Pietenpol-Archive.digest.vol-dt
February 26, 2004 - March 21, 2004
Hi all,
I have an older style (more like old) 80" Sears bandsaw. Has anyone been able
to figure out how to slow down this perticular band saw so it can cut metal?
I have been trying to figure out how to add a "jack shaft" and a pully to gear
it down but I can't figure out how to do it with the way the motor is mounted
under the table. So, if anyone else has this saw I'd apreciate suggestions.
Chris T.
Sacramento, Ca
<001001c3fcf2$21412af0$4f119241@Spot>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<001801c3fca9$d548daa0$1b02a8c0@WorkGroup>
I assume the motor is a separate item and not built in?
In other words, belt driven?
If so, go get a half horse, two speed washer motor
and wire it to a two way switch. There will be 1725 rpm
on the high speed and 862.5 on the low. This is what I
have done with my old beaver and it works just fine.
If you can find the older style Speed Queen 2 speed
motor, the wiring is dead simple.
If it is an integral part of the saw then you're in for a
lot more work. :-)
Clif
----- Original Message -----
To: pietenpol-list(at)matronics.com
Sent: Thursday, February 26, 2004 9:24 PM
Subject: Pietenpol-List: Bandsaw
Hi all,
Chris T.
Sacramento, Ca
Just put a smaller pully on the motor or a larger pully on the saw.
Howdy
From: | "Laurits Larsen" <pietlars(at)earthlink.net> |
Hi:
I have a Sears 80" bandsaw too. It dates back to the 80's also. I also have
a router varible speed control that I got from Harbor Freight. I got curious
after your message and I tried it out on my bandsaw. It worked fine, slows the
speed significantly. There is a caveat on the speed control that it is not
for use on AC capacitor start motors.
I noticed in a recent Harbor Freight catalog that the speed control special price
(half price deal) is $12.95.
I use mine occasionally on the router and it performs as it should.
Hope this is useful.
Lou Larsen
P.S. Just finished installing the brake assemblies on my straight axle gear, (21"
wheels). used 5" go cart brake drums with external brake bands; mechanical
/cable system. Have the bird back on the gear now.
Sent: Friday, February 27, 2004 12:24 AM
Hi all,
Chris T.
Sacramento, Ca
From: | "Richard Navratil" <horzpool(at)goldengate.net> |
You could try making a variable control. Get a pice of electrical cord with the
male end, a steel double outlet box with cover plate, a standard wall plug and
a light switch dimmer control. I used that setup to control heat on solder
irons.
Dick N.
Sent: Thursday, February 26, 2004 11:24 PM
Hi all,
Chris T.
Sacramento, Ca
I would be concerned about burning out the motor doing that. I think
the jackshaft would be a preferable alternative if you can figure out
how to add one satisfactorily.
John Ford
john(at)indstate.edu
812-237-8542
>>> horzpool(at)goldengate.net Friday, February 27, 2004 10:20:34 AM >>>
with the male end, a steel double outlet box with cover plate, a
standard wall plug and a light switch dimmer control. I used that setup
to control heat on solder irons.
Dick N.
Hi all,
been able to figure out how to slow down this perticular band saw so it
can cut metal? I have been trying to figure out how to add a "jack
shaft" and a pully to gear it down but I can't figure out how to do it
with the way the motor is mounted under the table. So, if anyone else
Chris T.
Sacramento, Ca
Another alternative would be to install a 3 phase motor with one of the new
solid state variable speed controls.
These things will go from near zero RPM to rated speed with the turn of a
dial and still deliver full power. You would still have to change blades
for metal but not all metals should be cut at the same speed anyway.
Example Aluminum versus 4130
Bob B.
Subject: Re: Pietenpol-List: Bandsaw
> John
> John Ford
> 812-237-8542
> Dick N.
> From: Catdesign
> Hi all,
> Thanks
> Chris T.
> Sacramento, Ca
If the motor drive a belt one can use the motor as the jack shaft with a
double pulley on the motor. I made mine with a 14" diameter out of 3/4"
plywood. Then when I want to cut steel, which is infrequent, I put a v-belt
between this large pulley and a small one on a second motor. Only turn on
the 2nd motor. Don't forget to remove the v-belt when done so you don't
damage a 2nd motor with extra high speed if your turn on the original motor.
I have been doing this on my 20" bandsaw for over 30 years without a
problem.
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Editor, EAA Safety Programs
cgalley(at)qcbc.org or sportpilot(at)eaa.org
Always looking for articles for Sport Pilot
> John
> John Ford
> 812-237-8542
> Dick N.
> From: Catdesign
> Hi all,
> Thanks
> Chris T.
> Sacramento, Ca
Subject: | Re: Pietenpol-List Digest: 3 Msgs - 02/26/04 |
> From: "Catdesign" <catdesign(at)intergate.com>
> Hi all,
> anyone been able
> cut metal?
Woodworking Bandsaw Owners,
You might try this before investing in modifications or a new saw. Install an
old blade and try your luck at friction sawing. This is kind of scary stuff initially,
with lots of noise and sparks --- not for everyone. Wear ear, eye,
and hand protection. Faster band speeds work better. Installing the blade with
teeth upside down is sometimes worth a try.
Nervous Nellies and purists may bring up the matter of edge crack propagation in
the heat affected zone. Satisfy yourselves on this point by bending a narrow
test piece till it fails. That is what Bernie would have done.
Happy landings, Mike Fisher
Dear List,
I ordered my axle (for a wood gear - spoke wheel set up). I ordered 1 1/8
X .083 Chromoly Tubing from Wag-Aero. Never having ordered Chromoly Tubing before
I wasn't sure what to expect. It has arrived and it looks and feels just
too light and flimsy to serve as an axle. So, did I screw up, or is this the
same material that most builders are using?
Dave
From: | "Peter W Johnson" <vk3eka(at)bigpond.net.au> |
Dave,
I am using 1 1/4 x 0.120 4130. I bought the ready made axle from Aircraft
spruce. Looks about the right size too.
Cheers
Peter.
-----Original Message-----
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of dpaul
Subject: Pietenpol-List: Axle
Dear List,
1/8 X .083 Chromoly Tubing from Wag-Aero. Never having ordered Chromoly
Tubing before I wasn't sure what to expect. It has arrived and it looks and
feels just too light and flimsy to serve as an axle. So, did I screw up, or
is this the same material that most builders are using?
Dave
From: | "Christian Bobka" <bobka(at)compuserve.com> |
Subject: | Re: Wing tank side reading gauage |
Max,
I would be sure that Rochester knows that in addition to it reading upside down,
that it has to show full when the cork is at the position farthest from the
indicator. This might not be readily obvious.
Also, you may wish to see if they would be willing to make these and offer them
up for sale through AS and S as there is a distinct market for them.
I would also let them know that the "normal" shortest gauge is no longer offered
by AS and S and they may wish to contact AS and S and find out why.
I will let you know if I want some after I check a few things.
Good work. I used to live in Coppell and Addision before that and always had the
instention of looking up Rochester. I think US Gauge is there too.
Chris Bobka
Minneapolis
Sent: Wednesday, February 25, 2004 10:54 AM
Subject: Re: Pietenpol-List: Wing tank side reading gauage
In a message dated 2/25/2004 10:35:12 AM Central Standard Time, bobka(at)compuserve.com
writes:
Max,
Can you give the p/n and the page in the 1999 AS and S catalog. I am having
trouble trying to tell which one you are talking of.
chris bobka
Cris:
1998-1999 AS&S, pg. 152, bottom right corner of the page. P/N 05-16800. It
is right under the Stearman type float gauge. This gauge is made to mount from
the top down only. It is sealed from the fuel and operates magnetically. They
can't tell me at customer service why it would not work if you mounted from
the bottom side, but it would register opposite if you mount it from the bottom
up. You can pull it up straight from the Rochester Gauge web site and it
tells a little more about it.
Max,
Arlington, TX.
Dave,
The Flying and glider plans call out 1 1/4 X 12 GA. Chrome-Molybdenum for the
axle. 12 GA. is .1045" thick, I think most guys go up to .120" rather than down
to .095".
1 1/8 X .083" does sound a little light and flimsy.
Mine is split axle and I chose 1 1/4 X .120".
Skip
Dave
There is a very good article of a large Jodel variant...FALCONAR F12A finished
in HIPEC with NO ribstitching in this months Custom Planes Magazine. This aircraft
wing loading is 12.857 lbs. sq.ft. at gross. Much more than any Pietenpol.
Shawn Wolk
Winnipeg, MB
C-FRAZ Pietenpol Aircamper
C-GZOT Skyhopper 2
I used 1 1/8" x .100 and was not happy with the amount of bow in the axle. I switched
it to a 1 1/4" x .120
Dick N.
Sent: Friday, February 27, 2004 7:30 PM
Dear List,
before I wasn't sure what to expect. It has arrived and it looks and feels just
Dave
The key word in Max's post is that these are "magnetic".
I beleive the Rochester gauge uses a magnet at the end of the spiral rod. The
poles of this magnet align with another magnet that is attached to the indicating
card. The magnet on the spiral is in the gas. Then there is the aluminum
of the housing and then the card is "outside" of this housing in the air, balanced
on a point as is a compass. There is no way for fuel to leak out ever!
Hence, the "hermetically sealed" statement. The magnetic field carries through
the aluminum of the housing to enable this. Once the poles of the two magnets
align, they don't move out of alignment at all. It remains rigid in the magnetic
flux.
This is the way the fuel gauges in the P-51 Mustang and the PT-19/22/26 worked.
Look at one if you ever get the chance.
Max, confirm this is the way they are constructed. I am quite sure from the description
that this is the case. If it is indeed true then it is the way to go.
These would be the most superior of the float style gauges to use!
chris bobka
Sent: Thursday, February 26, 2004 2:48 PM
We may need 6.
Barry
Sent: Wednesday, February 25, 2004 11:01 AM
Subject: Pietenpol-List: Wing tank side reading gauage
Pieters:
I have been visiting with Rochester Gauges here in Dallas about turning the
cylinder inside their spiral action fuel gauge upside down so it will register
fuel quantity correctly in a center section wing tank application.
This is a precision magnetic gauge with a float traveling on a spiral rod to
record fuel level on hermetically sealed side-reading dial marked E,1/4,1/2,3/4,F.
All aluminum construction. Housing has 1-1/2" NPT male threads for connection
to threaded bushing (they sell aluminum bushings and flanges for this
gauge as well). Length "L" 6", Float Travel 4-1/4". In the 1999 AS&S catalogue
they sold a top mounted one for $39.00.
They manufacture them here in Dallas. If I can talk them into making one that
will mount on the bottom of a tank, instead of only from the top, how many
of you would be interested in purchasing one. They have a $125.00 minimum order
for PO's. I have a tax I.D. # and could purchase them direct, if enough of
you are interested. They are supposed to call me back and let me know if they
can or will make this gauge as per my request. I thought it might have a greater
influence on them if they could sell more than one. We have not got a
price yet, or if they will do it, but, I don't expect it would be a lot higher
than the 1999 AS&S price on the similarly built top mount fuel gauge.
If any of you are interested let me know back ASAP. Bargaining power will
be much better with numbers, I'm sure.
Max
Arlington, TX.
Three phase? You running three phase on single phase?
Chris Bobka
new
> Bob B.
> From: "John Ford" <Jford(at)indstate.edu>
> To:
> Sent: Friday, February 27, 2004 9:40 AM
> > John
> > John Ford
> > 812-237-8542
> > Dick N.
> > From: Catdesign
> > Hi all,
> > Thanks
> > Chris T.
> > Sacramento, Ca
<003201c3fd4f$4c1bf450$9070fea9@VALUEDCB7D4C82>
<01ae01c3fdac$e8d0b4e0$0101a8c0@domain>
Again back to those big commercial washers.
Those that are not on an inverter drive and
in a single phase location use humungus
capacitors to "convert" the motors to single
phase. There have been all kinds of systems
used over the years. An article and assorted
letters on this very subject appeared in Fine
Woodworking years ago. I never had any need
or interest in figuring out how that worked but it
does. If you really want to know find your nearest
Wascomat or Unimat service place and ask their
techs.
Clif
> Chris Bobka
<001001c3fcf2$21412af0$4f119241@Spot> <002901c3fd45$42347250$0600a8c0@laptop>
This won't work. These motors depend on the current
CYCLES not voltage for speed. At North American 60
cycle current you get 1725 rpm. Using the same motor
in Europe at 50 cycles gives you 5/6 X 1725 rpm. The
only way around this is an inverter drive which takes in
the 60 cycle, turns it into DC, then converts it back to
variable cycle voltage from 0 up to whatever the designer
needs for the application. This is now used in industrial
washing machines from 18 lb up through 30,50, 75. 125
175 for places like hospitals and hotels. Electric trains
and monorails use huge inverters. The motor in your
hand drill is a brush motor that uses variable voltage. It
doesn't depend on the cycles at all.
Sent: Friday, February 27, 2004 7:20 AM
the male end, a steel double outlet box with cover plate, a standard wall plug
and a light switch dimmer control. I used that setup to control heat on solder
irons.
Dick N.
Hi all,
gear it down but I can't figure out how to do it with the way the motor is mounted
Chris T.
Sacramento, Ca
All the plans I've got specify 1 1/2" tubing.
That's the 1932 Fly+Glide Piet, 1933 F+G
Scout split axle and my plans from Don
Pietenpol.
Where's this reference to 1 1/4"? My copies
came from EAA 10 years ago. Did they
make a change somewhere along the line?
So, Richard, I assume your 1 1/4" is holding
up fine? I would rather use that if it does. I
could make it fit my wheels more easily.
Clif
Dave,
to .095".
Skip
Clif,
Your right. F&g 1 1/2 X 12 GA. The 1934 plans split axle 1 1/2 X 10 GA. (.130")
My landing gear is a combination of 1934 plans, Grega, and Wag Aero Sport trainer,
because I wanted wider tread than Piets 56". Wag Aero has the 1 1/4 X .120".
Skip, reading better with morning light and stronger glasses.
Pietenpol.
Clif
Chris T.......I subscribe to a magazine called "The Home Shop Machinist"
which is published bi-monthly. The Jan/Feb 2004 issue has an article on converting
a wood-cutting bandsaw to a metal-cutter. The conversion he describes
involves the addition of a jackshaft and idler pulley and may be too involved for
your interests, but he has some good data on saw blade speeds. This is kind of
an
obscure publication and you might have difficulty finding a copy. If youre
really interested, contact me off-net and I'll zerox a copy for you and send it
by snail mail. Carl Vought
Subject: | three phase from single phase was Bandsaw |
Chris,
The answer is not exactly, today there are a number of low cost variable
frequency solid state single phase to three phase converters on the market.
I run a small metal lathe with such a beast. For example if I'm drilling
and reaming a number of parts using the three jaw chuck and a drill chuck in
the tailstock. Being very lazy I don't like to change belt pulleys all the
time. So now I can change speed with the twist of a knob. Three phase
motors are a little cheaper than single phase and I got the converter from
ACTECH www.actechdrives.com is their web site. I have no connection with
this company and if anyone is interested in knowing more please contact me
off line.
Bob Bailey
> Chris Bobka
Subject: | bobka(at)compuserve.com |
In a message dated 2/27/2004 7:49:48 PM Central Standard Time,
bobka(at)compuserve.com writes:
> Max,
> down, that it has to show full when the cork is at the position farthest from
> the indicator. This might not be readily obvious.
> them up for sale through AS and S as there is a distinct market for them.
> offered by AS and S and they may wish to contact AS and S and find out why.
> had the instention of looking up Rochester. I think US Gauge is there too.
> Chris Bobka
Chris,
The gauge reading backwards was the first concern I had (E for F etc..). My
solution for this was to simply turn the cylinder upside down.
AS&S would not even talk to me about trying to special order the 6" gauge
that they don' carry anymore, let alone take the initiative to pick up the phone
and ask about designing an inverted fuel gauge of the same type. I do not
intend to help AS&S increase sales due to this fact.
The people at Rochester have not been much more help. If the computer says
it cannot be done, these people now days just say "It can't be done" and except
it -- and move on to the next call and the next coffee break. There is no
brain power involved. It is scary to me; how does anything get accomplished in
this country anymore?
At this point, I have taken the initiative done all of the leg work/research
and will market the item myself. If Rochester doesn't come through, I will
take your suggestion and go visit with US Gauge.
Please feel free if you have any more question or concerns,
Max Davis
Arlington, TX. 817.516.1116
Subject: | Re: Magnetic gauge |
In a message dated 2/27/2004 9:34:54 PM Central Standard Time,
> The poles of this magnet align with another magnet that is attached to the
> indicating card. The magnet on the spiral is in the gas. Then there is the
> aluminum of the housing and then the card is "outside" of this housing in the
> air, balanced on a point as is a compass. There is no way for fuel to leak out
> ever! Hence, the "hermetically sealed" statement. The magnetic field
> carries through the aluminum of the housing to enable this. Once the poles of
the
> two magnets align, they don't move out of alignment at all. It remains
> rigid in the magnetic flux.
> worked. Look at one if you ever get the chance.
> description that this is the case. If it is indeed true then it is the way
> to go. These would be the most superior of the float style gauges to use!
> chris bobka
Chris,
You have described this gauge perfectly, and also why I am so interested in
it.
Max,
Arlington, TX.
<00cc01c3fdcf$5ba20bf0$96715118@dawsonaviation>
Exactly! The brush type motor in a drill or "Skill" saw are called "universal
" motors and can be run on AC or DC. only voltage dependent. Only reason the
modern day ones cant be run on DC is the variable speed trigger is a circuit
by itself and can't deal with the DC.
I'm sure it wouldn't be hard to find an old style 1/2" drill at a flea market and
run it thru a rheostat, and somehow run it through the existing motor
walt evans
NX140DL
Sent: Saturday, February 28, 2004 2:49 AM
<<<< The motor in your
doesn't depend on the cycles at all.>>>>>>
irons.
Dick N.
Hi all,
able to figure out how to slow down this perticular band saw so it can cut metal?
Chris T.
Sacramento, Ca
From: | "Dennis Engelkenjohn" <wingding(at)usmo.com> |
You could just get a Dayton AC/DC variable speed motor. Comes with its own converter
and is reversible too. Available in 1 1/2 hp rating, 0-2500rpm. Thats what
I did on my Sears 80" bandsaw. Salvaged the motor off some junk.
Dennis Engelkenjohn
Subject: | bandsaw gear reduction |
Hi, Chris T.
My partner, Tom Schildt, has figured out a neat way to achieve the necessary
reduction to cut 4130 steel on a Delta 14" bandsaw. We purchased a wet-dry grinder
from Harbor Freight with a 1/3hp(?) electric motor for less than $40, (item
#35098). The dry grinder rpm is 3450 and the wet grinder rpm is 160. The
cost of a gear box new that would give a similar reduction is almost $400. To
achieve the blade speed of approximately 270'/min. we had to further reduce the
rpm by about 1/2, so we replaced the wet grinder wheel with a 2" pulley, and
connected it with a 1/2" belt to the 4" pulley on the lower 14" bandsaw wheel.
The bandsaw now has 2 motors which we will operate separately - one is the regular
1hp motor rigged for cutting wood, and the other is the 1/3hp motor rigged
for cutting 4130 steel. We haven't yet hooked all this up so we don't know
how it will work. It should be done in a couple of weeks. If you have any questions
please call at 337/937-6116 or email me at bl
ugoos1@d
lps. Jim Cooper
From: | "Norman Stapelberg" <norshel(at)mweb.co.za> |
I am using a frequency drive on my drill press, motor is a three phase
0.75 Kw ( 1Hp) 380/220 volt, cant remember if I got it connected in star
or delta will have open it and check, the drive is a single phase input
and three phase 220volt output. Please note that in South Africa we use
220volt for domestic use. The drive can also be controlled via a
variable resistor for different frequencies (speeds) I use
pre-programmed speeds, found that under 15Hz the current is to high. I
also have one on my three phase compressor programmed to 50Hz. So far no
problems benn about 5 years in use.
Norman Stapelberg
ZS-VJA (rebuilding)
South Africa
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Clif
Dawson
From: Richard Navratil <mailto:horzpool(at)goldengate.net>
Dick N.
From: Catdesign <mailto:catdesign(at)intergate.com>
Hi all,
Chris T.
Sacramento, Ca
Mistrakes! We don't make no misteaks!........oops!
Clif :-) :-)
I really am doing something on my Piet.
http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID=27
Sent: Saturday, February 28, 2004 4:10 AM
Subject: Re: Pietenpol-List: Axle
Clif,
Pietenpol.
Clif
From: | "Fred Weaver" <Mytyweav(at)earthlink.net> |
Nice looking work Clif. I especially like your airspeed emblem.
Weav
Sent: Saturday, February 28, 2004 10:09 AM
Clif :-) :-)
http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID27
Subject: | Spiral Fuel Gauge Interest Group |
Group:
Thanks for your quick response. I visited, in person, with a customer
service rep. and an engineer yesterday about the inverted spiral fuel gauge. They
have experimented a little with the idea and think they can make the
adjustments for us without too much retooling. This is a large company and a very
limited production run on an item they have never had a request for. In order
for
them to produce the item, I will have to purchase at least 10 units at a time.
In order to do this, I will make the purchase through my family's hardware
store in Silverton, Texas, once they've committed to manufacturing them. I am
supposed to hear back from them on Monday or Tuesday of next week.
The cost should be about $45 per unit plus tax and shipping charges to your
destination. I will ship them out to you on demand.
Please email back to confirm your order.
Max L. Davis
Arlington, TX.
817.516.1116
Subject: | Re: Spiral Fuel Gauge Interest Group |
Max,
I am sorry I didn't respond to your request for a picture. I just got a chance
to sit down and read a week's worth of email. You have seen the gauge by now
and it has been described very well already by Chris and others. I can see no
reason it won't work, if the readout can be reversed.
However, I would like to throw out a thought and see if others have had a similar
concern or have a solution. The deepest part of the wing tank is usually somewhere
about 1/2 way between the front spar and rear spar. It would seem that
is where the gauge has to go. Here is my concern. When the passenger is getting
in and out their head and back come pretty close to the bottom of the center
section. I have not figured out where to place the gauge so it didn't take
a chunk out of a skull or back. I like the Stearman gauge but have rejected
it for this reason. I hope to fly with a passenger tomorrow and will closely
observe how they get in and out vis a vis the bottom of the wing and report
back.
If someone has a thought on how to overcome this I would love to have this upside
down gauge on mine too.
