Pietenpol-Archive.digest.vol-de
May 15, 2003 - June 07, 2003
> "What's the hurry? Are you afraid I won't come back?"
> - Manfred von Richthofen, 'The Red Baron,' last recorded words, in reply
to
> a request for an autograph as he was climbing into the cockpit of his
plane.
From: | "walter evans" <wbeevans(at)worldnet.att.net> |
Subject: | Re: Cable cutting |
----- Original Message -----
From: "walter evans" <wbeevans(at)worldnet.att.net>
; "Nieuport Builders Group"
Subject: Re: Pietenpol-List: Cable cutting
> I used a dremmel with a cutoff wheel. This works good but you have to
> separate the two cables with a scrap of alum so you don't cut strands on
the
> good cable. Oh yeah, wrap the piece to be cut in masking tape, this way
the
> strands don't "birdcage" on you. This worked for me on two projects.
> Tony B. suggests the cold chissel method.
> walt
> From: "Gary McNeel" <gmcneel(at)mykitplane.com>
> To: "N11_Technical Group" ; "Nieuport
> Builders Group" ; "Pietenpol Group"
> Sent: Thursday, May 15, 2003 6:55 PM
> Subject: Pietenpol-List: Cable cutting
> > I am trying to cut 1/8" cable and having trouble getting a clean, smooth
> > cut. I bought the small cable cutters from Harbor Freight, but they just
> > bend it. I could not find a good one at Home Depot or Loews. I had my
> doubts
> > about the HF one, but it was cheap.
> > What have you guys used? Dremel with a cutoff wheel? Hack saw (this kind
> of
> > works, takes a bit of dressing up afterward)? I need it to cut stainless
> up
> > the 1/8". Thanks.
> > Gary P. McNeel, Jr.
> > MyKitPlane.com
> > EAA Chapter 12, Houston
> > gmcneel(at)simdesk.com
> > http://www.mykitplane.com/Planes/buildLogReport.cfm?PlaneID=319
> to
> plane.
From: | "Wayne McIntosh" <mcintosh3017(at)insightbb.com> |
1. Wrap the cable with masking tape were you plan to cut it.
2. Lay the cable on an anvil or other hard piece of thick steel.
3. Place a sharp cold chisel against the cable where you want to cut it.
4. Hit the chisel hard with a hammer.
5. Take the mashing tape off of the perfectly cut cable.
Wayne McIntosh Lafayette IN
doubts
of
up
> the 1/8". Thanks.
> Gary P. McNeel, Jr.
> MyKitPlane.com
to
plane.
My two cents worth. When you arrive, volunteer.
Sit those hardworking boys down, give them beer
and hamburgers and thank them profusely for
putting the show on. Then go clean the latrine.
Clif, on the far side of the mountains.
If anyone's interested I went to see the Mars
waterbombers. Pics at www.mykitplane.com
in my pic file--in the one labeled Victoria Piets.
What if this thing turned up???
I use a dremel with a cut off wheel. Bought two tubes of the little
wheels and two arbors for a nominal sum. Got the dremels in pawn shops
for about $10 ea. Worth their weight in gold, especially for cable.
Harbor Freight cutters make a fair paper weight, not a good one though.
Dennis
Gary,
Have you tried a sharp chisel with the cable laying on the anvil? Some say
this works great.
Alex Sloan
doubts
of
up
> the 1/8". Thanks.
> Gary P. McNeel, Jr.
> MyKitPlane.com
to
plane.
Hi Richard
Interested in that answer my self. I figure the tall wheels for ground
clearance tail up, and then fit the biggest diameter you can. The pitch is
the tough question as everyone seems to have a different way of measuring
it. I figure the engine should pull under cruise RPM static and will likely
spin faster in cruise. I'm planning to run my modified B on a dyno to find
the rpm that it produces a happy amount of power with out over revving it.
The slower rpm and higher torque of the Fords means they should be able to
swing a large diameter. The large thrust disk should blow some air back past
that draggy airframe. Grin!
Weigh in guys, what works here?
John Mc
P.S.
Good to see you on the list again Richard.
-----Original Message-----
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Richard
deCosta
Subject: Pietenpol-List: prop limits
Hey all. What would you say is the optimal prop size
for a Ford Piet? What's too big? I have a chance to
buy one, but it looks pretty big.
http://www.RicharddeCosta.com
http://search.yahoo.com
From: | "Gary McNeel" <gmcneel(at)mykitplane.com> |
"N11_Technical Group" ,
Subject: | Cable Cutters... |
Well, I used the wood chisel (all I had) and it worked BEAUTIFULLY. I may
invest in the more expensive cutters if need be, maybe I can find them
locally.
Thanks to all of you who gave me some advice. This building an airplane is a
blast.
-Gary
I am thinking about getting a prop for my model A, too. If we reach a
concensus, maybe we could find a shop that would give a better price if we
order two or three of the same props?? I'd like to hear from everyone
flying a model A and what prop they have.
Gene
Subject: RE: Pietenpol-List: prop limits
> Hi Richard
likely
past
> John Mc
> P.S.
> From: owner-pietenpol-list-server(at)matronics.com
> deCosta
> To: pietenpol-list(at)matronics.com
Hello Gary,
> bend it. I could not find a good one at Home Depot or Loews. I had my doubts
The best tool I've ever seen is the Felco C-7, which sells for about $50.
A friend who is an A&P here in Shreveport has one and I've used it several
times for cables on the Maule. I wrote down the manufacturer and model so
I could get one if I needed to do lots of cable work. Finally I found the
following url: www.floridaplants.com/Store/pruners4.htm
A search for Felco might give other sources which sell this product. My
A&P friend reported that HF was now selling a replica of this tool for
about $45-50, but I can't verify that and would not know about its
quality.
...Edwin
~ Edwin Johnson ....... elj(at)shreve.net ~
~ http://www.shreve.net/~elj ~
~ "Once you have flown, you will walk the ~
~ earth with your eyes turned skyward, ~
~ for there you have been, there you long ~
~ to return." -- da Vinci ~
AS&S has the Felco C7 for $44
I ordered mine last week.
DJ
Sent: Friday, May 16, 2003 7:48 AM
Hello Gary,
quality.
...Edwin
This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>.
Subject: | Does anyone on the list... |
Does anyone on the list live in the Knoxville, Tn. or Richmond Va. area. I
have a 3 month contract split between these 2 city's. Just wondering if
there was anyone to visit while I'm down there.
Ken,
GN1 2992
Canada
Ken Rickards
Cole Vision Canada
80 Centurion Drive,
Markham, Ontario.
L3R 8C1
tel 905-940-8675 ext 237
krickards(at)CVCI.com
Subject: | Re: Iron Butt Brousseau |
BFD,
I usually try to arrive on the Wednesday, but that
is kind of early, most don't start arriving until Thursday night or Friday
morning.
Skip in Atlanta
. Anybody know what is the
earliest you can arrive and set up camp at Brodhead? Thanks,Bill
In a message dated 5/15/03 5:26:07 PM Central Daylight Time,
curiousspider(at)yahoo.com writes:
<< Hey all. What would you say is the optimal prop size
buy one, but it looks pretty big. >>
The optimal prop size depends on how much horsepower you are getting from
your engine. The prop that Orin Hoopman drew plans for, dated 3/3/33, was
for a 76 X 48 prop. I believe this is the size that B.H.P used on his Model
A engines. It's called a 'Paddle Blade Prop', because chord is quite a bit
wider at about half way out the blade. These are the plans I used to build
the prop for my Model A, but mine was 75" dia. Doug Bryant used a 76 X 48 on
his Piet. Stock engine, I would get about 1650 rpm during ground run - up,
and unloaded in cruise flight I would get close to 1800 rpm. These are close
to the numbers that Doug got. Ken Perkins (Kansas City) thought we were
running too much prop for the Model A, and he uses a smaller dia and pitch,
but I don't remember what it was. Therefore he would run it at a higher rpm,
and take advantage of the higher horsepower above 2000 rpm. His Model A has
a pressure oil system, and that is DEFINATELY the way to go. The ol' Model
has potential to make good reliable power, but it has to be built to take
advantage of this potential...such as pressure oil system, improved induction
system, forged pistons, and a better prop flange / hub, to mention a few.
Chuck Gantzer
In a message dated 5/16/2003 6:42:45 AM Central Standard Time,
rambog(at)erols.com writes:
> Gene
Gene, I'm not flying yet but went through every issue of the BPAN back to
1982 and wrote down every mention of prop dimensions for the Model A. The
concensus by far was a 78/42. On the basis of this I ordered that size from
Chad Wilie (sp?) and was pleased with the quality. I am turning 1650 static
and anticipate 18-1900 in the air. Don Hicks
Just curious, are any of y'all Piet folks going to the SAA Fly in at Urbana, in
June?
Dan Bailey
Paola, Ks
I went to it last year, and will probably go again this year.
Champaign/Urbana is only about 3 hrs or so by car from my house and it
is a neat town and it is inexpensive. Lot of bang for the buck.
Frasca has a neat museum there with loads of airplane stuff,
engines, collectables, motorcycles etc.Not to mention their factory
tours where they make their flight simulators.
There were about 18 tailwinds there and several Baby Ace's, Super
Aces, Junior Aces which resemble a Piet from a distance. They have steel
tube frames and the Super Ace is side by side enclosed. There were other
planes including a minimax and some biplanes which I cannot remember
what, but I think Hatz. It was a very good fly in, highly recommend it
if nearby, more like Brodhead than OshKosh.
They had several forums, William Wynne was one, but was early
saturday morning and I missed his talk, but found him later. There was
also a guy there who took digital photos of the planes and stuff and
burned them on CD's, printed the labels, stuck them on and sold them on
the spot. Which was interesting of itself.
Camping is primitive, showers available at the factory. All for a
donation.
Dennis Engelkenjohn
Subject: | Re: cabane struts |
Before I put saw to streamline tubing I just want to confirm the proper
length for the cabane struts. I thought that the conventional wisdom is to
lengthen them 2" from the drawings, but someone recently mentioned
lengthening them 3" or 4". I have also heard someone mention that there is
a maximum that should not be exceeded. What are the proper numbers??
Gene
From: | "Richard Navratril" <horzpool(at)goldengate.net> |
Gene
I went 2" over, glad I did. Another inch would have been helpful, but in
Sport Aviation a couple of months ago there was a Piet that was built 4"
over. I don't know, I think that started stretching the porportional eye
appeal. Thats only my opinion.
Dick
Subject: Re: Pietenpol-List: cabane struts
to
is
> Gene
In a message dated 5/17/03 10:19:50 PM Central Daylight Time,
<< What are the proper numbers?? >>
Gene,
I am 6' tall, and lengthened mine 2". From the left side I have to lift my
right foot to the seat, with both hands on the cabane struts,bring the left
foot up over, and streatch way out over the right side to get my foot up over
the longeron, while dragging my back on the bottom of the wing. It has
become very easy for me to get in and out, taking only a few seconds.
Chuck Gantzer
From: | "Jack Phillips" <pietflyr(at)bellsouth.net> |
Gene,
I made mine 2-1/2" longer than plans and to me, they seem about right.
There is sufficient room under the wing to allow reasonable access to both
cockpits (I'm 6'2" tall). I have added steps to both cockpits and a
circular cutout in the trailing edge. Front cockpit is still a little
difficult to get in and out of. But as for the "correct" length, there is
no such animal, IMHO. I'll bet if you went to OSH and measured the struts
of the two BHP-built Piets there, you would find they had different lengths.
Jack
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene Rambo
Gene
Gene,
I think that I read in one of the old BPA newsletters that Mr. Pietenpol
raised his wing 4" on one of the last Corvair powered planes that he built.
He later commented that this was too much.
I raised mine only 1", and since the thrust line of the prop has been raised
about 4 inches due to the reduction unit, the overall effect was very little
trim change with varied throttle settings.
Except for some arthritis, (getting old, you know) getting in and out is no
problem.
to
is
> Gene
Thanks everyone that have responded, I'm still interested to hear from more
of you. I am 6'1", so I want all the room I can get without messing up the
appearance. I still think I remember some mention of an upper limit for
some structural or aerodynamic reason.
I happen to have two pieces of streamline tubing the right size, and they
are 48" long. If I cut them so that one is 1" longer than the other, they
will turn out to be 24 1/2" and 23 1/2" long. Giving the proper edge
distance from the bolt holes that would make them 24 1/8" and 23 1/8"
between bolt holes (which I'll probably make an even 24 and 23) Soooooo
they'll be 2 1/2" longer than the plans. Enough to help without hurting the
appearance??
Gene
I just got home from four days of volunteer work at the Southwest Regional
Flyin, Tired. It is the extra work of the "extra" people that is the issue.
I still think that we all should go. However, Why not try to give a hand
while there. Three or four hours collecting garbage would be a very worthy
thing to do. It is low on the totem pole and is something that all will
benefit from. I know as most of my timeat SWRFI was spent doing that. Last
year was my first time at Brodhead and they are a very good group. When the
number of visitors is overwhelming the attitude can slip to why bother.
Lets all go and all help. It will be an excellent event!!
Jon Botsford
GN-1 N4057T
Subject: Re: Pietenpol-List: Brodhead
Don,
You still dont get the message, even for me (english second language)
was clear...
What he wants to say is something very "normal" for some pilots:
"Hey, lets go ALL OF US to Brodhead, is a cool place to stay , just a
few days before Airventure, they have a little Piet Fly Inn and also
some camping area and services... Doesnt matter that we are 200 planes
with two people in each one, is THEIR problem... Joe Doe (a Piet
builder) invited us....
This is exactly what he said NOT: "No Piet airplanes allowded"
JEESS is clear as water for me.
Saludos
Gary Gower
Piet lover, 701 builder, No Not going this year :-)
--- ADonJr(at)aol.com wrote:
> Gene, and others,
> As part of the "sizeable N. California contingent" which came
> in and
> "took over" the Pietenpol Fly-in, I'd like to state that I came
> because I am
> a Piet enthusiast, a potential builder and thought that we were
> welcome. The
> tone of the comments I'm reading now, from other Piet enthusiasts
> makes me
> question the attitude of those folks. I have always been attracted
> to the
> Piet, and to the type of people who have been similarly drawn to it.
> I have
> attended Brodhead Fly-ins on three occasions, and been made to feel
> welcome.
> I hope that this group is not going to adopt the attitude that
> "outsiders"
> are not welcome. That would be more than sad.
> Don Cooley
> Ercoupe N3571H
In a message dated 5/18/2003 9:27:44 AM Central Standard Time,
Gene, you may be thinking about the comment by Pete Bowers in his articles
for the BPAN in which he flew four or five different Piets. His opinion was
that if you lengthened the cabanes and were using a center section fuel tank
(assuming it was full) you would raise the vertical center of gravity and
tend to aggravate any tendency to ground loop. That may have some validity at
4 or more inches but doubt that 2 or less would make that much difference.
Don
From: | Richard deCosta <curiousspider(at)yahoo.com> |
Here's the goods on the prop (I bought it anyway, even
if it wont work on my plane, it's absolutely
gorgeous!):
On one side it has printed:
42
A 82 46 CC 249
Experimental
Felix Propellers, Inc.
It's all-natural wood finish, beautiful grain, blank
painted tips.
If this wont work on my Piet, I'll sell it off again.
Anyone?
