-----Original
Message-----
I just returned from my FAA
interview which went just fine. After the various comments on the list
here which I very much appreciate, I realize there are big differences
around the country in how inspectors handle many of their duties. One
big reason for this might be the type of FAA office we deal with. The
office that I went to for this certificate is located at the Minneapolis
airport which is home base for Northwest Airlines. There was a steady
stream of people coming in for airline related ratings. Technicians in
avionics shops, propeller repairsor other specialty fieldswho
arent an AP need to be an Aircraft Repairman. Things in the larger FAA
offices just need to be more formal. My airworthieness inspection was
by the Aircraft Manufacturing office and this was by Flight Standards. I
suspect anyone going to Atlanta, Dallas or other airline bases will run into
the same.
The interview was about 15
minutes while I filled out a second copy of the application and he went thru
my builders log and operations manual and asked a few questioins about wing
construction and dihedrial. He was impressed with my Harley wheels and
asked about what areas I had help with. I got the impression that he
just wanted to be sure that I didn't just buy a completed project and claim
to have built it.
It was a pleasant experience, I
didn't have to write a check and I've got my certificate so I'm
happy.
Dick
N.
CR**
Subject: | Re: aircraft repairman - ahhhh... more FAA |
CR**
Some food for thought:
The FAA is chunked up into regions. Last year I found out from an
airplane-geek friend in the Chicago area (Great Lakes Region) that
airplanes and mechanics from the Southeast Region and Alaska are considered
(unspoken, of course) questionable. I guess there were enough people doing
repairs who weren't legal, shoddy repairs, or pencil-whipping log books in
those areas that the word got out. Some of it made the news. Some of it
made the local scuttlebut if you're spliced into the local pilots, and I'm
sure a bunch of it still goes on unnnoticed.You may be suffering the tail
end of the the Southeast Region trying to get some credibility back by
unreasonably tighening up on dotting all the i's and crossing the t's.
Jim Ash
>Well. I'm glad some of you are having good experiences with the
>FAA. I've just found out that I have to make a 4 hour (one way) trip to
>Tampa to the Tampa FSDO to be "interviewed" so they can "grant" me a
>repairman certificate - on an airplane I
In a message dated 12/21/04 11:18:05 AM Central Standard Time,
Plyn4par(at)wmconnect.com writes:
<< Im another Piet producer, hopefully by sept of 05 she'll be close to go,
thanks...Bob >>
Please tell us about your project, and yourself.
Chuck Gantzer
Wichita KS
NX770CG
Pietenpols Forever !!
Subject: | Re: aircraft repairman - ahhhh... more FAA CR** |
In a message dated 12/21/04 8:14:46 PM Central Standard Time,
ashcan(at)earthlink.net writes:
<< You may be suffering the tail end of the the Southeast Region trying to
get some credibility back by unreasonably tighening up on dotting all the i's
and crossing the t's. >>
That explains a lot.
Chuck
2.46 SUB_HELLO Subject starts with "Hello"
Hello again Chuck and the list. The building bug is starting to bite again.
There is another guy here in Mac that is starting the building process and I
think we will be able to team up. We are looking for a good wood souce to start.
Thanks for keeping this awsome resource going.
Chad Johnson
McPherson, Kansas
In a message dated 12/21/04 11:13:54 PM Central Standard Time,
flynpiper(at)cox.net writes:
<< Hello again Chuck and the list. The building bug is starting to bite
again. There is another guy here in Mac that is starting the building process
and I think we will be able to team up. We are looking for a good wood souce
to start. Thanks for keeping this awsome resource going.
Chad Johnson
McPherson, Kansas >>
Hey Chad !!
Good to hear the bug has bit you !! I tried to e-mail you last summer, but
you must have changed your e-mail. Gus Wiebie at Halstead airport is close to
you, and a very good source for spars, wood, and used airplane parts.
Chuck G.
My new email is flynpiper(at)cox.net. I've been flying my uncles Kolb firestar and
having a blast. I acquired a Sonerai project but sold it because I am not
much of a welder. I just keep coming back to the old piet. For those of you
that know Chris Price from Broadhead, he says hi. I fly with Chris at Air Wisconsin.
Chris's Health Parasol won a float plane award at last years Oshkosh.
Thanks for the suggestions Chuck. I will be in touch I am sure.
Chad
Subject: | Winter construction |
Doe anyone know the temperature restrictions for T88 epoxy? I would like to
do some fuselage work in my garage this winter, but am worried about the
glue not curing properly. Temperatures are above freezing but still get
quite cold.
John Fox
This message may contain confidential, proprietary or legally privileged information
and is
intended only for the use of the addressee named above. No confidentiality or
privilege is
waived or lost by any error in transmission. If you are not the intended recipient
of this
message you are hereby notified that you must not use, disseminate, copy it in
any form or
take any action in reliance on it.
I would like to do some fuselage work in my garage this winter, but am worried
about
the glue not curing properly. Temperatures are above freezing but still
get quite cold.
John Fox
proprietary or legally privileged information and is
privilege is
of this
any form or
Subject: | Re: Winter construction |
John,
I am using T88 and working with the understanding it will work in temps down to
35-40 degrees. I glue up when it is in the high 40's and at night it may get
down to freezing or below but next visit to the shop and it has warmed back up
and all seems to be O.K. Test pieces always seem to be strong.
Alex Sloan
Doe anyone know the temperature restrictions for T88 epoxy? I would like to do
some fuselage work in my garage this winter, but am worried about the glue not
curing properly. Temperatures are above freezing but still get quite cold.
John Fox
and is
intended only for the use of the addressee named above. No confidentiality or privilege
is
of this
any form or
John,
to 35-40 degrees. I glue up when it is in the high 40's and at night it may
get down to freezing or below but next visit to the shop and it has warmed back
up and all seems to be O.K. Test pieces always seem to be strong.
Alex Sloan
about the glue not curing properly. Temperatures are above freezing but
John Fox
use of the addressee named above. No confidentiality or privilege is
waived
or lost by any error in transmission. If you are not the intended recipient of
this
copy it in any form or
John, I think the company advertises the glue to be
useful down to 34 degrees F. I think also that Tony
Bengellis recommends not to glue (not sure if he was
specific about T-88 or not) below 70 degrees. I have
used T-88 successfully down to 60, but below that the
glue gets very thick and difficult to work with. It
seems to adhere quite well though.
Doc
> quite cold.
> John Fox
> are not the intended recipient of this
> use, disseminate, copy it in any form or
http://mobile.yahoo.com/maildemo
I would like to add to Alex's comment though that I
recall the company recommending that the glued joint
be exposed to 70 degrees for at least 24 hours before
heavy loads are attempted. I think I am correct in
that.
Doc
--- alexms1(at)comcast.net wrote:
> John,
> will work in temps down to 35-40 degrees. I glue up
> and it has warmed back up and all seems to be O.K.
> Alex Sloan
> epoxy? I would like to do some fuselage work in my
> John Fox
http://my.yahoo.com
From: | "gbowen(at)ptialaska.net" <gbowen(at)ptialaska.net> |
Epoxy resins of all types are addition reactions. This means that the
reaction will continue until complete, but the reaction rate varies with
the ambient temperature. All manufacturers report their data at 25 degree
C., ie. gel times, time to "full cure", viscosities, etc. The chemical
reaction rate rule of thumb is: for very 10 degrees C you vary from the 25
degree reported data you will double your reaction rate or you'll halve the
reaction rate if you're going down in temps. Soooooo, you could expect at
40F or about 5 degrees C you'd have a reaction rate about 4 times slower
than at 25 degree C. Generally speaking all room temp, hand laminating
epoxy resins designed to work at 25 C, will not cure completely in less
than 14 days. Soooooo, I would not put too much stress on your 40 F hand
laminate for about 45 days. Better yet, build a "hot room" under your
workbench by stapling plastic film around the edges or some insulation
foam, and put in a small space heater. Give it about 7 days under the
"curing bench" then go ahead and assemble, or wait until next summer, it's
just 180 days until first day of summer.
Gordon Bowen
Original Message:
Date: Wed, 22 Dec 2004 15:34:08 -0600
Subject: Pietenpol-List: Winter construction
quite cold.
John Fox
information and is
or privilege is
recipient of this
in any form or
the key to using T-88 in cold climates is to have the glue warmed to around
80-90F prior the intial mixing. This will speed up the curing process and
produce a good joint in shorter amount of time.
----- Original Message -----
Subject: Re: Pietenpol-List: Winter construction
> Doc
> quite cold.
> might want to use a heat lamp for your containers of
glue,this would at least help your batches be easier
to work.
Garry Low
> John Fox
http://info.mail.yahoo.com/mail_250
From: | "Richard Navratil" <horzpool(at)goldengate.net> |
I did some glueing last night and checked the T-88 containers. They recommend
50 deg. I left the hangar at 50 and my joints were set tonight.
Dick
To: Pietenpol-List(at)matronics.com
Sent: Wednesday, December 22, 2004 3:34 PM
do some fuselage work in my garage this winter, but am worried about the glue
not curing properly. Temperatures are above freezing but still get quite cold.
John Fox
information and is
or privilege is
recipient of this
it in any form or
I started taking the glue bottles inside the house and
let them get to ambient temp. This works very well
too.
> T88
> but
> > quite cold.
> of
> to work.
> Garry Low
> > John Fox
> you
> search.
> Contributions
> any other
> Forums.
> http://www.matronics.com/subscription
> http://www.matronics.com/FAQ/Pietenpol-List.htm
> http://www.matronics.com/photoshare
http://my.yahoo.com
Most of the glue joints I making now probably won't
fly for another year yet (sigh) so I guess I'm ok. :)
I'm using heaters to get the garage (workshop)up to
around 60 degrees, so that helps.
Doc
--- "gbowen(at)ptialaska.net"
> This means that the
> etc. The chemical
> completely in less
> or some insulation
> Gordon Bowen
> Original Message:
> From: Fox, John John.Fox(at)na.SunChem.com
> quite cold.
> John Fox
> information and is
> or privilege is
> recipient of this
> in any form or
> Contributions
> any other
> Forums.
http://my.yahoo.com
on the Web
Subject: | Winter construction - Manufacturer's Info on the Web |
Folks:
Check out System Three's website at
http://www.systemthree.com/index_2.asp
T-88 spec sheet http://www.systemthree.com/members/tds/T-88_TDS.pdf
T-88 MSDS http://www.systemthree.com/msds/MSDS_T-88.pdf
John Joyce
North Reading, Massachusetts
-----Original Message-----
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Galen
Hutcheson
Subject: RE: Pietenpol-List: Winter construction
Doc
> This means that the
> etc. The chemical
> completely in less
> or some insulation
> Gordon Bowen
> Original Message:
> quite cold.
