill". Good points, Mike. Citabria spars are (I believe) six inches in > height, but they are also several feet longer than Pietenpol spars. I was > responding to the remark that some Aeroncas used 3/4" spars. I think 3/4" > is a much more common thickness than 1". > > Before deciding on 3/4" spars for my bird, I ran a quick stress analysis, > with a number of assumptions: > > 3/4" spars > Gross weight 1050 lbs > 65% of load carried by front spar, 35% by rear spar > ultimate tensile stress for Sitka Spruce is 9400 psi > no load carried by centersection (actually a pretty fair assumption, it > turns out) > even lift distribution over entire spar length > > The result was that with the lift strut fittings as designed by BHP (not > in-line with the struts as modern ones are) the wing is good for about 4.9 > G's. If a more modern lift strut attach point is used, which doesn't impart > its own bending moment to the spar, the wing is only good for 3.92 G's > > These are ultimate loads, and I wouldn't expect the wing to survive too long > at these loads. This was enough to convince me that Pietenpols have no > business doing aerobatics, but are plenty strong for normal fun flying. > > Jack > > > -----Original Message----- > > Bernie routed down the center portions of his spars to save weight but > didn't rout the > spar caps. The material in the center of a beam (spar) in bending does very > little > other than carry shear loads. This is why there are many spars with the > "beef" > located at the top and bottom with only a plywood shear web between the > caps. > A much more important measurement than the spar thickness is the spar's > width, from > top to bottom. Before we go writing off Bernie's spars as overkill on > thickness, lets > do a real comparison with these other famously strong wings that includes > spar width, > length of the wing in actual bending (the Piet wing inboard of the strut > attach points > sees less bending load than the outboard portion), comparable flight loads, > etc. A > blanket statement that 1" is overkill because something like a Pitts has > thinner spars > is not really supportable. > The experiences of a very large number of builders who have successfully and > safely > flown 3/4" spars is certainly more reliable than comparing apples and > oranges, but I'm > not sure anyone has any idea how much safety margin is left over when > pulling > significant flight loads on spars thinner than designed. > Mike > > ________________________________________________________________________________
Date: Feb 05, 2003
From: "Greg Cardinal" <gcardinal(at)startribune.com>
Constant altitude, 60 deg. bank = 2 g. Airspeed doesn't matter. Load increases very quickly as the angle of bank steepens. Greg Cardinal >>> Isablcorky(at)aol.com 02/05/03 09:34AM >>> Jack, My curiosity compels to ask you, " give me an estimate of G's on a Piet wing (with 1 1/2 degree DIhedral) in a steep turn of 60 to 90 degrees,cruise speed "? Thanks Corky in La ________________________________________________________________________________
Date: Feb 05, 2003
Subject: makes me dizzy at 60 degrees !
Corky-----do you mean how many g's does a Piet take when it's 60 F or 90 F or bank angle ? (has to be a smart @#$ in every group.) One thing is for sure, the Piet in a 60 bank will turn on a dime. I mean it's TIGHT. I don't even know if you could make say a 70 deg. bank in a Piet and not loose altitude. Even with that big 65 horses up front like Walt and you and I have. Good question though. In the older Piets the termites have to join hands in turns like that:) Mike C. 17 F in Clev. ________________________________________________________________________________
Date: Feb 05, 2003
Subject: spars
Hi Pieter's ....While we're on the subject of spars I have a question that's been bugging my curiosity for quite a while. Don't beat me up here this strictly a theoretical question. Has anyone ever built a wing with aluminum spars and wooden ribs? The reason I ask is that Carlson's lists a sweet modified I beam 4 1/2" aluminum spar that they use in some of their kit planes with slightly higher gross weights than the Piet. If I remember right they are 45,000 psi tensile and 30,000 psi in shear. They're 9 lbs each and not too expensive . With a little shimming they would fit the piet ribs. I plan to use 3/4" spruce spars but Carlson's spars caught my curiosity. ________________________________________________________________________________
Date: Feb 05, 2003
Subject: Re: spars
Wag Aero sells a cub replica kit. You can buy the wing kit one of three ways, all wood, all aluminum, or aluminum with wood ribs. Now I sure don't if any piets have been built using this technique, but it does seem possible. Buy the way a couple years ago AS sold the extruded spars blanks for about $100.00 $150.00 each. Dan ________________________________________________________________________________
Date: Feb 05, 2003
Mike, Remember also that the "builder's manual" suggests using 3/4" spars and the ca. 1960 wing center section supplemental drawing shows 3/4 inch. On that basis, it's hard to say that 3/4" is "thinner than designed". Gene -----Original Message----- From: Mike [mailto:bike.mike(at)verizon.net] Subject: Re: Pietenpol-List: Question about Gross Weight Bernie routed down the center portions of his spars to save weight but didn't rout the spar caps. The material in the center of a beam (spar) in bending does very little other than carry shear loads. This is why there are many spars with the "beef" located at the top and bottom with only a plywood shear web between the caps. A much more important measurement than the spar thickness is the spar's width, from top to bottom. Before we go writing off Bernie's spars as overkill on thickness, lets do a real comparison with these other famously strong wings that includes spar width, length of the wing in actual bending (the Piet wing inboard of the strut attach points sees less bending load than the outboard portion), comparable flight loads, etc. A blanket statement that 1" is overkill because something like a Pitts has thinner spars is not really supportable. The experiences of a very large number of builders who have successfully and safely flown 3/4" spars is certainly more reliable than comparing apples and oranges, but I'm not sure anyone has any idea how much safety margin is left over when pulling significant flight loads on spars thinner than designed. Mike Jack Phillips wrote: > > Citabrias also have 3/4" spars, as do Pitts Specials and many other > aerobatic planes. 1" is overkill, which is why BHP routed them down. I > used 3/4" spars fore and aft in my Piet. > > Jack ________________________________________________________________________________
Date: Feb 05, 2003
Jack, In general, and I'd like Chris Bobka to check his extensive library on this, ultimate load capability should be 1.5 times service loads, the actual expected maximum normal loading. That would mean, if your assumptions are correct, that your 4.9g Piet is a 3.2g airplane at 1050#GW. However, your tensile strength for spruce seems a little higher than the more conservative numbers I remember from the cobwebbed past. If the number is actually 7500 psi, you should have a confidence in only 2.6g, even though 3.9g could be ultimately possible. The 1.5 safety margin should be there to account for the unforeseen anomaly such as a hidden flaw in the spruce or a not-so-perfect weld joint. Since we're building homebuilts, we don't always have to comply with FAA design guidelines. However, the FAA-mandated load capabilities for certificated airplanes seem like a good idea to me. As to John D's question about the term "tensile strength" or "tensile stress", when used in bending: The number relates to the maximally stressed fiber in a test specimen at failure. It does not have to actually be tension as opposed to compression which, as John noted, would be found on the side towards which the specimen is bent. In a symmetrical specimen, the compressive stress and the tensile stress would be equal during bending, though the first fiber to fail could be on the compressive side. Mike > > > > OK, I should know better than to make blanket statements like "1" is > overkill". Good points, Mike. Citabria spars are (I believe) six inches in > height, but they are also several feet longer than Pietenpol spars. I was > responding to the remark that some Aeroncas used 3/4" spars. I think 3/4" > is a much more common thickness than 1". > > Before deciding on 3/4" spars for my bird, I ran a quick stress analysis, > with a number of assumptions: > > 3/4" spars > Gross weight 1050 lbs > 65% of load carried by front spar, 35% by rear spar > ultimate tensile stress for Sitka Spruce is 9400 psi > no load carried by centersection (actually a pretty fair assumption, it > turns out) > even lift distribution over entire spar length > > The result was that with the lift strut fittings as designed by BHP (not > in-line with the struts as modern ones are) the wing is good for about 4.9 > G's. If a more modern lift strut attach point is used, which doesn't impart > its own bending moment to the spar, the wing is only good for 3.92 G's > > These are ultimate loads, and I wouldn't expect the wing to survive too long > at these loads. This was enough to convince me that Pietenpols have no > business doing aerobatics, but are plenty strong for normal fun flying. > > Jack > ________________________________________________________________________________
Subject: Re: spars
Date: Feb 05, 2003
Thanks Dan...So it is feasable to use aluminum spars with wood ribs. The Carlson's spar I was looking at is 4 1/2" X .812" (across the flanges) X 14 ft.6061T aluminum flanged I beam affair for $86.00 each plus shipping....didn't sound too bad...Lets see Mikes termites eat that sucker!!! Anyone know the best way to fasten ribs to them??? I don't think it would be a good idea to drill the flanges?? but then the aluminum ribs must be riveted to the flanges. Or are they?? Still just curious. Ed >From: ZigoDan(at)aol.com >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: spars >Date: Wed, 5 Feb 2003 11:44:01 EST > > >Wag Aero sells a cub replica kit. You can buy the wing kit one of three >ways, all wood, all aluminum, or aluminum with wood ribs. Now I sure don't >if any piets have been built using this technique, but it does seem >possible. > Buy the way a couple years ago AS sold the extruded spars blanks for >about >$100.00 $150.00 each. > >Dan > > ________________________________________________________________________________
Date: Feb 05, 2003
Subject: Airfoil
Pieters, Would some GNer please tell me what kind of airfoil the GN plan calls for. Thanks Corky in La ________________________________________________________________________________
Date: Feb 05, 2003
From: travis battreal <travisbattreal(at)yahoo.com>
Subject: Re: spars
The J-3 had wooden spars and aluminum ribs. --- "Ed G." wrote: > flyboy_120(at)webtv.net (Ed G.) > > Hi Pieter's ....While we're on the subject of spars > I have a question > that's been bugging my curiosity for quite a while. > Don't beat me up > here this strictly a theoretical question. Has > anyone ever built a wing > with aluminum spars and wooden ribs? The reason I > ask is that Carlson's > lists a sweet modified I beam > 4 1/2" aluminum spar that they use in some of their > kit planes with > slightly higher gross weights than the Piet. If I > remember right they > are 45,000 psi tensile and 30,000 psi in shear. > They're 9 lbs each and > not too expensive . With a little shimming they > would fit the piet ribs. > I plan to use 3/4" spruce spars but Carlson's spars > caught my curiosity. > > > > Contributions > any other > Forums. > > latest messages. > List members. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/Pietenpol-List.htm > Digests:http://www.matronics.com/digest/pietenpol-list > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Date: Feb 05, 2003
Subject: Re: spars
The original later model J3 had Aluminum ribs, wood spars. Just like the Champ, and later model Chiefs. But despite that for the record I am looking at a Wag Aero book right now and it say's Aluminum spar wood rib kit. BTW some early model Chief's and J3's had all wood wings, rib's and spar's. Right now I have a 41 chief, with all wood wings, just like Chris Bobka's 40 or 39 model. Ed, I once replaced a spar on a PA 22-108 Colt. The flange or T part was drilled, in fact it didn't seem to mater, they put holes all through it. The ribs were held on with about #4 sheet metal screws. I bought the spar from Univiar, and it was predrilled, boy did that save some time. Dan ________________________________________________________________________________
Date: Feb 05, 2003
Subject: Re: question on dihedral
I would love to hear a responce from piet pilots who have flown more or less the same plane with dihedral, in one version and wirthout in another version. If you have experience as above can you judge which form is nicer to fly? Henry Williams ________________________________________________________________________________
Date: Feb 05, 2003
Subject: Carelson spars
Ed: Those spars look exactly like Piper spars. In fact, I understand Mr. Carelson was an old Piper engineer-or something. I scrapped out a couple Piper Pawnees. The ribs have 90 d sheet angles at the spar openings with small #4 p.k. screws run threw them into the flange of the spar. 4 screws on each side. So, if Piper did it that way, it must be ok. It seems to me that the best way attach a Piet wood rib would be to widen the verticals of the rib at the spar opening so as to have some material to run a screw threw. Or, if you haven't built your ribs yet, Carelson has 'T' and "L" angles for making ribs. Ed, here is your chance to be a pioneer. The first known metal wing Piet! I would look into it my self, but I already have my ribs and spars built. Leon S. ________________________________________________________________________________
From: "Richard Navratril" <horzpool(at)goldengate.net>
Subject: Re: RE: fuel gauges
Date: Feb 05, 2003
Chris Again thanks for some great points that arrive as I am connecting fuel lines and such. Which leads to a related question. I have a main tank in the wing 11 gal. and a header tank in the fuse, 4 gal.with no independant fill, feed directly from the main tank. The question I have been pondering is the vent line in the header tank. I have installed a 1/8" line with a petcock bleed to remove air. Should this have been led back up to the highest point for venting? I have a fuel guage on the main wing tank but do not intend on using that reserve header and no guage installed there. Dick N. ----- Original Message ----- From: "Christian Bobka" <bobka(at)charter.net> Subject: Pietenpol-List: RE: fuel gauges > > Eddie, > > Follow these rules: > > The tank in the fusealge is the main tank. > > The tank in the wing is and auxialry tank. > > The fuselage tank must be no closer than 1/2 inch to the firewall. > > Both tanks must be vented and vented in such a manner is to prevent ice > formation on the vent (even in florida). > > Both tanks must have a sump and sump drain at their lowest point in a parked > attitude. > > Air must be able to circulate around the tanks somehow and fumes and liquid > fuel must be able to escape down and out from the space beneath the tanks. > > The fuel for engine use will not be drawn from the main tank at the sump but > at some point higher than the sump. > > Test pressure is 3-1/2 psi for the tanks. > > And what you asked for: "Where two or more tanks are interconnected and it > is impossible to feed from each one separately, only one fuel-level gauge > need be installed." Obviously the gauge is for the main tank only as the > aux tank will drain into the main tank. > > Copper fuel lines must be annealed after they are bent. > > Ed, I hope this helps. > > chris > > > -----Original Message----- > From: Ed Grentzer [mailto:flyboy_120(at)hotmail.com] > To: bobka(at)charter.net > Subject: fuel gauges > > > Hi Chris...How's it going...good luck with your D.A.R. application..We > definitely need more qualitied D.A.R.s out there. > I have a technical question..I'm building a 7.5 gallon wing tank for the > forward 15" of my center section. Behind the tank will be a small baggage > compartment. I'm trying to keep the cg forward as much as I can so this tank > is centered above the most fwd/rearward recommended cg measurements. The > function of the wing tank will just be to replenish the cowl tank during > flight. I think Walt Evans has a similar set up but with a full sized wing > tank. Anyhoo..I read somewhere that "each fuel tank must have a fuel > quantity gauge" My question is if a tank is only used to refill a tank which > has a gauge does that tank ( the wing tank) have to have a gauge?? My tank > mold is finished but if I HAVE TO install a gauge now would be the time to > add the sender boss to the mold. Thanks in advance. Ed G. > > ________________________________________________________________________________
Date: Feb 05, 2003
In any plane, with or without dihedral, regardless of cruise speed, a sixty degree bank will require a 2 G load on the wing, assuming you are neither climbing or losing altitude. It has nothing to do with the design of the plane, it's just simple trigonometry. The load on the wing equals the weight of the aircraft divided by the cosine of the bank angle. The cosine of 60 degrees is .5000, so the load is the weight of the plane divided by .5, which is the same as the weight of the plane multiplied by 2. In a 90 degree bank, assuming all the lift forces come from the wing, the load on the wing approaches infinity since the cosine of 90 degrees is zero. Sufficiently confused? Me too. Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Isablcorky(at)aol.com Subject: Re: Pietenpol-List: Question about Gross Weight Jack, My curiosity compels to ask you, " give me an estimate of G's on a Piet wing (with 1 1/2 degree DIhedral) in a steep turn of 60 to 90 degrees,cruise speed "? Thanks Corky in La ________________________________________________________________________________
Date: Feb 05, 2003
You're right Mike, the published "G" loading for an airplane includes a 150% safety factor. That's why I stressed that these were ultimate loads. This is a 3 G airplane and should not be used for aerobatics. By the way, when I continued with the simple stress analysis I did, I found that without Jury struts, the lift struts could buckle under as little as 1.0 negative G's, which can be produced by strong turbulence. Jury struts are absolutely necessary. Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mike Subject: Re: Pietenpol-List: Question about Gross Weight Jack, In general, and I'd like Chris Bobka to check his extensive library on this, ultimate load capability should be 1.5 times service loads, the actual expected maximum normal loading. That would mean, if your assumptions are correct, that your 4.9g Piet is a 3.2g airplane at 1050#GW. However, your tensile strength for spruce seems a little higher than the more conservative numbers I remember from the cobwebbed past. If the number is actually 7500 psi, you should have a confidence in only 2.6g, even though 3.9g could be ultimately possible. The 1.5 safety margin should be there to account for the unforeseen anomaly such as a hidden flaw in the spruce or a not-so-perfect weld joint. Since we're building homebuilts, we don't always have to comply with FAA design guidelines. However, the FAA-mandated load capabilities for certificated airplanes seem like a good idea to me. As to John D's question about the term "tensile strength" or "tensile stress", when used in bending: The number relates to the maximally stressed fiber in a test specimen at failure. It does not have to actually be tension as opposed to compression which, as John noted, would be found on the side towards which the specimen is bent. In a symmetrical specimen, the compressive stress and the tensile stress would be equal during bending, though the first fiber to fail could be on the compressive side. Mike > > > > OK, I should know better than to make blanket statements like "1" is > overkill". Good points, Mike. Citabria spars are (I believe) six inches in > height, but they are also several feet longer than Pietenpol spars. I was > responding to the remark that some Aeroncas used 3/4" spars. I think 3/4" > is a much more common thickness than 1". > > Before deciding on 3/4" spars for my bird, I ran a quick stress analysis, > with a number of assumptions: > > 3/4" spars > Gross weight 1050 lbs > 65% of load carried by front spar, 35% by rear spar > ultimate tensile stress for Sitka Spruce is 9400 psi > no load carried by centersection (actually a pretty fair assumption, it > turns out) > even lift distribution over entire spar length > > The result was that with the lift strut fittings as designed by BHP (not > in-line with the struts as modern ones are) the wing is good for about 4.9 > G's. If a more modern lift strut attach point is used, which doesn't impart > its own bending moment to the spar, the wing is only good for 3.92 G's > > These are ultimate loads, and I wouldn't expect the wing to survive too long > at these loads. This was enough to convince me that Pietenpols have no > business doing aerobatics, but are plenty strong for normal fun flying. > > Jack > ________________________________________________________________________________
