Pietenpol-Archive.digest.vol-ed
October 06, 2004 - November 01, 2004
table,
to prepare for the lightweight fiberglass application. Cut four pieces
of
fiberglass big enough to cover and overlap the leading and trailing
edge, and the
tip. Lay newspaper under the blades to control the resin that is going
to
drip off the blades. The fiberglass should go from the root, almost to
the hub,
and extend the full length of the blade. This protects the wood,
stabalizes
the moisture content in the wood, and keeps the Kevlar from coming off
with
centrifugal force. Do one blade face at a time, and make sure you have
100%
saturation, and have a smooth surface. Once the fiberglass is
saturated, the fine
cloth completely disappears, and the only thing you see is the yellowish
green color of the Kevlar strands. Again, speed is the key, once the
hardener is
added to the resin. Keep it straight by a dabbing action with a one
inch
paint brush with half the bristles cut off. Use cheap bristle brushes,
and
discard the brush after each application...it's just not worth trying to
clean it.
Allow the cloth to overlap the edges, and trim them off with a razor
blade
after it sets. Finish sand to blend the edge of the fiberglass. Flip
the prop
over and repeat the process. After the resin cures for a few days, give
it a
beautiful glossy shine with a couple of coats of Ace Spar Varnish, gloss
#16375. Use the varnish step to attain a final balance, by adding an
extra coat to
the light blade.
To build the 3 props that I have done so far, my main instruction
was
talking with experienced folks in the area of building propellers. I
also used
the drawing of the prop for the Model A engine, that Orrin Hoopman drew
up
dated 3-3-33. It is 76 X 48, but I think it certainly has too much
pitch for the
ol' Model A engine. I think Ken Perkins runs a 76 X 42, which allows
the
engine to run up to the rpm where there is quite a bit more power. My
other main
instruction is referenced on this drawing to the book by Eric Clutton
called
'Propeller Making for the Amature', available through the EAA. The
Hoopman
drawing, and the book by Clutton, show how to use an X Y chart to
determine the
blade angle at each 6" station. His book is the only reference I've
ever
seen to a True Scimitar Prop design, which I plan on building. Although
I still
haven't found anyone who actually built and tested one, and the theory
sounds
good, the challenge would be in the design location of the mass.
With the blade installed and torqued, the blade track must be well
within
1/8". I try to get mine within 1/16".
That's how I finish off my bug whackers !!
Questions ?
Chuck Gantzer
NX770CG
weekend weather is looking like the back side of a front - beautiful
flying
weather !!
Subject: | Re: serious smoke advice (now Tomahawk) |
I am so sad to hear about Bob. I didn't know of his
illness. I had not met him personally, but I knew of
him through ICAS (International Council Of Airshows)
the trade organization for airshows. I have always
been impressed with his flying. He certainly ranks up
there with the great preformers and not doubt, had he
lived, could have been one of the greatest. My
personal experiences were much less dramatic in the
airshow business. I was always the generic act :). I
only flew airshows for five years and it takes that
long or longer to build up a reputation. I avg.
around 12 shows per year. I flew under the trade name
of "Shooting Star Airshows." I had three people in my
troop; a long dear friend of mine wiith whom I served
in police work with a number of years ago who acted as
my announcer and his wife the lovely Jeanne who acted
as manager. I really miss the airshow business and
had a great time while flying the circuit. You meet
so many interesting people at airshows. I have flown
on the same stage with the former "Eagles" in one of
my first airshows. Those were a great bunch of guys.
I have flown with Bobby Yonkin, Gene Littlefield, Jan
Jones and a number of others. I sure miss the circuit
and miss the people I had once known. Again, I am
sadened to hear of Bob Sears. The aviation world sure
took a hit when Bob passed away. Thanks for sharing
your story with me. I will try to drag up an old
photo of my airshow days and try to get my scanner
hooked up and I will send a pic if you would like to
see it.
Doc
--- N321TX(at)wmconnect.com wrote:
> A very dear friend of mine by the name of Bob Sears
> introduced me to inverted
> flight in a Decathalon. Bob was a commercial pilot
> and CFII and the
> adventurer I took my flights into Mexico and Central
> America. (Plenty of stories for
> these trips, no time to explain.)
> Bob used to fly in various air shows in the late 80s
> and early 90s and
> actually flew in a few events that some really
> topnotch performers appeared in. The
> first show I went to with Bob was in Lakeland,
> Florida, where Bob flew a Super
> Viking as the Avenger.
> He developed a routine especially for kids and was
> actually dressed up like a
> super-hero. After his routine in the Super Viking,
> he would hand out pictures
> and autograph them for hundreds and hundreds of
> kids. He introduced me to a
> handful of airshow pilots and among the most
> impressive (personally) was Patty
> Wagstaff and her husband.
> Bob had four airplanes he flew in different
> airshows, to include a 300 HP
> Pitts Special. I never saw anyone do in a Pitts,
> what Bob did and he was a legend
> at the ABQ Balloon Festival when he flew is Pitts
> upside down in a drainage
> canal. From the audience perspective, it was quite
> alarming to see him do this
> because he appeared to look like he flew into the
> ground. The audience could
> not see the canal and it was startling to see him
> disappear into the canal.
> He also flew his Pitts upside down through a WWll
> hanger near Monahans, TX.
> The hanger was very large and part of a training
> base for B-17s. It was
> abandoned and simply out in the country as a vacant
> building. I'll try and find a
> copy of Bob flying upside down through the hanger so
> I can scan it and send it
> out on e-mail.
> The least impressive upside down flying was done in
> his Decathalon and he
> practiced his routine at his (Sears, DFW Sectional)
> ranch, not too far from my
> place, (5TA6, Knot-2-Shabby, San Antonio Sectional).
> I proudly can say I never
> blew chow on the three occasions I did with him in
> his Decathalon when he was
> practicing out here in the boon docks, but it hurt
> like the devil. The harness
> really digs in to the shoulders (at least for me,
> when holding a camcorder).
> Wanna see my video from inside the Decathalon,
> upside down? I still have a copy
> around here somewhere. He clipped ribbons on poles
> as he flew upside down
> about 25 feet off the ground.
> Bob also had a Yak and he was working on a routine
> for that, but be became
> ill from lymphoma and he died in 1995. I think had
> Bob not become ill, he would
> have made the airshow circuit in a very big way. His
> flying skills were
> extraordinary and he made friends where ever he
> went. He really made an impression
> with kids as the Avenger in his Super Viking and one
> interesting note for
> Pietenpol folks... Bob especially liked the Super
> Viking for aerobatics because it
> was made out of wood and gave him the strength he
> needed for the budget he had
> in finding an airplane that looked cool for kids. A
> black airplane with red
> and yellow lightning bolts.
> S.B.
Declare Yourself - Register online to vote today!
http://vote.yahoo.com
Subject: | Cub Brake Master Cyl |
Dear Group,
Has anyone used J3 Cub master cylinders on their Piet? If so....do you have pictures
of them installed?
I finally came up with a RH master cylinder and so I now have a complete J3 cub
brake system. I am going to look tonight and see if it looks like I'll have
room to locate them under the front seat. I have rudder pedals in lieu of the
rudder bar.
Terry L. Bowden
ph 254-715-4773
fax 254-853-3805
Subject: | Aileron rib build questions |
Build the entire aileron including from trailing edge forward, Trailing edge,
aileron spar, aileron leading edge and trailing edge aileron pocket "spar" as
per plan before cutting the ribs that make it part of the wing. You can eve install
the 1/4x1/4" fabric spacers before cutting out the aileron. This will
make it nearly impossible for a bad fit. I used a piano hinge instead of the
barn door hinges, just to seal the aileron gap.
Steve e
From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Textor, Jack
Subject: Pietenpol-List: Aileron rib build questions
Hi guys,
Only found two comments in the archives on this one, looking for some additional
comments. I'm building the 3 piece wing and currently building the ribs. I
want to plan correctly for the aileron ribs. It appears I will need to "modify"
6 ribs for each aileron. I plan to build the ribs the same as the rest and
make the cut =BC inch behind the last upright. Does this sound right? Also
should I build in place like Bernard recommends? Does that include doing the
trailing edge and aileron spars before making the cuts? And...on the non-aileron
ribs should I gusset the bottom of the last upright in front and behind the
upright? That's about clear as mud. I included a couple of pictures which
might help.
Thanks!
Jack Textor
Des Moines
Sears
Subject: | Re: serious smoke advice (now Tomahawk) now Bob Sears |
One last thing I forgot to mention about Bob Sears. His dad was a P-51
fighter pilot during WWll. Bob's dad had several kills and he was the only P-51
pilot that actually shot down a German airplane, while the P-51 was still on the
ground. Story goes that the airbase was being attacked by Germans and Bob's dad
jumped in his parked P-51, fired it up and while taxing out to the runway,
saw a German airplane flying low straight at him. Mr. Sears fired his guns and
got the SOB that was trying to shoot him.
Makes me feel like a woosie, having been a guy whose first airplane was a
Tomahawk. (But then again I did fly right seat in a B-52 once.)
Subject: | Re: N74DV's first passenger |
I've driven down DJs street a couple of times. That street ain't real wide!
Must have been a hoot to see DJ "driving" around on his block and I suspect
the cop could not have written a "speeding" ticket for a highly modified Corvair
without a tag.
"Corvair engines for homebuilt aircraft"
If he complained that you were weaving,,,Just tell him " That's the only
way to see around the nose of a taildragger while taxiing , Sir"
walt evans
NX140DL
great story!!
----- Original Message -----
Subject: Pietenpol-List: N74DV's first passenger
> DJ
> www.imagedv.com/aircamper
> _
From: | "Carl D. Vought" <carbarvo(at)knology.net> |
DJ got something else out of that ride...besides a lot of laughs. Did you
pick up on the extrodinarl level of confidence and trust in DJ that the
child's mother demonstrated?...Carl Vought
wide!
suspect
Corvair
> without a tag.
From: | "Jack Phillips" <pietflyr(at)bellsouth.net> |
Subject: | First FLight of NX899JP |
Another Pietenpol has been added to the sky. NX899JP, "IcarusPlummet", flew
for the first time this morning. Everything went fine - plane flew hands
off with no problems noted. Engine ran strong and all in all it flew just
like a Pietenpol should. I'll try to post some pictures later.
Many thanks to the many contributors to this list who have given me advice,
help and encouragement over the years I've worked on this airplane. I'll
see y'all at Brodhead next July (if I can figure out how to get it over the
Appalachians).
Jack Phillips
Raleigh, NC
Subject: | Re: First FLight of NX899JP |
Congratulations Jack! The first flight in any
airplane, and even more so in one that you built, has
to be one of the greatest experiences in life. Glad
all went well and see you at Broadhead.
Doc
--- Jack Phillips wrote:
> Phillips"
> pictures later.
> this airplane. I'll
> Appalachians).
> Jack Phillips
> Raleigh, NC
> Contributions
> any other
> Forums.
> http://www.matronics.com/chat
> http://www.matronics.com/subscription
> http://www.matronics.com/FAQ/Pietenpol-List.htm
> http://www.matronics.com/photoshare
From: | "Ed Grentzer" <flyboy_120(at)hotmail.com> |
Congratulations Jack...That is really awesome news...Glad to hear
everything went well...See you at Brodhead...Ed G.
>From: "Jack Phillips" <pietflyr(at)bellsouth.net>
>Reply-To: pietenpol-list(at)matronics.com
>To:
>Subject: Pietenpol-List: First FLight of NX899JP
>Date: Wed, 6 Oct 2004 19:11:35 -0400
>flew
>Appalachians).
>Jack Phillips
>Raleigh, NC
Sears
Flying in a Tomahawk dosen't by any means make anyone
a "woose." My first hours of instruction were in the
docile Cessna 150. Airplanes just don't get any
easier to fly than that little puppy. Bob's dad
sounds like quite a guy. As was his son. Guess it
ran in the family. Great story, should be made into a
movie.
Doc
> His dad was a P-51
> B-52 once.)
CONGRATULATIONS JACK.....
YEEEEEEE-HAAAAAWWWW!!!!!!!!
Looking forward to the pictures and hope to dhead next year.
Terry B.
From: | "Richard Navratil" <horzpool(at)goldengate.net> |
Subject: | Re: Aileron rib build questions |
I completely agree with Steve E. I also used alominum piano hinge. Do it all
before cutting.
Dick N.
Sent: Wednesday, October 06, 2004 12:21 PM
Subject: RE: Pietenpol-List: Aileron rib build questions
install the 1/4x1/4" fabric spacers before cutting out the aileron. This will
Steve e
Sent: Wednesday, October 06, 2004 10:03 AM
Hi guys,
I want to plan correctly for the aileron ribs. It appears I will need to "modify"
and make the cut =BC inch behind the last upright. Does this sound right? Also
trailing edge and aileron spars before making the cuts? And.on the non-aileron
might help.
Thanks!
Jack Textor
Des Moines
Great going Jack. It's an amazing feeling the first time around and so far
for me at least the feeling hasn't worn off.
Dick
> flew
> advice,
> the
> Appalachians).
> Jack Phillips
> Raleigh, NC
Like Steve E. & Dick N. said, build the entire wing and aileron as an
assembly, including pre fitting and drilling the holes for the aileron hinges.
The
wing should be complete, before you cut the ailerons loose. I used the plans
type barn door hinges, but replaced the aluminum hinge pin, with AN hardware.
The AN hardware I used was a screw with a long enough shank to go all the way
through the hinge, cut the threads off, and drill a small hole for a cotter
pin. Use a small flat washer under the cotter pin. I bridged the aileron gap
with 3" fabric, before any paint was applied.
Chuck G.
Subject: | Re: Prop - Kevlar Tipping and Fiberglass Wrap |
In a message dated 10/6/04 11:09:04 AM Central Daylight Time, steve(at)byu.edu
writes:
<< One more questions Chuck, did you carve out the wood for the leading
edge and fill in with the Kevlar or just lay it over the le blade as is? >>
Steve,
The Kevlar is just a very thin one ply of fibers, and I just laid it right
over the leading edge of the blade, and made it about 3/4" wide. I suppose you
could sand away a very slight amount of wood, and make it back up with the
Kevlar and Fiberglass. Lay it even on the front and back of the leading edge,
where the blades get the most abuse. Blend it in before you put the fiberglass
on the front and back, and the transition of the edges of the Kevlar blend
right in, and you can't even feel the edges.
Chuck G.
A BIG Congratulations, Jack !! Certainly a milestone !!
And I'm sure you'll find your way through the Appalachians to get to Brodhead.
Chuck G.
From: | "Chet's Mail" <chethartley1(at)mchsi.com> |
Good job on building and your first flight. Chet Hartley
Congratulations Jack. Send pictures soon.
Alex Sloan
> Appalachians).
> Jack Phillips
> Raleigh, NC
Alex Sloan
From: | "Michael Conkling" <hpvs(at)southwind.net> |
Subject: | Re: Ken's Piet was serious smoke advice |
And it flies nicely with a passenger!! ;-) (I got my ride in it this year
at Brodhead -- total crew weight was at least 375# -- you decide how that
was split up! ;-)
Mike C.
Pretty Prairie, KS
Subject: Re: Pietenpol-List: serious smoke advice
> I took some photos of Ken's plane (see attachments).
> I really like that Ford installation.
> Doc
HAHAHA...I'm not even going to try to figure it out.
It is a neat little airplane and seemed to have a lot
of thrust. The engine ran so smoothly too. I'm sure
Ken can build me an engine just a good. My Piet may
be a little heavier than his though. Try as I may, I
still want to make it a little "G's" proof. But it
probably won't be more than 5 or six pounds heavier (I
am already on a diet :).
Doc
--- Michael Conkling wrote:
> Conkling"
> was split up! ;-)
> Mike C.
> Pretty Prairie, KS
> From: "Galen Hutcheson" <wacopitts(at)yahoo.com>
> To:
> Sent: Tuesday, October 05, 2004 10:23 PM
> attachments).
> > Doc
> Contributions
> any other
> Forums.
Yeah, just follow the "Yellow Brick Road" or better
yet a set of railroad tracks that point toward the
direction you want to go. They always follow the
lowest terrain. But look out for those tunnels or you
could have a clipped winged Piet. :)
Doc
> milestone !!
> Chuck G.
> Contributions
> any other
> Forums.
Subject: | Re: homebuilt power |
<00b901c4aa7f$3ec14ac0$0100a8c0@Desktop>
OK guys. I'm sorry, but I have to put this right,being a
born Canuck and all. This right from the horses mouth.
" We don't care what you do to yourself as long as you
don't endanger anyone else."
We've had the equivalent of your new LSA for many years
and it didn't have to go through fifty million committees to
get passed. Yes there was a lot of work and study by gov,
industry and our representatives ( RAA ) but our gov was a
lot more easily receptive to the concept.
We have been completely self governing, including inspections,
for many years, through the RAA, the Recreational Aviation
Association, of which I am a member. Inspections have now
been split off on it's own but still RAA members, not gov.
Yes we have to have a license for all flying levels, including
basic ultralight but again, that's so that all such pilots know
the rules of the road and don't get themselves injested into
some 737's left engine. That could happen very easily in the
Vancouver airspace. So it's a good thing and not a big deal.
We don't have medical requirements for drivers licences so
a self declared medical with a signature from your GP is all
that is required. Carrying passengers is what ups the anti to
a regular medical.
In fact, now that your LSA and LSP are now in force there
is some concern here that our advanced ultralight rules may
become more restrictive to align them with yours to facilitate
cross border flying, sales, purchase, etc.
Clif
PS, Our third oldest registered homebuilt, a jodel, now up
for sale, was registered in 1957. The first is a lot older and
we had our share of Heaths and Piets in the 20's and 30's.
Aint no forbidding here! :-) :-)
> hmmm... kinda like the Canadian Gov't does?!
> DJ
> Can you even imagine how far
> > aviation would have advanced had the governments of
> > the world forbade the common man to experiment with
> > airplanes. Probably we would all still be dreaming of
> > flying.
> > Doc
From: | Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov> |
Subject: | This one is really nice----First Flight of NX899JP |
Our hats are off to you, Jack for sticking with it and going all the way
with your new Pietenpol Air Camper.
I've seen photos over the years you've sent me and look forward to seeing
it in person. You'll no doubt
attract more Pietenpol builders with your excellent workmanship and setting
the quality standards where they should be.
Way to go !