Richard
Subject: | Re: Honest? I say nada.....: Elbow room |
Jim,
Now thats the kind of comments I like. Whether you would do the same is not
in consideration. I like the idea of arm rest and I will have room for them.
I can see a left arm rest angled so the arm is comfortable on the throttle. A
very important point to me. thanks for the idea. I have felt that 41CC is a
bit confined. A possibility that Mr. Piet wanted to get two cuts from one 4X8
piece of plywood. Maybe not, but I got my 1/4 inch fir marine grade from
Wickes for about $45. That's the cheap end of building an aeroplane.
Thanks again for your comments
Corky in YKW
Hey All
Now that the warmer weather is coming to Mn. I can work with the hangar door open.
I get a constant stream of visitors stopping by to chew the fat. It's another
side benefit of having a Piet.
Anyway, today a A&P stopped by and made a couple of comments I thought worth passing
on. He commented first on my placement of the gascolator on the firewall.
He suggested that I move it so that at rest it was lower that the carb bowl
at rest, to be the lowest point in the system. Also, he suggested to do a fuel
flow test to verify that at rest, the fuel line provides a flow of 10 gal/hr.
with minimum usable fuel remaining in the tank to simulate adequate flow for
a go around. Also an extended test of the flow to verify adequate venting
of the tank.
Just a couple of points I don't recall having seen on the list.
Dick
Dick
It is a good idea to do your flow test at max climb angle. If you ever
ended up making a go around after a missed approach with low tanks it might
be the factor that saves your #####.
Navratril
Subject: Pietenpol-List: fuel system
Hey All
open. I get a constant stream of visitors stopping by to chew the fat.
It's another side benefit of having a Piet.
passing on. He commented first on my placement of the gascolator on the
firewall. He suggested that I move it so that at rest it was lower that the
carb bowl at rest, to be the lowest point in the system. Also, he suggested
to do a fuel flow test to verify that at rest, the fuel line provides a flow
of 10 gal/hr. with minimum usable fuel remaining in the tank to simulate
adequate flow for a go around. Also an extended test of the flow to verify
adequate venting of the tank.
Dick
Good points, Dick.
Another point to mention when choosing a spot to mount the gascolator on the
firewall - while it needs to be lower than the carb float chamber so it is
the fuel system's lowest point, it also should NOT be the lowest point on
the firewall. There should be structure lower than the gascolator so that
if a really bad landing wipes the gear off, the gascolator is not the point
that the sliding fuselage is resting upon. Otherwise, it will be destroyed
in a hurry and all that fuel will be deposited right where the friction has
gotten things really hot. Not good, but spectacular.
Jack
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Richard
Navratril
Hey All
Dick
From: | Jim Markle <jim_markle(at)mindspring.com> |
Subject: | Plywood spar web |
Well, I can hear a tiny bit of hesitation in my Tech Counselor's voice when we
talk about my decision to use marine grade 1/2" ply built up into an I beam for
the spar on my Air Camper.
Sure would be nice to show him the calculations the Brits are using or anything
else that (clearly) shows the numbers. I can review the shear/moment/etc numbers
on ply versus spruce/doug fir but if anyone knows of a good paper that's
been done, that would sure help me present my case.
Doc Mosher? Alan James?
Jim in Plano
From: | Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov> |
Thanks for the good words about the video tape, Oscar. (cute dog, by the
way) Info on the video and
ordering info is available at this web
site: http://users.aol.com/bpabpabpa/cuyvideo.html
Fred-- if you have a VCR in Australia that can play a non-PAL format my
tape will work fine for you. Otherwise
you'll have to take the tape to a place and have it dubbed from the US into
the PAL format so it will play
correctly on your VCR. Simon McCormack (Tasmania, Australia) and I found
this out while exchanging video
tapes over that past several years)
Mike C.
05/20/2003 02:01:49 PM
Fred: The US format is NTSC if you do not allready know that.... And Mike's
tape is well worth having converted....
Michael D Cuy (at)matronics.com on 05/20/2003
01:45:13 PM
Please respond to pietenpol-list(at)matronics.com
Sent by: owner-pietenpol-list-server(at)matronics.com
cc:
Subject: Pietenpol-List: video info
Mike C.
Subject: | Re: Plywood spar web |
You could try reading the NACA paper entitled "The Strength of One-Piece Solid
Built Up and Laminated Wood Airplane Wing Beams" it's from 1920. It tests a bunch
of different types of construction for built up wing spars. You can find
it at.
http://naca.larc.nasa.gov/reports/1920/naca-report-35/
Chris
Sacramento, CA
Jim in Plano
The best thing to hit the internet in years - Juno SpeedBand!
Surf the web up to FIVE TIMES FASTER!
From: | "Jim Markle" <jim_markle(at)mindspring.com> |
Subject: | Thanks for the spar info!!! |
I'm continually amazed at what incredible resources we have in this group!
Having a good local EAA chapter is important. But having this group really
makes the process amazing! (In fact, the spar article from Sport Aviation
and the NACA Report
No. 344 were mailed to me yesterday......)
Thanks for everyone's help/feedback. The numbers are in and I'm quite
satisfied that an I beam spar design will work just fine. A 1/4"(quite
adequate) or 3/8"(probably more than adequate) plywood web is what I'll use.
So full height ply with 1" tall strips of Doug Fir, each side of the top and
bottom, to build out the "I" design.
I found that a number of British Piets are flying with an I beam spar design
that incorporates aircraft quality plywood webs in the 1/8" thickness range.
So actually doing the calculations can result in a good safe structure
(estimated 1200# MUAW) with a lot less than my "overbuilding" tendencies
would dictate!
Thanks again.
Jim in Plano, TX having just completed my second Tech Counselor inspection
and it looks like I'm on the right track! :-)
My build log: http://www.mykitplane.com/Planes/buildLogReport.cfm?PlaneID=52
"Fishnet"
Subject: | anyone use one of those boat "clinometers" for a turn |
and bank?
If so, do they work?
thanks
walt
20hrs 10min down///4hrs 50 min to go
From: | "Alan James" <MADjames(at)theknapp.freeserve.co.uk> |
Subject: | Looking for Warren |
Is Warren D Shoun looking in?
If so can you send me an e-mail so I can return some information. The
address I have keeps bouncing back.
Alan James
The UK Pietenpol Club
Subject: | Re: Looking for Warren |
Dear Mr Deacon
I am grateful to you for responding to my call and I am saddened by the news
of Mr Shoun's passing.
I hope that my message has not upset anyone and would like to pass on my
belated condolences to any friends or family that may be reading this.
Sincerely
Alan James
Subject: Re: Pietenpol-List: Looking for Warren
> http://www.maddyhome.com/corvairsrch/message?sn=0&hit=5
> Mr. James
> I have the unhappy task of delivering some bad news.
> It was reported on the Corvaircraft mail list that Mr.
> Shoun had passed away last June. The above link will
> take you to the Corvaircraft mail archive where you
> can read the entire string.
> I would suggest contacting Pat Panzera or Robert
> Sutcliffe for more information.
> Sincerely
> Mark Deacon
> --- Alan James
> > information. The
> > Thanks
> > Alan James
Subject: | Re: anyone use one of those boat "clinometers" for a turn |
and bank?
Walt,
I believe that is what is on the one I am flying. If you mean the one that
has a little white ball in it. Works just fine.
I was thinking of hanging a little pendulum on the one I am building. Ted
Subject: Pietenpol-List: anyone use one of those boat "clinometers" for a
turn and bank?
> thanks
> walt
Subject: | Piet builder at Crystal Airport |
At one time there was a Piet builder that had a plane at Crystal airport in MN.
I had exchanged emails with him but can't remember who it is. I'd like to set
up a visit if possible.
Tom Brant
Brooklyn Park, MN
In a message dated 5/23/2003 5:20:01 PM Central Daylight Time, PNRBocchi
writes:
> ct: FW: Noah's Ark
After reading this silly little thing from a friend I thought about it and
realized how much it applied to Piet building. CMC
> >>This is really beautiful.
> >>Noah's Ark Everything I need to know, I learned from
> >Noah's Ark...
> >>ONE: Don't miss the boat.
> >>TWO: Remember that we are all in the same boat.
> >>THREE: Plan ahead. It wasn't raining when Noah built
> >the Ark.
> >>FOUR: Stay fit. When you're 60 years old, someone may
> >ask you to do
> >>something really big.
> >>FIVE: Don't listen to critics; just get on with the
> >job that needs to be
> >>done.
> >>SIX: Build your future on high ground.
> >>SEVEN: For safety's sake, travel in pairs.
> >>EIGHT: Speed isn't always an advantage. The snails
> >were on board with
> >>the cheetahs.
> >>NINE: When you're stressed, float awhile.
> >>TEN: Remember, the Ark was built by amateurs; the
> >Titanic by
> >>professionals.
> >>ELEVEN: No matter the storm, when you are with God,
> >there's always a
> >>rainbow waiting.
> >>My instructions were to send this to people that I
> >wanted God to bless
> >>and I picked you.
> >>Please pass this to people you want to be blessed.
Date: Fri, 23 May 2003 18:20:01 EDT
Subject: Fwd: Noah's Ark
ggacres(at)juno.com, ksr51(at)attbi.com, KKirsh(at)aol.com, toogees(at)netzero.net,
KDown20368(at)aol.com, mjkgarrison(at)aol.com, pacer(at)west-connect.com,
rob(at)woohaw.com, bldbomer(at)aol.com, icphish(at)yahoo.com,
5luvnlife(at)email.com
Date: Fri, 23 May 2003 06:24:33 +0000
When I saw this I knew I had to 'pass it on'. It is very true.
Chuck & Sharon
>From: Chuck Garrison <garry4197478(at)yahoo.com>
>To: our_ark(at)msn.com
>Subject: Noah's Ark
>Date: Thu, 22 May 2003 23:14:43 -0700 (PDT)
> >Subject: FW: Noah's Ark
>Noah's Ark...
>the Ark.
>ask you to do
> >done.
>were on board with
> >the cheetahs.
>Titanic by
> >professionals.
>there's always a
> >rainbow waiting.
>wanted God to bless
> >and I picked you.
Subject: | Re: Piet builder at Crystal Airport |
Hi Tom
thats me. I'm out there quite a bit. anytime works for me, but out of
town this weekend.
Dick Navratil 651-638-0793
cell 612-805-1742
Subject: Pietenpol-List: Piet builder at Crystal Airport
in MN. I had exchanged emails with him but can't remember who it is. I'd
like to set up a visit if possible.
> Thanks,
> Tom Brant
> Brooklyn Park, MN
"Sirius-Aviation Group" ,
"RV7and7A Group" ,
"Parasol Airplanes Yahoo Group" ,
"Group CorvAIRCRAFT" ,
"Flying Circus Yahoo Group" ,
"EAAHouston" ,
"CorvAircraft Mailing List" ,
"Boredomfighter Group" ,
"AirVW Yahoo Group" ,
"Airsoob Group" ,
"Nieuport Builders Group" ,
"Pietenpol Group"
Subject: | PETE BOWERS, FLY BABY DESIGNER, PASSES AWAY |
I was contacted and asked to pass this along. Anyone with plans on order may
see a delay in getting them.
http://www.eaa.org/communications/eaanews/030429_petebowers.html
Gary McNeel, Jr.
www.mykitplane.com
Subject: | am I back on line? |
Changed servers and went through the hassle of lineing up the new protocol.
Am I back on?
Another rainy day with out flying.
walt
NX140DL
From: | "Ken & Lisa Rickards" <KL0914(at)cogeco.ca> |
Subject: | Re: am I back on line? |
Yes Walt, Reading 5 -5 here in sunny Canada!
Ken
Gn1 2992
Subject: Pietenpol-List: am I back on line?
protocol.
> Am I back on?
> walt
> NX140DL
Subject: | Re: Tiger Moth / Pietenpol at Sun n Fun |
Hey Barry. How're those Piets coming along?
I've got my wings on now. Trying to make headway. Larry's got a Flyin'
Flea in the oven.
I'll take some pics and send em to you
Best, Bert
http://bconoly.tripod.com/
"piet discussion"
Just got some pics from a friend of mine and had to post them to the newsgroup.
alt.binaries.pictures.aviation
Check it out.
walt evans
I am about to drill the long fuselage for the cabane fittings and I am not
sure about the note "3/4 x 3" Filler for strut fitting" on the plans. Where does
this thing go exactly? And what is it?
Does it reinforce the cross strut that has to be cut to fit the front
fittings? I read some discussion on this on the British site but still don't
understand .
Please someone out there help before I do something stupid. Thanks.
George
Sugar Land, Texas
Walt
that address doesn't get the uninformed very far, if
you go to the picture yourself, high light the address
at the top of the screen. press "control c" then go to
your outgoing email and put the cursor on the body of
the letter and press"control v". this will put a link
into your email that other people can click on and go
direct to your pic.
on another note, I got my sonex/vair into the sky! so
its flying this summer and then back to the pietenpol
this winter, gotta get it done!
Del
> Check it out.
> walt evans
> Contributions
> any other
> Forums.
> latest messages.
> List members.
> http://www.matronics.com/subscription
> http://www.matronics.com/FAQ/Pietenpol-List.htm
Digests:http://www.matronics.com/digest/pietenpol-list
> http://www.matronics.com/photoshare
Del-New Richmond, Wi
"farmerdel(at)rocketmail.com"
From: | "rod wooller" <rodwooller(at)hotmail.com> |
Subject: | Re: Strut fittings |
George,
The 3/4" x 3" filler glues to the rear of the fuselage
uprights (actually the back of the front seat support). Not sure why BHP
didn't just move the seat back 3/4", but there must have been a reason for
it.
Rod Wooller
Chidlow
Australia
>From: Gdascomb(at)aol.com
>Reply-To: pietenpol-list(at)matronics.com
>Subject: Pietenpol-List: Strut fittings
>Date: Mon, 26 May 2003 20:34:38 EDT
>does
>don't
>understand .
>George
>Sugar Land, Texas
ninemsn Extra Storage is now available. 30MB of storage on ninemsn Groups -
great for sharing photos and documents. Go to
George,
As far as I understand the 3/4" x 3" is bit of reinforcement only. The
struts mount on the fuse uprights. Check out
http://www.pjshenton.go-plus.net/default.htm. Go to Builders Notes -
Fuselage. Half way down is an article on the fittings. Check out the
dimensions of the fittings on the center section and the fuse. Seems that
both ways work!
Hope that helps.
Peter.
Wonthaggi, Vic
Australia
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of rod wooller
Subject: Re: Pietenpol-List: Strut fittings
George,
it.
Rod Wooller
Chidlow
Australia
>not sure about the note "3/4 x 3" Filler for strut fitting" on the
>plans. Where does this thing go exactly? And what is it?
>don't
>understand .
>George
>Sugar Land, Texas
advertising on the Matronics Forums.
Share: Share photos & files with other List members.
For any interested parties, I have just updated my web site. Added a few
more elevator construction and engine pics. Progress has been a bit slow
the past few weeks. Work around the house has kept me busy!
http://home.cogeco.ca/%7Epietbuilder/index.htm
Ken
GN1 2992
Canada
Subject: | Rudder Bar and Pedal |
I have a few questions after this long weekend.
#1: What size bolts should I use to hold the rudder bar support bracket to the
1/4" floor? I was thinking AN-4 (1/4")or should I step up to an AN-5 (5/16").