Date: Feb 05, 2003
Then why wouldn't "anhedral" mean "no hedral"? ;>) Whats a hedral, anyway? Bert ----- Original Message ----- From: "Christian Bobka" <bobka(at)charter.net> Subject: RE: Pietenpol-List: I discoverd something > > DJ, > > The prefixes A or AN mean "without" so anhedral is no dihedral and no > cathedral. Atheist meaning without God and anonymous meaning without name. > > Chris Bobka > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of DJ Vegh > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: I discoverd something > > > hmmm I've always known it as "anhedral" > > DJ Vegh > N74DV > www.raptoronline.com > Mesa, AZ > > > ----- Original Message ----- > From: "Christian Bobka" <bobka(at)charter.net> > To: "pietenpol" > Subject: Pietenpol-List: I discoverd something > > > > > > > While researching dihedral I learned that the word meaning "negative > > dihedral" is the word "cathedral". I never could remember whether a > cathode > > was negative or positive. Now I will remember a Cathode is negative... > > > > chris bobka > > > > > This email has been scanned for known viruses and made safe for viewing by > Half Price Hosting, a leading email and web hosting provider. For more > information on an anti-virus email solution, visit > <http://www.halfpricehosting.com/av.asp>. > > ________________________________________________________________________________
Date: Feb 05, 2003
Subject: Re: Question about Gross Weight
Jack, I absolutely agree about the jury struts, and had mentioned this earlier. I realize now were I went wrong on saying build per plans. It seems all the Piets I have seen, including the Last Original have jury struts, so I guessed they were on the plans. Someone corrected me on this oversight, and asked me if I were to follow the plans which do not show the jury struts, then would I also follow the plans by using #7 screws to hold the stabilizer on. Of course not, AN hardware is the way to go, and I would certainly not leave jury struts off either. I think the hole debate had been over some UK Piets having only one jury strut, one is better than none, but for the price I would rather have both. Dan ________________________________________________________________________________
Subject: Re: Airfoil
Date: Feb 05, 2003
It's the same basic airfoil as the Piet, a Clark "Y", uses 1"spars, front & rear. Ken GN1 2992 ----- Original Message ----- From: <Isablcorky(at)aol.com> Subject: Pietenpol-List: Airfoil > > Pieters, > Would some GNer please tell me what kind of airfoil the GN plan calls for. > Thanks > Corky in La > > ________________________________________________________________________________
Date: Feb 05, 2003
Chris Bobka, Further to your treatise on dihedral, this is what an old aeronautical engineering book of mine says: "...the High Wing or Parasol type of monoplane, which often has no Dihedral Angle. The Low Wing Monoplane, on the other hand, must usually have a Dihedral Angle." Ref. MECHANICS OF FLIGHT by A. C. Kermode London Sir Isaac Pitman & Sons, Ltd. 1942 Kermode essentially says what you are saying: a parasol monoplane such as the Pietenpol needs no dihedral for adequate lateral stability. (In spite of this I did incorporate a modicum of dihedral in my Pietenpol, mainly to reduce the "droopy" look while parked.) The other day I obtained a brochure on the new Murphy JDM 8 which in- cluded a basic 3-view layout showing zero dihedral! Since this airplane has a low wing, it seems strange that they went this route. It strongly reminds me of the Druine Turbulent (a delightful little plane) I test flew for a friend years ago, but the Turbulent had dihedral typical of low wing monoplanes. I know of several low wingers with no dihedral, but some were not all that success- ful. Back in the 1980's a fellow from British Columbia built a low wing Pietenpol powered by a Continental A-65. It had strut braced wings with appropriate dihedral for this configuration. It flew successfully, but had a high sink rate. He cited easy access to the cockpits and good visibility as the chief benefits. Graham Hansen (Pietenpol CF-AUN) in sunny Alberta, Canada. ________________________________________________________________________________
Date: Feb 06, 2003
Subject: spars+ G
From U.S. Forestry lab, 1944, at 12% moisture; Spruce--6700lb/sq inch tensile. 4500lb/sq inch compression. I think later testing was done at 11% or lower moisture which results in higher strengths. In a spar like the Piet's the bending forces are equal top and bottom. Forces are 0 at the center, known as the " neutral axis " Forces are maximum at the outer edges ( top and bottom faces) Since forces are equal, top and bottom, then the weaker strength is the deciding factor as to when the spar will fail. Since the top of the spar is in compression, it will fail first. In fancier aircraft the top area has been made beefier than the bottom. you'll see cantilever aircraft with high pos and low neg G capability. Even the likes of AT-6's with 5.67 G pos and 2.33 G neg ( from flight handbook AN 01-60FFB-1 ).All in the name of weight saving.( and cost ) The 1" piet spar is routed to leave 1" X 5/8" full size at the outer edges but with the use of higher HP engines of lower weight than the Ford, The weight saving isn't critical and the spar will be a little stronger if left unrouted as the strength in wood, from neutral axis out, increases parabolicly, not in a straight line as it is in metal. Am I all wet, partialy wet, or reasonably dry ?? Clif ________________________________________________________________________________
Date: Feb 06, 2003
Piet isn't a Clark at all. It's very close to the Eiffel used on the Jenny. Bernard and his friend Orrin drew it up one night out of their heads as the story goes. ----- Original Message ----- From: "Ken & Lisa Rickards" <KL0914(at)cogeco.ca> Subject: Re: Pietenpol-List: Airfoil > > It's the same basic airfoil as the Piet, a Clark "Y", uses 1"spars, front & > rear. > > ________________________________________________________________________________
Date: Feb 06, 2003
Anhedral is the usage for downward angled wings in all my " From the Ground Up " groundschool manuals all the way back to my first one in 62. As far back as I can remember it's been " anhedral " in everything I've read. ----- Original Message ----- From: "Cy Galley" <cgalley(at)qcbc.org> Subject: Re: Pietenpol-List: I discoverd something > > I thought is was anhedral. When I spell check it, the correction comes up > "cathedral." Anhedral is what Burt Rutan called it on my Vari Eze. > Cy Galley > Editor, EAA Safety Programs > cgalley(at)qcbc.org or experimenter(at)eaa.org > > > ----- Original Message ----- > From: "Christian Bobka" <bobka(at)charter.net> > To: "pietenpol" > Subject: Pietenpol-List: I discoverd something > > > > > > > While researching dihedral I learned that the word meaning "negative > > dihedral" is the word "cathedral". I never could remember whether a > cathode > > was negative or positive. Now I will remember a Cathode is negative... > > > > chris bobka > > > > > > > > > > ________________________________________________________________________________
Date: Feb 06, 2003
thanks, clif, I have obviously been misled somewhere down the line. Ken ----- Original Message ----- From: "clif" <cdawson5854(at)shaw.ca> Subject: Re: Pietenpol-List: Airfoil > > Piet isn't a Clark at all. It's very close to the Eiffel > used on the Jenny. Bernard and his friend Orrin > drew it up one night out of their heads as the story goes. > ----- Original Message ----- > From: "Ken & Lisa Rickards" <KL0914(at)cogeco.ca> > To: > Subject: Re: Pietenpol-List: Airfoil > > > > > > > It's the same basic airfoil as the Piet, a Clark "Y", uses 1"spars, front > & > > rear. > > > > > > ________________________________________________________________________________
Date: Feb 06, 2003
Henry-- I have flown Frank Pavliga's Sky Gypsy and it has a flat, zero dihedral wing and then mine which has about 1.5" at the wing tips. There is very little difference that I can tell in smooth air, however I believe that a touch of dihedral helps when both of your hands are busy folding a chart or peeing in the bottle (trust me, it beats wasting a 45 minute stop when going x-country in a Piet) since you just rudder the airplane with your feet to keep wings level and pointed where you want. Like the balsa rubberband flyers we all played with when we were kids, they put a bunch of dihedral into those for a reason. Try modifying one of those rubber jobs with zero dihedral and give it a test flight. You'll see a short flight. Mike C. PS---have flown Joe Leonard's GN-1 which has dihedral too.....very, very nice flying machine. Heavy, but nice. ________________________________________________________________________________
Subject: metal spars/wood ribs
Date: Feb 06, 2003
The prez of the local EAA Chapter 35 is completing a Breezy that he and another partner bought as a project. It has metal spars and wood ribs, and has turned out to be a real bear to work with because of fitting the ribs around the shape of the spar. Unless you work out a clever and easy way to secure the ribs to the spars, it can be a lot of fussy work. And Bert asks- "what's a hedral, anyway?" I'm disappointed that no one popped up with, "it's the matching half of a shedral" ;o) Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Feb 06, 2003
Subject: negative g's in a Piet
> >Jack P. wrote this: with the simple stress analysis I did, I found that >without Jury >struts, the lift struts could buckle under as little as 1.0 negative G's, >which can be produced by strong turbulence. Jury struts are absolutely >necessary. And there is NO doubt in my mind that I (and you will) hit 1.0 negative G's MANY times en route to Oshkosh from Ohio and going to local fly-in's with the Piet. On hot summer days when you transition over dark wooded areas and open tan-colored farmland there are some real shear forces going on that can literally jolt a map or pencil right out of your hand and out of the cockpit. When flying side-by-side a more stable airplane like a J-3 or C-150 I am amazed at how they appear to be taking the turbulence so much better than me in the Piet. It's true. Nice to know the jury struts are out there. When Bernie built his Piets they used streamlined tubing that had internal stiffening webs which kept the struts from collapsing........now days they do not make strut material with internal webbing so Jack is right on-----Jury struts are an absolute requirement on a Pietenpol. Mike C. ________________________________________________________________________________
Subject: Dihedral, Structural analysis, aluminum spars
Date: Feb 06, 2003
1. I have looked at my zero degree dihedral (or would it be anhedral? Who really cares?) Piet from all angles and at various pictures and videos. I can't detect the dreaded "droopy wing" look in any of them. Oh yeah, it seems to fly just fine. 2. structural analysis for Piets...................yawn. 3. There IS a Piet under construction right now with aluminum spars, wooden ribs, and some kevlar laminate and aluminum honeycomb in the control surfaces. It'll have a steel tube fuselage and water-cooled straight four engine on the 100 hp range. Larry ________________________________________________________________________________
Date: Feb 06, 2003
ummm... not true... the GN-1 has the same airfoil as the Piet, with the exception of a slightly more blunt leading edge. The GN-1 and Piet's are not Clark Y. Bernie called it a FC-10. why?? he used a French Curve to draw it and it took him about 10 minutes.... I forget where I read that but thought it comical.... DJ Vegh N74DV www.raptoronline.com Mesa, AZ ----- Original Message ----- From: "Ken & Lisa Rickards" <KL0914(at)cogeco.ca> Subject: Re: Pietenpol-List: Airfoil > > It's the same basic airfoil as the Piet, a Clark "Y", uses 1"spars, front & > rear. > > > Ken > > GN1 2992 > ----- Original Message ----- > From: <Isablcorky(at)aol.com> > To: > Subject: Pietenpol-List: Airfoil > > > > > > Pieters, > > Would some GNer please tell me what kind of airfoil the GN plan calls for. > > Thanks > > Corky in La > > > > > > This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>. ________________________________________________________________________________
Subject: Airfoil
Date: Feb 06, 2003
Thanks for the information D.J. I knew the airfoils were the same, I just remember someone telling me that it was a modified Clark y. Was the design based on the Clark or the Eiffel? Ken GN1 2992 -----Original Message----- From: DJ Vegh [mailto:aircamper(at)imagedv.com] Subject: Re: Pietenpol-List: Airfoil ummm... not true... the GN-1 has the same airfoil as the Piet, with the exception of a slightly more blunt leading edge. The GN-1 and Piet's are not Clark Y. Bernie called it a FC-10. why?? he used a French Curve to draw it and it took him about 10 minutes.... I forget where I read that but thought it comical.... DJ Vegh N74DV www.raptoronline.com Mesa, AZ ----- Original Message ----- From: "Ken & Lisa Rickards" <KL0914(at)cogeco.ca> Subject: Re: Pietenpol-List: Airfoil > > It's the same basic airfoil as the Piet, a Clark "Y", uses 1"spars, front & > rear. > > > Ken > > GN1 2992 > ----- Original Message ----- > From: <Isablcorky(at)aol.com> > To: > Subject: Pietenpol-List: Airfoil > > > > > > Pieters, > > Would some GNer please tell me what kind of airfoil the GN plan calls for. > > Thanks > > Corky in La > > > > > > This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>. ________________________________________________________________________________
Date: Feb 06, 2003
Clark Y is a flat-bottomed airfoil, Piets and GN's use an undercamber. DJ has it right almost - it was made with a #10 French curve. Works well, don't it? PeoplePC: It's for people. And it's just smart. http://www.peoplepc.com ________________________________________________________________________________
Date: Feb 06, 2003
TOUCHE !! ________________________________________________________________________________
Subject: Wing tanks
Date: Feb 06, 2003
Does anyone have a sketch on how to build wing tanks for the piet?, or where can I find the information? Barry Davis ________________________________________________________________________________
Date: Feb 06, 2003
Subject: Airfoil
I hope this does not lead to even more confusion. John Grega, in an article in Sport Aviation a number of years ago, said he was attempting to "simplify" the building of the Pietenpol. He did that, to a large extent. In the process, he advocated the use of Cub wings and landing gear, which were in good supply at the time. So some Gregas are, perhaps, still flying on Cub wings, which do use the Clark Y airfoil. Doc Mosher Oshkosh USA ________________________________________________________________________________
Date: Feb 06, 2003
Subject: Re: spars
Take a look to a Kitfox wing, well, not exactly the same, but they use aluminum tube spars with plywood ribs, they use something like "JB Weld" in gray color, (like a putty) to join the ribs to the tubes. With a little research you can find out what is it... Looks real solid to me. Saludos Gary Gower --- Ed Grentzer wrote: > > > > Thanks Dan...So it is feasable to use aluminum spars with wood > ribs. > The Carlson's spar I was looking at is 4 1/2" X .812" (across the > flanges) X 14 ft.6061T aluminum flanged I beam affair for $86.00 > each plus shipping....didn't sound too bad...Lets see Mikes > termites > eat that sucker!!! Anyone know the best way to fasten ribs to > them??? I don't think it would be a good idea to drill the > flanges?? > but then the aluminum ribs must be riveted to the flanges. Or are > they?? Still just curious. Ed > > > >From: ZigoDan(at)aol.com > >Reply-To: pietenpol-list(at)matronics.com > >To: pietenpol-list(at)matronics.com > >Subject: Re: Pietenpol-List: spars > >Date: Wed, 5 Feb 2003 11:44:01 EST > > > > > >Wag Aero sells a cub replica kit. You can buy the wing kit one of > three > >ways, all wood, all aluminum, or aluminum with wood ribs. Now I > sure don't > >if any piets have been built using this technique, but it does seem > >possible. > > Buy the way a couple years ago AS sold the extruded spars blanks > for > >about > >$100.00 $150.00 each. > > > >Dan > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 06, 2003
Subject: Re: Wing tanks
Barry: It's not exactly a sketch, but try: http://www.geocities.com/keriannprice/Keri-Anns_Pietenpol.html George ________________________________________________________________________________
Date: Feb 06, 2003
ahhhh yes.... I forgot abou that...the early GN-1's did use a host of J-3 parts including wings... but, the plans (since the early 70's) show the Piet airfoil... DJ ----- Original Message ----- From: Doc Mosher To: pietenpol-list(at)matronics.com Sent: Thursday, February 06, 2003 9:31 AM Subject: Pietenpol-List: Airfoil I hope this does not lead to even more confusion. John Grega, in an article in Sport Aviation a number of years ago, said he was attempting to "simplify" the building of the Pietenpol. He did that, to a large extent. In the process, he advocated the use of Cub wings and landing gear, which were in good supply at the time. So some Gregas are, perhaps, still flying on Cub wings, which do use the Clark Y airfoil. Doc Mosher Oshkosh USA = This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>. ________________________________________________________________________________
Date: Feb 06, 2003
Sorry Doc, Cub's use a USA 35B airfoil not a Clark Y Cy Galley - Bellanca Champion Club Newsletter Editor & EAA TC www.bellanca-championclub.com We support Aeroncas ----- Original Message ----- From: "Doc Mosher" <docshop(at)tds.net> Subject: Pietenpol-List: Airfoil > > I hope this does not lead to even more confusion. John Grega, in an > article in Sport Aviation a number of years ago, said he was attempting to > "simplify" the building of the Pietenpol. He did that, to a large > extent. In the process, he advocated the use of Cub wings and landing > gear, which were in good supply at the time. So some Gregas are, perhaps, > still flying on Cub wings, which do use the Clark Y airfoil. > > Doc Mosher > Oshkosh USA > > ________________________________________________________________________________
Date: Feb 06, 2003
Experts, Granted that for several reasons the Piet has very little float after flair. Question: Would this airfoil of the Cub perhaps extend the float of a Piet somewhat. It WAS designed several years after the Piet and maybe, just maybe, some progress could be identified. Just wondering without using my can opener again. An old southern boy just whittlin and dreamin ________________________________________________________________________________
Date: Feb 06, 2003
Barry,, The Tony Bingelis "Sport plane construction techniques"book, it's the yellow one, has some great examples of fiberglass tanks. Plus a lot of other good things in there as well. I used his technique, measured the center section and went from there. If you go with the center wing tank, remember to take the bolt heads into concideration when measuring. Carl ----- Original Message ----- From: "Barry Davis" <bed(at)mindspring.com> Subject: Pietenpol-List: Wing tanks > > Does anyone have a sketch on how to build wing tanks for the piet?, or where can I find the information? > Barry Davis > > ________________________________________________________________________________
Subject: FUCK YOU!!!!!!!!!!!!!HAIL VIKTORY!!!!!!!!!!!!