Subject: | Re: Fuel strainer mesh |
Corky,
How much do you need?
I have some and can send you some; would a 3" or 4" square be OK?
Lou Larsen
Thanks Lou,
But I received a 12x12 inch piece from McMaster which should last through all
my needs. Probably will be able to send you or someone else some from
leftover.
Corky
Jack, congrats!!
What engine did you use?
--- Galen Hutcheson wrote:
> Hutcheson
> you
> Doc
> Rcaprd(at)aol.com
> > milestone !!
> > Chuck G.
> > Contributions
> > any other
> > Forums.
> Contributions
> any other
> Forums.
Larry Nelson
Springfield, MO
Beechcraft Bonanza V-35B N2980A
Pietenpol Air Camper N444MH
1963 GMC 4106-1618
SV/ Spirit of America
ARS WB0JOT
I, too was confused by the comments about our (Canadian) regulations.
Maybe you were thinking about the UK, DJ. (LMNOP)
-----Original Message-----
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Clif
Dawson
Subject: Re: Pietenpol-List: homebuilt power
a regular medical.
Clif
> DJ
> > flying.
> > Doc
Congratulations! What's the story behind the unlikely name, in case I
missed an earlier post?
Mark Hodgson
From: | "Oscar Zuniga" <taildrags(at)hotmail.com> |
Subject: | William Wynne: CC#8, Engine for sale, hangar gang photo. |
Howdy, low and slow fliers; if this was already posted I apologize, but here
is some information from William Wynne on upcoming "Corvair College" No. 8
as well as other info that he asked be passed along.
Oscar Zuniga
San Antonio, TX
Subject: CorvAircraft> Re:CC#8, Engine for sale, hangar gang photo.
Date: Thu, 7 Oct 2004 08:27:26 EDT
Friends,
Grace rewrote our home page last night with several new entries,
FlyCorvair.com has details on CC#8, An engine we built which is for sale,
and some new information about what we do in the hangar and why we do it.
If your on the 601, KR, D-fly, Q or Piet lists, please take a moment to
share
this with others.
Thank You,
William.
PS: DJ, I expect to see you on the TV show "COPS", I will write the
producers
and ask for a "dramatic reenactment."
Subject: | Hard Wire Rigging |
As most of you know, the Hoopman plans call for "hard wire" for bracing the
tailplanes of the Pietenpol. I found some stainless steel "soft" wire
of .080" diameter at Macmaster's and I'm in the process of installing it. I
keep having this nasty little feeling that the way I'm going about
terminating the wire in places like the turnbuckles or the "fittings" is
the sort of thing an inspector would jump all over. I've looked in the
references I have here and nobody even mentions solid wire. I have been
unable to convince myself that the thimbles I've used on stranded cable
elsewhere in the airplane (wing bracing and aileron control)just don't fit
in with the solid wire, so I wind up with the solid wire in direct contact
with the steel fittings or the turnbuckles. If there is someone out there
who would give me the benefit of their experience in this area, I would be
very grateful...Thank you...Carl Vought
Subject: | oil & oil temp questions |
The manual for the A-65 engine calls for 40w oil summer and 20w winter. Would
there be a problem with running Aeroshell 15w-50? I dont know anything about
oil science.
Also, I have noticed that my oil temp has dropped since air temps are going down.
I'm wondering if it might be a good idea to make some baffle plates for colder
temps? I know that running to cold can cause carbon build up and increase
the chance of fouling plugs while making power changes. I'm thinking of a
couple of perforated plates that would lay on top of the cylinders, inside the
eyebrows. I dont plan on extreme cold flying but it would be nice to get out
on good days.
Dick N.
oil science.
on good days.
Dick N.
Subject: | Re: oil & oil temp questions |
Dick,
In all my small Continentals I used Aeroshell 80 in
the winter and Aeroshell 100 (both with Marvel Mystery
Oil in the crankcase) in the summer with good results.
I always do frequent oil changes to prevent sludge
build up. I'm sure others have some good suggestions
also.
Doc
> summer and 20w winter. Would there be a problem
> about oil science.
> since air temps are going down. I'm wondering if it
> colder temps? I know that running to cold can cause
> carbon build up and increase the chance of fouling
> the cylinders, inside the eyebrows. I dont plan on
> on good days.
> Dick N.
Subject: | Re: Hard Wire Rigging |
Carl,
Thats the way we did ours... .080 stainless 304 solid wire from
mcMaster-Carr. I have seen lots of Piets done this way. Heres a link to a pic
of ours.
http://www.mykitplane.com/Planes/photoDisplay.cfm?PhotoName=CF0004.JPG&
PhotoID=1959
Terry B
I should have added that my reason for asking is that I sold my Seneca and
have some 15w-50 left over. I'd like to use it up.
Dick
Subject: Re: Pietenpol-List: oil & oil temp questions
> Dick,
> also.
> Doc
>> about oil science.
>> on good days.
>> Dick N.
In a message dated 10/7/04 6:23:45 PM Central Daylight Time,
horzpool(at)goldengate.net writes:
<< Also, I have noticed that my oil temp has dropped since air temps are
going down. I'm wondering if it might be a good idea to make some baffle plates
for colder temps? >>
Dick,
I have the same concerns. My oil temp hardly gets above 140 on the cooler
days. I think that's not hot enough. I'm curious what others have done.
When it's below 50, I dress warm, and I can get at least 4 or 5 circuits in
the pattern before my body heat is all gone !!
Chuck G.
Chuck
I put in 2.5 hr last Tue at 45 deg. I was mighty cold. My wife was nice
enough to make a cover for the front cockpit. I'm going to install cabin
heat and remember to throw the long undies into the truck.
I'm also remembering to throw in the shotgun in also. The last few times I
went to the airport it was too windy to fly, it became a grouse hunting day
instead.
On the oil thing, I have been running about 140- 150 deg on a 70 deg day.
Last week the temp barely came up.
Dick
> plates
> Dick,
> cooler
> in
> Chuck G.
Hey Chuck,
I used to fly the old Bird biplane in the winter and I
wore a snowmobile suit. Works pretty good too.
Insulated boots and gloves and you can get right cozy
in open cockpit. Coldest days a ski mask works too.
Doc
> Daylight Time,
> since air temps are
> Dick,
> Chuck G.
> Contributions
> any other
> Forums.
Continental A65.
Jack
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Larry
Nelson
Subject: Re: Pietenpol-List: First FLight of NX899JP
Jack, congrats!!
> Hutcheson
> you
> Doc
> Rcaprd(at)aol.com
> > milestone !!
> > Chuck G.
> > Contributions
> > any other
> > Forums.
> Contributions
> any other
> Forums.
Larry Nelson
Springfield, MO
1963 GMC 4106-1618
ARS WB0JOT
Subject: | hard wire rigging |
Regarding the use of "hard wire" for rigging, as per the old Piet plans,
there has been much back-and-forth discussion of that over the years. Most
of it is along the lines of "we have much better, modern stuff these days"
and will tell you not to do it. However, looking through the great majority
of details in the old Flying & Glider Manuals will show that they use wire
with twisted "ferrules" almost exclusively.
In the archives on the BPA site somewhere (the Grant McLaren site), is an
article on making a tool to form the wire ferrules. It also shows how to
properly install them. Again, you'll probably hear considerable nay-saying
about this and maybe also about how a ferrule with a round inner shape does
not properly secure the profile of two wires side-by-side and that the
ferrule needs to be flattened for proper installation. I don't know about
all that but I had planned to make one of those ferrule-and-loop tools and
get a spool of wire from McMaster, make up a representative samples using
wire ferrules vs. conventional thimble and aircraft cable, and test them
both to failure. Many of the nay-sayers express concern about hardening,
embrittlement, and/or fatigue of the wire where it forms the ferrule and
eye, and that would no doubt be the point of failure. I just don't believe
they would fail at any loading lower than would occur at the point of
connection of the tab that connects the wires to the wood framing of the
stabilizers, or of some of the other construction points.
For the really authentic old-time look, the wire bracing is really
interesting to me and I believe it can be done safely and adequately using
the right tools and methods. That, however, is my own personal opinion and
is completely NOT flight tested!
Oscar Zuniga
San Antonio, TX
Subject: | Re: hard wire rigging |
Oscar-- my feeling has always been that the wood structure will fail long
before any cable/turnbuckle/hard-wire support braces would.
I think either cables or hard wire are fine back there. If you want the
original look, learn and do the hard wire deal, if not don't use
anything more than 3/32" cables back there or you'll be adding weight where
you don't need any more strength.
Mike C.
List;
Sorry if I sounded a little harsh with my last post about hard wire bracing
and ferrules. As an engineer, I'm usually more logical, analytical, and
unemotional about these things. Let me rephrase my earlier comments by just
saying that there are some excellent posts in the archive on this, such as
Greg Cardinal's one from 2/28/01 explaining his investigations and comments.
He also references an early paper on various wires, cables, and
connections (available as a NACA report but you have to search for it with
Google and get it off a British technical paper site. I just printed it out
moments ago myself).
The bottom line is that the typical wire and ferrule method produces
connections that aren't as strong as the wire itself. My point was that
that may be plenty strong enough and probably stronger than other links in
the chain. Greg's bottom line was that pull testing should be done.
I haven't done that, but it should be very easy to do.
Oscar Zuniga
San Antonio, TX
Its hard to close up airflow around the engine case on an "exposed cylinder" cowl.
Some how the airflow needs to be blocked around the engine case for winter
flying in these continentals. We have this problem on the '39 T-craft. I noticed
some of the Piet builders have done a more meticulous job of fitting the
cowl around the engine nose than others. Perhaps these are the guys up north.
I noticed especially that Steve E's cowl seems to block a lot of air from
the engine case area than ... say... a J3 type nose cowl. Check out the attached
pictures to see what I mean. I couldn't find a good picture of Mike Cuy's
cowl. I seem to recall it does a better job of blocking air around the engine
case. Mike..Steve... have you had any cold-weather low oil temp problems?
Terry L. Bowden
ph 254-715-4773
fax 254-853-3805
Subject: | Re: Weight and Balance Fun |
Yes, I am still messing with the weight and balance
issue for N444MH. I have opened up the treasure trove
of boxes I got when I bought Howard Hendersons Piet
from Joe Santana. (I have a TON of newsletters to go
through, WOW!!)
I did find Howards original weight and balance calcs.
I took his work and made an Excel spreadsheet. Howard
used the firewall as datum, and then made an
adjustment in the form to locate the CG from the LE of
the wing.
Here are my conclusions:
It is a given that with full tank and one skinny FAA
type 175# passenger, Howards CG was 20.4 aft of the
LE.
Inserting an obese 222# person moves that CG to 21.2
aft of the LE. Am I correct to assume that is about
1.2" too far aft? As I burn fuel off to 12# of fuel,
the CG moves to 21.1" aft of the LE.
Moving the wing (and the weight and moment of the
fuel) back 2 creates a CG at 19.3 aft of the CG.
Consuming fuel down to 12# moves the CG to 19.1# aft
of the CG
Am I on the right track here? Where have I erred? I am
about ready to move the wing back about 1.5" and fly
the old girl.
Larry Nelson
Springfield, MO
1963 GMC 4106-1618
ARS WB0JOT
Terry-- I have not had any low oil temp problems that I know of. Here are
two photos, one courtesy of Corky, the other my cowl.
Jack Phillips and I have very similar cowls, Frank Pavliga, Steve E. Most
planes like a Champ, Piet have a hole just below the prop
to cool the engine case in the summer and then duct tape over that in the
winter. There are some places (univar, Wag RipOff, etc.)
that sell insulated "jackets" or coats that snap over your oil tank to keep
it warmer in the winter.
My oil temps in the summer run about 170 to 185 or 190 at the most.......in
the winter on say a 40 F day they run about 120-140, depending
on how long I can stand it to let it warm up.
Mike C.
Larry-- you are on the right track. Move the wing. It will fly mucho better.
I have flown mine near the 19" aft of CG limit when low on fuel and it
feels "greasy". Does that
make any sense. Like a car on snow covered roads where you think you are
in control but sometimes
not.
They just fly weird when they get towards the aft CG. Flaring takes very
little as the nose wants to come up pronto.
The thing even cruises in a tail low position and you have to hold forward
stick to keep from climbing.
If all goes well you should be able to use the same X brace cables and
turnbuckles after you tilt the wing back.
Go two inches and have it over with:))
Larry,
Instead of relying on the weight numbers taken from years ago, I recommend that
you go ahead and weigh the airplane for yourself. You never know what items
could have been changed since then. Probably not much....but you still never
know.
For safety's sake...
Terry L. Bowden
ph 254-715-4773
fax 254-853-3805
Larry there are some much more simple solutions than moving the wing. You
simply need enough ballast in the form of bags of lead shot or sheet of lead
in a secured position somewhere forward of the empty plane's CG.
I've got a Cozy IV. The damn thing will fall over on it's rear prop unless
you put 40# in the nose area. The min. front seat weight is 250#. Some FAA
skinny guys 170# guys have to tote around an extra 20# of lead shot out in
the nose so they can fly alone. So ALL IS NOT LOST.
Number one chore- Go thru the procedure that was outlined in earlier
posting. Find out exactly where the loaded CG is with you and a full tank
of fuel. Using the LE of the wing as datum. Mark that point on the wing.
Your wing should have a chord of approx. 60". Your loaded CG (you and a
passenger) with an empty gas tank can never fall back of 33% of chord or 20"
behind the LE of the wing.
Now set a limit for your plane for how much weight you're gonna allow in the
front seat and how much the pilot has max. can weight. For example 200#
passenger and #250 pilot. Plus 20 gallons of fuel at 6 #/gal, does this
exceed you Gross max weight on your certification. You have to place
limits. on each group of things. Baggage, passenger, fuel, pilot, stuff
etc.
NOW- and only after you've collected the data you need above. Calculate
where and how much ballast you'd have to put somewhere secure in the engine
compartment or in front of the fuel tank or anywhere out in front of the LE
of the wing. In order to assure, when you're at max. passenger weight and
you're at max. pilot weight and you've got empty fuel tanks. You never ever
have that loaded configuration GC slid back behind the 20" from LE.
Remember as you are flying along with max. fuel, as it burns off, you're
loaded CG is sliding back toward the 20" mark.
NOW- determine if your new loaded configuration of ballast plus fuel plus
people puts you loaded CG in front of 25% of chord, or 15" from the LE.
Fully loaded. This number is a little more flexible and could be 20-25% due
to the authority of your horizonal stab and your elevator. IF your elevator
can't lift the nose off the ground at normal takeoff speed, then it's not
got enough authority. You'll have to give up a some ballast and some max.
pilot weight.
All is not lost.
"The whole aim of practical politics is to keep the populace alarmed, hence
clamorous to be led" ; )...................Mencken
Gordon Bowen
Subject: Re: Pietenpol-List: Weight and Balance Fun
> through, WOW!!)
> the wing.
> type 175# passenger, Howards CG was 20.4" aft of the
> LE.
> Inserting an obese 222# person moves that CG to 21.2"
> fuel) back 2" creates a CG at 19.3" aft of the CG.
> of the CG
> the old girl.
> Larry Nelson
> Springfield, MO
> 1963 GMC 4106-1618
> ARS WB0JOT
I used to dress the same way when I drove my 1956 Jaguar XK140 roadster in
the winter. It was my main means of transport and I only put the top up
when it was cold AND raining. I LUV that snowmobile suit!...Carl Vought
wrote :
> Hey Chuck,
> Doc
> > Daylight Time,
> > since air temps are
> > Dick,
> > Chuck G.
> > Contributions
> > any other
> > Forums.
Terry, we weighed the plane and she is within about 6#
of Howards original weights, even with the tailwheel
instead of skid and with the doodle-bug brakes that
Joe Santana installed.
--- BARNSTMR(at)aol.com wrote:
> BARNSTMR(at)aol.com
> Larry,
> years ago, I recommend that you go ahead and weigh
> items could have been changed since then. Probably
> not much....but you still never know.
> Terry L. Bowden
> ph 254-715-4773
> fax 254-853-3805
> Contributions
> any other
> Forums.
Larry Nelson
Springfield, MO
1963 GMC 4106-1618
ARS WB0JOT
A Jag, wow, I'm impressed. Neat cars.
Doc
--- "Carl D. Vought" wrote:
> Vought"
> only put the top up
> suit!...Carl Vought
> Hutcheson
> wrote :
> Hutcheson
> > Hey Chuck,
> and I
> cozy
> too.
> > Doc
> Rcaprd(at)aol.com
> > > Daylight Time,
> dropped
> > > since air temps are
> > > Dick,
> gets
> curious
> at
> > > Chuck G.
> > > Contributions
> > > any other
> > > Forums.
> Contributions
> any other
> Forums.
In a message dated 10/8/04 11:47:12 AM Central Daylight Time,
lnelson208(at)yahoo.com writes:
<< Am I on the right track here? Where have I erred? I am
the old girl. >>
Larry,
You are certainly on the right track. Aft CG is a dangerous place to be.
You will probably Never load it to be forward of forward CG. I've Never heard
of a Pietenpol with a forward CG problem. I agree with Mike C. about moving
the wing back (at least) 2". Keep in mind that by moving the wing 2" back will
not move the CG forward a full 2", therefore you should re-weight it after you
have the wing temporarily secured in position, and do your calculations.
Adding ballast gives me the Hiebie Jiebies !! Use the design for what it was
intended for, and move the wing. I doubt if you will be able to re use all of
the cables, though...one will be too long, and the other too short. On the long
ones, you might be able to carefully cut, and re do one end, just remember
the portion of the cable that is consumed in the loop at the end. If you nick
any of the strands while cutting off the nico press sleeve, the cable is scrap.
Mount it in a vise, and use a hack saw to cut just most of the way through,
then pry it apart with a screwdriver. I've also used a dremmel tool with a
thin cut off wheel to cut most of the way through, then use a screwdriver to pry
it apart, and two pair of pliers to spread it apart and remove it.
Chuck G.
<054201c4ad79$d7edf200$b1a470d1@defaultcomp>
Do you plan on carrying a toolkit? or survival gear?
Mount these things as far forward as possible. Even
in the nose in the case of tools. What about things
like batteries. For my electric start Corvair, since I
plan on a Jenny style cowl, I will be able to mount
the battery quite far forward if necessary. Here in
B.C. you can't go very far without entering some
pretty severe wilderness, more up and down than
crossways, so survival gear is a must and a permanent
part of the plane. Every little bit helps.