Ted
PS my tank is not 6" deep. I assume that 6" is measured from the very bottom of
the spiral to the very top of the gauge that is outside of the tank and that
only 4 1/2" is inside the tank?
Sent: Saturday, February 28, 2004 3:12 PM
Subject: Pietenpol-List: Spiral Fuel Gauge Interest Group
Group:
Thanks for your quick response. I visited, in person, with a customer service
rep. and an engineer yesterday about the inverted spiral fuel gauge. They have
experimented a little with the idea and think they can make the adjustments
for us without too much retooling. This is a large company and a very limited
production run on an item they have never had a request for. In order for
In order to do this, I will make the purchase through my family's hardware store
The cost should be about $45 per unit plus tax and shipping charges to your destination.
Max L. Davis
Arlington, TX.
817.516.1116
In a message dated 2/28/2004 9:21:49 PM Central Standard Time,
nfn00979(at)naples.net writes:
> similar concern or have a solution. The deepest part of the wing tank is
> usually somewhere about 1/2 way between the front spar and rear spar. It would
> seem that is where the gauge has to go. Here is my concern. When the
> passenger is getting in and out their head and back come pretty close to the
bottom
> of the center section. I have not figured out where to place the gauge so it
> didn't take a chunk out of a skull or back. I like the Stearman gauge but
> have rejected it for this reason.
Ted:
The gauge is six inches overall. An inch and a half or so is outside of the
tank (the readable part). AS&S has a coupling and a flange just below the
gauges in question that would allow you to adjust the height of the gauge to some
extent. My tank is flat on the bottom, so I could have a larger fuel
capacity. It is probably 4-1/4" in the rear and probably 5" or 5-1/2" in the middle.
I would mount this gauge or a stearman type over to the side (right side) so
as to be out of the way and as far back as possible. I personally, am
concerned primarily about satisfying the FAA rules for a gauge, having a safe gauge
that cannot leak or be broken off by an accident and knowing where or when
"empty" is. Most of the stearman type gauges in current use on Piets, is as
close to the right rear cabane as is allowable; from what I have seen. At any
rate, this gauge does not hang down near as far as a 6" stearman type.
Max
In a message dated 2/28/2004 10:11:14 PM Central Standard Time,
Andimaxd(at)aol.com writes:
I like the Stearman gauge but have rejected it for this reason.
Max
My Stearman gauge was mounted just forward of the front windscreen. If I were
to use the magnetic unit I would like to use the existing fitting which is
welded into the tank bottom. It is a 3/4" female NPT. There is about 4-3/4 "
inside the tank at that point ( I will have to take an exact measurement. If an
adapter is used,there may be a bit more clearance at the top. Do you believe
my existing Stearman mount could be used ? Don
I was given some old magazines, and found an article on Hipec from the
early 80's, it is shown in Hipec advertising from 2003, still original
covering and paint. A pal came up with a great idea, we are going to
rig a test section, and mount it on a luggage reack on his truck, and
abuse it to death, inlcuding making rips and tears, and see if we can
get the fabric to ballon and part company. From the static test pieces
I have seen, I doubt we will be able to cause separation without
destroying the wood. We will also make a test rib, and try to pull it
apart and measure the force required.
Surprised the Jodel didn't go with ribstitching, as they do recommend it
for wingloading in excess of 8-9 lbs.
> F12A finished in HIPEC with NO ribstitching in this months Custom
> Planes Magazine. This aircraft wing loading is 12.857 lbs. sq.ft. at
> Shawn Wolk
> Winnipeg, MB
> C-GZOT Skyhopper 2
Chris,
I know you asked about slowing down the bandsaw. I thought I would add a possible
alternative. Use it as is. I have the same bandsaw. I wanted to get started
on cutting out metal fittings. I just used the wood cutting blade that was
on it at the time. I was shocked when it worked. I have since cut ALL of
my metal fittings using the band saw at full speed with either a wood cutting
blade or a metal cutting blade. I look back now and wonder why I wasted time
trying to figure out how to make something to slow it down. The only caution
I give is to make sure the saw is cleaned out after cutting wood and before cutting
metal. Otherwise the sparks from cutting metal might cause a fire with
the sawdust.
Hope this helps someone.
Ted
Hi all,
Chris T.
Sacramento, Ca
well... I did it again. I picked up another nearly finished GN-1. I did the
same thing back in April of 2002. On that one I pulled the control stick assembly,
some turnbuckles, and various other hardware and then sold the rest for
a little more than I paid for it.. I basically got parts for "free" that way.
Anyways, I'm eating breakfast at the airport restaurant on Sunday and afterwards
I decided to take a drive on the ramp and around the hangars. The weather was
beautiful and a drive on the ramp checking out the planes seemed like a great
idea. As I near the hangars I am thinking to myself... "ya know... you never
see a Piet in a hangar with someone working on it" they're rare out here.
Well.. no sooner had I thought that I round a corner and much to my amazement there
is a craft sitting there looking very much like a Piet. I pull up to it
and and I'll be damned if it's not a GN-1! I get out and take a look and I see
a "for sale" sign on it. The gentleman who owns it comes out of his hangar
and we chat. He picked up the project last year and intended to finish it but
has now changed his mind. He never did much to it and it's still in the same
state is was when he bought it.
I look over the workmanship and I am impressed. Very nice work. Some areas are
kinda iffy, but overall you could tell a good craftsman had put his time into
it.
So now I'm thinking "I could sure use them wings!" Having those wings would cut
my building time down about 6-9 months. The wings are about 90% complete.
Just need leading and trailing edge aluminum and ailerons. They have the drag-anti
drag wires in place and it's trammeled and ready for final assembly.
The fuse contained a J-3 cowl, J-3 engine mount for A-65, J-3 Fuel tank, J-3 landing
gear with cleveland brakes, Maule tailwheel, complete control stick assembly.
I'm interested but I'm guessing the guy is probably wanting about $4,000 for it
all. I ask him anyway..... he names a price I absolutley cannot refuse.
So.... on Wednesday I'm going to pick it up. He lives about 15 minutes away from
me so it ought to be simple to move over. I'm going to use the wings and J-3
Fuel tank and maybe some other misc items.. I'll probably sell the fuse/tail
feathers and remaining parts.
This has accelerated my project by almost a year. The only draw back and issue
I'm having a problem with is I will not have built my entire plane.... am I
"selling out" by doing this? I feel guilty that I'll be using someone elses
time/labor to get my maching in the air....so I'm thinking that I'll use these
new wings for now and then when I want a little project I'll make my wings and
then switch over.... but in the meantime I'll have a flying machine much sooner.
gimme some feedback.
DJ
www.imagedv.com/aircamper
_
This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>.
From: | Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov> |
Subject: | Re: bought a GN-1 ! |
<4012B457.CBE0EBFC(at)shaw.ca>
DJ-- in no way are you 'selling out ' by using wings that another built
! No way hose. You still will
have way, way, way, more labor into your GN-1 than some of these fast-build
or 'builder assisted' programs
that are really kind of a joke to qualify for the 51% rule. Doesn't
matter--I'm just glad to see another Piet or
Grega taking wing. Excellent move. Look at how much work you've put
into your engine conversion
alone ? You still have fabric and painting left too which to me makes it
yours--personalizes it.
I started with a fuselage skeleton that had changed hands over the
years and a runout 65 engine with no logs.
I even bought a set of wing ribs from a guy that had bought them from
Charlie Ruebeck. I had the same
misgivings that you are having but after completing the project I realized
that the majority of it was done by me.
Go for it !
PS-- finally got to fly over the weekend. Felt great. Walt E....any
flying in NJ for you ? Hope so.
Mike C.
From: | "Jack Phillips" <pietflyr(at)bellsouth.net> |
Hey DJ,
Having built all the structure (which is the most fun part of building a
plane - that and fabric covering, in my opinion) in my Piet, I can tell you
that doing all the systems work and making everything fit is still plenty
enough work for you to be able to say "I built this airplane". At least, as
long as the FAA or DAR concur that you still did 51% of the work. Go for
it.
Jack Phillips
Finally getting weather warm enough to spray some Poly Spray. It's been a
long winter.
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of DJ Vegh
Subject: Pietenpol-List: bought a GN-1 !
the same thing back in April of 2002. On that one I pulled the control
stick assembly, some turnbuckles, and various other hardware and then sold
the rest for a little more than I paid for it.. I basically got parts for
"free" that way.
afterwards I decided to take a drive on the ramp and around the hangars.
The weather was beautiful and a drive on the ramp checking out the planes
seemed like a great idea. As I near the hangars I am thinking to myself...
"ya know... you never see a Piet in a hangar with someone working on it"
amazement there is a craft sitting there looking very much like a Piet. I
pull up to it and and I'll be damned if it's not a GN-1! I get out and take
a look and I see a "for sale" sign on it. The gentleman who owns it comes
out of his hangar and we chat. He picked up the project last year and
intended to finish it but has now changed his mind. He never did much to it
and it's still in the same state is was when he bought it.
are kinda iffy, but overall you could tell a good craftsman had put his time
into it.
cut my building time down about 6-9 months. The wings are about 90%
complete. Just need leading and trailing edge aluminum and ailerons. They
have the drag-anti drag wires in place and it's trammeled and ready for
final assembly.
landing gear with cleveland brakes, Maule tailwheel, complete control stick
assembly.
it all. I ask him anyway..... he names a price I absolutley cannot
refuse.
from me so it ought to be simple to move over. I'm going to use the wings
and J-3 Fuel tank and maybe some other misc items.. I'll probably sell the
fuse/tail feathers and remaining parts.
issue I'm having a problem with is I will not have built my entire plane....
am I "selling out" by doing this? I feel guilty that I'll be using someone
elses time/labor to get my maching in the air....so I'm thinking that I'll
use these new wings for now and then when I want a little project I'll make
my wings and then switch over.... but in the meantime I'll have a flying
DJ
www.imagedv.com/aircamper <http://www.imagedv.com/aircamper>
_
information on an anti-virus email solution, visit .
dGhhbmtzIGZvciB0aGUgc3VwcG9ydCBndXlzLiAgIEkgYW0gc29vb29vIGV4Y2l0ZWQgYXQgdGhl
IHBvc3NpYmlsaXR5IG9mIGZseWluZyB0aGlzIHBsYW5lIGJlZm9yZSB0aGUgZW5kIG9mIHRoZSB5
ZWFyLiAgSSdsbCBuZWVkIHRvIHN0ZXAgdXAgYW5kIGJ1c3QgYXNzIGJ1dCBub3cgaXQncyBhIHJl
YWxpdHkuDQoNCllvdSBndXlzIGFyZSByaWdodC4uLiB0aGVyZSdzIHN0aWxsIHBsZW50eSBvZiB3
b3JrIHRvIGJlIGRvbmUgZXZlbiBoYXZpbmcgdGhlIHdpbmdzLiAgU3RpbGwgbmVlZCB0byBidWls
ZCBhaWxlcm9ucywgZmFicmljYXRlIGxpZnQgc3RydXRzLCByb3V0ZSB0aGUgY29udHJvbCBjYWJs
ZXMgYW5kIHB1bGxleXMsIGV0Yy4gICANCg0KSSdsbCBwb3N0IHVwIHNvbWUgcGljcyBvbiBteSBz
aXRlIG9mIHRoZSBuZXcgR04tMSBhbmQgaXQncyBhbGwgaW1wb3J0YW50IHdpbmdzIHdoZW4gSSBn
ZXQgdGhlbSBvbiBXZWRuZXNkYXkgKHdlYXRoZXIgcGVybWl0dGluZy4uIHdlIG1heSBnZXQgcmFp
bikNCg0KREogVmVnaA0KTjc0RFYNCk1lc2EsIEFaDQp3d3cuaW1hZ2Vkdi5jb20vYWlyY2FtcGVy
DQoNCg0KDQotDQoNCiAgLS0tLS0gT3JpZ2luYWwgTWVzc2FnZSAtLS0tLSANCiAgRnJvbTogSmFj
ayBQaGlsbGlwcyANCiAgVG86IHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20gDQogIFNlbnQ6
IE1vbmRheSwgTWFyY2ggMDEsIDIwMDQgNDoyOCBQTQ0KICBTdWJqZWN0OiBSRTogUGlldGVucG9s
LUxpc3Q6IGJvdWdodCBhIEdOLTEgIQ0KDQoNCiAgSGV5IERKLA0KDQogICANCg0KICBIYXZpbmcg
YnVpbHQgYWxsIHRoZSBzdHJ1Y3R1cmUgKHdoaWNoIGlzIHRoZSBtb3N0IGZ1biBwYXJ0IG9mIGJ1
aWxkaW5nIGEgcGxhbmUgLSB0aGF0IGFuZCBmYWJyaWMgY292ZXJpbmcsIGluIG15IG9waW5pb24p
IGluIG15IFBpZXQsIEkgY2FuIHRlbGwgeW91IHRoYXQgZG9pbmcgYWxsIHRoZSBzeXN0ZW1zIHdv
cmsgYW5kIG1ha2luZyBldmVyeXRoaW5nIGZpdCBpcyBzdGlsbCBwbGVudHkgZW5vdWdoIHdvcmsg
Zm9yIHlvdSB0byBiZSBhYmxlIHRvIHNheSAiSSBidWlsdCB0aGlzIGFpcnBsYW5lIi4gIEF0IGxl
YXN0LCBhcyBsb25nIGFzIHRoZSBGQUEgb3IgREFSIGNvbmN1ciB0aGF0IHlvdSBzdGlsbCBkaWQg
NTElIG9mIHRoZSB3b3JrLiAgR28gZm9yIGl0Lg0KDQogICANCg0KICBKYWNrIFBoaWxsaXBzDQoN
CiAgIA0KDQogIEZpbmFsbHkgZ2V0dGluZyB3ZWF0aGVyIHdhcm0gZW5vdWdoIHRvIHNwcmF5IHNv
bWUgUG9seSBTcHJheS4gIEl0J3MgYmVlbiBhIGxvbmcgd2ludGVyLg0KDQogICANCg0KICAtLS0t
LU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQ0KICBGcm9tOiBvd25lci1waWV0ZW5wb2wtbGlzdC1zZXJ2
ZXJAbWF0cm9uaWNzLmNvbSBbbWFpbHRvOm93bmVyLXBpZXRlbnBvbC1saXN0LXNlcnZlckBtYXRy
b25pY3MuY29tXU9uIEJlaGFsZiBPZiBESiBWZWdoDQogIFNlbnQ6IE1vbmRheSwgTWFyY2ggMDEs
IDIwMDQgMTI6MzcgUE0NCiAgVG86IHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20NCiAgU3Vi
amVjdDogUGlldGVucG9sLUxpc3Q6IGJvdWdodCBhIEdOLTEgIQ0KDQogICANCg0KICB3ZWxsLi4u
IEkgZGlkIGl0IGFnYWluLiAgIEkgcGlja2VkIHVwIGFub3RoZXIgbmVhcmx5IGZpbmlzaGVkIEdO
LTEuICAgSSBkaWQgdGhlIHNhbWUgdGhpbmcgYmFjayBpbiBBcHJpbCBvZiAyMDAyLiAgIE9uIHRo
YXQgb25lIEkgcHVsbGVkIHRoZSBjb250cm9sIHN0aWNrIGFzc2VtYmx5LCBzb21lIHR1cm5idWNr
bGVzLCBhbmQgdmFyaW91cyBvdGhlciBoYXJkd2FyZSBhbmQgdGhlbiBzb2xkIHRoZSByZXN0IGZv
ciBhIGxpdHRsZSBtb3JlIHRoYW4gSSBwYWlkIGZvciBpdC4uICBJIGJhc2ljYWxseSBnb3QgcGFy
dHMgZm9yICJmcmVlIiB0aGF0IHdheS4NCg0KICAgDQoNCiAgQW55d2F5cywgSSdtIGVhdGluZyBi
cmVha2Zhc3QgYXQgdGhlIGFpcnBvcnQgcmVzdGF1cmFudCBvbiBTdW5kYXkgYW5kIGFmdGVyd2Fy
ZHMgSSBkZWNpZGVkIHRvIHRha2UgYSBkcml2ZSBvbiB0aGUgcmFtcCBhbmQgYXJvdW5kIHRoZSBo
YW5nYXJzLiAgVGhlIHdlYXRoZXIgd2FzIGJlYXV0aWZ1bCBhbmQgYSBkcml2ZSBvbiB0aGUgcmFt
cCBjaGVja2luZyBvdXQgdGhlIHBsYW5lcyBzZWVtZWQgbGlrZSBhIGdyZWF0IGlkZWEuICBBcyBJ
IG5lYXIgdGhlIGhhbmdhcnMgSSBhbSB0aGlua2luZyB0byBteXNlbGYuLi4gInlhIGtub3cuLi4g
eW91IG5ldmVyIHNlZSBhIFBpZXQgaW4gYSBoYW5nYXIgd2l0aCBzb21lb25lIHdvcmtpbmcgb24g
aXQiICB0aGV5J3JlIHJhcmUgb3V0IGhlcmUuDQoNCiAgIA0KDQogIFdlbGwuLiBubyBzb29uZXIg
aGFkIEkgdGhvdWdodCB0aGF0IEkgcm91bmQgYSBjb3JuZXIgYW5kIG11Y2ggdG8gbXkgYW1hemVt
ZW50IHRoZXJlIGlzIGEgY3JhZnQgc2l0dGluZyB0aGVyZSBsb29raW5nIHZlcnkgbXVjaCBsaWtl
IGEgUGlldC4gIEkgcHVsbCB1cCB0byBpdCBhbmQgYW5kIEknbGwgYmUgZGFtbmVkIGlmIGl0J3Mg
bm90IGEgR04tMSEgIEkgZ2V0IG91dCBhbmQgdGFrZSBhIGxvb2sgYW5kIEkgc2VlIGEgImZvciBz
YWxlIiBzaWduIG9uIGl0LiAgVGhlIGdlbnRsZW1hbiB3aG8gb3ducyBpdCBjb21lcyBvdXQgb2Yg
aGlzIGhhbmdhciBhbmQgd2UgY2hhdC4gIEhlIHBpY2tlZCB1cCB0aGUgcHJvamVjdCBsYXN0IHll
YXIgYW5kIGludGVuZGVkIHRvIGZpbmlzaCBpdCBidXQgaGFzIG5vdyBjaGFuZ2VkIGhpcyBtaW5k
LiAgSGUgbmV2ZXIgZGlkIG11Y2ggdG8gaXQgYW5kIGl0J3Mgc3RpbGwgaW4gdGhlIHNhbWUgc3Rh
dGUgaXMgd2FzIHdoZW4gaGUgYm91Z2h0IGl0Lg0KDQogICANCg0KICBJIGxvb2sgb3ZlciB0aGUg
d29ya21hbnNoaXAgYW5kIEkgYW0gaW1wcmVzc2VkLiAgVmVyeSBuaWNlIHdvcmsuICBTb21lIGFy
ZWFzIGFyZSBraW5kYSBpZmZ5LCBidXQgb3ZlcmFsbCB5b3UgY291bGQgdGVsbCBhIGdvb2QgY3Jh
ZnRzbWFuIGhhZCBwdXQgaGlzIHRpbWUgaW50byBpdC4gIA0KDQogICANCg0KICBTbyBub3cgSSdt
IHRoaW5raW5nICJJIGNvdWxkIHN1cmUgdXNlIHRoZW0gd2luZ3MhIiAgSGF2aW5nIHRob3NlIHdp
bmdzIHdvdWxkIGN1dCBteSBidWlsZGluZyB0aW1lIGRvd24gYWJvdXQgNi05IG1vbnRocy4gIFRo
ZSB3aW5ncyBhcmUgYWJvdXQgOTAlIGNvbXBsZXRlLiAgSnVzdCBuZWVkIGxlYWRpbmcgYW5kIHRy
YWlsaW5nIGVkZ2UgYWx1bWludW0gYW5kIGFpbGVyb25zLiBUaGV5IGhhdmUgdGhlIGRyYWctYW50
aSBkcmFnIHdpcmVzIGluIHBsYWNlIGFuZCBpdCdzIHRyYW1tZWxlZCBhbmQgcmVhZHkgZm9yIGZp
bmFsIGFzc2VtYmx5LiANCg0KICAgDQoNCiAgVGhlIGZ1c2UgY29udGFpbmVkIGEgSi0zIGNvd2ws
IEotMyBlbmdpbmUgbW91bnQgZm9yIEEtNjUsIEotMyBGdWVsIHRhbmssIEotMyBsYW5kaW5nIGdl
YXIgd2l0aCBjbGV2ZWxhbmQgYnJha2VzLCBNYXVsZSB0YWlsd2hlZWwsIGNvbXBsZXRlIGNvbnRy
b2wgc3RpY2sgYXNzZW1ibHkuICANCg0KICAgDQoNCiAgSSdtIGludGVyZXN0ZWQgYnV0IEknbSBn
dWVzc2luZyB0aGUgZ3V5IGlzIHByb2JhYmx5IHdhbnRpbmcgYWJvdXQgJDQsMDAwIGZvciBpdCBh
bGwuICBJIGFzayBoaW0gYW55d2F5Li4uLi4gICBoZSBuYW1lcyBhIHByaWNlIEkgYWJzb2x1dGxl
eSBjYW5ub3QgcmVmdXNlLiAgDQoNCiAgIA0KDQogIFNvLi4uLiBvbiBXZWRuZXNkYXkgSSdtIGdv
aW5nIHRvIHBpY2sgaXQgdXAuIEhlIGxpdmVzIGFib3V0IDE1IG1pbnV0ZXMgYXdheSBmcm9tIG1l
IHNvIGl0IG91Z2h0IHRvIGJlIHNpbXBsZSB0byBtb3ZlIG92ZXIuIEknbSBnb2luZyB0byB1c2Ug
dGhlIHdpbmdzIGFuZCBKLTMgRnVlbCB0YW5rIGFuZCBtYXliZSBzb21lIG90aGVyIG1pc2MgaXRl
bXMuLiBJJ2xsIHByb2JhYmx5IHNlbGwgdGhlIGZ1c2UvdGFpbCBmZWF0aGVycyBhbmQgcmVtYWlu
aW5nIHBhcnRzLiANCg0KICAgDQoNCiAgVGhpcyBoYXMgYWNjZWxlcmF0ZWQgbXkgcHJvamVjdCBi
eSBhbG1vc3QgYSB5ZWFyLiAgIFRoZSBvbmx5IGRyYXcgYmFjayBhbmQgaXNzdWUgSSdtIGhhdmlu
ZyBhIHByb2JsZW0gd2l0aCBpcyBJIHdpbGwgbm90IGhhdmUgYnVpbHQgbXkgZW50aXJlIHBsYW5l
Li4uLiAgYW0gSSAic2VsbGluZyBvdXQiIGJ5IGRvaW5nIHRoaXM/ICBJIGZlZWwgZ3VpbHR5IHRo
YXQgSSdsbCBiZSB1c2luZyBzb21lb25lIGVsc2VzIHRpbWUvbGFib3IgdG8gZ2V0IG15IG1hY2hp
bmcgaW4gdGhlIGFpci4uLi5zbyBJJ20gdGhpbmtpbmcgdGhhdCBJJ2xsIHVzZSB0aGVzZSBuZXcg
d2luZ3MgZm9yIG5vdyBhbmQgdGhlbiB3aGVuIEkgd2FudCBhIGxpdHRsZSBwcm9qZWN0IEknbGwg
bWFrZSBteSB3aW5ncyBhbmQgdGhlbiBzd2l0Y2ggb3Zlci4uLi4gYnV0IGluIHRoZSBtZWFudGlt
ZSBJJ2xsIGhhdmUgYSBmbHlpbmcgbWFjaGluZSBtdWNoIHNvb25lci4NCg0KICAgDQoNCiAgZ2lt
bWUgc29tZSBmZWVkYmFjay4NCg0KICAgDQoNCiAgREoNCg0KICB3d3cuaW1hZ2Vkdi5jb20vYWly
Y2FtcGVyDQoNCiAgIA0KDQogICANCg0KICBfDQoNCiAgIA0KDQogICANCg0KICBUaGlzIGVtYWls
IGhhcyBiZWVuIHNjYW5uZWQgZm9yIGtub3duIHZpcnVzZXMgYW5kIG1hZGUgc2FmZSBmb3Igdmll
d2luZyBieSBIYWxmIFByaWNlIEhvc3RpbmcsIGEgbGVhZGluZyBlbWFpbCBhbmQgd2ViIGhvc3Rp
bmcgcHJvdmlkZXIuIEZvciBtb3JlIGluZm9ybWF0aW9uIG9uIGFuIGFudGktdmlydXMgZW1haWwg
c29sdXRpb24sIHZpc2l0IC4gDQo
<002201c3ffb3$cc939a00$0564a8c0@rdci.az.home.com>
Yes I think you sold out. pack everything up and send it to me, I will
clear your conscience for free! OK you can cover the shipping if it
makes you feel better!! Way to score DJ, hope to meet at a fly-in
sometime soon!! PS, just got a Subaru EA-81 with reductions drive 2:1,
complete firewall fwd pkg, with a spare engine!! Have to uncrate the
goods!!