Date: Feb 06, 2003
----- Original Message ----- From: <Isablcorky(at)aol.com> Subject: Re: Pietenpol-List: Airfoil > > Experts, > Granted that for several reasons the Piet has very little float after flair. > Question: Would this airfoil of the Cub perhaps extend the float of a Piet > somewhat. It WAS designed several years after the Piet and maybe, just maybe, > some progress could be identified. Just wondering without using my can opener > again. > > An old southern boy just whittlin and dreamin > > ________________________________________________________________________________
Date: Feb 06, 2003
"Pietenpol-List: FUCK YOU!!!!!!!!!!!!!HAIL VIKTORY!!!!!!!!!!!!" (Feb 6, 1:53pm)
Subject: Re: F*CK Y*U!!!!!!!!!!!!!HAIL VIKTORY!!!!!!!!!!!!
Well, I'm not sure what this guy's problem is, but rest assured I have removed him from the List. Sheeze, sorry people. Matt Dralle List Admin >-------------- > > >----- Original Message ----- >From: <Isablcorky(at)aol.com> >To: >Subject: Re: Pietenpol-List: Airfoil > > >> >> Experts, >> Granted that for several reasons the Piet has very little float after >flair. >> Question: Would this airfoil of the Cub perhaps extend the float of a Piet >> somewhat. It WAS designed several years after the Piet and maybe, just >maybe, >> some progress could be identified. Just wondering without using my can >opener >> again. >> >> An old southern boy just whittlin and dreamin >-------------- -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. Benjamin Franklin Historical Review of Pennsylvania, 1759 ________________________________________________________________________________
Date: Feb 06, 2003
From: Kip & Beth Gardner <kipandbeth(at)earthlink.net>
> >Does anyone have a sketch on how to build wing tanks for the piet?, or >where can I find the information? >Barry Davis Barry, This topic was covered, perhaps more than once, in the 'old' BPA newsletter. A number of us have complete sets that someone on the list (I think it was Mike Bell in SC) compiled & sold for the cost of reproduction several years ago. I also think one of these articles was reprinted in the 'new' BPA newsletter in the past year or so. My 'old' newsletters are still all packed somewhere from my move, but I'll check my collection of 'new' ones in the next day or so. If I find it, I'd be happy to run a copy for you. Regards, Kip Gardner North Canton, OH ________________________________________________________________________________
Date: Feb 06, 2003
Thanks Matt, We really ought to try and identify the SOB and take him for a ride. CMC ________________________________________________________________________________
Date: Feb 06, 2003
Hedral is two surfaces intersecting. Chris -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Bert Conoly Subject: Re: Pietenpol-List: I discoverd something Then why wouldn't "anhedral" mean "no hedral"? ;>) Whats a hedral, anyway? Bert ----- Original Message ----- From: "Christian Bobka" <bobka(at)charter.net> Subject: RE: Pietenpol-List: I discoverd something > > DJ, > > The prefixes A or AN mean "without" so anhedral is no dihedral and no > cathedral. Atheist meaning without God and anonymous meaning without name. > > Chris Bobka > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of DJ Vegh > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: I discoverd something > > > hmmm I've always known it as "anhedral" > > DJ Vegh > N74DV > www.raptoronline.com > Mesa, AZ > > > ----- Original Message ----- > From: "Christian Bobka" <bobka(at)charter.net> > To: "pietenpol" > Subject: Pietenpol-List: I discoverd something > > > > > > > While researching dihedral I learned that the word meaning "negative > > dihedral" is the word "cathedral". I never could remember whether a > cathode > > was negative or positive. Now I will remember a Cathode is negative... > > > > chris bobka > > > > > This email has been scanned for known viruses and made safe for viewing by > Half Price Hosting, a leading email and web hosting provider. For more > information on an anti-virus email solution, visit > <http://www.halfpricehosting.com/av.asp>. > > ________________________________________________________________________________
Subject: Panel overlays
Date: Feb 06, 2003
I have a question about instrument panel overlays. I like the looks of Mike Cuy's wood raised panel for the center cluster. My question is what is it made from? Solid wood or plywood? If it is thin solid wood is there a backing to keep it from warping? How are the instruments attached? to the base 1/8" ply underneath or to the raised panel? How is the raised panel attached? With screws from behind? Or bolts all the way through? So many details. So little time. Thanks, Ted Brousseau Beautiful flying weather in FL but making sawdust instead. ________________________________________________________________________________
"'pietenpol'" , "'Jim Skidmore'" , "'Jim Markle'" , "'Ron Oehler'" , "'Peter Denny'" , "'Pat Halligan'" , "'Mike Dolan'" , "'Jeff Coffey'" <coffey@crc-inc.com>, "'Greg Cardinal'" , "'Frankh'" , "'Ed Hansen'" , "'David Kujawa'" , "'Dan Carroll'" , "'Ron Hoyt'"
Subject: RE: blast it
Date: Feb 07, 2003
Hi Chris - Just got back late tonight from a 4-day business trip to Richmond VA, so just got your note. Your article is great! You're welcome to stop over at the house most anytime this weekend with whatever additional material you have - I assume you mean the diagrams? Just call first so I can be sure to be here. By the way, I really appreciate your getting this together for this issue - kind of lean on material this month. Had a flight back through Detroit on NWA. Sat on the ramp in a 757 for an hour or so. The problem was very interesting. I don't understand how this stuff is supposed to work, but as I remember it, the aircraft was not accepting the "external power" needed to start the engines. Apparently the normal "auxiliary power" used to do this was not working. Each time they would attempt to connect "external power" we would lose normal lights/air fans etc. and would go to emer. lighting. After a dozen or so of these attempts, some of the passengers were getting upset and one man asked to be allowed off the aircraft. Eventually they allowed those who wanted to leave to do that. Then they decided to try "battery power" instead of "external power" in order to start the engine(s) - in this mode, most of the emergency lights went off while they got the engines rev'd up and started with battery power. Once the engine(s) got up to speed, the normal lights/fans etc. came on and everything was cool. But apparently this abnormal approach left the computer systems confused, because they had to shut down an engine and clear out the status indicators and start over. Anyhow, after an hour or so of this everything was cool and we took off. I really felt bad for the crew - they were doing their best and really could not predict when things would be ready. Some people get so demanding in a situation like this. I was engrossed in a John Grisham book so did not notice the time passing. -----Original Message----- From: Christian Bobka [mailto:bobka(at)charter.net] Gavin; Pat Halligan; Mike Dolan; Jeff Coffey; Greg Cardinal; Frankh; Ed Hansen; David Kujawa; Dan Carroll; Chris Bobka; Ron Hoyt Subject: blast it Pete, Here it is. An attachment will come as well. I have pictures here at home to personally deliver on tuesday evening. Chris BLAST IT! Part VIII by Chris Bobka This series was discontinued after the seventh installment when son number two began to walk! That also coincided with David Kujawa leaving the chapter newsletter editorship and taking over editorship of Sport Aerobatics magazine and moving away to Arizona with his lovely wife, Diane. Instead of looking forward to dropping off articles at David and Diane's and sharing a few beers, I was frought with fear at having to bring articles to ugly Pete and Bob. I hope you can find me some forgiveness for leaving you all hanging. So sorry. Much prodding on the part of Pete, Greg, Frankh, and others from the Pietenpol chat group has gotten me back to finishing off the series with this final installment. We left off with the gauntlets ready for installation to the front of the box. I have included Figures 11 and 12 which show a cutting diagram for the gauntlet and what the finished gauntlet should look like. As shown in Figure 12, cut some darts into the big end of the gauntlet to help it lay flat as shown in Figure 13. Put some caulk around the left opening in the box and, using a heavy duty stapler, shoot some 1/4" staples into the box around the circumference of the glove to hold it in place. Don't do what Norm did so make sure you use the left handed gauntlet in the left hole of the box and make sure you orient the thumb so that it is at about the 12 o'clock position. If you put the wrong gauntlet on that hole, you will have to stand on the cieling in order to sandblast. Like Norm. Put more of the caulk on top of the gauntlet and then take one of the rings from Figure 3 and and use enough 1-1/4" drywall screws to hold the gauntlet in place. You can clean up any of the squeezed out caulk at this time. Install the other glove. Thumbs up! Next we need to install the door. You cut out the door opening in Figure 4 and at that time, I instructed you to save the cut out piece. Go get it. Have an assistant hold the cut out piece in the door opening. Take two old door hinges from the junk box and mark off the screw positions on the door and on the frame to the rear of the door. Ensure that the hinge pins lie directly over the cut line and the hinge lines are in line with each other. Now take the door piece and lay it onto another piece of plywood that is bigger than it. Mark off the same general shape but about 1-1/2 inches all the way around it EXCEPT for the rear edge. This mark off should be even with the rear edge of the door so the door can swing open. What we are making here is a piece of plywood that will overlap the door jamb so as to contain the direct blast of the sand. With your radial saw, cut out the new piece. As the hinges on the door must lay in the same plane as the box, it will be necessary to make cutouts to allow this new piece to clear the door. Cut these out with a sabre saw. The top and side views of Figure 14 clearly show this. You may design a better way and I know that there are better ways but this is the way I did it. Go for it! Make the latch as shown in Figure 14 from some scrap plywood. Attach the door and latch to the box. If you want, you can get some felt weatherstripping about 1/8" thick and 1/2-3/4" wide and put it around the door jamb as indicated to help contain some of the sand. An 1/8" looks thick but it will compress right down. Well that is it. The box is done. Now we have to come up with the gun. You want a good one. The reason is that the gun uses air that passes through a venturi in the gun to create suction which pulls the sand up from the hopper, through the feed tube, and through the venturi itself, accelerating the sand along the way. At the venturi, the sand makes a sharp turn before it exits the nozzle. My dad, the physicist, says that force times mass equals impact. We want impact as that is what does the sandblasting. Mass is related to the the size and density of the particle. Force is the effectiveness of the gun at accelerating the particle. Every particle of sand that comes out of the gun also is trying to wear down the venturi of the gun. A cheap ceramic nozzle coupled with a soft steel venturi will not last long as the sand will abrade it right down and the venturi will no longer be properly shaped to create a quality vacuum (if a vacuum sucks, is it good or bad?). Lots of air will come out of the nozzle but no abrasive. Then you will blame me that the sandblaster does not work. We need space age materials. We need titanium. We need carbide. So I will tell you what gun to get. It is shown in Figure 15. It is available at Grainger, among other places, and can be found on the internet as of February 2003 at: http://www.grainger.com/Grainger/catalogpageview.jsp?xi=xi&CatPage=1427 You want model 3JT01 for the 12 CFM model. It lists for a wopping 77 dollars but buddy Jim Markle at jim_markle(at)mindspring.com has agreed to purchase these guns from Grainger at his substantial discount and have them drop shipped to interested buyers. The best thing is that parts are available too as listed on the same web page. The gun does not have a trigger. You do not want a gun with a trigger. A gun with a trigger takes up too much room and your finger gets tired holding the trigger. Instead of a trigger, I merely connect and disconnect a Milton coupling right at the aft end of the gun. You could get fancy and use a foot pedal air switch or you could put a valve at the point where the air line goes into the box. Use what you think you would like. Once you have your gun, attach it to the end of the pickup tube inside the box with an appropriate length of 5/8" ID cheap clear vinyl tubing from the big rack of tubing at Home Depot that I told you to get earlier. Use some hose clamps to hold the hose on at both ends. Drill the smallest size hole you can get away with to let the air line into the box. It should be located near where the pickup tube is located so that both hoses can flop around more or less together. You need a vacuum cleaner of the big shop vac variety. This is a necessity as you are creating a mammoth sandstorm inside the box. Without a shop vac, it will be so cloudy inside the box after a minute that you won't be able to see your hand in front of your face. You are pumping air into the box at 100 PSI and at 11-15 Cubic Feet per Minute. All the air has to go somewhere. If there is no shop vac then this air will blow out through every seam and put dust all over the garage and make a big mess. It will also go into your lungs and you will contract silicosis and die a horrible slow death. The key is to create a negative pressure inside the box so that the dust is trapped by the filter of the shop vac. Better yet, use an extra long vacuum hose and put the shop vac outside as even the filter on the shop vac won't trap all the fines. Their are endless varieties of abrasives to use. I use number five white silica sand. You can remember number five as that is how many fingers you should have on one of your hands. It is the same stuff that you see in sand filled ashtrays next to the door to elevators in office buildings. Many sandblasting supply outfits are reluctant to sell you sand for sandblasting beacuse they are afraid you will not be using proper breathing protection and they will be sued by your hiers after you die of silicosis. If you tell them it is for ashtrays, then they will chum right up and gladly sell it to you. It will come in 50 or 100 lb sacks. 100 lbs should do for starters. Dick Navratril, a Pietenpol builder here in the Twin Cities area (horzpool(at)goldengate.net), says you could also try a larger swimming pool dealer to get sand. In his swimming pool supply shop, he carries red flint granite sand sized at .45-.55 mm. It is rather aggressive but doesn't dust nearly as much as white silica sands. Some may try to use glass beads or walnut shells. It all depends upon the finish you wish, the aggressiveness of the cleaning, and the price you are willing to pay. You may consider building more than one sandblasting box. Each can have a different abrasive. It is difficult to change abrasives from big to little for the following reason: you will probably never get all the big stuff out. What will happen is that you will make a change from big particles to little particles. You will think you have it licked and you will be blasting away looking at the fine, uniform finish on your blasted piece. Just as the ten millionth particle comes out of the nozzle, a stray big particle will come out, and whamo! there appears what will looks like a huge crater in your work as that single particle hits. It may not bother you and it may not matter based on the part you are blasting but sometime it may matter. Again, the choice is yours. Once my new hangar is done, it will sport a couple of blasting boxes each with a different abrasive. Additonal abrasives management discussion is outside the scope of this article. I am sure that industrious users of their new blast cabinet will seek out information on http://www.google.com for more information. A few tips on use are in order. All the debris you blast off of the pieces you are sandblasting will fall down into the sand. Eventually, they will migrate to the bottom of the hopper as it becomes their "turn" to be sucked into the pickup tube. Large pieces of debris will clog the venturi of the gun. The short term fix is to hold your free hand over the discharge nozzle of the gun, forcing the compressed air down the hose abrasive supply hose and the pickup tube and blowing all the junk out. This will work for a while but sooner or later you will have to empty the abrasive out the bottom of the hopper and sift it. I use a big sifter from the cookingware aisle of the supermarket that looks like a bowl made out of screening. This is the long term fix. Use a pair of pliers kept in the box to hold small parts so you are not always blasting away at the fingertips of your gloves as you hold parts. The box makes for really good storage of parts that must be kept rust free. The large quantity of sand acts as a dessicant to keep the air in the box dry. You can also experiment with different air pressures. 50-60 PSI works good for most work. It is hard for many air compressors to keep this up at 12 CFM so from time to time you need to give the air compressor a chance to catch up. Also, most air compressors have a duty cycle which means that it is expected that a certain percentage of the time, the air compressor should be off and resting. It cools when it rests. You may consider a supplemental fan blowing on your air compressor to keep it cool. Do not take stuff out of the blaster unless you have gloves on. The pros say to use surgical gloves. Oils and acids from your skin will cause the part to rust, even under paint. As stressed in the beginning of this series of articles, moisture is the bane of all sandblasters. you must have adequate moisture control in your system. The ideal air supply system uses many feet of metal, not plastic or rubber, air line between the compressor and the sandblaster. The metal absorbs the heat from the compressed air. As the compressed air cools, the water in it will condense out and deposit, in the form of water droplets, onto the inside surface of the cool pipe. As the air passes through the pipe it will roll these droplets along until they hit a moisture trap that will inertially snag them and keep them from traveling further. It is important to note that moisture traps trap water droplets, not water vapor. Putting a mositure trap at the compressor outlet will not do much good since the air will carry mostly vapor here as the air is so hot. The best "final" moisture trap I know of is the 1/2" coalescing air filter as illustrated in Figure 16 and sold by Tip Sandblasting at 1-800-321-9260. It uses a roll of toilet paper inside the unit to absorb all remaining mositure after the air has traveled through the standard inertial moisture traps of your system. The price is up there on this unit bust the performance is spectacular. Finally, as you sandblast and between sips of Guiness, USE PROTECTIVE BREATHING EQUIPMENT APPROPRIATE FOR SANDBLASTING. If it is good for wearing while doing drywall work, it should be good for sandblasting but read the labels on the devices you might want to use! Also, use hearing protection if you have the shop vac next to you. Ideally you can use a Walkman and its little earplug type earpieces under your hearing protectors so you can listen to the Grateful Dead as you blast away. Good luck with your new unit and try to imagine how life was before you had it! ________________________________________________________________________________
Date: Feb 06, 2003
It can be done. I believe there's software out there that can take you to his front door. ----- Original Message ----- From: <Isablcorky(at)aol.com> Subject: Re: Pietenpol-List: F*CK Y*U!!!!!!!!!!!!!HAIL VIKTORY!!!!!!!!!!!! > > Thanks Matt, > We really ought to try and identify the SOB and take him for a ride. > CMC > > > > > > ________________________________________________________________________________
Subject: Re: F____ Y*U!!!!!!!!!!!!!HAIL VIKTORY!!!!!!!!!!!!