Clif
You
lead
In a message dated 10/8/04 11:41:38 AM Central Daylight Time,
BARNSTMR(at)aol.com writes:
<< Its hard to close up airflow around the engine case on an "exposed
cylinder" cowl. >>
I will try using duct tape over the hole in front of the J3 fiberglass nose
bowl, to see how that affects the temp. I also like the idea of insulating the
oil tank, maybe with fiberglass.
Chuck G.
Another possibility might be a heavy prop hub cover sticking out front
like I've seen on some antiques such as the Tiger Moth. A half round
thing the same diameter as the hub. Can't get any farther forward than
that.
Clif
lead
Subject: | Balancing rods and pistons |
Does anyone have any experience in balancing rods and pistons?
I have a highly accurate digital scale used for weighing letters. I've
weighed my rods and pistons (separately) and have found some minor differences
in
weight. (Have not weighed them with bearings and pins yet...)
I knew guys in El Paso who balanced the rods and pistons on VW's they raced
in Baja and the Mojave desert, but I don't really suspect you get a performance
increase doing this and I'm not even certain if making everything weigh the
same produces less vibration, especially in something as small as a Continental
A-80 engine.
I suspect even if you get all the pistons and rods matching in weight, there
are still some minor issues with true balance of the crankshaft, making the
"balancing act" of the rods and pistons overkill.
The guys who balanced their VW engines, believed there would be less stress
on them.
Thoughts and comments appreciated.
Sterling
From: | "Douwe Blumberg" <douweblumberg(at)earthlink.net> |
Subject: | grounding mag switches |
What have you guys grounded your mag switches to?
Douwe
Subject: | Re: grounding mag switches |
Douwe,
Since the mags are case grounded to the engine block, obviously has to go to the
engine, but I think I cleaned up one of the studs/nuts holding the rear case
on.
walt evans
NX140DL
To: pietenpolgroup
Sent: Saturday, October 09, 2004 10:20 AM
Subject: Pietenpol-List: grounding mag switches
Douwe
My Slicks have a threaded grounding connection just above the P leads. I think
it would be a good idea to install a wire from one mag's grounding terminal to
the other and another wire from there to a case bolt. This would tie noth mags
to the case potential. (grounding it) Then the black (ground ) wire coming
from the mag switch should also be grounded to the case bolt. The problem
could be that if corrosion, or crud, somehow affects the connection betewen the
mag and the case, like say corrosion in the mag studs, , you could wind up
with a mag that is not at the same potential as the case (basically insulated
from the case). Looks to me like this could cause a problem
Bert
Sent: Saturday, October 09, 2004 5:56 PM
Subject: Re: Pietenpol-List: grounding mag switches
Douwe,
the engine, but I think I cleaned up one of the studs/nuts holding the rear
case on.
walt evans
NX140DL
To: pietenpolgroup
Douwe
I'll give it a try too. I was running at 140 deg today on a beautiful mid
60's day.
Dick N
> cylinder" cowl. >>
> nose
> insulating the
> Chuck G.
I ran the wire to the engine block and also ran a wire back to a ground plate behind
which also grounds the radio antenna.
Dick N.
To: pietenpolgroup
Sent: Saturday, October 09, 2004 9:20 AM
Douwe
Subject: | A "no shackle" question |
From: | "Christopher Friel" <cjfriel(at)ucdavis.edu> |
Hello everybody, I've been lurking for about a year now. I've managed to
put together a Piet while going to graduate school; I couldn't have done
it without all of you. I am now threatening to cover the beast but before
I do I have a question about the bracing wires between the spars. Is it
acceptable to connnect the non-turnbuckle end of the cables directly to
the brace wire fitting or is it best to use a shackle and clevis bolt? All
the talk about the hard wire on the tail got me to wondering. I used 1/8"
7x19 stainless wire and a thimble. What do ya think?
Chris
Davis, CA
Subject: | Re: A "no shackle" question |
Chris. In my opinion, the only down side is if you ever needed to replace a
be a problem with the rear spar, but if you use plywood for the leading edge
you may not be able to get to the nut on the bolt for the fitting on the
front spar.
If you use a shackle you can replace the cable fairly easy without that.
Now the reality is .. how often would you need to replace a x-brace cable?
I chose to use shackles.
My 1/50 th of a buck.
BC
Subject: Pietenpol-List: A "no shackle" question
> Chris
> Davis, CA
There is really no reason to use the extra shackle on that end. I just made
the hole in the fitting large enough to accept a thimble. You don't need
1/8" for these. 3/32" is plenty strong for that.
Dick N.
> Chris
> Davis, CA
<003101c4ae71$330e2900$6501a8c0@Nancy>
I don't think you'd need to pull the fitting would you? If you have to
replace the cable then it has to be cut off anyway and if you have
enough room to get at the fitting for removal wouldn't you have enough
to nicopress a new end in there? A little like modern appendectomy
maybe but doable isn't it? I must admit, I hadn't thought of ever having
to do it but s$t happens, doesn't it.
Landing gear brackets finally bolted in. Starting LG legs tomorrow.
Clif
a
> x-brace cable you'd have to pull the fitting off the spar. This may not
edge
> front spar.
> BC
> >Is it acceptable to connnect the non-turnbuckle end of the cables
directly to
All
1/8"
In a message dated 10/9/04 9:16:19 PM Central Daylight Time,
cjfriel(at)ucdavis.edu writes:
<< Is it
7x19 stainless wire and a thimble. What do ya think? >>
Chris,
I used 3/32" 7X19 cable, and attached the non-turmbuckle end of the cable
thimbles directly to the fitting. The hole in the fitting is a straight drilled
hole, so I took a fine file, and beveled the side of the hole, to match the
radius of the thimble. After over 200 hrs of test flying, the cables still have
the same 'twang' as they did when I installed them.
Chuck Gantzer
NX770CG
- nasty direct cross wind today, so I repaired the leak in the smoke tank,
and a couple of other squawks.
Subject: | Re: Balancing rods and pistons |
Sterling,
I weighed my pistons and rods before assembly, and they turned out very
close. I didn't do anything to get them any closer. I suspect those V W engines
turn up over twice the rpm of our Continental engines, where balance may be
more crucial.
Chuck G.
In a message dated 10/9/04 10:19:45 PM Central Daylight Time,
CDAWSON5854(at)shaw.ca writes:
<< I don't think you'd need to pull the fitting would you? If you have to
maybe but doable isn't it? >>
Clif,
Yes, the fitting would have to be removed. I pre-fit the fittings & cables,
then nico-press the cable end on before I permanently bolted the fitting in
place. No way to get the nico-press tool in there. The cables are permanent
fixture, and should never need replacement.
Chuck G.
<006a01c4ae76$fc2a48a0$42705118@dawsonaviation>
Cliff
I think you'd have a real hard time getting the nicopress sqeezer thingy
into a 4 inch inspection hole at the same time being able to hold and snug
the nicopress sleeve up against the the thimble while holding and squaring
the whole thing up- all the while squeezing that thing on.. Unless there's
a new laproscopic squeezon tool I'm not familiar with. I guess I'm like an
old "wash woman" and worry about every possible problem that could come up.
That's why it's taken me 9 years, 4 months and 3 days to build my plane.
(But that suckers about ready to go.)
Chris. Drill holes in your fitting big enough for the thimble and don't
worry about spending an extra four bucks per cable. (Until later........)
{PS went to Thomasville Ga flyin today but no Piets)
BC
Subject: Re: Pietenpol-List: A "no shackle" question
> Clif
replace
> a
not
> edge
> > front spar.
cable?
> > BC
> directly to
> All
> 1/8"
From: | "rod wooller" <rodwooller(at)hotmail.com> |
Sterling,
If you want to have a go at balancing the rods etc yourself, get a copy of
Richard Finch's book "How to keep your Corvair alive".
There are diagrams in it that show how to build jigs to balance the engine
parts.
I haven't yet done this myself, but it looks simple enough.
Rod Wooller
Chidlow, Australia
>From: N321TX(at)wmconnect.com
>Subject: Pietenpol-List: Balancing rods and pistons
>Date: Sat, 9 Oct 2004 08:48:29 EDT
>differences in
>performance
>Continental
>A-80 engine.
>there
>on them.
>Sterling
Protect yourself from junk e-mail:
http://microsoft.ninemsn.com.au/protectfromspam.aspx
I did a full dynamic balance on my Continental A-65. Since it was going into a
certified plane (Taylorcraft) the IA checking my work on the rebuild wanted all
the work done before he looked at the parts. After the stock car engine builder
did his thing a normal check was done by the repair shop at the airport.
The balance guy matched all of the pistons and took a light shave of the inside
of the piston skirts to get them in balance (had to exchange a couple of pistons
that were VERY light which he said were probably "inclusions" in the castings).
Next he made sure all of the wrist pins and caps matched afterwhich
he mated up specific caps, pins and pistons to get the TOTALS to match (stop tolerances
from adding up). Next he did the rods by weighing them from both ends
(use one hole as a pivot and weigh the other). He did this both ways so the
rods not only had the same weight, but their CG was in the same place. Finally
was a dynamic balance of the crank and cam. He spun the crank on a balance
lathe to over 20,000 RPM looking for balance and harmonics. THAT WAS SCARY!
I never saw something as massive as a Continental crank spin THAT fast. IF
it had come out of the lathe I can't imagine the damage it could do. He seemed
a little amused at my concern and said stock cars go MUCH higher.
I haven't run the engine yet but the IA said he was impressed by the numbers and
I should have an incredibly smooth engine. Remember it takes power to shake
an engine and that's what vibration is. If you get rid of the vibration you
get more power at the prop. I just wonder if it will be measurable.
All told I think I paid less than $200 US for all of the balance work. Even if
it doesn't make a measurable difference it was a blast to be there for.
Hank J
Sent: Saturday, October 09, 2004 8:48 AM
I have a highly accurate digital scale used for weighing letters. I've weighed
my rods and pistons (separately) and have found some minor differences in weight.
I knew guys in El Paso who balanced the rods and pistons on VW's they raced in
increase doing this and I'm not even certain if making everything weigh the same
A-80 engine.
are still some minor issues with true balance of the crankshaft, making the "balancing
The guys who balanced their VW engines, believed there would be less stress on
them.
Sterling
Good points and I thank all who replied.
I remember the VW racers were really dealing with high RPMs and the
VW engines were really hopped up.
I also submitted a bid on Ebay for the book Rod recommended.
I found a good article on engine balancing and it was an interesting and
informative read. It can be accessed at this URL.
Dynamic and static seems more than my postal scale can handle and for $200,
it seems like a small fee to pay for all the work the tech did on the
Continental 65. I'd like to see that 65 run someday.
http://www.babcox.com/editorial/ar/eb10330.htm
S.B.
Me too. It will probably end up in my other plane (41 Taylorcraft) when its engine
times out before it goes into the 45 Taylorcraft that is taking an eternity
to finish. I hope it meets everyone's (that worked on it) expectation. The
NASCAR engine builder that did the work said one reason he did it was because
he had never worked on an airplane engine and it was his off season. If it
works as well as it looks it will be a champion.
Hank J
Sent: Sunday, October 10, 2004 10:44 AM
Subject: Re: Pietenpol-List: Balancing rods and pistons
Dynamic and static seems more than my postal scale can handle and for $200, it
seems like a small fee to pay for all the work the tech did on the Continental
S.B.
<005701c4ae84$fad97d50$6501a8c0@Nancy>
Yeah, I drew it out to see and it would be something I would not
want to have to try. 9 years! I just posted a few more pics to
mykitplane. This is as far as I have gotten in 10. I figure another 5.
Why is it so many other things seem to get in the way of the truly
important things in life? :-) :-) :-)
http://www.mykitplane.com/Planes/photoGalleryList3.cfm?Start=61&AlbumID=27
Clif
> Cliff
flyers,
there is a section on balancing and engine on page 21 of the 1929 flying and gliding
manual.
bill shamblin
morganton nc
Subject: | about to begin?? |
flyers,
what are the important changes to the aircamper plans after those presented in
1932 f+g manual?? or can one reasonably work from those plans alone??
thanks,
bill shamblin
morganton nc
Subject: | Re: about to begin?? |
Bill,
The major differences in the "Improved" Air Camper plans and the F&G plans are
in the fuselage and the landing gear. The tailplane is slightly different as
well. Good airplanes have been constructed from either set of plans, and from
the "long" fuselage which came out much later. Many planes are constructed from
a combination of the different versions. My own Air Camper, which flew for
the first time last week, has the long fuselage, the Vi Kapler 3-piece wing,
but the original F&G landing gear. Choose what you like and build it. It will
still be a Pietenpol. I doubt if any two of the half dozen or so Air Campers
built by BHP were identical.
Jack Phillips
Raleigh, NC
> From: "billshamblin" <shamblin(at)hci.net>
> Date: 2004/10/11 Mon AM 05:53:31 EDT
> To:
> Subject: Pietenpol-List: about to begin??
> flyers,
> thanks,
> bill shamblin
> morganton nc
In a message dated 10/11/04 12:25:36 PM Central Daylight Time,
pietflyr(at)bellsouth.net writes:
<< I doubt if any two of the half dozen or so Air Campers built by BHP were
identical. >>
Jack,
Bernard Harold Pietenpol built either 24 or 26 Air Campers. Doc Mosher's
directory lists them. No two of them were exactly alike. The last two were
built in 1960 and 1964, with Corvair engines.
Bill,
If you are seriously considering building a Pietenpol AirCamper, purchase the
plans directly from the Pietenpol Family.
Their web site:
http://www.pressenter.com/~apietenp
Chuck G.
In a message dated 10/11/04 2:31:25 PM Eastern Daylight Time, Rcaprd(at)aol.com
writes:
> Jack,
were
It might be interesting to post details of the airplanes that BHP did build.
Chronological order and what improvements, or modifications he made on each
one would be good "historical" information. Engine type, Empty weight and
where the airplane is now also.
Subject: | Weight and Balance Fun |
From: | "Textor, Jack" <jtextor(at)thepalmergroup.com> |
Guys,
When you move the wing back do you move the lower struts back? If so I
assume you would have to angle the fuselage uprights back too. Am I all
messed up?
Jack T
Des Moines
Jack,
Fuselage-to-strut attachment locations don't
change. The fittings are designed to allow
the struts to pivot fore and aft allowing the
wing position to change in relation to the
fuselage.
Greg Cardinal
Minneapolis
Subject: RE: Pietenpol-List: Weight and
Balance Fun
> "Textor, Jack"
> Guys,
> messed up?
> Jack T
> Des Moines
> Forum -
> through the Contributions
> banner ads or any other
> Matronics Forums.
> http://www.matronics.com/search
Subject: | Lightened Sides & Wing Rib Questions |
Guys,
For the engineers out there, would the attached rough drawing be feasible? I came
up with the idea based on the concept that Lindbergh used a wicker seat in
the Spirit of St. Louis and looking at some of DJ's shots of the GN-1. The corners
would be rounded and the sections between the cutouts would be approximately
4" to 5" wide (WAG - wild ass guess). I would carry over the concept to
the seats and seat backs as well. Any thoughts?
On another subject, for everyone that's used Charles Rubeck's wing ribs (or hasn't
for that matter). I have noticed that the front "hole" width for the main
spar is 1" and the back "hole" is 1-1/8" wide. The spar matierial I have is
1" wide. Am I missing something here?
Stacy
There is only one greater thing than to believe in the impossible...and that is
to achieve it -- Stacy Clark
Subject: | Re: Lightened Sides & Wing Rib Questions |
In case it wasn't clear in the original posting, the lightened sides I'm speaking
of are the plywood sides that overlay the side fuselage frames.
Stacy
Subject: | Ceramic Fiber firewall insulation |
wacopitts(at)yahoo.com, pietenpol-list(at)matronics.com
Gentlemen,
My ceramic fiber material for firewall insulation came in last friday. I
finally got around to cutting and packaging some tonight for those who requested
for purchase . Sorry for the delay. I will be sending the packages off
tomorrow so I will let you each know the final total price with shipping by email
tomorrow. For those of you who already sent money, thank you. I will refund
any amount you over paid.
The following are those who I have already cut and packaged material for.
Dan Wilson 24" X 24" = $5.80 + shipping
Arthur Johnson 36" X 24" = $8.70 + shipping
Galen Hutchinson 24" X 24" = $5.80 + shipping
Rick Holland 36" X 24" = $8.70 + shipping
Don Hicks 24" X 24" = $5.80 + shipping
I also have some material set aside for myself and...
Sterling Brooks
Jim Markle
That leaves enough for about five more orders. Anyone else wishing to
purchase this material for $1.45 per sq.ft. let me know and I will send it out
this
week.
Attached is a copy of the labels on the box I received.
Terry Bowden
254-715-4773
Subject: | Re: Ceramic Fiber firewall insulation |
Terry, go ahead and send me one for a standard Piet.
Doyle Combs
To: dwilson(at)ci.austin.mn.us ; aejohnson(at)bigpond.com ; at7000ft(at)gmail.com ; wacopitts(at)yahoo.com
; pietenpol-list(at)matronics.com
Cc: jim_markle(at)mindspring.com ; N321TX(at)wmconnect.com
Sent: Tuesday, October 12, 2004 8:29 PM
Subject: Pietenpol-List: Ceramic Fiber firewall insulation
Gentlemen,
My ceramic fiber material for firewall insulation came in last friday. I finally
for purchase . Sorry for the delay. I will be sending the packages off tomorrow
so I will let you each know the final total price with shipping by email tomorrow.
For those of you who already sent money, thank you. I will refund any
Dan Wilson 24" X 24" $5.80 + shipping
Arthur Johnson 36" X 24" $8.70 + shipping
Galen Hutchinson 24" X 24" $5.80 + shipping
Rick Holland 36" X 24" $8.70 + shipping
Don Hicks 24" X 24" $5.80 + shipping
Sterling Brooks
Jim Markle
That leaves enough for about five more orders. Anyone else wishing to purchase
this material for $1.45 per sq.ft. let me know and I will send it out this
week.
Terry Bowden
254-715-4773
Terry,
I resubmit my order for a piece 24x27.
Corky
625 Pierremont Rd
Shreveport, La 71106
OK Corky. I'll find out the shipping cost and let you know tomorrow night by
email.
Terry
OK Doyle.