#2: I was trying to smash the ends of the rudder bar tubing like the plans show.
I heated up the tubing and squished them in my vice using two metal plates
with a curve bent into them so I can transition from flat to round. Here is
my problem, I can't seem to make the flat section perfectly flat. If I look at
it on end its more of a figure 8. The center of the flat section is pinched
in more then the edges. Is this how it is supposed to be or am I doing something
wrong here? Am I squishing them to much?
#3: What is the best way to hold or jig the 1/2" tubing for the front rudder pedals
so I can weld them. If I attach them to a board does the smoke and flame
contaminate the weld?
#4: What size bolt should I use to hold the front rudder pedal fittings to the
floor? There are two of them on such a small fitting so I am thinking two AN-3
bolts will be fine.
Chris
Sacramento, CA
From: | "Oscar Zuniga" <taildrags(at)hotmail.com> |
Peter (from Down Under) wrote-
>Check out http://www.pjshenton.go-plus.net/default.htm.
Yes, the 3/4" x 3" reinforcement is addressed there... and so much more.
For example, I know I've seen several Piets with nice steps, but here's a
great photo that says it all:
http://www.pjshenton.go-plus.net/pictures/Dscf0020.jpg
Oscar Zuniga
San Antonio, TX
mailto: taildrags(at)hotmail.com
website at http://www.flysquirrel.net
From: | "rambog(at)erols.com" <rambog(at)erols.com> |
Original Message:
Date: Tue, 27 May 2003 15:18:40 GMT
Subject: Pietenpol-List: Rudder Bar and Pedal
1. 1/4" bolt is fine for the support.
2. I've never used curved pieces, it isn't necessary. Just heat up and
flatten with the vise. Reheat as necessary and flatten some more. The
edges are slightly bulged where the metal is rounded down onto itself, I
don't think I would try to get them perfectly flat, you're just asking to
crack it.
3. Smoke from a wood jig does not contaminate. I have built rudder pedals
that way before. For my Piet, though, I now have a magnetic square for
holding just such things perfectly aligned. Most tool catalogs have them.
4. I would think one 3/16 bolt on each side is enough. I am still trying
to figure out how I am going to attach mine.
Just another opinion,
Gene
Subject: | Re: drilling holes in fuselage |
OK guys, I am trying to drill all of the holes in the fuselage and have some
questions.
1. Because I got all of my fuselage fittings from Replicraft, they are all
pre-drilled. Has anyone made a drilling jig to ensure that the drill goes
through and comes out the other side exactly centered in the hole on the
other side? I am mostly talking about the cabane strut, upper engine mount,
and tailwheel fittings. If anyone has such a jig, I'd like to borrow it.
2. I know there has been discussion on here about this, but I don't recall
if we reached a solution. Is there any reason to put bolts through the
leading edge of the horizontal stabilizer? I would think the ones through
the trailing edge/main spar and the center spar (both of which also hold
down the vertical fin) should be enough.
3. What kind of spacers have you guys been putting under the stab/fin? The
fin should be spaced so that it's spar is lined up with the tailpost so that
the rudder is not in a bind. If I place the stab on the fuselage, it sits
slightly nose down because the center spar is thinner than the rear spar.
Do most of you put spacers under the stab so that it is sitting level (and
therefore the fin is square with the tailpost), or does the stab stay nose
down and the spacers go under the fin?
4. What are most of you (particularly those with Model As) doing with the
firewall? Many of the Piets at Brodhead only cover the bottom square with
steel and leave the "shelf" behind the engine uncovered. The F&G plans
clearly show the sides and bottom of the "shelf" should be covered, although
it says to use aluminum. The later plans omit this entirely. It looks to
me like to cover the bottom only defeats the whole purpose of a firewall,
and would not keep fire out of the cockpit (not that I expect this is a high
risk) Concensus?
5. In response to my last question, which did not get very many responses,
I guess the most widely used prop for a Model A is a 76 x 44, but what about
blade profiles or specific manufacturers that any of you have had good/bad
experiences with? Surely there is one someone out there who, if called on
to build a prop for a Model A Piet will know exactly what I need.
I am sure there are more questions, but I'll save a few until after we solve
these. The list has been way too quiet lately.
Gene
Subject: | Clipped wing Piet |
I'm considering starting building a Piet some time in the next few years,
and there's one modification I want to make. My hangar door opening is 28
feet wide, so I'd like to make the wing 27'6".
My extensive experience with model airplane aerodynamics leads me to
believe it won't be a problem, but will the inspector and/or insurance
company disagree?
Stefan Vorkoetter
Subject: | Re: Clipped wing Piet |
hmmmmm the Piet already has a pretty low aspect ratio...
Sent: Wednesday, May 28, 2003 12:02 PM
Subject: Pietenpol-List: Clipped wing Piet
company disagree?
Stefan Vorkoetter
You could build two low-riding caster-footed little plywood platforms that
the plane rolls up on outside the hangar and from there push the plane in
the hangar at a slight angle to clear the doors.
Subject: | prop size final consensus? |
Hey all. Was there ever a final consensus on whether a
82" prop would work with the Model-A?
Richard
Stefan,
Several things will change from the many years' accumulated Piet experience.
Your wing will probably be ever so slightly better able to cope with high
G's because the spanwise center of lift will move a little toward the
airplane centerline.
By taking away 7.5 of your 145 square feet of wing area your stall speeds
will increase slightly, (about 2%). You may see slightly higher takeoff and
landing speeds.
Your induced drag, stronger at lower speeds, will increase slightly. (On a
Piet, parasitic drag is hugely dominant throughout most of the envelope so I
doubt if you'll notice.)
Your real experience will be in the unknowns of changed handling qualities.
You may have increased roll response (unless you clip each aileron by .75
feet, too), decreased roll stability, possibly increased yaw stability and a
number of others.
I don't know how many others have built clipped wing Piets but you're sure
to hear if anyone has had a bad experience.
Have you thought about widening your hangar door?
Mike Hardaway
> company disagree?
> Thanks
> Stefan Vorkoetter
I guess I didn't consider about 6:1 low, but perhaps it is for a full-scale
aircraft.
The other think I had thought of was to install rails and a dolly so I can
slide the plane into the hangar sideways.
Stefan
Gene. I bought a drill guide thing at Oshkosh several years ago that
works just fine for drilling holes straight. I've seen them at Ace
hardware, Harbor Tool, and other places since. It consists of a base
with 2 vertical rods that lean either direction for angle holes. On the
rods set a cross piece with a chuck for your drill bit, then you chuck
your drill to this chuck and go to town. The base also has ears to hold
tubing in perfect alignment for drilling holes threw tubing. It costed
about 25 bucks. I put glued
plywood on the fus., under the stab. until the stab. cord was level with
the fuselage longerons.
I plan to put screws threw the stab. leading edge as shown on the plans.
Again, I built up under the le. with ply so it is resting on something
when bolted down. I guess I will leave
the shelf bare like most people are doing. Running fabric up to the
firewall with no boot cowl also defeats fire prevention logic.
I haven't got to my prop yet, so I can't give an opinion there. I did
buy an adaptor from Dick Weeden at Brodhead so I can use props with the
Cont. bolt pattern. Does anyone know anything about the Model A guy and
his Model A conversion in DeLand Fl, mentioned in the new Sport Av.,
p.68? Leon S.
Subject: | Newcomer Question |
I often see references to a GN-1, and I think I saw reference to a GN-2 as
well. Is that a particular model of Aircamper, or someone's redesign?
Stefan
Subject: | Re: Drilling holes |
Gene-- I just drilled a little bit from each side of those fittings and
continued til the two holes met.
What about using/making something like in this picture. (I hope it is attached)
Chris
Sacramento, CA
questions.
risk) Concensus?
Gene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: | Piet builders in Montana? |
I am hoping to build an GN-1 or Pietenpol in the next
year after I complete my house. Does anyone know of a
builder in the Bozeman area (southwestern Montana)? I
would love to go talk to a builder about construction
and flying of a Piet or GN-1.
Looking forward to utilizing the experience and
expertise offered by this list.
thanks
Subject: | Re: Drilling holes |
yea, yea, I've heard that one (drill from each side) but I am leery of
screwing up a hole in my longeron. I used to have a jig built of a piece of
square tubing with two stand-offs welded to it, one was adjustable. I never
was really happy with it.
----- Original Message -----
From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov>
Subject: Re: Pietenpol-List: Drilling holes
> Gene-- I just drilled a little bit from each side of those fittings and
> continued til the two holes met.
Subject: | Re: Clipped wing Piet |
If the hangar is wide enough inside, the smaller opening is no barrier.
Just need room to manage the tail and rotate it in.
Cy Galley
Editor, EAA Safety Programs
cgalley(at)qcbc.org or experimenter(at)eaa.org
Subject: Re: Pietenpol-List: Clipped wing Piet
> hmmmmm the Piet already has a pretty low aspect ratio...
> From: Stefan Vorkoetter
> To: pietenpol-list(at)matronics.com
> Sent: Wednesday, May 28, 2003 12:02 PM
> Subject: Pietenpol-List: Clipped wing Piet
> I'm considering starting building a Piet some time in the next few
years,
> and there's one modification I want to make. My hangar door opening is
28
> feet wide, so I'd like to make the wing 27'6".
> My extensive experience with model airplane aerodynamics leads me to
> believe it won't be a problem, but will the inspector and/or insurance
> company disagree?
> Thanks
> Stefan Vorkoetter
> > This email has been scanned for known viruses and made safe for viewing by
Half Price Hosting, a leading email and web hosting provider. For more
information on an anti-virus email solution, visit
<http://www.halfpricehosting.com/av.asp>.
From: | "Dick and Marge Gillespie" <dickmarg(at)peganet.com> |
Cube up some 1 1/2 in. pcs of 2x4 and drill the size holes that you will be
using in them. After you drill a starter hole deep enough (maybe 1/16 in.to
1/8 in.) to aid in finding the hole with your drill bit thru the cube, you
should not have a problem drilling a good hole. Use a drill press to drill
the cubes to make sure the holes are perpendicular to the surface you wish
to drill. These little dudes will get you into some tight drilling spots.
DickG.
of
never
> To:
From: | "Hubbard, Eugene" <ehubbard(at)titan.com> |
Weld up a jig that looks like a C-clamp, but with steel tubes to guide the
drill where the screw would go. Some people have even used a C-clamp to
start with. Weld on the tubing in one piece, then cut out the section
inside the "C" so you have two perfectly aligned segments. Clamp your
fittings on both sides of the structure, stick a bolt, drill bit, or
anything else through the sleeve on one side, into the hole in the fitting,
then drill from the other side. When you get through, your drill will push
out the pin and you'll have two perfectly aligned holes. I've made several
of these in various sizes and for both AN3 and AN4 bolts. I even made up
one with bent arms to get to the cabane struts.
Gene
-----Original Message-----
About 20 years ago Ed Lubick of Ontario built a Piet with a span of 26 feet.
Used it as a test bed for powerplant alternatives. Claimed it flew "just a
little bit faster."
Jim Malley
> I'm considering starting building a Piet some time in the next few years,
> and there's one modification I want to make. My hangar door opening is 28
> company disagree?
> Thanks
> Stefan Vorkoetter
I am afraid of any tool whose only purpose is to keep the drill straight on
one side. Most of the holes that I am talking about are on a curved
surface (the fuselage side) and so there is no way to drill square through
and hit the other side. Maybe I am making too much of it, I just thought
someone, surely, has built a drill jig.
Gene
From: "Dick and Marge Gillespie" <dickmarg(at)peganet.com>
be
in.to
drill
> DickG.
> From: "Gene Rambo" <rambog(at)erols.com>
> To:
piece
> of
> never
> > To:
and
Had it at Oshkosh several times. Came down to grease the AMC auto spindle he
used in the reduction unit. If I remember right it was a Ford straight 6.
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Always looking for articles for the Experimenter
feet.
> little bit faster."
> Jim Malley
> From: "Stefan Vorkoetter" <stefan(at)capable.ca>
> To:
years,
28
> > company disagree?
> > Thanks
> > Stefan Vorkoetter
Subject: | Re: prop size final consensus? |
In a message dated 5/28/03 2:49:29 PM Central Daylight Time,
curiousspider(at)yahoo.com writes:
<< Hey all. Was there ever a final consensus on whether a
82" prop would work with the Model-A? >>
I doubt you would have enough prop tip clearance, especially if you had a
flat tire.
Chuck Gantzer
From: | "Lauritz Larsen" <pietlars(at)earthlink.net> |
Hi,
Concerning your inquiry about an A powered plane in Deland; haven't seen
the article but it probably is Bud Roger's A powered SE-5. He has had it
at S-F. He has had a booth there also DBA 'Thrust, Inc." sellin a 350
Chevy conversion.
I know Bud from way back, fabricated the ailerons for him for a Travelaire
2000. He has restored seveal planes including an OX Curtiss Robin and
scratch built several others. He is an AI .
The SE-5 has an 'A' with a starter and electronic ignition; it should be
complete by now. If you want to contact him, I can look up one of his
cards.
Hope this helps.
Lou Larsen
In Tavares FL; just finished the last coat of silver, waiting on the color
paint.
PS Its an A powered Piet with straight axle and 21" .
Subject: Pietenpol-List: Drilling holes
> Gene. I bought a drill guide thing at Oshkosh several years ago that
> works just fine for drilling holes straight. I've seen them at Ace
> hardware, Harbor Tool, and other places since. It consists of a base
> with 2 vertical rods that lean either direction for angle holes. On the
> rods set a cross piece with a chuck for your drill bit, then you chuck
> your drill to this chuck and go to town. The base also has ears to hold
> tubing in perfect alignment for drilling holes threw tubing. It costed
> about 25 bucks. I put glued
> plywood on the fus., under the stab. until the stab. cord was level with
> the fuselage longerons.
> I plan to put screws threw the stab. leading edge as shown on the plans.
> Again, I built up under the le. with ply so it is resting on something
> when bolted down. I guess I will leave
> the shelf bare like most people are doing. Running fabric up to the
> firewall with no boot cowl also defeats fire prevention logic.
> I haven't got to my prop yet, so I can't give an opinion there. I did
> buy an adaptor from Dick Weeden at Brodhead so I can use props with the
> Cont. bolt pattern. Does anyone know anything about the Model A guy and
> his Model A conversion in DeLand Fl, mentioned in the new Sport Av.,
> p.68? Leon S.
Gene,, For what it's worth, I used a piece of steel stock 3"x3" 3/4 thick.
I used the drill press to put in a few holes. ( 8th, 3/16, 1/4).
I would slide the piece on the bit close to the top, start my hole so the
bit wouldn't move, and then slide the piece down on the surface giving me a
90 degree straight thru. Works great just measure five and drill once.
Carl
on
> Gene
> To:
> be
> in.to
you
> drill
wish
spots.
> > DickG.
> > To:
> piece
> > of
> > never
> > > To:
> and
Gene,
I built one of these and it works great. You can go to
http://www.eaa1067.org/images/jig.jpg and see a picture of one I made. You
put the drill in from the right and place the bolt in the hole in the metal
fitting on the left. When making the jig you drill out the left hole with
the drill coming from the right. That makes the drill come
out exactly where the hole is on the left.