Date: Feb 07, 2003
02/07/2003 07:42:26 AM Hey Matt: Thanks for your quick action in getting rid of that BOZO, some people have no class. John Duprey dralle(at)matronics.com (Matt Dralle)(at)matronics.com on 02/06/2003 07:27:42 PM Please respond to pietenpol-list(at)matronics.com Sent by: owner-pietenpol-list-server(at)matronics.com cc: Subject: Re: Pietenpol-List: F*CK Y*U!!!!!!!!!!!!!HAIL VIKTORY!!!!!!!!!!!! Well, I'm not sure what this guy's problem is, but rest assured I have removed him from the List. Sheeze, sorry people. Matt Dralle List Admin >-------------- > > >----- Original Message ----- >From: <Isablcorky(at)aol.com> >To: >Subject: Re: Pietenpol-List: Airfoil > > >> >> Experts, >> Granted that for several reasons the Piet has very little float after >flair. >> Question: Would this airfoil of the Cub perhaps extend the float of a Piet >> somewhat. It WAS designed several years after the Piet and maybe, just >maybe, >> some progress could be identified. Just wondering without using my can >opener >> again. >> >> An old southern boy just whittlin and dreamin >-------------- -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. Benjamin Franklin Historical Review of Pennsylvania, 1759 ________________________________________________________________________________
Subject: Piet Project on e-bay
Date: Feb 07, 2003
02/07/2003 11:44:15 AM Not mine http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2402929702&category=26428 Too far away for me to go get. John Duprey ________________________________________________________________________________
Date: Feb 07, 2003
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
Ted ! I used 1/8" birch plywood for my instrument panels and in the rear cockpit overlayed the instrument cluster with 1/4" mahogany plywood. I attached the instruments to the birch and then the mahogany plywood hides all that. I used small machine screws from behind into, but not thru the 1/4" mahogany bezel. I drilled out little recess holes in the back of the 1/4" overlay and epoxied in small machine screw nuts to accept the screws.....but after 250 hour and temperature extremes the panel dropped in my lap one day while taxiing. I put a few dabs of RTV on the back of the 1/4" ply and popped it back in place. Held it there with masking tape for 24 hours then business as usual. I thought about velcro for attatching the overlay but the two layers of that would have lifted the overlay off the 1/8" birch and I didn't want that look. Let us know if you come up with a better way. I thought about magnets but then that would have given my compass schizophrenia. Bad enough that I suffer from it:) Mike C. ________________________________________________________________________________
Date: Feb 07, 2003
Mike, Loctite makes a small screw threadlocker that is removeable. Sounds like it would be just perfect for a removeable panel like that. I think it's called 222. Kent Hallsten OKC ________________________________________________________________________________
Date: Feb 07, 2003
Thanks Barry ----- Original Message ----- From: "Kip & Beth Gardner" <kipandbeth(at)earthlink.net> Subject: Re: Pietenpol-List: Wing tanks > > > > >Does anyone have a sketch on how to build wing tanks for the piet?, or > >where can I find the information? > >Barry Davis > > Barry, > > This topic was covered, perhaps more than once, in the 'old' BPA > newsletter. A number of us have complete sets that someone on the list (I > think it was Mike Bell in SC) compiled & sold for the cost of reproduction > several years ago. I also think one of these articles was reprinted in the > 'new' BPA newsletter in the past year or so. My 'old' newsletters are still > all packed somewhere from my move, but I'll check my collection of 'new' > ones in the next day or so. If I find it, I'd be happy to run a copy for > you. > > Regards, > > Kip Gardner > > North Canton, OH > > ________________________________________________________________________________
Date: Feb 07, 2003
Subject: J2-J3 tires, tubes, and wheels for sale
I have an old set of J-2 wheels (1930s) complete, no brakes, you didn't need em back then. You could easily put the asuza type brakes on. I had planed to use them as is. They are in serviceable used condition, not perfect, but good. With this set up I have some 8:00 x 4:00 newer Good Year tires and tubes, used also but very nice condition with lots of flying time left. These would look perfect on your Pietenpol, and really give it that 1930s look. The first $275.00 + shipping get them. If you want them e-mail me, the first e-mail saying yes I want them, get's them. No pictures at this time, but they are well worth it, in fact if you can't live with them I will refund your money less the shipping cost if returned with in 30 days. zigodan(at)aol.com Dan Zigo ________________________________________________________________________________
Date: Feb 07, 2003
Subject: Re: pleeeeeease stop snowing
Walt, It's not a bit better here. Took the trash out a few minutes ago and I remarked to Isabelle that it looked like snow clouds. Those low dark looking puffs like they had one winter when I was soldiering at Cp Atterbury, Ind. That's about 35 miles below Indianoplace. Boy was it cold. Cussed yankees for the next 20 years. We have had some good signs lately, the robins came through and striped the cherry laurels of berries about a month before they were due which says we will probably have an early spring. You can comfortably fly a Piet down here from 60 and above but not for too long. It was about 65 last Sat when I flew and after an hour I landed feeling like a popsicle. Ya'll come on down Corky in La ________________________________________________________________________________
Subject: Re: Panel overlays
Date: Feb 07, 2003
Thanks Mike. That was kind of what I was figuring. It sure is nice to follow the pioneers. I will let you know what I come up with for fastening the overlay. Ted By the way, are we planning a mass invasion again in to Oshkosh &/or Brodhead next summer (04)? ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: Pietenpol-List: Panel overlays > > Ted ! I used 1/8" birch plywood for my instrument panels and in the rear > cockpit overlayed the > instrument cluster with 1/4" mahogany plywood. I attached the instruments > to the birch and then the mahogany > plywood hides all that. I used small machine screws from behind into, but > not thru the 1/4" mahogany bezel. I drilled out little recess holes in the > back of the 1/4" overlay and epoxied in small machine screw nuts to accept > the screws.....but after 250 hour and temperature extremes the panel > dropped in my lap one day while taxiing. I put a few dabs of RTV on the > back of the 1/4" ply and popped it back in place. Held it there with > masking tape for 24 hours then business as usual. I thought about velcro > for attatching the overlay but the two layers of that would have lifted the > overlay off the 1/8" birch and I didn't want that look. Let us know if you > come up with a better way. I thought about magnets but then that would > have given my compass schizophrenia. Bad enough that I suffer from it:) > > Mike C. > > ________________________________________________________________________________
Date: Feb 07, 2003
In a message dated 2/7/03 9:40:49 PM Central Standard Time, nfn00979(at)naples.net writes: << By the way, are we planning a mass invasion again in to Oshkosh &/or Brodhead next summer (04)? >> I'm planning an invasion of One, this year !! Anyone from the mid west, or Kansas City area going ? I've been looking forward to this adventrue for years !! Chuck Gantzer Wichita KS ________________________________________________________________________________
Date: Feb 08, 2003
Ted, I'm in for '04. Bert (Tallahassee) ----- Original Message ----- From: "Ted Brousseau" <nfn00979(at)naples.net> Subject: Re: Pietenpol-List: Panel overlays > > Thanks Mike. That was kind of what I was figuring. It sure is nice to > follow the pioneers. I will let you know what I come up with for fastening > the overlay. > > Ted > > By the way, are we planning a mass invasion again in to Oshkosh &/or > Brodhead next summer (04)? > > ----- Original Message ----- > From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> > To: > Subject: Pietenpol-List: Panel overlays > > > > > > > Ted ! I used 1/8" birch plywood for my instrument panels and in the rear > > cockpit overlayed the > > instrument cluster with 1/4" mahogany plywood. I attached the instruments > > to the birch and then the mahogany > > plywood hides all that. I used small machine screws from behind into, but > > not thru the 1/4" mahogany bezel. I drilled out little recess holes in > the > > back of the 1/4" overlay and epoxied in small machine screw nuts to accept > > the screws.....but after 250 hour and temperature extremes the panel > > dropped in my lap one day while taxiing. I put a few dabs of RTV on the > > back of the 1/4" ply and popped it back in place. Held it there with > > masking tape for 24 hours then business as usual. I thought about velcro > > for attatching the overlay but the two layers of that would have lifted > the > > overlay off the 1/8" birch and I didn't want that look. Let us know if > you > > come up with a better way. I thought about magnets but then that would > > have given my compass schizophrenia. Bad enough that I suffer from it:) > > > > Mike C. > > > > > > ________________________________________________________________________________
Subject: pleeeeeease stop snowing
Date: Feb 08, 2003
Walt, Just got my March Kitplanes, there is a great article about flying open-cockpit when its cold. Mostly common sense but you may pick up a couple good hints. Article called Flying Alfresco, page 26. Skip, in sunny Atlanta, 24F cold More snow today,,,went up to knock snow off the hanger, and thought about hugging my Piet. This winter is far tooooooo long. Don't know what it is. Guess it's because I don't have a project to work on. Last fall with it's DAR and licencing, and test flying, seems like a dream. Haven't flown since Nov of last year. walt --- csfog(at)earthlink.net ________________________________________________________________________________
Date: Feb 08, 2003
Subject: Airfoil
Cy Galley is correct, of course. The Cub does use a USA 35B airfoil. I guess it is just that when I build ribs, the Clark Y and the USA 35B look the same. Doc Mosher Oshkosh USA ________________________________________________________________________________
Date: Feb 08, 2003
Barry Davis wrote: > > >>ones in the next day or so. If I find it, I'd be happy to run a copy for >>you. >> >>Regards, >> >>Kip Gardner >> >>North Canton, OH >> >> >> >> > Hi Kip: > Could I also get a copy of them? Am leaning toward Prices fiberglas tank, and have a friend who can heliarc an aluminum tank for me and actually encourages me to go that way. However, he is not as young as he used to be and may kick off before I get to it, so I would like to keep my options open. Dennis Engelkenjohn > > > > ________________________________________________________________________________
Date: Feb 09, 2003
>> Hi Kip: >> > > Could I also get a copy of them? Am leaning toward Prices >fiberglas tank, and have a friend who can heliarc an aluminum tank for >me and actually encourages me to go that way. However, he is not as >young as he used to be and may kick off before I get to it, so I would >like to keep my options open. >Dennis Engelkenjohn Dennis, Sure, I'll be checking shortly & will get back to you. Regards, Kip Gardner North Canton, OH ________________________________________________________________________________
Date: Feb 09, 2003
> >Does anyone have a sketch on how to build wing tanks for the piet?, or >where can I find the information? >Barry Davis Barry and Dennis, OK, I found 2 sets of fuel tank sketches/plans in the Brodhead Piet Assoc. newsletters; Jan 2001 and July 2001. They are rather different designs, so you can pick whatever suits you. One specifies 6061 alum. & the other terne plate, but you could probably make either one out of whatever material you want. I'll be glad to send you copies of both - send me addresses. Cheers! KIp Gardner North Canton, OH ________________________________________________________________________________
Subject: I need some welding help....
Date: Feb 09, 2003
I'm incredibly frustrated........just finished trying to do some welding and it just doesn't seem to be going well. Took a lot longer that the "recommended" 10 seconds to make a puddle and for some reason I got a lot more sparks than usual several times....and I'm afraid I may be burning all the carbon our of the metal and leaving it brittle.... I'm going to call my tech counselor and find someone local that knows what they're doing to give me some instructions/critiques. But in the meantime......can some of you welders (I KNOW you're out there, I've seen some of your welding!) give me a hand? Maybe look at some pictures of what I've done and see if you can make some suggestions? I know it's not hard but I have no idea whether I need more practice or a modified technique (training)... I'm preheating the general area of the parts to be welded and I'm using a "forehand" method. Material thickness is .090, using oxy/gas and 3/32" E70S-2 rod, Victor '0' tip. The flame is tweaked down to where the feather just dissapears and there is a relatively quiet roaring sound...... I've posted 5 "pre-sandblast" pictures on my mykitplane.com build log: http://www.mykitplane.com/TaxiWay/TheHangar/PlaneManager/buildLog.cfm?BuildL ogID=341&PlaneID=52&Menu=BuildLog I can add the pics of the sandblasted parts if that helps..... I simply don't know how close to acceptable (or how far away) I'm getting with this....... If you can help, a private reply might be appropriate but replying to the list is fine with me. Thanks, a VERY frustrated Piet builder in Plano........ ________________________________________________________________________________
From: "walter evans" <wbeevans(at)worldnet.att.net>
Subject: Re: I need some welding help....
