Pietenpol-Archive.digest.vol-dq
January 13, 2004 - January 25, 2004
      glad to try and send it directly to you.
          Hope all this helps.
          John Dilatush NX114D
          Salida, CO
<003a01c3da44$fa03f320$d401a8c0@Alex>
Subject: Re: Piet information list
Date: Jan 13, 2004
I have a formula that I got from Greg Cardinal somewhere around here that uses the weight of the ship level and then the weight of the ship in three point attitude, loaded, of course. It will determine the vertical CG of the ship when loaded. Maybe the math guys can come up with it faster than I can. Chris Bobka ----- Original Message ----- From: Alex Sloan To: pietenpol-list(at)matronics.com Sent: Tuesday, January 13, 2004 8:20 PM Subject: Re: Pietenpol-List: Piet information list Hank J. Good information. Can you give the math to go with the measurments? Alex S. ----- Original Message ----- From: hjarrett To: pietenpol-list(at)matronics.com Sent: Tuesday, January 13, 2004 6:05 PM Subject: Re: Pietenpol-List: Piet information list OK, I'm going to stick my nose in once more. To be useful you need to know where the contact point of the tire is in relation to the CG in a level attitude. Sorry guys but all the other measurements don't help much from a nose over point of view. The other thing that is needed is the height from the ground to the CG. With those measurements you can calculate the nose over moment and with the tail force and arm you can calculate exactly how much brake you can use verses the airspeed. That is what tells you if you are going to have a "grazer" or a tail dragger. Hank J ----- Original Message ----- From: At7000ft(at)aol.com To: pietenpol-list(at)matronics.com Sent: Tuesday, January 13, 2004 10:59 AM Subject: Re: Pietenpol-List: Piet information list Good idea Carl, one question though is what to use for a datum to measure from. Since people move their engine forward sometimes 6 -8 inches for CG I don't think that will work. Same thing with the wing leading edge, people move the wing forward and backward too. How about the front Ash floor cross strut? Rick Holland I think the questionaire on Piets is an excellent way of cataloging the variations in the airplanes. Unless I missed it, there's one addition I would like to see. When brakes are added to a Piet, some folks move the mains axis forward to reduce the tendency to nose over on heavy braking (mine have been moved forward 2.5" from the plans). We could include the dimension from prop hub to the axle....Whatta ya think?....Carl Vought ________________________________________________________________________________
Subject: Re: Landing Gear Location
Date: Jan 13, 2004
Re: Landing Gear Location ----- Original Message ----- From: Mike To: John Dilatush Sent: Tuesday, January 13, 2004 8:14 PM Subject: Re: Landing Gear Location Let's see, how about a two fuel tanks, brakes, electrical system, ELT, tailwheel with tow hook, some extra instrumentation to monitor engine performance, and the jenny gear which seems to be heavier than the split axle gear. The engine carries a 40 lb PRU too. Nothing added to the basic airframe which came out quite light in spite of 2.7 oz. covering. The engine complete with stock flywheel, alternator and starter was 222 lbs. One thing leads to another you know! Interestingly enough, in 1994 the Buckeye Pietenpol Association did weight and balance on 8 Piets at Brodhead. Those with the long fuselage averaged 742.8 lbs empty! This seems to be a long way from the empty weights being reported now by builders. Don't know what has changed? John Thanks, John. the spreadsheet came through fine. I see that you've calculated your cg positions from your empty weight and not weighed for them, which is probably what most people do. I'll do some math work later to see what your gear weighs on the scales. I notice that your empty weight is pretty high. What do you have in your bird besides that super-pooper turbo-charged Subaru engine? Mike Hardaway on 1/13/04 17:27, John Dilatush at dilatush(at)amigo.net wrote: Mike, Here is the W&B and you can see how it is normally computed for various loadings. John ________________________________________________________________________________
Date: Jan 14, 2004
In a message dated 1/13/04 7:11:56 AM Central Standard Time, Carbarvo(at)aol.com writes: << Unless I missed it, there's one addition I would like to see. When brakes are added to a Piet, some folks move the mains axis forward to reduce the tendency to nose over on heavy braking (mine have been moved forward 2.5" from the plans). We could include the dimension from prop hub to the axle....Whatta ya think? >> Carl, The datam on the Pietenpol is the firewall. I'll include you're suggestion in the 'Alterations' section of the Infomation Sheet. My split axle is in the plans location of 17" behind the firewall. I have brakes, for run up, and taxiing in tight areas - not to stop the landing roll out. If you move the axle forward, you place more weight on the tailskid / wheel, and it will not come up as quick on the take off run. Chuck Gantzer. 3 days in a row, of Piet wether !! ________________________________________________________________________________
Date: Jan 14, 2004
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
Subject: full stall vs. wheel
Group-- this is just an observation over the years--- I'm not good at wheel landings at all. I can do them, but I full stall my Piet 100 % of the time-- and after 350 hours, twice to Oshkosh and twice to Brodhead I've landed (especially at Brodhead last summer where they had the diagonal runway X-ed out) in some nasty crosswinds and never had a problem. Tons of aileron into the wind and a burst of power if you need it, but hardly ever so. Of course grass is more forgiving. I do wheel landings/touch/goes for fun on the grass on calm nights on one wheel then the other (try to be Bob Hoover in a Piet for a minute) but that's about it. Did the same in the Champ. I realize the rationale for doing wheel landings and keeping your speed up for aileron authority, etc, but if you full stall a Piet you are going slow enough on touchdown that if you have full aileron into it, keep the nose straight w/ the rudder, you won't go anywhere you don't want to. Mike C. ________________________________________________________________________________
Date: Jan 14, 2004
I have two words in reference to rough fields, big engines and good brakes: Helio Courier. It's mains are practically under the prop, and if not for the extremely slow rollout I would bet it would be very exciting to land. I hope John Dilatush will be a Brodhead this year. I really would like to see his pimped-out Piet performing like a VTOL. :-) John John Ford john(at)indstate.edu 812-237-8542 ________________________________________________________________________________
Date: Jan 14, 2004
Subject: Re: Buying spruce for AirCamper
I used to teach taildragging in a Decathalon and a Super Cub and never had an experienced pilot take over 10 hours, may want to find a different instructor. 2) I'm a private pilot with about 200 hours, now working on a tailwheel endorsement. Although my instructor says I'm "almost there," it has taken a LOT longer than I expected (over 20 hours), and this in a Citabria which sounds like it's much easier to land/take off than a Piet by all descriptions I have heard. Should low total time and a long time learning to handle a taildragger deter me from building a Pietenpol, or will this seem like a distant problem in a few years when I'm ready to fly it? ________________________________________________________________________________
Date: Jan 14, 2004
Subject: Re: wing & fabic/paint weights
Did you also need to move your wing back? Rick Holland DJ,,, I moved my corvair out 2 and a half inches and I'm sure glad I did. Besides my big butt not helping the w&b, it really gave me a little extra room from the firewall. It gets real crowded back there to boot. I know this is repetitious but don't ya just love that corvair engine? Man what a kick,,, your's really looks great. Carl ________________________________________________________________________________
Date: Jan 14, 2004
Hank - given this data how do you calibrate how hard you can press on the brakes at a given speed to avoid grazing? Rick H. OK, I'm going to stick my nose in once more. To be useful you need to know where the contact point of the tire is in relation to the CG in a level attitude. Sorry guys but all the other measurements don't help much from a nose over point of view. The other thing that is needed is the height from the ground to the CG. With those measurements you can calculate the nose over moment and with the tail force and arm you can calculate exactly how much brake you can use verses the airspeed. That is what tells you if you are going to have a "grazer" or a tail dragger. Hank J ________________________________________________________________________________
Date: Jan 14, 2004
----- Original Message ----- From: "John Ford" <Jford(at)indstate.edu> Subject: Re: Pietenpol-List: Landing Gear Location ================================== John I'll try to be at Brodhead this year if I don't sell Mountain Piet first. A word of caution however, the turbo'd engine is only useful here at high altitude where I live and fly. At sea level the plane will only perform the same as any other 110 to 135 hp powered Piet. 45 inches of manifold pressure at 10,000 feet or 100 feet produces the same hp. John ================================= > > I have two words in reference to rough fields, big engines and good > brakes: Helio Courier. It's mains are practically under the prop, and > if not for the extremely slow rollout I would bet it would be very > exciting to land. > > I hope John Dilatush will be a Brodhead this year. I really would like > to see his pimped-out Piet performing like a VTOL. :-) > John > > John Ford > john(at)indstate.edu > 812-237-8542 > > ________________________________________________________________________________
Date: Jan 14, 2004
<018b01c3da36$2e226100$d4ddf6ce@hjarrett> Don't want to profit from this, I'm too busy with the airforce, but if I can help someone and save them some $$ I certainly will. hjarrett wrote: > > > MAN! You should go into the kit parts business. Collect up and package all > the wood to build a Piet and sell for a huge profit. You would still be > beating the pants off the competition. Good deal for us and you. > Hank J > > ----- Original Message ----- > From: "dave rowe" <rowed044(at)shaw.ca> > To: > Sent: Tuesday, January 13, 2004 7:08 PM > Subject: Re: Pietenpol-List: Buying spruce for AirCamper > > > > > Silly question, but what part of the country do you live in? If you are > > in WA or Ore, you can do way better. My entire airframe cost for wood > > is under $400.00 Canadian. I should have plenty of leftover yellow > > cedar if anyone wants some for wing ribs, let me know. A local mill > > here lets me wander through and hand pick anything I want, so larger > > sizes can be had too. > > > > At7000ft(at)aol.com wrote: > > > > > > > > > Not having a lot of experience dealing with Aircraft Spruce or Wicks > (yet) I was wondering if some of you veterans would give me your opinion on > this: > > > > > > Aircraft Spruce has an AirCamper spruce kit for $804. Since Wicks has no > equivalent kit I asked AS for the kit part list, (the contents matched that > of an Excel spreadsheet I have seen posted at this site) sent the list to > Wicks and they came back with a price of $1075. Then I added up the AS > prices for the list items and came up with around $1070. The AS rep said the > $804 price is discounted because its a kit, however the lead time is 1 to 2 > months. Wicks claims a 1 weeks lead time. > > > > > > I can't believe AS is discounting spruce this much and there must be a > catch, problem is I may need to wait 2 months to find out what it is. Has > anyone else ordered this wood kit from Aircraft Spruce before? > > > > > > Thanks > > > > > > Rick Holland > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 14, 2004
Agree, sonds like some profiteering to me. ________________________________________________________________________________
Date: Jan 14, 2004
Subject: taildraggers
I personally know some tailwheel instructors are super-nit picky about signing someone off in a taildragger just because of liability reasons and that the person might be then renting that Cub or Citabria after checkout. Sometimes an instructor can be too casual and sign you off too early---case in point: A guy builds a Tailwind, gets a quickie checkout in a Cub and then on the second flight in his Tailwind he stall spins on takeoff. Saw it. Some people are just slow learners on tailwheels, others adapt more readily. The Citabria is really easy to see over the nose also like a Champ because you can fly it from the front seat. That's great for a while to get used to tailwheels, but then if you can for a Piet, ask the instructor if once you get good at the front seat if he'll let you fly from the rear seat to really see what it feels like. Course a Cub needs the pilot in the back--most models. More fodder. Mike C. ________________________________________________________________________________
Date: Jan 14, 2004
Mike, How is a stall-spin accident related to a tailwheel? Groundloop? Steve e. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael D Cuy Subject: Pietenpol-List: taildraggers I personally know some tailwheel instructors are super-nit picky about signing someone off in a taildragger just because of liability reasons and that the person might be then renting that Cub or Citabria after checkout. Sometimes an instructor can be too casual and sign you off too early---case in point: A guy builds a Tailwind, gets a quickie checkout in a Cub and then on the second flight in his Tailwind he stall spins on takeoff. Saw it. Some people are just slow learners on tailwheels, others adapt more readily. The Citabria is really easy to see over the nose also like a Champ because you can fly it from the front seat. That's great for a while to get used to tailwheels, but then if you can for a Piet, ask the instructor if once you get good at the front seat if he'll let you fly from the rear seat to really see what it feels like. Course a Cub needs the pilot in the back--most models. More fodder. Mike C. == == == == ________________________________________________________________________________
Date: Jan 14, 2004
du> >Mike, >How is a stall-spin accident related to a tailwheel? >Groundloop? >Steve e. Steve-- I guess the point is that this guy built a Wittman Tailwind and got a quickie checkout in a Cub that flies nothing like a Wittman Tailwind that he had just spend 7 years building and not flying. So he gets a tailwheel checkout and thinks he can fly anything with a tailwheel. Yikes ! I have flown a Corby Starlet and it was absolutely nothing like the Pietenpol or Champ---I mean totally different animal, but still a tailwheel airplane. Just like the back seat of a Champ or Citabria are much different than the front seats. Mike C. ________________________________________________________________________________
Date: Jan 14, 2004
I like this talk about taildraggers, as I need to get my endorsement someday. First, much more building to do. Back in my work history I spent lots of time driving forklifts, which steer from the back end. It took a little time to get used to that feeling of your butt moving before your front. But soon enough it came naturally and you can get in and out of tight spots and do things that a front steering vehicle could not do. By any chance would that help me in any way when I start training in taildraggers? Kent ________________________________________________________________________________
Date: Jan 14, 2004
From: Clif Dawson <cdawson5854(at)shaw.ca> (by way of Matt Dralle <nospam(at)matronics.com>)
Subject: Your local aircraft service centre (???)
The case for auto engines. At least here in Canada e513035.JPG Parts and maintenance for your CAM can be found at your local <http://www.firewall.ca/faq.htm#Question14>auto service centre. ________________________________________________________________________________
Date: Jan 14, 2004
Ok I understand the point and agree. Just didn't want it to get attributed to just being a Tailwheel airplane. Steve Eldredge -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael D Cuy Subject: RE: Pietenpol-List: taildraggers >Mike, >How is a stall-spin accident related to a tailwheel? >Groundloop? >Steve e. Steve-- I guess the point is that this guy built a Wittman Tailwind and got a quickie checkout in a Cub that flies nothing like a Wittman Tailwind that he had just spend 7 years building and not flying. So he gets a tailwheel checkout and thinks he can fly anything with a tailwheel. Yikes ! I have flown a Corby Starlet and it was absolutely nothing like the Pietenpol or Champ---I mean totally different animal, but still a tailwheel airplane. Just like the back seat of a Champ or Citabria are much different than the front seats. Mike C. == == == == ________________________________________________________________________________
Date: Jan 14, 2004
Subject: Re: taildraggers
Very good point Mike. If you are going to fly a tamdem/taildragger you really need a Rear Seat checkout (with a front seat passenger with a big fat head) AND a taildragger checkout. I don't recall if I always had a taildragger checkout student fly some time from the back seat with me in the front. Rick H > The Citabria is really easy to see over the nose also like a Champ because > you can fly it from the front seat. That's great for a while to get used > to tailwheels, but then if you can for a Piet, ask the instructor if once > you get good at the front seat if he'll let you fly from the rear seat to > really see what it feels like. Course a Cub needs the > pilot in the > back--most models. > More fodder. ________________________________________________________________________________
Date: Jan 14, 2004
Rick H-----I had zero tailwheel time and bought 1/2 interest in a Champ with my older buddy from church. (he had many hours from the 1950's when I wasn't even around) The insurance required that I get 15 hours dual in the plane before I was legal to go solo. I had a friend who was happy to help me out for pizza and dinner now and then plus fuel and oil but we got bored after about 8-10 hours so he put in in the back seat and said, "ok.....now let's see what you are made of." We worked off of grass strips at first and in fairly calm winds and then he worked me up to winds, then finally winds with in the back seat. The door removed from a Champ (it's fine to fly it like that) is wonderful !!! (it also makes landings easier because like in the Piet your side vision is pretty wide open which helps keep you in line. Walt E. , Steve E. and others can attest to this---when I have a front passenger I ask them to either shift their shoulders to the far right or far left side of the fuselage. They don't have to duck down, just move some shoulder out of my line of sight and it does make short final and flare out more accurate. Sure helps with a broad shouldered passenger. Mike C. ________________________________________________________________________________
Date: Jan 14, 2004
Mike, good suggestion! I'll try that. walt evans NX140DL ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: Re: Pietenpol-List: taildraggers > Walt E. , Steve E. and others can attest to this---when I have a front > passenger I ask them to either shift their shoulders to the far right or > far left side of the fuselage. They don't have to duck down, just move > some shoulder out of my line of sight and it does make short final and > flare out more accurate. Sure helps with a broad shouldered passenger. > > Mike C. > > ________________________________________________________________________________
From: "Richard Navratil" <horzpool(at)goldengate.net>
Date: Jan 14, 2004
I wouldn't worry about a bit too much instruction. When you send in your insurance application for your new Piet you will be dollars ahead with more than 25 hours in type. Dick N. ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: Pietenpol-List: taildraggers > > I personally know some tailwheel instructors are super-nit picky about > signing someone off in a taildragger just because of liability reasons and > that the person might be then renting that Cub or Citabria after > checkout. Sometimes an instructor can be too casual and sign you off too > early---case in point: A guy builds a Tailwind, gets a quickie checkout in > a Cub and then on the second flight in his Tailwind he stall spins on > takeoff. Saw it. Some people are just slow learners on tailwheels, > others adapt more readily. > The Citabria is really easy to see over the nose also like a Champ because > you can fly it from the front seat. That's great for a while to get used > to tailwheels, but then if you can for a Piet, ask the instructor if once > you get good at the front seat if he'll let you fly from the rear seat to > really see what it feels like. Course a Cub needs the pilot in the > back--most models. > More fodder. > > Mike C. > > ________________________________________________________________________________
Date: Jan 14, 2004
From: Dave and Connie <dmatthe1(at)rochester.rr.com>
<5.1.1.5.2.20040114114142.01761778(at)popserve.grc.nasa.gov> When I bought the Taylorcraft the insurance folks wanted 15 hours of dual for someone with 65 hours total and all of that in a 150. The first takeoff looked like a drunk weaving down the runway. We decided that I should yank it off the ground before I hit any lights. The last few hours consisted of lots of laughing in the headsets as we flew into every farmer strip around here. Dave N36078 '41 BC-12-65 --- ________________________________________________________________________________
<6.0.0.22.1.20040114194025.01dc8898@pop-server.rochester.rr.com>
Date: Jan 14, 2004
Love it.... So cool eh Dave? Now, don't you think the wing section would make a good Piet airfoil? Weav ----- Original Message ----- From: "Dave and Connie" <dmatthe1(at)rochester.rr.com> Subject: RE: Pietenpol-List: taildraggers > When I bought the Taylorcraft the insurance folks wanted 15 hours of dual > for someone with 65 hours total and all of that in a 150. The first > takeoff looked like a drunk weaving down the runway. We decided that I > should yank it off the ground before I hit any lights. The last few hours > consisted of lots of laughing in the headsets as we flew into every farmer > strip around here. > > Dave > N36078 '41 BC-12-65 > ________________________________________________________________________________
Date: Jan 14, 2004
I think the key is to get a tricycle and peddle it around the neighborhood while sitting backwards. Make airplane noises while you do it, what the hell most people think we're nuts anyway!! Seriously, experience is the key, and practice, practice, practice. I never do the same type of landing or take-off twice, I always work on short-field, soft-field, etc. every time I fly. I still draw lines on maps and figure wind vectors too. Anything to keep my skills as sharp as possible, and gives me the excuse to fly as often as my wallet allows until the Piet takes to the skies. Kent Hallsten wrote: > > > I like this talk about taildraggers, as I need to get my endorsement someday. First, much more building to do. > > Back in my work history I spent lots of time driving forklifts, which steer from the back end. It took a little time to get used to that feeling of your butt moving before your front. But soon enough it came naturally and you can get in and out of tight spots and do things that a front steering vehicle could not do. > > By any chance would that help me in any way when I start training in taildraggers? > > Kent > > > > > > > ________________________________________________________________________________
Date: Jan 14, 2004
Subject: Re: Your local aircraft service centre (???)
I LOVE IT!! Yes I'm yelling. I just read the biggest auto-conversion bashing session I've ever seen on the Thorp newsgroup. They feel if it's not Lycoming, it shouldn't be in an aircraft. They also seem to firmly believe that horzontally-opposed air-cooled engines are the be all and end all. Guess that old Rolls-Royce Merlin was a big hunk of crap! Bombardier better stop their V-6 development!! "Clif Dawson (by way of Matt Dralle )" wrote: > > The case for auto engines. > At least here in Canada > > e513035.JPG > > Parts and maintenance for your CAM can be found at your local > <http://www.firewall.ca/faq.htm#Question14>auto service centre. > > [Image] ________________________________________________________________________________
Date: Jan 14, 2004
When the time comes, I'll have to see if my 28 hours in a J-3 are still "useful" (in addition to getting some more current taildragger time!) My first solo was a long time ago! ;-) Mike C. Pretty Prairie, KS --- Original Message ----- From: "Richard Navratil" <horzpool(at)goldengate.net> Subject: Re: Pietenpol-List: taildraggers > > I wouldn't worry about a bit too much instruction. When you send in your > insurance application for your new Piet you will be dollars ahead with more > than 25 hours in type. > Dick N. ________________________________________________________________________________
Date: Jan 14, 2004
My old copy (1965) of "Practical Lightplane Design & Construction" by Bill Fike listed the average landing angle as being 12 to 14 degrees -- with the fuselage level, the wheel axle was in-line with the leading edge of the wing (16 degrees down & forward of the CG point) -- for a "cub" like airplane with brakes. Mike C. Pretty Prairie, KS ----- Original Message ----- From: Christian Bobka To: pietenpol-list(at)matronics.com Sent: Tuesday, January 13, 2004 8:51 PM Subject: Re: Pietenpol-List: Landing Gear Location To clarify John's post below, the 16.5 degree angle is with the tail up and the ship level fore and aft using the top longerons at the cockpit for leveling. chris bobka ----- Original Message ----- From: John Dilatush To: Pietenpol-list(at)matronics.com Sent: Tuesday, January 13, 2004 12:46 PM Subject: Pietenpol-List: Landing Gear Location ----- Original Message ----- From: At7000ft(at)aol.com To: pietenpol-list(at)matronics.com Sent: Tuesday, January 13, 2004 8:59 AM Subject: Re: Pietenpol-List: Piet information list Pieters, The proper location of the landing gear ground contact point is determined by the CG of the plane. The CG of the entire plane is a combination of the horizontal and vertical centers of gravity. From this point a line may be drawn to the ground contact point of the landing gear. The angle of this line is usually 16.5 degrees forward from the vertical if the plane is equiped with brakes, somewhat less if the plane has no brakes. It might be neccessary to increase this angle if the thrust line is high, so as to prevent nose over during run up and rough field operation. However, the heavier the tail load is, the more of a tendency for ground looping upon landing. On "Mountain Piet" this angle is about 12 degrees and this seems to work out OK, both for rough fields and no ground looping tendencies. The brakes won't hold the plane during run up, so this is not an issue. My tailwheel weight when the plane is leveled up is only about 9 lbs. I had attached the spreadsheet used for my plane, however it was too large for Matronics to accept, so it was bounced. If anyone is interested, I'll be glad to try and send it directly to you. Hope all this helps. John Dilatush NX114D Salida, CO ________________________________________________________________________________
Date: Jan 14, 2004
awwww come on! you used headsets in a Tcraft?!!! :-) DJ Vegh N74DV Mesa, AZ www.imagedv.com/aircamper ----- Original Message ----- From: "Dave and Connie" <dmatthe1(at)rochester.rr.com> Subject: RE: Pietenpol-List: taildraggers > When I bought the Taylorcraft the insurance folks wanted 15 hours of dual > for someone with 65 hours total and all of that in a 150. The first > takeoff looked like a drunk weaving down the runway. We decided that I > should yank it off the ground before I hit any lights. The last few hours > consisted of lots of laughing in the headsets as we flew into every farmer > strip around here. > > Dave > N36078 '41 BC-12-65 > ---- > > --- > ________________________________________________________________________________
Date: Jan 14, 2004
Subject: Engine mount and tailfeathers
Hello to all: My project is coming right along. The engine mount is welded straight, in other words no one inch down and no half to one inch right or left. We are using a cont. 75 HP. Should I mount the vertical tail fin an inch or so over to one side or is it worth messing with? Also do I need to have more incidence in the left wing to compensate for torque and P factor? Any constructive criticisms are welcome. I have seen them all ways. Let the debates begin... Thanks in advance, Max L. Davis Arlington Tx ________________________________________________________________________________
Date: Jan 14, 2004
I learned to fly (as much as I have 70 hours) in a PA12 sitting in the back seat plus some Cornell 18 hrs & Harvard 7hrs all dual time in the back seat. Had a lesson sitting in the front of a Citabria and found it harder as being on the axis of the yaw deviations from straight ahaead aren't picked up "by the seat of the pants" quite as soon. John Mc ________________________________________________________________________________
Subject: Re: Engine mount and tailfeathers
Date: Jan 15, 2004
My A-65 powered Piet has the top of the engine mount 1" longer at top. This was done by spacers at the engine mount/firewall. (1" bottom, 2"top) The tail isn't a standard Piet design or mount, but it's offset approx. 3/4" and its not enough. So a small trim tab was added to the rudder to compensate. The one piece wing was rigged with identical incidence on both sides. The tips have approx. 1.25" of wash. (this was measured in inches using an incidence jig) The plane will fly with the ball in the center for a long time in stable air. For you cold weather pilots out there. A pic of my Pietenpol won me a hat today on http://www.avweb.com . You just have to bundle up a bit to enjoy it. (it was mild, only -10C) It flew great on skis, and the air was smooth. Shawn Wolk C-FRAZ 1932 Pietenpol Aircamper C-GZOT Skyhopper 2 ________________________________________________________________________________
Subject: airfoils
Date: Jan 15, 2004
Weav wrote- >Now, don't you think the wing section [23012] would make a good Piet >airfoil? This airfoil has gotten kicked around quite a bit on the KRNet, in discussing it as a possible good one for KRs. The crux of the discussion was that the wing has an abrupt stall characteristic, as seen by the sharp break in the lift coefficient curve. Some of this effect can be moderated by using wing washout so the stall progresses from root to tip rather than having the whole wing stop flying at once, but that complicates the wing rigging and decreases the wing efficiency. The EAA Biplane uses this airfoil, so does the T'Craft, the Beech Bonanza, and a host of others... but there are ones with better stall characteristics. It sure would be interesting to get the Piet airfoil tested in a wind tunnel and get some characteristic curves to study! But until then, there will always be hangar discussions about possible airfoils, won't there? Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net Learn how to choose, serve, and enjoy wine at Wine @ MSN. http://wine.msn.com/ ________________________________________________________________________________
Date: Jan 15, 2004
Really, back in my day we just screamed and yelled at each other. Rick H awwww come on! you used headsets in a Tcraft?!!! :-) ________________________________________________________________________________
Subject: corvair engine gripe
Date: Jan 15, 2004
Last night, I was trying to clean up the garage a bit and the plan was to remove all the cooling tin from the Corvair engines I just got so they would neatly fit into the corner. Just to pull the tins off, I used every wrench from 1/4" to 5/8", it was nuts! I've pulled whole engines apart with less wrenches. Anyway, I was going to snap a picture of the cute little buggers lined up in the corner and attach it, but that may be just silly. Also, the question periodically arises about where a person should start an airplane project. The following is a section taken from an email that I sent to another gentleman, here are my thoughts: My opinion is that you should start with the engine first. Some people say the tail feathers or the wing ribs, and it's too easy to quit after just building those. I think it would be hard to futz around for a few years building inexpensive parts, and then try to justify the most expensive component on the aircraft. If you are willing to build the engine first, build a test stand, strap on a prop, and run the damn thing, just the presence of that assembly in the shop would provide the pressure to continue. Additionally, the engine complete won't consume anywhere near the floorspace as it sits and waits for the completion of the rest of the project, unlike a set of wings or a fuselage. Robert Haines Du Quoin, Illinois ________________________________________________________________________________
Subject: Re: corvair engine gripe
Date: Jan 15, 2004
I somewhat agree with the logic of building the engine first. I did not do it that way myself but I did build the engine pretty early in the project. I'm about 50% done with the airframe and I just finished my engine. Here's my logic and why I did it that way. Start with something small... ribs or rudder, etc. and get a feel for how to work with the materials. Them move onto the fuse. Get the fuse up on the wheels. By this point you have probably been working on the project for about a year or so and are probably in the downward swing of motivation (like I was). THEN build yourself the engine! It takes a couple months to get it done but when your done and you have fired that baby up you are pumped and overflowing with massive amounts of motivation. Building the engine is a rejuvinating experience. It will pull you right out of that slump that you seem to get in at the 50% mark. I haven't seriously touched my airframe for months and months. I built my Corvair back in September-November and now I'm juiced and going strong on the airframe again. In fact I'm hoping to have continuity to the elevators and rudder in the next week and then it's time for wings. You could build the engine first but I think after it sitting in the shop for a couple years it would loose it's luster and exitement factor. DJ ----- Original Message ----- From: Robert Haines Subject: Pietenpol-List: corvair engine gripe Last night, I was trying to clean up the garage a bit and the plan was to remove all the cooling tin from the Corvair engines I just got so they would neatly fit into the corner. Just to pull the tins off, I used every wrench from 1/4" to 5/8", it was nuts! I've pulled whole engines apart with less wrenches. Anyway, I was going to snap a picture of the cute little buggers lined up in the corner and attach it, but that may be just silly. Also, the question periodically arises about where a person should start an airplane project. The following is a section taken from an email that I sent to another gentleman, here are my thoughts: My opinion is that you should start with the engine first. Some people say the tail feathers or the wing ribs, and it's too easy to quit after just building those. I think it would be hard to futz around for a few years building inexpensive parts, and then try to justify the most expensive component on the aircraft. If you are willing to build the engine first, build a test stand, strap on a prop, and run the damn thing, just the presence of that assembly in the shop would provide the pressure to continue. Additionally, the engine complete won't consume anywhere near the floorspace as it sits and waits for the completion of the rest of the project, unlike a set of wings or a fuselage. Robert Haines Du Quoin, Illinois = This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>. ________________________________________________________________________________
Date: Jan 15, 2004
Subject: Headsets - intercom
On the subject of headsets... About 6 months ago, I bought a used pair of headsets with a portable 9v battery powered DC intercom system with plans to use the system in the open cockpit Piet whenever its finished. I have since started flying quite a bit in my father-in-law's T-craft BC-65. Most of my flights are buddy rides (whenever the president is not vacationing at the Crawford Ranch) and I spend a lot of flights training my father-in-law, who has yet to solo. Though I am not a CFI, I am helping him with the basic skills so that whenever he finds a tailwheel instructor he'll be ahead of the game. Anyway, the headsets are GREAT for that purpose. We have no radio, so the headsets are strictly used to talk between ourselves. Wow - what a difference. I have a lot of hours flying in old airplanes without headsets. At times, I have literally become horse trying to communicate with my passengers. Headsets change all that. It is especially gratifying to actually interact with my kids when taking them up for sightseeing. Its a whole bunch better than yelling at them. They get enough of that from me at home. Anyway, I am also looking forward to teaching them to fly in a few years. The headsets and intercom are the way to go. One adverse effect though, is that it took me quite a while to get used to flying with headsets on. They do a good job of dampening noise. But this can be detrimental if you are like me and rely on all of your senses to fly the airplane. Our airstrip is short with obstacles at both ends and sometimes (hot calm weather) it can be tricky to land the Taylorcraft there. As much as the T-craft floats, side slipping all the way to flare is a must at our place. You have to have the flare speed nailed just right or you'll float all the way down the strip. I found that whenever I am having difficulty with this technique it is best to go around and lose the headsets. I am used to them now and hardly notice them. Still, sometimes I am able to make better landings when I toss the headsets so I am able to listen to the wind noise on short final thru flare. I guess I am a seat of the pants kind of guy. Terry L. Bowden Trapped inside the Crawford TFR for the past 2 weekends...looking forward to flying this weekend if the weather clears. ________________________________________________________________________________
Date: Jan 15, 2004
It doesen't matter where you start...just GET CRACKING! As in my case...I need to KEEP CRACKING! Terry L. Bowden ________________________________________________________________________________
Date: Jan 15, 2004
Subject: Re: FW: 6 peteskis
Corky has been in the hospital for 3 days for tests. We hope he may be home in a couple of days. Isablcorky ________________________________________________________________________________
Date: Jan 15, 2004
Subject: Re: airfoils
Corky has been in the hospital for 3 days for tests as his left leg seems to go to sleep so I am going in today at 11:30 to check the test results. He feels fine but is staying in bed. Isablcorky @aol.com--his wife at home at this time. ________________________________________________________________________________
Date: Jan 15, 2004
The reason I like the 23012 section is less drag with plenty of lift. Nasty stall characteristics??? I don't think so. It's a forgiving airfoil that slides through the air easier than most. What's with all the graphs and curves anyway? How about good old practical flying? Besides, what do you want anyway? A faster airplane or one that "Stalls Better"? Weav ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Subject: Pietenpol-List: airfoils > > Weav wrote- > > >Now, don't you think the wing section [23012] would make a good Piet > >airfoil? > > This airfoil has gotten kicked around quite a bit on the KRNet, in > discussing it as a possible good one for KRs. The crux of the discussion > was that the wing has an abrupt stall characteristic, as seen by the sharp > break in the lift coefficient curve. Some of this effect can be moderated > by using wing washout so the stall progresses from root to tip rather than > having the whole wing stop flying at once, but that complicates the wing > rigging and decreases the wing efficiency. The EAA Biplane uses this > airfoil, so does the T'Craft, the Beech Bonanza, and a host of others... but > there are ones with better stall characteristics. > > It sure would be interesting to get the Piet airfoil tested in a wind tunnel > and get some characteristic curves to study! But until then, there will > always be hangar discussions about possible airfoils, won't there? > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > _________________________________________________________________ > Learn how to choose, serve, and enjoy wine at Wine @ MSN. > http://wine.msn.com/ > > ________________________________________________________________________________
Date: Jan 15, 2004
A few points: 1) I did unusual attitude/upset recovery training in a Super Decathlon, and the instructor pointed out that with 180 hp it was actually easier to land/takeoff than a lower-powered taildragger. I wasn't going for a tailwheel endorsement at the time, but landing it just didn't seem all that hard, either. 2) For some reason, wheel landings have come much easier to me than 3 point, proceeding well even under what the instructor called "very challenging" wind conditions at times. I had a tough time earlier on with the gradual pulling back on the stick for the 3 point. 3) The FBO lost a Citabria to a renter last September when a parked Mustang got in the way of a particularly low go-around (after the second bounce); the right wheel caught the driver's side window and pulled the car over on its side, with the plane sticking up like it had been planted in the car. Pilot and nephew allegedly walked away, but the plane was sold to someone in Indiana. 4) Don't know if I'll EVER get the endorsement, but the instructor, an ex-sky-writer, is simply one of the best I've ever had and I learn knew tricks with every lesson--we've landed and taken off from an uphill grass strip that can barely be seen from pattern altitude, in serious cross-winds on a short paved strip between a river, some woods, and a hill at the departure end, and numerous other small adventures that have made it worthwhile to me considering my relatively low time. Thank you all for the comments on the list in the past couple of days, Mark Hodgson ________________________________________________________________________________
Subject: Corvair trip to AL & Scanned Piet Article...