Ted
Subject: RE: Pietenpol-List: Drilling holes
fitting,
push
several
> Gene
> From: Gene Rambo [mailto:rambog(at)erols.com]
of
never
> To:
From: | "Richard Navratril" <horzpool(at)goldengate.net> |
Subject: | Re: Piet builders in Montana? |
Hi Tim
We are in St. Paul, Mn. but fly into Bozeman on a regular basis. We spend
lots of time in Gardner.
I always like to talk Piet's. I get lots of spare time while my wife hits
the antique shops around Four Corners.
Dick Navratil
Subject: Pietenpol-List: Piet builders in Montana?
> thanks
> Tim
Subject: | Re: drilling holes in fuselage |
Hi Gene. Check out my Pietenpol picture
file at www.mykitplane.com .
There's a drill jig there just for this very thing.
Once you see it you can see how to make it
using other materials you might have lying
around as it has been made by others in many
different styles.
Go to "picture gallery"
then scroll to Clif Dawson
then open the Piet file.
Also I've added a file for my corvair engine.
I've been having my fun. out of two engines
there was one head with dropped valve seats
( bad, very bad! ) two with extensive pitting
on the "squish" area and one good one. No
more heads were to be had around here ( Corsa)
so I took matters in hand, as it were, and
proceeded to " fix" the corroded heads. They
were dead anyway so I had nothing to lose.
All I can say is, thanks, DJ, routers are a
wonderful thing.
Erik Miesterman, another local corvair engine
experimenter, found a couple of spare heads on
hearing my tale of woe and sold them to me, so
I'm fine now. I'll test the heads I reworked but
use these good ones in the finished product. The
reworked ones will be saved as spares.
I have another couple of Piet pics at
www.myartclub.com
Go to "find artist" then to the "D's" then
my name, Clif Dawson.
Clif
> OK guys, I am trying to drill all of the holes in the fuselage and have
some
> questions.
I don't think you'll need rails unless you have soft
ground in front of the hanger. 4 or 5" dolly wheels
should do it, two castoring and two non castoring.
Build in little ramps on both sides and you should
be able to run the Piet right up on your dolly if it's
not too high.
If you do shorten the wing and some undesireable
flight characteristic shows up then what? Taking it
away is easier than putting it back.
On the other hand, wing clipping is a time honoured
practice. Not always with airplanes.
Clif
> The other think I had thought of was to install rails and a dolly so I can
> slide the plane into the hangar sideways.
> Stefan
Depends on were you live. Here in Canada
your plane is inspected by another experienced
airplane builder. Not so easy to fool. On the
other hand, the right one could be sympathetic
to the cause.
Clif
> Gene,
> That was GREAT!
> Sure, I never seen any Inspector taking messurments of anything, in
> fact here, we are so few homebuilders that we can "guide" them to what
> WE want them to SEE.
> Saludos
> Gary Gower
> Still grinin :-)
Long wing: Bill Rewey added 1 foot to the center section and made the
outer wing panels as to plans. This makes his span 29 feet. The plane
flys beautifully and climbs great with 2-200 plus pound people aboard.
Short wing: In the U.S. the inspector should not be concerned with
whether you followed the plans as to wing length or other modifications.
You are building a one-off experimental.
Dick H.
Dick
Thanks for the reply. I have been watching the list
for about 6 months and have enjoyed reading the posts.
I would like to start building next winter. I am
wondering which I should build, the Piet or the GN-1.
What did you build? What did you use for power? Is
your project complete? Well, I had better get to it.
Have a good day. Thanks again.
Tim Moody
--- Richard Navratril wrote:
> Navratril"
> Hi Tim
> Dick Navratil
> From: "tim moody" <tj_moody(at)yahoo.com>
> To:
> next
> of a
> Montana)? I
> construction
> > thanks
> > Tim
> Contributions
> any other
> Forums.
> latest messages.
> List members.
> http://www.matronics.com/subscription
> http://www.matronics.com/FAQ/Pietenpol-List.htm
Digests:http://www.matronics.com/digest/pietenpol-list
> http://www.matronics.com/photoshare
From: | "Oscar Zuniga" <taildrags(at)hotmail.com> |
John writes-
>has anyone done anything with a longer-winged Piet?
>Slats perhaps? I'm curious about anything that might
>make it more STOL-ish in a respectful (and safe) way.
Whoa! A Piet with vortex generators! ;o) I think one of the ways to make
it STOL-ish is to try the approach used by John Dilatush with his turbo'd,
redriven Subaru. I think his plane pops off the ground pretty handily just
due to the added muscle. My thought is that one could certainly apply a
more efficient low-speed airfoil to the airplane, but this gets into the
category of 'sacrilege' among Pieters.
Oscar Zuniga
San Antonio, TX
mailto: taildrags(at)hotmail.com
website at http://www.flysquirrel.net
From: | "Jim Markle" <jim_markle(at)mindspring.com> |
Subject: | Anyone know where THESE Air Camper plans came from???? |
or can be found????
The following link is from the EAA Airventrue Museum site:
http://www.airventuremuseum.org/collection/aircraft/Pietenpol%20Air%20Camper
%20Builders%20Notes.asp#TopOfPage
it shows plan and elevation views (well, parts of views) that I've never
seen before and I would LOVE to get a copy of those plans.....
Anyone have any idea how to do that or where the plans came from?
JM in Plano, TX......
Subject: | Re: Anyone know where THESE Air Camper plans came from???? |
That looks like those Paul Matt drawings (I think that's the right name)
from Historic Aviation Albums in California. I have some of them around
here somewhere (not the Piet, others). I have to find them, I forget who is
selling them now, I think someone in Arizona.
Gene
Subject: Pietenpol-List: Anyone know where THESE Air Camper plans came
from????
> or can be found????
> Thanks,
Stefen,
My Piet will fit nicely into my 30' wide Cover-it hanger, even though the
actual door opening is less than 28'..
I worried alot about it till I saw the guy next to me with the same 30' wide
put his old Cessna 120 with the 33 foot wingspan, inside in 2 minutes.
I use the same method of "nose first,K turn" method .
nose first in off center to the right, at the threshold, drive the nose to
the right pivoting on the right wheel. Now the plane is crosswise to the
opening with centerline about 4 feet inside. Now walk the tail to the
opposite rear corner. You're done. Just did it about 2 hours ago when I
put the piet away.
walt
NX140DL
> company disagree?
> Thanks
> Stefan Vorkoetter
From: | Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov> |
Subject: | Carl Loar----First Flight ?? |
Hello Carl-- I know that you were chomping at the bit for this rough winter
to pass from us in the nawth (as Corky sez)
and just was wondering if you have had a chance to finish up the details
and get some taxi tests done. Not even sure
if you've had your inspection actually. Hope you get some air under your
wings this summer !
Mike C.
I am determined to get this list talking, and building, and flying . . . and
whatever
To add to yesterday's questions:
6. Again, to those of you who are building Model A powered, the drawings
show the ash engine bearers angled down. The drawing suggests that the ash
bearers are notched at the aft end so that they sit flat on the front
fuselage cross piece. Wouldn't it be better, rather than reduce the
strength of the ash engine bearer by notching it, to simply put a hardwood
wedge under the aft end? What are others doing??
More to come . . .
Gene
FINALLY starting to make progress
Subject: | Re: Carl Loar----First Flight ?? |
Mikey,,, Going out this weekend to put the final touches on. Plan on calling
the inspector within next couple of weeks. I had to fine tune my carb and
heat box. Should be running up and down the grass by next week. I'll shout
for shure when I do.
Carl
Subject: Pietenpol-List: Carl Loar----First Flight ??
winter
> wings this summer !
> Mike C.
Carl-- Never too soon to give the inspector a head's up. It took a
looooong while for mine to show up. Maybe you are having a DAR. Those
guys usually show up much quicker since they fetch $$$ for the sign
off. My inspector wanted the cowling off and wanted to see the engine
ran-up. I knew this ahead so had everything unbuttoned. I also had all
the inspection holes open. One thing I did not do was remove the wing root
fairings. (us three-piece builders) He didn't ask me to remove
them. Glad to hear you are making hay !
Mike C.
From: | "Michael Conkling" <hpvs(at)southwind.net> |
Jim,
They look like the drawings that appeared in the mid-60's issues of "Air
Progress" -- they may have been with the Pete Bowers article on the Piet
(the one with the picture of Pete topping up the radiator using a coffee
pot)
Mike C.
Pretty Prairie, KS
from????
> or can be found????
> Thanks,
Subject: | Re: Anyone know where THESE Air Camper plans came |
from????
I thought so to. I've got those ones sitting in front of
me now and it ain't them.
There also in the Aug 1969 American Aircraft
Modeler.
Too bad as I could have mailed copies to anyone.
Subject: Re: Pietenpol-List: Anyone know where THESE Air Camper plans came
from????
> Jim,
> pot)
Sorry, I never hread of a straight six. His first converted engine was
a Ford Fiesta, then he build one with the Ford Escort, improved with a
built spindle for the prop reduction. I was in touch with him for
several years, I will try to get in touch with him... Will be
interesting what new projects he has.
His wife is (Was?) very active in Canadian Ultralight regulations.
Saludos
Gary Gower
> spindle he
> straight 6.
> From: "Jim Malley" <jgmalley(at)comcast.net>
> To:
> 26
> feet.
> "just a
> > little bit faster."
> > Jim Malley
> > To:
> few
> years,
> opening is
> 28
> to
> insurance
> > > company disagree?
> > > Thanks
> > > Stefan Vorkoetter
What size tubing have people used on the bell crank for the elevators.
Round ? Streamlined like the plans show? or made up from two pieces like the control
horns?? Any ideas or suggestions would be appreciated. I bought some streamlined
tubing from Aircraft Spruce and it sure feels too heavy.
Chris
Sacramento, CA
The best thing to hit the internet in years - Juno SpeedBand!
Surf the web up to FIVE TIMES FASTER!
From: | "Greg Cardinal" <gcardinal(at)startribune.com> |
Dale and I used the same tubing as the cabanes.
Greg Cardinal in Minneapolis
>>> cat_designs(at)juno.com 05/30/03 02:25PM >>>
like the control horns?? Any ideas or suggestions would be appreciated.
I bought some streamlined tubing from Aircraft Spruce and it sure feels
too heavy.
Chris
Sacramento, CA
Guys: I just bought some of this tubing (4130 Streamline,1.349"..049 wall) at
Wicks for $9.60/ft. Aircraft Spruce is $17.10/ft. Ouch!.
George
Do you happen to remember what size you use for the cabane struts. Did you flatten
the ends on it for use on the bell crank. The plans show you should flatten
the ends. The streamlined tubing I have is 1.685 x 0.714 0.049 thickness.
Is this to big? or does the geometry of the control cables (two into one attachment
point)require this much strength?
Speaking of flattened ends, when you pinch the ends for the rudder bar and the
bell crank do you need to weld the ends closed after you flatten them?
Chris
Sacramento, CA
Subject: | Re: Bell crank tubing |
I used that same size streamline tubing for my bellcrank, flattened the ends
by heating the tubing with a torch and flattening in a vice when it was red
hot. It helps to take a couple of pieces of angle iron, cut it at the angle in
about 2 inches and bend the free piece into a nice curve. Put two of these
between the jaws of your vice and it'll keep the sharp edge of the vice jaws from
cutting into your tubing and gives a nice easy bend from the round tubing to
the flattened section. I think Tony Bengilis has a description and pic of this
in one of his books on aircraft construction. And I did edge weld the ends.
One advantage of the streamline tubing is that, though it looks pretty
massive, you are going to drill a big hole in it for the axle shaft, so you need
some width there to carry the loads around the shaft, and to give something to
weld the shaft to.
Regarding the attachment of the two elevator cables to each end of the
bellcrank, standard shackles don't have enough room for two cable eye, with
thimbles, at least I didn't using 1/8" cable. I ended up taking two pieces of .090
steel, about 3/4" by 1 1/2", putting about a 20 degree bend in them and putting
one on each side of the bellcrank, with the bends pointing outboard in each
case with a pivot pin through, and attaching my cables to those.
If you have trouble visualizing this, I can email you a pic of my set up.
Oh, and while we're on the subject, think about making up some pulley
brackets and using pulleys where the elevator cables and the rudder cables make
that
bend at the rear seat back. I wasn't satisfied to just drill holes in the
bottom seat support for that, but to each his own.
Matt Paxton
flatten
Chris
Sacramento, CA
Matt,
Just an added 2 cents,,,
You can use just one cable eye in the center of a long cable. The cable
splits from the single eye and one goes left and one goes right.
I know a guy who flew a Piet that someone else built, and he told me that a
friend and friends wife was flying it and the weld at the bellcrank/shaft
broke with a very unhappy ending. He kept pushing me to put a "safety" tube
inside the normal one just in case.
But that's another story.
walt
NX140DL
22 1/2 down, and 2 1/2 to go
Subject: Pietenpol-List: Re: Bell crank tubing
with
of .090
putting
each
make that
> Matt Paxton
you
> flatten
flatten
the
> Chris
> Sacramento, CA
Pieters,
Our little Piet 41CC has 33:45 successful flying time. I have about 5 dual
with my test-instructor pilot Mr Johnson. Yesterday he had me shooting landings
on a sod crop duster strip in the cotton fields down south. 96 La degrees, mid
afternoon, lots of fresh cultivated acres below. CC was bouncing like Jr.'s
rubber ball. Density altitude, 200 ft above sea level. When I flared, usually
too high, CC seemed to be unaffected and kept on earthward.
QUESTION?
Given the 2 degree + incidence at the root in level flight according to the
plans, what should be the washout reading at the outer rib? I'm feeling that
the entire wing is stalling at the same time.
Need some thoughts and chatter on this subject
Corky in La
Subject: | Re: Piet rigging |
Corky,
My spin on washout ( and it's only my own addition of all I've heard and not
a bit of documented truth) is that if the washout is correct , the root of
the wing will stall first, and give you the indication of a stall, slightly
before the tips stall. This gives you time to use the aerlerons, which are
just barely still in smooth air.
sound like this has nothing to do with whats going on with your situation.
Since I've gotten into wheel landings, even though they seem scarier. the
vision is better, and more controllable. BUT I went to do a wheel landing
without power, and bounced four times. It was very scarey. (My log book
reflects four landings) I found that if you keep your hand on that
throttle thing, and just before the flare, (on both wheel and three point)
you goose the throttle to maybe 1000 rpm, It stops the drop and flies
forward momentarily , just to set down. Seems to work on the Piet
beautifully.
Thats a tip given to me by an instructor in the next airport who taught
Harrison Ford, for his tailwheel endosement. Great guy who will take time
to stop and talk to you.
Corky , keep us posted!
walt evans
NX140DL
in rainy NJ
"that brown on my face isn't tan,,,it's rust"
Subject: Pietenpol-List: Piet rigging
> Pieters,
landings
mid
Jr.'s
usually
> QUESTION?
the
that
> Corky in La
Repeat after me! NEVER EVER use ailerons at stall. Pick up the low wing with
the rudder unless you really want to spin!
Cy Galley
Subject: Re: Pietenpol-List: Piet rigging
> Corky,
not
of
slightly
are
book
point)
> beautifully.
> walt evans
> NX140DL
> in rainy NJ
> From: <Isablcorky(at)aol.com>
> To:
> > Pieters,
dual
> landings
degrees,
> mid
> Jr.'s
> usually
> > QUESTION?