Date: Feb 09, 2003
Jim, I'm self taught, with my AP Mentor looking over my shoulder from time to time, BUT, the hardest thing for me to get used to was the time that it takes the work to get to puddle temp. .090" is pretty thick and should take more than the count of ten to puddle. I've never heard that term of 10 sec, but maybe for something .032" or less. Don't think the time is a factor. On most of my Piet. I used a 000 tip. Once in a while used a 0 tip , and on the .090" had to go to a 1 tip. What tip size are you using? If you are joining a group of .090" matl. Don't think that a 0 tip will ever get you there. What type rod is that? My mentor advised using mild rod only. Just another welding tip to remember,,,always point the flame, like an arrow other depending on matl thickness, mass, etc. You can also "shield" the thinner matl with the rod, not to burn it up. Practice, practice, practice. Took me years to get to a point where they're not necessarily pretty, but I trust them. Letting the joint cool in STILL air is VERY important for 4130. Or it'll shatter like glass walt NX140DL ----- Original Message ----- From: "Jim Markle" <jim_markle(at)mindspring.com> Subject: Pietenpol-List: I need some welding help.... > > I'm incredibly frustrated........just finished trying to do some welding and > it just doesn't seem to be going well. Took a lot longer that the > "recommended" 10 seconds to make a puddle and for some reason I got a lot > more sparks than usual several times....and I'm afraid I may be burning all > the carbon our of the metal and leaving it brittle.... > > I'm going to call my tech counselor and find someone local that knows what > they're doing to give me some instructions/critiques. But in the > meantime......can some of you welders (I KNOW you're out there, I've seen > some of your welding!) give me a hand? Maybe look at some pictures of what > I've done and see if you can make some suggestions? I know it's not hard but > I have no idea whether I need more practice or a modified technique > (training)... > > I'm preheating the general area of the parts to be welded and I'm using a > "forehand" method. Material thickness is .090, using oxy/gas and 3/32" > E70S-2 rod, Victor '0' tip. The flame is tweaked down to where the feather > just dissapears and there is a relatively quiet roaring sound...... > > I've posted 5 "pre-sandblast" pictures on my mykitplane.com build log: > > http://www.mykitplane.com/TaxiWay/TheHangar/PlaneManager/buildLog.cfm?BuildL > ogID=341&PlaneID=52&Menu=BuildLog > > I can add the pics of the sandblasted parts if that helps..... > > I simply don't know how close to acceptable (or how far away) I'm getting > with this....... If you can help, a private reply might be appropriate but > replying to the list is fine with me. > > Thanks, > a VERY frustrated Piet builder in Plano........ > > ________________________________________________________________________________
Date: Feb 09, 2003
hmmm, hey, few things I haven't tried!......increase the tip, get some mild rod (is that the same as R45 maybe?) and keep practicing (well, I've done a LOT of practicing!). I've started a list....this is a nice start. Thanks very much Walt. jm ----- Original Message ----- From: "walter evans" <wbeevans(at)worldnet.att.net> Subject: Re: Pietenpol-List: I need some welding help.... > > Jim, > I'm self taught, with my AP Mentor looking over my shoulder from time to > time, BUT, the hardest thing for me to get used to was the time that it Walt's comments........ > Letting the joint cool in STILL air is VERY important for 4130. Or it'll > shatter like glass > walt > NX140DL > > > ----- Original Message ----- > From: "Jim Markle" <jim_markle(at)mindspring.com> > To: > Subject: Pietenpol-List: I need some welding help.... > > > > > > > I'm incredibly frustrated........just finished trying to do some welding > and My ranting and raving.... > > > I simply don't know how close to acceptable (or how far away) I'm getting > > with this....... If you can help, a private reply might be appropriate > but > > replying to the list is fine with me. > > > > Thanks, > > a VERY frustrated Piet builder in Plano........ > > > > > > ________________________________________________________________________________
Date: Feb 09, 2003
Could you spare another copy of those plans. Let me know the cost and I will send it to you. Address is Doyle Combs P. O. Box 421 Lometa, Texas 76853 thanks very much ----- Original Message ----- From: "Kip & Beth Gardner" <kipandbeth(at)earthlink.net> Subject: Re: Pietenpol-List: Wing tanks > > > > >Does anyone have a sketch on how to build wing tanks for the piet?, or > >where can I find the information? > >Barry Davis > > Barry and Dennis, > > OK, I found 2 sets of fuel tank sketches/plans in the Brodhead Piet Assoc. > newsletters; Jan 2001 and July 2001. They are rather different designs, so > you can pick whatever suits you. One specifies 6061 alum. & the other terne > plate, but you could probably make either one out of whatever material you > want. I'll be glad to send you copies of both - send me addresses. > > Cheers! > > KIp Gardner > > > North Canton, OH > > ________________________________________________________________________________
Date: Feb 09, 2003
What tip size are you using? if the tip size is too small, you can heat it all day and it won't puddle. Also if you want to practice today, use coat hanger for practicing. It's basically the same soft drawn wire as the welding rod. Just doesn't have the copper coating to stop rusting. Just kind of preburn the varnish off as you go. walt ----- Original Message ----- From: "Jim Markle" <jim_markle(at)mindspring.com> Subject: Re: Pietenpol-List: I need some welding help.... > > hmmm, hey, few things I haven't tried!......increase the tip, get some mild > rod (is that the same as R45 maybe?) and keep practicing (well, I've done a > LOT of practicing!). > > I've started a list....this is a nice start. > > Thanks very much Walt. > > jm > > ----- Original Message ----- > From: "walter evans" <wbeevans(at)worldnet.att.net> > To: > Subject: Re: Pietenpol-List: I need some welding help.... > > > > > > > Jim, > > I'm self taught, with my AP Mentor looking over my shoulder from time to > > time, BUT, the hardest thing for me to get used to was the time that it > > Walt's comments........ > > > Letting the joint cool in STILL air is VERY important for 4130. Or it'll > > shatter like glass > > walt > > NX140DL > > > > > > ----- Original Message ----- > > From: "Jim Markle" <jim_markle(at)mindspring.com> > > To: > > Subject: Pietenpol-List: I need some welding help.... > > > > > > > > > > > > I'm incredibly frustrated........just finished trying to do some welding > > and > > My ranting and raving.... > > > > > > I simply don't know how close to acceptable (or how far away) I'm > getting > > > with this....... If you can help, a private reply might be appropriate > > but > > > replying to the list is fine with me. > > > > > > Thanks, > > > a VERY frustrated Piet builder in Plano........ > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 09, 2003
I have never heard of 10 sec to puddle. What pressure are you setting your gas and oxy. Popping can be caused by getting your tip too close to you and/or having the flow of the gasses set to low. If you are worried about burning the carbon out of the base metal use a carborizing flame. Keep practicing. Ken av8or(at)citizen.infi.net kring(at)mountainviewdogs.com kring(at)irisweb.net -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Jim Markle Subject: Pietenpol-List: I need some welding help.... I'm incredibly frustrated........just finished trying to do some welding and it just doesn't seem to be going well. Took a lot longer that the "recommended" 10 seconds to make a puddle and for some reason I got a lot more sparks than usual several times....and I'm afraid I may be burning all the carbon our of the metal and leaving it brittle.... I'm going to call my tech counselor and find someone local that knows what they're doing to give me some instructions/critiques. But in the meantime......can some of you welders (I KNOW you're out there, I've seen some of your welding!) give me a hand? Maybe look at some pictures of what I've done and see if you can make some suggestions? I know it's not hard but I have no idea whether I need more practice or a modified technique (training)... I'm preheating the general area of the parts to be welded and I'm using a "forehand" method. Material thickness is .090, using oxy/gas and 3/32" E70S-2 rod, Victor '0' tip. The flame is tweaked down to where the feather just dissapears and there is a relatively quiet roaring sound...... I've posted 5 "pre-sandblast" pictures on my mykitplane.com build log: http://www.mykitplane.com/TaxiWay/TheHangar/PlaneManager/buildLog.cfm?BuildL ogID=341&PlaneID=52&Menu=BuildLog I can add the pics of the sandblasted parts if that helps..... I simply don't know how close to acceptable (or how far away) I'm getting with this....... If you can help, a private reply might be appropriate but replying to the list is fine with me. Thanks, a VERY frustrated Piet builder in Plano........ ________________________________________________________________________________
Date: Feb 09, 2003
Jim, the link wouldn't work chris -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Jim Markle Subject: Pietenpol-List: I need some welding help.... I'm incredibly frustrated........just finished trying to do some welding and it just doesn't seem to be going well. Took a lot longer that the "recommended" 10 seconds to make a puddle and for some reason I got a lot more sparks than usual several times....and I'm afraid I may be burning all the carbon our of the metal and leaving it brittle.... I'm going to call my tech counselor and find someone local that knows what they're doing to give me some instructions/critiques. But in the meantime......can some of you welders (I KNOW you're out there, I've seen some of your welding!) give me a hand? Maybe look at some pictures of what I've done and see if you can make some suggestions? I know it's not hard but I have no idea whether I need more practice or a modified technique (training)... I'm preheating the general area of the parts to be welded and I'm using a "forehand" method. Material thickness is .090, using oxy/gas and 3/32" E70S-2 rod, Victor '0' tip. The flame is tweaked down to where the feather just dissapears and there is a relatively quiet roaring sound...... I've posted 5 "pre-sandblast" pictures on my mykitplane.com build log: http://www.mykitplane.com/TaxiWay/TheHangar/PlaneManager/buildLog.cfm?BuildL ogID=341&PlaneID=52&Menu=BuildLog I can add the pics of the sandblasted parts if that helps..... I simply don't know how close to acceptable (or how far away) I'm getting with this....... If you can help, a private reply might be appropriate but replying to the list is fine with me. Thanks, a VERY frustrated Piet builder in Plano........ ________________________________________________________________________________
Date: Feb 09, 2003
Coat hanger wire is not the same. Coat hanger wire can be of any alloy and unless you get you coat hangers from the same lot they probably are not even the same. Now for practice and automobile exhaust systems coat hangers are ok but for anything else use a rod that you know is correct. Ken av8or(at)citizen.infi.net kring(at)mountainviewdogs.com kring(at)irisweb.net -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of walter evans Subject: Re: Pietenpol-List: I need some welding help.... What tip size are you using? if the tip size is too small, you can heat it all day and it won't puddle. Also if you want to practice today, use coat hanger for practicing. It's basically the same soft drawn wire as the welding rod. Just doesn't have the copper coating to stop rusting. Just kind of preburn the varnish off as you go. walt ----- Original Message ----- From: "Jim Markle" <jim_markle(at)mindspring.com> Subject: Re: Pietenpol-List: I need some welding help.... > > hmmm, hey, few things I haven't tried!......increase the tip, get some mild > rod (is that the same as R45 maybe?) and keep practicing (well, I've done a > LOT of practicing!). > > I've started a list....this is a nice start. > > Thanks very much Walt. > > jm > > ----- Original Message ----- > From: "walter evans" <wbeevans(at)worldnet.att.net> > To: > Subject: Re: Pietenpol-List: I need some welding help.... > > > > > > > Jim, > > I'm self taught, with my AP Mentor looking over my shoulder from time to > > time, BUT, the hardest thing for me to get used to was the time that it > > Walt's comments........ > > > Letting the joint cool in STILL air is VERY important for 4130. Or it'll > > shatter like glass > > walt > > NX140DL > > > > > > ----- Original Message ----- > > From: "Jim Markle" <jim_markle(at)mindspring.com> > > To: > > Subject: Pietenpol-List: I need some welding help.... > > > > > > > > > > > > I'm incredibly frustrated........just finished trying to do some welding > > and > > My ranting and raving.... > > > > > > I simply don't know how close to acceptable (or how far away) I'm > getting > > > with this....... If you can help, a private reply might be appropriate > > but > > > replying to the list is fine with me. > > > > > > Thanks, > > > a VERY frustrated Piet builder in Plano........ > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 09, 2003
I just said " if you want to PRACTICE today, use coathanger. You won't know the difference, if there is a difference. Would I want my engine mount done in coathanger?,,,no,,,but practice with it. walt ----- Original Message ----- From: "Ken" <av8or(at)citizen.infi.net> Subject: RE: Pietenpol-List: I need some welding help.... > > Coat hanger wire is not the same. Coat hanger wire can be of any alloy and > unless you get you coat hangers from the same lot they probably are not even > the same. Now for practice and automobile exhaust systems coat hangers are > ok but for anything else use a rod that you know is correct. > > > Ken > av8or(at)citizen.infi.net > kring(at)mountainviewdogs.com > kring(at)irisweb.net > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of walter > evans > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: I need some welding help.... > > > > > What tip size are you using? if the tip size is too small, you can heat it > all day and it won't puddle. > Also if you want to practice today, use coat hanger for practicing. It's > basically the same soft drawn wire as the welding rod. Just doesn't have > the copper coating to stop rusting. Just kind of preburn the varnish off > as you go. > walt > ----- Original Message ----- > From: "Jim Markle" <jim_markle(at)mindspring.com> > To: > Subject: Re: Pietenpol-List: I need some welding help.... > > > > > > > hmmm, hey, few things I haven't tried!......increase the tip, get some > mild > > rod (is that the same as R45 maybe?) and keep practicing (well, I've done > a > > LOT of practicing!). > > > > I've started a list....this is a nice start. > > > > Thanks very much Walt. > > > > jm > > > > ----- Original Message ----- > > From: "walter evans" <wbeevans(at)worldnet.att.net> > > To: > > Subject: Re: Pietenpol-List: I need some welding help.... > > > > > > > > > > > > Jim, > > > I'm self taught, with my AP Mentor looking over my shoulder from time to > > > time, BUT, the hardest thing for me to get used to was the time that it > > > > Walt's comments........ > > > > > Letting the joint cool in STILL air is VERY important for 4130. Or > it'll > > > shatter like glass > > > walt > > > NX140DL > > > > > > > > > ----- Original Message ----- > > > From: "Jim Markle" <jim_markle(at)mindspring.com> > > > To: > > > Subject: Pietenpol-List: I need some welding help.... > > > > > > > > > > > > > > > > > I'm incredibly frustrated........just finished trying to do some > welding > > > and > > > > My ranting and raving.... > > > > > > > > > I simply don't know how close to acceptable (or how far away) I'm > > getting > > > > with this....... If you can help, a private reply might be > appropriate > > > but > > > > replying to the list is fine with me. > > > > > > > > Thanks, > > > > a VERY frustrated Piet builder in Plano........ > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 09, 2003
I've never figured out why links get trashed when you copy them to the list!! Oh well, maybe it's best just to go to www.mykitplane.com and look at builder's logs and look at today's entry in my log.... Jim in Plano....not QUITE so frustrated now...... ----- Original Message ----- From: "Christian Bobka" <bobka(at)charter.net> Subject: RE: Pietenpol-List: I need some welding help.... > > Jim, > > the link wouldn't work > > chris > > -----Original Message----- blah, blah, blah...... ________________________________________________________________________________
Date: Feb 09, 2003
Jim. I found that practicing with .065 or .043 (?) was helpful. .090 and .125 were more difficult at first for me. - Icould never feel when he metal was "ready" - I'd get impatient and start jockeying the flame and sticking the rod in before it was ready. Also I found that starting with a simple fitting or just just simply combining two parts with and edge weld made it easier because of the uniformity of the fitting - you don't have to deal with the heat sink nature of certain parts of complicated fittings. 2 cents good luck. Keep practicing..bert ----- Original Message ----- From: "Jim Markle" <jim_markle(at)mindspring.com> Subject: Re: Pietenpol-List: I need some welding help.... > > I've never figured out why links get trashed when you copy them to the > list!! > > Oh well, maybe it's best just to go to www.mykitplane.com and look at > builder's logs and look at today's entry in my log.... > > Jim in Plano....not QUITE so frustrated now...... > > > ----- Original Message ----- > From: "Christian Bobka" <bobka(at)charter.net> > To: > Subject: RE: Pietenpol-List: I need some welding help.... > > > > > > > Jim, > > > > the link wouldn't work > > > > chris > > > > -----Original Message----- > > > blah, blah, blah...... > > ________________________________________________________________________________
Date: Feb 09, 2003
Check out www.airbum.com go to articles and then to " Zen of the Weld Puddle " ----- Original Message ----- > To: > > > > > ________________________________________________________________________________
Date: Feb 09, 2003