> I did the same thing back in April of 2002. On that one I pulled the
> control stick assembly, some turnbuckles, and various other hardware
> and then sold the rest for a little more than I paid for it.. I
> hangars. The weather was beautiful and a drive on the ramp checking
> out the planes seemed like a great idea. As I near the hangars I am
> thinking to myself... "ya know... you never see a Piet in a hangar
> Piet. I pull up to it and and I'll be damned if it's not a GN-1! I
> get out and take a look and I see a "for sale" sign on it. The
> gentleman who owns it comes out of his hangar and we chat. He picked
> up the project last year and intended to finish it but has now changed
> his mind. He never did much to it and it's still in the same state is
> areas are kinda iffy, but overall you could tell a good craftsman had
> put his time into it.
> would cut my building time down about 6-9 months. The wings are about
> 90% complete. Just need leading and trailing edge aluminum and
> ailerons. They have the drag-anti drag wires in place and it's
> tank, J-3 landing gear with cleveland brakes, Maule tailwheel,
> $4,000 for it all. I ask him anyway..... he names a price I
> away from me so it ought to be simple to move over. I'm going to use
> the wings and J-3 Fuel tank and maybe some other misc items.. I'll
> probably sell the fuse/tail feathers and remaining parts.
> and issue I'm having a problem with is I will not have built my entire
> plane.... am I "selling out" by doing this? I feel guilty that I'll
> be using someone elses time/labor to get my maching in the air....so
> I'm thinking that I'll use these new wings for now and then when I
> want a little project I'll make my wings and then switch over.... but
> DJ
> _
The rule is not 51%, The FARs state that more than half must be amateur built and
there can be any number of amateurs taking part.
I know, I know! Everyone uses the 51% number but it isn't in the FARs.
Cy Galley
Sent: Monday, March 01, 2004 5:28 PM
Subject: RE: Pietenpol-List: bought a GN-1 !
Hey DJ,
Having built all the structure (which is the most fun part of building a plane
- that and fabric covering, in my opinion) in my Piet, I can tell you that doing
all the systems work and making everything fit is still plenty enough work
for you to be able to say "I built this airplane". At least, as long as the
FAA or DAR concur that you still did 51% of the work. Go for it.
Jack Phillips
Finally getting weather warm enough to spray some Poly Spray. It's been a long
winter.
From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of DJ Vegh
Sent: Monday, March 01, 2004 12:37 PM
assembly, some turnbuckles, and various other hardware and then sold the rest
for a little more than I paid for it.. I basically got parts for "free" that
way.
was beautiful and a drive on the ramp checking out the planes seemed like a great
there is a craft sitting there looking very much like a Piet. I pull up to it
see a "for sale" sign on it. The gentleman who owns it comes out of his hangar
are kinda iffy, but overall you could tell a good craftsman had put his time into
it.
cut my building time down about 6-9 months. The wings are about 90% complete.
landing gear with cleveland brakes, Maule tailwheel, complete control stick assembly.
it all. I ask him anyway..... he names a price I absolutley cannot refuse.
I "selling out" by doing this? I feel guilty that I'll be using someone elses
and then switch over.... but in the meantime I'll have a flying machine much sooner.
DJ
_
Subject: | Re: bobka(at)compuserve.com |
Max,
You can put me down for two.
Thanks for doing all the leg work. You are outstanding!
Chris Bobka
Minneapolis
Sent: Saturday, February 28, 2004 7:48 AM
Subject: Pietenpol-List: bobka(at)compuserve.com
In a message dated 2/27/2004 7:49:48 PM Central Standard Time, bobka(at)compuserve.com
writes:
Max,
Chris Bobka
Chris,
AS&S would not even talk to me about trying to special order the 6" gauge that
and ask about designing an inverted fuel gauge of the same type. I do not intend
The people at Rochester have not been much more help. If the computer says it
it -- and move on to the next call and the next coffee break. There is no brain
and will market the item myself. If Rochester doesn't come through, I will take
Max Davis
Chris:
I visited with them again today and I should have the prototype by tomorrow
afternoon. I plan on mounting it in a tank and sending out some pictures. It
promises to be a really neat application, I was not going to go to Brodhead
this year, but I may have to now. I have committed to buying ten at a time.
Max
Subject: | Re: c/s fuel gauge |
Andy,
I don't need them immediately. It is ok to keep the order in your back pocket
to use if you need to get to the magic "ten".
Chris
Sent: Monday, March 01, 2004 8:16 PM
Subject: Pietenpol-List: c/s fuel gauge
Chris:
I visited with them again today and I should have the prototype by tomorrow afternoon.
promises to be a really neat application, I was not going to go to Brodhead this
Max
DJ,
Don't feel guilty. Building your own airplane is great, but flying your own airplane
is heaven! Get the Piet finished and in the air, then you can start the
next project.
Darrel
Sent: Monday, March 01, 2004 9:36 AM
way.
it.
DJ
_
<007a01c3fff5$0e552f80$f004fea9@new>
Who did start that one anyway?
and there can be any number of amateurs taking part.
Cy Galley
Dear List,
Can anyone who has used the spoked wheel option tell me what kind of bushings
they used? I've been looking at the photos of Michael Cuy's aircraft and others
that I took at Brodhead and it doesn't appear that the hubs are fat enough
to have used regular sealed bearings over the 1 1/2" axle.
I've found a machinist who will make those six inch hubs but he wants $275.00/wheel.
That seems pretty high to me. Is it really, absolutely necessary
to have those wide hubs? I've found some nice wheels that seem really strong
and it seems like a shame to take them apart. They even have holes where I can
just bolt on a disk for the brake. But I'll do what I have to do.
Thanks....Dave in Missouri
Dave,
I used bronze bushings, got them 1 1/4 ID and 1 1/2 OD, just had to cut to
length.
If you are talking about turned aluminum hubs, I assume 7075, $275.00 sounds
about right, based on how long it took me to make mine.
Another option is welded 4130 tube with 3 flanges (if you want breaks, 2 if
you don't) welded on and 2 of them drilled for the spokes. Should be a whole
lot cheaper than aluminum.
Skip
bushings they used?
Message
Dave,
I used
length.
If you
are talking about turned aluminum hubs, I assume 7075, $275.00 sounds about
if you don't)welded on and 2 of them drilled for the spokes.Should
be a whole lot cheaper than aluminum.
Skip
option tell me what kind of bushings they used?
Thanks....Dave in
Missouri
Sent: Tuesday, March 02, 2004 8:07 AM
Subject: Pietenpol-List: Bushings
Dave,
I have heard too many stories about stock motorcycle wheels and hubs collapsing
when subjected to a heavy side load. Remember, on a motorcycle, there is no
side loading except with a side car.
To be on the safe side, and from experience, I wouldn't take the chance that
each landing will be without some side loading. Some of my landings have been
pretty bad. In fact, not many have been without landing slightly crosswise.
In addition, some landings have been in pretty rough territory and the wheels
have taken quite a beating. Each time I think that if I had not made the 6"
hubs and a wheel collapsed, the plane could have been toast.
I think it's too much to risk on the assumption that all of your landings will
be perfect and on perfect terrain..
Dear List,
others that I took at Brodhead and it doesn't appear that the hubs are fat enough
can just bolt on a disk for the brake. But I'll do what I have to do.
Subject: | Piet model on ebay |
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3178224997&category=30
Subject: | Re: Piet model on ebay |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Hello Dave-- I got my oilite bronze, flanged bushings from Bearing
Distributors. Check this site for a retailer near you.
http://www.bdi-usa.com/ I had to machine my axle a tad for the bushings
to slip over--you may not have to. The trick is not to have your bushing
turn inside the hub so I did as Frank P. did and cleaned my bushings and
hub insides with MEK. I filed three grooves perpendicular to the direction
they slide on, applied T-88 around the 1" wide part that slips in your hubs
and let it cure. I used regular auto grease to lube them. Nuther thing a
place like Bearing Distributors can sell you are washers for your axle. I
didn't want those bushings rubbing on the hex shaped axle nut so I bought
the appropriate size steel washers.
On the axel itself I welded a washer on the inside of where I wanted the
hub to slide on and stop. I then ground it down to a smaller size (not
necessary but I needed to to clear my go kart brake calipers) This serves
as a stop on the inboard side for your hubs. Hope this helps,
Mike C
<002c01c3ffd6$abe2af30$2cc5fea9@home>
well I took delivery of the new plane today. I even took some time to
temporarily mount up one wing to my fuse and snap some pics.
here's pics of the wings
http://imagedv.com/aircamper/log/image-pages/03-02-04.htm
and here's pics of the fuse, which by the way is for sale :-)
http://imagedv.com/aircamper/log/image-pages/03-02-04b.htm
DJ Vegh
N74DV
Mesa, AZ
Hi Dave,
I agree with John - all it takes is one really bad landing and if a wheel
folds you might tear up the whole airplane (much less hurting yourself). I
had a machine shop turn my 6" wide hubs for me - cost me $400 for the pair
with me supplying the aluminum. I just got them back from Buchanan's all
laced up with brand new stainless steel spokes - they sort of make me forget
how much they cost me. I wish now I had polished the aluminum hubs before I
sent them off.
Mine are designed for a 1-1/2" axle, and I used some Timken roller bearings
salvaged from a set of Goodyear aircraft wheels.
BTW, the source I used for my aluminum was a company called Yarde Metals.
They have a "Drop Zone" where they sell remnants and cutoffs from jobs. I
got a billet of 6061 T651 aluminum 10" in diameter and 17" long for about
$150. Their website is: http://www.yarde.com/cgi-bin/dropzone.pl
Jack Phillips
Dave,
collapsing when subjected to a heavy side load. Remember, on a motorcycle,
there is no side loading except with a side car.
that each landing will be without some side loading. Some of my landings
have been pretty bad. In fact, not many have been without landing slightly
crosswise. In addition, some landings have been in pretty rough territory
and the wheels have taken quite a beating. Each time I think that if I had
not made the 6" hubs and a wheel collapsed, the plane could have been toast.
will be perfect and on perfect terrain..
Dear List,
bushings they used? I've been looking at the photos of Michael Cuy's
aircraft and others that I took at Brodhead and it doesn't appear that the
hubs are fat enough to have used regular sealed bearings over the 1 1/2"
axle.
$275.00/wheel. That seems pretty high to me. Is it really, absolutely
necessary to have those wide hubs? I've found some nice wheels that seem
really strong and it seems like a shame to take them apart. They even have
holes where I can just bolt on a disk for the brake. But I'll do what I
have to do.
Sent: Tuesday, March 02, 2004 6:15 PM
Subject: RE: Pietenpol-List: Bushings
Them's one beautiful wheels!
Hi Dave,
I agree with John - all it takes is one really bad landing and if a wheel folds
you might tear up the whole airplane (much less hurting yourself). I had a
machine shop turn my 6" wide hubs for me - cost me $400 for the pair with me
supplying the aluminum. I just got them back from Buchanan's all laced up with
brand new stainless steel spokes - they sort of make me forget how much they
cost me. I wish now I had polished the aluminum hubs before I sent them off.
Mine are designed for a 1-1/2" axle, and I used some Timken roller bearings salvaged
BTW, the source I used for my aluminum was a company called Yarde Metals. They have a "Drop Zone" where they sell remnants and cutoffs from jobs. I got a billet of 6061 T651 aluminum 10" in diameter and 17" long for about $150. Their website is: http://www.yarde.com/cgi-bin/dropzone.pl
Jack Phillips
Dave,
Dear List,
<003b01c400bc$bb00a5d0$d2a86d44@Desktop>
force.
Subject: | a question for the engineer types - 7075 aluminum thread |
pull-out force.
Done lots of reading online about thread pull-out force in aluminum but the
equations make my brain hurt.
Basically what I'd like to know it if I have a Piper Cub lift strut fork
(1/2" - 13 thread I think) threaded into a 7075 aluminum block (approx
70kpsi shear) about 1", what would it take to fail the threads in the
aluminum and pull out the fork?
My initial guestimate would say it would take at least 12,000lb..... Even
5,000lb would do as some rough math shows each lift strut sees about 1400lb
in a 4G load. Even with a safety factor of 3 that's only 4200lb..... but
guestimates and probably's don't do much for you when your wing has folded
and you become a lawn dart.
Who's got some engineering skills that could give me a more solid number or
even an opinion on whether I should use 7075 aluminum or 1018 steel block to
thread this fork into. (I can't seem to find 4130 in .75 and 1" square bar)
Maybe 7075 is a bad choice because of fatigue?
Opinions!?
DJ Vegh
N74DV
Mesa, AZ
thread pull-out force.
Subject: | a question for the engineer types - 7075 aluminum |
Hi DJ,
You need a little more information - specifically, how many threads will you
have engaged? Threaded holes typically fail by shearing across the thread
roots, so you will need to calculate the area of the thread roots,
multiplied by the number of threads engaged, multiplied by a healthy safety
factor. 7075 is not too bad for fatigue (for aluminum), but with cut
threads you will have some significant stress risers. Personally, I would
try to have a factor of safety of at least 5. If the Lift struts let go,
you will have a very bad day.
Given a choice between aluminum and steel for such a part, I would go with
steel due to its increased fatigue resistance, unless you have a large
safety margin. What about corrosion? What will this block be attached to?
Steel or aluminum lift struts? If steel struts, then definitely make this
block of steel to avoid dis-similar metals setting up galvanic corrosion.
If aluminum then I would lean towards an aluminum block, preferably with a
barrier of oil on the steel threads of the strut fork to avoid corrosion.
Jack Phillips
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of DJ Vegh
Subject: Pietenpol-List: a question for the engineer types - 7075 aluminum
Opinions!?
DJ Vegh
N74DV
Mesa, AZ
Subject: | Wire Spoke Wheels |
Jack,
Those wheels look great!!!!!!!! Now for a couple of questions........I noticed
that the flange on one side appears to be a different size than the other. Is
there a reason for this or do I need to re-calibrate my eyes? What are you
going to use for brakes? Do you have any drawings of the hubs? What shop turned
them for you?
Jim Dallas
Cliff
I am in taxi testing now and the axle seems fine so far. Lots of others have
used it too.
Dick
Quoting Clif Dawson :
> Pietenpol.
> Clif
> Dave,
> the axle. 12 GA. is .1045" thick, I think most guys go up to .120" rather
> than down to .095".
> Skip
From: | "Robert Haines" <robertsjunk(at)hotmail.com> |
Subject: | Re: a question for the engineer types - 7075 aluminum |
thread
DJ,
Jack is correct in saying that it's based on the thread failure. However,
and this may not answer you question directly, the height of a basic nut has
been determined so that failure based on the area of threads is greater than
the failure based on the cross-section of the bolt. This is not a absoulte
engineering solution, but it helps one visualize the strength of the threads
compaired to the strenght of the body of the bolt.
To determine failure, you have to figure the problem three ways: 1) will
the threads shear off of the threaded rod, 2) will the threads shear off of
the threaded hole, or 3) will the rod fail in tension at it's smallest
diameter (which is likely the minor diameter of the rod's threads). Try
looking at pages 1490 from the Machinery's Handbook (I have edition 26)
which has all the formulas for this and specifically has formulas for when
the material of the threaded hole is weaker than the threaded rod.
Robert Haines
Du Quoin, Illinois
thread
pull-out force.
Opinions!?
DJ Vegh
N74DV
Mesa, AZ
Subject: | Great photos of Jan '04 CA Corvair College |
Forgive me if this site has already been posted but it is just fantastic:
http://www.flycorvair.com/cc5.html
Mike C.
Hi Jim,
Thanks for the compliment. Yes the flanges are different on the inside and
outside, in order to allow installation of Cleveland 8" disc brakes. I have
drawings of the hubs on AutoCAD if you are interested. The hubs were turned
by Leland Machine Shop in Wilmington, NC. Billy Johnson, the owner of the
shop, has built several airplanes and I think gave me a special price
because of that.
The wheels without tires or brakes weigh 16.5 lbs each. Heavier than I
would have thought, but not a lot heavier than the Goodyears I got the
bearings from.
Jack Phillips
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of James Dallas
Subject: Pietenpol-List: Wire Spoke Wheels
Jack,
noticed that the flange on one side appears to be a different size than the
other. Is there a reason for this or do I need to re-calibrate my eyes?
What are you going to use for brakes? Do you have any drawings of the hubs?
What shop turned them for you?
Jim Dallas
Subject: | Re: Wire Spoke Wheels |
Jack,
Thanks for the answers, and yes I would love to get a copy of the drawing.
Jim Dallas
----- Original Message -----
To: pietenpol-list(at)matronics.com
Sent: Wednesday, March 03, 2004 5:52 PM
Subject: RE: Pietenpol-List: Wire Spoke Wheels
Hi Jim,
Thanks for the compliment. Yes the flanges are different on the inside and outside,
in order to allow installation of Cleveland 8" disc brakes. I have drawings
of the hubs on AutoCAD if you are interested. The hubs were turned by
Leland Machine Shop in Wilmington, NC. Billy Johnson, the owner of the shop,
has built several airplanes and I think gave me a special price because of that.
The wheels without tires or brakes weigh 16.5 lbs each. Heavier than I would
have thought, but not a lot heavier than the Goodyears I got the bearings from.
Jack Phillips
From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of James Dallas
Sent: Wednesday, March 03, 2004 7:51 AM
To: pietenpol-list
Jack,
Is there a reason for this or do I need to re-calibrate my eyes? What are you
them for you?
Jim Dallas
Jack,
Is there a site you could post your drawings? I'll be honest, I want to steal
them just like the rest of the guys.
Hank (steal from the best, the rest ain't worth the trouble) J ;-)
Sent: Wednesday, March 03, 2004 6:52 PM
Hi Jim,
Jack Phillips
To: pietenpol-list
Jack,
them for you?
Jim Dallas
DNA: not not archive
Subject: | [PLEASE READ] Virus Laden Spam Purports To Be From Matronics... |
Dear Listers,
First let me say that I normally don't condone the sharing of warnings
about Internet viruses on the Matronics Email Lists. I don't want to
start a storm of discussion regarding computer viruses on the Lists, so
please just note the information below and refrain from commenting to
the List. The circumstances I describe below are disturbing enough
that I felt an explanation is necessary. That being said...
There is a new email-bourne virus running rampant on the Internet that
is cleverly disguising itself as legitimate email warning of such
things as:
"your email account is disabled because of unauthorized access"
"Some of our clients complained about the spam (negative e-mail
content) outgoing from your e-mail account"
"Probably, you have been infected by a proxy-relay trojan server. In
order to keep your computer safe, follow the instructions."
"Our main mailing server will be temporary unavailable for next two
days, to continue receiving mail in these days you have to
configure our free auto-forwarding service."
All of these messages include an attachment that you are instructed to
click upon to "Get more information", "clean the virus from your
system", or "check your system for infections".
These enclosures all contain a virus that will infect your system and
propagate even more copies of the original message.
The disturbing part of these messages is that they appear to be coming
from very legitimate addresses and have very legitimate, convincing
dialog. For example, I have received a number of them today that
appear to be from "support(at)matronics.com", "management(at)matronics.com",
"administration(at)matronics.com", and "staff(at)matronics.com".
The text of the messages seems believable enough, and given the forged
source address, seem even more legitimate.
Please be assured that no one at Matronics.com will be sending you
these kinds of messages. If you receive one, it is a spam/virus that
has forged headers and was sent to you from someone other than
Matronics. Delete the message and the attachment promptly. Invest in
a copy of Norton Antivirus and keep the definitions up dated on a daily
basis.
Again, I want to stress that I *DO NOT* want a big discussion of
viruses on the Matronics Email Lists. Please do not reply to this
email with any comments. You may write to me directly at
dralle(at)matronics.com if you wish, but do not include the List.
Since many of these appear to come from matronics.com, I wanted to
assure everyone that Matronics wasn't the real source of these messages.
Let's be careful out there and keep those virus definitions up to date!