> John Fox
> information and is
> or privilege is
> recipient of this
> in any form or
> Contributions
> any other
> Forums.
http://my.yahoo.com
<001a01c4e88b$d3169ff0$0600a8c0@laptop>
The first link is their homepage. Go here and sign in as a member.
The second is direct to the pdf tech pages for T88. The second
page tells you that it is formulated for full strength cure down to
35=B0 F, just takes a lot longer. Be carefull with heating and
mixing. I warmed mine in hot water and it hardened before the
pieces were properly put together.Good thing it was something
small!!
On page one you will see a shear verses temp blurb on glue/Alum.
I take this to mean the glue failed. IF this is so then the same would
apply to wood/glue. IF this is so then spruce, at a shear strength of
1120 lb would equal the T88 strength at approx 170=B0. This doesn't
sound good until you calculate the square inches of material being
glued and realize that the OVERALL strength of that joint probably
exceeds the required strength by a fair margin.
If you have a joint that will be subjected to no more than 1000 lb
but the area of that joint is 3 sq in. then the joint is capable of
handling 3000 lb at 180=B0 so will be safe to some higher temp.
A good thing if you live in Florida or Texas. None of our flying
planes have fallen apart yet even though some have some pretty
dark paint on them.
If you want Wood Strength tables go here. Scroll to the bottom;
http://clifdawson.ca/Tools_and_Tips.html
Clif
Dick
John Fox
Since I spent the last 40 years of my working life as a chemist in the
epoxy and urethane industry, including formulating Rutan's Rutan Aircraft
Epoxy for the first Vari and Longeze's and Saf-t-poxy, feel homebuilders
can benefit from a few tips that we didn't put on "official" data sheets.
1) Don't believe everything you read. Data sheets are sales tools used by
manufacturers to sell more product. I've "doctored" enough data sheets in
my working life to fill a book, due to the request of the guys in sales.
Every technical data point has a range, the sales guys always want the most
attactive, not the mean or average data point.
2) Almost every hand lamination resin starts with Epon 828 (formerly Shell)
as the feed stock. There's 80 custom manufacturers of epoxy systems in the
USA alone, including System 3. Every one of them uses Shell's Epon 828,
it's the industry standard. This basic resin is cut with reactive and
unreactive solvents, because it's too high in viscosity to use by hand
laminators.
3) Reactive solvents are more costly but more functional for homebuilders
than non-reactive solvents. The cheaper the solvent the cheaper you can
sell you epoxy system. So don't buy your resin system based on price.
4) The reaction rate rule of thumb previously given is good for all
non-catalyst type reactions. Polyesters and derakane vinyl esters are
catalyst type reactions. If you lower the temperature of cure of an epoxy
amount of time it takes to come to full cure.
5) Most all hand-laminates never come to full cure. The only way to get a
full cure on an epoxy is to get the temperature of the laminate up to the
glass transition temperature of the resin, or about 180 degrees F.
6) No matter what is says on any data sheet, you will not get full physical
properties unless the epoxy has seen it's Tg. You get very close but no
max properties are possible without a post cure of the laminate. 4 hours
at 180F is the standard post cure given a laminate in the labs before
physicals are tested and reported.
7) If you warm the resin to 25C before using your get the approx. mixed
viscosity and gel times reported by the manufacture, but as soon as you
smear it on your work, all bets are off. The gel and cure times change
dependent on the mass (ie. a thin film takes longer to cure) and the
8) Back to thread- working in cold climate. a) buy System 3's fast amine,
b) experiment until you know the working time you've got, and vary the
batch size to make it all smeared out before it gels. c) make yourself a
little "postcuring" oven out of your workbench. d) don't be afraid to
experiment a little, the only thing you can screw up is the mix ratio of
part A to part B. As long as you keep this ratio as posted by the
manufacturer, you cannot go wrong.
Gordon Bowen
Original Message:
Date: Wed, 22 Dec 2004 19:06:08 -0800
35 F, just takes a lot longer. Be carefull with heating and
small!!
1120 lb would equal the T88 strength at approx 170. This doesn't
handling 3000 lb at 180 so will be safe to some higher temp.
dark paint on them.
Clif
recommend 50 deg. I left the hangar at 50 and my joints were set tonight.
Dick
John Fox
Subject: | Correct resin for fiberglass fuel tank? |
I'm going to be making a fuel tank for an air camper soon.
#1. Who is a good source (Aircraft Spruce?) for the resin and cloth?
#2. What weave material is recommended?
Sterling
Subject: | Re: Correct resin for fiberglass fuel tank? |
I bought mine from ACS. Check page 34 in cataloug un the heading of Polyester
Resins, read carefully. You will want to use #6060-5 resin. You will need to
use a combination of heavy roving and mat. If you havent done fiberglass work
before you may want to do some reading on it or get with someone from your EAA
chapter first.
Dick N.
To: pietenpol-list(at)matronics.com
Sent: Thursday, December 23, 2004 12:59 PM
Subject: Pietenpol-List: Correct resin for fiberglass fuel tank?
Sterling
Subject: | Fiberglass Construction |
In a message dated 12/23/04 1:00:37 PM Central Standard Time,
N321TX(at)wmconnect.com writes:
<< I'm going to be making a fuel tank for an air camper soon.
Sterling >>
Sterling,
Are you using the fuel tank mould that I loaned you ? If so, please use
enough release agent, so as not to destroy it !! There is a couple of other
folks that will need it. It's a really good mould (capacity - 10.7 gal.), and
we can pass it around to others, when you are done with it. (It is for the
nose cowling fuel tank for plans dimension short fuselage.) I designed it so
the bottom of the tank slopes forward, when the tail is on the ground, so any
water in the fuel finds it's way to the outlet. There is no place where a
pocket of water will collect. I might need it again, too, if I ever get any
alcohol in my fuel !!
Here is the way I built both my tanks, and J3 type nose bowl:
I used Polyester Resin (for auto body repair) on both tanks. It's
cheaper than Epoxy, and is a lower viscosity which aids in wetting out the fabric.
However, if I build another tank, I will use the West System Epoxy Resin 105,
with the 206 hardener. If you go this route, it is very convenient to buy the
pumps that go with the cans, which dispenses the material at the proper ratio.
Never handle any cloth with your bare hands, or touch any area where you
are going to do an additional lay-up, or skin oil will prevent the resin from
saturating the cloth in that area.
You have to be FAST if you use the Polyester Resin, because after you put
the hardener in...it Kicks in only about 5 to 7 minutes, depending on how
many drops you put in. West System has a lot longer pot life (work time). Have
all the fabric cut, pre-fit, and stacked in the order they lay. I can't say
enough about preparation, before you add the hardener. You can lengthen the
working time some, by using a few drops less than recommended, but once it
starts to jell, forget about proceeding any further. The challenge of doing
composite work, is to get 100% saturation, using as little resin as possible, with
no fabric separation. The way we achieve this at work, is 'Vacuum Bagging'.
One of the faults of the Polyester Resin, is that it is NOT alcohol
resistant. So far, I haven't had any problem.
Fiberglass Cloth:
I have a source here in Wichita, where I purchase the cloth, in all
sizes. It ain't cheap !! Seems like I had over $35 or $40 bucks for the cloth
in
the nose tank and nose bowl. I used two different weigh fabric - Light
weight, and Medium weight.
The first layer down, I used light weight. Then two layers of medium weight,
then the last layer down in the Mould I used another layer of light weight.
The difficult part is to get the cloth to stay down in the corners. It always
wants to spring back out of the inside corners, no matter how many times you
poke it back in. Light weigh cloth stays down in the corners much easier,
because the cloth is thinner, and bends easier. This is the reason I used corner
pieces in the mould, so the fabric only has to form to 45, instead of 90.
After the resin cures, and you pop the bottom and top out of the mould, you
need to carefully sand the edges, so you get a nice tight fit, preferably a 45
miter fit (that's what I did) then glue them together with the resin you've
been using. After they are glued together, put 3 layers around the entire
corner edge, stepping out from 2" for the first layer down, up to about 4" for
the
last layer down. You always have to sand the shinny off, before adding any
additional layers. After complete, leak test with a balloon, like Tony Bengalis
recommends. Then you should calibrate it at the gas station. Set the tank
in the static laden position (the angle it will be at when the tail is on the
ground), and add one gallon of fuel at a time, dip your 'Calibrated Dip Stick'
in, and mark each gallon increment. The distance between these marks vary,
because of the shape of the tank. I didn't have any leaks in either of the fuel
tanks I built.
I built the Smoke Tank with just two layers of fiberglass, moulded around
cereal box the right dimension, but used the West System Epoxy. It seemed
like the cloth was wetted out good, but it had two places where the baby oil
seeped through, and dripped about one drip every 6 minutes. I fixed them by
cleaning first with Brake Clean, then sanding the area, then some more Brake Clean
(with clean cloth and no finger prints), then used 5 minute epoxy, and two
layers of cloth.
Chuck Gantzer
NX770CG
Merry Christmas To All !!
Spruce and Wicks both carry a glass weave called 7781. It's a tight weave
in the satin style that drapes over edges very nicely. Stay away from "box
weaves" because they give you problems in compound curves. Just about any
good laminating epoxy resin will work, but Derakane epoxy based vinyl ester
has better chemical resistance. You work Derakane just like you do a
polyester (ie. boat type resins). A little dab of catalyst, you have to
work in small batches. Whatever you do don't use polyester resin on gas
tank, it'll get "fried" by the fuel additives and leak. EZ Poxy and
Aeropoxy were both approved by Rutan for composite fuel tanks. I ain't got
no dog in that fight no more, but I still use EZ Poxy from Epoxical for my
laminates.
My Piete rebuild came with a galvanized steel tank but if I were going to
build a fuel tank today I'd use the following technique: 1) shape a block
of styrofoam to fit the area you want, round the corners for ease of lay-up
2) laminate over the carved block with min. 6 plies of 7781 glass and
Derakane. Derakane doesn't need a post cure to completely cure but I'd let
3 weeks pass at Room Temp (25C) before I put fuel in any composite tank. 3)
Put the drains and vent blocks thru a 1/4" aluminium block I'd laminate
into the first 3 plies and cover with balance of plies. Laminate in the
filler cap ring, too. 4) drill and tap the al block for the fittings. 5)
Cut the entire laminate and foam block in half 6) use acetone or gasoline
to dissolve the foam and pour out the mess. 7) using min. 4 strips of
glass and Derakane reglue the now empty tank back together.
Piete purest can forget the above techique. Back to the dark ages.