Date: Jan 15, 2004
First, that trip I was going to make to Alabama to pick up Corvair parts is off. Never heard from the guy.....(Robert must have cleaned him out!!!) In the meantime, I received 3 good leads for 110's after one email to the local Corvair club. Ain't technology grand! I've found one, but also followed up on the others for the sake of several of you that asked me to check on bringing something back from Alabama for them. I'll let you know when/if I hear back from these others...... I just scanned and posted an article from the May 1956 issue of Experimenter. (Another cool benefit of having an old timer for a tech counselor, especially one that has saved every EAA Experimenter/Sport Aviation/etc publication from the beginning....and has a Corvair 110 in his garage waiting for a home.) Anyway, this article has several pages of interesting Pietenpol info - plus a note from Bernard Pietenpol....interesting reading. <http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID184> If anyone wants the larger file versions (mykitplane reduces the size of files to a more manageable web site size), just let me know and I'll email direct..... Jim in Plano......working on one of the most important parts of my successful Pietenpol completion......my wife's new kitchen cabinets..... ________________________________________________________________________________
Date: Jan 15, 2004
Subject: Shawn on skis
Great photo in AvWeb Shawn !!! Congratulations. Stay warm up thar in Canada, Mike C. PS: For those who missed this photo, go the way to the bottom and look for the yeller Piet climbing out on snow skis. ________________________________________________________________________________
Date: Jan 15, 2004
Subject: Re: Tailwheel training, was : Buying spruce for AirCamper
I have taken Tailwheel training in a 65 horsepower Cessna 120 and a 150 horsepower Cessna 152 Texas Taildragger at different times (and states), and have not yet gotten my TW endorsement. Most of the 65 horse training involved a narrow gravel road Southwest of Odessa, Texas, and the 150 horse training on a paved runway in Indiana. The 65 horses didn't require much compensation for torque or gyroscopics when raising the tail, whereas the 150 horses required a great deal of compensation. That said (or typed, as it were), 150 horses in a small plane gets you off the ground before you can say "runway lights." I never had any problems with 3-point landings, even in gusty crosswind conditions and could even do them as well as some of my instructors (I'm low time, but apparently it's the single thing I "get" and can do well in a airplane), but I never could stick a wheel landing without excessive speed, regardless of weight or horsepower. It is easier to get out of trouble (i.e. back in the air with a positive rate of climb) with more horsepower, but things seem to be a lot more graceful with less. Having said all that, for me it's still a tossup between a Model A, a Continental 65 or 85 or a Corvair. I am pretty sure budget will be the determining factor and I'll love whatever I get and pine for whatever I don't... John John Ford john(at)indstate.edu 812-237-8542 >>> mhodgson(at)bu.edu Thursday, January 15, 2004 12:19:56 PM >>> A few points: 1) I did unusual attitude/upset recovery training in a Super Decathlon, and the instructor pointed out that with 180 hp it was actually easier to land/takeoff than a lower-powered taildragger. I wasn't going for a tailwheel endorsement at the time, but landing it just didn't seem all that hard, either. 2) For some reason, wheel landings have come much easier to me than 3 point, proceeding well even under what the instructor called "very challenging" wind conditions at times. I had a tough time earlier on with the gradual pulling back on the stick for the 3 point. 3) etc..... ________________________________________________________________________________
Date: Jan 15, 2004
Max, Your P factor will be more pronounced with the engine not tipped down . walt evans NX140DL ----- Original Message ----- From: Andimaxd(at)aol.com To: pietenpol-list(at)matronics.com Sent: Wednesday, January 14, 2004 10:12 PM Subject: Pietenpol-List: Engine mount and tailfeathers Hello to all: My project is coming right along. The engine mount is welded straight, in other words no one inch down and no half to one inch right or left. We are using a cont. 75 HP. Should I mount the vertical tail fin an inch or so over to one side or is it worth messing with? Also do I need to have more incidence in the left wing to compensate for torque and P factor? Any constructive criticisms are welcome. I have seen them all ways. Let the debates begin... Thanks in advance, Max L. Davis Arlington Tx ________________________________________________________________________________
Date: Jan 15, 2004
For whoever asked, the stall spin on takeoff is related to horsing the ship off the ground before reaching flying airspeed. A little side slip and a snaproll ensues. I have done it with R/C ships. A weak tailwheel pilot, when about to lose control on the ground, will try to horse it off into the air where control is assumed to be available when in fact it is not, hence the relation to stall spin accidents with inadequately trained tailwheel pilots. Chris Bobka ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: Pietenpol-List: taildraggers > > > I personally know some tailwheel instructors are super-nit picky about > signing someone off in a taildragger just because of liability reasons and > that the person might be then renting that Cub or Citabria after > checkout. Sometimes an instructor can be too casual and sign you off too > early---case in point: A guy builds a Tailwind, gets a quickie checkout in > a Cub and then on the second flight in his Tailwind he stall spins on > takeoff. Saw it. Some people are just slow learners on tailwheels, > others adapt more readily. > The Citabria is really easy to see over the nose also like a Champ because > you can fly it from the front seat. That's great for a while to get used > to tailwheels, but then if you can for a Piet, ask the instructor if once > you get good at the front seat if he'll let you fly from the rear seat to > really see what it feels like. Course a Cub needs the pilot in the > back--most models. > More fodder. > > Mike C. > > ________________________________________________________________________________
Date: Jan 15, 2004
Rick,,, yes I did,, about three and half inches back if I recall correctly. but that's a piet,,, gn doesn't have that luxury. It's nice to be able to do,, really makes a difference Carl ----- Original Message ----- From: At7000ft(at)aol.com To: pietenpol-list(at)matronics.com Sent: Wednesday, January 14, 2004 9:12 AM Subject: Re: Pietenpol-List: wing & fabic/paint weights Did you also need to move your wing back? Rick Holland DJ,,, I moved my corvair out 2 and a half inches and I'm sure glad I did. Besides my big butt not helping the w&b, it really gave me a little extra room from the firewall. It gets real crowded back there to boot. I know this is repetitious but don't ya just love that corvair engine? Man what a kick,,, your's really looks great. Carl ________________________________________________________________________________
Date: Jan 15, 2004
You can tell Corky that the problem with his leg falling asleep during the day is that it is then up all night! Chris Bobka ----- Original Message ----- From: Isablcorky(at)aol.com To: pietenpol-list(at)matronics.com Sent: Thursday, January 15, 2004 10:58 AM Subject: Re: Pietenpol-List: airfoils Corky has been in the hospital for 3 days for tests as his left leg seems to go to sleep so I am going in today at 11:30 to check the test results. He feels fine but is staying in bed. Isablcorky @aol.com--his wife at home at this time. ________________________________________________________________________________
for AirCamper
Date: Jan 15, 2004
John, Making a first flight in a brand new RV-3 with 150 horses up front was a real kick. I had 2 hours total of trail dragger time when I did it and the landing was the best I ever made before or since. That was 1983. Since I have 500+ hours of tail wheel time in the RV-3 and then an RV-6. Only way to. Alex S. ----- Original Message ----- From: "John Ford" <Jford(at)indstate.edu> Subject: Pietenpol-List: Re: Tailwheel training, was : Buying spruce for AirCamper > > I have taken Tailwheel training in a 65 horsepower Cessna 120 and a 150 > horsepower Cessna 152 Texas Taildragger at different times (and states), > and have not yet gotten my TW endorsement. Most of the 65 horse > training involved a narrow gravel road Southwest of Odessa, Texas, and > the 150 horse training on a paved runway in Indiana. The 65 horses > didn't require much compensation for torque or gyroscopics when raising > the tail, whereas the 150 horses required a great deal of compensation. > That said (or typed, as it were), 150 horses in a small plane gets you > off the ground before you can say "runway lights." I never had any > problems with 3-point landings, even in gusty crosswind conditions and > could even do them as well as some of my instructors (I'm low time, but > apparently it's the single thing I "get" and can do well in a airplane), > but I never could stick a wheel landing without excessive speed, > regardless of weight or horsepower. It is easier to get out of trouble > (i.e. back in the air with a positive rate of climb) with more > horsepower, but things seem to be a lot more graceful with less. Having > said all that, for me it's still a tossup between a Model A, a > Continental 65 or 85 or a Corvair. I am pretty sure budget will be the > determining factor and I'll love whatever I get and pine for whatever I > don't... > John > > John Ford > john(at)indstate.edu > 812-237-8542 > > > >>> mhodgson(at)bu.edu Thursday, January 15, 2004 12:19:56 PM >>> > > > A few points: > 1) I did unusual attitude/upset recovery training in a Super > Decathlon, and the instructor pointed out that with 180 hp it was > actually easier to land/takeoff than a lower-powered taildragger. I > wasn't going for a tailwheel endorsement at the time, but landing it > just didn't seem all that hard, either. > 2) For some reason, wheel landings have come much easier to me > than > 3 point, proceeding well even under what the instructor called "very > challenging" wind conditions at times. I had a tough time earlier on > with the gradual pulling back on the stick for the 3 point. > 3) etc..... > > ________________________________________________________________________________
<002801c3db0c$21e126c0$57c5fea9@mke>
Date: Jan 15, 2004
Mike, I am having a lot of confusion trying to understand this angle thing. 12-14 degrees measured from where to where? I know how to find the C.G. horzontally but this vertical C.G. point is new to me. Can you clarify this point? Alex Sloan alexms1(at)bellsouth.net ----- Original Message ----- From: Michael Conkling To: pietenpol-list(at)matronics.com Sent: Wednesday, January 14, 2004 7:49 PM Subject: Re: Pietenpol-List: Landing Gear Location My old copy (1965) of "Practical Lightplane Design & Construction" by Bill Fike listed the average landing angle as being 12 to 14 degrees -- with the fuselage level, the wheel axle was in-line with the leading edge of the wing (16 degrees down & forward of the CG point) -- for a "cub" like airplane with brakes. Mike C. Pretty Prairie, KS ----- Original Message ----- From: Christian Bobka To: pietenpol-list(at)matronics.com Sent: Tuesday, January 13, 2004 8:51 PM Subject: Re: Pietenpol-List: Landing Gear Location To clarify John's post below, the 16.5 degree angle is with the tail up and the ship level fore and aft using the top longerons at the cockpit for leveling. chris bobka ----- Original Message ----- From: John Dilatush To: Pietenpol-list(at)matronics.com Sent: Tuesday, January 13, 2004 12:46 PM Subject: Pietenpol-List: Landing Gear Location ----- Original Message ----- From: At7000ft(at)aol.com To: pietenpol-list(at)matronics.com Sent: Tuesday, January 13, 2004 8:59 AM Subject: Re: Pietenpol-List: Piet information list Pieters, The proper location of the landing gear ground contact point is determined by the CG of the plane. The CG of the entire plane is a combination of the horizontal and vertical centers of gravity. From this point a line may be drawn to the ground contact point of the landing gear. The angle of this line is usually 16.5 degrees forward from the vertical if the plane is equiped with brakes, somewhat less if the plane has no brakes. It might be neccessary to increase this angle if the thrust line is high, so as to prevent nose over during run up and rough field operation. However, the heavier the tail load is, the more of a tendency for ground looping upon landing. On "Mountain Piet" this angle is about 12 degrees and this seems to work out OK, both for rough fields and no ground looping tendencies. The brakes won't hold the plane during run up, so this is not an issue. My tailwheel weight when the plane is leveled up is only about 9 lbs. I had attached the spreadsheet used for my plane, however it was too large for Matronics to accept, so it was bounced. If anyone is interested, I'll be glad to try and send it directly to you. Hope all this helps. John Dilatush NX114D Salida, CO ________________________________________________________________________________
Date: Jan 15, 2004
Isabel - Thanks for letting us know. I hope that he is OK; please keep us updated! I'll add him to our prayer list. Craig Wilcox Lake Worth, FL ----- Original Message ----- From: Isablcorky(at)aol.com To: pietenpol-list(at)matronics.com Sent: Thursday, January 15, 2004 11:49 AM Subject: Re: Pietenpol-List: FW: 6 peteskis Corky has been in the hospital for 3 days for tests. We hope he may be home in a couple of days. Isablcorky ________________________________________________________________________________
Date: Jan 15, 2004
One concern about building an engine and then letting it sit in a shop for months is corrosion. For anyone who wishes to do this, please read up on the processes required to properly store a motor, is would really suck to bolt it on your new airplane, only to find it totally seized, and requiring a complete overhaul!!! barnstmr(at)aol.com wrote: > > > It doesen't matter where you start...just GET CRACKING! > > As in my case...I need to KEEP CRACKING! > > Terry L. Bowden > > > > > > > ________________________________________________________________________________
<002801c3db0c$21e126c0$57c5fea9@mke> <005e01c3dbbe$1a2f9120$d401a8c0@Alex>
Date: Jan 15, 2004
Alex, The 12-14 degrees would be measured between the upper longeron line and the ground line -- it's the angle your planes sits at when it in 3-point position. Vertical CG can be done the same as horizontal CG -- use the upper longeron as datum & use the same weights for the components -- distances would be plus (above?) or minus (below?) the datum -- probably won't be too far from the upper longeron ( a good "ball park" location would probably be your horizontal CG location at the upper longeron) Mike C. Pretty Prairie, KS ----- Original Message ----- From: Alex Sloan To: pietenpol-list(at)matronics.com Sent: Thursday, January 15, 2004 5:20 PM Subject: Re: Pietenpol-List: Landing Gear Location Mike, I am having a lot of confusion trying to understand this angle thing. 12-14 degrees measured from where to where? I know how to find the C.G. horzontally but this vertical C.G. point is new to me. Can you clarify this point? Alex Sloan alexms1(at)bellsouth.net ________________________________________________________________________________
Subject: forged pistons
Date: Jan 16, 2004
Group, I have a set of +.030" forged pistons and I am about to have the barrells bored to suit. In the Corvair shop manual the piston to bore clearances are given as: Top land .022" to .031" and the skirt: .0011" to .0017". I'm sure I recall reading somewhere that forged pistons require greater clearances but I can't find where I read it. Could someone who has rebuilt their own Corvair using forged pistons (or anyone who has the knowledge) please clue me up on this. Many thanks, Rod Wooller Chidlow Australia Hot chart ringtones and polyphonics. Go to http://ninemsn.com.au/mobilemania/default.asp ________________________________________________________________________________
Date: Jan 15, 2004
Subject: Excellent article on W&B
From an early British aircraft design book. Provided by Greg Cardinal and Chris Bobka. Greg found this info and it is the only place we have ever found it. You just weigh the aircraft in the tail up, level, position and then in the three point attitude, loaded of course, and then do the formula and it will tell you the vertical CG. No guesswork. I've added it to mykitplane.com Photo Gallery area..... <http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID=185> I just wish it was something I needed right now but it's excellent information, and thanks Greg and Chris. Jim ________________________________________________________________________________
Date: Jan 15, 2004
That was before the divorce, right? ----- Original Message ----- Really, back in my day we just screamed and yelled at each other. Rick H ________________________________________________________________________________
Date: Jan 16, 2004
Hi Rod I have built several V8 Ford and Chevy engines with forged pistons. Because the aluminum is denser than cast pistons they expand more when heated. the piston manufacturer should supply the clearance information. All of the forged pistons I have installed called for .005" skirt clearance. You can actually hear them rattleing in the engine when they are cold which I personally dont like but they quiet down when they are hot from being loaded. Hope this is of some help. Ed G. >From: "rod wooller" <rodwooller(at)hotmail.com> >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: forged pistons >Date: Fri, 16 Jan 2004 12:37:23 +0800 > > > >Group, > >I have a set of +.030" forged pistons and I am about to have the barrells >bored to suit. >In the Corvair shop manual the piston to bore clearances are given as: Top >land .022" to .031" >and the skirt: .0011" to .0017". >I'm sure I recall reading somewhere that forged pistons require greater >clearances but I can't find where I read it. >Could someone who has rebuilt their own Corvair using forged pistons (or >anyone who has the knowledge) please clue me up on this. > >Many thanks, >Rod Wooller >Chidlow >Australia > >_________________________________________________________________ >Hot chart ringtones and polyphonics. Go to >http://ninemsn.com.au/mobilemania/default.asp > > Check out the new MSN 9 Dial-up fast & reliable Internet access with prime ________________________________________________________________________________
Date: Jan 16, 2004
> Rod, Have you joined this list? I remember your same question being discussed recently. Kent > See CorvAircraft list details at http://www.krnet.org/corvaircraft_inst.html ________________________________________________________________________________
Date: Jan 16, 2004
Thats right, after the divorce we only yelled when we were in an airplane. That was before the divorce, right? ----- Original Message ----- Really, back in my day we just screamed and yelled at each other. Rick H ________________________________________________________________________________
Subject: Re: Corvair trip to AL & Scanned Piet Article...
Date: Jan 16, 2004
Jim, I also have not heard back from the guy, although it may be because my emails have been bouncing back as if his email account is no longer valid. This happened to me before while trying to setup a meeting time, it took weeks to arrange. I doubt very much that he is no longer interested in selling what he has, he may just be experiencing "technical difficulties". If I do make contact, I will let you all (y'all) know. And speaking of your wife's kitchen cabinets... three days after my Alabama trip, I was ordering my wife a new laptop computer. :) Robert Haines Du Quoin, Illinois From: "Jim Markle" <jim_markle(at)mindspring.com> Subject: Pietenpol-List: Corvair trip to AL & Scanned Piet Article... First, that trip I was going to make to Alabama to pick up Corvair parts is off. Never heard from the guy.....(Robert must have cleaned him out!!!) In the meantime, I received 3 good leads for 110's after one email to the local Corvair club. Ain't technology grand! I've found one, but also followed up on the others for the sake of several of you that asked me to check on bringing something back from Alabama for them. I'll let you know when/if I hear back from these others...... I just scanned and posted an article from the May 1956 issue of Experimenter. (Another cool benefit of having an old timer for a tech counselor, especially one that has saved every EAA Experimenter/Sport Aviation/etc publication from the beginning....and has a Corvair 110 in his garage waiting for a home.) Anyway, this article has several pages of interesting Pietenpol info - plus a note from Bernard Pietenpol....interesting reading. <http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID184> If anyone wants the larger file versions (mykitplane reduces the size of files to a more manageable web site size), just let me know and I'll email direct..... Jim in Plano......working on one of the most important parts of my successful Pietenpol completion......my wife's new kitchen cabinets..... ________________________________________________________________________________
<007101c3dba2$0ad7b700$0101a8c0@domain>
Subject: Re: landings
Date: Jan 16, 2004
I have followed the flow of replies to the question of how to land a Pietenpol. They were all excellent and on point. If I might be so bold, I would like to take this opportunity to consolidate the advice into one place where others in the future might look and also benefit from our experience. I welcome comments and will incorporate any suggestions that clarify the answer. My background is that I fly and have around 400 hours in an Aircamper. I am presently instructing in a Cessna 140 that I own. I earned my flight certificate in 1964 in a Cessna 140. Over 2/3 of my hours are in a tail dragger. I am an EAA Flight Advisor and am in the process of doing the First Flight in two new Aircampers and hopefully mine later this spring. Attached is how it looked New Years day. First some basics. In generic terms a good 3 point landing consists of an approach that concludes with a round out, a flare and a greaser of a landing. A standard approach is done by flying the aircraft at a constant pre-determined airspeed (that is usually around 1.3 times faster than stall). I have been very successful in holding that speed solely with the use of pitch (using the elevators). The angle of the approach is controlled with power. This approach speed is carried to an altitude near the ground when the aircraft is pitched up to an attitude that results in nearly level flight. This part of the landing is commonly called the round out. Since pitching up results in a decrease in airspeed, the wings start to lose some lift. What follows is what determines the quality of the touchdown and is called the flare. The trick is to slowly pitch up at the precise rate to equally compensate for the loss of lift from the decrease in airspeed. If you have been paying attention, you realize that this is a constantly changing situation. As you pitch up you decrease speed, which decreases lift, which requires more pitch, which requires ... The object is to slow down from approach speed to stall speed, maintaining almost level flight, while allowing the aircraft wheels to ease closer to the runway until they touch down at the exact moment stall speed is attained. At the moment of touchdown the elevator control should be back as far as it will travel. This securely forces the tail wheel down and increases its effectiveness in controlling direction. This is very important since the rudder quickly loses effect because of loss of air flowing past it as it slows. I won't comment here on the importance of keeping a tail dragger going straight while on the ground, other than to say it is the most important aspect of flying one. Now, back to landing, if you get to the stall speed before touching the ground the plane loses all lift and drops to the ground. Not a bad landing if the drop is a matter of inches. If the ground is touched before slowing to stall speed a return to flight is likely. This is especially true in a tail dragger because the pitch angle of the wing is usually set for a climb when all wheels are on the ground. If you are flying above stall speed in all likely hood you will touch down on the main gear first. As you pull back the tail will lower, creating more lift, and you find yourself climbing back into the air. In most aircraft the round out and flare are distinct segments of the landing. The round out might take around 5 seconds and the following flare might take 15 to 20 seconds depending on airspeed at the start of the round out. Cessnas seem to float forever. Now for Aircamper specific observations. This is what it looks like for me in the pilot's seat. For many reasons the Aircamper doesn't float much. It has a lot of drag. It doesn't go very fast in the first place and slows quickly upon reduction of power. Therefore the round out and flare happen so quickly that they become one operation. If enough speed is not carried in the approach the elevators become ineffective before completing the round out/flare and the bungee cords get severely tested. One of the things you need to discover is the minimum approach speed that still allows elevator control until full stall and touchdown. This is going to probably be different for each aircraft because of configuration, instrument error, etc.. 65 mph works for me. 1.3 stall speed is 55 mph. I pancake in every time at that speed. I "aim" at the ground and carry 65 mph until a couple of feet above the ground and then smoothly pull back for the round out/flare and am on the ground in about 30 - 50 feet. No bounce. No drop. Just a smooth 3 point landing. I would suggest that one of the first things to establish on the first flight is the stall speed. I would then suggest that the approach be tested at no slower than 1.6 times stall speed. If that gives elevator control but results in a distinct flare you could reduce the speed in 2 mph steps until you find the speed that causes mild elevator loss. You now know the minimum approach speed for your plane in that weight configuration. I usually add a couple of mph for an adult passenger. This is a conservative approach to coming up with numbers you can fly with. Although I have only flown my own Aircamper to date, I believe from listening to others' experiences that this is the best way to approach your first landings. What do you say Mike Cuy or Chris? I met a list member at Oshkosh in 1999. He had completed his plane in April but didn't have it with him. He told me that on the third landing he bent the landing gear on a hard touchdown because he ran out of elevator. Hopefully this discussion will prevent a repeat of that experience. All of the above only applies to a power off landing. Carrying a little power allows a slightly slower approach speed and still provides elevator control during the flare. Cut power at the end of the round out and end up with a perfect 3 point landing. Hope this helps someone. Sorry this got so long. It is easier to do than describe. Ted Brousseau PS If any of the above does not make sense don't try it alone. Run out and get yourself an experienced taildragger pilot to help you. Also, this does not address crosswind, upwind, uphill, downhill, short field, soft field or wheel landings. ________________________________________________________________________________
Subject: Texas Air Museum "German" Piet info
Date: Jan 16, 2004
When I heard "Jose somebody with an L-19" in regards to the "German" Piet, a little light clicked on and I checked with one of my old email buddies... Jose Cano, from the Int'l Bird Dog Assoc. Sure 'nuff, it was him. Here's what he said... anyone looking for an L-19? (probably about my 3rd fave plane, behind the OV-10 and Piet...) -Mike Mike Whaley merlin@ov-10bronco.net Webmaster, OV-10 Bronco Association http://www.ov-10bronco.net/ http://www.ov-10bronco.net/users/merlin/ ---------------------- 10:4 Mike, that was me but I never flew it. Tim Talley from Clifton Aero did the test flight after we fixed one of the wings and reassembled the whole plane. I rigged the ailerons and installed the Jenny wheels on it. The airplane was sold to the TX Air Museum and I helped Ken Brown disassemble it and load it on a trailer. I was by the museum early part of last year and they still have it and fly it occasionally. My L-19 project has come to a screeching halt due to work loads and job changes. I think I am going to sell it this winter. I have had a few people inquire about it but you know the old story "I have to sell my other airplane first.". I have not advertised it because I keep thinking I will have time to do a few more things on it before I advertise it. As of the last 7 days, there have been two more Birddogs go down due to pilot error, this makes mine keep going up in value because there are fewer and fewer of them around. Let me know if any of your folks are interested. I check your OV-10 website periodically to check on the progress of your museum. Looks like you all are doing good things. Some of the IBDA folks may be contacting you all about a joint project. Due to my work load, I am no longer on the board of directors but due continue to put in my two cents worth. Hope you have a good new year ahead. Jose' C. Cano, Jr. Texas Parks & Wildlife Dept. Wildlife Biologist 406 N. Ave. R Clifton, TX 76634-1252 254/675-8729 Home/Fax 254/582-2719 Office/Fax ________________________________________________________________________________
and Kitplanes
Subject: List of Pietenpol articles from Sport Aviation, Experimenter,
and Kitplanes
Date: Jan 16, 2004
Maybe this has been done before but while I was compiling a list of acro bipe articles for the website at work, I also compiled all the Piet-related ones as well. This covers Sport Aviation, Experimenter (the old and the new ones) and Kitplanes. It may have been done before but what the heck, here they are. A thousand thanks to the Cozy Builder's group for compiling the indices in an orderly fashion (EAA's article search function really stinks!) PS - I'll post it as both text in this email (below) as well as attach a text file so that those of you who aren't on the digest can save to your PC. -Mike Mike Whaley merlin@ov-10bronco.net Webmaster, OV-10 Bronco Association http://www.ov-10bronco.net/ http://www.ov-10bronco.net/users/merlin/ --- --- Pietenpol Articles - Sport Aviation, Experimenter, and Kitplanes Compiled 1/14/04 by Mike Whaley (merlin@ov-10bronco.net) From http://www.cozybuilders.org/ref_info/ Includes: Sport Aviation (1954 - 1998)(aka Experimenter in the 1950's) EAA Experimenter (1987 - 1998) Kitplanes (1985 - 1998) Search Terms: Pietenpol Piet GN-1 GN-2 Bernie B.H. Grega Camper Aircamper Sky Scout Ford Brodhead Corvair Aerial Arial Sport Aviation (Feb. 53 - Dec. 98) (called Experimenter in the 1950s) November 1954, Volume 2, Number 11 Photograph of Campbell Modified Pietenpol p. 8 July 1955, Volume 3, Number 7 Photograph of Rudolph Pietenpol, N13691) _________________________ 1 The Old Pietenpol __________________________________________________ 4 (Three photographs of Rudolph Pietenpol Air Camper, N13691, Leo J. Kohn) ___________________________________________________________ 4 August 1955, Vol. 4, No. 8 Report On the Fly-In ___ Havel T. Lawson ____________________________ 3 Aircraft Seen At The Fly-In (article lists Schermerhorn Pietenpol L.S. Air Camper, N18224; Rudolph Russert-Pietenpol KC-257-13 Air Camper, N13691) January, 1956, Vol. 5, No. 1 Another Pietenpol Air Camper On The Way (with photograph of Ernest C. Seiler and Seiler Pietenpol Air Camper) __________________ 16 May 1956, Volume 5, Number 5 The Pietenpol "Air Camper," Second in a series on Famous Homebuilt Lightplanes ___ George Hardie, Jr. _______________________ 7 (Photograph of two Pietenpol Air Campers, B. H. Pietenpol) _________ 7 (Scale drawings of Pietenpol Air Camper, Jack McRae) _______________ 8-9 >From The Owners And Builders Of Pietenpol Air Campers (with Two drawings of Pietenpol Air Campers, Wm. Kupka) __________________ 10 (Photograph of Allen Rudolph and Rudolph 1933 Pietenpol Air Camper, N13691) ____________________________________________________ 11 (Photograph of Schermerhorn Pietenpol Air Camper, N18224) _________ 11 (Photograph of Rudolph 1933 Pietenpol Air Camper, N13691)________ __ 12 September 1956, Volume 5, Number 9 Aircraft Seen At The Fly-In (article lists Schermerhorn modified Pietenpol L. S. Air Camper, N18224; Rudolph Russert-Pietenpol KC-257-13 Air Camper, N13691) January 1957, Volume 6, Number 1 (Photograph of Schermerhorn Pietenpol L. S. Air Camper, N18224) ___________________________________________________________ 12 November 1957 Modernizing the Pietenpol Landing Gear...........................19 December 1957 The Pietenpol Seaplane Floats....................................12 August 1960 Modernizing The Pietenpol "Aircamper"............................16 MARCH 1962 Pietenpol Corvair Conversion.......................... 31 DECEMBER 1962 More About My Corvair and VW Conversions... 24 AUGUST, 1966 Converting The Model "A" Ford Engine For Flight........ 9 DECEMBER, 1966 Converting the Model A Ford............................. 27 FEBRUARY, 1967 Corvair, Volkswagen, and Drone Engines for Aircraft... 19 JULY, 1967 More on the Model A Ford................................... 11 OCTOBER, 1967 Corvair Powered Autogyro................................................. 22 FEBRUARY, 1968 Pietenpol N-8001R.......................................... 26 MAY, 1968 Corvair Conversions.......by Clayton King........................20 APRIL, 1969 Waterman Corvair Engines...by Waldo Waterman............................4 Your Forest Products Laboratory...by Bob Whittier......................30 A Visit to B.H.Pietenpol...by Bob Whittier.............................40 JULY,1969 Waterman Corvair Engines-Part Two...by Waldo D. Waterman......... 14 AUGUST, 1969 Waterman Corvair Engines-Part Three by Waldo D. Waterman... 14 SEPTEMBER,1969 Waterman Corvair Engines (Part 4).....by Waldo D. Waterman.................21 OCTOBER, 1969 Waterman Corvair Engines (Part 5)... by Waldo D. Waterman.... 18 NOVEMBER, 1969 Waterman Corvair Engines, Part 6....... by Waldo D. Waterman...............10 JANUARY 1970 Some Fundamental and Special Considerations of the Corvair Engine - As an Aircraft Powerplant . . . by David A. Paddock...........10 MARCH, 1970 Volkswagen Reduction Box on the Corvair.....by Bud Rinker......46 MAY, 1970 The Berg-Aero - from Pietenpol to SE-5A...by John B. Bergeson........38 SEPTEMBER, 1970 Pietenpol Powered by Corvair......................................42 NOVEMBER, 1970 Corvair Clarification.....by James C.Carvin......................22 DECEMBER, 1970 Testing The Corvair Engine...by Bud Rinker...........................19 JUNE 1971 Corvair-powered Corvair.................13 NOVEMBER 1972 Vega Sky Scout...by Jack Cox.......................................31 DECEMBER 1974 Update on the Corvair Engine Syndrome ... by Bud Rinker...............63 JUNE 1975 Chapter 148's Pietenpol . . . by Dale Wolford.......................36 MAY 1977 68 Duplicate Sawing... by John W. Grega NOVEMBER 1980 38 Ford Fiesta Powered Pietenpol . .. by Jack Cox MARCH 1981 44 The Pietenpol Aerial... by Chad Wille SEPTEMBER 1982 58 Imagineering a Pietenpol for the 80's?. . . by Al Baekstrom FEBRUARY 1985 42 Sky Gypsy/Frank S. Pavliga MARCH 1987 48 England's First Pietenpol Air Camper/F. A Hawke FEBUARY 1989 16 Howard Henderson's Model A Ford Powered Pietenpol/Grant E. MacLaren APRIL 1990 45 A Round Engine Pietenpol!/Jack Cox JANUARY 1991 25 Ol '12937 - The "Granddaddy" Pietenpol Air Camper/Norm Petersen February 1998 30 The Pietenpol Sky Scout - Chad Wille EAA EXPERIMENTER (Dec. 86 - Dec. 98) AUGUST 1991 page twenty-something: Don Higgs' Pietenpol by Robert N. Gilbert FEBRUARY 1994 6 A Little AirCamper Replica Named RagWing by Roger Mann MARCH 1996 A Corvair-Powered Nieuport 26 Solving the challenges of an unusual engine installation-by Rich Dietrich MAY 1996 Pietenpol NX1 7WR 25 A tried and true homebuilders favorite-by Bill Rewey Febuary 1998 Rick Crosslin's GN-1 ....................................... 