Today alone, the Matronics spam filter and virus blocking appliance
has filtered out 11,550 spam messages and 375 viruses! That's just in
an 18 hour period!
Best regards,
<1078324505.4045ed19ae45f(at)rain.goldengate.net>
From: | PAT HOEVELMANN <hoevelmann(at)sbcglobal.net> |
Subject: | 5.00 cleveland wheels |
I have a set of 5.00 cleveland wheels and brakes and was wondering if I could use
them on a split axel landing gear setup. I think they may be to small but
I would hate to waste them.
Thanks, J.J. Hoevelmann
Subject: | Re: 5.00 cleveland wheels |
J.J.
If you want an opinion I'll give you a little one for what it might be worth.
I owned and flew a C-150D for many years and about 700 hrs, enough to get
acquainted with the bird. Landed in rice fields, Interstate -49, concrete
runways, asphalt runways and an assortment of sods you wouldn't believe. Even had
a
bull chase me around the pasture after a forced, oil line disconnected under
instrument panel. He must have thought I was something from the other world
looking for his heifers. Had a few other experiences that I'd rather not expose
for those FAA people to know about. Point is:
It had 5:00 wheels and brakes and it was a much heavier machine than our
Piets. Just an opinion and you'll probably gain 3 or 4 mph over the 6:00
Corky in La watching everyone else fly
From: | "Oscar Zuniga" <taildrags(at)hotmail.com> |
I've been following the discussion on the fuel gauges and agree that the
"Stearman-type" gauge in the conventional location does have concerns. For
those not familiar with how this typically ends up looking, you can see one
at http://www.flysquirrel.net/piets/Pb030014.jpg and readily note that it is
in the area used by the passenger boarding from the port side (conventional
setup).
William Wynne, whose Corvair-powered Piet crashed a few years ago, was
burned due to this very situation. The fuel fittings in the sump/outlet
area broke off in the crash and spilled fuel into the cockpit area, where it
ignited. William is now advocating a setup with either a breakaway
flow-check fitting, or a different sump and fuel outlet connection since the
tank itself remained intact in the crash of his Piet. Any improvement on
the conventional outlet and gauge setup is a real plus.
Oscar Zuniga
San Antonio, TX
mailto: taildrags(at)hotmail.com
website at http://www.flysquirrel.net
Get a FREE online computer virus scan from McAfee when you click here.
From: | Kip and Beth Gardner <kipandbeth(at)earthlink.net> |
>the "Stearman-type" gauge in the conventional location does have
>concerns. For those not familiar with how this typically ends up
>looking, you can see one at
>it is in the area used by the passenger boarding from the port side
>(conventional setup).
>was burned due to this very situation. The fuel fittings in the
>sump/outlet area broke off in the crash and spilled fuel into the
>cockpit area, where it ignited. William is now advocating a setup
>with either a breakaway flow-check fitting, or a different sump and
>fuel outlet connection since the tank itself remained intact in the
>crash of his Piet. Any improvement on the conventional outlet and
>Oscar Zuniga
>San Antonio, TX
Oscar,
You are right about William's concerns, but I'll add some detail. I
looked over & discussed his fuel tank setup with him about 8 months
before the crash. Two items: first, William's tank was integral with
his center section. In other words, he basically glassed-in the
center section to creat the tank, which, as I recall, was about 20
gal. Much bigger than a drop-in tank. This idea has a lot of appeal
to me because the Corvair burns more than an A-65 (about 4-5
gal./hr.) and like Chuck Gantzer, I have an iron butt & like to stay
in the air instead of landing every couple of hrs. for fuel.
I think this setup is quite interesting in light of the fact that the
tank did remain intact in the crash.
Secondly, because of this tank setup, William had two sumps, one at
the front & one at the back of the tank, both on the right side of
the center section. I don't recall how or where the lines joined,
but one of them ran along the underside of the center section & then
both of them went down one of the cabane struts. They probably tied
together at a fitting that also fed the primer; I don't remember. He
is recommending flow-check fittings located where these lines exit
the tank bottom.
The other thing he is recommending on Corvair-powered planes is some
sort of total 'kill-switch' to the electrical system. The fire
started because of a crash-induced short. He thinks that the
distributor-coil type ingnition system was responsible for this.
Kip Gardner
North Canton, OH
Subject: | Re: 5.00X5 Cleveland wheels |
I put 5.00 X 5 wheels and brakes on my Piet with split axle gear, and, though
I haven't flown it, they look to be in proportion to the airplane. If a Piet
is too big for 5.00 X 5s, then I can't imagine what aircraft would be small
enough. I suspect they may bog down in soft ground a bit easier than the 6.00 X
6s but probably not by much.
Matt Paxton
From: | "Christian Bobka" <bobka(at)compuserve.com> |
See if there are bigger tires that fit on the 5 x 5 wheels. It is common to
8 x 6 tires on 6x6 wheels.
Call Desser Tires or look at their website.
Chris Bobka
Subject: Pietenpol-List: Re: 5.00X5 Cleveland wheels
though
Piet
small
6.00 X
> Matt Paxton
Since there's not much going on, on the list, I thought I'd send along the
text that I wrote for Max Davis, on how I tie my bunji strut loops. It's a long
post, so be warned !!
I finally got done with re-tieing, and installing my bunji struts back on
the plane. Installing the bunji's on the struts, is one of the most
difficult 2 man chores that I do alone, as regular maintenance. Last year, I pulled
a
tendon in my right elbow, this time all I did was pinch my finger (it only
bled a little bit), and now only have achy forearms from pulling and fixing the
loops over the struts. This is the last time I'm going to re-tie the
bunji's...I'm building spring struts !!!
It's difficult to put it in text, how I tie the loops, so I've taken a
lot of digital pictures, and will send them direct to anyone that contacts me
direct.
The instructions I'm giving here, is for the PLANS DIMENSIONS of the
bunji strut suspension. It took me 2 or 3 tries my first time, before I was
satisfied with how the loop turned out.
Start out using two wraps of medical tape where you plan on cutting the
bunji chord with a sharp knife, or the bunji chord will unravel before your
eyes. Cut up a piece of scrap to see how this stuff is made. It obviously is
stretched quite a bit, before the cloth weave is applied to the many small
strands of rubber bands. The 5/8" bunji chord from AS&S is part #06-12600. If
it's all in one length, you can use the medical tape centered where you wish to
cut, then just cut right down through the medical tape, leaving half of the
medical tape on each piece. I use a waxed chord from a leather company called
'The Leather Factory'. The wax chord from them has a part # 1220-01. Roll out
16 feet of the wax chord, and double it up. If you pull it through your
fingers, it will kind of stick together as a single chord. Use the doubled up
waxed chord, as a single chord. An airport buddy of mine showed me how to tie
the
loops, but I've learned most of this stuff by trial and error, and keeping
records of each process, and a sample of how the knots are tied. Measure back
from the tip of the cut bunji chord to 7 3/4", and make a mark with a black
pen. This is where you loop the tip of the bunji back to, to make a loop. Use
a
zip tie, cinched down tight, to hold the loop, while you tie the loop with
the waxed chord.
I started out using cut bunji length of 34". They loosened up, so I took
them apart and when I cut off the waxed chord of the tied loops, they had
stretched to 36" cut length !! I shortened them that time to 33", but they got
loose again. On 7/19/03 I re-tied them all to 31". They have loosened up
again, so now I've cut them all to 29" cut length. Tied length on all four is
now is 21 3/8" to 21 1/2". That's from the tip to tip of the end of the loops.
Here's the hard part to describe...tying the knots. The tied up portion
that the waxed chord covers, is 1" to 1 1/8". Measure up from the cut end of
the bunji 1" to 1/18" and make another mark. This is where you start to tie
your knots. Start out by taking one end of the waxed chord, up under the zip
tie, to the tip of the loop of the bunji and tape it there. Bring the length
of waxed chord down past the cut end of the bunji about 3" past where you made
your first mark, and loop it back up almost to the zip tie. Make the first
knot in the waxed chord closest to the bunji loop. Make a loose loop around
your first two fingers, and twist it counterclockwise one turn, and loop it back
over top of the loop of the bunji. Take up the slack with the long end of the
waxed chord, and line up the first knot closest to the bunji loop. You can't
make this one very tight, because there is nothing to tighten it up to. Work
each knot away from the loop of the bunji. The second knot, third, and so
on, will be able to tighten it up, with a leather protection for your hand, or
the waxed chord will cut the skin...gotta get it really tight !! For each
knot, you make a loop around the first two fingers of your left hand, and twist
it one turn counterclockwise, and loop it back over the loop of the bunji.
You have to line up the knots of the waxed chord, along the seam where the bunji
chord loops back to the cut end of the bunji chord. Your initial waxed chord
will be under the knots you are tying. Maybe 20 or 30 knots later (I haven't
counted them), you will have reached the cut end of the bunji, making the
tied portion about 1" to 1 1/8" long. Now you take what's left of the waxed
chord (about 3"), and thread it through the loop that you taped down past the cut
end of the bunji. With the first end of the waxed chord that you inserted up
under the zip tie, pull the other end up under the set of tied knots, bring
the ends together with a couple of square knots. This keeps the assembly of
knots tied together. You may be able to get away with a bunji chord cut length
of 30", because new chord isn't stretched out yet.
As far as getting it streached around the struts...do it when there are
no women or children around !! Tape the jaws of the vise to secure the strut,
and be careful not to over tighten the vise to the point where it crimps the
metal, but plenty tight enough to hold it secure. This is a two man job...one
to keep stretch on the chord, the other to keep working the slack around the
loops with a huge 24" pair of channel locks - with tape on the jaws so it
doesn't damage the bunji cloth. I used a small rope through the loop, and back
up
around the other end of the bunji strut, to keep stretching the bunji, and
keep it from stretching back. Good Luck, and HAVE AT IT !! If you find an
easy way to do it...Please let me know. I hope you can understand all this.
Fire away with any questions !!
Chuck Gantzer
NX770CG
Subject: | Fuel Gauge, Houston... we have a problem |
Group:
I hope you all are experiencing the same weather that Jim Markle and myself
are in the Dallas/Ft. Worth area of Texas, and are outside flying.
Rochester gauges of Dallas made a sample of the inverted center section fuel
gauge for me and it looks, and will work, great! That was the good news. The
bad news is that they said it would not pass tooling, and it would not pass
quality...I've said more than my share of curse words this week. At this
point, they will not make them for me, stating, that they cannot mass produce this
item and get the quality that they demand at the same time. I suggested that
maybe they could sell them to me as a novelty or paper weight, to no avail.
I showed it to Jim Markle and he also said it looks great. I have some
pictures and even a clip I could send you, if you want to be as disgusted as we
are. I truly think that in the event of an accident, this is an item that can
keep an airplane from burning up, a person from getting burned or in the
extreme, save someone's life.
I am now looking at the possibility of producing the gauge, as well as
marketing it, myself, to the homebuilding community.
I am sorry for getting everyone excited about this, I did not understand,
when the computer says it can't be done, the production engineers agree.
Sorry guys, I'll keep you posted.
Max Davis
Arlington, TX.
Subject: | Re: Fuel Gauge, Houston... we have a problem |
Max,
I would love to see some pictures of it.
Jim Dallas
Sent: Saturday, March 06, 2004 8:24 PM
Subject: Pietenpol-List: Fuel Gauge, Houston... we have a problem
Group:
I hope you all are experiencing the same weather that Jim Markle and myself are
bad news is that they said it would not pass tooling, and it would not pass quality...I've
said more than my share of curse words this week. At this point,
I showed it to Jim Markle and he also said it looks great. I have some pictures
and even a clip I could send you, if you want to be as disgusted as we are.
I truly think that in the event of an accident, this is an item that can keep
an airplane from burning up, a person from getting burned or in the extreme,
I am now looking at the possibility of producing the gauge, as well as marketing
I am sorry for getting everyone excited about this, I did not understand, when
Max Davis
Arlington, TX.
Max,
Did they know it was for an airplane? Maybe thats where they got cold feet.
Something for a plane sends up red liability flags.
walt evans
NX140DL
Sent: Saturday, March 06, 2004 9:24 PM
Group:
Max Davis
Arlington, TX.
I guess I'm back to using Bill Rewey's idea--a Cub type float-and-wire on
the gas cap and a mirror that I can hold up to see it.
Dick Hartwig
fuel
news. The
pass
>quality...
Subject: | tail wheel springs/chains |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Subject: | Re: tail wheel springs/chains |
Sent: Sunday, March 07, 2004 4:54 PM
Subject: Pietenpol-List: tail wheel springs/chains
Could some of you send me some pics or links to pics of your tail wheel control
connections?
I'm not totally pleased with the GN-1's method of tail wheel control. It says
to use some .090 steel arms bolted to the rudder and then connected to the tailwheel
via springs and chains. The angle is steep up to the metal arms from
the tail wheel. I tried a "taxi" test today in which my girlfriend pulled the
plane from the engine mount while I steered from the cockpit. Within 5 seconds
I managed to bend down one of the arms. The angle is just too much and any
good amount of pedal force just bends the arm down.
I'd like to see how the rest of you are doing it. I was thinking of ditching
the rudder arm thing and just running separate cables from the tailwheel directly
to the rudder cables inside the fuse... then the pedals directly control the
tailwheel
What about you Mike C. ? how is yours done?
DJ Vegh
N74DV
Mesa, AZ
In a message dated 3/7/04 6:57:38 PM Central Standard Time, djv(at)imagedv.com
writes:
<< Could some of you send me some pics or links to pics of your tail wheel
control connections? >>
DJ,
I don't like the thought of tailwheel nicopress on primary flight control
cables, so the way I did my cables, was to nicopress the cable / thimble
right to the springs, and installed the springs through the holes in the tailwheel
horn, and run the 1/16" cable all the way up to the rudder bar. The springs
are lightweight type, that when you pull the ends, it compresses (as opposed
to stretching) the spring. I don't recall what you call that type of spring.
The cables penetrate the fabric on the bottom of the fuselage, pass through a
hole in a hardwood fairlead block (epoxied in at the station just ahead of the
tailpost) and almost a straight line up to through the rear cockpit. I ran
them through 24" lengths of nylon tubing in the rear cockpit, at about 1"
each side of the torque tube, and secured each of the nylon tubing to the floor,
in 3 places with Adel clamps. The cables / nylon tubing approximately align
with the height of the rudder bar, where they pass through the bulkhead between
the front and rear cockpit.
I attached the cables to the rudder bar at 3 1/2" R.B.L. (right butt
line), and 3 1/2" L.B.L. using fittings that I made up out of a 1" length of
tubing that had an I.D. of the O.D. of the rudder bar. I welded a pair of toungs
to the this 1" tube, then used a hack saw to cut a slit in the 1" tube, between
the toungs. Drill a hole in the toungs for a bolt, and it now acts as a
clamp on the rudder bar, as well as another hole for the cable / nicopress. I
attached everything up at the rudder bar, then did the final nicopress at the
spring in the back...no need for adjustment. It's light, simple, and has so far
worked flawlessly. I've got a leak in one of the master cylinders under the
front seat, and tomorrow I'll take some digital pictures of that area. The
pictures will also show the slick way I built my brake pedals / master
cylinders. There's a lot of stuff going on under that front seat !!
Chuck Gantzer
still working some squawks
Andy,
If you are going to make them elsewhere, consider having them done in BRASS rather
than Aluminum as most would LOVE to shine them up BRIGHT ! Consider that
anybody with a modern Aluminum plane is going to go electronic gauge anyway, you
have a potential to capture the market for the more rustic aircraft with high
wings or biplane wings with a tank or tanks in them.
Also, it may be desireable if the card (the gizmo with the F and E letters on it)
has a more antique looking font on it. If you would like to change it to look
more '20s, let me know and I will see what I can do with people I know. We
would need the flat layout of what you have to start with.
Theoretically, if you changed the design just enough, you could have parts made
for different lengths and a top mount or a bottom mount. I have a gauge similar
to this that I used in my Taylorcraft although it was part of the gas cap.
The bottom line is that most people would want matching gauges. The parts could
also be assembled by the builder to keep the cost and liability down.
Make sure the float is compatible with ALL the fuels we use. Some might be using
regular oxygenated gasahol in whatever they are flying way out in the future.
A soldered brass float is always compatible.
BTW, ask Jim Markle about his sandblasting cabinet that he built from my plans!
Chris
Group:
Max Davis
Arlington, TX.
thanks! a good idea which I will consider.
DJ Vegh
N74DV
Mesa, AZ
Subject: Re: Pietenpol-List: tail wheel springs/chains
djv(at)imagedv.com
> writes:
> DJ,
control
tailwheel
springs
opposed
spring.
through a
the
ran
floor,
align
between
of
toungs
between
nicopress. I
the
so far
the
The
> Chuck Gantzer
I saw Chuck's installation and I like it a lot. I plan to do the same.
Terry B.
The sonex setup is one that you should seriously consider, the small wheel is all
that you need even in grass, and it puts a ton less pressure on control arms
etc. its light weight and the direct connection without springs is clean, and
works way better than any spring system.
http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID=157
connections?
I'm not totally pleased with the GN-1's method of tail wheel control. It says to
via springs and chains. The angle is steep up to the metal arms from the
I'd like to see how the rest of you are doing it. I was thinking of ditching the
tailwheel
DJ Vegh
N74DV
Mesa, AZ
Del-New Richmond, Wi
"farmerdel(at)rocketmail.com"
Subject: | wing construction |
Hey guys, I've got a question. Does it matter if the leading edge is
attached to the wing ribs before the drag/anti-drag wires are attached and
tightened?. I personally don't think it's a factor but the questioned was
raised.
Jeff in Texas getting the bbq out
One-click access to Hotmail from any Web page download MSN Toolbar now!
http://clk.atdmt.com/AVE/go/onm00200413ave/direct/01/
DJ-- I simply spliced another 3/32" diam. cable to the rudder cables behind
the rear seat for the tailwheel steering control. Then I ran those past
two nylon pullies that I bolted in just before the cables exit the fuselage
bottom. Works fine.
Mike C.
Subject: | Re: wing construction |
Wing should be trammeled before the leading edge goes on. This means that
you need to have installed the drag-antidrag wires so to straighten it all
up first.
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Editor, EAA Safety Programs
cgalley(at)qcbc.org or sportpilot(at)eaa.org
Always looking for articles for Sport Pilot
Subject: Pietenpol-List: wing construction
> raised.
> One-click access to Hotmail from any Web page - download MSN Toolbar now!
I would think you'd want the drag-antidrag wires installed and trammeled
first. The wing will need to move a little when trammeling and if the
leading edge is secured to the ribs it may bind up a little, but I have not
built any wings so my advice may be worth nothing.
DJ Vegh
N74DV
Mesa, AZ
> raised.
DJ, you and Cy Galley are both absolutely correct. The wing must be free to move
when trammeling, otherwise, since the leading edge is not in the plane of the
drag/anti-drag wires, any forces put on the wing when tensioning the wires
will be resisted by the ribs and leading edge, forcing out-of-plane twists in
the wing. For the same reason you certainly don't want the plywood skin on the
leading edge before trammeling. It's also not a terribly good idea to glue
the ribs to the spars, at least not before tramelling the wing
Once the wing is tramelled and square, then attaching the leading edge and the
plywood adds a little rigidity to help hold it that way.
Jack Phillips
> From: "DJ Vegh" <djv(at)imagedv.com>
> Date: 2004/03/08 Mon AM 10:33:20 EST
> To:
> Subject: Re: Pietenpol-List: wing construction
> DJ Vegh
> N74DV
> Mesa, AZ
> From: "Jeff Hill" <jeff2dogs(at)hotmail.com>
> To:
> Sent: Monday, March 08, 2004 7:05 AM
> > raised.
I would think if the wing is jigged up true, the leading edge should go
on first. It is my impression that the wires take loads due to
different angles of attack, etc, and are not meant to be a means of
forcing a crooked wing straight. I think. Maybe . . .
> raised.
<00a001c40521$6c8bd6e0$f004fea9@new>
Curious, i did the opposite, but the wing was in a jig and completely
squared up prior to LE and skins.
> up first.
> To:
> Sent: Monday, March 08, 2004 8:05 AM
> > raised.
Hey guys, what are the dates for the 75th Anniversary this year at Brodhead?
I haven't seen them posted in the Pietenpol Association newsletter. Also,
What is on the agenda as of yet?
Jeff in Texas
Frustrated with dial-up? Lightning-fast Internet access for as low as
Jeff,
The Piet flyin at Brodhead is Friday July 23 to Sunday July 25.
The agenda is casual, they will have a couple forums and 4 or 5 meals.
Bring tape measure, notepad, camera and pictures of your project.
Skip
Brodhead?
>Jeff in Texas
Subject: | Aircamper on Ebay |
I put the new GN-1 I bought last week on ebay. If any of you know someone who
may be interested here's the link
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item2465501291
DJ
_
Subject: | Pietenpol Down (but not out) |
Saturday,
My brother went flying on the first warm day....
Hard landing. RH gear failed and collapsed. Minor wing tip scrapage,
prop is kindling. No injuries.
Steve (Back to piet building again) E
Subject: | Re: Pietenpol Down (but not out) |
Steve,
what a total bummer......where exactly did the gear leg fail? Can you snap some
pics of the failed area? Thank God it wasn't worse!
DJ
Subject: Pietenpol-List: Pietenpol Down (but not out)
Saturday,
Hard landing. RH gear failed and collapsed. Minor wing tip scrapage, prop is
Steve,
I'm tickled about the no injuries part, a tribute to sound construction and a good
design, but ouch!
Did the gear fail in the steel or the wood?
Sent: Tuesday, March 09, 2004 10:34 AM
Saturday,
du>
Steve-- don't let your brother do any more landings:) Kidding-- I'm very
glad to hear that you both are ok.
That plane has the historic Utah-to-Oshkosh-And-Return trip under it's belt.
Mike C.
Steve,
Sorry to hear of the setback. That everyone os OK is the main thing. It's only
an airplane.
walt evans
NX140DL
Sent: Tuesday, March 09, 2004 1:34 PM
Saturday,
I have been following the posts here for a short while now while I get situated
in my shop to build a Piet. I have only heard great things about the plane and
great things about building them. My particular reason for building a Piet
is that from day one the plane gave me a real feel for a nastalgic, old airplane
and gives me the feeling that I am stepping into the shoes of the early flying
pioneers.
I have alot to learn as I get ready to build but the first thing that has caught
my attention is the multiple models of the Pietenpol. Would someone please
tell me what the GN-1 Aircamper is in regards to the simple Aircamper?