Jim,, I don't know about counting to 10 for a puddle, but I might suggest trying a #2 tip, bring your flame down to about half an inch. Make small circles slowly until the puddle starts,, then hold straight and start feeding with the rod. The #2 tip has a wide range of adjustment so you can increase or decrease the flame. If she's popping,, pull the tip back a bit and make sure you use the tip cleaner after that happens. hope this helps. Carl ----- Original Message ----- From: "Jim Markle" <jim_markle(at)mindspring.com> Subject: Pietenpol-List: I need some welding help.... > > I'm incredibly frustrated........just finished trying to do some welding and > it just doesn't seem to be going well. Took a lot longer that the > "recommended" 10 seconds to make a puddle and for some reason I got a lot > more sparks than usual several times....and I'm afraid I may be burning all > the carbon our of the metal and leaving it brittle.... > > I'm going to call my tech counselor and find someone local that knows what > they're doing to give me some instructions/critiques. But in the > meantime......can some of you welders (I KNOW you're out there, I've seen > some of your welding!) give me a hand? Maybe look at some pictures of what > I've done and see if you can make some suggestions? I know it's not hard but > I have no idea whether I need more practice or a modified technique > (training)... > > I'm preheating the general area of the parts to be welded and I'm using a > "forehand" method. Material thickness is .090, using oxy/gas and 3/32" > E70S-2 rod, Victor '0' tip. The flame is tweaked down to where the feather > just dissapears and there is a relatively quiet roaring sound...... > > I've posted 5 "pre-sandblast" pictures on my mykitplane.com build log: > > http://www.mykitplane.com/TaxiWay/TheHangar/PlaneManager/buildLog.cfm?BuildL > ogID=341&PlaneID=52&Menu=BuildLog > > I can add the pics of the sandblasted parts if that helps..... > > I simply don't know how close to acceptable (or how far away) I'm getting > with this....... If you can help, a private reply might be appropriate but > replying to the list is fine with me. > > Thanks, > a VERY frustrated Piet builder in Plano........ > > ________________________________________________________________________________
Date: Feb 09, 2003
Jim, I have a really good book that I bought at Hastings The Welders Handbook by Finch/Monroe. Now first I must tell you there are a few lines you have to read through. For one he talks about your shop temperature, lighting, breezes, coper coated wire ect. Made me think that a person would need a semiconductor clean room with perfect atmosphere. But I know dammed well most Pipers, Aeroncas, and Taylorcrafts were not built to his standards, but the guy is a certified welder. Some excellent things he points out are different tip sizes for different thickness material, operating pressures of your regulators, carbonizing flame (good) vs. lean (Bad) pulls the carbon right out of the material, overheating the tip which causes popping. Now I could go on but typing is not my cup of tea. If by chance you don't have a book, try and get one. I looked at your parts, first I hate to see people practice on finished pieces. Try setting up some scrap without doing all the finish work and welding on those first, once your happy then do your drilled & shaped finish parts. To me it looks like your flame went lean, you went to fast and your pressure on your regulators may be to high. A common mistake is trying to force to small of tip to weld heavy material, often by doing this you jack up your regulator pressure to high. Think of it this way, if you blow on a liquid metal to hard it causes it to puddle out and disfigure the weld. You need the right size tip, so you get a hot enough flame with a gentle touch. Watch your tip flame like you watch your airspeed, it must stay slightly rich Carbonizing (very important). The part you are welding is difficult because your flame is surrounded by metal fitting, which will make the tip get hot and pop, especially if using to small of tip. I am no expert but I hope this helps, and don't be hard on yourself, good welding comes the same way as good landings. Dan ________________________________________________________________________________
Date: Feb 09, 2003
Subject: welding
Hi friends Hi Jim Welding it's not hard, just practice and more practice, it's very important that you have the regulators with the correct setting , adjust the flame so you have a little acetylene feather (1 or 2 millimeters are ok), so you be sure that your flame it's not oxidizing and maintain the flame over the puddle with little circles , and at 45 degrees apx.. so you can maintain the heat on the metal, try that the blue flame don't touch the puddle, the metals have to joint, and the rod is for fill the metal lost. About the time, it's hard to know how many, that depends on your flame. I would like recommend you that make some weld works parts for practice and after check this with a hammer, and cut some welded parts too so you can check your work, looking for a good penetration... go ahead. Javier Cruz ________________________________________________________________________________
Date: Feb 10, 2003
Subject: Back on track....(welding update from Plano)
Ok, thanks for the input! I've determined that the following points need attention (most of these I already knew but old age has a way of....well, whatever.....). I'll probably print this out and post it in my shop: 1. Use the right tip. Don't be shy! 2. Adjust the flame properly (look AND sound). Avoid an oxidizing flame! 3. Avoid heat sinks. Tack it and then move heat sinking stuff like jigs, clamps, etc AWAY! 4. Re-read "Zen and the Art of the Weld Puddle" (www.airbum.com) 5. Review my "How to Weld" books. 6. Sit down and have some kind of support for my hands/arms. 7. Practice for a while before starting on the good stuff. 8. Pay attention to those sparks flying all over the place! They're telling you something! 9. Maintain a proper flame to puddle distance! 10. No puddle and you've held it there for a LONG time? More of item 1 above.... 11. Feed the rod consistently. Items that I left out or forgot and that impacted my frustration level, stress level and weld quality: Uhhh, ALL of the above....... I will still pursue getting my EAA Counselor to recommend someone to look over my shoulder and give me some input and I'll possibly take a basic welding class. I went back and did a couple little welds after getting my act together yesterday and the process was MUCH better. Not quite there, obviously, but better! Thanks again to everyone's suggestions! Jim in Plano (feeling a little better about this welding stuff now......) ________________________________________________________________________________
Date: Feb 10, 2003
Subject: Address
Piets Could someone supply me with the name of the man in Minnesota who makes those little cast hinges for the Pietenpol tail feathers. Thanks Corky working hard in La on N84CC ________________________________________________________________________________
Date: Feb 10, 2003
Subject: Re: Address
In a message dated 2/10/03 9:01:34 PM Eastern Standard Time, Isablcorky(at)aol.com writes: > Could someone supply me with the name of the man in Minnesota who makes those > > little cast hinges for the Pietenpol tail feathers. Thanks > > Corky working hard in La on N84CC His name was Vi Kapler, dont have his address tho ________________________________________________________________________________
Date: Feb 10, 2003
Corky, Check the Archives, I think you'll find more than one message with address in the last year or two . Clif, 1072 miles to your north, Heading -348.5 As the crow flies, of course. ----- Original Message ----- From: <Dmott9(at)aol.com> Subject: Re: Pietenpol-List: Address > > In a message dated 2/10/03 9:01:34 PM Eastern Standard Time, > Isablcorky(at)aol.com writes: > > > Could someone supply me with the name of the man in Minnesota who makes > those > > > > little cast hinges for the Pietenpol tail feathers. Thanks > > > > Corky working hard in La on N84CC > His name was Vi Kapler, dont have his address tho > > ________________________________________________________________________________
Date: Feb 10, 2003
Isablcorky(at)aol.com wrote: > >Piets > >Could someone supply me with the name of the man in Minnesota who makes those >little cast hinges for the Pietenpol tail feathers. Thanks > > Try this: Vitalis Kapler 1033 Forest Hill Dr.SW Rochester, MN 55902 His phone # (507) 288-3322 Besides the hinges he sells manifolds for the corvair and prop hubs, but they cannot use electric on the hub like WW's. He might make motor mounts, I've heard so, but haven't asked him. If you contact him, please ask him for me and how much $ Dennis Engelkenjohn ________________________________________________________________________________
Date: Feb 11, 2003
Thanks Clif, Corky, about 16 Piet hours away ________________________________________________________________________________
Subject: mockup
Date: Feb 11, 2003
HI Gang; I am in the Fla panhandle; on St George Island, 75 miles southwest of Tallahassee. I have a full size fuselage mockup from rear seat to firewall. Anyone is welcome to it. It was a great help in locating everything.Come and get it or it will become a beach bonfire. My fuselage is done-- here are the adjectives; level,plumb, square, strong, simple, and light. Thanks Bernie. Cheers John Ficklen ________________________________________________________________________________
Subject: Fw: [f-AA] transponder for a 7AC?
Date: Feb 11, 2003
FYI ----- Original Message ----- From: "Government Programs" <govt(at)eaa.org> Bogenhagen" Subject: RE: [f-AA] transponder for a 7AC? Cy and Paul, EAA has been working with the TSA (and the FAA) since they issued the new ADIZ around the DC area. In a meeting yesterday, they confirmed the requirements of the ADIZ Notam - all aircraft, including ultralights, operating within the ADIZ must have a operational transponder and a two way radio - no exceptions. They also indicated that when the threat level goes back down the ADIZ will remain, but will be moved in to match the current Class B airspace, but will move back to it's current position if the threat level should ever go back up to Orange or Red. I don't know about cheaper transponder or radio options - I'll pass that question to Joe and Mark in EAA's Aviation Information Services department. One good thing that did come out of the meeting is that normal ADIZ's require all aircraft to have 12" N numbers - but this is not a "normal" ADIZ, so all aircraft can keep their current markings, vintage/Warbird/AB ultralight aircraft with small N numbers and ultralight vehicles with small EAA/ASC/USUA registration numbers. TSA also acknowledged that procedures must be established to allow owners of aircraft and ultralight vehicles who elect not to install the required equipment to fly (or "flush") their aircraft from the effected area. They kind of did it this time with the 3 day advance warning, but for those who did not look at Notams during that advance notice they acknowledge that other procedures must be established for "flushing". Randy -----Original Message----- From: Cy Galley [mailto:cgalley(at)qcbc.org] Subject: Fw: [f-AA] transponder for a 7AC? Check with govt(at)eaa.org to see your options. Did they give you an FAR? Or just badger you with its they way we are going to do it under the "patriot" act and we make the rules. Cy Galley Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org ----- Original Message ----- From: "Paul Miller" <phmiller(at)usna.edu> Subject: [f-AA] transponder for a 7AC? > According to the TSA/FAA, yesterday morning the 7AC Champ (A-65-8) and many other classic > aircraft became a threat to national security as they do not have a transponder. They are no > longer allowed to fly in the Baltimore-Washington extended Class B airspace. As our plane was > based in that area, on Sunday we flew it out of the area. If we decide to keep the Champ our > options seem to be: > 1. Keep it outside and drive an hour to the plane (versus 10 minutes) > 2. Install a transponder and upgrade the handheld radio so that we can talk with the FSS and > Balt. Approach. > > Option 2 seems to mean that we need to get: altitude encoder, transponder antenna, transponder, > ground plane, battery, battery charger, wires and installation. The avionics shop quoted $2500 > for the lot. The radio upgrade ranges from $30-$2500 depending on how much needs to be done. > > So, has anyone installed a simpler, less expensive transponder system?! > Thanks, > Paul > > _______________________________________________ > Aeronca mailing list > Aeronca(at)mail.westmont.edu > http://mail.westmont.edu/mailman/listinfo/aeronca > ________________________________________________________________________________
Subject: Re: Wing tanks
Date: Feb 11, 2003
Thanks Barry Davis 728-B Bankhead Ave Carrollton, Ga. 30117 ----- Original Message ----- From: "Kip & Beth Gardner" <kipandbeth(at)earthlink.net> Subject: Re: Pietenpol-List: Wing tanks > > > > >Does anyone have a sketch on how to build wing tanks for the piet?, or > >where can I find the information? > >Barry Davis > > Barry and Dennis, > > OK, I found 2 sets of fuel tank sketches/plans in the Brodhead Piet Assoc. > newsletters; Jan 2001 and July 2001. They are rather different designs, so > you can pick whatever suits you. One specifies 6061 alum. & the other terne > plate, but you could probably make either one out of whatever material you > want. I'll be glad to send you copies of both - send me addresses. > > Cheers! > > KIp Gardner > > > North Canton, OH > > ________________________________________________________________________________
Date: Feb 11, 2003
From: Kip & Beth Gardner <kipandbeth(at)earthlink.net>
Subject: Re: long fuse gear
> >In a message dated 2/2/2003 8:04:58 PM Central Standard Time, >kipandbeth(at)earthlink.net writes: > >> I can ask him for details or make measurements for anyone that wants them > >Kip, >I would very much appreciate any info in this regard that Frank can pass >along. I have the long fuselage with the Model A and the solid wood gear, the >same as his. I had built and installed the gear before the thread began on >this subject. Of course that gear was intended for the original FGM version. >I positioned mine in the location of the second version ("new, improved") >which is probably equally wrong but I wanted to resist making any changes >before doing my w&b and seeing what my tailwheel weight was. There may be >meaningful differences dpending on whether Frank used fir or spruce on his >fuselage. I did make a concerted effort to keep mine light in the >tailfeathers and used spruce throughout. I'm fully covered, painted and >complete and hopefully will be doing my final w&b this weekend. Thanks agin >for the offer. Don Hicks Don, Well, I made it to the airport this weekend - missed Frank Pavliga by mere minutes! However, I'm told he's been there a lot recently, finishing up the Waco; anyone with 170k to burn, it's a gorgeous aircraft. Anyway, I did get the firewall-to-axle measurement on Sky Gypsy. It's 19", plus or minus 1/4" It was COLD & DARK in the hangar, so I'm not apologizing for the sloppy measurement ;). Also ,for what it's worth, the Chunk'o lead that Chris Bobka mentioned is definitely AWOL from anywhwere on or about the engine/engine mount. I will still try to get W&B details from Frank sometime soon, so as to make things more meaningful. Cheers! Kip Gardner North Canton, OH ________________________________________________________________________________
Date: Feb 12, 2003
Subject: Correction----go to: http://www.barnstormers2000.com/
group---my error. Try this to get to Barnstormers...... http://www.barnstormers2000.com/ ________________________________________________________________________________
Date: Feb 12, 2003
Subject: this is Way cool ! A biplane Piet
Group--I stumbled on this and it looks nice. Actually there are several Piets, GN-1's and engines for sale if you go to http://www.barnstormers.com THEN scroll and pick "experimental" then scroll down and pick Pietenpol. Neat stuff ! Mike C. PIETENPOLE -- BIPLANE =95 FLY RIGHT NOW!! .. PHOTO .. PHOTO .. PHOTO .. PHOTO .. Aerial Pietenpole Biplane; L 0290, 270 SMOH, Electric start, Hydraulic Breaks. This plane flies and looks great. $16,000.00. Contact Jeff Younce located Trenton SC USA. Telephone: 803-637-4949. -- Posted 5 January 2003 -- Show all Ads posted by this Advertiser -- To send this Ad to a friend: Click here. ________________________________________________________________________________
Date: Feb 12, 2003
Subject: Re: this is Way cool ! A biplane Piet
Aerial-plans-St Croix Aircraft. From Jan Kitplanes list of plansbuilt AC. Page 27, Clif ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: Pietenpol-List: this is Way cool ! A biplane Piet> > > ________________________________________________________________________________
Subject: long fuse gear
Date: Feb 13, 2003
Kip, Please ask him about the lead. It was there last time his ship was at Brodhead. I took a picture of it so I know I ain't lyin'. The measurement was with the longerons level fore and aft? chris bobka -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Kip & Beth Gardner Subject: Re: Pietenpol-List: long fuse gear > >In a message dated 2/2/2003 8:04:58 PM Central Standard Time, >kipandbeth(at)earthlink.net writes: > >> I can ask him for details or make measurements for anyone that wants them > >Kip, >I would very much appreciate any info in this regard that Frank can pass >along. I have the long fuselage with the Model A and the solid wood gear, the >same as his. I had built and installed the gear before the thread began on >this subject. Of course that gear was intended for the original FGM version. >I positioned mine in the location of the second version ("new, improved") >which is probably equally wrong but I wanted to resist making any changes >before doing my w&b and seeing what my tailwheel weight was. There may be >meaningful differences dpending on whether Frank used fir or spruce on his >fuselage. I did make a concerted effort to keep mine light in the >tailfeathers and used spruce throughout. I'm fully covered, painted and >complete and hopefully will be doing my final w&b this weekend. Thanks agin >for the offer. Don Hicks Don, Well, I made it to the airport this weekend - missed Frank Pavliga by mere minutes! However, I'm told he's been there a lot recently, finishing up the Waco; anyone with 170k to burn, it's a gorgeous aircraft. Anyway, I did get the firewall-to-axle measurement on Sky Gypsy. It's 19", plus or minus 1/4" It was COLD & DARK in the hangar, so I'm not apologizing for the sloppy measurement ;). Also ,for what it's worth, the Chunk'o lead that Chris Bobka mentioned is definitely AWOL from anywhwere on or about the engine/engine mount. I will still try to get W&B details from Frank sometime soon, so as to make things more meaningful. Cheers! Kip Gardner North Canton, OH ________________________________________________________________________________
Date: Feb 14, 2003
Subject: Sky Gypsy Lead
Frank Pavliga lost quite a bit of weight during the past year so he removed the lead weight that was attached to his motor mount on his long fuse. Cont. 65 Pietenpol. Mike C. ________________________________________________________________________________
Date: Feb 14, 2003
The truth comes out. I remember him to be slight of build. Is he ok healthwise? Chris Bobka -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Michael D Cuy Subject: Pietenpol-List: Sky Gypsy Lead Frank Pavliga lost quite a bit of weight during the past year so he removed the lead weight that was attached to his motor mount on his long fuse. Cont. 65 Pietenpol. Mike C. ________________________________________________________________________________
Date: Feb 14, 2003