23 An affordable plane anyone can build - by Mary Jones KITPLANES (Jan. 85 - Dec. 98) FEBRUARY, 1985 76 BIPED FOR FUN! Pietenpol's Air Camper is a people- pleaser that proves low-and-slow can be beautiful; by Owen B. Deaver. February 1987 EAA Museum Pieces (Pietenpol Air Camper), p.56 November 1987 Braking a Pietenpol, p. 46 May 1989 Flying an Air Camper (Pietenpol), p. 31 July 1992 Pietenpol Air Camper (Cover) Check Out This Pietenpol, p. 12. August 1997 Pietenpols Forever? p. 42 Who Was Bernie Pietenpol? p. 50 Pietenpol Articles - Sport Aviation, Experimenter, and Kitplanes Compiled 1/14/04 by Mike Whaley (merlin@ov-10bronco.net) From http://www.cozybuilders.org/ref_info/ Includes: Sport Aviation (1954 - 1998)(aka Experimenter in the 1950's) EAA Experimenter (1987 - 1998) Kitplanes (1985 - 1998) Search Terms: Pietenpol Piet GN-1 GN-2 Bernie B.H. Grega Camper Aircamper Sky Scout Ford Brodhead Corvair Aerial Arial Sport Aviation (Feb. 53 - Dec. 98) (called Experimenter in the 1950s) November 1954, Volume 2, Number 11 Photograph of Campbell Modified Pietenpol p. 8 July 1955, Volume 3, Number 7 Photograph of Rudolph Pietenpol, N13691) _________________________ 1 The Old Pietenpol __________________________________________________ 4 (Three photographs of Rudolph Pietenpol Air Camper, N13691, Leo J. Kohn) ___________________________________________________________ 4 August 1955, Vol. 4, No. 8 Report On the Fly-In ___ Havel T. Lawson ____________________________ 3 Aircraft Seen At The Fly-In (article lists Schermerhorn Pietenpol L.S. Air Camper, N18224; Rudolph Russert-Pietenpol KC-257-13 Air Camper, N13691) January, 1956, Vol. 5, No. 1 Another Pietenpol Air Camper On The Way (with photograph of Ernest C. Seiler and Seiler Pietenpol Air Camper) __________________ 16 May 1956, Volume 5, Number 5 The Pietenpol "Air Camper," Second in a series on Famous Homebuilt Lightplanes ___ George Hardie, Jr. _______________________ 7 (Photograph of two Pietenpol Air Campers, B. H. Pietenpol) _________ 7 (Scale drawings of Pietenpol Air Camper, Jack McRae) _______________ 8-9 >From The Owners And Builders Of Pietenpol Air Campers (with Two drawings of Pietenpol Air Campers, Wm. Kupka) __________________ 10 (Photograph of Allen Rudolph and Rudolph 1933 Pietenpol Air Camper, N13691) ____________________________________________________ 11 (Photograph of Schermerhorn Pietenpol Air Camper, N18224) _________ 11 (Photograph of Rudolph 1933 Pietenpol Air Camper, N13691)________ __ 12 September 1956, Volume 5, Number 9 Aircraft Seen At The Fly-In (article lists Schermerhorn modified Pietenpol L. S. Air Camper, N18224; Rudolph Russert-Pietenpol KC-257-13 Air Camper, N13691) January 1957, Volume 6, Number 1 (Photograph of Schermerhorn Pietenpol L. S. Air Camper, N18224) ___________________________________________________________ 12 November 1957 Modernizing the Pietenpol Landing Gear...........................19 December 1957 The Pietenpol Seaplane Floats....................................12 August 1960 Modernizing The Pietenpol "Aircamper"............................16 MARCH 1962 Pietenpol Corvair Conversion.......................... 31 DECEMBER 1962 More About My Corvair and VW Conversions... 24 AUGUST, 1966 Converting The Model "A" Ford Engine For Flight........ 9 DECEMBER, 1966 Converting the Model A Ford............................. 27 FEBRUARY, 1967 Corvair, Volkswagen, and Drone Engines for Aircraft... 19 JULY, 1967 More on the Model A Ford................................... 11 OCTOBER, 1967 Corvair Powered Autogyro................................................. 22 FEBRUARY, 1968 Pietenpol N-8001R.......................................... 26 MAY, 1968 Corvair Conversions.......by Clayton King........................20 APRIL, 1969 Waterman Corvair Engines...by Waldo Waterman............................4 Your Forest Products Laboratory...by Bob Whittier......................30 A Visit to B.H.Pietenpol...by Bob Whittier.............................40 JULY,1969 Waterman Corvair Engines-Part Two...by Waldo D. Waterman......... 14 AUGUST, 1969 Waterman Corvair Engines-Part Three by Waldo D. Waterman... 14 SEPTEMBER,1969 Waterman Corvair Engines (Part 4).....by Waldo D. Waterman.................21 OCTOBER, 1969 Waterman Corvair Engines (Part 5)... by Waldo D. Waterman.... 18 NOVEMBER, 1969 Waterman Corvair Engines, Part 6....... by Waldo D. Waterman...............10 JANUARY 1970 Some Fundamental and Special Considerations of the Corvair Engine - As an Aircraft Powerplant . . . by David A. Paddock...........10 MARCH, 1970 Volkswagen Reduction Box on the Corvair.....by Bud Rinker......46 MAY, 1970 The Berg-Aero - from Pietenpol to SE-5A...by John B. Bergeson........38 SEPTEMBER, 1970 Pietenpol Powered by Corvair......................................42 NOVEMBER, 1970 Corvair Clarification.....by James C.Carvin......................22 DECEMBER, 1970 Testing The Corvair Engine...by Bud Rinker...........................19 JUNE 1971 Corvair-powered Corvair.................13 NOVEMBER 1972 Vega Sky Scout...by Jack Cox.......................................31 DECEMBER 1974 Update on the Corvair Engine Syndrome ... by Bud Rinker...............63 JUNE 1975 Chapter 148's Pietenpol . . . by Dale Wolford.......................36 MAY 1977 68 Duplicate Sawing... by John W. Grega NOVEMBER 1980 38 Ford Fiesta Powered Pietenpol . .. by Jack Cox MARCH 1981 44 The Pietenpol Aerial... by Chad Wille SEPTEMBER 1982 58 Imagineering a Pietenpol for the 80's?. . . by Al Baekstrom FEBRUARY 1985 42 Sky Gypsy/Frank S. Pavliga MARCH 1987 48 England's First Pietenpol Air Camper/F. A Hawke FEBUARY 1989 16 Howard Henderson's Model A Ford Powered Pietenpol/Grant E. MacLaren APRIL 1990 45 A Round Engine Pietenpol!/Jack Cox JANUARY 1991 25 Ol '12937 - The "Granddaddy" Pietenpol Air Camper/Norm Petersen February 1998 30 The Pietenpol Sky Scout - Chad Wille EAA EXPERIMENTER (Dec. 86 - Dec. 98) AUGUST 1991 page twenty-something: Don Higgs' Pietenpol by Robert N. Gilbert FEBRUARY 1994 6 A Little AirCamper Replica Named RagWing by Roger Mann MARCH 1996 A Corvair-Powered Nieuport 26 Solving the challenges of an unusual engine installation-by Rich Dietrich MAY 1996 Pietenpol NX1 7WR 25 A tried and true homebuilders favorite-by Bill Rewey Febuary 1998 Rick Crosslin's GN-1 ....................................... 23 An affordable plane anyone can build - by Mary Jones KITPLANES (Jan. 85 - Dec. 98) FEBRUARY, 1985 76 BIPED FOR FUN! Pietenpol's Air Camper is a people- pleaser that proves low-and-slow can be beautiful; by Owen B. Deaver. February 1987 EAA Museum Pieces (Pietenpol Air Camper), p.56 November 1987 Braking a Pietenpol, p. 46 May 1989 Flying an Air Camper (Pietenpol), p. 31 July 1992 Pietenpol Air Camper (Cover) Check Out This Pietenpol, p. 12. August 1997 Pietenpols Forever? p. 42 Who Was Bernie Pietenpol? p. 50 ________________________________________________________________________________
Date: Jan 17, 2004
Subject: Updated 'Infomation List'
I've added all the suggestions, and here is the updated 'Information List.' I'm posting it again, to give everyone one more chance to add something to it. Speak now, or forever hold your peace !! I'll then send the 'Information List' to everyone that I have an e-mail for (builders and flyers), and they can copy / paste to a return e-mail, fill in all the blanks as much as they can, and send it to me, or to the list. I'll also bring a dozen blank copies (is that enough blanks?) to Brodhead for anyone else that I missed. This should give us a pretty good data base, in a common format, on the specific construction of our fleet of Pietenpols out there. Thanks to all who participate !! Chuck Gantzer NX770CG I flew the past four days in a row (about a half hour after work), and it's the middle of January !! Yesterday, I took my buddy's wife up for a ride, and she absolutely loved it !! Today at work, he said she talked about it all evening...she called her friends, her mom, and his mom to tell 'em about it !! Too Cool !! Here is the updated 'Information List': Aircraft Information: N Number - Name - Type - Short / Long fuse - Empty Weight - lbs. Gross Weight - lbs. Engine - Prop - X Empty CG aft of Lead Edge - " Weight of Primary Pilot - lbs. Max Pax Weight - lbs Inches wing tilted back - " Cabane strut length - " Cowling Material - Covering - Paint Process - Wheels - Tires - Brakes - Tailwheel - Bunji Chord / Springs - Seat Belt Harness - Survival Tools - Adhesives used: Ribs - Wing - Fuse - Fuel Capacity: Range - hrs. Wing Tank - gal. Material - Cowl Tank - gal. Material - Alterations : Fuselage Width - " Wingspan - ' " Engine Mount Length - " Fuselage Front Extension - Landing Gear Position - " Other - Wood type in various locations: Ribs - Rib Gussets - Spar Size - X Spar Material - Longerons - Longeron Gussets - Other - Steel type in various locations: Cabane Struts - Lift Struts - Landing Gear - Engine Mount Fittings - Fuselage Fittings - Firewall - Other - Airspeeds: Vr (rotation) Vx (best angle) - Vy (best rate) - Vne (never exceed) - Vs1 (stall) - Date first airplane noises / / Date of the first flight / / Address - e-mail - web site - builder(s)- ________________________________________________________________________________
Subject: vi kapler hinges
Date: Jan 17, 2004
Anyone have a photo or some info on Vi Kaplers hinges? Is he selling / making them? How can I reach him? I'm working on the tail section over the winter and I'll soon be ready for some hinges to put it all together. Tom Brant Brooklyn Park, MN ________________________________________________________________________________
Subject: Re: vi kapler hinges
Date: Jan 17, 2004
----- Original Message ----- From: Brants To: pietenpol-list(at)matronics.com Sent: Saturday, January 17, 2004 12:02 AM Subject: Pietenpol-List: vi kapler hinges Tom, I haven't talked to him for a couple of years, but try: Vi Kapler 1033 Forest Hills Drive S.W. Rochester, MN 55902 507) 288-3322 Hope this helps, let me know the results. John Anyone have a photo or some info on Vi Kaplers hinges? Is he selling / making them? How can I reach him? I'm working on the tail section over the winter and I'll soon be ready for some hinges to put it all together. Tom Brant Brooklyn Park, MN ________________________________________________________________________________
Subject: Cutting plywood
Date: Jan 17, 2004
Listers, Does anyone have a suggestion as to how to cut plywood without pulling up the top layer of ply? Even with new plywood cutting blades I tend to leave a rough edge. I'm ready to make a cut in the rear seat back so it can be hinged for inspection access. I would hate to leave a rough or "over sanded" appearance in a nice looking piece of plywood. Dave in Missouri ________________________________________________________________________________
From: "Richard Navratil" <horzpool(at)goldengate.net>
Subject: model a engine
Date: Jan 17, 2004
I just got the new issue of the BPA newsletter. There is a Classified ad for a model A engine with fresh overhaul and conversion including prop hub. It is listed for $950/offer. Sounds like a deal. Contact Karl 765-532-4864 or 815-459-7902 ________________________________________________________________________________
Subject: Re: Cutting plywood
Date: Jan 17, 2004
Dave, I did all my wood cutting with a 10" Delta bandsaw. Always a smooth beautiful cut. walt evans NX140DL ----- Original Message ----- From: dpaul To: pietenpol-list(at)matronics.com Sent: Saturday, January 17, 2004 1:23 PM Subject: Pietenpol-List: Cutting plywood Listers, Does anyone have a suggestion as to how to cut plywood without pulling up the top layer of ply? Even with new plywood cutting blades I tend to leave a rough edge. I'm ready to make a cut in the rear seat back so it can be hinged for inspection access. I would hate to leave a rough or "over sanded" appearance in a nice looking piece of plywood. Dave in Missouri ________________________________________________________________________________
Date: Jan 17, 2004
Try a fine toothed bandsaw ________________________________________________________________________________
Date: Jan 17, 2004
Score the top and layer with a knife blade along your cut line if it splinters out it will only go to the scored line. Terry Bowden ph (254) 715-4773 fax (254) 853-3805 ________________________________________________________________________________
Date: Jan 17, 2004
If you are in a place in the work where you absolutely, positively have got to have a perfect cut, just lay a scrap piece of wood over and under the piece you want the smooth cut on. Clamp them together and cut through all three at once. The splits and tears will be in the outer pieces and the center one will be perfect. This works really well when doing things like cutting holes for instruments. You can use almost anything for the outer pieces, like press board, cheap ply or even tempered masonite. Just make sure the three are clamped together so the outer pieces take the damage. Hank J ----- Original Message ----- From: dpaul To: pietenpol-list(at)matronics.com Sent: Saturday, January 17, 2004 1:23 PM Subject: Pietenpol-List: Cutting plywood Listers, Does anyone have a suggestion as to how to cut plywood without pulling up the top layer of ply? Even with new plywood cutting blades I tend to leave a rough edge. I'm ready to make a cut in the rear seat back so it can be hinged for inspection access. I would hate to leave a rough or "over sanded" appearance in a nice looking piece of plywood. Dave in Missouri ________________________________________________________________________________
Date: Jan 17, 2004
In a message dated 1/17/04 10:18:57 AM Central Standard Time, dpaul(at)fidnet.com writes: << Does anyone have a suggestion as to how to cut plywood without pulling up the top layer of ply? >> I've used masking tape on the top of the plywood, if you're using a circular saw, or on the bottom if you're using a table saw. Then put your line on the masking tape, or use one edge of the masking tape for your line, and cut as you normally would. You can streach the tape between your marks, and it makes a good straight line, eliminating the step of laying a straight edge on, and marking it with a pencil. The tape keeps the saw teeth from pulling the splinters up. Chuck G. ________________________________________________________________________________
Date: Jan 17, 2004
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
>Anyone have a photo or some info on Vi Kaplers hinges? Is he >selling / making them? How can I reach him? I'm working on the >tail section over the winter and I'll soon be ready for some hinges >to put it all together. > > >Tom Brant >Brooklyn Park, MN > > >------ <http://www.usfamily.net/info>USFamily.Net - Unlimited >Internet - From $8.99/mo! ------ Tom, Vi was at Brodhead & I think he told me that he's still making hinges & prop hubs. I got a set when I bought my project. They are nice. Not doing much on the Piet right now, I'm busy restoring a 50+ year-old sled for my daughter. Kip Gardner - cold & snowy here too, down to 0 last night -- North Canton, OH ________________________________________________________________________________
Date: Jan 17, 2004
Subject: Re: Engine mount and tailfeathers
In a message dated 1/14/04 9:13:12 PM Central Standard Time, Andimaxd(at)aol.com writes: << My project is coming right along. The engine mount is welded straight, in other words no one inch down and no half to one inch right or left. We are using a cont. 75 HP. Should I mount the vertical tail fin an inch or so over to one side or is it worth messing with?>> Max, The Continental Engine Mount, drawn by A. C. Hanfet, dated 3/15/67, shows a difference of 9/16" in the top and bottom lengths of the mount. I maintained this difference in my engine mount, but made it 8" longer with heavier wall tubing. It doesn't show any right thrust, but I built 1/16" right thrust into the mount. The Model A engine mount shows a 1" downthrust along the horizontal line. Downthrust helps reduce the 'Pendulum Effect' of a high wing, that the various power settings have. Add power, the nose pitches up, reduce power, the nose lowers, however, even with downthrust built into the engine mount. Also do I need to have more incidence in the left wing to compensate for torque and P factor? >> Do Not rig the wing to compensate for torque or P factor. Different incidence in the wing will cause one wing to stall before the other. Rig the wing with the same amount of incidence all the way across, or maybe a tiny bit of washout at the tips. The plans show rigging the vertical fin straight, but that is with a Model A engine. Offset fins seem to be used with engines of higher power. Mine is set straight, with no rudder trim tab, and I use just a tiny bit of right rudder during high power settings...almost not even noticible by my feet. You could rig the leading edge of the vertical fin maybe 1/16" to the Left of Butt Line Zero (BL0) to compensate for engine torque. Corvair engines would be offset to the Right side, since they turn in the opposite direction. P factor is only evident when flying at a high angle of attack, with a high power setting. I would suggest you use large 'fender washers' under the engine mount to put some downthrust, and right thrust. Chuck Gantzer NX770CG ________________________________________________________________________________
Date: Jan 17, 2004
Dave, Run a piece of masking tape along the cut line, where the teeth of the blade will leave the wood. If you cut on a tablesaw it would be the bottom of the wood. The tape keeps the edge from splintering. Kent ----- Original Message ----- From: dpaul To: pietenpol-list(at)matronics.com Sent: Saturday, January 17, 2004 12:23 PM Subject: Pietenpol-List: Cutting plywood Listers, Does anyone have a suggestion as to how to cut plywood without pulling up the top layer of ply? ________________________________________________________________________________
Date: Jan 17, 2004
Subject: Re: Updated 'Infomation List'
In a message dated 1/16/2004 11:37:44 PM Central Standard Time, Rcaprd(at)aol.com writes: and they can copy / paste to a return e-mail, fill in all the blanks as much as they can, and send it to me, or to the list Chuck, Great Job! I'm not much on the cut and paste thing. If you would you post your mailing address I could then mail you the filled out form on NX920Y rather than clutter up the list. Thanx, Don Hicks ________________________________________________________________________________
Subject: Re: Landing Gear Location
Date: Jan 17, 2004
With the plane in a level attitude the angle we are talking about is between a vertical through the CG and the tire contact point and the CG. You can find the actual CG location by doing a "weigh" with the tail down and find the CG spot on the ground. A line on the fuselage side (vertical) will become a sloped line when you bring the tail up to level. Do the weigh again and make a new vertical line. The crossing point of the lines is the actual CG. Pull another line from that CG location (with the tail still up) to the contact point of the tires. The angle between the vertical line and the line to the tire contact point is the angle we are talking about. The angle isn't going to be very big between the tail down and up CG locations so measure carefully (a 90=BA angle would be most accurate). A REALLY accurate way to locate the vertical location would be to just hang the plane up by the prop and drop a plumb line down beside it but that seems to cause a lot of fluid leaks. ;-) Hank J ----- Original Message ----- From: Alex Sloan To: pietenpol-list(at)matronics.com Sent: Thursday, January 15, 2004 6:20 PM Subject: Re: Pietenpol-List: Landing Gear Location Mike, I am having a lot of confusion trying to understand this angle thing. 12-14 degrees measured from where to where? I know how to find the C.G. horzontally but this vertical C.G. point is new to me. Can you clarify this point? Alex Sloan alexms1(at)bellsouth.net ----- Original Message ----- From: Michael Conkling To: pietenpol-list(at)matronics.com Sent: Wednesday, January 14, 2004 7:49 PM Subject: Re: Pietenpol-List: Landing Gear Location My old copy (1965) of "Practical Lightplane Design & Construction" by Bill Fike listed the average landing angle as being 12 to 14 degrees -- with the fuselage level, the wheel axle was in-line with the leading edge of the wing (16 degrees down & forward of the CG point) -- for a "cub" like airplane with brakes. Mike C. Pretty Prairie, KS ----- Original Message ----- From: Christian Bobka To: pietenpol-list(at)matronics.com Sent: Tuesday, January 13, 2004 8:51 PM Subject: Re: Pietenpol-List: Landing Gear Location To clarify John's post below, the 16.5 degree angle is with the tail up and the ship level fore and aft using the top longerons at the cockpit for leveling. chris bobka ----- Original Message ----- From: John Dilatush To: Pietenpol-list(at)matronics.com Sent: Tuesday, January 13, 2004 12:46 PM Subject: Pietenpol-List: Landing Gear Location ----- Original Message ----- From: At7000ft(at)aol.com To: pietenpol-list(at)matronics.com Sent: Tuesday, January 13, 2004 8:59 AM Subject: Re: Pietenpol-List: Piet information list Pieters, The proper location of the landing gear ground contact point is determined by the CG of the plane. The CG of the entire plane is a combination of the horizontal and vertical centers of gravity. From this point a line may be drawn to the ground contact point of the landing gear. The angle of this line is usually 16.5 degrees forward from the vertical if the plane is equiped with brakes, somewhat less if the plane has no brakes. It might be neccessary to increase this angle if the thrust line is high, so as to prevent nose over during run up and rough field operation. However, the heavier the tail load is, the more of a tendency for ground looping upon landing. On "Mountain Piet" this angle is about 12 degrees and this seems to work out OK, both for rough fields and no ground looping tendencies. The brakes won't hold the plane during run up, so this is not an issue. My tailwheel weight when the plane is leveled up is only about 9 lbs. I had attached the spreadsheet used for my plane, however it was too large for Matronics to accept, so it was bounced. If anyone is interested, I'll be glad to try and send it directly to you. Hope all this helps. John Dilatush NX114D Salida, CO ________________________________________________________________________________
Subject: Re: Piet information list
Date: Jan 17, 2004
You need to calculate the thrust and know the moment arm of the prop which gives you the thrust component of the nose over moment, the brake force (based on speed of the aircraft to calculate the weight on the wheels and the local friction coefficient) and the vertical CG location, which gives you the nose over moment from the wheel brakes, the deceleration of the aircraft times the height of the CG for the inertia contribution to the nose over moment, and the distance behind the tire contact point of the CG (which changes as the attitude of the plane changes, that also changes the lift, changing the weight on the wheels that changes everything else). Then you do the calculation solving for all the moments at say every 2 MPH increment to determine the critical speed, angles and brake force. You also have to factor in the down load available from the tail and its arm solving for the point where the elevator looses effectiveness. The one factor that is hard to calculate is how hard your "pucker" is trying to suck your rear to the pavement and the moment arm from the wheel contact point to the seat as the nose starts to go over. Three things are derived from the whole mess. 1) That's why the engineer gets paid as much as he does 2) Now you know why the tricycle gear is so popular with manufacturers 3) That's why we use a "Rule of Thumb" for the angle If you REALLY want to know the answer to the above I have done it before but it takes some time and can get expensive. It IS very informative and, by the way, I wrote the above as I sat in front of the computer so some factors are probably missing. I would normally do it on paper to make sure I didn't miss anything and them spread sheet it for each condition. Anybody want to help finance the paint job on my Taylorcraft? ;-) Hank J ----- Original Message ----- From: At7000ft(at)aol.com To: pietenpol-list(at)matronics.com Sent: Wednesday, January 14, 2004 9:16 AM Subject: Re: Pietenpol-List: Piet information list Hank - given this data how do you calibrate how hard you can press on the brakes at a given speed to avoid grazing? Rick H. OK, I'm going to stick my nose in once more. To be useful you need to know where the contact point of the tire is in relation to the CG in a level attitude. Sorry guys but all the other measurements don't help much from a nose over point of view. The other thing that is needed is the height from the ground to the CG. With those measurements you can calculate the nose over moment and with the tail force and arm you can calculate exactly how much brake you can use verses the airspeed. That is what tells you if you are going to have a "grazer" or a tail dragger. Hank J ________________________________________________________________________________
<002801c3db0c$21e126c0$57c5fea9@mke> <005e01c3dbbe$1a2f9120$d401a8c0@Alex> <044301c3dd64$6004c7e0$ceddf6ce@hjarrett>
Subject: Wood landing gear question
Date: Jan 17, 2004
Hi, Does the bottom ash block on each landing gear get glued to the legs or is it just held in place only with the metal fittings? Thanks, Ted ________________________________________________________________________________
Date: Jan 17, 2004
Cabinet makers trick-use a knife instead of a pencil. There are knives made especialy for this. They're called "marking knives". Available from all the woodworking catalogue outlets like Lee Valley Tools http://www.leevalley.com/wood/page.asp?SID&ccurrency1&page32502&category1,42936,42949 Garret Wade and others also. A good blade is the 45=B0 one from exacto. Cutting the top layer of fibres limits tearout to that line. Clif ----- Original Message ----- From: dpaul To: pietenpol-list(at)matronics.com Sent: Saturday, January 17, 2004 10:23 AM Subject: Pietenpol-List: Cutting plywood Listers, Does anyone have a suggestion as to how to cut plywood without pulling up the top layer of ply? Even with new plywood cutting blades I tend to leave a rough edge. I'm ready to make a cut in the rear seat back so it can be hinged for inspection access. I would hate to leave a rough or "over sanded" appearance in a nice looking piece of plywood. Dave in Missouri ________________________________________________________________________________
Date: Jan 17, 2004
Subject: Re: Wood landing gear question
<013001c3da49$5eaa6940$0101a8c0@domain> <002801c3db0c$21e126c0$57c5fea9@mke> <005e01c3dbbe$1a2f9120$d401a8c0@Alex> <044301c3dd64$6004c7e0$ceddf6ce@hjarrett> <002b01c3dd73$64fbb1a0$1e3b4e0c@cacjis20.jud20.flcourts.org> From a strength point of view, it won't help any as you are trying to glue end grain in the legs. End grain won't hold. I would varnish the block and legs before putting it all together for moisture protection though. Clif ----- Original Message ----- From: Ted Brousseau To: pietenpol-list(at)matronics.com Sent: Saturday, January 17, 2004 7:30 PM Subject: Pietenpol-List: Wood landing gear question Hi, Does the bottom ash block on each landing gear get glued to the legs or is it just held in place only with the metal fittings? Thanks, Ted ________________________________________________________________________________
Date: Jan 17, 2004
Hi Ted I glued and screwed mine together before the metal fittings. Dick ----- Original Message ----- From: Ted Brousseau To: pietenpol-list(at)matronics.com Sent: Saturday, January 17, 2004 9:30 PM Subject: Pietenpol-List: Wood landing gear question Hi, Does the bottom ash block on each landing gear get glued to the legs or is it just held in place only with the metal fittings? Thanks, Ted ________________________________________________________________________________
Date: Jan 18, 2004
Mine is held in place by the steel fittings. Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Ted Brousseau Subject: Pietenpol-List: Wood landing gear question Hi, Does the bottom ash block on each landing gear get glued to the legs or is it just held in place only with the metal fittings? Thanks, Ted ________________________________________________________________________________
"piet discussion"
Subject: found links to useful information on the net
Date: Jan 18, 2004
Was going thru a newsgroup and found this note. You can download useful text .,,,,,,,,, <<<<<<http://www.faatest.com/books/AK/ I found the link through: http://www.dauntless-soft.com/ which has LOTS of free stuff including checklists, links to other books (see Aviation Library under Freebies) to name a few.>>>>>>>> walt evans NX140DL ________________________________________________________________________________
Subject: horizontal stab dimensions
Date: Jan 18, 2004
I built the long fuselage and then (idiodically) built the horiz. stab for the short fuse (18" wide instead of 19 3/8") - didn't realize until today when I tried fitting it up. Question: can I glue a wider leading edge to the horizontal stab to make up the difference? Obviously this would add a bit of weight to the tail section.. Or could I just fill in behind the turtle deck to take up the space? Difference is about 1 3/8". Is the 1 3/8" width going to be missed if I leave it out? Does this cause a problem getting away from the 'airfoil shape'? Another related question: does the horiz. stab get bolted through the longerons? Any help on this would be appreciated. Tom Brant Brooklyn Park, MN ________________________________________________________________________________
Subject: Re: horizontal stab dimensions
Date: Jan 18, 2004
I didn't know they were different. I built the long fuse and the tail was from the original prints, so I guess I got the wrong one. but flies great. What two prints show different tails??? walt evans NX140DL ----- Original Message ----- From: Brants To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 5:37 PM Subject: Pietenpol-List: horizontal stab dimensions I built the long fuselage and then (idiodically) built the horiz. stab for the short fuse (18" wide instead of 19 3/8") - didn't realize until today when I tried fitting it up. Question: can I glue a wider leading edge to the horizontal stab to make up the difference? Obviously this would add a bit of weight to the tail section.. Or could I just fill in behind the turtle deck to take up the space? Difference is about 1 3/8". Is the 1 3/8" width going to be missed if I leave it out? Does this cause a problem getting away from the 'airfoil shape'? Another related question: does the horiz. stab get bolted through the longerons? Any help on this would be appreciated. Tom Brant Brooklyn Park, MN ________________________________________________________________________________
Date: Jan 18, 2004
You know Ted, this was a good piece of work. A lot of good, useful data, that can be used in other types of airplanes too. Thanks for taking the time to put it to print. I might add....... As I look at a lot of Piet's, some of them have tail sections with square leading edges. This contributes to a loss of elevator and rudder control prematurely. Builders should know to sand/grind the leading edges of all flying surfaces to get the most from them... Thanks again for taking the time to type it out... Weav On Friday, January 16, 2004, at 07:30 PM, Ted Brousseau wrote: > I have followed the flow of replies to the question of how to land a > Pietenpol. They were all excellent and on point. If I might be so > bold, I > would like to take this opportunity to consolidate the advice into one > place > where others in the future might look and also benefit from our > experience. > I welcome comments and will incorporate any suggestions that clarify > the > answer. > > My background is that I fly and have around 400 hours in an Aircamper. > I am > presently instructing in a Cessna 140 that I own. I earned my flight > certificate in 1964 in a Cessna 140. Over 2/3 of my hours are in a > tail > dragger. I am an EAA Flight Advisor and am in the process of doing the > First Flight in two new Aircampers and hopefully mine later this > spring. > Attached is how it looked New Years day. > > First some basics. In generic terms a good 3 point landing consists > of an > approach that concludes with a round out, a flare and a greaser of a > landing. A standard approach is done by flying the aircraft at a > constant > pre-determined airspeed (that is usually around 1.3 times faster than > stall). I have been very successful in holding that speed solely with > the > use of pitch (using the elevators). The angle of the approach is > controlled > with power. This approach speed is carried to an altitude near the > ground > when the aircraft is pitched up to an attitude that results in nearly > level > flight. This part of the landing is commonly called the round out. > Since > pitching up results in a decrease in airspeed, the wings start to lose > some > lift. What follows is what determines the quality of the touchdown > and is > called the flare. The trick is to slowly pitch up at the precise rate > to > equally compensate for the loss of lift from the decrease in airspeed. > If > you have been paying attention, you realize that this is a constantly > changing situation. As you pitch up you decrease speed, which > decreases > lift, which requires more pitch, which requires ... The object is to > slow > down from approach speed to stall speed, maintaining almost level > flight, > while allowing the aircraft wheels to ease closer to the runway until > they > touch down at the exact moment stall speed is attained. At the moment > of > touchdown the elevator control should be back as far as it will travel. > This securely forces the tail wheel down and increases its > effectiveness in > controlling direction. This is very important since the rudder quickly > loses effect because of loss of air flowing past it as it slows. I > won't > comment here on the importance of keeping a tail dragger going straight > while on the ground, other than to say it is the most important aspect > of > flying one. Now, back to landing, if you get to the stall speed before > touching the ground the plane loses all lift and drops to the ground. > Not a > bad landing if the drop is a matter of inches. If the ground is > touched > before slowing to stall speed a return to flight is likely. This is > especially true in a tail dragger because the pitch angle of the wing > is > usually set for a climb when all wheels are on the ground. If you are > flying above stall speed in all likely hood you will touch down on the > main > gear first. As you pull back the tail will lower, creating more lift, > and > you find yourself climbing back into the air. > > In most aircraft the round out and flare are distinct segments of the > landing. The round out might take around 5 seconds and the following > flare > might take 15 to 20 seconds depending on airspeed at the start of the > round > out. Cessnas seem to float forever. > > Now for Aircamper specific observations. This is what it looks like > for me > in the pilot's seat. For many reasons the Aircamper doesn't float > much. > It has a lot of drag. It doesn't go very fast in the first place and > slows > quickly upon reduction of power. Therefore the round out and flare > happen > so quickly that they become one operation. If enough speed is not > carried > in the approach the elevators become ineffective before completing the > round > out/flare and the bungee cords get severely tested. One of the things > you > need to discover is the minimum approach speed that still allows > elevator > control until full stall and touchdown. This is going to probably be > different for each aircraft because of configuration, instrument error, > etc.. 65 mph works for me. 1.3 stall speed is 55 mph. I pancake in > every > time at that speed. I "aim" at the ground and carry 65 mph until a > couple > of feet above the ground and then smoothly pull back for the round > out/flare > and am on the ground in about 30 - 50 feet. No bounce. No drop. > Just a > smooth 3 point landing. > > I would suggest that one of the first things to establish on the first > flight is the stall speed. I would then suggest that the approach be > tested > at no slower than 1.6 times stall speed. If that gives elevator > control but > results in a distinct flare you could reduce the speed in 2 mph steps > until > you find the speed that causes mild elevator loss. You now know the > minimum > approach speed for your plane in that weight configuration. I usually > add a > couple of mph for an adult passenger. > > This is a conservative approach to coming up with numbers you can fly > with. > Although I have only flown my own Aircamper to date, I believe from > listening to others' experiences that this is the best way to approach > your > first landings. What do you say Mike Cuy or Chris? > > I met a list member at Oshkosh in 1999. He had completed his plane in > April > but didn't have it with him. He told me that on the third landing he > bent > the landing gear on a hard touchdown because he ran out of elevator. > Hopefully this discussion will prevent a repeat of that experience. > > All of the above only applies to a power off landing. Carrying a > little > power allows a slightly slower approach speed and still provides > elevator > control during the flare. Cut power at the end of the round out and > end up > with a perfect 3 point landing. > > Hope this helps someone. Sorry this got so long. It is easier to do > than > describe. > > Ted Brousseau > > PS If any of the above does not make sense don't try it alone. Run > out and > get yourself an experienced taildragger pilot to help you. Also, this > does > not address crosswind, upwind, uphill, downhill, short field, soft > field or > wheel landings. > ________________________________________________________________________________