> the
> that
> > Corky in La
The purpose of washout is not to give YOU advance notice of a stall, but to
make the wingtips, i.e., the aileron area stall a little bit later to give
you some additional aileron authority. You may not, and probably won't,
notice the difference. I doubt that you would be able to tell that "the
entire wing is stalling at the same time."
> Pieters,
landings
mid
Jr.'s
usually
> QUESTION?
the
that
> Corky in La
To add to my list of questions (not that my previous ones have generated
many responses):
7. Are any of you offsetting the vertical fin to the left, or are you
aligning it with the fuselage?????
Gene
From: | "Jack Phillips" <pietflyr(at)bellsouth.net> |
Gene,
I drilled two sets of holes so that if I find I need more offset (the first
set is on the centerline) I can do it easily. I'm expecting to not need the
second set of holes, though. I think most Piets flying have the fin
centered on the centerline.
Jack
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene Rambo
Subject: Pietenpol-List: Re: Question #7
many responses):
Gene
I think the 1" difference in the front and rear cabane struts, equates to 3
degrees positive incidence. No need for washout on a Hershey bar wing. It
inherently stalls inboard first, then the stall progresses outboard, providing
you keep the ball in the middle. The drawback to washout, is it adds drag.
Cy is correct : NEVER EVER use ailerons at stall. Pick up the low wing
with
the rudder unless you really want to spin! Lets look at this-- Lets say you
are very close to the 'Critical Angle of Attack' (AOA where a stall begins),
at low airspeed (any airspeed actually). If the right wing is low, and you
give left aileron, lowering the right aileron past the 'Critical Angle of
Attack,' raising the left aileron and lowering the left wing tip's angle of attack.
Result : the right wing tip will stall, and it will spin to the right.
A little blip of power might be needed if your rate of decent is high,
and your airspeed is low, to help level off the rate of decent just before
touchdown. The propwash also helps the rudder to be more responsive.
Corky, my hunch is that you are doing your round - out, and flair all in
the same motion of the stick. This will bring the entire wing past the
'Critical Angle of Attack' all at once, and stall the entire wing.
It's been awhile since I've flown my Piet, but my preference for landing
was to cross the fence at about 50 mph, roundout at about 5 to 8 agl, then
ride the ground effect for a couple of seconds very close to the ground, then
break lift with very slight additional aft stick. My last 3 landings (last fall)
the tail touched just a split second before the mains, and it stayed on the
ground...no bounce, short roll out. This method, however, probably would not
work well with a cross wind. Wheel landing is preferred for cross wind
landings.
Chuck Gantzer
NX770CG
planning on first engine run of the A65 this week. Do 3 or 4 ground runs,
with cool down period, and inspections. If everything works out first flight
with new engine next Sunday evening, weather permitting.
In a message dated 6/1/03 9:03:31 PM Central Daylight Time, rambog(at)erols.com
writes:
<< 7. Are any of you offsetting the vertical fin to the left, or are you
aligning it with the fuselage????? >>
Gene,
My fin is aligned with the fuselage, but I ofset the A65 engine mount about
1/16" to the right. Low power aircraft usually don't need the fin offset to
account for torque.
Chuck
Subject: | DeLand Fl. Model A |
Hello Lou: Thanks for the work on bud Rogers. The article just called it
Travel Air Aviation, and gave no name. They did include a phone no., so
I will give him a call. Full pressure oiling, insert bearings, and
updated carburation may just be the ticket to a reliable Model A.
Thanks. Leon Stefan
Subject: | Off set vert. fin |
Gene: I was going to off set the fin, but decided to set it straight
with the fus. center line. I beefed up a small area of the rudder
trailing edge and drilled it so I can add a trim tab later if I need to.
I also did the same to the elevator trailing edges after the long
discussion about trim problems that ran on the list some months ago.
Leon S.
You guys shouldn't overdo the admonition about using the ailerons in a
stall. The discussion is about the pre-stall area, and if you were not
supposed to use the ailerons then, they wouldn't have designed the airplane
so that the inboard end stalls first in order to give you aileron authority
up until the stall. What you NEVER NEVER want to do is be screwing around
with massive rudder imputs at the point of the stall or you WILL spin.
Gene
It
providing
drag.
> with
you
begins),
you
of attack.
in
landing
then
(last fall)
the
not
> landings.
> Chuck Gantzer
> NX770CG
flight
I don't know about low powered airplanes not needing the offset, have you
ever seen a Aeronca Champ fuselage? The fin is offset nearly an inch. A
Cub is offset, too. I don't know for sure about the common belief that the
offset is for torque, I believe that it is to correct for adverse yaw as a
result of P factor. I know the Cessna Airmaster I used to have had the
non-adjustable fin set in the middle, and the thing would never fly hands
off without rolling off to one side until I discovered that they originally
came with an externally adjustable rudder trim tab (which the previous
restorer had omitted for appearance sake). Once I installed the tab, it
flew perfectly.
I do NOT want to install a tab on the Piet if I can help it. C'mon you guys
with flying airplanes, especially Model A powered, offset fin or not?????
Gene
Subject: Re: Pietenpol-List: Re: Question #7
rambog(at)erols.com
> writes:
> Gene,
about
to
> account for torque.
> Chuck
For the cabanes we used 1.349 x .571 .049 wall thickness. Bellcrank
ends were flattened. End holes for the cable attachments were drilled so
they would align through the bellcrank pivot centerline. This maintains
the cable geometry as a parallelogram to reduce uneven cable tension
throughout the range of motion.
We did not use cables from the control stick to the bellcrank. A
push-pull tube from the stick passes under the seat and connects to the
bellcrank. Stick / elevator movement ratios were maintained to the
original design.
Neither the bellcrank nor the rudder bar ends were welded shut.
>>> cat_designs(at)juno.com 05/30/03 03:56PM >>>
you flatten the ends on it for use on the bell crank. The plans show
you should flatten the ends. The streamlined tubing I have is 1.685 x
0.714 0.049 thickness. Is this to big? or does the geometry of the
control cables (two into one attachment point)require this much
strength?
and the bell crank do you need to weld the ends closed after you flatten
them?
Chris
Sacramento, CA
Subject: | Re: Pietenpol-List Digest: 8 Msgs - 06/01/03 |
Gene, I offset the leading edge of my fin 1/4" to the left. If I don't like
the way it flies, I'll make up two new forward fin brackets and align it
straight.
Matt Paxton
In a message dated 6/2/03 2:58:53 AM Eastern Daylight Time,
pietenpol-list-digest(at)matronics.com writes:
many responses):
Gene >>
Group,
How many of the flying Pietenpol's have placed a tuft of yarn about 12-18"
long in the center of the fuselage forward of the wind screen to see if they
are flying straight or in a crab? The answer to this question will do a lot
for us in answering the question of offsetting the vertical fin or adding a
rudder trim tab. I did this test when test flying the RV-6 and offsetting
the vertical stab caused a lot of unnecessary work. Ended up resetting it
straight and adding a trim tab on the rudder. On my Pietenpol I will set
the stab straight unless information gathered says otherwise. Looking
forward to the answer to the first question..
Alex Sloan
Subject: Pietenpol-List: Re: Pietenpol-List Digest: 8 Msgs - 06/01/03
like
> straight.
> Matt Paxton
> many responses):
> Gene >>
We set our rudder straight and after a few hours flight added a 3x3 .020
alum tab on the upper part of the rudder. Solved the problem completely, matter
of fact have never had to bend adjust since.Didn't even slow the Piet down,
still speeds along at 69 cruise, 72 in a dive and stalls at 40.
YKW
Subject: | Re: Pietenpol-List Digest: 8 Msgs - |
06/01/03
Alex,
Wouldn't that give an invalid reading, since it is in the slipstream? Perhaps
some yarn outside of the slipstream on the underside of the wing and some reference
lines visible from the driver's seat would be more accurate. If the yarn
extended beyond the trailing edge and you had a piece of masking tape marked
with a sharpie you should (might?) be able to see if from the cockpit.. Just
a thought from a guy who has never flown a Pietenpol (yet, at least), but only
sat in one in a hanger...
John Ford
jford(at)indstate.edu
812-237-8542
>>> alexms1(at)bellsouth.net Monday, June 02, 2003 9:41:29 AM >>>
Group,
Alex Sloan
like
> straight.
> Matt Paxton
> many responses):
> Gene >>
I think all Piets tend to do this. I fly a GN-1 and it does the same thing.
Add a little power when you start to flare and you will grease it on. Or
come in at 80mph. jas
>Pieters,
landings
mid
usually
>QUESTION?
>Corky in La
Group,
If it is proven a trim tab is needed on the Piet, it is important that the
trim tab be placed on the UPPER part of the rudder. If placed on the lower
part of the rudder the fuselage blocks out the effectiveness of the tab to a
degree. This is a lesson I learned the hard way.
Alex Sloan
Subject: Re: Pietenpol-List: Re: Pietenpol-List Digest: 8 Msgs - 06/01/03
matter
down,
> YKW
80 mph?????????????? Maybe in my model T but never in a Piet
06/01/03
Corky-- Had the exact same scenario with my Piet. I did put in something
like 3/8" washout as measured at the second last rib towards the tip as per
Cubs & Champs. Figured they knew what they were doing and the restoration
gurus at my airport (IA's, not just jaw flappers) said to put that washout
in as well. Went thru the in-flight rigging check that Tony Bingelis
describes so nicely and had to tweak one of my rear lift struts and add the
alum trim to the rudder.
Mike C.
Subject: | A-65 engine offset |
Forgot to say that I put some big fender washers on the left sides of my
motor mount to make the engine point
"right" a bit. About three or 4 1/16" thick washers I think. Can't help
the Model A builders with any input here.
Mike C.
Subject: | Piet speed (was Piet rigging) |
Which brings me to a question I've had. How fast can a Piet cruise (Vno)?
I've heard everything from 65 mph to 95 mph. Also, what's the typical (Vne)?
Stefan
From: | "rambog(at)erols.com" <rambog(at)erols.com> |
The yarn thing is probably not necessary as most of the builders I have
heard on here are putting turn and banks, or at least inclinometers in
their aircraft. I don't know whether the fin offset (or tab) would
necessarily affect the slip/skid, but it will affect wing heaviness.
I want to avoid using a trim tab at all costs. It sounds like most
responses on here have resorted to tabs, so some offset must be necessary.
I may make the holes in the horiz stab far enough apart that I could change
the lower fittings and move the leading edge of the fin as necessary (or
drill multiple holes like some have suggested).
Now that I think of it, though, I could make a fitting similar to the one
on the front of the fin on the Travel Air, which consists of two 90 degree
tabs with a long threaded bolt horizontally between them. The bolt goes
through the leading edge of the fin with a lock nut on either side of the
fin. This allows infinite adjustments by repositioning the locknuts and
moving the fin left or right. This is really not much different than
Bernie designed, the bolt through the fin is just a little longer.
Gene
Original Message:
Date: Mon, 2 Jun 2003 09:41:29 -0500
Group,
Alex Sloan
like
> straight.
> Matt Paxton
> many responses):
> Gene >>
In the same Flying and Glider Manual (1932) Check out the "Ramsey
Bathtub" The same way, just make it fit in the wooden fuse of the
Piet.
If I remember correct is about 1" each side with washer adjustments.
Saludos
Gary Gower.
> have
> in
> necessary.
> change
> (or
> one
> degree
> goes
> the
> and
> Gene
> Original Message:
> From: Alex Sloan alexms1(at)bellsouth.net
> 06/01/03
> Group,
> 12-18"
> if they
> do a lot
> adding a
> offsetting
> resetting it
> set
> Looking
> Alex Sloan
> From: <Woodflier(at)aol.com>
> To:
> don't
> like
> align it
> > straight.
> > Matt Paxton
> generated
> > many responses):
> you
> > Gene >>
http://search.yahoo.com
Subject: | Re: Piet speed (was Piet rigging) |
Stefan, at 2150 rpm on a 65 Cont. I cruise at 71-72 mph (gps, no wind)
stall at 29 mph and when I hit
about 95-100 mph I gently ease out of that since it sounds like the fat
lady is about to sing. Others may differ.
Running a 72"-42P wood prop.
PS-- Corky-- I think on a 96 F day the reason you don't have much left in
the flare with two souls aboard is because
the air is so thin. How was your climb out ? I wouldn't dare take
another person on a 96 F for a ride. (course then
Edwin doesn't weigh what we do---thankfully.)
Mike C.
Subject: | Pietenpol Wing Washout |
On the subject of wing washout:
Washout is a reduced angle of incidence at a wing tip as compared to the
root. (It's as if the wing is twisted slightly toward the nose looking from
root to tip.)
All wings that don't have any washout tend to stall near the tips first.
(Lower aspect ratio wings have a stronger tendency than high aspect ratio
wings and swept wings have a much stronger tendency that straight wings.)
The purpose of washout in any wing is to prevent a stall close to the
wingtip before a stall begins near the root. A stall causes a rapid loss of
lift and a partial stall near the tip, if not perfectly balanced, will cause
an airplane to roll towards the stalled tip. The natural tendency of a
pilot is to stop that roll with an aileron input which only worsens the
stall on the low side.
By rigging washout in the wing, the stall onset can be forced to occur
closer to the wing root. Any imbalance in a stall at the root won't roll
the airplane as much as a tip stall and stall recovery can be initiated
before feeling any need to roll the airplane upright.
I built it right down the middle, with the engine mount per plans ( only a
little longer) and yaw is not a problem.
walt
the
originally
> flew perfectly.
guys
> Gene
> From: <Rcaprd(at)aol.com>
> To:
> rambog(at)erols.com
> > writes:
you
> > Gene,
> about
offset
> to
> > account for torque.
> > Chuck
I offset mine 1/2 inch from the centerline, and offset the engine mount
too.
Steve e.
Rambo
you
A
the
a
hands
originally
flew perfectly.
guys
not?????
Gene
rambog(at)erols.com
> writes:
you
> Gene,
about
offset
to
> account for torque.
> Chuck
Subject: | Re: Pietenpol Wing Washout |
Mike,
I like your explanation of wing tip stall. So, for me to understand the
suggested wing twist in my Pietenpol, the outer wing tips should not have as
much incidence as the root, correct? So, as the wing loses lift, the wing
tips are at a lower AOA and will still be flying. Is this what your saying?
Alex Sloan
Subject: Pietenpol-List: Pietenpol Wing Washout
from
> root to tip.)
of
cause
Nx7229r is 74mph cruise. 104mph VNE.
I came up with the 104 on my own during flight test phase. The airplane
gave all kinds of complaints at that speed. Lots of wind noise, felt
like it wanted to nose over, stiff controls. Keep it slower and it
will be happy.
Steve e.
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Stefan
Vorkoetter
Subject: Pietenpol-List: Piet speed (was Piet rigging)
(Vno)?
(Vne)?
Stefan
Pardon me for asking but were you in a kamakazi attitude to obtain that
104?????????
In the book "How I make wood propellers" by Alvin Schubert the author talks about
carving several props for Berne Pietenpol and Vi Capler for use on a corvair
powered Air Camper. Full throttle speed was 100 mph (3500 rpm) cruise was 78
mph (2900 rpm). The authors indicates it was the best propeller that had used
on the plane. I'd say the Vne should be 100 mph anything above this is unknown
ground (and very hard to obtain).