Gordon Bowen
Original Message:
Date: Thu, 23 Dec 2004 13:59:43 EST
Sterling
As a polymer chemist I highly recommend to anyone considering using
polyester resin for construction of a fiberglass fuel tank to make a small
test. Make a 2" by 4" test laminate of polyester and fiberglass. Put into
a quart jar of AVGAS and MOGAS for about 1 month. You could weigh before
and after if you've got an accurate scale, but I think you'll discover the
discoloration of the AVGAS and MOGAS plus the somewhat slimy feel of your
test coupon will change your mind about the chemical resistance of
polyester resins.
Gordon
Original Message:
Date: Thu, 23 Dec 2004 16:02:25 EST
Subject: Pietenpol-List: Fiberglass Construction
Sterling >>
Sterling,
use
other
and
so
any
any
bowl:
fabric.
105,
the
ratio.
you
from
put
Have
say
the
doing
possible, with
Bagging'.
Fiberglass Cloth:
cloth in
weight,
always
you
corner
45
for the
Bengalis
the
Stick'
fuel
tanks I built.
around
oil
by
Brake Clean
layers of cloth.
Chuck Gantzer
NX770CG
Gordon,
I take it you are strongly recommending epoxy resin for the fiberglass tank, right?
I have never been a fan of polyester resin compared to epoxy.
Alex Sloan
> polyester resins.
> Gordon
> Original Message:
> From: Rcaprd(at)aol.com
> Thanks,
> Sterling >>
> Sterling,
> use
> other
> and
> so
> any
> any
> bowl:
> fabric.
> 105,
> the
> ratio.
> you
> from
> put
> Have
> say
> the
> doing
> possible, with
> Bagging'.
> Fiberglass Cloth:
> cloth in
> weight,
> always
> you
> corner
> 45
> for the
> Bengalis
> the
> Stick'
> fuel
> tanks I built.
> around
> oil
> by
> Brake Clean
> layers of cloth.
> Chuck Gantzer
> NX770CG
Gordon,
right?
Alex Sloan
-- Pietenpol-List
message posted by: "gbowen(at)ptialaska.net"
using
polyester resins.
Gordon
Original Message:
Rcaprd(at)aol.com
-- Pietenpol-List
message posted by: Rcaprd(at)aol.com
soon.
resin and cloth?
Sterling
Sterling,
use
of
other
and
so
ground, so
any
any
bowl:
It's
out the
fabric.
105,
the
pumps
ratio.
you
from
saturating
put
Have
all
say
lengthen
the
doing
possible, with
no
is 'Vacuum
Bagging'.
Fiberglass Cloth:
cloth in
the nose tank and
weight, and Medium
weight.
of medium
weight,
always
wants
you
easier,
corner
a
45
for the
last layer down.
additional
Bengalis
tank
tail is on
the
ground), and add on
Stick'
fuel
tanks I built.
around
cereal box the
like the
oil
by
then some more
Brake Clean
layers of cloth.
Chuck Gantzer
NX770CG
Each resin has it's place and function. In terms of chemical resistence it
goes like this: epoxy based vinyl ester is best, a post cured epoxy is next
and then comes polyester for some things like water. If MOGAS and AVGAS
was pure aliphatics C-7 and C-8's hydrocarbons then maybe polyester would
hold up better, but gasoline of all types has a lot of aromatics and some
ethers in it now that lead is dead in fuel. MOGAS changes from region to
region and season to season to fit the climate, these additives love to
scarf up polymers like polyester.
When no-lead came out 25 years ago, we had to redo all the test on RAE and
Saf-t-poxy for Rutan to insure the composite planes of his design didn't
dissolve into a great big puddle of plastic. These tests were 2 years of
submersion in all types of gasoline, weighed before and after on a scale
accurate to 0.001 grams. Epoxy holds up.
If someone out there has a polyester tank, and leaks do appear or your fuel
filters/carb gets a gummy deposit, step back and punt. Or take the thing
out, dry it out, cut it in half, relaminate the inside with Derakane and a
couple plies of glass.
One of the steps I left out in my last email for those using the "lost
mold" method of making their composite tanks: if you don't use epoxy and
decide to use Derakane, you have to coat the foam mold with a layer of
plaster to keep the styrene in the Derakane from eating the mold while
you're making your laminates. Go to Home Depot and buy a gallon of normal
plaster patching compound, spread it thin and smoothly on the carved stryo
and let dry, then go ahead with your laminations.
Gordon Bowen
Original Message:
Date: Thu, 23 Dec 2004 22:23:10 +0000
Subject: RE: Pietenpol-List: Fiberglass Construction
Gordon,
tank, right?
Alex Sloan
small
the
> polyester resins.
> Gordon
> Original Message:
> Thanks,
> Sterling >>
> Sterling,
> use
> other
> and
the
> so
> any
> any
> bowl:
the
> fabric.
> 105,
> the
> ratio.
> you
> from
> put
> Have
> say
> the
it
> doing
> possible, with
> Bagging'.
> Fiberglass Cloth:
> cloth in
> weight,
weight.
> always
> you
> corner
90.
you
a
> 45
you've
4"
> for the
any
> Bengalis
> the
> Stick'
vary,
the
> fuel
> tanks I built.
> around
> oil
> by
> Brake Clean
two
> layers of cloth.
> Chuck Gantzer
> NX770CG
Subject: | Re: Fiberglass Construction |
Gordon,
I wish I would have seen this post about all this epoxy stuff. I built my
wing tank in December of '98, and used a sloshing solution called '5000L'. At
the time, this is the method that several local builders used. Maybe the
sloshing solution saved the polyester resin. I've done quite a few inspections
inside the tank, and it still seems all right. I didn't use the sloshing
solution in the cowl tank, that I built in January '03. I've never found any goo,
or
fibers, in the gascolator, and I inspect it regularly. I'll have a very
close look inside both tanks, with my bore scope, as regular inspections. I'm
very careful not to use fuel with alcohol, and the fuel I use at my home airport
is 100LL. Ya never know, though.
The next two tanks I build, will be for my Wittman Tailwind W10. I'll
use West System Epoxy resin, and I plan on using Carbon Fiber for the 35 gallon
tank behind the firewall, and an auxiliary tank in the baggage compartment.
The West System dosen't mention weather it is epoxy based vinyl ester.
Gordon, is the West System epoxy based vinyl ester ?
Chuck G.
Yep, I'm going to be using your mold. I just forgot what you used when I
picked it up from you several months ago, and it'll stay here until I get word
who
gets it next.
S.B.
We have used here Poyester Resin in our tanks for 20 plus years, with no problem,
only they get yellow, the brown, later dark brown, cant see the level of
gasoline though, but no internal damage....
Ol' Ironsides a Tailwind look alike built inthe 60's (If I remember correct) used
the same and stlll in working condition (read the article a few years ago,
maybe my memory is not all correct. Is a Fiberglass plane but not complete
sure if the gas tank is fiberglass...
Saludos
Gary Gower.
Whats the name of that German guy that is stolling my memory? :-) :-)
Rcaprd(at)aol.com wrote:
Gordon,
or
Chuck G.
Send a seasonal email greeting and help others. Do good.
<"000e01c4e92b$75e2f450$0600 a8c0"@laptop>
My best whishes for all on the list on this Christmas...
Javier Cruz
Chuck,
Glad you've had good luck with sloshing rubber in the tank, it seems to
work in some cases, but didn't for the Osprey tanks I had to rebuild, the
gas got under the area around the drain sump and ate it's way thru the
polyester eventually. The Osprey has been around since early 70's and
someone decided to start selling wing tanks as an after thought, the
original designer didn't specify what type of resin to use for in-fuselage
tanks. Lots of rebuilds were done and lots of slosh sold.
Derakane is the brand name from Dow for their epoxy based vinyl ester resin
system. It's in the Spruce catalog. It's main commerical usage is for
chemical storage tanks including all the gasoline in-ground fiberglass
tanks at gas stations. The commerical folks like it because it's sprayable
with a chopper gun just like polyesters. For most builders it's a little
too tricky to work with, so they stick with any good epoxy resin system
like West or System 3.
Gordon
Original Message:
Date: Thu, 23 Dec 2004 23:13:47 EST
Subject: Re: Pietenpol-List: Fiberglass Construction
Gordon,
At
inspections
any goo, or
I'm
airport
gallon
Chuck G.
Subject: | Re: Merry Christmas |
Amen! Jesus is the reason. May God bless you all.
Terry
From: | "Oscar Zuniga" <taildrags(at)hotmail.com> |
Subject: | Corvair Piet in "To Fly" |
Just got my copy of the SAA publication "To Fly" and one of the articles
features a Corvair-powered Pietenpol built by P.F. Beck of South Carolina.
Very nice Piet, he says it cruises 70-75 MPH (which is about 5-10 MPH faster
cruise than the A-65 powered examples like mine). He has a real nice setup
on the sides of his cowling that allows each entire side to swing away for
access.
The Corvair is a "William Wynne manual" conversion with rear starter and
what looks like a rear alternator. He also has stock exhaust logs joining
to a single outlet with a muffler under the airplane.
Mr. Beck states that his Corvair Pietenpol cost him $6,800 complete. Can
you beat that for fun, dependable, two-place flying?
Oscar Zuniga
San Antonio, TX
mailto: taildrags(at)hotmail.com
website at http://www.flysquirrel.net
Subject: | Re: Corvair Piet in "To Fly" |
Hey, I met P.F. at Brodhead this summer and he was kind enough to allow me to
interview him for my alleged video I hope to produce someday about this Air
Camper experience. P.F. is a true southern gentleman and when he showed me his
pictures of his Corvair powered Piet, I nearly fell over. Nice looking
airplane and I hope to see it at Brodhead someday.
S.B.
Merry Christmas to all of you in Piet Land.
Clif
Subject: | [Please Read] Trim That Message!! |
Dear Pietenpol Listers,
I've been getting a number of complaints from various members regarding a
bit of List Etiquette. Primarily, the issues have revolved around the
trimming of previous posters text when replying to a message. In one
example I saw recently, the person replying sent a one-line response to a
message and included over *three pages* of quoted text in the
message!! This just fills up the archive and people's email boxes with
lots of useless data.
This issue is specifically addressed in the Pietenpol-List FAQ and Usage
Guidelines found at the following URL:
http://www.matronics.com/ftp/Archives/Pietenpol-List.FAQ.html
Specifically, the following paragraph speaks directly to this issue:
"When responding, NEVER quote the *entire* original post in your
response. DO use lines from the original post to help "tune in" the
reader to the topic at hand, but be selective. The impact that
quoting the entire original post has on the size of the archive
can not be overstated!"