Send me your address. I will let you know the cost with shipping tomorrow
nite. Hope all is going well with you.
Terry
Subject: | Metal Substitution |
Hi Gang,
Got a question I need some information on. Has anyone
thought about or has done substituting a high grade
aluminum (of equal strength to the steel fittings) for
some of the steel fittngs. I should think that by
redesigning the fittings to enhance their strength
might be a good alternative. Please respond with any
input you have. Thanks.
Doc
Subject: | Another question-motor cycle wheels |
Does anyone know of any "off the shelf" motor cycle
wheels that have been used with good results for the
Piet with the wooden gear? Money is really tight and
I can't afford right now to have a "top of the line"
set of wheels fabricated. Surely some racing or
motocross wheels would have the strength to handle the
side loads that one would anticipate with flying.
Thank for your advice.
Doc
Terry Bowden
I would like the insulation material --- 24" by 36"
Henry Williams
59 Crescent Dr
Huntington NY 11743
thanks a lot
Henry W ( borodent @aol.com )
Subject: | Re: Another question-motor cycle wheels |
Doc-- Wil Graf in nearby Wadsworth Ohio has used off the shelf used
motorcycle wheels
for years with no problems, despite what people say about needing the
wide-width hubs.
Wider hubs ARE the preferred way to go, but if you don't ground loop it or
go off into the toolies
the regular wheels as is work fine once you have them bored and bushed for
the axle size you are
using.
Mike C.
Subject: | "engine turning" cowlings |
Gentlemen,
I'm not sure what the proper term is, but I'd appreciate thoughts on how to get
those "turning/swirl" marks on a bare aluminum cowling.
Is it a very fine stainless wire brush in a die grinder or one of those nylon abrasive
brushes??
With a piece of metal the size of the cowling parts, using a drill press is out,
so I assume it'll have to be handheld, maybe with some sort of jig.
Thoughts??
Douwe
Subject: | Re: "engine turning" cowlings |
HI Douwe,
It is called "Engine Turning". I did my instrument panels using an old intake
valve with a circular pad of Scotchbrite superglued to it, mounted in my drill
press. It only takes a second of pressure to put the swirls into aluminum.
Jack Phillips
> From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
> Date: 2004/10/13 Wed AM 08:33:11 EDT
> To: "pietenpolgroup"
> Subject: Pietenpol-List: "engine turning" cowlings
> Gentlemen,
abrasive brushes??
> Thoughts??
> Douwe
Subject: | Re: Metal Substitution |
Doc,
The only place I've considered substituting aluminum in place of steel is the streamline
wing struts... but I've decided not to. Some folks have though. I
can't see that you'd gain much by changing the design of the fittings. The dimensions
would need to ge significantly changed. I would be most concerned about
the fatigue life, especially around bolt holes. Aluminum would require much
greater edge distance and/or greater thickness to equal the same strength.
So, you certainly couldn't expect to save much weight as the fittings are designed
pretty light to begin with. Thats my 2 cents worth.
Terry L. Bowden
ph 254-715-4773
fax 254-853-3805
Subject: | Long fuselage plans strut fitting |
The long fuselage plans have a large note on top "3/4" x3 Filler For
Strut Fitting". So I was going to attach my rear cabane strut fitting
to that. Then I read in the archieves that you should attach it to the
vertical strut that runs between the top and bottom longeron.
Opinions? Attaching to the filler block would pervent me from having
to cut off the ends of the 1/2x1 cross brace and the cowl support.
Rick Holland
I went with aluminum not for weight savings but for cost savings. 4130
streamline was going to cost me a fortune and I got all the aluminum strut
material for about $175 from Carlson Aircraft.
In reality I think the aluminum struts come out about 20% heavier than steel
once the end fittings are installed and they are ready to fly.
One day, after I get my TIG welder and learn to use it I'm gonna make 4130
struts..... one day
DJ
Subject: Re: Pietenpol-List: Metal Substitution
> Doc,
the streamline wing struts... but I've decided not to. Some folks have
though. I can't see that you'd gain much by changing the design of the
fittings. The dimensions would need to ge significantly changed. I would
be most concerned about the fatigue life, especially around bolt holes.
Aluminum would require much greater edge distance and/or greater thickness
to equal the same strength. So, you certainly couldn't expect to save much
weight as the fittings are designed pretty light to begin with. Thats my 2
cents worth.
> Terry L. Bowden
> ph 254-715-4773
> fax 254-853-3805
Stacy
In thinking about this weight saving issue, consider how much weight you are really
saving over how much you are compromising you safety. In basic structural
issues it is always best to stay with the plans.
On the wing ribs, I dont know but suspect its just for some extra wiggle room in
fitting the ribs.
Dick N.
Sent: Tuesday, October 12, 2004 2:31 PM
Subject: Pietenpol-List: Lightened Sides & Wing Rib Questions
Guys,
came up with the idea based on the concept that Lindbergh used a wicker seat
in the Spirit of St. Louis and looking at some of DJ's shots of the GN-1. The
corners would be rounded and the sections between the cutouts would be approximately
to the seats and seat backs as well. Any thoughts?
Stacy
is to achieve it -- Stacy Clark
Doc
Check out my Harley Davidson 21" wheels. They are working out great.
1 1/4" axle
18" - 4140 axle inserts
Wheel bearings have to be removed and replaced with rear wheel bearings
Dick
Subject: Pietenpol-List: Another question-motor cycle wheels
> Doc
Stacy... if you leave about 3-5" of ply at the edges and cut the center out, making
sure you have a nice large radius, it will be fine. I used a full roll
of Duct tape as my radius when I traced the lines. Do not do sharp radiuses or
hard corners as it will be a stress riser.
The material in the middle does little in the way of strength..... it's almost
nothing but dead weight.
Do use a good quality aircraft ply. cheap hardware store ply would not be suggested
if youre going to cut out the centers.
I saved about 2 lb by doing that, but 2 lb in the tail means about 4 up front to
counter it so it could be said youre saving 6lb.... although, for other reasons
that is debatable.
DJ
Sent: Tuesday, October 12, 2004 12:31 PM
Guys,
Stacy
Dick,
That sounds like a great wheel. I know the Harley
wheels are tough (once owned two Harleys myself, wish
I still had the wheels) do you know which model they
came out on? A friend of mine knows of a cycle
junk-yard and we were going to look for something.
Thanks for sending the pic and the info.
Doc
> Doc
> working out great.
> 1 1/4" axle
> rear wheel bearings
> Dick
> To:
> Sent: Wednesday, October 13, 2004 1:06 AM
> cycle wheels
> Hutcheson
> cycle
> the
> and
> line"
> the
> > Doc
> ATTACHMENT part 2 image/jpeg name=P1010109.jpg
Thanks Terry and DJ,
I just had a passing thought about the aluminum as I
had a damaged spring aluminum gear that came off my
Pitts that I have been looking for something to do
with except to bring back some unpleasant memories. :)
It is really strong stuff and would be good material,
but it also might be heavier. Thanks for the info
though.
Doc
> cost savings. 4130
> ready to fly.
> struts..... one day
> DJ
> From: <BARNSTMR(at)aol.com>
> To:
> Sent: Wednesday, October 13, 2004 6:26 AM
> BARNSTMR(at)aol.com
> > Doc,
> to. Some folks have
> around bolt holes.
> cents worth.
> > Terry L. Bowden
> > ph 254-715-4773
> > fax 254-853-3805
> Contributions
> any other
> Forums.
Douwe,
I've seen it done with a wire cup brush attached to
either a drill press or a good hand drill.
Doc
--- pietflyr(at)bellsouth.net wrote:
> HI Douwe,
> panels using an old intake valve with a circular pad
> Jack Phillips
> > Gentlemen,
> appreciate thoughts on how to get those
> grinder or one of those nylon abrasive brushes??
> parts, using a drill press is out, so I assume it'll
> > Thoughts??
> > Douwe
> Contributions
> any other
> Forums.
Galen-- you might want to shop around for aluminum rims/wheels as you will
save a decent amount of wt. there
in the wheels if you do. Steel rims are okay but alum. even better.
Mike C.
Hi Michael,
Nice talking to you again. I felt that way too.
There are some pretty heavy motorcycles out there and
many of them take some pretty good side loads and seem
to hold up pretty well. I appreciate all the good
info that you and the group have given me. I am still
plugging along and making pretty good headway. Except
for a little logging accident (a tree kicked back and
caused my prized chain saw to take a big bite out of
my knee) which put me on crutches for awhile. As
winter moves in, I am going to have to give up some of
my workshop to my wife's car. She doesn't share the
zeal I have for the Piet. :) I wonder if I
"accidentally" get some T-88 on her car she might want
to park elsewhere? I wonder...
Thanks to the group for all the fine info and I am
looking forward to meeting all of you at Broadhead
this summer.
Doc
> the shelf used
> motorcycle wheels
> about needing the
> wide-width hubs.
> using.
> Mike C.
> Contributions
> any other
> Forums.
Subject: | Re: wheel weights |
Great idea Mike, I'll do that. Thanks.
Doc
> alum. even better.
> Mike C.
> Contributions
> any other
> Forums.
Unfortunatly the wheel is off a 2002 and later, with sealed bearings. The
spread between spokes is 4 1/2". I commonly see them at M.C swap shows and
on e-bay at about $150. I used the Harley rotors also and go kart calipers,
though on my new Piet I'm using Harley calipers.
I compared notes with Greg Cardinal some time ago and my set up was within a
couple of pounds of his. As I recall, 63 lb. including wheels, tires brakes
and axle.
Dick
Subject: Re: Pietenpol-List: Another question-motor cycle wheels
> Dick,
> Doc
>> Doc
>> working out great.
>> 1 1/4" axle
>> rear wheel bearings
>> Dick
>> To:
>> cycle wheels
>> Hutcheson
>> cycle
>> the
>> and
>> line"
>> the
>> > Doc
>> > Declare Yourself - Register online to vote today!
>> > http://vote.yahoo.com
Stacy,
The GN1 has the plywood all the way to the tail, and I could see the
reasoning for carefully placing lightning holes there towards the tail. However,
the holes in the cockpit area are not recommended, because this is where the
majority of the stresses of the engine, wing, and landing gear all come
together, and your weight savings would be minimal. Also, if you put holes there
you
will certainly drop something in there, between the plywood and the fabric.
Keep in mind the seats in the Pietenpol are structural pieces, especially the
pilot seat. NX211 (Spirit of St. Louis) was a steel tube fuselage, and the
wicker seats are a light weight and durable place to sit.
As for the ribs, the aft hole should be 1". It seems you will have to
figure out where the holes are in relation to the plans, and shim with plywood
at each rib, to maintain the plans location of the spars.
Chuck G.
In a message dated 10/13/04 12:58:22 AM Central Daylight Time,
wacopitts(at)yahoo.com writes:
<< Has anyone
thought about or has done substituting a high grade aluminum (of equal
strength to the steel fittings) for some of the steel fittngs. I should think
that
by redesigning the fittings to enhance their strength might be a good
alternative. >>
Doc,
It's all been thought of, and some even built, but the resounding conclusion
is to stick with the plans method and dimensions of steel fittings.
Chuck G.
I believe the old time machinest call it "damiscening" (sp?). Carl V
wrote :
> Gentlemen,
to get those "turning/swirl" marks on a bare aluminum cowling.
is out, so I assume it'll have to be handheld, maybe with some sort of jig.
> Thoughts??
> Douwe
Galen: For the record, the wheels on my unlicensed/unfinished Aircamper are
19" BMW motorcycle wheels. The tires are 4.00/90 and my understanding is
that this means the inside diameter is 19" and width is 4.00" and the
height is 90% of that or 3.6". I believe that the wide (6") hubs are more
authentic, and more asthetic but gain one little in the way of side load
strength....Carl V
wrote :
> Dick,
> Doc
> > Doc
> > working out great.
> > 1 1/4" axle
> > rear wheel bearings
> > Dick
> > To:
> > cycle wheels
> > Hutcheson
> > cycle
> > the
> > and
> > line"
> > the
> > > Doc
Hi Carl,
Thanks, that gives me even more options. I agree, it
would be nice to stay with the authentic as much as
possible, but at what cost. Seems the smaller wheels
would be lighter too, esp if aluminum. Thanks for the
input. What did you use for an axel?
Doc
> Vought"
> my understanding is
> is 4.00" and the
> strength....Carl V
> today!
> Contributions
> any other
> Forums.
Thanks Chuck, looks like that is the general opinion.
Doc
> Daylight Time,
> << Has anyone
> aluminum (of equal
> alternative. >>
> Doc,
> steel fittings.
> Chuck G.
> Contributions
> any other
> Forums.
Dick, that's not bad. I will keep my eyes open for
some good deals. Might have to go rekindle some old
Harley friendships...hummmm. :) (I can see the
headlines now..."OLD MAN CAUGHT STEALING WHEELS OFF
HELL'S ANGEL'S BIKE--FULL RECOVERY EXPECTED, CONDITION
STABLE."
Doc
> Navratil"
> and axle.
> Dick
> ----- Original Message -----
> To:
> Sent: Wednesday, October 13, 2004 1:18 PM
> cycle wheels
> Hutcheson
> > Dick,
> wish
> they
> > Doc
> wrote:
> >> Doc
> are
> >> working out great.
> >> 1 1/4" axle
> with
> >> rear wheel bearings
> >> Dick
> >> To:
> >> cycle wheels
> >> Hutcheson
> >> cycle
> for
> >> the
> tight
> >> and
> >> line"
> or
> handle
> >> the
> flying.
> >> > Doc
> today!
> Contributions
> any other
> Forums.
I tried sending this earlier but it didn"t go thru.
If you all have time check this out. It is a beautiful tribute to our troops,
not political. Turn up the sound.
www.clermontyellowribbon.com/untilthen.htm
Subject: | Re: off the subject |
Doesn't work
Sent: Wednesday, October 13, 2004 9:02 PM
Subject: Pietenpol-List: off the subject
Dick,
We use Aeroshell 100 50w here in Florida year around. We had the Shell
expert talk to us this year and he said that 15/50 was exactly what you need
up in that COLD country of the north. Of course, we don't know anything
about cold down here but I remember his comments. Go ahead and use it.
Went flying for 3 hours today for the first time since the weekly run of
huricanes. It was nice to have some nice fall weather with blue skys and
low 80s.
Ted
From: "Richard Navratil" <horzpool(at)goldengate.net>
Would
about
oil science.
down.
colder
the
on good days.
Dick N.
Sorry, I left out a part of there adderss
Please try again
www.clermontyellowribbon.com/untilthenflash.htm
Sent: Wednesday, October 13, 2004 9:36 PM
Subject: Re: Pietenpol-List: off the subject
Doesn't work
To: pietenpol-list(at)matronics.com
Subject: | Google and "N" number |
DJ, you are right about that. That is incredible!
For fun, enter N894W, click on Bird4 and follow the
links. You will see my last love. I don't know how
that plane got on there, but those were some of my
pics. I'm going to try some of the other numbers.
Thanks DJ.
Doc
Thanks Ted
Good to hear you made it thru the hurricanes ok. It's time for the oil
change and the weather is changing.
Dick
Subject: Pietenpol-List: oil & oil temp questions
> Dick,
> need
> low 80s.
> Ted
> Would
> about
> oil science.
> going
> down.
> colder
> a
> the
> out
> on good days.
> Dick N.
Subject: | Re: Google and "N" number |
There are three pics of my Bird. One is listed as
part of the Bach collection. I sent Richard Bach some
photos, and we emailed for awhile, to keep him posted
on my barnstorming activities. Guess he liked the old
Bird too. I sure miss that old gal, we had a lot of
fun together.
> Hutcheson
> Thanks DJ.
> Doc
> Contributions
> any other
> Forums.
> http://www.matronics.com/chat
> http://www.matronics.com/subscription
> http://www.matronics.com/FAQ/Pietenpol-List.htm
> http://www.matronics.com/photoshare
Thanks guys. I've decided to stick with "as plans" on the side panels because
of your input. The wicker would have looked good though. I might still overlay
some on the seat backs (no cutout).
Stacy
I wonder if you couldn't give the seats the "wicker
look" by gluing thin strips of 1/16 birch ply, in a
basket weave, over the wooden seats. I know, some
weight, but it should give it a nice look.
Doc
> on the side panels because of your input. The
> overlay some on the seat backs (no cutout).
> Stacy
> the impossible...and that is to achieve it -- Stacy
Clark
Subject: | two Pietenpols for sale on Barnstormers.com |
<014e01c4b19f$9d987fb0$0100a8c0@Desktop>
Go to http://www.barnstormers.com/ and type Pietenpol after you click the
search button. Mike C.
PIETENPOL AIRCAMPER =95 $9,500 =95 FOR SALE =95 Completed and flown in 2001 2
seat aircamper FAA reg. exp. 35 hrs. t.t. af and eng. 85 hp EA 81 subaru,
bal & blueprinted , cruises at 75mph with 75% pwr. Internal wood const.
built buy a craftsman with over 25 homebuilt aircraft completed. Will send
pic's upon request. =95 Contact Lane Hetherington - located Pamana, OK USA =95
Telephone: 918-963-4467 =95 Posted October 10, 2004 =95 Show all Ads posted by
this Advertiser =95 Recommend This Ad to a Friend =95 Send a Message
OPEN COCKPIT FUN ! PIETENPOL AIRCAMPER =95 $6,000 =95 AVAILABLE FOR SALE =95 2
pass.tandem 730 tt A/E 65hp Continental recent valves and rings chrome
valve covers Delcom radio always hangared ELT new interior voice activated
intercom needs wood and fabric repair to the wings and elevator.Damage
caused by Hurr. Charley.Aircraft is worth repairing.Please call 239 - 549-
8886 =95 Contact Richard West - located Cape Coral, FL USA =95 Telephone: 239 -
549 - 8886 =95 Posted September 19, 2004 =95 Show all Ads posted by this
PIETENPOL FOR SALE =95 $12,000 =95 AVAILABLE FOR SALE =95 pietenpol tt 70 hrs
completed 12 8 94 constructed per 1931 original plans using a/c quality
parts and consrtuction methods ford model A with aluminum 7-1 head psi lube
system bendix mag s4ln-21 water pump from vw jeta carb na-s2. 3 peice wing
routed spars empty wt 630.contact Bob Borrows 540 473661 =95 Contact Bob
Burrows - R&B AIRCRAFT CO. located Fincastle, VA USA =95 Telephone:
540-473-3661 =95 Fax: 540-473-3661 =95 Posted September 15, 2004 =95 Show all Ads
posted by this Advertiser =95 Recommend This Ad to a Friend =95 Send a Message
What you want, to refine Galens suggestion is to
either find someone familiar with "marquetry" and
have that person make up a basket weave pattern
in a panel or learn to do it yourself.
http://www.marquetry.org/index.htm
http://www.staffsmarq.freeserve.co.uk/guide2.htm
http://www.staffsmarq.freeserve.co.uk/index.html
Of course, once you start down this road, the plane
will never get finished!