Date: Jan 18, 2004
Walt, You are concerned with a concept called tail volume. Tail volume is the square inch area of the horizontal surface (elevator and satbilizer together) times the distance in inches from the center of pressure of the horizontal stabilizer to the Center of Gravity, this being the point of rotation about which the aircraft moves based on input of the controls. As there are three wood fuselages that I know of, namely the version in the F&G manual and on the Hoopman drawings at 161 inches, the 1933 "Improved Aircamper" at 163 inches, and the fuselage designed for the Corvair at 172.375 inches, I am not sure which one you mean. I always called the Corvair fuselage the Pavliga long fuselage because, well, it is the longest and it is the fuselage used on Sky Gypsy. Anyway, if you take the square inch area of each horizontal design times the distance in inches from the loaded CG to the 33% chord point on each stabilizer design, you will come up with the tail volume...volume because the units will now be cubic inches. The hardest thing will be to figure out your loaded CG. If you make the distance between the CG to the CP of the stabilizer longer, you can get by with a smaller stabilizer area. Shorten up the CG to CP distance and you need to increase the tail area. My analysis of the different fuselages leads me to believe that using the 172.375 fuselage moves the seats back faster than the tail gets longer so it actually puts the CG further aft than on the shorter fuselages. This means that the CG to Cp of the stabilizer is actually a shorter distance so a bigger area stabilizer is needed. Unfortunately, the 172.375" fuselage drawing is a stand alone. No landing gear was ever published for it and neither is there a obviously a stabilizer. I wrote an article on gear placement on the 172.375 inch fuselage that was to be published in the Grant MacLaren published BPA NL but it never made it because the very issue it was to be published in was never published as he quit the post. I will dig it out. Only a hard copy exists, and even it is one of the drafts, so I will have to scan it to OCR software and see if I can post it. I hope this helps. I wish people said what inch fuselage they have when they talk of stuff like this as it really matters (or maybe it doesn't since they all seem to meet each aviator's expectations) Chris Bobka ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 7:04 PM Subject: Re: Pietenpol-List: horizontal stab dimensions I didn't know they were different. I built the long fuse and the tail was from the original prints, so I guess I got the wrong one. but flies great. What two prints show different tails??? walt evans NX140DL ----- Original Message ----- From: Brants To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 5:37 PM Subject: Pietenpol-List: horizontal stab dimensions I built the long fuselage and then (idiodically) built the horiz. stab for the short fuse (18" wide instead of 19 3/8") - didn't realize until today when I tried fitting it up. Question: can I glue a wider leading edge to the horizontal stab to make up the difference? Obviously this would add a bit of weight to the tail section.. Or could I just fill in behind the turtle deck to take up the space? Difference is about 1 3/8". Is the 1 3/8" width going to be missed if I leave it out? Does this cause a problem getting away from the 'airfoil shape'? Another related question: does the horiz. stab get bolted through the longerons? Any help on this would be appreciated. Tom Brant Brooklyn Park, MN ________________________________________________________________________________
<002e01c3de36$350ab400$0101a8c0@domain>
Date: Jan 18, 2004
Chris, I am the one that asked the original question.... You're correct in saying that the drawings stand alone, however if I'd been smart I could have figured on making a larger stabilizer... According to your comments (if I interpreted correctly) the 172 3/8" fuse (this is what I have) requires a larger stabilizer (and elevator??)... My previous post asks this question - can I use the 18" stab (and elevator) now that they're built, or do I need to modify or rebuild? I would be interested in getting a copy of your article on this. Thanks, Tom Brant Brooklyn Park, MN ----- Original Message ----- From: Christian Bobka To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 8:44 PM Subject: Re: Pietenpol-List: horizontal stab dimensions Walt, You are concerned with a concept called tail volume. Tail volume is the square inch area of the horizontal surface (elevator and satbilizer together) times the distance in inches from the center of pressure of the horizontal stabilizer to the Center of Gravity, this being the point of rotation about which the aircraft moves based on input of the controls. As there are three wood fuselages that I know of, namely the version in the F&G manual and on the Hoopman drawings at 161 inches, the 1933 "Improved Aircamper" at 163 inches, and the fuselage designed for the Corvair at 172.375 inches, I am not sure which one you mean. I always called the Corvair fuselage the Pavliga long fuselage because, well, it is the longest and it is the fuselage used on Sky Gypsy. Anyway, if you take the square inch area of each horizontal design times the distance in inches from the loaded CG to the 33% chord point on each stabilizer design, you will come up with the tail volume...volume because the units will now be cubic inches. The hardest thing will be to figure out your loaded CG. If you make the distance between the CG to the CP of the stabilizer longer, you can get by with a smaller stabilizer area. Shorten up the CG to CP distance and you need to increase the tail area. My analysis of the different fuselages leads me to believe that using the 172.375 fuselage moves the seats back faster than the tail gets longer so it actually puts the CG further aft than on the shorter fuselages. This means that the CG to Cp of the stabilizer is actually a shorter distance so a bigger area stabilizer is needed. Unfortunately, the 172.375" fuselage drawing is a stand alone. No landing gear was ever published for it and neither is there a obviously a stabilizer. I wrote an article on gear placement on the 172.375 inch fuselage that was to be published in the Grant MacLaren published BPA NL but it never made it because the very issue it was to be published in was never published as he quit the post. I will dig it out. Only a hard copy exists, and even it is one of the drafts, so I will have to scan it to OCR software and see if I can post it. I hope this helps. I wish people said what inch fuselage they have when they talk of stuff like this as it really matters (or maybe it doesn't since they all seem to meet each aviator's expectations) Chris Bobka ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 7:04 PM Subject: Re: Pietenpol-List: horizontal stab dimensions I didn't know they were different. I built the long fuse and the tail was from the original prints, so I guess I got the wrong one. but flies great. What two prints show different tails??? walt evans NX140DL ----- Original Message ----- From: Brants To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 5:37 PM Subject: Pietenpol-List: horizontal stab dimensions I built the long fuselage and then (idiodically) built the horiz. stab for the short fuse (18" wide instead of 19 3/8") - didn't realize until today when I tried fitting it up. Question: can I glue a wider leading edge to the horizontal stab to make up the difference? Obviously this would add a bit of weight to the tail section.. Or could I just fill in behind the turtle deck to take up the space? Difference is about 1 3/8". Is the 1 3/8" width going to be missed if I leave it out? Does this cause a problem getting away from the 'airfoil shape'? Another related question: does the horiz. stab get bolted through the longerons? Any help on this would be appreciated. Tom Brant Brooklyn Park, MN ________________________________________________________________________________
lengths
Subject: PhD dissertation on axle placement among the different
fuselage lengths
Date: Jan 18, 2004
Walt, The following is related to your issue and I hope becomes a classic posting that is referenced by many for years to come. I wrote it 5 years ago almost to the day in response to a question posed by Greg Cardinal. It was about 5 hours of research and headscratching. Of course, it will prompt some controversy. Since the fisherman is gone, we haven't had much. This was supposed to have been published in MacLaren's BPA newsletter. I sent it to him but he never came out with the next edition (and took everybody's money - but he did a good job). I think I will send it to Doc Mosher to put in To Fly! It appears that the 1932 fuselage has the wood gear axle about 13.5 inches aft of the firewall. The 1933 Improved Air Camper has the axle 17 inches aft of the firewall. The weight and balance sheet I have from Don Pietenpol shows the axle on the "1937 Air Camper with Corvair engine" (metal split axle gear on a 163 inch fuselage) at 16.5 inches aft of the firewall. The question Dale is asking is how far aft of the firewall should the axle be on the Pavliga long fuselage for which we have no help from the drawings? The 1932 fuselage (Hoopman drawings and 1932 Flying and Glider Manual) is 161 inches long. The 1933 Improved Air Camper fuselage is 163 inches long. The Pavliga long fuselage is 172.375 inches long. This is the one I understand you have built. It appears that the intersection of the first truss verticals with the lower longeron on the 1932 fuselage is 8.375 or 8.5 inches aft of the firewall, depending on which set of plans you look at. On the 1933 Improved fuselage, it is 10 inches, and on the Pavliga long fuselage, it is 12 inches. This would mean that the wood gear, unmodified from the 1932 plans and as mounted on the Pavliga long fuselage, would put the axle 12-8.5 or 3.5 inches farther aft on the long fuselage than on the 1932 fuselage. It would be at 13.5 (see paragraph 1 sentence 1) + 3.5 or 17 inches aft of the firewall. Is this a good place for it? Frank P. said it was too far forward at 17 inches aft of the firewall so he moved it aft when he did the engine switch. A better indicator of proper gear position is comparing it to the rear seat back position in the particular fuselage since this indicates the shift aft of the CG position as the fuselages have been stretched. The rear seat back (at the top longeron) in the 1932 fuselage is 70.5 inches aft of the firewall. The rear seat back in the 1933 Improved fuselage is 72.25 inches aft of the firewall. The rear seat back of the Pavliga long fuselage is 76.25 inches aft of the firewall. This is a substantial shift aft in the position of the CG versus the axle position as the fuselage is stretched. Therefore, the axle on the 1932 fuselage is 70.5 -13.5 or 57 inches forward of the rear seat back. The axle on the 1933 Improved is 72.25 -17 or 55.25 inches forward of the rear seat back. Let us ignore the value from the 1932 fuselage for reasons to be discussed later. Using the number from 1933 and applying this to the Pavliga long fuselage, we should have the axle at 76.25 - 55.25 or 21 inches aft of the firewall. Two paragraphs ago we determined that it will actually wind up at 17 inches aft of the firewall with the wood gear, unmodified, and Frank P. says this is too far forward. Therefore, it appears that we need to redesign the gear so that the axle will sit farther aft in the V to the tune of about 21 -17 or 4 inches. As we noted above, if you look at the sweep of the V in the 1932 plans, you will note that the front attach of the V is at 8.5 inches aft of the firewall. We know that the axle is about 13.5 inches aft of the firewall. Therefore, the sweep is 13.5 - 8.5 or 5 inches for the wood gear. Doing the same analysis for the 1933 Improved Air Camper, we know the front attach of the V is at 10 inches aft of the firewall and the axle is at 17 inches aft of the firewall. Therefore the sweep is 17 -10 or 7 inches for the split axle gear. The next sentence is important. If you put the 1932 wood gear on a 1933 Improved fuselage, you would have an axle that will be 7 - 5 or 2 inches forward of where it would have been if you had used the split axle gear!!!! So the gears are not necessarily interchangeable!!! Logic says that it does not matter which style gear you use. The axle should always be in the same relative position. I see this as an admission by BP that the original 1932 axle was too far forward by 2 inches. And now we know what Frank P. was talking about!!!! It is obvious that BP saw fit, when designing the 1933 Improved Air Camper, that if he lengthened the fuselage from 161 to 163 inches and moved the pilot's rear seat back aft by 1.75 inches, then he must move the axle aft by 17 -13.5 - 2 or 1.5 inches. (Consider 2 of the 3.5 inch difference between 17 and 13.5 as a design correction and the remaining 1.5 of the 3.5 inches to be an adjustment for the new fuselage length and movement aft of the rear seat back.) So what would BP do if he made the fuselage 172.375 inches long (a whopping 9.375 inches longer) and moved the rear seat back aft yet another 76.25 -72.25 or 4 inches? As mentioned before, I propose a redesign of the V to allow the axle to sit 4 inches further aft of where it sits in the 1932 V. This makes sense. As just discussed, the original sweep was 5 inches. The new proposed sweep is 5 + 4 or 9 inches. This is reasonable compared to BP's increase of sweep in the split axle gear to 7 inches for a slightly longer fuselage with a repositioned pilot. Adding even more length for the Pavliga long fuselage and moving the pilot an astounding 4 more inches aft over the 1933 fuselage and 5.75 more inches aft over the 1932 fuselage definitely calls for an adjustment in the sweep of the wood V. As I see it, after BP's design correction is factored in, if you want to use a wood straight axle gear in the short 161 inch long 1932 fuselage, then the axle should be at 13.5+2 (the 2 inch correction) or 15.5 inches aft of the firewall (the V has a 7 inch sweep). If you want to use a wood straight axle gear in the 163 inch long Improved Air Camper fuselage, then the axle should be at the same location as in the split axle gear, 17 inches aft of the firewall (the V has a 7 inch sweep). If you want to use a wood straight axle gear in the 172.375 inch long Pavliga long fuselage, then the axle should be 21 inches aft of the firewall (the V should have a 9 inch sweep). Frank P. started with 5 inch sweep and ended up with 7 inch sweep after his engine swap and gear modification. I propose that a 9 inch sweep is optimal but you could probably get by just fine with the 7 inch sweep. Either way, I would not use the 1932 gear as it is on the drawings. Does this help? I rest my case and am going to bed. Chris Bobka ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 7:04 PM Subject: Re: Pietenpol-List: horizontal stab dimensions I didn't know they were different. I built the long fuse and the tail was from the original prints, so I guess I got the wrong one. but flies great. What two prints show different tails??? walt evans NX140DL ----- Original Message ----- From: Brants To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 5:37 PM Subject: Pietenpol-List: horizontal stab dimensions I built the long fuselage and then (idiodically) built the horiz. stab for the short fuse (18" wide instead of 19 3/8") - didn't realize until today when I tried fitting it up. Question: can I glue a wider leading edge to the horizontal stab to make up the difference? Obviously this would add a bit of weight to the tail section.. Or could I just fill in behind the turtle deck to take up the space? Difference is about 1 3/8". Is the 1 3/8" width going to be missed if I leave it out? Does this cause a problem getting away from the 'airfoil shape'? Another related question: does the horiz. stab get bolted through the longerons? Any help on this would be appreciated. Tom Brant Brooklyn Park, MN ________________________________________________________________________________
Subject: Plans Differences
Date: Jan 18, 2004
Hello, My name is Mike McCarty, I'm a wannabe Piet builder in New Mexico. So far I only have the 1932 F&GM plans and was going to start building the tail surfaces from these plans. These plans were very clear to me and I didn't have a doubt in my mind about how the tail surfaces went together until I started reading the list archives here. Some messages made reference to the thickness of materials not adding up. Aside from tapering the main 3/4" beam on the horizontal stab to match the 5/8" material on the sides and tapering the sides to match the 3/4" leading edge the dimensions add up on the 1932 plans. I then realized that some of the dimensions being called out in these messages didn't jibe with the dimensions on the 1932 plans. The messages refer to a 1/8" rabbet in the leading edge material to accept the 3/32" ribs. This leaves a 1/2" thick web behind the leading edge. The 1932 plans call for a 3/32" rabbet leaving a 3/8" web. Some of the messages refer to a 3/4" diagonal brace in the H stab. I don't see this in these plans. So, are there a lot of significant differences between the D. Pietenpol supplied plans and the 1932 plans? I realize the newer plans show options for extended fuselage and split wing design, but I expected the tail surafeces to be the same... -Mac ________________________________________________________________________________
<002e01c3de36$350ab400$0101a8c0@domain> <000b01c3de3f$9285bd10$53246b43@youru10ixi0anw>
Date: Jan 18, 2004
Tom, I just refined the article and posted it to this list a minute ago. The article is not about the stabilizer size but it gets you thinking a little bit about the fuselage. I will look around and come up with my opinion on the stabilizer. Wait a little and see what the others say too. It really all depends on what loaded CGs others with the same fuselage have. And the CG needs to be given relative to a fixed point on the fuselage that is common to your fuselage i.e. the wing leading edge datum (an awful place to use) is not at all useful unless we know that particular ship's wing leading edge postion relative to the fixed point on the fuselage that is common to your fuselage. Chris Chris ----- Original Message ----- From: Brants To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 9:51 PM Subject: Re: Pietenpol-List: horizontal stab dimensions Chris, I am the one that asked the original question.... You're correct in saying that the drawings stand alone, however if I'd been smart I could have figured on making a larger stabilizer... According to your comments (if I interpreted correctly) the 172 3/8" fuse (this is what I have) requires a larger stabilizer (and elevator??)... My previous post asks this question - can I use the 18" stab (and elevator) now that they're built, or do I need to modify or rebuild? I would be interested in getting a copy of your article on this. Thanks, Tom Brant Brooklyn Park, MN ----- Original Message ----- From: Christian Bobka To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 8:44 PM Subject: Re: Pietenpol-List: horizontal stab dimensions Walt, You are concerned with a concept called tail volume. Tail volume is the square inch area of the horizontal surface (elevator and satbilizer together) times the distance in inches from the center of pressure of the horizontal stabilizer to the Center of Gravity, this being the point of rotation about which the aircraft moves based on input of the controls. As there are three wood fuselages that I know of, namely the version in the F&G manual and on the Hoopman drawings at 161 inches, the 1933 "Improved Aircamper" at 163 inches, and the fuselage designed for the Corvair at 172.375 inches, I am not sure which one you mean. I always called the Corvair fuselage the Pavliga long fuselage because, well, it is the longest and it is the fuselage used on Sky Gypsy. Anyway, if you take the square inch area of each horizontal design times the distance in inches from the loaded CG to the 33% chord point on each stabilizer design, you will come up with the tail volume...volume because the units will now be cubic inches. The hardest thing will be to figure out your loaded CG. If you make the distance between the CG to the CP of the stabilizer longer, you can get by with a smaller stabilizer area. Shorten up the CG to CP distance and you need to increase the tail area. My analysis of the different fuselages leads me to believe that using the 172.375 fuselage moves the seats back faster than the tail gets longer so it actually puts the CG further aft than on the shorter fuselages. This means that the CG to Cp of the stabilizer is actually a shorter distance so a bigger area stabilizer is needed. Unfortunately, the 172.375" fuselage drawing is a stand alone. No landing gear was ever published for it and neither is there a obviously a stabilizer. I wrote an article on gear placement on the 172.375 inch fuselage that was to be published in the Grant MacLaren published BPA NL but it never made it because the very issue it was to be published in was never published as he quit the post. I will dig it out. Only a hard copy exists, and even it is one of the drafts, so I will have to scan it to OCR software and see if I can post it. I hope this helps. I wish people said what inch fuselage they have when they talk of stuff like this as it really matters (or maybe it doesn't since they all seem to meet each aviator's expectations) Chris Bobka ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 7:04 PM Subject: Re: Pietenpol-List: horizontal stab dimensions I didn't know they were different. I built the long fuse and the tail was from the original prints, so I guess I got the wrong one. but flies great. What two prints show different tails??? walt evans NX140DL ----- Original Message ----- From: Brants To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 5:37 PM Subject: Pietenpol-List: horizontal stab dimensions I built the long fuselage and then (idiodically) built the horiz. stab for the short fuse (18" wide instead of 19 3/8") - didn't realize until today when I tried fitting it up. Question: can I glue a wider leading edge to the horizontal stab to make up the difference? Obviously this would add a bit of weight to the tail section.. Or could I just fill in behind the turtle deck to take up the space? Difference is about 1 3/8". Is the 1 3/8" width going to be missed if I leave it out? Does this cause a problem getting away from the 'airfoil shape'? Another related question: does the horiz. stab get bolted through the longerons? Any help on this would be appreciated. Tom Brant Brooklyn Park, MN ________________________________________________________________________________
Subject: Spruce for ribs on eBay
Date: Jan 19, 2004
Need spruce for ribs? Here's some located in Cincinnati, possibly a great start for someone doing ribs: I copied this from the ad: "Here are the deatils... a.. Each strip is 1/2" wide X 1/4" thick X 6' long b.. Approx 30 to 40 pieces ( I did not count them) c.. Was intended for the wing ribs of a Pietenpol Aircamper. d.. Has been stored in a dry location, but cannot guarantee the wood's condition. Buy at your own risk. e.. Still in original wood shipping crate." I don't know the person (and have NO association with him) but it looks like a treasure to me.... It's auction number: 2455258271 Jim in Plano ________________________________________________________________________________
Date: Jan 19, 2004
Subject: Re: Spruce for ribs on eBay
>Need spruce for ribs? > >Here's some located in Cincinnati, possibly a great start for >someone doing ribs: > >I copied this from the ad: > >"Here are the deatils... > >Each strip is 1/2" wide X 1/4" thick X 6' long >Approx 30 to 40 pieces ( I did not count them) >Was intended for the wing ribs of a Pietenpol Aircamper. >Has been stored in a dry location, but cannot guarantee the wood's >condition. Buy at your own risk. >Still in original wood shipping crate." > >I don't know the person (and have NO association with him) but it >looks like a treasure to me.... > >It's auction number: 2455258271 > >Jim in Plano Jim, Was there an identifying name with this ad (a real person's name, not a screen name)? This sounds a lot llike the guy I bought my project from, Bob LeTart. I got of a set of ribs with it, but half of them had been built by someone other than him, which means he could have wood to make a 3rd half-set left over (if that makes sense). If so, then I'd say this is probably a safe deal. Regards, Kip Gardner (still snowing & cold in OH, almost done restoring the 50+-year-old sled for my daughter) -- North Canton, OH ________________________________________________________________________________
Subject: landings
Date: Jan 19, 2004
[This message didn't go through for some reason, so I am re-sending it again as a forwarded message.] ----- Original Message ----- From: Graham Hansen <grhans@cable-lynx.net> Subject: Re: Pietenpol-List: landings > REF. Ted Brousseau's post on January 15, 2004 > > Ted, > > Your excellent dissertation on Pietenpol 3-point landing technique is > consistent with my own experience flying my Pietenpol Air Camper > and three other Piets. In total, I have about 760 hours and literally > thousands of landings with Pietenpols, but this is spread over many > years and I need to get out and get some practice once the weather > warms up. > > I agree completely with your observation that 1.3 x stalling speed = 55 > mph is too slow for a power-off approach speed; after round-out there > is virtually no "float" and no opportunity make any corrections because > the speed dissipates so rapidly. One's judgment needs to be absolutely > accurate in order to make a good landing and a heavy landing is a very > real possibility. > > If a power-off approach and landing is made, your suggested approach > speed of 65 mph will work fine with my Pietenpol, although I like to ap- > proach at 70 if it is gusty or if I have a load. We are at 2500' asl and, > on a hot summer day, one needs to be careful---especially when loaded > to, or near, gross weight. Under these conditions I will generally use a > "touch" of power to flatten the approach angle and carry it through the > flare. I feel that extra airspeed is "money in the bank" when flying a drag- > gy airplane, and getting rid of any excess speed never seems to be a > problem.with the Pietenpols and biplanes I have flown. > > A power-off approach in a Pietenpol is steep compared to other light- > planes of similar power (Taylorcraft, Luscombe, etc.). My Sperry Mes- > senger Biplane reproduction has a steeper approach angle, but my Piper > PA17 Vagabond, with the same wingspan as my Pietenpol, doesn't ap- > proach so steeply. As you aptly put it, one does indeed take "aim" at > the ground with a Pietenpol (or a biplane), and generally you will touch > down very close to the aiming point. > > Wheel landings, with the Piets I have flown, are much easier to accom- > plish than 3-pointers. Perhaps this is due to the main wheels not being > located too far forward. With all four Pietenpols it was easy to taxi all > over the place with the tail up by using just enough power. On the land- > ing approach my Pietenpol is fairly nose-heavy with reduced power, or > power-off, and this reduces, or eliminates, the need to "pin it on" with > forward stick once the mainwheels touch. One simply releases back > pressure on the stick upon contact. For me, with my aging reflexes, > this is good! > > In my humble opinion, if one can fly a J-3 Cub well from the rear seat, > he/she would do fine with a Pietenpol, provided they are made aware > of the dragginess of the latter. The Pietenpol is not a difficult airplane > to > fly, but it demands proper technique to make consistently good landings > (particularly 3-pointers). > > Happy landings, > > Graham Hansen > (Pietenpol CF-AUN in somewhat chilly Alberta, Canada) > > ________________________________________________________________________________
Date: Jan 19, 2004
Yes he is still selling them. They look great but do require some filing. His phone is 507-288-3322. Good luck, Greg Menoche Delaware ________________________________________________________________________________
Date: Jan 19, 2004
What is a FLY CUTTER? Greg Delaware ________________________________________________________________________________
Date: Jan 19, 2004
Netscape/7.1 (ax) These are the cast aluminum elevator and rudder hinges correct? Rick H Gnwac(at)cs.com wrote: > Yes he is still selling them. They look great but do require some > filing. His phone is 507-288-3322. > Good luck, > Greg Menoche > Delaware ________________________________________________________________________________
Date: Jan 19, 2004
Here is one pic I found on the net. It's adjustable for hole size. The BIG trick for a good hole is to cut about half way thru on one side and turn wood over to finish. This way no raggid edges walt evans NX140DL ----- Original Message ----- From: Gnwac(at)cs.com To: pietenpol-list(at)matronics.com Sent: Monday, January 19, 2004 1:59 PM Subject: Re: Pietenpol-List: Cutting plywood What is a FLY CUTTER? Greg Delaware ________________________________________________________________________________
Date: Jan 19, 2004
(ax)
Tom, Vi Kapler is still selling the hinges. I bought a set from him at Brodhead this past summer Rick Schreiber Valparaiso, IN Brants wrote: > Anyone have a photo or some info on Vi Kaplers hinges? Is he selling > / making them? How can I reach him? I'm working on the tail section > over the winter and I'll soon be ready for some hinges to put it all > together. > > > > Tom Brant > Brooklyn Park, MN > > ------ USFamily.Net <http://www.usfamily.net/info> - Unlimited > Internet - From $8.99/mo! ------ > ________________________________________________________________________________
Date: Jan 19, 2004
Chris, I am building the long fuselage and would appreciate the information you worked up on larger stabs. Thanks Alex Sloan alexms(at)bellsouth.net ----- Original Message ----- From: Brants To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 9:51 PM Subject: Re: Pietenpol-List: horizontal stab dimensions Chris, I am the one that asked the original question.... You're correct in saying that the drawings stand alone, however if I'd been smart I could have figured on making a larger stabilizer... According to your comments (if I interpreted correctly) the 172 3/8" fuse (this is what I have) requires a larger stabilizer (and elevator??)... My previous post asks this question - can I use the 18" stab (and elevator) now that they're built, or do I need to modify or rebuild? I would be interested in getting a copy of your article on this. Thanks, Tom Brant Brooklyn Park, MN ----- Original Message ----- From: Christian Bobka To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 8:44 PM Subject: Re: Pietenpol-List: horizontal stab dimensions Walt, You are concerned with a concept called tail volume. Tail volume is the square inch area of the horizontal surface (elevator and satbilizer together) times the distance in inches from the center of pressure of the horizontal stabilizer to the Center of Gravity, this being the point of rotation about which the aircraft moves based on input of the controls. As there are three wood fuselages that I know of, namely the version in the F&G manual and on the Hoopman drawings at 161 inches, the 1933 "Improved Aircamper" at 163 inches, and the fuselage designed for the Corvair at 172.375 inches, I am not sure which one you mean. I always called the Corvair fuselage the Pavliga long fuselage because, well, it is the longest and it is the fuselage used on Sky Gypsy. Anyway, if you take the square inch area of each horizontal design times the distance in inches from the loaded CG to the 33% chord point on each stabilizer design, you will come up with the tail volume...volume because the units will now be cubic inches. The hardest thing will be to figure out your loaded CG. If you make the distance between the CG to the CP of the stabilizer longer, you can get by with a smaller stabilizer area. Shorten up the CG to CP distance and you need to increase the tail area. My analysis of the different fuselages leads me to believe that using the 172.375 fuselage moves the seats back faster than the tail gets longer so it actually puts the CG further aft than on the shorter fuselages. This means that the CG to Cp of the stabilizer is actually a shorter distance so a bigger area stabilizer is needed. Unfortunately, the 172.375" fuselage drawing is a stand alone. No landing gear was ever published for it and neither is there a obviously a stabilizer. I wrote an article on gear placement on the 172.375 inch fuselage that was to be published in the Grant MacLaren published BPA NL but it never made it because the very issue it was to be published in was never published as he quit the post. I will dig it out. Only a hard copy exists, and even it is one of the drafts, so I will have to scan it to OCR software and see if I can post it. I hope this helps. I wish people said what inch fuselage they have when they talk of stuff like this as it really matters (or maybe it doesn't since they all seem to meet each aviator's expectations) Chris Bobka ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 7:04 PM Subject: Re: Pietenpol-List: horizontal stab dimensions I didn't know they were different. I built the long fuse and the tail was from the original prints, so I guess I got the wrong one. but flies great. What two prints show different tails??? walt evans NX140DL ----- Original Message ----- From: Brants To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 5:37 PM Subject: Pietenpol-List: horizontal stab dimensions I built the long fuselage and then (idiodically) built the horiz. stab for the short fuse (18" wide instead of 19 3/8") - didn't realize until today when I tried fitting it up. Question: can I glue a wider leading edge to the horizontal stab to make up the difference? Obviously this would add a bit of weight to the tail section.. Or could I just fill in behind the turtle deck to take up the space? Difference is about 1 3/8". Is the 1 3/8" width going to be missed if I leave it out? Does this cause a problem getting away from the 'airfoil shape'? Another related question: does the horiz. stab get bolted through the longerons? Any help on this would be appreciated. Tom Brant Brooklyn Park, MN ________________________________________________________________________________
Date: Jan 19, 2004
different fu...