Please be courteous and kind to your fellow Listers and to the Archive file
and take a moment to trim out the unneeded quoted parts of a reply. I
thank you; the Archives thank you; all of the other Listers thank you.
Best regards,
Email List Admin
I want to build my own tailwheel -- don't want to use a tailskid. Would like
to avoid buying a commercial tailwheel assembly. What makes the best
tailwheel? Should I use Bernie's design for the strut and attachment but simply
attach
a wheel at the end of the spring steel? What kind of wheel? I think I read
that one fellow used a hockey puck....Am open to suggestions...
By the way -- had to prove it for myself -- bought a nice piece of 5-ply
birch plywood from Home Depot. Stuck a little piece in boiling water -- after two
hours I peeled it apart like a banana! Not that any Piet would be exposed to
boiling water for 2 hours, but I won't be using that stuff in my plane...
Hope you all had a nice Christmas! And will have a happy New Year! "Here's to
the duck that swam in the lake and never lost a feather -- may this time in
another year we'll still all be together..."
Fred B.
I usedc the leaf spring with a Matco wheel assy. I don't like it and will be changing
it over the winter. I am going to the design in the plans with a much
lighter wheel. Keep us posted on what you find for a wheel, I will be looking
also.
Dick N.
Sent: Sunday, December 26, 2004 3:45 PM
Subject: Pietenpol-List: Tailwheel
to avoid buying a commercial tailwheel assembly. What makes the best tailwheel?
Should I use Bernie's design for the strut and attachment but simply attach
a wheel at the end of the spring steel? What kind of wheel? I think I read that
By the way -- had to prove it for myself -- bought a nice piece of 5-ply birch
hours I peeled it apart like a banana! Not that any Piet would be exposed to boiling
the duck that swam in the lake and never lost a feather -- may this time in another
Fred B.
From: | "tmbrant1(at)netzero.net" <tmbrant1(at)netzero.net> |
Subject: | back to the piet finally |
Well, first off - Merry Christmas and happy New Year to everyone.
It's been a long while since I've participated in the group or even worked on the
piet, but because I received a generous gift from a relative, some money will
be spent on wing rib material. Wondering what's the best place to purchase
rib material. I'll probably order online thru wicks of AS&S unless there are
other recommendations.
Tom B.
Subject: | Re: aircraft repairman - need info |
Merry Christmas (and I'm not afraid to say it that way) everybody.
I need some information. As you all may have noticed, I've been concerned
that some Federal Aviation Regs regarding the application for Repairman
Certificate may be either fraudulently or at least inconsistently be being
applied. I have first-hand knowledge that the Atlanta FSDO, in some cases,
is not requiring the builder to come in to the FSDO and be interviewed as
part of the Repairman Certificate application. I live about 15 miles south
of the Georgia border in Florida and I am being told I have to drive 600
plus miles (at least 8 hours round trip) to be "interviewed" by the FAA
Airworthiness Inspectors in Tampa to receive my repairman certificate.
Now, I don't mind the "interview" - hell I built this sucker from DIRT and
know it a helluva lot better than some FAA desk-dude. But I feel that there
is such an unreasonable inconvenience here that I'm not willing to take off
work, spend the travel time and money, and jump through their hoops to do
it. Especially since THEIR DAR has signed off on the plane and confirmed
that the airplane is airworthy, I built it, and I am who I say I am. So
basically I payed $400 for a DAR to show up 2 hrs late, chat for 2 hours
and, give me a partial process. If it's so d*** important they need to get
off their a**es into the field and do some "airworthiness inspecting".
That's what MY federal tax dollars pay for - yours , too.
I plan on writing the head of the FAA and asking for some answers - such as
why I am being mandated to do something somebody else - 15 miles north of
me- is not- to meet the same FAR requirement. I don't know if this is
discriminatory or why - it's at very least inconsistent and bureaucratic.
If you have received your Repairman Certificate on a project you built in
the last 5 years, please e-mail me off-line to tell if you had to "visit"
your FAA office for an "interview" - where it was- and how far your travel
was. Also please estimate out of pocket costs and time away from work if
possible.
Thanks, Bert
Subject: Re: Pietenpol-List: aircraft repairman - ahhhh... more FAA CR**
to
i's
> Chuck
Subject: | Re: back to the piet finally |
Hi Tom,
In 1997, I purchased capstrip material from
AS&S. No problems. They cut the material to
62" lengths as requested. 23 cents per foot.
Charlie Rubeck's ribs get good reviews and
can save you a month or two of work for about
$300.00. I don't have contact information for
him. Someone else on the list will have that.
Greg Cardinal
Subject: Pietenpol-List: back to the piet
finally
> the piet, but because I received a generous
> gift from a relative, some money will be
> what's the best place to purchase rib
> wicks of AS&S unless there are other
> recommendations.
> Tom B.
> Forum -
> through the Contributions
> banner ads or any other
> Matronics Forums.
> http://www.matronics.com/search
Hi all,
I used a supermarket trolley wheel, cut a leaf spring from a small
car in in half , drilled a hole in the end and bolted the wheel to it. Fitted
the spring to the a/c with u shaped brackets bolted thru the sternpost and
thru the ash block in the bottom of the fuz.
It works really well, cost nothing and I have three spare wheels from the
same trolley should I ever need them.
regards
Terry
Pieters,
Just a non-purist idea about selection of wood. Have used doug fir, pine and
sitka spruce for various parts of the two Piets I've built. Reading of your
inquiries pertaining to woods for ribs I really think if I were ever to do it
again I would buy some 12 ft 2x4 #1 clear pine and rip it to dimensions. It
wouldn't be but a skosh heavier than spruce and a bit lighter than fir BUT
stronger than either. Just an idea and a big money saver.
Corky in cold Louisiana
In a message dated 12/27/04 2:00:27 AM, pietenpol-list-digest(at)matronics.com
writes:
<< some money will
be spent on wing rib material. >>
I built my ribs out of standard douglas fir, obtained from the local lumer
yard( a pretty good one). The ribs, as specified, are very strong - the Beech
staggerwing down the line uses ribs that are half the size of the Piet.
So my pile of 14 ribs weighed almost exactly 5 pounds. Weight is not an issue
here, either. Would it make a lot of difference if the pile weighed only 4
pounds{spruce?}, or as much as 6{birch?)?
I don't know what woods are available in your area - I'd choose something
that is good and available though. I made my decision to use Fir after looking
at
the spruce at AS&S.
I did not install the gussets as I built the ribs - did that later, and there
was no advantage to this. I do have an extra rib, and this has been really
useful.
I used basswood plywood from AS&S, which is light and glues really well, and
would use this again. I think that it develops the full stregth of the
fir/plywood interface.
Birch or mahogany ply is stronger than my fir, but the gussets would have to
be larger to be stronger, as the fir or spruce is the limiting factor.
I soaked the rib stock in hot water for five minutes, then bent them in a jig
with a slightly sharper curve, and let them dry for a day or two. Worked
swell, none cracked or broke (but I had tested the material dry by bending it,
and some pieces did break..).
If you don't have a planer, now is the time to get one. You will really
appreciate what it can do for you.
Carl Lekven, Compton Airport, CA
For any Pieters that are in N. Florida area and still looking for wood. I
brought down to FL this year approx. 300 Board Ft of Kachemak Bay AK Sika
Spruce directly from the sawmill. It's mostly 3/4" by 4" to 6" wide by 8'
long. A few pieces 1.5" by 6" wide by 8' long. Knot free, dried 1 year
min. It's in standing in the hanger Palatka FL(28J). $3.50/bf
(12"x12"x1"), this is about 1/5 of what ASpruce charges. Above sizes are
full cut actual sawmill medium finish, you'd need a planer and ripsaw for
your work. If you're interested you can contact me directly, I intend to
bring down from AK a few hundred BF each Nov.
Gordon Bowen
Original Message:
Date: Mon, 27 Dec 2004 13:15:58 EST
Subject: Pietenpol-List: Rib material
writes:
<< some money will
Beech
issue
looking at
the spruce at AS&S.
there
useful.
and
to
jig
it,
Just a question on your comment that pine would be stronger than fir. Here in
Oregon our main fir is Douglas Fir, and our main pine is Ponderosa--and Douglas
Fir is definitely stronger than Ponderosa Pine. Which species of pine and fir
are available in your area? I used Western Hemlock for my ribs and it was good
stuff to work with.
Mac in Oregon
Sent: Monday, December 27, 2004 8:59 AM
Subject: Re: Pietenpol-List: back to the piet finally
Pieters,
sitka spruce for various parts of the two Piets I've built. Reading of your inquiries
pertaining to woods for ribs I really think if I were ever to do it again
I would buy some 12 ft 2x4 #1 clear pine and rip it to dimensions. It wouldn't
be but a skosh heavier than spruce and a bit lighter than fir BUT stronger
Sorry Mac,
In Louisiana we refer to pine as Southern Pine. It has strong grains as
spruce and make very nice, strong Piet ribs.
Thanks for clearing that up. I guess I have heard of Southern Pine, but I think
it was in reference to flooring--so it must be tough.
Mac in Oregon
Sent: Monday, December 27, 2004 11:09 AM
Sorry Mac,
In Louisiana we refer to pine as Southern Pine. It has strong grains as spruce
I bought some nice 2X6 spruce boards of different
lengths up to 16'. After cutting out the material and
pruning out the knots, I had lots of material to build
with. I picked out quarter sawn pieces to get good
grain orientation. The ribs are very light and very
strong. I paid like 6-7 dollars per board. I like
spruce, it is very easy to work with.
Doc
http://my.yahoo.com
Subject: | Torque tube question |
Concerning the two collars in the from of the torque tube, one is
welded to the torque tube and the front one is shown riveted. Question
is can the front collar be welded also? Any ideas why a rivet is
specified here?
Rick Holland
Richard
Take a look at clothes dryer wheel they are lignt and rugged.
I didn't see you on the ice iceboating today.
Dale Johnson
Subject: Re: Pietenpol-List: Tailwheel
also.
Dick N.
I want to build my own tailwheel -- don't want to use a tailskid. Would like to
Should I use Bernie's design for the strut and attachment but simply attach a
plywood from Home Depot. Stuck a little piece in boiling water -- after two hours
Hope you all had a nice Christmas! And will have a happy New Year! "Here's to the
Fred B.