A good artist knows his techniques, materials and how to use them.
A great artist knows when to stop.
The exception that proves the rule? William Turner.
Clif
Subject: Re: Pietenpol-List: Lightened Sides & Wing Rib Questions
> Doc
> > Stacy
> Clark
Subject: | rib gusset material?? |
builders,
what is our best source of rib gussett material?? i thought aircraft spruce used
to sell 1/16" plywood already cut up but i havent been able to locate it. is
there something eles that works?
thanks,
much to learn in nc
Subject: | Re: rib gusset material?? |
I went to the hobby stores and bought Midwest brand
aircraft grade 5 ply birch plywood. It is very strong
and comes in a couple of different sizes. It is a
little pricey, but easily obtained.
Doc
--- billshamblin wrote:
> builders,
> thought aircraft spruce used to sell 1/16" plywood
> is there something eles that works?
> thanks,
> much to learn in nc
Galen,
I have very good luck with Wicks. You can buy about any size. I buy a
4'x8' sheet and have them cut (to ship) to 2'x4'. Packed very well and
with regular UPS it gets to me in 2 days.
Jack
In a message dated 10/15/04 8:04:05 AM Central Daylight Time,
shamblin(at)hci.net writes:
<< builders,
used to sell 1/16" plywood already cut up but i havent been able to locate it.
is there something eles that works? .
thanks,
much to learn in nc >>
Bill,
It takes quite a sizable piece of 1/16" plywood to do the ribs, and there is
always other places to use it, so don't be shy about buying too much. Here is
a few links to some places I've heard about, although I've never bought any
there. The last two are info.
http://www.aitwood.com
Edensaw Woods in Port Townsend, WA. 800-745-3336; http://www.edensaw.com
http://www.hardwoodint.com/
Boulter Plywwod Corp.
24 Broadway, dept. WB
Somerville, MA 02145
www.boulterplywood.com
http://www.faa.gov/certification/aircraft/av-info/dst/amateur/default.htm
http://www.faa.gov/certification/aircraft/av-info/dst/43-13/default.htm
Jack,
I've heard that about Wicks too. I had bought some
from AS&S, pretty pricey but they shipped pretty
quickly. I had mentioned the hobby store ply as a
ready source and I use it in a pinch. It is a good
grade of ply and compares well with what I got at
AS&S. Thanks for the info though.
Doc
--- "Textor, Jack" wrote:
> Galen,
> any size. I buy a
> Jack
Subject: | Plotting Coordinates for Pietenpol Wing Rib ( NO FILES |
ATTACHED)
Pieters:
A few hours ago I sent out the message below with 3 small files attached. If anyone
is interested in seeing the files, let me know and I will post them to the
photo section. I can also email them to you.
Pieters:
If you're interested in looking at my early efforts to get a Piet rib into a CAD
file read on, otherwise trash this message.
Earlier this year someone published the coordinates for the Piet rib. As luck would
have it, I kept the coordinates but not the name of the person posting them.
Tonight I finally got around to converting the coordinates into a format acceptable
to rib design software I have been using for model aircraft design.
(It handles ribs up to 11 feet in size.) That software also creates DXF files,
the CAD interchange format. I plugged the Piet DXF file into AutoCAD 2000 and
now have a real CAD file. I have attached these files for you. Don't know if
there is much interest.
File 1: PIETCFWN.TPL Created using SoarSoft Software's CompuFoil. This "TPL" file
is a type created by this application. I provide it in case someone out there
has this software.
File 2: PIETRIB.DXF Created using software above. It is described as the standard
CAD interchange or exchange format.
File 3: PIETRIB.DWG Created using AutoCAD 2000.
Please note that the leading edge looks a little sloppy. I can't tell if it's the
Compufoil software or perhaps the coordinates. Maybe someone can re-identify
the original contributor. Also note I have made no attempt to add the internal
rib parts and won't get into it until I am more comfortable with the coordinates.
John Joyce
9 Sylvia Road
North Reading, MA 01864
978.664.3578
John Joyce
9 Sylvia Road
978.664.3578
Is it okay to splice the fuselage side plywood at an upright? I purchased
some 4x4' pieces of ply from McCormicks -- they didn't have any 4x8' sheets. If
it's not a good idea that's okay as I'll use the 4x4' pieces for gussets, etc.
Just wondering...
Fred B.
La Crosse, WI
From: | Dave and Connie <dmatt(at)frontiernet.net> |
Subject: | Re: Fuselage sides |
Fred,
Worst case you could scarf them. It is not all that hard to do with a hand
plane or a router jig. It is done for building stitch and glue kayaks and
canoes.
Dave
>sheets. If it's not a good idea that's okay as I'll use the 4x4' pieces
>for gussets, etc. Just wondering...
>Fred B.
>La Crosse, WI
If it is a scarf joint 12 to 1 See AC 43.113-1b for details.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
Sent: Sunday, October 17, 2004 9:29 AM
Subject: Pietenpol-List: Fuselage sides
Is it okay to splice the fuselage side plywood at an upright? I purchased some
4x4' pieces of ply from McCormicks -- they didn't have any 4x8' sheets. If it's
Just wondering...
Fred B.
La Crosse, WI
I did. I butted mine together on top of a diagonal or upright. Glued a corresponding
strip of 1 1/2 inch plywood over the butt joint and seems to work ok.
If it's under the fabric nobody sees it. And the glued area doing it this
way is as good or better than the scarf.
My opinion.
Bert
Just wondering...
Fred B.
La Crosse, WI
Hi Fred
I spliced ours at a upright.
I scoffed the joint so it is hidden behind the upright.
Used a radial arm saw with a sanding disk instead of a blade .
Set the saw about 3 degrees of horz.
Dale Mpls
not a good idea that's okay as I'll use the 4x4' pieces for gussets, etc. Just
wondering...
Fred B.
La Crosse, WI
From: | "Richard Navratil" <horzpool(at)goldengate.net> |
I dont see that should be a strength issue.
Dick
Just wondering...
Fred B.
La Crosse, WI
In a message dated 10/17/2004 2:50:25 PM Central Standard Time,
ddjohn(at)earthlink.net writes:
Did mine on a diagonal for more surface. Dale, how did you get yours BEHIND
the upright??
In a message dated 10/17/04 9:52:28 AM Central Daylight Time,
cgalley(at)qcbc.org writes:
<< If it is a scarf joint 12 to 1 See AC 43.113-1b for details.
Cy Galley - Chair,
EAA Sport Pilot
If it's not a good idea that's okay as I'll use the 4x4' pieces for gussets,
Fred B.
La Crosse, WI >>
I agree with Cy. The only acceptable way to join plywood, or any length of
wood for that matter, is to use the Scarf Joint, as described in AC 43-13
Chuck Gantzer
Subject: | ordering the covering |
I'm excited... I'm going to place an order for covering/chemicals sometime this
or next week. Covering begins soon!!!! yeeehawww!
DJ
_
( NO FILES AT...
Subject: | Re: Plotting Coordinates for Pietenpol Wing Rib ( NO FILES |
AT...
John,
Could you post these files to matronics file share or mykitplanes.com? I
would like to have access to them. Thanks for going to the trouble.
Terry
I was just looking over 3 pc plan and wondering, how do you lead the aileron cable
through the turning pulley and attach the wing? To clarify, the swedge turnbuckle
end are too large to fit thru the pulley. Do you have to unbolt the
pulley or is it typical to add a linkage at the wing side? I don't see anything
on the plan about this.
Dick
From: | "Jack Phillips" <pietflyr(at)bellsouth.net> |
Dick,
I made my aileron cable system with a total of 7 separate cables. Two in
each wing, plus two short cables going from the control stick torque tube
through the centersection, plus a separate cable through the centersection
for the return cable. Yours may vary. Mine was made more complicated by
the avionics in the centersection, which restricts access somewhat.
If you are planning on unbolting the centersection pulleys to pass a cable
through, you need to have the pulley bolts fastened with nutplates so you
can get the bolts in and out (at least on mine, with a fuel tank just
forward of the centersection spar).
Put a couple more hours on mine this weekend - up to about 5 hours on it
now. Wonderful fun, flying an open cockpit airplane on a crisp fall day.
As Walt Evans says, "Ain't life GRAND!"
Jack Phillips
Raleigh, NC
-----Original Message-----
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Richard
Navratil
Subject: Pietenpol-List: 3 piece wing
cable through the turning pulley and attach the wing? To clarify, the
swedge turnbuckle end are too large to fit thru the pulley. Do you have to
unbolt the pulley or is it typical to add a linkage at the wing side? I
don't see anything on the plan about this.
Dick
Subject: | Re: 3 piece wing |
Unbolting the pulleys is how we handled this issue. Access panels were built into
the underside of the center section, aft of the rear spar to reach this area.
Another good reason to build a one-piece wing.......
Greg Cardinal
Sent: Sunday, October 17, 2004 10:59 PM
cable through the turning pulley and attach the wing? To clarify, the swedge
turnbuckle end are too large to fit thru the pulley. Do you have to unbolt the
Dick
Subject: | Re: material sent |
Received Friday in good shape. Thanks
Corky
( NO FILES AT...
AT...
In a message dated 10/17/04 9:54:28 PM Central Daylight Time,
<< John,
Terry >>
John,
Me too !! Thanks
Chuck G.
Greg
I have a one piece wing on mine, it's a lot to handle in mounting. Thats why I'm
doing a 3 piece this time.
Something like what Jack suggests with seperate sections is the way I'll go.
Dick
Sent: Monday, October 18, 2004 7:00 AM
Subject: Re: Pietenpol-List: 3 piece wing
into the underside of the center section, aft of the rear spar to reach this
area.
Greg Cardinal
the pulley or is it typical to add a linkage at the wing side? I don't see anything
Dick
Dick,
I used Mike Cuy's advice, and don't regret it. Just marked each cable end and
left it rolled up in the root of the wing. After installing wings for the final
assy, simply measure the cables and install eyes and bolt up. This included
the turnbuckle in the overhead, and both cables comming down to the torque
tube. This allowed for smaller holes in the cowl, and if I ever had to dissassemble,
just cut the cables near the eyes and add more eyes later to reattach.
Yes, Life IS grand!!
walt evans
NX140DL
Sent: Sunday, October 17, 2004 11:59 PM
Dick
From: | Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov> |
Subject: | wing cables---sketch attatched |
Walt--- glad things worked out for you w/ the 3 pce wing rigging/cable set
up. Here is a chicken-scratch sketch I drew
up a few years back. Nothing fancy. I figure that if I ever ding a
wing or have to take the wings off I'll just cut the cables
and either add more cable or just re-string new cables. (used 3/32" diam.
cables)
Mike C. in Ohio
What's Kip G. been up to ?
From: | "Carl D. Vought" <carbarvo(at)knology.net> |
Subject: | Re: ordering the covering |
Have you ever done this? If not, I predict that after you get over the
initial reticence, you'll love it!...Carl Vought
sometime this or next week. Covering begins soon!!!! yeeehawww!
> DJ
> _
Subject: | Re: wing cables---sketch attatched |
Mike,
Exactly what I did after talking to you. Great to get outside advise when
I'm starting to go on a tangent. If someday I have to take off the wings,
It would only take me an hour tops to reassemble on the next site.
walt evans
NX140DL
From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov>
Subject: Pietenpol-List: wing cables---sketch attatched
> cables)
> Mike C. in Ohio
Subject: | Ford engine location |
G'day mates!
I'm getting ready to begin installing my Ford engine, but after perusing the plans
can't seem to find a measurement for how far forward of the firewall it goes.
Am I missing something?
Douwe
Subject: | The UK Pietenpol Club Web Site--- good ! |
<000801c4b4c6$e439e420$0600a8c0@laptop>
Guys-- this is a pretty neat web site for what's happening in the Pietenpol
world over in jolly old England !
Mike C.
http://www.pjshenton.go-plus.net/default.htm
Actually, I think the UK site has been updated and redesigned, with a
different address
http://www.pietenpolclub.co.uk/
Still very good.
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Michael D
Cuy
Subject: Pietenpol-List: The UK Pietenpol Club Web Site--- good !
Mike C.
Subject: | Re: The UK Pietenpol Club Web Site--- good ! |
Great site Mike, now bookmarked.
Doc
> Mike C.
> Contributions
> any other
> Forums.
Subject: | Re: Ford engine location |
The dimensions of the engine bearers specify the location of the clearence
cutout for the oil pump bulge in the oil pan, which, in turn, determines
the engine placement..right?...Carl Vought
wrote :
> G'day mates!
the plans can't seem to find a measurement for how far forward of the
firewall it goes.
> Douwe
Carl is correct on this. Just work between dwgs #6 & #8. After you have
enlarged the four pan-mounting holes to 5/16- inch as indicated just hold your
engine bearer up against the oil pump housing and transfer the hole locations.
Voila !! Now,see all of the fun you'd be missing with a kit built plane !!
Don Hicks
In order to reduce the download time, I'm breaking this up into two
messages. The subject of the second message which I will send next is
rudder control on the Air Camper. First message:
1)I'm considering outfitting my engine for dual ignition by buying a head
from Dan Price [www.dan4banger.com]. He offers an aluminum 6:1 compression
head with two 14mm sparkplugs per cylinder. I presume the 14mm referrs to
the plug diameter, but I don't know. Does it? The original plugs for that
engine were 7/8" diameter, 14 threads per inch. Is there a problem with
using a smaller plug? I will drive one mag with a "side drive" unit that I
got from Ken Perkins. The second mag will be driven directly off the
crankshaft in the traditional manner.
2)Is there anyone out there who knows Dan Price and can recommend his stuff?
Thank you very much...Carl Vought
Subject: | Aircamper rudder control |
Hi Pieters...I'm rigging my Aircamper. Just finished the hardwire on the
tail and the flexible cable on the stick/elevator. As I was about to
connect the cable from the rudder horn to the pedals, I did a dry run with
a string. The plans are vague on the routing of the rudder cables, but if
you plan to run them direct, they will have to go through the back of the
pilot's seat, close to the sides of the cockpit. There were two things I
didn't like about that arrangement. First, I'd rather have them out of the
way, running just above the floor, under the seat, not through it. Second,
I'd prefer a rudder bar instead of the pedals that are already there. What
I plan to do is leave the pedals as is and instal a rudder bar behind the
seat, close to where the bellcrank (or walking beam) for the elevator is
located and two inches above the surface of the longerons. I'll run cables
from this "rudder bar" to the pedals and from the rudder bar to the rudder
horns. This will put the cables where I want them withour adding pullies
and the rudder bar will isolate heavy foot pressures from the rudder horns.
This arrangement also provides a better routing of the rudder cables
through the fabric and fuselage structure (no rubbing). Maybe this is a
common practice? Maybe some of you know why it's a bad idea. I would
appreciate any comments you have..Thank you, Carl Vought
Hello Pieters.....I wrote this long email earlier today and as far as I can
tell, It went into the garbage instead of onto the net. It concerns my
engine. I'm considering rigging my engine for dual ignition. I can get an
aluminum head weighing 13 pounds, with a 6:1 compression ratio and two
plugs per cylinder from Dan Price (www.dan4banger.com). I will run one mag
off a side drive which I got from Ken Perkins and the other will be driven
directly off the crankshaft as shown in the Hoopman drawings. There are a
couple of uh-ohs. One is that the head is machined for 14mm plugs. The
original plug was a 7/8"X14TPI plug. Is there any problem with using this
small plug? Another open question is: Have they gotten higher compression
by reducing or eliminating carbon clearance space by lowering the clearance
between the head and the piston at TDC? Can anyone comment on their
experience with this company?...Thank you...Carl Vought
Subject: | Re: Bingelis' Weight and Balance form |
Have any of you looked closely at Bingelis' weight and balance form for the
Emeraude (page 298 of the Sportplane Builder" book - that's the blue one)?
If you look in the top box - where it calculates the empty weight, it sure
seems to me that the moment for REMOVING the oil should be POSITIVE 208.8
inch pounds. Instead of Negative 208.8 inch pounds.
I've done this every way I can think of and the only way that seems like it
fits is if it's Positive, Can't tell about the ballast because he doesn't
say where it's located but if it's in front of the datum it should be
positive too.
Maybe I missed something - or else it's a mistake.
PS
I included a picture of Larry Harrison's Flying Flea - We did the W&B on it
Sunday. By the way, he's started on yet another Piet. It's gonna be sweet,
too. Got the fuselage complete. Wing's already built.
Subject: | Re: Model A engine |
I, too, am most anxious in what answers or suggestions
come from this.
> Vought"
> net. It concerns my
> for 14mm plugs. The
> comment on their
> Vought
> Contributions
> any other
> Forums.
Larry Nelson
Springfield, MO
Beechcraft Bonanza V-35B N2980A
Pietenpol Air Camper N444MH
1963 GMC 4106-1618
SV/ Spirit of America
ARS WB0JOT
In a message dated 10/19/04 12:19:37 PM Central Daylight Time,
Waytogopiet(at)aol.com writes:
<< Carl is correct on this. Just work between dwgs #6 & #8. After you have
your
locations.
Voila !! >>
Douwe,
The only think I might add to what Carl & Don explained, is that if you weigh
consideribly more than B.H.P., you might consider making the mount an inch or
so longer, for weight & balance purposes.
Chuck G.
Subject: | ford engine placement |
sorry, disregard.
I found on the plans a way to figure it out.
Douwe
Dick,
Mine has simple linkage for disconnecting.
Ted
aileron cable
turnbuckle
anything
> Dick
Subject: | Re: Aircamper rudder control |
Carl,
I suggest you just rig the rudder bar per plans, and run the rudder cables
down low near the floor under the seat. Acording to AC 43.13 you can use
hardwood (not pulleys) as a fairlead, if the deflection is less than 7 degrees.