Subject: Re: PhD dissertation on axle placement among the different
fu... Chris, Thanks for a GREAT article ref. the 172 inch fuse builders out here. Your research and experience helps for those of us, me, who are just getting started and learning as we go. Greg Menoche Delaware ________________________________________________________________________________
Date: Jan 19, 2004
Tom, As I see it, there are two stabs. One is rectangular in shape, as in the 1932 F and G Manual, and the other sweeps about 80 degrees at the tips, as in the 1933 Improved Aircamper. Otherwise, they all have 18" chord. Anybody else in on this? Mike C.? chris bobka ----- Original Message ----- From: Brants To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 9:51 PM Subject: Re: Pietenpol-List: horizontal stab dimensions Chris, I am the one that asked the original question.... You're correct in saying that the drawings stand alone, however if I'd been smart I could have figured on making a larger stabilizer... According to your comments (if I interpreted correctly) the 172 3/8" fuse (this is what I have) requires a larger stabilizer (and elevator??)... My previous post asks this question - can I use the 18" stab (and elevator) now that they're built, or do I need to modify or rebuild? I would be interested in getting a copy of your article on this. Thanks, Tom Brant Brooklyn Park, MN ----- Original Message ----- From: Christian Bobka To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 8:44 PM Subject: Re: Pietenpol-List: horizontal stab dimensions Walt, You are concerned with a concept called tail volume. Tail volume is the square inch area of the horizontal surface (elevator and satbilizer together) times the distance in inches from the center of pressure of the horizontal stabilizer to the Center of Gravity, this being the point of rotation about which the aircraft moves based on input of the controls. As there are three wood fuselages that I know of, namely the version in the F&G manual and on the Hoopman drawings at 161 inches, the 1933 "Improved Aircamper" at 163 inches, and the fuselage designed for the Corvair at 172.375 inches, I am not sure which one you mean. I always called the Corvair fuselage the Pavliga long fuselage because, well, it is the longest and it is the fuselage used on Sky Gypsy. Anyway, if you take the square inch area of each horizontal design times the distance in inches from the loaded CG to the 33% chord point on each stabilizer design, you will come up with the tail volume...volume because the units will now be cubic inches. The hardest thing will be to figure out your loaded CG. If you make the distance between the CG to the CP of the stabilizer longer, you can get by with a smaller stabilizer area. Shorten up the CG to CP distance and you need to increase the tail area. My analysis of the different fuselages leads me to believe that using the 172.375 fuselage moves the seats back faster than the tail gets longer so it actually puts the CG further aft than on the shorter fuselages. This means that the CG to Cp of the stabilizer is actually a shorter distance so a bigger area stabilizer is needed. Unfortunately, the 172.375" fuselage drawing is a stand alone. No landing gear was ever published for it and neither is there a obviously a stabilizer. I wrote an article on gear placement on the 172.375 inch fuselage that was to be published in the Grant MacLaren published BPA NL but it never made it because the very issue it was to be published in was never published as he quit the post. I will dig it out. Only a hard copy exists, and even it is one of the drafts, so I will have to scan it to OCR software and see if I can post it. I hope this helps. I wish people said what inch fuselage they have when they talk of stuff like this as it really matters (or maybe it doesn't since they all seem to meet each aviator's expectations) Chris Bobka ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 7:04 PM Subject: Re: Pietenpol-List: horizontal stab dimensions I didn't know they were different. I built the long fuse and the tail was from the original prints, so I guess I got the wrong one. but flies great. What two prints show different tails??? walt evans NX140DL ----- Original Message ----- From: Brants To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 5:37 PM Subject: Pietenpol-List: horizontal stab dimensions I built the long fuselage and then (idiodically) built the horiz. stab for the short fuse (18" wide instead of 19 3/8") - didn't realize until today when I tried fitting it up. Question: can I glue a wider leading edge to the horizontal stab to make up the difference? Obviously this would add a bit of weight to the tail section.. Or could I just fill in behind the turtle deck to take up the space? Difference is about 1 3/8". Is the 1 3/8" width going to be missed if I leave it out? Does this cause a problem getting away from the 'airfoil shape'? Another related question: does the horiz. stab get bolted through the longerons? Any help on this would be appreciated. Tom Brant Brooklyn Park, MN ________________________________________________________________________________
Date: Jan 19, 2004
Subject: Re: vi kapler hinges
Yes Rick, They are cast aluminum. He sells a set of 9 and include the pin to mate the two halves. They are about $40. Greg Menoche Delaware ________________________________________________________________________________
Date: Jan 19, 2004
<002e01c3de36$350ab400$0101a8c0@domain> <000b01c3de3f$9285bd10$53246b43@youru10ixi0anw> <005701c3df04$2a7b6920$d401a8c0@Alex> I'm having some difficulty seeing why a longer fuselage would require a larger horizontal stabilizer. The longer fuselage puts the stab farther away from the CG, giving it more authority over the airplane's attitude. In Chris Bobka's terms, the longer arm increases tail volume without needing to increase the stab area. I have a long fuselage and the stab and elevators are built to original plans (signed by Orrin Hoopman). Mike Hardaway Fresh out of Corvair College and looking for a core. ________________________________________________________________________________
Date: Jan 19, 2004
Chris, Please post or send to me too. Have yet to build the tail, but better to research now than later. Greg Menoche Delaware Gnwac(at)cs.com ________________________________________________________________________________
Date: Jan 19, 2004
<002e01c3de36$350ab400$0101a8c0@domain> <000b01c3de3f$9285bd10$53246b43@youru10ixi0anw> <005701c3df04$2a7b6920$d401a8c0@Alex> I guess I should have included in my prior post that my long fuselage has 125-1/8 inches between the aft wing attach point and the tail post. The short fuselage has 117-3/4 inches for the same dimension. That indicates to me that, even if the wing is moved aft a little to accommodate a rearward CG shift, the CG is still farther from the tail post in a long fuselage than in a standard length fuse. This is what tells me you don't need to build a larger stabilizer with a long fuselage. Mike Hardaway Still looking. ________________________________________________________________________________
Date: Jan 19, 2004
Subject: Re: Cutting plywood
Don't use this thing in a hand drill. It is very much out of balance with one cutter way off center, and be very careful of it in a drill press. It has a lot of torque so take it easy. There is one I've seen with a counter weight on the opposite side but most don't. It does work quite well in a drill press following Walt's rules. If you want to cut thick material drill the center hole first and it will go easier. There is another fly cutter. It's a very small knife. Buzzzz. Clif ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Monday, January 19, 2004 1:01 PM Subject: Re: Pietenpol-List: Cutting plywood Here is one pic I found on the net. It's adjustable for hole size. The BIG trick for a good hole is to cut about half way thru on one side and turn wood over to finish. This way no raggid edges walt evans NX140DL ----- Original Message ----- From: Gnwac(at)cs.com To: pietenpol-list(at)matronics.com Sent: Monday, January 19, 2004 1:59 PM Subject: Re: Pietenpol-List: Cutting plywood What is a FLY CUTTER? Greg Delaware ________________________________________________________________________________
<002e01c3de36$350ab400$0101a8c0@domain> <000b01c3de3f$9285bd10$53246b43@youru10ixi0anw> <005701c3df04$2a7b6920$d401a8c0@Alex> <400CAACA.26B8A414(at)verizon.net>
Date: Jan 20, 2004
Mike, As I posted earlier, with the seats moved way aft in the 170+" fuselage, the CG is moving aft faster than the arm is getting longer if the arm gets longer at all, when compared to the shorter fuselages. I would like to see some numbers from flying ships, with the CG locations given relative to a COMMON point. The wing LE does not cut it as you move the wing around and that makes the numbers incomparable from ship to ship. One needs to use a fixed location on the fuselage not likely to be tampered with by the builder as is the firewall. I truly believe that the 170+" long fuselage has a tendency to get tail heavy much more easily than the shorter fuselages. I believe that the CG to 'Cp of the stab' distance is shortest with the 170+" fuselage, despite how it might look. This would mean the 170+" fuselage would have the smallest tail volume of all the fuselage variants. To compensate, maybe the tail does need to be made bigger, as Tom Brants suggests. Anyone out there with good weight and balance data to share, with it converted to use, say, the forward cabane strut to upper longeron fitting bolt on the longeron as the datum? Need it for both the shorter and longer fuselages. Anyone measure the stabilizer chord on "The Last Original"? Merely my opinion and waiting for facts to roll in. Believe me, I am a build it stock kind of guy but when you are dealing with the long fuselage, there is not much else given than a fuselage drawing. We are on our own for the rest. chris bobka ----- Original Message ----- From: "Mike" <bike.mike(at)verizon.net> Subject: Re: Pietenpol-List: horizontal stab dimensions > > > I guess I should have included in my prior post that my long fuselage > has 125-1/8 inches between the aft wing attach point and the tail post. > The short fuselage has 117-3/4 inches for the same dimension. That > indicates to me that, even if the wing is moved aft a little to > accommodate a rearward CG shift, the CG is still farther from the tail > post in a long fuselage than in a standard length fuse. This is what > tells me you don't need to build a larger stabilizer with a long > fuselage. > > Mike Hardaway > Still looking. > > ________________________________________________________________________________
<00d301c3df1b$0ecad230$96715118@dawsonaviation>
Date: Jan 20, 2004
Two rules of fly cutting. Never use it in anything BUT a drill press. Never hold the item being flycut in your hand. It MUST be clamped to the drill press table and you have one hand on the downfeed and the other poised over the off switch. That way you never have to look away from the work until after the drill press is shut off. Chris Bobka who drove his USMC aviator buddy to the hospital for 30+ stiches in his palm after he violated rule 2. chris bobka ----- Original Message ----- From: Clif Dawson To: pietenpol-list(at)matronics.com Sent: Tuesday, January 20, 2004 12:02 AM Subject: Re: Pietenpol-List: Cutting plywood Don't use this thing in a hand drill. It is very much out of balance with one cutter way off center, and be very careful of it in a drill press. It has a lot of torque so take it easy. There is one I've seen with a counter weight on the opposite side but most don't. It does work quite well in a drill press following Walt's rules. If you want to cut thick material drill the center hole first and it will go easier. There is another fly cutter. It's a very small knife. Buzzzz. Clif ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Monday, January 19, 2004 1:01 PM Subject: Re: Pietenpol-List: Cutting plywood Here is one pic I found on the net. It's adjustable for hole size. The BIG trick for a good hole is to cut about half way thru on one side and turn wood over to finish. This way no raggid edges walt evans NX140DL ----- Original Message ----- From: Gnwac(at)cs.com To: pietenpol-list(at)matronics.com Sent: Monday, January 19, 2004 1:59 PM Subject: Re: Pietenpol-List: Cutting plywood What is a FLY CUTTER? Greg Delaware ________________________________________________________________________________
Subject: Cutting plywood
Date: Jan 20, 2004
I guess I got off lucky - I only had 14 stitches in my thumb after violating rule #2. Be VERY careful as the cutter finishes piercing the metal. At that point it can have a tendency to "bite" into the work piece and can pull it out of your hand over even out of the clamps holding it to the bench if you are not careful. I consider the fly cutter to be one of the most dangerous tools in the shop. Be sure there is somebody home who can drive you to the hospital while you are using it. Seriously. Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Christian Bobka Subject: Re: Pietenpol-List: Cutting plywood Two rules of fly cutting. Never use it in anything BUT a drill press. Never hold the item being flycut in your hand. It MUST be clamped to the drill press table and you have one hand on the downfeed and the other poised over the off switch. That way you never have to look away from the work until after the drill press is shut off. Chris Bobka who drove his USMC aviator buddy to the hospital for 30+ stiches in his palm after he violated rule 2. chris bobka ----- Original Message ----- From: Clif Dawson <mailto:cdawson5854(at)shaw.ca> Subject: Re: Pietenpol-List: Cutting plywood Don't use this thing in a hand drill. It is very much out of balance with one cutter way off center, and be very careful of it in a drill press. It has a lot of torque so take it easy. There is one I've seen with a counter weight on the opposite side but most don't. It does work quite well in a drill press following Walt's rules. If you want to cut thick material drill the center hole first and it will go easier. There is another fly cutter. It's a very small knife. Buzzzz. Clif ----- Original Message ----- From: walt evans <mailto:wbeevans(at)verizon.net> Subject: Re: Pietenpol-List: Cutting plywood Here is one pic I found on the net. It's adjustable for hole size. The BIG trick for a good hole is to cut about half way thru on one side and turn wood over to finish. This way no raggid edges walt evans NX140DL ----- Original Message ----- From: Gnwac(at)cs.com <mailto:Gnwac(at)cs.com> Subject: Re: Pietenpol-List: Cutting plywood What is a FLY CUTTER? Greg Delaware ________________________________________________________________________________
Date: Jan 20, 2004
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
Subject: Ted's advice--and flaring too HIGH
> <003401c3daa0$c3e43000$b50ba5d1@LOU> <007101c3dba2$0ad7b700$0101a8c0@domain> Ted B's words on landings in a Piet were right on with what I've experienced and Ted has more time in a Piet than I do plus has been flying since I was 5 years old. Gosh Ted, you must have gotten your ticket when you were 16 ! You are not that old !! The only words I would add to what Ted had to say is that first time flights in a Piet/GN-1, the pilots tend to flare too high. You just are not accustomed to being that low to the ground (visually) in anything you've ever flown before. I looks like you are going to burry the plane on flare but you don't. Just like in a 'tall' taildragger like a Stearman, my first desire was to "make it look right by making it look like what I see on the Piet during landing." That was a mistake. Each plane has it's "view" during the touchdown and the best way to etch that view in your mind is to sit on the runway or taxiway and visualize where the horizon crosses thru your nose---get that picture in your head before you fly it and when you flare, that is the view you need to see to feel for mother earth. Sounds simple, but it works if you study it before your flight. Mike C. in balmy 6 F weather ! ________________________________________________________________________________
Date: Jan 20, 2004
Subject: Re: Wood landing gear question
> <013001c3da49$5eaa6940$0101a8c0@domain> <002801c3db0c$21e126c0$57c5fea9@mke> <005e01c3dbbe$1a2f9120$d401a8c0@Alex> <044301c3dd64$6004c7e0$ceddf6ce@hjarrett> >Does the bottom ash block on each landing gear get glued to the legs or is >it just held in place only with the metal fittings? > Ted-- I got as tight of fit there as I could and T-88'ed those pieces together. First I held them in place with masking tape to get my fittings formed just right so they would not put any force on the legs or ash piece and then glued the blocks in and later did the varnishing, etc. Mike C. ________________________________________________________________________________
Subject: The best Pietenpol article yet.....
Date: Jan 20, 2004
Well, I think it's just about the best one I've seen..... "The Pasture Pilot's Pride & Joy" was published in 1965 and it's a great article about the Pietenpol Air Camper with some mention of the Sky Scout...... This is a good one...... If you'll go into your browser's internet options and disable "Automatic Image Resizing", the pages will display in a size that you can print on your printer at just about the same quality as the original. Or you can save the file to your local drive. It's in the File Library section of mykitplane.com: <http://www.mykitplane.com/Planes/filesList2.cfm?AlbumID43> Enjoy JM ________________________________________________________________________________
Subject: Re: landings
Date: Jan 20, 2004
FWIW, I got my tailwheel endorsement yesterday, so when my instructor said I was "almost there" on New Year's day he meant it. It was the first time I've flown since then, and a chilly, gusty day in southern New Hampshire (but then, we've been getting your Canadian Arctic air a lot the past couple of weeks). Good for demonstrating cross-wind wheel landings, and from the looks of your note I'll need that skill someday when I'm ready to fly my Piet. Thanks again to the list for all of the useful comments, Mark Hodgson ________________________________________________________________________________
Date: Jan 20, 2004
Netscape/7.1 (ax)
Subject: Re: horizontal stab dimensions
<002e01c3de36$350ab400$0101a8c0@domain> <000b01c3de3f$9285bd10$53246b43@youru10ixi0anw> <005701c3df04$2a7b6920$d401a8c0@Alex> Tom My long (172 3/8) fuselage plans (Supplementary Plans) shows the distance from the tailpost to the back of the turtledeck 18 7/8" not 19 3/8". Thats only a 7/8" difference. Still makes you wonder if you should build the stab 18" or 18 7/8" wide. Rick H Alex Sloan wrote: > Chris, > I am building the long fuselage and would appreciate the information > you worked up on larger stabs. > Thanks > Alex Sloan > alexms(at)bellsouth.net > > ----- Original Message ----- > From: Brants <mailto:tmbrant(at)usfamily.net> > To: pietenpol-list(at)matronics.com > > Sent: Sunday, January 18, 2004 9:51 PM > Subject: Re: Pietenpol-List: horizontal stab dimensions > > Chris, > > I am the one that asked the original question.... You're correct > in saying that the drawings stand alone, however if I'd been smart > I could have figured on making a larger stabilizer... > > According to your comments (if I interpreted correctly) the 172 > 3/8" fuse (this is what I have) requires a larger stabilizer (and > elevator??)... My previous post asks this question - can I use > the 18" stab (and elevator) now that they're built, or do I need > to modify or rebuild? > > I would be interested in getting a copy of your article on this. > > Thanks, > > Tom Brant > Brooklyn Park, MN > > ----- Original Message ----- > From: Christian Bobka <mailto:bobka(at)compuserve.com> > To: pietenpol-list(at)matronics.com > > Sent: Sunday, January 18, 2004 8:44 PM > Subject: Re: Pietenpol-List: horizontal stab dimensions > > Walt, > > You are concerned with a concept called tail volume. Tail > volume is the square inch area of the horizontal surface > (elevator and satbilizer together) times the distance in > inches from the center of pressure of the horizontal > stabilizer to the Center of Gravity, this being the point of > rotation about which the aircraft moves based on input of the > controls. > > As there are three wood fuselages that I know of, namely the > version in the F&G manual and on the Hoopman drawings at 161 > inches, the 1933 "Improved Aircamper" at 163 inches, and the > fuselage designed for the Corvair at 172.375 inches, I am not > sure which one you mean. I always called the Corvair fuselage > the Pavliga long fuselage because, well, it is the longest and > it is the fuselage used on Sky Gypsy. > > Anyway, if you take the square inch area of each horizontal > design times the distance in inches from the loaded CG to the > 33% chord point on each stabilizer design, you will come up > with the tail volume...volume because the units will now be > cubic inches. The hardest thing will be to figure out your > loaded CG. > > If you make the distance between the CG to the CP of the > stabilizer longer, you can get by with a smaller stabilizer > area. Shorten up the CG to CP distance and you need to > increase the tail area. > > My analysis of the different fuselages leads me to believe > that using the 172.375 fuselage moves the seats back faster > than the tail gets longer so it actually puts the CG further > aft than on the shorter fuselages. This means that the CG to > Cp of the stabilizer is actually a shorter distance so a > bigger area stabilizer is needed. > > Unfortunately, the 172.375" fuselage drawing is a stand > alone. No landing gear was ever published for it and neither > is there a obviously a stabilizer. > > I wrote an article on gear placement on the 172.375 inch > fuselage that was to be published in the Grant MacLaren > published BPA NL but it never made it because the very issue > it was to be published in was never published as he quit the > post. I will dig it out. Only a hard copy exists, and even > it is one of the drafts, so I will have to scan it to OCR > software and see if I can post it. > > I hope this helps. I wish people said what inch fuselage they > have when they talk of stuff like this as it really matters > (or maybe it doesn't since they all seem to meet each > aviator's expectations) > > Chris Bobka > > > ----- Original Message ----- > From: walt evans <mailto:wbeevans(at)verizon.net> > To: pietenpol-list(at)matronics.com > > Sent: Sunday, January 18, 2004 7:04 PM > Subject: Re: Pietenpol-List: horizontal stab dimensions > > I didn't know they were different. I built the long fuse > and the tail was from the original prints, so I guess I > got the wrong one. but flies great. What two prints show > different tails??? > walt evans > NX140DL > > ----- Original Message ----- > From: Brants <mailto:tmbrant(at)usfamily.net> > To: pietenpol-list(at)matronics.com > > Sent: Sunday, January 18, 2004 5:37 PM > Subject: Pietenpol-List: horizontal stab dimensions > > I built the long fuselage and then (idiodically) built > the horiz. stab for the short fuse (18" wide instead > of 19 3/8") - didn't realize until today when I tried > fitting it up. Question: can I glue a wider leading > edge to the horizontal stab to make up the > difference? Obviously this would add a bit of weight > to the tail section.. Or could I just fill in behind > the turtle deck to take up the space? Difference is > about 1 3/8". Is the 1 3/8" width going to be missed > if I leave it out? Does this cause a problem getting > away from the 'airfoil shape'? > > Another related question: does the horiz. stab get > bolted through the longerons? > > Any help on this would be appreciated. > > Tom Brant > Brooklyn Park, MN > > > > > ------ USFamily.Net <http://www.usfamily.net/info> - > > > ------ USFamily.Net <http://www.usfamily.net/info> - Unlimited > Internet - From $8.99/mo! ------ > ________________________________________________________________________________
Subject: Re: The best Pietenpol article yet.....
Date: Jan 20, 2004
Jim, Thanks, I really enjoyed that article and pictures. The core of why I built a Pietenpol. walt evans NX140DL ----- Original Message ----- From: Jim Markle To: pietenpol-list(at)matronics.com Sent: Tuesday, January 20, 2004 10:58 AM Subject: Pietenpol-List: The best Pietenpol article yet..... Well, I think it's just about the best one I've seen..... "The Pasture Pilot's Pride & Joy" was published in 1965 and it's a great article about the Pietenpol Air Camper with some mention of the Sky Scout...... This is a good one...... If you'll go into your browser's internet options and disable "Automatic Image Resizing", the pages will display in a size that you can print on your printer at just about the same quality as the original. Or you can save the file to your local drive. It's in the File Library section of mykitplane.com: <http://www.mykitplane.com/Planes/filesList2.cfm?AlbumID43> Enjoy JM ________________________________________________________________________________
Subject: ZS-VJA Flies
Date: Jan 20, 2004
Hi all Just thought I'd pop in a quick note my baby flew Sunday for the first time in two years. Got some small mods to do, 1. prop to be repitched (only getting 2000Rpm static). 2. Battery to be moved C of G tad to far fwd. 3. A.S.I to be calibrated Regards, Norman Stapelberg ZS-VJA (115Hrs) South Africa FASI ________________________________________________________________________________
Date: Jan 20, 2004
Subject: congratulations, Mark !
>FWIW, I got my tailwheel endorsement yesterday, Way to go, Mark !!! ________________________________________________________________________________
Subject: Control Surface deflexions
Date: Jan 20, 2004
Hi all Just thought I'd throw this one out there, my pilot/instructor says that I need control surface stop put in. Just by the way what must the deflexions be for the control surfaces? I cannot seem to find them any where. Regards, Norman Stapelberg ZS-VJA (115Hrs) South Africa FASI ________________________________________________________________________________
Date: Jan 20, 2004
MIME_QP_LONG_LINE Rick, If it really bothers a builder to have to build a cover for the gap, it might be cheaper to build the turtle deck longer. I don't think anyone has ever complained that a properly configured Piet has insufficient horizontal stabilizer area, though it is well documented that large, covered, wheels make it want some more vertical stabilizer. You probably can't hurt the design by enlarging the horizontal stab area, but be sure to keep the front flying wires the same distance from the leading edge. Tail flutter hasn't historically been a problem but, considering how limber the thin stab is, you don't want to be the first to flutter test it. Mike Hardaway on 1/20/04 11:19, Rick Holland at at7000ft(at)speedtrail.net wrote: Tom My long (172 3/8) fuselage plans (Supplementary Plans) shows the distance from the tailpost to the back of the turtledeck 18 7/8" not 19 3/8". Thats only a 7/8" difference. Still makes you wonder if you should build the stab 18" or 18 7/8" wide. Rick H ________________________________________________________________________________
Subject: Re: ZS-VJA Flies
Date: Jan 20, 2004
Norman, Good for you! I've seen alot of things from my Piet, but never a giraffe ,elephant or hippo (Oh my) walt evans NX140DL ----- Original Message ----- From: Norman Stapelberg To: pietenpol-list(at)matronics.com Sent: Tuesday, January 20, 2004 2:46 PM Subject: Pietenpol-List: ZS-VJA Flies Hi all Just thought I'd pop in a quick note my baby flew Sunday for the first time in two years. Got some small mods to do, 1.. prop to be repitched (only getting 2000Rpm static). 2.. Battery to be moved C of G tad to far fwd. 3.. A.S.I to be calibrated Regards, Norman Stapelberg ZS-VJA (115Hrs) South Africa FASI ________________________________________________________________________________
Subject: Re: Control Surface deflexions
Date: Jan 20, 2004
Norman, I put stops for aileron deflection only, as per my DAR. Small wood blocks glued in place on the floor, topped with leather for the torque horns to "bump" on. They hit the blocks 'just before' the lower part of the aileron contacts the wing. As for the elevator/rudder, explained that they all had complete free movement with no possibility of interference with each other, so the DAR accepted that. walt evans NX140DL ----- Original Message ----- From: "Norman Stapelberg" <norshel(at)mweb.co.za> Subject: Pietenpol-List: Control Surface deflexions > > > Hi all > > Just thought I'd throw this one out there, my pilot/instructor says that > I need control surface stop put in. Just by the way what must the > deflexions be for the control surfaces? I cannot seem to find them any > where. > > Regards, > Norman Stapelberg > ZS-VJA (115Hrs) > South Africa > FASI > > ________________________________________________________________________________
Subject: definition of sweep
Date: Jan 20, 2004
I had a question as to what I meant by sweep of the axle. The sweep is how far back from the center of the front landing gear attach point the axle is located. If the axle had zero sweep, it would be located directly under the center of the front landing gear attach fitting with the fuselage leveled longitudinally. A 5 inch sweep would have the axle mounted directly beneath a point 5 inches aft of the center of the from landing gear attach point. Chris Bobka ----- Original Message ----- From: MacklemAW(at)aol.com To: bobka(at)compuserve.com Sent: Tuesday, January 20, 2004 9:48 AM Subject: Axle Positioning Chris, Please define "sweep" of the axle for me. Allan W. Macklem TEL: 402 289 2298 FAX: 402 289 3474 "Personal growth comes from being surrounded by smarter people." ________________________________________________________________________________
Date: Jan 20, 2004
I agree with Jack, this type of flycutter is very tricky to use. ( there is also a flycutter that's used with milling machines to smooth large sufaces) If you are going to use this, use clamps to secure the work and imagine the area that the work would spin in if it started rotating.Then keep all body parts out of that area. Also, make sure that the cutters are tight on the piece. There are cutters with tools on both sides. If your going to use one, this type is best as the cut is balanced. I believe harbor frieght carries that type. Please use with caution. Carl ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Tuesday, January 20, 2004 5:59 AM Subject: RE: Pietenpol-List: Cutting plywood I guess I got off lucky - I only had 14 stitches in my thumb after violating rule #2. Be VERY careful as the cutter finishes piercing the metal. At that point it can have a tendency to "bite" into the work piece and can pull it out of your hand over even out of the clamps holding it to the bench if you are not careful. I consider the fly cutter to be one of the most dangerous tools in the shop. Be sure there is somebody home who can drive you to the hospital while you are using it. Seriously. Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Christian Bobka Sent: Tuesday, January 20, 2004 1:26 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Cutting plywood Two rules of fly cutting. Never use it in anything BUT a drill press. Never hold the item being flycut in your hand. It MUST be clamped to the drill press table and you have one hand on the downfeed and the other poised over the off switch. That way you never have to look away from the work until after the drill press is shut off. Chris Bobka who drove his USMC aviator buddy to the hospital for 30+ stiches in his palm after he violated rule 2. chris bobka ----- Original Message ----- From: Clif Dawson To: pietenpol-list(at)matronics.com Sent: Tuesday, January 20, 2004 12:02 AM Subject: Re: Pietenpol-List: Cutting plywood Don't use this thing in a hand drill. It is very much out of balance with one cutter way off center, and be very careful of it in a drill press. It has a lot of torque so take it easy. There is one I've seen with a counter weight on the opposite side but most don't. It does work quite well in a drill press following Walt's rules. If you want to cut thick material drill the center hole first and it will go easier. There is another fly cutter. It's a very small knife. Buzzzz. Clif ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Monday, January 19, 2004 1:01 PM Subject: Re: Pietenpol-List: Cutting plywood Here is one pic I found on the net. It's adjustable for hole size. The BIG trick for a good hole is to cut about half way thru on one side and turn wood over to finish. This way no raggid edges walt evans NX140DL ----- Original Message ----- From: Gnwac(at)cs.com To: pietenpol-list(at)matronics.com Sent: Monday, January 19, 2004 1:59 PM Subject: Re: Pietenpol-List: Cutting plywood What is a FLY CUTTER? Greg Delaware ________________________________________________________________________________
Subject: Re: Control Surface deflections
Date: Jan 20, 2004
on the subject of control cable deflections..... how many degrees are we looking for in the elevator and rudder? DJ Vegh N74DV Mesa, AZ www.imagedv.com/aircamper ________________________________________________________________________________
Subject: elevator/rudder control cable tension and slack
Date: Jan 20, 2004
How many pounds should the elevator and rudder control cables be set to? Also, is it common for the elevator cables to lose some tension and slack when actuating the stick? For instance.... my elevator "up" pull cable is tight when pulling the stick back, but the "down" pull cable loses some tension and slacks slightly. Is this a bad thing? DJ Vegh N74DV Mesa, AZ www.imagedv.com/aircamper ________________________________________________________________________________
<00d301c3df1b$0ecad230$96715118@dawsonaviation> <002101c3df1e$4d1d88e0$0101a8c0@domain>
Date: Jan 20, 2004
Chris, Another rule for using the fly cutter, feed it into the material SLOWLY. Alex Sloan ----- Original Message ----- From: Christian Bobka To: pietenpol-list(at)matronics.com Sent: Tuesday, January 20, 2004 12:26 AM Subject: Re: Pietenpol-List: Cutting plywood Two rules of fly cutting. Never use it in anything BUT a drill press. Never hold the item being flycut in your hand. It MUST be clamped to the drill press table and you have one hand on the downfeed and the other poised over the off switch. That way you never have to look away from the work until after the drill press is shut off. Chris Bobka who drove his USMC aviator buddy to the hospital for 30+ stiches in his palm after he violated rule 2. chris bobka ----- Original Message ----- From: Clif Dawson To: pietenpol-list(at)matronics.com Sent: Tuesday, January 20, 2004 12:02 AM Subject: Re: Pietenpol-List: Cutting plywood Don't use this thing in a hand drill. It is very much out of balance with one cutter way off center, and be very careful of it in a drill press. It has a lot of torque so take it easy. There is one I've seen with a counter weight on the opposite side but most don't. It does work quite well in a drill press following Walt's rules. If you want to cut thick material drill the center hole first and it will go easier. There is another fly cutter. It's a very small knife. Buzzzz. Clif ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Monday, January 19, 2004 1:01 PM Subject: Re: Pietenpol-List: Cutting plywood Here is one pic I found on the net. It's adjustable for hole size. The BIG trick for a good hole is to cut about half way thru on one side and turn wood over to finish. This way no raggid edges walt evans NX140DL ----- Original Message ----- From: Gnwac(at)cs.com To: pietenpol-list(at)matronics.com Sent: Monday, January 19, 2004 1:59 PM Subject: Re: Pietenpol-List: Cutting plywood What is a FLY CUTTER? Greg Delaware ________________________________________________________________________________
Date: Jan 20, 2004
Carl, The only accident I have witnesse was with one of those double cutting fly cutters with cutters on both sides. They scare me. I have not seen any one mention where to buy the fly cutters..Sears has two sizes to offer. They do not call them fly cutters. Cannot recall their designation for them. My advice for any one using one, be sure the work is clamped down tightly and there is clerance for the tool on all sides. To get an acurate hole cut I found it best to use a piece of scrap to use to make a small cut then measure the diameter to see if it is what is desired. If the work piece is not clamped securely chatter is a possibility and the tool will not cut as you want. Alex Sloan ----- Original Message ----- From: Carl Loar To: pietenpol-list(at)matronics.com Sent: Tuesday, January 20, 2004 5:41 PM Subject: Re: Pietenpol-List: Cutting plywood I agree with Jack, this type of flycutter is very tricky to use. ( there is also a flycutter that's used with milling machines to smooth large sufaces) If you are going to use this, use clamps to secure the work and imagine the area that the work would spin in if it started rotating.Then keep all body parts out of that area. Also, make sure that the cutters are tight on the piece. There are cutters with tools on both sides. If your going to use one, this type is best as the cut is balanced. I believe harbor frieght carries that type. Please use with caution. Carl ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Tuesday, January 20, 2004 5:59 AM Subject: RE: Pietenpol-List: Cutting plywood I guess I got off lucky - I only had 14 stitches in my thumb after violating rule #2. Be VERY careful as the cutter finishes piercing the metal. At that point it can have a tendency to "bite" into the work piece and can pull it out of your hand over even out of the clamps holding it to the bench if you are not careful. I consider the fly cutter to be one of the most dangerous tools in the shop. Be sure there is somebody home who can drive you to the hospital while you are using it. Seriously. Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Christian Bobka Sent: Tuesday, January 20, 2004 1:26 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Cutting plywood Two rules of fly cutting. Never use it in anything BUT a drill press. Never hold the item being flycut in your hand. It MUST be clamped to the drill press table and you have one hand on the downfeed and the other poised over the off switch. That way you never have to look away from the work until after the drill press is shut off. Chris Bobka who drove his USMC aviator buddy to the hospital for 30+ stiches in his palm after he violated rule 2. chris bobka ----- Original Message ----- From: Clif Dawson To: pietenpol-list(at)matronics.com Sent: Tuesday, January 20, 2004 12:02 AM Subject: Re: Pietenpol-List: Cutting plywood Don't use this thing in a hand drill. It is very much out of balance with one cutter way off center, and be very careful of it in a drill press. It has a lot of torque so take it easy. There is one I've seen with a counter weight on the opposite side but most don't. It does work quite well in a drill press following Walt's rules. If you want to cut thick material drill the center hole first and it will go easier. There is another fly cutter. It's a very small knife. Buzzzz. Clif ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Monday, January 19, 2004 1:01 PM Subject: Re: Pietenpol-List: Cutting plywood Here is one pic I found on the net. It's adjustable for hole size. The BIG trick for a good hole is to cut about half way thru on one side and turn wood over to finish. This way no raggid edges walt evans NX140DL ----- Original Message ----- From: Gnwac(at)cs.com To: pietenpol-list(at)matronics.com Sent: Monday, January 19, 2004 1:59 PM Subject: Re: Pietenpol-List: Cutting plywood What is a FLY CUTTER? Greg Delaware ________________________________________________________________________________
Date: Jan 20, 2004
Great going Norman. Keep us informed. Alex S. ----- Original Message ----- From: Norman Stapelberg To: pietenpol-list(at)matronics.com Sent: Tuesday, January 20, 2004 1:46 PM Subject: Pietenpol-List: ZS-VJA Flies Hi all Just thought I'd pop in a quick note my baby flew Sunday for the first time in two years. Got some small mods to do, 1.. prop to be repitched (only getting 2000Rpm static). 2.. Battery to be moved C of G tad to far fwd. 3.. A.S.I to be calibrated Regards, Norman Stapelberg ZS-VJA (115Hrs) South Africa FASI ________________________________________________________________________________
<002e01c3de36$350ab400$0101a8c0@domain> <000b01c3de3f$9285bd10$53246b43@youru10ixi0anw> <005701c3df04$2a7b6920$d401a8c0@Alex> <400D7F4B.7080100(at)speedtrail.net>
Date: Jan 20, 2004
Rick, If you look at the top "plan view" drawing of the 172 3/8" fuse (I'll call it Fuselage C), it shows 19 3/8" from the back of the vertical brace (same place as a horizontal brace?) to the tailpost. Then in the layout below which shows the turtledeck, it shows 18 7/8" from back of turtledeck to the tailpost.. I nailed a 1/8" piece of ply to the back of the brace (19 3/8") to which my turtledeck stringers are mounted. So in theory, the dimension in mine from turtledeck to tailpost is 19 1/4" I don't know how they came up with 18 7/8" unless I hosed something up, which is entirely possible. Tom B. ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Tuesday, January 20, 2004 1:19 PM Subject: Re: Pietenpol-List: horizontal stab dimensions Tom My long (172 3/8) fuselage plans (Supplementary Plans) shows the distance from the tailpost to the back of the turtledeck 18 7/8" not 19 3/8". Thats only a 7/8" difference. Still makes you wonder if you should build the stab 18" or 18 7/8" wide. Rick H Alex Sloan wrote: Chris, I am building the long fuselage and would appreciate the information you worked up on larger stabs. Thanks Alex Sloan alexms(at)bellsouth.net ----- Original Message ----- From: Brants To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 9:51 PM Subject: Re: Pietenpol-List: horizontal stab dimensions Chris, I am the one that asked the original question.... You're correct in saying that the drawings stand alone, however if I'd been smart I could have figured on making a larger stabilizer... According to your comments (if I interpreted correctly) the 172 3/8" fuse (this is what I have) requires a larger stabilizer (and elevator??)... My previous post asks this question - can I use the 18" stab (and elevator) now that they're built, or do I need to modify or rebuild? I would be interested in getting a copy of your article on this. Thanks, Tom Brant Brooklyn Park, MN ----- Original Message ----- From: Christian Bobka To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 8:44 PM Subject: Re: Pietenpol-List: horizontal stab dimensions Walt, You are concerned with a concept called tail volume. Tail volume is the square inch area of the horizontal surface (elevator and satbilizer together) times the distance in inches from the center of pressure of the horizontal stabilizer to the Center of Gravity, this being the point of rotation about which the aircraft moves based on input of the controls. As there are three wood fuselages that I know of, namely the version in the F&G manual and on the Hoopman drawings at 161 inches, the 1933 "Improved Aircamper" at 163 inches, and the fuselage designed for the Corvair at 172.375 inches, I am not sure which one you mean. I always called the Corvair fuselage the Pavliga long fuselage because, well, it is the longest and it is the fuselage used on Sky Gypsy. Anyway, if you take the square inch area of each horizontal design times the distance in inches from the loaded CG to the 33% chord point on each stabilizer design, you will come up with the tail volume...volume because the units will now be cubic inches. The hardest thing will be to figure out your loaded CG. If you make the distance between the CG to the CP of the stabilizer longer, you can get by with a smaller stabilizer area. Shorten up the CG to CP distance and you need to increase the tail area. My analysis of the different fuselages leads me to believe that using the 172.375 fuselage moves the seats back faster than the tail gets longer so it actually puts the CG further aft than on the shorter fuselages. This means that the CG to Cp of the stabilizer is actually a shorter distance so a bigger area stabilizer is needed. Unfortunately, the 172.375" fuselage drawing is a stand alone. No landing gear was ever published for it and neither is there a obviously a stabilizer. I wrote an article on gear placement on the 172.375 inch fuselage that was to be published in the Grant MacLaren published BPA NL but it never made it because the very issue it was to be published in was never published as he quit the post. I will dig it out. Only a hard copy exists, and even it is one of the drafts, so I will have to scan it to OCR software and see if I can post it. I hope this helps. I wish people said what inch fuselage they have when they talk of stuff like this as it really matters (or maybe it doesn't since they all seem to meet each aviator's expectations) Chris Bobka ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 7:04 PM Subject: Re: Pietenpol-List: horizontal stab dimensions I didn't know they were different. I built the long fuse and the tail was from the original prints, so I guess I got the wrong one. but flies great. What two prints show different tails??? walt evans NX140DL ----- Original Message ----- From: Brants To: pietenpol-list(at)matronics.com Sent: Sunday, January 18, 2004 5:37 PM Subject: Pietenpol-List: horizontal stab dimensions I built the long fuselage and then (idiodically) built the horiz. stab for the short fuse (18" wide instead of 19 3/8") - didn't realize until today when I tried fitting it up. Question: can I glue a wider leading edge to the horizontal stab to make up the difference? Obviously this would add a bit of weight to the tail section.. Or could I just fill in behind the turtle deck to take up the space? Difference is about 1 3/8". Is the 1 3/8" width going to be missed if I leave it out? Does this cause a problem getting away from the 'airfoil shape'? Another related question: does the horiz. stab get bolted through the longerons? Any help on this would be appreciated. Tom Brant Brooklyn Park, MN ________________________________________________________________________________
<5.1.1.5.2.20040120075434.017c3e60(at)popserve.grc.nasa.gov>
Subject: Re: Ted's advice--and flaring too HIGH
Date: Jan 20, 2004
Another tip: If landing on a runway with a crop on either side, you will experience a tendency to round out and flare too high. I've been there and done that! The tops of the plants will give you a false reference and if you don't compensate for it, you will "drop 'er on". This effect is more apparent if the vegetation is tall and the runway is narrow. In the flare one has to look to the side of the nose to judge height, and a tall crop nearby makes this difficult. A little bit of power enables the pilot to "feel" for the ground under these conditions. I find that my landings improve once the harvest is finished. Cheers, Graham Hansen (Pietenpol CF-AUN) ________________________________________________________________________________
Date: Jan 20, 2004
Re: Pietenpol-List: horizontal stab dimensionsUse a piece of light spruce to fair the gap. Under the fabric, you won't notice. Chris Bobka ----- Original Message ----- From: Mike To: pietenpol-list(at)matronics.com Sent: Tuesday, January 20, 2004 2:02 PM Subject: Re: Pietenpol-List: horizontal stab dimensions Rick, If it really bothers a builder to have to build a cover for the gap, it might be cheaper to build the turtle deck longer. I don't think anyone has ever complained that a properly configured Piet has insufficient horizontal stabilizer area, though it is well documented that large, covered, wheels make it want some more vertical stabilizer. You probably can't hurt the design by enlarging the horizontal stab area, but be sure to keep the front flying wires the same distance from the leading edge. Tail flutter hasn't historically been a problem but, considering how limber the thin stab is, you don't want to be the first to flutter test it. Mike Hardaway on 1/20/04 11:19, Rick Holland at at7000ft(at)speedtrail.net wrote: Tom My long (172 3/8) fuselage plans (Supplementary Plans) shows the distance from the tailpost to the back of the turtledeck 18 7/8" not 19 3/8". Thats only a 7/8" difference. Still makes you wonder if you should build the stab 18" or 18 7/8" wide. Rick H ________________________________________________________________________________
Subject: New Piet
Date: Jan 21, 2004
I thought this was posted earlier but don't remember seeing it so.....I'll try again. I was invited to cast a critical eye on an almost completed Air Camper while on a house-hunting expedition in N. Florida last week. I was an honored guest of noted aviation artist (paintings and models) John Ficklen at his home on St. George Island for a couple of days. His Piet is assembled and rigged and looks like a winner. Lots of little personal touches that will keep spectators busy looking for an extended time at airshows. It's delightful! Although he does have dihedral and a center-section cutout YUCK (sorry Mike) he rest of the airplane is to-the-plans and extremely well done. That's expected from someone who makes historically accurate models for museums and private collectors, I suppose. Anyway, it is a treat for the eye and, as is always the case, it's a shame to have to cover it. John's goal is to have it finished for Sun-N-Fun. A two year build time shows what can be done if efforts are directed to the building board rather than the keyboard . Larry ________________________________________________________________________________
Date: Jan 21, 2004
Subject: myinks.com..WARNING!!!!!!!!