From: | "Tom Stinemetze" <stinemetze(at)mpks.net> |
Subject: | Don't Scare Me Like That |
Fellow builders. I assume that the majority of you =93Piet-Nuts=94 out
there have purchased at least some of your materials from Aircraft
Spruce and Specialty Co. (ASS) =96 abbreviation used with no derogatory
intent
My two sons got together and purchased a Christmas present for me that I
still can=92t believe. It was the complete spruce kit from ASS and,
believe me, I was bowled over. I received the two big packages about
three days before Christmas and really didn=92t have time to look through
the wood until last night. I got in there looking for the =BC=94 x =BD=94 cap
strip stock so I could start making ribs. I did find some cap strip
material in the package, about enough to build two ribs. So, I got on
the phone to find out if there was a problem.
The nice young lady at ASS informed me that cap strip material was not
part of the package. Why not? Because the material that is shipped
varies depending on the engine you intend to use. Oh and by the way it
sells for $8/ft =96 can I transfer you to sales? Now I can understand
that the fuselage stringers might vary in length depending on the engine
used but the plans don=92t say anything about that being the case with cap
strips. In fact, the only wing options I have come across are: 1-piece
or 3-piece. Also, $8/ft seemed a LITTLE high.
Later, after I calmed down a bit, I checked out the ASS web site and
discovered that cap strips of this size sell for $ 0.32/ft. (a
difference of approximately $6,500 vs $150 in materials cost). Now I
hate to say bad things about folks I do not know but this seems a little
over the top.
So, I have two questions for you listers out there:
1) Did your ASS spruce kit include the cap strip material?
2) Have you experienced this level of misinformation when dealing
with ASS?
If the error is mine, please point it out to me. (I wonder what is
really missing from my kit that will cost me $8/ft.)
=91Ol Tom
McPherson, Kansas
____ | ____
\8/
Are you talking about using pine for the ribs only or for the entire
A/C?
Ken
Isablcorky(at)aol.com
Sorry Mac,
My reference was to the inquires of cap strip material. HOWEVER, a Piet made
completely with #1 clear southern pine would not be overweight and would fly
like that Louisiana Pelican.Low and slow
Dick,
What didn't you like about the Matco wheel assy.?
Ted
> From: "Richard Navratil" <horzpool(at)goldengate.net>
be changing
looking
> also.
> Dick N.
the matco is a fairly heavy unit. one could most likely fabricate something
that weighs half as much.
I, on the otherhand, need the tailweight to counter my Corvair installation
so the Matco fits the bill nicely
DJ
> Dick,
> Ted
>> will
> be changing
> looking
>> also.
>> Dick N.
Depending on where you are in Oregon you should be checking
out Port Orford cedar. Find a wooden boat builder in your area.
Not only is it stronger in all respects than Sitka but lighter too.
Western hemlock is excellent and the same strength as spruce.
Averages slightly lighter but some pieces can be heavier.
My entire plane so far, except the doug fir landing gear, is hemlock.
Red pine is significantly both stronger and heavier but eastern white
pine is significantly weaker and lighter.
Clif, varnishing landing gear.
fir are available in your area? I used Western Hemlock for my ribs and it was
good stuff to work with.
Mac in Oregon
Subject: | Re: Don't Scare Me Like That |
Tom
The AS wood kit doesn't include capstrip. I attached the parts list
for the wood kit AS sent me. Many people just use cedar or douglas fir
for capstrip anyhow and save some money.
Rick H
> Fellow builders. I assume that the majority of you "Piet-Nuts" out there
> have purchased at least some of your materials from Aircraft Spruce and
> Specialty Co. (ASS) =E2=80=93 abbreviation used with no derogatory intent
> still can't believe. It was the complete spruce kit from ASS and, believe
> me, I was bowled over. I received the two big packages about three days
> before Christmas and really didn't have time to look through the wood until
> last night. I got in there looking for the =C2=BC" x =C2=BD" cap strip stock
so I
> could start making ribs. I did find some cap strip material in the package,
> about enough to build two ribs. So, I got on the phone to find out if there
> was a problem.
> The nice young lady at ASS informed me that cap strip material was not part
> of the package. Why not? Because the material that is shipped varies
> depending on the engine you intend to use. Oh and by the way it sells for
> $8/ft =E2=80=93 can I transfer you to sales? Now I can understand that the fuselage
> stringers might vary in length depending on the engine used but the plans
> don't say anything about that being the case with cap strips. In fact, the
> only wing options I have come across are: 1-piece or 3-piece. Also, $8/ft
> discovered that cap strips of this size sell for $ 0.32/ft. (a difference
> of approximately $6,500 vs $150 in materials cost). Now I hate to say bad
> things about folks I do not know but this seems a little over the top.
> 2) Have you experienced this level of misinformation when dealing with
> ASS?
> If the error is mine, please point it out to me. (I wonder what is really
> 'Ol Tom
> McPherson, Kansas
> ____ | ____
> \8/
Rick Holland
Subject: | RE: Don't Scare Me Like That |
From: | "Christopher Friel" <cjfriel(at)ucdavis.edu> |
> with ASS?
ASS specifies that <65hp uses 1/4 x 1/4 cap strips and >65hp uses 1/4 x
1/2.
I bought my wood from ASS. The only bad experiences that I have had
building my piet was dealing with customer services. Needless to say, I
did not get cap strips. Also, you will need to pick up wood for the
leading and trailing edges. The wood that i did recieve was top notch but
I don't feel that ASS deserves too much credit; after all, I payed a
bundle for it; I expected nothing less. While it would be contrary to the
holiday spirit to bellyache much more about it, you could still check the
archives and you will find plenty of gripes about ASS. The bright side is
that this list is full of resources including alternate sources of supply.
I got my cap strips from Wicks and my plywood from Noah's marine and
Boulter plywood. A very pleasant and more affordable experience.
Good luck on your project.
Chris Friel
Davis, CA
Subject: | Max crossind in a GN-1... |
report
What type of crosswind will generally keep you guys on the ground, assuming you
will be landing on concrete? I'm going to be flying a GN-1 before long, and
would like to get an idea what some other people are doing. Also, how much
more crosswind will you tolerate when landing on grass?
The plane I'll be flying has a tailwheel, not a skid. What kind of difference
will a skid make on concrete?
Thanks for the help!
Steve Ruse
Dallas, TX
<005f01c4ecab$90d5a5e0$4e705118@dawsonaviation>
Hello again. I do have some Port Orford Cedar 2X6's that I traded a load of logs
for 20 years ago. I've been hoarding it because I also have spruce trees so
just cut my own spruce for larger pieces (fuselage etc.). I should use the
cedar but it is almost too pretty to cut.
Mac in Oregon
Sent: Monday, December 27, 2004 11:05 PM
in Oregon our main fir is Douglas Fir, and our main pine is Ponderosa--and Douglas
Mac in Oregon
Hi Mac,
Are you a logger? That is what my son and I are doing
right now. Wish I had some nice spruce to cut. Our
logs are all oaks and hickory, of which neither is
very good for building an airplane with, it might be
strong, but it would fly like a lead sled. :)
Doc
Subject: | Re: Max crossind in a GN-1... |
Steve, a tail skid on concrete is a ground-loop just
waiting to happen. Grass is always more forgiving
(especially in tailwheels) than hard surfaced runways.
I have found it much easier to land a tailwheel in a
cross-wind by doing a wheel landing rather than a full
stall landing. By doing so, you can better keep the
ailerons turned into the wind and land on the up-wind
wheel first. Believe me, if you have a choice of
whether to land on a hard surface vs. grass in a
cross-wind, always select the grass. This works for
all tail-wheel airplanes I've flown (and that is well
over thiry or so). The tail skid works very well on
grass as it works like a tiller and holds the plane
straight on landing. But on a hard surface runway,
the skid will not bite into the surface and will
become a real liability when the plane begins to yaw
and you don't have enough rudder to hold her. If you
haven't done so, my suggestion would to get some
tailwheel dual first. It will pay off in the long
run. Fixing broken airplanes can get pretty
expensive. One other point--you're not a real
"tail-dragger" pilot until you have flown a tail skid.
Happy Landings...Always.
Doc
> grass?
> Steve Ruse
> Dallas, TX
> Contributions
> any other
> Forums.
Subject: | piet ribs - material specs |
Thanks guys for your comments on the piet ribs...
I can't find my guidelines on wood for the rib material - does it need to follow
the same guidelines as the spar? IE: grains per inch, slope, knot size, etc...
Tom B.
Hello. No, I'm not a logger but I do have 10 acres of mixed fir, spruce,
and alder timber that I cut a bit now and then and have a self-loader come
and haul out a load. I have some spruce that are about 5' in diameter that
I hope will provide some good aircraft wood some day. I wish I had some of
the "prettier" woods that you have for building cabinets and furniture,
although I did do all the trim in my house from my own alder--I made boards
with a chainsaw and my neighbor has a small planer.
I hope you are making good progress on your project. I have my Piet framed
up and now have to find a place to assemble it for installation of controls,
landing gear, engine, etc.
Mac in Oregon
> Hi Mac,
> Doc
Mac, I'll trade some fine Red or White Oak, or even
some Black Walnut for some of that wonderful Spruce.
I just love working in that stuff. The oaks and
walnut do make beautiful furniture, but I love
building airplanes more. I've decided to go beyond
the Piet and convert my project into a 75% Curtis
JN-4D that will have some Piet characterics as well as
those of the Standard. I'm back to building more ribs
(I'll need 50 altogether) and I am ready to install
controls and hardware. Glad to see your making great
progress with your project. Best of luck and a Happy
New Year to you all.
Doc
> protection around
> Contributions
> any other
> Forums.
Subject: | Rib Cap Strip Wood |
In a message dated 12/26/04 6:36:37 PM Pacific Standard Time,
tmbrant1(at)netzero.net writes:
> Wondering what's the best place to purchase rib material.
I used select Port Oxford Cedar, from the local lumber yard. Very nice wood
to work with, and ideal for the job. If you're cutting your own cap strip on
the table saw, be sure to cut the entire ship set of cap strip to the same
setting on your rip fence, before removing your rip fence. In other words, cut
ALL the 1/4" dimension, before moving your rip fence, and cut ALL the 1/2"
dimension before moving your rip fence. This way, you won't need a planner. Cut
a lot more than you need, then select from this batch, and remove any defects,
and what's left is the entire ship set of cap strip. This way the entire
ship set of cap strip will be the same dimensions, and it will not give you any
problems in the jig. A few thousands difference in the 1/2" dimension of the
cap strip, will show up in the rib jig, when you butt up the verticals to the
cap strips, and the gussets don't lay perfectly flat.
Chuck G.
In a message dated 12/26/04 1:46:44 PM Pacific Standard Time, TBYH(at)aol.com
writes:
> like to avoid buying a commercial tailwheel assembly. What makes the best
> attach a wheel at the end of the spring steel? What kind of wheel? I think I
> read that one fellow used a hockey puck....Am open to suggestions...