Chris
Sacramento, CA
Stefan
on 6/2/03 12:23, Alex Sloan at alexms1(at)bellsouth.net wrote:
> Mike,
> Alex Sloan
Generally, yes.
> From: "Mike" <bike.mike(at)verizon.net>
> To:
> from
>> root to tip.)
> of
> cause
Corky,
I had the same problem with no-float after starting to flare for the
landing. Probably more extreme than you have because of our higher
(sometimes more than 10,000 feet) density altitude.
The first few landings I made were when I came over the fence at about 60
indicated and when I flared, the damn'd thing just wanted to drop out of the
sky! The Piet design has so much drag that as soon as you increase the
angle of attack, it slows down dramatically and just quits flying (stalls).
I then experimented with a higher approach speed and this did the trick.
The higher approach speed results in a surplus of energy during the flare
which translates into more float and therefore you have more time to adjust
the height of the flare. You can also increase the flare by adding a
little power on the landings. As a result of this learning curve, I now
come over the fence faster than 70 indicated. When using power, set up your
approach some distance out and use just enough power to check the sink rate
and then don't change a thing until you have all wheels firmly planted with
the stick back in your belly so you have positive directional control.
As far as wash out is concerned, I put about 3/8" measured at the trailing
edge of the aileron. A normal stall is straight foward, although a power on
stall tends to drop the left wing, probably due to P-factor.
Hope this helps, Good Flying!
> Pieters,
landings
mid
Jr.'s
usually
> QUESTION?
the
that
> Corky in La
Gene,
I did offset the leading edge of the vertical fin 1" to the left. This
seems about right in cruise, however, you will still have to hold a little
right rudder in a climb.
> many responses):
> Gene
Subject: | Clarification of my Piets" landing characteristics |
Corky,
I should explain that my Piet probably weighs a 150 lbs more than yours does, because
of the engine, etc, etc.
This is the reason that my approach speeds are somewhat higher than you would see,
however, the principle of surplus energy is still valid to smooth out your
landings.
Subject: | Split Axle Springs |
Those of you who are using a split axle on their Aircamper, what type of
springs did you use and where did you get them?
In an old issue of the BPA there is a spring set up to replace the
bungees which calls for H56 Lamina springs, what are they?
Dennis Engelkenjohn
Subject: | Re:Fin offset and A engine mounts |
Gene
I really like your solution to fin adjustment as stated below. It is also
one of the reasons I stay with this group.
Great Ideas, new or old. One thing that led me to the Piet/GN-1 is the
infinite solutions builders seem to find to little problems or quirks of the
design.
In response to one of your earlier questions about A engine mounts: BHP
states that the down thrust angle of ash engine bearers allow the prop to
bite the air squarely in climb attitude. How do we know this is right? I
assume he tried many different angles.
I have decided to make a tubular engine mount that is adjustable in thrust
line both horizontally and vertically. It would consist of two long "V's" to
carry the front of the engine and two shorter ones for the rear. The engine
itself is a rigid beam. If the cowlings are mounted only to the engine and
mount, thrust line changes wouldn't require cowling changes.
The angle of incidence of the wing to fuselage and also to the thrust line,
seems like an area that a lot of experimenting can go into. When each
individual builder incorporates their own small changes, it gets a little
tough to compare if changes are beneficial. I think it was Graham Hansen who
said or quoted "Add lightness and simplicate!"
That Travel Air fin adjust method is a good example.
John Mc
Gene
Subject: | need some input from those who have flown a standard Piet, |
and also a Piet with dihedral
I have been running into an annoying problem with my Piet. In still air it flies
beautifully, hands off. but later in the morning when the turbulence starts,
I seem to be all over the place, being tossed around like a cork. I couldn't
even imagine flying some major cross country in anything but sunset or sunrise.
Could this be from my lack of dihedral, or is it just because it's a light plane.
(and mine seems to be one of the lightest.) Maybe the heavier planes are
better in the wind.
I would consider putting in the normal dihedral, but I don't want to go thru the
labor and time down, only to find out that it really makes no difference. When
I was flying the Cub and Aeronca, I didn't seem to feel this. But then again
I didn't have enough hours in either to maybe realize it.
Did anyone out there happen to fly both? And if so, was there a big difference?
thanks,
walt evans
Corky,
Try this. Use an approach speed of around 65 MPH and hold it until you are
about 6" above the ground. Pull back smoothly on the stick and you will
flare and should have a smooth landing. I found that trying anything less
than 65 resulted in what you describe. You just seem to run out of elevator
and the thing just keeps sinking into the ground with thud.
What I describe above is a dead stick landing. If you come in with slight
power you can slow the approach down a little. Cut the power at the 6"
point and you have another great landing.
I fly a Cessna 140A and this thing doesn't flare or float anything like it
or any other plane I have flown.
Try this and report back. You might experiment and find a better approach
speed for yours. They all seem a little different.
Ted
> Pieters,
landings
mid
Jr.'s
usually
> QUESTION?
the
that
> Corky in La
Subject: | Re: Split Axle Springs |
Dennis, The H56 Lamina Springs are Die Springs as used in large stamping
dies. If you have a tool and Die builder in your area he will be able to
get them for you. Another source would be from a McMaster Carr Catalog.
They sell everything you can think of for industry. There Web site is
www.mcmaster.com
Jim D.
Subject: Pietenpol-List: Split Axle Springs
> Dennis Engelkenjohn
Subject: | John Dilatush's comments---good reading |
Guys---it's good to see the list chattering again about Piet stuff
! John's comments about the Piet being draggy and not giving one much time
in the flare is so true when compared to other planes we have been used to
flying. (especially if you are used to the nice cushion you get when
flaring a low-winged airplane on landing.) I often adjust how much speed I
carry on the final approach depending on load and other conditions like
temperature and wind. Mostly load and temperature. Another thing that
takes some getting used to is that never has one's butt been so close to a
runway in a flare and it's just natural to flare too high for your first
few landings (or in my case 30:) .
Mike C.
Subject: | Eureka, Walt Evans !!!!!! |
Walt-- Would you please talk to all the other pilots in the area who think
I'm a whimp on hot bumpy, windy days with my Piet???? I have the EXACT
same issues with turbulence as compared to when flying a Cub or Champ or
anything heavier. Many others here do not believe me when I say how
sensitive my Piet is to turbulence. It's very obvious when I fly to a
pancake breakfast (or from more likely) with another plane in loose
formation that I am the one getting tossed around, not the other
plane. There are very few 2 seat single engine planes out there that have
an empty weight near 600 lbs. like ours do.
Mike C.
Dennis,
AS & S catalog for 2001 - 2002 page 214 describes "Shock Absorber Coil
Rings" @ $86.25 for a pair. They come with instructions for gear
fabrication. They are die springs.
DickG.
Subject: Re: Pietenpol-List: Split Axle Springs
> www.mcmaster.com
> Jim D.
> From: "D. Engelkenjohn" <wingding(at)usmo.com>
> To:
> > Dennis Engelkenjohn
Subject: | Chords, aero not music |
Pieters,
Would someone in the know, and that's most of you, list the chords and NACA
numbers of the wings of the Cub and aeronca. Would be interesting to compare
the airfoils to the BHP FC10.
CMC
I agree with you guys. The first time I flew a Piet, someone's A powered
one at Brodhead, I came in at what I thought was a good speed but with a
healthy sink rate. When I tried to flare a little to slow the descent rate
it fell out of the sky. I had to endure a LOT of ribbing from the "bunch"
and numerous inspections of the gear. Since then, it has been fast and
flat!
(not that I get to fly Piets that often)
Gene
FINALLY MAKING PROGRESS!!!!!!!!!
Original Message:
Date: Tue, 03 Jun 2003 07:33:32 -0400
Subject: Pietenpol-List: John Dilatush's comments---good reading
Mike C.
Dennis,
I used the A.S. & S springs on mine but a retired tractor dealer looked at
them sitting on the table and asked "what are you going to use them Baler
tension springs for?". May be you can find them locally.
Ronnie.
> Dennis Engelkenjohn
From: | "Alan James" <MADjames(at)theknapp.freeserve.co.uk> |
G-BUCO cruises at 70 knots at 2050 rpm on a C90 swinging home made 70 x 48
prop.
At 2150 rpm we cruise at 75 knots. The PFA quote a VNE for the Piet of 100
knots.
Alan James
Subject: RE: Pietenpol-List: Piet speed (was Piet rigging)
> will be happy.
> Steve e.
> From: owner-pietenpol-list-server(at)matronics.com
> Vorkoetter
> (Vno)?
> (Vne)?
> Stefan
Subject: | Re: need some input from those who have flown a standard |
Piet, and also a Piet with dihedral
Subject: Pietenpol-List: need some input from those who have flown a
standard Piet, and also a Piet with dihedral
Walt,
What you have been experiencing is pretty normal with a Pietenpol.
Remember, this plane was designed in 1929 and most planes of that era were
judged to be good flyers if they were only controllable! In the intervening
54 years designs have gradually improved, designers have discovered the
advantages of Frise ailerons (and other variations) to control adverse yaw,
tail volumes have gone from a coefficient of .3 to higher than .5 to improve
directional stability and airfoils have changed that are more stable as
designers have become more sophisticated. Many other aerodynamic
improvements have been made. A Pietenpol is an antique airplane and we can
not expect it to fly like a Super Cub, Husky, or Cirrus.
When you run into turbulence, and it starts wallowing around, part of the
problem is attempting to correct every little deviation. Just relax and let
it go, the plane will gradually settle down in it's own way, just not as
smoothly as the modern designs of today.
Don't change a thing on your plane, it is as it is. And you can brag to all
your fiends that you are one of the few, to have the skills of an old-time
pilot when you take off into the wild blue yonder!
None of this modern sissy stuff for us Pietenpol Pilots!
r
it flies beautifully, hands off. but later in the morning when the
turbulence starts, I seem to be all over the place, being tossed around like
a cork. I couldn't even imagine flying some major cross country in anything
light plane. (and mine seems to be one of the lightest.) Maybe the heavier
planes are better in the wind.
thru the labor and time down, only to find out that it really makes no
difference. When I was flying the Cub and Aeronca, I didn't seem to feel
this. But then again I didn't have enough hours in either to maybe realize
it.
difference?
> thanks,
> walt evans
From: | Kip & Beth Gardner <kipandbeth(at)earthlink.net> |
>Dennis,
>Ronnie.
If I remember correctly, there have been 2 references to this on the list
over the years (my computer is to old & slow to get on the web & do an
archive search).
If memory serves me, in one post someone mentioned a company in Minneapolis
that sells industrial springs (with a part #) & in the other someone listed
a John Deere part number (maybe the above-mentioned Baler Tension Springs?)
Maybe someone can check the archive? I'm interested in these too & now I
can't find either post among the ones I've saved for 'future reference'.
Kip Gardner
North Canton, OH
Subject: | Re: Eureka, Walt Evans !!!!!! |
Mike,
Got an email from a flyer who thought that the problem could be control
cables a little on the loose side. Didn't want to post his message to me on
the group, but he might have a point. I've always been very wary of over
tight control cables and something breaking. Could I/you have slightly
slack cables causing this squirrelly condition???
It just bothers me to think that some day on flying to Brodhead in my
dreams,,,, and in reality, when the wind kicks up in the real world, I'm
lucky to make it back the 15/20 miles to home base.
Maybe I'm just a sissy
ms. walt evans
would it help to carry an anvil in the front hole?
Subject: Pietenpol-List: Eureka, Walt Evans !!!!!!
> Mike C.
Subject: | Bartelsville Bi-plane Expo |
Just wanted to pass along to everyone there is a fly in at Bartelsville OK
(BVO) this weekend. One of the better ones that I have been too. Great
people and an excellent time. Took my first flight in a Bi-plane there and
was sold on open cockpit flying after that. If you get a chance come on up.
Mark
http://www.biplaneexpo.com/
"Once you fly you will walk with your eyes skyward.
For there you have been and there you will go again."
Leornardo da Vinci 1452-1519
From: | Richard deCosta <curiousspider(at)yahoo.com> |
I did a little more research and decided not to use my
82" prop on my piet. I posted it on ebay if anyone's
interested:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&category=26439&item=2418038376
Richard
http://www.RicharddeCosta.com
Don't know chords offhand, but Aeroncas, depending on model were NACA 4412 or Clark Y. Piper Cubs were USA 35B. Good resource for this stuff is: http://www.aae.uiuc.edu/m-selig/ads/aircraft.html "The incomplete guide to airfoil usage". Can't find my airfoil book, anybody got the ordinates for these airfoils? Lift curve?
Dan Bailey
Paola, KS
(Building ribs)
True cross country jaunts are really tough. Don't believe the anvil would
help, I regularly fly at 1250 gross and have often experienced not being
able to control altitude within 400 feet each way on a windy sunny day.
Tightening and loosening control cables has made no difference. Our trips to
Brodhead were made in the mornings and evenings of many days. You can try
going above the scattered cumulus but then you can't see the roadsigns.
Jim Malley
Subject: Re: Pietenpol-List: Eureka, Walt Evans !!!!!!
> Mike,
on
> ms. walt evans
> To:
think
have
> > Mike C.
I looked in the archives per Kips suggestion and found:
H56 Lamina is a brand and they are available at $17.25 ea. through:
Precision Punch and Plastics
Minnetonka, MN (800) 227-0690
The springs are also available in extra heavy duty, : XH56 Lamina and
are about twice as strong as the regular. Duane Woolsey recommended the
heavier duty in June of '99, said his Piet sagged down too far with the
weaker ones.
The John Deere spring is Part # T143444 and cost was $12.00 ea.
Dennis Engelkenjohn
Subject: | connecting rod nuts |
Thanks for all the replies to my question. Oscar hit it on the head with
what I wanted. I used the Mexican nut starting method to get them on. My
youngest sons girlfriend is a little mexican girl with tiny hands and
feet and her little hands fit in the crankcase with room to spare. She's
good to have around, hard worker too, more than her boyfriend!
Dennis Engelkenjohn
Jim,
That is the right attitude (pun intended). False expectations are what get
us into trouble. Like expecting other drivers on the road to drive sanely.
The same with the Piet. Once you start thinking of the Piet being a fun
plane that you have to pay attention to, you start to have fun. It is rare
that you can fly hands off. On the other hand, I give her a free hand and
roll with whatever comes. Most of the time every action is followed by an
equal and opposite reaction. Right wing lifts. A few seconds later it is
usually coming back down on its own. I hardly ever touch the ailerons. A
little rudder to bring the wing up, if it doesn't come up on its own, and
let the altitude run. The only time I jump in and take over on altitude is
if I catch a thermal and start climbing through 1000'. Then I get serious
and bring her back down to 500'. Starts getting cool up that high.
And watch out for those thermals you get at the end of paved runways during
the summer. Just when you think you have a greaser you start ballooning,
then dropping as you go over the runway numbers and then up you go again.
But, that's what gives you a swagger as you dismount and walk among those
tricycle pilots.
See you at Brodhead.
Ted
to
> Jim Malley
> From: "w b evans" <wbeevans(at)verizon.net>
> To:
> > Mike,
me
> on
over
> > ms. walt evans
> > To:
> think
EXACT
or
> have
> > > Mike C.
Ted,
I printed that one out and hung it on the wall. Says it all.
Peter.
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ted
Brousseau
Jim,
tricycle pilots.