I don't know, maybe it's just me, but why do they call the bi-plane a Piet? The tail isn't a Piet, the wing tips aren't a Piet. The rear fuse isn't a Piet. What on there is a Piet? If you have a Model A, and rip the body off it and put a Chrysler nose on it and a Buick rear on it, and a Hudson roof on it, is it still a Ford? How would you possibly recognize that as a Piet? (even the name is spelled wrong) Or is that the key? Should have been "Stearman for sale" (two holes,,,got to be a Stearman) Sorry,,, bad mood tonite. More snow on the way, 1 foot by Sunday nite : () walt ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: Pietenpol-List: this is Way cool ! A biplane Piet > > > Group--I stumbled on this and it looks nice. Actually there are several > Piets, GN-1's and engines for sale if you go to > http://www.barnstormers.com THEN scroll and pick "experimental" then > scroll down and pick Pietenpol. Neat stuff ! Mike C. > > PIETENPOLE -- BIPLANE =95 FLY RIGHT NOW!! .. PHOTO .. PHOTO .. PHOTO .. PHOTO > .. Aerial Pietenpole Biplane; L 0290, 270 SMOH, Electric start, Hydraulic > Breaks. This plane flies and looks great. $16,000.00. Contact Jeff Younce > located Trenton SC USA. Telephone: 803-637-4949. -- Posted 5 January 2003 > -- Show all Ads posted by this Advertiser -- To send this Ad to a friend: > Click here. > > ________________________________________________________________________________
Date: Feb 14, 2003
Hey it's not Piet that's for sure. But in defense of it I thought you might want to know that the one in the Barnstormers add had been modified to look more like a Waco. The St. Croix version looks more like a Piet with an extra wing. They also sell the mono wing Piet plans, but of course like Grega it just ain't a Pietenpol, unless the plans come from Pietenpol. Dan ________________________________________________________________________________
Date: Feb 15, 2003
Subject: Re: Sky Gypsy Lead
Walt---you are right about that biplane Piet. Doesn't even look like a Piet after I got to looking at all the photos of it. Also we are bogged down with cold and snow too. I'm getting a bit anxious to fly too. It's been since Nov. 15th. Normally we get to fly at least once per month even in Jan/Feb/March. Not this year. Chris---Frank Pavliga is in good health. His dad passed on from heart/cholesterol problems so Frank took on a workout program to keep himself pretty lean to guard against those problems. Mike C. ________________________________________________________________________________
Subject: near birdstrike
Date: Feb 15, 2003
I just had a heart stopping experience.... Went around for some local flying today in the club 152. A friend and I were just zipping around the valley (nice day today... partly cloudy and 68 degrees). Just as I'm calling Falcon Field Tower for landing my friend yells "Bird!" Straight ahead at same altitude is a huge Falcon heading straight at us. I had about 1 second to react... I nosed over hard and to the right just as the bird slipped passed us right over the windshield... I swear I saw the look in that bird eyes. It's a damn good thing my friend yelled cause I was looking off to my right at Falcon Field as I was calling in for landing. If I hadn't have nosed over that Falcon would have hit either smack in the center of the windshield or an engine intake. Those Falcons are big too.. probably 6lbs and 4 ft. wingspan. I figure we were doing around 100kts and the bird was probably doing 20kts. I could only imagine if it had hit the windshield... it'd have gone right through into the cockpit. I've come close to birds before, but this was a definate near miss. What's amazing is just about 20 minutes prior to that we almost hit a heart shaped mylar helium balloon (Valentine's balloon no doubt). That wasn't as scary since a balloon would most likely not do any damage.... Just goes to show you, you can have months of boring flying and then in one day have a handful. I'm definately gonna mark down some remarks of today's flight in the logbook... look back at it 20 yrs from now and chuckle. DJ Vegh www.raptoronline.com This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>. ________________________________________________________________________________
Subject: Re: near birdstrike
Date: Feb 15, 2003
Tell your friend that he deffinitely saved one life today,,, and maybe three. Can you imagine getting hit in the face with a bag of sugar at 100mph? I can't. I could have taken you both out, not to mention the loss to the raptor neighborhood. All of us in the sky have a special bond, either bird or Piet. (that the people walking the dirt don't understand) walt evans NX140DL ----- Original Message ----- From: "DJ Vegh" <aircamper(at)imagedv.com> Subject: Pietenpol-List: near birdstrike > > I just had a heart stopping experience.... Went around for some local > flying today in the club 152. A friend and I were just zipping around the > valley (nice day today... partly cloudy and 68 degrees). > > Just as I'm calling Falcon Field Tower for landing my friend yells "Bird!" > Straight ahead at same altitude is a huge Falcon heading straight at us. I > had about 1 second to react... I nosed over hard and to the right just as > the bird slipped passed us right over the windshield... I swear I saw the > look in that bird eyes. > > It's a damn good thing my friend yelled cause I was looking off to my right > at Falcon Field as I was calling in for landing. > > If I hadn't have nosed over that Falcon would have hit either smack in the > center of the windshield or an engine intake. > > Those Falcons are big too.. probably 6lbs and 4 ft. wingspan. I figure we > were doing around 100kts and the bird was probably doing 20kts. > > I could only imagine if it had hit the windshield... it'd have gone right > through into the cockpit. > > I've come close to birds before, but this was a definate near miss. > > What's amazing is just about 20 minutes prior to that we almost hit a heart > shaped mylar helium balloon (Valentine's balloon no doubt). That wasn't as > scary since a balloon would most likely not do any damage.... > > Just goes to show you, you can have months of boring flying and then in one > day have a handful. > > I'm definately gonna mark down some remarks of today's flight in the > logbook... look back at it 20 yrs from now and chuckle. > > DJ Vegh > www.raptoronline.com > > > This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>. > > ________________________________________________________________________________
Date: Feb 15, 2003
----- Original Message ----- From: "DJ Vegh" <aircamper(at)imagedv.com> Subject: Pietenpol-List: near birdstrike ++++++++++++++++++++++++++++ DJ, No way in the world you could hit that falcon.....Isn't it a protected species? :) John +++++++++++++++++++++++++++++++ > > I just had a heart stopping experience.... Went around for some local > flying today in the club 152. A friend and I were just zipping around the > valley (nice day today... partly cloudy and 68 degrees). > > Just as I'm calling Falcon Field Tower for landing my friend yells "Bird!" > Straight ahead at same altitude is a huge Falcon heading straight at us. I > had about 1 second to react... I nosed over hard and to the right just as > the bird slipped passed us right over the windshield... I swear I saw the > look in that bird eyes. > > It's a damn good thing my friend yelled cause I was looking off to my right > at Falcon Field as I was calling in for landing. > > If I hadn't have nosed over that Falcon would have hit either smack in the > center of the windshield or an engine intake. > > Those Falcons are big too.. probably 6lbs and 4 ft. wingspan. I figure we > were doing around 100kts and the bird was probably doing 20kts. > > I could only imagine if it had hit the windshield... it'd have gone right > through into the cockpit. > > I've come close to birds before, but this was a definate near miss. > > What's amazing is just about 20 minutes prior to that we almost hit a heart > shaped mylar helium balloon (Valentine's balloon no doubt). That wasn't as > scary since a balloon would most likely not do any damage.... > > Just goes to show you, you can have months of boring flying and then in one > day have a handful. > > I'm definately gonna mark down some remarks of today's flight in the > logbook... look back at it 20 yrs from now and chuckle. > > DJ Vegh > www.raptoronline.com > > > This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>. > > ________________________________________________________________________________
Date: Feb 15, 2003
DJ, A cessna will not fly with the windshield. It disturbs the airflow so much over the tail that they can't fly. Call it a lucky day. The mylar balloons are lots of fun to chase. Unless the prop actually hits them, they will bounce off the windshield and you have to go back and do it again. It is pretty hard to find it the second time around too. I used to live on the north side of Dallas and with the prevailing south wind, every afternoon had its handfull of balloons. I was a regular Frank Luke. At least a double ace and maybe even a triple. One time, in my Taylorcraft, I hit the balloon low and to the right. After bursting, the big piece of mylar wrapped itself around the wing strut and I landed with the "victim" as a souvenir. As far as the falcon, I have seen flight of ducks pass over the top of the cockpit, in the SAAB 340 without lights on, at 250KTS, at 9000 feet, AT NIGHT. chris bobka -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of DJ Vegh Subject: Pietenpol-List: near birdstrike I just had a heart stopping experience.... Went around for some local flying today in the club 152. A friend and I were just zipping around the valley (nice day today... partly cloudy and 68 degrees). Just as I'm calling Falcon Field Tower for landing my friend yells "Bird!" Straight ahead at same altitude is a huge Falcon heading straight at us. I had about 1 second to react... I nosed over hard and to the right just as the bird slipped passed us right over the windshield... I swear I saw the look in that bird eyes. It's a damn good thing my friend yelled cause I was looking off to my right at Falcon Field as I was calling in for landing. If I hadn't have nosed over that Falcon would have hit either smack in the center of the windshield or an engine intake. Those Falcons are big too.. probably 6lbs and 4 ft. wingspan. I figure we were doing around 100kts and the bird was probably doing 20kts. I could only imagine if it had hit the windshield... it'd have gone right through into the cockpit. I've come close to birds before, but this was a definate near miss. What's amazing is just about 20 minutes prior to that we almost hit a heart shaped mylar helium balloon (Valentine's balloon no doubt). That wasn't as scary since a balloon would most likely not do any damage.... Just goes to show you, you can have months of boring flying and then in one day have a handful. I'm definately gonna mark down some remarks of today's flight in the logbook... look back at it 20 yrs from now and chuckle. DJ Vegh www.raptoronline.com This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>. ________________________________________________________________________________
Date: Feb 15, 2003
DJ, A cessna will not fly with the windshield gone. It disturbs the airflow so much over the tail that they can't fly. Call it a lucky day. The mylar balloons are lots of fun to chase. Unless the prop actually hits them, they will bounce off the windshield and you have to go back and do it again. It is pretty hard to find it the second time around too. I used to live on the north side of Dallas and with the prevailing south wind, every afternoon had its handfull of balloons. I was a regular Frank Luke. At least a double ace and maybe even a triple. One time, in my Taylorcraft, I hit the balloon low and to the right. After bursting, the big piece of mylar wrapped itself around the wing strut and I landed with the "victim" as a souvenir. As far as the falcon, I have seen flight of ducks pass over the top of the cockpit, in the SAAB 340 without lights on, at 250KTS, at 9000 feet, AT NIGHT. chris bobka ________________________________________________________________________________
Date: Feb 16, 2003
I think you met to say... "A Cessna will not fly withOUT the windshield. It disturbs the airflow so much over the tail that they can't fly. Call it a lucky day." ----- Original Message ----- From: "Christian Bobka" <bobka(at)charter.net> Subject: RE: Pietenpol-List: near birdstrike > > DJ, > > A cessna will not fly with the windshield. It disturbs the airflow so much > over the tail that they can't fly. Call it a lucky day. > > The mylar balloons are lots of fun to chase. Unless the prop actually hits > them, they will bounce off the windshield and you have to go back and do it > again. It is pretty hard to find it the second time around too. I used to > live on the north side of Dallas and with the prevailing south wind, every > afternoon had its handfull of balloons. I was a regular Frank Luke. At > least a double ace and maybe even a triple. One time, in my Taylorcraft, I > hit the balloon low and to the right. After bursting, the big piece of > mylar wrapped itself around the wing strut and I landed with the "victim" as > a souvenir. > > As far as the falcon, I have seen flight of ducks pass over the top of the > cockpit, in the SAAB 340 without lights on, at 250KTS, at 9000 feet, AT > NIGHT. > > chris bobka > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of DJ Vegh > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: near birdstrike > > > I just had a heart stopping experience.... Went around for some local > flying today in the club 152. A friend and I were just zipping around the > valley (nice day today... partly cloudy and 68 degrees). > > Just as I'm calling Falcon Field Tower for landing my friend yells "Bird!" > Straight ahead at same altitude is a huge Falcon heading straight at us. I > had about 1 second to react... I nosed over hard and to the right just as > the bird slipped passed us right over the windshield... I swear I saw the > look in that bird eyes. > > It's a damn good thing my friend yelled cause I was looking off to my right > at Falcon Field as I was calling in for landing. > > If I hadn't have nosed over that Falcon would have hit either smack in the > center of the windshield or an engine intake. > > Those Falcons are big too.. probably 6lbs and 4 ft. wingspan. I figure we > were doing around 100kts and the bird was probably doing 20kts. > > I could only imagine if it had hit the windshield... it'd have gone right > through into the cockpit. > > I've come close to birds before, but this was a definate near miss. > > What's amazing is just about 20 minutes prior to that we almost hit a heart > shaped mylar helium balloon (Valentine's balloon no doubt). That wasn't as > scary since a balloon would most likely not do any damage.... > > Just goes to show you, you can have months of boring flying and then in one > day have a handful. > > I'm definately gonna mark down some remarks of today's flight in the > logbook... look back at it 20 yrs from now and chuckle. > > DJ Vegh > www.raptoronline.com > > > This email has been scanned for known viruses and made safe for viewing by > Half Price Hosting, a leading email and web hosting provider. For more > information on an anti-virus email solution, visit > <http://www.halfpricehosting.com/av.asp>. > > ________________________________________________________________________________
Date: Feb 16, 2003
In a message dated 2/16/2003 3:14:58 AM Central Standard Time, cgalley(at)qcbc.org writes: > think you met to say... "A Cessna will not fly withOUT the windshield. It > disturbs the airflow so much over the tail that they can't fly. Call it a > lucky day." > Actually, they will fly without a windshield but it's a bit windy and noisy. ________________________________________________________________________________
Date: Feb 16, 2003
true. I corrected it in a minute. My mind gets ahead of my fingers. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Cy Galley Subject: Re: Pietenpol-List: near birdstrike I think you met to say... "A Cessna will not fly withOUT the windshield. It disturbs the airflow so much over the tail that they can't fly. Call it a lucky day." ----- Original Message ----- From: "Christian Bobka" <bobka(at)charter.net> Subject: RE: Pietenpol-List: near birdstrike > > DJ, > > A cessna will not fly with the windshield. It disturbs the airflow so much > over the tail that they can't fly. Call it a lucky day. > > The mylar balloons are lots of fun to chase. Unless the prop actually hits > them, they will bounce off the windshield and you have to go back and do it > again. It is pretty hard to find it the second time around too. I used to > live on the north side of Dallas and with the prevailing south wind, every > afternoon had its handfull of balloons. I was a regular Frank Luke. At > least a double ace and maybe even a triple. One time, in my Taylorcraft, I > hit the balloon low and to the right. After bursting, the big piece of > mylar wrapped itself around the wing strut and I landed with the "victim" as > a souvenir. > > As far as the falcon, I have seen flight of ducks pass over the top of the > cockpit, in the SAAB 340 without lights on, at 250KTS, at 9000 feet, AT > NIGHT. > > chris bobka > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of DJ Vegh > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: near birdstrike > > > I just had a heart stopping experience.... Went around for some local > flying today in the club 152. A friend and I were just zipping around the > valley (nice day today... partly cloudy and 68 degrees). > > Just as I'm calling Falcon Field Tower for landing my friend yells "Bird!" > Straight ahead at same altitude is a huge Falcon heading straight at us. I > had about 1 second to react... I nosed over hard and to the right just as > the bird slipped passed us right over the windshield... I swear I saw the > look in that bird eyes. > > It's a damn good thing my friend yelled cause I was looking off to my right > at Falcon Field as I was calling in for landing. > > If I hadn't have nosed over that Falcon would have hit either smack in the > center of the windshield or an engine intake. > > Those Falcons are big too.. probably 6lbs and 4 ft. wingspan. I figure we > were doing around 100kts and the bird was probably doing 20kts. > > I could only imagine if it had hit the windshield... it'd have gone right > through into the cockpit. > > I've come close to birds before, but this was a definate near miss. > > What's amazing is just about 20 minutes prior to that we almost hit a heart > shaped mylar helium balloon (Valentine's balloon no doubt). That wasn't as > scary since a balloon would most likely not do any damage.... > > Just goes to show you, you can have months of boring flying and then in one > day have a handful. > > I'm definately gonna mark down some remarks of today's flight in the > logbook... look back at it 20 yrs from now and chuckle. > > DJ Vegh > www.raptoronline.com > > > This email has been scanned for known viruses and made safe for viewing by > Half Price Hosting, a leading email and web hosting provider. For more > information on an anti-virus email solution, visit > <http://www.halfpricehosting.com/av.asp>. > > ________________________________________________________________________________
Date: Feb 16, 2003
Hi Chris, I've hit a bunch of birds over the years but, so far, haven't lost a windshield yet. A couple of friends have had windshields taken out and they say it's really niosy but they mostly talked about the mess inside the airplane. I think the worst story I ever heard was the guy who hit a buzzard on the left wing root in a 172. Buzzard innards came in through the vent and covered him. He said the smell was just overpowering. One time I hit a bird going into Memphis in a 727. It hit just above the left eyebrow window. Being a young eager captain I followed all the procedures and reported a bird strike. FedEx sent a mechanic over with a stand and he checked #2 engine for damage. No problem. I started the paperwork and soon got bogged down. They wanted to know what species, sex, direction of flight and all sorts of silly stuff. They almost demanded his mother's maiden name. Hell, it was just a bird. From then on I only hit bugs - some of them had feathers though. Hit a duck one night in my Bonanza. He went through the prop and impacted the lower left side of the cowl. The damage was about $5,000. I could tell it was a green-head mallard though. Sure made a loud sound and the airplane jerked sideways so there was no doubt that I had hit something. Did a lot of flying down in South America and always wondered what a condor would do to a jet. Tom ________________________________________________________________________________