Fred,
I used the plans tail skid for quite a while, even flew to Brodhead & Oshkosh
'03 with the tail skid. Let me tell ya...the skid is a GRASS ONLY tail
dragger. I almost lost it on hard surface, several times !! I'm sure there were
several chuckles from the crowd watching me land at Oshkosh !! When I got
back, I bought a heavy duty 3 1/2" caster wheel from Harbor Freight, and installed
a bronze bushing in it, and installed it on the end of the tail skid, using
the single arm method. The wheel didn't last long. The bronze bushing quickly
wore out and the wheel wobbled a little, even though I kept it lubricated
with grease. The tire came loose a little from the plastic wheel, also. I have
since bought a 3 1/2" wheel from Wicks, with the ball bearings in it, for $16,
and it works fairly well. My only squawk about that wheel is it should have
been a 4" wheel, because in tall grass I have to use differential braking to
make sharp turns. Since I built the axle to the 3 1/2" dimension wheel, I
can't go to a 4" wheel, unless I cut off the wheel mount, and start over.
Chuck G.
Dennis E. , Lynn K., or any one else in the Wichita area -
I'm leaving tonight, to go back to Wichita from Wheeling. I am going to stop
at Wicks, in St. Louis, on Thursday Afternoon, to haul another load of tubing
for the Tailwind home, in my brand new '94 Toyota Celica. That should be a
sight, with all the tubing sticking out the back from St. Louis to Wichita !!
If anyone needs anything delivered from Wicks to Wichita, let me know
what you need, and I'll pick it up for you. Let me know now, and I'll check
my e-mail late this evening.
Chuck G.
From: | "wesley hartson" <wes.shirl(at)webiowa.net> |
"JCPenney" ,
, "Grocery Newsletter" ,
"Famous Dave's" ,
"daily-gibbleguts Confirmation \(from Lyris ListManager\)" ,
"Daily Joke" ,
"Carol Wright Gifts" ,
"Amazin Humor"
report
Our e-mail address is changing.
Replace the old (wes.shirl(at)webiowa.net) with our new
address -- (wes.shirl(at)netzero.com).
This is effective immediately.
Thank You.
S. Hartson
Talk to your Congressman...Isn't that part of what you're paying him
for?..Carl
Subject: Re: Pietenpol-List: aircraft repairman - need info
being
> applied. I have first-hand knowledge that > >
Subject: | Re: piet ribs - material specs |
With this size material, and only 60" long you shouldn't have
any trouble avoiding all knots and runout. Any size knot is
going to affect the curve to some degree. The more grains
the better, 12 to 16. 16 is only 4 in the 1/4" dimension and
8 if you orient them verticaly. Horizontal is better for bending.
Clif
follow the same guidelines as the spar? IE: grains per inch, slope, knot
size, etc...
> Tom B.
Subject: | Re: magneto plug wires |
Pieters, I am having a hard time figuring out how to run the wires from my
mags on a cont A65. The firing order is 1324 and looking from the pilots
seat the rotation to the terminals should be clockwise as they drive off the
crankshaft gear not the camshaft.
I have about 4 cont engine overhaul manuals and when I look at the
wiring diagrams and follow the wires to the cylinders it seems to be 1243.
Anybody know what I am doing wrong?
Ken Conrad in warm December ,no snow, Iowa
You are right that the firing order is 1,3,2,4 for ALL small 4 cylinder
Continentals
Forget the pictures which may or may not be right. The last AD for my
Bellanca was for a picture in the owners manual that showed the aileron
cables wrong. This was over 50 years after it was first published.
Evidently someone used it to rig and crashed.
Remember that right mag does the top plugs and the other the bottom plugs.
They are not split like Lycomings.
If you run your engine as an A-75 at a faster speed of 2600 instead of 2300,
the book recommends a small timing change. Hope that you have the big rod
ends drilled for squirt oil. Makes a big difference in longevity plus you
can run it faster for the additional 10 HP. Have to use a flatter pitched
prop is the ONLY change necessary.
Remember that if you run the plug wires in the wrong order. If it runs, it
will miss like crazy. Been there, done that..
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
Subject: Pietenpol-List: Re: magneto plug wires
my
the
Hi Pieters, I'm back with another dumb question.
The original Piet plans show 1 inch thick spars with routed sections to
save weight. The full-size rib pattern from BHP shows 1 inch thick
spars also. The three piece wing supplemental sheet calls the spars
three quarters of an inch. The Piet wood kit I received from Aircraft
Spruce contains spars that are three quarters of an inch. Since I am
building my wing rib jig now, I need to know which width to set it up
for and whether to contact ASS for a spar exchange. HELP!
'Ol Tom
McPherson Kansas
____ | ____
\8/
From: | Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov> |
In Tony Bingelis's book Firewall Forward he notes that you hook up the
spark plug wires
to the cylinder to fire next so the firing order of your Continental is
1-3-2-4 (those are cylinder numbers
not plug wire numbers) so the first one to fire happens to be cylinder #1
the second one to fire
is cylinder #3, the third one to fire is cylinder #2, the fourth one to
fire is cylinder #4.
Hope this helps, Ken !
Mike C.
Charlie Rubecks is located in Spencer, IN. I don't have a phone or address. I
purchased a set of ribs from Charlie this past summer at Brodhead. He uses
Port Orford cedar. Very nice ribs. While I can build ribs, they wouldn't be
nearly as nice or as uniform as Charlie's and it would take me two months to build
the 31 ribs for a 3-piece wing. Charlie's are like works of art and I will
feel badly covering them up in the wing...and by the way, I asked a fellow at
Brodhead if $300 was a good deal. Dumb question. He replied that he'd be happy
to build me a set -- for $900! Charlie is building these things at less than
minimum wage rates! He deserves and probably could get much more.
Anyway, that's my rationale for purchasing the ribs from Charlie -- and he
showed me in careful detail how to attach leading and trailing edges.
Got back from Wicks (Highland, IL) last night with some plywood for my Piet's
floor and sides. Wow that's a long drive from Wisconsin! I don't think those
Illinois maps are the correct scale north-south-wise! Wonderful folks. And if
you visit them you must take a tour of their pipe organ factory! Wicks has
been building pipe organs since 1906 or so.. Talk about craftsmanship and just
plain a fascinating process to see...would love to have one of those free
shopping sprees in their wood crib (they use lots of Sitka spruce)!
Oh, get breakfast at Buzzies just around the corner when visiting
Wicks...great food, good service, reasonable prices -- don't mind the railroad
memorabilia. In fact, every time one of us aviator types goes there we should give
them
some airplane pics and signs and help them redecorate...so what if they're
right next to the RR tracks...
Fred B.
Ken,
Once you have determined the direction of rotation of the magneto
distributor rotor and identified the #1 lead outlet, the magneto sparking
sequence will be 1-2-3-4 in the direction of rotation, starting from #1
outlet. On your A-65, the rotor will turn to the right (as viewed from the
rear of the engine).
The firing order of your Continental A-65 is, as you have noted, 1-3-2-4.
Run the ignition leads from #1 distributor outlet to #1 cylinder, #2
distributor outlet to #3 cylinder, #3 distributor outlet to #2 cylinder and
#4 distributor outlet to #4 cylinder.
As Cy says, the left magneto (as viewed from the rear of the engine) fires
the lower plugs and the right magneto fires the upper plugs.
Hope this helps.
Graham Hansen (In Alberta, Canada where it is snowing and too cold to be
fooling around with Pietenpols.)
Subject: | Re: Spar Thickness |
Tom,
It's builders choice. The 3/4" solid spar is easy, simple and equally strong as
the original routed 1" spar.
If you want to experiment with built-up spars using plywood webs and spruce or
fir flanges then you'll want to build your ribs to handle 1" spars.
If you already have the 3/4" spar material then use it, don't complicate your life.
I have a good article from an early '60's Sport Aviation on designing built up
spars. I'll send out a copy to anyone who sends a self-addressed, stamped envelope
to:
Greg Cardinal
5236 Shoreview Ave. So.
Minneapolis, MN 55417
Sent: Thursday, December 30, 2004 10:22 AM
Subject: Pietenpol-List: Spar Thickness
The original Piet plans show 1 inch thick spars with routed sections to save
weight. The full-size rib pattern from BHP shows 1 inch thick spars also. The
three piece wing supplemental sheet calls the spars three quarters of an inch.
The Piet wood kit I received from Aircraft Spruce contains spars that are
three quarters of an inch. Since I am building my wing rib jig now, I need to
know which width to set it up for and whether to contact ASS for a spar exchange.
HELP!
'Ol Tom
McPherson Kansas
____ | ____
\8/
Subject: | Re: Rubecks Ribs |
DNA: do not archive
Its-Bogus: do not forward to list
--- MIME Errors ---
A message with no text/plain section was received.
The entire body of the message was removed. Please
resend the email using plaintext formatting.
NOTE! This error can also occur when the poster of the
message has a specific type of computer virus. This virus
WAS NOT forwarded on to the List. The poster should be
informed of the potential problem with their system as soon
as possible.
--- MIME Errors ---
<001701c4ec92$6a01cde0$d7384e0c@TedB>
Hi Ted
The Matco with spring assy is too heavy, if I can save 5 lb back there
then I can eliminate the 30 amp battery on the firewall. Also there is a
bit of play in the spring/wheel assy which will give the wheel some
ability to lean one way or another could be a problem in controll.
I'm down in your area now for a couple of weeks sailing to the Keys. Any
Piet events coming up around here?
Dick
> Dick,
> Ted
>> will
> be changing
> looking
>> also.
>> Dick N.
Dale
Keep the Ice nice and slick for me. I'll be home in a couple of weeks.
How did your inspection go? I didnt see a post on it and wasnt able to
get to the last EAA meeting.
Dick
> Richard
> Dale Johnson
> From: Richard Navratil
> Sent: 12/26/2004 5:29:49 PM
> be changing it over the winter. I am going to the design in the plans
> with a much lighter wheel. Keep us posted on what you find for a wheel, I
> will be looking also.
> Dick N.
> From: TBYH(at)aol.com
> simply attach a wheel at the end of the spring steel? What kind of wheel?
> I think I read that one fellow used a hockey puck....Am open to
> suggestions...
> after two hours I peeled it apart like a banana! Not that any Piet would
> be exposed to boiling water for 2 hours, but I won't be using that stuff
> in my plane...
> to the duck that swam in the lake and never lost a feather -- may this
> time in another year we'll still all be together..."
> Fred B.