Thanks to all for the help and also all the other information I have been getting
from this group.
Brian (Michgan)
All-
I'll post some more details when I get time to update my site. I was
home sewing the interior for the Stinson when it happened. I got a call
from my bro stating that "the landing gear has had some trouble"... I
got there about 10 minutes later and they had pushed it off the runway.
He must have hit pretty hard. He did have a passenger with added to the
impact load. It appears from the runway marks and the damage that the
bungee strut to fuse connection failed in tension. The weld broke and
metal was torn. At that point their was nothing left to hold up the
right side of the airplane and the gear "V" tore away from the lugs at
the welds somewhere during the 180. Prop and wing tip damage following
suit. I'll be carving new prop and repairing the gear as quickly as
possible since the weather is just starting to get good.
I'll be there for Brodhead and the 75th in the piet. Making the trip
with new piet hats to commemorate!!
Steve E.
-----Original Message-----
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael
D Cuy
Subject: Re: Pietenpol-List: Pietenpol Down (but not out)
very
belt.
Mike C.
Subject: | Re: the new guy.... GN-1 vs. Piet |
go here Brian:
http://www.gregagn-1.com/faq.php
it'll explain a little about the differences between GN-1 and a real Piet.
DJ Vegh
Subject: Pietenpol-List: the new guy....
and great things about building them. My particular reason for building a Piet
flying pioneers.
getting from this group.
Brian (Michgan)
This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>.
Subject: | Re: the new guy.... |
Brian,
Welcome! In a way I envy you starting a Piet. Either one you decide to build
will be a blast. I built the original long fuselage with prints from Don Pietenpol,
with a Cont. A65, And was very pleased with the building process.
In the big picture of it all, the main thing is not what you build, but that
you did build it.
You can always relate to another who built a wood and fabric airplane,,,and flew
it!
walt evans
NX140DL
Sent: Tuesday, March 09, 2004 3:34 PM
Piet is that from day one the plane gave me a real feel for a nastalgic, old
airplane and gives me the feeling that I am stepping into the shoes of the early
flying pioneers.
caught my attention is the multiple models of the Pietenpol. Would someone please
Brian (Michgan)
Sent: Tuesday, March 09, 2004 11:34 AM
Steve,
Sorry to hear of the mishap. Get it repaired and we'll fly to Brodhead together!
Saturday,
Subject: | aluminum control horns and such |
Anyone use something like 1/4" solid alum. control fittings? I was thinking this
could be done - laser out the shapes and weld on the attachment sections...
Dunno - any opinions?
Tom Brant
The wood I used for the fuselage was 1" rough sawn spruce I got from Mckormicks
lumber.. When planed, I ended up with 7/8" think boards. For the tail sections
I used 1" thk. by 7/8" wide members where 1" sq. members were req'd. Anyone
think this will be problem? I know I probably should have checked this before
I started but as I saw it, it shouldn't be a problem. I am planning to add
1/8" thk. ply plates to the insided where the hinges mount to the main beams
(making them 1" thk. at that point).
Just having some second thoughts... I hate deviating from the plans, even a little.
Tom Brant
Subject: | Re: aluminum control horns and such |
I see no reason why not. The entire Fisher line of aircraft use 1/8"
aluminum control horns. I say go for it.... whats nice about aluminum is
standard wood working tools can be used in the fabrication process.
DJ Vegh
N74DV
Mesa, AZ
www.imagedv.com/aircamper
Subject: Pietenpol-List: aluminum control horns and such
thinking this could be done - laser out the shapes and weld on the
attachment sections... Dunno - any opinions?
> Tom Brant
Subject: | Re: tail sections |
I think you'll be fine so long as the grain tightness of the wood is up to
par. Just for point of reference, my dad's Fisher Celebrity has wood
longerons made from 3/4 x 7/8, the uprights and diagonals are 1/2 x 3/4",
it doesn't have a plywood bottom past the aft seat and it's stressed to
+4 -2 G's with a gross of 1230lb.
DJ Vegh
N74DV
Mesa, AZ
Subject: Pietenpol-List: tail sections
Mckormicks lumber.. When planed, I ended up with 7/8" think boards. For
the tail sections I used 1" thk. by 7/8" wide members where 1" sq. members
were req'd. Anyone think this will be problem? I know I probably should
have checked this before I started but as I saw it, it shouldn't be a
problem. I am planning to add 1/8" thk. ply plates to the insided where the
hinges mount to the main beams (making them 1" thk. at that point).
a little.
> Tom Brant
Steve,
Sorry to hear about your plane. Thank God it wasn't any worse. I'll bet
Andrew feels terrible about it, and will help a lot with the repairs. It's
really good to hear you plan on getting 'er back in the air as soon as possible,
and making Brodhead this year !! Prop strikes require engine disassemby,
inspection, and N.D.I. the crank...that's the tough part.
Chuck G.
put me down for 3 hats
In a message dated 3/9/04 10:02:15 PM Central Standard Time,
tmbrant1(at)netzero.net writes:
<< Anyone use something like 1/4" solid alum. control fittings? I was
thinking this could be done - laser out the shapes and weld on the attachment
sections... Dunno - any opinions? >>
Tom,
That's a no - no. You're givin' me the hiebie jiebie's !! It might work,
but if it doesn't, you're a smoking hole in the ground. Not worth the risk,
for all you get. Stick to the plans.
Chuck Gantzer
In a message dated 3/9/04 10:07:22 PM Central Standard Time,
<< The wood I used for the fuselage was 1" rough sawn spruce I got from
Mckormicks lumber.. When planed, I ended up with 7/8" think boards. For the tail
sections I used 1" thk. by 7/8" wide members where 1" sq. members were req'd.
Anyone think this will be problem? I know I probably should have checked
this before I started but as I saw it, it shouldn't be a problem. I am planning
to add 1/8" thk. ply plates to the insided where the hinges mount to the main
little.
Tom,
The ribs, and all the cross braces in the fuselage would probably consume the
spruce you have for the longerons. Then you can purchase 1" X 1" for the
longerons. I would also suggest you stick to the plans dimensions for the tail,
too. The plywood you mention to bring it up to 1", is to prevent crushing the
trailing edge of the stabilizer, right ? That plywood will do nothing to add
to bending strength of that member.
Chuck Gantzer
From: | Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov> |
Subject: | engine disassembly |
I thought that engine tear down after a prop strike was only required for
certificated aircraft ?
All of my fittings are 6061T6 Aluminum, and the control horns are all
made using 90 degree angle and flat plate. I can send photos directly
if you would like.
this could be done - laser out the shapes and weld on the attachment sections...
> Tom Brant
Again, you have to do some homework. It is very simple to work out the
strength of Al vs steel, and then calculate the thickness required.
Pietenpol didn't use steel because it was better, 6061T6 didn't exist
back then, and steel was cheap and aval. 1/4" 6061T6 is about 3X
stronger than the plans specified steel.
> Tom,
> Chuck Gantzer
Subject: | Re: engine disassembly |
Only on certain engine models with metal prop. The small continentals with
wood prop seldom are torn down. Might dial the crank but the beauty of a
wood prop is that it gives and not the engine.
From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov>
Subject: Pietenpol-List: engine disassembly
My Bellanca with a 216 mph red-line uses 1/8" plate and angle for the
aileron horns.
Cy Galley - Bellanca Champion Club
Newsletter Editor-in-Chief & EAA TC
www.bellanca-championclub.com
Actively supporting Aeroncas every day
Quarterly newsletters on time
Reasonable document reprints
Subject: Re: Pietenpol-List: aluminum control horns and such
> > Tom,
work,
risk,
> > Chuck Gantzer
From: | "Fred Weaver" <Mytyweav(at)earthlink.net> |
Subject: | Good Luck Steve E! |
Chuck.... No dissassembly required for prop strikes on Experimentals,
especially prop strikes with wooden props. Only mandatory on Certified
Airplanes and "maybe" an experimental with a Metal prop. I'm sure Steve will
dial the crank and that's all he should need to do. The engine was rotating
at idle probably too and not generating a lot of damaging energy. Note the
fact only one prop blade was wiped out.
Good Luck Steve E... I know you guys can get it squared away in time.
Weav
> Steve,
It's
possible,
> Chuck G.
I do want to check the engine and crank for damage. This is out of my
area of personal experience (not for long however). I appreciate the
input on this topic. The engine turns over by hand normally and there
isn't any visible engine damage. I do hope that there isn't any engine
damage since that will make a repair much more expensive. I'll get more
help locally on this issue, but I'd be interested to learn from folks
here, how to 'dial the crank' or make other measurements, and what
limits they should be within.
I assume that it entails mounting a dial micrometer, and turning the
crank, while still in the engine and look for wowies. Simple enough in
concept, but what are the finer points?
Steve E
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Fred
Weaver
Subject: Pietenpol-List: Good Luck Steve E!
will
rotating
the
Weav
> Steve,
bet
It's
possible,
disassemby,
> Chuck G.
Subject: | Re: Good Luck Steve E! |
Steve.... It really is that simple. AND if the flange isn't bent, (I don't
know the limits) I wouldn't tear the engine down at all. Just run it...
Weav
Subject: RE: Pietenpol-List: Good Luck Steve E!
> Steve E
> Weaver
> Sent: Wednesday, March 10, 2004 9:38 AM
> will
> rotating
> the
> Weav
> From: <Rcaprd(at)aol.com>
> To:
> Sent: Tuesday, March 09, 2004 11:51 PM
> > Steve,
> bet
> It's
> possible,
> disassemby,
> > Chuck G.
From: | "Bill Church" <eng(at)canadianrogers.com> |
Tom,
Something to be aware of is the fact that aluminum loses a lot of its
strength in the weld zone. For instance, for 6061-T6, the design stress
(in bending) drops from 24,000 psi to 14,000 psi within 1 inch of the
weld. That's more than 40% loss of strength! And, the welds are usually
at the points of greatest stress.
Tom Brant
From: | "Norman Stapelberg" <norshel(at)mweb.co.za> |
Just thought I'd throw this one out there, Lycoming 0-235 lost a blade
in flight should the motor be torn down or just dial the crank.
Norman
ZS-VJA (rebuilding)
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cy
Galley
Subject: Re: Pietenpol-List: engine disassembly
with
a
for
Hi Dave,
I would appreciate seeing photos of your aluminium fittings if you have them.
Managed to knaw mine out of steel but Alum. would sure be easier to use.
Thanks, Jim
Date: Wednesday, March 10, 2004 6:16 am
> if you would like.
> was thinking this could be done - laser out the shapes and weld on
> the attachment sections... Dunno - any opinions?
> > Tom Brant
> _-
> _-
> _-
> _-
Tom,
Seems to me that , that is alot of work only to get a fitting that might
weigh more than the steel one. The steel on the original horns are very
thin (forget the guage) and suprisingly light when done.
walt evans
NX140DL
> Tom Brant
Steve,
Around twenty years ago I asked a veteran mechanic if he had ever seen a
crankshaft or engine damaged by a wooden propeller strike. Since that time,
I have asked at least ten experienced aircraft mechanics the same question
and always received the same answer:
"Never."
Since I have been a licensed aircraft mechanic since 1953, I guess I also
fall into the "veteran" category. I have seen lots of engines seriously
damaged by a metal propeller strike, but never with a wooden propeller. So
long as the crankshaft flange has not contacted anything hard, you should be
OK.
However, a thorough inspection of just about everything is in order,
including:
---checking runout and a dye penetrant inspection of the exposed crankshaft;
---inspecting engine mount and fittings;
---inspecting the upper spar flanges just outboard from the wing strut
attach points* for compression failure;
---inspecting the lower longerons near the landing gear attachment points.
* On the side that contacted the ground.
Tough luck, but it could have been much worse. You should soon be
operational again .
Graham Hansen (Pietenpol CF-AUN) Alberta, Canada
Very good suggestions, and I'll take them. One thing I noticed when I
removed the prop, The tapered crankshaft is smooth, but has a very fine
coating of rust dust. I assume that this isn't a good sign. It wipes
off both the crank and the hub, but I expected bare or at least finished
metal.
Thanks again,
Steve e
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham
Hansen
<grhans@cable-lynx.net>
Steve,
time,
question
"Never."
also
So
should be
OK.
including:
crankshaft;
points.
operational again .
That is exactly all there is to it. Find an owners/repair manual for
the engine, and check the allowable runout on the crankshaft. Compare
it to the dial readings. Voila!! (Any chilton auto repair manual will
show detailed photos on setting up and using the dial indicator for
crankshaft runout. I bet an offer of a six-pack and any of the local
mechanics will be happy to show you how.
> Steve E
> Weaver
> will
> rotating
> the
> Weav
> To:
> > Steve,
> bet
> It's
> possible,
> disassemby,
> > Chuck G.
Sur thing, I'll be doing some photos tonight, and sorting through my
folders on the computer, and fire off a bunch. I was way too lazy to
start bending stuff, so everything is set to use flat plate and angle
pieces only, including the pulley brackets for the ailerons. Will fwd
photos later tonight or tomorrow, depending on how much I get done in
the shop tonight!!
jimboyer(at)direcway.com wrote:
> Hi Dave,
> Thanks, Jim
> From: dave rowe <rowed044(at)shaw.ca>
> > if you would like.
> > > Tom Brant
> > _-
> > _-
> > _-
> > _-
Hence the parts that I built that don't require any bending or welding
whatsoever. It took one evening to make all of the control horns,
hinges, and wing attachment fittings, no special tools required, just my
trusty old bandsaw with a $10.00 metal blade, and a drill press.
The control columns were a different matter, as welding is involved, I
went with steel, entire assembly took one evening, and will cost me a
pound of smoked salmon (my other hobby)to get the welds done. Again, if
Tom or anyone else would like more info and photos, contact me directly
and I'll send. Now that I have worked with both steel and aluminum, I
do prefer aluminum for most things, but there is no rocket science to
steel either, and if welding is a must, go with the steel.
Now, can we discuss wooden wing struts and landing gear??? Still would
love to see more input on that issue!! Cheers.
Bill Church wrote:
> Tom,
> Bill
> Tom Brant
<001e01c406dd$d63e1b30$2cc5fea9@home>
From me again, if you do all the claculating, you can build in Al, get
same strength, and weight, but the difference in either isn't worth
worrying about, I think it's just about what you feel more
familiar/comfortable working with. For me, avalability and cost were
main motivators. We have to pay to dispose of scrap 6061T6, which we
have in abundance, so I was able to get my CO's permission to have the
guys set aside any scrap in useful sizes. The local supplier will sell
to me at a discount, he likes military people and homebuilders, so I
just could not justify using steel. Our aircraft structures technicians
are definately subject matter experts, and inspect and advise on
everything I do. I definately trust their judgement, I fly in the
results of their labour almost daily!
walt evans wrote:
> Tom,
> walt evans
> NX140DL
> From: <tmbrant1(at)netzero.net>
> To:
> Sent: Tuesday, March 09, 2004 10:56 PM
> > Tom Brant
The EAA Chapter 866 (Titusville Florida) Smilin' Jack newsletter contained
this descriptive note. It makes Steve's landing gear failure look
relatively minor (not that that is any help, Steve). If you are going to
run your engine with nobody in the cockpit, TIE THE TAIL TO A TREE. Right
here in Oshkosh I can show you a tree (by the EAA chapel) that made a Piper
J4 into a sweptwing, a severe mark on a hangar corner some 200 feet from
where the airplane started, and several other horror stories.
Anyhow, this is a Pietenpol story, so it qualifies for Matt's website. I
quote:
Jim Webb told his story about an incident with his Pietenpol. The engine
was mounted on the fuselage with his brand new prop on it. Wings were not
mounted yet. He was adjusting linkage on the throttle cable and had
loosened the nut that jams the cable at the connection point to the linkage
on the carburetor. After this with the wheels chocked with 2 x 4s he
started the engine. The throttle went wide open and when he pulled the
throttle back to idle, it had no effect. The fuselage jumped the chocks
and Jim was being dragged around unable to get control. Jim said he tried
to steer it into an orange tree but it kept doing 360s in his
driveway. Finally it decided it wanted to go into the garage and wreak
havoc in there. The prop hit the top of the garage door frame taking some
of the prop away. Then it spotted the wings he's built for her and
promptly headed for those while dragging Jim along. The prop grabbed the
wngs and got hold of the cables and just wrapped them up around the hub and
totally destroyed the wings. Jim finally hit the primary switch and shut
the engine down. Wow! Luckily, Jim said, I wasn't seriously hurt, the
house wasn't destroyed, and no one else was hurt. Jim said that even
though the wings were destroyed, no glue joint broke and no pulleys or
connection points failed. Jim said I went out and bought a book to read
and Beatrice and I got in the motorhome and went to Sebring for three days
Good attitude Jim!
Doc Mosher do not
archive
Oshkosh USA
Tom,
You certainly might do this, after of course, doing some elementary stress
calculations to see if the aluminum would carry the anticipated loads.
BTW, I think that I heard or read someplace that Bernard Pietenpol actually
used the steel from discarded 55 gal drums to make some of his fittings!
> Tom Brant
Subject: | Re: Prop strikes |
Doc,
I don't understand why you included the "do not arc****" phrase. This is a
great story (except for Jim) and it may save an airplane or two, and
possibly somebody's life .
Subject: Pietenpol-List: Prop strikes
Piper
> quote:
linkage
and
> Good attitude Jim!
> Doc Mosher
> Oshkosh USA
Subject: | nicopress strength - wow! |
Q29uZHVjdGVkIGEgbGl0dGxlIGV4cGVyaW1lbnQgdG9kYXkuICBJIGluc3RhbGxlZCBhIG5pY29w
cmVzcyBzbGVldmUgb24gYSAxLzgiIGNhYmxlLiAgRGlkIHRoZSBzdGFuZGFyZCBkZWFsLi4uIEFO
MTAwIHRoaW1ibGUgYW5kIGEgMyBwcmVzcyBwcm9jZXNzIG9uIHRoZSBzbGVldmUgd2l0aCBhIE5h
dGlvbmFsIFRlbGVwaG9uZSBDby4gU3dhZ2luZyB0b29sICh3aGljaCBJIGFic29sdXRlbHkgbG92
ZSEpDQoNClRoZW4sIHVzaW5nIGEgZHJlbWVsIEkgY3V0IHRocm91Z2ggb25lIHNpZGUgb2YgdGhl
IGNvcHBlciBzbGVldmUuICBSaWdodCBkb3duIHRoZSBtaWRkbGUuICBUaGVuIEkgc3R1Y2sgYSBm
bGF0IGhlYWQgc2NyZXdkcml2ZXIgaW4gdGhlIGN1dCBtYWRlIGJ5IHRoZSBkcmVtZWwgYW5kIHBy
aWVkIHRoZSBzbGVldmUgb3BlbiBhIGxpdHRsZS4gIFRoZSB0d28gY2FibGVzIGluIHRoZSBzbGVl
dmUgd2VyZSB2aXNpYmxlLg0KDQpJIHRoZW4gcHV0IGFib3V0IDQwMGxiIG9mIGZvcmNlIG9uIHRo
ZSBjYWJsZS9uaWNvcHJlc3MuICBJdCBkaWRuJ3QgZXZlbiBiZWdpbiB0byBtb3ZlLiAgSXQgd2Fz
IGFtYXppbmcuICBUaGUgTmljb3ByZXNzIHByb2Nlc3MgaXMganVzdCBncmVhdC4gIEV2ZW4gYSBz
ZXZlcmVseSBjb21wcm9taXNlZCBuaWNvcHJlc3MgaGFkIHRoZSBhYmlsaXR5IHRvIGhvbGQgdXAg
dG8gYWJvdXQgMjAlIG9mIHRoZSBjYWJsZSdzIHJhdGVkIHN0cmVuZ3RoIGFuZCBtYXliZSBldmVu
IG1vcmUuDQoNCk1ha2VzIG1lIGxhdWdoIG5vdyB3aGVuIEkgc2VlIHVsdHJhbGlnaHQgZ3V5cyBh
bmQgZXZlbiBzb21lIGV4cGVyaW1lbnRhbHMgd2hvIGhhdmUgMiBhbmQgc29tZXRpbWVzIDMgbmlj
b3ByZXNzZXMgYXQgdGhlIGVuZCBvZiBhIGNhYmxlLiAgVGhhdCBjYWJsZSB3aWxsIGZhaWwgTE9O
RyBiZWZvcmUgYW55IHNpbmdsZSBuaWNvcHJlc3Mgd2lsbC4NCg0KQW55aG93Li4uIG5vdGhpbmcg
cmVhbCBpbXBvcnRhbnQgdG8gcG9zdC4uIGp1c3QgdGhvdWdodCBJJ2Qgc2hhcmUgYSBiaXQgb2Yg
bXkgYW1hemVtZW50Lg0KDQpESiBWZWdoDQpONzREVg0KTWVzYSwgQVoNCnd3dy5pbWFnZWR2LmNv
bS9haXJjYW1wZXINCg0KDQoNCi0NCg0K
du>
Steve-- when I balanced and tracked my wood prop last spring I too found
what you are talking about
on the exposed tapered portion of my tapered crankshaft on our A-65
Continental. I simply smeared a light
coating of grease over the whole thing and wiped off the excess before
re-installing the prop.
I also gave the inside of the prop hub the same treatment. In addition I
dipped my prop bolts in varnish before
inserting them and applying torque to the bolts. The front plate too was
a bit rusty so I cleaned it up and put a clear coat of spray clear over it
to keep it purty.
Mike C.
Subject: | how do you turn the engine without a prop ? |
Maybe a dumb question, but I get all the dial indicator setup on how to
check for a bent crank or
to see if a crank rotates within tolerance, but on a flanged crank for the
65 where to you grip to turn
it or what do you use ? Perhaps this procedure is done with the prop in
place ?
Thank you Graham Hansen for staying on the list with us----you are one
amazing guy (and contribute
some great wisdom to the list) that has flown
soooooe many Piet hours over so many years. You must be the highest Piet
time pilot in the world.
Literally.
Mike C.
Subject: | Re: how do you turn the engine without a prop ? |
<5.1.1.5.2.20040311074555.025b3e08(at)popserve.grc.nasa.gov>
Mike, I am sure there are more scientific ways but I just put a scrap piece
of 3/4 ply about 3 foot long and 6 or 8 inches wide on an old prop for a
template and then drilled it to fit the flange. Bolt it on and I have
about a 3 foot "bat" of ply to pull the engine through with the dial
indicator on the back outer side of the flange. It helps to pull the plugs
to keep from shaking things too much when dialing the crank.