ken brown , lisa , Sharon Mcmillan , pietenpol-list(at)matronics.com, maryann ross , rudy , Anne Vydra , Marianne Vydra , Richard Vydra , Vic Vydra , Elaine Vydra-Wiegand Do not ever order ink cartridges from this place. I did....has cost me over $50.00 for nothing. ________________________________________________________________________________
Date: Jan 21, 2004
Hello Mark, > > FWIW, I got my tailwheel endorsement yesterday, so when my instructor > said I was "almost there" on New Year's day he meant it. It was the > first time I've flown since then, and a chilly, gusty day in southern > New Hampshire (but then, we've been getting your Canadian Arctic air a > lot the past couple of weeks). Good for demonstrating cross-wind wheel Congratulations on the endorsement. You will certainly enjoy having that in years to come, and as I said before, it really makes you a better pilot. ...Edwin ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~ Edwin Johnson ....... elj(at)shreve.net ~ ~ http://www.shreve.net/~elj ~ ~ ~ ~ "Once you have flown, you will walk the ~ ~ earth with your eyes turned skyward, ~ ~ for there you have been, there you long ~ ~ to return." -- da Vinci ~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ________________________________________________________________________________
Date: Jan 21, 2004
Subject: John Ficklin's Pietenpol in Florida
Larry--- Glad you got to see and meet John Ficklin in person. He's the guy who encouraged me to make a Piet video after sending him a bunch of misc. footage in 1999 to help him along in the building process. He's full of energy and enthusiasm. Here are some photos of his instrument panel and fuselage on the gear and the motor mount for a Continental engine that he sent me last year. (hope you don't mind, John) And way to go John by adding the dihedral and wing cutout. Flop, shmop:)) Larry's Piet is very very cool tho with it's super simple panel and paint job......but we'll have to pass him on the left when heading to Brodhead next summer. Kidding Larry ! (we'll give you a head start:) Mike C. where it was zero when I left for work this morning ________________________________________________________________________________
Date: Jan 15, 2004
Congratulations, but we'd sure like to see a picture. It is easy now that you can just attach to your email message. Mac in Oregon ----- Original Message ----- From: Norman Stapelberg To: pietenpol-list(at)matronics.com Sent: Tuesday, January 20, 2004 11:46 AM Subject: Pietenpol-List: ZS-VJA Flies Hi all Just thought I'd pop in a quick note my baby flew Sunday for the first time in two years. Got some small mods to do, 1.. prop to be repitched (only getting 2000Rpm static). 2.. Battery to be moved C of G tad to far fwd. 3.. A.S.I to be calibrated Regards, Norman Stapelberg ZS-VJA (115Hrs) South Africa FASI ________________________________________________________________________________
Subject: FW: Pietenpol News
Date: Jan 21, 2004
Hey guys (and gals) This my be a repeit, but here is your special invitation! Steve E. ________________________________ From: Dan Duesterbeck [mailto:dbled(at)ticon.net] Subject: Pietenpol News Hey Steve- I've been trying to send an email to the Buckeye Pietenpol Association to have it posted on their website. I would appreciate if you being a Pietenpol enthusiast, that you would pass it on. Pietenpol Fly-In Brodhead Airport (C37) July 23, 24, 25 Brodhead , WI Chapter 431 Brodhead is looking forward to seeing all new and former visitors to our area. For those that are unable to attend, please follow the highlights of the event through our website. http://www.eaa431.org Looking forward to seeing you all!! Dan Duesterbeck Chapter secretary 431 ________________________________________________________________________________
Date: Jan 21, 2004
From: "Kirk Huizenga" <Kirk.Huizenga(at)moundsviewschools.org>
Subject: Axle Dissertation
Chris, Thanks for the research. I have one question that I hope will be simply answered. The question is what affect shifting the wing back would have on the proper placement of the axle. Example: For W&B reasons, one shifts the wing back 4in. In theory, this doesn't change the CG much at all, but the center of lift changes enough to allow for us that don't fit the FAA 180lb profile to fit leading edge datum CG limits. Should this also cause a move rearward of the axle? Thanks for your input Kirk ________________________________________________________________________________
Subject: Re: Axle Dissertation
Date: Jan 21, 2004
Kirk, First, let me recommend to you and everybody else we fly balance ships. Who cares what the FAA says about 180 lb people. You are flying the plane and it should balance with you in it. Second, I recommend using something other than the wing leading edge as the datum. It does not make any sense to do so. If you are moving the wing around, then you are moving around the datum . The whole IDEA of the datum is that it is a PLACE THAT DOES NOT MOVE. It is by definition, a fixed reference point. I was at a loss as to what to use until some others mentioned using the bolt on the left side were the front cabane attaches to the fuselage. It seems that people will stretch and shorten the fuselage, shift the wing forward and aft but this point seems to not get tampered with. So let us use it going forth. If people give me good numbers, I will calculate W and Balance for them if they think they can't do it. I agreee that the Leading edge of the wing eventually becomes important because we need to make sure the CG is within the fore and aft limits of the airfoil but we can work that into the calculations later. I suggest that you look in the archives under the discussions on axle placement where one puts the axle at some angle forward from the vetical of about 12-16 degrees with the angle measured at the longitudinal and vertical CG point on the side of the fuselage. I forget what the number is and I loaned the book out on it last night so I can't look it up. You will need to compute the exact point on the aircraft where the CG is when looking at it from the side. This means longitudinal (how far back from the bolt) and vertical or up from the floor (Of course the aircraft is level longitudinally and laterally). You are familiar with the longitudinal CG but the vertical CG is new for most and this can be computed through a method Hank Jarrett posted last week and I posted through Jim Markle where he put it up at: http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID=185 In short, yes, if you move the wing back, the axle needs to be moved back too. Chris ----- Original Message ----- From: "Kirk Huizenga" <Kirk.Huizenga(at)moundsviewschools.org> Subject: Pietenpol-List: Axle Dissertation > > > Chris, > > Thanks for the research. I have one question that I hope will be simply answered. The question is what affect shifting the wing back would have on the proper placement of the axle. > > Example: For W&B reasons, one shifts the wing back 4in. In theory, this doesn't change the CG much at all, but the center of lift changes enough to allow for us that don't fit the FAA 180lb profile to fit leading edge datum CG limits. Should this also cause a move rearward of the axle? > > Thanks for your input > Kirk > > ________________________________________________________________________________
Subject: awesome technical resource
Date: Jan 21, 2004
go here: http://www.engineersedge.com/Design_Data.shtml literally thousands of java calculators and pages upon pages of technical data pertaining to anything mechanical. I stumbled upon it tonight when searching for technical data on thread sizes. DJ Vegh N74DV Mesa, AZ www.imagedv.com/aircamper ________________________________________________________________________________
Subject: progress report
Date: Jan 16, 2004
I just returned from a "retirement property hunting" expedition to Florida and was hosted most graciously on St. George Island by Piet builder John Ficklin and his way above average wife, Susan. John has more talent in his little finger than most mortals and it shows in everything he touches. His Piet is no exception! It's bare-bones presently and fully rigged. Soon it will be taken apart and given a good once-over then the covering process will begin. EVERYTHING is superb, and many of the personal touches are only going to be seen by someone who takes the time to really go over it. They will be amply rewarded by John's antique instruments, clever inspection panels, small blisters and fairings, and a simple but very elegant elevator trim system. It's a jewel and his goal is to have it at Sun-N-Fun!!! If things go well, he will try to get to Brodhead and on to OSH with the gaggle. Made me wonder how many other Piets are out there waiting to hatch. Piet people are Great! Larry ________________________________________________________________________________
Date: Jan 22, 2004
Just remember that you are not moving the wing back,,,you are moving the body forward. Not being a wise guy, it's just easier to understand what is affected when you do this. Picture hanging the plane from the point on top of the wing that is the center of the theoretical CG. Now with you in the plane, the whole thing is hanging down with the tail near the floor. Now by losening the rigging cables, you push the whole body forward under the wing about four inches. now all of a sudden the whole plane is hanging level on this wire from the ceiling. weird thinking but true. walt evans NX140DL ----- Original Message ----- From: "Kirk Huizenga" <Kirk.Huizenga(at)moundsviewschools.org> Subject: Pietenpol-List: Axle Dissertation > > Chris, > > Thanks for the research. I have one question that I hope will be simply answered. The question is what affect shifting the wing back would have on the proper placement of the axle. > > Example: For W&B reasons, one shifts the wing back 4in. In theory, this doesn't change the CG much at all, but the center of lift changes enough to allow for us that don't fit the FAA 180lb profile to fit leading edge datum CG limits. Should this also cause a move rearward of the axle? > > Thanks for your input > Kirk > > ________________________________________________________________________________
Date: Jan 22, 2004
Netscape/7.1 (ax)
HTML_TITLE_EMPTY Good points Christian, and your datum point does sound logical. For people building the long (172") version no axle placement info is provided with the supplemental plans. Most people just assume it is placed the same a shown on the original Ford plans, at least until they read several of the postings on the subject the last few days. To give us a ballpark idea how about doing an FAA standard 180 lb. pilot (and maybe even 2 180 lb occupants) calculation for axle placement for the long fuselage with everything else "per the plans" (10 gal. wing tank, wing in standard position, corvair engine, etc.?) I would be interested in seeing how far off it is from the short fuselage position. RH Christian Bobka wrote: > >Kirk, > >First, let me recommend to you and everybody else we fly balance ships. Who >cares what the FAA says about 180 lb people. You are flying the plane and >it should balance with you in it. > >Second, I recommend using something other than the wing leading edge as the >datum. It does not make any sense to do so. If you are moving the wing >around, then you are moving around the datum . The whole IDEA of the datum >is that it is a PLACE THAT DOES NOT MOVE. It is by definition, a fixed >reference point. I was at a loss as to what to use until some others >mentioned using the bolt on the left side were the front cabane attaches to >the fuselage. It seems that people will stretch and shorten the fuselage, >shift the wing forward and aft but this point seems to not get tampered >with. So let us use it going forth. If people give me good numbers, I will >calculate W and Balance for them if they think they can't do it. I agreee >that the Leading edge of the wing eventually becomes important because we >need to make sure the CG is within the fore and aft limits of the airfoil >but we can work that into the calculations later. > >I suggest that you look in the archives under the discussions on axle >placement where one puts the axle at some angle forward from the vetical of >about 12-16 degrees with the angle measured at the longitudinal and vertical >CG point on the side of the fuselage. I forget what the number is and I >loaned the book out on it last night so I can't look it up. You will need >to compute the exact point on the aircraft where the CG is when looking at >it from the side. This means longitudinal (how far back from the bolt) and >vertical or up from the floor (Of course the aircraft is level >longitudinally and laterally). You are familiar with the longitudinal CG >but the vertical CG is new for most and this can be computed through a >method Hank Jarrett posted last week and I posted through Jim Markle where >he put it up at: > >http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID=185 > > >In short, yes, if you move the wing back, the axle needs to be moved back >too. > >Chris > > >----- Original Message ----- >From: "Kirk Huizenga" <Kirk.Huizenga(at)moundsviewschools.org> >To: >Sent: Wednesday, January 21, 2004 10:02 PM >Subject: Pietenpol-List: Axle Dissertation > > > > >> >> > > > >>Chris, >> >>Thanks for the research. I have one question that I hope will be simply >> >> >answered. The question is what affect shifting the wing back would have on >the proper placement of the axle. > > >>Example: For W&B reasons, one shifts the wing back 4in. In theory, this >> >> >doesn't change the CG much at all, but the center of lift changes enough to >allow for us that don't fit the FAA 180lb profile to fit leading edge datum >CG limits. Should this also cause a move rearward of the axle? > > >>Thanks for your input >>Kirk >> >> >> >> >> >> >> >> >> > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 22, 2004
I'm not a fan of moving the wing. the tail moment is shortened, the angle between the landing gear and CG is changed, etc. Why not move the engine fore or aft to adjust CG? Moving a 200lb engine fore or aft just 3" makes a difference. DJ ----- Original Message ----- From: walt evans Subject: Re: Pietenpol-List: Axle Dissertation Just remember that you are not moving the wing back,,,you are moving the body forward. Not being a wise guy, it's just easier to understand what is affected when you do this. Picture hanging the plane from the point on top of the wing that is the center of the theoretical CG. Now with you in the plane, the whole thing is hanging down with the tail near the floor. Now by losening the rigging cables, you push the whole body forward under the wing about four inches. now all of a sudden the whole plane is hanging level on this wire from the ceiling. weird thinking but true. walt evans NX140DL ----- Original Message ----- From: "Kirk Huizenga" <Kirk.Huizenga(at)moundsviewschools.org> Subject: Pietenpol-List: Axle Dissertation > > Chris, > > Thanks for the research. I have one question that I hope will be simply answered. The question is what affect shifting the wing back would have on the proper placement of the axle. > > Example: For W&B reasons, one shifts the wing back 4in. In theory, this doesn't change the CG much at all, but the center of lift changes enough to allow for us that don't fit the FAA 180lb profile to fit leading edge datum CG limits. Should this also cause a move rearward of the axle? > > Thanks for your input > Kirk > > = This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>. ________________________________________________________________________________
<4010208B.1000503(at)speedtrail.net>
Date: Jan 22, 2004
I built the long fuselage with an A65 (mount extented about 1 3/4" to anticipate my bodily weight of 215") And had to move the wing back (sorry, body forward) 3 inches. I used the split gear plans supplied. 14 gallon nose tank and 10 gal center tank (usually run empty). Had read an article by a "seat of the pants guy" who said something like " if you can hold the plane on the mains with the tail up without a problem on rollout, then the CG can't be far off. When doing takeoff roll, no problem getting up on the mains, and after a wheel landing, I can keep it on the mains for quite a while till it's quite slow. Not like the tail slams to the ground. If the wheel location was too far forward, wouldn't it show up in the rollout? walt evans NX140DL ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 2:12 PM Subject: Re: Pietenpol-List: Axle Dissertation Good points Christian, and your datum point does sound logical. For people building the long (172") version no axle placement info is provided with the supplemental plans. Most people just assume it is placed the same a shown on the original Ford plans, at least until they read several of the postings on the subject the last few days. To give us a ballpark idea how about doing an FAA standard 180 lb. pilot (and maybe even 2 180 lb occupants) calculation for axle placement for the long fuselage with everything else "per the plans" (10 gal. wing tank, wing in standard position, corvair engine, etc.?) I would be interested in seeing how far off it is from the short fuselage position. RH Christian Bobka wrote: Kirk, First, let me recommend to you and everybody else we fly balance ships. Who cares what the FAA says about 180 lb people. You are flying the plane and it should balance with you in it. Second, I recommend using something other than the wing leading edge as the datum. It does not make any sense to do so. If you are moving the wing around, then you are moving around the datum . The whole IDEA of the datum is that it is a PLACE THAT DOES NOT MOVE. It is by definition, a fixed reference point. I was at a loss as to what to use until some others mentioned using the bolt on the left side were the front cabane attaches to the fuselage. It seems that people will stretch and shorten the fuselage, shift the wing forward and aft but this point seems to not get tampered with. So let us use it going forth. If people give me good numbers, I will calculate W and Balance for them if they think they can't do it. I agreee that the Leading edge of the wing eventually becomes important because we need to make sure the CG is within the fore and aft limits of the airfoil but we can work that into the calculations later. I suggest that you look in the archives under the discussions on axle placement where one puts the axle at some angle forward from the vetical of about 12-16 degrees with the angle measured at the longitudinal and vertical CG point on the side of the fuselage. I forget what the number is and I loaned the book out on it last night so I can't look it up. You will need to compute the exact point on the aircraft where the CG is when looking at it from the side. This means longitudinal (how far back from the bolt) and vertical or up from the floor (Of course the aircraft is level longitudinally and laterally). You are familiar with the longitudinal CG but the vertical CG is new for most and this can be computed through a method Hank Jarrett posted last week and I posted through Jim Markle where he put it up at: http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID185 In short, yes, if you move the wing back, the axle needs to be moved back too. Chris ----- Original Message ----- From: "Kirk Huizenga" <Kirk.Huizenga(at)moundsviewschools.org> Subject: Pietenpol-List: Axle Dissertation Chris, Thanks for the research. I have one question that I hope will be simply answered. The question is what affect shifting the wing back would have on the proper placement of the axle. Example: For W&B reasons, one shifts the wing back 4in. In theory, this doesn't change the CG much at all, but the center of lift changes enough to allow for us that don't fit the FAA 180lb profile to fit leading edge datum CG limits. Should this also cause a move rearward of the axle? Thanks for your input Kirk ________________________________________________________________________________
<4010208B.1000503(at)speedtrail.net> <003d01c3e132$4f351880$2cc5fea9@home>
Date: Jan 22, 2004
Walt, How far is your axle from your firewall? I ask as I am building the long fuselage. I extended my engine mount 2" from the firewall. I will be using the Corvair engine. I am a long way from building the gear but assimilating as much info as this old brain can hold. ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 3:54 PM Subject: Re: Pietenpol-List: Axle Dissertation I built the long fuselage with an A65 (mount extented about 1 3/4" to anticipate my bodily weight of 215") And had to move the wing back (sorry, body forward) 3 inches. I used the split gear plans supplied. 14 gallon nose tank and 10 gal center tank (usually run empty). Had read an article by a "seat of the pants guy" who said something like " if you can hold the plane on the mains with the tail up without a problem on rollout, then the CG can't be far off. When doing takeoff roll, no problem getting up on the mains, and after a wheel landing, I can keep it on the mains for quite a while till it's quite slow. Not like the tail slams to the ground. If the wheel location was too far forward, wouldn't it show up in the rollout? walt evans NX140DL ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 2:12 PM Subject: Re: Pietenpol-List: Axle Dissertation Good points Christian, and your datum point does sound logical. For people building the long (172") version no axle placement info is provided with the supplemental plans. Most people just assume it is placed the same a shown on the original Ford plans, at least until they read several of the postings on the subject the last few days. To give us a ballpark idea how about doing an FAA standard 180 lb. pilot (and maybe even 2 180 lb occupants) calculation for axle placement for the long fuselage with everything else "per the plans" (10 gal. wing tank, wing in standard position, corvair engine, etc.?) I would be interested in seeing how far off it is from the short fuselage position. RH Christian Bobka wrote: Kirk, First, let me recommend to you and everybody else we fly balance ships. Who cares what the FAA says about 180 lb people. You are flying the plane and it should balance with you in it. Second, I recommend using something other than the wing leading edge as the datum. It does not make any sense to do so. If you are moving the wing around, then you are moving around the datum . The whole IDEA of the datum is that it is a PLACE THAT DOES NOT MOVE. It is by definition, a fixed reference point. I was at a loss as to what to use until some others mentioned using the bolt on the left side were the front cabane attaches to the fuselage. It seems that people will stretch and shorten the fuselage, shift the wing forward and aft but this point seems to not get tampered with. So let us use it going forth. If people give me good numbers, I will calculate W and Balance for them if they think they can't do it. I agreee that the Leading edge of the wing eventually becomes important because we need to make sure the CG is within the fore and aft limits of the airfoil but we can work that into the calculations later. I suggest that you look in the archives under the discussions on axle placement where one puts the axle at some angle forward from the vetical of about 12-16 degrees with the angle measured at the longitudinal and vertical CG point on the side of the fuselage. I forget what the number is and I loaned the book out on it last night so I can't look it up. You will need to compute the exact point on the aircraft where the CG is when looking at it from the side. This means longitudinal (how far back from the bolt) and vertical or up from the floor (Of course the aircraft is level longitudinally and laterally). You are familiar with the longitudinal CG but the vertical CG is new for most and this can be computed through a method Hank Jarrett posted last week and I posted through Jim Markle where he put it up at: http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID185 In short, yes, if you move the wing back, the axle needs to be moved back too. Chris ----- Original Message ----- From: "Kirk Huizenga" <Kirk.Huizenga(at)moundsviewschools.org> Subject: Pietenpol-List: Axle Dissertation Chris, Thanks for the research. I have one question that I hope will be simply answered. The question is what affect shifting the wing back would have on the proper placement of the axle. Example: For W&B reasons, one shifts the wing back 4in. In theory, this doesn't change the CG much at all, but the center of lift changes enough to allow for us that don't fit the FAA 180lb profile to fit leading edge datum CG limits. Should this also cause a move rearward of the axle? Thanks for your input Kirk ________________________________________________________________________________
Subject: Adjusting tension in drag/antidrag cables.
Date: Jan 22, 2004
As I stand here with fabric and Polyfiber Chemicals in hand I do wonder: 1) Is there really any "right" way to set the tension on the drag wires? I've tightened them to where I think they are "snug" but not so tight they twang. They are cables with turnbuckles. I have safetied everything off. Thanks, Bert ________________________________________________________________________________
<4010208B.1000503(at)speedtrail.net> <003d01c3e132$4f351880$2cc5fea9@home> <00b401c3e13f$3e5edf20$d401a8c0@Alex>
Date: Jan 22, 2004
Alex, Don't really know at the moment. My plans are up in the hanger. Maybe if you have the prints there,,,I built right to the long fuselage prints supplied from the Pietenpol family, with the split gear from the supplied prints of 1933/34? No changes to the long fuse and gear. (using 24" O.D. tires) One old brain to another : ) walt evans NX140DL ----- Original Message ----- From: Alex Sloan To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 6:27 PM Subject: Re: Pietenpol-List: Axle Dissertation Walt, How far is your axle from your firewall? I ask as I am building the long fuselage. I extended my engine mount 2" from the firewall. I will be using the Corvair engine. I am a long way from building the gear but assimilating as much info as this old brain can hold. ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 3:54 PM Subject: Re: Pietenpol-List: Axle Dissertation I built the long fuselage with an A65 (mount extented about 1 3/4" to anticipate my bodily weight of 215") And had to move the wing back (sorry, body forward) 3 inches. I used the split gear plans supplied. 14 gallon nose tank and 10 gal center tank (usually run empty). Had read an article by a "seat of the pants guy" who said something like " if you can hold the plane on the mains with the tail up without a problem on rollout, then the CG can't be far off. When doing takeoff roll, no problem getting up on the mains, and after a wheel landing, I can keep it on the mains for quite a while till it's quite slow. Not like the tail slams to the ground. If the wheel location was too far forward, wouldn't it show up in the rollout? walt evans NX140DL ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 2:12 PM Subject: Re: Pietenpol-List: Axle Dissertation Good points Christian, and your datum point does sound logical. For people building the long (172") version no axle placement info is provided with the supplemental plans. Most people just assume it is placed the same a shown on the original Ford plans, at least until they read several of the postings on the subject the last few days. To give us a ballpark idea how about doing an FAA standard 180 lb. pilot (and maybe even 2 180 lb occupants) calculation for axle placement for the long fuselage with everything else "per the plans" (10 gal. wing tank, wing in standard position, corvair engine, etc.?) I would be interested in seeing how far off it is from the short fuselage position. RH Christian Bobka wrote: Kirk, First, let me recommend to you and everybody else we fly balance ships. Who cares what the FAA says about 180 lb people. You are flying the plane and it should balance with you in it. Second, I recommend using something other than the wing leading edge as the datum. It does not make any sense to do so. If you are moving the wing around, then you are moving around the datum . The whole IDEA of the datum is that it is a PLACE THAT DOES NOT MOVE. It is by definition, a fixed reference point. I was at a loss as to what to use until some others mentioned using the bolt on the left side were the front cabane attaches to the fuselage. It seems that people will stretch and shorten the fuselage, shift the wing forward and aft but this point seems to not get tampered with. So let us use it going forth. If people give me good numbers, I will calculate W and Balance for them if they think they can't do it. I agreee that the Leading edge of the wing eventually becomes important because we need to make sure the CG is within the fore and aft limits of the airfoil but we can work that into the calculations later. I suggest that you look in the archives under the discussions on axle placement where one puts the axle at some angle forward from the vetical of about 12-16 degrees with the angle measured at the longitudinal and vertical CG point on the side of the fuselage. I forget what the number is and I loaned the book out on it last night so I can't look it up. You will need to compute the exact point on the aircraft where the CG is when looking at it from the side. This means longitudinal (how far back from the bolt) and vertical or up from the floor (Of course the aircraft is level longitudinally and laterally). You are familiar with the longitudinal CG but the vertical CG is new for most and this can be computed through a method Hank Jarrett posted last week and I posted through Jim Markle where he put it up at: http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID185 In short, yes, if you move the wing back, the axle needs to be moved back too. Chris ----- Original Message ----- From: "Kirk Huizenga" <Kirk.Huizenga(at)moundsviewschools.org> Subject: Pietenpol-List: Axle Dissertation Chris, Thanks for the research. I have one question that I hope will be simply answered. The question is what affect shifting the wing back would have on the proper placement of the axle. Example: For W&B reasons, one shifts the wing back 4in. In theory, this doesn't change the CG much at all, but the center of lift changes enough to allow for us that don't fit the FAA 180lb profile to fit leading edge datum CG limits. Should this also cause a move rearward of the axle? Thanks for your input Kirk ________________________________________________________________________________
Subject: Re: Adjusting tension in drag/antidrag cables.
Date: Jan 22, 2004
SSBzdXNwZWN0IGlmIHlvdSBrbmV3IHRoZSB0ZW5zaW9uIGluIHBvdW5kcyB5b3Ugd291bGQgdXNl IGEgdGVuc2lvbWV0ZXIgdG8gc2V0IGFsbCB3aXJlcyB0byB0aGUgc2FtZSB0ZW5zaW9uIChpbiB0 aGVvcnkgSSBndWVzcykgIFdoYXQgdGhhdCBhbW91bnQgaXMgSSBkbyBub3Qga25vdy4NCg0KWW91 IHVzZWQgd2lyZXMgYW5kIHR1cm5idWNrbGVzIGh1aD8gIE11c3QgaGF2ZSBiZWVuIGV4cGVuc2l2 ZSEgIFRob3NlIHR1cm5idWNrbGVzIGFyZSBsaWtlICQxNSBhIHBpZWNlISAgIEkgYW0gZGViYXRp bmcgd2hldGhlciBvciBub3QgdG8gdXNlIGNhYmxlcyBhbmQgdHVybmJ1Y2tsZXMgb3Igc3RlZWwg cm9kIHdpdGggZm9yayBlbmRzLg0KDQpESiBWZWdoDQpONzREVg0KTWVzYSwgQVoNCnd3dy5pbWFn ZWR2LmNvbS9haXJjYW1wZXINCg0KDQoNCi0NCg0KICAtLS0tLSBPcmlnaW5hbCBNZXNzYWdlIC0t LS0tIA0KICBGcm9tOiBCZXJ0IENvbm9seSANCiAgVG86IHBpZXRlbnBvbC1saXN0QG1hdHJvbmlj cy5jb20gDQogIFNlbnQ6IFRodXJzZGF5LCBKYW51YXJ5IDIyLCAyMDA0IDQ6NTIgUE0NCiAgU3Vi amVjdDogUGlldGVucG9sLUxpc3Q6IEFkanVzdGluZyB0ZW5zaW9uIGluIGRyYWcvYW50aWRyYWcg Y2FibGVzLg0KDQoNCiAgQXMgSSBzdGFuZCBoZXJlIHdpdGggZmFicmljIGFuZCBQb2x5ZmliZXIg Q2hlbWljYWxzIGluIGhhbmQgSSBkbyB3b25kZXI6DQoNCiAgMSkgICAgSXMgdGhlcmUgcmVhbGx5 IGFueSAicmlnaHQiIHdheSB0byBzZXQgdGhlIHRlbnNpb24gb24gdGhlIGRyYWcgd2lyZXM/ICBJ J3ZlIHRpZ2h0ZW5lZCB0aGVtIHRvIHdoZXJlIEkgdGhpbmsgdGhleSBhcmUgInNudWciIGJ1dCBu b3Qgc28gdGlnaHQgdGhleSB0d2FuZy4gVGhleSBhcmUgY2FibGVzIHdpdGggdHVybmJ1Y2tsZXMu ICBJIGhhdmUgc2FmZXRpZWQgZXZlcnl0aGluZyBvZmYuDQoNCiAgVGhhbmtzLCBCZXJ0ICANCg0K DQo ________________________________________________________________________________
Date: Jan 22, 2004
Dale Johnson and I are building a long fuselage, A-65 powered with original style gear. The axle on ours is 19" aft of the firewall. We have not taxied yet but it does look right. Cabanes are slanted back about 3 inches. Greg Cardinal in Minneapolis (-10 F this morning) ----- Original Message ----- From: Alex Sloan To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 5:27 PM Subject: Re: Pietenpol-List: Axle Dissertation Walt, How far is your axle from your firewall? I ask as I am building the long fuselage. I extended my engine mount 2" from the firewall. I will be using the Corvair engine. I am a long way from building the gear but assimilating as much info as this old brain can hold. ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 3:54 PM Subject: Re: Pietenpol-List: Axle Dissertation I built the long fuselage with an A65 (mount extented about 1 3/4" to anticipate my bodily weight of 215") And had to move the wing back (sorry, body forward) 3 inches. I used the split gear plans supplied. 14 gallon nose tank and 10 gal center tank (usually run empty). Had read an article by a "seat of the pants guy" who said something like " if you can hold the plane on the mains with the tail up without a problem on rollout, then the CG can't be far off. When doing takeoff roll, no problem getting up on the mains, and after a wheel landing, I can keep it on the mains for quite a while till it's quite slow. Not like the tail slams to the ground. If the wheel location was too far forward, wouldn't it show up in the rollout? walt evans NX140DL ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 2:12 PM Subject: Re: Pietenpol-List: Axle Dissertation Good points Christian, and your datum point does sound logical. For people building the long (172") version no axle placement info is provided with the supplemental plans. Most people just assume it is placed the same a shown on the original Ford plans, at least until they read several of the postings on the subject the last few days. To give us a ballpark idea how about doing an FAA standard 180 lb. pilot (and maybe even 2 180 lb occupants) calculation for axle placement for the long fuselage with everything else "per the plans" (10 gal. wing tank, wing in standard position, corvair engine, etc.?) I would be interested in seeing how far off it is from the short fuselage position. RH Christian Bobka wrote: Kirk, First, let me recommend to you and everybody else we fly balance ships. Who cares what the FAA says about 180 lb people. You are flying the plane and it should balance with you in it. Second, I recommend using something other than the wing leading edge as the datum. It does not make any sense to do so. If you are moving the wing around, then you are moving around the datum . The whole IDEA of the datum is that it is a PLACE THAT DOES NOT MOVE. It is by definition, a fixed reference point. I was at a loss as to what to use until some others mentioned using the bolt on the left side were the front cabane attaches to the fuselage. It seems that people will stretch and shorten the fuselage, shift the wing forward and aft but this point seems to not get tampered with. So let us use it going forth. If people give me good numbers, I will calculate W and Balance for them if they think they can't do it. I agreee that the Leading edge of the wing eventually becomes important because we need to make sure the CG is within the fore and aft limits of the airfoil but we can work that into the calculations later. I suggest that you look in the archives under the discussions on axle placement where one puts the axle at some angle forward from the vetical of about 12-16 degrees with the angle measured at the longitudinal and vertical CG point on the side of the fuselage. I forget what the number is and I loaned the book out on it last night so I can't look it up. You will need to compute the exact point on the aircraft where the CG is when looking at it from the side. This means longitudinal (how far back from the bolt) and vertical or up from the floor (Of course the aircraft is level longitudinally and laterally). You are familiar with the longitudinal CG but the vertical CG is new for most and this can be computed through a method Hank Jarrett posted last week and I posted through Jim Markle where he put it up at: http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID185 In short, yes, if you move the wing back, the axle needs to be moved back too. Chris ----- Original Message ----- From: "Kirk Huizenga" <Kirk.Huizenga(at)moundsviewschools.org> Subject: Pietenpol-List: Axle Dissertation Chris, Thanks for the research. I have one question that I hope will be simply answered. The question is what affect shifting the wing back would have on the proper placement of the axle. Example: For W&B reasons, one shifts the wing back 4in. In theory, this doesn't change the CG much at all, but the center of lift changes enough to allow for us that don't fit the FAA 180lb profile to fit leading edge datum CG limits. Should this also cause a move rearward of the axle? Thanks for your input Kirk ________________________________________________________________________________
From: "Richard Navratil" <horzpool(at)goldengate.net>
Date: Jan 22, 2004
Hey Bert My opinion is the wires should have a twang. Harmonics are good indication of tension. If you give them all the same sound your rig will be all equal. Dick ----- Original Message ----- From: Bert Conoly To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 5:52 PM Subject: Pietenpol-List: Adjusting tension in drag/antidrag cables. As I stand here with fabric and Polyfiber Chemicals in hand I do wonder: 1) Is there really any "right" way to set the tension on the drag wires? I've tightened them to where I think they are "snug" but not so tight they twang. They are cables with turnbuckles. I have safetied everything off. Thanks, Bert ________________________________________________________________________________
Subject: More Pietenpol magazine articles.....