Chuck G.
Subject: | Re: Bingelis' Weight and Balance for |
In a message dated 10/19/04 6:13:20 PM Central Daylight Time,
bconoly(at)earthlink.net writes:
<< If you look in the top box - where it calculates the empty weight, it sure
inch pounds. Instead of Negative 208.8 inch pounds. >>
Bert,
I don't see where it says anything about a Negative 208.8 inch pounds. I see
where the oil was removed : -7.20 X -27.0 = Positive 194.40 inch pounds.
E.W.C.G. is 9.69 inches.
Chuck G.
Carl-- I used two nylon pullies under my seats and nylon/teflon fairleads
on the
fuse sides near where the cables exit the fuselage.
Mike C.
Hmmmm Mine say -7.2 and - 29 giving 208.8 but it's listed as Negative
208.8. I wonder if I havean older edition or something with an error? Mine
says first edition, second printing.
Thaanks
Subject: Re: Pietenpol-List: Re: Bingelis' Weight and Balance for
sure
> Bert,
see
> Chuck G.
Subject: | Tractor type prop wanted |
I'm looking around for a wood or metal tractor type prop for my winter Piete project,
using a Lycosaur 0-235. Anybody who hasn't converted their dreams into
a lovely clock, contact me off line.
Thanks-Gordon Bowen
In a message dated 10/20/04 9:06:44 AM Central Daylight Time,
<< Hmmmm Mine say -7.2 and - 29 giving 208.8 but it's listed as Negative
says first edition, second printing. >>
Mine says:
Less Oil -7.2 -27.00 194.40
In the bottom left corner of this page it says: Revised 1-19-87
I can't find anywhere in the front of the book, or on the cover, where it
says what printing it is.
Chuck G.
Subject: | Re: Model A head |
Carl,
I bought a Dan Price head, and found the quality very good. These products
have been around for awhile, so the bugs are probably all worked out. When I
used this higher compression head, I had to use two head gaskets, because the
tops of the pistons protruded up past the deck of the block. This was
probably
due to the fact that the top of my block had probably been surfaced ground at
some point in it's life. The 6:1 head is machined flat, with dished out room
just in the area where the valves stick up. I ran, and flew the plane in
this configuration for maybe 10 hrs, but then went back to the stock cast
iron
head, and one head gasket. The main reason I went back to the cast iron head
was for W & B reasons. I could not tell any difference in performance
between
the higher 6:1 head, and the stock 4.8:1 head. I used only one Wico magneto,
driven off the crank the way the plans show.
I can't see any problems with the different size plugs, but you may have
to experiment with the heat range of the plugs. It seemed like my Model A
plugs didn't last very long. I would have trouble starting the engine,
change
the plugs, and it would start right up.
Chuck G.
Just a suggestion, but I suppose string is going to be run to make
sure all the framework is going to be cleared?
My share of silly mistreaks I'd gladly trade for chocolate cake.
But then I'd never fit in the plane!
Clif
> on the
> Mike C.
First of all, thanks to those who responded to my email. Yep..I run a tight
string between the intended attachment points of the cable, just to check
out the clearances. In the case of the rudder cable, I had to run the
string (on the outside of the fuselage) between the rudder horn and a point
corresponding to the position of the lug on the rudder pedal. I have every
intention to be faithful to the original plans, but I'm dealing with an
abandoned project and the builder who preceeded me did a first class job of
installing pedals AND the front seat. I could have ripped out the front
seat to access the pedals to remove them and install a rudder bar, but I'm
unwilling to do that...Carl
> Clif
fairleads
> > on the
> > Mike C.
From: | "Norman Stapelberg" <norshel(at)mweb.co.za> |
Hi Gordon
That power plant is that not a Lycoming 0-235, if it is e-mail me off
line as I also have one installed we can swap notes. I am running a 74"
dia by 44" pitch, on my next prop I am going for is a 76" dia by 42"
prop. With my prop I get 2300 rpm static, with the GSC I ran I also got
2300RPM static and cruised at 85mph indicted at 2300rpm,
The prop did not seem to unload enough, you should try to get 2400
static.
Cheers
Norman Stapelberg
South Africa
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gordon
Bowen
Subject: Pietenpol-List: Tractor type prop wanted
Piete project, using a Lycosaur 0-235. Anybody who hasn't converted
their dreams into a lovely clock, contact me off line.
Thanks-Gordon Bowen
Subject: | Re: Tractor type prop wanted |
Norman,
Thanks for email. I'm really attempting to use a Lycosaurus O-235, this engine
is an original pre WWII from Lycoming. 100 HP. I'm going to forward to you
an email I got from Jay Anderson in Texas that builds props. He also recommends
76" with 42-44 pitch.
Gordon
Sent: Friday, October 22, 2004 9:43 AM
Subject: RE: Pietenpol-List: Tractor type prop wanted
Hi Gordon
That power plant is that not a Lycoming 0-235, if it is e-mail me off line as
I also have one installed we can swap notes. I am running a 74" dia by 44" pitch,
on my next prop I am going for is a 76" dia by 42" prop. With my prop I get
2300 rpm static, with the GSC I ran I also got 2300RPM static and cruised at
The prop did not seem to unload enough, you should try to get 2400 static.
Cheers
Norman Stapelberg
South Africa
From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gordon Bowen
Sent: 21 October 2004 03:12 AM
project, using a Lycosaur 0-235. Anybody who hasn't converted their dreams into
Thanks-Gordon Bowen
From: | "Jake Crause" <admin(at)homebuiltairplanes.com> |
Subject: | Bending Allowances |
report
Got a question about bending allowances. Do the drawings of the
fittings that need to be bent already take into account bending
allowances or do I need to calculate them and adjust the dimensions of
the drawings accordingly.
Also, is there a spacer of some sort between the cabane fitting and the
spar where the fitting does not overlap the spar butt joint strap and
the pulley bracket? If so, what is it?
Thanks in advance.
Jake Crause
From: | "Jim Markle" <jim_markle(at)mindspring.com> |
Subject: | My Pietenpol Air Camper tires arrived today!!! |
Got home from a business trip today to find a couple of 21" Speedmaster Tires waiting
for me.....
My garage is SO full I won't be able to roll the fuse far but I WILL be able to
roll it before long....
I feel like such an idiot for getting excited over a couple of dumb old motorcycle
tires showing up at my doorstep but it almost brought tears to my eyes.....
This is SO much fun!
Life is good......
Jim in Plano.....
Subject: | Re: My Pietenpol Air Camper tires arrived today!!! |
Hey Jim,
I know what you mean buddy..... every single order I ever placed (probably over
100) for anything had me counting the minutes until the UPS guy arrived....
even for stupid stuff like a handfull of AN970 washers and a bag of cotter pins.
DJ
Sent: Friday, October 22, 2004 7:14 PM
Subject: Pietenpol-List: My Pietenpol Air Camper tires arrived today!!!
waiting for me.....
to roll it before long....
Life is good......
Jim in Plano.....
Subject: | Re: Bending Allowance |
Jake:
Tony Bengelis covers this in his book "Sportplane Construction Techniques" by telling
us to make the bends first and then the ends are measured to see how much
to cut off. Also, he never drilled any holes until after the bends are made.
(page 40) Quote from Tony..."There you have it.....a fitting with the correct
height and base dimensions." Not a very professional way to make fittings, but
they will be accurate...consistently more accurate than many you'd make using
the metal working formulas involving bend allowance charts, setback tables
and that sort of thing."
Regarding the spacer: Look just to the left of the line giving the dimension "3-1/4"
between the two end attach holes of the pulley bracket and it calls out
3/32" ply both sides. If I interpret the plan correctly this 3/32" ply would
be shaped like a piece of pie...the bottom flush with the spar and the top would
be against the spar joint strap.
Finally...I hope this helps....and I can't say enough about how much Tony's books
have been so helpful to this amateur plane builder.
Subject: | Re: Bending Allowances |
In my opinion the drawings do not include bend allowances. Also, lots of people
have said to make the fitting's a tad bit longer (so they stick out more).
I guess it's hard to get the bolts in once the plane is finished.
Chris Tracy
Sacramento, Ca
Sent: Friday, October 22, 2004 6:36 PM
Subject: Pietenpol-List: Bending Allowances
Got a question about bending allowances. Do the drawings of the fittings that
need to be bent already take into account bending allowances or do I need
to calculate them and adjust the dimensions of the drawings accordingly.
Also, is there a spacer of some sort between the cabane fitting and the spar
where the fitting does not overlap the spar butt joint strap and the pulley
Thanks in advance.
Jake Crause
Eeexxxcceeelllleeennntt! Keep me appraised!
Our learning curve on covering is coming along nicely...I might try to go to
the panhandle next week, we'll see.
Isn't this great, stay with it and good luck,
md
<001301c4b8ac$4f403470$0100a8c0@Desktop>
I wonder what the Plano cops are gonna say.......
Clif :-)
Sent: Friday, October 22, 2004 7:59 PM
Subject: Re: Pietenpol-List: My Pietenpol Air Camper tires arrived today!!!
Hey Jim,
over 100) for anything had me counting the minutes until the UPS guy arrived....
pins.
DJ
waiting for me.....
Life is good......
Jim in Plano.....
From: | "Dick and Marge Gillespie" <margdick(at)peoplepc.com> |
Subject: | Razorback Covering |
List,
Looking for info on Razorback covering. Instruction manual and supply sources.
Dick G. in Ft. Myers, FL
Subject: | [ Galen (Doc) Hutcheson ] : New Email List Photo Share |
Available!
From: | Email List Photo Shares <pictures(at)matronics.com> |
A new Email List Photo Share is available:
Poster: Galen (Doc) Hutcheson
Lists: Pietenpol-List
Subject: Biplanes
http://www.matronics.com/photoshare/wacopitts@yahoo.com.10.23.2004/index.html
o Main Photo Share Index
o Submitting a Photo Share
If you wish to submit a Photo Share of your own, please include the
following information along with your email message and files:
2) Your Full Name:
3) Your Email Address:
Email the information above and your files and photos to:
Subject: | good price for REAL Pietenpol plans on ebay now |
just spotted this auction:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2496643097&category=26441&sspagename=WDVW
Subject: | N 40044 for sale |
Hello pieters,,, I know I haven't been on here much lately,,, though I do enjoy
reading all
the continuing news about everyones piets. Lately my health has not been what it
should to be in the air and money has been tight. So I think it's time to put my
plane up for sale. It's about an inch away from being inspected and flown. I had
planned
on putting it on ebay but I thought I would throw it out in here first.
I have some pics on a website,,
you can check it out. It is hangered in Blissfield Michigan. That's the lower SE
corner
of the state. I'll be starting the bids on ebay at $7000 which I feel is reasonable.
That's a little less than what I have in it. When things get turned around,, well,,
I'll probably
start building another one,,, that was most of the fun...
Well,,, just wanted to throw this out here before she went on the block.
Carl
Subject: | Re: Razorback Covering |
Why do you want to use a system that is not very forgiving? A rank amateur can
do the heat shrink processes but not Razorback. Razorback is also heavier than
cotton and twice as heavy as polyester. You want your airplane to be light and
forgiving.
Cy Galley - Chair,
EAA Sport Pilot
Sent: Saturday, October 23, 2004 7:14 AM
Subject: Pietenpol-List: Razorback Covering
List,
Subject: | [ Mark Hodgson ] : New Email List Photo Share Available! |
Poster: Mark Hodgson
Subject: More Brodhead 2004
http://www.matronics.com/photoshare/mhodgson@bu.edu.08.07.2004/index.html
2) Your Full Name:
now
Subject: | Re: good price for REAL Pietenpol plans on ebay now |
Anybody check out the price these things are going for? $96 when I just looked
at it. I don't know what Don is charging for plans lately, but I think I only
paid him $75 for mine.
Jack
Really enjoying the delightful flying qualities of my Air Camper
> From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
> Date: 2004/10/25 Mon PM 01:57:18 EDT
> Subject: Pietenpol-List: good price for REAL Pietenpol plans on ebay now
report
Tracy thanks for the reply. After looking at the plans a bit closer
and thinking about it a bit longer, I see that you are right. I do plan
on adding about 1/2 inch to some of the fittings where it looks like it
might be a close fit getting the bolt into the hole due to fabric or
other obstructions.
Is a 1/2 inch appropriate in most cases anyone? Thanks.
Jake
From: Catdesign [mailto:catdesign(at)intergate.com]
Subject: Re: Pietenpol-List: Bending Allowances
of people have said to make the fitting's a tad bit longer (so they
stick out more). I guess it's hard to get the bolts in once the plane
is finished.
Chris Tracy
Sacramento, Ca
Thanks in advance.
Jake Crause
"Email List Photo Shares"
Available!
Subject: | Re: [ Mark Hodgson ] : New Email List Photo Share Available! |
Mark,
Great pictures!
I got a kick out of them.
walt evans
NX140DL
From: "Email List Photo Shares" <pictures(at)matronics.com>
Subject: Pietenpol-List: [ Mark Hodgson ] : New Email List Photo Share
Available!
> 1) Email List or Lists that they are related to:
> 2) Your Full Name:
> 4) One line Subject description:
> 5) Multi-line, multi-paragraph description of topic:
> 6) One-line Description of each photo or file:
Cy,
I bought a hurricane damaged piet. The wings will be recovered with Polyfiber
but there's only a couple of small patches to be made in the fuse. I would like
to find the best way to repair them and not have to recover the whole fuse.
The razorback seems to be in good condition after 20 years and really looks
good. If you could provide a source of information, I'd really appreciate
it.
DickG. in Ft. Myers, FL.
Sent: Monday, October 25, 2004 2:26 PM
Subject: Re: Pietenpol-List: Razorback Covering
and forgiving.
Cy Galley - Chair,
EAA Sport Pilot
List,
now
Hello!
Last year, I bought a complete set of "new" plans from Don Pietenpol for $165.00
including postage. This price included all plans with mods for extended fuselage
and the steel tubing fuselage, all with the complete builders and flyers
manual.
Fair winds to all,
Jim Courtney
jbciii5656(at)yahoo.com
Jack
> From: Michael D Cuy
Express yourself with Y! Messenger! Free. Download now.
I was just in Photo share looking at Shawn Wolks' post from last winter, of his
Piet on skiis. Are there plans available for building snow skiis?
Dick N.
<00d501c4baf0$6378e040$7d81bd3f@dickmarg>
I sent your request on to rec.aviation.homebuilt where the razorback owner sometimes
makes an appearance. They are located in Manila, Arkansas.
Sent: Monday, October 25, 2004 7:06 PM
Cy,
like to find the best way to repair them and not have to recover the whole fuse.
it.
List,
Henry,
I suggest that you plan to use the insulation blanket in a "sandwich"
assembly between plywood firewall and sheet metal (stainless or galvanized steel).
In my case, the original fuselage builder used a 1" thick solid plywood
firewall. So for weight savings, I ended up cutting lightening holes in it. So
I
plan to use a very light gauge sheet metal backing to prevent the ceramic fibers
from molting off inside the cabin. Since the ceramic fiber material can
compress, I believe it would be natural for it to compress from 1/2 inch down to
about 1/4 inch. This should work just fine, but the less you compress it,
probably the better job it will do as an insulator. Spacers would help ensure
that you don't compress the material excessively. I don't think it's necessary
to use an adhesive like liquid nails. Instead, I think screws with large
light-weight wachers or even staples would suffice to hold things in place until
you can attach your sheet steel firewall. The sheet metal should be designed to
permanently clamp the blanket in place and hold it against the wood. The
engine mount attach fittings pose a challenge for trimming and fitting the sheet
metal firewall, but I expect to have to do some creative bending and
attachment in that area to keep as much insulation material against the wood as
possible. Keep in mind the intent of the insulation when you are designing your
parts and you'll do fine.
I hope this helps.
I am copying this letter to the Pietenpol email list since there were several
who bought the ceramic material from me.
Terry B.
In a message dated 10/25/2004 7:54:20 PM Central Standard Time, Borodent
writes:
> Subj:Re: mat'l sent
> Date:10/25/2004 7:54:20 PM Central Standard Time
> From:Borodent
> To:BARNSTMR
> Terry
> material arrived
> many thanks
> Henry Williams
> I have some questions,
> Do I take it from the plywood firewood forward; ------
> next: the material - insulation
> next: the (Im using stainless) steel
> Do you screw the stainless down to the plywood, or use spacers- to keep the
> insulation from compressing excessively. If so what dimension would you want
> for the insulatiuon ( 1/4 in? 1/2 in? thick )
> And I guess you just come as close as possible to the engine mounts with the
> insulation and stainless.
> Would you glue the insulation to the plywood say with liquid nail?
> OR do you have a source, where I can check on the insulation?
> Henry W
From: | "Oscar Zuniga" <taildrags(at)hotmail.com> |
Mike wrote-
>Congratulations, Walt--- you are young for being a grandpa !
Well, I'll show you mine if you show me yours ;o) Our grandson, now 3-1/2,
was born when I was 49. Of course, I was 17 and my wife 16 when we got
married in 1969. By the grace of God and the patience of my dear wife, we
are still together after 35 years and will be till death do us part...
I don't take too many unnecessary risks when I go flying, because I always
think about that wonderful wife waiting for me at home (and the dog doesn't
sleep too well when I'm not there, either ;o)
Oscar Zuniga
San Antonio, TX
mailto: taildrags(at)hotmail.com
website at http://www.flysquirrel.net
Unless you must build it yourself. There are plenty of old factory built skis
available that will work well on a Piet. There's two sets on EBAY right now
at reasonable prices. I htink it would be difficult to build skis as light and
strong as the factory made stuff. If you must build, make your own tail ski,
or wheel penetration tailski.
And yes I'm ready for the flying this winter again.
Shawn Wolk
C-FRAZ
Subject: | web site for my piet |
Here is the website for my piet.
http://members.core.com/~skycarl/pietpage12.html
Thanks,,
Carl Loar
Folks;
I've thought about, and prepared, my M-19 "Flying Squirrel" for both floats
and skis. My thought on the skis was to incorporate a set of used
snowboards, but those are quite flexible and pretty large unless you're
operating on deep powder snow.
There are a couple of photos of skis that I thought I'd pattern mine from,
on my website at http://www.flysquirrel.net/floats/ski.jpg and
http://www.flysquirrel.net/floats/ski1.jpg if someone just wants to gather
ideas.