Ted
> would help, I regularly fly at 1250 gross and have often experienced
> not being able to control altitude within 400 feet each way on a windy
> sunny day. Tightening and loosening control cables has made no
to
> try going above the scattered cumulus but then you can't see the
> roadsigns. Jim Malley
> To:
> > Mike,
> > control cables a little on the loose side. Didn't want to post his
> > message to
me
> on
over
> > slightly slack cables causing this squirrelly condition??? It just
> > I'm lucky to make it back the 15/20 miles to home base. Maybe I'm
> > just a sissy ms. walt evans
> > To:
> > > who
> think
EXACT
> > > Champ
or
> > > how sensitive my Piet is to turbulence. It's very obvious when I
> > > fly to a pancake breakfast (or from more likely) with another
> > > plane in loose formation that I am the one getting tossed around,
> > > not the other plane. There are very few 2 seat single engine
> have
> > > Mike C.
advertising on the Matronics Forums.
Share: Share photos & files with other List members.
Dennis,
One of the few parts I bought new, it figures I paid too much!
I bet they are the same thing.
I would post a picture if someone can tell an ignorant redneck from Arkansas
how to do it. No big words please!
Ronnie
> weaker ones.
> Dennis Engelkenjohn
Subject: | Emachienshop.com parts soon to be here! |
I will be receiving my laser cut steel fittings from Emachineshop.com this
week. I'm excited to see just how well this process went...
I drew up the fittings in CAD, placed the laser cut order online, paid via
credit card, all without talking a person....
For those building GN-1's I'll have a bucket full of extra parts... rudder &
elevator horns, cabane brace wire lugs, and more... In order to get a
discount I
had to do a few extra pieces...
I'll post pictures when I get the stuff...
DJ Vegh
N74DV
Mesa, AZ
www.imagedv.com/aircamper
> Dennis,
Arkansas
> Ronnie
> To:
> > weaker ones.
> > Dennis Engelkenjohn
This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>.
Subject: | slack cables and anvils |
Walt-- Since we have to THINK when doing things while building a Piet and
rigging it, one of many, many questions that I had to answer was "how tight
should my control cables be ?" I dunno. Some guys have them slack, some
you can hit B sharp on. My (always simple-minded, but it works) method was
to tighten the cables until I felt a 'binding' or sluggishness in the
control stick feel and then back-off on the turnbuckle a bit and safety
wire it. Don't want your cables jumping off the pulleys--but that would
never happen anyway since we all are installing cable guards like Tony B.
and the FAA want us to have. But, bottom line is that my cables are
pretty snug, not slack, but not guitar tight either and my plane flies just
like yours in turbulence. Your idea of the anvil in the front seat is
actually an excellent idea. I have found that with full fuel or a
passenger that the plane flies better in turbulence. Stands to reason I
guess as you are increasing the wing loading per square area.
One additional note- I found that the front seat as built to the plans
is not really durable. I've done several repairs to mine and
"beef-ups" Maybe my passengers are just rough on the seat but it seems to
take a beating. I did put rudder bar stops (simple wood blocks glued to
the floor in front of the rudder bar on each side so that the rudder does
not bang into your flippers (elevator.))
Those help to keep us from kicking the rudder bar into the front seat front
support plywood. (of which I would have made 1/4" thick not 1/8" as the
plans show.)
Mike C.
Subject: | Cross Country in a Piet |
Jim Malley is right on about his trips to Brodhead in his Piet. (by the
way, that is a really pretty, pretty airplane) On my first trip to
Wisconsin it took 12 hours door to door to fly from Cleveland to Watertown
Wisconsin when you could have driven that in about 9.5 hours or less. The
vis. and ceilings were superb but the wind was gusting, hot, bumpy, and
totally fatiguing. I never have slept so good in my life as that
night. It's not unsafe, it just is very, very annoying. Many times the
bumps were so strong that I would re-grip the stick about 8" down from the
top since prior to that my arm would literally fly up off the stick in a
bump.
Seat belts snug ? I was a non-gps owner then and it was no easy task
watching the sectional chart and keeping it tucked in my knee
board. Folding it to a new section was an art in itself in that kind of
turbulence. Even on a smooth day, fold your maps down low by your knees,
not up by the upper longerons.
Jim made another excellent point. On hot/turbulent days you are
basically at the mercy of the dark and light colored fields below you for
altitude control. On those days when x-country it is a constant battle to
maintain altitude. You feel like a happy sailpane one minute gaining
altitude by the gob, and the next you feel like you are in a
mini-microburst being pushed toward the ground.
The really good, happy, encouraging, and satisfying end to this e-mail
is that those days are not always the case. There have been some
days (like the trip to Indianapolis and back last Sept.) that I barely had
to touch the controls. Just keeping track of the chart and gps and
relaxing as the gorgeous farmlands scroll by below, not even noticing your
pile of sticks flying 2000 feet above. How sweet it is !
Mike C.
es eeeee
Hey DJ,
Just let me know what you have and I will take them off you hands, along
with the other pieces that I am getting from you.
You going to Oshkosh this year?
Ken
GN1 2992
Canada
Subject: Pietenpol-List: Emachienshop.com parts soon to be here!
discount I
DJ Vegh
N74DV
Mesa, AZ
----- Original Message -----
> Dennis,
Arkansas
> Ronnie
> To:
> > weaker ones.
> > Dennis Engelkenjohn
Subject: | RE: continental engine |
I am not at home, so I don't have my mail list to know who I have been
talking to about engines. I have been encouraging someone on here to buy a
65 for his project. There is a Continental C-65 on EBAY right now with a
starting bid of $800. It says it was running when removed. It does not
look like there is a reserve. If I had the spare cash, I'd buy it for that
price.
Gene
Subject: | Re: Emachienshop.com parts soon to be here! |
Thanks Ken... I have you down as wanting some parts.... I won't make it to Oshkosh
this year... I'd like to bu don't have the time... :(
To: 'pietenpol-list(at)matronics.com'
Sent: Wednesday, June 04, 2003 5:38 AM
Subject: RE: Pietenpol-List: Emachienshop.com parts soon to be here!
Hey DJ,
Ken
GN1 2992
Canada
-----Original Message-----
To: pietenpol-list(at)matronics.com
discount I
DJ Vegh
N74DV
Mesa, AZ
To:
> Dennis,
Arkansas
> Ronnie
> To:
> > weaker ones.
> > Dennis Engelkenjohn
No problem, just let me know how much I owe you and what other parts you
have.
Ken.
Subject: Re: Pietenpol-List: Emachienshop.com parts soon to be here!
to Oshkosh this year... I'd like to bu don't have the time... :(
Hey DJ,
Ken
GN1 2992
Canada
this
discount I
DJ Vegh
N74DV
Mesa, AZ
To:
> Dennis,
Arkansas
> Ronnie
> To:
through:
and
the
the
> > weaker ones.
> > Dennis Engelkenjohn
Subject: | Re: Cross Country in a Piet |
Mike C. has it right when he describes X-country flying with a Pietenpol.
Flying it in smooth air is pure delight, but in turbulence it is a tiring
operation with no possibility of demonstrating any degree of flying finesse.
It's just a matter of hanging on and keeping the nose pointed where you
want to go. Maintaining a precise altitude is out of the question.
I have owned Aeronca Champs, Taylorcraft and Luscombe airplanes and they
were not much fun in rough air, either. But they all are physically bigger
and heavier than a typical Pietenpol and don't react so quickly to
turbulence. The Pietenpol is a pretty small and light airplane which doesn't
fly very fast. For its size it has a relatively large wing and is
short-coupled with fairly small fixed tail surfaces. As a result, it isn't
very stable in pitch and yaw. My Piper Vagabond has about the same wing span
as my Pietenpol and is very short-coupled. Its gross weight and wing loading
are comparable to the Piet figures, but its pitch and yaw stability are much
better---likely because of its generous (standard Cub) fixed tail surfaces.
It also flies faster (90 mph) with less tendency to "wallow". Nevertheless,
it still gives a wild ride in rough air.
Considering the age of the design, the ol' Pietenpol does pretty well and
likely it was not intended for extended X-country flying of the kind Steve,
Mike, Ted and others do. My hat is off to them regarding their perseverance
and endurance! Years ago, the late Peter Bowers dubbed it "the pasture
pilot's pride and joy", thus indicating its true mission.
Preferably, one should try to confine lightplane travel to the early morning
and evening hours in order to avoid punishing turbulence during the heat of
the day. Unfortunately, that isn't always possible.
Graham Hansen (CF-AUN)
Subject: | Two Landings Aborted |
Two summers ago there was a pot-luck fly in at an airport about 20 minutes
away. It was WINDY. A nice
day otherwise but windy. The wind was right down the runway at both
airports but it was that kind of wind
where the gusts are not rhythmic and steady but erratic and forceful every
few puffs. I had flown in similar conditions
so I headed out. What a bumpy ride over but heck, there were 10 to 12
planes on the ground and a nice crowd.
(the smart ones arrived by car) On the approach to this sod strip it was
evident that it was going to be one of those
things where if you timed it right you would touchdown during a nice steady
portion of the wind but otherwise you'd
either balloon up again or get slammed into the ground. After two really
valiant attempts to get the plane down safely
I headed home without landing. I came within about 10 feet maybe, but then
went around. Not embarrassed at all
actually, I was just disappointed I couldn't share the plane with others
and missed some good chow.
I got some razzing from a few of the guys who were there watching me try to
land but the guy who said " You did the
right thing if it didn't feel right." was the guy I consider the best pilot
of them all. Larry Minch is a long time tailwheel
pilot, CFI, etc. etc. etc.....kind of like Corky's Edwin. Lots of good
solid time under his belt and a common sense
pilot and instructor. Larry has flown my plane. He knows what it's like
in turbulence. The other guys arrived in
182's, Aeronca Sedan's Bellanca Decathlon's, and the like. It was not
worth all that hard work, money, time, and
sweat to crack it up over a pride issue.
Mike C.
Subject: | Thanks for everyone baring their soul on the turbulence |
thing
Everyone who responded gave me a new confidence in flying during the midday. Think
Graham Hansen used the best word,,,"wallow". In the wind, the Piet has kind
of a lack of total stability. Not a single problem with just roll, or just
pitch, or just yaw,,,but a rolling around like you are hanging from a big string
from above. Hard to explain, but you guys have all described different,
but the same thing.
I still like the Piet in smooth air when it flies great with my hands on the front
of the cockpit behind the windshield. Love to put my fingertips out on the
right or left, and make the plane turn for me. Even put them both out like
little wings (like you used to do in the backseat of the '62 Chevy and your arm
would pull up or down), and tip them up or down to make the whole plane climb
or dive.
Wonder if the whole thing has anything to do with the fact that it is a parasol
wing? All the planes we are comparing it to have an enclose fuse like the J3
or Aeronca. With the same wingspan we would have more lift cause of the wing
in the middle that the others are lacking. could this be a trait of the parasol
wing?
The full fuse of the J3 has got to give more yaw stability with it's full sides
than sitting in a Piet shaped like a loaf of bread.
Oh well, I'm rambling.
walt evans
NX140DL
Subject: | pilot seat and other ramblings... |
Wondering if anyone has ever had the experience of their pilot seat frame members
cracking. I'm not THAT fat (200 lbs)... I just installed the pilot seat last
week and I was sitting in it trying to get a feel for how the front seatback
would be layed out. Each time I sat, I heard a small creak. I thought maybe
it was the workbench but I figured I'd look around. Found out it was one of
the inner structural members of the seat. Didn't crack at the glue line (proof
that the glue is stronger than the wood) it split about 1/8" from the glue
line, right down the grain. What I think may be the cause is that there is so
little support for the wood at that point, other than the glue on the ply and
end grain.
So, If I remove the member, what's a good way to do it without ruining the seat.
I thought I might just pry the split section appart, apply some epoxy in the
crack and clamp together. Then add a plywood gusset beneath the back frame
member and the 4 other members, tying them all together. Any opions here?
Also, wondering if others are using T88 as filler on occassion where small gaps
in joints appear or where plywood gussets are held down. I've come accross a
few situations where the plywood, although I staple it down, leaves a small gap
(1/16" or so). Wondering if filling this void is acceptable.
And lastly, any people here fly around the West Virginia mountainous areas? I'm
planning a trip later in the summer and could use some feedback on my plans.
If so, contact me directly at tmbrant(at)usfamily.net
Thanks!
Tom Brant
Brooklyn Park, MN
I called Precision Punch & Plastic Co. this afternoon and ordered a pair
of XH56 Lamina die springs for the Piet. The price was $28.77 ea plus
$3.00 S&H and whatever UPS charges to ship them to me. The XH56 are the
heavy duty ones. They should be here mid next week or so. They will ship
them tommorrow.
Dennis Engelkenjohn
>weaker ones.
>Dennis Engelkenjohn
Thanks Dennis, I knew my memory wasn't fuzzy on this one. Anyone know how
the John Deere springs compare to the heavy-duty Lamina springs?
BTW, what types of payment does PP&P accept?
Kip Gardner
North Canton, OH
Kip & Beth Gardner wrote:
>I used a Mastercard, never asked about anything else.
>Kip Gardner
>North Canton, OH
Chords on J-3's (and yes, they used a USA 35B airfoil) were 60". I think
the Aeronca was the same chord, but don't know for sure, nor do I know what
airfoil they used. I don't think it was a Clark Y because that has a flat
bottom and a Champ wing has a slight undercamber.
Jack
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Daniel
Bailey
Subject: Pietenpol-List: Chords, aero not music
compare
Dan Bailey
Paola, KS
(Building ribs)
Dennis,
What is the rating of the XH56 springs, I believe die springs are rated at
the force in pounds needed to compress the spring 1 inch, mine are rated at
2400 lbs, but my gear is lower and wider than plans so I need a stronger
spring.
Also can anyone advise me about removing or painting over power coating? I
think my springs are power coated and they may not match the color scheme
planned.
Skip in Atlanta, just got my spokes back from Buchanan's and they look
great!
>them tommorrow.
>Dennis Engelkenjohn
From: | "Kent Hallsten" <KHallsten(at)Governair.com> |
Sandblasting was the way we did it in one shop I worked in.
Kent Hallsten
> power coating? I
> color scheme
> planned.
Hi Dennis: This post is probably too late since you have already spent
28 bucks for the die springs, but Wag Aero sells a die spring sock kit
for around $165. It has the springs, tubing, washers etc for a turnkey
weld it your self shock kit. Leon S. Hutch, Ks.
Gadd, Skip wrote:
>Dennis,
>spring.
John, at Precision Punch and Plastics said they were rated at 1650
lbs to compress 1". I am going to use the plans except for mating
Taylorcraft axles to the landing gear because they were a gift and I
can't afford to turn them down.
In one of the older BPA Newsletters were the plans for a split axle
gear using the die springs. The tubing sizes were given and I went over
to Shapiro and bought all the tubing for the die spring shock set up for
$15 last saturday. Hope to have less than $135 total in gear when done.
Not that I am trying to skimp, but if you go to Shapiro in person on
saturday morning, the guys in the cutting rooms know you and make you a
great deal.