Date: Jan 22, 2004
The following two articles are now available in the "File Library" section of www.mykitplane.com: September 1999 Kitplanes http://www.mykitplane.com/Planes/filesList2.cfm?AlbumID45 July 1992 Kitplanes http://www.mykitplane.com/Planes/filesList2.cfm?AlbumID44 Enjoy ________________________________________________________________________________
<4010208B.1000503(at)speedtrail.net> <003d01c3e132$4f351880$2cc5fea9@home> <00b401c3e13f$3e5edf20$d401a8c0@Alex> <001501c3e147$aab879d0$0300a8c0@pc40332>
Date: Jan 22, 2004
Greg, Thanks. I will add that to my growing file of useful info on things to do to mine when the appropriate time comes. Alex Sloan ----- Original Message ----- From: Greg Cardinal To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 6:27 PM Subject: Re: Pietenpol-List: Axle Dissertation Dale Johnson and I are building a long fuselage, A-65 powered with original style gear. The axle on ours is 19" aft of the firewall. We have not taxied yet but it does look right. Cabanes are slanted back about 3 inches. Greg Cardinal in Minneapolis (-10 F this morning) ----- Original Message ----- From: Alex Sloan To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 5:27 PM Subject: Re: Pietenpol-List: Axle Dissertation Walt, How far is your axle from your firewall? I ask as I am building the long fuselage. I extended my engine mount 2" from the firewall. I will be using the Corvair engine. I am a long way from building the gear but assimilating as much info as this old brain can hold. ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 3:54 PM Subject: Re: Pietenpol-List: Axle Dissertation I built the long fuselage with an A65 (mount extented about 1 3/4" to anticipate my bodily weight of 215") And had to move the wing back (sorry, body forward) 3 inches. I used the split gear plans supplied. 14 gallon nose tank and 10 gal center tank (usually run empty). Had read an article by a "seat of the pants guy" who said something like " if you can hold the plane on the mains with the tail up without a problem on rollout, then the CG can't be far off. When doing takeoff roll, no problem getting up on the mains, and after a wheel landing, I can keep it on the mains for quite a while till it's quite slow. Not like the tail slams to the ground. If the wheel location was too far forward, wouldn't it show up in the rollout? walt evans NX140DL ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 2:12 PM Subject: Re: Pietenpol-List: Axle Dissertation Good points Christian, and your datum point does sound logical. For people building the long (172") version no axle placement info is provided with the supplemental plans. Most people just assume it is placed the same a shown on the original Ford plans, at least until they read several of the postings on the subject the last few days. To give us a ballpark idea how about doing an FAA standard 180 lb. pilot (and maybe even 2 180 lb occupants) calculation for axle placement for the long fuselage with everything else "per the plans" (10 gal. wing tank, wing in standard position, corvair engine, etc.?) I would be interested in seeing how far off it is from the short fuselage position. RH Christian Bobka wrote: Kirk, First, let me recommend to you and everybody else we fly balance ships. Who cares what the FAA says about 180 lb people. You are flying the plane and it should balance with you in it. Second, I recommend using something other than the wing leading edge as the datum. It does not make any sense to do so. If you are moving the wing around, then you are moving around the datum . The whole IDEA of the datum is that it is a PLACE THAT DOES NOT MOVE. It is by definition, a fixed reference point. I was at a loss as to what to use until some others mentioned using the bolt on the left side were the front cabane attaches to the fuselage. It seems that people will stretch and shorten the fuselage, shift the wing forward and aft but this point seems to not get tampered with. So let us use it going forth. If people give me good numbers, I will calculate W and Balance for them if they think they can't do it. I agreee that the Leading edge of the wing eventually becomes important because we need to make sure the CG is within the fore and aft limits of the airfoil but we can work that into the calculations later. I suggest that you look in the archives under the discussions on axle placement where one puts the axle at some angle forward from the vetical of about 12-16 degrees with the angle measured at the longitudinal and vertical CG point on the side of the fuselage. I forget what the number is and I loaned the book out on it last night so I can't look it up. You will need to compute the exact point on the aircraft where the CG is when looking at it from the side. This means longitudinal (how far back from the bolt) and vertical or up from the floor (Of course the aircraft is level longitudinally and laterally). You are familiar with the longitudinal CG but the vertical CG is new for most and this can be computed through a method Hank Jarrett posted last week and I posted through Jim Markle where he put it up at: http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID185 In short, yes, if you move the wing back, the axle needs to be moved back too. Chris ----- Original Message ----- From: "Kirk Huizenga" <Kirk.Huizenga(at)moundsviewschools.org> Subject: Pietenpol-List: Axle Dissertation Chris, Thanks for the research. I have one question that I hope will be simply answered. The question is what affect shifting the wing back would have on the proper placement of the axle. Example: For W&B reasons, one shifts the wing back 4in. In theory, this doesn't change the CG much at all, but the center of lift changes enough to allow for us that don't fit the FAA 180lb profile to fit leading edge datum CG limits. Should this also cause a move rearward of the axle? Thanks for your input Kirk ________________________________________________________________________________
Date: Jan 22, 2004
Subject: Re: progress report
Larry, Is John Ficklen on this list ? Do you have his e-mail ? I need to send him an infomation list to fill out on his Piet. Anyone that I missed, please e-mail me direct, so I can send you the Pietenpol 'Infomation List' to fill out. Chuck G. ________________________________________________________________________________
Date: Jan 23, 2004
In a message dated 1/22/04 8:35:58 PM Central Standard Time, horzpool(at)goldengate.net writes: << Hey Bert My opinion is the wires should have a twang. Harmonics are good indication of tension. If you give them all the same sound your rig will be all equal. Dick >> That's how I did it. Not too tight, though. I put an inspection hole to be able to adjust the turnbuckles, if needed. So far, after about 100 hrs, not needed. They also need something to prevent chafe where they touch in the middle of the 'X'. While we're on this subject, my drag / anti-drag cables touched a few of the ribs. I notched the stick for clearance, and added support on the oposite side. Did this happen to any others ? The wing on Doug Bryant's plane was the same way. Chuck G. ________________________________________________________________________________
Date: Jan 22, 2004
Dale and I had some rib / wire interference. We did the same thing you did, notch the rib and add a doubler. Greg Cardinal ----- Original Message ----- From: <Rcaprd(at)aol.com> Subject: Re: Pietenpol-List: Adjusting tension in drag/antidrag cables. > > In a message dated 1/22/04 8:35:58 PM Central Standard Time, > horzpool(at)goldengate.net writes: > > << Hey Bert > My opinion is the wires should have a twang. Harmonics are good indication > of tension. If you give them all the same sound your rig will be all equal. > Dick >> > > That's how I did it. Not too tight, though. I put an inspection hole to be > able to adjust the turnbuckles, if needed. So far, after about 100 hrs, not > needed. They also need something to prevent chafe where they touch in the > middle of the 'X'. While we're on this subject, my drag / anti-drag cables > touched a few of the ribs. I notched the stick for clearance, and added support on > the oposite side. Did this happen to any others ? The wing on Doug Bryant's > plane was the same way. > > Chuck G. > > ________________________________________________________________________________
Date: Jan 23, 2004
In a message dated 1/22/04 6:32:13 PM Central Standard Time, djv(at)imagedv.com writes: << I am debating whether or not to use cables and turnbuckles or steel rod with fork ends. >> D.J., The steel rods would be required to have rolled threads, and built to specific lengths. Probably end up being similar costs to the cables / turnbuckles. Chuck G. ________________________________________________________________________________
Date: Jan 23, 2004
In a message dated 1/22/04 5:53:01 PM Central Standard Time, bconoly(at)earthlink.net writes: << As I stand here with fabric and Polyfiber Chemicals in hand I do wonder: >> Bert, I'll bet you also wonder if you should cover up such beautiful artwork !!! Chuck G. ________________________________________________________________________________
Date: Jan 22, 2004
Subject: [ Shawn Wolk ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Shawn Wolk Lists: Pietenpol-List Subject: Pietenpol on skis http://www.matronics.com/photoshare/shawnwolk@sprint.ca.01.22.2004/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jan 22, 2004
Available!
Subject: Re: [ Shawn Wolk ] : New Email List Photo Share
Available! Check out the tail feathers. Clif > A new Email List Photo Share is available: > > Poster: Shawn Wolk > > > http://www.matronics.com/photoshare/shawnwolk@sprint.ca.01.22.2004/index.htm l ________________________________________________________________________________
Date: Jan 23, 2004
On the rib/wire business, I also encountered the problem while building 41CC. This time I will leave my ribs unattached, install wires and fittings, bring up to tension,THEN move the ribs a skosh here and there for clearance before glueing, skrewing or nailing. I hope it works easier. Same difference just sorta working backwards Corky in La/ with a new walking cane suffering HLS. ________________________________________________________________________________
From: "Dick and Marge Gillespie" <margdick(at)peganet.com>
Subject: Piet tube fuse available
Date: Jan 23, 2004
Piet long tubular fuse available with formers, floor boards, 2 sticks with torque tube, rudder pedals and miscellaneous. $1500.00. Also available 2 Lyc. 0-145 65 HP, prop and eng. mts. For details call: Lloyd Moore 239/693-2605. ________________________________________________________________________________
Date: Jan 23, 2004
Corky, Good to see you back up and talking and walking, even with a cane. Alex Sloan ----- Original Message ----- From: Isablcorky(at)aol.com To: pietenpol-list(at)matronics.com Sent: Friday, January 23, 2004 10:01 AM Subject: Re: Pietenpol-List: Adjusting tension in drag/antidrag cables. On the rib/wire business, I also encountered the problem while building 41CC. This time I will leave my ribs unattached, install wires and fittings, bring up to tension,THEN move the ribs a skosh here and there for clearance before glueing, skrewing or nailing. I hope it works easier. Same difference just sorta working backwards Corky in La/ with a new walking cane suffering HLS. ________________________________________________________________________________
Date: Jan 23, 2004
Good idea Corky, Which ribs are affected during the thighting of the cables? I have not started the ribs yet, but something to place in my notes to save time later. Greg Menoche Delaware ________________________________________________________________________________
Date: Jan 23, 2004
Subject: Re: Piet tube fuse available
Lloyd, Where is area code 239? Greg ________________________________________________________________________________
Date: Jan 23, 2004
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
Subject: popsicle sticks and tramelling
Did what Corky is planning to do on his new wings---run the X-cables in the wings then take most the slack out then slightly reposition the ribs to clear the trusswork of affected ribs. I then squared up the spars to each other with small nails pounded into the tops of the spars at each of the four ends to measure each dimension as I tightened and keep them equal (=square wing/parallel spars) Ended up gluing and nailing the ribs to the spars while I could still slide the ribs left and right. After cured I checked the tramell and snugged up the cables and safety wired them. Where they cross over each other I slit some small aquarium hose or clear tygon tube from Home Depot about an inch long. I slid those over each cable where they crossed to protect them from chaffing each other and used two small tie wraps to snug up the whole intersection against vibration. In moving the very few ribs that are in your way, I only moved them enough to just clear the ribs--then glued in some dry popsicle sticks to the flat of the truss that came closest to touching the cable for added protection. (similar to the doubler idea) Mike C. ________________________________________________________________________________
"Pietenpol-List Digest List"
Date: Jan 23, 2004
My understanding is that the location of the axle is determined by the location of the CG, both in height above and distance behind the axle. The relationship between the location of the CG and the axle effects the balance between a minimum longitudinal moment required during braking (needed to apply brakes and not nose over) and an instability in the vertical axis while on the ground (the propensity for a tail dragger to ground loop). It's the relationship between the axle and the CG which matters, not the axle and the wing. Since moving the wing back 4" only changes the CG position a fraction of an inch, would it really be necessary to change the axle location because of the new wing location? Or, is it the fact that the 4" wing relcation is in response to a 4" movement of the CG. Movement of the wing would then be an indicator of a CG movement. With this said, I agree with DJ in the solution of moving the engine forward for a tail heavy (or pilot heavy) Piet, which keeps the CG in the same spot and the geometry between the CG and the axle (and also the CG and the tail volume) the same. Then again, I've not heard of any that have moved the wing back and found they had control problems because of it. Robert Haines Du Quoin, Illinois ________________________________________________________________________________
Date: Jan 23, 2004
Greg, Go ahead and string your ribs on the spars and position according to plans. Small nail in each will hold until you find which ones to move. It's all so very slight and not enough to spoil that FC-10 airfoil Corky ________________________________________________________________________________
From: "Wayne Cahoon @ Aircraft Engravers" <wayne(at)engravers.net>
Subject: Fuel Cap Engraving, Labeling, Indentifying
Date: Jan 23, 2004
Have your Fuel Caps engraved, it's permanent and easy to read. Aircraft Engravers has been engraving fuel caps for over 14 years. You can see our web page at http://engravers.net/aircraft/fuel_caps.htm Other types of engraving jobs can be viewed at http://engravers.net/main/ac_products.htm There are a few sets of loaner fuel caps for the more common styles if your tanks are wet. FREE shipping by USPS Priority mail for all fuel cap engraving orders in the month of February. Wayne Cahoon Aircraft Engravers (860) 653-2780 (860) 653-7324 Fax http://engravers.net/ ________________________________________________________________________________
Subject: Re: popsicle sticks and tramelling
Date: Jan 23, 2004
Mike, I like the antichafe part. Tygon is teflon and should last forever. I don't know about the aquarium hose though. I would rather know there are no nicks or wearing of the wire crossing point especially if I can't see it. Chris ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: Pietenpol-List: popsicle sticks and tramelling > > > Did what Corky is planning to do on his new wings---run the X-cables in the > wings then take most the slack out then slightly reposition the ribs to > clear the trusswork of affected ribs. I then squared up the spars to each > other with small nails pounded into the tops of the spars at each of the > four ends to measure each dimension as I tightened and keep them equal > (=square wing/parallel spars) Ended up gluing and nailing the ribs to the > spars while I could still slide the ribs left and right. After cured I > checked the tramell and snugged up the cables and safety wired > them. Where they cross over each other I slit some small aquarium hose or > clear tygon tube from Home Depot about an inch long. I slid those over > each cable where they crossed to protect them from chaffing each other and > used two small tie wraps to snug up the whole intersection against > vibration. In moving the very few ribs that are in your way, I only moved > them enough to just clear the ribs--then glued in some dry popsicle sticks > to the flat of the truss that came closest to touching the cable for added > protection. (similar to the doubler idea) > > Mike C. > > ________________________________________________________________________________
Date: Jan 23, 2004
Believe it or not, the MacWhyte wires, when they were made here, had cut threads. Chris Bobka ----- Original Message ----- From: <Rcaprd(at)aol.com> Subject: Re: Pietenpol-List: Adjusting tension in drag/antidrag cables. > > > In a message dated 1/22/04 6:32:13 PM Central Standard Time, djv(at)imagedv.com > writes: > > << I am debating whether or not to use cables and turnbuckles or steel rod > with fork ends. >> > > D.J., > The steel rods would be required to have rolled threads, and built to > specific lengths. Probably end up being similar costs to the cables / turnbuckles. > > Chuck G. > > ________________________________________________________________________________
<4010208B.1000503(at)speedtrail.net> <003d01c3e132$4f351880$2cc5fea9@home> <00b401c3e13f$3e5edf20$d401a8c0@Alex> <001501c3e147$aab879d0$0300a8c0@pc40332> <016201c3e164$0336ad40$d401a8c0@Alex>
Date: Jan 23, 2004
And greg meant to add that theirs is a bone stock long fuselage 170+" Chris Bobka ----- Original Message ----- From: Alex Sloan To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 9:50 PM Subject: Re: Pietenpol-List: Axle Dissertation Greg, Thanks. I will add that to my growing file of useful info on things to do to mine when the appropriate time comes. Alex Sloan ----- Original Message ----- From: Greg Cardinal To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 6:27 PM Subject: Re: Pietenpol-List: Axle Dissertation Dale Johnson and I are building a long fuselage, A-65 powered with original style gear. The axle on ours is 19" aft of the firewall. We have not taxied yet but it does look right. Cabanes are slanted back about 3 inches. Greg Cardinal in Minneapolis (-10 F this morning) ----- Original Message ----- From: Alex Sloan To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 5:27 PM Subject: Re: Pietenpol-List: Axle Dissertation Walt, How far is your axle from your firewall? I ask as I am building the long fuselage. I extended my engine mount 2" from the firewall. I will be using the Corvair engine. I am a long way from building the gear but assimilating as much info as this old brain can hold. ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 3:54 PM Subject: Re: Pietenpol-List: Axle Dissertation I built the long fuselage with an A65 (mount extented about 1 3/4" to anticipate my bodily weight of 215") And had to move the wing back (sorry, body forward) 3 inches. I used the split gear plans supplied. 14 gallon nose tank and 10 gal center tank (usually run empty). Had read an article by a "seat of the pants guy" who said something like " if you can hold the plane on the mains with the tail up without a problem on rollout, then the CG can't be far off. When doing takeoff roll, no problem getting up on the mains, and after a wheel landing, I can keep it on the mains for quite a while till it's quite slow. Not like the tail slams to the ground. If the wheel location was too far forward, wouldn't it show up in the rollout? walt evans NX140DL ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 2:12 PM Subject: Re: Pietenpol-List: Axle Dissertation Good points Christian, and your datum point does sound logical. For people building the long (172") version no axle placement info is provided with the supplemental plans. Most people just assume it is placed the same a shown on the original Ford plans, at least until they read several of the postings on the subject the last few days. To give us a ballpark idea how about doing an FAA standard 180 lb. pilot (and maybe even 2 180 lb occupants) calculation for axle placement for the long fuselage with everything else "per the plans" (10 gal. wing tank, wing in standard position, corvair engine, etc.?) I would be interested in seeing how far off it is from the short fuselage position. RH Christian Bobka wrote: Kirk, First, let me recommend to you and everybody else we fly balance ships. Who cares what the FAA says about 180 lb people. You are flying the plane and it should balance with you in it. Second, I recommend using something other than the wing leading edge as the datum. It does not make any sense to do so. If you are moving the wing around, then you are moving around the datum . The whole IDEA of the datum is that it is a PLACE THAT DOES NOT MOVE. It is by definition, a fixed reference point. I was at a loss as to what to use until some others mentioned using the bolt on the left side were the front cabane attaches to the fuselage. It seems that people will stretch and shorten the fuselage, shift the wing forward and aft but this point seems to not get tampered with. So let us use it going forth. If people give me good numbers, I will calculate W and Balance for them if they think they can't do it. I agreee that the Leading edge of the wing eventually becomes important because we need to make sure the CG is within the fore and aft limits of the airfoil but we can work that into the calculations later. I suggest that you look in the archives under the discussions on axle placement where one puts the axle at some angle forward from the vetical of about 12-16 degrees with the angle measured at the longitudinal and vertical CG point on the side of the fuselage. I forget what the number is and I loaned the book out on it last night so I can't look it up. You will need to compute the exact point on the aircraft where the CG is when looking at it from the side. This means longitudinal (how far back from the bolt) and vertical or up from the floor (Of course the aircraft is level longitudinally and laterally). You are familiar with the longitudinal CG but the vertical CG is new for most and this can be computed through a method Hank Jarrett posted last week and I posted through Jim Markle where he put it up at: http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID185 In short, yes, if you move the wing back, the axle needs to be moved back too. Chris ----- Original Message ----- From: "Kirk Huizenga" <Kirk.Huizenga(at)moundsviewschools.org> Subject: Pietenpol-List: Axle Dissertation Chris, Thanks for the research. I have one question that I hope will be simply answered. The question is what affect shifting the wing back would have on the proper placement of the axle. Example: For W&B reasons, one shifts the wing back 4in. In theory, this doesn't change the CG much at all, but the center of lift changes enough to allow for us that don't fit the FAA 180lb profile to fit leading edge datum CG limits. Should this also cause a move rearward of the axle? Thanks for your input Kirk ________________________________________________________________________________
Date: Jan 23, 2004
My mentor is from the old school,,,whenever wires cross, he taught me to use rib stitch cord,,,make about 4 turns around the "X", but not tight, now you change direction and circle around between the two wires about 3 or 4 times to make a "standoff" between the two cables. Winds up looking like a tight hangmans knot with two loops. Now if the slack was right in the beginning, when you pull the whole thing tight, It all goes tight. Tie it off with a double knot, and a little varnish on the assy and you're done. It's authentic to the 20's. walt evans NX140DL ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: Pietenpol-List: popsicle sticks and tramelling > > Did what Corky is planning to do on his new wings---run the X-cables in the > wings then take most the slack out then slightly reposition the ribs to > clear the trusswork of affected ribs. I then squared up the spars to each > other with small nails pounded into the tops of the spars at each of the > four ends to measure each dimension as I tightened and keep them equal > (=square wing/parallel spars) Ended up gluing and nailing the ribs to the > spars while I could still slide the ribs left and right. After cured I > checked the tramell and snugged up the cables and safety wired > them. Where they cross over each other I slit some small aquarium hose or > clear tygon tube from Home Depot about an inch long. I slid those over > each cable where they crossed to protect them from chaffing each other and > used two small tie wraps to snug up the whole intersection against > vibration. In moving the very few ribs that are in your way, I only moved > them enough to just clear the ribs--then glued in some dry popsicle sticks > to the flat of the truss that came closest to touching the cable for added > protection. (similar to the doubler idea) > > Mike C. > > ________________________________________________________________________________
Date: Jan 23, 2004
Walt. Thats what I did but I cheated and stuck a little square of rubber motorcycle tube between them before I laced it all together. Seemed to work well BC. ----- Original Message ----- From: "walt evans" <wbeevans(at)verizon.net> Subject: Re: Pietenpol-List: popsicle sticks and tramelling > > My mentor is from the old school,,,whenever wires cross, he taught me to use > rib stitch cord,,,make about 4 turns around the "X", but not tight, now you > change direction and circle around between the two wires about 3 or 4 times > to make a "standoff" between the two cables. Winds up looking like a tight > hangmans knot with two loops. Now if the slack was right in the beginning, > when you pull the whole thing tight, It all goes tight. Tie it off with a > double knot, and a little varnish on the assy and you're done. It's > authentic to the 20's. > walt evans > NX140DL > ----- Original Message ----- > From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> > To: > Sent: Friday, January 23, 2004 2:36 PM > Subject: Pietenpol-List: popsicle sticks and tramelling > > > > > > > Did what Corky is planning to do on his new wings---run the X-cables in > the > > wings then take most the slack out then slightly reposition the ribs to > > clear the trusswork of affected ribs. I then squared up the spars to each > > other with small nails pounded into the tops of the spars at each of the > > four ends to measure each dimension as I tightened and keep them equal > > (=square wing/parallel spars) Ended up gluing and nailing the ribs to the > > spars while I could still slide the ribs left and right. After cured I > > checked the tramell and snugged up the cables and safety wired > > them. Where they cross over each other I slit some small aquarium hose > or > > clear tygon tube from Home Depot about an inch long. I slid those over > > each cable where they crossed to protect them from chaffing each other and > > used two small tie wraps to snug up the whole intersection against > > vibration. In moving the very few ribs that are in your way, I only > moved > > them enough to just clear the ribs--then glued in some dry popsicle sticks > > to the flat of the truss that came closest to touching the cable for added > > protection. (similar to the doubler idea) > > > > Mike C. > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Here is the man to do the inspections in MN
Date: Jan 23, 2004
IT'S OFFICIAL: EAA'S JOE NORRIS IS FIRST AUTHORIZE AB-DAR January 23, 2004 - History was made Thursday morning when the first amateur-built designated airworthiness representative (AB-DAR) was officially and fully authorized to perform homebuilt aircraft inspections on behalf of the FAA. Suitably, the first AB-DAR hails from EAA: Joe Norris, senior aviation information specialist. Joe received his final orientation via telephone interview Thursday from the principal inspector at Minneapolis (MSP) Manufacturing Inspection District Office (MIDO). EAA worked extensively with FAA over the past several years to develop the AB-DAR program to help alleviate a growing backlog of inspection requests from amateur-built aircraft builders. EAA facilitated recruiting more than 60 AB-DAR candidates, and also played a key role in developing the required training course and materials. David R. Smith, an Aviation Safety Inspector (ASI-Manufacturing) working out of MSP MIDO, gave Norris the orientation, the last required step in the AB-DAR approval process. MSP MIDO Office Manager Andrew B. Lown signed Norris' DAR certificate and letter of authorization. "Now that all the steps are completed, Dave Smith will be sending me the appropriate paperwork that I'll need when I certificate an amateur-built aircraft," Norris said. "I will then work with Dave on scheduling certifications that he (or his office) would like me to handle." Builders who wish to contact the MSP MIDO can call 612/713-4366. Builders can contact the MIDO to request the Amateur-Built Certification Packet, which will include all the applicable forms and FAA advisory circulars. The first AB-DAR course will take place on January 27-29 at the FAA Academy in Oklahoma City, Oklahoma. Conducted by the Transportation Safety Institute (TSI), 18 AB-DAR appointees are scheduled to attend. Another course is scheduled for June 8-10, 2004. Officials are also considering adding another course date between January and June. ________________________________________________________________________________
Date: Jan 23, 2004
Another time-honored method of protecting cross wire bracing from chafing is to place a micarta disc approximately one inch in diameter between the wires where they cross. This disc is usually about 1/16" thick and has some holes drilled in it beside the wires. Then rib lacing cord is threaded through these holes and around the wires to hold the disc in position. The whole thing is then coated with orange shellac. I have seen this method used on DeHavilland Moths, etc. and used it on my Pietenpol for the cabane wires and the wire bracing between the lift struts. It would be fine for drag/antidrag wires, also. (I used 1/8" cable with turnbuckles for all such bracing; turnbuckles were not very expensive in the late 1960's when I bought mine.) Graham Hansen (Pietenpol CF-AUN in freezing Alberta) ________________________________________________________________________________
Subject: Re: Axle Dissertation
Date: Jan 23, 2004
But if you make the engine forward, the tail volume requirement will change. Moving the engine forward would destabilize in the vertical axis due to the increased vertical surface area forward of the CG. This needs to be countered with more of the quantity (surface area of the what is added forward of the CG) x (mean distance forward of the CG the area is added) added aft of the CG. For instance, you move the firewall forward by 4" and then you build a cowl for the A-65 forward of that. The A-65 on a motor mount is lonbger than the Ford Model A installation. The end result is that you add about 8" more length forward of the CG. This is 24" high so 192 sq in is added, say, an average 38" forward of the CG. So you have to add 192 x 38 = 7296 cu. in. aft of the CG. I am not looking at drawings, just throwing numbers out for an example. So you add more vertical stabilizer area 130" aft of the CG to counter. The amount to add is 7296/130 = 56 sq in. You would have to add 2" to the chord of the 30" high vertical stabilizer to counter the added destabilizing area up front. And this weighs something 130" aft of the CG, which has a large effect on CG etc etc Chris Bobka ----- Original Message ----- From: "Robert Haines" <robertsjunk(at)hotmail.com> Subject: Pietenpol-List: Re: Axle Dissertation > > > My understanding is that the location of the axle is determined by the > location of the CG, both in height above and distance behind the axle. The > relationship between the location of the CG and the axle effects the balance > between a minimum longitudinal moment required during braking (needed to > apply brakes and not nose over) and an instability in the vertical axis > while on the ground (the propensity for a tail dragger to ground loop). > It's the relationship between the axle and the CG which matters, not the > axle and the wing. Since moving the wing back 4" only changes the CG > position a fraction of an inch, would it really be necessary to change the > axle location because of the new wing location? > > Or, is it the fact that the 4" wing relcation is in response to a 4" > movement of the CG. Movement of the wing would then be an indicator of a CG > movement. With this said, I agree with DJ in the solution of moving the > engine forward for a tail heavy (or pilot heavy) Piet, which keeps the CG in > the same spot and the geometry between the CG and the axle (and also the CG > and the tail volume) the same. > > Then again, I've not heard of any that have moved the wing back and found > they had control problems because of it. > > > Robert Haines > Du Quoin, Illinois > > ________________________________________________________________________________
Date: Jan 23, 2004
"If the wheel location was too far forward, wouldn't it show up in the rollout?" Walt, Why have you been asking for instructions on how to land, then? Chris ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 3:54 PM Subject: Re: Pietenpol-List: Axle Dissertation I built the long fuselage with an A65 (mount extented about 1 3/4" to anticipate my bodily weight of 215") And had to move the wing back (sorry, body forward) 3 inches. I used the split gear plans supplied. 14 gallon nose tank and 10 gal center tank (usually run empty). Had read an article by a "seat of the pants guy" who said something like " if you can hold the plane on the mains with the tail up without a problem on rollout, then the CG can't be far off. When doing takeoff roll, no problem getting up on the mains, and after a wheel landing, I can keep it on the mains for quite a while till it's quite slow. Not like the tail slams to the ground. If the wheel location was too far forward, wouldn't it show up in the rollout? walt evans NX140DL ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 2:12 PM Subject: Re: Pietenpol-List: Axle Dissertation Good points Christian, and your datum point does sound logical. For people building the long (172") version no axle placement info is provided with the supplemental plans. Most people just assume it is placed the same a shown on the original Ford plans, at least until they read several of the postings on the subject the last few days. To give us a ballpark idea how about doing an FAA standard 180 lb. pilot (and maybe even 2 180 lb occupants) calculation for axle placement for the long fuselage with everything else "per the plans" (10 gal. wing tank, wing in standard position, corvair engine, etc.?) I would be interested in seeing how far off it is from the short fuselage position. RH Christian Bobka wrote: Kirk, First, let me recommend to you and everybody else we fly balance ships. Who cares what the FAA says about 180 lb people. You are flying the plane and it should balance with you in it. Second, I recommend using something other than the wing leading edge as the datum. It does not make any sense to do so. If you are moving the wing around, then you are moving around the datum . The whole IDEA of the datum is that it is a PLACE THAT DOES NOT MOVE. It is by definition, a fixed reference point. I was at a loss as to what to use until some others mentioned using the bolt on the left side were the front cabane attaches to the fuselage. It seems that people will stretch and shorten the fuselage, shift the wing forward and aft but this point seems to not get tampered with. So let us use it going forth. If people give me good numbers, I will calculate W and Balance for them if they think they can't do it. I agreee that the Leading edge of the wing eventually becomes important because we need to make sure the CG is within the fore and aft limits of the airfoil but we can work that into the calculations later. I suggest that you look in the archives under the discussions on axle placement where one puts the axle at some angle forward from the vetical of about 12-16 degrees with the angle measured at the longitudinal and vertical CG point on the side of the fuselage. I forget what the number is and I loaned the book out on it last night so I can't look it up. You will need to compute the exact point on the aircraft where the CG is when looking at it from the side. This means longitudinal (how far back from the bolt) and vertical or up from the floor (Of course the aircraft is level longitudinally and laterally). You are familiar with the longitudinal CG but the vertical CG is new for most and this can be computed through a method Hank Jarrett posted last week and I posted through Jim Markle where he put it up at: http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID185 In short, yes, if you move the wing back, the axle needs to be moved back too. Chris ----- Original Message ----- From: "Kirk Huizenga" <Kirk.Huizenga(at)moundsviewschools.org> Subject: Pietenpol-List: Axle Dissertation Chris, Thanks for the research. I have one question that I hope will be simply answered. The question is what affect shifting the wing back would have on the proper placement of the axle. Example: For W&B reasons, one shifts the wing back 4in. In theory, this doesn't change the CG much at all, but the center of lift changes enough to allow for us that don't fit the FAA 180lb profile to fit leading edge datum CG limits. Should this also cause a move rearward of the axle? Thanks for your input Kirk ________________________________________________________________________________
Date: Jan 23, 2004