From: | "Richard Schreiber" <lmforge(at)earthlink.net> |
I just finished the rest of the welding on my torque tube and can't seem to get
it to fit. From previous posts I new this was a problem so I mocked up the torque
tube with wood and plastic. The fit was going to be tight but seemed to work
out. Unfortunately the real thing wont fit. I know that Walt Evans and a couple
of others have notched the rear seat to clear the rear pulley support, but
I hate to do this if their is another solution. Has everyone else run into
this same problem or is it just me? If you have what were the solutions? It looks
like if I make the side leg openings in the front seat wider than the 6 inches
shown on the plans, it may allow the aileron horn enough clearance to get
the torque tube in, but I don't want to hog out more wood if it doesn't work.
Richard Schreiber
Subject: | Final Inspection |
Hi Dick,
Dale and I had to re-submit our paperwork to
the MIDO office because they lost the first
package.
I'm meeting with the FAA guy next Tues. or
Wed. The inspection should happen shortly
after that.
Lesson learned? If you live within driving
distance of your local MIDO office, hand
deliver the paperwork. We would have been
flying by now.....
Greg Cardinal
> Dale
> Dick
nk.net>
As promised, Charlie's mailing address on the crates is:
Charles Rubeck
RR7 Box 520
Spencer, Indiana 47460
Jim
>Charlie's phone number is (812) 829-2069.
>His address is:
>Charles Rubeck
>12225 S Rd
>I saw a set of Charlie's ribs at the fly mart at the Sun & Fun this year.
>I would have bought them then, but I'd flown to the show (commercially, as
>a passenger) and had no good way to get them home. I asked around and
>found Charlie working in the (where else?) woodworking workshop.
>I bought a set from him a couple months ago. They arrived well-packed and
>intact. Well-packed is really an unfair understatement; they were
>beautifully crated in two different hand-made wooden boxes, and the ribs
>were snugly fit inside with foam padding all around. I've never seen
>anything as well-packed. The ribs themselves are beautiful, and he also
>included some of the little rib-related parts (I'm assuming they're
>aileron ends), and a handful of pairs of small chunks of wood, which I'm
>guessing are glue samples (Charlie uses T-88). I asked if the $300/set was
>enough, and that's all he wanted. I felt like I robbed him. In addition to
>the $300, Charlie asked for an additional $25 for crating (also a steal),
>and I paid his UPS costs as a COD.
>(The above address is the one I hand-wrote on his business card way back
>when. I'll verify it's the same as the one on the crates tonight).
>Jim Ash
>Sent: Dec 30, 2004 11:29 AM
>Subject: Pietenpol-List: Rubecks Ribs
>address. I purchased a set of ribs from Charlie this past summer at
>Brodhead. He uses Port Orford cedar. Very nice ribs. While I can build
>ribs, they
>Forums.
Subject: | New Pietenpol Forums |
I've started a new aircraft homebuilding forum at http://www.WingsForum.com
"They" say that a picture is worth a thousand words. The ability to attach
spreadsheets, documents, and CAD files can speak volumes.
I am not asking anyone to leave this list. I'm just offering an additional
resource that will offer easily accessible photo and data file content
intergraded with the message threads. http://www.wingsforum.com also has
form based email and private messaging that will nonpublic communications
while protecting your email address from SPAM email harvesters.
http://www.WingsForum.com was created because the email based groups just
can't compete with the forum format for organization of topics, searching
information already covered by a group, and relevancy of information
presented. I can't tell you how many HOURS of my life have been wasted
scrolling through off topic threads and information irrelevant to my search
on Yahoo and MSN groups. Lets face it, if you are looking for info on your
spar why should you need to scroll through 30 email post on firewalls 5
about rudders and 2 about nothing at all?
At http://www.WingsForum.com you will find topics well organized, pictures
and relevant files directly attached to their post, private messaging, and
more all on one site. Forum membership is, and will always be, FREE. Try
in out, it cost nothing, and you just might like it. If you don't like it
just let me know how I can improve the site.
Email Digest are available for those who prefer them. You can customize
them for what forums you want to watch, if you want a short excerpt or full
messages of up to 36,000 characters, and what time of day they will be
delivered to you. Users just click the Digest link at the top of the page
once logged in to enable them.
Thanks for your consideration,
Sean C. Caranna
Subject: | Re: Repairman Certificate Tirade |
> Hello everybody. I was able to work out my problem in a rather
unconventional way. It seems that the Tampa FSDO was extremely helpful
after all. I , as some of you remember, had been told I was required to
make a 8 hr round trip to Tampa FSDO to be "interviewed" and signed off for
my repair man certificate. This after I payed a DAR $400 to inspect my
plane. When I asked why this was happening and relayed that my adjoining
FSDO (Atlanta) was not requiring this, I was told "because our manual " says
we do it his way. Paraphrased of course. Well I've been on a tirade for
two weeks about the inconsistent application of FAR requirements, use of
DARs, bureacracy, the weather, anything else I could bitch about. As it
turned out a very helpful person from the FAA arranged a meeting at a thrird
location nearer my fair city. We exchanged my drivers license ( I proved I
am who I am) for the official FAA sign off and I now possess a repairman's
certificate for NX327BC without having to drive to Tampa for the 2 minute -
26 second ordeal. I might add that they WERE helpful after all - once I
complained and showed my rear end.
So as you all approach your inspections, contact your FSDO and talk with
them. They are (or can be) very helpful.
I practiced high speed (how high speed can you get in a Grega/Piet) taxiing
today till I got tired of it. At one point she got tired of the ground and
decided to take off. No surprises. I simply pulled power kept directional
control with the rudder and let her settle right in on all three. I am
amazed at how stable the Grega is. With the wide landing gear, it's just
NOT a problem on the ground or during transition. The Piet I have flown had
a narrower gear and was way more squirrely.
Well happy New Year everybody - Talk next year!
Bert
http://bconoly.tripod.com/
Subject: | Re: Torque Tube fit |
Richard,
When you say your torque tube does not fit just where does it not fit? I had no
trouble placeing mine in for a temporary trial fit. I have not as yet placed
the rudder bar as I am not sure as just what the distance from the seat front
support it should be positioned. Other than that, Where is your problem?
I may have a problem and not know it.
Happy New Year.
Alex S.
Richard Schreiber
Richard,
I had no trouble placeing mine in for a temporary trial fit. I have not
as yet placed the rudder bar as I am not sure as just what the distance from
the seat front support it should be positioned. Other than that, Where
is your problem?
Happy New Year.
Alex S.
get it to fit. From previous posts I new this was a problem so I mocked up the
torque tube with wood and plastic. The fit was going to be tight but seemed
to work out. Unfortunately the real thing wont fit. I know that Walt Evans and
a couple of others have notched the rear seat to clear the rear pulley support,
but I hate to do this if their is another solution. Has everyone else run
into this same problem or is it just me? If you have what were the solutions?
It looks like if I make the side leg openings in the front seat wider than
the 6 inches shown on the plans, it may allow the aileron horn enough clearance
to get the torque tube in, but I don't want to hog out more wood if it doesn't
work.
Richard Schreiber
Subject: | Aileron control horn and stops |
I saw a picture of a Piet cockpit with an extreamly simple aileron
control stop, it was two small wood blocks glued to the cockpit floor
under each end of the aileron control horn. Can anyone think of a
problem with this? And a question for you folks with flying Piets,
what is the distance between the floor and the ends of the aileron
control horn at full aileron deflecttion?
Rick Holland
Subject: | Re: Aileron control horn and stops |
Rick,
That pic could have been mine. Just glued an ash block to the deck under
the horn arm, with a piece of leather glued to the top of each. The height
was determined by the horn hitting the stop just before the aleron
contacted the bottom of the wing.
My inspecting DAR liked it. Said it was simple and couldn't fail. (He is a
pylon racer in a Cassutt Racer)
walt evans
NX140DL
----- Original Message -----
Subject: Pietenpol-List: Aileron control horn and stops
> Thanks
> Rick Holland
Howdy, folks;
Well, the Piet is at the welder's today, in line for cabane strut and
landing gear repairs. Made the 200 mi. trip on a trailer behind my wimpy
little Pathfinder yesterday, but it was worth it for all the stares I got.
Anyway, my question is on the Scott 2000 tailwheel, which is the small one
with a single "arm" (no fork), solid tire, steerable but with "break-over"
free swivel. It's developed a shimmy and seems to have lots of play in the
free swivel mechanism. Looking at the price of a replacement arm assembly,
it's $169, which makes most of us Pieters pause to see if we really need to
spend that kind of money for something. Anybody know if these things can be
taken apart and worked on, or am I going to have to just pay the $$ for the
replacement? I already know about using different springs on the L and R
tailwheel steering chains and will try that prior to taxi tests, but the
mechanism does seem to have excessive play anyway. Thanks, and Happy 2005!
Oscar Zuniga
San Antonio, TX
Subject: | Re: Scott tailwheel |
Oscar, I've disassembled Scott tailwheels before and
there are quite a few parts in them. Just keep up
with where everything goes. It could be berings
making it shimmy. Might neet to replace them. I sure
would try working on it before I spent all that money.
Some catalongs (I think WagAero for one) has a diagram
showing the parts and where they assemble, this could
be of great help. Hope it works out for you. How old
(worn) is the tailwheel? Happy New Year to all.
Doc
> Contributions
> any other
> Forums.
> http://www.matronics.com/subscription
> http://www.matronics.com/FAQ/Pietenpol-List.htm
> http://www.matronics.com/photoshare
It's not the tail wheel . you need anti shim springs on your tail wheel.
In a message dated 1/1/05 11:35:38 AM Central Standard Time,
at7000ft(at)gmail.com writes:
<< I saw a picture of a Piet cockpit with an extreamly simple aileron
control horn at full aileron deflecttion? >>
Rick,
For my aileron stops, I use the inside of my thighs !! There is No Way, I
could go full aileron stick, with my feet on the rudder bar. If I move my leg,
and go full stick, so the bottom of one aileron touches the aileron spar,
there is probably 1/8" or 3/16" between the horn on the stick, and the floor.
Chuck G.
In a message dated 1/1/05 4:32:54 PM Central Standard Time,
taildrags(at)hotmail.com writes:
<< my question is on the Scott 2000 tailwheel, which is the small one
mechanism does seem to have excessive play anyway. >>
Oscar,
If the top of the vertical axis of the pivot, is pointing too far forward, it
will cause a shimmy, and could be what wore out the bearings. That's what
happens to shopping carts...someone bangs it into the curb, bends the caster,
and that's the cart I seem to always pick.
Chuck G.