Dennis Engelkenjohn
Subject: | Re: pilot seat and other ramblings... |
Tom,
I have sat in my seat numerous times, honestly I am test fitting not just pretending
I am flying and you have to make the airplane to get the fit just right,
and I have had no problems with it braking but I am a light weight (160 pounds),
I think you could split it apart and glue it back together if it fits together
well. If not take it out and put in a new piece. I found the best way to
remove things like this is to use a SHARP chisel, a 1" chisel is my preferred
weapon of choice. Use a small saw to to make a cut almost all the way through
the piece near both ends. You don't have to be to close say 1/4" away. Using
the chisel take the bulk of it off in large chunks but as you get closer the
the glue line slow down and take smaller slivers of wood. Now as you get close
to the ply sharpen your chisel again. Lay the back of the chisel flat on
the wood you are removing, at about a 20 degree angle. Now push it by hand don't
use a hammer. You should be taking little chunks of wood off, if not raise
the angle slightly. When you get down to nothing but glue you can usually scrape
it off with a single edge razor blade, I like the heavy duty ones for the
razor blade knifes used for cutting drywall. Also round the tips off using you
grinder so you don't gouge the plywood. This works great for cured T-88 and
I would guess it would work on other types of glue.
As for reinforcing the seat you might be able to put a support running left to
right under the 4 seat frame pieces at about mid span. support this on the ends
from the lower longerons. This may be a problem with hitting the control cables
though. Perhaps this one support was higher then the rest and took the full
load. If this true the new one should be ok because with the seat bottom installed
it will line up better.
Just my opinion, for what ever that's worth
Chris
Sacramento, CA
end grain.
Thanks!
Tom Brant
Brooklyn Park, MN
From: | Mel Martinez <melitonm(at)prodigy.net.mx> |
Subject: | Model A Engine Restoration |
Hi:
I've just received a Ford Model A engine ready to be rebuild.
I'd like to receive information about the rebuilding expec's, or a Web
link to see such information to install the engine in a Pietenpol.
Mel Martinez
San Carlos, Sonora, Mxico.
The Piet I fly sounds just like what hjasd been written. A-65 powered 31' oversize
wingspan with steel tube fuselage and monocoupe tail.
cruise and flat out are basically the same. It climbs at 2125 rpm, flat out
is 2250 rpm at 71-73 mph, and throttling back to 2200 seems to make no difference
to the speed. Climb is 300-350 fpm and I've found best climb around 58-64
mph. It's wonderful to fly in the morning or evening, and during the thermals
of the day a handful. I recently went flying about one hour after a strong system
passed over with more cumulus forming. And found it to be a white knuckle,
attention getter. 200 ft altitude bounces both wats were the norm. But the flying
in smooth calm air makes it all worth it.
I also find that landing the Piet well is a challenge. If I come in without
power, the flair must be perfect. Otherwise it will slow down instantaneously
and drop. I usually fly final at 55-60 mph with 1500 rpm right to the flair. Once
I am level in the flair power is removed fast or slow depending on how high
the flair was and the stick pulled back. I have inadvertently done some nice
wheel landings by not pulling back on the stick fast enough and it just rolled
out on the mains.
Shawn Wolk
C-FRAZ
Please see the attached file.
From: | "Oscar Zuniga" <taildrags(at)hotmail.com> |
HUBBLUGG(at)aol.com wrote-
This list doesn't accept attachments (good thing, too!) If you have
something in the way of photos, video clips, or other information to share,
post it to one of the many available sites for things like this and then
give us the URL and a description of what you've posted. I can pretty much
guarantee you that nobody in their right mind is going to willingly accept
an attachment with no description of what it is, nor will they go take a
look at a site without you indicating why they should want to go there.
Too many viruses and other bad stuff floating around out there these days.
Be specific, make it interesting, and make it easy for folks to find what
you're offering. Like this; an image of a Pietenpol fuselage in the framing
stage: http://www.flysquirrel.net/piets/pietfuse.jpg
Oscar Zuniga
San Antonio, TX
mailto: taildrags(at)hotmail.com
website at http://www.flysquirrel.net
Just received the latest issue of To Fly with a flyer for the SAA Gathering
June 13-14-15 at Urbana Illinois.
First on the list of forums is the Pietenpol forum Friday morning by Larry
Williams, I assume our own Piet list Larry Williams.
At this point the weather doesn't look VFR from Atlanta anyway the Skyhawk
will still be in annual, so I'll be driving. Looking forward to seeing
lister's and all other Pietenpol people there.
Skip in Atlanta, Map Quest says 10.5 hours from Urbana.
I was sitting here wondering about all the bolts we need to use to holding the
fittings, pulleys, and controls to the plane. Do you (I) use all drilled shank
bolts so I can safety wire them or should I use self locking bolts (the kind
with the plastic insert)? Is there certain places you should use one or the
other? It seems so simple until you need to actually buy some then that little
voice in the back of your head says "Are you sure?". So what kind of bolts
should I get? I know what length but I don't know what kind.
Chris
Sacramento, CA
The best thing to hit the internet in years - Juno SpeedBand!
Surf the web up to FIVE TIMES FASTER!
I am in the process of installing the rudder pedal in the front cockpit. On the
plans they are tilted towards the back of the plane(if you are sitting in the
front seat the tops are tilted towards you when the rudder is centered). I
was testing them out before I drilled the holes and they seemed to be awkward
to use. Has anyone on the list used the front seat ruder pedals while flying
and do you have an opinion on the way they feel when flying? I think they would
be better if they were vertical or slanted away from you. Does this make any
sense it's still early out here in California and I was up late building.
Corky what does your Test Pilot think of them?
Chris
Sacramento, CA
If one parts being held with the bolt rotates then it needs to be fastened
with a drilled bolt shank and castle nut and a cotter pin or safety wire.
If the pieces are being held together do not rotate, then a nylon lock nut
is sufficient (firewall forward excluded in some cases)
DJ Vegh
N74DV
Mesa, AZ
Subject: Pietenpol-List: Bolts
the fittings, pulleys, and controls to the plane. Do you (I) use all
drilled shank bolts so I can safety wire them or should I use self locking
bolts (the kind with the plastic insert)? Is there certain places you
should use one or the other? It seems so simple until you need to actually
buy some then that little voice in the back of your head says "Are you
sure?". So what kind of bolts should I get? I know what length but I don't
know what kind.
> Thanks
> Chris
> Sacramento, CA
Subject: | Re: Rudder Pedals |
Chris,
Mr Johnson, the test pilot, will probably pick up on your message and in time
will probably give you an answer.
Corky
From: | "Richard Navratril" <horzpool(at)goldengate.net> |
Hey all
Check out the nice Model A engine in June, Sport Aviation Pg 68. Anybody know
what that costs?
Dick
A quick word of caution: Do not, under any circumstances, use safety wire in
a cotter pin application. A cotter pin is designed to resist the shearing
action of a castellated nut against a drilled bolt shank and safety wire is
not. Use safety wire in tension applications (like where it tends to pull a
nut tighter).
Mike Hardaway
> DJ Vegh
> N74DV
> Mesa, AZ
> From: <cat_designs(at)juno.com>
> To:
> know what kind.
>> Thanks
>> Chris
>> Sacramento, CA
I should have been more clear.... I meant safety wire in a drilled bolt head to
prevent rotation.... thanks for the clarification
Sent: Friday, June 06, 2003 11:28 AM
Subject: Re: Pietenpol-List: Bolts
nut tighter).
Mike Hardaway
> DJ Vegh
> N74DV
> Mesa, AZ
> To:
> know what kind.
>> Thanks
>> Chris
>> Sacramento, CA
If you slanted them away, or even vertical, you would have to move them
back substantially from the firewall or they would hit the firewall before
you got to full rudder travel. I kind of like the original plans which
show the pedals hanging down from the cross brace at the top of the
firewall. I have asked numerous people, though, and cannot get an answer
why Bernie moved away from this system, pluses or minuses. I am just now
trying to figure out how I am going to mount my front pedals. If you come
up with any good ideas, I'd like to hear.
Gene
Original Message:
Date: Fri, 6 Jun 2003 14:58:36 GMT
Subject: Pietenpol-List: Rudder Pedals
On the plans they are tilted towards the back of the plane(if you are
sitting in the front seat the tops are tilted towards you when the rudder
is centered). I was testing them out before I drilled the holes and they
seemed to be awkward to use. Has anyone on the list used the front seat
ruder pedals while flying and do you have an opinion on the way they feel
when flying? I think they would be better if they were vertical or slanted
away from you. Does this make any sense it's still early out here in
Chris
Sacramento, CA
Gene
One thing I know I am going to due is use tubing to connect them to the rudder
bar. I think it is a much simpler installation and a more elegant looking solution.
The only problem I see with hanging them off the firewall is the firewall
is only 1/6th inch ply whereas the floor is 1/4 inch. Maybe too many firewalls
were getting broken in use. I had forgotten about this being different
then the F&G plans. Guess I will try it out tonight and see how it works.
You are correct about having to move the mounting lugs farther away from the firewall
if I slant them differently then the plans. It should not matter where
I attach them as long as I leave enough room for them to travel. One other thing,
the rudder pedal also seem to wide for my tastes. But then again I don't
plan on sitting up front very often.
Chris
Sacramento, CA
Gene
Original Message:
Chris
Sacramento, CA
Oh yah I had forgotten about the cotter pins. If I understand this right wire
for the head, pins for the castle nuts and no self locking on moving parts. Wouldn't
you only use drilled heads when you are NOT using a nut you can secure?
Such as a tapped hole or blind nut.
Chris
Sacramento, CA
nut tighter).
Mike Hardaway
> DJ Vegh
> N74DV
> Mesa, AZ
> To:
> know what kind.
>> Thanks
>> Chris
>> Sacramento, CA
It does not bolt to the firewall, but to the oak cross member, much more
strength than the 1/4" ply floor, so that cannot be the reason.
Gene
Subject: RE: Pietenpol-List: Rudder Pedals
> Gene
rudder bar. I think it is a much simpler installation and a more elegant
looking solution. The only problem I see with hanging them off the firewall
is the firewall is only 1/6th inch ply whereas the floor is 1/4 inch. Maybe
too many firewalls were getting broken in use. I had forgotten about this
being different then the F&G plans. Guess I will try it out tonight and see
how it works.
the firewall if I slant them differently then the plans. It should not
matter where I attach them as long as I leave enough room for them to
travel. One other thing, the rudder pedal also seem to wide for my tastes.
But then again I don't plan on sitting up front very often.
> Chris
> Sacramento, CA
> Gene
> Original Message:
> From: cat_designs(at)juno.com
slanted
> Chris
> Sacramento, CA
Gene,
May I make a small statement on the subject of rudder pedals.
Place the rudder bar forward for the front pilot. Put your pedals with Cessna
style brake cyl for rear pilot. Connect the two with 3/8 4130 tubing and
connect the rudder horn to the pedals with cable. Taut fit without return springs.
This is the fab I'm using for Repiet.
Corky
From: | "Jack Phillips" <pietflyr(at)bellsouth.net> |
On Mine (long fuselage version) I installed the front rudder pedals such
that they bottom out on the firewall at full rudder deflection, saving me
from having to add a stop. I used 5/16" tubing to connect them to the
rudder bar so no return springs are needed and at neutral rudder the front
rudder pedals are just about perpendicular to the floorboard. Feels fine in
my basement. We'll see how it does in the air this fall.
Jack
rambog(at)erols.com
Gene
Original Message:
Chris
Sacramento, CA
There seems to be a concern about the knobby motorcycle tires I have on my
piet.
I know most aircraft have smooth tires and it lets you slide on the grass.
But those same
smooth tires don't slide much on asphalt runways. Maybe later I will opt for
smoothys but
I think that there shouldn't be a problem with the ones I have now. I don't
plan on doing a
lot of heavy cross wind landings for a while. My early flights will be in
calm weather. And if
I do get a cross wind, I'll land like it was asphalt. I thought I would
throw this out and get a
feel for the groups opinions. Thanks as always.
Carl
check out my webpage at http://members.core.com/skycarl
Subject: | Re: enough rain already |
Hey Corky, you know it has rained wayyyy too much in 'Ol Virginia when I was
working on the Piet in my hangar today listening to the thundering rainfall
(all day) and I looked down and about a 4" crayfish was crawling across the
floor at my feet.
I'm gonna convert the Piet fuselage into an ark, might get some use out of
it.
Gene
Subject: | Re: knobby tires |
Carl
the pics of the torque tube looks almost like the
parts were brazed, not so, I hope.
Del
> piet.
> But those same
> smoothys but
> plan on doing a
> Carl
> Contributions
> any other
> Forums.
> latest messages.
> List members.
> http://www.matronics.com/subscription
> http://www.matronics.com/FAQ/Pietenpol-List.htm
Digests:http://www.matronics.com/digest/pietenpol-list
> http://www.matronics.com/photoshare
Del-New Richmond, Wi
"farmerdel(at)rocketmail.com"
Del,,, Originally,, the control tubes were brazed, then I redid them after
learning that was a no no. That was another pain in the butt lesson I
learned but the knowledge never stops on here. So what do you think
about the tire deal?
Carl
Subject: Re: Pietenpol-List: knobby tires
> Carl
> Del
> > piet.
> > But those same
> > smoothys but
> > plan on doing a
> > Carl
> > Contributions
> > any other
> > Forums.
> > latest messages.
> > List members.
I don't know the answer to that for sure, I can't
think that there would be a problem, my sonex has
treaded go cart or garden tracter style wheels on it.
and it works fine
Del
> the butt lesson I
> what do you think
> Carl
> From: "del magsam" <farmerdel(at)rocketmail.com>
> To:
> > Carl
> > Del
> Loar"
> > > piet.
> lets
> > > But those same
> runways.
> > > smoothys but
> the
> > > plan on doing a
> > > Carl
> > > Contributions
> > > any other
> > > Forums.
> > > latest messages.
> > > List members.
> Contributions
> any other
> Forums.
> latest messages.
> List members.
I don't see why knobby tires would grip any different then treaded or
smooth. Actually knobby tires grip less on asphalt then smooth tires do.
When was the last time you saw a street bike with knobby tires. You
could always cut off the knobs with a razor blade and smooth them down
with a disk sander to make smooth tires.
Chris
Sacramento, CA
I think it needs to be said again so no one else has to learn the hard
way like Carl did.
If you use 4130 steel it is prone to cracking if you braze it. Do not
braze 4130. Yes I know bike frames are built out of 4130 and they are
brazed with a lot of success but if they brake you will most likely not
be killed. Ever book on aircraft welding I found says not to braze 4130.
These same books also say you should not weld a joint that has
previously been brazed. The braze material will contaminate the molten
metal and make a weaker weld. Now, if you use 1020 steel like the plans
call for you can braze it just fine and it will be good joint. There is
nothing wrong with using 1020 steel to build an airplane as long as the
plane was designed to use it. A lot of the antique airplane are built out
of it. The only part that BHP calls out as needing to be made out of
4130, that I can find, is the rudder bar. Remember, even though most
people are using 4130 for everything IT IS A CHANGE FROM THE PLANS so you
need to due your homework on how this change will affect your building
process. And my study of this change is to weld 4130 in a draft free
area using a welding method that heats up an area of approximately one
half to one inches on each side of the weld bringing the temperature up
slowly and after welding you should allow the material to cool slowly in
a draft free area. Knowing this I choose to gas weld all my parts and
reheat the weld as well as an area around the welds to release any built
in stress. I do all me welding in my garage with the doors shut to keep
the drafts down. I'm not an expert on any of this so you should do your
May 15, 2003 - June 07, 2003
Pietenpol-Archive.digest.vol-de