Hope that helps. A big hole saw for the center and a drill bit for the
bolt pattern is all that is needed to drill it. It is one of those
homemade tools that stays in the hangar with the special jacking tools,
vacuum pump bent and ground off wrench etc.
>place ?
>Literally.
>Mike C.
You could take the stop screw out of the hub, and screw it alone back on
the shaft and turn it with a lever through the holes. If an axle nut
was the same thread that might work. I also noticed the front end of
the crank looks like it has a large slot in it. You would need one
large screwdriver.
Thanks for the posts guys. It does make me feel better...
Steve e\
D Cuy
Subject: Pietenpol-List: how do you turn the engine without a prop ?
the
place ?
Piet
Literally.
Mike C.
Steve,
Put some lapping compound between the hub and the crankshaft without the key
installed. Line the hub key slot with the slot int he crank and lap back in
forth about 30 degrees either side of each other. This will make for a
better taper fit and illuminate most of the "gap". Be sure to clean the
lapping compound off when you are done.
Chris Bobka
Subject: RE: Pietenpol-List: engine disassembly
> metal.
> Thanks again,
> Steve e
> Hansen
> Sent: Wednesday, March 10, 2004 2:29 PM
> Steve,
> time,
> question
> "Never."
> also
> So
> should be
> OK.
> including:
> crankshaft;
> points.
> operational again .
<6.0.1.1.0.20040311072707.01b9eec0(at)mail.powernet.org>
Steve,
As you turn the crank, make sure that you have the crank pressed in to the
case all the way so you don't have crankshaft end play counting into your
runout reading.
chris bobka
Subject: Re: Pietenpol-List: how do you turn the engine without a prop ?
piece
plugs
> John
the
> >place ?
Piet
> >Literally.
> >Mike C.
Subject: | Re: nicopress strength - wow! |
<006d01c40732$f4bea2f0$d2a86d44@Desktop>
I'm like you, doing a lot of metalwork right now, and loving it. I was
a little nervous, my woodworking background is very strong, but not a
lot of welding, cutting, etc. My R/C stuff is big, but not that big.
Most people seem to go overboard on the fittings, even though the wood
they're attached to is probably the weakest link.
Get one spark plug off each cilinder, attach two bolts to the flange
in oposite positions and turn the engine with a wooden 2 x 2 or broom
stick, no compression to fight and no danger of firing, an extra
safety, switch off...
Saludos
Gary Gower
> to
> for the
> in
> place ?
> one
> Piet
> Literally.
> Mike C.
http://search.yahoo.com
<4050FD6F.F2B30246(at)shaw.ca>
Subject: | pulley cable guards |
where can I find pre-made pulley cable guards?
DJ Vegh
N74DV
Mesa, AZ
Steve.
Sorry to hear of the setback. Thank the Lord it wasn't worse. A couple of
comments.
1) I would not necessarily tear the engine down. But like the others
suggest, do check for bent crank and runout using a dial caliper.
2) ALSO, I haven't seen anyone mention it, but I would do a dye-penetrant
inspection on the prop flange and the prop hub key (if yours is a tapered shaft).
3) AND, I'd probably pitch the prop bolts and get new ones.
Terry B
Mike,
Wouldn't just installing a new prop and tracking it tell the tale?
You are right about Graham. One piece of advice he gave me was to put a
magneto kill switch on the outside of the cowling so you could shut it down
from where you prop it if something is amiss.
Ted
> place ?
> Literally.
> Mike C.
Subject: | Pitot tube installation |
Pieters: I hope I'm not bringing up a worn out subject, but I've run a couple
of searches with no results. Where do most builders mount the pitot tube on
an Aircamper? I am aware of the vane type airspeed indicator and I plan to
incorporate one (mainly for nostalgic purposes), but I'm also installing a nicely
rebuilt conventional, modern airspeed indicator. If left to my own devices, I
would mount it on the leading edge of the left wing, but I wonder about the
subtleties that are not obvious. Any comments?...Carl Vought
Subject: | Brake Disc Assembly |
Dear List,
I bought Michael Cuy's video and saw that Michael used go-cart brakes on his
Piet. I've found a web site Mowerzone(at)smallengines.CC - which has a Disc Brake
Assembly that looks like it might work. But I'm not sure if it's big enough.
The description says it's for use on riding lawn mowers, mini-bikes and snowmobiles.
It costs less than $13.00 /brake. It looks right to me, but before
I order I would like to hear from someone who may have some experience with
this.
Thanks - Dave Paulsen in Missouri
Subject: | Re: Brake Disc Assembly |
Dave,
I used the drum brakes. 5" (I think) They are plenty to do runup and hold on the
taxiway. Always heard horror stories of nose over.
Got mine here,,,
http://www.apskarting.com/
Guess they still have them.
walt evans
NX140DL
Sent: Friday, March 12, 2004 1:31 PM
Subject: Pietenpol-List: Brake Disc Assembly
Dear List,
his Piet. I've found a web site Mowerzone(at)smallengines.CC - which has a Disc
Brake Assembly that looks like it might work. But I'm not sure if it's big enough.
snowmobiles. It costs less than $13.00 /brake. It looks right to me, but before
this.
Subject: | The second easiest rib question |
Would someone please confirm my counting? I count 30 total ribs needed for
the 3 piece wing, including 6 end ribs with the extra braces.
<4050FD6F.F2B30246(at)shaw.ca> <000501c407db$2d9358c0$d2a86d44@Desktop>
Subject: | dihedral - how much? |
For those of you with 3 piece wings.... what dihedral angle are you
running? The GN-1 plans give no indication of how much. I'm going to make
my lift struts next Wednesday and need to determine dihedral before then.
DJ Vegh
N74DV
Mesa, AZ
Is anyone running any washout in their wings? If so how much?
DJ Vegh
N74DV
Mesa, AZ
Subject: | Re: Pitot tube installation |
Sent: Friday, March 12, 2004 6:21 AM
Subject: Pietenpol-List: Pitot tube installation
Carl,
Mount it on your jury strut, about 6" below the wing. I think you will get the
most accuracy in this location.
of searches with no results. Where do most builders mount the pitot tube on an
Aircamper? I am aware of the vane type airspeed indicator and I plan to incorporate
would mount it on the leading edge of the left wing, but I wonder about the subtleties
<007201c408a5$b3b69550$d2a86d44@Desktop>
DJ,
Here is a response I got from Chuck G. to the same question last year. I
saved it in my goodstuff folder.
Bob B. - Missouri
In a message dated 9/6/03 8:40:23 AM Central Daylight Time, baileys(at)ktis.net
writes:
<< I haven't started construction so I'm spending a lot of armchair time
with
the plans.
My question is; what is the correct amount of washout and how do you
establish it? Is it done when the putting the ribs on the spars or while
mating the wings to the fuselage? Also what serves as a reference point?
Bob B. - Missouri >>
Washout is a twist in the wing, where the leading edge of the outboard
portion of the wing is twisted to a lower angle of incidence than the
inboard
portion, causing the inboard portion to reach it's Critical Angle of Attack
before
the outboard portion. Angle of incidence is the angle between the Mean
Aerodynamic Chord (MAC) of the wing, and the longitude 0 of the fuselage -
on the
Piet it's the top of the longerons at the cockpits. On the Pietenpol the
angle
of incidence is set with the difference in length of the cabane struts - the
front ones are 1" longer than the back ones, making about a 3 angle of
positive incidence. The purpose of washout is to ensure the inboard
portion of the
wing is location where the stall begins, leaving the outboard aileron
portion
to be the last part of the wing to stall, thus maintaining aileron control
until the entire wing is stalled.
Now comes the kicker: On a hearshey bar wing - constant chord, straight
wing
-, the stall naturally occurs at the inboard portion of the wing, therefore
washout is not really required. Just rig the entire wing at the same angle
of
incidence as the inboard portion, where the cabane struts are, by the length
of the lift struts. Although, it could be recomended to err the tips toward
a
lower angle of incidence. The wing twists easily, till the lift struts &
cables are installed. On wings where the leading edge is swept, or the
trailing
edge is swept forward (tapered wings), or the entire wing is swept (like on
jets) is where washout really is needed, because sweeping the wing back
causes
the tips to stall first.
Chuck G.
----- Original Message -----
Subject: Pietenpol-List: Washout??
> DJ Vegh
> N74DV
> Mesa, AZ
Subject: | Re: The second easiest rib question |
I made 30 ribs and ended up with one left over. It is now a conversation piece
in my office.
The only ribs with the extra bracing are the two outer tip ribs.
Greg Cardinal
P.S. Walt Evans has nice pictures of his plane in the latest issue of "To Fly"
To: pietenpol-list(at)matronics.com
Sent: Friday, March 12, 2004 7:42 PM
Subject: Pietenpol-List: The second easiest rib question
Would someone please confirm my counting? I count 30 total ribs needed for the
<006c01c408a5$90cdd0d0$d2a86d44@Desktop>
Subject: | Re: dihedral - how much? |
Hi DJ,
Dale and I built in about 2" of dihedral and between 1/2" and 3/4" of
washout. I don't have that
in degrees.
Next time I would skip the dihedral and stick with anhedral per the plans.
Greg Cardinal
Subject: Pietenpol-List: dihedral - how much?
make
> DJ Vegh
> N74DV
> Mesa, AZ
From: | "Richard Navratil" <horzpool(at)goldengate.net> |
I hope so, I just built 30 of them.
Dick N.
DJ,
The original Pietenpol with the one piece wing had no dihedral, of course.
The 3 pc wing came along because it was easier to build in a restricted
space, and then someone decided to use this modification to put in just an
inch or so of dihedral so as to eliminate the "drooped wing" appearance of
the one piece wing.
I understand that there is no discernable difference in the flight
characteristics with or without dihedral.
make
> DJ Vegh
> N74DV
> Mesa, AZ
In a message dated 3/13/2004 8:27:53 AM Central Standard Time,
At7000ft(at)aol.com writes:
> Thanks
Hi:
You need to make 31ribs for the three piece wing. The 31st one is for
hanging on the wall in your den/office. It truly is a work of art, and makes a
great conversation piece.
Max Davis
Arlington, TX.
From: | "Cory Emberson" <bootless(at)earthlink.net> |
Subject: | Request: Information for Kitplanes Article (Interiors/Exteriors) |
Hello!
I am writing an article for Kitplanes magazine that will feature builders who have
distinctive interiors and/or exteriors.
My deadline is rather short, so if you could email me as soon as possible, hopefully
by Tuesday, that will give me enough time to put it together.
Here are some of the criteria I'm looking for:
Interiors that are (one or any combination):
1. creative
2. inexpensive
3. very comfortable
4. lightweight
5. generally cool and different
6. distinctive in some way.
Exteriors that are:
1.. stunningly attractive
2.. original design
3.. historically accurate
4.. distinctive in some way
Other things to keep in mind:
1. How you came to design your interior/exterior (How you got your idea)
2. The reasons why you did it as you did
3. What benefits you had in mind
4. Any unexpected benefits (and/or pitfalls) there were
5. What you learned
6. How many hours you've flown with it (if completed)
7. How much of the work did you do yourself?
8. Did you have any professional assistance? How much?
9. The equipment and tools you used
10. How much time it took to build and install
11. The cost of building it.
12. Would you do it again the same way? Why?
Here are the photo requirements for Kitplanes: Photos must be 300 dpi at a size
large enough to use in the magazine, which is usually at least 3 x 3 inches.
If an image is 300 dpi at 1 x 1 inch, it won't be big enough to do any good. Hard
copy photos are good, too.
Thanks so much - I really appreciate your help!
best regards,
Cory Emberson
Hayward, CA [KHWD]
510.599.4409
cory(at)lightspeededit.com
I've only got 28, but have two half-ribs, due to putting a tank in the
centre section, so 30 sounds right.
<006d01c40732$f4bea2f0$d2a86d44@Desktop> <4050FD6F.F2B30246(at)shaw.ca>
Good question, I assumed ther wouldn't be any, as the 1 pce doesn't have
any. . .
> DJ Vegh
> N74DV
> Mesa, AZ
Subject: | wing washout & dihedral |
DJ asks about wing washout and dihedral for his GN-1.
Not sure what the Grega plans call for, but the Pietenpol plans and manual
are pretty much for a straight wing. Zero washout and essentially zero
dihedral (although the manual suggests rigging the wings with a tad extra
'up' at the tips so that when everything is buttoned down and the wings'
weight is released from slings or braces holding them up at rigging, they
will relax down to essentially zero dihedral).
Others have used a little dihedral to good effect; witness Mike Cuy's and
others. There has been plenty of discussion on this and a search on
'dihedral' on the archives will keep you reading for a while.
PS- I note several Piet pictures and clips in the latest issue of "To Fly",
including Walt Evans, who looks younger than he sounds here on the list.
(Did I say that right?)
Oscar Zuniga
San Antonio, TX
Subject: | Re: wing washout & dihedral |
Thanks for the response gents....
I keep forgetting how useful searching the archive is. Just spent the last
30 minutes readin olds posts about dihedral.
I think I'm gonna run 1.5 of dihedral and 0.3 of washout.
DJ Vegh
N74DV
Mesa, AZ
Subject: Pietenpol-List: wing washout & dihedral
Fly",
> Oscar Zuniga
> San Antonio, TX
Subject: | Sport Pilot errata |
Just a couple interesting hangar-flying things...
At the TICO airshow today I stopped in the Aero-Adventures tent (they guys
that make the Sventura series among other neat planes) and talked to a
gentleman who's going to be doing SP training soon. He said the total cost
for someone off the street to get their SP license will be about $850 (no I
didn't forget a number there!) Ten lessons at $85 apiece, with no time
limit... you work on the lesson until you understand and can do what you
need to know how to do. This floored me... that's less than 25% of the
current cost of PPL training! No wonder that the FBO's refuse to acknowledge
that Sport Pilot even exists. (In fact, 3 weeks ago the local FBO told me
that the reason they weren't going to offer any SP training was "we don't
have any high-performance instructors available." Umm, yeah, whatever.) He
said he didn't expect too many problems with being able to rent SP planes or
in getting insurance... not too sure about that, at least for a while, but
we'll see.
After hearing that, for the rest of today all my wife could talk about was
how now we could both get our licenses soon. and when were we going to get
started on the Piet? She almost beat me when I mentioned other neat plane
ideas that crossed my mind... "No! I'm all excited about the Pietenpol! You
got me daydreaming about it! Dang it, that's gotta be first, THEN you can
build something else!!" Well, I guess that settles THAT! :)
I also talked to EAA HQ on Thursday, the gentleman there said that they're
expecting Sport Pilot to be published by late April if we're lucky (but not
to count on that, of course.) They also expect the weight limit to be raised
a little bit (maybe to 1300 lbs) and suspect that FAA will phase in various
aspects of it over a period of time... ie, existing private pilots who wish
to fly as sport pilots will be able to do that first, since there's little
infrastructure required, with other types of sport flying to be brought
online at prescribed intervals. They sound pretty enthusiastic about it all.
I know this has little to do with Pietenpols, except that I bet a lot of you
like Bird Dogs and L-4s and the like. Anyone interested in Forward Air
Controllers and their history (going back to balloons and biplanes) might be
interested to know that the very first ever FAC Museum is getting started,
and we desperately need support soon to help it get off the ground. Only $20
and you're a charter member. Details at http://www.ov-10bronco.net/ - tell
'em Merlin sent you.
-Mike
Mike Whaley merlin@ov-10bronco.net
Webmaster, OV-10 Bronco Association
Subject: | Re: Request: Information for Kitplanes Article (Interiors/Exteriors) |
Cory,
How about this for an interior. It is the instrument panel for the Air Camper Dale
Johnson
and I are building. The front cockpit panel features a veneer that is matched to
the rear panel.
Greg Cardinal
Sent: Saturday, March 13, 2004 5:35 PM
Subject: Pietenpol-List: Request: Information for Kitplanes Article (Interiors/Exteriors)
Hello!
have distinctive interiors and/or exteriors.
1. creative
2. inexpensive
3. very comfortable
4. lightweight
Exteriors that are:
2.. original design
5. What you learned
Hard copy photos are good, too.
best regards,
Cory Emberson
Hayward, CA [KHWD]
510.599.4409
Greg,
The woodworking is Beautiful!
Just looking around, think you might have trouble with the inspector on the throttle
linkage. Because it's a moving/critical assy, would have to be a castle
nut w/cotter pin.
walt evans
NX140DL
Sent: Sunday, March 14, 2004 12:33 AM
Subject: Re: Pietenpol-List: Request: Information for Kitplanes Article (Interiors/Exteriors)
Cory,
Dale Johnson
to the rear panel.
Greg Cardinal
Oscar,
You said that perfect!! Thank you (the check is in the mail) :
Yeah, it was pretty cool following an article about Paul flying one of my
favorite planes (like my instructor had flown in WWll),
And across from the plane I'd like to build some day. The Aeronca C3.
For any of you who haven't joined the SAA, it's a great magazine. If
nothing else I ordered the past issues, which you can get for just a
donation! It's some of the best reading on flying ever.
Sorry to say that even Kitplane Mag has gone the way of Lancairs, and Metal
rockets.
As for the dihedral, thats exactly what happened to me. I rigged everything
at zero/flat but in final assy with the weight of the wings, and the
tensioning of wires, and the tollerences in strut bolt holes, the wings
have a slight droop in them.
walt evans
NX140DL
PS the pic on the scales was pre-moving wing back.
Fly",
> Oscar Zuniga
> San Antonio, TX
> mailto: taildrags(at)hotmail.com
> website at http://www.flysquirrel.net
> Get a FREE online computer virus scan from McAfee when you click here.
So you have 28 full ribs in your wing, that is the same number as the one
piece wing. You have 2 full ribs in your center section, and 13 ribs in the left
and right wings correct?
(Interiors/Ext...
Subject: | Re: Request: Information for Kitplanes Article (Interiors/Ext... |
Beautiful interior Greg, what kind of wood did you use on the instrument
panel? Seeing the hand turned knobs makes me want to go out a get a wood lathe.
Rick Holland
Dale Johnson
to the rear panel.
Who was it that has data plates for sale? I need one. I ordered the plate from
Wicks and installed it, this is the one that goes on the exterior near the tail.
My check list from the FAA says aluminum is not acceptable for this plate.
Also there is no space on that plate for the builders name.
Dick N.
<001301c409cb$0380cbc0$2cc5fea9@home>
The throttle linkage is bolted through a rod end bearing so it isn't considered
a rotating joint.
Greg
Sent: Sunday, March 14, 2004 7:48 AM
Greg,
nut w/cotter pin.
walt evans
NX140DL
Cory,
Dale Johnson
to the rear panel.
Greg Cardinal
(Interiors/Ext...
It is burled black walnut veneer. And I want everyone to know that Dale Johnson,
my
building partner, is responsible for the furniture quality work.
Greg Cardinal
Sent: Sunday, March 14, 2004 9:36 AM
Subject: Re: Pietenpol-List: Request: Information for Kitplanes Article (Interiors/Ext...
Beautiful interior Greg, what kind of wood did you use on the instrument panel?
Rick Holland
Dale Johnson
to the rear panel.
Got mine from Aircraft Spruce. It's made out of stainless (CRES).
If you don't have a catalog,,,it's free. Just go on their site and follow the free
catalog thing.
walt evans
NX140DL
Sent: Sunday, March 14, 2004 12:55 PM
Subject: Pietenpol-List: data plate
tail. My check list from the FAA says aluminum is not acceptable for this plate.
Dick N.
Subject: | Need a little help |
Pieters,
When I built 41CC one of the highest hurdles and time consuming projects was
the fabrication and installation of the fuel plumbing particularly the cut off
valve and remote control. I am at that stage again and would like as many
solutions as you would feel free to share with me. I have an 18 gal fuse tank
just rear of the fire wall. I need a on-off valve easy enough to operate with a
push pull wire.
Corky in La
No, the wing centre section is 48", with four full ribs, and two
half-ribs for the fuel tank space. Tank is kevlar, one-piece molded
into the centre section. Twelve ribs in each oute section.
There was someone on the list who had a very nice plate made. I'm trying to find
that one.
Dick
Sent: Sunday, March 14, 2004 4:22 PM
Subject: Re: Pietenpol-List: data plate
free catalog thing.
walt evans
NX140DL
from Wicks and installed it, this is the one that goes on the exterior near the
Dick N.
Subject: | Re: Antique Instruments |
<000c01c40a12$d3c37e30$2cc5fea9@home>
Someone sent a link for instruments a while back, and I'll be damned if
I can find it. Could someone send any links for antique-looking
isntruments. Thanks, Dave Rowe
Subject: | Photo posting etiquette - please check your attached file |
sizes!
Folks,
I love the neat pictures that get posted here, but there's no reason at all
to post a 1+ megabyte JPG or GIF file here! That's why so many folks have
complained about this new feature. If you don't have broadband internet
access, 1MB is a big hit to the download time, and it's a big waste of hard
drive space no matter how you're connected.
JPEG files have a quality setting built in (it has to do with how much the
image is compressed - the more compression, the more data you lose in the
image.) But believe it or not, you're quite unlikely to see any significant
difference between "full quality" (10) and "low quality" (3) unless you're
printing it out on a photo-quality printer or you're zooming way in and
greatly enlarging a little piece of it. However, the "low quality" version
of an image is a tiny fraction of the size of the full-size, full-resolution
file.
An 800x600 size JPG photo can easily be 50K or less at a lower quality
setting, while 60% quality or greater can easily push it well into the
megabyte range. 99.5% of all viewers can't see any difference between them.
Virtually all digital cameras and scanners can record images at lower
quality, that's the easy way to do it... set it to record the image at a
lower quality (or, take photos at the highest quality setting that keeps
files under 100KB or so.) Or better yet, take photos or scan things at a
high quality setting, but reduce the file's quality for emailing. Pretty
much all photo-editing software that can handle JPG files can do a "Save As"
which will ask you specify the quality level as well. Quality 3 or 4 (out of
10) is plenty good for nearly all uses except full-color magazine
publishing. My favorite program for this is called EyeBatch (it's not too
expensive, available at http://www.atalasoft.com/ ) which will let you
create scripts to re-size the physical dimensions AND the quality of one or
any number of images at a time. This is nice for saving hi-res photos from
the digicam, while creating smaller (under 75KB) versions at 800x600 that
are safe for emailing and posting on webpages. (If any EyeBatch users want
my scripts for this kind of stuff just lemme know...)
Sorry for the rant, but there has been a lot of needlessly huge (but
otherwise interesting) files posted lately. Keep the good photos coming!