Rick, I would like to see the numbers too but I need some actual wieghts of a ship on the scales with good measurement data on seat location, fuel location, etc. If you do a weighing with the plane empty, then adding fuel, then oil, then pilot, then passenger then bags, you can calculate the exact postion inches from the datum of each thing you add so that you have really good numbers. We need some really good numbers. By late spring, I should have participated in Greg and Dales' Piet W and B as well as Dick Navratil's so I will have good data. Chris ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 1:12 PM Subject: Re: Pietenpol-List: Axle Dissertation Good points Christian, and your datum point does sound logical. For people building the long (172") version no axle placement info is provided with the supplemental plans. Most people just assume it is placed the same a shown on the original Ford plans, at least until they read several of the postings on the subject the last few days. To give us a ballpark idea how about doing an FAA standard 180 lb. pilot (and maybe even 2 180 lb occupants) calculation for axle placement for the long fuselage with everything else "per the plans" (10 gal. wing tank, wing in standard position, corvair engine, etc.?) I would be interested in seeing how far off it is from the short fuselage position. RH Christian Bobka wrote: Kirk, First, let me recommend to you and everybody else we fly balance ships. Who cares what the FAA says about 180 lb people. You are flying the plane and it should balance with you in it. Second, I recommend using something other than the wing leading edge as the datum. It does not make any sense to do so. If you are moving the wing around, then you are moving around the datum . The whole IDEA of the datum is that it is a PLACE THAT DOES NOT MOVE. It is by definition, a fixed reference point. I was at a loss as to what to use until some others mentioned using the bolt on the left side were the front cabane attaches to the fuselage. It seems that people will stretch and shorten the fuselage, shift the wing forward and aft but this point seems to not get tampered with. So let us use it going forth. If people give me good numbers, I will calculate W and Balance for them if they think they can't do it. I agreee that the Leading edge of the wing eventually becomes important because we need to make sure the CG is within the fore and aft limits of the airfoil but we can work that into the calculations later. I suggest that you look in the archives under the discussions on axle placement where one puts the axle at some angle forward from the vetical of about 12-16 degrees with the angle measured at the longitudinal and vertical CG point on the side of the fuselage. I forget what the number is and I loaned the book out on it last night so I can't look it up. You will need to compute the exact point on the aircraft where the CG is when looking at it from the side. This means longitudinal (how far back from the bolt) and vertical or up from the floor (Of course the aircraft is level longitudinally and laterally). You are familiar with the longitudinal CG but the vertical CG is new for most and this can be computed through a method Hank Jarrett posted last week and I posted through Jim Markle where he put it up at: http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID185 In short, yes, if you move the wing back, the axle needs to be moved back too. Chris ----- Original Message ----- From: "Kirk Huizenga" <Kirk.Huizenga(at)moundsviewschools.org> Subject: Pietenpol-List: Axle Dissertation Chris, Thanks for the research. I have one question that I hope will be simply answered. The question is what affect shifting the wing back would have on the proper placement of the axle. Example: For W&B reasons, one shifts the wing back 4in. In theory, this doesn't change the CG much at all, but the center of lift changes enough to allow for us that don't fit the FAA 180lb profile to fit leading edge datum CG limits. Should this also cause a move rearward of the axle? Thanks for your input Kirk ________________________________________________________________________________
Subject: building to build
Date: Jan 24, 2004
Man, now that the tail section is getting completed it's really starting to get even more fun... Building something from plans out of God given materials can't be beat! I haven't flown a plane for over two months and frankly don't miss it much.. I'm having too much fun working on the Piet. I took the advice of some who've said, "build to build, don't build to fly" and "spend some time on it each day". It's amazing the momentum you can build when you just spend some amount of time on your project each day, even if it's just studying the plans to see how to make your next move. I find it motivational to set small goals... I set the goal of completing the 'end spinach' over the winter... certainly not difficult to achieve if you get at it each day. By spring I should be able to get to finishing up the odds and ends of the fuselage over the summer and then get at making the center section and ribs... I really wasn't looking forward to starting the wing but after seeing Dick Navratrils project(s) I see just how fun it looks to build. He's even said that the building of the wing goes by way too fast. I say all of this for those who need some encouragement, motivation or just want to read something that's more personal and less technical. The people on this list make it a phenomenal tool! Thanks for all the discussion on the horizontal stab. Sorry for the ramblings but it's nearly 2:00 am and I can't get my mind off of the piet. Ain't building great! Tom Brant Brooklyn Park, MN ________________________________________________________________________________
Date: Jan 24, 2004
Subject: floats
Want to see a Piet on floats? Go here http://www.paf-flugmodelle.de/index.htm?/Webseiten/videos.htm :-) :-) :-) Clif ________________________________________________________________________________
Subject: Re: floats
Date: Jan 24, 2004
dGhhdCB3YXMgcHJldHR5IGNvb2wNCg0KREogVmVnaA0KTjc0RFYNCk1lc2EsIEFaDQp3d3cuaW1h Z2Vkdi5jb20vYWlyY2FtcGVyDQoNCg0KDQotDQoNCiAgLS0tLS0gT3JpZ2luYWwgTWVzc2FnZSAt LS0tLSANCiAgRnJvbTogQ2xpZiBEYXdzb24gDQogIFRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25p Y3MuY29tIA0KICBTZW50OiBTYXR1cmRheSwgSmFudWFyeSAyNCwgMjAwNCAxOjU0IEFNDQogIFN1 YmplY3Q6IFBpZXRlbnBvbC1MaXN0OiBmbG9hdHMNCg0KDQogIFdhbnQgdG8gc2VlIGEgUGlldCBv biBmbG9hdHM/ICBHbyBoZXJlDQoNCiAgaHR0cDovL3d3dy5wYWYtZmx1Z21vZGVsbGUuZGUvaW5k ZXguaHRtPy9XZWJzZWl0ZW4vdmlkZW9zLmh0bQ0KDQogIDotKSA6LSkgOi0pDQoNCiAgQ2xpZg== ________________________________________________________________________________
Date: Jan 24, 2004
Netscape/7.1 (ax)
<000e01c3e231$00f77c80$4d2226d0@grhans> Hell, gold bricks were'nt very expensive back in the 60s either. RH > (I used >1/8" >cable with turnbuckles for all such bracing; turnbuckles were not very >expensive in the late 1960's when I bought mine.) > >Graham Hansen (Pietenpol CF-AUN in freezing Alberta) > > > > > > > > > > > ________________________________________________________________________________
<4010208B.1000503(at)speedtrail.net> <003d01c3e132$4f351880$2cc5fea9@home> <005d01c3e23b$fdd13540$0101a8c0@domain>
Date: Jan 24, 2004
What does that mean? walt evans NX140DL ----- Original Message ----- From: Christian Bobka To: pietenpol-list(at)matronics.com Sent: Saturday, January 24, 2004 12:36 AM Subject: Re: Pietenpol-List: Axle Dissertation "If the wheel location was too far forward, wouldn't it show up in the rollout?" Walt, Why have you been asking for instructions on how to land, then? Chris ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 3:54 PM Subject: Re: Pietenpol-List: Axle Dissertation I built the long fuselage with an A65 (mount extented about 1 3/4" to anticipate my bodily weight of 215") And had to move the wing back (sorry, body forward) 3 inches. I used the split gear plans supplied. 14 gallon nose tank and 10 gal center tank (usually run empty). Had read an article by a "seat of the pants guy" who said something like " if you can hold the plane on the mains with the tail up without a problem on rollout, then the CG can't be far off. When doing takeoff roll, no problem getting up on the mains, and after a wheel landing, I can keep it on the mains for quite a while till it's quite slow. Not like the tail slams to the ground. If the wheel location was too far forward, wouldn't it show up in the rollout? walt evans NX140DL ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 2:12 PM Subject: Re: Pietenpol-List: Axle Dissertation Good points Christian, and your datum point does sound logical. For people building the long (172") version no axle placement info is provided with the supplemental plans. Most people just assume it is placed the same a shown on the original Ford plans, at least until they read several of the postings on the subject the last few days. To give us a ballpark idea how about doing an FAA standard 180 lb. pilot (and maybe even 2 180 lb occupants) calculation for axle placement for the long fuselage with everything else "per the plans" (10 gal. wing tank, wing in standard position, corvair engine, etc.?) I would be interested in seeing how far off it is from the short fuselage position. RH Christian Bobka wrote: Kirk, First, let me recommend to you and everybody else we fly balance ships. Who cares what the FAA says about 180 lb people. You are flying the plane and it should balance with you in it. Second, I recommend using something other than the wing leading edge as the datum. It does not make any sense to do so. If you are moving the wing around, then you are moving around the datum . The whole IDEA of the datum is that it is a PLACE THAT DOES NOT MOVE. It is by definition, a fixed reference point. I was at a loss as to what to use until some others mentioned using the bolt on the left side were the front cabane attaches to the fuselage. It seems that people will stretch and shorten the fuselage, shift the wing forward and aft but this point seems to not get tampered with. So let us use it going forth. If people give me good numbers, I will calculate W and Balance for them if they think they can't do it. I agreee that the Leading edge of the wing eventually becomes important because we need to make sure the CG is within the fore and aft limits of the airfoil but we can work that into the calculations later. I suggest that you look in the archives under the discussions on axle placement where one puts the axle at some angle forward from the vetical of about 12-16 degrees with the angle measured at the longitudinal and vertical CG point on the side of the fuselage. I forget what the number is and I loaned the book out on it last night so I can't look it up. You will need to compute the exact point on the aircraft where the CG is when looking at it from the side. This means longitudinal (how far back from the bolt) and vertical or up from the floor (Of course the aircraft is level longitudinally and laterally). You are familiar with the longitudinal CG but the vertical CG is new for most and this can be computed through a method Hank Jarrett posted last week and I posted through Jim Markle where he put it up at: http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID185 In short, yes, if you move the wing back, the axle needs to be moved back too. Chris ----- Original Message ----- From: "Kirk Huizenga" <Kirk.Huizenga(at)moundsviewschools.org> Subject: Pietenpol-List: Axle Dissertation Chris, Thanks for the research. I have one question that I hope will be simply answered. The question is what affect shifting the wing back would have on the proper placement of the axle. Example: For W&B reasons, one shifts the wing back 4in. In theory, this doesn't change the CG much at all, but the center of lift changes enough to allow for us that don't fit the FAA 180lb profile to fit leading edge datum CG limits. Should this also cause a move rearward of the axle? Thanks for your input Kirk ________________________________________________________________________________
Subject: Tail Volume
Date: Jan 24, 2004
Chris, Since the subject of tail volume has come up in the recent e-mails, I thought that this might be interesting. When I first started my Piet in '95 using the long fuselage, I was concerned about the small vertical fin and rudder. I then computed both the vertical and horizontal tail volumes using the formulas quoted by David Thurston in his book "Design for Flying" These calculations showed that the tail volumes of the Pietenpol are woefully short of modern standards. The Piet vertical tail volume came out to .1389 and a modern standard is .30. The horizontal tail volume was .31389 vs. .55 All this adds to the difficulty in increasing the nose moment of a Pietenpol when mounting a lighter engine such as an A65 or Corvair to the plane to maintain W&B. Since a Model A powered Pietenpol is notoriously known to be slightly tail heavy, I thought it was worth considering using a more powerful engine that is heavier and has more horsepower. This both corrects to tail heavy condition without moving the wing back and also keeps from aggravating the tail volume problem. My solution using the turbocharged Subaru engine seems to have worked to solve both problems, although the plane doesn't slip as well as one using a lighter engine and longer nose moment. Cordially, John ________________________________________________________________________________
"pietenpol"
Subject: Re: Tail Volume
Date: Jan 24, 2004
John, You have to remember that the tail volume is necessitated by the pitching moment of the airfoil. As pitching moment increases, tail volume must increase. If there is zero pitching moment, you don't even need a tail, like the flying wings. So the piet's airfoil must fall somewhere between what is common today and a zero pitching moment airfoil. It flies ok so it must have enough TV. Also, if the tails are bigger, more CG range may be available. This is important for a four seater where it has to remain in balance without the use of ballast when only a pilot is aboard with full fuel vs. all four seats filled, full bags, and as much fuel as possible to bring the ship up to gross weight. Chris ----- Original Message ----- From: John Dilatush To: Christian Bobka Cc: pietenpol-list(at)matronics.com Sent: Saturday, January 24, 2004 10:12 AM Subject: Tail Volume Chris, Since the subject of tail volume has come up in the recent e-mails, I thought that this might be interesting. When I first started my Piet in '95 using the long fuselage, I was concerned about the small vertical fin and rudder. I then computed both the vertical and horizontal tail volumes using the formulas quoted by David Thurston in his book "Design for Flying" These calculations showed that the tail volumes of the Pietenpol are woefully short of modern standards. The Piet vertical tail volume came out to .1389 and a modern standard is .30. The horizontal tail volume was .31389 vs. .55 All this adds to the difficulty in increasing the nose moment of a Pietenpol when mounting a lighter engine such as an A65 or Corvair to the plane to maintain W&B. Since a Model A powered Pietenpol is notoriously known to be slightly tail heavy, I thought it was worth considering using a more powerful engine that is heavier and has more horsepower. This both corrects to tail heavy condition without moving the wing back and also keeps from aggravating the tail volume problem. My solution using the turbocharged Subaru engine seems to have worked to solve both problems, although the plane doesn't slip as well as one using a lighter engine and longer nose moment. Cordially, John ________________________________________________________________________________
Date: Jan 24, 2004
Subject: Re: Cutting plywood
<003901c3dd1a$20f6cfc0$2cc5fea9@home> If you are talking about sheets of ply, and need to use the table saw, get a Freud 71/4" narrow kerf finishing blade. They are cheap, cut perfectly with no tearing, and are also perfect for cutting strips for wing ribs, etc, and the blade is 1/16th thick, so every two cuts saves 1/8". If you cut lots of strips from wide boards, as I do, you save huge amounts of wood. Any narrow cutting use a band saw with a fine blade. ________________________________________________________________________________
Date: Jan 24, 2004
Subject: Re: Adjusting tension in drag/antidrag cables.
You may want to look at West Marine, they have the wire, turnbuckles etc, all in stainless steel, and good prices. They also have delrin pulleys for controls, bearingless no maintenance. Rcaprd(at)aol.com wrote: > > > In a message dated 1/22/04 6:32:13 PM Central Standard Time, djv(at)imagedv.com > writes: > > << I am debating whether or not to use cables and turnbuckles or steel rod > with fork ends. >> > > D.J., > The steel rods would be required to have rolled threads, and built to > specific lengths. Probably end up being similar costs to the cables / turnbuckles. > > Chuck G. > > > > > > ________________________________________________________________________________
Subject: Rib jig
Date: Jan 24, 2004
Hi all I been lurking on the list for quit some time and really like the way this list works, its like coming home to family and hearing all the things that happened today. The reason that I'm writing is that I started making my rib jig, then went to the archive and read up on it. Very confusing. Does anyone have an accurate cad drawing for a rib with 1" holes for the spars? I want to make a three piece wing with 1" routed spars Thanx Deon Engelmann EAA322 Midrand # SA12055 Pretoria South Africa ________________________________________________________________________________
Date: Jan 24, 2004
Subject: Picture Posting Issue Resolved...
Well, you guys aren't going to believe what the problem was... A number of people complained that the pictures they posted never showed up on the List, while others seemed to not have any problems... So first some theory on how my list filtering works. I wrote a filtering program that every single new post gets screened through before its passed onto the actual email List. This filter looks for all kinds of bogus things that spammers and other unscrupulous emailers send out these days. It also filters out messages posted with enclosure types like .bat, .exe, .src which usually always contain a virus of some sort. Its also a place where I can easily and quickly add a filter if someone starts posting a bunch of offensive messages to the list just to annoy everyone. Anyway, way back when, there was a real problem with people posting that bogus JATO urban legion about "the guy that put JATO engines on his 57 Chevy" or whatever. When ever that message would get reposted, a bunch of people would post back bitching about how many times they'd already seen that story and stop posting it and it wasn't related to blaa-list, etc, etc, etc... You get the picture... So, I just put in a filter entry in to filter out any message that contained the string "jato". Worked great, well, until recently when I started letting enclosures through on the Tailwind-List and Pietenpol-List. Turns out that a great number of pictures (jpg's) when MIME encoded have this four letter string, "jato" in them! So, I've just removed the JATO filter and things seem to be going through great now. I guess I don't have to remind everyone to not post the JATO Chevy story, now, do I...? ;-) Party on! Matt Dralle Email List Admin Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
<4010208B.1000503(at)speedtrail.net> <003d01c3e132$4f351880$2cc5fea9@home> <005d01c3e23b$fdd13540$0101a8c0@domain> <001c01c3e291$43706300$2cc5fea9@home>
Date: Jan 24, 2004
If the mains are too far forward the tail will drop too quick on roll out and will be difficult to lift in the first of the take off roll. Hank ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Saturday, January 24, 2004 10:46 AM Subject: Re: Pietenpol-List: Axle Dissertation What does that mean? walt evans NX140DL ----- Original Message ----- From: Christian Bobka To: pietenpol-list(at)matronics.com Sent: Saturday, January 24, 2004 12:36 AM Subject: Re: Pietenpol-List: Axle Dissertation "If the wheel location was too far forward, wouldn't it show up in the rollout?" Walt, Why have you been asking for instructions on how to land, then? Chris ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 3:54 PM Subject: Re: Pietenpol-List: Axle Dissertation I built the long fuselage with an A65 (mount extented about 1 3/4" to anticipate my bodily weight of 215") And had to move the wing back (sorry, body forward) 3 inches. I used the split gear plans supplied. 14 gallon nose tank and 10 gal center tank (usually run empty). Had read an article by a "seat of the pants guy" who said something like " if you can hold the plane on the mains with the tail up without a problem on rollout, then the CG can't be far off. When doing takeoff roll, no problem getting up on the mains, and after a wheel landing, I can keep it on the mains for quite a while till it's quite slow. Not like the tail slams to the ground. If the wheel location was too far forward, wouldn't it show up in the rollout? walt evans NX140DL ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Thursday, January 22, 2004 2:12 PM Subject: Re: Pietenpol-List: Axle Dissertation Good points Christian, and your datum point does sound logical. For people building the long (172") version no axle placement info is provided with the supplemental plans. Most people just assume it is placed the same a shown on the original Ford plans, at least until they read several of the postings on the subject the last few days. To give us a ballpark idea how about doing an FAA standard 180 lb. pilot (and maybe even 2 180 lb occupants) calculation for axle placement for the long fuselage with everything else "per the plans" (10 gal. wing tank, wing in standard position, corvair engine, etc.?) I would be interested in seeing how far off it is from the short fuselage position. RH Christian Bobka wrote: Kirk, First, let me recommend to you and everybody else we fly balance ships. Who cares what the FAA says about 180 lb people. You are flying the plane and it should balance with you in it. Second, I recommend using something other than the wing leading edge as the datum. It does not make any sense to do so. If you are moving the wing around, then you are moving around the datum . The whole IDEA of the datum is that it is a PLACE THAT DOES NOT MOVE. It is by definition, a fixed reference point. I was at a loss as to what to use until some others mentioned using the bolt on the left side were the front cabane attaches to the fuselage. It seems that people will stretch and shorten the fuselage, shift the wing forward and aft but this point seems to not get tampered with. So let us use it going forth. If people give me good numbers, I will calculate W and Balance for them if they think they can't do it. I agreee that the Leading edge of the wing eventually becomes important because we need to make sure the CG is within the fore and aft limits of the airfoil but we can work that into the calculations later. I suggest that you look in the archives under the discussions on axle placement where one puts the axle at some angle forward from the vetical of about 12-16 degrees with the angle measured at the longitudinal and vertical CG point on the side of the fuselage. I forget what the number is and I loaned the book out on it last night so I can't look it up. You will need to compute the exact point on the aircraft where the CG is when looking at it from the side. This means longitudinal (how far back from the bolt) and vertical or up from the floor (Of course the aircraft is level longitudinally and laterally). You are familiar with the longitudinal CG but the vertical CG is new for most and this can be computed through a method Hank Jarrett posted last week and I posted through Jim Markle where he put it up at: http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID185 In short, yes, if you move the wing back, the axle needs to be moved back too. Chris ----- Original Message ----- From: "Kirk Huizenga" <Kirk.Huizenga(at)moundsviewschools.org> Subject: Pietenpol-List: Axle Dissertation Chris, Thanks for the research. I have one question that I hope will be simply answered. The question is what affect shifting the wing back would have on the proper placement of the axle. Example: For W&B reasons, one shifts the wing back 4in. In theory, this doesn't change the CG much at all, but the center of lift changes enough to allow for us that don't fit the FAA 180lb profile to fit leading edge datum CG limits. Should this also cause a move rearward of the axle? Thanks for your input Kirk ________________________________________________________________________________
Subject: Fw: Emailing: Jim and Bill over Dallas 1915
Date: Jan 24, 2004
Ok Matt, I'll try it to see if pictures are making it through the server now...... A old friend of mine is taking a PhotoShop class at a local college....and he is WELL aware of my passion for Piets..... This picture is 1915 Dallas....I won't tell him it's a few years too early for a Piet! Jim in far north Dallas..... The title he put on the postcard: Hail the ancient aviators! ________________________________________________________________________________
Date: Jan 24, 2004
Corky, glad to hear your back. Robert Haines Du Quoin, Illinois ________________________________________________________________________________
Subject: Re: Pietenpol-List Digest: 20 Msgs - 01/23/04
Date: Jan 24, 2004
Exactly what you just illustrated happens when you allow the CG to move aft 4" (due to a tail heavy craft or a tail heavy pilot) and counter that with a 4" aft movement of the wing. Of course the fuselage remains the same, but the CG is now further aft of that fuselage, there is then more surface ahead of the CG, there is less surface aft, and the moment arm of the tail is shortened by 4". On top of that, the CG to wheel base geometry is now different. Robert Haines Du Quoin, Illinois P.S. - If the problem is a heavy pilot, move the pilot forward. > From: "Christian Bobka" <bobka(at)compuserve.com> > Subject: Re: Pietenpol-List: Re: Axle Dissertation > > > But if you make the engine forward, the tail volume requirement will change. > Moving the engine forward would destabilize in the vertical axis due to the > increased vertical surface area forward of the CG. This needs to be > countered with more of the quantity (surface area of the what is added > forward of the CG) x (mean distance forward of the CG the area is added) > added aft of the CG. > > For instance, you move the firewall forward by 4" and then you build a cowl > for the A-65 forward of that. The A-65 on a motor mount is lonbger than the > Ford Model A installation. The end result is that you add about 8" more > length forward of the CG. This is 24" high so 192 sq in is added, say, an > average 38" forward of the CG. So you have to add 192 x 38 = 7296 cu. in. > aft of the CG. I am not looking at drawings, just throwing numbers out for > an example. So you add more vertical stabilizer area 130" aft of the CG to > counter. The amount to add is 7296/130 = 56 sq in. You would have to add > 2" to the chord of the 30" high vertical stabilizer to counter the added > destabilizing area up front. And this weighs something 130" aft of the CG, > which has a large effect on CG etc etc > > Chris Bobka > ________________________________________________________________________________
Date: Jan 24, 2004
Subject: Re: Fw: Emailing: Jim and Bill over Dallas 1915
In a message dated 1/24/04 2:09:29 PM Central Standard Time, jim_markle(at)mindspring.com writes: << This picture is 1915 Dallas....I won't tell him it's a few years too early for a Piet! >> I didn't get any picture. Chuck G. ________________________________________________________________________________
Date: Jan 24, 2004
In a message dated 1/24/04 11:22:51 AM Central Standard Time, bobka(at)compuserve.com writes: << So the piet's airfoil must fall somewhere between what is common today and a zero pitching moment airfoil. >> The Pietenpol, as well as any undercambered airfoil, has a lot of negative pitching moment (nose down). I believe this is why the Piet is somewhat tolorant of an aft C.G. That's the thing I've always been curious about, is why Pietenpols are more forgiving for an aft C.G. condition. B.H.P called out 1/3 (33.3%) of the chord, as the aft limit. I've never seen, or heard of any other plane with the aft C.G. limit that far back. Most designs call out no more than 30% of the chord for the aft limit, but they are not undercambered. (Tailwind calls out 28% as the aft C.G. limit). I think this is because an undercambered airfoil has such a high negative pitching moment, that it is more forgiving of an aft C.G. I've tried unsuccessfully to find the aft C.G. limit of planes like the Jenny, but it is a Biplane - difficult to compare. Another design that has an undercambered airfoil is the Ryan Navion. Does anyone have the C.G. range of the Ryan Navion, or any other plane that has an undercambered airfoil ? Chuck Gantzer NX770CG ________________________________________________________________________________
Date: Jan 24, 2004
Chuck, Excellent observation. I have no data on the Navion but will look later. The Type Certificate Data Sheets are available on the FAA website. Chris ----- Original Message ----- From: <Rcaprd(at)aol.com> Subject: Re: Pietenpol-List: Re: Tail Volume > > > In a message dated 1/24/04 11:22:51 AM Central Standard Time, > bobka(at)compuserve.com writes: > > << So the piet's airfoil must fall somewhere between what is common today and > a zero pitching moment airfoil. > >> > > The Pietenpol, as well as any undercambered airfoil, has a lot of negative > pitching moment (nose down). I believe this is why the Piet is somewhat > tolorant of an aft C.G. That's the thing I've always been curious about, is why > Pietenpols are more forgiving for an aft C.G. condition. B.H.P called out 1/3 > (33.3%) of the chord, as the aft limit. I've never seen, or heard of any other > plane with the aft C.G. limit that far back. Most designs call out no more > than 30% of the chord for the aft limit, but they are not undercambered. > (Tailwind calls out 28% as the aft C.G. limit). I think this is because an > undercambered airfoil has such a high negative pitching moment, that it is more > forgiving of an aft C.G. I've tried unsuccessfully to find the aft C.G. limit of > planes like the Jenny, but it is a Biplane - difficult to compare. Another > design that has an undercambered airfoil is the Ryan Navion. Does anyone have the > C.G. range of the Ryan Navion, or any other plane that has an undercambered > airfoil ? > > Chuck Gantzer > NX770CG > > ________________________________________________________________________________
Subject: Re: Tail Volume & aft CG
Date: Jan 24, 2004
All the indoor flying models for the kids doing Science Olympiad have aft CG -- some of them even have the CG aft of the wing -- it works for them 'cause of massive tail volume (a long tail boom and area equal to 50% of the wing area) and the same airfoil as the wing (a lifting tail vs "flat plate"). Mike C. Pretty Prairie, KS ----- Original Message ----- From: <Rcaprd(at)aol.com> Subject: Re: Pietenpol-List: Re: Tail Volume > > In a message dated 1/24/04 11:22:51 AM Central Standard Time, > bobka(at)compuserve.com writes: > > << So the piet's airfoil must fall somewhere between what is common today and > a zero pitching moment airfoil. > >> > > The Pietenpol, as well as any undercambered airfoil, has a lot of negative > pitching moment (nose down). I believe this is why the Piet is somewhat > tolorant of an aft C.G. That's the thing I've always been curious about, is why > Pietenpols are more forgiving for an aft C.G. condition. B.H.P called out 1/3 > (33.3%) of the chord, as the aft limit. I've never seen, or heard of any other > plane with the aft C.G. limit that far back. Most designs call out no more > than 30% of the chord for the aft limit, but they are not undercambered. > (Tailwind calls out 28% as the aft C.G. limit). I think this is because an > undercambered airfoil has such a high negative pitching moment, that it is more > forgiving of an aft C.G. I've tried unsuccessfully to find the aft C.G. limit of > planes like the Jenny, but it is a Biplane - difficult to compare. Another > design that has an undercambered airfoil is the Ryan Navion. Does anyone have the > C.G. range of the Ryan Navion, or any other plane that has an undercambered > airfoil ? > > Chuck Gantzer > NX770CG > > ________________________________________________________________________________
Date: Jan 24, 2004
Michael, Great info for those of us who have to build the wings. Keep the tips coming. 'Question, on your video tape you mention "dead soft stainless " for the firewall. I have made inquires with sheet metal men, aircraft mechanics and fellow homebuilders and no one can answer, what it is or where may I get "dead soft stainless". Can you give me a number associated with it? Such as 2024-T3 is the aluminum in my RV aircraft. The stainless should have a designator for ordering purpose. Thanks. Alex Sloan ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: Pietenpol-List: popsicle sticks and tramelling > > Did what Corky is planning to do on his new wings---run the X-cables in the > wings then take most the slack out then slightly reposition the ribs to > clear the trusswork of affected ribs. I then squared up the spars to each > other with small nails pounded into the tops of the spars at each of the > four ends to measure each dimension as I tightened and keep them equal > (=square wing/parallel spars) Ended up gluing and nailing the ribs to the > spars while I could still slide the ribs left and right. After cured I > checked the tramell and snugged up the cables and safety wired > them. Where they cross over each other I slit some small aquarium hose or > clear tygon tube from Home Depot about an inch long. I slid those over > each cable where they crossed to protect them from chaffing each other and > used two small tie wraps to snug up the whole intersection against > vibration. In moving the very few ribs that are in your way, I only moved > them enough to just clear the ribs--then glued in some dry popsicle sticks > to the flat of the truss that came closest to touching the cable for added > protection. (similar to the doubler idea) > > Mike C. > > ________________________________________________________________________________
Date: Jan 24, 2004
Don't forget the Bleriot Clif > > All the indoor flying models for the kids doing Science Olympiad have aft > CG -- some of them even have the CG aft of the wing -- it works for them > 'cause of massive tail volume (a long tail boom and area equal to 50% of the > wing area) and the same airfoil as the wing (a lifting tail vs "flat > plate"). > > Mike C. ________________________________________________________________________________
Date: Jan 25, 2004
Subject: Re: Rib jig
In a message dated 1/24/04 1:25:14 PM Central Standard Time, engelmannd(at)icon.co.za writes: << Does anyone have an accurate cad drawing for a rib with 1" holes for the spars? I want to make a three piece wing with 1" routed spars >> Deon, If you just measure out the dimensions listed on the plans, then blend in the place on the top where there is a little dip, you'll be just fine to build the ribs to this shape. Chuck Gantzer Wichita KS NX770CG ________________________________________________________________________________
Subject: Seattle visit next week......
Date: Jan 25, 2004
Clif Dawson and I are going to the Boeing Museum (I know it's not called that but that's where it is and I don't remember the correct name and I'm too lazy right now to investigate) next Sunday, Feb 1. One of the Concords is there along with the rest of the really cool stuff they already have.....excellent aviation museum. So this is an inviation for anyone in the area so inclined.....to join us...... I arrive at SEATAC around 10:45 and will go directly to the museum to meet Clif...... Jim in Plano ________________________________________________________________________________
Subject: Re: Seattle visit next week......
Date: Jan 25, 2004
Don't miss "The Red Barn". This is Boeing's original building. It has been restored and is attached to the main museum building. I was there last October and all of the really cool stuff is located there. Greg Cardinal ----- Original Message ----- From: Jim Markle To: pietenpol-list(at)matronics.com Sent: Sunday, January 25, 2004 9:40 AM Subject: Pietenpol-List: Seattle visit next week...... Clif Dawson and I are going to the Boeing Museum (I know it's not called that but that's where it is and I don't remember the correct name and I'm too lazy right now to investigate) next Sunday, Feb 1. One of the Concords is there along with the rest of the really cool stuff they already have.....excellent aviation museum. So this is an inviation for anyone in the area so inclined.....to join us...... I arrive at SEATAC around 10:45 and will go directly to the museum to meet Clif...... Jim in Plano ________________________________________________________________________________
Subject: about a different type of flying
Date: Jan 25, 2004
Don't know if anyone's seen this link. Cam on the mars rover that you can pan around and zoom. Need quicktime though. http://www.panoramas.dk/fullscreen3/f2_mars.html walt evans NX140DL ________________________________________________________________________________
Subject: Rib jig
Date: Jan 25, 2004
Hi Here are some pics of my rib jig. The paper will be removed and the rib redrawn on the jig when completed Please give comments and critique as needed. Thanx Deon Engelmann EAA322 Midrand # SA12055 Pretoria South Africa ________________________________________________________________________________
Date: Jan 25, 2004
Deon: Make sure that, when you finish your jig, all of the ribs will be identical. On mine, the outside cannot move and everything is pinned up against it from the inside. This produces identical ribs. The cams are not bottomed out. The holes are offset and will turn farther if the wood happens to be a little narrower, or not as far if the strips are a little wider. Then secured with the wing-nuts. There will be some variance in the cap strips and some of them are more flexible than others. From the look of your jig right now, it looks like if some of the strips bend easier than others, the curves on the bottom and top of your ribs may change from rib to rib. But that's your call, this is what makes homebuilding so much fun. You have drawn in uprights on both sides of the spars. You don't really need this, you only need them on the inboard sides of your spars; you will put in compression X-bracing wires inside the wing which will force the spars together. If you feel you must put them (the uprights) in anyway, wait until you have glued the ribs to the spars or you will have a very difficult time sliding them on to the spars. If you put them on last you will have a much tighter fit/and less cursing !! I used wax paper and scotch tape to keep the glue off of the jig. If you could make the jig out of Plexiglas you wouldn't need anything as the glue would not stick. I could not find anything thick enough made out of plastic that was large enough and affordable. I have read where others have and said it worked quite well. Let me know if you have any other questions or don't understand my view point on something. You better get to bed boy, isn't it like 11:30 p.m. there? md PS Did you get those pics of my plane, what do you think? ________________________________________________________________________________
From: "PHILIP HUMPHREY" <phil.humphrey(at)btopenworld.com>
Date: Jan 25, 2004
Hi, There was a UK homebuilt with a 16% thick gottingen 535 wing section - heavily undercambered - it's CofG range was 25% - 35% and it needed a tailplane incidence of +3 degrees. Didn't go very fast! Phil Humphrey ----- Original Message ----- From: <Rcaprd(at)aol.com> >............. Does anyone have the C.G. range of the Ryan Navion, or any other plane that has an undercambered > airfoil ? > > Chuck Gantzer > NX770CG > ________________________________________________________________________________
Date: Jan 25, 2004
If that is the one at Paine field, then don't miss the Me-262 hangar, they are building 5 exact flying replica ME-262s. It's a great tour. #1 has flown, but had a minor accident involving the landing gear, is probably ready to re-commence with testing. Dave Rowe
January 13, 2004 - January 25, 2004
Pietenpol-Archive.digest.vol-dq