Date: Feb 16, 2003
Oops. Sorry guys. Thought I was responding to Chris off the board. Tom ________________________________________________________________________________
Date: Feb 16, 2003
> >Kip, > >Please ask him about the lead. It was there last time his ship was at >Brodhead. I took a picture of it so I know I ain't lyin'. > >The measurement was with the longerons level fore and aft? > >chris bobka Chris, The measurement was taken by dropping a line at 90 degrees from the top longeron to the axle & measuring from that. I'm not at liberty to go horsing Sky Gypsy around without Frank present. Like I said, it was COLD and DARK in that damn hangar! The main doors were snowed shut & the power was off at the panel, so all I had to go by was the light from the 'clear' fiberglass skylights. Hence my disclaimer about accuracy! Glad Mike C. cleared up the lead issue. Frank looks MUCH slimmer these days than he did in the pictures I've seen of him from several years ago, before I met him. He's not exactly a tall guy either; the top of his head just barely clears the cockpit on the Waco. Don't know how he plans on seeing out - presuming he doesn't sell it before he gets a chance to fly it! Regards, Kip Gardner North Canton, OH ________________________________________________________________________________
Date: Feb 17, 2003
Subject: Spring:
Walt: Just 32 days until spring. Leon S. In Ks. counting the days. I've become a big fan of global warming. ________________________________________________________________________________
Subject: Re: Spring:
Date: Feb 17, 2003
Leon, Right now crocus are my hero. walt evans ----- Original Message ----- From: "Leon Stefan" <lshutks(at)webtv.net> Subject: Pietenpol-List: Spring: > > Walt: Just 32 days until spring. Leon S. In Ks. counting the days. I've > become a big fan of global warming. > > > > > > > ________________________________________________________________________________
Subject: Blizzard of 03'
Date: Feb 17, 2003
Sorry to tell you folks up north. I will be putting a rebuilt cylinder on my GN-1 tomorrow. The hanger door will be open and I will be looking at green grass. Had enough sense to leave Wisconsin. jon b Hewitt, TX ________________________________________________________________________________
Subject: Using substitute wood
Date: Feb 17, 2003
There is a nice article in the March issue of CustomPlanes magazine on knowing how and where to substitute different kinds of wood in building an airplane.You don't HAVE to use expensive Sitka spruce to build a safe wood airplane. Also several other good articles in that issue. ________________________________________________________________________________
Subject: Light Plane Heritage
Date: Feb 18, 2003
Howdy, low 'n' slow fliers; I hope I'm not the only one who dropped Mary Jones (editor of EAA Experimenter) a note about Bob Whittier's column in the most recent Experimenter. Now don't get me wrong... I love Bob's column (Light Plane Heritage) and drawings, but when he says that it's a "fact" that the Piet is an ugly plane- I have to speak up! So I dropped Mary a note. I mean, thousands of homebuilders over several generations (including today's 'fast glass' and 'fast tin' generation) can't be so wrong about this pretty little ship, can they? True, there are some homely Piets out there, but I dare anybody to tell (for example) Mike Cuy that his baby is "ugly"... ;op Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Feb 18, 2003
Subject: Re: Light Plane Heritage
Right on, Oscar! Beauty is in the eye of the beholder. There is no such thing as a "fact" that any person, thing or Piet is ugly or, for that matter, beautiful. (However, it might be a "fact" that some columnists are "forgetful" of that.) What's Mary's address? Mike Hardaway Oscar Zuniga wrote: > > Howdy, low 'n' slow fliers; > > I hope I'm not the only one who dropped Mary Jones (editor of EAA > Experimenter) a note about Bob Whittier's column in the most recent > Experimenter. Now don't get me wrong... I love Bob's column (Light Plane > Heritage) and drawings, but when he says that it's a "fact" that the Piet is > an ugly plane- I have to speak up! So I dropped Mary a note. > > I mean, thousands of homebuilders over several generations (including > today's 'fast glass' and 'fast tin' generation) can't be so wrong about this > pretty little ship, can they? True, there are some homely Piets out there, > but I dare anybody to tell (for example) Mike Cuy that his baby is "ugly"... > ;op > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > ________________________________________________________________________________
Date: Feb 18, 2003
From: "Greg Cardinal" <gcardinal(at)startribune.com>
Hi Oscar, I didn't think it was an offending comment. Bob Whittier is the biggest supporter of Pietenpols I've ever met. He refers to Brodhead as "Mecca" or "Heaven". Even in his 80's, he is content to sleep on a concrete hangar floor just to be at Brodhead. Greg Cardinal >>> taildrags(at)hotmail.com 02/18/03 08:18AM >>> Howdy, low 'n' slow fliers; I hope I'm not the only one who dropped Mary Jones (editor of EAA Experimenter) a note about Bob Whittier's column in the most recent Experimenter. Now don't get me wrong... I love Bob's column (Light Plane Heritage) and drawings, but when he says that it's a "fact" that the Piet is an ugly plane- I have to speak up! So I dropped Mary a note. I mean, thousands of homebuilders over several generations (including today's 'fast glass' and 'fast tin' generation) can't be so wrong about this pretty little ship, can they? True, there are some homely Piets out there, but I dare anybody to tell (for example) Mike Cuy that his baby is "ugly"... ;op Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Feb 18, 2003
Beauty is in the eye of the beholder. ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Subject: Pietenpol-List: Light Plane Heritage > > Howdy, low 'n' slow fliers; > > I hope I'm not the only one who dropped Mary Jones (editor of EAA > Experimenter) a note about Bob Whittier's column in the most recent > Experimenter. Now don't get me wrong... I love Bob's column (Light Plane > Heritage) and drawings, but when he says that it's a "fact" that the Piet is > an ugly plane- I have to speak up! So I dropped Mary a note. > > I mean, thousands of homebuilders over several generations (including > today's 'fast glass' and 'fast tin' generation) can't be so wrong about this > pretty little ship, can they? True, there are some homely Piets out there, > but I dare anybody to tell (for example) Mike Cuy that his baby is "ugly"... > ;op > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Feb 18, 2003
Come on guy's! It isn't Mary's opinion. Why pick on her? Cy Galley Editor, EAA Safety Programs (Mary's flunky) cgalley(at)qcbc.org or experimenter(at)eaa.org ----- Original Message ----- From: "Mike" <bike.mike(at)verizon.net> Subject: Re: Pietenpol-List: Light Plane Heritage > > Right on, Oscar! > Beauty is in the eye of the beholder. > There is no such thing as a "fact" that any person, thing or Piet is ugly or, > for that matter, beautiful. > (However, it might be a "fact" that some columnists are "forgetful" of that.) > What's Mary's address? > Mike Hardaway > > > Oscar Zuniga wrote: > > > > > Howdy, low 'n' slow fliers; > > > > I hope I'm not the only one who dropped Mary Jones (editor of EAA > > Experimenter) a note about Bob Whittier's column in the most recent > > Experimenter. Now don't get me wrong... I love Bob's column (Light Plane > > Heritage) and drawings, but when he says that it's a "fact" that the Piet is > > an ugly plane- I have to speak up! So I dropped Mary a note. > > > > I mean, thousands of homebuilders over several generations (including > > today's 'fast glass' and 'fast tin' generation) can't be so wrong about this > > pretty little ship, can they? True, there are some homely Piets out there, > > but I dare anybody to tell (for example) Mike Cuy that his baby is "ugly"... > > ;op > > > > Oscar Zuniga > > San Antonio, TX > > mailto: taildrags(at)hotmail.com > > website at http://www.flysquirrel.net > > > > ________________________________________________________________________________
Subject:
Date: Feb 18, 2003
Here is a question! Answers to quietpilot(at)aol.com > ----- Original Message ----- > From: "Quietpilot" <quietpilot(at)aol.com> > Newsgroups: rec.aviation.homebuilt > Sent: Tuesday, February 18, 2003 11:34 AM > Subject: Pietenpol Mods > > > > Okay, this may be heresy, but I was wondering if anyone has ever built an > > Aircamper with a metal wing/ragwing covering? > > > > Thanks in advance.. > > > > MG > > San Diego > Cy Galley Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org ________________________________________________________________________________
Subject: On Ebay.
Date: Feb 18, 2003
Hey all, I noticed this GN1 for sale on ebay Item # 2404116435 Located in Casper WY it says. Steve e. -----Original Message----- From: Cy Galley [mailto:cgalley(at)qcbc.org] Subject: Pietenpol-List: Here is a question! Answers to quietpilot(at)aol.com > ----- Original Message ----- > From: "Quietpilot" <quietpilot(at)aol.com> > Newsgroups: rec.aviation.homebuilt > Sent: Tuesday, February 18, 2003 11:34 AM > Subject: Pietenpol Mods > > > > Okay, this may be heresy, but I was wondering if anyone has ever built an > > Aircamper with a metal wing/ragwing covering? > > > > Thanks in advance.. > > > > MG > > San Diego > Cy Galley Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org ________________________________________________________________________________
Subject: Bob Whittier's column
Date: Feb 18, 2003
Pietenpolers: hold your calls and letters to Mary Jones! Please read her reply to my email to her, and I apologized to her for causing any ruckus. I only intended to stick up for the Piet in a good way, not to bark or snap. ================================== From: "Mary Jones" <mjones(at)eaa.org> Subject: RE: Bob Whittier's column Date: Tue, 18 Feb 2003 11:10:44 -0600 Hey Oscar ... Please don't get riled about Bob's comment that the Pietenpol "is no beauty." Honestly, I don't think you could find a bigger fan of the Pietenpol airplane than Bob Whittier. In fact, I'm suspecting he may have made the statement just to be more "journalistically objective"; that's how much he loves Pietenpols. Witness that he plans his trips to AirVenture to include time to attend the Pietenpol Fly-in in Brodhead ... and, frankly, that's his favorite fly-in to go to, bar none. He goes to great effort to be able to go there. This past summer, his usual ride, Jim (who's last name I can't remember at the moment) wasn't going to go to the fly-in, but Jim helped find someone else to give Bob a ride, and we arranged for him and his new ride to meet at Oshkosh. He goes to great lengths to get that fly-in, and he'd be heartbroken if he wasn't welcome there again. So, fear not, Bob wasn't trying to disparage this wonderful airplane in any way...and if he thought that he upset Pietenpol owners, he'd be very distraught. So much so that I'll gladly take any guff anyone wants to give him. I won't mention this to him, and I'd ask Pietenpol owners to not write him. If someone has to let off steam, write me. Bob probably wouldn't want me to say this, but he's having a lot of struggles in his life now as his wife is in advancing stages of Alzheimer's Disease. Sometimes just being able to get an article done is a lot of stress for him. But, he's adamant about wanting to keep writing as long as he possibly can. This is what he lives for. I guess what I'm asking ... let's give Bob a break on this one. I wouldn't want to see his heart broken over this ... and that could easily happen. Oscar, feel free to put this on the Pietenpol list, if necessary. Thanks for your consideration. Mary ============================================= Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Feb 18, 2003
Oscar, I havent read the article, my EAA magazines (Aport Aviation and Experimenter) get here about two month late, if they get here... I AM SURE there has to be a mistake. I have been reading everything I can get about the Piet since the late 70's and I am sure Mr. Whittier is one of the biggest fans of the Pietenpol. I know my word is of no weight, you barely know me, but trust me. I felt in love with the Piet reading his wonderfull articles. Please re-read the article, maybe there is a mispelling or something. Saludos Gary Gower Piet dreaming since the 80's here where snowed 1/4" about four years ago, once in 95 years. --- Oscar Zuniga wrote: > > > Howdy, low 'n' slow fliers; > > I hope I'm not the only one who dropped Mary Jones (editor of EAA > Experimenter) a note about Bob Whittier's column in the most recent > Experimenter. Now don't get me wrong... I love Bob's column (Light > Plane > Heritage) and drawings, but when he says that it's a "fact" that the > Piet is > an ugly plane- I have to speak up! So I dropped Mary a note. > > I mean, thousands of homebuilders over several generations (including > > today's 'fast glass' and 'fast tin' generation) can't be so wrong > about this > pretty little ship, can they? True, there are some homely Piets out > there, > but I dare anybody to tell (for example) Mike Cuy that his baby is > "ugly"... > ;op > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > > > > > > > ________________________________________________________________________________
Date: Feb 18, 2003
Subject: Re: Blizzard of '03
> >Kip, > >Do you think that with all that snow, there will be flooding problems >in the spring? > >I still remember the article about the Neuport 11 (Kansas Dawn >Patrol)that was rescued from a flood... > >Saludos >Gary Gower Gary, Spring flooding can always be a potential problem in the Eastern part of the US, with the biggest problems being in the Appalachian Mountains. However, I think this recent storm won't cause trouble in our area as it should melt off pretty gradually. Here in northeastern OH, flooding tends to be confined to the creek and river valleys, since we have a low, rolling-hill topography (not unlike the Hill Country between San Antonio and Austin, TX, if you've ever been there, but wetter & with more trees). When I was young, I lived for a time near the Mississippi River, and spring floods there were a big deal. I remember standing at the top of a bluff overlooking the river and seeing the old St. Paul, MN airport under about 10 feet of water down in the river's flood plain. Any hangar queens that were down there were pretty much out of luck! At any rate, I hope no one has to deal with rescuing planes this Spring! Cheers! Kip Gardner Do Not Arcive North Canton, OH ________________________________________________________________________________
Date: Feb 18, 2003
My Two cents worth. Beauty is the eye of the beholder. Went to Brodhead to see if I really liked Pietenpols. Got in very late after a twenty hour non stop drive. (two drivers) A couple of guys were sitting around the campfire they told us to basically set up camp where you want to. The next morning I was awoken to the sound of an A Ford swinging a prop. Nicest alarm clock ever built! Met Bob Whittier and found him to very interesting, his hearing disability made it a bit difficult to converse with, but he was extremely interested in the aircraft. He genuinely does like Pietenpols and has a thing for A powered Piets. We should be thanking him for writing about Pietenpols and spreading the good word about them. Piets ugly never!......Beauty, well a MK IX Spit does that for me......But I can if I persist have a pretty little Piet. John ________________________________________________________________________________
Date: Feb 18, 2003
Subject: Piet owner Jimmy Dean featured in "Sportsman Pilot"
Pieters - Jimmy Dean, who owns NX15767, a Ford-powered Piet, lives in Sanford NC. Jack Cox, who writes and publishes "Sportsman Pilot" quarterly magazine ($12 a year to Sportsman Pilot, P.O.Box 400, Asheboro NC 27204-0400 www.sportsmanpilot.com) has a great article on Jimmy in the recent Winter 2003 issue. The article is about Jimmy's 1933 cabin Waco UIC that he purchased in 2000. It required "some work" and he regularly flies it now. He also has a Waco ASO that he is rebuilding. In the Summer 1990 issue, Jack had featured Jimmy Deans' Pietenpol, which Jimmy still has. As usual with Jack, the airplanes get their due in his writing and photos, but it usually turns out that the people get their share of ink too. And Jimmy is sure worthy of the effort. Good going, Jimmy - and Jack and Golda! Doc Mosher Oshkosh USA ________________________________________________________________________________
Subject: Re: Piet owner Jimmy Dean featured in "Sportsman Pilot"
Date: Feb 18, 2003
Now for the REALLY cool part....5 back issues contain Pietenpol Articles (or mention of Piets in some way.....) http://www.sportsmanpilot.com/back_issues.htm I'm betting there's some GOOD reading in those issues! Jim in Plano.... ----- Original Message ----- From: "Doc Mosher" <docshop(at)tds.net> Subject: Pietenpol-List: Piet owner Jimmy Dean featured in "Sportsman Pilot" > > Pieters - > > Jimmy Dean, who owns NX15767, a Ford-powered Piet, lives in Sanford > NC. Jack Cox, who writes and publishes "Sportsman Pilot" quarterly > magazine ($12 a year to Sportsman Pilot, P.O.Box 400, Asheboro NC > 27204-0400 www.sportsmanpilot.com) has a great article on Jimmy in the > recent Winter 2003 issue. > > The article is about Jimmy's 1933 cabin Waco UIC that he purchased in > 2000. It required "some work" and he regularly flies it now. He also has > a Waco ASO that he is rebuilding. In the Summer 1990 issue, Jack had > featured Jimmy Deans' Pietenpol, which Jimmy still has. > > As usual with Jack, the airplanes get their due in his writing and photos, > but it usually turns out that the people get their share of ink too. And > Jimmy is sure worthy of the effort. > > Good going, Jimmy - and Jack and Golda! > > Doc Mosher > Oshkosh USA > > ________________________________________________________________________________
Date: Feb 18, 2003
Subject: Winter Relief
Pieters, In honor of those snowed under I have posted three photos I snapped at Brodhead last summer. Use them to bring warmth to your lives. These were taken about 6:00 A.M. from the west side of the runway right after I awoke. The yellow Piet is Larry Williams and the Blue one is Dennis Hall's. I think I got the identification right. I have a few more from this year and last if anyone cares. Enjoy! -john- http://www.johnnyskyrocket.com/bh/ Follow the above link for the photos. ________________________________________________________________________________
Subject: Blizzard of '03
Date: Feb 18, 2003
Here in Va they are forcasting rain later in the week. Back int 96 we had a similar snow fall followed by rain and had sever flooding along the Potom