These skis slip onto the same axles as the wheels on your landing gear...
NOT penetration skis that go on over the tires.
I guess the best thing to do is to fly in to the winter ski deal at Oshkosh
to get ideas and take pictures of other ski setups. February, is it?
Oscar Zuniga
San Antonio, TX
Skis...........................................in San
Antone....................................... ease off on those Coronas or
whatever.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Corky,
Oscar's probably talking about water skiing on the Rio San Antonio. He does love
that Riverwalk jazz festival.
Sent: Tuesday, October 26, 2004 1:10 PM
Subject: Re: Pietenpol-List: snow skis
Skis...........................................in San Antone.......................................
ease off on those Coronas or whatever.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mike Cuy,
Do you have a scan of your leading edge drawing? I know of a couple of people who
are interested in your technique using handrail to form the LE.
Greg Cardinal
Project update: Dale and I have taxied NX18235 under its own power. A very BIG
milestone. Just waiting for the final inspection and hoping for a first flight
before the weather gets too cold.
Howard, Did Doc ever reply to you?
There are several of us around that have GNs. I could probably connect you with
somebody if you want to talk about them.
Bert
Tallahassee FL
Sent: Sunday, July 25, 2004 4:56 PM
Subject: Pietenpol-List: gn-1s.
Doc, Any GN-1s at Broadhead? I'm new to the list and Pietenpols in general,
but I wonder why I never see much about the GN-1 which I understand is a "modern"
version of the Piet.
Howard Bissell
Hi Bert, Howard,
This is one "Doc" but I'm not sure you are addressing
me. I see your question was about Piets at Broadhead.
I truely don't know since I have never been there. I
have only been a member a couple of months. I have
heard through this newsgroup that GN-1's do go to
Broadhead, but there are others who can tell you much
more about that. If I am the wrong "Doc" please
forgive my intrusion, but if you are new to the group,
welcome and nice having you aboard. I will happily
answer any questions I can.
Doc
> could probably connect you with somebody if you
> Bert
> Tallahassee FL
> From: lanny bissell
> and Pietenpols in general, but I wonder why I never
> "modern" version of the Piet.
> Howard Bissell
Subject: | Re: web site for my piet |
Hi Carl,
GREAT PICS!!! Thanks for sharing them.
Doc
> Thanks,,
> Carl Loar
Subject: | RE:piets near Tulsa |
Subject: Re: Pietenpol-List: gn-1s.
> Hi Bert, Howard,
> Doc
> > Bert
> > Tallahassee FL
> > From: lanny bissell
> > Howard Bissell
Hello,
I'm sure there are folks out there that have been to Brodhead many times more than
I. I don't recall seeing more than one GN-1 there each time I have been.
Also I never saw it parked with the Piets but on the other side of the field.
I believe I saw a remark somewhere (possibly on the Piet list) by some GN-1 owner
saying they didn't feel welcome. This is very unfortunate because IMHO most
Piet owners don't feel that way, it is those very vocal few that are the problem.
Anyway a trip to Brodhead is well worth it, 99 percent of the people you
will meet there are super.
Bob B. - Missouri
BTW I don't even bother with that other Wisconsin Flyin anymore.
Sent: Wednesday, October 27, 2004 12:12 AM
Hi Bert, Howard,
Doc
> Bert
> Tallahassee FL
> From: lanny bissell
> Howard Bissell
From: | "Douwe Blumberg" <douweblumberg(at)earthlink.net> |
I seem to remember this topic a while back, but does anyone have good suggestions
for a light plastic tube that could be glued next to the fuselage side stringer
under the covering to run the mag wires up through?
I think I'd like to use a conduit type arrangement rather than affixing the wires
in case I should ever have to fix or replace them without ripping off the covering.
Thanx!
Douwe
Subject: | Re: RE:piets near Tulsa |
Not sure what's up with the "piets near Tulsa" subject but if someone's
interested, there are several in the area, including at least one GN1 (pic
attached and size reduced for quicker D/L). I included a pic of the tail
number if someone wants to look up the owner on landings.com
Also, try contacting EAA Tulsa Chapter 10: http://www.eaa10.org/index.htm
Actually, there's a LONG history of Pietenpol support in the Tulsa (MY
hometown) area. Those folks have known about the Pietenpol for a LONG time!
Jim in Plano.....
Subject: Pietenpol-List: RE:piets near Tulsa
> From: Galen Hutcheson <wacopitts(at)yahoo.com>
> To:
>> Hi Bert, Howard,
>> Doc
>> > Bert
>> > Tallahassee FL
>> > From: lanny bissell
>> > Howard Bissell
Subject: | Re: Leading edge |
Way to go, Greg and Dale! I hope you can get NX18235 in the air soon. I have
about 6 hours now on NX899JP and have flown it comfortably in temps as low as
43 F. As Walt says, Ain't Life Grand!
Jack Phillips, Raleigh NC
> From: <gcardinal(at)mn.rr.com>
> Date: 2004/10/26 Tue PM 07:28:02 EDT
> To:
> Subject: Pietenpol-List: Leading edge
> Mike Cuy,
who are interested in your technique using handrail to form the LE.
> Thanks,
> Greg Cardinal
go here and you will see a picture of the conduit I used
http://imagedv.com/aircamper/log/image-pages/09-05-04.htm
I got it from Tap Plastics
http://www.tapplastics.com/shop/product.php?pid142&PHPSESSID20041027075604198496889
$4 for a 6' piece of 3/4" square tubing.
I secured it by drilling and bolting it to the side of the fuse with countersink
screws and lock nuts.
DJ
To: pietenpolgroup
Sent: Wednesday, October 27, 2004 6:13 AM
covering.
Thanx!
Douwe
Hi Bob,
I agree with you. I feel there is no room (for me
anyway) for short-sightedness (for lack of a better
term) in running down someone else's airplane for any
reason (other than gross safety concerns and those
comments should be made only with adequate
documentation and not opinion). If I choose to build
a Pietenpol, and I choose to make safe modifications,
based on many years of aviation experience and
research, then it is my right to do so. I would not
befriend anyone who would run-down someone else's
airplane just because it didn't meet the expectations
of of what that person(s) thought an airplane should
or should not look like or represent. I do hope that
this attitude does not prevail in this group of what
seems like a very decent bunch of aircraft builders
and pilots. (Sorry, but I just felt like preaching
today).
I hope not to offend anyone, but I have seen this
attitude many times in the last 30 plus years of
aviation I have enjoyed.
With respect to all,
Doc
--- baileys wrote:
> Hello,
> Brodhead many times more than I. I don't recall
> been. Also I never saw it parked with the Piets but
> Piet list) by some GN-1 owner saying they didn't
> most Piet owners don't feel that way, it is those
> very vocal few that are the problem. Anyway a trip
> people you will meet there are super.
> Bob B. - Missouri
> Flyin anymore.
> Hutcheson
> Hi Bert, Howard,
> addressing
> Broadhead.
> there. I
> have
> much
> group,
> happily
> Doc
> > Bert
> > Tallahassee FL
> > From: lanny bissell
> list
> never
> > Howard Bissell
> finish.
Galen wrote-
>This is one "Doc" but I'm not sure you are addressing me.
>I see your question was about Piets at Broadhead. I truely
>I have heard through this newsgroup that GN-1's do go to
>more about that. If I am the wrong "Doc"...
Yes, you're the wrong "Doc". He's no doubt referring to Doc Mosher, who
is/was also on this list, and who maintains a really nifty listing of Piets,
Piet owners, N-numbers, and related information. The list is periodically
updated and I believe it does include Sky Scouts and GN-1s if they are
recorded and the data is readily available. And Doc frequents the Brodhead
event since he lives up that way (Oshkosh, I believe).
There has been some hesitancy on the part of some, to recognize GN-1s as
belonging to the Pietenpol group. Most, however, are here to have a good
time building and flying Piets, their offspring, and reasonable facsimiles
thereof, while still respecting the Pietenpol family and their traditional
ownership of the marque.
PS to Doc Mosher: be sure to change the next directory listing to show me as
the new owner of NX41CC!!
Oscar Zuniga
San Antonio, TX
Subject: | SKETCH attachment here----- Leading edge |
Greg-- here you go. Also included the trailing edge idea I used.
PS-- Glad you and Dale are getting close !!!!!
I thought there was probably another (or more) "Doc"
out there, I just hadn't seen him (her) as yet. :) I
responded because I wasn't for sure and wanted to be
friendly. I do respect the Pietenpol markee and
wouldn't expect a very differently built airplane to
be called a Pietenpol. I haven't heard anyone call
the GN-1 anything but the GN-1. I could be mistaken
of course. My "Piet" is going to have some
modifications which to me are minor but to others may
seem more so. The basic design, though, is still a
Piet but with enough dis-similarities to be somewhat
unique. I am encorporating the things that I have
found great about different airplanes I have flown,
things that I found to make some airplanes more unique
than others. I may not end up with a "Piet" by
traditional values, but down, deep inside, it will
still be a "Piet" if nothing more than pure genetic.
Doc (the new guy)
--- Oscar Zuniga wrote:
> Galen wrote-
> addressing me.
> I truely
> go to
> much
> GN-1s if they are
> believe).
> Oscar Zuniga
> San Antonio, TX
> Contributions
> any other
> Forums.
__________________________________
Group,
My nephew is in gradeschool, and is doing a science project on the Pietenpol
Airplane. He is looking for an inexpensive model to build, and information to
write a report. I have directed him to the Family Pietenpol Web site, and
also tried to impress him with the wonderful comradery that this design has
brought upon the generations, but I can't find a model for him to build. Does
anyone know of where a model of a Pietenpol Airplane can be had ?
Chuck Gantzer
NX770CG
Subject: | Re: Pietenpol Model |
In a message dated 10/27/04 9:14:34 PM Eastern Daylight Time, Rcaprd(at)aol.com
writes:
Pietenpol
information
> to
has
> Does
There is/was a Pietenpol cardmodel on the www.fiddlersgreen.com site. Light Aircraft from
Fiddlers Green There is a free J3 Piper Cub download: The Piper Cub Free
downloadable cardmodel model I have built many of them, in different sizes,
using paper from 8.5" x 11" to 3" x 5" card stock. There is also a balsa model
at
: House of Balsa Pietenpol Kit - Kit (ID: 1441), also Peck sells one PECK
PP001. Retail price: $11.88. I believe DJ also has plans for a 1/7 scale
electirc powered RC Pietenpol.
A personal thought on the leading edge material. I went to our local home
center (Menards) and purchased a piece called a brick molding. It goes on a
house at the bottom of the siding above where a brick facing starts. It is
available in long pieces. One piece will do a wing and the center section.
It is finger jointed clear pine. Although it is a strange shape, it is
large enough that a couple passes through the table saw and use of a disk
sander produced a very respectable leading edge. Since it is for exterior
use I assume the glue in the finger joints is water proof. Once the leading
edge is bolted on and covered with aluminum or plywood, a finger joint
couldn't separate if it tried. My project is not completed, but the leading
edge is in place and is going to work fine
Carol and Ralph
Raymond
From: | "DOUGLAS BLACKBURN" <twinboom(at)msn.com> |
Chuck,
On any given day you can usually find a "Peanut Scale" model on E-Bay.
That would be a small rubber band powered model you build much like the real
model. I think it has 26" WS, and you wind it up and off it goes. A very
nice plane covered with tissue after the stick construction is finished.
Chuck, I decided to look before posting, and here you go. Found one.....
5928963200. Go to Ebay and paste this number in and it is just what you are
looking for.
Doug Blackburn
Doug/Elizabeth Blackburn
Yucaipa California
www.inlandsloperebels.com
W.W. conversion manual, #3202,#5782 www.flycorvair.com
>From: Rcaprd(at)aol.com
>Reply-To: pietenpol-list(at)matronics.com
>Subject: Pietenpol-List: Pietenpol Model
>Date: Wed, 27 Oct 2004 21:13:23 EDT
>Group,
>Pietenpol
>to
>Does
>Chuck Gantzer
>NX770CG
I have a set of 1/7 scael plans I drew up a couple years ago for an electric
RC version.
email me off list and I'll email them to you if you'd like.
DJ
djv(at)imagedv.com
_
Subject: RE: Pietenpol-List: Pietenpol Model
> Chuck,
real
are
> looking for.
> Doug Blackburn
> Yucaipa California
> >Group,
> >Pietenpol
information
> >to
and
has
> >Does
> >Chuck Gantzer
> >NX770CG
Chuck,
I've a bunch of spruce left unused from Repiet. If someone would scale it
down and give me a bill of materials I'd be happy to furnish it for the project.
Corky
Chuck,
Dumas Models has a pretty accurate Piet for about $60.00
(30" wing span). Probably too expensive for him though.
Sooo...go to ebay use the search for "Pietenpol."
Normally they have "Peanut Scale" Piets for sale. From
what I've seen they go for about 13-14 bucks.
Stacy
Yep! I forgot about those card models in my other post.
They're pretty darn cool, be great for the kids. BTW, I
found a Wells Fargo Bank on Fiddler's too. By coincidence
it's based on the one in Columbia, CA...I go there every
time I'm back home in CA. There's a GREAT fly-in
campground in Columbia (O22) if anyone's ever in CA I
highly recommend you stop there. Especially in a Piet
(has grass strip)!
Stacy
Hi Chuck,
Peck Polymers makes a "Peanut Scale" (13" wingspan) rubber band powered flying model of a Pietenpol. Check out www.peck-polymers.com and click on kits, then peanut scale. Current price is $12.95. It is a good kit (i've got one, but haven't built it yet) with high quality balsa.
Jack
NX899JP
> Date: 2004/10/27 Wed PM 09:13:23 EDT
> Group,
> Chuck Gantzer
> NX770CG
From: | "Michael Conkling" <hpvs(at)southwind.net> |
Chuck,
If you can't find the Peck kit locally (I kinda know what that answer will
be -- it's not R/C! ;-) -- check on the Penn Valley Hobby Center website for
it -- good prices & wonderful service, just like an old fashioned hobby shop
(or a Piet! ;-)
Mike C.
Pretty Prairie, KS
> Group,
Pietenpol
information to
has
Does
> Chuck Gantzer
> NX770CG
From: | santiago morete <moretesantiago(at)yahoo.com.ar> |
Hello, I need to know what kind of pulley (part number if possible, please) is
used for the control system.
Also, I think most of you are using 1/8 cable for the drag/anti drag wires and
for the flying wires. In my plans is indicated 3/32, something wrong about that?
If I choose 1/8, could be 7X19 or should be 1X19? Thanks to all.
Santiago Morete
Encontr ms informacin aqu.
How are these skis listed on ebay? I searched on "aircraft skis" and got
nothing.
Jim Ash
> built skis available that will work well on a Piet. There's two sets on
> EBAY right now at reasonable prices. I htink it would be difficult to
> build skis as light and strong as the factory made stuff. If you must
> build, make your own tail ski, or wheel penetration tailski.
>Shawn Wolk
>C-FRAZ
Subject: | Re: Pulleys, etc |
Santiago-- I used 1/8" cables for the drag and anti drag wires w/
turnbuckles and also for the X wires that go between the lift struts. From
what I have seen most builders are using this size for these
applications. Some also go with the 1/8" for control cables but I went
with the plans and used 3/32" for all of those----except for the short runs
from the stick to the elevator bellcrank, as per plans. Pullies can be
had in nylon, plastic, phenolic resin, with bearings, without
bearings. You just need to look in a Wicks or Aircraft Spruce cat. to
find the ones you want to use that accept the cable diameter that you will
be using.
Mike C.
PS--- the Tony Bingelis books tell which cables to use to what
applications----like strands, etc. Also I am a firm believer that you
should not use stainless cables
for anything that will experience bends around pullies. Only
galvanized. For fixed, stationary cables it is fine to use stainless.
Thanks Mike. I have read that 1/8 1x19 should be used with
swaged end terminals and you can't form it around a thimble. Is that correct?
If it is, is not an option for me (costs!!)
Saludos desde Argentina
Santiago Morete
Hola Sanitago,
You can form 1/8" 1x19 cable around a thimble, but it is difficult. That's what
I used for my drag and anti-drag wires in the wings and for the undercarriage
brading wires (I used the straight-axle, wire wheel design). I used standard
thimbles and nicopress fittings. The 7 x 19 stuff is nearly as strong and much
easier to work with. If you use the -16 sized turnbuckles, the turnbuckles
will break before the 7x19 cable will. If I were to do it over I would use
7x19.
Jack Phillips
NX899JP
> From: santiago morete <moretesantiago(at)yahoo.com.ar>
> Date: 2004/10/29 Fri PM 01:38:07 EDT
> Subject: Pietenpol-List: Pulleys,etc
> Santiago Morete
Thanks Jack!
What did you used (or recommends me) for the flying wires? I'm about to buy cables,
turnbuckles, etc. It is common practice to use -16 turnbuckles whit 1/8
cable or should I use -22? Gracias.
Santiago
Santiago, de donde es usted? Su ingles is perfecto. Estoy listo volar un version
de un Pietenpol. Estoy trabajando en la pista. Mi email es: dcombs(at)Ltex.net.
Escribemi, por favor in espanol. I necisito la practica. Adios and gracios. Saludos.
Doyle
----- Original Message -----
Sent: Friday, October 29, 2004 3:23 PM
Subject: Pietenpol-List: Pulleys, etc
Thanks Jack!
Santiago
Encontr=E1 m=E1s informaci=F3n aqu=ED.
Santiago,
Use the -22 turnbuckles with the 1/8 cable. I would also recommend performing a
pull test on your cable assemblies. The thimbles have a tendency to deform under
load which would require readjustment after they've been in service for awhile.
Pull testing will deform the thimbles prior to installing them on the airplane
and they won't need readjustment.
Greg Cardinal
Sent: Friday, October 29, 2004 5:23 PM
Thanks Jack!
Santiago
Has anyone out there used a Aviation Metalcraft metalwork kit for thr Piet? If
so what are they like? Just came across them on the web and they look perfect
for anyone thats as lazy as I am.
Here is the link. They don't look too bad.
http://www.aviationmetalcraft.co.uk/index.htm
Thanx
Mike Green
Romsey
Victoria
AUSTRALIA
From: | "Ed Grentzer" <flyboy_120(at)hotmail.com> |
>Date: Fri, 29 Oct 2004 19:23:08 -0300 (ART)
>Thanks Jack!