-Mike
<000c01c40a12$d3c37e30$2cc5fea9@home> <40550980.B9D5FE38(at)shaw.ca>
http://www.bugsandbuggies.com/vdo_main.asp
http://www.stewartwarner.com/Products/prod1.html
United Auto here in Coquitlam apparently carries
these " Wings " gauges. I haven't gone to see yet.
Clif
Subject: Pietenpol-List: Re: Antique Instruments
From: | "Peter W Johnson" <vk3eka(at)bigpond.net.au> |
Oscar Zuniga I think.
Cheers
Peter.
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Richard
Navratil
find that one.
Dick
the free catalog thing.
walt evans
NX140DL
From: Richard Navratil <mailto:horzpool(at)goldengate.net>
the tail. My check list from the FAA says aluminum is not acceptable for
this plate. Also there is no space on that plate for the builders name.
Dick N.
Try http://www.stewartwarner.com/Catalog/2wng.html
Cheers
Peter
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of dave rowe
Someone sent a link for instruments a while back, and I'll be damned if I
can find it. Could someone send any links for antique-looking isntruments.
Thanks, Dave Rowe
advertising on the Matronics Forums.
In response to Dave in Missori: Although there have been many suggestions
that motorcycle wheels have no ability to sustain side loads, there are also many
examples of successful applications of them on Pietenpols. A notable example
is Chad Wille (from Washington state I think) who uses a pair of British
motorcycle wheels on his Scout. Before Chad used them, his father used the same
wheels on his Piet. While it's true that a motorcycle is seldom in a position to
sustain a side load, it would be difficult or at least improbable to build a
wheel for production which had NO such capability. General statements aside,
can anyone out there site chapter and verse on specific failures of motorcycle
wheels as used on Pietenpol aircraft? I'd be very interested in the failure
mode of the wheels. There are about four possibile failure points and I honestly
do not see where fabricating your own 6" hubs buys much in the way of a
guarantee against these failure modes. Carl Vought
From: | "Oscar Zuniga" <taildrags(at)hotmail.com> |
Subject: | antique instruments |
Here's a link to another instrument site besides the Bugs 'N' Buggies, which
is also good:
http://www.classicinstruments.net
Oscar Zuniga
San Antonio, TX
Dick; I'm the one who is offering brass dataplates (info at
http://www.flysquirrel.net/piets/dataplate.html ) but they don't include
space for the builder's name and aren't intended to meed the FAR
requirements for the permanent data plate that is to be affixed to the
airframe. They are intended more for installation in the cockpit, in front
of the passenger on the "glove box", or similar, to impart that old-timey
feel. But if you want one, shoot me your snail mail address offline and
there will be one in the mail to you tomorrow.
I had 100 of these plates made up and have only sold about 1/4 of them, so
if anyone wants one, info is on that webpage. I won't make a living selling
them but wouldn't mind recouping my investment. I plan to take them with me
to any fly-in I might attend, such as Brodhead, Urbana, Sun 'n' Fun, etc.
Oh, and to the person from Kitplanes who was asking about unique cockpits,
William Wynne's instrument panel was carbon fiber and would have been of
some interest just for that 'look'. I have a digital image of the panel,
but it's very low quality since it was a scan of a photo.
Oscar Zuniga
San Antonio, TX
Netscape/7.01
<000b01c40a2c$9fd1c4a0$0600a8c0@laptop>
Oscar Zuniga:
You can see a picture and get ordering
information at http://www.flysquirrel.net/piets/dataplate.html and they are
$10 postpaid to anyone in the known universe.
Leo Gates
> trying to find that one.
> Dick
Netscape/7.01
Oscar Zuniga:
Leo Gates
> Dick
Hi Greg,
That is beautiful! How close are you to completion? Can you tell me a little
more about how you designed and built that gorgeous interior? Can you tell me
anything about the seats, etc. as well?
Thanks so much!! (wolf-whistling :-) )
best,
Cory
Sent: Saturday, March 13, 2004 9:33 PM
Cory,
Dale Johnson
to the rear panel.
Greg Cardinal
Hello!
hopefully by Tuesday, that will give me enough time to put it together.
1. creative
2. inexpensive
3. very comfortable
4. lightweight
Exteriors that are:
2.. original design
5. What you learned
size large enough to use in the magazine, which is usually at least 3 x 3 inches.
best regards,
Cory Emberson
Hayward, CA [KHWD]
510.599.4409
I'm running into some roadblocks and thought that others on the net might have
traveled the same road and could offer some advice.
I'm trying to get some term life insurance but flying the Piet seems a bit much
for the various companies to deal with. To date I have had one flat-out refusal
and one that said they would cover me but they would exclude ALL aviation-related
pay-outs!! All this because I have a home-built airplane. What to do???
I'm definitely NOT interested in ways to circumvent the system, just experiences
or names of homebuilt-friendly life insurance companies.
Thanks-
Larry
Subject: | Re: life insurance |
Have you tried the EAA - ( www.eaa.org ) members have access to several
insurance companys.
I've not started building yet but I do belong just to be able to get
discounts.
Sid
<022101c40acf$59248490$cbfe79a5@lightspevjz355>
Cory,
The veneer was glued onto birch plywood. Seat bottoms are also walnut veneer.
Seat backs are hand wickered.
Control column is walnut with maple inlay turned to the dimensions of a Waco
ATO stick (I always wanted Waco stick time and
this is as close as I'll probably get...) Primer and throttle knob are laminated
and turned.
Fuselage was moved into the paint shop last Saturday. Wings have been painted
to completion. Tail feathers only need the blue trim.
Greg Cardinal
Sent: Monday, March 15, 2004 2:51 PM
Hi Greg,
best,
Cory
Subject: | Re: Need a little help |
Corky,
How about a twist instead of push pull? I turn mine 90 degrees for full on to
off.
Ted
Sent: Sunday, March 14, 2004 6:37 PM
Subject: Pietenpol-List: Need a little help
Pieters,
valve and remote control. I am at that stage again and would like as many solutions
as you would feel free to share with me. I have an 18 gal fuse tank just
rear of the fire wall. I need a on-off valve easy enough to operate with a push
pull wire.
Corky in La
From: | Kip and Beth Gardner <kipandbeth(at)earthlink.net> |
>might have traveled the same road and could offer some advice.
>a bit much for the various companies to deal with. To date I have
>had one flat-out refusal and one that said they would cover me but
>they would exclude ALL aviation-related pay-outs!! All this because
>experiences or names of homebuilt-friendly life insurance companies.
>Thanks-
>Larry
Larry,
How old are you? They may just be using the Piet as an excuse for
not wanting to insure you at a decent rate because of your age. I
have an old medical condition that makes it very difficult for me to
get additional insurance at a reasonable price, even though I had
surgery to correct the condition years ago.
Beyond that, I'm afraid I don't have any good advice beyond checking
with EAA & seeing if they have any recommendations.
Kip Gardner
North Canton, OH
<000b01c40a2c$9fd1c4a0$0600a8c0@laptop> <4055F4B5.40705(at)allvantage.com>
Subject: | wings installed!!! |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In a message dated 3/14/04 5:39:01 PM Central Standard Time,
Isablcorky(at)aol.com writes:
<< Pieters,
off
tank
with a
push pull wire.
Corky in La >>
Corky,
I'll e-mail you direct, with some digital pictures (still in the camara) of
how I did mine. Might give you some ideas.
Chuck G.
<005a01c40afe$a7c34620$d2a86d44@Desktop>
Subject: | Re: wings installed - weight |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Subject: | Re: wings installed!!! |
Wow DJ!!! It looks beautiful, congratulations. Jim
Date: Monday, March 15, 2004 6:30 pm
Subject: Pietenpol-List: wings installed!!!
> Need to share my excitement... I just spent the last 5 hours
> making the lift struts and installing the wings. Not a tough job
> just time consuming.
> I went with 1.2 degrees of dihedral and 0.4 of washout (which is
> about 3/8" at the trailing edge at wing tip) My incidence at the
> root is 1.8 degrees.
> Man... was it ever cool to have this thing parked in the driveway
> with the wings on!
> lots of pics here
> http://imagedv.com/aircamper/log/image-pages/03-15-04.htm
> DJ Vegh
> N74DV
> Mesa, AZ
Bet you're glad you bought that project now. It's looking good and was
interesting as to how you put your dihedral in. I've read of others who
put 1 degree in and said that it made a definite difference on the GN-1 stability.
Would you hurry up and finish? There are a bunch of us who've
been following your work. We're getting impatient.
Larry Ragan
Jacksonville, Fl.
lragan(at)hotmail.com
Subject: | Piet in the street |
DJ-- looks fantastic ! (oh, by the way I do know that DJ has a GN-1 and
not a Pietenpol) Good for you. You have to be motivated
now. You've got an engine that has been rebuilt and test run to boot !!
PS-- reminds me of when I had the Piet out in the yard test fitting things
or running with the smoke on at full bore.......cars slow down, people look
at you like you are mostly a troubled individual. It was great:)
Mike C. in Ohio
Sent: Monday, March 15, 2004 7:30 PM
DJ,
Wonderful pictures, your plane is a "work of art".
Need to share my excitement... I just spent the last 5 hours making the lift
struts and installing the wings. Not a tough job just time consuming.
I went with 1.2 degrees of dihedral and 0.4 of washout (which is about 3/8" at
the trailing edge at wing tip) My incidence at the root is 1.8 degrees.
Man... was it ever cool to have this thing parked in the driveway with the wings
on!
lots of pics here
DJ Vegh
N74DV
Mesa, AZ
DJ,
Pics are great! It IS a big step for a builder to see his project when it first
REALLY looks like a plane.
Have you considered putting in a cutout above the rear pit? I'm very glad I did.
It's the only way to see above you in flight. But then we have a very busy
sky diving operation here and you have to be looking all ways. 22 jumpers leaving
a plane at once pretty much fills up the sky.
Nice progress!!
walt evans
NX140DL
Sent: Monday, March 15, 2004 9:30 PM
on!
lots of pics here
DJ Vegh
N74DV
Mesa, AZ
<005a01c40afe$a7c34620$d2a86d44@Desktop> <001901c40b8e$48fe1850$2cc5fea9@home>
I have a flop that hinges at the rear spar. I was thinking of making another one
and using 3/32" lexan to cover the top and bottom of it.. basically making
it transparent. Would help greatly in seeing other traffic while in steep turns.
DJ
DJ,
It's the only way to see above you in flight. walt evans
NX140DL
Subject: | automotive seat belt retractor for should harness |
Why couldn't the shoulder harness strap be attached to an automobile seatbelt retractor
mounted in the aft fuse? This would allow freedom of movement yet still
keep you retained in an impact.
I see them on ebay for various cars for like $15
DJ
_
Would Mr. Calley of Eaa technical get back to me direct. I have a few tech
questions for him. Thanks
Corky in beautiful La.
From: | "Christian Bobka" <bobka(at)compuserve.com> |
Dick,
If you have a metal plate elsewhere on the aircraft, you can just handwrite with
a sharpie pen the stuff near the tail. Reread the regulation on aircraft markings,
Part 45.
Chris Bobka
A and P with IA
Sent: Sunday, March 14, 2004 11:55 AM
Dick N.
Subject: | Beginning to Build - Questions |
Hi All,
Just a couple of quick questions from a beginning builder:
1. How much T-88 is needed to build the wing ribs and tail feathers?
2. Im ordering 90 degree mahogany plywood from Wicks for the 3/16 tail
feather gussets, and need to choose either 3-ply or 5-ply. The 3-ply is
lighter, but I assume the 5-ply is stronger. Im thinking that the 3-ply
will be plenty strong enough, and the weight savings in the tail will be of
greater importance. Am I correct in my assumptions?
Bruce
Subject: | The hardest part |
Somebody once said that the hardest part to build on a Piet, are the legs for the
straight gear. I'm finding now it's got to be all of this paperwork. I hate
paperwork. Re-writting the builders log and writing an Operations manual getting
a little frustrating.
Has anyone published a Operation s Manual for the Piet?
Dick N.
Subject: | Re: Beginning to Build - Questions |
I got the quart kit of T-88 and it lasted me through the entire tail section
and wing ribs. It goes a long way.
As for ply... I say go with the 3 ply. 5 ply is overkill.
DJ Vegh
N74DV
Mesa, AZ
Subject: Pietenpol-List: Beginning to Build - Questions
> Hi All,
> 2. I'm ordering 90 degree mahogany plywood from Wicks for the 3/16 tail
> lighter, but I assume the 5-ply is stronger. I'm thinking that the 3-ply
of
> Thanks,
> Bruce
available.
DJ
Your GN-1 looks great but I would have to say that the Z looks almost as
good, like that blue color too.
RH
at the trailing edge at wing tip) My incidence at the root is 1.8 degrees.
wings on!
lots of pics here
DJ,
Ah yessss !! Another milestone reached. Really feels great, huh ?
Congratulations !!
Chuck G.
harness
Subject: | Re: automotive seat belt retractor for should harness |
The same thing was suggested to me by one of the engineers at work. He did add
that the tighter the seatbelt is the better off you are in a crash. He is a
avid car buff who races on week ends and is very knowledgeable on stuff like this.
He also suggested putting in a single shoulder harness in the front seat. He said
that a single harness is ok to have mounted below the shoulder because in
a crash you body is able to twist instead of being compressed downward. Not quite
as safe as a 4 point harness but it might be a workable light weight solution.
Anyone have an opinion on this?
Chris T.
Sacramento, Ca
Sent: Tuesday, March 16, 2004 12:46 PM
Subject: Pietenpol-List: automotive seat belt retractor for should harness
retractor mounted in the aft fuse? This would allow freedom of movement yet
still keep you retained in an impact.
DJ
_
on an anti-virus email solution, visit .
From: | "Christian Bobka" <sbobka(at)charter.net> |
<003601c40bec$64edccf0$a1179341@Spot>
harness
Dick,
First thing I need you and everybody else to do is to change my email
address in your address book(s) to :
I am closing out the compuserve account.
Answers to your (old) questions are inserted below.
Chris
> Chris,
> I am a little confused (make that very confused as to the pulleys I
> should be ordering for my Pietenpol.
> *Elevator--I am using 1/8" cable from stick to bell crank and 3/32
> for bell crank to elevator. On the torque tube should I use larger
> pulley on the "up" cable where the cable deflects about 110 degrees. The
> plans show 2" pulleys. AS&S catalog says they are only good for 15
> degree cable deflection. I have one (2") MS24566-3B--is that OK for
> the "down" cable where there is less deflection? or should I be using
> the MS20220 pulleys?
It is always best to use the largest pulley possible. Too small a pulley
will cause the cable to fail. There is an AD on the Luscombe because they
did not use big enough pulleys, nor did they leave enough room for bigger
ones. You would be better off with 3/32" cable over the smaller pulley if
that is all you can fit. 3/32" is fine for what we are doing and that area
is very accessible during each preflight inspection. My Aeronca 50-C prewar
Chief uses 3/32" throughout. 3/32 is about 1/2 the weight of 1/8".
Galvanized is superior to Stainless as it is more flexible and is stronger.
> *Aileron cables--they deflect more than 15 degrees at each pulley,
> but the plans show 2" pulleys for 1/8" cable. Is there a reason for
> using the 1/8"+ pulleys for the 3/32 cable? I will be using 3/32 cable
> for the ailerons. What pulley specification and diameter are you using?
> I checked the Archives and could not find good info. Respond on
> the Pietenpol List if you feel this question and the answer should go
> there.
I don't quite understand the question but I would use a 2" min diameter
pulley with a 3/32" cable.
> Dick Hartwig
Subject: | the myths about rib stitching |
I almost hate to bring this up because of the recent string of e-mails on
this subject but I thought I'd try to encourage those
who have this unfounded fear about the complexity and time that they
perceive rib stitching will demand.
When trying to learn this skill, I ordered the poly fiber book to see how
to rib stitch but the step-by-step diagrams left me with a mess of string
and no confidence at all. My wife and I then spent about 2 hours learning
and practicing rib stitching for free under the poly fiber tent at Oshkosh
a few years back. The hands on teaching was what it took to get it thru
my thick head that this was not a black art or superhuman skill only
achieved by the old masters of wood and fabric airplanes. Hogwash. I
learn better hands-on but you may be able to learn from the book. I think
that poly fiber or EAA offers a videotape too on how-to do fabric
work.
Anyway, yesterday I took the afternoon off to help a friend rib stitch his
Fly Baby wings. Our other friend came along to help and my method of
doing the seine knot (or insane as we like to call it) was different from
Bill's method-- but we both ended up with the SAME knot ! We taught the
owner of the Fly Baby (72 years old) how to rib lace in about 40 minutes
and before the clock hit midnight we had BOTH wings completely
done. Just don't get discouraged over fabric covering and rib stitching
is what I'm trying to say and don't take any cheap, weak, shortcuts that
might kill you or your passenger. Nuff things can kill us when flying.
Dig out there for help wether it be someone who knows how to stitch and is
willing to teach you or the books or video resources we have
available. Don't let someone tell you either that this is the ONLY way
you can rib lace. There are many ways to get to the same knot or two knots
that are both acceptable. Many pilots and builders are quite full of
themselves and forget to be open-minded about how to skin a cat. Tony
Bingelis is fantastic in this respect in his books (tho he doesn't show
how to stitch step by step) in that he gives the builder several options on
"how-to" do the many tasks that face us during building.
Keep on and don't let anything hold you back--including yourself !!
Mike C.
Subject: | Re: The hardest part |
Dick:
I think your guy telling you that he wants all this documentation, pictures
and paperwork is constipated.
When I built my Avid a few years ago, the FSDO guy came out, looked at my
binder. I had probably 20 photos of the construction process with a caption of
a
sentence or so for each picture. My dad (has and A&P license) signed each
photo/caption. I also had my weight and balancce and the builder's manual laying
on a table and another binder full of receipts.
The FSDO guy looked at my stuff and was gone in about 12 minutes. I flew the
airplane later that day.
Maybe you need to find a "kinder and gentler" FSDO rep.
Good luck.
S.B.
<002d01c40bea$89714090$a1179341@Spot>
Dick-- Why did the head of our MIDO office just want to see the invoices
for my raw material purchases and photos of my progress during
building. Your guy is going wayyyyy overboard and I would call him on it
bigtime. Trouble with these inspectors is that they take way too many
liberties about what is required from inspector to inspector. There must
be some guidelines that they have to follow. I would get another
inspector or DAR.
How the heck to you know what your performance figures are going to be
until you FLY the blasted airplane. And he wants a PARTS list ???? Where
the heck does it require you to have this ??? This guy is wacko. I'll
gladly forward my FAA guy's email to you off-line so those two can
talk. I don't mean to sound irritated at you by any means at all--- I
just think that this guy needs to lighten up and make sure your plane is
AIRWORTHY and that you have built the majority of it yourself. The
so-called not in the regs 51% rule that everyone calls the 51% rule. That
is a majority last time I took statistics. Anyway---I think this guy is
way out of line.
Mike C.
Subject: | Re: Pietenpol-List Digest: 17 Msgs - 03/16/04 |
In a message dated 3/16/04 11:57:11 PM, pietenpol-list-digest(at)matronics.com
writes:
<< From: "Bruce __" <bruce___@hotmail.com>
I recently finished up all of my ribs, and used one pint of T-88 for all. But
I laminated my four spars, using seven layers, and used three pint kits for
this. I buy the T-88 a pint at a time, so that it will be fresh. I'm going to
try to weigh my wing components today, but so far, I don't think that there is
any real difference in total weight between my Vertical Grain Kiln-dried
Douglas Fir and AS&S Spruce. When we compared Fuse weights, mine was 71 lbs., vs.
70 for the Spruce approach. And you can still get very good Douglas Fir at your
local lumber yard. I did choose Basswood plywood for all my ply things, it
being lighter and glues better. Carl L , Compton Airport.
Subject: | Covering of the fuselage |
Just thought I'd ask while I am waiting for my material to arrive,
what is the covering procedure/sequence of the fuselage, got the
fuselage back and should be ready in the new week for covering, just a
couple of small things to do.
Cheers
Norman
South Africa
ZS-VJA (rebuilding)
From: | PAT HOEVELMANN <hoevelmann(at)sbcglobal.net> |
I am about to purchase my landing gear from St.Croix aircraft, I found them in
the Pietenpol directory. I wanted to know if anyone has purchased anything from
them. I also wanted to know what size axels to put on it and what size wheels
I should use. Any help would be appreciated. Thanks,
J.J. Hoevelmann
Subject: | Aerocarb on Ebay |
didn't get much interest on selling my Aerocarb so I put it up on ebay... if
anyone is interested here's the link.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2467879692
DJ Vegh
N74DV
Mesa, AZ
www.imagedv.com/aircamper
Subject: | Aerocarb for sale |
SSd2ZSBnb3QgYW4gQWVyb2NhcmIgZm9yIHNhbGUgb24gRWJheSByaWdodCBub3cuICBJdCdzIHRo
ZSAzMm1tIHZlcnNpb24uICBDYW4gYmUgdXNlZCBvbiBhbnkgNjUtMTE1aHAgZW5naW5lLiAgaWYg
YW55b25lIGlzIGludGVyZXN0ZWQgaGVyZSdzIHRoZSBsaW5rDQoNCmh0dHA6Ly9jZ2kuZWJheS5j
b20vZWJheW1vdG9ycy93cy9lQmF5SVNBUEkuZGxsP1ZpZXdJdGVtJml0ZW09MjQ2Nzg3OTY5Mg0K
DQoNCkRKIFZlZ2gNCk43NERWDQpNZXNhLCBBWg0Kd3d3LmltYWdlZHYuY29tL2FpcmNhbXBlcg0K
DQpf
Dear List,
My Flying and Glider Manuel is a little blurred. It appears that the steel
that is used to reinforce the areas around the wood landing gear on page 17 is
16 gage steel. Even with a magnifying glass it is hard to be sure. Can someone
confirm that it is 16 gage. Thanks. Dave in Missouri
Subject: | Re: Landing gear |
I believe that St. Croix Aircraft is or was connected with Chad C. Wille.
He's an old hand at Pietenpols. (I mentioned him the other day in a posting.)
Chad's Scout is featured on p.30 of Sport Aviation Feb 1998. I have one of their
propellers and I'm glad I do, but can't speak for it from experience because
I've never spun it....Carl Vought, Huntsville, AL
Subject: | Re: the myths about rib stitching |
I did my rib stitching by myself. To reduce the number of trips from one side
of the wing to the other, I made 15 straight needles each about 8" long.