In a message dated 12/30/04 10:22:26 AM Central Standard Time,
stinemetze(at)mpks.net writes:
<< The Piet wood kit I received from Aircraft
for and whether to contact ASS for a spar exchange. HELP! >>
Tom,
Set up your jig for the 3/4" spars, and use the quarter sawn, straight grain,
spars that you have.
Chuck G.
carry on your ok with 3/4" spars
Subject: Re: Pietenpol-List: Spar Thickness
> Tom,
> grain,
> Chuck G.
replace brass inset bearings are fine put antishimmy springs on !
Subject: Re: Pietenpol-List: Scott tailwheel
> the
> assembly,
> to
> be
> the
> Oscar,
> it
> caster,
> Chuck G.
Subject: Re: Pietenpol-List: Aileron control horn and stops
> Rick,
> leg,
> floor.
> Chuck G.
Caution
3/4 spars ok however make your spar positions on the rib jig adjustable for
3/4 and 1" spar openings to accomodate the root ribs, center plate and outboard
ribs which fit over the spar and spar plates and steel lift fittings. 3/4 +
1/8 + 1/8 = 1"
Just a caution. If building the 3 pc wing this will require 8 ribs of 1"
opening.
Carve necessary clearances for steel.
Corky in humid Louisiana but happy to be a part of this new year.
In a message dated 1/2/05 9:00:19 AM Central Standard Time,
Isablcorky(at)aol.com writes:
<< Caution
outboard
1/8 + 1/8 = 1"
opening.
Carve necessary clearances for steel. >>
Very good point !! Another consideration might be to alter the size of the
aft gusset of the rib that is at the inboard end of the aileron cut out. Or,
you could just install the extended gusset while you are building the ribs,
which would mean you have a R/H and a L/H rib in that location.
Build new rib jig, so that the gussets and the upright x next to the
spars, are spaced 28 1/16" to 28 1/8" apart. This should be the exact
dimention between the spars, with the exception of the 3 center ribs, and the
outboard ribs where the struts attach. These locations have 1/8" plywood doublers
on each side of the spar.
On my Model A Radiator installation, I used the center section of the
wing, forward of the front spar, and designed so as to allow the top of the
radiator to be within the wing. Two 1/8" plywood L.E. ribs were spaced evenly
between, and paralell to, R1 and L1. These ribs will accept the 1/16" plywood
L.E. (on top), and the 1/32" plywood (within the radiator cavity). I had the
radiator custom built so the top tank was inside the wing, out of the prop
slipstream, and it was the width of the cabanes, and extended down about 12", so
you could see under the radiator.
Hinges are numbered 1 thru 6, beginning on the left wing tip.
Lots of places on the wing needed to be drilled using Granpap's hand
crank drill (chordless !!), because of clearance reasons.
Cable guide blocks were numbered 1 thru 8, starting at the top left.
Jury strut C/L is 37" outboard of C/L of cabane strut attachments. I
estimated the placement of the jury strut attachments by referring to the picture
of the Pietenpol on the 1999 I A M Union Calender.
The 1/8" Plywood doublers, located at the center section and the lift
strut attachments, should have Spaded Ends (football shaped). These doublers
bring the width of the spar to the plans width of 1", and allow the plans
dimentions to be used for all the fittings.
Chuck G.
Subject: | Timeless Voices article |
Here is a Dave Harris article to read:
http://www.timelessvoices.org/news/voiceoftheweek/040206_dave_harris.asp
Alex,
The fit problem I had with my torque tube was due to its length. When I tried to
fit the completed torque tube (Pulley supports and aileron horn welded in place)
the aileron horn and front pulley support hit the front seat back before
I could get the rear of the torque tube to clear the front of the rear seat.
What I finally wound up doing is putting a 3/4" grove with a rotary sander in the
front cross brace of the rear seat. Since the center of my rear seat is removable,
I am going to just rebrace the seat and put a small cover over the hole.
I think this is what others have done in the past that have had the same problem.
The misfit was not off by much, so I am sure that on some Piet's the torque
tube goes in fine.
I spent today mounting my tailfeathers and trying to locate the ideal position
for the elevator bellcrank to get rid of cable slack and rubbing of the cables
on the horizontal stab.
Rick
Subject: Re: Pietenpol-List: Torque Tube fit
Richard,
Happy New Year.
Alex S.
Richard Schreiber
Subject: | General metal working question |
Am starting to work on controls and have a question about the
fabrication of several parts that involve smashing (for lack of a
better term) the ends of 4130 tubing, like the walking beam. Is heat
necessary prior to smashing the ends or do you just put the end in a
vice or beat the hell out of it with a hammer? Most of the pictures I
have seen of these parts leads me to believe that less barberic
methods must be employed.
(Metally and mentally challenged)
Rick Holland
Rick,
Are you building the extended fuselage? That is what mine is and perhaps that
has something to do with it. I have no problem installing my torque tube controls.
Alex
Alex,
tube goes in fine.
Rick
Richard,
Happy New Year.
Alex S.
Richard Schreiber
Rick,
that has something to do with it. I have no problem installing my torque
tube controls.
Alex
Alex,
to fit the completed torque tube (Pulley supports and aileron horn welded
in place) the aileron horn and front pulley support hit the front seat back before
in the front cross brace of the rear seat. Since the center of my rear seat is
removable, I am going to just rebrace the seat and put a small cover over the
hole. I think this is what others have done in the past that have had the same
problem. The misfit was not off by much, so I am sure that on some Piet's the
torque tube goes in fine.
I spent today mounting my tailfeathers and trying to locate the ideal positionfor
the cables on the horizontal stab.
Rick
Richard,
is your problem?
Happy New Year.
Alex S.
work.
Richard Schreiber
Subject: | Re: General metal working question |
Hello Rick,
I am certainly not a metal man, but I would guess that you flatten it cold,
My GUESS!!!
J.C.
Signature of: J.C. Wheeler, The EC-47 History Site.
Subject: Pietenpol-List: General metal working question
> Thanks
> Rick Holland
Rick
No don't do it cold as this may cause cracking of the tubing. Also, don't
just whack it with a hammer. Been there done that. Basically what you want
to do is take some angle iron, I used about a 6-inch chunk of an old bed
frame. Then I cut a 2-inch (ish) slot at the vertex (?) and bent one of the
sides into a gradual curve, probably a 3-inch or so radius. I played with it
until it looked right. Take a mount this in your bench vice, I had to
secure it with some duct tape. I marked where I wanted the end of the
tubing to go on the tape before heating the tube. I then heated the tubing
until it was red hot and squished it in the vice. Worked out nicely but I
ended up with the squished ends a bit wavy. Perhaps if you don't squish
them so far or put in a piece of flat metal in the tub while you a squishing
it might work better. Make the tube longer then you need an cut it after you
squish the ends.
here is a small picture of metal brackets I described
File Squish 1 is the setup to only squish one side of the tubing, like on
the rod connecting the two sticks
File Squish 2 is for squishing both sides of the tubing like on the rudder
bar.
Also you need to read the articles by Tony Bingelis called Making Fittings -
part 1, 2 and 3. They are on EAA's website under the members section on
their website.......look for (also in his books if you own them (if not you
should))
homebuilders
building
articles
basic construction.
or here if it works
http://members.eaa.org/home/homebuilders/building/basics/articles.html
Chris Tracy former "metally" challenged still not metally gifted
Sacramento CA
> Thanks
> Rick Holland
I left off the plywood face on the bottom front of the seat and came up through
the floor. Works great for now. I plan on figuring out some way to make this
piece of plywood removable in the future.
Chris Tracy
Sacramento, Ca
To: pietenpol-list(at)matronics.com
Sent: Sunday, January 02, 2005 2:46 PM
Alex,
to fit the completed torque tube (Pulley supports and aileron horn welded in
the front cross brace of the rear seat. Since the center of my rear seat is removable,
Rick
Sent: 12/31/04 9:44:44 PM
Richard,
no trouble placeing mine in for a temporary trial fit. I have not as yet placed
front support it should be positioned. Other than that, Where is your problem?
Happy New Year.
Alex S.
to get it to fit. From previous posts I new this was a problem so I mocked up
the torque tube with wood and plastic. The fit was going to be tight but seemed
It looks like if I make the side leg openings in the front seat wider than the
work.
Richard Schreiber
Subject: | Re:Pietenpol List: General Metalworking Question |
Rick, thanks for asking the question and Chris, thanks for an answer. I stuffed
two lengths of tube yesterday trying the "cold squish in a vise methood"!!!!!
Mike Green
Romsey
Victoria
AUSTRALIA
From: | "Phillips, Jack" <jphillip(at)alarismed.com> |
Chris's method is what I used and it works well. Look in the EAA's
Aircraft Welding book - it describes exactly how to do this.
I found that it sometimes takes several applications - heat the metal
till it glows orange, then shut off the torch and squish it in the vise.
You can get it about halfway the first time, then heat it again and
squish it almost down to flat. Third time gets it all the way flat.
Then I welded the tip closed.
Jack Phillips
Subject: | Congratulations on your Repairman Certificate and high |
speedtaxi
BERT C......way to go fella with the FSDO people. Finally common sense did
actually rule. Good going and the photos of your high speed-tail up runs
looked
like great fun. Hope the weather cooperates for your first flight.
Mike C.
Subject: | Re:Pietenpol List: General MetalworkingQuestion |
Mike, Rick -- I cold squished (in a nice big vise here at work) both my
rudder bar ends and bellcrank ends.
Mike C.
What alloy are you using? I used 4130 and Pressed it flat with a vice. I
didn't heat it for fear of hardening it to the point of being unable to
drill it for the fittings. 'Nuther question...I have flattened one end of my
rudder bar and I'm in doubt as to how to guarantee that when the other end
is flattened, it will wind up in the same plane as the first. Any
advice???....Carl Vought
Subject: Re: Pietenpol-List: General metal working question
> Rick
want
Test
<004c01c4f157$27c44740$3f375142@Spot>
<002e01c4f1df$0d28df80$9d4fd618@knology.net>
Clamp a stick to the flattened face and eyeball it vertical
to the vice jaws and hold with just a little pressure. hold
a stick or ruler to one vice jaw face and sight the two sticks.
Repeat until both line up. Then squish away.
I have two 3/4" X 3/4" sticks 2' long, one white, one black
hanging on my tool wall. They are known by the ancients as
winding sticks.
http://www.robcosman.ca/RC_Jigs.htm
http://www.tools-for-woodworking.com/browseproducts/Winding-Sticks.html
Clif
Sounds like most people recommend flatening 4130 tubing by simply
smashing it in a vice cold. I will give it a try on some scrap first.
Rick H
> winding sticks.
December 13, 2004 - January 04, 2005
Pietenpol-Archive.digest.vol-eg