>cables, turnbuckles, etc. It is common practice to use -16 turnbuckles
>whit 1/8 cable or should I use -22? Gracias.
>Santiago
>lugar.
From: | "Antonio A. Racioppi" <chopo(at)adinet.com.uy> |
Hola a Todos
Mi nombre es Antonio Racioppi, vivo en Mercedes, Soriano, Uruguay, estoy
construyendo un Pietenpol desde hace ya dos aos y estoy leyendo sus correos
desde ese entonces. He aprendido mucho de ustedes, les agradezco mucho.
Ya que Doyle ha pedido que escriba en espaol he decidido hacerlo y ponerme
en contacto, ya que mi ingls es un poco malo.
Saludos
Antonio
Hello to All
My name is Antonio Racioppi, I live in Mercedes, Soriano, Uruguay, I am
building a Pietenpol for already two years and I am reading its mail then
from that. I have learned much of you, I thank them a lot.
Since Doyle has requested that writes in Spanish I have decided to make it
and to put on in contact, since my English is a little bad.
Greetings
Antonio
-----Mensaje original-----
De: owner-pietenpol-list-server(at)matronics.com
[mailto:owner-pietenpol-list-server(at)matronics.com]En nombre de Doyle Combs
Enviado el: Viernes, 29 de Octubre de 2004 09:47 a.m.
Para: pietenpol-list(at)matronics.com
Asunto: Re: Pietenpol-List: Pulleys, etc
version de un Pietenpol. Estoy trabajando en la pista. Mi email es:
dcombs(at)Ltex.net. Escribemi, por favor in espanol. I necisito la practica.
Doyle
Thanks Jack!
buy cables, turnbuckles, etc. It is common practice to use -16 turnbuckles
Santiago
lugar.
Hola Santiago: Estoy en Mercedes, Uruguay, tambin construyendo un Piet.
Tengo tus mismo problemas por los materiales pero lo estoy subsanando con
alternativos.
Saludos
Antonio A. Racioppi
Mercedes Soriano Uruguay
Antonio, usa su ingles en el net. Los miembros son muy buenos hombres y ellos van
a interder su mensaje con poca ayuda. Es un placer conocerle y si usted me
da su email, voy a escribirle solo y n uso el net por cortesia. Mi Piet esta
lista para volar. Necisito un instructor que tiene tiempo en un Piet. Tambien,
necisito una pista que estoy construyendo ahora. Otra vez, gracias por su participacion
en el Piet net. Adios and Saludos.
Doyle
Sent: Saturday, October 30, 2004 6:48 AM
Subject: RE: Pietenpol-List: Pulleys, etc
Hola a Todos
Mi nombre es Antonio Racioppi, vivo en Mercedes, Soriano, Uruguay, estoy construyendo
un Pietenpol desde hace ya dos a=F1os y estoy leyendo sus correos desde
Ya que Doyle ha pedido que escriba en espa=F1ol he decidido hacerlo y ponerme
en contacto, ya que mi ingl=E9s es un poco malo.
Saludos
Antonio
Hello to All
My name is Antonio Racioppi, I live in Mercedes, Soriano, Uruguay, I am building
a Pietenpol for already two years and I am reading its mail then from that.
Since Doyle has requested that writes in Spanish I have decided to make it and
Greetings
Antonio
De: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]En nombre de Doyle Combs
Saludos.
Doyle
Thanks Jack!
cables, turnbuckles, etc. It is common practice to use -16 turnbuckles whit
Santiago
From: | Jim Markle <jim_markle(at)mindspring.com> |
DNA: do not archive
Its-Bogus: do not forward to list
--- MIME Errors ---
A message with no text/plain section was received.
The entire body of the message was removed. Please
resend the email using plaintext formatting.
NOTE! This error can also occur when the poster of the
message has a specific type of computer virus. This virus
WAS NOT forwarded on to the List. The poster should be
informed of the potential problem with their system as soon
as possible.
--- MIME Errors ---
No Jim, we are not idiots, just big kids. I felt the same way about
the J-3 tailwheel leaf spring I got off ebay two days ago. Kind for
like waiting for that balsa order to fix my U-Control airplane back in
junior high school.
(Sure am spending a lot more on these orders now than I did back in
the good old days).
Rick H
> Tires waiting for me.....
> motorcycle tires showing up at my doorstep but it almost brought tears to my
> eyes.....
> Life is good......
> Jim in Plano.....
Rick Holland
Pieters,
Have a new 60" tac drive cable. Was too short for my Repiet, needed 72" which
I bought. Anyone in need of the 60" is welcome to it for shipping costs.
Corky in La
Hello Gang,
Just for curosity sake, has anyone tried or even
considered a little wider fuselage for that skinny
little Piet. Surely in all the hundreds of Piets built
or started, at least someone has thought about it or
maybe even done it. Say maybe 2" or so at the most.
That would make for a lot more squirming around room
inside the cockpit on those long voyages cross
country...you know, with those long range fuel tanks
installed. I realize that everything would have to be
sized up to accomodate the change and there would be
some extra weight, but it's an interesting thought.
The rear cockpit on the Piet is going to be about as
wide as my 1940 Porterfield, and it sure was a little
tight for comfort.
Doc
Y! Messenger - Communicate in real time. Download now.
Hi Doc,
A few thoughts on widening the fuselage. I did that on my Pietenpol, and if
I were to do it over I would still make it wider than plans. I widened mine
by 1", making it 25" wide. Mine is the long fuselage version. I'm 6'2" and
200 lbs and felt I needed the extra room in the cockpit. I have flown short
fuselage, standard width Piets, and they are just a little too tight for me.
There are downsides to widening it, though. They are:
1. Weight. Long fuselage Piets tend to be heavier than standrd length
Piets, most weighing in around 700 to 750 lbs according to Doc Mosher's
survey at Brodhead a few years ago. Making it wider adds more weight. Mine
weighs 735 lbs, which is a tad over 100 lbs heavier than Mike Cuy's. It
shows in its climb performance.
2. Cost. Ol' Bernard knew what he was doing, designing the plane to be as
economical as possible. the stand width allows a 48" sheet of plywood to be
plit lengthwise and make two pieces that will fitthe fuselage. Making it
any wider requires two sheets, with lots of waste.
3. Complexity. Widening the fuselage means the cabane struts are spaced
further apart, which requires modification to the wing. One little change
snowballs into several changes, rippling throughout the airframe. As I can
recall, those changes included:
a. Making the centersection spar longer (I went ahead and made mine 6"
longer to give me more fuel capacity)
b. Making the fuselage taller, to keep the proportions with the wider
fuselage (not a bad thing - it gives more room in the instrument panel)
Again, if I had it to do over, I would still make it wider. Just realize
there are downsides to it, most notably weight. Sure makes it nice on those
cold mornings when I have to wear a heavy leather jacket to fly it
comfortably, though.
Jack Phillips
NX899JP
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Galen
Hutcheson
Subject: Pietenpol-List: "Skinny Piet"
Hello Gang,
tight for comfort.
Doc
Hi Jack,
That was a well written response. I just knew that
someone had to have widened the fuselage some over the
years. I realized it would add some weight, but with
enough horsepower, that shouldn't be too much of a
problem. I am now fitting up my fuselage halves and I
formed them up on 26" instead of the 24" called for in
the plans. I tapered everything back accordingly. It
looks good and proportional to other aircraft I have
seen. I plan to adjust the centersection to
accomodate the wider cabane strut, ect. I am going to
ponder over this a couple of days before I decide
whether to do it or not, but, right now I'm leaning
toward the wider model. I plan to do a lot of cross
country flying and don't like being cramped up. Plus,
I like to carry some baggage with me. I just talked
to a very good friend of mine by the name of Dennis
Yates from Illinois. I know he has been to Broadhead
many times and he said he has seen widened Piets
before too.
Again Jack, thanks for your response.
Doc
--- Jack Phillips wrote:
> Phillips"
> Hi Doc,
> are:
> than standrd length
> than Mike Cuy's. It
> fuselage. Making it
> wider. Just realize
> jacket to fly it
> Jack Phillips
> NX899JP
> On Behalf Of Galen
> Hutcheson
> Sent: Monday, November 01, 2004 2:37 AM
> Hutcheson
> Hello Gang,
> built
> be
> little
> tight for comfort.
> Doc
> now.
> Click on the
> this
> by the
> Admin.
> Contributions
> any other
> Forums.
> http://www.matronics.com/subscription
> http://www.matronics.com/FAQ/Pietenpol-List.htm
I think Corky and Max Davis have built their airplanes wider. I saw some photos
of Corky's re-piet and it looks great and like it is a lot roomier. I wonder
how some of the things like the aileron cables come out in relation to the backside
of the instrument panel. Also does this end up lengthening your rudder
bar and widen your leg stance? How about the angles on your engine mount structure?
How does it affect the loads in the tubing? Do you assume they increase
and go with a heavier wall thickness. More added to overall weight. Hmm...is
it still a Piet? I think I'll stick to the plans on mine.
Terry L. Bowden
ph 254-715-4773
fax 254-853-3805
Subject: | Re: "Skinny Piet" |
Doc,
I built my Pietenpol with the fuselage 2" wider from the firewall aft to the
rear instrument panel, and tapered the sides from there to the tailpost .
The fuselage length was unchanged from Orrin Hoopman's drawings for the
"Improved Air Camper".
On the 15th of this month, I shall fly it to commemorate the 34th
anniversary of its first flight, weather permitting. Over the years some of
these flights have been pretty chilly here in Alberta, Canada--and I have
appreciated the ability to wear lots of clothing due to the widened cockpit.
It seems the widening of the fuselage has not resulted in much weight
increase. My Piet weighed 630 pounds dry in 1985 after recovering. A C85-8
engine and wooden propeller were installed together with an absolute minimum
of fixed equipment. Today, it is a little heavier with a C85-12 engine and
some very lightweight seat cushions to ease my old bones--but is still
lighter than several other Piets in our area.
If I were to build another (which I won't), I'd go with the widened
fuselage.
Graham Hansen (Pietenpol CF-AUN)
Hi Terry,
Thanks for your response. I don't know if I will end
up with a "Piet" or not, but I hope to end up with an
airplane I can enjoy and use. I am kind of building
my "dream" airplane so I want to make it fit many of
the things I have always wanted in an airplane. The
cables you mentioned can be engineered without too
much bother. Of course the angles of the engine mount
will be different but the moment arm of the force the
engine exerts on the mount is going to be the same so
I think the same guage will work. The Piet is way
over built for strength so there is plenty of room for
inovation. There would be a little wider stance on
the rudder bar, but it would be about the same as I
had with the Bird biplane (which also had a rudder
bar) and that was actually real comfortable. The top
fuselage cowlings will have to be sized up but that is
what I had planed to do anyway. I have flown aircraft
long distances that were cramped and uncomfortable and
by the time you get to where your are going you are
just worn out. The Aeronica Champ and the Chief are
examples where the fuselage was widened with good
results. My adding 2" in width to the Piet certainly
isn't as drastic a change as in the Aeronicas. Each
person has his (her) own individual likes and dislikes
about what an airplane should be and since I plan to
build only one airplane I want to make it as much to
my liking as I can.
Again, thanks for your response.
Doc
--- BARNSTMR(at)aol.com wrote:
> BARNSTMR(at)aol.com
> airplanes wider. I saw some photos of Corky's
> roomier. I wonder how some of the things like the
> lengthening your rudder bar and widen your leg
> structure? How does it affect the loads in the
> tubing? Do you assume they increase and go with a
> weight. Hmm...is it still a Piet? I think I'll
> Terry L. Bowden
> ph 254-715-4773
> fax 254-853-3805
> Click on the
> this
> by the
> Admin.
> Contributions
> any other
> Forums.
Hi Graham,
That was a great response! It seems like there are
several wider Piets out there. I agree with
everything you wrote about the needs for a wider
fuselage. The narrow fuselage is alright if you are
just going to go out and play in the air or take short
trips in, but if you are going to do some serious
traveling (and I plan to follow my old "barnstorming"
routes) you need something more useful. I think I too
will widen the fuselage the 2" and taper everything
back proportionally. I can't see it adding all that
much extra weight and since I'm not building an
ultralite anyway, I want to make this little airplane
useful.
Again, thanks for your wonderful response.
Doc
--- Graham Hansen <grhans@cable-lynx.net> wrote:
> Hansen" <grhans@cable-lynx.net>
> Doc,
> bones--but is still
> with the widened
> fuselage.
> Cheers,
> Click on the
> this
> by the
> Admin.
> Contributions
> any other
> Forums.
Someone (Ted Brusseau???) wrote an article in the latest Brodhead Pietenpol Association
Newsletter about a plans change to aluminum spars and the attendant problems
that an "improvement" to the plans can cause. Seems like we've been fighting
this battle for years and years.
Anyway..... I have a friend who has built a one-piece wing and he used aluminum
spars so, after reading the article, he's really concerned. He has no computer
so I am writing on his behalf. Will the author of the article please contact
me directly to answer some questions regarding the spar material that was used
in the Piet (NOT) that you tested.
Thanks-
Larry
Fellow Piet Builders:
I've got a dandy workbench built, I've got an engine (Model A -- to be
rebuilt), wing ribs from Charlie Rubecks, and enough spruce and ply to build the
fuselage. And so I'm going to start actually gluing wood together in the next few
days.
I'm also going to be writing a series of articles about the project as it
progresses for a regional monthly magazine serving the Wisconsin, Iowa, Minnesota
area (The Tapestry published in Lansing, Iowa). In the initial article I'm
going to talk about the history of the plane and BHP and I'd also like to
include some photos of completed Pietenpols -- especially in-flight photos -- just
to show the Tapestry readers what kind of "kite" we'll be building.
Here's my request: Could some of you send me a pic or two of your Piet? We
can work with digital but they must be 300 dpi at full size (say 3x5 or 4x6).
Or, if you can snail-mail me some traditional film prints that would be
terrific. I'll be glad to send you a copy of the magazine that your plane appears
in.
I plan to write an article every three months or so as the plane progresses.
I'll be happy to share the articles with this group, too. We're thinking that
the article series will kick off in January.
Hope to hear from some of you soon!
Fred Beseler
1619 Cass St.
La Crosse, WI 54601
_TBYH(at)aol.com_ (mailto:TBYH(at)aol.com)
Good luck with the project Fred. Don't have any
flying photos as yet, but I'm putting the fuselage
together right now and my engine is being built for
me. I have most of my ribs done too. Sounds like a
good bunch of flyers up your way. I used to barnstorm
up to Neilsville and the towns around. Never did stop
in La Crosse though, nice flying country up there too.
Doc
> (Model A -- to be
> days.
> we'll be building.
> magazine that your plane appears in.
> Fred Beseler
> 1619 Cass St.
> La Crosse, WI 54601
Subject: | Air Camper project for sale |
I've listed my GN-1 Air Camper on Barnstormer. My still picture with the ad
is lousy, and vastly better pictures of this project can be seen on DJ Vegh's
site at http://imagedv.com/aircamper/log/image-pages/03-02-04b.htm.
I bought this Air Camper project from DJ in March and it has been stored in
my hanger under a couple of canvas tarps.
The workmanship is extraordinary. DJ bought this fuselage from someone in
Mesa, AZ and I believe I am the 4th owner. The fuselage is 80% complete and I
think I have 15 completed ribs (originally built by DJ). The project also
includes all the wood necessary to complete the project. The fuselage is mounted
on
J3 Cub landing gear and it has a Maule tailwheel, minus the actual wheel. Also
included are a rib jig that DJ built and another jig that I think is used for
the nose ribs. The torque tube is already mounted in the fuselage with sticks
installed.
I can send a few more photos showing the airplane in a hanger in Abilene, TX.
There are some very minor mildew issues that can be removed with light
sanding using a 400 grade sandpaper. We had a serious drought until I brought this
project home and about as soon as I parked it in the hanger under the canvas
tarps, it became VERY humid, thus the mildew. There is one small stain on the
exterior right side of the fuselage where condensation drained off the low spot
on the tarps. This is only cosmetic.
I cannot deliver. This project needs to be picked up at Abilene Regional
Airport, located about 2 hours West of Fort Worth on I-20.
Sterling Brooks
325-754-4609
Doc,
I have a short fuse, to the Improved AirCamper plans. It has the standard
plans width, and I don't have any problems with having enough room, now that I
am used to it. However, I suppose my biggest problem, is reaching down to
buckle the 4 point harness. I'm 6' tall, and weigh 205 lbs. Mounted next to my
left hip, I keep a small personal fire extinguisher, the ELT, fuel sump cup,
camera, cell phone and fuel quantity indicator (dip stick with calibration
marks) on the seat. On the right side I have the Pietenpol Oporation Manual, four
way screwdriver, Leatherman Tool, and other paperwork. I also keep a bottle
of water there, for cross country trips. I keep all this stuff secured with
Velcro. The fire extinguisher is mounted with the bracket that came with it.
Once I'm all strapped in, it is comfortable. I made a seat pad that supports
the forward portion of my thighs, but is very thin in the middle portion where
I sit, to keep me down in the pit as far as possible.
Talk about cross country trips...
Last summer, I flew Wichita to Brodhead and Oshkosh.
This past summer, my cross country trip was for 26 days, from 7/17/04 to
8/11/04. I flew down thru Kansas, Oklahoma, Texas, Louisiana, Missouri,
Arkansas, Illinois, Wisconsin (Brodhead), Indiana, Ohio, east to Wheeling W Va,
and
back to Wichita, covering 3100 miles, and logged 69.7 hours !! That was the
biggest adventure I've ever had !! I burned 288 gal. fuel, 32 bottles of baby
oil, made 62 landings, gave 35 rides, spent 8 nights in a tent, 10 nights
with family in Wheeling, 4 nights with friends, and 5 nights in motels, spent
$1270, and had an average speed of 66 mph.
Chuck Gantzer
NX770CG
Doc, Make up a 'mockpit' out of scrap material and play
with it. Dress in your winter flightsuit and move your arms
around with a broomstick and see what your elbows do.
I've made my fuse 1" wider as a result. Everything else is
normal except for lengthening the tail 6". Here's my
mockpit.
http://www.mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID=27
I moved the throttle quadrant 9 times to get it where it's comfortable
for me as well.
Clif
Subject: Re: Pietenpol-List: "Skinny Piet"
October 06, 2004 - November 01, 2004
Pietenpol-Archive.digest.vol-ed