After marking and punching stitch locations, I ran all needles through the wing,
along one rib, went to the bottom side of the wing and ran them all back
through the wing. Then I went back to the top side and tied starting knots at each
location (the Polyfiber manual speaks approvingly of using all starter knots).
Then I proceeded to the next rib and did the same thing....Carl Vought
Dave,
The outside vee fitting in the lower right corner of the of figure 6A is
pretty clear, 16 gage steel. The other inside vee, outside and inside
landing gear fittings are not very readable, but do look like 16 gage, most
likely, probably ;<)
Maybe someone who actually made this type of gear will write in and say what
thickness 4130 they used.
Skip
steel that is used to reinforce the areas around the wood landing gear on
page 17 is 16 gage steel. Even with a magnifying glass it is hard to be
sure. Can someone confirm that it is 16 gage. Thanks. Dave in Missouri
Message
Dave,
The
outside vee fitting in the lower right corner of the of figure 6A is pretty
clear, 16 gage steel. The other inside vee, outside and inside landing gear
fittings are not very readable, but do look like 16 gage, most likely, probably
Maybe
someone who actually made this type of gear will write in and say what thickness
4130 they used.
Skip
blurred. It appears that the steel that is used to reinforce the areas
around the wood landing gear on page 17 is 16 gage steel. Even with a
magnifying glass it is hard to be sure. Can someone confirm that it is
Missouri
Subject: | The myths about rib stitching |
From: | "Sayre, William G" <william.g.sayre(at)boeing.com> |
As usual, Michael is right on with his forge ahead advice. My first job rib-stitching
still makes me chuckle inside. I had the book (Stitts). I had the video.
I had 41.13. I read and watched carefully. Both paper resources just gave
me a headache with the "pull line A through loop B while going under piece
C" stuff.
I have to mention that my workshop/play area is about 200 feet from my house.
I'd watch the video, pause certain scenes, rewind and repeat for details and when
I was totally convinced that I understood it I'd confidently go to the shop
and discover that in 200 feet I had totally forgotten what I had just seen.
I'd get about three knots down the rib and "poof", "How'd that go?"
Back to the house and pause, rewind and repeat until I was absolutely, positively
totally convinced I understood it and off I'd go that 200 feet just to find
I was still confused. This had to happen three or four times before I finally
grabbed a scrape front seat frame and covered it with fabric, shrunk it and
sat down in front of the TV and slowly followed the video step by step. For me,
that finally did it and the rib-stitching went well after that.
It really is easy and even enjoyable - once you work through that dang nab convoluted
process. Of course then there's the brackets or braces that end up in
the way. The wax feeling you get on your hands and of course, how darned sharp
that thread can end up being after doing a bunch of ribs. But that's another
smile I get thinking about the joys of homebuilding. Keep at it. We all need
things to smile and chuckle about!
Bill Sayre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Pieters-
Just got word that John Ficklen's Piet will be inspected on Saturday!! It will
be based at the Apalachicola, FL airport. His next goal is to have the time flown
off in time to take it to Sun-N-Fun. After that, he's committed to getting
it to B'head for the 75th anniversary reunion.
Speaking of the anniversary............... looks like there is NOTHING planned
at OSH for the observance of this venerable old design. What to do??
Larry
ps. Got an e-mail last night from Mike Madrid out in Lompoc, CA that he just bought
an airplane.........it's a Grega, though.
I hope so. Sure he isn't refering to an Advisory for an aircraft manufacturer?
Maybe I'm doing too much here, but in my conversations with Dave Smith at MSP
MIDO , who is supervising my inspection, they are asking for more. He says
the log is to include pictures of sub assemblies not visable, a written
description of work preformed, including outside help received, detail of any
modifications from plan and a cronological timeline of construction. I just passed
20 pages on this part.
The operation manual is to include a parts list, weight balance data,
anticipated operation limits and preformance data. I was told the Cessna 150 manual
might be a good base for design.
The Advisory Circular for Homebuilts states that all aircraft must have an
Operations Manual for flight. Am I wrong on this point?
Subject: | Re: Aerocarb on Ebay |
DJ
What carb did you end up using on your Corvair?
RH
Interesting idea but why didn't you do several ribs at the same time? One starter
knot and then work up these ribs. With 15 needles you could do 15 ribs minimizing
the switching sides as well.
Sent: Thursday, March 18, 2004 7:40 AM
Subject: Re: Pietenpol-List: the myths about rib stitching
of the wing to the other, I made 15 straight needles each about 8" long. After
marking and punching stitch locations, I ran all needles through the wing, along
one rib, went to the bottom side of the wing and ran them all back through
the wing. Then I went back to the top side and tied starting knots at each location
Subject: | threads on wing stuts |
Max,
At the bottom end of the strut, what is the depth of the threads and how long is
the threaded portion of the clevis?
Chris
To: sbobka(at)charter.net
Sent: Thursday, March 18, 2004 10:25 AM
Subject: Re: threads
Chris:
I have the struts off of a cub...that we are going to cut down from the top.
Max
Subject: | Re: threads on wing stuts |
I haven't taken one of them apart yet. They came off of a flying cub. Piper
specs.
Max
I think I'm gonna get an Ellison TBI. It's expensive but it's a damn good unit.
I may have to run a Marvel or Stromberg in the interim until I can come up
with the $$$ for the Ellison.
DJ
Subject: Re: Pietenpol-List: Aerocarb on Ebay
DJ
RH
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item2467879692
This email has been scanned for known viruses and made safe for viewing by Half Price Hosting, a leading email and web hosting provider. For more information on an anti-virus email solution, visit <http://www.halfpricehosting.com/av.asp>.
Subject: | threaded end of cub struts |
Max,
Now I remember... I think there should be a witness hole up along the threaded
part of the strut bottom about 3/4" or an inch. When you have the clevis in the
strut, a piece of wire stuck in the hole should hit the clevis indicating that
it is in that far or more. Does this make sense? It may be clogged with
paint, etc..
Spherical joints also use this witness hole method of ensuring adequate thread
engagement.
chris
Sent: Thursday, March 18, 2004 9:59 AM
Subject: RE Max Davis
Chris:
How's it going? I have been extremely busy at work as of late and have not had
the time to pester the Rochester Gauge Co. I thought I would give them a little
time, anyway, and regroup before the next attack.
I have some photo's and even a 20 second clip if you are interested and have
DSL. I can't remember if I sent it out or not. I don't think I did because of
all the whining about large files on the list.
Let me know back...I would be happy to send pictures of the prototype with assorted
fittings to date. We are going to install them in the next few days.
As soon as we get the plumbing installed we are going to put the wings on. Does
the 2 1/2 thread rule apply the lift struts? If so, how in the world can
I cut those things to those tolerances. I am almost positive a cub has more than
3 treads showing.
Have a good one,
Max Davis
Arlington, TX.
Subject: | Re: threaded end of cub struts |
the Piper fork has a 7/16-20 thread. The way I did it was I threaded the fork
into the strut 20 turns... which gave me 1" of contact I can go up to 4 turns
out and still be OK.
DJ
Subject: Pietenpol-List: threaded end of cub struts
Max,
paint, etc..
engagement.
chris
Chris:
3 treads showing.
Have a good one,
Max Davis
Arlington, TX.
<008b01c40d12$fb3d7da0$0564a8c0@rdci.az.home.com>
DJ
That is good info. You obviously use 1" less 4/20 of an inch or about 3/4" engagement
as a minimum. What is the basis of this?
chris
Sent: Thursday, March 18, 2004 12:00 PM
Subject: Re: Pietenpol-List: threaded end of cub struts
DJ
To: Andimaxd(at)aol.com ; pietenpol
Sent: Thursday, March 18, 2004 10:01 AM
Max,
the strut, a piece of wire stuck in the hole should hit the clevis indicating
that it is in that far or more. Does this make sense? It may be clogged with
paint, etc..
engagement.
chris
Chris:
had the time to pester the Rochester Gauge Co. I thought I would give them a
little time, anyway, and regroup before the next attack.
of all the whining about large files on the list.
assorted fittings to date. We are going to install them in the next few days.
Does the 2 1/2 thread rule apply the lift struts? If so, how in the world can
than 3 treads showing.
Have a good one,
Max Davis
Arlington, TX.
<008b01c40d12$fb3d7da0$0564a8c0@rdci.az.home.com> <000b01c40d16$34281460$0101a8c0@domain>
well... first I wanted to find the thread stress area if the fork was threaded
1/2" (10 turns) which on a 7/16-20 is .119" =B2/revolution.
I foundthe formula for that here:
http://www.engineersedge.com/calculators/thrd_strss_100a_pop.htm
so.....
.119 x 10 turns 1.19" =B2
I figured 5G's of the gross weight hanging on just one strut fork with the strut
at 60=B0 would be 12,000 lb
so 12,000/1.19 approx 10kpsi.
I'm guessing the lift strut fork has an ultimate shear failure of at least 90kpsi.
that leaves me with a factor of safety of 9! and thats if the entire plane is
hanging from just one fork which does not happen happens.
So then I just figured 3/4" looks about right. :-)
DJ
DJ
chris
DJ
Max,
paint, etc..
engagement.
chris
Chris:
Have a good one,
Max Davis
Arlington, TX.
DJ:
I did some research on this and if I can find my info, it isn't a good idea
on a gravity fed system. This info came to me from EAA HQ about 4 months ago.
That's the way I started to do it....one needle for each rib..But I decided
to do one rib at a time because the work is concentrated in one place,
requiring less movement from one rib to the next. Secondly, I thread 30" of waxed
cord
onto each needle at a time. I wind all 15 pieces of cord around a fixture (a
board with two nails 15" apart) at one time then thread all needles at one
sitting....It all seemed simpler to me to deal with the short pieces of cord than
the long ones. How many feet of cord are required to do one rib on a piet
with the conventional method? What is meant by stitch "sides"? Besides, with the
starting knot, a straight needle is required. That makes it easier to get
consistency between needles and to find the hole on the opposite side of the wing.
I found that I was tying enough knots per hour to put some serious wear on my
fingers, so I took a RH glove and cut off the thumb and index finger. That
protected the fingers getting the most abuse and provided the dexterity required
for the thumb and index finger.
Message16 ga. or .063 is correct.
Dale and I weighed our landing gear. Included were the
gear legs, axle, spreader bars, bracing cables, wheels and tires.
Total weight - 60 lbs
Greg Cardinal
To: 'pietenpol-list(at)matronics.com'
Sent: Thursday, March 18, 2004 8:25 AM
Subject: RE: Pietenpol-List: Steel Gage
Dave,
The outside vee fitting in the lower right corner of the of figure 6A is pretty
Skip
17 is 16 gage steel. Even with a magnifying glass it is hard to be sure. Can
As per the Poly Fiber manual, if, after you snap chalk lines, you
"pre-poke" the stitch holes, by sliding the wing toward you , you can
stitch half(front to back) the wing at the aeleron area. From the rear and
then from the front.
The root of the wing can be done with just a little stretching to get to the
center.
Just put the wing on horses instead of a table, so when you put the needle
down thru you can climb under and pull it down and send it back up.
The note in the Poly fiber manual about the light under the wing pointing up
is the answer. Makes the wing invisable, and you can see everything.
including all control cables and drag/anti-drag wires
Funny how the strangest things put up a mental block of jobs to do on
building. :
) (including me)
walt evans
NX140DL
you did some research on what? and it isn't a good idea on what gravity feed system?
Del
Knot2Shabby5TA6(at)aol.com wrote:
DJ:
I did some research on this and if I can find my info, it isn't a good idea on
Del-New Richmond, Wi
"farmerdel(at)rocketmail.com"
DJ
I see in the ebay pic that you had the carb on top of the engine, but I think I
remember that you put it underneath although the 2nd pic doesn't look like a
vair setup. did you run it gravity feed on the bottom and it still didn't want
to run right? I've been thinking about a pressure pump that will work with the
aerocarb. I also noticed that when you had it mounted on top, it is oriented
the wrong direction to the intake tubes to run properly. Its just that mine works
so well that I hate to think that you have to waste your money on an ellison.
I mean, we are innovative people here, who can make a simple vair engine
work, why can't we figure out a little ol' aerocarb. that so many are flying with
already, with good success. the aerocarb may have its thing, but it atomizes
the fuel well, it only has a couple of moving parts, and its ice resistant,
unlike a complex expensive ellison.
Del
DJ
----- Original Message ----- From: At7000ft(at)aol.com
DJ
RH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In a message dated 3/18/04 10:18:48 AM Central Standard Time,
cgalley(at)qcbc.org writes:
<< Interesting idea but why didn't you do several ribs at the same time? One
starter knot and then work up these ribs. With 15 needles you could do 15 ribs
minimizing the switching sides as well. >>
That's the way I did it. I had my 29' wing mounted on vertical jigs in
the living room, dining room and out the back door to the enclosed back porch.
It was pretty easy to access the top and the bottom of the wing. I marked a
5' piece of capstrip with the stitch location, and just went down the wing,
and pencil marked the stitch locations. I think I spliced the chord once for
each rib. A bright light allows you to see inside the wing. Some stitches
had to be moved a little, to avoid some things inside the wing. I think they
were 2 1/2" apart in the prop blast + one rib, and the rest of the wing was 3
1/2" apart. I think I had like 500 stitches total wing.
The wing was a main topic of conservation when I had a visitor. The two
most popular questions were "Are you married?", and "How are you going to get
this thing out of the house?"
Chuck G.
Subject: | Wire/turnbuckles |
The wing plans call for the use of 13 gauge hard wire, and 325 SF
turnbuckles.
Does anyone have a source of supply, or a better description of these
two items?
Dick Carden
After my post from a few days ago I soke with the FAA guy again and Joe Norris
from EAA who will be my DAR. Turns out the FAA supervisor was not clear when
talking to me that this was a plans built experimental and not a kit that was
purchased or such. Joe says I will have to have limitations displayed
arcs, placards and such but technicaly there is no manual required. HOWEVER,
that does fall under good practices and the FAA Advisiorl Circular calls for one
to be developed with anticipated preformance data. Translation, it would
score some points on my side to have something in hand.
I am currently writting an Operations Manual for the Piet. It will be a MS Word
Doc and I will post it when complete. You all can make changes to fit diffrent
fuse lenghts and engines a needed. I was up late last night on it and will
have it in a couple of days. Warning in advance, I simply estimated a couple
of figures and corrections willl be needed.
One piece of info I could use help with is, with a Piet weighing 682 lb and an
A-65 engine, what is the WING LOADING AND POWER LOADING?
Dick N.
Power loading is lbs/hp but it is based on gross weight.
Wing loading is lbs/wing area but it is based on gross weight.
We need to know your gross weight.
Chris
To: pietenpol-list(at)matronics.com
Sent: Friday, March 19, 2004 9:38 AM
Subject: Pietenpol-List: paperwork
one to be developed with anticipated preformance data. Translation, it would
an A-65 engine, what is the WING LOADING AND POWER LOADING?
Dick N.
wing loading is going to be 4.7lb/ft sq. EMPTY. If a 180lb pilot is in it it will
be 5.9lb/ft sq.
Power loading is 10.4 lb/hp EMPTY and 13.2lb/hp with a 180lb Pilot.
All of these figures do not include fuel
DJ
Dick N.
Dick,
To get those figures the gross weight of the plane is needed, you have
to estimate the weight of a pilot and passenger (I dont know if there
is a "Std" estimated weight in USA) also the weight of the gasoline in
full tank(s) and don't forget the engine oil, if not already in the
engine when you got your empty weight.
Saludos
Gary Gower
> Joe Norris from EAA who will be my DAR. Turns out the FAA supervisor
> was not clear when talking to me that this was a plans built
> experimental and not a kit that was purchased or such. Joe says I
> HOWEVER, that does fall under good practices and the FAA Advisiorl
> Circular calls for one to be developed with anticipated preformance
> data. Translation, it would score some points on my side to have
> something in hand.
> be a MS Word Doc and I will post it when complete. You all can make
> changes to fit diffrent fuse lenghts and engines a needed. I was up
> late last night on it and will have it in a couple of days. Warning
> in advance, I simply estimated a couple of figures and corrections
> willl be needed.
> 682 lb and an A-65 engine, what is the WING LOADING AND POWER
> LOADING?
> Dick N.
From: | "Richard Navratil" <horzpool(at)goldengate.net> |
Subject: | Re: Wire/turnbuckles |
I used 3/32" SS 7x10 wire with the stress threads, available at Boat U.S. or
West Marine. Turnbuckles from ASS or Wicks, I dont remember which ones.
Dick
Subject: Pietenpol-List: Wire/turnbuckles
> turnbuckles.
> two items?
> Dick Carden
Subject: | Re: Pietenpol-List Digest: 29 Msgs - 03/18/04 |
In a message dated 3/18/04 11:57:11 PM, pietenpol-list-digest(at)matronics.com
writes:
Bruce __ <bruce___@hotmail.com> wrote:
Don't mind the ranting, Bruce, they don't really understand what they are
doing. Please feel free to contact me any time, either on the list or off.
I did weigh my wing parts, the spars were almost exactly 10 pounds each, made
up of 7 layers of vertical grain Douglas Fir. The ribs for a side (14), were
almost exactly 5 pounds for the lot. This weight total suggests to me that
there wouldn't be much difference in the flying weight no matter which woods you
use. I chose DF because there is a lot of very good stuff available, and I
did not like what I looked at, at AS&S. If the two wings weigh 50 pounds (wood
structure), and the Center Section weighs about 10, this means that there is
about 90 pounds available for hardware, fabric and paint, to keep to the 150
pounds Bernie sugggested. Carl L @ Compton Airport
Subject: | 4130 availability |
There was a question here about availability of 4130 sheet. Be aware that
steel prices are completely out of control at the moment, in all areas of
the market. Not to go out and scare anyone, but if you're in the process of
putting together a list of materials for your project and you're anywhere
close to getting it finished, I'd suggest ordering your materials (steel
stock) right now. Commercial vendors are only honoring price quotes on
steel for max of 5 days, so it's a very volatile market right now. Steel
has increased in price about 40% over the last 90 days.
Or you could avoid the panic, sit back and think about it, and let this
"crisis" pass like they all seem to! That would be the Pietenpol "low and
slow" style, eh?
Oscar Zuniga
San Antonio, TX
Subject: | Re: 4130 availability |
Or go Aluminum, it's still affordable, and the stress conversion charts
readily aval.
> slow" style, eh?
> Oscar Zuniga
> San Antonio, TX
In a message dated 3/19/04 11:39:10 AM Central Standard Time,
ANNCARLEK(at)aol.com writes:
<< If the two wings weigh 50 pounds (wood
pounds Bernie sugggested. >>
I thought B.H.P. said the wing should weigh about 90 lbs. This would be the
one piece wing.
Chuck Gantzer
Dick,
The 325 SF is an obsolete designation. Perhaps you could find
them in an old (1920's era) Nicholas-Beazley catalog but they
are not available today. Hard wire is still available, 13 ga. would be .090.
Finding the "correct" wire can be a challenge. Some call it piano wire,
others call it
music wire. These are generally too stiff to use. Chris Bobka has done
a lot of research on wire; he would be a good resource to ask.
The common practice today is to use 1/8" cable and -22 turnbuckles.
Greg Cardinal
> turnbuckles.
> two items?
> Dick Carden
Subject: | inexpensive goggles |
If anyone is interested, here's a site for inexpensive "over the glasses" goggles.
http://www.kroop.com/
walt evans
NX140DL
Dick..I got my solid wire from McMaster-Carr. They have a catalog on the web
and their Atlanta phone number is 404/364-7000. They also have a printed
catalog which is over 2" thick which they won't mail to a residence...only
companies. The wire I got looks just right..low gloss, uniform and appears to have
the
right softness/hardness. Music wire is way too hard for this purpose. The
product description is as follows: Type302/304 stainless steel soft temper wire
.081" dia., 1-lb coil, (52') $8.14...Carl Vought...Huntsville, AL
Heres a link to some pictures of our tail brace wires. These are the same as
suggested for the wing brace wires by Carl Vought, except we chose 403
stainless wire.
http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID=143
Terry B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Thats a good point DJ. I was not aware of there being a cable-eye type. I
was wondering why these didn't have the smooth radius like they needed to have.
There was a slight radius, maybe .025. So before we made up the ends, I
worked each one over a bit with a small round file to break the radius a little
more. Next time, I will order the AN-170.
Terry B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Subject: | cub lift struts on ebay |
Zm91bmQgdGhpcyB0b2RheS4uLi4NCg0KaHR0cDovL2NnaS5lYmF5LmNvbS9lYmF5bW90b3JzL3dz
L2VCYXlJU0FQSS5kbGw/Vmlld0l0ZW0mY2F0ZWdvcnk9MjY0MzkmaXRlbT0yNDY3NTc1NzM0DQoN
CkkgdGhpbmsgaGUncyBhc2tpbmcgYSBiaXQgdG9vIG11Y2ggYnV0IG1heWJlIGlmIHNvbWVvbmUg
d2FzIGludGVyZXN0ZWQgdGhleSBjb3VsZCBlbWFpbCBoaW0gZGlyZWN0bHkgYXMgc3RyaWtlIGEg
ZGVhbC4NCg0KREogVmVnaA0KTjc0RFYNCk1lc2EsIEFaDQp3d3cuaW1hZ2Vkdi5jb20vYWlyY2Ft
cGVyDQoNCg0KDQotDQo
<006201c40fa7$fb06abd0$d2a86d44@Desktop>
Subject: | Re: cub lift struts on ebay |
Got mine from the rafters of a local airport. Was put up to it by another homebuilder.
There were hundreds of them. Didn't want to just take them, so went
to the Mgr and made a deal. After cutting off the top and bottom, the visual
inspection showed they were clean. sure beat $15.00 per foot for new.
walt evans
NX140DL
Sent: Sunday, March 21, 2004 7:52 PM
Subject: Pietenpol-List: cub lift struts on ebay
found this today....
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category26439&item2467575734
I think he's asking a bit too much but maybe if someone was interested they could
email him directly as strike a deal.
DJ Vegh
N74DV
Mesa, AZ
<006201c40fa7$fb06abd0$d2a86d44@Desktop> <000c01c40fb5$9e18a910$2cc5fea9@home>
Walt,
I need to drive my honda from CT to MN in the fall. Do you think you can set me
up with a set of struts when I come through?
Chris Bobka
Sent: Sunday, March 21, 2004 8:30 PM
Subject: Re: Pietenpol-List: cub lift struts on ebay
February 26, 2004 - March 21, 2004
Pietenpol-Archive.digest.vol-dt
